Pietenpol-Archive.digest.vol-nj
March 22, 2014 - March 29, 2014
      > Dan,
      > Here is a positive suggestion:
      > What don't you, Don and Mike Cuy, who all have flying planes that you
      > like, Take a few minutes to walk out to your planes, get the weight and
      > balance form out and type it in here, do I can all it to the data base we
      > have for planes. Please include your axle and tailwheel location, and your
      > pilot weight. If you guys like your planes, then share the data with
      > everyone and let them directly copy your set up if they choose to. Brian
      > sent in a lot of data, but I need to know the weights to put it in the
      > data base.
      > Jack Phillips sent me an email saying his plane is actually in the CG
      > range with his pilot weight and set up, It is useful to others to pick
      > which path to follow if we can get it in the data set.
      > If you don't like the numerical information, just ignore it. A new builder
      > doesn't need to understand every line that Chris and Brian wrote in. I
      > will do the math for them, it is not an issue, I know you guys as pilots
      > can do weight and balance calculations, don't make it sound hard to new
      > guys, it is a simple format with 6th grade math. I don't think flying
      > around out of CG adds to the romance of flight, nor do I see how having a
      > better fuel line ruins every sunset flight.-ww.
      > http://forums.matronics.com/viewtopic.php?p=420825#420825
      This email is free from viruses and malware because avast! Antivirus protection
      is active.
      http://www.avast.com
Date: Mar 22, 2014
Subject: Re: running lean
with carb heat off-the engine is fuel starving. carb heat changes that. n ow how do you fix that?? overhaul the carb. im assuming that you have check ed the mag timing..i had this problem on an o200 on my mong sport. I never figured out what was wrong but sent the carb for overhaul. they found nothi ng wrong but when I got the carb back and installed the motor ran great..so if timing is good compression good fuel to the carb adequqte then that lea ves the carb, if you put the plane in a level flight attitude does it make a difference??=0A=0Ajim=0A=0A=0A=0AOn Saturday, March 22, 2014 8:28 PM, tai ldrags wrote:=0A =0A--> Pietenpol-List message pos ted by: "taildrags" =0A=0ATimed the fuel flow in the 3-point attitude today.- Filled a quart container in 21 seconds, so it's not fuel flow.=0A=0AAdjusted the damper blade in the air box to shut tight ly when carb heat is off, then warmed up the engine and ran it up.- It st ill will not take throttle above 1500 RPM without carb heat on, and will no t run up to full static power without it.- So it's not the carb heat box. =0A=0AI'm thinking more and more that it's an obstructed passageway or some thing in the carb.- I'm rebuilding a core Stromberg and when it's ready, I'll swap it out with the one that's on the engine and we'll see if that's it.- Meanwhile, I'm encouraged that the engine starts very readily and id les well.- As soon as it's running right, it will be ready for annual.=0A =0A--------=0AOscar Zuniga=0AMedford, OR=0AAir Camper NX41CC "Scout&qu ot;=0AA75 power=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://foru =============== ________________________________________________________________________________
Subject: Re: CG vs Wheels Location..emergency situation
Date: Mar 22, 2014
Donna, Please save this for me. Your Lover! Sent from my iPad > On Mar 22, 2014, at 7:46 PM, "Greg Cardinal" wrote: > > Attached is the spreadsheet I use for calculating CG on NX18235. It is an Excel 2007 file. > I can enter any combination of weights and it spits out the CG location. Interesting to see how little the CG changes with varying fuel and passenger weights. > > The numbers briefly: > Empty wt. 616 lbs > Cabanes angled back approx. 3 1/2" from vertical > Axle located 6 1/2" aft of the leading edge. This works well, NX18235 was built without brakes. > > It should be noted that this spreadsheet is unique for NX18235 only. > > Greg Cardinal > Minneapolis > > ----- Original Message ----- From: "William Wynne" <WilliamTCA(at)aol.com> > To: > Sent: Saturday, March 22, 2014 9:52 AM > Subject: Pietenpol-List: Re: CG vs Wheels Location..emergency situation > > >> >> Dan, >> >> Here is a positive suggestion: >> >> What don't you, Don and Mike Cuy, who all have flying planes that you like, Take a few minutes to walk out to your planes, get the weight and balance form out and type it in here, do I can all it to the data base we have for planes. Please include your axle and tailwheel location, and your pilot weight. If you guys like your planes, then share the data with everyone and let them directly copy your set up if they choose to. Brian sent in a lot of data, but I need to know the weights to put it in the data base. >> >> Jack Phillips sent me an email saying his plane is actually in the CG range with his pilot weight and set up, It is useful to others to pick which path to follow if we can get it in the data set. >> >> If you don't like the numerical information, just ignore it. A new builder doesn't need to understand every line that Chris and Brian wrote in. I will do the math for them, it is not an issue, I know you guys as pilots can do weight and balance calculations, don't make it sound hard to new guys, it is a simple format with 6th grade math. I don't think flying around out of CG adds to the romance of flight, nor do I see how having a better fuel line ruins every sunset flight.-ww. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=420825#420825 > > > --- > This email is free from viruses and malware because avast! Antivirus protection is active. > http://www.avast.com > ________________________________________________________________________________
Subject: Jeep Pietenpol motor/ magneto
Date: Mar 23, 2014
I couldn't find a magneto conversion for my 134 jeep motor , so I have been converting a omnix distributor base to match a slick mag. Actually I expected it to be harder than it was, but after cleaning out the innards of the dist, I found it had a nice arm with two dowel pins in place to mount the disk that matches the magneto drive. Then I had to turn a sleeve that fit the distributor case and also matches the magneto mounting ring. I plan to rivet the pieces ive made together to keep them from shifting, then find a good aluminum tig welder to weld it all up. My engine is running smooth now with a totally worn out distributor and burnt up points, so it should run great with a new mag . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420883#420883 Attachments: http://forums.matronics.com//files/magneto_1_337.jpg ________________________________________________________________________________
Date: Mar 23, 2014
Ryan, I can't tell you what people think nor what they do, or do not unders tand when they visit my site...sounds like you can. Impressive.=0A=0A- It 's disappointing that this thread has changed from building landing gear to a debate on the quality/integrity of my DVDs.- Have you seen any of my D VDs? I'm just curious because-you seem to-have a lot of negative things to say about them.- I could be wrong, but it seems to me the only time y ou reply to any of my posts is to belittle, condescend, or otherwise have o ther than positive things to say. You've taken the time to review my websit e and count the-thousands of-words that describe my DVDs.- You have a lso taken the time to make note of the last 30 words on a particular paragr aph and post them to the list. Plus, you have taken time to add up-the nu mber of DVDs on the site, add up the cost and do some math to find a differ ence in price between them and a set of plans. -Sounds like quite the eff ort-just to make negative comments on a set of DVDs you have never seen. That type of energy could be used in a positive manner. I'm surprised you haven't talked bad about the site itself...the colors, the layout, the siz e, etc. (maybe that's coming...)-Are you implying that because I have not built an airplane before, that because I am- not an engineer and because I am not a pilot, that I-therefor can't possibly have anything worth con tributing? Therefor my entire DVD series has no good useful information in them at all?--Uh-huh...=0A=0AI usually let things go, roll off my back. I try to stay focused on the thread and stay respectful of others and what they post. However, there are times and issues that I will not just sit- idly by.=0A=0AI suggest rather than to further clutter up this list, anyon e wishing to discuss this topic further, they should contact me directly. B y phone would be the most productive. I am not looking for an argument, but some 1V1 conversation may clear up some misconceptions.=0A=0AIf God is you r co-pilot...switch seats.=0AMichael Perez=0APietenpol HINT Videos=0AKareta ker Aero=0Ahttp://www.karetakeraero.com/ ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: widening jig
Date: Mar 23, 2014
Hey Gardiner, You could add washers one by one to the jig until your mount tubes are correctly spaced, or close. Then tack the thing together and remove it from the jig. Bolt it onto the firewall and if you have to move some things around a bit, just cut the tacks. Once it's bolted on, re-tack and add lots of small tacks everywhere so it can't warp. You should then be able to finish the welds away from the firewall easily. you could then conceivably cover up the planes front-end with a welding blanket if you are tigging and do a lot of the welds at that end of the mount. Or just make put lots of tacks so it can't shift around and finish them off the plane. If you're gas welding, you'll have to obviously be more careful about the plane, but a welding tarp should protect it. If you have a nose tank, or there's any fuel anywhere around, you shouldn't try this technique. Douwe ________________________________________________________________________________
Date: Mar 23, 2014
Actually, it took more time reading your description of what I did than to actually do it. I read your page selling the videos, the browser provided the word count; you have a listing for your "Total Package", 8 for $170, and Piet plans are $100. I'm not the arbiter of good taste, so I have nothing to say about the design. I am not implying that because you have never built an airplane before, are not an engineer, or a pilot, you have nothing worth contributing, or that your videos may not contain useful information. I am making a statement on the incongruity of a person with those credentials marketing and selling (at least on your website, Barnstormers, and in the BPA newsletter) an extensive collection of "builder hints and step by step procedures" on how to build a Pietenpol. On Sun, Mar 23, 2014 at 9:09 AM, Michael Perez wrote: > Ryan, I can't tell you what people think nor what they do, or do not > understand when they visit my site...sounds like you can. Impressive. > > It's disappointing that this thread has changed from building landing > gear to a debate on the quality/integrity of my DVDs. Have you seen any of > my DVDs? I'm just curious because you seem to have a lot of negative things > to say about them. I could be wrong, but it seems to me the only time you > reply to any of my posts is to belittle, condescend, or otherwise have > other than positive things to say. You've taken the time to review my > website and count the thousands of words that describe my DVDs. You have > also taken the time to make note of the last 30 words on a particular > paragraph and post them to the list. Plus, you have taken time to add > up the number of DVDs on the site, add up the cost and do some math to find > a difference in price between them and a set of plans. Sounds like quite > the effort just to make negative comments on a set of DVDs you have never > seen. That type of energy could be used in a positive manner. I'm surprised > you haven't talked bad about the site itself...the colors, the layout, the > size, etc. (maybe that's coming...) Are you implying that because I have > not built an airplane before, that because I am not an engineer and > because I am not a pilot, that I therefor can't possibly have anything > worth contributing? Therefor my entire DVD series has no good useful > information in them at all? Uh-huh... > > I usually let things go, roll off my back. I try to stay focused on the > thread and stay respectful of others and what they post. However, there are > times and issues that I will not just sit idly by. > > I suggest rather than to further clutter up this list, anyone wishing to > discuss this topic further, they should contact me directly. By phone would > be the most productive. I am not looking for an argument, but some 1V1 > conversation may clear up some misconceptions. > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > http://www.karetakeraero.com/ > > ________________________________________________________________________________
Date: Mar 23, 2014
I think-the disconnect is that-my DVDs showcase how-I-am building -MY plane, not how to build-THE plane.-If that is the way people perc eive my website and ads in the BPA, etc. I need to address that.=0A=0AIf Go d is your co-pilot...switch seats.=0AMichael Perez=0APietenpol HINT Videos =0AKaretaker Aero=0Ahttp://www.karetakeraero.com/ ________________________________________________________________________________
Subject: W&B info to Ryan M. please
Date: Mar 23, 2014
Builders, Here is a positive suggestion: All of you guys who would like to contribute your data to the W&B project should read the original articles to understand the format we used, and then send your data to Ryan by email and let him process it in a way that allows your contribution to be read by a new guy as a continuation of the original data set. How we measured the length of a motor mount for example (firewall to prop flange) and how we spoke in terms of distance from firewall to LE rather than inches of rake on the cabanes. Is a little different, but Ryan and I came to this for a reason after considering several systems. in most cases, you can take any info set and put it in these terms with simple addition and subtraction. The terminology that Ryan and I used comes into play, not when looking at one plane, but it is very useful when teaching a new builder how to alter a close example of a plane like his, to make his own plane suit his needs and goals. I thank guys in advance for contributing and putting it in the helpful format. A crucial element of our system is the computer algorithm (math formula) that Ryan developed that quickly spits out the maximum pilot weight that the plane can take before getting to the 20" aft limit. This is very importiant, because if you are a 165 pound guy with a data set and your plane is flying at 18", it is very hard for a 215 pound new guy to eyeball that and tell if he builds a clone of the plane if he will be in CG. With Ryan's program, this is immediately known. This is the single biggest reason for using the format. I did not want the project to be a one time deal. The concept that set data set can get bigger is good. Perhaps the additions can be published in the same format, written up by Ryan for the newsletter? Ryan is friends with Mr. Hofman, so this should work smoothly. There are a lot of people who get the newsletter who are not on this list, and the new contributions would expand the knowledge base and assist builders way into the future in the newsletters. It is a good feeling to have contributed to something lasting, something that will help other builders, many of whom you will never meet, but they will be thankful just the same. -ww. -------------------------------------------- This is the last post for a while, we are prepping 16 hours a day from here until Corvair College #29, and then back to 10-12 a day until Brodhead. I hope to see many of you there. Dan Weseman, the guy who designed and built the Corvair powered Panther, on the cover of kitplanes last month, is my neighbor and said he is planning on bringing the plane back to Brodhead just as he did last year. I built the 3,000 cc Corvair in that plane, and you can see it flying aerobatics on youtube. He picked up 24 orders for planes since Oshkosh, and the plane and engine got rave reviews fro the editor of Kitplanes who flew it. It has also got a lot of coverage by the EAA, and will be featured in lots of publications this year. One of the reasons why I want to have the plane at Brodhead is to get a shot of it with the last original, to connect the latest work with Corvairs to BHP, the man that started it. I would like it to be formation air to air. The Panther can do 165mph on the top, but with the flaps down it will fly slower than a Piet. Dan's Company SPA-LLC, which he tooled up to built the kit as a 100% made in North America kit has been about 4 years in the making. He is not yet forty, but has about $200,000 invested in the project, all his own family's money, none borrowed. He purposely selected the Corvair as the best engine for the plane. It will take others, be it was designed around the Corvair. Everyone who has seen the plane fly thinks it was a very smart move. I find it very ironic that experienced builders and industry people understand the Corvair, but here, where people admire and build BHP airframe designed by the man who started the entire world of flying Corvairs, there are still many people who openly question if the engine can even be made to work. -ww. ------------------------------------------------- Over and out from Mr. NOAC........(nails on a chalkboard) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420890#420890 ________________________________________________________________________________
Subject: Re: Jeep Pietenpol motor/ magneto
Date: Mar 23, 2014
I know this is a simplistic question, but does the Jeep distributor turn the same direction as the Slick mag? -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420891#420891 ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Subject: Weight & Balance Spreadsheet
Date: Mar 23, 2014
Okay, Here is a spreadsheet that I developed to be able to compute weight & balance for a generic Pietenpol. It requires the plane be completed, but it can be used to determine when the wing has been moved back far enough. I have input the values from my Pietenpol, so you will need to just type over those values with the weights and measurement from your own airplane Input values are red, calculated values are blue. The procedure is pretty simple. All of the measurements are made using the firewall as the datum, so you can make most of the measurements with the tail on the ground, which is easier (and safer) than when the tail is supported on a stool or sawhorse. The only measurements that must be made with the plane in level flight attitude are the distance from the firewall to the wing leading edge, and the distance from the firewall to the main gear axle and tailwheel axle. For these three measurements you will need to use a plumb bob and a tape measure. Strive for accuracy, because small variations in distance can have a large effect. You will to measure the distance to the middle of the fuel tank(s) which must be estimated to some extent. You will also need to sit in the cockpit and make note of where your belt buckle is (the belt buckle is very close to the C.G. of a human body in a sitting position), then measure from there to the firewall. Same for the front seat passenger (you will be surprised how little a passenger affects the CG position). If you have a baggage compartment and/or a helmet box, measure from the firewall to the center of those spaces (or, if you really want to be conservative, measure to the back of each of those compartments to get worst case). You will need a good set of aircraft or race car scales. Bathroom scales are worse than useless - most do not go up to 300 lbs and unless you have built your airplane exceedingly light, your main gear wheels will weigh over 300 lbs eac. Besides, bathroom scales are notoriously inaccurate - particularly at the extremes of their range. While building mine I weighed it several times with digital electronic bathroom scales. My estimated weight turned out to be within 80 lbs of my finished weight on aircraft scales. You need better accuracy than that. Position the plane in level flight attitude on the scales after setting the tare to include the weight of any supports and chocks that are on the scales. Enter the data in the spreadsheet and then input weights for pilot, passenger, fuel and baggage. The spreadsheet will calculate the CG position with respect to the firewall, the CG position with respect to the wing leading edge, and the CG position as a percentage of Mean Aerodynamic Chord. You can play around a bit, inputting different weights to see what effect they have on the balance. You will have to do trial and error to find the max weight pilot that will keep the CG ahead of 20" aft of the leading edge - I don't have the fancy algorithm that Ryan and William put in their program to determine this automatically. This spreadsheet is in Excel 2003, so unless your software is even older than mine, if you have Excel on your computer you should be able to use the spreadsheet. Good luck and don't hesitate to ask questions if it is not clear how to use it. Jack Phillips NX899JP Smith Mountain Lake, Virginia ________________________________________________________________________________
From: "H. Marvin Haught" <handainc(at)madisoncounty.net>
Subject: Re: Weight & Balance Spreadsheet
Date: Mar 23, 2014
As a lurker, and following along the weight and balance thread, it was interesting to enter different configurations as discussed over the last couple of days or so into your spreadsheet and then see the effect on where the CG ends up. Needed to be doing something constructive, like completing a cabinet making project, but I've just frittered away an hour playing with the spread sheet! Very interesting and educational! For example, moving the gear to the wing leading edge position changes the CG to almost it's most forward recommended location as a percentage of MAC. Likewise, moving the wing back 1 inch, moves the CG location dramatically forward to 31.56 of the MAC. This goes into my "keeper file" - Thanks, Jack M. Haught On Mar 23, 2014, at 2:32 PM, Jack Phillips wrote: > Okay, Here is a spreadsheet that I developed to be able to compute weight & balance for a generic Pietenpol. It requires the plane be completed, but it can be used to determine when the wing has been moved back far enough. I have input the values from my Pietenpol, so you will need to just type over those values with the weights and measurement from your own airplane Input values are red, calculated values are blue. > > The procedure is pretty simple. All of the measurements are made using the firewall as the datum, so you can make most of the measurements with the tail on the ground, which is easier (and safer) than when the tail is supported on a stool or sawhorse. The only measurements that must be made with the plane in level flight attitude are the distance from the firewall to the wing leading edge, and the distance from the firewall to the main gear axle and tailwheel axle. For these three measurements you will need to use a plumb bob and a tape measure. Strive for accuracy, because small variations in distance can have a large effect. > > You will to measure the distance to the middle of the fuel tank(s) which must be estimated to some extent. You will also need to sit in the cockpit and make note of where your belt buckle is (the belt buckle is very close to the C.G. of a human body in a sitting position), then measure from there to the firewall. Same for the front seat passenger (you will be surprised how little a passenger affects the CG position). If you have a baggage compartment and/or a helmet box, measure from the firewall to the center of those spaces (or, if you really want to be conservative, measure to the back of each of those compartments to get worst case). > > You will need a good set of aircraft or race car scales. Bathroom scales are worse than useless ' most do not go up to 300 lbs and unless you have built your airplane exceedingly light, your main gear wheels will weigh over 300 lbs eac. Besides, bathroom scales are notoriously inaccurate ' particularly at the extremes of their range. While building mine I weighed it several times with digital electronic bathroom scales. My estimated weight turned out to be within 80 lbs of my finished weight on aircraft scales. You need better accuracy than that. > > Position the plane in level flight attitude on the scales after setting the tare to include the weight of any supports and chocks that are on the scales. Enter the data in the spreadsheet and then input weights for pilot, passenger, fuel and baggage. The spreadsheet will calculate the CG position with respect to the firewall, the CG position with respect to the wing leading edge, and the CG position as a percentage of Mean Aerodynamic Chord. You can play around a bit, inputting different weights to see what effect they have on the balance. You will have to do trial and error to find the max weight pilot that will keep the CG ahead of 20=94 aft of the leading edge ' I don=92t have the fancy algorithm that Ryan and William put in their program to determine this automatically. > > This spreadsheet is in Excel 2003, so unless your software is even older than mine, if you have Excel on your computer you should be able to use the spreadsheet. > > Good luck and don=92t hesitate to ask questions if it is not clear how to use it. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > ________________________________________________________________________________
Date: Mar 23, 2014
Yes fortunately I found this new mag on ebay . it turns the right direction and though it is a slick mag it was made for military 4 cyl motors for generators and such. It would not be considered airworthy by the faa on a certified aircraft. But my bet is it is just as good as the certified mag, since it had to meet mil spec. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420896#420896 ________________________________________________________________________________
Subject: Re: widening jig
Date: Mar 23, 2014
Hey Douwe, I have been paying with it all day and I have decided to try your way by loosing the jig and spreading the jig to where it will meet the fire wall mounts. Then tack it into place while on the firewall then remove it to finish welding. My Tig guy says he can do this. Cheers, Gardiner Sent from my iPad On Mar 23, 2014, at 10:25 AM, "Douwe Blumberg" wrote: > Hey Gardiner, > > You could add washers one by one to the jig until your mount tubes are cor rectly spaced, or close. Then tack the thing together and remove it from th e jig. Bolt it onto the firewall and if you have to move some things around a bit, just cut the tacks. Once it=99s bolted on, re-tack and add lo ts of small tacks everywhere so it can=99t warp. You should then be a ble to finish the welds away from the firewall easily. you could then conce ivably cover up the planes front-end with a welding blanket if you are tiggi ng and do a lot of the welds at that end of the mount. Or just make put lot s of tacks so it can=99t shift around and finish them off the plane. > > > If you=99re gas welding, you=99ll have to obviously be more ca reful about the plane, but a welding tarp should protect it. > > If you have a nose tank, or there=99s any fuel anywhere around, you s houldn=99t try this technique. > > Douwe > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 23, 2014
Gardiner, That sounds like it oughtta work. If you could, when you're done, just set it back to the standard width for the next guy. Good Luck! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420906#420906 ________________________________________________________________________________
Date: Mar 23, 2014
Don't worryDon. I am not going to alter the jig. Gardiner Sent from my iPad On Mar 23, 2014, at 8:08 PM, "Don Emch" wrote: > > Gardiner, > > That sounds like it oughtta work. If you could, when you're done, just set it back to the standard width for the next guy. > > Good Luck! > > Don Emch > NX899DE > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420906#420906 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Motor mount fittings
Date: Mar 23, 2014
Great picture of this, thanks Keith goff Sent from my iPad > On Mar 22, 2014, at 10:24 PM, santiago morete wrote: > > Here is another idea > > Santiago > ________________________________________________________________________________
Date: Mar 23, 2014
Waaiiit a minute. Moving the location of the wheels should have very little, if any, effect on CG. What DOES change, from a CG perspective, when you move the wheels forward is the weight on the tail wheel. A couple of pounds increase makes a large difference since the arm is so long and moving the wheels forward increases it. Using Jack's spreadsheet, I added just 5 pounds to the tailwheel weight and it moved the CG aft by 1 inch. That's 20% of the total allowable range. A Scott 2000 tailwheel from a Piper Cub is about five pounds heavier than an original BHP tail skid. As Jack, and others, have said, accurate measurement is important. Bathroom scales are for my fat ass, not aircraft. You have correctly noticed that moving the wing also has almost a 1 for 1 relationship to CG. Moving the wing aft 1 inch moves the CG almost 1 inch forward and is by far the most effective way of achieving a correctly balanced airplane. That's one of the advantages of this design is that it's relatively easy to do since the cabanes are equal length and parallel, more or less. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420910#420910 ________________________________________________________________________________
Date: Mar 23, 2014
Moving the axel only changes the weight on the tail while on the ground...not in the air. Gary NX308MB Sent from my iPhone > On Mar 23, 2014, at 6:59 PM, "dgaldrich" wrote: > > > Waaiiit a minute. Moving the location of the wheels should have very little, if any, effect on CG. What DOES change, from a CG perspective, when you move the wheels forward is the weight on the tail wheel. A couple of pounds increase makes a large difference since the arm is so long and moving the wheels forward increases it. Using Jack's spreadsheet, I added just 5 pounds to the tailwheel weight and it moved the CG aft by 1 inch. That's 20% of the total allowable range. A Scott 2000 tailwheel from a Piper Cub is about five pounds heavier than an original BHP tail skid. As Jack, and others, have said, accurate measurement is important. Bathroom scales are for my fat ass, not aircraft. > > You have correctly noticed that moving the wing also has almost a 1 for 1 relationship to CG. Moving the wing aft 1 inch moves the CG almost 1 inch forward and is by far the most effective way of achieving a correctly balanced airplane. That's one of the advantages of this design is that it's relatively easy to do since the cabanes are equal length and parallel, more or less. > > Dave > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420910#420910 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 23, 2014
Subject: Re: A Couple of Welding Questions
I have a Smith torch and I love it, and I feel the quality is as good as any you can get. --Mac in Oregon > > > I have a couple of welding questions that I hope some of you can help me > answer. Here is the situation - a friend of mine in my EAA Chapter has all > of his now passed grandfather's tools (he was Mechanic at Delta Air Lines > for over 35 years) My friend is building an RV-10 so he has little use for > the welding equipment, so he has offered it to me. I have read some but > have no one to really guide me on the following questions, so your help is > appreciated. > > 1. The tanks have some level of Oxygen and Acetylene in them but the tanks > have not been tested in who knows when (I have not really looked for the > last date stamped onto them. Is it safe to use them ntl empty? Or should I > take them in and swap them for other, newer, full tanks? > > 2. The hoses appear to be okay (no cracks), but I have not yet pressurized > them and sprayed them with soapy water to check for any leaks. Should I > just go ahead and buy new ones? I am guessing the hoses have been coiled > up easily 6 or 8 years since last used. > > 3. The torch it self is a Smith and I have tip sizes 200, 203, and 205. I > replaced the o-rings on the tips. Should I take the torches somewhere to > have them inspected? Can they be rebuilt, if needed? > > 4. The regulator is the 2-stage type. Do I need to have them inspected as > well? Can they be inspected and repaired if needed? > > Obviously, I am trying to ensure the equipment is in good working order > before using them. Thanks for the advice. > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > USMC, USMCR, ATP > BVD DVD PDQ BBQ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420824#420824 > > ________________________________________________________________________________
Subject: Re: W&B, Axle Loc., Cabanes and fuel lines
Date: Mar 24, 2014
Thank you, William. This post is an example of why you are one of two people I ask for advice on aircraft building. -------- Kevin "Axel" Purtee Rebuilding NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420917#420917 ________________________________________________________________________________
Subject: Combustible lines
Date: Mar 24, 2014
Hello, Like allways asking for something... I build a wing tank, and I want to know if the lines (from the tank to de gascolator) could be of rubber. I ask because i never saw any one of this kind, all looks like aluminium. If there is a reason why not to do it with rubber I will be very gratefull if someone can explain me . By the way.. this weekend I install the firewall with a ceramic fiber insulation of 10mm.. It was a little bit gross in width, but it was the thinner I could find. The firewall is a galvanizad sheet of 0.48 mm. It gave me a lot of work because I put it with the engine in place, but after an hour of folding and unfolding it stay in place ;o) -------- Mario Giacummo Photos here: http://goo.gl/wh7M4 Little Blog : http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420920#420920 Attachments: http://forums.matronics.com//files/dsc_0181_413.jpg ________________________________________________________________________________
Date: Mar 24, 2014
Subject: Re: [c-a] Attention eTech, Arduino, PLC, Glass panel,
3D printers, tablet users
From: Patrick Panzera <editor(at)contactmagazine.com>
Is your printer home made? Pat On Mar 23, 2014 6:19 AM, wrote: > > > Thank you to all who responded to our survey! > It appears there are a lot of us out there using or are interested > in some of the emerging technology out there and are applying > it to their airplane projects. > > Randi and I are the Engines Workshop co-chairs at Sun N Fun > and they have approved our plan to test the waters for an > Emerging Technology Uses Group; eTUG. > > Time is short but we hope to have a demo 3D printer running in > the workshop, at the very least we will have sample 3D prints from > an ongoing project of ours and prototypes of the project as well > as an Arduino project under development. > > If you are coming to Sun N Fun, please stop by the workshop > and say hello. Tell us about your interests and projects, better > yet, bring them along. > We will have our first in-formal meeting on Friday, April 4th at > 10:00am in the Engines Workshop tent. Its an opportunity to get > together, talk with others about your projects and ideas and let > us know what you'd like to see in the future. > If you have a project you'd like to bring or do a presentation, please > contact us. > > www.EmergingTechnologyUsers.com was launched yesterday! > Even if you cannot make it to Sun N Fun or Oshkosh please go there > and join in, tell us about your aviation related eTech projects. We are > hoping to see this grow into a lively and interesting community of > aviation eTech geeks. > Please be patient, the forum will have it's glitches at first and until > we get some moderators in place who can devote the time to help > this all run smoothly. > If you have suggestions for sub-forums and topics, > please let us know. > > And finally, if you are on the Velocity list, Van's list or other aviatio n > related list please forward this posting to help get the word out. > > Regards, Chrissi & Randi > CG Products > www.CozyGirrrl.com > Sun N Fun Engine Workshop co-chairs > > __._,_.___ > Reply via web post Reply > to sender > Reply > to group > Start > a New Topic Me ssages > in this topic(1) > Visit Your Group > > - New Members > 1 > > [image: Yahoo! Groups] > * Privacy * > Unsubscribe* Terms > of Use > . > > __,_._,___ > ________________________________________________________________________________
Date: Mar 24, 2014
Mario, Reject rubber lines! Ultra-lite guys seem to use them a lot, but they are often far close to the ground than most. You should only use hard aluminum, or steel shrouded flexible lines (from wing to fuselage). Don't be intimidated by manufacturing either of them, as they are easy...plus you always have your friends on this list to coach you! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of giacummo Sent: Monday, March 24, 2014 8:02 AM Subject: Pietenpol-List: Combustible lines --> Hello, Like allways asking for something... I build a wing tank, and I want to know if the lines (from the tank to de gascolator) could be of rubber. I ask because i never saw any one of this kind, all looks like aluminium. If there is a reason why not to do it with rubber I will be very gratefull if someone can explain me . By the way.. this weekend I install the firewall with a ceramic fiber insulation of 10mm.. It was a little bit gross in width, but it was the thinner I could find. The firewall is a galvanizad sheet of 0.48 mm. It gave me a lot of work because I put it with the engine in place, but after an hour of folding and unfolding it stay in place ;o) -------- Mario Giacummo Photos here: http://goo.gl/wh7M4 Little Blog : http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420920#420920 Attachments: http://forums.matronics.com//files/dsc_0181_413.jpg ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: Speaking of outdated stuff? Center section fuel tanks
vs. nose tanks on a Pietenpol?
Date: Mar 24, 2014
Scott Knowlton-your new nose fuel tank looks great! Way to go. Speaking of outdated items and things that could be considered unsafe or ob solete----let us rethink Bernie's putting fuel up in the wing right over the passenger and pilot in a Pietenpol. Is this wise? Is it safe? Is there a better way to do this? YES! Just trying to become a free thinker here and not tied to any dated ideas or products. Now where are those old oatmeal containers for my new wing leading edge? Install your fuel tank in the nose. - You don't have to get up on a ladder to fill the tank. -You don't have to run long fuel lines to the firewall. -You don't have to worry about spilling fuel into the cockpits if you over fill the tank then smell it for the next 20 minutes into your ride or fligh t. -Your CG will benefit because Pietnepols are notoriously tail-heavy (espe cially with our full-figured girl figures!) -You can run a really short fuel line from the nose fuel tank to the gascol ator---and in my case I used a flexible braided line which works fine. -How much fuel CAN you really fit in that wing tank anyway??? Not much ri ght? Comfortable for x-country?? Not really. Need a header or nose t ank anyway? Usually. -A nose tank (in my case I hold 17 gallons) can hold MUCH more fuel than a Pietenpol center section tank. -You can use that wing center section space for dry stuff won't leak out if you crash like your sleeping bag, your pillow, some rags, a tent, your ti e-downs, a few spare tools, quarts of spare oil..... -The nose tank can be filled without a ladder or climbing up all over the a irplane where you risk not only falling but damaging your airplane. -in the event of an accident there will be no fuel overhead to spill onto y ou or your passengers. Bernie had lots of great ideas when he designed the Pietenpol and I admire his design skills that still bring us the joy of simple, safe, economical f light today but his center section wing tank isn't one I would recommend. Mike C. Ohio [cid:image001.jpg(at)01CF4759.7E0BFCD0] ________________________________________________________________________________
tanks vs. nose tanks on a Pietenpol?
Date: Mar 24, 2014
I'm firmly in your camp Michael =2C if the engine installation allows it. I wouldn't build one any other way. From: michael.d.cuy(at)nasa.gov Subject: Pietenpol-List: Speaking of outdated stuff? Center section fuel t anks vs. nose tanks on a Pietenpol? Date: Mon=2C 24 Mar 2014 16:06:32 +0000 =0A =0A =0A =0A =0A =0A =0A =0A Scott Knowlton=97your new nose fuel tank looks great! Way to go. =0A =0A =0A Speaking of outdated items and things that could be considered unsafe or ob solete----let us rethink Bernie=92s putting fuel up in the=0A wing right over the passenger and pilot in a Pietenpol. Is this wise? Is it safe? Is there a better way to do this? YES! Just trying =0A to become a free thinker here and not tied to any dated ideas or products. Now where are those old oatmeal containers for my new=0A wing leading edge?=0A =0A Install your fuel tank in the nose. =0A =0A - You don=92t have to get up on a ladder to fill the tank.=0A -You don=92t have to run long fuel lines to the firewall.=0A -You don=92t have to worry about spilling fuel into the cockpits if you ov erfill the tank then smell it for the next 20 minutes into your ride or fli ght.=0A -Your CG will benefit because Pietnepols are notoriously tail-heavy (espe cially with our full-figured girl figures!)=0A =0A -You can run a really short fuel line from the nose fuel tank to the gascol ator---and in my case I used a flexible braided line which works fine.=0A =0A -How much fuel CAN you really fit in that wing tank anyway??? Not much ri ght? Comfortable for x-country?? Not really. Need a header or nose t ank anyway? Usually. =0A =0A -A nose tank (in my case I hold 17 gallons) can hold MUCH more fuel than a Pietenpol center section tank.=0A =0A -You can use that wing center section space for dry stuff won=92t leak out if you crash like your sleeping bag=2C your pillow=2C some rags=2C a tent =2C your tie-downs=2C a few spare tools=2C quarts of spare oil=85..=0A -The nose tank can be filled without a ladder or climbing up all over the a irplane where you risk not only falling but damaging your airplane.=0A =0A -in the event of an accident there will be no fuel overhead to spill onto y ou or your passengers.=0A =0A =0A Bernie had lots of great ideas when he designed the Pietenpol and I admire his design skills that still bring us the joy of simple=2C safe=2C economic al flight today but his center=0A section wing tank isn=92t one I would recommend. =0A =0A Mike C.=0A Ohio=0A =0A =0A =0A =0A =0A /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAoHBwkHBgoJCAkLCwoMDxkQDw4ODx4WFxIZJCAmJSMg IyIoLTkwKCo2KyIjMkQyNjs9QEBAJjBGS0U+Sjk/QD3/wAALCAONAsYBAREA/8QAHwAAAQUBAQEB AQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1Fh ByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZ WmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXG x8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/9oACAEBAAA/APM4wDG/AwccCkwoPbOK AB8uMZ69KMY7d+MUoGBijGMdTQRnrQQDnI69aMAfMeD0q7Y6NeakQtlbPIB/cFdZpPwp1W9xJdlL aPvuOX/AV2cPwo0VIlEm9pMckN1+oqX/AIVZoO0Dy5P++qR/hZoQXbskH/AuhqCT4X6CD8ol59Gp 6fC7Ql6RP1676U/DLQV48l/rupF+GehD/li7dh81B+G2g8f6M3PvR/wrbQMA+Q3H+1Sr8ONBLZNs Rx2anD4b6Ac7bZ8/71U4fAHhx757VBJ5sQBODwKtf8K00EH/AFLfi1Sp8NvD+B/o2Se2af8A8K38 OYGbUf8AfVNPw48Pjragjt81J/wrnw7z/ogH/AqQ/Dvw9nAssn/epP8AhXfh/wD58iPbNH/Cu/Dw P/Hmce7Uf8K88PdrL/x6kHw88P55s+P96l/4V34eKn/Qsf8AAqafhv4dJwbRiPQNTv8AhW/h5efs ZJbgZelh8A+GpZXRLVXZR8/z808/Dfw9n/jzAx/tU/8A4Vx4dOMWWPqacPhz4dGAtkMj/apo+HPh /cd1kPdgc4ob4c+HTkfZD+DU0/DXw8AP9EHP+1SN8NvDwB/0Rhn/AGqaPhl4f5LW7e3zYpjfDHQQ SWR1AGThu1RRfDrw5KdsZEgHZJM4PvTZ/ht4fiyGLIqc5L4qO2+HegXqM0KTGIHG7pmqk3gfw7Dq 0OnyxSLLOCyMTxn0p1n4H8O3j3KxJIRbt5bO7cFqbF4S8OHUltGtp/MIJ3E8HHpVb+zPA63jW0kc izBtu0nqa3Yfh/4cmiEkdtvVhwQeKkPw60AAbrQg+pNIfhv4d72zA9R7Uq/DjQMf8emfxpG+HPh8 H/j0P4NQvw48PnraHHrupf8AhXHh9Rk2mf8AgVB+HPh/nFp+tA+G/h/r9l9s7qF+HHh/af8ARTj3 NB+G+g8/6KR9D2pp+G2gHOLcjPX5qB8NtA7wE98k07/hXGgHAFr9eaE+HOgYwtvn1G6kb4daD1Fs 3r16VE3w90BYyzQHAGTubjFcvq+jaJF5kek6bJctEpLyBv3aVv6P8O9Jm0uCe4hJkkXcT0IB7VeT 4baACf8AR2/76pR8NfDxX/j3bp/epP8AhWGgtjELDPXmkPww0Ik5ibjjl6cvwv0DGVjfB/26X/hV egcHy3+m6hvhZoAPEcnHo1B+FWg43bJQT/tc0g+E2hEDBlXPT5qG+E2hjOPOJ7fPTF+FGh+s5wOz Uh+Euhnd/rgPUN0qNvhNonrMM/7VIvwn0M8FZjjoN1Wovhb4fA+aCQk+rVaT4ZeG4wCLIbv9o5zW 5o/hnS9FDpYWqxB/vbe9fNUZ/dSZz14qNh6cH1oH16daUe/NLSYJPUAetOA3DjrnAHrWppXhrUtX O2xtZJMdWIwB9c13ug/COdbmKfV5V8kcmKM5/M16VY6TaabCI7O3jiUDGVHJHvVoRcY6gnnNAXIG M4PWl/hGB6/So5OPmzxUXPm5C9RzntTwvPTB/SkZeh6+tMOem4fgKjLbj97AHejbkHJPB4HY1C15 ENQFoGbzSm/AHGKrX1/FYX8PmTFVYfMp6KKp6LMl1ruoTxMPLGFDD+Ktq7lkiVTCnmEkDGelSruO Mgg4GRnpS8H1z7GjAwSx5I4xTSM+rH3poQkgAgEilOV6+nNIynbkDj+lYfiTxD/wj1gs7QGbe20K DgZ+tcrF8QNXvZ1gttICyMeDkkGux8P3Wq3No7arbJA4PQHrU2t6iNKsGk3IrSMEDMeAT3rDuL1L trCzgv2muVl+dlGMVa8JLc215e2F3bj7Srb3mDZLZPArpyCRhhg4yBmqN3q9paOI3kZnYfKi8njq TV2ORZUDI2FODk8nBrHeG5vr+4tzfSRLFgkRrjrzmoLrVbnRV+zTlrx5eLZ0GCx9/pWpp8jR28cV 5cxGcj5sMOp7VW8QS3dpZwy2kwjbzVRiw3Dk4zUtjeyvbXT3BVzCSNydHHtVWPXEv9OvvKjeKWJC xQkcr65rO0xLe7vrKXSInQqN1w68p9D6mr+tpbRXMQa0lu55RuCJyqgdTUtibu8ufMMJtrJBwpXB c/0pdW0e2v1imORc2xLRuPXrWBPp01tokFxsZkVnluEU4LE9DWpoP2XUYYLkIY54ARs9z2/KsXWf CT6rqtzL5G2UuGhuV6IPQjvW1oDXmmaUY9aaOIRNtRo+A47fjW8MkZPzKfu45pSF69M9SKUEbdwO SOo9aaynOO4//XQBjkZBHvTtuBjPFNIwME5+tPVeep96UA8cnkc0uMA4/WmgbumcfWlVcdSSetLs yc+tN2dQgAPtWbqutWejqftEmJW4WMHLE/SsYWGq+J2D3xexsM5WKM4Zh6E0avb20CWei2UYQzuC yr12jqTXVRReUgRRkKAFHpT8cEfzpAh2kZ49c1Hd3H2eAuELtjoO9Z72UupxK008kUefuL1q/DCt vAIo8kKeM8mrKONwXJL44WpQF+8w560YxxnnpSYO3jrSjkZ6c0qr0IwPakIOef8A69Nx5nWo2iVT wo59KEBHTOak/DHtTogRyo7dzXyonRs4ByM0mCTnHPp3pdowM/TnpVqHTrqdh5dvIwzwQpINakHg zXJ5Aq6dPycZxxXY6R8HZy6tq10ig4OyLk/Q13OleA9E0kh47KOZ8YzIM/jW9BbRwgLFGqL2AUDF PC5YYI454GM0oBPTGB6UDOSMjrzilHNDKD61GyFx6VAV/wBLHP8AD17VKFJzTWAx83SopI85PYdB WdqOs2ulyJDPu/eAlAP4j6VQF7qaTWtxMEhink2iE9cepqTUriWPVY76ztJLry0KOI8AfhU1ppv2 zfPqsCNJOOIzztHvVuwsBZ3E4iRUiYjCKOAKuBcsRgdc80BliRmkYKgP3if51nS6xAu77LHLcyA/ cjHJ+meKiXWNQOWbQbsIOfvJn+dTwa3BMMypJbv3SVOR+NXYninQtG4cZ5K9qVgOMH3pqruGM8dK 5b4habJf+HxDbrvcuCF9PpU3gi1UeGbcum59xBJGSpFdKDk47djimS2kV2oS6hjljzn5lBB/CsI+ F2/tiTUJHSJfNXywgCgIK2J1itLe7vLbb5rjlgc8imyanHbSWaTY/wBJU4YnjpXHaRLJfeIdWxLB FB5hTzpD8230X61f1iaK2nnVLtoIovJkJV8Fhg5+tR6LeT6hrWpQgtIj2wVZeQGIGMg+tSR6drGl 3li7wy38UKEKIyNwY+ue1W28JpPpzyeSsV+771bcfkOfWtq+0973R2tWOZCgXcTxuHeqlh4fkhtE gvboywqPuKMZz6+tPs/C1hZ2UlrEr7JjlvmwT/s/StK2sobGARW8axRKfuqMc1KFXcemcYHHUU0o CGIOD3P/ANao9pGFUfIQDkDqPWoLy2ivbd7RyFEqnheuKqabZ2OjwPaxybmiXdKx5YDsTV+CVbmC OWLJDAlcHGR9K5q+kOu+JYdPjJNpafvbjb0LDoDXTouM7AQB/COmKeHBB2YOBxz19qy7++upbg2t htDKu6Sd+Fj9jUmh3z6hZ+ZIQzIxUsOj471fZRn60Aeg+ntSFCW9R9akC8cClwfSjbjnrmgLnJH4 mlAUnAI+pqK7vILGDzbiVYkA+8x6fQVzzaxqOvStDosDQ2ve9lGM/wC6Ktaf4ZtbGY3Mxa7ujyZZ eT+ArXC9MnpyRnArE0iAX2uXWqOMqh8mH2H8VbznZk5247moRINuCS2fTtR5E00WJJPKwf4R2qWK 3CLtTlR3Y5JpwUpuwMepqEQmWZQUK85LA1OkO2XcRkY+93qYg9SMGlUDnuMUYwMEdf505V5zkZpC fp+NC88YIpdo7dM800oMg8e1NZMZx17ZpjFhkn8Klh5565r5Vt0MziMfKzkZr1vTfhBYPEstzeTM HUMEUDg49a6rSvA+hadb7EsUlbHJlG4n8+K24dNtbeNVjgSNRzhVAq0q8hjx6A0zAYnp+FOwOAAR 604Kdgz+NIwAx+uKTr0GKXHXFJg7s9qP73+c01jjpzULEmbH69qfkgdOg70xiF5JwPemY3MQRjiu W1C3i1HxLJG4PmRIPJk/hDDnpWtd2g1jTFhuCY3yOnBznrntS6ddWDKbO0n8x4Ttb1J71ezxjJJ9 CaeDwMggjqM1Dd30duiggtI5+RAeT/8AWqJNNeeTzr9vMJ5EQ4Vfw71ejjSJSIkRD2wKrfaRdPMt qV3xnazEd+9SmNDHslJcY+8R1/CqjaSvmLLayNBKPT7p9iKWG6eScw3EflzoOmOG/wB01dXaOnes nXsZtFGSTLjH4GqOl3I0jw8ilMyl2VYgeZDVxdYg06yX+0LgNdH5jGnzN/ugVHFqOq6ln7FZfZoi OJrjr+VTR+GhKwk1O8uL2U/MF37EH4CtM2Fulq9vFGI0kXB571nWmiySn/ibiOdI/lhA9PWrn9ia eCpFrDvQbQdv5Ut1olhe/NcWqSNwMlR0HQVYht4YR+6jWMAbcKvSpTgNkgA4ycU4jIwOAfQcU3JD ZXn+tGOQxHUU25lW3geVvuopas3Sb+4ury6juFwIwpX23VozzRW1vJNKwWNB8xPb6VA1/b/YTe+b utwoPmL8wC1yNhrlz4i1kyabJObeKQqAq4TbnqSf5Va04R32r3uo3l4YXtp9kaiTChAO4qlr9/PF qwezikntb1R5rRj5gqnJxWufFGnxaPLcQsyeQgCxOuGz0xWPpVxeWUZtbG18/UZv9IuCx4QHpn/C uj1HVTpfhxr+6jYyJHyqDoT6VzGk6peQ3Fu2n2lxsukPmm4PBf1Geg+lSaXa3PiG4u7e6vDHDHL+ 9ih43f8AAq7G0s4LOAQW8eyNOAMVMQSPekBA6c+9OGO1P28Ar1zilPb0559KXpjsSOM1FNLDDE0s zqka8lycVgT+JZr6XydCtftLDgztwifj3/Cn2fhZp7j7XrU7XdweVVeI0/Ct+ONYlCxqEUDgAcD6 UFVI3c9MYrE8Q3jx2gsrVv8ASbv5IyOo9TViwtZrCxhs4EACABif4j61eitVG5mJYse/QVYjRVBU AAD0pdvHPbigqQM8Z6UKARjPFOAwuD24zSqOM8g5oAyMZ9smlGB9B6UmPbmgE5NGfcAH2pQ38ulG TkdfrQenp7U09Pl65qJ8M3PWpIUIyT+FfLmn4+2xDpmRT+tfTdkMWUA/6ZrVnBz0/wDrU4ZLDpim kjPfFJt6Ywafjgc5pMkjOeexpOpPp1p2DnHp7UjDHtzSDp3/AApDt9TzzTZCdh6DnmoSwErbiS2A WrO13XbfRrJ2dw8xHyIvVj2FYWs3utXGkQyTaa0Q8xWZxMORnuBV69n1WwX7a6idcYaCEZK56c1F 5P8AZun297dAtOjmV0789vwq9fXqtoM95ArKrRFvcGqWlQxWyWEaBPMdPMcjqcjPNboYZPAwKd2J 6YBJJqnp8a3E73rLkscRn+6PatEDnr17mlUZ4zg9qg+yQwvIbdQsrsGcA/0qcRhQOoJ7nqaUA7iF Pbk1Dd2q3UODuUryjjtUNjK9xExlTbKh2utVNaGJbIKu4+ZkenA7ntXLaBpep389xcyGIKZnWPzC T5frjH866fRvD8emzl5VikfGRJgs2fxraGcAHnHSnLyd3QnqMUY3N/On7cgZ4x2oK4U9s0uCBk/l UeBuy3GB1okZVQMWAPck4FQy3kEKq7ShEkOEOe9Nvr6Ows3u5yfJQbmK/wAqparqos4LUqyxvcEB HkPAzz09azLrUpYtEkeR3kSWYRxM4wXB68UaLrVraXE0N/5lveSyElnQ4cdsHpW3rKJJo90MAqYy fXIrHs9Gu10VILCZIredBujdeUz1x/8AXotvB8FkPJtb66ggwA6RkYc+vtVn/hENIDqfsxZl+9mQ /Mfer/8AZ8X2yC5QbPs6FVUdORisPULaLWPFdvaiJDFaL50xC9W7Kakew1Wx1G4NhFA8Ny+9pnON ntjqasa3pd1e+Gr21WTzbqVAAe2cjpVmPTXkFi0xx9njwR/tUzQ/D0WjS3sm/ebqUuR2FahB4657 00rnsaAueAPwp/lgcZGc0i43Yzx704kjPODWJqviS301vs8Cm6vX+7BH835ntVOHQLvWJY7rxBId vVbWNsKP971rpLe2jtbcRW8caIDwqjGKcR85fnaOuDikWdJGwrEgdxUbhypaZ1VcE4HYDuaxNKj/ ALU1ifVGX9zCfKgHqB1b8a31TK5yTzUiKR9M09V9uh7UY7e9IRjihRlflp49PXoaQlff86U/UUA9 qQ5P0xS7VPfnNHGADwPSk257D3pR1/GgkY9cdaDjGeM+1MC/Nxz9KkVduR2r5Y05WN7B6+Yo/Wvp 61XbaQjOPkH8qk3Y/DtSqTnrihsDt1pdhUggZzSgDaTgAn3pOnPOPSkAYHnoD+BpxPPcn60hI29f agEfjQfTAzUco6tjiuY8QS3ul6pbXmmxPI0kRR0528dzWff2cT6Xpt4JftJlvY5Lic/wrz19FFbG qE6x5tjZklEw7zL0yOQB+VaNvcLJaRvMyxswwQTgk1n64VSNJevlKzDI9uKrRwJN4PKu+PNhJ4Pc 81X8MTrNa+dcOizqBFsJwyAeorfSRGJETq57jOSKj1OQpYSiM7XI2L7E96t26JFDHEoCKoAAqUcj H6UqhVPBOfanbF4Pfs3f86UHIGCSPU9qMYYYGPf1pjE8elNGRnp17Vh+K7h7XTfOjIEincKj8D3E l3oAupkCtO5cD6966Tb+h4oYAfSlyTjgnPpSn5R3/wAKdtwR2pw5PuKCwAySaZxweCAetc5rEznx Bb2xiM6vHuVFbAznvUXiFbg2lrBNFEiyS+WAvVOOCKWK7TV9Dk05yTebGQoRzkcAmo0ku9SitU+w ss1rw3nr8pwMcflWzDZPcSpNfLG3lkPFGo+VCO9XJraC5TbPFG4yDhh0NS7AYyuBtxjFKFHHp0/C hQAMDA9KaygKMev+RQwyMMcYqKO1hjleWNQJJcB2H8X1qbZn2U4xQoUfd4z6UmPmJyeeaUrkY6jr zTWyvP60Adh+NGwCm5yc846Gori4isrd7m4dUijGSx4z9K546jqXieN00lTZWT/L9ocfOw/2RWxp ei2WkxgQRDzCMPI3LE+pq5lYGfzHCg45ao2uXKv5Kjao4Y9Cais7CZMyXty0xb+E8AVe8tVQBeMc ZWsbxBO8pi0uBv8ASLs5OOqoOtaNtbpa28dvDgRxrhe1WFyOo/8A11IAB06dqUcAn0FJnsQMCgjc pGOaBnnGPY0u7A6c9uKU4OeMjFJng/zo59fxxSnOOpozkA/yFIcg4J4pRx9aByDgc+1GeCc0HqfT 0pflB9MUo6dc18saYP8AT4SeDvXgfWvp22YG3hGedo4/CpCBk4B9jQB+VKx6cdacOnocelISOo5p QMDGc8dqU8DGRSfzIprcknHtS5wR1pevOTTH+UNu6AVTvv3kcseM4Tcq96xNLMJt41aLNhfKVaPG VWTuPxq7clNIS2+yhEty/lybT1z3zVCWOG+8Q3sk5DfZFCRryPmI6+9R+KZZYfDrvGxLqF3cc49K Zo7Sa6kJ8sx2VsAArDHmNite40SxvJjLLbpvIwzDIJPvVm3t44UaKNBGAB0qDVhi0QDauZFORVsT ojrHIcyP91R6VOpBGM//AK6dnqOD9KcCSRjtwBSH2GM88dqQAnjP0prKc9O3btShV+p681geK4nm sYI0AYu5XHpwaZ4Dlkbw1HDcKEmt2MTLj0NdIvyctnA6Gl+uPbmk4zhSR7U/A28cUuOR6+g7UhcI pZzsUdzxWcdbikZo7FGuZQcFU+6D7mnJHqFwQ0zxwAdUU5P51Dcwu2vWDEbsREFiP61Pf6YmoPbF mK+TJ5gA747VbWJA7SBEDE/eAAankYI+Ykg0gGDwAPSl46YB+tHHOOp6il659/8AOaaw65596TBG MHgU3kscCnYw3egnJOTgZ607jBpvG08+tB6UmOOoG09aMKWC5oYZwDx9aztX1m20e0aSfJkY/LEn 3nPsKybTS7rX51vdcBSHOYrQenYtXQvJDZxAMwRVH3R1+lRLcy3PMEWEP3mcYxSx6chkMkrNIzjB 3dPyqeQfOibcAnBx6Utw+0qjZUswxgelSFiu48fKc5J4rC0OMXl7c6k3zFmMUT/3VHpW2AAvHXrz TsHIwc07HHHJpxAAP6+9M2jAHcDrmkAK9+nQU4EkgUuS2AetLlcj39KBgdOlKMfmOtGOcdsU3B4w fxFJ36/XNLu4I9s5zRg5PpnrRkZyP50p4GevvSFskf40q5z1yK+WtN/5CEP/AF0Xr9a+nrb5baNu mUH8qfjIzketOGe2cUdcryPalAKqB+uaMddw47mj5t3HT3pTwD2FMP3hn9ad3JpMZwM0AYPpzUcp byzs9OhqJSvmgNgsVx+FV7GwWxWeNdrQSSmRU/uZ9KxEupIUv9LvLWeV95ePy0yGU8j8qr2VpfLc tftbbpWUIIiehHGTWvc6SL3SZLSdiHk+Znz0OcgVftoRbwRIFUlVA4H51Ss52Gs3to7lmXEi57A8 VK1+q6iLZ1Yb1+WTHB9qZrIB0+RgRuXDc+1RafMbnVLyTZjYqICe2BzWspHGPrz0p2cknHBFPA3c 9CP1o9Mn/wDXTJJ47dQ00iIuCcscViaj4rs7OPzPkaEf8tGbCn8axLT4jw3UjRm2EYH3X5IIqpr3 jBL5bWO3UK4k3FhkFcVPoWuRwPqkov4wgkDgMOoPvXR2OvPcIzrbBlVtu4NntSjxJGpcz2V1FGOr 7MqffNa8ciyxq6nhlyCe9PaRY8FsAAZJJ7VkjWzfSMmkxtcbMhpmGEB9AaWHRpLmYy6pMZ2x/qF4 jX/69akcEcShY0jQD0FP644xj8KRFxjjPUc0pIHPAxxS8/iOw9KMHI44FNYc4/SjAJyTj0p2zFBH 4fWkA/H6UhBPTn1xSdjkUbSWxkYoAxkdeOKdnH8qBjqO1NOOeOM4oYLj/PFRyYUMeNo5JNc9ceJ2 u7mSy0SFrm4TrM3Man61LpWg/ZZW1DV7gXd7IclmHyx+yitJ2uLniDbGv97OaetrEmGlPmSf3pOT mrI+8OAAPToKd0Q7s4pFQDcy5y3JBqIAy3xbeNqDAHof/wBVZ3iGRms1sYGKy3TeWW9Aepq/aWcV naRW0XCRIFX/ABqfg8dR2pyAL9Kf/FSck+hzijBHQcUh+hA9KUdOR1/WnEDHTmmkDOP5dqUc9Mj6 UoP69BSEAf54oP8AL2powG68mlGe348UvA6jHvRjBz2Hc0hz78HvSDAP8qVTjtnHHFfLWmZOoWvr 5i/zr6gg/wCPaLJJ+UVIcc4/SlA+XqfwowQRn9OtAOVB5oHXHQdaOmCPTtTvw/Om8e4780YAPvTW PT1pwIxjj35qJhleaYv/AB9dR9wZNTMgOSevtVOW1P21J1XDY2tj0p4UKzbehoB45xmjnI7DrWUE aPxYHHG+2wceu7NP1UmW3E9u26SBtwUDk+tSyONQ0h2ib5Zo+PY1T8Lu1xaXM5wQ8pwR6CtsA8YF Ltck4Yc9aVem3j8acCQB7dvWsbxdo/8AbOhtAgxJGyyAE9QDnH41iX0WjavoUtjDEi3IjAIQElWH Y1maP4lt9P0aTRr1XW4h+RZlTdgdiaoXfizzddtJScW7AqwaPlSOp+hqSPVtIvdN1J5dpLyhkA4y ucfhitzw3qWlut1o9uwZmz0Oeo/WnHRNQn8N/wBmwAxNHIASxxvAbrn6VrS+JrSzuItNtVlvrtVC +XCNwHuWq3Fpc9+3m6u+5TytujfIv1PetSONIUWOGNUUdAB/Snjdlug9cUoIPU5o6n2PWlOAf600 ZHOMjrmkPGMn60oPPXvSAZIx60mMN9KU498H/OaXPy/hS+36CjA5z6U0gk8UoGOp+tNPDDvzTiOB +fvTGyOnSkDZ+tNmlS3jaWVwkajJY9Frk/PufF1wDFJJaaMjkFujTEf0rbs7VbS1aDToEtod3D45 /wDr1bitBGxdm3uf4u35VOSEUHHOOwqNYzNJvbjBqYFVQc/h60Llpd5PGOgonlWGIuWPHIH9Kgs4 PKjaVsh5Pnb6+lZsEral4luCMNbWK+WMd5D1rZ287s9ulGCvHOMfnTwSfX/GnHofUUfn780p789e 2Kb06AnFGSPX+dBUlfT0FKBs65pe/QZH8qQcYP8Ak0E/XmkbjpwR6UnGAPT9aeOvej/gXfFLk+lN xjnPWk2gDOeMU5SD26cV8saYQL+37EyoMfjX0/CwMEf3uEGOPapACQcDmnKW/iBOaUYzk/lScNzj j60g24+bI+p60jSxg53rj6ionureN8PcRpx/E4zTP7SsgQftkI7geYKT+0rEDLXdufUCQdajfWNP iI8y9twexDg4qrN4q0S3ZhJqMKn1LGqcnjfQQhH9oI+OyAmorfx94euJt630cZ6fOMVbPjTw+dwO rQN7E0z/AITbQGXH9pwAntmo38Z+HscapB14pr+NPDwx/wATOEk+lNbxroKqSupQkjJwScVSPi/Q zrUVz/acPl+TtPXg0aZ4t0eLz2n1KA5clOeoqCLxZo+l2t5GmoxTJhpIB9e1SeHfE2iafoVvDJqc Il25ZecZNag8ceH0Gf7Vg9+tMbx5oC5/4mKEgZzzip7TxnoV4Bs1CMf7LD+tWJfFGiwctqEAb3Oa P+Es0MnDalAc984qxYT6bcI0lg9qyMckxkcn3Fc9plnD/wAJ9qwaJGDRIQMcCs74ipHp9vaTW9tG HkfYXVOBng5q14T8GRWVtMupQRyK7Boj1OPeqemzWWiah4kvgkEawSIkZ6KrFauQ+JG8UzpYW12k FukYe8uV43+yntW7ZXGi6ZF9lsbizhfud4Ofqe9XotW09lB+32uRxxIKmTUbM4C3dv8A9/RTW1Oz GQbu3B95B/jSf2jZNnF3b5x2lXH86f8A2lZZ5vLf8ZRSNqllwPtduR/11FJ/adl1+2W34yik/tOy PIvLf/v4KU39s2Qt1bkjr+8FC6jZ5z9rgGDz+8FOF9akfLPEQe/mD/Gla/tQObuD8ZAKQajasPlu oDj0kGKDqFmvW5gGfWRf8aDqVkP+Xq3GewlXn9aP7SswBm6t/wDv6v8AjSf2lZAg/bIPp5i/40ja pZYA+2QZz1Mq/wCNH9p2ZI/0u3z6eYv+NL9ttm/5eoj9GU/1pVubc52zRsP98cVy3i29a/1Cw0G2 kVFusyzOWGNgPSuiggtra2SGNlWGMBVTcBjFTLLDkESRnb0+fpTvORTlZELf7wpispYvJKpPYbhT 1lUnO+Pj0YClDxHLblPsG6U5Zoy+BIuB/tdajkMc8iZePYOSuRT5LiNI5GDqSATwRWd4btfI0xZG +/M7TNngkk96184P8zSEbsjqc0pGTxz9KUjHXuelISQPrQW9SRS5+mPek9Md+4oz0Hv6UoY4Jxz9 aOD3P50ZIbnv60uR68kU0rxzzSqMjIPPvRnkYHJoyTgcZoznGDmjsP55oOD9P50o+g/CvlW03fao zGwRt6kORkDmvWmk8WeUGj1WJoyBt2xt0/Kkhj8XSn5r5xEepVOaunTdcZf+QjqTdjtjUf1oTQta kA/4mGrgH1Cf40r+GdbIOL3UGx2YqAfyNRN4a8QTgKyYH957px/KlXwNrDLzJb7u5N3JmrCeA7pl 2z/Zi397znY/rT0+GsAAaS52t2CoCB+dSr8PrYAj7RyOuIFzVqPwDpsWA+5z3OwUXHhHQYMR3TQp u/vkAn6VV13wvpeneGr0WsCKTGCrDr+dZemeDNHudeezmtP3SWkcg+c8s3U1uf8ACudAB4tGx67j TD8OtByQLRgfdqZ/wr3w6mS1seT/AHzTf+FfaA7YFv8AQK+ad/wrnQSwxauCB03VlXngfQrK7Pmw FYShfeXPUDpUmh+BdFv9MjnNsRvJKEt1FaB+G2gcgwOCeuGoHw60JeFicY6fNQ3w50EjLQPnv8xp w+HmihNjQNjsSeani+H+hwriO34P+11qwvgbRdozbcg9Qarz/DzQLj5pLdsjpzxmr2keE9M0KQvY QNGWIyC2c/hVHRjnxvrh2EEKij6U7xtAJbGzjYZja6TIz1ro2H7ojOMqBnvXmekeFP7d1nXbW/ld LRblZDt6ufQ12y+FNIXTBYrbBLbdkqh5Y+5qofh54dZAv2EYzxhjxSD4ceHQObM49N5o/wCFd+Hw fltWyP8Apoaa3w60Bj89mSfeQ09Ph54eUDFl1HQsaX/hX2gEn/QufQOad/wgGgjA+xAgf7Zpr/D/ AEB+BZ+/3jSJ4A0Bf+XTp33mj/hAtDP3bUjnkBzzQfAOgg5+zMMDoHNPHgLQ+n2eRfXDmg+AdDdS DBJ75kNMPw90IKVW2fI6YkNNb4daEQP9GYkD+JyaQ/Drw/n5bP8ANjgmqk/hPwnDfpYfZgbqQcIG Jx9fSrY+G/h0g5siB6bzR/wrbw9g/wChn67zSN8N/D562z89PnNSR/D/AEOHBSGYH2kIqT/hCdKA +VZgPaU81ieJPB9pZxwajaxzsLZ/3qlzkp3q7b+FtH1Oziubea6eKQblZZjSHwBp4Jxc3q/9tjS/ 8K/sT/y933t++OaX/hXtiQc3t8B3/fGj/hXdjkYvb/GO8xGaF+H1gOPtuoKR28480kvw9sFb5b+/ Bz/z2NOHw4ssf8f+oDvxMaz9c8F22naa00N9ftMxEaKZSdxJrpPDdwLrTYomYrPbjy5YjyVI9a18 bAPvdeppQ2D2yOtPXAA6n3peCp60m0+mfpSHG7DelDDPGSKY65AAYhsVGluxct5jfT3qVV2sTknP Y9KeOvBzijZk53Gk5X8etOGD93OfSkHv97vSFWOSGIz1wKZJHM5XZcFcHnCA5pBDOfvXJP0UUnky jB88n2KimPb3JckXbKB/CEFTQxuoIaXcfXbivl/TCx1CAqAMTLx7Zr6bgX/RouONoyPwpwYAY4we gzTgo6HlvSn5IwMAigEHDAZPuKRsFjnPI9aEBxhTj6Cl3YyM4PvTcDhgMj1qpdapa2scjvdQqU+9 83SsObVdU1jcmgosUSjm5uAQCf8AZHes+Hw1rahnd7K4mJ+Zp1LY+npVTX59etdFu4dVYeRt+/Cg KqP51HpkR1DXpTbX00mbKIq6AZI9PatyTRbu5QEreIyHGJJyAff5abD4YuCx86Vsdv8ASHNLdeGk VPMa8lQp94mY4/WsC30+3e5dZby4jQn7y3QH9a6m3vrS3tUi/tGM7RgF5ASfqaqao9hrGny2t1qM IUjAKtytXNK1bTrfS4IVuI444xtUbs8CrX9u6ZnAvI/zpv8AwkOldPtsee1IfEel7gPtiGnN4j0o DLXsRpy+KdHGP9LT0+6aG8V6Rgg3i++FNM/4SvSACftQOB02nNcjrHxKurScfYdOMsBziQ9TSfDn WJ9Q1u/n1AyiedBnchA+ldN4rkBi05e5u0xnua6CR1zywB9PWvJNQ8Ua1oviTUhpdtLcW8kuWBjJ GR7iu60PxVHeaVFPfxyW1wfvIImq63ifTFTmWX3Jjamf8Jdpiop3zfQQt/hUb+NtKieNWaZS7BUL RMASa3fM3IrADn9aXIzjIye3aj5Qp/xpNy9fSo9y/ezkemaczA9xyKTrnBHvzSbhkvkcdeaeJkHB YfiaUShjjIPGcCmlxgHA56kmmtNGkDyvt2KMnHOAK4+/8cRX0qWOgt5lxO215mGEh/8Ar1vaLocW khpncz3kvMs7clvx9K1RIjEKsikjsDR5iY4dT6gHp70qur4wVO7uCKPMQYywB9KTcOgKgd+RTX2S IQxVkIwQe9cjbSnwjq7wvk6RdMTG3aJj2+ldaGVwWXbtxkHOaQyrn5iAfc4P4U4SISvKjPY0F1GD wfTnrUc1xFEpLMC2eFzzTYEYyGSRhvboP7tWdwwQPz/rWHrUq3Wt6XZj5iJDK4B7AcH86g1aI6Jq Q1qAExNxdIO6/wB78K3rS6ivreOe3kBjkGQQc09WAAJYA4/lTtwB25+nNJ5yZI3qCO2acJM87hjH rTTJGTneKA4bBUjp3NBkUAEsPXFCSKwwCD+NO3gkAnOTSjGOOP6UZHPOOPypSPw9qQYJ69uadkDg GkOOCQRmkyD06n3pSfTp+VDAEnjnvRnNKoIJ96+W9KH/ABMYT6yJ069a+m4wDbR5HYcCk+zq7EkM APel+xxbsjfnp1PNAsIweA3P+0eKUWsaAff46AtS+QmeWI9eTVG51jT7Ntklwrv0CIdzVTn1S9nJ /svT3eQ9JZjtC/hSQ6JqF1tfVdRctgfuYflUf1qrHo0F3qs1vFFGtlbENIp5eSTtkntUXiDVZ4Vk tNMkt7Zk2hnc8rnsq0zw42uTX7pfXiXNkF/1hQow+lWvFMccXhq8ViRvTG0tln5rM8MWYs/EksXl iNGsI+AeRXYG2V1wWbK8cNUJso2YHL5/3jWD4ukS0sZRKGe3MZLpnkmptG0bTZtHtJmsYfnjB5Xn pVyXRNKjjLGxh47YqIaHp7xNPJaRhthAAUdKk03SrD+zokFpEVx3WpbnSrRbFxFaQBguRlRxTrbT bCaCGVbSAl0B+4OKsrp1kc/6JDx28sU5dOsc/wDHrDn/AK5ipBY2eAPssOAf+eYprafZlg32aEn/ AK5ilFjaD5vs0Ax/0zFL9jthx9nhwvT5BT1toomJjjROeSFrm/GLBbvRY9oPmXi10ksKSjEi5ANU NJtljS6AiCKZiR6mr7RqSTsz7Y6UohjPVFIx0xRsRB8qKMHnArlviK/2bww02wFUmRiw64zzXRWM on06GRM7XjXAP0qwFXIbb24yaGVWH3R9RQcAEjGAKbsRsgDBHPFL5Snjrx61GIFViAeM9KcII/TO ecmj7PEMEqOOvNZsuo2i3E9vESLlI2YLnhj7fSsGK4v9It4bne16buIvtJ+6/sPTFTf2lrE9nOps 7Vsw7ykRILKR1BrQ0vStNvfDwS3t0iS4Qbjtw28D/GrmhTvPpgiuh+8t28ph2OOn6VdS1hTLLGqk 9waa9tboWYrjaOTnt3rn4PE1u+r21tb2MgtZZPLjuWGAz+wro/s8RbLD5vXNHkx5JKjIGM04Iqjh Rx3zVaext7uBreWJWjfOQwrnYhd+F5jE2660cngn78J/qK2hNZS2ovUdXhUZ35yB7/WsePXHTWFF 5bpHp0hIWTdyh7bvrXRrHG0YIUY25G05AqNdMiNwZWO5iMDPYelWFtI1J+Xg/Wn+UMbRgDpWSliH 8VvdbRiO2CoffNarwowcMoIIwQwyDXMz6fd+G7qS600GXTpTma2HLJ7rWvYahZarDut5MlR86Hqp 9D71bWFGwSrED3prW0LyBim4joc1JHBEA2FGPrSi1jAOE569aURIDggAUhhVsZGCBTvJUNuHbtil VMYIUDPrTwCeoApdp9qQDt6UFR320o6cEUrZx2x71GVGegz6jtTgppei8/pS4GOOcUA9vSvlnS8/ 2jAOTmRf519PQ/6mL12j+VS4wB1pAQFxnj1HSqlxq1paNiSdM+inJP4VROsXl5ceXpuns0feaZto Hvilk0e7v8rfX7lD1jiG1SPT1qxYaHp+mLstLVIyTks3zM34mtBRgf1pGG1c+h4BrKutJzfG8s7h 4J24YYyrH3pqWV4ZjJOLOUk/faPmrG1wMSzAAnI2jFZHiJbWLw/fOjozlCCznk/SqelTwp4slbzk AFhFjJ/SukN9bqQDPGpI6E0gv7QnC3URP+9XGfEnUBFpKNEyskp8pjnNdR4eLN4fsSeoiHT6VovH uZA2D3qLUgw0252gKfLOCO1LY5jsLcZyQgNTH5lK4GTnmqukL5dh5PXy2Kj3q8MdO/NPXO31FIvH 3sc+1OJHO3PpSZOOOppc7h06Uh6jGfxrjfG07jxF4ctowdrTl2x2Ars+p3D+LuaZHGE3Ad+aewOc Z6UgHc9AeaUZGOnXpXL/ABBiWXwlLGW2AzKMntzWh4amEvhy0ZCTsjC5PetfGRwMUYz746UcEdB9 aaq7hkjHPehjnjIA9KTt1BPUUbsDv+FDso+Zn2A/eDVxchhXxHp8K/NL9tlLgdQp9farVrp81t4x EU/mvZxxlrTA+UZ+8Ca1NL0htN1C4nM26GQYijxygzyK2AgVlG0BccbaqRXtqLua1jws6nc69D9f erMztHG7qASqkgeuK4vU9ZlunsJsNEtzbSqyduKv6Vok1w1je31xHJDaqDbwxfdU9ifeuoKgjk/W jt2wOlIxIP4dqjBLtk5+tMuZoYYneZo0iUfMW5DLXCLp9zPJcXGjDy7GN/MNm54mA7j0qPTLC01m W6t7K5uFM4D3QmIyhHZRXoNqhghWMnO1QOf51MOgH696cT2HHakA3evrWfp9yZ7+9HZJAufwrQP3 h7nNITgfNWJqHh2G4uheWUj2d2v/AC0jH3j7r3ql/bmpaPP5Os2rS2x6XMAyB/vDrW3aajaX6B7W 4jlzwQp5A9xVxcEnOOOxpykZ5FKVA5/Hml7fp0pM0LwxBpx4OBQD2H4Ud/f270Gj+H0+go5PpR9R 7UhHQGlz6dT60HpxjFC9PbtXy1pGBqtuGzkyr05zzX0tNf2llBGLmZUYqMD+lUjrF1dErYWDsvQS TfKv5VG+j3+ocanqB2H/AJY242jHoTWjZ6NY2igQwICOhPJ/Wru3I24XA9KNuFxycetHf0zRk4Iw Tnn0qpeahZ2uBc3CIW5wTVGbV5JhssbWSbsWf5VqrHp2r3oCXV4trAo4jtjlm+prRtNLt7NPLjBf P3i5JyaxvFulWb6BdOYAGROGDGs/S9NtW8WtugU7bGJhnPWunGkWIlaQW6FnPLGmtpVkh3LBGpPc CuJ+JOmW1vo0T28QWRpeoPB4roPC4jh8N2Ezzsg8sZAbg1uQTtLITGo8nse2almjWa3kj5ww2ke1 Kg8tFTIGABwOMU5cqcjB9qWNAiHaAAeuBzT9g7AA/wAqFBVumTkinZ4OeuKBgEnP0pR8xIB46UBc Dkk59qNu3AyKwLuJbzxlZKRuNtC7MDyFzjFbp4brgdTmnEjOeMfXrTTkDkH8qB0HJPrmlxuHPc8Z 71zfjxwnhebzB/y0XqM1L4MYP4ZtgBhQMAMOcV0A+6c/SkOcEgnNJsJHUj3xTsbcfe/xppUAmm5w 3J/GsTWr+Q3KWkEogUfPNMTgIo7A+pq2tza3+mTxRTrL5cWSxPzA44zXK6aLtJ9M1xY/Ma4TZPgZ 3ds13WS8eDgf0FZuo+ILewmFuqvPdNykMQ3E/wCHrWNNr2p3t5dJAsVmLNN0287st2X6mrUpj1W4 EV6iwypbrMJB8rKfr6Ve0a9fVNEDscvtKlx0OMgEVzWi6Re3kzrqETww2sLxRtJ/GzdT9Olbehal aWlra6U06T3KL5ZMXzDI966DJ2nKjIHWlIx65+lMJG0jJJx6Ui85PUA8jFYPirTbm+tIjafObeTz Hg/56r6Vg2VjJr2qXNxaC7slOFkeXgKO6oK6O58K2MsaLAWtZo8FJImww+p70wXGsaYds0K30OeZ I+Hx9O9X7PXLG+fakyrKOsUnysDV/jv+nenE5J6A9cVmaXA8d/qMjAhXlDIPbFajjJ6HkY4oyDj2 45prEbf/AK3SmmNWBVhkHqtYOoeErS7lE9q0lncryskBxz7ioft2v6LFi6t49QiX/lpCcMB9O5rR 07xNpupssaTeVP3jlG1s/StYknkHGBn8KaDlQc4BHGaeDnJ6YNIPQ/5FOznkGgc55yMUucDGOgpD zyO/FLjJ9hR3GeTQOvHQe9AAz6+9Ge/Qe9JnpnHB/KlWvlrSkD39sq95VxjqOa+kLbTobWISRweZ OVGWc5bpUyXUzLk2kiAHlc/rSfbmAY/Zptq/7PP4U8XnBKwT5A7pS/2hHg+YksQHTeNuarXfiKyt QBullbssK7jUNvqWpX7sYdONqn8L3Bwx/wCA05rC7uIiLq7cZPKwjbxRZ6ZYW7nbaOz93lGSferc c+/IWKYFfVcClNyFyHSU4/2aY17tUAW87ZOOI6xfFd9/xTd6qwT/AHO6Yqto84/4Sdl2sCdPiOMV vSagi5JhuDg4O2PNC3qyIWWGYYGcFK434j3Eb+GBJ5MqhJN3K+orX8KW9vF4XsZhA24RgnjJNbK6 im4D7PcD6pxSpqKMDiCfg4Pyc01tTVePst0cHGRHUiXoZ8C3uM+6U434XJ8i5O30Tn8Kcl+WA/0e fkZHydKc98Yjzbzk+yZpEvzJn/RLkEDvHjNOS+Z3KfZbkMO7JgU03rFiiW8xb1K8fnUkdxIWCtBI CtOMsrYKwjn1rBtWlPjvUzsB220QPzeua2hPcmRlNuAgHXfT1acDBhGOn3+lKzTBsLCCB1+ao2lu h0toyueMvzUkbzFCXhAboRuzXN/EKd08KTEqgBkQdc1a8Jm5HhyzJjRmYA4LYwK242m53ooIHGHp jPOGO6NOf9rrTkeZsboxjud1PBcjDDAznhulIwbjao9+e3rSfvS3AUDtz/Ssu60G2utT+23G5xtG Yy3yEjuR7Vkw6Vdaje6ncWkxtVkYwKRyrr3IFbtnaHS9OtrO1jWSOBQhZmx07j3qsviOP+1xY+TI 5LANKnKK390mue0bUp7W/wBSjTS7i61GS5YLIR8gTPGW7cVLPpmpWWvyX0lidR+1bSI0fasbDgZ/ xq7qvh+/1TUreeWTy4jHieKN8E+gz3FWdR1lfD1tDZ21n5s5AENvEeefX2qvHomq6tF5uu3ZjRsn 7LC2F9gx70mtPJ4d0uC30i1t7eeeYQo7EEAf3ia2NHuHuLFGaVJ9h2mQcA1eJfAAXPHdqjBn3H5F x67qRmmwdsakj1fFRiW6JG63QH/ZkpVknBwIF4HGG6UrSXS4C26ksOVMlPjknYfPEFP1zVLUNMj1 E4uLCKQDo2/aw/KqcOm6vZgrY3gKAcR3B3AfQ0yGXxYs0hkt7Fk/gQSYzWlps2oyl3urGKFgOAkm QTV0mYYbylLE8/NTkaXBDIq88YOabI82CFQFh/tUx3mMY2wqXxzl6RXuCx3QoMjs9IZLrdiOGMr/ AHi+MVRvtDt9XBF/Yw7u0qH5vzFZw0XWdLQDSdSaRADiG65X6A01PGFxYyrBrulT27DgyxjzE/Ot q11ywv0za3kLHuC2DV/LY3fKRnqDTjkjC4zijDYOBzjj2phLcDjPc08Bs84z9afnHXPSkHcA/nTc PnJwAOetO+bOe3tS56DP1oGcdM/jSj9K+XNFUtq1tkf8tUz6da+m4+IE+n0qnqGs2GnRFrqZM9AF O4k/QVV/tu5vQPsOnTOCMq0w2L9af5esXSkPPFbKeu0bj+HpToPD9shY3Mk147clp33Aew9K0YbW G3yI4kQn0FS8/KT6/Sjkf3vakOQOcAdOaY3zHrwT60p56ke2aYA+wYPSsfxdk+F74HoE65rM0dx/ wlzDg/8AEviwa6ncQM889abyAcd/WuX+ISZ8FX/GBtDc/WtDwmGXwvYBgP8AVithj6Cmb8n0Xocj rTiPlwvGKcreuPyqQj5QV65HUUAH5ucZp6jnBLZz60Y5559y1KQpBXPGfWmg8jJwOuKd0PXr79KU E7cYJI4zXOWblfiBqSBh81rEefbNdCuBwD04I7ZpN2Oc9BR3znmndeppOwGfT+dcf8UZ44vBs4eQ KzyKAvfrWt4QlMnhjT2YAN5IArcXC+lNIJY9OmaAAM4+tOUY69aNppuCx+akZQW9j1HrXOXeqyw6 nLpumpFAYV82eZl+RFPt3rk28R6lrN3KsVzM1zbZ+zrEu1GH99x6Vb8PSTS/YPtRhjRZWdIVbLzS HqTXWabbywa7fZH7mULIpPQHpj61sbSAOcY702SZY1Z3YIFwNzGoo1t5ZVuotjZG0SAc/nVa91ux 00ItzdRRyuCUUnO4isGNrbx1pc9pqEDQXER3RyDqB2YVbg07W7OzSxszaIg4ExXoPXb61tabaPZ2 McU8xnkB+eRu5q2fl6nOKjJB9cevpRnIPp/Omrxg8cGnqeM9hSheBzn+tLjn196FGSF7CnFTkDnA 7ihRjHPX86UEEgY6dqCckj+dJgBsn600gbieR3pTjPtmmAAA8nr+tOzjv2pDxkkBhjnNRugkj2yR hh3Vhmsq/wDC2laiWElsqPnO+E7G/Os6PQNc0iUvpeqG4jHWK6GR+B7VMfFsmnsseuafNaA/8t1+ aM/iK3rPUbO/jElpcRSKR/C3NWGYdeevelHAHt39KXg4POaOMk7uvFKfQ9Kbu9/frTsdqBn/ABzS jp0xXy1opI1e12nH71evPevoxNMlu1Rry7fbgDy4/l/M1Zh0uztm3x2yBgOvXNW/ocj0p2BgcZIp cYxnn2o44H86PunHv6UjNjvx3poZi3X8KUjqcjnpSDj+VMyMZOePWsTxWx/4Rm+POfLrL0dc+LWz jP8AZ8WRXUk7RmmkhvUdq5L4j3Ji8ISJu5lcR/hmt/Q8Jolko4AjFXiDu6ml4xzycU9ORkfgKcEz g44qQY6ZyTxmkU5Jbv2p+QB14pCSx68igcHJH1oU7m96MjIOOVpQ3fPOOtYASJfHLugIka0+cj0H St0btx/uE5FK3J6imkZGP0pFLAL/AL1POcNjrnOK4j4rwJP4aiyV3ecqqPXnmuo0Syj07R7a2iDG NY1wD9K0Ac8MOBxkjvSD5lbJyT1PagY8wD7uB0HelLememKC2frUTSCKRFJA39j/ADpzyKibpHCj jknpXJ69bWyeJYprqUpb3VsyOynBBXofxqHwzaX0c09zZ20f2O6kyJZeJNvuKlmvNH0/WH/siwN5 qbnH7rkKfc9BW/pZ1JombUhAjsc7Ijnb9T61fIBXgfnXH3V7Dq2r3Rv5PK0ywcJ5WeZJKoal4mK3 Tx2Uc1vb2cZZovL4cnopHoa1tP8ADUVzqaaphTa3Nrte2foCfQV0VlYQWMCQ26BUQbQB/KrBOMjO MUM3y8nI9cUmPkxzSHscc5pDggg00AqeBk0/+IYFG7kd808c8Z4x2pAVx05FGT09e1OBBB7A+1AO WByPSg5BAHTNBOMDnrTTnHPpQcc5PFJwQeTmmjplcEZ6fhQSdvPbrQc9M5wORQmD0HJxTx2PYHmk kjWUFZEDAj+IZB9jXP3/AILsZp/tFg72Fx/fhPGfcVD5/iXRf+PiNNStxxuj4kx9KuWXi7S7xvKZ zazD70U42EfjW1FLHLGDFIJFPcHOakXjGAFHpS7uncHpRnvzk9vSkBGMEUZ+uRSqeK+X/D2P7btU /wCmq/zr6cQgooz29KNynjr70vOOoz64oxnPXtj3oJLL0PPalAHAJGaU55xyR+FN/iIBytIF6k9M ce9KM45wSRSE8jP400jJ3Eceh61i+LEL+Gr4EBRsrJ0vjxoQM4XT4gRjpxXVNkZHcetRuAwBb5T3 rjPigSPD0WF488Hpxmup0j/kCWZG0DyV/lV3AIyDz1zScDrwB+tLkgjn8alB+XnoOuKTofTPf0pV zkcfhTwTtXrkjpQp7tkn2HFOHzDpg03kMDswKXque/oRSnpyRjtxXNQKx+Il2dxwbNAB2ro93zcD nODxQCcHA+lJhhjGAM96CCOOM9faoZ723s4mnuJVjQAks7Yx+FcJ431nTdasdLWzu4nH2xQwPGPX g11Woa3p1lphLXsITbt+SUZXj0rgdI8by2rzvNrYe281ljjljyWHbnritQ/EMXOmyNLe2McpU7UB bII/Cuv0DU1v9CtbiSaMySRgkhhWmM8Ag5+lAzx75x7VyEupsPEd3qUhZoIALa3h/wCeknfj+tW4 NFvdVuYrvW5WQKdyWsJ4X03etamqaPbar9n+0LnyGyM+1R63p95e2ItrCdbYOcSvjBCegqbS9ItN JtlhtYduBy+Pmc+pNXxgDG0jNAB+oFZraHpxvPtjW8fnbtzMOhPqRWb4f0SaG91W81Hyma7l3KMZ UKOldEmxFVfl+UZXFKXTdkuBn070F1GCCOuaXeMY3D8qQ8r97B70m4DHIyB69ahS4hl3eXKrkddr Cnl8KMFT9KcDwcemcmjK884BBGaFOAckHFPVx0H64pR6kjH160FlUZLD8SKas0fTzUx9aBPFkbZE J7804yLz8yntTfNXj5hz1yaj85Mn5168c05ZojuBdAB33CmfaYz1ljB/3hThLF3lQ9/vCm+dGRnz U/Fx0p32m3B5ljBHT5hR9qt1yWmjGOg3ik+2W23P2iIZ9XFI15bknbcwn6SAUG+s1wzXMIwP+egq ndx6PfoftLWUgI6sy5rFn8OWcUgl0jWTZSDkoJgyn8CakW912y2q8+n3wU8yGQKRUEnjuaDzPN0/ ds6mOVSPyzUEfxO0+TO90hYdRIpzVu38eWVy22K6tCfQlhUV18QIrK4WKURSHGf3TE7vpXUaXqS6 lYR3YjkiWQcJIMEV82eHFzr9kG/56rX00E3RgEkAr2PNQC1RW+SSRSR0BqpqE1rp0JnubiQKR8qg 5LH0AqTTZINQsYrmF5fLc/KWOD+VXHhDqDudCO4NIYcbSXbjqe5pDBuUIZX5OM0PBkr87fKO1KsJ BJDtye/agQckhy2T3pDAWfPmPt6Y7VE1mzRsDNJkjhvSsTxTZGHwzqH72R/3fUnp6Vz1jpWoS+K5 Eg1SVM2URJdAWAx0FdAmjarBG2ddlYdTuiXpVGM3G4419mIPIMA4rn/G8s40HYdXluUkmC7DEBj6 VuadbXK2Fun9tyIAg+Tyh8tXobK+kOBrUoHb90OahkknS4ML6zcSOOD5cAIH1qzaWV5dKWTV7jAO MGFQRVsaTqBPGszk/wDXJaVtI1BlAGsTjPfylqvc6ZfwQNIdXum2jOFiXJrn7TU9Xe6Kyf2oIl4D NGvNbNrPNK+83V/Ft4KPHwatx2NzOxlTUrwx/wB0qBzVuW0lFuoWS5LjjIPNVmgkggMjNdn13OOK qRX1tcj/AEe4u5ATg4cDFZllbpP43vB5lyrLaJ95+a3jHAjBJbm6jxycnvViPTI3BYXk5HXIbrSy aR5wx9qn/Bq4Txpqv9mata6Pb39xEHIaWYv90GsDw34a1TxtfzNd6jcmwhYoJ85Lc4GAeK6j/hTd iZPMbVbt2zhmZVyaki+EOnxMSb6aRmGDuUdaoaj8LdKsZLLbfTjz5hEWIHSrVl8NdLuGu7c3EhSJ tp4GT71pQ/DvTLNV8qS7ATG1VlOD+FacUVpI/lLrEiuowyeZyKkfT4mhwuquDg7TvHJri7Lwb4ib UTcnVI0jViyNnJPvXW23htLZ/NuNXuZZHG1mL4zn2HSi+sLGziR7jUbpFc7VIYnmpk8OwoCw1G8J xz+8qEaHlQINau1b064pq6JIs4jk8R3LsQcRlVBb1qvLpthbzJBLrV5IZH2oivkAn1xWb4p8N3Wk 6Ze6hFqlxJGiZ2SSEEfTFW9PktRoljcXa3cavGGyJsgjHatKwXSb63EsNxcqjdDI5GR7Zq0INKCq DeA84BM5q1/ZNsVDb5CucZ800LpFs2cNNgDr5hpv9lW208yk/wDXQ1E+kWhBLCUk8cSGs3/hHotN YvaMVRjzvY8fiKtxaWef3ZdcZ3LM1CaUwODDPhu/nGnHS90pAjmCjr+9NSnRonGR9pHsJTTP7Jhx udLgLnn94ani0qydMo8+BwAZDVa/t9OsQi3BmLP91Q5/nUVvY6fNJta2lT/aM/T9avf8I/p7ZO18 AdBIakGi2iZAMvA7yGoX0K1OD+9zjp5h6VBdaNplrEZbh5EUYzukNVtNGhahJNHb78xDLhiw49ad aWul3N0YobeRlX/loW+WtE6NYlhmHJxxyelOGiWIyfKHp1o/saw/59+B1JNNfSdOjX54E5OOfX0p zaJp6qxa3iVRySfSkTR9KljDrbwup6FeQ30pJND0oJuks4VQdzwBUNvpmg3it9nht5fLOHKgHBFW RoGmZB+wxf8AfPSkbQtOY4NpHgdRimr4d0pWytjACT94DoaWXw9prJxZwnHODGOfrUR0XT41CSaV A3diqDAqeDS9KJPk2tuGzn7gBBrRjQLjjBxXzH4aGdcsCMczKK+mk+6hz/D1prHEnOAMfez3rjod RmvPEtzqDWEs9nF+6gkBBXj7xx9auafe36+G5Z7G0JmWViqv/dLckCnafHqd+izwa4W2n54jEAV9 iOtadvfmTWL22Lr5cEaH6k9aXTZZ7uea6kO22LbIU9v71aXrzQMZ7UYPP9O9Lz36EfnSE+/TrWH4 uP8AxTV+Cc/JWJYTPH4sZ7YxFjYQglzXRedc5+YQEg9A1RYlLD9zb4J+YKK5zx/Hs0O3+RFWO6Ri R1Irejv4IoYw8J+dQcKmSeKvxeXKoaPaT6+ntiqbaQqzyT21xJbvIcnZg5qZLG576nOO/wBxeakh s5Ek3teTN65Ap8Wy6DorllQ/eB71ZjhSPAGTjrk81MoOMdR1GaXnHIGMdKQEDPJz6HnFRkllLbsY 7npVW0uftizqRlY32ZI4b3FPFhaK2RBGhPZVrEsoC3jvUyVXYtrCMYx61uTskKEyLnHJXGSahsIm jhLMhQE5VP7tWiQqZz8o7+n1rxv4tvatqkEkABnOQ79iMeteg+AVhi8NWlrCpR1iDygcDJ7105OA c4GOwqtf3yWFu002NmRs9Sx7VxHjxb99PsjPJsZrhSkcQ6c9SfWrmla7Z6TqF5DNN5k00i4wOTgY /PNXb3WNSTUILeERK8vzPFjlE/vMf6U7RNJ867ur2+ZLjLeXAxQL8vc8e9VLjT1i1hYbxBcwzv8A u4ovl2D1NLqcV3p8sj3O7+ykA8tbc4K/UnmuisraCO0hES7oyNwLck1ma8b/AO5b2kYtB80kxxuX 1wDVPToLB5rEW1xdyT3UPmhnbonqR0qlrXiC40u6itNNme7eV9m4xjr6DHpUUdrdaXqEAu3D6tqp 2Asc+RGOWYemarzPcHX4bTTVgDruYtu4UdN7HoTVHxbez2OiXsX2pru0eRFLSd3Byceopvg2WDUL G2gu4bkRwjIQIx8054wegWtefT3uNaXTLG12LxJPK0hbYvoB2rpYvDOkTAbrIYXpliPxqzFpkOmR sbRnjTl2RmLDA+tXreQSW6SLjEgyPoaeUAG3t2xzTNu0sQQfwprAFMcEHk571XsmVnl8sAx5wCDw at4PGD8ozwaOQODnv9aejZ4bjApWwBnhR1JzWfaXDXd9M0KYt1AUOf429RV14klAEiKyr6jODWRq eo2ujzIG06aVXXO6GIv/ACqF/FMMdhJcfYrlIk4JkTZk9hzWbYXd7q13Da6nPLbvcIZooo8Z2dgx 7VpWPm6fr76f58k9rJGZgX5MRH8OfesKTW7TV9XkcxXF2bVjHBDGvyE+pPTFbGjadPDfz6lqIRLq ZBFHCg+4nv61fltbHT7SWWVRHCvzOQxHPWoPDktxfaYbm6TakshMCknOztmpr+dbSSGCC6hiuJTh BISc+2KxrzxTdWFjIJEje+W58kgfdxVzVr37Rren2IcIIv8ASpjn0HQ/nWLqGuJ4oWePz1tdJtz+ 9IbEkpHbHXFW7C9vfLg+zyLa2keAsQXIVR/eNS6lOLq4U3bB0k+aC2V8Bh/ef2+lPtDFpGl3E00q WJlbczYA/wC+R3/Gqd7MdIsrXWbfVbuWGRx+5mAyyk9hXU6PqsWr6el3bZ2PnAI5+lUre8dPGE9k rZjMCyFT/CTW6MlRx06UHj1HPWq8tsjPvAAcHtx+dWI2DAGvmTwxgeIrDHK+ctfTCEFF9AKju4Bc W7w52+YpXcO1QR2KWumfY7b5UCbQfUnqainhvLPTUj0wRvLGAB53T3PFR6bYTWBnurl0mu5huby1 2qfQCsHUfD8ckTXkrzJql62FEbYA9sVraR4cbS3hZNSvHSP70TkbT61ugAA549KAwGePpS/5GKTG 4ZB/A0xywzxnisTxiM+GL4kYGzoelYuj2Ns3jCWPygQNPiIUkk59c11i2Vsij92mD254qvcQ2cEe 9tiY7gnn8K5bxgJbrwvdyRxbbdGVhv8AvNyK6bTFD6Zat8u7yx17HHFNgC/2nIImwqp+8A/v5q9l mC4GAKjub2G1AEzqpPRT1NVWNzqBC5a3tj94kfM/sPStC3jWGMJGoVRxjv8Aianx37nmlBBYimSz Q28W+eREQ9ycVUk1QSEJbQyTE9wNo/M1GlhcXEpkv5iVJwsUQwAPer8aLENi4wBx6Cq91qFvZY86 ZEJbpnk/hXOafcz3fjDVntUCqYoMtJwFGDzjvXQW1okMjOGkkc937GrJIVSS3yAZYntWLda/YysE tw904PSFSR+NeS/Eiab+3NjwLbqBu8vOSMjqa9B0HxO9tpFtD/YF2kccagOnzB+OtX/+E2RDubSN Q9MiM5rO1nxlpN9aLFdWWoKu8OMxEMrjpiuf8Q6zDeabD9mi1aZt4GZY8bVzknP4VNpGraPFetf3 dndtcoxEe2IlFHt7mtWbxFpNxqK3R0zUt5XblYzz9aunxpaPbNbjS79EHygLCQRUMHiywtFbytM1 HzCMbzESwqEa7FcJi8tdVuI/+eTRfL9DitWPxf8AKFXR78J0AEeMYqlfeKzJKFutM1Dyv4VjjOD9 azL/AMQWl1qK3YsNWgxH5RSOLAK0sPjfS7e4SZNCv1ktgQMLnr1NZ7eLtFvdT/tPVLG+Nwo2Kq52 gVrN4p0K9aOddHvd8K4UrCQAPw61T8ReIrbUrFbaHw3eSbVIhPl4Ck8dK6bwZY6pY6LZw3v2ZIUj AVUU+Z68noBWrG8FvJMbGJWmlbLFe7fWrdrA0OWkJeRuSe30qpeSm/kNna5IVh5rjtnsK0kiCIEX ACjAwOlOGemcCo2bAJJxjr7VTeT7cpWFiIujSY6j2qxDEsKJGqgY6EVKfbrRgjOOvYGoLi8itceY 2M/dQcsT6VXSK41AM1xGYbc8iLPJ9yf6VoQxCKNUjXaB6d6fzxjoaRsAfKcLjt2rlZY59fv3uZVL abbqWjiHWdx0OPQVX0m4mEMt1DayS6pN95pl2rEOy5PYe1S6ok2maNeyeakusXabFC569gB6CpfD 9hPp/h+3tbaLyp8ZlmkHVj1/Ctu2tEttz73eQ8B2Nc94ysNRvmsktYmmtFbdPEjBS+OnX3q/Yzam ++WezjtrWNPkgBzIce/SuZ0m4v72aS7+yzPqczld06YSBM9s96s6f4PurqHUJtRlMVzPIBB6IB0Y 1ZvfCdzDod4Lecz6hdFTPKTgug6qvpS3HhU6rZnbbRWLoirGx5Ykf3sdaj1XRPEN5aRafHPZRW7H EggUqfoxNaSeD7VxazXTSSXFugVSG/T6Vn3GjX0Guyy/2eL9GAFu8ko2Ie+VPWpJfCt/qOsWVxqt xHJbQDe0MYwA/YAelTWVzceHLKWxNjLOEdjA0Q4cE5GT2qz4V029ha71LVlUX12+SoOdiDoua6Lg DB556+lUbjVreCTylcySj+BBuJqiW1TVJQvl/YrIdc8yOfb0rYjHlqAuBgY3Ma+afC2P7fseP+Wq 8Z6V9JXN1BZWwmuJERAByx4rIXxnpbH9207IOCRGSBWpY6pbahAZ4N7Rg45Qg043aBl+STJyMBel ON/EMfK59PkqM3Fu8qloZC8Y+VivTNPS5SRtgV/xWpPOXHI6nGKUyoCdwPHHNN89M4Y4B7Gl81GP 3+O/4VCl7byAsso+U+nFY3im7gfwtfbXVoyu0EHqa5u2106b4ym32c7q1jCo2D0HWtAfEO2uWeCz tHM8edyPwR+Helt77Mxup9Ovp5hyAy8KPYVV8Wa6LrwzexPpt0qhQdzJgdRU1rr076TaqmmXm0Rg B1TqKu2uv+VbgRaVfAL1OzqaX/hJZXQbdMvEJ4yI8kUyPV44pCZNJvnk/vtFk1a/4Sckhf7KviOh /dUh8TSqM/2RfYP+xTl8WSOwH9j6gSen7qqd14k1KTEcGk3kWepVck/j2pttrLuwE+g6hMyn70g6 GtFvEV2ifu9EumAPpiobjxReQRbzod2wHZaqP4i1m+A8rRruCLuf4jTbW8aGQyL4dupJAfvyNkiq 1hr96niDVZI9FuGlKRqybhwB0q4/iXVZAy22g3HmJ3ZuM96qtNqF6i/2lpF7MOpTzMJ+Qq9b65c2 cYS38OXEap/dwM15v4987V9Zub2TTLiNY1C89B9a9B0LxHdJotnHHot5IEiA3AcHirqeKLk8PoN4 AD1xVWTxDOLlhceHbqUDDL8gwPesfUPiPp93bNbtp9wpDbXAXlSO1R+G/GLtN9jGlSymVnkXKjcR ntXT/wDCRXMZxFoNyT3YAc0weK5jnfoN4Dnn5Qad/wAJJdbcpoV2R1+6KafF0sYydCv+fSPNO/4S uXhhomocn/nnxQ3iyVGKnRb8j18qmP4tLwkf2JqPPHMXaiPxCIoyf7BvSD3MPWlHiCKT7ugXRbr/ AMe44pw8StHlRoV6O/EWAaRfFblgi6Hegnn/AFdQya9LdRss+jagE67EXrVhdfmtrZfK0K729kC9 Kgm8W3cqkW2jXwKjMh2c/hUln4heKNEXRb4KTyxSp38TzDn+x77jjhKVfEk0qkrpN4pB7rVSfXpb iQK2l33lj7yhOtWF8RtHECukXq44C+XTv+EnKLzpd8PX90aP+Ep5H/Er1D3xCTSHxXg7v7L1Fh1w IDUR1y2+2reNpGomYjH+pJwKsDxfGf8AmFanx/0wNB8XKAD/AGVqf/fg8VJ/wkNw6botIuznoGG0 0067fuuyXQ7gKRg4NOXWzGm3+y7tAOPlTNVbvxKrxMg07UlJOCyW5zVa01mzskUro+os/Xe8BJNW P+EsjP8AzCtT6ED9welOHi1Tn/iVaiOw/wBHNKviYk/8gu/wfWI1K3iFm/5hd7u9fLpDrzhCzaZd 4PX93Sx+IpSn/IKvTznlKlTXJGx/xKrvjvtpx1yVVz/Zl3ycY2019dkTAOlXec4JC0HxCYwB/Zd6 R67KaviORmxHpV5k/wB5MVJ/bkoZQ2l3Qyc5C5ph8RsGI/su9GDj/V5pT4l2/wDMM1An/rlUbeIl nUodLvwD/wBMjzSDW47X/V6Te49RD81OTxOsxwNM1HnrmI4rahkM0IYIUJ7MK+aPC3/Ix6eeAPOX ivonV9Pj1SxaB5NhXDBs9D1Gfaqej6qs1jM14IA1u+x5IgCr+hFak93BZwB5GWNGxjaMZJ6cVBfa rFZ/uxG002MhIxkr9fSotE1eTVbFrqe2FqocquWB3Y75rT3DqMdOO4oSSNshCm4dcEHFLjH3VGPT FJjIJYDp+YpGwDuGN2Mc9K5y78Myq73Gk6ncW07sWYN8yH8Kih8Sz6YfI8Q2nlAcC5jXdG3ufSpv FFxBd+EbqW3kjkiZQMpyPrXE634kg8L+Lopp7E3RksYgoEm0A/1rjdf8QDVtUa8g0/7K0r7gADnd 6Z75q7pXj3VtKLOkYdSoQF1JUHvmtC6+JV1qmnTafe28e2baAyLtZeR2r1rTiBpdqFJCiIYxVjkY B/SliLOTxjFSA4JPUmnKudpOPrTgOBxnPqacCN2Bxx2pcEv1BJHX0pQepYsGXg+hoySeOp5+lRvM sSNKx2ouSfwqpY6ta6lZG6tZleNchjnlSO1Q6drA1Od1it5PIUbRMeAx9hVDRMjxLrwPPMeD+B4r d24zt4BPrTiSV5P3evrStnGQx4/QV5347Utp2tRRAlpJECgc84HNd7pa7dJsxk4WBAdvA6DNWscn BI/pSNlhgkjdnjPSvF9TsNY0qC8zPDDHNcPPsdBlsHqDXTeCNNlvNVj1drx5wkGx2I2kMeSAPSu/ VsHHB4zjvSliuBjHuOKOSvfnsDTwCSMnv+VAP4ilxySQOe1ByWwT07+9NzyQDyO+KCcE8nPQYpVb KYJNIAMAKcZ6nNG3JHJHZajmkWPBclVGBuY4FVpNVs7c4kuYgDzlDmoB4gsmUeSzyhTyEU05taXa WS1umOM424pqa0zoW+wXC4PR1ok1idFDfYJyCeg4NOj1K4Y5+xzA9sinreSsxzaTADk+9MTUTOoQ QSoc8grVkXyA7DFKPcr1pRqMCjJV1Pb5c08ajb95CB70h1K2RdzSgL65pyXcEgUxyg+gzUvmpnKu CwHI3ClBJ+vTrmlBXoMfSmkAJwCT2FNIAJAH4d6TYemTjrzTfu8noD2NC4ODnkmnAbgcZHsaULtI PI+hpwOCQOKMYUc8jvmnYGCGPI/lQQDj5uAKRiB/F+dBJBHzHrSgA5BPB/nSg46Ak5qoNTtvtz2h mRZ1AOxjgkVazkHr9aQnnOc+9PTOOevrXzL4Tz/wk2ndh5wHWvoy/sItStvJnZvLwCwU4z7GsvWN Ckl0m3tdEMdu1tKJFQ/df2NQPYSWMZ1bWbr7RcwKfLQD5FY9ABUw0vz7Iz3VxInnL5txs4JGPuk+ ntWNfPb6zp32aAMyMu2KJTtSFR/ExrqNJlhbTYUt50mjiQRlk5GRVOTwjYNcyXMBnt7iVss8MhU5 pv8Awj0ycx6xfn/efNTR6XqcLcavI2Bkb0yKQ2+uxKxFzBMeysmBUP8AaGvW2PtWlxzgnrBLnH4V m6l4qlh3RXmi3E0DcMrx/wAhXJa1rOl2unT/ANjSXdp5o+eykTKke3pWlpV7pWt6/LdSW8Mz/YYl RZuAGGe/9ai18rDcaN5SwxxrcgAK2/8AXFW/D1lFqdjewyXB3rdu+11BUgGuB8XYXxqwUADMf3Vw K9ysVIsbbaR/qwR+VTsvHUU5BtUDpT1+maXAOMnt+VOwcDJ+tMaWONWaVgqjqScVE+o2qWzXHmqY g2N4PH0rOuvE0VvqUNukMksbnY0ichWxnH5UsuttL4fmvoV2FCQM+xqt4n1v7D4dRsBpr0JEMH7u 7vXL3ulatosN5awXDTRXMQl8uJMYb+LA+ldRomv29wltaWdndgKoVmMeEX1zS6IQNe10DoJU57Yr ZkmS3jd5JF2pycmsnT/Ea31jeXbwMsdrnP8AtKP/AK1R6Zq769qUdxps3/EtjQGQnrIT0FYPi64N tFrDIAW82M5P4V2ukbv7MtvmLERj+WauYOPYCgnKdASRmuc8S+GbPxB5I1F2CRkkFev+7U2haNa+ HdNe3snlMe/ILc1pRXXnKWjDZzghh1FTlmf8OppxY9AefSlDZUgnoaU9xngGhflwOwNKx3HP4Yph znI/P0pR94Hp3JPaq02o21oSZ541HpnOfwrPfX7i4l8rTtNmnDf8tX4QU4WmsXS5uLuK2IPzLEM8 fWmt4at54dl5PPcg8/vHIFXLPSLCywbazijYdCF5q4oUEhcAg84A5p4ABzjnPQigp/eH4DmkIAyO oHQikIA2nkj3FQXdyttb7y3zZCoPUnpTbSIou9wPNY/Me61a+Vh93AHtTgF29hj2oKKMjC/iM0hR SvIU8Zxtpj20MnyvEGH+7xUC6PYxPvito1c9SMipVtFRi0bOM/7dOeItwJmHHXNVhZujEm6k57Dm kktp937u4b5vUU6KKdesyvnqStPRZtxy5we2KZsm3H94MnplelLGLsSL+8j2n+ECpCJ933k9vrTV +2A5/d4PU5py/atxLOmPpT1MvOWy304pWWfs6j8KaFlD5aQH8KeUlP8Ay0A/CoyLnOVZR9abJc/Y 4/MvJ0jT+8elcvr+meH9XkF/M7GcqFEsBIIrIsLa6dpRpGvXtusbbQt2mVY+grqvDVzrMnnR6xHH iMAJKnR6315/LmvmbwkP+Kq03cBgTrxX0xnAGB+NMY4A4AA54qnqemw6pFFFcZ8tHDkDuRyAaqeI La8vLFLOwwBNIFkfpsUdf0rG164js7q10W1tZXQqHcRr/rOwBNLZTXek3kmm2FqDdTgTM3/LODPY mjUn8QaQYZ1Z9Qm5L7fkRR6cVLZ+O1kQG70q8gVuS+zcn4Gtaz8TaVeNsjvFV2H3JDtI/OtXOcMm 054znjFYl5r9xa3bwwaVdzhejoAFqD+0vEFwfk0aGMHo0k3I/Cub8WaBqd5pklxqctjBHCQ2LeP5 mPYE1StfDAtdeuoLa4eKBbSKWX5ucH/PSmapEsaaKJdqyLeDO1s+uM+/tV7w/qMFvoUvkKZLu4vJ RCO/Uc/zrh/GMP2fxuFzux5e4/3vpXt9lxZW+3psGM/Spy3XPp0pcHA7U4dcYzmpRwMZ4/pTc7yB gkZziuTmvIrvVpxrMc0dvBLtjUg7CP7x+tRXq3Vtql5pmmJB5c0H2hVl4VQOuBWd4NV7B5zq0c5v JJvMjKqSnPQgVtWmg6pJbTaddvENPZmYkH53BOfwxU934W0saZ5VzcSJGHRvOlk5G3oAT0ragktr ny5YJEm2fIGVg2PrUu0IQRwepwMCuNS6+xeM7u289YQxE85fABX+ED1zWTc38mrS6qujR3AjII/e A7WfIwRW7otvrFvp40240yMRSoyyTK+SSR1xVfRfCK22jpJp1w8N9CzA7HzG5B6EVneLo5JdN1kS bfNDRhypzyQMmu901Wj0q0Q84iTGO/yirZbAGRyfXtTTkZ29hUbBH2eYmcHj3pXUYKqRj0pwGANu Ac9hSjcrAAgc0dM7QTzQqEEY/HingYGT+XtSjj7v4VDNPFbIHmkRAP7xHH0rNbXDMSunWktw2fvE bUH4042F7dvuvrzYp58qDgD6tVq20qztTmOEFu7NyfzNXAeQF6YzgDFN5GAVXGc0oGzOOMjNOVc5 pMAZ+UZ9aUf7Pp1PakyQM+tBBwPpimlhztIKqfyqjEBe3bTFd0UTYTd3b1q+AA2c5HTpRJhY29KI m3RJ708ckg59R7UL359cmnHp7YpvH4e9DLg5zxmmnAOM8etIwCnhjz6U3nk8cDrnmnqoGccZFNx9 eQaUDGD6ULluTxxTuVHBzxS4IzzilHJPHPFA46ik5OcAdKUADGfwpeAMgYNNcYXjP4VBcW0F3G0U 0KPHnBBHWoY9JsoECxQKoH4U020CX8ShFAUFjx3q/tyQOOmDinKCtfM3hIhvFGmnON069a+lXVsj a4GO1VWhmxjzxjdkcUqRXQly0owfapwsu3GVGPWo2ik+8pUPjrikjhKFipQMx5461k63JJeEaVZs ytP/AK5x/wAs078+ta8Vt5NulvCcIiADI61XuNItbqZZJ7S0cju8QJBqwYZUQLEYwijgAfyoC3XO XTPuKjK3e7LPGQfbmsTxfHM/hm5EjIW8xO3vWHMN3i26ja5SLfZQBgTgtWP4oe0mvdLiWWMxrc43 hhkjuxPvVnwbp6PLdXy3EUeZ3SEOwAjX+LA9TXNePownja2CtGUITaUOa9hiWZrG3McqgbB1HNKU vCc+YhHpinqtzt5lT6YpypckEB0I9cUMt0cBJV/EUoW5CsWmX3OO9Zuq2l9eIlgsqhJeWkx91c9P qadqMKae8V35Jdtgt2deyn+dRXfiK3028S3YN5Me0PIi5SEEcbqyW8Uajq+m3sOm2+2W2LF7pv8A V4HPHfJFUoNLGu6C0+r3r/aJE82GJptwUj1X+lXvB8Mt3eve29oLG0SMRnbwJ3HfHautZZTt/eAj PQVz2n6JZ32qXeoX8azzxzFEZxwMdB+FdDHEqtmBlGCQcAYzUdy7WUEl1LMRDCpckgfMBzWZ4Yhk fQ/OV3QXEjTIGHKhjkGuX8Wq6WPiA7sEyxhenPAzXZaZHcvpVr/pDLuiUD5R6CrbW9wCB9pLewUc 08wTcfvu3TAqFYbg5JuOR0GKVo5hGAZstnkqopvkTkuRcED6DipY45WdczEgDsKlEcrAYlOPcUrR ymMAS5PUNUEgMUG6W5C7epbgVjtqOo3s7QaUWCDrdSLhB9B3qb/hGY57lLq+uGuZkAAMg+TPstaS QzLjExC54XaB0p/kzswH2jGOSNopUhm3czk845A4pPs8204nJOcZwM0ggmXP73JZcDinJby45mJx xyKeiOpBMpx9O1IIXGQZW57EDAoWGQLtMrE5yGAqDULxNLsJLmeVvLQZJAGT9KzPDmtT63FOJbeW 3WM4jLchwec5q/qDb9ttHKwkmBXKj7o71ait/LRY1OAoHGOKfgk/fOM9+tDoVR8vlccCiCNkijXd naOvrUgXBPzdfSk2MDy/T0pWjY8h2/CmrG+PmdiffpSmHM24SEDuvammJmYZfg9sUnlMBkueD1NN khMjD59o74FJHGyr80rNx6Uqxtg/vWLEelO2tgYYnHU4p/l5A5xnvnpSiPIxubFDxbwoDEfShU2t 1YcYz2pSuPunOR0NKFPrj1oK4HXHsKcqjA6ijGF69KMEdO9MwT9D+tQfKb9d3Ur09ferQzk9OO1I QT0OD3r5p8JDPinThxzOtfSuBgHjpximSR7mByPwp23Ixk8U489QPWkHXsO30pCBtwf0pixoHLBA C3LHHJqQdAMnj/PNGzv+lJjggkY+lNxk8HpRtAPA561zvjmNj4Zk8ofOZUB/OqFnp9tfeNLuO6iW UxWMDLkd65DxLb2em+PYY3hhhsIgJlEgOGPpSeDYIb/xjMtxEslvcM7KseQgIp3j2wtbfxLbeQuw ooIAHfcK9Utxmzgzwdg/lQ8gV1XJyewFP+b/AOuaVeA3Bx2Worq8W0tpLgguifwqOSfas6LXxLp8 jsiwXMZ2BJiBgnoaz4fFn2aynk1BFlaG48qQRdQOxxTo7k6rcakLJ3mgeIOAf4XHb2NNg0eXVLiZ 5bdrVLi2CTBz99x0OK2bDSI7Fw7FdrQqjqowGI7+9Nt9B0yxleWG0VWdtxJ5Az6elLrAki0iaSym +yvEpbcig8D2PFc3oI1vW9Pt7xNakTcSSphUGnaRo739jqC3jtMwunHyyMhz7gVnWEly3iiyggln W0t2YyqTkZXrzXRa/qVrftb6d5ybJSHlbP3VzwPqfSulEaxxqiqFVQFUDsK8s8aW5l/tiTLKiXKA 7e/Ar0XQCv8AYdl14iGN3XpWjyeo9/8A61NYDkZ/SoyQDkgc9welIOe5565pwUGnA4PygD5cD0pS xAOASMetZlzq0McrQ2yNczDgonOPqe1RjSjdXHn6tIHK8rDuwif4/jUNr4lhudYGnW9u5i5G8fd4 6n2FVLnxRDo+qXttqLSEjDWyBSTIP9mr+i3Wo6g0l3eRfZ4GH7qFxzj1NaxK4IKnnkEilBKsOBj1 x1qQZ7evpSEgdO3Oewpu48ZLcnise+8RQabrENhcFVVl3PIxwEPYGs268R3WordtpTR29rbZE12/ zEfRag8O67PfXFh9svUlBSRjKSFB5wOPWrXiXSpfE+n7rOcsIX/1XRJse/WoLO+16C1EUekW9pHH hfmc4auh0yGdY2uLsA3MnXb0A9BV/gZB79aAuAT+NQXhAtJDnAAqWNfkQc9OeaeMg4z+lPB5PvRy DgYpByMevejcPT8DR1J5FIeAeB6cmozwuOnv609Rkew96ap+YnHXpzTl9e1PGOPQ9OKCTx1+lJk5 xjHNNwzcKcEUBMLgn5s04HAxk/Wlz6DBNGcDjA+poBxn/Ggk4OKax6k8D61SOTrMZ9YzV72/zmnD 1r5q8GIX8Wadxn9+vSvpPGD/AIUDhuvXjFGduc8Z9KD15xx3NIPbp2oyc9cH6UAfr7UvcAjk9qQ9 +uaTAxzzzSfxE4OfWhj0Heud8dS+T4bJ5w1xEp/FqbpKD/hNb1u4tIqx/ifpsl1p9leW9uJGhmAc BcnB6U/4WoU8OzRtFiWK4dclcNyema5z4hP5fi+MjBMkaqoHruBr1GAH7LEfVB+FSbQuC2D79aCS xIx0PpTbgSvDIISEkYfL/hXMi4utZe6jaGSKe2hwVAwN/wDWm/8ACKQaog1ANN58qYZZTwPbH16G rWn+EoWsLYanGDdx43yI2N5HTNdBFbRQg+VCiBzl9gA3H1qXeScMM59u9INp285pCWycDII5BrP8 QBn8P34TGWgYDj2rm/CPiC0t/C9rC4medISTsiLAEfSrvhm+gg0+S4RZGmvbh2C9z9K5fSdSlj8c 6hDbwuyS71jEnBLNz0rU8J+Db22na/15lMm/esGcn2yfau6LhcYyRnOa8x8X3bwTasiRhka7TJLY wdoxXoHh6UzaFZO4AYxgAZrTyRzg8jpjrTT97ocimMRznGaAoJ4yOOKRR19B1I7U+SRYkLOVVAOW JwBxWBcanJqCSyJKbTT4jh7luso9FrLs/EcUEDzWcKW9opJBPzSzY749K0NZv11KKytNPdjJdEMd pGUj7mjQPD13pE8iGSERM24yAEyOPQ56Vuy20Ek4leBHlTlWK/Mo9qzvEGvwaLY3TmVPtSpuVSeh PAP0rG8Oar5Ms015qLSo8a7i54Zz2UeldfE4kjEkY+Q9ARUoPvUF3OltbTTTELHGhZj7VgaFdeXZ vqN7cPJPeEyLEW+6vbArmJLf+045vE88buYL0KIzypjU45H410Ethdafrt8dPsknhv4VYRtwpcet WtO8J2/9neVqcUctw8hlZkGwKT2GPSt2CBLW3SK3ULGvAA6Yqlhr+9Lci2gbG3P3zWkABgcAEdAa U4HI/OkPc57Z4qrqChoBExwZCFUZ6mrQG3bgc4xThwff2oyOmc/SlHTPcUmQeF544pCf1pPQnr1N INw7cY6004JGe9Pjz0INOHTjIOe4oBwOn4Uu4+neg9SPWgkkcCkDZx8pyTSnnqCP60fhkd/UUZzn pRgntSd+evvTXk2DI70KSQWbr6VVnJXUrZ+F3Arz61e5P4dKFA7d/Svm7wMw/wCEt0/KnmYYr6Nk dUGXIAPqag+32+5j9oiGOoJ6Cl+32u0H7REQfepRcRnP7xce9IssTYKuhOCCc00XEAYhZo8jsTSi ZGGA6njrmj7RDkjzEBHTmlM0a7RvBBHakM6DPzr178YpPtUJODKgx70huISOJEyB61zPjy6ibw0M MjD7TCOD/tVJpDo/jK/bI2i0i710Lz27jb5kZ46VGn2W3ZhGYo1k+8F4y1eU+PGB8awhlUxFowjA 57ivVVngjiTzJFRcdzTf7RtJMBJ4uuODSm7gMhUXEYOeOaBeWrMNk8eSeoPemyX1pEwEk8SsTjPc /WpBdQDjzU3emePwpRd2xO3z4855yajbUrTPFxECp5+alF3DJ8wmTB54NNa/s4/v3MQPoTStqNuG GZ0yVOPSq97c29xp9zDHcxbmjKjnqcVy+h6nYWvhK1in1BbWZwVPlDLnk9qTw/cTXHhgi1mIktrl 0My4yq5+99aryQQH4h2c8Uwmd9srPG3y4AIrvnu7ZCommQbjn5mFRm/tB0mj4bGM15n4o8q4utSi eTcWv48Y75ArvfD08VtokcUk8bGLK7ye1X/7WsmJC3UbEDnBpf7QtXZitxHgdTupFv7Ultk8eF75 pWvLcHAnjAPTBoW9gY7FmXPt3rBluR4i1J4I5CumW74mcfdlb+6K0tRFhd6Tc2AkhVNhQDPC8cYF VNHTTF0xLjyYkZl8uQnHOOPyNOkXTPD9pJdabaxGVyEAViSSe3Paq0vjeI26taxM8isBcBhgReuf eneJtUtoHtZ7a7BubdvM8pGyGTvmqWmy6b4ludRvbwRvZOBDEZPYYNWtE0DQNEDNbTLcunO+Vtxj HtW2+sWIWJvtMYWVikXOCzd6qar4js9KgjJkBkkkCJH3Y/8A1qmvrix1DTZrS6uEVJ0KMFOCAetZ +m6bo2iWwtoZ2eV08sSyHc2KuaTDYWGlJYrKsiLy24ffz61opdwlAVmG3HBx6UovoGXesyECqN5q UUrpaQS75JvTjavrVtJ7a1jRd4UY796kS8hYYEgzUgmQr99Rn9KaJ0Ztm8ZI6VTvfLubmzi3/Oj+ cceg/wD11eaUJ97qvy5oEgPzHOOlHmAkDv8ATNIZ1VyMPke1HnrnGHx0zilEiuTgHPuppnnBSFIf B7BDUDX8W5k2TZXr8hp4u1yGEbgNwMoaVbpcgbZcdM7TUi3CtkBHGPVTQJhyArD22mm/a+P9W+CO ymmC9U7VKSZz/cNSrLnrGw7fdNOSUOxBDZHtinb8rwp57etKXOTgfWk3EYGOvpQWCjJU8+lRSzbE LBTz0+vpRCxkQO6jd2X+7U5OQT/kVm6tgR21y5ISCcM306f1rSXjJPHYU4dK+b/ASrJ4x00np5wr 6N2BuoBANR+TEMr5Kc9eBzR9niKg+Wg28j5RTjGhHCrjr0pDbx4ztAJ9KTyIuB5YB6dKQQoucIPx NILOHJPloSelONvGAMxjgdqa9tEy8ovI700WkCDaI1NC2luDxCmT61zPjy1hi8OIVjABvIen+9U+ lQL/AMJhqZZMAQRD6VtzW8KyEC3XJHWkFnbcbolOf0ryrxrBt8dWqIAEDR7fcZr1d7OBwDJGrbR3 pqWdsQSIogSePlp/2KBVyIYyT6ikWygDY8qPJ56d6T7JASC0cZPutO+zRZ3CNcjpxS/Z4txxEuR1 zij7LDjPlJx0yopWiiBwETHoV4pGihyC0KH6KMUNCuR8qgdsKPypJLe3jRmZI0U9SQK890rU9muX Gmm0sR5DkGd2GSp9Kd4JnhjutbtxfRxxpOQEJG1yfStKOKLSPGGnRxQLMlxAYxN1HXNdk8Ecm0si NlupUUhgjLD92uOf4RXB6jbRLqOqs5RsX0LBSOMYFdRoUwu7KUywxoVkIG0DBFX0toYyT5CYPXCj NSeTEAdsadOyigQxrx5SA+oUUGJAduxPbgcmsfWppHnj0zTVRLm45kcD/Vp3Falhp8On2SWsCDZH z0/M08W0RIPkocgg8DJqhPJb6ZNaW5t1MdyxUnHAPb86xfENw9xG9rE3lLHdxqzoOQD/AIVbTwlb wpNax7vsl3D/AKQx+9vHRvqauaT4asdIhIRPNkkG1pZhlmFTGXSNPXyGa1iCkny+OffFY/iC901I I4bfUkt5WBaPywCHIGefaoLqxvfEGjaVqeneR9tgO4LIPlJ6E1f0nwvIt3/aGsSi8vRyAB8kfstb rRIcbYkz3yoJpTDEB80adcdBmnFEDfcUYHYD8qcEU4GMe22q97dQafavMyrgdEwMsfSotMttqG5n jCzTDcy4+77VeESkKSq475FJsQgkKufbFKMA4OMfSkAyVYKD1HSodqm8A+XeEIxirKqOPfmlIGeM ZpCATgZB+lOA+XpzTGx1/Wjp+XNDHnI7Go+nHccinD68U9TgcDNID+tA646il68rnNJztx3pRnJy cetOI/Hvmgde/wDhQT69fQU08H+nrSN054PbFQ+QDL5jksOw96nGA3al5/H0qlq8RuNLnjHQgHB+ oNW1O7B/vgGnj75x+NfOXgAf8VrppxwJfTNfRg9cnjrSHHXHuKRgSc7eppcDkjgCgcgAClI56flT dv5Z7dqXd055PpR1bOM4/OkJxnAx7mlU5+nrSHc3C8H1rmPiANvh2MY/5fYMY/3qdor7/F+rAlji KMcjiuhc/wAsZpNrDhW4968x8fzL/wAJppcYjG7K/NjnqK9QI4x8xz6UBdvK/wD6qfk8deRSYwh5 z7+tB4zknBPGBSN8y4J6DPrUF1dQWcBe6cRRrjLN/jWTN4haefyNJtWuzgbphxGAfertglzBuk1K 9ieR/wCFflVR6AetaCkMuUbI7ZpV4yPqaZLGksZWRdwPUVyXiD4c6dr98tykklo4Xa5i43VDZfCz R7fT2gmkuJGZs+crbXI7CtPSvB1npUkDJdXUqwEmNJH3BTXRBskjOR2FCOWYdAMcetef6jKn9oa5 ZsMzzTo0Q9cAZro/CQ26OQQPvkkelbRAX1z3pxyQGXHvTgeikYz+hqjqmox6Xp011IQfLHyjux7C qfh2yeO1N9d/NdXXzsf7o7Ctk852t15/+tUflHfnOF9M1U1bT/7Ss3hR/LkxujYdmHQ1U0DRpbWy k/tFkuLqeQyOcce2K2ASVz3HQ9Koa3e/Z9HmnjcFnARWRvU44NY9hpNpba49i9sZ1eESieX5n9wT 6Ulz4A0u+lkacTcy+YgjbbtGMY+ldJa28VpbJBAgjiQAKo7Yp8jsGACgtTlyQGYYJ7UzllJIz7D+ dEUPloVLMR94k9akZto+8MAc5/nWZHH/AGperctg2kRIVSPvH1rVUnk457ihmxnnt60xABnrzTs5 5x9fpSZIzu9ulQ8fbZCOoWrG7Hrx70MST7GgHA6ilU9/Tr60hIJx1zRj356mgnjHU56iozgtu7D9 KcCG5zx0pQRgnOCB3oyCcdqeB16/hQMYBxgdTQTzx1Pekzjt7YpwGRnPJ7igA9fWg5yOfypCwJx6 joaYFJbcw5Hal5Ygc/hTtpwD396QDBGefwqK7XNnKOg2mi3z9iiHPCLUqE7j6V87/Don/hN9NBAy Xr6I4/Cgg57c9/SlI6cnPvSYweoB7D3pASvTkUbh0J/OgMcZzjHfsabuww3H/Gq17rFnpuwXEwVn ICgDJPbpWV4gluI7+0E0jRac2fNeL74fPGT2FbkZVlXadwwOe+Oxp2Sc9uOprm/HfOgwA4H+nQc9 f4qdoTf8VLrR35IZF5HQYrf/AIOhwe/vTSrZHzZHTivNfiCG/wCE00rYq/KVye/UV6eeR8pwPYc0 gJBGXIHoaTfgA8j096A5xxgGqOqazBp6JvWWR5TtjVBksfT6Vjxarq2pafc3aGCxih3KYtu98j19 KpeKb6W70zTBbOsgkIkljxuO3HXFW3hkXQbcWEMsIglRg0g2l/Xj0rem0eyv7hLm5i82RRxk8D8K vRRrGmF6LwOMClYjhjjHtTdw4C9T6dqA6heQOelNbacHJJHY9KYWLDr09qAWJznOPWlXJ+8DgZ4r zPxYfJu9SeN2G26jfcoyRwMgV1vg5xJoSsGZhvJyw5/GtzfkkZBx+lBkCkHdhj2NSbhJyhypPJFc 7qDf234iisEJNtanzZiOm7stdGpxwMBQv+RTfMGOOaTgg8kDpmkaRQG3MMAck8AD1rH0jXTfW97f TYSwhJETnqQOprDubu7vyz6ZfSS3lwDIka8qsX+0O1WbHwb5kOntPdTRQRbZpLQnI8wd810v2SBb 17zy284qF3noBTzOiLvc5B7gVMdskeTkLimgBHABJHrSOS+3azDbyc0uSATEOc8huOKI5D5mNxKq ORWde3Iv7n7BbsCxGZ3HHlj0+prSjSO3iWNF2oAFAHanbuPlOT1NAIzuO7OKXnado5x0oUjGc/40 gcAY9exqrGD9ulYHsOD3q3nrkg/j1pMnI5B56+tAbPB6fypCdx6Hr3pQSM85xShhjrwCKaGB55ye P/r0w8nDH24qTO0hSMZpMkZY44FPwOPpzSg5APHPtQDg4H6ikDcngkemKcKOR1HP50qnjjnNNZgB uPQcE1Eubhg/8I9KsenqO9APsaAcDocU0+5qK72/ZH3AjCHpSQHNrHjn5Vyalj+8a+d/h0p/4TfT v+un9K+g5TIB+5KBv9qoi13sH3Ce5PQ09DdGTDbMd+KezyY4CliaguGuzBugMaOCCSx421DfpJJY +erYljXerA8H1zVXw9q76lZ3txOQUjuHVT22gCsyKLUPEN0txMzW9qx/dhJOWA7496n1W4it/EFi ICJrziOSAjOE9at63JJeQnTY4t8s5G4jlVXuauhZ4YI44kjIRQnJ6gUw3F8dpWGL05brWB47mmGj xLtUf6bB/wChVSR9Yk1zWRo32eNzIoZpB04FNupvFscbGbVdMh2jrgDNcreeLdXsmbfqjTOz4X7O hxmnzHV5r6ym1dGM5dSrOOq5r1l5Jht8vAB9T2qCee/3gQRxYz94t+dZmsahqtqIYoPJ86WTbGeu 0dzis9dfvdJucahNHc2wkEbzqv3SfpVu2v28Q63FPZ4awtQf3pHDt7VdsbW7tmvlZIjDPKWUE/eB 6k0um6aNKZjbW8ahj13ZIX0HtUt5qVzb2090fs7wxKWJ3Zx6VnW+ra/9ijvFS0uYnXzFVTh9vWtS y1iTU7GO5s1Cgg7lkPQ05ry+faFSEHvk96z38QsdQGntLC92/wDDGSQv1I6VoSSX2AEMJOOeT0oM mp7QE8jryc0IbxAd5iJ+ppUN+XYMIVXtzQrXrMgJhx1+led+JWum1HWmQR7FILDPHSuk8F/apPCc MkYjEjHPJxWwFv8AIVvJUdxnrSY1F8vmEkcYx2p817c21rNNIIkiiUnI/iNVfDljcQ6fJdyFDPds ZWPqOwrQkGoMTtMS/wCFKFulTCmLd60J9t/i8r6ZqO8gu7qyuId6IHQplfeucsfCuoHTo7DUp0Fl ChHlQtgPzwWNa+laSNGiaOygijlcZLE5JHpmpxPqbO8bi33dduetMcasRtdYFXHIBzxSvLeRQpH+ 4Kn+9UwbUGz81uAMYqCddUmi2CSIHP8AexRGurRRlPPhJx3HIpsUmrSR482Fye4HSo7q61a1iILQ yzyfLEoHf3qTTrLUrOHZJLC8kh3SEDhj6Zq2DqTKdzRZPfHFK4vtoVZIt5pF/tDHMsQ9SBVqMXH2 cK7IzetRMLwkbpExn0qTbPgBShx69aqWhumup97oQMcAdKvDzg2cpj0xSAS93/ShhLlSr8U0+eQd sgHPNK3nMuN4U+o701UuA2TPkem2nukhICSlQe+2mRxzqpEk4kJPB28gU4xSiP8A12T67elIY5j/ AMvGB7RinBZwCDcDJ/2aaY7hsEXH4bab5NyHz9rYkdPlqdUm2jNxj/gNSBXzgSkHH90UpjkLcytw eQB1pxyvPmc9ORVaRPtUgySsaNyR3q0oAIAIHHAHpS7R6kegpRjnk80ZBUjPNNY47VWvTmwkGcFl NLaAi1hBP8PNWY87jmvnv4aRPJ40sZdvyK45PuDX0Fkgdun41m6hq9vYP5bM8spPEcYy35dqq2ut TiaZtUFtZwjmKMyfvcepqpr3il7aOD+zIhcM/wA0jDkIg7/U1M+qvqn2W1ltJ7ZLghiWx8wH8P41 DeanexXE+yFprZwYY0jH3GHTNS6HoN3o7vAlxG9hK7SsjL84duo+la9rptvaZaCMjPTJzj6UtysE EolWNTNJhA+MtVWxvpLrUL9cr5UDqiYHPTnNW3lEUbSycKoJOfSsVfFNvdErZWlxdAc5ROPzNc14 tvNe1OxhjXT47WH7VGVkkYls54yKfpHh7UbvU9T/ALQ1WRH81RJ5HAfj9K0rnwxpGnwtcXytNsBw ZnLfgKg0zRH1G8W/vIEt7WM5tbVVwP8AeNUPE0cj+K4FBYIXTAB4/Ku/wzDDZHtTWwQOoAOapapo w1Lyg8rxNESVeM9QadFplpa2n2Yopjbkq5zuPvToIYoD5MSxRccIpwMe1UtdmaKxXyb0W8vmBfMC 78e2DXL+I9T17SLBLa4kt5VuiFS4jyGUe4/nV3SzAmlS2Fkz3c10f3jAHYuepGe1R6PZava2Euip nykc/wClH+GM9h79q3J7mHw5p9tDsxESUDMeFOMgk9ga5N9Z1fU76KLUZfsNhO/lLJbjI3dsk+td ppej2ekw7LOJVZvvvnJP1J61pIrAfLjHr7elSoiheoA9MdqTYDj5hQqEHtgfmaUrxu456eteY+Kd Qtba81uC4H71yChHQYHeuy8JRxJ4WsBEQFaMFs+tW9NvodWt5WjjkhKSGMh15JHetHCKVGG+Y8D1 rntflg1ORNOilHyEPcqh5CjtTPDmo3kupTWt00bxGMPEij/VjsD7102FJJ46cmlKhhkHApPLDHJI yBmmtGR0I/CoyjmRdg4J5pwibaecZOSKpvADdxsm8Z61djjyuMnPvTDZqchkBC8j1pDbFnGBtAHN M8p1kKsAydj3py2+yRthLZ7NSXDJaQPczkIqdcVXsYHfdfT5Mj/cjPRV7VoLGGiAYYOacYhg4yTQ IiSB1x1xTvLAx+VGCcDHamGLnr/+ujYQueoIxiq1sjGe5fodwH5Va5I5JHrS4+uOtBU8A9v50eUC eaPLHTJ60nljqvJ/SjySR6GkETDGT1547U7aT155zQsXHoTSeTjPp7UojwMfjS4xyfrQFJPoARS+ Xj0yfSn4Pc1VuA821YmwoPzH1FTxx7U25JAPFO2888UpBPQ4zSAMOppNhJwf170OuMnvjtUcoHly hyMYpyjCYHYAU5Awzxz7189fD5pD4tso16vMGbHHAr6DZCwbB6jGfSsEaLcaf59xb343HLFpUBOP TPWm3VraXumJPNaRPcXhVckZJ7ZGfaorKy+y6jqlrawbLbylVeOCe9aJ015b+wnaQBLePhAOScYq xcy22lWctw0ZwpLlRyWb2qDRNaTWopT5ElvLC+Hic/MPSszXdevdP1xLe3geUfZy4VB945p0WozX 4fUmhkhtrVf3SMMNJJ/hmtXRLWSDTVedR58xMknHOT2q5PAk0LxyLuVhtI9qwVspPDpQW90fsTuA IZO2euDTPGS502zKkjN7F/OnaBGBr2snH/LYDnp0rVutPhu41jmQMiPuA7ZFS7AVK9j+lcFqsom8 fpEuSI3Tn8K76RNzZJJH5c1WvrqLTbN7qZGMaddvaq51myjvUtJJ9ryRCVQf7p6YrkrrULnVfEBs mXCRjKsr4UEHqT61o6neJbX9pqEDPcQwKY5miUtyRSWFld+IdPle4i8i2nO7r87EdD7CtHStFnj2 S6syTyQKEj4yPrj1NX57q000xKQIkmbahVMD2rGv9bis9ZuYLqcxwQxhPKUfPI7dMCsOLRptVF5a am9yLi3/AH1vC5yrDrz610t7FYX+gWtnqBS3ebasKAbcOOhFaFrdxSXUtirNJLaqPMOOOO1cfJqt z4muilncSRutzsgijPIAPzM/tXaXmqWen2we8uY0xgfMfmP0FTW0iXtslxDvMci5Unj9KsKpUZ7m kwfL7e3FeO+Ot0etalgrtLBWD9Tx1Fdd4e1/T9G8MabHeyunnAoh25zgZyfQV0tzfraLazRIjwXE gDOD93PQjFZGv6wrWzy6bfIJ7GQefGTgkegrnPBdnvfVNeuruJElaSMKW5z6n/CrPh59c0qye7g0 6G+glbcZI2+Yj6Guv0DWIdetmliilhdG2srjvWqI8dcYNKEGckDPrmnMuSDxxzx2pMKq5JxzmoXf +4M4PU1IGJBbGCfbrRv645I9R+lRw3SSSMn8aj9KlOFAGQM88mkIDdNuSeopM9QOo/WsVkbXL1XY kWVu/A7SMP6CttRlQcDb6Cm7pOqjAPrT1c4XdxnvTyT/AA4570gZWYgHFKfwIoHzDjt3pAMkEAfW oLMbhPzkGQ1Pt5/DtQE/Kl2npgYpAuBkHj6UBec8nmnAAdiOaMZGB2NAHGQMH0pCPx9qMEcCjPI9 h3pcDjnB7UnU/X1o68cZpOu4Y5HbNVLu5fzlt4AC/ViOwq1GgVdvU9zTiQNuO3HNBJ/+tQCOtOzz ijI9aTGeepHrUN0gkhK4znpj1zU3Q9O1KDn0r53+HLEeN7DnHzV9CZyMHkZ6VUv7YahGIfNYKHBZ VI+celIXs/NjRpoN6H5U3DK9uBULa1B/bEVhHG0jPnMi42rgZwazPFOqGwKvHfCF4V80RjkyjP3R Wd4i1e/1DRreSxg+zxNNHiWTrk+grpNG0pdKhkaSTzJ5m8yaVv4mq+0aGQOVXco+VgOaUorg5wR3 3dqGlWJWkkKhR/ETgAVjXHiaGUtHpcL38w4xF90H3aiy0me4nF3q0nmXHVIl+5F/9eqXjaRhZ2K9 c3seSOnWpvD77tc1sAceepx68VvtgLhjxzyajMY3A7u/HHWvOL35/iVIA+G8+MYPH8Jr0pm6k8mo Z7eO7t5IJQrxSDawBrGsvDUMDySXsn2okbE3jGxOwB9qsP4a0yS3WJoBtB3ZDYJNN1WFNP0CaGzi WMSYjC9Bz3z61m69qVzp1xZabb7reCSAkTBd2SBwi+5rOh127WAeffG3vbaEO0Mq4WQenrmrraTq mpiF0uI/sE7rcMsmd8Z6kCrWo+Eob/Wlv3nCREq7jHz7l6YParOoeItP0zW4rO6iKvNHu+0MMBc8 YJrF8Va1ouqW1zaLdBbmzXzoZV5G8dADXMW2o6w+nSxQlopru5VmlIOZVIGMHt3rs4vAWl28ontp Zra6ZAHaOTlj3zWhYeF9LsZvNdPPuCciSc7jn6HitpFTYuzAA7DoKgur22tIpZp5kSKNdzgnoKyp fF2kW9rHLLdeWZRuRGHzEZ4IHfNeUeNr2zv9bvbhZHLOR5cTqV7e9dXDb3UnhnQL21NszHMMpmXK KG4GR9aefDF9YRS6fNdyXMsa+faqhIUMDyv0q5rnhiweVrm9TbdXnlrEisQd/fNbdj4R0W2dJFhG Yxhhu+Ut3yOlbdpawWMCwQosca8gZp6NFC3HloGPQADJqXzB13Lgd80gkQnrml3gsMY20wlW4GMf Wml4hlAyg+maV5owwQyKpPQE4qNp4i5VZYwRwfm5NKpgQ7tyBiMDJp3mxTKQWjJ+tNjeJXwrg+gz WXfXsN1OdOS5Vef3rq3Ke31rSt2t4IVjieMIgCgZBH/66eJoS6fvFB7AGl85ATmReMnk9KRp7d4c mUbO3NCzQBFVZUxng7hzR9phySJUK+u4U4XETcrIpx70puIdobzUA+tNaeMcpKpJI7iqmm3Ea/ah 5qELcPkZ6VcF3BnAljz2GaU3cAIBnjB9moF1FwPNTJ96X7XD/wA9F/OlaeNV3M6hfUmmG8gDhPOQ sRkDcOR60j31si72nj44+9Qt7bPnbcR4HP3hTRf2mP8Aj5j/AO+qd9qt/wDnqhJ6DcKRry3Df61c +hPFPW4ixu8xTnkUvnITlXB74pBIHBKk8cH2qvdX0cJWJTmWToo60sPl27qGOZH+8SOfpVkOM47j oKcWyOvH0pM/4UO2Dj+lN8wA4bjmlDg4/Xinbhwe44NQyy7ZIh/ebpUpOeP4iKVBtyD1r55+HHPj jT89n/pXvWpPbw2b3N0D5cQzhcg1zWkb/ETG4t7hbW0JIMEb/vGX/az0qHTvC2kzvqsn2aQoj7Ym LtuBC84OfWs7wvdXdveQvqllOYG3R206jOzB6sK3orQ6hresy3FmsqxIIoHcdQRyBWr/AGPDcada QXi7hbsrAA9x0/Co7vUNJsi0d1cIHHBXccn8KzJfEVhuP9nafeXch4yoIH5nipVbxHdNiO0t7CJ+ cySb2x+FPbwkl8+7Vr24uwB/qy21R+ArShtNPtkSyijjiOPliU4JH0FYEur2w1VrVtPmNk0oi89J TgP703xjp0KW+mJDlNt/GWAYnPNTaDZpNruumSNgv2gAHcRxgVtnRbV4yGjcjvmQ80p0myIUbD8p +UmQ/wCNcB9ktz49RI4ym64GSWz0B716FJY2zoQyMQfRjVddGslfiJskc4kb/GlfSbVVDGJtwOfv n/Gmx6baklxC4J65c1n63plnNLYwmNtssq8b2HA/Grl1pNneWItYW2GF9yspLeWRVYeF9O8zfeQf arnIIklOT+XpWZr2tn+2o9Mj22yBdxuZMr8voo7mk0/ULaPVprW/d5IDEJYJ5SU346g1i2mgR+Iv EmqJfJMUMIks2Ynao7V02k+D7SJpZr22jMk4XzYDgqpHAYflXRC1gwi+TGBEBgbelUby30kMs968 YyeHeUgE/gad9g00yoFAEpBMY805+oGayNGuDcapf6RqgLyWx3RtuI3IfYVNr3hJNTt44LSQW3zg yE5O4Cq9vaJdaddvcW8D3VuwiScJnIB/SuC8f2Ntctd3gwLiOVEwONw2jj8Otd1oPgyzi0CGP7RO VmWORxvyuRzkeldILC182OXywZEBAbJ49axYbaDVfFzyshaLTgApJ48w9TW5/Z9rgAxgLnJIY8mp RbRYAK8Hpk01rSF9oaPgHg5qT7NEVKhOPrTPs0WeFGR7nFBt4mONmQfc0fYoB/AOfc1AdNtGk3tE Mnvk0j6bamMI0JbB6huRUf8AZdiUwbZD3PzHNSR6PYghlh2nHOXJp39n2ikt5IU9jzVS+jggxHaw hrmQYAyePU1Jp+iWmnw7I4U3ud8j9Sx9ealSwtAWzAvqRzSjTrWNiywgk/Xih9OtMLujBA5Byc0q 2FsxDiFA47ZOP8Km+xwPjdGuVPYUxrG22GPylw3Xiljs4IhhI16betBhhVSjICPpSC3hYphBx2FZ 2jQxst6dg5vJOuO2K0DbQ90AB6nHQ04QwhQBHG3vtp+yPIxGme/FKUXbzGmCecDpSFd3BQMvbgUg gjOMxp167elDW8cnyskZXrgqKVYYgAFijwTxhRSi2gGQsMZHptHWn+TH2jXPrtFAhjJ5jQ8f3aDE oG3auAOwxSLGiZ44+nWobu4W1QkL+8PCKP4qS1tTkTzKPPbqcdKtbe7BeDwaMYY5IJpTxycDHc0c eopDk45/KjGW7HHtS4OM579xS4PtUDruuFbjIH61LwpI6c0u0OPmr54+Gxx43sOMEvk19CyKjgja rZ+8DzxXONppbxRBPaQ/ZIbYfvXAwJs/w4rct7WO1WQRJgZLHPcnmpVRdgQINg6ACl4BxtG49lqK S5htzmaVFYjHzN+lRHT7QzGZraNpe7Fck1BY363F7NDb24EEPHnDgM3oKlsNQjv7WWWNW2RuyHvy DVa+1hU0o3FuvmysxSJCcbmHauU8NR38uryalqNtcm/YMFR1ISIex71paL4fv5njk1bbFFDK0qQI fvsTwxqbxoD5ujHpm8Qn+lWfD5b+0dZkOGBuSP5V0Bxnpj+tNMYAI6d68ygkMvxCQkHAusYHOPlN el8bM9B1puQPr37ZpfRmyCKgvUla1nW2fbPsO1hyR+HrXmer3qyX+nxSS311dcsyIe/pjtWroGuT aVq621xYy29ncEIWkbJVx0z9a7zAOTh8571leIdATW4YHAUXdvIHic/qD7VcutJs9RWH7bbpI8YB HoPpT2vbS38xSyoYI9zgD7o7c/0qnb69Be2N7cRI4a3BJVxjt/I1zVz4lv7nwjHczqN0l0ImMP8A EhPQfWsG4nePxFcW01stnFKAY/tD5VV7nH96tfULW/1C/wBEk0MyW8VuGiE55D/UenFbfh/RNTi8 SXOr6s0XmSRCPbGeDjviugu4zc20kCSmJnBAZOSKi0zT4NMsUs4S7bRuLOcux9T9a8s8XW76h40l 0oER/aJARu6DKgV6ppFrJYaRbWs7h5IUCFh0IqXULxLCxmuHAEcKkgeprP8ADVi9lpQec/v7g+dI TzknpWznP07UA5PA6UhPzDORRkEgD6cUnRh/Ol4z1xkUFgCCTxTc4GT0xQOV/p61G44Zhzg4py9T v6EYOarXt+llFu/5aOQI065osrYRl7iQ7ppB3/hq1kdOcDjFHByAaUH5sHnBzmg4BBPQUbh0pC2c H0OKG69TnHFHO/pxmoz8x7CnopGCOSazdHVvKvMr/wAvb1oqxPYnJ/Knlflbd+lOUADHOBzzSAcH B5pQcY70vQEdDTCMYIA45xWD4n1mXTYFhswgvWQyruPCoOprW0qeS50u0nuABNJEGYehNXVJ9qTO 1ufSlyOc9uaiubiO1h3P93sPX2qraxNLILq6GZMfIv8AcH+NXR6Hntmkd8YPfH61Vg1ayuL5rWO5 je4QfNGpyauZyc9ATgg0Z9/1p3r19aDxz+ZpM/TJoJ4/Dp3qMc3OcHOMVKeR1z9KF4+lfO/w1XHj ewOScEdfXFfQZyV4HOMisfUL/UP7QFppltGzBdzSyNhV9frVa8v7rSnhSe8jknuM7VIwq+pNT2Or XLmzW5VCt1I6hxxkKOCBU+vWs15YsIr2a12Asxj4JFY2h+DNOaG3vbpp7iYnzAXcnn6Vua9cz2el SG2ZFncrEjt0XPc1kW326a5l0qwZILW2RS87Hc0hPcUzRdK12xiltJpYEt2mZjKrbncE+nY1d03w vBpt8bhrqaZVYmONzkIx6mt4jaQ3fHSkHC49P/11znjLn+yFZhhr1OaXwtzc6sQcj7Y3X8K6PknP qaDkjHOe1eUWEp/4WeYmPW6yuO2FPWvU93QDr70bPlySAfpTcgDgnNJkZJyVwc5xXnMl3AnjlW02 MvJM7pk8bXPU4qlO8c2sXFtbx3l5cW4bEu0t+869PWuy0nxC8lnZC8eJJHUtPz9zHb61fk8TWqy+ XBBd3XHW3h3D86l0+/vNTjuN9jLYgAqjy9/Q4rk9Ztbvw/os0MV2L2e6l/eIE+ds+laNuLjXNNmt LS1extXjCySyja8pxjGO1VbP4aQQabHby3t2OQzxo+VzntXQaf4f03R43yvmuzZaSdgx/DNWJdY0 62yr3UK7egB6Vk3/AI3023lCxrNO7fdZV+UfjWdN4+bynZVtxtyNkTeax+tYdz4s8TajzpFlcl2+ 8fK2it3wl4Tu4b9tY1+QzXswzsbkx+1drk54bIJ6gVheIyt61npUZ/4+ZQzj1Qda3RtQBV4TgD2x SdMFjjPP1py9z07ihsc+lIcYyDzinAZOenqe9IfXmmbRk8npn60mSTgke1KNx4xjjvS4Kj29BUNz OLeJppMgKOn9Ko2Fq11Ml9djEmfkTsq/41qFOMBuD+tLgtgEDH86Yw2tnJ+uKcMdjmhiCvzdzilK r/8ArpoXg98d6XYRznH0p2DkccHpTQgycjFOB5465/LNZ+lMHW72/MPtUnPpWiHCnkgk9jxgVEJ4 33CKRTt+9g9Pr6VlN4lgF7DbLDcSRu2zzlT5CfY96ytZ1e7vta/sbTJnguh98gYwPXNdVbRvDbRr JJvdFAZj1JpbqeO0tpJpDhI03E+tcbN/aU6299HqUy3k8wKWqnKCM9AR2qh4tj1KbxtB9it/tHlW ++SHoHHcV1+ga3HrdqT5MltLCdskLjlfStf1PHTgUAg5LYGKjuLqO2jDzOFXtnjNUrZJLycXN2qg J/q0P9a0VZXBxjr1FYep+JBaakLGzs5by7wGdE4CL61W8Xa//ZuhSLbt/psq7EiH3snsPes/wRot 0vl3l9afZRGpSNQfnbJyWau1GT945x0OMUoPvRkHr1pTwCck9qTp6ZoIPOT34zTV5dmU9DzUgHqT j0pVx2PFfPvwuTzfG1qMHhS3Ne9zu8a7ok3npgGuTubK61bxNMhmubWBIhvSFsFvbNJd2VtpGoWt zLps00AQoX++wOeCRWhqVhPrVhbTWRa0uIH327Fc/XI+lSw6bcR6fOkryS3UyMrSscgfQVd0+N7O zit/KYhFClj1qW6gF3E0M1uskLjBVhkVWsrOHTQ0NnYCJG6lfTtVsySBQRCxJHJqM3EofH2c8d89 KcZpQflgbmk89/mzEw9Mc1zXjGeRptDBjwGvAOT0qbwrPJs1N1jZgbx+a3WupgcC2duc5FAvJiR/ or88Y9K8l0zzR8WuUJxdsCM4xwa9WuLqeJgI4GcdM9KQXU+3AtWGeuTUZv5gD/ojcVG19dngWUhP b5uBXC+ObW50+4g1yzh+z7GAuQo/8ep/hK7v7Tws1xBAyz3MnM7cDk9am0rRLmLX7rIhuJ5AJl39 MHrgdq7a0muLSEm6W3QLwNjDiobnxXpdoG+0XkQf+4rZY/SsK58eaSbhZYdPlmk/hcgDB9azL34m 3ccnlRWMMbjnLvuz9MVgzeOte1Jn/wBIliRTgCKEqT+NRRW3iTVM/Y7S5cE/NJcEtj6HtW9a/DrW rpEkvtVeIPgMg5OK2LL4b6Xatm4FzdsrZJeTC10Fto1jYQlbTTYY93ovSrZkkixtt1H04FSM0pCs q8j0pommDlWiCqBknPSsHSJ21XVrrU1i/cxDybbnsOp/GtkzXBb5oABjGd1WFdzg7OnbNReZMCT5 PTtmlaSTcMRlt3UZxinF5c48sdMZzTfOm6bMke9PjlkY4KBf1zQWbPQe9NHmE5CKfxqbMgAGwEkd M0xpWUHKDp1J4FUImkv3M0sTCFT+7Dfx+5q1LLOMKsQZT3zjNP3z5+4uCPWmtLceaf3QKHoQ1SB5 uWEYA9zSb5h/yyGe3PWkV7gnmEexB4pS8p6ImRn+KjfOF4jHXkZzSjzVxmPLEc/NxTJbloY/Mk2J GvUlsAVnReJdPmvorWOUmWXOw4O0nvg1evLiS2tJ5VjyIlLAMetcRc+IdSu3e10y2mijceazwrlw D39qk8RatLeeF/8AQ2vpDENrzKNqlhx8xqG3h1XTdKVDZqb+/RY4xCflI6nI9x3rX0ue8Ij87Srg zR/LGHXbHHVKz8LTavfaheXrXFlerN+5ljfB24/Wum0uz1eylMd3dR3kOPllZdr/AI+tWLu0bUbS W2uYx5EikOQ+Cfp6VBpWjQacvlwREYXAkd9z47c1aKSmfzVgi8zGC7HkVTv9RtNF3Xd4EhMzBWcd M1PbajHfqZLGWOWPHO1qnaWaPLShFVR97dXF+ItWvb26jsmsXeCdC1qE+/5gPU+1W7LxRqsulXTT aYgexQpOWfByB6U7TbtF1i1OmXZlju0zPbkllj9wexq54kXT8DETtqTHEJhH7xT2OfSl1Lw/c6vp Np5k6w38DLIsmMnePX1qOKx8XOh8/U7JOf4YBn881s6Za3drA/2+8+0u5Bzt27avg5Y+1ICcZHrS nnqTz7cUYIPPGaXIwfTrxVSxE3lyeeVYmVtnbC54FXAM5yKdXgfwo58bKQcYib5ele7nJ6cZz9ar w2yRXMk/JllADYPpVggHOM5NKDnHHPv/AEoB5wPyobJHfI/Ckzu59e1Gcnv07mkJCt39OtL/AHiB n8etIc8YwCBxzSFcLx2/WuX8ZhTqWgZzzd8Y+lWfBgP2XUTjBN7J/SuiyTnnA9c0m45x3z615Bps gX4wOmMlrlicfQ16wegG7OaQk/hVWa5t4M+bPGo/2nFULnxHpUA+e73BeyAnP5Vzmu+NNOn0ue3k sLmSOQbWDjCYrkbp9ZjaGy0iKY2a7ZBEDuU56YNR6tr+sWWpW73wms3WPy2jiUAlexrMuNRv9S1C ERSXDLO2xXmJwSfeu68P/Cx7GZZby4EoIyUVsYPua6iPwXYRq6mOMBwVO1efzqew8HaJpjB7exTf jaS5z+Va/wBitlQKIIlUHpt61NtCpgEIpH0FKrBl+UhsdhS9M4HB9+KQsMdsexppUnjsPejd1XnH YjvWbr12tppzDed85EKfVuKtadZJp9hDbRjCIu3HqfWrDNntmmqSBwzAU4Hn1OOtIxOfqOTSquVz 396GUggnOe+OwpDkZ29fp2pwTd1B+vrTxGAMc4pPl255AAyTVEMNQZkCg24PODjJH9KucJ8oG3jA 9MUY4Ck9/SlHUk8jsPamkEsAoAHWsy41xDdG2sbeW6kU/MU+6p96uy3kdqkJucRSSsEAHI3HtUWo agtkUjjUPcSE+XHnt3JqHTr27vbGdjFCsqErGQ3yP+NZFr4muLvXIdKuoPsdzEd0m4/K/oAe9dYv 8QHT096xvFMPm+HbkIMtGu/b/exWRa3F3camwh0tsRRqkMjABEyoy1Og0/X5rVtPu5Ivs7uS9wD8 xX2pyaLeJrQl04CGEwmGSRj97049a1ptFt5NEk0wgiKX7xHGTnORS2OjCznWaS4luHjXam/nyx7e 9af8IwQB9Kfnnnr0z70hcAgHAJPT1qlda3YWt+LOaYJOy7tpB6VBp/iPTdRkmSC5jZojh88flWfZ 69eaj4ma1tolOmxA75SOp+tP8VfLNpe/aYRdbXQjIIINZN5Z2en+I7VdDLxXG/E8cR/dhOpLfjXQ FY9ZJUsTaq3UDAkI/pmmappct3qel3NuEVLaQmQjqVxwKvJpiJdXM20N9oxvB4B+tS29jbWK7beC OJSctsXGaeIYxJ5nlr5p43dwPrUny4O7nHqOlA2nlSuPbmnE9Ru/SmE7efwxSAnaPfvTsnGce/Wn dfofemSn92xI4xRECkY+XPAxTwe2T1704dcdfevAfhVdRWfjAyXEoRRbthiM/rXu0NzDOu6CRJAP 7rZ4qQHt932pwyccigAjBzj601gfxFKuCOvI5zSkkYwO/NICemOe9NLYOOlA65OR/SnBaARnpXLe Mj/xNfD3H/L5/Sp/BzZtdR/6/pP6V0BJ4OPoaaeoye9eL3M02kfE1r2a2k2xXDFWzgMCD61q6h8U L0TNFYWKMQ2Ny5bB9xWcur+KNcvApe78s8lYo9gx+NV77WYtMlaB9GuTc5+Y3MjN+IHSptLs/EXi LQzNp88CCNypRIxGR9T1NIPht4mvWDXdyoTr875zj2rtfBuny6dFcaXPNFKYCGSRSOP8a5/xfPYW Hi5ZtVtzfJOgCJyoQ9MfjWjr2m6jqGhRQ22m2dgsbrLDucBlx39KqNrWrrKLe+8RW6FFBaK2t97H 2yK7O18RWB0pLy8n8hU4bz/lYn129azv+EyN63/Ek0+a4QtgzP8AKn4ZqlrOu6raxRCbU7SzdzlI 4U80sPTnpU9r4dinia61fWbiZfvEefsVfyrKig0u51Fk0vVdQs7cAgzGRnDsOuM1s2t9qdizxwX0 OqwoMhCAshH17muh07UodQtllhx1w4/iQ9xV1uT6+uKYQOFIAPc1z4tv7Z8VC4lObbTxiJR03ng5 +lb+GOMAjufX60rADGcc0EE49e570oJGAPxo2KGyMn3pUK+vHv3pw69aQA7wQM8Ypc45xgUpP+RV acNcN5SAbP8Alp7/AEp4aCBCoaONOwYgCqN3r2l2p/f30C54wHB/lVJfGuincsdzJKw7LE3P6Uyb xvpcUTySLMgj/vIVzWxpmow6tp0V7bq4hlHylhg4rD0X7bFdapFbJGyi5YbmPSl1y6mtdQ0uS+SR wjFmWFSy7u3Sq1zpF7q3iBdV+zMLbywixSSFW+uB/Wuito7mGIq0MMYAxGiZxWfJ4aivreb7aw+1 u+/zU4Kntg1s2sTQ20cTyFigxvJ5P1pZUWVGRxlSMMD6UixiOILGRtXhcD+dI3EbGQgA9wQMVXsJ I3tgYZEkwx3FSCAasghhjpj9KqatqC6ZZmVleRiwCqpwWJ7VTtNZvHvWhvbVIQsW9ip3FR70t1c3 GptFBpkvlpIm57krnC+w9a5G51HWJNQS0s4ri6u9MbczlsBhnow9619Pu/7b8TSNdWxQTWIC5/hP OfxzU2keHXSa3a6s4oVgRo2K9ZSe5qXT9H1nTbY2Fpc26W4ZmSbbmQDPTHSr8mixyWTQ3Fw7yOQz yNyQfb0qK1sY2kMFoiraL/rZCdzSEeh7itdNqABQAoGFUDAWngc4BHA4qO4uobSAy3MqxxDqWOBi qmqatDpukS6jzIirlAo5z2qXR9Ti1fTIb2EgJImcHjae9cXrOuyazrtxpcF8bRIWCRiI5efI5wTw BXVeGNKm0fTBDPcNOx+YM5yRntWv9456A0x8rgcgeppUHIPY9KdwM7e/ajtwPy7UyRlVS3RTgU/j g7unTikbqOc805T8x/WvB/hJBHP4wdXRZENs2UIyD0r2G40CEtusGe0mHIKfdP1FV01e80xlj1iD KjgXMXKf8CHUGtiKeO4QSQSBkHR1Oc+1TZ9vzPejrkevOabznqeR2707oowNp9zWJfeKLe0vfsqw TzvjJ8pMgfjVf/hMLTOJbS8jXGSWiOKtW3ijTLk48/YT08xSv861Y5kmAMbxtnkYNObI6k59AK5f xec6x4d4yBdnJ/CpvBn/AB56gMg/6dJj9K6Fz1IXPcg004K5IwWrIm8P2ElyZ5rcTSZz+8O4D8Km g0mwtn8yK0iV2PUIKtABWA/IVBPZ21zgzwRyOpyCVya55/Dmppqt09hex21nMdxAT5ge9PtvCV68 jPqet3EqbsKsfy8e9cJ9nudI8U3unxtIsyv/AKPkkgr6/wD662tfsLjU9Bl/tG4D3cSb43JXJcH2 qC51bRrKysrsNdalNtAmgYkqSRk+3FZ9v4z1GW9SLw9otvAzn93ldznvye1XdNv7Ke4abxHHt1OR S6lzuDHOMAdq6lr9THMdUZNOSOPEEe35ORw3pXKaUmjvqtxe3F7cXUhG2BIhuJ9TWkuiXF/cPJZa XM0J+79tk2of+AitaXTfEtvaKsKacybcGKNMNj0UnirmjXmnxW5Qae0LRPiQFdzo3vj+dRx31pb+ KxNYzL5N1+7uEAwPM/hP5VrJr0EmrPp6Fsxpulf+BOemfWqer+LNOsrWUQ3Ub3QGEQfN83Y1Doeu 6RZ2Mdsssu+TLszxsAzHqc10iuJSrxspDdCORQzfNyw/HFKpUEfNn8aVWUjAIPsD1pQ6sef50iEA E8ZB4GOKY9xFCcyyxoB1JbGKzLrxXpVm203QdmONsI3VB/wklxdBhpul3Moz9+T5R+FRyt4ivlKI 9nYjocZZgPekh8M3ALC61q6kBHIUBR+lWU8KaWUHnGScr3aYmp08O6NGVxZWu4cjIBP61ditbSP7 kUKEHooFQSaVZTMJLmJZSGzlzkflV1TGiAR7VCjAC8Cq1nZxWtxcSK4P2h/Mbtire/OdrAn1zRvX k7lwepzUUV5DMSsUyOy53BWBp3nKRkMCo9+lCTJIpMZWRc/w1ELy3M3lLcxNL/Cm8E+4xWXN4ija +NlYQtcTIdsmCFCn8etUfFIumW28yOY6YFJuTB98H39vpWpoCWSaRbtpqKttIoYHufTPvWjuQk8j PsayvEVq97pREfM0LrIhHXg/4Vkrpif2zE1rczfaJ3E0x7BfQ1s6Hpk2lG8MtwJI5ZzJGM/cB7VY tdLtLPU7u+iz51zgS5PHHSp7e0gt8eWifKSc981naTqUmo6nqZbBt4XEaY9R1rW3qASWXA59qzrh zfym3hZlgHMso/iHoKsSz22lWbOSEhjAHy1OHEiCQfdYZHPanBlwcYHsK4+9v9O1vWLiPULpPsVi djRluHf198VV17xJ9s+x6dotjJcyF8xq42o4X1qnp2k65JqMcGr3CafaTyGRIIWOM/3a6q40LQYo Ire4jhi4yrFgGP41j2ryweKLa10TUJbm2B/0lZDvWJfTNduuDjb37ikdgAMtn2IoyD0OR1pQw556 c03Py5U8Y6VHdBTsTcFLuBipgQNpOQMcU889uaRAQSf1rwT4ULP/AMJZIbQK0i274DnHpXrx1mFX FrqiPaSMflYn5WPsa0fs0LKx/wBYsgwc8g1kP4cezm+0aJctbOTl4mJMbf4USa5c6e+NTsJVUnmS Ab1H1q7a61pOoKv2e9iZjwE3gN+VVtSfUjeR2ukPDGsilmlkOeR6VVg0rxG8ZdtdAPPy+UCAKrjw lrQ3D+3mAc5JSMCoz4Q1V2LPrV1ID06YqXSPCF5a6iZNQvEuoNuBG6g5/Grk/gvT3GbWS6s5Cx5i kP8AI1DHoev2qlLfXWZO3mIC1Y17PdT6ro9rezCa6tdQKNIvAPyg/wBa2fBkavZ6geSWvZTjOK2n 02CQklpQeh+c0jWSCEKpcEccsahm0+OQ/OZeOOGpxsImZSN42jAIc04WcSEn58567jTjaxlNp3dM Z3GkWzi4Ub+OOWPNP+xRAABm9/mJrm/GGgW0lvb36RAXMUgQyFyBtPXdimweDrbVLcTXl2ZIJFG1 LfhQPr1qZvB9tbeGrnTIoxIrkyRjGGX8fWvONLt/s+pT273z2lmo8x5FA3Ajse4PatrTdI0nXYpt QtGjQRHMZmf94Wx1PotdFp3heHW7cT63eHUjnCxhsRJ+XWups9IsbGPZbWsMYA2jYgGB9anWGNQB huDxzTLp1t7d5TG8gXnYp+Y/hXG/a7zUvEGoJaxS29p5afaMf63HbApviq4stJ8LwrpaqSsoXeo3 GM/3j3z9ap+H9O0RrTztR15Jy7lynmeXlvfvW3p9hpt/rINhbW7WlkvMg5DSH3+lXdduoXmj0u3i Q3N3x0+4o6n2rbtbOK1jSONSQoAB3daR7SCXJK5PoTQLWAAArhVGBlscVkahrug6Tl5bqMt0Mcb7 mz9BzVSLxHcXz40jR7hxjIll+RT+dLLpniTURia+isYG6pCpZqls/BOnqpN3Jc3r5+9K569+BWtB pFjaKPItoYwvU7R0+tSyzeVhOrnhVHb3qOHToI9zBSZJeWIY1YWCONdqA7QMAZpgsrcA/u/x3GlF hb9fLJI6ZJp/2WEfdTH40rwROcMvPTrTJIIUXc/yqvLHPT3rOs9QtL67lWC3kaJODMThD9PWrscN op2x4OTz8/JrE1HUJLa6V0t0XT4XCTSOx3c9xUeoa1pnhmcBIkWCRPMkKfMzZOKLa+gmub+3tsyC W0NzbkH224H41m6XeSw+B4bexmVtSc7XjD/vAN3zceoFP0PSD/ai3DWs6rE2UDDaCe7EnkmtXV9J l1C7xb2qRYkDtcA4P6VZvdD+2grNfXHkY+aJWwGGPXrVrS7O3tNLgt4ExEi4RSamW3QN8wIBqQWy Z+ZckjqDSiBQWO0dOg/xoeCIqQV+Udqqahc29i9sksbFZnEYfPGT0qa9eKwspp2GEjUscGsrwpZe ToiTldsl0TMzE9CTVHxndmTSprS2lEALAPcF8KlVfDvjG2uNMhso7eW4vIx5brCpKkjoS3oas3Wr x6n4bnSVBDOJhFJF3B3V0yBba0QSdEUKfahiZbZ2gGWKnb9a4fTtG0u7sxaSaRcvehi0kjKVBOTz k8V1SaPF/aVtesWD28XlrGBgDPf61fmtYLraJIwdjblz2PrVfU9DsNYhWO+txIE6EHBFS6fpdnpU PlWMCQKeTt7/AFNXFx3PH5UEc9P/AK9AUIOn503AYH9c0fLlRjHPQVG6BriLKhgM/MeoPapxyelL gLnmlBzXhXwfCt4yk4IP2V8A9jkV7Vc28N5CYrmNHQ9iM/8A6qxbnQ77T18zQboo4/5YTHcje2e1 LF4lmtF26xp89tJjBkQbk/CtKy1jT9QX/RrmOTP8OeT9RUd14f0y7bfJZwq+c70UKfzFcfr1hYaR eJ5M1xbRtFIxbeThgM4rU8O6rjwol9NKWjETM5zk+lbuhzPNo1v5v+tC4Y5zitLcvUj0700n5jno OwpcDHJJzUM8v2eGR2UlF+9s5NeZavrmn/8ACZWkpufLjFx5siuMFSBWj4V8Sq0V5BZCIvJdO4eV wBg98d/wrs7KK6SNjezrO55yi4Vfp3qyD3/HrTCS2e3uKXgD69Kbn5sUoIJ605VDHrxUiL8vGKhv LSO+tJracZikBU49K5rS8+EVbTJxPcRE7rdgpYgehx0p95qGv6jhNHs1toyebic8n6CuH8VeANRt rI38t99peWTE5VduAfbvzWh4M+HkyTm9vrlhCCNiKMeZ9favTI4Y4lCRxpGv91QAKd0zyQPU0ZGA xwMdzVbUr+Kxtt7fNK3yxoO5rIs7eaFZ5IsvfXZBllXlYyPekkt4JtWgsokWTycy3TFchj2B96dr mlaRBbeZJY2xuZDsjGwck+1WtC0K30O18uBAhdt7gZAJ9qym1eLSNdvZL2zu3nfAjlSPd8ntU3/C Xy3AUWOi3sxHHz/J/Omyt4t1IBYIrTTIT3Y72qWLwlJcJ/xN9Uubp+p2naufpWhY+GNK08kwWUQk J++RuJ/OtQKu0IuAOy9qdwcdSD2pOmTjimSuqR5f7vTGKrxRPkzTH5mPHHQVZONpbHB7DrTgcnry KXHUk9ehpRkLnPPfmmDIA55pevP61h63Hc3F7FCYJZLJkzIEONx/uk1Vnut62mn3ukm3t5pBGiiY ZHvgc1S0XRbYa5rSFJFWFlMJDnhSPerFn4csdSsbwuJ5Vd2VQ7nBI6Gqkvgaaa8tJYHjijSFVk3Z b5gQenuK6O18P2Wn6nJf20OyV12HqQF68enNWYtOs4rj7THbRJMf4wo3VYfkbmzyeM+lRyTR20bz SsEjjU5YnpVO41TT7a3V57mKISj5HY4yKsWWPssOJFZdmQfUU67uEtraSVz8q5/E1m6NqV5fyXKX kCQhPuhTnitgNlR/CwP51z2k39zHJqdneTqZoSzwlv7prLtfEsWs21jZFGa/FwpkQrjAB61veKpf +JWLVcA3Uqwj6GrWzZBHaW5wEUKXH8PrWF4r0m0k07TbaRGMBvFVgT9/OeDVzTtOj0bX2S0gEdvc xA4UYwRT7rwnZ3etJqbPKroctEpwjnsSK2iM8FRg9qNo2gAAgHg0uDwOcdcH1pQcjndj60YOT79q euAf6+tJj5unB9aX8MGkJPPNHGBzgUcbcj/9dNxt2kn6U5cl+eo4p4wO/PSg8dSPxoGOOe1eF/B7 /kc5PT7K/wDSvbhkkHOBUgYk+9NOHU7wpB9eRWTeeF9LvX3yWoSTH+sjbaR+VUZfCDrDi21i9iHb LZFcxrWkSW7Sw39nqepSFcJcRnKr9BVay1ax0/Tray+w3cMHS4cxnLexrZs/H2nS6h5gjkit3TbJ +7OQw6VrR+PdEZ3VpphgDkxmn/8ACf6ExI+1sD6eWaU+PdCGc3bdOhjIpp8e+H2GPtZBPX5DXC+J bnRdR8b2syS27QSITLI4wM44/GtDwtLarpUpEEV7Cs7Dy0T5wPX6V176Z5CmXTLlrZyNwiZsg/XN X7OSaS1QziMTn/WiM5Gfaphxk9fpUFzf21oVFxMkZc4QMfvGlW6gdvLWeMyYyV3c4qVPl5wB71Lz weD9acGwxGRz1FOEi7u3PYVHcTRwQtJKQAgLE98VyOmeOrjVVcwaPczIHZVki5U4NXxr32y9i0zU dMmg+1gqCxypx/WtqNY4Y1jQgIgCqOmKSS6t4gDLNGg/3qh/tey8ppWuY0jXrIxrObxKt7KYNHt5 LuQceaBiNPcmqkugi8uD9une7u5AcgEiOIdsU5opPDEUdvBfvcNINtvA33gf8K2NPsxplq0t0yia TMlxJ6n/AOtVPTlfWNQ/tSXDWqfLaoRyPVq3vlO09s9TStjIB5P+71oCdB09cGl6/wB4+lJvHXIJ 6cUgIZtoo24PUfhQM8etNd1iDbgdoGSexqCINM3nP8y9Qh9PWp92Dnkn09BQX+6V5A60hOWHY4xi n7uPm70ozyfSmk4Oe1OTv69OaQrgqcNnqazYNHI1N768lM8wOIweBEPUVfWBFlklWNQ7gBie4HSn qixg7FCqDnA9afwvVaQyr5mwsM9SCe1VRqVq1+1msyfalGSgPOKzNR8W6Rp10Lae7UXA6qnzGsPx HrNlrlnb29ndskj3ceVfjdz09xTdYs9Ot7e5ub2F7y9LCFI1B/djttFWU1+2gfRJwxS3fdbyBxgq ewIpPGmow3GmQiJ3a2S5VZ5IjjC10mm2ttb2Uf2PJhYbt5OS3pk1c6YOMkcDH86xtW8L2er30V1M 8qSRcExtjeOuDWjDp1rBOJooI0kC7WZV+bHaue1yV7/xjpdlEc+SrSue3+RXT2sCQxhVBJbqT/FU d7YwX4i+0xhhHIJFUnGGHSpcAY4OMZC+hqVed3fgVEev4c0bsHqB3HFOBBHtSZP0NKPm6ZFPA25A GaUEYyPxyKMn/IpOcjjj170FRsG7p7UdOOMGjjIHJxTFfdK3y9MVKMbRgUnXvz+lOFeFfB3jxk/J 4tX/AJivbSwB5zUb3RjQkRO3svWkjv4pCF+ZWPUMMEVK04UjKMVz1HSlM2ccHPtTHuNm3CSfhTS6 OGzCenOVFYnh90Z9QjkgUhblsfIK1J4bRtz/AGJW29T5YzTPsGnSkFrCMhh1MY4qALpE1o84s43Q OY8CMdQcVTNx4fWAyz2kUaqxT5oumOtct4mi8O3ur6csdpldz+Z5SY3YGQMVS8MRaNDYSug1CB/M YO8fAxngVfmn0maTdBHqk7gffGTVjwlq8lpZXUgtL+dZJ25Kcitt9fuSCIdJumJ/vnbWdqt1c3t9 ZtdaQMqrfu3kwv51yd59s/4SiP7Fbm2LAARxS+YAfrXYrFqjAGZroY+8VNZOv+JV0LiVL15mIwjS 7Rj1rCT4kO7If7Omx/ERMSP5V0Gm395q1obqDT5SkrHbLJc7eKSe216VDHHNbSKwKlA24gY9e9YP hi21qGxnT+1U06zimbeerMfYVqywzX2s6P52qXE8Du4EjJsYcdq6G503TLMo15NetGOsjudp/wAK fHpGlaiPNhE8ECjO4NhX981FcWGl22PsmmSX8nRWySv40Wmm6hbo1zfal/Z1uPlMKY+UexqyNWka L7L4fia4YcNdS/cUf3s+taFho6WDia4Zru7I+ec9QPQDtVS9ll1y9+wwq4s4mzPNnhj2QVvxhII1 jWPaiLtAHagSs33oyAORntSrIxwdp4pDIWYjaadlmb7n50m8qwwrdO1I0hyco5welP3s3WNgB600 yFeuRjnpUCzG6kIVCIh19zUok42qhUA8cdKDKQdoDEY61G0jAfLGef0pRKyvtKkofSnmYqOI369A elIs2RtMbfU0qyttZjG2QcU9JSQW2HjpmmvKRgbSxPHydQazpNa26utjDC87gbpmTpH6Vdm1C2s9 puplhz8q+Yduan81QpI+vXhvoarnUIhfpZkkXLpv2E/w+tc9NKreKIJY8vdeY0bpn/lkF9PrXMXW tXN/It1pOnOt7FOyy3bcKozjGO9bVzoMei2UGo4+03LTpJPKydj1rZ8S20c+ieYLcMyusiFVAOe1 MvIbuzvo7+2gEwlhCTRkdGx8pFS2mhQzaOkGoxCd3fzpcjHzn0+lXBp9pFYfY1tlFv8A3OuasQql siQRRfulXgCpWkkUriNm9dvSnEnb9x/pVG4vZCRBbKWmc4LD+EdyfepLbT4rbbKEDTZOZD1NWfNw w2pI2fSmPMytjynAzwTzTvMYnGw89vSk89gCBC5+hpiSu0Jcwuo/u560vmHaP3eBjv1FODkAnHPY dqUEmLJGDSKzH+HPPepxxxyKCeTkdqccnPpikHt1FB+mOeTSD73OeaQD94V7AcUKNrHH3TTuQMc+ nSg5/AUICK8M+Dq58ZSHuLV8fmK9uyCB2yORTlXb8vbuKbLBHMoSRFYdfoahKSRA+XIT/sOKaupB ZBHcxvCw/iK/K30NWlYSAsOQe470fdY8D8aytE4u9RU9ROTn1zWrtxz7Ac03YoOASp9c1x+ivMun 36SsZFjuy8eTzjfzW7ZsVur6O4RQrHzVB5AXHNcp4iUp4nsri0K+XcRyCNl/vbcZFYOi6tp8HhW4 tNQ3zT/a3JEa5IPqa2NJ1FeIxJekOMKGVVUfhngVNpl3JpOky3kE6SKsrkxM33snsarjxbq12pP9 mz24xlPlDbh9e1OupJ9eWyW6tZCysQ3mHYBx60yTTLi21WCSF7aBY2AwJASCa6RtM81G+1apKXY5 BRwteaeN7Ew+KLeGS4a4tgFBDvk7fSust9Y07SPDtw8VlaWqHMcMbEF5Gx1qPwDHaR+G5hqEcU48 1vKDsMkfnW9HrCqixpLaafGvAGcnFcjo9zZ2hvJI57M3Zumy1yeNpOflHc1Le6vH/belyNd/avLd zt8o4UkdvWt6HWldSp0/Ub95V2j91hMf0qnHomoOdljpstoq9FluDsH0Falv4b1tuZtZaP8A2Yuc Vei8I2bypJqE01/Ip4EzkqD9K2hCkaKsYCoOAEGAKx9QvJb27Gn6fy7fLPOp/wBUP8a1bK0is7WO 3h+6g4J/iPqfepwAWyOvWnMM9ycc0ANk9fzpCcjA+hFHcdz/ADpQec9v1pvJPzfzpSM59R1xUEjG 4fyf4O5HepUjCRhVzt/rSbtxGScUjOwPBwBxgUFSQeTnPegYUcgZ47UobIX5iP6UFm34yeffpTjn Pfp1zSKW5DNmqmp3yabp8tyRyowi5+83YVU0+OLRtONzesizynzJGHJJPbFcwken6vNqOra9+8t1 n8qyRm549B60/Ul1G0jh04Tv/pW2W1z1jKjlD65qxbxahqxg1yOBkvIJAjRP8u5Rww+ma09O0uW3 8Y3t40H7qaBSsjHlTnlR7VY03RntotQt5ERYJpC8SqemeT+tX57OO9tTaTgNGyYI9xU4ULCq9QFA welGcoVYHApqgsBuzgcA0oAwMgfUUoHORwD6U5cegA+tVru5dH8iIbpm6H0HrUlraLbDCj943zOw 7mpjg8tg57+lLkjJx7007h1LZ9zT8856n3ox165PpTR1J/ix1pCAOc5oJK9yfajqM8+tKBx3/PpT sYyBS8ge1B5+uOtB46Hil6EEnt0qPfvJFPzyDSDJ6jPbrUUl3DCQJZIwWOACwFQHWbHfgXMZPQgZ zVtJA6h0JZT0wK8P+Dh/4q+Q54+yt/MV7UXdcCNQyk8etAvI9212CEnHzdKnBG3J79KUYGAG5x9a RlBGOMHsec1Wa22yFoWKH07VHJfNA4M8TEA4DKMis3QZd+r6uvT50Iz9DW+zDqMkd/akJ9OOn0rI m0gqJjbMA8mSFI4z61BeCZNHD3eBOMRuy9weKx77TYrLVtGs4ZDhYZ2QvztO3Nct4R0PV7lLua2F k8XnN8twnXnnmt59FvUw8vh+xlbHJjkK496doHhO3lsJVvLOe2YSEqolOMVrp4R08E4N1jH3TMcU 2TwXprr/AKy6yDx++NUrrwdpaGZ5IpFORsYyEkn/ABrMmutAtZzHdW92sQGPPkc4LdxUWuSeEbjR riS3KvLs+Q85H41paRpfhKbTUkZRIzRjc0xJwcU/w9p3huXTN8lvGCGIIIPHpW1HbeHEGI4LcZ7b M5rntL8MaNq893N5X+kJKfmjYqoGeMCtux8IQ2d/b3X2yeU25YrE/I5rexhDj9e1PRQcAcD0HGak GDg46ignnOSMdRWFdX0+qzm10xzGpO2W5H8l9607OxjsYBFEOP4nP3ifU1Yz8xyp+brT+Nvb1pAS PypR1yO56elHfGMYOcUY7Z700HBzjtzR2GCMgU1nO4AdT1PpTYwsa46AHqacxPPB+tMHXHY0/oBk decClXj0yMUi4J60n3sg/gKUZwQ3AHQ+9PB6jnH86jYEMCO3FZniHTrzUrNBYyxxXEMqyIZPukj1 FR6boMyT/atYujd3R5wBiNPYCi18J6baajJeIju5YuBI2VVj3ArUuLGC4ngnkXdJAdyN/dNTY24P APfAoC/MMHnvQy/3epoIGRx3/Wk3YzwaY7Hyyfu0REleopwHrx2FByG/pUM0+wlIsGToV9PenW1u Ic5YvJ1ZiKsjDY2t/wDXpQO5Gc00sAQM/pQc+5weKTOW46D9KVR1HAoGTyBxnNN29eCPr6UpUYHH tijnnGPrRg8cdu1HJwO30p/8JB/lUUk0cTfvJUQf7TAVXm1ewg5mvIR2GHBzVR/E+nKSI5WYj+6h 5qnL4sy4W3027nY9Pk4/OgXviW8GIbG2slPQytk/lVmPR724IN/qkjeqQrtH51OnhzTQ6yPCZXXk GRi1Xo7S3iH7qGJQeeFqVc9VA+h4rxD4OKT4rnZgMC2b+le2BdpOOGPOabPbxXI2yRo49x3qsbS5 gUi2nB/upJyPzpEvyhCXkRgft/cb8auxOsiK0bhl9VPFDkbCeePTrVZHMhMrkeUOg7g1zmgsbrxN rciO8ZBjyAOOhrplmZZMPG3P8a9D+FSK24HnPuaM4OO45NZ2uKDpFwc8KPM/LmsXUyJvEuhtg/Na yn/xypvBWR4cT5VB81zkdxmt4DnsB9aTJA6EkUm4nB79cUoOQQcfeyPrWJe3Iur+Z5ARDaISxHRn PTFMSxhun062mVZvlM8iSDIGemaXxHpVhaeF7429jboRHuG1ACTV/RorG70K3mihiK+T2X25qHwj DDP4ehLQp8zMTke9bK21uSSYo84wcL2oS2igJ8uONAeoQcmnZOOVwP6UHAGOuelRhsZFOmuY7aBp J2EcYXvwKybe6uNdmZoAYLBW2l8fNL649BWva20VpCIYYxHEnGKkIIOARikwCoJ644B7Uc5yaTPI OevUUoY479OopQc9+T60ZX05pM7W56HpTARj5cZpQMcjr3zTS2G5AIpcnOOcD3peAvAHTNNByehN P4YDjjrQTgnjIHpTTwegx2pSwJHqDSkjGeeOaM8ZOODTlIyo79cUoHQj1pDnIoBB4Jx60pOAeB0p AQAewNKDnr/+qjGTz+P0pDgjPfnp60xhlMKOp49aRV2YH+TSkdx680xixyB34JpsUKwMWVS0jdWN PDqpKtIoOeuaZJfW0JG+eFSfWQAZqu+u6bCdpuot3sSc1BL4s0yMECSV29EiY/0qk/i6VmZLTRr+ VicqcAA/nTBrviOQZTw9sPq0gzVmN/FEsYfybCEnkq7Hd+lDL4nKkbtPz7M1NFr4lYjN7aKO4Cni nix19hltSjUn+7EKT+ztc3gtq6Knf90KRtG1NjxrD4P91BSjQr53BbWbk5HQACopvDkcUgaXVdRL McbVkPNWP+EP0uQK08c0zjndJKTmrsWg6ZAV2afb8dGKDIq2IIxwsSDBwQBTyNpVcBQT/DTgMdl/ CnZxzt5o49h34prYHGBnHSlyF5J49q8Q+DbD/hK7gY5+zN/MV7bggkZA70BH5DOKCpz9/GfSmyRC ZCj4YH1FZl1o0okSTT7s2jp2ABRvqKZeXVynlQSBwSf3kyDjH096lR11GVY4JFa2iI3leQT6VleH wy+KdeG7r5RGR0GDXRFWAA4IzVLUdPkuoyLad7dzwSvcen/16dbtKm2N8qqDAyck/U0zV1dtHuxv wDC3asC43NrehKX6Wkp6f7Aqz4HOfDcfzZ/eP29zW+V77iB6VCyvu3eawI9hzShHwQXYE+w5qtey zWVpJIsjvIwIijCjBY8Cs+OxeMWlhKzNJK3mzNnt1/nV7TbFl1C5vpGJaU4Tpwg7VPqlmZ9Ku42k ba8LcYqLwrF5fhaxjztIiK5xyetJ4ag8jTTEsp/dysvQcc1rbSDxI3PsKYyPnmQ8dOlR+S6sXE7l QOAQAMVSuNWsbdyr38XX7incR+FUm1u4upQml2ksp5HmyLtT8altdBmuHWfWLprhwciLpGv4d63t ipGFACqB91aNpVidxAPQYzQMr8pPtnFKRjj8aaWxgGmyruGN23PGaRAFAXzGJ9aN+Rt5+tKMHPGC B196bjaMg5FNCDdvZuDxipAcAnPFMOOo70Bc9aUjHTNIB9R7ilOYwck01o3PGWC+lIsMiIcyEelI wwctKQo6k4pVnhOf9IjJB/vgVE15Zocvdwrj1cUyTVLCEBpr+BB6+YKjPiPR0GTqtsPX5wc1CfFG ks5K3xbHXYuf5Ui+K9LlBEckshHYRNzUc3im2Qjba3z7uSFiNNbxE7EPBpd2/wDs9P5046/fgHZo d02fSReKBqusT/6vRXTv+8kFSLe+ISOdNtk/4Gaaz+I5QQkdlBjoWYmmLbeIWI86+tYif7iHP60x tG1yRm3a+6g9liXApqeHL4hhPrl0xP8AcUDFOTwqpYNLqd649C+M1MPB+mu26X7S7epmcVMfD2lL GYhbh89Cxzz+NXINJsoERPs0Jx0JXmrXkIBgKFOfSpNoLZJ6dBiojCC+SWH0708IpTGTj071EsSo uR1HOGbJpsQW4jMnzgdPQGpRGNhALce9OUAAZwcj+IUhAY9OM0x1DbWJyw6Z6fjTY7dYdzli7H5t xPT2FOa4jXG05DdMdjT/ADEJUbgewINKsYVmYE89qgup4Y1DyNgr2zTY9TtGH+uUf7OaRtWs4ztL k/RScU0avbEdJCPaM81E2sxFgsdvcOfZTV+CUvEG27M9Q/WvF/g0P+KouW7LAc17YMgdPrkdaeOv SkzjsB2FByBkmqt1N5MPC5cnao9WqIs1rajcA0rHB56n/wCtVOXTodPLXkcnkFf9Zt6OT3x61h6L cX6+Nr6O9gCq0A/eKcBgOh/WutVwy/Lj8+tVtR1FLJSGbDkZ6cKB3rDd77UmjkWeOKIjhZDgkepA ov7y8s9JuI7qEtE0TAXEZ3L07jrVW4uIpNe0jy5FcLbSBip6HYOKg8LeIdPsdFitpmlEqO25RExA 5Pet3/hIdMeRUF4uT3YfpWkG3qpTGGHXGaevOeMU4YbjIwT39ao2Cma7urlirA/u19gOtaCKAvTj 0HpTNQBWxn25OEJ5PrXm17q3iszWVroVsyWoUKpC/fJPJyeK6TQ7rX4luY/7NhVhKSwMoJBP0rWd tekKrGLSIdwwY0rWuqucS30SZ/55L/jUH/COpMVN9d3M6gk7S+0fpVq10SwsgPJs4l5zkjcfzNXg GBUJtAHbtT0Xbg4J+p4p/Vfc98UzzlUf6xVI7Me1RteW8Z+a4jX2LdaifVbNQCbmMZOOOagfWrEu R52dvVQMmq7+KLBCEIumPT5YGNRS+JMSotvpt3cE9SF2AfnTxq+p7CyaDOT6+ctRSarrzKdmgnA/ vXC0yHUvETSYfSIYhnqZgasH+22GV+yKR2OTTQNaC/vJrVfoDThDrDKc3luvPZTxSrZ6oS3magrA DjCdKjbSL+T72rzKccbVFMbRLkZD3143HUEUR+HkY5N/e7v9pulKfCcEjZe+vD6/vSKiXwVYLktd XzZ9Zz/jTx4O05Rtd7hlx/FMx/rTh4P0lCrfZm2+plbJ/WpIvBuilgy2fzA/xSE1dHh3TFGBYxMP UqDTv7D0wcHTbY4/6ZL/AIVKljawKFhtoEz6KBilAiU4jjAYcZCACpxwvocdj0pMYHvilACn5c7j 3xT+opjswyNoI7moZoMqeCpbjIPSlhhECBUBbH3ixzT1ODjt1x1pQ2c5HUc005GAASR/KlXk5Zvl 9M09QiL1wSe9L/DhfxJpRkZGfTrTTKowCQufekEyKcbsEDp/WqtxrFlbD95cJuPQDrmqrazbK485 pCT0EcZI/EiiXXoVQeRC8hHRR8vH41Xu/E0lrErf2ZOxc8BGDfninaTrkuqNJEsTRXCDLBl4x7Vp mK7eLDSqrk9QKUWfmQlLiQSDuFOKFsoIwWwxAGMbjio1sLaBNqdCcgZJ5NWEjVAo289/apgeemMd OaR4kx8yKV9xmmi3hHIiiGe4UU4xJkkIme/y0oXAwOgpT14/KlCAds/WvGfgpGDq+oSf9MwMGvZC 5B/ligNkf3s96Oe2aXggNg+prLW5Fxf4U5C8LtPbuanSIS3P2jdlUBRB2PvSXcJnaFMA4cbiehFV NYsWuIEuLRgl1bHfHu6NjsfauetfHmjTArqUn2a6hJDqgJAYVEnimyvHbzBLPFglmSM/MPQ+1bVv q1lKsUVrays5TcFaPHHbk1VFwdbsLi300ND5oKyyNyF5wcCsy4sbbQda06G3Rii20rEAZZjt5NZX h2PUXtYZ7bUWiiZ2zHOgO7mt86PrTOpFzp4A5BWHmrirrUJXISRVHO1gAKkt7/Uy7Mtssig9RIKX UNYv7exdzp53P8ow4+8elR6fqF7a28dvLYqsgGW/ejknrWmt3qMgJ+wqPo4pZLjUTEwayQ7hjG8c 1gW3/CXWEaW8f9nLCnCB85xn9auaPB4igec3EVoxmfcXGR+laUv9uFR5TWqY4JYHmo1g1cx4N3bA 9ysZqBtL1hjITrTAP90eWOKG0K6mTbNrl+c9Qu0A/pTF8JxFcG+1AnH3hIMmq48MRRLI8t/fbFOF 3TdT6VfsvDtk9ojv57F+Qryt/jUz+GdKIDG2bOepkbP86nGk2KLtS2QrgYJyak+x20bY8qMDPHyi oj5Ak/0eGN3Y4Y7QKnKGNW8pVDgd+maqA6k2N8kK/QE1IkVwOZrjP+5wBUMqyZHlXUrMD0OMVcjU lAWHzdTUgUD2OajOWzgbzTY08tTknnnA7VKv3fvZ+nWnkfKMYB96YWOPU0kivJ0+UdsVNxjPy0c8 bWwW9RVKS8l8wrDbsxzjJ6U6O3uC++7cMCciNfuiranBA6nsKkGSCPm/lTCDz15qJYFVy2AG7En+ lSBCABkjPUEdaXtuI/Cgkc5wvsaaHwAcgf1pHnjjIDSxr3yTUf220Q4e4jXjnLVE2rWJVgLqL5eW +boKSPVLWePfC5lB6mMbhWdeeKLe1l8s2t05z94REU+LX2nz5dhdbf8Ad61Lbahe3RYpaNGo67+t WC94RwIg3uKy7698QRTGK3so5FK8SK3A98VGlx4hIAFsrA/fLN0rWjs7lrcRSy7WIycc4P1rPl8P rOj+dJcs7uMbHxippNKWaNo5Bc8DYH8z5vzqvB4K0yCVZmhmlkByDI+a2YrcRpgWqqPY08Qhmx5K DHU+tL5OwARJHt5OAKTypSqhPLjY9cLUxjY8mR+OCPWnogznnNIUH3eme3tS4Q4IXp04pSOeR+lI W/8Ar4pR2z1oPQD0NICQOQRigNk/lk0u7HOPpTgc/WvHPgn/AMhDVD2CLXrhcJ94gZPfpmgyoFzn C8YpFmQn7xI9acsisu7dkZI+tZ7JbWgZLfCzTvsLDk568fSrcKRwxoqknb056+poSVJSzRsDt4yK U4OcgYxgD1rmvElhpsNsjvZROjP84EfLDvzUGj6Bpl7pokhiCwyMSuGxxWfZ6Nby3luJp7jcGkiy rkfKDwPyroYrU6HYmKwXzIs7lVjyT3rn7/xHp82uwyyTm3eOGSNgwwQSOmas+FNX05dBtxLcW6yI SMMR6mttNb09gCl3ESOoyAKhe9tJ2Bnv08r+4rYH51Yi1XTIgEjuoFXtjjNVrnV9PnvbaM3UQRMu w3c57Gpf7b0RZWke6g392Jzmp18S6QVDLew4P91uKqz+KLF5sRXsSxkfM4+9+FKutaJENzXYYg8M 5z+VTnxVoYbab6IH13c0v/CV6Kylvt0TBRyd3NUrrxXo10qomrpHg/Mynk+1OTxVoECGNb+N8c5y TmnJ4w0eVcx3BcgcqsZ6etUW+I/h6OQq1zKGBwQIzxSS+OvD08iySSzyIOiCI9fWtC28baPcq+yW RFB6PEVJ+lOPi/SNw/eysCfurGTUT+OtGhIWeeSFiPlDxlciqdz4t8OTPuuNULrnhF6VctfFWitB m3lZo88MIyTQvizTDyftP/fo0h8YaWAWdp0Ud2hIFQf8JxobNj7RLu6Z8s1ci8S6bIuY3kOBnPl4 po8U6aCo82QZ7FDk0j+LNOVtv+kn02xE1HP4z0y2++t2PYQmoT470v8AhS6J/wCuJqGb4h6bGMLb XbsOMCI0Dx8HH7vRr8n/AHKfF4zeUn/iS33021M3i6dEBGiX3/fNM/4TcxcTaNfRk9gmc/jVmLxD f3AIh0O624ypkbbn6U2PVvEUuVOjxRr23TinyP4kcAJBZpk93zVPUte1TSsRTKJZm6mKIkCqkPiv WriMlLGY9gPINSPr3iORAE06Qt/1yKn86v6Svia8nD6i8NpF2UfMzf4VprY6gOWv93+yV6VJNa3h VRBdKj4+Ylciqh0u8aVGe/5xyNp5qddIt8hm8xiO5frUo0u0JAkiDHqCcmkbT7JmzJAuQOuKF0+w w2LePDcEbKsxxRRALEgVQOFUbRQQHPJDEnuKcTt+XBHNLwcjoD6daUZQ4XkH8aM9UAzSb13suOp6 9qduB7NnOeKcGBHKsR2zSZySNjYPJprTbSPlbJ6inCQMOjD0yKC/TarjPXimeYGcrtfBGeBQZtuP 3bge9CTE4OxgKPPIH+rkYE46VKrcBsHn17Ud84z7UoJPDCkwT1B/GkHuMe9Lnp70vXrn8BSAbj3p DznsB3pwXcPmHHavH/gmP9L1Rhx8in6V65sByXGRSsiYPyDH0pPKXB54Bz0oIUcBRtz0x0qkgW5v pHCbfJbYCe59auFVKnACn1pgVFH7v5Bnpjr70djxjHWsLxISpsUDANJKUOemCpqPwvbTafo0MDTI 8cbsATgcZ4qjbSrHq5jJUv8AbMqAc4BWuqaNTkMAee9VJdGsJsGSzhfJzlk5NUP+EQ0RXZ/7PiTd 1x0qjc+BrGWTdBJc2wH8EbcUi+A7DGPtmoHHOfM7/lS2/gizt2eaW5upgoJAdutJpHhDTp0kvZbY NJMxCCTnao9PStS28H6XETi3XB5+bvV6PQtPWNVS0hAx2Xn8KmXSbMRMi20akjbnaAw981iN4B0x n3y3V9IM8K0wx/KrKeCdCCg/YVkI6Fuv41YTwzo8SGNdPtyDwRj86ij8L6Lb5EWmwc8ksnSp49E0 2L7llbr3GEFTLZ2yfdt41yMHCDpUC+HtJBL/AGC3JJ5Yr1q3DpllEAY7OIDpwgNTLZ2448pMj/ZF IbaFTlYYlB6naKq3WjWN6yNcWcUpUYBZO1Qr4e0tVx/Z1sP+2Yq3BZWsEeyGCJFH91BSmJR/An/f Ipk1vHKm1o4mGeQVBqH7Fadfs0QOOfkGala2hljKGJNhH90A1VTRbGOQMtuoKj5SDmmy6JbSybla QO3YHGKkt9HtoJTITJK3bzTmrX2S3bP7iL3+Qdab/Z9ruJ+zRqTyDtqwEAIZVXI6fLS7QOODz6Uc ehxjrinEBuNqlh6ij7zE5PHr2pSgJ5BPHSmumccf/XpjJllbII9CvNPVCBwNvHanZx13H60hOPfH NKSOvtS8UBRg+vejaOPTv7cU0NtJoIzuPHPWmYCgf40pfjkU0MB2696XnPIIpwOfb2pcc/L16UgA yAOuecU5VPHI/CnEAgev86UkAjHQ/lQCDgY6elAXk8daXIHTFJyfrSEY6dc03HOPT+VOXoaXADcU h9xTuPfPbNNyM/1pQSeRn8TQw46cU0nGPY0u4Y46D0pemMnnrg0YA5P1/GnLxxXjvwSH+l6qPRV4 r14fgTQRz+FGeRyBgflUdxJ5UMj57cUy3jdYFEnLkc/0qU/MCO2O9IRk5JIpjEAfKaytc0S21u3S OcvGUbdG6tyDXMt4TMNtffZ7qWNopAQWO75cVd0jwlbWmqpfiSWVjGHLOOjfSurzhd2DhupIpM56 fnR05xk03JwSDkikxu+bHf8ASs7W7o22nbYcmed/KQDtk8n8q0IIfs0EcKnIQYzVtWHUDPFOGCAf yApwbJzS856HFNbOeR3pjEimnBzwePXrSMoYD09ccUgXH0xQSS33vaplLDGeB1p5Occ4NJzg/rim E+vNIx6AdfbtSch89qQnORxj6cUwjucCmnoeM0mepXp1p2BnNPUY4z1PSnlc4wB7ClCg+g9+9LtU cjP9cU3kHPPSjaMeoBpcKfT2pOuD6etP3Zzn/wDVSAkDr1NM6/lTm4U0AZwMY9qDjAHA+lA9yad/ Fn8cUpIAH88UmAQffrRxgHg47etABA7fjTSKYfoe9OHoenr3puQDjr0oxzz/AJ9qUDAz0pw+XFIq 5OR35qTPIH3hS+2MfjScnnv2oOODkg+9C8bs8k07GMenekyTRjP1HvTMeh+lSAYJwfrQvI4GKaRy OOnWheAP50Fvm/zxRnJP8xQTxSY45600deOtPGM498f407pwP/rUteNfBe7ht7jU3mkRAwTAZsGv Whf2rED7RDz/ANNBT0mRl+/GR04brTs8nPDe/eqty+66hh3fJ95xjI9qsbiAApB9hSls9COPWmsd x6HA9aa4O04IBrl7yPxV9pkNpc2sMIJCgpuJHvXJ+Kp/FWg6bLeXF1A8Nw+2TYoBzip9F0rxVqem 2l1DrGLWROFzkrXY6Jpd/ps4+16i92hGdrDoa2m4z3+lIeenrSFePX2xQMkt2/CsliLrxEoXBWzj 3f8AAj3/ACrZHPb3z7VIFOcU4bgT0wO1OGOnPtml3dDn06Um/kkD6ZprHPGP061HnIbsQKXnr6Ur ZUZFIvI6c+tPycfyAp4bg9Bmgn06+mabjcenHrSFcnn6/wD16Yfu4YHI/WjHueOaYc+2M9aY2ScA 49KB0Jx+VOAp4bqMY9KeSeAPzpw6diegFL93gAfnTSd2R+HHakwR/KmlcDpnNSg5HbnrTR069aTj nn3pu3IBH60oPQNnjvSk84JwPalGCMHkU5lwD+NI2fQc80HB68HNKAAPakAGev40EcjPApMHkDrS bdvPGc8GmlicjHTmkBDcYFPI689aaenBx9O1OUfLjOQOlOHOAacRjjoT70AZwe/XNBzn+lGB17dc 0o6ZzxQOcFRxRyMe3vQp5HH0JowMnjgnnNAOPXigcjceKXIzkHrxTepyaQ4GOOlGM/0xS5yB07UY wD2z60mOM0o/HHbHelOQQPTpxTgcj3rxj4M2kF1daqLiCOVQExvXmvTZPDmmO5l+xQhu2Bg1G3hy 037ohIhA6eacCnf2DgBkvrmM+hcnFUYdM1gtLLb60zbm2oJYxg4prR+KoMktp9yB/Bypqa31LXlJ +2aVFsHTyZM/zqZNcuPm83TLyPHPUHNMHiSB3bdaXYAHUp0qI+KdOxgtKCPWJv8ACuU+Iuow6voE FtZCVmM25z5R4GPpV7whrq6Z4Vt7e4tLlpYgflVCCa6/T7wX1lHOg2K/WNh8y1YwxJxjFIEZVw5B YHg0wsTu56DBPpTZX8mF5WbAUZ/L1rM8Nwu1tLeyHD3chkwf7vatxBxweDTwCTkHj/PWnAHk5PFK M4xkA49KXnuevY0wr33HHQ/SmHd2J/wpoBB4OCP1pQGzjjmlAJI+bvSsSrcZ/CnZ6dye1KOFGW6U Hpwec0meOSePal69Dz7Ux0bPEhCjqKjIO7Kk4/Wk5zyf/r0bWGMmnYJGaVQfw9qXYc5zz7UoHb09 KkHbPofyp20BR3JFNwMfrTCDuOD06U5VIx82R2FId+Qd5A+lIC2eWI7ULu4JPNDI5Aw2MGnEnbjO McZoALArub3GKUryMsT9RSkbhnPfikccDBpCeAcYGKQALznjvSkZPA/CnMOhHWmKcc0NkAZJqIgi lTrzjHfNKSe/Sl2g+3fFPUY7+/tTh/nPrR156igDLYz0pdpOSCfbNKU9/rSe3rSAFfxo5Hfk0ue3 IoYFl56Y70wgZOeuafwgxnPOaXquSTik6Z5we1IR6+tITtXHYU5WyOo5oYk444oUfTil2n2/Ognj FAOAcAnmvIPghlrvVMkfdXivXMbV+U9fzzTWJyMn5fp1qG8lENs75OW4H8qdDEIIEQdemfelHPX1 7UEZz1pQowRnj1phTqMEfj1qMxKewx9Ka0aZwyqQf9mq8unQ3UmZw5A6bXK/yq3BBHbwiOIAKPXk /nTzweOlJ147UjAbT0z1A9TWN4iuCbWO2j+9cyBBj0PU1qwQLbQpEmNqLtFToQAOxH5VKOnFKDkc d6XB6NyT09KTIwuOPT2puMmgDjGOPSmHgn37DpRz+J6UZbP86Ac9OpFPyQaU8f403n1zx0pQMZxS k/zxSYO7PbmkxnkDFRNxnGTQOaO3SnA9OMemKkByKUDkc5p2OMdqdzx9O1IcdaaFyQMelJ1+UHmj IOeSe9NwP1zQBtz15/nTifmx6mlJ5+lHXinYyMcDFKfu5HSkBGMf0prA49j+tIAoHv2pQF4PQj1p T1BXmmZAxnrSZbpjk01hwB0GcA0yn7MdT6U7OBxyfU09Tkfj+dK3J9yKQHP0pV68k5NOxx16+tNJ Jz15/lS4IySKMk/WgnjJ9OcUmfrS5JzigKexpFGTzyBS596G6n60g44pGxxnoKA3Ufw0E5T68U4f 5FOX7opOueTSrXj/AMEP+PjVP91K9cDYAPrQUAGWOOOaq3SrLPHGRxndVgj+Ick0hHP16CgrtJA/ Sm4AI459aQ9vTHFMIzx2paFAJ6Yp5OAMfhxSBsDvTaQ4OM/UViFhfeJRGMMtkmW93NbKLgn61IB0 wDU23pnpSYx3xTh8w478ijOznt6Upyx64HXmm5GemMU1h82SOKNuTzj8KRkzz+lNXIOMVIwzx700 /exn609eRz165p2COAecfnUfRhyeuM048DGRUeeMnn1pDhsY600cduPSl+X3pwwCPangA468U7bz z07j2pwIHQZ7UoHpSYGc54pvp/nikZsNnnmmHnHYU5RjinE8Z6HHWm8Nn16/WlA7dqOdxp68ds+1 L1784oAx83TvTWBI69qaBknjpTieTkCjcNw64qJhlwR6UpAzkHjrUbH5j6Ui4DZ5qX5W+6cc0uAB yacOGJ/DilIyQR0pNpxtzz1o9+gNP/kDR3Io7D8aavK+n40nGM447Cjhuc4x6UKMDinEYoAwOPX1 oA+v/wBejGCM8ke9MbBfGcE804DP3uSPagj+WaUkdc8+4pT82Pr0pev0zSEHqR0py47V478ET/pW qD/ZXHvXrZwccjAHfvTiykbdy5x0zWdC/m6ncy7gETCLz19avb1DYJHPQUm4ewNBPXkcelJkHlsc joKTGVBzgU0kA9aQsOxFLuA5yMUm4HkEY+tNEmejLn0z0pxYeoqKdwkTPkHaCwrJ8OwAW0905y91 KXyfTtW0jBjx3p65yCM9alDZxz19O1P+U8ZAJ9etIM7T60MQM57ChcNnk89KQ8d+BTfX2FICOnJG KGJJ+Xn1ppJUg46+tSBuMHjjjNNZevHA6U5Rj6U48nuO+KQnjuaT5W7cj1pp5HII+lNHI44poGaU ZHI7U4EDAJ6dfepARgknIH60qNnk/hTgR0GKTIH19j0pD+nSg85zxz+tMLBeO2aRmHUHk0iyAgDK 8VJkf3lwOvNN3IwyGABPQnk0K4LYBGR15p/mLgH1/lSGaMDLN+lORgyDacg/xUFlBwWAJ9KFOOp6 03Kg/MfpQGQsR+VKccEYx9aaWXkMc/Sk3rwAw3e9DMCG5HtUWQCBzmnAjp296d168H2p4ZQex74z 3pS4CkkjgetGdw3R8+1AYLtHSgSLx8wp+flBB96QMvPP1xSHjAPSkZwMY/P0oAA5xxSkcYHANIM9 8+tO6/8A66TOCPT60pGRgg0EAsTgfWl6/T6UcYxg/lSHnkDmlH4j2o680gPbse9PHU81458EsC81 Q/7Cc+teulVzjAOOM0x0RFeQKCQPxOKq2NrFHb+YqAGQFmzzkmrHlxtglPnWlZQDwOfShSD2wfUU g5b5Rg01gGGMcUmBjFLgYPFRXEkNvEzzuqRqOWbpTUaJ4g6YZWwQR3FPWJEGQoyPSneWvYYrP12c W+jXHGGcbF9yasWNuLexggUYVFAP1q0qAkcDrTwuD3+lSAHHQD6U4EZyQOKXB28ZoAHPHT070mzA xjj0pCm7nHIx0o9f0puwBgR+lNJGR657UhP94DNOKqcAkinkN6fnThwen4ChuBz3NIcHP9aQgLzg E+9MYAD6daYPmbk8dzTmGew980wKN3IOfSlK5yeOOtOG3PNPRgMAAYHQ088jOBn1owDzQB75Pbnp TWGMnHFNKoWPFKehwox0pAFOCF4pWTIOB0ppG4fKMfrTgoxzkD1pSp9fwNJnIwVXGOeKco29AFGe xoIDcnt6UFcpxk9hSFcjGO3NBA5/PpSt0/pmo2j6k9+lGFABIHXFByRkHGPUUzByCRn2pcDJBAFP IIAwO/egBQWPI+lOwDxyc9qAQD6/SgjK9eCOmKMKCfl6cA0/sBwPqKQL6HB96PmzyQOO1IuCfSl+ 6CCOnTFAxuPel/AdevvSZzz3pOM/jSk9O/8ASk7+/tTieMdvejHqOPakIyf5Chjjjv60KM4z3FB4 znmlTv0rx74I83OrccbE5r104Oc9PaortylpISPmxTos+Ug27QF7Uoz/AC4pHOTz0zTCABkUZ68D mjP48UhpRk/KMc9M1zniWQyxSw/62NVEap6u1bVhbi1sIYV/gQD8cVY6jrSgcc9PWsfW4heahYWj fdWbzmHYhf8A9dax4PA4PU0seTgZ61Kvb6npUifNx2xSkcYwR9KUHGcnPtQMccjGaUgYxnk+tBGc 9PamEYzjp/KmE54/X+VNPTH50Z6Z69ad8pGRg+makyP1o6ngcHvS4yev4Uwk5xQOPl7U0kJnPJNN UcjuaP4/X1+lJj0yfSjoR0H0NKqqRwT60vIOD371Kv3e/wBBSgqT3NNJxz15700H8qXoT04oA4we wxSZBOB9adnC+o9TTe3SlPqfwFKvKe3ahRzkdDzzRztHbnFHY+mKUk4HegMR259KTknp1pQMDvTX IBye/FBGRn04pg4b/PNIcY9R0HtSKFH+9Ui8/wBaDkJ7/rTh1H0ppHIOfpmlz1OOetB64x+Qp7HA A6e1IDgZz+lBOOAOvakClfpShiV+vekCn6/SjA6dO/0pSAMj8etGASe4JpSCPf6U3Pp1xRn0xTh0 79e1H3fwpD93PPNJnnvnpTjjHt1zSqAMgCvHvgiALvVfUKnPrXrwHynAzzVXUDts34ByVH1Oan28 HHUYzSjgn360jHA5HFR4IHPT0pQQTjPBPYVQ1LVEsLq1h8sk3D7QfQUl3ren2isLi6jXZ1BPOfpX PXOq3euavHHpck0dlb4aWRFwGP19KoLrsTalBeXMc7WXmv8AvFXjcOPmFdrZahaahGrWs6SDGODk jNWQuBz2HSncc5zg9KyWTd4pVycmO3K+3NadKoz9KkX3/Wpd3Hf/AApx6cjketIecUA80H2yMdMU hPX3OKQn15A6Uh46dhio2O3jtSDDA+3tS4xn0NPByf50u7C9OP6Upbd+dGOo6c9KMDPv+lNPWk25 PBx/jQRnj+lJtAA46UhXPfI7Gl7Acc9qdkYz1+lODE8DrQRznigjkZ6Gk6c9eaTIP3vQ0pxjjrRj 2zikYk9sn2NG7C8Z/rT+D1oUKuPWkznPT64oPHXr1pB06e1KDwTyOaMFV4H/ANajBzycj+XFIfmH 1NGB1Oc0cED1qMkMMkYpGwBtxz29qQ4zmpFJNSZ6Ag5FN3ZOMcmlbPI/yaQEhunNBLFsAZA9e9Kc tzjmlU8cdKPU/nSAbvrTgMDIo6c80hGPyp2OeKBxjPp60047455zRtAPTn60hBOccNS9iB2pD36e /FO9ueKQA+2e1KDyRnPpmlX0rx34I5+2amD02pXrhYj5VUkCqmpSyR2bFYWbkcDtzUrNK2W8sDgd TTlklZMmEccEZp29th3AcdSOwqJpI/M8reqyHkAnn8KrWl6l3Ncxwq3+jvsfPrWBrEtzf3t0lsyh bMplyO/tUuo+H4msYmeCK4uZZF3TOvIqxa6LfxpNBI8K2m5iBGOWB5Gfxq5omi/2XpJtJdkxLsz7 uhyc1Sn8I28d4t3prNZyB8usbfKw+ldATIp243Lt+8T3pFLSKWkQK3GMHqPWs5RI2uXDFRt8tQDn mro385C08sdvA9iRT13Y+bb05BpymUdEXOcZJpd0pB+RSR70imZs741GPujNIzShdyqvX86cDLtH yqCfehTIR+8Cg/WmnzScqEYfWnfPx0zimODwMA9+DTVznG39alww546+tI+Y1OBnFNy5ABGRTlDY DHH49qcd/X0GKdyR39qYTITyBz0pDkA8YpGBKZxyKa+4Ee3f3pQSef5DtT1GQdx5zmhUwQd2RTsc e9KS7dCPf60HPXA5FMO4HOFpo3dMAjr9abmUcBR+dC+YWP3fXGaU+YPTHTilQOe2cetI/nqDtKgZ pV809QDnvTj5mc4GetG0tg5w3pmjDAZJ+lHJBxjPpTvmx/D9aMPnHGAP1pnz5GMde1I+9j2xSjeD zjNJj5SQPeopBICuw4PQ1IiHnOfpRtZkHP8A9ehfNx2OKk2sPTNNAfBLFcA+tEgfHybScc801RPj J2E9/epFDjlip9aF3HIOM44xSEkqOV3fWm/vAoKgE571IA5xuAxS4Pr+NDBhjHX1pw7Z5OPSjHAI GKTB6evekwPx/nRgsBnt6UYxxRgZ68ZpemPbilHbnjFIQOucHGKcP1rx34KE/bNVwDjavSvXhyOc 49jWfd6vYQv9lnuVSUnGMk4+tPhv7eS7mtEcmWIDdkZ69wapX3iKC31KLT7YG4vH6ovOwerGm2d1 e3F010/lrZEkKgHOOmSfrWRf30N2rzpGFkhuljhkU/M5zz+FWNPn1GynurKKyZpZJTJ5zfcAPQ1e 0PSJbOG8F7Isz3EhkYkdBWuLdSiKei/pUpA5IHbmkwV5yCenTtR156AdqULjsMDr6U3YCAO/86rJ bBL1nJHzADIqcjrx9eKBsLEZBYDOKcGwvzEDHOcfrTlIIyDkEZHFPOR36D0oB69iaMjbwe/p0pPf APPFJn1PfBJFLvXGevPBxRtxxjrTGQdMA+opqjHUdBnn0p4xk5xgU1mUEDt1Oad0U7vqfahTlc9T 3pRySeMjnFA6k45B+tBIPH6+9Jww6jjrTW7jGKQjjk5xQOOOh+lKOOpyD39KViUUs3QDP5VDZXsN 7CJIHDAk8dxzVnIGcY4/WkMg3Yx1/WkJwMHvzmmHIJAwO5zTguVxgfnQOucCjHzcDinBtvrS4Xnn j6UmMc5HX9aaQDkYNObBGMY4ox044zQQANpUAUq4x/hR+PPTigLwOlNPJHTBoI+X/P6U3sRt9gKA uAM469RSkZJPt+VDDnjp/SnKPl6DFAHfp2oI+Xg5/DpSqABnbz6YpfXv70mOmCOvTFAGCcdKAASO AP8AGjaO5Bx1yKAD6j86CMHp27Uu0HIJ6UoOAPpR15HegjjrxSEc/WjkHAz70h6D0HWk9BnPrRnn GOc08dgeTQee3NCjHPSvHvggSLrVBjjYnH+Fema1ePb2ohgDCe4bylx1GepqnLpmnadZxx3Mo3Ag yMw3PL7VkR2V7qV7C8My21hIWUSRsfMlH932qzeWC+HbltSs2iw6rC0b5LHnseuauWum3pKQzPGL RPmVFyN2ecH86fa+G7OLUDdcthi6KT8qk+1a+Mc9Sv55pyqBgjrT+hz70uMrx9eaMcjcePU0q9D6 0ZzgN9DVWbUbe3SYynaIVyw9jSJd21xBFLHMhim4jJPX2HvVfVA8f2d47l4AZNvyqDuzTNUZ7O2i vUPMDDzAP41PFW7pFubGZUbG6JtpHuKh0KUy6La7m3Mi7C3XpxzWkT1xycVUv7t7OzeeOBriRekY xk/Ss+01PUpWVryzSzh253SSAmtH7dB5DTLKpSMZfb2FZ+qa7FZCOO3CSXUq7kVmwNvqaqHxDM+i rdN5cVwZRDtzwTnse9dIHyB3wM470nX2/CoJ5VgheWbhEUlsDt3qC7vEt9Oa64wse9cn73oKy/EO qvZaCkjTJbXM21A2M7SeeKr+HvEsmrWcMa2VxLIBsll6KSOvXvW1Yag19cXamPakL7N3fNTXd9Fb XEMUwwZ22qR7USXscLyKwfbEPmIHrXLx6pd+IriSWwvHt4Y3KQqiZ80juxPSuvi3KkfmZ3YAPpnv Ts9ccDvTWBB4xkVVN9F/af2HkSmPzMnpVkSLvCNjJGcE8n8Ka86LMsW752+6D2FVNJktrhJLm1jE eWKMezYPpTotVt5zcLCd623Vux9eazrLUZ9bv1a0zFp8X33HPmP/AHRSa/4lbSbqK2httzyjKyuc RqfermjyahPG735t2LKCiwHIx9TWmMjAPBNBJPPofSlBz29TS7QeeaUAcDmnbu2PrzTduc/0pvBH HQ+lLjtmm5B47gc08HPGMUgHT656U4dqTt2J/nTQeMYz/Sg8jj16mjjnI70e3f8AnTgMnnvQSMdR npSjA79P1pScsMU0HGMnn19aOmfUUo7ZzigL1HpSBQvt3pQwHTn+lJkE9AD70dVJxilz16enNBBJ JFLznqetB79wO1JngdaXceeKR8lTScA49aAvuP8AGlxj7v6UoJOTjkUo475rx34IZNxqvYbU/CvS roCfX7RHbAWJnUH+9mlhhtpdQup44g77eZGOcHHas/wfbSNoqtNuDi4kK5H3eTWnLo1tLqS3sqs8 oGEDH5QfXFXwpPuabjtxgccU7BGAf/1UoAyOaMZ/ClAzk/5NGQx/xpec8nj6U3CnhuCeTXK+IFnX xBYrGFaO9wjqe4X1/OoLjw3ePfNDEcWMGbi2CHBWQ/w/StfVzNPoG8o3nqFcIoyQQRWVqlzrUtxd QW9v59tNGmwEgFM/4V09ohhs4IpT84jCn+oqro1lNYQTRSAbTKWUDsDWmzYPpxWL4jhvJLOJrK6N s6uFdwOQp/SktPDVpBGXupp7yQ8l5mzz9BxWPqFzJHrF3pVvbsZLoJtKrhVUdc0+/wBPli1iWSbS mv4mjVUIcAJgc5q/qmgjW9EitmjFrNERNAVxhGHtVjQYNYtYfK1i5iusfdlUYY/hWuTu6H5j1qK6 g+02ssLfKJFIz9eK5KG11TU5ItJurcw2FtIPMmJ5lweFHtWpcae+o+JU+024awtY/k3Dhn/+tV6z sDZXd0Yzi2lw6xDorfxEViWun+INIvJobT7HPaSytJukJ3gHtWjrFrqF3pEbQ+T9ticSIAeOvSpt JsbhLKVtR2vcXDFnRW4Gew9qyLLw7q2g3Mv9j3cT2chLCGdfu/TFdRD5hiQy437RlQeM1kxaLdxa rJeNrNwYnbIt8Lt+la4G04yAcVhataamurwahpqRy7IjG6OcHnvVa4sNVtng1IkXV2jHfAhxlT2B q5pv2+9vBe3tuLfYpSNCcnmlu9Mubbw7c2unt+/ckg9zk9qqaNFenRmtJNNW0TyiuN4OW9T3qho+ ieJNBtlSzuba6hbJ8mQYK/Q1t6nPGmkK2pWDXJI+aONd/NZPhzTbsaw99AlxZ6dIuPs0jZz/AIV1 E19awTLFPcRpI/3UZwC/0qYvwOOOmBTv4MjGfrQc+YOflAyaC2QMHilJVhnpxzihWGTjGPTPU07O VIGBnpSZzkqRmkOQevtSkjBIIwO2abn/AGuMetPUjcRkcU0kHHPXvSFueBg0hxg4IIAzSE5KhSKk B5PpTcg/xYNAKkjaeadkDnNKSRzlaQMOPm69KaZApzkZJANODD5ufu8U0HvnOPSjIyFyOfWnH5cZ PT2phYdSwJz3pRIpA6e3NPGf7w5o7Edf60E5pA3P0/Wl3+/5Uh4HPak3bQcnFG4fLyDz2o3CnD1x +FKcjvSjPOa8e+CH/HxquDxtTPtXp+oaXb6mIzNuVo/uMhwQe9T2dhDYweTEuF6nJ6mpxGqjjgHr gYo2LnPI/GnYBHGc+tR7MHPB9MU4AYPNKqjPegDsAaTGc5pcA4x07UjJn1460jIrhl5GRg471EbS FQAyAhCCp6kU8qO/JI7cUvlqecDPXigxKFII69zTFtkUhs08RIpIU9TnrTJbaOTOc4xyc0j2sUsR jkUsh6gng1KkKhSoyB0oWFFPCAHGN3f6ZpPKTGOgPXmgRJnADAn3p4iXHfimiJc5AOT60pUHAx27 0gQFhxmgLjHB4zRtHoc9AKQxDOcA49aXaB2H5UBF2tx+FKMtxx65pAikndnNHlJx8ppdqgdBj6Ug GcfSlwG7cDmgKBjH4UHgAYAx6UzAcAnqDzUNxNb2zxLM4QynamT1PpUwQbt3IbHPNOUDk9AapXOi 2NzeR3VxAkk0X3HYcirYROnT3p2xBwAfxo2KRwKURoCcgY+tNaFCuCBz70gt4yu3b+tSCNSoyOB0 pu0A/KB+NIwDduDRsUg4XB9qFiXnPOPWnBFBz0oAUEYA5pQNw5Gab5a5xtHNHlIvajYv90fnQUHO P0pFRU4A7djTsAjGODR5a4HAx+lJtUkfKKQxJxlRnqKVkGD7n170KgHBHHtShFJyFGc8UpHY8j0p vlp/dX6UCJOgUflT8AdAMd8UvAGBxj1pD1xTSCOg5owc9uOope/qMUjAY9h60mOD6ilC9e9OX14p SOPl6UL6jpXj3wRJ+1apz1VCRXr+ffijGM9ce9Lk/l70ufbgdaOdvvTDkk8fpRyPqad1BBAz6Ufx ZzjtRxzz6dKTIz+eTThgnp9KQ8DJyOagvbqOytZJ5TiOMZzVfTbm4urMTXsXlM3KqDnAPSpbi9t7 VQZ544yemW70y31K1uLyW1hmV50UMyqemaLzVLKxaNbu6ihZzhVY9TU6zJIw2MCevHWorW+t7xpk t5Axify39M+lWjwOckCmk/MMkke1OHJLZJHbFISMgnjjrS9PmzgHtSg9BuPPek3DOM4J7d6Mgk7e SKTsSSM9PrQSAOfvCoZ7uC1ZRPKke47VDNgt9KmQ5Y8Eeme9Bzkcc+lIvU89elOJIJ4/Kqt9qFrp tv593MsUfA3E/wAqmgnjniWWJwyEZUg9qRpY1BLMABkHnNVrDU4r6aWOJJA0ONxZcDmrbOqIWbAQ ckscAChXEoBXBDchl6EUoznnv096rz3dvaxmSaSONF7u2Me9czqXiXStZU6faQXF/IehgX7h9d1a Oh3txBMum6lk3CpvifP309D7it/Jx94D+tIQSM46dyetIemAe3p1oU5OD6fnTwARjvikHVv1xSZO enNL1+lAJx15xR1PPb0o28ccim++PrilXuSaCDwc4/GgggD2oHJx1FP6kcEUE/l7UwnH4+9ABzx0 9RS+/oKaRzx3pwG4YyPrS7eMd/0phPIPbrTtwz9OM0pPHHX1NC4xnuelB59D/jRnofXtQODk9qX6 8c/nQck+h9KCCOhPJpCM/WjCjjr680hx+HqaQqMdc0oGP9rmlI4yaD3I6H0pR3xgGlHIrx34HkG5 1TB6olevr096MqBkHjHel+h/WkwRxnp+tAYjGc8dzRkcY/MGk/hI756dqUP3z+dG7t3oOMZzR0zj oKQnnBP0pQwGc/WsLUB/a2uwafkrDABPOB/F/dBqPxVdvFFp9vFM0DXNyiMyjonOadbnSlE8lqq3 LxIWMjnIyB61yWnS61c3Nte2VpBZm8kdVmd9xbPI49KvadbvoNxPe+IYXnnLH9+DuU/Qdq09amvN Nt5tZ0sxsk0S7kk46/dx/KtLwxYHT9FhSQDz5f3svHJY81Nql3qNtgWFgl1gdTJt21iaRrPiLUrE kWMAZGZWd5scj8KLm61Fobi4uNSSyngO3ykXcreg/Guh0yaW50u3knG2V4wzpjHNVtcvnsrONIWK z3MnkxkjOGPNNtLaTS5C8twWtzHli7dG7mueXXbH+24NWa+GyV2gMQfO1QPSrvijW7keH/tWlO8R MyxBnXaTuOKi0m5vtJe9m1S5dljiARJD98+orpbeWQ6astwgV9hdlridOin8RX0891p8s7SylVmk bakUYPBX3r0BTj2JHHvQX5IPXvSDOfmycDt3rlbzxk6aslpptkbrFwIJZC+FHripPEFpc6nq8drA iM6RFhJLysOeDx3yKfrP2vTdJtdL0kobmX92jPwAO5JrHXzPCGg3Ml2ftd5cSKGSLLAE9K0PDWta db2QU3e+8nYySrgnax7fQVJ4suby6it9O0oI1xcEuQ5x8vfisjTdP8RXeh+ZJq8dpHAHUIiZI2+/ 4UosdVj0E6nc+InERTgCPjJpsOn6HOIvlu9VuWQbssSN2O/oK7axsobOBI4LeKFeDsQdOOlZ/idQ lhHdg7ZbeVWDDrgnkVsqQ6gk9RmjkcdccH2pFPB75NOXr+dO9vwxSZzj6UgAOCp69T3pzdcevFLj PHr29KaSOR78mndRwOaaeeMHPpQh/HtSkHrnGOaT7o5pcgvx2pR2AIFBPPuKRhnjI96ULkZ9aYeP T2pT+JpFI3YwfSlJbgDr703pk/rTg3U+vNOJAwOlAx2470jHv1ozgDnkUHB4XOad3xn6UnOfoOtA POQODRj1wM9KQ5zwfy7UbTx+dA6EYzmjGdv8jSgjgZ5PPFLkYxn8RSZzn9aNwGcDP0rx34JMFutV Gc4Va9ZacBgGzz0PpUQvEkBIRuOMEd6kju1YgBSCB3qTzRkcUoKkD1ApM7cYOaDKD68ijzTk4x60 vmgcEdKQSjByB7UvnAE4Ge1G/G3C5z61HJPslxgtjn8Kz7OKSPU7y4ZXKT42t2HsaXVLKS7eCeF1 WaHIUMuVOfWpIbU/2cbadY/nB3CNMKKjjtbe2ggggjytuMpt9RVWfR7a/vo7m68+QIMpEx+T8qn1 O1a/MEO0iGKQMyrwMDoK0RPhgNjAHjn0o89tpIR+AT938qzdDhktNLCzozPIzNtPGMmoG8O2baqb +YzytncI2b5R+FbAmLbd0bDnv2FZ2s2k1+lvJbfu7i2l8xA4+UnGKqHTNSvrKdNTuleR0IVYhtC5 /nU2leGtO0uyhWOxiaeMAmZkzubuan1rTl1XTPK2M7Rssqj1ZTkCqcGkz6tFNJrBIeVdsca9Ix61 NaaPPC4a+v57tANvlnhce9U4NH1fTbmRdPu0+xltyxyJnGfQ+ldDDJKkaCb5mx8xU8VKTgj5c7qZ 5xDbdjemfxrG07wvZ2GrT6gN0lw7lgHPypn0HrWkIVN+12BIpaMRlT3AOag1PT4tUijFwJUeI7o5 I2wRT7Oxhs4fKhtmJc7mZ+cn1JqaKG3WZnjtUDt/FtAqsLAf28+oNuZ/LCRgjhPWpGsli0q6trdW /eJIeR1LZrL1DRZNQ8M22loDEY0TJYZUketQWGja5bbUa9tkhHBMUYBxXSRNsjRSpLDHzHvWHrd0 2o6pZ6ZbjcRKJLhh/Co6D8a32kIcKsTkkcnHAFQm5ctt+zy8enelW5dxkwSjtgipVlYgkxv0zzxm kW5bIHlvz3zStO6n/VsR14NNW4JyvlOPwp4lYg/u2574pUlYPgxtz7UbmwTtbH1pQzEZyaC5Xnn6 CkDtz8o+tCklcbaQvnd8vze9LG7FPmUZ9c04uf7o65PtTd5BHyilXJLLjgHrTgSVyBg9MdjSBnIO UHtzTTvx90H603dIP4Ru9KZJJKI+Ix14AP3qXzZv+eaY6EFulKjS7yDEqHHTd1oV5/MP7oAf71Ba cOcRKfX5ulETzndvQAdgGpC8wK/u1XJ5O6piWJ7D6NSgtjoM9xTslR1HHakJJPY+1APYj8KQnnvi lLce3pQGwDwelJu25HT0pM4I7AdaUsRjb/OkZgMHPTg09Ov15rxj4MtsutTyedi5A6V6t5q85wQa UygL19uBSRzd2xjpzTzMP4uP6UhnBYg5z/OlaXPQ8+tIsnXJpfOAOBn3o8wZ9qBKpxjoaPOAI9/W lM6lDzkim+flTjqOKaZsY3cj0pTN2HUikaXPPryPrUTP83TpS+b1z3p4lAx70faM53HP9ab55249 euKXzShI/Gl8wMpOBQJB1Ocjpml+0cHPI9KYLgYweoPWpxIPLHOTnNMafPPPFAuBn3I604TgKD6U okUcg4NBlAGOp6kDrQZcDBwDRvX1pyuOowcdPalMg9fc0hk2kn26UCYYx0OeKPMAIHTFL5ozg9aQ SqGA6+mad5inPdu+aUSDB6Z9qjm3NayLGdrlcBh296oaPpEelrK4lM9xKQZZn+8/pWl5mRjtigv/ AHeOeKXeTyf170hckn+VG/HuPem79q9cClWQnIDdPWnqwIPy9KAw3HJ5pS+O/PuelIZSc4OBRv8A 9rH0prNk59PWjfgHByDTg3fJx2oDdcEAfypHJzzjGegpC3HA+uaVZMDDDNO83jAP50gYYbpgdOKb vyckfhSFs59T3p27OOx7mgNgccDNL5mQOlOVwwO7qRijO7t1FKW+bPfHT2pCQ+D04zShsAY9M/Wg MBjn6ZpWfI/WkJHGKb5mFAwPTinbxnP5U1j6Uu/HGe/rSbwTz3pC3J55560nmdv1FAkPfn3qaIhn Jznj8q8S+EUmL/UVAwxQGvUxITkjgehp27jIBNMMjLzjk8ino7cgjPPUilppcgnjp3o80j5gDnvS iQkcAj2pBIScNTgwwaaZM9iaRpM9FwPemrI69OcdM9ac0pHbJpGZhnGcDngU1ZXb+HvS72B5JNAl xnIJxTS7Ek80FmcAHP4Uu8tg+npTlLgYIyccUGUq3HHoR3pvnEZz1x6Uby3OQB3x2phLelTKzhPU 9qaHfoeuOOKYXYZwCKe8hA5yOaSOZs9OlSGRgeBzThLkZcc+1NMwzwDjr704Snrg8UNNyeMdAKdv IxjtTgxK9MjvTd59advLDGMZpGJ3emO9KW9OtJvIAp/mZGB9OKb5pB9c9c0K+RnnGecU4O38OR6U 7zG60gY5/nQJGyQec0F8g5GOetAcnHv1NOEpXOOg9aar/NTy2CQTkeg60CQg8kc9B0NG4r+PY0eY xyABnFN3fKMcD0Pems56BuamycdgabuYHBo3sHxk46Y9aQSknH60CTBPOcnvSibkjHBFI02DjBFC vli36fyp3mdwOKY0rY6flSpIdvIp6sWU/pS+ZtwWBzijeCeT+NMEuT04qTeNvsehpC3POT60pYYH saYZCDgdKcXYkCmiQj8+3pSGUjpgen1oEueopTKfT6f0qMucknp7UFyfu8ZGab5hHU8+9SQT5LAM QR715F8G4S+rXzEnaIxmvWzbAk9OtKtsOvJ/ClNqG4GfpT1tcL8wyRzzQ0IVsYxjtSG3GRkcHpQt so6A8UG3yDkAfSmrag8c/T0oNpnGD70n2Xbngk/1pzWwIHBFMNuo6ZNDW65HJFH2cADHpQbfaOBn jrTTDnOAcHrSC34FL9nx3/Og2+epHFKkBBBwP8KeIQc8cGm/ZgT0GB0zSm3B9KabcYABHX0oFrgH J5pRbsDwM4/KlMAJzj8fSmvb4GR2/Wk+ygjrkj1p32THODx6Uv2cUpsty8N+FMFkf8cCnrbDjufe gWoLEYJ70ptcHHOakSI7TheOuDUbQ7mA2n2wKPJJJwCKesJOQRkH1pWtyMkdaYbYEE7TnFCWxxkg gelP8k9dvH0rOV5T4iNszDyzBuC9600tztPqfXvS+Q3fBOM59aUW4ySefpSNbkdAMUjQKEz2z3oM GcAfljrTDbluSOB+FVLjUbLT/wDj4nRWIyFz8x+grFl1++v1K6TYOIx965uBtA9wKzX8MapqjCX+ 0rlZQcmU8Iv0FXX8P+JrSJTZ6ys23+GWPBb8RTbbxZcWM0Vt4h094HdtiSodysa69IQw67hjcPaj 7Oq/MRhhzUuxOBtOTULRMwI6j2pPJJHfP060wwY454pRACx4PPapFgBHykD8KX7PleCBn1pBCQeR mnCDnjIoMA7HGKb5B7D+lSJEMENjIqNoieR0pohOORxjHNKLbv26ge9OW2PT+HpS+QAQAeRTvI6c mjyFB6/lSiBQcc4qNrYsfT0z3pPsYP8AEMdcYp32fp096d9nH40w2wByOmaY9vyNo6fnUb2/TPHN OgtlywxmvJvgohN7f4/55qK9bKPgEHFKIpGOQ5GR+dSNAwX753e1IsTY5fPvmnmMHA6/XvTwg/iP I5pNuB1+tMIwTyMf5xSgZHB+poVSMhj0NKEO4HP+fShkznk9KiMXzHk4P3QaRYXCjcQSTThCRxuH TrR5LDGW/wDrUNATyrn8qPK/2h+VNaE5GDijyTx8+PwpDbkkHeaR7Us2fMwKf5GP4+B7U4xE/wAQ z06UnlHvxSLBnOGP5U9INvBc/iaBFgnBPP5UgtwG+99aU2+4fKSPelSMAkbmP9KUQqSTz9DQyA9D 15pAuwk7iQaTyecknBNOEYyDk0NHk5DGlCYzzzUbW245DkY4pxhYjBds+1Cw4OS7dOVNKYt2MMci jaSepOP1pfL46njrSeX8uNxHNYKp/wAVtINxJFt1re2MRy7Z9OKb5LBSPMfk+1DQsSMyuOO1I0ZJ z5rAjjtUNzNFaoZLm68tPVsYP0rn7jxUZbj7NotrcajJnBfIWNT9e/4U99N8QahtF7qcVpu6xQrk 4+pqK18EQQ3wkSSVm2/PPI25mPcDPQV0FlpdtYptg3HP95iwNWhGVUAtwT0Ap2AOpwAarXmn219G sc8IcDnGOazl0++0uFv7NkM8Y5EMx5PsDUtlrVvcS+Tco9rdDrHL/Q9DWngPhtxHrQluV3fOxBOa GhDfeLAZ45pGt1GeWOfelVQEXhuOc0uwH7oYcetNa1RxtYNg9eaQWse0KpbHTBY0v2deMgjn1NRG zibO4P1HO4ipDbxsApDDHuaQWMIJGH577jzSfY4thXDgeu40GyhYgMGwOhDmpPIQ8YPHTk0eRGD0 P4E04xKeSCD9aeqgAYGKUDFG0YxSEdT096T+H+dH59c04Z70hAz6+tJsBPXOeaayYxxkURptY8fj XkHwQH+mamfVUr18J04x7U7GFx6+tKBjPGPejb/KgjoT2pu7Lcc0Nx1//XQORjqaO/rj0oxgDH40 dcdKBQeSPpR3H+FKMHn8OBRjpycH2pH64HbtSAHaAGpdueTz9KUL7ZpCvqeaACVpuNpwelO25Bye e9Lj5RtBxQAVGTjNKDnPANJnB68Z4pM4X0P0pcHafTNLnHcf/Wpp/HnuacCDk45o5/yKO/19aB+Y 9aQHt/nFLnIB6e9HJGCKCfrxSjqelA4JFGRnAo4OKawIBwecdTWNZFZfFWosBzFHEn86045RLNIF 5Cgc+/epQwz3z1Oe1RyzJDGZppAI1HJJwtc7qvitmj8rQLf+0LgnGQPkX3zWdpXhnVL2+F74ieOc 9fJZyVQewFdjBDDDGEt0RFx0AwMVAtqZL37Q7FsDbGueF9auqOg6980oOB6Y65p3OOODTTg5/Tik 5GckY6UhIP19DVa6tILpClxGp3cZI6fQ1mCO80XOGe5sSckNy8Y9vUVs21zFdRrPDIro44IqXPTr 170DOTwKbzuPanBe36UvXP8Aex60Z6YHP0oHtjBpuwjOSPrSkevc80owfx96Dz26UuB6Ug5P0p1J QTz3ozkDjrRk+lIT+A9aPyBPajjk56fpQFGB60vA/Gkz24HOKPu/T1oHU+teP/A4j7VqmcghE617 BjoM0oAHakye/Apce56UjHA700ZXPFDZY8YoHy+v5Ubsgj+lKAPQ8nrR07/hQcgdDTScDqCcUA5H bmn9O/FGD68UhOcdPpQBznGfrQOCTjnv7U7mmlTnNAHGevoKMDOfftQevrzSgk5BFBGeo+poIIHG aMZ75BppGQQuMGkByMnrj1pSxGaQMO/404gYzjHuaD1wOT60dsnigckjocdaYCQTnoP504Djt+FL jrxkHvmjJAJ9e9Jndn09qCOnp25pA4bPBH06U/qOOPeq89zHbp5srbVB7DNZVoyW1/qt6z7gFDHb 6AVU0vxHawaUt5cyZluWMiwxrucqegAqVb3W9VJ+zWq2EPaWflsfSnweFrd5fN1K4mvpCP8Alo2F H4Ctq3tIbaNUgiREHZRingY6csPXiqNvaTPqU1xOxKqcRL0wPer4GTyCM8c96OFwFI445pep689K UnIxj6imkgfez7ZpoXnDZ45pTjGcjPtSYAXHce/NNMalT8uc/eHrWVJGdGu2uoVJtJD+9Qfwf7WK 1kk8wKVIZWAYZ9KcGyfvflSq2fc0oBHpQewBz6mgDGBzn2ppJz0bFOOPQ4ApCOOAc0DA46ind89e 4pMkA44HvSjkjpxQCTjpRu454NJnOOfwFH5fSgYJFByPTPagcfQH0oJPelHQ45oPv0o6ZxyRS9Se fwoAx3rx34HhvtGqk9Sq5xXrvmBFJJwB1NN+1RbR+8we1Il1G+dr9PWlFxG2TvGP50rTqibmZQvr 60iXETgMrqfcCl+0KeNwB7mkeeNT94Z9qTzYwcbxz7U4Soc4bn3NHmoM/PwDS+apAAbBqNp4cn5+ B6U5Zo2UOHG0frQlzG2QrgkdRTTewZKGVc9xTorhJM7XBFL9oTJ+cZ9DSmVRyxyPami4RiCpOM44 FPMo9DnqOKaZ1Hy5PHel80c8n14FIJBnGOfTFIJl3lASWHoKQ3Iyfkbp/dpPtQ4+R8gf3aeZgQSF Y7fami53RCQRyAdMEYpfOwhIVz9BUIugxP7uXGcZ206O4DPjy5B7leKka4CEgI7H0ApFug+R5cnP qtI1ztbbsfp1A4o+0DOAjkng/LSNcDGNknTHSka7CMFMUpOey8CnLPnIKPkdiKeZuB8j/lQJMn7j 8eooaUZ27Gx9KBKG3bVPAxnFME4BJIZVXqW4xWDq/iGzkE9naxSXsjKQwhXKj6muPhuda1W0lgkW SxtXlWLav3z659q7HStObTp9kOmwrbD/AFcmfnx71ofbLuHURFcLF5Mp/dH+JfqKuLNjdtjlODjg dfek+1/NtMM2TxnZVeHVvOuZVjt5WiiO3eF6n2qyJ+mYpumTlajjvxIR+4uBg8kp0p73flsFMcrZ xyFyKa94UkZTDKcd1WpRcbjjY4J6cUGfHVXPpx3pBKSQCrfN1OO1Bk+cjY+B1wKFm3yDCt+IpfNL HaqnHriiXaysjxlkYYIPesiwMumXh0+di8L5a3kbrzyUP0rW3vvIVc8ZyBSrIzc+Wfxo8x8/6vIN IZ5OghJpn2mRDjyGH1NOM8obmBj7ZoNxMrYFs31p3nSFSTCw9iaUyyYysfPbNM+1Sn/l3bA7g07z ZDtzGcZ9aQyOJDmPC9aerMcEpkGmmVt2BHx/I1J8x4C8HmlUs2dy8e/el9/696Qgg54GaOnJ/MUZ 56c+gpVPbP4UoOeOR/Og9+v4UE49vSlGa8d+CBP2vVBj+FO1evhcLjGRj0ppAHIUYHt3pQMYHOaD 684oIyMYDD3NC4/h49sUoHJ24wPalOO+BSEgDPHv7UcAZ6k9fagKODjr6CjGVznv60hA3d+aMYwB wOlBGeVVfrmjbwcoB/u0oVVI6DPYUoUdwMnpxSjnAxx34pCB0Ax26UYJJ6YB/KgYPTd9aCBu5/Ck IxjkUmOeAMj+KnKoBB65oJ5I5FJyRyM9iKaR0yoAHag56jIHekxlst2755poJGc9jUmenJ/CnE5P BP4UnOep9qBwTz9aBznBznsaCAR2x3PejG045Pel55znjpig55PP4Go3lWJd8j7Bn+I1jXGvvJI0 Gk2z3koPLniMfjVDU7HUEsZrvUJjNKSNluhwi59TWtotlPZ6eguBbrIR8ywpgD/GoLrw9Hda3Df+ eyLGQzQAcMR3rTvbsWlvLORuCj7uetV7WBLt7e/mjKTeUcRt0Ga0A2PmABHrUTSI4eFXAkwc88im W0SWsKRQrgD3/M1NuBUDnHc5o3k4J9fXilLAdTkH0FK2dvy5z+tISeQQPp/jR6jqc0jE9Dz7ZqKa 6igG55FGe3WmQ30E5dYixIHcVOGGcngHtSnIXBGQf51S1Oz+2WrIrkSId8T91Yf40mlXxv7MeYNt wnyyL/dYVdBViB7d6k/LApeDwCQe1GcnucUcNkd8+tIR3Pf3oLZ6Yz9aUAdj83ejcPXnpSH5s5JB 7YpMEAbiTxz704D1B46e9IQOgzjuKXGOmePfrSjByOSPelxzmkOf8im88A/nQOAdvX+lLznr3zQe MZPvmkJ9+QOTTs++PTihe/8AKvHvgjzd6p/dKLwO1evgdPT2p2fY038P8KXaSep+poI45PPpTRgd velB9v8A9dIfvfL6UbsEZp2cdM5puD1ByTTsnPvSHPQAc03JPBHpTj2JpcYz7elJnGemKcTgYHaj tz0oPOeuaQtkYyPxpqnpk08/d78+tNHyqaQjgjoKGbuD+VLvzgU08+v0oPTIPr+FJ0/Co5GJ47dT TgCVyrcihSBkE/SpFJApeSCR/wDroX+vBpSx9/yoHvxn3pCQPx9O9RzTxWsbSTSJHGuTljWWmrtf xg6bA8secCZhsX8O5pI9Gaafz9Una4k7R4wi/h3rWhjjih2pGsadMKOtEkQkDK65VhjBPX8KyYYN Yt0Efn28uMhZGXB9uKrHTPEM/wAkurxJG2cmOIbvzqwvhy0FnBbzy3E/ktuy8nLt6k1rDhegwB2p DIqDLMFBPCk9TVOx037C1xK8nmSzvuZ/7voKugd8YNOBwoz+A9KQnp6HoKUngc8nvSDPB4pTu55P XoKz7rV4LScRDMs7jhI/mP41FPFqF6PL3i0Q9XX5mI9ParNvp1vbKu1S7Y4eTkk1O0iLw2wZ+gpj XEMQOZY1GM8kdKpS+JNKgO17og91VGP8hilTWopo/Mt7S5lUHAKrj+dZN1qc+lamb4aZcJavhJiS OGPANbA1C8yMWD5+opxvr8xNiyIYHjcaYLzVGZSbFVJ/2utPF1qQAzaR4Ho9O+0akQMWiDPX56jk vNSQfJYKwB5w3Sq/9u3kSvNdWHl2wGQ4OSfwrQ02+XULNbhEKh87fUetWyeOe/ajtg/5+lGRjI4I 4pehH1pdxxnr+FJn6ZJ5pd3rR19enrQOaQg9vzo6Ak9DQCc496cW49vWkA7e3ODQ3B60JyelePfB E7rzVOxKqOK9gXkDjGe2KXf168dqTJJHYnvQT6ZPNGQT1PJpMY9Rx1pThRgj8RSdAOT+VIzfPjqc 0M3ODwB3pVJGMkH1IoZioz1PvQSFx379aUcAc8+lLkYABOfakL8EgZJ9aBkZHHpmgDvkZFKCc9MZ 70ZyRjn3pOGHU0AYPI59KXsDg496Q9SOeB+NIzDOeRmmZK5HBIpA2MEcik3ZbkgD0pS+RnOPpRu7 H04prEAcEEmnJuKnIxj8KBjA4O0e/Wn564zgHigEkkD+VKvOOuBQWwMjA56mobm9htF3Tyog68nr 9Kyp9YuroKNNijRTw09wdqgeoHrSwaXaO4a6u1vJc5yzjBPsvStjIULwDxwPSnDDde3c0Kc4z27U vU5PJH6U3gFcjjPHtSk8EA8jpmgqoOBgUwMeM8ke3JrMvtP/ALV1Cym+0YhtXLPGp5ZsYANahBXn 1HSkDfdz+Ypc8DGTn2oxgng/ShucH/a5HpVS71S2spNjOXkPSNBk1UaC+1KUee5tLXsi/ff6+lMg 0Se1lY2t75aueT5Slh+PerCadOEAa8mkOcZChfypw01RkPPOT7NSDSbcsC4dj3Japv7Mtcbfs0b4 /vLk1YSNIlMcahVA/hUUgBYYOeKhurZbu2khlUMrrt2npk9CaqaFeCW3ktH+W4s38qQH8wfxrTOB g9PUDnmhTub5m69BTwc4yMZJ7UmcgAgYPr1qne6nBp6Kbhigc7V46t2FU7SA3e64u2jwhykCtkIP U471JoPmfYHbaAGlYgDtz1rU5Udif50hbnP5e1AwvbPr7U4E56dKUt+vUYpDzknp9OlKCe2MUhyO c49xQ3LDp0waN3c/zpBz15xxTsAjI65pRxxnmjr0zikL8Y70qdfrXj3wR/4+9UzgEquRXrWZD3Cj vSMLnOdyY69KRI7kZLshJPGO1IBd7zudAvpTLed7hXeGWNxnHFSoJgxEsiEewNPBckksu09BQwl3 Ehk9+KZIsvVSufU96ZAJ+kjKcnqKkKyFjhhj0I70iC4G8yFST0x2rOSe9fU7mBZIsRoNuV7mtBBc CI73QyeoHBp6ibHzOmQe1BSX+F16dwaasdysQVpELeoHWhVn2Ll0JHtUmJOzjOPSmbJguBIoOc9K XbKFLBlJPp60qCXYNzqff1pNsnTzFIpGSV1Xa6hhyfpSMkuSQ42kfnUbCUEZYdMUi71J+alYyFwQ wxjHIpj+aXBEmFz0ApwWUklpOnpSGOTacSc9QcUkcc2fnmyOp4qXErNjzBjHpRsk/hmOPyqGdmts yzXoiiX7xbAA/E1ljxD9pcjS0nvdp+8E2p+Z608w+JL58ia309PRV3H9eKqnwDa3E73F/fXVzK+O S20D6AdKvxeE9NjjCkTuo/vzM3FKfCWklSqQMgHdZCD+FRf8I1Jaq39l6lcQH0kPmD9aal7rOmhh qNut1COk0HUfUVesNVttUXfa3JJHBjIwy/VetXVWU5zLkD0ANIYpPM4lwD/sik+zysxYXHXn7opp gnPIvGA90HNVrmCUxvE1/skmXYpbAJPtUekaP/ZVgltBdSOEB3M6jJJOcmrkkE3AW5cHP90U5LaT BzcNn12iomtZ2+X7ZICOSQoqO7ItbYyXGoNEg/jwPy+tU2Oo6mqrbzG3tmHMrqNzj2Hb8arWk1jp t+9nb+fPeIA0kvl5b86u/wBpvuYrBdOenCAUwav5K4kius5zu8vOPypP+EgtCQGe7TjvA3+FJPq9 kCub5xu9UPFINY0xUA/tHnPentrenxjab/n0pkeuWGwgXM7DPURnNI+sWqRFwbpl7Yibmkj1WKeL 93DdkYx9wg1nPfSWetW94tncBZlMLkkDee2fetstdPGW+yTLgYwXFMH9pM67bYKv+1J0pGg1JsjC 7V9zWdqGp3+jWzy3QikkH3I0clue5rJ12w1A6aby+uIxJLIm0KxIUH096uR6Zd2VzNPA6RKsPKFj hlK9T71s+H9Nmi0e3FzKxOzIKscc+tX/AOzgSGEsv13GlGnpjHmyjPq1B06MLtEsvX+9Tkso1XG6 T/vs0+K1RWLeY5z23Gnx24Vid7Z+vFO8rrljTgoUYBPv70ABVPOT6elBAIAzntS44BGcn9KXHrz7 CjjNAIH9RQenQ/lRGOc+1eP/AAT/AOP7VM9dqdK9cBKsTjOelZV34n020uGg855Z14KRjJB+lS6f rcepTmJY5YXxkCRSDj2qfVbwWenXFwQfkiJqDw5B9m0O2XHzMvmMT1OTnn860RtwfTnrSggH3FDd Mjnn86jw3r9BTgu3qMk9CKUYJ3dKCSR1Oaw7Af8AFWalzkFFwK3V5Az24pwxg5OPWl47YBPPWg9a QcDApcn+HpQcE8jg00jCkAg0DkgDp3prDnjpQDgdfpTTIc8/njio8g9f0oYADjioQSvUU/cGbA6U 4HnIIpc8ck5ppB7Hmnh1CFiyqE5Zj0H1rHuNdkvGNvocJuZu8rf6pfcnv+FPi8NJcSCXVZjeygfc c4iU+w7/AI1tRRLDH5caIijgKowBS7eflOMepqRSf/103nBI79KQcE0pA6dOMUgQj0z3IrMv9Atb uf7Sqtb3Q6TRHDfj61Uj1S70hjFq0TSRKfluYxxj0YetbUU0c0SzQsrq3IKmpAegwfwpCRtJPFZN 7pn2zXLS9Mi+XaKf3ffeeh/KtQEjAJ59fWk3k4G0+gp4PFZep6s0FtcfYE+03ETbPKU8q3v7VU02 1u7uJJry2DTn5iZTlAfZa2mkWCBpZWUKqks54AxWBH4q0tpmlggn8+XClkjJ3Y9/StBPEVnJIqHz kJIHzKQM/WtJ2Ytt4+tNBPOC4+lRvFGTkxRgn1QE/Woms7dsn7PAcdzGKPslsSCbaE+xQU9URSSi KPfHI9qkI3ALkkH8qQ4/hLewrP16yN5o8xRiJov3if7w5q5p832qyt5+MugLZ9e/61Z45+6OcZNU JL+WaQ21jHuYHDSsfkT6HvVHWdPgstCvZT88rJ88jcnqOBWdrgF9/ZWjQ7TMZVmPoEHX8aL65bUL 6eC3Unc4XjuFGD+tdTYjFlCoG3EYHNTOfkzkg+lIH456njilzkDikXtwOPejBH3uvHSnL145z7Ur cKeOtJj5c5+nFJ908nr2py9emeaU8daRcjILUufTjOKMAjjp1o9eTTlGM9hXjvwUJ+1apz/Cuea9 dAIA3c/0rOeHT9Gtri6EKRKSZJHwCc/WsrQ5Wna41zU5FhFwu2KMtgxxg8H8aPEF5/a8+n6VZsdt 04kdx/Ci88/WnanCNa1gaUZmjs7aMSTBW2lj0C59Kn0nW7Br6TSIJnlktlznGRj0z7VmTeLZ4b0S bY4tMSbyWc8s/qw9q62J1kiWVCpVhlTnhqcG4549KCOD159KBjH5U4Z4xWTZx7fEF6wHVR83rWpk 7h6EU4jI569adxgAcfh2pucj8afxjkdzSAkZ9KPr1HNNJPPGD/KgdTxn2pN/fPT9Kacc9OeuaiJA zuP0oLZx7007c89elNJDHg4BpMnPHHYU7PPTNKXBJH5VTvNRgsI83DgOBhVHJJ9AKoJp97rZ83VW aK0BylshwSPVvX6Vv29vFbRrFCixxgYRYxjI96lHy9KcvPHSg85wOetIO/p0oBPGfxpxz27+lGcf Sl/h5/HikxwenpTHRXGx1DI3VWHWsOXTLnSma40X/VZ3Pak5Vv8Ad9K0NN1SLUbdZIwVkU4ZG4IP cVcX72c8E9KoWNiYLm5uDMZWuH3YzwuKv9vUDrn1ob+vSm7CVUg4zz+VcZ4bhuL+81ib+0GtzLdt lIwN+McVNq0FnZxCGe9u7y4ByEEmCvuSOBXJ6be2mveIk02Vr6VpGA+VyFTHcjvXc6kLLRdPUT3s yhRhY0ALN7ADrVax0i51hI7rUDLb26/PDa5wfqxrb/s4lgBdTqhOevSni0cHH2mbAOBUT2ch6XUq 4/Shbe4A+e6cHPoKfLDcvs23JGM54ojglREzNlu/FBiuS/yz4XsCKr3moR6dH5l1dQpjrn+grFk1 nXdUcHSLOL7Ky4LT/KW57Csix8Uatommyie1t5DAxBG/nk9MV0em3t7r1uPt0ItLeRQwRW+Zs1vw QxW8IihRFVf4SeazPFUgXw7dNtEnA6Hqc1gW9zHbytd3IEN60exVbkQoRyfqa2NEtLVLT7WsZigK FU3ZzjuT7nrWppvmi2BkxwSEAP8AB2P1qzn5SCKTORkDI9/WhS34dKdyATxn+dOIyeD3oXpn6U7G M+lAOfXOeMUMBk9sUZXvnPtS5znvTOcj6g0vKnjrTlPOaUncMdBTlORXjfwT4utU7DalevbhjDHG f1qlrGl2+tae1pcsfLfHKnBrNtvCOl28qNJ5twy/KnmyZxRo6xXWuajdhQqxYt4/YDk1b1DQ7LUZ mlm82ORuH8tsbx2zWPoNhbweLdVW3jCpFCiIv161qR+GdMi+0HySxkQqQ/KjPYVD4QnM2hqkjhmg dozg9wa23ZQRuAwffrSqwxwR7c0m8AckAAUu9Rn5vyqLdArPIWVXx8zE9cU43ERQOrqd3ORT/NUY O5SD+NCyxscbucdKPNjUcvg46GnefH2ZSB2FMN1GuCzqPTNKbqE9ZE/PrTWnj2bjIFB700XUJXcJ FOaYbuHbkyqGHvSfaI24V1PtmmNdRKcM6j6mjzonGdw9c5qPzkHO8c9s5pPPG4YZQO1Ks8Z5DrkU rTRhsbx7juKoalrEVptihPnXTj5Il6/U+lN07TBHN9rvmWa765bomewrX+0RjnzF5pVniOf3oGet SCeIZHmLgU9Joz/ECe+KJriKLG5hzwMUguI9wG9ckUGRQRzwaUTIWADZqQuBzu/TrSGQBsdKaZlH ce+KC4PBIx1prspcfNgdscVkapYvHKNRsABcofnjX/lqPerGn6xBqlq8sW5WXKsjD5o27iobW9sd L0vfNP5UJY5aU881oC/h2RyBt0cg+UgdRTvtcf8AeII7kVDNqFtDbG4eUCMKctngVyOiyLq+nE6d EFnO4yXb8AcnketTp4Y/sy3ldLsXe5P3v2ngN9D2rn7Waexe7bw1pP8Apcmd98z+Yi+oGK1dG1bR rFlk1K4e61EfeklX7p7gV0ieJ7C4X9z5rr6KmaZdeLNNswpuWmjQnALIetJbeK9PvQXtvMkUHHyI afJrtvEoeWOVASR8yYzSprAcB0tpnjxncBwaDq21d0sO2Mnje4FEWrfaZW+zC3kGRysw/lWF4i1v Wnv1stLt1CEczE4x9DWXqtrJpWlyXN8rXM7DOMZKn61U8Pahrl0rT3l19mtCuFfbhsf7Iqx4e0KP UNZu55/O+xxSblSQcu2Op9u9djZXCxx2hwQSWUDb+VaDzoi/MHODndiq2pJDqmny28+9VkHUDkVz N9a2txqMKPdzXvl4GyJc5I7ZroEEs0qS3JZIgABbqvAHvWgt4ihgEkG3Bzt6ikF2hJyso9ttOS8U 5ba5yOu2gXIwcK4x1O2nC4BUDayjp92lF3GMgBsfSpfNDngNn+dPLbUztODxQHBBwD7VH9oUOFO7 d9KcGoEnqTnOeKcXC8YPHel3e3TsKFIAP50ueev/AOqlBxk4J57V4/8ABL/j61MAj7qj2r11QuMc 08qrD7v0OKQRqB06dMioILKC2DiKMBWO5uOuamEakDIAz2qpbaYltfXN2oHmTkE8dKtBdvzHoMk+ lc94Ut1ii1LaMK127DNbjRrIQAAff0pfITaBtBxSGMc8ZHpRs6g/pUT2sLMzNGMsOc9DTltoVRcR gAcAU9UXGAo+uKcEUAEIMnvTtkeBhQR796OFGFxn0AxTfLQg7wPxHek2Jg5VT3HFNIJBVTkZ6EU3 5c4wPyprxRnJ2DmoyQj7VUfgKjfbuzhcnrxxTxk+mD2xQy5YkjkU0rzwevbFOChehwKztS1A25W3 s18y8l4jT+6O7H2o07TFsi88n767l+/I3ceg9q01PA2/iB6e1SBAwGQCPpTgF7qKfgdAOP1pyjb0 C8j0oZR/dXGfSgAA52LuHtwKNvXIBPpjpShF9APwpwwM5A6daUqHHzDJHHFNYA9FB/Cmk5O0BR68 UHkkYH4ikwPlIH0x1BrlPEcy+H7xNUtpCHlb97boufMXufrV2PRdO1+SPU7gtc28igpEx+Vceore SJI4lREUKmNqAcAVl6jrsFswtbOE3dyxI2RjIH+8ewqtJoM+o2m7V3VyqkpbRnEan+tYXh++v9Kg extNI8wq53zwfN36EeorWkEF+NmrXrtDjmFU2qfYnvWxb3GmxQJbwyQrEo2hAMCop9O0e75ktrWR WGDlafY6Rpemk/YLe3hYjkqanlt0fO5I3z1yB1qG1021tXk+zQRxtJ98oMZNN1DRrHVFVLy2SVY8 lc5GKh03RbTRy32MSqrdVLZWoNXgsb8CJrBL2U8AYOB/vHtVK08HafbyLO0KwyKfmWBiF/8Ar03x FbaTcxKlyjzypxHFbtz+OKbo/h6YWaHVLqV4wd0duzZVPr61ia3Bo41D7Rf6jLLKkgWG3t+SgHoo rpfD0pkW5nnt3tlkcbRIQGYY64qS61CKwsFcSRl1ckAnrzSHxD9qKw6ZaSXcxI3sBiNT9afJpV7q GBqF4ViP3obc7Qfx71fsdNttPgWO1gRIx145zVsKmRnPT8aXgL9fbrTNwYnb+dPHToPQcdaMYPBB 470hXouBjsaAxHenqw5/IetOGec+tL075/SgMQOvJ6ZpGPX1poU5JwARSjIOO56Z7U8dRz9B6UnH vSkYx/nmnoP/AK1eP/BHIutUGONi168oGRzTgf19+1APPv0waCfmo5B680nOenHqaYzfu24/hORW boVk1npuyTh5HZ2Hpmr3Qccf1p4PByMdzQT155FRnkjIyT1pSMA5yff1oPQANk9KCfpn+dL0HX2p N+B1P5UEgc8kHtRvBByT7cUm4DPGfc1GeGzn/CkzgcHLHpTd24HIzmoG9V60DnJOfrTnbfwBnFKp YA5P4HvS5Bbgnd61T1PUlsLcfLvmkbEajqxqHSdPktQ0902+8mO52PY/3fpWkyg4PPSnAlTzTxyT gnHtTx64xmpAwyMDmnbgcDvSEjPP4U7P+R2oDcdun5U7G7pz70nJOPzpCD2PNL0PHWmYwcgc9qTg /wCye1VNSmeG0lMMgjkx94jhPeua0XXtNQGHUNWW8uGJ+eWPAz3C+1WrK5i0DVGtWlU6XefvbeQt 8sb/AMS596vX96l9ZuumanHHtBZyhBYj29KNMGm6Lp0W+eKNpBvZpZOXJ71NeanaXWm3C2t3BJIq H7rg1b02KKOxiW3K7QgyU6Zq00SH70aknsRUMyWaR7p1iVP9oACoTY2cijZGjj1Wq9zFplqwNy8U JzkBnAqRFtbiENDcAr28uUc0NBFGfnu5Ez/ekFQXNzBYwgvdO5c4UK+S35VmlLjUTGkly9lDnPlt IA7j39KlmuLDTITAs8zyNyqRNkn8ao3ELXdusuoXos7YNkbJct+PoaqRanbrmDw/pct0xzmaTO0n 3J61ZTw/qupoi6lfCCAjLQ2319aLDT9A0q4eJlTz4ycNI2W9eTSS31tezyQ2lopx1mmY7R9PWm6N 4fsbyRmuJ2uZI3LbQ5Ea/QV0qWrRkCJ1RM/cC8Y+tWhyCzrk0c57UtFIoAzijI556daCxBG3rSBz t6/MeooP4ewpy5BGOtSg9vyzS5Hcjmk3DoSM9ee1GRye2OtHmDoBikXI4xkk/hTs8Ac880dcjv3I pe+alQ/j71498EPlutU452pivXsZwc8AUoJ54pQT+FIxzn060fh+lNKgkDHUdKCexwaax4447fSm gkD0pwbP3etGcjpx/OmA/N6+tNYlTzxinDDZJzgdqQkgZ/vVHk59BTieOvFIzEjIxTCx3DHb9aUS DHrzjNRysc8c5pSx25OASD+FMYknbwewxQGznv8ASgsqjtz2pGO09R/XFNLZ6fzqK4uRbwvK52oq ncfb0rM0y2kvLv8AtO85dh+5jPRAK2wc/e5Jx0oH/jx7UvOfbrmlVyP51KGx16Ubxmnhx0z0pSxO D0PrSZK/jzT/ALh4x+Bp4z1zyTRnLDuRSE80B8kgE4HNIeMkYB/lTONuccZqO6jzaTKFDEoWGfpW bY2Nte6Jbm+soGd4wXDoOvtUWueHLbUfD8unW8CoFG6KNRkBux/GsXSPD2jarpZuJLTyL2AGOZYZ CgDjg8Vu2+jaff6bbfb7OG4aMbVeRN3FVNR8GaE0MsyWghk2EHymKj8aZp3g2OwiiNpqd/AMZ2JJ lfxFdJaxyW8IWSQylTyzdaqapotjrUaR3u91HQK5H6U3StFt9GV1tXm2Z+68hOPwpLvw/pd/MZLy yinJzzIM4qiPC+kWRa4WNotgyMSEKKzJbMeLEYRW32exDYSZyd74/uj0qa1t9H8OMY7VJrq+IwIw 29if5CornwmdevEvtTAgYj/VxMQR9TWmPCunC1SDbKsX8WHwW+prn7Lw/YyeLbmzliJtoIw8UbMd v1I712kcccSKkahFHAUDj8Kdg7WwBuFVDpto160z28LOe5HJ4qYWsAIKwxDB6bKfHCkT5hjCg9dq jBp4JViOOKUZJxnjmk3AMOB+FSBsDPSmhwQSO1NLYA60qMD1PP1oZgnJ6ignIzgH3oI9TnPal3jj nnvUqng9D9aB0J+X600tnqOT1pQ2B0yKcp44HNALdzSZ5HbvQHGCMUu4ZBzkZ61LEe2ea8h+B+Tc 6of7yrzXrwDAjAHPvQd5JwP1pMyD+Ecd80o3H7wHNLlsDb17mm5PHTP0oCnoOR05phJ7LkAUjEnn ZljSIzbCSuMdfej5m6DnqaQ5zjGPUConeT59sYJHTnrToy+wF0wxHQHpTyzE429PamnnqBUTGUfd RTjpzSneVGQM+nakO5ewzTZPMAHA69qikM5YbUTA+tLmckgLGRQpkGQQAR6UP5gXgdO3rTd02eFQ 9qicXGQQin6mg+ecnaowfWsjXI7q/wDsligCmSUO/P8ACOSK2FRlCLGFCKOh7VIHcNk4wRThuPfH NP8A3uMYFKPM/ugUO0oYbcZPSkYzqwComev1pY2m3/MqY6/WplMpbsc/54pD5pO4KAO/1qVTIMHA p67yRwBQRJuB2jp2puJCp2AZ9zSjfjqM+oFM/ek/IVx15pG3BcDHWoJXl8iUlVzsbHPtWfoD3k2g 2byeXkr1555rQK3OTjYcHPGa5e9ml0PxajYQWuqRkNycBx6e9bemNeCwTa0eRnAIPTPenaol7Jpc 6h4wSOcdKngS9W1iRZIgVUc80CPUBjdNAR9DSMl8xP7yLH0p6R3Svu82I5HcVIVujgB0B78Vm69F df2NchpkYFMYUYqxY29xFp1uiyIP3SjGOnFZ2h6bLb20zh0855STIRk9a0mS6BOZUxjpjinotyHG JEJ75Fc5pk/2nx1qBxtaGEJzXRvHMWJWVBx0IpI1uMcyr9dvNOZJvlPmA9vu03bPhgJuc8fLSeVc kjbcLnHI24pxWfH+sHPQ7ajeO7K7Y7gKQeu0UxoLwkD7WuR/sCpEiuMjddcf7gpRBcnJE4+gUUGC cN80456/L1pdk4BDTD6haFgmB/12T7rT44p+84x67acY5SpxLnPQkdKXY6py3PsOKdGsi8PJuX6V IW45pMk4OaTBX/PSgZHofTNLmnAj6ZoUAn0z0pzKMD3NSxDDH6flXkPwO/1+q7c/cTFeunHTAGOe ajNygd48nei7j7imW9/Bc2puIZA0agknPK465p9peR3kCzwtujbp7057iGOVImkVXk+6pPJ9adnj OMAdT6VHFcQzZ8qWN/o2cU8c/MB+A600bXX5SOPlyPWmO6Qxl5XCqO7HAP0pI5Yp03RSK4/vA/p9 alwOM4P400AKeepPSmjgnHPFPJwR+tRt0GetGaDnr6009e9MPHX8jTecck4pFXGewoLEnn0pWPI4 5Pao93BOBntxQzbgCo5xTDk54wRzmsqCXzvEsrBRtihwB6E1r85ByM9OlKBkin44B+ozS9eg4NAY cBuMinnBOO3pS8ZwMn8aQA7gOKkGcdD7UuePu8H3pwA284PHang47Uqscn07f4UE8cKKYXGSPTvT dxyflFNLZzUbcxsT0AJxTLCaK40+CWFNiMvC/wB2pgcnPIOOaw/GFp9r0GZ4lBuLf97Cc8qR1xVz w/ObjQLKfIYugJI9e9WNT3f2dMEIDFasQgLBGoycKOR34p+WYjJ6dM0uACeu0nmhlJ+UdQPzpMY9 PrVHVQz6dLjr1NTQSloonPAAHb2qnpRIjnQsGImPHtV884OMA9KZkNw3Y8HpXPWkAg8c37tw0sC4 x3rocYyvftxQTzxnnpS7iMdT6e9KeTxke+aQE/jnrTWJKg8DnnnpRjOOhGeM0YzjvweSKdgYI42+ ppIxwQBTnHGMmhRj2Pc0DIx1PpT6CDxzTWLHjt6E9KAcD+eTQG+tOpSdx55phbDDHI/lSnOOOtKD 6in9ccY+lOwTweBx0pyHJPzYOfy9q8j+BwY3WqEjgonNdpLrN2PHkOmmRPszR7+ev0rV1GcWmuWG Rn7STBj/AMez+lYuvxS2F+LOwxHHqrbWOeh74H0rYATTNRsbUMEgWLavpketQ70uvGO0Mrrb2wbj naSa5/XLq5l8SPFrUt3aaTD9zyFJV/8AeYdKY8/labdaxpyGGxR0WBUOTIucFj9a6ey1+G9v7y0U bJbVQev3lxmsjwxeTwanf2tzIxW5/wBKgLdlPUVNb2x8S6pJeXkjNYW7FIIBwrt3JrYstPj06S5M PypKwOzsvHare8AHIxTWcEg+vpRuzgdqdnPuaG6d+tNOccdaOCKaVHQfXHrTSMnt7CkLdMnnP50h bAOCAKQEMRzyTSZyDzyeg9aaD/COvv3pV44P3s00kbSem3rz1rC8NBrpr2+IObiYhR/sjit8jjgc YpEyCM5wal27hz+VHAIxzimE85BH07U8OACABQCw+VaemDgk8+lPH48dKc3GMnOfSnHjqO3UUpBx nGCaUfdHOc+1BOOOveoxyOn/AOqkYdKjYhPcHvSqcjBx9KIkCKUjH4DsKOCfcVU1QqNMn3KPmXbz 71z3gKV7aC70mf79rJ8gPdTzmuk1GMzabOicHb1qa2bdZxHJBCiplJVckZGRTHBdlO7vk08EZx7d c0bTsBHX61XvUJtJR32Hj14qCwnVrCBy/GzGB6jtVTT2C6neoEPzMGrRfzNpCkgD0FNRHAJkcyEd M1h3biz8X2jsSBcQlBn1roD1YHnPSgDnHXHp/OkYr/ex9aTG7ow7nHrTkOBgnn6U08jHfNI3APag nD4z15oyDjBOfWnrkjAH5Uo/HGeaMg4GQKF5IINO4VfYUucgelI3b3puPXP5U4Lz6ikLdgaQk++c dKXkAjHJ9aFYDHHHvTww/EU4H2+hpfb161Km0D5se+a8h+B+Rc6qSeiJ0ru7/wAPNJ4jl1WMhZlj HlfNwSOxpbaK71XXYbu+tjBFaIWjG7O5zxn8qZJps2r3V1eXK7JI8LZgn7uOc/UmtbyYNW0+MXiK zbfm7YbvVKzs7ew8RNFbx7Y5LZTnuxB9ag8Y3Jg0YR5IimkVZSBnaueeKx2hMPgHWmhhaK0ZC0Eb cHAx+QNV1guZdBsdUsoy1xPGYXKjna2P8K3NTsfssVhOjYkSP7O7nspHf8az9I1oeHrIabqVtcrN ETtlSMssi9jV9PE1zdg/2fpM8ueA7nywfrmtDT21J90l8LeIZyI1BJH49KvZ75ApOhHIzj8KcvzD I7UNIuOWGe9NDgqDuHNIXVeCRmk34P3lpG2fwkZ9jTGkB6mjcrDGefemgqDjPA6E05dvJzgChtuC Nw6Cmh8jO4cD86r38vl2M7hwCsZIqn4ZVV0C2yVBbLZ9cmtRXUNyy8HgZp6sBg5+Wmlw2SDjjvSN MFJ+YCkEiHOCpP07U4SrlRvHrmhZ4gceYA3pUgmjdiu4cfrUgdegYZ7URsi5+YHH6U8TRE/JIpGO aUSxkFd646g5pGuITz5gCE+tHmw8nzEx9aY08KplpFCeuaZ9oiIz5qkeuaY1xDu/1iZ7Zpv2mJjg SocdcVV064CXF2JJV4kJHParZvYAwUzKM9896p6xeW/9mygyryVAGevNYd/f2+leNNMwf+PuHyWY cV1M8sJjkieQD5SOtVtHvYZNNiUyqzoCr8981o+cojB3rjsaTz4pMHcMAnOKYt1EePMAo+0xld28 YzSNLG7KC/J/WsnQrhWt5Y2ZWZJWGO+M8U+3vIzr9yiuvMKnH41eN3FuOJMEDBo81WQnflQMVzXi x44tU0ScvhVvFT65BrpzcQsp+dSR831FKk0ThWUimPcRo4DMAD7U1by3OT5gIB7jFAuoslhIOelO +1RjOXGKj+2WwIQSjOM0G6gJA3Cla6thk+dkdxTlu4AD8+BjmkjnjdSVbinC7gUHdIOOSaUXMbqH VvlNO+0RH+Pk9KPMUKemPQU7zUIAyfTNOyox+lNzhvT+tDOofHfvTfMCckeuMU5ZM4HfvmlLA4I+ uaUnPTr/ADoWQoOS3FPVjtB6qeeanjK4yx6eteRfAwf6XqnuqZr1x7aOQ/MmT65pFtIlBULgEetN S0hQEKuQevNK1pAcExgEcjBprWkRnSYrmQcDHTFK8MTKRtVgTn5hmmz2kFzbSQSx/upF2Mp6EUy1 s4bKzighj2RoOADSzwJMvlypujJ6GmNGjNll5AwQeaTy4iB29ugNO2hk244qNreNzgg8e9L5aMAC uPXmlVExwmB9aa1tG/3hz160nkIU2lVGO47Uv2eHOdoA9c0hhiDZCc/yprRovKJkEY5phgiYglVz jgA96WK2jjBO0EnqM0LBHkDA59aXyI2yAgxjB5pPslv0MafmaQ2sIXaFXHfmqmrqv9iXeFAAjYD8 qZ4fhQ6HZkL1jGaveREpJVB0456U/aoXDDnNNESHgL8vrmlaGPB3Jxn1703yUQ/KnNKkcZYNt6dM 05LeEu0gRcngn1p6xopyFTn0qURr1wKXylAIVME9aURRA/KiqKcI05OFPHIApjRQlQBFgdcetG2M DhAKY8UefmVTTPJiU/6tcGmNDH0ZBR5KD+AdRwajSKAO2FUsSCfrUgt4SfmSMkdyKzvEKxx6aD5a kmVVxj3rP8Z6dF9is9S8oFrKZDj/AGc10kTRSxJJ5aFWwy8etZ+jRxpcagmFwLogD04FaDsMFEjD Ae1PVcnOMD0xSGOMsdqjr97FAVT94D24oK/7CgDmsvTnUarfIFAG4c49qehT+3bkKihxCCTj3q6U TncBj1IpyKPLYYGMelc74zVVt9Ofjal5GR7da6IFQAdqnIHQUqrgnYqgA0rRg4BVSPpSCFBn92n5 UhVD/wAs169MUrBCOQMH1FNaOMEfu1x9KaVTaflQY9u9GxSqkKpOe4p0Sodx2L054pdqKnCD8KRo w+4FARj7vFKFQKqqvA6gincDnYuRTlQLnAHNLxntRz1xSYBwMH1pQO5ppyecY+lHzDAwKQkHGacm AcAY9R6U6nAkKMDjr7VLEcfe6e/rXkfwM/4+dU6H5Uz6ivQrvxbp9pqf2Dc8tx3WNCStDeJ4Iru3 guIJ4PtDbEZ1xk1stOiEB3RDjGCRmncgDJPpVWzvhewuQNjqxRwexFUX16P+3k02CNpZQP3zIeIv TP1qfWtQbS9Fu71Bn7OhcDPWq13q8sOi2t6qrmYopz/DmtTOQeuSOTmmP9/KgEkcD2qnf6la6dEr 3k8cWf73X8qSz1O2urVZ49yqzbQrLgk+1SrdpNcyRL1jGHx2NJ9ttvtP2ZZozNjmMtzU4bdg8D1O aYJ4hn99Hn0yPzqlaaza39zNFA+5ofvtjj8KWfVYYNOe9wWijbbgdTziriypMgkjO5GAxng0rYI6 4Oc8c0jDB9utCtzzyT0yaAjZ5J5p3Axzx9aOqtxg9MmmMSQAMc9qpauoOlXY9YW/lVbw0wPh2yYj rH9BWpzg5FKThuPXHPejICcDH0pN204NKecEY4PX2prc8jGM1IpwGBPHoop/3hnPTjOKVSMADFPH Xk0byO/ApuSMfXtTtx/H1pOAOTTSwA45qNmJPWgHseccYpxOARjkDA4qhaF21O7WTgYBXjvVzthv lGOc9TWJ4gma4m02zUqWlmDPzyqjnNaGtQfbNGurXIJeMhT3J7HFUvDmpm40WEiJwkCeWzsP4hxV rSrIRC5uHfebmXzB7VpAgLxx/SgtnGByOeaADnhs/jR06fypsjhcA55/lWbbIx12+zyCAcD0otiv /CQ3RJOfIXg+ma0Xxk7e/WgZHvxWH4yTfo0THkLcI3J461uREeWpbHK56VIPpwOlOAx0pODkZpoG MZAobDDJHFIw+XkDPeom74HJ708KAm0dc8+9IoxyGP19aUfexyeM4FOGSBjoO+KPu/N1Oe9O2gjj oe1KOBilGKMH8qTPJHX+lKaaAQx96MEBsnIxTdw9f/r0dwB19M0oHOOR71IMZ56VKuAvB4+teR/A 4EXWq/7qZYV3cRhXxdqd26L/AKJbrnaOTkZJ/SqFrqNm4bXdVljBIP2aEndsXsR7mq9zaWE2ijVp Fne9uWBhZ3Ic5PGK1rK/aDX7uG8m2xi3WTDtwCBzUNhqRstA1XWJiuyeRpos9xjAH6VR0/UpvD7r HcaZLNcXi+YZo+Wfvir2v6idQ8F6rJ5E1uywFdkq4PUVlXuupH4dt7V7C7YJEhMiR5U4966PRtSu NTQNJZNbQbcq0nBatC48zyH8kjzMfLnpmuNttI1qC6e5u7W2vHLE7nkyR6YFXNT1OZ9FiuIbdlmR 8eUOfmHpUel67ZxaNdFPNSeFC7rLwxJ7+4o8P2YvDHeyQGM5LmaQfO5P9KTxpaLILWYXNyizzpCy JJhcHvSXfhXTYntbSJHMs7ZLM5yVrofs9tYW5jiRInERQepX/GuYmudWOjNa2mmB7Z42/eM+AP8A 69XNBj1y6sbV7i5ghiChdqLknA710qjYmMggdx60nBODj1/CgYPByCOvFOPr/WgFcZOTx+dIemBy KTB4XjIqrqYYaVd+piOB74qj4WG7w5Z/MOUP6GtTdyO2O1J6gg5FKc5B6Z6HNJt3LuHTp+NAZUzl hmml0B+8M/XrR9qh8zBmQfVhSm4i6+am3pndQbu3PCzozexpwvYVzumXA96Z/atnxmdR370HV7LH +vGTxjB5pv8AadpyqzL9MGqtz4o022lCecXOcZRSQKWHxJp0wf8A0jYV7OCCBUDeKLAQPODIEVsZ 29fpVhNUW4RWWGZs9OMdadJfSnCJaS89z7VlpqV19tunWGIIoADM1Q3Ov6nCd0dpujx88gGVH51k Lqut3esPcWVpHcKibUcDOK09l8irf3ZvZZ8YCRqPk9azvCRfUzqFsLm5hgil37G+9n3robPU0ivF tmupEwcASxYB/Gt6SWOGN5HYKByWNZ8GvaZcOI4ryNnzgjkHPtV9QVJ3YOTx71SvNesbOZIbiTZI xwBg1bG11DRncOo+lZdpcwN4jukjmVm2D5Qe9LcD7Pr9tcFgEmiaJvTI5Fam7cFORx1IowNwAYA9 hmsHxf8A8i7LghmVlJXPPUVuWxJtoHXkMvWpA5D44YkdBUooxTBwTxz296GPI45FIoyODkDgEUxh gg9sc0hcHO3v2qVOV5APrSZO4nAGeKTdjPXaO/pRuzgA5NSdeCDj3pRgUH1yOe1O3AjmmMPbPqKQ kgH19abkkAdD70EseOh96T05PHt3pV68cc0/OTwRjPSnDvU0QIBxgkcV5F8DiPtOqtg/dQfjXpa6 cYNVvLkxh47lVQqfYYqn/YNjHbyRx6Uqlxt3Ac4Pp6VXsvDP2CWOW5nnvTCB5SSAbY/T61Y1PR4t ZZGvLWQSLn5lbGRUt5p0NzpH9nPan7OQF8uP+H0pmm6RFZMJGWaV1+VWlbOz6U7V4JdS0u6s0Rg8 6Y83sP8AOKS4tZm0UWyjLBFU9gKvRAIioCcqMYPSkWTDEGMgjpu6Vm31xeXMn2W1haPP35ieg9qc lgsf2RYySsGTk9XyOtM1TSLTUQftELbipVinBOfSqGneHJraRTJqd3LEMBY24wPStfUNOj1CyW32 qCjBlLDnIqvrGkDVTEyXE1tLAcLIh/hqa0sUsITtLzORtMjnJwalggjS2NusZEZBAH1p8Ci1iSGN G8tOOKlaRs7djFOme9M81uvltkdPejziAT5b89qaZyAv+jyY9zU0crFM+UR6CmNOTuPlP17U1Z3a X/UvwOmagvpJGsbgeS+NjfNnpxisLwdqUb+GrWHa7NHuUjb3DGtpr5snbbys3bAFVJNQvzkx2iRq ByZH5rHur67uZSlzObeRh+6WLv71qLNMbCN13yyuOhOCT2qnp1vdRanPDfrI7uBIp38AdMVqrayI 237JG0Y7licVHJZr95bCBuepHNOaDc4/0K2GRwuaiRFimbdZ2aAdeRk1ZWSJckRWnI/vgZFEV9ty rLaKM4XZLnIol1doW3uLZIuzZ6ms06lcarcNHCgt7MH53XO6Q+1c5qn9pnVA8dxHZ2Fu2RtGTIfe tyxnl1ny59RtgsCfcjC5ZvetC/231u1qsAQHG0lfu+1LDdXtukcX2XzREvzN0qo2o6jqG+Eac0UK tjhuTVsXE2n2ZkNnHHDGu44bk+wrCsItU8V+ZJdgR2G87Id2C/1ro4Y5NMtAkVrbwxKPuhj/ADqv E+pajieW3ijiQ4jQsfmrE0mWbTfiDdWCpGBcx7yGPGRzwa61mvmYf6PamP8A2nNITqbMR5NrtXoN 5xUTWMkkg82zst2fvDOfzqwxvVf5YYPLHfceKWWJ2374YGU9jz+tQXN1NaQsNkXndI0Rv6VR0zRp 45Hvrq3tzfuc8HG0fWjVYbue3j+0QwYEgYbZDkHNXGF8sflCKAIR/fOcVTXR5klMsK4c9czGuf8A EOmXctzHYaaHNxKA8rNKWAUHniuzjS7jtYxGkJk2BSWbABpc3ZTKrCJe4yalj+2EHekS46YNLI16 rgRxQsO5LEUxjfZz5UGP980sj3igeWkJYjkFjTInu/L/AHkcK+mGNNc6hu2rDalR1y5ojF8Y8tHC rH0c4xSxHUDvBig2r33nkU6P7b5h3xwbexU81MfNwCVGTx96m/6T5gDCPaOetOIuifmWLZnj5qlQ SYU/JkHmlZGxwqEfrQokH3sc9MUNk/8A66YQQWP5GmqrDp/OlYHtwB3pADkDtTxx7GhiNw6deTT0 GDjk57Zqe3654xivIvgaSbrU/otewAnr1ApC3P41GSOwyOmc/wAqjMsZYo8iFjwBuGfyoOTjPWkJ wD/KmGTlj1Pp7U0HPYcUoY7iM8Uh7YxgimgnIwMZP5UBepwKCq+opeQM89elKhyBjqOgHelPTLYX 1AGc0hOecZz/ACpVOTxyOtG4A/Kox6e9Bbceny00ZP1xTj078ds04dfrTc5OMcdOaXPQj/61ZMus xWuqXENw21UAK4XJOagl1WO7DRZmjtuhOw5bNY3hLUo7C3urDypZJIJ2wcHJU9DW+dRZtzR2FwyD ucD+dU1bUbmYubVUiH3FY9ay7+2vE12C4Zo/NzsSHOQvua07SyvT5jy3WJC2DtXIX2FLPYypc27N dzOQ+C6jHFW5NLVid9zcMD6ORTV0iDI/eXJA4IMppRodqRkibn/psaX+w7BTuMJc/wDTRialXS7E L8lrBg9cgVWvm0nSohM1vbq7fKsYUfOapx/Y53S41G4t8D5ktw3Cfh61fn1yxghyjrJK33EQfM3s K5iGO91LxNMNSAjhT5kiDZC/UetdnabI4URgAB6moJ7mGKbzN67VU7lHcVXsruSXdPdvHFC3+rTq xHvVmXVLSGMyNKCCOFAOTWSt0NSAa9WQQq3yRKp5+tLpmq+RbSeXZXDJvYAgAAfSrP2q+uCsn9nt HGOm9xg+5qO61+S1wswgZzwqRkkn8q5y6/tfUvFdlcw2C2spVjGZG+8B1rsdLOo4ZdQjUnPEinAP 4Voo5K9c/wBaeG9zSFiBnHH1qC7u4bOF5Z2Ijx26k9qq2Vv9onF9cR4lYYQH+EdqvjjOQcnPFZV9 Mb27SxgXcEIkkf0A7CtYgE8DORikdlCM7nCqMkn0rD0FPtl1eapICBK+yHP9wdK3eoX0NOBwMjr6 UKSWBPQ1IPfpRTWyeOPam52nIHCjilC8k8D1+tDKOf8AOKcBwccE00kE9eaVQeoo6kEHrT1BIGe/ pTgeO3FIPmOc89qN2OhP400ngcdKZuO4Z5x60m4H0yf0pCefY+9BOGGD3596A3A/A4oIPqMVIoOc c/j3qxAMH3xXkXwN/wCPrU8/3Ur14tg+mB+FcufE93d3U7abZCextX2TSbsMxzzgelS6u8uozW9n b3f2RXTzGYdWHoDUdjY6Lp95Gsc4luzwN0m459a3i+Mbj16VjeILxlhitIbkW807fLKewHWq2ka3 5umTK0yy3tqGDgH7xHrWrb3iT2CXTlVDKG9hntmp96svtjcCPSoPtkYgaZ2AQDlv602w1C21G2aa 2csgJXnsR1pmm36apbmZAQFkKnHPIq5jJPHtVLWNTbS7J7hYXnYHCIvc+9c02sX907Ld38VkuMCO 3G+St/QHt/s0otpJnkX/AFhnzu+uKq3niy20+wkmuuJkkMYiA+8RVXQfEl9qX2yW4gWK2jjLq/PX HStnR7lrvSYrh33NLls44FX+MADgY5pQOSOOaXIPGMGhefbJoIA44AzUczSLF+5XLdt3SsgzWkOr yzXzIZQoyDwM1qNfWxCYmQ55xiuZn1az07xUsrSgRXcYG5VP3hWpfalbT2bo5fa3GRWJHcTyAJDq rhf7uFqslko1KKbe0sqyA73lHP4CtqCW/a/nRVhUAAkkkip7qC+8yJ2uEQZwAoyKn+y3Gf3l2R2A VaBZSk83cpB6ginjTkDFnllYj/aposIxn5pWye7mpltY9u3BI75NRXGlWlygWaAMq/dz2+lRQ6Jp 8DDZaxE5zlqZbaNDbXkt2+JJXOF+UDYPauftZVj8d3wfAjAXcxbviune8sE+Vpot5PTdyahe8sEu FO4YIIPy5qGbWrCFGKqHk6BVTmq9vqFqsguLhJTN1KCPhR9Kuvr0CxlzBcHIy2UxWC13rRcHT7Vz bqS370Y61csYL3UbgpqouEQjOMhV+nHNb9pYWlphbeFEPZyOcfWszxEv2e/0u9GR5cxQc9m4rfKf MDgH0NIuB93PNOKg4/mKiuJ0t03MRg9FPf6Vmx2TX92l1eBgif6mL+prUBVVYu20L94+lUTcy6gx jsyViPDT+v8Au1atrSO1gEcIJOck9STUwAGQvB/nWPr07SJBpsJxJdcMAeVXua1IYEt4I7eJfliQ KB6ip1UFQCOnSlwF5zxnOKO3qPUUHHXBpQe2KCCe+KY/QY4z2pQvyjJyTjrSnknH5GhSTkkU0rhs 44/rTsfgD2pQT/8AXpfwpR0P86UDjpk00/TFFI3r2FRv/SkxgH8qTvn3ozjA+nFSbuB1zT1GRT4y ATkE/SvJfgYT9q1X12JXrM4ZreZFHzNGwHvxXF+H11KG1j0m3054MSMZbqQjDc9R/wDXq/rehQah qVjFMz+RGpHyEgk++K07HRbDSoittboh/vtyT+NWyQQAGyfSuc8TaSmt6jYW0wf7OrM8hU47dKo6 vp1r4a0i/lsEEInjWMNyfxJoh1uC60tNK0q3muWMexnxtQHHqaSx8Q3FxaQaTbwSLqCr5crMPljA 9+9THfH4jg0oAtG0IkZh6g/40571tO1O6sI4JGe5YFMLhR61Z8O239mXl7p5DKm4SoT0wf8A69dA SAxzknk4rN8RAPoVxu9Bt9Safpmi2Gn22bW1VS6AliNzAnrzXP32qX+m+Ib+1tbKaW4uggjkx8gX HU1Hc2V3od3BLNYvqMciHzCACd5PX2rpLaF7vSpI54Et/PQp5S9gRjJxXMaXrkvhbOl6vbzmGFts U0aZBX6VsJ4usJx/osd1Ox6Dyiv862LWdrm3WRoGiYjhGPNWCuBk/jilBJzgEUnJP3fzoRBj1A6Z 6VE9nbyy+ZNEhLdyAae9vG2NsafXFc94wsD9ihvbdE82ylWQjb/Bn5q2IjDd2yT7UZZFDdPWmNZW xB220QPX7grK1bRbKRUeS353DlTtP6VFDolp/aF1tEke3aQyyHOfpU97YSrbg/a5XKuOuOBmrvkX eW2XKn6im+VfDhrpOe5FRtbal/z+xj320G2vyq/6coA77etK9tefKTfHj/ZqRLSdmA+2yY6YwOaV 9M34MlzKwHTaR1praJasQzmXcf8Apoea5ttKih8X3IhhLZiBXcc7jmuisNFgtt0kiRyTucsSvA+l R6rIkL26Wqp52SAMDA+tWrSzW2BMgjaZxlsDpU7vDEhdtmR1z3FVIIJbiU3F2diL9yMHp9avhkH8 X1BOacxBxnp7kU1WAxn7tZPidfM0nfuG+CRG+vNbMbqYY2yBlQeTQXUE8gY9/wBKgvr5bOBnC75A PlQHkn0qnp9rLcy/bNQIM38EWfljrSmkSNQ0rhSM4bv+VZ6LPqXMw2W275VPBb3NaiKiJtQBVA6L 0poYcnO0detRXN0lrayTyEKkKk59DWdodgzmXUrtT9puj8uediDpj3PettWyzdeKRiGGefypQD15 FJuwo6D604NlSew60Ajt3oyCRk4b0zTGwM4IyBjmkDAdSOe9KD03HAPT3p6j5ScjFMaRT0deD60B 1wPmH1NODpnhl/OnB1IyCD+NODoOMg/jTd6/3gSfejcBnJH403IOSR+tNZsEE9PftSEhQQTn6Ux3 Xrn8KVWHBPT0oBX8hzinBgP504NlasWvU/SvIvgdj7ZqoHQKtesT2yzZLhsYxkHpVcWEQx/rAB6t 1NMm02FpFcq2T2DdKQ2cBUjBLA/3qDZQg52Egf7VRNp0Hm52tk+rVHPZQOhSSPzE/uueBTorSCKP ESqgHZRjmlS1jRiwXO/O4Acn3pTawrL52AZNu0nHOKcIE3E5OTwGPXHtSxwqpLZyTwWY849KR7cl WUTSbT055FPazjltDBIxdCOSacsXyqA/7sDAIoMAYcs6tjGQeRSrbMOVnkYYyecU17dnOfPkAPUj 09Kja0DkNIzSgcLuApqwxxXHli5KSMOFCjGKe0GfmNxINvAAIqUQlUGZHbjqe9IIyy43tn1zRHEq DBkY56HNSKm9cAkcfhThHj72T70hC8HODnpUU9sk8E0btlJFK89OawPCl1ut7nS7gkXFm+w+6/wk VsmziZict9C9I9nEy7WG4dR83Ss+G1hj1e5C5O5ASu6pdQtYktHO0nBB4Jqx9kgkjVhuORzyaY2n W5PIbI6fMaf9hi4wjY+po/s2CQYw3XkbjR9hiTHysMf7Rp32GAscq2MZ6npSiyhC4RDgnn5j1rOk vbY35t7WNp7gHD4JKrT0to21lWVQSkJ3HnuaV9jztDaxs0h4d93CUjaXb26R7ULv5oLSMTlqtfZr WOJnKkgjrk5qpDpMFzOLicPtT7iFjV99NtmVt6H8GNRjTbYLgRsOf7xp7adA2GCkHHdjR9ggLYCc 5/vmqGv2cI0S6wmSFz1PardhaxTafbOyks8YPU+lNvFt7KNmMZeU8LGCfmNR6fpbLJ9pvV3TOOF5 IjFT3LW9iDIRkscBc/fNR21ibidbq9QbxyqZOBWiYVYDjv1HekECkncCe5oNrCc+Yvy/WsQxrr+p oFybC1fOQeJH/wABW/8AZ1I2suMdMHpTRbxpHt2nn/apRbxMPukfiaeYVI2gfrQYlPagxIV2kcfW o2to+MAj6E80G0jJzj9aQ2cJPKZ6ckmhrGFsZUg+xNDWURI+U8d81IsKjjBx25pn2WLOdmM+/SnL bxhSAuAe1At4xtOzkds04QxKoCpj15p3loMcD16UhjUEkDNBQMOV5HSm4wvGKQlVA4JI4owCOQMV G+DkdxzSjAUZAPFJwDnB+uOop2AcDFSKcn8e/ep4+mPxryT4InbeaoeB8iV66Sex96Z97rnP6VGf lyC3brmqkV3bzuywyhyn3lFO34TkKahtb63vVf7PJkK20+oqtJdONSigEYWN1OB1Jq2RnjGacBn1 +tLnAy/QVmXPiXS7JnR7lXdf4Y/m/KrumajHqUBlhjlRe3mJgGrMkscMO6Z1VF+8WqKG/tLllWG4 jkYdFU1awCMnn1FKBt4x+NN3AgjIyOtJkE4A79Peg4IIAzn2rBM32jxokQLBYbf5vrW4ScnOBzxT iOp/ShTjOP1pT9BxQvHT/wDXRxgZyKTGeQM4pDx8oHfFcrqmNG8V2l/jEN4PJl44z2Oa6dsFlAAN NPJDd881nRLs8Q3Dgfejz+Aq1qOP7OmLj7sZIxSafILjTrZx/FGOast8p6fpijqozgYpM8g84pT0 G7/GmiTaTgcnv2xRKgmgdV+UMMblPX6VHZ2cFhEUtlCZ5Y/xE+5rLaVrnXXituFMWGkH1rXiiWGP aq/P3aquqN5FoZPmIRgSB3p1tGblUuJVZQ33UPYe9XlGADgH0FIpPHHSlOOtJwRyPf6UN83PGOua p6sFk0q4A5yhJH0qtp14sWhWjKvmO0eAoP61bsrUpIZZ5BJM3Iz0QVPeXkVlAZJGIHbHVjVHT7Rp pPt94hErfcQ8rGP8a09uUyFx60obK5zn2xRnDcdew9axtTu3v70aVZMwDLmeb+6vt71r2tvHZ24h gjCIgwMd/epsH1/OlwM5ox0pQSM470dR2BzSgEHOB9TQeHJ6YPSkJ7YwaQDPAoOabyM45470oIKE 98UgJNHYnP0OaRSRgc4x0pxzgYpEz3PNOboOgzSHPPpTQCWxk9fypGGBzwKjOQT60mQTzx7ig9/X OeaCSCMn8acABn9BTw4JFWIccggn6V5F8ECPtmp9OVQ4r0nW31X7J/xKWh84nB80ZFcZqEfiO31b T7e41llF85QmMYCHGavak2t6Bp007agt5bgbWDj5xnjIrF0XW4rDVlMVrdeXPFl/lOSw7iul0HxK NXuZoZUWJlYmPsXX/GqkE5WXW5LTOxMH5eBuHXFUNB8UWl/rMk2oTGKZQI4Q42gj1rtQ6OqmJg6k Z3A8Uu4LgkH6UkmXhkHzfMpyPUelclpwvYbbda6JAYw7fvCwz1qxHqniDUrowwQ21nGF3Zdckjp+ FXtP1CW80S4fU1inWAlSYx8sntioorSyl163Wygjt1gjEsjL1Oei1q6nrkGnQl+JZAQNqnPNV9L1 5tQ1i5snjCCEZRs4D+prPttXmj8WxiR91ndZjhB6ZXqa6nHy8fgcUNj733VIOSK5jw0kt3q2p6lI cLJJsQD+6K6PB5yPfHakWQ5xUu4EE4yKaWwRkkjnn2p8fOe/8qd6YxnHSkPQnH6d6RVwc5BweAax fFemtqGiTqhPnJiSMjruXnipNB1Eato1rd4yzDDDuCOCKvkZJPPr+FUFQP4g4OP3J9u9XbtPOsp4 yobMbce2KraLn+ybZeMIu3HpV1hjIPPp7UDAHTOfSkZ/nye1IcBCzMAoHasef7Vq83kxM1tZo2Hk H3pPYVrwRx2luIk4CDjcen/16gKtesEUlbcHmQfxUhiSLVbdETA2HgVclkjhhMkjAIPzNZM8L3MT TzgBVOY1Pp61rxAFABgMVDfU0YA+lGGAPYjpSMSuOAc9M0hyvU5pDyA2PwqtqcgWwlRVDO6EIM9f asjwbb7NGE0hLSljwTnbz0FbxkEcbPN8q9SazrMSapefbplxbKcQL/e/2jWt90cjIHf1FPVflYj8 CaTjgk4zzk9KytW1P7CIoLdd17cZSJOv4n0FWNL03+z7Yqx3yudzv3Y960dueeQcUtGcds5pN3sa Ug/QHvSZ5xj8alB7cYHcdKQ8ZJ6/SmHkULx15PtQTzzzmjPOKOmeOtJ0YUcAc/rTCRnjvTgx45oH XnPtmhzx9TSlRnOSM0wZJOc8U0t9PypuC2cEAfSmHIOM/jT+Co9xiozwenWnLzk7jxyT71MMYHU8 /lViAEMdpAryD4KEpdannrsT8K9TmnI2nynbBxXOax5174g0h4reQx27M7jH4UnidL3ULOO3t7dy GmUvu9BTri0mOs2EyWxCRKyN24xVWbwzv8w27SW8ryGRXB+4T2HtWjY6aLTTGs1WQ7wRI56sT3qA +HbK5sktbq03LEMK+Pm/Oqel6dqOh6wltE8k+myDd83JiPpXSl2zgo7D3FMMrvFIDBJjaeB3qtpC SW+nCGaBx8xwSPes7UtFubvVvtC3EiWzIFkRV+Yj0q9dxh9HntLO1kj+UhQFxj3+tZ8/hVLm6S5M 93C7RqJVQ43kUa7oUz6NBBpMbJKk6uzueSB1JNPvvD32mOzaKeSGWJRG7oOXHcU/XtJFzokcdgji a0IeE4wSR1/OtnT75ruxhmlgljfb8yleRVLxBqv2TSpRGCJ5TsjGOual0q3XTNMgt2Vg2NznHBY1 Ze5A6q35Ukdwhk24cH6VO02zOVOaQSBgOPxNKsuwtwxHXinfalUhQjnPJ4pWkA6K/HYCmvKAPuOP TApryZjAVH2njBFcv4XkbTtb1TSjnar+bEO2D1rphKYz/q2x1A9KzZpfK8QxMUYCSE8enNafnD/n k+MGqGjXP+gMgjk4lYHj3q8LnfIQYJTz6daYLrd96Gbg4+7Ve91e209GNzG6sDhUA+Z/oKmt7x7m ES/ZZAH52EdqmaXy8gxMOOoGOKpEPqMnzxyJbL6cbqurcbBtW3k2jgCs25uyms2xaGVRsO4+tTQS tfsZZoJVhiOVjI5PvT9TuWGnu4gkyACRipkuSYlzDKDsBHHWmveOhXFtMd3+zQLp2kdTbTcdyKGv GXH+jzH6DpSi7Kjc1vMQOvFJNd+TF5jwSZAzgiqMFw16GuXs5VXqgIqr4TlePTJP3T5E7DGPen3V 1Lql79gjikEa/wCvcc49q1o5fJiVVtpAo+UAU/7Q+7H2eTHcYqQSkLjy398j8qp6nq8Wm2bzSRyF ydqRkcsfYVX0fTpUJ1C+UtezKOSP9Wv90e9a6y5O3y3GOn0oWUk9G+lL5xzjynBPfHSgSsQzeXIM dMDrTFuXPW3kH4U/zm7wyflUiSEj7jj8OaRpCOPLbj0FPDuJNuwgeoFRyyMpOyNmqNLiUEZt5B70 rSyjpbuT701pbgLn7KeD606KSdwxa3249TUYkuevkAfVqPMuscRLn0JpjTXmeIIyfXdipI3uWALr GM++adm4U/cUj/epSZivzIvPYc0fP/F0z601/NJ+XB/GkzNkghfw70q78ZyM9aZ849aCTjgnA4pC RyOxpyjr6dRmpATt4PA5qzADzkAn3NePfBY7LvUwcj5UwCa9XJLKSvU461G/UHaAcYzio5CxwApy e47Uwyx+csbPiQ8BSep9qfgEfLk/U0KecHr1pSM+tOYKQeNufSl6nrxjt3oRsDGB1zSMc/e59x2p ykDHXOOuaTdw23B46mpFwOMEE88Gn5G/k9fek+8ucjGe3rSSnkFj7ZPajIU7M8EZAqnPZw3FxFPJ H88Rygx3q0OQeeOwPUetHBJBAyDjgUgfDdjjnpzTgQcDvjoe9AA28AfXFPyM8dD6UoG5vYDtTiCT x/OlOO/PtTT6NjFcrqo/s/xvpl4MhbsGAnHBPauobGcqCT1rKmw+u2q/3YicntzWtjPLZzn9Kz9J TyoJgQ2TM2Bn3q/tAYYH49c1XuZGit3MMe+QDhfU9qzNN0UpP9t1CT7Tesc8jKxj0Fa0s6QRtMzD A9utVo0e9dZZCUgHKpnGferoRduNuMenSkd1jUyOfkx9MVhS7r3XLQyriBUJUetboG3AwMjoSe1V dTw2nyBhkuR71ajQeXGpA4Uc05gVxhj9AKYSWBI/Oo2dck46DjNL5i8MDnuBWbJIuo3PlIf3URy7 DufSrpPynBGAOB6Vyuh6nJbWd1awjzLuSd1RB2B710un2Is7ZUzmQnMjdNxq6jZIznIPAzSnli2e B3xUN5eQWFo9zcPiNBnn1rG02yn1K+/tW/yQP+PaIj7nviugGMjBOevXinDnjqPSnY/LrQOeqjPr Sjj0xSDGOOhpwAGOODUi/dxwR9aT5c5zn3B6UvAwSOR700AbssOPal2DNNK88c0uBjB547U4AEH6 dzTTwM9D0pF6HpTSq+YD6elRjEROcn04pS270x1oBbcQeKUFSeMe9RuAD2pp4zuPFCmmsemO3akZ iV6YBpM4x0NOzgk9zSkjqD0GOnSrNt9394QPTNeQfBgj7VqPsid69WYqCG7/AM65/UPF0Ntdy2cN rPdTxj5hGvAJqCLXtYuXXOnwW0Z6GaXn8qt3l5BHfWZuhEcox85SflI9PWq03jCxkl8mxjnu5cdI 1wD+Namm3VxeW5kuLZrdugRu1XFB/D1pevU04ei8epNYN/rdy141lo0Sz3KDLsei+1N03WtVe4EV /pXlZOC6MStdKoAHA+U849KYsa7G9SeDWWNQmk8XmyVsQi3Dn2zVLULzxINSeCwsoDBnasrnmo4N U1yy1S0h1Y2zR3bbQqAgg11DEAkYHPJzXO65rU0Uy6bpQEt9JjLdfLHqasaLHqWn29x/bF0k0md4 YdhjtT7DxHY6jayXCShFicxsHPf1qtFrLT+KPssTbovI359TV/UdSi02ylu7nIjiHOOTXKxeKNY8 QHbo0UUUAPMsrZbH0rsbIyiCMTsrSbcMyjGathjgDGR/Wn88dj6U6lK89OlGzls4zjpXK/ECGRNH tr6I/NaXKSAjsM810ccgnt4pF6MAQPwrPlOzXYFOMGA4P41qDjjq2f0rN0pj/pKsQAZTimXmuW1r KtrGWmunGVhTrn/Crdv57Wy/aVQSNgkJ0H/16fLIkMbMx6cY9aqQwNdv59wCIgcKmP1q927Z9KZN cJbxGSVgqr+Z+lVYt2ofvJ4ykP8AAn973NVpi58UQQrhUjgJPuM8VrKDgqOpPeqmqoF098McD5jV lD+7RsgggYqRuF4HQ9aZuABVVI57+tRvHvUhgT3GKo3kks4+yWZxv4kf+6ParFvapZ26xxLwo6ju fWqeoX0VhERtZpZTiJB95zWF4HtPKvdV+1p/pYnKk/3e9dkCc9eo5pVyefoaR5lhhMsj7UQZ57e9 YEMb+JL/AO1XII06Jv3SD/lofU+1dHjAGAML2FKCCv0NGcDP4UBiGweafx3pdvFNK/MCe3anAE9K Npxnp6U8HGWHfrTmHv8AQU1Tk8Db2+hpxyevXmmgAkUo6e3T/wCvR1X5ecDH1qPBHPFAPIzjihjk 59aawyP6UgTHJPQ5pM5PfNMHp+OKOOP6etIT+FNzjjPPpQThSQQM0zBK56j+VIPpmlIOT9acOOTz 3+tWLYhQSeh/GvIfgz/x+ahxysanmvVJOQdvXP4VgR2g/t/UYCzJ9ogUgrwaig8GafET50k9wx5y 8p4rPu9PXTfFmmQRM7W7hso53du1azQw2HiONY4lRJYeigDmtvuSeSPQ8UhlUOEz8zcgZoVyTz/K hmdo3EZ+ZlOAwrlNP0/xBZS3AtobaISOWMpOWb2qyvi9rNhaXthP9sBxsQEqffNdNbSSS26STAKz dQeMU52dFkOcgNWDYK0njq+d87RaR4U8Z5NdKwxkkEEDgVzd4pv/ABxbQLkx6fHvkH+03QVr6tdf YtNuLogExpuGO/auFt11W0vlgt0SOa+w0l2SGYg9gPapvE2hNZaJPctfXVxc7goJfaOT2AqDQPDI s9ZUanIZ/NiWVcAhVJ9u5q9pd1aweINRurmaKFkbYgdgOB6Cte01W31hpEghM9ueGkdflP0rP1bw 1pttazXluz2LxKWVkbAJHbFamgXzyeHre9vs52biO5HrWzbXC3MCSqDhxuweKtKAc5zThjGT0B4N KoBwQT9BQw6N19qz9eshqGhXlu4+/EWH17Vn+Erv7T4Ys3duVUoc+oqWfLeILXC5/dN/OtXbh+vB 7VgtNPKs9tpqsspYhnIyIx6+9WdL0O10wNIvz3L/AH525Y1au7qKzjw+5nY/Kij5m+lV4Yp7kiW+ j2AHKxqePx96vpu25HHYAdqhnlEAAySxOAFHJ9qrrYSXMpkvG4U/JH2X/wCvWggwAFxt/l71z17d LY+LEmcHYLTp/e5rS07UpbzJNpLbxr0Z+9VfEJ1IWUhtIYpojGdyk4P1FWdHvY7/AEq3nXcW2jIx 90+1Xi5yMnJ9QOlKoGeeCOxrLu9RaW6+xWf+uIxI46R/jVm2sks4VjQlm6tIT1NQ6jqMViiBtzTS nCovr9Krabp0qTNd37K9wxwpH/LEe1Z2kjyfF+rQsdqybZFyetdNyVBGDznPpSo2M89Bk1z9zJN4 g1E2UKMunxNmZycb2/ujHaujhRIkCxqqqq7Qo4xTiM4wPlz+dAYZIHX+lKDuJGMr7UzGTz164p4b gBexxzUmOOD+FBJBBxSrjt+tOA7kjj36070246+tGME5xz3zR7n+Yo5DDn/61R9+4H8xT8hRkkAj /apAVK5yMeoPSk4GWyPwINN3DGcr7801JcnjacdiaduXbyw69BTC6FeWAI9+lMZogud4HYHNKzrw QVOOpB6VHuU87gUHv0pNyEYBX86jJXPPT2prOoxk8dqUPg8HpQDz1p2cnOcUrEHHTirVt1b07V4/ 8HQXutSQNglAAe5r1JolPVmzjqKqPpsUlyJ23iQLtyD1FL9iRjkliPTNRtpFtNNFLIr+ZDna2eRn tTptOgkmSchiyDAJPQVILWNRtXdjvzVS50rz7y2uI3YCHPGfvZq41smQNzk9etKljGr7laTd7txT 3slLBmaQZHODUJsULhiTlTkGrSxqFyWfI7mohaq7v+8fGfWl/s2A363Y3iXaF69QO1WTahju8xy3 Xg1Wh0mC3uZrhGcTT48wlvSn3FgtxbSRTMzJKNrD2rPsPDtlpvzW4dmHAZ2Jb/61SXekw30ax3DO yo24A+tSNZR7lkJbzFG3Oe1Zeo+EtMvrv7VNBukyDnsav29rHAixRZijXoicAVQufDCX92JL28uZ Iw24REjaa2ktkEQhXiMDG3HAHpUy2+Nqq7BRxgdqmSFtu3zXznk0G1bGBNJjrUyxMFGXbPvSmM7h h2+lRNAZM/OR1GD0rlfBMit/algrswtbpsHthugxWpehYtYhnaR0VYGPToM1WS7v9dkRLSKW0sw3 zzydX+gq3o1l5EEsaXDkiRiNx56+tTSzPLuisXPmH5fMxwtLbaWkBLySSS3AHMrHpVowBk2s7Z65 rNvbxlkkt9PPm3PAP91Pcmp7DTvs2WkleWd+XY9j7Va8rLHEjk+h7UGDqA5B9a5/V2ig8SWMku5t 0RVU9cc8VsW1wbi0+0zpJbgZOyTkgD6U64QTadK6yswZDg4rEtlnbQdNkszIpVgH24GVJOa2jbFH P76Tkg49qzr5pb+VrSyuZA4OJJR91R/jVq10uOxTy0kkLdS/GSah1Cf7EgO+WSZ+EjH8Z7VBY6RK sjXd5M8l0fvYxhPYVeNqx+9LIT0J9qwbq22eMrMrI48yEqSMc46VumybPFxIAc/gax9RkmvbpNH0 y4cyj/j5l/uL7H1rdsNMh0u2jt4ZHZVHPqTVhYmDli59hUgjIzktjHSmiPDbtxpyYGTzSPGHkzuP 4UohH949MU4REfKW46ZzTPKK3a/fbPYHgVYaM/7Q9cUxosrtJbp1pq2/H3mx60G2Qk5kbHfmhrJZ MDc42+h60fYlZs/NyOm6oxp8YGdzZPUFqGsofMKFWI74NSLYQjIYMOM4JpqWUEYIjU/N2znNM+xQ cqFOT7mkGn24PyxnP1NOFlCq5VMc9c0wWFvtYGPr15PNONnDtC7eB05p32aIDCoB26037LGg+RQP rTTCuOhz70jIi9c496jKKeo6dBRj260gA64wTTgOR296cVzzVm2YLkHr6V5D8HMG91D/AHBzXqch CjrzVdpMR/MTycUqbsFUbI67vSmm42KXlbYqdSehqK1vYdQUyW0vmKDjjpU+4jOR909PepBubG0g Fug9KiS+tjKVWdCw6jPSrCvGVJBGPUnimQXMV3GTbSLIqnadpyM1Xl1K0guorW5kCTSfdjzyas3N 1Da2xluJFRF6lqY05EMjxlSpAIINXUYmFfl5IqK/eSPTpntiokCEqSeM1Fpt213pkM0roJWX56Zc 6zY2QxdXiBv7oOT+VV7LXLbUNQmtLfezQqGJxjk9KztZ8RvbavaaZYkPcytmUdcCt1iCNzEYPWoW 5JxxTVAVsY6etS5x64/zxUsQOCOnHrUy8jjNToMkDpTyccHoOtBwQNvUnilPysCfSkX+Htn72fSu A06eHw3481o3k6wW00SzfN3PtV681gajrOlT2sUi27uYsuMBu/TvXWKwjAZ8IcYPYD8Kw9Ikmu0n WPCwCVtzAZJ57VsxQxwJsiAVB1x1/GnEkj7659Kzprqe7mNvpx6HEko6LVuys4rGEJGBkn5iR949 z+NT4xz1NJ7ngjqKD/tcZ4+lcz4kiW21/SdRfcVQmIDGce9bmo3DW9izpC0wIwNvUA+1QaLcmfR0 cqysNwwRxVDwpGYrDMszSSBmXB6Dk8VPd3r3twbGxJ3dJpwOFH1q7Y2cVlAIIANvdj/EfU1HqF2L C3aTOWJyoP8AE1V9MsZBuvL1911MNxB52ew9KvHOwcj6D+tNOcHrmue1wGHW9KnB+USbGPpVnXtY e3WOysQHvbk4Qf3B3arukaZHo9p5EBLTNzJK3JZj71pRIUj2ufmJ64608nJwM46fhS7gCRg4NLnq P5U3GTk4/PrT9v8A+qlzzikRg7EdAPWpOgwwPB6igtn1ApGwMAE57ntT1x1AwP50hwCTjp3pwbA+ lJnJ296Y6FZcnIX0p5zwQce9NVvMDAsSB2xSFxG4C4yRjJNKSM7iBnpUfmq7EAjd3pUcNkDIPTml Ix6UuCFPNMOe3PtSHk47Hioz3z2FRnJzuzzTGOOp4FIGzQFy45NLnnjgU4t0/Sp4R9488mvH/hEy pe3xzyUHFem3cjYHljp+tUdZ1FrDT45im9i6qV9AadqUyWmjyyFvLQIScH8q5me6udQi02xuLg28 Mql3Z/4lrrrOzgs7aOK2RUiUfKU71ZxjJxnPPJ5rM1qSU20VrAxWS4O0kHBqR9FtZbNLd14Xo44J x61T8UXpstLjt4w++YhNqDLAd+Ky/Dd7dW1zeWNnpTbAytiWTayj1x71VF02s+J/JeFReJOMsDu2 KPerfjTVrN9Ug0q+kCWhQyzMvU9gKg8L+JbyfQfKSxaW3tyxNw74yoPHH0q7YWet67ZNqRvTDI7f 6PCvC4z3rb1jWbbT9ImS4mV5kh+YRjIz3rPj0CPVdDsZ5Li4tykO4eW23dUXg3RbCXTzeeSJpTKy B5TuPBqn4pk1Lw7q9zqGmpG0V6EiLYxtI46Vp+H/AA6mnN9uu3E+oTfM0n93vitthn2x1H1700YA 46/yoL89s/SnI2Tx3qVMlcNjOKmjYAgEfpVhQTzjFSBAcnH4UqoNwx1prIWJYnFJ5fJHTPPXOa83 8UaBqNv4oTVBA2pwMuCg4Kgdqs3vii8kNtNJ4Wu0S1cNH+8AOemelWj4uvbuRTceHrtYUwW5zk+t JY+MobYTRtpV+mZCcLFkc1aTx7p5PlyW13A3XLRHFZ9x42sL6cxyTTWdoOoMR3P+NXrbxx4ftoUh hnCRjoChFWz450IPta8A99pqT/hNNBIH+nLnGehpr+NdDVc/awf+AmhfGeizDC3Y5GeQaztc8RaR c2KNHqETSxSq4H863I/EGmzxKy31vhl5+boao6PqtlBYMkt7BuDt1bqKxH1yCK/vLCxubePzJNzS l/lRT1/Gtiz1nQ9PgW2hv7fPV2LdT6mh/F2iR7na/g2L1ANZ1t4j0q/vPtV3qECovEEZPC49frWu PFGjFGP9pQjPYnmmN4o0fGF1CD8GqKTxdosQwb+In0BzWNrWv6ZqFtHNbyGd4HEnlp39jWh4ZtzL O95eLm/l+Yk9Ik7AV1CKOo/Ee3rUhIPXHvzQFGCeM0Bt2RjNLhQeTSjGSKQgjBzzThuYAfpTkCrk dvWlPHI6/pQR8uDmlxsJGOe1KSVwMcdsdqBxjPJ64pAQc4JyOaZzlmA69cUofdznPGKc7HHPrTVX bIZMY7Go2VHOeuOhp2V2ZU5I6g1GiYl8wYIIqSBjuYMBjNSk5LHPT070gGCOntQW4+XrntUUi5zz 75qB05Lc0AAjPc+lMfbjikC9DjIPpS5A+npik+UckcE0/jAHv0qzb8ZOf1rxX4VyLFcXe45JTORX ox1KFAQyykj/AGM1n63dJf6HPDFDIXwGXC4OQaxkutQ8USQRXFpNa2EAG8EcyEVv39/p66esVxZS yxgbFiKc/gazPD0uopeNuini09eUilOeK6M34IyttPk9tnSs/VzcXMUctjFL59u25QRwcetR6fe6 zecXNqtpF0LHkt9KjWRV8XwIY5pPLizvKbhmp45Psnjm4k8qUxy2oy2336Uzw/bf2XqGpXElnMon l3IVjyStVI7S11LxzdXl5YzSxwwKYi6Z5z6VZgEcUuuR+ROtvM4CMsfTIqlb2GrxRJarq9wttj5Q ifMoq1d6Fb/2DPZWEc6zSEGWZ1yX55FbtvewrpyWiQzZSIqBs9sVR0CYaNo62s8E3mB2Y7V45NZf jG9a/g0+K2guP+PhWY7OAAa6FtShU4Pm8D+5jNRSatE3aRe3TrQ2oW4jOQ4OM9KRdQibqSPXK1LH fwtuKsSQOgWrK3kON2TwM4Ip8Wo2rA8njr8tXRewDBY9s8LQuoW/y8t17r1p39pQEDJYjkHC0n26 EHaN2T0IFI2oQA7vmz7LUNxqEZjzGJAw5yV61L9tiYhSGOfvErTG1C3QE4fCnpt6is6R542kFlIm 2VsncnK0y2sbeOVrm8driX1KcA+1W1ubR8r5anI4zEKc4swm9rdNv/XIcUGHTpRtNrCwPbyxUaW+ kxn93aQqwPaOp8aeBjyIuR2jFRyJpxBLQxbe/wC6FZ97pGg3cMu6xg83aQp2c1ztnY+GHskW90xU uVypjjRstisiPQLG5tXuVsvs9sJ/LCuTvJ7cVuN4X0HT7uKeawjktpFAYuCdpq3dad4Rt7dpV0+2 kbsigndVPT/D+hzf6VqGmW0Sn7luFJVfr61dGk+EmLbdMtzj/YPWll0bwwiArpcDbjyAhpraL4YA z/ZUA/7ZmmraeG4CTBpkKsvGRETU0s1iLOaK3iCMy7gVjxgir2kX8T2MTyKRI6gtlcGryajApwfM 46ccU86lAH438/7NP+3REZw59OKPt0GeQ3oDilN3GSAqsAfVaa2oRqDuVz9FoW7jY7stgj0qRb2F R0c/hSjUoZGx5U3HovFA1KLcVEMue+FqR9QQAMIpSB6LUK6pGVXFtcEdspTpNQCBf9HuOvGE5px1 JQWxBcZXGPkph1DaWzaXQPtHUX9rKIC32S6yexjqB9VnjTEen3YRu+ylOpzhP+QdcOeuGGKWPVrp gSmnXGFGPaov7RuSHP8AZ8uNudrN1NMXUbyBCw0wr3wJOTUovr4oZYtOAL8ndJiporq+UYFinXlv MpRdXwnDfYU2np+95p8dzqDMQbKLaB/z0p7z3YRNlvHuPJHmU4TXLffiVfbfVeWa6VyBAhA4J39K YJp1b/Ugg/7VKJLguf3S7e+Go3S4wFA/GnZyBTg3TIzTjuyOPrirNrxuzn868U+GDRpcXJLKjAcb iADXo7yxcgvEB6Bx1qDzwWAZ4yuezjNTfakICmaJAvIIYfrUqXMHlEGaHd6hxVczQ7lBuogAc4Dj ipWv4Y2Dm5i44JDDkU5dStgQ63kA/wCBDmlk1GzHzR30K+oLCkOpWLEuby33Y27tw6UjalpxljZ7 2FiBjIcZqVdZtImO6+gcADaC44qIaza73Zr61RfQMOapx69ZPFcAXUSl24O8VY/tW0TYwvLU46/O M1bXXNOG4i9gU8H/AFgOKh/t+zecYvrYAnqGFTTa9pyMP9LtmB/iDgfpTW1vTGUf8TG3x1A3Diqp 1vTUOTfW/wBdwpr+IdKHW9gJHo1MbxDpTsD9shx6ZpP+Ei0rn/TYOP8Aap6+I9IIH+n24x71Knif RkXBv4P++qlHi/QkOWv4FHsetTJ428PKMtqdv07miPx14cHXVLbrwKcPHnhoDjVbbnP40Hx14bwB /adsffNL/wAJ54a4I1a26Zzmmnx14bP3tWt/8KYfHPhvdxqtuO+aRvHXh3H/ACFLc89qjPjzw2QR /acPNNPjnw6GGdUtyo6Cnp478Ok86lB9BSt478OYGdTgx1x6Un/CfeHAONSgJ96aPH/hwnnUYePQ Uj/EHw2CcahGf90UxfiF4dzzfp+VMf4jeHF4F+hPuKqXfxB0B4y8F7Gk45V9v3qxJfHGjXEdmBOF /f75fbFbsvxE8OTRkG8RhnHK5qkPHfhuAM0MsKt/eEfNQ/8ACwdGH/L4CQePl6fSlj+JOiqQz3Q4 64TrVpfiP4f8sn7Zk+mzpUZ+IugyL/x9DA4OUqP/AIT3w/twLkgn0SkX4haGGXdcv05IWn2/xG0G OEo1yx54O3tVhPiX4eaP5rh/wTml/wCFm+Hupum4/wBinf8ACzfDwbm4fn/YpzfE/wAPH/lu49tn WoW+Keh7gDJJg99tL/ws/wAPgYM0uT/s0/8A4WloA48yXHc7af8A8LT0AdJZBnjGylPxX8PxgBXm I/3c1HJ8WNACjYJifXbUS/FzRgACtx74TrTj8Y9EPSC5OP8AY61G3xh0XOTb3I/4DUJ+MOmsW221 wUx/d61Inxh0nAD21wTjqFqle/FrT7hdghuQnXG2nx/F/TI7YKLa64HHy0L8XNL3sWtrrgZBK8VH /wALgsFLBbS5wT/d4pw+L+mtuWW0uNh6YWj/AIWvo7qFe0u+Om0U6P4v6WH2vZXJTtxTn+MGkrEV js7vnkjFJD8YtKhjA+x3WfUjmnn4y6Wdvl2VwCDzQ3xl07+HTp/xNRH4x2hPy6dL/wB9Ux/jHbng abIP+B1A/wAXYRkDTW/77po+LsPOdOfPYeZS/wDC4IsY/sw/990h+MMYP/IKyP8ArrTT8Y03Y/sg 49fNoPxmQH/kFenSTrU8HxpRS2NKbj/prXlUDuhJjYoSBnbxmp/tEx/5av8A99UfaJef3jDPoaal 3MI2PmNgZ708XcxVf3jDj1oNzMRjzGx9aQ3DnHzNx6tQZnznc2R05pPOcjG4+nWmmVywUk4xnrTR OyyuB2GetNMxBHUlhknNNW4JAO0cnHWlUhiq4IBPr701ZSwZT1BxmnbijEZ9KQSllz9e9M84h9pG TnGc04SNzz0OKVmZdp3Z3dvSk8w5x7ZpBIzgc43HH0oBYOy7uhx0pRuUcN/FjpUYkZt2T0FG8sCR kbRnk5p20kE7umKYw+U/XbxQvOR3xQF3Bfc4oHCkjtxSbiRjnk+tPY7MZJPUdaQElQQSOcdaJNyO V3E4pCSACSTnnrSb+cnPvzSl8nOO/rTiw2A4PJ9aGLRqhB6igEtt5wWz0pBk45+9k0M7Lxn3pQcg A85G4expqsZFVj1xuoz8ilhkZPHSkDAYwMY689aXzCXz3p2CHHOTzyRTA574/AYpfM+XAyD65pQx 2kjAxzSnn8RupqksTz2pygh2we+OlG0hGOegzTihCqd3X2prhgn3ieN1BJAbnkYNNDbmA55PrSmQ 5x6UvmEIDzyfWl3sueckHbQc926frTlBYN8xG2ozKT1zn2NPRi+MEjJx60cn+JvzpdxPc80nLADJ 7UhO5Ceeh4JpxP3c5+YZzmmFyp5ye/WlZjz/ALPNPVWkQNvxn0FRnh2XPIHWjPf/AGc00SdP8aA5 yBzj61IvJZQSNo6+tR7xxkfrS7/l3c+nBpXPyBv73akI43fQ0qr056gcUm3nt0z0oC/Of9n2oOVI GeCe1Swjlj6cV//Z ________________________________________________________________________________
Subject: Re: Speaking of outdated stuff? Center section fuel tanks
vs. nose tanks on a Pietenpol?
Date: Mar 24, 2014
Michael, I like your article on fuel tanks. My tank is in the center section and is 20 gallons. It works great for my corvair but I am changing to a C 85, so how much head pressure do I need if I decide to install a nose tank? Sent from my iPhone On Mar 24, 2014, at 12:06 PM, "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, L LC]" wrote: > Scott Knowlton=94your new nose fuel tank looks great! Way to go. > > Speaking of outdated items and things that could be considered unsafe or o bsolete----let us rethink Bernie=99s putting fuel up in the > wing right over the passenger and pilot in a Pietenpol. Is this wise? Is it safe? Is there a better way to do this? YES! Just trying > to become a free thinker here and not tied to any dated ideas or products. Now where are those old oatmeal containers for my new > wing leading edge? > > Install your fuel tank in the nose. > > - You don=99t have to get up on a ladder to fill the tank. > -You don=99t have to run long fuel lines to the firewall. > -You don=99t have to worry about spilling fuel into the cockpits if you overfill the tank then smell it for the next 20 minutes into your ride o r flight. > -Your CG will benefit because Pietnepols are notoriously tail-heavy (esp ecially with our full-figured girl figures!) > -You can run a really short fuel line from the nose fuel tank to the gasco lator---and in my case I used a flexible braided line which works fine. > -How much fuel CAN you really fit in that wing tank anyway??? Not much r ight? Comfortable for x-country?? Not really. Need a header or nose t ank anyway? Usually. > -A nose tank (in my case I hold 17 gallons) can hold MUCH more fuel than a Pietenpol center section tank. > -You can use that wing center section space for dry stuff won=99t le ak out if you crash like your sleeping bag, your pillow, some rags, a tent, your tie-downs, a few spare tools, quarts of spare oil.. > -The nose tank can be filled without a ladder or climbing up all over the a irplane where you risk not only falling but damaging your airplane. > -in the event of an accident there will be no fuel overhead to spill onto y ou or your passengers. > > Bernie had lots of great ideas when he designed the Pietenpol and I admire his design skills that still bring us the joy of simple, safe, economical f light today but his center > section wing tank isn=99t one I would recommend. > > Mike C. > Ohio > > > > > > ________________________________________________________________________________
Subject: Combustible lines
Date: Mar 24, 2014
There is another discussion starting suggesting that the fuselage is the ri ght place for the tank. Please read that. Rubber hoses are still in the mainstream of certified aircraft. They are re liable and easy to purchase but be sure you get the right type. Adding the term combustible to your question opens a huge can of worms. It is a question with no correct answer and many=2C many=2C opinions as no one wants to be killed by a post crash inferno . Is it as important to prevent a fire or stop the spread of a fire? If you a chieve the first then the second becomes less important. For example many p eople think firewalls are designed to slow the spread of a fire - I don't b elieve that is true because it won't work. There are there to prevent a fir e from an exhaust leak. So expanding on this concept design a fuel system t o try to prevent a fire first. Here is the safest fire system that I can conceive of. I know no one with this so it tells you that compromises are the order of the day. The tank s hould be in the strongest part of the airplane. That is likely the forward fuselage. The tank should be made of a flexile material such as used in rac ing fuel cells. There should be a holding cage (tank) and there should be n o sharp items near. Note that fuel cell are combustible but in a crash the tank likely won't brake apart. In a fire even aluminum will melt. If stress ed aluminum will break. The lines too should be short as possible and flexible. Internal metal bell ows lines are large and expensive but are probably the best. Rubber hoses w ith wire reinforcement=2C internal or external are likely nearly just as go od. Many Van's RV owners believe that fuel in the wings are safer that fuel in the fuselage. Unfortunately this is not true and wings are fragile and the fuel is still close enough to be a problem. > Subject: Pietenpol-List: Combustible lines > From: mario.giacummo(at)gmail.com > Date: Mon=2C 24 Mar 2014 08:02:23 -0700 > To: pietenpol-list(at)matronics.com > m> > > Hello=2C > > Like allways asking for something... I build a wing tank=2C and I want to know if the lines (from the tank to de gascolator) could be of rubber. I a sk because i never saw any one of this kind=2C all looks like aluminium. If there is a reason why not to do it with rubber I will be very gratefull if someone can explain me . > > By the way.. this weekend I install the firewall with a ceramic fiber ins ulation of 10mm.. It was a little bit gross in width=2C but it was the thin ner I could find. The firewall is a galvanizad sheet of 0.48 mm. It gave me a lot of work because I put it with the engine in place=2C but after an ho ur of folding and unfolding it stay in place =3Bo) > > -------- > Mario Giacummo > Photos here: http://goo.gl/wh7M4 > Little Blog : http://vgmk1.blogspot.com > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420920#420920 > > > > > Attachments: > > http://forums.matronics.com//files/dsc_0181_413.jpg > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Mar 24, 2014
The firewall cannot 'stop' the spread of a fire. But it may slow the fire i n the engine compartment for a long enough time for you to get on the groun d before all the good pieces are consumed. Maybe not=2C especially in a woo d-and-fabric plane. 'Can't hurt=2C might help' to take your best shot at it =2C though. Good food for thought. Lorenzo From: brian.kenney(at)live.ca Subject: RE: Pietenpol-List: Combustible lines Date: Mon=2C 24 Mar 2014 12:46:03 -0400 =0A =0A =0A There is another discussion starting suggesting that the fuselage is the ri ght place for the tank. Please read that. Rubber hoses are still in the mainstream of certified aircraft. They are re liable and easy to purchase but be sure you get the right type. Adding the term combustible to your question opens a huge can of worms. It is a question with no correct answer and many=2C many=2C opinions as no one wants to be killed by a post crash inferno . Is it as important to prevent a fire or stop the spread of a fire? If you a chieve the first then the second becomes less important. For example many p eople think firewalls are designed to slow the spread of a fire - I don't b elieve that is true because it won't work. There are there to prevent a fir e from an exhaust leak. So expanding on this concept design a fuel system t o try to prevent a fire first. Here is the safest fire system that I can conceive of. I know no one with this so it tells you that compromises are the order of the day. The tank s hould be in the strongest part of the airplane. That is likely the forward fuselage. The tank should be made of a flexile material such as used in rac ing fuel cells. There should be a holding cage (tank) and there should be n o sharp items near. Note that fuel cell are combustible but in a crash the tank likely won't brake apart. In a fire even aluminum will melt. If stress ed aluminum will break. The lines too should be short as possible and flexible. Internal metal bell ows lines are large and expensive but are probably the best. Rubber hoses w ith wire reinforcement=2C internal or external are likely nearly just as go od. Many Van's RV owners believe that fuel in the wings are safer that fuel in the fuselage. Unfortunately this is not true and wings are fragile and the fuel is still close enough to be a problem. =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Subject: Steel-tube fuselage update - landing gear welded
Date: Mar 24, 2014
Hello good Piet-ple, Hope the sun was shining where you live. It was sure shining in Seattle the past few days...! [Rain for the next week however :-( ] Mike from "ready Weld" made another visit and performed more of his craftsmanship magic. FYI my axle was moved 3 1/2" forward - to move the CG of the plane forward and make the plane less likely to nose-over. (Hey, wasn't that topic discussed on this message board recently...??) THANK YOU ALL for bringing that information up for discussion. THE FUSELAGE FRAME IS NOT YET COMPLETE - AS I WILL BE ADDING AN ADDITIONAL CROSS-PIECE BETWEEN THE WING STRUTS. (Several owners have had the cross piece fail in compression - so this additional structure NEEDS TO BE ADDED in order to prevent this situation.) I had cut the cross-piece tubing but since Mike had already put in almost 12 hours we decided to weld them in next time......... I tried to take photos from angles that would be helpful. Please note that I have not yet completed or flown this plane so do not take any of this info as proven...(!) Hope all of you are enjoying YOUR Pietenpol adventures/journeys...!! Jake -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420937#420937 Attachments: http://forums.matronics.com//files/lg_1_359.jpg http://forums.matronics.com//files/lg_2_126.jpg http://forums.matronics.com//files/lg_3_212.jpg http://forums.matronics.com//files/lg_4_507.jpg http://forums.matronics.com//files/lg_5_145.jpg ________________________________________________________________________________
vs. n
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Mar 24, 2014
I have a C-85 with a nose and center section tank. 10 in the nose and 12.5 in the center section. The carb on the cont engines are the lowest point of the engine. I have 3/8 fueline and the bottom of my nose tank is about 14 inches above the floorboards. This arrangement has worked very well on my plane for 42 years as well as J3 cubs. The pressure is not as important as the fuel flow. Put your plane at what you believe is maximum climb angle and do a timed measure fuel rate test. My plane can burn as much as 5.8 gallons per hour. Based on that number you will want to see a fuel delivery rate at 8.7 GPH. That is 1.5 times the 5.8 GPH I can burn. Good luck. You should not have any issues. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420949#420949 ________________________________________________________________________________
vs. n
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Mar 24, 2014
Mike, Thanks for bringing this up. I don't consider it as bringing up outdated ideas as much as a discussion of risk management. And discussing risk management is never a bad thing. I have no dog in this hunt as I have yet to decide on fuel tank position. I lean toward the Center Section tank, but am open to either location. So here are my questions for people smarter than I to answer- 1. Maybe Jack or Ryan can chime in here since it is a CG question. How much movement of the CG would occur with a 200 pound pilot (I know I am not FAA-sized) in the "average" Pietenpol (yes, I know there is no such creature, but you know what I am asking), if there was a 17 gallon fuel tank in the normal nose tank location. What would the change be from full (~17 gallons) to reserve (say, 3-4 gallons remaining) to completely empty? I realize the center section tank has much less effect on CG. My point in asking the question is this. In terms of risk management, how many guys have had incidents involving takeoff or landing out of CG range, as opposed to guys that have landed and the center section gave way? are we creating one risk management issue (flying out of CG range) by trying to prevent another one (the chance of fuel leak/spill in the event of a crash)? 2. This is a tough one to ask, but I will ask it. Kevin Purtee is the only guy I know personally that has had an accident in his Pietenpol. We all have heard his story, and I appreciate his sharing. I would ask him to share one more time. Kevin, do you think that your accident would have had any better or worse outcome had you had a nose tank instead of a wing tank? What tank are you building this time? Thanks for sharing. I really appreciate it. 3. We have had quite a discussion lately on the wisdom of braided fuel lines over hard lines from the center section, so let me add one more thought for discussion of risk management. What about adding breakaway fuel fittings between the center section tank and the braided fuel line that would shutoff in the event the lines tore away in an accident? Race cars have them. We had them on our helicopters when I was in the Marine Corps. Anyone want to chime in on the use of such fittings? Don't tell me they are too expensive as , most likely, only one or two would be needed. 4. Does anyone know which tank Mr. Pietenpol flew with most often? Just curious. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420951#420951 ________________________________________________________________________________
vs. n
Date: Mar 24, 2014
Terry, I forgot to mention that my engine gets 100% of its fuel from the nose tank. When on a cross country flight I use the center section for the additional fuel. As I burn the fuel from the nose, I refill it from the center section tank through a shut off valve. Just like many other airplanes do. Yes there is a large change in cg if running only a nose tank. I try to keep my nose tank as fuel as I can by draining the CS into it. I weigh 225lbs. I do have a different wing but my cg range is nearly the same as the Piet wing. The wing tank certainly helps with cg management. My cabains are verticle and I have the long fuse. As far as which tank is safer??? I guess it would depend on how you crash it and if there is a passenger on board. You could get super crazy and build your tank like a race car with foam inside. Just saying. You will need to decide what risks you are willing to take. I would build mine the same way again. Cheers, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420953#420953 ________________________________________________________________________________
vs. n
Date: Mar 24, 2014
Good info, Scott. Thanks! -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420954#420954 ________________________________________________________________________________
tanks vs. n
Date: Mar 24, 2014
Terry William Wynne also had a bad crash in his Pietenpol. He speaks from experience and true desire to keep us safe. I know I am listening. >From http://www.flycorvair.com/carbice.html "William Wynne was the passenger in his Corvair powered Pietenpol when it crashed north of Tampa, Florida, on July 14, 2001. The engine cut off at 700' AGL, which gave only 60 seconds to attempt a restart and execute a forced landing. To avoid people on the ground, the pilot tried a sharp bank and the plane spun in from 80'. The impact destroyed the airframe. When freeing the trapped pilot, a fire started and ignited William's fuel-soaked clothes. While extensively burned, both William and the pilot survived the accident. An investigation into the engine stoppage has indicated that carb ice almost certainly was the cause. Because a few of the engine components were incinerated in the fire, no one will ever be able to say with 100% certainty that carb ice was the cause. The engine was recovered from a wrecking yard where it sat for months, placed on a test stand, and runs well. The remaining wreckage was examined very closely and no evidence of any kind of failure was found. " His advice on what design element was wrong is here. http://flycorvair.net/2013/12/19/pietenpol-fuel-lines-and-cabanes/ http://flycorvair.net/2013/12/20/fuel-lines-and-cabanes-part-2/ Chris T. Sacramento, Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jarheadpilot82 Sent: Monday, March 24, 2014 3:52 PM Subject: Pietenpol-List: Re: Speaking of outdated stuff? Center section fuel tanks vs. n --> Mike, Thanks for bringing this up. I don't consider it as bringing up outdated ideas as much as a discussion of risk management. And discussing risk management is never a bad thing. I have no dog in this hunt as I have yet to decide on fuel tank position. I lean toward the Center Section tank, but am open to either location. So here are my questions for people smarter than I to answer- 1. Maybe Jack or Ryan can chime in here since it is a CG question. How much movement of the CG would occur with a 200 pound pilot (I know I am not FAA-sized) in the "average" Pietenpol (yes, I know there is no such creature, but you know what I am asking), if there was a 17 gallon fuel tank in the normal nose tank location. What would the change be from full (~17 gallons) to reserve (say, 3-4 gallons remaining) to completely empty? I realize the center section tank has much less effect on CG. My point in asking the question is this. In terms of risk management, how many guys have had incidents involving takeoff or landing out of CG range, as opposed to guys that have landed and the center section gave way? are we creating one risk management issue (flying out of CG range) by trying to prevent another one (the chance of fuel leak/spill in the event of a crash)? 2. This is a tough one to ask, but I will ask it. Kevin Purtee is the only guy I know personally that has had an accident in his Pietenpol. We all have heard his story, and I appreciate his sharing. I would ask him to share one more time. Kevin, do you think that your accident would have had any better or worse outcome had you had a nose tank instead of a wing tank? What tank are you building this time? Thanks for sharing. I really appreciate it. 3. We have had quite a discussion lately on the wisdom of braided fuel lines over hard lines from the center section, so let me add one more thought for discussion of risk management. What about adding breakaway fuel fittings between the center section tank and the braided fuel line that would shutoff in the event the lines tore away in an accident? Race cars have them. We had them on our helicopters when I was in the Marine Corps. Anyone want to chime in on the use of such fittings? Don't tell me they are too expensive as , most likely, only one or two would be needed. 4. Does anyone know which tank Mr. Pietenpol flew with most often? Just curious. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420951#420951 ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
tanks vs. n
Date: Mar 24, 2014
Terry, you can see the effects of what you are asking using the spreadsheet I posted yesterday. If you just swap the values for the fuel tank and the baggage compartment for my airplane (the data that I sent in the spreadsheet) you can see pretty closely what the effects would be, if it were my airplane. I just did that - swapping the 90 lbs of fuel from the centersection tank to the baggage compartment, and taking the fuel tank weight to 0.00. With 90 lbs (15 gallons) of fuel in the nose, the CG with my 195 lb butt in the rear seat would move from 19.94" to 17.71" aft of the leading edge. Very Nice! However, when you are down to 2.5 gallons of fuel (15 lbs) the CG goes back to 19.42" - nearly a 2" shift. I suspect you will need a trim system of some sort otherwise you are going to be constantly pushing on the stick to keep the nose down (f the plane was trimmed to fly straight and level with a full tank). If you are flying near empty and for whatever reason you take your hand off the stick, the nose will want to pitch up which could get very interesting if you were already flying close to a stall. With the centersection tank, the situation is reversed, but the change is slight. Again, with the data from my airplane, with my 195 lbs of Macho, Pietenpol Aviator sitting comfortably in the rear seat, with 90 lbs of fuel on board and no baggage in the nose, my CG is hovering around the dreaded 20" barrier at 19.94" aft of the Leading edge (one reason I generally carry about 5 lbs of stuff in the baggage compartment). If I burn all but 2.5 gallons from my tank, the CG moves to 19.83", or just over a tenth of an inch, and in the direction that if I take my hand off the stick, the nose will go down, not up. I like my centersection fuel tank. I never have to worry that an extreme noseup attitude might starve the fuel supply, and I have a large enough baggage compartment to hold a tent and sleeping bag (a true "Air Camper"). The only worry is the possibility of a shifting centersection in a crash causing fuel leakage. When I recover my airplane (hopefully not for several more years) I will put in braided flexible fuel lines. I have had one forced landing which caused substantial damage to the airframe, including dragging a wingtip in the ensuing groundloop when the axle broke, without causing any shift of the centersection or damage to the fuel lines. I was lucky. In Kevin Purtee's crash, those on the scene reported a large fuel leak due to the ruptured fuel tank. There was no fire. Kevin was lucky. There was nothing left of the fuselage forward of the rear cockpit, so I don't think you could say a nose tank would have fared better. This is one of those decisions in building a Pietenpol that every builder needs to make for himself, based on facts and information, and how he wants to build and fly his airplane. There is no right or wrong answer. Just try to make an informed choice. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jarheadpilot82 Sent: Monday, March 24, 2014 6:52 PM Subject: Pietenpol-List: Re: Speaking of outdated stuff? Center section fuel tanks vs. n Mike, Thanks for bringing this up. I don't consider it as bringing up outdated ideas as much as a discussion of risk management. And discussing risk management is never a bad thing. I have no dog in this hunt as I have yet to decide on fuel tank position. I lean toward the Center Section tank, but am open to either location. So here are my questions for people smarter than I to answer- 1. Maybe Jack or Ryan can chime in here since it is a CG question. How much movement of the CG would occur with a 200 pound pilot (I know I am not FAA-sized) in the "average" Pietenpol (yes, I know there is no such creature, but you know what I am asking), if there was a 17 gallon fuel tank in the normal nose tank location. What would the change be from full (~17 gallons) to reserve (say, 3-4 gallons remaining) to completely empty? I realize the center section tank has much less effect on CG. My point in asking the question is this. In terms of risk management, how many guys have had incidents involving takeoff or landing out of CG range, as opposed to guys that have landed and the center section gave way? are we creating one risk management issue (flying out of CG range) by trying to prevent another one (the chance of fuel leak/spill in the event of a crash)? 2. This is a tough one to ask, but I will ask it. Kevin Purtee is the only guy I know personally that has had an accident in his Pietenpol. We all have heard his story, and I appreciate his sharing. I would ask him to share one more time. Kevin, do you think that your accident would have had any better or worse outcome had you had a nose tank instead of a wing tank? What tank are you building this time? Thanks for sharing. I really appreciate it. 3. We have had quite a discussion lately on the wisdom of braided fuel lines over hard lines from the center section, so let me add one more thought for discussion of risk management. What about adding breakaway fuel fittings between the center section tank and the braided fuel line that would shutoff in the event the lines tore away in an accident? Race cars have them. We had them on our helicopters when I was in the Marine Corps. Anyone want to chime in on the use of such fittings? Don't tell me they are too expensive as , most likely, only one or two would be needed. 4. Does anyone know which tank Mr. Pietenpol flew with most often? Just curious. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420951#420951 ________________________________________________________________________________
vs. n
Date: Mar 24, 2014
Chris, You are absolutely right. William is the first guy I know that had an accident in his Pietenpol. Kevin is the second. My point was that Kevin is rebuilding his aircraft, so I was wondering what his thoughts were in the rebuild - what, if any changes he would make in the area of his fuel tank. Did he feel it made any difference as t the cause or outcome. Or none at all. I have read William's postings about fuel lines and cabanes. In fact, I put a link on this forum right after he wrote those two postings, as I thought they had value for all of us Pietenpol builders and flyers alike. Thanks for reminding me. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420959#420959 ________________________________________________________________________________
vs. n
Date: Mar 24, 2014
Jack, Thanks for doing the leg work with the spreadsheet. I was hoping you would, so that people who have not downloaded it, wold still get the info. Thanks. My point of the questions is exactly as you put it. I am not convinced that either is better than the other. They both have their risk management issues. I think that the point should be this - make your decision based on an informed analysis, and not because one looks better than the other, or some other less informed reason. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420960#420960 ________________________________________________________________________________
tanks vs. n
Date: Mar 24, 2014
I have a 17 US gal forward tank and the change in the fuel load from full t o reserve changes the trim from slightly nose up required at full fuel to a slightly nose down requirement at minimum fuel. I don't have a trim and t he forces are not significant in either direction. Where it starts and ends depends of course where you start. I try not to have a lot more fuel on b oard when I don't need it. Trim is also speed dependant. You can counter so me of this trim change with a power adjustment. I have flown for 2 and 3/4 hours a couple of times. The lack of a trim was not a factor. While the trim changes less in the center section it is always in the wrong place if you have a light engine and there is more weight or moment needed on the front to counter it. So like everything there is a compromise invo lved. From: jack(at)bedfordlandings.com Subject: RE: Pietenpol-List: Re: Speaking of outdated stuff? Center section fuel tanks vs. n Date: Mon=2C 24 Mar 2014 20:43:48 -0400 =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A Terry=2C=0A you can see the effects of what you are asking using the spreadsheet I post ed=0A yesterday. If you just swap the values for the fuel tank and the baggage =0A compartment for my airplane (the data that I sent in the spreadsheet) you c an=0A see pretty closely what the effects would be=2C if it were my airplane.=0A =0A =0A =0A I=0A just did that - swapping the 90 lbs of fuel from the centersection tank to the=0A baggage compartment=2C and taking the fuel tank weight to 0.00. With 90 lb s=0A (15 gallons) of fuel in the nose=2C the CG with my 195 lb butt in the rear seat=0A would move from 19.94" to 17.71" aft of the leading edge. Very=0A Nice! However=2C when you are down to 2.5 gallons of fuel (15 lbs) the CG =0A goes back to 19.42" - nearly a 2" shift. I suspect you will=0A need a trim system of some sort otherwise you are going to be constantly=0A pushing on the stick to keep the nose down (f the plane was trimmed to fly =0A straight and level with a full tank). If you are flying near empty and=0A for whatever reason you take your hand off the stick=2C the nose will want to=0A pitch up which could get very interesting if you were already flying close to a=0A stall.=0A =0A =0A =0A With=0A the centersection tank=2C the situation is reversed=2C but the change is sl ight. =0A Again=2C with the data from my airplane=2C with my 195 lbs of Macho=2C Piet enpol=0A Aviator sitting comfortably in the rear seat=2C with 90 lbs of fuel on boar d and=0A no baggage in the nose=2C my CG is hovering around the dreaded 20" barrier =0A at 19.94" aft of the Leading edge (one reason I generally carry about 5=0A lbs of stuff in the baggage compartment). If I burn all but 2.5 gallons fr om=0A my tank=2C the CG moves to 19.83"=2C or just over a tenth of an inch=2C and in=0A the direction that if I take my hand off the stick=2C the nose will go down =2C not=0A up.=0A =0A =0A =0A I=0A like my centersection fuel tank. I never have to worry that an extreme=0A noseup attitude might starve the fuel supply=2C and I have a large enough b aggage=0A compartment to hold a tent and sleeping bag (a true "Air=0A Camper"). The only worry is the possibility of a shifting=0A centersection in a crash causing fuel leakage. When I recover my airplane =0A (hopefully not for several more years) I will put in braided flexible fuel =0A lines. I have had one forced landing which caused substantial damage to=0A the airframe=2C including dragging a wingtip in the ensuing groundloop when the=0A axle broke=2C without causing any shift of the centersection or damage to t he=0A fuel lines. I was lucky. =0A =0A =0A =0A In=0A Kevin Purtee's crash=2C those on the scene reported a large fuel leak due t o the=0A ruptured fuel tank. There was no fire. Kevin was lucky. There=0A was nothing left of the fuselage forward of the rear cockpit=2C so I don't think=0A you could say a nose tank would have fared better.=0A =0A =0A =0A This=0A is one of those decisions in building a Pietenpol that every builder needs to=0A make for himself=2C based on facts and information=2C and how he wants to b uild and=0A fly his airplane. There is no right or wrong answer. Just try to=0A make an informed choice.=0A =0A =0A =0A Jack=0A Phillips=0A =0A NX899JP=0A =0A Smith Mountain Lake=2C=0A Virginia=0A =0A =0A =0A =0A =0A =0A =0A -----Original=0A Message----- =0A From: owner-pietenpol-list-server(at)matronics.com=0A [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jarheadpilo t82 =0A Sent: Monday=2C March 24=2C 2014 6:52 PM =0A =0A Subject: Pietenpol-List: Re: Speaking of outdated stuff? Center section fue l=0A tanks vs. n=0A =0A =0A =0A -->=0A Pietenpol-List message posted by: "jarheadpilot82"=0A =0A =0A =0A =0A Mike=2C=0A =0A =0A =0A Thanks=0A for bringing this up. I don't consider it as bringing up outdated ideas as much=0A as a discussion of risk management. And discussing risk management is never a=0A bad thing. I have no dog in this hunt as I have yet to decide on fuel tank =0A position. I lean toward the Center Section tank=2C but am open to either=0A location. So here are my questions for people smarter than I to answer-=0A =0A =0A =0A 1.=0A Maybe Jack or Ryan can chime in here since it is a CG question. How much=0A movement of the CG would occur with a 200 pound pilot (I know I am not=0A FAA-sized) in the "average" Pietenpol (yes=2C I know there is no such=0A creature=2C but you know what I am asking)=2C if there was a 17 gallon fuel tank in=0A the normal nose tank location. What would the change be from full (~17 gall ons)=0A to reserve (say=2C 3-4 gallons remaining) to completely empty? I realize th e=0A center section tank has much less effect on CG.=0A =0A =0A =0A My=0A point in asking the question is this. In terms of risk management=2C how ma ny=0A guys have had incidents involving takeoff or landing out of CG range=2C as =0A opposed to guys that have landed and the center section gave way? are we=0A creating one risk management issue (flying out of CG range) by trying to=0A prevent another one (the chance of fuel leak/spill in the event of a crash) ?=0A =0A =0A =0A 2.=0A This is a tough one to ask=2C but I will ask it. Kevin Purtee is the only g uy I=0A know personally that has had an accident in his Pietenpol. We all have hear d=0A his story=2C and I appreciate his sharing. I would ask him to share one mor e=0A time. Kevin=2C do you think that your accident would have had any better or worse=0A outcome had you had a nose tank instead of a wing tank? What tank are you =0A building this time? Thanks for sharing. I really appreciate it.=0A =0A =0A =0A 3.=0A We have had quite a discussion lately on the wisdom of braided fuel lines o ver=0A hard lines from the center section=2C so let me add one more thought for=0A discussion of risk management. What about adding breakaway fuel fittings=0A between the center section tank and the braided fuel line that would shutof f in=0A the event the lines tore away in an accident? Race cars have them. We had t hem=0A on our helicopters when I was in the Marine Corps. Anyone want to chime in on=0A the use of such fittings? Don't tell me they are too expensive as =2C most =0A likely=2C only one or two would be needed.=0A =0A =0A =0A 4.=0A Does anyone know which tank Mr. Pietenpol flew with most often? Just curiou s.=0A =0A =0A =0A --------=0A =0A Semper=0A Fi=2C=0A =0A =0A =0A Terry=0A Hand=0A =0A Athens=2C GA=0A =0A =0A =0A USMC=2C=0A USMCR=2C ATP=0A =0A BVD=0A DVD PDQ BBQ=0A =0A =0A =0A =0A =0A =0A =0A =0A =0A Read=0A this topic online here:=0A =0A =0A =0A http://forums.matronics.com/viewtopic.php?p=420951#420951=0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
vs. n
Date: Mar 24, 2014
Terry, My centersection tank is a Cessna 140 wing tank. It fit because I have a cub airfoil which is thicker than the Piet wing. I do like what the guys are doing with the moth style tank. It looks cool and you can carry all the fuel you may require for a decent cross country. Also keeps it on the cg. Way cool. My nose tank is not aluminum. Frankly I don't remember what it is made of. Last time I had it out was in 2000. It did however come out of an Opal Kadet car from the early 1970's. Was a perfect fit after moving the filler neck from the side to the top. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420965#420965 ________________________________________________________________________________
Subject: Corky's Miss Isabelle
Date: Mar 24, 2014
Some of you may not know Claude "Corky" Corbett, but he's the gentleman from Shreveport, LA who completed and flew my airplane, NX41CC, before selling it to me. His email address for as long as I've known him or seen his posts has been Isablcorky(at)aol.com , with the first part of that being his wife Isabelle's name. These last few years, she has been in a nursing home and Corky has been living by himself in a little place in the country. I just had news from him that Isabelle died on Sunday morning, March 23. Just thought I would pass this along to anyone who knows Corky and might care to send condolences his way. By the way, Corky was a builder who didn't waste a lot of time on theoretical matters or clever innovations. He built 41CC light, simple, and very deliberately. He completed the paperwork, W&B, and testing- and then hit a brick wall when the FAA dragged its heels for years before passing the Sport Pilot rule that would have permitted him to continue flying without a medical. He decided that the rule would never pass, sold the airplane to me, and then the rule passed shortly after that. I always felt like I took his airplane away, but have tried to make the most of being its steward since then. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420968#420968 ________________________________________________________________________________
Subject: Re: Steel-tube fuselage update - landing gear welded
Date: Mar 24, 2014
Jake; Would you mind pointing out where this additional cross-piece will be added? I guess I must have missed hearing about where compression failures may have occurred in a spot related to this cross-piece, and I can't visualize it from the narrative that you provided. Thanks. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420970#420970 ________________________________________________________________________________
vs. n
Date: Mar 24, 2014
Terry: I'll tackle your Question No. 1 by plugging your numbers into the Excel spreadsheet that documents my W&B on 41CC, which I also sent to William shortly after a very competent EAA Tech Counselor, his experienced assistant, and I conducted the W&B on race car scales and I documented it in my Excel spreadsheet (which cannot lie, you understand ;o). I believe 41CC was included in William's survey of the geometries, weights, and axle locations of various Air Campers and variants thereof, which survey is presently being discussed and is making the rounds. You said to use a 200# pilot and to check the CG shift from 17 gallons in the nose tank down to about 3 gallons remaining in the tank. In my 633 lb. (empty) airplane in the given configuration, the CG shifts 2.3" from 19.1" to 21.4" aft of datum (out of the aft limit). This shift will be the same for any aircraft since it represents a moment that is the result of a mass times a distance. The important thing, and Jack brought it out, is that in the wing centersection the weight changes with fuel burn but it's located essentially on the CG so nothing shifts. In the nose, the weight of the fuel is "hanging" out there on a moment arm, so as the weight changes, so does the moment. The poor pilot, sitting out there on the other end of the teeter-totter, has no way to move forward (or shed weight) to balance the lightening load of fuel, so the CG comes creeping aft to get him as punishment for drinking all that beer and eating all that ice cream while watching TV at night ;o) *FULL DISCLOSURE; TRUTH IN ADVERTISING; ONE PERSON'S OBSERVATION ONLY; USE AT YOUR OWN RISK; MAY BE TOTAL B.S. AND UNSAFE*: my airplane has flown in the latter configuration on many occasions and the handling was not reported as being squirrelly, uncomfortable, unstable, or uncontrollable. On several of those occasions, the pilot was an experienced test pilot, so it may be that his tolerance for what constitutes "controllability" may be broader than that of the average recreational pilot. I am not sanctioning such operation though. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420971#420971 ________________________________________________________________________________
vs. n
Date: Mar 24, 2014
Airlion: I forgot to address your original question in this thread, but I will echo what was suggested. It's not so much the head of the fuel tank height above the carb as it is the fuel flow that you get. You can have a wing centersection tank several feet above the carb float bowl, but if you use small diameter fuel tubing and a lot of fittings, the fuel flow may still be inadequate. 1 ft. of water (static head) = 0.433 psi. This is one of the unbending mathematical laws that William alluded to. It won't change, as long as Earth's gravity doesn't. My Stromberg carb was designed for "gravity feed", less than 2 psi fuel pressure, or about 4-1/2 ft of head. If you assume that pipe friction and fittings add roughly 50% to the total head, that means about 3 feet of "gravity" head (elevation)... pretty much the height of a wing tank above a carb. Any more than that pretty much means that you have a "pressurized" system... a fuel pump. Some of the little electric Facet pumps can develop as much as 15 psi... definitely a "pressurized" system. So if your system has a nose tank "down low", use good sized fuel lines and minimal fittings. If your tank is "up high", you have the luxury of adding some bends and fittings, and maybe using slightly smaller tubing, but you're still better off if you keep the tubing size generous and limit the sharp offset bends and fittings. I won't say what Tony Bingelis recommends for fuel tubing size. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420972#420972 ________________________________________________________________________________
vs. n
Date: Mar 24, 2014
Oscar, Thanks for the input. Your clear explanation was the reason for my question. It sounds like running your nose tank low puts the non-standard weighing guy like me in an aft CG condition that may put the aircraft beyond the recommended aft CG limit. I also get it that you have flown in that regime with little to no consequence. But my question still boils down to risk management. Are we trading one risk (fuel in the center section, a potential risk in the event of a crash which one hopes never happens) for another risk (nose tank which has the capacity to affect every flight, but definitely affects longer flights with greater fuel burn). That is not an area that in which I would want to fly on a regular basis. The nice thing about your long, clear explanation is that a beginning builder can write in and post this same question a year from now and someone can answer back, "Look it up. It is in the archives" [Wink] -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420974#420974 ________________________________________________________________________________
Date: Mar 24, 2014
Jake, Nice. Really nice! Are you doing bungees or die springs? -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420975#420975 ________________________________________________________________________________
Subject: Re: Weight & Balance Spreadsheet
Date: Mar 24, 2014
Gary, that's precisely my point. Moving the wheels has virtually NO affect on CG in flight, all else being equal. That's why you can change a Tripacer into a Pacer or vice versa. Same wing and fuselage. In theory, you don't even have to put the scales under the wheels to get a valid CG. You could put a fork under the prop and a knife edge stand under the pilots seat and calculate a CG with accurate scales and known tare weights of the supports. The only other necessary missing piece is their location in relationship to whatever datum you choose. Weight x Arm always = Moment. Total weight and total moment determine CG. My point was that you can't change just one thing in Jack's spreadsheet without at least considering its affect on the others. Moving the main wheels forward WILL slightly increase the weight on the tail while on scales but the calculated CG will stay almost static. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420976#420976 ________________________________________________________________________________
tanks vs. n
Date: Mar 25, 2014
Sorry I think you are making the wrong conclusion. Your weight has nothing to do with it. You simply don't fly if there is an aft CG and having the fu el in the wing just makes the problem worse. Running out of fuel (or nearly running out of fuel) in a nose tank versus t he same in a wing tank (or nearly running out of fuel) cannot make the si tuation worse. If the fuel is gone it is gone. The difference that in a nos e tank is that any fuel moves the CG forward at everything but empty. Since no one can fly on empty it is always better in the nose than in the wing a nd the amount of weight added to the nose=2C the length of the engine mount or the amount the wing is moved back is less and on average the cg is more forward. There is also the 15lbs or more of the tank weight itself that is helping the aft cg problem all they time. The 10 lbs (or whatever you con sider that to be) of reserve fuel that no one ever uses is also helping. If you weigh more and it is your airplane then it is more important that th e fuel is forward. > Subject: Pietenpol-List: Re: Speaking of outdated stuff? Center section f uel tanks vs. n > From: jarheadpilot82(at)hotmail.com > Date: Mon=2C 24 Mar 2014 22:57:53 -0700 > To: pietenpol-list(at)matronics.com > tmail.com> > > Oscar=2C > > Thanks for the input. Your clear explanation was the reason for my questi on. It sounds like running your nose tank low puts the non-standard weighin g guy like me in an aft CG condition that may put the aircraft beyond the r ecommended aft CG limit. I also get it that you have flown in that regime w ith little to no consequence. > > But my question still boils down to risk management. Are we trading one r isk (fuel in the center section=2C a potential risk in the event of a crash which one hopes never happens) for another risk (nose tank which has the c apacity to affect every flight=2C but definitely affects longer flights wit h greater fuel burn). That is not an area that in which I would want to fly on a regular basis. > > The nice thing about your long=2C clear explanation is that a beginning b uilder can write in and post this same question a year from now and someone can answer back=2C "Look it up. It is in the archives" [Wink] > > -------- > Semper Fi=2C > > Terry Hand > Athens=2C GA > > USMC=2C USMCR=2C ATP > BVD DVD PDQ BBQ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420974#420974 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: all good--even the outdated stuff which.....really isn't
outdated at all, even wing cc tanks!
Date: Mar 25, 2014
Great discussion here guys and what I was trying to do here was sarcastical ly (intentional) lluminate William Wynne's criticism of the outdating products/ possibly unsafe suggestions that he notes the Tony Bingelis books contain and that the old ways of doing things with homebuilts aren't always the best anymore. I was just applying William's logic to the Pietenpol center section wing ta nk to see what kind of a response I would get PLUS to advocate what I belie ve is a great place for fuel in a Pietenpol but both wing and nose tanks are, of course, totally acceptable---just like the older ideas in specific insta nces in the Bingelis books. The main point is that I want to bring to this list a sense of encouragemen t, not discouragement. I want to remain positive and enthusiastic, not stand around and urinate on specific pet-peeve campfires that I'd like to dampen. Long laborious posts with multiple web links are simply exhausting and unle ss you're nearly unemployed or retired, few of us have the time to read that stuff nor is it necessary to build a safe Pietenpol. Practical, sound, proven advice is what I like to see on the Pietenpol list and for the most part we have that which has always attracted me to the li st, the airplane, and the people who build them. Simple, light, and cheap. It doesn't have to get all convoluted and complex and wordy to be safe an d fun. Here's to common sense and having fun building! MikeC. Ohio ________________________________________________________________________________
tanks vs. n
Date: Mar 25, 2014
Terry, I'm glad you asked that question, as it's been on my mind all day, since Mike's post. I don't mean this as a rebuttal for what Mike said, only an observation. I'm not sure if there is a conclusive answer. Certainly, no one could argue much with Mike's logic...but I have a 16 gallon wing tank. Quite honestly, I love the process of refueling...even if while perched on a ladder and the strut. Who wouldn't? Re-fueling means that you're going flying again! Maybe not that day, but, again, someday. I enjoy that as much as I enjoy removing the 84 screws that hold my cowling in place....as much as I enjoy removing all the panels for annual inspection. It's what I signed up for. As mentioned, my wing tank is 16 gallons. Cabanes are tilted back 4". That's the real key...the beauty of setting CG with the wing. There is no worry about fuel burn. Most aft CG, Most Forward CG, Gross CG, all fall within limits. I used Jack's chart. It's great! You can easily plug in hypothetical numbers all day and watch the results. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jarheadpilot82 Sent: Monday, March 24, 2014 3:52 PM Subject: Pietenpol-List: Re: Speaking of outdated stuff? Center section fuel tanks vs. n --> Mike, Thanks for bringing this up. I don't consider it as bringing up outdated ideas as much as a discussion of risk management. And discussing risk management is never a bad thing. I have no dog in this hunt as I have yet to decide on fuel tank position. I lean toward the Center Section tank, but am open to either location. So here are my questions for people smarter than I to answer- 1. Maybe Jack or Ryan can chime in here since it is a CG question. How much movement of the CG would occur with a 200 pound pilot (I know I am not FAA-sized) in the "average" Pietenpol (yes, I know there is no such creature, but you know what I am asking), if there was a 17 gallon fuel tank in the normal nose tank location. What would the change be from full (~17 gallons) to reserve (say, 3-4 gallons remaining) to completely empty? I realize the center section tank has much less effect on CG. My point in asking the question is this. In terms of risk management, how many guys have had incidents involving takeoff or landing out of CG range, as opposed to guys that have landed and the center section gave way? are we creating one risk management issue (flying out of CG range) by trying to prevent another one (the chance of fuel leak/spill in the event of a crash)? 2. This is a tough one to ask, but I will ask it. Kevin Purtee is the only guy I know personally that has had an accident in his Pietenpol. We all have heard his story, and I appreciate his sharing. I would ask him to share one more time. Kevin, do you think that your accident would have had any better or worse outcome had you had a nose tank instead of a wing tank? What tank are you building this time? Thanks for sharing. I really appreciate it. 3. We have had quite a discussion lately on the wisdom of braided fuel lines over hard lines from the center section, so let me add one more thought for discussion of risk management. What about adding breakaway fuel fittings between the center section tank and the braided fuel line that would shutoff in the event the lines tore away in an accident? Race cars have them. We had them on our helicopters when I was in the Marine Corps. Anyone want to chime in on the use of such fittings? Don't tell me they are too expensive as , most likely, only one or two would be needed. 4. Does anyone know which tank Mr. Pietenpol flew with most often? Just curious. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420951#420951 ________________________________________________________________________________
Subject: Re: all good--even the outdated stuff which.....really
isn't out
Date: Mar 25, 2014
Mike, First of all, sarcasm is in the eye of the beholder. It usually works best when speaking with people who know your normal demeanor and attitude. I did not get the sarcasm, and I am sure that I am not alone. Long and laborious posts with multiple web links is a problem? Then none of us should point people toward westcoastpiet.com or any builders website. The truth is that I have all the time in the world to research construction practices and design issues if it means I build a better airplane. I will take the time. I work 2 jobs, Mike, and I read a lot. It just means I don't watch Dancing With The Stars or Duck Dynasty. I think that you sell builders short by assuming that reading and studying as they build is just "too much". I am not trying to over complicate things, but I am trying to research as much as I can. This is a first time build for me, and I don't want it to be my last. If writing a long post about safe construction practices or risk management turns people away from building a Pietenpol, then they did not need to be building one anyway. Fun can be had and still pass along good information. Give builders some credit, and let them decide to read or not to read. Gonna close, Mike, I am headed to the shop to work on my empennage. That is after studying and reading for quite a while yesterday so as to, hopefully avoid mistakes in building. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420981#420981 ________________________________________________________________________________
vs. n
Date: Mar 25, 2014
Brian, I am not getting your logic- "Your weight has nothing to do with it. You simply don't fly if there is an aft CG and having the fuel in the wing just makes the problem worse." Fuel in the wing makes it worse? How is that? Fuel in the wing sits closer to the CG than fuel in the nose, and the burn off affects CG less, not more the closer it is to the aircraft's CG. "Running out of fuel (or nearly running out of fuel) in a nose tank versus the same in a wing tank (or nearly running out of fuel) cannot make the situation worse. If the fuel is gone it is gone. The difference that in a nose tank is that any fuel moves the CG forward at everything but empty. Since no one can fly on empty it is always better in the nose than in the wing and the amount of weight added to the nose, the length of the engine mount or the amount the wing is moved back is less and on average the cg is more forward. There is also the 15lbs or more of the tank weight itself that is helpingthe aft cg problem all they time. The 10 lbs (or whatever you consider that to be) of reserve fuel that no one ever uses is also helping. " Brian, I am not worried about the fuel that is left in the nose tank. I am worried about the fuel that burned off that was, at one time, forward of the CG that was balancing against my fat butt sitting behind the CG. Once that fuel has burned off, there is less weight to counteract my fat butt, so the CG moves aft. Check your aerodynamics and design books. I just don't want to move it so far aft, that the airplane is aft of the safe aft CG. That can be mitigated in the construction phase by adjustment of the wing location, and all I am saying is that that issue should be dealt with in the build. Nobody should fly an airplane outside of the CG range. Will the airplane fly? Yes. Are your options lessened when you do? Absolutely. "If you weigh more and it is your airplane then it is more important that the fuel is forward." It is most important that the CG is balanced, and the aircraft is flown in the proper CG range. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420985#420985 ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
tanks vs. n
Date: Mar 25, 2014
Terry, you commented exactly on what was going through my mind as I read Brian's post. No one is advocating using a wing tank and THEN setting up the plane to be out of CG limits, that would be, frankly, stupid. Using a wing tank, just to be clear one more time, eliminates a factor that is always the case with a nose tank - that the CG will shift aft as fuel is consumed. The arguments against a wing tank to some degree fall in the category of what Chuck Gantzer, a former member of this list who flies his Piet literally all over the country, used to call "building for crash-worthiness, not flight-worthiness". There are potential problems with both tank locations. I might mention that many years ago the Pavliga's wing tank on Sky Gypsy split a seam while the elder Frank was flying. He got soaked with gas and by all accounts spent a number of terrifying minutes getting the plane back on the ground. As you, Mike, and William have all said earlier, it's a matter of building well with risk management in mind. (It is possible to build well and still produce a crappy product! - our home is a good example, built like a tank by an expert craftsman, but much less than comfortably livable because of design flaws). Kip Gardner On Mar 25, 2014, at 9:11 AM, jarheadpilot82 wrote: > > > > Brian, > > I am not getting your logic- > > "Your weight has nothing to do with it. You simply don't fly if > there is an aft CG and having the fuel in the wing just makes the > problem worse." > > Fuel in the wing makes it worse? How is that? Fuel in the wing sits > closer to the CG than fuel in the nose, and the burn off affects CG > less, not more the closer it is to the aircraft's CG. > > "Running out of fuel (or nearly running out of fuel) in a nose tank > versus the same in a wing tank (or nearly running out of fuel) > cannot make the situation worse. If the fuel is gone it is gone. The > difference that in a nose tank is that any fuel moves the CG forward > at everything but empty. Since no one can fly on empty it is always > better in the nose than in the wing and the amount of weight added > to the nose, the length of the engine mount or the amount the wing > is moved back is less and on average the cg is more forward. There > is also the 15lbs or more of the tank weight itself that is > helpingthe aft cg problem all they time. The 10 lbs (or whatever you > consider that to be) of reserve fuel that no one ever uses is also > helping. " > > Brian, I am not worried about the fuel that is left in the nose > tank. I am worried about the fuel that burned off that was, at one > time, forward of the CG that was balancing against my fat butt > sitting behind the CG. Once that fuel has burned off, there is less > weight to counteract my fat butt, so the CG moves aft. Check your > aerodynamics and design books. I just don't want to move it so far > aft, that the airplane is aft of the safe aft CG. That can be > mitigated in the construction phase by adjustment of the wing > location, and all I am saying is that that issue should be dealt > with in the build. Nobody should fly an airplane outside of the CG > range. Will the airplane fly? Yes. Are your options lessened when > you do? Absolutely. > > "If you weigh more and it is your airplane then it is more important > that the fuel is forward." > > It is most important that the CG is balanced, and the aircraft is > flown in the proper CG range. > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > USMC, USMCR, ATP > BVD DVD PDQ BBQ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420985#420985 > > ________________________________________________________________________________
Subject: Re: Corky's Miss Isabelle
Date: Mar 25, 2014
Oscar, thanks for letting us know, I will send Corky my condolences - I miss his regular presence on the list. Kip Gardner On Mar 24, 2014, at 11:40 PM, taildrags wrote: > > > > Some of you may not know Claude "Corky" Corbett, but he's the > gentleman from Shreveport, LA who completed and flew my airplane, > NX41CC, before selling it to me. His email address for as long as > I've known him or seen his posts has been Isablcorky(at)aol.com , with > the first part of that being his wife Isabelle's name. These last > few years, she has been in a nursing home and Corky has been living > by himself in a little place in the country. I just had news from > him that Isabelle died on Sunday morning, March 23. > > Just thought I would pass this along to anyone who knows Corky and > might care to send condolences his way. By the way, Corky was a > builder who didn't waste a lot of time on theoretical matters or > clever innovations. He built 41CC light, simple, and very > deliberately. He completed the paperwork, W&B, and testing- and > then hit a brick wall when the FAA dragged its heels for years > before passing the Sport Pilot rule that would have permitted him to > continue flying without a medical. He decided that the rule would > never pass, sold the airplane to me, and then the rule passed > shortly after that. I always felt like I took his airplane away, > but have tried to make the most of being its steward since then. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420968#420968 > > ________________________________________________________________________________
Date: Mar 25, 2014
Subject: Re: Speaking of outdated stuff? Center section fuel
tanks vs. n
I believe Terry has nailed the crux of the issue right there: it is more important to be in CG limits. It has been demonstrated that the most effective way to correct an aft CG is to adjust the location of the wing relative to the fuselage. By doing so you are not moving just one component relative to the datum, you are moving the entire fuselage and everything contained within relative to the datum (it may be easier to think of the wing as the fixed point, and the fuselage is shifting fore and aft beneath it). Being able to reposition the wing in relation to the fuselage is a feature of the Pietenpol that many aircraft do not have, and allows you to setup the aircraft to be in a safe configuration for a given builder. If simply adjusting the wing's location is undesirable from an aesthetic point of view....well, ok, there will have to be more compromises elsewhere. As far as safety of the fuselage tank versus the wing tank, I think that's a question best answered by, as Terry has mentioned, risk management. Empirical testing by certain members of the community has shown that the fuselage tank can be compromised quite handily.....I believe one will see a better return by taking measures to reasonably manage the risk, such as braided fuel lines from wing to fuselage as William advocates, than being overly concerned about one location versus the other. Ryan On Tue, Mar 25, 2014 at 8:11 AM, jarheadpilot82 wrote: > jarheadpilot82(at)hotmail.com> > > > "If you weigh more and it is your airplane then it is more important that > the fuel is forward." > > It is most important that the CG is balanced, and the aircraft is flown in > the proper CG range. > ________________________________________________________________________________
Date: Mar 25, 2014
Good discussion here guys and what I was trying to do here was sarcasticall y (intentional) lluminate William Wynne's criticism of the outdating products/ possibly unsafe suggestions that he notes the Tony Bingelis books contain and that the old ways of doing things with homebuilts aren't always the best anymore. I was just applying William's logic to the Pietenpol center section wing ta nk to see what kind of a response I would get PLUS to advocate what I belie ve is a great place for fuel in a Pietenpol but both wing and nose tanks are, of course, totally acceptable---just like the older ideas in specific insta nces in the Bingelis books. The main point is that I want to bring to this list a sense of encouragemen t, not discouragement. I want to remain positive and enthusiastic, not stand around and urinate on specific pet-peeve campfires that I'd like to dampen. Long laborious posts with multiple web links are simply exhausting and unle ss you're nearly unemployed or retired, few of us have the time to read that stuff nor is it necessary to build a safe Pietenpol. Practical, sound, proven advice is what I like to see on the Pietenpol list and for the most part we have that which has always attracted me to the li st, the airplane, and the people who build them. Simple, light, and cheap. It doesn't have to get all convoluted and complex and wordy to be safe an d fun. Here's to common sense and having fun building! MikeC. Ohio ________________________________________________________________________________
tanks vs. n
Date: Mar 25, 2014
sorry I wasn't clear so if you didn't follow my logic maybe I can try agai n. Of course the weight of a pilot matters and you must compensate for it. I was responding to the concept that if a heavier pilot is in an airplane and the fuel burns off in a front tank that the CG moves behind the aft lim it. That is not necessarily so. While that could occur the idea is to move the adjust the aircraft CG so as the fuel burns off it does not move to behind an aft CG limit and therefor e the weight of the pilot doesn't matter if you do that. That was my point. When you complete an airplane you make sure by calculation that the aircraf t stays in the CG range with a certain pilot weight. If you design it for y ou and you are 200 lbs then you adjust the aircraft to fly safely by three of the methods I mentioned. I weigh over 200 and this in not a problem in m y aircraft. So to my original point. You have a moveable object in the aircraft=2C tha t for argument sake=2C weighs 25 lbs (in this case - tank plus reserve fue l) and you move it forward the CG moves forward. Add another 75 lbs of fuel and it has even a bigger effect. Yes a tank directly on the CG it has less effect on trim=2C but if you have an AFT CG problem then moving it forward helps this problem. Likewise if you had a forward GC problem you would wa nt to shift weight back. Pietenpol`s with A65 continentals typically have this problem that require s a long engine mount and moving the wing back or both. Both changes reduce s the directional stability of the airplane. Add a heavy center section win g tank and the problem gets bigger. I have seen three Piets with this problem. These are extreme examples. Two of them moved the pilot to the front seat and made a two seater into a one seater. The third had a about 25 lbs bolted to the engine. Then there was the guy that was flying at 22.2 ins behind the leading edge - he sold it b ecause he knew he was going to kill himself! The new buyer fixed the proble m by moving the wing. > Subject: Pietenpol-List: Re: Speaking of outdated stuff? Center section f uel tanks vs. n > From: jarheadpilot82(at)hotmail.com > Date: Tue=2C 25 Mar 2014 06:11:46 -0700 > To: pietenpol-list(at)matronics.com > tmail.com> > > Brian=2C > > I am not getting your logic- > > "Your weight has nothing to do with it. You simply don't fly if there is an aft CG and having the fuel in the wing just makes the problem worse." > > Fuel in the wing makes it worse? How is that? Fuel in the wing sits close r to the CG than fuel in the nose=2C and the burn off affects CG less=2C no t more the closer it is to the aircraft's CG. > > "Running out of fuel (or nearly running out of fuel) in a nose tank versu s the same in a wing tank (or nearly running out of fuel) cannot make the s ituation worse. If the fuel is gone it is gone. The difference that in a no se tank is that any fuel moves the CG forward at everything but empty. Sinc e no one can fly on empty it is always better in the nose than in the wing and the amount of weight added to the nose=2C the length of the engine moun t or the amount the wing is moved back is less and on average the cg is mor e forward. There is also the 15lbs or more of the tank weight itself that i s helpingthe aft cg problem all they time. The 10 lbs (or whatever you cons ider that to be) of reserve fuel that no one ever uses is also helping. " > > Brian=2C I am not worried about the fuel that is left in the nose tank. I am worried about the fuel that burned off that was=2C at one time=2C forwa rd of the CG that was balancing against my fat butt sitting behind the CG. Once that fuel has burned off=2C there is less weight to counteract my fat butt=2C so the CG moves aft. Check your aerodynamics and design books. I ju st don't want to move it so far aft=2C that the airplane is aft of the safe aft CG. That can be mitigated in the construction phase by adjustment of t he wing location=2C and all I am saying is that that issue should be dealt with in the build. Nobody should fly an airplane outside of the CG range. W ill the airplane fly? Yes. Are your options lessened when you do? Absolutel y. > > "If you weigh more and it is your airplane then it is more important that the fuel is forward." > > It is most important that the CG is balanced=2C and the aircraft is flown in the proper CG range. > > -------- > Semper Fi=2C > > Terry Hand > Athens=2C GA > > USMC=2C USMCR=2C ATP > BVD DVD PDQ BBQ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420985#420985 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Mar 25, 2014
tanks vs. n If I may...=0A=0AHere is how I am looking at both views on wing-V-nose fuel tanks... solely looking at weight, not the pros and cons. of having fuel o ver your head, ease of fueling, fuel line length, etc.=0A---- If we use an imaginary Pietenpol with a wing mounted fuel tank with it's various CG scenarios, etc. then move said tank to the nose, keeping everything the same, (which is easy with an imaginary plane)...what do we notice?- One point of view, I believe, looks at the static differences...now you have th e weight of the tank moved forward along with the weight of the unusable fu el...all pluses on a usually tail heavy plane. These are somewhat static ch anges, as much as a longer engine mount or the moving of the landing gear. When viewed from a dynamic point, fuel weight change in a wing mounted tank has little effect on C.G.- In the nose tank, with the longer arm, the dy namic fuel weight change has a greater effect than the wing tank, again, in our keeping-everything-else-the-same Pietenpol. So is it best to have a co rrect static, on paper, C.G.; or a- correct, dynamic, in flight C.G? From here you can forget about leaving the two imaginary planes the same and start to look at the other variables...climbing ladder s, having fuel over your head, tank damage with nose damage, fuel head, fue l pressure...and the various other points brought up so far. Now the "corre ct" answer starts to get complicated and it is here, the builder needs to m ake some potentially tough decisions.=0A=0ASomething else, I thought about, which may or my not matter:=0A--- A wing mounted tank does have an a rm of sorts, along the longitudinal axis. In a roll, the wing tank has an a rm greater than the nose tank. It is a weight, being swung around the longi tudinal axis. Does this matter, does it effect stability? What, if anything , changes as fuel burns? =0A=0A=0AI don't have any answers, but I do have a nose tank and for now, I'll give it a try.=0A=0A=0AIf God is your co-pilot ...switch seats.=0AMike Perez=0AKaretakerAero=0ASTILL Building...=0A ________________________________________________________________________________
Subject: Re: Speaking of outdated stuff? Center section fuel tanks
vs. n
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Mar 25, 2014
Mike, Thanks for your response. You are doing what all builders should do- read, study, analyze then decide. That is much better than building based on empirical data. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421000#421000 ________________________________________________________________________________
Date: Mar 25, 2014
tanks vs. n
Mike, What you want to determine are extremes of the CG range of your aircraft, and ensure they fall within the recommended limits of the design (with aft CG admittedly being more of a concern with the Pietenpol). You would establish the most adverse aft condition by calculating the CG for zero usable fuel and pilot only......that will be the condition you could find yourself in, in flight, that would present the most aft CG. You can add fuel and pax to determine your most forward CG condition. The passenger should not have much effect, as they are under the wing....and as has been pointed out, the fuel in a fuselage tank will have more effect than the wing tank. As long as you setup your Pietenpol so that it's most forward and aft conditions fall within the recommended limits, then the shifting CG as fuel burns off should not be a safety concern. Ryan On Tue, Mar 25, 2014 at 10:14 AM, Michael Perez wrote: So is it best to have a correct static, on paper, C.G.; or a correct, dynamic, in flight C.G? ________________________________________________________________________________
Date: Mar 25, 2014
tanks vs. n If I had to do it again, I would seriously consider a wing tank only. I do like the "pros." of the wing tank and for me, I may still need a ladder even with a nose tank...I need access to that storage area on the wing the fuel tank left behind... If God is your co-pilot...switch seats. Mike Perez KaretakerAero STILL Building... ________________________________________________________________________________
vs. n
Date: Mar 25, 2014
Both the MD 11 and Airbus A330 put fuel in the VERT STAB to help CG issues! In the A330, we just get occasional messages as to what it's doing... nice how it keeps us in the loop... Geesh Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421004#421004 ________________________________________________________________________________
vs. n
Date: Mar 25, 2014
Mike, Ryan explained it much better than I, so I will simply say, "Yeah. What he said". -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421005#421005 ________________________________________________________________________________
Date: Mar 25, 2014
tanks vs. n Understood Ryan, thanks.- This is good intel. for me to have because I be lieve I will forgo renting a hangar and do my "final" assembly at home this summer. Of course it will need to come apart again, but at least I can do my W&B, figure out wing location, fabricate diagonal braces, cowling around braces, wing cross cables...etc... =0A=0A=0AIf God is your co-pilot...swit ch seats.=0AMike Perez=0AKaretaker Aero=0ASTILL Building...=0A ________________________________________________________________________________
Date: Mar 25, 2014
tanks vs. n Real time messages in the cock pit? Like: "Hello pilots, fuel in the vert. stab. has been depleted and the CG is whacked. You may want to turn on the seatbelt signs."- =0A=0ALike Mario...just playin'.=0A=0A=0AIf God is your co-pilot...switch seats.=0AMike Perez=0AKaretaker Aero=0ASTILL Building... =0A ________________________________________________________________________________
vs. n
Date: Mar 25, 2014
Terry - To answer your specific question to me: I'm using a wing tank again. 16 gallons this time. A fuselage tank sits in the lap of the passenger. In my accident, a fuselage tank would have resulted in more fuel nearer to me after impact than was the case with the wing tank. Had there been a fire I would've likely died in either scenario. The fuel spill situation was not good after the crash, but it was better than if I'd had a fuselage tank. -------- Kevin "Axel" Purtee Rebuilding NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421010#421010 ________________________________________________________________________________
vs. n
Date: Mar 25, 2014
Closer to that than you may like to realize! Seriously. We can't transfer it willingly, but it can. Just weird. I mean, talk about excess complexity, wow. Of course we're never taught how the thing decides whether it needs to move fuel around for CG reasons. Computed using how much trim is actually being used vs what should be being used based on flight testing or something I imagine. Isn't like we can mess up the system, because like my Piet, it doesn't even HAVE a trim button! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421011#421011 ________________________________________________________________________________
Subject: here's an idea for risk mitigation strategies---and for
us full figured girls
Date: Mar 25, 2014
Bernie would have spit nickels hearing this kind of lingo that seems to be so popular these days but here's an idea to increase safety and decrease risk---use an engine that ha s a good reliability record, no matter what homebuilt you're using. Just throwing that one out there; ) Mike C. PS-and being a bit on the full-figured size like I am, (205 pounds) the we ight of the nose fuel really helps my CG situation in all phases of flight except when I'm down to 2 gallons in the tank and I never go that low. My experience with CG vs. fuel burn is exactly what Brian Kenney posted. It sure is great to have all that luggage space in the wing center section too! Again, the bottom line is to use whatever fuel tank position you think is b est for you----and just because it is a very old design doesn't mean is isn't perfectly good to use today but like William Wynne pr ofesses.....there are newer, other ways to do things now days no matter how old those plans are or the Tony Bingelis books are b ut both are chock full of good stuff that still works today! My new Facebook profile photo..... -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of kevinpurtee Sent: Tuesday, March 25, 2014 12:52 PM Subject: Pietenpol-List: Re: Speaking of outdated stuff? Center section fue l tanks vs. n --> > Terry - To answer your specific question to me: I'm using a wing tank again . 16 gallons this time. A fuselage tank sits in the lap of the passenger. In my accident, a fuselage tank would have resulted in more fuel nearer t o me after impact than was the case with the wing tank. Had there been a f ire I would've likely died in either scenario. The fuel spill situation wa s not good after the crash, but it was better than if I'd had a fuselage ta nk. -------- Kevin "Axel" Purtee Rebuilding NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421010#421010 ________________________________________________________________________________
Subject: Re: here's an idea for risk mitigation strategies---and
for us f
Date: Mar 25, 2014
Mike, I know Mr. Pietenpol (I never knew him, so I respectfully call him Mr. Pietenpol) didn't use the word risk management as nobody did most likely in the 1930s. However I am sure he did use the word safe. I think he would be happy that people were talking about methods to build a "safer" airplane. So I don't think he would spit nickels over the idea of building safe airplanes, and talking about building safe airplanes. By the way, what did you mean by reliable engine? Is that a veiled way of saying certificated engine? Define reliable. Don't throw the word out there without being more specific. I know that most likely means a lengthy discussion, but I think the forum can handle it if it is a knowledgeable discussion. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421014#421014 ________________________________________________________________________________
Date: Mar 25, 2014
isn't outdated at all, even wing cc tanks! ..."The main point is that I want to bring to this list a sense of encourag ement, not discouragement. =0AI want to remain positive and =0Aenthusiastic , not stand around and urinate on specific pet-peeve =0Acampfires that I =99d like to dampen."=0A=0AI agree Mike.=C2- Not that disagreements wo n't happen, but they can be handled in a way to=C2- be encouraging rather then discouraging. =0A=0ASorry for the delay guys, I flew through some pos ts initially, (busy day) and am just going back=C2- through getting caugh t up.=C2-=0A=0AIf God is your co-pilot...switch seats.=0A=0AMike Perez=0A KaretakerAero=0ASTILL Building...=0A ________________________________________________________________________________
Date: Mar 25, 2014
tanks vs. n "Best of luck....share some pics and show it off once you've got it together." I'll definitely give that some thought! My plan from the start was too keep things under tight wraps until complete and unveil the ship in all its glory, (or lack of) once it has flown. But it is difficult not to post more pictures now rather than later. If God is your co-pilot...switch seats. Mike Perez KaretakerAero STILL Building... ________________________________________________________________________________
Subject: what is reliable?
Date: Mar 25, 2014
http://www.eaa.org/news/2010/homebuilts_report_wanttaja.pdf Terry-see pa ge 6 which compares factory built engine failures to homebuilt engine failu res then you decide which is more reliable. You're a smart guy with 2 jobs and lots of time to read all this stuff so I won't take time to explain it. and also.... Terry Hand writes: Mike, I know Mr. Pietenpol (I never knew him, so I respectfully call him Mr. Piet enpol) didn't use the word risk management as nobody did most likely in the 1930s. However I am sure he did use the word safe. I think he would be hap py that people were talking about methods to build a "safer" airplane. So I don't think he would spit nickels over the idea of building safe airplanes , and talking about building safe airplanes. Well Terry you might read a lot but you completely misread what I wrote and misquoted me. What I said Bernie would spit nickels about is 'this kind of lingo' not building safe airplanes. See below. You'd make a great journalist! Bernie would have spit nickels hearing this kind of ling. ________________________________________________________________________________
Subject: Re: what is reliable?
Date: Mar 25, 2014
That study offers nothing useful for helping someone to decide whether to use a "traditional" engine over a "non traditional" engine other than "may" and "probably" coupled with the fact "non traditional" engines rarely get any useful post accident attention like "traditional" engines do, though one of the higher classifications associated therewith usually restart and run well after the crash... "DOES pose increased risk". Wow. I'll take that to the bank... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421018#421018 ________________________________________________________________________________
Date: Mar 25, 2014
Mike, I sense the smart a-- coming out in you. I read what you wrote. Could it be possible that your point was not made clear, rather than your premise that I don't know how to read? Or maybe you were just throwing a little sarcasm out there. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421020#421020 ________________________________________________________________________________
Subject: I Googled that for you---engine reliability
Date: Mar 25, 2014
Perhaps someone out there has a better source for determining what defines a 'reliable engine' but I thought I'd defer to the NTSB Accident reports and FAA registration d atabase data which has been summarized here in this article. You're all really intelligent, accompli shed folks out there so you read, you decide..... nose tank or wing tank, conventional aircraft engine or auto engine, 3-pi ece wing or single piece wing, blue and white or red and white? Mike C. Ohio http://www.kitplanes.com/magazine/miscellaneous/8485-1.html Auto Engines Versus Traditional Certified Engines One of the oldest controversies in the homebuilt world is the use of conver ted auto engines. Unfortunately, we cannot come up with an overall accident rate based on engine type. Sure, the FAA registration database lists hundr eds of homebuilts as powered by Volkswagens, Subarus, Fords, etc., but thou sands more are listed as mounting AMA/EXPR engines. We don't know how many of these have Lycomings or Continentals at their core, or those that sprang from GM or Subaru, so we can't reliably calculate an overall rate. However, most NTSB accident reports list the type of engine. We can easily determine how often a loss of power was the cause of the accident, and comp are the rates for traditionally powered aircraft with those mounting auto-e ngine conversions. Obviously, a higher percentage means a higher relative n umber of engine failures. While we're at it, let's show the two-stroke engine results as well. Traditional Aircraft Engines: 12.2% Two-Stroke Engines: 28.9% Auto Engine Conversions: 30.5% The differences are even more striking when only fixed-wing homebuilts are included: Traditional Aircraft Engines: 12.3% Two-Stroke Engines: 32.8% Auto Engine Conversions: 37.5% So, if a fixed-wing homebuilt has an accident, the probability is three tim es higher that the engine was the cause of the accident if an auto-engine c onversion was installed! (Please note, this does not mean it has an accident rate that is three time s higher. Fewer than 20% of homebuilt accidents involve problems with the e ngine, and not all of those are directly the engine's fault.) For years, auto-engine naysayers claimed that the internals of the engines were more prone to failure than traditional engines. A comparison of engine -failure causes in Figure 5 (on Page 28) indicates otherwise. Auto engines seem to suffer from internal problems at a lower rate than traditional airc raft powerplants. However, auto engines are worse in three major areas: ignition systems, coo ling systems and reduction drives. The need for a reduction drive on most a uto-engine conversions provides a failure source that the traditional engin es don't generally face (the 0.7% shown in Figure 5 is a single accident in volving the drivetrain on a helicopter). Neither do traditional engines hav e external cooling systems-though some of those internal failures may well be due to poorly baffled engines. The water pumps, belts, hoses and radiato rs on many auto conversions provide another failure source the traditional certified engines avoid by design. The biggest difference is in ignition system failures: Auto engines suffer them four times as often as conventional aircraft. Sure aircraft magnetos a re primitive, and individually they are probably less reliable than a moder n electronic ignition. But the vast majority of homebuilts with Lycomings a nd Continentals carry two magnetos that are completely independent of any o ther aircraft system. Several of the ignition failures in auto conversions were due to electrical power problems with electronic ignitions. Electrical systems do fail, so a completely independent backup power source is vital. ________________________________________________________________________________
Subject: Re: I Googled that for you---engine reliability
Date: Mar 25, 2014
It's awfully long to read, Mike... -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421022#421022 ________________________________________________________________________________
Subject: long to read!
Date: Mar 25, 2014
It's awfully long to read, Mike... Ahahha! Terry-you actually made me laugh! Good one. Gosh....I think I may like you (just a little) after all! See.....you do have a sense of humor in there. Did you like my fat guy photo? That was meant to make people laugh and e njoy our list. You just made me laugh-thank you. Now get out to the shop and start working on your airplane:) ! Mike C. Ohio ________________________________________________________________________________
Date: Mar 25, 2014
Mike, Thanks for posting this. To me, the discussion of typical failure modes for auto conversions -- when considering the Corvair option -- was reassuring. With the Corvair, there's no reduction unit and the cooling setup is typical of lots of aircraft designs. Of the three biggies discussed in the article, that leaves only the ignition as a major concern. The current state of the art on ignitions for Corvairs would seem to eliminate many of the gotchas of ignition systems on auto conversions. I've posted previously my rationale for choosing to mount a Corvair on my Piet (available via an archive search). I can also see the rationale for small Continentals and would seriously consider one of those if I lived and flew closer to sea level. Parenthetically, it seems time for folks to go back to playing nice with one another on this list. There's plenty of room for disagreement. No need to be disagreeable when doing so. Cheers, Ken On Tue, Mar 25, 2014 at 1:32 PM, Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] wrote: > Perhaps someone out there has a better source for determining what > defines a 'reliable engine' > but I thought I'd defer to the NTSB Accident reports and FAA registration > database data which has been > summarized here in this article. You're all really intelligent, > accomplished folks out there so you read, you decide..... > nose tank or wing tank, conventional aircraft engine or auto engine, > 3-piece wing or single piece wing, blue and white > or red and white? > > Mike C. > Ohio > > *http://www.kitplanes.com/magazine/miscellaneous/8485-1.html*> > > > *Auto Engines Versus Traditional Certified Engines * > > One of the oldest controversies in the homebuilt world is the use of > converted auto engines. Unfortunately, we cannot come up with an overall > accident rate based on engine type. Sure, the *FAA registration database*lists hundreds of homebuilts as powered by Volkswagens, Subarus, Fords, > etc., but thousands more are listed as mounting AMA/EXPR engines. We don't > know how many of these have Lycomings or Continentals at their core, or > those that sprang from GM or Subaru, so we can't reliably calculate an > overall rate. > > However, *most NTSB accident reports* list the type of engine. We can > easily determine how often a loss of power was the cause of the accident, > and compare the rates for traditionally powered aircraft with those > mounting auto-engine conversions. Obviously, a higher percentage means a > higher relative number of engine failures. > > While we're at it, let's show the two-stroke engine results as well. > > Traditional Aircraft Engines: 12.2% > Two-Stroke Engines: 28.9% > Auto Engine Conversions: 30.5% > > *The differences are even more striking when only fixed-wing homebuilts > are included:* > > * Traditional Aircraft Engines: 12.3% * > * Two-Stroke Engines: 32.8% * > * Auto Engine Conversions: 37.5%* > > So, if a fixed-wing homebuilt has an accident, the probability is three > times higher that the engine was the cause of the accident if an > auto-engine conversion was installed! > > (Please note, this does not mean it has an accident rate that is three > times higher. Fewer than 20% of homebuilt accidents involve problems with > the engine, and not all of those are directly the engine's fault.) > > For years, auto-engine naysayers claimed that the internals of the engines > were more prone to failure than traditional engines. A comparison of > engine-failure causes in Figure 5 (on Page 28) indicates otherwise. Auto > engines seem to suffer from internal problems at a lower rate than > traditional aircraft powerplants. > > However, auto engines are worse in three major areas: ignition systems, > cooling systems and reduction drives. The need for a reduction drive on > most auto-engine conversions provides a failure source that the traditional > engines don't generally face (the 0.7% shown in Figure 5 is a single > accident involving the drivetrain on a helicopter). Neither do traditional > engines have external cooling systems--though some of those internal > failures may well be due to poorly baffled engines. The water pumps, belts, > hoses and radiators on many auto conversions provide another failure source > the traditional certified engines avoid by design. > > The biggest difference is in ignition system failures: Auto engines suffer > them four times as often as conventional aircraft. Sure aircraft magnetos > are primitive, and individually they are probably less reliable than a > modern electronic ignition. But the vast majority of homebuilts with > Lycomings and Continentals carry two magnetos that are completely > independent of any other aircraft system. > > Several of the ignition failures in auto conversions were due to > electrical power problems with electronic ignitions. Electrical systems do > fail, so a completely independent backup power source is vital. > > > * > > > * > > ________________________________________________________________________________
Date: Mar 25, 2014
I'll summarize it for you. Auto engine conversions have less internal failures, but more ignition system, cooling and gear reduction failures. At that level of specificity, it's qualitative not quanitative. Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=421025#421025 ________________________________________________________________________________
vs. n
Date: Mar 25, 2014
I must apologize for posting erroneous information. The same mass acting on the same moment arm will produce the same moment on any airplane, but it will NOT result in the same shift in the CG on every airplane. Consider the extremes: my 16 gallon fuel tank on a moment arm a couple of feet long will produce a certain moment and will result in a shift of my CG by a certain amount (couple of inches). If I place that same fuel tank the same distance away from the CG of a Boeing 777, the CG will not shift perceptibly. If I place that same fuel tank the same distance away from the CG of a child's balsa glider... well, you get the idea. You have to calc it for YOUR airplane to determine how much the CG will shift as you burn fuel off. I would also encourage anyone who does a W&B on their aircraft to use the wing leading edge as the datum. The reason that I've heard most often for using the face of the prop hub is so that all of the moments are positive and the math is simplified since there are no negative numbers to deal with. Using the firewall may make things easier to measure since the firewall is big, flat, and convenient. However, you still need to drop a line from the leading edge to reference it in the calculations, so why not use the LE? [Abstract thought: using only positive numbers means you throw away almost HALF the entire universe of numbers just because they are negative. It sounds like discrimination to me, and a waste of good numbers.] -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421028#421028 ________________________________________________________________________________
Subject: Re: long to read!
Date: Mar 25, 2014
Been working on the horizontal stab today. Got it glued up on the jig. Glad my casein glue, I mean T88:wink:, works in these temperatures in Georgia. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421029#421029 ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Date: Mar 25, 2014
Weeeelllll, I'm not sure about the interpretation of those data, not becaus e they are wrong and not because you or Ron Wanttaja are wrong. It's just n ot clear to me that the data available from FAA speak directly to engine fa ilures per se versus what I think of as "systems failures" that directly im pinge on engine reliability/performance. Of the engine failures at 2GA9 for which I have direct knowledge, two were Continental O-300s with stuck valves, one that resulted in short final thro ugh the pine trees (literally) and the other with an off-field landing (nob ody hurt in either one). Another was a Continental C-85 with stuck valve th at resulted in a mid-field 'lawn dart' landing with substantial airframe da mage and minor injury to pilot. A fourth was a Lycoming IO-360 that holed a piston and resulted in a long glide that ended with a near-perfect outcome (just made the field). So, all four of those were certified engines, all f our had true engine failures. Of the experimentals, one went down off-field due to improper induction/fuel system design. Another was a Jabiru 3300 th at blew a hole in the oil pump cover. The final was a 2-stroke that crashed on field due to the carb falling off the engine (!), killing the pilot rig ht in front of his family. So, only one of the three experimental engines i tself failed. I realize that many anecdotes don't make data, but these exam ples illustrate the point that what gets termed "engine failure" may not be failure of the engine itself, but rather a failure to provide to the engin e that which keeps it running: fuel, spark, or air. -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine From: <Cuy>, "LLC]" <michael.d.cuy(at)nasa.gov<mailto:michael.d.cuy(at)nasa.gov>> >" > Date: Tuesday, March 25, 2014 2:48 PM etenpol-list(at)matronics.com> Subject: Pietenpol-List: what is reliable? http://www.eaa.org/news/2010/homebuilts_report_wanttaja.pdf Terry=97see page 6 which compares factory built engine failures to homebuilt engine fai lures then you decide which is more reliable. You=92re a smart guy with 2 jobs and lots of time to read a ll this stuff so I won=92t take time to explain it. and also=85. Terry Hand writes: Mike, I know Mr. Pietenpol (I never knew him, so I respectfully call him Mr. Piet enpol) didn't use the word risk management as nobody did most likely in the 1930s. However I am sure he did use the word safe. I think he would be hap py that people were talking about methods to build a "safer" airplane. So I don't think he would spit nickels over the idea of building safe airplanes , and talking about building safe airplanes. Well Terry you might read a lot but you completely misread what I wrote and misquoted me. What I said Bernie would spit nickels about is =91this kind of lingo=92 not building safe airplanes. See below . You=92d make a great journalist! Bernie would have spit nickels hearing this kind of ling. ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
vs. n
Date: Mar 25, 2014
Abstractly speaking, Maybe more than half? Don't imaginary numbers come the square roots of negatives? Just sayin' Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421031#421031 ________________________________________________________________________________
Subject: Airplane Weights
Date: Mar 25, 2014
Good discussion thread on Weight and Balance. I have just received my packa ge from Doc Mosher with WWs articles. Well documented info on CG and axle l ocation. Keeping the CG location in mind as I build will have a high priori ty. I have much more to study and learn. The CG spreadsheets recently poste d are also valuable tools. New question for some of you who have finished and flown your plane regardi ng the total weight of the plane. Like everyone=2C I want to be careful of adding unnecessary weight as I bui ld. So far I am following the plans carefully. But like everyone=2C I am su re=2C I have some personal customizations in the back of my mind. WWs articles document specific data from individual planes. I pulled a hand ful of them to examine more closely regarding Empty Weight (EW) - long/shor t fuselage=2C A65/Corvair engines. The lightest weight airplane I studied w as 590lb=2C the heaviest 842lb. Subtracting a 'standard' engine weight from the EW yielded some interesting information. In most cases=2C regardless o f the engine type or fuse. length=2C the weight of 'everything else' came o ut to about 410-415lb. In only 2 cases I examined was there a great differe nce - one was 581lb and the other 617lb. Not just over=2C but WAY over the others. Here's the question: What in the world do some builders add to their plane s that takes a 400 lb plane to over 600 lb?? OK. Some extra instrumentation=2C tailwheel vs the original tailskid=2C bra kes system=2C extra fuel tank=2C etc. But 200lb worth? What do I need to lo ok out for? Thanks for the replies. Lorenzo ________________________________________________________________________________
Subject: Re: Steel-tube fuselage update - landing gear welded
Date: Mar 25, 2014
Hello good Piet-ple, Terry, I plan to uses springs. Regarding the "cross-member" that has had some failures, see the RED tube in the attached image. I plan to add a second tube next to the red tube. This second tube will be 0.75" diameter with 0.065" wall thickness. I am going to have it welded about an inch away form the existing tube. This is less than the ideal solution which would be to use a MUCH stronger tube in that location in the first place. What at least three owners have found is that the RED tube is an un-supported two-foot tube which collapses in compression during a hard landing. See the additional attached drawing which shows that in a hard landing the inertia of the wings drives a force down the struts to the landing gear fitting - while at the same time a force is driven up through the landing gear struts to that same fitting. These forces compress the cross-member and with it "per plans" (only a 0.035" 5/8" tube) it cannot take the load and the un-supported two foot member buckles. This also buckled the sides in a couple inches and ripped up the floorboards. If I was to do this from scratch I would use a MUCH thicker wall 0.075" diameter tube instead of "sistering" another tube alongside the first one, but my cluster joints are already welded and it should be easier at this time to simply add another tube rather than cut up my completed cluster joint. Although, there have been no failures (that I am aware of) in the AFT landing gear (green) cross member location (it is supported mid-span by the "vee" brace), I plan to add another tube there as well. Hope this helps..... Jake -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421036#421036 Attachments: http://forums.matronics.com//files/cross_member_crush_920.jpg http://forums.matronics.com//files/steel_tube_fuselage_cross_member_128.jpg ________________________________________________________________________________
vs. n
Date: Mar 25, 2014
I am a new guy so to speak so my opinion probably won't mean much. But here I go. I'm building my piet with the center section tank like the plans call for. If I wanted more endurance I would add a little header tank, but I don't think I want it. As far as safety goes , I feel just as safe with a wing tank over my head, as a nose tank sitting over the passengers legs. Many years ago when piper entered the crop-duster business with the Pawnee, they built them with a nose tank sitting right behind the engine made of fiberglass no less. I've met a few of the guys that flew them and not a few have horrible burn scars on their faces. The first thing that happened at a crash, which is not infrequent in a cropduster, was that the fuel tank was crushed between the chemical hopper and the engine and a fire. Piper learned after awhile and started building them with wing tanks. Now I admit they were a low wing aircraft so the location was lower and along side the cockpit but not as many caught fire. Maybe the center section location is not the safest place for fuel but unless you plan on building tip tanks I think it is just as safe as the nose. That is my two cents worth. And I love all you guys, Well maybe love is not the right word. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421038#421038 ________________________________________________________________________________
Date: Mar 26, 2014
Trouble-maker... -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine On 3/25/14 5:01 PM, "jarheadpilot82" wrote: > > >Been working on the horizontal stab today. Got it glued up on the jig. >Glad my casein glue, I mean T88:wink:, works in these temperatures in >Georgia. > >-------- >Semper Fi, > >Terry Hand >Athens, GA > >USMC, USMCR, ATP >BVD DVD PDQ BBQ > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=421029#421029 > > ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Mar 25, 2014
If you mean me, Jeff, I have been called much worse. [Laughing] -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421040#421040 ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Mar 25, 2014
Lorenzo, My Pietenpol came in at 745 lbs., which was about 80 lbs more than I was expecting. I believe most of that extra weight was in the paint that I chose, PolyFiber's Aerothane polyurethane. It is very heavy, and difficult to paint. I ended up putting several coats on the fuselage before I got a decent finish with a minimum of orange peel. The only way to get it off is to sand it off, and I know I didn't sand all the extra coats off. The wire wheels are also heavy, weighing (with tires and brakes) 25 lbs apiece. And the straight axle weighs quite a bit as well. The battery and the avionics add a bit but not as much as you'd think, and I was expecting the weight they added (my original estimate, including the electrical stuff was 660 lbs, which would be a decent weight). End result? Mine doesn't climb too well with a heavy load. I limit myself to carrying passengers weighing no more than 180 lbs. The benefit of this is, I can limit my passengers to pretty young women for the most part. Simplicate and add lightness! Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of larharris2 Harris Sent: Tuesday, March 25, 2014 6:37 PM Subject: Pietenpol-List: Airplane Weights Good discussion thread on Weight and Balance. I have just received my package from Doc Mosher with WWs articles. Well documented info on CG and axle location. Keeping the CG location in mind as I build will have a high priority. I have much more to study and learn. The CG spreadsheets recently posted are also valuable tools. New question for some of you who have finished and flown your plane regarding the total weight of the plane. Like everyone, I want to be careful of adding unnecessary weight as I build. So far I am following the plans carefully. But like everyone, I am sure, I have some personal customizations in the back of my mind. WWs articles document specific data from individual planes. I pulled a handful of them to examine more closely regarding Empty Weight (EW) - long/short fuselage, A65/Corvair engines. The lightest weight airplane I studied was 590lb, the heaviest 842lb. Subtracting a 'standard' engine weight from the EW yielded some interesting information. In most cases, regardless of the engine type or fuse. length, the weight of 'everything else' came out to about 410-415lb. In only 2 cases I examined was there a great difference - one was 581lb and the other 617lb. Not just over, but WAY over the others. Here's the question: What in the world do some builders add to their planes that takes a 400 lb plane to over 600 lb?? OK. Some extra instrumentation, tailwheel vs the original tailskid, brakes system, extra fuel tank, etc. But 200lb worth? What do I need to look out for? Thanks for the replies. Lorenzo ________________________________________________________________________________
Date: Mar 26, 2014
;) -- Jeff Boatright On 3/25/14 8:58 PM, "jarheadpilot82" wrote: >If you mean me, Jeff, I have been called much worse. [Laughing] ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Mar 25, 2014
I like pretty young women . . . From: jack(at)bedfordlandings.com Subject: RE: Pietenpol-List: Airplane Weights Date: Tue=2C 25 Mar 2014 21:40:51 -0400 =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A Lorenzo=2C=0A =0A =0A =0A My Pietenpol came in at 745 lbs.=2C which=0A was about 80 lbs more than I was expecting. I believe most of that extra =0A weight was in the paint that I chose=2C PolyFiber=92s Aerothane=0A polyurethane. It is very heavy=2C and difficult to paint. I ended up=0A putting several coats on the fuselage before I got a decent finish with a =0A minimum of orange peel. The only way to get it off is to sand it off=2C an d=0A I know I didn=92t sand all the extra coats off. The wire wheels are=0A also heavy=2C weighing (with tires and brakes) 25 lbs apiece. And the stra ight=0A axle weighs quite a bit as well. The battery and the avionics add a bit=0A but not as much as you=92d think=2C and I was expecting the weight they add ed=0A (my original estimate=2C including the electrical stuff was 660 lbs=2C whic h would=0A be a decent weight).=0A =0A =0A =0A End result? Mine doesn=92t climb=0A too well with a heavy load. I limit myself to carrying passengers=0A weighing no more than 180 lbs. The benefit of this is=2C I can limit my=0A passengers to pretty young women for the most part.=0A =0A =0A =0A Simplicate and add lightness!=0A =0A =0A =0A Jack Phillips=0A =0A NX899JP=0A =0A Smith Mountain Lake=2C Virginia=0A =0A ________________________________________________________________________________
Date: Mar 25, 2014
Thanks for the input. I'm strongly considering Oratex fabric - so I don't n eed no stinkin' paint. Lorenzo From: jack(at)bedfordlandings.com Subject: RE: Pietenpol-List: Airplane Weights Date: Tue=2C 25 Mar 2014 21:40:51 -0400 =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A Lorenzo=2C=0A =0A =0A =0A My Pietenpol came in at 745 lbs.=2C which=0A was about 80 lbs more than I was expecting. I believe most of that extra =0A weight was in the paint that I chose=2C PolyFiber=92s Aerothane=0A polyurethane. It is very heavy=2C and difficult to paint. I ended up=0A putting several coats on the fuselage before I got a decent finish with a =0A minimum of orange peel. The only way to get it off is to sand it off=2C an d=0A I know I didn=92t sand all the extra coats off. The wire wheels are=0A also heavy=2C weighing (with tires and brakes) 25 lbs apiece. And the stra ight=0A axle weighs quite a bit as well. The battery and the avionics add a bit=0A but not as much as you=92d think=2C and I was expecting the weight they add ed=0A (my original estimate=2C including the electrical stuff was 660 lbs=2C whic h would=0A be a decent weight).=0A =0A =0A =0A End result? Mine doesn=92t climb=0A too well with a heavy load. I limit myself to carrying passengers=0A weighing no more than 180 lbs. The benefit of this is=2C I can limit my=0A passengers to pretty young women for the most part.=0A =0A =0A =0A Simplicate and add lightness!=0A =0A =0A =0A Jack Phillips=0A =0A NX899JP=0A =0A Smith Mountain Lake=2C Virginia=0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A ________________________________________________________________________________
Subject: Re: Airplane Weights
Date: Mar 25, 2014
Hi Lorenzo I looked at the Oretex website. When checking prices, I became discour aged when all they said was "compared to other finishing systems, the cost o f spray guns, compressor setting up a booth...blah blah blah Oretex is compa rable to other finishing systems". Please cut to the chase. Here. What doe s it cost to cover a pietenpol? Anytime a supplier hides behind a bunch of B S , I run the other direct ion. The concept is interesting, however Thanks Glen Sent from my iPhone > On Mar 25, 2014, at 7:14 PM, larharris2 Harris wrote: > > Thanks for the input. I'm strongly considering Oratex fabric - so I don't n eed no stinkin' paint. > > Lorenzo > > > From: jack(at)bedfordlandings.com > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Airplane Weights > Date: Tue, 25 Mar 2014 21:40:51 -0400 > > Lorenzo, > > > > My Pietenpol came in at 745 lbs., which was about 80 lbs more than I was e xpecting. I believe most of that extra weight was in the paint that I chose , PolyFiber=99s Aerothane polyurethane. It is very heavy, and difficu lt to paint. I ended up putting several coats on the fuselage before I got a decent finish with a minimum of orange peel. The only way to get it off is to sand it off, and I know I didn=99t sand all the extra coats off. T he wire wheels are also heavy, weighing (with tires and brakes) 25 lbs apiec e. And the straight axle weighs quite a bit as well. The battery and the a vionics add a bit but not as much as you=99d think, and I was expectin g the weight they added (my original estimate, including the electrical stuf f was 660 lbs, which would be a decent weight). > > > > End result? Mine doesn=99t climb too well with a heavy load. I lim it myself to carrying passengers weighing no more than 180 lbs. The benefit of this is, I can limit my passengers to pretty young women for the most pa rt. > > > > Simplicate and add lightness! > > > > Jack Phillips > > NX899JP > > Smith Mountain Lake, Virginia > > > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Mar 26, 2014
Lorenzo, I did a little "dumpster diving" on the internet and found a guy's estimate from Better Aircraft Fabric for the Oratex 6000 dated September 2013. It shows the price for the 1800mmX1m material to be $134.87. I think that the Oratex 600 is slightly cheaper, but I am not 100% sure on that. Doing the Math, 1800mmX1m equals 1.8 square meters which equal 2.15 square yards, or $62.73 per square yard. The invoice shows the cost of glue tape, etc. but this is what I come up with for the price of the cloth itself. I have seen this stuff first hand at OSH and I have to say, it is as strong as you-know-what! They beat on it with a huge hammer, then took heat and pulled out the divits in the fabric right there in seconds. Really impressive stuff. I am strongly considering the use of Oratex for the same reasons you mentioned - weight savings, strength, ease of use, and savings on the cost of painting equipment. I will tell you this, though. If you want a glossy finish, then you should move on to another covering. I would not call it dull, but it definitely is not glossy. Works for me, but you may want a different look. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421046#421046 ________________________________________________________________________________
tanks vs. n
Date: Mar 26, 2014
Doesn't the wing fly the aircraft? It seems to me that you can fly a wing without a fuselage, but I'm pretty sure a fuselage ain't gonna fly without a wing. In a high wing ac, where is the longitudenal axis in relation to the wing? Remember, the wing flies the plane. Doesn't everything below it act like a pendulum? Clif Always remember to go to other people's funerals. Otherwise, they might not come to yours. Yogi Berra Something else, I thought about, which may or my not matter: A wing mounted tank does have an arm of sorts, along the longitudinal axis. In a roll, the wing tank has an arm greater than the nose tank. It is a weight, being swung around the longitudinal axis. Does this matter, does it effect stability? What, if anything, changes as fuel burns? Mike Perez ________________________________________________________________________________
Date: Mar 26, 2014
Here is my take on how you can add extra weight. In the wood there are a couple of considerations. Spars of 1" thickness=2C if not routered=2C adds if memory serves about 16 lbs of additional weight . Spruce of the optimum density is about 27 lbs/cubic foot. There are spruc e boards that are heavier than that. If you use Douglas fir I believe it is about 10% heavier. Plywood varies in weight and birch can weigh more than mahogany. Adding thickness to plywood is adding weight proportional to the extra thickness. Adding additional plywood or filler blocks adds weight . While you can add weight in the wood selection its use pales in comparison to the steel components. In contrast to spruce at 27 lb/cubic foot=2C ste el weighs 500 lbs/cubic ft. . Therefore close attention to the area and thi ckness of every metal part is very important. Using bolts and screws that a re bigger than needed adds weight. There are shear nuts that weigh less tha n full depth nuts and many nuts are used in shear. There are military nuts that are very much smaller than conventional nuts. In some locations you ca n use counter sunk heads or pan head fasteners instead of hex head bolts. B ecause it weighs so much these little things adds up. There are one or two areas that are really critical. Streamline struts of t he type used on the original Pietenpol are not available. There replacement are not longer available either. By that I mean 0.035 wall struts of small er equivalent diameter. Today much of it is 0.065 and larger equivalent dia meter and that is all you can buy new. If you use this material you can be adding 10lbs or more per strut. Do this comparison. Compare the weight of the smallest steel streamline lift strut available from Aircraft Spruce to the weight of a 1.25`` diameter 0.035`` wall 4130 round tube. You can strea mline a round tube with foam and 1 mm plywood and save on an aircraft perha ps 25 to 40 lbs. I am not sure about that but do the math. A straight axle can weigh a lot if it is 0.125`` wall but is close to half the weight if you use 0.065`` but you need ash in the center of the tubing at each end. The wood weighs much less than the extra steel. My first axle was 0.049`wall but bent it slightly on my fourth rather hard landing. I use d it for about another 3 to 5 years and it didn't bend any more but then we nt to 0.065 and it has taken many a hard landing. You must keep it short an d tight to bungees to reduce the bending moment. Adding thickness to steel parts doesn't seem that much more but 0.049 weigh s 50% more than 0.035. When substituting 4130 for mild steel you can reduce thickness of steel in some places. I did this but I won't tell you where. Don't do it if you are not knowledgeable on material strengths. I reduced s ome wood dimensions in some areas but again I am not telling where you need to figure that out. You can substitute wood for metal=2C you can use very thin plywood over the top of the fuselage. The wooden gear is lighter than the steel gear. While the wheels and tires are heavier than small aircraft wheels and tires the gear is shorter and made of wood. I think the complete assembly weighs less . My motorcycles wheels and brakes weigh 19lbs each and I think aircraft wh eels weigh about 5lbs less each. If you use big aircraft tires then the dif ference is much less. Don`t trust my memory on all of this because it has been so long=2C just do the math before making your decisions. Adding starter motors=2C alternators=2C batteries=2C cables etc and you are talking perhaps 75 to 100 lbs. The motor you select can be hugely differen t. If you use a lighter one you save. In the continental A65 there is a cas t aluminum accessory case but there is an magnesium one that weighs less. Covering and paint need to be minimum. Dacron that is 1.6 oz works fine. Weight is got to be part of the mind set. I was obsessed with it. My ELT an tenna is mounted on a wooden structure inside the fuselage and is attached with a #4 stainless steel screw. I like Burt Rutan's attitude. If you take a part and throw it up and in fal ls back down to the ground then it weighs too much. DO NOT ADD EXTRA STUFF. Wooden propeller=2C not metal. No ballast for CG correction. Very light tai l wheel with coil spring=2Cnot leaf spring. You can't use very light tailwh eel components if you move the main wheels forward . The same thing happen s if you move the wing back and don't adjust the gear position. Instruments in the passenger seat are not necessary. The Grega design adds about 100 lbs of unnecessary material=2C mostly steel and plywood. My Air Camper weighs 588 lbs with an ELT =2C a fairly heavy fire extinguish er and a first aid kit but without a portable radio and no transponder. So as I fly it normally it weighs about 600 lbs empty plus fuel plus passenge rs. My max pilot and passenger combined weight so far is 465lbs. The record empty weight of an Air Camper is over 900 lbs. Every additional 25 lbs of weight requires about one additional horsepower and the associated additional fuel capacity to feed it. It can be a few choices that make a big differences but it is usually hundr eds of decisions that add up. Hope this helps=2C good luck with your project. From: larharris2(at)msn.com Subject: Pietenpol-List: Airplane Weights Date: Tue=2C 25 Mar 2014 18:37:29 -0400 =0A =0A =0A Good discussion thread on Weight and Balance. I have just received my packa ge from Doc Mosher with WWs articles. Well documented info on CG and axle l ocation. Keeping the CG location in mind as I build will have a high priori ty. I have much more to study and learn. The CG spreadsheets recently poste d are also valuable tools. New question for some of you who have finished and flown your plane regardi ng the total weight of the plane. Like everyone=2C I want to be careful of adding unnecessary weight as I bui ld. So far I am following the plans carefully. But like everyone=2C I am su re=2C I have some personal customizations in the back of my mind. WWs articles document specific data from individual planes. I pulled a hand ful of them to examine more closely regarding Empty Weight (EW) - long/shor t fuselage=2C A65/Corvair engines. The lightest weight airplane I studied w as 590lb=2C the heaviest 842lb. Subtracting a 'standard' engine weight from the EW yielded some interesting information. In most cases=2C regardless o f the engine type or fuse. length=2C the weight of 'everything else' came o ut to about 410-415lb. In only 2 cases I examined was there a great differe nce - one was 581lb and the other 617lb. Not just over=2C but WAY over the others. Here's the question: What in the world do some builders add to their plane s that takes a 400 lb plane to over 600 lb?? OK. Some extra instrumentation=2C tailwheel vs the original tailskid=2C bra kes system=2C extra fuel tank=2C etc. But 200lb worth? What do I need to lo ok out for? Thanks for the replies. Lorenzo =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Date: Mar 26, 2014
I like how you think Brian. If God is your co-pilot...switch seats. Mike Perez Karetaker Aero STILL Building... ________________________________________________________________________________
Date: Mar 26, 2014
tanks vs. n I can't help you Clif, I have no idea.- But you bring up good points that I obviously didn't think about.--=0A-=0A=0AIf God is your co-pilot.. .switch seats.=0AMike Perez=0AKaretaker Aero=0ASTILL Building...=0A ________________________________________________________________________________
Date: Mar 26, 2014
Subject: Adding Tank to Wing
Crew, with all the fuel tank and CG posts, I have a general re-work questio n.=0A=0ACurious if anyone has, in fact, added a wing tank to an already com pleted, (built, covered, painted, cables, etc.) 3-piece wing? Maybe "added" is not the correct word. I mean replaced the nose tank with a wing tank. I would guess it would be best, (easier?) to just build a new wing from scra tch.- Since my plane is close to completion, I have no intentions on chan ging my nose tank location. But, if someday I want to make the change...has anyone done so? Maybe it is just a matter of building a new C.S.?=0A=0AJus t curious. =0A=0A=0AIf God is your co-pilot...switch seats.=0AMike Perez=0A KaretakerAero=0ASTILL Building...=0A ________________________________________________________________________________
Date: Mar 26, 2014
I haven't yet run a side by side comparison of prices. There is no doubt th at Oratex is more expensive. But the savings in time=2C tools=2C and weight are of great interest to me. I am expecting at least a 50lb savings in wei ght. This is worth a lot to me. Lorenzo From: glenschweizer(at)yahoo.com Subject: Re: Pietenpol-List: Airplane Weights Date: Tue=2C 25 Mar 2014 19:31:10 -0700 Hi Lorenzo I looked at the Oretex website. When checking prices=2C I b ecame discouraged when all they said was "compared to other finishing syste ms=2C the cost of spray guns=2C compressor setting up a booth...blah blah b lah Oretex is comparable to other finishing systems". Please cut to the c hase. Here. What does it cost to cover a pietenpol? Anytime a supplie r hides behind a bunch of B S =2C I run the other direction. The concept i s interesting=2C however Thanks Glen Sent from my iPhone On Mar 25=2C 2014=2C at 7:14 PM=2C larharris2 Harris w rote: =0A =0A =0A Thanks for the input. I'm strongly considering Oratex fabric - so I don't n eed no stinkin' paint. Lorenzo From: jack(at)bedfordlandings.com Subject: RE: Pietenpol-List: Airplane Weights Date: Tue=2C 25 Mar 2014 21:40:51 -0400 =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A Lorenzo=2C=0A =0A =0A =0A My Pietenpol came in at 745 lbs.=2C which=0A was about 80 lbs more than I was expecting. I believe most of that extra =0A weight was in the paint that I chose=2C PolyFiber=92s Aerothane=0A polyurethane. It is very heavy=2C and difficult to paint. I ended up=0A putting several coats on the fuselage before I got a decent finish with a =0A minimum of orange peel. The only way to get it off is to sand it off=2C an d=0A I know I didn=92t sand all the extra coats off. The wire wheels are=0A also heavy=2C weighing (with tires and brakes) 25 lbs apiece. And the stra ight=0A axle weighs quite a bit as well. The battery and the avionics add a bit=0A but not as much as you=92d think=2C and I was expecting the weight they add ed=0A (my original estimate=2C including the electrical stuff was 660 lbs=2C whic h would=0A be a decent weight).=0A =0A =0A =0A End result? Mine doesn=92t climb=0A too well with a heavy load. I limit myself to carrying passengers=0A weighing no more than 180 lbs. The benefit of this is=2C I can limit my=0A passengers to pretty young women for the most part.=0A =0A =0A =0A Simplicate and add lightness!=0A =0A =0A =0A Jack Phillips=0A =0A NX899JP=0A =0A Smith Mountain Lake=2C Virginia=0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=0A npol-List"">http://www.matronics.com/Navigator?Pietenpol-List=0A D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=0A //forums.matronics.com=0A D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=0A ot=3B">http://www.matronics.com/contribution=0A D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Date: Mar 26, 2014
I'm starting to sound like a commercial for Oratex. If you contact the reps in Anchorage=2C they will send a free sample kit (t hey may ask for postage- they asked me=2C but never charged me). It include s about 1/2 yard plus a small bottle of the glue so you can practice with i t. I asked for more - I wanted to see and feel all the colors and feel the two weights of fabric. They were very gracious and included some smaller cu toffs in the package. They say that the 6000 fabric is more resistant to in cidental damage=2C but I think the 600 weight will do just fine for me. Aga in=2C the ease of application and weight savings are worth a lot to me. Lorenzo > Subject: Pietenpol-List: Re: Airplane Weights > From: jarheadpilot82(at)hotmail.com > Date: Wed=2C 26 Mar 2014 00:27:18 -0700 > To: pietenpol-list(at)matronics.com > tmail.com> > > Lorenzo=2C > > I did a little "dumpster diving" on the internet and found a guy's estima te from Better Aircraft Fabric for the Oratex 6000 dated September 2013. It shows the price for the 1800mmX1m material to be $134.87. I think that the Oratex 600 is slightly cheaper=2C but I am not 100% sure on that. > > Doing the Math=2C 1800mmX1m equals 1.8 square meters which equal 2.15 squ are yards=2C or $62.73 per square yard. The invoice shows the cost of glue tape=2C etc. but this is what I come up with for the price of the cloth its elf. > > I have seen this stuff first hand at OSH and I have to say=2C it is as st rong as you-know-what! They beat on it with a huge hammer=2C then took heat and pulled out the divits in the fabric right there in seconds. Really imp ressive stuff. > > I am strongly considering the use of Oratex for the same reasons you ment ioned - weight savings=2C strength=2C ease of use=2C and savings on the cos t of painting equipment. I will tell you this=2C though. If you want a glos sy finish=2C then you should move on to another covering. I would not call it dull=2C but it definitely is not glossy. Works for me=2C but you may wan t a different look. > > -------- > Semper Fi=2C > > Terry Hand > Athens=2C GA > ________________________________________________________________________________
Date: Mar 26, 2014
Brian=2C Thanks for the well thought out reply. Just what I was looking fo r. I=2C too=2C am becoming a 'weight Nazi'. I figure that if I concern myse lf with shaving ounces now=2C I will be able to comfortably add a doodad=2C or two=2C at the end. Lorenzo =0A ________________________________________________________________________________
Subject: Nice article!
Date: Mar 26, 2014
Kudos to William Wynne, and the nice article in Aprils Sport Aviation! Now we can all become Motorheads! -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421059#421059 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: fuel tanks
Date: Mar 26, 2014
Both fuel tank locations have worked fine. Here's why I went with a wing tank and like it. 1. The fuel is farther from the hot engine and electrics in most "unplanned attitudes" such as upside down or on it's nose, or in case of an engine fire. 2. I have heard of too low fuel head pressure/fuel starvation issues with fuselage tanks, but not with wing tanks. If you're building a big fuse tank, it can be tricky to design it so you get the head pressure you need. It can certainly be done, just watch it in all attitudes. 3. Fuel overhead or fuel in my lap can both be bad situations, but it's all dependent on the incident and there's probably no way to foresee. 4. zero CG shift from full to empty. 5. I like the storage area up front. In view of WW's accident and the very real potential for forward wing displacement during a sudden stop, I strongly recommend flexible fuel lines to the tank. When 799B went over, the wing DID move forward about three inches and my hard lines held fine, but when I rebuilt her, I was sure to use flexible lines. There are certainly pros for fuselage tanks too, but these are the reasons I went with a wing tank. Douwe ________________________________________________________________________________
Subject: Re: fuel tanks
Date: Mar 26, 2014
I can add to several of Douwe's points (his #1 and #2)- 1. My airplane has been upside-down. Carb ice, power loss, precautionary off-field landing on rough terrain... a weld broke on the landing gear leg and it went over on its nose and onto its back. There was no fire, although there was some fuel loss through the vent on the fuel tank cap. What I'd like to emphasize with this is the point that William makes about providing some flexure in the fuel lines and for making the cabane brace connection rigid rather than adjustable once you've set the wing angle. Examine the photo of my cabane braces after the roll-over and you'll see why: http://www.flysquirrel.net/piets/incident/PB130010.JPG 2. The final couple of gallons (about 2.5) in my 16 gallon tank are unusable in the 3-point or climb attitude. I demonstrated that fact on a x-c where I landed with about that amount of fuel in the tank and as soon as I eased the tail down, the engine quit. It's simple physics and geometry... liquid doesn't like to flow uphill ;o) Examine a side shot of my engine, like this one: http://www.flysquirrel.net/piets/engine/P5060008.JPG Picture where the carb float bowl is relative to the bottom of the fuel tank (an inch or two above the horizontal seam in the firewall). So Mikee is right... I don't fly it down into that last 1/4 tank or so. Two more things and I'm done. First, that seam in my firewall was intended to make the bottom portion removable to provide access to the underside of the fuel tank, the front rudder pedals, and anything else up in the forward cockpit. Unfortunately, I forgot about the engine mount bolting on and being in the way, so it's not removable. Sometimes good ideas aren't ;o) Second, I have never fueled my airplane without using a ladder. I like to be able to see down into the fuel tank because it's too easy to flood the tank and cowling if I let it get up to the top. It sometimes happens even when I can see down into the tank. So don't think that using a nose tank will eliminate the usefulness of a ladder for fueling, unless you're a lot taller than I am (5'-9" in high heels). -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421069#421069 ________________________________________________________________________________
Subject: Re: Adding Tank to Wing
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Mar 26, 2014
Mike, I don't see any reason you couldn't add a tank at a later date. It sounds like you already have a three piece wing. I say get your plane flying and evaluate the need for the second tank. It would be easy to build another center section while flying/enjoying you plane. Then swap center sections on the weekend sometime. It should be easy to do it that way. My three cents, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421080#421080 ________________________________________________________________________________
Subject: Red Baron video
Date: Mar 26, 2014
OK, time to let up on the tense discussions and get back to something lighter. This is a very good (and as far as I know, pretty factual) animated video recounting the demise of Manfred von Richthofen, aka "The Red Baron": http://www.youtube.com/embed/ywug11nLFfg?feature=player_detailpage It's less than 6 minutes long. I was surprised at how well the graphics portray the control responses and aircraft behavior in the various maneuvers, and the sound effects are quite good as well. In fact, there are a couple of spots where I can close my eyes and the sound is very much like my engine sounds if I push in the carb heat ;o) The final scenes, whether completely factual or not, are pretty dramatic for an animation. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421089#421089 ________________________________________________________________________________
Date: Mar 26, 2014
Brian Kenny probably has the lightest Pietenpol (CF-AUK) around and his dissertation on weight saving/adding is =9Cbang on=9D. I cannot say that I adhered to all of the points he made when I was building my Pietenpol (CF-AUN) during the period 1959-70, but this isn=99t to say I was unaware of them at that time=94having been involved in aircraft maintenance and design since 1948. There were compromises made due to availability of materials and a shortage of cash during that time period. If I were to build another Pietenpol today, I would do some things differently. But there are many things I would not change, either. I used Sitka spruce for just about everything but the wing spars and maintained the dimensions in the plans. At the time it was difficult and expensive to get Sitka spruce in the size needed for the spars and I discovered some beautiful Douglas Fir boards at a very reasonable price and built them up to the I-beam dimensions in the plans, and used =9Cswallow tail=9D blocks at attachment points in accordance with good engineering practice. Since fir is a tad heavier than spruce, these spars are a bit heavier than spruce ones would have been. Another compromise related to cost and availability. I made the fuselage two inches wider (26=9D) to allow more clothing to be worn in these northern parts; a compromise that paid off big time in spite of it adding some weight. The wing is in three pieces; a single piece wing would have been lighter. Yet another compromise due mainly to available working space. Since I was going to be operating from some pretty rough grass areas, I elected to beef up the landing gear/lift strut fuselage fittings and added perhaps a couple of pounds by doing so. A trade-off in weight saving for serviceability. All other fittings were pretty much according to plans excepting the Aeronca engine mount-to-fuselage fittings which were specially designed to use this engine mount. Virtually no weight gain here. Originally I used a 6 inch Scott tailwheel with the yoke and coil spring arrangement and it was OK. Later, I made a lightweight fork assembly with a 4 inch commercial caster wheel which was used for years, requiring wheel replacement at a modest cost every 100 hours or so. This saved some weight in a critical location and it worked just fine. I used very light Shinn 6.00-6 main wheels and axles from a wrecked Taylorcraft and this helped save some weight over other wheels I could have used. Brian states the weight of the aircraft covering being important when trying to save weight, and he is right! My Pietenpol originally was covered with Grade A aircraft cotton and had a hand-rubbed doped finish. It looked nice, but was heavier than necessary. The empty weight (including oil) was 645 pounds with a Continental A65 engine, and this was an accurate figure because new certified-accurate scales were used. Fourteen years later, the a/c was stripped and recovered with Lincoln polyester fabric, doped to a =9Cserviceable=9D (not fine) finish. The empty weight with a C85-8 engine and wooden propeller was now 630 pounds on the same scales. So the covering really does make a noticeable difference (but the lighter tailwheel accounted for some of this). As Brian pointed out, the weight of the wing struts is significant. Again, I had to compromise because of cost and availability. I used Aeronca rear strut material for the center section struts (cabanes), Aeronca front lift strut material for the front struts and Taylorcraft rear lift strut material for the rear struts. Much heavier than required, but it was what I had at the time. I flew CF-AUN for 862 hours and literally made thousands of landings over nearly 43 years. The only thing that ever broke was a somewhat-worn tailwheel coil spring salvaged from my dad=99s old grain binder. She could have been a tad lighter, but she was durable. I retired her last September when I donated her to a local museum. Cheers to all, Graham Hansen (Alberta, Canada) From: Brian Kenney Sent: Wednesday, March 26, 2014 3:11 AM Subject: RE: Pietenpol-List: Airplane Weights Here is my take on how you can add extra weight. In the wood there are a couple of considerations. Spars of 1" thickness, if not routered, adds if memory serves about 16 lbs of additional weight. Spruce of the optimum density is about 27 lbs/cubic foot. There are spruce boards that are heavier than that. If you use Douglas fir I believe it is about 10% heavier. Plywood varies in weight and birch can weigh more than mahogany. Adding thickness to plywood is adding weight proportional to the extra thickness. Adding additional plywood or filler blocks adds weight . While you can add weight in the wood selection its use pales in comparison to the steel components. In contrast to spruce at 27 lb/cubic foot, steel weighs 500 lbs/cubic ft. . Therefore close attention to the area and thickness of every metal part is very important. Using bolts and screws that are bigger than needed adds weight. There are shear nuts that weigh less than full depth nuts and many nuts are used in shear. There are military nuts that are very much smaller than conventional nuts. In some locations you can use counter sunk heads or pan head fasteners instead of hex head bolts. Because it weighs so much these little things adds up. There are one or two areas that are really critical. Streamline struts of the type used on the original Pietenpol are not available. There replacement are not longer available either. By that I mean 0.035 wall struts of smaller equivalent diameter. Today much of it is 0.065 and larger equivalent diameter and that is all you can buy new. If you use this material you can be adding 10lbs or more per strut. Do this comparison. Compare the weight of the smallest steel streamline lift strut available from Aircraft Spruce to the weight of a 1.25`` diameter 0.035`` wall 4130 round tube. You can streamline a round tube with foam and 1 mm plywood and save on an aircraft perhaps 25 to 40 lbs. I am not sure about that but do the math. A straight axle can weigh a lot if it is 0.125`` wall but is close to half the weight if you use 0.065`` but you need ash in the center of the tubing at each end. The wood weighs much less than the extra steel. My first axle was 0.049`wall but bent it slightly on my fourth rather hard landing. I used it for about another 3 to 5 years and it didn't bend any more but then went to 0.065 and it has taken many a hard landing. You must keep it short and tight to bungees to reduce the bending moment. Adding thickness to steel parts doesn't seem that much more but 0.049 weighs 50% more than 0.035. When substituting 4130 for mild steel you can reduce thickness of steel in some places. I did this but I won't tell you where. Don't do it if you are not knowledgeable on material strengths. I reduced some wood dimensions in some areas but again I am not telling where you need to figure that out. You can substitute wood for metal, you can use very thin plywood over the top of the fuselage. The wooden gear is lighter than the steel gear. While the wheels and tires are heavier than small aircraft wheels and tires the gear is shorter and made of wood. I think the complete assembly weighs less. My motorcycles wheels and brakes weigh 19lbs each and I think aircraft wheels weigh about 5lbs less each. If you use big aircraft tires then the difference is much less. Don`t trust my memory on all of this because it has been so long, just do the math before making your decisions. Adding starter motors, alternators, batteries, cables etc and you are talking perhaps 75 to 100 lbs. The motor you select can be hugely different. If you use a lighter one you save. In the continental A65 there is a cast aluminum accessory case but there is an magnesium one that weighs less. Covering and paint need to be minimum. Dacron that is 1.6 oz works fine. Weight is got to be part of the mind set. I was obsessed with it. My ELT antenna is mounted on a wooden structure inside the fuselage and is attached with a #4 stainless steel screw. I like Burt Rutan's attitude. If you take a part and throw it up and in falls back down to the ground then it weighs too much. DO NOT ADD EXTRA STUFF. Wooden propeller, not metal. No ballast for CG correction. Very light tail wheel with coil spring,not leaf spring. You can't use very light tailwheel components if you move the main wheels forward . The same thing happens if you move the wing back and don't adjust the gear position. Instruments in the passenger seat are not necessary. The Grega design adds about 100 lbs of unnecessary material, mostly steel and plywood. My Air Camper weighs 588 lbs with an ELT , a fairly heavy fire extinguisher and a first aid kit but without a portable radio and no transponder. So as I fly it normally it weighs about 600 lbs empty plus fuel plus passengers. My max pilot and passenger combined weight so far is 465lbs. The record empty weight of an Air Camper is over 900 lbs. Every additional 25 lbs of weight requires about one additional horsepower and the associated additional fuel capacity to feed it. It can be a few choices that make a big differences but it is usually hundreds of decisions that add up. Hope this helps, good luck with your project. ------------------------------------------------------------------------- ------- From: larharris2(at)msn.com Subject: Pietenpol-List: Airplane Weights Date: Tue, 25 Mar 2014 18:37:29 -0400 Good discussion thread on Weight and Balance. I have just received my package from Doc Mosher with WWs articles. Well documented info on CG and axle location. Keeping the CG location in mind as I build will have a high priority. I have much more to study and learn. The CG spreadsheets recently posted are also valuable tools. New question for some of you who have finished and flown your plane regarding the total weight of the plane. Like everyone, I want to be careful of adding unnecessary weight as I build. So far I am following the plans carefully. But like everyone, I am sure, I have some personal customizations in the back of my mind. WWs articles document specific data from individual planes. I pulled a handful of them to examine more closely regarding Empty Weight (EW) - long/short fuselage, A65/Corvair engines. The lightest weight airplane I studied was 590lb, the heaviest 842lb. Subtracting a 'standard' engine weight from the EW yielded some interesting information. In most cases, regardless of the engine type or fuse. length, the weight of 'everything else' came out to about 410-415lb. In only 2 cases I examined was there a great difference - one was 581lb and the other 617lb. Not just over, but WAY over the others. Here's the question: What in the world do some builders add to their planes that takes a 400 lb plane to over 600 lb?? OK. Some extra instrumentation, tailwheel vs the original tailskid, brakes system, extra fuel tank, etc. But 200lb worth? What do I need to look out for? Thanks for the replies. Lorenzo st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com ="_blank">http://www.matronics.com/contribution No virus found in this message. Checked by AVG - www.avg.com 03/25/14 ________________________________________________________________________________
Date: Mar 26, 2014
Great story Graham. I wish I could duplicate your pietenpol history but I do not nave the time in my lifetime. Cheers, Gardiner Sent from my iPad On Mar 26, 2014, at 6:17 PM, "G Hansen" <ghans@cable-lynx.net> wrote: > Brian Kenny probably has the lightest Pietenpol (CF-AUK) around and his di ssertation on weight saving/adding is =9Cbang on=9D. I cannot sa y that I adhered to all of the points he made when I was building my Pietenp ol (CF-AUN) during the period 1959-70, but this isn=99t to say I was u naware of them at that time=94having been involved in aircraft mainten ance and design since 1948. There were compromises made due to availability o f materials and a shortage of cash during that time period. If I were to bui ld another Pietenpol today, I would do some things differently. But there ar e many things I would not change, either. > > I used Sitka spruce for just about everything but the wing spars and maint ained the dimensions in the plans. At the time it was difficult and expensiv e to get Sitka spruce in the size needed for the spars and I discovered some beautiful Douglas Fir boards at a very reasonable price and built them up t o the I-beam dimensions in the plans, and used =9Cswallow tail=9D blocks at attachment points in accordance with good engineering practice. S ince fir is a tad heavier than spruce, these spars are a bit heavier than sp ruce ones would have been. Another compromise related to cost and availabili ty. I made the fuselage two inches wider (26=9D) to allow more clothi ng to be worn in these northern parts; a compromise that paid off big time i n spite of it adding some weight. The wing is in three pieces; a single piec e wing would have been lighter. Yet another compromise due mainly to availab le working space. > > Since I was going to be operating from some pretty rough grass areas, I el ected to beef up the landing gear/lift strut fuselage fittings and added per haps a couple of pounds by doing so. A trade-off in weight saving for servic eability. All other fittings were pretty much according to plans excepting t he Aeronca engine mount-to-fuselage fittings which were specially designed t o use this engine mount. Virtually no weight gain here. > > Originally I used a 6 inch Scott tailwheel with the yoke and coil spring a rrangement and it was OK. Later, I made a lightweight fork assembly with a 4 inch commercial caster wheel which was used for years, requiring wheel repl acement at a modest cost every 100 hours or so. This saved some weight in a c ritical location and it worked just fine. I used very light Shinn 6.00-6 mai n wheels and axles from a wrecked Taylorcraft and this helped save some weig ht over other wheels I could have used. > > Brian states the weight of the aircraft covering being important when tryi ng to save weight, and he is right! My Pietenpol originally was covered with Grade A aircraft cotton and had a hand-rubbed doped finish. It looked nice, but was heavier than necessary. The empty weight (including oil) was 645 po unds with a Continental A65 engine, and this was an accurate figure because n ew certified-accurate scales were used. Fourteen years later, the a/c was st ripped and recovered with Lincoln polyester fabric, doped to a =9Cserv iceable=9D (not fine) finish. The empty weight with a C85-8 engine and wooden propeller was now 630 pounds on the same scales. So the covering rea lly does make a noticeable difference (but the lighter tailwheel accounted f or some of this). > > As Brian pointed out, the weight of the wing struts is significant. Again, I had to compromise because of cost and availability. I used Aeronca rear s trut material for the center section struts (cabanes), Aeronca front lift s trut material for the front struts and Taylorcraft rear lift strut material f or the rear struts. Much heavier than required, but it was what I had at the time. > > I flew CF-AUN for 862 hours and literally made thousands of landings over n early 43 years. The only thing that ever broke was a somewhat-worn tailwheel coil spring salvaged from my dad=99s old grain binder. She could have been a tad lighter, but she was durable. I retired her last September when I donated her to a local museum. > > Cheers to all, > > Graham Hansen (Alberta, Canada) > > > > > > From: Brian Kenney > Sent: Wednesday, March 26, 2014 3:11 AM > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Airplane Weights > > Here is my take on how you can add extra weight. > > In the wood there are a couple of considerations. Spars of 1" thickness, i f not routered, adds if memory serves about 16 lbs of additional weight. Spr uce of the optimum density is about 27 lbs/cubic foot. There are spruce boar ds that are heavier than that. If you use Douglas fir I believe it is about 1 0% heavier. Plywood varies in weight and birch can weigh more than mahogany. Adding thickness to plywood is adding weight proportional to the extra thi ckness. Adding additional plywood or filler blocks adds weight . > > While you can add weight in the wood selection its use pales in compariso n to the steel components. In contrast to spruce at 27 lb/cubic foot, steel weighs 500 lbs/cubic ft. . Therefore close attention to the area and thickn ess of every metal part is very important. Using bolts and screws that are b igger than needed adds weight. There are shear nuts that weigh less than ful l depth nuts and many nuts are used in shear. There are military nuts that a re very much smaller than conventional nuts. In some locations you can use c ounter sunk heads or pan head fasteners instead of hex head bolts. Because i t weighs so much these little things adds up. > > There are one or two areas that are really critical. Streamline struts of t he type used on the original Pietenpol are not available. There replacement a re not longer available either. By that I mean 0.035 wall struts of smaller e quivalent diameter. Today much of it is 0.065 and larger equivalent diameter and that is all you can buy new. If you use this material you can be addin g 10lbs or more per strut. Do this comparison. Compare the weight of the sma llest steel streamline lift strut available from Aircraft Spruce to the weig ht of a 1.25`` diameter 0.035`` wall 4130 round tube. You can streamline a r ound tube with foam and 1 mm plywood and save on an aircraft perhaps 25 to 4 0 lbs. I am not sure about that but do the math. > > A straight axle can weigh a lot if it is 0.125`` wall but is close to half the weight if you use 0.065`` but you need ash in the center of the tubing a t each end. The wood weighs much less than the extra steel. My first axle wa s 0.049`wall but bent it slightly on my fourth rather hard landing. I used i t for about another 3 to 5 years and it didn't bend any more but then went t o 0.065 and it has taken many a hard landing. You must keep it short and tig ht to bungees to reduce the bending moment. > > Adding thickness to steel parts doesn't seem that much more but 0.049 weig hs 50% more than 0.035. When substituting 4130 for mild steel you can reduc e thickness of steel in some places. I did this but I won't tell you where. D on't do it if you are not knowledgeable on material strengths. I reduced som e wood dimensions in some areas but again I am not telling where you need to figure that out. > > You can substitute wood for metal, you can use very thin plywood over the t op of the fuselage. The wooden gear is lighter than the steel gear. While th e wheels and tires are heavier than small aircraft wheels and tires the gear is shorter and made of wood. I think the complete assembly weighs less. My m otorcycles wheels and brakes weigh 19lbs each and I think aircraft wheels we igh about 5lbs less each. If you use big aircraft tires then the difference i s much less. Don`t trust my memory on all of this because it has been so lo ng, just do the math before making your decisions. > > Adding starter motors, alternators, batteries, cables etc and you are talk ing perhaps 75 to 100 lbs. The motor you select can be hugely different. If y ou use a lighter one you save. In the continental A65 there is a cast alumin um accessory case but there is an magnesium one that weighs less. > > Covering and paint need to be minimum. Dacron that is 1.6 oz works fine. > > Weight is got to be part of the mind set. I was obsessed with it. My ELT a ntenna is mounted on a wooden structure inside the fuselage and is attached w ith a #4 stainless steel screw. > > I like Burt Rutan's attitude. If you take a part and throw it up and in fa lls back down to the ground then it weighs too much. DO NOT ADD EXTRA STUFF. > > Wooden propeller, not metal. No ballast for CG correction. Very light tail wheel with coil spring,not leaf spring. You can't use very light tailwheel c omponents if you move the main wheels forward . The same thing happens if y ou move the wing back and don't adjust the gear position. > > Instruments in the passenger seat are not necessary. > > The Grega design adds about 100 lbs of unnecessary material, mostly steel a nd plywood. > > My Air Camper weighs 588 lbs with an ELT , a fairly heavy fire extinguishe r and a first aid kit but without a portable radio and no transponder. So a s I fly it normally it weighs about 600 lbs empty plus fuel plus passengers. My max pilot and passenger combined weight so far is 465lbs. > > The record empty weight of an Air Camper is over 900 lbs. > > Every additional 25 lbs of weight requires about one additional horsepower and the associated additional fuel capacity to feed it. > > > It can be a few choices that make a big differences but it is usually hund reds of decisions that add up. > > Hope this helps, good luck with your project. > > > > > > From: larharris2(at)msn.com > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Airplane Weights > Date: Tue, 25 Mar 2014 18:37:29 -0400 > > Good discussion thread on Weight and Balance. I have just received my pack age from Doc Mosher with WWs articles. Well documented info on CG and axle l ocation. Keeping the CG location in mind as I build will have a high priorit y. I have much more to study and learn. The CG spreadsheets recently posted a re also valuable tools. > > New question for some of you who have finished and flown your plane regard ing the total weight of the plane. > > Like everyone, I want to be careful of adding unnecessary weight as I buil d. So far I am following the plans carefully. But like everyone, I am sure, I have some personal customizations in the back of my mind. > > WWs articles document specific data from individual planes. I pulled a han dful of them to examine more closely regarding Empty Weight (EW) - long/shor t fuselage, A65/Corvair engines. The lightest weight airplane I studied was 5 90lb, the heaviest 842lb. Subtracting a 'standard' engine weight from the EW yielded some interesting information. In most cases, regardless of the engi ne type or fuse. length, the weight of 'everything else' came out to about 4 10-415lb. In only 2 cases I examined was there a great difference - one was 5 81lb and the other 617lb. Not just over, but WAY over the others. > > Here's the question: What in the world do some builders add to their plan es that takes a 400 lb plane to over 600 lb?? > > OK. Some extra instrumentation, tailwheel vs the original tailskid, brakes system, extra fuel tank, etc. But 200lb worth? What do I need to look out f or? > > Thanks for the replies. > > Lorenzo > > > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > http://forums.matronics.com > ="_blank">http://www.matronics.com/contribution > > > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matr onics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > No virus found in this message. > Checked by AVG - www.avg.com > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Here Is An Interesting Read
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Mar 26, 2014
How many of you have heard of the book, Aircraft Maintenance, by Daniel J. Brimm and H. Edward Boggess? Maybe all of you have. But if you havent, it is a great read to see how aircraft maintenance was done in the 1930s and 40s. Lest I be accused of suggesting you copy maintenance procedures from a time long past, I find an interesting historical read. The best part is that you dont even have to buy it, although I did. Here is a link to an online copy. If you ever wondered how they did those darn 5 tuck navy splices on the control cables, simply go to page 333. I mean, Clyde Pangborn wrote the forward. You do know who Clyde Pangborn was, dont you? http://babel.hathitrust.org/cgi/pt?id=wu.89090516238;view=1up;seq=1 -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421095#421095 ________________________________________________________________________________
Subject: Re: Here Is An Interesting Read
Date: Mar 26, 2014
Terry, I have a copy of this book. It was still in use in the late 1940s when I was at technical school. Not as a text book, but as a reference. It is historical, for sure. A relic, like me. Graham Hansen -----Original Message----- From: jarheadpilot82 Sent: Wednesday, March 26, 2014 6:26 PM Subject: Pietenpol-List: Here Is An Interesting Read How many of you have heard of the book, Aircraft Maintenance, by Daniel J. Brimm and H. Edward Boggess? Maybe all of you have. But if you havent, it is a great read to see how aircraft maintenance was done in the 1930s and 40s. Lest I be accused of suggesting you copy maintenance procedures from a time long past, I find an interesting historical read. The best part is that you dont even have to buy it, although I did. Here is a link to an online copy. If you ever wondered how they did those darn 5 tuck navy splices on the control cables, simply go to page 333. I mean, Clyde Pangborn wrote the forward. You do know who Clyde Pangborn was, dont you? http://babel.hathitrust.org/cgi/pt?id=wu.89090516238;view=1up;seq=1 -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421095#421095 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Mar 26, 2014
Graham, Also, like you. An informative, knowledgeable relic. [Wink] -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421099#421099 ________________________________________________________________________________
Date: Mar 26, 2014
It's been mentioned a bit in the past, but surprisingly hasn't come up in these recent discussions at all. About point #2. Dick put a 4 gal (or so) header tank in the nose of 2RN. His reasoning was (and I'm a big fan, think it's a great idea) that it prevents pretty much any chance of the engine quitting because of sloshing in the relatively wide and flat wing tank. At 4 gal, it's an hour reserve of fuel if necessary. I got to thinking about it, I've got a shutoff right outside the cockpit where the fuel exits the wing tank. If I were to lose my engine and was in the midst of deadsticking it in, wouldn't take but a fraction of a second to reach up and close that, which would be even more insurance against free flowing fuel in the event of a fuel line rupture due to wing displacement. Like everything, it's a compromise. It does complicate the fuel piping somewhat. However, as 2RN needed some nose weight due to the relatively light A65, that was absorbed. Just more food for thought. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421100#421100 ________________________________________________________________________________
Date: Mar 26, 2014
Subject: mike C.
Mikeeee- Welcome to the Council of Curmudgeons. I knew you'd make it someday. ________________________________________________________________________________
Subject: It's FINALLY a hangar...
Date: Mar 26, 2014
N2RN got her tailwheel, horiz and vert stabs, elevators and rudder, WING, and an aileron reinstalled today. FINALLY... For the first time, a big structure is holding an airplane, so it's technically a hangar I guess. Tomorrow is lots of adjusting wires, controls, cotter keying and safety wiring turnbuckles. Hopefully get the motor running. Early next week should be in annual and ready for flight. The runway finally seems hard enough to fly upon. Been a long haul on this one. [img]https://us-mg4.mail.yahoo.com/ya/download?mid=2_0_0_1_1096192_ACINiWIAABLeUzOKpwAAAJxxXlE&pid=2&fid=Inbox&inline=1[/img] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421104#421104 ________________________________________________________________________________
Subject: Re: It's FINALLY a hangar...
Date: Mar 26, 2014
So cool to see that. Very exciting times. Fingers crossed for the engine run. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421107#421107 ________________________________________________________________________________
Subject: Re: Speaking of outdated
stuff? Center section fuel tanks vs. n
Date: Mar 26, 2014
Although I need all the help I can get I wasn't asking for help. :-) I was, however, hoping to nudge the collective grey matter in thoughtful directions. Clif It ain't what we don't know that gives us trouble, it's what we know that just ain't so." Josh Billings I can't help you Clif, I have no idea. But you bring up good points that I obviously didn't think about. Mike Perez ________________________________________________________________________________
Date: Mar 27, 2014
Subject: Re: Red Baron video
Thanks Oscar. Have you seen/heard of the History Channel series Dog Fights? They are mostly computer generated animated documentaries depicting- air combat scenarios form WWI through Desert Storm.- They look fantastic! Ve ry well done. You may be interested in taking a look. =0A=0A=0AIf God is yo ur co-pilot...switch seats.=0AMike Perez=0AKaretakerAero=0ASTILL Building.. .=0A ________________________________________________________________________________
Date: Mar 27, 2014
Subject: Re: Speaking of outdated stuff? Center section fuel
tanks vs. n Neither was I. Like you said, Just trying to nudge the collective grey matt er... =0A=0A=0AIf God is your co-pilot...switch seats.=0AMike Perez=0AKaret aker Aero=0ASTILL Building...=0A=0A=0A=0ASomething else, I thought about, which may or my not matter:=0A--- A wing mounted tank does have an ar m of sorts, along the longitudinal axis. In a roll, the wing tank has an arm greater than the nose tank. It is a weight, being swung around the lon gitudinal axis. Does this matter, does it effect stability? What, if anythi ng, changes as fuel burns? ________________________________________________________________________________
Date: Mar 27, 2014
Its from a WW! flight sim called: Rise of Flight. Its not factual its fictitious. There are factual accounts better then the sim video posted on MvR death. The video is good just for the enjoyment of watching. The sim RoF is free to download and play, the cravat is you have to purchase more airplanes. {url}http://riseofflight.com/en[/ur]l Enjoy, WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421118#421118 ________________________________________________________________________________
Subject: Yes indeed...
Date: Mar 27, 2014
It's truly a great book, but I didn't know there was a second edition... I have the first, along with the companion book, Aircraft Engines, by the same authors. Once I started reading them, I was sure I'd be able to acquire or develop the skills needed to build a Piet. I'd recommend them to anyone wanting to know the old school way of doing things. As some other threads have mentioned lately, old school isn't always what we might do today... but there's value in knowing how things were originally done in the aircraft world, compared to some more modern techniques. Along with you, I think a lot of folks here will either learn something from this book, or at least derive some pleasure reading it. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421119#421119 ________________________________________________________________________________
Date: Mar 27, 2014
I own RoF ICE. (Iron Cross Edition) Not sure if that is a free download or not, but I paid for mine at the time.- Very impressive sim. for sure...al ong the lines of IL2 HSFX6. =0A=0AIf God is your co-pilot...switch seats. =0AMike Perez=0AKaretakerAero=0ASTILL Building...=0A ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Mar 27, 2014
It'll be good to see that Pietenpol back in the air! Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tools Sent: Wednesday, March 26, 2014 10:31 PM Subject: Pietenpol-List: It's FINALLY a hangar... N2RN got her tailwheel, horiz and vert stabs, elevators and rudder, WING, and an aileron reinstalled today. FINALLY... For the first time, a big structure is holding an airplane, so it's technically a hangar I guess. Tomorrow is lots of adjusting wires, controls, cotter keying and safety wiring turnbuckles. Hopefully get the motor running. Early next week should be in annual and ready for flight. The runway finally seems hard enough to fly upon. Been a long haul on this one. [img]https://us-mg4.mail.yahoo.com/ya/download?mid=2_0_0_1_1096192_ACINiWIAA BLeUzOKpwAAAJxxXlE&pid=2&fid=Inbox&inline=1[/img] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421104#421104 ________________________________________________________________________________
Subject: Re: Speaking of outdated stuff? Center section fuel tanks
vs. n
Date: Mar 27, 2014
Cliff, You ask, "Doesn't everything below it act like a pendulum? The short answer is NO, however that requires some explanation... In a most properly designed and built airplane - the designer sets CG so the plane is slightly nose heavy, which requires an equal and opposite tail down force in flight. Now on the surface this may appear to be a pendulum, but in fact, its quite different. The purpose of nose heavy, coupled with tail down force is what gives us pitch stability. In other words, the plane will tend to stabilize itself in flight when you take your hands off the stick -assuming, of course, that you've trimmed the plane for whatever pitch attitude you need. What is somewhat bothersome is that many on the list have indicated that the elevator on a Piet "droops" during flight, when in fact, the elevator should be slightly up, in which case it's providing the tail down force. Perhaps the horizontal stabilizer on the Piet is - HERESY COMING - improperly designed, but satisfactory. If the angle of incidence of the stab were changed somewhat, this condition would be corrected... Personally, I'd like for Jack Phillips and a few of the others to comment on the drooping issue, as I'd like to make sure the plane I build is flying "correctly." I KNOW, I KNOW, I KNOW, BUILD IT PER THE PLANS, AND IT WILL FLY.... that still doesn't satisfy the Mechanical Engineer I am.... just sayin. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421123#421123 ________________________________________________________________________________
Date: Mar 27, 2014
Tools, Share with everybody how > expensive that big hangar is, and how you did it. I think that it would encourage people with maybe ideas of their own. P.S. She looks like you gave her a bath from when I was at Toolstock. It IS good to have Scott around! -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421124#421124 ________________________________________________________________________________
vs. n
Date: Mar 27, 2014
Cliff, You ask, "Doesn't everything below it act like a pendulum? The short answer is NO, however that requires some explanation... In a most properly designed and built airplane - the designer sets CG so the plane is slightly nose heavy, which requires an equal and opposite tail down force in flight. Now on the surface this may appear to be a pendulum, but in fact, its quite different. The purpose of nose heavy, coupled with tail down force is what gives us pitch stability. In other words, the plane will tend to stabilize itself in flight when you take your hands off the stick -assuming, of course, that you've trimmed the plane for whatever pitch attitude you need. What is somewhat bothersome is that many on the list have indicated that the elevator on a Piet "droops" during flight, when in fact, the elevator should be slightly up, in which case it's providing the tail down force. Perhaps the horizontal stabilizer on the Piet is - HERESY COMING - improperly designed, but satisfactory. If the angle of incidence of the stab were changed somewhat, this condition would be corrected... Personally, I'd like for Jack Phillips and a few of the others to comment on the drooping issue, as I'd like to make sure the plane I build is flying "correctly." I KNOW, I KNOW, I KNOW, BUILD IT PER THE PLANS, AND IT WILL FLY.... that still doesn't satisfy the Mechanical Engineer I am.... just sayin. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421125#421125 ________________________________________________________________________________
vs. n
Date: Mar 27, 2014
Cliff, In response to your question, "Doesn't everything below it act like a pendulum? The short answer is NO, that said, some explanation is required... In a properly designed and built airplane - the designer sets the CG so that the plane is slightly nose heavy, which, in flight, requires an equal and opposite tail down force. Now on the surface this may appear to be a pendulum, but in fact, its quite different. The purpose of nose heavy, coupled with tail down force is what gives us pitch stability. In other words, the plane will tend to stabilize itself in flight when you take your hands off the stick - and return to whatever pitch it's trimmed for, assuming, of course, that you've trimmed the plane for a given pitch attitude, i.e., climb, cruise, descent. What is somewhat bothersome is that many on the list have indicated that the elevator on a Piet "droops" during cruise flight, when in fact, the elevator should be slightly up, in order to provide the tail down force. Perhaps the horizontal stabilizer on the Piet is - HERESY COMING - improperly designed, but satisfactory. If the angle of incidence of the stab were changed somewhat, this condition might be corrected... Personally, I'd like for Jack Phillips and a few of the others to comment on the drooping issue, as I'd like to make sure the plane I build is flying "correctly." I KNOW, I KNOW, I KNOW, BUILD IT PER THE PLANS, AND IT WILL FLY.... that still doesn't satisfy the Mechanical Engineer I am.... just sayin. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421126#421126 ________________________________________________________________________________
vs. n
Date: Mar 27, 2014
Mike, I just reread your post where you asked- > A wing mounted tank does have an arm of sorts, along the longitudinal axis. In a roll, the wing tank has an arm greater than the nose tank. It is a weight, being swung around the longitudinal axis. Does this matter, does it effect stability? What, if anything, changes as fuel burns? so, are you asking about lateral cg? If building to plans the wing tank is not appreciably wider than a nose tank, I would guess. Unless you either builder a wider center section(i.e. a Bill Rewey center section), or you put the fuel in true wing tanks, which I have not heard of anyone doing. So, I don't think there is an appreciable difference between either tank in terms of the longituinal axis, or in terms of a lateral cg. However, I did not sleep in a Holiday Inn Express last night, and I am not an aeronautical engineer. But I have flown aircraft that lateral CG was a very big deal - helicopters with rescue hoists sticking out the side of the aircraft with people on the hoist. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421128#421128 ________________________________________________________________________________
Subject: Re: Yes indeed...
Date: Mar 27, 2014
Tom, I actually saw a 4th edition (I think) published around 1960. It was listed on eBay. It had a picture of a Pan Am Boeing 707 tail in the front pages, so I thought it was too "modern" for my needs. [Wink] -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421129#421129 ________________________________________________________________________________
Date: Mar 27, 2014
Like everything, there's a thousand ways... and Scott and I climbed a really steep curve! The one constant is that, unfortunately, the chicken industry is going through quite an upheaval. Like lots of things, all the chicken houses built in the 80's aren't economically feasible to update. Most of them are either 36' or 40' wide and clear spanned. You can get the trusses and tin for nickels on the dollar, or free. And seem to be available about everywhere. I've got maybe two grand in it as it stands, 40 x 85 but not yet sided and no big front door. It's really tall so that we can get the motorhome in it from the side (at the back) so it wouldn't block things in, or get blocked in. Lots of hangars have built in living areas, well, the motorhome is going to serve that purpose in this one. Gotta go work on a plane! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421130#421130 ________________________________________________________________________________
tanks vs. n
Date: Mar 27, 2014
OK Tom, You asked for it... I think the drooping elevator is largely a myth. From many angles, the elevator looks like it droops in flight because the reference that the eye has is the horizontal stabilizer. But the edge of the stabilizer is at an angle to the edge of the elevator, hence the appearance of a droop. Here are a few pictures from my files of Pietenpols in cruise flight: This shows the difference in angles I was talking about. See the angle of the edge of the horizontal stabilizer, compared to the edge of the elevator, which is straight? This is what creates the illusion of tail droop. Your eye tries to make the two edges line up. This one is a picture of Gene Rambo flying his son, Will, in my airplane. In this picture the horizontal tail is just about edge on, so the side of the stabilizer doesn't give the impression that the elevator is drooping. Looks pretty straight to me Here's another picture of my plane in flight: Here the angle is different and the side of the stabilizer does make it look like the elevator is slightly down, but I assure you it's not. Here's Mike Cuy's airplane, photo taken from mine. Note his tail - no droop. Here's Randy Bush's airplane, photo taken from Ryan Mueller's (now John Hofmann's) N502R. Notice the tail. Where's the supposed droop? Lastly, this picture shows Kevin Purtee on the left, Shad Bell in the center, and me on the right (photo taken by Bill Church during Brodhead 2011). You will note that my tail is slightly drooped with respect to the other two. The reason for this is that I was having to push my little Continental A65 for all it was worth to keep up with those two Corvair powered Pietenpols, and I had to hold the nose down to maintain my position in the formation and keep it from climbing at that speed. There may be a slight droop due to downwash from the wing, but other than that, I don't think the dreaded tail droop exists at all. Build it to the plans, and build it straight and it should fly just fine. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tkreiner Sent: Thursday, March 27, 2014 8:20 AM Subject: Pietenpol-List: Re: Speaking of outdated stuff? Center section fuel tanks vs. n Cliff, You ask, "Doesn't everything below it act like a pendulum? The short answer is NO, however that requires some explanation... In a most properly designed and built airplane - the designer sets CG so the plane is slightly nose heavy, which requires an equal and opposite tail down force in flight. Now on the surface this may appear to be a pendulum, but in fact, its quite different. The purpose of nose heavy, coupled with tail down force is what gives us pitch stability. In other words, the plane will tend to stabilize itself in flight when you take your hands off the stick -assuming, of course, that you've trimmed the plane for whatever pitch attitude you need. What is somewhat bothersome is that many on the list have indicated that the elevator on a Piet "droops" during flight, when in fact, the elevator should be slightly up, in which case it's providing the tail down force. Perhaps the horizontal stabilizer on the Piet is - HERESY COMING - improperly designed, but satisfactory. If the angle of incidence of the stab were changed somewhat, this condition would be corrected... Personally, I'd like for Jack Phillips and a few of the others to comment on the drooping issue, as I'd like to make sure the plane I build is flying "correctly." I KNOW, I KNOW, I KNOW, BUILD IT PER THE PLANS, AND IT WILL FLY.... that still doesn't satisfy the Mechanical Engineer I am.... just sayin. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421123#421123 ________________________________________________________________________________
vs. n
Date: Mar 27, 2014
My theory of the elevator droop is it could be an optical illusion. The outboard line from the elevator and horizontal stabilizer is bent because of the leading edge of the horizontal stabilizer not having the same span as the rest of the tail. I had this discussion and wanted to do some testing at Brodhead last year, but because of lack of time I was unable. I propose those who could, prior to Brodhead, set, their elevators in a faired (neutral) position and and somehow temporarily make a mark on their torque tube and the cable just above. Then go fly and compare in cruise flight if the marks are aligned yet. If not, make another mark to show the difference. Also while the tail is faired neutral on the ground, sit in the cockpit and look over your shoulder and look or take a picture of the tail and let us know what it looks like. Take pictures in slightly up and down elevator position. This is a great exercise not only to prove my theory right/wrong, but also like Tom said, the tail should always be creating downforce while flying and if elevators are drooping, the horizontal stab might need some shimming and re-rigging. My planes not flying and I'm definitely not an Opthamolagist, he'll I don't even think I can spell. -------- Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421132#421132 Attachments: http://forums.matronics.com//files/image_545.jpg ________________________________________________________________________________
tanks vs. n
Date: Mar 27, 2014
Tom being similarly educated I have thought about this too. Yes you could conclude that the horizontal stabilizer is not at the correct angle however here is some more to think about I think in reality the more correct assumption is that angle of incident of the wing is incorrect - this is important - wait for it - because these ai rcraft are flying too fast. The Air Camper was designed for an engine that produced less power than mo st of the ones flying. If you reduce the power the trim changes and the ele vator position changes and this slightly down elevator position changes fro m slightly down to level and if you are slow enough to up. When I first bui lt my aircraft it had an engine problem and it was producing an estimated 4 0 to 45 horsepower. I needed a fixed trim to give the elevators an up posit ion to adjust the nose down trim. While this a true observation it creates another mystery? Why does flying faster not do the opposite? Asymmetrical airfoils have a negative pitching coefficient. What this means is that the air coming off the tailing edge is at a downward angle and this is behind both the center of pressure and c enter of gravity so there is a torque created that wants to rotate the wing nose down. If you have every thrown a model wing without a tail you will o bserve that the wing just dives. The amount of this torque increases the fa ster you fly. In many aircraft the tail or elevator trim has to be adjusted to increase the negative tail lift or to say it another way to increase th e down force on the tail. So flying faster should mean the opposite to what is observed in reality wi th an Air Camper. Here is why I think the Air Camper is different. The wing is higher than th e tail. As the wing downwash exits the trailing edge it hits the horizontal tail and automatically compensates for the increasing negative pitching mo ment. This is not a feature of just the Pietenpol but many high wing aircra ft. The faster I fly the more I have to push the elevator down (stick forward)- totally counter intuitive. The correction to this problem is if you are going to fly faster you need t o reduce the lift on the wing at the higher speed and that means you need t o reduce ever so slightly the wing incidence. Here is another way to look at it and it demonstrates why this is the fix i f you want to fly faster. If you use more power the angle of the wing to the horizon changes. This is because the lift is increasing with speed. You can get this wing "up on th e step"=2C as some people call it=2C so far the bottom of the wing is on a negative angle to the horizon. That means the by that point the fuselage i s pointing down quite significantly. So at that speed the wing is lifting and the fuselage is diving. So you are really starting to increase the drag and aerodynamically the airplane tryi ng to separate the wing from the fuselage. So decreasing the angle of incid ence would reduce the negative angle at that speed and reduce the drag for that speed and allow the aircraft to fly even faster. In reality everything is just fine if the elevator is pointing down slightl y and the aircraft is completely stable and safe. The mystery of the Air Camper continues - why is it so good? > Subject: Pietenpol-List: Re: Speaking of outdated stuff? Center section f uel tanks vs. n > From: tkreiner(at)gmail.com > Date: Thu=2C 27 Mar 2014 05:30:26 -0700 > To: pietenpol-list(at)matronics.com > > > Cliff=2C > > In response to your question=2C "Doesn't everything below it act like a > pendulum? > > The short answer is NO=2C that said=2C some explanation is required... > > In a properly designed and built airplane - the designer sets the CG so t hat the plane is slightly nose heavy=2C which=2C in flight=2C requires an e qual and opposite tail down force. Now on the surface this may appear to b e a pendulum=2C but in fact=2C its quite different. > > The purpose of nose heavy=2C coupled with tail down force is what gives u s pitch stability. In other words=2C the plane will tend to stabilize itse lf in flight when you take your hands off the stick - and return to whateve r pitch it's trimmed for=2C assuming=2C of course=2C that you've trimmed th e plane for a given pitch attitude=2C i.e.=2C climb=2C cruise=2C descent. > > What is somewhat bothersome is that many on the list have indicated that the elevator on a Piet "droops" during cruise flight=2C when in fact=2C the elevator should be slightly up=2C in order to provide the tail down force. > > Perhaps the horizontal stabilizer on the Piet is - HERESY COMING - improp erly designed=2C but satisfactory. If the angle of incidence of the stab w ere changed somewhat=2C this condition might be corrected... > > Personally=2C I'd like for Jack Phillips and a few of the others to comme nt on the drooping issue=2C as I'd like to make sure the plane I build is f lying "correctly." > > I KNOW=2C I KNOW=2C I KNOW=2C BUILD IT PER THE PLANS=2C AND IT WILL FLY.. .. that still doesn't satisfy the Mechanical Engineer I am.... just sayin. > > -------- > Tom Kreiner > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421126#421126 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
tanks vs. n
Date: Mar 27, 2014
It is not an illusion but it requires two things to be happening for it to happen and to be obvious The aircraft need to be lightly loaded and the airplane needs to be flying fairly fast. If the CG is forward it is less likely to happen as well. > Subject: Pietenpol-List: Re: Speaking of outdated stuff? Center section f uel tanks vs. n > From: curtdm(at)gmail.com > Date: Thu=2C 27 Mar 2014 06:26:20 -0700 > To: pietenpol-list(at)matronics.com > .com> > > My theory of the elevator droop is it could be an optical illusion. The outboard line from the elevator and horizontal stabilizer is bent because o f the leading edge of the horizontal stabilizer not having the same span as the rest of the tail. > > I had this discussion and wanted to do some testing at Brodhead last year =2C but because of lack of time I was unable. > > I propose those who could=2C prior to Brodhead=2C set=2C their elevators in a faired (neutral) position and and somehow temporarily make a mark on their torque tube and the cable just above. > Then go fly and compare in cruise flight if the marks are aligned yet. I f not=2C make another mark to show the difference. > > Also while the tail is faired neutral on the ground=2C sit in the cockpit and look over your shoulder and look or take a picture of the tail and let us know what it looks like. Take pictures in slightly up and down elevato r position. > > This is a great exercise not only to prove my theory right/wrong=2C but a lso like Tom said=2C the tail should always be creating downforce while fly ing and if elevators are drooping=2C the horizontal stab might need some sh imming and re-rigging. > > My planes not flying and I'm definitely not an Opthamolagist=2C he'll I d on't even think I can spell. > > -------- > Curt Merdan > Flower Mound=2C TX > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421132#421132 > > > > > Attachments: > > http://forums.matronics.com//files/image_545.jpg > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
tanks vs. n
Date: Mar 27, 2014
In this picture, Lee Graybill, a retired AA pilot and longtime PT-22 flyer, pulled up alongside. He later told me, without being asked, that he had eyeballed my rigging and noted no elevator deflection, nor any aileron deflection (and was impressed with the 'look' of the plane!). Admittedly, I was pushing the airspeed a bit to the high 70's, as his Baby Ace is much faster. I believe it is Dick Navratil who gives a lecture at Brodhead about tweaking the horizontal stab to correct tail-low conditions. I believe that may be useful on some airplanes depending on weight and preferred flying speed. Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Phillips Sent: Thursday, March 27, 2014 6:15 AM Subject: RE: Pietenpol-List: Re: Speaking of outdated stuff? Center section fuel tanks vs. n OK Tom, You asked for it... I think the drooping elevator is largely a myth. From many angles, the elevator looks like it droops in flight because the reference that the eye has is the horizontal stabilizer. But the edge of the stabilizer is at an angle to the edge of the elevator, hence the appearance of a droop. Here are a few pictures from my files of Pietenpols in cruise flight: This shows the difference in angles I was talking about. See the angle of the edge of the horizontal stabilizer, compared to the edge of the elevator, which is straight? This is what creates the illusion of tail droop. Your eye tries to make the two edges line up. This one is a picture of Gene Rambo flying his son, Will, in my airplane. In this picture the horizontal tail is just about edge on, so the side of the stabilizer doesn't give the impression that the elevator is drooping. Looks pretty straight to me Here's another picture of my plane in flight: Here the angle is different and the side of the stabilizer does make it look like the elevator is slightly down, but I assure you it's not. Here's Mike Cuy's airplane, photo taken from mine. Note his tail - no droop. Here's Randy Bush's airplane, photo taken from Ryan Mueller's (now John Hofmann's) N502R. Notice the tail. Where's the supposed droop? Lastly, this picture shows Kevin Purtee on the left, Shad Bell in the center, and me on the right (photo taken by Bill Church during Brodhead 2011). You will note that my tail is slightly drooped with respect to the other two. The reason for this is that I was having to push my little Continental A65 for all it was worth to keep up with those two Corvair powered Pietenpols, and I had to hold the nose down to maintain my position in the formation and keep it from climbing at that speed. There may be a slight droop due to downwash from the wing, but other than that, I don't think the dreaded tail droop exists at all. Build it to the plans, and build it straight and it should fly just fine. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tkreiner Sent: Thursday, March 27, 2014 8:20 AM Subject: Pietenpol-List: Re: Speaking of outdated stuff? Center section fuel tanks vs. n Cliff, You ask, "Doesn't everything below it act like a pendulum? The short answer is NO, however that requires some explanation... In a most properly designed and built airplane - the designer sets CG so the plane is slightly nose heavy, which requires an equal and opposite tail down force in flight. Now on the surface this may appear to be a pendulum, but in fact, its quite different. The purpose of nose heavy, coupled with tail down force is what gives us pitch stability. In other words, the plane will tend to stabilize itself in flight when you take your hands off the stick -assuming, of course, that you've trimmed the plane for whatever pitch attitude you need. What is somewhat bothersome is that many on the list have indicated that the elevator on a Piet "droops" during flight, when in fact, the elevator should be slightly up, in which case it's providing the tail down force. Perhaps the horizontal stabilizer on the Piet is - HERESY COMING - improperly designed, but satisfactory. If the angle of incidence of the stab were changed somewhat, this condition would be corrected... Personally, I'd like for Jack Phillips and a few of the others to comment on the drooping issue, as I'd like to make sure the plane I build is flying "correctly." I KNOW, I KNOW, I KNOW, BUILD IT PER THE PLANS, AND IT WILL FLY.... that still doesn't satisfy the Mechanical Engineer I am.... just sayin. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421123#421123 ________________________________________________________________________________
vs. n
Date: Mar 27, 2014
Jack, I concur, it appears to be an optical illusion... But if that's the case, why does Dick N give a spiel on drooping at Brodhead? -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421139#421139 ________________________________________________________________________________
tanks vs. n
Date: Mar 27, 2014
Maybe he needs the money. Those forums pay incredibly well. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tkreiner Sent: Thursday, March 27, 2014 10:38 AM Subject: Pietenpol-List: Re: Speaking of outdated stuff? Center section fuel tanks vs. n Jack, I concur, it appears to be an optical illusion... But if that's the case, why does Dick N give a spiel on drooping at Brodhead? -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421139#421139 ________________________________________________________________________________
Date: Mar 27, 2014
Subject: Re: Weight & Balance Spreadsheet
But it shouldn't moving the axle forward help prevent noseovers? A La Cessna 120/140s? Blue Skies, Steve D On Sun, Mar 23, 2014 at 9:04 PM, Gary Boothe wrote: > > Moving the axel only changes the weight on the tail while on the > ground...not in the air. > > Gary > NX308MB > > Sent from my iPhone > > > On Mar 23, 2014, at 6:59 PM, "dgaldrich" > wrote: > > > dgaldrich(at)embarqmail.com> > > > > Waaiiit a minute. Moving the location of the wheels should have very > little, if any, effect on CG. What DOES change, from a CG perspective, > when you move the wheels forward is the weight on the tail wheel. A couple > of pounds increase makes a large difference since the arm is so long and > moving the wheels forward increases it. Using Jack's spreadsheet, I added > just 5 pounds to the tailwheel weight and it moved the CG aft by 1 inch. > That's 20% of the total allowable range. A Scott 2000 tailwheel from a > Piper Cub is about five pounds heavier than an original BHP tail skid. As > Jack, and others, have said, accurate measurement is important. Bathroom > scales are for my fat ass, not aircraft. > > > > You have correctly noticed that moving the wing also has almost a 1 for > 1 relationship to CG. Moving the wing aft 1 inch moves the CG almost 1 > inch forward and is by far the most effective way of achieving a correctly > balanced airplane. That's one of the advantages of this design is that > it's relatively easy to do since the cabanes are equal length and parallel, > more or less. > > > > Dave > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=420910#420910 > > > > > > > > > > > > > > > > > > > > > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Mar 27, 2014
Subject: Re: fuel tanks
Douwe-- I agree with you on the value of the head the wing tank provides--it was put there for Ford engines which don't have (and don't need complication of) a fuel pump. --Mac in Oregon > Both fuel tank locations have worked fine. Here's why I went with a wing > tank and like it. > > > 1. The fuel is farther from the hot engine and electrics in most > "unplanned attitudes" such as upside down or on it's nose, or in case of > an > engine fire. > 2. I have heard of too low fuel head pressure/fuel starvation issues > with fuselage tanks, but not with wing tanks. If you're building a big > fuse > tank, it can be tricky to design it so you get the head pressure you need. > It can certainly be done, just watch it in all attitudes. > 3. Fuel overhead or fuel in my lap can both be bad situations, but it's > all dependent on the incident and there's probably no way to foresee. > 4. zero CG shift from full to empty. > 5. I like the storage area up front. > > > In view of WW's accident and the very real potential for forward wing > displacement during a sudden stop, I strongly recommend flexible fuel > lines > to the tank. When 799B went over, the wing DID move forward about three > inches and my hard lines held fine, but when I rebuilt her, I was sure to > use flexible lines. > > > There are certainly pros for fuselage tanks too, but these are the reasons > I > went with a wing tank. > > > Douwe > > ________________________________________________________________________________
Date: Mar 27, 2014
Subject: Elevator droop
Date: Mar 27, 2014
Uh Oh........here are some photos of a to-the-plans, properly-built (and po wered) Pietenpol in flight. If I am not mistaken, I detect some elevator dr oop in all of them.You know, there are consequences, to making changes to t he original genuine BHP-authored plans. Just say'n. And by the way, what is all this talk of "improper" angle of incidence? ... .and "wrongly-designed" mounting-angle of the elevator? There is a lot of d issention on this list. Disturbing. Dan Helsper Puryear, TN ________________________________________________________________________________
Date: Mar 27, 2014
That's surprising -to me it is a bunch of people sharing ideas and concept s to better understand how things work. Sorry if that disturbs you. Subject: Pietenpol-List: Elevator droop From: danhelsper(at)aol.com Date: Thu=2C 27 Mar 2014 20:27:51 -0400 =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A Uh Oh........here are some photos of a to-the-plans=2C properly-built (and powered) Pietenpol in flight. If I am not mistaken=2C I detect some elevato r droop in all of them.=0A You know=2C there are consequences=2C to making changes to the original gen uine BHP-authored plans. Just say'n.=0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A And by the way=2C what is all this talk of "improper" angle of incidence? . ...and "wrongly-designed" mounting-angle of the elevator? There is a lot of dissention on this list. Disturbing.=0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A Dan Helsper=0A =0A =0A =0A =0A =0A =0A =0A Puryear=2C TN=0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A ________________________________________________________________________________
Subject: Re: Elevator droop
Date: Mar 27, 2014
Brian, You do understand there's a lot of tongue-in-cheek stuff that goes on here, r ight? Gary NX308MB Sent from my iPhone > On Mar 27, 2014, at 6:34 PM, Brian Kenney wrote: > > That's surprising -to me it is a bunch of people sharing ideas and concep ts to better understand how things work. Sorry if that disturbs you. > > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Elevator droop > From: danhelsper(at)aol.com > Date: Thu, 27 Mar 2014 20:27:51 -0400 > > > > Uh Oh........here are some photos of a to-the-plans, properly-built (and p owered) Pietenpol in flight. If I am not mistaken, I detect some elevator dr oop in all of them. You know, there are consequences, to making changes to t he original genuine BHP-authored plans. Just say'n. > > And by the way, what is all this talk of "improper" angle of incidence? .. ..and "wrongly-designed" mounting-angle of the elevator? There is a lot of d issention on this list. Disturbing. > > Dan Helsper > Puryear, TN > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Re: Elevator droop...zoom in
From: "M. Zeke Zechini" <marcus.zechini(at)gmail.com>
Date: Mar 27, 2014
Date: Mar 27, 2014
We're so bad! :-) Neither was I. Like you said, Just trying to nudge the collective grey matter... If God is your co-pilot...switch seats. Mike Perez Karetaker Aero STILL Building... ________________________________________________________________________________
Date: Mar 27, 2014
We're ALL so bad! :-) One really good thing is that without this discussion we wouldn't have been privy to some really great pics! Clif Not a shred of evidence exists in favor of the idea that life is serious. -Brendan Gill Brian, You do understand there's a lot of tongue-in-cheek stuff that goes on here, right? Gary NX308MB ________________________________________________________________________________
Date: Mar 27, 2014
No I thought my family invented it. That's why I left home. Sent from my iPad > On Mar 27, 2014, at 9:44 PM, "Gary Boothe" wrote: > > Brian, > > You do understand there's a lot of tongue-in-cheek stuff that goes on here , right? > > Gary > NX308MB > > Sent from my iPhone > >> On Mar 27, 2014, at 6:34 PM, Brian Kenney wrote: >> >> That's surprising -to me it is a bunch of people sharing ideas and conce pts to better understand how things work. Sorry if that disturbs you. >> >> To: pietenpol-list(at)matronics.com >> Subject: Pietenpol-List: Elevator droop >> From: danhelsper(at)aol.com >> Date: Thu, 27 Mar 2014 20:27:51 -0400 >> >> >> >> Uh Oh........here are some photos of a to-the-plans, properly-built (and p owered) Pietenpol in flight. If I am not mistaken, I detect some elevator dr oop in all of them. You know, there are consequences, to making changes to t he original genuine BHP-authored plans. Just say'n. >> >> And by the way, what is all this talk of "improper" angle of incidence? . ...and "wrongly-designed" mounting-angle of the elevator? There is a lot of d issention on this list. Disturbing. >> >> Dan Helsper >> Puryear, TN > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Corvair Mounts
Date: Mar 28, 2014
My new wide body 24 1/2 mount is completed by WW. He made a second while he had the jig set up and will have it at Sun-n-Fun if anyone is interested. It is listed here. http://www.flycorvair.com/products.html, it is part number 4201C. I elected to take delivery of my mount at Brodhead but if anyone in the Dayton, OH area is traveling to Sun n Fun and can bring it back to Ohio, I would be grateful. John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421192#421192 ________________________________________________________________________________
Subject: Steel-tube fuselage update - Major Welding Completed...!
Date: Mar 28, 2014
Hello good Piet-ple, Well, with one more full day of welding behind me I can report that the major fuselage structure is complete.....!!!! Now there is still a LOT more to go, with tabs, cable guides, more tabs, a few more things like the tailwheel spring fittings, more tabs.... however, the MAJOR structure is welded. (insert smile here...!) You can see the "extra" cross piece at both wing strut attach fitting locations. As I have said in other posts, this is not the ideal solution but the two tubes should add enough strength in those areas to work just fine. Glad to be enjoying this adventure. I appreciate the connection to many of you on this list that are on a similar journey - and those who have completed a Pietenpol and are enjoying the FLYING phase of your adventure...!! Jake -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421198#421198 Attachments: http://forums.matronics.com//files/_fuselage_welded_1_170.jpg http://forums.matronics.com//files/_fuselage_welded_2_107.jpg http://forums.matronics.com//files/_fuselage_welded_3_136.jpg ________________________________________________________________________________
Date: Mar 28, 2014
Looks Good Barry -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of aerocarjake Sent: Friday, March 28, 2014 10:51 AM Subject: Pietenpol-List: Steel-tube fuselage update - Major Welding Completed...! --> Hello good Piet-ple, Well, with one more full day of welding behind me I can report that the major fuselage structure is complete.....!!!! Now there is still a LOT more to go, with tabs, cable guides, more tabs, a few more things like the tailwheel spring fittings, more tabs.... however, the MAJOR structure is welded. (insert smile here...!) You can see the "extra" cross piece at both wing strut attach fitting locations. As I have said in other posts, this is not the ideal solution but the two tubes should add enough strength in those areas to work just fine. Glad to be enjoying this adventure. I appreciate the connection to many of you on this list that are on a similar journey - and those who have completed a Pietenpol and are enjoying the FLYING phase of your adventure...!! Jake -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421198#421198 Attachments: http://forums.matronics.com//files/_fuselage_welded_1_170.jpg http://forums.matronics.com//files/_fuselage_welded_2_107.jpg http://forums.matronics.com//files/_fuselage_welded_3_136.jpg ________________________________________________________________________________
Date: Mar 28, 2014
Subject: Re: Steel-tube fuselage update - Major Welding Completed...!
Hi Jake, WOW; your fuselage is really looking great. Beautiful welding. Jim B. =C2- ________________________________________________________________________________
Date: Mar 28, 2014
if you look at the website"the vintage aviator" you will see inflight pics of a fokker D-8 with exactly the same sort of droop on it's elevator. this is commonly seen on parasol type aircraft, and is a product of the interaction between the airflow coming off the trailing edge of the wing and the tail surfaces the piet airfoil has an umcommonly high cruising lift coefficient closely related to its large pitching moment. its a bit counterintuitive, you would think that in order to counter the more than 900 foot pounds of torque twisting on the wing at 80+ miles per hour that the elevator would be pointing up, but you don't generally see that unless the "decalage" is off or a nose heavy condition is present. this particular behavior is not by itself indicative of an aft of C.G but it's not an excuse to be an idiot and ignore or ridicule william wynnes heartfelt advice.just sayin. ________________________________________________________________________________
Date: Mar 28, 2014
stuff? Center section fuel tanks vs. n HAAA! I hear you Clif. (Enter M.J. music here...)-=0A=0AIf God is your co -pilot...switch seats.=0AMike Perez=0AKaretaker Aero=0ASTILL Building...=0A =0A=0A =0AWe're so bad! :-) ________________________________________________________________________________
Subject: More droopiness
Date: Mar 28, 2014
Here are a couple more. Dan Helsper Puryear, TN ________________________________________________________________________________
Date: Mar 28, 2014
I don't see any droop here, Dan. I see the illusion of droop, caused by the outboard edge of the stabilizer not being in line with the outboard edge of the elevator. Look at a picture where the horizontal tail is edge-on to the camera. Droop is an illusion, except for perhaps a slight amount due to the downwash from the wing. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of danhelsper(at)aol.com Sent: Friday, March 28, 2014 5:34 PM Subject: Pietenpol-List: More droopiness Here are a couple more. Dan Helsper Puryear, TN ________________________________________________________________________________
Date: Mar 28, 2014
Damn fine looking!! Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of danhelsper(at)aol.com Sent: Friday, March 28, 2014 2:34 PM Subject: Pietenpol-List: More droopiness Here are a couple more. Dan Helsper Puryear, TN ________________________________________________________________________________
Date: Mar 28, 2014
From: Yahoo! Account Service <skipgadd(at)earthlink.net>
Subject: Re: Corvair Mounts
John, We have been at Sun N Fun since January. We will be kind of tight driving the van home, but we may be able to get the mount in. If you don't get any other offers we could do the job. We will be heading to our WV home around April 15. We have bought a house in Miamisburg OH and will be heading there within a month of heading north. I'm sure I will be seeing William during the show. Skip PS Anyone looking for a great airport home in North West WV please email me. -----Original Message----- >From: john francis <Mrkringles(at)msn.com> >Sent: Mar 28, 2014 5:16 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Corvair Mounts > > >My new wide body 24 1/2 mount is completed by WW. He made a second while he had the jig set up and will have it at Sun-n-Fun if anyone is interested. It is listed here. http://www.flycorvair.com/products.html, it is part number 4201C. > >I elected to take delivery of my mount at Brodhead but if anyone in the Dayton, OH area is traveling to Sun n Fun and can bring it back to Ohio, I would be grateful. > >John > >-------- >John Francis > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=421192#421192 > > ________________________________________________________________________________
Subject: Re: More droopiness
Date: Mar 28, 2014
Hey Dan, I don't care about the slight droop, it just means you have a stable flight Ha. a little control pressure takes out some bumps. I have that beautiful picture you sent me . It is going on the wall in my work-shop. It will remind me what my goal is, and it will be something to point to when the non-airplane folks ask me what a pietenpol looks like. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421221#421221 ________________________________________________________________________________
Date: Mar 28, 2014
A little droopiness is normal. See attached photo of Bob Poore and me. Greg Cardinal ----- Original Message ----- From: danhelsper(at)aol.com To: pietenpol-list(at)matronics.com Sent: Friday, March 28, 2014 4:33 PM Subject: Pietenpol-List: More droopiness Here are a couple more. Dan Helsper Puryear, TN --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Date: Mar 28, 2014
Thanks - appreciate it....... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421228#421228 ________________________________________________________________________________
Date: Mar 28, 2014
Thanks Barry...... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421229#421229 ________________________________________________________________________________
Date: Mar 28, 2014
Is this where this list has gone now? A bunch of old men talking about droopiness....... Well I think there is a pill that help with that. Do not achieve.. From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Greg Cardinal Sent: Friday, March 28, 2014 7:37 PM Subject: Re: Pietenpol-List: More droopiness A little droopiness is normal. See attached photo of Bob Poore and me. Greg Cardinal ----- Original Message ----- From: danhelsper(at)aol.com <mailto:danhelsper(at)aol.com> Sent: Friday, March 28, 2014 4:33 PM Subject: Pietenpol-List: More droopiness Here are a couple more. Dan Helsper Puryear, TN _____ <http://www.avast.com/> This email is free from viruses and malware because avast! Antivirus <http://www.avast.com/> protection is active. ________________________________________________________________________________
Date: Mar 28, 2014
I don't think that the elevator is drooping the pilot is holding forward pr essure on the stick because of cg, stab angle, or maybe a big fat pilot who knows???=0AOn Saturday, March 29, 2014 12:27 AM, Chris wrote:=0A =0AIs this where this list has gone now?=C2- A bunch of old men talking about droopiness....... =0A=C2-=0AWell =C2-I think there is a pill that help with that.=0A=C2-=0ADo not achieve=0A =C2-=0AFrom:owner-pietenpol-list-server(at)matronics.com [mailto:owner-piete npol-list-server(at)matronics.com] On Behalf Of Greg Cardinal=0ASent: Friday, March 28, 2014 7:37 PM=0ATo: pietenpol-list(at)matronics.com=0ASubject: Re: Pi etenpol-List: More droopiness=0A=C2-=0AA little droopiness is normal.=0AS ee attached photo of Bob Poore and me.=0A=C2-=0AGreg Cardinal=0A----- Ori ginal Message ----- =0A>From:danhelsper(at)aol.com =0A>To:pietenpol-list@matro nics.com =0A>Sent:Friday, March 28, 2014 4:33 PM=0A>Subject:Pietenpol-List: More droopiness=0A>=C2-=0A>Here are a couple more.=0A>=C2-=0A>Dan Hels per=0A>Puryear, TN=0A=C2-=0A=0A________________________________=0A=0A Thi s email is free from viruses and malware because avast! Antivirus protectio n is active. ________________________________________________________________________________
Date: Mar 29, 2014
The slightly down elevator is its normal position in level flight. This due to the down pressure of the moving air cylinder coming off the wing an applying a slight pressure force of downward moving air on the top of the elevator. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421239#421239 ________________________________________________________________________________
Date: Mar 29, 2014
OK....I guess.....either that or its from my fat, like Mr. Hyde said. Why d oes somebody always have to bring that sensitive subject up? Dan Helsper Puryear, TN -----Original Message----- From: Jack Phillips <jack(at)bedfordlandings.com> Sent: Fri, Mar 28, 2014 5:33 pm Subject: RE: Pietenpol-List: More droopiness I don=99t see any droop here,Dan. I see the illusion of droop, cause d by the outboard edge of thestabilizer not being in line with the outboard edge of the elevator. Look at a picture where the horizontal tailis edge-on to the camera. Droop is an illusion, except for perhaps aslight amount due to the downwash from the wing. Jack Phillips NX899JP Smith Mountain Lake, Virginia From:owner-pietenpol-list-server(at)matronics.com[mailto:owner-pietenpol-list- server(at)matronics.com] On Behalf Of danhelsper(at)aol.com Sent: Friday, March 28, 2014 5:34PM Subject: Pietenpol-List: Moredroopiness Here are a couple more. Dan Helsper Puryear, TN ________________________________________________________________________________
Date: Mar 29, 2014
Hurry up and finish your Piet, so that you're not one of us old men talking a bout droopiness... Gary NX308MB Sent from my iPhone > On Mar 28, 2014, at 10:20 PM, "Chris" wrote: > > Is this where this list has gone now? A bunch of old men talking about dr oopiness....... > > Well I think there is a pill that help with that. > > Do not achieve > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Greg Cardinal > Sent: Friday, March 28, 2014 7:37 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: More droopiness
March 22, 2014 - March 29, 2014
Pietenpol-Archive.digest.vol-nj
