Pietenpol-Archive.digest.vol-ob
February 24, 2015 - March 18, 2015
      IGZyb250IGNvY2twaXQgYW5kIGhhdmUgYSB2ZXJ5IGxhcmdlIGJhZ2dhZ2UgY2FwYWNpdHkgaWYg
      eW91IGFyZSBnb2luZyBjcm9zcyBjb3VudHJ5IHdpdGhvdXQNCmEgcGFzc2VuZ2VyLiAgIEkgaW5z
      dGFsbGVkIGEgcmVtb3ZhYmxlIGNvbnRyb2wgc3RpY2sgaW4gdGhlIGZyb250ICAoc2xpcCBmaXRz
      IGludG8gdGhlIHN0aWNrIHNvY2tldCBpZiBteSBwYXNzZW5nZXIgd291bGQgbGlrZSB0byBmbHkp
      ICBhbmQgaGFkIGEgbG9jYWwgdXBob2xzdGVyeQ0Kc2hvcCBzZXcgdXAgYSBibGFjayBjYW52YXMg
      VS1zaGFwZWQgc2FjayB0aGF0IHNuYXBzIGFsbCB0aGUgd2F5IGFyb3VuZCB0aGUgcGVyaW1ldGVy
      IG9mIG15IGZyb250IGNvY2twaXQgdG8gaG9sZCBteSBjYW1waW5nIGdlYXIgYW5kIG90aGVyIGVz
      c2VudGlhbA0KdGhpbmdzIGxpa2UgcGlsbG93IGFuZCB0ZWRkeSBiZWFyIGFuZCBzbmFja3MgYW5k
      IHN1Y2guICAgTG90cyBvZiByb29tIHVwIHRoZXJl4oCUeW914oCZZCBiZSBhbWF6ZWQgd2hhdCB5
      b3UgY2FuIGNhcnJ5IGJldHdlZW4geW91ciBvcGVuIGNlbnRlciBzZWN0aW9uIGFuZA0KZnJvbnQg
      Y29ja3BpdCBzbGluZy4gICBJIGFsc28gaGFkIHRoZSB1cGhvbHN0ZXJ5IHNob3Agc2V3IHVwIHR3
      byBnZW51aW5lIGZha2UgbGVhdGhlciBSaWNoIENvcmludGhpYW4gKGRpZCBJIG1lbnRpb24gZmFr
      ZT8pIGxlYXRoZXIgY29ja3BpdCBjb3ZlcnMgdGhhdCBrZWVwIGFsbA0KbXkgc3R1ZmYgZnJvbSBm
      bHlpbmcgb3V0IG9mIHRoZSBmcm9udCBjb2NrcGl0IGFuZCB0byBjb3ZlciB1cCB0aGUgY29ja3Bp
      dHMgd2hpbGUgcGFya2VkIG92ZXJuaWdodCBhdCBmbHktaW7igJlzLiAgICBJIGhvcGUgdGhpcyBo
      ZWxwcyENCg0KTWlrZSBDLg0KT2hpbw0KDQoNCg0KW2NpZDppbWFnZTAwMS5wbmdAMDFEMDUwNDYu
      REQ5RDk4MTBdDQoNCg0KDQoNCg=
Date: Feb 24, 2015
Subject: Re: Andy-- storage space and fuel
From: "Charles N. Campbell" <charlescampbell1924(at)gmail.com>
Mike, if it didn't help him it certainly helped me. I'm going to archive that so that I will remember when I get ready to build a gas tank. Could you give me the dimensions of your tank? Thanks, Chuck On Tue, Feb 24, 2015 at 3:30 PM, Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC] wrote: > Andy, > > > Welcome to the list. My two cents on your ideas of a wing tank and heade r > tank---no need for either. Simply fabricate a large nose tank > > for right behind your firewall and you will reap the following advantages : > > > 1) your wing center section can be used entirely for baggage. > http://www.westcoastpiet.com/images/Mike%20Cuy%20A-65%20Piet/mike_cuy.htm > > 2) you=99ll never need a ladder to get up to fuel your center section > tank. > > 3) you=99ll never spill fuel from filling your wing tank into your > cockpit > > 4) you=99ll have about 2 hours, with generous reserves with a large > nose tank. > > 5) My nose tank is 17 gallons and I have flown 2 hour 30 minute legs > which his ridiculous but it can be done. > > 6) you=99ll eliminate extra fuel lines, shutoff valves, fittin gs, and > weight. > > 7) you will be able to fill your tank standing on the ground, > without a ladder if necessary or from fuel cans of your choice. > > > As others have mentioned, you can still install a spartan front cockpit > and have a very large baggage capacity if you are going cross country > without > > a passenger. I installed a removable control stick in the front (slip > fits into the stick socket if my passenger would like to fly) and had a > local upholstery > > shop sew up a black canvas U-shaped sack that snaps all the way around th e > perimeter of my front cockpit to hold my camping gear and other essential > > things like pillow and teddy bear and snacks and such. Lots of room up > there=94you=99d be amazed what you can carry between your ope n center section > and > > front cockpit sling. I also had the upholstery shop sew up two genuine > fake leather Rich Corinthian (did I mention fake?) leather cockpit covers > that keep all > > my stuff from flying out of the front cockpit and to cover up the cockpit s > while parked overnight at fly-in=99s. I hope this helps! > > > Mike C. > > Ohio > > ________________________________________________________________________________
Date: Feb 24, 2015
Subject: Andy-- storage space and fuel
I'll vouch for Mike Cuy's comments on the fuselage tank. I went the same wa y with a tank in the nose. I see Mark Chouinard is doing the same thing. I ended up with 16 gallons, and I call the last 5 non-usable. This gives me 2 /12 hours of endurance which exceeds the endurance of my butt. I do notice a small trim change as the fuel burns off but it's not noticeable holding the stick. My airplane doesn't have a trim system and with a full tank, wil l begin to go nose-down hands off. But at about a half tank, it's stable. A t low fuel, there's a tail heavy moment. It's close enough to being in trim that if I put my arms outside the cockpi t and forward, the nose goes down, If you put them back, it goes up. I like having the center section baggage compartment and found a small flat soft bag that fits in there just fine. I keep chocks, cockpit covers, a fe w tools and tie-downs up there. Matt Paxton NX629ML -----Original Message----- From: Charles N. Campbell <charlescampbell1924(at)gmail.com> Sent: Tue, Feb 24, 2015 5:00 pm Subject: Re: Pietenpol-List: Andy-- storage space and fuel Mike, if it didn't help him it certainly helped me. I'm going to archive t hat so that I will remember when I get ready to build a gas tank. Could yo u give me the dimensions of your tank? Thanks, Chuck On Tue, Feb 24, 2015 at 3:30 PM, Cuy, Michael D. (GRC-LME0)[Vantage Partner s, LLC] wrote: Andy, Welcome to the list. My two cents on your ideas of a wing tank and header tank---no need for either. Simply fabricate a large nose tank for right behind your firewall and you will reap the following advantages: 1) your wing center section can be used entirely for baggage. http: //www.westcoastpiet.com/images/Mike%20Cuy%20A-65%20Piet/mike_cuy.htm 2) you=99ll never need a ladder to get up to fuel your center se ction tank. 3) you=99ll never spill fuel from filling your wing tank into yo ur cockpit 4) you=99ll have about 2 hours, with generous reserves with a la rge nose tank. 5) My nose tank is 17 gallons and I have flown 2 hour 30 minute legs w hich his ridiculous but it can be done. 6) you=99ll eliminate extra fuel lines, shutoff valves, fittings , and weight. 7) you will be able to fill your tank standing on the ground, without a ladder if necessary or from fuel cans of your choice. As others have mentioned, you can still install a spartan front cockpit and have a very large baggage capacity if you are going cross country without a passenger. I installed a removable control stick in the front (slip fi ts into the stick socket if my passenger would like to fly) and had a loca l upholstery shop sew up a black canvas U-shaped sack that snaps all the way around the perimeter of my front cockpit to hold my camping gear and other essential things like pillow and teddy bear and snacks and such. Lots of room up th ere=94you=99d be amazed what you can carry between your open ce nter section and front cockpit sling. I also had the upholstery shop sew up two genuine fa ke leather Rich Corinthian (did I mention fake?) leather cockpit covers tha t keep all my stuff from flying out of the front cockpit and to cover up the cockpits while parked overnight at fly-in=99s. I hope this helps! Mike C. Ohio ________________________________________________________________________________
Date: Feb 24, 2015
From: Charles Burkholder <born2fly(at)abcmailbox.net>
Subject: Re: VNE at cruise- bungees versus springs landing
gear Thankyou for your input everyone. I am going with the steel spring setup. I have watched people work on bungee's and have no desire to have them. On 2/20/2015 9:39 PM, jarheadpilot82 wrote: > > Glen, > > Here is a link to a discussion about the replacement of bungees with die springs written a while back by William Wynne- > > http://flycorvair.net/2012/10/27/new-die-spring-landing-gear-on-a-pietenpol-10-a-m-4-p-m/ > > Below is a copy of the page of the catalog in which I have noted the die springs I ordered. They were , if memory serves, around $85 or $90, cheaper than I could find anywhere else. The contact info as at the bottom of the page. > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438541#438541 > > > Attachments: > > http://forums.matronics.com//files/diamondwirecatalog_dragged_177.pdf > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > -- Charles Burkholder Visit my blog @ http://missionmechfund.blogspot.ca/ ________________________________________________________________________________
Date: Feb 24, 2015
I like your thinking. =0AG ________________________________________________________________________________
From: Scott Knowlton <flyingscott_k(at)hotmail.com>
Date: Feb 24, 2015
I followed Mike's good advice and am glad I did. Front combings are 10.5 in ches above the longerons with the tank holding 18.5 gals. Very simple and e asy to engineer/install. Scott Knowlton Burlington Ontario. Sent from my iPad > On Feb 24, 2015, at 3:30 PM, Cuy, Michael D. (GRC-LME0)[Vantage Partners, L LC] wrote: > > Andy, > > Welcome to the list. My two cents on your ideas of a wing tank and header tank---no need for either. Simply fabricate a large nose tank > for right behind your firewall and you will reap the following advantages: > > 1) your wing center section can be used entirely for baggage. http: //www.westcoastpiet.com/images/Mike%20Cuy%20A-65%20Piet/mike_cuy.htm > 2) you=99ll never need a ladder to get up to fuel your center s ection tank. > 3) you=99ll never spill fuel from filling your wing tank into y our cockpit > 4) you=99ll have about 2 hours, with generous reserves with a l arge nose tank. > 5) My nose tank is 17 gallons and I have flown 2 hour 30 minute legs w hich his ridiculous but it can be done. > 6) you=99ll eliminate extra fuel lines, shutoff valves, fitting s, and weight. > 7) you will be able to fill your tank standing on the ground, without a ladder if necessary or from fuel cans of your choice. > > > As others have mentioned, you can still install a spartan front cockpit an d have a very large baggage capacity if you are going cross country without > a passenger. I installed a removable control stick in the front (slip f its into the stick socket if my passenger would like to fly) and had a loca l upholstery > shop sew up a black canvas U-shaped sack that snaps all the way around the perimeter of my front cockpit to hold my camping gear and other essential > things like pillow and teddy bear and snacks and such. Lots of room up t here=94you=99d be amazed what you can carry between your open ce nter section and > front cockpit sling. I also had the upholstery shop sew up two genuine f ake leather Rich Corinthian (did I mention fake?) leather cockpit covers tha t keep all > my stuff from flying out of the front cockpit and to cover up the cockpits while parked overnight at fly-in=99s. I hope this helps! > > Mike C. > Ohio > > > > > > > > ________________________________________________________________________________
Date: Feb 24, 2015
Date: Feb 24, 2015
Well, that's just pretty obvious, isn't it? I'm left wondering why anyone would do it the other way. This doesn't require a pump does it? Still gravity feed--yes? -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438682#438682 ________________________________________________________________________________
Date: Feb 24, 2015
Let me give the response from the Loyal Opposition: A nose tank is a good solution, but does have its drawbacks: 1. Pressure head. With a gravity fuel system (no fuel pumps) the recommended head above the carburetor at minimum fuel is 17". One of the worst things that can happen is to be at very low fuel and be on short final when some idiot in a Cessna pulls out onto the runway to takeoff (having just announced his intentions on the radio, assuming everyone has a radio and uses it). You shove the throttle forward, haul back on the stick and the engine sputters and quits because there is not enough pressure head to flow sufficient fuel to the carburetor. That's why one of the critical tests you need to make before your first flight is a fuel flow test with the tailwheel set in a hole several inches below ground level, simulating the maximum angle of climb you might ever need. 2. Loss of easy to access baggage space. With my fuel tank in the centersection, I have a very nice baggage compartment big enough to hold a tent, a sleeping bag, an airmattress and a small duffle bag, in addition to the chocks and tie downs I always carry. And I can access that baggage compartment without a ladder. I don't see how you can carry much of a tent in the centersection, since it's only about 5" tall at the most. I've seen the tent Mike Cuy uses. My dog wouldn't fit in it. And it's a very small dog. 3. With the tank in the centersection CG changes with fuel burn are minimal and are not noticeable. 4. With the tank in the nose it is difficult to provide a sump drain that can be easily reached to check for water in the gas. With a centersection tank the sump drains (you need one at the lowest point of the tank, and if the tank is flat, you'll need one on each side at the rear of the tank) are easy to check when pre-flighting the airplane. Of course, you'll also need a drain at the gascolator, which should be at the lowest point of the fuel system. Building a nose tank that won't trap water in a low point is difficult, and relying on the gascolator to show you all trapped water is dangerous 5. We can start a discussion about whether it is good to have a lap full of fuel in the event of a crash, but I'm not sure which is worse - a lap full of fuel or a face full of fuel. I think the dynamics of each and every crash are different and it is not possible to find a place for a fuel tank that is totally crashworthy. 6. When refueling with a nose tank you can get careless, knowing that your butt will stay dry even if you run the tank over. You'll only do that once with a centersection tank. Then you'll learn to refuel much more carefully (ask me how I know). Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Andy Garrett Sent: Tuesday, February 24, 2015 7:19 PM Subject: Pietenpol-List: Re: Andy-- storage space and fuel --> Well, that's just pretty obvious, isn't it? I'm left wondering why anyone would do it the other way. This doesn't require a pump does it? Still gravity feed--yes? -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438682#438682 ________________________________________________________________________________
Date: Feb 24, 2015
Gotta Love Experimental. Three good solutions. 1. Dual tanks, 2. Big nose tank, 3. Big wing tank. All three rationally considered and planned. Blue Skies, Steve D On Tue, Feb 24, 2015 at 8:10 PM, Jack Philips wrote: > jack(at)bedfordlandings.com> > > Let me give the response from the Loyal Opposition: > > A nose tank is a good solution, but does have its drawbacks: > > 1. Pressure head. With a gravity fuel system (no fuel pumps) the > recommended head above the carburetor at minimum fuel is 17". One of the > worst things that can happen is to be at very low fuel and be on short > final > when some idiot in a Cessna pulls out onto the runway to takeoff (having > just announced his intentions on the radio, assuming everyone has a radio > and uses it). You shove the throttle forward, haul back on the stick and > the engine sputters and quits because there is not enough pressure head to > flow sufficient fuel to the carburetor. That's why one of the critical > tests you need to make before your first flight is a fuel flow test with > the > tailwheel set in a hole several inches below ground level, simulating the > maximum angle of climb you might ever need. > > 2. Loss of easy to access baggage space. With my fuel tank in the > centersection, I have a very nice baggage compartment big enough to hold a > tent, a sleeping bag, an airmattress and a small duffle bag, in addition to > the chocks and tie downs I always carry. And I can access that baggage > compartment without a ladder. I don't see how you can carry much of a tent > in the centersection, since it's only about 5" tall at the most. I've seen > the tent Mike Cuy uses. My dog wouldn't fit in it. And it's a very small > dog. > > 3. With the tank in the centersection CG changes with fuel burn are > minimal > and are not noticeable. > > 4. With the tank in the nose it is difficult to provide a sump drain that > can be easily reached to check for water in the gas. With a centersection > tank the sump drains (you need one at the lowest point of the tank, and if > the tank is flat, you'll need one on each side at the rear of the tank) are > easy to check when pre-flighting the airplane. Of course, you'll also need > a drain at the gascolator, which should be at the lowest point of the fuel > system. Building a nose tank that won't trap water in a low point is > difficult, and relying on the gascolator to show you all trapped water is > dangerous > > 5. We can start a discussion about whether it is good to have a lap full > of > fuel in the event of a crash, but I'm not sure which is worse - a lap full > of fuel or a face full of fuel. I think the dynamics of each and every > crash are different and it is not possible to find a place for a fuel tank > that is totally crashworthy. > > 6. When refueling with a nose tank you can get careless, knowing that your > butt will stay dry even if you run the tank over. You'll only do that once > with a centersection tank. Then you'll learn to refuel much more carefully > (ask me how I know). > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Andy > Garrett > Sent: Tuesday, February 24, 2015 7:19 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Andy-- storage space and fuel > > --> > > Well, that's just pretty obvious, isn't it? > > I'm left wondering why anyone would do it the other way. > > This doesn't require a pump does it? Still gravity feed--yes? > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438682#438682 > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Feb 25, 2015
Subject: Re: Four-bladed prop
WF2, Thank you for all your advice. I momentarily considered slicing-up my too-wide blades, in order to increase efficiency, and make it look like a Cub, but then in about a millisecond came to my senses and decided against. Then I got to pondering (that's what we do down here in W. Tennessee) wondering why Hartzell, the hard-core air racers, military transports, commercial turboprops etc. do not use a single-bladed prop since it the most efficient design. The conclusion I came up with was, that those props need some way to harness all that horsepower from those engines, and after some thought, figured that that is precisely why I also needed four blades. Dan Helsper Loensloe Airfield Puryear, TN -----Original Message----- From: womenfly2 <Love2Fly.KAP(at)gmail.com> Sent: Tue, Feb 24, 2015 9:14 am Subject: Pietenpol-List: Re: Four-bladed prop Solidity is simply the ratio of the total blade area of the propeller to the disk swept out when the prop turns. The blade area is roughly the length (called the radius) times the width (called the chord). More solidity = less efficiency. Generally speaking, the more blades, the less efficient the propeller...for cruise. Of course, a whole lot depends on the blade cross section, width, length, rotational speed, etc. So think of it like this: The blades of a propeller interact with each other, in a manner which decreases efficiency. If you think of the blades as wings, each blade will be operating in the downwash and disturbed wake from the preceding blades. More blades mean more interaction means less efficient. Four blades are fine but thin out the blade chord width like a Cub prop. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438645#438645 - The Pietenpol-List Email Forum - Navigator to browse Un/Subscription, Photoshare, and much much more: http://www.matronics.com/Navigator?Pietenpol-List - MATRONICS WEB FORUMS - Forums! http://forums.matronics.com - List Contribution Web Site - -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: nose tank---gravity fed
Date: Feb 25, 2015
Andy, Yes, my A-65 is all gravity fed with no need for a fuel pump. I highly suggest to follow the gravity fuel flow test that Tony Bingelis ou tlines in his homebuilder book series because that way you know exactly how much useable and unusable fuel you have in your tank. For a full-power, nose high (takeoff climb attitude) for my engine I can sa fely operate (according to the calculations I gleaned from Tony's books and test suggestions) down to 1.3 gallons remaining of my 17 gallon capacity. I never cut my f uel this low but at least I know when the fuel flow rate becomes insufficie nt to keep the carb fed. I basically built my plane with a phone, a credit card, and the Tony Bingel is books. The Bingelis books are worth their weight in gold for any homeb uider---a bit dated but airworthiness never gets out of date really. And Chuck Campbell, I'm sorry but I don't have dimensions for my fuel tank but basically I followed the shape of my front cockpit instrument panel ra dius (though I raised my instrument panels 1" higher than plans.) and then made the bottom of it slope forward at about the same angle and a little above as the front seat passenger's legs would be positioned. ________________________________________________________________________________
Date: Feb 25, 2015
Makes sense to me ! They did the same thing with the spitfire. Two blades, then three, then four, then five, then the contra rotating. You have that God given Pietenpol grin even when your not flying ! Now get started on the five blade model to harness all that Ford horsepower ! Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438725#438725 ________________________________________________________________________________
Date: Feb 25, 2015
One good solution is to strap a tent or whatever you wantunder the wing, I d id and itdoesn,t change the flight characteristics. Sent from my iPad > On Feb 24, 2015, at 10:11 PM, Steven Dortch wr ote: > > Gotta Love Experimental. Three good solutions. 1. Dual tanks, 2. Big nose t ank, 3. Big wing tank. All three rationally considered and planned. > > Blue Skies, > Steve D > >> On Tue, Feb 24, 2015 at 8:10 PM, Jack Philips w rote: s.com> >> >> Let me give the response from the Loyal Opposition: >> >> A nose tank is a good solution, but does have its drawbacks: >> >> 1. Pressure head. With a gravity fuel system (no fuel pumps) the >> recommended head above the carburetor at minimum fuel is 17". One of the >> worst things that can happen is to be at very low fuel and be on short fi nal >> when some idiot in a Cessna pulls out onto the runway to takeoff (having >> just announced his intentions on the radio, assuming everyone has a radio >> and uses it). You shove the throttle forward, haul back on the stick and >> the engine sputters and quits because there is not enough pressure head t o >> flow sufficient fuel to the carburetor. That's why one of the critical >> tests you need to make before your first flight is a fuel flow test with t he >> tailwheel set in a hole several inches below ground level, simulating the >> maximum angle of climb you might ever need. >> >> 2. Loss of easy to access baggage space. With my fuel tank in the >> centersection, I have a very nice baggage compartment big enough to hold a >> tent, a sleeping bag, an airmattress and a small duffle bag, in addition t o >> the chocks and tie downs I always carry. And I can access that baggage >> compartment without a ladder. I don't see how you can carry much of a te nt >> in the centersection, since it's only about 5" tall at the most. I've se en >> the tent Mike Cuy uses. My dog wouldn't fit in it. And it's a very smal l >> dog. >> >> 3. With the tank in the centersection CG changes with fuel burn are mini mal >> and are not noticeable. >> >> 4. With the tank in the nose it is difficult to provide a sump drain tha t >> can be easily reached to check for water in the gas. With a centersectio n >> tank the sump drains (you need one at the lowest point of the tank, and i f >> the tank is flat, you'll need one on each side at the rear of the tank) a re >> easy to check when pre-flighting the airplane. Of course, you'll also ne ed >> a drain at the gascolator, which should be at the lowest point of the fue l >> system. Building a nose tank that won't trap water in a low point is >> difficult, and relying on the gascolator to show you all trapped water is >> dangerous >> >> 5. We can start a discussion about whether it is good to have a lap full of >> fuel in the event of a crash, but I'm not sure which is worse - a lap ful l >> of fuel or a face full of fuel. I think the dynamics of each and every >> crash are different and it is not possible to find a place for a fuel tan k >> that is totally crashworthy. >> >> 6. When refueling with a nose tank you can get careless, knowing that yo ur >> butt will stay dry even if you run the tank over. You'll only do that on ce >> with a centersection tank. Then you'll learn to refuel much more careful ly >> (ask me how I know). >> >> Jack Phillips >> NX899JP >> Smith Mountain Lake, Virginia >> >> -----Original Message----- >> From: owner-pietenpol-list-server(at)matronics.com >> [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Andy Garr ett >> Sent: Tuesday, February 24, 2015 7:19 PM >> To: pietenpol-list(at)matronics.com >> Subject: Pietenpol-List: Re: Andy-- storage space and fuel >> >> --> >> >> Well, that's just pretty obvious, isn't it? >> >> I'm left wondering why anyone would do it the other way. >> >> This doesn't require a pump does it? Still gravity feed--yes? >> >> -------- >> Andy Garrett >> 'General Purpose Creative Dude' >> Haysville, Kansas >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=438682#438682 >> >> >> >> >> >> >> >> >> >> >> >> >> >> ========== >> br> enpol-List" target="_blank">http://www.matronics.com/Navigator?Piet enpol-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ========== > > > > -- > Blue Skies, > Steve D > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Re: nose tank---gravity fed
Date: Feb 25, 2015
This is amazing. Now that I see the sketches of how Mikee did it, I realize that the fuel tank, float, outlet, valve, and everything aft of the firewall on NX41CC is nearly identical to what is shown in the sketches, down to the tensioning strap across the top and everything in-between. My tank holds 16 gallons but I have never actually run the Bingelis test to determine unusable fuel... I ran the Zuniga test, where you fly it to fuel exhaustion. I do not recommend this test method unless you are interested in methods for assisted suicide (legal in Oregon but not in Texas, where I inadvertently ran the test). -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438744#438744 ________________________________________________________________________________
Date: Feb 25, 2015
Just as a point of interest: had a friend who commuted to Chico State Colleg e in a Cub. He strapped a bicycle to the struts so he could ride from the ai rport (Ranchero) to the campus, 1.5 miles! He said the plane flew the same w ith, or without the bike...slowly! Ray Krause Covering SkyScout Sent from my iPad > On Feb 25, 2015, at 12:28 PM, airlion2(at)gmail.com wrote: > > One good solution is to strap a tent or whatever you wantunder the wing, I did and itdoesn,t change the flight characteristics. > > Sent from my iPad > >> On Feb 24, 2015, at 10:11 PM, Steven Dortch w rote: >> >> Gotta Love Experimental. Three good solutions. 1. Dual tanks, 2. Big nose tank, 3. Big wing tank. All three rationally considered and planned. >> >> Blue Skies, >> Steve D >> >>> On Tue, Feb 24, 2015 at 8:10 PM, Jack Philips wrote: gs.com> >>> >>> Let me give the response from the Loyal Opposition: >>> >>> A nose tank is a good solution, but does have its drawbacks: >>> >>> 1. Pressure head. With a gravity fuel system (no fuel pumps) the >>> recommended head above the carburetor at minimum fuel is 17". One of th e >>> worst things that can happen is to be at very low fuel and be on short f inal >>> when some idiot in a Cessna pulls out onto the runway to takeoff (having >>> just announced his intentions on the radio, assuming everyone has a radi o >>> and uses it). You shove the throttle forward, haul back on the stick an d >>> the engine sputters and quits because there is not enough pressure head t o >>> flow sufficient fuel to the carburetor. That's why one of the critical >>> tests you need to make before your first flight is a fuel flow test with the >>> tailwheel set in a hole several inches below ground level, simulating th e >>> maximum angle of climb you might ever need. >>> >>> 2. Loss of easy to access baggage space. With my fuel tank in the >>> centersection, I have a very nice baggage compartment big enough to hold a >>> tent, a sleeping bag, an airmattress and a small duffle bag, in addition to >>> the chocks and tie downs I always carry. And I can access that baggage >>> compartment without a ladder. I don't see how you can carry much of a t ent >>> in the centersection, since it's only about 5" tall at the most. I've s een >>> the tent Mike Cuy uses. My dog wouldn't fit in it. And it's a very sma ll >>> dog. >>> >>> 3. With the tank in the centersection CG changes with fuel burn are min imal >>> and are not noticeable. >>> >>> 4. With the tank in the nose it is difficult to provide a sump drain th at >>> can be easily reached to check for water in the gas. With a centersecti on >>> tank the sump drains (you need one at the lowest point of the tank, and i f >>> the tank is flat, you'll need one on each side at the rear of the tank) a re >>> easy to check when pre-flighting the airplane. Of course, you'll also n eed >>> a drain at the gascolator, which should be at the lowest point of the fu el >>> system. Building a nose tank that won't trap water in a low point is >>> difficult, and relying on the gascolator to show you all trapped water i s >>> dangerous >>> >>> 5. We can start a discussion about whether it is good to have a lap ful l of >>> fuel in the event of a crash, but I'm not sure which is worse - a lap fu ll >>> of fuel or a face full of fuel. I think the dynamics of each and every >>> crash are different and it is not possible to find a place for a fuel ta nk >>> that is totally crashworthy. >>> >>> 6. When refueling with a nose tank you can get careless, knowing that y our >>> butt will stay dry even if you run the tank over. You'll only do that o nce >>> with a centersection tank. Then you'll learn to refuel much more carefu lly >>> (ask me how I know). >>> >>> Jack Phillips >>> NX899JP >>> Smith Mountain Lake, Virginia >>> >>> -----Original Message----- >>> From: owner-pietenpol-list-server(at)matronics.com >>> [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Andy Gar rett >>> Sent: Tuesday, February 24, 2015 7:19 PM >>> To: pietenpol-list(at)matronics.com >>> Subject: Pietenpol-List: Re: Andy-- storage space and fuel >>> >>> --> >>> >>> Well, that's just pretty obvious, isn't it? >>> >>> I'm left wondering why anyone would do it the other way. >>> >>> This doesn't require a pump does it? Still gravity feed--yes? >>> >>> -------- >>> Andy Garrett >>> 'General Purpose Creative Dude' >>> Haysville, Kansas >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=438682#438682 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> ========== >>> br> enpol-List" target="_blank">http://www.matronics.com/Navigator?Pie tenpol-List >>> ========== >>> FORUMS - >>> _blank">http://forums.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> target="_blank">http://www.matronics.com/contribution >>> ========== >> >> >> >> -- >> Blue Skies, >> Steve D >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> npol-List"">http://www.matronics.com/Navigator?Pietenpol-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Feb 25, 2015
More excellent points. I suspect this will be a trend--multiple solutions to challenges. To be clear..., a 'header tank' is just a smaller tank in the nose which is fed by the wing tank. Yes? -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438750#438750 ________________________________________________________________________________
Date: Feb 25, 2015
Andy; My answer to your question about a header tank is just my answer-"yes", but to elaborate, I consider a header tank to be one that doesn't have its own filler cap and so it is filled from the main tank by the pilot's manipulation of valves. If I could possibly stretch an aviation regulation that says there must be a quantity indicator for each fuel tank, I would further stretch things by saying that header tanks don't usually have quantity indicators. You have a fuel gauge for the main tank, but once it feeds into the header tank you don't typically have a readout of what's in that tank. Anyone else care to comment? -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438753#438753 ________________________________________________________________________________
Date: Feb 25, 2015
WF2, I'm with you on the principle of one blade's interfering with the aerodynamic efficiency of those that follow it in the arc. As I understand it, the trend towards 4-, 5-, and 6-blade props on the fast twins and turboprops has more to do with noise than with efficiency, although there is no arguing with the airlines' desire to move the most load while burning the least amount of fuel. That said, I hope you'll concede the point that on this list at least, appearance (and aesthetics) carry almost as much weight as efficiency? We never were about efficiency here, or else we would have come up with a fast glass parallel to the traditional Air Camper much as "Lionheart" is to the Beech Staggerwing. The 4-bladed wood prop that a builder carves by hand says so much more than a Prince P-tip says about the airplane... and I'm saying this as an Air Camper owner/pilot who owns a perfectly good (and probably more efficient) P-Tip but has not yet had the heart to install it on my airplane instead of the laminated wood Tennessee Props stick that is on it. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438754#438754 ________________________________________________________________________________
Date: Feb 26, 2015
Really large bump in the fuel line.=C2- :-) Clif ----- Original Message ----- To be clear..., a 'header tank' is just a smaller tank in the nose which is fed by the wing tank. Yes? -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas ________________________________________________________________________________
Date: Feb 26, 2015
Andy, Don=B9t forget to vent it so that the vent is higher than the centre section tank vent. I also reversed the direction of the header tank vent so that the pressure inside the header tank was less that the head of the main tank. I originall y had the vent facing forward and the pressure generated didn=B9t allow fuel to flow from the main tank into the header tank. A bit disconcerting=8A. This how I did mine. http://www.cpc-world.com/images/fuel%20system.jpg Cheers Peter Wonthaggi Australia http://www.cpc-world.com From: CLIF DAWSON <cdawson5854(at)shaw.ca> Date: Thursday, 26 February 2015 6:30 pm Subject: Re: Pietenpol-List: Re: Andy-- storage space and fuel Really large bump in the fuel line. :-) Clif To be clear..., a 'header tank' is just a smaller tank in the nose which is fed by the wing tank. Yes? -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas ________________________________________________________________________________
Date: Feb 26, 2015
Its all about the math. Prop design is about Engine HP, torque, RPM, speed, etc. The reason multiple blades are use is not for noise but for turning the HP into thrust. Noise reduction has to do with blade design profiles. Anyway have fun .... your 4-blade prop will need to be thin and small in diameter to get the thrust you need, but you will find that out as you experiment. Based on my Model-A engines HP and other known facts, my propeller calculations for the 2nd prop I carved was this one. Its the one we flew with. Here is some in site: Simplified propeller design for low-powered airplanes https://archive.org/stream/nasa_techdoc_19930080999/19930080999#page/n3/mode/2up Cheers ... I will be quite now. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438759#438759 Attachments: http://forums.matronics.com//files/m_01fb956990cac72515cb0ce22f9790dd3a4fd39ba5_193.jpg http://forums.matronics.com//files/m_01afcc644ff0cd3005372b950f259aabde769c000e_172.jpg ________________________________________________________________________________
Date: Feb 26, 2015
Yes, A header tank is a tank behind the engine/in front of the front instrument panel that is fed by the wing tank. However, for lack of a better term, people (including me) often call all tanks behind the engine/in front of the front instrument panel, a header tank. Mine is not a header tank. I have a wing tank and a tank in front of the front instrument panel/behind the engine that feed separately. I have a fuel tank lever that has two off positions and one Wing tank position and one "header" tank position. True confessions. We put the lever on the valve so long ago that I can't remember if the handle points to the tank or the little pointer on the knob points to the correct tank. I guess I will figure that out during the fuel flow tests. Blue Skies, Steve D ________________________________________________________________________________
Date: Feb 26, 2015
The Show "How it is made" on the discovery channel has a section about "how propellers are made." It is really good and shows Tennessee Propellers Inc. making a wood prop. Worth watching. Blue Skies, Steve D. On Thu, Feb 26, 2015 at 6:50 AM, womenfly2 wrote: > > Its all about the math. Prop design is about Engine HP, torque, RPM, > speed, etc. > > The reason multiple blades are use is not for noise but for turning the HP > into thrust. Noise reduction has to do with blade design profiles. > > Anyway have fun .... your 4-blade prop will need to be thin and small in > diameter to get the thrust you need, but you will find that out as you > experiment. > > Based on my Model-A engines HP and other known facts, my propeller > calculations for the 2nd prop I carved was this one. Its the one we flew > with. > > Here is some in site: Simplified propeller design for low-powered airplanes > > https://archive.org/stream/nasa_techdoc_19930080999/19930080999#page/n3/mode/2up > > > Cheers ... I will be quite now. > WF2 > > -------- > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438759#438759 > > > Attachments: > > > http://forums.matronics.com//files/m_01fb956990cac72515cb0ce22f9790dd3a4fd39ba5_193.jpg > > http://forums.matronics.com//files/m_01afcc644ff0cd3005372b950f259aabde769c000e_172.jpg > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Feb 26, 2015
=9CTrue confessions. We put the lever on the valve so long ago that I can't remember if the handle points to the tank or the little pointer on the knob points to the correct tank.=9D Sorry to pick on this statement, Steve, but I couldn=99t help thinking about the inexperienced, or rusty pilot (like me), flying his new Pietenpol for the first time, and having to worry about fuel management. What happens the first time that engine coughs on takeoff? It=99s just my opinion, but, whether a builder designs and builds a beautiful 15 gallon nose tank, like Mark=99s, or a 16 gallon center section tank like mine, the Pietenpol does not need any more fueland definitely not multiple tanks. In other words, one large tank is better than two smaller onesagain, just my opinion. Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Steven Dortch Sent: Thursday, February 26, 2015 5:37 AM Subject: Re: Pietenpol-List: Re: Andy-- storage space and fuel Yes, A header tank is a tank behind the engine/in front of the front instrument panel that is fed by the wing tank. However, for lack of a better term, people (including me) often call all tanks behind the engine/in front of the front instrument panel, a header tank. Mine is not a header tank. I have a wing tank and a tank in front of the front instrument panel/behind the engine that feed separately. I have a fuel tank lever that has two off positions and one Wing tank position and one "header" tank position. True confessions. We put the lever on the valve so long ago that I can't remember if the handle points to the tank or the little pointer on the knob points to the correct tank. I guess I will figure that out during the fuel flow tests. Blue Skies, Steve D ________________________________________________________________________________
Date: Feb 26, 2015
Mike, one more question -- two really. 1.) What thickness aluminum did you use for the tank? and 2) Did you weld it or rivet it with sealer in the joints? I was just wondering if it would be practical to even consider riveting. If I rivet, I'll get the rivets and rivet puller from Zenith. I like the way their rivets look after installing. Your buddy flew the BIG ones. I was a fighter pilot in the Navy, flying off the USS Hancock, CV-19. I got about 75 carrier landings in the F6F Hellcat. Thanks for the information. Chuck On Wed, Feb 25, 2015 at 11:22 AM, Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC] wrote: > Andy, > > > Yes, my A-65 is all gravity fed with no need for a fuel pump. > > > I highly suggest to follow the gravity fuel flow test that Tony Bingelis > outlines in his homebuilder book series because that way > > you know exactly how much useable and unusable fuel you have in your tank . > > > For a full-power, nose high (takeoff climb attitude) for my engine I can > safely operate (according to the calculations I gleaned from Tony =99s books > and test suggestions) > > down to 1.3 gallons remaining of my 17 gallon capacity. I never cut my > fuel this low but at least I know when the fuel flow rate becomes > insufficient to keep the carb > > fed. > > > I basically built my plane with a phone, a credit card, and the Tony > Bingelis books. The Bingelis books are worth their weight in gold for a ny > homebuider---a bit dated but > > airworthiness never gets out of date really. > > > And Chuck Campbell, I=99m sorry but I don=99t have dimension s for my fuel > tank but basically I followed the shape of my front cockpit instrument > panel radius (though I raised > > my instrument panels 1=9D higher than plans.) and then made the bot tom of it > slope forward at about the same angle and a little above as the front sea t > passenger=99s legs > > would be positioned. > > ________________________________________________________________________________
Date: Feb 26, 2015
On 02/23/2015 10:22 AM, Dave Abramson wrote: > VERY COOL DAN!!!!!! Actually, I think it's VERY COLD in TN, today. Dan - If you forgot your snow shovel up here, you can always use your new prop to dig out... :-D Dan -- Dan Yocum yocum137(at)gmail.com ________________________________________________________________________________
Date: Feb 26, 2015
Why not just have a fuel indicator in the "header" tank. That way it would always read "Full" until the "main tank" runs dry and the header starts feeding the engine without the fuel being replaced from the main tank. C On Thu, Feb 26, 2015 at 12:41 AM, taildrags wrote: > > Andy; > > My answer to your question about a header tank is just my answer-"yes", > but to elaborate, I consider a header tank to be one that doesn't have its > own filler cap and so it is filled from the main tank by the pilot's > manipulation of valves. If I could possibly stretch an aviation regulation > that says there must be a quantity indicator for each fuel tank, I would > further stretch things by saying that header tanks don't usually have > quantity indicators. You have a fuel gauge for the main tank, but once it > feeds into the header tank you don't typically have a readout of what's in > that tank. Anyone else care to comment? > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438753#438753 > > ________________________________________________________________________________
Date: Feb 26, 2015
If you have used all fuel from your main tank and lets say half from your header tank, when you refuel you may have to pause to allow the fuel from the main to flow to the header through the connecting hose before filling the main tank. Blue Skies, Steve D. On Wed, Feb 25, 2015 at 11:41 PM, taildrags wrote: > > Andy; > > My answer to your question about a header tank is just my answer-"yes", > but to elaborate, I consider a header tank to be one that doesn't have its > own filler cap and so it is filled from the main tank by the pilot's > manipulation of valves. If I could possibly stretch an aviation regulation > that says there must be a quantity indicator for each fuel tank, I would > further stretch things by saying that header tanks don't usually have > quantity indicators. You have a fuel gauge for the main tank, but once it > feeds into the header tank you don't typically have a readout of what's in > that tank. Anyone else care to comment? > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438753#438753 > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Feb 26, 2015
Gary, My point was that I don't remember which way it was put on. It is my intent to make it like the tank selector in my Bonanza. the little red arrow will point to the tank not the handle But I don't know which way the "knob" was installed, So I will have to check. The Red arrow should be obvious. Each detent will be marked with a sticker. "Off, Off, "Wing tank" and "Front tank." I bought a really nice new interior for my Vtail out of a salvaged plane. The new owner got in an argument with his mechanic and took off without the tank markers in place. He ran his left wing tank out of fuel and could not figure out where the detents were. He landed in a corn field, gear up, totaled the plane. I am very conscious of fuel management. OT In my Vtail Bonanza you manage a fuel system 3 tank system that pumps 14 gallons per hour to the pressure carb (like a Throttle Body Injector) which burns about 9.5 GPH in cruse. The remaining 3.5 gallons are returned to the left wing tank. (So you must burn fuel from the left tank first to make room for this fuel return, otherwise it pumps fuel overboard.) In flight I burn almost all of the fuel out of my left tank, 18 gallons useable, I switch at 1 hour and 45 min, then I go to my Aux tank (behind the rear seat in the baggage compartment), until it is close to empty, 20 gallons useable, about 1 hour 40 min. Which has returned 5+ gallons to the left wing tank. (Please note, I plan 3 hour trips as a rule, at 3 hours someone has to get out and pee and the pilot needs a break. 3 hours is about 450 miles plus.) Then I burn fuel out of the right wing tank (18 gallons useable about 1 hour and 40 min), which returns another 5+ gallons to the left tank. At that point I should be about 700 miles down the road and be landing on the left tank with over an hour of reserve fuel in the left tank. It is perfectly safe to run each tank until it is totally empty and the engine starts to die, the engine starts up when the tank is switched, but that really stresses passengers and I don't like the VERY LOUD SILENCE!. So I have timed the tanks and switch just a little early (within 5 min.) Some V-tails have 5 tanks (two mains, two tip tanks and an Aux tank. and a few have up to 7 tanks with two more outboard wing tanks. for all of these tanks the extra fuel is returned to the left tank! Some tip systems go directly to the engine and some feed a wing tank, but you must make room for that fuel or it will be pumped overboard, some have fuel pumps themselves. Yes, there is a larger fuel management issue that has caused pilots to crash due to fuel starvation with fuel in tanks. Y'all be careful now. Steve D On Thu, Feb 26, 2015 at 8:40 AM, Gary Boothe wrote: > =9CTrue confessions. We put the lever on the valve so long ago that I can't > remember if the handle points to the tank or the little pointer on the kn ob > points to the correct tank.=9D > > > Sorry to pick on this statement, Steve, but I couldn=99t help think ing about > the inexperienced, or rusty pilot (like me), flying his new Pietenpol for > the first time, and having to worry about fuel management. > > > What happens the first time that engine coughs on takeoff? > > > It=99s just my opinion, but, whether a builder designs and builds a > beautiful 15 gallon nose tank, like Mark=99s, or a 16 gallon center section > tank like mine, the Pietenpol does not need any more fueland def initely > not multiple tanks. In other words, one large tank is better than two > smaller onesagain, just my opinion. > > > Gary Boothe > > NX308MB > > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Steven Dortch > *Sent:* Thursday, February 26, 2015 5:37 AM > *To:* pietenpol-list(at)matronics.com > *Subject:* Re: Pietenpol-List: Re: Andy-- storage space and fuel > > > Yes, A header tank is a tank behind the engine/in front of the front > instrument panel that is fed by the wing tank. > > > However, for lack of a better term, people (including me) often call all > tanks behind the engine/in front of the front instrument panel, a header > tank. > > > Mine is not a header tank. I have a wing tank and a tank in front of the > front instrument panel/behind the engine that feed separately. I have a > fuel tank lever that has two off positions and one Wing tank position and > one "header" tank position. > > > True confessions. We put the lever on the valve so long ago that I can't > remember if the handle points to the tank or the little pointer on the kn ob > points to the correct tank. I guess I will figure that out during the fue l > flow tests. > > > Blue Skies, > > Steve D > > > *http://www.matronics.com/Navigator?Pietenpol-List * > > *http://forums.matronics.com * > > *http://www.matronics.com/contribution * > > > * > =========== .matronics.com/Navigator?Pietenpol-List> =========== =========== om/contribution> =========== > > * > > -- Blue Skies, Steve D ________________________________________________________________________________
Subject: small dogs, storage space, and tents
Date: Feb 26, 2015
My good friend and Pietenpol builder/owner/operator Jack Phillips wrote: 2) I have a very nice baggage compartment big enough to hold a tent, a slee ping bag, an airmattress and a small duffle bag, in addition to the chocks and tie downs I always carry. I don't see how you can carry much of a tent in the centersection, since it's only about 5" tall at the most. I've seen the tent Mike Cuy uses. My dog wouldn't fit in it. And it's a very small dog. I hate to be a stickler for the accuracy but in this case I'll make an exce ption. Jack doesn't actually carry his tent on his trips to Brodhead in th e Pietenpol but has it delivered to him by a good friend who holds it at a secret location somewhere in Wisconsin during the rest of the year. Here's my tent (that Jack's dog wouldn't fit into) that I use when going c ross country in my Piet. This photo happens to be from Lee Bottom Flying F ield in Hanover, Indiana in 2008. Not only does my tent fit in my center section baggage compartment but my a ir mattress fits up there too with lots of room for other things as well. I do admit that I have to sleep diagonally in this tent to be comfortable b ut it works and it is lightweight. Mike C. Ohio [cid:image001.png(at)01D051C4.8561BF80] [cid:image002.jpg(at)01D051C4.8561BF80] ________________________________________________________________________________
Date: Feb 26, 2015
Ah, but Mike I have carried the tent with me in the Pietenpol. You will recall in 2005 when I first flew mine to Brodhead, with a stop in Cleveland along the way. That year I did carry everything with me. Here's a picture of my baggage compartment while under construction, showing my sleeping bag and tent in place. You can see there's quite a bit of room left for other stuff. Here's the baggage compartment with the cowling and baggage door in place: Jack Phillips NX899JP Smith Mountain Lake, Virginia From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC] Sent: Thursday, February 26, 2015 1:03 PM Subject: Pietenpol-List: small dogs, storage space, and tents My good friend and Pietenpol builder/owner/operator Jack Phillips wrote: 2) I have a very nice baggage compartment big enough to hold a tent, a sleeping bag, an airmattress and a small duffle bag, in addition to the chocks and tie downs I always carry. I don't see how you can carry much of a tent in the centersection, since it's only about 5" tall at the most. I've seen the tent Mike Cuy uses. My dog wouldn't fit in it. And it's a very small dog. I hate to be a stickler for the accuracy but in this case I'll make an exception. Jack doesn't actually carry his tent on his trips to Brodhead in the Pietenpol but has it delivered to him by a good friend who holds it at a secret location somewhere in Wisconsin during the rest of the year. Here's my tent (that Jack's dog wouldn't fit into) that I use when going cross country in my Piet. This photo happens to be from Lee Bottom Flying Field in Hanover, Indiana in 2008. Not only does my tent fit in my center section baggage compartment but my air mattress fits up there too with lots of room for other things as well. I do admit that I have to sleep diagonally in this tent to be comfortable but it works and it is lightweight. Mike C. Ohio ________________________________________________________________________________
Subject: Toolstock officially underway.
Date: Feb 26, 2015
Scott and I each got a couple landings this morning in the yard... Complete with six inches of snow! Videos later. Hope to get some more flying in on Saturday. Got confirmation we will be having our first ever fly in guest coming Saturday. Gardener got in about an hour ago. Unfortunately had half a dozen guys stuck last night due to road closures, but all made it in this morning alright. Already made our first part, to get Scott's broke truck out of the way to start restoring a jointer for a guy who lost everything in a fire, tools he used to make a living. Will be pouring babbit nuts for the table adjusting mechanisms. Tons of great beer and food showing up. Anyone on the fence should hop off and head over! Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438780#438780 ________________________________________________________________________________
Date: Feb 26, 2015
You know I thought you carried your tent up there at least one time so that makes perfect sense! You have more room up there in the nose baggage section than I knew. I do recall shipping my suitcase to Wisconsin in 2009 when we did both Brod head AND the 75th Anniversary of the Pietenpol at Oshkosh because I had so much stuff that year and then mailed my baggage home from the University of WI, Oshkosh before flying home. [cid:image003.jpg(at)01D051D2.093BA430][cid:image004.jpg(at)01D051D2.093BA430] ________________________________________________________________________________
Date: Feb 26, 2015
I'm not a fan of fuel mangement procedures. The work load in any cockpit is high enough. That's one of the reasons I like highwings in general. When I bought my Airbike, that was one of the first mods I made. Previous owner had it set up for either/or on the wing tanks. That just didn't make sense to me. Whatever method I employ will be hands off in flight, and there will be no way to starve the engine as long as there is fuel in the tank(s). As a basic philosophy, I want engineer the ship to minimize the oportunities for pilot errors to create hazards. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438783#438783 ________________________________________________________________________________
Subject: Re: Toolstock officially underway.
Date: Feb 26, 2015
Hi whats on the agenda for Saturday? I will be attending my first TOOL STOCK on Saturday. I'm going to start on my Piet very soon.Anything you need me to bring? Tony 480-748-3470 -------- Tony Crawford Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438787#438787 ________________________________________________________________________________
Subject: EAA announces Long-Awaited Aeromedical Reform
From: "Jeff Boatright" <jeffboatright(at)emory.edu>
Date: Feb 26, 2015
Bipartisan bill in Senate, EAA asks that we try to get all delegates in Senate and House to sign on to bills in both houses: http://www.eaa.org/en/eaa/eaa-news-and-aviation-news/2015-news/02-26-2015-second-pilots-bill-of-rights-pushes-long-awaited-aeromedical-reform-forward And here's the link to the Rally Congress initiative. I did it; very easy. http://govt.eaa.org Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438788#438788 ________________________________________________________________________________
Date: Feb 26, 2015
BEER! Having a great time, looking forward to meeting ya. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438790#438790 ________________________________________________________________________________
Date: Feb 26, 2015
Chuck Have you seen the RV-12=99s 20 gal tank? Chris Sacramento, CA WestcoastPiet.com From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Charles N. Campbell Sent: Thursday, February 26, 2015 6:46 AM Subject: Re: Pietenpol-List: nose tank---gravity fed Mike, one more question -- two really. 1.) What thickness aluminum did you use for the tank? and 2) Did you weld it or rivet it with sealer in the joints? I was just wondering if it would be practical to even consider riveting. If I rivet, I'll get the rivets and rivet puller from Zenith. I like the way their rivets look after installing. Your buddy flew the BIG ones. I was a fighter pilot in the Navy, flying off the USS Hancock, CV-19. I got about 75 carrier landings in the F6F Hellcat. Thanks for the information. Chuck On Wed, Feb 25, 2015 at 11:22 AM, Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC] > wrote: Andy, Yes, my A-65 is all gravity fed with no need for a fuel pump. I highly suggest to follow the gravity fuel flow test that Tony Bingelis outlines in his homebuilder book series because that way you know exactly how much useable and unusable fuel you have in your tank. For a full-power, nose high (takeoff climb attitude) for my engine I can safely operate (according to the calculations I gleaned from Tony=99s books and test suggestions) down to 1.3 gallons remaining of my 17 gallon capacity. I never cut my fuel this low but at least I know when the fuel flow rate becomes insufficient to keep the carb fed. I basically built my plane with a phone, a credit card, and the Tony Bingelis books. The Bingelis books are worth their weight in gold for any homebuider---a bit dated but airworthiness never gets out of date really. And Chuck Campbell, I=99m sorry but I don=99t have dimensions for my fuel tank but basically I followed the shape of my front cockpit instrument panel radius (though I raised my instrument panels 1=9D higher than plans.) and then made the bottom of it slope forward at about the same angle and a little above as the front seat passenger=99s legs would be positioned. ________________________________________________________________________________
Date: Feb 26, 2015
No pics... Didn't happen... http://youtu.be/WjM19j4PFWs http://youtu.be/FQpBW1VjdU4 http://youtu.be/j8qRXp6jXL4 Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438793#438793 ________________________________________________________________________________
Date: Feb 27, 2015
Thanks Jeff I Fwd'ed this to our 120 EAA Chapter members Barry NX973BP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff Boatright Sent: Thursday, February 26, 2015 7:44 PM Subject: Pietenpol-List: EAA announces Long-Awaited Aeromedical Reform --> Bipartisan bill in Senate, EAA asks that we try to get all delegates in Senate and House to sign on to bills in both houses: http://www.eaa.org/en/eaa/eaa-news-and-aviation-news/2015-news/02-26-2015-se cond-pilots-bill-of-rights-pushes-long-awaited-aeromedical-reform-forward And here's the link to the Rally Congress initiative. I did it; very easy. http://govt.eaa.org Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438788#438788 ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Subject: Re: EAA announces Long-Awaited Aeromedical Reform
Date: Feb 27, 2015
VGhlIGZpcnN0IFBpbG904oCZcyBCaWxsIG9mIFJpZ2h0cyBwcmV0dHkgbXVjaCBzYWlsZWQgdGhy b3VnaCBpbiAyMDEyLiBIb3BlZnVsbHkgdGhpcyBvbmUgd2lsbCwgdG9vIQ0KDQotLQ0KSmVmZnJl eSBILiBCb2F0cmlnaHQsIFBoRCwgRkFSVk8NClByb2Zlc3NvciBvZiBPcGh0aGFsbW9sb2d5DQpF bW9yeSBVbml2ZXJzaXR5IFNjaG9vbCBvZiBNZWRpY2luZQ0KDQpGcm9tOiBCYXJyeSBEYXZpcyA8 YmVkQG1pbmRzcHJpbmcuY29tPG1haWx0bzpiZWRAbWluZHNwcmluZy5jb20+Pg0KUmVwbHktVG86 ICJwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPG1haWx0bzpwaWV0ZW5wb2wtbGlzdEBtYXRy b25pY3MuY29tPiIgPHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnBpZXRlbnBv bC1saXN0QG1hdHJvbmljcy5jb20+Pg0KRGF0ZTogRnJpZGF5LCBGZWJydWFyeSAyNywgMjAxNSBh dCAxMToxNiBBTQ0KVG86ICJwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPG1haWx0bzpwaWV0 ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPiIgPHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb208 bWFpbHRvOnBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20+Pg0KU3ViamVjdDogUkU6IFBpZXRl bnBvbC1MaXN0OiBFQUEgYW5ub3VuY2VzIExvbmctQXdhaXRlZCBBZXJvbWVkaWNhbCBSZWZvcm0N Cg0KLS0+IFBpZXRlbnBvbC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiQmFycnkgRGF2aXMiIDxi ZWRAbWluZHNwcmluZy5jb208bWFpbHRvOmJlZEBtaW5kc3ByaW5nLmNvbT4+DQoNClRoYW5rcyBK ZWZmDQpJIEZ3ZCdlZCB0aGlzIHRvIG91ciAxMjAgRUFBIENoYXB0ZXIgbWVtYmVycw0KQmFycnkN Ck5YOTczQlANCg0KLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0tLS0NCkZyb206IG93bmVyLXBpZXRl bnBvbC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tPG1haWx0bzpvd25lci1waWV0ZW5wb2wtbGlz dC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbT4NClttYWlsdG86b3duZXItcGlldGVucG9sLWxpc3Qtc2Vy dmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBKZWZmDQpCb2F0cmlnaHQNClNlbnQ6IFRo dXJzZGF5LCBGZWJydWFyeSAyNiwgMjAxNSA3OjQ0IFBNDQpUbzogcGlldGVucG9sLWxpc3RAbWF0 cm9uaWNzLmNvbTxtYWlsdG86cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbT4NClN1YmplY3Q6 IFBpZXRlbnBvbC1MaXN0OiBFQUEgYW5ub3VuY2VzIExvbmctQXdhaXRlZCBBZXJvbWVkaWNhbCBS ZWZvcm0NCg0KLS0+IFBpZXRlbnBvbC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiSmVmZiBCb2F0 cmlnaHQiDQotLT4gPGplZmZib2F0cmlnaHRAZW1vcnkuZWR1PG1haWx0bzpqZWZmYm9hdHJpZ2h0 QGVtb3J5LmVkdT4+DQoNCkJpcGFydGlzYW4gYmlsbCBpbiBTZW5hdGUsIEVBQSBhc2tzIHRoYXQg d2UgdHJ5IHRvIGdldCBhbGwgZGVsZWdhdGVzIGluDQpTZW5hdGUgYW5kIEhvdXNlIHRvIHNpZ24g b24gdG8gYmlsbHMgaW4gYm90aCBob3VzZXM6DQoNCmh0dHA6Ly93d3cuZWFhLm9yZy9lbi9lYWEv ZWFhLW5ld3MtYW5kLWF2aWF0aW9uLW5ld3MvMjAxNS1uZXdzLzAyLTI2LTIwMTUtc2UNCmNvbmQt cGlsb3RzLWJpbGwtb2YtcmlnaHRzLXB1c2hlcy1sb25nLWF3YWl0ZWQtYWVyb21lZGljYWwtcmVm b3JtLWZvcndhcmQNCg0KQW5kIGhlcmUncyB0aGUgbGluayB0byB0aGUgUmFsbHkgQ29uZ3Jlc3Mg aW5pdGlhdGl2ZS4gSSBkaWQgaXQ7IHZlcnkgZWFzeS4NCg0KaHR0cDovL2dvdnQuZWFhLm9yZw0K DQoNCg0KDQpSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6DQoNCmh0dHA6Ly9mb3J1bXMubWF0 cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9NDM4Nzg4IzQzODc4OA0KDQoNCg0KDQoNCg0KDQoN Cg0KDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUgUGlldGVucG9sLUxpc3QgRW1haWwgRm9y dW0gLQ0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJy b3dzZQ0KXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3Jp cHRpb24sDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0 LCBGQVEsDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAt LT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9QaWV0ZW5wb2wtTGlzdA0KXy09 DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PQ0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0g U2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCl8t PQ0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KXy09DQpfLT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09 ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KXy09ICBUaGFuayB5 b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPSAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0KDQoNCl9fX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fDQoNClRoaXMgZS1tYWlsIG1lc3NhZ2UgKGluY2x1ZGluZyBhbnkg YXR0YWNobWVudHMpIGlzIGZvciB0aGUgc29sZSB1c2Ugb2YNCnRoZSBpbnRlbmRlZCByZWNpcGll bnQocykgYW5kIG1heSBjb250YWluIGNvbmZpZGVudGlhbCBhbmQgcHJpdmlsZWdlZA0KaW5mb3Jt YXRpb24uIElmIHRoZSByZWFkZXIgb2YgdGhpcyBtZXNzYWdlIGlzIG5vdCB0aGUgaW50ZW5kZWQN CnJlY2lwaWVudCwgeW91IGFyZSBoZXJlYnkgbm90aWZpZWQgdGhhdCBhbnkgZGlzc2VtaW5hdGlv biwgZGlzdHJpYnV0aW9uDQpvciBjb3B5aW5nIG9mIHRoaXMgbWVzc2FnZSAoaW5jbHVkaW5nIGFu eSBhdHRhY2htZW50cykgaXMgc3RyaWN0bHkNCnByb2hpYml0ZWQuDQoNCklmIHlvdSBoYXZlIHJl Y2VpdmVkIHRoaXMgbWVzc2FnZSBpbiBlcnJvciwgcGxlYXNlIGNvbnRhY3QNCnRoZSBzZW5kZXIg YnkgcmVwbHkgZS1tYWlsIG1lc3NhZ2UgYW5kIGRlc3Ryb3kgYWxsIGNvcGllcyBvZiB0aGUNCm9y aWdpbmFsIG1lc3NhZ2UgKGluY2x1ZGluZyBhdHRhY2htZW50cykuDQo ________________________________________________________________________________
Date: Feb 27, 2015
Thanks Jeff, I pushed mine through my fb account hoping it will spread throu gh social media also It's just too important to neglect through complacency Sent from my iPhone > On Feb 27, 2015, at 11:25 AM, "Boatright, Jeffrey" wrote: > > The first Pilot=C3=A2=82=AC=84=A2s Bill of Rights pretty much sailed through in 2012. Hopefully this one will, too! > > -- > Jeffrey H. Boatright, PhD, FARVO > Professor of Ophthalmology > Emory University School of Medicine > > From: Barry Davis <bed(at)mindspring.com> > Reply-To: "pietenpol-list(at)matronics.com" > Date: Friday, February 27, 2015 at 11:16 AM > To: "pietenpol-list(at)matronics.com" > Subject: RE: Pietenpol-List: EAA announces Long-Awaited Aeromedical Reform > > > Thanks Jeff > I Fwd'ed this to our 120 EAA Chapter members > Barry > NX973BP > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff > Boatright > Sent: Thursday, February 26, 2015 7:44 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: EAA announces Long-Awaited Aeromedical Reform > > --> > > Bipartisan bill in Senate, EAA asks that we try to get all delegates in > Senate and House to sign on to bills in both houses: > > http://www.eaa.org/en/eaa/eaa-news-and-aviation-news/2015-news/02-26-2015- se > cond-pilots-bill-of-rights-pushes-long-awaited-aeromedical-reform-forward > > And here's the link to the Rally Congress initiative. I did it; very easy. > > http://govt.eaa.org > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438788#438788 > > > > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > > > > > This e-mail message (including any attachments) is for the sole use of > the intended recipient(s) and may contain confidential and privileged > information. If the reader of this message is not the intended > recipient, you are hereby notified that any dissemination, distribution > or copying of this message (including any attachments) is strictly > prohibited. > > If you have received this message in error, please contact > the sender by reply e-mail message and destroy all copies of the > original message (including attachments). > =C2=C2=B7=BA~=B0=C3=AD=C2=B2,=C3=9E=C3=99=C3=8A%=C2=A2=C2=BD 4=C3=93M4}=C2=A7=1Er=B9=C2=AB=B0=C3=C3=A7{=07(=C2=BA=C2=B8=C5 =BE=C2=AD8^>'=C2=ADzzh=9D=C2=B8=C2=AC=C2=B4I=C5=A1=C5-Qh=C2=AE=C3=A9 =9D=C2=B1=C3=ABax=C3=86=C2=AD=C2=AE=B0=C3=A2r=C3=82=C3=A2=C2=B2=C3 =91^j=C3=9B=C2=ABz=C3=83Z=C2=BE(=1A=C2=B6=C5-=C3=AD=C2=A1=C2=BA=C3=A8=C3=82 =C3=87=C2=AD=C3=A9=C5=A1=C5=B8"=C3=A2=C2=B2=C3=9B=C2=AD=C5-X=C2=AD =B0=C3=AB,=C2=B9=C3=88Z=C2=B0=C2=B8=C2=AC=C2=B5I=C3J=C3=C3=ACr=C2 =B8=C2=A9=C2=B6*'=02=C2=B7!=C5-=C3=B7=99y=C2=C3=9C=9E:0=C5=BE Z=1Aw=C2=B0=C3=9A=C3=88=1A=C3=A8=C3=82=C3=87=9A=C2=ABE=01=03=C3 =A1=C2=A2=C3=9A,=C2=C3=9Ejwf=C2=B9=C3=88f=C2=B9=C3=88f=C2=A2=C2=B7 =C5=A1-=C2=B7=C5=B8-=C3=9Bi=C3=C3=BC0=C3=82f=C2=AD=C2=AE =B0=C3=A2r=C3=87(=BA=C3=B3Z=C2=BE(=1A=C2=B6=C5-=C3=8F=B0=C3 =AB^=C5=BE=C5=A1%.+--=C3=9Bi=C3=C3=BC0=C3=82f=C2=AD=C2=AE=B0 =C3=A2r=C3=87(=BA=C3=B3Z=C2=BE(=1A=C2=B6=C5-=C3=8F=B0=C3=AB^=C5 =BE=C5=A1%.+-=C3=BD=C2=A3M=13=C2=8D $=93=10=11NEC=12I=C2=A9=C5=BE =9A=C2=B7=C5=A1=C2=B5=C3=8A'=C2=B5=C3=A9=C3=ADj[(j=C3=B6=C2=A2=A2=C2 =C3=A5z=C3=B8=C5=A1=C2=B6=17=93y=C2=B1h=C2=AE=C3=A9=C2=ACj=1A=C3=9E~=1B m=C2=A7=C3=C3=9F=C2=A2=C2=BB=C2=C2=B2f=C2=AD=C2=AE=B0=C3=A2r=C3=87 (=C5=A1=1Bm=C2=A7=C3=C3=9F=C2=A2=C2=BB=C2=C2=B2f=C2=AD=C2=AE=B0=C3 =A2r=C3=87(=BA=C3=B6=B9=C5-=C3=8BB=C2=A2{k=B0=C2=BB=C2=AD =C5-=B0=C3'y=C2=B4=C2=A2=C2=B5=C3=A4=C3=A1jy2=C2=A2=C3=A7=C3=A8=C2 =AF*.=C2=AE=07=C2=A7z=C2=BA.=C2=B2=C3=8B=C2=A9=C2=C5-=C3=AD1=C2=ABm=0E=C2 =B6=C2=A5=A2=C3=A2=C3=A2=C2=B2=C3=90=1D=C5=A1)=C3=9A-=C2=B7=C5 =B8-=C3=9Bi=C3=C3=BC0=C3=82f=C2=AD=C2=AE=B0=C3=A2r=C3=87( =BA=C3=B7(=C5=BE=C3=9A=C3=A2n=C3=ABb=C2=A2xm=C2=B6=C5=B8=C3=C3=83=0C&j =C3=9A=C3=A8=C5=BE',r=B0=C2r=B0=C3=AD=C2=AE&=C3=AE=C2=B6*'=C3 =BD=C2=AF=C3=9B=C3=BD=C3=BA'=C2=B7=C3=BAk{=C3=B6=C3=A8w/=C3=A1=C2=B6i ________________________________________________________________________________
Date: Feb 27, 2015
I will sign and I will contact my congresscritter. One suggestion for improvement is to raise the ceiling to 18000 feet to make it more useable in the Rockies. At 15,000 feet there are areas in Colorado and Wyoming where at 15,000 feet you are a 1000 feet above the mountain passes. Not enough space when there is nothing but turbulence and granite cumulus around. Blue Skies, Steve D On Fri, Feb 27, 2015 at 10:16 AM, Barry Davis wrote: > > Thanks Jeff > I Fwd'ed this to our 120 EAA Chapter members > Barry > NX973BP > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff > Boatright > Sent: Thursday, February 26, 2015 7:44 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: EAA announces Long-Awaited Aeromedical Reform > > --> > > Bipartisan bill in Senate, EAA asks that we try to get all delegates in > Senate and House to sign on to bills in both houses: > > > http://www.eaa.org/en/eaa/eaa-news-and-aviation-news/2015-news/02-26-2015-se > cond-pilots-bill-of-rights-pushes-long-awaited-aeromedical-reform-forward > > And here's the link to the Rally Congress initiative. I did it; very easy. > > http://govt.eaa.org > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438788#438788 > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Feb 27, 2015
4 Big Piet Dudes will be there around noon tomorrow Barry -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tools Sent: Friday, February 27, 2015 1:54 AM Subject: Pietenpol-List: Re: Toolstock officially underway. No pics... Didn't happen... http://youtu.be/WjM19j4PFWs http://youtu.be/FQpBW1VjdU4 http://youtu.be/j8qRXp6jXL4 Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438793#438793 ________________________________________________________________________________
Subject: Re: small dogs, storage space, and tents
Date: Feb 27, 2015
I know it's hard to believe but there's actually quite a bit of room up in the center section. I can fit my tie downs, air mattress, tarp to cover the cockpits, and my nylon Hilton up there. I'm kinda long so I like to have a long enough and tall enough tent. I'm also done with sleeping on the hard ground so a queen size air mattress it is. It's a bit tight up there but it works out well. With careful planning and creative packing, my son and I can live out of the Piet for a week. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438806#438806 Attachments: http://forums.matronics.com//files/image_151.jpg http://forums.matronics.com//files/image_101.jpg ________________________________________________________________________________
Date: Feb 27, 2015
What's a "big Piet"? Glen Sent from my iPhone > On Feb 27, 2015, at 1:19 PM, "Barry Davis" wrote: > > > 4 Big Piet Dudes will be there around noon tomorrow > Barry > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tools > Sent: Friday, February 27, 2015 1:54 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Toolstock officially underway. > > > No pics... Didn't happen... > > http://youtu.be/WjM19j4PFWs > > http://youtu.be/FQpBW1VjdU4 > > http://youtu.be/j8qRXp6jXL4 > > Tools > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438793#438793 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 27, 2015
Glen; I'll let the actual "Big Piets" reply formally, but it's a group of builders who worked on their airplanes all at the same time and "right sized" them for their bigger builds. I don't remember exactly what they stretched or by how much, but they were not built to stock size. Oh, and several were involved in the "PietenPile" that happened when a storm hit Sun 'n' Fun a few years ago. Gardiner (who is also at Toolstock) was the unfortunate star of the PietenPile and I wince every time I see the picture of his airplane all balled up. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438808#438808 ________________________________________________________________________________
Date: Feb 27, 2015
WF2: that is a beautiful prop. What is the finish on it? Looks like a gloss polyurethane varnish that should be pretty easy to keep the bugs cleaned off of. Do you use the Lemon Pledge method to keep the bugs from sticking? -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438809#438809 ________________________________________________________________________________
Date: Feb 27, 2015
I saw pictures of that. What a damned shame. I also read that a lot of damage was caused by sun n fun officials and volunteers carelessly tearing the pile apart. Glen Sent from my iPhone > On Feb 27, 2015, at 6:06 PM, "taildrags" wrote: > > > Glen; I'll let the actual "Big Piets" reply formally, but it's a group of builders who worked on their airplanes all at the same time and "right sized" them for their bigger builds. I don't remember exactly what they stretched or by how much, but they were not built to stock size. Oh, and several were involved in the "PietenPile" that happened when a storm hit Sun 'n' Fun a few years ago. Gardiner (who is also at Toolstock) was the unfortunate star of the PietenPile and I wince every time I see the picture of his airplane all balled up. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438808#438808 > > > > > > > > > > ________________________________________________________________________________
Date: Feb 27, 2015
We will be looking for you, Gardiner. Sent from my iPad > On Feb 27, 2015, at 4:19 PM, "Barry Davis" wrote: > > > 4 Big Piet Dudes will be there around noon tomorrow > Barry > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tools > Sent: Friday, February 27, 2015 1:54 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Toolstock officially underway. > > > No pics... Didn't happen... > > http://youtu.be/WjM19j4PFWs > > http://youtu.be/FQpBW1VjdU4 > > http://youtu.be/j8qRXp6jXL4 > > Tools > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438793#438793 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 27, 2015
Thanks Oskar, I am at toolstock now and looking forward to seeing the Big Piets. Gardiner Sent from my iPad > On Feb 27, 2015, at 9:06 PM, "taildrags" wrote: > > > Glen; I'll let the actual "Big Piets" reply formally, but it's a group of builders who worked on their airplanes all at the same time and "right sized" them for their bigger builds. I don't remember exactly what they stretched or by how much, but they were not built to stock size. Oh, and several were involved in the "PietenPile" that happened when a storm hit Sun 'n' Fun a few years ago. Gardiner (who is also at Toolstock) was the unfortunate star of the PietenPile and I wince every time I see the picture of his airplane all balled up. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438808#438808 > > > > > > > > > > ________________________________________________________________________________
From: Fastnaught John <fastnaught(at)windstream.net>
Date: Feb 27, 2015
Hello Gardiner, Jack here. Just got my airworthiness cert. and am planning to fly to Brodhead this year. I would like to talk to you and the big Piet guys to maybe hook up and fly together for those that are going. Would you send me a contact info so I might give you a call and talk it over. And the Big Piet guys as well if any are interested. Thanks, Jack N144JF Wire wheels And a Ford Model A. > On Feb 27, 2015, at 9:49 PM, Gardiner Mason wrote: > > > Thanks Oskar, I am at toolstock now and looking forward to seeing the Big Piets. Gardiner > > Sent from my iPad > >> On Feb 27, 2015, at 9:06 PM, "taildrags" wrote: >> >> >> Glen; I'll let the actual "Big Piets" reply formally, but it's a group of builders who worked on their airplanes all at the same time and "right sized" them for their bigger builds. I don't remember exactly what they stretched or by how much, but they were not built to stock size. Oh, and several were involved in the "PietenPile" that happened when a storm hit Sun 'n' Fun a few years ago. Gardiner (who is also at Toolstock) was the unfortunate star of the PietenPile and I wince every time I see the picture of his airplane all balled up. >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=438808#438808 >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Subject: Re: Four-bladed prop
Date: Feb 28, 2015
taildrags wrote: > WF2: that is a beautiful prop. What is the finish on it? Looks like a gloss polyurethane varnish that should be pretty easy to keep the bugs cleaned off of. Do you use the Lemon Pledge method to keep the bugs from sticking? Thanks. You are correct, with glassed tips and a reinforced leading edge. I used Simoniz wax, it worked great. Wood is Ash. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438814#438814 ________________________________________________________________________________
Date: Feb 28, 2015
WF2: one more question on your prop. I just noticed that prop has an 8-bolt pattern. What hub, what engine-? -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438817#438817 ________________________________________________________________________________
Date: Mar 01, 2015
taildrags wrote: > WF2: one more question on your prop. I just noticed that prop has an 8-bolt pattern. What hub, what engine-? Model-A @ 59 HP. Custom hub was machined to mate with engines crankshaft, 8-bolts needed to prevent propeller slippage. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438819#438819 ________________________________________________________________________________
Subject: Re: New (Free) Aviation App
Date: Mar 01, 2015
Now approaching 6000 pilots using the app with over 1350 listings, and a recent review on the EAA website. And in a feeble attempt to recoup my costs, I am now offering very reasonably priced ad's for aviation related businesses as I keep my word to keep this app free for pilots. If you or someone you know may be interested, please email me at airportcars101(at)gmail.com for rates. And please tell your FBO where you found them. Thank you. Glenn -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438852#438852 ________________________________________________________________________________
Subject: Recent visits.
Date: Mar 02, 2015
I had the honor of two visits with Pietenpol builders while working in the Charlotte NC area recently. Here are some pictures from my visit with Don Youngblood. He is building a VERY close to plans Pietenpol Air Camper near Greenville, SC. And it's going to be a nice one! Don is retired and gets to work on it a LOT. In fact, every time I called before my visit he was in the garage working on it! I wish I had visited him a few years ago, he did a couple little things I SHOULD have done! Oh well. Getting to meet Don (and Chuck Campbell the week before) was a real pleasure. Jim in Pryor....where my visit with Don resulted in me being motivated to put the final topcoat on the bottom of my first wing panel....one more topcoat on the top and the FINAL wing panel moves into the (heated) garage! Thanks for the motivation Don! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438881#438881 Attachments: http://forums.matronics.com//files/don6_186.jpg http://forums.matronics.com//files/don5_749.jpg http://forums.matronics.com//files/don4_598.jpg http://forums.matronics.com//files/don3_175.jpg http://forums.matronics.com//files/don2_104.jpg http://forums.matronics.com//files/don1_108.jpg ________________________________________________________________________________
Subject: Jeepenpol progress
Date: Mar 02, 2015
I finished the silver coats of dope today and will soon move this fuselage to my hanger to finish paint and assembly. I need to free up the space in my small workshop so I can begin to assemble my wings... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438891#438891 Attachments: http://forums.matronics.com//files/left_side_silver_fuselage_817.jpg ________________________________________________________________________________
Subject: Shop Press Dies on eBay
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Mar 02, 2015
I came across this eBay listing and contacted the guy. He is looking for me a punch and vee die along with an additional gooseneck to use- http://www.ebay.com/itm/111569842812?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Basically, he sells you a 3 inch to 5 inch section (but can sell you longer pieces as needed) of each punch and die that you order from him. I will let you know how it works out, but I emailed him and he seemed to be on the up and up. It might be a good source for dies for the small amount of metal work needed for building a Pietenpol. I have attached a screenshot of the listing for you to get a quick look, and you can click on the link if you have further interest. Hope it helps someone. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438892#438892 Attachments: http://forums.matronics.com//files/ebay_dies_for_sale_548.jpg ________________________________________________________________________________
Date: Mar 02, 2015
I came across this eBay listing and contacted the guy. He is looking for me a punch and vee die along with an additional gooseneck to use- http://www.ebay.com/itm/111569842812?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Basically, he sells you a 3 inch to 5 inch section (but can sell you longer pieces as needed) of each punch and die that you order from him. I will let you know how it works out, but I emailed him and he seemed to be on the up and up. It might be a good source for dies for the small amount of metal work needed for building a Pietenpol. I have attached a screenshot of the listing for you to get a quick look, and you can click on the link if you have further interest. Hope it helps someone. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438893#438893 Attachments: http://forums.matronics.com//files/ebay_dies_for_sale_548.jpg ________________________________________________________________________________
Date: Mar 02, 2015
I came across this eBay listing and contacted the guy. He is looking for me a punch and vee die along with an additional gooseneck to use- http://www.ebay.com/itm/111569842812?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Basically, he sells you a 3 inch to 5 inch section (but can sell you longer pieces as needed) of each punch and die that you order from him. I will let you know how it works out, but I emailed him and he seemed to be on the up and up. It might be a good source for dies for the small amount of metal work needed for building a Pietenpol. I have attached a screenshot of the listing for you to get a quick look, and you can click on the link if you have further interest. Hope it helps someone. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438894#438894 Attachments: http://forums.matronics.com//files/ebay_dies_for_sale_548.jpg ________________________________________________________________________________
Subject: What color is this Pietenpol?
Date: Mar 03, 2015
Blue/Gold? White/Black? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438948#438948 Attachments: http://forums.matronics.com//files/600_piet_830.jpg ________________________________________________________________________________
Date: Mar 03, 2015
White & Brown? Barry -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bill Church Sent: Tuesday, March 03, 2015 12:53 PM Subject: Pietenpol-List: What color is this Pietenpol? --> Blue/Gold? White/Black? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438948#438948 Attachments: http://forums.matronics.com//files/600_piet_830.jpg ________________________________________________________________________________
Subject: Re: What color is this Pietenpol?
Date: Mar 03, 2015
Definitely Blue/Gold Sent from my iPhone > On Mar 3, 2015, at 11:57 AM, Bill Church wrote: > > > Blue/Gold? > White/Black? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438948#438948 > > > > > Attachments: > > http://forums.matronics.com//files/600_piet_830.jpg > > > > > > > ________________________________________________________________________________
Date: Mar 03, 2015
I think it's black and white and read all over... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438984#438984 ________________________________________________________________________________
Subject: Re: Recent visits.
Date: Mar 03, 2015
Great pics! I like that he did the wire wrap/solder thing to his wires--very old school. Yet, at first glace his elevator control horn looks like a flat piece of material, aluminum maybe? I've actually been wondering about that as I study for my build. What options have people used for control horns. I'm looking at ways to reduce the amount of welding to be done. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438985#438985 ________________________________________________________________________________
Subject: A couple of questions about wing construction
Date: Mar 03, 2015
So, I have read that their is a discrepancy between the full size wing rib layout provided by Andrew Pietenpol and the actual stated dimensions in the plans. My own measurements confirm this. Go with the plans? Go with the stencil? Works either way? I also have a question about the three piece wing. The mounting method to the center section looks as simple as one bolt per spar--at the bottom in the notch. This allows the wing to lower when the strut is disconnected. The method for covering the gap is not discussed (or I haven't seen it yet). Photos reveal that most use sheets of aluminum and a lot of screws. Is this correct? Other options? I also wonder if this is the area where we are to add the 1" dihedral mentioned in the manual to avoid the appearance of a drooping wing. I interpret this as meaning that the wing tips are 1" higher than the center section, and that I achieve this with a subtle angle cut on the spars. Is my thinking sound? -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438986#438986 ________________________________________________________________________________
Date: Mar 03, 2015
Andy, Did you know there is a "Search Engine" on the matronics site? I entered, "control horns", and got 325 entries! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Andy Garrett Sent: Tuesday, March 03, 2015 3:19 PM Subject: Pietenpol-List: Re: Recent visits. --> Great pics! I like that he did the wire wrap/solder thing to his wires--very old school. Yet, at first glace his elevator control horn looks like a flat piece of material, aluminum maybe? I've actually been wondering about that as I study for my build. What options have people used for control horns. I'm looking at ways to reduce the amount of welding to be done. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438985#438985 ________________________________________________________________________________
Date: Mar 03, 2015
Ditto for this subject. Note that there are 421 responses to the query, "Dihedral." Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Andy Garrett Sent: Tuesday, March 03, 2015 3:31 PM Subject: Pietenpol-List: A couple of questions about wing construction --> So, I have read that their is a discrepancy between the full size wing rib layout provided by Andrew Pietenpol and the actual stated dimensions in the plans. My own measurements confirm this. Go with the plans? Go with the stencil? Works either way? I also have a question about the three piece wing. The mounting method to the center section looks as simple as one bolt per spar--at the bottom in the notch. This allows the wing to lower when the strut is disconnected. The method for covering the gap is not discussed (or I haven't seen it yet). Photos reveal that most use sheets of aluminum and a lot of screws. Is this correct? Other options? I also wonder if this is the area where we are to add the 1" dihedral mentioned in the manual to avoid the appearance of a drooping wing. I interpret this as meaning that the wing tips are 1" higher than the center section, and that I achieve this with a subtle angle cut on the spars. Is my thinking sound? -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438986#438986 ________________________________________________________________________________
Subject: Re: A couple of questions about wing construction
Date: Mar 03, 2015
Yes. Thank you for the subtle 'Use the search feature before posting rookie questions' tip. I'll try not to wear out my welcome. [Wink] -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438989#438989 ________________________________________________________________________________
Date: Mar 03, 2015
Andy, the one question that you posed that has received less attention through the years is how to cover the gap between the center section and the wing panels when building to the three piece wing supplement. Most people have done what you've suggested as a possible answer -- i.e., used a strip of aluminum that is held in place with screws. That works. I opted to use four inch fabric tape and covered the gap with fabric, which I then primed and painted using a brush. The trade-off is that if I ever have to remove the wings, I'll have to start by using a box cutter to slice the fabric covering the gap. On the other hand, my wing looks like it was built to the original one piece plans. And I'm pretty sure that eliminating all those screws will increase my top speed so much that I'll be able to out run whole herds of stampeding dairy cows. Welcome to the list, Ken On Tue, Mar 3, 2015 at 5:59 PM, Andy Garrett wrote: > andy_garrett(at)live.com> > > Yes. Thank you for the subtle 'Use the search feature before posting > rookie questions' tip. > > I'll try not to wear out my welcome. [Wink] > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438989#438989 > > ________________________________________________________________________________
Date: Mar 03, 2015
Andy I don't believe Gary was saying not to ask questions. I'm sure he was saying that if you only ask questions to the list you will get a few answers from the people currently on the list. All beneficial but by searching the archives you get the benefit of years of discussions by way more people than you would get by just simply asking. I've read through all the archives and there are a ton of good things in there that new builders should know. Problem is I forget most of them so I have to go searching for them all the time. Chris Sacramento, CA WestcoastPiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Andy Garrett Sent: Tuesday, March 3, 2015 4:59 PM Subject: Pietenpol-List: Re: A couple of questions about wing construction --> Yes. Thank you for the subtle 'Use the search feature before posting rookie questions' tip. I'll try not to wear out my welcome. [Wink] -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438989#438989 ________________________________________________________________________________
Date: Mar 03, 2015
...and don't forget to check out Chris' website, www.westcoastpiet.com, where you will see interesting things like this (speaking of alternative methods of attaching those wing fairings, see attached). Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of CatDesigns Sent: Tuesday, March 03, 2015 5:50 PM Subject: RE: Pietenpol-List: Re: A couple of questions about wing construction Andy I don't believe Gary was saying not to ask questions. I'm sure he was saying that if you only ask questions to the list you will get a few answers from the people currently on the list. All beneficial but by searching the archives you get the benefit of years of discussions by way more people than you would get by just simply asking. I've read through all the archives and there are a ton of good things in there that new builders should know. Problem is I forget most of them so I have to go searching for them all the time. Chris Sacramento, CA WestcoastPiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Andy Garrett Sent: Tuesday, March 3, 2015 4:59 PM Subject: Pietenpol-List: Re: A couple of questions about wing construction --> Yes. Thank you for the subtle 'Use the search feature before posting rookie questions' tip. I'll try not to wear out my welcome. [Wink] -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438989#438989 ________________________________________________________________________________
Date: Mar 03, 2015
FWIW, I took the initial response the same way Andy did. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439002#439002 ________________________________________________________________________________
Date: Mar 03, 2015
Don's control horns are actually not one solid piece of material. It's hard to tell from the pics but they are made from two pieces of thin 4130 welded together. Pietenpol control horns built per plans are light, extremely strong and simple to build. And the welding part of the horns is really minimal. Jim in Pryor Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439007#439007 ________________________________________________________________________________
From: "=?utf-8?B?c3RldmVuLmQuZG9ydGNoQGdtYWlsLmNvbQ==?=" <steven.d.dortch(at)gmail.com>
Subject: =?utf-8?B?UmU6IFBpZXRlbnBvbC1MaXN0OiBSZTogQSBjb3VwbGUgb2YgcXVlc3Rpb25zIGFi?=
=?utf-8?B?b3V0IHdpbmcgY29uc3RydWN0aW9u?
Date: Mar 03, 2015
SSB1c3VhbGx5IGdvIGEgR29vZ2xlIHNlYXJjaCBhbmQgIGluY2x1ZGUgdGhlIHN1YmplY3Qgd2l0 aCB0aGUgd29yZHMgIFBpZXRlbnBvbCBhbmQgbWF0cm9uaWNzLgoKV29ya3MgbGlrZSBhIGNoYXJt LiBNb3N0IG9mIHRoZSB0aW1lLgoKRnJvbSBteSBIVEMgU2Vuc2F0aW9uIDRHIG9uIFQtTW9iaWxl LiBUaGUgZmlyc3QgbmF0aW9ud2lkZSA0RyBuZXR3b3JrCgotLS0tLSBSZXBseSBtZXNzYWdlIC0t LS0tCkZyb206ICJHYXJ5IEJvb3RoZSIgPGdib290aGU1QGNvbWNhc3QubmV0PgpUbzogPHBpZXRl bnBvbC1saXN0QG1hdHJvbmljcy5jb20+ClN1YmplY3Q6IFBpZXRlbnBvbC1MaXN0OiBSZTogQSBj b3VwbGUgb2YgcXVlc3Rpb25zIGFib3V0IHdpbmcgY29uc3RydWN0aW9uCkRhdGU6IFR1ZSwgTWFy IDMsIDIwMTUgMjA6MzMKCgouLi5hbmQgZG9uJ3QgZm9yZ2V0IHRvIGNoZWNrIG91dCBDaHJpcycg d2Vic2l0ZSwgd3d3Lndlc3Rjb2FzdHBpZXQuY29tLAp3aGVyZSB5b3Ugd2lsbCBzZWUgaW50ZXJl c3RpbmcgdGhpbmdzIGxpa2UgdGhpcyAoc3BlYWtpbmcgb2YgYWx0ZXJuYXRpdmUKbWV0aG9kcyBv ZiBhdHRhY2hpbmcgdGhvc2Ugd2luZyBmYWlyaW5ncywgc2VlIGF0dGFjaGVkKS4KCgoKR2FyeSBC b290aGUKTlgzMDhNQgoKCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tCkZyb206IG93bmVyLXBp ZXRlbnBvbC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tClttYWlsdG86b3duZXItcGlldGVucG9s LWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBDYXREZXNpZ25zClNlbnQ6 IFR1ZXNkYXksIE1hcmNoIDAzLCAyMDE1IDU6NTAgUE0KVG86IHBpZXRlbnBvbC1saXN0QG1hdHJv bmljcy5jb20KU3ViamVjdDogUkU6IFBpZXRlbnBvbC1MaXN0OiBSZTogQSBjb3VwbGUgb2YgcXVl c3Rpb25zIGFib3V0IHdpbmcKY29uc3RydWN0aW9uCgotLT4gUGlldGVucG9sLUxpc3QgbWVzc2Fn ZSBwb3N0ZWQgYnk6ICJDYXREZXNpZ25zIiA8Q2F0RGVzaWduc0BhdHQubmV0PgoKQW5keQoKSSBk b24ndCBiZWxpZXZlIEdhcnkgd2FzIHNheWluZyBub3QgdG8gYXNrIHF1ZXN0aW9ucy4gIEknbSBz dXJlIGhlIHdhcwpzYXlpbmcgdGhhdCBpZiB5b3Ugb25seSBhc2sgcXVlc3Rpb25zIHRvIHRoZSBs aXN0IHlvdSB3aWxsIGdldCBhIGZldyBhbnN3ZXJzCmZyb20gdGhlIHBlb3BsZSBjdXJyZW50bHkg b24gdGhlIGxpc3QuIEFsbCBiZW5lZmljaWFsIGJ1dCBieSBzZWFyY2hpbmcgdGhlCmFyY2hpdmVz IHlvdSBnZXQgdGhlIGJlbmVmaXQgb2YgeWVhcnMgb2YgZGlzY3Vzc2lvbnMgYnkgd2F5IG1vcmUg cGVvcGxlIHRoYW4KeW91IHdvdWxkIGdldCBieSBqdXN0IHNpbXBseSBhc2tpbmcuICBJJ3ZlIHJl YWQgdGhyb3VnaCBhbGwgdGhlIGFyY2hpdmVzIGFuZAp0aGVyZSBhcmUgYSB0b24gb2YgZ29vZCB0 aGluZ3MgaW4gdGhlcmUgdGhhdCBuZXcgYnVpbGRlcnMgc2hvdWxkIGtub3cuClByb2JsZW0gaXMg SSBmb3JnZXQgbW9zdCBvZiB0aGVtIHNvIEkgaGF2ZSB0byBnbyBzZWFyY2hpbmcgZm9yIHRoZW0g YWxsIHRoZQp0aW1lLgoKCkNocmlzClNhY3JhbWVudG8sIENBCldlc3Rjb2FzdFBpZXQuY29tCgoK Ci0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tCkZyb206IG93bmVyLXBpZXRlbnBvbC1saXN0LXNl cnZlckBtYXRyb25pY3MuY29tClttYWlsdG86b3duZXItcGlldGVucG9sLWxpc3Qtc2VydmVyQG1h dHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBBbmR5IEdhcnJldHQKU2VudDogVHVlc2RheSwgTWFy Y2ggMywgMjAxNSA0OjU5IFBNClRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tClN1Ympl Y3Q6IFBpZXRlbnBvbC1MaXN0OiBSZTogQSBjb3VwbGUgb2YgcXVlc3Rpb25zIGFib3V0IHdpbmcg Y29uc3RydWN0aW9uCgotLT4gUGlldGVucG9sLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJBbmR5 IEdhcnJldHQiIAotLT4gPGFuZHlfZ2FycmV0dEBsaXZlLmNvbT4KClllcy4gVGhhbmsgeW91IGZv ciB0aGUgc3VidGxlICdVc2UgdGhlIHNlYXJjaCBmZWF0dXJlIGJlZm9yZSBwb3N0aW5nIHJvb2tp ZQpxdWVzdGlvbnMnIHRpcC4KCkknbGwgdHJ5IG5vdCB0byB3ZWFyIG91dCBteSB3ZWxjb21lLiAg W1dpbmtdCgotLS0tLS0tLQpBbmR5IEdhcnJldHQKJ0dlbmVyYWwgUHVycG9zZSBDcmVhdGl2ZSBE dWRlJwpIYXlzdmlsbGUsIEthbnNhcwoKCgoKUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOgoK aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00Mzg5ODkjNDM4OTg5 CgoKCgoKCgoKCgoKCgo ________________________________________________________________________________
Date: Mar 03, 2015
A close look at that first picture points out that he's thought about providing some offset in the vertical stabilizer leading edge in case some rudder trim is needed. He's placed an indexing pin (a nail) right ahead of the leading edge, maybe what he used to run a string down the longitudinal axis to align everything with or maybe what he's using to square the wings by measuring from there out to each wingtip, but the yaw adjustment comes in the form of extra washers or spacers under the bolt heads that attach the forward VS attach brackets. Adding or removing spacers will permit deflecting the leading edge, thus adding yaw trim without holding rudder pedal pressure or using a rudder trim tab. On my airplane, a combination of vertical stabilizer offset and engine thrust line offset *almost* got me there, but 41CC still has a fixed bent-metal rudder trim tab on it for flying straight in cruise without having to ride a rudder pedal. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439017#439017 ________________________________________________________________________________
Date: Mar 03, 2015
Oh, and- note to Chris Tracy: snag these photos and the ones of Aviken's "Jeep Camper" for upload to Westcoastpiet. Good stuff in all these photos! -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439018#439018 ________________________________________________________________________________
Date: Mar 03, 2015
See, you guys all just want to make fun of this airplane as if it were some kind of a dress. All I see is an Air Camper, and one with a lot of similarities to 41CC when I had the A65 on it. The Aeronca heat muff is what I still have, but with the 65 I also had a small forward-facing air scoop like this one on the inlet to the heat muff in order to get a more forceful flow of air through the heat box. I had those standard Aeronca stacks, which rusted out in just a few short years and that I replaced with welded stainless steel ones. I had the tall cooling air scoop "eyebrows" like these till I went to a set of lower-profile J-3 style scoops. Scout still has cabane brace struts very similar to these, with Aurora ball end fittings at the top, which proved to be a weak link and a failure point when the airplane went over on its back. One broke and one bent, right where those fittings thread into the streamline tubing. My airplane has a slightly higher turtledeck than this one, where this one seems to dip to a lower profile just aft of the pilot's seat back. This airplane has one thing that I was determined to avoid on mine: the brake cables have quite a bit of extra length in them, which (to my mind) makes them susceptible to getting snagged when landing in fields and tall grass, which I do from time to time. Although I don't have cable-actuated brakes, I made it a point of routing my brake line tubing tight to the gear legs, on the aft side of them, in order to protect them from passing brush and grass. I am not being critical here... just trying to be observant and learn from other airplanes. Some people see a dress: I see an airplane ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439020#439020 ________________________________________________________________________________
Date: Mar 03, 2015
Oh, yeah... and notice that the blue and grey airplane has a simple float rod fuel level indicator in the nose tank, just like Scout ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439021#439021 ________________________________________________________________________________
Date: Mar 04, 2015
From: "Charles N. Campbell" <charlescampbell1924(at)gmail.com>
I made all my control horns out of .09 thick 4130 steel sheet. They might be a bit heavier than the two-piece, welded model, but they were a lot less trouble to build. 2 cents worth. Chuck On Tue, Mar 3, 2015 at 6:18 PM, Andy Garrett wrote: > andy_garrett(at)live.com> > > Great pics! I like that he did the wire wrap/solder thing to his > wires--very old school. Yet, at first glace his elevator control horn looks > like a flat piece of material, aluminum maybe? > > I've actually been wondering about that as I study for my build. What > options have people used for control horns. I'm looking at ways to reduce > the amount of welding to be done. > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438985#438985 > > ________________________________________________________________________________
Date: Mar 04, 2015
You can look here too: Pietenpol Plan Packages (https://sites.google.com/site/pietenpolplanpackages/) Remember adding dihedral will reduce lift. You will have some dihedral as the wing starts to fly. If you just want it for appearance then add in just enough to give you that visual appearance, no more. Good luck with your build, WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439028#439028 ________________________________________________________________________________
Date: Mar 04, 2015
Andy, Control horns built to the plans will be lighter and stronger than control horns cut from flat sheet. Do not fear the welding. Greg Cardinal Minneapolis ----- Original Message ----- From: "Andy Garrett" <andy_garrett(at)live.com> Sent: Tuesday, March 03, 2015 5:18 PM Subject: Pietenpol-List: Re: Recent visits. > > > Great pics! I like that he did the wire wrap/solder thing to his > wires--very old school. Yet, at first glace his elevator control horn > looks like a flat piece of material, aluminum maybe? > > I've actually been wondering about that as I study for my build. What > options have people used for control horns. I'm looking at ways to reduce > the amount of welding to be done. > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438985#438985 > > > --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com ________________________________________________________________________________
Date: Mar 04, 2015
Ribs built to the drawing supplied with the plans will fly just fine. Keri-Ann Price used to sell plans for a gapless 3-piece wing. This was used on NX18235 and is a good option. As others have stated, www.westcoastpiet.com and the archives have a wealth of info. Enjoy the build. Greg Cardinal Minneapolis ----- Original Message ----- From: "Andy Garrett" <andy_garrett(at)live.com> Sent: Tuesday, March 03, 2015 5:31 PM Subject: Pietenpol-List: A couple of questions about wing construction > > > So, I have read that their is a discrepancy between the full size wing rib > layout provided by Andrew Pietenpol and the actual stated dimensions in > the plans. My own measurements confirm this. > > Go with the plans? Go with the stencil? Works either way? > > I also have a question about the three piece wing. The mounting method to > the center section looks as simple as one bolt per spar--at the bottom in > the notch. This allows the wing to lower when the strut is disconnected. > > The method for covering the gap is not discussed (or I haven't seen it > yet). Photos reveal that most use sheets of aluminum and a lot of screws. > Is this correct? Other options? > > I also wonder if this is the area where we are to add the 1" dihedral > mentioned in the manual to avoid the appearance of a drooping wing. I > interpret this as meaning that the wing tips are 1" higher than the center > section, and that I achieve this with a subtle angle cut on the spars. Is > my thinking sound? > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438986#438986 > > > --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com ________________________________________________________________________________
Date: Mar 04, 2015
Actually, the edge welding done on the control horns is very easy and is fun to do. And the built-up horns look mire "Pietenpol-ish" Just my opinion. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Greg Cardinal Sent: Wednesday, March 4, 2015 7:58 AM Subject: Re: Pietenpol-List: Re: Recent visits. --> Andy, Control horns built to the plans will be lighter and stronger than control horns cut from flat sheet. Do not fear the welding. Greg Cardinal Minneapolis ----- Original Message ----- From: "Andy Garrett" <andy_garrett(at)live.com> Sent: Tuesday, March 03, 2015 5:18 PM Subject: Pietenpol-List: Re: Recent visits. > > > Great pics! I like that he did the wire wrap/solder thing to his > wires--very old school. Yet, at first glace his elevator control horn > looks like a flat piece of material, aluminum maybe? > > I've actually been wondering about that as I study for my build. What > options have people used for control horns. I'm looking at ways to reduce > the amount of welding to be done. > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438985#438985 > > > --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com ________________________________________________________________________________
Date: Mar 04, 2015
as I said on FB... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439033#439033 Attachments: http://forums.matronics.com//files/497000120_t2qkm_o_352.jpg ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: a few words about dihedral
Date: Mar 04, 2015
Just a few observations about adding dihedral to the 3-piece Pietenpol wing . Women Fly 2 points out that dihedral can reduce lift which is true but for the minuscule amount of dihedral that we put in our Pietenpols the effect is negligible. Wing cuts outs in the center section is another place where builders fuss o ver the "loss of lift" when if you just build a light plane it will climb great. Add 2 feet of wing if you're worried a bout lift loss. If you want to reduce lift build a Pietenpol that is wayyyyy overweight or adding electrical systems and lots of radios and front cockpit instruments but losing a little lift for the sake of dihedral is well worth the trade off---and here are my reasons: 1) dihedral increases stability. 2) easier to fold and read maps while going cross country if you have to take your hands off the stick momentarily 3) birds have dihedral. 4) Cubs and Champs have dihedral and fly pretty nicely. 5) Piets with flat wings sometimes appear to have drooping wings so ju st a touch of dihedral eliminates that appearance. 6) Dihedral irritates the purists which is a fond hobby of mine! Mike C. ________________________________________________________________________________
Subject: Re: a few words about dihedral
Date: Mar 04, 2015
very few words. :) > Just a few observations about adding dihedral to the 3-piece Pietenpol wing Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439036#439036 ________________________________________________________________________________
Date: Mar 04, 2015
Greg Cardinal wrote: > Ribs built to the drawing supplied with the plans will fly just fine. > > Keri-Ann Price used to sell plans for a gapless 3-piece wing. This was used > on NX18235 and is a good option. > > As others have stated, www.westcoastpiet.com and the archives have a wealth > of info. Enjoy the build. > > Greg Cardinal > Minneapolis > > --- ..... still do. WF2 ( Keri-Ann) -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439039#439039 ________________________________________________________________________________
Date: Mar 04, 2015
*Average dihedral for an Aeronca Champ is 1 degree. On a piper cub it is 1 inch at the tips, max. On a Cessna 150 it is 2 degrees. Some some parasols have 0 degrees.* *Blue Skies,* *Steve D* On Wed, Mar 4, 2015 at 10:08 AM, womenfly2 wrote: > > > Greg Cardinal wrote: > > Ribs built to the drawing supplied with the plans will fly just fine. > > > > Keri-Ann Price used to sell plans for a gapless 3-piece wing. This was > used > > on NX18235 and is a good option. > > > > As others have stated, www.westcoastpiet.com and the archives have a > wealth > > of info. Enjoy the build. > > > > Greg Cardinal > > Minneapolis > > > > --- > > > ..... still do. > > WF2 > ( Keri-Ann) > > -------- > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439039#439039 > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Mar 04, 2015
Thank you for your responses. Very helpful. I will make my horns as indicated in the plans. As for my response to the suggestion that I should use the search feature before posting questions--I hope I did not come across as 'snarky'. That was not my intent. I have been a member of several forums over the years and understand the etiquette. I know it can be frustrating for the old hands to be patient with the new guys who seem to always ask the same questions. I will be cognizant of this in the future. However, this would be a boring place if it were only treated as a repository of static information to be researched like a common reference library. A forum is first and foremost a community, where ideas are fluid and dynamic. Asking even an old question can inspire a new and creative response. So, I will be diligent in my search engine use before asking questions, but I may ask it anyway simply to mine the current view of whatever it is. I will try not to be tiresome. Cheers! -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439044#439044 ________________________________________________________________________________
Date: Mar 04, 2015
Also, I discovered westcoastpiet even before I found this site. Very good stuff over there. I've also been pouring over every Youtube video I can find to compare and contrast methods and configurations. Great stuff. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439045#439045 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: what color is this plane, control horns, etc
Date: Mar 04, 2015
I think this is Rob Bach's plane which is blue and gold. He flew it to Brodhead a few times, and it's really a nice plane. Cool instrument panels, lots of brass if I remember correctly. Interesting dude, told me when he gets bored flying he does mathematical algorithms in his head to pass the time. My control horns are just flat stock and works fine, but I'd do the plans version if I did it again. Easey peasey to build, strong and super light. My plane has NO dihedral and the wings don't really look droopy to me. Adding 1" is very common and is easily done. Andy, you are very welcome on this list and PLEASE ask questions, that's what it's all about. I personally found it helpful though to search the archives first because otherwise, I would have submitted 1,000 questions during my build. As it was, I only submitted about 500!! Douwe ________________________________________________________________________________
Subject: fun fly-in, piets invited
Date: Mar 04, 2015
I went to this last year and though the WX was crap, it was fun. Lots of grass to land on, the field is closed during the fly-in. people were really nice. Larry Williams was there, Andy with the old Rudolf Piet and another, plus me. with good WX it should be fun for those nearby.(Ohio crowd.) I've been asked to invite Piets, hence this email. Barnstorming Carnival July 11-12 Springfield-Beckley Ohio. Douwe ________________________________________________________________________________
Subject: Re: what color is this plane, control horns, etc
Date: Mar 04, 2015
Actually, Douwe, the plane in the photo was built by RT Searfoss. Very nice looking Pietenpol. And clearly, from this photo, it is white and black. BC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439056#439056 Attachments: http://forums.matronics.com//files/nx499rt_131.jpg ________________________________________________________________________________
Date: Mar 04, 2015
Mike, Nice rundown on the dihedral topic! You are right about the added stability. Good that you made it #1, because stability is paramount. I would also add "a bit of dihedral gives a piet a spunky and eager look". So, let's not forget the spunk factor :-) On Wed, Mar 4, 2015 at 8:47 AM, Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC] wrote: > Just a few observations about adding dihedral to the 3-piece Pietenpol > wing. > > > Women Fly 2 points out that dihedral can reduce lift which is true but fo r > the minuscule amount of dihedral that > > we put in our Pietenpols the effect is negligible. > > > Wing cuts outs in the center section is another place where builders fuss > over the =9Closs of lift=9D when if you just build > > a light plane it will climb great. Add 2 feet of wing if you=99re worried > about lift loss. > > > If you want to reduce lift build a Pietenpol that is wayyyyy overweight o r > adding electrical systems and lots of radios and > > front cockpit instruments but losing a little lift for the sake of > dihedral is well worth the trade off---and here are my reasons: > > > 1) dihedral increases stability. > > 2) easier to fold and read maps while going cross country if you > have to take your hands off the stick momentarily > > 3) birds have dihedral. > > 4) Cubs and Champs have dihedral and fly pretty nicely. > > 5) Piets with flat wings sometimes appear to have drooping wings so > just a touch of dihedral eliminates that appearance. > > 6) Dihedral irritates the purists which is a fond hobby of mine! > > > Mike C. > > > * > =========== .matronics.com/Navigator?Pietenpol-List> =========== =========== om/contribution> =========== > > * > > -- Greg Bacon ________________________________________________________________________________
Date: Mar 04, 2015
Dihedral is for Piper Cherokees. Get a wing - leveler and or auto-pilot, too.... Was that mean? Just kidding. I like my Piet GN-1 'cause it's fun. On Mar 4, 2015 9:53 AM, "Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC]" wrote: > Just a few observations about adding dihedral to the 3-piece Pietenpol > wing. > > > Women Fly 2 points out that dihedral can reduce lift which is true but fo r > the minuscule amount of dihedral that > > we put in our Pietenpols the effect is negligible. > > > Wing cuts outs in the center section is another place where builders fuss > over the =9Closs of lift=9D when if you just build > > a light plane it will climb great. Add 2 feet of wing if you=99re worried > about lift loss. > > > If you want to reduce lift build a Pietenpol that is wayyyyy overweight o r > adding electrical systems and lots of radios and > > front cockpit instruments but losing a little lift for the sake of > dihedral is well worth the trade off---and here are my reasons: > > > 1) dihedral increases stability. > > 2) easier to fold and read maps while going cross country if you > have to take your hands off the stick momentarily > > 3) birds have dihedral. > > 4) Cubs and Champs have dihedral and fly pretty nicely. > > 5) Piets with flat wings sometimes appear to have drooping wings so > just a touch of dihedral eliminates that appearance. > > 6) Dihedral irritates the purists which is a fond hobby of mine! > > > Mike C. > > > * > =========== .matronics.com/Navigator?Pietenpol-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Mar 05, 2015
Mike' I like Point 6 the best. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439069#439069 ________________________________________________________________________________
Date: Mar 05, 2015
Wow! Gary's Piet is stunning! Love the wood struts! Well done sir! (Watched your Youtube videos.) -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439071#439071 ________________________________________________________________________________
Subject: Good Advice from the April 2015 issue of Kitplanes
Date: Mar 05, 2015
In the April 2015 issue of Kitplanes in the "Ask the DAR" section, the writer suggests that all pilots of aircraft utilizing the NX markings without the word "experimental" on the aircraft carry a copy of CFR_45.22b to show any FAA inspector who questions them on it. In case anyone needs/wants a copy, I have attached a copy below. I reduced the font to get it all on one page. I plan on doing just that and using the NX markings on my Pietenpol. It sounds like a good practice to me, since it comes from a DAR. Just thought I would save forum members the time of looking for it. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439072#439072 Attachments: http://forums.matronics.com//files/cfr_4522b_144.pdf ________________________________________________________________________________
Date: Mar 05, 2015
Thanks, Terry. I have NX markings without "experimental", and the FAA inspector was ambivalent about that. Sooner or later I'll run into one who isn't... Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jarheadpilot82 Sent: Thursday, March 05, 2015 8:42 AM Subject: Pietenpol-List: Good Advice from the April 2015 issue of Kitplanes --> In the April 2015 issue of Kitplanes in the "Ask the DAR" section, the writer suggests that all pilots of aircraft utilizing the NX markings without the word "experimental" on the aircraft carry a copy of CFR_45.22b to show any FAA inspector who questions them on it. In case anyone needs/wants a copy, I have attached a copy below. I reduced the font to get it all on one page. I plan on doing just that and using the NX markings on my Pietenpol. It sounds like a good practice to me, since it comes from a DAR. Just thought I would save forum members the time of looking for it. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439072#439072 Attachments: http://forums.matronics.com//files/cfr_4522b_144.pdf ________________________________________________________________________________
Subject: Re: Good Advice from the April 2015 issue of Kitplanes
Date: Mar 05, 2015
Terry and Gary and others, I just got my Airworthiness inspection a couple of weeks ago. I went through the same discussion with the DAR and the FAA. I have X in the number and dont have experimental on the airplane. Having a copy of the FAR in the airplane is just a good idea. I have one mine. The only problem is adjusting the weight and balance for the paperwork ;0) Jack > On Mar 5, 2015, at 11:49 AM, Gary Boothe wrote: > > > Thanks, Terry. I have NX markings without "experimental", and the FAA > inspector was ambivalent about that. Sooner or later I'll run into one who > isn't... > > Gary Boothe > NX308MB > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > jarheadpilot82 > Sent: Thursday, March 05, 2015 8:42 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Good Advice from the April 2015 issue of Kitplanes > > --> > > In the April 2015 issue of Kitplanes in the "Ask the DAR" section, the > writer suggests that all pilots of aircraft utilizing the NX markings > without the word "experimental" on the aircraft carry a copy of CFR_45.22b > to show any FAA inspector who questions them on it. > > In case anyone needs/wants a copy, I have attached a copy below. I reduced > the font to get it all on one page. I plan on doing just that and using the > NX markings on my Pietenpol. It sounds like a good practice to me, since it > comes from a DAR. > > Just thought I would save forum members the time of looking for it. > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439072#439072 > > > > > Attachments: > > http://forums.matronics.com//files/cfr_4522b_144.pdf > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 05, 2015
Good reminder Terry and good attachment to the post. Back in 1998 when my FAA/MIDO inspector came out to do my airworthiness ins pection I printed out a copy of the FAR that allows for the NX and he was surprised to learn about that hidden gem. One item with using NX is that the X appears nowhere in the FAA records so when registering or looking up, selling or buying the X doesn't have any role----it is only an aircraft marking that takes the place of the big, now unnecessary EXPERIMENTAL. Good post. Mike C. [cid:image001.jpg(at)01D05743.5B90DC70] [cid:image002.jpg(at)01D05743.5B90DC70] ________________________________________________________________________________
Date: Mar 05, 2015
Thanks, Andy. You are very kind! Yes, I get a lot of compliments at the airport, but I find that all very humbling as I consider myself fortunate beyond measure for having the opportunity to build this plane. There are so many who, for various reasons, do not have the time, money, situation, etc., will never have that opportunity, or may take an incredibly long time to completion. I'm currently re-building a damaged Baby Ace, which grew up in the same era as the Piet, but just doesn't seem to have the same mystique. I'm sure I asked my share of questions to this list, but found that searching through the archives yielded hours' worth of good reading that would often take me in directions that were unrelated but equally useful. Same for westcoatpiet. Looking through all those pictures helped me to quickly solidify an opinion about what I liked and what I didn't; rounded corners on the tail parts, or not; tall wheels?; taller cabanes, or turtledeck? Deck angle? Cowling appearance? The list goes on... Color choice is something that will come sooner or later, but I think the building process needs to be started with your vision of aesthetics, if that is important to you. I look forward to hearing of your progress, Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Andy Garrett Sent: Thursday, March 05, 2015 8:32 AM Subject: Pietenpol-List: Re: A couple of questions about wing construction --> Wow! Gary's Piet is stunning! Love the wood struts! Well done sir! (Watched your Youtube videos.) -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439071#439071 ________________________________________________________________________________
Date: Mar 05, 2015
That's exactly what I did. I didn't have a DAR, but an inspector from the FSDO, whom I thought should know the regs. Just in case I carried a copy of the FARs with that one highlighted. Good thing I did. When he challenged me, I just showed him the book and he grunted and said "learn something new every day". Jack Phillips NX899JP Smith Mountain Lake, Virginia (Where yesterday it was 61 degrees and today is snowing. Low tonight is forecast to be 17. Gotta love a Southern Winter) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jarheadpilot82 Sent: Thursday, March 5, 2015 11:42 AM Subject: Pietenpol-List: Good Advice from the April 2015 issue of Kitplanes --> < jarheadpilot82(at)hotmail.com> In the April 2015 issue of Kitplanes in the "Ask the DAR" section, the writer suggests that all pilots of aircraft utilizing the NX markings without the word "experimental" on the aircraft carry a copy of CFR_45.22b to show any FAA inspector who questions them on it. In case anyone needs/wants a copy, I have attached a copy below. I reduced the font to get it all on one page. I plan on doing just that and using the NX markings on my Pietenpol. It sounds like a good practice to me, since it comes from a DAR. Just thought I would save forum members the time of looking for it. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: <http://forums.matronics.com/viewtopic.php?p=439072#439072> http://forums.matronics.com/viewtopic.php?p=439072#439072 Attachments: <http://forums.matronics.com/files/cfr_4522b_144.pdf> http://forums.matronics.com//files/cfr_4522b_144.pdf http://www.matronics.com/Navigator?Pietenpol-List http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 05, 2015
File under FWIW... The Vertical component of lift for a 1 dihedral angle, expressed as a percentage is 99.98%. Just my .02%! -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439085#439085 ________________________________________________________________________________
Date: Mar 05, 2015
I don't know how adding dihedral could irritate the purists. It says to add some to the three piece wing right in the 'official' manual. *SNAP* The three piece wing must not be pure either. [Shocked] -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439088#439088 ________________________________________________________________________________
Date: Mar 05, 2015
Terry, thanks for the post. I copied the FAR and plan to keep it in the same place with the other paper work. I just today sent off the paperwork to get my Piet registered. It will be NX10003. I have had the 10003 reserved for a few years. It was the lowest all-number registration available when I reserved it. Am getting excited about the possibility of finishing my plane, getting it inspected, and flying it for the first time before the snow flies next winter. Notice that I said, "Possibility!" Chuck On Thu, Mar 5, 2015 at 2:07 PM, Jack Philips wrote: > That's exactly what I did. I didn't have a DAR, but an inspector from the > FSDO, whom I thought should know the regs. Just in case I carried a copy > of the FARs with that one highlighted. Good thing I did. When he > challenged me, I just showed him the book and he grunted and said "learn > something new every day". > > > Jack Phillips > > N*X*899JP > > Smith Mountain Lake, Virginia > > (Where yesterday it was 61 degrees and today is snowing. Low tonight is > forecast to be 17. Gotta love a Southern Winter) > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] On Behalf Of jarheadpilot82 > Sent: Thursday, March 5, 2015 11:42 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Good Advice from the April 2015 issue of Kitplanes > > > --> > > > In the April 2015 issue of Kitplanes in the "Ask the DAR" section, the > writer suggests that all pilots of aircraft utilizing the NX markings > without the word "experimental" on the aircraft carry a copy of CFR_45.22b > to show any FAA inspector who questions them on it. > > > In case anyone needs/wants a copy, I have attached a copy below. I reduced > the font to get it all on one page. I plan on doing just that and using the > NX markings on my Pietenpol. It sounds like a good practice to me, since it > comes from a DAR. > > > Just thought I would save forum members the time of looking for it. > > > -------- > > Semper Fi, > > > Terry Hand > > Athens, GA > > > Read this topic online here: > > > http://forums.matronics.com/viewtopic.php?p=439072#439072 > > > Attachments: > > > http://forums.matronics.com//files/cfr_4522b_144.pdf > <http://forums.matronics.com/files/cfr_4522b_144.pdf> > > > http://www.matronics.com/Navigator?Pietenpol-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > > * > > > * > > ________________________________________________________________________________
Date: Mar 06, 2015
those people are the bottom feeders in aviation. they are lazy and brain de ad.=C2- why else would anyone take a gov. job when they can do so much be tter out in the real world and not have to tell friends and family that the y work for the gov. me On Thursday, March 5, 2015 5:53 PM, Charles N. Campbell wrote: Terry, thanks for the post.=C2- I copied the FAR and plan to keep it in the same place with the other paper work.=C2- I just today sent off the p aperwork to get my Piet registered.=C2- It will be NX10003.=C2- I have had the 10003 reserved for a few years.=C2- It was the lowest all-number registration available when I reserved it.=C2- Am getting excited about t he possibility of finishing my plane, getting it inspected, and flying it f or the first time before the snow flies next winter.=C2- Notice that I sa id, "Possibility!" =C2-Chuck On Thu, Mar 5, 2015 at 2:07 PM, Jack Philips wro te: That's exactly what I did.=C2- I didn't have a DAR, but an inspector from the FSDO, whom I thought should know the regs.=C2- Just in case I carrie d a copy of the FARs with that one highlighted.=C2- Good thing I did.=C2 - When he challenged me, I just showed him the book and he grunted and sa id "learn something new every day".=C2-Jack PhillipsNX899JPSmith Mountain Lake, Virginia(Where yesterday it was 61 degrees and today is snowing.=C2 - Low tonight is forecast to be 17.=C2- Gotta love a Southern Winter) =C2-=C2------Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of jarheadpilot82 Sent: Thursday, March 5, 2015 11:42 AM Subject: Pietenpol-List: Good Advice from the April 2015 issue of Kitplanes lot82(at)hotmail.com>=C2-In the April 2015 issue of Kitplanes in the "Ask th e DAR" section, the writer suggests that all pilots of aircraft utilizing t he NX markings without the word "experimental" on the aircraft carry a copy of CFR_45.22b to show any FAA inspector who questions them on it.=C2-In case anyone needs/wants a copy, I have attached a copy below. I reduced the font to get it all on one page. I plan on doing just that and using the NX markings on my Pietenpol. It sounds like a good practice to me, since it c omes from a DAR.=C2-Just thought I would save forum members the time of l ooking for it.=C2---------Semper Fi,=C2-Terry HandAthens, GA=C2-=C2 -=C2-=C2-Read this topic online here:=C2-http://forums.matronics.co m/viewtopic.php?p=439072#439072=C2-=C2-=C2-=C2-Attachments: =C2 -http://forums.matronics.com//files/cfr_4522b_144.pdf=C2-=C2-=C2- =C2-http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matron ics.comhttp://www.matronics.com/contribution=C2-=C2-=C2-=C2- " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 06, 2015
Subject: Rib Jig
Does anyone have a rib jig with which they are willing to part?-=0A=0A=0A Thanks,=0A=0AMike Salerno-=0A=0A=0A=0A=0ASent from Yahoo Mail on Android =0A=0A ________________________________________________________________________________
Subject: Re: Rib Jig
Date: Mar 06, 2015
1. Which airfoil? 2. Borrow, or keep? 3. Where do you live? FWIW, They are not that hard to make. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439116#439116 ________________________________________________________________________________
Date: Mar 06, 2015
Andy; I've lost track of this thread but in case nobody has mentioned this to you yet, by all means get Mike Cuy's build-and-fly DVD. You will learn a lot about Pietenpols and building them by watching the video, but more than that you will get to walk around the airplane and get a running narrative of what's what and why it's that way, and you'll also get some really fun flying sequences. It's something that you can pull out on a rainy day and just sit and watch with a mug of coffee and learn something new each time you watch it. You can search the archives on 'Mike Cuy video' or just wait for him to post the ordering info here... I'm sure he will. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439117#439117 ________________________________________________________________________________
Date: Mar 06, 2015
Didn't really have a preference on airfoil. I may be misinformed, but it se emed they were about the same in performance.=0A=0A=0APrefer to keep, more than willing to purchase.=0A=0A=0AI live in Durant, Oklahoma. I was just lo oking for a quicker way to get going...=0A=0A=0AMike=0A=0ASent from Yahoo M ail on Android=0A=0AFrom:"jarheadpilot82" =0ADa te:Fri, Mar 6, 2015 at 7:49 PM=0ASubject:Pietenpol-List: Re: Rib Jig=0A=0A- il.com>=0A=0A1. Which airfoil?=0A2. Borrow, or keep?=0A3. Where do you live ?=0A=0AFWIW, They are not that hard to make.=0A=0A--------=0ASemper Fi,=0A =0ATerry Hand=0AAthens, GA=0A=0A=0A=0A=0ARead this topic online here:=0A=0A http://forums.matronics.com/viewtopic.php?p=439116#439116=0A=0A=0A=0A=0A ===================0A=0A=0A=0A ________________________________________________________________________________
Date: Mar 07, 2015
Mike you can do one in a couple hours. Scroll down here http://textors.com/ PietProject.html to see mine. Instead of plywood I would use composite for l ess warp. I bolted mine to my bench. Also drilled about a 1/2 to 3/4 hole u nder each joint to keep the glued joint from sticking to the jig. I used 1/ 2" square wood from the lumber yard for guides. In my opinion less is bette r. Using too many makes it harder to remove from the jig. I made pretty ti ght joints, glued with epoxy, removed and then glued the gussets. Good luck , enjoy. Sent from my iPad Jack Textor > On Mar 6, 2015, at 9:13 PM, Mike Salerno wrote: > > > Didn't really have a preference on airfoil. I may be misinformed, but it s eemed they were about the same in performance. > > Prefer to keep, more than willing to purchase. > > I live in Durant, Oklahoma. I was just looking for a quicker way to get go ing... > > Mike > > Sent from Yahoo Mail on Android > > From:"jarheadpilot82" > Date:Fri, Mar 6, 2015 at 7:49 PM > Subject:Pietenpol-List: Re: Rib Jig > mail.com> > > 1. Which airfoil? > 2. Borrow, or keep? > 3. Where do you live? > > FWIW, They are not that hard to make. > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439116#439====== ==================http://www.matronics.c om/Navigat - MATRONICS WEB FORUMS -<= --> > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Mar 07, 2015
Building a rib jig will take you all of 2 hours. Better to keep it in case you ever need to make a repair and you want the new rib to be exactly like the old broken ones. For that reason I doubt you'll find anyone wanting to give you one. I loaned mine to Gardner Mason after his Piet was crushed at Sun'n'Fun under the condition that he return when he finished (which he did). Jack Phillips NX899JP Smith Mountain Lake, Virginia From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mike Salerno Sent: Friday, March 6, 2015 10:13 PM Subject: Re: Pietenpol-List: Re: Rib Jig Didn't really have a preference on airfoil. I may be misinformed, but it seemed they were about the same in performance. Prefer to keep, more than willing to purchase. I live in Durant, Oklahoma. I was just looking for a quicker way to get going... Mike Sent from Yahoo Mail on Android _____ From:"jarheadpilot82" > Date:Fri, Mar 6, 2015 at 7:49 PM Subject:Pietenpol-List: Re: Rib Jig > 1. Which airfoil? 2. Borrow, or keep? 3. Where do you live? FWIW, They are not that hard to make. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439116#439===================== ==http://www.matronics.com/Navigat <http://forums.matronics.com/viewtopic.php?p=439116#439116> - MATRONICS WEB FORUMS -<= --> <http://www.matronics.com/contribution> ________________________________________________________________________________
Date: Mar 07, 2015
I built a 2 sided jig out of 2 pieces of MDF and dadoed 2X6s. The offset dowel circles were rotated to hold the rib pieces in place and the clamp studs went through the jig. After the rib was aligned and glue set, I use the other side of the jig to glue the gussets on the other side of the rib. That way I had 2 ribs setting up at the same time. Used small squares of waxed paper to control glue drips. Tim White Ocklawaha, Fl On 3/7/2015 7:36 AM, Jack wrote: > Mike you can do one in a couple hours. Scroll down here > http://textors.com/PietProject.html to see mine. Instead of plywood I > would use composite for less warp. I bolted mine to my bench. Also > drilled about a 1/2 to 3/4 hole under each joint to keep the glued > joint from sticking to the jig. I used 1/2" square wood from the > lumber yard for guides. In my opinion less is better. Using too many > makes it harder to remove from the jig. I made pretty tight joints, > glued with epoxy, removed and then glued the gussets. Good luck, enjoy. > > Sent from my iPad > Jack Textor > > On Mar 6, 2015, at 9:13 PM, Mike Salerno > wrote: > >> Didn't really have a preference on airfoil. I may be misinformed, but >> it seemed they were about the same in performance. >> >> Prefer to keep, more than willing to purchase. >> >> I live in Durant, Oklahoma. I was just looking for a quicker way to >> get going... >> >> Mike >> >> Sent from Yahoo Mail on Android >> >> >> ------------------------------------------------------------------------ >> *From*:"jarheadpilot82" > > >> *Date*:Fri, Mar 6, 2015 at 7:49 PM >> *Subject*:Pietenpol-List: Re: Rib Jig >> >> > >> >> 1. Which airfoil? >> 2. Borrow, or keep? >> 3. Where do you live? >> >> FWIW, They are not that hard to make. >> >> -------- >> Semper Fi, >> >> Terry Hand >> Athens, GA >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=439116#439========================http://www.matronics.com/Navigat >> - MATRONICS WEB FORUMS -<= --> >> <http://forums.matronics.com/viewtopic.php?p=439116#439116> >> >> >> <http://www.matronics.com/contribution> >> >> * >> >> D============================================ >> npol-List"">http://www.matronics.com/Navigator?Pietenpol-List >> D============================================ >> //forums.matronics.com >> D============================================ >> ot;">http://www.matronics.com/contribution >> D============================================ >> >> * > * > > > * ________________________________________________________________________________
Date: Mar 07, 2015
Tim: I am speechless. That jig is unlike anything I have ever seen. Amazing. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439139#439139 ________________________________________________________________________________
Subject: spinner
Date: Mar 07, 2015
I got the second short flight in of the year for me today. Little corvair ran smooth as usual. I ordered a skull cap spinner from Wicks last fall about the end of October. They told me it was on back order. since they have them priced pretty cheap I was content to wait a while. but now it's into March and still no spinner. I know it won't change my speed and probably worthless except I think they look cool, and it just could smooth the airflow a little into the scoops. but it sure doesn't need to run any cooler. anyway anybody had poor luck with Wicks or did I just order the one item they can't get? Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439140#439140 ________________________________________________________________________________
Subject: Corvair College #33 Registration Now Open
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Mar 08, 2015
For this of you who are building or considering building a Corvair engine for their Pietenpol, I wanted to point out that the registration for the next Corvair College has just opened. Follow the link below- http://flycorvair.net/2015/03/08/corvair-college-33-sign-up-now-open/ It will be in Leesburg FL 17-19April. For a chance to see what a Corvair College is like, please click the link below. It is a short 7 minute video really well done by Brady Lane and EAA- http://youtu.be/wvXAX0C2q5c Even if you aren't building a Corvair it is a great place to meet other, like minded builders. I have been to 3 and plan to go as often as I can. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439154#439154 ________________________________________________________________________________
Date: Mar 08, 2015
Subject: Sensenich torques
Here is a shot of the decal on my prop Ben Sent from my iPhone
Date: Mar 09, 2015
Subject: Fwd: Better, the enemy of great!
Yesterday, I had my wing gas tank cover out in the yard to paint. Rattle can red. First coat was perfect! Then I thought I would add one more light coat. Oh No a run. well I will try to wipe it of with a smooth rag with acetone. Now it is even worse. So I end up sanding it and finally repainting it, It is not near as nice as the first coat. But it is OK. I will not mess with it until some time long after the plane is flying. Sound's like the story of my life. -- Blue Skies, Steve D -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Fuel tank - feels like I'm building an RV-7 !
Date: Mar 09, 2015
Hello good Piet-ple, A quick update on my project. Been working on the fuel tank lately - only one tank that will sit in the wing center-section. After a couple false starts it's finally starting to come together. I'm making the tank out of 0.063 5052 sheet so it feels like I'm building the wing to an RV-7....! (So much for a steel-tube, wood and fabric airplane...!!) The current plan is for the internal grid to be rivited to itself and the external seems to be fully welded - similar in construction to the Stearman. Hope you all are enjoying spring...! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439203#439203 Attachments: http://forums.matronics.com//files/4_practice_rib_492.jpg http://forums.matronics.com//files/3_bent_flange_184.jpg http://forums.matronics.com//files/2_bending_flange_589.jpg http://forums.matronics.com//files/1_fuel_tank_in_work_808.jpg ________________________________________________________________________________
Date: Mar 09, 2015
Subject: Re: Fuel tank - feels like I'm building an RV-7 !
Looks great Jake! Are you incorporating a low spot to keep water from accumulating? How wide is your center section? On Mon, Mar 9, 2015 at 1:22 PM, aerocarjake wrote: > > > > Hello good Piet-ple, > > A quick update on my project. > > Been working on the fuel tank lately - only one tank that will sit in the > wing center-section. After a couple false starts it's finally starting to > come together. I'm making the tank out of 0.063 5052 sheet so it feels like > I'm building the wing to an RV-7....! (So much for a steel-tube, wood and > fabric airplane...!!) > > The current plan is for the internal grid to be rivited to itself and the > external seems to be fully welded - similar in construction to the Stearman. > > Hope you all are enjoying spring...! > > -------- > Jake Schultz - curator, > Newport Way Air Museum (OK, it's just my home) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439203#439203 > > > Attachments: > > http://forums.matronics.com//files/4_practice_rib_492.jpg > http://forums.matronics.com//files/3_bent_flange_184.jpg > http://forums.matronics.com//files/2_bending_flange_589.jpg > http://forums.matronics.com//files/1_fuel_tank_in_work_808.jpg > > -- Greg Bacon ________________________________________________________________________________
Date: Mar 09, 2015
Thx... Yes I am installing two Stearman sumps in the aft corners of the tank. My center-section is 48" wide. That is wider than plans so I can accommodate just one tank an have enough capacity for my thirsty engine. This tank SHOULD be about 18 gallons (by calculation) so with my ROTEC engine burning about 6gph I should have 2 1/2 hours + the 30 minute reserve. -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439206#439206 ________________________________________________________________________________
Date: Mar 10, 2015
From: "THOMAS.233327" <thomas.233327(at)comcast.net>
Jake! It looks like you are installing the ends of your tank backwords! The weld is best done from the edge of one sheet to the outside radius of the other. Call me and I'll run up there and see your project. I learned about that welding tip when I was building the Hummel Bird tanks (3 of them). It easier by far the have the ends of the top, bottom, front and back weld the edge of one sheet to the outside bend on the ends than it is to weld along the edges of two sheets that are lapped. Also, if you swap the ends of your tank so there is no flange on the finished tank, you'll have room for more gas. When is the next 441 meeting? Tom Hale- (253) two-three-six--eight three two two Still not building my Sonex kit-but that will change soon! (New wife wants to build and airplane) ----- Original Message ----- From: "aerocarjake" <flight.jake(at)gmail.com> Sent: Monday, March 9, 2015 2:15:06 PM Subject: Pietenpol-List: Re: Fuel tank - feels like I'm building an RV-7 ! Thx... Yes I am installing two Stearman sumps in the aft corners of the tank. My center-section is 48" wide. That is wider than plans so I can accommodate just one tank an have enough capacity for my thirsty engine. This tank SHOULD be about 18 gallons (by calculation) so with my ROTEC engine burning about 6gph I should have 2 1/2 hours + the 30 minute reserve. -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439206#439206 ________________________________________________________________________________
Date: Mar 09, 2015
Jake When you say Stearman sumps do you mean the Stearman type fuel gage or is there an actual bump in the bottom of the tank? Chris Sacramento, CA WestcoastPiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of aerocarjake Sent: Monday, March 9, 2015 2:15 PM Subject: Pietenpol-List: Re: Fuel tank - feels like I'm building an RV-7 ! --> Thx... Yes I am installing two Stearman sumps in the aft corners of the tank. My center-section is 48" wide. That is wider than plans so I can accommodate just one tank an have enough capacity for my thirsty engine. This tank SHOULD be about 18 gallons (by calculation) so with my ROTEC engine burning about 6gph I should have 2 1/2 hours + the 30 minute reserve. -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439206#439206 ________________________________________________________________________________
Date: Mar 09, 2015
Jake, Sure looks great! This will be one of the most perfect Piets around. Congratulations. Ray Krause Building SkyScout Sent from my iPad > On Mar 9, 2015, at 12:22 PM, aerocarjake wrote: > > > Hello good Piet-ple, > > A quick update on my project. > > Been working on the fuel tank lately - only one tank that will sit in the wing center-section. After a couple false starts it's finally starting to come together. I'm making the tank out of 0.063 5052 sheet so it feels like I'm building the wing to an RV-7....! (So much for a steel-tube, wood and fabric airplane...!!) > > The current plan is for the internal grid to be rivited to itself and the external seems to be fully welded - similar in construction to the Stearman. > > Hope you all are enjoying spring...! > > -------- > Jake Schultz - curator, > Newport Way Air Museum (OK, it's just my home) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439203#439203 > > > > > Attachments: > > http://forums.matronics.com//files/4_practice_rib_492.jpg > http://forums.matronics.com//files/3_bent_flange_184.jpg > http://forums.matronics.com//files/2_bending_flange_589.jpg > http://forums.matronics.com//files/1_fuel_tank_in_work_808.jpg > > > > > > > ________________________________________________________________________________
Subject: Re: Fwd: Better, the enemy of great!
Date: Mar 09, 2015
Steven don't feel bad I can't stop that temptation to add just a little more either. In my 38 years of repairing telephone cables I think over half of them were cut because the machine operator wanted to make just one more swipe with the back hoe. -------- Building steel fuselage aircamper. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439218#439218 ________________________________________________________________________________
Date: Mar 10, 2015
Looks good, Jake. Looks very much like mine. Be sure to leak test it after welding. I used a latex glove as a pressure regulator, and inflated the tank by mouth (you don't want more than about 2-3 psi). After the initial weld I found 37 pinhole leaks. Back to the welder, then tested again and found 9 leaks. Back to the welder again and no leaks. It's been in service now for over 10 years and still has no leaks. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of aerocarjake Sent: Monday, March 9, 2015 3:22 PM Subject: Pietenpol-List: Fuel tank - feels like I'm building an RV-7 ! --> < flight.jake(at)gmail.com> Hello good Piet-ple, A quick update on my project. Been working on the fuel tank lately - only one tank that will sit in the wing center-section. After a couple false starts it's finally starting to come together. I'm making the tank out of 0.063 5052 sheet so it feels like I'm building the wing to an RV-7....! (So much for a steel-tube, wood and fabric airplane...!!) The current plan is for the internal grid to be rivited to itself and the external seems to be fully welded - similar in construction to the Stearman. Hope you all are enjoying spring...! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: <http://forums.matronics.com/viewtopic.php?p=439203#439203> http://forums.matronics.com/viewtopic.php?p=439203#439203 Attachments: <http://forums.matronics.com/files/4_practice_rib_492.jpg> http://forums.matronics.com//files/4_practice_rib_492.jpg <http://forums.matronics.com/files/3_bent_flange_184.jpg> http://forums.matronics.com//files/3_bent_flange_184.jpg <http://forums.matronics.com/files/2_bending_flange_589.jpg> http://forums.matronics.com//files/2_bending_flange_589.jpg <http://forums.matronics.com/files/1_fuel_tank_in_work_808.jpg> http://forums.matronics.com//files/1_fuel_tank_in_work_808.jpg http://www.matronics.com/Navigator?Pietenpol-List http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 10, 2015
Going to use actual Stearman sumps. I have not decided yet if I will cut off part of the flanges and have them welded on or use bolts and proseal. (Stearman tanks do it both ways.) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439229#439229 Attachments: http://forums.matronics.com//files/2_sump_211.jpg http://forums.matronics.com//files/1_sump_386.jpg ________________________________________________________________________________
Subject: aluminum welding troubles
Date: Mar 10, 2015
Frustrated in Arkansas. I took my 050. aluminum sheet metal gas tank to the local sheet metal fabricators , and they tell me it will be a couple of days before they can weld it . I wait two weeks and call and they tell me they are afraid to try it because they feel the tig machine they have won't weld that thin .... Why didn't they tell me that two weeks ago. DANG!!!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439240#439240 ________________________________________________________________________________
Subject: Basic Torch Safety
Date: Mar 10, 2015
Recently, I observed, and intervened in a situation that could have become dangerous - even deadly. A number of us were working on equipment when one of the guys was about to begin brazing a cast iron piece, and upon lighting his torch, we heard a series of Pops. The sound was staccato - almost like low intensity machine gun fire, prompting me to immediately shut off both the Ox and acetylene. The Popping ceased moments later... What was occurring was due to several factors, including: a runaway acetylene regulator, faulty check valves, and, last but not least, bad O-Rings inside the torch handle. The issue with the regulator was solved by Welding Supply to the tune of $140 for a new regulator. Since they were out of the check valves, we removed them from the torch handle, and continued on. While troubleshooting, we noted that the torch tip wasn't flowing gas -- so with tank valves turned off - I wrapped my hand around it and attempted to remove it from the handle. As many of you know - or should know - Victor 100 torches, including all their clones like the Uniweld, and Harbor Freight torches - use two O-Rings to seal the gases from one another and, since they are compliant seals, the tip is to be HAND TIGHTENED ONLY. The torch in question not only had a wrench tightened tip, the O-Rings were cut, allowing the gases to mix INSIDE THE HANDLE... Exactly why the O-Rings were added to the design in the first place; to eliminate mixing within the handle! In the pic you'll see the handle end of the torch tip - where it enters the torch handle, along with the two O-Rings. The O-Rings themselves are metric, and they are available from Amazon at this link: http://www.amazon.com/Uniweld-TXRK-Tip-O-Ring-Repair/dp/B00FI1JM9G I've also located the same O-Rings in Viton, which should cost a whopping 3 cents more each, assuming we can buy then in the right volume. I'm attempting to get a quotation on 300 pieces of each to keep on hand in my shop and supply to anyone needing some for their torch collection. Now - please make sure your torch is ready to go, and if you have any issues that don't seem right, STOP. Figure out what the issue is, or take your rig to a competent welding supply shop. They will assist at no cost for trouble shooting. If, on the other hand, like the torch above, and the 8 torch tips in my own collection, which had cracked O-Rings.... Upgrade now and ensure that anyone using your torch is using a tool that's not going to hurt them. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439242#439242 Attachments: http://forums.matronics.com//files/torch_o_rings_491.jpg ________________________________________________________________________________
Date: Mar 10, 2015
Thanks, Tom. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tkreiner Sent: Tuesday, March 10, 2015 5:49 PM Subject: Pietenpol-List: Basic Torch Safety Recently, I observed, and intervened in a situation that could have become dangerous - even deadly. A number of us were working on equipment when one of the guys was about to begin brazing a cast iron piece, and upon lighting his torch, we heard a series of Pops. The sound was staccato - almost like low intensity machine gun fire, prompting me to immediately shut off both the Ox and acetylene. The Popping ceased moments later... What was occurring was due to several factors, including: a runaway acetylene regulator, faulty check valves, and, last but not least, bad O-Rings inside the torch handle. The issue with the regulator was solved by Welding Supply to the tune of $140 for a new regulator. Since they were out of the check valves, we removed them from the torch handle, and continued on. While troubleshooting, we noted that the torch tip wasn't flowing gas -- so with tank valves turned off - I wrapped my hand around it and attempted to remove it from the handle. As many of you know - or should know - Victor 100 torches, including all their clones like the Uniweld, and Harbor Freight torches - use two O-Rings to seal the gases from one another and, since they are compliant seals, the tip is to be HAND TIGHTENED ONLY. The torch in question not only had a wrench tightened tip, the O-Rings were cut, allowing the gases to mix INSIDE THE HANDLE... Exactly why the O-Rings were added to the design in the first place; to eliminate mixing within the handle! In the pic you'll see the handle end of the torch tip - where it enters the torch handle, along with the two O-Rings. The O-Rings themselves are metric, and they are available from Amazon at this link: http://www.amazon.com/Uniweld-TXRK-Tip-O-Ring-Repair/dp/B00FI1JM9G I've also located the same O-Rings in Viton, which should cost a whopping 3 cents more each, assuming we can buy then in the right volume. I'm attempting to get a quotation on 300 pieces of each to keep on hand in my shop and supply to anyone needing some for their torch collection. Now - please make sure your torch is ready to go, and if you have any issues that don't seem right, STOP. Figure out what the issue is, or take your rig to a competent welding supply shop. They will assist at no cost for trouble shooting. If, on the other hand, like the torch above, and the 8 torch tips in my own collection, which had cracked O-Rings.... Upgrade now and ensure that anyone using your torch is using a tool that's not going to hurt them. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439242#439242 Attachments: http://forums.matronics.com//files/torch_o_rings_491.jpg ________________________________________________________________________________
Date: Mar 10, 2015
Subject: Re: aluminum welding troubles
I hate to hear that they can't weld 0.050" AL because I've got 0.040" AL bought from Spruce A/C which I'm told is for gas tanks. I don't know much about welding AL but here's a youtube video where a guy welds soda cans with a TIG welder: https://www.youtube.com/watch?v=lJksVs2QT5Q Regards, John Franklin GN-1 / Corvair 164cid Prairie Aire 4TA0 Needville, TX -----Original Message----- >From: aviken <aviken(at)windstream.net> >Sent: Mar 10, 2015 6:48 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: aluminum welding troubles > > >Frustrated in Arkansas. I took my 050. aluminum sheet metal gas tank to the local sheet metal fabricators , and they tell me it will be a couple of days before they can weld it . I wait two weeks and call and they tell me they are afraid to try it because they feel the tig machine they have won't weld that thin .... Why didn't they tell me that two weeks ago. DANG!!!! ________________________________________________________________________________
Date: Mar 11, 2015
Subject: Headset Modification
I just posted a new video tip for adding cheap earbuds to your headset to cut down on the engine/prop noise. It's effective and economical. http://www.youtube.com/watch?v=ETiRiRqb5_I Enjoy Malcolm Morrison www.wienerdogaero.com ________________________________________________________________________________
Date: Mar 10, 2015
Jake That is interesting, I didn't know they made sumps like that. Chris -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of aerocarjake Sent: Tuesday, March 10, 2015 8:32 AM Subject: Pietenpol-List: Re: Fuel tank - feels like I'm building an RV-7 ! --> Going to use actual Stearman sumps. I have not decided yet if I will cut off part of the flanges and have them welded on or use bolts and proseal. (Stearman tanks do it both ways.) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439229#439229 Attachments: http://forums.matronics.com//files/2_sump_211.jpg http://forums.matronics.com//files/1_sump_386.jpg ________________________________________________________________________________
Date: Mar 10, 2015
I think if truth be known, the problem lies with the welder, not the machine. Too thick for the machine, maybe. I tig machine provides a very precise and incredibly fast heat source. I've welded Nixon marine exhausts with the same machine as I welded an aluminum tuna can. Glen, aerial in progress Sent from my iPhone > On Mar 10, 2015, at 6:09 PM, John Franklin wrote: > > > I hate to hear that they can't weld 0.050" AL because I've got 0.040" AL bought from Spruce A/C which I'm told is for gas tanks. I don't know much about welding AL but here's a youtube video where a guy welds soda cans with a TIG welder: https://www.youtube.com/watch?v=lJksVs2QT5Q > > Regards, > John Franklin > GN-1 / Corvair 164cid > Prairie Aire 4TA0 > Needville, TX > > > -----Original Message----- >> From: aviken <aviken(at)windstream.net> >> Sent: Mar 10, 2015 6:48 PM >> To: pietenpol-list(at)matronics.com >> Subject: Pietenpol-List: aluminum welding troubles >> >> >> Frustrated in Arkansas. I took my 050. aluminum sheet metal gas tank to the local sheet metal fabricators , and they tell me it will be a couple of days before they can weld it . I wait two weeks and call and they tell me they are afraid to try it because they feel the tig machine they have won't weld that thin .... Why didn't they tell me that two weeks ago. DANG!!!! > > > > > ________________________________________________________________________________
Date: Mar 11, 2015
Jake I planned on doing the same bur couldn't make the sump fit properly close to the edge. So I just machined one from aluminum. Can share a pic upon my return from Florida. Sent from my iPad Jack Textor > On Mar 10, 2015, at 10:31 AM, "aerocarjake" wrote: > > > Going to use actual Stearman sumps. I have not decided yet if I will cut off part of the flanges and have them welded on or use bolts and proseal. (Stearman tanks do it both ways.) > > -------- > Jake Schultz - curator, > Newport Way Air Museum (OK, it's just my home) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439229#439229 > > > > > Attachments: > > http://forums.matronics.com//files/2_sump_211.jpg > http://forums.matronics.com//files/1_sump_386.jpg > > > > > > > ________________________________________________________________________________
Date: Mar 11, 2015
You need to find another welder and now you know the questions to ask up front. Your tank should not be a problem. Barry NX973BP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of aviken Sent: Tuesday, March 10, 2015 7:48 PM Subject: Pietenpol-List: aluminum welding troubles Frustrated in Arkansas. I took my 050. aluminum sheet metal gas tank to the local sheet metal fabricators , and they tell me it will be a couple of days before they can weld it . I wait two weeks and call and they tell me they are afraid to try it because they feel the tig machine they have won't weld that thin .... Why didn't they tell me that two weeks ago. DANG!!!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439240#439240 ________________________________________________________________________________
Date: Mar 11, 2015
A custom car builder (Mustang specialist) did some MIG welding on 22 gauge (.0299 thick) stainless steel for me. Said it took some attention to keep from burning through and he had to weld up a tiny hole that he burned through. Every other welder I found in my area were specialists in welding on Oil rigs or Semi Trucks, they either said no or priced themselves out of the market (Cheapest was $85) . The mustang guy did it as a favor for me for $25). Blue Skies, Steve D. On Wed, Mar 11, 2015 at 8:05 AM, Barry Davis wrote: > > You need to find another welder and now you know the questions to ask up > front. Your tank should not be a problem. > Barry NX973BP > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of aviken > Sent: Tuesday, March 10, 2015 7:48 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: aluminum welding troubles > > > Frustrated in Arkansas. I took my 050. aluminum sheet metal gas tank to > the > local sheet metal fabricators , and they tell me it will be a couple of > days > before they can weld it . I wait two weeks and call and they tell me they > are afraid to try it because they feel the tig machine they have won't weld > that thin .... Why didn't they tell me that two weeks ago. DANG!!!! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439240#439240 > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Mar 11, 2015
Looks great Jake =) -------- riegerpietenpol.tumblr.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439264#439264 ________________________________________________________________________________
Date: Mar 13, 2015
Subject: Re: Basic Torch Safety
Here's another thing to avoid. I was at A & P school 1973. It was the final welding test for the practical exam. I was so preoccupied with getting on to the welding assignment I neglected to tighten the hoses to the torch body with the wrench. About half way through I had my face down close to the welding, and all of a sudden there was a horrific BANG! right in my face. Thankfully only some hair singed. I dodged a bullet that day. Only good thing was my hand was shaking just right after that so as to make perfect dimes! Dan Helsper Loensloe Airfield Puryear, TN -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Tue, Mar 10, 2015 8:08 pm Subject: RE: Pietenpol-List: Basic Torch Safety Thanks, Tom. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tkreiner Sent: Tuesday, March 10, 2015 5:49 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Basic Torch Safety --> Pietenpol-List message posted by: "tkreiner" Recently, I observed, and intervened in a situation that could have become dangerous - even deadly. A number of us were working on equipment when one of the guys was about to begin brazing a cast iron piece, and upon lighting his torch, we heard a series of Pops. The sound was staccato - almost like low intensity machine gun fire, prompting me to immediately shut off both the Ox and acetylene. The Popping ceased moments later... What was occurring was due to several factors, including: a runaway acetylene regulator, faulty check valves, and, last but not least, bad O-Rings inside the torch handle. The issue with the regulator was solved by Welding Supply to the tune of $140 for a new regulator. Since they were out of the check valves, we removed them from the torch handle, and continued on. While troubleshooting, we noted that the torch tip wasn't flowing gas -- so with tank valves turned off - I wrapped my hand around it and attempted to remove it from the handle. As many of you know - or should know - Victor 100 torches, including all their clones like the Uniweld, and Harbor Freight torches - use two O-Rings to seal the gases from one another and, since they are compliant seals, the tip is to be HAND TIGHTENED ONLY. The torch in question not only had a wrench tightened tip, the O-Rings were cut, allowing the gases to mix INSIDE THE HANDLE... Exactly why the O-Rings were added to the design in the first place; to eliminate mixing within the handle! In the pic you'll see the handle end of the torch tip - where it enters the torch handle, along with the two O-Rings. The O-Rings themselves are metric, and they are available from Amazon at this link: http://www.amazon.com/Uniweld-TXRK-Tip-O-Ring-Repair/dp/B00FI1JM9G I've also located the same O-Rings in Viton, which should cost a whopping 3 cents more each, assuming we can buy then in the right volume. I'm attempting to get a quotation on 300 pieces of each to keep on hand in my shop and supply to anyone needing some for their torch collection. Now - please make sure your torch is ready to go, and if you have any issues that don't seem right, STOP. Figure out what the issue is, or take your rig to a competent welding supply shop. They will assist at no cost for trouble shooting. If, on the other hand, like the torch above, and the 8 torch tips in my own collection, which had cracked O-Rings.... Upgrade now and ensure that anyone using your torch is using a tool that's not going to hurt them. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439242#439242 Attachments: http://forums.matronics.com//files/torch_o_rings_491.jpg - The Pietenpol-List Email Forum - Navigator to browse Un/Subscription, Photoshare, and much much more: http://www.matronics.com/Navigator?Pietenpol-List - MATRONICS WEB FORUMS - Forums! http://forums.matronics.com - List Contribution Web Site - -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Subject: FBG, Part Deux
Date: Mar 13, 2015
I know that Kevin would not likely do so, so I have taken it upon myself to provide a link showing his repair. The quality looks awesome! The workmanship is great, the humor still shines through ("Axel, the pond. The pond."), and his engine looks great with the new exhaust. I can't wait to see it flying. Just wanted everyone to see what a nice repair looks like. Hats off to you, Kevin! http://flycorvair.net/2015/03/13/current-corvair-instalation-in-a-pietenpol-pt-1/ -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439317#439317 ________________________________________________________________________________
Subject: Re: Arch support question
Date: Mar 13, 2015
Paul, Look at the pictures of Kevin Purtee's repair by clicking on the following link- http://flycorvair.net/2015/03/13/current-corvair-instalation-in-a-pietenpol-pt-1/ Is that what you are talking about in picture #4? The area between the rear instrument and the back of the front seat? -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439319#439319 ________________________________________________________________________________
From: Scott Knowlton <flyingscott_k(at)hotmail.com>
Date: Mar 13, 2015
A couple of pics for another example of the same. The laminating is fun, easy and strong once the instrument board and seat ba ck are glued on. Scott Knowlton Burlington Sent from my iPhone > On Mar 13, 2015, at 9:35 AM, "jarheadpilot82" wrote: > mail.com> > > Paul, > > Look at the pictures of Kevin Purtee's repair by clicking on the following link- > > http://flycorvair.net/2015/03/13/current-corvair-instalation-in-a-pietenpo l-pt-1/ > > Is that what you are talking about in picture #4? The area between the rea r instrument and the back of the front seat? > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439319#439319 > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Subject: BPA
Date: Mar 13, 2015
I sent my check for membership to the BPA more than a month ago. It has not been cashed, and I have not been contacted in any way. The website is still showing the cover of a newsletter more than a year old. Has this assn gone dormant? I had planned to order several of the publications they list and sell, but I am reluctant to send another check not knowing if anyone is on the other end. Is this type of delayed response and out-of-date website condition common for the BPA, or is something amiss? I'm not judging--just trying to get a feel for what to expect. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439322#439322 ________________________________________________________________________________
Date: Mar 13, 2015
Subject: Re: BPA
Andy, you have elected to build a Pietenpol. That won't happen fast. have some patience. It will prepare you for cross country flights in your Pietenpol. I just dropped my dues in the mail box 10 min ago. Blue Skies, Steve D On Fri, Mar 13, 2015 at 11:41 AM, Andy Garrett wrote: > andy_garrett(at)live.com> > > I sent my check for membership to the BPA more than a month ago. It has > not been cashed, and I have not been contacted in any way. > > The website is still showing the cover of a newsletter more than a year > old. > > Has this assn gone dormant? > > I had planned to order several of the publications they list and sell, but > I am reluctant to send another check not knowing if anyone is on the other > end. > > Is this type of delayed response and out-of-date website condition common > for the BPA, or is something amiss? I'm not judging--just trying to get a > feel for what to expect. > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439322#439322 > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Mar 13, 2015
PM him. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439331#439331 ________________________________________________________________________________
Subject: Re: BPA
Date: Mar 13, 2015
Just curious. I guess I'm just eager to apply all the facts and opinions to my developing understanding of what is to come. Having that information at my disposal is required for that understanding. Besides, the rather philisophical writings of William Wynn are central to my corvair-powered Piet build, and he is quite passionate in his distain for the idea of 'waiting'. [Wink] Just can't read and learn enough right now. [Shocked] -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439332#439332 ________________________________________________________________________________
Date: Mar 13, 2015
Subject: Re: BPA
Andy, another site with lots of great info is the bowersflybaby.com site. many ideas and tips that crossover to Piets. Blue Skies, Steve D On Fri, Mar 13, 2015 at 3:47 PM, Andy Garrett wrote: > andy_garrett(at)live.com> > > Just curious. > > I guess I'm just eager to apply all the facts and opinions to my > developing understanding of what is to come. Having that information at my > disposal is required for that understanding. Besides, the rather > philisophical writings of William Wynn are central to my corvair-powered > Piet build, and he is quite passionate in his distain for the idea of > 'waiting'. [Wink] > > Just can't read and learn enough right now. [Shocked] > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439332#439332 > > -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Re: BPA
Date: Mar 13, 2015
That is a great site! Looking it over was inspiring, as many of those Fly Baby guys and gals choose to 'theme' their planes with WWI livery--several with faux Spandau machine guns on the cowling. I intend something similar. Fun attitudes over there as well, and as you said, plenty of crossover information. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439336#439336 ________________________________________________________________________________
Date: Mar 13, 2015
Subject: Re: BPA
if you like that, look up the Faker Fokker. A pietenpol with a tail modified to look like a Fokker On Fri, Mar 13, 2015 at 4:46 PM, Andy Garrett wrote: > andy_garrett(at)live.com> > > That is a great site! Looking it over was inspiring, as many of those Fly > Baby guys and gals choose to 'theme' their planes with WWI livery--several > with faux Spandau machine guns on the cowling. I intend something similar. > > Fun attitudes over there as well, and as you said, plenty of crossover > information. > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439336#439336 > > -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Re: BPA
Date: Mar 13, 2015
Andy, No, the association has not "gone dormant." There was a bit of a disruption in the publishing of the newsletter after Doc and Dee Mosher handed over the reins to John Hofmann about a year ago. However, it seems that those troubles are now in the past. The latest issue of the newsletter is currently being delivered by the post office. A revamped website is in the works. Word has it that online dues payment will be a welcome new feature. However, I'm not sure about your comment about "publications they list and sell". Doc compiled a list of useful books, but those books are available through the EAA, not the BPA. http://www.pietenpols.org/id1.html Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439339#439339 ________________________________________________________________________________
Subject: Re: BPA
Date: Mar 13, 2015
Hey Andy You'll also want to check out Kansas City dawn patrol website. One of the original members (Marvin Story) developed, an had plans for an oxy acetylene fired faux machine gun on their site. You mentioned possibly a WWI derivative? What are you dreaming up(tell me yours and I'll tell ya mine) Glen. Aerial in progress(fuse off the bench tail feathers and rear pit seat this weekend) Sent from my iPhone > On Mar 13, 2015, at 2:46 PM, "Andy Garrett" wrote: > > > That is a great site! Looking it over was inspiring, as many of those Fly Baby guys and gals choose to 'theme' their planes with WWI livery--several with faux Spandau machine guns on the cowling. I intend something similar. > > Fun attitudes over there as well, and as you said, plenty of crossover information. > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439336#439336 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: BPA
Date: Mar 13, 2015
Thanks for the clarification Bill. I'll grab those from EAA then. Glen, I'm not planning any 'cloning' really--just a 'flavor'. I'll have what is essentially a solo cockpit due to my body weight of 255-260 (no gear). The forward cockpit will be baggage and maybe a lot of fuel (still haven't made my decision on a wing tank). It will have a removable hard cover with fake guns mounted to it. The engine will be a high mount Corvair with a spinner and eyebrows outside a narrow cowling. No tail changes, but colors will be German with a nod to my time with the 101st Airborne Division. That's my daydream vision this month. It may evolve. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439347#439347 ________________________________________________________________________________
Date: Mar 13, 2015
Subject: Re: BPA
Hey Andy! Glad to see another 101st vet. I was in the 1-101st Attack Helicopter Battalion "Expect No Mercy!" :-) On Fri, Mar 13, 2015 at 10:08 PM, Andy Garrett wrote: > andy_garrett(at)live.com> > > Thanks for the clarification Bill. I'll grab those from EAA then. > Glen, I'm not planning any 'cloning' really--just a 'flavor'. > I'll have what is essentially a solo cockpit due to my body weight of > 255-260 (no gear). The forward cockpit will be baggage and maybe a lot of > fuel (still haven't made my decision on a wing tank). It will have a > removable hard cover with fake guns mounted to it. > The engine will be a high mount Corvair with a spinner and eyebrows > outside a narrow cowling. No tail changes, but colors will be German with a > nod to my time with the 101st Airborne Division. > That's my daydream vision this month. It may evolve. > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439347#439347 > > -- Greg Bacon ________________________________________________________________________________
Date: Mar 13, 2015
Subject: Re: BPA
My buddy/mentor Lew Mason has this WWI look alike, he calls der chicken flieger. http://www.35.eaachapter.org/apps/photos/ He now has a gun ring he mounts (for static display only) behind the pilot hole. I looks like a Bosche with a picklehaube helment and a Spandau. Blue Skies, Steve D On Fri, Mar 13, 2015 at 10:36 PM, Greg Bacon wrote: > Hey Andy! Glad to see another 101st vet. I was in the 1-101st Attack > Helicopter Battalion "Expect No Mercy!" > > :-) > > On Fri, Mar 13, 2015 at 10:08 PM, Andy Garrett > wrote: > >> andy_garrett(at)live.com> >> >> Thanks for the clarification Bill. I'll grab those from EAA then. >> Glen, I'm not planning any 'cloning' really--just a 'flavor'. >> I'll have what is essentially a solo cockpit due to my body weight of >> 255-260 (no gear). The forward cockpit will be baggage and maybe a lot of >> fuel (still haven't made my decision on a wing tank). It will have a >> removable hard cover with fake guns mounted to it. >> The engine will be a high mount Corvair with a spinner and eyebrows >> outside a narrow cowling. No tail changes, but colors will be German with a >> nod to my time with the 101st Airborne Division. >> That's my daydream vision this month. It may evolve. >> >> -------- >> Andy Garrett >> 'General Purpose Creative Dude' >> Haysville, Kansas >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=439347#439347 >> >> >> >> >> >> >> >> ========== >> br> enpol-List" target="_blank"> >> http://www.matronics.com/Navigator?Pietenpol-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > > > -- > Greg Bacon > > * > > > * > > -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Re: BPA
Date: Mar 13, 2015
We got back from CC#32 and found a very nice new issue of the newsletter in the mailbox. Special thanks to Dowe, Ken and all the others who made material contributions to it. Andy, welcome aboard. While I have made a lot of comments about not waiting, I am mostly speaking of the people who will get started 'some day.' As pointed out by others, some patience and understanding goes a long way in traditional homebuilding. The key to not 'waiting' once you have gotten started is to find ways to make effective progress when waiting on one element. My actual golden rule of homebuilding is "Persistence Pays." Your project will present at least 1,000 opportunities to call it quits. To finish, all you have to do is master the phrase "I can always quit tomorrow" and keep chugging along. Even when the newsletter is set to 'High Blower' it still only comes out every 120 days. If you are thirsty, consider ordering a set of back issues direct from Doc and Dee. You will have a large pile of timeless content, and they are a good way to get to know a bit about many of the most prolific contributors here. -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439350#439350 ________________________________________________________________________________
Date: Mar 13, 2015
As Ken and Barry pointed out, .050" is plenty thick for anyone who knows what they are doing to weld. So is .040". If you tour the Zenith factory you can see countless leak free wing tanks welded from .025", all done with normal Tig machines, by mortals. Keep in mind: Never weld mounting tabs on the tank, always use straps to mount it - Try to avoid any butt weld on a tank - If you are having a welder do it for you (good idea) bring him a pound of 1/16" 4043 rods so he isn't tempted to just try the rods he has laying around. I have welded about 150 Corvair oil pans from .050". If you would like to see what the welds look like, here is an 11 year old story with good pictures. http://www.flycorvair.com/601March2004.html -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439351#439351 ________________________________________________________________________________
Subject: Upcoming trips to Houston and Los Angeles...
Date: Mar 14, 2015
I'll be working in Houston next week and Burbank the following week...anyone available if I was to invite myself over for a visit? Jim in Pryor Sent from my smartphone. ________________________________________________________________________________
Subject: Re: BPA
Date: Mar 14, 2015
Thanks to all for the comments. Above all, I want this process to be fun. My 3.5 year boat build was the most rewarding experience of my life (and I've had an interesting life so far). I expect the Piet to be the same only more so. William, thanks for taking the time to comment, I know how busy you are with nearly back to back CCs. I've been buried in my Corvair Conversion Manual for weeks now, and have found the tone to be motivating. So much of this pursuit is very technical and it is easy to loose sight of 'why' we chose this path. Thus, it becomes easier to accept one of those thousand reasons to quit that you mentioned. Your style of information presentation never strays far from the philosophical reason we do this. This type of encouragement drives my desire to absorb as much as I can from all angles. I just want to get started, because I know how I respond once I get rolling--I will have momentum and that will get things done. Life will eventually intervene, but in good bursts..., it'll keep moving along. I just have to save some $$$ for the crank and bearing work (as I hunt for an engine). Everyone wants to sell the whole car as a package for more than I want to spend. I will be patient and press on. Thanks again. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439368#439368 ________________________________________________________________________________
Subject: engine mount
Date: Mar 14, 2015
So..., I have an interest in making my own mount for the Corvair per BHP's plans, but at a higher thrust line. I suspect I'll need a slightly bigger prop. Does anyone know the difference is between the 'standard' thrust line and the 'high' thrust line? -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439388#439388 ________________________________________________________________________________
Subject: Re: engine mount
Date: Mar 14, 2015
Andy, Not to put you off, but there is more info on this subject on the FlyCorvair.net and FlyCorvair.com websites than here. I would email William Wynne directly to get more info about this aspect of your build. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439389#439389 ________________________________________________________________________________
Date: Mar 14, 2015
Your comment about a larger prop caused me to pull up this link- http://flycorvair.net/?s=Propeller&submit=Search Maybe this will help you some. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439393#439393 ________________________________________________________________________________
Date: Mar 14, 2015
Andy, To further Terry's comments: If you have a question about the stuff we do with Corvairs, I like to cover that on our own sites. I try to make all my comments here applicable to all Piet builders. I am glad to share stuff about what BHP did with Corvairs here, but I like to keep anything that sounds like commercial work or customer service on our own sites. If you missed it this page: http://flycorvair.net/2013/11/28/corvair-pietenpol-reference-page/ has links to a few dozen stories I wrote on Piets and our work with them. Detailed answers to your mount questions can be found there. To be clear, 'High thrust line' is just a descriptive term I made up to differentiate The mounts we make from BHP Corvair mounts. There is about 3" difference, but our mounts are also 3" longer, as a result of things we learned from the weight and balance project: ( http://flycorvair.net/2014/02/23/pietenpol-weight-and-balance-project/ ) If you look at the BHP mount, it has two legs that come back to meet the cross reinforcement 2/3rds of the way up the fuselage. You can't just make it 3" taller, it will not meet any structure. Our mounts just contact the four longerons. Study the pictures in the links and it will make sense. I actually do not have a drawing for our mounts, I just built a fixture and have made about 20 of them. BHP selected the thrust line he used because it was very close to the Ford's location, it worked with original fuselages, and he needed the vertical clearance to fit the Corvair's stock blower fan, which we do not use. Terry's comments on what we do are pretty accurate because He comes to the Colleges, is a good researcher and voracious reader, he has a complete and test run Corvair, a fully welded fuselage, and most of his wings done. I listen to his thoughts on flying because he has about 25K hours flying Boeings around the globe, a long stint as an instructor at Pensacola, an active CFI and good judgment. Our Pietenpol page has a very good guest editorial of his on risk management. -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439402#439402 ________________________________________________________________________________
From: =?utf-8?B?Ymx1ZXBpbG90NUB5YWhvby5jb20=?= <bluepilot5(at)yahoo.com>
Subject: Log time listener first time caller
Date: Mar 15, 2015
CgoKCgoKICAgIEdvb2QgbW9ybmluZyBhbGwgZnJvbSB0aGUgc29nZ3kgc3RhdGUgb2YgV2FzaGlu Z3Rvbi4gQWZ0ZXIgbWFueSB0aG91Z2h0cyBJIGhhdmUgZGVjaWRlZCB0byBidWlsZCBhIFBpZXRl bnBvbCBidXQgYXMgYnV0IEkgd2FudCBmbHkgZXZlcnl3aGVyZS4gSGVyZSBpbiB0aGlzIHN0YXRl LiBJIHdpbGwgYmUgZmx5aW5nIG92ZXIgbW91bnRhaW5zIGFuZCB3YXRlciBhbmQgbGFyZ2Ugd29v ZHMuIFNvIGNvdWxkIHNvbWVvbmUgYnJhc3MgdGFja3MgdGhlIHJlbGlhYmlsaXR5IG9mIHRoZSBD b3J2YWlyIHZzIHRoZSBvLTIwMC4gUGxlYXNlIGFuZCB0aGFuayB5b3UuClNlbnQgZnJvbSBteSBW ZXJpem9uIDRHIExURSBTbWFydHBob25lCgoK ________________________________________________________________________________
Subject: Re: Upcoming trips to Houston and Los Angeles...
Date: Mar 15, 2015
Jim I don't know if you remember but we met for five years ago when you were in Houston and if you have the time and you are not already committed give me a call 832-326-2970, and will get dinner. Tom -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439421#439421 ________________________________________________________________________________
Subject: Re: Log time listener first time caller
Date: Mar 15, 2015
Mr. Pilot: Theory: O-200, as a purpose built certified aircraft engine, is more reliable than any conversion engine like a Corvair. Reality: You can't expect any O-200 for sale for $7K to demonstrate the same reliability as a New, certificated $25K O-200A. (The O-200D at $19.9K does not have the same track record) Do you like to gamble, particularly with very large wagers? Buy a used engine, don't tear it down, and fly it banking on the idea that the seller said it was 'great'. The wager isn't the $7K, it is your life. Don't like to gamble? If you are willing to invest time to learn and get your hands dirty, I can show you how to build a $7K Corvair that is far more reliable than the great majority of used O-200s at the same price. If you just read this and said "But my buddy bought an engine from Banstormers and it turned out great" You are a gambler at heart, and I wish you good luck. If you just read this and said, "I would rather know what was inside", you are a builder at heart. You will not need luck, which is good because it doesn't exist. -------------------------------- A VERY importiant story to read about flying in unforgiving places: http://flycorvair.net/2012/10/22/ed-and-claire-jeffko-a-love-story/ -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439422#439422 ________________________________________________________________________________
Date: Mar 15, 2015
No Message here. You must have the same computer Jeff Boatright uses. Jack Phillips NX899JP Smith Mountain Lake, Virginia From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bluepilot5(at)yahoo.com Sent: Sunday, March 15, 2015 2:50 PM Subject: Pietenpol-List: Log time listener first time caller ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Date: Mar 16, 2015
I resemble that remark!! Hey, man, I went flying for the first time in 2015!! GOD I LOVE FLYING!! ________________________________________ Jeffrey H. Boatright, PhD Professor of Ophthalmology Emory University School of Medicine ________________________________ From: owner-pietenpol-list-server(at)matronics.com [owner-pietenpol-list-serve r(at)matronics.com] on behalf of Jack Philips [jack(at)bedfordlandings.com] Sent: Sunday, March 15, 2015 8:38 PM Subject: RE: Pietenpol-List: Log time listener first time caller No Message here. You must have the same computer Jeff Boatright uses. Jack Phillips NX899JP Smith Mountain Lake, Virginia From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of bluepilot5(at)yahoo.com Sent: Sunday, March 15, 2015 2:50 PM Subject: Pietenpol-List: Log time listener first time caller ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Subject: Ford Model A Question
Date: Mar 16, 2015
I am looking for the springs that go on top of the Model A block that hold the engine block to the wood bearers. Does anyone have a source or part number of what they have used? I have checked with local hardware stores, McMaster Carr, MSC, etc. everybody has springs but not the correct size. Dia. Is too big, coil size to big, etc. smaller ones that I have found that would work are too weak and not strong enough. Any leads would be apprecaited. Thanks Rob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439429#439429 ________________________________________________________________________________
Date: Mar 16, 2015
Both engines can be reliable if built and maintained correctly. My pick wou ld be the 0200, sorry Corvair folks... Sent from my iPad Jack Textor > On Mar 15, 2015, at 1:50 PM, bluepilot5(at)yahoo.com w rote: > > Good morning all from the soggy state of Washington. After many thoughts I have decided to build a Pietenpol but as but I want fly everywhere. Here in this state. I will be flying over mountains and water and large woods. So c ould someone brass tacks the reliability of the Corvair vs the o-200. Please and thank you. > > Sent from my Verizon 4G LTE Smartphone > =C2=C2=B7=BA~=B0=C3=AD=C2=B2,=C3=9E=C3=99=C3=8A%=C2=A2=C2=BD 4=C3=93M4}=C2=A7=1Er=B9=C2=AB=B0=C3=C3=A7{=07(=C2=BA=C2=B8=C5 =BE=C2=AD8^>'=C2=ADzzh=9D=C2=B8=C2=AC=C2=B4I=C5=A1=C5-Qh=C2=AE=C3=A9 =9D=C2=B1=C3=ABax=C3=86=C2=AD=C2=AE=B0=C3=A2r=C3=82=C3=A2=C2=B2=C3 =91^j=C3=9B=C2=ABz=C3=83Z=C2=BE(=1A=C2=B6=C5-=C3=AD=C2=A1=C2=BA=C3=A8=C3=82 =C3=87=C2=AD=C3=A9=C5=A1=C5=B8"=C3=A2=C2=B2=C3=9B=C2=AD=C5-X=C2=AD =B0=C3=AB,=C2=B9=C3=88Z=C2=B0=C2=B8=C2=AC=C2=B5I=C3J=C3=C3=ACr=C2 =B8=C2=A9=C2=B6*'=02=C2=B7!=C5-=C3=B7=99y=C2=C3=9C=9E:0=C5=BE Z=1Aw=C2=B0=C3=9A=C3=88=1A=C3=A8=C3=82=C3=87=9A=C2=ABE=01=03=C3 =A1=C2=A2=C3=9A,=C2=C3=9Ejwf=C2=B9=C3=88f=C2=B9=C3=88f=C2=A2=C2=B7 =C5=A1-=C2=B7=C5=B8-=C3=9Bi=C3=C3=BC0=C3=82f=C2=AD=C2=AE =B0=C3=A2r=C3=87(=BA=C3=B3Z=C2=BE(=1A=C2=B6=C5-=C3=8F=B0=C3 =AB^=C5=BE=C5=A1%.+--=C3=9Bi=C3=C3=BC0=C3=82f=C2=AD=C2=AE=B0 =C3=A2r=C3=87(=BA=C3=B3Z=C2=BE(=1A=C2=B6=C5-=C3=8F=B0=C3=AB^=C5 =BE=C5=A1%.+-=C3=BD=C2=A3M=13=C2=8D $=93=10=11NEC=12I=C2=A9=C5=BE =9A=C2=B7=C5=A1=C2=B5=C3=8A'=C2=B5=C3=A9=C3=ADj[(j=C3=B6=C2=A2=A2=C2 =C3=A5z=C3=B8=C5=A1=C2=B6=17=93y=C2=B1h=C2=AE=C3=A9=C2=ACj=1A=C3=9E~=1B m=C2=A7=C3=C3=9F=C2=A2=C2=BB=C2=C2=B2f=C2=AD=C2=AE=B0=C3=A2r=C3=87 (=C5=A1=1Bm=C2=A7=C3=C3=9F=C2=A2=C2=BB=C2=C2=B2f=C2=AD=C2=AE=B0=C3 =A2r=C3=87(=BA=C3=B6=B9=C5-=C3=8BB=C2=A2{k=B0=C2=BB=C2=AD =C5-=B0=C3'y=C2=B4=C2=A2=C2=B5=C3=A4=C3=A1jy2=C2=A2=C3=A7=C3=A8=C2 =AF*.=C2=AE=07=C2=A7z=C2=BA.=C2=B2=C3=8B=C2=A9=C2=C5-=C3=AD1=C2=ABm=0E=C2 =B6=C2=A5=A2=C3=A2=C3=A2=C2=B2=C3=90=1D=C5=A1)=C3=9A-=C2=B7=C5 =B8-=C3=9Bi=C3=C3=BC0=C3=82f=C2=AD=C2=AE=B0=C3=A2r=C3=87( =BA=C3=B7(=C5=BE=C3=9A=C3=A2n=C3=ABb=C2=A2xm=C2=B6=C5=B8=C3=C3=83=0C&j =C3=9A=C3=A8=C5=BE',r=B0=C2r=B0=C3=AD=C2=AE&=C3=AE=C2=B6*'=C3 =BD=C2=AF=C3=9B=C3=BD=C3=BA'=C2=B7=C3=BAk{=C3=B6=C3=A8w/=C3=A1=C2=B6i ________________________________________________________________________________
Date: Mar 16, 2015
JacK Textor: About 300 years before the Wright brothers, a guy in England wrote a play about the Roman Empire, and the dialog included a timeless bit of wisdom: . "The fault, dear Brutus, is not in our stars, But in ourselves " . The passage is really about resisting elevating a man to divine status who on the basis of observed evidence, was a mortal. It addresses the element in all humans that wants to believe that they can abdicate from difficult decisions if they grant special powers, ie: emperor, certification, etc, to one side and then blindly follow it. Both engines can be made to work well, The fault dear jack, is not in the metal, but in the people. And the primary fault of the people is granting a used O-200 some special status, because some of the parts on it were once inside a set of specifications called certified. To blindly trust that, or to believe that O-200s without logs or papers still inherently will have advantages over conversions, is the very core of the exact attitude that has cost many people dearly. The only defense in aviation is Never to grant an engine, plane nor pilot special status that no longer requires you to examine it for what it is. Trust, only on the basis of what you can see and understand, and have verified. This kind of thinking was taught to me by old men, aviators who were alive because the never made 'gods' of things that were just metal systems.-ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439431#439431 ________________________________________________________________________________
Date: Mar 16, 2015
O-200 is turn key by in large. and more expensive New lightweight (199LB) is $21,000+ older O200 is around 220Lbs+ or - overhaul to new limits is $13000+ plus core $2-3000 You can do the overhaul yourself and save money. Lots of certified and uncertified props. Corvair takes work but is much less expensive "New" from WW runs $9700 to $11,700 (120HP). Built up by yourself runs around $5000 to $8000 and is zero time Weight 225lbs Corvair engine turns the other way so it needs a"left hand prop" but there are many out there. Lots of opinions, out there Pro and con. I would certainly consider either engine. If I ever need an engine I think I will go Corvair and build it up myself for the experience. Plus I would really know how to work on it! Blue Skies, Steve D ________________________________________________________________________________
Date: Mar 16, 2015
Thank you gentlemen. I've read through the links again and picked up a few things I had missed on previous reads. I am inclined to send off for Doc Mosher's Piet info packet. Is he still offering this? -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439441#439441 ________________________________________________________________________________
Date: Mar 16, 2015
I have an engine mount that fits a 26 inch wide fusee.I am switching to a continental. Gardiner mason. 7065943811. Lagrange, Ga. Sent from my iPad > On Mar 14, 2015, at 7:49 PM, "Andy Garrett" wrote: > > > So..., I have an interest in making my own mount for the Corvair per BHP's plans, but at a higher thrust line. > > I suspect I'll need a slightly bigger prop. > > Does anyone know the difference is between the 'standard' thrust line and the 'high' thrust line? > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439388#439388 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 16, 2015
Hi Terry, Do you need the engine mounting hardware? Gardiner Sent from my iPad > On Mar 14, 2015, at 8:27 PM, "jarheadpilot82" wrote: > > > Your comment about a larger prop caused me to pull up this link- > > http://flycorvair.net/?s=Propeller&submit=Search > > Maybe this will help you some. > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439393#439393 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 16, 2015
as far as bigger props go- I expect WW can fill you in as what performs best, but if I remember right a 68" dia. was about what I think I remember being pretty much optimum for the vair.probably can play plenty with the pitch and blade width and such but I'm not sure it's adviseable to go a lot longer - due to weight, flywheel effect and such on the corvair rank. but I'm pretty sure someone will give a better opinion Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439453#439453 ________________________________________________________________________________
Subject: Wind Chill - 120mph, 35 degrees, raining, shirtless....
Date: Mar 16, 2015
Piet Fans: At Corvair College #32, Kevin Purtee, came up with a fun idea to separate the tough guys from the really tough guys....... http://flycorvair.net/2015/03/17/current-corvair-installation-in-a-pietenpol-part-2/ Some people are just made for open cockpit flying. -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439459#439459 ________________________________________________________________________________
Date: Mar 17, 2015
Subject: Re: Ford Model A Question
Rob, I bought extras, probably a bag of 10, when I got mine. I just walked out to the hangar to look in my "spare hardware" box and I found them. I will wait till it gets light to confirm that these are the ones I used. If so you are welcome to have them. I will let you know as soon as I can see out there. Dan Helsper Loensloe Airfield Puryear, TN -----Original Message----- From: Pietflyer1977 <rob(at)stoinoff.com> Sent: Mon, Mar 16, 2015 6:56 am Subject: Pietenpol-List: Ford Model A Question I am looking for the springs that go on top of the Model A block that hold the engine block to the wood bearers. Does anyone have a source or part number of what they have used? I have checked with local hardware stores, McMaster Carr, MSC, etc. everybody has springs but not the correct size. Dia. Is too big, coil size to big, etc. smaller ones that I have found that would work are too weak and not strong enough. Any leads would be apprecaited. Thanks Rob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439429#439429 - The Pietenpol-List Email Forum - Navigator to browse Un/Subscription, Photoshare, and much much more: http://www.matronics.com/Navigator?Pietenpol-List - MATRONICS WEB FORUMS - Forums! http://forums.matronics.com - List Contribution Web Site - -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 17, 2015
Thanks Dan! Would really appreciate it! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439462#439462 ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Mar 17, 2015
Gardiner, Yes I do. I am in Dakar, Senegal, West Africa right now on a trip and will call you in a day or so. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439463#439463 ________________________________________________________________________________
Date: Mar 17, 2015
Rob, I am sorry, but upon closer examination I see that these are not the ones I used (not close). I tried to mike the ones on the engine and it appears the over-all diameter (slightly compressed) is .423, and the wire size is .06. They look a little wimpy to me now. I can't remember my thought processes at the time, but I do remember ordering and trying a bunch of different ones. I am almost sure I got these from McMaster. I know there is not very much room to work with in that situation so one is really limited. I might have "settled" for these I have on the engine now, if you know what I mean. The engine does rock upon start-up, that is for sure. I can clearly see evidence of that. Dan Helsper Loensloe Airfield Puryear TN -----Original Message----- From: Pietflyer1977 <rob(at)stoinoff.com> Sent: Tue, Mar 17, 2015 7:15 am Subject: Pietenpol-List: Re: Ford Model A Question Thanks Dan! Would really appreciate it! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439462#439462 - The Pietenpol-List Email Forum - Navigator to browse Un/Subscription, Photoshare, and much much more: http://www.matronics.com/Navigator?Pietenpol-List - MATRONICS WEB FORUMS - Forums! http://forums.matronics.com - List Contribution Web Site - -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 17, 2015
Thanks Dan appreciate the effort. Jeff Faith gave me the info of what he used. They are Model T ( which is why I couldn't find them, I was looking with A stuff ) radius rod cap springs. Snyder Ford # T-2742. $1.00 a pair. If you think yours are light maybe try some of these? Thanks Again Rob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439468#439468 ________________________________________________________________________________
Date: Mar 17, 2015
As a student pilot, I was on my second cross county solo from Wichita to Salina. During that flight, somewhere over McPherson, KS, the certified engine in the 1976 Cessna 150M I was flying (N8634U) started sputtering. This was my first experience with engine trouble and it gave me a pucker. I went to the checklist and did as it said. Carb heat did nothing much but it ran well enough to complete the flight. I could see Salina after-all, and I had numerous off field options, so I stuck with it. As I started my descent, ATC called and advised me that I had a 747 heavy off my right wing passing under me. I looked out to read 'United States of America' down the length of the President's plane heading out to the gunnery range just to the west. I had not radioed my engine troubles to the tower. Otherwise, they surely would have vectored 'Bigfoot whatever he was calling himself' away from a path directly beneath me (POTUS was obvious not on board). On the ground at Salina, I called the owner back at Dead Cow International (71K) and described the engine issues. He was convinced it was carb ice, but put no pressure on me to fly it back if I was not comfortable. He instructed me to let it sit for an hour and do a lengthy run-up before taking off if I chose to do so. I did this, and the return trip went fine. What this experience did to me as a student pilot with a couple dozen hours, was put me in a constant state of awareness. Before that day, I operated on the 'if millions of other people can fly and be safe trusting their rented equipment, then so can I' mentality. After that day, I have not fully trusted any aircraft I've flown. It was even worse flying a Rotax two-stroke while fully exposed in my Airbike. I never really 'relax' when I am piloting. I think if knew the engine intimately, having gained an understanding of what is going on in their, and having turned the wrenches myself--knowing the quality of the components and the workmanship, I would be able to relax just a bit more. I don't want to get back to being blissfully ignorant of the risks like I was as a student. I just want to be more in command of them. That has been my path to Corvairs and the philosophy that governs the 'movement'. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439471#439471 ________________________________________________________________________________
Subject: Re: Wind Chill - 120mph, 35 degrees, raining, shirtless....
Date: Mar 17, 2015
Great article! As a native of Florida..., that would not have been me. [Shocked] -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439472#439472 ________________________________________________________________________________
Subject: Back on the forum
Date: Mar 17, 2015
Hi everyone, Hows it going? Well after a several year absense, and looking at other plans I'm backing to the Piet again. Right now now I have 13 ribs made, but not done. I also have a corvair engine also. take care, Ben Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439475#439475 ________________________________________________________________________________
Date: Mar 17, 2015
Andy, Friends don't let friends fly two strokes! Steve D. On Tue, Mar 17, 2015 at 11:31 AM, Andy Garrett wrote: > andy_garrett(at)live.com> > > As a student pilot, I was on my second cross county solo from Wichita to > Salina. During that flight, somewhere over McPherson, KS, the certified > engine in the 1976 Cessna 150M I was flying (N8634U) started sputtering. > This was my first experience with engine trouble and it gave me a pucker. I > went to the checklist and did as it said. Carb heat did nothing much but it > ran well enough to complete the flight. I could see Salina after-all, and I > had numerous off field options, so I stuck with it. > > As I started my descent, ATC called and advised me that I had a 747 heavy > off my right wing passing under me. I looked out to read 'United States of > America' down the length of the President's plane heading out to the > gunnery range just to the west. I had not radioed my engine troubles to the > tower. Otherwise, they surely would have vectored 'Bigfoot whatever he was > calling himself' away from a path directly beneath me (POTUS was obvious > not on board). > > On the ground at Salina, I called the owner back at Dead Cow International > (71K) and described the engine issues. He was convinced it was carb ice, > but put no pressure on me to fly it back if I was not comfortable. He > instructed me to let it sit for an hour and do a lengthy run-up before > taking off if I chose to do so. I did this, and the return trip went fine. > > What this experience did to me as a student pilot with a couple dozen > hours, was put me in a constant state of awareness. Before that day, I > operated on the 'if millions of other people can fly and be safe trusting > their rented equipment, then so can I' mentality. After that day, I have > not fully trusted any aircraft I've flown. It was even worse flying a Rotax > two-stroke while fully exposed in my Airbike. I never really 'relax' when I > am piloting. I think if knew the engine intimately, having gained an > understanding of what is going on in their, and having turned the wrenches > myself--knowing the quality of the components and the workmanship, I would > be able to relax just a bit more. I don't want to get back to being > blissfully ignorant of the risks like I was as a student. I just want to be > more in command of them. > > That has been my path to Corvairs and the philosophy that governs the > 'movement'. > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439471#439471 > > -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Re: Back on the forum
Date: Mar 17, 2015
Hi Ben. Welcome back! Where are you located? Tell us about your project. Glen. Aerial in progress Sent from my iPhone > On Mar 17, 2015, at 9:58 AM, "MNBenny" wrote: > > > Hi everyone, > > Hows it going? Well after a several year absense, and looking at other plans I'm backing to the Piet again. Right now now I have 13 ribs made, but not done. I also have a corvair engine also. > > take care, > > Ben > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439475#439475 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 17, 2015
Yea, they don't inspire much confidence Steve! Yet, my buddy Paul just crossed 1000 hours TTAF on his Airbike (built in '97). Two engines (447 then 503), and only one off-field incident due to a stoppage. I think that would be a Rotax success story wouldn't it? -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439489#439489 ________________________________________________________________________________
Date: Mar 17, 2015
I'm in St. Joseph, MN. That's 75 miles NE of the twin cities. I have 13 ribs made so far, but not complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439490#439490 ________________________________________________________________________________
Subject: BRS in a Piet?
Date: Mar 17, 2015
Surprisingly, I find no discussions on this subject with a search. Anyone install a ballistic chute on their Piet? Heard of it done? The center section of the wing seems like a descent place to engineer such an installation. Just a curiosity. I am aware that there are those who believe that 'real pilots' don't use BRS, so I'm prepared for some ridicule--hit me. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439491#439491 ________________________________________________________________________________
Date: Mar 17, 2015
Seriously, two stroke reliability has greatly improved with some of the more advanced monitoring systems and improved maintenance. However, it is still not near the reliability of a 4 stroke. If I got a 2 stroke ultralight, I would stay near the landing field and/or only fly over lots of good landing places. Still would be a lot of fun. Blue Skies, Steve D On Tue, Mar 17, 2015 at 2:27 PM, Andy Garrett wrote: > andy_garrett(at)live.com> > > Yea, they don't inspire much confidence Steve! > > Yet, my buddy Paul just crossed 1000 hours TTAF on his Airbike (built in > '97). Two engines (447 then 503), and only one off-field incident due to a > stoppage. I think that would be a Rotax success story wouldn't it? > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439489#439489 > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Mar 17, 2015
No ridicule - just reality. By the time you get a BRS that can safely descend a fully loaded Pietenpol you will have added 30 lbs or more and invested over $5,000 (roughly increasing the cost of your airplane by 33%) for something you hope to never use. A Pietenpol lands so slowly and uses so little real estate that I would rather take my chances flying the plane down "as far into the crash as possible" as Mr. Hoover says, than trusting that a totally non-steerable parachute won't deposit me into power lines or trees. I've had a forced landing in my Pietenpol. I was able to fly it over the lake and forest where the engine failure occurred and make it to the only open space, US Highway 64 west of Raleigh, NC, in the area and land it on the highway after passing over one set of power lines and under another. I doubt if the parachute could have done as well and I would have ended up in the trees (or the powerlines) Not a stupid question, but you've got to look at all the angles. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Andy Garrett Sent: Tuesday, March 17, 2015 3:37 PM Subject: Pietenpol-List: BRS in a Piet? --> Surprisingly, I find no discussions on this subject with a search. Anyone install a ballistic chute on their Piet? Heard of it done? The center section of the wing seems like a descent place to engineer such an installation. Just a curiosity. I am aware that there are those who believe that 'real pilots' don't use BRS, so I'm prepared for some ridicule--hit me. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439491#439491 ________________________________________________________________________________
Subject: Re: BRS in a Piet?
Date: Mar 17, 2015
For the information of the newer members of the List, the archives actually go back to 1996. The current Forum http://forums.matronics.com/viewforum.php?f=7 was started in 2006, and if you execute a search from the Forum, it will only find results from 2006 onwards. However, if you use the old search function http://www.matronics.com/search/ you will get results that are pulled from the very beginning. Performing a search of the Pietenpol List Archives for "BRS", using the old search engine resulted in finding discussions on the matter from January 1999, April 2004 and February 2005. The search also produced a lot of unrelated messages that you will have to weed through. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439495#439495 ________________________________________________________________________________
Date: Mar 17, 2015
I think this search information should be available on the forum for all of us newbies. I never knew this. Why not offer this as an additional search? Thanks, Ray Krause Sent from my iPad > On Mar 17, 2015, at 3:05 PM, Bill Church wrote: > > > For the information of the newer members of the List, the archives actually go back to 1996. The current Forum http://forums.matronics.com/viewforum.php?f=7 was started in 2006, and if you execute a search from the Forum, it will only find results from 2006 onwards. > However, if you use the old search function http://www.matronics.com/search/ you will get results that are pulled from the very beginning. > Performing a search of the Pietenpol List Archives for "BRS", using the old search engine resulted in finding discussions on the matter from January 1999, April 2004 and February 2005. The search also produced a lot of unrelated messages that you will have to weed through. > > Bill C. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439495#439495 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 17, 2015
I was standing there in camouflaged coveralls and I can confirm how cold it was. I think we can nickname Kevin Iron man. -------- Building steel fuselage aircamper. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439501#439501 ________________________________________________________________________________
Date: Mar 18, 2015
Ray, My assumption is that the newer Forum Interface can only access the messages that have been posted since the time that it became operational (almost 9 years ago). Adding all of the previous archives would likely require someone taking the time to (manually?) add all of the archived posts. I sure wouldn't want to be saddled with that task. In any case, the old archived materials are all available, just through a different format. Here's the link to the old information page for the Pietenpol List, with various links to access the archived information. http://www.matronics.com/Navigator/?Pietenpol-List Of course, all of this information is provided in the message at the very top of the Forum page (Official Pietenpol-List FAQ). It just isn't explicitly stated that the newer Forum can only access messages that have been posted after April 2006. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439505#439505 ________________________________________________________________________________
Date: Mar 18, 2015
Is he a Putin wannabe? LOL On Tue, Mar 17, 2015 at 11:24 PM, biplan53 wrote: > > I was standing there in camouflaged coveralls and I can confirm how cold > it was. I think we can nickname Kevin Iron man. > > -------- > Building steel fuselage aircamper. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439501#439501 > > -- Blue Skies, Steve D ________________________________________________________________________________
From: Fastnaught John <fastnaught(at)windstream.net>
Subject: Re: Model A Engine overheat
Date: Mar 18, 2015
Hello good friends and fellow Pieters. My project is finish and inspected. I had my first flight yesterday, what a thrill. Of course there are a few things to address. The most important one is the engine overheat problem. I have overhauled a Model A and it runs great. I have about 10 hours on the engine running it on the ground. I have overhauled and modified the oil pump, drilled the crankshaft for better oiling of the mains and rod bearings (it has bearings not babitts), had the crank balanced, installed stainless valves and seats, and it has a Winfield high compression head. I=99m running a Texas T water pump and have a Forrest Lovely radiator. Hopefully I have covered the installation. At idle or even up to about 1300 RPM=99s the temp remains around 170-190F. At open throttle and after a few minutes the temp climbs to 210-215 and boils over. After 3 trips around the field yesterday it was 220F. Any thoughts or ideas would be greatly appreciated. jack ________________________________________________________________________________
Date: Mar 18, 2015
The current list server is Matronics. what was the older system called? Steve D On Wed, Mar 18, 2015 at 7:45 AM, Bill Church wrote: > billspiet(at)sympatico.ca> > > Ray, > > My assumption is that the newer Forum Interface can only access the > messages that have been posted since the time that it became operational > (almost 9 years ago). Adding all of the previous archives would likely > require someone taking the time to (manually?) add all of the archived > posts. I sure wouldn't want to be saddled with that task. > In any case, the old archived materials are all available, just through a > different format. Here's the link to the old information page for the > Pietenpol List, with various links to access the archived information. > http://www.matronics.com/Navigator/?Pietenpol-List > Of course, all of this information is provided in the message at the very > top of the Forum page (Official Pietenpol-List FAQ). It just isn't > explicitly stated that the newer Forum can only access messages that have > been posted after April 2006. > > Bill C. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439505#439505 > > -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Model A Engine overheat
Date: Mar 18, 2015
Check the timing and/or the flow of coolant thru the system. Bary From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Fastnaught John Sent: Wednesday, March 18, 2015 1:58 PM Subject: Re: Pietenpol-List: Model A Engine overheat Hello good friends and fellow Pieters. My project is finish and inspected. I had my first flight yesterday, what a thrill. Of course there are a few things to address. The most important one is the engine overheat problem. I have overhauled a Model A and it runs great. I have about 10 hours on the engine running it on the ground. I have overhauled and modified the oil pump, drilled the crankshaft for better oiling of the mains and rod bearings (it has bearings not babitts), had the crank balanced, installed stainless valves and seats, and it has a Winfield high compression head. I=99m running a Texas T water pump and have a Forrest Lovely radiator. Hopefully I have covered the installation. At idle or even up to about 1300 RPM=99s the temp remains around 170-190F. At open throttle and after a few minutes the temp climbs to 210-215 and boils over. After 3 trips around the field yesterday it was 220F. Any thoughts or ideas would be greatly appreciated. jack ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Mar 18, 2015
Your plane is beautiful. Now that I have that out of the way. I am not that familiar with the Model A installation. But I am wondering if you have a thermostat or even a flow restrictor like a flat washer or something of the sorts. It sounds to me like the water isn't staying in the radiator long enough to cool. If you have an inferred thermometer you can check the temperature differential between the lower radiator hose and the upper hose. The hot water should leave the bottom of the engine and the cool water should leave the top of the radiator and back into the engine. On the Diesel equipment that I design we look for 30 degree differential between the lower and upper hoses. One other thing to look at is to make sure the water pump is turning the proper direction. I hope this gives you some kind of starting point to work with. Good luck, oh and again. You have a beautiful looking airplane. Cheers, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439513#439513 ________________________________________________________________________________
Date: Mar 18, 2015
My thoughts are that a Pietenpol, properly flown, lands (or crashes) so slow that a BRS would potentially reduce the safety of the aircraft due to the extra weight, pyrotechnics, etc. Build it light and put that effort towards making the fuel system and engine reliable and you will have a safer airplane than you would with a BRS. With a 150' landing area, precisely flown, a Pietenpol could probably be landed without hurting the pilot. WIth a 300' landing area and a little headwind, you can land a Piet without damaging the plane. Check the Pietenpol crash statistics, or read Chuck Gantzer's excellent summary. Very few people die in Piets. Especially in Kansas, where there are more suitable landing areas than non-suitable landing areas. :-) Speaking of Chuck Gantzer, does anyone know what happened to his site (or Chuck himself)? Steve Ruse Aledo, TX (Fort Worth) On Tue, Mar 17, 2015 at 2:37 PM, Andy Garrett wrote: > andy_garrett(at)live.com> > > Surprisingly, I find no discussions on this subject with a search. > > Anyone install a ballistic chute on their Piet? Heard of it done? > > The center section of the wing seems like a descent place to engineer such > an installation. > > Just a curiosity. I am aware that there are those who believe that 'real > pilots' don't use BRS, so I'm prepared for some ridicule--hit me. > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439491#439491 > > ________________________________________________________________________________
Date: Mar 18, 2015
do you have a pressure relief radiator cap or is it direct vent. Jeff martin In a message dated 3/18/2015 2:02:22 P.M. Eastern Daylight Time, fastnaught(at)windstream.net writes: Hello good friends and fellow Pieters. My project is finish and inspected. I had my first flight yesterday, what a thrill. Of course there are a few things to address. The most important one is the engine overheat problem. I have overhauled a Model A and it runs great. I have about 10 hours on the engine running it on the ground. I have overhauled and modified the oil pump, drilled the crankshaft for better oiling of the mains and rod bearings (it has bearing s not babitts), had the crank balanced, installed stainless valves and seats , and it has a Winfield high compression head. I=99m running a Texas T water pump and have a Forrest Lovely radiator. Hopefully I have covered the installation. At idle or even up to about 1300 RPM=99s the temp rem ains around 170-190F. At open throttle and after a few minutes the temp climbs to 210 -215 and boils over. After 3 trips around the field yesterday it was 220F. Any thoughts or ideas would be greatly appreciated. jack ________________________________________________________________________________
Date: Mar 18, 2015
The older system was called Norman. :) But seriously, Steve, did you actually read the posts? All of the links posted are from Matronics. The List server was and is Matronics, since 1998 or so. In 2006, the new interface was introduced, called the Forum. The old interface has continued to operate, in conjunction with the newer interface. The content is the same - just a slightly different format. Bill C. > The current list server is Matronics. what was the older system called? > > > Steve D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439517#439517 ________________________________________________________________________________
Date: Mar 18, 2015
I just read my last post. The tone seems a bit harsh. That wasn't my intent. My apologies, Steve. BC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439518#439518 ________________________________________________________________________________
Subject: Jack's new Piet
Date: Mar 18, 2015
Didn't want to post this in response to Jack Fastnaught's question regarding engine temperatures, since I have no useful information to offer in that regard, so here's a new thread. Beautiful work, Jack. Congratulations! Jack Phillips now has a really good idea what his Piet would look like with a Model A instead of the A-65. "Slight resemblance." More photos, please. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439520#439520 Attachments: http://forums.matronics.com//files/nx144jf_158.jpg http://forums.matronics.com//files/nx899jp_130.jpg ________________________________________________________________________________
Date: Mar 18, 2015
Mike Groah, too. 3 beautiful Piets, all similar, but different somehow...ah, yes, I can see it now, ...(someone got a finish?) Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bill Church Sent: Wednesday, March 18, 2015 2:10 PM Subject: Pietenpol-List: Jack's new Piet --> Didn't want to post this in response to Jack Fastnaught's question regarding engine temperatures, since I have no useful information to offer in that regard, so here's a new thread. Beautiful work, Jack. Congratulations! Jack Phillips now has a really good idea what his Piet would look like with a Model A instead of the A-65. "Slight resemblance." More photos, please. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439520#439520 Attachments: http://forums.matronics.com//files/nx144jf_158.jpg http://forums.matronics.com//files/nx899jp_130.jpg ________________________________________________________________________________
Subject: Frustrating day of study
Date: Mar 18, 2015
Piets flew with Corvairs for 48 years or so before the arrival of the 5th bearing. The search function reveals that some have hypothesized that the later higher performance applications of the Corvair exposed a weakness that the 5th bearing could strengthen--a weakness rarely if ever experienced in Piets. As a $16 per hour hospital security officer trying to 'get into the arena' -Sterling Hayden, and build the airframe which was designed for the 'working man', a few grand for a 5th bearing is steep. Corvairs earned their coveted reputations in Piets, without 5th bearings. Do I need one? Will my TBO be cut in half without one? Will I be forever branded as a 'corner-cutter' in this community? Will I be 'that guy' when I visit Brodhead? Will others snicker behind my back? Does a 4-bearing engine built today represent a bad choice in homebuilding? I just don't want to make a fool of myself as I build an airplane that I can afford with my resources. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439522#439522 ________________________________________________________________________________
Subject: Re: Jack's new Piet
Date: Mar 18, 2015
Both are beautiful! -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439523#439523 ________________________________________________________________________________
Subject: Re: New (Free) Aviation App
Date: Mar 18, 2015
I still get a lot of questions on how to download the Airport Courtesy Cars app on an iPad. So here are some simple instructions on how to do so. The app is approaching 1400 car listings with over 6,400 pilots that have downloaded the app. Glenn Go to the app store on your iPad, Click the search box and search for Airport Courtesy Cars, The search will not show any results, however when the search is complete a bar of menus will appear along the top of the page, The very first one on the left says "Ipad only", Click it to show a drop down menu, Choose "iPhone only" and Airport Courtesy Cars" will be displayed, and you can download the app. -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439529#439529 ________________________________________________________________________________
Date: Mar 18, 2015
Andy, I fully understand the frugal approach. I tend to be that way, naturally...or, I just like doing everything myself. Money was a bit tight when I started, but not so tight that I could not afford to build; but my frugality usually won most arguments. When I started building my engine in 2004, the crankshaft issues hadn't come to light. Well, that's not fair...let's not call them "crankshaft issues," let's just say a better idea came to the forefront. As you say, there have been few issues with Piets. That's not the same as saying there have been no issues. A very good friend of mine, a master auto mechanic, as well as his dad, had a broken crank early in their test flying. He made it down OK, but that's a credit to cool nerves, a good location... and some good luck! That's all it took for me. I ordered the fifth bearing and never regretted it. You have several years to save for that 5th bearing. You need to seriously get in tune with William Wynne, if you wish to continue building a Piet...no matter what engine you choose, but especially if you choose a Corvair. Get on his website and start reading... Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Andy Garrett Sent: Wednesday, March 18, 2015 2:20 PM Subject: Pietenpol-List: Frustrating day of study --> Piets flew with Corvairs for 48 years or so before the arrival of the 5th bearing. The search function reveals that some have hypothesized that the later higher performance applications of the Corvair exposed a weakness that the 5th bearing could strengthen--a weakness rarely if ever experienced in Piets. As a $16 per hour hospital security officer trying to 'get into the arena' -Sterling Hayden, and build the airframe which was designed for the 'working man', a few grand for a 5th bearing is steep. Corvairs earned their coveted reputations in Piets, without 5th bearings. Do I need one? Will my TBO be cut in half without one? Will I be forever branded as a 'corner-cutter' in this community? Will I be 'that guy' when I visit Brodhead? Will others snicker behind my back? Does a 4-bearing engine built today represent a bad choice in homebuilding? I just don't want to make a fool of myself as I build an airplane that I can afford with my resources. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439522#439522 ________________________________________________________________________________
Subject: Re: Frustrating day of study
Date: Mar 18, 2015
Thanks Gary. I've been reading Mr. Wynn's amterial since I began this pursuit--even before. I have the most recent edition of his conversion manual in front of me as I type, and I've been waiting patiently for a DVD for a few weeks. I am inspired by John Franklin's engine build (detailed on Flycorvair.net). He took a frugal approach as well. I guess I'm doing my due dilligence on risk management. I tend to agree that the 5th bearing is indeed a better way of doing things. A better way can almost always be had at the other end of spending spree. The guy with endless resources and motivation will surely find the BEST way. I just want to find acceptable risk and performance without ending up in debt up to my eyeballs. Your response helps a lot. Thanks again. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439558#439558 ________________________________________________________________________________
Date: Mar 18, 2015
Congratulations, Jack! Wonderful feeling, isn=99t it? Nothing like taking off for the first time in an airplane you built yourself. Beautiful job! Jack Phillips NX899JP Smith Mountain Lake, Virginia From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Fastnaught John Sent: Wednesday, March 18, 2015 1:58 PM Subject: Re: Pietenpol-List: Model A Engine overheat Hello good friends and fellow Pieters. My project is finish and inspected. I had my first flight yesterday, what a thrill. Of course there are a few things to address. The most important one is the engine overheat problem. I have overhauled a Model A and it runs great. I have about 10 hours on the engine running it on the ground. I have overhauled and modified the oil pump, drilled the crankshaft for better oiling of the mains and rod bearings (it has bearings not babitts), had the crank balanced, installed stainless valves and seats, and it has a Winfield high compression head. I=99m running a Texas T water pump and have a Forrest Lovely radiator. Hopefully I have covered the installation. At idle or even up to about 1300 RPM=99s the temp remains around 170-190F. At open throttle and after a few minutes the temp climbs to 210-215 and boils over. After 3 trips around the field yesterday it was 220F. Any thoughts or ideas would be greatly appreciated. jack ________________________________________________________________________________
Date: Mar 18, 2015
Andy... I can totally relate to your position!=C2- I too had the same basic thou ghts about the 5th bearing.=C2- I saw a significant cost in adding the be aring and not a lot of evidence that it would be an issue in a Pietenpol. =C2- I thought only guys with the high performance applications would bre ak them.=C2- Well.....I was wrong.=C2- I was flying along straight and level in my Pietenpol when the crank broke into two pieces.=C2- I had 37. 7 flight hours and about 10 ground run hours on the engine. =C2- I got lu cky and just barely made it back to the airport.=C2- I now have a Sport P erformance Aviation Second generation 5th bearing ( https://flywithspa.com/ corvair-5th-bearing/ ).=C2- I was able to learn from my mistake and hopef ully you will too.=C2- While many Pietenpols have successfully flown many hours on Corvair power without a 5th bearing there is now something better that adds a lot of safety and should be considered mandatory, not optional if you plan to fly a Corvair. =C2- There are many other areas in the Pie tenpol build where there are choices that can save money and don't compromi se safety.=C2- If you plan to use a Corvair you need to follow the recomm endations of=C2- William Wynne and add the bearing. I now have another 115 hours +/- since the crank breakage and all is going smoothly.=C2- I now feel comfortable taking my wife, daughter, father, fr iends and students up for flights knowing I've built as much safety into my engine as I know how. =C2-=C2- 150+ hours of Pietenpol flying fun! Mike Groah Tulare CA414MV =C2- From: Andy Garrett <andy_garrett(at)live.com> To: pietenpol-list(at)matronics.com Sent: Wednesday, March 18, 2015 2:20 PM Subject: Pietenpol-List: Frustrating day of study > Piets flew with Corvairs for 48 years or so before the arrival of the 5th b earing. The search function reveals that some have hypothesized that the la ter higher performance applications of the Corvair exposed a weakness that the 5th bearing could strengthen--a weakness rarely if ever experienced in Piets. As a $16 per hour hospital security officer trying to 'get into the arena' -Sterling Hayden, and build the airframe which was designed for the 'workin g man', a few grand for a 5th bearing is steep. Corvairs earned their coveted reputations in Piets, without 5th bearings. D o I need one? Will my TBO be cut in half without one? Will I be forever bra nded as a 'corner-cutter' in this community? Will I be 'that guy' when I vi sit Brodhead? Will others snicker behind my back? Does a 4-bearing engine b uilt today represent a bad choice in homebuilding? I just don't want to make a fool of myself as I build an airplane that I ca n afford with my resources. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439522#439522 S - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Mar 18, 2015
Andy, I'm sure that someone will soon throw the "isn't your life worth the extra $50, $500, $5000, or whatever the amount might be" argument. This is a debate that can go on forever on every piece of material that goes into your project. Why would you use Fir or Poplar when Spruce is just a little more. Isn't your hearing worth a $1200 headset. Why use use non-certified covering. I've had people tell me that I'm a fool for using latex paint on an airplane because each batch is not subject to quality testing.What about a 406 ELT, parachute, helmet, Oakley sunglasses, oxygen, synthetic oil, and on and on. For me it all boils down to dollars or hassle vs risk. If I don't feel that the $1200 headset provides a substantial benefit over the $200 set then I will go with the cheaper one. If I believe that I can substitute Fir for Spruce with only a small weight penalty then I will go with the Fir. Obviously, I went with latex. And I did not go with the 5th bearing on my Corvair believing that It would not be stressed on the Piet like it would be in the KR2s. I'm not flying my Piet yet but I like the track record of Corvair Piets. Should the Engine fail, the wood break, the covering rip off, and I plummet to my doom, I'm sure that will be someome yelling "I told you so you cheap idoit". But I won't be able to hear them because my headset will have made me deaf. Malcolm Morrison www.wienerdogaero.com ----- Original Message ----- From: "Andy Garrett" <andy_garrett(at)live.com> Sent: Wednesday, March 18, 2015 5:20:15 PM Subject: Pietenpol-List: Frustrating day of study Piets flew with Corvairs for 48 years or so before the arrival of the 5th bearing. The search function reveals that some have hypothesized that the later higher performance applications of the Corvair exposed a weakness that the 5th bearing could strengthen--a weakness rarely if ever experienced in Piets. As a $16 per hour hospital security officer trying to 'get into the arena' -Sterling Hayden, and build the airframe which was designed for the 'working man', a few grand for a 5th bearing is steep. Corvairs earned their coveted reputations in Piets, without 5th bearings. Do I need one? Will my TBO be cut in half without one? Will I be forever branded as a 'corner-cutter' in this community? Will I be 'that guy' when I visit Brodhead? Will others snicker behind my back? Does a 4-bearing engine built today represent a bad choice in homebuilding? I just don't want to make a fool of myself as I build an airplane that I can afford with my resources. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439522#439522 ________________________________________________________________________________
Date: Mar 18, 2015
Hi Andy I too worry about the dollar issue. Is it really necesary? I feel that the crank is the spine of your engine. If you look at the price of the build and the engine, is the additional 1200 or so really that much more to throw in the pot? There are ways you can save at least that much by using (for example) a latex finishing system or maybe hemlock instead of spruce. Our lives and the lives of our passengers as well as those on the ground depend upon the reliability of our handy work. Does acceptable risk mean that this is a good place to economize? That is where you have to decide. By the way I plan to use a 110HP WW conversion. This as you know is the middle of HP range. I will not only use the Wessman bearing but a billet crank as well. If I build this e ngine to the best of my ability, with the best internals, I can accept the risk and responsibility to others Glen. Aerial in progress Sent from my iPhone > On Mar 18, 2015, at 3:46 PM, "Andy Garrett" wrote: > > > Thanks Gary. > > I've been reading Mr. Wynn's amterial since I began this pursuit--even before. I have the most recent edition of his conversion manual in front of me as I type, and I've been waiting patiently for a DVD for a few weeks. > > I am inspired by John Franklin's engine build (detailed on Flycorvair.net). He took a frugal approach as well. > > I guess I'm doing my due dilligence on risk management. I tend to agree that the 5th bearing is indeed a better way of doing things. A better way can almost always be had at the other end of spending spree. The guy with endless resources and motivation will surely find the BEST way. I just want to find acceptable risk and performance without ending up in debt up to my eyeballs. > > Your response helps a lot. Thanks again. > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439558#439558 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 18, 2015
Mike, your response is appreciated and somewhat expected. It echos much of the published opinion regarding the 5th bearing. Still..., it's the sweeping statements like "should be considered mandatory" that make me cringe. That means that if I make a different choice then I will indeed be 'that guy'. It's hard to dispute a personal experience like yours, though. May I ask what crank you were using when it broke? Who did the work to it? Still, 48 years of success on who knows how many Piets... That makes me feel vindicated in my hesitance if not my ultimate decision. How many Piets are flying with 5th bearings anyway? How many of each type? What issues have they had if any? Malcom, love your response! Your points are spot on about the endless debate over expenditures. I ran into much of that during my boat build. In fact, that is probably working against me here. I went frugal (not cheap) on pretty much everything with that and have had no problems. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439564#439564 ________________________________________________________________________________
Date: Mar 18, 2015
It's easy to miss some of WW's articles, as he has been prolific, especially on the subject of risk management. Here are 3 appropriate articles worth di gesting. He has certainly modified my approach: http://flycorvair.net/2014/10/31/understanding-flying-corvairs-pt-3-my-way-o r-the-highway/ http://flycorvair.net/2013/04/20/risk-management-judgement-error-money-in-th e-wrong-place/ and http://flycorvair.net/2014/11/13/thought-for-the-day-having-two-achilles-hee ls/ Gary Boothe NX308MB Sent from my iPad > On Mar 18, 2015, at 3:46 PM, Andy Garrett wrote: > m> > > Thanks Gary. > > I've been reading Mr. Wynn's amterial since I began this pursuit--even bef ore. I have the most recent edition of his conversion manual in front of me a s I type, and I've been waiting patiently for a DVD for a few weeks. > > I am inspired by John Franklin's engine build (detailed on Flycorvair.net) . He took a frugal approach as well. > > I guess I'm doing my due dilligence on risk management. I tend to agree th at the 5th bearing is indeed a better way of doing things. A better way can a lmost always be had at the other end of spending spree. The guy with endless resources and motivation will surely find the BEST way. I just want to find acceptable risk and performance without ending up in debt up to my eyeballs . > > Your response helps a lot. Thanks again. > > -------- > Andy Garrett > 'General Purpose Creative Dude' > Haysville, Kansas > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439558#439558 > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Mar 18, 2015
One more thought: Wiseman 5th Bearing is $1050. You have 5 or 6 years (mayb e more) to save up. I don't mean to be blunt, but I don't know how else to s ay it: By your own description you are not a small man. Even without a passe nger you will be demanding maximum performance from the entire plane on ever y take off. Gary Sent from my iPad > On Mar 18, 2015, at 4:50 PM, Gary Boothe wrote: > > It's easy to miss some of WW's articles, as he has been prolific, especial ly on the subject of risk management. Here are 3 appropriate articles worth d igesting. He has certainly modified my approach: > > http://flycorvair.net/2014/10/31/understanding-flying-corvairs-pt-3-my-way -or-the-highway/ > > http://flycorvair.net/2013/04/20/risk-management-judgement-error-money-in- the-wrong-place/ > > and > > http://flycorvair.net/2014/11/13/thought-for-the-day-having-two-achilles-h eels/ > > Gary Boothe > NX308MB > > Sent from my iPad > >> On Mar 18, 2015, at 3:46 PM, Andy Garrett wrote: >> om> >> >> Thanks Gary. >> >> I've been reading Mr. Wynn's amterial since I began this pursuit--even be fore. I have the most recent edition of his conversion manual in front of me as I type, and I've been waiting patiently for a DVD for a few weeks. >> >> I am inspired by John Franklin's engine build (detailed on Flycorvair.net ). He took a frugal approach as well. >> >> I guess I'm doing my due dilligence on risk management. I tend to agree t hat the 5th bearing is indeed a better way of doing things. A better way can almost always be had at the other end of spending spree. The guy with endle ss resources and motivation will surely find the BEST way. I just want to fi nd acceptable risk and performance without ending up in debt up to my eyebal ls. >> >> Your response helps a lot. Thanks again. >> >> -------- >> Andy Garrett >> 'General Purpose Creative Dude' >> Haysville, Kansas >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=439558#439558 >> >> >> >> >> >> <======================== ===================== >> http://www.matronics.com/Navi=============== ========================== ===========; - MATRONICS WEB FORUMS - > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Mar 19, 2015
Andy, Shad Bell here.=C2- We are flying=C2-Dad's Corviar Piet that we f inished in 2006.=C2- We do not have a 5th bearing in ours.=C2- That bei ng said we did have a crank break in flight around the 60 hour mark, with a n induced in flight shutdown, due to severe vibration.=C2- The flight tur ned out uneventful other than landing in a cut wheat field, and a trailer r ide home.=C2- We currently have about 350 hrs on it with no further incid ent.=C2- When it comes time to rebuild the engine I intend to install the 5th bearing.=C2- We probably should have done it at the 60 hour mark but we did not.=C2- After the crank failed and the engine torn down it was v ery evident that the journals were not radius enough, the corners were fair ly sharp in the corners (there were some other findings that were inducing detonation which helped lead to the demise of the 1st crank).=C2- It=C2 -works well like it is but=C2-it defiantly would add piece of mind for me on those choppy days flying around=C2-Chicago enroute to Brodhead. Feel Free to contact me offline if you want more details. Shad Bellaviatorbell(at)yahoo.com=C2-=C2- On Wednesday, March 18, 2015 7:57 PM, Gary Boothe wrote: It's easy to miss some of WW's articles, as he has been prolific, especial ly on the subject of risk management. Here are 3 appropriate articles worth digesting. He has certainly modified my approach: http://flycorvair.net/2014/10/31/understanding-flying-corvairs-pt-3-my-way- or-the-highway/=C2- http://flycorvair.net/2013/04/20/risk-management-judgement-error-money-in-t he-wrong-place/=C2-=C2-and=C2-http://flycorvair.net/2014/11/13/though t-for-the-day-having-two-achilles-heels/=C2- Gary BootheNX308MB Sent from my iPad On Mar 18, 2015, at 3:46 PM, Andy Garrett wrote: > Thanks Gary. I've been reading Mr. Wynn's amterial since I began this pursuit--even befo re. I have the most recent edition of his conversion manual in front of me as I type, and I've been waiting patiently for a DVD for a few weeks. I am inspired by John Franklin's engine build (detailed on Flycorvair.net). He took a frugal approach as well. I guess I'm doing my due dilligence on risk management. I tend to agree tha t the 5th bearing is indeed a better way of doing things. A better way can almost always be had at the other end of spending spree. The guy with endle ss resources and motivation will surely find the BEST way. I just want to f ind acceptable risk and performance without ending up in debt up to my eyeb alls. Your response helps a lot. Thanks again. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439558#439558 <======================== ===================== http://www.matronics.com/Navi=============== ============;=C2-=C2-=C2-=C2-=C2-=C2- =C2-- MATRONICS WEB FORUMS - ________________________________________________________________________________
Date: Mar 19, 2015
To answer your question I was using a Chevrolet crank that had been magnafl uxed, machined and nitrided by the provider recommended by WW.=C2- I felt at the time this gave me the best possible non-5th bearing crank.=C2- It really sounds like you've already decided not to use a 5th bearing but I really do urge you to reconsider.=C2- As Gary mentioned it will be some time before you need that part and you can save up the cash.=C2- It took me four and a half years to finish my plane.=C2- Lets say you go with the $1100 retrofit 5th bearing as Gary did and you need it in three years.=C2 - That's only about $30 a month you'll need to save.=C2- Leave out the coffee, 32 oz from the mini mart or be the DD instead of having a beer when out with the guys.=C2- The sacrafice will be no fun but flying your own Pietenpol without having to worry about the crank will be. From: Andy Garrett <andy_garrett(at)live.com> To: pietenpol-list(at)matronics.com Sent: Wednesday, March 18, 2015 4:49 PM Subject: Pietenpol-List: Re: Frustrating day of study > Mike, your response is appreciated and somewhat expected. It echos much of the published opinion regarding the 5th bearing. Still..., it's the sweepin g statements like "should be considered mandatory" that make me cringe. Tha t means that if I make a different choice then I will indeed be 'that guy'. It's hard to dispute a personal experience like yours, though. May I ask w hat crank you were using when it broke? Who did the work to it? Still, 48 years of success on who knows how many Piets... That makes me fee l vindicated in my hesitance if not my ultimate decision. How many Piets ar e flying with 5th bearings anyway? How many of each type? What issues have they had if any? Malcom, love your response! Your points are spot on about the endless debat e over expenditures. I ran into much of that during my boat build. In fact, that is probably working against me here. I went frugal (not cheap) on pre tty much everything with that and have had no problems. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439564#439564 S - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Mar 19, 2015
Date: Mar 18, 2015
Andy, at the risk of being shot at, Here is a rough recap of a study I did of the Pietenpol accidents in the FAA database since 1969. *I reviewed the NTSB list of accidents for Pietenpol type aircraft (note there appear to be some Grega included.) and **looked at the **contributing causes. Please note there were several cases where there were multiple causes for the accident, So some accidents have been put into two categories, IE airspeed INOP and Stall spin, * *=EF=BD* * The largest group was Stall/Spin with 16 cases. Here are the situations described: **=EF=BD* * 1 steep turns at 500 ft. 1 in pattern (unauthorized use of plane, 0 hours in type) 2 Low pass first flight 1 loss of power, first flight low turn 1 airspeed INOP, first flight in 6 years, 1 on climbout, DEMO FLIGHT 4 on climbout (1 fatal) 1 Low turns 2. on final one instruments INOP, one Loss of power. 1 aerobatics 1 distracted by loose spark plug, loss of power * * This is far from scientific, but to prod discussion.* *The stall/ spin accients seem to come from * * 4 stalls due to low time in Piet/first flight/rusty The only thing that could be done about Low time/first flight/rusty is make sure you are ready. I am going to get 2 or 3 hours in a Piper Cub in a couple of weeks. Then I will mooch rides with a buddy in his Champ until I fly my Piet. DON'T do what some of these guys did. They spent time building a plane and not flying. 4 or 5 stalls invovled distraction due to Loss of power/running rough, Demo flight, or instruments INOP As far as distraction, Fly the plane! Even when the engine is running rough. Make sure it is airworthy (Instruments work) and FLY THE PLANE. 3 stalls during Maneuvering flight. pattern work, Steep turns, Low passes and aerobatics. Keep your speed up, Lest the ground rise up and smite thee!* *Among Engine problems causing crashes the main areas are: * * Mechanical problem 1 Carb needle stuck, 1 Fuel vent blocked-starvation (wasp nest) 1 Mag problem 1 Loose sparkplug A Good preflight would have stopped at least two of these. The pilot usually did not "Fly the plane as far into the crash as possible" Otherwise easy landings were screwed up. Pilot head up and locked. 1 Carb ice 3 ran out of fuel (Landed OK then crashed on takeoff) Uh don't take off without gas and Use your carb heat, Especially if the charts say you are in the icing zone. Today is 90degrees and humid Here in SA. Good day for ice. 1 unexplained power loss I think the pilot should be forced to explain the power loss! Actually the pilot/owners of this plane would not talk to the FAA and the FAA never did figure out who was flying.* *OF 9 Stall/Spin accidents only 1 was fatal. a testimony of the design. BTW this data was collected starting in 1969. The only Non engine mechanical incidents in the database are: a broken wire due to a improperly installed turnbuckle. Two incidences of Push/pull elevator control system failures (On a Grega?) that resulted in two fatalities. and one hard landing where a bad weld allowed the gear to collapse. * *One older Pieter recalled a fatality from structural failure in the mid 1960's that was most likely due to negative Gs and no jury struts. * *Over half of these events happened down low, not up higher. **since the BRS requires at least 300 feet to deploy that lowers the investment on return. Also The BRS deploys as much from airspeed as altitude. Not much airspeed on a Piet.* *Blue Skies,* *Steve D* On Wed, Mar 18, 2015 at 3:09 PM, Steve Ruse wrote: > My thoughts are that a Pietenpol, properly flown, lands (or crashes) so > slow that a BRS would potentially reduce the safety of the aircraft due t o > the extra weight, pyrotechnics, etc. Build it light and put that effort > towards making the fuel system and engine reliable and you will have a > safer airplane than you would with a BRS. With a 150' landing area, > precisely flown, a Pietenpol could probably be landed without hurting the > pilot. WIth a 300' landing area and a little headwind, you can land a Pi et > without damaging the plane. > > Check the Pietenpol crash statistics, or read Chuck Gantzer's excellent > summary. Very few people die in Piets. Especially in Kansas, where ther e > are more suitable landing areas than non-suitable landing areas. :-) > > Speaking of Chuck Gantzer, does anyone know what happened to his site (or > Chuck himself)? > > Steve Ruse > Aledo, TX (Fort Worth) > > On Tue, Mar 17, 2015 at 2:37 PM, Andy Garrett > wrote: > >> andy_garrett(at)live.com> >> >> Surprisingly, I find no discussions on this subject with a search. >> >> Anyone install a ballistic chute on their Piet? Heard of it done? >> >> The center section of the wing seems like a descent place to engineer >> such an installation. >> >> Just a curiosity. I am aware that there are those who believe that 'real >> pilots' don't use BRS, so I'm prepared for some ridicule--hit me. >> >> -------- >> Andy Garrett >> 'General Purpose Creative Dude' >> Haysville, Kansas >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=439491#439491 >> >> >> >> >> >> >> >> ========== >> br> enpol-List" target="_blank"> >> http://www.matronics.com/Navigator?Pietenpol-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > =========== .matronics.com/Navigator?Pietenpol-List> =========== =========== om/contribution> =========== > > * > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Mar 18, 2015
Bill, I did read the posts, but simply missed that they were all called matronics. I was afraid that I was missing some good information. Blue Skies, Steve D On Wed, Mar 18, 2015 at 3:38 PM, Bill Church wrote: > billspiet(at)sympatico.ca> > > The older system was called Norman. :) > > But seriously, Steve, did you actually read the posts? > All of the links posted are from Matronics. The List server was and is > Matronics, since 1998 or so. In 2006, the new interface was introduced, > called the Forum. The old interface has continued to operate, in > conjunction with the newer interface. The content is the same - just a > slightly different format. > > Bill C. > > > > The current list server is Matronics. what was the older system called? > > > > > > Steve D > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439517#439517 > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Mar 18, 2015
Thanks, Bill. Ray Sent from my iPad > On Mar 18, 2015, at 5:45 AM, Bill Church wrote: > > > Ray, > > My assumption is that the newer Forum Interface can only access the messages that have been posted since the time that it became operational (almost 9 years ago). Adding all of the previous archives would likely require someone taking the time to (manually?) add all of the archived posts. I sure wouldn't want to be saddled with that task. > In any case, the old archived materials are all available, just through a different
February 24, 2015 - March 18, 2015
Pietenpol-Archive.digest.vol-ob
