Pietenpol-Archive.digest.vol-nt
August 31, 2014 - September 14, 2014
> > Read this topic online here:
> > http://forums.matronics.com/viewtopic.php?p=429680#429680
http://forums.matronics.com/viewtopic.php?p=429714#429714
Subject: | Re: Used Pietenpol plans |
They're worth $0 to someone with ethics.
Doug Dever
=0A
In beautiful Stow Ohio
> Subject: Pietenpol-List: Re: Used Pietenpol plans
> From: dlplett(at)swko.net
> Date: Sat=2C 30 Aug 2014 20:05:52 -0700
> To: pietenpol-list(at)matronics.com
> plett57(at)hotmail.com wrote:
> > The plans came with the Pietenol. The Piet is long gone and I still ha
ve plans. By count there a 19 sheets all together. I no longer need the
plans. What is something like this worth and is anyone interested?
> > Dan
> D'oh. Interesting this posted me as a guest.
> Dan Plett
> N28WH
> http://forums.matronics.com/viewtopic.php?p=429663#429663
Doug. How do you figure that?
Dan Plett
N28WH
http://forums.matronics.com/viewtopic.php?p=429717#429717
Subject: | Vi Kapler hinge re-bushing |
Hello, Pieters-
Among the tools and parts that I got from Vi Kapler when I purchased the rights
and the "tooling" for the cast hinges was a jig and instructions from Vi on re-bushing
the pivot pin holes in the hinge castings. According to the instructions
that he wrote (by hand, all of them), Vi says that when a set of hinges
has 750-1000 hours on them some play may develop due to wear. The fix is to re-bush
the pivot pin holes with brass sleeve inserts.
If there are any Piets out there that have noticeable play in their Kapler hinges
and have flying hours up in the range that Vi mentions, I would be happy to
re-bush your set of 9 pairs of hinges for $20 plus return postage, which is $6
in the small USPS prepaid box. For overseas, I'll have to check with the USPS
to see what it might cost to ship them back to you. Of course you'll have
to remove your tail surfaces to remove the hinges, and if you've covered over
them with fabric, you'll have to use an XActo knife to cut away the fabric to
get to them. This operation is something that is best done during winter when
you're not flying or when you have the airplane down for annual condition inspection.
I am no longer on the Matronics list and only check the forum periodically, so
if you are interested in having your hinges re-bushed, contact me directly at
taildrags(at)hotmail.com or I likely won't see your response.
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power
http://forums.matronics.com/viewtopic.php?p=429727#429727
From: | Ray Krause <raykrause(at)frontiernet.net> |
Subject: | Re: Evening flight |
Jeff,
I will be using an A-65, just overhauled and hopefully putting out the full 6
5 hp. Unfortunately, I have not been trying to be too "light weight" minded.
I may come in on the heavy side. It is built to plans, save for a few thing
s like the rudder horns, tail wheel and extra blocks here and there. Not sur
e it it's G loading could be any greater than the Aircamper with only on per
son up. It is the same wing, shorter fuselage, same tail, motor mount, etc. I
have been told it performs better because it is lighter, but I don't know i
f that will be true. I'm sure it will perform better than my Aeronca in cli
mb, but maybe not speed. But I think it will be a blast...just like your!
I will attach some pictures, maybe too large...
> On Aug 31, 2014, at 4:31 PM, "Jeff Boatright" wr
ote:
y.edu>
> Hi Ray,
> Thanks for the kind words. I just got lucky -- the beauty was there for th
e camera.
> My wife noticed that face, too. Sort of a Bert and Ernie look.
> Yep, my rudder control horns are below the horizontal stab. I didn't build
the plane originally (though I've disassembled/reassembled it twice and reb
uilt the forward fuselage once).
> I have always thought that the Skyscout was a very, very cool airplane. Do
you have any pix of yours? What will you power it with? I've also always wo
ndered if, given that I've been told it's the same design as the Aircamper b
ut weigh less, how many Gs can it take?
> Jeff
> Ray Krause wrote:
>> Jeffery,
>> Absolutely beautiful!
>> Observations: how do you fly that plane sitting backwards in the cockpit?
Note the first couple of views right after takeoff.
>> You have your rudder horns below the elevators? I did the same on my SkyS
cout. I know, it is not that way on the plans, but it should make the steera
ble tail wheel easier to operate.
>> Thanks for the great inspiration,
>> Ray Krause
>> Sent from my iPad
>>> On Aug 31, 2014, at 7:09 AM, "Jeff Boatright" wrote:
>>> Just some floobydust for your Labor Day weekend:
>>> http://youtu.be/ZdcKXbX8eVw
>>> Hope you get a chance to fly or work on your project this weekend!
