Pietenpol-Archive.digest.vol-no
June 28, 2014 - July 13, 2014
Subject: Pitot tube placement
Originally the Pitot tube ran up the left front strut to the bottom of the wing. I am looking at running the tube through the wing and would like to drop it down where the jury struts are. The jury struts look to be about 12 inches outside the prop arc. =0A Is this far enough out to be outside the prop wash? -- Blue Skies=2C Steve D =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Date: Jun 28, 2014
Subject: Re: Broadhead light this year???
I might be going, not sure yet.=0A-=0AShad =0A=0A=0AOn Saturday, June 28, 2014 11:30 AM, Jack Phillips wrote:=0A =0A=0A ngs.com>=0A=0AI most likely won't be there this year - the Bed & Breakfast is much busier=0Athan I expected and we have a full house that weekend.- If I get a chance to=0Aget away, I'll try to come up Friday for one night, but it will have to be=0Ain the RV4.=0A=0AJack Phillips=0ANX899JP=0ASmith M ountain Lake (W91), Virginia=0A=0A-----Original Message-----=0AFrom: owner- pietenpol-list-server(at)matronics.com=0A[mailto:owner-pietenpol-list-server@m atronics.com] On Behalf Of Douwe=0ASent: Saturday, June 28, 2014 9:47 AM=0A rg(at)earthlink.net>=0A=0ADang, I sure hope more of you than responded are fly ing up or it'll be a=0Avery light year!=0A=0ADouwe=0A=0ASent from my iPhone ======================== ________________________________________________________________________________
Subject: spring type spit axle
Date: Jun 29, 2014
Ive been working a little on my landing gear. Hope to get her standing up-right soon. I decided to go with the spring type suspension that William Wynne described to avoid bungee worries. It is a neat design although I'm not sure that it is Lighter. It will possible be heaver, but less drag. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425720#425720 Attachments: http://forums.matronics.com//files/spring_2_929.jpg ________________________________________________________________________________
Date: Jun 29, 2014
Subject: Re: spring type spit axle
Just a comment-- Looks great, but you won't gain much in the drag department unless you can put an airfoil shape onto that round tubing. --Mac in Oregon > > Ive been working a little on my landing gear. Hope to get her standing > up-right soon. I decided to go with the spring type suspension that > William Wynne described to avoid bungee worries. It is a neat design > although I'm not sure that it is Lighter. It will possible be heaver, > but less drag. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425720#425720 > > > Attachments: > > http://forums.matronics.com//files/spring_2_929.jpg > > ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Jun 29, 2014
Steve and Peter plan to fly their Corvair powered Piet from French Valley airport in CA. This is the one they trailerd back a few years ago. EAA chapter 1279 built it. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425729#425729 ________________________________________________________________________________
Date: Jun 29, 2014
Here are a few pics of the die spring landing gear struts-I built for the Baby Lakes.- Springs for-a Piet will need to be a little stiffer.- M cMaster Carr has many sizes and wt. ratings for springs, these were about $ 40 each if I remember correctly, and weigh about 1.5-2lbs each.- If you l ook closely at the the upper end of the 2nd pic you can see the solid barst ock welded into the tube, that is where the strut attaches to the fuselage. - The good thing about this setup is you can change the springs out if ne eded (too stiff, too soft) without cutting and welding. I have a similar ge ar on my Jungster, but there is no changing springs out without welding up a new upper tube.- If I like this gear I may build one for the Piet.=0A -=0AShad=0A-=0A-=0A-=0A- =0A=0A=0AOn Sunday, June 29, 2014 2:07 P M, "macz(at)peak.org" wrote:=0A =0A=0A=0A--> Pietenpol-List m essage posted by: macz(at)peak.org=0A=0AJust a comment--=0ALooks great, but yo u won't gain much in the drag department unless you can=0Aput an airfoil sh ape onto that round tubing.=0A--Mac in Oregon=0A=0A=0A=0A> --> Pietenpol-Li st message posted by: "aviken" =0A>=0A> Ive been wor king a little on my landing gear.- Hope to get her standing=0A> up-right soon.- I decided to go with the spring type suspension that=0A> William Wynne described to avoid- bungee worries.- - It is- a neat design =0A> although I'm not sure that it is- Lighter.- It will possible be he aver,=0A> but less drag.=0A>=0A>=0A>=0A>=0A> Read this topic online here: =0A>=0A> http://forums.matronics.com/viewtopic.php?p=425720#425720=0A>=0A >=0A>=0A>=0A> Attachments:=0A>=0A> http://forums.matronics.com//files/sprin ============= ________________________________________________________________________________
Subject: Re: Brodhead light this year
Date: Jun 29, 2014
I plan on flying out from Virginia, leaving Wed., the 23rd and arriving Thu rs. or Fri, depending on weather. Is there a group planning to fly to OSH on Sunday? Matt Paxton NX629ML ________________________________________________________________________________
Subject: Re: Engines
Date: Jun 29, 2014
The NZ Piets were/are powered by Toyota Hilux engines: http://nzcivair.blogspot.com/2013/07/pietenpol-aircampers-of-new-zealand.html I have no idea which of the many Hilux engines they used though. Over the years there were many variations, from 1.5L and on up. Most of them seem to make rated power at 4800 RPM but I don't see a reduction drive on the pictures of the NZ Piets, so who knows how much power they get out of them. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425737#425737 ________________________________________________________________________________
Date: Jun 29, 2014
OK... sorry... I found out that the Kiwi Piet uses the Toyota 22R engine but that still doesn't help figure out how much power it's making. They are variously rated at 97-108 HP at 4800-5000 RPM. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425740#425740 ________________________________________________________________________________
Date: Jun 29, 2014
Subject: Carlson streamline tubing - jury strut fittings.
A couple of pics of one way to do jury strut fittings.... Jim in Pryor, OK ________________________________________________________________________________
Date: Jun 29, 2014
I believe it is a 4Y engine which is a pushrod engine not with an overhead cam > Subject: Pietenpol-List: Re: Engines > From: taildrags(at)hotmail.com > Date: Sun=2C 29 Jun 2014 14:40:22 -0700 > To: pietenpol-list(at)matronics.com > > > OK... sorry... I found out that the Kiwi Piet uses the Toyota 22R engine but that still doesn't help figure out how much power it's making. They ar e variously rated at 97-108 HP at 4800-5000 RPM. > > -------- > Oscar Zuniga > Medford=2C OR > Air Camper NX41CC "=3BScout"=3B > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425740#425740 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jun 30, 2014
Subject: Re: Aluminum Wing Strut/Jury Strut Attachment
Thank you all for the ideas and pictures. I will be making straps and forgo the drill/eye bolt idea. Jim M., I like that way of making the straps...will be considering that idea more. If God is your co-pilot...switch seats. Mike Perez Karetaker Aero STILL Building... ________________________________________________________________________________
Date: Jun 30, 2014
From: Douwe Blumberg <douweblumberg(at)earthlink.net>
Subject: barnstorming fly in
I'm planning on flying up to the Barnstorming fly in in springfield with my daughter for Saturday, leaving Sunday IF the weather is nice. This'll only be her third flight so it needs to be smooth. might fly up Friday night, or super early Sat. Douwe ________________________________________________________________________________
Date: Jun 30, 2014
The article also mentions a Ford Cortina engine. Extensive research (Google) shows that the Cortina had a 1.7 or 2.0 liter engine. Would that be new to the engine list? Blue Skies, Steve D On Sun, Jun 29, 2014 at 7:50 PM, Brian Kenney wrote: > I believe it is a 4Y engine which is a pushrod engine not with an > overhead cam > > > Subject: Pietenpol-List: Re: Engines > > From: taildrags(at)hotmail.com > > Date: Sun, 29 Jun 2014 14:40:22 -0700 > > To: pietenpol-list(at)matronics.com > > > > > > > > > OK... sorry... I found out that the Kiwi Piet uses the Toyota 22R engine > but that still doesn't help figure out how much power it's making. They are > variously rated at 97-108 HP at 4800-5000 RPM. > > > > -------- > > Oscar Zuniga > > Medford, OR > > Air Camper NX41CC "Scout" > > > A75 power > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=425740#425740 > > > > > > > > > > > > > >========== > > > > > > > > * > > > * > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Jun 30, 2014
Subject: Re: barnstorming fly in
Dow that sounds great!! We will all look forward in seeing you and others a t the event. This is the first year to try this event so let's keep our fig ures crossed for good weather. So far, we have some really cool airplanes c oming to the event and if any more Piet's want to join, that would be GREAT . I know I plan on having mine there. Saturday morning the flight school wi ll be hosting a pancake breakfast in their hangar ( 8-11). General admissio n starts at 10 am ( Free) . During the event we plan on having a good selec tion of aircraft on display, some old cars in the parking lot, kids bounce house, rocket building workshop for some youngsters, biplane rides, ice cre am, model airplanes,and etc. Saturday night we will be showing -a outdoor movie ( Barnstorming) at Young's Dairy which has the best ice cream around . Fell free to call me if you have any questions. 937-877-0837=0A=0AThanks =0A-Dewey --=0Awww.barnstormingcarnival.com=0A=0A=0AOn Monday, June 3 0, 2014 7:49 AM, Douwe Blumberg wrote:=0A =0A arthlink.net>=0A=0AI'm planning on flying up to the Barnstorming fly in in springfield with my daughter for Saturday, leaving Sunday IF the weather is nice.- This'll only be her third flight so it needs to be smooth.- mig =========== ________________________________________________________________________________
Date: Jun 30, 2014
Forgot to mention. The control tower is closed on Weekends.=0A=0ADewey=0A =0A=0AOn , dewey davenport wrote:=0A =0A=0A=0ADow that sounds great!! We will all look forward in seeing you and others at the ev ent. This is the first year to try this event so let's keep our figures cro ssed for good weather. So far, we have some really cool airplanes coming to the event and if any more Piet's want to join, that would be GREAT. I know I plan on having mine there. Saturday morning the flight school will be ho sting a pancake breakfast in their hangar ( 8-11). General admission starts at 10 am ( Free) . During the event we plan on having a good selection of aircraft on display, some old cars in the parking lot, kids bounce house, r ocket building workshop for some youngsters, biplane rides, ice cream, mode l airplanes,and etc. Saturday night we will be showing -a outdoor movie ( Barnstorming) at Young's Dairy which has the best ice cream around. Fell f ree to call me if you have any questions. 937-877-0837=0A=0AThanks=0A-Dew ey --=0Awww.barnstormingcarnival.com=0A=0A=0AOn Monday, June 30, 2014 7 :49 AM, Douwe Blumberg wrote:=0A =0A=0A=0A--> Pietenpol-List message posted by: Douwe Blumberg <douweblumberg@earthlink. net>=0A=0AI'm planning on flying up to the Barnstorming fly in in springfie ld with my daughter for Saturday, leaving Sunday IF the weather is nice.- This'll only be her third flight so it needs to be smooth.- might fly up ________________________________________________________________________________
Date: Jun 30, 2014
I'm planning on flying my Piet up from Virginia, leaving Wednesday, the 23r d and arriving Thursday or Friday, depending on weather. Are there any plans to fly a group of Piets on Sunday to Oshkosh. I'm in fo r that. Matt Paxton NX629ML ________________________________________________________________________________
Date: Jun 30, 2014
From: "Charles N. Campbell" <charlescampbell1924(at)gmail.com>
I bought a set of Taylorcraft struts from a friend of mine who had to replace the struts on his T-craft, not because they had rusted out (There is absolutely no apparent rust inside the struts) but because the directive from the FAA said they had to be replaced. The front struts have the strap around them and I guess I'll have to make a strap for the rear struts. That is still a few weeks off. I had to take about a year off from building because of my wife's illness. She passed away in May of this year so I guess that I will have time to get back on the project now. On Mon, Jun 30, 2014 at 7:15 AM, Michael Perez wrote: > Thank you all for the ideas and pictures. I will be making straps and > forgo the drill/eye bolt idea. Jim M., I like that way of making the > straps...will be considering that idea more. > > If God is your co-pilot...switch seats. > Mike Perez > Karetaker Aero > STILL Building... > > > * > > > * > > ________________________________________________________________________________
Date: Jun 30, 2014
I don't know anything about a "group" fly up on Sunday, but I'm planning on heading out then, hopefully Jeff B will be as well. The Hatz guys have arranged some group parking for "vintage homebuilts" at the convention, and have invited us. A gent named Kevin Conner said he'd get hold of us during Brodhead with details. I've never flown in before, hoping to tag along with someone as I may not even have a radio! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425770#425770 ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Jun 30, 2014
Charles, I'm saddened to hear about your wife's passing. Hopefully she's in a better place now. I think you'll find working on your Pietenpol to be the best "Grief Therapy" you can find. Good luck to you. Jack Phillips NX899JP Smith Mountain Lake (W91), Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Charles N. Campbell Sent: Monday, June 30, 2014 10:29 AM Subject: Re: Pietenpol-List: Re: Aluminum Wing Strut/Jury Strut Attachment I bought a set of Taylorcraft struts from a friend of mine who had to replace the struts on his T-craft, not because they had rusted out (There is absolutely no apparent rust inside the struts) but because the directive from the FAA said they had to be replaced. The front struts have the strap around them and I guess I'll have to make a strap for the rear struts. That is still a few weeks off. I had to take about a year off from building because of my wife's illness. She passed away in May of this year so I guess that I will have time to get back on the project now. On Mon, Jun 30, 2014 at 7:15 AM, Michael Perez wrote: Thank you all for the ideas and pictures. I will be making straps and forgo the drill/eye bolt idea. Jim M., I like that way of making the straps...will be considering that idea more. If God is your co-pilot...switch seats. Mike Perez Karetaker Aero STILL Building... " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
From: "Dennis Engelkenjohn" <mushface1(at)gmail.com>
Subject: wing spars
Date: Jun 30, 2014
I am ordering the spruce for my spars today from Wicks but have some questions. Am building the 3 piece wing. The spar butt joint straps in the center section that connect the spars to the center section will require the ribs to be cut out to fit over them or the ribs will all have to be spaced 1/8=9D further apart front to rear with a strip of 1/8=9D X 4 3/4=9D plywood. Trying to determine which method to use. What is the best way or what have others done? Think I remember reading years back of the plywood method on this list. Dennis ________________________________________________________________________________
Date: Jun 30, 2014
After some research I did the following on my Piper struts. I stripped and derusted the outside. (I found wrapping them in aluminum foil while coated with stripper worked best. followed by steel wool. Then rustoleum self etching primer and White Rustoleum auto paint (rattlecan) Then I Then put a tiny light inside one end and took a look. Some rust but notihing bad. This plane was kept indoors. Then i plugged one end (with the threaded attachement) Bought Boiled Linseed oil (($19 per gallon, I would have preferred raw as it does not harden, but boiled is good also.) Heated the linseed oil up (in a big pot of water on a outdoor propane burner) to about 150F Used a funnel and hose to pour it inside each strut. (I put in way more than needed, but it is cheap) Plugged the holes with my gloved fingers and Rolled the struts all over the axis for about 5 minutes each. You could hear it slosh. Poured most out, but left some in and leaned them in the corner waiting to go to the airport. I will "reslosh" before I put them on. I put the extra back in the gallon can, so now I have 7/8ths of a gallon left. Too bad it cannot be used with Latex paint. I decided not to do the AD required Maule Fabric test on it for 2 reasons, 1. It beats up a $300 dollar Maule fabric tester and 2. It beats up your strut. THis test is where you put graph paper on the bottom end of the strut and punch the strut in each square, thin wall dents. I will borrow an ultrasonic metal thinckness tester and use that. Why linseed oil and not the newer oils? I looked at CorrosionX, LPS, ACF50 and several other products. None seemed to do much more than what the Linseed oil would do. It flows in well and (especially heated) fills all the little crevaces and seals holes. Then it hardens, first as it cools and then more as it ages, to a waxy oxygen barrier. (Raw stays more waxy, Boiled eventually gets hard.) So no more rust production without O2. Each year Just retreat, Cheap and predictable results. Blue Skies, Steve D. On Mon, Jun 30, 2014 at 9:28 AM, Charles N. Campbell < charlescampbell1924(at)gmail.com> wrote: > I bought a set of Taylorcraft struts from a friend of mine who had to > replace the struts on his T-craft, not because they had rusted out (There > is absolutely no apparent rust inside the struts) but because the directive > from the FAA said they had to be replaced. The front struts have the strap > around them and I guess I'll have to make a strap for the rear struts. > That is still a few weeks off. I had to take about a year off from > building because of my wife's illness. She passed away in May of this year > so I guess that I will have time to get back on the project now. > > > On Mon, Jun 30, 2014 at 7:15 AM, Michael Perez > wrote: > >> Thank you all for the ideas and pictures. I will be making straps and >> forgo the drill/eye bolt idea. Jim M., I like that way of making the >> straps...will be considering that idea more. >> >> If God is your co-pilot...switch seats. >> Mike Perez >> Karetaker Aero >> STILL Building... >> >> >> * >> >> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> tp://forums.matronics.com <http://forums.matronics.com/> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > > > * > > -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Re: Brodhead help
Date: Jun 30, 2014
Douwe, I plan to drive from Cincinnati to Brodhead this year. I should arrive in Brodhead on Saturday morning and will overnight before moving on up to Oshkosh for the week. I will send you my contact info to your e-mail. -------- David Gallagher Zodiac 601 XL-B: flying, 250+ hours now Next project under construction: Finish my father's Aircamper Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425776#425776 ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: steel tube jury strut idea, ala Aeronca Champ
Date: Jun 30, 2014
VGhpcyB3b3JrZWQgd2VsbCBmb3IgbXkgc3RyZWFtbGluZWQgc3RlZWwgbGlmdCBzdHJ1dHMuDQoN Ck1pa2UgQy4NCg0KT2hpbw0KDQoNCg0KDQo ________________________________________________________________________________
Date: Jun 30, 2014
well according to wikkepedia,the early 22r engines made 128 ftpounds at 2800 rpm(torque peak) thats about 68 HP. ________________________________________________________________________________
Subject: Engines
Date: Jun 30, 2014
Ivan Bellworthy's is a y4 http://www.toyota-industries.com/component/prod ucts/y4.html > From: smikewest(at)comcast.net > Subject: Re: Pietenpol-List: Engines > Date: Mon=2C 30 Jun 2014 17:36:15 -0500 > To: pietenpol-list(at)matronics.com > et> > > well according to wikkepedia=2Cthe early 22r engines made 128 ftpounds at 2800 rpm(torque peak) thats about 68 HP. > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jun 30, 2014
Subject: Brodhead & Oshkosh 2014
My partner Steve Williamson & I are planning to fly our Air Camper N1279Z to Brodhead leaving our home base F70 (Murrieta CA) on Sunday July 20th. We will route south of Phoenix, up the Rio Grande Valley to Tucumcari then NE to Brodhead. Along with our wives who are traveling by car we will stay at Brodhead until the 27th & then depart for Oshkosh leaving for the return journey on Monday August 4th. We hope to have the chance to meet a number of you & look forward to an opportunity to share memories of what should be a great adventure. Peter Griffiths N1279Z ________________________________________________________________________________
Subject: Re: Brodhead & Oshkosh 2014
Date: Jun 30, 2014
Peter and Steve, Enjoy the to flight. Looks like you are flying the route dad and I took in 96. Have fun. Cheers, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425801#425801 ________________________________________________________________________________
From: Peter Griffiths <peter.griffiths(at)roadrunner.com>
Date: Jun 30, 2014
Pretty much Peter Sent from my iPhone > On Jun 30, 2014, at 17:11, "AircamperN11MS" wrote: > > > Peter and Steve, > Enjoy the to flight. Looks like you are flying the route dad and I took in 96. Have fun. > Cheers, > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425801#425801 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 30, 2014
WOW, that's fantastic. Have a safe journey, make sure the ground crew knows how to post here to keep us updated... unless of course your Piet has a glass cockpit and you can do it enroute! Of course (Scott), two planes are (Scott) better than (Scott) one, and the mutual (Scott) backup would be (Scott) great... just (Scott) sayin'.. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425803#425803 ________________________________________________________________________________
Date: Jun 30, 2014
We may have CT Light Sport coming with us Peter N1279Z Sent from my iPhone > On Jun 30, 2014, at 18:03, "tools" wrote: > > > WOW, that's fantastic. Have a safe journey, make sure the ground crew knows how to post here to keep us updated... unless of course your Piet has a glass cockpit and you can do it enroute! > > Of course (Scott), two planes are (Scott) better than (Scott) one, and the mutual (Scott) backup would be (Scott) great... just (Scott) sayin'.. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425803#425803 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 30, 2014
O.K. i think you're on to something, i just posted about the 22r horsepower @2800RPM however, the 22r has the spark plugs on the other side of the motor than the one in the photo. ________________________________________________________________________________
Date: Jun 30, 2014
I missed the fly-in schedule.- Is it this weekend in Springfield Ohio? I missed any info on this.=0A-=0AShad =0A=0A=0AOn Monday, June 30, 2014 7:4 9 AM, Douwe Blumberg wrote:=0A =0A=0A=0A--> Pietenpol-List message posted by: Douwe Blumberg =0A=0AI'm planning on flying up to the Barnstorming fly in in springfiel d with my daughter for Saturday, leaving Sunday IF the weather is nice.- This'll only be her third flight so it needs to be smooth.- might fly up ========= ________________________________________________________________________________
Subject: Re: steel tube jury strut idea, ala Aeronca Champ
Date: Jun 30, 2014
I had intended to mention that the Aeronca does use an eye bolt through the m ain struts to secure the jury struts. The eye bolt does pass through a 3/16 I D tube that is welded through the strut. The Aeronca folks were pretty brave to do something that the Cub folks did not do! The bracket that Mike has dr awn certainly makes attachment of the jury strut to the spar very easy and c lean. Thanks, Ray Krause Building SkyScout...slowly Sent from my iPad > On Jun 30, 2014, at 2:22 PM, "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" wrote: > > This worked well for my streamlined steel lift struts. > > Mike C. > Ohio > > > ________________________________________________________________________________
Date: Jun 30, 2014
Sure wish I could go with them. It would most certainly be fun. While you guys are all having fun I will be moving to a new hangar. My hangar partner of 19 years is selling his plane. Time to get my own but smaller hangar. Another time maybe. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425809#425809 ________________________________________________________________________________
Subject: Tail wheel
Date: Jun 30, 2014
Hello everybody - I am new to this board - although I have been reading it for quite some time. I have been wanting to build a Pietenpol for about 5-6 years now and finally - I have been able to start a few months ago. Currently I have the tail section built and I am in the process of joining the fuselage together. - I will try to post some pics soon. Anyway enough introduction - this is my first aircraft project and so I will probably be asking for help often! ...and now for my first question! I am thinking through what I want to do for a tail wheel - for those who modified the "plans" tail skid with coil spring - where did you get your spring? What type of wheel did you use? I am thinking about the MATCO T-6 tail wheel with the plans built "A-frame/coil spring set-up" Has anyone used some non-Aircraft caster/wheel to build a "home-made" tail wheel? What is the advantage of using the "leaf" style spring/set-up? Any info/opinions would be welcome help to a newbie! Thanks, Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425811#425811 ________________________________________________________________________________
Subject: Re: Tail wheel
Date: Jun 30, 2014
Welcome and glad to hear that you are building. Where are you from? There are many good folks on this list. Some may be near you. Back to your question. I think Gary Boothe has been down the path you are asking about. He has flown his plane with both tail wheel scenarios you have mentioned. Gary, over to you now. BTW, I have a leaf spring on mine. Go to WWW.westcoastpiet.com. you will find a lot of info there. Cheers -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425812#425812 ________________________________________________________________________________
Date: Jun 30, 2014
I'm in the Milwaukee area (I will be flying out of Timmerman Field MWC when the ship is complete) It's great to live in WI because we are less than 2hours drive from EAA and Brodhead - my brother and I camp out each year at both events! - Hopefully soon I won't be driving - but rather flying to these events! Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425813#425813 ________________________________________________________________________________
Date: Jun 30, 2014
Welcome. I have the plans A frame with a Matco tail wheel. I really like it. It works very well. I did change from the pneumatic tire to a solid one because of several flat tires. The adaption was fairly simple. There are some pics on westcoastpiet. Example : http://www.westcoastpiet.com/images/WCP_2013_Gathering/IMG_0712.JPG Mike Groah 414MV Tulare CA Sent from my iPad > On Jun 30, 2014, at 7:58 PM, "AircamperN11MS" wrote: > > > Welcome and glad to hear that you are building. Where are you from? There are many good folks on this list. Some may be near you. > Back to your question. I think Gary Boothe has been down the path you are asking about. He has flown his plane with both tail wheel scenarios you have mentioned. > Gary, over to you now. > > BTW, I have a leaf spring on mine. Go to WWW.westcoastpiet.com. you will find a lot of info there. > > Cheers > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425812#425812 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 30, 2014
That seems to be a nice set-up... Where are you guys getting the spring? Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425816#425816 ________________________________________________________________________________
Date: Jun 30, 2014
Thank you, Scott! Let's hear it for Scott Liefeld [BIG applause]... Andy, Welcome to the best 4-6 years of your life!...or, as with some, the best 16 years of your life! Yes, I have been down two roads when it comes to tail wheels. That's not that unusual, either. There are builders here who share my experience...and those who have experienced the inverse (going from leaf spring back to A-frame!). Simply put, there is nothing wrong with Mr. Pietenpol's A-frame design. Mike Groah is a good example. His plans-built tail wheel gear sports a Matco 4" pneumatic wheel...and functions perfectly. Kevin Purtee did as I, and abandoned his A-frame for a leaf spring and a 4" Matco tail wheel and liked the result. So far, I am ecstatic with mine! "Ecstatic"...was that too much emotion? My main gear is pretty narrow...about 52". My tail wheel was the small experimental one from ACS, with my own hand made swivel, ears, etc. Cable linkage was provided from the rudder pedals, which had spring returns. All these things added to my early difficulties, and I drug wing tips 3 different times, plus my 15,000 hr test pilot/instructor drug a wing tip once! William Wynn says that, with my narrow gear, if I can fly the past 20+ hrs and only drag 3 tips without ground looping, I could land a P51 with a flat tire! Well, we know that ain't true...but you get the point. I have a plan to widen the gear, which will happen this Winter, but I have changed the tail wheel to a leaf spring and a Matco 4" solid wheel. Moving the wheel that far back allowed me to hook directly to a rudder bar (see attached). I have since tightened those springs. I can now drop in from 5' (not that I would ever do that...;-)), and the tail no longer wanders. Yes, "ecstatic" is the word I would use! >From what I have seen, making your own mounting device, using the plans design...those are not the issues. I could never tighten up my tail wheel cables because to do so would loosen the rudder cables. That was caused by the spring returns that I have on the pedals. Other designs would work just fine. BTW...I think 6" is too big. Enjoy your dream and your planning...but, GET TO WORK!! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Monday, June 30, 2014 7:59 PM Subject: Pietenpol-List: Re: Tail wheel --> Welcome and glad to hear that you are building. Where are you from? There are many good folks on this list. Some may be near you. Back to your question. I think Gary Boothe has been down the path you are asking about. He has flown his plane with both tail wheel scenarios you have mentioned. Gary, over to you now. BTW, I have a leaf spring on mine. Go to WWW.westcoastpiet.com. you will find a lot of info there. Cheers -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425812#425812 ________________________________________________________________________________
Date: Jun 30, 2014
The bad news... this one question is gonna yield a dozen or so answers... The good news... this is EXACTLY the kind of thing you go to Brodhead to help you decide what you wanna try! I've got a Matco, 4" solid, 2 leafs, cables directly from the rudder bar. Probably about as "modern standard" as it gets. My son and I both learned to fly tailwheel with this setup. I like it alot. I have no experience with the more authentic A frame setup whatsoever. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425818#425818 ________________________________________________________________________________
Date: Jul 01, 2014
One point to keep in mind is the material of the struts. The Aeronca design, as illustrated by Mike, is used on steel struts. Welds in steel, when done properly, are as strong as the base metal. Aluminum, however, is a different story. Some alloys of aluminum are greatly affected by welding. When Alloy 6061-T6 (which is the alloy that Carlson Struts are made of) is welded, the base material loses its temper in the weld zone - effectively reducing the strength to approximately 25% of the original strength. This strength can be restored, through heat treating, but this is an expensive process. Best to avoid welding 6061-T6 in any area where strength is a concern. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425826#425826 ________________________________________________________________________________
Subject: Tail wheel
Date: Jul 01, 2014
Andy, I noticed nobody has answered your question as to where to get the compression spring. I know many have used a spring from John Deere, but they are very proud of their parts and charge accordingly. I used a compression spring from McMaster-Carr: http://www.mcmaster.com/#compression-springs/=snaoy4 . The one I used was part number 96485K141. it is 6" long overall, with an outside diameter of 1.93", a wire diameter of .25" and a spring constant of 116 lbs per inch. It costs $11.17 and works very well. Just to confuse you further, I originally had a 6" Scott tailwheel on a leaf spring from a Piper PA-12. After a forced landing which caused a groundloop, the leaf spring was torn from the lower longerons, resulting in substantial damage to the longerons - which is something to think about. Most leafsprings are designed to attach to welded steel tube fuselages. You can do it with wood, but the attach structure needs to be well thought out (mine obviously wasn't). During the rebuild, I changed to the A-Frame design. The first one I built strictly to the plans. I found that it was too wimpy torsionally, and steering loads on the tailwheel (which that design was never intended to withstand, since it was designed for a skid with no steering loads) caused the whole A-Frame to twist. Here is a picture of the first A-Frame I built: Note that I had the tailwheel aft of the compression spring, which I'm sure exacerbated the twisting problems. I flew this assembly for about 4 hours and then one day while taxiing for takeoff the tailwheel simply broke off as I turned around for my runup. Glad that didn't happen on landing! I rebuilt the tailwheel assembly using an A-Frame of heavier tubing, and with a crossbar at the front, making it a rigid triangle. I also moved the tailwheel underneath the compression spring. This assembly has worked well for over 300 hours and many bad landings. It also uses the 4" "Homebuilder's Special" tailwheel from ACS that is not entirely satisfactory. It tends to go into free swivel very easily when turning left, and is difficult to break into free swivel when turning right. I probably need to take it apart and make some adjustments Good luck, and welcome to the wonderful world of Pietenpols and Pietenpeople! Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake (W91), Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AG Sent: Monday, June 30, 2014 10:44 PM Subject: Pietenpol-List: Tail wheel Hello everybody - I am new to this board - although I have been reading it for quite some time. I have been wanting to build a Pietenpol for about 5-6 years now and finally - I have been able to start a few months ago. Currently I have the tail section built and I am in the process of joining the fuselage together. - I will try to post some pics soon. Anyway enough introduction - this is my first aircraft project and so I will probably be asking for help often! ...and now for my first question! I am thinking through what I want to do for a tail wheel - for those who modified the "plans" tail skid with coil spring - where did you get your spring? What type of wheel did you use? I am thinking about the MATCO T-6 tail wheel with the plans built "A-frame/coil spring set-up" Has anyone used some non-Aircraft caster/wheel to build a "home-made" tail wheel? What is the advantage of using the "leaf" style spring/set-up? Any info/opinions would be welcome help to a newbie! Thanks, Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425811#425811 ________________________________________________________________________________
Date: Jul 01, 2014
Hi Andy, welcome aboard! The tailwheel spring you can get from John Deere- The part number is T143444 Think it was about 50 bucks- I don't have the sizes in front of me, but it is slightly larger in diameter than what is called for in the plans, so the Tubing for the cups that the springs go into needs to be slightly larger as well -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425829#425829 ________________________________________________________________________________
Date: Jul 01, 2014
Yes, the Ford Cortina engine is already on the list. John Fay in Peoria On Mon, Jun 30, 2014 at 7:22 AM, Steven Dortch wrote: > The article also mentions a Ford Cortina engine. Extensive research > (Google) shows that the Cortina had a 1.7 or 2.0 liter engine. Would that > be new to the engine list? > > Blue Skies, > Steve D > > On Sun, Jun 29, 2014 at 7:50 PM, Brian Kenney > wrote: > >> I believe it is a 4Y engine which is a pushrod engine not with an >> overhead cam >> >> > Subject: Pietenpol-List: Re: Engines >> > From: taildrags(at)hotmail.com >> > Date: Sun, 29 Jun 2014 14:40:22 -0700 >> > To: pietenpol-list(at)matronics.com >> >> > >> taildrags(at)hotmail.com> >> > >> > OK... sorry... I found out that the Kiwi Piet uses the Toyota 22R >> engine but that still doesn't help figure out how much power it's making. >> They are variously rated at 97-108 HP at 4800-5000 RPM. >> > >> > -------- >> > Oscar Zuniga >> > Medford, OR >> > Air Camper NX41CC "Scout" >> >> > A75 power >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=425740#425740 >> > >> > >> > >> > >> > >> > >> >========== >> > >> > >> > >> >> * >> >> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> ttp://forums.matronics.com <http://forums.matronics.com/> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > > > -- > Blue Skies, > Steve D > > * > > > * > > ________________________________________________________________________________
Subject: Tail wheel
Date: Jul 01, 2014
Welcome aboard Andy! Search the archives and you'll assuredly find discussion about where guys found their springs. I've heard a John Deere spring and others, just don't recall specifics I have the plans unit and made up my own tail wheel using a small wheel from McMaster Carr. My humble observations thru the years is that the plans design is very good, just needs a cross piece added ahead I'd the wheel since it wasn't designed for steering loads originally. I feel it is actually stronger in a side load condition and light. Douwe Sent from my iPhone ________________________________________________________________________________
Date: Jul 01, 2014
Hello Andy. Later this month will mark my 6th year of building. I am curren tly doing a full assembly of the plane needed to measure/layout and fabrica te the last few items and to get an initial W&B.- It has all gone by quit e fast.=0A=0A=0AThe spring I used is from a John Deere tractor. I bought tw o of them new and if interested, I can get the part number from the spare I have at home.- I am using the small homebuilders tail wheen from ACS, it is a 4" wheel...I agree that 6" would be a too big and heavy. You can see from the pictures that I made my own steerable tail wheel assembly and adap ted the homebuilders wheel. I also modified the "A" frame mounts at the fus elage to wrap around the frame and use through bolts. The ends of the "A" f rame were modified with the tube-through-tube idea used on the control torq ue tube assembly.-=0A=0AIf you have been following the list some, you may have seen the posts concerning rudder control horn attachment. That thread progressed into tail wheel cables and the like which you may find interest ing.=0A=0AI can't compare the "A" arm set-up to the leaf spring as I don't have any experience with it.=0A=0A=0AHaving not been flight tested, none of this may be worth much, but it may get you to consider other ideas.=0A- =0A=0AIf God is your co-pilot...switch seats. =0AMike Perez =0AKaretaker Ae ro =0ASTILL Building...=0A ________________________________________________________________________________
Date: Jul 01, 2014
Bill, Thanks, great information. Bicycle frames are often made from 6061-T6 (many Raleigh bikes that I sold in a past life). The welding was once done in the USA but is now all done in China. The welds are beautiful and the frames are heat treated after welding, as I remember. There are several ways of doing this, but I don't remember! Is one purging the frames with non-oxygen gas during welding? Seems like something the home builder should be able to do at home! Gary Booth put me in contact with a friend of his who had a supply of strut aero aluminum in his hanger. I got enough for my SkyScout at a good price. Guess I will use straps for the jury strut attach points since my purge tanks are low and the struts won't fit in my wife's oven! Thanks, Ray Krause Sent from my iPad > On Jul 1, 2014, at 4:58 AM, "Bill Church" wrote: > > > One point to keep in mind is the material of the struts. > The Aeronca design, as illustrated by Mike, is used on steel struts. Welds in steel, when done properly, are as strong as the base metal. > Aluminum, however, is a different story. Some alloys of aluminum are greatly affected by welding. When Alloy 6061-T6 (which is the alloy that Carlson Struts are made of) is welded, the base material loses its temper in the weld zone - effectively reducing the strength to approximately 25% of the original strength. This strength can be restored, through heat treating, but this is an expensive process. Best to avoid welding 6061-T6 in any area where strength is a concern. > > Bill C. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425826#425826 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 01, 2014
Ray, No, unfortunately it isn't as simple as purging. Effectively, when 6061-T6 gets welded, the metal in the weld zone loses all of its tempering, and goes back to the annealed state (T-zero). In order to return to T6 temper, the weldment will need to be solution heat treated, and then artificially aged. Solution heat treatment involves carefully heating the weldment in an oven to a pretty high temperature, around 980F (too hot and the aluminum just melts), and held for about an hour, then quickly cooled, by quenching. Once returned to room temperature, the aluminum is again heated, and held at a set temperature for a specified time. For aging, the temperatures are in the range of typical kitchen ovens ( 325 - 400F). When you stick a toothpick in, and it comes out dry, you're done. (just kidding about the toothpick test). So, I doubt that any homebuilder is going to be up to the task of re-tempering aluminum lift struts after welding. For those using aluminum struts, fabricating a few strap fittings would be a much less daunting task Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425859#425859 ________________________________________________________________________________
Date: Jul 01, 2014
Gary, You are very welcome. :) The bus I threw you under looked like a small one from where I was standing, But, perhaps it was further down the street and bigger than I thought when I glanced at it. Hope you just got bruised a little and didn't get any broken bones. Just the devil inside me I guess, Cheers, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425866#425866 ________________________________________________________________________________
Date: Jul 01, 2014
It was no problem, Scott! Re-telling the story helps to remind me of the travelled road...a road I am very fortunate to be on!! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Tuesday, July 01, 2014 12:00 PM Subject: Pietenpol-List: Re: Tail wheel --> Gary, You are very welcome. :) The bus I threw you under looked like a small one from where I was standing, But, perhaps it was further down the street and bigger than I thought when I glanced at it. Hope you just got bruised a little and didn't get any broken bones. Just the devil inside me I guess, Cheers, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425866#425866 ________________________________________________________________________________
Date: Jul 01, 2014
Wow - this board is great - Thanks for all the info! and - here's another question. I have heard some opinions that connecting the tail wheel directly to the rudder will put too much stress on the rudder. I got some drawings from Bill Rewey for a set-up which runs a separate set of cables from the tail wheel up to just behind the pilot's seat and then connects them there with split-bolt connectors to the main rudder cables. Obviously you guys are flying with the direct connection - any problems with that? Thanks Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425889#425889 ________________________________________________________________________________
Date: Jul 01, 2014
Andy, Pay no attention to the way mine is hooked up. I have a steel tube fuse and tail feathers. Totally different than most all other piets. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425892#425892 ________________________________________________________________________________
Date: Jul 01, 2014
Thanks, Bill. I wonder how a bicycle mfg could afford to do all that? There is no that much profit in a $300.00 bike! Maybe if you are set up for it and can handle large volumes, that would do it. I'm sorry to hear you lost your wife. That almost happened to me last year, so I understand. Thanks for taking the time to explain all that. Ray Krause Sent from my iPad > On Jul 1, 2014, at 10:19 AM, "Bill Church" wrote: > > > Ray, > No, unfortunately it isn't as simple as purging. > Effectively, when 6061-T6 gets welded, the metal in the weld zone loses all of its tempering, and goes back to the annealed state (T-zero). > In order to return to T6 temper, the weldment will need to be solution heat treated, and then artificially aged. Solution heat treatment involves carefully heating the weldment in an oven to a pretty high temperature, around 980F (too hot and the aluminum just melts), and held for about an hour, then quickly cooled, by quenching. Once returned to room temperature, the aluminum is again heated, and held at a set temperature for a specified time. For aging, the temperatures are in the range of typical kitchen ovens ( 325 - 400F). When you stick a toothpick in, and it comes out dry, you're done. (just kidding about the toothpick test). > So, I doubt that any homebuilder is going to be up to the task of re-tempering aluminum lift struts after welding. For those using aluminum struts, fabricating a few strap fittings would be a much less daunting task > > Bill C. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425859#425859 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 01, 2014
Yikes, Ray. I didn't lose my wife. Haven't even misplaced her. I think maybe you've got me mixed up with Chuck Campbell. I believe he recently mentioned his wife's passing. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425897#425897 ________________________________________________________________________________
Subject: Tailwheel steering
Date: Jul 02, 2014
Andy I personally like a separate set of cables to steer the tailwheel and have been happy with it. I set it up just like bill rewey did. One often overlooked issue is steering ratio. To avoid an overly squirrelly steering response the wheel should turn the same ratio (or even less IMHO) than the rudder. This requires the wheel steering horns be the same length as on the rudder I used a 3" wheel to keep weight down and everyone told me it wouldn't have steering authority and it would wear out real quick but it's working great. I just bought ten at the same time thinking I'd change it each season and haven't changed it after about 75hrs I just don't think we really need these big honkin' wheels back there $.02 Douwe Sent from my iPhone ________________________________________________________________________________
Date: Jul 02, 2014
Ray-I spliced in (nicopress sleeve) a separate set of cables like Bill Rewe y, Douwe, & others have done to the rudder control cables just under the pilot seat and they have worked very well over the ye ars. Be sure to follow the guidelines that Tony Bingelis outlines in his Sportpl ane Builder series of books on the proper selection and installation of aircraft cables and pullies and especially pulley guard saf ety straps/wires when installling these cables (and all other cables as wel l) and you'll have many years of worry-free and trouble-free flying. Mike C. Ohio [cid:image001.jpg(at)01CF95D2.D41A2DF0] -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Douwe Sent: Wednesday, July 02, 2014 8:20 AM Subject: Pietenpol-List: Tailwheel steering --> > Andy I personally like a separate set of cables to steer the tailwheel and have been happy with it. I set it up just like bill rewey did. One often overlooked issue is steering ratio. To avoid an overly squirrell y steering response the wheel should turn the same ratio (or even less IMHO ) than the rudder. This requires the wheel steering horns be the same leng th as on the rudder I used a 3" wheel to keep weight down and everyone told me it wouldn't have steering authority and it would wear out real quick but it's working great . I just bought ten at the same time thinking I'd change it each season an d haven't changed it after about 75hrs I just don't think we really need these big honkin' wheels back there $.02 Douwe Sent from my iPhone ________________________________________________________________________________
Date: Jul 02, 2014
From: santiago morete <moretesantiago(at)yahoo.com.ar>
Subject: Trip to Brodhead
Hi everyone!=0AI'll be traveling to the USA and visiting Brodhead for just one day. This is my second time, first was in 2008 and had a wonderful expe rience thanks to Dan Helsper and his family. This year I'll be there with m y girlfriend Paula and a very special lady, Betty, Dan's mother.=0A=0AAs so me of you know, I'm from Argentina and have been building a Model A powered Piet since september 2004. The airframe is finished and all covered but I' m waiting for the engine to be assembled.-=0A=0AThere are some items I wo uld like to acquire while in the USA. If any of you have a decent set of pl ans to sell, I'll be happy to buy them, mine are very worn-out and I would like to have a new set to preserve. Also I'm looking for two nice goggles ( e.g. Halcyon, Climax). We are not allowed to import things freely here, so I don't mind to pay the full "store" price for these items.-=0A=0AI hope to meet as many of you as possible.=0ASaludos!=0A=0ASantiago ________________________________________________________________________________
Subject: ###4th FLIGHT###
Date: Jul 02, 2014
Just a short clip of what's going on. I took everybody suggestions.....I twisted the tail, added a shim and still no change. Terrible stick pressure to keep the nose up. Re-checked weight and balance and yes it is forward at 15.9" I bought two lead shot bags at 25 lbs each and that's the next step is to put one along side of the driver and see if it make s a change, one at a time. On a funny note, im the only guy with a nose heavy Pietenpol!! should have built the long fuse version! http://youtu.be/o02X2V7F4VM -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425917#425917 ________________________________________________________________________________
Subject: Re: ###4th FLIGHT###
Date: Jul 02, 2014
You're not the only one. My cg is also towards the front of the envelope. I have a long fuse, Corvair powered Piet. I have my horizontal twisted to compensate. I moved my wing too far back in the build and I think this winter I'll move my wing forward some so I can take the twist out of the stab. It flies nice how it is though. I had the engine shut down on take off due to carb ice while taking my first passenger up (my wife). With the forward cg the nose came right down and was very controllable. We made a safe landing off airport and yes, my wife still flies with me. Mike Groah Tulare CA 414MV Sent from my iPad > On Jul 2, 2014, at 7:23 AM, "Chris Rusch" wrote: > Me. > > Just a short clip of what's going on. > I took everybody suggestions.....I twisted the tail, added a shim and still no change. Terrible stick pressure to keep the nose up. > Re-checked weight and balance and yes it is forward at 15.9" > I bought two lead shot bags at 25 lbs each and that's the next step is to put one along side of the driver and see if it make s a change, one at a time. > > On a funny note, im the only guy with a nose heavy Pietenpol!! should have built the long fuse version! > > > http://youtu.be/o02X2V7F4VM > > -------- > NX321LR > Now test flying!! > Mitsubishi Powered > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425917#425917 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 02, 2014
Don't think this one has actually taken flight (yet). But if/when it does, I'm sure it will be a "first". http://msumadvocate.com/2013/10/22/its-electric-physics-prof-builds-experimental-plane/ Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425927#425927 ________________________________________________________________________________
Date: Jul 02, 2014
Move the wing forward.... Gene On Jul 2, 2014, at 10:23 AM, "Chris Rusch" wrote: > > Just a short clip of what's going on. > I took everybody suggestions.....I twisted the tail, added a shim and still no change. Terrible stick pressure to keep the nose up. > Re-checked weight and balance and yes it is forward at 15.9" > I bought two lead shot bags at 25 lbs each and that's the next step is to put one along side of the driver and see if it make s a change, one at a time. > > On a funny note, im the only guy with a nose heavy Pietenpol!! should have built the long fuse version! > > > http://youtu.be/o02X2V7F4VM > > -------- > NX321LR > Now test flying!! > Mitsubishi Powered > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425917#425917 > > > > > > > > > > > ________________________________________________________________________________
Subject: Chris Rusch stick-nose heavy conditioin
Date: Jul 02, 2014
Chris-forgive me if this has already been covered but your rear cabane stru t is one inch shorter than the front strut yes as the plans show? I agree with Gene that moving the wing forward should help but your 25 poun d bags of shot next to you in the rear seat should be (one at a time as you say) a very good experiment. You're probably one of the few Pietnpol pilots who actually has a very dece nt, even possibly a low, body mass index! I'd gladly fly your Pietenp ol around to let you know what 210 pounds in the rear seat will do for your st ick/CG forces:) ! You are doing GREAT. Your plane is stunningly beautiful, you are breakin g great new ground with that Mitsubishi engine, and your video is excellent and I'm sure it will inspire those new to the list to keep on building! Mike C. Ohio PS- I can send you my diet plan if you like......:) ! https://www.youtube.com/watch?v=o02X2V7F4VM&feature=youtu.be ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Date: Jul 02, 2014
I am pulling the plug on my 2014 flight to Brodhead and Oshkosh. We=92ve ha d a serious setback at work, an administrative self-inflicted wound that is badly affecting my program (over half the income to the lab). I can=92t be away from the group until it=92s resolved, and that doesn=92t look to be h appening any time soon. I=92m probably going to have to pull the plug on a professional trip that was also planned for this month, so this isn=92t jus t affecting =93play time." Big, big bummer. You guys have a great time and please send photos, movies, and commentary! Sent from an iPhone with a spelling problem On Jun 30, 2014, at 10:00 AM, "woodflier" > wrote: I'm planning on flying my Piet up from Virginia, leaving Wednesday, the 23r d and arriving Thursday or Friday, depending on weather. Are there any plans to fly a group of Piets on Sunday to Oshkosh. I'm in fo r that. Matt Paxton NX629ML ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Jul 02, 2014
On 07/02/2014 10:56 AM, Gene Rambo wrote: > > Move the wing forward.... That's what I was going to say. From the video we see that you've slanted the cabanes back - that's only necessary with the lighter Continentals. How much shorter are your rear cabanes? > > Gene > > On Jul 2, 2014, at 10:23 AM, "Chris Rusch" wrote: > >> >> Just a short clip of what's going on. >> I took everybody suggestions.....I twisted the tail, added a shim and still no change. Terrible stick pressure to keep the nose up. >> Re-checked weight and balance and yes it is forward at 15.9" >> I bought two lead shot bags at 25 lbs each and that's the next step is to put one along side of the driver and see if it make s a change, one at a time. >> >> On a funny note, im the only guy with a nose heavy Pietenpol!! should have built the long fuse version! >> >> >> http://youtu.be/o02X2V7F4VM >> >> -------- >> NX321LR >> Now test flying!! >> Mitsubishi Powered >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=425917#425917 >> >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Jul 02, 2014
Jeff, I'm sorry you can't make it. Have you ever been to the Triple Tree F ly-In in South Carolina. I went last year, good time and by September maybe your issues will be fixed. That 7000' grass runway is like a putting green . I may try that in the Piet this year. Matt Paxton Fairfield, VA NX629ML -----Original Message----- From: Boatright, Jeffrey <jeffboatright(at)emory.edu> Sent: Wed, Jul 2, 2014 1:50 pm Subject: Re: Pietenpol-List: Re: Brodhead light this year I am pulling the plug on my 2014 flight to Brodhead and Oshkosh. We =99ve had a serious setback at work, an administrative self-inflicted wound that is badly affecting my program (over half the income to the lab). I ca n=99t be away from the group until it=99s resolved, and that do esn=99t look to be happening any time soon. I=99m probably goin g to have to pull the plug on a professional trip that was also planned for this month, so this isn=99t just affecting =9Cplay time." Big, big bummer. You guys have a great time and please send photos, movies, and commentary! Sent from an iPhone with a spelling problem On Jun 30, 2014, at 10:00 AM, "woodflier" wrote: I'm planning on flying my Piet up from Virginia, leaving Wednesday, the 23r d and arriving Thursday or Friday, depending on weather. Are there any plans to fly a group of Piets on Sunday to Oshkosh. I'm in fo r that. Matt Paxton NX629ML ">http://www.matronics.com/Navigator?Pietenpol-List ics.com .matronics.com/contribution This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Jul 02, 2014
Hi Matt, I haven't been to Triple Tree, but two of my hangar mates went last year, s o it is on my calendar for this year. Hope to see you there. Jeff Sent from an iPhone with a spelling problem On Jul 2, 2014, at 2:20 PM, "woodflier" @aol.com>> wrote: Jeff, I'm sorry you can't make it. Have you ever been to the Triple Tree Fl y-In in South Carolina. I went last year, good time and by September maybe your issues will be fixed. That 7000' grass runway is like a putting green. I may try that in the Piet this year. Matt Paxton Fairfield, VA NX629ML -----Original Message----- From: Boatright, Jeffrey <jeffboatright(at)emory.edu<mailto:jeffboatright@emor y.edu>> etenpol-list(at)matronics.com> Sent: Wed, Jul 2, 2014 1:50 pm Subject: Re: Pietenpol-List: Re: Brodhead light this year I am pulling the plug on my 2014 flight to Brodhead and Oshkosh. We=92ve ha d a serious setback at work, an administrative self-inflicted wound that is badly affecting my program (over half the income to the lab). I can=92t be away from the group until it=92s resolved, and that doesn=92t look to be h appening any time soon. I=92m probably going to have to pull the plug on a professional trip that was also planned for this month, so this isn=92t jus t affecting =93play time." Big, big bummer. You guys have a great time and please send photos, movies, and commentary! Sent from an iPhone with a spelling problem On Jun 30, 2014, at 10:00 AM, "woodflier" > wrote: I'm planning on flying my Piet up from Virginia, leaving Wednesday, the 23r d and arriving Thursday or Friday, depending on weather. Are there any plans to fly a group of Piets on Sunday to Oshkosh. I'm in fo r that. Matt Paxton NX629ML ">http://www.matronics.com/Navigator?Pietenpol-List ics.com<http://ics.com> .matronics.com/contribution<http://matronics.com/contribution> ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). tor?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com bution">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 02, 2014
Subject: Re: Brodhead light this year
I had fully intended on making the pilgrimage but, finances or time simply will not allow it . Finance and time has also slowed my finish time so I will spend my Broadhead time working on my Piet. Blue Skies, Steve D. ________________________________________________________________________________
Subject: Re: Chris Rusch stick-nose heavy conditioin
Date: Jul 02, 2014
HI Mike, Well......first off that not me in the pilot seat, it my mentor test pilot, he very skilled in T/W airplanes. He is only about 150......me, im with the majority at 205. that is what we are trying the weight sacks first before moving the wing or anything drastic. I am using the riblet, so my cabanes are equal length. There was a post about this subject and it shows that the if you lay out the wing incidence, the riblet cabane should be 11/16 shorter in the rear to get the 2deg angle of incidence. if the sand bags don't help, that's what im going to do. Thanks for the nice comments! I still want to try a shorter prop and get the RPM's up more into the power band, but its working fine with the 76 incher I have on there. Chris -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425944#425944 ________________________________________________________________________________
Date: Jul 02, 2014
That's the part that is kinda baffling as the weight and balance is perfect......we are going to add weight to match a 200 lb guy in the back and see what happens. If then no improvement, its shorter cabanes and possibly shift the wing back forward. -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425946#425946 ________________________________________________________________________________
this year
Date: Jul 02, 2014
RHVlIHRvIGNhbmNlbGluZyBteSBCcm9kaGVhZCB0cmlwLCB0aGVyZSBpcyBub3cgYSByb29tIGF2 YWlsYWJsZSBhdCBUaGUgU3V0aGVybGFuZCBIb3VzZSBCICYgQiBqdXN0IGRvd24gdGhlIHJvYWQg ZnJvbSB0aGUgYWlycG9ydC4gIEl0IHNsZWVwcyB0d28gYW5kIGlzIGN1cnJlbnRseSBhdmFpbGFi bGUgMjQsIDI1LCBhbmQgMjYgb2YgSnVseSAoVGh1cnMsIEZyaSwgU2F0KS4NCg0KU3V0aGVybGFu ZCBIb3VzZSBpcyB2ZXJ5IG5pY2UsIGEgNSBtaW4gZHJpdmUgb3IgMzAgbWluIHdhbGsgZnJvbSB0 aGUgYWlycG9ydC4gQ29tZXMgd2l0aCBicmVha2Zhc3QuIE15IGRhZCBhbmQgSSBoYXZlIHN0YXll ZCB0aGVyZSBtYW55IHRpbWVzIGFuZCB3ZSByZWFsbHkgZW5qb3kgaXQuIEZXSVcsIGl04oCZcyBh bHNvIHdoZXJlIFdpbGxpYW0gJiBHcmFjZSBXeW5uZSBhbmQgQ2hldCBQZWVrIHN0YXkgc29tZXRp bWVzLiBUaGUgYnJlYWtmYXN0IHRhYmxlIGNvbnZlcnNhdGlvbiBpcyBhbHdheXMgaW50ZXJlc3Rp bmcsIHJlZ2FyZGxlc3MuDQoNCkkgaGF2ZSBubyBmaW5hbmNpYWwgaW50ZXJlc3QgKGl04oCZcyBu b3QgbGlrZSBOYW5jeSBpcyBnb2luZyB0byBkaW5nIG15IGNyZWRpdCBjYXJkIGZvciBjYW5jZWxp bmcpLCBJIGp1c3Qgd2FudGVkIHRoZSBsaXN0IHRvIGtub3cgdGhhdCB0aGUgcm9vbSBpcyBhdmFp bGFibGUgKEkganVzdCBjaGVja2VkIHdpdGggTmFuY3kpLiBJZiB5b3UgcHJlZmVyIG5vdCB0byBj YW1wLCBJIHRoaW5rIGl0IGlzIGEgZ29vZCBkZWFsLg0KDQpOYW5jeSBhbmQgR2FyeSBTdXRoZXJs YW5kDQo2MDIgRWFzdCAybmQgQXZlbnVl4oCoDQpCcm9kaGVhZCwgV0kgNTM1MjDigKgNCihDb3Ju ZXIgb2YgNnRoIFN0cmVldCBhbmTigKhFYXN0IDJuZCBBdmVudWUpDQo2MDgtODk3LTQ0ODENCuKA qGlubmtlZXBlckBzdXRoZXJsYW5kaG91c2ViYW5kYi5jb20NCg0KLS0NCg0KSmVmZnJleSBILiBC b2F0cmlnaHQsIFBoRCwgRkFSVk8NClByb2Zlc3NvciBvZiBPcGh0aGFsbW9sb2d5DQpFbW9yeSBV bml2ZXJzaXR5IFNjaG9vbCBvZiBNZWRpY2luZQ0KDQpfX19fX19fX19fX19fX19fX19fX19fX19f X19fX19fXw0KDQpUaGlzIGUtbWFpbCBtZXNzYWdlIChpbmNsdWRpbmcgYW55IGF0dGFjaG1lbnRz KSBpcyBmb3IgdGhlIHNvbGUgdXNlIG9mDQp0aGUgaW50ZW5kZWQgcmVjaXBpZW50KHMpIGFuZCBt YXkgY29udGFpbiBjb25maWRlbnRpYWwgYW5kIHByaXZpbGVnZWQNCmluZm9ybWF0aW9uLiBJZiB0 aGUgcmVhZGVyIG9mIHRoaXMgbWVzc2FnZSBpcyBub3QgdGhlIGludGVuZGVkDQpyZWNpcGllbnQs IHlvdSBhcmUgaGVyZWJ5IG5vdGlmaWVkIHRoYXQgYW55IGRpc3NlbWluYXRpb24sIGRpc3RyaWJ1 dGlvbg0Kb3IgY29weWluZyBvZiB0aGlzIG1lc3NhZ2UgKGluY2x1ZGluZyBhbnkgYXR0YWNobWVu dHMpIGlzIHN0cmljdGx5DQpwcm9oaWJpdGVkLg0KDQpJZiB5b3UgaGF2ZSByZWNlaXZlZCB0aGlz IG1lc3NhZ2UgaW4gZXJyb3IsIHBsZWFzZSBjb250YWN0DQp0aGUgc2VuZGVyIGJ5IHJlcGx5IGUt bWFpbCBtZXNzYWdlIGFuZCBkZXN0cm95IGFsbCBjb3BpZXMgb2YgdGhlDQpvcmlnaW5hbCBtZXNz YWdlIChpbmNsdWRpbmcgYXR0YWNobWVudHMpLg0K ________________________________________________________________________________
Date: Jul 02, 2014
Oops, sorry! Guess I will attribute that to old age! My age gets me out of a lot of jams. I apologize to both you and Chuck. Regretfully, Ray Krause Sent from my iPad > On Jul 1, 2014, at 8:55 PM, "Bill Church" wrote: > > > Yikes, Ray. > I didn't lose my wife. Haven't even misplaced her. > > I think maybe you've got me mixed up with Chuck Campbell. I believe he recently mentioned his wife's passing. > > Bill C. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425897#425897 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 02, 2014
Chris, Congratulations on getting your bird flying. I just read over your notes and would like to share some thoughts. Forgive me in advance if I missed anything you said, but here are some thoughts: 15.9" is not having the CG too far forward. I have plenty of time flying in that range, and as Mike G pointed out, the plane has normal handling there. As the plans note, the acceptable range is 15" to 20". If you are in this range and the plane does not have normal behavior, it is likely something else. If you have a good electronic scale W&B, it is a very easy matter to do an exact calculation to know exactly where the CG will be with a 205 pound pilot. If you have any trouble with this, send me the data privately, and I will do it for you. The whole point to our previous work is so people can do a calculation, and not guess nor estimate. I can not say for sure without numbers, but there is a very good chance that a 15.9"/150lb pilot plane will still be in CG with a 205 pound pilot. If you load up the plane and move the CG back and it flies better at say 19.8", this doesn't mean that the 'problem' has been corrected. It is possible in rigging to have the illusion that the condition is 'fixed', when it has just been masked. If the incidence is not correct, but this is less noticeable with the CG aft, that doesn't constitute a solution, just a mask. If your plane has a different airfoil, than the best advice is going to come from a guy who not only has time with your airfoil, but also the standard one. You need to contact PF Beck and Don Harper. Both their planes fly well, they have motors in your weight category, PF would box as a welterweight, Don as a super Welterweight. (147 and 154 lbs) PF's has the Std. airfoil, Don the Ribblett. Get on the phone with them and ask about their CG, and also the rigging on Don's plane, including the incidence and the position of the horizontal stab. Get a smart level, and measure the stuff in degrees, and listen to the man flying the combination, not the theory of what it should be. A few guys mentioned 'twisted' stabilizers. Am I reading the correctly? or is the comment really about the incidence of the stabilizer? Twist to me implies wash in or wash out on a wing, I am not used to calling anything in the tail twisted. I bring this up because other people may also not be getting the comment. A little work on calculation and direct research with people flying the same airfoil in a similar plane is a whole lot less work than following any suggestion to move the wing some random amount. If, after investigation, it turns out that the wing does need to be moved, I can also show you the exact calculation to hit your new target CG right on. That is more complicated than a normal calculation, but the CG articles we did, available from Doc Mosher, walk you through it step by step. My neighbors 200HP Glasair only did 160mph with full aft stick on its first flight; 3 people from the EAA chapter all claimed the CG was wrong. Actual issue? LE of the stabilizer was off by 5/8". Corrected, the plane does 240 mph. 601XL came to our hangar 2007, aircraft could not be effectively trimmed. Builder was told it was a CG issue by several people. In reality, stabilizer was off by 1.5 or 2 degrees. Corrected the plane flew very well. I have a lot of stories like this, do some research and your plane will get squared away shortly. Follow someone's guess and go on a wild goose chase. Take your pick. Hope to see many of you at Brodhead. William Wynne Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425958#425958 ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Jul 02, 2014
Chris, A couple of questions come to mind- 1. How did you weigh your aircraft? Was it actual aircraft scales? Using something like 3 sets of bathroom scales can be extremely error-filed. 2. Did somebody else check your W&B computations? Not to say that you don't know how to do a weight and balance sheet, but I would not feel bad if someone checked my work if I was having W&B issues. 3. Have you read William Wynne's series of articles on Pietenpol weight and balance? I think that they are well written and are backed up by some real numbers, as opposed to guesswork. 4. Did you mention where your cabanes are set? Straight up? Aft? How far? Although I am still building, it would seem to me that cabane height and angle of incidence are not your issues. If you need the W&B articles let me know. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425960#425960 ________________________________________________________________________________
Date: Jul 02, 2014
You ain't the only one, N92GB is nose heavy with me flying it.- I have- had the shot bags by my butt on many occasions. It was set up for a 230 lbs pilot, I am only 190.- Dad adds ballast in the nose compartment when he flys.- I need to get fatter or move the wing forward, he has only flown a bout 6 hrs in the last 2 years.=0A-=0AShad =0A=0A=0AOn Wednesday, July 2, 2014 3:27 PM, Chris Rusch wrote:=0A =0A=0A=0A--> Pietenpol-List message posted by: "Chris Rusch" =0A=0AThat's the part that is kinda baffling as the weight and balance is p erfect......we are going to add weight to match a 200 lb guy in the back an d see what happens. If then no improvement, its shorter cabanes and possibl y shift the wing back forward.=0A=0A--------=0ANX321LR=0ANow test flying!! =0AMitsubishi Powered=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp: //forums.matronics.com/viewtopic.php?p=425946#425946=0A=0A=0A=0A=0A=0A=0A ================= ________________________________________________________________________________
Subject: Continental primer connection
Date: Jul 03, 2014
Hello, I am connecting the cables, tubes, roads and everything to the engine, but I have a doubt about the primer... where do I have to connect it?, to each cylinder port or to the manifold above the carburator?.. In winter temperatures in the morning are general above above 5 degrees Celsius (41 F) , and I don't plan to fly with this temp. I supouse is better in each cylinder, but simpler just in one place. You who have this engine, what do you recomend to me? By the way, two weeks ago I cover the second wing in a weekend, I cover it, pass the iron, glue reinforces and inspection rings; a very profitable weekend. I finish the covering step of the Piet, I have to sew the ribs and ready to paint.paint it. Regards -------- Mario Giacummo Photos here: http://goo.gl/wh7M4 Little Blog : http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425987#425987 ________________________________________________________________________________
Subject: Re: Continental primer connection
Date: Jul 03, 2014
Either way is fine. However, I've NEVER used my primer, just don't find a need for it. Not sure I'd even put one in were I doing an initial build. My Piet has it to each cylinder. Have had a couple lines break which is immediately noticable in that the engine will backfire. Seems less lines, less breakage... of course the whole engine is affected vs mine which only causes one cyl to run lean. So as usual, it seems it'll come down to what makes you feel comfortable. It's a VERY reliable engine, either method of priming is well tested and has no obvious problems I know about. I do believe going to each cylinder is considered somewhat of a "upgrade" in some circles. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425991#425991 ________________________________________________________________________________
Date: Jul 03, 2014
Here are my w/b numbers using digital race car scales -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425998#425998 Attachments: http://forums.matronics.com//files/img_3486_159.jpg http://forums.matronics.com//files/img_3487_529.jpg http://forums.matronics.com//files/img_3488_137.jpg ________________________________________________________________________________
Date: Jul 03, 2014
I used 60.5" from the firewall to the bellybutton of the pilot for the arm location. Subtract that from 173.25 an you get 112.75 All of the other distances were done using a plump bob with the plane perfectly level. I marked all of the locations on the floor and used a tape measure to document them. -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426000#426000 ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Jul 03, 2014
I have my primer going to the intake manifold. I use it any time the plane has sat more than a few hours and the temperature is below 45 F (7 C). Just makes starting easier. To prevent having vibration casue cracking and leaking, put a loop in the copper tubing between the last mounting point and the engine (you should do the same for the oil pressure line). You can see both these lines in the photo below: Good Luck! Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tools Sent: Thursday, July 03, 2014 9:59 AM Subject: Pietenpol-List: Re: Continental primer connection Either way is fine. However, I've NEVER used my primer, just don't find a need for it. Not sure I'd even put one in were I doing an initial build. My Piet has it to each cylinder. Have had a couple lines break which is immediately noticable in that the engine will backfire. Seems less lines, less breakage... of course the whole engine is affected vs mine which only causes one cyl to run lean. So as usual, it seems it'll come down to what makes you feel comfortable. It's a VERY reliable engine, either method of priming is well tested and has no obvious problems I know about. I do believe going to each cylinder is considered somewhat of a "upgrade" in some circles. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425991#425991 ________________________________________________________________________________
Date: Jul 03, 2014
I ask because I prefer install one cooper line than four, the one to four adapter, etc (less job, just one point of failure, etc). Thank you, I am going to install it in the manifold. Regards. -------- Mario Giacummo Photos here: http://goo.gl/wh7M4 Little Blog : http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426009#426009 ________________________________________________________________________________
Subject: CG, rigging, trim
Date: Jul 03, 2014
Food for thought: What is meant by nose heavy? That a plane with no in-flight adjustable elevator trim requires aft stick in cruise flight? If this is the case, and the plane is between 15-20", the correction is the angle of incidence on the stabilizer. Because of the seating configuration of the Piet, where the PIC is much further aft of the wing than common tandem seated planes like a J-3, a Piet will be much more sensitive to variance in PIC weight. Even with a wing shifted back, a Piet pilot's CG is more than 20" further aft than a J-3. If we are speaking of a 675 lb empty weight Piet and a 775 EW cub, the difference is going to be even more exaggerated because the PIC is a higher % of the gross. Ask anyone with a J-3 if the plane will fly hands off with a 50 pound PIC weight change without re trimming, and I am all piper pilots will say that it would need a trim change. The same weight change in a Piet will have an even stronger effect. It is not reasonable to expect a Piet to fly hands off with no trim change with two PIC's with a 50 lb weight difference Compare the trim system on a side by side classic (T-craft, 120, etc) to that of a tandem piper. The SBS planes use a trim tab on the elevator, but the pipers use a much more powerful system of altering the incidence of the stabilizer. I am not suggesting that anyone redesign the Piet, I am just pointing out the types of systems professional designers used in certain configurations, and the relative power of altering the incidence of the stabilizer. The Piet is an extreme example of tandem CG shift, and it is an easier path to a good flying plane if the rigging is seen with than in mind. I didn't see it mentioned, but speed is a factor on trimming planes and a guy who like to cruise at 68mph will have a different story than one who flies at 82mph, even in identical planes. Airfoils with strong pitching moments have strong pitch changes with speed changes. There are also other configuration considerations; a builder with 1929 gear going from 60 to 75mph is going to have a different condition than a guy with 6x6's doing the same speed change. There are other factors like the down thrust angle on the mount etc that effect pitch changes with power. Many things to consider, but one must start with the fundamentals of wing incidence, CG, and stabilizer incidence. From there, gather first hand data from a plane with a very similar configuration. I understand that the paragraphs above constitutes "ruining a simple plane with numbers talk" to some Piet fans. Last year a Brodhead a guy told me that I my CG work had ruined a good thing, "A simple club of good old boys who liked flying around low and slow and not thinking too much." I politely asked him if he understood that his ideal condition fulfilled two and a half of three points on the saying "Don't run out of altitude, airspeed and ideas all at the same time." If anything I say is offensive, I am easily ignored and deleted. Just pretend I don't exist. Reading a single word of my input is not a requirement for building a Piet, I offer it for people who find it useful assistance in getting the plane they personally want. Perhaps the most productive thing to do is collect some examples. It would be quick work at Brodhead to measure wing and stabilizer incidence on a number of planes, put this in with CG information and some pilot notes on their experience trimming. With 2 or 3 people we could get this data from 10 planes in 2 hours. We could then stick the data here, or in the newsletter, or with Doc's CG notes, or on my Piet page: http://flycorvair.net/2013/11/28/corvair-pietenpol-reference-page/ If builders like the idea, good otherwise I am just as happy sitting around eating brats and catching up with friends. Thank you. William Wynne Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426018#426018 ________________________________________________________________________________
Date: Jul 03, 2014
Chris, That is very good data. You actually used the same model scales that we used for the W&B data collection at Brodhead. For the data we have, we actually put several sample body type pilots in the plane and weighed them to try to come up with a PIC datum location that builders could use as a standard. What we settled on is 10" ahead of the location of the top if the front face of the pilot's seat back. This is accurate with 145-175 pound PIC, it errs on the side of caution slightly as the PIC weight goes up and the pilot's body type is more burley. I looked at your You tube video carefully. Good looking bird. I watched the elevator position in flight and it is up all the time. What was the level flight speed? If the plane needs up elevator in flight, and it is in CG, you can always lower the whole leading edge of the stabilizer until the elevator lies in trail in level cruise flight. I will get out a calculator after dinner tonight and look at your CG data. I think it might be slightly further forward than you are thinking. I can also give you the change with 50 more pounds of PIC. The plane is a neat innovation, I am sure you are just a few steps away from having it rigged to your liking. -ww Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426020#426020 ________________________________________________________________________________
Date: Jul 03, 2014
VGhlIHByaW1lciBsaW5lIG9uIG15IEMtODUgZ29lcyB0byB0aGUgbWFuaWZvbGQgYWJvdmUgdGhl IGNhcmIuIEFzIFRvb2xzIHN0YXRlZCwgbWFueSB0aW1lIHByaW1lIGlzbuKAmXQgbmVlZGVkLiBJ IHVzZSwgYXQgbW9zdCwgdGhyZWUgc2hvdHMgb2YgcHJpbWUgb24gYSBjb2xkIGRheS4gQ29sZGVz dCBkYXkgSeKAmXZlIGV2ZXIgc3RhcnRlZCB0aGUgZW5naW5lIHdhcyAyOCBkZWdyZWVzIEYgYW5k IHRocmVlIHNob3RzIHdhcyBwbGVudHkuDQoNCi0tDQoNCkplZmZyZXkgSC4gQm9hdHJpZ2h0LCBQ aEQsIEZBUlZPDQpQcm9mZXNzb3Igb2YgT3BodGhhbG1vbG9neQ0KRW1vcnkgVW5pdmVyc2l0eSBT Y2hvb2wgb2YgTWVkaWNpbmUNCg0KRnJvbTogZ2lhY3VtbW8gPG1hcmlvLmdpYWN1bW1vQGdtYWls LmNvbTxtYWlsdG86bWFyaW8uZ2lhY3VtbW9AZ21haWwuY29tPj4NClJlcGx5LVRvOiAicGlldGVu cG9sLWxpc3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNv bT4iIDxwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPG1haWx0bzpwaWV0ZW5wb2wtbGlzdEBt YXRyb25pY3MuY29tPj4NCkRhdGU6IFRodXJzZGF5LCBKdWx5IDMsIDIwMTQgYXQgOTozNiBBTQ0K VG86ICJwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPG1haWx0bzpwaWV0ZW5wb2wtbGlzdEBt YXRyb25pY3MuY29tPiIgPHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnBpZXRl bnBvbC1saXN0QG1hdHJvbmljcy5jb20+Pg0KU3ViamVjdDogUGlldGVucG9sLUxpc3Q6IENvbnRp bmVudGFsIHByaW1lciBjb25uZWN0aW9uDQoNCi0tPiBQaWV0ZW5wb2wtTGlzdCBtZXNzYWdlIHBv c3RlZCBieTogImdpYWN1bW1vIiA8bWFyaW8uZ2lhY3VtbW9AZ21haWwuY29tPG1haWx0bzptYXJp by5naWFjdW1tb0BnbWFpbC5jb20+Pg0KDQpIZWxsbywNCg0KSSBhbSBjb25uZWN0aW5nIHRoZSBj YWJsZXMsIHR1YmVzLCByb2FkcyBhbmQgZXZlcnl0aGluZyB0byB0aGUgZW5naW5lLCBidXQgSSBo YXZlIGEgZG91YnQgYWJvdXQgdGhlIHByaW1lci4uLiB3aGVyZSBkbyBJIGhhdmUgdG8gY29ubmVj dCBpdD8sIHRvIGVhY2ggY3lsaW5kZXIgcG9ydCBvciB0byB0aGUgbWFuaWZvbGQgYWJvdmUgdGhl IGNhcmJ1cmF0b3I/Li4gSW4gd2ludGVyIHRlbXBlcmF0dXJlcyBpbiB0aGUgbW9ybmluZyBhcmUg Z2VuZXJhbCBhYm92ZSBhYm92ZSA1IGRlZ3JlZXMgQ2Vsc2l1cyAoNDEgRikgLCBhbmQgSSBkb24n dCBwbGFuIHRvIGZseSB3aXRoIHRoaXMgdGVtcC4NCg0KSSBzdXBvdXNlIGlzIGJldHRlciBpbiBl YWNoIGN5bGluZGVyLCBidXQgc2ltcGxlciBqdXN0IGluIG9uZSBwbGFjZS4NCg0KWW91IHdobyBo YXZlIHRoaXMgZW5naW5lLCB3aGF0IGRvIHlvdSByZWNvbWVuZCB0byBtZT8NCg0KQnkgdGhlIHdh eSwgdHdvIHdlZWtzIGFnbyBJIGNvdmVyIHRoZSBzZWNvbmQgd2luZyBpbiBhIHdlZWtlbmQsIEkg Y292ZXIgaXQsIHBhc3MgdGhlIGlyb24sIGdsdWUgcmVpbmZvcmNlcyBhbmQgaW5zcGVjdGlvbiBy aW5nczsgYSB2ZXJ5IHByb2ZpdGFibGUgd2Vla2VuZC4gSSBmaW5pc2ggdGhlIGNvdmVyaW5nIHN0 ZXAgb2YgdGhlIFBpZXQsIEkgaGF2ZSB0byBzZXcgdGhlIHJpYnMgYW5kIHJlYWR5IHRvIHBhaW50 LnBhaW50IGl0Lg0KDQpSZWdhcmRzDQoNCi0tLS0tLS0tDQpNYXJpbyBHaWFjdW1tbw0KUGhvdG9z IGhlcmU6IGh0dHA6Ly9nb28uZ2wvd2g3TTQNCkxpdHRsZSBCbG9nICAgOiBodHRwOi8vdmdtazEu YmxvZ3Nwb3QuY29tDQoNCg0KDQoNClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToNCg0KaHR0 cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00MjU5ODcjNDI1OTg3DQoN Cg0KDQoNCg0KDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUgUGlldGVucG9sLUxpc3QgRW1h aWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9y IHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9T dWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3Nl LCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpf LT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9QaWV0ZW5wb2wtTGlz dA0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAt DQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVt cyENCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KXy09DQpfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQ0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KXy09ICBU aGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPSAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCl8tPSAgIC0tPiBodHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0KDQoNCl9fX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fDQoNClRoaXMgZS1tYWlsIG1lc3NhZ2UgKGluY2x1ZGlu ZyBhbnkgYXR0YWNobWVudHMpIGlzIGZvciB0aGUgc29sZSB1c2Ugb2YNCnRoZSBpbnRlbmRlZCBy ZWNpcGllbnQocykgYW5kIG1heSBjb250YWluIGNvbmZpZGVudGlhbCBhbmQgcHJpdmlsZWdlZA0K aW5mb3JtYXRpb24uIElmIHRoZSByZWFkZXIgb2YgdGhpcyBtZXNzYWdlIGlzIG5vdCB0aGUgaW50 ZW5kZWQNCnJlY2lwaWVudCwgeW91IGFyZSBoZXJlYnkgbm90aWZpZWQgdGhhdCBhbnkgZGlzc2Vt aW5hdGlvbiwgZGlzdHJpYnV0aW9uDQpvciBjb3B5aW5nIG9mIHRoaXMgbWVzc2FnZSAoaW5jbHVk aW5nIGFueSBhdHRhY2htZW50cykgaXMgc3RyaWN0bHkNCnByb2hpYml0ZWQuDQoNCklmIHlvdSBo YXZlIHJlY2VpdmVkIHRoaXMgbWVzc2FnZSBpbiBlcnJvciwgcGxlYXNlIGNvbnRhY3QNCnRoZSBz ZW5kZXIgYnkgcmVwbHkgZS1tYWlsIG1lc3NhZ2UgYW5kIGRlc3Ryb3kgYWxsIGNvcGllcyBvZiB0 aGUNCm9yaWdpbmFsIG1lc3NhZ2UgKGluY2x1ZGluZyBhdHRhY2htZW50cykuDQo ________________________________________________________________________________
Subject: Happy 4th everyone
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Jul 03, 2014
Here's a challenge to all. Lets see how many of us with flying Piets can commit aviation on the 4th. Even if it is only to go around the pattern once. Then we'll report back here so we can get a head count. Could be fun. Have fun, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426027#426027 ________________________________________________________________________________
Date: Jul 03, 2014
Chris, Where is the fuel tank located? Greg Cardinal ----- Original Message ----- From: "Chris Rusch" <rmdinfo(at)rmdbenders.com> Sent: Thursday, July 03, 2014 9:36 AM Subject: Pietenpol-List: Re: ###4th FLIGHT### > > > I used 60.5" from the firewall to the bellybutton of the pilot for the arm > location. Subtract that from 173.25 an you get 112.75 > > All of the other distances were done using a plump bob with the plane > perfectly level. I marked all of the locations on the floor and used a > tape measure to document them. > > -------- > NX321LR > Now test flying!! > Mitsubishi Powered > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426000#426000 > > > --- This email is free from viruses and malware because avast! Antivirus protection is active. http://www.avast.com ________________________________________________________________________________
Subject: Re: Happy 4th everyone
Date: Jul 03, 2014
Scott, I will be committing aviation on July 4th in a Boeing 767 (work). I would much rather be doing it in a Pietenpol. A Happy 4th to all. -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426034#426034 ________________________________________________________________________________
Date: Jul 03, 2014
I'm in! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Thursday, July 03, 2014 12:05 PM Subject: Pietenpol-List: Happy 4th everyone --> Here's a challenge to all. Lets see how many of us with flying Piets can commit aviation on the 4th. Even if it is only to go around the pattern once. Then we'll report back here so we can get a head count. Could be fun. Have fun, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426027#426027 ________________________________________________________________________________
Date: Jul 03, 2014
I should be able to to do that. Forecast here is good for tomorrow (sucks right now, though). I was able to get in a flight in the Pietenpol this morning, carrying one of our B&B guests. Squeezed it in under a 1500' broken ceiling with a scattered layer at 700'. The pretty young lady was thrilled. Her boyfriend was too heavy for the Piet so I took him in the RV-4. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Thursday, July 03, 2014 5:19 PM Subject: RE: Pietenpol-List: Happy 4th everyone I'm in! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Thursday, July 03, 2014 12:05 PM Subject: Pietenpol-List: Happy 4th everyone --> Here's a challenge to all. Lets see how many of us with flying Piets can commit aviation on the 4th. Even if it is only to go around the pattern once. Then we'll report back here so we can get a head count. Could be fun. Have fun, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426027#426027 ________________________________________________________________________________
Date: Jul 03, 2014
(like the little school kid in the back of the room, with his hand up): "I know! I know! Chris's fuel tank is in the wing centersection and it's a 14 gallon one" I know this because I'm just wrapping up the article on the MitsuPietshi that will appear in the all-Piet issue of Contact! Magazine, just in time for the 85th anniversary of the Air Camper. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426042#426042 ________________________________________________________________________________
Date: Jul 03, 2014
Subject:
=0AUnsubscribe ________________________________________________________________________________
Date: Jul 03, 2014
Subject: Re: tenpol-List:
The Unsubscribed" The cold fog thickened noticeably as the newcomer hurried towards his destination. He pulled his heavy overcoat around his neck a little more tightly. This part of the city was not a place to tarry. Thieves and whores were the only permanent residents here. Even the cops rolled through these streets with a nervousness and an edge to heir normal macho banter. Trouble and misery closed around everyone who ventured into this pustule of urban blight like a leech on a warm vein. "Damn!", he hissed under his breath as he stepped on something soft that squealed and skittered off into the darkness and dankness of the mist. It can't be much farther he thought. It mustn't be much farther. The sickly yellow flicker of light from a street lamp shone dimly through the fog as he quickened his pace. There it was. The doorway seemed to be just blackness without definition. As he got closer, two winos eyed him suspiciously through bloodshot and yellowed eyes. He hustled past them, their breath leaving a rank scent that lingered on his clothes. The door pushed inward and the newcomer was inside. The room was smoky and dim. The bar stank of liquor and broken dreams. Several tables decorated the periphery. The man he had come to see was sitting at one of those tables and beckoned him over to sit. The man was darkly clothed and utterly shapeless. He might have weighed three hundred pounds... or he may have been only bone. His shape was indecipherable. The dark mans eyes were gazing down at the dirty glass in his hand, half filled with cheap whiskey. He had been reading a glossy magazine filled with lurid and obscene images. He folded it tenderly and stuffed it quickly into his coat pocket like a vulture gobbling a rotten piece of flesh. "What is it you want of me?", the dark man asked, not lifting his eyes from the glass. His voice rumbled deep in his belly like a toad. "I need you to tell me how to unsubscribe", said the newcomer in as even a tone as he could muster. The dark man looked up from his glass slowly to gaze at the newcomer. His eyes were a pale watery blue. And his gaze lingered on the newcomer. "You wish to unsubscribe?", he said, with a hint of amusement in his voice but no trace of a smile on his thick pasty lips. "You come to me with a need to unsubscribe?", he said, his voice getting louder now and any hint of amusement gone. He sucked in his breath and hissed through his teeth spraying the newcomer with a repulsive mist of spittle, "Why? Tell me why it is that you wish to unsubscribe." The newcomer felt fear now creeping up his spine. "I don't have the time to sort through all the posts", he mumbled. The dark man sat unmoved, his eyes stared at the newcomer without emotion. His eyes were cold and amphibian. "And I sold the Pietenpol and bought a Husky", added the newcomer. He realized in a heart beat that he should not have said that. The dark man had him by the throat with a quickness that seemed otherworldly. And the dark man squeezed that throat as the newcomer wriggled and squirmed in a voiceless scream. The dark man pulled the newcomers face to his own until they nearly touched noses. He breathed his fetid breath on the newcomer and a trickle of drool escaped his mouth to plop loudly on the table between them. "Go!", he rumbled. "Go now you fool!", he bellowed. "Run if you can. It shall do you no good! Once you have subscribed, all hope of ever unsubscribing is gone! We will find you. Your email is now ours to control. Your email box will fill to bursting with our messages. And there is no hope for you. There is no good deed you can do to change what you have done. The List will not be denied!" And with that he released the newcomer who reeled and staggered towards the door, gagging and stumbling. The dark man began to laugh, a low rumbling laugh that grew louder. The newcomer fled up the streets as he had come with the croaking bellowing laughter chasing him. He was doomed... and he knew it. The dark man sat back at the table in the dimly lit bar and sipped at his drink. "I guess I could have just told him to go to http://www.matronics.com/subscribe/ and follow the directions to unsubscribe", he muttered under his breath. No, he smiled to himself. That would have been all too easy. Still chuckling to himself, he reached into his pocket and pulled out the magazine he had been reading before the newcomer interrupted him. He quickly thumbed through the slick and edge worn pages until he found his place. He never missed a single word of each and every issue of Martha Stewart Living... Anonymous On Thu, Jul 3, 2014 at 6:49 PM, wrote: > Unsubscribe > > * > > > * > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Jul 03, 2014
If I didn't know better, I would say that you've been listening to too many episodes of "Guy Noir" on the Prairie Home Companion. "A dark night in a city that knows how to keep its secrets. Brodhead, Wisconsin". -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426051#426051 ________________________________________________________________________________
Date: Jul 04, 2014
Good one, Oscar. Happy Independence Day everyone! On Jul 4, 2014, at 12:28 AM, taildrags wrote: > > If I didn't know better, I would say that you've been listening to too many episodes of "Guy Noir" on the Prairie Home Companion. > > "A dark night in a city that knows how to keep its secrets. Brodhead, Wisconsin". > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426051#426051 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 03, 2014
Steve, That is a classic, worthy of Raymond Chandler. I would like to know who wrote it, it made me smile. In defense of Mark McKellar: He may not know how to unsubscribe, but he was a pretty good student of engine building. He came to Corvair College #2 held at our old hangar at Spruce Creek FL. He built up a long block under our supervision, intended for a Piet. Years later, after a life issue, he sold it to Robert and Barbara Caldwell for their bird. They bolted on some updated parts but didn't touch the basic engine Mark assembled. At Corvair College #21 at PF Beck's the engine fired right up after 3 seconds of cranking and ran smoothly. Elapsed time, almost 11 years. There are pictures at this link: http://www.flycorvair.com/cc21.html It also contains first runs on a number of Corvairs bound for Piets, like "Early Builder's" and Don Harper's. We are holding Corvair College #31 at PF Beck's in Barnwell again this November.-ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426053#426053 ________________________________________________________________________________
Date: Jul 03, 2014
Chris, I took out a pencil and calculator and went to work on your data. I came out with the following: EWCG: 8.66" w/150 lb PIC 15.26" w/ 205 lb PIC 17.1" w/ 290 lb PIC 19.8" Thoughts: The suggestion by two people that you have to move the wing is lacking data and merit. If you look at our CG articles, check out the Corvair installment. The plane identified as "Aircraft #3" was Kevin Purtee and Shelley's 'fat bottomed girl'. It is a very close approximation of your plane in EW, CG, Landing gear, etc. Kevin's plane actually had it's EWCG at 8.2", slightly further forward than yours. His plane flew 345 hours and many long flights like this. Kevin is about 5'11" and 175 pounds dressed. Yet his plane didn't have 'terrible stick pressure', and I suspect that the prime difference in the two planes will be the angle of the stabilizer. As further evidence, I have done a W&B on "the Last Original". It is hand prop and lighter, but the CG with a 210 lb PIC is 17.0". BHP's plane in the hangar at Pioneer airport is the same way. In 2006 my wife flew the last original and said it was totally normal. Bill Knight reworked the plane a few years ago and would have changed the wing position if it needed it. Bill is a 215 pound guy, but 1,500 hr Piet guy Tom Brown has flown it a lot also, and he is a 165 lb guy, and he has never said anything but positive things about the plane. Again, I suspect that you have a stabilizer issue, not a CG one. Yes, you can crank the wing forward and mask this, but you would be moving away from how BHP set his planes up, not closer. One possible point: I saw your number of 60.5" for the PIC-CG. If you look at the notation that Ryan and I used, PSL is explained in the series as the pilots seat back length, from there our PIC-CG for calculations was 10" ahead of this. Your number looks like you estimated your PIC to be further forward than this, maybe 15" ahead of the PSL in your plane. If we recalculate your CG w/150 lb PIC by my method, the CG is 16.04" about 3/4" further back. Likewise the CG w/205 lb PIC becomes 18.2", over an inch further back. I suspect that my estimate that the pilot CG from the LE of your plane is close to 55.875" maybe closer than your estimate of 50.875. For accurate W&B nothing beats the pilot sitting in the plane dressed while it is still on the scales. The 'belly button rule" isn't accurate enough. Note if my number is right, and someone had talked you into moving the wing 2.5" forward, you would have ended up aft of the CG limit. At the risk of confirming suspicions that I am a tactless jackass, I want to say that we did the W&B work to discourage people from offering advice without calculation. If you are heading to Brodhead, I will gladly go over this in person with you and we can go get a look at the last original and carefully measure the incidence on the wing and the stabilizer and compare it to your bird. Thank you. William Wynne Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426056#426056 ________________________________________________________________________________
Date: Jul 04, 2014
William, OK, I will be the jarhead that asks the simple question that probably has a simple answer. What should the angle of the horizontal stabilizer be? Zero, in relation to the top longeron? Or is the answer, "it depends."? Start at zero and adjust during flight testing? I don't see it shown on the plans, or am I missing something? There have been previous discussions on the forum about elevator position in flight. The elevator should be in a neutral position for cruise flight, is that what you are saying? I understand that elevator position out of neutral will create more drag, but I thought there was some discussion of it being " normal". In the Marine Corps we used to say that there is no such thing as a stupid question, although there are many that come extremely close. Maybe mine is one of the close ones.[/b] -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426060#426060 ________________________________________________________________________________
Date: Jul 04, 2014
Good morning Pieters, I flew for 30 minutes this morning before it gets hot. Lifted off at 5:45. Great smooth ride. Happy Landings, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426073#426073 ________________________________________________________________________________
Date: Jul 04, 2014
Terry, I went back last night after doing Chris's W&B calculation and read most of what I could find on it to get a bigger picture. "Depends" is a very good answer. Chris, I would strongly consider getting in touch with Don Harper at Barnwell and looking at which wing incidence he used on his plane with the same airfoil you have. Even 1 degree difference is a lot on a plane, and if we know what works for him, and if it is different from what you have, it is starting off a lot better armed in the info department. The plans show 2 degrees, but this is really applicable to only one set of parameters, a weight and a cruise speed and the original airfoil. 2 degrees may be right on the button for a 1100 pound A powered plane at 68 mph with the BHP airfoil. A 1200 pound plane at 78mph with a ribblett may not only need a different incidence to be idealized, but it will likely also require a different stabilizer setting. If the BHP and Ribblet airfoils had tables like the naca airfoils do in theory of wing sections, anyone could do an accurate calculation in a few minutes. Without this, working from carefully validated previous flying planes takes longer, but can produce a fine tunes plane just the same. -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426074#426074 ________________________________________________________________________________
Date: Jul 04, 2014
There was a discussion about wing incidence about three years ago, and at that time I created a couple of drawings to illustrate the relationship between the cabane strut lengths, and also between the chord line vs the bottom of the spars. They are attached again to this posting. For the "to the plans" Pietenpol, the 1" difference in cabane struts creates a 2 degree angle. Added to this is a 1 1/2 degree angle formed between the chord line and the bottoms of the spars (since that's where the cabanes attach). So the effective angle of incidence between the airfoil chord and the top longeron is 3.5 degrees. For the Riblett 612 airfoil, there is a 2.1 degree angle between the chord line and the bottoms of the spars. So, if a Riblett 612 airfoil is mounted on "stock" cabanes (front 1" longer than rear), the effective AofI would be 4.1 degrees. If the front and rear cabanes are made equal lengths, with the Riblett, the effective angle would be reduced to only 2.1 degrees - almost 1 1/2 degrees less than the "to the plans" Piet. In order to produce the same 3.5 degree angle, but using the Riblett 612, there should be a difference of approximately 11/16" difference in cabane lengths (front vs back). Food for thought. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426085#426085 Attachments: http://forums.matronics.com//files/piet_incidence_145.pdf http://forums.matronics.com//files/riblett_incidence_159.pdf ________________________________________________________________________________
Date: Jul 04, 2014
I'm waiting till this evening. Right now we have winds at 15 knots with gusts to 25, directly across the runway. Too much work flying in such winds! Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Friday, July 04, 2014 10:20 AM Subject: Pietenpol-List: Re: Happy 4th everyone Good morning Pieters, I flew for 30 minutes this morning before it gets hot. Lifted off at 5:45. Great smooth ride. Happy Landings, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426073#426073 ________________________________________________________________________________
Date: Jul 04, 2014
Know what you mean Jack...gusts to 3 here! Sent from my iPhone > On Jul 4, 2014, at 10:08 AM, "Jack Phillips" wrote: > > > I'm waiting till this evening. Right now we have winds at 15 knots with > gusts to 25, directly across the runway. Too much work flying in such > winds! > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > AircamperN11MS > Sent: Friday, July 04, 2014 10:20 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Happy 4th everyone > > > > Good morning Pieters, > I flew for 30 minutes this morning before it gets hot. Lifted off at 5:45. > Great smooth ride. > Happy Landings, > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426073#426073 > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 04, 2014
nBill, Those are some very clear and useful drawings, a good reference point, and I would be very interested to read about what the incidence of any flying Ribblett airfoiled plane is. 4.1 degrees on that airfoil is a lot. People miss how many kits use Ribblett airfoils, even things like Zenith 601XLs. I am pretty sure the same airfoil used on the Piet is also on modern Kitfoxes, and they don't have anywhere near that kind of incidence, even when you factor in the speed and wing loading difference. With 6% camber, this airfoil will still produce lift even if the incidence is lowered to 0 degrees. If the plane is trying to fly with the fuselage angled down 3 or 4 degrees in flight, the often forgotten part on trimming is that it is also adding this to the down thrust of the engine and subtracting it from the incidence of the stabilizer. Was anyone else at Brodhead about 10 years ago when a plane flew in that had the cabanes reversed? I recall a plane flying around the pattern with the nose about 4 degrees up. I have seen some rigging errors before, but that one stands out in my memory, and I have no explanation why the builder might have thought it was OK. -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426089#426089 ________________________________________________________________________________
Subject: 4th of July
Date: Jul 04, 2014
Happy 4th of July! My wife and I enjoyed a beautiful sunset flight, 75 degre es, clear skies. No humidity it was absolutely perfect. By the way, for all of you that congratulated me on the article in Experimen ter magazine, thank-you. I'm not sure if my previous thank you went thru or n ot. Randy bush NX294RB Sent from my iPhone
Date: Jul 04, 2014
Date: Jul 05, 2014
R2xvcmlvdXMgbW9ybmluZyBmbGlnaHQgdG9kYXkgb24gdGhlIDR0aCEgIFZlcnkgY29vbCB0ZW1w cyBmb3IgdGhpcyB0aW1lIG9mIHllYXIgaW4gQXRsYW50YS4gSSB3YXMgYWN0dWFsbHkgY2hpbGx5 IGF0IDIzMDAgTVNMLiBXZW50IGRvd24gdG8gMTcwMCBNU0wgZm9yIHdhcm10aCBhbmQsIG9kZGx5 LCBmZXdlciBidW1wcy4NCi0tDQoNCkplZmZyZXkgSC4gQm9hdHJpZ2h0LCBQaEQsIEZBUlZPDQpQ cm9mZXNzb3Igb2YgT3BodGhhbG1vbG9neQ0KRW1vcnkgVW5pdmVyc2l0eSBTY2hvb2wgb2YgTWVk aWNpbmUNCg0KRnJvbTogSmFjayBQaGlsbGlwcyA8amFja0BiZWRmb3JkbGFuZGluZ3MuY29tPG1h aWx0bzpqYWNrQGJlZGZvcmRsYW5kaW5ncy5jb20+Pg0KUmVwbHktVG86ICJwaWV0ZW5wb2wtbGlz dEBtYXRyb25pY3MuY29tPG1haWx0bzpwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPiIgPHBp ZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnBpZXRlbnBvbC1saXN0QG1hdHJvbmlj cy5jb20+Pg0KRGF0ZTogRnJpZGF5LCBKdWx5IDQsIDIwMTQgYXQgMTowOCBQTQ0KVG86ICJwaWV0 ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPG1haWx0bzpwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3Mu Y29tPiIgPHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnBpZXRlbnBvbC1saXN0 QG1hdHJvbmljcy5jb20+Pg0KU3ViamVjdDogUkU6IFBpZXRlbnBvbC1MaXN0OiBSZTogSGFwcHkg NHRoIGV2ZXJ5b25lDQoNCi0tPiBQaWV0ZW5wb2wtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIkph Y2sgUGhpbGxpcHMiIDxqYWNrQGJlZGZvcmRsYW5kaW5ncy5jb208bWFpbHRvOmphY2tAYmVkZm9y ZGxhbmRpbmdzLmNvbT4+DQoNCkknbSB3YWl0aW5nIHRpbGwgdGhpcyBldmVuaW5nLiAgUmlnaHQg bm93IHdlIGhhdmUgd2luZHMgYXQgMTUga25vdHMgd2l0aA0KZ3VzdHMgdG8gMjUsIGRpcmVjdGx5 IGFjcm9zcyB0aGUgcnVud2F5LiAgVG9vIG11Y2ggd29yayBmbHlpbmcgaW4gc3VjaA0Kd2luZHMh DQoNCkphY2sgUGhpbGxpcHMNCk5YODk5SlANClNtaXRoIE1vdW50YWluIExha2UsIFZpcmdpbmlh DQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiBvd25lci1waWV0ZW5wb2wtbGlz dC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbTxtYWlsdG86b3duZXItcGlldGVucG9sLWxpc3Qtc2VydmVy QG1hdHJvbmljcy5jb20+DQpbbWFpbHRvOm93bmVyLXBpZXRlbnBvbC1saXN0LXNlcnZlckBtYXRy b25pY3MuY29tXSBPbiBCZWhhbGYgT2YNCkFpcmNhbXBlck4xMU1TDQpTZW50OiBGcmlkYXksIEp1 bHkgMDQsIDIwMTQgMTA6MjAgQU0NClRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPG1h aWx0bzpwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPg0KU3ViamVjdDogUGlldGVucG9sLUxp c3Q6IFJlOiBIYXBweSA0dGggZXZlcnlvbmUNCg0KLS0+IFBpZXRlbnBvbC1MaXN0IG1lc3NhZ2Ug cG9zdGVkIGJ5OiAiQWlyY2FtcGVyTjExTVMiDQo8U2NvdHQubGllZmVsZEBsYWNpdHkub3JnPG1h aWx0bzpTY290dC5saWVmZWxkQGxhY2l0eS5vcmc+Pg0KDQpHb29kIG1vcm5pbmcgUGlldGVycywN CkkgZmxldyBmb3IgMzAgbWludXRlcyB0aGlzIG1vcm5pbmcgYmVmb3JlIGl0IGdldHMgaG90LiBM aWZ0ZWQgb2ZmIGF0IDU6NDUuDQpHcmVhdCBzbW9vdGggcmlkZS4NCkhhcHB5IExhbmRpbmdzLA0K DQotLS0tLS0tLQ0KU2NvdHQgTGllZmVsZA0KRmx5aW5nIE4xMU1TIHNpbmNlIE1hcmNoIDE5NzIN ClN0ZWVsIFR1YmUNCkMtODUtMTINCldpcmUgV2hlZWxzDQpCcm9kaGVhZCBpbiAxOTk2DQoNCg0K DQoNClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToNCg0KaHR0cDovL2ZvcnVtcy5tYXRyb25p Y3MuY29tL3ZpZXd0b3BpYy5waHA/cD00MjYwNzMjNDI2MDczDQoNCg0KDQoNCg0KDQoNCg0KDQoN Cg0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PQ0KXy09ICAgICAgICAgIC0gVGhlIFBpZXRlbnBvbC1MaXN0IEVtYWlsIEZvcnVt IC0NCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93 c2UNCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0 aW9uLA0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwg RkFRLA0KXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCl8tPQ0KXy09ICAgLS0+ IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UGlldGVucG9sLUxpc3QNCl8tPQ0K Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0NCl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNh bWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0N Cl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAg ICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91 IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRy b25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KDQoNCg0KDQpfX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fXw0KDQpUaGlzIGUtbWFpbCBtZXNzYWdlIChpbmNsdWRpbmcgYW55IGF0 dGFjaG1lbnRzKSBpcyBmb3IgdGhlIHNvbGUgdXNlIG9mDQp0aGUgaW50ZW5kZWQgcmVjaXBpZW50 KHMpIGFuZCBtYXkgY29udGFpbiBjb25maWRlbnRpYWwgYW5kIHByaXZpbGVnZWQNCmluZm9ybWF0 aW9uLiBJZiB0aGUgcmVhZGVyIG9mIHRoaXMgbWVzc2FnZSBpcyBub3QgdGhlIGludGVuZGVkDQpy ZWNpcGllbnQsIHlvdSBhcmUgaGVyZWJ5IG5vdGlmaWVkIHRoYXQgYW55IGRpc3NlbWluYXRpb24s IGRpc3RyaWJ1dGlvbg0Kb3IgY29weWluZyBvZiB0aGlzIG1lc3NhZ2UgKGluY2x1ZGluZyBhbnkg YXR0YWNobWVudHMpIGlzIHN0cmljdGx5DQpwcm9oaWJpdGVkLg0KDQpJZiB5b3UgaGF2ZSByZWNl aXZlZCB0aGlzIG1lc3NhZ2UgaW4gZXJyb3IsIHBsZWFzZSBjb250YWN0DQp0aGUgc2VuZGVyIGJ5 IHJlcGx5IGUtbWFpbCBtZXNzYWdlIGFuZCBkZXN0cm95IGFsbCBjb3BpZXMgb2YgdGhlDQpvcmln aW5hbCBtZXNzYWdlIChpbmNsdWRpbmcgYXR0YWNobWVudHMpLg0K ________________________________________________________________________________
Date: Jul 04, 2014
I got to go up for a bit this morning too! It was hotter at 1000 agl than o n the ground this morning, but still not too bad as the high today was suppo sed to be 103 here in sunny central California. And I get to fly the wife to breakfast in the Piet tomorrow. Ain't it grea t? Mike Groah Tulare CA Sent from my iPad > On Jul 4, 2014, at 7:31 PM, "Boatright, Jeffrey" wrote: > > Glorious morning flight today on the 4th! Very cool temps for this time o f year in Atlanta. I was actually chilly at 2300 MSL. Went down to 1700 MSL f or warmth and, oddly, fewer bumps. > -- > > Jeffrey H. Boatright, PhD, FARVO > Professor of Ophthalmology > Emory University School of Medicine > > From: Jack Phillips <jack(at)bedfordlandings.com> > Reply-To: "pietenpol-list(at)matronics.com" > Date: Friday, July 4, 2014 at 1:08 PM > To: "pietenpol-list(at)matronics.com" > Subject: RE: Pietenpol-List: Re: Happy 4th everyone > s.com> > > I'm waiting till this evening. Right now we have winds at 15 knots with > gusts to 25, directly across the runway. Too much work flying in such > winds! > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > AircamperN11MS > Sent: Friday, July 04, 2014 10:20 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Happy 4th everyone > > > > Good morning Pieters, > I flew for 30 minutes this morning before it gets hot. Lifted off at 5:45. > Great smooth ride. > Happy Landings, > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426073#426073 > > > > > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > > > > > This e-mail message (including any attachments) is for the sole use of > the intended recipient(s) and may contain confidential and privileged > information. If the reader of this message is not the intended > recipient, you are hereby notified that any dissemination, distribution > or copying of this message (including any attachments) is strictly > prohibited. > > If you have received this message in error, please contact > the sender by reply e-mail message and destroy all copies of the > original message (including attachments). > ky=C2=B7=C3=A8=C5=BE=C3=9B"=C3=8D=C3=AD=C5=93=C2=A2Z+=C3=93M4=C3=93G=C3=9A q=C3=A7(=C2=BA=C2=B8=C5=BE=C2=AEw=C2=B0r=B9=C2=AB=B0=C3=C3=93 =C3=A3=C3=A2z=C3=97=C2=A7=C2=B0K=C5-=C3=8BD=84=A2=C2=A8 =C2=A5=16=C5-=C3=AE=84=A2K=1E=C2=B6=17=C5=92j=C3=9A=C3=A8=C5=BE',.+-=15 =C3=C2=AD=C2=BA=C2=B7=C2=AC5=C2=AB=C3=A2=C2=81=C2=ABh=C2=AE=C3=9A=1B=C2=AE =C5=92,z=C3=98^=84=A2=C2=A9=C3=B2.+-=C2=BA=C3=98=C2=A5=C5-=C3=98=C5=BE=C2 =B2=C3=8B=C5=93=C2=AB=0B=C5-=C3=8BT=C5=B8=C3=B4=C2=AEn=C3=87+=C5- =BAb=C2=A2p+r=18=C2=AFy'=C5=A1=C2=AD=C3=88C=C2=A3 =C3=A5=C2=A1=C2=A7{ =C2=AC=C2=81=C2=AE=C5=92,x(Z=C2=B4P=10>=1A-=C2=A2=C3=88Z=C2=AD=C3=C2=A7v k=C5=93-k=C5=93-j+y=C2=A8ky=C3=B8m=C2=B6=C5=B8=C3=C3=83=0C &j=C3=9A=C3=A8=C5=BE',r=B0=C25=C2=AB=C3=A2=C2=81=C2=ABh=C2=AC=C3=B8 =C5=BE=C2=B5=C3=A9=C3=A9=C2=A2R=C3=A2=C2=B2=C3=98m=C2=B6=C5=B8=C3=C3=83=0C &j=C3=9A=C3=A8=C5=BE',r=B0=C25=C2=AB=C3=A2=C2=81=C2=ABh=C2=AC=C3=B8 =C5=BE=C2=B5=C3=A9=C3=A9=C2=A2R=C3=A2=C2=B2=C3=9F=C3=9A0=04=C3=918=C3=92=02I a=01=14=C3=A4T1$=C5=A1=84=A2=C3=A8+y=C2=AB\=C2=A2{^=C5=BE=C3'=C2=A5=C2=B2 -=C2=AFj)ZnW=C2=AF=B0=C2=ABayg=BA=16=C5-=C3=AE=C5=A1=C3 =86=C2=A1=C2=AD=C3=A7=C3=A1=C2=B6=C3=9A=7F=C3=BD=C3=BA+=C2=BAk&j=C3=9A=C3=A8 =C5=BE',r=B0=C2=A1=C2=B6=C3=9A=7F=C3=BD=C3=BA+=C2=BAk&j=C3=9A=C3=A8=C5 =BE',r=B0=C2h=C2=B8=C2=AC=C2=B4*'=C2=B6=C2=B8=BA=C2=BA=C3=98=C2 =A8=C2=9Dg=BAJ+^N=16=C2=A7=9C*.~=C5-=C3=B2=C2=A2=C3=C3-zw =C2=AB=C2=A2=C3=AB,=C2=BA=C5=A1h=C2=AE=C3=93=1A=C2=B6=C3=90=C3=ABjY^.+-=01=C3 =99=C2=A2=C2=9D=C2=A8ky=C3=B8m=C2=B6=C5=B8=C3=C3=83=0C&j=C3=9A=C3=A8=C5=BE ',r=B0=C2r=B0=C3=AD=C2=AE&=C3=AE=C2=B6*'-=C3=9Bi=C3 =C3=BC0=C3=82f=C2=AD=C2=AE=B0=C3=A2r=C3=87(=BA=C3=B7(=C5=BE=C3=9A =C3=A2n=C3=ABb=C2=A2=7F=C3=9A=C3=BD=C2=C3=9F=C2=A2{=7F=C2=C2=B7=C2n =A1r=C3=BE=1Bf ________________________________________________________________________________
Date: Jul 04, 2014
=C3 the On Jul 4, 2014 9:22 AM, "AircamperN11MS" wrote: > Scott.liefeld(at)lacity.org> > > Good morning Pieters, > I flew for 30 minutes this morning before it gets hot. Lifted off at 5:45 . > Great smooth ride. > Happy Landings, > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426073#426073 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jul 05, 2014
I flew for 1.6 yesterday evening doing my flight review (BFR). I felt very independant. Greg Cardinal ----- Original Message ----- From: "AircamperN11MS" <Scott.liefeld(at)lacity.org> Sent: Thursday, July 03, 2014 2:05 PM Subject: Pietenpol-List: Happy 4th everyone > > > Here's a challenge to all. Lets see how many of us with flying Piets can > commit aviation on the 4th. Even if it is only to go around the pattern > once. Then we'll report back here so we can get a head count. Could be > fun. > > Have fun, > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426027#426027 > > > --- This email is free from viruses and malware because avast! Antivirus protection is active. http://www.avast.com ________________________________________________________________________________
Date: Jul 05, 2014
Subject: First Engine Start - No Joy
-My Fourth was spent doing fuel flow tests and getting ready for the firs t engine run. As mentioned in the subject line, no luck getting the engine to start. At the end of a long day, we spent about two hours and multiple h and propping attempts with no luck...absolutely no sighs of life.-Pulling the #3 lower spark plug verified no fuel was making it into the cylinders. The spark plug was dry and had no smell of fuel. I verified that fuel was in/at the carburetor fuel bowl by loosening the fuel filter nut and allowin g the fuel to-drip out-of my NA-S3B. I do not have any primer system in stalled and I do not have any type starter fluid on hand, so there was no " pre-charge" of the cylinders/carb./intake attempted.=0A=0ABefore I remove t he carb., (or anything else) and start to tear down components, I am open f or suggestions.--I understand that troubleshooting vie email is tough, but I appreciate any help provided.=0A=0AIf God is your co-pilot...switch s eats. =0AMike Perez =0AKaretaker Aero =0ASTILL Building... =0A ________________________________________________________________________________
Subject: Re: First Engine Start - No Joy
Date: Jul 05, 2014
Cover the intake with your hand (I.e. choke it) and rock the prop on an inta ke stroke for each cylinder until you hear it slurping... Or get starter fluid.... Gene On Jul 5, 2014, at 9:14 AM, Michael Perez wrote: > My Fourth was spent doing fuel flow tests and getting ready for the first engine run. As mentioned in the subject line, no luck getting the engine to start. At the end of a long day, we spent about two hours and multiple hand propping attempts with no luck...absolutely no sighs of life. Pulling the # 3 lower spark plug verified no fuel was making it into the cylinders. The sp ark plug was dry and had no smell of fuel. I verified that fuel was in/at th e carburetor fuel bowl by loosening the fuel filter nut and allowing the fue l to drip out of my NA-S3B. I do not have any primer system installed and I d o not have any type starter fluid on hand, so there was no "pre-charge" of t he cylinders/carb./intake attempted. > > Before I remove the carb., (or anything else) and start to tear down compo nents, I am open for suggestions. I understand that troubleshooting vie ema il is tough, but I appreciate any help provided. > > If God is your co-pilot...switch seats. > Mike Perez > Karetaker Aero > STILL Building... > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 05, 2014
Michael, when pulling the prop through can you hear air sucking through the carburetor? Does the sound change when the throttle is opened or closed? Are you running an air cleaner? If so, try propping it with the carb heat "ON" to bypass the air cleaner. Has the carburetor been overhauled and the needle valve checked? Is the needle valve set to maintain fuel at the prescribed level in the float chamber? Lots of questions. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Saturday, July 05, 2014 9:14 AM Subject: Pietenpol-List: First Engine Start - No Joy My Fourth was spent doing fuel flow tests and getting ready for the first engine run. As mentioned in the subject line, no luck getting the engine to start. At the end of a long day, we spent about two hours and multiple hand propping attempts with no luck...absolutely no sighs of life. Pulling the #3 lower spark plug verified no fuel was making it into the cylinders. The spark plug was dry and had no smell of fuel. I verified that fuel was in/at the carburetor fuel bowl by loosening the fuel filter nut and allowing the fuel to drip out of my NA-S3B. I do not have any primer system installed and I do not have any type starter fluid on hand, so there was no "pre-charge" of the cylinders/carb./intake attempted. Before I remove the carb., (or anything else) and start to tear down components, I am open for suggestions. I understand that troubleshooting vie email is tough, but I appreciate any help provided. If God is your co-pilot...switch seats. Mike Perez Karetaker Aero STILL Building... ________________________________________________________________________________
Date: Jul 05, 2014
Hi Gene. Considering I have the heat box in place, should I remove it for t he choke you describe? Would any starting fluid work? (Auto store)- Where is the best place to spray the starter fluid...I have easy access to the p lugged port on the intake spider where a primer nozzle would go.- Could i t really be this simple!?=0A=0AThank you.-=0A=0AIf God is your co-pilot.. .switch seats. =0AMike Perez =0AKaretaker Aero =0ASTILL Building... ________________________________________________________________________________
Date: Jul 05, 2014
If its a 65 you don't really need a primer. Any starter fluid will work. Re move filter and spray into box. If it fires backwards, that means too lean, y ou need more prime. If its a J3 type air box, do like Jack said and pull car b heat and cover the inlet with your hand to choke Gene On Jul 5, 2014, at 9:44 AM, Michael Perez wrote: > Hi Gene. Considering I have the heat box in place, should I remove it for t he choke you describe? Would any starting fluid work? (Auto store) Where is the best place to spray the starter fluid...I have easy access to the plugg ed port on the intake spider where a primer nozzle would go. Could it reall y be this simple!? > > Thank you. > > If God is your co-pilot...switch seats. > Mike Perez > Karetaker Aero > STILL Building... > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 05, 2014
Check your float level Jeff Martin > On Jul 5, 2014, at 9:14 AM, Michael Perez wrote : > > My Fourth was spent doing fuel flow tests and getting ready for the first engine run. As mentioned in the subject line, no luck getting the engine to start. At the end of a long day, we spent about two hours and multiple hand propping attempts with no luck...absolutely no sighs of life. Pulling the # 3 lower spark plug verified no fuel was making it into the cylinders. The sp ark plug was dry and had no smell of fuel. I verified that fuel was in/at th e carburetor fuel bowl by loosening the fuel filter nut and allowing the fue l to drip out of my NA-S3B. I do not have any primer system installed and I d o not have any type starter fluid on hand, so there was no "pre-charge" of t he cylinders/carb./intake attempted. > > Before I remove the carb., (or anything else) and start to tear down compo nents, I am open for suggestions. I understand that troubleshooting vie ema il is tough, but I appreciate any help provided. > > If God is your co-pilot...switch seats. > Mike Perez > Karetaker Aero > STILL Building... > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 05, 2014
Jack, "Lots of questions."- Boy, you and I both!-- I was in cockpit, so I could not hear anything from my vantage point. The engine is currently set up as it would be for flight...heat box, air cleaner, etc.=0A=0AI did the rebuild on the carburetor myself following the correct overhaul manual and various other NA-3B literature I have. I cross referenced the various p art numbers and confirmed that the jets, nozzles, etc. are correct for my e ngine. I installed new seals/gaskets/shims as per the manuals and set the f loat level.- (All to say that I did what I could, but may have missed som ething or did it incorrectly.)=0A=0AWhen I attempt another start, (as soon as my "manual starter" can come back over) I'll do it with the carb. heat O N initially and advise him to listen for suction.=0A=0A=0AIf God is your co -pilot...switch seats. =0AMike Perez =0AKaretaker Aero=0A Attempting first engine start. ________________________________________________________________________________
Date: Jul 05, 2014
I'm sorry, I guess I should start by telling you what engine...it is an A-6 5.-- It is a J3 type box.- Just so I am clear:- do I prime-AND ch oke, or choose/try one or the other?- Do we attempt a start while choking , or are we just covering the inlet and "walking" the prop. to get flow sta rted?=0A=0A=0AIf God is your co-pilot...switch seats. =0AMike Perez =0AKare taker Aero =0AAttempting first engine start ________________________________________________________________________________
Date: Jul 05, 2014
I wouldn't try choking it while starting - too dangerous. Do as Gene suggested, walking the prop through the intake stroke of each cylinder with the switches "OFF" and the intake choked. That should pull enough fuel/air mixture into the cylinders to start it. After doing that for 4-6 blades, remove the choke, turn on the mags and prop it hard. Many people don't prop very vigorously. I find it much easier to start an A65 with a really strong swing - you should be able to prop it hard enough to get two blades before it stops. Just be careful to not wrap your fingers around the trailing edge of the prop very far, in case it does kick backwards (it can break your hand or arm). It's not necessary for you to be in the cockpit, as long as the tail is tied down very securely. Have you had any instruction in hand-propping? Be sure to start stepping back as you pull on the prop, so your body already has momentum away from that meat cleaver in case you fall. It is not necessary to kick your leg up before pulling down on the prop - that is just for Hollywood and actually can make you overbalance and fall headfirst into the prop. If you go to Brodhead later this month Rob Busch and Matt Paxton can both give excellent advice on hand-propping airplanes. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Saturday, July 05, 2014 10:25 AM Subject: Re: Pietenpol-List: First Engine Start - No Joy I'm sorry, I guess I should start by telling you what engine...it is an A-65. It is a J3 type box. Just so I am clear: do I prime AND choke, or choose/try one or the other? Do we attempt a start while choking, or are we just covering the inlet and "walking" the prop. to get flow started? If God is your co-pilot...switch seats. Mike Perez Karetaker Aero Attempting first engine start ________________________________________________________________________________
Date: Jul 05, 2014
Starter fluid or choke. Choke it until you hear sucking and should see fuel dripping. Then prop without choke. Gene On Jul 5, 2014, at 10:24 AM, Michael Perez wrote: > I'm sorry, I guess I should start by telling you what engine...it is an A- 65. It is a J3 type box. Just so I am clear: do I prime AND choke, or ch oose/try one or the other? Do we attempt a start while choking, or are we j ust covering the inlet and "walking" the prop. to get flow started? > > > If God is your co-pilot...switch seats. > Mike Perez > Karetaker Aero > Attempting first engine start > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 05, 2014
I'd check for a stuck needle valve. Is the needle valve attached to the float, or not? Some carbs they are, and some they're not. Light tapping on the carb bowl sometimes helps, air pressure into the bowl can help. Or pull the bowl and double check. If the needle is connected to the float, and you're sure you can hear the float clunking around, then it's probably alright. Might have to pull the carb to check that. I know, I know, NONE of this is fun, especially when everything is safety wired. However, you do need to MAKE SURE the basics are covered. An engine needs three things... air, spark and fuel. The air and spark are the easiest to check in this configuration. You know you have gas to the bowl, so make sure it can get past the float valve. Then the needle. With the throttle closed, it should prime itself. However, to get stuff flowing, I do agree some external prime (heck, a squirt bottle and a LITTLE gas would probably do the job) is a good idea. Not to offend, but EVERY PULL of that prop can be a life threatening event. EVERY SINGLE ONE, I've had a few hard starts (ALWAYS after the engine was off and/or drained) and found myself getting complacent pulling that sucker over. Had to concentrate HARD to pull, and wait, before heading back in to grab the prop again. And manual priming and rocking props can start that thing up. So BE CAREFUL and establish a GOOD SOLID routine with your switch guy. Don't let all the looky loos giving advice on how to get it running get in the way or distract you. Be methodical and make only one change at a time. Don't belabor things too much either. Make a change, give reasonable time, then move on to something else, keeping in mind, it's usually a very basic thing that's wrong, which reminds us, it can start at ANY time! Lastly, if your arms are getting really tired, you're using bad propping technique. Working up a sweat, getting frustrated, generally pooped, all normal, but the arms should hold out. Good technique will keep the rest of you in the game longer and help you get this figured out. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426138#426138 ________________________________________________________________________________
Date: Jul 05, 2014
-Jack,- we do have the tail tied to a car and have two 25 pound weights lying on the rope at the tail wheel. We also have sand bags at the wheels. I just feel better in the cockpit for the added weight and instant access to the throttle/mags.=0A=0AMy starter and I spent time going over proper ha nd propping technique and he did many practice starts to get the fingers, s tepping back, posture, etc. correct and comfortable.- I do thank you for the tips and concerns.=0A=0AIs there a good way to determine when each cyli nder is at the intake stroke?- Do I need to walk the prop through or just rock it, (pump) it? Walking to me implies that the prop is turned in one d irection effectively progressing through all cylinders and all 4 strokes. =0A=0AI am off for flight training and other commitments now, but I will be back later to answer any other questions.=0A=0AThank you all for the help. I hope to try again tomorrow or Monday.=0A=0AMike Perez=0AKaretaker Aero =0AAttempting first engine start ________________________________________________________________________________
Date: Jul 05, 2014
what is the history of the carb??? =0A=0A=0AOn Saturday, July 5, 2014 10:07 AM, Michael Perez wrote:=0A =0A=0A=0A-Jack, - we do have the tail tied to a car and have two 25 pound weights lying o n the rope at the tail wheel. We also have sand bags at the wheels. I just feel better in the cockpit for the added weight and instant access to the t hrottle/mags.=0A=0AMy starter and I spent time going over proper hand propp ing technique and he did many practice starts to get the fingers, stepping back, posture, etc. correct and comfortable.- I do thank you for the tips and concerns.=0A=0AIs there a good way to determine when each cylinder is at the intake stroke?- Do I need to walk the prop through or just rock it , (pump) it? Walking to me implies that the prop is turned in one direction effectively progressing through all cylinders and all 4 strokes.=0A=0AI am off for flight training and other commitments now, but I will be back late r to answer any other questions.=0A=0AThank you all for the help. I hope to try again tomorrow or Monday.=0A=0AMike Perez=0AKaretaker Aero=0AAttemptin ________________________________________________________________________________
Date: Jul 05, 2014
might try asking asking mr g- =0A=0A=0AOn Saturday, July 5, 2014 9:53 AM , Gene Rambo wrote:=0A =0A=0A=0AStarter fluid or choke . -Choke it until you hear sucking and should see fuel dripping. Then pro p without choke.-=0A=0AGene=0A=0AOn Jul 5, 2014, at 10:24 AM, Michael Per ez wrote:=0A=0A=0AI'm sorry, I guess I should st art by telling you what engine...it is an A-65.-- It is a J3 type box. - Just so I am clear:- do I prime-AND choke, or choose/try one or the other?- Do we attempt a start while choking, or are we just covering the inlet and "walking" the prop. to get flow started?=0A>=0A>=0A>If God is yo ur co-pilot...switch seats. =0A>Mike Perez =0A>Karetaker Aero =0A>Attemptin 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Jul 05, 2014
Subject: A65 carb attachment
Good People, On some small Continental engines the carb has a strap or metal mount in addition to where it is attached to the engine. On some it does not. Is this a function of where the glass bowl fuel strainer is? I don't think I need it, My fuel strainer is on the firewall. What have y'all done? -- Blue Skies, Steve D ________________________________________________________________________________
Date: Jul 05, 2014
Mike, You probably have done this, but number one, tie the tail down with a rope and knots that you would feel comfortable restraining a pit bull next to an elementary school playground with. Do not trust wheel chocks nor brakes. If it starts unexpectedly, your throttle and mag switch may not be set, and have a CO2 fire extinguisher on hand. 10 years ago a FL Piet project was largely destroyed on the first start for want of 6 feet of rope. Any engine that is giving trouble starting is a distraction, and is creating a situation that could lead to inattention on the brakes. Two hours is a lot of hand propping on a warm day to not have a single hint of life. Even if you don't know the starting drill on a 65 yet, in 120 minutes you will have by random chance a pop over if everything is set right. Go back and check things. Popping over on starter fluid does not correct what is out of adjustment. You don't need the motor to run to time the mags and verify float height. Now comes the stuff only a tactless person would say: If the guy who is teaching you about hand propping a 65 doesn't already know every single thing that has been written by Jack and the other's he is the wrong guy to be helping you. Hand propping and diagnosing engine issues are skills to learn, but if your guy doesn't know what is going on in 2 hours, you need a better in person assistant, or to have the realization that you are on your own. You can not imagine how many people I speak to every year who are new to airplanes and have 'a buddy' who is just providing a false sense of progress and security while the stumble on. Tactless part #2. If in any way shape or form, it turns out that your 'carb rebuild' or any of the adjustments to it are the starting issue, take it as a warning shot from the universe not to play aircraft mechanic on critical items. Sounds harsh, but read this story about a guy I knew who insisted that anyone could rebuild an airplane carb, that hubris and an internal mistake, killed him on the first flight: http://flycorvair.net/2013/04/20/risk-management-judgement-error-money-in-the-wrong-place/ Not to hurt your feelings but your tone on carbs reminds me of Ken. I asked him 3 times to have a pro check it, he died a week later. Any engine, Continental, Corvair or Lycoming, if it is set correctly should start near instantly on a warm day, even if it has never started before. The average crank time on a brand new Corvair at a College is 3 seconds. A perfectly set new 65 should light on maybe 5 blade pulls. Tactless part #3: if the best prep work you can do before a start test doesn't work, take it as an important sign that you need to re-evaluate what you think you know, and who you think you are learning it from. It should not take two hours of pulling on a prop and an email from a tactless jackass in Florida to have a 'moment of awareness' on this. In the past you have offered a lot of information for sale for a guy who can't start an engine today. I have been an A&P for 24 years, but I still touch every plane cognizant that safety is only found after you discard the myth of personal infallibility. If you would like to learn more, This link has stories of a number of friends of mine, all dead now: http://flycorvair.net/2014/01/21/risk-management-reference-page/ -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426144#426144 ________________________________________________________________________________
Date: Jul 05, 2014
One last cautionary tale. We have a Piper Cub with an A-75. During it's last annual, the mechanic had the mag switch OFF preparing for an engine run and pulled the engine through slowly. It was cold and unprimed but started anyway. Scared the crap out of him. He DID have it safely tied to a concrete post and chocked so there was no further drama. Turned out there was crud in the 60+ year old switch and it provided a path for the p-lead. The lesson to be taken from this was mentioned earlier. ALWAYS treat the engine as "live" if it's completely assembled. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426145#426145 ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Jul 05, 2014
Never got up yesterday - just didn't feel like fighting such winds, but today was spectacular. I took my wife, Karen, up and she got a number of good pictures of Smith Mountain Lake, where we live. I never get tired of the views flying over the lake. Here is my favorite of the pictures she shot: Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Boatright, Jeffrey Sent: Friday, July 04, 2014 10:32 PM Subject: Re: Pietenpol-List: Re: Happy 4th everyone Glorious morning flight today on the 4th! Very cool temps for this time of year in Atlanta. I was actually chilly at 2300 MSL. Went down to 1700 MSL for warmth and, oddly, fewer bumps. -- Jeffrey H. Boatright, PhD, FARVO Professor of Ophthalmology Emory University School of Medicine From: Jack Phillips <jack(at)bedfordlandings.com> Date: Friday, July 4, 2014 at 1:08 PM Subject: RE: Pietenpol-List: Re: Happy 4th everyone I'm waiting till this evening. Right now we have winds at 15 knots with gusts to 25, directly across the runway. Too much work flying in such winds! Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Friday, July 04, 2014 10:20 AM Subject: Pietenpol-List: Re: Happy 4th everyone Good morning Pieters, I flew for 30 minutes this morning before it gets hot. Lifted off at 5:45. Great smooth ride. Happy Landings, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426073#426073 _____ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ~=03 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: July 4th flights
Date: Jul 05, 2014
Stupid iphone, it discourages me from writing long enough, so here's the full story. Marci and I shared a gorgeous 20 minute morning flight, buzzed our house and some friends houses, landed and started our day. That evening, our entire July 4th party wanted to fly so to the airport we go. Set a Douwe record, 7 flights back to back. Aint much for some of you veterans, but a lot for po ole RE-PIET and Douwe. Was SO much fun. Not super strong winds, but CRAZY directionally, constantly shifting, could almost never tell which way to take off or land! Once when coming in with a big dude, the wind shifted 180 from my nose to my tail on final!! Gave some people and kids their first real flying experience and every single one enjoyed it immensely. My mother in law was crying when we landed. She said it was because of the beauty, but maybe it was my landing, who knows! I can feel RE-PIET chompin' at the bit to stretch her legs a bit in a few weeks!!! Happy 4th. Douwe ________________________________________________________________________________
Date: Jul 05, 2014
Beautiful Jack. I tried to post the pictures my wife took of our flight yest erday but we didn't do something right and it didn't go through. Hope everyo ne had a great 4th. Randy Bush Sent from my iPhone On Jul 5, 2014, at 12:16 PM, "Jack Phillips" wrot e: > Never got up yesterday =93 just didn=99t feel like fighting su ch winds, but today was spectacular. I took my wife, Karen, up and she got a number of good pictures of Smith Mountain Lake, where we live. I never get tired of the views flying over the lake. Here is my favorite of the pictur es she shot: > > > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Boatright, Jeffrey > Sent: Friday, July 04, 2014 10:32 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Happy 4th everyone > > Glorious morning flight today on the 4th! Very cool temps for this time o f year in Atlanta. I was actually chilly at 2300 MSL. Went down to 1700 MSL f or warmth and, oddly, fewer bumps. > -- > > Jeffrey H. Boatright, PhD, FARVO > Professor of Ophthalmology > Emory University School of Medicine > > From: Jack Phillips <jack(at)bedfordlandings.com> > Reply-To: "pietenpol-list(at)matronics.com" > Date: Friday, July 4, 2014 at 1:08 PM > To: "pietenpol-list(at)matronics.com" > Subject: RE: Pietenpol-List: Re: Happy 4th everyone > s.com> > > I'm waiting till this evening. Right now we have winds at 15 knots with > gusts to 25, directly across the runway. Too much work flying in such > winds! > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > AircamperN11MS > Sent: Friday, July 04, 2014 10:20 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Happy 4th everyone > > > > Good morning Pieters, > I flew for 30 minutes this morning before it gets hot. Lifted off at 5:45. > Great smooth ride. > Happy Landings, > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426073#426073 > > > > > > > > > > > > > http://www.matronics.com/Navigator?Pietenpol-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > > > > > This e-mail message (including any attachments) is for the sole use of > the intended recipient(s) and may contain confidential and privileged > information. If the reader of this message is not the intended > recipient, you are hereby notified that any dissemination, distribution > or copying of this message (including any attachments) is strictly > prohibited. > > If you have received this message in error, please contact > the sender by reply e-mail message and destroy all copies of the > original message (including attachments). > ~=03 ________________________________________________________________________________
Subject: Re: Happy 4th everyone
Date: Jul 05, 2014
I flew 1.2 again this morning. Took an old friend of mine. It was his first ride in the Piet. He was smiling ear to ear when we got back. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426163#426163 ________________________________________________________________________________
Subject: Re: A65 carb attachment
Date: Jul 05, 2014
Steve; are you talking about the blue bracket ahead of the carb in the picture attached? I asked the same question and got varied answers. 41CC has always had that bracket but the original one broke in the nose-over. When I found out how much the Continental part cost, I made my own. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426164#426164 Attachments: http://forums.matronics.com//files/a75final001_594.jpg ________________________________________________________________________________
Date: Jul 05, 2014
Gene, thank you. I understand now. Mike Perez Karetaker Aero Attempting first engine start ________________________________________________________________________________
Date: Jul 05, 2014
Understood Dave. We are treating everything at this point as unknowns and, like you said, consider every time the prop. is touched that it will start. Mike Perez Karetaker Aero Attempting first engine start ________________________________________________________________________________
Date: Jul 05, 2014
Thank you all for the advice.- It appears that I may get another shot at this thing tomorrow. I will try the various suggestions to see if I can at least get the plugs wet. At that point, I hope to get a sputter or cough to verify that some form of ignition is present. Either way, I will try to up date the list as to how things went.=0A=0AMike Perez=0AKaretaker Aero=0AAtt empting first engine start ________________________________________________________________________________
Date: Jul 05, 2014
Subject: July 5th...New Milestone
-It has been a long time coming, but today I finally soloed! It was great weather for it and after three circuits around the pattern, I did another three solo.- I was very surprised that I was not nervous, concerned or wo rried in any way. Everything felt really good and I was very calm...no diff erent then when driving a car. It all went very well and I could not be mor e pleased.- =0A=0AAs I mentioned in another thread, tomorrow it is back t o trying for my first engine start.=0A=0AMike Perez=0AKaretaker Aero=0AAtte mpting first engine start ________________________________________________________________________________
Date: Jul 05, 2014
Subject: Re: July 5th...New Milestone
Congratulations on the first solo Michael. Jim B. ________________________________________________________________________________
Date: Jul 05, 2014
Congratulations, Michael! You've taken the first step into a larger world. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Saturday, July 05, 2014 6:27 PM Subject: Pietenpol-List: July 5th...New Milestone It has been a long time coming, but today I finally soloed! It was great weather for it and after three circuits around the pattern, I did another three solo. I was very surprised that I was not nervous, concerned or worried in any way. Everything felt really good and I was very calm...no different then when driving a car. It all went very well and I could not be more pleased. As I mentioned in another thread, tomorrow it is back to trying for my first engine start. Mike Perez Karetaker Aero Attempting first engine start ________________________________________________________________________________
Date: Jul 05, 2014
Jack, Beautiful photo. I was just in Virginia last week, absolutely beautiful! Do I remember that you are that you are planning on an airport bed and breakfast ? I visited Kill Devil Hills for the first time, very impressive. They let m e take many photos of the 1903 Flyer...close ups. Are your jury struts just round tubing, what size? Thanks, Ray Krause Building SkyScout Sent from my iPad > On Jul 5, 2014, at 10:16 AM, "Jack Phillips" wr ote: > > Never got up yesterday =93 just didn=99t feel like fighting su ch winds, but today was spectacular. I took my wife, Karen, up and she got a number of good pictures of Smith Mountain Lake, where we live. I never get tired of the views flying over the lake. Here is my favorite of the pictur es she shot: > > > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Boatright, Jeffrey > Sent: Friday, July 04, 2014 10:32 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Happy 4th everyone > > Glorious morning flight today on the 4th! Very cool temps for this time o f year in Atlanta. I was actually chilly at 2300 MSL. Went down to 1700 MSL f or warmth and, oddly, fewer bumps. > -- > > Jeffrey H. Boatright, PhD, FARVO > Professor of Ophthalmology > Emory University School of Medicine > > From: Jack Phillips <jack(at)bedfordlandings.com> > Reply-To: "pietenpol-list(at)matronics.com" > Date: Friday, July 4, 2014 at 1:08 PM > To: "pietenpol-list(at)matronics.com" > Subject: RE: Pietenpol-List: Re: Happy 4th everyone > s.com> > > I'm waiting till this evening. Right now we have winds at 15 knots with > gusts to 25, directly across the runway. Too much work flying in such > winds! > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > AircamperN11MS > Sent: Friday, July 04, 2014 10:20 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Happy 4th everyone > > > > Good morning Pieters, > I flew for 30 minutes this morning before it gets hot. Lifted off at 5:45. > Great smooth ride. > Happy Landings, > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426073#426073 > > > > > > > > > > > > > http://www.matronics.com/Navigator?Pietenpol-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > > > > > This e-mail message (including any attachments) is for the sole use of > the intended recipient(s) and may contain confidential and privileged > information. If the reader of this message is not the intended > recipient, you are hereby notified that any dissemination, distribution > or copying of this message (including any attachments) is strictly > prohibited. > > If you have received this message in error, please contact > the sender by reply e-mail message and destroy all copies of the > original message (including attachments). > ~=03 ________________________________________________________________________________
From: Scott Knowlton <flyingscott_k(at)hotmail.com>
Date: Jul 06, 2014
Congrats Michael!!!! Another fledgling leaves the nest. No small feat and o ne very few humans on this planet accomplish. Scott K Sent from my iPhone > On Jul 6, 2014, at 12:29 AM, "Michael Perez" wr ote: > > It has been a long time coming, but today I finally soloed! It was great w eather for it and after three circuits around the pattern, I did another thr ee solo. I was very surprised that I was not nervous, concerned or worried i n any way. Everything felt really good and I was very calm...no different th en when driving a car. It all went very well and I could not be more pleased . > > As I mentioned in another thread, tomorrow it is back to trying for my fir st engine start. > > Mike Perez > Karetaker Aero > Attempting first engine start > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: A perspective on Carbs, Mags and Certified engines
Date: Jul 06, 2014
Builders, I have been an light aircraft mechanic in Florida for a long time. One of inspection tasks that is occasionally done is looking over a single engine plane before it flies to the Bahamas. The gap from West Palm to West End is 56 miles, and smart pilots, particularly those renting, get another set of eyes on the plane before they stick their family in it. When given 30 minutes to evaluate a certified engine's condition on the ramp, my focus is on the Mags and the Carb, as there two are the most likely sources of taking a swim. A slightly low compression cylinder is not the same trouble as a failed mag on a 95 degree day with four people in a C-172. If the Mags and the carb are working perfectly, odds of other trouble are quite low. The slightest hint of issue from either is a good reason to delay the trip. . The exact same logic applies to Experimentals, and I can make a statistical case that flying the 40 hours on a new homebuilt, even one with a certified engine, is greater risk that flying for a week in the Bahamas. If a neighbor chose an A-65 Continental for his newly built Pietenpol, I wouldn't be concerned that the basic engine had 800 hrs. on it. If it has consistent oil pressure. it is not likely to throw a rod, but I would advise him to stack the deck in his favor and make absolutely sure that he had a perfect Carb and Mags on it, as they are the likely source of any issue. When looking at the O-320 headed to the islands, I look at the logs to make sure that the last people who touched the mags and carb were in a repair station, or the factory. After visual inspection for leaks and security, I run the engine to full power and try to make it misbehave with the throttle and mixture. A critical test is full static power and slightly leaning must show an rpm increase. Carb heat must work, and cutting off the fuel and letting it idle must cause a 25-50 rpm rise before it quits. Engine must idle as solid as a rock. Turn the prop and feel for low compression and listen for impulses to click at the same time. The 1/2" nuts holding the mags are checked for torque. Hands on mags to make sure they are secure. Leads traced to look for cuts, every 3/4 nut checked. Engine is started and the key is messed with to make sure a worn switch will not short. The run up is performed with the engine heat soaked, because mags have trouble when they are hot, not cold. Zero tolerance outside of limits on mag drop. The goal is to find the circumstances in which it misbehaves, not to show that it runs ok. Any discrepancy on mags or Carb, even one that is hard to quantify, is cause for the delay of the trip. If I bring any issue to the pilots attention and he responds with a variation on "It will be alright" I never fly with him nor work for him again. I am not a cat, I don't have 9 lives. . If a newly finished home built has a used certified engine on it, and the builder is having trouble starting it, odds are the trouble is with the Mags or the carb. If it is stored in a reasonably dry place, a piston in a bore can happily wait 20 years to be re-stared, but the points in mags don't like this and carbs don't like fuel, especially auto fuel evaporating from them. (The sole common exception to the mags-carb rule is the camshafts on Lycomings left to sit often corrode and if the engine is run without correcting this the grind the lobes off in a few hours and pump the metal through the oil system.) A homebuilder is allowed to fix his own carb and mags if they need attention, and there are manuals and parts lists on the net, but I can make a case that this isn't always smart. . Looking at the carb: aircraft carbs are deceptively simple, and they look far easier to rebuild than a four barrel. Here is the hidden issue: Many carbs on engines for home builts are 60 years old and have had long periods of inactivity, previous owners mix and match parts, and people who like to drill out jets. A skilled guy in a FAA fuel system repair station can spot all of these, but a homebuilder is likely blind to them. I like aircraft carbs, and I teach people to use them after sending them to a professional. Maybe 3 of 10 NAS3's or MA3's sold at fly marts have mix and match parts inside. Hard starting is not the worst thing about poorly tuned carbs. First, a carb that is set too lean or has a malfunctioning enrichment circuit will damage the engine in flight. Second, ones that don't run smooth will often quit at idle. Put this on a hand prop plane and combine it with the fact that many pilots don't fly every pattern power off, and the new homebuilt ends up 100 yards short of the runway threshold. For more info on carbs, look at this link: http://flycorvair.net/2013/12/03/carburetor-reference-page/ . I do not trust mags that have no logs, were repaired by amateurs, or have had a decade with no inspection of any kind. My neighbor owned a Mag test bench that could run all brands and evaluate them with proper loads on the leads, a tool you find in a Mag repair station. He just sold it on Ebay and got $4,000 for it. If it was actually possible to properly evaluate, repair, overhaul and test aircraft mags without this tool, then it would not be possible to sell it for $4,000. It is legal for a homebuilder to 'repair' his own mags, but no rational person who make the argument that a first time amateur without the test device could do as good a job as a professional with the correct equipment. . Now lets think about a new Pietenpol getting ready for it's first flight: Plane is built by a nice guy, but planes are a hobby, not a career. A tech counselor looked at it, but that man's experience was building one RV-6A, and all his "looks good" offered was a false sense of security. It passes the FAA exam, with a DAR that charges $400 but didn't even ask to see it run. The plane is out of rig, but no one knows this yet. The low time pilot's time in type is two trips around the pattern at Brodhead. He got 3 hours of tail wheel in a Cessna 170, (a plane that could land itself) but he was not allowed to solo it. The pilot has never flown anything that has the short glide ratio of a Piet. At his last Biennial the CFI allowed him to drag the 152 in with power and plop it down on the runway. He is nervous enough even without the video cameras, but there is a growing group of spectators adding pressure. Under these conditions, does it sound smart that he is also flying the first aircraft carb that he has ever 'rebuilt'? . A small continental is an easy engine to troubleshoot if you are trained on them. This training can come in many forms, but the most effective is learning them in person, from someone who knows them. Theoretically you could learn to fly by reading a book, but everyone understands that in person flight training works. I only make the same point with maintenance, that instruction is best, person to person. On a relative scale, making one run that is reluctant to start is very easy compared to doing an airworthy job overhauling a carb or a mag without specific tools or training. Everyone is entitled to their own opinion about this, but what ever difference in opinion is, the wager riding on the opinion is the same, the whole value of the plane and the lives of the people in it. Place your bet carefully. I like Continentals, and have a lot of time flying behind them. Their primary quality is reliability. This well earned reputation was made seven decades ago, when homebuilding was still illegal in the US. The Continental reputation was built on relatively new engines, installed at factories, and maintained by trained, licensed A&E mechanics, in a era where people had longer attention spans. Seventy years later, anyone expecting that the same reputation magically lives in the metal is deluding themselves. To get the same results, you have to get as close to the original format as possible. But the issue is that the parts can be old, the details of the installation on a homebuilt can be weak, and the guy working on the carb may have never built one before. Is the issue beginning to make some sense? To even get close to the original reliability, One must spend some money on parts, the used parts must have a history and be within limits, and critical items like mags and the carb should be done or at least checked by a repair station. You can choose to do otherwise, but it is not possible to then argue that you can expect the full reputation for reliability. Anyone who thinks that you can have the reliability of a certified motor when you buy one that is advertised as no logs or experimental only is mistaken. You dont get to have it both ways. Continentals reputation was not built on engines made of junk and spray painted. If the engine was just as reliable with out of spec parts, then they wouldnt be out of spec would they? . There are always people who argue that they have to have a reliable certified engine and that they will not fly auto engines. Then the first thing they do is go out and look for the cheapest collection of parts bolted together that are masquerading as a certified engine, made of out of spec parts. That behavior isnt rational, but people who are compulsively cheap often are satisfied with the illusion of reliability instead of the real thing. Want to know who isnt fooled by this? Our old friends Physics, Chemistry and Gravity. If the FAA considers the engine un-airworthy in a certified plane, it is just as un-airworthy in an experimental one. Physics, Chemistry and Gravity dont care if the plane was built in a factory or your garage. An engine built of out of spec parts doesnt magically become airworthy when it is bolted on an experimental. . I am an Embry-Riddle trained A&P with 24 years of continuous work on light aircraft. I am qualified to work on virtualy any part in GA planes, but that doesn't mean I am reluctant to hire other mechanics with greater experience and better tooling. When the right mag had excessive drop on the C-85 in my wife's Taylorcraft, I could have replaced the cracked coil myself, but instead I took both mags to a repair station and waited while they were overhauled. In the last 10 years we have finished several homebuilts, and I could have overhauled each of the carbs myself, but I elected to send them all to a certified repair station. The difference between 'fixed' and 'Yellow tagged' is often hundreds of dollars. It sounds like a lot of money until you have lived through to plane crashes and attended a few funerals. 90% of the people reading this make more money than I do, and 95% have less experience with aircraft engines. If those people are trying to save money by fixing a mag or a carb themselves, when I would send the same part out, they should rethink that plan. My known specialty is training amateurs to build aircraft engines for experimental aircraft. It doesn't matter that the hardware is mostly Chevrolet and not Continental, It isn't about metal, it is about the capacity of builders to learn, and I am not speaking of turning wrenches, I am speaking of learning to make good decisions in a very unforgiving environment. No one has to agree with my perspective, but I have been doing this for long enough, with enough homebuilders that it is worth considering carefully. Homebuilding, including building engines, can be done with reasonably low risk, but only when the builder makes good decisions. -ww Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426182#426182 ________________________________________________________________________________
Date: Jul 06, 2014
Congratulations Michael! Youll fly with more confidence now knowing that guy in the right seat isnt really needed. John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426183#426183 ________________________________________________________________________________
Subject: solo
Date: Jul 06, 2014
Congratulations Mike! Douwe ________________________________________________________________________________
Date: Jul 06, 2014
Thanks, Ray. We opened our Fly-In Bed & Breakfast last December. You can check it out at www.bedfordlandings.com <http://www.bedfordlandings.com/> . We've had a number of Fly-in guests, but so far nobody has come in a Pietenpol to stay the night (half off if they do!). We have had some interesting airplanes in here, such as Gene Rambo's 1927 Travel Air (you might remember seeing it at Brodhead last year). Here is a picture of it in our hangar: As for my jury struts, they are 5/16" x .035" round tubing. Jury struts are necessary to keep the lift struts from buckling under compression loads, but they carry almost no load themselves, so they don't need to be very stout. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause Sent: Saturday, July 05, 2014 10:21 PM Subject: Re: Pietenpol-List: Re: Happy 4th everyone Jack, Beautiful photo. I was just in Virginia last week, absolutely beautiful! Do I remember that you are that you are planning on an airport bed and breakfast? I visited Kill Devil Hills for the first time, very impressive. They let me take many photos of the 1903 Flyer...close ups. Are your jury struts just round tubing, what size? Thanks, Ray Krause Building SkyScout Sent from my iPad On Jul 5, 2014, at 10:16 AM, "Jack Phillips" wrote: Never got up yesterday - just didn't feel like fighting such winds, but today was spectacular. I took my wife, Karen, up and she got a number of good pictures of Smith Mountain Lake, where we live. I never get tired of the views flying over the lake. Here is my favorite of the pictures she shot: Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Boatright, Jeffrey Sent: Friday, July 04, 2014 10:32 PM Subject: Re: Pietenpol-List: Re: Happy 4th everyone Glorious morning flight today on the 4th! Very cool temps for this time of year in Atlanta. I was actually chilly at 2300 MSL. Went down to 1700 MSL for warmth and, oddly, fewer bumps. -- Jeffrey H. Boatright, PhD, FARVO Professor of Ophthalmology Emory University School of Medicine From: Jack Phillips <jack(at)bedfordlandings.com> Date: Friday, July 4, 2014 at 1:08 PM Subject: RE: Pietenpol-List: Re: Happy 4th everyone I'm waiting till this evening. Right now we have winds at 15 knots with gusts to 25, directly across the runway. Too much work flying in such winds! Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Friday, July 04, 2014 10:20 AM Subject: Pietenpol-List: Re: Happy 4th everyone Good morning Pieters, I flew for 30 minutes this morning before it gets hot. Lifted off at 5:45. Great smooth ride. Happy Landings, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426073#426073 <http://www.matronics.com/Navigator?Pietenpol-List> http://www.matronics.com/Navigator?Pietenpol-List <http://forums.matronics.com> http://forums.matronics.com <http://www.matronics.com/contribution> http://www.matronics.com/contribution _____ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ~ _____ ________________________________________________________________________________
Subject: Re: A perspective on Carbs, Mags and Certified engines
Date: Jul 06, 2014
Thanks, William. As always, I appreciate your insight on risk management in homebuilding. Thoughtful builders will read carefully. -------- Kevin "Axel" Purtee Rebuilding NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426186#426186 ________________________________________________________________________________
Date: Jul 06, 2014
Subject: BFR
Not on the 4th, but on the 5th I did a biennial flight ride in a 1947 Piper Cub. Sure felt good. After almost 2 years of not flying. CFI had about 300 hours in a taildragger, mostly as an instructor. He is still a little edgy about landings. The old pilot who taught me tailwheel in a Champ really taught me right. All of my landings were spot on. Much better than the instructors two. Wheel landings and three point. He also was slightly nervous about 3 point takeoffs. Just to brag, he said he had never seen better landings. Before going on this flight I reread the tailwheel chapter in "What I didn't learn in flying school" by Vern Foster. It was a great refresher. Since Vern (96 Years Old) gave me my tailwheel checkout, I really understood his description of tailwheeling. This Piper cub is very basic, like a Piet. Not even a ball. It rents for $85 per hour. You have to have renter's insurance for $40,000. It only rents out 4 times a month. If I wasn't doing my Piet, that would sure be a cheap way to fly once a week. Blue Skies, Steve D -- Blue Skies, Steve D ________________________________________________________________________________
Date: Jul 06, 2014
Congratulations, Once I was signed off to fly on my own it was hard to motivate myself for my ticket. I was happy just flying around on my own. Blue Skies,Steve D On Sat, Jul 5, 2014 at 5:26 PM, Michael Perez wrote: > It has been a long time coming, but today I finally soloed! It was great > weather for it and after three circuits around the pattern, I did another > three solo. I was very surprised that I was not nervous, concerned or > worried in any way. Everything felt really good and I was very calm...no > different then when driving a car. It all went very well and I could not be > more pleased. > > As I mentioned in another thread, tomorrow it is back to trying for my > first engine start. > > Mike Perez > Karetaker Aero > Attempting first engine start > > * > > > * > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Jul 06, 2014
Mike, Congratulations isn't enough. Good job. Now you need to decide whether you want to cheat gravity by yourself or build. Tough decision considering we only have 24 hours in a day. Keep plugging away. Happy landings, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426193#426193 ________________________________________________________________________________
Date: Jul 06, 2014
Mike, Congratulations isn't enough. Good job. Now you need to decide whether you want to cheat gravity by yourself or build. Tough decision considering we only have 24 hours in a day. Keep plugging away. Happy landings, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426194#426194 ________________________________________________________________________________
Date: Jul 06, 2014
Hi William, Could you please give me a quick call at first chance. I tried calling the office but your mail box was full. 661-400-1876. Regards, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426195#426195 ________________________________________________________________________________
Date: Jul 06, 2014
Thanks, Jack. Your jury struts are the first ones I noticed that were not ai rfoil in shape. Not sure it would make much difference on such a draggy plan e! I will try to remember you Smith Mountain "resort". Maybe pay you a visit s omeday! Thanks.....nice plane that Rambo guy has! Ray Krause Sent from my iPad > On Jul 6, 2014, at 5:56 AM, "Jack Phillips" wro te: > > Thanks, Ray. > > We opened our Fly-In Bed & Breakfast last December. You can check it out a t www.bedfordlandings.com . We=99ve had a number of Fly-in guests, bu t so far nobody has come in a Pietenpol to stay the night (half off if they d o!). We have had some interesting airplanes in here, such as Gene Rambo =99s 1927 Travel Air (you might remember seeing it at Brodhead last year). H ere is a picture of it in our hangar: > > > > As for my jury struts, they are 5/16=9D x .035=9D round tubing . Jury struts are necessary to keep the lift struts from buckling under com pression loads, but they carry almost no load themselves, so they don=99 t need to be very stout. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Ray Krause > Sent: Saturday, July 05, 2014 10:21 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Happy 4th everyone > > Jack, > > Beautiful photo. I was just in Virginia last week, absolutely beautiful! D o I remember that you are that you are planning on an airport bed and breakf ast? I visited Kill Devil Hills for the first time, very impressive. They le t me take many photos of the 1903 Flyer...close ups. > > Are your jury struts just round tubing, what size? > > Thanks, > > Ray Krause > Building SkyScout > > Sent from my iPad > >> On Jul 5, 2014, at 10:16 AM, "Jack Phillips" w rote: >> Never got up yesterday =93 just didn=99t feel like fighting s uch winds, but today was spectacular. I took my wife, Karen, up and she got a number of good pictures of Smith Mountain Lake, where we live. I never g et tired of the views flying over the lake. Here is my favorite of the pict ures she shot: >> >> >> >> Jack Phillips >> NX899JP >> Smith Mountain Lake, Virginia >> >> From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-l ist-server(at)matronics.com] On Behalf Of Boatright, Jeffrey >> Sent: Friday, July 04, 2014 10:32 PM >> To: pietenpol-list(at)matronics.com >> Subject: Re: Pietenpol-List: Re: Happy 4th everyone >> >> Glorious morning flight today on the 4th! Very cool temps for this time o f year in Atlanta. I was actually chilly at 2300 MSL. Went down to 1700 MSL f or warmth and, oddly, fewer bumps. >> -- >> >> Jeffrey H. Boatright, PhD, FARVO >> Professor of Ophthalmology >> Emory University School of Medicine >> >> From: Jack Phillips <jack(at)bedfordlandings.com> >> Reply-To: "pietenpol-list(at)matronics.com" >> Date: Friday, July 4, 2014 at 1:08 PM >> To: "pietenpol-list(at)matronics.com" >> Subject: RE: Pietenpol-List: Re: Happy 4th everyone >> gs.com> >> >> I'm waiting till this evening. Right now we have winds at 15 knots with >> gusts to 25, directly across the runway. Too much work flying in such >> winds! >> >> Jack Phillips >> NX899JP >> Smith Mountain Lake, Virginia >> >> -----Original Message----- >> From: owner-pietenpol-list-server(at)matronics.com >> [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of >> AircamperN11MS >> Sent: Friday, July 04, 2014 10:20 AM >> To: pietenpol-list(at)matronics.com >> Subject: Pietenpol-List: Re: Happy 4th everyone >> >> >> >> Good morning Pieters, >> I flew for 30 minutes this morning before it gets hot. Lifted off at 5:45 . >> Great smooth ride. >> Happy Landings, >> >> -------- >> Scott Liefeld >> Flying N11MS since March 1972 >> Steel Tube >> C-85-12 >> Wire Wheels >> Brodhead in 1996 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=426073#426073 >> >> >> >> >> >> >> >> >> >> >> >> >> http://www.matronics.com/Navigator?Pietenpol-List >> http://forums.matronics.com >> http://www.matronics.com/contribution >> >> >> >> >> >> >> This e-mail message (including any attachments) is for the sole use of >> the intended recipient(s) and may contain confidential and privileged >> information. If the reader of this message is not the intended >> recipient, you are hereby notified that any dissemination, distribution >> or copying of this message (including any attachments) is strictly >> prohibited. >> >> If you have received this message in error, please contact >> the sender by reply e-mail message and destroy all copies of the >> original message (including attachments). >> ~ > > > http://www.matronics.com/Navigator?Pietenpol-List > http://forums.matronics.com > http://www.matronics.com/contribution > ________________________________________________________________________________
Subject: Cast aluminium hinges
Date: Jul 06, 2014
Hi everybody - I am wondering if anybody has a set of the aluminum cast hinges (Vi Kepler - I believe) for the tail feathers. I am debating what type of hinges to used (debating if I want to make my own or not) and I was wondering if there are even any of those cast alum. hinges available. Thanks Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426214#426214 ________________________________________________________________________________
Subject: Steel
Date: Jul 06, 2014
Hi, Here's a question which I'm sure will be controversial (sorry...) I'm getting ready to start making/welding my metal fittings for the control assembly and landing gear. I was all set to order a bunch of 4130 steel sheet/tube - until I started reading about welding 4130... Apparently it is quite sensitive to sudden heating/cooling - (i.e. what happens in welding) I am very experienced with mig welding but have limited experience with gas welding. >From my understanding mig welding 4130 can be very tricky. As I started to research this issue I came across an experienced Piet builder (built/flew 3 piets) who used mild steel (I'm assuming 1018 mild/cold rolled). He argued that the original Piets were designed/built by Bernie Pietenpol using mild steel and so it is completely adequate (and the fittings are designed to work with the strength of mild steel). I know I can safely weld mild steel with mig - so I'm wondering if I should just use mild steel. On the other hand I could go with 4130 which would presumably make my plane safer (technically stronger). However, if welded improperly (or heated/cooled improperly) I could actually end up with fittings that are weaker than properly welded mild steel. I do have limited access to an oxy/acetylene welder and I could take a sport-air class on aircraft welding - if that is absolutely the best option I'll just have to get the gas welding skills (or get someone to weld for me) - I guess I'm looking for some help thinking this through - Is anyone else building with mild steel? Is anyone using mig to weld 4130? Thanks (and sorry for the lengthy question) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426218#426218 ________________________________________________________________________________
Subject: WW's post
Date: Jul 07, 2014
Thanks William for taking the time to give such a thorough and practical explanation/warning. This is the type of stuff that sneaks up on us and can bite us bad and I think it's great to get a dose of reality sometimes. See you soon! Douwe ________________________________________________________________________________
Subject: mild steel-4130
Date: Jul 07, 2014
We MIG a lot of aluminum, and I tig'd my Piet together, but haven't migged 4130. I've not heard of it being tricky, and almost every race car you see is migged 4130 tubing, so it can't be that hard. I don't honestly think the control system experiences any strong loads, just repetitive type movements and it worked fine before 4130. Just be sure that the "mild steel" you choose is at least the equivalent of what Bernard used. However. I would still use 4130 because I'm sure it migs fine, might be a few tricks, but shouldn't be too hard. $.02 Douwe ________________________________________________________________________________
Subject: Re: mild steel-4130
Date: Jul 07, 2014
Thanks for your thoughts - I would prefer to use to use 4130 - even if it is overkill - because safer is better - If I can mig 4130 safely that's the way I'll go. I guess my only reservation is the ability to test my welds. Do you know of any way to test my mig welds on 4130 other than the "bash" test (bash it with a sledge until it breaks)? In my reading the concerns with mig on 4130 are that the high localized heat can create "break points" just beyond the HAZ (heat affected zone) of the weld. If oxy/acetylene is much safer with 4130 - I could just start learning (I can get access to a torch). - but like I said I've done quite a bit with mig so my confidence/proficiency is much higher with mig. Thanks, Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426238#426238 ________________________________________________________________________________
Date: Jul 07, 2014
Andy, Perhaps one of the greatest things about building a Piet is that you will develop lots of new skills... So, consider that gas welding class, and give it a try. Gas welding is easy, and once you weld a few test pieces together, you'll ask yourself why you ever questioned trying it. Keep in mind aircraft welds are never ground down or smoothed, so the skill you develop will display your craft to all... Just my $0.02 -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426240#426240 ________________________________________________________________________________
Date: Jul 07, 2014
Andy, I'm no expert on welding, but I think there was a discussion of this in the archives (or maybe I read it somewhere else- Bingellis?), and the bottom line was you can MIG 4130 and then heat the entire area cherry red with a gas torch and allow it to air cool and your weld should be good to go. You should verify this, but that's what my middle-aged brain remembers. Kip Gardner On Jul 7, 2014, at 9:13 AM, AG wrote: > > Thanks for your thoughts - > > I would prefer to use to use 4130 - even if it is overkill - because safer is better - If I can mig 4130 safely that's the way I'll go. > I guess my only reservation is the ability to test my welds. > > Do you know of any way to test my mig welds on 4130 other than the "bash" test (bash it with a sledge until it breaks)? > > In my reading the concerns with mig on 4130 are that the high localized heat can create "break points" just beyond the HAZ (heat affected zone) of the weld. > > If oxy/acetylene is much safer with 4130 - I could just start learning (I can get access to a torch). - but like I said I've done quite a bit with mig so my confidence/proficiency is much higher with mig. > > Thanks, > > Andy > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426238#426238 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 07, 2014
Andy, http://www.weldingtipsandtricks.com has been an excellent resource for me... Sent from my iPad > On Jul 7, 2014, at 8:13 AM, "AG" wrote: > > > Thanks for your thoughts - > > I would prefer to use to use 4130 - even if it is overkill - because safer is better - If I can mig 4130 safely that's the way I'll go. > I guess my only reservation is the ability to test my welds. > > Do you know of any way to test my mig welds on 4130 other than the "bash" test (bash it with a sledge until it breaks)? > > In my reading the concerns with mig on 4130 are that the high localized heat can create "break points" just beyond the HAZ (heat affected zone) of the weld. > > If oxy/acetylene is much safer with 4130 - I could just start learning (I can get access to a torch). - but like I said I've done quite a bit with mig so my confidence/proficiency is much higher with mig. > > Thanks, > > Andy > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426238#426238 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 07, 2014
Subject: WW post on mags, carbs, and maintenance
Wow! I think this post is as enlightening on these subjects as anyone could post. All of the post is a great read. However if you want to put the thrust of the article in perspective, read this part first: (quote) "I am an Embry-Riddle trained A&P with 24 years of continuous work on light aircraft. I am qualified to work on virtualy any part in GA planes, but that doesn't mean I am reluctant to hire other mechanics with greater experience and better tooling. When the right mag had excessive drop on the C-85 in my wife's Taylorcraft, I could have replaced the cracked coil myself, but instead I took both mags to a repair station and waited while they were overhauled. In the last 10 years we have finished several homebuilts, and I could have overhauled each of the carbs myself, but I elected to send them all to a certified repair station. The difference between 'fixed' and 'Yellow tagged' is often hundreds of dollars. It sounds like a lot of money until you have lived through to plane crashes and attended a few funerals. 90% of the people reading this make more money than I do, and 95% have less experience with aircraft engines. If those people are trying to save money by fixing a mag or a carb themselves, when I would send the same part out, they should rethink that plan." (end quote) Thanks you, William Tim Subject: Pietenpol-List: A perspective on Carbs, Mags and Certified engines From: "William Wynne" <WilliamTCA(at)aol.com> ________________________________________________________________________________
Date: Jul 07, 2014
Subject: Engine Starts/Runs
-Yesterday, July 6th, marked the first start and run of my A-65.- We sp rayed some starting fluid into the heat box, (3 quick squirts) with the car b heat "on". It took about 8 pulls on the prop. there after, but it fired r ight off and ran really smooth. It was a-short run, about two minutes. An oil leak was noted and I shut down the engine with the mag switch. Turns o ut, one valve cover was leaking and an area around the tach. tube/boot/fitt ing.- This leak is between the black rubber boot and the brass nut it fit s into. (pic attached) Oil pressure came up to about 28 PSI, but I noted af ter shutdown that there were air bubbles in the clear tubing.- The oil te mp. needle never moved, lowest number being 120 F.- I was focusing on oil pressure, listening and watching for obvious signs of bad news, that I nev er looked at the tach. reading.- I also never moved the carb. heat to "of f".- No restart was attempted, so it will be interesting to see how it starts again cold.=0A=0AObviously I have a lot more work ahead, but it sur e is nice to finally get to hear it run.=0A=0AI plan to post a short You Tu be vid. if I can get the raw footage edited.- I'll be sure to have some l oud, obnoxious music playing the entire time...=0A=0AIf God is your co-pilo t, switch seats=0AMike Perez=0AKaretaker Aero=0AFirst engine start complete ! ________________________________________________________________________________
Subject: Re: Engine Starts/Runs
Date: Jul 07, 2014
Mike, that's a mighty nice sound when it finally lights off and runs. On yo ur oil temp, it usually takes some time before I get an indication and mine usually only indicates 140 to 150 during the summer. In the winter, it str uggles to get to 120. Matt Paxton -----Original Message----- From: Michael Perez <speedbrake(at)sbcglobal.net> Sent: Mon, Jul 7, 2014 1:41 pm Subject: Pietenpol-List: Engine Starts/Runs Yesterday, July 6th, marked the first start and run of my A-65. We spraye d some starting fluid into the heat box, (3 quick squirts) with the carb he at "on". It took about 8 pulls on the prop. there after, but it fired right off and ran really smooth. It was a short run, about two minutes. An oil l eak was noted and I shut down the engine with the mag switch. Turns out, on e valve cover was leaking and an area around the tach. tube/boot/fitting. This leak is between the black rubber boot and the brass nut it fits into. (pic attached) Oil pressure came up to about 28 PSI, but I noted after shut down that there were air bubbles in the clear tubing. The oil temp. needle never moved, lowest number being 120 F. I was focusing on oil pressure, l istening and watching for obvious signs of bad news, that I never looked at the tach. reading. I also never moved the carb. heat to "off". No restar t was attempted, so it will be interesting to see how it starts again cold. Obviously I have a lot more work ahead, but it sure is nice to finally get to hear it run. I plan to post a short You Tube vid. if I can get the raw footage edited. I'll be sure to have some loud, obnoxious music playing the entire time... If God is your co-pilot, switch seats Mike Perez Karetaker Aero First engine start complete! ________________________________________________________________________________
Date: Jul 07, 2014
Subject: Seatbelt eyebolts.
Pietenpolers, What is recommended for my lapbelt attachment bolts? I think a 1/4 eyebolt with big washers for both sides. Also a sacrificial piece of thin plywood on each side of the wood to take the compression. After looking at the aged and mismatched pile of seatbelts I have gathered over time. (Some came with the plane and some are good for a bonanza) I bought two sets from http://wescoperformance.stores.yahoo.net/ofsebe.html They were about $130 delivered. Look good and the price was right (Also US made) I bought red to match my interior. The set came with a huge 7/16 eyebolts, designed to go through 2 inch steel tubing. The original seatbelt hole in the diagonal wood frame piece plane is 1/4 inch. I obviously don't want to drill the hole any bigger. The weak spot in the whole system is the wood attachment. I may also run a strong wire/strap further back to another structural member. In a hard crash the wood is the weak point, in that event a loop of wire going further back and looped around a structural member will provide more stopping power. Unless I am overthinking it. Oscar, This passenger seatbelt has a snap end and will snap around the cross brace wires between the pilot and pax. is there a specific reason you made the wood discs you made or could I attach them directly to the wires? I can easily attach the rear shoulder straps to the old mount. Blue Skies, Steve "a big believer in shoulder belts" D. -- Blue Skies, Steve D ________________________________________________________________________________
Date: Jul 07, 2014
Subject: VW Radial
I wonder what HP at what RPM. https://www.youtube.com/watch?v=SyRJeZ6s8uM -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Re: VW Radial
Date: Jul 07, 2014
Low/high Gene On Jul 7, 2014, at 7:51 PM, Steven Dortch wrote: > I wonder what HP at what RPM. > > https://www.youtube.com/watch?v=SyRJeZ6s8uM > > > -- > Blue Skies, > Steve D > > > ________________________________________________________________________________
Date: Jul 07, 2014
Very nice....!!!! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426273#426273 ________________________________________________________________________________
Date: Jul 08, 2014
Thank you Matt. I expected the engine to light, sputter, die. Then a few pu lls later...more sputter, cough, die. Another few pulls...hack, cough, then finally run and settle into a nice idle.- I was happy to see/hear it lig ht and immediately settle to a nice smooth idle. =0A=0AI am moving on to at taching the wings so I can start fabricating cross cables, cabane diagonals , etc. I don't believe I can get the plane out of the garage with the wings on, so the next engine run will be after the wings come back off, (so I ca n move it back into the shop) and I get ready to store it for winter.=0A=0A Thank you all for the encouraging posts, emails and texts.=0A=0A=0A=0A- =0AIf God is your co-pilot, switch seats=0AMike Perez=0AKaretaker Aero=0AFi rst engine start complete! ________________________________________________________________________________
Date: Jul 08, 2014
I will continue to divide my time between flight training and building. However, the major building is really close to being complete. I have a few items left to fabricate and some other small items I plan to work on during the winter. Having soloed has really changed my motivation. At times, I was not looking forward to the drive out to the strip for more of the same work, just to make the drive home feeling like I accomplished nothing. Now, I am excited to fly alone and really work on my skills and procedures. Thank you all for the encouraging posts, emails and texts. If God is your co-pilot, switch seats Mike Perez Karetaker Aero First engine start complete! ________________________________________________________________________________
Date: Jul 08, 2014
No joy on the You Tube vid. as of yet, but here is a picture just after shu tdown.=0A=0A-=0AIf God is your co-pilot, switch seats=0AMike Perez=0AKare taker Aero=0AFirst engine start complete! ________________________________________________________________________________
Date: Jul 08, 2014
Great pic..... Mike! Congrats!! Brian SLC-UT From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Michael Perez Sent: Tuesday, July 08, 2014 7:34 AM Subject: Re: Pietenpol-List: Re: Engine Starts/Runs No joy on the You Tube vid. as of yet, but here is a picture just after shu tdown. If God is your co-pilot, switch seats Mike Perez Karetaker Aero First engine start complete! ________________________________________________________________________________
Date: Jul 08, 2014
Subject: Fuel Float...Doesn't
I bought two cork floats from ACS. I took one, coated it with either T-88 o r varnish, (Don't recall which...) and found out during the fuel flow tests , it sinks.- The "gauge" consists of the cork float and a thin wire passi ng through it.- I plan to test the other cork, as is, from ACS and hope i t floats. Any other suggestions?=0A=0A-=0AIf God is your co-pilot, switch seats=0AMike Perez=0AKaretakerAero=0AFirst engine start complete! ________________________________________________________________________________
Date: Jul 08, 2014
What is your wire made of? I found that a steel wire requires a vry large cork to support it. I made my wire out of aluminum, and just melted a ball on the end with my oxy-acetylene torch and painted it balze orange. I coated the cork and the paint on the ball with epoxy varnish. After 10 years it hasn't sunk yet. Here's a picture that shows my fuel gage as seen from the rear cockpit: Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Tuesday, July 08, 2014 9:54 AM Subject: Pietenpol-List: Fuel Float...Doesn't I bought two cork floats from ACS. I took one, coated it with either T-88 or varnish, (Don't recall which...) and found out during the fuel flow tests, it sinks. The "gauge" consists of the cork float and a thin wire passing through it. I plan to test the other cork, as is, from ACS and hope it floats. Any other suggestions? If God is your co-pilot, switch seats Mike Perez Karetaker Aero First engine start complete! ________________________________________________________________________________
Subject: Re: Fuel Float...Doesn't
Date: Jul 08, 2014
Cork is pretty rough and porous. Not sure coating it helps. It's nigh near inevitable that there's gaps in coverage UNLESS you really coat it thickly with epoxy, which'll make it a lot heavier and even less able to support weight. Is the cork you bought designed to hold an indicator UP out of the fuel (as in a nose tank), or hang DOWN (as into a transparent sump in a wing tank) into fuel? The latter can be smaller. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426292#426292 ________________________________________________________________________________
Date: Jul 08, 2014
Hi Jack. My float is in the tank, passing through the tank cap. (Nose mount ed tank.)- I thought that maybe the clearance between the wire on the cor k and the tube is slides in, through the cap, was too tight. So I held it i n hand and stuck it into a jug of 100LL and it sank!- I believe the wire is S.S. welding rod. I just measured a .062" dia. welding rod I have here n ow, I believe my float wire is thinner.=0A=0A-=0AIf God is your co-pilot, switch seats=0AMike Perez=0AKaretaker Aero=0AFirst engine start complete! ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: cork sealant that works
Date: Jul 08, 2014
Congratulations on your solo and engine run Mike P. If the cork is dipped in shellac, allowed to dry one day between coats, and given 2-3 coats it will be impervious to avgas for many years but will not be impervious for auto fuel that contains ethanol. Mike C. Ohio ________________________________________________________________________________
Date: Jul 08, 2014
Michael, Training in the Cessna 150 is good and cheap. I am a 150 fan. BUT please get a really good tailwheel endorsement before you play with your Piet. I had an old tyme instructor beat good landings into my head (Literally, he rolled up a sectional and hit me on the head while he screamed "Step on the ball, dammit!" ) The result was my landings in a J3 Cub on Saturday during my Biennial Flight Review were echelons better than the CFIs and that was after almost two years of not flying. I am very comfortable with my ability to fly the Piet, but even so I am going to beg some time with a couple of guys who own taildraggers just before I start flying it. Blue Skies, Steve D On Tue, Jul 8, 2014 at 8:30 AM, Michael Perez wrote: > I will continue to divide my time between flight training and building. > However, the major building is really close to being complete. I have a few > items left to fabricate and some other small items I plan to work on during > the winter. > > Having soloed has really changed my motivation. At times, I was not > looking forward to the drive out to the strip for more of the same work, > just to make the drive home feeling like I accomplished nothing. Now, I am > excited to fly alone and really work on my skills and procedures. > > Thank you all for the encouraging posts, emails and texts. > > If God is your co-pilot, switch seats > Mike Perez > Karetaker Aero > First engine start complete! > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Jul 08, 2014
The float is 1.5" long by 1.0" diameter. It came pre-coated/drilled, but it seemed to me that the coating was so thin and "broken" that it would not s eal.- (Did I test it prior to coating myself...ah, nope...doh!)=0A=0A- =0AIf God is your co-pilot, switch seats=0AMike Perez=0AKaretaker Aero=0AFi rst engine start complete! ________________________________________________________________________________
Date: Jul 08, 2014
Subject: Re: cork sealant that works
Thanks Mike!- I copied your fuel "gauge" almost exact...guess I missed so mething. From the pictures I have of yours, it appears you used only one co rk, correct?=0A=0A-=0AIf God is your co-pilot, switch seats=0AMike Perez =0AKaretaker Aero=0AFirst engine start complete! ________________________________________________________________________________
Date: Jul 08, 2014
I completely understand Steve. My first 15 or so hours of flight training w ere in a 120/140. I was taxing and doing takeoff/landings in it from day on e.- I had planned on going back to that for my T.W. endorsement, but anot her student locked the brakes after touchdown and rolled it over. I'll be n eeding another place/plane for the T.W. work.=0A=0A-=0AIf God is your co- pilot, switch seats=0AMike Perez=0AKaretaker Aero=0AFirst engine start comp lete! ________________________________________________________________________________
Subject: cork floats in nose fuel tanks
Date: Jul 08, 2014
I actually shaved/belt sanded two corks so that they would fit in the fuel filler neck and then epoxied them end to end, inserted the float wire and pulled the j- hook into the bottom and then started applying the shellac coats. Mike C. Ohio [cid:image001.jpg(at)01CF9AA1.7EF5BDC0] ________________________________________________________________________________
Date: Jul 08, 2014
Subject: Re: cork floats in nose fuel tanks
AH!- I only used a single.=0A=0A-=0AIf God is your co-pilot, switch sea ts=0AMike Perez=0AKaretaker Aero=0AFirst engine start complete! ________________________________________________________________________________
Date: Jul 08, 2014
I ran into the same problem at Poplar Grove with their 140 right before I started taking lessons, back in the day. :-P Congratulations on your achievement (both in the air and with your engine), keep up the good work, Ryan On Tue, Jul 8, 2014 at 10:00 AM, Michael Perez wrote: > I completely understand Steve. My first 15 or so hours of flight training > were in a 120/140. I was taxing and doing takeoff/landings in it from day > one. I had planned on going back to that for my T.W. endorsement, but > another student locked the brakes after touchdown and rolled it over. > I'll be needing another place/plane for the T.W. work. > > If God is your co-pilot, switch seats > Mike Perez > Karetaker Aero > First engine start complete! > ________________________________________________________________________________
Subject: corks
Date: Jul 08, 2014
[cid:image001.jpg(at)01CF9AA3.F43FEA90] ________________________________________________________________________________
Subject: completeness of plans
Date: Jul 08, 2014
I'd like to know if the plans are complete, without endless errors and omissions. If there are such problems, are they documented somewhere with solutions/corrections? I just quit my Hatz Classic project after two years, $8K and 400 hours as I want to build a plane; spending my time correcting plans is not what I want to do. I'm not a designer or engineer. I need solid, detailed, plans. Thank you. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426307#426307 ________________________________________________________________________________
Date: Jul 08, 2014
Thanks Ryan. It just figures...that 140 has been there for years and it was hardly ever used. I flew it for 15 or so hours, then others started to she dule it.- I don't know if the "student" was a green pilot or a seasoned v et getting a T.W. endorsement.- I hope to get all my training in before s omeone wrecks the plane I fly now.- (I'm doing my best to ensure it isn't me!)=0A=0A-=0AIf God is your co-pilot, switch seats=0AMike Perez=0AKaret aker Aero=0AFirst engine start complete! ________________________________________________________________________________
Subject: Re: completeness of plans
Date: Jul 08, 2014
John I respectfully suggest maybe plans built is not your best direction. All have changes and omissions. I believe the archives have an article detailing many of the changes. Good luck. Sent from my iPad Jack Textor > On Jul 8, 2014, at 11:31 AM, "Pocono John" wrote: > > > I'd like to know if the plans are complete, without endless errors and omissions. If there are such problems, are they documented somewhere with solutions/corrections? I just quit my Hatz Classic project after two years, $8K and 400 hours as I want to build a plane; spending my time correcting plans is not what I want to do. I'm not a designer or engineer. I need solid, detailed, plans. Thank you. > > -------- > John > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426307#426307 > > > > > > > > > > ________________________________________________________________________________
Subject: Glue
Date: Jul 08, 2014
I have just ordered my wing kit and am wondering if anyone has a strong reason use a specific glue like the West System epoxy or other glue. Robert Gow ________________________________________________________________________________
Subject: Re: Glue
Date: Jul 08, 2014
Hello Robert Here we go again. You might want to check the archives for many in depth di scussions of this topic. Obviously, an important component of your project, this is one area where you should follow the lead of previous successes. E njoy your build! Sent from my iPhone > On Jul 8, 2014, at 10:01 AM, Robert Gow wrote: > > I have just ordered my wing kit and am wondering if anyone has a strong r eason use a specific glue like the West System epoxy or other glue. > > Robert Gow > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Jul 08, 2014
John, in general the Pietenpol plans are pretty good. That is not to say that you won't have to spend considerable time studying them, because the dimension you need on sheet 4 might have been put on sheet 2 (the plans were drawn by a high school student). They apparently are good enough, because hundreds of planes have been built from them, most by builders who never built an airplane before. If you want to build a plane with excellent plans and drawings, I'd suggest contactong Vans Aircraft, and building one of their RV's. If you are willing to take the time to study and think over the plans, you'll find building a Pietenpol to be a rewarding experience. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Pocono John Sent: Tuesday, July 08, 2014 12:32 PM Subject: Pietenpol-List: completeness of plans I'd like to know if the plans are complete, without endless errors and omissions. If there are such problems, are they documented somewhere with solutions/corrections? I just quit my Hatz Classic project after two years, $8K and 400 hours as I want to build a plane; spending my time correcting plans is not what I want to do. I'm not a designer or engineer. I need solid, detailed, plans. Thank you. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426307#426307 ________________________________________________________________________________
Subject: Glue
Date: Jul 08, 2014
OK I will see what I can find From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of glenschweizer(at)yahoo.com Sent: July 8, 2014 1:24 PM Subject: Re: Pietenpol-List: Glue Hello Robert Here we go again. You might want to check the archives for many in depth discussions of this topic. Obviously, an important component of your project, this is one area where you should follow the lead of previous successes. Enjoy your build! Sent from my iPhone On Jul 8, 2014, at 10:01 AM, Robert Gow wrote: I have just ordered my wing kit and am wondering if anyone has a strong reason use a specific glue like the West System epoxy or other glue. Robert Gow claiming to be http://www.matronics.com/Navigator?Pietenpol-List claiming to be http://forums.matronics.com claiming to be http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Glue
Date: Jul 08, 2014
T-88 is fine, even the FAA will approve it on a 337 for STC aircraft on wood repair. Is easy to mix, 1:1, and have a good overall strength in a wide range of temperatures. Many, many home-builts flying using T-88 epoxy, that is real world proof enough. -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426315#426315 ________________________________________________________________________________
Subject: Re: Glue
Date: Jul 08, 2014
Yes and it is spec'ed by a number of homebuilt kit companies. So T-88 it is. Thanks -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of womenfly2 Sent: July 8, 2014 1:55 PM Subject: Pietenpol-List: Re: Glue --> T-88 is fine, even the FAA will approve it on a 337 for STC aircraft on wood repair. Is easy to mix, 1:1, and have a good overall strength in a wide range of temperatures. Many, many home-builts flying using T-88 epoxy, that is real world proof enough. -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426315#426315 ________________________________________________________________________________
Date: Jul 08, 2014
I assume because of how you asked, you're interested in a plans built plane. The Piet plans are complete without ENDLESS errors and omissions. It's the reason I decided to go this way, WHILE my dad was building a Hatz and kept getting frustrated with how vague the plans were. Like mentioned, they are not perfect. However, probably as much as ANY plans build design, there are countless examples, usually one pretty close to where ever you live, to go eyeball in person which makes a world of difference. About the best source of little detail specifics, would be your own camera at Brodhead. In the absence of that, westcoastpiet is an excellent picture resource. Asking here and of course contacting a piet owner/builder directly. The plans aren't good enough to build a kit full of parts, and then assemble them into a plane, so you'll have to study them and build as you go. They certainly are good enough to estimate accurately how much of whatever material you'll need it you want to buy all at once. Also, there's TONS of VERY usable "quick build kits" out there in the form of abandoned projects or unflyable ones that need restoring or used as a collection of parts. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426319#426319 ________________________________________________________________________________
Date: Jul 08, 2014
Subject: Re: July 5th...New Milestone
One popular setup for Early (1947 and earlier) Cessna 120/140s was an extender that put the wheels forward about 5 or 6 inches to reduce the chance for noseovers. It was a factory option. In late 1947 they moved the gear forward and did not need the extenders. Blue Skies, Steve D. On Tue, Jul 8, 2014 at 11:40 AM, Michael Perez wrote: > Thanks Ryan. It just figures...that 140 has been there for years and it > was hardly ever used. I flew it for 15 or so hours, then others started to > shedule it. I don't know if the "student" was a green pilot or a seasoned > vet getting a T.W. endorsement. I hope to get all my training in before > someone wrecks the plane I fly now. (I'm doing my best to ensure it isn't > me!) > > If God is your co-pilot, switch seats > Mike Perez > Karetaker Aero > First engine start complete! > > * > > > * > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Jul 08, 2014
Here is the You Tube link to the first engine run. It is heavily cut, so it is very short and not much for entertainment. I'll post the full version at a later time. https://www.youtube.com/watch?v=jBqgvB5OxVc If God is your co-pilot, switch seats Mike Perez Karetaker Aero First engine start complete! ________________________________________________________________________________
Date: Jul 08, 2014
Open these 2 attachments. We used #30 size corks. Barry NX973BP From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Tuesday, July 08, 2014 9:54 AM Subject: Pietenpol-List: Fuel Float...Doesn't I bought two cork floats from ACS. I took one, coated it with either T-88 or varnish, (Don't recall which...) and found out during the fuel flow tests, it sinks. The "gauge" consists of the cork float and a thin wire passing through it. I plan to test the other cork, as is, from ACS and hope it floats. Any other suggestions? If God is your co-pilot, switch seats Mike Perez Karetaker Aero First engine start complete! ________________________________________________________________________________
Date: Jul 08, 2014
From: "Charles N. Campbell" <charlescampbell1924(at)gmail.com>
John, I agree with Jack. The Pietenpol plans (more complete than most give them credit for) are still woefully incomplete. I would suggest a kit that the directions say, " connect parts A and B with five bolts and nuts as shown in illustration A14". I would suggest you go to the Zenith Aircraft web site and look at the sample directions. I think the directions are for constructing a 601 rudder. Chuck On Tue, Jul 8, 2014 at 12:57 PM, Jack wrote: > > John I respectfully suggest maybe plans built is not your best direction. > All have changes and omissions. I believe the archives have an article > detailing many of the changes. Good luck. > > Sent from my iPad > Jack Textor > > > On Jul 8, 2014, at 11:31 AM, "Pocono John" wrote: > > > > > > > > I'd like to know if the plans are complete, without endless errors and > omissions. If there are such problems, are they documented somewhere with > solutions/corrections? I just quit my Hatz Classic project after two years, > $8K and 400 hours as I want to build a plane; spending my time correcting > plans is not what I want to do. I'm not a designer or engineer. I need > solid, detailed, plans. Thank you. > > > > -------- > > John > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=426307#426307 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 08, 2014
I have a brass float that was for some year of mustang- have no idea what year now, but it has a rolled groove around it at one end and works fine though I have yet to make a bottom of the tank gage so it can hang down. it is for now through the cap and being a top of the wing center section tank fairly useless unless you are brave enough to loosen the seatbelts and raise up enough to view it. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426333#426333 ________________________________________________________________________________
Date: Jul 08, 2014
Mirror. :-) :-) Clif being a top of the wing center section tank fairly useless unless you are brave enough to loosen the seatbelts and raise up enough to view it. Raymond ________________________________________________________________________________
Date: Jul 08, 2014
In response to your question I should first explain my position. I am a first time builder in the relatively early stages of my build. Now to answer your questions I have already come across numerous "errors/omissions" with the plans. - a great source of frustration at times. One thing I've learned already is this - the "errors/omissions" usually crop up when you try to figure out the whole project at one - biting off too big a piece to chew on at once. It seems best to break the project down into little pieces and that makes it more manageable- then you can break apart that smaller step or assembly and figure out what you know and what you still need to find out to proceed. At this point I've found both this board, numerous print/web/human sources beneficial - and Andrew Pietenpol - the one who sells the plans is more than happy to answer many many questions by phone or email (ask me how I know...) Incidentally - as I progress I'm finding that many of those "omissions" in the plans don't actually exist - I just hadn't studied the plans enough or hadn't found that misplaced detail. part of this - I think - is this internet age we live in. So often the temptation is to give up and run to Google at the slightest problem -when most of the times spending even 5 more minutes studying the drawings would yield the info we're looking for. Perhaps the biggest source of frustration one might find with the Pietenpol is the many different ways people build them. Even the plans show 3 different fuselage options - 2 landing gear options - 2 wing options etc. Secondly - look at 10 Pietenpols and you'll find 10 different ways of building a Pietenpol. This can be more frustrating than a plan which is more "cookie-cutter" as you have to sort through the options and make decisions - but it all depends on how you look at it - the Piet really allows you to make it uniquely yours. Anyway - that's just my novice opinion (long-winded too) I understand your frustrations - but so far I believe they can be overcome - ... Hope that helps in some way. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426339#426339 ________________________________________________________________________________
Subject: Re: Seatbelt eyebolts.
Date: Jul 08, 2014
Steve; the wooden disc that I used to transfer the front cockpit shoulder belt loads to the cabane X-bracing is purely my own idea of how to transfer the load more elegantly. I thought about just clipping onto the crossing point of the 1/8" cables, but that particular metal-on-metal connection didn't appeal to me. Nothing wrong with it, though. As you know, the secondary purpose of the wooden disc is to provide a rear sight for my Browning .50 machine gun. There is a sighting notch in the top of that disc, if you'll recall. Several times I've made strafing runs on the train that runs to Hondo from Castroville out of San Antonio, with devastating results to the train. One time, I overtook the train from behind (took a while), strafing it from caboose to engine, then pulled up into a duster turn and used up the remainder of my ammo strafing the train back the other way from engine to caboose. Never knew what hit 'em. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426343#426343 ________________________________________________________________________________
Date: Jul 08, 2014
Mike; 41CC has two corks butted together, inline, on the end of a brass float rod. I'm guessing that the rod is 1/8" but I don't have it here in front of me. These corks are much smaller than #30 that the Big Piets use but I don't know what size these are. Corky sealed them with T88, I believe, and they have sat in 100LL for years and years with no sign of waterlogging (fuel logging?) They don't exactly bob happily on the surface of the fuel, but that adds a little bit of dampening. Normal engine vibration in flight keeps the rod free in the cap and keeps the float indicating the fuel level as closely as necessary for flight. In short, it is neither sluggish and heavy, nor light and bouncy in the fuel. Like Goldilocks in Baby Bear's bed, "it's just right". -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426344#426344 ________________________________________________________________________________
Date: Jul 09, 2014
O.K. I'll be adding some larger cork, (X2) and making sure to TEST IT prior to using in my fuel tank.=0A=0A-=0AIf God is your co-pilot, switch seats =0AMike Perez=0AKaretaker Aero=0AFirst engine start complete! ________________________________________________________________________________
Subject: a common place to undersell yourself---diagonal struts
Date: Jul 09, 2014
Over the years we've seen just about every size and type of forward diagona l struts used on Pietenpol center sections in lieu of the X-cable bracing that is shown on the plans to keep the four cabane (and thus wing) erect, upright, and to keep it from shifting forward in the event of a crash but what is somewhat distu rbing is seeing very small diameter tubing used here in such a critical area. If those diagonal struts are too small or not strong enough the wing will c ome forward in an accident involving a high rate of deceleration. Don't whimp out on what size tubing or strut material you're using up there----it could save your life or ruin your day and a passenger's day. Mike C. Ohio [cid:image001.jpg(at)01CF9B58.3CDD09E0] [cid:image002.jpg(at)01CF9B58.3CD D09E0] One I would not let someone I loved ride in. One I would gladly let someo ne I loved ride in. ________________________________________________________________________________
Date: Jul 09, 2014
I used three wine corks from our local vineyard, with 4 coats of old-fashi oned shellac. Has been working fine for 3 years, although I don't leave the cap with the float rod in the tank when it's parked or hangared. I don't w ant to give the gas the opportunity to dissolve the shellac through long-te rm dunking, and the solid cap I use when it's parked keeps water out. The r od is just steel welding rod threaded to take some simple nuts. A nut and w asher above the corks, then the corks on the rod, then a washer and two nut s, one as a jam nut on the bottom. Matt Paxton -----Original Message----- From: Michael Perez <speedbrake(at)sbcglobal.net> Sent: Wed, Jul 9, 2014 8:42 am Subject: Re: Pietenpol-List: Re: Fuel Float...Doesn't O.K. I'll be adding some larger cork, (X2) and making sure to TEST IT prior to using in my fuel tank. If God is your co-pilot, switch seats Mike Perez Karetaker Aero First engine start complete! ________________________________________________________________________________
Date: Jul 09, 2014
Subject: Re: a common place to undersell yourself---diagonal struts
If you see carefully the first photo, it have the X braced cables too. And the second one is strong enough as the bolt it have in the upper side, It look thin. Mario Giacummo 2014-07-09 10:29 GMT-03:00 Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC] : > Over the years we=99ve seen just about every size and type of forw ard > diagonal struts used on Pietenpol center sections > > in lieu of the X-cable bracing that is shown on the plans to keep the fou r > cabane (and thus wing) erect, upright, and to keep > > it from shifting forward in the event of a crash but what is somewhat > disturbing is seeing very small diameter tubing used here > > in such a critical area. > > > If those diagonal struts are too small or not strong enough the wing will > come forward in an accident involving a high rate of > > deceleration. Don=99t whimp out on what size tubing or strut mater ial > you=99re using up there----it could save your life or ruin your day > > and a passenger=99s day. > > > Mike C. > > Ohio > > > One I would not let someone I loved ride > in. One I would gladly > let someone I loved ride > in. > > ________________________________________________________________________________
Date: Jul 09, 2014
Mike, In the interest of improving the "crash-worthiness" of my Pietenpol, I've decided this winter to replace the cabane diagonals on mine, per William Wynne's suggestions after his experience. While my diagonal struts are plenty beefy, and the attach points to the front cabane struts are good and solid (see photos below), the weak point in the system is the turnbuckle fork that I used to allow for easy adjustment of the wing. In the event of a crash, any forward movement of the wing will likely buckle the turnbuckle fork shaft. I will remake the struts with the streamline tubing going all the way to the attach point, now that I have the wing where I want it. Wing movement in a crash is not much of a concern with a nose mounted tank (of course, having a tank full of fuel in your front passenger's lap might be something to worry about). But with a centersection tank like I have, it won't take much motion to rupture a fuel line and cause a fire. Another point to consider is that using streamline tubing produces much less drag than round tubing (there is almost no worse shape moving through the air than a round tube), but the round tube is much cheaper. Trying to reduce drag on a Pietenpol is pretty much a losing proposition. Anyway, this is a good discussion to have for those who are in the building process and making decisions on how to brace their wing structure. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC] Sent: Wednesday, July 09, 2014 9:29 AM Subject: Pietenpol-List: a common place to undersell yourself---diagonal struts Over the years we've seen just about every size and type of forward diagonal struts used on Pietenpol center sections in lieu of the X-cable bracing that is shown on the plans to keep the four cabane (and thus wing) erect, upright, and to keep it from shifting forward in the event of a crash but what is somewhat disturbing is seeing very small diameter tubing used here in such a critical area. If those diagonal struts are too small or not strong enough the wing will come forward in an accident involving a high rate of deceleration. Don't whimp out on what size tubing or strut material you're using up there----it could save your life or ruin your day and a passenger's day. Mike C. Ohio One I would not let someone I loved ride in. One I would gladly let someone I loved ride in. ________________________________________________________________________________
Date: Jul 09, 2014
Ever thought about using a classic car tank float=0A'65 mustang and other m akes are very similar=0A- =0A=0A=0AOn Wednesday, July 9, 2014 7:49 AM, Mi chael Perez wrote:=0A =0A=0A=0AO.K. I'll be add ing some larger cork, (X2) and making sure to TEST IT prior to using in my fuel tank.=0A=0A=0AIf God is your co-pilot, switch seats=0AMike Perez=0AKar ========= ________________________________________________________________________________
Date: Jul 09, 2014
Subject: fluid dynamics of drag
Check out youtube videos on "Fluid dynamics of drag." old videos done in 1940s or 50s. A blade is much better than a round object. Sure makes you consider adding some farings. or faring some wires and struts. -- Blue Skies, Steve D ________________________________________________________________________________
Date: Jul 09, 2014
I'm not sure that a streamlined tube on a 45 is any better than a round tube ....although I'm sure one of you engineers will prove me wrong... Gene On Jul 9, 2014, at 9:50 AM, "Jack Phillips" wrote : > Mike, > > In the interest of improving the =9Ccrash-worthiness=9D of my P ietenpol, I=99ve decided this winter to replace the cabane diagonals o n mine, per William Wynne=99s suggestions after his experience. While my diagonal struts are plenty beefy, and the attach points to the front cab ane struts are good and solid (see photos below), > > > > > > the weak point in the system is the turnbuckle fork that I used to allow f or easy adjustment of the wing. In the event of a crash, any forward moveme nt of the wing will likely buckle the turnbuckle fork shaft. I will remake t he struts with the streamline tubing going all the way to the attach point, n ow that I have the wing where I want it. > > > > Wing movement in a crash is not much of a concern with a nose mounted tank (of course, having a tank full of fuel in your front passenger=99s la p might be something to worry about). But with a centersection tank like I h ave, it won=99t take much motion to rupture a fuel line and cause a fi re. > > Another point to consider is that using streamline tubing produces much le ss drag than round tubing (there is almost no worse shape moving through the air than a round tube), but the round tube is much cheaper. Trying to redu ce drag on a Pietenpol is pretty much a losing proposition. > > Anyway, this is a good discussion to have for those who are in the buildin g process and making decisions on how to brace their wing structure. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-LME0)[Vantage Par tners, LLC] > Sent: Wednesday, July 09, 2014 9:29 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: a common place to undersell yourself---diagonal s truts > > Over the years we=99ve seen just about every size and type of forwar d diagonal struts used on Pietenpol center sections > in lieu of the X-cable bracing that is shown on the plans to keep the four cabane (and thus wing) erect, upright, and to keep > it from shifting forward in the event of a crash but what is somewhat dist urbing is seeing very small diameter tubing used here > in such a critical area. > > If those diagonal struts are too small or not strong enough the wing will c ome forward in an accident involving a high rate of > deceleration. Don=99t whimp out on what size tubing or strut materi al you=99re using up there----it could save your life or ruin your day > and a passenger=99s day. > > Mike C. > Ohio > > > > One I would not let someone I loved ride in. One I would gladly let someo ne I loved ride in. ________________________________________________________________________________
Subject: Re: fluid dynamics of drag
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Jul 09, 2014
Found in my Websters dictionary just a few minutes ago. DRAG: A force acting against thrust. ie; see Pietenpol or Men dressing as women. I don't worry about drag on my plane. If you need or want efficiency then build a different airplane. Just having fun guys, Don't shoot me out of the air on this one. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426377#426377 ________________________________________________________________________________
Subject: Length of wire length for Horizontal / Vertical stab stays
Date: Jul 09, 2014
I'm on a business trip without Piet plans, and I have the opportunity to pick up some rolled stainless steel flying wires to attach to the horizontal, vertical stabilizers and the bottom of the fuse. Can anyone tell me the approximate length of the stays? Any help will be appreciated. Thanks! -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426385#426385 ________________________________________________________________________________
stays
Date: Jul 09, 2014
We ordered 48 of them for the Big Piets with rolled threads. As I remember each airplane has 8 and there are 2 each of different Lengths. If you are having rolled threads, it would be safer to order these when all the tail is assembled to get the correct length for each wire. The stainless hard wire does look great. Just my $ .02 Barry NX973BP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tkreiner Sent: Wednesday, July 09, 2014 2:39 PM Subject: Pietenpol-List: Length of wire length for Horizontal / Vertical stab stays I'm on a business trip without Piet plans, and I have the opportunity to pick up some rolled stainless steel flying wires to attach to the horizontal, vertical stabilizers and the bottom of the fuse. Can anyone tell me the approximate length of the stays? Any help will be appreciated. Thanks! -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426385#426385 ________________________________________________________________________________
From: "=?utf-8?B?c3RldmVuLmQuZG9ydGNoQGdtYWlsLmNvbQ==?=" <steven.d.dortch(at)gmail.com>
Subject: =?utf-8?B?UmU6IFBpZXRlbnBvbC1MaXN0OiBhIGNvbW1vbiBwbGFjZSB0byB1bmRlcnNlbGwg?=
=?utf-8?B?eW91cnNlbGYtLS1kaWFnb25hbCBzdHJ1dHM=?
Date: Jul 09, 2014
RmVkRVgKCkZyb20gbXkgSFRDIFNlbnNhdGlvbiA0RyBvbiBULU1vYmlsZS4gVGhlIGZpcnN0IG5h dGlvbndpZGUgNEcgbmV0d29yawoKLS0tLS0gUmVwbHkgbWVzc2FnZSAtLS0tLQpGcm9tOiAiSmFj ayBQaGlsbGlwcyIgPGphY2tAYmVkZm9yZGxhbmRpbmdzLmNvbT4KVG86IDxwaWV0ZW5wb2wtbGlz dEBtYXRyb25pY3MuY29tPgpTdWJqZWN0OiBQaWV0ZW5wb2wtTGlzdDogYSBjb21tb24gcGxhY2Ug dG8gdW5kZXJzZWxsIHlvdXJzZWxmLS0tZGlhZ29uYWwgc3RydXRzCkRhdGU6IFdlZCwgSnVsIDks IDIwMTQgODo1MCBhbQoKCk1pa2UsCgogCgpJbiB0aGUgaW50ZXJlc3Qgb2YgaW1wcm92aW5nIHRo ZSAiY3Jhc2gtd29ydGhpbmVzcyIgb2YgbXkgUGlldGVucG9sLCBJJ3ZlCmRlY2lkZWQgdGhpcyB3 aW50ZXIgdG8gcmVwbGFjZSB0aGUgY2FiYW5lIGRpYWdvbmFscyBvbiBtaW5lLCBwZXIgV2lsbGlh bQpXeW5uZSdzIHN1Z2dlc3Rpb25zIGFmdGVyIGhpcyBleHBlcmllbmNlLiAgV2hpbGUgbXkgZGlh Z29uYWwgc3RydXRzIGFyZQpwbGVudHkgYmVlZnksIGFuZCB0aGUgYXR0YWNoIHBvaW50cyB0byB0 aGUgZnJvbnQgY2FiYW5lIHN0cnV0cyBhcmUgZ29vZCBhbmQKc29saWQgKHNlZSBwaG90b3MgYmVs b3cpLAoKIAoKCgogCgoKCiAKCnRoZSB3ZWFrIHBvaW50IGluIHRoZSBzeXN0ZW0gaXMgdGhlIHR1 cm5idWNrbGUgZm9yayB0aGF0IEkgdXNlZCB0byBhbGxvdyBmb3IKZWFzeSBhZGp1c3RtZW50IG9m IHRoZSB3aW5nLiAgSW4gdGhlIGV2ZW50IG9mIGEgY3Jhc2gsIGFueSBmb3J3YXJkIG1vdmVtZW50 Cm9mIHRoZSB3aW5nIHdpbGwgbGlrZWx5IGJ1Y2tsZSB0aGUgdHVybmJ1Y2tsZSBmb3JrIHNoYWZ0 LiAgSSB3aWxsIHJlbWFrZSB0aGUKc3RydXRzIHdpdGggdGhlIHN0cmVhbWxpbmUgdHViaW5nIGdv aW5nIGFsbCB0aGUgd2F5IHRvIHRoZSBhdHRhY2ggcG9pbnQsIG5vdwp0aGF0IEkgaGF2ZSB0aGUg d2luZyB3aGVyZSBJIHdhbnQgaXQuCgogCgoKCiAKCldpbmcgbW92ZW1lbnQgaW4gYSBjcmFzaCBp cyBub3QgbXVjaCBvZiBhIGNvbmNlcm4gd2l0aCBhIG5vc2UgbW91bnRlZCB0YW5rCihvZiBjb3Vy c2UsIGhhdmluZyBhIHRhbmsgZnVsbCBvZiBmdWVsIGluIHlvdXIgZnJvbnQgcGFzc2VuZ2VyJ3Mg bGFwIG1pZ2h0CmJlIHNvbWV0aGluZyB0byB3b3JyeSBhYm91dCkuICBCdXQgd2l0aCBhIGNlbnRl cnNlY3Rpb24gdGFuayBsaWtlIEkgaGF2ZSwgaXQKd29uJ3QgdGFrZSBtdWNoIG1vdGlvbiB0byBy dXB0dXJlIGEgZnVlbCBsaW5lIGFuZCBjYXVzZSBhIGZpcmUuCgogCgpBbm90aGVyIHBvaW50IHRv IGNvbnNpZGVyIGlzIHRoYXQgdXNpbmcgc3RyZWFtbGluZSB0dWJpbmcgcHJvZHVjZXMgbXVjaCBs ZXNzCmRyYWcgdGhhbiByb3VuZCB0dWJpbmcgKHRoZXJlIGlzIGFsbW9zdCBubyB3b3JzZSBzaGFw ZSBtb3ZpbmcgdGhyb3VnaCB0aGUKYWlyIHRoYW4gYSByb3VuZCB0dWJlKSwgYnV0IHRoZSByb3Vu ZCB0dWJlIGlzIG11Y2ggY2hlYXBlci4gIFRyeWluZyB0bwpyZWR1Y2UgZHJhZyBvbiBhIFBpZXRl bnBvbCBpcyBwcmV0dHkgbXVjaCBhIGxvc2luZyBwcm9wb3NpdGlvbi4KCiAKCkFueXdheSwgdGhp cyBpcyBhIGdvb2QgZGlzY3Vzc2lvbiB0byBoYXZlIGZvciB0aG9zZSB3aG8gYXJlIGluIHRoZSBi dWlsZGluZwpwcm9jZXNzIGFuZCBtYWtpbmcgZGVjaXNpb25zIG9uIGhvdyB0byBicmFjZSB0aGVp ciB3aW5nIHN0cnVjdHVyZS4KCiAKCkphY2sgUGhpbGxpcHMKCk5YODk5SlAKClNtaXRoIE1vdW50 YWluIExha2UsIFZpcmdpbmlhCgogCgogIF9fX19fICAKCkZyb206IG93bmVyLXBpZXRlbnBvbC1s aXN0LXNlcnZlckBtYXRyb25pY3MuY29tClttYWlsdG86b3duZXItcGlldGVucG9sLWxpc3Qtc2Vy dmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBDdXksIE1pY2hhZWwKRC4gKEdSQy1MTUUw KVtWYW50YWdlIFBhcnRuZXJzLCBMTENdClNlbnQ6IFdlZG5lc2RheSwgSnVseSAwOSwgMjAxNCA5 OjI5IEFNClRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tClN1YmplY3Q6IFBpZXRlbnBv bC1MaXN0OiBhIGNvbW1vbiBwbGFjZSB0byB1bmRlcnNlbGwgeW91cnNlbGYtLS1kaWFnb25hbApz dHJ1dHMKCiAKCk92ZXIgdGhlIHllYXJzIHdlJ3ZlIHNlZW4ganVzdCBhYm91dCBldmVyeSBzaXpl IGFuZCB0eXBlIG9mIGZvcndhcmQgZGlhZ29uYWwKc3RydXRzIHVzZWQgb24gUGlldGVucG9sIGNl bnRlciBzZWN0aW9ucwoKaW4gbGlldSBvZiB0aGUgWC1jYWJsZSBicmFjaW5nIHRoYXQgaXMgc2hv d24gb24gdGhlIHBsYW5zIHRvIGtlZXAgdGhlIGZvdXIKY2FiYW5lIChhbmQgdGh1cyB3aW5nKSBl cmVjdCwgdXByaWdodCwgYW5kIHRvIGtlZXAKCml0IGZyb20gc2hpZnRpbmcgZm9yd2FyZCBpbiB0 aGUgZXZlbnQgb2YgYSBjcmFzaCBidXQgd2hhdCBpcyBzb21ld2hhdApkaXN0dXJiaW5nIGlzIHNl ZWluZyB2ZXJ5IHNtYWxsIGRpYW1ldGVyIHR1YmluZyB1c2VkIGhlcmUKCmluIHN1Y2ggYSBjcml0 aWNhbCBhcmVhLiAKCiAKCklmIHRob3NlIGRpYWdvbmFsIHN0cnV0cyBhcmUgdG9vIHNtYWxsIG9y IG5vdCBzdHJvbmcgZW5vdWdoIHRoZSB3aW5nIHdpbGwKY29tZSBmb3J3YXJkIGluIGFuIGFjY2lk ZW50IGludm9sdmluZyBhIGhpZ2ggcmF0ZSBvZgoKZGVjZWxlcmF0aW9uLiAgRG9uJ3Qgd2hpbXAg b3V0IG9uIHdoYXQgc2l6ZSB0dWJpbmcgb3Igc3RydXQgbWF0ZXJpYWwgeW91J3JlCnVzaW5nIHVw IHRoZXJlLS0tLWl0IGNvdWxkIHNhdmUgeW91ciBsaWZlIG9yIHJ1aW4geW91ciBkYXkKCmFuZCBh IHBhc3NlbmdlcidzIGRheS4gICAgIAoKIAoKTWlrZSBDLgoKT2hpbwoKIAoKIAoKICAgICAgICAg CgogICAgICAgICAgICAgICAgICAgICAgICAgICBPbmUgSSB3b3VsZCBub3QgbGV0IHNvbWVvbmUg SSBsb3ZlZCByaWRlIGluLgpPbmUgSSB3b3VsZCBnbGFkbHkgbGV0IHNvbWVvbmUgSSBsb3ZlZCBy aWRlIGluLgoKCg= ________________________________________________________________________________
Date: Jul 09, 2014
Jack, I am thinking about re-doing mine also. I am inviting all comments/criticis ms on my design, in order that I might make some improvements. Please feel free to comment as you wish,.... but.... please ....if people could possibl y refrain from using the words "1960's swing-set technology".........don't think I can withstand the rejection again..... Dan Helsper Puryear, TN -----Original Message----- From: Jack Phillips <jack(at)bedfordlandings.com> Sent: Wed, Jul 9, 2014 8:52 am Subject: RE: Pietenpol-List: a common place to undersell yourself---diagona l struts Mike, In the interest of improving the =9Ccrash-worthiness=9Dof my Pi etenpol, I=99ve decided this winter to replace the cabane diagonalson mine, per William Wynne=99s suggestions after his experience. While my diagonal struts are plenty beefy, and the attach points to the frontcaba ne struts are good and solid (see photos below), the weak point in the system is theturnbuckle fork that I used to allow for easy adjustment of the wing. Inthe event of a crash, any forward movement of the wing will likely buckle theturnbuckle fork shaft. I will remake th e struts with the streamlinetubing going all the way to the attach point, n ow that I have the wing where Iwant it. Wing movement in a crash is not much of aconcern with a nose mounted tank ( of course, having a tank full of fuel in yourfront passenger=99s lap might be something to worry about). But witha centersection tank like I ha ve, it won=99t take much motion to rupture afuel line and cause a fir e. Another point to consider is that usingstreamline tubing produces much less drag than round tubing (there is almost noworse shape moving through the a ir than a round tube), but the round tube ismuch cheaper. Trying to reduce drag on a Pietenpol is pretty much alosing proposition. Anyway, this is a good discussion to havefor those who are in the building process and making decisions on how to bracetheir wing structure. Jack Phillips NX899JP Smith Mountain Lake, Virginia From:owner-pietenpol-list-server(at)matronics.com[mailto:owner-pietenpol-list- server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-LME0)[Vantage Partn ers, LLC] Sent: Wednesday, July 09, 20149:29 AM Subject: Pietenpol-List: a commonplace to undersell yourself---diagonal str uts Overthe years we=99ve seen just about every size and type of forward diagonalstruts used on Pietenpol center sections inlieu of the X-cable bracing that is shown on the plans to keep the four c abane(and thus wing) erect, upright, and to keep itfrom shifting forward in the event of a crash but what is somewhat distur bingis seeing very small diameter tubing used here insuch a critical area. Ifthose diagonal struts are too small or not strong enough the wing will co meforward in an accident involving a high rate of deceleration. Don=99t whimp out on what size tubing or strut material you=99re usingup there----it could save your life or ruin your day anda passenger=99s day. MikeC. Ohio OneI would not let someone I loved ridein. One I would gladly let someone I lovedridein. ________________________________________________________________________________
Subject: Landing gear about finished
Date: Jul 09, 2014
I finished my landing gear last night ... I built the die spring type gear that BH used on the last original. It has been quite a task to complete, but I am pleased with how it looks.. I hope it performs ok. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426407#426407 Attachments: http://forums.matronics.com//files/landing_gear_finished_1_276.jpg ________________________________________________________________________________
Subject: Re: Landing gear about finished
Date: Jul 09, 2014
Kenny; Wow! Nice job on the gear. Just wondering (it's not obvious from the photo), did you crank in a little bit of angle on the axles so when the completed airplane sits on the gear and the springs compress under the weight, you'll still have a little positive camber (top of the tire pointing out, not in)? I am presently having to add some tapered axle shims to restore the positive camber to my gear, since the tires have been wearing a bit unevenly. I don't know if the springs on my gear legs have weakened and compressed a bit or what. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426409#426409 ________________________________________________________________________________
Date: Jul 09, 2014
I'm about to the point of having mine solidly welded with some streamline tubing too. I think this winter I'll get my welding artist Jeff Sterling to do the honors and eliminate the Aurora ball-end fittings from the connection between my diagonals and verticals and be done with it. I will not need to ever adjust the sweep-back angle of the cabanes. Unless, of course, I ever re-engine Scout with something heavier or lighter than a Continental. Hmmm... shall I go for a Warner Scarab (125 HP, 285 lbs.) or a Rotax 582 (65 HP, 100 lbs)-? -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426410#426410 ________________________________________________________________________________
Date: Jul 10, 2014
This is all well and good, but the weak link is the motor bracket attachment to the top wood longeron. That will fail first as the load on the bolts will split the wood. -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426418#426418 ________________________________________________________________________________
Subject: Dan Helsper makes cover of CONTACT! magazine
Date: Jul 10, 2014
https://www.facebook.com/www.CONTACTMagazine Builder/ pilot, owner-operator of NX929DH, Captain Dan Helsper of Loenslo e Air Service has made the cover of CONTACT! Magazine with his beautiful Model A Ford powered Pietenpol Aircamper. Way to go Dan! [cid:image001.png(at)01CF9C18.7BB26230] ________________________________________________________________________________
Date: Jul 10, 2014
struts
If you put the Rotax on you will have to extend the nose so far it will look like a turbine! Blue Skies, Steve D ________________________________________________________________________________
Subject: Re: Dan Helsper makes cover of CONTACT! magazine
Date: Jul 10, 2014
Yes, that's right. However, the photo on the Facebook page is not what the cover actually looks like. Pat has added a commemorative medallion for the 85th anniversary. Be at Brodhead or Oshkosh and get your copy of the magazine... -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426433#426433 ________________________________________________________________________________
Date: Jul 10, 2014
WF2; At first glance, I would guess that the "bolts are stronger than wood" makes sense, but eyeballing it, even with an educated eye, does not prove correct here. I have photos of a number of Crashed Piets, going back to one a Brodhead in 1990, where all the planes had sevearly compromised diagonal cabanes, but none of them had ripped the bracket off the top longeron. This includes my own plane, which burn to a cinder following the crash which folded the diagonal cabanes right in the middle, but I still have the top longeron brackets and the wood left between them is charred, but intact. I also have photos that a bystander took while the plane was 1/2 burnt that show the top longeron is still intact after the impact. I have read almost all of the comments you have made here. and they are well thought out, but on this issue, I would like to politely point out that your perspective is not correct in light of physical evidence, and I would not want anyone considering improving their diagonal cabanes not to do so because they read you comment. Most things people have a different opionon on in piet construction are really expressions of preference, but my 3 points, Diagonal cabanes, fuel lines and CG are important enough that I will explain them at length. The two stories are here: http://flycorvair.net/2013/12/19/pietenpol-fuel-lines-and-cabanes/ and: http://flycorvair.net/2013/12/20/fuel-lines-and-cabanes-part-2/ Please look at the photos, and consider copying the red strut attachment style. It is on Dave Mensik's Piet, and it eliminates the weal point ay the ends of the struts. Any system that ends with a fork, plate or a flattened tube can be strengthened by having the tube stay full cross section like on Dave's. If someone is understood to be a fool, and they tell people that my 3 points don't matter, I don't care, as few people will follow them, and in some ways it illustrates the issue better. Conversely, when people who are well thought of, trend setters, educated or experienced builders say things that conflict with the risk management message I want to share, I am compelled to respond because I don't want the practical issue lost in theoretical debate. At first glance, this gives the illusion that I am arguing with some of the most respected people, when I am not, and hopefully the people I respond to will understand that it is validation that their perspectives are well read and usually correct. ------------------------------------------------------- In 4 days, I will be at the 13th anniversary of my accident. The time allows a better understanding of the actual cost; the plane and burns don't add up to a meaningful loss when considered against 1) My wife, who has always been a better pilot than I, lost much of her pure joy for planes while sitting in the ICU with me for a month when I looked like a burger left on the grill, 2) The event made my parents age, their support over a long year stole some of their remaining optimism. 3) the PIC who was lightly injured, who I went back to extract from the wreckage, has terrible ptsd over what it cost me to save him. You can build a new plane, you can forget the physical pain, these just take time, but I have found , no matter how hard I have tried,I am completely powerless to fix 1-2- and 3. Think that over. The sole good thing that came about was that my father, who's office was on the 89th floor of the World Trade Center #2, took the day off on 9/11 to be with me in the hospital. In 24 years there he had missed very few days in the building. I wrote some notes about it with a photo, they are at the bottom of this link: http://www.flycorvair.com/hangar0911.html -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426438#426438 ________________________________________________________________________________
struts
Date: Jul 10, 2014
I would like to hear the engineers chime-in on this. Maybe my swing-set tec hnology will work after all. Dan Helsper Puryear, TN -----Original Message----- From: womenfly2 <Love2Fly.KAP(at)gmail.com> Sent: Thu, Jul 10, 2014 8:54 am Subject: Pietenpol-List: Re: a common place to undersell yourself---diagona l struts This is all well and good, but the weak link is the motor bracket attachmen t to the top wood longeron. That will fail first as the load on the bolts will s plit the wood. -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426418#426418 ________________________________________________________________________________
Date: Jul 10, 2014
struts But will climb like a homesick angel if the one we have here in the UK is anything to go by! Keith Hodge On 10/07/2014 14:54, Steven Dortch wrote: > If you put the Rotax on you will have to extend the nose so far it > will look like a turbine! > Blue Skies, > Steve D > * > > > * ________________________________________________________________________________
Date: Jul 10, 2014
Very nice work. I built mine with open springs via the Cub/GN-1 plans (but I think the Pietenpol design you used is better). Like a moron I paid no attention to those that said that the springs should be pre-compressed. So now in order for my axles to be horizontal at gross weight I will need to shorten each spring-strut by around an inch and a half. Gear works fine though, am thinking about replacing mine someday with the Pietenpol design using the same springs and an inch and a half shorter. rh -------- Rick Holland NX6819Z Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426447#426447 Attachments: http://forums.matronics.com//files/gear1_173.jpg ________________________________________________________________________________
Date: Jul 10, 2014
I'm with WW on this one. If you take a good look at how the Cont and Corvair engine mounts are constructed and the fact that they bolt directly to the diagonal cabane strut mounts, it ties everything together with a lot of triangular structures. I don't think the upper longerons are carrying the loads you think they are. The firewall is providing a large gusset, this will help prevent diamonding the structure too. There are a lot of triangular structures involved there if you step back and look at it. Triangles are very strong. I don't have any degrees in engineering, but I do design engineering at work on a daily basis. My 3 cents, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426448#426448 ________________________________________________________________________________
Date: Jul 10, 2014
Mounted my lap belts as you described through wood with extra 1/8" ply on each side. My shoulder belts attach all the way back to my AN6 tailwheel attach bolt with a 1/8" cable in between. -------- Rick Holland NX6819Z Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426449#426449 Attachments: http://forums.matronics.com//files/img_3641_115.jpg http://forums.matronics.com//files/img_3639_626.jpg ________________________________________________________________________________
Date: Jul 10, 2014
Give the shutterbug some credit ;) - Jonathan Apfelbaum -----Original Message----- From: Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC] (GRC-LME0)[Vantage Partners, LLC] Sent: Thu, Jul 10, 2014 7:54 am Subject: Pietenpol-List: Dan Helsper makes cover of CONTACT! magazine https://www.facebook.com/www.CONTACTMagazine Builder/ pilot, owner-operator of NX929DH, Captain Dan Helsper of Loenslo e Air Service has made the cover of CONTACT! Magazine with his beautiful Model A Ford powered Pietenpol Aircamper. Way to go Dan! ________________________________________________________________________________
struts
Date: Jul 10, 2014
In response to your comment about the firewall being so structurally importa nt: my firewall is 1/4" plywood with a stainless steel face plate. I now hav e it bolted to the two upright members that join the top longerons vertical ly. I use four AN-3 bolts through the firewall and the front vertical member s, threading into a plate nut. Would this be adequate for strength, or shoul d the firewall be glued to the vertical members? Which is best, adequate, or just OK? By the way, I am not too worried about weight because this is a SkyScout, si ngle place with an A-65; therefore the 1/4" firewall. Jim Boyer and his friend Jim were just here for a great lunch, visit and vie wing of my build progress. All visitors are welcome. Plane to start covering this fall. Thanks, Ray Krause Sent from my iPad > On Jul 10, 2014, at 11:43 AM, "AircamperN11MS" w rote: > ty.org> > > I'm with WW on this one. If you take a good look at how the Cont and Corva ir engine mounts are constructed and the fact that they bolt directly to the diagonal cabane strut mounts, it ties everything together with a lot of tri angular structures. I don't think the upper longerons are carrying the load s you think they are. The firewall is providing a large gusset, this will h elp prevent diamonding the structure too. There are a lot of triangular stru ctures involved there if you step back and look at it. Triangles are very st rong. > > I don't have any degrees in engineering, but I do design engineering at wo rk on a daily basis. > > My 3 cents, > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426448#426448 > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > >
struts
Date: Jul 10, 2014
Ray, My galvanized firewall started out not being anchored to anything...then the process of adding engine support stuff started! Eventually, I added pan head screws around the perimeter since that's where the cowling is anchored to the firewall. I think you're OK... Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause Sent: Thursday, July 10, 2014 4:12 PM Subject: Re: Pietenpol-List: Re: a common place to undersell yourself---diagonal struts In response to your comment about the firewall being so structurally important: my firewall is 1/4" plywood with a stainless steel face plate. I now have it bolted to the two upright members that join the top longerons vertically. I use four AN-3 bolts through the firewall and the front vertical members, threading into a plate nut. Would this be adequate for strength, or should the firewall be glued to the vertical members? Which is best, adequate, or just OK? By the way, I am not too worried about weight because this is a SkyScout, single place with an A-65; therefore the 1/4" firewall. Jim Boyer and his friend Jim were just here for a great lunch, visit and viewing of my build progress. All visitors are welcome. Plane to start covering this fall. Thanks, Ray Krause ________________________________________________________________________________
Date: Jul 10, 2014
struts
While on the subject of firewalls, one thing I am very glad I added to mine was a small opening large enough to get an arm through with a stainless cover held on with short wood screws. Very handy when you need to attach/detach a fuel line or cable/spring to the front rudder pedals, etc. rh On Thu, Jul 10, 2014 at 5:32 PM, Gary Boothe wrote: > > Ray, > > My galvanized firewall started out not being anchored to anything...then > the > process of adding engine support stuff started! Eventually, I added pan > head > screws around the perimeter since that's where the cowling is anchored to > the firewall. I think you're OK... > > Gary Boothe > NX308MB > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause > Sent: Thursday, July 10, 2014 4:12 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: a common place to undersell > yourself---diagonal struts > > In response to your comment about the firewall being so structurally > important: my firewall is 1/4" plywood with a stainless steel face plate. I > now have it bolted to the two upright members that join the top longerons > vertically. I use four AN-3 bolts through the firewall and the front > vertical members, threading into a plate nut. Would this be adequate for > strength, or should the firewall be glued to the vertical members? Which is > best, adequate, or just OK? > > By the way, I am not too worried about weight because this is a SkyScout, > single place with an A-65; therefore the 1/4" firewall. > > Jim Boyer and his friend Jim were just here for a great lunch, visit and > viewing of my build progress. All visitors are welcome. Plane to start > covering this fall. > > Thanks, > > Ray Krause > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
struts
Date: Jul 10, 2014
Don=99t I wish I had that two weeks ago, making some changes to the forward rudder pedals!!! Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Thursday, July 10, 2014 5:02 PM Subject: Re: Pietenpol-List: Re: a common place to undersell yourself---diagonal struts While on the subject of firewalls, one thing I am very glad I added to mine was a small opening large enough to get an arm through with a stainless cover held on with short wood screws. Very handy when you need to attach/detach a fuel line or cable/spring to the front rudder pedals, etc. rh On Thu, Jul 10, 2014 at 5:32 PM, Gary Boothe wrote: Ray, My galvanized firewall started out not being anchored to anything...then the process of adding engine support stuff started! Eventually, I added pan head screws around the perimeter since that's where the cowling is anchored to the firewall. I think you're OK... Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause Sent: Thursday, July 10, 2014 4:12 PM Subject: Re: Pietenpol-List: Re: a common place to undersell yourself---diagonal struts In response to your comment about the firewall being so structurally important: my firewall is 1/4" plywood with a stainless steel face plate. I now have it bolted to the two upright members that join the top longerons vertically. I use four AN-3 bolts through the firewall and the front vertical members, threading into a plate nut. Would this be adequate for strength, or should the firewall be glued to the vertical members? Which is best, adequate, or just OK? By the way, I am not too worried about weight because this is a SkyScout, single place with an A-65; therefore the 1/4" firewall. Jim Boyer and his friend Jim were just here for a great lunch, visit and viewing of my build progress. All visitors are welcome. Plane to start covering this fall. Thanks, Ray Krause ============== br> -List" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List MS - k">http://forums.matronics.com e - -Matt Dralle, List Admin. t="_blank">http://www.matronics.com/contribution -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Date: Jul 10, 2014
I did add in the 2 degrees of camber like the plans call for... I don't know if that will be enough, time will tell.. I think I will wait to finish weld the struts until after I mount the engine. I have a lot of room to extend or shorten them where they enter the 1 inch tube that comes out of the spring housing. I also considered building the center a frame like the cub gear so the offset of the struts wouldn't be necessary, but decided against it. I wound up with a pretty good offset at the wheel end of the struts but I think it will be Ok... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426466#426466 Attachments: http://forums.matronics.com//files/landing_gear_finished_3_236.jpg ________________________________________________________________________________
Date: Jul 11, 2014
Subject: Airventure Latex Paint Forums
Hello Piet friends, If you are attending Airventure 2014 in Oshkosh, stop in for one of the Latex Paint for Aircraft forums. I have some updates to last years forum and the webinar, and it should be fun and informative. My Piet is still not done so I will be flying the Tripacer out to Brodhead and Oshkosh with a friend this year . Hope to see you there! - Monday, July 28, 11:30-12:45 in the Forum 1 building - Wednesday, July 30, 10:00-11:15 in the Forum 6 building Malcolm Morrison http://wienerdogaero.com ________________________________________________________________________________
Subject: Re: FYI Aluminum Strut Sizes
Date: Jul 10, 2014
Looks like there are three sizes, small, large and heavy duty. Is the small sufficiently strong enough to use for lift struts? Also on the topic of lift struts, why are steel airfoil ones from ACS so expensive compared to these? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426470#426470 ________________________________________________________________________________
Subject: Re: Brodhead 2014
Date: Jul 10, 2014
My son and I are planning on flying our Sonex from Denver to Reedsburg, WI on July 26th, then getting up early and head down to Brodhead either Saturday late afternoon or Sunday morning for a few hours. Then up to OSH at noon for the big show. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426473#426473 ________________________________________________________________________________
struts
Date: Jul 10, 2014
struts
Date: Jul 10, 2014
Thanks, Gary. Nice to hear your support. I really don't want to add any more bolts for fear of weakening the verticals between the top and bottom longerons. Just sent a picture of the firewall, you can see the four bolts in the picture. Sure enjoyed having Jim here today. Ray Sent from my iPad > On Jul 10, 2014, at 4:32 PM, "Gary Boothe" wrote: > > > Ray, > > My galvanized firewall started out not being anchored to anything...then the > process of adding engine support stuff started! Eventually, I added pan head > screws around the perimeter since that's where the cowling is anchored to > the firewall. I think you're OK... > > Gary Boothe > NX308MB > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause > Sent: Thursday, July 10, 2014 4:12 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: a common place to undersell > yourself---diagonal struts > > In response to your comment about the firewall being so structurally > important: my firewall is 1/4" plywood with a stainless steel face plate. I > now have it bolted to the two upright members that join the top longerons > vertically. I use four AN-3 bolts through the firewall and the front > vertical members, threading into a plate nut. Would this be adequate for > strength, or should the firewall be glued to the vertical members? Which is > best, adequate, or just OK? > > By the way, I am not too worried about weight because this is a SkyScout, > single place with an A-65; therefore the 1/4" firewall. > > Jim Boyer and his friend Jim were just here for a great lunch, visit and > viewing of my build progress. All visitors are welcome. Plane to start > covering this fall. > > Thanks, > > Ray Krause > > > > > > ________________________________________________________________________________
Date: Jul 11, 2014
That's great news! Katrina and I will be getting in Thursday afternoon and will be there 'till Sunday Looking forward to seeing everybody! -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426480#426480 ________________________________________________________________________________
Date: Jul 11, 2014
That is in a perfect impact with the wing moving forward and a compression load on the fuselage brace I assume? What happens when a twisting force is applied like a wing tip hitting first? The fuselage bracket will shear sideways and the wing plane will twist down in a helical vector. All I was saying is that you cannot reinforce one area thinking that is will mitigated all the forces. You need to look at the total system. I know from first hand experience when our Piet flipped over on her back, hard during a landing. We had heavy wall square diagonal braces with air-foiled shaped spruce epoxied over it and it was rigidly bolt at both ends. I know what damage was done, the ash motor support split, the firewall split down the middle, the shelf aft of the motor split, and the top of the diagonal bracket support where forced outward when the wing moved forward and took the weight of the plane plus the impact forces. Quite a lot of damage. So you need to do more the just strengthen up the diagonal brace. That was my point. BTW, no damage was done to the diagonal support braces, they were still in-tacked, just the support brackets they bolted to bent. I am all about being safe and sharing my opinions too. Cheers, WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426483#426483 ________________________________________________________________________________
Subject: RE: Brodhead 2014
Date: Jul 11, 2014
Looks like I won't be making Brodhead this year. Long story short, my partn ers and I have been trying to sell another airplane for several years, We h ave a buyer but a lot of engine problems have turned up on the pre-buy and I'll probably be knee deep in engine or hopefully delivering the airplane. There's an outside posibllity of flying the Bellanca to the buyer in Kansas the week of Brodhead and driving in but all the stars, and the cylinder sh op will have to align. Matt Paxton NX629ML ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: diagonals
Date: Jul 11, 2014
Hello all, My FAR less drastic experience with a sudden deceleration and nose-over demonstrated the need for stronger diagonals than I had at the time. While the plane was maybe going 25mpg on the ground, the wing still displaced about two inches forward upon deceleration. My hard fuel lines actually held (with ace hardware compression fittings, thank you very much) except for a little leak. Nothing was damaged on the engine mount whatsoever, yet a bit more displacement and my fuel lines would have been torn and fuel would be spilling out. I now have very strong diagonals and the top portion of each line going to the tank is flexible. I am sure there is a point at which the engine mount will "tear out" of the longeron, but I'll bet that there are many incidents short of that occurance which would dangerously displace the wing if the diagonals are too puny. AND. what do we possibly lose by beefing them up??? A few ounces??? This is NOT the place to be saving weight!! Douwe ________________________________________________________________________________
Date: Jul 11, 2014
Ray, It sounds to me like Gary gave you great direction. The 1/4 inch firewall will be strong. Please keep moving forward. I can't wait to see it next June. :) WF2, Thanks for your input too. This is a great sounding board and everyone's thoughts and comments very much appreciated. Because of this website, we have a lot of great, safe and beautiful Piets being built by some very talented folks. We have a lot of very smart people on this board. Including you. Keep on building, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426496#426496 ________________________________________________________________________________
Date: Jul 11, 2014
I plan on flying down on Thursday, weather permitting. Patrick Hoyt N63PZ - CH601/Corvair Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426497#426497 ________________________________________________________________________________
Date: Jul 11, 2014
I plan to arrive sometime Thursday afternoon with my travel trailer. Will stay until Sunday morning. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426504#426504 ________________________________________________________________________________
Date: Jul 11, 2014
Sadly, I am not able to make it this year due to some ongoing health issues that I'm trying to get resolved. There is a bit of good news in this, the money I had set aside for the trip to Brodhead will be used to buy some spruce so that I can resume building my Piet after a 3+ year interruption due to moving twice. Hopefully I will make the journey next year! -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426510#426510 ________________________________________________________________________________
Date: Jul 11, 2014
Billy, Stay home. Be well. Build airplanes. Gary Sent from my iPhone > On Jul 11, 2014, at 3:40 PM, "Billy McCaskill" wrote: > > > Sadly, I am not able to make it this year due to some ongoing health issues that I'm trying to get resolved. There is a bit of good news in this, the money I had set aside for the trip to Brodhead will be used to buy some spruce so that I can resume building my Piet after a 3+ year interruption due to moving twice. > > Hopefully I will make the journey next year! > > -------- > Billy McCaskill > Baker, LA > tail section almost done, starting on ribs soon > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426510#426510 > > > > > > > > > > ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Date: Jul 11, 2014
I have an offer to coach the Swedish Bikini Volleyball team this summer so I'll be missing Brodhead as well. Carry on good people! Mike C. Ohio ________________________________________________________________________________
Subject: Re: Airventure Latex Paint Forums
Date: Jul 11, 2014
I do hope your forum is on a Webinar or on YouTube. I so enjoy the last one and looking forward to your next with even more great information on using latex house paints. Thanks for doing this education topic. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426515#426515 ________________________________________________________________________________
struts
Date: Jul 11, 2014
Thanks, Scott. I have hopes of getting covered this fall. Who knows, I could be to the fly in next year! I do not know WF2, Women Who Fly; or do I? Sure appreciate your comments, you have a lot of good advise. Thanks, Ray Krause Sent from my iPad > On Jul 11, 2014, at 7:38 AM, "AircamperN11MS" wrote: > > > Ray, > > It sounds to me like Gary gave you great direction. The 1/4 inch firewall will be strong. Please keep moving forward. I can't wait to see it next June. :) > > WF2, > > Thanks for your input too. This is a great sounding board and everyone's thoughts and comments very much appreciated. Because of this website, we have a lot of great, safe and beautiful Piets being built by some very talented folks. We have a lot of very smart people on this board. Including you. > > Keep on building, > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426496#426496 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 11, 2014
Ray WF2 has left some thoughts to consider too. I have not met WF2 either but I sure love looking at their Piet pics. It's just got a good look. I hope to see it someday. Thanks for the nice words, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426522#426522 ________________________________________________________________________________
Date: Jul 12, 2014
WF2, Scotty, Ray, friends, An important point, that many have been covered many times: The type of firewall with a shelf that Ford powered planes need is structurally a different situation that a Corvair and Continental one where the plywood can come all the way up to the top longerons. The latter is reinforced and a lot more rigid in an extreme load. My Piet was original Ford powered, it had the shelf set up, it was noticibly more rigid when we did motor mount torsion load tests after the firewall was closed back up to the top longerons. we did this by applying a 200 ft pound torque load to the mount, I was looking for deflections in tubes in the mount tubes, but noticed that the unsupported upper mount locations on the longerons deflected much more than the mount. This could have been fixed with a cross tube in the mount, but I elected to put the plywood back in. Today, if a builder opts for a continental or a Corvair, there is no reason to have the shelf, the plywood should go all the way to the top, and the fuselage will undoubtedly be more rigid. Putting the plane on its back is less violent that a sudden stop or a very hard hit. I think the loads from having the airplane roll over its' nose are different, and the wing doesn't have the same deceleration, or impose the same force on the diagonal cabanes. None of the Piet crashes I have looked at closely had a "perfect impact", they all hit one wing first. In my accident, you could have used the last 6 ribs on the right wing again, the fabric as not even cut, and the left wing as a bag of kindling and sawdust on impact. Planes that are spun in do this. Even planes that are stalled at 15' tend to hit one wing first. a plane with it gear too far back, or landing with a tailwind is much more likely to impose a symmetric load as it goes over. Again, theory vs observation: saying "The fuselage bracket will shear sideways and the wing plane will twist down in a helical vector." is a reasonable sounding theory, but observation says that the loads don't remove this bracket from the longeron, they fail the diagonal cabane first. Any comment that includes the word "Will" is a statement of certainty, and my experience, absolute predictions like that don't address all the variables present in something like an accident, even if a single accident produced a result that looked that way. When a guy like Jack Phillips who has been flying his bird for a long time, decides that he is going to put in the required effort to make an improvement to his plane, an improvement which there is a 98% chance he will never use, It makes me think that there is some good effect of trying to share with other builders some things I paid a very high price to learn. This isn't ego telling anyone how smart I am, just the reverse, read part 1 of my cabane and fuel line story, and I have a picture there and directly say that I was doing something stupid the way my plane was set up. Go back and read my words on the three effects on other peoples lives that I didn't foresee, things you can't just fix with time, money or an apology. If you spend a few moments considering them as your wife, parents and friend, then you will have a much better understating of why this isn't a lighthearted theoretical debate on structures to me.-ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426528#426528 ________________________________________________________________________________
Subject: Brodhead rigging project - 2014
Date: Jul 12, 2014
Builders: Just for my own personal interest, I am going to bring the tools to measure wing incidence and rigging information to Brodhead. I mentioned this before, but have not heard from anyone else, but I am going to spend some of the time there measuring planes. Of particular interest is "The Last Original ", because I want to see if BHP decreased the wing incidence on his last plane. I am going to measure the stuff with a smart level working off a full chord profile board, so it will not be necessary to even level the plane, I can just do the math. I am also going to pick up the ground AOA number for planes while we are at it. I would like to show a few people how to do this, and have a standard measuring system so later data point collection is apples to apples. The CAD drawings done by Bill Church got me looking at this after reading about Chris Rusch's rigging condition. My book on Riblett airfoils is out on loan right now, but staring at the lift curves in Theory of Wing Sections of NACA airfoils with similar camber distributions to the GA30U-612 makes me think that the Riblett airfoil might do better with a lot less incidence. Structures is the hard part of Aerospace Engineering for people with robust gray matter. Basic Aerodynamics that applies to light planes can even be done by mathematical monkeys like me. The calculated numbers are very real world and useful. When looking for a desired angle of incidence, you rearrange the lift formula to solve for Coefficient of lift and stick in your numbers: CL = Pounds of lift / ( .5 (density of air) (speed in feet per second squared) (wing area in square feet) Lift = the flying weight of the plane, lets call it 1150 pounds Density of air at sea level = .00237 feet per second at 75 mph = 110.25 (projected cruise) Piet wing area = 145 The Coefficient of lift for the above numbers is .55 You can go right to a lift curve for the airfoil and look up which angle of attack on the airfoil produces this CL. I don't have the Riblett book in front of me, and his data was mostly computer simulation. Actual wind tunnel data for 6% camber airfoils suggests that 2 degrees (measured through the leading edge to trailing edge not the underside of the wing) might be very close. The goal is to have the plane set so that the fuselage is level at cruise speed. It will fly best in this condition and it will be easier to trim to fly well. Why would BHP's plans have 3.5 degrees actual incidence? Go back and run through the numbers, but look at it for a 62 mph cruise speed plane flying at 1100 pounds. The CL for that condition is .77, and the original airfoil may be making a number like that at an angle of attack of 3.5 degrees. A few measurements, and a 20 minute flight with a smart level on the front cockpit longeron and a GPS or calibrated airspeed, and we could have by reverse engineering, the center of a lift curve for the BHP airfoil. A few planes worth of data points, and a new builder could custom tailor the incidence for his plane to have a much better chance of it flying in proper trim from the start. The right incidence varies on different versions of the plane depending on the weight and the cruise speed. Why I want to look at The Last Original is to see if BHP lowered the incidence because the plane has a much higher cruise speed than one built to the 1929 plans, (and is also lighter) The formula above is very well known, and BHP absolutely would have seen, understood and used it. I own an original set of Flying and Glider Manuals, and it is in there in an article about selecting airfoils. Many people who don't like math or numbers still like Pietenpols. This is fine, but I contend that it is a false conclusion to suggest that BHP didn't know and use math and aero formulas. If you look at the man's life work in things like electronics, one can safely conclude he was comfortable with learning, and particularly testing improvements, often by rapid iterations and modifications, and this is why I suspect the Last Original may have something different for incidence. I have had a number of old breed Piet builders assure me that BHP was not the 'flying farmer' image projected by the magazines of the 1930s, that he was much more technical and insightful, and the farmer stuff was just editorial spin of the day. To my eye, BHP's evolving work further debunks the 'country boy' myth. There are people who actually believe that BHP's contribution to aviation was to provide them with a flyable airframe that they can decorate with style sense developed from watching Chitty Chitty Bang Bang too many times in an unfortunate childhood. I am all for people building their creation any way they like, I only object to BHP being recast as Dick Van Dike to support the idea that magic is more important than math. -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426537#426537 ________________________________________________________________________________
Date: Jul 12, 2014
Subject: Milestone Moment
I just got done flying around in the Pietenpol, and I promised the boys (Ja ke 5, Joe 3) an airplane ride (taxi around the airport).- Joe the 3 yr ol d went 1st and we taxied up and down the runway.- When it was Jake's turn I figured he was ready to fly.- He said he wasn't scared, even though my wife was giving me the evil eye.- I briefed him to keep his hands on the top of the longerons and not touch his seat belt (wife's eyes-still burn ing holes thru me).- We went up around the patch one time and he kept his little hands right where I told him, he was actually drumming his fingers on the longerons the whole 4-5 min we were flying.- He is the 3rd generat ion "Bell Boy" to fly in NX92GB!- Now I need to see if Aircraft Spruce or Wicks, sell Smile Remover, I can't get it off his face.=0A-=0AOne Proud Papa, =0AShad ________________________________________________________________________________
Subject: Re: Milestone Moment
Date: Jul 12, 2014
Builders, I just gathered up a number of photos of the Bell family Pietenpol, mostly from Brodhead 2008-2013, at this link: http://flycorvair.net/2014/07/13/the-bell-pietenpol-3-generations-of-flyers/ Hats off to Shad and Gary on a great day. ------------------------------------------------------------- A link to a collection of Piet stories: http://flycorvair.net/2013/11/28/corvair-pietenpol-reference-page/ . For a link to Pictures of Pietenpols: http://flycorvair.net/2013/01/11/pietenpol-review-in-pictures-15-more-corvair-powered-piets/ . -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426553#426553 ________________________________________________________________________________
Subject: Re: Brodhead rigging project - 2014
Date: Jul 12, 2014
William, BRILLIANT, sounds like fun and informational. Let me know if you need any help, should be around for most of Brodhead. Should also check the red and clear piet in the museum as well. Honestly, I've kind of always thought of you as what BHP was in his day. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426558#426558 ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Jul 13, 2014
Count me in! -------- Semper Fi, Terry Hand Athens, GA USMC, USMCR, ATP BVD DVD PDQ BBQ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426593#426593 ________________________________________________________________________________
Date: Jul 13, 2014
Subject: Brat Fest
Jack, I would like to participate in Brat Fest and will be happy to bring Watermelon as usual. If you would prefer I bring something else, please let me know. Thanks Joe Swithin Morris, IL ________________________________________________________________________________
Date: Jul 13, 2014
Me too- I'd like to help out -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426599#426599 ________________________________________________________________________________
Subject: Spring has sprung
Date: Jul 13, 2014
Imagine my surprise on Friday, to find the Spring issue of the BPA newsletter! John wasn't kidding when he said it was in the mail. Since it has already made it up to Canada, shouldn't be more than a month or so before it gets to the Southern States. Before you know it, it will be summer. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426605#426605 ________________________________________________________________________________
Date: Jul 13, 2014
Subject: Fw: Milestone Moment
=0A=0A =0AOn Saturday, July 12, 2014 8:57 PM, shad bell <aviatorbell@yahoo. com> wrote:=0A =0A=0A=0AI just got done flying around in the Pietenpol, an d I promised the boys (Jake 5, Joe 3) an airplane ride (taxi around the air port).- Joe the 3 yr old went 1st and we taxied up and down the runway. - When it was Jake's turn I figured he was ready to fly.- He said he wa sn't scared, even though my wife was giving me the evil eye.- I briefed h im to keep his hands on the top of the longerons and not touch his seat bel t (wife's eyes-still burning holes thru me).- We went up around the pat ch one time and he kept his little hands right where I told him, he was act ually drumming his fingers on the longerons the whole 4-5 min we were flyin g.- He is the 3rd generation "Bell Boy" to fly in NX92GB!- Now I need t
June 28, 2014 - July 13, 2014
Pietenpol-Archive.digest.vol-no
