Pietenpol-Archive.digest.vol-nw
November 28, 2014 - December 22, 2014
      >> www.transferbigfiles.com. It's free.
      >> Gary Boothe
      >> NX308MB
      >> -----Original Message-----
      >> From: owner-pietenpol-list-server(at)matronics.com
      >> [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff
      >> Boatright
      >> Sent: Thursday, November 27, 2014 1:42 PM
      >> To: pietenpol-list(at)matronics.com
      >> Subject: Pietenpol-List: Re: Radiator from a P-51 ?
      >> aerocarjake wrote:
      >>> Ray,
      >>> I shot lots of photos of the Port Townsend Aero Museum's Sky Scout -
      >> including lots of details/closeups. I could put them on a flash drive
      >> and send it to you if you get me your address.....
      >> Hi Jake,
      >> I don't know if your internet connection allows you to upload them (in
      >> terms of time, cost, or other limits), but have you considered sending
      >> them to Chris Tracy at www.westcoastpiet.com? This would allow a
      >> semi-permanent archiving and access for many of us.
      >> westcoastpiet(at)westcoastpiet.com
      >> Maybe Chris has an ftp site or something like dropbox that you can
      >> upload the images efficiently to.
      >> http://forums.matronics.com/viewtopic.php?p=434846#434846
Subject: Pietenpol project For Sale
Date: Nov 28, 2014
Started my Pietenpol last November but have decided to sell my project. After much consideration, it looks like the Pietenpol will not fit my flying needs. Status of the project is: The fuselage is framed up, bottom attached, seat backs and bottom framing installed. Firewall and other bulkheads cut but not installed. Wing center section about 90% done, right wing panel about 80% done. Riblett 613.5 airfoil. All ribs completed. Have spars for left wing panel prepped and ready for ribs. Horizontal and vertical stabs, elevators and rudder are ready for varnish and hinge installation. Corvair motor disassembled, cleaned and case parts painted. Basically ready for reassembly with Wm Wynne's conversion parts. Have old cylinders, rods etc for use as cores. I planned on the split axle landing gear so I have a set of Cleveland 6" wheels, brakes, bolt on axles and 6.00 x 8.00 tires. 1 sheet (4ft x 8ft) each of 1/16 and 1/8 (for fuselage sides) birch aircraft plywood. Various 4130 wing fittings completed. If interested, please contact me off list. Grant Ziebell Savannah, TN 731-926-2454 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=434956#434956 ________________________________________________________________________________
Date: Nov 28, 2014
Subject: Re: Pietenpol Engines
I am fascinated by electric flight. For my weekend flying an electric motor would be awesome. One good flight of less than an hour with a good reserve. quieter and when you are done you just plug the plane in and go home. Don't have to get gas. When I deployed I did not want my wife to have to struggle with a gas mower and all that comes with it. IE gas, oil, sparkplugs and so on. When I came home I got used to using it and I am a convert. The big problem is usually the batteries and you just replace them. I will eventually buy an electric car when the prices and performance are right. Getting a electric Chevy Suburban could be on the horizon. My understanding is that a Pietenpol is a poor candidate for electric power, as electric power is at this time. Too draggy. But I am willing to be wrong. The electric motor is much smaller and lighter but the batteries are heavy. Having said that, you would be able to replace a heavy Model A engine and the fuel tanks with batteries. The wings of a Piet would be perfect for Solar cells, just to extend the range. I fantasize about converting my old 1948 Vtail bonanza to electric. But it is most likely too heavy. Electric Blue Skies Steve D ________________________________________________________________________________
Date: Nov 28, 2014
Subject: Re: Willys Jeep Pietenpol
Quite impressive. I really hope it pans out. Blue Skies, Steve D ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Date: Nov 29, 2014
U2FtZSBmb3IgbWUuIFRoZXJlIGlzIGFuIGVsZWN0cmljIFBpZXQgcHJvamVjdCBvdXQgdGhlcmUs IGJ1dCBJIGRvbuKAmXQga25vdyBtdWNoIGFib3V0IGl0LiBUaGUgbWF5IGJlIGRyYWdneSwgYnV0 IGl0IGlzIGludGVyZXN0aW5nIHRoYXQgc2V2ZXJhbCBvZiB0aGUgbW9yZSBzdWNjZXNzZnVsIGVs ZWN0cmljIGZseWluZyBjcmFmdCwgc28gZmFyLCBhcmUgYmFzZWQgb24gdWx0cmFsaWdodHMuIFBs ZW50eSBvZiBkcmFnIHRoZXJlLiBJIHRoaW5rIHRoYXQgYSBiaWcgcGFydCBvZiB0aGUgZXF1YXRp b24gaXMgdGhlIG1pc3Npb24uIEFzIHlvdSBwb2ludCBvdXQsIGFuIGhvdXIgb2YgZmx5aW5nIGlz IGFib3V0IHdoYXQgSSBkbyBpbiB0aGUgbW9ybmluZy4gTWF5YmUgYW5vdGhlciBob3VyIGluIHRo ZSBldmVuaW5nLiBGb3IgdGhhdCBtaXNzaW9uLCB0aGUgZWxlY3RyaWMgc29sdXRpb24gYWxyZWFk eSBleGlzdHMuIFdoeSBkb27igJl0IEkgaGF2ZSBvbmU/IFdlbGwsIEkgYWxyZWFkeSBoYXZlIGEg UGlldOKApiAgOykgTWF5YmUgaWYgSSBkaWRu4oCZdCwgSSBzaW5rIHNpbWlsYXIgbW9uZXkgaW50 byB0aGUgZmlyc3QgZ2VuZXJhdGlvbiBFbGVjdHJhRmx5ZXIgYW5kIGdvIGhhdmUgZnVuIHdpdGgg dGhhdC4gU3RpbGwsIGl04oCZcyB2ZXJ5IGF0dHJhY3RpdmUg4oCUIGVzcGVjaWFsbHkgYXMsIGxp dGVyYWxseSB0b2RheSwgbXkgY2FyYiBzdGFydGVkIGxlYWtpbmchISAgPW8NCg0KLS0NCkplZmZy ZXkgSC4gQm9hdHJpZ2h0LCBQaEQsIEZBUlZPDQpQcm9mZXNzb3Igb2YgT3BodGhhbG1vbG9neQ0K RW1vcnkgVW5pdmVyc2l0eSBTY2hvb2wgb2YgTWVkaWNpbmUNCg0KRnJvbTogU3RldmVuIERvcnRj aCA8c3RldmVuLmQuZG9ydGNoQGdtYWlsLmNvbTxtYWlsdG86c3RldmVuLmQuZG9ydGNoQGdtYWls LmNvbT4+DQpSZXBseS1UbzogInBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnBp ZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20+IiA8cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNv bTxtYWlsdG86cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbT4+DQpEYXRlOiBGcmlkYXksIE5v dmVtYmVyIDI4LCAyMDE0IGF0IDc6NTggUE0NClRvOiAicGlldGVucG9sLWxpc3RAbWF0cm9uaWNz LmNvbTxtYWlsdG86cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbT4iIDxwaWV0ZW5wb2wtbGlz dEBtYXRyb25pY3MuY29tPG1haWx0bzpwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPj4NClN1 YmplY3Q6IFJlOiBQaWV0ZW5wb2wtTGlzdDogUmU6IFBpZXRlbnBvbCBFbmdpbmVzDQoNCkkgYW0g ZmFzY2luYXRlZCBieSBlbGVjdHJpYyBmbGlnaHQuIEZvciBteSB3ZWVrZW5kIGZseWluZyBhbiBl bGVjdHJpYyBtb3RvciB3b3VsZCBiZSBhd2Vzb21lLiBPbmUgZ29vZCBmbGlnaHQgb2YgbGVzcyB0 aGFuIGFuIGhvdXIgd2l0aCBhIGdvb2QgcmVzZXJ2ZS4gcXVpZXRlciBhbmQgd2hlbiB5b3UgYXJl IGRvbmUgeW91IGp1c3QgcGx1ZyB0aGUgcGxhbmUgaW4gYW5kIGdvIGhvbWUuIERvbid0IGhhdmUg dG8gZ2V0IGdhcy4NCg0KV2hlbiBJIGRlcGxveWVkIEkgZGlkIG5vdCB3YW50IG15IHdpZmUgdG8g aGF2ZSB0byBzdHJ1Z2dsZSB3aXRoIGEgZ2FzIG1vd2VyIGFuZCBhbGwgdGhhdCBjb21lcyB3aXRo IGl0LiBJRSBnYXMsIG9pbCwgc3BhcmtwbHVncyBhbmQgc28gb24uIFdoZW4gSSBjYW1lIGhvbWUg SSBnb3QgdXNlZCB0byB1c2luZyBpdCBhbmQgSSBhbSBhIGNvbnZlcnQuIFRoZSBiaWcgcHJvYmxl bSBpcyB1c3VhbGx5IHRoZSBiYXR0ZXJpZXMgYW5kIHlvdSBqdXN0IHJlcGxhY2UgdGhlbS4NCg0K SSB3aWxsIGV2ZW50dWFsbHkgYnV5IGFuIGVsZWN0cmljIGNhciB3aGVuIHRoZSBwcmljZXMgYW5k IHBlcmZvcm1hbmNlIGFyZSByaWdodC4gR2V0dGluZyBhIGVsZWN0cmljIENoZXZ5IFN1YnVyYmFu IGNvdWxkIGJlIG9uIHRoZSBob3Jpem9uLg0KDQpNeSB1bmRlcnN0YW5kaW5nIGlzIHRoYXQgYSBQ aWV0ZW5wb2wgaXMgYSBwb29yIGNhbmRpZGF0ZSBmb3IgZWxlY3RyaWMgcG93ZXIsIGFzIGVsZWN0 cmljIHBvd2VyIGlzIGF0IHRoaXMgdGltZS4gVG9vIGRyYWdneS4gQnV0IEkgYW0gd2lsbGluZyB0 byBiZSB3cm9uZy4NCg0KVGhlIGVsZWN0cmljIG1vdG9yIGlzIG11Y2ggc21hbGxlciBhbmQgbGln aHRlciBidXQgdGhlIGJhdHRlcmllcyBhcmUgaGVhdnkuIEhhdmluZyBzYWlkIHRoYXQsIHlvdSB3 b3VsZCBiZSBhYmxlIHRvIHJlcGxhY2UgYSBoZWF2eSBNb2RlbCBBIGVuZ2luZSBhbmQgdGhlIGZ1 ZWwgdGFua3Mgd2l0aCBiYXR0ZXJpZXMuICBUaGUgd2luZ3Mgb2YgYSBQaWV0IHdvdWxkIGJlIHBl cmZlY3QgZm9yIFNvbGFyIGNlbGxzLCBqdXN0IHRvIGV4dGVuZCB0aGUgcmFuZ2UuDQoNCkkgZmFu dGFzaXplIGFib3V0IGNvbnZlcnRpbmcgbXkgb2xkIDE5NDggVnRhaWwgYm9uYW56YSB0byBlbGVj dHJpYy4gQnV0IGl0IGlzIG1vc3QgbGlrZWx5IHRvbyBoZWF2eS4NCg0KRWxlY3RyaWMgQmx1ZSBT a2llcw0KU3RldmUgRA0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPQ0KXy09ICAgICAgIC0tIFBsZWFzZSBTdXBw b3J0IFlvdXIgTGlzdHMgVGhpcyBNb250aCAtLQ0KXy09ICAgICAgICAgICAoQW5kIEdldCBTb21l IEFXRVNPTUUgRlJFRSBHaWZ0cyEpDQpfLT0NCl8tPSAgIE5vdmVtYmVyIGlzIHRoZSBBbm51YWwg TGlzdCBGdW5kIFJhaXNlci4gIENsaWNrIG9uDQpfLT0gICB0aGUgQ29udHJpYnV0aW9uIGxpbmsg YmVsb3cgdG8gZmluZCBvdXQgbW9yZSBhYm91dA0KXy09ICAgdGhpcyB5ZWFyJ3MgVGVycmlmaWMg RnJlZSBJbmNlbnRpdmUgR2lmdHMgcHJvdmlkZWQNCl8tPSAgIGJ5Og0KXy09DQpfLT0gICAgICog QWVyb0VsZWN0cmljIHd3dy5hZXJvZWxlY3RyaWMuY29tPGh0dHA6Ly93d3cuYWVyb2VsZWN0cmlj LmNvbT4NCl8tPSAgICAgKiBUaGUgQnVpbGRlcidzIEJvb2tzdG9yZSB3d3cuYnVpbGRlcnNib29r cy5jb208aHR0cDovL3d3dy5idWlsZGVyc2Jvb2tzLmNvbT4NCl8tPSAgICAgKiBIb21lYnVpbHRI RUxQIHd3dy5ob21lYnVpbHRoZWxwLmNvbTxodHRwOi8vd3d3LmhvbWVidWlsdGhlbHAuY29tPg0K Xy09ICAgICAqIE15IFBpbG90IFN0b3JlIHd3dy5teXBpbG90c3RvcmUuY29tPGh0dHA6Ly93d3cu bXlwaWxvdHN0b3JlLmNvbT4NCl8tPSAgICAgKiBSYWNlIENvbnN1bHRpbmcgd3d3Lm1ycmFjZS5j b208aHR0cDovL3d3dy5tcnJhY2UuY29tPg0KXy09DQpfLT0gICBMaXN0IENvbnRyaWJ1dGlvbiBX ZWIgU2l0ZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmli dXRpb24NCl8tPQ0KXy09ICAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQpf LT0NCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBB ZG1pbi4NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRoZSBQaWV0ZW5wb2wtTGlzdCBFbWFp bCBGb3J1bSAtDQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3Ig dG8gYnJvd3NlDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1 YnNjcmlwdGlvbiwNCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2Us IENoYXQsIEZBUSwNCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQpfLT0NCl8t PSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1BpZXRlbnBvbC1MaXN0 DQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0N Cl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1z IQ0KXy09DQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpfLT0NCl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 DQoNCg0KDQpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KDQpUaGlzIGUtbWFpbCBt ZXNzYWdlIChpbmNsdWRpbmcgYW55IGF0dGFjaG1lbnRzKSBpcyBmb3IgdGhlIHNvbGUgdXNlIG9m DQp0aGUgaW50ZW5kZWQgcmVjaXBpZW50KHMpIGFuZCBtYXkgY29udGFpbiBjb25maWRlbnRpYWwg YW5kIHByaXZpbGVnZWQNCmluZm9ybWF0aW9uLiBJZiB0aGUgcmVhZGVyIG9mIHRoaXMgbWVzc2Fn ZSBpcyBub3QgdGhlIGludGVuZGVkDQpyZWNpcGllbnQsIHlvdSBhcmUgaGVyZWJ5IG5vdGlmaWVk IHRoYXQgYW55IGRpc3NlbWluYXRpb24sIGRpc3RyaWJ1dGlvbg0Kb3IgY29weWluZyBvZiB0aGlz IG1lc3NhZ2UgKGluY2x1ZGluZyBhbnkgYXR0YWNobWVudHMpIGlzIHN0cmljdGx5DQpwcm9oaWJp dGVkLg0KDQpJZiB5b3UgaGF2ZSByZWNlaXZlZCB0aGlzIG1lc3NhZ2UgaW4gZXJyb3IsIHBsZWFz ZSBjb250YWN0DQp0aGUgc2VuZGVyIGJ5IHJlcGx5IGUtbWFpbCBtZXNzYWdlIGFuZCBkZXN0cm95 IGFsbCBjb3BpZXMgb2YgdGhlDQpvcmlnaW5hbCBtZXNzYWdlIChpbmNsdWRpbmcgYXR0YWNobWVu dHMpLg0K ________________________________________________________________________________
Date: Nov 28, 2014
It seems to me that an electric Piet is feasible--it currently would only be limited by flight time (battery capacity). Sure, a Piet has lots of drag, but if you look at what's being done you can see examples like the Pipistrel electric 2-place training plane which has a 31 lb Siemens motor which is supposedly equivalent to a 110 HP aircraft motor, and the 3500 lb Nissan Leaf car which has amazing acceleration, to see that electric should work in a Pietenpol once the batteries can hold enough juice to overcome a Piet's extra drag for a reasonable length of time. Even today, if you could live with a single-place Piet, an hour of flight is probably possible. Some of the new car battery packs are getting pretty compact. --Mac in Oregon > Same for me. There is an electric Piet project out there, but I dont > know much about it. The may be draggy, but it is interesting that several > of the more successful electric flying craft, so far, are based on > ultralights. Plenty of drag there. I think that a big part of the equation > is the mission. As you point out, an hour of flying is about what I do in > the morning. Maybe another hour in the evening. For that mission, the > electric solution already exists. Why dont I have one? Well, I already > have a Piet ;) Maybe if I didnt, I sink similar money into the > first generation ElectraFlyer and go have fun with that. Still, its > very attractive especially as, literally today, my carb started > leaking!! =o > > -- > Jeffrey H. Boatright, PhD, FARVO > Professor of Ophthalmology > Emory University School of Medicine > > From: Steven Dortch > > > Reply-To: > "pietenpol-list(at)matronics.com" > > > Date: Friday, November 28, 2014 at 7:58 PM > To: "pietenpol-list(at)matronics.com" > > > Subject: Re: Pietenpol-List: Re: Pietenpol Engines > > I am fascinated by electric flight. For my weekend flying an electric > motor would be awesome. One good flight of less than an hour with a good > reserve. quieter and when you are done you just plug the plane in and go > home. Don't have to get gas. > > When I deployed I did not want my wife to have to struggle with a gas > mower and all that comes with it. IE gas, oil, sparkplugs and so on. When > I came home I got used to using it and I am a convert. The big problem is > usually the batteries and you just replace them. > > I will eventually buy an electric car when the prices and performance are > right. Getting a electric Chevy Suburban could be on the horizon. > > My understanding is that a Pietenpol is a poor candidate for electric > power, as electric power is at this time. Too draggy. But I am willing to > be wrong. > > The electric motor is much smaller and lighter but the batteries are > heavy. Having said that, you would be able to replace a heavy Model A > engine and the fuel tanks with batteries. The wings of a Piet would be > perfect for Solar cells, just to extend the range. > > I fantasize about converting my old 1948 Vtail bonanza to electric. But it > is most likely too heavy. > > Electric Blue Skies > Steve D > > > www.buildersbooks.com<http://www.buildersbooks.com> > www.homebuilthelp.com<http://www.homebuilthelp.com> > www.mypilotstore.com<http://www.mypilotstore.com> > > > ________________________________ > > This e-mail message (including any attachments) is for the sole use of > the intended recipient(s) and may contain confidential and privileged > information. If the reader of this message is not the intended > recipient, you are hereby notified that any dissemination, distribution > or copying of this message (including any attachments) is strictly > prohibited. > > If you have received this message in error, please contact > the sender by reply e-mail message and destroy all copies of the > original message (including attachments). > ________________________________________________________________________________
Date: Nov 28, 2014
Hey, maybe I can convert my Sky Scout at sometime in the future! Thanks for the idea, Ray Krause Sent from my iPad > On Nov 28, 2014, at 7:59 PM, macz(at)peak.org wrote: > > > It seems to me that an electric Piet is feasible--it currently would only > be limited by flight time (battery capacity). > > Sure, a Piet has lots of drag, but if you look at what's being done you > can see examples like the Pipistrel electric 2-place training plane which > has a 31 lb Siemens motor which is supposedly equivalent to a 110 HP > aircraft motor, and the 3500 lb Nissan Leaf car which has amazing > acceleration, to see that electric should work in a Pietenpol once the > batteries can hold enough juice to overcome a Piet's extra drag for a > reasonable length of time. Even today, if you could live with a > single-place Piet, an hour of flight is probably possible. Some of the > new car battery packs are getting pretty compact. > --Mac in Oregon > > > > >> Same for me. There is an electric Piet project out there, but I dont >> know much about it. The may be draggy, but it is interesting that several >> of the more successful electric flying craft, so far, are based on >> ultralights. Plenty of drag there. I think that a big part of the equation >> is the mission. As you point out, an hour of flying is about what I do in >> the morning. Maybe another hour in the evening. For that mission, the >> electric solution already exists. Why dont I have one? Well, I already >> have a Piet ;) Maybe if I didnt, I sink similar money into the >> first generation ElectraFlyer and go have fun with that. Still, its >> very attractive especially as, literally today, my carb started >> leaking!! =o >> >> -- >> Jeffrey H. Boatright, PhD, FARVO >> Professor of Ophthalmology >> Emory University School of Medicine >> >> From: Steven Dortch >> > >> Reply-To: >> "pietenpol-list(at)matronics.com" >> > >> Date: Friday, November 28, 2014 at 7:58 PM >> To: "pietenpol-list(at)matronics.com" >> > >> Subject: Re: Pietenpol-List: Re: Pietenpol Engines >> >> I am fascinated by electric flight. For my weekend flying an electric >> motor would be awesome. One good flight of less than an hour with a good >> reserve. quieter and when you are done you just plug the plane in and go >> home. Don't have to get gas. >> >> When I deployed I did not want my wife to have to struggle with a gas >> mower and all that comes with it. IE gas, oil, sparkplugs and so on. When >> I came home I got used to using it and I am a convert. The big problem is >> usually the batteries and you just replace them. >> >> I will eventually buy an electric car when the prices and performance are >> right. Getting a electric Chevy Suburban could be on the horizon. >> >> My understanding is that a Pietenpol is a poor candidate for electric >> power, as electric power is at this time. Too draggy. But I am willing to >> be wrong. >> >> The electric motor is much smaller and lighter but the batteries are >> heavy. Having said that, you would be able to replace a heavy Model A >> engine and the fuel tanks with batteries. The wings of a Piet would be >> perfect for Solar cells, just to extend the range. >> >> I fantasize about converting my old 1948 Vtail bonanza to electric. But it >> is most likely too heavy. >> >> Electric Blue Skies >> Steve D >> >> >> >> www.buildersbooks.com<http://www.buildersbooks.com> >> www.homebuilthelp.com<http://www.homebuilthelp.com> >> www.mypilotstore.com<http://www.mypilotstore.com> >> >> >> >> ________________________________ >> >> This e-mail message (including any attachments) is for the sole use of >> the intended recipient(s) and may contain confidential and privileged >> information. If the reader of this message is not the intended >> recipient, you are hereby notified that any dissemination, distribution >> or copying of this message (including any attachments) is strictly >> prohibited. >> >> If you have received this message in error, please contact >> the sender by reply e-mail message and destroy all copies of the >> original message (including attachments). > > > > > > > > ________________________________________________________________________________
Subject: Re: Honda Goldwing radiator
Date: Nov 28, 2014
My 'Goldwing radiator came In the mail today and after un-packing it I noticed it would fit behind the prop and above the prop shaft. I believe I will try it to see if it has enough cooling ability. It will surely look cool in that spot. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=434972#434972 ________________________________________________________________________________
Subject: Re: Radiator from a P-51 ?
Date: Nov 28, 2014
OK... I'll send a flash stick and try to post them to west coast Piet. I post at lunch from my work computer which blocks access to all large file sites. I'll find some way that works. Finished up the wing strut ftgs today should be assembling the whole airplane for the first time on Sunday (to measure the wing strut lengths) so I'll post pictures soon - pretty exciting....... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=434973#434973 ________________________________________________________________________________
Date: Nov 28, 2014
Well I finally found pics of Jim Malley's Fiesta Piet. As you can see he has two rads beside the prop shaft and had to add one more small one just ahead of the landing gear. Clif > > My 'Goldwing radiator came In the mail today and after un-packing it I > noticed it would fit behind the prop and above the prop shaft. I believe > I will try it to see if it has enough cooling ability. It will surely look > cool in that spot. ________________________________________________________________________________
Date: Nov 29, 2014
OK... I'll send a flash stick and try to post them to west coast Piet. I post at lunch from my work computer which blocks access to all large file sites. I'll find some way that works. Finished up the wing strut ftgs today should be assembling the whole airplane for the first time on Sunday (to measure the wing strut lengths) so I'll post pictures soon - pretty exciting....... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=434976#434976 ________________________________________________________________________________
Date: Nov 29, 2014
From: "Charles N. Campbell" <charlescampbell1924(at)gmail.com>
I'm not getting the pictures that people are sending. Is it my computer/program or what? Chuck On Sat, Nov 29, 2014 at 2:55 AM, Clif Dawson wrote: > > Well I finally found pics of Jim Malley's Fiesta Piet. > As you can see he has two rads beside the prop > shaft and had to add one more small one just ahead > of the landing gear. > > Clif > > >> My 'Goldwing radiator came In the mail today and after un-packing it I >> noticed it would fit behind the prop and above the prop shaft. I believe I >> will try it to see if it has enough cooling ability. It will surely look >> cool in that spot. >> > > ________________________________________________________________________________
Subject: Progress in Pryor
Date: Nov 29, 2014
Finished rib tapes in the first wing panel yesterday. Moving the project fr om my workshop (200'+ from the house) to the attached garage sure makes work ing on it a lot more likely! Perimeter tapes today and maybe stating the pa int tomorrow. Life is good. Hope everyone had a good Thanksgiving. We especially give thanks for those o f you who served our country. Thank you. ________________________________________________________________________________
Date: Nov 29, 2014
Jake, Thank you so much! If sending the large file is too complicated, I will gladly get the stick to Chris Tracy. Or, if you find a way to send the large file, that would also work for me. I have a desk top computer I can use, if my wife will allow it (she will)! If you send the large file, please send it to both me and my wife at dmkrause(at)frintiernet.net. That way, it will be sure to arrive safely. My iPad sometimes gets cranky with larger files. Have fun building, Ray Krause Sent from my iPad > On Nov 29, 2014, at 12:58 AM, aerocarjake wrote: > > > OK... I'll send a flash stick and try to post them to west coast Piet. I post at lunch from my work computer which blocks access to all large file sites. I'll find some way that works. Finished up the wing strut ftgs today should be assembling the whole airplane for the first time on Sunday (to measure the wing strut lengths) so I'll post pictures soon - pretty exciting....... > > -------- > Jake Schultz - curator, > Newport Way Air Museum (OK, it's just my home) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=434976#434976 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 29, 2014
Subject: Make Sure You're Listed! List of Contributors Coming
Soon! Dear Listers, There's just two more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Nov 29, 2014
I dunno. I kind of like the "pockita pockita" sound of a Model A or a Continental. "Whirrrr" just doesn't sound the same. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Boatright, Jeffrey Sent: Friday, November 28, 2014 9:31 PM Subject: Re: Pietenpol-List: Re: Pietenpol Engines Same for me. There is an electric Piet project out there, but I don't know much about it. The may be draggy, but it is interesting that several of the more successful electric flying craft, so far, are based on ultralights. Plenty of drag there. I think that a big part of the equation is the mission. As you point out, an hour of flying is about what I do in the morning. Maybe another hour in the evening. For that mission, the electric solution already exists. Why don't I have one? Well, I already have a Piet. ;) Maybe if I didn't, I sink similar money into the first generation ElectraFlyer and go have fun with that. Still, it's very attractive - especially as, literally today, my carb started leaking!! =o -- Jeffrey H. Boatright, PhD, FARVO Professor of Ophthalmology Emory University School of Medicine From: Steven Dortch <steven.d.dortch(at)gmail.com> Date: Friday, November 28, 2014 at 7:58 PM Subject: Re: Pietenpol-List: Re: Pietenpol Engines I am fascinated by electric flight. For my weekend flying an electric motor would be awesome. One good flight of less than an hour with a good reserve. quieter and when you are done you just plug the plane in and go home. Don't have to get gas. When I deployed I did not want my wife to have to struggle with a gas mower and all that comes with it. IE gas, oil, sparkplugs and so on. When I came home I got used to using it and I am a convert. The big problem is usually the batteries and you just replace them. I will eventually buy an electric car when the prices and performance are right. Getting a electric Chevy Suburban could be on the horizon. My understanding is that a Pietenpol is a poor candidate for electric power, as electric power is at this time. Too draggy. But I am willing to be wrong. The electric motor is much smaller and lighter but the batteries are heavy. Having said that, you would be able to replace a heavy Model A engine and the fuel tanks with batteries. The wings of a Piet would be perfect for Solar cells, just to extend the range. I fantasize about converting my old 1948 Vtail bonanza to electric. But it is most likely too heavy. Electric Blue Skies Steve D _____ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ~=03 ________________________________________________________________________________
Subject: Re: Progress in Pryor
Date: Nov 29, 2014
Well Jim, the "People's Piet" looks good in pastel colored stripes ;o) Sure is going to scare the chickens when you light off the engine though. Probably pull the side off the barn when you hook up the fish scales, too ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435065#435065 ________________________________________________________________________________
Subject: Re: Sky Scout
Date: Nov 29, 2014
Dick; do you plan to put your Sky Scout on those Muktuk floats? It would likely be the first ever to fly. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435066#435066 ________________________________________________________________________________
Date: Nov 29, 2014
Ray; this has nothing to do with a radiator from a P-51! It's kind of a slow holiday weekend though, and I don't know about your location but Medford is low and messy IFR so we're mostly indoors. Don't worry about the cataract surgery- my wife had both eyes done (with a few months between surgeries) and could not believe all that she had been missing when she looked out through the first new lens. You guys who are talking about going to visit Ray in Colusa, I have a favor to ask. Gary and Chris have been most gracious to have moved and stored my little Ultravair engine for all these months but I'm hoping that it can be shifted over to Ray's if he'll be headed up here to Oregon to visit his son. I'll be happy to pay fuel costs for moving it so I can get it in my hangar. Thanks. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435067#435067 ________________________________________________________________________________
From: "Jeff Boatright" <jeffboatright(at)emory.edu>
Date: Nov 29, 2014
dfwplt wrote: > ...Moving the project from my workshop (200'+ from the house) to the attached garage sure makes working on it a lot more likely!... 6 feet of snow and uphill both ways out and back to that workshop, eh Jim? [Wink] Looks great and thanks for sending the photos! Jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435068#435068 ________________________________________________________________________________
Date: Nov 29, 2014
Oscar, This is what we'll be using to move your engine...so your offer to buy gas is most appreciated!! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of taildrags Sent: Saturday, November 29, 2014 10:23 AM Subject: Pietenpol-List: Re: Radiator from a P-51 ? --> Ray; this has nothing to do with a radiator from a P-51! It's kind of a slow holiday weekend though, and I don't know about your location but Medford is low and messy IFR so we're mostly indoors. Don't worry about the cataract surgery- my wife had both eyes done (with a few months between surgeries) and could not believe all that she had been missing when she looked out through the first new lens. You guys who are talking about going to visit Ray in Colusa, I have a favor to ask. Gary and Chris have been most gracious to have moved and stored my little Ultravair engine for all these months but I'm hoping that it can be shifted over to Ray's if he'll be headed up here to Oregon to visit his son. I'll be happy to pay fuel costs for moving it so I can get it in my hangar. Thanks. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435067#435067 ________________________________________________________________________________
Date: Nov 29, 2014
Gary; if you'll be moving my engine in a twin Beech, I'll not only pay for the gas but I'll also drive down there, help you load it up, ride right seat to go drop it off, help you unload it, and then ride right seat back down after unloading it ;o) I would love to get a ride in one of those. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435074#435074 ________________________________________________________________________________
Date: Nov 29, 2014
My apologies. I'm so bad. I thought I was so clever finding this stuff that I forgot to paste in the link!!! So here it is. You'll have to scroll down a bit. http://forums.matronics.com/viewtopic.php?t=58665&start=0&postdays= 0&postorder=asc&highlight=&sid=39ef372d0a98a685fc403c5dd2d2b64b Bad Clif You cannot escape. Every day a part of you turns to shit. I'm not getting the pictures that people are sending. Is it my computer/program or what? Chuck ________________________________________________________________________________
Date: Nov 29, 2014
Just poke a piece of cardboard into the spokes, er, prop blades. Clif ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Saturday, November 29, 2014 10:00 AM Subject: RE: Pietenpol-List: Re: Pietenpol Engines I dunno. I kind of like the "pockita pockita" sound of a Model A or a Continental. "Whirrrr" just doesn't sound the same. Jack Phillips NX899JP Smith Mountain Lake, Virginia ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Boatright, Jeffrey Sent: Friday, November 28, 2014 9:31 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Re: Pietenpol Engines Same for me. There is an electric Piet project out there, but I don't know much about it. The may be draggy, but it is interesting that several of the more successful electric flying craft, so far, are based on ultralights. Plenty of drag there. I think that a big part of the equation is the mission. As you point out, an hour of flying is about what I do in the morning. Maybe another hour in the evening. For that mission, the electric solution already exists. Why don't I have one? Well, I already have a Piet. ;) Maybe if I didn't, I sink similar money into the first generation ElectraFlyer and go have fun with that. Still, it's very attractive - especially as, literally today, my carb started leaking!! =o -- Jeffrey H. Boatright, PhD, FARVO Professor of Ophthalmology Emory University School of Medicine From: Steven Dortch <steven.d.dortch(at)gmail.com> Reply-To: "pietenpol-list(at)matronics.com" Date: Friday, November 28, 2014 at 7:58 PM To: "pietenpol-list(at)matronics.com" Subject: Re: Pietenpol-List: Re: Pietenpol Engines I am fascinated by electric flight. For my weekend flying an electric motor would be awesome. One good flight of less than an hour with a good reserve. quieter and when you are done you just plug the plane in and go home. Don't have to get gas. When I deployed I did not want my wife to have to struggle with a gas mower and all that comes with it. IE gas, oil, sparkplugs and so on. When I came home I got used to using it and I am a convert. The big problem is usually the batteries and you just replace them. I will eventually buy an electric car when the prices and performance are right. Getting a electric Chevy Suburban could be on the horizon. My understanding is that a Pietenpol is a poor candidate for electric power, as electric power is at this time. Too draggy. But I am willing to be wrong. The electric motor is much smaller and lighter but the batteries are heavy. Having said that, you would be able to replace a heavy Model A engine and the fuel tanks with batteries. The wings of a Piet would be perfect for Solar cells, just to extend the range. I fantasize about converting my old 1948 Vtail bonanza to electric. But it is most likely too heavy. Electric Blue Skies Steve D www.buildersbooks.comwww.mypilotstore.comhttp://www.matronics.com/Navigat or?Pietenpol-Listhttp://forums.matronics.com ------------------------------------------------------------------------- ----- This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ~=03 ________________________________________________________________________________
Date: Nov 29, 2014
Oscar, For me, the cataract surgery may be really beneficial because I also have macular degeneration in that eye. This will allow more light in and possibly increase distance vision? It is dry macular degeneration and is not getting worse, so hopefully I can keep flying for a while. Not sure how big your Ultravair engine might be, if smaller then a cat D-9, I can take care of it and probably get it to Medford, sometime. As you know, my grand daughter goes to the University of Portland and we were just up there to visit her. My grandson will be going there in the fall. So someone will be going up there. Glad to help you out, Ray Sent from my iPad > On Nov 29, 2014, at 10:22 AM, taildrags wrote: > > > Ray; this has nothing to do with a radiator from a P-51! It's kind of a slow holiday weekend though, and I don't know about your location but Medford is low and messy IFR so we're mostly indoors. > > Don't worry about the cataract surgery- my wife had both eyes done (with a few months between surgeries) and could not believe all that she had been missing when she looked out through the first new lens. > > You guys who are talking about going to visit Ray in Colusa, I have a favor to ask. Gary and Chris have been most gracious to have moved and stored my little Ultravair engine for all these months but I'm hoping that it can be shifted over to Ray's if he'll be headed up here to Oregon to visit his son. I'll be happy to pay fuel costs for moving it so I can get it in my hangar. > > Thanks. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435067#435067 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 29, 2014
Cliff, Do you happen to know how the wing was finished on this PIET? Just clear dop e? UV protection? Thanks, Ray Krause Ready to start covering SkyScout Sent from my iPad > On Nov 29, 2014, at 7:23 PM, Clif Dawson wrote: > > My apologies. I'm so bad. I thought I > was so clever finding this stuff that I > forgot to paste in the link!!! So here > it is. You'll have to scroll down a bit. > > http://forums.matronics.com/viewtopic.php?t=58665&start=0&postdays=0 &postorder=asc&highlight=&sid=39ef372d0a98a685fc403c5dd2d2b64b > > Bad Clif > > You cannot escape. Every day > a part of you turns to shit. > > I'm not getting the pictures that people are sending. Is it my computer/p rogram or what? Chuck > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Re: Jim Malley's Piet
Date: Nov 29, 2014
Wow, what a beauty! Excellent workmanship, and the whole visual scheme is very tasteful and reminiscent of the times. Great work, and great photos. But is it just me, or is the gap between rudder and vertical stabilizer quite large? Not at all being critical, just commenting. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435080#435080 ________________________________________________________________________________
Date: Nov 29, 2014
Looks great Jim and happy Thanks giving . My gas tank project sucks. Worked half a day soldering all the seams when I put water in it well you could have taken a shower under it. I think I will cut out the parts from aluminum, rivet them together then get a friend of my who can weld aluminum to put it together Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435081#435081 ________________________________________________________________________________
Date: Nov 29, 2014
No, sorry. There was an article in Kitplanes, I think. With this nasty move I'm involved in my home has turned into a house full of box's. That mag is in one of them. Somewhere. The paint info is probably in that article. Well, at least da plane has found a home. Clif Cliff, Do you happen to know how the wing was finished on this PIET? Just clear dope? UV protection? Thanks, Ray Krause Ready to start covering SkyScout ________________________________________________________________________________
Date: Nov 30, 2014
It was Jim's Piet that inspired my build. Sent from my iPad Jack Textor > On Nov 29, 2014, at 9:23 PM, "Clif Dawson" wrote: > > My apologies. I'm so bad. I thought I > was so clever finding this stuff that I > forgot to paste in the link!!! So here > it is. You'll have to scroll down a bit. > > http://forums.matronics.com/viewtopic.php?t=58665&start=0&postdays=0 &postorder=asc&highlight=&sid=39ef372d0a98a685fc403c5dd2d2b64b > > Bad Clif > > You cannot escape. Every day > a part of you turns to shit. > > I'm not getting the pictures that people are sending. Is it my computer/p rogram or what? Chuck > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Nov 30, 2014
What is the cylinder that's sticking out of the top left of the cowling? =97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97 =97=97=97=97 Jeffrey H. Boatright, PhD, FARVO Professor of Ophthalmology Emory University School of Medicine Sent from an iPad with a spelling problem On Nov 30, 2014, at 8:15 AM, "Jack" > wrote: It was Jim's Piet that inspired my build. Sent from my iPad Jack Textor On Nov 29, 2014, at 9:23 PM, "Clif Dawson" > wrote: My apologies. I'm so bad. I thought I was so clever finding this stuff that I forgot to paste in the link!!! So here it is. You'll have to scroll down a bit. http://forums.matronics.com/viewtopic.php?t=58665&start=0&postdays=0& postorder=asc&highlight=&sid=39ef372d0a98a685fc403c5dd2d2b64b Bad Clif You cannot escape. Every day a part of you turns to shit. I'm not getting the pictures that people are sending. Is it my computer/pr ogram or what? Chuck 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D com"> uildersbooks.com"> lp.com"> e.com"> .com/contribution"> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ww.matronics.com/Navigator?Pietenpol-List"> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Nov 30, 2014
...Oscar calls his bluff... Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of taildrags Sent: Saturday, November 29, 2014 2:32 PM Subject: Pietenpol-List: Re: Radiator from a P-51 ? --> Gary; if you'll be moving my engine in a twin Beech, I'll not only pay for the gas but I'll also drive down there, help you load it up, ride right seat to go drop it off, help you unload it, and then ride right seat back down after unloading it ;o) I would love to get a ride in one of those. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435074#435074 ________________________________________________________________________________
Date: Nov 30, 2014
Second the beautiful plane AND photos - wow....! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435096#435096 ________________________________________________________________________________
Date: Nov 30, 2014
What is the cylinder that's sticking out of the top left of the cowling? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435097#435097 ________________________________________________________________________________
Date: Nov 30, 2014
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 51, so don't reminde me! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2014
Thanks, Cliff. You should never move after you turn fifty, too much stuff! J ust airplane stuff is OK. RAY Krause Sent from my iPad > On Nov 29, 2014, at 10:52 PM, Clif Dawson wrote: > > No, sorry. There was an article in Kitplanes, I think. > With this nasty move I'm involved in my home has > turned into a house full of box's. That mag is in one of > them. Somewhere. The paint info is probably in that > article. > Well, at least da plane has found a home. > > Clif > Cliff, > > Do you happen to know how the wing was finished on this PIET? Just clear d ope? UV protection? > > Thanks, > > Ray Krause > Ready to start covering SkyScout > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Nov 30, 2014
Besides the sound of a "for real" engine vs. an electric motor, there is also the smell. I'm in a building of T-hangars and the hangar immediately behind mine is home to a Beech Duke. He will sometimes pull it straight out and start up the engines, and since the prop blast then goes through his hangar and into mine I get to enjoy the smell of burned avgas for a minute or so. It's a smell that I associate with airplanes, airports, and flying- and it is pleasant and distinctive. Every now and then I can smell it when I stick my head down into the front cockpit of my airplane after we've been flying, too. I can't imagine an electric motor ever making the beautiful blue cloud of smoke that a radial does when it lights off, either. If it does, it has reached TBO or the electric motor equivalent of it ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435181#435181 ________________________________________________________________________________
Date: Nov 30, 2014
Hey Oscar, Yes I am going to do that and it is also getting wheels and skiis for the winter, I have one more session to go in putting together my corvair engine, I am slowly working on everything trying hard not to be in a hurry, with the weather in St Paul that's not hard, plus working on my broken hangar door. Dick N ----- Original Message ----- From: "taildrags" <taildrags(at)hotmail.com> Sent: Saturday, November 29, 2014 12:12 PM Subject: Pietenpol-List: Re: Sky Scout > > Dick; do you plan to put your Sky Scout on those Muktuk floats? It would > likely be the first ever to fly. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435066#435066 > > > ________________________________________________________________________________
Date: Nov 30, 2014
Air cleaner. That's the one thing I think possibly could have been done a little more airplaney. Clif What is the cylinder that's sticking out of the top left of the cowling? =97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97=97 =97=97=97=97 Jeffrey H. Boatright, PhD, FARVO ________________________________________________________________________________
Date: Nov 30, 2014
Hmmmmm... maybe. But with the 'white' paint that could be an illusion. Clif > But is it just me, or is the gap between rudder and vertical stabilizer > quite large? Not at all being critical, just commenting. > Oscar Zuniga ________________________________________________________________________________
Date: Nov 30, 2014
I guess you're right... I just looked at one that I happen to have a side-on photo of, Chris Rusch's "MitsuPietshi" and it looks like the gap is about the same. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435200#435200 Attachments: http://forums.matronics.com//files/chrisr_163.jpg ________________________________________________________________________________
Subject: Jim Malley Kitplanes article.
Date: Dec 01, 2014
I have that article and would be glad to make copies if anyone wants them. Please contact me off list. Jim in Pryor Sent from my smartphone. ________________________________________________________________________________
Subject: "The Eagle has wings...!"
Date: Dec 01, 2014
Hello good Piet-ple, OK, that's an Apollo 11 quote but it seems appropriate...! Assembled all the major structural components for the first time yesterday. Now only a couple more years to go...!!!! I had three friends help with the wing panels and bolts - in 35 degree weather - THANK YOU to (L-R) Mike, Ron and Brian. (Brian is also building a Pietenpol in the Seattle area!) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435208#435208 Attachments: http://forums.matronics.com//files/piet_first_assy_1_267.jpg http://forums.matronics.com//files/piet_first_assy_2_179.jpg http://forums.matronics.com//files/piet_first_assy_3_117.jpg ________________________________________________________________________________
Subject: Re: Jim Malley Kitplanes article.
Date: Dec 01, 2014
Jim, I sure enjoyed seeing the progress on your plane, the covering really looks great. That will be my next job this winter, looking forward to it. Keep building, the winter is meant for building airplanes, especially when you don't have to even go outside to do it. Ray Krause Sent from my iPad > On Dec 1, 2014, at 3:55 AM, Jim Markle wrote: > > > I have that article and would be glad to make copies if anyone wants them. Please contact me off list. Jim in Pryor > > Sent from my smartphone. > > > > ________________________________________________________________________________
Date: Dec 01, 2014
Beautiful! Your wheels are even skinnier than mine! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of aerocarjake Sent: Monday, December 01, 2014 8:20 AM Subject: Pietenpol-List: "The Eagle has wings...!" --> Hello good Piet-ple, OK, that's an Apollo 11 quote but it seems appropriate...! Assembled all the major structural components for the first time yesterday. Now only a couple more years to go...!!!! I had three friends help with the wing panels and bolts - in 35 degree weather - THANK YOU to (L-R) Mike, Ron and Brian. (Brian is also building a Pietenpol in the Seattle area!) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435208#435208 Attachments: http://forums.matronics.com//files/piet_first_assy_1_267.jpg http://forums.matronics.com//files/piet_first_assy_2_179.jpg http://forums.matronics.com//files/piet_first_assy_3_117.jpg ________________________________________________________________________________
Subject: West Coast Piet Project for Sale :(
Date: Dec 01, 2014
Well, it looks like I will have to sell my Piet project instead of moving it to Tennessee. Sad day, but I will move my jigs and will keep the plans. I just can't afford to store it here, and we could use the money for moving expenses. The project is located in Fresno CA. It is a framed fuse with the side door modification. I made the fuse 2" deeper at the rear seat (I'm 6'4" tall and wanted to sit a bit deeper in the fuse), 2" wider from the nose to the rear seat, and 2" longer at the firewall to compensate some for the lighter Corvair motor. It has 2 coats of varnish over most of the fuse (underneath some of the struts it will need varnish) so another coat and you're ready to start mounting metal! I thought I had pics of it in it's current configuration, but I don't. It is in storage in Fresno, and currently I'm in TN. I built it well, as I planned on putting my life in it's rear seat one day. Speaking of metal, the control sticks, and rudder pedal assemblies are made and ready to mount when the varnish is completed. Looking for $500, and it's worth it. I will keep the plans for when I start here on version 2! I need to move on this pretty quick, so if you're interested, contact me below. I plan to be moved and settled before the end of the year... Mark Roberts 615-487-9784 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435212#435212 ________________________________________________________________________________
Subject: Re: West Coast Piet Project for Sale :(
Date: Dec 01, 2014
bummer... I had to step aside from the first Piet I started many years ago. It made me all the more happy to get back to a project later. Hope it finds a good home and a new life.... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435213#435213 ________________________________________________________________________________
Subject: Re: "The Eagle has wings...!"
Date: Dec 01, 2014
Very Impressive... I love the lines of the fuselage to that beautiful radial engine. What a nice job!!!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435214#435214 ________________________________________________________________________________
Date: Dec 01, 2014
Yes, it is no fun. Building is fun. Parting with what you built with love and care is no fun :( But, it helps to know others have "been there, done that!" Thanks! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435215#435215 ________________________________________________________________________________
Date: Dec 01, 2014
The Pietenpol is all about reducing drag - ha! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435216#435216 ________________________________________________________________________________
Date: Dec 01, 2014
Mark, I'm very sorry to hear that you need to abandon the project, but most definitely can identify. Aviation loses a lot of flavor when a person is financially challenged...I know that feeling all too well. Fall back, recoup, keep the dream! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mark Roberts Sent: Monday, December 01, 2014 10:06 AM Subject: Pietenpol-List: West Coast Piet Project for Sale :( --> Well, it looks like I will have to sell my Piet project instead of moving it to Tennessee. Sad day, but I will move my jigs and will keep the plans. I just can't afford to store it here, and we could use the money for moving expenses. The project is located in Fresno CA. It is a framed fuse with the side door modification. I made the fuse 2" deeper at the rear seat (I'm 6'4" tall and wanted to sit a bit deeper in the fuse), 2" wider from the nose to the rear seat, and 2" longer at the firewall to compensate some for the lighter Corvair motor. It has 2 coats of varnish over most of the fuse (underneath some of the struts it will need varnish) so another coat and you're ready to start mounting metal! I thought I had pics of it in it's current configuration, but I don't. It is in storage in Fresno, and currently I'm in TN. I built it well, as I planned on putting my life in it's rear seat one day. Speaking of metal, the control sticks, and rudder pedal assemblies are made and ready to mount when the varnish is completed. Looking for $500, and it's worth it. I will keep the plans for when I start here on version 2! I need to move on this pretty quick, so if you're interested, contact me below. I plan to be moved and settled before the end of the year... Mark Roberts 615-487-9784 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435212#435212 ________________________________________________________________________________
Date: Dec 01, 2014
Thanks Gary! You know too well what junk I've been through in Fresno with stinking Job layoffs! I had to get out of CA, and this Nashville job popped up and seemed to be divine intervention. Until today I have maintained that I was moving the project. But, I have had to look at it like I was talking to Dave Ramsey, the financial guy on the radio... the cost and the storage (not having a garage here or workshop) would quickly eat up the eventual replacement cost to just rebuild it. So... (sniff) it's available to someone that will finish her. Better if they are slightly oversized like me :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435218#435218 ________________________________________________________________________________
Date: Dec 01, 2014
I can store it indefinitely just south of chatt tn if that works for ya. I also have my Piet there flying, if you want to come down some day and get a ride or something. Also welcome to come visit in February when I'll be having a lot of Piet enthusiasts over for a weekend working on projects. There are several old woodworking machine enthusiasts in Nashville that are coming as well. All very talented woodworkers with very nice shops and tools, good guys to know. Tools. 423 580 1383 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435219#435219 ________________________________________________________________________________
Date: Dec 01, 2014
Mark, Keep me in mind if you don't get a response. I'm building a Sky Scout with an A-65. The wing is the same, as well as the tail structures. I might be able to use your fuselage to convert to an Air Camper configuration in the future. Would be nice to go back and forth. Thanks, Ray Krause Colusa, CA, Just a few hours North Sent from my iPad > On Dec 1, 2014, at 1:53 PM, Mark Roberts wrote: > > > Thanks Gary! You know too well what junk I've been through in Fresno with stinking Job layoffs! I had to get out of CA, and this Nashville job popped up and seemed to be divine intervention. Until today I have maintained that I was moving the project. But, I have had to look at it like I was talking to Dave Ramsey, the financial guy on the radio... the cost and the storage (not having a garage here or workshop) would quickly eat up the eventual replacement cost to just rebuild it. > > So... (sniff) it's available to someone that will finish her. Better if they are slightly oversized like me :D > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435218#435218 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 01, 2014
Oh, now why didn't you remind me that you were using a radial? LOVE IT!!! What a beautiful assembly! It will definitely NOT be a matter of years till it flies. All you have now is covering, finishing, and paperwork and it'll be ready to fire up and taxi test! Summer 2015... -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435224#435224 ________________________________________________________________________________
Date: Dec 01, 2014
Jake; also curious to know roughly how much weight is on the tail stand when you set it up in the 3-point attitude with that radial on the nose (is that an R2800 Rotec Radial?) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435225#435225 ________________________________________________________________________________
Subject: Toolstock date change. 26 Feb - 1 mar
Date: Dec 02, 2014
Should increase the odds of good weather... The runway is in good shape, got some landings in yesterday. Should have more home building mentors there this year. Cheers, Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435233#435233 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: the Eagle
Date: Dec 02, 2014
Wow, what a gorgeous plane!! Maybe flying this year?? Douwe ________________________________________________________________________________
Date: Dec 02, 2014
Thanks Guys! I will keep ya'll in mind as I move forward. I'd still like to move it, but if I can't sell before I move, and moving it is too expensive, then I can probably store it at a friend's warehouse there in Fresno, and continue to market it. Or, the heaven's open up and I get a way to move it here eventually :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435239#435239 ________________________________________________________________________________
Date: Dec 02, 2014
It's a standing offer, and free if it wasn't obvious. Just let me know if/when/how I can help. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435240#435240 ________________________________________________________________________________
Date: Dec 02, 2014
Bless you brother! I appreciate that, and hope to meet before too long. I love Tennessee so far, and hope to make it my home for good! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435241#435241 ________________________________________________________________________________
Subject: Re: the Eagle
Date: Dec 02, 2014
Thanks for the positive comments/feedback - it really helps.... OK, so I dont really want to make a list or have a schedule (that would feel too much like WORK) but...... I have remaining (in no particular order): build a fuel tank from scratch, build an oil tank from scratch, build the wing struts, build the jury struts and all connections, build the aileron horns, revise the ailerons to piano hinges, complete the landing-gear/springs structure, add brackets to hold the brake calipers in position on the landing-gear legs, complete the secondary structure for the center section, complete the internal bracing in the wings, build the sheet-metal engine cowling(!), get upholstery done for the two seats, purchase/install the engine instruments & XPDR & COM, do all the engine accessory installations(!), complete the tail-wheel assembly mounts, get the wheel rims drilled to match the hubs & have the wheel assemblies powder coated and then spoke-laced, wire/plumb all the instruments, have "Applied Finishing" in Seattle sand-blast and paint the fuselage truss, build the windscreens, build/install the throttle quadrant, create the VOR and ELT antenna mounts, have "Columbia Airmotive" make the remaining control cables, make the control cables for the wing bracing, create and run all the fuel systems, complete the wiring, order the propeller from ROTEC, cover the structure, paint the airplane, and then I should be fairly close! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435242#435242 ________________________________________________________________________________
Date: Dec 02, 2014
Don't forget the W&B Jake. Outstanding work! Sent from my iPad Jack Textor > On Dec 2, 2014, at 11:43 AM, "aerocarjake" wrote: > > > Thanks for the positive comments/feedback - it really helps.... > > OK, so I dont really want to make a list or have a schedule (that would feel too much like WORK) but...... > > I have remaining (in no particular order): build a fuel tank from scratch, build an oil tank from scratch, build the wing struts, build the jury struts and all connections, build the aileron horns, revise the ailerons to piano hinges, complete the landing-gear/springs structure, add brackets to hold the brake calipers in position on the landing-gear legs, complete the secondary structure for the center section, complete the internal bracing in the wings, build the sheet-metal engine cowling(!), get upholstery done for the two seats, purchase/install the engine instruments & XPDR & COM, do all the engine accessory installations(!), complete the tail-wheel assembly mounts, get the wheel rims drilled to match the hubs & have the wheel assemblies powder coated and then spoke-laced, wire/plumb all the instruments, have "Applied Finishing" in Seattle sand-blast and paint the fuselage truss, build the windscreens, build/install the throttle quadrant, create the VOR and ELT antenna! > mounts, have "Columbia Airmotive" make the remaining control cables, make the control cables for the wing bracing, create and run all the fuel systems, complete the wiring, order the propeller from ROTEC, cover the structure, paint the airplane, and then I should be fairly close! > > -------- > Jake Schultz - curator, > Newport Way Air Museum (OK, it's just my home) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435242#435242 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 02, 2014
thx.... I have not yet finished the leading edge of the center section - which will just be "normal secondary structure" not a fuel tank in the leading edge area. I will have a center section tank - without a header tank - which is why I made my center section wider than plans. I might have a small storage area BEHIND the rear spar of the center section...?!?? I don't have too many weight numbers yet. I was going to do some W&B measurements after we did the strut work this past weekend - but it was 35 degrees so I thought that could wait. (Didn't want to "push it" with my help on a chilly day!) See a related post for project the "next steps"... :-) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435244#435244 ________________________________________________________________________________
Date: Dec 02, 2014
Yep, I have done some "high level" W&B already..... .....also can't forget the EAA Tech Visits (one scheduled in a couple weeks and with additional visits as I get closer to flight) .....and the ever phunn FAA paperwork. (It will be registered: N507N ) Oh, and the flying to get my skills up. ....and the "secret" nose art :-) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435246#435246 ________________________________________________________________________________
Subject: Pietenpol in Print
Date: Dec 02, 2014
The December issue of Sport Aviation features an article on the Allen Rudolph Piet. Even made the cover. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435252#435252 Attachments: http://forums.matronics.com//files/sa1214_111.jpg ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: for you Continental guys
Date: Dec 03, 2014
Infidels, countrymen, Piet enthusiasts, Received some refurbished parts back from Aircraft Engine & Accessory http://www.aea-precision.com/ this week for my A-65 major overhaul and th e gent who helped me refurbish my original engine told me that the connecting rod bolts and nuts are a one-time use item. I had forgotten that. Originally I asked Greg at AEA to magnaflux the rod bolts and nuts so I cou ld reuse them and that is when he told me they never reuse rod bolts on any aircraft engine. Nice to know. I used new rod bolts in my original engine rebuilt but thought I could get away with reusing these..... not a good idea! Mike C. [cid:image001.jpg(at)01D00EF6.8B9F7010] ________________________________________________________________________________
Date: Dec 03, 2014
I remember that someone on this list had rod bolts at a good price and were taking some to Brodhead. Maybe they will read this and repost them for sale. Barry Davis NX973BP From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC] Sent: Wednesday, December 03, 2014 12:42 PM Subject: Pietenpol-List: for you Continental guys Infidels, countrymen, Piet enthusiasts, Received some refurbished parts back from Aircraft Engine & Accessory http://www.aea-precision.com/ this week for my A-65 major overhaul and the gent who helped me refurbish my original engine told me that the connecting rod bolts and nuts are a one-time use item. I had forgotten that. Originally I asked Greg at AEA to magnaflux the rod bolts and nuts so I could reuse them and that is when he told me they never reuse rod bolts on any aircraft engine. Nice to know. I used new rod bolts in my original engine rebuilt but thought I could get away with reusing these... not a good idea! Mike C. ________________________________________________________________________________
Subject: Re: Pietenpol in Print
Date: Dec 03, 2014
Cool...!!! I've been pinging EAA with feedback to return a greater focus on HOMEBUILTS. I'm just one voice in the wind but apparently I am not the only one who feels this way as they have had LOTS of similar requests. Lately SPORT AVIATION feels like reading FLYING magazine (not surprising as EAA hired their editor) and if I wanted to read FLYING magazine I would buy FLYING magazine. I want to read about HOMEBUILTS...! IMHO -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435266#435266 ________________________________________________________________________________
Subject: Federal Aviation Skis for sale
Date: Dec 03, 2014
A friend in my EAA chapter, who recently moved to TX from IL, has a MINT set of Federal Aviation Skis from the early to mid 1940's. These are the correct skis for J-3's, along with many other 2 seat aircraft from the period. Model # for the skis is 1500. Skis of this period had no wheels, therefore, one needs to have snow in order to take off / land... When I get a chance, we'll take pictures and post them here, unless someone jumps on them right away. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435271#435271 ________________________________________________________________________________
Date: Dec 03, 2014
Subject: Re: Federal Aviation Skis for sale
I want!!! For my Piet! On Dec 3, 2014 3:27 PM, "tkreiner" wrote: > > A friend in my EAA chapter, who recently moved to TX from IL, has a MINT > set of Federal Aviation Skis from the early to mid 1940's. > > These are the correct skis for J-3's, along with many other 2 seat > aircraft from the period. Model # for the skis is 1500. > > Skis of this period had no wheels, therefore, one needs to have snow in > order to take off / land... > > When I get a chance, we'll take pictures and post them here, unless > someone jumps on them right away. > > -------- > Tom Kreiner > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435271#435271 > > ________________________________________________________________________________
Date: Dec 03, 2014
I have large dia. Axles..(Super Cub?), but I think spacers available On Dec 3, 2014 3:27 PM, "tkreiner" wrote: > > A friend in my EAA chapter, who recently moved to TX from IL, has a MINT > set of Federal Aviation Skis from the early to mid 1940's. > > These are the correct skis for J-3's, along with many other 2 seat > aircraft from the period. Model # for the skis is 1500. > > Skis of this period had no wheels, therefore, one needs to have snow in > order to take off / land... > > When I get a chance, we'll take pictures and post them here, unless > someone jumps on them right away. > > -------- > Tom Kreiner > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435271#435271 > > ________________________________________________________________________________
Subject: Flying and Sport Aviation
Date: Dec 03, 2014
Glad you have been pinging EAA Jake about their publication becoming more a nd more like Flying. I went round and round with J. Mac McClellan via e-mail a few months ago af ter one of his articles in Sport Aviation made the ridiculous claim that basic VFR navigation using a sectional and a track were pretty much a waste anymore. We spit nickels back and forth for a while so perhaps EAA is hearing that w e don't believe the publication should be what it was starting to become. Mike C. ________________________________________________________________________________
Subject: Re: Flying and Sport Aviation
Date: Dec 03, 2014
Good stuff Mike..... You must be one of the myriad of folks who have been relaying those comments. I know there is much more to EAA than homebuilts but that should always (IMHO) be their core.....! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435282#435282 ________________________________________________________________________________
Date: Dec 03, 2014
You are not the only person who feels this way!!!! I am also in the Biplane Forum and most of them feel the same way. The magazine needs a lot more hands on and homebuilt plane articles. -------- Building steel fuselage aircamper. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435293#435293 ________________________________________________________________________________
Date: Dec 04, 2014
Perhaps someone could write a passionate message in the 'all groups' in this and other lists? There must be a way to convince any editor to change his ways. Btw, the same is happening in electronics magazines. Years ago, it was filled with schema's and building descriptions for amplifiers and the lot, these days its more and more reviews on gadgets... On Thu, Dec 4, 2014 at 8:21 AM, biplan53 wrote: > > You are not the only person who feels this way!!!! I am also in the > Biplane Forum and most of them feel the same way. The magazine needs a lot > more hands on and homebuilt plane articles. > > -------- > Building steel fuselage aircamper. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435293#435293 > > ________________________________________________________________________________
Subject: First Run Of My Engine
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Dec 04, 2014
Just wanted to post a link to YouTube showing the first run of my engine- http://www.youtube.com/watch?v=0QVBRCKk5_E William Wynne helped me get it up and running. A lot of work had to be done to the engine as we rebuilt it, but it ran great. 2000 rpm for 30 minutes and no leak was found after shutdown. Many thanks to William. Also a big thanks to Dan Weseman for helping with the fifth bearng adjustment. I encourage you to look at the Corvair as your flight engine. Corvair College 32 in Texas is coming up soon. So think about attending. You will be glad you did! -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435298#435298 Attachments: http://forums.matronics.com//files/image_612.jpg ________________________________________________________________________________
Date: Dec 04, 2014
Subject: Re: First Run Of My Engine
Awesome! =C2- Keith ----- Original Message ----- From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com> Sent: Thursday, December 4, 2014 4:02:39 AM Subject: Pietenpol-List: First Run Of My Engine ail.com> Just wanted to post a link to YouTube showing the first run of my engine- http://www.youtube.com/watch?v=0QVBRCKk5_E William Wynne helped me get it up and running. A lot of work had to be done to the engine as we rebuilt it, but it ran great. 2000 rpm for 30 minutes and no leak was found after shutdown. Many thanks to William. Also a big thanks to Dan Weseman for helping with t he fifth bear=C3=83=C2=AEng adjustment. I encourage you to look at the Corv air as your flight engine. Corvair College 32 in Texas is coming up soon. S o think about attending. You will be glad you did! -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435298#435298 Attachments: http://forums.matronics.com//files/image_612.jpg =========== =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== =========== MS - =========== ________________________________________________________________________________
Date: Dec 04, 2014
How much for the ski's? Do they include all the fitting too. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435305#435305 ________________________________________________________________________________
Date: Dec 04, 2014
Sounds good and smooth, Terry! Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jarheadpilot82 Sent: Thursday, December 04, 2014 4:03 AM Subject: Pietenpol-List: First Run Of My Engine Just wanted to post a link to YouTube showing the first run of my engine- http://www.youtube.com/watch?v=0QVBRCKk5_E William Wynne helped me get it up and running. A lot of work had to be done to the engine as we rebuilt it, but it ran great. 2000 rpm for 30 minutes and no leak was found after shutdown. Many thanks to William. Also a big thanks to Dan Weseman for helping with the fifth bearng adjustment. I encourage you to look at the Corvair as your flight engine. Corvair College 32 in Texas is coming up soon. So think about attending. You will be glad you did! -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435298#435298 Attachments: http://forums.matronics.com//files/image_612.jpg ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Dec 04, 2014
Good job Terry. It really feeds the building fire within every time you reach a big milestone like this one. Keep it up. Cheers, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435309#435309 ________________________________________________________________________________
Date: Dec 04, 2014
Awesome - a live thing of beauty...!! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435310#435310 ________________________________________________________________________________
Date: Dec 04, 2014
Great job! Vroom! Vroom! and Pocketa-Pocketa! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435311#435311 ________________________________________________________________________________
Subject: Warp Drive Prop Alert
Date: Dec 04, 2014
If you are interested in the Warp Drive prop or know someone who is, you should read this posting by William Wynne- http://flycorvair.net/2014/12/04/warp-drive-prop-source-warning-hoverhawk/ There is a company masquerading as the factory, and you could be dealing with someone on the internet that you do not want to deal with. Just wanted to pass it along. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435314#435314 ________________________________________________________________________________
Date: Dec 04, 2014
Congratulations on the 1st run!! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jarheadpilot82 Sent: Thursday, December 04, 2014 1:03 AM Subject: Pietenpol-List: First Run Of My Engine --> Just wanted to post a link to YouTube showing the first run of my engine- http://www.youtube.com/watch?v=0QVBRCKk5_E William Wynne helped me get it up and running. A lot of work had to be done to the engine as we rebuilt it, but it ran great. 2000 rpm for 30 minutes and no leak was found after shutdown. Many thanks to William. Also a big thanks to Dan Weseman for helping with the fifth bearng adjustment. I encourage you to look at the Corvair as your flight engine. Corvair College 32 in Texas is coming up soon. So think about attending. You will be glad you did! -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435298#435298 Attachments: http://forums.matronics.com//files/image_612.jpg ________________________________________________________________________________
Date: Dec 05, 2014
From: "Charles N. Campbell" <charlescampbell1924(at)gmail.com>
You need to like WW2 airplanes and $500,000-dollar speed merchants to read the EAA mag. Or have they changed? I haven't read an EAA mag in several years for that very reason. Chuck On Wed, Dec 3, 2014 at 2:13 PM, aerocarjake wrote: > > > > Cool...!!! > > I've been pinging EAA with feedback to return a greater focus on > HOMEBUILTS. > > I'm just one voice in the wind but apparently I am not the only one who > feels this way as they have had LOTS of similar requests. > > Lately SPORT AVIATION feels like reading FLYING magazine (not surprising > as EAA hired their editor) and if I wanted to read FLYING magazine I would > buy FLYING magazine. I want to read about HOMEBUILTS...! > > IMHO > > -------- > Jake Schultz - curator, > Newport Way Air Museum (OK, it's just my home) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435266#435266 > > ________________________________________________________________________________
Subject: Getting Started Again
Date: Dec 05, 2014
Well after a move and about a year, finally getting started on the Piet again. It's been tough finding (and remembering) where everything is and where I left off. Looking forward to moving forward. Excuse the incorrect hardware. Does anybody have a good source for the hardware? Should it be brass? Thanks! Jack Textor West Des Moines, IA ________________________________________________________________________________
Subject: Re: Getting Started Again
Date: Dec 05, 2014
Jack, Beautiful panel! Looks like you might be planning on IFR, how much fuel will you be carrying? Nice to see you building again, Ray Krause Sent from my iPad > On Dec 5, 2014, at 2:53 PM, Jack wrote: > > Well after a move and about a year, finally getting started on the Piet ag ain. It's been tough finding (and remembering) where everything is and wher e I left off. Looking forward to moving forward. Excuse the incorrect hard ware. Does anybody have a good source for the hardware? Should it be brass ? > > Thanks! > > <<...>> > > Jack Textor > > West Des Moines, IA > > > > > ________________________________________________________________________________
Date: Dec 05, 2014
Jack, Is that one of those Russian automatic mechanical clocks out of a MIG 23 ? Please identify... Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435399#435399 ________________________________________________________________________________
Date: Dec 06, 2014
Yes it is Dan, they were used on various models, heated, operable to 100,000 feet and 6Gs. Two day movement. Just what a Piet needs! Works well. Sent from my iPad Jack Textor > On Dec 5, 2014, at 10:31 PM, "dwilson" wrote: > > > Jack, Is that one of those Russian automatic mechanical clocks out of a MIG 23 ? Please identify... > > Dan > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435399#435399 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 06, 2014
Beautiful panel. Yes Jack that hardware should be brass. Then it will be curmudgeon-approved. Available (of course) from Mcmas terCarr. Love the clock also.=0A=0A=0ADan Helsper=0ALoensloe Airfiel d=0APuryear, TN=0A=0A=0A-----Original Message-----=0AFrom: Jack <jack@te xtors.com>=0ATo: pietenpol-list =0ASent: Fri , Dec 5, 2014 4:55 pm=0ASubject: Pietenpol-List: Getting Started Again=0A=0A=0A=0AWell after a move and about a year, finally getting started on the Piet again. It's been tough finding (and remembering) where everything is and where I left off. Looking forward to moving forward. Excuse the incorrect ha rdware. Does anybody have a good source for the hardware? Should it be brass?=0AThanks!=0A <<...>> =0AJack Textor=0AWest Des Moines, IA=0A=0A=0A=0A=0A=0A=0A ________________________________________________________________________________
Date: Dec 06, 2014
Ray 11 gallons in the center section and a cub nose tank which I have not ca lculated its volume. Know it's overkill... Sent from my iPad Jack Textor > On Dec 5, 2014, at 9:46 PM, Ray Krause wrote: > > Jack, > > Beautiful panel! Looks like you might be planning on IFR, how much fuel wi ll you be carrying? > > Nice to see you building again, > > Ray Krause > > Sent from my iPad > >> On Dec 5, 2014, at 2:53 PM, Jack wrote: >> >> Well after a move and about a year, finally getting started on the Piet a gain. It's been tough finding (and remembering) where everything is and whe re I left off. Looking forward to moving forward. Excuse the incorrect har dware. Does anybody have a good source for the hardware? Should it be bras s? >> >> Thanks! >> >> <<...>> >> >> Jack Textor >> >> West Des Moines, IA >> >> >> >> >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Dec 06, 2014
The Rudolph Piet just goes to prove that Ford powered Piets can fly on and on and on! As far as the EAA, I quit the association some years ago when the flagship publication (the main reason I joined EAA 35 years ago) featured "homebuilts" that cost in the six figures, green tractors, and other things that did not interest me or reflect what I consider to be experimental aviation. The one shining star in the EAA line of publications has been the "Hints for Homebuilders" series of video clips. THAT is real stuff, by real people, for real people. Yes, they have a few "factory people" in some of the videos, but they are sharing valuable skills and information. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435424#435424 ________________________________________________________________________________
Date: Dec 06, 2014
Jack; You'll find that the layer of dust and rust on your building skills is pretty thin and it wipes off easily. Glad you're back in the shop! To elaborate a bit on what Dan said about panel hardware, it's because of the mag compass that brass (or nonferrous) hardware is recommended. Ferrous metal in proximity to the compass can affect it. I don't see your mag compass in the picture, so maybe if you have it located on the underside of the wing it won't matter if you don't use brass hardware on your panel. I think brass would enhance the already very attractive look of the panel though. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435425#435425 ________________________________________________________________________________
Date: Dec 06, 2014
Jake; Not sure what you have in mind for the nose art for your airplane, but several of us have had very good results working with Dennis Demeter at Avgrafix. http://www.avgrafix.com/ His work is excellent and his prices are reasonable for custom graphics. Matter of fact, Denny is making me some vinyl graphics for the two kayaks that I'm building for my wife and I. Also secret, but I hope to unveil them in time to go paddling next spring. A lot of Piet building skills translate directly over to boat-building, too. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435426#435426 ________________________________________________________________________________
Date: Dec 06, 2014
Hi all I agree with points made about changes at EAA. They've (we've) become more and more corporate over the years. I don't like the fact that 6 figure aircraft are promoted or reviewed either. I think a lot of it stems from people wanting instant airplane,quick build, high performance stuff which is way beyond many (my) budgets. On the other hand, EAA has led the way to many positive changes as far as FAA regs regarding GA. Also, where else can I get assistance from a recognized Tech. Counsellor? I feel that even considering the negative aspects we are a great organization. Glen Schweizer EAA#1133012 Sent from my iPhone > On Dec 6, 2014, at 10:38 AM, "taildrags" wrote: > > > The Rudolph Piet just goes to prove that Ford powered Piets can fly on and on and on! > > As far as the EAA, I quit the association some years ago when the flagship publication (the main reason I joined EAA 35 years ago) featured "homebuilts" that cost in the six figures, green tractors, and other things that did not interest me or reflect what I consider to be experimental aviation. The one shining star in the EAA line of publications has been the "Hints for Homebuilders" series of video clips. THAT is real stuff, by real people, for real people. Yes, they have a few "factory people" in some of the videos, but they are sharing valuable skills and information. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435424#435424 > > > > > > > > > > ________________________________________________________________________________
From: "Dennis Engelkenjohn" <mushface1(at)gmail.com>
Date: Dec 06, 2014
The "Experimenter" was more to my liking. It is still online, but apparently most members are not interested in real homebuilding anymore. When I tell people I am building a Pietenpol the first question is: "Where did you get your kit?" I guess most people interested in aviation now are of the carriage trade and several hundred thousand dollars is peanuts and so the EAA caters to them. At least that was the feeling I got since Paul Poberezny hated ultralights so much. I assume the EAA knows their target market better than I do. Dennis -----Original Message----- From: taildrags Sent: Saturday, December 06, 2014 12:38 PM Subject: Pietenpol-List: Re: Pietenpol in Print The Rudolph Piet just goes to prove that Ford powered Piets can fly on and on and on! As far as the EAA, I quit the association some years ago when the flagship publication (the main reason I joined EAA 35 years ago) featured "homebuilts" that cost in the six figures, green tractors, and other things that did not interest me or reflect what I consider to be experimental aviation. The one shining star in the EAA line of publications has been the "Hints for Homebuilders" series of video clips. THAT is real stuff, by real people, for real people. Yes, they have a few "factory people" in some of the videos, but they are sharing valuable skills and information. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435424#435424 ________________________________________________________________________________
Date: Dec 06, 2014
Sent from my iPhone Begin forwarded message: > From: glenschweizer(at)yahoo.com > Date: December 6, 2014 at 11:16:39 AM PST > To: "pietenpol-list(at)matronics.com" > Subject: Re: Pietenpol-List: Re: Pietenpol in Print > > Hi all > I agree with points made about changes at EAA. They've (we've) become mor e and more corporate over the years. I don't like the fact that 6 figure ai rcraft are promoted or reviewed either. I think a lot of it stems from peop le wanting instant airplane,quick build, high performance stuff which is way beyond many (my) budgets. > On the other hand, EAA has led the way to many positive changes as far a s FAA regs regarding GA. Also, where else can I get assistance from a recog nized Tech. Counsellor? > I feel that even considering the negative aspects we are a great organ ization. Glen Schweizer > EAA#1133012 > Sent from my iPhone > >> On Dec 6, 2014, at 10:38 AM, "taildrags" wrote: >> >> >> The Rudolph Piet just goes to prove that Ford powered Piets can fly on an d on and on! >> >> As far as the EAA, I quit the association some years ago when the flagshi p publication (the main reason I joined EAA 35 years ago) featured "homebuil ts" that cost in the six figures, green tractors, and other things that did n ot interest me or reflect what I consider to be experimental aviation. The o ne shining star in the EAA line of publications has been the "Hints for Hom ebuilders" series of video clips. THAT is real stuff, by real people, for r eal people. Yes, they have a few "factory people" in some of the videos, bu t they are sharing valuable skills and information. >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=435424#435424 >> >> >> >> >> >> >> ========================== ========= ========================== ========= ========================== ========= ========================== ========= >> >> >> ________________________________________________________________________________
From: "=?utf-8?B?c3RldmVuLmQuZG9ydGNoQGdtYWlsLmNvbQ==?=" <steven.d.dortch(at)gmail.com>
Subject: =?utf-8?B?UmU6IFBpZXRlbnBvbC1MaXN0OiBSZTogdGhlIEVhZ2xl?
Date: Dec 06, 2014
S2F5YWsgb3IgZ3JhcGhpY3MgYXJlIHNlY3JldD8gUmVtZW1iZXIgaW4gdGhlIEdSVCB3ZSBqdXN0 IGdvIHR1YmluZywgeW91IGNhbid0IGRyaW5rIGJlZXIgd2hpbGUgeW91IGFyZSBwYWRkbGluZyBh IGtheWFrLgoKQmx1ZSBza2llcywgClN0ZXZlIEQKCgpGcm9tIG15IEhUQyBTZW5zYXRpb24gNEcg b24gVC1Nb2JpbGUuIFRoZSBmaXJzdCBuYXRpb253aWRlIDRHIG5ldHdvcmsKCi0tLS0tIFJlcGx5 IG1lc3NhZ2UgLS0tLS0KRnJvbTogInRhaWxkcmFncyIgPHRhaWxkcmFnc0Bob3RtYWlsLmNvbT4K VG86IDxwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPgpTdWJqZWN0OiBQaWV0ZW5wb2wtTGlz dDogUmU6IHRoZSBFYWdsZQpEYXRlOiBTYXQsIERlYyA2LCAyMDE0IDEyOjQ5CgoKLS0+IFBpZXRl bnBvbC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAidGFpbGRyYWdzIiA8dGFpbGRyYWdzQGhvdG1h aWwuY29tPgoKSmFrZTsKCk5vdCBzdXJlIHdoYXQgeW91IGhhdmUgaW4gbWluZCBmb3IgdGhlIG5v c2UgYXJ0IGZvciB5b3VyIGFpcnBsYW5lLCBidXQgc2V2ZXJhbCBvZiB1cyBoYXZlIGhhZCB2ZXJ5 IGdvb2QgcmVzdWx0cyB3b3JraW5nIHdpdGggRGVubmlzIERlbWV0ZXIgYXQgQXZncmFmaXguICBo dHRwOi8vd3d3LmF2Z3JhZml4LmNvbS8gICBIaXMgd29yayBpcyBleGNlbGxlbnQgYW5kIGhpcyBw cmljZXMgYXJlIHJlYXNvbmFibGUgZm9yIGN1c3RvbSBncmFwaGljcy4gIE1hdHRlciBvZiBmYWN0 LCBEZW5ueSBpcyBtYWtpbmcgbWUgc29tZSB2aW55bCBncmFwaGljcyBmb3IgdGhlIHR3byBrYXlh a3MgdGhhdCBJJ20gYnVpbGRpbmcgZm9yIG15IHdpZmUgYW5kIEkuICBBbHNvIHNlY3JldCwgYnV0 IEkgaG9wZSB0byB1bnZlaWwgdGhlbSBpbiB0aW1lIHRvIGdvIHBhZGRsaW5nIG5leHQgc3ByaW5n LiAgQSBsb3Qgb2YgUGlldCBidWlsZGluZyBza2lsbHMgdHJhbnNsYXRlIGRpcmVjdGx5IG92ZXIg dG8gYm9hdC1idWlsZGluZywgdG9vLgoKLS0tLS0tLS0KT3NjYXIgWnVuaWdhCk1lZGZvcmQsIE9S CkFpciBDYW1wZXIgTlg0MUNDICZxdW90O1Njb3V0JnF1b3Q7CkE3NSBwb3dlcgoKCgoKUmVhZCB0 aGlzIHRvcGljIG9ubGluZSBoZXJlOgoKaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0 b3BpYy5waHA/cD00MzU0MjYjNDM1NDI2CgoKCgoKCgpfLT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0KXy09ICAgICAgIC0tIFBs ZWFzZSBTdXBwb3J0IFlvdXIgTGlzdHMgVGhpcyBNb250aCAtLQpfLT0gICAgICAgICAgIChBbmQg R2V0IFNvbWUgQVdFU09NRSBGUkVFIEdpZnRzISkKXy09Cl8tPSAgIE5vdmVtYmVyIGlzIHRoZSBB bm51YWwgTGlzdCBGdW5kIFJhaXNlci4gIENsaWNrIG9uCl8tPSAgIHRoZSBDb250cmlidXRpb24g bGluayBiZWxvdyB0byBmaW5kIG91dCBtb3JlIGFib3V0Cl8tPSAgIHRoaXMgeWVhcidzIFRlcnJp ZmljIEZyZWUgSW5jZW50aXZlIEdpZnRzIHByb3ZpZGVkCl8tPSAgIGJ5OgpfLT0gICAKXy09ICAg ICAqIEFlcm9FbGVjdHJpYyB3d3cuYWVyb2VsZWN0cmljLmNvbQpfLT0gICAgICogVGhlIEJ1aWxk ZXIncyBCb29rc3RvcmUgd3d3LmJ1aWxkZXJzYm9va3MuY29tCl8tPSAgICAgKiBIb21lYnVpbHRI RUxQIHd3dy5ob21lYnVpbHRoZWxwLmNvbQpfLT0gICAgICogTXkgUGlsb3QgU3RvcmUgd3d3Lm15 cGlsb3RzdG9yZS5jb20KXy09ICAgICAqIFJhY2UgQ29uc3VsdGluZyB3d3cubXJyYWNlLmNvbQpf LT0KXy09ICAgTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGU6Cl8tPQpfLT0gICAtLT4gaHR0cDov L3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT0KXy09ICAgVGhhbmsgeW91IGZvciB5 b3VyIGdlbmVyb3VzIHN1cHBvcnQhCl8tPQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgLSBUaGUg UGlldGVucG9sLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBG ZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBz dWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9h ZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNo IG1vcmU6Cl8tPQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Q aWV0ZW5wb2wtTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VC IEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBX ZWIgRm9ydW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0K Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0KCgoK ________________________________________________________________________________
Date: Dec 06, 2014
Graphics are secret, kayaks are definitely NOT! I am very pleased to recommend and promote the skin-on-frame kayaks and boats designed by Dave Gentry. Simple to build, affordable, well documented and tested, and beautiful boats. http://gentrycustomboats.com/home.html . I'm building a pair of Chuckanut 12 kayaks and I also plan to build a Shenandoah Whitehall rowboat for our friends up in Washington who have two young daughters and will soon need to have a way to take the girls and all their camping gear out to the small uninhabited islands in Rosario Strait to show them the beauty of the whole Puget Sound island region from a sturdy rowboat and by the side of a campfire. They already have ocean kayaks, but now with the children and gear they will need a rowboat! Keeps you fit, too, and lets you teach navigation and seamanship while you pull-pull-pull on the oars with your children in the boat and orcas keeping you company. The only reason this is even vaguely aviation-related is that the skin-on-frame construction technique uses wood framing with heat-shrunk fabric covering, and rather than sewing and stapling the fabric on our kayaks, I plan to use Poly-Tak to cement the fabric to the frames and finishing tapes to complete the overlaps and seams after heat-tautening the fabric with my covering irons. Might even fill the flotation compartments fore and aft with ping-pong balls or empty milk cartons ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435446#435446 ________________________________________________________________________________
Date: Dec 07, 2014
Subject: E-LSA reregistration?
We've had a situation develop on our local airport. An older gentleman had a mishap flying his J-3. The airplane has been in his family over 60 years, and he actually soloed in it 60 years ago. He has thousands of flight hours and is a former ATP. During the mishap his landing gear struck a runway sign and collapsed. The landing gear was the only thing damaged, so whether this was an accident is open to interpretation. However, the FAA was notified by the mechanic that helped remove the aircraft from the runway. The FAA is asking the pilot have a test-flight with an FAA examiner, which I can understand due to his age, etc. They also dinged him because he was flying as a sport pilot in his J-3 with its original registration as a standard class airplane. They claim it is necessary to re-register the airplane as light sport in order to fly it as a light sport pilot. I have been flying my Pietenpol for 5 years as using light sport pilot rules, and although I remember I had the option to register it as E-LSA, the conventional wisdom at the time was Experimental Amateur Built was the way to go. I've searched the FAA regs and can't find any clarification. Has anyone else out there heard of a push to re-register as E-LSA to make an aircraft eligible for light sport pilots? Ben Charvet 235 hrs on NX866BC sitting on my DL medical ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Subject: Re: E-LSA reregistration?
Date: Dec 07, 2014
SeKAmW0gc29ycnkgdG8gaGVhciBvZiB5b3VyIGFjcXVhaW50YW5jZeKAmXMgbWlzaGFwLg0KDQpB cyBsb25nIGFzIHRoZSBDdWIgaGFzIGFsd2F5cyBtZXQgdGhlIGRlZmluaXRpb24gb2YgYW4gTFNB LCBwZXIgdGhlIEZBUnMgKGkuZS4sIGdyb3NzIHdlaWdodCBiZWxvdyAxMzIwIGxicywgbm8gbW9y ZSB0aGFuIHR3byBzZWF0cywgZXRjLiksIHRoZW4gaXQgY2FuIGJlIGZsb3duIGJ5IGEgcGlsb3Qg d2hvIHF1YWxpZmllcyBhcyBhIFNwb3J0IFBpbG90Lg0KDQpJIGhhdmUgbm90IGhlYXJkIG9mIGFu eSBwdXNoIGZvciByZS1yZWdpc3RyYXRpb24uIEluZGVlZCwgSSBkb27igJl0IHNlZSBob3cgdGhh dCB3b3VsZCBiZSBwb3NzaWJsZSB3aXRoaW4gdGhlIGN1cnJlbnQgRkFScy4gV2hhdCBGU0RPIGFy ZSB3ZSBkZWFsaW5nIHdpdGggaGVyZT8gUmVnYXJkbGVzcywgSU1PLCB0aGUgb2xkZXIgZ2VudCBz aG91bGQgY2FsbCBGQUEgaW4gT0tDIOKAkyB3aXRob3V0IHRoZSBsb2NhbCBGU0RPIGJlaW5nIG9u IHRoZSBsaW5lLiBIZSBzaG91bGQgYWxzbyBjYWxsIEVBQSBhbmQgQU9QQSwgZXZlbiBpZiBoZeKA mXMgbm90IGEgbWVtYmVyLg0KDQotLQ0KSmVmZnJleSBILiBCb2F0cmlnaHQsIFBoRCwgRkFSVk8N ClByb2Zlc3NvciBvZiBPcGh0aGFsbW9sb2d5DQpFbW9yeSBVbml2ZXJzaXR5IFNjaG9vbCBvZiBN ZWRpY2luZQ0KDQpGcm9tOiBCZW4gQ2hhcnZldCA8YmVuY2hhcnZldEBnbWFpbC5jb208bWFpbHRv OmJlbmNoYXJ2ZXRAZ21haWwuY29tPj4NClJlcGx5LVRvOiAicGlldGVucG9sLWxpc3RAbWF0cm9u aWNzLmNvbTxtYWlsdG86cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbT4iIDxwaWV0ZW5wb2wt bGlzdEBtYXRyb25pY3MuY29tPG1haWx0bzpwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPj4N CkRhdGU6IFN1bmRheSwgRGVjZW1iZXIgNywgMjAxNCBhdCA3OjUwIEFNDQpUbzogInBpZXRlbnBv bC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20+ IiA8cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cGlldGVucG9sLWxpc3RAbWF0 cm9uaWNzLmNvbT4+DQpTdWJqZWN0OiBQaWV0ZW5wb2wtTGlzdDogRS1MU0EgcmVyZWdpc3RyYXRp b24/DQoNCi0tPiBQaWV0ZW5wb2wtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogQmVuIENoYXJ2ZXQg PGJlbmNoYXJ2ZXRAZ21haWwuY29tPG1haWx0bzpiZW5jaGFydmV0QGdtYWlsLmNvbT4+DQoNCldl J3ZlIGhhZCBhIHNpdHVhdGlvbiBkZXZlbG9wIG9uIG91ciBsb2NhbCBhaXJwb3J0LiAgQW4gb2xk ZXIgZ2VudGxlbWFuDQpoYWQgYSBtaXNoYXAgZmx5aW5nIGhpcyBKLTMuICBUaGUgYWlycGxhbmUg aGFzIGJlZW4gaW4gaGlzIGZhbWlseSBvdmVyDQo2MCB5ZWFycywgYW5kIGhlIGFjdHVhbGx5IHNv bG9lZCBpbiBpdCA2MCB5ZWFycyBhZ28uICBIZSBoYXMgdGhvdXNhbmRzDQpvZiBmbGlnaHQgaG91 cnMgYW5kIGlzIGEgZm9ybWVyIEFUUC4gIER1cmluZyB0aGUgbWlzaGFwIGhpcyBsYW5kaW5nIGdl YXINCnN0cnVjayBhIHJ1bndheSBzaWduIGFuZCBjb2xsYXBzZWQuICBUaGUgbGFuZGluZyBnZWFy IHdhcyB0aGUgb25seSB0aGluZw0KZGFtYWdlZCwgc28gd2hldGhlciB0aGlzIHdhcyBhbiBhY2Np ZGVudCBpcyBvcGVuIHRvIGludGVycHJldGF0aW9uLg0KSG93ZXZlciwgdGhlIEZBQSB3YXMgbm90 aWZpZWQgYnkgdGhlIG1lY2hhbmljIHRoYXQgaGVscGVkIHJlbW92ZSB0aGUNCmFpcmNyYWZ0IGZy b20gdGhlIHJ1bndheS4NCg0KVGhlIEZBQSBpcyBhc2tpbmcgdGhlIHBpbG90IGhhdmUgYSB0ZXN0 LWZsaWdodCB3aXRoIGFuIEZBQSBleGFtaW5lciwNCndoaWNoIEkgY2FuIHVuZGVyc3RhbmQgZHVl IHRvIGhpcyBhZ2UsIGV0Yy4gICBUaGV5IGFsc28gZGluZ2VkIGhpbQ0KYmVjYXVzZSBoZSB3YXMg Zmx5aW5nIGFzIGEgc3BvcnQgcGlsb3QgaW4gaGlzIEotMyB3aXRoIGl0cyBvcmlnaW5hbA0KcmVn aXN0cmF0aW9uIGFzIGEgc3RhbmRhcmQgY2xhc3MgYWlycGxhbmUuICBUaGV5IGNsYWltIGl0IGlz IG5lY2Vzc2FyeQ0KdG8gcmUtcmVnaXN0ZXIgdGhlIGFpcnBsYW5lIGFzIGxpZ2h0IHNwb3J0IGlu IG9yZGVyIHRvIGZseSBpdCBhcyBhIGxpZ2h0DQpzcG9ydCBwaWxvdC4gIEkgaGF2ZSBiZWVuIGZs eWluZyBteSBQaWV0ZW5wb2wgZm9yIDUgeWVhcnMgYXMgdXNpbmcgbGlnaHQNCnNwb3J0IHBpbG90 IHJ1bGVzLCBhbmQgYWx0aG91Z2ggSSByZW1lbWJlciBJIGhhZCB0aGUgb3B0aW9uIHRvIHJlZ2lz dGVyDQppdCBhcyBFLUxTQSwgdGhlIGNvbnZlbnRpb25hbCB3aXNkb20gYXQgdGhlIHRpbWUgd2Fz IEV4cGVyaW1lbnRhbA0KQW1hdGV1ciBCdWlsdCB3YXMgdGhlIHdheSB0byBnby4NCg0KSSd2ZSBz ZWFyY2hlZCB0aGUgRkFBIHJlZ3MgYW5kIGNhbid0IGZpbmQgYW55IGNsYXJpZmljYXRpb24uICBI YXMgYW55b25lDQplbHNlIG91dCB0aGVyZSBoZWFyZCBvZiBhIHB1c2ggdG8gcmUtcmVnaXN0ZXIg YXMgRS1MU0EgdG8gbWFrZSBhbg0KYWlyY3JhZnQgZWxpZ2libGUgZm9yIGxpZ2h0IHNwb3J0IHBp bG90cz8NCg0KQmVuIENoYXJ2ZXQNCjIzNSBocnMgb24gTlg4NjZCQyBzaXR0aW5nIG9uIG15IERM IG1lZGljYWwNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0NCl8tPQ0KXy09ICAgICAgIC0tIFBsZWFzZSBTdXBwb3J0IFlvdXIg TGlzdHMgVGhpcyBNb250aCAtLQ0KXy09ICAgICAgICAgICAoQW5kIEdldCBTb21lIEFXRVNPTUUg RlJFRSBHaWZ0cyEpDQpfLT0NCl8tPSAgIE5vdmVtYmVyIGlzIHRoZSBBbm51YWwgTGlzdCBGdW5k IFJhaXNlci4gIENsaWNrIG9uDQpfLT0gICB0aGUgQ29udHJpYnV0aW9uIGxpbmsgYmVsb3cgdG8g ZmluZCBvdXQgbW9yZSBhYm91dA0KXy09ICAgdGhpcyB5ZWFyJ3MgVGVycmlmaWMgRnJlZSBJbmNl bnRpdmUgR2lmdHMgcHJvdmlkZWQNCl8tPSAgIGJ5Og0KXy09DQpfLT0gICAgICogQWVyb0VsZWN0 cmljIHd3dy5hZXJvZWxlY3RyaWMuY29tDQpfLT0gICAgICogVGhlIEJ1aWxkZXIncyBCb29rc3Rv cmUgd3d3LmJ1aWxkZXJzYm9va3MuY29tDQpfLT0gICAgICogSG9tZWJ1aWx0SEVMUCB3d3cuaG9t ZWJ1aWx0aGVscC5jb20NCl8tPSAgICAgKiBNeSBQaWxvdCBTdG9yZSB3d3cubXlwaWxvdHN0b3Jl LmNvbQ0KXy09ICAgICAqIFJhY2UgQ29uc3VsdGluZyB3d3cubXJyYWNlLmNvbQ0KXy09DQpfLT0g ICBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cu bWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCl8tPQ0KXy09ICAgVGhhbmsgeW91IGZvciB5b3Vy IGdlbmVyb3VzIHN1cHBvcnQhDQpfLT0NCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAg IC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRo ZSBQaWV0ZW5wb2wtTGlzdCBFbWFpbCBGb3J1bSAtDQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlz dCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRp ZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERv d25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVj aCBtdWNoIG1vcmU6DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2 aWdhdG9yP1BpZXRlbnBvbC1MaXN0DQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgICAtIE1B VFJPTklDUyBXRUIgRk9SVU1TIC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFi bGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09DQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRy b25pY3MuY29tDQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09DQoNCg0KDQoNCg0KX19fX19fX19fX19fX19fX19fX19fX19f X19fX19fX18NCg0KVGhpcyBlLW1haWwgbWVzc2FnZSAoaW5jbHVkaW5nIGFueSBhdHRhY2htZW50 cykgaXMgZm9yIHRoZSBzb2xlIHVzZSBvZg0KdGhlIGludGVuZGVkIHJlY2lwaWVudChzKSBhbmQg bWF5IGNvbnRhaW4gY29uZmlkZW50aWFsIGFuZCBwcml2aWxlZ2VkDQppbmZvcm1hdGlvbi4gSWYg dGhlIHJlYWRlciBvZiB0aGlzIG1lc3NhZ2UgaXMgbm90IHRoZSBpbnRlbmRlZA0KcmVjaXBpZW50 LCB5b3UgYXJlIGhlcmVieSBub3RpZmllZCB0aGF0IGFueSBkaXNzZW1pbmF0aW9uLCBkaXN0cmli dXRpb24NCm9yIGNvcHlpbmcgb2YgdGhpcyBtZXNzYWdlIChpbmNsdWRpbmcgYW55IGF0dGFjaG1l bnRzKSBpcyBzdHJpY3RseQ0KcHJvaGliaXRlZC4NCg0KSWYgeW91IGhhdmUgcmVjZWl2ZWQgdGhp cyBtZXNzYWdlIGluIGVycm9yLCBwbGVhc2UgY29udGFjdA0KdGhlIHNlbmRlciBieSByZXBseSBl LW1haWwgbWVzc2FnZSBhbmQgZGVzdHJveSBhbGwgY29waWVzIG9mIHRoZQ0Kb3JpZ2luYWwgbWVz c2FnZSAoaW5jbHVkaW5nIGF0dGFjaG1lbnRzKS4NCg= ________________________________________________________________________________
Date: Dec 07, 2014
Ben I believe Jeff is correct. As far as I know it is not possible to re-regist er a standard or experimental airplane as an E-LSA. You can only re-registe r S-LSA as E-LSA. I think the only way to register a new airplane as E-LSA is to have built it from an approved LSA kit. You acquaintance has been given incorrect information from the local FAA, w hich is not really that uncommon with respect to Sport Pilot and LSA. Malcolm www.wienerdogaero.com ----- Original Message ----- From: "Jeffrey Boatright" <jeffboatright(at)emory.edu> Sent: Sunday, December 7, 2014 8:21:38 AM Subject: Re: Pietenpol-List: E-LSA reregistration? I=99m sorry to hear of your acquaintance=99s mishap. As long as the Cub has always met the definition of an LSA, per the FARs (i .e., gross weight below 1320 lbs, no more than two seats, etc.), then it ca n be flown by a pilot who qualifies as a Sport Pilot. I have not heard of any push for re-registration. Indeed, I don=99t s ee how that would be possible within the current FARs. What FSDO are we dea ling with here? Regardless, IMO, the older gent should call FAA in OKC =93 without the local FSDO being on the line. He should also call EAA an d AOPA, even if he=99s not a member. -- Jeffrey H. Boatright, PhD, FARVO Professor of Ophthalmology Emory University School of Medicine From: Ben Charvet < bencharvet(at)gmail.com > Date: Sunday, December 7, 2014 at 7:50 AM Subject: Pietenpol-List: E-LSA reregistration? We've had a situation develop on our local airport. An older gentleman had a mishap flying his J-3. The airplane has been in his family over 60 years, and he actually soloed in it 60 years ago. He has thousands of flight hours and is a former ATP. During the mishap his landing gear struck a runway sign and collapsed. The landing gear was the only thing damaged, so whether this was an accident is open to interpretation. However, the FAA was notified by the mechanic that helped remove the aircraft from the runway. The FAA is asking the pilot have a test-flight with an FAA examiner, which I can understand due to his age, etc. They also dinged him because he was flying as a sport pilot in his J-3 with its original registration as a standard class airplane. They claim it is necessary to re-register the airplane as light sport in order to fly it as a light sport pilot. I have been flying my Pietenpol for 5 years as using light sport pilot rules, and although I remember I had the option to register it as E-LSA, the conventional wisdom at the time was Experimental Amateur Built was the way to go. I've searched the FAA regs and can't find any clarification. Has anyone else out there heard of a push to re-register as E-LSA to make an aircraft eligible for light sport pilots? Ben Charvet 235 hrs on NX866BC sitting on my DL medical =========== =========== =========== =========== This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). =EF=BD=EF=BD=EF=BD~=EF=BD=EF=BD,=EF=BD=EF=BD=EF=BD% =EF=BD=EF=BDM4=EF=BD=EF=BD=EF=BDx=EF=BD=EF=BD=EF=BD =EF=BDw=EF=BDr=EF=BD=EF=BD=EF=BD=EF=BD ________________________________________________________________________________
Date: Dec 07, 2014
Ben On the FAA website the J3 is listed as " Light Sport Aircraft: Existing Type Certificated Models" here http://www.faa.gov/aircraft/gen_av/light_sport/media/ExistingModels.pdf. You cannot reregister an existing aircraft as experimental light sport. See section Section 6. Light Sport Aircraft Category Airworthiness Certifications 4038. General. http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgOrders.nsf/0/7a0 9d53fb0d5325586257885004d9e1b/$FILE/8130.2G_CHG1_Incorporated.pdf Chris Sacramento, CA WestcoastPiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Charvet Sent: Sunday, December 7, 2014 4:50 AM Subject: Pietenpol-List: E-LSA reregistration? We've had a situation develop on our local airport. An older gentleman had a mishap flying his J-3. The airplane has been in his family over 60 years, and he actually soloed in it 60 years ago. He has thousands of flight hours and is a former ATP. During the mishap his landing gear struck a runway sign and collapsed. The landing gear was the only thing damaged, so whether this was an accident is open to interpretation. However, the FAA was notified by the mechanic that helped remove the aircraft from the runway. The FAA is asking the pilot have a test-flight with an FAA examiner, which I can understand due to his age, etc. They also dinged him because he was flying as a sport pilot in his J-3 with its original registration as a standard class airplane. They claim it is necessary to re-register the airplane as light sport in order to fly it as a light sport pilot. I have been flying my Pietenpol for 5 years as using light sport pilot rules, and although I remember I had the option to register it as E-LSA, the conventional wisdom at the time was Experimental Amateur Built was the way to go. I've searched the FAA regs and can't find any clarification. Has anyone else out there heard of a push to re-register as E-LSA to make an aircraft eligible for light sport pilots? Ben Charvet 235 hrs on NX866BC sitting on my DL medical ________________________________________________________________________________
Date: Dec 07, 2014
Here's yet another opportunity to gently and patiently educate one of our public servants and employees (FAA person). As frustrating as it is to encounter ignorance, error, confusion, or misinformation in the agency that is supposed to promote and regulate civil aviation, there is much more to be gained by getting the correct information right out of the regulations or advisory circulars and then discussing it with our employees in the FAA. But I'll admit, sometimes you just want to whack 'em upside the head. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435462#435462 ________________________________________________________________________________
Subject: Re: West Coast Piet Project for Sale :(
Date: Dec 07, 2014
Mark, I am going to lay down a bit of a challenge. It would be easy to let your dream kind of slide and allow yourself to let your project go. Ask guys that sold their projects if they are glad that they did, and I think most would say that, in retrospect, they wish they had not. The little bit of money was not worth the setback. You have a place to store your fuselage. Make the effort to get it to NAS Danford (Tool's house and hangar). It probably will be a pain to lug the project across country. But think of the story you can tell once you have it flying. You will in the long run be glad that you did. If your plans and desires change later on, sell it then. But do not let it go - yet. My advice - and only worth what you paid for it. Best wishes in the move and the new job. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435463#435463 ________________________________________________________________________________
Date: Dec 07, 2014
I fugured this was just some mis-informed FAA guy. The regulation they quoted was 21.190, which excludes standard certified airplanes from being reregistered as E-LSA. Thanks for the input. Hopefully in the next few months all this will be irrelevent and the DL Class III medical will happen. Ben On 12/7/2014 2:58 PM, taildrags wrote: > > Here's yet another opportunity to gently and patiently educate one of our public servants and employees (FAA person). As frustrating as it is to encounter ignorance, error, confusion, or misinformation in the agency that is supposed to promote and regulate civil aviation, there is much more to be gained by getting the correct information right out of the regulations or advisory circulars and then discussing it with our employees in the FAA. > > But I'll admit, sometimes you just want to whack 'em upside the head. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435462#435462 > > -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Dec 07, 2014
Well, that's good advice, even if it was free! I appreciate it, and I might just be doing what you suggest. It is kinda a logistic's issue with the truck, but I might be able to squeeze it in, and that would be the main issue. I really don't want to sell it, and at this rate, I might not! :) Thanks for the advice! Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435470#435470 ________________________________________________________________________________
Date: Dec 07, 2014
Sorry to be the first to tell you Oscar, the Federal Aviation Administration Reauthorization Act of 1996, approved changes to the FAA's mission that removed the agency's dual mandate of regulating safety and promoting industry development. After that the FAA was to promote safety only!. Blue Skies, Steve D On Sun, Dec 7, 2014 at 1:58 PM, taildrags wrote: > > Here's yet another opportunity to gently and patiently educate one of our > public servants and employees (FAA person). As frustrating as it is to > encounter ignorance, error, confusion, or misinformation in the agency that > is supposed to promote and regulate civil aviation, there is much more to > be gained by getting the correct information right out of the regulations > or advisory circulars and then discussing it with our employees in the FAA. > > But I'll admit, sometimes you just want to whack 'em upside the head. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435462#435462 > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Dec 07, 2014
Mark; if I were retired or not married, I would volunteer to drive a rental truck one-way from CA to TN with your project, just for the adventure and sightseeing and to meet Tools and some of the other Pieters along the way (including a mandatory stop at The Chicken Coop in Oklahoma). I'd even pay my own way. But I'm not ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435472#435472 ________________________________________________________________________________
Date: Dec 07, 2014
Ha! Oscar, I am still chuckling. As we have all heard before, it's the thought that counts! Choosing to build a piet brings with it the best people in the world. I hope I can keep the project and meet ya'll in brodhead sometime! Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435479#435479 ________________________________________________________________________________
Date: Dec 08, 2014
In a message dated 12/7/2014 8:10:53 P.M. Eastern Standard Time, steven.d.dortch(at)gmail.com writes: Sorry to be the first to tell you Oscar, the Federal Aviation Administration Reauthorization Act of 1996, approved changes to the FAA's mission that removed the agency's dual mandate of regulating safety and promoting industry development. After that the FAA was to promote safety only!. Blue Skies, Steve D On Sun, Dec 7, 2014 at 1:58 PM, taildrags <_taildrags(at)hotmail.com_ (mailto:taildrags(at)hotmail.com) > wrote: --> Pietenpol-List message posted by: "taildrags" <_taildrags(at)hotmail.com_ (mailto:taildrags(at)hotmail.com) > Here's yet another opportunity to gently and patiently educate one of our public servants and employees (FAA person). As frustrating as it is to encounter ignorance, error, confusion, or misinformation in the agency that is supposed to promote and regulate civil aviation, there is much more to be gained by getting the correct information right out of the regulations or advisory circulars and then discussing it with our employees in the FAA. But I'll admit, sometimes you just want to whack 'em upside the head. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435462#435462 ========== br> fts!) r> > com" target="_blank">www.aeroelectric.com w.buildersbooks.com" target="_blank">www.buildersbooks.com p.com" target="_blank">www.homebuilthelp.com e.com" target="_blank">www.mypilotstore.com " target="_blank">www.mrrace.com target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. ========== br> enpol-List" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ========== FORUMS - _blank">http://forums.matronics.com ========== -- Blue Skies, Steve D (http://www.aeroelectric.com/) (http://www.buildersbooks.com/) (http://www.homebuilthelp.com/) (http://www.mypilotstore.com/) ________________________________________________________________________________
Date: Dec 08, 2014
> the FAA was notified by the mechanic Why would the mechanic do that...? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435487#435487 ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Date: Dec 08, 2014
Because he was an ignorant busybody? Around here, if it comes to their attention, the police insist that any off-field incident (such as a safe, off-field landing) involving an aircraft be reported to the FAA. We once had a local sheriff crash a family reunion party, where a family member was hopping his family rides from their pasture, because they weren't using an 'official' airport. Kip Gardner On Dec 8, 2014, at 7:55 AM, PatrickW wrote: > > >> the FAA was notified by the mechanic > > > Why would the mechanic do that...? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435487#435487 > > ________________________________________________________________________________
Subject: Gooseneck Die
Date: Dec 08, 2014
There was a thread a few months ago regarding Gooseneck bending dies which I thought would be a great addition to my own shop. So, in my travels, I came across a rather long Gooseneck die, and I picked it up for a rather pricey sum. If you want a short gooseneck, I'm cutting the long piece into a series of short pieces, so you can bend the U shaped fittings - along with any other fittings - without having to jury rig something special. The cost per linear inch of the material is $7.50, and it will fit into a $5.00 shipping box. I'm not trying to make $$ here, just help out anyone wanting such a die, at a reasonable cost. Let me know if you're interested, and I'll cut a 3", 4", or whatever length you need. For my purposes, I'm going with a 4" bending setup like the one Curt Merdan showed in his pics. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435489#435489 ________________________________________________________________________________
Date: Dec 08, 2014
Subject: Classic Carwil Bubbleface Compass
OOPs Photos attached -- Blue Skies, Steve D ________________________________________________________________________________
Date: Dec 08, 2014
On a personal note: I once landed at our local non-controlled and under-used airport after a week of heavy rain and turned a few feet too soon onto a taxi way with the result that the left wheel mired in the mud. I gave the J-3 full and rapid throttle to pull through the mud, but the engine stalled and quit. With the momentary, but short power surge, and the one wheel stuck in the mud, the plane nosed over in very slow motion. I climbed out into ankle deep mud, pulled the tail down and managed somehow to pull the plane out of the mud. By the time I got the plane back to the hangar, the sheriff showed up and asked if I were the one who "crashed"! Being the only airplane at the airport, and standing there with mud up to my ankles with only one shoe and hosing the mud off the plane; I had to admit that I was the "crashed plane"! He wanted a complete report on the crash because he had already called the FFA to report it! Some motorist, driving by the airport, had reported the "crash". The sheriff's protocol was the immediately call the FFA prior to even responding to the crash site! It took only six months and many letters and phone calls to get the "incident" straightened out. As they say, the FFA is not happy until you are unhappy. Ray Krause Sent from my iPad > On Dec 8, 2014, at 5:03 AM, Kip and Beth Gardner wrote: > > > Because he was an ignorant busybody? Around here, if it comes to their attention, the police insist that any off-field incident (such as a safe, off-field landing) involving an aircraft be reported to the FAA. We once had a local sheriff crash a family reunion party, where a family member was hopping his family rides from their pasture, because they weren't using an 'official' airport. > > Kip Gardner > >> On Dec 8, 2014, at 7:55 AM, PatrickW wrote: >> >> >> >>> the FAA was notified by the mechanic >> >> >> Why would the mechanic do that...? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=435487#435487 > > > > > ________________________________________________________________________________
From: "Jim and Grace Malley" <jgmalley(at)comcast.net>
Subject: Re: Jim Malley's Piet
Date: Dec 08, 2014
Good eye, Oscar. Both the rudder and elevator gaps are nearly 7/8". I taped them closed for a few flights, there was small improvement in elevator authority and nothing noticeable in rudder so the tapes went into the garbage bin. The ailerons are attached with piano hinges and the short spaces between the hinges are sealed with tape; they are very effective resulting in little stick movement. Jim Malley -----Original Message----- From: taildrags Sent: Saturday, November 29, 2014 10:35 PM Subject: Pietenpol-List: Re: Jim Malley's Piet Wow, what a beauty! Excellent workmanship, and the whole visual scheme is very tasteful and reminiscent of the times. Great work, and great photos. But is it just me, or is the gap between rudder and vertical stabilizer quite large? Not at all being critical, just commenting. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435080#435080 ________________________________________________________________________________
Subject: Re: Gooseneck Die
Date: Dec 09, 2014
Tom I searched the archives for a picture and couldn't find one. Can you share one? Are they stainless? Thanks! Sent from my iPad Jack Textor > On Dec 8, 2014, at 7:43 AM, "tkreiner" wrote: > > > There was a thread a few months ago regarding Gooseneck bending dies which I thought would be a great addition to my own shop. So, in my travels, I came across a rather long Gooseneck die, and I picked it up for a rather pricey sum. > > If you want a short gooseneck, I'm cutting the long piece into a series of short pieces, so you can bend the U shaped fittings - along with any other fittings - without having to jury rig something special. > > The cost per linear inch of the material is $7.50, and it will fit into a $5.00 shipping box. > > I'm not trying to make $$ here, just help out anyone wanting such a die, at a reasonable cost. Let me know if you're interested, and I'll cut a 3", 4", or whatever length you need. For my purposes, I'm going with a 4" bending setup like the one Curt Merdan showed in his pics. > > -------- > Tom Kreiner > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435489#435489 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 09, 2014
Subject: First wing is ready for paint!!
Huge step forward in getting the People's Piet in the air! Very exciting. I worked out a nice easy project plan that had me finishing the fuse and starting on the wings right after the new year. It's really great to be well ahead of schedule and still not feeling rushed. And covering is FUN!!! Oscar...I better not EVER find out you were in the area and DIDN'T stop by!! Or any of you'se guys for that matter! Especially now, there's a LOT of painting to get done! LOL Hope the Holidays are good for everyone! Jim in Pryor ________________________________________________________________________________
Date: Dec 09, 2014
Jack, The pic of the Die is attached although not all the dim's are shown. If you need additional info, I can measure the die, and add additional dim's. The material is alloy steel, probable 1018, or thereabouts. There is no nose radius, so I'm going to add one for my own bending, maybe .09 or so. Bending our U shapes fittings should be pretty easy with this. You will need to procure or mill a VEE block, as I don't have any of those. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435544#435544 Attachments: http://forums.matronics.com//files/gooseneck_die_181.jpg ________________________________________________________________________________
Date: Dec 09, 2014
I'll take a 9" length if that is possible....? My press brake has a 9 &1/8" opening - so less than 9" is ok but it can't be greater. THANK YOU...! Let me know how to get the funds to you. -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435547#435547 ________________________________________________________________________________
Date: Dec 09, 2014
See pic of my home-made press... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435548#435548 Attachments: http://forums.matronics.com//files/2014_12_09_18_46_04_1_427.jpg ________________________________________________________________________________
Date: Dec 10, 2014
I sent you a pm the other day. Thanks Rob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435552#435552 ________________________________________________________________________________
Subject: Merry Christmas!
Date: Dec 10, 2014
In case your family is like mine, and just never knows what to get for you: http://www.cafepress.com/+pietenpol-air-camper+gifts Gary Boothe NX308MB ________________________________________________________________________________
Subject: Dragonfly for sale or trade
Date: Dec 10, 2014
Pat Panzera and Contact! Magazine have a Dragonfly for sale or trade in the southern California area. Pat would very much like to trade the DF for a Piet, if anyone is interested. Here's a link to pictures and information on the plane, which is complete and ready to taxi test: http://hanford.craigslist.org/search/sss?query=dragonfly&sort=rel I know nothing more about it than what is listed in the ad. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435586#435586 ________________________________________________________________________________
Date: Dec 11, 2014
Subject: Re: Merry Christmas!
Thanks Gary; Arlene was non-committal to all of them. Merry Christmas, Jim and Arlene =C2- ________________________________________________________________________________
Subject: Vi Kapler
Date: Dec 11, 2014
Vi Kapler's daughter Rebecca asked me to inform you that Vi had a heart attack on Monday. He is on life support in the ICU at St. Mary's Hospital in Rochester. Please keep Vi and his family in your thoughts and prayers. Thank You. Dan Wilson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435598#435598 ________________________________________________________________________________
Date: Dec 11, 2014
Subject: Re: Vi Kapler
So sorry to hear this. Vi is a class act and true gentleman. I always looked forward to seeing him at Brodhead. Ken On Thu, Dec 11, 2014 at 11:57 AM, dwilson wrote: > > Vi Kapler's daughter Rebecca asked me to inform you that Vi had a heart > attack on Monday. He is on life support in the ICU at St. Mary's Hospital > in Rochester. Please keep Vi and his family in your thoughts and prayers. > Thank You. > > Dan Wilson > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435598#435598 > > ________________________________________________________________________________
Date: Dec 11, 2014
wow - really sad to hear............ sending my best regards -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435600#435600 ________________________________________________________________________________
From: "Jeff Boatright" <jeffboatright(at)emory.edu>
Date: Dec 11, 2014
I met Vi way back in 1992 (still seems like not that long ago to me), at my first Brodhead. I've chatted with Vi at several Brodheads and Oshkoshs since then, and if memory serves, even an SnF. I was at that first Brodhead with my dad, who has since had two heart attacks. My dad survived both, but even with best outcomes, these are sobering moments for both the patient and the family. I now own a Pietenpol in partnership with my dad. The airplane and the world of Pietenpols have been a great common interest for us. Vi is part of that world. I still have a couple of letters from a correspondence that he and my dad had over the years. He is such a great representative of what the Pietenpol world is all about. I hope he makes it home for Christmas. Please let us know if you think cards, etc. to Rebecca and Vi would be welcomed or just a burden right now. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435601#435601 ________________________________________________________________________________
Date: Dec 11, 2014
Such bad, sad news, I never met him, but he was an inspiration to me. He had the foresight to set up Oscar to carry on some of his past efforts. Ray Krause Sent from my iPad > On Dec 11, 2014, at 10:57 AM, dwilson wrote: > > > Vi Kapler's daughter Rebecca asked me to inform you that Vi had a heart attack on Monday. He is on life support in the ICU at St. Mary's Hospital in Rochester. Please keep Vi and his family in your thoughts and prayers. Thank You. > > Dan Wilson > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435598#435598 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 11, 2014
Guys, At this point in time, and assuming no one cancels, the entire bar has been spoken for. I'll let y'all know if anyone falls out... -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435605#435605 ________________________________________________________________________________
Date: Dec 11, 2014
If you would like to send something (not live flowers!) to Vi's room, the address is: Vitalis Kapler Room 726, Mary Brigh 4E St. Mary's Campus Hospital 1216 2nd Street S.W. Rochester, MN 55905 (507) 255-5123 The nurse asks that you NOT send live flowers. Anything else is OK. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435607#435607 ________________________________________________________________________________
Subject: Gooseneck Die, Part Dieux
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Dec 11, 2014
If anyone else missed out on the Gooseneck Die (like I did), and would like to join in on a group buy of another length of die, please contact me. I am willing to make the purchase and divvy it up, as long as others are interested in part of it. Just let me know. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435612#435612 ________________________________________________________________________________
Date: Dec 11, 2014
It is indeed sobering news. As Ray mentioned, I am glad to have been able to continue some of what Vi has done for the Piet community, but it's just a small part of who he is and what he has meant to so many, for so long. It was not that long ago that I spoke with him on the phone on a Saturday morning (it was afternoon, where he is), and discussed taking over the manufacture and sale of tail hinge parts for Air Campers. Little did I know what I would get from him a couple of weeks later, well packed in a recycled moving box. I expected to get a shoebox sized package with some leftover casting blanks and maybe a jig or two because he said he had some castings that he had rejected but that would be good for me to practice on. I was wrong. In the box were many hand-made (and well worn) tools and jigs that he used to make the hinges over the years, and each of them had an index card taped to it with handwritten notes on how he used each item and in what sequence. He included samples of the recommended hinge pins, AN screws, and representative parts in process. All with hand-written notes on index cards. He included a cutoff saw that he used to face off the hinge tabs, a machinist's vise that he used to clamp the hinge halves for drilling, and a wheel to mount adhesive-backed emery material to true up the bottom and sides. I have kept all of the handwritten notes, parts, and everything else. It all means something to me. When I discussed a price for acquiring the rights and the "tooling", Vi went quiet on the phone for more than just a few seconds and I thought maybe he was conferring with a family member about it or something, but he was thinking. I expected some lawyer talk and a discussion of liability, forms, and negotiations. I was wrong. "Well, I guess I would let you have it all for $100. Or maybe less." He spent more than that on what he sent me on the box plus the cost of shipping it to me. When he said that it was my turn to fall silent on my end. I was flabbergasted. Then we discussed why he had stopped making the parts and why he was glad that someone would be taking over the production of the parts. That has been my only personal contact with Vi Kapler, but it was enough. He has lived his life the way I want to live the rest of mine, and for the same reasons. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435621#435621 ________________________________________________________________________________
Subject: Re: Gooseneck Die, Part Dieux
Date: Dec 11, 2014
Belay that last! I think the word you want is 'deux' (second, in French). 'Les Dieux' are 'the gods' and I don't think any of them have goosenecks or want to die ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435622#435622 ________________________________________________________________________________
Date: Dec 11, 2014
Oscar, So much for my Spanish and Greek studies. I have no background in French, other than to recite the line from "Monty Python and the Holy Grail" - "Of course I am French. Why else would I have this OUTRAGEOUS accent." (With an outrageous accent, of course) But the offer still stands... [Wink] -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435624#435624 ________________________________________________________________________________
Date: Dec 12, 2014
I would chip in for a 9" segment. Really appreciative that Tom has done this - I am getting a short segment from him. I would like to have a full segment if I can for future bending of longer parts..... THANK YOU both for doing this....! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435650#435650 ________________________________________________________________________________
Date: Dec 12, 2014
>From Forrest Lovley via FB, this morning: "I went to visit Vi Kapler yesterday afternoon, and he was still holding his own, but he passed away last evening shorty after 6 PM. Arrangements are still pending." Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435654#435654 ________________________________________________________________________________
Date: Dec 12, 2014
Does anyone have an address for the family? -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435657#435657 ________________________________________________________________________________
Subject: Fw: Vitalis Kapler has passed on.
Date: Dec 12, 2014
A message from Vi's daughter... Begin forwarded message: From: Rebecca Kapler <purpleorchid235(at)gmail.com> Date: December 12, 2014 at 11:43:21 AM CST To: peterthepilot99(at)gmail.com Subject: Vitalis Kapler has passed on. Dad passed on to the great gig in the sky Thurs Dec 11th about 5:55 pm. 2 014. It was so beautiful, I held his left hand Jenny held his right, as he was taking his last breath, I closed my eyes & gave thanks. I had the feeling of being a little girl again, In the plane with Dad, Taxiing down the runwa y, sitting at the end of the runway, Revving the engine, checking the wings just one more time to make sure they worked real good. I turned around and saw my Dads face with the biggest grin ever. He flashed me the thumbs up s ign. Up, up, up, and away we went. I had the sensation that I was flying. w ow I am just in amazement. I am Filled with peace. I will miss him dearly a nd thank you for your condolences. Rebecca Kapler 1033 Forest hills Dr SW Rochester, MN 55902 507-288-3322 home 507-990-2938 cell purpleorchid235(at)gmail.com --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Subject: Sport Aviation
Date: Dec 12, 2014
Hey All, I just got my December Sport Aviation with a really nice article on the Pietenpol and also an article on Doug Ward with his Log Cabin fly in, also an article on Nordo I felt real good reading this issue, just like the old days. Hopefully they will keep it up. Dick N. ________________________________________________________________________________
Date: Dec 12, 2014
I have tried my best to keep my mouth shut, but my curiosity won't allow it. What the hell is a gooseneck die and what is it for? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435662#435662 ________________________________________________________________________________
Date: Dec 12, 2014
Aviken, Maybe a picture will help. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435664#435664 Attachments: http://forums.matronics.com//files/screen_shot_2014_12_12_at_124237_pm_175.png ________________________________________________________________________________
Date: Dec 12, 2014
Thanks, Oscar, well said. Ray Krause Sent from my iPad > On Dec 11, 2014, at 5:47 PM, taildrags wrote: > > > It is indeed sobering news. As Ray mentioned, I am glad to have been able to continue some of what Vi has done for the Piet community, but it's just a small part of who he is and what he has meant to so many, for so long. > > It was not that long ago that I spoke with him on the phone on a Saturday morning (it was afternoon, where he is), and discussed taking over the manufacture and sale of tail hinge parts for Air Campers. Little did I know what I would get from him a couple of weeks later, well packed in a recycled moving box. I expected to get a shoebox sized package with some leftover casting blanks and maybe a jig or two because he said he had some castings that he had rejected but that would be good for me to practice on. I was wrong. In the box were many hand-made (and well worn) tools and jigs that he used to make the hinges over the years, and each of them had an index card taped to it with handwritten notes on how he used each item and in what sequence. He included samples of the recommended hinge pins, AN screws, and representative parts in process. All with hand-written notes on index cards. He included a cutoff saw that he used to face off the hinge tabs, a machinist's vise t! > hat he used to clamp the hinge halves for drilling, and a wheel to mount adhesive-backed emery material to true up the bottom and sides. I have kept all of the handwritten notes, parts, and everything else. It all means something to me. > > When I discussed a price for acquiring the rights and the "tooling", Vi went quiet on the phone for more than just a few seconds and I thought maybe he was conferring with a family member about it or something, but he was thinking. I expected some lawyer talk and a discussion of liability, forms, and negotiations. I was wrong. > > "Well, I guess I would let you have it all for $100. Or maybe less." He spent more than that on what he sent me on the box plus the cost of shipping it to me. > > When he said that it was my turn to fall silent on my end. I was flabbergasted. Then we discussed why he had stopped making the parts and why he was glad that someone would be taking over the production of the parts. That has been my only personal contact with Vi Kapler, but it was enough. He has lived his life the way I want to live the rest of mine, and for the same reasons. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435621#435621 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 12, 2014
Truly a sad day. My best to his family, he and they will be in my prayers. Ray Krause Sent from my iPad > On Dec 12, 2014, at 1:12 PM, Ryan Mueller wrote: > > >> From Forrest Lovley via FB, this morning: > > "I went to visit Vi Kapler yesterday afternoon, and he was still holding his own, but he passed away last evening shorty after 6 PM. Arrangements are still pending." > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435654#435654 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 13, 2014
https://www.google.ca/images?q=gooseneck+press+brake+dies&hl=en-CA&gbv=2&sa=X&oi=image_result_group&ei=qPaLVMD7BoG7ogS-r4GYAg&ved=0CFkQsAQ Clif Always remember to go to other people's funerals. Otherwise, they might not come to yours. Yogi Berra > > I have tried my best to keep my mouth shut, but my curiosity won't allow > it. What the hell is a gooseneck die and what is it for? ________________________________________________________________________________
Subject: Fabric help please!
Date: Dec 13, 2014
I'm about to place an order with Aircraft Spruce and am going to order my covering fabric. Going through the archives it appears we need about 45 yards. What's the difference between Dacron and Ceconite? I'm looking at the 1.8oz Dacron but it's width is 60 inches. From memory the chord is 60 inches so it might be a stretch to get enough coverage? Can some please tell me if I am looking at the correct product. It is part number 09-00100 from AS&S. Scotty -------- Tamworth, Australia Building a Corvair Powered Pietenpol Air Camper www.scottyspietenpol.com Fuslage now on its undercarriage! About to start wing spars...Corvair engine at Roy's Garage waiting to be modified. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435672#435672 ________________________________________________________________________________
Subject: Re: Fabric help please!
Date: Dec 13, 2014
=0AScotty,=0A=0A=0A60" is too narrow. How about this? http://aircr aftproducts.wicksaircraft.com/item/certified-ceconite-fabric/ceconite-fabric/lig ht-17?&plpver=10&origin=keyword&by=prod&filter=0=0A=0A=0AThis is wha t I used. "Ceconite" is a trade name, and is in fact dac ron polyester. =0A=0A=0ADan Helsper=0ALoensloe Airfield=0APuryear, TN=0A =0A=0A=0A-----Original Message-----=0AFrom: bubbleboy <scott.dawson3@bigpo nd.com>=0ATo: pietenpol-list =0ASent: Sat, Dec 13, 2014 4:33 am=0ASubject: Pietenpol-List: Fabric help plea .dawson3(at)bigpond.com>=0A=0AI'm about to place an order with Aircra ft Spruce and am going to order my =0Acovering fabric. Going through the archives it appears we need about 45 yards. =0A What's the difference between Dacron and Ceconite? I'm looking at the 1.8oz =0ADacron but it's width is 60 inches. From memory the chord is 60 inches so it =0Amight be a stretch to get enough coverage?=0A=0ACan some please tell me if I am looking at the correct product. It is part =0Anumber 09-001 00 from AS&S.=0A=0AScotty=0A=0A--------=0ATamworth, Australia=0ABuilding a Corvair Powered Pietenpol Air Camper=0A=0Awww.scottyspietenpol.com=0A =0AFuslage now on its undercarriage! About to start wing spars ...Corvair engine at =0ARoy's Garage waiting to be modified.=0A=0A =0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/v =========================== -Matt Dralle, List =========================== =========================== =========================== ===============0A=0A=0A=0A=0A =0A ________________________________________________________________________________
Date: Dec 13, 2014
Check the lightweight fabric at Wicks. I bought mine there and it was wider. I believe I used 40 yards, but it's been a while and my memory isn't what it once was. Ben bubbleboy wrote: > >I'm about to place an order with Aircraft Spruce and am going to order my covering fabric. Going through the archives it appears we need about 45 yards. What's the difference between Dacron and Ceconite? I'm looking at the 1.8oz Dacron but it's width is 60 inches. From memory the chord is 60 inches so it might be a stretch to get enough coverage? > >Can some please tell me if I am looking at the correct product. It is part number 09-00100 from AS&S. > >Scotty > >-------- >Tamworth, Australia >Building a Corvair Powered Pietenpol Air Camper > >www.scottyspietenpol.com > >Fuslage now on its undercarriage! About to start wing spars...Corvair engine at Roy's Garage waiting to be modified. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=435672#435672 > > ________________________________________________________________________________
From: Scott Knowlton <flyingscott_k(at)hotmail.com>
Date: Dec 13, 2014
AC spruce sells 1.87 oz poly fiber for just over $10.00 per yard. It is 72" and would enable you to lay it up loose (as required for shrinking) on the 60" Pietenpol chord. Scott K Burlington Ontario Sent from my iPhone > On Dec 13, 2014, at 7:35 AM, "Andre B. Charvet" wrote: > > > Check the lightweight fabric at Wicks. I bought mine there and it was wider. I believe I used 40 yards, but it's been a while and my memory isn't what it once was. > Ben > > bubbleboy wrote: >> >> I'm about to place an order with Aircraft Spruce and am going to order my covering fabric. Going through the archives it appears we need about 45 yards. What's the difference between Dacron and Ceconite? I'm looking at the 1.8oz Dacron but it's width is 60 inches. From memory the chord is 60 inches so it might be a stretch to get enough coverage? >> >> Can some please tell me if I am looking at the correct product. It is part number 09-00100 from AS&S. >> >> Scotty >> >> -------- >> Tamworth, Australia >> Building a Corvair Powered Pietenpol Air Camper >> >> www.scottyspietenpol.com >> >> Fuslage now on its undercarriage! About to start wing spars...Corvair engine at Roy's Garage waiting to be modified. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=435672#435672 > > > > > ________________________________________________________________________________
Date: Dec 13, 2014
From: "Charles N. Campbell" <charlescampbell1924(at)gmail.com>
I bought enough fabric (1.7 oz) of 72 inch width for the wings, and the rest was 62 inch width for the fuselage and tail surfaces. I don't know how without sewing strips of 62-inch fabric together to fit the narrow fabric to the wings. I forgot how much of each to buy but it is fairly easy to figure out how much you will need. Chuck On Sat, Dec 13, 2014 at 5:32 AM, bubbleboy wrote: > > scott.dawson3(at)bigpond.com> > > I'm about to place an order with Aircraft Spruce and am going to order my > covering fabric. Going through the archives it appears we need about 45 > yards. What's the difference between Dacron and Ceconite? I'm looking at > the 1.8oz Dacron but it's width is 60 inches. From memory the chord is 60 > inches so it might be a stretch to get enough coverage? > > Can some please tell me if I am looking at the correct product. It is part > number 09-00100 from AS&S. > > Scotty > > -------- > Tamworth, Australia > Building a Corvair Powered Pietenpol Air Camper > > www.scottyspietenpol.com > > Fuslage now on its undercarriage! About to start wing spars...Corvair > engine at Roy's Garage waiting to be modified. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435672#435672 > > ________________________________________________________________________________
Date: Dec 13, 2014
I bought the wider fabric from Stewart Systems and the 62-inch from Aircraft Spruce. I could have gotten it all from Stewart but the 62-inch was a little less expensive and I'm Scotch enough to want to save a few bucks. Chuck On Sat, Dec 13, 2014 at 7:33 AM, Andre B. Charvet wrote: > > bencharvet(at)gmail.com> > > Check the lightweight fabric at Wicks. I bought mine there and it was > wider. I believe I used 40 yards, but it's been a while and my memory isn't > what it once was. > Ben > > bubbleboy wrote: > scott.dawson3(at)bigpond.com> > > > >I'm about to place an order with Aircraft Spruce and am going to order my > covering fabric. Going through the archives it appears we need about 45 > yards. What's the difference between Dacron and Ceconite? I'm looking at > the 1.8oz Dacron but it's width is 60 inches. From memory the chord is 60 > inches so it might be a stretch to get enough coverage? > > > >Can some please tell me if I am looking at the correct product. It is > part number 09-00100 from AS&S. > > > >Scotty > > > >-------- > >Tamworth, Australia > >Building a Corvair Powered Pietenpol Air Camper > > > >www.scottyspietenpol.com > > > >Fuslage now on its undercarriage! About to start wing spars...Corvair > engine at Roy's Garage waiting to be modified. > > > > > > > > > >Read this topic online here: > > > >http://forums.matronics.com/viewtopic.php?p=435672#435672 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: Vi
Date: Dec 13, 2014
Hello all, With Vi's passing, yet one more direct link to Bernhard, his times but most of all to that unique generation. Though I mourn his passing, I also mourn the passing of that generation which in great part possessed qualities which seem so absent from subsequent ones. Marci and I had the pleasure of visiting him in 2010 as he was putting the finishing touches on his gorgeous Ford-powered Piet, and though we only spent an hour or so, it was memorable. I will miss seeing his face at Brodhead. Douwe ________________________________________________________________________________
Subject: Re: Vi
Date: Dec 13, 2014
Douwe, very true words. This is one of the main reasons I am choosing to build a Pietenpol. Sure there are planes out there faster, roomier, etc...but I can't think of any airplane that embodies the spirit of those past generations better than the Piet. I hope by building, it will help preserve and pass on thier legacy, and hopefully a little bit of what made them so special. Jon -------- Jon Jones Ironton, MO Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435693#435693 ________________________________________________________________________________
Date: Dec 13, 2014
jarheadpilot82 wrote: > Does anyone have an address for the family? A message from Vi's daughter... Begin forwarded message: From: Rebecca Kapler Date: December 12, 2014 at 11:43:21 AM CST Subject: Vitalis Kapler has passed on. Dad passed on to the great gig in the sky Thurs Dec 11th about 5:55 pm. 2014. It was so beautiful, I held his left hand Jenny held his right, as he was taking his last breath, I closed my eyes & gave thanks. I had the feeling of being a little girl again, In the plane with Dad, Taxiing down the runway, sitting at the end of the runway, Revving the engine, checking the wings just one more time to make sure they worked real good. I turned around and saw my Dads face with the biggest grin ever. He flashed me the thumbs up sign. Up, up, up, and away we went. I had the sensation that I was flying. wow I am just in amazement. I am Filled with peace. I will miss him dearly and thank you for your condolences. Rebecca Kapler 1033 Forest hills Dr SW Rochester, MN 55902 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435696#435696 ________________________________________________________________________________
Subject: nothing in particular
Date: Dec 13, 2014
Okay=2C Pieters- it's been a sad weekend=2C what with Vi Kapler leaving thi s earth for judgement. May God find him to have been a good and faithful s ervant. We had our first sunny afternoon in a long while here in southern Oregon so I went out to the hangar and changed out the bent fork end fitting on the lower port side forward strut (one of the squawks at the last annual). Eas ier than I thought=2C but then again I had a helper to wiggle the wing and hand me tools=2C so it went well. Re-tensioned the X-brace cables=2C safet ied them=2C and then taxied out to the fuel pumps to warm up the oil and to p off the tank. It was nice to have the A75 come to life and carry me here and there without complaint. At the pumps=2C I took on about 10 gallons w hen a Taylorcraft came taxiing up after an easy out-and-back flight to do w hat I had done on the ramp... warm up the oil and knock off a little of the rust. We talked about A65s and starters (he wants to upgrade to a C85 on the T-Cart)=2C and how the runway surface was at one of our nearby unpaved fields (Beagle Sky Ranch). Even without flying=2C Scout provided enough sensory input to keep me going for another week or two of fall and winter weather. Just firing up the en gine was enough=2C but taxiing out with gloves and flying helmet on and fue ling and restarting and taxiing some more was just gravy. These airplanes are so rewarding. ________________________________________________________________________________
Subject: Pietenpol Sighting
Date: Dec 14, 2014
Yesterday my brother in law sent me this picture of a plane that "looks like the one you are building". I wasn't to surprise when it turns out the picture is of Scott Liefeld in his Pietenpol because my brother in law and Scott both live in Sothern California. Then he mentions they are in Flagstaff. Wait a minute, Flagstaff! That's like 400 miles from Scott's home airport. That's 400 miles away from home in a Pietenpol in December. Not too shabby Scott. Chris Sacramento, CA WestcoastPiet.com ________________________________________________________________________________
Date: Dec 14, 2014
Sure hope you can make that happen Sent from my iPhone > On Dec 7, 2014, at 10:50 PM, "Mark Roberts" wrote: > > > Ha! Oscar, I am still chuckling. > > As we have all heard before, it's the thought that counts! > > Choosing to build a piet brings with it the best people in the world. I hope I can keep the project and meet ya'll in brodhead sometime! > > Mark > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435479#435479 > > > > > > > > > > ________________________________________________________________________________
Subject: Vi Kapler Information
Date: Dec 14, 2014
Date of Birth: Saturday, May 14, 1927 Date of Death: Thursday, December 11, 2014 Age: 87 years old VITALIS J. KAPLER Visitation Date: Thursday December 18, 2014 Time: 4:00 pm - 7:00 pm Location: River Park Chapel at Macken Funeral Home Second Visitation Date: Friday December 19, 2014 Time: 11:00 pm - 12:00 pm Location: Holy Spirit Catholic Church Memorial Mass Date: Friday December 19, 2014 Time: 12:00 pm Location: Holy Spirit Catholic Church Burial Location: Calvary Cemetery Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435714#435714 ________________________________________________________________________________
Date: Dec 14, 2014
Subject: Re: First wing is ready for paint!!
Jim-- Those sure are pretty wings, mine just look like skeletons. --Mac in Oregon > Huge step forward in getting the People's Piet in the air! Very exciting. > I worked out a nice easy project plan that had me finishing the fuse and > starting on the wings right after the new year. It's really great to be > well ahead of schedule and still not feeling rushed. > > And covering is FUN!!! > > Oscar...I better not EVER find out you were in the area and DIDN'T stop > by!! Or any of you'se guys for that matter! Especially now, there's a > LOT of painting to get done! LOL > > Hope the Holidays are good for everyone! > > Jim in Pryor > > ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Dec 15, 2014
Jim, They look GREAT. Keep up the good work. Makes me want to recover someones airplane. I found that part of building to be loads of fun. Cheers, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435740#435740 ________________________________________________________________________________
Subject: Model A Engine
Date: Dec 15, 2014
Are there any websites or good books anyone can recommend for converting a model a engine for use in a Piet as some books and materials are better than others. I figured some of you guys hat have already converted their engines you could point me in the right direction. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435757#435757 ________________________________________________________________________________
Subject: Re: Model A Engine
Date: Dec 15, 2014
No one source I know of.... So.... Read up on model a engine sites for modifications relating to durability, not horsepower. Like inserted bearings, balancing, better pistons, porting, polishing, blue printing, valve face angles, etc. some of that does give more horsepower, but it's free. What you want to avoid are the modifications that reduce reliability. Boring for displacement is a bad idea generally. Then read bhp's original article from the flying and glider manual which contains the aviation stuff like better oiling, mounting mags, carb mounting, carb heat, prop mounting, etc. Back issues of the buckeye piet association newsletters have a lot of info. Lastly, search the archives here and ask specific questions! Asking how to build a motor won't get much response. However, as you research, and you find conflicting info or just don't understand a particular thing, those questions become easier to talk about. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435760#435760 ________________________________________________________________________________
Date: Dec 15, 2014
Thanks Tools. Exactly what I was asking for. A direction to go looking for the necessary information. I have found lots of sites to look into. I just happened to buy this engine at a good price and never really looked into anything for the A. Great suggestions...... Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435762#435762 ________________________________________________________________________________
Date: Dec 15, 2014
Hope it helps! Be sure and pass along what ya find useful. I still want to build up a ford one day. Have a couple orphan sad bastard blocks laying around for when I do. Should have kept notes from when I was researching that a lot. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435767#435767 ________________________________________________________________________________
Date: Dec 16, 2014
Scotty, you might look at oratex Fabric. In our high school shop we are covering our Piet with Oratex. No chemicals, no paint. Easy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435771#435771 ________________________________________________________________________________
Date: Dec 16, 2014
Thank you everyone for your replies! Some great options! Scotty -------- Tamworth, Australia Building a Corvair Powered Pietenpol Air Camper www.scottyspietenpol.com Fuslage now on its undercarriage! About to start wing spars...Corvair engine at Roy's Garage waiting to be modified. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435781#435781 ________________________________________________________________________________
Subject: Another pietenpol egg has been laid
Date: Dec 16, 2014
Finally, I've committed to build a Piet! Not just any pietenpol,however, a Chad Wille Aeriel. This is a Biplane adaptation. Some one just threw a wrench at me but I ducked it's OK. I know the purists will probably throw me out of the pieten-polpit, but if it's any consolation, the lower wing is removable, so come on , can I stay? I've got a few ideas I'd like some input on if you're still reading. I'd like to try to source this build using primarily locally sourced materials. Around here(Oregon) that means Doug Fir. I realize the weight penalty(about 15%), but there is the strength increase as well. As far as spars go. I've noticed that some builders have used a routed spar to save considerable weight. Could the same result be obtained using a full depth web with spar caps laminated to either side top and bottom? For power I plan to use a William Wynn Corvair conversion. I would find it very helpful if someone could provide performance numbers for a normal aircamper powered by a 120hp Corvair Thanks. Glen Sent from my iPhone ________________________________________________________________________________
Subject: Re: nothing in particular
Date: Dec 16, 2014
Okkkvndvrnnn nn Hughsnet vdjjjjnnn bcdsdgb Sent from my iPhone John Kuhfahl President, KUHLCOUPER LLC On Dec 13, 2014, at 8:21 PM, Oscar Zuniga wrote: > Okay, Pieters- it's been a sad weekend, what with Vi Kapler leaving this e arth for judgement. May God find him to have been a good and faithful serva nt. > > We had our first sunny afternoon in a long while here in southern Oregon s o I went out to the hangar and changed out the bent fork end fitting on the l ower port side forward strut (one of the squawks at the last annual). Easie r than I thought, but then again I had a helper to wiggle the wing and hand m e tools, so it went well. Re-tensioned the X-brace cables, safetied them, a nd then taxied out to the fuel pumps to warm up the oil and top off the tank . It was nice to have the A75 come to life and carry me here and there with out complaint. At the pumps, I took on about 10 gallons when a Taylorcraft c ame taxiing up after an easy out-and-back flight to do what I had done on th e ramp... warm up the oil and knock off a little of the rust. We talked abo ut A65s and starters (he wants to upgrade to a C85 on the T-Cart), and how t he runway surface was at one of our nearby unpaved fields (Beagle Sky Ranch) . > > Even without flying, Scout provided enough sensory input to keep me going f or another week or two of fall and winter weather. Just firing up the engin e was enough, but taxiing out with gloves and flying helmet on and fueling a nd restarting and taxiing some more was just gravy. These airplanes are so r ewarding. > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Dec 16, 2014
Good point. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435794#435794 ________________________________________________________________________________
Subject: Re: Another pietenpol egg has been laid
From: "geraldmorrissey" <geraldmorrissey(at)yahoo.com>
Date: Dec 16, 2014
You may consider Port Orford cedar. It's source is close to you. Considered by many to be a great alternative to spruce for spars. Steen Aero used to recommend it for Skybolt spars. Cheers Gerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435796#435796 ________________________________________________________________________________
Date: Dec 16, 2014
Glen-- I agree Port Orford Cedar would be a great choice that is much better than Doug Fir. Unfortunately, disease wiped out many of these beautiful trees so it is hard to find good stuff. Back when it was plentiful it was used for arrow shafts and boat planking. Where are you in Oregon? --Mac, on Oregon coast > > Finally, I've committed to build a Piet! Not just any pietenpol,however, a > Chad Wille Aeriel. This is a Biplane adaptation. Some one just threw a > wrench at me but I ducked it's OK. I know the purists will probably throw > me out of the pieten-polpit, but if it's any consolation, the lower wing > is removable, so come on , can I stay? > I've got a few ideas I'd like some input on if you're still reading. > I'd like to try to source this build using primarily locally sourced > materials. Around here(Oregon) that means Doug Fir. I realize the weight > penalty(about 15%), but there is the strength increase as well. As far as > spars go. I've noticed that some builders have used a routed spar to save > considerable weight. Could the same result be obtained using a full depth > web with spar caps laminated to either side top and bottom? > For power I plan to use a William Wynn Corvair conversion. I would > find it very helpful if someone could provide performance numbers for a > normal aircamper powered by a 120hp Corvair Thanks. Glen > > Sent from my iPhone > > ________________________________________________________________________________
Date: Dec 16, 2014
You know, Tools, you could designate one of your tool-a-palooza work sessions as a Ford engine building session and I'll bet you could get a good group of people to attend with tools, parts, and skills needed to drag one of your project Model A engines out onto the table and start turning it into an airplane engine. Start out by posting what you need (head, mag, crank, whatever) and I'll bet you could get a nice engine put together when folks start dragging things out of their parts bins and showing up for the event with stuff in the trunks of their cars, or in their pickups, or even in some Piets if they fly in. Call it the Ford version of a Corvair College ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435801#435801 ________________________________________________________________________________
Date: Dec 16, 2014
Glen; Unless you just want a biplane because it's a biplane, be advised that an Aerial will weigh more than an Air Camper, take more time to build, require more space, require more power, not cruise any faster, cost more to build, and not have any better performance. I love biplanes, but to me the Aerial is an Air Camper with extra stuff stuck on it, and the result is no better than an Air Camper. I bought an Aerial as a project a few years ago, with the sole purpose of obtaining the beautiful set of spoked wheel landing gear that came with it. I donated the fuselage and wings to a school in Alaska so that the students could have a project to learn on and build. I have not heard how it is going up there. An Oregon builder could do a lot worse than to use locally available and affordable Doug fir for the build, knowing in advance that the airplane will be heavy and will require more power in order to perform. With 120HP available, you should have enough power. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435802#435802 ________________________________________________________________________________
Date: Dec 17, 2014
Hey oscar, I thought of that. I actually have a cylinder boring machine, a line boring machine and a valve grinder. Thought it would be cool to repour my own Babbitt as well. Even if you didn't fly the engine, everyone would learn a lot about how a rebuild goes, and how to measure and ensure proper clearances, which is really the key to a good rebuild anyway. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435805#435805 ________________________________________________________________________________
Date: Dec 17, 2014
What John said. If it was a good thing. Oscar, that's the best part of being at the airport. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435807#435807 ________________________________________________________________________________
Date: Dec 17, 2014
To the naysayers, I recommend the Robert Frost poem "The Road Not Taken". Since BHP was arguably the father of EXPERIMENTAL aviation, I think we should allow divergence and creativity. As Oscar pointed out, there are issues to be solved but half the fun in the process is finding elegant, workable solutions to problems. Ref the wood issues, since doug fir is stronger and heavier than Sitka, you could reduce the size of the longerons to 1 x 7/8 and still have the same strength as 1x1 Sitka. If you really wanted to go avante garde, you could make the spars from a 1/4 inch plywood web and 3/8 x 1 caps on each side top and bottom. I'm even betting that you could use 3/8 x 1/4 capstrips for the ribs. Aeronca used 1/4 x 1/4 on the Champs and Chiefs so there is some basis for that premise. The road less traveled may have some big potholes but it will eventually get you somewhere. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435810#435810 ________________________________________________________________________________
Date: Dec 17, 2014
Another possibility is Western Hemlock. Bernard Pietenpol used it in the last plane or two and said it worked good. I used to get 1-1/2 inch by 1/4 inch hemlock lathe at the lumberyard and pieces 16 feet long had over 24 rings to the inch with no ring leaving the board in 16 feet! I don't know if that stuff is still available, but with some looking you could probably find some. It is very comparable to spruce in strength and weight. --Mac in Oregon > > Glen; > > Unless you just want a biplane because it's a biplane, be advised that an > Aerial will weigh more than an Air Camper, take more time to build, > require more space, require more power, not cruise any faster, cost more > to build, and not have any better performance. > > I love biplanes, but to me the Aerial is an Air Camper with extra stuff > stuck on it, and the result is no better than an Air Camper. I bought an > Aerial as a project a few years ago, with the sole purpose of obtaining > the beautiful set of spoked wheel landing gear that came with it. I > donated the fuselage and wings to a school in Alaska so that the students > could have a project to learn on and build. I have not heard how it is > going up there. > > An Oregon builder could do a lot worse than to use locally available and > affordable Doug fir for the build, knowing in advance that the airplane > will be heavy and will require more power in order to perform. With 120HP > available, you should have enough power. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435802#435802 > > ________________________________________________________________________________
From: "johnnysdrop" <johnnysdrop(at)googlemail.com>
Date: Dec 18, 2014
Glen If you want a light spar use the UK approved Jim Wills spar, it is tested and used on most UK Pietenpols so has a lot of hours on the design. Basically consists of an 1/8th ply web scarfed from 50" sections with (from memory) 1.125" x 0.875" spruce caps on the front spar and 1" x 0.750" spruce caps on rear spars. There is various blocking in between the caps for lift struts, tip bows and root brackets to centre section, blocking for jury struts and for rib supports. This is then covered in 1/8th ply but only where any blocking exists. It's quite a lot of work but the finished spars ARE LIGHT, I know as have just built mine! If you want anymore info please email me and a word of caution, do not reduce sizes of materials because you think something is stronger in a different spec material without a full analysis of the component. Regards English Johnny Building the 3 piece Wills wing -------- The only way is UP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435827#435827 ________________________________________________________________________________
Date: Dec 18, 2014
I'm using Doug Fir almost exclusively in my Piet and I first considered lowering the dimentions of the members. But I thought, "Hey! down the line this might cause a problem (changing the dimentions.) So I used the plans dimentions. Don't know yet how much difference the weight will be, but I'm using a larger engine (Corvair) so maybe the performance will be at least as good as a spruce airplane with a 65HP engine. On Wed, Dec 17, 2014 at 8:05 PM, wrote: > > Another possibility is Western Hemlock. Bernard Pietenpol used it in the > last plane or two and said it worked good. I used to get 1-1/2 inch by > 1/4 inch hemlock lathe at the lumberyard and pieces 16 feet long had over > 24 rings to the inch with no ring leaving the board in 16 feet! I don't > know if that stuff is still available, but with some looking you could > probably find some. It is very comparable to spruce in strength and > weight. > --Mac in Oregon > > > > > > > > Glen; > > > > Unless you just want a biplane because it's a biplane, be advised that an > > Aerial will weigh more than an Air Camper, take more time to build, > > require more space, require more power, not cruise any faster, cost more > > to build, and not have any better performance. > > > > I love biplanes, but to me the Aerial is an Air Camper with extra stuff > > stuck on it, and the result is no better than an Air Camper. I bought > an > > Aerial as a project a few years ago, with the sole purpose of obtaining > > the beautiful set of spoked wheel landing gear that came with it. I > > donated the fuselage and wings to a school in Alaska so that the students > > could have a project to learn on and build. I have not heard how it is > > going up there. > > > > An Oregon builder could do a lot worse than to use locally available and > > affordable Doug fir for the build, knowing in advance that the airplane > > will be heavy and will require more power in order to perform. With > 120HP > > available, you should have enough power. > > > > -------- > > Oscar Zuniga > > Medford, OR > > Air Camper NX41CC "Scout" > > A75 power > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=435802#435802 > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 18, 2014
On Wed, Dec 17, 2014 at 10:56 AM, dgaldrich wrote: > dgaldrich(at)embarqmail.com> > > To the naysayers, I recommend the Robert Frost poem "The Road Not Taken". > > Since BHP was arguably the father of EXPERIMENTAL aviation, I think we > should allow divergence and creativity. As Oscar pointed out, there are > issues to be solved but half the fun in the process is finding elegant, > workable solutions to problems. > > Ref the wood issues, since doug fir is stronger and heavier than Sitka, > you could reduce the size of the longerons to 1 x 7/8 and still have the > same strength as 1x1 Sitka. If you really wanted to go avante garde, you > could make the spars from a 1/4 inch plywood web and 3/8 x 1 caps on each > side top and bottom. I'm even betting that you could use 3/8 x 1/4 > capstrips for the ribs. Aeronca used 1/4 x 1/4 on the Champs and Chiefs so > there is some basis for that premise. > > The road less traveled may have some big potholes but it will eventually > get you somewhere. > > Dave > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435810#435810 > > ________________________________________________________________________________
Subject: It is no longer "Lance Captain" Mike Danford
Date: Dec 18, 2014
Hello Good Pietple, In the Marine Corps there is the rank of Lance Corporal which is one rank below Corporal. You are not a lowly Private First Class, but you are not yet a Corporal. You are a Lance Corporal. Several months ago Mike Danford, aka "Tools" on this forum, got a Captain bid here at Delta, our mutual employer. As he was no longer just a First Officer but not quite a Captain , I began calling him Lance Captain Danford whenever I talked to him. Well, Mike is Lance Captain Danford no more. And the pictures shows the four stripes to prove it. Mike is the one on the right. The one with hair and who does not (yet) need glasses. Congrats to Mike! By flying the MD88 ( which I lovingly refer to as 'the tube of pain') he will rapidly exceed his Pietenpol flying hours. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435832#435832 Attachments: http://forums.matronics.com//files/image_501.jpg ________________________________________________________________________________
Subject: Re: It is no longer "Lance Captain" Mike Danford
Date: Dec 18, 2014
Congratulations! Now he can buy the SECOND round for all of us! [Wink] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435834#435834 ________________________________________________________________________________
Date: Dec 18, 2014
Congratulations, Tools! Nice to know the guy in the left seat's been approved! -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435836#435836 ________________________________________________________________________________
Subject: Another Pietenpol
Date: Dec 18, 2014
With the recent emails about building an Aerial I thought I would post some pics of several "Barn Finds" out in a little town called Jensen in Eastern Utah at a private airfield. The older Gentleman David Karren owned 7 airp lanes among them was a Pietenpol Sky Scout, an Aerial both he built himself and a early Baby Ace. There is also a picture of the Sky Scout on Westcoas t piet in the snow. Brian SLC-UT ________________________________________________________________________________
Date: Dec 18, 2014
Oh ya, beers on me... But ya gotta come to toolstock to get them! My life of luxury is over. Most heavy drivers coming back down to a light twin tend to flare high. But as it turns out, I have WAY more stick time in the Piet than the A330 over the last three years... Sooooo... Treated my first 700 passengers to a proper landing. One where ya land like ya mean it! Ya... One day off then the final trip complete with an observation by the Feds... THEN the Lance goes fully away. Hopefully it'll warm up enough to get a fee landings in the Piet before I lose my touch. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435841#435841 ________________________________________________________________________________
Subject: Wing rib help!
Date: Dec 18, 2014
Hi Guys, I've just finished my 3rd rib and just found out that I should have been making "test strips" with every batch of epoxy [Shocked] . What are these and how do i make them? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435842#435842 ________________________________________________________________________________
Subject: Re: Wing rib help!
Date: Dec 18, 2014
Uh... You using a one to one ratio epoxy, probably t88? Have no clue what a test strip is! Can tell you if you have any idea how to form two piles of goo that are different colors the same size, and aren't color blind enough to the point you have no idea if they're mixed (meaning you can tell when they are), you'll be fine! Now, if you're mixing a specialized epoxy to hold tunnel support rods in an underwater tunnel in Boston... I'd get a little worried! Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435843#435843 ________________________________________________________________________________
Date: Dec 18, 2014
I didn't know that a pietenpol had a left seat!?? Congratulations Captain! Glen Sent from my iPhone > On Dec 18, 2014, at 6:52 AM, "tkreiner" wrote: > > > Congratulations, Tools! > > Nice to know the guy in the left seat's been approved! > > -------- > Tom Kreiner > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435836#435836 > > > > > > > > > > ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Date: Dec 18, 2014
Wow Brian---those were some GREAT barn finds out in Utah. Thank you for sharing the photos and your discovery! Mike C. Ohio ________________________________________________________________________________
Date: Dec 18, 2014
A test strip tests the bond strength of each mixed batch of epoxy. Do two. One to test to destruction, one to keep. Glue scraps using the same clamp method as the joints you made Sent from my iPhone > On Dec 18, 2014, at 7:26 AM, "rkirk77" wrote: > > > Hi Guys, > > I've just finished my 3rd rib and just found out that I should have been making "test strips" with every batch of epoxy [Shocked] . > > What are these and how do i make them? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435842#435842 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 18, 2014
Hi Tools, Yes, I am using T-88 Epoxy and mixing it at a 1:1 ratio (.. or near as I can tell.. lol). Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435848#435848 ________________________________________________________________________________
Date: Dec 18, 2014
Glen - Put one overlapping the other? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435849#435849 ________________________________________________________________________________
Date: Dec 18, 2014
Glen's idea is even better, gluing scrap with the leftover. You'll feel comfortable and confident soon enough. Glen's suggestion will also give you an idea where you're using too much or too little glue. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435850#435850 ________________________________________________________________________________
Date: Dec 18, 2014
I always use too much glue on all of my joints.. ROFL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435851#435851 ________________________________________________________________________________
Date: Dec 18, 2014
First, thanks! What terry didn't mention was that neither did I! I put the preference in over ten years ago and forgot it was there! We have a saying, bid what ya want, and want what ya bid... Wups! It was time anyway, I was starting to get a little surly... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435852#435852 ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Dec 18, 2014
Way to go, Tools! Maybe now, since you are worthy of a salute, we should reverse your name and call you Sloot! Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jarheadpilot82 Sent: Thursday, December 18, 2014 9:20 AM Subject: Pietenpol-List: It is no longer "Lance Captain" Mike Danford Hello Good Pietple, In the Marine Corps there is the rank of Lance Corporal which is one rank below Corporal. You are not a lowly Private First Class, but you are not yet a Corporal. You are a Lance Corporal. Several months ago Mike Danford, aka "Tools" on this forum, got a Captain bid here at Delta, our mutual employer. As he was no longer just a First Officer but not quite a Captain , I began calling him Lance Captain Danford whenever I talked to him. Well, Mike is Lance Captain Danford no more. And the pictures shows the four stripes to prove it. Mike is the one on the right. The one with hair and who does not (yet) need glasses. Congrats to Mike! By flying the MD88 ( which I lovingly refer to as 'the tube of pain') he will rapidly exceed his Pietenpol flying hours. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435832#435832 Attachments: http://forums.matronics.com//files/image_501.jpg ________________________________________________________________________________
Date: Dec 18, 2014
Got a new guy in my s3 squadron... He farted a lot, we called him stool. Before him I was the fart king. Although we looked way different, we both had jet black hair and monster eyebrows and people got us mixed up all the time. We eventually both became known as stools! Practically nothing in this world is new! Maybe go with sloots?! Not my call... Of course lots of folks would joke about just calling me tool... Which, again, wasn't my call, but I would remind them of self fulfilling prophecies! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435854#435854 ________________________________________________________________________________
Subject: Re: Another Pietenpol
Date: Dec 18, 2014
Wow! A Sky Scout with a Corvair engine! Sure would like to see some performance numbers. When did it last fly? I love those wheels, wonder what they are. Thanks, Ray Krause Building SkyScout Sent from my iPad > On Dec 18, 2014, at 7:45 AM, Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC] wrote: > > > Wow Brian---those were some GREAT barn finds out in Utah. Thank you for sharing the photos and your discovery! > > Mike C. > Ohio > > > > > > ________________________________________________________________________________
Date: Dec 18, 2014
Very cool find! Thank you for sharing them with us! What is the model in the second photo? -------- Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435860#435860 ________________________________________________________________________________
Date: Dec 18, 2014
Brian, So did you buy it? [Wink] Are those VG's on the upper surface of the Sky Scout wing? Thanks for sharing! -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435861#435861 ________________________________________________________________________________
Date: Dec 18, 2014
What was this toolstock thing again ? Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435862#435862 ________________________________________________________________________________
Date: Dec 18, 2014
Hey Terry, Did Mike order a larger hat size as well? LOL Wink Barry -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jarheadpilot82 Sent: Thursday, December 18, 2014 9:20 AM Subject: Pietenpol-List: It is no longer "Lance Captain" Mike Danford --> Hello Good Pietple, In the Marine Corps there is the rank of Lance Corporal which is one rank below Corporal. You are not a lowly Private First Class, but you are not yet a Corporal. You are a Lance Corporal. Several months ago Mike Danford, aka "Tools" on this forum, got a Captain bid here at Delta, our mutual employer. As he was no longer just a First Officer but not quite a Captain , I began calling him Lance Captain Danford whenever I talked to him. Well, Mike is Lance Captain Danford no more. And the pictures shows the four stripes to prove it. Mike is the one on the right. The one with hair and who does not (yet) need glasses. Congrats to Mike! By flying the MD88 ( which I lovingly refer to as 'the tube of pain') he will rapidly exceed his Pietenpol flying hours. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435832#435832 Attachments: http://forums.matronics.com//files/image_501.jpg ________________________________________________________________________________
Date: Dec 18, 2014
It's a Baby Ace, I think he told me it was a 1929. Brian SLC-UT -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of curtdm(at)gmail.com Sent: Thursday, December 18, 2014 10:06 AM Subject: Pietenpol-List: Re: Another Pietenpol --> Very cool find! Thank you for sharing them with us! What is the model in the second photo? -------- Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435860#435860 ________________________________________________________________________________
Subject: Winter Flying!
Date: Dec 18, 2014
Dang it was cold last Saturday, but hey..somebody's gotta do it. Barry Davis NX973BP ________________________________________________________________________________
Date: Dec 18, 2014
Dan, That is a weekend where anyone and everyone who wants to can come camp out at Tool's house and use his equipment. It may be some that you may not have Normal access to. VERY extensive collection of tools, hence the call sign. He is the only guy I know with 3 phase power to his personal shop, if that tells you anything. I like to refer to it as "Toolapalooza" myself. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435864#435864 ________________________________________________________________________________
Date: Dec 18, 2014
Correction... A/W date shows it's a 1990. Brian -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of brian.e.jardine(at)L-3com.com Sent: Thursday, December 18, 2014 10:13 AM Subject: RE: Pietenpol-List: Re: Another Pietenpol It's a Baby Ace, I think he told me it was a 1929. Brian SLC-UT -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of curtdm(at)gmail.com Sent: Thursday, December 18, 2014 10:06 AM Subject: Pietenpol-List: Re: Another Pietenpol --> Very cool find! Thank you for sharing them with us! What is the model in the second photo? -------- Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435860#435860 ________________________________________________________________________________
Date: Dec 18, 2014
Date: Dec 18, 2014
Good idea! That way would be great for comparison. Sent from my iPhone > On Dec 18, 2014, at 7:52 AM, "rkirk77" wrote: > > > Glen - Put one overlapping the other? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435849#435849 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 18, 2014
The subject once again is T-88. Good stuff. One concern is thermal resistance. Try this. Then tell me what you think: glue a piece of 1.5mm ply to a piece of wood let it cure. Use your covering iron to get the ply just slightly too hot to touch. The ply will peel off like a post it note. With thousands of planes being built using T-88, obviously it works, but should this be a concern? Sent from my iPhone > On Dec 18, 2014, at 7:50 AM, "rkirk77" wrote: > > > Hi Tools, > > Yes, I am using T-88 Epoxy and mixing it at a 1:1 ratio (.. or near as I can tell.. lol). > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435848#435848 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 18, 2014
Last weekend in February, just a weekend where folks show up and use my shops and machine tools to do projects. Started as a group of folks who restore woodworking tools. Starting last year, expanding to home builders as well. Can crash anywhere, have a decent sized house available, thirty five acres, a couple motor homes, spare tents, a box truck... Don't matter! We just pass the hat and cook onsite, lots of coolers full of everything, goes from Thursday to sun. Usually lots of shooting as well. Have had machine guns show up, rifles, shotguns, pistols... WWII vintage, you name it. My piet should be available for rides, might have access to a 182 this year as well if anyone needs a bfr or something. Go to OWWM.ORG and search toolstock, and youtube search toolstock '10 for pics, movies and discussion. It's free, casual, no schedule. Looks like we will have accomplished aircraft welding mentors available this year as well as a tech advisor or two. Insofar as piets, can play with a ford a block, make, rout, mill wing spars. Mill wood, cut parts on a metal cutting saw. Might have an a and p available if someone wants to fly in and get an annual. Have a couple grass fields nearby, and a rather varsity strip at the house. Might be a hundred folks, might be ten. About 40 to 50 during the event is normal. Kinda fun. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435870#435870 ________________________________________________________________________________
Date: Dec 18, 2014
That's one reason T-88 isn't approved by the FAA for repair work on certificated airplanes. As far as I know, the only glue approved by the FAA is Resorcinol. Resorcinol meets a Mil Spec that requires, among other things, being able to be immersed in boiling water for 24 hours with no loss of strength. That's very handy to know, if you ever plan to boil your airplane. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of glenschweizer(at)yahoo.com Sent: Thursday, December 18, 2014 12:37 PM Subject: Re: Pietenpol-List: Re: Wing rib help! The subject once again is T-88. Good stuff. One concern is thermal resistance. Try this. Then tell me what you think: glue a piece of 1.5mm ply to a piece of wood let it cure. Use your covering iron to get the ply just slightly too hot to touch. The ply will peel off like a post it note. With thousands of planes being built using T-88, obviously it works, but should this be a concern? Sent from my iPhone > On Dec 18, 2014, at 7:50 AM, "rkirk77" wrote: > > > Hi Tools, > > Yes, I am using T-88 Epoxy and mixing it at a 1:1 ratio (.. or near as I can tell.. lol). > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435848#435848 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 18, 2014
Brian, Great photos, especially of the man himself. I have never met him in person, but he corresponded with many people, and in the late 1980s and early 1990s he wrote short bits and sent photos in to the Buckeye and international newsletters. When I first started working with Corvairs, he was one of the few people writing about what he was up to. His Corvair/Scout snow photo is popular, it has been on our old site for 15 years, it is the 2nd one down at this link: http://www.flycorvair.com/planes.html Mr. Karren wrote about flying in UT, often mentioned that his field elevation was something like 7,000' Nice to see that he is still out there and his work is in good condition. -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435872#435872 ________________________________________________________________________________
Date: Dec 18, 2014
I am also using 1/4" nails.. and I am keeping them in. :) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435873#435873 ________________________________________________________________________________
Date: Dec 18, 2014
Keep in mind all my stuff came off a scrap truck. Some restored to original, most is reasonable, some barely working and some pure yard art. I spend my time showing folks idiosyncrasies of tools, looking for tooling amongst the clutter, fixing neglected stuff and drinking! I invite as many mentors as I can, but it's very much a what YOU make of it event. Come with a project, help someone else, just watch, doesn't matter. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435875#435875 ________________________________________________________________________________
Date: Dec 18, 2014
My Resorcinal pretty ugly....dang, I guess I can't steam clean those spots! On Dec 18, 2014 12:46 PM, "Jack Phillips" wrote: > jack(at)bedfordlandings.com> > > That's one reason T-88 isn't approved by the FAA for repair work on > certificated airplanes. As far as I know, the only glue approved by the > FAA > is Resorcinol. Resorcinol meets a Mil Spec that requires, among other > things, being able to be immersed in boiling water for 24 hours with no > loss > of strength. That's very handy to know, if you ever plan to boil your > airplane. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > glenschweizer(at)yahoo.com > Sent: Thursday, December 18, 2014 12:37 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Wing rib help! > > > The subject once again is T-88. Good stuff. One concern is thermal > resistance. Try this. Then tell me what you think: glue a piece of 1.5mm > ply to a piece of wood let it cure. Use your covering iron to get the ply > just slightly too hot to touch. The ply will peel off like a post it note. > With thousands of planes being built using T-88, obviously it works, but > should this be a concern? > > Sent from my iPhone > > > On Dec 18, 2014, at 7:50 AM, "rkirk77" wrote: > > > > > > Hi Tools, > > > > Yes, I am using T-88 Epoxy and mixing it at a 1:1 ratio (.. or near as I > can tell.. lol). > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=435848#435848 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 18, 2014
Unbelievably, casein glue is also legal on some planes... Is the heat thing a concern? I just REALLY don't know. Boat builders sure put the screws to the stuff, is that comforting? Again... I'm not so sure the reason epoxy isn't legal isn't the same reason casein is. As in the case of the l-5. Pretty sure there isn't an ad requiring you to make sure microbes haven't eaten your glue. That airplane is totally dependent on glue in the wings, doesn't even have anti drag wires, rather plywood shear panels. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435877#435877 ________________________________________________________________________________
Date: Dec 18, 2014
Tools please mention the dates and your location again. We may be coming back from Florida about then... Sent from my iPad Jack Textor > On Dec 18, 2014, at 11:50 AM, "tools" wrote: > > > Keep in mind all my stuff came off a scrap truck. Some restored to original, most is reasonable, some barely working and some pure yard art. I spend my time showing folks idiosyncrasies of tools, looking for tooling amongst the clutter, fixing neglected stuff and drinking! > > I invite as many mentors as I can, but it's very much a what YOU make of it event. Come with a project, help someone else, just watch, doesn't matter. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435875#435875 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 18, 2014
I just finished my 30th rib, (so you know I have not tested my Piet). The way I test is to take each Popsicles stick that I applied that batch with and apply it together with a scrap piece of plywood. After two days I tear them apart. I make sure the joint tears apart with wood fiber, not at the glue joint. -------- Scott Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435880#435880 ________________________________________________________________________________
Date: Dec 18, 2014
Would be great to have you! Feb 26 to mar 1. Always welcome by anytime though. I may or may not be there, but someone will. Chickamauga ga, just south of chatt tn. Closest interstate exit, battlefield parkway off I-75, last exit in ga. Or the Trenton exit off I-59. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435881#435881 ________________________________________________________________________________
Subject: a little more about the all metal Piet builder
Date: Dec 18, 2014
He appears to be from Istanbul, Turkey. http://atolyecoptenadam.com [cid:image001.png(at)01D01AC8.75E44560] ________________________________________________________________________________
Subject: T-88 in the heat
Date: Dec 18, 2014
Glen, I used T-88 for every glue joint in my Pietenpol and I have had it out in the sun on 90, 95, and 97F days and flown it on those days with bumpy turbulence and nothing fell apart due to T-88 softening so I would say ignore any thoughts or worries about using T-88 from that standpoint. Should this be a concern? No. You have bigger fish to fry. Merry Christmas! Mike C. ________________________________________________________________________________
Subject: all metal Pietenpol
Date: Dec 18, 2014
https://www.youtube.com/watch?v=AubJnqouy78 28 second video. I know about as much about this project as you. Mike C. Ohio Oh yes.....and their human-powered helicopter too.....35 seconds. https://www.youtube.com/watch?v=RDoyZAfDAYw ________________________________________________________________________________
Date: Dec 18, 2014
I built some Smith Termite ribs back in 1968. They have been hanging in various places in all kind of temperature and humidity conditions unvarnished ever since. Last year I tested one to destruction and the wood broke before the glue bond. The glue was Weldwood Plastic Resin. I've built a lot of stuff with T-88 but still love the plastic resin the best. Mix with water, fool proof. Cheers Gerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435886#435886 ________________________________________________________________________________
Subject: Re: all metal Pietenpol
Date: Dec 18, 2014
Good stuff Mike. That helicopter would have VERY SHORT flights if I was to power it. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435893#435893 ________________________________________________________________________________
Date: Dec 18, 2014
Glen, I think it is a great idea. So what if it is slow. So is my Piet. :) Biplanes are cool. We need variety and Pietenpol's seem to offer more variety than any other homebuilt I can think of. Like Mike C says, "They are all snowflakes". I can't wait to see it. Cheers and happy building, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435894#435894 ________________________________________________________________________________
Subject: Re: Winter Flying!
Date: Dec 18, 2014
Beautiful! This may be considered torture! How much down pitch do you have o n your engine mount? Thanks, Ray Krause Building Sky Scout Sent from my iPad > On Dec 18, 2014, at 9:17 AM, Barry Davis wrote: > > Dang it was cold last Saturday, but hey.somebody=99s gotta d o it. > Barry Davis > NX973BP > > > ________________________________________________________________________________
Date: Dec 18, 2014
Con llll gratula llll tions -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435903#435903 ________________________________________________________________________________
Subject: Re: T-88 in the heat
Date: Dec 19, 2014
I have done the FAA "Glue Boil Test" using T-88 .... nothing came apart. An interesting read; From "Construction Notes" Falco Builders Letter." (http://www.seqair.com/skunkworks/Glues/Notes/Notes.html) WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435905#435905 ________________________________________________________________________________
Date: Dec 19, 2014
I also love T-88 easy to use and reliable. I used it on my first Piet as we ll as my current Piet project. Lately I have been building a boat=2C GLen-L Sea Knight and have used T-88 on all structural parts. Craig > Subject: Pietenpol-List: Re: T-88 in the heat > From: Love2Fly.KAP(at)gmail.com > Date: Fri=2C 19 Dec 2014 04:45:25 -0800 > To: pietenpol-list(at)matronics.com > > > > I have done the FAA "Glue Boil Test" using T-88 .... nothing came apart. > > An interesting read=3B From "Construction Notes" Falco Builders Letter." (http://www.seqair.com/skunkworks/Glues/Notes/Notes.html) > > WF2 > > -------- > > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435905#435905 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Dec 19, 2014
Some of you may remember Douwe's FIRST Piet, the one hop wonder. I still think it was the best looking Piet built in the last 10 years but I digress. We started repairs on one one wing at Sun N Fun a couple of years ago and discovered that the gussets on the ribs could be popped off with a pen knife with the wood left perfectly intact. Not good. The ribs were assembled with casien glue aka plastic resin. At the time, it was available from AS&S as well as others even though AC 43-13 cautioned against it. Hopefully Douwe himself will chime in on the issues it caused and the effort that went into making RePiet Several years ago, as an experiment, I made test pieces to compare T-88, Resorcinol, and West Systems. The T-88 was mixed by eye, the Resorcinol by weight and the West System by volume. I used Sitka cap strip and Okoume gussets to make a Tee and then slowly applied pressure until something happened. In all cases except one, the wood failed. The single failure was an improperly built Tee. It is my opinion the reason the FAA does not list epoxy as "accepted" or "approved" in 43-13 is because there are so many kinds with wildly differing quality. I further suspect that none of the manufacturers want to go through hoops to get their products recognized and then ride the liability tail for 17 years or whatever it is now. I have a dollar in my pocket that says both T-88 and West Systems could pass whatever mil or astm spec that applies. If anybody knows what specific testing is involved, it might be a useful data point. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435919#435919 ________________________________________________________________________________
Date: Dec 19, 2014
Apparently Weldwood Plastic resin is not a casine glue. It's a ureaformaldehyde wood glue I may be wrong on this but from what I can tell from a web search and Weldwoods web page, it's not the same stuff. Also plastic resin has a shelf life which a lot of people don't know about, must be applied correctly (a little thick), needs sufficient clamping pressure and can be real messy. Gerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435925#435925 ________________________________________________________________________________
Subject: Re: making progress on Sky Scout
Date: Dec 19, 2014
Hi everyone, The last week has been productive and I have my plane all together and rigge d. I have the covering material and will start after the New Year. Just a co uple pictures, if I can add them. The cowling and other metal work is done, also. Ray Krause > > >
Date: Dec 20, 2014
Looking good, Ray! If my experience is any indication, you should have it flying in about a year from now. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause Sent: Friday, December 19, 2014 10:30 PM Subject: Re: Pietenpol-List: Re: making progress on Sky Scout Hi everyone, The last week has been productive and I have my plane all together and rigged. I have the covering material and will start after the New Year. Just a couple pictures, if I can add them. ________________________________________________________________________________
Date: Dec 20, 2014
From: "Charles N. Campbell" <charlescampbell1924(at)gmail.com>
Jack, Gad Zooks! I hope you're wrong. I'm not anywhere near where he is and I hope to fly this summer. Could be wrong! On Sat, Dec 20, 2014 at 8:45 AM, Jack Phillips wrote: > jack(at)bedfordlandings.com> > > Looking good, Ray! If my experience is any indication, you should have it > flying in about a year from now. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause > Sent: Friday, December 19, 2014 10:30 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: making progress on Sky Scout > > Hi everyone, > > The last week has been productive and I have my plane all together and > rigged. I have the covering material and will start after the New Year. > Just > a couple pictures, if I can add them. > > ________________________________________________________________________________
Date: Dec 20, 2014
Beautiful work , Ray! Anxious to see you cowl. Thanks for sharing. Glen Sent from my iPhone > On Dec 19, 2014, at 7:30 PM, Ray Krause wrote: > > Hi everyone, > > The last week has been productive and I have my plane all together and rigged. I have the covering material and will start after the New Year. Just a couple pictures, if I can add them. > > > > > The cowling and other metal work is done, also. > > > > > Ray Krause > > >
Date: Dec 20, 2014
Jack, You are probably about right. As I read the Stewart info, it looks like a lot of steps to get her done. But I will keep plugging away. Ray Sent from my iPad > On Dec 20, 2014, at 5:45 AM, Jack Phillips wrote: > > > Looking good, Ray! If my experience is any indication, you should have it > flying in about a year from now. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause > Sent: Friday, December 19, 2014 10:30 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: making progress on Sky Scout > > Hi everyone, > > The last week has been productive and I have my plane all together and > rigged. I have the covering material and will start after the New Year. Just > a couple pictures, if I can add them. > > > > > > ________________________________________________________________________________
Date: Dec 20, 2014
Ray; she's a beauty! Coming together nicely. Question: what diameter are the wing X-brace cables on the airplane? They don't look like 1/8". -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435940#435940 ________________________________________________________________________________
Date: Dec 20, 2014
Interesting undercarriage configuration. What were your contemplations to build it like this? On Sat, Dec 20, 2014 at 4:30 AM, Ray Krause wrote: > Hi everyone, > > The last week has been productive and I have my plane all together and > rigged. I have the covering material and will start after the New Year. > Just a couple pictures, if I can add them. > > > The cowling and other metal work is done, also. > > > Ray Krause > > > > > > > > >
      > www.aeroelectric.com
      > http://www.buildersbooks.com">www.buildersbooks.com
      > www.homebuilthelp.com
      > www.mypilotstore.com
      > www.mrrace.com
      > http://www.matronics.com/contribution>
      > http://www.matronics.com/Navigator?Pietenpol-List>
      > http://forums.matronics.com>
Date: Dec 20, 2014
Oscar, my plans call for 3/32 wire for the wing x-brace cables. Chuck On Sat, Dec 20, 2014 at 12:55 PM, taildrags wrote: > > Ray; she's a beauty! Coming together nicely. Question: what diameter are > the wing X-brace cables on the airplane? They don't look like 1/8". > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > >
http://forums.matronics.com/viewtopic.php?p=435940#435940 > > ________________________________________________________________________________
Date: Dec 20, 2014
Garrit, The landing gear is built exactly to plans for the Sky Scout. My understandi ng is that the Sky Scout was designed and built AFTER the Air Camper and in r esponse to complaints of potential builders to the cost of the Model A engin e. So Bernard designed the Scout as a single place plane with the Model T en gine ( 25 Hp on a good day) that was very plentiful and almost free because t he A had come out. The T's were filling up the junk yards! An A-65 should ma ke it a hot rod! The Scout has the same wing, tail and a little shorter fuselage. I guess the gear was designed as an alternative for the "lighter" Scout. It is interest ing that the plans for the gear just call for a spring that "is about 11" lo ng and will hold about 400 lbs". Finding that spring is/was quite the chall enge. Harley spring forks have springs the right diameter but too long and p rogressive... do not work, too springy! Living in a farm community, I found a GlenCo chisel spring plow spring that is close, but not yet stiff enough. B ut I think it can be fixed with some fooling around. I'm becoming a "spring e ngineer" (spring rate and spring load). Suggestions are welcome! The gear placement is also according to plans and may not jive with William W ynn's findings for gear placement (relation of wheel center to leading edge) . I will find out. It is also interesting that the plans call for the wing to be "sloped back 5 inches". I'm just using a modified J-3 tank as a header tank instead of a w ing tank. That should help the CG, at least when it is full? I also added a n inch to the mount. Guess I can always hang a 100 lb sack of beans between the landing gear (lots of room there) if I'm still tail heavy. I figure two hours in the Scout might be enough! When I fly it to Brodhead, over the Sie rras and Rockies, I might need a wing tank, too! How's that for an answer to a simple question? Ray Krause Sent from my iPad > On Dec 20, 2014, at 10:58 AM, Gerrit-Jan Kaal wrote: > > Interesting undercarriage configuration. What were your contemplations to b uild it like this? > >> On Sat, Dec 20, 2014 at 4:30 AM, Ray Krause w rote: >> Hi everyone, >> >> The last week has been productive and I have my plane all together and ri gged. I have the covering material and will start after the New Year. Just a couple pictures, if I can add them. >> >> >> >> >> The cowling and other metal work is done, also. >> >> >> >> >> Ray Krause >> >> > >> > >> > >> >>
      >> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
      3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3
      D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
      >> Gifts!)
      >> br> ttp://www.aeroelectric.com" target="_blank">http://www.aeroelectric
      .com">www.aeroelectric.com
      >> ot;http://www.buildersbooks.com">www.buildersbooks.com
      >> http://www.homebuilthelp.com" target="_blank">http://www.homebuilthelp.
      com">www.homebuilthelp.com
      >> "http://www.mypilotstore.com" target="_blank">http://www.mypilotstore.c
      om">www.mypilotstore.com
      >> ="http://www.mrrace.com" target="_blank">http://www.mrrace.com">www.m
      rrace.com
      >> nics.com/contribution" target="_blank">http://www.matronics.com/contrib
      ution">http://www.matronics.com/contribution>
      >>   =C3=82  =C3=82  =C3=82  =C3=82  =C3=82  -Matt Dralle, List Admin.
      >> nics.com/Navigator?Pietenpol-List" target="_blank">http://www.matronics
      .com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-
      List
      >> EB FORUMS -
      >> tronics.com" target="_blank">http://forums.matronics.com">http://forums
      .matronics.com
> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Dec 20, 2014
Oscar, The plans for the Scout call for 3/32" cable for all the cross bracing on th e Scout and solid 14G wire for the tail, where I used 1/6" cable. I have the AirCamper plans, but could not find the call-out for the wing cables to mak e a comparison. As an engineer, do you think 3/32" is enough? You certainly have a good eye. Did you notice the idler cable for the ailero ns above the fabric on the wing? Kind of neat, maybe it will work as a VG th ingy in some way! Hope it does not interfere with the lift, probably not muc h to spare! I assume Bernard test flew it and obviously survived. Thanks for the comments. Ray Sent from my iPad > On Dec 20, 2014, at 12:28 PM, Charles N. Campbell wrote: > > Oscar, my plans call for 3/32 wire for the wing x-brace cables. Chuck > >> On Sat, Dec 20, 2014 at 12:55 PM, taildrags wrote : >> >> Ray; she's a beauty! Coming together nicely. Question: what diameter ar e the wing X-brace cables on the airplane? They don't look like 1/8". >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=435940#435940 >> >> >> >> >> >> >> >> ========== >> br> fts!) >> r> > com" target="_blank">www.aeroelectric.com >> w.buildersbooks.com" target="_blank">www.buildersbooks.com >> p.com" target="_blank">www.homebuilthelp.com >> e.com" target="_blank">www.mypilotstore.com >> " target="_blank">www.mrrace.com >> target="_blank">http://www.matronics.com/contribution >> -Matt Dralle, List Admin. >> ========== >> br> enpol-List" target="_blank">http://www.matronics.com/Navigator?Piet enpol-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: glues
Date: Dec 20, 2014
Yeah, not a big fan of "plastic resin" glues. Douwe ________________________________________________________________________________
Date: Dec 20, 2014
Gosh, when I quit Delta in 86 I thought they were probably just about of them Navy surplus double breasted suits. Apparently, I was wrong. Why don't you call your airplane by its' real name (DC-9) on steroids.Do they still have the DC3 and the Fairchild? Now, THERES's a couple of beauties! -------- Just east of Graceland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435952#435952 ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Dec 20, 2014
Ed, DC-9 on some crappy steroids, if you ask me. I have a DC-9 type because of flying the MD88, although I have never set foot in the cockpit of any DC-9. Makes sense to me. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435953#435953 ________________________________________________________________________________
Subject: Vi Kapler hinges
Date: Dec 20, 2014
Update on the latest batch of hinges. I finished up a representative pair of hinges for load testing and rigged up the load testing jig=2C but ran ou t of daylight before I could run the test. I want to make sure everything is set up properly and can be photographed and documented before I run the test. It's really not anything fancy or esoteric... a lever arm gives me t he leverage to develop the required load on the hinges by using a 5 gallon pail that I'm going to fill with wet sand and then weigh after breakage. T he last set that Vi tested failed at about 700 lbs of static load=3B no fat igue testing was done and we know that aluminum fatigues but to my knowledg e there is no known or reported failure of these hinges and there are a lot of them out there. We expect the single-tab hinge half to be the part that fails since the mat ing double-tab half has twice as much area to carry its load and the AN3 cl evis pin is WAY stronger in shear than the cast aluminum hinge halves are i n tension. In Vi's test the single-tab hinge half broke right across the h inge pin axis. I suppose one other possible failure mode is "pull-out"=2C where the pull of the hinge pin against the top of the tab causes it to bre ak and the pin pulls through. My load test should go quickly. I have now used all of the (simple) tools and jigging that Vi used to make the parts in years past=2C and now that he's gone I look at each tool a lit tle bit differently than I did before. His hands were the last ones to tou ch the tools and jigs before I touched them today. I wish I could have got ten the first set of hinges completed before he died so I could have told h im about it=2C but I came pretty close. The first set of hinges from this new run has been promised for a long time to Bob Coolbaugh and Andrew King for the restoration of "Blitzkrieg"=2C wi th nine other builders' names on the list after them. When they are availa ble and ready to ship=2C I'll post that information here. Oscar ZunigaMedford=2C ORAir Camper NX41CC "Scout"A75 power=2C Culver prop ________________________________________________________________________________
Date: Dec 20, 2014
Still got the antiques. Not sure the dc-3 has been active though. Ya, seriously nice planes! Also never been in a dc-9 except my northwest interview... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435955#435955 ________________________________________________________________________________
Date: Dec 21, 2014
Looks great Ray! -------- riegerpietenpol.tumblr.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435961#435961 ________________________________________________________________________________
Subject: The Jeep powered pietenpol, Testing a front mounted radiator
Date: Dec 21, 2014
http://www.youtube.com/watch?v=dtNecdtPPSM I hope this url will lead you to my new video of my Jeep powered pietenpol. I am testing a new carburetor, and a new radiator set up in the front of the engine. I have mounted a Honda Goldwing radiator in front and it seems to be working ok. After warm up to max temp, the temp gauge showed 190 degrees at an idle. When I increased the rpm to about half throttle the temp decreased to 180 which seems to me a positive sign. As before my computer skills are pretty thin so if this link does not work, just go to Kenny crider and scroll down the list of videos to jeepenpol test run. Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435962#435962 ________________________________________________________________________________
Subject: Re: The Jeep powered pietenpol, Testing a front mounted
radiator
From: "Jeff Boatright" <jeffboatright(at)emory.edu>
Date: Dec 21, 2014
Looks and sounds great, Kenny! Did you get a fish scale run in? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435963#435963 ________________________________________________________________________________
Date: Dec 21, 2014
When I went to work for Delta we were flying ship 201, the first DC9 in service (DC9-14), When I left 17 years later we were still flying it. Couple years later it was sold to, I believe, Republic, then Atlanta. Don't know if it's still around. As all you Northworst guys know, Republic was later folded into Northwest. Geez, I must be getting old, remembering ancient history like that. -------- Just east of Graceland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435964#435964 ________________________________________________________________________________
Date: Dec 21, 2014
Ray Here is an Air Camper with the exposed wire above the fabric. http://westcoastpiet.com/images/Walt%20Bowe/images/IMG_1069.JPG It seems to have flown just fine. http://westcoastpiet.com/images/Walt%20Bowe/images/IMG_0144.JPG I wouldn=99t worry about yours. Chris Sacramento, CA WestcoastPiet.com From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause Sent: Saturday, December 20, 2014 1:35 PM Subject: Re: Pietenpol-List: Re: making progress on Sky Scout Oscar, The plans for the Scout call for 3/32" cable for all the cross bracing on the Scout and solid 14G wire for the tail, where I used 1/6" cable. I have the AirCamper plans, but could not find the call-out for the wing cables to make a comparison. As an engineer, do you think 3/32" is enough? You certainly have a good eye. Did you notice the idler cable for the ailerons above the fabric on the wing? Kind of neat, maybe it will work as a VG thingy in some way! Hope it does not interfere with the lift, probably not much to spare! I assume Bernard test flew it and obviously survived. Thanks for the comments. Ray Sent from my iPad On Dec 20, 2014, at 12:28 PM, Charles N. Campbell > wrote: Oscar, my plans call for 3/32 wire for the wing x-brace cables. Chuck On Sat, Dec 20, 2014 at 12:55 PM, taildrags > wrote: > Ray; she's a beauty! Coming together nicely. Question: what diameter are the wing X-brace cables on the airplane? They don't look like 1/8". -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435940#435940 br> fts!) r> > com" target="_blank">www.aeroelectric.com <http://www.aeroelectric.com> w.buildersbooks.com <http://w.buildersbooks.com> " target="_blank">www.buildersbooks.com <http://www.buildersbooks.com> p.com <http://p.com> " target="_blank">www.homebuilthelp.com <http://www.homebuilthelp.com> e.com <http://e.com> " target="_blank">www.mypilotstore.com <http://www.mypilotstore.com> " target="_blank">www.mrrace.com <http://www.mrrace.com> target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. br> enpol-List" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List FORUMS - _blank">http://forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ot;">www.aeroelectric.com <http://www.aeroelectric.com> books.com"">www.buildersbooks.com <http://www.buildersbooks.com> quot;">www.homebuilthelp.com <http://www.homebuilthelp.com> quot;">www.mypilotstore.com <http://www.mypilotstore.com> ">www.mrrace.com <http://www.mrrace.com> ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D npol-List"">http://www.matronics.com/Navigator?Pietenpol-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D <http://www.aeroelectric.com> <http://www.buildersbooks.com> <http://www.homebuilthelp.com> <http://www.mypilotstore.com> ________________________________________________________________________________
radiator
Date: Dec 21, 2014
Hi Jeff... yes I was disappointed in the new carburetor, I was 300 rpms short and about 50 lbs less on the scales. It ran very smoothly and the radiator worked great, but I may have to keep searching for the right carb. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435966#435966 ________________________________________________________________________________
radiator
Date: Dec 21, 2014
Good luck with the search and development. Dinking around with carbs is fun right to the second that it's not. But when it's correct, smooth and maximum power, boy is it worth it. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435967#435967 ________________________________________________________________________________
Date: Dec 21, 2014
Brian, Thanks. When will you be in Davis? Maybe we can get together again. Ray Sent from my iPad > On Dec 21, 2014, at 10:35 AM, Riegerb wrote: > > > Looks great Ray! > > -------- > riegerpietenpol.tumblr.com > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435961#435961 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 21, 2014
Thanks, Chris. I'm not really worried about it, just interested in it since this design cam e after the AirCamper. Was it just a test, or catering to whiners who wanted cheap and easy? I have the 146 photos that Jake took of the Sky Scout in th e museum outside Seattle. There are really great pictures of this feature. I will get them to you as soon as I transfer them to my computer. They would b e great on the Westcoastpiet site. It's all fun and games, it just makes me wonder. Ray Sent from my iPad > On Dec 21, 2014, at 12:16 PM, CatDesigns wrote: > > Ray > > Here is an Air Camper with the exposed wire above the fabric. > > http://westcoastpiet.com/images/Walt%20Bowe/images/IMG_1069.JPG > > It seems to have flown just fine. > > http://westcoastpiet.com/images/Walt%20Bowe/images/IMG_0144.JPG > > I wouldn=99t worry about yours. > > Chris > Sacramento, CA > WestcoastPiet.com > > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Ray Krause > Sent: Saturday, December 20, 2014 1:35 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: making progress on Sky Scout > > Oscar, > > The plans for the Scout call for 3/32" cable for all the cross bracing on t he Scout and solid 14G wire for the tail, where I used 1/6" cable. I have th e AirCamper plans, but could not find the call-out for the wing cables to ma ke a comparison. As an engineer, do you think 3/32" is enough? > > You certainly have a good eye. Did you notice the idler cable for the aile rons above the fabric on the wing? Kind of neat, maybe it will work as a VG t hingy in some way! Hope it does not interfere with the lift, probably not mu ch to spare! I assume Bernard test flew it and obviously survived. > > Thanks for the comments. > > Ray > > Sent from my iPad > > On Dec 20, 2014, at 12:28 PM, Charles N. Campbell wrote: > > Oscar, my plans call for 3/32 wire for the wing x-brace cables. Chuck > > On Sat, Dec 20, 2014 at 12:55 PM, taildrags wrote: > > Ray; she's a beauty! Coming together nicely. Question: what diameter are the wing X-brace cables on the airplane? They don't look like 1/8". > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435940#435940 > > > > > > > > ========== > br> fts!) > r> > com" target="_blank">www.aeroelectric.com > w.buildersbooks.com" target="_blank">www.buildersbooks.com > p.com" target="_blank">www.homebuilthelp.com > e.com" target="_blank">www.mypilotstore.com > " target="_blank">www.mrrace.com > target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > ========== > br> enpol-List" target="_blank">http://www.matronics.com/Navigator?Piete npol-List > ========== > FORUMS - > _blank">http://forums.matronics.com > ========== > > > > > > > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ot;">www.aeroelectric.com > books.com"">www.buildersbooks.com > quot;">www.homebuilthelp.com > quot;">www.mypilotstore.com > ">www.mrrace.com > ot;">http://www.matronics.com/contribution > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > npol-List"">http://www.matronics.com/Navigator?Pietenpol-List > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > //forums.matronics.com > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > > > www.aeroelectric.com > www.buildersbooks.com > www.homebuilthelp.com > www.mypilotstore.com > www.mrrace.com > http://www.matronics.com/contribution > http://www.matronics.com/Navigator?Pietenpol-List > http://forums.matronics.com > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
radiator
Date: Dec 21, 2014
Jeff, You are making great progress. How might the radiator work below the engine? Good research and development for those who might follow. Thanks for doing it, Ray Sent from my iPad > On Dec 21, 2014, at 11:34 AM, aviken wrote: > > > http://www.youtube.com/watch?v=dtNecdtPPSM I hope this url will lead you to my new video of my Jeep powered pietenpol. I am testing a new carburetor, and a new radiator set up in the front of the engine. I have mounted a Honda Goldwing radiator in front and it seems to be working ok. After warm up to max temp, the temp gauge showed 190 degrees at an idle. When I increased the rpm to about half throttle the temp decreased to 180 which seems to me a positive sign. > As before my computer skills are pretty thin so if this link does not work, just go to Kenny crider and scroll down the list of videos to jeepenpol test run. Thanks. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435962#435962 > > > > > > > > > > ________________________________________________________________________________
radiator
Date: Dec 21, 2014
Kenny, How do you know that your prop is right? Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of aviken Sent: Sunday, December 21, 2014 12:27 PM Subject: Pietenpol-List: Re: The Jeep powered pietenpol, Testing a front mounted radiator Hi Jeff... yes I was disappointed in the new carburetor, I was 300 rpms short and about 50 lbs less on the scales. It ran very smoothly and the radiator worked great, but I may have to keep searching for the right carb. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435966#435966 ________________________________________________________________________________
Subject: Re: Vi Kapler hinges
Date: Dec 21, 2014
I just completed the load test of the latest batch of hinges and am happy to report that they have met or exceeded the strength of the earlier ones that Vi tested. The test sample that Vi sent me had broken at 700 lbs and mine was loaded to over 900 lbs and it never broke. For anyone who is interested, details of my load testing are at http://www.flysquirrel.net/loadtest.html . -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435974#435974 ________________________________________________________________________________
radiator
Date: Dec 21, 2014
I don't know how to tell when you have the perfect match prop without trying as many different combinations as possible. I probably will build another one when I have time, maybe a little longer and a tad more pitch. When I used the previous carb, I was getting 2300 rpm and 225 lb on the fish scales, Now I'm getting 2000 and 180 lbs. so the carb is a big part of the picture. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435977#435977 ________________________________________________________________________________
Date: Dec 21, 2014
My error... The glue in Douwe's wing was plastic resin, not casien as originally stated. It appeared that the tail feathers were assembled using the same stuff but those joints were MUCH stronger. At the time, we suspected that it was used correctly on them and not on the ribs. The latest version of 43-13 says that urea-formeldehyde glues are only used with specific, case by case, FAA approval. AS&S no longer carries it. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435979#435979 ________________________________________________________________________________
Date: Dec 21, 2014
Ray; if the plans call for 3/32" for the wing strut x-brace cables, then far be it from me to second-guess the adequacy of it. Don't change a thing. FWIW, many standard catalog listings for galvanized 7x19 cable show a breaking strength of 1000 lbs. for 3/32" and 2000 lbs. for 1/8". -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435984#435984 ________________________________________________________________________________
Date: Dec 21, 2014
Thanks, Oscar. I am the proud user of a set of Vi's hinges. I will never worry about hinge failure! Ray Krause Sent from my iPad > On Dec 21, 2014, at 2:35 PM, taildrags wrote: > > > I just completed the load test of the latest batch of hinges and am happy to report that they have met or exceeded the strength of the earlier ones that Vi tested. The test sample that Vi sent me had broken at 700 lbs and mine was loaded to over 900 lbs and it never broke. For anyone who is interested, details of my load testing are at http://www.flysquirrel.net/loadtest.html . > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435974#435974 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 21, 2014
Thanks, Oscar. I will go with the plans and fly straight and level, only in good weather! Ray Sent from my iPad > On Dec 21, 2014, at 5:07 PM, taildrags wrote: > > > Ray; if the plans call for 3/32" for the wing strut x-brace cables, then far be it from me to second-guess the adequacy of it. Don't change a thing. FWIW, many standard catalog listings for galvanized 7x19 cable show a breaking strength of 1000 lbs. for 3/32" and 2000 lbs. for 1/8". > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435984#435984 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 21, 2014
Jack, I hate to admit it, but I bet you will be right! Thanks, Ray Sent from my iPad > On Dec 20, 2014, at 5:45 AM, Jack Phillips wrote: > > > Looking good, Ray! If my experience is any indication, you should have it > flying in about a year from now. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause > Sent: Friday, December 19, 2014 10:30 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: making progress on Sky Scout > > Hi everyone, > > The last week has been productive and I have my plane all together and > rigged. I have the covering material and will start after the New Year. Just > a couple pictures, if I can add them. > > > > > > ________________________________________________________________________________
Date: Dec 21, 2014
On Sat, Dec 20, 2014 at 7:18 PM, Oscar Zuniga wrote: > Update on the latest batch of hinges. I finished up a representative pair > of hinges for load testing and rigged up the load testing jig, but ran out > of daylight before I could run the test. I want to make sure everything is > set up properly and can be photographed and documented before I run the > test. It's really not anything fancy or esoteric... a lever arm gives me > the leverage to develop the required load on the hinges by using a 5 gallon > pail that I'm going to fill with wet sand and then weigh after breakage. > The last set that Vi tested failed at about 700 lbs of static load; no > fatigue testing was done and we know that aluminum fatigues but to my > knowledge there is no known or reported failure of these hinges and there > are a lot of them out there. > > We expect the single-tab hinge half to be the part that fails since the > mating double-tab half has twice as much area to carry its load and the AN3 > clevis pin is WAY stronger in shear than the cast aluminum hinge halves are > in tension. In Vi's test the single-tab hinge half broke right across the > hinge pin axis. I suppose one other possible failure mode is "pull-out", > where the pull of the hinge pin against the top of the tab causes it to > break and the pin pulls through. My load test should go quickly. > > I have now used all of the (simple) tools and jigging that Vi used to make > the parts in years past, and now that he's gone I look at each tool a > little bit differently than I did before. His hands were the last ones to > touch the tools and jigs before I touched them today. I wish I could have > gotten the first set of hinges completed before he died so I could have > told him about it, but I came pretty close. > > The first set of hinges from this new run has been promised for a long > time to Bob Coolbaugh and Andrew King for the restoration of "Blitzkrieg", > with nine other builders' names on the list after them. When they are > available and ready to ship, I'll post that information here. > > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power, Culver prop > > > * > > > * > > Oscar, Just a reminder, After those who need them to complete their builds get what they need, I am willing to buy a set to put on the shelf, for potential future projects. One of my goals in life it to be the old man who has a lot of strange and unrelated aircraft parts available. You know the guy who has 2 B25 compasses and a BT13 oil tank in the back corner under a Curtiss P-40 elevator. Blue Skies, Steve D -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Re: Another pietenpol egg has been laid
Date: Dec 21, 2014
I'd like to thank everyone for all the positive input. I had considered a Staaken Flitzer. I even went as far as purchasing plans. After studying that short coupled, high landing speed little go cart of an airplane, I thought it was probably more airplane than I am a pilot. Sent from my iPhone > On Dec 18, 2014, at 1:30 PM, "AircamperN11MS" wrote: > > > Glen, > > I think it is a great idea. So what if it is slow. So is my Piet. :) Biplanes are cool. We need variety and Pietenpol's seem to offer more variety than any other homebuilt I can think of. Like Mike C says, "They are all snowflakes". I can't wait to see it. > > Cheers and happy building, > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435894#435894 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 21, 2014
I thought it would be a great way to become a colorful ball of rags and sticks on the side of the runway. Yes it has to be a biplane. But one that's house broken, not one that's a spring colt. I'll be starting the Aeriel build in January. I'll keep you updated. Thanks again for all the support. (Damn that's a lot of ribs!!) Glen Sent from my iPhone > On Dec 21, 2014, at 7:09 PM, glenschweizer(at)yahoo.com wrote: > > I'd like to thank everyone for all the positive input. I had considered a Staaken Flitzer. I even went as far as purchasing plans. After studying that short coupled, high landing speed little go cart of an airplane, I thought it was probably more airplane than I am a pilot. > > Sent from my iPhone > >> On Dec 18, 2014, at 1:30 PM, "AircamperN11MS" wrote: >> >> >> Glen, >> >> I think it is a great idea. So what if it is slow. So is my Piet. :) Biplanes are cool. We need variety and Pietenpol's seem to offer more variety than any other homebuilt I can think of. Like Mike C says, "They are all snowflakes". I can't wait to see it. >> >> Cheers and happy building, >> >> -------- >> Scott Liefeld >> Flying N11MS since March 1972 >> Steel Tube >> C-85-12 >> Wire Wheels >> Brodhead in 1996 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=435894#435894 >> >> >> >> >> >> >> >> >> >> ________________________________________________________________________________
Date: Dec 21, 2014
Glen; I have a few pictures of the Ariel project that I bought out of Santa Fe a few years ago, and although they don't show much more than a mock-up of the fuselage, gear, and wings, perhaps it might be useful to you to see pictures as you get into your build. I might also have a picture of the ENMA Tigre powered Ariel that was under construction in Missouri awhile back. Also, I still have the beautiful set of welded-leg, split-axle spoked-wheel landing gear that was built for it. As near as I can tell, it is exactly the same as the standard Air Camper gear, same fuselage width, same mounting brackets and bungee shock struts. I would be happy to lend the gear to you for trial fitting, getting dimensions off of, and (perhaps best of all), getting your fuselage up off the building table and able to roll around. The fuselage build should go quickly for you. I also have an unairworthy Scott 2000 tailwheel that can go on the back of it to permit you to move it around the hangar or workshop, and you're welcome to that as well. Let me know where on the coast you're located. I get up to Salem once a month if that's any help. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435994#435994 ________________________________________________________________________________
Date: Dec 21, 2014
Ray, looks beautiful, really beautiful...! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435995#435995 ________________________________________________________________________________
Subject: Re: Wing rib help!
Date: Dec 22, 2014
Dave,=0A=0A=0AAS&S still has it. http://www.aircraftspruce.com/search/se arch.php?s=WELDWOOD+GLUE&x=0&y=0=0A=0A=0ADan Helsper=0ALoensloe Airfie ld=0APuryear, TN=0A=0A=0A=0A-----Original Message-----=0AFrom: dgaldrich =0ATo: pietenpol-list =0ASent: Sun, Dec 21, 2014 5:26 pm=0ASubject: Pietenpol-List: "dgaldrich" =0A=0AMy error... The glue in Douwe's wing was plastic resin, not casien as =0Aoriginally stated. It appeared that the tail feathers were assembled u sing the =0Asame stuff but those joints were MUCH stronger. At the time, we suspected that =0Ait was used correctly o n them and not on the ribs. The latest version of 43-13 =0Asays that urea-formeldehyde glues are only used with speci fic, case by case, FAA =0Aapproval. AS&S no longer carries it.=0A=0ADave=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://for =========================== =========================== -Matt =========================== =========================== =========================== ======================0A=0A=0A=0A=0A =0A ________________________________________________________________________________
Date: Dec 22, 2014
Oscar. Just curious but what are your thoughts on using those hinges on the aileron s ? Your thoughts? I would doubt the hinges would be exposed to 3000lbs pressure at the aileron s. Naturally I'm thinking 3 hinges per side Thanks John Sent from my iPhone > On Dec 20, 2014, at 8:18 PM, Oscar Zuniga wrote: > > Update on the latest batch of hinges. I finished up a representative pair of hinges for load testing and rigged up the load testing jig, but ran out o f daylight before I could run the test. I want to make sure everything is s et up properly and can be photographed and documented before I run the test. It's really not anything fancy or esoteric... a lever arm gives me the lev erage to develop the required load on the hinges by using a 5 gallon pail th at I'm going to fill with wet sand and then weigh after breakage. The last s et that Vi tested failed at about 700 lbs of static load; no fatigue testing was done and we know that aluminum fatigues but to my knowledge there is no known or reported failure of these hinges and there are a lot of them out t here. > > We expect the single-tab hinge half to be the part that fails since the ma ting double-tab half has twice as much area to carry its load and the AN3 cl evis pin is WAY stronger in shear than the cast aluminum hinge halves are in tension. In Vi's test the single-tab hinge half broke right across the hin ge pin axis. I suppose one other possible failure mode is "pull-out", where the pull of the hinge pin against the top of the tab causes it to break and the pin pulls through. My load test should go quickly. > > I have now used all of the (simple) tools and jigging that Vi used to make the parts in years past, and now that he's gone I look at each tool a littl e bit differently than I did before. His hands were the last ones to touch t he tools and jigs before I touched them today. I wish I could have gotten t he first set of hinges completed before he died so I could have told him abo ut it, but I came pretty close. > > The first set of hinges from this new run has been promised for a long tim e to Bob Coolbaugh and Andrew King for the restoration of "Blitzkrieg", with nine other builders' names on the list after them. When they are available and ready to ship, I'll post that information here. > > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power, Culver prop > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Dec 22, 2014
Thanks, Jake. The photos are really helping. I made some cable guides for the aileron idler cable just like the ones in your photo. They are streamlined and should work great. I'm really concerned about the "drag factor"! Maybe we will be flying about the same time. Based on the chit-chat, there might be an entire Air Force of Piets taking to the air around the same time. Ray Krause Sent from my iPad > On Dec 21, 2014, at 10:27 PM, aerocarjake wrote: > > > Ray, looks beautiful, really beautiful...! > > -------- > Jake Schultz - curator, > Newport Way Air Museum (OK, it's just my home) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435995#435995 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 22, 2014
That's some fine looking work! Is that a built up spar I see? Tell us about it please? Sent from my iPhone > On Dec 19, 2014, at 7:30 PM, Ray Krause wrote: > > Hi everyone, > > The last week has been productive and I have my plane all together and rigged. I have the covering material and will start after the New Year. Just a couple pictures, if I can add them. > > > > > The cowling and other metal work is done, also. > > > > > Ray Krause > > >
Date: Dec 22, 2014
Oscar. Thank you for your amazingly generous offer of assistance! That would be most welcome and appreciated. One other reason for this project is the people on this list. It truly is a community here which I am pleased and proud to be a part of. Thanks to all. Glen Sent from my iPhone > On Dec 21, 2014, at 8:27 PM, "taildrags" wrote: > > > Glen; > > I have a few pictures of the Ariel project that I bought out of Santa Fe a few years ago, and although they don't show much more than a mock-up of the fuselage, gear, and wings, perhaps it might be useful to you to see pictures as you get into your build. I might also have a picture of the ENMA Tigre powered Ariel that was under construction in Missouri awhile back. > > Also, I still have the beautiful set of welded-leg, split-axle spoked-wheel landing gear that was built for it. As near as I can tell, it is exactly the same as the standard Air Camper gear, same fuselage width, same mounting brackets and bungee shock struts. I would be happy to lend the gear to you for trial fitting, getting dimensions off of, and (perhaps best of all), getting your fuselage up off the building table and able to roll around. The fuselage build should go quickly for you. I also have an unairworthy Scott 2000 tailwheel that can go on the back of it to permit you to move it around the hangar or workshop, and you're welcome to that as well. Let me know where on the coast you're located. I get up to Salem once a month if that's any help. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435994#435994 > > > > > > > > > > ________________________________________________________________________________
Subject: Winter Flying!
Date: Dec 22, 2014
Seems like 2-3 degrees. I=99ll have to look that up to be positive. It makes it fly without elevator droop. Also has trim to compensate for fuel burnoff, but it is very seldom used. Barry From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause Sent: Thursday, December 18, 2014 11:02 PM Subject: Re: Pietenpol-List: Winter Flying! Beautiful! This may be considered torture! How much down pitch do you have on your engine mount? Thanks, Ray Krause Building Sky Scout Sent from my iPad On Dec 18, 2014, at 9:17 AM, Barry Davis wrote: Dang it was cold last Saturday, but hey.somebody=99s gotta do it. Barry Davis NX973BP ________________________________________________________________________________
Date: Dec 22, 2014
John; Why would you want to use the tail style hinges for the ailerons? Piano hinges are the way to go on the ailerons, plus they effectively seal the aileron gap. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436007#436007 ________________________________________________________________________________
Date: Dec 22, 2014
Oscar my compliments on carrying on the important work of Vi Kapler! Sent from my iPad Jack Textor > On Dec 21, 2014, at 4:35 PM, "taildrags" wrote: > > > I just completed the load test of the latest batch of hinges and am happy to report that they have met or exceeded the strength of the earlier ones that Vi tested. The test sample that Vi sent me had broken at 700 lbs and mine was loaded to over 900 lbs and it never broke. For anyone who is interested, details of my load testing are at http://www.flysquirrel.net/loadtest.html . > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435974#435974 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 22, 2014
The following is cut and paste from the latest AC 43-13-1B. I sent this to AS&S two years ago and the glue was removed from their on-line catalog. Their description at the time included reference to aviation use. Now they just list a Federal Spec. Plastic resin glue (urea-formaldehyde resin glue) has been used in wood aircraft for many years. Caution should be used due to possible rapid deterioration (more rapidly than wood) of plastic resin glue in hot, moist environments and under cyclic swell-shrink stress. For these reasons, urea-formaldehyde should be considered obsolete for all repairs. Any proposed use of this type adhesive should be discussed with the appropriate FAA office prior to using on certificated aircraft. Since we're working under experimental rules, you can use anything you like -- hot glue from the craft store or Elmer's glue from Walmart. AC 43-13, like many of the FAA rules, was written with a mixture of tradition, science and blood. If 43-13 speaks to what I'm doing, I'll listen lest it be my blood on the revision pages. For those interested in epoxies, the following is excerpted from 43-13. (6) Epoxy adhesives are a two-part synthetic resin product, and are acceptable providing they meet the requirements of paragraph 1-4a. Many new epoxy resin systems appear to have excellent working properties. They have been found to be much less critical of joint quality and clamping pressure. They penetrate well into wood and plywood. However, joint durability in the presence of elevated temperature or moisture is inadequate in many epoxies. The epoxy adhesives generally consist of a resin and a hardener that are mixed together in the proportions specified by the manufacturer. Depending on the type of epoxy, pot life may vary from a few minutes to an hour. Cure times vary between products. CAUTION: Some epoxies may have unacceptable thermal or other hidden
November 28, 2014 - December 22, 2014
Pietenpol-Archive.digest.vol-nw
