Pietenpol-Archive.digest.vol-ou
September 11, 2015 - September 26, 2015
      I understand that the alcohol can freeze in the tank and lines, but I don't
      think that is an issue with our type of low and slow flying.
      The other problem I've heard about is "vapor lock".  What exactly is this
      and why aren't cars lining the sides of the roads because of vapor lock?
      Douwe
Subject: Re: Ethanol
Date: Sep 11, 2015
Douwe Cars have the fuel pump in the tank with a lot of pressure not gravity fed. Ethanol fuel will asorb water not what you want in the tank. Dale ----- Original Message ----- From: Douwe Blumberg To: pietenpol-list(at)matronics.com Sent: Friday, September 11, 2015 8:32 AM Subject: Pietenpol-List: Ethanol Hey all, Would anybody truly "in the know" help me understand why ethanol fuel is considered a "no-no" in our type of airplane? I understand that the alcohol can freeze in the tank and lines, but I don 't think that is an issue with our type of low and slow flying. The other problem I've heard about is "vapor lock". What exactly is this and why aren't cars lining the sides of the roads because of vapor lock? Thanks, Douwe --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Sep 11, 2015
Ethanol, as I understand it, will also eat rubber fuel lines and gaskets if they are not ethanol-compatible. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=446992#446992 ________________________________________________________________________________
Date: Sep 11, 2015
Douwe Let me share one first hand experience that will illustrate how this could bite some one. Years ago I was putting auto fuel in my wife's C-85 powered Taylorcraft. The next day it seemed like the cork and wire fuel gauge was lower than expected. Inspection shows that the fuel actually had 10% ethanol in it. The Cork on the wire was attacked by the ethanol content in 4 gallons of gas, left in the tank overnight. The bits of cork were floating on the fuel, but some of the reaction was laying in the gascolater. This shows that 100% of your fuel system must be ethanol proof is you are ever to use any fuel other than 100LL. I am not sure you can count on auto fuel having zero ethanol even when it says so. Thus everything, down to the gas cap gasket, the float, the gasket on the bowl of your gascolater, the O-rings in your fuel valve, and your lines and carb, must be tolerant of ethanol if you consider car gas. Car systems have ZERO to do with plane systems. Modern EFI cars, as pointed out are immune to vapor lock because they hold the fuel at pressure in the system, and it is circulated for cooling. Their tanks are 100% sealed and not vented, and they don't absorb h2o for this reason. The systems and function are so different that it is very bad logic to make any conclusion about ethanol in planes based on car experience. Alcohol effectively will not freeze at flying temps, it was added to the ADI water injection on piston airliners for that reason. The issue is that it is hydroscopic, and this is a factor in planes with vented fuel systems and long periods of inactivity. Vapor pressure on car fuel is very different, and this contributes both to the potential of carb ice and to vapor lock For those that have not seen it, my wife wrote this story 15 years ago, it has been reprinted many times, but it is still very valid today: http://www.flycorvair.com/carbice.html -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=446993#446993 ________________________________________________________________________________
Date: Sep 11, 2015
Yes, it is so. Fortunately, I experienced with old tractor, not my Piet. I DO run 87 octane mogas, but 'tis ethanol free. No problems, yet. 100LL does dirty up the fuse way more than the mogas. -Zeke GN-1 w/C-85-12 On Fri, Sep 11, 2015 at 10:06 AM, jarheadpilot82 wrote: > jarheadpilot82(at)hotmail.com> > > Ethanol, as I understand it, will also eat rubber fuel lines and gaskets > if they are not ethanol-compatible. > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=446992#446992 > > ________________________________________________________________________________
Date: Sep 11, 2015
Terry is right, I know. It's that the ethanol will destroy o-rings, seals in your carb. On Fri, Sep 11, 2015 at 9:32 AM, Douwe Blumberg wrote: > Hey all, > > > Would anybody truly =9Cin the know=9D help me understand why ethanol fuel is > considered a =9Cno-no=9D in our type of airplane? > > > I understand that the alcohol can freeze in the tank and lines, but I > don=99t think that is an issue with our type of low and slow flying . > > > The other problem I=99ve heard about is =9Cvapor lock =9D. What exactly is this > and why aren=99t cars lining the sides of the roads because of vapo r lock? > > > Thanks, > > > Douwe > > * > =========== .matronics.com/Navigator?Pietenpol-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Sep 11, 2015
for Continental engines the ethanol will deteriorate the seals inside our carbs. not sure about Model As, corvairs or other engines. Water absorbed into the ethanol is a big problem. Also vapor lock at his altitude (may not be an issue for us, as you mentioned.) Blue skies, Steve D On Fri, Sep 11, 2015 at 8:32 AM, Douwe Blumberg wrote: > Hey all, > > > Would anybody truly =9Cin the know=9D help me understand why ethanol fuel is > considered a =9Cno-no=9D in our type of airplane? > > > I understand that the alcohol can freeze in the tank and lines, but I > don=99t think that is an issue with our type of low and slow flying . > > > The other problem I=99ve heard about is =9Cvapor lock =9D. What exactly is this > and why aren=99t cars lining the sides of the roads because of vapo r lock? > > > Thanks, > > > Douwe > > * > =========== .matronics.com/Navigator?Pietenpol-List> =========== =========== om/contribution> =========== > > * > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Sep 11, 2015
Interestingly you can "wash" ethanol out of your gas by adding water! Seriously, that is a way to remove alcohol. Basic technique is to put in enough water to bond with the alcohol. then shake or stir the fuel to get it to bond. Then let it sit so that the water/alcohol mixture settles to the bottom and drain it off. Now you have ethanol free gas. You may want to test it for ethanol and for octane. Alcohol raises the octane. So removing it will drop octane. It may still be high enough. Blue Skies, Steve D On Fri, Sep 11, 2015 at 9:06 AM, jarheadpilot82 wrote: > jarheadpilot82(at)hotmail.com> > > Ethanol, as I understand it, will also eat rubber fuel lines and gaskets > if they are not ethanol-compatible. > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=446992#446992 > > -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Re: The quiet after a good day in the shop.....
Date: Sep 11, 2015
It is great to see someone else that appreciates the quietness of your work shop.. I suppose it is a mixed blessing that hardly anyone ever comes to my shop . Maybe it is because it is hidden behind my house in the corner of my yard. True I would love to see people who appreciate this little airplane and the effort it takes to build one . I do love the build that is so true, but my goal is to fly it and not spend years on this project. Who knows I might have another project in mind! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447009#447009 ________________________________________________________________________________
Subject: Re: The 'Piet Builder's Bible' Project - Want In?
Date: Sep 11, 2015
Jim, Have you ever read any of Tracy Kidder's books? If he were to build a Piet and write about the experience it would be a classic, at least amongst airplane folks. It would also generate interest in home building and aviation, I suspect, with people who formally might not had an interest in that sort of thing. If you have not read him you might give him a try. It may give you some ideas for what you are trying to do. His book titled House would be a good one to start with. Doug Wright Stillwater, OK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447010#447010 ________________________________________________________________________________
Date: Sep 11, 2015
Subject: Hybrid Bernard Swing Arm Steerable Tailwheel
Pieters, =C2- =C2- =C2-Are there any good plans or details out there for a com bination Bernard swing arm/steerable tailwheel? I really don't want to rein vent the (tail) wheel if someone has a good design that works. May be a goo d column for the newsletter if there's not one already... Ryan ________________________________________________________________________________
Date: Sep 11, 2015
I applaud builders like yourself who make progress quicker/more effectively and are not so focused on a serene workshop - well done...! So neat that this "building an airplane" thing can be done is so many different ways. One important aspect for me is keeping my neighbors from being worried/concerned that I am building an airplane - since my shop is in the garage of my condo and there are people living above these garages..... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447014#447014 ________________________________________________________________________________
Date: Sep 11, 2015
Doug, how far along are you on your post? I am based at Enid, OK (my piet is in San Antonio.) Steve D On Sep 11, 2015 4:52 PM, "DonkDoug" wrote: > douglas.wright(at)okstate.edu> > > Jim, > > Have you ever read any of Tracy Kidder's books? If he were to build a > Piet and write about the experience it would be a classic, at least amongst > airplane folks. It would also generate interest in home building and > aviation, I suspect, with people who formally might not had an interest in > that sort of thing. > > If you have not read him you might give him a try. It may give you some > ideas for what you are trying to do. His book titled House would be a good > one to start with. > > Doug Wright > Stillwater, OK > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447010#447010 > > ________________________________________________________________________________
Subject: Re: Hybrid Bernard Swing Arm Steerable Tailwheel
Date: Sep 12, 2015
Westcoastpiet has lot of pictures to use in making your tailwheel -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447023#447023 ________________________________________________________________________________
Date: Sep 12, 2015
Douwe; while I don't claim to be "in the know", as a fire protection engineer I do have some knowledge of fuels and I can read a table of physical properties of fuels. Strictly from the "fuel as energy" standpoint, ethanol has an energy content of about 11,590 Btu per lb and gasoline (including 100LL avgas) has an energy content of about 18,700 Btu per lb. This means when you're burning a blend of gasoline and ethanol, you're leaving some power on the table. Here in Oregon, regulations mandate the sale of "E10" in some areas of the state and at certain times of the year. This is a blend of 90% gasoline and 10% ethanol and it results in a fuel with somewhere between 3% and 4% less energy than straight gas. To put it in practical terms, but greatly oversimplifying, your engine that produces 100HP running on avgas will only produce 96-97HP on E10 mogas. Granted, the E10 will cost quite a bit less and that's the attraction of it. As you've read from other posts here, there are downsides and one of them is the fact that ethanol is incompatible with a lot of materials. Another downside is the potential for vapor lock. Ethanol has a lower boiling point than straight gasoline, so it is less tolerant of high temperatures under the cowling and it can vaporize in the fuel lines or anywhere it's close to a hot surface. A vapor pocket or bubble in the fuel system can stop the flow of fuel... "vapor lock". The problem is increased in the summer, of course, because when we land with a nice warmed-up engine and taxi over to the fuel pump and shut down, the areas inside the cowling become heat-soaked and since there is no flow of cooler fuel in the lines when the engine is shut down, the fuel can vaporize and lock the system, making startup more difficult. The reason why you don't see cars sitting all over the shoulders of the road with vapor lock is because most vehicles now are fuel injected or they have fuel pumps that deliver the fuel under pressure, not gravity, and the boiling point of a liquid increases as the pressure increases. You know this from your camping experiences when you try to boil water while camping up in the mountains. It boils at a lower temperature up where the atmospheric pressure is lower, and your beans never cook! Of course this same effect means that flying at higher altitudes lowers the boiling point of fuel that contains ethanol, but most Piets fly down pretty low where that isn't a big factor. More than you wanted to know, I'm sure ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447027#447027 ________________________________________________________________________________
Date: Sep 12, 2015
Steve, I have been "washing" Ethanol from gasoline and burning it in my old Bonanza for years. It's a simple process and requires patience. I determine how much ethanol is in the fuel, then add enough water to produce a 50/50 mixture of water and alcohol. I process 45 gallons at a time as my cone shaped tank only holds 50 gallons. The yield is 40 gallons of Ethanol free gasoline, if the gas contains 10% Ethanol. You loose about 3 octane points when the ethanol is removed. Right now in NJ, avgas is $5.35/ gallon and regular gas is $1.98. My finished product cost is about $2.20/ gallon and I burn about 12 gallons per hour. $58.50/ hour v.s. $24.20. Stu Sent from my iPad ________________________________________________________________________________
Date: Sep 12, 2015
By the way, I love your shop and your building style.... My next door neighbor's bed room window is pretty close to my small shop. I have to pace myself on those nights when I can't sleep and I am up at 3:30 4:00 AM. I want to work in the shop, but my power tools are too noisy and hammering is also a problem, so I have to find something quiet to work on. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447035#447035 ________________________________________________________________________________
Date: Sep 12, 2015
Great Read. John Cox Aurora, OR On Sep 12, 2015 11:10, "taildrags" wrote: > > Douwe; while I don't claim to be "in the know", as a fire protection > engineer I do have some knowledge of fuels and I can read a table of > physical properties of fuels. Strictly from the "fuel as energy" > standpoint, ethanol has an energy content of about 11,590 Btu per lb and > gasoline (including 100LL avgas) has an energy content of about 18,700 Btu > per lb. This means when you're burning a blend of gasoline and ethanol, > you're leaving some power on the table. Here in Oregon, regulations > mandate the sale of "E10" in some areas of the state and at certain times > of the year. This is a blend of 90% gasoline and 10% ethanol and it > results in a fuel with somewhere between 3% and 4% less energy than > straight gas. To put it in practical terms, but greatly oversimplifying, > your engine that produces 100HP running on avgas will only produce 96-97HP > on E10 mogas. Granted, the E10 will cost quite a bit less and that's the > attraction of it. As you've read from other posts here, ther! > e are downsides and one of them is the fact that ethanol is incompatible > with a lot of materials. > > Another downside is the potential for vapor lock. Ethanol has a lower > boiling point than straight gasoline, so it is less tolerant of high > temperatures under the cowling and it can vaporize in the fuel lines or > anywhere it's close to a hot surface. A vapor pocket or bubble in the fuel > system can stop the flow of fuel... "vapor lock". The problem is increased > in the summer, of course, because when we land with a nice warmed-up engine > and taxi over to the fuel pump and shut down, the areas inside the cowling > become heat-soaked and since there is no flow of cooler fuel in the lines > when the engine is shut down, the fuel can vaporize and lock the system, > making startup more difficult. > > The reason why you don't see cars sitting all over the shoulders of the > road with vapor lock is because most vehicles now are fuel injected or they > have fuel pumps that deliver the fuel under pressure, not gravity, and the > boiling point of a liquid increases as the pressure increases. You know > this from your camping experiences when you try to boil water while camping > up in the mountains. It boils at a lower temperature up where the > atmospheric pressure is lower, and your beans never cook! Of course this > same effect means that flying at higher altitudes lowers the boiling point > of fuel that contains ethanol, but most Piets fly down pretty low where > that isn't a big factor. More than you wanted to know, I'm sure ;o) > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447027#447027 > > ________________________________________________________________________________
Date: Sep 12, 2015
I'm assuming you have Two Years Before The Mast and Voyage of the Cachalot? This message is Piet related because there are wings and control cables involved. Clif Life is uncertain. Eat dessert first. > > Clif: thank you for the book recommendations. I've always wanted to learn > how to sail and "The Craft of Sail" sounds like a wonderful addition to my > reading stack for this fall and winter! I'll nestle it in between > Hornblower and Aubrey & Maturin books ;o) > Oscar Zuniga ________________________________________________________________________________
Date: Sep 13, 2015
Clif; of course I have "Two Years Before the Mast", but I have not read Bullen's "The Cruise of the Cachalot". I see that it's available as a free download e-book, so I'll download it. Thanks for letting me know, since I really enjoy good books about the days of sail and tall ships. Other than perhaps the word 'cruise', there is nothing Piet related in this post so I've changed the subject line and noted that it's Off Topic. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447043#447043 ________________________________________________________________________________
Subject: Ethanol
Date: Sep 14, 2015
Thanks everybody for your input, William, your info was very informative. I appreciate it. Douwe ________________________________________________________________________________
Subject: hybrid Bernard swing arm steerable tailwheel
Date: Sep 14, 2015
Hi Ryan, Here's what I did. 3 years of use and I'm really happy with it. You can use any sized wheel you like, everyone tells me this one is too small; that it won't track well and will wear out. Works great for me. bought a bag of ten from McMaster and change it out every season. Regardless of the wheel sized, I think the design is a bit more robust than some I"ve seen. DO add a cross bar or even a couple diagonals in the "V" since the turning wheel now introduces some twisting loads it wasn't designed for. Douwe From: Ryan M <aircamperace(at)yahoo.com> Subject: Pietenpol-List: Hybrid Bernard Swing Arm Steerable Tailwheel Pieters, =C2- =C2- =C2-Are there any good plans or details out there for a com bination Bernard swing arm/steerable tailwheel? I really don't want to rein vent the (tail) wheel if someone has a good design that works. May be a goo d column for the newsletter if there's not one already... Ryan ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Subject: Re: hybrid Bernard swing arm steerable tailwheel
Date: Sep 14, 2015
VEhBVCBpcyBhIHJlYWxseSBjb29sIHRhaWx3aGVlbCBkZXNpZ24gYW5kIGV4ZWN1dGlvbiENCg0K LS0NCkplZmZyZXkgSC4gQm9hdHJpZ2h0LCBQaEQsIEZBUlZPDQpQcm9mZXNzb3Igb2YgT3BodGhh bG1vbG9neQ0KRW1vcnkgVW5pdmVyc2l0eSBTY2hvb2wgb2YgTWVkaWNpbmUNCg0KRnJvbTogRG91 d2UgQmx1bWJlcmcgPGRvdXdlQGRvdXdlc3R1ZGlvcy5jb208bWFpbHRvOmRvdXdlQGRvdXdlc3R1 ZGlvcy5jb20+Pg0KUmVwbHktVG86ICJwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPG1haWx0 bzpwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPiIgPHBpZXRlbnBvbC1saXN0QG1hdHJvbmlj cy5jb208bWFpbHRvOnBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20+Pg0KRGF0ZTogTW9uZGF5 LCBTZXB0ZW1iZXIgMTQsIDIwMTUgYXQgOTo0OSBBTQ0KVG86ICJwaWV0ZW5wb2wtbGlzdEBtYXRy b25pY3MuY29tPG1haWx0bzpwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPiIgPHBpZXRlbnBv bC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20+ Pg0KU3ViamVjdDogUGlldGVucG9sLUxpc3Q6IGh5YnJpZCBCZXJuYXJkIHN3aW5nIGFybSBzdGVl cmFibGUgdGFpbHdoZWVsDQoNCg0KSGkgUnlhbiwNCg0KDQoNCkhlcmXigJlzIHdoYXQgSSBkaWQu ICAzIHllYXJzIG9mIHVzZSBhbmQgSeKAmW0gcmVhbGx5IGhhcHB5IHdpdGggaXQuIFlvdSBjYW4g dXNlIGFueSBzaXplZCB3aGVlbCB5b3UgbGlrZSwgZXZlcnlvbmUgdGVsbHMgbWUgdGhpcyBvbmUg aXMgdG9vIHNtYWxsOyB0aGF0IGl0IHdvbuKAmXQgdHJhY2sgd2VsbCBhbmQgd2lsbCB3ZWFyIG91 dC4gIFdvcmtzIGdyZWF0IGZvciBtZS4gIGJvdWdodCBhIGJhZyBvZiB0ZW4gZnJvbSBNY01hc3Rl ciBhbmQgY2hhbmdlIGl0IG91dCBldmVyeSBzZWFzb24uICBSZWdhcmRsZXNzIG9mIHRoZSB3aGVl bCBzaXplZCwgSSB0aGluayB0aGUgZGVzaWduIGlzIGEgYml0IG1vcmUgcm9idXN0IHRoYW4gc29t ZSBJ4oCddmUgc2Vlbi4NCg0KDQoNCkRPIGFkZCBhIGNyb3NzIGJhciBvciBldmVuIGEgY291cGxl IGRpYWdvbmFscyBpbiB0aGUg4oCcVuKAnSBzaW5jZSB0aGUgdHVybmluZyB3aGVlbCBub3cgaW50 cm9kdWNlcyBzb21lIHR3aXN0aW5nIGxvYWRzIGl0IHdhc27igJl0IGRlc2lnbmVkIGZvci4NCg0K DQoNCkRvdXdlDQoNCg0KDQpUaW1lOiAwNDowMjo1OCBQTSBQU1QgVVMNCg0KRnJvbTogUnlhbiBN IDxhaXJjYW1wZXJhY2VAeWFob28uY29tPG1haWx0bzphaXJjYW1wZXJhY2VAeWFob28uY29tPj4N Cg0KU3ViamVjdDogUGlldGVucG9sLUxpc3Q6IEh5YnJpZCBCZXJuYXJkIFN3aW5nIEFybSBTdGVl cmFibGUgVGFpbHdoZWVsDQoNCg0KDQpQaWV0ZXJzLA0KDQo9QzItID1DMi0gPUMyLUFyZSB0aGVy ZSBhbnkgZ29vZCBwbGFucyBvciBkZXRhaWxzIG91dCB0aGVyZSBmb3IgYSBjb20gYmluYXRpb24g QmVybmFyZCBzd2luZyBhcm0vc3RlZXJhYmxlIHRhaWx3aGVlbD8gSSByZWFsbHkgZG9uJ3Qgd2Fu dCB0byByZWluIHZlbnQgdGhlICh0YWlsKSB3aGVlbCBpZiBzb21lb25lIGhhcyBhIGdvb2QgZGVz aWduIHRoYXQgd29ya3MuIE1heSBiZSBhIGdvbyBkIGNvbHVtbiBmb3IgdGhlIG5ld3NsZXR0ZXIg aWYgdGhlcmUncyBub3Qgb25lIGFscmVhZHkuLi4NCg0KUnlhbg0KDQoNCl9fX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fDQoNClRoaXMgZS1tYWlsIG1lc3NhZ2UgKGluY2x1ZGluZyBhbnkg YXR0YWNobWVudHMpIGlzIGZvciB0aGUgc29sZSB1c2Ugb2YNCnRoZSBpbnRlbmRlZCByZWNpcGll bnQocykgYW5kIG1heSBjb250YWluIGNvbmZpZGVudGlhbCBhbmQgcHJpdmlsZWdlZA0KaW5mb3Jt YXRpb24uIElmIHRoZSByZWFkZXIgb2YgdGhpcyBtZXNzYWdlIGlzIG5vdCB0aGUgaW50ZW5kZWQN CnJlY2lwaWVudCwgeW91IGFyZSBoZXJlYnkgbm90aWZpZWQgdGhhdCBhbnkgZGlzc2VtaW5hdGlv biwgZGlzdHJpYnV0aW9uDQpvciBjb3B5aW5nIG9mIHRoaXMgbWVzc2FnZSAoaW5jbHVkaW5nIGFu eSBhdHRhY2htZW50cykgaXMgc3RyaWN0bHkNCnByb2hpYml0ZWQuDQoNCklmIHlvdSBoYXZlIHJl Y2VpdmVkIHRoaXMgbWVzc2FnZSBpbiBlcnJvciwgcGxlYXNlIGNvbnRhY3QNCnRoZSBzZW5kZXIg YnkgcmVwbHkgZS1tYWlsIG1lc3NhZ2UgYW5kIGRlc3Ryb3kgYWxsIGNvcGllcyBvZiB0aGUNCm9y aWdpbmFsIG1lc3NhZ2UgKGluY2x1ZGluZyBhdHRhY2htZW50cykuDQo ________________________________________________________________________________
Subject: best wood for capstrips
Date: Sep 14, 2015
Hey all, For those of you with lots of experience, what are some of the best and most available woods for rib capstrips? Douwe ________________________________________________________________________________
Subject: Re: best wood for capstrips
Date: Sep 14, 2015
Other than spruce? I used Poplar. Sent from my iPhone > On Sep 14, 2015, at 11:29 AM, Douwe Blumberg wrot e: > > Hey all, > > For those of you with lots of experience, what are some of the best and mo st available woods for rib capstrips? > > Douwe > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Sep 14, 2015
Douwe Cedar Dale ----- Original Message ----- From: Douwe Blumberg To: pietenpol-list(at)matronics.com Sent: Monday, September 14, 2015 1:29 PM Subject: Pietenpol-List: best wood for capstrips Hey all, For those of you with lots of experience, what are some of the best and m ost available woods for rib capstrips? Douwe --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 14, 2015
AC 43.13 -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447064#447064 Attachments: http://forums.matronics.com//files/screen_shot_2015_09_14_at_114527_am_510.png ________________________________________________________________________________
Subject: Re: Fuel tank progress/welding.....
Date: Sep 15, 2015
Did you use 5000 series aluminum or 6000 series for the tank? Filler rod 4043 or 5365 for the welds seams? Just curious, WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447081#447081 ________________________________________________________________________________
Date: Sep 15, 2015
Oscar-- I had heard that ethanol only degraded fuel mileage (the only thing I am re ally interested in for my pickup) a relatively small amount--but someone in my Model A club said it was a bigger deal than I thought. So I ran a test- -a thousand miles each with E10 gas vs non-ethanol high test gas. And I got 26% BETTER mileage with the non-alcohol gas. So now whenever I can get non -alcohol gas for less than about a 25% price premium, I get that. Cheers, Mac in Newport From: "John Cox" <rv10pro(at)gmail.com> Sent: Saturday, September 12, 2015 8:30:13 PM Subject: Re: Pietenpol-List: Re: Ethanol Great Read. John Cox Aurora, OR On Sep 12, 2015 11:10, "taildrags" < taildrags(at)hotmail.com > wrote: Douwe; while I don't claim to be "in the know", as a fire protection engine er I do have some knowledge of fuels and I can read a table of physical pro perties of fuels. Strictly from the "fuel as energy" standpoint, ethanol ha s an energy content of about 11,590 Btu per lb and gasoline (including 100L L avgas) has an energy content of about 18,700 Btu per lb. This means when you're burning a blend of gasoline and ethanol, you're leaving some power o n the table. Here in Oregon, regulations mandate the sale of "E10" in some areas of the state and at certain times of the year. This is a blend of 90% gasoline and 10% ethanol and it results in a fuel with somewhere between 3 % and 4% less energy than straight gas. To put it in practical terms, but g reatly oversimplifying, your engine that produces 100HP running on avgas wi ll only produce 96-97HP on E10 mogas. Granted, the E10 will cost quite a bi t less and that's the attraction of it. As you've read from other posts her e, ther! e are downsides and one of them is the fact that ethanol is incompatible wi th a lot of materials. Another downside is the potential for vapor lock. Ethanol has a lower boili ng point than straight gasoline, so it is less tolerant of high temperature s under the cowling and it can vaporize in the fuel lines or anywhere it's close to a hot surface. A vapor pocket or bubble in the fuel system can sto p the flow of fuel... "vapor lock". The problem is increased in the summer, of course, because when we land with a nice warmed-up engine and taxi over to the fuel pump and shut down, the areas inside the cowling become heat-s oaked and since there is no flow of cooler fuel in the lines when the engin e is shut down, the fuel can vaporize and lock the system, making startup m ore difficult. The reason why you don't see cars sitting all over the shoulders of the roa d with vapor lock is because most vehicles now are fuel injected or they ha ve fuel pumps that deliver the fuel under pressure, not gravity, and the bo iling point of a liquid increases as the pressure increases. You know this from your camping experiences when you try to boil water while camping up i n the mountains. It boils at a lower temperature up where the atmospheric p ressure is lower, and your beans never cook! Of course this same effect mea ns that flying at higher altitudes lowers the boiling point of fuel that co ntains ethanol, but most Piets fly down pretty low where that isn't a big f actor. More than you wanted to know, I'm sure ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447027#447027 =========== br> enpol-List" rel="noreferrer" target="_blank">http://www.matronics.c om/Navigator?Pietenpol-List =========== FORUMS - eferrer" target="_blank">http://forums.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution =========== === ________________________________________________________________________________
Date: Sep 16, 2015
Subject: Mid-Atlantic Fly-In
Pietenpeople: I am trying to get an idea of who would show for a Fly-In at 3VA7 near Winchester, Virginia ( http://www.airnav.com/airport/3VA7 ) the 3rd weekend in October. "Camping" would be in my home 4 miles from the field. I am providing dinner (of course, libations, too) and breakfast. RSVP so I can plan, and stock up. -Zeke Grega w/C-85-12 ________________________________________________________________________________
Date: Sep 16, 2015
New car or old? My 2013 Ford Explorer only gets about 2 mpg better on 100% gas. It's electronic brain adjusts the system to digest the 10% ethanol. Indeed, it is a flex fuel vehicle and can run E85 (from 51% to 85% ethanol.) I have not run it yet but will give it a try and will follow the fuel mileage. I will then run some E10 and then run 100% gas. In Texas there is only 10% ethanol or E85. In Oklahoma you have a choice of all three at some places. According to a Wikipedia list on ethanol (written by a very pro ethanol writer) the fuel system cannot have unprotected aluminum, magnesium, and rubber. Blue Skies, Steve D. On Sep 15, 2015 10:17 PM, wrote: > Oscar-- > I had heard that ethanol only degraded fuel mileage (the only thing I am > really interested in for my pickup) a relatively small amount--but someone > in my Model A club said it was a bigger deal than I thought. So I ran a > test--a thousand miles each with E10 gas vs non-ethanol high test gas. And > I got 26% BETTER mileage with the non-alcohol gas. So now whenever I can > get non-alcohol gas for less than about a 25% price premium, I get that. > Cheers, Mac in Newport > > ------------------------------ > *From: *"John Cox" <rv10pro(at)gmail.com> > *To: *pietenpol-list(at)matronics.com > *Sent: *Saturday, September 12, 2015 8:30:13 PM > *Subject: *Re: Pietenpol-List: Re: Ethanol > > Great Read. > > John Cox > Aurora, OR > On Sep 12, 2015 11:10, "taildrags" wrote: > >> >> Douwe; while I don't claim to be "in the know", as a fire protection >> engineer I do have some knowledge of fuels and I can read a table of >> physical properties of fuels. Strictly from the "fuel as energy" >> standpoint, ethanol has an energy content of about 11,590 Btu per lb and >> gasoline (including 100LL avgas) has an energy content of about 18,700 Btu >> per lb. This means when you're burning a blend of gasoline and ethanol, >> you're leaving some power on the table. Here in Oregon, regulations >> mandate the sale of "E10" in some areas of the state and at certain times >> of the year. This is a blend of 90% gasoline and 10% ethanol and it >> results in a fuel with somewhere between 3% and 4% less energy than >> straight gas. To put it in practical terms, but greatly oversimplifying, >> your engine that produces 100HP running on avgas will only produce 96-97HP >> on E10 mogas. Granted, the E10 will cost quite a bit less and that's the >> attraction of it. As you've read from other posts here, ther! >> e are downsides and one of them is the fact that ethanol is incompatible >> with a lot of materials. >> >> Another downside is the potential for vapor lock. Ethanol has a lower >> boiling point than straight gasoline, so it is less tolerant of high >> temperatures under the cowling and it can vaporize in the fuel lines or >> anywhere it's close to a hot surface. A vapor pocket or bubble in the fuel >> system can stop the flow of fuel... "vapor lock". The problem is increased >> in the summer, of course, because when we land with a nice warmed-up engine >> and taxi over to the fuel pump and shut down, the areas inside the cowling >> become heat-soaked and since there is no flow of cooler fuel in the lines >> when the engine is shut down, the fuel can vaporize and lock the system, >> making startup more difficult. >> >> The reason why you don't see cars sitting all over the shoulders of the >> road with vapor lock is because most vehicles now are fuel injected or they >> have fuel pumps that deliver the fuel under pressure, not gravity, and the >> boiling point of a liquid increases as the pressure increases. You know >> this from your camping experiences when you try to boil water while camping >> up in the mountains. It boils at a lower temperature up where the >> atmospheric pressure is lower, and your beans never cook! Of course this >> same effect means that flying at higher altitudes lowers the boiling point >> of fuel that contains ethanol, but most Piets fly down pretty low where >> that isn't a big factor. More than you wanted to know, I'm sure ;o) >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=447027#447027 >> >> >> >> >> >> >> >> ========== >> br> enpol-List" rel="noreferrer" target="_blank"> >> http://www.matronics.com/Navigator?Pietenpol-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> * > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com <http://forums.matronics.com> > _blank">http://www.matronics.com/contribution > > * > > > * > > > * > > ________________________________________________________________________________
Date: Sep 16, 2015
I imagine vehicle age makes a difference. I have a 2001 Toyota Sienna van that is supposed to make 26mpg & it stays pretty consistently at 21 on 10% EtOH gas. I may try Mac's experiment, the premium differential around here is less than 25%. Kip Gardner On Sep 16, 2015, at 9:30 AM, Steven Dortch wrote: > New car or old? My 2013 Ford Explorer only gets about 2 mpg better on 100% gas. It's electronic brain adjusts the system to digest the 10% ethanol. Indeed, it is a flex fuel vehicle and can run E85 (from 51% to 85% ethanol.) I have not run it yet but will give it a try and will follow the fuel mileage. I will then run some E10 and then run 100% gas. > > In Texas there is only 10% ethanol or E85. In Oklahoma you have a choice of all three at some places. > > According to a Wikipedia list on ethanol (written by a very pro ethanol writer) the fuel system cannot have unprotected aluminum, magnesium, and rubber. > > Blue Skies, > Steve D. > > On Sep 15, 2015 10:17 PM, wrote: > Oscar-- > I had heard that ethanol only degraded fuel mileage (the only thing I am really interested in for my pickup) a relatively small amount--but someone in my Model A club said it was a bigger deal than I thought. So I ran a test--a thousand miles each with E10 gas vs non-ethanol high test gas. And I got 26% BETTER mileage with the non-alcohol gas. So now whenever I can get non-alcohol gas for less than about a 25% price premium, I get that. > Cheers, Mac in Newport > > From: "John Cox" <rv10pro(at)gmail.com> > To: pietenpol-list(at)matronics.com > Sent: Saturday, September 12, 2015 8:30:13 PM > Subject: Re: Pietenpol-List: Re: Ethanol > > Great Read. > > John Cox > Aurora, OR > > On Sep 12, 2015 11:10, "taildrags" wrote: > > Douwe; while I don't claim to be "in the know", as a fire protection engineer I do have some knowledge of fuels and I can read a table of physical properties of fuels. Strictly from the "fuel as energy" standpoint, ethanol has an energy content of about 11,590 Btu per lb and gasoline (including 100LL avgas) has an energy content of about 18,700 Btu per lb. This means when you're burning a blend of gasoline and ethanol, you're leaving some power on the table. Here in Oregon, regulations mandate the sale of "E10" in some areas of the state and at certain times of the year. This is a blend of 90% gasoline and 10% ethanol and it results in a fuel with somewhere between 3% and 4% less energy than straight gas. To put it in practical terms, but greatly oversimplifying, your engine that produces 100HP running on avgas will only produce 96-97HP on E10 mogas. Granted, the E10 will cost quite a bit less and that's the attraction of it. As you've read from other posts here, ther! > e are downsides and one of them is the fact that ethanol is incompatible with a lot of materials. > > Another downside is the potential for vapor lock. Ethanol has a lower boiling point than straight gasoline, so it is less tolerant of high temperatures under the cowling and it can vaporize in the fuel lines or anywhere it's close to a hot surface. A vapor pocket or bubble in the fuel system can stop the flow of fuel... "vapor lock". The problem is increased in the summer, of course, because when we land with a nice warmed-up engine and taxi over to the fuel pump and shut down, the areas inside the cowling become heat-soaked and since there is no flow of cooler fuel in the lines when the engine is shut down, the fuel can vaporize and lock the system, making startup more difficult. > > The reason why you don't see cars sitting all over the shoulders of the road with vapor lock is because most vehicles now are fuel injected or they have fuel pumps that deliver the fuel under pressure, not gravity, and the boiling point of a liquid increases as the pressure increases. You know this from your camping experiences when you try to boil water while camping up in the mountains. It boils at a lower temperature up where the atmospheric pressure is lower, and your beans never cook! Of course this same effect means that flying at higher altitudes lowers the boiling point of fuel that contains ethanol, but most Piets fly down pretty low where that isn't a big factor. More than you wanted to know, I'm sure ;o) > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447027#447027 > > > > > > > > ========== > br> enpol-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > > > > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > ________________________________________________________________________________
Date: Sep 16, 2015
In my Bonanza, I run 100LL in the wing tanks. If available I run unleaded MOGAS in the AUX (Baggage) tank. the system is a pressure carb and pumps 13 Gallons to the carb and returns 3.5 gallons to the left tank. So I end up with a Mix in the left tank and Do about 1/2 of my cruising on the aux tank. The old bird (1948) seems to prefer the autofuel. the 100 LL keeps me trying to keep the lead burned off of the plugs. Note! 100LL is very stable. It can burn cleanly after 1 to two years in good storage. The modern MOGAS is not very stable. It goes bad (separates into varnish and other chemicals) after a couple of months. When I put my Bonanza in storage I put 100 LL in all three tanks. Just a point of reference. Blue Skies, Steve D On Wed, Sep 16, 2015 at 9:34 AM, Kip Gardner wrote: > I imagine vehicle age makes a difference. I have a 2001 Toyota Sienna van > that is supposed to make 26mpg & it stays pretty consistently at 21 on 10% > EtOH gas. I may try Mac's experiment, the premium differential around here > is less than 25%. > > Kip Gardner > > On Sep 16, 2015, at 9:30 AM, Steven Dortch > wrote: > > New car or old? My 2013 Ford Explorer only gets about 2 mpg better on 100% > gas. It's electronic brain adjusts the system to digest the 10% ethanol. > Indeed, it is a flex fuel vehicle and can run E85 (from 51% to 85% > ethanol.) I have not run it yet but will give it a try and will follow the > fuel mileage. I will then run some E10 and then run 100% gas. > > In Texas there is only 10% ethanol or E85. In Oklahoma you have a choice > of all three at some places. > > According to a Wikipedia list on ethanol (written by a very pro ethanol > writer) the fuel system cannot have unprotected aluminum, magnesium, and > rubber. > > Blue Skies, > Steve D. > > On Sep 15, 2015 10:17 PM, wrote: > >> Oscar-- >> I had heard that ethanol only degraded fuel mileage (the only thing I am >> really interested in for my pickup) a relatively small amount--but someone >> in my Model A club said it was a bigger deal than I thought. So I ran a >> test--a thousand miles each with E10 gas vs non-ethanol high test gas. And >> I got 26% BETTER mileage with the non-alcohol gas. So now whenever I can >> get non-alcohol gas for less than about a 25% price premium, I get that. >> Cheers, Mac in Newport >> >> ------------------------------ >> *From: *"John Cox" <rv10pro(at)gmail.com> >> *To: *pietenpol-list(at)matronics.com >> *Sent: *Saturday, September 12, 2015 8:30:13 PM >> *Subject: *Re: Pietenpol-List: Re: Ethanol >> >> Great Read. >> >> John Cox >> Aurora, OR >> On Sep 12, 2015 11:10, "taildrags" wrote: >> >>> > >>> >>> Douwe; while I don't claim to be "in the know", as a fire protection >>> engineer I do have some knowledge of fuels and I can read a table of >>> physical properties of fuels. Strictly from the "fuel as energy" >>> standpoint, ethanol has an energy content of about 11,590 Btu per lb and >>> gasoline (including 100LL avgas) has an energy content of about 18,700 Btu >>> per lb. This means when you're burning a blend of gasoline and ethanol, >>> you're leaving some power on the table. Here in Oregon, regulations >>> mandate the sale of "E10" in some areas of the state and at certain times >>> of the year. This is a blend of 90% gasoline and 10% ethanol and it >>> results in a fuel with somewhere between 3% and 4% less energy than >>> straight gas. To put it in practical terms, but greatly oversimplifying, >>> your engine that produces 100HP running on avgas will only produce 96-97HP >>> on E10 mogas. Granted, the E10 will cost quite a bit less and that's the >>> attraction of it. As you've read from other posts here, ther! >>> e are downsides and one of them is the fact that ethanol is >>> incompatible with a lot of materials. >>> >>> Another downside is the potential for vapor lock. Ethanol has a lower >>> boiling point than straight gasoline, so it is less tolerant of high >>> temperatures under the cowling and it can vaporize in the fuel lines or >>> anywhere it's close to a hot surface. A vapor pocket or bubble in the fuel >>> system can stop the flow of fuel... "vapor lock". The problem is increased >>> in the summer, of course, because when we land with a nice warmed-up engine >>> and taxi over to the fuel pump and shut down, the areas inside the cowling >>> become heat-soaked and since there is no flow of cooler fuel in the lines >>> when the engine is shut down, the fuel can vaporize and lock the system, >>> making startup more difficult. >>> >>> The reason why you don't see cars sitting all over the shoulders of the >>> road with vapor lock is because most vehicles now are fuel injected or they >>> have fuel pumps that deliver the fuel under pressure, not gravity, and the >>> boiling point of a liquid increases as the pressure increases. You know >>> this from your camping experiences when you try to boil water while camping >>> up in the mountains. It boils at a lower temperature up where the >>> atmospheric pressure is lower, and your beans never cook! Of course this >>> same effect means that flying at higher altitudes lowers the boiling point >>> of fuel that contains ethanol, but most Piets fly down pretty low where >>> that isn't a big factor. More than you wanted to know, I'm sure ;o) >>> >>> -------- >>> Oscar Zuniga >>> Medford, OR >>> Air Camper NX41CC "Scout" >>> A75 power >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=447027#447027 >>> >>> >>> >>> >>> >>> >>> >>> ========== >>> br> enpol-List" rel="noreferrer" target="_blank"> >>> http://www.matronics.com/Navigator?Pietenpol-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> * >> >> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> tp://forums.matronics.com <http://forums.matronics.com/> >> _blank">http://www.matronics.com/contribution >> >> * >> >> >> * >> >> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> >> * >> >> * > > href="http://www.matronics.com/Navigator?Pietenpol-List ">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com/ ">http://forums.matronics.com > href="http://www.matronics.com/contribution ">http://www.matronics.com/contribution > > * > > > * > > > * > > -- Blue Skies, Steve D ________________________________________________________________________________
From: Fastnaught John <fastnaught(at)windstream.net>
Subject: Re: Mid-Atlantic Fly-In
Date: Sep 16, 2015
Marcus, I=99m glad you thought of this. We=99ve been having this discussion down here in South Carolina for a while now. Unfortunately I=99m still in phase one of my fly-off and probably won=99t have enough hours to make that trip, as much as I would like. Maybe in the spring or other date would be good for me. Please keep in touch. Thanks, Jack Ford model A Wire wheels phase 1 > On Sep 16, 2015, at 7:33 AM, Marcus Zechini wrote: > > Pietenpeople: > > I am trying to get an idea of who would show for a Fly-In at 3VA7 near Winchester, Virginia ( http://www.airnav.com/airport/3VA7 <http://www.airnav.com/airport/3VA7> ) the 3rd weekend in October. > > "Camping" would be in my home 4 miles from the field. I am providing dinner (of course, libations, too) and breakfast. > > RSVP so I can plan, and stock up. > > -Zeke > Grega w/C-85-12 > > <http://www.matronics.com/Navigator?Pietenpol-List> <http://www.matronics.com/contribution> > ________________________________________________________________________________
Date: Sep 16, 2015
...all of which goes to prove the now-overused phrase, "your mileage may vary" ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447122#447122 ________________________________________________________________________________
Date: Sep 16, 2015
Will do. Always open for suggestions. Good luck with fly off! On Sep 16, 2015 11:25 AM, "Fastnaught John" wrote: > Marcus, > I=99m glad you thought of this. We=99ve been having this disc ussion down here > in South Carolina for a while now. Unfortunately I=99m still in pha se one of > my fly-off and probably won=99t have enough hours to make that trip , as much > as I would like. Maybe in the spring or other date would be good for me. > Please keep in touch. > Thanks, > Jack > > Ford model A > Wire wheels > phase 1 > > > On Sep 16, 2015, at 7:33 AM, Marcus Zechini > wrote: > > Pietenpeople: > > I am trying to get an idea of who would show for a Fly-In at 3VA7 near > Winchester, Virginia ( http://www.airnav.com/airport/3VA7 ) the 3rd > weekend in October. > > "Camping" would be in my home 4 miles from the field. I am providing > dinner (of course, libations, too) and breakfast. > > RSVP so I can plan, and stock up. > > -Zeke > Grega w/C-85-12 > > * > > href="http://www.matronics.com/Navigator?Pietenpol-List " class="">http://www.matronics.com/N avigator?Pietenpol-List <http://www.matronics.com/Navigator?Pietenpol-List> > class="">http://forums.matronics.com > class="">http://www.matronics.com/contribution > > * > > > * > =========== .matronics.com/Navigator?Pietenpol-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Sep 17, 2015
Hello WF2.... Thx, I am using 0.063 5052 sheet for the tank. Since I hire out the welding I am not exactly sure which wire Mike (Ready Weld) is using with his TIG welding torch. Mike has been welding professionally for over 20 years so I yield those decisions to his talent. Ordering an additional sump (from a Stearman) today......... (progress one day at a time!) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447160#447160 ________________________________________________________________________________
Date: Sep 17, 2015
Update on E85. With current low oil prices. Texas and Oklahoma e10 gas is 1.93 to 2.20per gallon. E85 is $2.47. My guess is that Ethanol base price is less affected by oil prices. They also have fixed costs. At my present situation, I don't want to experiment at a definite loss. Blue skies, Steve D On Sep 16, 2015 9:57 AM, "Steven Dortch" wrote: > In my Bonanza, I run 100LL in the wing tanks. If available I run unleaded > MOGAS in the AUX (Baggage) tank. the system is a pressure carb and pumps > 13 Gallons to the carb and returns 3.5 gallons to the left tank. So I end > up with a Mix in the left tank and Do about 1/2 of my cruising on the aux > tank. > > The old bird (1948) seems to prefer the autofuel. the 100 LL keeps me > trying to keep the lead burned off of the plugs. > > Note! 100LL is very stable. It can burn cleanly after 1 to two years in > good storage. The modern MOGAS is not very stable. It goes bad (separates > into varnish and other chemicals) after a couple of months. When I put my > Bonanza in storage I put 100 LL in all three tanks. > > Just a point of reference. > > Blue Skies, > Steve D > > On Wed, Sep 16, 2015 at 9:34 AM, Kip Gardner > wrote: > >> I imagine vehicle age makes a difference. I have a 2001 Toyota Sienna >> van that is supposed to make 26mpg & it stays pretty consistently at 21 on >> 10% EtOH gas. I may try Mac's experiment, the premium differential around >> here is less than 25%. >> >> Kip Gardner >> >> On Sep 16, 2015, at 9:30 AM, Steven Dortch >> wrote: >> >> New car or old? My 2013 Ford Explorer only gets about 2 mpg better on >> 100% gas. It's electronic brain adjusts the system to digest the 10% >> ethanol. Indeed, it is a flex fuel vehicle and can run E85 (from 51% to 85% >> ethanol.) I have not run it yet but will give it a try and will follow the >> fuel mileage. I will then run some E10 and then run 100% gas. >> >> In Texas there is only 10% ethanol or E85. In Oklahoma you have a choice >> of all three at some places. >> >> According to a Wikipedia list on ethanol (written by a very pro ethanol >> writer) the fuel system cannot have unprotected aluminum, magnesium, and >> rubber. >> >> Blue Skies, >> Steve D. >> >> On Sep 15, 2015 10:17 PM, wrote: >> >>> Oscar-- >>> I had heard that ethanol only degraded fuel mileage (the only thing I am >>> really interested in for my pickup) a relatively small amount--but someone >>> in my Model A club said it was a bigger deal than I thought. So I ran a >>> test--a thousand miles each with E10 gas vs non-ethanol high test gas. And >>> I got 26% BETTER mileage with the non-alcohol gas. So now whenever I can >>> get non-alcohol gas for less than about a 25% price premium, I get that. >>> Cheers, Mac in Newport >>> >>> ------------------------------ >>> *From: *"John Cox" <rv10pro(at)gmail.com> >>> *To: *pietenpol-list(at)matronics.com >>> *Sent: *Saturday, September 12, 2015 8:30:13 PM >>> *Subject: *Re: Pietenpol-List: Re: Ethanol >>> >>> Great Read. >>> >>> John Cox >>> Aurora, OR >>> On Sep 12, 2015 11:10, "taildrags" wrote: >>> >>>> taildrags(at)hotmail.com> >>>> >>>> Douwe; while I don't claim to be "in the know", as a fire protection >>>> engineer I do have some knowledge of fuels and I can read a table of >>>> physical properties of fuels. Strictly from the "fuel as energy" >>>> standpoint, ethanol has an energy content of about 11,590 Btu per lb and >>>> gasoline (including 100LL avgas) has an energy content of about 18,700 Btu >>>> per lb. This means when you're burning a blend of gasoline and ethanol, >>>> you're leaving some power on the table. Here in Oregon, regulations >>>> mandate the sale of "E10" in some areas of the state and at certain times >>>> of the year. This is a blend of 90% gasoline and 10% ethanol and it >>>> results in a fuel with somewhere between 3% and 4% less energy than >>>> straight gas. To put it in practical terms, but greatly oversimplifying, >>>> your engine that produces 100HP running on avgas will only produce 96-97HP >>>> on E10 mogas. Granted, the E10 will cost quite a bit less and that's the >>>> attraction of it. As you've read from other posts here, ther! >>>> e are downsides and one of them is the fact that ethanol is >>>> incompatible with a lot of materials. >>>> >>>> Another downside is the potential for vapor lock. Ethanol has a lower >>>> boiling point than straight gasoline, so it is less tolerant of high >>>> temperatures under the cowling and it can vaporize in the fuel lines or >>>> anywhere it's close to a hot surface. A vapor pocket or bubble in the fuel >>>> system can stop the flow of fuel... "vapor lock". The problem is increased >>>> in the summer, of course, because when we land with a nice warmed-up engine >>>> and taxi over to the fuel pump and shut down, the areas inside the cowling >>>> become heat-soaked and since there is no flow of cooler fuel in the lines >>>> when the engine is shut down, the fuel can vaporize and lock the system, >>>> making startup more difficult. >>>> >>>> The reason why you don't see cars sitting all over the shoulders of the >>>> road with vapor lock is because most vehicles now are fuel injected or they >>>> have fuel pumps that deliver the fuel under pressure, not gravity, and the >>>> boiling point of a liquid increases as the pressure increases. You know >>>> this from your camping experiences when you try to boil water while camping >>>> up in the mountains. It boils at a lower temperature up where the >>>> atmospheric pressure is lower, and your beans never cook! Of course this >>>> same effect means that flying at higher altitudes lowers the boiling point >>>> of fuel that contains ethanol, but most Piets fly down pretty low where >>>> that isn't a big factor. More than you wanted to know, I'm sure ;o) >>>> >>>> -------- >>>> Oscar Zuniga >>>> Medford, OR >>>> Air Camper NX41CC "Scout" >>>> A75 power >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=447027#447027 >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> ========== >>>> br> enpol-List" rel="noreferrer" target="_blank"> >>>> http://www.matronics.com/Navigator?Pietenpol-List >>>> ========== >>>> FORUMS - >>>> eferrer" target="_blank">http://forums.matronics.com >>>> ========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>>> ========== >>>> >>>> >>>> >>>> * >>> >>> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >>> tp://forums.matronics.com <http://forums.matronics.com/> >>> _blank">http://www.matronics.com/contribution >>> >>> * >>> >>> >>> * >>> >>> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >>> tp://forums.matronics.com >>> _blank">http://www.matronics.com/contribution >>> >>> * >>> >>> * >> >> href="http://www.matronics.com/Navigator?Pietenpol-List ">http://www.matronics.com/Navigator?Pietenpol-List >> href="http://forums.matronics.com/ ">http://forums.matronics.com >> href="http://www.matronics.com/contribution ">http://www.matronics.com/contribution >> >> * >> >> >> * >> >> >> * >> >> > > > -- > Blue Skies, > Steve D > ________________________________________________________________________________
Subject: Reporting in
Date: Sep 18, 2015
Well, its been a while since I last posted so I just wanted to let everyone know how the Piet Project has been progressing. I did my first taxi testing about a month ago. Yesterday I had a DAR come out and inspect the plane, so now I have my Airworthiness Certificate. The inspection went very well, though I admit that I was a little nervous. The DAR that I used was Lowell Farrand. Lowell was the test pilot for the Mini-Max line of home built aircraft as well as the test pilot for the first powered parachute aircraft. He also served as the test pilot for military ejection seats. He has really had an interesting career. He has been actively involved with the EAA since the early days and was one of the first certified DAR's. The EAA did a timeless voices interview with Lowell that is pretty interesting. Here is how NX478RS now looks. I also uploaded a Youtube video of the first taxi testing, here is the link. https://www.youtube.com/watch?v=GHOlvuizuc4 I am working on my tailwheel endorsement, so hopefully I can fly it soon. Rick Schreiber NX478RS Valparaiso, IN ________________________________________________________________________________
Date: Sep 18, 2015
Subject: Re: Reporting in
Date: Sep 18, 2015
Looks great, Rick. Can't wait to see it fly. Matt PaxtonOn Sep 18, 2015 8:25 PM, Rick Schreiber wrote: > > Well, its been a while since I last posted so I just wanted to let everyone know how the Piet Project has been progressing. I did my first taxi testing about a month ago. Yesterday I had a DAR come out and inspect the plane, so now I have my Airworthiness Certificate. The inspection went very well, though I admit that I was a little nervous. The DAR that I used was Lowell Farrand. Lowell was the test pilot for the Mini-Max line of home built aircraft as well as the test pilot for the first powered parachute aircraft. He also served as the test pilot for military ejection seats. He has really had an interesting career. He has been actively involved with the EAA since the early days and was one of the first certified DAR's. The EAA did a timeless voices interview with Lowell that is pretty interesting. > > Here is how NX478RS now looks. I also uploaded a Youtube video of the first taxi testing, here is the link. > https://www.youtube.com/watch?v=GHOlvuizuc4 > > I am working on my tailwheel endorsement, so hopefully I can fly it soon. > > > Rick Schreiber > NX478RS > Valparaiso, IN > > ________________________________________________________________________________
Subject: Ford Model A engines for sale
Date: Sep 18, 2015
Members of the list: I have two short block Ford Model A engines for sale. One is from a combine with very few hours (1934) and the other if from a car (1929). Both ran when removed. Looking for $500.00 the pair or best offer. KM Heide 701-793-3030 Fargo, ND Sent from my iPad ________________________________________________________________________________
Date: Sep 18, 2015
Members of the list: I have two short block Ford Model A engines for sale. One is from a combine w ith very few hours (1934) and the other is from a car (1929). Both ran when r emoved. Sitting for years in dry storage. Looking for $500.00 the pair or best offer. KM Heide 701-793-3030 Fargo, ND Sent from my iPad Sent from my iPad
Date: Sep 18, 2015
Very sharp, Rick. Congratulations. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447216#447216 ________________________________________________________________________________
Date: Sep 18, 2015
Date: Sep 19, 2015
[Rick, where are you based? I noted the "Kelly field" on the side. Steve D Pietenpol in final stages of restoration. San Geronimo Airpark (8T8) San Antonio, Texas On Fri, Sep 18, 2015 at 10:12 PM, Ray Krause wrote: > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Sep 19, 2015
Love the paint scheme ... looks very familiar ;) WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447230#447230 ________________________________________________________________________________
Date: Sep 19, 2015
On 9/19/2015 12:46 AM, Steven Dortch wrote: > [Rick, where are you based? I noted the "Kelly field" on the side. > Steve D > Pietenpol in final stages of restoration. > San Geronimo Airpark (8T8) > San Antonio, Texas > > On Fri, Sep 18, 2015 at 10:12 PM, Ray Krause > > wrote: > > > -- > Blue Skies, > Steve D > http://www.matronics.com/contribution Steve, I'm at the South end of Lake Michigan just East of Chicago. I was born an raised in San Antonio and my family history with San Antonio goes back to the early 1900's. My Father was in the Air Force and worked at Kelly Field after WWII through the Korean War and the Berlin Air Lift. I had a Great Uncle that worked in the fabric shop at Kelly covering Jennys and an Aunt that also worked there. From a very young age I always knew I would build my own plane. I can remember going out to Kelly with my Dad and seeing row upon row of Biplanes in storage. I thought they were Jennys at first, but most likely they were PT-17's. I originally wanted to build a WWI fighter, but that morphed into a 2 place single wing fabric plane as being more practical. Once I discovered Pietenpols, that was it! Rick ________________________________________________________________________________
Date: Sep 19, 2015
On 9/19/2015 6:55 AM, womenfly2 wrote: > > Love the paint scheme ... looks very familiar ;) > > WF2 > > -------- > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447230#447230 > > Thanks Keri-Ann, before I get accused of plagiarism here are the original inspirations for the paint scheme :-) When I was into RC models I always wanted to build the 1/4 scale Proctor Jenny, but could never afford it. Once I had the money I would have been afraid to fly it. I finally decided to just make it full size ( well almost) and remove the lower wing. I if you look at a Jenny, you can see where Bernard was getting some of his design characteristics as he did own one. Rick Schreiber NX478RS ________________________________________________________________________________
Date: Sep 19, 2015
Rick very nice! Inspirational which I'm in need of, thanks! Sent from my iPad Jack Textor > On Sep 18, 2015, at 7:25 PM, Rick Schreiber wrote: > > Well, its been a while since I last posted so I just wanted to let everyon e know how the Piet Project has been progressing. I did my first taxi testin g about a month ago. Yesterday I had a DAR come out and inspect the plane, s o now I have my Airworthiness Certificate. The inspection went very well, th ough I admit that I was a little nervous. The DAR that I used was Lowell Fa rrand. Lowell was the test pilot for the Mini-Max line of home built aircraf t as well as the test pilot for the first powered parachute aircraft. He als o served as the test pilot for military ejection seats. He has really had an interesting career. He has been actively involved with the EAA since the ea rly days and was one of the first certified DAR's. The EAA did a timeless vo ices interview with Lowell that is pretty interesting. > > Here is how NX478RS now looks. I also uploaded a Youtube video of the firs t taxi testing, here is the link. > https://www.youtube.com/watch?v=GHOlvuizuc4 > > I am working on my tailwheel endorsement, so hopefully I can fly it soon. > > > > > Rick Schreiber > NX478RS > Valparaiso, IN > > > ________________________________________________________________________________
Date: Sep 19, 2015
On 9/19/2015 8:22 AM, Jack wrote: > Rick very nice! Inspirational which I'm in need of, thanks! > > Sent from my iPad > Jack Textor > > On Sep 18, 2015, at 7:25 PM, Rick Schreiber > wrote: > >> Well, its been a while since I last posted so I just wanted to let >> everyone know how the Piet Project has been progressing. I did my >> first taxi testing about a month ago. Yesterday I had a DAR come out >> and inspect the plane, so now I have my Airworthiness Certificate. >> The inspection went very well, though I admit that I was a little >> nervous. The DAR that I used was Lowell Farrand. Lowell was the test >> pilot for the Mini-Max line of home built aircraft as well as the >> test pilot for the first powered parachute aircraft. He also served >> as the test pilot for military ejection seats. He has really had an >> interesting career. He has been actively involved with the EAA since >> the early days and was one of the first certified DAR's. The EAA did >> a timeless voices interview with Lowell that is pretty interesting. >> >> Here is how NX478RS now looks. I also uploaded a Youtube video of the >> first taxi testing, here is the link. >> https://www.youtube.com/watch?v=GHOlvuizuc4 >> >> I am working on my tailwheel endorsement, so hopefully I can fly it soon. >> >> >> >> >> Rick Schreiber >> NX478RS >> Valparaiso, IN >> >> >> > http://www.matronics.com/Navigator?Pietenpol-List > http://www.matronics.com/contribution > <3D%22http://www.matronics.com/contribution%22> > * Jack, I sure understand the need for inspiration when things start to bog down. For me I would look at Mike Cuys video and the pictures I have taken at Brodhead. Speaking of Brodhead, I am fortunate in that I am only a little over an hours flight away. I mange to go at least twice a year, once to the Piet convention and then to the MAAC flyin, which was last weekend. My build took 12 1/2 years. The last 3 years it has been at the airport. I have moved it at the airport into 7 different hangars (and actually 3 airports) depending on availability, space and needs. The Piet has generated a lot of interest in the local community. What doesn't show in the edited taxi video, is what happens after I made the first turn onto the main taxiway. I was going to show it off to my AP/IA. As I approached his hangar, which can be seen on the left side of the plane, all of a sudden people were coming out of the wood work. There was running, yelling and grabbing of cameras, cell phones and Ipads. There must have been 15 people running up to the plane. It was pretty exciting for me, something I will always remember and this was just the taxi test. Regards, Rick Schreiber NX478RS ________________________________________________________________________________
Date: Sep 19, 2015
Hey Rick, Looking awesome! If you send me a high resolution picture you will make centerfold in an upcoming BPA newsletter. Good luck with testing. Best, -john- John Hofmann Vice-President, IT and Production The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com > On Sep 18, 2015, at 7:25 PM, Rick Schreiber wrote: > > Well, its been a while since I last posted so I just wanted to let everyone know how the Piet Project has been progressing. I did my first taxi testing about a month ago. Yesterday I had a DAR come out and inspect the plane, so now I have my Airworthiness Certificate. The inspection went very well, though I admit that I was a little nervous. The DAR that I used was Lowell Farrand. Lowell was the test pilot for the Mini-Max line of home built aircraft as well as the test pilot for the first powered parachute aircraft. He also served as the test pilot for military ejection seats. He has really had an interesting career. He has been actively involved with the EAA since the early days and was one of the first certified DAR's. The EAA did a timeless voices interview with Lowell that is pretty interesting. > > Here is how NX478RS now looks. I also uploaded a Youtube video of the first taxi testing, here is the link. > https://www.youtube.com/watch?v=GHOlvuizuc4 > > I am working on my tailwheel endorsement, so hopefully I can fly it soon. > > > > > Rick Schreiber > NX478RS > Valparaiso, IN > > > ________________________________________________________________________________
Date: Sep 19, 2015
Rick, I apologize, I know it is not polite to ask someone where they are from. If they are from Texas they will tell you. If they aren't, there is no reason to embarrass them. You should get the book "wings over San Antonio, Texas" by Mel Brown. There is also one called "San Antonio and the great war." Lots of great photos. Mine is an alternate history military paint job. Blue skies. Steve D. On Sep 19, 2015 7:52 AM, "Rick Schreiber" wrote: > On 9/19/2015 12:46 AM, Steven Dortch wrote: > > [Rick, where are you based? I noted the "Kelly field" on the side. > > Steve D > Pietenpol in final stages of restoration. > San Geronimo Airpark (8T8) > San Antonio, Texas > > > On Fri, Sep 18, 2015 at 10:12 PM, Ray Krause > wrote: > >> >> >> > > > -- > Blue Skies, > Steve D > > > Steve, I'm at the South end of Lake Michigan just East of Chicago. I > was born an raised in San Antonio and my family history with San Antonio > goes back to the early 1900's. My Father was in the Air Force and worked at > Kelly Field after WWII through the Korean War and the Berlin Air Lift. I > had a Great Uncle that worked in the fabric shop at Kelly covering Jennys > and an Aunt that also worked there. From a very young age I always knew I > would build my own plane. I can remember going out to Kelly with my Dad and > seeing row upon row of Biplanes in storage. I thought they were Jennys at > first, but most likely they were PT-17's. > > I originally wanted to build a WWI fighter, but that morphed into a 2 > place single wing fabric plane as being more practical. Once I discovered > Pietenpols, that was it! > > Rick > > > * > > > * > > ________________________________________________________________________________
Date: Sep 19, 2015
Beautiful, Rick! Are you going to do the first flight, or have someone else do that? Jack Phillips NX899JP Smith Mountain Lake, Virginia From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Schreiber Sent: Friday, September 18, 2015 8:26 PM Subject: Pietenpol-List: Reporting in Well, its been a while since I last posted so I just wanted to let everyone know how the Piet Project has been progressing. I did my first taxi testing about a month ago. Yesterday I had a DAR come out and inspect the plane, so now I have my Airworthiness Certificate. The inspection went very well, though I admit that I was a little nervous. The DAR that I used was Lowell Farrand. Lowell was the test pilot for the Mini-Max line of home built aircraft as well as the test pilot for the first powered parachute aircraft. He also served as the test pilot for military ejection seats. He has really had an interesting career. He has been actively involved with the EAA since the early days and was one of the first certified DAR's. The EAA did a timeless voices interview with Lowell that is pretty interesting. Here is how NX478RS now looks. I also uploaded a Youtube video of the first taxi testing, here is the link. https://www.youtube.com/watch?v=GHOlvuizuc4 I am working on my tailwheel endorsement, so hopefully I can fly it soon. Rick Schreiber NX478RS Valparaiso, IN ________________________________________________________________________________
Date: Sep 19, 2015
I have two Ford model A engines short blocks for sale. These engines were running when removed years ago. One engine has low time hours as it came out of a combine (1934) and the other engine is out of a (1929) vehicle. These are good blocks. Looking for $500.00 for the pair or best offer. Call 701-793-3030 Fargo, ND Ken Heide Sent from my iPhone ________________________________________________________________________________
Date: Sep 20, 2015
From: "Charles N. Campbell" <charlescampbell1924(at)gmail.com>
I used Douglas Fir. Chuck On Mon, Sep 14, 2015 at 2:29 PM, Douwe Blumberg wrote: > Hey all, > > > For those of you with lots of experience, what are some of the best and > most available woods for rib capstrips? > > > Douwe > > * > > > * > > ________________________________________________________________________________
Date: Sep 20, 2015
On 9/19/2015 12:32 PM, Jack Philips wrote: > > Beautiful, Rick! Are you going to do the first flight, or have > someone else do that? > > Jack Phillips > > NX899JP > > Smith Mountain Lake, Virginia > > Thanks for the compliment Jack. Since I am still working on my tail wheel endorsement, I am having a friend do the test flight. If there are no squawks, He will then fly it from my airport, Porter Co. Regional to Starke Co. airport. Starke Co has a nice grass strip where I will be able to practice before I bring it back home. Rick Schreiber NX478RS VPZ Valparaiso, IN ________________________________________________________________________________
Date: Sep 20, 2015
Good thinking, Rick. I=99ve landed on the grass runway at Starke County and it is nice and wide and smooth. Sounds like a good place to get used to flying your Pietenpol. Mine is a pussycat on grass but can be a little twitchy on pavement. Jack Phillips NX899JP Smith Mountain Lake, Virginia From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Schreiber Sent: Sunday, September 20, 2015 7:32 AM Subject: Re: Pietenpol-List: Reporting in On 9/19/2015 12:32 PM, Jack Philips wrote: Beautiful, Rick! Are you going to do the first flight, or have someone else do that? Jack Phillips NX899JP Smith Mountain Lake, Virginia Thanks for the compliment Jack. Since I am still working on my tail wheel endorsement, I am having a friend do the test flight. If there are no squawks, He will then fly it from my airport, Porter Co. Regional to Starke Co. airport. Starke Co has a nice grass strip where I will be able to practice before I bring it back home. Rick Schreiber NX478RS VPZ Valparaiso, IN ________________________________________________________________________________
Date: Sep 20, 2015
On 9/19/2015 11:49 AM, Steven Dortch wrote: > > Rick, I apologize, I know it is not polite to ask someone where they > are from. If they are from Texas they will tell you. If they aren't, > there is no reason to embarrass them. > > You should get the book "wings over San Antonio, Texas" by Mel Brown. > There is also one called "San Antonio and the great war." Lots of > great photos. > > Mine is an alternate history military paint job. > > Blue skies. > Steve D. > > ** No apologies needed Steve. I understand perfectly. Thanks for the info on the two books on the history of flight in San Antonio. I will be ordering both books. I keep looking for more images of Jennys with a Kelly Field association. Rick Schreiber NX478RS VPZ Valparaiso, IN ________________________________________________________________________________
Date: Sep 20, 2015
On 9/20/2015 6:46 AM, Jack Philips wrote: > > Good thinking, Rick. Ive landed on the grass runway at Starke County > and it is nice and wide and smooth. Sounds like a good place to get > used to flying your Pietenpol. Mine is a pussycat on grass but can be > a little twitchy on pavement. > > Jack Phillips > > NX899JP > > Smith Mountain Lake, Virginia > > Jack, I know the people at Starke very well. I actually did the painting of all of my control surfaces and center section in a spray booth they have at Starke. You are right about how nice the grass strip is. I have a friend who recently bought a 1929 straight wing Waco 10 who learned to fly it off of the grass at Starke. This is where he keeps it along with his Citabria. His instructor is the same person who will be test flying my Piet. Also Jim Haklin keeps his almost complete Pietenpol at Starke Co. Hopefully I can get my 40 hrs. flown off so I can bring the Piet to Brodhead next year. Regards, Rick Schreiber NX478RS VPZ Valparaiso, IN ________________________________________________________________________________
Subject: Flyin pictures
Date: Sep 20, 2015
Here are a couple of pictures from the recent Antique Aircraft flyin at Blakesgurg, IA and the MAAC flyin at Brodhead -hope you enjoy Rick Schreiber NX478RS Valparaiso, IN *Douwe "smokin" during a Dawn Patrol of Blakesburg** * * **Pretty Curtiss Robin at Blakesburg* * **Gene Rambo's beautiful Piet at Brodhead* ________________________________________________________________________________
Subject: I Re-built My Panel
Date: Sep 20, 2015
Gary Boothe NX308MB ________________________________________________________________________________
Subject: Re: I Re-built My Panel
Date: Sep 20, 2015
Gary, Can you read that indicator from the cockpit? Looks like it is on backwards? I bought one of those stupid Brodhead this summer. Nice, Ray Krause, up the road a little. Sent from my iPad > On Sep 20, 2015, at 8:27 AM, Gary Boothe wrote: > > > > Gary Boothe > NX308MB > > ________________________________________________________________________________
Subject: Re: What's up Doc?
Date: Sep 20, 2015
Doc, If you would like plans for the Pfeifer Sport Piet-like plane I can send them as PDFs by email. I'm nearing retirement age and hope to get it back in the air. Darrel Jones N154JP ________________________________________________________________________________
Date: Sep 20, 2015
Should have read that email before I hit "send". I did not mean to say "stup id Brodhead", but "at Brodhead". What I really should say is this iPad is " more stupider than I am". But my English is gooder than that. Ray Sent from my iPad > On Sep 20, 2015, at 10:05 AM, Ray Krause wrote : > > Gary, > > Can you read that indicator from the cockpit? Looks like it is on backward s? I bought one of those stupid Brodhead this summer. > > Nice, > > Ray Krause, up the road a little. > > Sent from my iPad > >> On Sep 20, 2015, at 8:27 AM, Gary Boothe wrote: >> >> >> >> Gary Boothe >> NX308MB >> >> ________________________________________________________________________________
Date: Sep 20, 2015
Here=99s another view, Ray. You can see that the trailing edge is streamlined for minimum drag and maximum speed! I bought this in 2009 at Brodhead, from PF Beck, and proud to sport some of his craftsmanship. Sometimes it doesn=99t pay to pull the trigger too soongotta think these things out I read the numbers just fine, and it appears to be pretty accurateat least as accurate as my AS indicator, which has its own calibration backstory. Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause Sent: Sunday, September 20, 2015 10:05 AM Subject: Re: Pietenpol-List: I Re-built My Panel Gary, Can you read that indicator from the cockpit? Looks like it is on backwards? I bought one of those stupid Brodhead this summer. Nice, Ray Krause, up the road a little. Sent from my iPad On Sep 20, 2015, at 8:27 AM, Gary Boothe wrote: Gary Boothe NX308MB 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Subject: Lee bottom
Date: Sep 20, 2015
Hit the lee bottom fly-in with daughter carynn. Would have been awesome but the one crap wx day in weeks happened to be Saturday so attendance was down . Still had a great time at a wonderfully organized event. Great food, gre at people, movies at night, fun camping, some good ece flights. Here's the m orning flight home. Good stuff! Sent from my iPhone
Date: Sep 20, 2015
Gary, Mine has an "almost naked" lady! Could cause me some problems finding the st ick! If your plane is flying, the AS must be OK. Nice photo. Off your video camera? Ray Sent from my iPad > On Sep 20, 2015, at 10:57 AM, Gary Boothe wrote: > > Here=99s another view, Ray. You can see that the trailing edge is st reamlined for minimum drag and maximum speed! I bought this in 2009 at Brodh ead, from PF Beck, and proud to sport some of his craftsmanship. Sometimes i t doesn=99t pay to pull the trigger too soongotta think these things out > > I read the numbers just fine, and it appears to be pretty accurate at least as accurate as my AS indicator, which has its own calibration backs tory. > > Gary Boothe > NX308MB > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Ray Krause > Sent: Sunday, September 20, 2015 10:05 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: I Re-built My Panel > > Gary, > > Can you read that indicator from the cockpit? Looks like it is on backward s? I bought one of those stupid Brodhead this summer. > > Nice, > > Ray Krause, up the road a little. > > Sent from my iPad > > On Sep 20, 2015, at 8:27 AM, Gary Boothe wrote: > > > > Gary Boothe > NX308MB > > > > > http://www.matronics.com/Navigator?Pietenpol-List > http://forums.matronics.com > http://www.matronics.com/contribution > > ________________________________________________________________________________
Date: Sep 20, 2015
Wanna trade? It was a bit difficult, but that pic was from my I-phone. They aren't very h andy one-handed cameras! Gary Sent from my iPhone > On Sep 20, 2015, at 6:28 PM, Ray Krause wrote: > > Gary, > > Mine has an "almost naked" lady! Could cause me some problems finding the s tick! If your plane is flying, the AS must be OK. > > Nice photo. Off your video camera? > > Ray > > Sent from my iPad > >> On Sep 20, 2015, at 10:57 AM, Gary Boothe wrote: >> >> Here=99s another view, Ray. You can see that the trailing edge is s treamlined for minimum drag and maximum speed! I bought this in 2009 at Brod head, from PF Beck, and proud to sport some of his craftsmanship. Sometimes i t doesn=99t pay to pull the trigger too soongotta think these things out >> >> I read the numbers just fine, and it appears to be pretty accurate at least as accurate as my AS indicator, which has its own calibration backs tory. >> >> Gary Boothe >> NX308MB >> >> From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-l ist-server(at)matronics.com] On Behalf Of Ray Krause >> Sent: Sunday, September 20, 2015 10:05 AM >> To: pietenpol-list(at)matronics.com >> Subject: Re: Pietenpol-List: I Re-built My Panel >> >> Gary, >> >> Can you read that indicator from the cockpit? Looks like it is on backwar ds? I bought one of those stupid Brodhead this summer. >> >> Nice, >> >> Ray Krause, up the road a little. >> >> Sent from my iPad >> >> On Sep 20, 2015, at 8:27 AM, Gary Boothe wrote: >> >> >> >> Gary Boothe >> NX308MB >> >> >> >> >> http://www.matronics.com/Navigator?Pietenpol-List >> http://forums.matronics.com >> http://www.matronics.com/contribution >> >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Re: best wood for capstrips
Date: Sep 20, 2015
Way back when I was a ribmaker I found 1/4" X 1/2" strips of clear Hemlock from the trim section of all of the local lumber yards. I can't find it anymore. It's all prepainted sawdust board now. Clif When I was younger, I could remember anything, whether it happened or not. Mark Twain For those of you with lots of experience, what are some of the best and most available woods for rib capstrips? Douwe ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: Richard Schreiber's new Pietenpol Air Camper
Date: Sep 21, 2015
UmljaGFyZC0tLSBpdCBqdXN0IGxvb2tzIEZBTlRBU1RJQyEgICBDb25ncmF0dWxhdGlvbnMgb24g Z2V0dGluZyB5b3VyIGFpcndvcnRoaW5lc3MgY2VydGlmaWNhdGUuICAgU2hlIGxvb2tzIHNvLCBz byBiZWF1dGlmdWwgaW4gdGhhdCBwYWludCBzY2hlbWUuICAgIEkgaGF2ZSBhIGxvdCBvZiBmYXZv cml0ZSBQaWV0ZW5wb2xzIG91dCB0aGVyZSBidXQgSSBoYXZlIHRvIHNheQ0KeW91cnMganVzdCBz aG90IHRvIHRoZSB0b3Agb2YgbXkgbGlzdC4gICBHb3JnZW91cyBhbmQgeW91ciB3b3JrbWFuc2hp cCBsb29rcyBmYW50YXN0aWMuDQoNCkJlc3Qgd2lzaGVzIG9uIHlvdXIgdGFpbHdoZWVsIHRyYWlu aW5nIGFuZCB0aGFuayB5b3UgZm9yIGtlZXBpbmcgdXMgcG9zdGVkIQ0KDQpNaWtlIEMuDQoNCg0K DQpGcm9tOiBvd25lci1waWV0ZW5wb2wtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBbbWFpbHRv Om93bmVyLXBpZXRlbnBvbC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2Yg UmljayBTY2hyZWliZXINClNlbnQ6IEZyaWRheSwgU2VwdGVtYmVyIDE4LCAyMDE1IDg6MjYgUE0N ClRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBQaWV0ZW5wb2wtTGlz dDogUmVwb3J0aW5nIGluDQoNCldlbGwsIGl0cyBiZWVuIGEgd2hpbGUgc2luY2UgSSBsYXN0IHBv c3RlZCBzbyBJIGp1c3Qgd2FudGVkIHRvIGxldCBldmVyeW9uZSBrbm93IGhvdyB0aGUgUGlldCBQ cm9qZWN0IGhhcyBiZWVuIHByb2dyZXNzaW5nLiBJIGRpZCBteSBmaXJzdCB0YXhpIHRlc3Rpbmcg YWJvdXQgYSBtb250aCBhZ28uICBZZXN0ZXJkYXkgSSBoYWQgYSBEQVIgY29tZSBvdXQgYW5kIGlu c3BlY3QgdGhlIHBsYW5lLCBzbyBub3cgSSBoYXZlIG15IEFpcndvcnRoaW5lc3MgQ2VydGlmaWNh dGUuIFRoZSBpbnNwZWN0aW9uIHdlbnQgdmVyeSB3ZWxsLCB0aG91Z2ggSSBhZG1pdCB0aGF0IEkg d2FzIGEgbGl0dGxlIG5lcnZvdXMuICBUaGUgREFSIHRoYXQgSSB1c2VkIHdhcyBMb3dlbGwgRmFy cmFuZC4gTG93ZWxsIHdhcyB0aGUgdGVzdCBwaWxvdCBmb3IgdGhlIE1pbmktTWF4IGxpbmUgb2Yg aG9tZSBidWlsdCBhaXJjcmFmdCBhcyB3ZWxsIGFzIHRoZSB0ZXN0IHBpbG90IGZvciB0aGUgZmly c3QgcG93ZXJlZCBwYXJhY2h1dGUgYWlyY3JhZnQuIEhlIGFsc28gc2VydmVkIGFzIHRoZSB0ZXN0 IHBpbG90IGZvciBtaWxpdGFyeSBlamVjdGlvbiBzZWF0cy4gSGUgaGFzIHJlYWxseSBoYWQgYW4g aW50ZXJlc3RpbmcgY2FyZWVyLiBIZSBoYXMgYmVlbiBhY3RpdmVseSBpbnZvbHZlZCB3aXRoIHRo ZSBFQUEgc2luY2UgdGhlIGVhcmx5IGRheXMgYW5kIHdhcyBvbmUgb2YgdGhlIGZpcnN0IGNlcnRp ZmllZCBEQVIncy4gVGhlIEVBQSBkaWQgYSB0aW1lbGVzcyB2b2ljZXMgaW50ZXJ2aWV3IHdpdGgg TG93ZWxsIHRoYXQgaXMgcHJldHR5IGludGVyZXN0aW5nLg0KDQpIZXJlIGlzIGhvdyBOWDQ3OFJT IG5vdyBsb29rcy4gSSBhbHNvIHVwbG9hZGVkIGEgWW91dHViZSB2aWRlbyBvZiB0aGUgZmlyc3Qg dGF4aSB0ZXN0aW5nLCBoZXJlIGlzIHRoZSBsaW5rLg0KaHR0cHM6Ly93d3cueW91dHViZS5jb20v d2F0Y2g/dj1HSE9sdnVpenVjNA0KDQpJIGFtIHdvcmtpbmcgb24gbXkgdGFpbHdoZWVsIGVuZG9y c2VtZW50LCBzbyBob3BlZnVsbHkgSSBjYW4gZmx5IGl0IHNvb24uDQoNCg0KW2NpZDppbWFnZTAw MS5qcGdAMDFEMEY0NkYuMjQzQUUwRDBdDQoNClJpY2sgU2NocmVpYmVyDQpOWDQ3OFJTDQpWYWxw YXJhaXNvLCBJTg0KDQoNCg= ________________________________________________________________________________
Subject: Last Call! 12th Annual Alternative Engine Round-Up and
Experimental Aircraft Fly-in
Date: Sep 21, 2015
>From Pat Panzera: Friends=2C =0A =0A =0A =0A It=92s just a few days away! =0A =0A 12th Annual Alternative=0A Engine Round-Up and Experimental Aircraft Fly-in is this Saturday=2C Septem ber 26th=2C=0A at French Valley Airport (F70) Murrieta=0A California=2C (Near Temecula on the Los Angles Sectional). =0A =0A It=92s a one-day=2C totally free event (there might be a $7=0A tie-down fee imposed by the airport) and the 10-day forecast calls for seve re=0A clear! http://www.weather.com/weather/tenday/l/Temecula+CA+92592:4:US =0A =0A While the experimental aircraft on display (hopefully yours!!!) will be the feature=2C we=92ll also have=0A educational forums all day inside a very nice air-conditioned building with =0A real bathrooms. =0A =0A Here=92s the line-up:=0A =0A 8:00am - Arrivals and parking=2C EAA Chapter 1279=0A =0A 9:00 am - Automobile=0A Engines in Experimental Aircraft=2C Pat Panzera=0A =0A 10:00 am - Caravella=0A Aerospace presents the CaraVellair Prototype Roadable Aircraft=2C Joe Carav ella=0A =0A 11:00 am - Revmaster R-2300 and R-3000=2C Joe Horvath=0A =0A 12:00 pm - Pegasus=0A Power Systems - The O-100 Engine(1/2 O-200)=2C Pete Plumb=0A =0A 1:00 pm - Ellison=0A Throttle Body Injectors The KR-2 by=0A nVAero=2C Steve Glover=0A =0A 2:00 pm - Building=2C flying and maintaining the tandem-wing=0A Viking Dragonfly=2C Tom Hall=0A =0A 3:00 pm - Corvair Confab - looking for a presenter!=0A =0A 4:00 pm - Rotary Round-up=2C Mazda Rotary Engines for Aircraft=2C lookin g for=0A a presenter!=0A =0A 6:00 pm - Dinner at the airport Restaurant. Nothing formal=2C=0A just join us. EAA Chapter 1279 =0A =0A Commercial displays: * Revmaster Aviation ' unveiling their new turbocharged Revmaster R-2300 * Pegasus Power Systems - The O-100 Engine * Caravella Aerospace - the CaraVellair=0A Prototype Roadable Aircraft =0A =85and hopefully Tom Aberlee=2C Reno record breaking Phantom biplane. ...and of course displaying is FREE! =0A =0A If you=92d like to display or volunteer for presenting a forum=2C please co ntact me=0A ASAP!!!=0A =0A =0A =0A =0A =0A Thanks! And I humbly apologize if you get this message more than=0A once. It just means that you and I are on multiple email lists together. Oh yeah! PLEASE forward this message to anyone you think=0A might be interested in=2C especially email groups that are about homebuilt =0A aircraft. Pat Panzeraeditor(at)contactmagazine.com =0A =0A Our Website: www.contactmagazine.com=0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A .=0A =0A =0A =0A =0A =0A =0A __=2C_._=2C___=0A =0A =0A =0A =0A =0A =0A ________________________________________________________________________________
Subject: Tillotson Carb
Date: Sep 21, 2015
Does anyone know of a BHP Corvair Piet with a Tillotson carb? Gary Boothe NX308MB ________________________________________________________________________________
Date: Sep 21, 2015
Subject: Re: Tillotson Carb
Hey Gary Duane Deuey in Faribault Mn. has one & Doug Ward at Log cabin airport in Mondovi Wi. has one. Cheers Bob Poore. -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Mon, Sep 21, 2015 3:36 pm Subject: Pietenpol-List: Tillotson Carb Does anyone know of a BHP Corvair Piet with a Tillotson carb? Gary Boothe NX308MB ________________________________________________________________________________
Date: Sep 21, 2015
Yes, Duane Duea has one based in Faribault, MN. His airplane is the sister ship to The Last Original. They were built at around the same time. It is complete with cooling fan and a Tillotson X carb. Greg Cardinal Minneapolis From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Monday, September 21, 2015 3:35 PM Subject: Pietenpol-List: Tillotson Carb Does anyone know of a BHP Corvair Piet with a Tillotson carb? Gary Boothe NX308MB ________________________________________________________________________________
Date: Sep 21, 2015
Thanks, Greg. I'll contact you off list. Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Greg Cardinal Sent: Monday, September 21, 2015 5:35 PM Subject: RE: Pietenpol-List: Tillotson Carb Yes, Duane Duea has one based in Faribault, MN. His airplane is the sister ship to The Last Original. They were built at around the same time. It is complete with cooling fan and a Tillotson X carb. Greg Cardinal Minneapolis From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Monday, September 21, 2015 3:35 PM Subject: Pietenpol-List: Tillotson Carb Does anyone know of a BHP Corvair Piet with a Tillotson carb? Gary Boothe NX308MB http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 21, 2015
Gary, I have one that was owned by BHP. I obtained it from Vi Kapler several years ago. They were installed on Ford model B's. Pretty sure that Virl Deal from Iowa has one too. I am also aware of a corvair powered Heath Parasol with the Tillotson carb. What are you doing ? Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447326#447326 ________________________________________________________________________________
Date: Sep 21, 2015
Trying to help a Pietenpoler in Oregon, Jerry Carlisle. He has a BHP Corvair, that once belonged to Bernard, as well as the carb. He is having difficulty making the combo work. Gary Sent from my iPhone > On Sep 21, 2015, at 6:52 PM, dwilson wrote: > > > Gary, I have one that was owned by BHP. I obtained it from Vi Kapler several years ago. They were installed on Ford model B's. Pretty sure that Virl Deal from Iowa has one too. I am also aware of a corvair powered Heath Parasol with the Tillotson carb. What are you doing ? > > Dan > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447326#447326 > > > > > > > > > > ________________________________________________________________________________
Date: Sep 22, 2015
... better readability. [IMG]https://sites.google.com/site/pietenpolplanpackages/pietenpol-plan-packages/suppemental-plan-packages/AirSpeed%20Pic.JPG?attredirects=0[/IMG] WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447332#447332 ________________________________________________________________________________
Date: Sep 22, 2015
HI Rick, Your plane looks awesome!! What did your final weight come in at? -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447336#447336 ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Sep 22, 2015
Gary, Very nice. :) Looks a lot familiar to me. Cheers, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447345#447345 ________________________________________________________________________________
Date: Sep 22, 2015
Since 41-13 was written many decades ago, are there any updates? Specifically, the chart indicates a difficulty in gluing with white cedar. Does it glue better with modern epoxies? Any experiences? Cedar is far more available around these parts. -------- Andy Garrett 'General Purpose Creative Dude' Haysville, Kansas Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447356#447356 ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Sep 22, 2015
Last revision is dated 1998, not many decades ago. Not to say there aren't needed changes, but it is not as old as you imply. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447359#447359 Attachments: http://forums.matronics.com//files/screen_shot_2015_09_22_at_90928_pm_172.png ________________________________________________________________________________
Date: Sep 22, 2015
On 9/22/2015 7:37 AM, Chris Rusch wrote: > > HI Rick, > > Your plane looks awesome!! What did your final weight come in at? > > -------- > NX321LR > Now test flying!! > Mitsubishi Powered > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447336#447336 > > Thanks Chris. My final weight was 758# . I was hoping for a lighter weight, but I do have the straight axle gear, 3 piece wing, starter and a heavier paint color. By that I mean that I had to paint the Piet white to hiding, then paint it yellow. That more or less doubles the total paint weight. Rick Schreiber NX478RS First test flight planed Saturday 9/26/15 ________________________________________________________________________________
Date: Sep 22, 2015
Rick, You are very close to my weight...sure looking forward to your first flight report... Gary NX308MB Sent from my iPhone > On Sep 22, 2015, at 6:12 PM, Rick Schreiber wrote: > > >> On 9/22/2015 7:37 AM, Chris Rusch wrote: >> >> HI Rick, >> >> Your plane looks awesome!! What did your final weight come in at? >> >> -------- >> NX321LR >> Now test flying!! >> Mitsubishi Powered >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=447336#447336 > Thanks Chris. > My final weight was 758# . I was hoping for a lighter weight, but I do have the straight axle gear, 3 piece wing, starter and a heavier paint color. By that I mean that I had to paint the Piet white to hiding, then paint it yellow. That more or less doubles the total paint weight. > Rick Schreiber > NX478RS > First test flight planed Saturday 9/26/15 > > > > ________________________________________________________________________________
Date: Sep 22, 2015
I glue cedar fairly regularly and have not had any problems with using even aliphatic resins (yellow glues). Certainly can't imagine any modern epoxies having any problems. I do not have experience using resorcinol or casein glue with cedar. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447363#447363 ________________________________________________________________________________
Date: Sep 22, 2015
This reply is based on my experience working with Douglas fir, of which there is a LOT in Oregon!!! It is readily available in all grades, is affordable (even free, if you look in the right places), and is definitely suitable for building airplanes out of. Beefy sections like wing spars and 1x1" longerons are easy to work with but rib capstrips will put it (and you) to the test due to the slenderness and small dimensions of the pieces. DF is more brittle than spruce and depending on how the grain is oriented relative to the bend you are trying to put into it, you can snap it easier than spruce. Nailing or stapling into it (such as when attaching gussets) is far more likely to split DF than spruce if you nail or staple too close to the edge, and even if you don't hug the edge it likes to split anyway. Thin, short wire staples into DF are best for holding gussets in place while they glue. The other thing about Doug fir is that the grain lines are harder than the wood between the lines. When you drill or nail parallel to a grain line (not through it), your drill bit or nail or staple will want to follow the grain line away from the center that you're trying to drill or nail. It's a bit fussy but it makes up for its shortcoming by being affordable, strong, and -to my nose, at least- pleasantly aromatic, where spruce has almost no smell at all. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447364#447364 ________________________________________________________________________________
Date: Sep 23, 2015
41-13 now lists Western Hemlock as the direct substitute for Sitka Spruce. Clif > Last revision is dated 1998, not many decades ago. Not to say there aren't > needed changes, but it is not as old as you imply. > Semper Fi, > Terry Hand > Athens, GA ________________________________________________________________________________
Subject: Off Topic
Date: Sep 23, 2015
Hi Pieters, If any of you find your way to Virginia do yourself a huge favor and spend some time with Jack and Karen Phillips at Bedford Landing B&B. While on Vacation my wife and I found ourselves not too far away from Smith Mountain Lake. We called Jack and they had a room available. We had never meet Jack or Karen before and this was the perfect opportunity. We had a wonderful time with them. The airport is very friendly, Jacks planes are beautiful and the B&B was superb. I only wish that I had flown my plane in there to stay with them. Perhaps next time. Next time we find ourselves in VA we will make it a point to stay again. Thank you Jack and Karen for the wonderful memories. Cheers, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447384#447384 ________________________________________________________________________________
Date: Sep 24, 2015
What Bill said - your attention to detail is superb! On 09/18/2015 09:32 PM, Bill Church wrote: > > Very sharp, Rick. > Congratulations. > > Bill C. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447216#447216 > > > > > > > > > > -- Dan Yocum yocum137(at)gmail.com ________________________________________________________________________________
Subject: Off Topic
Date: Sep 25, 2015
Thanks, Scott! It was great to finally get to meet you. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Wednesday, September 23, 2015 12:40 PM Subject: Pietenpol-List: Off Topic --> Hi Pieters, If any of you find your way to Virginia do yourself a huge favor and spend some time with Jack and Karen Phillips at Bedford Landing B&B. While on Vacation my wife and I found ourselves not too far away from Smith Mountain Lake. We called Jack and they had a room available. We had never meet Jack or Karen before and this was the perfect opportunity. We had a wonderful time with them. The airport is very friendly, Jacks planes are beautiful and the B&B was superb. I only wish that I had flown my plane in there to stay with them. Perhaps next time. Next time we find ourselves in VA we will make it a point to stay again. Thank you Jack and Karen for the wonderful memories. Cheers, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447384#447384 ________________________________________________________________________________
Subject: NX478RS first flight
Date: Sep 26, 2015
Well fellow Pieters today was the day. The first flight of NX478RS occurred today at about 12:45 without any problems. For years I told everyone who asked, that it would fly "Friday" - just never what week, or year. Well I only missed it by a day. Here are some shots of the occasion. The first flight was done by a good friend of mine who also works for the FAA. So everyting had to be done right. Rick Schreiber VPZ Valparaiso IN *Take off!!!!* take off 1 * Climbing nicely* take off 2 * **Good first Landing with a little wind gusts* landing * Happy smiles for Kris the test pilot!* happy ending ________________________________________________________________________________
Date: Sep 26, 2015
So very happy for you!! Keep the news and info coming Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Schreiber Sent: Saturday, September 26, 2015 5:00 PM Subject: Pietenpol-List: NX478RS first flight Well fellow Pieters today was the day. The first flight of NX478RS occurred today at about 12:45 without any problems. For years I told everyone who asked, that it would fly "Friday" - just never what week, or year. Well I only missed it by a day. Here are some shots of the occasion. The first flight was done by a good friend of mine who also works for the FAA. So everyting had to be done right. Rick Schreiber VPZ Valparaiso IN Take off!!!! take off 1 Climbing nicely take off 2 Good first Landing with a little wind gusts landing Happy smiles for Kris the test pilot! happy ending ________________________________________________________________________________
Date: Sep 26, 2015
Subject: Re: NX478RS first flight
Excellent, excellent, excellent! Congratulations! On Sat, Sep 26, 2015 at 6:25 PM, Gary Boothe wrote: > So very happy for you!! Keep the news and info coming > > > Gary Boothe > > NX308MB > > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Rick Schreiber > *Sent:* Saturday, September 26, 2015 5:00 PM > *To:* pietenpol-list(at)matronics.com > *Subject:* Pietenpol-List: NX478RS first flight > > > Well fellow Pieters today was the day. The first flight of NX478RS > occurred today at about 12:45 without any problems. For years I told > everyone who asked, that it would fly "Friday" - just never what week, or > year. Well I only missed it by a day. Here are some shots of the occasion . > The first flight was done by a good friend of mine who also works for the > FAA. So everyting had to be done right. > Rick Schreiber > VPZ > Valparaiso IN > > *Take off!!!!* > [image: take off 1] > > *Climbing nicely* > [image: take off 2] > > *Good first Landing with a little wind gusts* > [image: landing] > > *Happy smiles for Kris the test pilot!* > [image: happy ending] > ________________________________________________________________________________
Date: Sep 26, 2015
OK,OK. Tomorrow after church I will go get something done. Man it motivates me to get mine completed Great job Ken. On Sep 26, 2015 7:37 PM, "Ken Bickers" wrote: > Excellent, excellent, excellent! > > Congratulations! > > On Sat, Sep 26, 2015 at 6:25 PM, Gary Boothe wrote : > >> So very happy for you!! Keep the news and info coming >> >> >> >> Gary Boothe >> >> NX308MB >> >> >> >> *From:* owner-pietenpol-list-server(at)matronics.com [mailto: >> owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Rick Schreiber >> *Sent:* Saturday, September 26, 2015 5:00 PM >> *To:* pietenpol-list(at)matronics.com >> *Subject:* Pietenpol-List: NX478RS first flight >> >> >> >> Well fellow Pieters today was the day. The first flight of NX478RS >> occurred today at about 12:45 without any problems. For years I told >> everyone who asked, that it would fly "Friday" - just never what week, o r >> year. Well I only missed it by a day. Here are some shots of the occasio n. >> The first flight was done by a good friend of mine who also works for th e >> FAA. So everyting had to be done right. >> Rick Schreiber >> VPZ >> Valparaiso IN >> >> *Take off!!!!* >> [image: take off 1] >> >> *Climbing nicely* >> [image: take off 2] >> >> *Good first Landing with a little wind gusts* >> [image: landing] >> >> *Happy smiles for Kris the test pilot!* >> [image: happy ending] >> > > ________________________________________________________________________________
Date: Sep 26, 2015
Steve, congratulations are for Rick and his test pilot. I'm just enjoying the flight vicariously a thousand miles to the west. Cheers, Ken On Sat, Sep 26, 2015 at 6:44 PM, Steven Dortch wrote: > OK,OK. Tomorrow after church I will go get something done. > > Man it motivates me to get mine completed > > Great job Ken. > On Sep 26, 2015 7:37 PM, "Ken Bickers" wrote: > >> Excellent, excellent, excellent! >> >> Congratulations! >> >> On Sat, Sep 26, 2015 at 6:25 PM, Gary Boothe >> wrote: >> >>> So very happy for you!! Keep the news and info coming >>> >>> >>> >>> Gary Boothe >>> >>> NX308MB >>> >>> >>> >>> *From:* owner-pietenpol-list-server(at)matronics.com [mailto: >>> owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Rick Schreibe r >>> *Sent:* Saturday, September 26, 2015 5:00 PM >>> *To:* pietenpol-list(at)matronics.com >>> *Subject:* Pietenpol-List: NX478RS first flight >>> >>> >>> >>> Well fellow Pieters today was the day. The first flight of NX478RS >>> occurred today at about 12:45 without any problems. For years I told >>> everyone who asked, that it would fly "Friday" - just never what week, or >>> year. Well I only missed it by a day. Here are some shots of the occasi on. >>> The first flight was done by a good friend of mine who also works for t he >>> FAA. So everyting had to be done right. >>> Rick Schreiber >>> VPZ >>> Valparaiso IN >>> >>> *Take off!!!!* >>> [image: take off 1] >>> >>> *Climbing nicely* >>> [image: take off 2] >>> >>> *Good first Landing with a little wind gusts* >>> [image: landing] >>> >>> *Happy smiles for Kris the test pilot!* >>> [image: happy ending] >>> >> >> ________________________________________________________________________________
Subject: NX478RS first flight again with pictures
Date: Sep 26, 2015
I dont know if the photos came through the first time so I'll try again. Well fellow Pieters today was the day. The first flight of NX478RS occurred today at about 12:45 without any problems. For years I told everyone who asked, that it would fly "Friday" - just never what week, or year. Well I only missed it by a day. Here are some shots of the occasion. The first flight was done by a good friend of mine who also works for the FAA. So everything had to be done right. Rick Schreiber VPZ Valparaiso IN *Take off!!!!* take off 1 * Climbing nicely* climb out * **Good first Landing with a little wind gusts* landing * Happy smiles for Kris the test pilot!* happy ending /9j/4AAQSkZJRgABAgAAZABkAAD/7ACFRHVja3kAAQAEAAAACgADAHAAAAA2ACAAIAAgACAA IAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAA IAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgAAD/7gAOQWRv YmUAZMAAAAAB/9sAhAAUEBAZEhknFxcnMiYfJjIuJiYmJi4+NTU1NTU+REFBQUFBQURERERE REREREREREREREREREREREREREREREREARUZGSAcICYYGCY2JiAmNkQ2Kys2REREQjVCRERE RERERERERERERERERERERERERERERERERERERERERERERET/wAARCAO2BioDASIAAhEBAxEB /8QAnwAAAwEBAQEBAAAAAAAAAAAAAAECAwQFBgcBAQEBAQEBAQAAAAAAAAAAAAABAgMEBQYQ AAICAQMDAwMDAwMCBQQBBQABEQIDITESQVEEYSITcTIFgZEUoUJSsSMVwWLRkjNDU/Dhcgbx giSiYzQRAQEBAAEDBAEDBAIBBAIDAAABEQIhMRJBUQMTYXEiBDJCUhSBkWLwobEFgiPRM0P/ 2gAMAwEAAhEDEQA/AOoAA9TzGAAAAAAMAAAGIAGAAAAAwAAAAABgAABQAAAAwAAAAAAAAGAA AAAAMAAAAAAAAAGAAAAAAAwAAAAAAAAGAAAAAAAAMAAAAAAAAAGAhgAAAAAAAAAwAIAAAAAA AABgAAAAAAAAAAAAMAAAAAAAAAAAAAAAAYAAAAAAAAAAAAAAAAAADABAMAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AQDEAAAAAAAAAAAAAAIBgAgGIAAAAAAAAAAAAAAQAAAAAAAAAAhgAgAAAAAAAAABDABAAAcQ xDIoAAAAAAGAAADAAAAAAABgAAAAMQwAAAAAAKGAAAAAAAwAAAAAAAYAAAAAAAAxDAAAAAYh gAAAAAAAAAwAAAAAAAYAAQAAAAAAUDEMAAACAAAKAAYQAAAAAAAADAAAAAAAAAAAAAAABgAA AAAAAAAAAAAwAAAAAAAAAAAAAAAAAAAAGAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIBiAAAAAAAAAAAA AAAQxAAAAAAAAAAAAAAAIYAIAAAAAAAAAAQwAQAAAAAAAAAIBgBwjEMigAAAGIYAAAAwAAAA ABgABQAAEMAAAAAKAAGAAAAAAAAMAAAAAAYhgAAAAAAAwAAAAABgIYAAAAAAAMBDAAAAAAGA AAAAAAAAAADAAAAAIAAYAAAAAAAAAAAMAAAAAAAAAAAAAAYAAAAAAAAAAAADAAAAAAAAAAAA AAAAAAAAAYAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAFAAAQAAAAAAFAAAQA AFAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAYgAAAAAAAAAAAAAAAAAQDEAAAAAA AAAAAgGIAAAAAAAAQxAAAAAAAAAAAAhgBxAAEUAABTAACAAGAAAAAAADAAAAAAGAAAAAAAxD AAACgAAAYAAAAAADAAAAAAABgAAAAAAADEMAAAAAAYAAAAAAAAxDCAAAKAAAAYhgAAAAAAEA xDAAAAAAAAGIYAAAAAAAAAAAMQwAAAAAAAAAAAYhgAAAAAAAAAAAAAAAAAAAwEMAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAACAAACgAAAAAAAAAAAABiGIAAAAAAAAAAqAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAQwAQDEAAAAAAAAAAAAAAAAIAAAAAAAAAAAAAAQDEFAAAA AAAgAAAAAAAAAAAAjiAAIoAAAYAAAMQwAAAKBiGEAAAUAABDAAAAAAAYAUAAAAMQAMAAAAAA BgAAAAAAAwAAAAABgAAAAAAADEMAAAAAAAAYAAAAAAAADAAAAAAAAAIYAAAAAAAAAAwAAAAA AAAoAACGAAAAAAAAAAAAADEMAAAAAAAAAAAAAAAAAAYgABgAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAABFAAAAAAAAAAAAAAAAAAAAAABUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAACAAAAAAAAAAAAAAAAoAACEAwAQAAAAAAAAAAhiCgAAAAAAQwABAABAAAAAAA cIwAigYgAYAAAMQwAAAKAAYQAABQMQwgAAAAAAGAAUAAAAMQwAAAAAAAYAAAAAADEMAAAAAA YAAAAAAAAxDAAAAAAABgAAAAAAMQAMAAAAAAAAYAAAEAAAAAAFAwAAAACAAAAAAAYAAAAAAA AAAxAADEMAAAAAAAAAAAAAAAAAAAAKYAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAABAAABQAAAAAAAABUAAAAAAAAAAAAAAAAAAAAAAAAAAFAAAAAAAAAAAAAAAAEACAKA GIAAAAAAAAAAAAACAAAKBDEEAAAAAAAAAAAhiAAAAoAAAAAAEAAEAAAAAABxAAEUDEMKAAAA YhhAAAADEMKAAAAYhhAAAAAAwAAAoAAAAYhgAAAAAAAwAAAAAAGIYAAAAAAwAAAAAAAYAAAA AAwEMAAAAAAAAAABgAAAAAAMQwAAAAAAABiGAAAAAAAAAAEAxDCgAAIAAAAAAAGAAAAAUAAA AAAQAABQAAEAAAAAAAxDEFMAAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAoAACAAAgAACgA ACgAAAAAAAAAgAAAAAAAAAAAAAAAAAAAAAACgAAIAAAoAAAAAQQDAAEMQBQAAAAAAAAAAAAA AABAAAFAAAAAAEAgAAAAAAAAAAABAABQAAAAAAAhiAAAAAAADiAAIpgAAAAAAMQwAAAIBiGF AAAAMQwAAAIAAYAAAUAAAAMQwAAAAGIAGAAAAAAMAAAAAABiGAAAAAAADAAAAAAAAGAAAAAA AAMQwAAAAAAAYAAAAAAAAAMBDAAAAAAAAAAAYAAQAAAAAAAAAADEMAAACgAAIAAAAAAKAAAA AAIAAAAAAKAAAgGIAGAgAYCABgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAABQAAAAAAAhgAhgACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIB AAAAAAAAAAAIAAAAAAAAAAKAAAEAAAAABHEAARoDAAAAABgAAAAADAAAAAAAYhhAAAADEMoA ACAAAKGAAAAAAAxDAAAAAAGAAAAAAADAAAAAAAAGAAAAAAAAMQwAAAAAAABgAAAAAAAAMBDA AAAAAABgAAAAAAAAAAAAMAAIAAAAAAAAAABgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFA AAQxAADABAAwAAAAAAAAAAAAAACgAAAAAAAAAgAAAAAAAAAAAAAAACAAAKAAAKAAAgAACgAA IAAAoAAAAAAAAAAABAAAAAAAAAAAAAAQAABQAAAAAAAAAQAABQAAEAAAAIYgAAAAAAAAAAAQ wAQAAAAAAAABSAYggAAA4gACNAYAAAAwAAAAAAAYAAAAAAwAAgAAABgAAAAUAxDAAAAAAAAG AAAAAAAAAwAAAAABgIYAAAADEMAAAAAAAAYhgAAAAAAAwEMAAAAAAYAAAAAABAAAFMAAAAAA AAAgGIAGAAAAAAAAAAAAAwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApiAAhgIA pgIAGAAAAABAAAFAAAQAAAAAAUAABAAAAAAAAAAUAABAAAAAAAAAAAAAAAAAAAAAAAAAAgAY gAAAAAAAAAAAAAAoAACAAAAAACgAAAAACAAAAAAAAAAAQwAQAAAAAAAAAAAAAIYgAAAAAAAA AAEAxAcQABGjAAABiGAAAAAAMAAAAAAAGAAEAAMAAAAAACgGIYAAAAAAwAAAAAAABiGAAAAA AADAAAAAAAAGAAAAAAADAAAAAAAAGAAAAAAAAADAAAAgAAAAAAGAAFAAAQAAAMQwAAAAAAAA AAAYCABgAAAAAAAAAAABQAAEAAAAAAFAAAQAAAAAAAAAAAABQAAAAAAAAAQAABQMAABDAIAA AoAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAMBAABQADCEAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAhgAgGACAAAAAAAAAAABAAAAAAAAAAAAhiCuIYhkUAAw EMAAAAAAYAAAAAAxDAAAAAYhhAAAUAAADAQwAAAAGIYAAAAAAAAwAAAAABiGAAAAAAAAMQwA AAAAAAYAAAAAADEMAAAAAAAAYAAAABAAAADAAAAAKAAAgABhQAAEAAAAAAADEMAAAAAAAAAA AAAAAAAAAAKAAAgAAAAAAoAACAAAAAACgAAAAACAAAKAAAhiAAGAgCmAhgAAAQAAAAAAAAAF AAAQAAAAAAUAAAAAAQAAAAAAAAAAAAAAAAAAAAgAYAAAAgGACAYBQIACAAAAAAAAAAAAAAAA CgAAIAAAAAAKAAAgAAAAAAAAAAEMQAAAAAAAAAAAIYgAAAKAAAAAADhGAEUDEMAAAAAAAGAA AAAAMAAAAACGAAAAAFUAAAMAAIAAAAYAAAAAAAADAAAAAAAYhgAAAAAAADAAAAAAGIYAAAAA AAAwAAAAAAAAGAAEAAAAADAAAAoAAAAAAAAGEAAAAAAAAAAAxDAAAAAAAAAAAAAAAAAKAAAA AAIAAAoAACAAAKAAAgAACgAAAAAAAAAAAAAAACABiAAAApiAYAAgABgAAAAAAAAAAAQAAAAA AUAABAAAFAAAAAAAAAAAAAQAAAAAAAAhgIYAACGAAIACgAAIAAYCAACgAAIAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAQDEAAAAK1uKk83D+QrbI5s+PaNj0MmSuNTY8LzL3Vvk+OKP+458uWVq R7uPJXIprsWeb4OdL21bdX6HpG5diWYBDEVAAxAAAAVxAAEUDAAAAAAGAAAAAAMAAAAAgABg AABQAAAAwAAAAAAAYAAAAAAAAAMAAAAAAAAYAAAAAAAMAAAAAAAAYAAAAAAAAAMAAAAAAYhh AAAAAAAAwAAAACgAAAABhAAAAAAAAAAAMQwAAAAAAAAAAAAAAAAAAAAAAAAAACgAAAAAAAAA gAACgAAAAAAAAAAAAAGIAgAAAAAAoAAAAAYQgAYCGABQAAAAAAAAAAAAEAAAUAAAAAAQAABQ AAEAAAUAABAAAACGAAAAAAAAAAAAAAACGACAYgABgAgAYCAAAAAAoAYggAAAAAAAAAAAAAAA AAAAAAAAQDADzvyKdK/Ly0r/AG9zhWfH5GL3ckuiXc9XzPG/kViYa2PNv4lqXTs+Nf7nGh5+ eyunEeI81Ys4j/Q9bFl+SdDz3hlN0e+ig7fGo8dPdv3NfHfQ5R0AJNW1Wozs5kAwAQAEAcQw AjQAAABgAAAAADEMAAAAAAYAAAVAAAFAxDAAAAgABgAAAAAAAAAAMAAAAAABgAAAAAAAAMAA AAAABgAAAAAAAAAwAAAAAAAYAAAEAAAAMQwAAAAAAAAAAAYAAAAAAAAAMQwEMAAAAAAAAAAA AAAAAAAAAAAAAAAAGAgAAAAAAAAAAAAoAAAAAAAAAAAAAAAAABiAAAAAYCAAGIAGIAhgABQA AAAABAAAFAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAABQAAAAABAAAAAAAAGLzLlxWq6l5 brHV2ZNn/S4Sy1mGXM7HlWyqqa46vU08TzOd1Ti/U48fl25W7wekAAd3MAAAAAAAIYAIBgAg AYCABgIBiAAAAAAAAADJ56zpqNVqBjkor+6X9EyPGyu3ts9V0JpjpOD8jneOvFJWVtDvOfyf Hx5lF9H0fUnLt0I86mWmGtacpt1lHVkzOlHW1XeVOhhny0x34USs1/cb4ElaZ1exzl9HSzZr DxMkVmjj/tbPUWxwWwUxO160htz9To8XJa9PcoNcPZmugAA6MAAADiAAI0BgAAAAADEMAAAA AAYAAAAAAFAADCAAAAAAAYAAAAAAAAAAwAAAAAAAYAAAAAAAAxDAAAAAAGAAAAAAAAMAAAAA AAABgABAAAADEMAAACgAAAAAAYAAQAAAAAAAADAAAAAAAAAAAAAAAAAAABgIBiCgBgEIBgAC AAoAACAAAAAAAAAAoAAAAAAAAAAAAAAAAAAAAABgIBgAAAAIYAEAAAUAAAAAAAAAAAABAAAF AAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAcdrZKX92qOw4vLxL76uLfU5/JubPRrj 3FMlvmemjWgsnkY81vgyJqXBXi3is22M6ePW13mq+Uvr0MS2z9WrP/Zw2pmx0tXLRyvt1Wwf jMtXliq1jVvc1/I+K8jtnu1alVsiPHxWXHKqKnbonX6GPHK3uxtS+RZnVNOLavqesc9cdMjb ddZTb9ToO/GY5cgAAbZAAAAAAAAAAAAAAAAAAAAIBgAgGRkdlVuur6SFOz4pt9DxVmeVu326 9Tox+Vku5cSnr0ODLmtfJok0/wBzz8+UvZvjMez4+RxxulPoXaFbb9TxsWTLVTVwm9melTP9 tL9ewnLei2erV+XSuja5djmzvJzTcKr6nP8AkfEdnzxwo1a7mdM1061u2uuwvLelJPWLyeMl Z3rdR/d/9jXxrKzSxxL3ZFrvLdpe2vRs5vGuq3bTa4mZZKvo9DLTLWFa3LU1x+Qq2+PjE9Tj Wb+VblS0tboef7W5a47m5yypZ0erWytqnJnlUtdjn8K3t9uzNMlbVvy5N9qnS3YxmV0LYZlh yO69yhmpr0T1cFLq6lBzr3PAp5Vq/ayf5LTmWc5yax9IB41fyNuMDt590oiDU5Qx63NTx6lH z1vJs3M6lvy7tQ7Dyhj3pGeBTy7Uaa1Ohfk7rVrQnlDHrgefj/I1a13O3Fk51k15RMaABlbP WtuM6lGoGVM9bvijUbADACgAACAAABgAAAAAAAAADAAAAAAGAAAAAAAAAAMAAAAAABgAAAAA AAAMAAAAAAAABgAAAAADEMIAAAoAACAAGFIYjHL5NcancI3A83P+RURQ8/J5mR7tk2Lj6DnW YnUpNM+ddsjcy5fQ9bwbNY07MnkuOwDmv5tKtrqa0y1suU6F1Ggzkv5tatr9jLB56tbg9H6i 2Qx6ACTkl5azxnUosAAAAACABgAhgAAAAAABLulq+gVQGdc1bbM0AAAAgAACgAAAAAAQDAIQ DAKQDEAAMQAMQAMQAEAwAKQwABDAAAAAAAAAAAAAAAIAAAoAAAAAAgAAAAAAAAAAAAAAAAAA AAAAAAAAM/mry49TQ8zybW8XIslrL42+2prh8p2af9q3k5Tnlzk34+sdwAmmpA6sAAAAAAAA AAAAGBLOfzMH8jFbGtGzoBks2K8DGsni3WPJV/rs0dmO3x1412fSdjl8t5PKbtWa2q41Ix4F Xla90m/2PFbl6O86zq68WW1W26xCac7MimPFd8n2N8LxZqV902S1f0M8mPGslclVpZaW6HTL JvokvXHXW2WmK1qxey+2qKx5rUonmXue8BhxutXrq9mcStF2sluUTtqdLysxiTdeqnKlDObw 86y1hdNjpOsusWYAACoAA4fJzNuMbcp6ozy5TjNqya7jj8yzq6uuvc6cVnaqbUMw8zHW1NXx /wC5GeXWdGuPd0UfKqZR5P8APt47rhyNT3PSWVPH8j2g1OUqWY0A5sHlVzOEdJZZeyWYAACo AAAAm1eSgoAOHL4UY+OPV/8AccNsdfEtN2nb/oe4zhzeJTg/l9y3mxx5cPZucvd4vk+PfLb5 MLir6F4fJdbKjmFqaLhgXLEmnOnXQu2euVcrKWjjK6O11rkavMKN2Y/c/c4v0RKzVfuto10N seFZ7PK3oa79k7dXHlx9bPXcd8VJ5V0TWoZdLtxNTDNkpjn/AEOVvXG/RVclfEslV77s73em XH6vueUsny2mdI0R1K3HG09PVG5y9EsdFM7x33SXZHo/IuPJngvJx+9xod/j+Rzaxtpwjrw5 WxjlHfhs7TPQ1M8WP41G5odvRz9XxNcaRNqpuJLd1+pkquzOMbWrJaIuBWXFQOqlEUO0Etsq qVpSJs3X7i4hqRWtycdAeRQRXKhg25awj3fHzVrRcnsj56tm7aGtrW3E6Ue9k8mqrNXueVkz cnpuY8nAcl0LefoY6fFt/uJ2cHs1smp6HztWp9TeuXI1xThGZyyrmvdlBJ4fy3S48nAn5WRK Ezp5xnxe8S7pHh4vJyV6mlsjuPOGPW+au0mh4lcro9zot5746IeRj1APKr51up2eP5Hyb7l8 4Y6QAZtkAAAAAAAMAAAAAAAAAAJMf5NNddgNwM6Zq2UyXVqylDQwAYAAAAAAAAwAAAAAAAVr KilgUBlTMruEaknKXstlncAASioAAE5AYAAABlmy/EpMMPmK7izgluDsA56+XS1uKOgbArXV NWcvk+X8cKv7lebHCTw8t9YkW4R6uXzavHo5bPMeZsw5MOTZzvK9msXbJBDUvkC1E30T/QzF brO8luT6G+XzLXSqtELx6Y0v9x69DPyLVS0LOqVi8rZvgz2pKnRnPRpqEtTW1OGhKsbfJyFa 3Iy5QDszCuxebai4owt5Dnl1Od2M7M3NR9J42b5KJ20B+Wq34v8Ac8jFnaoqoi2VpzJZz6Yl nV9ErJ7DPDw+W2tXqep42R2rqanPUsdICkjJkVaux0ZaGGTyaVW+phfzVxjqebfK25MXljUj qv5TT0Yf8heGupw0s57ocqTl5VrHbTzr1+7Uyy+U7J67nJZPfoZy7OEXadHb43kLH7rLU7MH nWyXVWjya2US9zXHkddVuTysMfQoJOKnkP4ladTmt52RuVB18pms49bkpidRnhPyLK0rRnpe N5NbKLP3MTnDHWAAbZAAAUAABAAAFAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAA AAAAAAAAAAFAAAQAAAAAAAAAAAAABnlyrEpt10NDzfy+S2OiaUr/AEM8rktWda3y+RSyauk6 9ZObzfAxpLNi9jrv/jH0PLp5LvX214qdX3PQv5SthuruVGlWeect3zdczsi/kZsVJvZ2USuC 0g1r+Tbr/uadmjitaubHu0kvcp/0FHOqaeijXbQ5+d9F8Y9/x8yzV5I1PM8W9qW9zXCq2SYs T8nyFZWfGVNX/wDXU9M+Tp17ud49Xp2uq7j3Pn7Z/wDaVU28ibqe9inhWd4ReHPytS8cWAAd GQAClMAMsmauOOT3cGpy+Vh5NXelVuZ5WydFjH8jRVx/ItIerR5uW+PNX/b90L6HTfz747Kq UJ7TsPN42G6VlpedY6nl5ycrsduPSdWfi+KqVaTltaKTtwYoxcJ9y3ObxuDzRWrTW1n1O+aY ddFV6Lu2b48d6lvo0w0XBfQ57cazVUWnVdTp51xpKzhnkPPbHmdnouUeh05XJGJNrq8NNX0s nXaF0PSMcdceuSka7wFfIVsjxrdbmuM8YzbtagMDbLj/ACGXJix8sanvHQ855KZKzLbPayKa s8vL5Dx145UlXoeX5u/Wu3Bfj+X8SfOrjdRqb5vJV8PyY1yq/wCh51cmK3syaTskdSwrHRY6 3lPeBx53x6reM1Xw486TtrffVHZjtXJXiltpDPMo7rZaLRmuGuSydMbX6muPL0Z5QUx28Wyi k1b3rsa5M9q5HVGjrauP/c0dXOhxZUs1rZqWSa049WLsn7Vll7vVx351Vizl8O6dIiGdR243 ZrlelIBkZFNWkUNWTcJ6kZsjx1dkpg8vxKUwXdnaGt6s6MvnpwlV8X1MXnMXxdWDN8tZagOX yt1a9pxU8pYlxTTr07mbtlwTauqeqkxfk6NeKs/i2o26NPH1r2OazpxfHRnR4WTKvdkS4veT HzMNfkd8VlqtUY5cf7o1L6VFnf45vEl0sqpY62+5b1MbRXjzU2ZnC5+2ZMW9WmuSlsFeFZTb 15HLmo7Y0kpfU6clXxdrPk/Ux4u1WnoYt6tSObnkojppZ3pES+pyXpey0aiYjqdq5YFWltG/ 3Nyal6OrxvHtWs5Kp1Xc0w1ayc+PFdjss8dKK/SDndq3yJy2up1zKxuu3Hd3Upe3ocXy5fX7 u3Q7+ar7VtBn/I9GdnN8a6pPVlKyT9B/FC13ZlCraOhz7tKd+WrKrZEXsnoQi4jZZXXRGduV n3KxVbsddcaRm8sXNcyrVbj41s9NEbqq6kqqX0Jq4VKVrsV6GV7RsKl3MEymt1ZNhoYu6kj5 Gi4a6uVV9RfJHUxrZW1YW9zJhretpLdUzmx24s0dnbYYuqVGjSrdfQhWaUMl2berA1bjVk/I S2VWrt0CBNm2PNZW9u5lXit0aKLQqFg9Lxb2s9TtPLw514yi2rLp5F89lGxvjc7s2PSAhPj9 zJvnrSvI6S6y1Zx38u1LRY5s35Cz20RxXzu2r1JeUXHrYfPrktxiDa3lUThOWeCpWqFyacox 5Lj6VWkZ4vg+U1bjbY9h3VVyZqctSwZMiopZ5/keXZqF/QfmZa5q+08rI7LRFvLp0Mda826X GdDky5JczBVa8lLM8mKWjlOTWKplddT2MXnVVVyPIVNddi4JeXssj3lnrpPUu2RVUs8C9rLU 6qeRKXNmpzTxetWyeo3ZI8m/kPlKftJtmtpZNwu5J809VvD2ezIzzq+VC5MxyefZvTQ3PklZ vGx6xnbIt09jjw+arqLaM6uFWpQvLf6Vknq2TlSMii0L2NTWaTsluYZLVSlPcy8vMkoW5z43 NdNTHPlJ0rfHje8dFciq5Kt5Da02OLJfXsJWb0q5OHneM/a6eMvd04/OSfFkX8tNynqcNqNO SG41Ok52ud4vQfmOyiTSnnquj2PKrZMbuPKmR79PJpavKTnyedxtprU8euRz6Fubbl86mO3y fM+X212OFcp10HX2rUnm59DN5WrjfDfhaWpPQt+QSWm54/Oy0Ww22WWxLHZ5Hn/KuLUHAmm9 BNTuTWv7Gry1MaKP1ItohWslsxVum4bJim20pTIWTXUu1q2MLbyiyJXQsqY55HNWzWg3YuGt aOHubZH+5hTIn01NG5Rm91VVwhy2RR6DcsmASkK1S1ZOpda9yh8tDN67lWcr0IvZLREg6vGz rFpZSaPzcinjomcCT6bFKz2aKjur51u4vms1vocsKxokqxLJqi1nGpLv2K+7qQ3GhFXVp6wT zdHNlKJpZzC0HZcnr1L2R0c65FNFCJcT7SWlXYXKVpoS9VVojJzMp6diXNNUNVvZO62XUuJr ZX0iSsdlLq3COeuTj9ylGity+3QWYa7KePW1ZkfjqMi4pPucXy2iEZcrJzWUyzKPqlZbFHzu HyLrVtpnfT8guHF/cdJynZnHpgeWvO04rUeP8jxcWWhfKGPTAwxeVTJ6M3LuoAACgAACAAAK AErJ7DAAAAAAAAAAAAAAAAAAAACAAAKAAAgAACgAAIAAAAAIy5FjUsirA5b+U4Topb6Fvy8d VNtGTyhlbgcXyXzdePYwvmi2rcbEvOL4vUkDzcKdG7K30W4/5mSrltNfSB5z1MeiBngzLNXk jU1LqEMAKgEMAA8P8hneHJZXni9vbp+57h5eVZ/Iu8V6TRbtdexy+SbMb493J42bxlavsae2 uprfyP47thvX2OYb7nN4WS/ycrrSs69oNfL5P/cVpxX/ALWvtZxmyfl09U/BjxKtrPTfhbux ZPDtdPJV19prRrPkrrqlxfr6hlwOlK1pWzl629SZ/wBK2/FtS8dpdupyWx5MU8eXJXbeunE6 cfivFkdpiVvJ6FsPPHxq9+p0nG8pnsxbleevM+KqyvE0k4Win9zvv5dVjWXae5x+Xkd1XHaq 4txvrobJ4sNfhVXHRvU1P2zEvXq68N/kryhpPuaEY7cqplnWdmE3TacbnN43NP3zsdZzZvHo q+xcbdDHKdZy9ll9HSc3l0taq4KXJpgtZ1VbpppamflrK0vjX1LcvEnSjJxrj45Vokedl4e1 Yk1XqYZ/J5vhkl6awPHnplbSvxaWlOpw5ct6OkmNFRPJDbnSNT1bYazXTVHm4sbaTq/VHZjr m+VXvaat+1dkb4dYnJ0ZeEJWUycPlYVdcbKFX7WjvthrZ8nv9Tk8p3Sj+3qzXPsnEeDS2Krr eyb6QdONLdpK3c8zD5Lo9H+g8nmO9uK3TMz5JJ+VvG2vXTT2GeZhzWezf0K8/wAm+OteH93T qb85msZ1x3ZUnVq0x6Hl/wAenk+6qbqtNdzvw5bZI5aaGF1kx5IrqkpOfOTnJfRvj+2vN8nB fEtP3e5n4CvScuSunq4kvPiWW1rq8VrrxsFvItmSrSOPVHGTK6brX527tvSjWx0+NnrhlTo/ 6GOXCvinlDlQjFZKVal6NbjeXG6ZLHZ5WajSrytdW1TW30Ofx/Hv4+RWqlN3rOugsKfOtat2 pXVHV5eVUotVvsdu/wC5jt0Q8v8AFyW4ttdK+p6eO/yVVl1PMeGudyph9as7fGu6/wC3ffob 4cvRnlHSKzhCtdV3cGHlPlRpODdskYkeblxWtlmr97+5dB5VaOVXZWr0SIw1+O3yNty4lF3V 8dbcbWtPpqeazXaMXjlclu0dGK7ti45NFHU4V5NvVNbHSrOybtDjUzJ1V6PjKiwylKPJ83xn fJbNRpVjqe1jSviVauJXQ8vyfErgq+duT3qmduc2OfG9WEvjW16dIk5L2ti9ycSXm8q6SaSj 90iM1vko2nqtWcK6NvlWSkT9RVda6Tou5y47V4rWW+h2Vomovqn0MNRWZ1yrlT2tbwTXFe1l aXbs7FYsTWn9rO3JlpjpK2Z34xmscuZqKRxa7/8AgGPyHWzl+6NNCc2ersuKmzWvojLDarv8 l4XTUzLfIzo9bx6u6TyTK2Zt8tfTeP1DAqWXKq3J/h0//wAuR6cct6vk7EfG92aVso9R2aZy 1py1pyeux00otIQkka0Q5UkOtFVNidtNB6LchpLSTCoVrTqN2gXKEQn3N4yczuOKInl0G6J7 6lE2UvQyZo1H0F8dmpRqIFbQ1x47WcvQmmPubRx66GbfZYfCtd9Sk0jL73oKza+pMXW08txP GmpRguT22N6uCZg0VfbPUKWaIsyKtzuBsnz+pdHDldCElXqENzGwgqXdyzs8S1cfuco4a1cd jRZISUyUb+R5LyW02ML5bxE6F24xPU53aDV5WphWb67ChQa0tTruRfTYyM3OyLS47hR9egWy TqO41w3Ten6m9vItMJ6HHTJDNm9JRL0qzqu151IskupNLTKIy6kaTfI+gvkb3EQ6vc3jDpVt JE7RqYq20nUmrLRbGL0anUnbkpZeG+NP3jeRWUcYqtzG1KvUz36Xo3nq7b8XV/0RhW/JQ3sZ paNTJC4vTZrck4zF11cld8YhLsK2Cqo7J69jDHdco6dDaJWr1M2WdrhLLGKrZLl0R04POtRc d0RbHybqvbX1ORr49XqdeN1izHvV8qtayL+XXJK/t7nm0c11BxMLY1edzJ3PGN3mSblJ+oO6 trMNmT4vYlri1H9TjZ5d29xrkdbLjVR6iTdIgyXuLs4sl2GdMPyjLK9zMdWdbrWy5WZyw7TG xrjYzyiaJJlbWRVcHGnNtS+hnZQ9Wa2VnLG2a9avQhXlEcLZOKruweONG9RJC61QcpITVUTz S+oxWkdhO0ElJFRE6SwVkFlL9DNviysrtSvUyirZaqmpKTS2Loi9VVEY9H3LyqTKi7bmp2Rs 3VLU57Wl+hVnO4/jcFnQFLcOm5tX3EJOq1QlZ12RL1GsBy1gjE9ZZq8lV9TNVPOXsNWnczs5 ZdcSjUILNdwwqt3FhZMXYrF496rk1p0FzFndpfFWn2tsi1uKKtdJxtBnlqmvaSflb+Eq/LQu ynqZcOLGtHqzWMr+3U0mtlpoYzJdcfUiqxvi53BO19tkU6p6F1dUtCWmM3le0DSnUuzhhSyu n0IqeCXqx/PalPiaM1paGzSEa2xM1lWs6dCXR10Tk30iEiZVSaYi1XRdwl6SU7Tr0Iu+Sko0 petrwzotjqn7WcWKievU6BehFTD0InUaknipMq1rZvWYPcw5U4r1g8Hkoho2w+U8f27mpc6p er3wOLF59buLKDp+aspTudZZWMrQBSRbIq76FFWtGpx5fMVfoyfI8mNFqc/x819uh5+XyenF 148Pd2+PdNNzqzoVm9Nznx09vsguitXV7M3xtxnlHQAq7DOrAANjHJlSUpi2TuSa1tZV3FWy tsedbym3FthePl/3XjVva9Uc/slvRvx6PUASsnswd0tzowYbanNfzKUs6voc2fz/AG+xasl5 SLONr0k09QPO8Xyua423R20sJylLxxoAuWkhW6tqjSGADCEMxyZ1Syr6mxNUhWuquGUeT5H8 imVuVxempnnbJsXjNr1U09UTkyVxqbM5f5Na4uK+5aaHCqWv7nqkY5fLJPys4WvTp5eO2zOP K1nbbcdK6nHe+PL9mj/x7BaaqGc/tvKY3446fHpVpy/cmbZsL3blHJjvKgL5rXUN7F2YZVJP RpwFctY4sxrfhoZNNskq466UxtLdP0Hmzu269qMKylozqrTlSLaI1OvRMV4dnM1/Y9Ktp+p5 2FrD7k1G3qaYvIXNu2zN8ekZs13gR8lSzqwAAAAw8rBbPThV8Zev0NyMuRY1L+hKPC93h3+K 7443t1bN7+V8tXjiEkogflYcVbN5Ly/8LGPiTyTXtjVdTx25fH3d5Njqx0fj05JJQp1WrF5m Wy8e16yrRpB0ZsnGyrZrVcpZljf8mnK7cqft2fY7bnRjN6uHPayVMdZdePKeovD83NkrWnWY S6//AMF528Mqs7w39ThxRW6z0b5Vn9TlOfVvHq0yLBZrNZWyxrpDO6la54yPTTY4q4/5FVmy L3qINMPlWWSyvVqtXHovU6y9d5dmLPbu7Xkphiu3ZGlbKylHl+R5NPIbeL7qvjL9Tt8ayqli WrS1NTnvLx9Gbx6a6DPLVXUzoR5V3Wr479V6GXh5MeWnHf0Zby6+CSdNceLy3iz8bLRdTr8j zHjsqpaPqa0yY76WjfRM5s0K0W1Uycrbx49K3Mt6jL4ePzfc4Vl20Z5v5LxcWHLSXGnc3r5t sVo2SfaZMfJ8ankzkyNvs1/oS2Z+Vy7+GWPyq7UTs3s09j08FvZV2lWUpNnmrCqNcIWOfuel p9DseS2S9bLWvVbQTjZFrux+YnX3NSY5sryJpdex52bIpWNay+hpW7xxrqhy+Sk4xNoxrXfo Sq1yONjTJVWtqukmePG9bU26GK06cf8AtxxeoZ7q9OLfua0ObGm20tf1Kxut7S9o/qNtiO7w cdsaSdtep3eRf46O/RI8yl3Sq5L9jfya/NjVI9f0OvDl0xnlx9XmZ8j8m/NQlBlhy8Le9JdV 6nd5n+xSk6Tv3ODBS2W3Ki4t9TGderX6O/F5OPyHysoXZ7HNTjVObJJ//WhVGsjVbNSnD03L y4FiS51XGz9texeWkdHjZK4qzWeKUmOTIrKXu/7miMV2rcaL9D0F46yVl6t9BL0LOqvGq8OJ N6t9jRYudlfZR+pjSrxNJzw9eh2Y7Vex1nVi9GHlWUJPfocbz2ro9upXlZfdxrucrvqm9W1B xt3k1J0b1t8kro0dNL1wV3lJfucmGt6tdl3JzZOP3aicsLDzUrW3zbp/pBhTLbHy+RcWv9De jrbVanTm9uLlZadWWZZqs/EzvJESqrZC8i2RxSzSnruRTI7Va6G9cizUSjVDy2dE8crxsvjP BdqtnZPWTaKuiulLftsj0MiomqWTTZnbEnjdMba1kxl9Wo8hYnWzstDTxnOtUjvt4P8AdVyv 7pNVixYa+xaNfqWTe52ct8aqkk3P+h1/xcd1N5mq0cmOLIrRXGoa0s2bYfamn7nXdGpMS9XB kmy5V6HR4mOtbLkuUqWnsS/IXG/CiXRItZ64opdaQXjJEu12K9cN1xslV7pHb81O/STw8tLt q6Sb/wC09H5f+3+2Nup33oxj5qtZMmmmbKEJxJxlawqVZpW/RbiQKyWpL1C5f5CtxNFZWQKL AY1q1qyLNJydNknocrWrk3OrNHOqZXNdDCynYIaNYjW1tBVyOTNsvGpYzoN4n0JtK0Q2jPm6 szIoTddwrLckpzqy6W0NItZIJWSHJnezbJkYOxK19egqUdXL2Jw2hFZG4lMx+GlNqz0Y8bh+ hnSr3Y7ONx+Bpa8bGmPHP1M1tJLyJbMDe7cnPku1qweXUizkqCuR2fqVZNdTFUtZ6FXV6qOh cFu/STpyUpjqnV8n1PPqpep0VcVaRLCUPKraGlLqEp0OWznfQ2x568fjVVPViwjoouNkgzaO CFbklXqh5FGrM51a9HO7tuCfkaHCbkEqvZnRgnZPU7PE4Q3Z6vZHE6xtudXiv3awjPOdGuPd 071gaw1uttUPLZqrVGkc2P5KqbLR9Th1s126a2tWLcVoZZafHWerDjNlapWanL9Dc6M1GKvO yWxs3bFZ237My5qiV2tSln+WvRKdhev6E6dPVpjTy6rfscsNX2mDfG+L92kini9RPVK2ma+p M1hVYVtvBjzdnqTDXRjlbbE2pa//ANi6VbrPRA7R1gzO/RrEUSRq6tNtmDSbUM6XGsF9SOd6 uOg5S0ehdk7aJaoxdvd0bXcoeVVrb2mWRpRPUeStruUtCLqXHY1xjFXVKJM7470eponOi2Qr 5FMGvUZais2jWUyLRuzUZTW/cv5Ohg9ia21guJrXk5NciTUsy4tOSr6kq6VVxUk0trJpSlsr 4VWh34Pxd94j6mOXyceP9Va48OXL+mPPV+Thk5NNEe3j/DVT5Xs/ojqp+N8ev9sv1PPy/l/H x7bXafx+V73HyktnRixXamGfV1wY6fbVL9DSIPPy/nz04Ok/jT15Pla4sr+6rj6A6Nbpn1Qn HUxP59/wX/X4+9fJWpa21X+xHxZFvVn17fYh2Z2n86X+1P8AVn+T5atL1Uwymsl9If7H00j5 mv8Abnsv+r/5PmG7LSGbVva1axLaPoeQK0Gb/K430Wfxs/ufP2wt3cpwzPMnXRI+k5BKH+3P Y/1vy+WVLtTDJvjsuj/Y+s5hyk1/uT2T/V/8nyVa27M6a0cS0/2Po5HzYv8ALl9D/V/8nzrq 4lSJJ9Uz6LkPkZ/2p7H+t/5Pl8tbvVJhjq36H1HITj0Nf7c9k/1f/J8y+Uy1oaUvOux79sdL bpGVvExvbRmp/K+O99jF/jc52seNWjbb1/QXxXW9Weu8PkU/9LK16AvJ/JYtmrr1O/H5Pi5d vk4/87HO/D8k/t/6ePev1Jde57q875vb5OB0f/yY1K/VHn+VXNS0UTuujSO0nG/3z/uOV485 /bXLWYNKKehpi8fyr6xwX/cer42J4aw7Oze7OHy/J8fCf1zlfaO3x/Dz5X908Y8hOH1Jqos2 pf6Hv8g5Hl/2ePs9H+v/AOT5+2K97Tr+w64710SPf5+ouQ/257J/rfl49fEyW1Zpjrmw2TVW 9T1eb7i5D/anss/jfkWy2VU4ZyZMlsnthnXyE2nuX/c3py7fgv8AFn9teY65P8WaY3d+2Gkz td7U1q5XZjWfkpkvlk+zj+7j/wCu6T45b425yLBj4121N7UW/Yy+X1D5J6ln8vjJ2P8AV6/1 N9iok5ea7k6bpw/Q6cf5nDtZjF/iX0uuqzhHneTjzt+xTPY2+Z1cW/dGnP1M/L/IsnXj0vax eH8fje3K7O8eZh8fNW/vo9f2Ir42dWbVLTOjPW5ruHyLueafyZPR2/157scHjZKe6z17Grxt vlDkPlr3/qHy17r9zc/l56M/60965M3jXs3Zrc5LY7VUW2PV+en+S/cm2en+S/cf7Uvfiv8A re1eXhdqPSIOyuaqhcpf1JyvA9+LOd4/Ht1j6M78P5HD25Mcv43L3j2sWO96tpcl6Of9DJZ6 YPbea/VHkrx8NXypmdH3TOyvlO1fj8jLTNTu9Lr9ev6nefyPh/yv/Vjhy/jfJ6Rvl8+kf7dk 366E4fNVU/la9I1PJfiUdv8A1qpHVhxeJifK1+T9di8/5Pw8esvLl+InH+N8l7yR3eR4/wDI SvSzTa07HXRxVcnL6nC/Ow/5on+fg/yR4P8Ab57s4vZ/rcMx25UrLRnNk8b5Uq3tKRl/yOD/ AC/oD/I4e7/Y535+du5erU+DhPRrbxdZpfj6QFfFqlDtoY/8ji9f/KH/ACOPorf+Uz9nP/Ff q4NKeDiptZ7zsK3g0f8AdYz/AORr/jb9g/5BdKW/Yv2fJ6cT6uH4aV/H4v7rWZa8LCtFP7nP /wAh/wBlg/nt7Y7F+35fY+v457Nv4GH/ALv3NF42Ff2vT1OX+bf/AON/uT/Ny9Ma/wDMTz+b 8nh8f4dj8bE3Mf1NFWiUcTz/AOXn/wAF/wCYX8vP/jX9y+XzHj8f4eh8WOZVVqS8NF9qg4X5 Of8A7US/Jz96/sWX5u6WfF649PBNVwtr6l5cvBpdzylmzvXnX9jO3kZr6Waf+p7Pj+bnmc+P X3eP5Pi+Pd4cv+HuqytqtRnj4s16ao9Dx/IeTS6g9fHnK8142Og5fL8iuF1Vlv1aOqTzPIu6 2blWT+0nPl4xOM2uPy28mZ2bmNtDTDfhbSOTW0nP8uTKuL+1PSS7JVc455tank8uvlXaTpi3 dq0ty2uuqNMb44r9XWLR9DzsbtZ8H30fQ6sOXjZ0WiuuNnJn11Yr+bW6/wBxKfuMrW+RKrl1 3hb1E8Krj+1J1cfUxxK/yTWqmO4vVXd8ta46uu1e73DNleWlrJe5dDHE6ZJx23b/AELeRUyV pO/2voa8rDE4qrhxsondnRiy2pZcXt1nSDLOuX+3ryfbYyeK9JlLbVJmZUsdq8hZG7Wcv+17 F+LV2yt5NG1CObHGDGny5J/0N/keJS7e2Op0l/dtZ9McubNf8fkeO1uaeyj3Iwv5lE65E4nr /wCJun8t0rb/ANtktTm8nHbBytX7U9KNakvKXsuY6sd1myc7+6vbaTfyvHtWlf4qbq3ytrse R4l7Xvxbhbs9bysvDH/stpTqzfG5OqWOfJ4mXybVyL2pKOMRr3DyOXNY8Th8VK7su35G16qr sm12ObPl+LGsiXKyerJbPRZBg8e9WuT2fU0sk7RZ7kUyWdnmpq30fQj5GnNlq++hzquu+StG 6us6bkY3NIb1IhvW+3cjf3Jmt0xna7VnwiDXFCftUvf6nNlxN2d1t1NcMKrty9y+0suUx6mf yVeiaXF9gXkcknda7HmK9kueVz/qaxyryT36EtukjqzUplqk9yq1xUiuO3+4tYMMbcuzhKIl ifjUzbNprT2ll0XNcT+W1W3baB+Tl/kw1WH0FW1caeJV13lmOWONWlxc+4u3MJPVNKt1tV2c z2O6HirXlkls53etmljc/wDUyva2S8NQkc9aerk8icekGGHy64tbaz1OWtuC47ozztunpJ04 8r6s2R0ebFn81U2RWImkQ+jJ5t4paSgzVVko2pVid0Xk8qHDlfQmuX5Hr/U4eTs07PVG+Wrr Xm2vojKuylq1c1U+h0Vur4rfJOp5eKzyaP8AQ9HHldaw0u2pqXEqMFLXrL000RjXnjtP9vfo O2e0wmoQrZnpP2Pc5XZW+ljo+fSa/oyvl51q590+45bXrjsrUfKpdG2nx33NedTCy57Vmi+k EYcmTG3K/cry0rWVv8luc+d2xJCWxW9fKtqlVU5MteQq2hpVt1aOOmWtrSnJllbX+4/cjoy9 DJRZJqm9S/htgrRWXJ7ycnhZbWVnrxO7L5bqtpddpNbIzldHi5MbT4qE31OyUeXg8r5IdoOn 513R08uiZ1fLc3YSsxKjZfFE6J1WrdinqjNJpF77EFKYIu3VlR0JyJVEg2Vk1Jnas7EY7a+h qknrMDsvdjjx6x1LvhXU1oo9SbPXUm9UxzXpG2xdKxWUPJVvUTmINbqJ5NEu6TlkQ51G68nJ vEN2VvqVWraE8dk4SFF0P0BwbIcopXdSW5LBVbMtXgxBMYOrm2iqWrbR7mNG2tBNwYw103sq 6GNknqhO86l1yDMGfFmlbJa2G7p7oLKjQCeZf2iVm9GRWnJ6ItyloOgp0SUyZ43xv6GvxfIk 3oJ4I6iX3UWrDaexCXFqDozOcafbQ5eZZ1hXRko2uSKvWzxp9UPDdNQzSlXZtTozG5/wuOK8 mdU9zb4nL00N8a+OvHeTd5ZEkTdVvRcFLe7NMaWT/wDJF4lybotB46Vx2cbnPymNzurNRynr sTW7yaPX0OiXeJFSlW3DiDneUk6tydWGNS32RTfJx0ZtbBStJW5yUtD43Tb6CWWbD1aXsqra Scbpx0Hku63SS3Wp0VTx0buo7InK5P1WTa5s7tCs19Ca5FkUNHRayvT3ymtjnxrg03oi8bs/ KWdWmOjtaFoi8aq2067F04cpSkpJT7iXlqyJpZ1XH+0LUV1PYu2O1lPQyvZKqnccev6lKlPc n0R0N/3dCHDq2vtGm4X0Leoh2VrabmVlrsO94tFf1CylrqXMZ1Nbcat9TOteLbgWa7mEZrK5 g6SdGdawYWbXQ6HFVG5ja07FjNZ1c7itvoONJ7G1cF80fFVyzVsnWpJb0jFQ9jNp1cnrYvxr xqc9609N2bq/iYNa15272PPy/k8J04/u/R6OP8fne/7XJ4/hZcynj+rPQxfh6L3ZnPotEY5P y13pRKqOPJ5WXJvZnl5fL8nLt+2PVx+Hhx79Xuq/j+MoUV+hjf8AK4q7SzxViyW1hieGy3OH 129eVtdt4vSv+Yf9tTG35XM9oRzUwp/czevjU7WZLw4zvG5N7Yl/kM7/ALmT/Ozf5su9MdGl EfU3rlxV6J/RE6enFrx/LlXmZv8AJm1PN8jo2/0OmuRPZQVyLLxvfjEvG+l1P8ryMiWir6ij O97r9ipQ5TLnD0STkzjL/wDJ/QEs3+f9DWUKUM4r+5m1l/8Ak/oLjl/zf7G0DgZxP3Mfjzdc n9AjIv8A3H+xrCBwM4/+ofu9mPHM9rv9hOmRb5GaWajf+pyVzO1oS07lnCXsl5Wd41XP/OxS pke+Rl46qzhmrxrub+vix9nL26MONl/7lv2FxyPbIzbhXu2Lgukj6p7n230iHiyJS8rM7cqp 2eVwvQ1dF1GsaekSWfDPdm/Lf8XBi8nJmbVMjivUVvJyTFbXs/REZvx9k/lwvjZf2ybeN+QV /wDbyrhkX7M6T4eP6xyvzcv0orfyXrLX1Ivl8pbNs7LZK9WYZctUtJZ0nw8P8XO/Nz93Lbyv Ixqb3S/U53+WzJwrN/QqzxTqtf3KpZP7VZ/RQPr+Oei/Z8l9WuHzcuRS3b9jS+XMrJcmpUo1 w06usfVyXmhcX2Zn6+F7cWvs5zvXH82ZW42b/wD6TaqyvezX1ZyK0Z2j0aqz2Rn6+O9mr8nL 3Z8bdb2f0Gsdns7/AKs3VX1cF+1b6m/q4+zH28vdyXx3qprb92TjtbJvyn66GnktfE1XR9zL 8ZecKlLrr3F+Lj7J9vL3bfE3/db9zm85X8enNO37noKzexy/kMTyYLabamp8fH2S/Lz9x4+F OtcjvZyp00Nr462+5tnn/jMtq0SyW9n21+vY9XQs4ydIxeVvWub4Kvo/1YLx6PSX+50adgiP Qnjx9mvPl7vIpa38h4by1rCk7v41VZcm61e8OWeX5qyLyq3xtVdtn/Q735KTpS/3pwy+E9k+ zl7u1Ux0UY+X1szJ4FZy3b9yvlLo23qtC+OzPRJzsu+rH+NT1f6k/wAevVR+rZ1O9ETznapP CL9nL3crxUmFXTuTZ4qOOMnXq+iMPKw2yUar93QvhE8+XumtcWRrjXQPHx86J2op2Zx+H5aT +G9nbIn20+h24PJtNkqNazqy+E9k8+XudsKXRIjivQ3d7veqMW3Jm5G+PlyHGq3j9jThTpVG d78FLmPQ6atP1LLGbOU9WDwzsl+iPLyrJTyFh8ezdv7uUNI9D8h5j8fH7fvtpUz/ABvj1wJ2 u5y239BeyTd7u2tGkk0m+rgtV9Alhr3M43tEfQIAAhx2CGKQdo3cAVDF+pk8tZVZls0pF3Ce vYWyBwD+pleyduFXL6mni242fWz7k2ZrOptetdWZPyq9EwyN47WraJRi/e4W504yXuxeVa18 mreqNK56zEHOsMfU2x2+B84nQt8fRN5Lr53jvVJyhY8uLInaqcTv2Zx4/M/7ffdxtol9C8mZ Y68HXil+hyGuFUdoV512ZpfFjrf5L2TXY5fHy47N6rk1+x0rx5lqyskty+o1x8N29H2NKvrV ykcOJVSm8vskbYsijjWsdPqLysqPW+eFETY4bu15SfHXQ5s3KdG0yHi+V88ct16GufPf0SSN 1hyKrmzTWzI5ZaSknPotzneR1U/bZm9syeNqs8nszGtMr80lK3esV2Na2tXWJfeBUy2lJdVu yLZbJtqz06FnVWls+R6Wrp9CMllji6qn/qJXzWxq6sxvNku004TKFTOmvkdEnMM1y5K4lztT po0ilTIsdrLVTpJNc2Rx26kuCMPl/M26UTha8i68Kr7VK3hmdb3nlKS7cUaYsidGrJcmt2Oi OdX4t+190pOmmReRVu+i61bMsnkWULjV1Wjb3NbX/vqlx+gvVGdvIriSVW3H7mONWyvRWS/7 rSdNMibaarK9C3kUa1/YkrSFXFy4zxtYutq8eMb7nPeLuts1PRW6Gq8nG5SSRr9A6+PTDstX qnBzeSuif3b6HS7zRclp/wDkc2S+LiudHHpYRGuG6xp0TTnq0Fqu1ffZOvYmvlUdOGPHp11G 7VVV7dJ76iwLdJVadQx1T0bUjXBWiqevqVb405aafaRoTw1s4tbjV7snHiVV7YcM0jEkmpb7 SZWeOrell+pO6tq8YaaVk1v2M1RVWkR0KV6JOZg0q8bU0q4IqtbUj+pdKWiE5MK2ol7eTXYd L0reat6mp3Snnu8j3Whh8c/c9f7TqbWKL26kZK42uTTbmdyjPH49VflZ7b1KzVXHlRx0SJra mNuE230kuaXfGygaMq0bWj0NMc3TrpoWr1rWFMN7EcFW2koVCsmq7prqYvlvOnQ1+PleatyZ 2pVVbcyuhmVcTXDS/Zv6muStWlTQ5Meaqts5L+ZVv7pZrEdHGq10TM8jmFZ6GVKVu3klqDF5 62cQ99Rg66Ud9G1C2NIrV6PTrJnhdKNO0wb88eqS6mLWoztNW1Hstt9S8VXWScu6qtUbYrVq n7tX0Je3QVf3Y9ehguFloXF1OmhnSyUOC6Od0WPWuw6YqZtE5SNbxHMx8fJwU1WpveiOvx8a 96WyRjdLJVqdTpwrnLru9zFO2JexT3M6MPExXs/a219Dph9+pWO9nrSII45Oy77mvJl5VaWq tw4NL1NlVykXZVSjqdNTHO6tOTZVhaDTROS3ToXuJe8oyvNi1NkzO6dTcZq8dFVDsurIpkiE F83F7GeuprVVhSmJe7VkO/OI0Ha0ImKGrDVlszO1r2gvhb9So0jsRC6kqzmGPdBU/JGlQvbQ yft0Jhm8Za/FWJbM3XXQtK2/QK1dmUZ2Ik0yV4mRqI1pkheo17nBFFLOn4VOhm5FJ1lR2Iu1 XY6HSVoZZMcuDMozb5KWOqRrTEth5aKq9pd9DBzjYj7rQVWs62HCrZPoyKuzrRQtyUoUjv48 a11GrKi13M/oqsFXk9t+pj5Xj/BaFqi3lS1Nsl656R/Us2X8HSz8ubBlUwdWKeUnFWqraLad j0oUKyHPovEVwXtKr9WY4aWrbXqzXmqWbsVW0pafqcOV5f8ADpJCzxjvpqyYm07Jl5cT66lY qyuNns5RONydVs6pTbqn2cCpa1XPQ1tRWcVUQ5Jfjuz5PZdBbLDsaz1b4vb1DHyV3CmvcK4q 2mdlsRbI/Fa5Pc5/iH5GWk2lTJpfil1ZNcs/du+o7f8AdrJd3pfQ1F266sVbVSm2pGSkrRkp QoR0n4TW+Crey/Q6MlXE6Qc1Mjqpe0FrJa1fRGL5b+G5mLb7dCcNeWujgbye2EvqFKutXr6w a64nqSbdmo0Fks1tsaVvWdVBlnvzvoi8L1yxmuZ5fc1Td7m1cioo3syKUVbRGpN8VuXKqmTp 01F2VN+vUwvZKXSsLudla8adJF8dcq47dzM5dSzo81Xh67HVh8TLmXJe2v8AlbRC/ie58ftX VnXld+Kh+mpvnyv9mb+U4Tj/AP6b/wALpj8fBrrkt+1RZvIy5IVfaltx0OelslnC1Not31PL fitu8+XlXqnzcZM4TxY/Hke7TBYe5bvNZUSTTNa1kuKHhkPulUsVf8X+51YM3xbUX7I5L5bJ xVG9MuJKLN8uxPDOrV+aXo7bedK15f0PPy5eT2Y7WhS1BnKak36MTnNKuV1ekmn8ir3bJarG +pNMFsmtThz4etejh80nRzvyKvLGjr6nYs6j2wvoji8n8dP+5V8brb1L8erupfthe6TPL49k vFrj80lsrrV0/wC5lJpb2kWPNX7UafKlucfHl/i7efx3+41eq6lK9X1I+egfyK9NRnL/ABp5 8P8AKNOVfQfNdDn/AJVOtRPy8X+J0nxc734sX5vjn9zqn1FP6mNfIrk2TQWz1T46mp8N9Yxf nnpyjdKz2QnjndpGNcitrD0Gsk7I6T45PRzvzb/cy8vwV5ChXa9EYeP5FcLWHyFwstE+jOz5 PqRnw0z1i6/U34zMvZz8+vlxvV0VtRbGiqnqeLW2Tw3xyTbH0suh6NM6tVNOavZjwzsfZrpd Ut2Q3Vd2Zu6Dmizh+C/Jv9ynd/2pIj3vcXy17i+ei0bL4/hPOe7LFj48qt7P/UnP4lM6h/d0 sW8iV5WzRrPJSuhrqz+15uPLbxbfHnWnS515KrJXefoaquPNNcmqOBq3hWmi54v8Sbv6nSev RLxXT9tUvVjVL2++7/Q68flYc/2wvQr58VHHX6CS38LeUnrpYsSr1KyL2tKWV89HrIVyKzhG pkc7deRlyPF5Sf2qyiYnc9ilm1vJ5X5GKfHkS1q4f6HpV8iFCrFWS3tkWZ/dVWvxWu5FLWu9 FC7tA8/G3HjA1ns+hpnYWXF/t35WnR9Dj/D2Tx2q9WrHda/R9TyvDv8AB5N8fS2v7C3oS9Xt tkPG7ppvcwvndV0OfzMt3hcbPsZnLV6I/H1T+TBfVSejgw5K0btDVXE9Y6SfO+PpkXPWT1vG v8V+VVo9HXo12ZeVSV2y3sRZab7k5sTxJXw647bT/a/8TN2tMbRuPKROtcv5PElSt0/tZrmx 0yY65qr3Vi02K8pPJitVdpOTxc1rYOHbQvlLNR72bBk8eG0oalOuqMedn0J/F/kfkovD8lxW 3/p3/wAbdvozn8vHm8e7x2lepZeg7ZquiJd30PMpbvq2Dvar93Qz5D0Ha3dfucvneS/Gxzve 2lUY3uq15JppGWCy8zK8+VbKMdV/qahro/H+E8CeS6Tvbqdj5VyKY1X+g/Ho8iVFo1I/Lu+N f8qPf6l8fW08vYm36GVh2brvq2JM4/JMj0fFy245fKyWxutrfZKk3y+ZipXla+kSkluXdK9e N/t6niVwPPd46tvFR7k4WWafNsuO3wfHyeXd+bl+1OKnqV6tN6avQ4ZyYuKUqkfai6Zsllyq 2qvSPQtvq4bY3+arrzltDWWrScuGc2SypeHG3QvHlq44qNNZM21ddGjcS9pOjF41cmF5lZ+i OLNSqXBLdSzt/G0f8a2sqWJbs1qWuJ5OK6y1p2MreNdp3a1T0IdotGracR6HW89EnaX9BbZc YZY0qKbV16FvjW3NTLW0EfIre6q/cFbk5uzFVlkyPHWYW+/UdMkx/qb0rjsrJz/26dTk5RlW nJo3Mxk6uleTe7epStWr5R9Cq4v7nuW6Ld6naWMnis7W2n0OrJbHiaV0p2+hza0Sdd+g1jWW ryZ07JONzHK+oM+NXa/jtq1XP/3OfyMXt4WtydtW2OzpR8ebVZ2QWor3q6zbX9TOqnFXDgUX j5HpDNaYvk0ThrpOhF0r8q1q3aImC8fx2a5W4WS4xG4/QXiq1aKqXT9hvKruYfLr2Jz0tiSV W4j6SPG9OMS5SF6oilnaVf7p0IvW2FxMVfY67ZMdrcIaddORy3pV61cT/kXfQaTz1iV3Wwre QqWinTUzx5m01MJ9DXFXRJxt+rJ+qnjtRptuVvCX9DlzPjZWrPG20m2bE3foqJBe3y0+Olm0 J0Vv4zda3x1T1XJGOKrvjS4xavWdzajpRp2fTj+rOLLhy2txpbkmi90ddMdq5FRy01L1hIyy TS6VXLeo1dunG3J+oseOy43mZn7iwVW+Oqbdm31qT5Fa3qvhT13+pjj8a9m8jWhq7pVVWtV1 Jel6A+Ozf0JtfJ9q6s0d4rv7ttNxPPajfOtbcdJWhZqNrq/kJqtYvX7rInFpKfQa8i7q3Sv7 BEykt1u+hmtRpbhkp8erUf1ObH48XmsutdIsavyMqiqa4mOfJF+UNu39Cz2FZsfvatugeN3r DRrTLazWW61fYLNJu86SKJ8rFXnVQ60df6nC5xQ+Uy4jsaZvNdVwV3E6I4clbWcqYOkmsvQr Z8W9/UfOt6t1lP6k4scJQ3D3k7MeP407JKOhmzFYYXa1ePGPUMlU1roLEudeUnQ60dV827/x MerTmxYW2ludLupeKOPoYWx8G3VxGz6jrymd36i9VFlFkqyo+6DTHq427FVssibe5krOVZbo m4Hatr+5tuehpkUKLf0E7w5Wj7CyPh+xtlhd1Sdq6sml3dxbVkcnwbWksmbVcp7FkHZZ11Ve nc1vLprq4MaZeTU1ehplyae3r0MqwplvRPlojNZGusjvRNy+n7Gda2taI1NMhL5LpbM2vjo0 0nN0S65K1dY1WrNfHpXjztDkivPr5FqW4vbsd1cGN0d04ZbxVsuKS+pjnVvHaVdal1lp4yr9 t+xu8da113ON5ptNd+h01WTLtqZs9Wod8UVm7l/2k400osa8bKOWzKeB3uq1ctklaVgs549B rFVq1VpGwKmTDb3V02YZZrb67gcmSlsdIs1Bnix6P/FaleTWbe3WOhpS7VKu37Gp1iH49nje +nUnJ5+KisqPUqnj2o/dt2Oby61rdrTi/QiXs565b2ajqdPHL/kS74rx8bho15P/AD/oOrKG 5X3bCaaWlkcPKXAp1hHowdidt5qFq3tskcrXci13U1Iza760a/tRF1O9GYKzvWXsZ8rJ7uBi a6lSu/Fmd8VbvaxKvZKZZNc+VuFZwPyi7YK1Xt5fsFcNN23JT8u60n9x48+S6mUTri9C54q6 NstKr1TM1lfJ8o/Yb8ni4hfsM9jUulJ+5Ctj4v7kT/Jl/YjR5VveiZrEHwq/VSOvjuu+oqeR SfsRu8tLb1JdXoyeOzfoCx2rr1Ltkx/4sm98dVrVgY5sbsvUweC63Ru8uD/G37iV8LetX+50 nRE1wWUaG9aWnYmjw2e1lHqbLJjTiWYoT03TITa6Gl8+OvVsmtqPX3EwVXFClEcHy7mr8mm0 v9iaeRWXFn+xMq9A/daIJyUb2WxqstF/c5+hKy1s45/0KMm741oP4/k1g61avcaaez/oZ1ce blxWqpZeDJNeL6HfZ0sonX6EKtaaT+pry6JJ1YqL6RKX9DoxOKtJzAJqr0t/Q1panfUxa3Im uD53HVEPlWUb2ejhv6mc1j7tfoZ7/o0pQqruXVazdakKyf8Adp9DV2e7ejOPKejcLgqqZ32M XdzDn1OmyTa9yQZsFq7WSMwrmzZP48Ljo/7jnv5CyttPbbkjrsrYtbPlJ5t/I4ZNXp2g3xmx i9HV4ytDs3r/ANDbHem1dYF4+SmSbJ6R+hNUqttEzdaU51lbmDqphm1bOy30RcU3nUss4per lxWVJV/0OisKjeurNMmPiuW7Mq3bXZI3LvWGejSlVdwrbGix1Wzk51ZpyDV715pOpnl37jeO LlqTFYbXy89q9jVQqJO/u9GTRO1k5JvqYvilL3HevyV4pRJOS7b4ozba237Gp16+q01g4KLM zvVRFU+XUq17U3RPK0T3NT3YtTVXiI9prajhthNnWJTMKu6lXhDdF4Zq4q4XU2bXTcxwujb5 foZXzOto0j0LetRraj9Euppj8dpLgp9SFZ3qp09ToxqqSi36IxasjkWHJzab0NPhrPKjX1Om q5zz0SMcOC2T2VtLe0C2LnVSatX3OTC+OsbxHU97w/wELl5Ll/41f/UPzfh46YarHVVS7HT4 /j8uU4+7PK5NfK5/JS+xzB9RhjhXjooWx8XkrDZ9h4bnDR/9qPN/9l8c4ceOe70/xbvl/wAL 8jDXLTVRZde55lcdaymz2DzPKpwcJaHh/jfLf/6+Tr8vDZ5TvGTvx1hfUSvW2j1ZjW7Wu/oa YkrrnEep9HZ7PITpVPXcqtardak2+6HqK2Tk4WxdDt8aG1j46Ix0W405+0zedMaVsqbI6NH7 kuhhDouVth/NNYWiHnauNrW02CstTtBz3yJxqVZ2bSmEzFvJeg+S0uA+V7yLisem7Zm3y+hr rjNK2W15q9UcdsGTx3zxa1/uodd7cdia6uVojXkyfj565Zt26FfIrT0ObPgTfPH7benUfjeV r8eRRb/Ub6q6K1G6IptdNBuraluDpLqM7+2Ldjp8bJRTyOS1HEJSy3jVsc9Y1JyyQjbzMdqN e2F19TKrq0lxab012JrfSHylf3TJFPI+Fy1yTOeqxz+E62d8O66Cx56ZaOtnxst0cv5LyHpW k1T1g4sVnfS2vqdZOmnd9DW9K0UqUzSmWjUqfSDwcd8mG3t1X+L/AOh6+DKstU44nLlM/RXm eVmvlr/udda6HVgtfJiq3d/SEPBRXoqvryWpj4vkLA3jyJ8Z37HSX/2R0t3TVrWdl1lHbjxu 0Myx1V9OhWK9sNuD2/tJyuzoSe7S9dXaNjyfKt8PkUzJb7nsWslM6M8/8rj54ua/tZjhy65V s9XXenKqbOTyae222xePK71raZlIvJgtatrWium3oTj07leXmx6K/R6HVS1vHS5+6nS3/iPK 6/xap6PQ57/kclcfx6REbas7Sazr18PlVrKeuO33L/qvVf8A2Kvi+OzUqyalWXVdzyfE8TNm pMulHsu56WHIsMYcq4p/bbdT9Thy5cf6ZdbibUb32Z5+Dx8lbWpDSnc9p0acMOJz+3Oki5ry aeHmbhQlM6nt3y3zYK4s8WyV0+RdV6/+JKrA4NT5azY5LeJO0IyfiWU6JnoAPMx42Xwc10sS SVJmxdlkwtKlWlEbHrDUm58qY83FldbJrR+p1ZW8lLN7wGfy8OBTksp7bsrBlxeRXnicrZmr zsm+iY562UQy06pROrNl49FEaQctsuPn8dVMdTPLl5R1+PpyistW6tLqYVw/FThXTr9TutRJ S9jHLSK7pTsc+F6PR/JnWOe17xC6dDXG73+9Qlsh461xPld8pWkEfOqaLVs6V4ofCsuV+rMV Z41xUwbWyueLa5MVlV0mfcuhI0pzWrs9X2Z6v42yy4rvbXZHh4pyqyf3RP7HqfhovTIn0g32 sI48mNVdmrJWkVZeNWT02fcPL8e3J3VocmeD20Sst9mS99FclWsW1X9sBVtWXJaRsw+RYoUS 53RXkYclrJ1bXL+hn16iMuW0u1f6E0yWUqqU9CLq2O1aWt6aC+Fu1ly+3VepvjJO6Vpiu3Kn U1XJHPXLZv3Jpv0N7OtbRVz6m2W1vIlQlLS0Rmst+PLJtMca9BVyTbu0XmzrMq1qlVud+pzs wYX8a9nbLRJpaxy2L4NJXq+KIXPHWXtsqoPjs1OsBXVhvZRWr/X1OW2TLROFV6tttSXko0lf km5lJFXr/I9mJe7eTfRGPjZtHytNjVUpa/VON5Ma+M8TfOG10Lqqpw1PZGcWNlkrRPHVTC1b 6mapa+JPq3sPi6VXFJrqy/nerpDquhIM82KtqQ2qtbLuaYk7VrpH/cyL2tKaXt7mnHLkTa1j aX0HKkFq1dvbbfch0iz4PQr70ohOr2Q23KslxhaiKlS021Nf8QxOqXJKGx5UrJ1paJRhiw2x w7Sqtaos7ILTju3zfG3Tui8uWmNON9o6L6GvlX+avCrShf0MlScWqTS0KDE1ivMtroVnfFNx q30HithS0U+rZeLi27Of/rqZvRccVciT9zfKNEWsDtPNxPu/UdqWtPHU1xWvZqmjT3k1qY34 vDRfFaP8lJnfLZubayoKdMVnyrpbr2M7qW1WWZ3VwNcfdXXqTTyrZm1b2udC8mKaLJV8qrdd UZVxpN6PTVFHo2wzVWb6ao57Yq1rEaMVLq9YbasnoUsjye0l7q8/yKVpkcxC0RgrXTmdOh6G elcmXlEytjlvWqaraarqdJWWni3vaW1ombWyLJNcUtdTOs4aSm4b3JpntWyWOFO9hujbx7Wb eCi21bKviq1PLVE4osufL3dYGuNqWdtGtoOd7qu91etUlr1kq1FCbcdDlpk7M2xzZNTLT09Q KwUtV6tTAq11a0TkWWqWRKCnZXifuWhK06vhpKtZ6vqZZ7Y6NKZ7mTdqNV3QsiU+3Vo1O6Kz 4q1pWH7W9UdeLw8Hk5pq/YkpODHbmv8AdT4z0O38dl4ZLJV5ViNd4NTBXnY648iqt/8AH0NP FxY7Vs8lVojoz+V4+Svy0a+Sv9phi55MXyTWq3Ve4zojz15CbtjdY0mGT/JtdLG4VFs0tReU 8i/32uSen0MfHyK7TsnCcFR3XfGnHp37nFly6+3bsXbHkh2X2lqj4pR0MjntldfatGi35FnS GpYlWt7crdC7Y62bs3p0KNKZEoy2ScaQd/h+U65fsivY87x8btXSIk9TIq0as3Da/qOyunyq Vy1tbZLstTPxMVlVur42S0lHnvLyb5WhGl75fiawtkVvjyXtW1rN3unr2MctvlrM7D8PJkvT 4kt1qc2Kl8d3jt1M1WdrKtpspMctuWR2Sa9Dsx4eWTj/AHLuZZMatk9r33LxqVrkzWvhV3pG jkh+LXNVO9uKZeLHXk62c1jqZ+W3TAuLlSLImuHP4nxXmrmvoa/ozPHW1kmlHc00/wAkOvbR wNqlYM67porMmtDFXh6HqkYtdF8kmN3I4b16CtSTUYVjfsYVTutNwvFMaXUMftU9yjXjHUSb otSHK1YvkS3cmcRbyprVFK+kVUGSy1dvQrNZJadSZ6B0c21C7beiM8brMsV8mr47FzqBOHDL a79TKmtjbLpEIt7i60qkU3GrM6JtqDohdTFrUTj7vcTrybnU2UJyyfkW9UY1rHFakPXRCtXt qdGR/IoNK41EJHTzZxxrm9ES53Z6PFLTqYZ8CiampyiWMMc3aR02s6dTmxKzcI0q1X7tWOXd GiStsK6rRT1M/mjRIh2d2JKE25NKpxpuK2SdGpYUq93oaRtWzrp1OrE4OC1W3odKsmt9Tnyj Uq3LbnQht41KZVW/7hw3WXsQKXkryXQVL66lY7KYWxosE6ozcbjox5Pmq1XocuzhmuNWx2ld DS9JtzMzp0bRZJ7DondQ+hPLWUaVVlqtupKp0rL93Qny/Kvi9zr7ehVrwuSOXNitn1bcHPJp WuLylm1ehi/Bpdu86meGtaPj/U7quqir1Rmy8b0WdXn0Sl0ThLodFMrq4iEjovix2adYRjmx utoS1ZudU7NMcZHPQMkKVX9yfjdVGzZmpp7SZO40rZVaXU3bVnxrCqjPHxTm+sCaT12JZL1i yjIuD4jtndaw3L7Etc9U5eyFkwS07ymjW8bOqZTx4qWm0+99DSHSsPcFSic10fUOXyppNIxK p483GXGonkVnDjUxbU6aolPim11N+MTTzVasHuUILzCnVl0t8ulnxS/qal6fhMaYFZJ2ro/U mcd1H9/UP5ELilotkRaU1Z+2TE3bSxndR7Y3Kx42tXXYvRvVmd8Vo58tPqb3UzGl6WyLSFAq 4/iaberFWtrrR6GtbVjhGvcw0Tu7trojfw8nDPja0SsjnVXWVoOr4tPs0zlzt19f+L8fG/F5 Z+7lvV90ed+XpywP0O+r5JPujl/I1nBY93x39/G/l8XnP21+c51FmfTfi8vPx6a6pQfPeRR2 yOqPa/FJUXGswlrJP/tOMvD9Orr/AA93/h6xz+Zi+Sk9UbjidD8xx5eN2PovnrTTTRs2l1qu L/8A6S8/iccjs3p2Iu+Cbrs+59vhy8pLHg5cfG2FfFZarqZ7KTLndrVwS+VtDpjC3kb0hFVe hk3wZStGr1RmwXa9q6PYFer30Erqz9Cn490uUe0vQbOqq+j0kxvd3txpuVnssdaNdURgvwbt v2NZ01C8qZ0+hOLJ3DNR2jt1JV3EQLOjKska92Tjv/kbVW0sMmKj1jUx5TtV8fUKnbbcxy41 n0a16M6qY1WvuFTK6e2JT/caSOKubJ4/szKavax2UXJ6IeT/AHE6WWnY5Ur+JrRu2Lr3RN39 Vx31y8XC0aMsbu06v1KxXpkXKjkFjpyal66mPJrBevx0SWhFaVvum5ZrfBH2S31M7JY4rLTY 43Z0K8/L4tfJ8h4lbZafUT/H18VuuS8W6JKTfL4ePFd5U5Zx5L9z1SXJ7Lxsz8uXJNbav2nb jvkw1VrJvHbZnDacloSls9ir4Y/iVW1HUzz9EqPCS4S+7OS3k1x5LWjlW2jRnTP8d9Np1rO5 lasy1sWMLp57x29i9vSrexvX8jkyLVKP9DzEpcHStNDWK7v+Qyehq/NWXFal1DaPNkqSXhFe n+JusmJUa2bO3NTHjo8l7Jx33f0PI8W9cfJWfFPU48+X5HC2MXj1QZclm93HRHpYvDrmeKz2 4y/U8rdHv+BPx0lfb37Gfl5ZOiyO3ol0QrUrdcbKU+g5FJ4WzxJpLE9Y+y3df4v17DRL1Hju 7Wav/wCZdTW737o1dm9G9Fsc/leXj8WvLI99kt2ayjxfL8LL5fla6Y/8vQ68ZLf3XozWv/OV u4x423/9djnv+bztxWlUF/xP+8sPj2bcS29Ed1f/ANVVE3mz1qerjx4XrIy5X5ubL47zPNWl k+PxVXufr9Dzb+Zlcp2t+rZ9Vh/heJZK98Nq0SVXGs/uzDyvA/HebdU8W7tks9bLY7SSduOM vlLXb0PS/B1by2ctVS1Se/1PR8j8HS9qYMVo46Wu9ifB8P8Ah5MmPkr/AG+6py+a3wta493o ZrOuO1l0R43j2/3Een5rjF+pxfj/AB/kzcnoqrkeWWceO114TeU/V71sVF41st3HSq7ni1tb a+3Znt4eFq3tb+z7V6s4MvDyaWTTmr3O3x8JeOun8jl+7x/5c2bE2lxWr0Fiw1xL/csvoX49 7Y08a1nZmWT2zaIfcz17POnLX3co07kaWmUo3NbZE1OvpoZqrdusbmoljXx7KuVKv9yj9z0v wyX+56nmYq8bKFp0k9LwKrDmvf8Atu+K/wBSrHL5P/qvqkzmz5Fksqv21jQ689V8l7KEyeXK tq8Vxemu5bmo5edMeNw/enoXfy7VtW1lLstiV40qzekA6cnE6JdyYM/IeOPbKfqXhVm06ubP 9yHT5Pu/crxaWx2TTiGazId60zWs0lSVZb+hpd0wYuEcrvXkjZ6X0lq2tu0nJfndtKvFTJma dIjDW1rK1N0Pyb1ranBvlu6m2PHeiTrM9i74U7O7puuxrleuMFZ8qq7rrOs9TTHkWSbyojQW HyXio6XVnX1Wxll8Z1qnqqvXQxGkVpbI0lv2O6+N+MnZt1cScNLVpaKN7bmrva1Wnq7dbGqi smTHCS+5/c53M6ynMfoXiolTaY2RC0bqtPr0J1Vrmx10a0XU51k+Kzquu8nWqtrjaGu5598d ldu//wBjUK7sN8dccZU/dqFHet5SlPadNDnVXkrFdq9zetpSTWq69DnZhDVFPZ9pKvkTrwaa l/c0FeTTVkqv/JdTOuKzbmzhbIRWSildXsUsNknflyo1oWq2ejSXqZ3ng8eqe5uCL+3Sr3N6 uMb5acf6yceNNri+nc3WCzs02y2DnfvtKWiOrHntHwuFJk8VsadLJpvX6F4aWyataLqS9Ub1 rWriY1HfiskUaaj3SRWrx1s3rqZ4EsnK1v0JIuuh2paVVKsbvuatY60hWlvqcbo74nxjQjHi vb3W/QZ0G1cHxKKrdyLLj4L3OE+5o+V6xfddTJubJ21SJFLmtYZoq/KpWj9diMWS69tUtXBt kVmuL0qtde5cHOm00nv3Rhlqs1+LcSddlC9yST/uXQ5L+JaJ+5FjNVV3quGkV6s58T42l7G7 xJVcrb+hg6WtotjQ6bZ1jm+n0ROG6y2tZOF2Ma0n2pOe7NseJ0hLcmQU7cU0pTWpt4vvbaep n5SfJ2ScegvHduU1UaGcVrNda21ZusapVN2T+piscxb+7cryK3vRf5ehmNKtpqmoegYUvla9 DmSdqvlozbHfjxvGkQa6o1rm+K3aDN53hu744drJyYXlvut5NHhlfI+hYVzq7VG7fe/9DFeU 1CmY2Q8s2vyiZNMfj1s04aa/qbZdNG704pS2aYqfDZVS3Wp1+NWsRKSWuplnx+6dpMKL3rjr o9uhxVyPJb7nD6di8rmrVv3McGG33bpFiOyuLFhbcyns/USwzVtQznyK+3TsXGS2zVWSwFXw aqnv2Oy9q3tV5n+xzVSqvc1L7EcIfvf6lFeVTHLWBv8AU7/A8t4Ke+so4HTipjbqapN6p6eo V1VebFkeRVir2Iy5nZq6Wq3OnJm50oqtNrQzeCaN16asllVyZb0x5HZazqjnvkat7Vozoz4l kx1vV/aZaV42S0EGFcrbXH+p05rXVVfj7eqRnS+N3drGmbzUl7Kq1V1JUTS0yo9j6djL4sfZ 7jr5Nb2mjhj5Pu95Ia821U9zmtXXQ05O2linTsevjcYvVkmaUrNZ7A8brVtmEtG+7PZs4s5e yJTd3oJJtCq2pKhTOjYmtYWp0eN4vz2amIJyY/ieg32Rg6tbhLZWtmemvBokuXVGbynHuSa8 yto0NbUbgr4qNxOzIyV4apjevQK6Vdhc3fQrHj5asvb2i1cXiqp1NuUGKfGJ6m9K3tV2qnwW 9jlW4l3nRjspRFuItZgYNK0SRommtCXWFBD0WhFabSSq99jXBjrarvZuUZWvOxqRC4urmqMu KerR1UTnUyy2q3CRYlYWuuiMJacnesKg38n8TbBhrkTnnr9DfGzfH1rNnq4aP5emwsqb0WwO tsehXLaNmPVGeOUpeqIdpZ6Wbx7YaJ2iH2OfDSjbcSN6eRnoynglZsqt5Uzp6m2R1qogiOaU LQzqnRKJWp0Y22jkqnS0JHVWa7GeU6tyiuVNtbI6m1asRsZLDWylbjwXU8Xuzly79PR0jSmO rUk6pxULNNwtENtRy6IllXWla14w3uK3Gq4p6sxxxk7cuxF3kx2SvFktkc7uhvBj17ku7qtd isme8w6pJrSCoXHi9WXfdGCo7J2TiTs0VU2tYMrVtw4twlsiFfnSF/aWdVb1yVtaGtEZ242e mo8Va1q+W72JbSfCmk7mekvQ7p4xpsS38f3aovjzmy6FV43Wqcm5znapjRxdaQmVaz0nWDOF V+3saZLt1SmGc/Xo0h2dnoiEuVo7lpqqh7vsY2bn27I3IiuKq3UTdbLiGb7l67mWWpuRlusa WlXOmpKdcSi6TZCzuqVehnx+SvJPUknpVb48zvrHtWxd689d16nPRXVJqtC63iOSGZU0q4t7 N6Ba+8RoXZq7lqEyPbX7enUvcPm6pQa1bTeqZlyVtI1fYnInRaHPFaquuozPFdtwzU5fI+z/ AArvx2e1fZeFbngxv/tRXlV5YrL0Of8AE35+LT0UHZkU1a9D18L0418j5ZnLnx/Nfnfm2dL2 qur1O/8AC5Hel3bV8v8AocX5SvHIzb8Fb3ZK+iZ6P/seO/Fb+jH8S/uk/V9AMSA/IvqObzcf KvJbnltXU1stz3WuSafU8nPX4rS9z6H8Xn/Y8/zcenk5WoWuxjyScM6cjtlpyfQwpTnvoj6M 6zq8pWtWdNvUavy+gr0rEEQ21D0EmjauF2cULz88cJtt9jKmZ0t7Z9TRZa51xyTHcYzad7q9 UuqkiiVEk16m1ap1jH9q/qYZb2zN0xVNQpWytrTVE1vpotTmrz58Ho0dardKdJ7k5SJDba2H ifN+5wiFVt92dSV6apJrqYvsqrNW0Wq7mfFdXD6DV7WcF1x8n3sjFajH5bJum/cdczpqkda/ H5Mmtfb9ToX4qj++z/QxefGf1Ok4cq8e2Bv/AHsD42616MnFntlyKtk1fbjGp9Li8TFiSVa7 GHneLiyV529tq6q9d0cv9jjud2/q968ryfJXiJfJVy99Ueevyd8vtpVfVnH5dr5LN2ty9TXw qpUnqz6HxfHLm93n53OsLJkut9V6GDyJ7HRmaOK9bNzVHqucZjnNqvHyfHmV7bLc9LyfNp8c Y3+p5yot7fsU1J5+UnK7HTtOrne8mlMjnUvgn0GvHb2TFiSpePWVv2JmDpXjZH00JyYWnF9P Uz5Z0b8b3zo5/kF8r6HdT8fV68pRvXw8dekmL8vGOk+LlXlNuw61b0SPZWKi2SNEktjnfm9o 6T4L615WPw8l2lG7PqKeFbTooOLx6zkr9T3jxfP816Y6T4eMnu5V4S6v9jReLjRsM8d+TlfV rw4z0ZrFRKFVGPlUmqVV1Okw8ptVldy8Lbym05T9t/R5z0Gqt7Gir1e424Pozi8OvGzefXBl umuVmlRvt30PLy5lkbhaSdX5bC65OS2sec5Wh9HhZn7ezn19WvytJJQoNvG8p4npK6zXR7dz jlg9N9zQ+k/EZ8mXH/uN2h6Truh+Jkm+RKN0eP4/kVxYLUaatZ+26e0HX+Kt7Ld+W5y+W/sq zu7/AMhkaxyn17Hk4fNthurPaIPS8rXGzw7o4cP3Tq3LeN2PewfkGnLXte52ZPJx4sUclFnO nVnjeA5bxvZ7HRiw0V3yUwzpw5eFvC/8Ovyzz4z5f+KeXLaG6wmdePKvji2tjneVW0ouPRku uRa22e0C3XndGXE++xz08h4lFnr1XoOjtdN2bUdCbUWZw9LbMn6q6Kut09J67m/jeOs2VWT+ xSee8d8Mct0z0/xPJ5LtpJtC9l493D+Qs8edpf8A1JnTHZJN6T+x2ebVvLa/GapanFkbtRRM Toi6l7rzKKOtZdZ3ONtUhRLXc9KXkrFtbRCT6HHlrwcNJpl4pTpi+S9a13t2NL4beG5s5nYf j1SfLGmkuppjyt2923STSMceW95ddivhe7eprzq8jqlEvRFNRsTcVklakPk9DZ5edVyu5T2J emtkaP47QnVKv+XWRyvqjPyb2b4puOoszdHXhZpR1N8la2q3X9Djphva6W67MwOlYq8Pvi7e wnVVScuV0Koq3yWURGw3hs/dKcfcluXaHZWtZcXutV/1M70X2y+W8luifG2Lb13YWrZzq1Ye S4wx5m3asyLPblWatptE0o6WTt3Oi2G1k3Gi2Jbgz8d+2bqUtNzoxJUiHMnO+WNexTOhPPWE ofcdxvbK7NTpUjJnvSyVJlE2tetX1C172qrWhsIbd8u33NaiunxScpwFl7ZmZQkvkn3Pbqai jHS2VRV6I6K2sl7tZ0ObHlWO6fbobXyYuTs243gl3Rz2Trd1tbVdjorVKvBuLL+pFb4rS19z /oacatTPUluh4bXq1qnIRw06z0MW2rcXo+6NsuO1Y13XToIoyVW6ft6k2um4o2+n0IrR1Xu/ fubUVW26OJX9S6MrUyctdoLrV2q09nsaUzO+mRbaE0xVaa1//kKzs9Eqv3G+GiyWVrNutuhy JRXi/wBjf4b48czxcSio48trY5TbcPQvx3kyuyq/17GObC5V25bWsDr47cW1TNMu2160ard8 bbadRWx2VlClPqTTxU4nddWc6zPDktVOakgLY8js27S1sVjyO1VZwrIq2dcm1C0OPJFXNWaH ffI7xZaLqT47fytpyZY3xpO5FPJVLNxrJj1V2rHZe7RNuI6m9Mb15PY86+RXTab5I68OZWp+ m5mrrnbbbo1NX1NcFdeNftfXszK1tYjXuaYrX4KOkmxWPFypKfuThoLVd6tLo9iK21cKGXju 8mKzt3JfcY4vHpZ2d39FJ0LFTFxhszpkeHepLzVbXJ6DayeZu7mvfYxWVttPR+puskP27mOS jduTUsgSu76P7ToxWx41yqjDhVw3oY2t8b01T2NDTNkV1xW8iyNKsX6GCtalp6spVVre6ZAq 966Kss1c3Sb3MfjatNZk2pjs029xSLwu7ms6dTox2tS3FPSxx0tG2nc1l8ldBY6MV7Y7w9Gb 2y3lpbM55lz3FS1kte+5L2adfipy8Vo1WhhlxzidXvVjd42+5M08uvyY1kpu/uRJ1Hkuj0jb qbK6qmlomhU8hYrQ1oK3l1o2613KyinCq0Omaf0/qc2mRcq/0CH26EHJRPL7ma1XFS3ohLE1 TipD+PaI1g7ZWFpVyVlnLmxqmi3Oy2NtppNQZPxpcwy8dlSua9eJNWp1O2/jO2rTRNfDU+6Y O2zGcr0PDoliVq13/uMbXxYlZ2qrN9y6K9K8K/aQ8My2tzjrpI8u2RO/KqhHY812k7OUuhvi 8PHxbsib4ZrFNhysvb0SRjW7pSzS0sZ4sDbm+x15Fk4KsavZCeGza6meNpjG3GYqZ30Z118e 07Iv+I99DcHHpuz3vGsq/jGm19zPO/ivaEP+NZLj07Cd5fa6ONLVwaP277m6xNaaA8Nn2Ly/ ddJGb0Wu5nyhHT8NupLwNOCSDTxLJYbu3fQ5H7nJ0rx29JLXixsyyyTEyuN5bQ40gxxWlnp/ xdNWJeH2a/YuzDKyWp6fleZXJ49KJrklqjkXiv8AyH/Fr3MzJfL2X0xy28arh3e5hk8fi5r0 PS/jLuxPx69x13uWI8qnLFTu1qZUxVqoXQwz5r1tx10Mv5WSVXXUvLjck1J3dV6KOTU+hVc1 lVUSgeF0to29Data21OPdvHJajbmv6g6XXqdnw1exLrROHJudkxlgVl960exoqcHqbPGrLVy lsNqq0sRphnUdNTK6brK0g6bVTUMdcdWhOhXLWlXR2t93cWSrdU1LO34k1xS0MLVU8Uoglzu MlLaVmOuTjaI/Uq2JRruJpaKv7nPIqcz3fVi8RPZ9Ua0w/JZy5SISeO6bftRemYNEqLR/rIq xM00SNPI4WsoMsft9q67mfH1U8cVmzUoayO+j0R0JdGlAq0SctaGrxk2oxc9DOuTndp6JHRk c6JbmVcaq5vGvQky91p1xtp2tsyF7HMSjotvC0RdqpwjeRNc97LimtGyIb+h0zMrRIzsOkHM 8Vi6KqZum01roxuiTgboxdXVp1ajsWsb3fUbXGydYDJLftmfRFRDxNv3faY0xWs3Gx08L99i 6NvdQyaY5K0tSZ0IdrPSzldD0r1WRQzkvStor1RcncQo5KP1LZLsqvVaFs4fLOz6v8C9OcfS fgbT47XazPWPD/8A163tyV9Uz3Dr8f8ATHi/kzPl5/q+E/OU45H9TH8H/wCtb/8AE7//ANgx P5XCnU8z8UrU8mreic1Pf/Lnl8H/AOLyfxunyT9X06GJDPxr64OD8jhVlzO8nJRXq6s38fLx 5TklmzHz/K1ZSenYfyTo/tRrmqsfTU5eUKIln3OPWa+fZlypeWtW52Ju7V16M0pivfV1hGr5 V9qR0ljCseRUrE/d6Dq8dFFVL6hayo4vWR5OVEqpJJ9zGmHytjqlVe1zBx41etmk4Ox8r1VV MrtqVTws+W2leNe7F5yTq1ONvZli8WlpvZ+5bFJLZrU9PD+P4a2tJ1U8fHTZHm5fyOE/LpPh v6PGp497zwWp118DJavGzVV6bnpgebl/K3+mOs+KTv1cWH8ZixPlLs/U7K0rT7UkORckefl8 3Pl3rpJJ2hgTzQuZy21rFScf5CLU42lJ6e06eTM7463c2Um+FnHlOVXHxmelaXdaJtepnwvV Sp4nt+RWqu4UGR9ifN0ljjfh69a8ymG+RSmjVeJd7s1yYHV88Wj7FYc6yaPS3Yt529YnHhN8 eXdnXw6rdmlfHouhsFoSlmPPlfV1+vjPRKoq7Io4MvkPq/2Fj8hzvodPq5WbU8uMvjHok2qr KLKUTfKqVVnsxWzJXrRdTnONvZq8pOlYPHfx3yprTsdGPLXKpqQ3kyWdaNVSMv410uddL9V3 LZs/dernLeN/ZP2/+uztgaRz4PJWT220t2Og5WZ3duPKcpsdHhqc1T2zyPx9Zyz2R7B4fnv7 o1SABSjzsmY+R9hpyMfIc42b4dOUpZsrhtkjYybb3BwttSD6dr57HysC8inB/oeVk/GZa60h ntAa4/Jy49ksfNvxr1+9NCeJvdn0b131Mr+Njv0j6HafN7pjwfiPU/HOK2r2YsvgcVyrZR6m GPyPiq61Wr6muV8+PRJ0ehlummnszyLIq2S1nLYknZpJS30HHjiurw3GWrPScrJo4T6nN43j cLJ5HxfRHXaU5qTn/VP0duHX4+U/OtJqtHozHFMTq3V6djHN72nL03NcWfJSjrH+3v8AUuWO PqVW7N1a1Znd3xtNbz+oWXKbKyUGqpy1lNjBjXI3pkevqeh4MvPx2TrCOO2Lm+S6anb+NzK+ daawSrx7r8hfFZ1tMv8A0POpjq1prJ6n5OivkmzhKp41LVopThm5xS3qrJivzrVvdGnyPM1j slFdNDKtsjftcS41NMOF1s1E9mXPdkq5bVTr0mEKlpsk9bLY6XhfGDlm1LP2vbcVTdLN679D elnVJvcnVreGh43j/u+7sQb/AAq9Xflr2Cnj3spa9q9SePt5T+hmvIybtPj2JbezLa9FGj96 6ILQvfy+qHatr2V6S7dkugZP9zSPcYac1uSs7U1rvD1NedeKeOa2e/qUnabVst10C2er40st FtxNVBW1k123UieVWbdnFnsa45mJlepFqVr7r6tEVF8bhJa8upa/2q8k501Mru11xq0kFaut Nej1fc0KdrJS5h6mdcNn/uf2o2rlsk20rJ6e4mtqcv8At7EiItj/ALqvXsRZZMcTpyUo3vCl UMHbilGrRYMm3RTDXqyqppy/tZeS6tV9SsV7Zlxvov7bGgq1TyNrSNpLycrJ2XXRjpF22vuW jXYp1lNVeq76EqufBihOiUN9SqKlklO3U0w4lMztJrbFW0RoS0LHiravN7pmia4ut95lM1rW tKOXLWxlixLLdO+qOc7tVPJ1XFaveTOJTjpr+pd6PDeHMbFpcK8Y+5m0SstL/wBr21ZorqsW XXQi1ImdzCzvV9yK1unb2cY1lXRjnrezWKzbfQdfIvy4WLvlejW62ZdqFhs3XhwUJ62YWy8U 1W2pks+SkptcXv6lXWqtxb7GvVGSzXq3XJv0FkqsihadxLHkWTk66s9DHS9q8tI7GmdeZWkO ciipl5FUpvTbY9fJhd4a6HF5njWetUoZV1zLInVNfqa4MNcyfR9Dm+C9LcNvqbY8jxONmtBY FmSxtJzLOxYF8cY/1MPJrbI6q23RnTiVa1VeWhzt6KitK8eNrS1poa46WWLi3LTOTKrJzRTV nbisr43VqGX0VyZrNvWZ6nRitV0+Par1JarRuuz3BXdVr+g3RVkoabb7I5PKrWYrszT5dZSI zVd3EaCMtaU+NTrA+UrXcrBitZRLYZaVUaOFoxRyZdHMywrfhZStyXVc2l0Gq6e7YuAzPk5p pqKtvdFtzXDSl1DGq0o2lrJey56rTvL10M3fju9DWyey0lHHmfBpMncaclVd0zTFd10szmqn dcjR341neS4O3xsjq3W+qZve1bViux52Ju0W6ydVZrMaMzVinZ0jsJ57OVX7e5OTHrLbLx0V 8TXYnEcuTXd6CdqOsdDX4+S02Fkx1pXaZ/oX8DHiq60NPny+hWNJ1joP+MTepjZKNyuJLN8d 0qy4R31hzOzWvFiWb0ZqvJeRwlt1HzXNQS8pFZ2yStEwVXxaaHfPwZD8taTpJZdBS1qp8mLm rIWWs6yTVP8AUxVa8rVTrUwVsmqNLS36iU1TnqQZujb5WbnY6Kp7kNy0kXks+MVepqI1iSkc mHM/ttudRoORNN6LQpFU7sDBeNkb+/8Aoarxbrex01RUjRy2wOq+7Uyfj2bnkdWS2sEIqMVg a/uH8Tf9xvMbEyRWfxa/cx/Eu7NPUllRHxdm/wBxrAurZTZSAj4a+pPwVZq2C0AwvgoqvQjB gpZcoOq2zkx8Z+0voeofj0nQn4Iem31OncNI1MqwrgW9lqVbFjWrQ6tbIrfQkE0h6L9jR4+5 jWa2eho7TqZtzouIyJdzP7NH1L489WHHXUXqrejmnoc2a6rZKu8mlkrVhaGV6rZkkwrO1bZH vqycidHuVyTvxW3cPjdHD2MzoMbTdRrHoaUhoVlyft6CrXi5enqTdHaqVvVWeijcWOtL+1IV H8mONoMq0dtbWj6G9zuGr2V/jiZNMluMUOZ471yTRtruaUStM6Mls9SLrbSWtSK3mbNayVxi rUk15YlHQuSwF8lrNdi/kfXqTZp7sKXVPa9UzHWKdbavsOOWu5Laq9dmVjvCemvQvdGTbxv3 OEyq3vT3fcmZ5KWtq3sdGDDa1Pe1DLYhZEt1DfUzr5Nqvix2tajhpQQrUyTD9xGWnJXe36jr 7dmc1vkVkktEdGN1er3DcbJKNdUcuTE7vTT1Nr29srYt3XGVqalRz5MFawpAq3HI09YXYt4r W+2rOfy2Y+h/Buc+W9rHqf8A69b/AHMi71TPoj5f8U7+NnfyLhVr77f6H0a8jE9r1/dF+Gy8 cc/5c35bynavnf8A9i5Y786OHG58z4me78ujs5927PrPzqWeFSLaf5I+ar4NqZK3S2af3o93 y/Jw+mceVnljx/F8fPz2S+Ovp0UY1z4/8kV/Ix/5I/J3jd7Pq2X2aDMv5GP/ACQv5OPWbKCe F9jxvs5POwS56HmX3ldD3rquesV/c56/jsa+6x9D4fmnHjnO9Y83yfFeV2f8vMWZpamuKmW+ tatyetTDhx7JG3yIvL+TP7Yk+D3edi/H5d7WS/qdK/H421a82a7nR8hFsj6annvz/Jy7XHSf FPZrSlaKKpJD5IyA895W963jTmhcyQMLkPmw5NiPG8zzrLyqY6OK8kmdfj+O/JfHiXJ3ew2l q3BhfzfHx/dkr+5XkYfnx8Jj1POr+BwV1vazN/Hx+Oz/APZysvtC7/a7cHn4fJu6YnLSlmXn /kV4kVquVn0OX8R41aZMmSn2/YjorVfzrN7qvtO1+P4+PyZNvHjx3Em2delcFvynm6ZHjii3 9p7mLIslFdbNSZ+detMFubjQz8Oa+LXlo+JnnePPh5ThOGXOhxll768zM5uzI0vq2Qemdmql 6a9jlVV5K5L22T3N8740bMMGWjyOtXo0d+M6XlHHlZ5TjezL5cvLha0Nf1OnK7fGuW/Uyyvx 7WtzcNbo5+dlVKZruvQ30uejEt427ddf4zw6eVe18mqr/aP8l4lPHunj0Vuhy+L59/Cu3Vcq 23TJz+bk8u/O6S7JHt42SbXl8eV5zPd0WXLCk+5NcNqWra3eDVY3fFxmG9S74+aSbejk8H2Z 0nu93L4/K6jJTHa7mzq+usFePlTrHKdXBL8XHaHZS11ZrXHWqiqhIxecsxqcLL5JzYa5ddrd GRj8i2N8M36WOhILY65FFlKOfl6cuzV4dfLj0v8A8vR/HfdZ+h6Us+d8XJl8FtqryYuvep7v j+Rj8inPG5R4vm4XfKdePuu73mVqAAedQTZSmihAeQ0S2aZatN/UxbPpy7Hz7MthkthJyZvN pTSvuf8AQ1ONvZl1NwpeiOTL59K6Y/c/6HDly3zP3P8AToZxB34/FJ/Uzqsua+ZzZz6ExG4V fO3CmrZ62D8asLVsvuu9p+1f+J3yToji8fw8mfVLjT/J/wDQ9Kni1w0boo09zf3M3UUnk3O+ osrapPdQSbaejK9eaqnpHU1bSS6nHXNNVRtyvQ6Uq1WmvUzznZ1+O940e3uW2pk+NraPRr7S 3d5FqpRlfkr+yNOoxyvdhbAsc1jVbGlZxPVb7lu9lNsjlt7kZMVqubOeqLMo6KWVZcaNddCf GzUwX+SVCnRGNcn9tkjb8RStvK4tSobhkyYs7tfyGemZVvW0I4liTaa6dDq/LYq1acQtTDDZ Uo7KHpobt7JW2Ktk9Yjoae7WI36EeN5TWC2J0rrvfqZ5fJpVcqUlv+4uajpdb3SWxjkTW+sG GX8hZ1XsVY7Crd3U9xeOd03TfJtyKuzgXyWbhMvHaytFm4noXEdWPI1VLdL0FaiWPlZazsNX SxNWlT9rk5beddV+PeO5jx8uytb5Ml2mm1r00Rpbkr8U50mTnpe947f0NsqvRTaP0JeMVThe x2ixVsWOldFFluzJ39suG0DzKtFr7nuhgn5LVtxWqfU1yWcVb26mDvW20F5L1rjdbVnqoHip 14at+1DeVVpweskWVeCTUoK2qrS042JiM2qKkt6t6eg6YrNKX13FeFpspNsV1WrUuN9S9hMR Rqdt+4pq6xEwaV4N8o+7QrhbToKrneHkt9OxeKcdoWtUzXJVu3Kf/wAtBUSS/wBWND8rI8dk qx7tGJrk+MBlx0dladd9jaaOX1FB8a1nQ1xOqWvUmjTWsNGVbcZWyOdlsaa3srPihxxX6dCN HqmJVVtdnXZyYvGxrV53yaa3idTKtbujVnLT0Nsj5Y62rErRmSVo0eprL6J0GCrs/wBNZLtS lZUxGxnixzo3CesgqtL6msqMrclxiGXejruva9zV46uvGu3/AFNLV+RV130Zco471hvF0nRl XsudKJ7L3E+VjdLOilxGpCXO6mV6molVku7Sk5a2ZeLyFWsfvJnmwXx++mqemnQ5ovasNOUa xh2/PKiqMKeVWVCag56Zb1aVVD7tF3w5bNWiGMHR5OWuW0P7u5z+RjrCb+7rHUyuuNpvPJl4 3PSWFbYXZV49YjU1dEqqPuF99P8AcURtHQ58HLm3dP0M4rfG2nD0XSTTFrltLURsu5Nla+N2 6J7HPj5VurpQ0WQ1XmWh+pm8ltrKDp8mnPIraw0Z+S7XhJRCSGCKL5Ja6BRPM4Uyi8S47E1z vFZpqZCNqZEvbEOov5L4xZbMj5FdvTU5nktLpEQJBpDzX00bNMmBY6tW17GeG8uddjpf+5H/ AFLeg89ZYnoN2bcpQX5Pi3pbVaehdfkcKtft6gYvLO7ehnks8m5q07Wba1Kx4ob5SO3VHNyV awa4bOIa0MM9W2+KfFGuO9uOtW/U16DpxOXpoi8/kJPklHRmSu66urhmkc6bQzOK2pkb3Orx 68sdp3Rwe5rlHTY7vDs4btC0JJiuXE+SiIZrb3KXutzFO1ZSQ64rOynqZvc0Ym7LVfQ0+Ff5 f/yTxh6PREcf/Edd7Kyvns7e7Yt5XbToefbI0zqwWtZSXlaxOrspX266BbjVqGZWs2+O4r1i UtDnOvdvGeJvJkfWNkaZqUt9y2F497Ytoi250+RhokrTqztKjDFbT3HU0q/ajnquPqPDe7eo nc1d6JLlGpk6uNTpabMeLlo2jH5ODdX12HwVkrf6FZMOqc6gsbqmkwNcS4qN/U0rettmcbu+ PGsto6PGqlWY1e47Dfc2qjKqbZ0VRRSFMIGTbsBml1E0PbcIAJgTUjgJ7ACQoHEjAlaBPYYQ VADYkoGQTZ6Mz8ZzRF5HFWZ+N9iNeh6uhCsp/QJFZOydU4kyOe+R1jip1NKZuXQyWFUfBax1 Na14rVGfXo0HZrZijWWxWVUuzIVnXXclhGtnrBarC1IVG3ye/Y09CKyfK7322F8Tbm2xpeUt NGTdOFrK7GNtXpGaerScNAm24YZq2SVko7idm0nuzWYh1pDei0On45x8o9rOC2S3KLLQ6lmd nxWqWyHTdGaalJJrp9RVwpPWY3Nk3zSs0p6m7btSJ0q/ci90Y+ZwvVOidatHAsypKWx1+Zlp e6vWY/uMONbSmokt6dyHjyzWd0FdW9NApXHWjIyX9sr7SQaJtQluVdL6sywppzbqdFU2m05k ndWTc6MKXez2KS19/QztNnKUISDSaWc2cM7/ABq0tR8pnocOB2x25VcN9Tqx+U3ZUvZyznyv Pf2yN8Zwz91pZ/x+R/8ApOZ7kYvF8jFV0arr/c3qdcTKbbZxXx5lLb/QufJy9ou/HPS1dvDt Ze61U/qLH4mKv3ZP2Rz0yW3sTkzcdNTn4c70vP8A6Xz4Ttwek148cW20QvI8fF7K1R56u7JQ 2yq1V3/uNqpPqn93LlWvtz+njI9L+XH2pL9DLL5tqqZ09Djpxq3vHqEqy0Whq/Fw4zfF1+Hl fk+ScL01HieRbz86xzpMRufXYvx+JL/01Pqj478fiXjeZS60q2p9D79NNSjpwk3Yz/I43hnG 9/V83+e8OtKq9FGnQ+Pvdp7s/QfzdeWA/O/IfGzPo8fj48/i2+jwz5OXHl4xrjzOxfOxl46T rPU3g+VzycrI+p8dt4y1M2fUpVndstYrdi1ja6HO11j6HxlGOq9EbmFW60rHoHve+2p8uzba 1ZrfQUp7amHwtvXY2pXioM2SeqWSepuie4614qEMG4J1vRkxiGZQAABGXk5lgx2u/wBDwL+I 18XkX+61k/0k6/zfkrHxrbWqhtdzzvL/ADXz1rwxuqq5XU+l/H+PlOM5cf7r1v4Y5cuM6cvT q+pRy/kc3w4G+r0Dw/Jtmw1yWUWa1Rw+fleby8WBbJ8n+mp5uHD/APZnLtx63/h0vu9HwsHw Yq067v6s4PyeH58tcWLTJvy2g9NWZ5Pn5f4vkVz2TdYi0Gvi5W/JeX93XC8enXs58n4TJWjy WycrLWNz08flPN4qyPdrWDzs3/7DgVXXHW1m1HZGvgUuvCm+nJuyXoztz+y8N+aZ+6eLPCcf LOP/AC57W1Jlg9wg26M8uP5K8W4UithpZptbdjQZdqZGTwY3vVP6mkLaDC2Zzaq3qOtmpVn0 +hcvqksY5/F/up+xHj0o/dd7dDo5fJT2v3IMvjVupWljpOVzx5VjLL5cP+lfNRba9oQ/k0bS 26HJZ3lUyaPuzoWO3V77wjN4yLOVq8d3Ze5Q0aGePHw6tz3NDF79G4pFJCQzDTv/AB/93YnP 4Fsd/n8N8bf3U6M0/HbWO+JPLy53jzuf8/lOUcfiefXyPZb2ZVvR/wDQ7Di83wF5Kl6WW11o zj8P8pamT+N5Otul1/1/8S345znl8X/PH/8Ahjc7vZEcdfyFMk/GrWhw3BFvNbbUNR/2/wDi Xh/G+Tl6Z+rN+Tjx71l5a45Gebm82lNK+5mvnWpnhK7Vn32/U8u//wDbp1vRNvZzt+x9P4/g 8ZJy6vFz5bytgy+TfL9z07Ix5RsPAubba0QUw2yvTRdDvJI5oeSDoweDm8lc5VKd31+hr/D4 2rTRvdpansYq/K1tNdyXliuKni18VJY17n/e/wD60OnPXNo72b/x9B34uzVmlVGbrZtXf2mN DrezulfU18+mVVrau0QRbHbGq2dknOh1XvONUs3PdCXrqPJrhyJJ9Dra00CL29q01C01+7oL talxMaTIKMSideyFLbcDxtJSlr3ZalY52t6Tx9QTd6pWejRd0stlqpWhFox0sseycWLGSwJW u5cVR6P4z2+R6tOI2PLx5rY08aiLHqfir1r5NKPXRk5avHuPzFbXdIWsnnZlycr28Vqj2Py7 rW3JHg58iX2ddzeat7tMVHmo5ftr0NcflPHT44TW0nPgbcVr0WpXxtt8Yj1L2Y10LC3x5LS2 wZarFVR0Id7VTS3X29iXa2WvuJbaqbTdykmjasVXD/QiIXGv7g1ZaGkaZc0V+NqePdmKqmlk u1D0hblZeCqlWZ6ycZ048dnRm122zrVUlV9AxXb01aZxJs7fFzKqa6scuPjxWV1ZapWVeKTM 7Ure6V2kutka5dV8l9WRmxpaWUN6q3oeaVphWvFutWnXuXZNfc5Ct/j9rX6nVXJjtWLI0pce Kf0ObVypN8+Rui6GTWiezJhQ07aX2HjraIa6jte1rJ2qlGhrW6M0kUsaW0C5WKq1EGfLoTWz 5sqtNG+hCvNoSNttv1RL0EZ0tK+g+GiI8yysq9TTStYr+5rl2jJpKtp6dSMtZb0LrVOskWvt x1MyqdEonqjThbi3o0zKid3oOme8tXcwO4rE1wdGtJlE5P8Ab0rX9Sq2TbdtENZJbVtRqlSt brWJ9CceN1fG63ZTx0S03bNctlpZbrcujkeN47WSej1Hhtyq+S17m7yK1m2oTWhm7xLWzLqO atbWm25OKsXXJ6bmiu9VZwn1M7VtyS3jY1qVu+Dcuz/QmuSlr8l+pz5LuuiULqzmtlpM7R/U sYdHk4OT5Y7P6M5KZrpuW4N8PkOtm7S6voXmonRt1S6pmtHNkzSoVmtCMee73bM+HPVvQ18f ElZctpNDrvkcTLWhVbXutG0oObLOKzo3MD+bR8NEY6qdPIvX22bN6Xd6Oys2133OS8ZWlXRw c3O1LSmaHs4W8iTTfqh3pZuU2kiLOtcayUcKxirWv3hmerTW929KWMaqzbll4Krk6r9zK1Lc 2mSX0Sqvyp7qtwOlrWl20Y6WhJMlZtYjUu1GWPyLJtNv0Lee6ru5J+Ot3zfc6qxy0ScqNS2o ivkWXVuSq5VjmbPXoRarUzstgw15fcv3Jqh48j1pZ8X3MqfPZNzEdzoo3LSZle9odVuxqM8W W7fubgn5GnabfRCSdX7inFsicaF0YWzZIjk/3NsGW73ZeTxsT1ThCeNUr7HLX7Mui7NdZ/c7 sHHi/oeavclyslJ1+NlpRNtTBmtQNzp1G4olr7hp8vfsuhg18ltWYG1catXlb2/Qwg7K4/bo 9EZy+y3CuK3jRozfHxooSN1r9247VSZm3UxjjyRaTnurZLaG13WpiuczsWDSmJtybPHZQ3qC tCgm+Rxo4EGlqwiVkeNaL6kVvbpqu5N3edepqUx2483Os9Cvto7JHNgulozpyOK7m5yKz5u6 1RDUaW2Ix5naatbdS7puvKuprUVg4pQjcnBgTqrLdmnBzDEF46vc2SEnRb2S/UutsVv70USY u2rNMmTDXTmv3MXfD/mi4g5SDsL5MU/cJ5sCf3DBXIbZm8+CfvK+fx/8hgpWDkQvI8faWN58 C6tjBUhLJXkYH1Yn5OBaKWMGkhsZPysS7lLycPVsYDJPFsy8ZzRGtvJwqr3OfxvJw1rDmS50 PV1j3Mf5eL1E/NxrZMmDXipM2+b10SMsPl0rrZN9xvyKWfKtWq/6mbFin92yjuO8LRbmOTPS 7Vqp1joylmx3UtGeytaXTWm6LolZ7wzlz5VZzRRPRF4n8mt1EdupOV6LO7bJo3Raruc6vaeK Ku6q3HqZ2jHaLbnPjtWujM3Svue5jhu37GtRYrq0v+1F/NVxaq1Xcs6XE7lnrWrnqc6izmp2 ZvJVv7ZXc5reRR6UrDXU36I3yPlVUTnj2IeR00tpJle746bitlTrqpshAsl3WElu9i7NSm9D Hk7axqQpvbTRI1R1WXJT/oNWTSSQrTfC9YjsTjzZFFd4RM2DZ05PtCJVrJSSstrOEw5Orh7d TNnRQ7q2r2KyZU0u5N/a5WxDXPXqZncaY8nG0xJV6rM5adWuxzYq2W+50PDaq91ty+qVVruq UPRepVclsq9VsZuKNRsS7u9pr7S9RV8dkOjo001LC9uUKWDdaL2tMl6isdm3skkDXKXvBy3V rPkmVyulxbguDqxuU1GxTwuOUbnDq9UzRZulrSazZ1b4c7w5Tnx7xqvZZPqmmfcJypPg8lU0 tdGd/jfnPI8Zcbxkqv8ALf8Acxw4zjf1d/n+e/NOOzLxfQflY/j2k/MvLc3Z9Z+R/N/y8bpW rq+iPkcysre5H0OHKT47x3rXgs/drq8PWn6nTByeDqmvU7G4Pk/J0519X4r+yCCkhI0puvqc a7R9Bj+1R2NEiK7FSfMvdaoCHZky2TExpISkZgMXGnNC5kgMMiuTAQARfDju+V6pv1Ob8jhV vHsklp2R2DNceVll9hh4tnbFR23hScuHw8n8m3kZNoip6IGvOy8s/uCJyYqZa8bqUWBz3BzY /A8fF9uOs/Q0zpfGzUy8j/02a8rbNukeI9xDe4j3oAGAGbxVbba3GsVF0Whoqt7IpYrvozXV neM9kCg2Xj3fQbwOutrJfqXx5eyfZxnq5r465FFjktz8b/uoepXHif8AegsvFS999Dpx4cu1 nRx5/JwvWXr7uHHmV9jdHl5Kcbt0tFZ3R63jZKLHxtyn/Oprl8XXv0SfNk6zqqtLPZMeOjyz xhwN+RjvZSrONNbaGbrix6Uqk5ncs+Hj61m/yOXpG3iefXGrV0mepGT8xkvbhi1szl8rG/Ij HT2xrpsedXDl8e6duhr6fj7+PX8sfbz5Xu9mqzZMvx5re56pSexl/H4/B8V3cfNk05W3/Qz/ AP1/xfnb8m6hdJOf855q8nNxxuaV0NcOE576cOP/AL1OXK8en91/9nnvhh+3lr90aSbY/ivR 3VFK25e7/U5U/wC1l0dqW4pTJ0rkf8p03S+iSRpgw85vkhz0MXT3e5HRRmbUedbjiyrG1FeU P6Hq1Sx2mnF16Hm/kaxZWXY7Hk9qZjl1bs6RdK0WR37mdqO7mm3+Pcl+Q6WXJaNEu6taIJNY 1q8Karz2KyUmkqYkwqnWyeT7TpdmqJpwmKpXpSyVN30kulrQqvozDC3kb7JnRXL8StbR9EjW DS9le7T6HD5CtiuvU6aWeavu0kq1JUL6SZ3BzUvZ9ILxtL7kXkqlb2g7uFXd7stqsXipFmpn oYZK8KRXq5Z1ZqVjR69gx4Hartf21S3LKy821uTnZno/iG35FZ6JnDbHy+p3+Bj4Zsdk9Zho 1y7HHu7vzGLlVNuNTx/K+OK1Vfct33Pb/KqVr3Pn7W4ZNdixeRY3FpWkm9HKiu8hR15pWiLG +alMbrxncms4cqsTOu5z2pMxp6GvkWrV8uTb/wATJOFPRliJx2dd9kafI3LYOum2hk4rWDWJ qbWeW8Qb/wAGz1WxngUWU9z182S2JQ0a8rOxJry/4Vkm4OfFa2O/9D2V5CsoOZYK2t3fYefT qXil1cRv6mtHa9feprXqbWq1VKih9jm+Tg3U83fs3irLnV1qvoxZFazSbh7Fc7VXKujBVbUv V9yiXT2R1RnZN1l7I1srOyjVGWW1l7H/AENQaKyVZe5pWys+09iK4vkXu26C4R7UZiujlVGN LNN8iOfDTqDs3qTGm1LRaAdbO0JkKygqj0laNFiDKpaqlrCNG3VQzPI3z03SCjd1qXlPca2h 10ME92i6w1KYWfH3JbmewvDNt9+wr1tbT9xNttcdGy8jhf8AQlGWrTa3RCvZWifUutk26taM jR6Po9AOyylJsh09urkma116RqRTMrP/ALXsXBrwS2MFbjNbS6m6skkt5Mk4e8WmRBk4s2kt OzKvVaLFKTg0yZlez01e5NeNNbaroX1SuXyOVJX9Tj+OXy3Z6ebIq6tfsctctLPWEjUYS8nx 041UPuc1st7TWzlsPKycrTVQjltZydJEbKttzrxtXqujRx4bqYu9D0bPHSFS0pqRVTanyvm9 Wc/urbRQd2TOnjiqiOqOWzbWj2Mqwtdtyh2orwv3YUXyf7dlDk7cfjqtXLVY/qa7B+PjSo6P aTHHR8+Lsdla/aphnHZ1WRqy0Ird14a7GWSzzNRo0i7X41+uw7244o9TMVyKztbtHQLNtcug 3TlrXU0irT49tjTJYbK74t6F/Iq20MOFVjTaabGko5IWDqWRRt9SPlS9qZlSycpvcwtNdWiY O2tkk9P1DSZ3Oet26x1CuRxqMNbLlL2MrZUnq9SbZf8ADdix0dlIkA5ct/aXeF7ceqaOh00V b6StRKtayq6yhqOajqtbGlMvG3LoZVSmDeteWkCqbz2TUr29jenDJXaGw4KeL0ZriqqrnXV9 jnTUUslKtsc8+vU6W4t6s14r07mdNcVceRqZ1HdpKbPUutmnMwc+dvqWW2tYOe2kmqm2iZzY at9dDWtLLWTTLXJislvJzO1lubWzWrocztaxudkb1yQtBZMy6bmXC2vHqLGo0sRWiyOrmEbW va9Vpocum3QqXZabDVLHm4W1R21o7rm4S7HNh8dXtFumsnc1CnqW8vYkZO8KF+hTlxyFDe5l ll6IeS4vLxSg5PkptL/c6MXjqyixr/x+N+hqcvSnjXJXhbRG3D0PQ8HwMVckvVep05/AVrTV pI3OUtxm8bHiXtWmjRNL1u9jr8zw4hJ6j8PwrWfEvKyQxi1XsgfGziFJh+Qw2x5eMj/H+O8m dVrua5dJrMaZHWil1IXk0/xZ7Hl/j/jrD1PM/hVM7M1qcax/lV/xGvKq/wC02Xg1Zrf8XXHj +S1tB5bcPHGNb8lyahGdfIxNwbXxY8uFOraqupxrD41fus5NZ0Y9XXdqtZiTmp5CrpxPTvhp i8dXtqnsLxPxfzY/ktp6EtzjvvWpOrz/AOV6C/lPsdr8Gi3J/iY0tSeTXijFb5FLUIzt5FG4 tpB3V8dPC7126HkeRhvdq2OunVmZfJLMei52aX7nO5paIhHd+I/Hq+N3y6FeT4VKWhOTM9Yu OTFjVnymCubtbid3i1xVrwtWWY+ZSlbJ0ULqYk3ut6ObJ93f1M7Oy6I6LxV6PQ51NtJG4YLX 4b1NH7tVt1DDXnd1tsa2XHSNDF5ash1smklqjHNVV1S2NWq1rzW/Y56Wd9HLLNk0XhTyaRDH bFwTe8Hp+F4qyTZppbHJ5GN473W6g68es1i9K85ZrTCjUfKyTZnhpa2SEi87urQ9GW3qK+W6 rC3Yc7pab9grNobNly2jQx5NY5K5bPpBrXInpZ7ml6OEjP4l9yLUxdbvG1W2qZ1Y6qis7L2v qcFeVn7jv5tU4xJjeq+gx8bJ36BetcnoRfH7VauhyLJZ29xuMNnuupN/ddQXhy0TneCHunsR qL+FWTncXw8F2ZeFw5ex33tjtWKLT1Jq48+mN/cTXE9ZO58YiDJtKrKuOW9XVbBwlJwdDvFd idLaIzaiFL32ItdxEaHQoWiM70dtYJFc6stZ6CfG1Z3k0zVeOsRuc+LszfojV4seKk1UN7nL lvdREQzssm1HQwzUiLNe1Mz4y9a1OfKdJV4sSetnH0NKa616CbxVTaenY5LeTPtpMf1J4S+i /Zynq9PJ+Yti3Ska/MrhMp2/xR51MFr119q69bM7Vjphx+xJdzn9Pxf4tfdz92tfyOd63pWq 6JuWU/yGaJ4o5FW1lKQfK9npBPo+P/E+7n7ui35XJX+2pVfyeR7qpxWXNSkSsjq46F+j4/8A E+7n7u9/ksmySLr+Rva0JI8q1mnKYq2snyWpPo+P/FPu5+71b/kctWqqq1If5XInEVOF+U0/ cXi4tfUfR8c78V+7n7uyv5S734mi/I3e0SeVkwWpr0Z0OyVUuJL8Hx+nE+7n7vQ/m5IlcZZF vMyr+5L9DhV+DcrUXyq2rT0H08P8U+3n7u7+Xm6v+gfy8rUqyX6HDbyIrxWz6lY7+2OvqWfF w/xh9vL3dX8vO5Ux+hOXPdqHeZ/tMLWs9Hq2PHXjLS1NfXwn9sS/Jz/yqLWfTbuc/wAl/uT0 2Oi2yjf1MPhbvxWvoaknszt914OVnq3t1OxK9ayjnssldHojalq47VfJtRsKmo4ptN9Cead2 66G16e2TDnWq13AG9ZkvjXImraGWq1Rqr66lGeP/AG6xYzs1evvehrnyVVZZ41s7tflbZbI1 xm9UdnGq0nQ1x5eC41cI4K2yZpWNSluVwyU3ZvIu3s72nv8A6FUtprsc2HNfHaH+qOm6UfJT YYjWrhc67M0w+O/JssffczUXryR9D+E8P46PPk+v6HLnb2net8J63tD/ACuav47xFgxr3XUf ofJY88OMm/c9H8jnflZ7ZLfovQ4MlFdepvPGThPTuTltt5erS9Oamr+p0YlVOZn1PNXLDo/t Z24780lj9y/0M2l442vCemxKcMq74xK0ZF067lYYeb7qT2POy+bkVVjWiS36jzeS8uTivtWh n8FszSopYyS9W+/Fz2va2tm39Qre1HNW0z1afjaVrFpd2Vl/ErVrSFJrynZhhg/KXbSzar/I 9TJldqqGrLoz5u1XVwzq8PyXT/at9renoyXh7D6DDNK7pT0M5quSmbSTj8ilYVen+p0Wp8yV tJXUxOlVLjWZUbrsGScMayRit91ZT/7jSq05v7uxKqVnqtY1CHu1okW8SunZv3STlq3pXppA xGV8N7VlV9ZJWR8bSnrt6HThy3bVMulI6bkUo1lastEp1KOJvk5ag7PE8hXtXG/ukebEs1lT GtWc3jYb18lJKdS9LD1e3+Vq1RprU+d+B5JdpnofQ/mLO1J6pHiY/clasyt+xZ2Xl3GDDa1N dEY5slq3lfszr9+KjSmNzjvlbXGyLJdc7cRjvNpsdN8qqoephSqnuoGm/wBDp4sXk3x5navH 1LyVlz0MsdXulodrtVJSY5XL0WXY4odXJv8ANZ6Mi1pcIPclrsbyVnyqqSpLo7pq2PSyFwTi N+p0Vq006nO3i1NXTMnrkmUc9sfL3F3x+6QeN11nQ55jbOW9GzS1uFlGqZirvk0kOtkVYmzs re3YeW3KI1cam+OeLgzq1WbWW4lMRjytpKdVpBrbE/vrsZ46av8AcbbrZIl7qHXrYdGtiraJ xrO5LrD1WnQXqqnXsSnxeg+LZWTHxaIIxLk3qb1p7YIcLJFe0wa179GbqMOHHSNtTXknWEF1 NdB43VPi1qYqprZL222IdVZvjtOjNLurVu6Hjty0Wi31AxyY+K5uEJNXSS3ZGfWzdpa2GrKt lGxYNK/4vVlY+FrJVrCW46OtHyb0ZDmr5UahhF3xLE009LC++6SX6sfuvpo0l0KrldGvrqiK 5Mml7JbTBV7Yvtaa/UrLi/3LWr11g57pq6q9OpuMUNacbPRmNvHpyhanXbE+PLj+smSppLYR jkVcfto1ZdfQ8+6mxveatpfuEKyR0iHgpjb90fqFsXD31cpMiqh6ptG1oaiGk9iiMeVw1vJs uNUm9yX4jx0WSrnXY7c2RWxKr0nfQzVede7paV+5d1a9VZPViy0skn0Jo4hr9iq9PEnxqqL3 GSrPualmzSriTrpqcmR8W27emhlWyq3HKEpLzY6qis2uMnJN644essvLCwrtJRbyVxw6RBz/ ACK9237UTTG8qbr0Hal4U6Domtc2OaK9ftRFIj29TtxKiapy5Ve62DNVuvx41s9DO+ia5MWB XvprG50ZfEWJ+62jWxv4l6Y1CXFreepz5s/y25euxNujjzY+C9u5GNWv7Fo31Oi962tqnBje /VaJGxrXDfxsnFw2deOlUuTUanHjz87JvU78nC6haGOVvajLK685Zl8iqp1FyU66MWe1dOK9 GxBglyn66FO+RbdAacwdVLTWIktuDnpmbc21Z6GO9Zhvc46eJF067+poqq79+6M8so2ytV1e 5n/Jr/QLWTUdjPhUxiFa90+5F7StTetesj+OvT+pZXSubFjsbtPGpLWmiIc20aL6soyOUn16 GHN0csvKofYzfu0Rsb0s2uS0Jbr1MsVrL2hbIthgr4016lKjVYkz1tXQqlqpzbfoFdGLHZPu mattL6kprIkti0kvojKlPRD4aE2jcqr7hppiSf6GnJdTCq09SqyFduDSyb2PWdUeR4i55Ee0 6IvHunJ8/wCRWLs6/wAfd61Vf/6h/kMCp7l1F4Du6wog6850lSXo8bzPKpTNZXpycnZ+Cz/J 5KVaJaOWc/k/i82fI7VU6nq/gvxWbxc3yZNFEQb+ayz9vs58fy6fyfJL0PKT7Hrfkndv06nl K/FNwZ5do3KNnruep5PivyPC2fN9DLw1iy5K1anq2e/dJJrpBnh/XOXt1OV2Y+QpieP8bDSm WfN2mzhdz735sVaKlqTVsxpn8KmO7pjTVXD0PTeX9XHO/Jyz1cP5TFx8PFjr2/c7PC5fxa9N Njqr5mLIlTh/bKlbE+HmaxJqqaexyv8ARx4/43/5ane/l5N03aHuFMF8r4VUtnrrya1vxWNT 1hHoePj425KkStWYrprzfN8NYMS+JbLU+UfkZcN45adj7zza8sdp2PE/4jxfvyWU9TpMnDHP vXneP5N3R8m9SXfWJOrL4mPHPxW07HnfErP2vU43o1HXjblNGmSzzPaDDDZ1bb2Rqsrer2Me WdWu7myPjZqu3qRRWlu2xrntGihNmHyVsmm9US7ew2SX3JSXXneylx6GeH7dX9DSlXZ8k9UZ is8uF6vZJ62BJ0qmnudeKuO1FW+7epWbD4z0q3yex0zWXd4XmUeNY0ny7nm+TZvK1br2DHkp iStMXTiOgJ47XdrM1xuSxLOuvKs7LK+OkF1yLNNXpYrybKmRtdTmxZn7k1M9WWo0c478d0dP yLjK37EYMb3svoXkSq1O5zza01xO1q6kXTq9Voa1tpCHKvbi+hdarPHTqVe3FSdNZ48VBnkq qpdTMZrmrazUIyyYdOTcs6rPT26HLlypNJLQ3GSxePZe7oGdPFaUVTJWz0cJGuTyKWxqrT5L qWGMnrWT0L4740uK0aPL+dQ6xB2U8i9qaN+kmbMab3bWltyHxUhfJFFzYZXXTiZ8mmOSzS+o Y9pKupCsJQaqJnk5ZrSsepn9OhSvG5lVWryTbODj8dmoO3I/byqcWez0bRqXpjDej0aZh5Tt avBGuNQpIzNxyqOK15VkuXG12/oeji44VCrL+p5XCzvystJPUpLWpvkzGtcnJ7KqOml62UXe nocCx2X26nXhT+N8kjF6NQc62fs6E2qrSxKK19r17EQ+PqZzqFjbWj0SNnfFxiq17mKpWzhv Q3WKr0QqMcni2UOdzS+euJcI1W8C+PJaYbhDx4UmpJvuY58rpZ9l1NnjpWqtV79B5uGTQ46r 3QtDfdHbW11o9hWTUmVMsaPcutnZz0IrRY5XLqjC+jaOulklqZNu8uq0JKVlTGrObaI3qqJx uLF701bRIar7l2IsF6PTiU8iqttTS1olozdZUzr2J+qs7N8exr4uauPW+5hk5/3aszyJqq9T WbGXTmyLNblZwukmbo1VWTlnK7KZep2Ynop0BG1VfJZV6djPPhrMFNzbf9ib0SbZmKx+G/Qp YdJtoOuTjoO2VWWuxrqPL87LL+NbLc48dHlsqovPfnZ2Ov8AGRRWu93odr0nRmOrj8FeFdiM 1dF2Zrk43qoepna3JJW2RiNblT49eT5SuVddTV5bcnyj3bxsRiy+PwaX/qddBWyq8P8AQst2 rymXp6uv8ZjWTyVhb0tr+x9F+X8+vj414uL7n93oj5FeTfxslc2NxeuqZ3NvMvmvq7a6jM5e f/RbvHxTdctyXUta6MWSdkZRkrUtNLLfqY2x2xW5YW9C+OqnqbVqmtXEkWXGeHyKZFwy7kef l443H0QZfHq6yvuRwXvfyksS14mp3LJesclXDTPR8PJwbKx/juGSr5dOUdjnm1MrT0bb1Ncp sON9HpfyIosi0ZX8ht6PdQzj8fPbxrPDdKe72It5FHfR+6f0MeLDo8/DW+P2b11k8U9xWeSr V1p3PGyLjZo3w7dR6viZFkxQ9ztWidTzvxWRV5J6voexgdbtpqNJM2dVY0xJTau4smXnlmdF udHGXFF0MaOsOkerMjS+ROIh2f8ARCyJ20fU0rfG6pUW28ital0k9zKlbDVxbVqpTeRLlaHK 01I4uYXXsK1lVzbSNwGnk5JuUvQr21SiVflqxVyWhaSjN2dsy7Si4PU82Gly2PN+J47/AB01 nU9Pz0uMM87PaLVtXdo1PZrkztldU1t0g5slaZHVz6HRl4V16vcwtVJTVSjXDI48tYWxuraq 5XQpXpVwnOg090dGTDitRfGnyjWTpbjnJrk+dpwnoZPNYTxty+25LSSbf6GeldJGmPK/1PTx 3d6r0MPAyYnjaa/3F/caPNR3dnon0OXLr0XHRltCTaXJdib2q1NZ5GeG6yTyWhosSx15Jadz litMOZ2UWr7v+hV7TptJnaW+VFGgV6Ns1qoeO1dXsPhVJtbmebkrJrbuHJKsmhovam1sEVvV yyKW5abF40rPomv6kUqp4olvj0LjmkJ0tZcX01RddKwi8uvUK0RDMcloeuxtE69CL1VnPUxx qnSrlJPTqbXo7twzPnSFE8uzLtkaryqtRRz1rZ3ffudGN2bVa7oq9nSH3WpNGre7qb33FxX+ 7uHGrbaM7ZKtJDWj5LXSIMXv0NJ8aJ3trOkGOLJW2ttC3XtoRENqE1uak6I1WJtzP6EWxOWt G2Nu263IticzV6km6tOlOUqFotTObclRrRFfClbeTo8nGnZ8uy2NI5Mtk9tI2OjDbm4giuP4 2uv1KV2lNF12IJvl4u9FG+hFrptPtoa3xauyUM5a2TvpqyyJWubyVEKZ7mPze3VbmHkW97np 0RlbK3/4G8Za5a/NZRuCvdex1UIzw54epr5XkTX2vUfgUuO7mOpjkdG5pojKmSzUSbLDe2Pl Gk/qVDXktLQdbvJWLOXJi8f9r0ZFbtPiMVrfLai49DNQqz1L48nq50MbVdXDNQepy/8A7ZfU 5cSctOsp7HTxa8atq9zOuSKNPVojTa9Jxqr1bFeq4U5Joxwt6t7GmVt0oupkLHRzwUeptkri ulVOLLq+pzKnGsa8m9WaZMaquT1glZwVfGH+hqvJWOyVdzLJkrnShKtltCOTOtf+4mdUepe6 ybaR1OW6rVpp/U0xYVjwu13DZjkxN05pAVwV/dTdGtcNODeSst6L6j8SlaVdmaUzrRX+0Wq4 f4bwV+Sf0FS/K0HqZnhzLk3Hoeb5Dx8k6KBLvdDdfls4cQc9kqaLcLZUtV06F0vC52X3bDsq sdeWs6mlJo4b0ZhVur5M6Hatob6ijpae62RlbJMrZkq9sbUOV2Ku1ZStzCIrj4esmnyY+xhl 5aR03MeXr1H5R1V0bsTa6WwZKz1ML+37dy46VayWo5RVfIc7HNF7PsWpW5rEZ5MnJ+p0UxcI a6mOkz2K+dt6lGjxtNvuc3CLRY1q3utTHJLfqaF3y8Pb0M3ZtisuRWyA1x3aeswbK/PQ43kh m1bxEEsadjqUrLbqQlyW43XszLTatmTa7JqK1RivQ8G6WRN7HtWyqT5/x6OUu7PdsmlA49OS cuzk8y6yKF0OGma+JRRl+Ta9E+KRx4vJV7cXozfK1iV6OD8hnw6So+hovyPkZdOUL0POyWjR OQrZ0rEk8iuryPJslDcnFazvaNiMztGmxkm5h7ktJH03jXx+NRcK8rs2y+Zaqm9WpR41eeO1 bUtsdPl+bbNWISN8OiVtXDa2OuV60kmmC1q2pjhcrK0tHm4PItXSzfHsWvNa0WxdV9Fn8e3J OjWq4niJ3xWeNOa0fQm35O3F1Sc92cHj52q2b11N7PE9XuePezvxnWzlnu0px6yfI+N5Va11 TlnTi82y+1P9zEi17P5JuuG3qfL3uzt8n8lkyrjY8x8m46GuV/b4pDdm3LMObrqtDoWGzRNs ajU4bFTWy3fU1tdVr/0JS6NEXTr7tySdUtPInlfJpKEY2xr6doHiyWs2+5ba0cFpErI6VSaN KZUt2Zqr36Gd8Hu2JJrTp+au5Vsidfbuc9cEaGmLE61bexRlXTfua2pzUoi9Yr6nRXxb1qrv b6l9RyeVjTpy6nOqe2F+56Hk09nJ7HN4q+Ztv7Ua9GfUYFdVU/oVdvkp3Orx/HeRNpqE4OdY rPJbrGhPdWWS7q9NCsN23q9R5cfu1M6zVyiUehVpUl7jx2UScl/ImpFM17aIz6I7nWltW4ON takt2VttyW5mso1BpVaRCC1XbRs6/EwVyKbOH6mmXxe1kWK8W1OF03qjvpktd+3Q1zYaqIeq JwVSs5e+w5TZpG2TG7KXqc7vx9rWh1fGk9bGVlX7W59TEnRUUunuJ+0dapuW9DbOsddaOWyj Cil7lWqp13Eqqq5SZ8nb0Mi3Pf8AQwzv2y9Rq2upcK2peyJo5oS7dHsyqtRx6jeOsLuXoORe KrNPl7auYgvM2n6F2SSda6i+KVq9TW+6Yz+R1f1OuG6w9jlrj1atsdDvo41hC9SM+Lr7kgyR El4HzSb/AGFm16E9VZ1xzodF+WKI1MViaXI2pZp+5/QlQ1ltVarcb42bWwndu3TTdhmzp7b+ hjDXP5GPjqnNfU53VtprQ6edUmrQ29geC2k2TfY6airUdWlKaKb0hCpTlf3OYWiLpWX7tCap qqVdUJY3D4vQtuYhyyacE4s2tTIc/HWIIrNn7noLLlrPsenqTW86zqWQdasvtOXNd1t6Cfku YWrDLVXSYk91tNW5b/oZZLRruLjZNa6FRF4saxF86x7a6vubq9FVK2tiFdXcpTA1RKjb0tJh Rj9VAs1nt0LfvoY3einc1BlbY0xQkyEub+hrjpXlDJR4GQ7PAftaZz+RThe1ezOn8faaunrJ 25dtZjTJXhrZe2Hoc78nkmq1ih6F8d8ldXoJ4VWvwpKO5Jyg8e1k/tUHVju+FImZ1Oin4zHK 5tpM38nx1gVK00rMl2K4vJt7TrpTzrUT9sR1jY8/yHyaot2z35t9iexLcV5ap5SejRLp5GR6 3PRyY9PU5seNzMk8kc9cOdvjyB4My0eQ67rhaXpOxrWqtSE5Y8jHC/CyrV5NzLyfFt4/Hjee fVHpWq37Tl8zDZ4J/wAXP6MsvVHP4tcuHlmeqro1JtX22Wa13Wt9Yrr+h5dct6p1TcPdHsUd b4uPT0LbiuDPkr5WdtSqvSWZvxnz4r7Z+5nqUw45h6tLRJE5Gkq06zqZ89RXCrfsenaTxs33 2juerlp8M2e26Z47cuS8ew7fx69zcwe7496VU1lX7ni+HR0x8+7PQxtOsLczyV1u7pRtPUzx O2GLbhlV37W/UL2T0WjOcU65m3ydZ9ERlyKIqtehqlOu30M7KG31KYiub44beqN8kXo3XXrq ZNyoaX1FS14mCi8dqvTua4uPKs7Scz1s6rQpKGq7l6JK9bz7J0ldEefkStStv9Dr8xcsbW2h w0V/gVU9noSN8mWSivKnUSwWotXKNVWftU2NKO2RWVtILKxmscOHldvTRTr1C7hzfT6FO6xK ephnvySs00n1Lu1MkHjV5X4xpEmmTxseeXyVWtqsx5UVdHDRtW+NU6OdZJ13Rh4eH4072cVe jO7K8ToseOG12M75px/Eqpzsc/j43jtqT8jsriWWsbMulVTRWmu8eorOte5SXJQkc1HJueTh MLUSqk9u4+b4ulugr3qlBcAq1a9CHXko6Iqt1asLcHpWepFY8eNXPQrHGT7tuhGSG5tuVjyK d9EUaq8JLsKt1fVSidOU12nqa6Y26lvZU8klDM1kfLQbaUphjSTmNySCnZWcW2NdFNaOavUx dFZaFUXCZ0UFsFWx86t13W8mWO7rp1NLt6WRg1ytqLEb/C5037kfFxbj7i621S7FtKtpkxb0 axhNn11Qvjac2cLsbO/GYjUzVXesrdM3xRcK2icGPHi5Tn0LtW0SoXoFaLG4/oBmk0+NjW6l KNiMur5dzTA+atW2nqUZXbUQyFbJVxpvqzSJcQOtrY3yqlxe6YRrnh7aSup5NV7m3ud/ke6G +pytrjyrq9jUSs7Q04Ry0xvLb6myxXsm+kSPBZY2m+puMtKeLx+9OO6M/I8ZUqnVyjpfkXfa DF5rLSFBBz46cVL0behpa7Vva9JMs2RaJbwYy9i5qPUx+Rj4vlE+qObLbHeY0M8ab6bFXpVP eQqE9FD1H8nyaW36EZKrHFk5Hiqstp2RR6rq34tVKq+5hXFZLjZz3grzk/4+OpOOjxt8XpH9 TLQrV6pvQHk6fuFJVfctW5NZcOzrKJuJpVtyrHQ251qu8nN8yWlB1zLL7moOeajDN7L+xyug 1av3P7lrqZ5KtP6nXirivVK61/yOnZGmOy8mvufGqDJnpeqpVxU5/P5LjjppTp6nOqWo1XIo RM9R0Z/IXHgtkY0tW+lnBHmLGr/7UwZJvepZB1PJSm2/Uyvkblb9jJarXQmzdIZZBoqxWXuS sjcJ7IvDa7+16M2+Gt6uXDQt9xDfPQVk0oXQh2049i8NHMhWlLW1s9h/yXRQ1qb3cJTscuZ1 b10OfdF/Ja65M549Op04aStGP4n6bj8DRe/bYKVq7OdEiLU6YtPUp1dmqLoTHRFm+hzZG1q9 mdPvtKB4XesZbQlsb7I4pZrSjtZJ6SFMda2mZg0thtf31FqOvIseGqrXc87LvK3NPc91t1Nn 4ruuTaRJc6UcuKlrOEbZstV0RfyUpXj19Dium/e9kWdb1FOkw5/QdUm4M6WlcYNccJ+42O3D ZW9EdS+JLXc4K2qtehtyTU9Tm268fw7y/wBTZZMPVSedSY1O/DlpTHDWrHqOzx74LWUJnZ5O dVWmp4mHNDmq1KXkPI2noXcrNo8i7zOKmNsVen3Ldmts6o+K26tEZL1t9uxLdSMK5J36G3JM xrjtVudnuNJJGb36KrJm2Rl8rmWpSBI04xXVmxeO8qZMn5FleG9BS6Uhb9yceP2zYRGk2sm0 ZtNa9jal1XYzdk9WwqXmcamWLLxkaadu6M/ie/qblG3zvodPj5rWThnBy+NQ1LO/xrVdNF0k nK4sReeb1LWVxBja0arUrE516i+6ummSYSeof3bmbrVOTSlqvQ5Ja04uz92sHPfCv1Zq7Wpt 1It7WnbWTUYYXxNWNbaWVWtCLrnkSWhrlo66rYlaiHjmWrbdDKvO71eg1dS1uUvbCMzVJ2sr pI15WqtXJhk9jncvHdbmxnZu2pVcradZLtmVnskzmlVyabM1ia6ZdsbUnNir8adW99Topklx 1MMmPl7pUiUUszxVaraJM8V2tG9XqTSsNcup0eTWuJp1ck63oJd+kaiVG9JiTKr56yW5ahiD SvjcLa6l1wP+1qWLHZJQ2WrayuhLQ7L49tzjtibfI6btPdmd7bxsagrDKRo269Tnpk7GuPMm /dsDRdN6+g8a48bNy+xpkycuihE2pzx86/oO6naWx5G9oMrK1aKze4+SaJVW8tUthL3LTQyl p6l4rwm2ZRpxe1kZusr6mtsnNS3oZ6PrqIM6147Gbs6uZg2vbj0E8KvWXuaQsVHb3d9jprhs 9Ec9s/BpVWxvyslO3XQl1SsseKkR7+pnFbKXoD1lszacGcVVko9C62XLTqjN1nQdcc5OWyg1 Eb0qqKOoXgnH6snJbqjN7hP3ODn8j5H7Y22g7cVl13E7pssuGa89WskqvQ1rVRDerOi+F2Wi OGLVbTRrv1ZW8Wyk1xJLW7+kHN8j2Z0KumuqFGlaVhN2c+gTSrisnPNpSWiOlqtNZ1IHis0u ZyZMjb+peW/u9mqJpZWcxr0LJnUVXFNXPQit+LaXUtp6vlDMqTVTElDrTh7pL+VbEK6VY6sb pCV7AW1ZOXsaZapuV2OfJlbTg6uS4KzXQKzw5HVz0OnLVKvKTnV60fLob2yfI9DN7qww50pn dltp+rJtVV92nqSrTaV1GIqlEr2ltKDoxpJcn0Oe9YbszSqjWzJyHm/kae/5FsyfA8bLkdsm NTSn3s782FZatGXiVWOrxXmr7o3x5bPFI1vdtcabdWaUXsT6v/qctsV8Siq5V7oume3Hjxbf 0F430WOutU/ucR1OLycyu3ZNwtKyVlvay/3PbX/FPV/U83PleR8KIvGZ3G/4+lc2fndxWuv6 nuYeKTdnqzh8bBXx6cVDtu9Du+OF9sPuc+V1qJvxRw5bKq07na6qq1MViVk2OKWMc2RWidep NPIh6sp0dqwuhnTE8mrcNG+mI6E3dO1noKtOSdXqmbUxT7Z9q3LxJ4m9PoZ1XzOfE8V3R9DX xc/BxZ6HsfkPD/lVWSv3rT6ngXx2xvjZQzrvlE7PfwtXStG7j9BXpR2afb+p4tPKy468K2ar 2Fk8i+TWzMeHXua6fN8z5F8VftXU48dHksqLdsmtXZxVSz2fCw/xquzSeRr9jXaZArUeKKdK m2PKm46Ea3vr9zJvjf2pEzpg7HdXUz7SOKWxzYW0nV7GyyrG4bM5hrqVkqpMjJy0t3CuT2R0 fUatp6mZ0VzNW/Q6sb414f5E4k76QPJ7PuWiZbeuAvVrSm/cvxl7tfvmEL5Z9qFaz5q1dLIk 7dR6Xm+3GzgpR1pyq9JO3zbO+Ke6OLxprV1erLOzfJTonZQ/qFtFK3DHaW9Ne43FambrDltN /a3uY+Tata/GnMHRa6q5W5z3rXI4bh9zURx41yTTRvj8mlK8boVKWwPmtUxO1L5Fy0RtETN1 DcHpOaLeVAX8NUtONTj+5G1IquSryT0gxboxp5KyaX2RpSH7qzBg/jqp6hizWh1WqM0jsful 6EpKXLRdLVvTiq+4XFKrSWpGkqs+kA466MnnZLU0prujOYqeLjXUiFKf7mtn02HCbjcaFWsJ 9ZMratWRtjUWhnPkl7ODfHrAWprK6muOZiDns42exeKzTlMUVkyPlD0aZosqtCtsjN3+WZ1s ieHJprZms2I6crWOyrXbczbrEsw8nJZZUnpGhry5L1M8opw5lbGq0bT1kyTCySfJmYquMvsJ P2mbu5HSztojU6I0y+6qb3RCbpeG5nr2KWRKvG25DaS5AbJ819CcltEjKmR6qqk6MetX3KMa /dK0gjHkvWWtR1XJaktcfYtyo08r3YqyoaOStU12+h1+XljHRPeDgSisp7mvRF0mrs1qoIx1 eivB0Yqe207tGKqq1XVoqNLUq6zPuk5bNWeu5rks5MmnMSSIwtRJudzKI17HZmxy0099zmvj acGpQq5uhotU46GPx9zVTVqtSoznRp9TXxMPyPW3FFVxWspgydOD0YXHp3bvSuNatGavwbVt znxeRbD9u5qs97e5w53IurWVrR6p7HWmuMJwji9t9e3Y1rjeTH7e5iwO2NV1rDf1H8/xpuqU Pcyryh0gXjYos1ZaExlz5Mru9NDe1stqrX9jHJi4/WTp8W3w0dr6o16DOMj/ANqz9U+zCjth beVzbo2RnyfJ70tTD/19clnIwU3XXkpt3kF5bT0jbsVXx6LG3e8W6IwrjrOswaG1MHy2Tton 1NfJ8bx8WGa2fOftY8Xk8fYlp0MXStrN5NZJ10T43lVxJ1tXfr2HzlTOxm6Vb4vbuZfFbWNk XNRu68Vzb3CuaXFVCMvku6cHrGxeLDa7XRDPcd6V5SetTK+HnKW6Om2FqiVXr3CteH6HPsrl eDJgajRvUrlft6/qa53bIk30I+Sw69wr3a0WyLpaysmtia351U7s0SarxjTuWxsKzab2G6V4 tXczsSnRNIMqVVFdTOarC6rjpv7mYrPemqcIi0yaLE79JbN/qyePM7TL0Nb5bX06CpWtfbfY zvasvjsTOoj429RvDWN9X0I+Rp90bV4PVb9ijSipjcIVsaa02Ma3TtqaN9WOw00USafLy0SM qrlrJfPsRppROJPTx4U8Ss1qefidnp0PSx5IrxZJ3WudbtJQwdq1+5Qbq0X5Royc+P5H0UGr 3ZrkyZ67JfqYRyfZFNJPXU2wYlk30RikZbbuTPk24DPXhbj0M6qXpuWzDWyr30Iy5XERoaRb ZsarX9REXjvNE7oK2V6t7RsRkdUlVaybY6cKyxBhgVr2KvVawVb7proiE5nsW9xKo17o0M7X iUjpXkVdeLWhOetGkqKCS9cquVUn7iseb426LZk5F0Zp4fjfPeKnS/kK15arOnU0q67LUzeG 1MjrEwa1rC0Jz42EreVZajq616mONq/6GmW1EvU54lrS9lSqbcoxvejcqdjCnvvqnCNMuSkq NINMqplUuZ5RoCs8nXY5L2tZynp6FeO9XXZjsrdVYsj6t6ozVLUfueg8mJrVdTNnVqB2eSsi WNt9kZKsOX+xpW8LUfoOzx8VLJu706MwzKq0WolkhQtjDJkaehqDXFk9yrEtl5MHKY6HNS8R 0Z2tudNmN6no41VqKkeRKcWPVxVSur2QeThpneugl6pXiKyrqjSmZrV6nRk8KlXp0FbG8mqS qkaxE0u76svlxRFaOrdVubLG2osYrRO9Y0WpzN2szfKlxbMcLW7NTsNMWK9noti3iVtum46N L7bOqe5jZ66bFRVbzaOh6VL1dGkoUHnWXGOx3UhL26ruYtajN1+Sq7IjFo46GjhW4oTxPlr1 FoTq8utehzRDdTpsuOuxk2luIiK3eyL58dWZJ8XI7LlqzWDow3V7cmtEWna6b2SMMeSqmvc0 ph4U5N7slVjlSb1OvJTRE8U4Ly7yybojVtFZHKMHZ7rYrWCKt6Qy1aj+56+hh9z1RrX/AHLK FDRBV6VqpRjx0hjyTZbmVeUy9EaxDx1u0106GbtdWg2V2tK7FQq6vWRRNs2R7W07FYsidtpc Qc/NS0TVulpIjZ+Inaf3R1Vrjq9tCa1052eofJx3Whi2tSC3x9EtNxccdtVojnzY29a6JmVM br3nubk6MNcmBPWuhz0v8c6G9rOqhOfQyyVaUuNTc69xeLjeza69xXbqonTsLH8dPe3N+xOa 1tmhBlZO+xusbtRVfQyx3hM6MORurS3FWOZ1dXHQ68FeVIYfdq1sb4rUtSyT1QtIi/jK7iuy LriWOkzrIK8GeTIphmOtUsj5KFALGonaCWuOqRKyLZmhWdTEvc2rjVVoT8XJqduhrd8VBjnf RGN8vEzyOueE9H3Fk0Xoc6q3dQST1RpembFpX3L0MLeTn24s9L4rJdisatXWTfnZGnjXw+Rl XKyda+p6nieJhxUmmt3vZ/8AQuv+5KY71S0W6JbaNKU4ubKUX8qtOkvoc98nBKy3NMNqtTMs Z0BZTbVwF6vDXeUyuPyOQondw9i9lY0uktFowadrTA2lZtJxDFfjjtW3J7lRpjq05n9CtXb3 bBKnTd9S71V6xuzGKcRVpGfkeHiz/wDq79+oePbi47rUdbq2TRzVdxtkSvGy/ioXKltJ/uLp +HSXLJkUf9qO+zfNqvQrLyVFfTTdGpytQvGxY/HxWWOqjrZ/cc1uTsqpRPU0rduno+htjdaV j+rHZru5/g4623RrHBcbNLTQ0lOGvtWpy+RatrauFA3UY1lNlutbJN79SvHqmlye25rXx3a3 ZFtZxMWqkt1ub6Ksom6m2ttUc6yS46GZ1ab47xXl1NrXd8fBrVGcOqiOo/Id7VXRyXpol4nZ 8u3Y0zfdV7ypK8fKqpq25MqLa67EHpZ//RX0PPq+V26bQehltPj1foeVgmWqidm76Op8eMrd 7nHkyOIT9qNuUVjr1JfiO9ObcITv1Yc8w5e0aGKvxTrM23Om/jLJXlJhXE8VpSN9ERR2sos9 FrqRgqrZm7Q0dHJUq+S07nLS1bZEl9pfSpXt4vY/jWkbSXloljdkoszDH4+WrVb2Tx9+p3X4 Xq6Vex5rcq948emL53C39RVeStuKNMnCl5qtEQrcnOsnSXUdlE6q3KJ6dwTbhLcwd1styqS/ /EljTaydtK/ciq2tbdKeqQ8eX403EsyVJ9zWpMFtu3t6BWtqOE4+oWWmhNtlO4xS+SLd5YfH zs1XoJ1UwDXHVM3IjG2JzqbZG0p7FRyXJP6kw3aHoiWXeonEq5Ju9+iNaU5Ncd1/UqtK1XI0 x2SafQsGGTF8rtfrV7EV9+nU6KuvJ2rqnuKuP4/cuo5KxdLU0HxlJlv376QJcqppfoZnUQuM S/uKpVLbdk1q3ujox0WOPU1lHJaPte6ON5XPF6tHoeS1WzhHMsdpV+v9TeMowXtSV3R2+Pkn 20WpGPBZ68WaY8dqX0Tq/UWLrHm5dWtg4z7l9xrfx8jvs/2KXj3/AMX+xPE1yWdr1VGtiMeK U0lsdNvBy2tPFm1vDzKirWv1Z0xnXKm37OwrY3Revc6aeFlr7r107m1PBy7vb1ZmweLZWs9y lXi9Weu/Dxb86z9TG34xNyslH+pcR5N/fbRmqwtw5/U7V4fj43GTNVOf7dS1i8bb5f8A/EYO C2KuRTsxYMSry+RTpoz0vg8ZqPkj9CVj8ejU5JT7VIOOkQkYeRji/GrmD1aY/HqnkrazS7VM Y8Rr3u+vXjuakkHl2hbbmmOFZOJO278WkcVdhTJ4nKON5L0QqfHesRD6mlcrrWcZ0Vv41VpW 0vpIsefBELG1+pzsnuOdZbUas1P6E/JLdktWdF/Ix1f/AKcv6k/zse/xVUDIMuKv0lnNkwNP Y76/kuO1KpehVvMyLVw/0L0iuJN4cbtDbei0MaUdn7kz1M3mZKqnGNVroct/ymZOIUL0NdE6 uG+Gztxho2pjvjhRK+g8n5XyU9Gv2Mq/kPLvosjL0G2fxc2e3LHjaX0Jf43yLV1qyF53l8nW 2S2h038zyeOlnI6QyuVfjPIT+3Y634uXKlThE79DnplztfJa9h+RlvmSm7TQtiY1p+GyWcOE dXj/AIu2OU2v3PJXk5Krg257tnR4E/KnvO43THp38W1tmkvqcr8C1XyeSqRh8kXc6qWZZcuv u1Rjequ9YK1SnIivjwf5VPKy2T+3Qy0LoqidXyXU7cVm6wcsuQx3smqmc1uOjIljtzYua4Pu ZrO7PjdayVwq3ECzp1VjfHVR3Y23ityxuWbYlWtmkv1G0qarWe43eg5K2b0e7C+F1OlWrROV qc7vOj3HqyyqtXJCcsdlDmxCr1WxrEU7cXoDyMtVTUs0eG1qpwTouM6Z+O5vSytqkclsbmDu wJU0Ys9iV3YYiWb48b48+hzJ9eg/ncwtEZkW3XRSy5QmXn+1s4cSbtyT6nT5GThuX1RxVyfH ebKTrtkmvtXGUYUx2s+bUIrLm4qDN79Bjl2U7mNK8LJ32NFkT32CK30WiJvuNbpW1psyaRPF 9SKNqatltKSaNbVX6GtFyT5bENVVZT/Q18HyVXlW0Q11E9xzW00ReN47qLPijG7i8LWTPOq9 jfKdcR1Px196ftQ/5HPS2kHNgyLGt/0JyNv6Ez3aaZLSmj1//wBawTXLdP0PBXKtWe9+Fz1w +LebJPsavWZ+Rw5cbrleu7OPyMdsTmtmjtvk5uUY2dW/9zU78ucvKsTsnxKtVl6yb3xJuf6E Uyqu2iD5r3cLc4W9VR9s9EjjvlTeux25E6/epTOS+NTy3JBK9q5L7QxWhw1uZcbqyVtjfXfq VVX9y0FW9klLM1MasddPVmaOhWTWqJbq0SrNbl19xlUVvyfFBfHW0tuINPjWNSt+o64q5bPk 4NyjJOlWlbY7nataqN2cz8eKx/U2quNIt0M1FJw9WGXIrOG4Od2o2ZOG9dRiOvlVVanXuct8 j+1F48d7tt6JF8IcwXcVnRKZNW4Mb192hviUVbtuStOXJl3q0Lx8TyTOle5tbDWybOezaft2 NTrOiNljUw9jTGlMNTBzLyNYZfOz1S2FHZmStCcR2CsJKHoc9b1tR/5Dx1bUsnoroSqpbIvk j9BJz7WZWs6zIz1G7rKU7M5sm8IdZa0eyMK5NfUsiVbvCfJakXs4Ru6/Jrbc5+FnbijWopaU 21N6K9qQ2ZcXyVS+TpbgtpJeytMbsrJGvk2m3FBTM6WlQ+5Ga6f1Mzu16M7NwaVyJaPUi6q0 uJXBLUZ0RdXEplcqUa4OW9zDj1ZWKq5KCYKum7BbErxr+hpmTts4OfFZzrua9Og1pStWybJ7 ySrpast35fQxdVhdxZCVbPRbmlqqS6Xr/wD1dC7iYmuK7XK+/QtO19In1Ks5it3ouiC9+C9m nYzVC9v3y4Msk3+0Hmce9y5L8bIph7M126suPKrNqFqDVpXLdnflxVbUbmeSiTUGpUYUxqlv epLzWrl0SiDa1FZzoqroZXdOXJrigMK4pKxJ0vDOrDZVURMnPelq5J3JLuyq0z3dF9TTx6UX ut2LpheZS9EgVlVyTfRUte12T0RksfOqZvZJ11M6PRcXCGiq4WtTFUfKeh01vylMy4uj5SZ4 2qSyKtlV7F2epF6w1kUahdpF5RmovXloLHj4akPLx+hX8iVtoTKjZN7s0pav0FV+0y56lzVd HyUdnXE2n3JvZ113ZFaOvu7l58dqJNxqXOqprF6pZNFO4Y3xbrj2YqW9vF9C8bX2/wBSiq2a 0gpWSlpRJPK2O3vUoqqV9FshnqOKr9zb7l3hr1C1E7OPqQqP7uhuoFmlpNHTS39qOXDTnMHV hwRV3s+pM1ZWiyNtQtOphnx3VnGhaUWg6Mq1n0M4PJxZHS02e51q6cSpW5zZvHbfLsdOOs6N bo1YkqrUrb3L9jJNN8Y33NquFHUtaP2qe5MVjpVxXsTLiLJNtmrq3bUXx8vtkSYM3hqlpuwT /wArQdePxnPuWm7M8vjXyX5cWkti5s6prJVreWmGLjVtusr1N8PhZk37XBsvDyclNX+pPGmu arc+g7uzh6RManRbws8vSF6sb8O+lNNOraHia5MeHg2m9OgrVi0P6HoV8ZR7r1UepD8St27L LRteonGmrdeXjKP7TzsVFZ6HoquGtFV5O+yMsdPHrV3rZwi8eLVrkukrNWehnW9l7Z9p25F4 2TV2b/QeOvicZlv1g14xjXI6XShdSl49m9dWdNF495adm100RSvip91bf+YmYrgz+O7NU/tJ wYcONvpb9zufleLW88bW9DK3m4m2liUPuLx2ZqN8C5OKWldZNvi92tdY1aM6Z8ePWtat+g8H 5C+azrZVrB5rJ3l6OiPIpFISWjkxtatdqxpqda8zJPGrWr1cCzeRd2aq9jrwvHx7scpdcbxc krVTmex04sWSqnjuRbzMvGORj8uW7l2f7l2VOrf48tJ9r16QXTDm04rQ5fkttL/cuuS/GOT/ AHHRXVTx8lnLjTpKC3i26Na+py0hTJNI1TY3ivV05PEaTbsp+oseKlUle9Z/U5ml0Js5NbEd 1sGNKLXiOwlkxyuN/T7P/uZ3tVtctHCgwru1/UnK9exI6XXBMt207I1rbx69zh56BjmHIlXH VXNgr0tBTy4LV0rbfY41K2BXt0HlTHR/IxLbG/1ZS8yn9mNT6uTlabXIG0lHUz5Ux1LzbTLp SfoVn83JjvFVWP8A8Tz+cuDo8vJWlt+iOm3E6NM3m3041rD/AO0yfm5bqFCa20M75P8AbSRz u8R36k2rjtt5uaFFmH8vJfezTOHInyhNwy6fdqTqO23l5a29lnr3MP5WXI/ddseVcmn3Rg8b x2hrUstHUvJtZqLNQZeXlbyWVm2uiNfFwrexfl1xWu1/cupr0Z9XDW+ja6GuNtr3tw/Uy4Kk p9RO8tIyLs4mVKOf429epvK6DbX6k3FUvFqqe7QMuOmNrjr6mryaLVfQyyOuN+3Wehz61GNl MoKrp26F1jlOzMp425WUmojrwVfxZI7HPlqrUTb/AENvDdvjvpujizPipqbvoKr5VqLg1PqX TNXqtzlWVvQuvu6FwdtMlUpZjly6TXSWVjpK4pEfDrFtTEgFjdfdMyHx6tNSma0pVaaotYMn R8l3Loyw0VNGjezkypWyfcWqlsze6x0ZlwrR12g8+63c7s6/Ks1SnHszkqnVo36jBY2beNie 7UNHUsa6l46paE8yQmuL5IhNWe5V1aYFTHw0JquVu1NmoMrNvdm18Fm2uhnfxrvWDexnGyx1 dYyLU18GtVkiu3qTjx24xbUfjeNauSZ0ZJeows7Y72a7k2961Om2K2sGTwZJmNBpjHG+Gr6E /Iuy3k6LYHEMX8MbFxNXD2lDdfj90amtFx0Qs9k1xenqZndpGN68mW8mvQnFj4Ju0MyunPJb G0dFXDhL6hk9zhOEjCt5a5HTwo/Rmb0XuxVH01nqTlwtQdFbfERlsr2SfUSo47YrO3cXGN9j tuljRLXyqf6GtTGeH2vaUK1+T+hS9qaqiFZREakUUyaxBo0n0JpVTPU6calSzUYp466alcHZ xsgu0oIV1+4qyNqRhc7wdV61zw2c9UibWaMW+yrzX46PY4czk0ved9jlyX6E0TyaNFkjdGFX rqaVSab6jFa4m7WNrPi5ZyK7pEG+TLyhomdR0LKrKTC9tfaCyuyhKBrG1qx0hh1ryXucG3ke PjrROtpMlTk9di3XGv06EnLKY5eLa2NMWNpw2a0fLSoZ4SiTe6YWWOmo8TjfYw5LodGNr+4X si7ZlVQkcmTLa2pWa/RLQ5bS9EiRG9bu8VOhVsktGm+pPi41V8m9TqefivoTvRk3atUtWzOz b0RpbO76yZWtJViMjddtzFu/U6VZpQyb1SRdHHks0xUu5k6njTTnfoYVxuNNy7KB3dtjdxjj i5M8b47nRS3Nx0Rmh1TupkqmFL7nLIvTj9q0FZwtArRTWW5fZGrbdYMKX5V01N0mlsZo5bTX YiqsnL6nelVrTRmCrLlmt6B0slqmTfNOz3LyNRCOO9bJwOMHRWk2ncVr/pAle1VKFfFe+23U Zout95Zz5bp6I3xYobTRz2pq1BZDWdF1g7KJ2x6LWTLx6tWhqUepxar7UhetR56pK4ybY21X iUoe5MS5WhK0VklqQ0Vx4z6l1po2aRinCgz+F2em50cE92V8banoBlLW/wBBfIo6SjX40tv1 M/jrWz03LgypebKNXOp0XVeT9QePhEb9R3rytproMGUuvWZKvRszvq9tjolWS0GYa51uqopT EHb47wUltTdh5GKz2UGd24ORtaRrA8c8pGq8Hsa46vnXsXDUZHE6wZNNfabfHbJZvrJeRNQk tty4WuVpvR6G6SqktxLHe70qzdYcn9qbM3jprkzNN6aCouNU2dT8PNbdMF41q1hVclnE1yJt ZFZ7GtvcjdeHl34s3r4OaJaSJYa8+2P2w9yMdbNpUWp6P/HZcjltfSTfB+PeLXkpNSJry3fJ SZhtEXm1eXU9S/45NS7pMzr4VIatdF8YmvPpboi6Y3kfc6V4OGYV3P0NceDHTa+q9CWT0NR/ F+Kyc/oa4a45s7wdC+Ffc3Zkp+MlpV7nLx3vWtc1rfIuNVCOa69rR6lM2GjnjaDPJkwXlqjL JJe5rixJWSHair9q9qZ2YsuBSljtoP5cf9uOF6s3nGeqa4Jaew2lE26ndbNT/wCNCt5GN7Yv 6kk4+664bLnFa9BRChLc6l5UP24qlrPZqOKNW8Ucd/E5JepnXxnX1R6GTys6jhWsfQleRm3d UZ2e6MeFlXZwKviXyRpo/Q6f5fkxpH7FUz57NcrOF2EvH3NZ28LIk60W3chfjsresQO/yX3b j6hZX2TcFvKDL/jsrs9UvqzXD4eZ29qTXeTL+NOrUk18e66uOw84uuvN4blcmv3FXxIU86ow tgtdQyreMv7UTzg2xYPHcUV07dSn43jVcPIo+hyY/Fsr/JOpu8TlyLzipqvETj5Hv/idOVYE 1jbtop0OO3iaybZau0Jdi+cT/kP4OX90/oVf4rtTLMvhcpmyVk+S3gz5r0YX8jx8cr427Luy KedjjlTGv1KyePbJbkzGvhRMbM15xOh087Vxjok/1NF+QdXpSifojNeG6mv8XqtyXmdGlfPy 190Vb+hl/wApk1brWe8FXwWaJp4sLUef5Ojb+dkeG1pXKV0ORZ813NrvU6lhjG6aatMVfH4i 8+h0Qr5XXlyf7nNa2W+trP6yd+PE6uW9F0HbDVp1XUzOXuux5603bbfqN79zqXi6Jdiv46jT Ql5GxwpQxxLbO2vi1roTbxew02JratcTlS5/Yxn/APt3HS2p0PA+PFMdcHHG8fdya48pFtlj lvKSstEyXbRRsdiwSuL2RL8NbjzjOxypS5fU31S1co6PgqhPCtjPkvlHDk0mDFwlL3Z6b8ej iR28WllGw84mx52Bw4T1Cjtju41Z6FfFpG2posVa7GbV1lgtRtW2a3DPZPI2WsKcwN4k3yM8 eks9y8pXLkzLjEGSbslZaLsehbDWNOpP8eiRqWQ8nA+TsdCcdDd4a6F/DXdi3U8nG2xVR1/C nsV8NYGxfJw3lOI0FbHyR2vDV7h8Val8oeUY+VWeFl2gwTfQ77UT3JWKpeXKVJXEqamjVqqU js+KrUDdJhdhOUXXn45epXuZ2OqkOKJ5Hk4qqzTTJtyejO1UTfoWsa7E8jyeb8VrdINfJxu2 TilOiO9QLqa+zomuG2N8Eo1TMvitvB6caEtTsZ818nBTHbW0e4p+O7e6dTvSQo1HmbHPejfG d0oMngdvuZ2uGLhy1HmbHHhxOll2NMuKbtvU6IWwKupfsqOO3jO2vQheLGiPSWxPBQTzprg/ i66FPxp0Z28UkKEyeS64v41VrYS8WLcqvXud/FBxQ8k1xPxXZ8m9RrxoXHudjWgcR5GsMWFU ratu0I5n4SaiTvgcJl86muHH4GOq13Lr4da61OrZDHnTXN/HU6j/AI9VqjpcCcdCeRrmWNdU XjrGxs4WoKETV1k8dZlbieKreqNdOpUqNBqazvVXSTW2xn8K7G0jmS+VptQ6IXBNbFsHqTTa zWNA8SkuULbUabU8OxNMUbmttpRPP0GmkqQS6OdDWtkKZGmpVFAuCKbHI1NZussrgOU36j5j V14vKqWu5z2s7ODW2Gy0rsXTE3MnfpGtYq8pU6nRwaXuCmKyWyT7lYq25TdyNVh8fG6T6m3F xL1gWXG7WmqgvHW9dJ0YvumuW6td+hvVJaRqze+Jw4EvHSS6szyuwc7XGbX1RVeORTTSTbJh 5Liv1Kx04JJDeia48NnLpuY5LQ4jU7K4GsnId/Fly2a2Jrlwep0VSXXRlrx40Rq8C3Wg8hNc VEm5WpiqKtt5Nl43UdfGW5jV2Dkk9Nib37GyxqrB4atk6GvPyy2HBJep6Tw1bnsS8CGmvMti T23JtSND1a4a1Iv4/wAjNyxNeektmVirq52Ox+Ip1L+BQkibF1w8k7bG6behsvFqnLZfwrZE tlPJz2yKutNTOLX1g6141VsaVSroS4eTgq7JzVaia56Rqd1cdavQXwqZRryia5vidkoUGdqO m8wegqIV8auotqPKJrz3a9lsPBheO3N7nf8AFSqDjXYnlF1yXm1uS3ZF1aD0FWrUQLhV9B5Q 1wY8Ua2Oj401obvHQuqqlBPI8nEqdxrBC5Wf0R1KH0K0ZfJNcSrw6TJN6p/bp6noQhRXqibO 668ys2eqn1Nq4tNEd3GkArLoLyTycyo0tTCuPJrxW/c9FtMEWcjXDiwWrujqVGlBryQuRPLT WDx66E2xPob7FK0al8jXH8LtojO3jWf6He79huw8zXKsLa1Wpda5Njd3Dk1sPM1g/He8mX8S +8HXyYvkaE501jj8O8p20Oi2F7ToS8j7lci+aan+Iv8AIF4kdRqzG3BPNdqa+HWZkuvjUXUa s0gbfQedNqf4mPqxLxqzpZwUrdxSPOmm8GOqiWxrDimdQqxtpDzqaPjxzqmy0sVVPEynqC13 J502mseLfjP6lNY+lUTHQloedNrSa9kW8r2UGDWg02TyprSeT1j9i1ZLopMasrceXIa1yR2J bnsZOQ5MeXL3VvW76OA5WaiWZ+ouRPK+4uqa6spXa2epkryLkNvuNbWb1bIb6sSuDumNqDdD URBPIFZdSbRShqB6dArFthOsAU9iUuomvUS0AtuHIpIcsfJrcge5SaREMhKzKNtxpmdauNRh VaTqN8RPXcOKIYrR9B6ER2DVAw2LVkqSkmUwQ2CbTJs9NCeWpBq3I4Rk7whK+oGzUkpwLnJL vARqJuGY/JD1GsnUo2aUEKvqQ8mgllncYN4cQPj1MVlK5ToF6LSKlEyiLNLbYi4ewT0RWhm1 ATFRImx1iCbFMNvuLkU0hpLcGDRg9wgapJDBZRsKdA4yEFMDfUTlDhd9QjTci4mWwdmUuw2D ERKBepbstiU41CYmGn6FD5S4CYBgb6ADsuo2+oXEWt2BByTK5IIjUJaKdpE2Apka1egNwFGk DDkaEKZYFeoNzuHJbA4YUk0lHUUtlcUTtrIQ9SW5KlhACbQblcVIKAECbHomToFOQ22FHqNQ A+QctQ0E9gG2RzK4yp6gqJhBV9UxNlv0HC6hcS31BW6BxTQabANVe8iXoV9CVWEAkoZTXqJV jUbqBKZe6IdQaAaUCeuwNdg4uJQDWwk41HGgmgHuhr6iiAtHQB6LcnQOJXGrAEkGjJVew61A rih8EQ3Gg0wquKDikS3qQ23sDo14pi0RG+gaIHRU1D2yQqqJQgjXmmoIlEJQDKLrZdQsl0JS GmiC0h8SB9AvQ0kKE2S2pCZB0PiPjIpgOYOhOsChFcp0DQHRwvsTGpPKS0zTAabJdWmU7CbK FDZVY2YlqiVaGQatzoIluBS4gC2wRH0BONwNVWRWgnn2Fy7AXWAlkSpHKQFyw1J0GnoEDYk2 Q9S1ooRVaJwTzgmrfUqEyBc2JWK5JicbgORO0Eq0ja0ArkOZZCBBFtzsJaOSUVMsByPl2RKR WsBRyHuTC6jTIDiEQW7ErXcBQkNbhohSUNxIoQQ2VEATspHEhKE9iAeg2/3Hx0EkDEy51G11 HZEqQgQ+QKX0El6FU51E9S5Q4QRlqUpiSp1gG+wUlqN+gLQfJARM6A20Uktx8ZAjnIROgcS9 giVVdRyhujYOoUPQX3D2GmQNKAejFLmB76gEvsS1JUpIJAK6A1oN7aC5tgLiCmo04KV53Cob bCeg7dyI6hFtzsGqM1LHqgL9w9UTP7hygBy0Vxe5K9Q5NqAppieg/wBRJANNRIpkfFwSpCNJ gmdQtIuIVTliY50FxSAOUBy7i4IbrABuOkaicA/QAiNQHpAnYCiZcg3JSYC5Nsasp1HEomOo UK7kfNsW2oStwap3aHKaImRLVwQ1fONtw5QTxUhZIGmmh6EKpfoE0m0EoTU7hxkpqpSBw9SV VyD0Iap8WS4WwJahowH7W4FxTE69RfTcqLUQCaJhhWrepFXoOEyOPRDafQGmwdlsAcYAJSGh OugcZQNJoOSWjBKECr3CDloUmTBUIGly1gG9Rus6oS106g0TqNt1cMfFMbxxqwM+SGtepXFE xroARInqWtdSrUTrKexRklAPeAnQTTggbrA1rqKe4m4AfEmGtBq3JfQOUbgWlCDpoDegpjUB ROgkhu2gN9gCdBbjdkgVm9wI1mIKgG4YnbsyhtQHFrUXKQ5PYCgSkSeg1qgEk5G06j6aC3IF xG0PiVCQEpQNQDglPQCxMScoAaNwShj3Wgo01AG+qDnIJCrjBp9YCAa1Db6FD2BpvVAvcoJs 2gE2ym20hRI3ooApTuTI2tJWxK9wA2NXITez3K2AJZVnoQmnoNuNCBpAtdBJCUoC5glMGiU5 tBRachIcYFx0kge40zJvUb0KLaT0JS46Ez1K5RuAciuhMpolvXfQguew5I26lViNQE9whhuJ PXcC+gtgcbEtgOR8pM2o1RXSShyJWghhpuiCuchyIUJg2UWnOxUPuYrTUrkBy8UkNQZqWNyi i4XUITFVinUo0SSIe4OxLkDRwhNAqtoHWCAbQpTQNvsCT7FBpsNUBVbDWrCnwgE+hSkmEA9h TroOGJ6kBIlIcGyknIMHFsXGC54rUnmDE8XMF8ZHIAxEajaQNy4KiAYSSHWo1ZC5qdQBjSgU yCYBApkqeWhLUBFKGCSM57FICloTLkrQI0kKIbGlqTzhwyldvUiG32Bt7Etvct2b1An6jUCe qCrhAOWmEQPkyW3JQ5HoTDEmyCuUuBrVepMMqXsAuQTOw1UJhgORKNgali49wHUriCTBpoKI HMEddy4QEciuSYoSGmgiuSBwxaMNtQpwkJKGEoJU6AKz1A0VVOonCYEv0EpHPYKy0AnLJa6G iTErSDE67DSZWxVYYGbXQOJrBLQMZx2KUvQtOEPfUGJ4oSUlppC+gEvsCqN7jkBKssUOe8FO zQS0AtWwdRyHLr1CptUaUjbRKT6BFOqYRA7KNhOQoHaBW1Cq6sIKpbsekg9/QmAKS3YvUNtG R6lVaSe5UIhOUHF7kFByQKsj4AxLabgQNBwAagSXcvg0hceskTCCGvoXxYrVcx0BgS0E20N0 caA6ywJspGk2VCjUnktkA76Ercp1Jh77FD0FAuSTHsA5ElJHU1pCIYIhAnGjFKb9StNZBiVo OY1G2tJJtC1KYFbqTa0BWLbbFNJPUGJV9BPI0i5SIs6tgwLI2tBt9SeWu2hrRcu2moMJORJy XnxOteSfSdDLHPUti43q6w+pD9rIlxOyErw9SGHzaHW0boVfd6QU+4MN20ClkpdtxKrfXRFx K0QwxXFOnKdexCmI6C5PZktuQmHxqol6tjdWtehDifUVnZhcOuoP7vQb+2SnZW0WgMS5UvoD rOo7vjElWaS02BiLaMl6uColSgVJmz2GGJWhUJaoXFT2RdU0mDE7kOE46GqhCdVZ6Axm9QWO VvqaOvFahXjEoGJVY0Czq9C7bwTVc7cWDC4obSRraqro3KRjKbC5CVktHuNaajvsiFVvdhMa 1YWs19BMeTVS9gYPa9P3C2SreihEVcoSskgYfLsW3oYbmiaBiqtlt6GbUajb2IYlaF1ZDTT0 KsAT3H7f0JnQcKIKJ5QxyiXpo9xQBbtIuXQUNwTxnRgayEkpcWUrdAKVdZJtqx6xoKrc6aML 0TCUtEtt6oq9unVkLfQHRpS2pVqpEVekMfONyJkS23ow4rd7jTTG1Ckp0Kr7ibbTB6agptqg vRNVOhPFyapT6CWrgJ0Sq6jdVrIKsPcpaoHRFapoFVFVSQPGnqiA0jUSSexewQm5BhJIXBNy O1eqE3O4Cde7E9NHqDYRJQfUKt7BWvccw/QBWarqLR6lWXInoAtE9Rwm9CdG9dy1XWUA1RPU OIJWKhk0eY7xuXW0jdUxqsGzCs2+g1qgbcyLlIVTSF1JnVIbBhu0OCpM7Mas3oBfJMqdDLVa IaTegFK4neUCqS69wYayPuC1BJdEDcbAwNx1DkwSlDSBhc7Iqt2NNB9AE7NoTcMcdgS3kB1v 0Fe2soqq/YmyEEVXJ9ikmlMjqpY4jToAq1bUkwaKr3qtBQ1qERDK4tjVW9TTikQwqqES0+42 ugXroBMMvoL7VApgCuPVjdW9iWUpiAD46vdFKiSkVXrC6FOJKM3WQVXA7V6oKvSCImC1tPQN weigKVbJhZ6iqymAlZjHx6haZAXJjq3VyKGJqGBpPVsnRkpJocNAVtuTLsVrbRiiN9iBqSZb ZU1jsSoAt1kIFXsxgIcLoD1QtiiqsTlv0HVA7kC4ajagTs2DclClvUauo1FyTe2gkly9ANFY HZEqvLREukAXMrcVVLlExoVUguQqS9CVYDXQG4MV3KtZhWmtip0gzraNxu6TIKbnQlphzQO0 sqBTPoHUm1tQmNAL3Gl0M+T2QlZvQDSVsOqTM9SbMg0idwT4vUyrL1Gyi3bWVsN3hmddUWqy DWnypLQl2SZkqyJri9SGtbWlBzkzdkDUqCrrV6g2YKzHyn6hG3KKwJX7mSt3K06A1tzRVn7Z 7nMgT5aENaJjnQmeiFw9SipDmF+O1dSeLJhqq3ZSvJnasbMT1GJrW2RxBHLQnpIk000imrdn sQ05lCbbHzjUGr+SVCJd3sCr3E6vcKTt1KdocC4wN0XQCoXQcypQ5dVx7iUPQCEm9gVjTTci 6QCo+ftB2a32IVUtWWlyUPZA06v2hylDiqE3roDTTlNzBCl6sHYhZOL12ZV1qrapDSs5gh3U JjVtZXUJqndtR0GogluHIJKJQXVrWooS+pNbzr/QTvDiALShFJNuTCtnLRpz6diDSzWkdSHd rYlWbe4KyTnuUVDieoq2Vfa/3KTWuuoNazBlChLcm1l0BPXUGpZQm21oLnOnVBay4uCMUP6g 1t83VqbMLPoJV1kasnKjUKlVs9EO1XCn9hq8DWu+oTSd0lruVks25q506EOqGvauKC6Uv9S/ lS6CrFVLHyrA1NVe7yLi2voRjS6hCTkdbDV0OvVE8ilqTK2ZNS03aE9ZIUNIaoug1VoGpSb3 LSU67BynQfoDSr7thtW2DkojqTqtwalVa3LrTqwsw56BBxSE8aWqDlpJDc/Qpq7TsFrO0Kdi Js1A1aCGrbcyS3OqFXJL4luVqkDSraSn7WYcHOg9ga2b5P3E6Imz/VCpD3Bq6t9NionVk1rG qG9AaVkKtoY99CXjhgVzhwJ3G6rk2RaEDQ3ygr6EwrKRtOABb6idYBXT3LtC1AzrPXZA7OfQ 0hbsl1hygiXd1GrjVZWuw1TWAqq3VkS3xY2uO5DYDjluKG+pU9hbMgEmkE2Wha2M2pYBzfUr fVkxrJSUoofXV6Eu0PuJ7QS1G4GihgkiUoWgnRvUC2xaPZi48lD3JVHUCk4EpRSQcX0CojqN Xgq1YFwbYArzoTNi+Ouo+ARx1q05C5WnQbN6usnVrYFjXc1bEoGmptjgFQ0bD2tQDWVUluaK HMDs0loRV6jTVPb6Cuk1uVEiXcmmprWSuGkBPYOTZTQqFuqMnaDRPluRNNUQ7VgnruUtAazj XQ0qLSQjUGq0F8aFy1G7g0uPF6h9w5E2DQkKCk0vqEohpRsOFsyVYUplw1pWIFBCv0Dmwa1d ZRDUahqlLFa3SAmmtQaTJ5NbgraBdWkNTsRyY02E07KNRyJ5BO6BocsTcOCm5RKo256AVPoP VhVrZsdtAqVXohttBayS0I+T9wNJbY3oRWxcyAIVkuplZ2TK5/IEUlA4bJrd7ND+VTAVf2k2 1YrX7ClNepEPj0BVkTvqi7NdCqmI3LrtLIttoyE3sRG/T0E4B2Ua7ehFrTEGlVOsDh7Ga3Lc tkQPRjr3FDenYhN13CnZhvq9A3cCnWALrK2B2EmF66Sguh15D4voJWnpqFW5GIp17mShOOht PLYz46gPpMjafQV66E0UBVpTow41e4Q50BY09WRKnRvRyHOHDQ1VLUrgv1KIbXUa112G6QpZ XGVLYGatBSYrUTHy4oItXJspM6+7VF8ddQqIacIp1/cpjZEDp8a1IrroOydgrRrVlEQ0OuOd ehd2rDpXRSFYJzZwavaBtJaF46qydm0uwVhEKSlarOhVWsMlYXrC3AxcDSbq0aKqWjWvqN2V G0hiRyq0MpNpjrTlbXYNpC92lbaai+SdEFnyiRJa6BBEvcfOAiJnclVnUIdrTojPLLWhVpex XFwA8ahJvqK1tdoXoXZcYc9DJy9EBSfYbdXoTxtOg2te7AJ1hFNNIHSdSXIFSuhNtFpuVViu uoVi81qtGtrOy9o60S9RukBEqRVTmC5SSjcGmBnlmfQilnMIta6MrgAm+gfc4B0a0IxY2m29 gG019oXi31RdlIKgGVbc9OxcJQw+HUt4+SlkE3SSnoyKaLQ3eNaLoCoumhVSo7DWR10aHxS1 fUG0RHPMWbSKVm2bOqeolRJ7ARyjUSsma2x16CWNLXqUFHVasTu2XwW/QXDUgmWgq51ew710 +pns4AvR7ErRwkWqygcfqAnfUHqtC1RNSOqSIMnXVeo1ozSql6i4pMojdgmo0KeglVWRAN8t SIhmqWgnogFWvPRviQnblHTua1UrUNtCKVK2kTmdFoW5gUvYqJrRlKeo2rCrMgQ+437ti7Ns IGjNJlJvqW4/UlatdgE95ZLrJpavWSvjUTIGSoiq1kIYLVagLVaEr1NFMAojUCYUSkDs0NLo UkAtVqJuXLRe5Lr3AlRMMIU7F17FOEUZwOJcPct66k13kim0LfcqJJ9AE9Q4pldJDlBBnEOF sN1KlMTagon41MlaPRiTncahBD0Enq52JdoZcqAoemwtGKrncdoQCaXUbSrsTZytBUtpqBWw 3D1CU0PktgHBnfHGqLZKlgPHWFx3HEbEpyUvUGp+PX0KaTUCTcwDcIASSG2kRt9BNSDWiemo nAuKHAClIfONjN7AkuoXVt9WCcsULoOqUgPkmyiOMigI4YiIHyaE6pIXx2hWWzNbEyrkmSlV rcI0lDYZRMhCexVHWu6FZRrsDD+NLVCftWgld7ItvRIauBNpSRynbYbbKrFtCbhhqOM7GXJz oXwM70ZZUsXp1Ha0bCxbxBrxSJq4yb6hMFOsGbc6F1DT1NJUmddoSHWdmQXoyLudEaaQZvTQ sBLegW9RqsAtXA0TynQ0hpA00g6EUkupK3LWw1Rbl1MLiWqpIKudRO3ImidhNNvUpNblJp7j VwkuwrS9ENqHoLm09tAYnbctpdCVDLu4Q0xHBsGtJYrWbWgVU7hDTfQvlIe2A4p+4A4yxOpb 11B24hU2caPYmPQrS2g1CCCIQk2th5cjpspJp5NXowq6w1qV8dUTPLYHP6AJtbDVKsmmqBXh gWqRsC1epKuNWkCW+L1QlvL2HeUJ2hbBDs0tilSVJim50NecVAST2KWuhKbejJ2egFWXEc6y Tx5blKJ1AbuJw/oS6xoGL27lDVYKVYL32J5Oq1JqiqnVibVfqNWkbqmpCJTb2Q7ORLSYLSTU sKSTSkniOZ2Jba3IintA1SdhVty0CdYRVNpp6CvpsJuzBV1hhE6rUdbNDac+gbAS7uexSekB ZN7icrQBsCLV1GlD3KHDWhXFpeg1I5a+hBCT3LdY1YVunqxNphTlLUl67heyiEKNYCFenKIe xpMV13FRatBxbAVdoZPFTqO2mnUaWwBPF6FrJbeSWm2Vx/YBWb+pPNN7GyrJPDj7jPlFy90p 8dSOE6mnHqxpTsalGSrqX9BcWv1J1VoKd1QJaIuq1KaWxEZTA6pscalLQDNpvQFWDTlpAbjR CXcUFdRPVgWnoS4eiBIFuBLTmOg+qQ/oLjqNGi37Ce8CnUb9yIqLKAkGnZBjxNPXUqJTk0bH 8cOQempBnDW4NxoPlOpKq+8lMDs19DRaOQSlQNVkgRGqWpcawPjIGStESaJ6CdYga1AVgSSi TXh7ZJdJQMJbwN9jNJ9yq0cSDEu3oNWVtCkhcF0GmDpJOq3KdLQXVStdxpjKYQcZNL07bhWu mo0xPFsngm56mtq9B1rKgauJSgThl8J0ElG4MHGCWiq6j0RNGaSY+I6qHKLs9BoyWhXGdhr3 bjXtUlEuag9ylL0DjrPUBXqnoJJIb9RrUgVnoSnDUl6W0E6p7AJ1YTGjG5iB6RLAzYVZTaaG 42QE8S9EjFcuWr9poqz+gA9dgVXUaSTLvoFJJQTVDbgVbJasqBaOSeSkb2klWSIK5cQTnUnc Vboppt9Sm51E7JJdxWt0QQ1LQk2VWIFPREEctYHLCddht6gDlCSbKq5mdBalCaa2Gk+pdbJI WRroFHHci+mxTtqO+uwRjVOYextKJ+gq1ckEvVlcZQKjktNTBRFavqPn0gt3gmEFTKgpJSS1 L9CoANty9BToJLqAluFmkDcpNBGoCXcTcbmlfajOyAE+SBvXUEuwIAnuKNZG7BV6AGuxPoOW 2DrroBnDTLxppepbUDVoKE4QaE31CGQc13OlTJMqZ2J1NLqnZk1s1qDTKdZ2CaTfNyxqsais oIfJ6jua0tC0QkmjHjaTetWtyCpRVYM40DoLF1qrQ5Mr3bY3bktRJcdxJEttXRtLUpNfqLlo Qn3A05JkuEoE1L0Fx6gNOHoFrSCc7CsA6tqUw07ArDCGtdJJjUcrclxuFWp2Dm2TVwywCAra H6FViNSYT2AuthaPQir47dSuUIglVaBVaUhyfQb1KHOgrPsPj3B1hATMbFVyNkx2GpbgCuMi SdXBWqRDsBaBaGSfdg02Bc6wRZ8XL1BJplPH1ZdIdbp6g/QajGvapBe59iLYVnOnQ53hbtyT OtrTUitY1GopStOommwmGUBHGNhx0Y4kaGmFoh7akpOZgIbAHZtjae7CleRTTW40RxSJ+Oz2 L1e2xbGmIqoKVYAnkArWJaaKgGnsEJblwSpqVAMNvohXtoCmBWXUihTGpTkaTgLLRdyom1o3 6h/oN0calLGwIc1Dda9Te2PuFseiaC4wqoY1ZSyq1aepSogmM0pTYofQ1rWAsuwGF24gamq7 m3x1Wr3Fp02M+Ua8ahTZGtMU1h7kKkaybVUOUa0kZ3o59vQnJTSTp4w5C9OS+ho8WFay13Ha n7FxxtIZ7ykohmL+GuMYZEo9pmkbVTa1MrWhMcZ0S90NRsaWu7RJnjsnVprU0d66QW3Ek07O E4DHNlqS7S4RpRycpXXOmLdFuTxbNN9x8eiNdfcsiK6bA09x1yKja6sdrrvqLyxnwQ+SrKM6 ZXqmb2vClmGj6HDdvVvs1tquQ6+nUxSVVCc9y2+MdmdeNpkLJoNLXXsZ2hP6mq317HXejNhW UvQUMvGpQ3C+pHKxPB9S7JbSNJNJg6QQSqQiHq4Nm0iJhyNMPjoRCmTRWn6EwpGmELlpsVZL oNKUUTX3ajfcK14hq2QSENspJrcrj1AiFQtagLk5Cm02ZNdTXlqCqnuCxnCiR0r1LjWOgJQB OiYVcDiWVWsAQtG2GqU9QgqJcEEt8kL7S+PUzh7sqNlbSGTDWiBJ2Fa2ugxdNwidQScyxT3A aThSNKNxOziRq07hBeyqgruDrKCJ/QB2tPoyZ1G9dOop1BoUu0BV6sjWdCnK17glXOhKYc9Y Fe2sASqcE9TVNcZMm5YOVogL5Qg5aepCGqwDQraluy2J32FRONdwi56itZ9DKXJok+hRS13E loNpvUJcBU6ArcQeuwrLQGnW87jlMS+2RJJ7gVaHqL6ArRo0CWsgZ2b6FUtClg0+g36kCdtN BttrVhXX9SbJu24FRy/QUzb6FpRqJuHDRQ9W4JeJP9CtXr2J5wBWJJSraiWNEO8ah8mkg6Ld U0Sq8dWOvvhLqJayiCk1AnqpQq7NFVXcCZlaijQT5Nwthz0YBZuCqvQjctJ6IIFqtDO3Qf2t hZO2oUt3LNHZaMwalmmLTR9AHW25T203Br3SiL346hDdmvqQk55DrFtTSqQMRqwacQty3FWK QqaT1G5XUlrqFbzuBrXXcPQzvZ9AUxIGlWKVsxJyibeoGi1JnoSrQKfcBonuiNAThg4AHTqg S5bCo4+gO0bFRWoqrqHOKkK+hBq07akvQFfQXNPRlVXJxJPyIptJQKAOarSG1JlyT0Ctiq0l ISfUjkmOr1Aq24KI1Ibcjb09AFXVyPUG/aJ3f6BF0emo5I3UoFbuFWkD9xKbstA4/uEUtAbE rJCbnYKp90HoRzgHfqBpSKsMlqmEtjerQxF8nOiNHroRZ/qJOHBRcLYnhCB1TL4pKSKhVG2k VuiOEKQq50hFJpb7kTA25YRWhMp6DhJTMkPuEWmU7Gc8n6FWrOzCmmrbD5cdGKtOOom09UAa PY0ULUmvoFnADtZExIkp1LewRnCLSUE2QVU6EGltNieaegm50S0JgqtFZdTSEc9ZmDVvitCK qVI9bSkZc09R2y8K+m5ZOphWfFwOGN+5Jjp3FDqoQkp2Jabe+nYvYgFaGXWLMzcjTUeoFwqy Q7PpsTfI1oTS7/QDSrGpId41HW6YWKXqZ3mttClaC+M6sImZB6hvsKZGJQ/UrjoTsn6BWze4 xcaKIDQyu+iCq6DBshtmK02HyhwyB3aKlpGVw33LiyNU56lq+iMOSqgrbTQNY3b6mfyRuEp6 BdaFYsO2REu0vQVaSpZaTl9iEibbb7hVyuK1FZ9CqpJEyKq20lVncUaCraNynq1VnIcmnqZv KnaNoMcmWdDHldxvI6p0kyVuV5esE4tVL1K4vn6GctrRUtyu12Iy1h6BV8buAbnWx2nToxZr lrKs29mdCx9F1G8bvV2QsFr303JeS5iLUdJh7FYrNQys1LRx/uYsdW6wlqiZsI6HmT2/WROz lvoS8FtHESb8KpcLMkk49G7tcmVr7kokTttaDb4VxabJWJoZMSy9ytkIdtZOy9KXqq136si2 CrSS36nOTei2XXFy5ehn5GdUejPW8fxMXFq6cnLk8HHe0uYOnC8dsS8bjk+auRKDTlC1K/hJ Vihrj8dTF9jfTDKypn4qHsFvKS/XqVkx11rRytjmx+O8jmJVSdGLHoYk+Emi79Qx4+dezKth 4JQ5kx5Hhe7G2rHEmv8AGs9WZ2q6Nob7E4X1SZ6twdKrV0nqS8UuVpoXTwqa1Y3oVZNQiuEi 9E8KzsJLQ6KYoanZk3qpcLUkur4Vn9wehbq+xKp/cyp4VMKRNQa0xc3oPJjheqGzsfXXMaVg V6OiVo3Ic9C9zxrVuR8tIIpjs1L0RfxWbSEsa8WYWbN8uFY3o5kjHiTl22GzNPBjKVdCqXhN mjxrYLUmIJqfXWTvrI92bKuKtYf3B8evKBp9dZO01hGXGbSdKwNrkTk8ay9B5Tsl4Vm9HAdR rHpykdqRXk+g1rxZ210DroauqalBjxWb4otud2PG70Qraajbn9R2xOtth5MbpZJLcz5HhUL2 pk1925tXC51K+F13HlOy/XWSSWhERudHGuRRV6md8XBe5yx5L4Vk68lPUOML3amvHhCbTnsC xq2hdZ8KzldENV0NcmLotg+KFoNLwsZPRSSm7HRXx7Zq6aNbkq1EocyjPkv11mkW6wPhOqNs uFViNUa08K5FKZpMGtPG5Lkmia4VrycPsNT66lVexm30NrV4PubNUyJRWIFqzha4log5aeh1 W8d3pNdDO3j8UknI0vx1lV9BrfU0rj4uWy7utrLp3LehODC+v1BPT1Oq+Kn9pNKx0keh9dc8 f1DbUt1baaUFUo7W4kX66xrKY1B0WpwtqpM8lqZHyxqIeqJvsv1snK1K0s9djSXeiaWxNdW6 g8CtjtXVaolKWdHN1rwWzM8ONt2l6LoJbO6345ezJpdTJV5bbHdaq/t1FWZaskhvqz9fuwpV V+pPCDotxdtiG1P1LLpfjTdaQTHFanSsXJaboztSWDwrKePQTq59Ta2P0LVZSRT63PbG6lKr alnVSqqnadexCVGvfv2M+Tf1dXK8be4Vq1sdb421WwrKtlFVDW5Wfrcdqa+papC2Nr15Jdwx u1FqOp4TWeOk6EXxaHXTi9Z1MnsU8GWLC7qEtSlhf6mtMTTTqzS9nELcz11fCY5cmN13RjWr mT0a0tf7yGlHHdeg0vxxx/HZsHih8ep21Tdl2Q8tU3PUvqfW4ljbDg5k6EtNdx1s6LRl/Q8I 591CF8b5SdFSnWWuwTw1yusbC+Nvbc7bY06yv2FhVVaWLV8OrlpitbTqTHG0WTOvIptyWhFq NLm9SRPBy8W3K2K4s68V69UFuC13ktuL9ceesbbHbE5g61TXkNJSNT63IsduwXwWUW6M7b1d n7dPQ5bdFbq9gfXE8HPcOFjprilTUfxlT668asQFraaCsvUhVVlo/wBjpjOLTlShcnOw60cm r9tdETDGcuIHyjRsdVa+yIa4uC4YObbgrfQutlGldUZTZuEMTFtwtyVaSnK3QnqMXArNMOci 6wAww6LkXwjcWNWWq3LtLckwxnsVo1oa0oqrlGr7mbhayXExGswUnLJtVxKCstQtxYuK567B Zto2TdPa6/uRZzshIYhS9FodCUowpWX9DSza9ETOphvG93ohabFKjupYqYrfoXDEqisuTM1o at8VCE7OyiBhiEaVc6E1rGjKvpoTxMS3DhbA9PoKegQ7aFwxo7ON9CK369w4qqhA6pEwxq9U Y3cbFJyK2jGLjXHZRqTdroRXVQiuPcmJhcpQa1I4R6jxuS2K05wpFzTQNLdkXsqabtiQw+SW qeo3ez03MlXXU2bXTZdy5FxUQp6k3asoBtzoty1jVt2MRLvx1YVytrQ0y40oSfIysotCQxVa wFLOYexVqOFGhFd4WpjEatNqUyH7WXWsPUFx5AZWUvUK1NXTWURDa00KhNPYFU0rXR9xVTYW NK1VkNpJfQmfboOz01LAVcNwC0qJbCS5foAXt2Mledjo+PQxpTcomrb3NIgax1c22gTnoYMK qnQnI4ZVFrqdFqUVdXqNxZGFYsibV1Nq14/bqPLV2WuiRNjXi5rUa3KtW3HbQ1WJW6vbQ1hL GlYzeWdm5x92FU7R2Nb41VQnIVtKhPQm7e1XBLdTJ2UqxuhuHoSsvP1gqmSLR3KkjBqbG1Ky jTGlWzkd8tMb0+0zeV9FnGeqLKq+3UmNNSqutodVoVb6GpbVvGMPjmxpbx61h23NE02Npt6F vVMhYvH69EKv3e7cpXa0T0GknqJFyI4VVuS2FfArvlOhVKy99JNLY6pbksyrmxyLG1otKl1q 6V9ppdtbbF+7jPRjpO6YxSXLl19SqJJSgrprui61X6jfZSXuUzCE0mNqtKwa43Sq13FuTVxF sdY1cstOKRBzvMk0mWnzcMz37r27GuTemwuNlDK5cdEUpjUuYiFd80wyXd3BplrWloRipTh7 vYdP6kLFjddH1NXSsabkXs67dCectPYuGqtio17FA+D32FWyT1E7y9C5NQWTrpJWKjSQJy4Z N7uj4vRlyLrR8pab0YrLUiuV23UDs7MkwWqKGTiVUtGJtxqQsn9qFnU1bbKqnVzbVCahb6ml GoM8szqQ71UclqRX9kO9+OnQxrd2WpnjVuOm1lpxcyTVQ5stBVuqqVuJN33Y6T9F3WiuqppL 9SneqTVdWzK9famnoxaJabjJTVW96VUiVVK0PXQrFm+P6ky25bNSf9IdGruXsillT07GSsiq 8ZF4w0qr3a7GvGdV9qM72s2ktK9yr2URV6IxfZfyee1VXlEIeOcmtYhGN72uuD0TRl4mb4rc bdB6XO7OzW+elb2lKDVVqkl+hlmzc9Euo65dF0gt28Wp3a2/2WuOv1Fet2ubahmF83Ny9jP+ S54pF48eyVpwSKtxf0MqzDdtkJYWlyf2vsatkSTWvCrWjNK2aiHsjLlS3FbeorWltLYn4o0y XtZ8lsR7m+Vn9DKvkVr1lLcefyq3SVVBJxm9ItrW+TXUU8rLsKvx/G7XevQ19nFOu48pvZJo tiVWp0YZa1cVZOezcNvUd6WooaUvqTe1q77IeRY1MJpGuG+K7bajqjk4fJu4Ix3dfbbpojWM +TvravGLa66GVqcbcpj0MufC6bcoLZJbfQkm3o1atZJs1WdCUqvUitt7V37Bjq3quo7Vl0Qq rVwhuytXTVrsY/Iq1aexyUyOmi2Lm9l12UvGoZMzbl6nNbPP27HLXK3Kvv0NSetTXp1ulHPc vHbhL7nBbK5T7HRTOr0hkvZddN89I06Gd8s9NDnw119OoazCtKMzInlXUnGlibqqa7sxtkat PYTzO/vsoaN3bR23r8dVZwibZ9E6/ucTtK9xSu04nQxfz1XydNVy23J5+sMxfka6bkfJz6wX anlHVmt8a5N7mVHWY6Mxvbno2ZqzXt2JNxny6uu6VG+DcELLDkLTVLXc5efuaZeK2u/nVKdy U4yS9E1oc1btKG9SsuK1uKWr/wBC7nRWnJq01NcmT5KQvuJq+Liy+pGR25Slxkzu4dmlcitp bQWXx0qJVtOsyZWyWtblboo0FjyfHLa0Zb5d4mzs6mmvbO5LbdWq6tGeNu65P6mKzuk8epb2 /Ja6q5LJqmTbdGtXFtPtPOzQ0rzqbrJZ0bXREuwl9Gtr1Tdt0TXPVuGtehz4m71cakXVpTKa 9Cq5W41M8mT47pE4quOaZk8i5TZaNmd62Rb2aXtN1qaTKjqcWeK2TrqkWsylm52Z10q60aWp SyPIuRwJytJFjvelmq6omevqa9Gm4KEcjy/3Iy/kWZuLr0c2bmlV6QQrdTjeZtT+5eO6acly LrqeVTEaMTb16wc9201x6hjzcZ5dDPYb1vrD/qCe87F/Ks2KVH/Uypd0xut953OflutU+STg ptp67HO2vqi1ls/oa8qjf5a7GTskZO6U+pi7tCTqzeTtrZRIvlSTk5KZYTTKpduILLTW/wAi LVkZfJarh7CU7vYm+6w7ZZc9isl3KjZ9TOmSjlonk1ZKfb0G5PwjqrdpHF5U8k+h1WyOr+Nb dyfLxV4q6e3Qk55/yubFVdkkVPqZO2zWzJmvcbyHnSo1HWvFaaGroh8UtEdtcNZV9rYOXsU6 J6lqumg01MOtdLOTLV7nRxCtEPI1gm0v+hrXTXSWO1RVqnqNPJNaS3Ow9P2KvWNS6w0PJNZu I2/UhVZrsVKHkayVXI22jVtJSRRcmTTWdm7ahxnc146+g3qXyNZ0UFqq1stCqrQS7E8jWWSr akVH6SbpwtSW0i+S6zTbHqma8FHJC66k8k8lVdn+o616MG+w25gsq6l40242M1T+htf2ilQL yTUOFr1Kq1bSBWh6hy4onkaHRzLM1poa8iXDL5G4K0TehXGAT46JArwiamodFvI3SfqVXIrb oV7JbDTUKiTKsuWwldNCrZWQ1dCo4lMVFxc9QreNAvl4jqSi91HdsilE9yaWl69TocJaFtzo 0E3VplYqvm7W1kVb66lK/Vk1NVZpalUr17mfLkaVypKCahuvEhqXBN7pyZY8kNyaaa7/AEHF VqHKDG901BEbclk2BI58eX42uJvkyOO0kFuURqRh5Xempq89Mb+O7hTqZt9PVc9U+5blceKl vcmuSmWziUh2slPLTsXUik5UF8UzK3+3F+hFMvObV6F3psabWiuhmr8LQ047meXyaNJrdFVy rLqnoiWkjotZJxVySoWpljT5OX6id7bRq2A8nu0RpSs1Tb+g3NFNqxoZ4cqpt7o3OfPls6On GZ3b41WJa1NuFU4a1SOd5la67dS8udvWinuzndrcxSTtq/2KdklDRircnM6F5rJVXUvVAkqO Z/Qya4/f1FW9IbVZZyZ21blbY6cJbeqcrHTjxTb2m3Hi4bOXFbs9SquylvVmr3Jjoda41LDH fl71oZQstVa86dDTnWGuq2M/8Hqrk7W49zi8zRtWftXYlXtezt/bMFZcTvtsanSs27HV47rx mu0Fz13OXFdpcNvoXbJR+20pTqTjGt101smpQ+U/qRbNR1SUpQcuG9p1enqTjy1a7ZrW3FuF A6Z0lxS36nJZrJffYvHp9V1Jv+X/AEzvs71gtSvPWDmvkS36G2bxfKdFNrcYn0OC+NKdXyPV yu8ZcYmy2RvS/NSVez0Rh49HWu8mvJJN2cdjj23W5QrQVS6tsZ096HZ8FoP0VXTQcbTqiX9q joKmSrnk9exm9BTonr0NHklpxoTkatotkZwWTYbWjyzFehTvxf1Oe7tpAfM9KPX1J4+yeXpX VytXVbGVrw5e4PJoo3JyXm0Fy1T+X5d0aKv9DivkaU9EWs8R2GdMiSt73Stxe4VzTXi1qct8 q5cl9JGmt5HieTrV4UvcmlotyupORZNYNq3dtWS8SVvXJz1f6IVrzt0MbNVhieVR7epZxzst q5VbJ3/U1yZVK47dDlvezepTs3u/oZzrqeXo1q5TdtCbPRQZK2mr6jvdrfoXDWrTTTYlklue pO7Sb0JyWqregxZXRWPqyK2unxr16nP8mxvXIm/aLxSUZFfklX9TZWaUdOpja3J6C+Sautf1 GJrSdSbXXLjGpj8nB6lPJ7irqodXLKvfgc2TK3bidXOtqw2ZupGazNxy2Q/kjbZdDnVkrcba ehrS6bfYSdV1WG97NtppiaV78mtTXJm5LRQogxS2Wye5Z7pW3PguVVK2gxyZbV2WosluDTT0 RpdK8STL392tTWsJuz07G1UoOZY1VtTozattDU9kVZ8tCcfj81FrNRrBGS7W2wrt1Uz9RZfR dxfKtX3gTyN/aiLWV9VuhLK6px1Fn/aRLVKy4kq1drwc0mrukkXPVldq/LSEtTRzj9tnEQZ4 7NbvQzpazu1bUzl/4Nx25cirZQ9Gh3y2s07aqDndk06kWzNJKdUZnCtWvQy5qNrjGxzuvJyl BzYsj5t2Wr7DyZW3xWjQnGyYl5b1rpyPiktNWCjZbmVr8qJtarYdHyem5uRpdG6t26ote/WT OjdJ5bdx0twTZnp3GeRPGptrU5ck8ufcu1+d4W0FJtQt6zqa4+9ZpUrWktP6nPx5aroXf22i dxSlXQ32RVLPZmuOySan1OfBkXKGa2rMRuzFabLM1tozJ5uN1qaWtxWykWTHjspq9XqYKm03 9zKukklO5LyOI3gfJ5HrskdGVXmqVbaruTe6j1HW6snS262MIbJgn5HOj0G7e6X1FWqltk5a y5LjDZZN0x2i65J6mHJbsK3/AGJg3T4xy6Gjab5JHN8k/Q3c1Uj1biOXKya3Oyrum7Pr1OKt Zaa0NHld3q9icosrarta0t6DyZ7ZMjV9ktDO2Ru6vXSvUjIuq1kSb6La1wqs2Wo8nH49OjM1 eyS7EZKtr0Hj1TejbFndMbVIc7k+VkpaqePqtTlvpXRhSytTi9y+HXyTy6Y0tdcdd+xfjZLX VktJMclLNK39sQi8bdFDUoWbE9W2Kl8d4o/cXDvR2s19DBZ1KtVehryl/Qzltb6YlK1Ek3pb qa2dbPi3NVs0clslm0uiZ2/Dj4cqPUzel1N2MbUSfcHCjuyKW9z5b7GTfJwlqup1jLotx2b1 M634JpdTmy5GmRWzb1ZrDW9rayth1skiFuZpuSo3teX6F0vDOevJtyjSW669CVdbvyFp3Msl tXBhk25DV5WujGGunC1DacWNLXiJepyuuw/q9UYvHqutcloiN5G8tk4T6GdX0aMW3X9Bhre9 nvOpn8kiduRllSrqjTLXmaYcnc46PSRrJG25cI9GeWsm1L8nC2POrdrRbM68Xt/Uz4tyurLi WNJqGzjvZWfuUGtprvqn3D4PlrxWyMdptq5T+OVyqyPIye1V3Rra6xrj0IvWdRPf0LPZndO1 PQ54yd+h03hU0OT5v9DfTuq5fUOWhnZwKrlQV5sap7lJ8dOhzpy9TTkumwRpykqTKU2PnGoV T3DloZ/JLkeRtNepUW7dxq7ehkrrqLuyK2bT2Erw5MvoS3LjYI3d51G7QjOqlQiXMga8tNBc 4ZlLqhzL0BjTm4JpaNiY0gFWy2C4u129xfM0oRnare4rKHp1CY3rkKdk3JlRNFPRBcafIRyj VszvZJJIdYanoF6tHaRK7iCGn02M3aXAR01bSFe3Ejk1uZ5LvcQsbctGTWzVSK2T1C1G3oDK 1rmfUHeTPh7dybNpbAXOv0C15XqiVFoj9R6S0ExDs4NKzWu5N6QvqOi0aZTqfNPQwtk1gtrU PjU6llxZqXZ1Zs76IlJLcVraDus6t1ZNJp6kWszOqbcV6DnloxVrel4XoROk9CWmt9iL2aUd iK0+VE/J2erMeSeg6VnV6QEdGLNrqK2St3FVoiHRzJKXGXI6QVa6s1VE2y2rPqTkfxxx3JrN /v3LE1ti8jhWG9TL+TZy7Q5Fmwuy0ZjarooWpZNV3Y8i4e1itfKlL69zz/GtatuC7nqpt/f2 Mcv21WdnfJTj2L/kXw4+CWjRjju8dnVdTe1XkUW3Jc7LO2s+Cskl13LwYk5nRLsS6qhVciou zFlzosra2N11WsdSMcWfJv7dhp8qwyscw1GhMuNd1vPfPWI2Hzo0qpalJNJquiOa0023J4Gt uKjXQzXkOidFsxV8i0Q+orpbiT0pvs0+RcQmayZrKuMCs9o2L4mtaVa36k562s6pbGtU7UnY mymql6l4jLFbVupsr/uzL41RT1B5OKmNS2ab0au2j+hx5ct0lXGtWafI91sRajv/ALk+hZMR WGWuOyJs3VNcm2yq041haCXutER6kwbeLkSmVL7jvatbTBy8njbS1Rul7eQkyrL0Vjm99XoF qql0qa9zKtVOmj6m3Hqi+Kfow+RvJL01N/ki3B6p9TB4WrTJcJOd2Lw1Jr63zMta+O4fRI+a yWnWTbO5w0a7HEnOjLx+W85ZmZcavDxqa3ddTN53dwtWX8PKWTTHxnTXuMc8rXFks3xSNrWc QtzKluK9R1s1q+pMbjR3brpoLVuUSly2BLia8WmnyPqXjsm9TmdtTWjkWGtL3UyYq3FyHLX6 GbeupPHErb5VGg+a0ndnM7QzRTYJqMjdm5eiMb3aOi2FxLMnjlRBZGU1u2acl+hFccDWNvYY sLWZLV7ctdiVSxSo92TFbpygolsyE3ME3q5Jg1Vq2trsRayb9CVR9Ohap0fUYiFZN9y7w9yK 1deg3RtckMNKtrPUbb69RS6FToGfJDahyX48USfRk8W91KIrzxzUJ5Op3UwjN26JiVHM9R2x RqDyZS7uGFU9eXQ0Wug7bSweSNJ5FWzJrjGu5FlpoOi6ImLORVh6sfP3QhcYlBTE2m0XCcml rN+1Dxua67k/Haj9WFFauga8oWXJqkXXaHuJ403r2KSh6j0XYNlqC8h20aHZTqiLY9SYa3d1 EdTG1rRx6BDIeN7kw1lbeEN2aNPh6i+JrobTWMwVMwir0fQSxWcSVPIVlv3bF89ZNFSy2HbC /uMw1hezTlkK0uDqvh5rQyeBq3oWGlWzTG5TaNbY4tqVjxtzOxDWcJadCsb130B44WhLpuVZ yO95XGfaPFkmQWKdAriVUoJkPJmrKuqMU2m9dzrVFMEWxQ4gdE8nPensdkJ6LQ6lhVVDJrhn VlZ8nI6voddU61XcpUg0pjhakuVqcnPdtpf1FX2rTdHV8a1RKwKfUmRPJy8+PuLrbWNpNHhb bkp4NdS4nkyxpcpifQMj5N8F+ho6tPkvoT8bevUznXfVfJzNPd6EZLOIWp1LG7KLbhbx09Fs aia8+z4NT1NOS6bm9vFlwNeNo+5roawrL3NrWdlBovH0NMmCIjcz0PJzK2i7mjUv2l1ww9di 60dfoQ8nPVb9y5b06G3wzLHXHp9AeTG13HFCrZ6Jmzxp6krHroDyYfFGhFqtJQdDXXqghJQy ynklUs4hzUV7OWlozXhxch8T3HRdZXrChdgpkaptqa2wtNRsWsUKWQ8nLy7KDfFn+NarTsJ4 nrA642SyVmcrGLXOzaFX2Nya1xxb0NLYkzWGuK9FuZ2pDlHoPEkjL45kur5ObHvDNbJVN/gS C+LlWOoXVYM6x0stHOgLHS1fu17GeLAlubPCt0c7x67Lh5OJppPsFkmo6G7xOdNjT4J3Oia4 nRvVPToGtt1qdlMKemwrYeOnUdFvKOaqt31Fk2TZ0rHqUscponQ8o89uI00LvRWTjaDpeFcY NFhrMPZovQ8o8l8uPoFMbaR6z8Wsr0MrYUtC7E2OPFZpwehhuq6vUx/jpNM1pj469DNytTlj XNmWWycQhLyOM0ooXcnhFpHHVHPwmePo19msFkb3TLsrzL2NnVKJ6g+xqp5pbeSvFIz/AI6N 2uK0HoTJ29DzcCqRakQ3sabqSfrsdGNhNV2JrPTY14TtsW6cd9wywS4v1Kvja1kqw2+hDWVM U2mxVquz9C1XqS3GxV2IaaWg66/cVVtjvRdCGwo0jqDr6DVevY0UWQ1djHVbDSsaRxFVw9WV NiY5aEcOGvQ25JuEK2q9AahPqh1TmXsN2Qq2hwQ2BuAqWmmKJGmnd6GUSy3dVeoW2mRp5Mvh 5Gtcapo3qZq8ODWrTY1fKM7VljWNvWwNKSuSgJsLjV7BaummxpVoLvlogawVY1Q05cs0q01C 3Is4IeSk+Qrqz0gVdHKOhPSQeTBYu+wnSNjRZNBXatsDYyTnR7FLDDmSeStUul4UFNZ2T1hF 1oVZxtsUkv1GpqXRuI2IvidtOxdrx+gcp1GnkzovjUspVlz0NbRZEu20DTyS6yN4u400mXLY 08mWOirPcdsbkprjqi1edRprB4naZMV49n7Vqdureg+XF6DTXJbx7P0K+KyiDos+pLeg1EWx yhV8dPV7jd+I65WNqynXxK01FwVn3LtklCpkSWq1Fq+Sq4q01SllOW5kzeRhXI1q0Q8lrHrr qO2FPXsLm/uLd1BdPIlCNFWVMmM6QXTYmr5FZt6GXGepdm3ZomsN6l08idO5TotlsKzaWoNt xAPIKiqtjVVSrruZNNOXsVa8KBp5LV9OLY7tOuhlXbXoDaemyJ0h5GlyrqFqyuJO0I15Rp0L qeTH40W8ftiTWsNBy5E8l8mPCHoVwaatOj0L0SkppcUyaeTmdFV9ylS36FZNXPY0rlUwy+R5 JVIWo6J10KUJw+hbsmXyXzZ2pJn8bk1V4XEa0L5J5tcsfDWqOWtJehVmxc03rpBy4S8d/N1v l8mm6RuJLi2o0HzTBvT1N6x5JvWXoTXHLHyabkFPTYeR5NFVV2Dj3WolaNx1vL1L5L5FTFMl KnGGNO2/Qiza3G1nyq3REPES83FRA+biUZ2nlVvAokaXFNCWZP29QnuNpqmEIizaMnl47l2n lW9qJMqtVBz/ACu7lGlbtTI2ptO1V+g4VnBFnOwtasastaKoaCnXQL2lytmTTafXQp1q9Opn vLWhLcx0Q1NreyTei3CqUQZq8yyXkcwuo2nVo6JgsaaaMpbcLcpXjR7k1GqontoHGrWpm7KP aKU9WUxuqoie5Ncl0gX+pDqTpWdOoQpgV1JzuzThFHS4eg1Wu07HJ8jqpRVbStRo6WkrDW0I wTlrpoClbjR1NqyT7KCEkramDy8X6m3ybv0Gr1W9XKIuv2MndrV9SuU6DU6rrWVoKej6GNbN TVDom3L7FOrat1a0DbUnMrpRO5Utsiuhuqhg7qurJniuLMclZWmoTq3TrEoW7UGCs5SXQubv Xouo6r1bK/cpOdDlffoPlHXQiN1eNBW9DB3a3KWSFKCNk0xN8XoSrpitbWHuBVoiV9QT1noT y46EqWXquVrayrqHyVmOnUzb4w0aUxcl2bLIuUnZNwt+hCv0tuV8a3b1Q3gXBNuWxhlRbN7S 65E1BP8AGTUN6M0XjKJmH0GE41gskNzstDRX/YdMCrLsOmNWmNhhlaJzLI5urkm9lRHM8rt+ +hMTK3eRtya851OOqi289TarnQnUxqrVmCG0mZOzbhbo6Ma5Vm3Tcq4hONQV0kVkppyexlo9 uoTDtbTkib5Oq/UvJNFxqZVUjKZWlLzojW9pj0M6YnuxvTbYnUyq5L9GOkfazC0rQnDy37F6 mVvrUKsmytv0HjpyQw8altpR1Iu7VcLqb3wtapkukNcthh41zt2kvZSb/Erb7DeB9dhi+NYW cOo/kg2eHlt0C+KsQxh41k8sfRiWSdEafHVVh7EvCquasuHjR8kqCa5fb6o1eNIz+Ja+pMPG h5FfVadxympTIXt3GlXfuOp40O+sdBwq6m7xpJPeTNY02DxpWtHuB2TrKG6f29CGuKgZTxqF fTUt20THTCrbsr419oPGs+Uo0vZwkRkUWhdCUnZtsqeNOdAlxqXRK1RWdepOp41HNSaUfFjd aP3MtYk/t2GL41nkh15IVbcqy90XxUkY6Q3VaouHjU3bqDvzX6G3BP2oztgSYw8aytbbsXKe xu/HXHUhU4uP6jF8az5OUmEw46GnGq1ekFcVeGMTxrL6ieq+hvSk7F2xcVIw8a43rowl9+h1 vAuPIy+KvfoMXwrzPk0aGrCdI3KS5JBnGivKgTu2FqpaGVquvuLlLKrlMhW/TqRzlhW2sMlM aNy5ZLlv0NOS2QVae2oMStOpq16mXKHoK7bakZVxordBO0aMn5IUk2stxhjWZ2IdlKTIrvIX u0oW5JLpjat0npsQ8yZhVPqVTGq+6zhdupqRMXa2jFS7e47aPhaO7glPGk3r6C8aYtJ/qazp D3MK2Wy2KtaOpMph2WncpQtTK1mloZ87NehcpjRJOS5ddjOGojUqrbUsmUwrtpSSram0SoJd dNti+NW8VY7cWWpnQnHXnEdzS1YfYTjTxQ/ucIVpbiNDZ2slxWskuumpfGniji002tDS+ygl UbFarbgeNXxS1oDq510NPj0Ul0wvdjxqeLltinUlY3WG+p22xswy4rtzVMs4U8UTBdHO4/gy f4sP49+xPCmJcdCoSiN+pVcGT/Fhfx8qelWXwpiXZTCFpMg/DyW1hmb8PyW4VXAnx1MU7S/U r5o9prj8LLEOupVfx+WZS1H11cYuya1JeaqS7mt/xvkWeldDT/i8+6rqX66mM01YtLuaV/HZ 1o0bV8DLGqJ9dakcbhslJP8AU6v+Mztz0Nl+OyJF+upjy7Wl67k2bS1PUf4u77Er8Tk6wPrq Y81OUzJXaZ7P/FXXYz/4a8y2Prq48x5FJorOyg9JfhH3RS/FWX9yH11JHFjsq7ha6cLc7X+J lzzBfilT+7cv1NPPtaIE8jWx6K/F1W90D/HViOSH1s44k+STZnrL7nqV8Cq/uQLwKLV2TJPj pjz45VjqDslPoemvCqt7Ih/jqWet0v1L9ZjhVuSM9X6npf8AG1X96/ctfj6dbIfXVx5kNuYF ZaHp/wAHGnPNFfwcb1d0PqMeTDSkuI3/AEPU/hYv8v6DXh4etv6D6jHkVbroFZThnr/wcCc8 hvxMHf8AoPqTHju2kDVnGux6y8PAur/YP4fjxGv7D6jHkWtAVaadmex/F8ddH+w/4+Dsx9S4 8aZZvRaaHpLxvHXf9ivgwev7D6jHmRpDLrVrod78fDvqUqYusl+pqPLstdSb450PV+PD/i2N 48L/ALWX6x4UWxrVyD5N6HufBg/weg/ixdKD64jw/dMWRNrM9/hi/wARcMX+CH1xXi0XLTqa Kj6HrquNbUQ18a/sH1w15EtSi2/apWp6n+296Dfx9KD64uvC4tyo3Fh5Kawe8nRf2Ic0/wAE Xwia8K9eLlF0tPuPa5U/wQO2P/BD64PCyq1tt2ZRZ/cj6L5KL+xB89f8EXwg8OuPSKpxBnkp kdT6D5u1EP5p3oh4QeGqWrRCau9kz3vm0+xAs3eiHhDXg/Hd1fcMNcnHVOZPf+Vf4oPm/wC1 Dw4j521Mjt1NrUtbSqPbeX/tQfL/ANqHhPYeFXDflBpbC6rRans/L6IXydkh4QeG8F051kPh u25R7jyvsgWRdkPCI8PHhydUVXFfZo9r5l2Q/mXZDwivKeOyqkkZZMV29mey89eyD+QuqRPC DwFiyrSGy14uSJjU9teT2qv2H/Kb/tX7F8J7JjwcniZXoqs0p4mSqh1Z7a8mz6L9h/yLPoi+ M9h4b8XI+jF/GyNuU40Pdea3ZC+a3ZDxnsrwM3iZI9qbaKx+Nl1lPU935H6fsHyW9P2HjPZH ifxsivopUBbxsu6TPa527/0H8ln1J4T2Hi4/GyJbF/xr9metyY+b9P2HhB4dvDyOyhFvxMyt EaHtLI/T9g+S3oXxnsPIt4eV6j/hZI2PW+S3oP5ben7Dxg8av4/InPcp+Dm48J9p63y2D5bD xnsPIp+PvXfvsK/gXTlbHsfJYOdh4weM/ByNRGgP8fk6bHs/JbuHyWHjPYx43/H5DSv4+0a7 nq/JbuHyX7jxg85eFfsFfCsump6LyX7h8t+5ciuJeHbjFt+hS8SyOv5L9w+S/cmQ1x28NtQt yV4V1szu537h8l+5chrjt4drdQp4V67vTsdnyX7h8t+4yLtcv8NwQvCtU7fkv/kwWW66kyI4 r+Fe0rQ5/wDiLrqj1flydweW/wDky4PKp+Ly1tyVkjSv4u1Y92p6Py3/AMhPLf8AyGI4P+Nd X7WNfj217ok7flt/kHzW7kyK81/i79Ladif+IvMq0HpvLbuT8r7suJjk/wCOyOybfQt/jrbp nRzb6sfN92Miuf8AgMF+PaR0fJfuw+TIu5Mgwf4+Qr4Vq6dDoeXJ3YfJl7jIuue3huygh+Da U0zr+XL/AJC55P8AIZDaw/iWjUpeLO5pN/8AJjTt/kx4w1z5PFs9tDWmCyUM05W62Yq2strM eMNrP+NZEW8Vtm/Oz6sOT7jIbXEvAs1DcKR/8fZuUzs5W7j5WfUuRNc38Gz0Fb8dZ7M6eVu7 DlbuxkNctvx1rKGC/G2XX+h0y+7HNu7GQ1z28FxDZn/AvyidDrm3djVr92TIu1y/wL6Odgt4 DbTe6Orlbuw5W7sZDXPbwW9tBfwrpydPO/dhzt3HjE2uW/g3e25L8PI1DR2c7d2HK3djxi64 sfg3oZv8bkiPU9Buz6sJfdjxia41+PvKa2Lr4eSqaOnlbuw5W7seMXa4/wCDeTSnh3r0Oibf 5MOVu7HjDa5beFd6rca8fItGjol92Evux4w2sMnj3tsiH4uSZOrk+7CX3Y8YbXF/DyaprRlY vDvVRbc6+Vu7Dk+7HjDXLXxr1nQ1eKzWxsr3XVg727k8YeVczwZHXihfw3/Q6edu4uVu5fGH lXi28DJZbMMfg5q9Drmz6h7tpHjE1hfwsttkS/x+VqNDph/5MOM7tv8AUvjDXDb8TncREjf4 nK42lep2/GvX9wVEPGI5v+NydY/ceP8AGZKbtHVxHxXYnjFcv/GuZdq/uH8Bf5o6lX0HBcg5 P4C/zQl+Nr/mjrB6DIOf/jaRHyFU/F4Vvc2Wo+IyDP8AgYZnnt6FW8PDaZvv6FQOGMgxX47x UmuT130Cv47xUolwbQxR6oon+F4qjVhbwvFtu7F8fUXH/uAT8PxYj3QOvjeLXZMIXcIquoQ1 g8ZbU/qUsfjr/wBsz9vcqagWlgrtRDdsX+CImoTUClbD0ohPJjf/ALaDkg5IA+Wi2xj+VP8A 9tByQSgK+T//AF1F8n/ZUJCQp/J/21/Yay/9tf2Jn0CfQIv5X/jX9hfNbsv2Jn0CfQCvlvPT 9g+S/wD9ImfQOXoBayZF1/oP5b9zN39A5egVp8l+4fLkW1jJXbf2g7X6JBGvy5P8g53f9zMF 8j7FJW6sK153/wAmHO76szU9RuQi+V/8mJz3ZHEfH0Cn+r/cP1YQw1AP1DT1DUeoC09RfSSt e4a9wFH1Dj6C93ccPuAcfQFUEn3CH3AfAHQIY+LAnh3Y+A+LItidurQFcEDrUhYEupaxoAfE Jr0Hw9Q4LuwFK7BPoDx1e8jWOqAXJ9oKTBVQcUAwFxQcUBUCgOKDigCPUI9Q4oOKQBCCEGgS gHoEIluqCU+gFAL9A/QB6BKQoHCAegggcAGgaBCFwQDlCTXcOK7BwqugDldxSg0XQcgKahKH +gSkApRWhLukHMB6BKEnPQc+gCd6on5Kt6F/oGvoAp9GE+gPl3QQ/wDIAbfRA04HHqKF3ASq 53HHqGg+KAUJD9o1VIcICPahyuhUBoAk/Qf6BKQSApDkEhIDkJCQkAkU+g5B2AJCfQJDkQEi l9h8gkA5BL7ByQc0ApfYOT7D5idwDm+w5fYn5Et2L56vqBcvsEvsZ/PVdUHz0X9yA0l9gl9j F+VirvZfuS/OxLV2RR0S+wuT6I5L/lPHr/d+xk/zGD1/YZfZNehya6ByZ5v/ADOHs/2Jf5nE tqsuX2Nj1OVuwcrdjyX+bXSjM3+Zv0p/UeN9jY9nlbsHK3Y8N/l8z2qg/wCUzvaqL41PKPbb t2Cb9keF/P8AKe0fsT/I8u/V/sPC/g8nut5OkEp5VvB4v/8AdvrYTweVbd2Hj+YeX4e5ya3Y nmXV/wBTwl4ee3+Ra/GZ7dGXwn+SeV9nsPMl1X7kPyqLdr/zHmf8Tle/+pa/DX6tDx4/5Lt9 na/PxVW6/ch/lMS6pmC/Cvuil+GXWwzj7m32af8ALYybfmKTomyl+Hp1sWvxOJdWM4H7mP8A zNf8WTb81/jQ61+MwruzRfj8C/tH7Pyfueb/AMzk/wAP6i/5fN/ij1P4WD/Ea8XFXaqG8PY6 +7yv+Wz/AOCG/wApme1Eev8ADT/FD+Oq6Ibx/wATL7vHX5Lyf8EV/P8AKe1F/U9d1XYekQTZ /iZfd5C83yn/AGB/K8xvSiPXgIGz2Mvu8xZ/MenBFq/mP+2p6DAm/hccNX5j3VUWl5XXgdcD kaY448n/ALS1XO97VX6HQBBz8c3+S/YtLJ3RqIKlStxywbgOSQBLDUXJeo5XZgE2CWH6MWvY BtsUsblihgE29AlhDBVANQ17hAQAai17j4hCANRQygAQpY9wAUsU2kqAAluwJsuBQApYe4cB AE+4PcVCCAJmwTbsMAOHk1u0J3XdDVfRBH0AXNdGNWfcf6oP1AJY9RSv8gmvf+oCas/QXxt7 t/uPlT/L+o+VO6CJ+L1/qNUS3Y+dO6D5Kd0FChdQlLuVzp3QLLV9QhSvUJ9GP5KjeRLv+wVL XoHAfyr1/YPlXZ/sAcEHBf8A0g+Vdn+xSun0YC4/UXxp9yufox8vRgTwr2HxXYfJ9mCs+wC4 rsOI6Dl9gl9gBDgUvsE27AP9A1FL6im3oBakBTbsGoD1DUXuYLl6APUepPuH7gHqEMlK/dA6 3/yAeo0iVS3Ww+L7gUEonh6gqvv/AEAfKvcOaBJ9/wCg0n3ASsE+jHxfcFX1AXJvoHu7D4+o cfVgL3dh+70Hx9WHH1YC93oEPuVx9WHH1YE8H3BUHw9WPh9QBVCEHFeo4QCSGEIIQAEBCCEA AOKi9oDAjlT0DnUCwI51Iaq9dQNpCTKEDnasAa8kDtBklZbtFp94AFaQljmvoHtAEn1YfqEr sOUAfqKF3Y5QuSAaSQe0OaDkAe0JQchyAKyDkiXIuNu4Dd30gXN+hDx2f9zE8L/ysEaqw+Xq c78ef7rifiVf3Oz/AFA6HZLdi+Wncw/hYuqb/Ub8HD/i/wBy9Bq/IpXdmb87Ct2T/Cw/4gvC xf4IdDqm35XBXZt/RGNvzFelLM614uNf2Iv4KL+1D9p1cP8AzFf/AI7Avy07Usd/xrsg4pdh +32Orhf5O/THYT/IZ39uL92d/wCqHyVd7IbPY/5eVbz/AC+mNIX8zzH/AGr9j1Pmr/kibeVj r/ei7P8AFM/Lzl5Pmv8AtX7FPP5j/tj9Dsfn4l/eQ/yeJdW/0H/4n/LmWTy3v/oN5PI6/wCh s/yuNf5fsS/yteisXr/idPcueZbt/wDlKWXL/wB3/lM7flu1bEf8pb/F/uMvsbPd0/NkW6t/ 5Sv5F1/ZZnC/yeX/AB/qQ/yGd7KB432PKPR/mXX/ALdg/m3/APjseX/M8q3UPm8v/Jjwv4PJ 63823XHYj+c+lLHm/J5j/uf7Av5lv7rDw/Q16D/IWX/t2E/ycf8At2OC3i+Vde52Yq/j/It/ l+5fGe8Ta7n+Vj7qWRm/zdFtVmC/E5rb/wBWaL8Lbq0PHj7m8g/zfan9Rf8AN2/w/qWvwvew /wDhl/khnA/cx/5q/wDgv3B/msn+C/c6l+Ix9WP/AInF3H7D9zj/AOayz9qB/msn+KO+v4rA u7H/AMXgfcn7D9zz1+ayf4IH+YzdKpHor8dgRa8LD2G8PZf3PHf5XyXr7f2Jf5Lyn1X7Htvw cXYX8LCuhd4+yZfd4j/IeU/7l+wv5flP+9/se6vFwrao/wCNin7SeXH2Mvu8JW8q391hvF5N 97M+grjrXapceg857L4vm/4ue27f6iXg5n3Ppv0CF2H2fhPF84vx2b1GvxmbsfQtgx9lXxfP r8Vm7B/xWXsfQSed+Y8jJ4+HnjcOYHnanjHFX8Vl9B/8Tl9Dy6/m/LppKb9UZv8AMeXZ/f8A sh58jxj2f+KvGrX7lf8AEX/yR4mPzfKyX4PI0zqdfK/+VnPl83jc5VqcN7R6NfxeSvWpr/Cy L/A8rh5L3ysXw55n5WY/2OPu19d9nrPw8td7VQlgyLXml+h5fw5nvlt+5P8AFv1yW/cn+xx9 1+uvY9//AMq/8pSrmW2T+iPE/hvre37j/gp72t+5n7+J9de1/vv/AN1f0K55K/dnr/Q8P+Bj 9Q/gYvUn+xxX66975HE2zr+hpjrbKppl5fsfOvwcXY9T8HVY8d0v8jfD5Zy7JeNj1Fhut7st Y31sw5P1CW9kzrrKuHqHD1Jbb6MNfUCmn3E6vuS57B7p2ILh9xcfUnXsCl9AK4+oR6ky42Hq yhxPUI9RLkHu9AG0+44fcjX0D3dQKafcIfcn3B7mBTTfUI6STFgi3cC4CPUiLdwh9yC2ImLd wiz6gUMzdbPqLjbuBoBk1/3MI/7mUaSMyj1Y5XdkGgpM59Qie4GgGXD6idH0kDYDDhYPjt3A 3F+pl8du4/jfcDT9Qn1M1igfxgU7eo59SPjD40UV+oT6k8AdAK5eqCV3I4SHxgVy9R8vUngH F9AHPqE+pLxtsODAc+qHJnbDPUawtdX+4Fchc13F8XqHxIDk+OocKLcaaHKAnjjYcMa3grQN OyAlYsXZDVMfRIaf0HL7oCeFF0/oUq16VFPqPku4BCW1Q1/xDQJQBLXQlXb/ALS+SHKCEn6M qROwK0hTldhb9ByHIBzHQOQmwTAc+gSwkABsOTCWE+gQKWULUGFMQAAaj1FqPUAkNQ1GEJSg cjAKWo9QkEAahDDUaAIYtRhqAxBqGoBDHqGote4DgIJhvqw4vuwKgFWCeI4QFahJMDAf6hIo QoQFoJJ0FoBchJGg9AKkJROgpQFNoXtDkglAEUYcce0IUocoA9i6IfKvoeT+Q8rJS7rjcJI7 /Hyc8dbPdo3y4XjxnP3ZnKW3j7N5T7A7ISaCUYaOa+gTX0FKHyAPaEoOQciAlBoCsu4c13AJ QSg5ruHNLqA5UD5QR8qF8i9QL5/UOfoyVeegcwK5eg+U9DPmJ5PRgau3oCt6GSu+zDk+zA05 PsHN9jPk+xSs+wFc32/qHyPsRL7DlgP5H0Q+b7E8mJ3aAr5LdKsOduxPNjlgP3MXGz3bHq+r BL1ZRDxt7z+4n49XvX//ACNOP1CPqBl/Gx/4r9xvxsf+CNPpIa+o6jP+Pj/wqP4Kf4VL/Rjj 0HUZ/BX/ABr+xSxr/GpX6Ap7DqJeJf41E6V7VNE32DXsOozdKdVUFSvav7F/oNARwr0S/YPj r2X7F8mgT6kE7bJfsHN//SK16BIC52GrW6g5E1YB8rBysKLQOLegBNhJ3B1u9moDhbo0MBbm 9nBMX62KVLbtj4soIt1YoZXF9R8EQRr6Dlrqh8V2HBRMtayhO77/ANC9gQGfKz6/0HL7suRM AlwKX3HEhHoTDS1fUTXqyw1Az+tmTxnqzYclGHBv/IfB9JN5CWBgsTPN/O42vHns0eyeV+e/ /wCV/VFndL2fIXyWyWd7uWy/Hw2yN2o4dfcYgm1sB1eJd2zq1nLb1Z7TR4Xhf+tU988H8j+q fo7/AB9kjG0c3j5rZb2X9qOEmy32dNdAioCDKsflXP4+sSaHnPLHlT0nielZ6ONzpz4+Pj+Y zLuuXJ52PHbgzpq+SlbHHi8NWo3de5mvhN/HD6OC8pxz9vp3SW71dKUHZ+HXtyf/AJHGdf4h 65V/3HT+P/Vf0Z+Ts9T9Ri1DXue5xLj6sFX1Ya9x69wFwnqw4eo4fcNQFwHwfcHISAcPUOPq J/UNkA4jqEeopEBUeonHViDcA0XUf6iQwD9WE/UNe4tQDX1DUNQ17gGoRbuEMNQE6N9RPH/3 MvUWvcBfGu4+CQS+5Ls9kBUeo49QTYpAOPqEPuJuAdmBUeoQSmxcmBceoQRLFyswLh9w/Umb BNgLf1J/UWvcTq31AsCOPqw4oCtRu3QmEwhdgHPqHLTcQSAuYc30kewwFNgmwSKQCb+ge7uM ACbdw1FISBywhwiJqE1AvQNCOVQ5IDTQJIVl3E7pAaBJHNBzQRSs+w5ZHNIFdBVyw5Mj5PQO foEXL9AmxHMHdgWmxyzN3D5H2CtNQlmas3shy+wFqQT9SOTXQE32AvUUsU2CWBUsOVvQmWL3 AaJ2GrGfuBJgXL76D5epm0whgach8jKAnpKA05A7PoZfqOGwL5MfNkLbcI9QKV31HyZnxnrA /wBQL5PYObM1H+RULuBXJhyYoW+olX6kFcg5i4L1B0TAfJsOTJ+NB8VWBasLlILHVbIfBAEi 5eo+CD40Ak0wbTH8aG6ICNGNL0L417BxKJSCC+K7BxXYgiBR2g0hdg4rsBnxGkjSPQEvQCIT GoKhdh/oMHn+T+My51bLXWsFeFR0xVrd6o9vx3/sv9Tz6tJawPt5c9+Pl249jwnH9070oCEP kp3QSn1GBQg9uwQ/VlJW7FwTKCV2G1k6QgSyLd1AUrsCsuxpI5QGTsl0f7Aren9DWfUJAjkG vqVyfqOWwI5P1CX6l+7oPXqBmm+zDVdGzQYGUPsw1XRmkBAEa9mGvY0gAMtew/d2LSCAJ17A 2+xYoTAnXsEvsVxQ4QES+wrXjdGkBCAzV32BXb6GkIYGas+w5fYsAIm3YU37GgAZTd9Bxf6G gnsBHGw4sVIyDPi+w4fYuUEooiH0RUMaYSpAXugNRyJ2S6gHuCLEvNRdQ+encC0rC1F8q9Rf J2TAqLMcMnnbsJ2t6AXDE02tDObPWUOH/kBopS1CGRH/AHMcLuyCoYtRe0XCjAe3UUxu0PjR dBzVdEBKfqE+pasg5IaJlkuz9S/kWwfJXuNEzbsC5lfJUPlQ0Jq4KtusD5z0Yc12YBFu44fc m1+yMr5nVbC0bw+55n52r/iv6o6fntHTY4vy+Tn4tv0JOU1K+RbEUyTSOjwv/Wqe+fP+G4zV +p9CeH+R/VP0ej4+zHysnxY3bqef4/l1w0iHL1Z6PkY1lo6nn+Hgx5U+X3JwzPDx8L5e68t8 ujfH59b2VUnqdpz18THVppao0y240s+yOfLxt/Y1Nz9zzGuVLZOqserS0pPujwVhzWq3WeL1 PW8O/PEp3Wh2+WdO/ZjhVeT5KwV9eiF4Saxy925ObFReRnte2ta6I9FHPlnGePr6tTrdM6vx Cm2X6o5Db8VlVL5V6o18Nzknydns8X3Dg+5hbyO0C+eHDaPb5xwdHF9wdX3OavkTOuwLNXq2 Tzg6OL7jj1Of5qPqxfyKzEDzg6GvUNO5zPPXoNeQo0Q84N3HcP1OW3lawZ38ixPsiO4IZyY8 r6sdc+6fQvnB1pBD7nDbPGqYl5erlDzhrs4t/wBxXF/5HFTye5p89HsPODp4ytwh9zkt5S2K XkaJJjzg6kmt2CUHHby1ZOHqFfLS0Y84uuxr1CPU4f5krTVsS8vu9SfZE13R6hDXU863lNtR sTbzHW0N6E+yGvSh99SXiVnynU5F5EuejFbNbdF+yGu1Va6lNep5r8i1bLWVuafy2nA+yGu2 PUcPueZ/KtM9DV+Yq192g+yK7mmuoQ+5xLzavToD8xPboa84OyPUGn3OGvmy9tCq+dW016jz g7GnvI2n3Oa3lVrGsh/Lq9ZHlBvFu4Q+5zfy6sVfLncnnB1QxpPucr8msxJNvIqu5fODs1E5 7nKvKrOvYS8hW2Q84OqH3HDRzryV2B+VWYJ5wdDT7i9y7HP/AClr6B/LrEl84N/cPXuc9vJW jrsRfyVWLQTzg62rdw9y6nN/K7kvy0tB5wdXu9B+70OP+bVP0F/Pr2HnA1HYJRdKYrP7zT4c P/yI6Dn5LsHN/wCJ0/Fi/wDkQfHg/wDkX7hHOrPtA5fSDfj43XIDt4u3MDBN+g9e5ry8Vf3l fJ4i/vA5rY+e7Y1jjqbvJ4f+TJ+Twt+T/dgZuF1CPU2+bw/X+ovn8Xtb+oxWfH1DijR+V4q3 T/qNeV40Sqv9mBlC9Q4/U0fk4X9uNsH5uBaWxv8AYdBnwkOJo/P8df8Atv8A8ofz8T2xMIji HGOpX/I0nTE/2KXn1/8Ai/0AiPUXFd2aP8hG2IP+QutsaAiEOEUvyOT/AOJfuNfkMv8A8a/c CeKfcFVPoy/+Qzf4L9xPz8/StQEsa6Jhw/7X+zH/ADvI7VEvP8r/ABqA1T/tf7DWF/4v9if5 /lv+2v7krzfM7UA1eJ/4v9g+Jr+1/sZPzvL6KoLzfLe/FfQDb47f4v8AYfxXf9jMP5Xk9w/l +U+qQHR8N/8ABifj2f8AYcz8jy/80T83mP8A9yv/AJQOleM3tQv+Pdf2nNS+eurvP6D+XNr7 yarq/j5P8Q/j5P8AE5llzLe8g8uX/MaOn+Pk7B/Hydjk+XMtrlrNmjW40dK8fJ2X7g/HvXt+ 5y/Jk/zZLd7b2Y0dawZH0X7lfx8nZfucdb3r/cweTI/72TaOt4Mnp+5Lw3jdfucaVut2xure isNo6ceK7WrU/U1Xj39Dz6qycqxU36WY2jqWO9rcU0avxrrqjg5XX97M7K1mpuxo9ReLk7oT 8TLOjrH1PMtz2V3+5nOZac2PIex/EydbVE/Dyf51/Y8pVydbv9x/FZ72a/UeQ9T+HfrkX7D/ AIT/APkPIeK8aZGK1Lr7so8vyj2P4U/3i/g/96/qeMsabh5Ww+OicPJb9x5z3H0OKqpidVZe pzU8XG0nyX7HH4irbDniX9foefXHiSSSc9dTjx5Ty5105f0x7/8AFr0uv2H/AB6LfIv6HicM S0c/uy6LE+h1857sPXfj0f8A7v8AoH8bF/8AIeVSmJ6pFrHjeyHnPcej/Hw//ID8fCv/AHI/ Y85VxyUqU7DynuO9Y/H63/0Hx8f/AOQ854qX1gl48aew8p7j1FTB/wDJ/VFfHg/z/qjyfjx7 wJ48fSo857j1uGBb5P6oX/8Abf5z+p5cUr0Gr1T0SJ5z3HoWtgX9zJtfBGlm39Ti+Wr3J+Wt ZehnzOj0efjKJs/3D5PE/wAv6nmPPVdAeSqU8S/ZDY9VW8W21v6jV/F7/wBTx3mhtJIK5fRE +yJsevOCev7hy8fu/wBzyvlaaLpZOZM/Yux6LyeMnEsheR42zb/c8prjLnVgqw9e0j7E16t8 vj9J/cmvkePy1lL6nmOVqyb2VnLJ9lNeys/ivq/3F/I8V9/3PJS0Rk23sPspr3fl8XeWTbP4 26bPJxvkob3G8mvZIfZTXqLyfGmNQtnwK0Kf3PLhpuGCTer3H2U16P8AJwpuU3+pK8rFGzZ5 98dk1Bnbl9o86a9K3mYv8X9ZE/NwOy0cddTz1SVDH8VY9SedNdt/MxtTVRqSvNx8pdHH1OL4 9O4cug86muuvm0ajjD6aiXlpqWjkyUmLLSCK+18SeVNd9vJq4a19B/yMK3bOBKHKHxh6ovnT Xo18rCpmtm+ksf8ANxSvZpBxO20boFZRqPOmu7+Zhtpw/dkV8vAm1ahxNq31M3VrUeVNd787 DP2QaY/yGPbgpPMVerZSVYgnlTXofzqWtpTQp+bj6Vg81WXQm1ubHlTXo281coVFC3ga86ie tNDhraNexVrTWGXyq66cXmUs7TWEJ+ZV68epzqiruS7Vp10HlUdVvyGPSK95B+XWF7Tkdqph 8ldyedNroXlJJrhMxqa/zavVU0W6ONZP2Bt7dGPKrror5TnWsg/J5bL9Dntm6ISy8dR5U1vT M6z7W30Nvm6x+hxfLZk/K9ieVTXc86bl1gXzv/FGCySlILJ0L5VXQslqqYUjeSzWyTOb5HvI 7ZH0J5Udiz6RC7E1yw4spOVWXVj5yPKq6ZbcpIyl6ytwrlS3JtkTeg2r0LWHpqcf5Nz47OjJ Z31TiDh81t+PaS8e8Yr58K1dnC1NL4740lZROqDDlthtyruesPxtMtfqfRHzypbHmrzUOUz6 A8X8nvHo+LsDnp46pkeRPR7o6APNLY6YRz+a4w29dDoFZK2jLLllLOiMNIxqvocvhzVZK/4t nchJJF8u/wCTHiYvJy4ZVVu5PS8LNfNVu/RnRFeyGoWxvnznKf05fdnjxs9TMvGtxzZF9DWU c2J/79/oifH3rPyf0uzlryKlxye5LUKX2HVq1XG8HXHm1Cu67squZxtJmsbej3KShIYa0+Zt RsKudrcl9GZ8dZ6jDWryqsa/oDzaQjOmPlfk9zW2GXKfXYYaSyOz13E7ap9i+CrNl0It7tWM NJ59dBc2tZ3G8CqpmRfGnWRiat5FsyXbipZFnK2LtSvNNbBdO2RtaoytZzFdja6SbjYza7ET TTmGaK/Uydk1ILNWIjcK25KY7kulruFsZ20cbmtcqqoiNCiVS1dLIVbzMlfK7arcwbn0YOyn Z9QvrBmqt6yNuGmyDRZHX29DR2hN9DNxElvSEtmgMr5eWqHWd0W69xLGm9Z0Lipu3HFktN6v WTbj7oeo3VJ6jE1gscKUZvaGdbfG0LsSkp1KMcatSINHji3N7Gj1ST6F7zV9gMkpcr7RPGXo tieU7gWqe1WHSi7zJHKVCGnHUinZJNwZ2dpjqafJNoYOyZRnyfY1pla0jUHZbvcK2T1YDtml QjNPXU05VcsztoyLp84UPcyd4RpeLdCa05fQJqXl4qUFctrV4sd6Je4OHLYYabvEC5NlQtHA q1VWwamybUrQzl/0OisxDJj0C66vgx9g+DF0qi4YHt1U/Dj24oFixraqKHsQHGvZBFeyCQlI BpLsghdhck9ZDkn1GioXYWnYn5K9yfnqNGqAz+aonnqnEk2DUZzryKit5NVsPKDpDU5l5VYl i/lVZPKDqlgc/wDIT0Qv5CiOo84OlCOf55XYn51EzsTzg6wOZeSoD5m9h5xHSBy/O4hErM1t sPODsGcTy6bjWVwT7IOwUo4/ku9xTZ77E+wdvNbyLnXeTjdZckKka2Y+w16HNCtkrVas8693 ZwmNY3fToPsNdlvIptI/5FO5x2wIHXSOhPOm10ry03sP+Sp20OT423vCRo6pxL0J50dH8lPb UT8lLTqc9adUU4T2HnTq2flJOAp5Cs9TFJdUS67WjRDyp1dP8iuy3JfkbGNlp9QW8k86mul5 09EL+SjBKfdJF9YHnTXS/JU6E/POpzvIoiAVqr6k8qa2t5LjQTzWcLbuZuyWqCf3J5UacnpU btasRqR8i39B8k6yNoHktbZ7Eutm0/6CppoHKbE0UuS0kuUtVLJyOB2toNNNZLdthvM1sS8q VY6krJqmNNPm4gqOpN7L9A5Ntk0a1VYT7CaTc9TBWa03RdWtwmvU8GiWHIec6qe2p3eBZvDl bPKvedEY4d+f6uvP+ni6+K1lmXGH6HMs7bgl527Qbctdy9v6C+bQxrdzFiVuyGumjUwjRXln LRv9jWrncLrXl06BcxsxWT36GjVpxpJpzjYxfcTcS2E1d766k2entJV23MF1bc6QBNW2ttBP XQrg1oTemqgBN6itMytinTWR8Y0Jgm9m4a/UjHZ7larRhP6BBeYkatOw6KRVo6SFP5NR1y8r amVatpoeP2/9Bg3adhVUv0SB2bUkTu0A25egcdZIejkLOz1bCL4Ldktw/QfOCk0+mhVDypvQ rHkl6ohWXYrlG5BrZt/UybjWROyqZthFO+5Nm7DTUk3e/cBrJCFSsuW9zGzW3UFkT3A1tZtt IKOG53FjesDUOU9wKWXiCfL0E6ytAova2t0BdRWo7MFaNP3Lq61coCePF/oTZ9B2tNoJvDYE SraCaddUXRaSiW0nAFVXFJ9x01XYidPUacAazOj0SFL/AGJl7DXKJYVDd39GTaiq07G2O8bo nI/k16FRDr+5MQl3NFZTsNpSQFY48WaW0ST6GDfHQfyK0yFaK3FNLqKtE3PYzWugVmGBouKT noELoQtJQr2cR1LgvkwVlYzT47jrVSp6hFcui2LdlG5lqrNLZFwhgtWlbFUbrE/Qi1uy2Jrk slrqMVpMNpouiqtWRa3KF1gzzJt9oGK2dU1yRyeTXlhvXdsuuS9q+nY1pVKq5dWWdGXz9/Hy 3a5y4UKexf8Ax+WOXFnt3U5PRH0FcVLeLtqkerhz3vFfA2wZVZWabfqdXy+T/iellVXaCsaW hw+Sy3rOyzlZ2eVbJ5S3UFqnlxOkHputW9UNw1C2Mft/xh58vd5Cr5Vtivg8p/3I9HE5M7q3 KV0OtnGTpIt5X3ca8XybOHeB38PNW3H5JOxWdlFU56kubP3bnPfxE8r7ue347yKuHf66mdvA yq3Hm2dmR3e5v4/Zm+F30huvO/gN11yPl2NPH8d+NZ8nLaOvJHNyiUm/UnK94zaL2/ZojHkT +3RlXhuDK1fjcswjrtdOqf8AcY3s0Y5LtbbMrf2LbdSBq37NNdQtZbCo407qCHV7tSmMHSl7 kn23Id4S7ix3mvG2xouF3D6aSAsGRWsld6MyzX4+x9yuC23ItjtKkgdW+HFlY3sn0FaX/wBQ rRv3AOVXVbkz7dN+pLo09NUWq6ytgFVPZ9ELHNTpVJ1a2Rm6JLsMEUxc9d0K+DjZo0VuK022 IsnW013AnHSXCLb5W4NbGaq3r3NcdeEX/cKcqjlEKvN/Q0Vk5XRjWOAJrijWNxKqhqxTs50e xTq3HJfqBNaStDJvv0KTdbPsTPoQXaz+3oXSk7vQxqndNLcuISUgDamCrNL1XUVqtQzRUnUD K+RS42BuEh3wtOBPHEAO7UomycynoavHohKsVAhuXotBW7FW006Bo67a9AEqqJTG42jUVbJ+ kD5cbaoBPXVqBWaNGm1CMq42pIpZGim4SJ+Np6lvE5kInk016mjqoTJ4ufoU6uJQUkpcFceN o6CjjqV6sGIjlIKsadUVOqaCy7gxKQVh6sp9F2Fx7BcJWlfRmn69ZI4r9RcWDD+VzBFsjTRg ssbvcf8AIr01OvlVbfN2C+a0o5pTcmnOCbRbzWexXzWagwd3PoGtnEwNprV2tHEGrPqSrP8A VE2yQ4Q2hNWo5mR9IfQKuvVyJZVDhBCtazhrZCrynrJrTI2tEQ8kLTVsgitHO8GlMbe7lCq1 vYqqS1RDVKEK9aymthKH+po4S+gBTitHoJ3qtaol5FvuyuaW5TTmVroFa8lqRbLJPKdEE1tb Gk99R8lEMyqtZ3FbE29Aa1dqoOVdGZ2xgqStCGt/a5fYSiuvUzsnt0JtkbWgG7yTCSB66Loc s2rtuxO9quWF11XJrZV1epzxeymSk409AmtXkXYdc9l0MKNxruzSNHqDau2ezsu4a3TlktV3 W4scptzoDV8unYTyRoybLk/Uaore5lNUr9Vsxq8L1JahJPbsJp9Howau2aNxWzykhXryjshX xLXXUhtF8qUJGdsjrsN46vRGlcSe/QIi17Va7sdrRuadO7E0mtQM3kQuTenU1sqpE1SWvUDN W479RvKthujfuF8a4y0EVWyS9DavFKDlUvpoVasxDhLcmK2vbaOpCq3JCluXokWtwC7tsunU VbctLfuWqVX/AIhxqkAr07EVT/Y2caJFOiUAxlVyUtE095BuNY0DnqFKmjLdNJ3Zk7Nv1G7u j2A9LBlWPFevWx57ov3D5VAlf9iSZbfdq8tknsmuKs+oliUpo2vCgdWuP/Q1rJKuuvUvio06 AtdQczHQgPuiCq0lakK3HYdcnR6IDVNRHVD06bHPz1cMdVy3KNbPuLktJIW47paKoFtpKRPI kjBtVe+glZ3qB0LJ1QpXXdGClVhCct6BHRzUETpDM4c9xptJyRV8ujEusnO+T0NfjsuoFO0O EDySQknbV7FcF0YDqpfZF2rDUE3tx0Rm8jspQMVezrL6dCa3VdzOzdloRko9wjovkqnpsL5K xsYYcbu4geSr5cUgrZ5kmiq5lDW5zZMbUJbofB1/XcYN65lXUd8kw+5y3TX0HSdl0CLtaZZN LzoJqdGJ01gDStunYMk8tSFFLQzW3u16kXGUzuaQupFKuzagp1iUDFqzq9BVfJ6rUbiF6GVm 09C4NLWjTYtWS3ML1aj1NrY20XAnl15PYmuRWWjMX47u5Ww8WF1cCwdadbaLr1E7VWjJWNu3 Gu5nadnuMGtbqBcosYYXq6M1rlq/V9xgtXWyWg8aTlMdb8tByphbgP5KKGhZLe3kZOrrqkU3 yrqDTxW5bl240XoTSsOfQdl0YNOqnoDtqp+g9KrVieRLcGpeKLcm9ArRbjbq9xJzsUR9tnG4 KtrblpN2noXDWgGaxOyaKeHTUuraeiBWs9wuWsnjX6jqtfVG7xWtqTbDamqZrGvBgtG09ylC cFQ9urM7Li4M1zvRei/UK+3VbES+o7K0wTqg4om129HrBoq2WjB0hOdwMKt20tobW0hENOJS Nfds0mu4VVKu79qlnt4m6+Pxe55nh+UqN6R9Do8jzeUOqaOvGyNR5mTE1dt9wpXSUdLz87px o90dFfKxVhceupLlqZHDxbUw5JtkVFDPTt59NVSmx52S3ye6Ouxm4WRx1zS3xOjHdR6js+iS FXE6pyXly2YjVLqiGkmZ25dy66b7nMMhPjaSkuW3QS9S8bZ1CbtZyh8dZbLpVtNExDjsL16i VVKWLhK9S+De2xdavRbAYfDO5bwcUn0NlVtOwNSo6AxzurTgnZxum9TpVJ/Qj43y9CmM743s OlX1NFituarE9wY544tlJ9TZ4p3E8esEMc70TGtlBv8AEmivjqtAY5npsFa2tutjbjrDLs0k kQxDaiO6M3VwpZW79Co1a7lXGNaauOpVqaabmr41sPQGMnR1j1Fxb0b22L+TktegluQTfHMN FKvHbqFrRouug7KH3Aluemwc+nQSTSjoQm00BpaukoVlGodI6BSdmAUerewp4uehcSHDmDCr kW5aurGdcEbl1pCbGB2toKsMlvitR/bHqBSlud4E7ToDu17YFayS0Cm6LqZ5kntsiXd3XqQ6 tfqQarjo4HzrZqTBq0C90xvIR1uEmhY1uY69S6aOUA7Q9X0BxZSS666FYvu4sBpxqZ3tExpJ V6OJRk29n1Iqq2nQvZkrHGkbhwacbgaW0UlX2gmrcNLqTW2kMqqTla7hWGiaUfUr4mmAmmte 4SXM6E/GOqPKSlfQnbbqFZZrbVxB0ZTydYVSqWb1NljUaom3t1WxFCbt+gnopYK+u0o0upXo VGLcbI0rXlo9zP2pueg0uWtdCUXZJaLcn449z2Lx25MMjUtbIKKJNNlvGmtNIJVuxXKdCaF8 aa3HakCV+O6DklvsyoOJVaxuUnNZ7ErIp1C4VqJuOg7KsDtaXCHdOAYnitxVT3ei6GtV1/oK qTcBcZy2V71sa8VXczs7bdAYnjZS2hctCk7aqBOrjbVgw6t7dybVjQuqddQdZckMZrcfDk5b NeHFT1YnWy1BhY8fJMVcXu0Nq2rEV3K4pOZIY5suPXQSx6pLY7EqbPdkvhToUxzOqTjoVjpa znojWroobRp82mihAxn8a3e5bolWOg1dDeXitpKuM1TlVv10D4HEw2x38p9NhfybdNgmCuG9 twfj2nUiue9upayOz1ehFxT8dVhyUq12Rla0z1JSb1QRpaOhg0l+oNtMOcqXuAlVSbcNNVqZ O37h8tkvoDoqa7Cd23HQl5FD7kpuimJkgE9dJL5amaydeg8dmv1CFey6LcSvbfsN5HOyCtmn FuoEc3YptpabEyqzBVPd9QhVu2X8lkJUhQt3uTxaX0C60mVKGn1ZHX0KVG9e4Fyp5By5Jk2x vlrsU6vi53ZRkmumppp9zM1ja1ZfBp+4gVW7WabNYqtBQq7depLrGoGswuKIlxuVZ6aLUnSu 4CsmmvUS1fu2HddZFa+sQBeSsOFsTSXt1E7ctugnd11QRo3qRa8mNeSST2G7R+gVtSL79CqJ JudUjmTalvqzSuVr2gXtoU7qv0FVu1vQp05212AVr8dKhZvZ9pJdUnLNNUvqUROisGRuySX6 g2pjsUlLcbECSVH9Scnthr9R3bWm7JWqAVLKX1ZotfbXbcVcCak6MeJOWgOXi6uHsjT40031 ZsqS2LjKaRRz1Trp3Gqcn6m/xNrUapWv6AxjE6Im5qodp/cUTZ9gM64pZose62Hf229upXLv qBm8Ser3Ivh6s3UF8VvYDj+Ntl1x8badzaqeyNEo0BjmahtLcngkbWpOswFEmBy/Hzc7di71 ek7m/FLVktSXUQmmpaHay2Q7Y+Khbmar1egA5rELpqCo+WnU1hpwupVaRv1AxsnLjfuLi7a9 TezSfGAq4/YaY51iatz77jt49bOK/U3tfol9TWrqtuo0clKQo6lLFxt6mzTnlGjBWTmr3Jqs 5hhDepcKfQJUQhqYVat1gxtjbcPoarMto+oO6T+hFxHwvd7ItYlbX+pTu2mZ0yuGo0Lpiq4k tQePj+oc22lA3y07Ma00piqvqL2vQibqbdURVv8AUautoiSk1EmFOXczvy5Sxp5OpcrPTYp1 bTnc5nyokweS7a13GprbgpnsFsSb9DKvKj79y62b32JqZG1sS4oPi5a9jF30hSDyWaSGnRql DHbHV6GNVaUVxty9EBaxVrpbYtYq2RjZvYKZGqyDo3eGtft6CeFPclZU0HNr9Rq4fxJaobxp mfyNCeW6GmNXVVaS6mfxOdBVdr7aQTW903L2YMbXwTqCxx6sj5MmpHyXb0B0aPCkpqR8XLUX Ky1ZPyNvRhGnxk3xp6T7iXks16ClRqxo2x0iJJtraEZ2vZF4rcnKGqtKGUqJvXYztV26grNa AXdOYBdECy9SOW7n1Ar4+WwWTQfI9H1JtZsDV2dVPcK22fQztSdJ0JbhcXsBtxl6MmycNdSK N7wQ8lm5QMaVTUq3UzrK3LlNJyPjyfJgxnWlnotxfFa2j0NVZrVbDWRbf1GmMrYXUPjsnJpa 7mC3br2BjK2J2mxTxNL2jeTT0K+TYGIthbUg8Lej6Grs/wBGT8jTKuRFcTaaH8LX1QVyatdS rXSaaJpgWONRPBy1XUFe+4K3cumRm/GVXE6GlvG00Y25egTZ7dBpjH4mtmarxklKYKVutyqt Ueo06D+PpEyHxqyM+TchdW4prcmjT46OJYnjrChmacL/AFQ66V02GnRtxqHw43trJmm3qvoC xtV03QEWwVUyFKV2b0Lu21InRRruAOlIhbieKsyXXVS+hM/0AVq1TLpRLRrcl1kfJpSugF3S q04M7Q5Y+cz6kUUP3AKqb3KrSFqEzK2YS+MBDdtF6CUJT1FvP0MmmnqDVWq7PR6mV1Chm6ro Li1bXoA65FSqUTA221IuPREqtq6yBpZxVwtUTzf/AFFRN1k25vsga8iiS2KeO+7L4cVpqPm2 lrJrTCXJ7gq8nqa9dXJN7qkhSWJaSN405S2FW/JbB8jT0CYLYE+hLxqvtgfztygrf0GmFTDq VbDXV79hPJZuS6Ru2QZVo6vU0VU3KE3LFVRrBaFfGt5NVRNJMnhMvoKXtIOy3txSMXgt9zce hacsVU9yDRUaWpdKStdDNvQFeE5CtWo0SKrja1a1OZ5H0Nfms0u4RdrOYZNk256Gd+dp1Gm/ 2KNLtqI0TFynbczs3ZyHLitdyC2w+RL2ozteVqJWT6agbKPuYL3KHoYO7qtSldNOWA1KUdSc au2NudavU1WRpICL3aW2pNeTZd7z9vcV79imlaz2HKX1Id40W463rXXqQ1osiWvQSe5Eq2sB zWxF0Ws22uhDyPoaK6ekEzyWwTUX5JaKUVjyPTQtJxLE7NNQE0m7OdNB1vaqUIK3bfueg/ma TX9SjNcnVtBWeMxqV8nRaDV9YT0Iibvj6iT5LYuzc6odbRpuBnDiC7UfGHpI7Zt6xuWssJFV lSiThhkxapLY0ab1ffcrePQI5q4OMstVUS91sb2WqgV6e5t7AYcNdjemPRtrqRRw4ZpzVG0t mRYn45lELG50Nlbquw3aFO7KYdcUTPVBwVY9AtZ1aHyrZ+qC2Ja6kWiJNXjb+pWPDyU2YSRx pOVL3NG9ZOhYKrRD+NSyr4uPk5cLqRxdm2dmRKNUOtqrYJjBJvfYp1j3M3eSVotDGylOSGM3 WU43Qo56NG9ccKe4NqlQYwWN10Q1gdmktjZNW93Qh314oGB40k0CwpdNxcoclfNDi23QKm+J 9tCKYm02/wBirZLTKF8jsn3CYumKdSvhtVSmZPnD9SHmutEE6OpUla7mdMd7TazMnktYePJZ adgq3i0+rKrpotUQr2sn6EY7Wq9iI1+ONV0GsXfrsTVWevdl8nVxugocSFW1ECbciU1+3uBr bQzp7diqa1c9BUVeu8hRzabl7ExLnuK1Zs2aY5WsbF0OrhSLiP40khVW7ZEOlk36IISmxnq9 VsEe3XuNFtp1TXcpZFs9SXj4qDJaP1IN1dJ+pLskzJ1TfqXauincodvdr/QeOnGrb2M05RrR afUAaTSJsluirOP0Q5WjgLiaRfVj+PV1sFnooB309RqK4pVnqFWnozPlL16iro4Y0g4zaew6 0SUIrltxDkk47jVwqpbmjiIIb4aRuXEvUiYWKX7Sbvi5RdWq2chZVer6hWUcXC2ZNaQvVFWb 6Co299wDgkm41IalP0NnvHUEtwIohuiReRLil1ZNvdVVAutuGkA436GV5VkaWf7AVy5JQFaL fuTb26dC6WlNjRHFJNDsk9H0CdJ6g3K1AaiCbVUBz46CkClbXb0Itbjuipcx3C28MQVyW6XQ VLp9NiKtr29R09sgVS/JhfI66ojGk3Gxpai4pL9ShfIo1LWSkbGLcoTUbEXWvJRtvqTXJqCe kiaiwCWWXtBo7uIMrSmUr6qQiq3a0JmHMajdlLNeKiWNVHPQFdLRoWiUrqUrJpjQNzJg/VHQ rqCJ1a6F1Cb5VSS16i4xBastxvRDRlEqQd+LQ7PjsZy37v6EGys23poOE9UY8m6K6/Umydoa cEG0KfQV3xq33JxWl6sLaab+hTV1supTbM+XtiNhfI0oC62S01+pSiyl7kc06voxY3zGh2no Z9YRrdtWMm23KKitWostUOrZmrtPU0qtPqRUK7Urowq9jLk9mOXOpEau0Lkya2l8pM+TenQr HWXC07FNa8ui2ErQRZOjldd12Lj27AaPIoTM3kltLoZ3Tum0yMWSU29wa2teNSFazfoVCste xHKEvR6gbVv+w73ckX3lGfK1WwuumXE9Q5Wt9pi8j1gilmrA10PJOj6BzUrXUxvpaOoOHo9w a25Kz10KqY1TTgrnwcf2sDS6lytxKYM5bcfsWrxv+oAk6qUTW7eqLadloYw4XQqVu4evQatq tJMqXiV06oLaWSWwNNt1cdCK9V1NHZWq0Ypd9ga0aY6tGdW0Zq0Mi62s+P06GVb9WW1NXX9T Gtk6wwmrn3b/AENK3kwhWlPpsx0q25nTqE1s1D0B5m2JZHroQkkgratlZyJ6MwwuG4NWnZab g1XqTbcm1uLS7hduQqk+P6hzMtW47GnyvsgmuL+30HjbjRadAA0pp27Cu3OqAAKrLajQdo6g AE0iNCumgAVFI0x/pAARYVmoEpgAKCbR6CXHruAERT2FLjQACpc/oZ95ACg1gp/cgAiJfLWC 6T1AAItspJtLeugAEJpdXoaY+OkAARVo46mVYjTYAA0p6blVbAApa6xuLLMABSo2fdisly31 ACI3067GenJQAAVrrJFp6AAF6QK0T6gAgVi1x4gBFVNeiUwYLfTYAKNm3ClaSTVw9AAgq7be qSZOnXYACuht8Hx2nUzhrqAFKad9IWkg5h8pkAIiatxohvVqdGABYSSnQ1U8vQAClknqC3AA nqrJLfqFeXTaAADVu7Wigj3dAAKVp1kyrPQAKVadteKGtvcAEBVRVS5qFwAqCvHg/qpJ9rnk AEZZ24xoXeI1AAp0iPbsXV6apABFXXjGpk/jhgBUolaQhOG9Y/QAKNHx/oS9FoAEVsttDG8R puABVKP1CkTruABDWkxr3IfUAIoW3rIPcACNLf0JbesIAAmrtGmw7ROoASC7z1MWAFQU+5dz RzOoAFZ169i1toABIddtSUlxcMAC0lvqGX7lIAT1QlHJd4GnqABV020/QT303AAHb+ppbX9g AqsnPXcd+gARBliNDNfYAFPU2vcu8FgBArP3QwqAFUOJ13KtDWuiAAEoXqRSemwARKqsy47I bnoAAZ6yNTH+oAUVj3XY0W+oAQZ339ROY9QAFNb/AOpV5jTYAKE4jQS3ACIevQrXruABReJ1 3FeOOoAURWdDW/26gBIejJb6lL0AAkVXci24AVTpHP0Kts/qAEVDn+4SkACFTdx9pT303AAe iVx5Sv1Ncm/qAFSIU8tf1C/HoAEVEqNh4+SnhqgAFdGSJ036mNH7npoAGkGRL9B05f8AgAEo m8N66D06/oAAgbrxZFO6/QAC1d55St41QqcktNawAAhV022Mb8df6gARri2H10AABx02D2gA EZY5e3eBV+5AAX1XXfX9DSVpIAFS+XJR+hTenuAAM1KjqN76bdQAI1pOnHcd+XHXeQAoxTfJ xuNev6AAQl/UpzrIACMFMjr6bgBBr/br2MP7faAFBrC5DwRNpACCsUqupVnp6dAAL6Jxdf6l U20ACjLPPOvL1KtOncAIDWXG8i1/qAER/9k /9j/4AAQSkZJRgABAgAAZABkAAD/7ACFRHVja3kAAQAEAAAACgADAHAAAAA2ACAAIAAgACAA IAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAA IAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgAAD/7gAOQWRv YmUAZMAAAAAB/9sAhAAUEBAZEhknFxcnMiYfJjIuJiYmJi4+NTU1NTU+REFBQUFBQURERERE REREREREREREREREREREREREREREREREARUZGSAcICYYGCY2JiAmNkQ2Kys2REREQjVCRERE RERERERERERERERERERERERERERERERERERERERERERERET/wAARCAKQBI8DASIAAhEBAxEB /8QAmwAAAwEBAQEBAAAAAAAAAAAAAAECAwQFBgcBAQEBAQEBAQAAAAAAAAAAAAABAgMEBQYQ AAICAQMDAwIFAgQFAwQCAwABEQIhMRIDQVEEYSITcZGBoTIUBUJSsZIjFfDB4WJy0fGCojND U5MkBjQWEQEBAQACAQQCAQMEAgMBAAAAARECEiExQVEDYRNxgSIykUIEFKGx8MFScv/aAAwD AQACEQMRAD8A9cy4q7WzUlKGemvPFgAFQAAAAwAAAAAAAYAAAAAAAAAMgAAAAAAoAACAAAAA AAAAAAAAAAAAAAAAAAAAGAAAAAhgAAAAAAAAAAAAAAAAAAAhgAgGIBiGIAAAAYgAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQwABDEAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAUAhgAgAAAAABAMAEAAAAAAIAAAAAAQDEAAAAMlfqKJ6kqxYA BUAAMAAAAAAAAYAAAAAAAMAAAAAAAAAAAAAAAACAAAAAACgABkCAYAIBgUAAAAAAAAAEAAAA ABF+RUWQLAzvy1opkXHzV5MLUaNQFWyto5GAAAAAAAAAAAAAAAAACAYgAAGAhgAAIYAIAGAg AYCAYAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEAxFAAwAQDAgQDAB AAAAABQAAAAAAAAAAAAAAAAAAAACGACAAAAAAEAxAAAAAIYAIAAAEMAEAABRPUZP9RKsWASE lQwAAAAAAGAAAAAAADAQwAAAAAAAAAAAAAAAAAAAAGAhgAAAAAAAAAAAAAAAABNr1rCbiQKA AACOXkXHXcyLyrpzjsc3PuV4VnnoyW4smt+DyPkcHP5fLato6ION3rbGguX3W3JTGpzvLZ+W s8snyfItvcvx+O1MoxbTt/6HXxV213PBznmt3xF8XkV3ujw2R5Xlvjuqo5uWu2+9v6HPzcu+ xrtksZ6+Y9BfyNU2rLHSDfj8ut5hYR4e1tucHocHKq8LUal487fVLx8O/h56807ehdbK2UeP W9uG006nf4d01tmWanLUsx1gAk09DoyYAAAAAQAABQAAAAAAAACIGAAUAATa21SAWvWn6nEh WytozzPIsuRJZ3J9SvEtet41k595rXXw7bc9aX22xjVmlbq6muUcXncLbV9V2L8fkiZ1/tNb 5xM8a7AACoBDABAMAEAAAAAFAAAQAABQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATa9aK bOAKAmltykaaYDAx5OdV0yNc9Hick2DURyfvluajQ6Kc1eT9LJsq5VgMDSEAAnOgAAA3GWAA KtlbKyErQBgYryabobNFyVejJsFAJNPQZQCGACAYgAAE2llgAE0urqalAACtZVUs8+/mtX2r Qlsnqua9ADG3k10rlmtbKylFQwErK2jmBgIBiAG1XUnWyhnl38q1st4O7g5VaF1Od5Tcbkua 6shkTsq6jVk1J0YGewfgZ25q1cPqXW6bhED/AAYShjKJldxz6jCAFIwhBtQAAbUG0AkJCPUI fcgchIofcIYDAWfQM9gGMmH2D8AKAn7j+4DAUhJQwFPqY38qlHDeQNwJrZWUpjAnkttq2TXl qqq1mLyOTZU8n5VnX7GOXLq1xmvZs5q3Uy4fId3tjK1Zzfu06pTBlw8q47bpakzefos4vUvd Uyzlv5qSws+pzeT5Du8WwcsUt+pwTl9nnOKzj8vTr5yb2tZ+p1pp5R4d1tirco7v3H7ZKuqH Hnf9yXj8NvL8pcKhP3M8q/lXuov069SvJ8q/Lh7Ujm5MLoZ589ucTjx+XreFz0VffbL7nemn lHzVJtmrPX8fyWuNK1covDn/ALacp7nz7vk9uDPlq29zcG1/IrdRZRJi+VRttntJq2fPik0v GsnaTTyLq0Rg51dVekyaPZasxDMy+Mazzrk3Q4eY0LfNKhamdqxbBShnLcbxorPZGpjaibk0 3PoJ1byNMY23JzJfFW0w0TerUdDThvallbUqK8lutYT+pfgctq26tE8vLblc7VBr4qhO13D7 G55vhj0nl305ldNroc3i+Q23VrV4F4llWX/Sznt7eVbHKk3eXjfyknnHrgTW6a1yOUdGDAJC UUAClDkAAJCQADOnNW7aWqJ5Of43pJNMbHPa0ciScIjl8tOk1lM4OW92008/QxecanGvZTT0 GeNw8l65s2dlfKiFohOcq3jXaTe6opZx28uzt7dBc/KnDb6aF7ROtR5F+qymZU5NvuS9yE7p 1hkzGEzjeXnXSTxg5vJvy4bwbeP5T3JWgxuoUke1JMna7tXrPR0c3PydHiTTg8x2fuOLelly aVhOaove6nWPQ/eU37Oj6nSrJ4TPHs1O5LU7vDdbKVqdOPO24xeOR1mXLyrjj1HeVoYXpa1p bwbtxJErna5ImV3Nb1luyeIMlt48tYJtzRlaGN+WsnsunJdNJS11Ojjtuk5Pno8pmlbVUW09 BOVLI6XZLUXyVbhOX6FT1OS9fJ5LxS+2hu3GZJXVuQ8rVQYcnFyS0nNXoPg8dcNXLbdu7M9t XrGwSJVhQG1G2TkJM+V7Kyjn/cN2caJdSW4Y67WSUk05FdJrqcXkctomuj1I8bnw6xnpBnv5 Xq9MDLiq9uWWlOjN6igJhiz0iQiwMVez/DVSC5p9MwNi42bjJC5FerdXJz+Tz7Vs7nBVbLYe e2TN5yXFnHXoePXlXuu8djq1yjy+fl5HaJhGnFytZtaJMznJ4Xrb5dH7h1tttX8Tbeonoefz 82+0qIXZkrltftGhe/k6um/kNuONpo2+WH7lBw8la0e6n4lX55iNTPderu+Svcx8rKhHMuNP 3dSpvd+7KL22HXKV7QlWk+o6+Q6OPyKrhtdDHk4/cmZ2rgtVrkmy9rHdVrfSEw5L5z+Rm1ay hzBmrIye6XCwaVuqxGpo17ZWpg5tlrPoZ9FexS6tVWkwfl1bdOvQ462s67W8BVbTd+32jM4f LV+RdWU9gpz2UKdDLkU6mDduK27VdDl+zlb6t9ZHqPypUpZOXl8i1zlrzXu8JQWrwy9+XJOs i+Pn+O6l49DTy+dbsNpNHn2ndEhya51NdrmJjfP9JVLNN5hkVruScjr7pUkVtw896WydL8h0 qv7mcWzbg2VtmbZUG5ysS8Y9CvImlLUk8/J8dZ6nnU5M7k8ydXLzLkrKcM6d/Dn1acPkLkWc Mzfkxuq3DWhz05dia6dyeX3pTqZvOtdXb4/OuSktzBy+T5G/C0RPHVrKZg290poXlcJx8uvx eZpbUd6cni1tte6cnbx+U0paNceXyl4q83kSrGh5Sadpeh1eXzLmfojmbSq8nPldrUmQ97Wj g7+Hyq14/dEo83fXTUcYXZiWxbNdniclnyY6npTmDxKcq4/qdfF5LvdSb48vHlm8Xda6q0n1 G7JHmct45GpLtz+1ZL3Tq4nS1nGCuPk5OJ/qg5OPntb3W09Dbar5yk/xOLTtXkWtqzanO9Dz Kvbhs1lapjbq+Hba+UtTWl2r5/I4vmrZKcHRwWq3LeheyY9IZjXnVrbUaXuqrLPRLrkx5eZ1 wibeTELH1MXZ2mreDnbVcHPlz+G5xdy8mFOsC5fKTqnVnEubp0M+WzahNGe9XrHqcflK2uDm 5vOacVg4Ku6edAu6vDZO99F6x6XF5TdXOpvweSuTHU8hWhYLrK90wiTnYXjHtcnIuNSzC3mc a01PP+bcos5HVrk1WEW/d+Gerfm/kbJxSuBvz3tiPccy2p5J5Kw5Q/ZV6RdfJ5q3Tu5R6XD5 NeXGjPDW6Tbjs09056FnO75Osx6Hk+Y+K0VUkr+RrGVn0PN5HezlkqNVlmuX2Z6Mzj8vQr5l 7ppasvg8t09vL9zzJf4h8jev3OP7K31j0OT+Re51rp0OK02ctw33M9tWzWEl7jXL7bScGnB5 FuL1R03/AJCf0fmcD0klqFMk486Xi2t5F7yuhnu25yZK0PuVuhx3M8rb6tRaunmWW7YXUxWW 0UrQ8mVbXuv6ScvXUzWdR15EstmNot2dXki/NLwZXtLlBWtoNMlyc9np/gRbks4mIZo4Woob wlg1KDhu6taNHS7dZM68NlmDZ1kzebWHLiHoRW0dMFUsphyabUO64y+RuEsFz2wV8anOo3Vd SXnKYytVPPUl2WhdniDHNu2DpPQbVbegnZios5KbjUgyvDwy6JRE5B6yvzDbkaK3JvbIWUPb 0ElGRPOjLOWJjRXrRQtR25Eo26k7cCS7DsY6/H5dtnucI61zVa3J4PIuorLKpy2qok3x+zGb xeivLpa21aG++jUzj6nib2p9TG/NFWkX9uXzNZvGez03/JVV3WJS0MrfySVljHVHmUx7h4u8 ZZi/ZyXrHt187ibyml3MOfzvdHHp1POrZKe/dlV4r8j/ANJN9x+2+h1aXta7lv7C3X24blGD veloaG+bPvM21pnbmt6ruL5FtlubdA5lXb7cJ9zBq6U/0ga0tusp0PVVlZxVJruzyuLiaXuT S1nuejSy46qGXcV2cl4UKEcdarValWta6ywpa1f+Zby1JMK1W1IlU0hRoTKSyiNFCZljK6j3 Qk+hNORS5wS0PiSsotk0rdTt6nOuVVwlr1NKylMZ9DKtYK426J2TiTLe0oDcupqeErur5O3V SujL5OamxtarocPyT7XoU7cdcVy30Os5Vjqx5OV8sTMCdGntTOi9YWUYvknBys+VxFpriMhX ktMrP1HkHhZJ6Ljfh8nk3yn+HQ76+XTS3tZ5HG4chyN7pR0nOz8sXjK9bl5KcVXfLfTJb5ON xW8Trk4eCz56urx2I8nl3+1v3LGDfeeaWXI9W/JWn6nBFvIpVJt4Z4yT6y2Cbf0M3757ROj2 r3rajtqjgX693Rir5c12NYM3Zk5/bMi8eLp5VV1ffpk5uO9eOyE8MmYyjn+7y318PW+RUpv6 GXF5NLWamDjfkXag5kmrT3O37Zf8XPo9u/LVLXXQx4eZ2t78PQ4ac9q6PCxkXzXSaUIt+w6O 63L78a6Gfkc60zKOFWl7nMjvZrKMfsrXVrtbq7JufUEm7Kzh4DivCi2SnFXKZVxny3V7SSuS 1lt7BZx0lmF3ZOdDny5Z5ouyhT3LqtIcHNS1phqTSl3bDxBOPLVdHK1ZKF9RJbFKyRa6Q+Wv tmS2jbj5E/c2X8irXdOWeXSat/29jR33RSuZJ38Iv91dPtAfL8t5YuWi40oWpCt26GLys9Rt a2zpKI+fZG2SPks9TSqXG5nD7m+yrpy4eHklc61pqCe7KOe7e+EicuWxHS+dNxd6mV2uN7at v0Mbt7cfcSjbuszkav5WlKNFRQr2y2c6srYSOmnBWuW8FyrGquksVIm39WOxdLdYDkdeuhuT KqLNvMmC5IsdPHVR6BFVks5JiKXd056dCFaHKwapNZTE1KzkvYxvS9nWbQaNzXHXocqqm022 mjp5Kwk5wdNE0q2xqVKt+BnriYNYhZyIgrafakyLWeZenQdHFs4gVqp2y9SiK+RZPOnYzh2t I+WjbxoVWWlXT1AVJs4NlWFtbhE7Epz7ukBerrDtq+hYiOZWtaF0WpFqO1MF8lI9PQVW61aa IrlVGtHg047JVh6Er26huVnBnUVZbvoacMcZm1AR16k1W/L7n3Zms6iVnOTSreWIrnXEqqEn BVKWiEYW5lZTtZD5m8Vx3KyrkSnLkKNtxWS6qt0pwU4birhlD22aiYRol7Y3ORXs0lGTPc3n QyOjh5LUeuhs+a1nPQ41dmytiTXbPBi971kjd1YL1BukaGVTZKTdJbYMaxEqTR2wBly8qr7W jNJWLtSnJ+qZHTiVHKkbMQ9sZGpv7a6jtdP3PAm0lNdTIFCxbUtc1eNQngx5LTSMpmaq+6aL k90dP7msw4JfK/0tYMltWWbWva1O8D0VE7XJpxzfVnParsv+ptTl2rYlkK2fHMpHM18SzqdN btIz5O/UeoxspysGbtOppROc6Dskn2GA43gb5MZJpNXkq/uqRoVc+o7JPUjjTrjOS7p6JApP 26LBmknKsaKuM6mHJTOpYiv0OU5K4nveTK9ZrLkvxmm+pbPBGnIc7bthI35GqvDJUVylqZnh CotizgjktaITk0a3fUyVW/ajUDSbWTq4dtUo6mdOLaps8FNJKUYuXxFnhsrJuZFyNtRUz4rN i5G6tGOvldVx2mZUs042llvJm7pqEn+AOyr0z2FmmrtZayWsqfzOZ1Tc/kau8whZ8ErR2lxB lx8TpLeWZ2vkuvJu0NSWei601yN5RTUKCUannyEqqZZS1B4yx4cAKW8Ida9xYr+ItWqrqyUd fD4vLy13UrK7mN6bW8GfN5nw2fHVvauzHXl3JPuX0/lNKylQFOLc84QO5e/rEEtTXNyP+16G G9RFpk6bpJyjCa6dyTyI2qJqTxJpSO7iOwLa36m8Q4Vn2Ong8n4m3XOIyY8fGszj8QXH1Wnc zcWDnvXls3ET2MrJpJJY7mjhOG1AuR1Sirll3Ucd3PttGNDTjunRqSbU3p7tUc3CrJxGC+w9 K3NtW1xZmvGnZK1lr0ON7bPOH0k1pypaktV2w650Y6vuzCvOrKIybVqksvJJflWivDgzd4bT 0CyU+7BjzzVKy09DX8CubGmnY5N9Zz9i7cydezOXerOOhMTXWrVtX2qDfhtFYnU8/hvXed3E tuWsE9DV7krGbbblGlkolBsTg1LA6tNZ1BxGWU1tWEZ2qiYq1ZRCyFkugq1hdh2jQm0Zt7WK 2Stu76gsPAvgJVhE8kxPUbs04KxbAlRfiXa/Tr0Fy1i8PXqzTwuNO7raZWhnzVdeR9vUt8xU 7swU3EMl5yhusqWc8WK6yinaNdDNpRqUoaM2B709QaIdGtdCkoWNCYoba0LTcSQ3I09xueEU tBxuJTxATDNaHZbUKWU3OCVKKppdXqaytdJMlbIWu25T/A1LIzYbUanLy1sk40OjkvuWNTJ8 sRuMc/Pojm4efq1LLVm3uTiehd+Wiyl6GCanUx7I1bcp9wtfMPQiHqDtmCaaT5IcNguWHrkF WZjQztxqqTblSaiL5eV8jzqZLlU7eo67U8C+CcupfF9Rpv3PUd69xU4936sRoXPSDOwTWyWV IfI7t/4sn5EnCHe/UgU2qu4K7t0wXVrb7nA603L26ak1Bx8i49FEmlW1bdaXVmNE1l6Fy5ha F2xp0PlSU1mDHkfyKbNfQzVbbtsuBXpZtwjWVbXQ+WtUVXdZTUw4uFVqnZ57HTTlVlhaDLCB Sl6kWTWXktvfWU4MrcyiXhrr3HZa0qoTnCZooqotoc7b5Kp1C3K/0icka05N0pdDo479LfYw 4ltrgztyO14N9rB1Xa06oOS1HVdzns4aL3JvU1+xBZwkgjc0Dzk57K1nK0E5eRvZpuf8A5LO yh59TGlW9XgtKNP0i8yRfJyb6qNUZ2bSnqNbUOZ0J3Vy8l3b2xkS47Xw+h11qqy2hN49Cdvg xyXVumiNatxkvb1XUj4nOuDW6mJd8wUnZrHQ38fxHz8ipT7s9Ti4Vyt1VWq0Trup+lvvZv8A 5GuM92px14FU2/QlKitDZfkqlLQ8wYNcfJ1yasz1ctbV43dzRpJCvTdeZ0M60tV5tCRqubrb poZVrx275YuV7NUc1uf3dja9uO6izyME051pJ0VZzU46pydKuiVqL3QS20xJS5QOUyK143h7 nkhqcyNQ0ViumSCFOhrxt1kyhszvZp7e4zUrezV8WgwuksJjXC/1MqN6zg1iMnybsLJbmuug V4/j9RtVtOpDEbk/Qb5JjOB1okogm3ArNduw8GK5HX+lEV1lnW6JcK7T2OTbFp1LPKtqqNcI H6C+R2w9EHyLVIzipvIJxgORvEHq8H8MuWqva8Y0go82t5xp6mlp74NPJ8b4HtTk563c4Flh Kbtarw8FWs2tTOz3PAWYxTV3oxcsr3IilW3gu9G0PdEUsnmyk13pL2JGVeNV1KpWV6CzRN36 IUShOrq4ehTtWjmChOy6ovhtWYSgVkrVlBxcexy+hLfA0t2svsXV1WM5KfuIstrlKTG6qqz0 rHqZ2VnnazT5GtXJFuXM9DM34FVpWnvcyK/uUoi/I66r2me+tnK07GpL6oridU905Ld9znQ5 04tHRmtK7ctSzV8eRV6S5bkdYnCUm3j8a5eVVenU9WlPDvZ8bptsv6hxl5Q3HkN9WG5PM5I5 fZd1mVODXi4bcjSqpbNWZ4N0Ky0wylX1RHKrcTi2qOVclk8vBi3DXVZVfXP1OrwVurfRtdex 5tuWto7+h6P8dfbx8kuCbtjUeRyVcv3LXudHE8Qzge7kvOiXU34+TOde5b6sui2Poi43LP8A iYNxlmlHREvn0ReVrEfUi1U8LUzlWcmkIsmKXu/TGCP27TlMvdWii2pk7voXz7BurHWaYWUF FvWSI2POhdnpQ7V3Yev1MeXjbXquzHeLvDEnbRrARlVt5WH6mleOPdnJg+GtW+3qHC0qw5/A UVyUe6YbNONXeWoM6VSbss/UXJyNr2v6j8DrV9ubKWvQ6Fa1luyrdUefwbFV2eX0OvxqN/6l tSWQdbraylJx1M78XyVdcydPBzt0twptbnhLqX5HjcnBX5LJbe6cknj0V4i472UNOPU5+VOq 21TOtubNyzPnqmpqalmox8fhbejTO6tbJSmedSrvdo7KcTplv7Dlg6aVtZ5KVrpwljuZ8acz mGdFONsxvuuNFK1ItXBbiMamF+VpToy3l8KdpSMU7Jz0Id5bTOZ3VesPtJM1LXdW0uGHMmq4 OTju3icnTuTWS+iFxqy1Ltx/2uJBJGP/ACNerTu8OjXNLyoyV5ib5G1oc/g8a5eVVbhanT5q jkhaQM8DBNxoSp/TA3MEzmTEguGitdCbPGoRKwxiq1+qHqsE1U9ciVXXVmfEGiyvUhp9/qUr 9h2e7PUoVSbN2YOz6DVsSaFuy0FJNW9X0C7fQmYqbcqI3V5caMHdLXUnfmVgzWdLkx1x2FXh rypOzyRflc92VWzazhjPdlHLxVejwVWkrDlC5GodlbP0MruzrC6ms0G7tqiq8iiSaWdKQ2se hK5XZbUvxJeMRpu6hayeAWY6RrKH825xjHoZ8eyFtSfr0BO0tuS53OcKNSb8zrmcASrWThvB dbIXzNqai4+WXE5GaqV7Jxhg9ujlk/Jfdl4Rs2mtXktmIytD0kt2dVt6fQG7PHbQzsuRZTkZ KN1d1qkupi9+bKEuw+R2xaWoCvNW1VnIkzyNqptS9SPkcF1t2bItfemtGZ91NPErqPgt7HXL bFRRXUivI52qTXqOi00SrqjndvkwsGN+a+6GzTitHQZk1HRx19mX9jm5VaVaqYrc0Spw8F8d ttdqLnnarZcloSZXBx5dmc/Epc36G75FVF8RqOitW3kdqNPODm4eS3I4eJOryPJra+yjbSUE p4CyoQohBRmleK/K4op+gzVZbRKkfp0Ot+DzJS6nM5rK6l60RtybcPDfle3jU+hjW22Wzu/j rp8j29heP+iyObm47cL23TTMpwd/l3p8080uv/acNmnZuk7ekiTwpq2IQm0JqVn7mdbFxHW+ RV8dpUltxvnT8DNct612Kzh+pXJz/Jxqm2GtLL/mYWmUat9mryz/AB8Onl8TxuV7rK0/Uzr4 Pj103r8ZPWXn+C82o19asa87wHoo/wDKrOlnP4c5y4PKt4Pj31tYlfx3B1vf8j1l5fgPVL7W RlzfyP8AH8ThUtb/AMZHXn8G8Pl57/jvGTlWt9jS3h+Pde5v7HR/uX8a/wCjkX4M34vJ/jOZ e2zX1wSzl8L/AG/LzKeFxU0u4/8AEr9pTpf8j11T+Palcj+4/g8F6csf/JGfPwv9ryXwpaW/ In4esntLwPGs4ry5+qLf8Ov6b/dEy/C+Hh/H6on4uuDp5qviu6PoRMjLPZPF92XxvuiP286v J1Q+wDyuT5c64rV0iC1xtawbJMIY/oZPlzPitbqoBcLXY6cjSsyJ1jm+N+gvisdTlai3MmLk VxWquFUsk3OhzcvGrWTrWK9kdG5hvjp+RuXJmJn5ct+PfmtdpNOKy1R2b/QN67GbdXq5VxWb /TJ7fj+Q60j4rQv+5HAr1WYNv3lf7Kl4pY5fL8hcto2tM5HVrNk0dVuOru+SInoVZUsofUvK y1Jx8OJUss1Qvjd3Nqs7kqJQNuvTUzq4568aSwmS6p9zR8lv7fzH8r/tf3Lgh8W7CTHyePal U4aQn5Fk8Ub/ABKpzO7adWvWSdfmjnSa9Sbq0Qkde63b8xTft+ZpHNamFhyO1a1crU15OXko 1FJ/Ej9zyNx8bGVTdpWkCVnbEQkdtVgNpzyLjhT2vKkyXJOqx6Hp7RbUayJjjit6tVwjLi45 lTlHobECpGhJ4Mc99qUYkh5r9DsdJ1j7C+Nen2M9fyuMPAl8yN/Or786l8CXFbdE/TBXkW+a 06L1ydZc41m8bsebb26PJv4fu5azk1+JdY+xpwVVLq2I+hlccHm1TvZeuDlWPaelz8NeW7l9 TkvxV48axoTn5tYnHwyVoxGD0v45b+DlSeTyrX6M9r+IX/8AWuzHnZ/LfH3/AIeDa1k2sBxP +oqyUtd2T7K41N1lvW8uDb41b6+hhxVbeNEd3BR8lq78U6vrBjzPQk1lw+LZOVL9EgfA8tJs +k4OTxfHrspyOP8Aj0ClvEruau/d+rLNycvW1cfIujmdAaarB9Rbx/49uW/zZouP+P0iv3Nb y/Bj5XjqoO2njV56bk0vQ9pcf8d0pU8/z+Ph4rVtwVUPDSsLLbtHg343RvsX/TiPxNr8vHW/ 6VHVSHk/DfjtbiW23aZJm1lzcvGnWOvQwsmq/Q2/cKK2+NN11nr+BHkci5fdVKqfSpqDCt7v FTWlce5qXqdVOGvFSVlsy+eqvZwp6SWgdUlu5MJaHVxciaTlNdjGqv5fKlaqXVJYR38nDDq2 lRLstTOGIpyUy3h6k8/LKinXXLML/q9q16BZX405UE8+wxdno1BNOR1foKtpfvWO5jzvbEPD GaN/lrlvAU5Pk/ToLjpW9ZNeLjbfsWgwa0V1nsdFeS1kFXFXCb7lcXByN4UJk/oppODDmiuW egv4zyLN7a6a+5HN5Xgcyao65ZM8jybq1nho53ZUcPp1O/yfC5fDuq8kaTqjB8Kv+qYN+nqy z8RO7dmdVU2TOzC0O7wvBfkVbq61dV1Y9arOtl+l6is1odXF/F8vNR8qtVJOMs1v/FvjttfJ Rlxph/HPbzI0/kpXIo6o6PH/AIvl4+Te3V1r1TI8/gte29NJJdWVXDW+YGss08bwn5H9dU10 k6rfxbo0vlo2/wAjODhf5BVNOOh3cf8AHJ8mx8lWtZR0P+LWdnJVwLKeHnNJZZFrQpR6tP4r 5VnlrPYpfwaeHyL7GJxvwrxK8kPQvc30Pa/2Cv8A+zH0/wCoV/gUteX/AOn/AKms/CPGaSW4 luEe2/4Sk55V9I/6mz/jdy2255otFCEl9yvnqbrKGU2exX+I4k4+ZQ/T/qXyfxPBxqXyNfYW W+w8D41XXUy5K2qprk9Pyv4vZNqcisp9J/xOK/C+OrTy+kMz1/DNcfHyWy7IqZUonddWdbpf gbRxUW7P/UvVGHyuN35F1pyNS8Fcfw7v9RNVfYJq3Fd0FyHgWo70lRg56UtuVpwjqVq1rttV /VMLWo0nWrj1Zj2Rm/JTcMxvyLdtDyNutcejCtMbur0E4yRDpdpPdrI21rb7BVuPchq/E9az ZdS55B7bLWBu3Ha219ugV47criq10k25P4/k4F8vInHXBeq45rvbjMg6PD/wNdjidUZ2yoTy Ch3UkbnZxUlvYu5VOPkeV+AyINt7TuwkFW6+1F/DfkU2aT7E8lHxJbFkbL4FLkazYmibs+zI s7queocVs56DB0UttynL6mbTrZ2blscbHuWEwVHb3dDIxqk8s1XNXbjoT+3ejJfH8aS1XU14 oHFukl8XCk9zcGqrRQ+oLyU/a0Z7X2GUqz2pyzT43MXRlW8cisklBvfkte25uTVUWulWHr3F wp2slWW2YNQ27P8AA9DwP5GniP2UTfdicfkdPH/HeTG50tk9D+P4ubhbb47PoZ3/AJXyOekU aVnjB6vjcXPx0Sd1p1T/APU3xmNo5LcrX/2rfkeTy/x3kWtvVHlnutc6/rX2Obk5fItXLSaf /HU0PI/2rybuNjOvwf47n4bt2rCO7g+VuVfX0Ol15f7/AMiWK8PzvB8i93s420zlr4PkxGx4 1Pc8l81c/J/9Jy1rezad3PXBmcYtrl4/4nyrVjal9WTf+J8irzVP6M9N8fJVR8jX2JfDa7Sd m8ZHWJrkp/HeTaqptUL1Jt/EeS7xtUa6np08baoV7fcLcOld9/uOsR4AAM+k+cQwAAQtqfQa ACfip2QPip2RYAZPx+Nx7UK9dlXsdqv0szYz5f0MYu14tubln9dvuH7jl/uY+WsOTM52eXaX w0Xkcq6lfu+T/hsxAnWLrf8Aecnd/cP3d+rt9zACdYdq6F5T/uv9xPyXquS5gJ6DrDs7OPns /wD8rX/lBT5OZ6cq/I4Uh7UTqvZ1vm51/wDlQnzeR/8AsX5HLEAXqdnWvL8in9aLr5nlPKaZ whA6w7O+3meX1hfgZrzvKrrH2OQN1p1ZOp2d3+5eUspL7Df8p5XXb9jjXLdaWf3D5b/3MdTs 6v8AdPJ/7R/7p5H/AGnHub6iTaL1h2d3+7c61VQ/3bm7VORc1l2f1QfN/wBtfsTqdnX/ALty 9VUP945O1fscvyrXbX7E/In0r9h1i9q7f92v/amC/l7J/oRyfKuta/YS5Kf2IdJ8Hauv/d7P XjX3D/eOT+xfc4rWq/01j8ZHW1VrVP8AEdJ8Hau3/eb/AP619w/3i60419zj3cc5o4/8gb4X 0svxHSfB2vy7F/M3X9C+/wD0D/er/wBiOL/S9QXw9rE6z4O1d/8AvVoj4/zGv5rvRr6Hn/6X a35B/o/935DpPhe1ej/vS60Yv95X9jPPT4eqt+Q/9F/3L7DpPg7X5dz/AJhP+llL+Xq8bWed HD3t9kVxfEnrb7EvCfCzlXqU/kK3XtTK/eRMr8zhXDxvKb/IdlxuKuThfw3tddPKalRroRe+ 7PU5t/GnC3F1vRdX9jnZV0vVHtfxNI4eRp6nk7k8y4+h7H8TD4Lusmbuz+WuPv8Aw+e5b7W2 lgPk9mkMvmrx5e60t9h2pRqE7fY6Ywz4eZ53NnocXlrjrnCOWnDxLo2kTa/G21FvyGbTcdv+ 6cX9zD/deLu/seZSnG5lWhepFnxdFb8Wd+nFnvXr/wC5cX935Ff7hxPSy+x4k16o6OJ8UJbb STlwk84s516n7/iWtkZ8nn8LUbl9jjtXja27dPU52+NONj/zE48eNLyrfkcw6xtZz7sutXB0 Lkqlmk/iZK9Kt+z8ZZzzBFuP2w2vqLih+22Uspm1r1tT9Kj8TD9xWr2qiX4ss8q3lQ7rVmCr L3Nmz51sSSr9jFeU6421+xZPdNa0/kL8fImsxhI635NuWN9vpHQ5Pku1viq+lRcXkclnOPwS F/C66LPY899TWU0m3P4aGa5OT+p6k8fNyNtNwcwcnErOTi5eO1ntrU9Ddu1Zzc3HvcVee5eN 8h8HByUrDq0acXDyUy8fiZVryViuPqaKk/qf4FuDso9sOY/FHseF4/Heu5tu3VdD5/hardWt oj2q/wAr+1soTfHZYyiYuvZXHSihWusaL/2PnP5RbLNp2/E7fN/macvElVZ6nJzc/FyUVWpc Y6fcuwcPk8fDZVsruYyc1drUNt/gaclHXVpz2OSvFZttvBEb2a0ehvxcu2u2kpP1PP5bp2VY mDp47NXrjHYEfQ+Fw8PxNu1l/gcStW93XdKnuHJ5y4aWpx/1arsYeKtu29ohla93pV468d9s uf6WLyfHvpa25+pnTyPm5l0qnhHX5tXZpLBRy8Ph0V4tr6GflqtH7fwNrtcdVazc/YwvZJTG mcgaeJwrksp1+x2W8Osu0rb+JyeN5NuSYrmIOrl34TcJrRBTrwUlbVXanrH/AFOz9tRKUk/v /wCpw8fKlKs8x1PQ4uZW40/wCFw8VWv6fz/9TX9ul/TT7M56cvG7bV0Ojj5N9HtctALl4Kqv 6KfYmnHRrbs45RpyN2SqtYPNfDajrajysMDs2rT46RMaf9B83EnT9FCrckNGr6wtQPKpXj4W 7WqnXR+htW6aiqSj0KxS7V00rd+5N6/Gn1rE4A+a8njsr3tfRPBnuXbd2N/Krvs3VOJxJqvF pXjVm2m+hExz8fHXmlWVp9FEG68PbZVdnLXUT59rVVhLsaOqst/Ipx7RhjndKLDcmbrSNsmP N5bbnbDMOG9rWz+Znqy7bqurcr6GLvVvbWyntDMOS7mNTq8fw3zWaTVLJT7upesBb+2zX0yN fHikr0wyZiyX5mvkcLdc1e5dTOQCmjVlZODpt53Pejp8k1eso5uLhrbgd3fbyVeaM5XyOrxo y+YOx8j2fFuW3XQ4rKs/rn8GVTl3Wz+kV3L9qUehZ+RdVxbZbnPZml3FVteDlsnOdX0GuNrG YJZKjfkhpRhl092Z/IwWcLUN7S2szg1v8airs5foS1xVeXn6E1vthNC2723bHqWKr/RSnc3+ AcduNYTf2JfHxpYbky3OttC+KjrtZV/Vuf0Q4ovc5f2MePnbl2UIVuSt7e3T6mP6DS16zlNm HJbi5bKVZP8AALWU50FZ7npg3PHsNqrj/S5hepomoxMHNshx37l1vChKW8fQvqrR+NveONv1 3HX/ABviV5uRLbCX6txxPm8rxl8dHC1wsnT43zvmq+S2H/UbkivqvF8SnHazrE/Q67KyzP5H z/l/zN/EdeJWVsZaOin8tbl4XhJ6SRdeq92m78jHn4ntlPB43D/IcnHavE7b561ye3LfHLcs LHP47cTuyjq4bfJWdzn8DzuHlSu69PUvhuuLmaWjKOy+1wpZwuq+WG2+h12hWTWj1OLn5tnL uSwmBr5lFWMv7k8ddqUzLI5OR87TiFJpo85gDorWtFL1+pFaVzaDnVt1k7Jx+R0Ll9ugHhjE B73zgMQygQCMHa0r3Ixy5Tj6tceN5ens6QEBpk+xnyuKM0Mub9DKPMtXcjmg6uoKqMV0jmCG dOClBF1yQwg6kCSGGuWBqrbg6R11GGua6hwSdXVjWgNcgQzrDoDXJAHXiBQMNchfHWW2+iN2 i1VQ4XQYmuIZvSqa0NIQXXJDCDrAuGuSBHZgULsTDXIXWk0dux0bVGgcijj9JLia5AOnZWNB 7K9iLrlEdT469g2V7A1ygde1dgdavoDXIVam2qfc6Pjr2FyrNUDXKB0ba9h7V2C6l+LdcfzP 9Jgd1vN5K0+LDp2gw217Em+62z2YpS4N/hVUmtSqcaTk3doiVg5c+Vno3xmpT2qVkhp8jlPP Yu2HPQytyUTSPNXQrV2tu35Fcc6yS1bkcKfUqqaeuEBuljB7X8Xbb495/I8SVU93+Jafj3bO d8Wfy6cPf+HzuyW41k0VnpE9yORNcjjQz3xadF3N3yw1tLlIzfG1k2rnC0J0tiZEuILVVa/8 zkZ28ldy2kcnCtsJnb6+WevrWOUc9ErJrqKky5bSRpTjSeTS1cN4UnXlcucvSszz6Iryvjec ruaTx8y/9DL9vjVE0Vq2hfZHDlMu8a6Tz6ta8DonFtegq2r+m2YNLJX0T3I5q8b3ZM7vr6rI 15VvuqrQxvwWdlWIg2hVanRDvywmJcGXJZt7arTsbU4FxqW5ZzcfI1Y3tNtdGLobq+R5UJFp cczxqCaO3TRFrrCgefQK91SItqFOXfZpL8TG/Duzoh0s1KUNDr8Gt2oUyTXkW1pLJl8u+jUa GNeRpszOKunjbalFfEm91jnStVprRl35VqpNZRvule14ErS9rMeJws9TaI1eTFgLcjrgXyuq xmSbUnR5J5GklVFkRpeyansYvke36j2t1lDlKsP7CCFWqy9UacfNDeNTG0OraUsleRetdsGs HSp57KtXMnXyWrxJVj3I4+PSV7R2tP6dehfT+R6PibVZWbzOh6/lPMnheJZ25Kq3Rnu+Uoqi 8c1fZxWpW0TmCbcNbuWaRImdrJ8MzaVKbJVXqJ1eqeSpJbgzcamlSkNTDU5k9Th8ikOmFnB5 lbS4Kkzkayu/O7dCjRHRWu2r1k8be08HQvJ5Yh2wTN9Fvh6bs0k2ZtVtbdozj/eNYspK4vJr DrfRkyjp5rW41Dyp6dDFeTejb7dPQ6OLyKRFmmu5nzeMs2TwyI6FdeRx41OFc16crolKiMj4 uR8L2J/qXtZl5e7junrOsAc3l8UVWf8Aoct7tLZb7nR5Cdq20nWTzlzYaeSjfjv8TdmprBy2 8+8ylhaHO7Oybc50Rz2V52MjNrbn5vltuerM+TdiTpp49auWlPY1fHVrKUme0lRw8d2tcydn P5HI3Ns2jX0MLcTq/blPUv5FGkFovwn8/Kq30WcH0VfF5Oatq8WKvq9fwPlabKWTtPqk4Pcp yVttVL/HH6U3MFajhXFXxt9eSfkTx1+5VeWj44hfU6Ofwrc3JNuRbolvuee+Rcb2pboM1Krb vwjN8dsquhnyeRfdisKDThu0jNljJUplW0+ocm6W0i3yS0l+Jz8lrNtJibQq3atDwx8mOsyZ OtpmzbNtlrKHBpTpdUWcma5Nz92hTpCS257l14nb22wu48CKrd+nDLVFWytfQm3C6+5ZRpVN VlZFG/yVak5+X40065ZFU7MadbN1aiepiccA6u9cyFK30iEL38eWmKvO+xoO1d72zg2o1xaZ CllbRQyLVtu7E32Hpfv0qS6J8n93ocrvbastJuYM627z9Dsr8fKlyNOVhroXzRhSla1d71Vp GrXjrHSDm5eZ2t6LQ9X+OafuvDS0rIyq83xrc6u3RNWqe1/G8/Jfkb5bva11YvNT5k+SidWv U4uLks1LypNaPU5OO297cuMGa5H8i3TnDJ/cWs9t8bcovk9/Irp4sVt2cVq2dqJ6HP5zUKOo nyPibes9Tl53Pu/IDu42v0rDgXJyVV9tXJzePyq1XnOgqcipea/dlHoUTqt18vojecQ9Y0PP fK7LUFzR1ywOIYL1A975pDEMAMf2vGrb0vcbIAGAmMAM+bNGaGfL+llHmoQwMV0C1ASGgAaE CYDHXUlFVCIeLMYWxZoOgDkOgdAnAB0AOggAtdfoSUuv0Ay49DTqZ8ehfUKOoAhdQhoBIaAO guT/AO3+IdCr/wD239QJ6AwTwgeQBg3kGD1AHqEh1EA+hPKv0sc4FzP9IUgEIildblCHDWo5 NGlGNTPLlmLJp1ttrJF7WcRoOlsQyk5e1Hm5+OTtx8xh8lrPaReqWhvZ1yjNcU6NZ0MNHxXa q5NKXlS4J5K7auIOer3akzR2Oyb+h738Pdft7pHy9va85Po/4is+LdrBjnMz+XTh7/w8fls9 zfSehGytrbrZJmzu6r/Az5uS1fazWMVfzJ2xhLsXx2cswpSqUte710M3ZzMmsR6ScKXqZVW+ 0vQ5lzNqNDdcntwOM6+Uvkra4KSbzr6ENyXVNpx0PVym8XGXKSs9zUfQGt07cNC+SH2M7q1X u1PL6O7WlWvdMP1B1SUuW2RxWbWcF8j2659S2e8Rz8e9XbqV8jyv+Rp8yWEzn47TaLPDE8rR WrlM6Eq3jdMkU+TKqvxZXx22w3L9TfLM8JFcnK64TIXJa+MwjK8TC1L+VxCMTwuNeFTMtJk1 rSssVUlXcy68rutr0HgJbdjdfscacWzodtrqqiIRC4d7xgaKSql7TKziynQ3fFWi1Ct2tfwJ 2VSomtHBNkm9vQ1tZLV5g41Z2bj9RnyOjj4tnWal/HSGyKT+q2GRvSbTymWVDbVVFXJzyrXS NbU3aPJFOC1k7V1LBtalbYTwY2ru/wBOrbciXGq1lv8AA2pxqid86F9AUbqmrKUa14bcllmI MOJu016m9n8a+pn3HbXk46xRZcrKPX8n9KPB4orDf5nuedy7OFXfobl8rPRzDOSvmKzjA7c8 PBu84s4uh17E2Zg/Isv05D5n2yYvKezUl92i1HPYwtyuZKrysy1rdIJg53z7R/NvNama6E4y LcYPkhZJfOloNax1q0lqzro4OJeQlkm3mJaG5y+WLx+HdLWjjqa8vNbkjCnuePb+RdcJIlfy ndHTrK5drHoeRW1qzx/qjoeZzcV050wa/wC6eiH/ALmuqRm/XDu5owkRsTtnJ0fv+NuXxoxf k8LzVNGemLOUa3qjLmSqks7jZ8iovk1+hPHdctrc9qzGiOWLgVHSqyp7GHJWtsJyzLm5ne7s 1DekF8PC7J73DegzEZ3WxrqaeNx3tbdVT0HxePbkttbUf3G3Gvh5Pb07DQ+BOnPt5auyS/Sy efjVbfJxyq9n0Nrbvk+R5aMvL5b8uUlUzu+hpV5t2WU/cvacO2yq2a8NGlN59BZ7jXC92rRk 6Wv6FWtWuEJ+ZauIQ8+yLfHC1Karthai4vI+RRZGPLdK81M+bcouHTGZC25V7GPzXq13NFa1 r+5bjeK24uO+33RHYuJUV6Cu1ETC6C3OyiTFto0Vmqz+Rm8y4j1Jokv1PIuTyE4Q/gFrXS9+ ZJ+RRlZRd3OJyRxrkWmjNTMGb5d+Uog6KcbtXfuX0I5ay8pJ+mDXx+Clv1X2+qL4ETfOJSOy t6cXErppufdVanoeF/H8dItyXmr6LqPz/G8bkalOiejqtSxcY8vhePy+N8/Eo5NYNOD+P8fm hp7b9pN/B4K8SduO26q6WydHJ4T5UufgaU90VWnD41eKdyTRk/G4auIhPsFuJxG5z2Whk+K+ qt+DHhpPkeIknevuS1OBczTirlL9Mnp057Nut5T9OpweXxult6UJ64AfP5Hy8a9NUYO0rdrJ k01bboXvo0l2JRrwxWsvV5Lrb3txnoZ2nji1l9CFdpy8MnYdlrK8JxBldrekoics5Hff/wBT t8P+P+fh5Oa7cUq7V+qQl30TWY5EM+k+cQxDAEB6n8X4fF5Cb5FLXqej/tXjf2/mzlftkuY7 T6rZuvmhno/yXh8fjx8eJPOOkuzflysy4DPkymjQOpSea4F4fL2D9ly9j29sKbOOwKp5v2X5 eno8T9ny9hrw+Tse3CegmoHf8nT8PG/Z3D9lyHs2haPIPbVTZwO9+Tp+Hjfs+TsH7Tkrk9hJ vTQL0wO/5On4eK/F5LWdksB+05I0PR4eWHscHSq2eildy3nZfVJw8PF/a8kaCfjci6Ht7bdE JesJk735Xp+Hift7xoP9rydj22rNTVSNVfVQP2X5P1/h4n7Xk7D+C9Znqj2WktWkY+Qmq7iz nbfVLwyejyKeJyJaF/teTsetx33VmIK93bJO/wCV6fh437bkT0F+35Fqj3Ev7oQ2uzkfs/J+ v8PCXBfsNeNydj2lWz0WPqW+N9ifs/J+v8PB+DkS0FbitsdYcnvbX2Meajo1ayLPs/JfreOu C8aD/b3PcVdywpH8TJ+38r+r8Pn3w3fRg+G76M95UzGgfE4l4Rf2flP1/h4L4rzoxbLdnJ79 uJroL4vuP2H63gulo0I5atqveT33xvojL4nW/oWfYn6/Lw2mE9j6L9s2iX4zXRE/Yv63z7Lq 4eUe3bx2loY83jWSlLJOXPZ7LOGPMdOtTGtmoTyj3PC8JWVuTlX/AMSfL/jqPjXNxqPTocdt mN9ceM2qN9R78TEIObxb74qtSv2vI1N8JYM+GsZXu7KenUx5LUf6U0zrtwtvalI14PIlhShs iY5acFrZeEj6D+Js7eNyLQ8/9lycilpqq7M9rweLb49qxD9Dnz5bn8uvCev8PA37W0u5jycb 5JlwzoXh8lrvEw9CeXxua0+1wblns55XA+K1NcE7q6HU/E57Y2t92VT+N5W8rCN9p71MrKid Xuul9C3e1njKOvj8Rpe5Ntanfw+BGiw+4ll8nWvH9DXjiLT2PXfiNdETyeG65Syd/wBkc/1v EmqiFL7svft1/I9Tk8W16p0WepzLwL2cX/I89vGus41hZrbKg5t2+v0PV5v4vbRbHK6nOv4/ kWa4RmWReteXb22UZG6xaXoenx/x9uTG2GupPN/E3U2nPY12idajhvK1x6ivLaX2NODwrNKr UPuacvgctV7VLfUnaeida4Nu5yyXyKfbqdl/4/liKrJVP4e15dnk124nXk4OS1uRbY0FxcfJ bFVg7uT+L5KVmrkqnjcqTJeU9l61guK9VF2J8mxRXXqb18bk15JF+xtLw5M7PcyuZ3lZHXlq +mQ/Z8t5dVoH7LlVU1VmvBlLyUlDWGZVq7WU49Tu5PDtC3diuPxndbWsonaYmVkm1jXsY3s5 aWZ6nQvHunDRFfF5KttrBNhlTWkp7nEEJLe4awjd8HLdzWYRPJ/HuyV/ubnPjPVOtJWVmpiD RZq1h9jntwN3VI9p18fC6r26E7SHWpTVVFsMvg8Pn8tt8dHZVeYMf2/JyXmIR9L/AAaXHx2d sZMzN/LWPL8jwueiU0tqswel51Hbg2pS8Hq35FtspzHRnnX/AJDl4/6Uzvbvq43tw8cJseFb xW3NqWX4MutVVeh6XL/J8t65qofY86NJUHH7PE8V0+u8rveZ8JXG65QQ1G41XHOMitS2jWDl OWuyHGUtQqxPjtG9KSq0fI+zjMG9WE0gb6Benx5ZSrPugaIhsl1cm6pORqlnoOy45Y7EXS6L J1vjsyPgsblSx51qO3Qn432PQ+OzG+Jpxk693G8ded8b7B8b7HofBbomR8V29qwy906PPpxv Lgb4kmnbCO/4HTDyb8fFW19tloupLy0nF5fwXb2p+02tXkrxutXC9Op6Hk8LrG1PPQ5eTjtS LPRnK2r5cexOFasM6liuy7wTfkz3HalrJWjDMW2om3ItvtY1ecrP0BcSmbHs/wAbwxniS3a5 0gmEjx1Z26k81b2qrU0rqdXl8L8bf8izZzV10Lp4L5+JbbRd6KP+ZrFx4rTtPcKXvbTsdnP4 3Jxci345GsqCVv46W4duvU2Yxot1JfQydfdqdVKVblTHXA7eGnnRGdkGbS/TRfic7q1bJ2U4 Xu2o6KUawlLM9sR5tOF3tB08fA6PDN/du2xDMOXfRtbXL0Ha3weRycjqtupirTl9NC7cfJaN yjsR8N/0wzUmLh3b3KXKJtLz0Zu/E5OOG6t1YX4LJ7moXQuxcZrjty/qcQaWv8UVTlwbLibr 7c9/QHxOrU9DFvz6JhZdVOocatxuKOPUV+K9lKTL+CyqnaVKxHckMp8fIrX22s9vU92/lcFv EfFDlHy9eV8d4eH9Dpva3Iu2P6TpvjyNePzVxp1rb2vv0Z6/8N5HHLVuVSv6WfMLxedYrVw3 9zpt4/k0qtyhLQuyHl97Ct2aE+KsaHyH8Y/LndxX/wDi+p71ac6srS5fToXw06PI8elq4weT 5drKnx3zV6NHr8/Larx+J5/krj5axb2/iZHiN2blv3LEsqtIUvUnmpttFv8A3N+GkqXBzt1W W5zJN3K1NXx2rbOhhdWstNDKispqq6n2lPHVPEfElrRr7o+KpS9WrPEQfZ/u18G9f2nfhP7f 6se7574L9iv29judhTkv/Z5H/X4uL9tboNeNbqd0oSuT/s8j/r8XR/Fr4Nys8M9P5qdzxN6K Vjnft87XWfXJMjT+V/1WlXJwLxm0dW8E+qZv/scsnGezH6OO233cy8WBfto/A7NyZLsjN+/k s+njEqnYFxtvVhuheg1eDn+yunSJdGuoLjaRfWSXdDvTpDXD3ci+FN+7Je7GSfk6k706wfFj GA+PHqNcjbErw4HenWMaeKlfcjd09WRuzBe5i87aTjIhVdSvj0s9Q3g74HenWKtSdMCdIwTk reTvV6wOmMitx1uoegbpD6F706wV4q0WNClRaE7wTJ2p1hqqcplLjUQifUTsidquRW1L9Inl ikIGmKtVMztxJ4tlDdiq2USTQ1jTAnnqKVINxgKTom/VFL3Ez2KWhdTDjDI2pDq2MaYSrEsc 16gmpFCmWNMXrkm0SJPONAY7UyG6ZE6yUoaJ+g7UyKrFMdxNJLb0DVifqO1MjN+PW2WW+Krr A6oehNMjL4KYjoXtUQxpEtdhq4apVKFoOq247h0yPoBOxJyO1a9EEAqvoDC+OszGoOqh4KzE E5TGmHWqWKpZG1gWQGmGkNxqLIOUNMNwRCbKjuEwQNQuhEJjazJSSaAzrVV0RTiw2uqE7QBD ok9Ckk8DnqDiBphxKJSSLldCFZtjQKqahoNtUNOROS6E6V6FQmsrItsYFO3JNAqV6ISpXRo0 Tkl4foXTELjTwD4qrMZLQNy4GpjP469UO3FWyho0eFLEsjTELirVD2KqwimiMdcIaYT8emvU deCkaD6QiqqcMaYS46t4KpbZKridSW0tNRvDyNMW7QoInoDa6CeH9S9jISWWK1K31RUCxJOx kVtTWkk7K6wFbZwP6ajTC+OvQmvFStpSyWnIpQ7GE+Otv1KQXHTKWjHugTcZHYw68dViJBcV ZwhbinaHJOxhLjqtRulXkN0v0J3dJL2AqKuiDZXWB7ugqvJe9Mi9lYgzrw1TmC1YE1XXqO9M hfFVi+KkzGe5atITLiB2pkG2rjCMrePx2mUXaFkdWO1MjH9pxOsQD8Li27YN1ZNhvGmRl+2p ClLBsoUVRNrC6DtTIfLxU5Vtuk0iuK3xratCW+opXQdqZD5uKnM5upjSSbePS6hotS0Kuo0y I4+ClVopKfHVra0ioSeSZ6ommRC8ejzAv2tKTCwaz1QPI0yMvgo9FIPxqSp6GqwgGmRiuCic Rgt8NU5SKT7AXsZE/HVfiNcPG1taHOBVxYmmJXFx1W2EH7bjXT8C7TIVfcaZGfw0/qRe1REI eqJcvQaZE/t+LdO1SNePxpykht7YDdgdjIuqrWLRlGl+V31MG4BW9cF7JkPapyjT5L1eLP7m Svu0E7N1cajvTI0tZ31bMrcSuo7FJtiVoJ2XIn4KPLzA/iospalWtmA3OYGmQnSonxVZTtLF LWGOyZGfwUTyjZYrE47CzCJdX+ZqcrDIuSclKz6goeTKiQkSyN5UBU6FVfqEdw6AD1GyayNp ANBALQT9oDkNWCc6hbDwQOJFjRA5WQs+wDqugWpAsvJStgCalZklpzKL6ATZNvAJMcw8B6gD qKIeSpG1gCVlE5koITAScBpqP/kSlueoFtbsk2GmtAbXUBLGore4G4KTSQCX6cj0IbWpU4kg XUroTu6hPYoddcaFNIifwHuwQE5x1HBDs7aZKTzBQWxoVqiJ7CrK1eCC3ZJ4G3kznMobt2KK a7FakJwvUWdUQVMYEmHUX0KLmMi3PqKJFM/UCpc4HKeRJyhPGAHV9gTQrLoSlGgGjeAmepLr p1FmvQC00/qS+SOmBRkqJAavIlZdR6E2orLAFNqAdlBG2cFKqj1IK3YkN2JJdYFGALVtyQWe glBSqnIENvRD/wARt9BYgAeMIThsr1IlMoE40G2xYTyVuXQBJwxVmSm8imSaKiMksqfUUjYJ lIEpyJ9kxq8DQ6vqNfkTWyeSm0lI2BJyLTBUvEdSbOMDYE7ZDOom8w0FLLKYRbtECcMabawg Wmg2KlppuB5gLNDpZPUbAolCeENtdSVZWrNRsBLKWskyyl6DwDvAsxg0TxLI3NYeg0Q12Gpn AUdnhfmNyv8AoNQ4kzVYyVGrTYpa6SNVSrKyJVxkpJr1K2vpoBkq4xqNp21Y60amQVWVBCQt s5KdW8AqvsRSr66A1I/c8tDdXrUaJicMNsCVLLL1NFWUBKAra0sgljOpfIVl3IjbDNbV3VgF WNVkeRlXGWNRJbrHohLjjRz9R5NKznBNH3waLjUzoG3vknlNZWaq5bLbU40KtRPUexLHQZRm lLwJ2aedEapJY6DfGnAyjJ26oG8uDR1joPYhlGSbt+Am23Bu0kpFCbLghzoJp9DTahRDGDN1 YtlsybKPxB5GDKqerC9G2mjV1H6MYM3SPxBca+5eoV7DBnamRVpHXBqG3qMgzfH9iq8arKGl APJcgT401HQm3Gogt2xEhhoYIrxlbEvqN40HrkGI27X6BtxBTt9iZ7ACSgFWBsSaKCybyCrO oK0OIFpoA9BasE116g4kCGo1BIWdB+pgCRTskKcEJd9Aq5aEDQpjQeqKTjAVWY6kZayNJ9wr RQnDYmJw8BdRoTyHVwgdn0I1UMFMRITVTIrWkVVGdSkIJrewlaMJyU1OhG1yxgvdjI68ieQ2 Y9SVVA8qtddAV5E10HWqSHkJ8kOBfLZqHhDdOoVoMPIz00FWzLgFVajDE5WugVfdFpKAecMK j0G84YaFdJKI9GJuEU1LHaskRMThA7NYKawoIt7WXVNNplLLF9Rykk0yaJeuStuMCs5YrN9M DQ9CtSFdIbtjQaHCBRoSl3B4bGoeg3CyRvnUFF3qLVVOfQqEhK1Ya/q7E/IlhYJ2GjW0Tsk4 ZFvd+lmae9wy7U10LKwR8lVqQ26pwoYuNJdPqTaa2lajdl2x3M2t6e3oKGkvQXV1e5sbtEEQ 2OJcaSW6jSVmNCK23OCm+xNq4wMCs2loG9pe0rp3KtD1RcPLOrs8M0lpBX00B9upMXypJLUW 2G5yTuhZHZyUNqRNNrDgN0aCd+rJ4MVXGWC/UZ1s5fYFdTKA0slLJVFEoVrdSa3bXZF8DZKc SJ1XQw3QpllPkTtLcYM6NcIm1EmmjL5VD7otRyasuwXaqEqpTnUzizw9RbnMdQjR8crI3Tcs MmsvUmqy1OGUb7VHqSph9B6VgVtMlUnxpZH8S1XUit4/E1VieEw0tqhE2rjuVZimPoXwYS41 16hsSGrLqVP5jwYldtRKrkcwwmGPC4Vq6DSgHbGRtytR4MTtTyxfGq9NS5f4CbkeDC2LXqCr kI7lznQaYXoOECsJdRphVSQOolqVZ5cDTBCYoyKWxtpFMPViiRSP6DTDeRQpJYpyNMXdpBVy TYJljRWrHPQVquJFD1JoaaKxHqZKJhlWQ0VIrNEpOB7e+g0VuwDSJiEPb1GhaFJky+oP01Gi tQwkTZsGi6H1H0yJd0DYAn2E3Ouo0ocodqoaBPuJOXAkslYAIJecFK3QTeQGniGTEPI5nInK 1AcoWUxtiSzkBtCmSmoF9AFWQlg3GOgwExiT/EaWJAloZLc6ajkAedRNdRbvzDdmBoI6lRkV XGo5aAG4wxLuhNxoNtIB2holMFLQsuAKx+JLaYW1JhMBttZWhLcQ+jKyLb/7AP0DQz+uCmrP M6GNDSGktROX+nUnc04Y0XKnALWAnAphx1GgeNdB7cSnANrqxWjRMaLSl5CJIV2sRkq1hqjb GgpbUMnc4lsqt+gQsLUtOVA3VWyDe0eRMNZYO8ZSEqKznqO0twtCeQqvOQtKHt7iiCgmBKda otRqTu92XgAW5rIt0GtmujM3XGNSZQ5XYqsSyHI1ZW6Cyg3ROB/IngTcv0EmqvBMopuFkdGr ZRNtFAkoYyinKwsg1I1rOrE856lygTxLQ9uNw64WBJvQYE+xG7d7Y0HZAoq8LBcFJRqvoQq3 cvDQ7fkCtCwidURDeuo07ThdDSuajiNBi4iLNeolX7mlmumoJFyCXWPxM1xOtsdTZNRDBuui JkTGdeLZae5VqdUUnJLun9SqErQyK8T16mlXu+g6OJTGiXxyHxLDNNyJcz6E7GJSa6DtGC9j ssYISznI1Q46BiV1KeNBOk5SF5LlD19BtT+knko+iyRx0vrpBnUy/C00sPQpS57Ge2Vl6F0s k4RryC2MEtqYmWVyKYa1EqP/ANhlTQlEyNV6jjBKTmUMA1kbqpHbuwTUSy5BFk5HtslKLdUx tOuJGQxjWm5e7VlKsdDSG84CyejKYhpP/wBBbK2/UWo1BpWc9AYVabdMoW2MoSw2UsagxKbK 5Eo3NBHVCTlQ9AuHCjQGuqQra40KTkBVzosA9NBPGR/q7jRMd1JSc4EsYyCcvIFuyjuRa0aF NdmQ4vh6gUOQWFAnNYYA3KBNaop+otqYEN4ZaWJ6kWrJVYWC4mh2yFnD7jrEEqI9SYuqS3ZR SaajqLs0J190oYiXWc9hqRKdRvOUXArToOcd0Vr6ky11GB1jSRtQ4JhLQbnqMBd9EStX3Gmr POo3GQC1UDROIz0LiBgmzdC+kktPV5El1kYHW2Bz1BNLUcpMohRI1IWcZQVc6AJNlJzhitL9 BaqUA4krD0ImVOoLOQKh6MJS1DdLyTLcAUmEzjoTCWegKyq2mQU1t00Bt6kTGWWm+mShbo1H LnBnu3l4gik01lFTiepKcKRV9zKht9Q9ELcln7j1ruXQgMdQUJ4YlnQVbbrbYKHLmCn6E2UZ DeuuoDdsOQbTeOw1TcpTE6wpJ4CctDVsiUv8A7YwxoH3Q623LPQW7UdXDjuUEJCXp1BrGcDS 2qexNMJqVnUnDXqOzSU6yTbkShzBTFJNhoPdu0IteGv/AFGwyqsgiM9ArdZdhWaRNhlNJZSG u5KaaT0YO6WS7DKTSf1BIqyl40ZKaWGybDFJuv0F1K1+nQlMbDKzspDMehq6ypRMJYGJqWtI KVSbSnjU0l9UDU7UskunUeVqFliXp6A0NT0E69i6pQW1iUMGcL8R20HjrhlOuBis61gFqWkJ 6jA56Cekjq5ZV1AGdXJTTtoCqmVtbGGsnOsDagu1duWTart0GU0Y6E7N2UX8cg1Gg8mlCeOp G1mlVDmBbZeNRhqXX7grGmyHDBruPJqOo6w/qVX8huqQympwkTCXUtJT6hC/AZTSaSyKrrbK f4lbF0BKHkZTUw1kaypG1CClJGU1OfxBucPoW8MbsMNYpSFcYKdUxqiJ1TS6zEA1DxkqX10D RsvU0k3DnoT9C3VdRKrr9B1NSlj3ahbGR2yVHcdTRSF0E6y5HVfkCaWrRLk9Vkt9Eqv4Ddca 5Jvz1oni1n0hGH76yxTih/8AeY2e010n111fHKiDSvFbEs89+R5d/wBO2v0g5+Svk3ttvyZf /d/6HO3l7ZHSfU9rbWmW4+rMn5Pj8et6/wCJ5S/j2/1XLXgca1szneFv+XOtzhHc/wCT8euj b+lRf7twf932OVeFw+r/ABIvw8Vcbf8AEs+jjyTlOM9ZXb/u3B/3fYa/lfHf9TX1qeVzrj46 boRw/JV9Tf8A1JHPtwvtX0/7vhst1b1JXlcTzKPF8XjlytDqXFKO/D6uUmdqzfs4x6a5uN9U UrU6f4nh8vBnBzVpyLk2zK+pq/Xyh34V9MlXuD2rOf8AE+Z8rl5fHvXMVfY9Cju1Ldl+Jqce U9pWLeF97HoXtTWcdzSnE1lNM8zk5eSqlN6rUb5+Wuln9ka5cf8A88cv8pxz35b/AEepsf1E +Gzz/wAzyb+dzcal/mjTh8/l5KK6ShnPrd8xu9favQrw3nCn0G+O3Znn8X8le1nSItXWf+R0 rzbv9Vfxk11Z8fLV1dXLWQU9VqYvzXXWr+4fvFZTtbRMnvKufHKNdXA4iFBy287jTVbNqdFb /l1NuPy1VRZt/gavHjm8bf4xOM5bnLP51p6smmcD/e07/kP95x9/yOexvpRVQ4YtsP0H+74+ 6E/I4n1Q8HSqiBwoUaGa5aPCtLKtdKB4YssVCRG2H6DtaFKeCXZPrD+g2JlVonCElCHVsMTD cDYuVTyhKk4BVdddAe2ZWGTVwnh4Bw9RWaphZ9ATVlL1LsTBmmXoUu5luVXtYk620l/VktXG kr8CrUnK6GKftivcdLqfc9SdjFUtu00CW7RUx+ZVb3YjGDRP5FFcwi9jBa0ZfTWA3bo26mdr e1P7s2tC1snjGBpgnOXoRua0HN7rGjMk22lGexNXG7strifsN20M7tO0S0yn7ktrl+hNMCde 8ei1Kt21bOeZXucW7j+W1Wq4c6WRdMbvHteSaWdVD1Mqc9qyraGtk3l/4DTEu/uVrYRTirh/ gZ7rr2tqEW0uNbrWXu+xNMV7U9W0VKq3u6nM/J3VW3KnXqXzOEnlJ9y6NLWhLbhSTZpPSUKr WiKbtVZf1SJq4mlk8zCa6hS6VnBPJFX7XuOXl5FS6y46yVHob1Dbwu5mm7Jp4yZcdtiyprbQ bce6qcPWoGivZtVSl9xObW2tZ1RKtX9ShvWCldKNq19eoMNW9rThGlLJrcnL7mNXW01rCbHx VSW22PUgfLKaTUD3Q8dNTHZseraWrLqoTdW4Aao5cZTyinZ2wtVojmpd2lRldx8XJZqcN5S6 NlHRV166/kChz7tDPjs+SujTWtRQ2sSrPVMgr5FXFcodLJOX17GPJXZlfhBpTktddJXTRlC4 7p2snMGjvtSSyZX5HWb2r1/E1cccXo/c/wCkgTu1CmIKVlyNtr6CW7d7quH3Mr0txuJx0ko0 dYeuOxpvS6+3qYV5G01qn1MOfyNloSy8MGuxrbdKcegbk28SloYrktFb2rHSBb96dJiyzkg2 q07NJNNdwUW7fcxbvbLab0RTramKzH0wA6XjWEjSt02lZxJzcXIlbGc5TI5Vt5VarmqmUB02 q03GqJbdrKunoZ1avbcsr8y+S9k3a6U6VSCLq4s7ax0Eljelrkx41Vyna1b9nobcbeE9F+r0 ClbmUwlD/IOS1qtNtKdII5Fh8lVNSoreqaaVfUuou/IuRx2ITy11gjfXbHR9dDNRTCsrKdeq Ia6ONNpNqY6iblyxU478dvZCrbT6k2e2HZ5ZUW+arqnXPclXaeIjqF3alZpVNav0M6Xo0+T+ mCL5daajBVI6isnXoH6Toxh6lSksIhDTXUvgxTixM5grbGUS3kbDDVUNvAVzqDJsMFlnILQQ JNjYYEhtwvUlvaOyGwwKVkpOSU8D6SNhh7tYBNhWqeuGCzoNi4Vm2hq3QUS5DI1MEuo5kiZW cIqlk8IauGm2LdGYKZPadCbDKrdGSZlYG6rVMiYbguxMV6oaUSSs4eCqvEDTCmcoctaCpD01 Byn2JsXA0CsmEp4byTKSkuwxfQKvaY8nNSmr07HreN4lL0re2ZUwWS8rkOXG8Z25TJXmtyY1 8njd1xbvc+x1f/5FxKvjJ1URbofM+C9vPR+p6v0f2Xnb5yuE+zec45419O6Y1yZtxqbmXJFc vRnx/p+/leXXm9d4+PCPoRZPR6jlzp7UNucfmevXPqHZD0WSKJZWWNRfRrA1cCsm8MqSH7W3 GfyDc1Gk9Rpi7StFA9fqZvdtzhlO6SxhodlwrOHEA4x2Gk4lKavUztONUh2FfFW3Y4L+LyeN yvlpN6Ww6t5r9PQ7aucToaOzWW8Mdl8+1cqpyvol+M/8g99Xn/A6bQpbeg43rdMvoTZ8NduX y59zM7ZOhWdHFlBdnvxg1OUl9GbvL3eZ5XjLn43V69DzuGu72uqV64Z9B7V0lHJ5lFxteVwr Nf1r+6p0/bvhz6Yy4KXr+pmnFWyrGXEo7OC9eau/jU0egVSlpqHrgfth0cj4nqzl4Pb5d696 pnpc3JxcO1Ww7OEcHkOq8ni5auZb43/wy95YnWxn/LJulU8J2Sb+pp4PNaX43N/9ymnqjb+X 46PgvVfqWfxRhyeK/J4V5fFZ/JWqaXp1Re8uJ1vl22ymokmjbs5XRMfi24uXiXLTR6z0Y1Wt Wm1Cyh+zinSo8jjrellaFK1PO/i77eKzzba4dfTujo/keO9lW1P0JWb/AAOb+Kjj5Lca0st1 S9pZqdbuNZdPMmjVVyVnvMHoUvXkUr6NPVHFzePttTmU1athdM6/c71VVsr1jdo0/wCpf+vY zfsns1OHsh1S0RHEvYkqtLTJ1uOSrae1kU/VttbrJn9jXSPN/keGt3xcdm62taa4mY9Zwen8 Nkef5Hv/AJCtdVxUn7nrKjtlPBOXO+P4XjxjNcPditWtVLb1gfLfYnp6pl05Lcdd1s9jHa/L fWM6qre3VspVo+3qTu3Wb07Jiu8TV5J2vyZF1brLpmr7o0VZymn3r6ism1FmmkRycVqpN5T6 kqqmz9uneCFd1zb8H0I+LY20/wAGVej2ykp0kDSl09ZkeF7U/wADHfVqquot0dRYVtzcNgdF VambZRM7nOiM+Zvicu7SC/NWsOjlAVa/Gkk046MunJTkULBguarSlwzPit/qXtyOF0SImx02 cprLtqyFyUVdze1r0GuO18q2Vp6md3Szj+pdPULU15Ntnn9Q+SFCq86yZ8LXJR2hzPu7F3tX d7Vt6hnW1a1lwvc++hCsqLEpI5P3G9WfZ4Na8r5fZDhLQpq7civWs+1f4hdtWy8vR+hhflaX +m8rodNfek7qP+ZF06N8fuTano2Tdcdr/IpTSHW9ORZTTQ+XiS9qaVWupVW+dv8AUocYsupN G0m5y+/Um/O+Lj2P9UQpzJFKbeP5WlLei7kTVci+O+/p1r1KV68dpTmrWEXZ7Wt0aSYWpXkv La29wmtL23Q6Jx17F0tWyizfeF0MXy1qvjsy0knhS2omQa0vy04/cmrJ6d/xM7c3tmqmOhhy U3Q6pR37Akqtc1rejRTV8brStrLCblV9TTltVpKyl6yY8lq8dlo6mdueOVV48prRAtdN3umy tEaQZ8fk2sov7mv6v/UyXPHI99dsqIMnRXlKylPBTXdZ2VNZfRnNeny197cLO5dGb8HErt8e VZIxrReLupZRVPR9URnfODit8bVbZq/cmtUzqdapq+u7tlmHHzqPbWZeCJsuR2SSq3r1Fa11 cV/f7P1L+kryK1dW6OG/yZxqitu5ocVFXnia2bafuCyuujram3a9/ScSRe9latW3j1I4uavP FWnW8SnbQzS9/vc7VMkqWumat7cPugveqS+OrcaqrOa1lx2nj93XBXMnX3rHtmO4NFKtWcaP 3VT7FcdluWFaOhPHavkUUYah+sGVa2+SJ1/SzQ3u7cN7WcKrymiac91ZusumsszvSys6tzDw 1k6ODktwvZeM9zLO+VX5HdK8QphwK/JNYsopV/qepKuttrrOvtXQG1y8S5bwmstJ6pegXU+R eq9qTh5hnM+eqn4nFn3Oqu/kvu44hrEnJD47OvJx5enbJqJvl28TrCs3Foyw8h/I1OPpoNcC dVaj06dTi5uPk8dTZyk5hkXXZXkdUqNqza16mPhcTrWz5V/qTC3aGPP5FKKvMkrRGDqp51Ob 28tdlXFkX0TtKrj5/jb47UnMvWTO/L7/AHViy07NFeReNt3aOj/8QpenPV7d3xpddQ014uNf qb0zHU5vI509rTtr+roXK5+KeBNXWV6nLTnrVxy1mf1VfQiWu6nI62nqtfoLmdb0dqJrkeUZ fLXjVPhXs0tJpZJva1tdc1XQJvg+G0bbRF65tByfyHlWTr8WUsv0N7/6XFviHOEZVa4776rD rNk/8B7lrZpWoplvX1J4+d3rpGYaZl43lU5pdpparwvQyrZ3bxClqWMNd3LutWFhPocfj+Pa lrOd1e3Y6a7trdnlLEnPHJZOzUJL3R2ES3WvF7k12cP8R147cFU3GW909h1txpK1bar9SXVG XJzulq3tV23KPQqt6pcL2qydbe5KdDOvNWHvU9ieGqd3a+F/R9SnXdTWHPQg14V/Sn7Wv1BF VWK99rZlWyu4rV+1ZaxP4D4+WE04hg12uzWNQu2v+pC5bVXqhNv+sNNK2nQbe/Qw5LJWWHHo W+RWWFgqr+S0w0F9Yhpd0ZVvZvbSWaUtbO5w0TRV+WMJYHTSUcn7jLVpn1NaWanrARqrbmpK Vk3jVdjO9nCbUP0FxJt+7QlqtbuUZVbTzgp3URP4mXHy/PXP6k+oRrx2SmxVrboSWBca2uzn HWDnp5Ks5SbXp1Bvs6Xh4lom1r1jbhEvyPc1XEaplq1uT9JN+TTd92U/wJdttk8mNab7NN7W F6OYXQu+xrp37szD9UQ7KcYIdulvyI+S1M1WQOpWxKlom3Mmloc9bunubaQObe+Yr0Ia6N9a rH5hOZUT1OVWdZaqpXdlK+/DW3HQprVcibTZrV6nm35a8Mws9TbjdrZej/SCOuqtedvQzwnt epbdW0qJqy1ZjD3+33T1gKpP3Q1Mdg9r3S8dCL81uLdZVj/mTVLnh1UIpL5cx9V/HufH436H yzUM+l/iXPjV9JX5nb6v8np/5n+Ev5Yfz9Z8S3o0fHePaOWjXdH2/wDL13eJyL0PhuN7bJru fT4+frz+XxvTnP6PreO26svUdq7lDFTQqT8jyucrny+rfVxpNNpOSLp8ea57mvk76uaaPU5v 0+5WcPXJ9Lhy7ceznfFdL5Ht9uV1MLNtrElUvLl5Ra48xbDejk0lZq0KbvK6B8lWm4+sGj4b RF3E9jk/b2ryPY59GGd8uivMr1xLq9BJpKLaeupzK64uRVqsW6PRM0fI6WcpzpCLi77uj5f6 a5k2olD0n6nIr35dKqF31N60rZbnholVN7LEJt9y/kUqdOsmVuVJREAqK79zS7ANt61XtHVR lPD6mKtbhT2/rkvltv4021LeYCacWysQ+rK4ruNqy0c3G07b/wDEcZeZnRgdSarKbSlSfH+f 5F+XlcWcfU+o5nVRT9NmtTyeLgr4NrW8jjV1Ze1N/md/p9/G1jl5sm4w8Hy+TgtXj3f6benS We7zXtxxyWaS/TB4t7U8yy468ao1ras6G3Dfkb+G36q5TfWpPsnn/wBrLn/09HyOanJWmFb3 Q19UeX53HycVVa6lJrbb/kz1PIVPF4nySnerVj53yv5Pm8izbftf9I+uX+jPK/6vo/mr5FKx +mOvqc38VzKnDbhetLWq2eDXyearVKWaVowe14V/j3Vid/fuW/XcwnObpbl4XKuWmeDkcW/7 X3PWtVVUNzXFkzDk4+O3H8fLHuWVJx+B5Ds14nJ+qs7LP+pdjl6zW54uOz+UrWnjqqbncof/ AJHmedycHFy0+B+6uLRoT/NeXa1KcfZ5/A8dW967Ho+vj/b5cufLz4e7zfyHH5Xj243b/Uf6 axmTv4uRPjrOWks+p4v8Txf61m/6UexbiTysPujzfZZxvSeyzlfVuuVSnt+plxp13O0NvstB UtZe2+vfozbaZnKwvKubg8evDyX5Zl319Drq+LVyn6aGV7Vot1mkl1ZzP+Q8Zf8A5Ea28v8A ak5We7u3tratO5Vb7ardX2z31PNp/IePyW21tLf4fm4Rg/5jjWlbN/gbn18r/tq/tx7HNzPc nVL6QHtndasRoePw/wApbyOSvE6e209ZeOp228jKnMMX67L192p9kvl0WtW2XNYeq0YvJvyf GqRPZsx5d9ptTrBpy3vSkQr7cuehj/21yvguLj5K+21vf09S72anjw31Ujpdclqv00a/5guO sWvasp6W6oyus3d/o5FCrnUfNe9qeyGpTOLyFus5lYx6nXWt+GistrwvbOSs231a25P3Ht5P a+kir4NuNO87rI5fKs3x4UPVLrBHi8/NSyrZvd06yWEsdPuv7quWtUq6Gdea6s01uJ5fKtw8 sqsK691dDR7uKFWvueRg199uNUrKl9TLyaukta/mwXkWu3WZdcpeg6c9ub9LlLqyLp+ErX42 1XKTk5uPn2tW5ZU40Lo53Q9ttHnLRl8ERV1069y4jdLhabcwunU2VfbvWJxVI5v2ia3Vs86+ ha/03V2c1qRPwhfJwcqo4afdG3kVveyWm3OppytWp8tZn/uM71rxTNU7NTIPLLm5Hdq36Wll HRflbhP3XedqPMq7X5HZttdTp4+ateRclFh4NNbsG6/JZ8l3C0y9Dp5OV120WVEy9DDyLV+Z KqTV1+BzXXJytUSyvzIzXfy8vyWqlr0RltTvavJNe9fU1v4q2q9VG39Wck896QnPTX/kwvtr OlN9XyNqtf0oXDPHfarYXR6E+Pxcm1KzaTcw8ofN4zpevJrDcpahL4Vy3vR2dFhsfj8Vtr+T Wc7jakWW/lUdUzPlXyTemnZvIVG+nFybLaP2t9kavx6Phb40lej1TDha8vjwv9Svt2mXJxc3 Ba1JadlNdoTytu3O6Lcm469zltdcFrTWbGvArNPiayoavoa03c1mrNJ9yrHJvtXjfMmnKjHT 1HzcvNyunJdSkknZdTbk4OOlYcPLRmrL27GlXsn2Ce48zi+GL1ftejXQys2qpJ7rI9Lno1xr c062/S0Y24KcXus4cYSRCxHjXvsSS9qls2VK8iw/c1ozC7fH41lRuW4fcfj8dqVXNZzRd9R7 KTpuaiFt1Nf299q5aOa3xPb6mXJx25d1qNS/1JdjNcVuO0UtiMlxWlOJePzKqc1S90m3K1y0 2U7wmxV8b5Gq1cPu+rOfk4r8X+nbF5bBmM6vle2nSr2yj0eKt1S1l9PoYcfFbg40rTDy8Gd7 3peJ2uNH0QvkHNzqlappqyetTTzOWnlVraXV9oMuXxP3aVeDPf6mvL41vFXTdXXPUnjPymMp vx13rLrjb6GTvxOm5qyc/wBXQvx/k8i222OjsdlfCVeC1OS6aq8F9PVmeRyWpw13Ubbsor9T zXy2vVO82Sr36lcjvx1quHDrL3dTaivWqva00a92NJLJ4MLj5nyOvxN5/JlPkfy/6ib3LutR 14/kv8VHWif6X1NL+LyUSryNOtXO6Mk8Na6K8HD5SdbUstv6tqlHL5Pj1tV34rbuOsVzqmdl n/ounFeOT9SjEktX8jh+JuLWzfaFxn5q+XipSubJ5r/1OfjdaOs8mVP/ALC85fFW1eLc7VU2 bx9jn8W1Gluhz06lk8Hu6+Hj+Rbqt17Pt6mnMq8anlSmz/UtDbxualKOtUuzq9ZOXyJ5W+F1 e1RaOqIljPj8t8dXx0X6n/UdPH475HHI5lRb6HN5fjvYrSoxtf8A6m9KQp43Lqs+ouE+G/HS kvjtrVxVnB/IfJal7TCr+Zp5PLXkhL25Tx1O104ORv5G3WP027k9LqZrx/Hru43erlrB17mq JWcbXD7GFvGv4zdatOmqdf8ABnVyVfL4yvGbFvqknsLXqttKtTZ9Tlr5EWdLOVMONCqU3Uj+ pOEb8X8a78W6ri1Xp37k8T1TNcyV3ZUpWK1l6no/H+48eON7bdV/6HHbmXiVpRqd7930NLeZ x15J49O2mS+a16eWWx8tlWz99f0xqa8ib4/kr+qq23+g+PgXnN8t1tXZalcNavl/bcVoed3X 7k/+UY8fIr7t2EsK1f8AmTy15PHdVtxf2zOM+pr5Hj/Hx/EpcSvbqzDi8hvx7cXIm3tbr3Xo WfM/0M9notUdtddYMfLvGKsf7ZV5PkbytRc6V3uxHqTEt8Jp5ClUs8l25M7c7Tkrf3NxHqdl VWZ1ldQ1ut+TyFx1Vl1Mny1tCfUx8nhtRytIwRxcm+HeoxJfLTyFia5Rrte3arQxridk+Oto T1ZccdKPjtbK69A37IrNaRaW/Uj5FiehmuaicJuz/wC0fHyJ1beLPEEzGd+G9VazalbYk5fF 4+SytyUaS9SeanJRpzh49vQHa1GuLgmFrgvsxuVVrv8ATEWep0eMqbHWySddDGa2tNvxRXyV bdK4aRF7JvbMdeht8kU2aW+xzeMuVUbu5/tXUL8j5LQlosvoWzynotctr1dbxjsdFJdYpaDm ry0adYhrqjJ+QnE2h92Rdd3HwRZOtpc9S+ffvTSUI5/Gi6bbl/0m9uTjWLJzXOpPdphW7dXu hQ9CV5GxxG+v+Bzc3MuTk/0ZybVfMq/HtyzVjO/Dp9tlEJTpIvkVMOWtHBnVRRzPyLDMbeRa tWnmxn3atjW93y32Oq2LV9S3yvjW1r2P9CjJyX8l3a2Vhs6fk3pJ619clTVJ8btKbWCuXyHx cbtXvDFZclulU+iepy15LO9q8sQX8rvs7N9efjh4tEwRwX+JS3r0Of3Xsrp4WsdURbl2vKif 8B7J292182bXc+g/hXPA12sz55tTjK7nu/wbnisu1jr9f+Ue/wD5Pn6d/h2fyFd3jci/7Wfn +h+ieTXdxXXer/wPz12rVvfMeh9T6/8AC/y+Jf8AJ9Xwr2Vb7GkGPi2V+GlqzEdTc/JfbP7+ X8vq1HJR2q0tTyFdXTpdOV/ae0efz8Pxcj5FiV+Z1/4/PL1vuxymx53H5d1Vpppr8zsU24/n t+nQwfk0tZU5VD7o1+WlXsThP+49/u5XVcdk1ttyVqm8bnn8DSyvROHuX9NqtM434ru2ruEs yh8HFXa6UcpvVjx6p5q6u1543rb8i3x/FVVVm16iv4/Junic2rnBs+Dn5rK91GMozeUnrW+t rmrfkbex4Wvcv5LpbnpodT8B2tulL8zo4fFXGo3Nrsc+X28J7r1eTd2eiw+gfDdVpEyezXxu OrlVyaqsHO/8ie006vKpxctnuUyOvgXb3OEz1YCDnfv5X0i+HC/BVnLs16Ir9tTgo4l9cnYY eUt3G6rrjBmfZz5WS1f6Pn6cfL5vPWrv7W+i0SM/5DkfNdy21X21nsjv4eHk8Otr8NW3GvI5 PEfHz3bb6n3vp+765Lfd5Of089nwrwPJ/b822z9l/bY9XzvDqqPn47NOv6J/wPGfh3tmzRrb h5uRKt+Ruq0U4OP2Xjy5dpf5dePDlJljHzfOfkV2wknrHc8+Du5vE+NKzc1/qNV4PG1Mticu Mifr5W+ji4mpra2iO1eTw0c6/gXXw+NYKXi8a/pRf2yLPo5Nrfyvj1e6kz22nB5PnLn22Sa5 E53HWuGi/pRXx17I4d+M9I7fq5WeryeS1uW2+zbbBcdn0Z33T8e3y1U1eLL/AJnVVypWjNX7 MksnhifTts5XzFfxPBd77bXmD1V4/J2D+M/Rb6nefN+37b3rpfq48fDjXjX76mz8m3Dxrh21 bX9Xc2OLyf1Gvo+3l3xjnw49b4cPn+N++2K7Va1ctJa/icj/AIjx7N8jb4+FPbFfc29T0W1X U8Hz+S1OdvusR2Pp/VduWvJXocfj/wARRy7clmujqXy8f8f5qXHTdTln9SW2ue/0PA+ZLoH7 h6aHqxNe9weEvA8inN419yrupa3ds15eK3LeUvdadDzv4/y5qqP9Vr7pnsjf+Qta1a7dUzzf Zyzl1nu3xd/g8q5OR8dmk6Vdp6wuht81U1S9W1b+o8zxfD5K8lfIVqpWn2udHqjvXLZPa20k 9FoZycv8fV2/n0Z+T7eZcNW0kek+C3xzTseb8a57uz+4+Hm5OC8XhrTDOXOZf4JlbTTqk49u JHbhfJVqqiNJ1L8nltxtWhR6GfLzLkrvfs6rJlv2ct20l8qs7V0j9Ja3K6arlrPoFPNvalr8 eFMPP5mz5uRr3XlM1fyzWHk8sOrqk0uppw+SvI5FxvRv9UZMLp1vWzzXsdXF8t6Wtw7U1+Nn BLFk9yr/AB1uLld6tvj9NTOLp2dXhadzenktuyqmutp0OS3lvlurum5zC24/ETSweP40Wb5p te3rodC4OGr/ANS9nVaOJOjm568dNkJ2ed06GXJyu906xCXtbWo8rjLl5ePiTxaHpLg4FZu9 XdTXT2nd/pPkXyqVPuszPyOPjVnSje1ualjOXY0te3JdePwvGsuGiV5D43bj5MvTQ5uHmtXn r06Qjt/1KWtyLKTmGLFxh8apaKLD1ku/HxvbTjTdlMroHBa3JPLZxuyOnGr2teVP/IkZks8F s4b8a4lO/VfX6nTwwuHbR5nL7HPW75Lp1WyVC6G/IqUhV1epm0vhn4jp8nJRJ2q9c5nuLlVK VXzJt9loRXlavt4qw282Yc/jN0fJv3WThzp9jRNw/kTp/pqySme34MXu5abeOJecvP0kS5Xz UfjOySqp0Odc3Jw8MpZq4n0LG7PDazrWqpZe56q2WjXkrx8aV+Ou5LXOhy8XLXni1lFohONT qpxKubtNwS+KxbjPi5q7q2pVUf8AjJbasnzcqurrHoVw8SdnZ6J4NXb5+V2c7dGibF2Y5OPy 1yJfLSfpqy68NFdNNpPOvQP222u2ZSbf6dJ9SXRrk/S4jua8X0T8Nb8S8njd1CVZhxmDjS4f ZSkNN+6NT1r3wlVbcHBZ/NZ2olvWG4JFsFfE46SqNpfc0sqNe7MdiODcqxyJSVW1XV4HuzrD zPN4dta8fHZWn9TJVd/Crxu7Qacvh2dMttRie4/Db4eNVs+u2qNeM8Nwq/Je9Vx16Zk18vnX BX40la71t2RO7l4546Jw9bEcHj8l+VtNbY927qQbq/7aq5mpr3XZ/wDMPlq1ZrNW1tb1M6+L v4Il66F7UuNWSwuhLS+D57c81rw/peIvlSc3JyLg9103eYsx15LtZb1wh8rq/c6yOzHZ2cHL bhT5ON6rQzdLc9nueNWYW5LcdPV5/A6+G00hqdxnTsz8a9eCtnypQmZfu6OzhvY/xH52atdT i8fg5KKqddZbZueZrXHy7FfgfHa9k7OYj6mPN5NeGz4XTVZU69jlfjctm9iesnbxcXJycity f/cVXoa8RXV43j156K3MklGI6Gc8vByfFbKf6ZzJjzvkvaqbyotEncuT3qllKeU+zMUcSfw8 1VaItOOz7HXa65Gr8SzEW9Dn5vFvfkiG4s2n+A15LpwWpRJWs4hlBy+M+Lg+Xkat8jhLrBxr xq/K+S1lWq6dTvXzW2cXMvbWuI7k8nFS/KlZ7VKj1f1EqeGdkuJ031zZ6rod3Fy8T5W5922L V6tdw5eT9VKV3S0jO1b15lx1rVbq/qzJN2eVjl5OetbV4dKTuTiWa83JWvJ8rnY8YMmp5d14 qlhN9Tq5a6JqZ17ErLP4l5HG+bkxSqe1ep5/J5XxcdJzDe5f9Tu8pLyarx6wqrLfcxr49Xxt NJqcSanp5Wr8Lh4uet71xKlmj568vHZUfsrgx4eCiW2ktz7nOB04IfLRqE0sIuJmNL2rWnyc GX27k/x3lrlpal1ZtuZ6r/oRXir8NOOHMNdoZj8FvGW2tXlpNjxllV3V8jj8Xd87T5HitEtP xPGtxWXIm0omV6Hd+ype/bG78TTz/CjhfJOq07MSyX+Us2Lp5L4LPaprbovoZeFW9vIt5C/R b7kcO+nEnVe9dWRwW5K2+NykmJ4l/wBCvYrybrp29dDKvJRvZWXVOGms5MuKyrySbqm6eVdH LOSy65E1u3Utpqjl8nyr3tVOHWTTk+LxbTarc/1HZyeHTyeOtqNQswdfT+rGWxz05FLlGXL5 1P0pZ7s35eG/Ek61W1nNw8X6m64bJ4PTwr9/blsk9DoXHTXjvn+1nLelPItHH7I6dyuTxuXj dZWgvrhl9/8AVvxu1qvf7bJ6nJ5nLe8cbrFf8Tq4OW7u8PtLZrfwq/Ir8tpWrQlzSz0ctfGX HRcnG9rZp+5rau3ltFlo41O28cmK+2vTBly+HXkdVZNruZ/lbPhPJVJ1dZl6mz5+JPV1svQ4 78FuNv8AUkv0yXvteiTqlfoy4WaXMlZ7qNS9DKnFa0xiNV1Z21quKLR7ieTyKOy0TeNw9U6/ Dz78nNfk3aUSjAly3xtbg9Djfx8jptmryacnFWvHtSSnSot8mPI5uPlS2r8gvw8lqpvprk7f mpwxxWar9Rc1d69rlehrfKXiy4fLrWrperldUdFOZVe62E+4vF8SvLxuyabnNR3xdcNkl1U9 DHv4akwcXC63fNRTX7QZeTPJTcm8PEnRTyOSlk1VOswLzPHrb30tE9JNT1LPHhn4lm67NbP8 GKnC1yTaH02krxrcNk20337Grr8rtseX1MmI5uB8TfIk4jBzW5GlR1xd63O3h5bKKbt04ybW pXjSXKk/VF3/AFTq4PFpyfuHe73pLLOrYuS1r1W014/Hs261S2/XUpcVuJOrU4Jb5XPDg5PC vT9M2Vup0c3gV5OJbaur6ojj5bNR8mz6sXmfyN+KqXG2rd90yJ23xjWcZPOqtwW4/brg9f8A g5XyJ+jPIp5nNZJ7/sep/EctuXltW9m8SuhvheXaej3fbt+m/GR7d1NWvQ+IX8dy3TXwXmXF p/5H2XL46vVpNptQn2Pz/wAnyfK4r24+Tkt7W1Mn0J+yz+zr6+d18f8As3+7X1Hh8HJxcKre u2F1Zo+bjrh2S/E+Rrd8vHW25vWZYbWfH+3/AI8vO23zvnH0uEnKdn1v7jj/ALl9yOd05aOt WnbofKrjPR/iqqvLjscuX0zhO0vmOnSOuv8AFS91sP1clL+Ho82udu+vcT5ao5/v+y+jl0/A p4fFVRLf4mteLjpiqRNWrKUDrPVnK87fW0xqrV6BvISjQZipkVvDeyQIYbvCluET8qdd6c17 nnfyV78v/wDW4dWt1/RGv8Z7vGqn2g7/AK8+v9lvv6fhcVb+V8Zf/kn6Sa8HlcfkVd6N7V1e DHy/i8XitdUrOlcdWPw/F+Lg+P8Aqss/VmrPr6dps85N/wDIyf8AJq0/Hx3ul1SwdHi+VXya t1TTTi1X0OHxf5Cvj0XC6Wdqe17VKNv423yvk5dN9v09V9Tpz+uTjy/szPTlvqrt5f0W+jPn mfQ82OO30Pnmx/x/StT0S2k46k25K1wzDl5Eru39sZK5OWit+pqV21Pd1nj8ufa+c9l8vIlW dUzgVr8aTaex/pZ0c19/Gn9wf8hS3jftr8bdl+l9Pqej6uPHHH7uXKZeLTh5dyc5aQ686s6p ddTm8O0prqkb7GlVpLctTjy6S2Os72Sz+o+Szah1106nQc1uO93l1iZmMm6mMnLlZ7OvGX3U 0moehz8L+C/xW/S80f8AyNzPm4vlrHVaP1My+19KvKe89Y9z+M/Rb6neeP8Aw3N8lbVti9X7 keqfP+2ZzsrN83VSjh8y0NR2Os4vNWjH1XOUY5z+2uRvuYc/j051F1p1NhNnuls8x5Hlcn8S v6LY7M5uTwb01Tg9u161U2cHJy+cljjU+rwejj9nP+WLI5PBSpypvomdXLzV5LKqZlx+PzeZ bclProj1PH/hqccW5HufZaDlZu31WSuunDSnFSzUt6IOW1bNJGq41b2qcaFU4Yw1k42yX1ds tc3HSbOYaJaTtHIuuDs2QsYB0SyhbpmJ56rCehyc/wDq3SrXFatZO9qrWVkVEnhF2N683j8e tabUmpL2RXazrumpT6HPyVdq4Frnam3G+SsJJ+g78PJxunJwPbaqyh+KrLD1O58b1WB2k/ya m+zjVbxZ9bLsY8HgunX3TMnarVmGOtWmzXaei6wfBXMrdPcdOPbVKZg05fbiZkunFiMIm8U8 sKUdnPZmnLXdbc/uFW+P2pN+pdqqVOrHaDkr4VauW3MzJ0uap9ZBpN6kNzicC8pU2k+NXcvF VolginBss3Vxu1OjZtKrRUzWJJ2/qqLVmiq/6dCa8i427OG2o+hrNY92hklWuGRm+qbdE+qD ha41teU5WSrVUpuVAVScy4LLPUhftq/qri0dOpnbx99XVuWzdKdehnxu1XL7yNLU8fiVVVV5 ZN+P41VTKk6LzfMQmc3ItEujG2l9FN14lCNFZRKwc93u0WTWlcLpBlk68uIZKu2svqc251u5 Jrze5ruakxNd/G0pqyFwU4nNPxM+Lm3N4mDbhT5K4xkb8tS6xdIyacNN2dFqbXriFqcfE2pb JvwnpXXdu0RoSqKiUZhyPx1KzhPSRcqdZSzBe2NfldqNrBOiiNTLj5HZR2NE7asnZnVxtUdC HVxFdOqHTkn19GVhdc9jXbWvVy8nC71lYjJn8Dv1wdt+y1fQdK1iFqZ0yOVcVrOumP8AA3tZ JzEIv4dqy5M713JMS6YhVTtLUo6qVW6emhlVWazj0Bt1rhajbCeDfGuOUngKJPPUztau3cnm NBcLeX0Epb51paqfYrbo9IMq209DVttSlqa7LBTkcu1de5OxW6aF6Yeo09+E4Zby+Blycktf YXHl56FLjVm56CtalPdMzjBjZGc91clFO5amie+I1Oe1tycFU9ySnJVlK9E5TNNv9Ppr0JtC 0HNqpY+w3y0lUmqqsNE1qq4ZdXDbfUjkTbRWb6LolT3QDSrZ2iWyLOFnUuid12HaH4KvEnaR 2487W5QNN4Yszp+I23y0FSicou7bUPKIVnZtMrcnWew35RNKqq2mHO1TKZuszqpM346b3WKl c9Ju5R18dfa47MIijqtBTCjuCeHDz8V7+xr8S/Hpy1pDeF6ZPQsnKtYqyxiCW+iyZtcdr8mx fKm+0HPwVXJfZZtKZ9D1apxFtDOqiYSQ32X31xc3C7cyhbV3Om93R7auU+jyaVpyazuY7cW7 Nyb5PZhSnKluVV9Qc/qspOmtV1HdJYrqTZpY5K8vI/a9OhVsKXP4M6EnVS9Sq1V1FmN92erh 5acllh2df7Wa83Da6rmFVYOl1f4BauJQ3WrPDFqz4Xxs53wWdKpJJrU7NrnGAicTksuRaVKv jU2zZ6HPyeI3b5G3Z9JZ2Vdc1ae7uZ7tspskvqV5i/jb8vMr3wju5ODlbVa2crqab9qRtMrG o5X3STxjl+G/Gmpi3cji4Lbt3Ok3HtcnVimuvqOFyONIJvj1X0cr4K3aSmZ6M0+KtHjPdQWq rjt7tO6KlaTDJ20ZcfF8dbUSnd36EU8d8SaVtTsrWs+549DJ69zU5QY04tubdNMBzUry/qOi yVUk8ol0cZJ2hjPj4oqluZTTdYTCtlVREguS0bXohOX4Vycvg0vNnMsdPCVKe57l2aOq9N8R Jo+S9VttVOPQs5fDOOevBx2SVcHT/HpeNz7r2W2GiLUiu6v2FZ6bNTU5zdjp35df13/H0e5y edw0ru3K3ZVyfnH8nzPm8nks8TZ4PrXZ/pwcfkfx/ByubUUv+pYPVx/5MkvGx5OX1edleJ4d Z4V9WbbTup/GV46Rx2w3OTNeFyWvai/p69DzfZynLlbx9Ht+rlOPGTl6uZVO7+Occq+hnx+F y2xj7nX4ni8nHfc4hdUzhz3rXac+Py9BcdV0KVF2MP3fE7bFZbuxavu0Z4bx5+8rPmttAkxF qZ60xunGrDcjEYsOrXehO+MGYyJkeTw8fncbvataTfV2eTX+Gvy/C1eITaqeiZ8XDThTVFCb k9HL7u3HlxsnnPT8LkcXNyPyvMrxL9HEt1v/ACPSdm8GdOKlG3VJN6+pZz5ctyT04xfDx/F/ kP2VPg5aX31b/TWZN/4935OXl53V1rdqFbXB6IG+X2y7nHzy9bojlU0t9DwD6G6mr+h8+zf0 elanomCLclayuxoS+NNyz0zPdL+E7k9euDNcNG3jQ2+OvYcGtz0HFzJr/UoodXH1RpXn30mu p0wcfLPj23r9Fv1I3LOXj39nO7x8+3u6qOUm9SzPjsrqUXKWDnY66ZVVklOU2tFqVVN6Jv6E 634Ttxnu0rw347fuuLWn6q96ntcXLXmor0ymef4tuXjT/wBJtP1S/wATHwa+Rxb7U2ql7RSt nOfwOPP67znn1npf/pm8uN9HsnL5uKp+p538r5Xl+JVPdWW9Ejr5fCt5HFtvdqzqnM9TPH6L xvHly5THLlyllk8vP5PJpTV57I4uTz7PFFC9dTb9lWuLVatX9cafh9T0vA8GvHT5PjidG8s9 +cOM2vLONryeHwvJ8tzWrjra2Een4/8AF8fDnk99vy+x6rTq0rJNdib0q4b17I5cvsvt4jpO Mn5Doq1hY9AW2ziSnxtZafoRe1FZVzvZict92vENVhvawpd6shuzU1UwDu6wmvsXcvysa25J ShL8DJpptpybbquE3H0JVa1w9ehmUsZ8dm/1YfZFwktyM2q0fVTqxutZjrqa1PYK6axlPqVx cTu3DUdiUoUVUrsxptL2rPoX+pBt2z/ggsm+6LpW8bu43ZqXbCXQzqs1SspX6jVfjeFgncnF 0nKNKcjemUO1pkgst1dPxghVb9zUpdUN729B0s5aWJ1E8eiVjvtfFUzSqxuvgp8aVve9f6ky rVq3FMjsdWajk00NKcSah6IypbbaLpz6GtbqPcn6C8vhZNCxrEEw5cZQOqeiwLY6z/VJJyMR PuhpFuiiUvxDjVM2ac9HIq3s3tt+Rby8+PZDtRclVZOCq1SlNfQ0dFxpJPLIaURde4kq+qKV 3vYmg5FSjhsq1Vi0DtSzqmtGXfO25BF1tXcm645UJNs12usWTb+mhKX+o3GupNqYmvCm96aX YPitDdi97TmJ6F7nb26OR58Lkcvx0vqoRVfHVVMYL5d1X7UslOzaSbk1vhnPKOPipxqYy3k0 da/0+1dBQ0va4KtZqsuDO5fVbJjL49YcsFxNKH+JUV1hIKzbWfuX+VwXqlT2pNozvSvJOYfV ByWVHhwwrWHL7yXJJ4S/CuHiSr7cdMhekaalXvlN4X/aCt3M38mRm+FVtvTw+hdpmax6lJpq GtOqM71cpJqWpEvnyZk8Litc1zCMlDW5J6lqa1m70BttJ2cp6RqX3N/Cvher/wATPlsq+16m 6mq3Tr3Rltq37+vUk9Ssly6TobRVrGXBlWqTxqimti3VWWazyQrqtUnfC0nuRy0dc00NrPdX bZT6Fy1Sa9tCJktc9KOyUr6m1uKlczCFw8lnVv8AT6C5G2vb01km/lcgo/bKe6C7VWLJpitV JexS2O1065TVl1gSrfRLr9yfhVPdElK1btQFWrp1T6ll+E8UPjrau6yba0KrTpBmtz0mV3Kb d+6jsXz8nj4LlpaM4Lovb7n9jOnLZv3S/qNzGWoJ6gpZWeempdkpzhIz+RPCTbK427N1jPSR b59QWquTOICvGq4Wg61s201hBWG9I+hZfiiWt8QogqE8pRAqpZU4kpYWNH1JhQ3u/VWJ6ixV RoJVcqZ29y1WdB6eFzUQNKv6bfiaclHCwOta1q6tbrPRi8knhjCqoXUNk/gXbjm0UUNC22nX Ohqck8IWc2Uibc4x6CT2guRS9ybfQz6eirtlQ3kpWle7Ji09a/mFudNpPUW4St5Sm1XAVdX+ rUlOtni2EFntas+pnVVuVXCyOF/U4XoLcmsL8TPkW6E2WW+od3ZYSx6jVdqn8ibXaxn6se5u sW17lluJ4NXX3J9zwsCpyfHWEs9xcL3PLyTfX8Gt0ofu1HezrZQvxIXI+0j38dst5fQzb+Go u0pbnbL6GW2HLiSPk9yTUwEy8ISWJsa2S5faoCvFDmufUxs0k08Mdb8lVFdCzf6EsbS0n1RF rPbFlCCrvq2RzWtxWy5knnS5g4pviy/Mrlo20sfQzrebSlCNbTm2X2F2eU8VN1ZJPCIfI7Yq aN26ahD46uNS7hPUrbL9G49TT3pYRzKy0sm/UXHyVo5Tcv7InrDXRC27oyRxp26fcjkcPdJp x+QozqXzPRNnuV6ttZiAfI7WiR8fI3R2spZzKzu8qI0Ltvk2a6Y2uWxVonnK9JMd9qOJ3I0U 30rr0H/g7NVFLPsRZ9OnUXJa9cNN/ToRTmd006z/ANxON9zVqtdvte7/AAOf91x8HLZcllWY Nk6JJRt9Dh/kqVtVLjondx7up0+uduXX5S8smum3kPk//wBeiaX9d3tX21ZNPDn3eRd3X9i9 tf8A1f4i8bxuJpPVxq+512p8SnEMcuUnieFnmaXE+PiTdVWq7JDrzb80WAosNMvjsqKHhehi +P5WFatqa/aSpdlmKmTspmsyP9xVVaax6Ik2eymr2eKx+BTrObdCausQnkm3LarSehc2+CNK 0UGNquITa9TRXlzp2FZzhMZhv5aq6VY1fczfI3+l6DVqPClvrJF6ZiGp0JM9Oq7+T33cKPxN PkUZwyXZUsqt4E9t81WhnJ8L2vvWyafXJG5zEmPx3jdXBpTjdaynNmXrx35TtWnK4Udzlr4n C8JNvvJdLvc5Uv1LXIqvK1EmT+2Hb8sLeJwLEOfqV+z4XX9LX4mrunRszry2tjCS7GvJ2/LG 3i8bUVWe8mj8Xhq9qSswlzFdOprtStJdvr/4TbfcV8XheNqkz5fE4eej4tqq3o0aVoqy9zlm lqpOKPp1J2sp/LwfFqvE5H4/NVNd+v3Dy/46/jcn7nxvfVKbUtn6nb/JcVXwu/I0nT+r/kfO 8/8AI+R5KrxuzhYSrq/r3PTwnLn/AHS+P9znzsn/APT6bw/N8Pl49ydePvVxqdvFyq+atNPs fGL+L8i2XSMTk6fG5n4irXdF8yqynX69H+Zb9PG/4ctqTn88cfVX9/tp+pmXLycXEnLSrTFc xocnH/MV4+K/JyfrS9rXU+Xrx8/8hySps+/RHPj9Pr38SOl5yT+3za9j+Y83h561rxXV2nLa Pc4uXj5612WVoS0Z8nzfxl/GtSjtV25O3Qz5PF8j+Pt8lXEaWqdL9fHlJOPLz7flnvk8x9s6 bVFUpfVkWoqJJs8j+K/ln5lnTlhX1nue5W1LVbUJ+p5bx5cbnL2dJZZsZWcQvQdUn+l5RW2r mcPqc3I3EZhGZ58e5bjWt63/AFSvxKs6WcrL7nJyUlNLqW1WvHtq8r9RrrfVjs1skq4nI1x1 slbkbTWn/sTVNqOjB8MYTF+Gor20c6z2Dis7KP8AEaVNusPoZX20znJOqatda6sKRtjRohXV c9eg53OdDU4kxryU7a90R8lapSss127F3RldVTwpM+b4X0UuWvK3XCaMrpJY09S+Ors2xbXt hrQsnsm+DadKJIVUqOH16l1e2sQm3oS62pDakfhW9KuybSmDl27ZlvOTRcjpMOEyK1Sa3Fkz zWaridHTelH1Jryy8D9sx/SupS46WW/q+5jZF8h39PzIlW/Vgaup2vqNWpRt2ak1cUKe2Foy qq1m7PQj5nbFXPYt1bao2tDF2fys8kuOuZWWQ06W97RS3Vvs3SvUK+5tWSldRKlCot26znsV W9Zbtkhul3roRsdkluhMG56Oilqr3Nz2Q3aeNx/icz21sq6wXthPKhMvhNqYdrKqxgp224/q J5OLbX5U9OiClqqyjM6jd9PKtF7XXc5nJVrqGk/+hHJXZVquvcz49jy8vuTfemtN3tVbP3dx O7phQ3pJzPN4c+hrRKraaf4l98TbfK6t2UvU0+TevjWEZKypZVr06kW3btlP1a5LumxvSt0n ZE2jbK/V6i43yVcaDveJT1J5tXSb3Ruz9C22oS7k8Sd8xjuOrblNaaFtl8RIq101DUOTH5FX 2Rls0btZPdO4i01XuUvoMq7D+RptNdAtZpJ5kVovGFPcV3arf9pcZtXOMdS96Sl6GVv01a/E e/5HtrmBqxTiHCy9DP5ce5S0UrNYWqGqb3DWSb4L6nSbe+uPRjtpnQTdUnVshUbrExnqNaXW yXtXQh8rVkksMFx2dpq9MSVasLcsNGtZO1XdR9xJKuIhtEfJZ+5rI78t9GsIyeDtNYah2fYu 3GrpJuLfXBNLLOEm8oz+f5GnZR0wDwpVdNHox341T3PAvk465Uh+qzUzOg2Ho1mzhVevci6p tVW3u9DK1rVUV/MFmEuhcNaUVarbVueslVrLSn8Sa8U2SvKKWxuULZdIqVTHbqSnfkcpKCfl Smryn1Jp5G6a1w/8SeL5N9mju657dB15LKGsSTXjtyfpaUGN062iekl8X+T0U445s8z0NN3s 2xBFY/qRc2u9MDx7qhXdVu/D8TRaTXUyePatPU0vW1VJcnuVV+bkwrMvLst2kdDKlNzW569y XizVW4RLJuB0dk27Yc4GnbdD+skdcuexu3Ne0Dl48pPLnfJKbQqN11YKq16CcYOt44ydq5l2 wZpRbdX8zW16tY1Oe97XtkJXZRrY2zPddrEwRDSUdAveFEmPfw023uNcGS5t6iuq7jrdJepl xtKzgt4/+Et9m+qzqQ02oWSrJ2WDKrbcNlkTfLSnI24SC1a753fgKOiRhfOq0L1wtdVrdif0 4TyR8mnQpc+3FRYrRYTVmmc9uVUqylyqqadZkzbrasaE4y75StuNrlqmlnqaYa2mfDtrWKKB 1ee5mRV1dVWGzHZWrcaGjU/UUw8nSccShZeSt8Pb+RKsm8hVpyW8VXOWiW9VMsi1knIJpsdU FKyotY1tCrGJM9XOoq1e5ucEvFTw1DYnFaz1BuHgGpr7nkueyZBVt9B0SnLgisdG2aVwScfC pdavCyw3vh9z6dBJxaXqXfk+TMaYF4+yJ4+R3q7vDfQeldF9SaYr3KtNsvBJx9lZ2qngLcNe VpucdAabcvVBWzTybkzzExdlCW3C7FXuojozPd9h2utyqS8ZWlNPDT0B336vIRt65IrWG111 gl46mtG3MtwK1klh5JbmDS9m1ooRcDo5IvbMMmr09SrRYdRo7VSnqQr7XKUky9u1tQh0uZ6+ yqmVIK7b3rVGV7awNTiNB1ZbXunXdZa9hUeNBSnhYJcaImeVq97riQy1K1BLqxWco3gaq1G/ L7lWjTUjjsohodrTjQxIrHkbopI+arrNSuXj31g5lX45qjpjlXR413d50OtzPocfHPG5XQ0f M9X1M3j51uXI6lyVriJBJPL1OSj3adDS9rqyjCMdY12eH/P+Zbl5FwTimX6smv8AHvx+OvNR v5VlrscnK9/mPd15M/c+mvejcf4Hq5f2Tjwnp7uc8/3e7LxvMr5PHhe5fqJ87xOLnpV3aVun c8Pz3bh5LVpNavsc3j35eSyVW25S1Ncfqz+6Xwl5y+z1vM8ZeNd8Sc1aTPR/j9teFU46pVer esngcfI+S7ltuq2/YFz8qmtP0rJrl9faTjb6e6dptuPR8hK3ncalOFJ6vsvTa0mo909T5viS 5LVs01eG5nU+j4G68VZ2vGYPP93Hr1uunHlsfLeTxv8Aj/K9jxVq1X6H0+7dttRympPn/wCd vu5q/wDiex4lf/6tN+rRfslvHhy92ePvHbW97SlliXJLSbx3Zkm6w09TWa2pCy+rOF4+7flV pjGQVJrGk6hTCicBDT2uMdjX49xVVVJJfQE2m2yW2WmpyxjRNLVajo3Ve7PqS3Dz0BuFOv1L ZqBUq2rYlBCXQ568qs30fZGyadcaknE2LSs9GO+H6mabo4nKJ3t3UdSfwiqvWrwi96rGUY8l bJu3+JnW1t3uhqDO6m2OhXtdpzgq9tqw5OO6VGnWUpyya83yOKYc9SZbdTtniuyzdYxgHdPJ jycj3JIztd1s5X4iWxbXVSzbhdewQ+Nw1kxbdKTXPqTfmbibS2T/ACvhbyxq771poGHhHPx2 TcS4LVlW2DWYm6d7xiyidGCvmZ0Rj5XJbdWtnNdURTMtSxmza523cenXkdkm1Ae6cas4F5N1 VcfQuvJvrC6dDHXI6zlq+Liab0leprTkbbq8tdR18dfrtZJC5NqVrNpt6QYnKWrngJ2cqEyb 1hpRnuZWvasbXDJ+Tkmbw/odPOsa3fJC+NaDta9VtSX/ADMVy3eHoi53v6ExvfC3vcyslUs1 VKuDKkpw3kut2s11N9fBpQ+NK1nl9jofMkn7ehycdXa0WtpoK/yO21aQYs2ZfY2T0bJ1eLLd K+woSXZ/Ums1jBrZ1tl6nTPKeya26LQdYdvdlCtdN7VWBRtX01GeFUvbZwmk/UGmrS3kh3S6 k1dk85NTilrSlpWVJcYbX2IXJLx+MCdlgt4qpJtylku87ZeiIdvVkOGoeSYClpWdAd/dMR9A oraWj0B1TkZELe2k+pc8ie6cMSdYz0Jd22ktOxm8fhf5aQktzctk25Iq66om73KDN3aaqvxQ yJralE7Jtp9oYrV5J3V+mpM5mqirGnrWUuxMvquirssSFuWH7rD41urlmFuNvkT6Ivr/ACk8 OjhtstK6md090276FXq9PsD5WnXak31kePYHFF07Nwl0DjUuav6GFuXam3q39i6X30dlqsfU z6bam633t290BudU2lBirrv9ClfK3OPQ11hrZ8rUe7eTFVdWenYxvatre1QF7KVZrJJPC2tX y0rZvT0J3KsMVuPdDcT0J5rrbWrWV1GexrfjurOafTINNvMQuplxq36mUuVXTq1MDx7Lvjya s5n8DVWq8TtZgrtLZ2Jo/e03h9RZsJW17dHqL5ItCeOs9DGz9ZVeo1nK6lzU1pV1/S3I3KUr KM7W2RiZcfQdrKtWqyXDQrJtVtqaZ0kjjsp3LUV1uafVORfPg3wz3Kclq6eDevgX6x90W/Dv okvudunL4cNvy43H4kt9js/ZXiMT9Q/Zci7P8R+vl8G35cb5Ab3ZaOv9heZ9v3LXh8lf7fuT 9fL4Nt93FqoF+lnfbxOVvCX3Rm/4/nbzEfVF/XyLb8sK3xBChZR1/wC3cn/b9xLwORPWv3Q/ Xy+Db8uevJPUmzTOp+Har/p+4v2XI+33H6+SbflxpqS3hStTrX8byLL2/wCZD/27m/7Y/wDI fr5G35cdWmTbiTz1O3/buZabf8w34HNGHX7ov6+S/wBXFWKse6HJ1f7fzTrX/MaLwbxHt+6J +vl8E35cXyZH8h2P+Os3/T/mJt/Gcm6U6x/5D9fI8/Lh3dS96eh2P+O5O9PuN+ByrTYv/kXp yPPy8937k/Mzvt/HcjeLV/zGa/i+Vaun+Yfr5Jt+XL8sMpckHQ/47kU5p/mQf7feVLp/mH6+ R5+WL5V+JLvOh1cvh2cKrp/mE/47lnWkf+Q6cl8/LlraMov5E9MM6f2F0omj/wDkJfxt0taT /wCQ/XyNvy5rX+5Lvk6V/H8v/ZP/AJIT/j+Xq6f5kTpyTb8sVbAW5DZfx/LP6qR/5GdvFdf1 cnH/AJy/r5fBt+WfyJjVluCviTNq8vE1/wCZLrWmvLxyv++R+vl8G35X8kBa6mWZb+PpyV+4 b+N430f4j9fP4Nvy1+RJ4G+TO6DB2p/fRf8AyFup/fT7j9fL4O1+Wzv1WgfL9jJ8tH7Vesmn Hxy8NP6MnTl8G1T5ZYV5I/E2XhXsp9q/+SLX8fZ9aT/5odOXwbXNbLnoG9aHVXwbLV0f0uiP 2N+tqfjdDpy+F2/LmrdWfoUr9jR+DZP2344/80V+zf8AdT/PUdOXwm1g+ScBvg6bfx9plWp/ nRFvBvEq1P8APUvTl8G1l8ufUduUK/x99Xfj/wD5EV+zem/j/wA6J05fBtZq6iGL5emhpXxL Nzu4/wDOjWvhOcOj/wDnUdOXwS1zO76k4g7n4Fm8On+dEfsbL9VqV/8Ami9OfweflyK6WGau 1WkW/FX/AO3i/wD5EP8Ab8dFL5OP/wDkQ6cvg2udXSZpbk3OOhle3FVyuSjf1M7cvHjbeuB+ vl8G14/8nxPi5960t7l9T2fH8pc/GuSusQ/qYeX+38mm23IlZaP1PDpy38e/tcP8mdrwvLjN 9Yktnh9E61u9rW5f1SZcPBxy8JQ8YOGv8u0v0Ke8mj81cnHv5Wkv7K9fqYnDl6HlnzUpwvk5 K6WeDs8Hnpfx1WsO1U5UHnpV8pu3LbZSIqkcVq8njXmr/wDlU68uHaZ8G4+krWrplRbGSuTn pxL5HhRDPAr/ACnOuqfq0YcnLy+Tb3Ntvp0OU+m2/wBy7fZfJZ+d5HtUbnC9EfU0hVVeyg8n +P4+LxK7rNPkevodr8mk4Y+zjyt/tniG46HywFOXME1XyrFuNL1upKrx0jF+Nx/31OX6+Xwu 35Nc2GkOvJGjyQ+NPS1P86CvDmd1Gv8AzQ/Xy+E2tneRfJH1JXG/7qT096HXhvZ5dJ/80P18 vhe1Jcu76g+RPDDk8blb9rpn/vRrx+Fy1Ut0j/yRbw5fC9q5qwrPGWVWzUpdTr/Y8t3K2/ch fxnkT/TH/kOnL4TbHNXkdLSsg3nd36nT/tfPpNV/8hv+L5p1q19Sfr5fCbXLf3OZ0Kpf7nS/ 4zncJbUvqJfxfkL+3/MP18vg2sGlZe4yfDWdyPRX8fzJQ9r/ABHX+O5OqX+Yv6+U9izfd57p VrAnVadD1P8AbnOi+4W/jvRf5ifq5fC/1ebVworoc743h9T2f9vtEJL/ADIl/wAdd6VX3Q/V fgeXWjWe440lyen/ALfytYql/wDJEv8AjeVaJf5kX9fL4Ta858btrlCXCkel/t3L0if/ACQn /G8z12/5kOnL4La87a+g6024f3O+v8dzLVViP7kKv8bzR7ts/wDkifr5fBtczsuSNElgTjRa HUv47kqpcf5hr+O5Hmsf5jP6rPZrtXFyttbTOlXVbT03/HczWin6kf7bzp/pX3RenL4Ta4dj q5nJVW025Ox/xvM3ov8AMhr+L5Y/p/zIfr5fBtcm56k0u0o0Oz/beZJr2/5gr/G88Z2T/wCS L+vl8Ha/Lkrf7mnJyu1s4SN/9t5+1P8AMg/23nf9v+ZE/Vd3DtXEr2Tab9TS19DZfxPkK39M f+SLt/GczcpL/Mi/r5fBOVcz5MzIV5MOOp0L+M54l1X+ZEf7X5PSv/1IvTl8Has62hZz6hW6 eS1/GeVMbXH1Rov4vmSXtz9UOnL4O1cycOZHa/T1Oj/bOb+2fxQv9s53Cdf/AKkOnL4O1Yrl afqxLkUw+p0V/i+aFNfzQr/xfNuxWV9UOnL4NvyxV+wK+6Tav8bzvFqP7oh/xnkvGz/AdOXw dqx3pKWVayw1g6H/ABfM6xtc/gJfxnPC9ufqidOXwbflzfIl1CnLtbstWdFv4rmS9tJ/FAv4 vn61/Ml+vlfGJt+WXySibciZ0v8Ajef+z80Z2/jfJelHP4CfXynsu35YV5NmA+RtydVf47nT TtRx1F+w5dNjL0vwnn5c299cQTSyTbOz9hzabMFf7fdTFJkfr5fCzflxK1ct6hfbeqWprf8A jvIelHqacfg8y1o0P18vgmuZWUJdi9+d2pu/C5nX/wC25M14Hk/2OB05fBbWbvVrsykt6x0N /wDb7/2uSbeFzUULjbb1wOl+Dayw0noFsOdYL/Z88f8A239hLw/Ij9DJ+u/C7U2vuUzkW9Tu 6my8LyEv/ttgvD51rxvI/XfhLbWD55fuB8ig2fhcr147E/seVP8A+3Yv678G35c7hWdn11NK 3zJb8Hm//XYn9jz7oXG4H678G1N+WevqJc+Y7mz8HnVs0cfQh+NyJv8A03H0J0s9jaFyZEsN uRft+b/9dvsV+35H/Rb7F6X4Nr0ttewbK9jX8RNN/wBR7WUbK9g2LsaR/wBwbV3/ADAj46h8 dTTbXuT8VP8AhkEvip/wxqnH2LVKrSBqO4GfxU7D2V7GmO4sdwI2VHsr2Lhdwj1AjZUWyppj uJWCs9tew9texf4hnuvuBntXYFXukXH/AHClabmAtq/4QbE//YcLu/uG1dvzAW2oooy9qXYa +qAj4qPoHx0XQbtWf1j3V7tgT8dOy+w9lei/IqfqEv8A4YE7aroS9i/pb+iNFHVj3V7gc7aj HG/tBoqVazX8B25OOutl9wV6vRsCHx1trQh+LxvWq+7N8ChdF+YHO/D4utV92QvC8Z/0pnZC /wCGOOwHH/t/jP8A/Ghr+O8Zf/jOqPUI9QOX/b/Gf/40Nfx/jL/8VfsdST6tC2/9wRgvD8da cdf8pouHjWlUvwNElXrP1Y8dwrP46dkJ8PH/AGr7GuO4Y7gYftuF/wBC+wv2vCv6K/Y3hd/z CKrr+YGD8Xh/sr9g/a8P9lfsbpV7/mOK9wOd+Nw9a1+wfBwf2L7G+O4/xA5HwcCyuJP/AOKI dKRjgn8KnbC7/mELuBwOr0XjL71M7cfL/T41F9Wj1Md/zFjuB41uDynpw8S/BGVvB8u/9FV9 FU9+F3CF3Lo+Yv8AxHP1rP0Ev4bnf9B9RgMDUx8x/svP/b+aF/s3P/YfUR/xIofcu0x80v4T nfRfcH/Cc/Zf5j6R1nW35guOvoO1MfO1/g+R/qtVfiaf/wDPK+HyJr/xZ9BtjqhQu/5k2mPC r/8A4xwa2vb8Den/APj3i0z7meonxp4tL/8AKSnZepFcK/h/F/tf3HX+J8WrxU7sC3RomEY/ s+DTZX7DXjcNdKL7GuX0/ManrH3Csf23CtKL7D+DiX9C+xtCE7VWG1P1AxfjcL1ovsNcHF/Z X7Fuy6ZFNu33YCXFx/2r7B8XH/ais9Y+49s9Y+gEfFTsHx07GiSS1/MaSAyXFx9g+OiLbqsN pfiLdVALZUXx0LnsmGe35gR8dQ2UK9/Zf5hRyPWF+IB8dSbLjpq4LVH1t9huqXVgYzTom/uC U/0x+JqvpZlQ+wGWxen5hsqbbQgDLZX/AIYbKmsBEgY7K/8ADFs+n3ZvAbQjmfDP9UfQa4ar Vt/idG0W0Kx+Kj/9w+Hj9DaEtWLHcIj46AqVKx6jSnuFRsr/AMMPjqabQ2gZ/HUPjqaR6htA y+OofHRmu0UAZ/HXsPZUqH2/MHW3RpBEfHUfx16DdL/3fZD+J/3P8gqfjr/ww+Oi/wDcr411 bf4h8VewEbad/wAx/FX/AIZoqrsEAZ7K/wDDD46lwOAM/jr/AMMWyv8AwzSGG0Iz2V7/AJhs Xd/c0gT+qAh0Xd/cNle/5jd6rWyGmnp/gFTsr3f3DZXu/uG1vq/sT8PrZ/iEV8a7v7j2T1f3 Eq2Wi+5SVusATsXd/cHVdW/uXH0CPRARtXd/cNi7v7l7QgCdn/c/uG1/3P7j2v0+wbX/AMIB RH9T+5G+sxvbf1L2dx7Egqdv/c/uG31t9ytvoG30CIytHb7jSv8A3P7lR6BHoBLrZ/1MFR/3 sr8Az2Cp2f8Adb7g+P8A7rfcrPYPwKhKrWln9wi39z+4fgH4EC22/uf3CH/cwj0CH2QBFv7n 9wi39z+4lV9Ug2f8QBrCfQIXYyryJ6Mn5UnEjYN4XYEl2MXypdQXIn1JsG6+goRl8iWrYt67 jYNoWmBwjmd0nllq67jYN49BR6GXyL1G717jYNYQQuxh8lV1HXkq8tjYNY9EOPoY/NRdQfPT uXRtCCE+xy8vNXbCbClq8dFqTR1QkPBj8ldZcB8iXXBdGwlDMXdPqx1uo1Y0bKHoBlvSfUm3 Im4TGjf8A/A51zV0bKXJToxo1/AVuPdrj6HO+eNZKXKnDUsaLXj1XV/i5KXGlp/gSuTuTa6T y4RLZJo3hdgMXZYUsqVEyNitAMlyVaHuSLqNCbPasKSVeoO9fxAc2eiX4hFuyJ3oHddRouLe hL+Tpt/MN9UCsmgFs5H1r+FRqlutn+QK6YvkqNFfGus/cS46r+lA7rQl3S1kaNEl0SQ/wMq3 TcE/IphyTRv+Ao9DOt16jd47lGn4C/8AiZ/IivkXcC49BPHREO66B8ijI0aZ7B+Bmrp6MduS q6gXHoD+hj8y1Q3zJLqNGun9Ipf9v+Bnx8m5Y/xLbfoN0J7/AO2v3Htt2SJd41slIlyVf/5P tAGio+r+yQfGnrLMb81V1s16FV5Oyf4saNFx0X9I4XYzfI10/MG7aNpDRrnsH4GVU+thylqw NI9A/AlWT6ku6Q0afghddERvTErpYGjWI6IWeyId8YYK6a1GwaR6B+CIlayLd1kC4+gR6IhW lxI3ZLMsCn9EJ/REbs4Yt60kaNNq7IceiMVZXX6ngXyUfUaNXC6IE0+iIVqtasN+1asC5XZD w8pEbn1cfiLc0s2Gim3/AGjz2SM3Zz+v8kVv9RobVuiQKj7pfgR8i7i+RJv3Mmwa7O7kraux m7pLUavK1LsFwuwoT6aGSvL1KVoxJNVpC7ChdjPf69QtdJNyNRrtXYW1dkY/JGG8jXJjLGi3 WkzClDVkun5GPzpYnI3zKP1DYNGp/pE1bokT8nrr6Evlt0/MbFavjs9WkvQFxJa5M99sN2X4 Iq14zJdRpsSWgbF2Mvk9RfNCyyaNtiDbXSDN29RO/WS6NdqHtRjbkiHOJK+Ra7kNF7Rwjntz Q8ORfNbMf4E2K6YQbUcfy8ieqNa8rhy1KLqN4QQjBXnO4c1eZbA1hC9pn7ZwkG9LsBo3UlXr pl/gL5PUn5fXBNFxV61bBUr0rBC503CaDdOExqrdX0qvuNVfoQ+WEsi+TDz1Go02Pqw+JdW/ uZ/I+41ydJyi6NEq9B7UZvljqJcsqZA02ocIx+XEsduTb2yBrtXcTS7/AJma5A3z2A09q6/m LdTuyVeOwvlGip7Jh7u35kLlh5D5cwBolbuDo31ZC5H0Qrcrq4cZA0VfVjj1Mt7haD+TA1Wk erDb6sxXL0L3uMQNRcerCPUxd7Lqia3s1ljR0R6hHqY+kyKu22YA2a9Qj1IV+hNuaq1aAv41 1b+4bUZ/uF0yD5pykNHmV5bRrgVrtEquAhWPn7WFLksw+faxKrtipCo057F2q6f3EqGS+Zox 2Nvcxxj1HajV8zgqvO+pjas6jXUnajT5rxjQFzNmaUa6DwlgdqD5bPUpcj06GfokVEvUdqKd 8yiq8rawQ+O8TGO5apWMF7UUruzhsVuWzeNEZqqWUwTHajT5rWwwfM0oTwZbG8j0Hailz2gd eZrRkpRkbSbnQdqHfyHOWJ8mZ6sx2t2NGs5L2oN7duxo+Wy0MlTMlWJ2ob5bNz1GrWSw4ZnV wV6DtRS8i0g+dvBjHugaUMd6Ohc7x6E25nbq19DPH4hb2uNR2p5avmaxI/ms2lWyZktYgl1z pJe1V0/NZadCF5Fpmcmd7yoShmamdBeVG9vIu57Drz2aUmGJJtZzCJ2qOt+Q0KvlW6mP6tNB P00NduSup+S1DRm+eycoyknLJeVo6X5TmSPntJkqwu8irS3Uvejd+Q25/wACXytt26mcZ1Kh fgTtRpx8z1bK+a3Q5t3ujoaVtCL2ofJzWbwy3y2WF9znTa1LTknajW3NZwRXyrLHQzrZt5HZ JrA70bLyLdNCbeVZ4nBnesQZJvT1He/I6Fz2iGP5LPU5611NarA7Ua15rVT6CfO3kyjcGzoh 3sVXybtNS1zWp1MdkMi9m3CHasul81nUVOV6JnO07DrXbqx2o3/cW6snl8mz1ZlZKqnuRdYx r0HajqXk2ShuRW8l6dDFVhZ1EquyZe1WuheTZKUV87awc6ThIdfbhE70a/ubSP5m229WjJ02 uSV6ajvRuua22CFy2yEd2Z2Tb+hO1G/7i2a9A+eygwhA5j6l70dH7hpSO3lTUwq5WRNL8B3o 0+a2WFeazMU3bTqV+jGrJ3qNFyw+5quZpRoc0tQn1YTKgvajZ8+IB8tm89Dml2wUpWuo71W1 uVw5J4/KdZrbQm1W9TOIyO9Ty0fNZwW+ZuGjDLKTjUnanltW8sh8jTlE2WiWBNJajaqnz2iS 687WuZMLVTZTaxI7UafK5cdUC57YTyZbuiHOcjtVa8nK4x1E+Vtf4mdrTCK6wO1RT5epn8z3 eg2n+qPQW2cjajT5W3KE+VslpoUNjaNX5DSgS5rL6kWq3poPpA7VWteZr8RLmenQzTiJC1Y1 HarV159V0JtdtamDTSaNK1aXcdqjf57YnoZW5LN+gtsD2zrgdqK+R7clLnt+Rld7sdAUxBe1 Frme7PQFe05JUai1yidqL3u1ob0I+V16ifueCdrthdB2qNq8jajqWuZxtRjG3PUjWxe1V1Pn siPleqcGd6tOA11HaopczWBvkbeNDBqfUt6E7UWuS1XgKeQ0smS1yFar8B2o2+Vu2WO3Jar9 GZJZkbXtgdqKXK90IuvK6ue5jVtoH+Q7Ub25nZyR87hJETCgmlZefsXtyVr89oC3LZtfQzS2 2cibc5WB3qNHzWbRVeZy2znbaErP+od6Ov5m1HYS522c1XmXiBzGVoO9V0257L6EPmsnNTJ7 rEzFh2qN15TTTZV+V2e4yaVo+hFHCaHfkrenO9X3KXO9V1ZhMr0E03poO9Gq5HLH89qqDCr6 P7l666E7UavmtbQy+ZrBjaroty1E09e47VHR89t0TkK+Q66mD43GCXMaF7UdHJyrVairzur+ phWYcgpcfQdqOm3M1o9DP5rRMkKfxM9udvSR2o2rL1CGzaqRVknlIwrBYNa6SFsB6ASsuA2m ir6A2BOpLWIKsuwpWjCYEpQehdUkTbGUFa8vDWqXvq7P+mvQxSh9xw0pHS84j8RQ735OWqpL aWlZFalq+3qO0Cr2ZQ+RUhVqnPVsKrRVWR7Xq9AmXBKJtWywx7ZXqNtE7o0KoiKwLVdivrqL VQAlWGC/UV6Ev2kMVX1E1OmgVaYMGJqu4Pj7DTT+gaOBphOr1QlX8jZdg2xIXGbr1SyKr3F6 4CqVcIpjSl+JcbV6t36ZwZyk12Lhf1CdE1gumJspeBuk6l1rVVmUn26idpWEBnt92FgTpD+p URllJJkTEqkqEJUiUzV+3A1aQuM9q2yTarcI6GlVfUhrqDGVVOpdVKCsKxacZIMrVhqOouuh s6qBxlSDHM+Nq3oN1N7pPQmceoTEOswG2HJpYbcpV6hWTr21KdVGCplQGuugXEbZWehDqump tsSwxKkoJjNVjDGqwvU11UEtxkCJnKFZtGlapsLVzDyDGVrYwLbEM3STCOrBjL45yCr+RvVY kmenUqYy2JoVqNYNFVv7lpQQxg6/mLa5wa7VmR/pWgTEOsYITdjoWuRbFXPcLjGucsUN6msZ C66AxLThJkqrjGhptzgu1ZTgGOa1HqWqQirSmVE/UGMqVx6AqxKOitV1IsoeAuIVYUrUl10t 1NlXqxNN6Axlas66iVJ1NlHYHDQMYquXHQr1KrR6jVduoTGdnp2Ytsm6qQqtBcRtlwOvHmUa KmZHowYyVVaWg5K/dFuGy7ZtoDGFa7tQdM5RptywXaAYxVWngezJtpoOAMXVg01lFwG3rGCo l6f4Ebm2mlk1VdUJ1iH1CJl/gwSlSWsKH1FZQ8aEVCT/AABNRk0T6kVrn6gK6jJObZeDWyrt gnHQCFRtSFZroa00aRMdegTyKuRy30HWu0pa56BWLWJQLGppq89xclWmEwtvQnOq0LayugJz nQCdmBpNYXUdcscS/oDCtXczOqj7mlmL1ZQlq5C0K31Ko+jWNQblTAGarH4j6lpSVtmHH1CM LL3Idaw2u5pdZklKCGFSuPQbsPOqBJNsojR6E6FwvsNrogJSbz2CW0Pqu7KrRJ/iNXyzskso f9MPua8lFmNBVp01ImI2r8ibrBdpTgdoa+gGaUoarLhGqaUSJ1zKwVcQn06kWaLahz3CyTw9 QiK1eWVtllJYSRcJx6EXEP2YElEwaNpkNR7uhULa24BysdB9Z6ChTqArKQ2epTTWYwS2lr1C ltwCr7XJcKMMTW7QghpPUEsQ/wADXamvWCFTMlMRudcroZv9WpveqajrJD4np1CY2T6Fr8yV SNBbbJkaVbNoDbLFGZBNplVaaYWSaEsMHIE31S6BaU4XUbW5LoFk00AtrY0slpRqKI0CE3In TMo0VXaoKoololVNZ6EtYkBNbVgzS7G1o6E1UsDMitm3CN3UHRaoIHXCbFZSPVqCbKXkKa9y jqCS6ho5Qm/dKIocdBPLSFrlDayoCaHTH0CdIKt7c9ycLIXVw3kHZwLeKr3OAlpp4EnGRTub XYaq+uEMNUmnI97jIsTgVnLLhpasdLw3KJzlIpKc9QujbiWUnKlfiHXA66QQS9ZYldRHcbyi HVNpLUGtnaMBJk1kpQwaarutCKstoN7XIL3oGlXWSo6kPCkpWUSgum3jJDrGg1aXDGrTj7A1 N01oPbOEaWUOGLESVNZrs1kI6M0rDIs+2oXSrqxp9CV1ZLwRNWrRrqVun8DJe7BVaw2mF0q2 SnOpbtKM7UjPqN0zC0BpJxoaTH0IaQlMYyQ1rVroK2ucoittqnqNMoqegnaciVugqLJA6rcN slaeoWXuRTVK2Qs8mVvQqnuTnoDWmMkuzC1kkQ7QE1skoJVugp/pZLlYBrWFE9RJpL6kK8+g 7PGAuqraJfca92OpjVyaLAFJSuwkK1sk0tteeoNW1meo1pKCHP4CroAnjLEljPUd23XHTUVH LgCV9maTiRKHgHXasoIndJajbkxeNDRZTICjlT2HuScE40rox2rhMqhOWFX7mmCw46CtX7yA 241GsIm7jQrjumoagIjSWilZqiC2MlU96hFE3WZQ7uUmiG1M9UVulhCtTdC6oTWqLTmWDUuU RShQmhRmfsUoWBJpLDAm1pcCf5kPDNH6lDTjIlDErR0Jth4wBo/a4ejGmkZbgXdgU3tbnqaV dbra9URbOo64wiEq0prDIVZqCsuoNtYRRNqw12ZShKX1JX6km5TLaVoXYmGoWHD06EzKhl3W 7DJiJQRa/RK1DjeNBcPupIk2UUkpb6lJtZIdY+490WIKul16mWmDRWkzby0ANihpiSxnqaNS pLiJslYd1P4CecodnOWFJZiehrVbTBtzg0+RP0YWNV26ERmexO9TP3KVi41ibU3LctRJODXo S3DGJjK6jQ1UuuSbNNtCs9qlZIh3UqV0JtWRp5nQjcpa0BVPSBqrhCbgrdjAVLrP4FPNYQq3 znQWsoAcVf1M+rXQu6TjuiLY9wQ1bEjspSkTS7iiyhIBqHKRcZlE1oob6lLGGgmGtMk9WNvS NfUIlpgZ6Pd21KtyaWJaiY6MNriegG6Y5lCVZQ2tuhcUmm0Sg1BZ1IE5kqU1kXr2NE08lxGM uS5bWAtRaoVXAFPOWOrxklN2foJKHAVdXtfoDtOERECbIiqXhZ1QO7ss6EOvXqVVYIqqvGcg sPBKt0LTmoBM/QrXBOjxoFs5QBnRkTLKbaQqqfqA6uOo2k89SEmVlaALbOROrKUxIpxDLiUp 3AqOynsUk086FpJOFoBiqvWCk49Ea7IeCb1hEMZOsZqXuf1BJx6CjowBW6iynuKSX4CApOWO MSPbCG17fULiLXbSgpCThwO1kAnVzA9se5dBp4kSUILg2yvUSUrArWyOJSCFZtoK/wDboO8Z SJrZJPsBbjbjA66IVUmp7DUWl6AxEt2z2KSmyFErGpdYSh6lRLeWOr6PQV66PqJtN/UirS3O SLVZW51ldBxnBdEZjHYTqmkmjR6QglNakMYrDguv6nI9pPJKwBVnItCJcZwwl9Rouq620HtS yLdK2hJQnWUzNxMfYas046MqzlxGSAr66g1kJ2qGDtLhagPAPuF4nBN5WC0XsQnoNuVkVZa9 OxBMQybLMPqaYkm9ZU9UEJS9MQU5dpehCth4yzTCr6gxDrtcmjSaglZw9RPKhFIfxqtssTmz K2v8UJJyvQjUJpalpJqehF9ZKWVjvkIusQQ9ciTWYJVmp9ABPLXQIh46Gd7POBVlw9Ajoo1I 7TauOhkn7pG11r1Cr2qJQVWGZ2s04egld6TC9QNePsa1slhnKr9EVvbeANYSchDh9jN6pvQc NfR5Kp71ZehVWmRt6FVrMkTE2cy33LXt0MbJm0N1gLgWddR6fQzhlZjs4KYUQpWgO0/pJ413 KdYkgSUqeo1X3SCT1HHUYYi3XAbsKTSGtVgVayo7GsMQ84SyibJtONUNraVVjDGSwlOJLf5C lPUSW6URMOU3BVH7iVWPcKuNCmLvbMLUVbS1ARadyQlXqgC8LKFuh5BOXPYeyZQMJ2zJbsoh 57C2OPqGyVHVEQ01VJLqVtRMfkCUpx9guBNtMj9SnqVWsJyOqcQxgl4Fekw09Mjsm0XEouLh VSsCprH/AAx0muo4XRwTKJ466zqJLEDvbr1IrMyEWqw89RclJeBzGehSa1nAWM4mC6va4Y3j QiZcxoVWqxKMs5bG3jUMTJEL/uRFW84NV2eg9qZTGMdhJS+5cNt1Gk6SiImHpoZWn8DpvDIt XEgTtHVMdVKK0UgRMZJnuOepLaSkC1trp1JvMrshziVmBpyXALFofUbl2gLKYRW2czlDBDmU oFuaWfuXZdZhipEQOqrlWTI3Yxr2IraMNBuTtPQuI0pqaRu+hCwa0e38Sts9sPA2oLs0Zzgl jOIbDjcvJUKBOvUyik4ygvpJFbDyUNOdCepolGhLJlMPdOoWyLa7FbGXKYSZNLJJjVYXqOlO jGLlEz9Aqmiq1RpAwxmq4KrVxkemBppLGgwxm6xoSlGhrIktryMMKqwx1jqS3DIbzJcXG9kl oZX6FLSRdRiWKmJb0Er7XL/AzbchaVlGbEWrtk723kTl5JrCwxg13uMAqwxRBVXiS4uBYeRN oLWnXVkKsF6rjVXxAO8qDPPUm1WjUi4tJE8ibz1HXOTR5RMSw1DRO5rTQKpTCFdQTqgb3Imr SQTGoLAxcCcz6jVekAqK40oUNkxMKWloOYQkgalYGCqwljUl9F1LeiSM8z6kwatJr1MqpJjT tVg64wMFNpArolpaMW0YKtOI66kw66GinvkmHOS4liaP01LedQhaobhiRcQqy9Avjsav1Fap cMY7XoO6hmqbiSVV2TnoSQxg6YRPHazsm9DprVW+glVJQMTGUOR1lOWabW8C+PahhiGsyVEv OpS1kNqWheq4XSAruq8la4mGwaznUdTDaJ2NZLVktRu0aF6tTizdZgvZOUC1BWj6FxepqnWC lRIFZNDV5wyYvVERJDT1Ohx1MbExMZus5Y9mJ9CkpcvQfUiYwrScGjhYKdUJLOUXDEqiw+qE 6ZNUoGtcjqdUNJuVqRde19DZrAtiagYmVzL3BtW6I0OmvGkDotUOp1Y2rGSq1zPU0dEwZeq9 U2SeAo5w9B7RfpyOq9RtScIaUaBuhyG5fcdF6h0UYHtzPYUgrSa6L1N17ajWVLX1FMA7xgXg mGqxknUtWUbTNLOR1MWlINdCRpyslzFwNRgJyEicMmGKrRMGlXDJT6DtMGsXE24ZIXHtNN8o luWOqYTU6idHqWik1+lk6p1ZptImto+hus4ZlarROiXinrHRlLAJSi6rVdx1OpLSSN0OTRYw yXVNk6nVG7toNZYKpTrH1L1JxEFR0YgTnU1OLXVLUFuGDrKwRV5LkXFNYJcPRFfQEpHUxm0E dUaugQTqz1ZNYBam20n4+qJeK9UJZG0vwLVegWXcdTqi1YJVXGS1gpLqOp1Qq9UUkDQSy9Tq e3qibpPJeHglruTqdWL9zNNqeg6qGA6nVmq4aKaisDUA9R1TqhccrJPxpKDaenQTzgnVOqKc SSj1K2bfqEOIKSxDGGBcTjJnujU1a7kOuZRcXMH6sj9UKILRcWxGyc9RfH16m0YyKcw9DOJ1 ZJwsg3OSrKUS1IxnA51RMvqCs4hg8IiHUbmxKaRah6GcMKtM4NdolC+pW8sXAqdhqqZK5A3w akaxW3sCcakPk6CfLChAPE+g5Ri7YyPctCUaztCXMol3TRKs0RNXadSU8i/UKIFTWyWYYrVM 62agrdLyZ1NZ2bbLa6vQcJNNFaouhUfdE2Xuwxtr6DSjXJVSlLwS+5VWDWpExP0GlOvQzdZg tvELoMA7QVVzlmVphDqvuE1tWusDnoZ1tEsusMNQrLMjtTILqNPJfK4SX2KsoWCJgTuzUi4t JMmyawS79tS3loiWCq3ZM4zk0nbaHgl2yZQ62jqDcqGTZjemSBxCS6jjITGAdtsIqHLWCX3H klym+zAMasvp6mW3oXDCnE6C0CH01GtJLhiq5yDT1JTdcsN8v0LiraxKFtlwJ27jraXgmGHE eok51FLkqUXFwWRK1hGmsQJvOSriNAepTrgysnECpY0lIDNTqN5+gQNRkG4aTHsM7VhpjRVn 0Fu7hZRbI1VLCJppJlJQLai5xA8r5RnoOSp2k29Oomnkt7nA5xglqFgqqkoab65J3NmqWfQH VadRi4EoJdnMhMEu0ZQww211FVyjOzc4HmJNq1mB7okzrZoFaXLJqqVi9xj6opFFqwbkyFhi Tn6EGu4W5Mhia7Fg0V0TbODOyHp9AFl5Q0i0kkERoXRC1KEkwhoqmwjAR1HMIBFNyKBxBBP1 Jk1XqTdQwiXaAfdDdeq0HtAWWXu6CjA+hFTEORx1CXoK+mCiVaJBeugssWmANMrA9dSUEznq DGip1RLcPIk4FvnUClERAmpJraBu0ZWoAm19UGmQT3ZDIAxpJitYSsupRcdhRDEnOBuxBWGJ ODLdkTsUdO+MGbujJWyK0oK3Vy1yI5VaByEdDyDcnOuWC90ZIG8FJkSraDUoot5It2KbQokg W4uZM2uwSBe4UTgmWOZIE0La+paKKYzgaTZagidrIYemom+oNysCUDDDmQSwUoB2gonXUluP VDs5cktdygVlYrdiBJQVoZFwmjPbDBsTsXEw4XUeyUSnk0reHkliYm3HglVawbtktImGIVRx IbowU/zJhiLLoQy2hWXY1hhNYVhYsim8QJVgliYz2z9ClWC0slJGcTE7SVxs1TguIGGOf42m aKkGriBSMXqx+MpcfU0bkmZL1XqSUFKqagJG8aF6rhWoSlCgtOSXYYmJjoP4xbkzRWUGep1R 8QfC3oaplqww6udcDmS/gnU1d41B8i0Lh0Y/DGB144NLPEoSc6jF6xm6LQHxdh2cDrYuGM/i cQiPjsnDOmUxSgdXP8Tk1VGtSm0tBq4sOpOjtr0ItXEm+5MixMLxc6o3g0fHGXqCcMc9R1Z6 picCf5jdh7oM4mKpTGdROhXTBm20xhgdRpISbeoaaFxZA3DwDwTLbkbcooHnA3UhZZeRCB10 EnDGshtTagYYWo8LXMk9YL2poqnkTe5ChoSAvdC9CX3YTmSbWgYLSE0OuVjUFhkxMVtM3qik wsOphOs6hsacsaw56lfKrLOowxG2Q2wOewk4Li4izjUEW41QkpFhgalgqqZRT0M9SZRq3BM7 lJLtkEpQCnMPUTmJGkmOz/MaahWktVkVkilKAbTb7mbWS1bqZzkuGKiB1alJE2ywiCimhJQy U9UVqFxUAIvclqUQxJdR3caaEzADyhN9ysPXDJ2xljFNMt5yjOrSZUwSim5QoDdEyJ36FFLT 1BaCrbA8TgBz0B2nDJlaFNJ5XUCFNXJSfVA6qPUh+hBq2mQ2Q7YBJxKyijTDHscGUmlbuc4A m1cSgw8g7airaSBMP8RpIJTeOxNiIs3qToaN4UoFSZkdlRuHOj6GuxJSTC+jkvYLbDlDfoNV llJPQmjOZ1CITk1S3YJhARXutC9uSnSH7QclNYXrnXBKlONTWy9NBbUNCVZ0ByilVpEqrbGi ca9Rqy6kuZyPa08mtEuqTw8FVq36EOjThaGtU1lk0L9ODSZ9GZt5C1mtdCYNM/iCtDIu2oh4 YslGmmUTKCtWyYcZWgGhP5Ew+hO521A0mBt9jLMwyqy8EDdmG7ciXVodqxoNhpTt+oOwtvR6 g0XYaqvI5L3JrOphasZRS0wQaalJGLb6Ds3qBoJshNtT1GkygVpUg7SJJjaKiqlYklYHOSBN 5KkIknTIGln2EQ8gmA90ag7yK0MSCk7SOl51B1gmsrBm1nVK2TRNPUhruDaKq5j6FWt2MVfo xtyFaKxLtArPGCZ7lNXuJV4YlK1JdQNZnISRVMrL0Gi5hYJ3dATghy2A4LrJCcFq3cDQHaME T6kWsRVuRpxklWI3Abq6ZO5JmJScoo1tkziyCRqzeoQtzQm+o2RK6FFNhva0FgPUClcre2oM nOoVcExWiUBuJVweSoLMEyR1YqK3sTtjIrWYmsADtBVb5JqvuXXj6snhVRAJJBta0GiAhaib LXYnRlxEiTaBqGDaARayZsaePUDRtEpTgle7BatGCBbXkmDSZ0IbyDDWMjTklvHoOr2ooqrb BpWXYSy56FKAohxkz2wUmPdGWAlQHXMMbsKZZQoaHgc9RNgCbJaDQazqETscyXxrLBJrUrDx ozNgjbH1FtjI1Og4lExMQwTaLakFWMjFkZobUmlknoCfc0rF11ZVauy7lwhp7SIztRpg6w/Q 2VpFOgVEEfq/A29CdmGUZ2lCX5Gm2AVFkCOslWq3kuIYNyBhteGWqOZNaQPTQiM9ncbrCLbE rSVWWyCoyXYSAlV7lKkjlalKy6mbBLU6i2ZlFuCZGCbUkSr2LanQiTQFXGRQ9XktOUTMExVQ kjJpfgzTdiATXQmM4mHD7EUlJGjfUl4hkwDt0DXPUAWgxcXX1Jhtj6gr6MuBTnA03aSXacot LRkAnjGqJlj25cA3qBVbS8jraGzOYyNWzgYim9SU5wDtOupNVJcVq2oM5G23giIEgcqBb+hL rgqqS9WaCbQ949RNRggI6j1cDmKwhbp1KKamENqB1h1wQ7J4IrSYRDhrIn6DfqEJOEQkpwVb GCW4coocBV7dRPpY0qk8NkuCVdErWB2q0CfcmBWUsbr3F6jtNqwnpkYmJdoUIndGhSRLbRcB M4ZSwvqTtX1kNvRZQU4hYDoD9NUSm9CouqG3gjTBacrIDspWpKcajTWjCyQDV5C1zNqMlKso CW+olZyaJJuA25kAV+hTgXxPVFKpBLtkacPI0sitDx1M4hvJnt7FwwnaD3TsLqnqDsVV4KpL OA2ja69BNlCtXAmpK3JomehVJVLSEgc9QgaElLMVulwXS70ZnflJyaJdCWjRtTEhW1eo1dZ7 X0HWs6l/LX9M5KrZF1WeyEJrojWzTIsyhKq0KVMkz2K3dAK2TlCdIHWzKbmGBk6whbE1gtuM ISaAhUKdUupW5aEPXIA6oWwcrqVqTyMnZJwx1aYnXOhbyh5QlCcdymo+gk4B2KqdpptTyZp9 zRMgaSjA3ZdCU/sCZA5gJ6oluXAjUFK2Qs8k9cDbnAtQJ6yQq6waStHoCQGUPqaw0LBVQFAm i+R4glNL6DAogbS6k2xoE9GA3UIkJiOxSZVQ8CTgB9AE8jSnUWGVXJkDUPAQO2SMoobWQecD VpJmGUVA1BG/sPcpFFaMHZN6EPOCPQg11HMMzq5BSxRpMLIVtpJm50E+xnRr8kv1FPQlJVzq wWFOpdDWpphqTNtN4QOs6F0aKySxqVKepz5mBu0Mg3knctGYu+fqEyUaOIJmMkS9ASgDWZWB OehLzpqNW7gUm0PcmpWpDYL0ActjpBEwy08ySgsyXZovUh6ACtI1gl1f3Ep6lF7ujJklomXq Uab2Cs+v4MiMyXZNwkZ0S2+gK86i9RNSTRVW5Ks0ngKYTEuzGht9QlsUS/QEoKCXKG6kyyk5 rkAmIZKcYY6JpPsKy7IGlWyLmMIziB/phvKJqSrs5Egs5rJKtMIzpqlpkegLT8RYLpp1QnWG WuTjhq6c9GjPci6urlPKBwyK2QJ/Y0KS1BJNinJVcZRlUWTQNyNMdV17BLDSwT0yGiyOre1y ii6vBFpq5HX0FMoimrDs10EqhXKYEuLPUI7gkVrgIzVs7S7WVVjUjbNpLvhzGCBLklQEzkla lJYfqUXCgi2socaZyVeu1pSNVntySnBpZNZRD7iJgWFA6pPXUVXL+oRCnsyUkJpvTUlamsTl CaThepdXCWNQa6oqzTCr6F1lMDSLURBLT66F1BA0+gQn9AsgpNQLcngroROSi90FbjNuQagi rnqiXaPqVWDO6llRVbY9R1WvqJIqjRMAq9wVIL650E12GGJchZQgdWTDSLgUiedC6ruER6kC TaKmdSdjB1lZAf1IdcyWlOB7drCYzgJbNGskNQyZDE04+rNMokIb1K0tsnOpSpI7cb17AZg2 XAbZcF0LcN2jHQL1hYJSkB1yOxLUaBIDlyO0sEwzqBkyk2hwKqgILN6hkraKspdwCWwkpegl l5QAQrFqkvA/jkB1tGGJ21gHXIaIgrCiQUZkWZkV1kocinAaihyQDGs9QVO4bYAchunQmMlR gKbfchuNBxIoZUG7DExqsZB1cEDs9o5SWSHXcx7enQnlPJ39BTFYHtBqF3DSUsz0KTSQojA2 pAbbRM/Yp51EokoUdQaWpbXRkpATHUdap50HrgEp1FA1JG026A6p6DRk1BVXBTYlGhBD1Has Q+pUCeYQDWuQ2x+Ip6sE+qCGqx9SsMz3NFNgUqrUyvWS1aVCB51IJqpwXRi6yQ9SeRqtsZ1B 1mUuplJStBRTrp6E7RK8lKIaKqaqUVVZgIWEhRD+hRLSf1E5Rbr1D0AKT1ETaUym4JgqJRGr yy5xkiyyVFqqE6YFWxo7SMCotuuUDhrsxyZ2tBMA1qEE7uw5aHUOlpbnQXX0En0HKUQXAmmV E6CbjIJzoFK1cT0BzCNdUkibqMozRFW51yXbMPqSltyUnKKiNrWQTn8DTd9gx0GGMduvqOtM 9kylVwNuFgnVMbc3C+FJ7quf7XJztFJ4gG1PqFjPrArKDZQ9dBWrHqhgyrmJKjaVRKcrUpqM dBRCTKb69yoyTichSjuOudAf5A1GUE03L9rDQTs2GpnyBe3DBtQoBqYJ0wVdaUfQptKSbaYM 25JlFTKKrt1IaxJMsTRpuSvPSCbX3QhQJymXAQp9TRVaYpjQFKywK2/kOFZpsztlZCrh+iIu tYlQKE1BDtuaemB4SnqFXaq2tLUi2nqVa+MGdn27Aa1pjBG3IVvKyJLPWCDK2o5G0nlDeh11 nCmCpwQ1OpSrgJhrQSzqUoQ9iZNVGv0KiMozynBazqNQ2l1FBSiclNIgnYNpIafQUo1FJNLK 0EmhOnYSwVDdugK0BapC1QVvukThky0xvJkK1g3uIG10RKUIgrdDwJsUFY0KFVZ+pTTCIyhb p+gCTxAlfuKW9ASKKUMKyJKQ4024ehBTtA5Sr6hWnRitxtPJNNVME2e5yhOssaXUBZHV9AjI LsUKJtAku48JlJgLRi3ZwOXqwalygBMFZE7ocGkJ4QEpz9AVewlVoJyA6uBp5E/aEpoBtdhw S2+o3bsATlpiagU4lgmUVVsdoeVqTPQltgU2NOSGysTkaCehS1IwE5Ab1Gsk7s4KrMNgJqQr 6kxOhWQHDcgtBzGCVbqA1r6MGpC2WkDlTkaJmcFaoS93TQcuVggSBgkxfU0HqitNCGoGrRgg rDEoQKGOyxHYCYgG5YLOGU+PRoCU9rDcDo5hBZRhk8B4so6i0YT2CJcgDZSaalEbY9RLCwUX aOhMRqSnjJWxzADXu11CGhJwi0nbDCJT+w7C24nsLUAefwHMitlDaIEsCSK2uGKqbCmoQokt uESk2A1bbgPViSUSwxAFLX0IXcrUTS1QQ1kUSHSBuGsagSnKyKZY09o69fTQCUslXulp0J6e okpzYCk5yiesM0410HdZKrGMAk24Lq3XD0YlNWgg2/ciGnDNXKsK7mwELLgFBapGZElmAo3Y gnc+pcEWrjBKmtL2JT6CdHAoaUCKrDKVocaEVTRVlKkqFkp6ErXBVk1LYENwEsdu3caUkAtY KShZyZqrRD7AaJ5hDtyODPTUeIyMFp7nDBrLhi6Sic4fRgCRaUkt9By+pQVaThg1DKVZyhbc SwqplRJm05ktYyNLdUmDKzHMLIWegVeYATlIiY+httgnbJYhVcoKvuERlDpj6E01S0Jh69yr LqtBp+5SRWcNIONd9C7OLehPTAxAocId3OnQiQ3diIW9podU9SoyhrGOjCkslKziTOuHJXUK WExwmTaV0JSepRrXILSRLSAssQUG7ograCI6FJToBThueoQCrkpoB74Xt1FW0vINQJPI0F7R lEOzZV3ODOmudBqLTjAKzTBxqg29RqrmXgVqxoCUYKjvoTRLUBOQjImuxRVrZwKznItw64x3 IiFaB7lPoO1VoJUgLpy1oJpxCKSLhAZ1fQE8wVarnAKsvIAoRVX31HtW6K6AqpOAgt2Wotzk btjAowAmusiSK2hMgIXUqYJbfQoUZkrA011FsT0ZDSq5yDcZWg9j/Ai1ZAhdzR9wrVLH5FNF GbvnJTvInxyWq7QEs5DrgqMBWo0J0glr7mttJYsOGTROpNalpwGmhdCwxJdGP0ACbUTZW3IO G8FO2AM7JdAeQdZBYKoXcK3hQxpCdYZKHR4Y1aMPoKwl7mBW9asjjSs5RSUa6BphEuhPUqcT 3En3JcgOUgWMDaTIsmobJiC7ho03Izsxr0NKqzn6ksqO4alCSjUqlpww3TAWS1REUsOBN9hp TghrtoQW3ugnLYqt6MpajBFSssbeYAieSlyTDHE6D3djShoCUlqCKprCNE4Rmq9SgHbQzjbn uU2U6z9AImRO6b2gNw3MED3QUo6mTBMg0blw+gVcZYTuEoSAFHUmYBpfiEFFQtCYnIOysOAK tUlBPcWn4gCwAQSwKSQ1GgpkcRkASaWOgLuyktUtRKuQJWmBt5XoVtjUh5wATkpd2KszD0FM OAi3nIYeepKclVmQG66E7OnQbt+QXeTKCIwxOmMBunA23XQ1FRL0C0PAPLKxBRKr1RTUqRpw gWSKHD1JTS0C2dBQmvUItZZLSbklYHMFFNKwvjwhbug1ecEU6VSUDdIIWclu8oiYztXsNOGl 0CU1jUTxk0L3fYW9LHchKXgFoQU8SJaeg4lMiHVQPI0jcyGociVoG0wK1eAEmkOv5AD1EtYk N0/UnMjBcwoDLRKeQT1kB3TeSdXGg90wwbbyTWkZ0DX8SnWXnQU9O2hWU1WZWqNJY1p6g10I IahytAhr3FNbRtLBBLT+o9vUqUtA/UzYl26j/Vlg5Q0BNk51BOHkqExNwBTw5YETuHX8gpv1 EoZDeQljBd6pmaTNE5UCynARNVmDVLBNVDLklUo6kuVhF6obtCIiEwaHKTmAs10KIrVyMpWl QGGMBBSpuSbJdowXvhEBCWgm1AbsSZ1ZEazESJ+hNregt35iLratvbL1IUv3CrfWot04ZVp9 RWbbyK76IHbA1ITTq4Gm0FbS8mlqwIJWWL0Gn2CZKE32F1LgbUgwnZwSmaKsonTAUpzIk51B YF1CKhLUHWBbhJt4RNkAnnI029NCHqOdoVdknhkpvQN+ZB3h4ImCOpNk5nQopE9TCrhZFI8o nXXqbXDQ1OpEwU3KkYG79wSghW6C3dgrWEtAjaYq0v1L3wgimmlPQE0wVu/UztKZRo2glPJn h/UdbQ4ZBeYGkuoVeCuvoRUWU5J1+hs0loSkkVGeGNYE1LkaePxGimxK3Ql50CtsgWsaBbGh DtAq2nTUiNJgqIRla6wVTkzAFJMlzJT5If0E/d9RoTt0BWaIkW8umtXnItddSFboUmka0Fn0 Be15Idv+g5kmi3jR4KVn9SIxIWviES0O0BW2om5X0JTRFW3KlDfuMtzq/qG7JRVlKEpS9Spk GmA8pT1GukkbuhaXYBNRgNNC/qTjToBOz+pDTbG8DcMBag4gaUEym9rAlvIk+g7La+5MlGgK 3QHbEGYR0VagUQ5MVeP/AEH8jX1A2bklZRl8jk2cNSgiP0uB21lit9xq8uDFTTrCGmZpyKYA els9SLuTSOplZZjUmIdLPVmrbZjVOJLmCxqLgrVfQhMW7JpTs4HVt4M7WlCVuhVazP1ItYbz l9TJ4At27g+5lG7QE/6WBq8ZFuSckNtjVU9QHuclr3Jk6YKiNCaIWGa7ZIaeklqzf4ECcJj1 yKZyyXaMFFaY6kt7sic6kKXkC6l64MpaLUsAfthlejFd9BziRoWEpIrZSNIJSZdAlP4AniSo 2/QhZnsQGuAS6hRIaeQBit/gPRhrgIE5KXpqKIGmiBJzqD7lEvWC4DX0DQn6jTKrTdOpFqid h1t3AatIrWkGuqJmQBOGWtcEYQ92TNFXzkhKcEXuxbp0Go1TyaNJ6GCsHyP6DRvtBJv1JV5W dQnaNVacidZchW8v0DclMk0J1zImXvTRla04Q1DTgJjJEx9QXJDzoXfA3b7kNYnoR8nYHfoi Sq1STFdrUyTgd7YfcuhpyFVkyltYCrtJKjZ+16iWBbpZaaY0hJNuO4tvRl73qDbn6gTVdzVW WkkupLL4Vo0llMzthiT7kWbNDet11L3ScjtKLV8Iiul2ghW7mdrzkXyIDS1YcgnORK/fQUxl aAxb45yibWdSVZp+hpaLGbnuljKj6hd9iU2nHQb7lBJDcFpQidvcgvjYJuZRbqu4lXsJBO6L YFa06lbU9cMl1g0Cug0nox0UCdoYBtzke0cprGqFMhUuJB9xNzoTVvQC92kjbkSpBbpuWCIz 0ZXqHx211K0wyh0jqXR9OhjPQae7KA1t6mTs0zRXcbXlGTlfQlRbWYGqpSRrk03YMVKxaacE w17jXktKM/1VaRJfZN9kzu1KWDFJpFO22smjVNybcVZ11OelnZZ6G1HqyaappZ7jScSTa0uU NprPQuqlpSY2bmOhs1l9hvjQRlVPqWsyugOVqFYWGTTVKmM/Uqq3OfQzvmGh0u1KGrKtoxso iOpXyTgnRlgqra10BqRJzhFzODapicAkymP6hTXu/SFtJ/IluMovfuUsmjNqXIZqHUlXbwBS sXHUxuyac04GproePoTu6MNyaIdmm+qM2pbjRtr8SXbPqFkoTI27l9Camqb6dSbe3I4wK69m pexp0UjlJxb7hELd6Cnc5ZNrOqvWLJDa7IiurNd0zBdXWaqn9TRSLECV41KsU5glrKZavKwy ZhlxcL6jVd2CZCt2lIMaJNKDOIYO8idu4MSnkqz3ZRCeWFbKGZ9GFN4JracdjSyleupHqVpN 3tyOj3L1LfHuz0CtVI1TqxWQ4hytSdrRfKpUdRpS2NKVBSW0vlUuqE08FxLgNrRAl2fQN3QU RoFXDzoUE9ylfEPQpR+JNpIKrn0JbWkAhJ5Fmmm1HUFWHIL1KthehQWS6AlBM9hb5wwKbkzs 4XoU7OCXoBE6FJ5wGpouPqgGnj0CtSlSC1VdQM1XGAVDbZgEkNGbr2If2NXqS4sURoKYKagz s4Iych1JlNk5WAa//9k /9j/4AAQSkZJRgABAgAAZABkAAD/7ACFRHVja3kAAQAEAAAACgADAHAAAAA2ACAAIAAgACAA IAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAA IAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgACAAIAAgAAD/7gAOQWRv YmUAZMAAAAAB/9sAhAAUEBAZEhknFxcnMiYfJjIuJiYmJi4+NTU1NTU+REFBQUFBQURERERE REREREREREREREREREREREREREREREREARUZGSAcICYYGCY2JiAmNkQ2Kys2REREQjVCRERE RERERERERERERERERERERERERERERERERERERERERERERET/wAARCAVQCAUDASIAAhEBAxEB /8QAsAAAAgMBAQEAAAAAAAAAAAAAAAECAwQFBgcBAQEBAQEBAQAAAAAAAAAAAAABAgMEBQYQ AAIBAgQCBgYIAwYHAAIABwABAhEDITESBEFRYXEiMhMFgZGhsUJS8MHRYnIjMxThggaSwkNz NBXxorJTYyRE0oMW4pNUo9MlEQEBAAIBAwIFAwQCAgICAgMAARECAyExEkFRYXEyEwTwgSKR QlIUobFiM9HhwfFygpKyI//aAAwDAQACEQMRAD8A8cMQzqyAAYAAAVAAAAwAQDAAAAAAAYhg AAAAAAADEMAAAAAAAAAAAAYgAAGAhiGRQel8i3+peDN4rI80WWLzszU48DO0zFj6AIzbLcrc 2lJZmk4NgAAgAAAAAAAAAAAAAAAAKAAAgAACgAAIBiABgIYUAAAAAADARC5djbVZMCwhO7G3 jJnK3Pm6WFs5N3czuvtMlr0acG23fpHa3Hm0YYQzOTe3127m6Iy1AxbXr14tdTcm8xCAjqYg AigAAAAAAAAAAAAgAAAABgFAABAAAAAAMAAAAAACAAAABgAAAAAhgAAAAAAAgGIYgoAACAAA BAMQAIYFAAAAAAEAADAAAAAAAAAQAAAAAAAVAAmFQGFSIyo17Pez20sMY8Uels3o34KcHgzy CRs2G8e1nj3HmjWu2HDl4vKeU+r/ALenASkpJSjkxnV88CGAQhgAAAgAYgAAAYAAAIBgABQA AAAAAMBAAwEMIBiABgV3b0LMdVySiuk4e7/qJKsdtGv3pFkyO7duwsx1XJKK6Tibv+oors7Z VfzSyOBf3FzcS1XZOTKzU1F1/dXdxLVdk37ioQGlMAAAAAAAAAAQwCIgMRUIAAoQDEVAADAQ DABDAAgAAAAAAAazQgA723xijB5lGkkzdtH2EYfMsWmcdfqb2YBAB2YAAAAAAAAAAAABAwAK BQAAAUDAACACUbcpZIvhtG8wMxZCxOXCh0be1UeFC5W0gMENnTF4miztopVovSacsMimDxaC J6Ix6SLHjxFTACma1LAhalRlrRT3ZHDedctxtQsmKDqhswpiBAAgGICIDEACGIBAABFFxFRo mZ2AgAQE4l8TMjRAobJ2niRaCDoyVHV28jrLtQOJt5HZ27rGg17s1zZqkmiJduI0kVHPeY2r 363MhDADKgBjKiCxZKgRGUR4gHEAPHgAH0XzwAAADoCCpQxAAQAAAMAAAAAAYCGAAAAAAADA AAAAAAAAAAAAAAAAYgCgYAQAAAHW8m3zsXPDl3WesrXFHz5Np1WZ67yjffuLemXeRy3nq3K6 YxAclMBAAxAAAAAADCgAAAIAAACgYhgAAAAAAADEADAQZYsoZGU1BVkzHufMYWcFizh7jfXL zzojNuHbTi22+EdbdeaxhhDFnGvbq5efaZRUDNuXs049dewAQGXUwEAUxABAAABTAQAMAAAA AIAAAAAAAYABAAABQAAADEMAAAIAAAAAAABiABgAAAhgACAAAAAAAYgAAAAAAABDEAAAFAAA QAAMAAAAAAAABAAAAAAABQAAwhUCgxYvJANCLoW7aVbkseSJ+PCKpbj6Wax7sZ9plCO3m1qe C6SFIrN1Cc5T7zqRGZ6LJfV2fKN5j4EsvhOyeQhJwalHNYnq7F5X7cbi4o3rcvFz6YvlPXus AANvMAFUAAAAIAAAAAAKAAAgAAAAAAAAAAGIAGBXevW7Edd2Siuk4W8/qLOO2j/PL7CyZHeu 3rdiOq7JRXScLef1F8O2j/PI4N6/cvy13ZOT6Ss3NUytvX7l+Wq7JyfSViGaDAQwoGAEUDEM BgAEUAAAAhgVEREhFQhDAqEAxFQAAAAAAQAAAAAAAAAAAAAdva/poyeYrBMv2brAr8x7q6zj PqbvZzBDA7MEAwABDUWwAQ6NgnQKvIB6aKtUGHAiSjCUslUihuojRDZ3JdBrt+WL436gOYOK lLupvqO1HZWYZRr+Isc1DBUiuSCZcm3srks8EbLewhDvOrLvEbyTfUHbfJe0JlKNmBJtR6CG nm2x0SyRYiLuLpYam+A6hUKjR9BHTLMsqFagVUlzFpfMmxNkRXpa4lV1cS6TK5KqOe8zGoss yqi4yWZUZrRwbCAXEZQhDACIDEAgAAEIYBEJIzSWJqZnmgKxDEA0WwZUTgwL2RWDJIg8yo3b eR2drI4VhnX20jPqlT3kcamWh0N1GsamAck65eniudSoFBgcnYJBLIaFJ8DSGlRCY6MKJARo A8AA8aBdK0QcGj6Er56FBgIoYgAAGAFAAAAwAAgABgIYAAAAAAAADAAAAAAAAAAAAAAAYCAY goGIYAAAQBr2O5e2uqay4mUCVXvrV1XYqayZM895Fvv8Cb6j0Bwsw2YCAgYCCpAwqIKgOoVE MAAACgAAAAAAYCABgIYAAm0sWc7eeZxtdmGLC663a4jbe3ELKrJnD3fmkrjpDBGG9fnedZMq qZte3ThmvXbrTcnJ1YgCpl6DEAiKYCABgIApgIZAAAAAAMKAACAAAAAAAAAAgBiGFAAAAAAA AAAMBDIAAAAAAAAAAGAgAAAAGIAAAAAAAAAAAAAAAAQxAAABQAAEDAQAAABQAAAAAAAAxAAD CnMIRJRbxyDVTITdcwdTdOsNTIjABiCoDyCvIQAM7fkl2sZ2nw7SOIdLyV0vtc4suvdy5pnT Z3xAB3fMAAAQAAAACABgIAGAgAYCABgIYABXevW7Edd2Siuk4W8/qLOO1X88vqRZMju3r9ux HVdkorpOFvP6izjtY/zy+w4V6/cvy13ZOT6Ss3NUysvX7l+Wq7JyfSVgBtAAAADEMBjEMjQG IZFMBDAYAMigAAAEMCoiIkIqEIYFQgACoQDABAMAhAMAEAwoAgGABQBoFFsDp7J1iPzFdiot h3Szf/pHH+5u9nHoNwazCtcOAYHZgYJ8xa6OqwBllqxK73SLhVWoI6dvy35jTb2sLeQRx4be 5LJGmHl8n3mdVRSE7iTosX0Ayy29hCPCvWaFajBY4Il2391e0NMVjm+bCFrj8Kr1DrOWVENy IuixbATjXvNsSilkiq5vLVvBuvViZpeYOWFqDYG1sjWmZja3d3OkV6hLYyeNyYGp37ce9JFM t9aXFsUdlZjnVl0bVqOUV6gdGZ7+PCLYv30uEDbWPIdUUYHvLnygt9LjE6Kg3isSucE8GiDP HdwlnVFqkpYopuWEsYkrcNOIFj5FZOROzZldywXFmdrJOqyW3EZO7I2QdUUbq14bwJ2ZVR5n SzC1jB5AioBDEAhDABCGACEMQQii6jQU3EBnAbEAicSLBAao5EZIIMckUWWZHV20jjW3RnT2 8jNR2ZLVA5rwZ0bL1QoYLsWpMu3XXLpw3rYgFeQsFixp1yRyek6VzItrVTkS0/MyKzwLgSxf QRouvpGDLhCrgA6cAA83Cy3g82OVlxrU23Nq4y8RMzXdc5Y5HpleOxiuW6YoqN0o1RjlGh2l YRAAKAAGAgGBQAAAAxDCAAAAABgIYUAAAAAAAAAAAAAAABgIAGAAABQCKAAAAAGBO1cduSnH NHs9julubSms+J4k7Hkt6dq5SjcGc9plqPTjqRqByaMBDABiABgICBgAFAAAQMBAUMBDCghc uxtKsmU7ndw28avM87ut7PcPHIluHXj47v8AJr3vmjudm3kcxurq8xCMWvdrrNZiGAgI2YBU QDAQyKAAAAAAKAAZAAAAAAAUwACAAAAAACAAAAAAAAAAKBiABgIYAMQEDAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAABDEUAAAAMQwEAAAAFB4JdJUIBrF0WLCUZRwkqDAQxDTIAaa9Igo8wB uoh0CoACosxVqADqxAAAMQyAAQwA6Pk3+pX4ZHOOl5Kq7hvlFmte8c+T6Nvk74AB3fLAAIIA AAAAAAAAKAAAgAIXbsLMddySjHmzh7z+okuztVX78vsLJkdy7dhYjruSUV0nC3n9RLGO1j/P L7DhX79zcS1XZOT6So6TVMrb1+5flruycn0lQAaQAABAAAADEADGIApjEMimAhhTGIZFMYhk UAMAAQxgRYmSFQqIioSoFDTKNAJUCgREB0ChQgoOgUAVAoSUWwVOIREKEqirgAaQdFkIkrcp ZIBV5CNNvZTbrLA1W/L4rF+0gj5dky/eQc7bUVVltu3G3hEui6Js5X6m/Rxrfl1+fCi6TRDy lLG5P1G13G82QzOrGVdvZ2beNNT6TRroqLBFbaTpi3yQUfHDoAk50zCsnwp1iSpkOoQnFPvY kk6YLAhO5G2qzaiukxT8wc3psRcnzf2BXQfMy3d9at8dT5Iz/tL9/G9LDkn9EabW1tWso1fN gZv3d+/+jCi5j/ZXLmN+foNzb/4EQiiGzswyVXzkXKkcqIGJgEmQY2yNQGOpEYQwEGSq8kUS jc8LtN0Q5XVdxRzb12W5moW1h9MTZCKtRSIqck2tKzeCHKlUo4pZdLHatzuvs+l8jfasRtYr GXM57bzX5umnHdvhFFraV7VzBfKaqJKiyXAkJ4nk22u3d69dJr2Yd5brHpMNmVGda9CsTjta J0LrejlyTFy2oSFB1Q2dHEwAAEIYgEAAAhMkIBEJqpMTCMkiLLJrErAQAAF9tk2U22XlEIuj Oht5HO4mzbyM1He2suBTuYPVhgPbSxLN3GqqanXWxdLjZjUUukdRAc+z1kCQMYAJjEyhAAAY bd2F1VTxLY24SwkjgLVDGOBrs+YShhPE7zo8ndr3Ozk1+Xkcy5alF0kqHYs7qM8Ys0uVu6qT R1llc7K8xK3xRXQ9Fd8qjPG0/QcvcbKdvvI0jCA2qZgVSAYBCGAFAAAAAAwEMAAAAAAAAAAd QCkAwCEAwAAAdAEMBEUANRcnRKpss+W37vw0XSMjENYnes+QrO46nSs+XWbPdijF2i4eYs7G /e7sXTpOjZ8hlLG5L1HoVBLJEjF2rWHOseUWbXCr6TdC1GGCRMDOQDIjIpgIYAAAAwEADAAA BiABgIApmLe7+O3jRd4jv9/Hbxou8ecuXZXJapZktw78fF5dduyd6/K9LVIqEBh7ZMGAgIpg ABQAAADEBAwEMKAAAAYhkUAAAAxARTAAAAACAAAAAAAAAAAAAAAAAAAABgABTAAIAAAAAAAA AAAAAAAAAAACgAAAAAAAAABAMQAAAEAxAFAxAAMEAxlMLVd09xUK5NydXixJVDgW20kkIYAZ U8nzFUAAQAAAAAAAABAAAAAAFQHa8jt/qXOqJxT1Hl9nwNvGLzfafpN6zq8/PtjTHu1CADq+ eAAAAAAoAACAEMo3Xjq23t6a/vFFly5C1HXcajHmzh7z+oox7O1VX88sjh7q7euzf7htzXB8 Cg6TVnK2/uLm4lquycn0lQAaQAAAAAIoYCGAAAAAABADEADGIAqQCGRTRIiMKaJERkVIBDIp gAwEAwoVEaCJ0EVEaBQkFCoVAoPIWrliEFB0aINyeGRKNic+YMItrnUi5Lgb7WwtxWq/KnRk aYbjbWV+THHmMjnR2t14taU+ZfDZOeMnUtd9zeoam5dJEShtbUORctKyRTGVfQS7TXJgW631 EXIjTniSqUNFvw0Ko4stlgsDnfqanZU2oqvAi9Uvur2/wBRxq8WSOjISSyVBiKNxuo2MM58v tAvlNQWqToubMNzfym9G3i2+b+wqt2Lu8fiXW1H6ZI6VuzCxGkVRe1gYrfl7m9d+Tb5V+s2w jG2qQSS6BuVRAHWACCAQxAITAQCIkmQbbwAY0yqd2FvvunQsyh7i5dwtKi5gabt6FlVk8eXE yvxd2/lh9PWXW9iodu88+fH62brVt3MLaovmZLcdasmek61mt2Y2VpisfebLOyr2rvqNNqzG 1isZc2WHn25c9NXq04sddgkoqiwQAI4O5iYxEEZKpyd3DTKp12Yd5CqqNb1Y5JmM9mVUXGSz Kjoa0do8gQABQESQgEIYgATGAERMkJhFE1QpbNM1gZWAgAAJReJoTwMyNEXgURky+wyiSJ2X iSo7e2lkdC8tUDlbaR1odqBdO6drlzQJSVG0Ixe72RF5khLMkFIhJ4k2QeYCAAA87G9F4MTd sSsB+3OuXjQlJLGBZa8wnDCWKK5bdxyK2ms0bmB2tvv4yydGdKG4jcVJqqPIaaYxOh5duJa9 EsUazYmJXXv+T27/AGrbocbebCe072XM9LC24KsWO4o34OF1VqWbypix4wDfu/LZ2HWPaiYT oyQDAoAAAAAAAAAAAGACGAAAAAAAAFMKEoWpXHSKbN1nym9cz7KJkc/IcYSm6RTfUehs+SQj jPE6Nra27SpFIxd1w8zZ8rv3c1RdJ07HkUFjcdTtJUyAzdquGe1srVruxRoSSyADCnUkQAKn UCNR1AAEMgAAAGMVQAYCABgAAAxAAwAAAx77ex28eks3W5jt4OTzPMX78r8nKRLcO/Hx+Vze yN27K7JylmQEBh7oBiGFAABAwEMKAAAAAAgBgAUAAEAMAAAACKBgAAAARQAAAAAgGAhgACAB gIAAAABgIYDAACmAhkAAAAAAFQAAAAAAAAAAAAAAABQAAAAElBvGgmqAIBVAgAAAAQDSqAAO lMxV4BQPIQAMAAgAAAAAAAEAAAAAQAICgAACAAAqNfl+2/c3lH4V2pdR6dsx+XbT9ra7Xflj L7DYddZiPnc2/lt07QAAG3ECGIBiAAAAAAGIYGLfeW2t7Htqk1lJHk95sruzlpurDhLgz3JX dtQvxcLiUovgyy4TDwQqHX8x8lntq3LNZ2+XFHIzOsuWQAAUAgAAAAAYAAAAAAAAAAxAQSAQ 0FMYhoKkMQ0RTGIeJFMYqIdUgAKNi8RZIePUA9InJIenniOiQRHF5L1jUG836iacVwqPW+GB UONhZtU6yaUI5uvUVvmx5OgE3cisYxXpFPcXZ4aml0EeNeHCoLBU55hFXh17TxLFBKntHQki olFKtUqE4rmRSLEQSXQSIpEihjERk8oriBOEu1RcMy6pRFJYLBF0Tnt3jU7KgADoyo3O48CO Hffd+0z7Taa34t3HjR8esN0q7iOrKiob6UwAlqUe1LqSFKTk6szbptLoWTIW9/B4Tw6QjXkB CN63LKS9ZLVH5l6wpiIu5BZyXrK5bqzHOS9ARaBll5haWSbK/wB5cn+nADaVznGHeaRm8Lc3 cZPShx2MU6zk2wFPeQWEU2ytePfy7Meg1xtQt91IJS6QKLe0hDGbqzTCWSgseFMyVnayu4vC PM6Fq1G0qRWPF8TltyTXpOtdtOK7db0ii3s/iu4vl9prWCosEAHnu127vVrrNZiGACMtGJgJ kUwBAZCZTejqRcyElUh3jitaJ0Ndt1RTu4aZVHZlU7yvFtMVewB4gjTIEMQCAYgEAxECEMRR CRmmqM1Mz3EEVAMQAXQZSWQYFkhW3RjZBYMqOrtpHZ27qqHA28jtbWRmdKlV340kVGrdRxqZ WXbu9WlzrAgoCAy2TZAlLIgAwDhUCo4jkokVOmYpKotLK8qzUmVSgpDaoIuRT4NchwUrT1Iu TLFRlyL7fnM4KjiarXmtu7hLBnNdtMolaoDL0aSuKsXUw7ny6FzFLSzn2NxcsPB4HYsbyN1U kdJtYlkrg3trOy+0sOZRQ9VO0prDFHN3HlkZY28HyOs2lZsw49BFty1O06TRWbZADwFQAAAA AGNRcsEqgRGa7Xl1+7lGnWdGz5C3jcfqM3aLhwy63tbt3uxZ6ez5XZtZLE1xtxjkjN39lw83 Z8luzxm6HRs+TWreMsX0nVoFDF2tXCmG3hb7qLaUHQCKQDEQA6iABgIYAAVGFAAAAAAAwEMA AQwGAhkAMQAMAAAFOagnJ5IZyPN91pXhRzYb118rhzd9u3uJv5UZAA5voSSTEAAAaMBDAAAC KYCGAAAEUDEMAAAIoABgAAAUAAEDAAIAAAKAAAEAAAAAAAAAAAAAAAFAMQyAGAAAxDIAAAoA AAGAAUAAAAAAACGIAAAIAawEFSiTk3mJRb6BAMxMVOUYJUi25cyADpQW5WTBAFeQmRQFaiGE AAAUDEMgAAAAAEAAAAAAIqGIAAAEAQAAFQHX8o2Wt/uLi7K7i5vmZvL9g91KssLazfPoPSJK KUYqiWCRvWery83Lj+Gvf1PMAA6vEBAAAAAAAAAAAAAMQwAAAAON5l5HG/W7t6RucY8GdkBL hHgLluVqThcTjJZpkD3G92FnexpcXa4SWaPJ77y67sZUmqweU1kdZtlnDEAxGgAAAAwAAAAA QAADAAAYxBUCQxIaI0khkRkEqidymSGMKrTrxLIRhnKrYDoMmE1cUe7FEat4hSjo8hoi4FR0 pTpDhTghhAs+gaWFGAyoBgkSoVCAdACESQiaQEkTRFE0QNDBDKAVKSJCaqAy+BQnUugc9/Rq dlTzAcliI6MoTtxmqSVSyKTVG8SIATdqvFMon5fbli16mWUFpQGZ+Vx5sivLIcZNeo10QUAz Ly6ys2/WSWzsLhU0CowIK3CPdikS1dSCnMTS6whOXMjjwRJVySxNNvZ1xuf2TO2017t663bs ywtSuOkcTXa2kLeMu1L2GlJRVIqi5IR5t+S3t0j1acU163rQ3UBAcXZIBAUMBDABAAAhkQqZ DIsbqJozRi3cNSbMVqVGdS6lJHKa0SoddLmPPy64uW1OoIjbdUSZ1cAAxAIRIQCEMCBCYxMC DdSm4i5ormioziGwARKLxIjQF9SDzJIjIqNViR2NtLI4dlnW20jFHS3CrGphZ0O9AwPM3t2l deK9MAQAZdlcnViGMKlp7FekC/R+V7QNYc8/9vLyTg6SCp2d1tFNY+s5Fy1K06Ml6OAaqiuh LVUaQEKBiibiQYFkJVJSjUpToXxlUoomnxIxm4vA0tVKJ2qZFlRqt72dvFYo6Nrd276o8GcG LcSxKuMcGa79jPu7lyxGapJVRy9x5XxteodjfztYTxR07V+3eVYujNzfHcx7PMztyg6SVGI9 NesQuqk1XpMVvYx289dNUTrNmMOXbsXLmEYtm6z5Neud7snodtcszXYonyNdDF3rWHEs+Q24 4zdTo2tlatd1I1BQxbauEFFLIdCQiBUFQkAEaCJBQKiAwCIgMAEAwCkAwAQDABDAAAAABgIY AAAADEADAAIGAhgQu3Fbi5PgeTv3nem5Pidrzm/pgrazZwTNezh16eRAAGXoADAKQDAAABkU hgAAADIoAAIAAGFIYhgAABFAxDAAACAAACgQxAAABQAAAAAAAAAAAAAAxDIAYhgAxDAAAChg AFQAAFwmQAAFAABAgGBFIAAgAHTAMOAAkGHETdQCnUQAQAmMTAQxAVDAAIoAAAAAAAAAqABA AAAghiACgAACA2bDYS3cqvC2u9L6kS2Hl0t09UsLa48+o9JCEbcVCCpFZI3rq83LzeP8dfq/ 6KEI24qEFSKyRIAOrwkAxAAAAAAAAAAAAAAAAAADAAAAAAIzhG5FwmlKLzTJAB5nzHyGVqt3 a9qPGHFdRwz6EczzHye3vO3DsXefB9Zube7NjyAFu429zbT8O9HTL2PqKjogABgIBiAKAOgY IBDoxrqHXmReiNAqNyqIqGNCoNEUyRFMlUipUGiKJIjR9AxDQDHQENAFBgkSSCEkSSBIlQqE kSCg6FQhEqCCEiaIk0gJIkhJE0QCGMZQhgABSpasisnDE57taoyzESksSJ0ZIYBQIVEGAxBR gIYAFRMCy3ZlcxWC5slsnWklvSKXgXW9tKeL7K9pqt2I28c5c2WHDbl/xenXh9dv6IQtxtqk V6eIxiON6u86EJjYjLRCACKYyNaAESAiGCGQ6gKtcsSShJ9A7iDHq5Yk3aoq5smkksB41LtF VJPoISaWbqyc030lTjyJdSVFyrgjnbqNJVOgZ9zCsS69LhjkmYpsPgXsx2pUZsR2jyGIEMoQ hgBEBiIEAxAQkVstZVIqKJLEiTmQAQxDAsiwkKJJoodp4nV20jkRdGdHbyxM1HesOsaGO4qS aL9tIjuY0lXmanXVrjuNmcUsiRXN4mXpIklV0IltiNZIsSt/h/lProBr8L8mnHMDrhw8v+3n 9pvobiNHmSv7VTXNHlbdyVt1izubLzRS7NzM1to5ys17aStuscihM9HKEbiqjm7jYqWKwZxs ac2TbIpVLJwlbdJIEQVtUBOg5OoqAWRnUszM2RbGZQp2+KKnWLNRGUKlyirUp4PMjSVt1ixy g0EZ0weRrOU7Nm38zcezcOlbuQuqsGcGVtPFEIznadYsdYuXoJWk3Xuy5ott7u7YwuLVHmjm 7XzDX2ZnQ6jWZfqMezo2txC8qxZacJwo9UezI2bfd3IvTdWHzDHsZdAB55AZUgGIAoFBUAAo IkIoQqEgCIgMApCJCAQDABAMAEAwAQDAAAAAAqAAMAAgBgV3p6IOXJAed8zu+JefJYGInN62 5VzZGhivpazEkRGAEaAAAUAAEDAACgAGQIYAFAABAAAwoAQwAAAigYhgAABAAABQIYgAAAoA AAAAAAAAAAAAAYgIGMQwAYAADARUMBAMgqSilm2RoNIszUolTgJItWhZ1bFK5XCKSRenrTN9 IhQACnPIzn2XHuAox4LpFUiiiXSFeWAgAAACKAAAAAAAEAFCAACGAAAAAAAAIBiAAAAEVAAA EAhkrduV2ShBVk+CKZROt5f5S7lLt/CPCPFmzY+VQ29J3e1c5cEdGtTc193j5Of+3T+oSSVF glkgADo8gAAABDABAMAEAxAAAAAAAAAAAMQAAAAAMAAAAAoBVuNta3UPDvR1L2rqPK+YeUXd l249u183FdZ7CgdHAsuEsfPcwPReY+Q6q3dphxdv7PsPPNUbTTqs0zrLlkgCoihqi6SSuUyS RAeADcnLPEVBVAgeA6kRgMYhoKZJEUSRFNEiKJIKkhoSJIihEkgQ0A0iSQIkggoOgEkioSQ6 DAqI0ESAIjQmiJJEE0SRFE0gGMdB0KEOgUGEIlbwQgTwMb9m9RLMRJiNRkgACoQDHCErmEVU W47rJnsiShblc7q9PA029rFYz7T5cC/oOO3L/i768X+Si3toxxl2n7C8AOFtvd3kk6QhDI1I 0BBViZFJsTYNpCo3kiKTCpLwpcWkHhJZYvpJimYh4iWQJylki+MaZ0b6iVEXwvunnPZRGFc3 6ixW4omBqayM3a0hgBpkEYRoqEyOUqAJorki1lbM1qKWiE41RbIrZz7VrvHKa0yoa7bqincx pKo7EuB2lePaYq/iMTGaZIBiAQiQgEIYEEWVTzLiqaKKJlZaythEQGICcSbIRJFCyZtsTqY2 i+xIlR3dtLI07mNUmYNtLA6Nxa7ZdPYlxZWF0WbKm6snKixSoVkeqGbNlDU6mJM7HltrJvrN azqzvejp6fh6KAHGoHpw8Xl/3l8qGug79n+n/wDuSOjZ8qsWuFWLvG8OJ5fur8Xp0to7q7a7 Soao2oQ7qG4p5nK2VpzL+3UlSSqjl39nK12oYo9DKDj0oplaTxRiweazEqrA6m52Kl2oYM5s k4vTJUZjsqDQidKZibXACcJ8GWVqVxgmDrHqKLGqlM7fFFqlUkBkTcSyimsMycoJlLTizcrO EZQccUdHZeZKP5d7LmZV2ljmVztlwZem8BTWq26opuWp07KOPs9/c2kqZxPS7XeW9zGscyNM Nnd3LOEsUdGzuoXcniF3bRudDOde2krbqvWijrgcm1vp2sLmK5nStX4XVWLAmAwAQDEACGAC AYgAAABAMAEFBgBEBhQBAMAAAAAAYAIYhkAY/M56dvI2GDzdV276Gg3p9U+bzY60ARzfRS1V zCiYuAAPSxUBDqRSAeDDSAgHSgBQIYEAAxBQMQyKAAAAAAgAAAoGIYAAAQADEAAAAIAAoAAA AAGRSAAAAACgGPTxeAYIASHgukjUZAwEMAAB0KEOgV5CAYAOlMyBDpTMVcKCAlWmQgAAEMRF AABUAAAAAAAAAAIAABAAFQwACKAAQAAAVAAAAgGBUICy1anelotpyfQdvZ+Txt0nf7Uvl4L7 SyZc9+TXTv8A0c3Z+XXd1j3YfM/qPQbba29rHTaXXLiy/o4COkmHh35dt/hPYAAGnIAAAAAA AAAAAAAAAACAYAIBgAgGACGAAIBgAUCiACB6qZBVsAAVBgAAc7zLyi3vlrj2Lqylz6zogXsP BX7FzbTdq7HTJfTAqPdbzZWt7Dw7q/DJZo8hv/L7uwnpuYxfdmsn/E6zbLFjGAAaAAAADEMB jQkNEVJDQkSQU0SRFEkQNEkJDQVJEkRRJEEkSQkNMCQ0IZUMEAyoBDAIiSQhoCaLEVosRBIY IZUIYwARCpYVpUbMb9mtVjQiTyQ4W5T7q9JqXp1TFtxFY4wlN0iqmqG2iu9i/YXVSwyOW3J/ i7a8V/uUQ2qWM8Xy4F+WCyCvJCxONtvd3msnYxakJ0XefrFr+VN9SI0lV8hNPi6EK3ZZKiBb eWcn6jOb6RrE9acnGOftFVvupsthaUOCRPA1is+UUaJvOi9pJWFxbZcFC+MTyqCtqOSSIyLK EJFZVtDQAiKYABUAABFAAAAJ4NMYpZANohJFhFoiqJFbLZLgVM5bOkZd1DVEyWpUZ0pxqjmS WmVDel6PPyzFy3LEEQtyqiZ1cAAAAhDABCGAESE1UsZFgZXhgVstksSthEQAAGmTK0WZooHi TtOjIIcXRhHY2sjrW3WFDh7WR2du+BmdKlYbq04dJUi/dxpOnQUJGtu7163MSiquh6PZwpFv 0HD20azXRiejsx0wSOmkcOW9EqAOgHd5XHAAPO7gYAAFU7fGJaAGRxTzwZk3O0jdVJLHmdSc FIolFrCWQwPN3tvOw6SxjzKHHkekuWk1R4o5W52Lh2reXIxYrHb6R3BJ1dMmWYcSDPWhZG5z FKNcUQpQDQJxqVRnQuTqUUuLjiicJKWDJvErlDijUuEsKdsjauTsS1QZOM6YMnK3XFGsZ7I7 ex80jeWmeDOpg1zR4qji6xzOtsfNHHs3CK697aQudDOdPbzsuq9Z17dyNxViyTSeDKrmWd/K PZuZczo27kbirFme7sozxjgzC7dzbvDADsAYbO+4XPWbYyUlWLAYhgAgGIAAAABDABAMAEAw AQDABAMAEAwAQDAgDPvLfi2Zx6DQFK4BZcXLxiAu3Frwbsrb4MqOb6c6zIrhQQwIpAMAoAAA abCqEBA6VyCgh1AAHqrmDowpAOgiAAACgAAgAAAAYgAYABFAxDABAACAAKAAAAAAAAHTmFQC nMK0EAAMEWQnp7qxAFZk8XgiMopOixLlZu3MXgukbt2rfelqfKJrDOVCi2FEsydy7rwitMeR UiXHosz6pV5ACQyNEh4cRVqBA61wEAAMAABDARQwEMBAADCAAAAAAAAAAEIYmAAAFDEAEAAw CEAwKAAN218rvbjtPsQ5yz9CLIzttNZna4YOjidTa+Tzu9q92I8viOtttlZ2q7CrL5nmaDc1 93k357emn9VdmzbsR0WlRFgAbeW9etAAAAAAAAAgGAgAYhiAAAAABiABgAAIYAIAAAAAABiA BgICBgIYAMQAMBAAyN23C9B27i1QeaZIAPI+Z+TT2dbtqs7Ptj1/aco+hnnvNPIc720XTK3/ APj9h01292bHnQADogGIYDQ0IaIqRJEUSQEkNCQ0BJDQhhUkSRFEkQSRIihhUiSIDqVEiRAa ZUTASY6hkgGIgnEsRUixMgsRIiiVUs2UMBauSbLYWLk+UV04slsndqa29lZClJG1WrdrGTq+ cvsM12alKscjjeSX+Mdft3WeVaLdqNE2qv2F2PUU2XOUeylTmy3w2+82/Ycrba76ySE6LvP1 iUl8Kb6kWKEY5IkMLlVSb5L2j8Oubb9hYAwmUFbiskTCgFTICgAUFAAAABAQDIMkyLAgwBgR TABlCAAAAACAHmIYCjkDEsG0NkVTIqZdIqkc9m4gc/cwpKp0DPuoVjUmt6s8kzFFiXA0MxWp UZtR3jx0ACAoBDEAgGIBCZIQGa4sSll91FARERJiACyORWiyJQ1mDwFxJyyCNW3kdrbSyOBt 5YnZ20sEYFm9jimZUjobmOqFTCkdL6V247/Ft2FvVLrZ6A5fldv4uR1DrpHHkvUAAHRycUAA 4OpgIYAAAFANJgAFMrbjisiiduuMTaVzt1xWYRxtxslcxWEjmzjK29M1RnpJRrhLBma/t43F pmvSZsVxU1Qhp1MtvbeVh44x5kFLDAyK5RoClQm51IOLAti1IlQz5FkLnBlDlColNwweRaJx qWXCYDSmqrMplFp45jxg6rIui43FjmbzNvmz2WbXezsPPA9Btt3C+sMzy8oOPUStXpW3WLJ2 ay9cKUVJUZz9n5iri0zzOjnkVWO7sk8YGReJYeGB1yMoKSowMtnexlhPBmtNPFGG9suMTPG5 csOi9TA64GWzvIXMHgzUAgGIAAAAAAAAAAAAAAAAAAAAgAAAAAADi+dbajV+P4ZfUcg9fctx uwdueUlQ8te28rE3blmvajO09Xt4N8zxveKAJOLImHpADABAAEAAAAAMApDACAyHqYhgGAUA ACgh1YBSAdOQUIEAwAQwAKAACAAAABDClShAh0SzBsApTMGxAAAMVQCgVHp54BVLJVAFFvEk pUyINt5gBNzcs2RClAqAxkRkUwAAAAAqAYAUAAAQAAAAABQhgIAAAAAAAAAABCYwAQAMgAAY CAdKuixfI6G38ovXe1c/Lj05+osjO20167XDnM27byy9fxpoj80vsO3t9hZ2+MY1l80sTU3U 3Nfd5d/yP8P6se28us7bFLVP5pGtuuYAbeW27XN6gAAIAAAAAAAAAAAAAAAAAABAMBAAxAAD AQwCoAIgAAAAAAoAAAAAAgBiGAAAAAAAAAAADrQQAczzPye3va3LdIXufCXX9p5S9ZnYm7d2 LjNcGe+M+82Vrew0Xliu7JZxNzbCWPDAbN/5bd2Eu32oPuzWXp5MxnTuyY0RJIokiSIIkmRU 0NEUSTAkNERoomNEUOoEqjqQqFQqyoVK6jqEWVHUrqOpUWpkkylSJrU8iosBtLMhJ6e86ewr /dWk6R7T+6qkF6lXLEmmwt2b13FR0rnI0w2MV+rJy6F2V7DltvrHTXj227KorU6VbNFuxz9h ohGMFSKSXQWI4Xkt7dHecWs79UIQ091JdObJO25ZyaJhQxjPd0zjshGxCOLxfSZt0kpJI20M u5XaTNayRne2zqtsYRoXFO3dUXFqTsAAAoABAMAEAxAAQAAAAAAUiLJCYEGIbImVSQyKGAAA ihgICBgICKUm1RobE8h1qgISRTJF8imRjZqKyM41RN0FU5ZxXSzMcprTKhrtyqindQ0yrzHY lwPTK8G0xV/EYmSNMkAAAhDABCGJgV3FgZGjbLIxyVAhEWSzEwEicSBKIE2SzQmSjiUFl0Z1 9tI46wkdLayM1HZ78KGCKq6G6w6qhTC3+bQ6TrGtLjMdrZQ0268zSRtw0xS6CdDtOzltc0gG BWXEAAOLqBiAKYCABgFB0AQDACMoqWZRKDjg8UaAeJUYJ2U+lM5e52Dh27WXI7srbWMSpxT6 yWDzSVXyY640Z1t1s4XHWOEjnTg4PTcVHzMWYVS4og0afD4kXBMgqjNotTqUNY0JqqKLHiVy hTFFlajAhC7wY5W+MRSgmRjJwzNzb0rOBGTizq7PzJw7M8Uc+UYzxWZU6xzLZglevhONxViy R5ra72Vl4ZHe2+6hfVVmRpeQnajPNEwKObf2TWMCu1ublp0ePQzrFV3bwuZrECNncwu9DLjm XdnKGMQtbydvCWKA6gFVq/C6uyy0AEMAEAwAQDABAMAAAAgAAAAAAAMXmOy/dQrH9SPd6eg2 gGpbrcx4/FYZNcA1c0d/zHy79x+bawuLNfN/E4DTTo8Gs0c7MPoabzeZnf1gwfQGl8BAZdCp zAak0PUuKCogSonk/WGh8MQIgAAAABADEMAAAIoAAAAqIAJVFgIAJUEA9QUhhgPSBEB5A8QE DdQBRbAQ4wcskWR0RxeLJSuylhFUKnyU0oFWyyFquM3pXtIzlGvYWAEac8A1UyEFCKMwzHgh NgFKZhXMBAAxDQDGIZFMBDKgAAKhgIZpAAAAAABAAAACGIoAAAAAAAAAIAQwpV0WL5IKQzdY 8qv3cWtEecvsOpY8psWsZ1m/vZeoeNcdubXX1z8nBtWLl90tRcuo6ljyRvG/Kn3Y/adhJRVI qi5IZuax59ufa/T0VWdta26pail08SwANPPbb1oAAAAAAAAAAAAAAAAAAAAABgIdA9gYAKgD bqIAEMAEAwAQAAAAAAAAAADABAMQAAAAAAEAAAADEADAQAMBAAwAQBKMZxcJpSi80zzfmPkM rVbu1rKHG38S6ua9p6QdaFlwmHz8D13mHk9reVnD8u983CXX9p5bc7a7tZ+Hejpl7H1M6zbL KtDTIjqaE0yVSuo6gWVHUrqSTNYRYMrqPUFTGQTYEEqhUEmSUOkKRJU6yUYRWZfatyudyNek mcGM9lSUuC+sktvduOkriguSWPsxOhb2b/xJeiJphCMFSCocduWf29XXXiv93RzrflFrObcn 0m6zYt2VS3FItEzjdtr3rvNNZ6BvmNESSObaSRNCRJGozTAANIZl3fBmoy7zBIsZ27HtHVM0 mXZ5M1BNewAACgAAAAAAQAAAAAAAAgATGDArZEmyDM1qGhkESAAATAACosQpiqR1LLMkoyeS IoqJYLEsVlvN/UEoRtuqoxipmK88lUpnNLMLspt0bw6CihjZqJOfIEyA0c20N1HVGqMVuVGd JrUjmSWmVOR21ry8kxW5YgiFuVUTyZ0cQAwAQhgBEBiAizLdVGayi9EIzoJAhtAQJRECAs4E ouhFDjmUOWDNu2lkY5l23kSo7+2lia7FrVeT5nP20sjtbKNZV5I1p7J2rcFCQHdnBUAYAw4I ABzbAABAwAQU6hUQFDqOhEZeiAAAgCE7aljxJgBmlHGksyq/Yjejpkja4qWZW4UweQxkebuw lt5aXiiKuJs7t/axuLFVORuNg4Yw9RzswrNK3V14BRxzyFC44YMvTU1gZVXTihjcKZCzKhA1 XMYFFVHB1RdCUbqoxUqVyt8Vmam2EsOcHDqJ2r8rbrFkIXXWkiUrVcYmsZ6xM4d3Z+YRurTP BnQPHRm4s6+z8ycaRniiZadoBQmprVHFDKAou7WF3oZeAHKubadp1XrRZa3soYXMVzOiZ7u0 jPLBgW27kbirFkzkzszsOqL7W+phc9YG8BRkpqsXUYAAAAAAAAAAAAAQAAAAAAAGLe+XQ3Xa XZuc+fWbQDUt1uY8leszsy0XFRlZ629YhuI6LqqvccTdeU3LNZWu3D/mRzuvs9vHzTbpt0rm 0AYjD0AAAKep8cQrF5oiARLSnkxOLQhptcQEMeuuaqPsvoAiBLS3liRpQigAAAAAAQwAKAAA AAGAVHh1CBAOjzE6sKUCoDUlHgHiPhgJ0DTUCLxBIdKCAeAAAAIYiAAAKAAABgAEDABlAAAa jIGIDSGAAVAAAAAAAAAAAAUAAA1WfL9xexjBpc5YI32vJFnenXoh9owxtya6964xps7C/f7k HTnLBHoLO0s2P04JPm8WXt1L4uG35H+M/q5NnyWKxvSr92P2nSs2LdhUtRUeniWAXDhtvtt9 VAABWAAAAAAAAhgAgGACAYgAAHQBAAAAAADAQAMBAAxAAAAVAAAAAAAAAQwAAAQDEAAMQAAA AAAAAAAAAAAAAAAAAAAAAAAAIBld+xb3EPDvRUo/TImAHlfMPJbm1rctVuWv+aPX9py06nvk 6HH8x8kjuK3dtSNzjD4ZfYzc292bHmhoUoyhJwmnGSwaY0dUNDSBIlor0DIjVcMRpOXFIsUI LpLKpYJJEyquMIrNtlmfQiy1Znd7ka9PA22/L0sbkq9EftOe3Jrr3dNePbbtGCMauixbNVrZ XJYvsrpzOjC3C2qQSRI4Xmt+no768Mn1KLe0twz7T+99ho6OAqhU52293WSTskMgMsSpCABU BJESSIqaJIiiaNRigYAaQGbeKsTUZ92uwIzVez4mwxbTvUNpU17AQxEaAAAAAAACGIAAAABD EACCoYgJlciTksq+oi+heszWojUabFRsPDTzxJ1XobkuLK/Er3Itl6jTIdC4qZihQuyzdESV mK7zbLaBQeM+Zdr8iVFglQephQKGmRUTVVQlQKBGWccDPJG1qqZkmsTltHXWqwGBxdE4mHdQ 0yrzNsWV7uGqFeR01rjyToy2JcDSzFblpZtWJ2jynwAEBQgGIBCJCAiyu6sC1kZKqAwk1iKa oyUAiElQROSIATiCzIxxJvBlFklgFl4hmiEMJCo7e2keg8vnXDoPNbWR3vLpdoad0rrgAHdA AAVHBAAObYAAAAAAAAABgIAGAAAAAAAAAUkqdK5ELm3U1WGPQWAsHVZjujibrYqeKwZy5RnZ dHgeylbheXyz9jOXutmn2ZoxdVy48Lqng8xyiR3G0lZxWRG3f4SMKlRrMKFjVcURpQogBITQ RCUFIgpytujxRcJpM1KmDcY3lVZlElK28RuMrbrEthcjcVGbzNvmnZfs9/Ky8HhyO/Y3ML6r F48jyt2w4YxyHY3U7LrUnbus6vXgYdn5hG+qSzN5VIAAAaTwZku7KMsY4M1gBx9NzbPDA2Wt 8nhcw6TXKKkqMx3din3PUBsTTVUM5MZXdu+g2Wt5GeEsGBqAMwAAAAAAAAAYEAAAAAABQAAB m3Ows7nGapL5o5nG3PlV6z2o9uPOOfqPRBUzZK66cu2nbt7PHCoerv7Ozuf1I4/MsGcq/wCS TjjZlqXyywZi616tefW/V0ckCy7anZdLkXF9JAy7y56xGgDAKQDAAJamRGQOqeaCi4P1iWOC G40weDAGmiI6j1c8QIgTjDXhFA7biqyLgygADUWRSGk2OqXSKrYDwQqgOnMgQUHUQBlkIYgC o68xAUFEOjEAAA6sMAEA6chUCEMAAAGAUDEMIAADcZAwA0gABlQgJQi54QTb6FU2W/K9zc+H SvvOgS7Sd6xUA7FvyT/uXPRFGy15btrWUNT5yxGHK82s7dXnYQlcdIJyfQjba8p3E+8lBfeZ 6BdlUjgugC4crz3+2Yc215Naj+pJzfRgjda29qz+nBR9GJYBcON32270N1AADIAAAAAAAAAA AAAAAKAAAAAAAAUH2VmIMgHWuQNgIBAMAAQAAAAAAAAAAAAAAAAAAAAAAAAUAACjHpfIBAPS +TDRLkwEIlolyYaJcgIgOlOXrItxWco/2kAwIO7bWc4f20Qe6sLO7D+2gLhGd77arO9b/tEX 5ltF/jQ9YxRqAxvzXZr/ABo+37CL842S/wAX/ll9gxRuA57862S/xH/YkRfnmyXxSf8AIy4o 6QHLfn+zXzv+T+JF/wBQbRcLj/lX2jxqOsByH/UO1+W4/QvtE/6j2/C3c/5ftHjR2AOMv6j2 /G3c9cQ//iSxwtT9aL40y7KTeQ9PNnDf9S2+FqdPxL7BL+pLX/Zl/bX2E8aZd3DgLE4v/wDE tnjan/aQ/wD+JLH/AGp+tDxqt2+8us75dvs3PhuLP080eV3G1ubS54d5UfB8JLoO5/8AxHY4 25+uJOe/s7+3ouWLjhwbcVTpTLnx+rsTXP0vOolFOTpFVfJHRt+W24us25LgsvWbYRjbVIJR XQY255Pp6u2vBtfq6Oda8vuSxnSC9pttbO1bxpqfORcM47cm23q768euvolUCIVObokKoqhU BjIVCppmpjIVJI1GakAhlQE0QJoyJomitE0ajKQCGaQync9xlxTuVW2wlUbSlam0wbTM3lZ1 7AAAjQAAboACCvIHVZ4FAJ4C1LpfULHgkQOoY9QaZPNh4a4gRclzr1EHOXwwfXLAvogoRcqN N6WclH8KqPwK99uXWy8Bg8r8kNNCLRYyEiorGkIkgGkMQwAB0CgQqDoOgFCAYUAqao2uZkuq jNs1RpmW/HGvMxtOjetZRgwPM7GixrVGhUi6BZWdp0cia0ypyNdqVUQ3kNM68yO3fA9EePaY aMmMHzGaZIQxAAhgBETJCAx3liKBbejxKYhFkkVNcy/gUyQBEbIxJsonF4EcmOD4CkwjobaR 3NlOkked20jtbaVKMnapXpk6oZVZlqimWnpZKoDADg1DME0gqYxGwxDAgAAAAAAAAAAYAAAA AFAAAQDAAChNOM1ouYrg+RAAM262bgq96D4nF3Ox+K36j0sZOOWXIy37Cfah6UZuqvLxuStO jNMZRmsDbuNpG6uTOVctTsPEwq9oVAt3lLCWZNxAroIm0IIiVzt8Y5ltAKK7d9p6ZErlhT7U PUKcFIrjKVp9BubemzOPZCMpWnhgdrYea17FwwPRfXJmW5albYsx1nZZfd7OMlJVjihnl9l5 lPbuksYno7G4hfjqgxLlVoABQAAARnCM1SSMN3Y0xhlyOgAHKhduWHThyZss7uF3B4MunajP CSMN7ZNYxxA6IHKt7m5ZdHiuTN9ncwvZOj5AXAAAAAAAAwIEAAFAAMBAMCBAMQCnCNxaZpSX JmG75Rt7lXFODfy5eo3gGptdfpuHCu+S3o/pyU16mYLu2u2f1ISj6MD1g6sz4x2159p36vGL EZ6q5sbF51nbVeawMlzyWy+5KUXyeKM+LvPyNb3zHASqNqmZ07nlG4j3HGS5J0Mc9lft963J dSqTFdZya3ttFOrgRCtHR5joZbIaSHpbyJaFHN+oCcYReClXoRKdu2u86PoZTrawjgQHVMJa orLEJS1ZkVEKpZBT01DSRCpUSqIKhgRQA6A0DJAx0ERSAYFQgGACGAAIlVoQAPB5oKchZ5Fk bNyfdhJ9UWVLZFdBmqHl+5llba68C+Pk+4l3tMfSXxrF5NZ/dHOA7EPJPnuf2UaIeT7ePe1S 9JfGsXn0nxefHFOXdTfUenhsdvb7tuPpxNC7OEUl1Gpq5X8iekeZt7DcXO7bfpwNMPJrz78o x9p3qiNYc7zbXt0cyHkttd+cpdWBqt+X7a3lBN85YmkZcOd32vehdlUjgugAAMAAAAAYAIDP u99Y2dPHlRv4VjL1GR+fbJZSk+qBcVHTA5L/AKi2iyjcf8q+0rf9SWOFub9KL40doDhP+poc LL9M19hW/wCpnwsr0z/gPGmXoQPNv+pr3C1Bellb/qTdPKNteh/aXxpl6gDyb/qHevJwXVAg /Pd8/wDEp1RQ8aZewoFGeLl5xvZZ3peihXLzHdyzvT/tDxMvc6Zcg8OXJng47nc3XpjO5J8l JsnKVyGF69Kvyxk5P30Q8DL3OlrMhKcYd6UY9ckjwUrjeVeuUqshp1Y59ZfAy9491Yjndtr+ dFb8w2izvQ/tHh9MV0hq4LBDwMvaz812cO9ej6n9hW/PNiv8WvVCX2HjAL4RMvYPz/Yr4pP+ RkH/AFFsll4j/l/ieSAeMMvVv+pNpwjcfoX2kH/Uu24W7n/KeXqFR4wy9O/6ms8LU/7SIv8A qe3wsy/tr7DzIy+MMvRP+p1wsf8AP/AX/wDE74WF/bf2HnRjxiZd/wD/AInnwsx/tMT/AKmv cLUPWzgjHjDNdt/1NuOFu3/zfaRf9S7r5Lfqf2nGAeMM12H/AFHu+Vv+z/EX/wDEW8+4v5Dk gXxhmuo/6g3r+KP9hC/37ffPH+xE5tB0GIZdD/fN8/8AE/5Y/YJ+c75/4r/sx+wwDoMQy2/7 tvX/AI0vZ9hF+abx/wCNP1mQBiGWr/cd2870/wC0L97uXnduf2mZ0MYMrnub7zuz/tsi71x5 zl/aZGgqADnJ5yl/aZF45t+slQVAIuK4kdC5ExAR0rkg0okxAKiAAIGABq5KpUMROVm6o6pL SunAg1BfE5Poy9YCqGLyDVyX1ibbzYB1sKoiFQp1AQdADA02theu4taFzl9huteW2oYzrN9O C9Rx25tNfXN+Drrw77emJ8XKhCVx6YJyfQbrXlk5Y3WorksWdOKUVpiklyQHm2/I2v09Hq1/ H1n1dVdra2rOMY1fzSxZfWpEZ583a52uXeSTpOiQCA3BIZEZpkwqICgqFRAAVABoqGiSIokj TFSQxIZUMkiIVILESRBMmispIlQSRLA0gK7yrBlmLyRXeaUWm11BGHaPt0Oi2lmcvaulxHTx 4URWdTryE3TNpCpzbY0ksiNIuS6WQ13X3IKPTJlwDC5U+Fcl3rj6o4EoWYxxxb6WWAMQ8qVB gBWQAAAAAAAAFAEQkTeRBqhBWNCY0FSQyJJBDGIZQDEFQGITYVAU1VNFF1ao1L2+boUywTbq ZrUYnFiHKS4EdR5rOrvlJFkHwWJRUshKhdZ7paW9tNw1Pgc63Kkjr3Hri0ceUdLodpj0eXed W9YoEV2ZVRYsGbcgAxAIBgBERITAquKqMyRskqoySVGEWrFFc4lkAkgKEqEmsAaAoIMcsSMS TCLdvKjOztpYHDsujOvtpEo9Rsp6oGo5nl8+B0zvrcxgAAGhwAAZzbACGAAAAAAAAADABDAA AAKAAAgBgAAAAFAUAAKrlhXMsGc+/Y+GaOqJxjLCSqiWZHlr+0dvtRxRC3eccJZHoNzs5RWu Haicm/tFPGGEuRizAhhJVQmjMpStOjwNMLiuLpMqQqE3EjQqIg0mMVAKHBwdYl8LyuLTICud viszc2wlmRd2+ntRxRCxuZ7eVYMst33HCRO5ZjcxhmaxL11SXHd3dl5lDcqjwkbjxNJW5VWD R29h5xWlu96zOfdvv2dsATUlVYoDSAAAAAAAquWIXM1iYb2zlB6o49R0wA5lneTt4SxXtN9q 9C6qxfoI3drC5jkzBd2s7T1L1oDqjOba38o4XFVczoW7kbirF1AkAAQAAAUAAAAABAAAAAhg AUAQAADGnyQEaDTayG4tZkQIztwud+Kl1ool5ftpZ216MDSAals7Vil5Xt5cGuqRTLyWy8pS XqZ0wJiNTk3n91ciXka+G564kX5JNd25H1M7IE8Y197f3cKXkl75ov1kH5Nufuv+Y74Dxi/f 3eefk+65R/tEf9p3XyL+0j0YDxi/f3+Dzf8AtW6+T2oP9r3X/bfrR6QB4xf9jb2jzf8Atu6/ 7b9aH/tu6/7ftR6MB4w/2NvaPO/7Zun8HtQ/9q3L+FL+ZHoQHjD/AGN/g88vKNy+C/tE15Nu OOlek7wDxiff3+DhryS685xXrJryN/FcXoidkB4xPvb+7lLySHG4/QiyPk23Wbk/SdEC4jN5 d7/cxx8r20fgr1tlsdnYjlbj6i8C4jF22ve0oxjHupLqRLUxAVkxDAAAAAAAAAAGAAAAAAMB ANKpyd955Z29YWfzbn/KvTx9BZLUdO5chZi7l2SjFcWef339QylWG0Wlf9yWfoXA5G53V3dy 13panwXBdSKTrNMd0yJNyblJtyebeYCA2yAAAAQAQMQBUKQAwUqZEFkLdcZPSubLpT20O5GV yXO49Mf7Kx9pmzxYYFF1zdXLi0YRh8kFpX8fSVUSQtT4YdQgHVcBNt5gIAAAAAAAEAAEAAAA ABQBgAAADAoKDAAAYDCABgADoFCSQCoFB0CgCRJISRNIiigUJ0ChFVtCaJsWmoEBULXoj3mQ dyLdIJsCLRHInKEl3sOvD+JBpLJ1AQiQmAsFniPW1lh1EQIBqrq8WIYFCEWW7c7rpCLl1Gy3 5XOWNySiuSxZjbfXX6q1rptt9Mc8ttba7e7kW1zeCOxa2dm1io1fOWJobbPNt+T/AIT+r06/ jf53+jm2vKksbsq9EftN1qzbs/pxS6ePrJgebbk23+qvTrx66/TAACMOhgICB1GRGWIlUBAd IlSGRA0ykAgKGAgCGNCqBpExoikTUSs00SBQfIMFxKyCNSVaiafEimmWJ9NClIsjgJUsW6ly bIud14RSgueYZkka7p2V+CpfqSlL00RLw4Qi9EUiygpZMSJbXL2+FxI6tDlWv1PSdahpiAAG FIBgAgGACAYAIBiCAYCAAAAAjJEhMCiSEmTmivIjSZJFeoaq8kwLKhXkQo+he0HCvF+4CUpq HeaRBXlLCKlJ9CCNuEcoqpZVjqdC7XGkQpHi2xUJULhMnWMV2ViYL0aqrxafE3UM16PtJt2X XuxCGI8tegEokRokvUrRHFHP3cNMq8zoWyneW9Ua8jtO7hvGTbypgaWYYOkqm7NHSPMYAsgK EAAAhDEAjPcjiaCu5GoRXAm0QjgWAUsiWyRWwIcSZHiS4FBF0Z1NtI5TN+2kSo9Ds7mmVTrq /HjgcDbSxR0nLI7cXXo57XDf4sM6gYNYHfwZ8qxAAzg7EMAAAAAAAABgIAGAhkAAAUMAAgAC g6AIB0YUAAAVUuK9ZQwIO5BZyXrIvc2VnOPrAtjJxeBn3G0hd7UOzLkD323WdyPrK5eZbRZ3 YjGRy79pPsXVjwkYLtmVl14cGjvz3e13b0RmnPgY7+3ladKYP4efUc9tcKwWr6lhLMtcSq7t sNVvLiuKK7d5wweKMKvaFQmmpqqE0BCgDAqK521LrKozlbdGaKClFSWJciVYXl2s+Zlu2Hbe OQ5RdvLI0W7ykqSxR0zNu/dnrOyWy8zntnpljA9JY3ENxHVbdTyt7bUWqGKKrV6dh1g2jPXX u1LK9ppYaWeQndu3Vqt3JV4x1e4yO9cec5etnWa57VLcPdEXKKzkvWeFcpPNv1iNfbTye5d6 0s5x/tEHu7CzuR/tHiaIKIfbTye0fmG1Wd2PrIPzXZrO4jx1EMv24eT0l/fbGWMZtPoiym1d Uu1alicEcZyg6xdGS6ey+T1UPMnBfmRb/CUz/qCzF08OfsOVZ8wrhdXpNMrdu+uDMYx9TTQ/ 6jt8LT9ZB/1Hytf8xy72ylB9kytNYM1iJl23/Uc+FqP9ot2fnrvXo270YwjLCq58DzwUqS6x XvWqYMDB5Tvf3ljtP8y32ZdK4M3nNQFQAgBDClQEA6IKhQsB63wIgAAMQAAAAAAAAAAAAAAg GACAAAAAAAAAAAAAAAAgAACgAAIAGBVAAAQAAAAwAAAAAAAjduQsx8S7JRguLKJmbe7+zso1 uvtcILvP7Djb3+oJTrDaLSv+5LvehcDhtuTcpNtvNvM3NPdm1u33m1/e9l9i38kfrfE5+QxH WTDIAAo2UIBiIACcLUrjpFFkrNqH6l1V+W2tXtyCs7wJaJZvBdJYr8bf6UaP55Yy9HBFL1Sx k69LGA+yukVXJiwXSFWEJhUAoShgJDKAAABAAEAAAAAAAIBhQBAMACgUGBQqDoAwAAGAIBhQ IAQ6DASRKgUJUASRKg0hpAKgmidKg4sCtE0QeGYa+XtIq4jKSWYaJtVl2V04fxF2I85ez+JF Qc+Q1D/uNxXqHrl8NI9X25lbis3iBY5baHctym+dyWHqRXrlTs0ivu/bmLqFmAUo8RgBQiLJ dHE0W9heuYtaVzl9hnbaa/VcLNbt9MyyDinJ0im3yR1bfltqPfbm/UjZCKtqkEoroPNt+TrP pmXo1/H2v1XDk2vLbs8Z0gunP1G215fZt4tOb+9l6jUB59ubfb1x8np14dNfTPzGSosFyQgA 4uoAQDAYgAoAEBVAABmhjEBqIYCA0iQVIhU0iQyI0EMYRjKWQIuUOhJER+gqJp8ialLh2Sqr CppMLNEX3m5Dql3UkV6iSHjEtSq3mxABahonEgiyJIlTSJoiiaNsCgPIYUKjkxf5tOk6xyJY XX1nXWSKzAAwIpAMChAMCBAAFAAVDpoAARr9EHoIHUKhRi0oBSmo5tIrd5PuxlL0UXtLdCzo Mi9FH5kvhUV11DwlxxLmRbGFyiopZYEqAOhUKgDoOgRECVAoBGgUJAUKhRuVSNTQZ784OLWp VJVndz5qjYhXb0I5yRS9zFLs4nm8NrekdrvrO9X0FqSCzS7BSWL4ozb2cVJQjmljyOk4b61z 25p6R0dvruvTbSrzk6L62LcwnGThOSdOEFRe3El5NJOab+V+wpc3dk5Zts9GvFJf2ebbl2vw c6So6cjXZlVFW4tyg02qJhYlR0OdmLg7tKzoMTwxGAMQxAAhiARGSwJCAz0oyxCkqDiEKSKm i5lbQFTRJZCkggUDNW2kZGXbd0YR3dvI6mtaavI4+2kdex2o0ZrjuNmNuw1xzqAvCjWtAPZi uTlvzXar40J+cbVfH7DyQGPtx18nq351tV8T9RF+ebVcX6jywD7cPJ6d+fbblL1EX/UFjhGR 5oC+EPJ6N/1DZ4QkRf8AUUOFt+s88A8IeTvv+olwt+0i/wConwt+04QDwh5O2/6iucLa9ZF/ 1De4QicYC+EPKuu/6g3HBRIPz7dfd9RywHjE8q6T883b+Jeoi/Od2/j9hzwHjPYzW1+bbt/4 jIvzLdP/ABJGQC4hmtD3u4edyXrIPc3XnOX9oqAYhmpu7N5yl6yNW+L9YgLgyAogAGRRAABD R2Nl5xRKzuu1DhLijjASyXusuHp71hU8W09UX8a+sxXbCufdn7GYNnv7u0lWDrHjE7cPB30N W3dJ8bb+o82/Hjs6S5cjtWZUeDNMLiudZZNJ9i6suPFGS7YlaxzjwaOGMNNDiRoQt364T9Zc 0BWInQVCoiUztNdqJeAFVq+10MtnZjeWqOEuRXctKeKzIQuO26SOk29NuzNnsqlGVt8mSem9 3sJ8+ZsbjeVJesyXtvK31F66/wAteyy56bM0oSg6SwYjQpprTcxXuK7lpwxWMeZ313m3zZuu FYAM6MAAAigAAAJQuStusXQiFDNajpWd/GXZu4dJdc28LyqvWciqRO3fnbdYs53XHZpbd2c7 eOaMzfBnUs7+Fzs3MGSvbOF7LB8yZVh2W9eyvK6sVlNc4ntFSSUousWqrqZ4qWxnCVG11npP KLsYwW2uTTnGrhTOnL0GdpF6uiNRbHqSyXrE23mYUYITYAAgGIBiAAAAAAAAAAAAAAAAABAA AAAAAAAAAAAAAAAAAAAAAADAAAAAAAAGAAAAAANdBQhpVMe98zsbLCb1XP8Atxz9PI83vfM7 +97Mnpt/9uOXp5mprlHZ3vntqxWG3pcuc/gX2nndxubu6nrvScnw5LqRXQR1kkZpAMDTJABK NuU8lUCIFjgo5v1Ea0ywKDS3n7QrFdInV4sQwCTcsOHJEXGmY6iCFWmRF45kxUQEQHpABwVZ ULpQVChOjqSlcbRz27tRAZEkjUQCGBQgGCXEgQAAAAAAAAAAABQwAAHQKAMAGAwgQAMAGgSq S00wbphUoRJKoqpU9tRa8MMUQW0JO7bt55dJVC1cmqpUjzyXrZKLt2ZalLVL7qw9cl7kBL95 qwtW69Lx9w1ZvzWq52I9K0r1v+JZLzTdyVIS0JfKlX1mObdx6rsnN826+8yqTdqGTc30YL1v H2DV2fwJRXNfbmVrDJUHTmUPjVurJV5CSJJECFQlkW29tcu92LpzeCJbJ3akt7dWegUOlDy5 Z3JV6I/aa7dm3a7kUunicdufWdurtrwbXv0ci3s7tzKNFzlga7flsF+pJy6I4I35iPPtzb3t 0ejXh0nfqhbtwtYW4qPUNjEcLcu8mOxAAGFMBAagAARQAAAAABQgACAAQyKBiAsQwAaNIKVG kCJI0g08vaSUebFUKjCZSdBCqIodRVFURUSqAhpGozUkWIgkTRpmmAxEQ0WRKky2IiVaidCM SdDbAAdBhHIvYXX1nUjikcvdYXH6DqW+4uoqRIA6iM7kYd+SXWwqQiCvKXdq/RT3ksSGDqJu gCSSxSAKideCJABW4zecqdEVT7QVqKdXVvpdSwAuQACCGIAoACJUACNA0khAKg6Ck9OMmkuk zvfWK6Yy1y5QTk/YBqEVx/c3P07Ekud1qC+32F0djuZfqXYQ6LcdT9csPYXCZk9SxKp37cHS UlXlm/UjUvLbH+I53X9+WHqVEa7du3YVLcYwX3VQ141i7xzYK5c/Ttya5y7C/wCbH2Fsdnel 35Rh+Fan7aI6GtPLEGm+gvizd6yf7dBpqUpSfS/qVEcy75MtvZuXZXNTjFtJRp6zvKPFnH8z 8wuSlPZ24dlrS3RylKvKhqSRm215WUtTrgCyNe58qu7bCcor14GG4oQVNTlLowRm91kuDd1q tG4p50ZBSbyqyUI65qEM5Oiqb35bPTSM058qURMoXlm6lZuRVFi6VfSdyUksLssFwWC9h5eD dWuK+o7UJK5ajPnn1ku2GtZKPMJxvR7C7pzIPTJM61uCeD4nJnFwk4vNMxtc9WrMN2aGsiux LVEnHB0DKQhiAQDEAhDEBCSIoskVhDZGSJoTAzyIwzJzK45gSeDJ23RkZLiEXiVHX20js7WW JwdtI7G2liiTpcpW+mNALKYVA9vk4YfMwADbYAAKAAAAAAAAAAAAAAAAAAAAAAAgAACgAAAA ACAAAAAAAAnCcrb1QdGiAwO5t9/b3iVvcdm5wnz6ydy1PbvTJYP1PqOAdHZ+ZytLwr/bte1H PbjlamyVywnWUPUV27zhg8UdK5YU4+LYlqhzWa6zBchXrPLtpdXSXK+LU1VCaMibg8DTbuqe DwZhQ0IscSNAIkZRU1RkxFRnpK0+aNFu8pKjxQdDKJ2nHtQNTaxLMp3tthqhijPGTh1cjRZv tPp5Fs7UbyrHCXI3iXrr3SWzuwytKXat+mJUXSjK2+TG0rvRL3nTXk9Ni6566qAJOLi9LWIq czswQ6cx15CIorTLMQnJC1LiyKdQo2XW7E5qqVI83gidLdv779hi1uRRC3KbpFVZrtze370q v5Y4lM70pKmUeSwK6cDF6tdnWtbu3ewlhIJbZwmr1rCcXVM5WmnedDRa3k7eCxXSQx7PV2d1 C+qrCXGJcedtbi3eywkb7W9naem52o8+JnA6YFdu9C6qwfoLCBAMQAAAAAAAAAAAACAYgAAA AAAAAAAAAAAAAAAAAAAABgAAAAAAAAAAMAAAAJNQi5zajFZyeCOHvf6gjGsNoqv/ALksvQvt LIOxuNxa2sdd+SiuHN9SPPb3z67erDb/AJcPm+N/Z6DlXLk70nO7Jyk+LIm5AveAVDE2zQOK c+6qk4beU1qyj80sEWLw4Kjbn0RemPrzKihxfD2InHbTb7XZrxngWrc3IrTa7C+5n68yqlcZ P62WIklGHDU+byFKcp4YtclkKtMhVNIKJZ+wjWmWHSSST6BOD4UfUVEAG1TMQCEMAIiJCIEM AATREsqFEjntthqRBRZY0orColJDeWPMxNrlUB054BXlgI7MnVLLHrE23mICAABgIBgAhgIo YCGAwEMBjI1JaXxw6wCo10CHroES04V9A6YP2MLNu9fdLMHLm0vryJT2rh+tdhF/Knrf/Lh7 RlUXczpx5BCE7ncVeocZQjhag5v5p5f2Vh62xzc5/qSy4L+GAQeHCHfkm+UO17cveSV3/twS +9LtP24L1EFRd1esHV5sAnWbrck5P1iWGSJKJJRCq6VzHpLKFsNtcud2LpzeCM2yd1kt6Rmo B0oeX/8Acl6I/aaIWLdvuxVebxOG3PrO3V314Nr36OZa21y53YunN4I12/Lv+5L0R+03VqM4 3m2vbo7zg1nfqrt2LdruRVebxZY3UYjlevd1kk7EIYiNEAxEEREmRZitABDMgAYG4hCGIoAA ZQgACBMQwIoGqCCpFSqIQEDGRGdIzUh1IDNMpVHUiBUSEAFAAAVDSJIikTjEsZtNE0gjEmom 2LSoRZbpISiSmVdS2DKWicCQrXAsMsLlXRJ+4tU6fwX1s1lnC4VSGqo6lRzN2vzWdGz3F1HP 3a/N9Bvs9xFZiUo6s26CjCMO6kiYEwuSoFBgUAh0CgCAdAoAgHgJumJAAV+NFukXqfKPa9xa rV6eUGvxtR/j7Cp2ITklmWraXPilFfhVfa/sKN35dO5p8GVaV1Kbp7kXxqeUE7sIYykl1sUb rn+lCc/wwovXKiN2128dtbUaRc+MlEvc2+bL4s+ftHOW33c8oQtr/wAk9T9UftJLyycv1b8u q1FQ9rqzfiNVLiM+VZIeVbSGLt63zuyc/fgbIUtqkEorlFU9xXKcYYykl1sqlvbMcm31L7Qn WtLxBp5mGXmPyQ/tMqlvb0snT8KGTxrpaeJB3bUc2vecqU5Sxk2+sjroMr4um95Fd1N9eBU9 1J8VHq/ic9zZFuTGWvB0PEtydZty62Wx8wt2VSKwOVRhpJk8Y5Hmm5u7i7KVx4VppWRzpo7P mFmrUl8Sp6UchrAzUos3HanG4km48GdKfmVtLsRbk1jXChyssg1N8gicOydTZypFw4d5HISd as7GwjrtOXGDXqZceXT1SXxuWuGGJi38KXNXzI6at4GbzC3+UpPgzl6O2zn7eVHQ1vOpgi9M qm/NVLHKmIayAoQhgAhDEAiEkWEWBBDEiQRnmirI0SVTOwLHkJDjihJFG3byOxt5ZHDss6+2 kZqOr+6eENPB4gU8NQHXy/8A9XLH/bwQhge0IAAAAAAAAAgAAAAAAoAYgAAAAAAAAAAAAAAA AAAAAAAAAGIYAAABftt1c2stdt05rgzsQu2d8qxpC5xg8n1HAGnTFZksl7jp3rEoZoz0oatp 5lGaVrdZcJ8TTuNg32oNOuKpkzzb8WOuvZube7Fav0wlkaKVVUYZRcXR4Mnbuu30o8/Z0aWh EozjcVUDQEBEmhUKiqdpTxyZCNx23SXrL6ClFSVGWUWVjeVJ+hmS9t5W30Dala6Ymi3eUlR4 xOmZt37s9Z2Y9aktM8uD5Fc4OGOa5my9tcNVvFGZSccOHIs2unS9l6bfNTVvIttbG9exSw5l kbUJdqtEvh4h+4cVS2tPTxO3ln6Umv8AktflOhar1yMF0ijc2u3/AE4+LP5p4R9RleLq8X0j 0PPIz82vkldvzvPVN+jgQSbJdldIm2yKKJZ4hqfDAVAMtFQB0AgVD0+ynDzCwpSwuw7M/qfp PMmvy/efs7yuPuPszXR/DMlHYuba5ZdeHNFtrfuOF1VXzI6OHDFP2ma9s4XMsGTKL4TjcVYO qJHHnaubZ1VV95Gm15h8N5U+8hj2G4AjJSVYuqAgAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAD AAAAAAAAAAGAhgZ93vbOyVb0sXlBd5+j7QNCTeRzd751Z2tYW/zbnJd1db+w4u+84vbvsx/L t/LF4v8AE+JzapYI3INW73l7eS1XpVSyisIr0GZsFGUi79vJpeJLSun7DS4tUaidu3O7hFN9 RcnYtPsRdx/fwj6liO5uLt1Uk6RXwxVEVkv28YfqSo+Ue0/sGrih+nFL70u0/s9hXSgVpkA5 OVx1k23zZHAH0iryKh1EKv0RPwp5tUX3sDTKNSLkkWK3BZz/ALK/4D024/C31y+wqKXNEXJ8 jRrplFeqoeNPhRdSReoo1yI6n0GjxrnCTG9zdecq9aT+odRmqwqaVfTf5luEl0LS/XEm7Nq6 tVluL/7c8fUydlxljqgoDjUelKKb4lQqMVCVOTItNZhBQ0ba0rk2pd1Y4mdKpdYuuE9SVa5x 5o57zMajXc28LsXWkaVxS5L6zDpdJJ8F9ZtnvIyt6IRada4mOq0uKz4nHW9Y1VQDEelgBQAI AAAKABJP+INNBAAqgUAAOoAAm6ZmiGyvTh4kkoW+Erj016uL9BMimtAVW6JYlyjajzm+jsr7 fcTVySwjS3F/L9veKIftpLG41Bfez9SxJR8KLpCLnL72C9Sx9pGKisaVfGo6ulOARKUpzjpl Kka9yP2L6yCjFKiXrJKJLSBF1lmCRNKuCNENndnwovvYEu0173DU1u30zLMojodGHl8V35N9 EcDTC1C33IpdJwvPrO3V214Nr9XRzLe2uTyjhzeBphsF8cvRE3dYUON5dr26O+vDpO/VVCxb t92KrzzZY8R0Gcr17usxOyDQidCLRmxqUkSQkSQhQIYGkIBhQgjQTJMTCoMiybIMxWoQxAYV IACjNxCAMAAlodKtpekTpzqRFUCVRCAKAAQAACJQxiAkDAAOkQwqRAqJVCpEEVE0MjUkismN IETiVKcYlsYCiyXiU4pe00xVigDaWbRS5qWdZdeC9gtT4dnqLlMLyEmV054jBgiUXQQ0yKtT bJpFcS2JqMVJIdAQysubvsJLqNu3/TRl3y7aZo2jraRWfVeAnJLFkPGjzQaWAKMLtzuQk+l9 le0tjsrr78ox/DWT+pDFZu0iqqIyuRhjJpdZrWxt/E5S9Olewl4Fq1jCCjLg0sfWXxqecYYz lc/TjKX4Y4et0RYtvflmow/FKr9UftOgqtUk6sejkXxZ86wx2fz3JPohFR9rqycdrYjj4ep8 5ty95s08yErkI5suImbSUpJUiqLksApN9BB7lLupkHfm8qIZPGr1bfF1FKUIZsyynKXebZCi J5L4Kb/mG5jf8OzbXhqnaab1enJGye8+WPrZSKhPKr4w5bm68qLqRTKVyfek36S3SFCZrWIz eGPwzRQVCZVRoDSWtCoBU4i0l1BUKKtIaSzSNRAqUSSgW6QwKjNubHiWpRWea60ecuxo6rji esboef39rw5ySy7y6mRm+7mtUFSuQ1jgyVVHIyySRu2G4nZbpGsJLSzA5N5m3btyh1HTTuxt 2X3/ADS7HsW4qH3n2n9hjjKd+525OUubJ7iNY6uKKrVx25akN5i/NrW5ibw9BssS1RMs5KTr HJlm2lR0OMarUuQxPBjNIQAAAIYgEJjEwK3gyQpIEERlEzSNcjLcWIDtkkV23iWcSi226M6m 3kcmOZ0NvIlR19XYAr1dgCI8SAxH0nIAAAIBgAAAAAAMoQDEAAAAAhgAgGIgAAAoAAAAAAAA AAAYAIAGAAAAAAAAbdn5jc2vZ71t5xZiAD0c7dve2/FsutFiviX2nLuW3BmSzenYkp23SSO1 a3FnzFaZUt3+nuyOW/HNus7rNsfJzU3F1Rqt31PCWDK7+3lak4zVGuBQeS63W9XWXLe4kaFN rcUwnijTSqqjKq6CoTaI0KiHWVStNdqHqLxZAQs36Fs7MbyrHCXIpnaUsVgyELsrbozpNvTb szZ7K5RlbfJjSjc6Je82pwvqks+ZkvbeVt9BcXXrr2WbelVt6cKUfSRdXmWKal2Z+vkRlBwz y4M3NpW8IgMRFADAilQBgQIBjCvQeR7zxIftpvtQxh0x5ej3HWPGWrs7E43Yd6Lqj2Fm9HcW 43Yd2Sr1dHoMpU2k8HkY72xjPGGDNgBlxaXdrLCq9xts+YRlRXOy+fA1yipKklVGK9sE8bf9 llz7jdnisgONGd3aSosF8ryN9nfQuYS7MukYGoAAigAABAMAEAwAQDAIQAAAAAAAAAAwAAAA AAAaTYARuXIWY+JdkoxXGRyd959asVht14k/m+Ffb7jgXr1/eS8S63J+xfYa8fc7utvf6gk6 w2i0r/uSz9C4HDblNuTbcnm3mTUEsx6qZI01hFWm8XkTUYR6eoWLz9oYdYE1cawj2fw/aRpx YqgEOq4Em6pEQbUVVlQENa4C7V3PCJrtbeFuPi3cn3YrOT6+CKii3androjWmbfD6kWO3ah3 5eI+UO76/sRK7cnd7LVIrKEe6vpzZWo1dF7FUqH4rXcSh1Z+vMg8XV4vpJSi455dVBUKhUCg 6AaZRFQnQTKICJMTwzwCIhGbWQ425XHSKqT027eb1vku76Xx9HrHdex2LKuvXclotJ9qf1RX GXR6w3G48WX5a0W4rTCP3enpebIXLsrrTm8sEskupEMwIjVeAOi6RN1CHJp4UVBUXUIAHKvO qZK3x6hLFNekcMzz7TFb9EAHKiYqcjsyQAxAAAAAFaZAShCVzuqoEa8wwLPDjHvSXVHH25e8 adMYR9Msf4AQjalLGmHPgWRjbiu09T5QX95/UmLW61cnUFOnqoBbC74brahGDpVSn2pe3D1I hcm7std2TnKmcmRwfQOhQ03wwwpgNRLbe2u3O7F05vBGy35a/wDEkl0RxMbcmuvet68e+3aM KROEJTdIpvqOrDaWYfDV/exL1hgsEcb+RP7Y7T8e/wB1c2GwuS71I9eLNENjbj3qyfqRqHQ4 3l3vrj5O04tJ6Z+aMYxgqQSXUMYHN1FAoMYQgHQCgCgwKhUItEyLJViBIQzKmIYioYABQiLJ VItPqIqDFRjYpNvN1OdbhYA6cAEYU6gIZYhVEMRoAAAUgACoAAAoEAGKAYIYiEAAdACJUCgQ hokkSWHH1FEVCWdMOkaG6MCsmmPURqFTSJ1qNEUTSLGaaRJIaiTUDWGLUaAyzSHhthMqWCZZ K0yqTjDNomVXxLYowx3UG9McWdeGwl8c/wCwvrf2G5L7Od2k9VKRHxI1onV8o4v2G6OysrOL k/vuvsyNEVoVI0iuSVC+NYu89Hn9/GcaSlFxT+Y0eX2HdtV1aVySqyXnaWiD41L/ACengYtL HiXHozm4yL/lkb1twUnGTpSUnX2KhZsdgtnFx1a5SdW6U9RfLc24/FV9GJm3G5lchKFpuDao pGuida2uLWaYUZx9lbubVNa6t8v4l8pyl3m2Mni3SmorFrqqUq/FdqVXLoM1AGV8Wh7t/CvW Vu/clxp1FYzOWsQN1zdQAApgAEAIYEUgAAEAwKEKgxAKgqDckiDuBEqBQrdxsK82XCZWYIi5 8hakDupFwZD1vJJdZKNiUs5P0YFbvMPGkE6tj2tuMHJvtJYHnd9F3UnmdV3K5s597j0MzWpH F0rHmmVs03YaJ9DwKJCuaJp2ksXHmZ1BtVpgSVI4puo1uLlL1joOKx1ZMx2bU7r0W05tfL9u Rq2tjxZJTeEsFXHM7W1l+TFUpp7EkucTrv1mcMa98ORd2U7FpSnhLjjUzRemVTsbzd2dLttq rwpm/UjjNNdaPPfd2sw6Faqo8yqxLVGhZErIYqjYkAxAMCIDEBFkUToQyYQ2ZrqxNJnuoCmO DL+koLlkBYjVYkZVkXWnRlR19XYAp1dgDI8qAwPpOJCJAURAYAIYDAQwGAqBQdAAiAwAQhgA gGIAAAAAAAAAAgAAAAAAKQDAAAAAAAAAAAAGKoV5gdTbeZRlFWd2tUPhn8USW52jtJTi9dt9 2ay9PJnOt2JzVUsPmeCNW33X7OqjLWn3ofCZ2k26VZmdkGidu67b6ORq8G3uo69rn8Vp5rq5 mNo8m/HdXSbZbYTjcVUJoxJuLqszXbvqeEsGcmjaFQscaEGgINEZQUlRllBFRladt9HM1Wtw pLTPFEWqqjKJW9OKyNS2dksytvbX4oYozxm4YPFci61uHDqLp2o31qhmbxL116Uls7sjgmtU MV7UQJNStS5Mnhdywly4MmfSuk6qgJUpg8wK0QUGOhFKgDoOgCOr5Nu/CuOxLuT7vRL+Jy6D pyzIYeyAy7Dd/u7Sk+/Hsz6+fpNQYAhgBCduNxUkqowXvL2u5iuTOiAHItbi7t3peK5M6Fnd 27uGUuTLLlmF1UmjBe2Mo5dpe0qOlQDlWt3dsvTLtR6czo2dxbvd148nmTCrAGIgAAAAAAAA AKAAAAAACAAAADMq3G5tbZar0lHkvifoOHu/Obt6sLP5cOfxP08PQFktdfd+Y2Nn2ZvVc+SO fp5HA3nmV3eLTcei3/24YevizFlkJo01iT4m3BKkYJdLFKc5qjeC4cBdQniVbbQFeQCDIGAF QIkIkgBIbtKUHLkxpEk6YgnxJRoiv9w3Klzh3TQmuKp1CdqE8360al90uvtUFjisUSoQezj8 MkvSRe1fzr1lTFWqqyqQZH9rzmgjtocblPQ2Vk20sxa0NWbK4yfUqEkrayh62VFWquQ425z7 sX7i3xWu6kupCkpS71f5mVEPD096SXRHFirGOSr0yHRcyLosl6yyIUpSng8egi4tZ4EnJkCg wWQm6gIoBDERCAYBQnR1J0o+grLo9qJx5J0y1ELi4kKFklWJCEJXHSCb6i6XMCrQIxc3SKbf QizwVH9SaXRHtP7PaThcUP0ocM5uvswXvNCMNnfm6Qtyk+SVR/tXGOq7JR+6u1P1LL0tBO/c mtMpvT8scI+pURWmo91U94E1KEf04V+9cx9nd95GcnPvyr0L6UEpOWC7XRmaIbG9c+DT0ydP 4mbtNfquGprb9MyzVS7q9PEG64s6Vvyn/uT9EV9pphsbNv4KvnLH+Bx2/I0nbq6z8fe9+jiw i5ukE5PoVTXb8uvT7yUF977EdhOiosFyQjjfydr9Mw76/jaz6rlih5Zbj35OXVgjXbs27Xci l08SQzjd9tvqrtOPXX6YlqbzxDAQyRqmkAIaZpkDAZUIB0AqAAAIYABQwAAgIsZFirEWwRFs kovjgukw0YtSyWI0ocVq9iJObyVIrlFFQaXxpFC7PWKg6AJy5YEWSoKgEGRZY0QaM2NyoMQ2 ByUDEM1AgGI2hAABQIYUCEAwZFRAYjFU0iVCI0VAA6BQ0EFRgVBUAAqGOgqhU0iVCSRBMsi0 WM1OMS6MB2rF2fdg+t4e81w2Vx96SXUqnSa1x23k9Weij3nQktOSdXyjj7iV7ye5dacbtHx1 R91Dp7fawsRUIYtLGXPpZrw9653kno5txStQ1yhRfeaVfRiy6ztp3YqdyWivwxWPrf2GTcze 43a0pzt2/k7R1Ib2zcrRtUz1rT7zX25Pix57Vz/Ndno20p2U9Sxbcm3Q8pKTkubPbz8xsQ46 uiKqeZe3hqbUnSrpHIvlrqnjtsw2ZSTqqnttnfV6xC42lhR48jztrb208Ir04nQtwRPPLX28 d66r3NuPGv4cSqW9+WPrMqQ6DJ4xm80vTuQWp4J8CGxVYUZLfr8tdZHy/KRFbKDCg6FCoAwA QDAgKDAYUgGKpAAKoOQDAhrBthUhOSWbIMWCyRBLxY8xO4iDqxUKhu6+BB3JMdBUKI4iJ0Cg RGoqsnpGojIrxChdoBWwqijGoNmhQSHQqZUK0c/eW5QuPDstHVm1BVk0uszvd2rlVBSuP5YQ ciWZ6EuOrg3mnBPk9L+pmfU69lY8WdbfbmMaWXaUG3xktS60jmXsG6cRjHRna5uYhK68kVoc uDEZZbdtJvsrPgej/wBshdt1vt0m1ccYulHSjy9pwfLaRlq4nqdtPVHS+Br7l7MWeqG321ra Y2IQjTil9Ged8xt6L8nwliegn2ZNPgcrzWFYqa4HTeyzDWsx1c7bTo6GpZmBPTKpuzSZ540k yt4MsKrjoUSqSK06k0ACYwAiQZNkWEBVcRaVzAyssg6ohJUZK2BfDEshgyq2WrMqNursAVau wBBwgAZ9JxIBgBEKDABAMCgQxoaQQqCoToDRRWFCVBUIIgSoICIDEAUCgBVhSAAIAAAAAAAA AAAAoGAAACIpgIai5PBVAMXkXW9neuYxjgQ0xXefoQeJTuqnvA0z8u8FVv3YQfyrtS9gLcWL EaWbeufz3PqiY6EtPPAmFSuXZ3XWbbIqLfUFUskJtvMCyE/DanFvUuKOjDdW95hepC9wnwl1 /acoAN96xOzLTNUfv6ipk7G9cY+FeWu37Y9RbcsdnxLb12/m5dZ59+L11bl9ytbjThLFGnCS qsjA0O3dlbdV6jzdm2xoiShcjdWGfIGgIESbREqKJ2+MSEJuDqsGaSuduvWXIuUobhUeZmvW JW2QdYmm1uE+xcxXM3mbdNu/uz1nZRG4pdm56JDlBxePHJll7bU7UcUUwuuHZeMeRLmd3XXa U6DoT0prVDGPtQg6FQKDGAqAMZFaNjuf2t1TfcfZn1c/QemZ5E7vlG68W34Mn2od3pj/AADN jogABgAAAAAAVVdsQu5rHmYL2zlb7SxXNZnUAuUw5lrfTt4XO1HnxOhauwuqsHUhd2sLmOT5 o513bXLD1KtPmiB1xHPteYOOF5VXzI3wnG4tUHVDAYDEQAAAAAAAdYVQPBOUmklm3kcrc+cx hWO2Wp/O8vQuIXGXRvXrdiOu7JRj08epcTjbnzyU+zt1oXzS738Dm3ZTvS8S7Jyk+LIaS5am uClJybk8ZPNvMTHQVAqIiVBUKiNAGBURAAKgABlDRJEUSQRJEkRRJFDSqMACChGnSMRULDmG HSFBFQYcvWx15JAFCoKvmRoToFCoqaItFrRBo0yrYibIsqIiG0KgUh0Co4wlPuqoERaki7wU u/JdSx/gWRvK2qW7cK/NNan9hFZYp3HSCbfQaY2JWe+4qT+BOsvZghO5dv4VlL7sFh7MC6zs Lza7CivvM572Sfyreutv0xQ1h1EZzcsJSw5LL1ZFrVJNPqNexsWrkW5xTlF8eRwm80ma1rpd tvFzFi6RVX6y+Oyv3Pha6ZYHbVIKkUl1KgHLb8m/2x6p+NP7q5kPK3/iTS6Io0w2FiHwuT+8 zSBx25d9u+ztrxaa+hRSgqQSiuhUGAHJ0AJ0AAHXmGAgKHQBDqVDAB0NIaGkIkjbNFB0ACsg AABgRqFWDCQVK9VcFi+gsVmbxfZQz7GPcCc11lqs21nWT6XRDaXCMV1IuKzmK1anJVdIp8xu 3FZ1kTpxeImi4TKpumWHUVlskVtGa3ANCRNIASHQdBlZyjQVCYhgyg0VSRcyuZLGpVLENkan nroZIgTRrVKBEqEaHRCAdB0XEBDpXIE6ZL1g5N5sik10gAEEaAMDNUDREkSAAKkam0OoVEsc gl2e+1HrLJb2S2TuAqVT3NqC4v2Ff7ucu7SK6DrOLa/ByvLrO3VrUX1LpFWKzdeoypuWMses sbpjyR2nFPXq5bct9Oi/b3vEuKChqrzdD0Vq1G2uxFLqR5PZXp2biuQVac8jvrziCj2oPVyi 8PWdbrrr2xHDO+/vXUSLKYVpgeeued35fpqMP+Z+0w3dxcvOt2cpdbOd3jc4tvXo9Nd8x29n CU03yh2vcc/debxvQlahBpSTjqbpn1HGXQWRg2Tyt7N/b1nfqs29bKattqudMDRSueJC3apm WuIvxMydme5IpqaLkDLLBnOxuVqss3wOZZlidO1ijerGy1DCg6GmGTfL8r0kNhxRfvF+UzN5 c6ykQdCgUGFQEAnIi5ATCpU3ceSp1jUZfE/URU9QnMNKCiQCq3kR0zlxS9pOonICKtri2/SO iWSBsjUCVRVFUVQGIKhUAoFAqNAKg6Dk1BVk6LpKpbyxDB3E3yj2n7ALNIaSr905fp2rkulp QX/MVyv7h4KNuHW3P3UNeNZ8o1UHppi8Ec65O9hquuj+RKP2snDa2pqsouT5zk5F8KnnGiW6 swwc415LH3EJb2K7sJy9Gn3lkNrbS5dGRoUdvGPdbl0l8WfL2jFG9euxrbUE/lbrL6kS/abq 66SclHrUfcbFep3UkJ3pPiXpD+VU2/IsdU7lE8+PtZn3e2pbu2tpbuQ0drxVKilTPI1qeOJd G/TPIZTxrwMlR9PM2z/MgpLiqh5ltvAuyUe7XDqZXtJ1i4PhiupmKqpYpr0kUWSWiRCSo6Ga rTtZ6ZUPT7C7l6jyMJUdTvbC9UxWa7e5tuVJrPuyMe426nBpuptnW7ZkovTJx7MvvLI5mx3b 3lnW1Saema6Trr1mb6LrfRwJKnWjXYlqjQjvLei61weJXt5UdDl2rVbFkVXEWLMU1UqKossi yitHQsiwLGAAgIsQ5EUAIhJEyMwjJMIvElMggNEHiXGeD4mjgUWV7IEK4AEcoAGfRcQIYFCA YUCFQBjSAEiaQJFkYlEdInEuUROJUUNEaFrRGgFbQmibRFogiIlQQVEBgQIBiCkAwpUBASSS z9gV5YAGnngRGLMgBVRbbtQm6Tm49Uamz9vsLX6k7knyjFR95cGXOquJZGzJrVSkecsC79zb tSrt7aj9649b+wonclceqbbfSRT7EfvP2CdxvDJckRox4IBJVHRLMTdQIHqfDAQAAwAZFIYD oFBbYvzsS1QdOa4MroSSM5VuiobnG12Z8Yc/w/YUSjR04rgUpUxNcb6urTe73Cf2nPbWbLFC dMUabW4UuzPPmV3LLg8eOTWTKWqHm21say6DRBootX3DCWKNNVJVWRlVdBULCNAKpRTzKJRc TW0QlGpUV2r8rfSuRfK1C+tVvPkZZRcQjJxdY4M3NvS9mbC7dmVVgy+Dje7uEvl59RZG5DcL TLCRmu2ZW2Wz117N67+lWU5jFC+p9m5g+EvtJyg45mXaXKNB0HQdCNI0LLN2VicbsM4v1rkR oOgHqYTjcipw7slVEjkeU7ije3lk+1Dr4o65XOzBAMAhAMAEAwAQDEBmvbKFzGPZZglaubZ1 TcX8yyOwGlPPEuUww2vMPhvKj+ZZGxSUlWLqugz3tlCfcw6OBicbm2eGHuY6HV1kBks7+Muz cWl+wnuN9asYV1S+WP1vgSrOvZpoYNx5nbtdm3+ZL/lXp4nP3G7u7jCbpH5I5fxMzVDPl7Os 090txfubl1uyquEfhXoKWibREmWsINEWibIsCLItEmRNMkRZJkTSExMdAKyiIYGkIAAqGiSI kkESRNEUTRUNIdBoYEaCaJ0FQqK2Im0RKgoOgJEkghUChLqHRlRW0VtFknHLN+sStzuPsx+s uRU0QcoridG35bqxuxk+jWo/UXrYW13YQiums37aL2Gby6z1bnFtfRxoQnd/Ti2S8KK78kuh Y/w9p2f2dtqk3KS5VpH1KhbC1bt9yEV6Dneeeky6z8e+tw41uy5fpW3Lplj/AANC2N+5+o0l yr9SOo5N5iOV59r26Ok4NZ36sUPLYLvSb6sC6G0swygn+LEvEcrvte9dZx6ztBWmCwXQIAOV dXK30NFyq+Jaieynpu04TVPSi/fw1W1P5Wc6EnHFZxdTvr/LXDxb/wAOTy/d2xDqnisniB5X vIAAAAAIoAAKgAdAKAACpUMYqgaZSRIgOppEgEm33U2T8G686RXSwnzRdSNU3RYsuViCzbk/ Ui3XpVIpRX3UXF9ejN2k7dVCszlyiuknGxBd6siTmv8AiGps1iM+VTTUcFgJyIDNMitQGkSU QZRAnpHRDBlTKJU4mhpFUiWLKhQaECMtJDEMqAQwAiyuaLSuTJVjOxE5EDz12BOKbIEkIVNp c6voIjA7MExDFUigBVCowGBEekYTJNkaknBlMrtuOcqvlHH+BPG3tC7yd6nUnFN5GOe9ce5F Lplj/AVq/K5LtSb9x214L/d0cNueT6erXK5BPS5KvJFV/cxtJaEm+lmW6kptJEFE7Tj0nxc7 yb7euE5bq9PCtF0YFWl5tupojZbxeBZKzCtVyxXSa89Z2Z8NrWRRRfC23iWpRjkh1Od5fZ0n F71KMUixUKKjTM+drp4SNNSLK1IadSBUqWQtNk7camy3bNSMXZTCwaYWaF0YFqibc7VGiiIq NWXzVCFtBFdy3gcy9GjO5KNUc3dW6Ga1rWO1KjOtt5VRxqNPBG3bXtLoyStbR10DdCuMpSXI lp5lc1O7kvCkY9jLS3RV6jbuLa8OTpjQxeXS7VOgDoKrzwHpJiqULSgE2KoDCpByE5ATqR1E HIjiMCxyIuRBumZFziuIVY5C1FbuYVpRc5dn3lM95bjlJP8ADiMJmNVR4nNlvJy7ifuKpeNd 5mvGs+UdSVyEe9JIi9xBLUlJrnkvac+G0vLLDpZP/b5y/UmMT3PK+yU/NadyC9LKJeZ3pOla dEVQ0x8usrOrLY7azDKC9OJf4n8mS5q3NE7UcMaubbY7b3cv0ZqKXw6dKRvSpkqdQy59k8fd ljZ3Msbl31KpZHb0xc5Nlw6Dyp4xCNmCdaYlqwyEkBMriHUNQUJKKIdEdQYlioh1C5VKMn0F 0NvqzZFzoON+gOrJ575fFWFfhnF6ZdTPK25+HcTeWT6me2u3letytSykqHitxZ8KbgGcLr8K Y8UUyxSZojLxLabzppfWihcYsxRFHR2N2hzkX7eemRmo9htpK5Fx5mPbbfw7t23Fdu5LXH1d r2hsbuRq3U/AfipVXHmuo1pe+vuzOlczzXb6YqfFOjOQnplU9Xelb8wg4SdG12bvN8pfaeUm qYcU6E2x0sdOvq3J4JkmqoosS1RoXxyIjLJUeI0x3kVxkBpTwBEIMmAMrriWlcsAGyMshilk EZp0Ki2aZUBbFmqLqjHFmq06oomAAEcoYAfRcTABlQgoMdChUGkCJJASii2KIRRdBFQ1EJRL UgcSoySiQoXziQoBU4kGi/SQlEiqGgoTaFQghQVCbQ9FM8AqugULKqPdz5sjhmwFRdYiLuLg myHiVzIuE20gx6jTZ2s5x8SmiHzzwXo5g3Zt92tx85YR9WZcIohblPuqpY7cId+Wp/LD7QuX Z3MJPD5VgvUVqLeQE3eklSCUF0Z+sqSqSpFdINvIBaaZhq5YCAikAwIEAwCkMBkUiSQJEkiV YVB0JUChjLWCSJJDoNImVwSRKgJEkjOWsJ27jgtLxjyHK2mtUMV7UQoSjg6ozavjlU1QcJuD qi5pS6GUyjQ5XX1jPbu125xudD5EmjBVp9JqtbhPCfrOaptEaFriQoUVuNSmdumKNJFoIy59 Zot7jDRdxXMrnb4kM8Galwli29tqdqGKIWr7t9mWMOX2Erd2VnpiWzswvrXbz4m8Tbt3JtdU kk1qi6xChjjKdiVVg+KNtq5G93cJcY/Yc8PRrtkUHQdB0I2SqmnF0axTPRba+txbVxZ5SXJn n6GnZbn9vc7XclhL6n6AzZl3AG1QRpzABUajJ9CAQDcKZsFRZIAowpQdREUABG5cjaWqbogG U7i9atL83j8ObZiv+YylhZWlfM8/4GB4urxbJdm5pnunO7GUm1HTHlWpB2lnHIixJtZEm19e y3T116UpJxzI1L43U8JClZUssGXxl+n+ied1+ufuztkGyycJQdJIg0TGO7ec9YgyJPSFAKxU LHEWkuUwroJotaI0LlMK2hULGRaNIhQRIRplEQwKyCSIjRUWRLIlcSyIE0idAinLJNl0dvcf wv04DMnemLe0U0IuJtWzm82l7Sa2Mfik31Gbyaz1anFtfRzWiOB1VtbK4V63UuhbUe5FR9Bi 809I3OG+tw48LM592LfoLltLnFJdbOtpj8bb6ELsruxS68TN5dvSSNzh19ba58djOfxJeiv2 Fq8ttL9SUpen7DW23mwM+e3uv29Z6K42LVvuQS68Sbby4DEZub3bkk7IsiyTIsikIbERohgB AAAFCEMRmrEZx1xcXxRxI9mWl9R3Dk7+34dzUsnj6jfHetjhz69Js3bOWq0lxi9P2GgwbGdJ uPCSr6UbzG8xs68W3lpPh0IBiObqBgIuAxAAAACqAwBJyyJKMV33/ZNSVm2FUFVuiVWTrBd2 P9p1+wNbpSuHJYGvG+7PkfhNd5pe0sjGC4V6ypOmWA0zckYtq/Xyw6hVK9RFzoXLOFzkLUZ5 XaFfjSeXsLJb2iW6zvWvUJySzaRk03JZ19LBW2uNOo3NL6ud5NfRtU482/QPx4LNr0yRi8JP PEkoRXB+s34Ri8nwav3ltZUfpHHeweFPUzJLRgot15MFb14UHh8U+58G/wDcReRF3EyvSklG OSzfNj0NHHNejEPUReJNRBxSAqoOhN4ENVcseoy0YVGrUnnSJLwY8avrL1TMV6uWPUS0XHml FfeeJOiWWHUIYMq3DnJvqwBrlgTbEMGWWaoVlt7BlLZw3nV1l6GNEKgmYirkDIqoSi0qs9E7 OeQ2Ko+ylVunWUz3luPdx6jc0t7M3ea96uowolizBPe3Jd2iXrZmuTlPvNvrO2vBb9XRx255 /bMujPe2ocav7pQ99KaehU68TntcSyzGUpLSm1xOs4tdf/tyvJtt/wDSU9xKTTm6lc3R4F72 Un3ml7SxWIZvHrM78ms7f8GvHtf/ALY6OWWNTXtrUoussC1UjgsOoEzz3mv9sdpwz+6pO3Ft yeNRqkcsB5oiZu1vd21knYVEMDLRAFQqEAxVCpRMaZGoVKjXamka4XUcyEi+MmdJXLaOrG4X RdTm2/El3VhzeCNMLdyvalh0I054XXmFuaSHoSXPrKlVyGEXSm6YI5+4lKtXivUdFRKL8Koz hZXHd2SwWHUaNrLHHMz3YaWSsS0skbvZ3YZEzLauVRY5cjVuHPB33WEl0HM2D0zS6DdPU4vq MG0VJ1eCJnJh03MTmOMFLu9r8OJattcfw0/E/sEuS9GerY9LZrWxnhWSpxSw+0ut7Ww69ltr B63U6YY8nMbis2iPiJ92MpdUWdxaLeVI+whLeQjxb6gZrkK3uZ9yy+uWBbDy/dzfbcIrrb9x rnvvlXrM9zczmqN4dAyYqFzy7bpr9xexXBfRspl+1lclajC7JR+LVpi+rIdVHJUE51JlfFTP aWpd23GHTKTmxrbQj/BUJagqM1fGGoRjkg1ERqNQoqBLSlxI4AACqFSiVBCAIdR1IjAdR1Ij SbAlUWoekatg6I6gTqWK2iaSQwZZ2myUbEnngaKpCdxIYM1OzslJ4nA/qLYLb3tce7JVPRQ3 SiYPN0t7aa4rIdE6vL7aVax9P09BG4qSqR/Smmssy69HDAlRnlmOLoDxQkYR3NhdyO7hdtUe NOB5PZ3KOh6fZ3KrrM9qzWS75bLRJWLrhLNcuo4t6M1Nq4tMuKPUz7LocTzW3PxPE+GlFQ67 Ys6Nzr1YNvKkqG2OZz12ZVNydaM5QK9GqMndZumqoxTVCiyEi5mSDZpWRBNFcySCSqUQixsh F4k2BmuZlTL7qKAhpmiyzKjRZeIGgAAo5gDoB9JwCHQESoVCoFCVAoAkiSCg0ionFF0UVRRf FFRbFEnEIFlAMlyJUkabqM6zAVCEol1UiuWIFDjV0DTzLGuBFuMMyKi3TLAreGZNycsnpXtJ W9v4j7KbfMCjF5IFCrXFmx2LcO/Jt/LH7RO9KKpaSgujP1jA0Wtxd2y7fhwXTBOfq+0V3zrc NabbUVz0qpi0VfNj8KnedOjiBVduXLzrdk5PpYvDaxeHWXZYRXpI6AK8Fkq9LFJuWZZpFoAr oFCzSLSFQoFCekNJBXQKE6CoBAY6DoRpGg0iSRJIyqKRJIkokkjFrchUChKgUOeW8FQaRJId CWrgkh0HQdDGWsFQY6DoS1qREkqPCWXMKDoZzhcZVXLTj0rgylqhtjJx6U80RnZTVYelF6bf Nyut1+Sq1fcMHijUmpqqMDjTIcLjg6o52WI2tEWh27sbnQxuNAK2qlcoci5oQRmTphmuQ1WD 122TnbriipS0vpKNUZw3KpLCRlu2ZWnX1Mm4qWMcJFtvcJ9i6dMzbpt/VnrOx2d0p9m7hLhL n1mhpp0oY722p2o4oVjdO2tM8Y+4xdcO2u7aotkXKC7Ob5LEhHbXr/ad1K3zjh6zVCFq0tMW 5exDDpnLp+Xbh3rfhywlDKubj/DI26eZw4XpW5KcKJrhz6DtQnG5FTjkwzYmFRAGTEABQDai tUnRLizJe38IYW+0+fw/xOfduzuus3X3EWTLZe8xSwsqv3n9SOfOUpvVN1fNjEzNrrJIiRZJ kaGWkWJkqBQCFBxk45D0hQmVwtjdU1pmQnt1nEjQcbjibm/pt1crx466dFThTBioatcJ4SK5 2Wsi+Ofp/oTfHTeYUUFQk3TBgot5Jv0GO3d079lbRFovVi6/hfpwJftJvNpeknnJ6njb6MjR Fo3rY/NL1IktjaWep+kfd1i/b2rltEW0dhbayvgXpxLFFR7qS6kT789IfZvu4itzl3Yt9SLI 7K/L4adbSOw2xE+/t6SNTgnrXNj5bcfelFe0uj5bBd6bfUqGwZn7299WpxaT0Uw2VmPBvrZo hahHuxS9AkyS1PInlb3trXjJ2kWVp0Cc0syKt/MyyMYxyS9Imb8C4hJueRLQvidSTbeYG8MZ LLJCeOZKhFlZIAAKAACoAAAIsiyTIsCIhsRGgAhkUAAAIQxEpCMm/t6rWrjHH7TWJpS7LyeD 9OA1uLKm88tbHHsXNFJfK/YdlnDgnCbhLhWL9B1ttPXaTea7L9Bvknq4cG3W6/uuEAqnF6zA l4cs32V97AcYwTxrP2L1lxUzFbkWQs3JrUlSPzSwXrf1E/HlHuKEPwxq/W6sqnJzdZNyfOTq Xxnrcpm+nQqRXGv4ftHWmSS68WRAfINycs231gCQ6GsISJEoxJ0UVV8Dc1YuyugpvR3nR8uJ S9zOfd7EejP1krNu2oucvRHn1nWcXu4bc3+IU3Pupk1B/E6dQlOubQ3KKzaOk1k7Rxu+23ej 8uPdVX0klKWUcuqhW78I8UL9xKWEE31I0wtcXnIG4xzePIrVm/c4NdZZHy+T78qEtWTKuV6K yIp3LncWHNm63s7cOkvVF3UZuzc0rHZ2WntN4vi/qNKtqKogndjHvNJ+thqbVUnT72HszOd2 y6zXHU6IG1HF4dYtLeb9CGoxWSXpI0p8aM8IJyfRgSULr5RRc5NiqTBn2iuNmKxnVss1RyQh PEuDOTb5EWOnIWIRETJEWFJkWSo3kqiklBVnJRRFyovLCpmZquyjK25QjJxWc6dlekwyvQjz Zy20tvRqb66zrVossXgidiSnDVTGtOZiv08SSRdeLr1rG3N0/jG+NymCYVcnnj0me3NKKlJ0 VMRxd6/ht4Sa+d4L2nt149Z/9vNeTbb/AOlW71NpTpVGTN0WLOh/tck63pY8o/aarPl1MbaS 6c36zd3kmIzNLe/RyJba6mlpzVa8Ccdn88vRE7f+3qOM2QlG1DI53k29OjpNNfXq5sdvCOUV 1yxLHqZolOPBFbdTjc3vcu0xO0wp0t5lclQ0NOpXeg1iZs6NS9VNQqIRyw3lohihNDtYslON DpjozL1ViGyLM4ayKhUQgHUEm8hBUoscXHPAVRIConGRrt3KGJMujI1GK6Nu7zNMLlTlRuUN Nq7U1lzsdFyqiFtVZVqdDRZtuhm7yJhYVzVUXPTHBvHkRvydi27rtycY5nLzt+mWr0ndxt1Z axMSkost3fmzursQUUY7O5mpqXJ1Oumu1+rol3k7O7sYTuZRlTqOtHay5Jdf8C2zvIXrcbla VWQpbmPB1LeLW3O1Y876K7mx1wac2qp5JHE2jhC6vFo4RrWuWB2pbmVHpRwbGN2jxq3UuNZ9 J19Xpre4tTgpwa0PLh7CEtzBZVZiwWCwE2XyPFplvJfCkil3ZOrrmVAFxDchVGosNKWZVRbI sm6EXJICGlsl4a5icyDkRU2okW0iFQoA3IWoNLDSXCCoDUSSouAEQoSbqRAKDohAVDwGIAGS REeIMJ1DURoCQ6nRLWRc2KU4Qxk0iv8Adwf6cZT6kXFTMW1bBW5SK1evydI21H8UvsLI29xL vTjFfdiPE8lkNtV4mq9sVbsuce8sTG4Qh+rdb9NCm/PazWmyrjfNyfuHizdnnt/Z8O5KKy7y K7ctUUuWB0vMIeJYjeS7Vt6J9TyORbeiWklhkLBtEMiy4qOpCXMwJ2paXU9FsL32nmkdbYXa UMUeluJSSkYt3FXbUo9BssPXHSUu1zdD0cVzMezlbY8rJYGqxLVEW7teHdlHhmirbSo6HCzF w7d+rdHFGa7E0Q5EbiAxppZl1uVUU3FRkrciC+pIgSRRnboy5OqKruDwJQbaAhdM7NNxYGZh CLLboyslF4gba4ARr2QKMQHZcYvNIg9vbecUemc/vGrwe1coaaOk9nbfQRexjwkzpObX4ud4 dmFDobHsHwaZH9lNcE+o3OTW+rF49vZmoFDR+2mvhZF25LOq9BubS+rF1s9FcTRFFNMcycZt dPUaZaYlqMynL4YMtVH32/TgBG5NPBY9RjnWOZ0Vpa7PsM91RyzYGJ3nHIolunU2Lau5m6Lo L47KFKJelkxTMcuPjXcpURZHy67LFOLXNyodWGxtxxa1MtduqpRUGFy5cbW2sLtt3JcoLD1j luJ3cFHTH5UdHwqklZRUy5ihJ5IkrXPHoOl4XDgCtAc/wnlkg8E6KtD8EDmOyLwmdN2ULwQO Z4TE7R0nZIOyBzvDYnA6DskfBKMGgTgbnZIu0QYnAi4m12iLtDCsekFE0u2LwzNailRJqBYo jocLXaRDSGknQKHO1uRCg6EqDoYtbwjQdCVAoZyuCoCRKgUJlSoOgwIpUHQYyKVBoBkVGdtX OiXMy3LTi6PBm0bSkqSxRubZ6bOW3H66ubVp8marW4r2ZkbthxxzXMzuLRLrjrHJ0HHiiDRn tX3DB4o1pqaqjKq2iu5b1FzRFoIyVcXiW9m4qPMnOCkZnFwKL4XZWHSWMS25YjeWu28TPG5V aZ4odJWXqhkbm3pezNnsjbuT28sPTFnSs3YX1WGD4xM6lb3So8JGW5anYlXJrKSF19Z2b13x 0rr0NmwvaJeFLuyy6JfxOXt96rvZuYT58Ganhg8Dm9GZY7g8zLb3tt21Ob7WTSxbf8TPd3V2 7hBOMejP1lzGPG1rvbqFnDvS+VfWc69fne7zovlWRFWp8IskrE+XtM3ae7pNL7KqAXft58Wi X7Z8Zewz56+7Xht7M1CNDZ+2XFsf7aHS/ST7ka8Kw0Ezf4FtcB+HBZRXqMXkns1NK5tUNRby TfoOlWmQnJmLyfBrw+LArNx/Cx/trj4Jek21FUn3KvhGRbSXGSRJbSPGT9RoqIz57e7XjFP7 a2s6v0knajSiwJiJ5be5ddb0sVadPXzGrsvixJkZRr1nacmu/Tln7uP29tOvFf8A+pqSeQFd OeDGpNZk24b9Wn8ouvNM+O/8dkxBWuQji7kwAQUAFUNSayw6ShNNZhgJuuLxY6lE0+RJMrTJ xNxirETSIRLEdY5WpUAANMkyJMiwIiJMRAhiAoYgABMiyTIsCLIkmRZGiAAIpgAAIQ2wo3kB ERPTzFRLh6zOKuY5PmENF3WviSl6cmavL2pSlCUlFNak30D8xhrta+MH/wArw99DFtrmiUZc nRne9dXj+jk/f/t2aR4Vl0vsoNbWWH4SLzxChxewN8RVqOgECoOgVE2AARqFQJ1CpCo6mss4 WKYanwZWiSRqWpiJXJ+I9U4py+ZYP00+wjpXIkkSSOk2293O66f4oKxB5xRZHb218ESaJOcY 5uhfK+7Hjr6Q4wUcoxXoLNTKldUv01KfUqL1hS483GHQu1L7DPkvj+y3UQ8RcMeoWiPS/wAR KoCrJ9HWDgpd6r6K0XsHUACKjHupR6kMQFDCogAdQFUAhgNRbEpRboqyfKCqADUW8iyNm7LK KgvvPH1FG12t6dyl5NQo61fHoLis3aT1OcoQwnJV5LFjhau3P0bTp81zsr24+w6dmzG13Ipd Sx9Zc5KNNTSrlVm5p7sXk9nOj5Zdn+td0r5bS+t/YarPl+2susYJy+afaftNNOZCVyEeKNeM jF22qO7t+PYuWucJJHgW+zVnu3efA83e3O32kpW9raTuRzuXFXHoTFSRyo3dGMZNPoIeKl3V 6xty3F2tx9qb7UjbudpaUJOEVFxXe6vtOVvVrFrLY3Vy1OMqrTF1pTgepncg8bl16XlWiPJJ 1SR1NjblctVjV40aNZXV03vLNruOT9GHtKbnmlySpCkRR2M5OrLP2UbfedCtdGGdyc3WTbEo SkdBW7ayVR9lZEXLHHbt5lisUL9XQNKuKGDLPctJKvIq3cOxVGyaWl1fAy37kJWUk8XgSrK5 aBjlHQ6OnoE8jg7r7Lo0ab3UYrcjpztaoqXQdJ2c70rAyEnjgqFs4UKpGW5UQBiqRQAqhUCQ yFRlE0yaK0XQjJ5OhqS3sxdpFtuzKXQunAvd23YjhJSn8qM3gKXfbZs2SsWbkZOKpxwqX7fr ts53f2i62r24aVqKUqV7VaexGrZXbd269tuVON+OcW+w+qhLc76VyGjbN23XvdBTajqu+O6u 5SmpmsaT4uf8r8HbioWl2EoroKrm5hRqWKaozLnniDRm747L4e7gS8ujbzblyK1CMHgkdm/B NHJuU1UTMed2rpNZPRrsTN8ZVRy7MK5uh0bUcMzVyLGzk2v1f5jsURyIRpdz+ISM11tImkhO ZB1ZRPBC1EaDoawgcmRbZPQGkvQV0YtJZghO7TJDMMIO2LSN3GyDbZMrhKiWZLxEskVCHU6J yuVI6hNoKGvGs+UOoFbu0yF4jZfFnyi6girUxVL4p5rqpZsWuKKaDNeLPnVviLkLxGQAvjE8 qnrfMdSFB0LhM1ZHHKhLw0822VKJNQGEyko24YpIcrreXsFG2kTokTC5Qc7jywIuzOecn6C6 q4KpJObyiVOqu3soLNV6zVCEbMllpeZWrd2XFIl+zldprn6iDg3nGzvZ2H+neTg+vgzjXYOD o+9F6Wej30dvYu6bka3E6Y+w5HmFpRkpxrpmuPzIzt7t6s0+1FSKuBZZdVpINUdDk0iatrc0 yMpODozNHrdjdrT1GrcRalVLM4+wundrrhXkXS4rFjg+a2HHTc9Byq6ZVR6be2vFtSjxoeYm sKl5O+XSdm+LyZOSM9mVYmhYqpgZL0SiODN044GKcaMC+MkTTM8HQtTIFfRXakky64qxM0XR gX3DMy+TqiiRURGmDEBpr2AIanpAD0f7ObdJRXoH/t7fQdXMKI9XjPY8tvdyX5fJcRLYTeTR 2NKHTkPGL57OR/t97gk/5gWw3FaaH60dZN1oy+y+1iTEPOuE9lfjnbl6MfcVaJpV0yp+Fnqf EinSoopKTafoIedeVaTwdCPgQfwo9bOClmk+soe3tSzhH+yaiXf3jzS28ORONiK5neeysP4E uptEX5fZeWpfzG5tfes2630cOW2i+XpRXLb9Efadx+Ww4TkvUyEvK28rnrj/ABL533TGjiR2 z4URZ4D6zpvyy6spxfWmiP7DcL5X1S/gX7lPHRylsmpa6yr0zw9RZ4UufuN72e4+T1SRH9ve WcJD7lPDVi8Kf0oPwrnL6es1OMo96LXWmR1R6C/cp9vVn8Ofyhon8pqSTyJaesfcp9qe7JR/ Kw9D9Rro+bHjzL9y+x9ue7HVcfcHZ5m2sugKy5Ifc+Cfa+LFpTE4o24/KhU+6PufA+18WFxR FxRvrHimvQLsc17C/c+B9r4sGhCcDoUh931IfhrlH1D7nwPtfFzHbK3bOs7S+VEXah8q9g+5 8D7Xxch2iDtnXdqHy+wrlatLgjG3LPZvXivu5DjQjQ6srVvkiDtW/lR5NuWez068V93MoOh0 fBt/Kg8G38qOV5p7On2b7udQKHR8G38qH4Nv5UZ+7PZftX3c4Do+FD5V6g8KHyr1E+7PY+1f dzgOl4cPlXqDRH5V6h934L9q+7mhVHS0R+VeoemPJeon3fgv2/i5tVzCqOlhyXqCq5In3fgf b+LnVQ0dFSB3VHNj7vwX7fxc9VeSZJQk+D9CNj3FckWQhcmqtUXqRPu57Q+3J3rAouOUXXko lU9rOfajBx+6zrpRj09Q9XLDqNzlsY24Zs81KFAhccHgdvcbSN7FYS5nJvWJW3pkqM6yzeZ1 7+zy76XS9e3uvt3Vc6xtGDGLNNrcJ4SzIysaISipKjLmqkGgMc7bh1DhccOo1NcGZ7lqmMcg hyhq7dvMutblSWi6jJGTjii3s3ehmptYlmUr+109qOMS/Z+ZSsUhc7UOfFFFq/K09Msi2dmN 5arefFGrrNu39DXa613oXFcWqDqmSPNbfcXNpLs5cYM7223UNzGsHjxR5duPHZ79OWbd+68B gcnYqDAC4AIAGDKLIskyLM4VEVRsiRRUQAZCABAACbFUBiqIVSKZF09IUChvXa69ZU20m0xs i1TFYAp8GSE0n0Hbz03/APZMX3cPDfj/APXc6/40CFRrrCpnbis6zrG9ebXbpf432OoqgI4u x1AQFRJE4laZOLOkZq6JaimJbE6xyqaGJEjbmVCLJiYFbFQm0RoFRoA6AAgAAEJjEyKiyLG2 gcX1BUREqLrBOmWBMLkRhKWVPSDhzkvQOtRlxEzQqLJesTlUZFmmUWyJJiM1qFo8RO28ppx9 eXtODGqqnn9h3Tl7+Gi+2spdtfzZ+01p2w4c07bOlZueJbjLox9BOph8vn2ZQfDE2GLMV20u dZTqKoUChlsVFUdAKIhQdQqTBkJDIj1ciokSRFRk86R6yWhcW37Dcz7M3HuepIktTyXrHF6c IJR6s/WBrDGUlDm/USUYrJCRJDCZSbrmIAKhgIAGIVSUbc5YJAKoaiXhxi6Tlj8scWXw2033 Lb/Fcen2Z+wuKzdpGdVlkqknbcVWbUV0m5bOT/Uufy21T2vEut7WzB1jBOXzS7T9pqaVi8kc yEdf6cZT6UsPW8DRHaXnm4wXR2n9h0m3xZE1NYxd6yR2EM51m/vPD1ZGmMNKpHBckhSuxhm0 Vy3SiqrLnLBGukZ61fGFcZKoSlGOLojj3fOKvTarN/cwXrKK7u9m1bX3c/WTK+PvXaubu3aV ZP0vA4e+3O23F1XdUnJJKkFXLk3kRjtbevTPVN/NmvWzXGzCPdil1jqdIqueaX7v6dp/zy+w grm8n3morlFU9pf4qUnF1VONMCl7yDem2nOXKOP8Bgyi7N2fedets5u+su1OsviXDmdZbfcX /wBRq3Dkn2vXw9BHf7OC2zUF3MfRxJcYJl5uWdSU79y5FQnKsa19I7sGirI5NGq1xOx5PecL k7SeE1qXWjjGrb3/AAZ27vyyx6iyp6vQ3FKapKtOh092IowfB06F9KmxxxwE7aeaNtZZfD5i okavCSyf1ktLXBegGWPtvuxf06x/tpzxm6dRplchDvOnWQnfoqwi5EXKqOzgnXvfixI6K2rl px7tciyN27POOn01EozV5p4a419QHmmqDWI54Sl1sjGVMzhe7vEredDt2HqsxOHGVZVO/wCW tS2+Oak0b1Y2Yb8KGSR0t3KKWZy5ySFi633RZHEUbsW6Vp0ivuM5JRlLLGvMTS1bvIbklmxK a4BPau3FSarUirdc8DXjrO9Zm217Ja2EW3gNQSJonnJ2jXjb3pxVMy6NxrIpROJm8lXwi5Ny zNNqJRbjXFs0xuKOWJx22tXGGu3B0J7eWLI2JOYri8K6ksmdJOjle7cpN5L1jxGgGIjPet6k ca/DSzvyRyt9bpiZ8o1GK3c0s623uakcZwcczpbFJ8Tp1wVubZyn2b0m+Z18Fmcq+/zZU5oa y+rFdPSFBa2xIskglgh6+RCqFqOklrNsiTm2RdSLmJyXF0NeLPkbE6DinLupvpZYtus5YlxE 8qoTUnSKqy6O3b7zoi5KmCwAuGc1FWYR6SN2zG4uT4MsoPSyo5U4yg9MsyDVTrTtqapIw3rT tdK5lFCiS0hqaCrZUFAJK3J5Jk1tpvoKioDSto+LLFtIcW2QcOfmErd5wnDsLDp6zoQeuEZr FSVcMfXyZl852c/1YKsIJZe2ph2e6ubd67T/ABJ5Mx5YvXs3jMdtQk8ky2Nib4E9tvIbiGtd lp0lF8H9hY9xBcam8sIKw+LRNWFxZB7nkiLvyfGgGhWorgPsR5GTxK5uoamBqd1LIi7xmcub EqPg2Bpd9LNk4bvT3YtmZU5I1WpqDUmkS4WS+jkedbe/uZePFUw9xmvbRXdn40J669tV9qOl 57v91K21aWiyl2p8/sPKK5OxahJXaxbf5cXl19ZO8XGCjLTJPgyy6qYldxJqqyfaRanrgmca 2pYIYiDpbK7Rnp9pdqqHjdvPTI9JsLuC6DFStt2NxSaVKHm93Z8O5KD6z1c1VJo4nnFmjjcX Uzrf5a5XWuVtpUdDbbeFDnJ6Z1N0Hj1nKKsaqZLscTYym7GpUYlgWKXIjJY4CXJkVoTqjNLB l0HwKrqo6gSTqiuQQYMqIiGICdeyBHgAHtZ7jQ1XJqolupPCKqUwlFRi5Vl0cCb3kqfl2pS6 kexloVy4+BJXJfEjH+9uPDQ0+miJrcXXmor019wGxOo9SWZj1yebdOhEkuOPrGBrVyK4orlf SKtClw9pL9vXOPtCLYX6YpmqE9arkc57VJ1S9rNW31Rbi8mMJWkQARkAAAAAAUAAAOrE8c8Q Kr1+NlKub6aFkyhvbWZ96EX/ACo8nevXLV6VqE2qSapU9Gt/GTpGS/ki37XQVq1bTclblVur elY+w14X16LOTF93Msym12pVNatt8Wb1Zt/9tr+VB4VrpXWjldNvTZ2nNp/dr+v+GNWun2D8 GVcNL9Zs8GL7r9oS2/X9RP5z1a8+O/Bj8KXJev8AgLw5cjX4T610EWksHgTz2nduTW/SzaWs 016BNfShqyxCtch9y+x4RjpF8heFF8EbMxaU8aVNfc+B4fFj8KPITt8m/WbtEXwE7ceXtH3J 7M+F92HQ/m9iK5qS4r1HQ8GD5+shLaW5ZSZnbeWdGpLO7kyb6CttnUl5euEvYZNzb/bd7HCu B5NptXp1sZtXQGpcgt7m1ddFqr0o1LbTljFVOfjt7OmWbWg1R5l7sTjnF+oi7bX/AAJ40zFe DHQbjHi0Ctx4P2kwZRoIm7L6fWR8FvJsmFyi2Rci7wJ8kSW3r3kvQx40zGVyI6m8jatpb5st jZjHKv8AZoX7drN3kYI2Zy4F8Nppxn6i+cbjfYmor/Lq/W2SeGbXpNzjk7s/ctV009yKj00q yDhKbrNtvpLtUXk0/SFRZ8SX4KlCg9JOoVRPGNZRoRuWo3VpmqosqgE6dYl69K4m62MrWKxj zMEo0PVGDc+XKXatYP5T0a7zbpv393l34rOunb2ci1fcMHijWpRmqpmO5acW01R8URjOVt1R brY4ZbWiLQ7d6NxU48iTRFZ7lpSxWDKKOL6Ta0QnBSzCKVNTwkCcrLqsiE4ODxJQuUwlkXI1 KUNyqSwlzKHGe3lqTo+EvtISg49qORotblSWm5ijpmbfUz1nZ0tn5irvYuYT950Dzd3b6Fqh 2o59XUbNl5g49meMeZx34/Z6uPm9NnYAjGSmqxxQzhh6c5AhiCkyLJMizNWIsiNsizFaBGox N0IpVYtS5hj/AMRUXHEgG6CxY6iqFAAKoAAgABVAAoqFVn7BCN677a9nPfj13+pJxr3cCDqs xqVCWpS+w7Z05O/8dnHHJx9v56qxktFcsGQdVmY249tevee7rpy679u/skiUWQROJI1V0S2L KYlkTrHKxamOpBEkjTJ1AKDKyQqDqRlcjHN+jNlAyLByk+7CXXLBAo/NJdUcfaQ7IvAM8sSX ZWS9YNtjBktPN06sSLjb5Sk+cpfUhiGFzUV2csCLJMiwIsBiCpIZFEkAxMYmaZQZFk2iJKsq Bk8xhqtwn8rcH1SxXtqbCN234tudvnHDrWKJr0qbzOtcvaXNF2LeTwZ18jgReFTuQl4kVPmi 7Rz4r31SqJsCSszeNKLpMO6GLIuSWbL1Zh8UnL8P2ltufhfpxUelrU/aXxqeUZIRnPuRb9BN 2HHvyS6Fiy+5duXf1Jyl0N4eoqyyL4z5nlfkShBZJv8AETTfV1EKjqWM0xiGbZMaESSLhMmi aCMS2MBhMoUGoMtdIqrwXSZrm/tQwTq/u4k6TuTN7LvCfHAkrUeNWc2fmU33IpdMsTLc3F27 hKTfQsPcYu+vzbnHte/R3PFhF6Y4PojqfqKZbZ3LylrSjVNu52X0qmXtOZa2V+eMItLm8DR+ wisNxdo/lVWzWu2f7WNtcf3vT2oRS/JUafcp9QTatpym6RSq2zyuwltpzcdvak5Rxq3pNlzb b6/PROSjt3SsVJt09J2l+Dz3X2uXWtb2xfg7kJrTF0bl2feRe+jP9Ba/vZR/j6Dny8p28k1O Na88X7RrYzgkrV6UUsFGUYyQyTVve5lgqJPrqQcpXM26GSK3lrLwri9MH9aGt3dh+rt5pc7b U19TJlrCy7rjhZim38UngjNLaeJ2rzdx8uHqLP8Actq3Sc3bfK5FxLZXrLjrjOMo84uvuBcq YXIQVI25rqgxO7KWVub66L3stUXcxdacmSgvhgkqchlPFUluJd2EY/ilX3IJbef+LeUeiCS9 5p8N/E36AjC1HGKVebzGaYjPHYWM5J3HznKvsNUYqKpFKK+6iQAKgOKlWLyeDGIDzlyx3rMs 1WPqyOU16z0XmdvTdVxfEvajibqK16llNavtMWEZiaxTREcWYHrPLb/j7WEm8Y9iX8pbPc2o OjdX0YnB8rv3IOVm2lJy7Sq+RruW7raVyemrytxqdZ1XMdJ7mNK1oVfuYSwTb6v4GZbK0u85 S6ybVq0uCXWawmV3jwjwfqF+6gn3Jvpiv4lMHO5hYhX7zVEaJaLdPHnFPks/UMRM1lvbnd3X p2sGo/PNYnOvbHdzcZbiWDko6nOtK9CO1t95+5m7O3hKTjz7K9pff8u3F21PVKEXTUowTk6r HN/YZw15YcSXlFy0pUdUvaced2jod3z+ErULTg5OF2OrW5OteXI89hqTlkS6xZvT8WVczv8A 9PQt7mU7F5yeGuKTpXmce9dtSt6YxSlhR1LPLdw9vuIXIulHj1PMSSJbb6uv5zs5wuUsQpba w04+s5cdpdUaXFTrPUXJVzdTBuIOSqkTbb2a11xerjPaQQvDUMlQ1SjTBkHalmlQ4Xa3vXeS KG288QoWOKWeJF0XQTLRKLATbYsSKmmSUitJsshFBF1tVNdu3UhZVe6qm6zabeOBz71K07a3 RFO+emcH0m6EKIxeaW9FvWs0z0auOerWpVWA8SG2lrtRkuKLCWQJo529stqqqdFtIz3ppqhn PtFefeDNO1u6JHP3N2Sm1l1FVqa1pzbod9dLerN5J2er1JqpzLz/ADZPqNlqa0KjqjJfeq66 ciTWzuz5ZblJJKo9aKE26F0LcpZI1JGbaetIjqbwSNEdqviL4wUclQ6xhkjt5yzwRfDbwh0v pLhOiKhCoJ3IriQd5cEBZgKpU7j6EVu9zkFw01E5dJjnuIrLEqd+TyVBmL41vclzIynGlJZG Gs5cyyO2uT7zogYnqtgrDdFmaFFLJFdvbxhisWWSTphmVi49DqJtLMxXLtxPS8GVVrniXCN0 r8I8SuW8XBNmTAKlwL5biU04tLS1RnnPCdm67L4PD6juajLuH4N23u6V0PTLqZjedF1vVu2u wvXZ+NuHpdFFRiqYLmXX9rK1isYnUjJTSksmSrXA4a7Xvla4aJUN17ZKXat4PkZfDUcGsek7 zeJNcq+oNLfAuSSJEuzc091KhLoRJW65tssGZza3NZEYwS6C6CjHMgkiyOlGVUebyV3ZTspd qbjGHW2eJ323e2vSsSpqh2XQ97Kt3cWYpVjCtx9eSPHee7edjfXVczk9afQ/pQ6aud7slmWq 3TjF+xltjCsfSZrMtM1XJ4M0LsSrywZjaEKSo6ES24sOorZhRF0Z2/L7uKOGbtnco6Gaj19l 640M+9seNZlHjSobS5VJ8za4p1fM6cd6+LOcPETXE02pViuge9s+FclD0op28uBizxtjp36t +ZGSwC26ok0QY7ioUNUNdyJlkiBxdGO9iV1oWPFAUpkmQJVqAhDEyoYCAD1EIX1g7kYrlbhj 65fYW6K95uf43X2ZHLhfvbZ078F8LzXUb9tu7W5wtvtfJLvHsllS62NCwyw6iYoqroWKCz4m mSiqlsI1ElTMmpEFqGV1JLHIirFQGRTJogE2iSmuOAqiaTCYWAV6Wsg8VR7zS9JWcLAFGSkq xafUMIBiABnJnDxrjvXUqVpHW6Rp1Zs2b294VuidJSelGGjtrU9MX81ztT9XA7cc9WNq1Wrk aUg5P/LjRF6TeauGaF1SelyuS6lRF1VqpS5gNp+v1hMrlh86JKdcp+tEIXY8JSXWTUm+MZdZ yqy/r9UJN/DF9Q8FxcesTVMXGnTEcZ1wjL0SIv6/XZKjeaUulCweGfRIHSOLTXSh11cpL2kX /tW7MeroeRVKDi6SX2GroXqkHR7GYusrtry2d+rGOKLZ2qYx9RUmcrMPRNptMwmKlMyUkHAj SHUBPTxRF82FyVWZt/a1QjcSwWDNFaFsZJrS8mIXp1eTnYlblqhkjs+X+JJamqRXMzXLTt3H DpwOrZh4dtR48S1u24E3V4l22rr9BQ3iaNqsW+SJr9TnydNK0tKWaTK5bazLO3H+yi0D0YeL NZv2G3+SnU2vrB7G08tS/mNIE8Z7L5be7FLy+PwzkutJ/UR/2+XC4v7H8TeBPCL57e7nPYXV lKPqaIvYX+Dj7fsOmBLxxqcu0ceWx3Hyp9UiqWzvLOD953QMXh1rc59p7PPS28lnB/2WV+HF Zqh6Wo6mfsT3a/2L7PMqK6fWS09LPQu3CWcU/QVvaWZZwiT7Hxa/2Pg4VHz9gqPoO29hYfw0 6myD8ttPJyXpJ9mtf7Grj48l6x+h+s6j8rjwm/Sit+Vy4TT60T7Wy/f0cm/toX12k1LhI425 2krLpJYcGetflt1ZOL9JXPy+7JaZQ1J8Ko3r5a9NpmOe/ht1lxXjHFxZotbnhP1nR3vlF2yn OMJOHHDI5MrfFGrp6xxz6NtE8URaMdu67bwyNkZxuLDM5qi1XBmadpxxWKNbRFoIyQm49RNw U+1HMlcs1xiUpuL6Si+zuJW3Rl07MbvbtYS4ozpq5g8JCjOVpm5t6XszY1bfdzsypk+KOxZ3 Ebywz5HHrDcKksHwZXqnt5drLhIzvpLMx04+W69K9CJySMNneqSpN+k1KMpd1Yc2eTabS4fQ 1212mYk5FUrsVg3V9BY9v879GQeC44RVCTTennrPVS7j5UXSCcn/ABJ+E0RaoPCr5wmhZCbo QciWLlJsRHUKpnDSVQqRAgdRVEBFOoVEAAACKoEMQAIYFApNE9VenmisKnXTe6uO/Frt8/dP SvhY1g6MgpUJa697I64037fxrlnk4/q/lr7rYlkSnu9KLIuuXsJ43Xu1Npt9K5E10FNJ/DRd LJKD+KTfRki5SxZX6IKPl6xqozTBaVxbfsBPT3VQdBFwmUJJyxliRoWNEWgZQEToRCkIYiCL IsmyLCoMAYgqSJIiiaAYNDQpSSzNMINEWSbbyT9OAqLi/URpFii2mnFVaJ4cEKpMLlxNzaVm /OCyrVdTxOh5bKMoOMlqcXk3RYlPmsO5dX4H6Mvp0FexnovJcJYGr1eafx2dhSfCkVyigpXM QEdzqJsCDlQBtkHIhK5QhGTuPTBOT5RVTNrUi3UNMvs+U7u7nHQuc3T2Zm6HkatrVeuYf2V7 TWs2voxttrPVzFiWKLZrnPZ2cIy1v7uPtyMV3zHhagl0yxN3bXXvUk227RdG02Ep27fekkc6 5uLlzCUm+hYe4lb2V653YtLm8DH3c/Rrlr7ePr2w0y38F3It+wonvrssmoroNNvyr/uTp0RR stbHb28o6nzliMcl79E8uPXt1cNRuX3gpTfrNdvyq/PvUgun+B3FgqLBdAUE4p69WbzX+2Yc 635Taj35OT9SNtuxbtdyKRYOp0msnaOV32velTmJW4VrRVHUDTIjGMa6UlXOiBicks2Qd15R jKXsXtAnQVOkS1S72HtJaVxxKK5XYxwbTfJYjTbyTXWWLDIAZQcVLCbquTK47SxFuUIKLfGO BeFEMJlRLa1eqFy5B9Eqr1OoaN1HK7Gf+ZCntj9hfQTdOIwuVPibiPetKX+XP6pUD9zFd+M4 /ihX3VJSv6eDfUiSlceXZIFC5audySb6HQk+zx9ZVc28Lv63b6xx21uKolgBFblSbUe01nQH Kcvu9ZN2pLu3JLodGiLV6P8A25ehxf1gZ95ac7T7VXHtJJHDvw1QbXw9pdXE9BPeeFhdg1F4 dntfxOLLTnHGOK/lZmlcuSEiycdOHJ0KjmrTtr3g3I3VwePUehuRvtPsxtxfxTkkeYjiqHr/ ACKW33NjVKEXet4ScscODxOutZrFZ27udmM53OizF0/tPA3WfKprFQhB/NceuXqWHtOrLcwj hX0Ipluvlj6zSdUF5bGX61yc+hPRH1R+00WrFnbL8uMYdNMfXmZpXpyzdOoqwzzJlfGtbvWY ycopOTzaWfpMu5lLcONJStxi8VF97rFUWtGfKteMczdWHd2bg23KzJpdX/A8xci16Mz2UXS9 ODyuRUvVg/qPN7mx4c3Hk6CJWS24pSVK1WHWRttRapjQ0WZyt3axpFY9OBlVE8MuBSvXbXcw nYjKTSa7Lq+Qrl+3Lutv8KdDl+U3Ypyi4qUmuzhU7EZ35d2CX4jOI15OdeUbfapKnOlPeUyv LR4iinjSkpY+o6dzZO7jfm391YIzXdlGP6SJfGemWp5X1w58rkpxxik+gpaNz2r+N06heFbi qYvrPPttMu06RipUmrcurrNNEsiLg2TLWVagviePQX27UXkhwsvkzfY26zYxb2Zu2BYtV6Do WraWRGHZVEidG+gvjjv0c7tleqIxeaySsSeZoUekw+c22tpOcK1jRvq4nTTxz3c7aq8p3Wuz pya4GzU3mzynlO7dvdQT7snofpPXStNPM6b6yXoktqt4lbhFcEXUpmRcW8jHWDzfmdjwp6lk znasT0Pmu2nOClFVa4GCx5Vdl2rrUFy4nfjuY57TFa/K7jlbafAsvJxniqVRo2l3b2JK2pJy ZHd3Vcu1XBUM7d25nDobezDSpNVbRpqo9BitOWhKuFCWC6TE2npGvFe7sV0kPGbyRU58kKsm dZWbFrlJ5srlKPF1I6G8xq1XJG2cQvEXIg5yeWBerDLFZSzBmMLg5Zscds3kjoKKWSAYPJkW 054FsdtbWeJa2lmyuV+3HNjCW1YklkgM8t7BZJsg98/hiVlrHpMS3N6WSSJa7rzkMritFywr ipL1mC9YlaeOK5lr1POTFTpJ5YXwUKL5EtDLcAqTyrXhEFBBOzG7F25LCSoTxAzmtYjH5X5l esy/a3aS01ilTtYHRuXVunFRbtXY10XE/Y+afJnPncez3dvcruz/AC59fA9Dg+CaJLNb2ctp WWzvXqVndJW7jwUvgn1cn0P0Gm7ZjPCWDXEhfsK9Fwn2otZMwP8AcbKlJyuWOWc4dVc10Z8j ptx566f0Ym3v3W3LUrTxy5kUa7dyV2Gu3KFyD6GvXyZRctTjioOnQ6nOOs290AJ3LcrUtMqe ghQrWUkTTRBEpTUIuXJAWbOblOdxLN6V6Dnf1dsXcsQ3fxW3pl+GX2P3nR2alC3FN04+s2X9 vb3ViVmbqpqhqXDNfLWjVXXFS5rHrRB7aVu7KzcwlBuMvQb71teCtKppM7X0SKF2qdK0sppT DkTg8WueKC4sa8GYaVstsy0yKmNMg9NsLuHUdqLrE8tsL1Gj0m2nVJGdb42X2Y2jm+e7ekLV 5caxZwIvTI9p5rt/E2WnisUeLnzOvLOs29107Y9m628S0yWpYI1rE5NoTVTJcjQ2tFFyPQBi ZODwoRmsRRIIywY0wmJMBiGIqAAAD2e528L77SpP2nF3exUWlcX4ZI7dvf27klZvqVu48lPC Xofdl6HUuvwUE4uS5uE8fUdJmO2cvPW95udq/wDvW/vd70M6m181225emMtM/knh/Ax3rFt1 0N4YpGC5t4SjruJPgl0+jkdJtWLrHp2nUkqHkbW43W1/012sflnj7zoWv6gngr9mn3oM35Rz 8a9CugK1Obb842s/icfxIv8A39h4q4i5iYramSqYP9x26+OvVFlF3zdR/SjXpl9hLYuK7CZz t753tdpVOWufyxOLdnv/ADW3J2JYR71tdl+g8/JStTcLiams4zWIR2tx/UG53GEX4cfu5+sz xvyk6ttvpOdXkWxnTPFBXX229nYlqg6NepnsLdxXYRuLKSTPAWdUmlB6q4U4/wAT3u3tOzah becYpFjGy0CEpKOZLUknLglUMOL5nvYQvPXJxjbVK9L4LpObPf3Gm7FuMK/HddZergQdx7ic r83SFcP4dJv2Gzlextwai/jlR+pv6l6T2SeOvXtHPursfvL7rPcXXX/tQw9xuWw3Lyv30+n/ AIl9zbRg1G5clPnWTw6+0N2rHB6+iMsTnmXt/wBLmox229gmlfcvx20yHiby3hctW5r7knB+ 0vV21DKN2L6pE1en8MpUfzxp719Znr7f/j/pLf10/wDpnj5rZtdm94lh/fjWPrWButXo7hao ONyPODIuVxqkoKS6v+JknstrckrnhyhP5rT0v2GcS/rP/wAVc+/6/wDw6EaJ0jJp8pClhjON PvRMkY3LeV5Tj8t6OP8AaVPamXS3ULWE3ork84ev7TOL6dV6e7RFtrBqS6R14eyRCqktTSa+ aA6umHbXtM4X9fr9VPLDLof1MruWqqsc+RJSTwX9mRJOmHsf1GbMt67YuYypDp6zROFcVmZ3 mcbMPXrt5DPMqkydWVvOvEy3EeJOrK8mCkiNraReLWPNikR1rPgQnKq5FSQpOrNe0XZcubMD lxOrbhogo8kb0nXLlzXphIAA7PIBiABgIAGAgAYCABgIAGAgAYCGAAAAMBAQOpxfMvIobit3 b0hc4r4ZfYzsjA+dX9vK1JwuRcZrNMoxg+k+hb3Y2d7HTdWK7slmjyPmPlV3ZPt9q28riy9P Ixtrns3Ky2r6nhLMtcTBKDRba3LjhLI42YaXtFc7an1l9FJVRFoisMouLoyyNxSWmfrL5RTw ZnnacelBA07bqsjTb3CktM8UZoXNODxQ5Q4xNy4SzK6dl2+1DtQfD7DTsvMZbfBrXa5fFHq+ wx2r8rbo8i6dqN3t2nSXH+JrE27d0lurvwdq8letKDr8enH+A3XoPPbXcz2tzVBLV8UJd2X0 5nqvL72z8xj2E43F3rblivtXSZ8bXacknoxSqUzqd5+XWnk5L0lcvK4vKbXoJeOtzm1efcSL VDuS8nbymn1ool5Nd4OL9LOV4tnWc2rkiOjPyrdRyin1SRmnsd1HO3J9WJzvFt7Ok5db6s4V CVu7DvQmuuDKXcSzw68DF0s9HSbS9qtqLUQU08veOpnDR1CoVAmFMAAqmIAoQFRVGohRIZEQ JaW+A6UL1TCKi3kibg44SwDXJKidF0EKm4zYtS5D1OOJWpFsWdtd7HDbil6zpVsLqeZejG7S fdwErkrbpLA6dL26OVu2v1dZ7t9QqUwuqWeDLaE6xZZex1AKDoVCoRaJ0E0EVtCZNkGFRZFk mIiosTQ2xYvIKi0Kg+tv+Ui1GuC/tOoU065Ykkn1EdTfEaAnh1jrTLAiiRpmotVzI0Jsi0MG UQoMdCYMs27teJYnHiu2v5f4VONCWCks0elhGr5nnJ2/BuTtPg2jWOjjv3y9DD8yKmspKpbG xJ5FXktyE7DjN0duXseP2nQe+sW8u0/ujpJna4alt+mZUx8vnPo6y+35JGffm+qKM8/NZv8A Til+LEyXd5evPTK4392P2IxeTjnb+VdJx8l/8XYey8u2mN3S39+Wp+r+Aped2LK07e236FBf T0HMs+Wbi7jG3pXO49P8TZDyaMf1rv8ALbX1sS8l+jTx+aXXjn17+TPf853NzJxtr7ufrZij C7u5VSndfpftyO0rO1sfp205fNPtMvV+5PDhyy9xr7O23/s3/ZPu66/+vRyo+UXmvzHG0ul6 pepE/wDbNvazcrj6eyjoNSeeBVKB114dNfRz25t76/0ZoqNv9OKj1IlVvMckCR1xhzzlOKLU QiiTaWZzokBHU+CFRvP2EEyrxoVopJvoxG7UX3lXrJpKOCSXUAqvqDTXNjGAlFLJDAAAAbSz Kv3EW6RTl1LAC0CCcn0D088QG5JEHck+7FvpeBNYZBUCKUn3sOolpjyAKgMVQo2QuXbdpVuS S9IE6kczBd8529vCCc30FP77e7nCxaoudPtwM+Ubml+Tq6WYd3uJQj+pbtyr8XadOpFH+2bz cf6i7pXKtfdgX2vI9tDvuU36iZvsvjrO9/ow7rzDbXI+HpnN866UyqdyV9a5Q0LupJOlD0Nr b2bP6cIr0Fe/g71iS4x7S9A6pcY6R5bcRxrzXtRmlz5m69HVBtcMTHJVTp1manojFnU8rk4z k4YzitaXzR+KPqxXSjlI17S+9vdhdXwvHqER6yM4zipwxjJVTByM0LUdte8LOFysrb5SzcfT mvSa6I0qFeSCjfQTGRVStLPN9JLw31E6i1pkVnvW4wnbuP5tD6pfxOb5zt1CSuRyeD60dPdd u1JLNLUutYlW8j+5sNrkposuGbMvLXo6ZKSyZnNt1Vhp41qjGzdZa9jfdi7G4uDxPWObeWR4 qDxPWeX3vGsRbzj2X6DFb1q7RXFj0km0iOszhcou0mRe2hxRJzbFV8R4xPIlbtx4IfZWSFpb yRTd3Vmx+pcjHozZfFMr6BVI5F3z3bx7ilP2Ip//AIiplaXrL4VPJ31cLYyrwZ5+1/UMG6XI PrTOvtvM9puGoq4k38LwM7aSeizZsTSC7FX7c7Tx1RcTRGzGlcyyMVHJUMT4arfm+bWrUorX VJwadPSfQJWpSdeeJ5r+pPL1tb0N5aVITknNcpL7T01y9K4lKGTSdTrvekucM6hbeOcgfhx6 SuMG+8yzRFdJ5dt5HWaqbtzVFpYHjNxduyk43ZPB5Ht9KWSPO+beWzuXnOC71MzXFvbcdeq4 kcna3FbuRlyZ2HNTk2jDDyqUHqnNKmJs1WdVLUtTzfQemy92btL0jpWk3BF8bbYbdqNpPAJX 3wbOMubgtWKy+OA/Dis2ZncbIN15s9Grla267cRPcx4GMFq4G2Gl7lvJEXuJFStSeZLwksxm L40nffSQc5yyLaRWSHV8CXZqaKHanLNjW3XFlrTZHTzM+Va8YWmCyxCq4IfZQq8kTK4gq2PS xKrDTzYA0RwJYEaooeAYhVh1sIQ8BYcw6kBXubK3FqVvi1h18DZ5RunudqnLv2+zJFKr1Gfa zWy31H+nfX/NxM2M2O5q5EnFTVVmwa0uj4Ci5Vpp6sTrx3pj2cbOrBc2s7U3d270XPiT7sut fXmW7fd+NdjR+HejXValjGcX8vOnr5o2yjNrGPtMG82rmqThqWalF4p/Tibus269qS2fJpu2 VPHJmWUHB0kU2t/d270buMnb+G9m1+JLPr9Z0NSnFNdqLxTWKZ57nW/yblZYpt0WLIbiMmlb pjJpHQsRSuReRVfevc04QTfpZ11kvqXf4CPZeRr29x3G45URlZfs85PoNeMkZ87a8j/Uth29 zHcrK4qS/Ev4GfbyUlpeTPReb7T93tZQXej249aPJ7S5VIxy69MxdblVKLtya4xZZONYunDF Fm9hSSuLKWD6yEMqcsPWcu7agRJrS2uQmqBWraXKOh6bZ3dSXSeRtyozv+X3aqhi90r0urXa 0s8Vu7PhXJ2+TPYbeWpU5nC88sabkbiylgzt9XH8dWdem3zcizLgbrbwObF6ZG60zi6LmVzR aRaqEYbsaZFCzN12OBhkqMinIgSqRAkAkMIQABR7VxV5aJ9uD+GcdSM9/wAuvW4qW1lqiv8A CuPD+VvtLqq0OKltJKMsbcnRS5G+E6PB1/5vsijcuHex5q87kGoztu1KWC1p0fQnkRnttw3j Nqnw0SPU3LUdxHROlHmpKv2I81c2j8vuThVu1RyiovLpxrh0G4z1c+9DdwlSqcXzS+orhN5S kjp2Nzdt/mRrC5SmNHSvL+JXK5dkqyk2KRkhbVc1L0mqEXHNUCEFNYpPrRJRiotxrFrhXsv0 GbW5Ebu4hYVZ1b5InbuwlpUsHPKpCNyFxt0eCxdPrNdry65vVS1FOz89x9n0cX9MTUjnvtVm 23C2tdFK5GmW4sb5ad5bjNcHxXU8zLe8lubO2pzuucU8WoVcV/aq17SNzbTtQV1NST5G+sea 98st/wAo2ur8mc4dEqSX2lln+npzWtX4afwupa26dpEVuG8kzPmZq61Ys7KrhWdzhPl1Iufm NxxpJvrMi3DWFKMbuau9kx51m9WiW/uz7LdUbVNOxK1ck1rTXZ7yT9iM+x2LlNTlFqKyrTH1 nQ31rxLbrilwckl7D0adceTN+DLtfKtvVSUvEUfm7q9lDqzk0qJqMuHQvtKdtFxhGMlw1you WSLNUpYuM8emhdrbfhCdso+G5fqUn/J/AkrUI/Al/Kx4/LL1jipPGj/tmcmIabXF06mSUnxa fXgKunNSXpqGquUl/MjKmlTFJrqxHqxx9uBDB8F/KySqs6pdOIU8sViuX/AVVwSa5A2uj0Og Vb6etEFL2ttPVbbty+46etPB+onolHvUl0xwfqJquXs/4glT6Y+ouadFdu9G9hFqdM1lJejM sjjgnX7siM7cLneSbWT/AI5oNDpg6r72fr+0dE/X6/VWRf8Aw4kLkK9pApVwef8AzE1LCua5 /aZsb12xWNsg8y+/bo9SyM7Zwsw9utlmYVKkHTnQnUquSaVCNk51VCuV3l7Sm7cphj1lGqlP Wmi4TLVKTUX0YYBY39y26SepVKZqsa1p0FSWlpt1R1n8Y8fJt5X5PTRlqSfMZy9tvvDVJ4o0 29/bnWrolxZudXNrGZYb+zN0jI0OSSrUplIRXG6pZD8WOrRXGlQJgJTTdExgAxAQAABVAxAA wEBAwITk01yJpgMBAAwEADFKKmnGSTi80wGB5rzLyBwrd2mMeNvivw/Yecnb5Zn0g5vmPk9r e9uPYu/Nz6zNkvdZXiLdx230GuNyNxYEd3s7m2n4d6OmXDk+oyYwdVgzjtrY6StjTFQVm+p4 PBlriYVlna4x9RVGTi8DY0VztqfQwiCUZrAinK06og04Pky2NxSweDLKL1KG4VJYS4Mr/M28 1KrjKPduRzRW4UfZ9Rda3Ca03MVzOkue/f3Y7dnpfLPP43mrO6pG4+7P4ZfYzunzy7t9CrHt QfD7DqeV+ez2qVu/W5ZyUvih9qN5x3O/Z68CFq7C9BXLbUoPJomaZACAB1YnSWaqBGVyMc8w que0sT71uD/lRRLynaS/wkuqq9xo8SUu6qDUJPNmLdfm6SbT1wwS8k2nDVHqn9pTLyOz8Nya 9T+o7CtpElFGLrrf7Y6Tfef31wJeRS+C5X8UP4lb8j3CylB+lr6j0tAoYvFrWpz7z1eXflG6 j8KfVJFb8t3Kzty9jPWaQboT7Orc/J29o8g9pchjK3P+wyuVxQzTXWqHr53VBVMt3fwSzRm8 U93XX8ja/wBryzupuqpUTnJ8T0cdxYuvtRi+uKJT22zkm3bhhyVDP2/i19/31rzOIU5nVv8A +3W+8tNcqSZiVzZTnpWtLmmmT7ezU5JfdSiyNTXDZ7a5Sl2Ua5OUMPWaX5DOlYXU+uP8SzTb 2S8mnrcfswRTJ0TVJLA1vyXcRylB+lr6iP8At26h8KfVJGvHb2Zu2l/ujDKxxg6U4MUL0oYS wfJm17fcRzty9Cr7iucJNUuQlTpizctneOV0l662Z+CULsZ9DLaHOnaUe4/QyVrdOL0svS9m LbPq/q3kGxRnqyY3ZnPLEL8VUppFTvJGp7FUrLF8q0JwsW7a7iT66kxTMYk5TxjHDnJ0Q0ub r0RX1m50ItLkMHkyJUyVBOLeZpaItFwZZnEjQ0NFUkMLlWMTaBJyyQVNMYK2+LoW27Wrupy6 i492bVVQ0t8C99nChW5N4JGLyaT+7+jc03voirT4kqQhmU65KquMFHWqRT68jn97PTj1y19v H17YXvcqPdTfsOJ5pF+LG9lrz61/Ch24bWUsZSp+Ez+b7OC2uqFawkm6uueB01nJbnft7OXJ 9vGNe/u5mwq7uiKq54JdJ3rflN6X6jjbXS9UvUvtPL2brtuNyPeg1Jeg+h2tNxK5HuySkvSa nFrtfLZznLtrr46udDyrb28bjlcfS9K9SOlZhC0qWYKK6FQcraLoLA7TXXX6Y57bbbfVcqZR lLNlcrXpNbQmjWWXPnaHagabiSzIQeOC+o1kN2ymduhfJXpZSjFdEa+1/YRdp0xxfNiVHOuU 4Ylar1G29AzKIqou1q7zfUnT3FkIKHdGkM5qAGJtRzYDAjr5YirJ9AEyt3radNSryHoTzxGo qOSS6iKSk3kvWOjebGOgEVFDHQG6YsBDoZru/sWu9NV5LEzPzOVzCxalLpZLtGpptfR0qCk4 xxk0l0nOVrf3u81bXRmSj5PbbrenKb9RnyvpF8ZO9/otu+Z7W1nLU/umf/c797DbWG+mR0LW 0sWf07cU+bxZoqx1XOs7T+rjvab/AHH6txW1yX8PtJW/JLEXW7KU36jqkdSGDzvp0U2ttZs/ p24rpoXNyfEPQFGGUaBVDdtPPEaSWRRGvJAk3mSAg83fteFdlbfBnMcdL08nQ9B5tbpKN1cV R+g4m5h2q8JEpGTJ05FscVQhPF15jgyI9TtGt7s4pukl2dXKUcmaLG48aNWqTT0zjykvpVHJ 8ju0nOy/iWuPWjp3vyJrcLuukLvVwl6OPQaVoqwxG0IilQKBUKgCRRtMLeh/A5Q+noLdRnjJ xvTj8yjP6mMGXD3trwLrXBSw6jBfhom+s7nnFnVFXF1M5N6OuKl6Gb9GGSLO35Pe7TtvKSqu tHDNe0vO1OM1wdSD1NA0lyt6kmng8USVlAUURTud3a2kNdx9S5mu/O3trcrs8FFVPEb7eT3t x3Z5fDHkiyZF2883v7l0T0Q5I5r5jYG0IQwAawHUikTUaAdHaecbvaKludY/LPFHoNl/U9i+ 9G4XhS55x/geQzKmiXWUfRfMtpHfbS5CLUqx1Qa5rEzeQX1utlFSfatvQ/qPNeR+cT2F1Rm2 7EsJR5dKOx5a1svMr21Xcu9u370cdtZJi9fVqW5d9W4rgS0lEpyqCcpHnu3+Mkbx71bKSjmz h+c3WsVdUItYYY1Ov4TeZi8ysRjt7l5Ks4RbiTXkxZnb+hdejyN7cWZ2YSWp31Ks9XdaOlb3 i3l3xVb8NadOGTaOBnidPyx1bjV86Ht27Oevd6Pb23KCZoVvmyrYzUtVrKS7S6Ua9KWbPJtv ZcO01lVO1Uj4K5mjAizeu9qXWK424rgSpyGDO7CNBUQ2IKMBVYAQRo2KiWZJoWAUqrgJ1J48 CLT4sqI0fFj7PWLAmqvJFRF9CItsu8GbxL/2CUIzlKteBrFZ8pGHrY1Grok2zctvCPAtsxSu RouJfCs/cnowKxcrTTTrJrbSebodG+6zZSamkZu9R2uyhcctdXRGHzTZK5t3K1+pb/Mj6Mzs bPKbKU6Ms1jN2qm3vVf2sN3FOWC8RLNc2auzWsHXiji+Wv8AZbu5sn3Jdu31P7Ds5PE4y+Oz V6xpq5Ii1XAjblVtFsY1Z27Md1F/ar4PSjl/trm0bltng3WVqXdfV8r6V6Tu3FiUztKeefMZ zMbLjF6MVjcw3NVGqmu9bl3l9q6UT0JNyWbzKdzsIzaljGa7s44NEIbyVp+Hu6Jvu3V3X+L5 X7Dldbrc6L3aGX7TCM30Fco8yyzSFuarizc3m0x6s4wpyPF7/b/s93O2u7Ltx6me0Zw/6j2v iWY7iPetvH8LOlmZg1uK5U4+NaceOaMVuVfTh9PSa9rcrQzXoeHclHg8UeOezsV1VpLmV8Oo vmtSquK1L6/aUxzpzKIrA6ewu0aOYzRt56ZGaPY7W57A84seNYbWa7SMeyu1SZ18Jwo+o3xX G2PdzvTr7PCz4M02ZVRHc2fCnK2/hZCxLgc7MXDs6CdUBG26omwKpqqMN2NGdGRi3CFGdkWS FmQJDENBAAAUe0u21dg4PCuTf2Bs72paJ4Tjg0QUtL1LH7zMe8jV611N8zUep34Tg8Vj1Gfz bbx3FinHVBJ9DkvYZ9u/DtxVaJKrFe8wik7cI60865GpWbp16OXftShNxeDWZRorxLNzuJ6q zpLqz/iZVuFN6VF4cCjTpSjp5maCfiqDxjFY4fSpKlzqXtJ2qRdEi4RK7to3JJN0iq6+mNMj 0tu5Da2IO5g2sIx9yXQcKizodyxbsRirtU8F25vH+BvtOjlvP6KmpX5eLeem3Huw4Lr5y9xy fMdxG21KK01pWKXw/ay3e+cW32bfa+VLLrZyvEdyrmsXmPm424Thc8XjVELyuODSwpijLo8K 5V9w6e0sXd3crba0LNvInj16MZZ7F6W4ahBNz6Ds7PZR27Tm9dx9FVHqNdna29stFmOL7zWf 8BSrcu6O01FZKa9ryXUejTSTrXO3KbbU9clFP77+pFl2cbiioODq1Xg/aUuPhSX6cF0vU/rN ltKWecqpYUw4s3t0xf1+v3J7Bzco1dVqeGj5VkEYclP0ugSbk6x10ySWCGoN5w9cjm1YahXN J9c6ktHOHqYK2l8HtE4v5H/aJn9fqrj9fqJpactSB6nnX+yiOl/L/wAw9LXwy9ZFGC5emI+q i6pUDtcpewWLz1epEBVLNv1pjxeSr9OsWpLj/aQ1R8IvqwAHXi6fiQaedadGKHWnNdeKI6q9 1V6YsIlRPHNc4/YFVn/zL6yLTbxdOtU9qG1TvYdLxQDdMG6V9j+wfxVyb+npKp37drvSjFvm 8GZr3me3sp1ba5Ri2vQyzW3tKZbsNOOWTRjuxdt09Rhn545fpwVHlKUqp9enL0lU/O70V24x jF4dqLa9awfsNXg2renJ4/GN7x6KGe883mY35s6pShFNrBp9mXpx9xTPzSNxdqLSrpePdfSc vsbvR97TAuzbbTT9ZOxaU6yTpGKxb+nEpjcUq4tuuVMV0C8XxI+Hio1r6eknhZcbRNuSeP8A Gn4qboWxlFZmNS0z0Ojo8zcktWt0007pbr1efJaarMhOLyLZqtZL1GS/eaWiObJ43JepptZF kb044NvEVvbXZZ5JY0I36RmorkXFjLXtd14Lq8UUPcylNzbxkU3LjSwWBn8Xgsx1wOhC/ODq mdaPm1pJKXLFnAtuuDJ6Yz7zwQlHZu+cW8rWPSSW8nG3XOjR5qDUJ04VOgt49Ct07KZrI6j8 0cG1OPUaI7+3o1vPkcG3LxJPVLHgCuSTo8uJnLTuS8xtqNeI9t5hC/hkziTu1eCK7E9FxPNJ 1LlK9TKSgqydEZZ+ZWYc31HL3m+8eSVKJGWrboMq9GtxbmlOtFSoT3lmGckcWUqQabwS4GCj rqWFRlbLHrLd+F3uOpaeWs3ZRdYujOp+/dpUm64CdWcuqBwbPmtxRaarKuFeBTc3t668XSgX L0gHE2u+larr7SOvZuq7BTWFQLAK7t6FmOqbojn+YbytteDLN40Lgys3s7e4XhTipx6eHUeY 3vl0rNZwrK37V1/adK1frg8jTavOj0qq41J0pLXkZRp1F1rc6cJ5czs7vy2G5blt1oucYfC+ rkcK5alCThNaZrNM47aezpNst1NWKINGOFyVt4eo127kbmWZybRlFSwZmnbceo2tEGgM0LnC WRZKKlj7RTs8Y+orjNxKi23eladOHFFztxu9u06S4lOElzXuI9q29UX6Tc29L2Zsa9jv72wn W1k+9afdl1cmew2HmVnzCGq06SXeg+9E8Ypw3C0zwkQ/M21xXItxmu7NfWblx27J37voQpSU VVnF8s8+juaWb6UL3B/DLq+w62h1rLFlu0WaZ7ouU55YIlCCXWSoSUaHPre7r0k6CtMhqrJJ DSLhnJKJJIYmzWGTE3QqncoYr29VtYktamlrc7iRjv7+3aXaZmha3O6xl+VDp7z9BrsbCzYe pLVP5pYsYtW3XX41y93d3F6CmouMHxlhU4kpTjhJnpPObqjoTeOL08TzdxSjblNurboi3SYa 05L7BXlDFuhG55i3hbq3zeRg8OU32mOdbNFHM54dvL4Ccp3HqniyNXHJ4ltiSpJutCq9YkpY ZFLXU8t8zvbeShdeq0+9F4nqltbVyKlt5OEs04uq9R4m3t0o4ydeo9d5em9rBKfbjSLlgVi/ 0T3O73mzt65RjcjxlGqp1ontPN7G5STqpPoNEHciqJa+GrBewLW0s2pa4QUZPOhqZc7dcfyn 9F4VYCOjzh0eaTM9/YbfcKk4Lrjg/YaAJhc15/ceUXtv27D8SPL4v4kdtvrb7F6LVM6Npr0H ozLuthZ3eNxUlwnHBkw1Nqhb21m9HVam2usb2C4TfpRybux3OwfiWm5wXxRzXWjXs/OY3KRv f2l9aJiGb7tD8vfzL1EH5dP7rOhGSmtUWmnxQy+MPOuZ+wuLJL+0Vz2V7hH2o7AE8YedcF7G /wAUl6GR/ZTycav0noKhUnhGvuV5i5GNiWiVFPlSrIqTbVa6a9R6C5sLF2TnKPaebTaKH5Rt 3xmv5jF029LiOk5NcdZbXK2tyNqWu+lJUy5es6VrzfbSkoKqb6MCX+zbbim/xOpL/a7SwjgY 24Jtc7Wl5Nb6ObduxnJyhF5/FgZ2/EWLouVKe8678sp3aPrkyEtje4Rh6/tGn42mvpn5tXnt 7XDmRjGOSxLYquboaXsdxxh7UZ24QdJNJ9LR6JrI5+WV8IR6X1l1yyr1udprCcWjNblHNNPq Y57rw+7mVO7xsU4ScHmsD2n9P7rxNmovO23D0Zr6dB5XzKGncOayn2sOZu8jm3elZq0rirhz jj7qnKdKmHr7t+EI1k0iq15hZeEW5PlGLl7iiGyjWrgn03JV9mRvtqUVRUS5I6oXi3ZukbbS +abS9iqy5W28yab4jqRFfgoh4aizQQnkMgihSiQV+Ee9JKoXL1O6q+xF6ii9EwtOpfduXJ4a orqxM726brKUn6cADUkFXwRNQSyChlVbi3m36CMbEIuqWJdUKgJIKCclFVk6IolvIfBWb+6j NsjU1t7RoHQxue6udyMYLnN1Yv2c7n612UuiOCJ5e0Xx96vu7m1ZXbkkZn5lqdLNuU37C63s 7FvKKb5yxNCdMFgh/K/Bf4z0ywf+9d+W0vWwXlanjfuSn7DeJySzZPH3PK+nRTb2W3td2Crz eJoryIqVchlS5vcyOuNaVxHRDVFkENMliKowE4J54goqOSoOoVCgQOvB0ElTNtkAAwAg9T5I dBiAz7614liSWce0vQebvR1Qw4Hq1JVpmecv2vCuStPLGP2BHKnl7RInJUdCtGStm0v+Bdhd +V49R6ySTqmqxftTPGQxwPT7Dc+Lt4N96PZfoNQT29YN7eTxgqwfzQ4erJl7ojNuE5pTh+pD GPTzj6SyFyFyKnBVUscTWDKTnyFVvLEanTJJA7s+dBhM01bm+FOsqu2tFy3OTSVXB+n+ISk3 myjcR1W3TNdpegI07mxbuWpwri06dZ5aGK0vij0saSpJZM83eg7TjLm37xFY5qjJQeJK8lWs cipOhFr1Xl27lcsKNcYdk0u5J5s4XlV6k9HCS9p2KmbTDl+d3nJRs1z7TOE0dHdz8S7Kb6kY Zqp0nZFDFQnQFGrNCCVSyNlsthEvRm1ua5UK0o5klFMtcFLMi4td0zlvxVTgkZ3GrNDtznmS VvTwxNRzsZJKh1Y7lq3Y3Ne3Zlpkvu8PsMf7dyZK1bdxuEeKYvVmPoeqMkpxykk16RJvkc3+ nt1+42UYvvW3of1HSq6nyt547WO+vWJaWUbq0p2bkOcJL2Ggi1qw5nPqr5mlgb/K3S6+oyzh plKPJte00eXYXV1H17cx553ens2Fftpp6bkJVtz5fwfE1W7quVUsJx78fpwfAzbWMpQel0xJ y2Df5mtu4suTXyvoPHv4+WNq9E7NOpcEFWRsSjONYKjWEo8Uyx1LOhUAoDCp6p2c6TQqEmyO ZUICShJ8Ccdu5R1NlxalsndSLF4I1KzFZ4graUo05mppWLyT0UuxcrSSoxra82btzjN4lLRq axi71LZ7aHa1KtEJJLIt21VGbrwKqGpGbbUZt0NV7C3BdBkmnQ0360iugqKSVjG8kQdSW3cl dTLUiV11m+srZKTbbZB1A07R1tTkUlliUlYl1lOJJ6rXL86tuMIbuHetPH8LOvbuq/bjejlJ Y9ZRcj4kXbkqxktL9Ji8knK1K55fd70HSPoy9aOfJOuWte2HZttVVTXEwI12m83jUS5nyFsl UqZJyxE1XE1FpRWrDgZru3Uk1Sq5GmHFiLEceMLuz/SXiWeNt5x/C/7rwNVm9DcR12nVZPmn ya4M1zgpdDOXuNnKE/FsvRc5rKXQ+Zm6Tbt0pn3bFBN4ui40KL1uNyErUsYyTiQ2+6TvUn+V dktLj8NynGPT0ZmqUK55mZvdemyWezwduMtvclZlnF0Ld5HVCNxcMGdP+ptrG3dhu7awktNz rX2mG3S5BweTRjfpfKdq6Rmtdu3Kn+G9X8svsdPWUSVGWbaXh3FGeEXW3Pqlh/EV2Dg3GXei 9LJeyoS58wg6MFjFrkRMjveX3eB6LbTqqczx+yu6Wmem2twz2/ZmuZ53Z0XlNZSVH1o40Xpk et8123j2ZSjmlrXozPJ3OZvk7zb/ACa1+n5NtuRczJZlVI1pmGiaTzKb0aouIzVUBzaESyap JorIEwRJrCpGoDAAKj2DXIybhOKSfM1xlTKtMWV3Nq77Syom+s1Hptx1ZLt9TWlvArUm12U+ s6kfLbdlKdxxXQzVa2MUqyrjyR08XP7jz/hUbrjQpnZlam520nXOL956e5sbUkmk0ov38TBd 2U4JtpNfd4lwnm5C3rh+tblFc12l9pa9Nyk7brF8UarlqmEq5JYmaOw8G8/Dwi+AWbe7qbfb 2HFOcseKRarViKppTXTiZlYhFVadeVcC9TwOe2eybbSp+HYfwL1B+ysXMoJhFOS1vCPMfiyj 0L7z0r7WdOLi2267dI8++8nSd0Z+U7eXehn0l1qMbUfDtKkY4KMe17qL1slGWpViq/ht/XIj PFfmU/8A2T+qJ6ddPHo5W5J0Xe0r8Uv7sSpRk5a9Ca4OXYj6FgT1wS0xmk//ABwqRjtIPFxu S6ZvSdZ07/r/AK/7YWRcb35dLequSepo0Xr0LUdTlpr2INdGZRYhbtylO3FRbpbVHXEnO/Y1 6darBaaaa0MWZvrj9fNqe6hThPCl2XT9Kmm3H/xy9LILcwf+JJ9SJKcXkrki3Pt+v+E6fr9V c7f3H/aF4f3P+crSb/w5esag/wDtP0sx+v11a/X66LVD7q/tD0fdX9og4On6ftGov/t/8xn9 frqv6/XRLR91/wBoelrJS9DIxh9z/mHo+4/7RP1+up+v10SrL73qQm28MfTAruSjai5TUkus 49/zW86xs2rsV8/xehUZrXS7di12Jyt2VquSjFffSRgvedWI4WlG4+amor2nEneuTdZu+396 KZVK+1nK4vxW0zvOKf3dWMuld813E8Yy8NfLpUo/2liZHdlLOepv4Y3cH6JmX9xH/uSj12l9 RCV2Eu/K1Lp0ST9iR1kk7RGluSwUJw//AFxkvqFHsusFFy5Rag/+r6jMpw+Cdtddt/WmNR8T ONuf+VLTL6egZFjuuTcU9E/kuxjR+mnv9ZBNxlSC8O58VuXdl1fTqHonJaXGcorJTgm16api yWirS+Wafukpe8ik4xinBpqLx0SwlF84t4MkqSq2q1VJdPteJDXGGFdK9K/gNdvJal93RP2Y MC3VGPewdKY4e+hY7qnHTJVXX9lfeZ4qS7qa6lOPs7SIvpqvQv8A/WS9WsNEY26ppyVODoy6 7di4pJ4/hl9hzqwbpSDfTpj74DbUXpaSfyXEo1/DONDldNb1VshuJRq4yTXuLLdt35PFYYrt LHqMFXXFuqybwnH05SXpHpaxeHur0V58Yk+3KZdW1fnt5ST9Rz7k3OanKWYapdyTqnkq4+gj K3F/p005YvGpi6WCy4pRi6OqKYXdaUHgTW0vTwo3HoxNG22PYc7kaaXhU54VCMJW0q5sm6yj QL87l2WprojhwE5TjJRpTAlghCMNSk8CyKjjqePAt2+1huV4upqUXjEy3V4cnF444NlGzYRU 7kIzycsSF6SjcnGGKUpJdRLZQ03bSbWmcsSF2MYTuQj3XOVOqpOndWfxJatPAvhHHDIzaMWl kjZYsymn2XhyQs9kKSqyyL8Kk3ilwH+1vTa/Lmlxekd+1OuMZaIcaOhJFadxaenUqLUkznye Glc8zp7lxdqsm0qI5sIa5qEXhzZS571GODXSW3ZNxca0ZBW9N1wk8FxJX+yklmydqjKrr4Cc /FdU8iUK0bbWFSi03GiWZrA3W7jT0tYczt+XXoRjpbxeOPA4kJ1WJC5daljkzBWzza/C/dWh txS9phgnHCpG72o1WQrMZyxjjQ33F0XQtjNxemufAp1VlSWDLYNK6ptVSzM46q6W2koTrPgS 8yhtN7D8zvLuzjmhrc2Zw7So3icud2Lm6OqL2iRydxtJWcZdqHCcfr5GVpxf1ndUlGX3aYrg zJd2kLmO3x52+P8ALz6szndcuk2ZLe44T9ZopXEwyhTFZDt3pW8suRxsw6NbiVXLSl0Muhcj cyz5A4kGKkoPkWRmpdZdKNcGZp23DHgESlCmRba3FFpuYoqjcrhL1jlHmalwli25YwrDtQ5c uo63lfn0rFLW6blbyVzjHrOLCcrTwyLtMb3ahhLijfS9u5LZ37PfW5RuRU4NSi8miZ4TYeY3 /LpUhjD4rT/unr9j5hZ30PEsvLvReaGWu/WNlaD1FLZB3KDJ4tDmUzuUKLm5jBVk6FMLc932 nWFr2y+xDrezWJOtSlenelosqr+KTyRdY2cLL1vtT+Z/VyL4QjbjpgqRXAZ0muHLbe3pOkMB AaYeU3dyf+4XvGwSj2K8uBjvSagrbyzNX9Rwd3eRjwUYV9bM25xZK9GkzhnjFSzKrqin7i/u xbMjmk9TVeRyy73Vp2ltLA0TgopIr2t+OmrVHyLpylest6aUeDqXuUoW1U7vlVusnJqsUvac HbXtWeaO75TN65LhQjN7OtKUWnbk6OWCM/l9yc7bU3Vxk416jQ4p0dKtPAVm0radPik5FneO W2PGrAADq84AAAAAACpi3fllnc9qmifzR+tcTaAwPOTtbry16lVx+aOK9KOjtPN7d7C5SL58 P4HSOduvKLN6srf5c+juv0GesazL3dHNVWKGebVzd+VypPuc84v7DrbXzK1uMH2ZcnkXKWNw CAqGAhgAAAAAFd+54Vqdz5Ytged/qDzh262LLpTBvmzyFy45us3U0bu47k22YZsxerrJgKTT rHDqO55Z/Ue62TUZvxLfJ5+hnCgqlqiStyZeo8+3FjzLb293t3Vwema4rV/E5Gx3H7e7bvfJ JP0cfZUz7N0uqLwjcTty9OXqdAh2W4vqMVLMPp6hB4pLEhKy1jF+iRyfKfOtv+2t279xRuRW lqXRxOg/NdolXxE+rE0xipeNO26Ttypzj2l9vsLI30+DVeaoRhuJXsbcWo/NPD2Zjnajca8T NcVgTr7rj3X5kXbUs8SEYuHdxXIsjJSNSsqXaVcMOpEHt4vhV/exL5ZiNs5Z3ZlwSKntpvgb QBlyLilGWmjr7CNHxqaNw/zGVSN+EZ86z3NxbU1Y1NTkqpL7S5wupY0Sa62cy7j5jDohI7lz KPUZukvRfOzqxzta6a410qi1Mm7Vy32aU6ixmjdd/wBCJOPWdIv3dr3YtMukNLjg8PQXLNdZ O4+0y+ET7l9mXVyq/QKs60pgarffj1juPtvrHgv3Pgy6W8ySjQ0Wu/EU+8+sn2/ifc+CkMzR t0ncWBGaWp9ZPt/FfuT2VEfEVaUZbGKclgGlD7dPuRWpNlV/dWNvp8eejV3am2xbjOai8qHC /qawnYhcXwT0+iRPCxfOOlDd7efcuwf8yL12smn1M8DbueFqwTTWl1VSduNaaK1+7X6jDo93 pfIMjxcb24t925NemX1l68x3NuCULknOrrqo40+0YMx6tzSBSqecs+d7lYTjB+ihqh5420pW s3TCX2gdkDmx86st0lGSa6mXR8028sm1+JEVsOR5xaacbq4qnpj/AAOpGcpxUotNPijPvrUr lmXFx7S9H8BipcPM31jqXEy8TdNVi18uPoZikjKJRdGdfym9pnK08pqq60cdGq1Nwcbkc4s1 qlelyM6/IuafguOq6J//AM3vLY3JXEppYPEJ2Hei4S48eT4M6IeIaSNhXLiakqTg9M+vn6cy x22s2YtXFQoRfJ8Sekg4oz5SNTW1Rt50go8Ytx9Rzt3b8SzLnGcvtOjGKVycedJL6yMNvKbu wUcKr2oeca8K8w281xzETuwdubi+DIs25r9vccJKSzTqeknu4Rg5QVarieVg8Ts7S1K/ZlKL 7ixMbdG9cXpXNlVZmebxNVE6ylkU3bKfc9R0yk1uMqKNkkqdZBppl0VJY5ikicYFlKENfoHU xXWLE0SRTqSLYTixhctNtJrE0q1ClFmyi3h1Gp4Yo3GKrjsYvGbbIbbbxW6cKZtUNdtM1bXb OMnfjmyb3ozJ1UbBLy/zS7tcrd1aoe87zR5zz2V23OzvaUlblpbXI7a3qnFTUXSSqePfS7SW db6ta9OjTQEsSlbm2820Sd+2uJ57pt7Vt4TzCHh7q9HlORHY/rI2+b2q765VUT0y9hksR0Xo tcT6OnXWX4PP6vWeWtaZeg1tow+XfGuhHRtW1Oai8mefbh232u07O3nrJ1ZbsZKXi2++sGvm XLr5E4XFdipxyZocFFme5F2pO7bVU+/Hn0rp9531/HvrXK809IlobxGrXMsg1K2pJ1i8UM7z jkc7yWq1bSkizSk8ER+JE3mbkkYttRYQ7oMId0rIHHvR6xB8SKLbrrJlfEcniIgssvsTIBbf Za6QCoyyLrzrTqKJZFk3UIiO26T9AmKPeKGxDYgLreFl9ZUycX+Ul0kCQqL4GDzyL2u5tb2G GVu5/dZ0OK6x+YWFu7c7D+JUXXwJZnosuOq2TU6XI92aqWWp6cHkcvyK/LcbeVmfftvLpWZ0 OFTlr0vX17t1rlR4oE8MSmE03RE6nXCZSyTIjTwIoBjmk4UfEi3QlKmlAc3d7KN2NJLVH2ox Q3d3Z9ncVuWeFxYyj1/MunM7bKp7dXXhgy2TafyYmZ2VpwvQqqTtzXXFo4m68k8J+JtMY8bf Ffh59RpntL2ym7m0wrjO1LuS+x9KNez31veVUKxuR71qXeX2rpPPtpdfjG5c9ni93b7dfm95 O9+ZGN3540l+OOD+pnrfMPK7W/jj2Liymvr5nmL+zvbTXYvKn+Jba7rpnR9XuJPZuVgi6PHq YpKjoSmsesJYpS9BGk7EqM9HsbtUug8xB0aOzsLtHQzUr1m1UbicJcn7TxG5su1OVt5xbR6/ aXKUfI4vn1jw9xrWU17TU66Wf4pr3x7uRYfA3QdUc2D0yN9p1MNrAYm8Qb5BGK+qMprQ1bhY dJkZFSbbVCosSISVGEACAK9zGwrXCkqccf4FqtSk4yrRLDlmWK44vs9p8x3Xpwm8a1PRg8rX O3Owu7qbc2pRrToic655durM1KxcmnF83R+s9NG9F55ElJS7MaV+oEvweVXmW8U5PczcX8Ki uyv49Zfa8/uuFXp11wVzB/Vmdu/tFeiouKOLuvJaySUdSfvDpJrV1/d3ZtRlBJrk6l9mCl+Z NqPpOfZ8tu2buMGnxlXgdR0SUaZjq57YnSLZQsz+NVIy29tUdW11YEFGMe1RPrdP+PoJdp91 S/l7C/tSxO2nH/du8939IsngsqLhXsL24lHiRi8JRT+5DU/WyUbE3KijCL46q3H9SLPCuUxu uK+5GMcPad8yfr/9uSuWqaxjckuc5aUR7UWtKtR63qf1lv7W3qWpznjTtTzb4YB4dptxt206 vRGvP4n1Ivl+v1f/AMKzu806SvPqtwf8CHYfa0XZv7zp9p0qft4uFmKSjpiqLi8x3bjUJy5P RH6yeftP1+xYxbOfZgoxaUdUn2ZUrwxoaJW7sE7k3ags26fwJRvSmkuDfsRn3HiXYw04tVuN NZv6ZDrb7JmRevHkuzPClaxivtQ4xnOlZyo1qrkPa7yG5hK7DjpjQvnZTkkvhi16znbZcWY/ Zpl8KVIublSX3sV7CcLKkotN9rp4ErU5J2lL5X60Rsyp4TXFTLbf1+//AMJ+v+kZ7eSi5ReC eC5r1hK3FOacpdnT7S+zLVC2vmqzLvd3Yt27jnKrb0qMcXVCXa3x/XcsmP17f/pdLb6G25y0 xjV5fYcu7v4twhtnNyeMpOlKHO3u9u3neU20tMexXBGbxXBya/7aO2umPq6pceiN1yvpXLly UpOWlaqZClYjHxHrfZootUzNCcZytW8lFa2Z5J+Hq+e4dkNWJqcYOck9OqRFeJ4cZxuyrJ0p jl6y2d2kr0nmlpQQVLlmPJamRUJO+pT03pOMOLqR1bjsJTxnwpkRc34M5fPMvWG4VMoQ+ois 8p3tEpvRJRdMYxr7g0zlJQdu3JtasMPc0KtNuvvTL8r82vhhT2EGNSjp1+EqVpnL7Sx3HF6d NxNKtFcf2A8dvBPjIsctF26uUfqIqqO5SxU7sa9KkvqCU4N9qUG+crVH7CT/AE7K+8xtJzvt pZMioUi+Fp9UpQZKMZZRjXojfIO3Gll0z73rIvbwfjfd7vrIq6UnFUnrivlvR1x9eZVG5Cmm M4U+Vuen2ocISg7ahNx1rmLxbyhKTlqUXRqSTILVGVOzF0525Kcf7ItWnutRfOPdf4oZr1FT STpK1FumqsG44eslK7CdHqa/zIKf/NmBNJ0oo4POGcP5XnEb7L7VVwrLOnJ8JL2kFFPJWrnV +XL+6OjtcLttf24/UTKrI1t9qL0pfFF1p6Vw6HkdCz5vetr8xxuQ5v8A/L3VOXBqTrBxlLnB +HP1ZMJT8OVZPTJ56k4N9dKxfqJtJt02mVls7PT2N9avvTgpUrpl9MTQo6m6xyVankqNJUjh nWPaX/Ll6idm/ci62pUf3X9X2o894Jn+N/ZvzuHtNtG3TFJNsqjtrU7rrGLiuZydlvXeat3p qM8ovgzouzLLWjlZdbixPJbd2m38WNIxSXLIyXNpYlJ4YV4Fv7Zv40SVmaykjFu17NSz2Zoe X2ITUortJ1OjYuON5+JTVPu06DP4NzNNE1G7rjcdHp6TWlsl8ktno6hXeS8OS6GZ/wBzdr3F T8RC7euzTjpST6TWTLl3dncuQ0a8KIhHZXoycqxywN9LuWkWmfynO77r/Fybfll6OLaYr2x3 M6qNKdZ1X4i+FgnLinUee/sY1cReW7iCacU8MCUdhfiquGNDtPV0j7XCpfubex46+7hLa38H KLQ527qVXFv0HdrPpFrnyJ9y+x46+7h+DOUWpRarwNNiEtrB29D1SR0XKTGpy4lnJZ6J4T3c 69bTg046ZUeJnsYR6TtOceKEpQfwot5c+h4fFwtzfceykZEu1Wp6fRaeOlCVmy84ofdnseHx eddzBqlWX3qRtRcVSWdeJ21YsLKKxCe1s3aVWRZy6l464M1b3CWt6bnz0z/F9pgvbWdt0ao8 +hrmuZ6t7GzLoIS8utSj4brp93SuRm761qa2PHYrrNNrc/Dc/tG7f+Vzsdp9qH/cXD8S+s5U 7bhg/WYs9Yre0QaMtq9K3hmuRsjKNxVj6jKs07XGPqIxk1hmuRqcSuUNXQ+YRXTCuaI0ccYk sU+T9jHngs+RciyN2N5abmD5gvF2txXbcnGSykvrKWlLoZZbvOHYnijpmXuz1nZ6TY+e29yv Dvdi9/yy6i25upzmrdpVkzy9zbqSrDFe40eX+Zz2d2M7jcorsvq6SY69XXXeY+L1W38vUX4l 9658vhRuKNvvLO6VbUk+jiX1O0mHHa23+QATklmCknkVkwCqCqA4fn1h67d9LCjhJ+44N3Fn qfO5U2kulx955WTrQzt2ejhVXU3SJC2lHB5mqEVJ48jnW4XLdx3ILU3WqZiTp0drevVvq5OL Sy6C+F1J4YOnENt+4lFUsN0edcCvebLc3Uldh4Ua11FmWbj0huy1JTtqqeHpPUbHa+BDHvSz Mnk230bVyuYuvHPA6qdEZqZuMLFJRxYyh3owxk6IsdyCVaqhvWerhvcXCYEYTjPGLqNtLNm3 MMZRdm0iuO6SemTKmWsBVQEUxAADAQADSkqNVT4M5e58mhLt7d6JfK+7/A6oiWZXOHAt7zcb B+HdTX3ZZP8ACzrbbf2tzhF6ZfLI0ThG5HRNKUXwZyNz5L8W2f8AJL6mTrPivSuyB5+x5pf2 kvC3Cbpwln6Gdmxu7W4VbcsfleZcpZheAqoZUBVurbvWbltZyi0i0APme5g03XBrNGFxbx4H 0vzDy3b7mEpysxncpx7PtR5q/wCV3Fa0+BbhRVc4Nt0MYw6TbLzkFFc2XqiWVUyNxSrVKiL7 Lk0o1aXQR1nRVNunZVC/dOtxXVlcSn6Xn7akrlt1cJcq1IaH+3Vc7cqfyyx99fWSzol6rrcr alC5dVYJ1kuh4P6j1GzW326jcjGT1t6deOlVwx6jy+0lFLVJalFrVHnFno7Ow/e21Kf5UV2d EccDJrOjuS3dOCk/li6sblcuJ9nTXpIWIRsQUIKiXIJXMMC5Xx9maS3NqkopSoa9vcdxa2nF rOpdF9mrM1y140k8HDKUektZkz3am08UIw7S2rF25aj3KKUVy5m2pudY576+NwYEIZV5upM0 w5l5VuPrK2XXO8+splmdXJy3j5l1W/rO5d+HqOHDHzGfRbXvO5ezXUiNeirius0bn9T0Ioj3 l1ou3P6j9A9U9FKzXWSud5ij3l1jn3mAWu/EJ959Y7H6iFLvPrHqeh2f1EKWb6yVj9RdRB5s ep6LNt+oupkHm+ss2v6noKmPU9BHvAOPeAC3afq+hnP83teNtL0eKWpfyup0dp+o+oqcVOsX lKq9ZPU9Hz+zuJ2VLRSk1R1VcyNu5K01KDaayaFKDttwecW4+o07XYXd5Gbs0crdG4cWnyPN 1zh6c+rq7LzZXuxeemT+Lg/sN0oJYNI8lTNPBrNM6Gz8zlZpC52oe1fTkb129Klmezs+BaeM oJvqIS2VluumnUy+zKF1aoNSi1mNG7GIyvy+zJ4VXpKrvlk0vyppvlNfYb45kqmcRvLmbTzK 9sZKzfhSGWDw9H2HqKqiaxTXsOBurcZYTVYyzK9rvrnlzVu63PbvKXGJddsdKztpmZjLu7X7 e9KDyTcfQ8jBcjRtcjvec243VDcW3WM1pquaxRxZ9pKXrOW0xs1rcxnRp2/arFmbJltmWmSZ J3WvReTzVyMrMs44rq4nWjaTi3V4HntrPwbutcFr9HxezH0HpYU0SaybPRJMdnK2+7nbqz4T /cpvDC4ucOf8vuNNvaK5KmrClalpX5evBuy27yUXK0/u8v5fdQXTX2Jvt7oftUni6k4beLkk 1my1me/duRajZjWfBk8NJ1ws332uMlv/AAtpehOmGMWuvFHIu76c709HZUlHBdBo3OzuzjK7 ek3Jdr1F9vbQt31pWErbfqZw22tmJ0j06Sa3N/lXmfMrLhJTapqMR6zzza+Jt9azg/YeUWK6 i69mNu9RTodTy/c+DqXCcXFnLeZosSxLWTj2ouP3ivX2iyEXG5OnWN21GalwZK7a9Yc4Rk8C Tt0RXJ0ZJXOBGsISI6l1Ep8yulWVKnrjSrqS12viTRbbSdC+aWl1SNRiq7F2KdE69ZtjKsTi 6tEqI6NpylbouAI1u+4YJNs6Xle5UlK1KiuLHTxocaxbv3JrRRp8zfLy6EZeJfUrdxd2/axS /Eibaeeviz54uXU3+3/eba5Z4yWHWsjF5DuFe2aU87T0uo9n51FqULuNyGTSwudK6zmbBRW+ nZmnGF3tqJ5NOLe+XHentWrtJjaPQvTPCCXWJbWKfSW0SaSwSJPM9enDNe+1rjty29ph5rzu 2obpNfFBew5dr9SPWdzz+Paty6JI4ce+us3tE1r0vlr/ADJrnH6zr7b9VdRxPLpUvpc4yR3N t+p6Bp9Kb/UhLNkWSeZB5HRzVzj+2ipxxtyxnH5fvL6y7gmsUyTfZRl/0zp/gt/2H/8Aj7gq 9d5DeYl3x8QhMce6J5Dj3UAgj30NiXeQEpZkSTzIgTh+n6RcBx/TXWICMuBZczIS4E55gQHb WL6gpiStrvBUSLyJ0E1gVE6flxINYFssIRKmyKEu0ussu99kIOs4juvtPrCOW5/7f5jG7/h7 hUf4uP2ncuQpJ8mcjzPbPdbeUY9+Pbh1os2e+ubvbW7tujlBrxIv4kY2/wC251jWm4SryNao 1UztqTrSifAutOi0S4ZPoNZzMp2qUY4CaoSuTUVRC1J+kLhAnPgQlgSm8fQERHBdoBwzAi4q WDOVv/Ko3aXItxuR7k44NHWQSjqVC5RwbHmsrMlY8wWmTwjeXdl18mdWduF2Ph3UpQf0qii/ toX4u1cSaeGJy1DdeTy0207+24w+KH4Wc9+P10/o1Ll53c2Ht5zsyztycfQVwVax54o6/nU7 W4uQ3Vl9m5HTKLVJKS5rqOPF6X1M5V0iBt2lyjRluKkiVqVGZo9fs7tfSS86s+NtlcWcMTn7 C7VI7Mo+NZlDmqk1uL82fV4qao6mqxLIpvQcaxeadAsSMulbmKo1ihZFRC6tUTAdB4rmYGqN olURFcXElBYjuRqgKAACD6BGDjVp6elvnyHDTXQkmvmqKWXYSb6ScbrSTmkn909TK6VtzhhS v04E1BQo36WxK6mssglcSjiswFKUU61qxSq197gRcNdcadQ2pQg26Jp+wRb0Qvyk6Jog6XEt PZS+Li/4CuX3cXLp6CCbcaZV930zO+umOt7vNtvnpOxW4xjWaVZPCvHq9JdN0pKbyx9P0yKf F0Kkc+HW/wCBW7rkk0q1rL0LCPreJ0xbXOdl7uxitKzbo/RmVeK6anw7VP8ApX1ijBJKPQ1X oWMn6XgWRi28V2m9VOn4V6EXpAJOLrxitK/HLN+g1WratxVO9SkftK7MVLF4xVcfey6rePxS y6Ectr6Nz3KfYx4Qx65GTeVUYWln3pG6ilh8Efazn37mq+k8K0p1F4+/yTbpPmm+wlF56dPr xZojFKcPwsyWL6vt866fp6DdWtxdEWNszoTv/R5/c2J7Rwv2X2ZVquTjijp7PzGO4jJ5SbWH Qy63FSVpPFdo4G42k9rpuWu43JdVHVeg69N+m3f3/e//AAk6fr4f/b1GlOa+4veZo2nHwuiU vUzlR880Wpya1Telx5ciu55revXGnLTC2q0jx9JjXj27fr9dWrf1+vhBut9KxKNq3LKcoSfL oOTal+nF5a5VBwei2nnOeoreFWso3cPSenGGYtlNTtzk+9clpFeS1XOUIKJVXT/Lc94XJdm7 z1pe0ZMJqqkq5u0K3KvgReWJKb/Nn923T2EbfesLobCoTlqt3Zc5pe0ur+f+G39Rmf6D6bhe 3+dc6IfUTIp/wLa5zLm/zbz5RfuKP8OyvvMsk+3uH0MmVQf6Vpc5Msb7d98kyunZsdb95J1r uPpxJkRf6dlc2/eSk6zvvoZHhY+nEbz3Hp95FJvsWV0v3kn3tx1P3kH3bH04k5d7cdTCovKx 6feHHcL6Zg+7Y637xtdrcfTiQFf0H9MxPuX10/WNf4H04hLLcdf1kDh+rafONCma/Ji/lm0X w/UsdRXprYuLlNBTuWYuV1JY01RIxhKDt+HJx1rg+Jel+e1zt/UVRfYsy5SaAi7kpKt2MZ1e nKkq9aoSjdUOzG5O392a1x+noC6uzcpnCepE7rad1r4oxmiCHh+JLUoRm/msy0v+z/8AylkW qam5Siu9q78PtRCdmEp0SSSt66rmWxcpLU3W5GOpS+aPGL5hFV23cg3p7WnF04xfFfTA7Ple /juIaJ95fSnWjn0Ue5kl4lv8L70RJaJq5DCUaNP7svpQzvrN5hZcPQvQx6YZkoTjciprJqpL snzsYdcfJDscwWnmT7IdkfuY+SNY82KsV8T9ZNaeAUiP3MfBDV95j1P5mPTFg4xH7mPgNb4S Frl8xJQjyDRHkX9zHwLxJfMHiT+YfhxyoCtxQ/cx8B4k/mDxLnNB4cVkHhxY6+5j4DxbnNB4 1zkheEg8JD9zBu/P5UHjy+VEfCQ/DQzfcwPFk/gQePzgLw10h4fSxmpg/FjxgHiw+Rho6Q0d IzVwPEhxiw8SHysHBi0PmM0whevaINwi3LpObuPLY3o67KSnTtWuH8r4dWR1PDfMatyWTGas uHjbtiUG8HhmuK9BXCbi6xPY7jZx3GMnSayms/TzRwd5sHCVLtISfdmu5L6esYVRbvqeeDJu JhnCVt6ZKjL7V+nZlkTAslGuDK3GmeK58TRSqqiDVCKqarn6xNVwkWaaZEaJ4cCohGUrTqsi +kL6qsJFOMelC00xh6jc2/ozYcXOxLjToz60zqWvPrtqjufmW8tSwkjBC9G6tNzPmVXLMrL1 RxX0zLj27Omu/wDbvMx7S1cV+CuWu1F5YkqSXBnhEqqkG1x019xv2nnl+wtFxucVxrjQzj4t 3jtnlpcx6q7c8KDnJOkVUp229huZOME6pJv0nPn5lttxbcHe0qSxTM8N7ttgpXYXdblSOmOb oJOnrlx/lns6fm2O0nng4v2nmlI17vz6N+Hg24uk12nLh1GCMjU7dXfjl9ejXZlSrfAq0OU9 Mcaji8cOJ1tptYWrsKvPFvrNejW3Ste0289pBRUu9jI6Mu3GlztdYpwjWkVShc1FR6ciYc7t fVXDBLCiRG3WTLozxxyIxZKa3uruRUlRqpU7UeSIXd3FXXa4xz9IOb5GLfim8uuLtO/ZdD8v COBXKzCTrLPrI+L0B4nQPK+7nnX2SdqLzr6yD2ltuvENfGhLxK8B5be5/H2C2yqmpPDpNEZS jGla9LM/idDFr6y+W3uY19mtXWljiHjy5GXWJSTzZfPYxq2eOuQ/HXIw66cQlcrSg89jGrbK /wAkNX1xMUbmGI1cHnsY1923xogr8TEruGIK6h9y+yY192u9GzuI6bqUl0nD3Xl0rMm9vWcO TOjG7R45D8ag877LJPdxre4knSrTWSkdV765O2lbWKzI34W9xhdjXpWZglYvbfG23KPB/EjU 5L6s3WejTDcbiEk6P0m1+Z0zgzBZ8zk1S4qtceJujfU1VYot5L66nhPdVf8AM5uqtx7LXEje vNbSVxZqPHmaPEjyM27UJ255pNYpcR9z4LNPjl4y5qbodTy7y6e4mowwSzkzDdXh9pHY2PmC syXKmFBn2eiT3bd9/T6jac4TcpxphTNcTm7rRGuziopTVYOLr2lj78DuP+obEMMXL7qqcHzW 7DcS/cQjolGWpYY16R3TOO7l7OjuKEsppw9Z7fyvTuNnBy72MZ/ijgzxG5Xh3nKGCdJx9OJ6 PY7t2pSXw3FG9H04S9pmf9MTvj3dlW3aydUXRimkZVeUkmnVPkbLcKUzJh0tw0Lsqpwdxtbt q949h1hcliuTO83gZbl2KWmGMnilE1ZlnTay5FuNLkn1Isn2noXHPqM0txC3GNytaqpCzd0y cpvF5mpZJ1cd829G8Cn9zDgS8eHM1mM4rFPvPrKpZljdWyt5nZxczb4+YXeiMTt3+96EcXZY 7+++iCO1f779BPVq9kIYzj1lm4/UZC1+pHrJ3/1JE9U9FcO8glmx2+8hPNlE9v8AqIg82T2/ f9BAep6LNv3/AEFZZt+8+orHqLdr331FRdtu9LqKiep6CPeEOOfoEUX7PvvqKa0xLtpnJ9BQ PWnpHjPN7Xhby7Hg3rX82Jf/AE/c0bvT88JL1Yl39SWqX7dz5oU/sv8AiczY3fB3Nq5ymq+n A4Xpu7Trq9PvfKrW/dX2LtMJr+9zPLbra3dpPw7yo+D4S6j3UI9prkUXrNvcQdu7FSi+H2HT bWbMTax43a7q5tZ67b608md7ab23ul2ezPjD7DmeY+UXNn+ZbrO1z+KPX9pzoyaeqLo+DOWb r0rp026vWLMDl7LzXW1bv0T+fL1nVfsNy5VXdjri4rPNGK3cjPsyyeDOgszl7u34V10yl2kY 292tfYrlq5tOxFt2W09Pyv7DJKNJShzyOztpq9BaseDOVu7fhT/C6Gdp6jHNY1CLoWXF9Osq Rkdixc0qN3PQ8er/AIHotk0rMrdauEtK/C8Yv1HltlOqcWd3Yz0wt3K4V/b3PfB/V6T063Mc a6BGVh3sbbpdh27b6eXU8mTZZYzk+g3eznFFq6r0FcjhXNcnxXoLbP6kesySf7e9q/w7rpL7 tzg/5sus12k/ESAleSnJp5PA5lt/oVzXiWn6P+B0Z95nOu9i7p/8kJr+ZUZFbr1qNyDg/iVD wV227N2VuXNo+gXMGjyf9Rbbw7yurKar6TO06Na3q4klT0E7cqMJ40fMgjlXV042u3XmqGac JRkom6xLXbjLisGK9jgSx1026YYJIFgWNEKGXQniCQE0gJ2ooslCMYttugW1RVZn3FxzwWRq JVepPJGzZ3NMuhmKNyOCo6m/awpKrwXSDph0dvehZuJpVo8jr2btxqksXKv8vQcazNTmmscT 0E8TprM9Xn5OjFa8os22rsW+y8Isx+fQdp2d5HO3LTLqZ24usDPvdut1t7ln5ounXwNuOVqm rmmayaqSeZy/Itw7+3jGXeh2WdR5lK5Hn0a2YS5S96PO5SXWep84jq2suhpnlpZnPZvR3dm9 N+304etHoNqu3LqPNW5aJW30o9Ptu9N9BNPpq791JGWRIjLI6uSySol1EGk1R4p5k5utOoiQ ZrT8C4rcn2H+nJ8Puv6jTxI6I3KxmqxaxK7UpQl4Nx1fwS+Zcute0KslkSXdQpLAnTsoCIo9 4m6Ci+2AUxE0SbK28Ai2K7CFgJ9yJECUmqolKWJX8SJtVYCqO3lIEh2+6+sKRGWRIhLIIunl HqKmW3eHUVMQp2v1EOfefWFn9RCeYCTo6nK2P/o7+W3f6V3tR9P8Tq0MHmm3c7K3EO/Zlq/l 4k2mZhdbiurKDhJp8C2CrSmdPWKElurEb0c2qhbeFDGvS492rEE45NUJxnwpgiM4NupZCCrk dLgmSqqVRGM3LvBuI6Hqjk8zPG608chNemYt29K1akiDuNd0od3kiLusuKxlo8RjdyqxdDK1 czo6C8OXrLietTKdy7R6VFyGo8/UOMdPWNtLFnm25PTXs1J7sPnG1/dbWdFWcFri+PZ4eo8Z LF14NHuJ364LI8bu7DsXJ2vleHUzlNpejpJhU+1BPiitYFsM6cJIqapgVp1thdo6Hpdrcy6D x21nRnpdncqkYrNczzax4W4kuEsUcyGDPR+d29duF1cMGecmqMZ6tzs6Ft1iDK9vKuBbIohW hju4SNknQzbhVxIK40riWyjVFKNCdUBkpjQCynaAD2VrdRnhRpl1UnVVPP2L/iKqeJvt3m3/ ABO0rd1daE3J4rLmy5xc+r1GC1deb9pqjewrhiajneixussXRGW9uPFk6d1ZdJDcbhN+HHD5 n9RnUnwPVx8f91efk3z/ABi5SSWp5/UQnNy7K6I168X7CtvVhwbVff7iyEapN4LGvpxfsO2M OIjCUqLi6v0yy9SLVGtdPRGP1erMSnTF8at/T2DrSL1OlE6+nvfYZuRJpKj4Oi9Cy/tMhcut K444uPYX4pZgm3O3XhF3ZfUS2lnUoauLd2X1DpOt/X6wuGq1DRCFt8qy6kWRbfa+KeXQiD7f XN/8qJwlWtznhHqOF/X6/XZ0n6/X67rKLuLJZmDd2fElG6s9SjHqVTdT4Fm+8VzpjLhFaY9Z Nbi5Nv1+vg5HlMV4ta5VZ160k3ygvacbZwlt93K2+Co/SqnXuPtNc1BHbl67fCxmdJ8go6Z2 lyUjM7sLULU7jpHVIlufMbFm48dUoRfZieaubm5uZWXc5yajwQ00tmb0n/7L7fr0U3JRuSrB UjKc4pdDKdbcZc5R9sSUMVbS/wC5IjHCj/8AJKPrO1GhXl4jm8oQTiVaKwtwXenLWyuKfd56 rf2ErVx6oy46Gl1os29zBXHVTlzuKgr2V78URwWuNq38z1MjceqF2aylJJD5Cdzv3fwILf6l n8Irj7V38CHb/VtfgMqp/wABf5hdL9W9+D6ihfoL/ML5fq3vw/UBUu5Z62See4+nESXZsdb9 43nuPpxIpNYWPpxHw3H04hx2/wBOIcNx9OJAv/7f6cR8dx9OIuO3+nEfHcen3hUX3bHp95N9 /cdTINdmx6feWNdvcdT94EJdyx1v3kpd/cdTE+7t+t+8lLv7jqfvII8Nv1v3jkv9R1/WNZbf rfvHL/6Ov6wCP6m36vrK/wDAu/jRdH9Tbro+sq/wLv40Bcv9Qv8AL+ooj+ja/GzQv9Qv8v6j Ol+Rb/GwLLmH7j6cR4eJCuTt4+0VzvX10Alqna6YAKzVq0+cZWyaVHWmmcO/FZfij0c0Vwro s6VqdZYcy1U7Li6Kv5c38L+SXQAKsKfdr/Zl9Xu4gqpU4qOn1OqDKvw6Xivkk/7khrB5UphT l9OAHQ8v3StT8OXck3ToZ2HGnA8046lgd7a3/FtRk86UfoPH+Rpj+c/dZV9FyDSha0mCaPG0 NHQGklqWYqpYlC0oNISuJArikghaUCiiakniLUuGQUmgoNNA5AyTRHQyWoKrmDKKiwo6kk8K sSuJgyVGgSkxu4o5saknkDJOqCr4okuYqDK5qOp8hVJ1Y10jKZqvUSTZKqYV4IuVzSqGodGF HxGTypVCSjci4TSlF5pjSEsx5L5ORvfK3GNbdblvPT8cermvb1nCuWHBaljHn9p7XjgZN1sI 3nrhSF3j8svxfaXyam0vd5W3ecDXGanlmV7naStyacdMvl+zoMqbgy92uza4kaBbvKWZY4kF VCDi44x9Ra0KgRTRXMVhInavuHZnkKduuKzIqSl2Z+s1LhLFt3bKa12vUZWlJ9rCXPg+stjK Vl9HsZe4w3K5SN9L27rrvdLmObcg4vTJUZTkzfOLtvRcVVwfLqKHtnJpLtV7rQzju9mu05Pp 7+zM8Ddt7imukpv7O7t6eLGieT4FMJO26otuYuLK60Mzo7a+q9t0aWByrN5XFhmaoYnPOHTb SbR3Xu3Ki1qkViWS3icaQxlwOLCCNlptd015OF43ZU1RVzBSaMdpyfeNlqNcWTKYkcHd27m3 3kncyuduL6OXoOnZnqjisUWedWlKxG5xhJU6ngzDbm44ozZiu0n3uLxvfXo30XISiuRTHc1z wJq8R49uLbXvE1GPIXZXMXjD8ZBzwOz0g6cwV6LH4iYEcOYUXMnqiLUimENK5hpXMlVDqugG EdPSPT0jrFDrHkQR09ItPUSeli0RCYFOodOgjp5BoYD9A8ORDTIeljKfsrvbW1fzTjL5kYJ2 r21epVlH5l9Z0W3yZJOSGVyy2N/C4u3gzTcSnB8U0Z72yhdeqPYnzRlcr+0dZrsvisjWZTp6 OHu4t0QUWldrSb7238Ru5b7SeNOTODOMvESrxOsjtdsuvsr0NpJXJR1UUlTnU6K31l25VtuS 5dBgjvIVVLUq+g2+Bu70KW4QhhxlViF1z2ji7icb0FcinHS3Bp+tfX6jfsLtbduT/wAOfhyr 8tz7GV39hc28ZxudqUlqr0xx91Snyx6pTsv/ABItelZE9fm53p+z1dm04444cjp2ricNUsOs 81P+obW1tqic77iqxyUXxqcS95pevNXJvtcOK9WRqardsve3PMLFtanNNLjHte481LzqxC5N x1vVLNLguB5e7ubk+y5NquVcPUVq9NYKTS6C4SXHZ6mG/sX7iWqSisVgbo2fF7Vu5VHh/Edc Gbtt5tdsfeXt9Zm6+zL1fgXU8JElavRedUZ/LfN7O8/Lm9Nzh0nUywOebL1OoK33iwhxPY4O Z5djvb76YL2Havd9nG8pVdzfl99L2HZvd9j1W9hY/Uj1jvd+XWLbr82JK8qanzZPVPRVCVJI TeLFbXaQSzZpFu3fb9BWTsNKTb5FepE9VXbfOXUQFC+oV6UR8VAaNv8AH1FIoX9FdPEXiLkR UovNiIu4km8zHtt65xS0OlWiph1trlN9BQEL/h1VMGDkuGKJ6q439RWtW3hc+SdP7SPLSbSq s1ie28ySu7O9CmOnUuuOJ4rM48nfLpp2e/2s1dj4qylBS9aIGXyS7q2MJPhW36masDtKxZ1N OjOL5j5HG9W7taRnm7fwvq5P2HbSo6ioLJUmZ2eHvzlKWmcVCUcNNKP0mnZ+Yz2/Zl2ocuXU ek33l9rfKlzCa7txZr7UeX3uxu7GWm6sH3Zruv6cjjtrdesdtds9K9FYuQv0lbdV7ijf2ddt tZxxOBt9zc201O26NHe2m/t7rB9mb+Hg+ok2z0rWMdYyeX3KXdDyll1lnmFuvaXH6jJehLbX sM4usTpXWr1tzXHtI1JmYTbvlxZKseopNMo0bXo+wzs4tL9rPTM72xpcc9vWiuxw6JRxR5uE tLryOxt72hxuLOLqduO+jlvHoLF3xrcZvPKS+8sGabGUjHBqF+UV3Lq8WH4vi+pmyz3ZHa9n NTctxuwdufdkqMXltyUp+Hc/Ut4S6Vwl6feTKparVxbmCq4JqcVm4cfSs0L2J3aLvffWc3zH sStXOc4wfrqjoykpvVF1jLFPoMXmUdW3k1nFxmv5XUDdd7xyvO9v422bWcMfQdW66uq4pFco qacXk1Qnoer56sU1yIGjc2nt70oPg6FElQ413joeX3M4F1/BnO21zRNM6m5VYqSL3i63G3zY iVMBcSWRzd0KYk7casQQmo1IKrl9Vo2QjpfEJW01iSt6Y4SVUaSL7FuLeOZrvQXgtCsKFxaU 6V48ihOcn4Lxo8WVK6vlG31tSeUTuMz7Cz4Vlc3iaGddZiPLybZpwVIAsCUsIw6SJphxdmls /MrljKF3tx9P8TtPM4vnsXalZ3cc7ctMupnZjNTSmspKoVn38de3uL7rPHSyqe2urVCS5pni pLChjZrV0ZS7CfKjPW7R1jKXOKPHydbXoR6vyx6ttq+7Qxp2re4IyyLKcyMmjq4m1kPSO7LE hUBwpqZG7CN2LhL0PinzQoZsYVTC9J1tXf1Fx+Zc19ZoeSKL9tXYpVpJOsZcmSt3nPszVLke 8vrXQwLGKHeGKDxYRNYkZwwbFUJPACxx7K6hUSCWCS6CIVKq1obeJWu+SriEOo4dz0kKk4/p rrCokZZEiL4FRbdz9BWyy73iDIJWP1PQR4krHeb6CIASgk4NPJ4MiSh3fSBX5M3Z17WXwPs9 TN0lolXgY5JWr9u9z7E/qOlcjqRzrr6IXIV7SIxaz4lluWpdRGcaPAuRCaqUaFjHoLpkFBJ9 SNTsXup0JA4InQjOSgm2Xq5k5eHHTzyQKPF5lcYSnFyrplJdl/KT8SkFK5FQawarU473LUht qK1PIxXLrmyfb3UZXLeMYulPsMzdMOJ5d8/s6SG3yOP5za7ULyyfYl9R1alW7s+PYlb4tVXW jOtxVeXrpx5MleWNeZGWNHzJrtQ6UdxC3KjO/wCX3ao88dPY3aSRmpXpbsP3FiUOawPJ3Fh0 o9ZtZnA8yseDfnHg+0vSZXX2ZLEqM2vE5sHRnRjjEqq55FF1VWBpksDO8iihF8KNGdZsug3k iCWntASrjUCoqsX3akdSG6SWGL5Ep+RzrVO37SS8qupUdyEFzSbZ1w6+Tny3u4u3lt4S1OT7 v0ySPS3JKzFVxpRLrM+x2FnZVdtOU33rksyrdXdV5QWUMX1s9HHrmvPvt0WJt4vMblqSiuJU sc8+JalTo4HteVZTCvDP1/wQ3cSrzVX9PTQqc3J9Ff4+5FlmLaTl9PiZkWJNYvnGPp/4ivNz jNrjONtejMLbcp2m8u1c9WQ7OEY9Gq76XgifH9froLJLVKX3mrS6lmX6qppZykra6kVRcbcr ca4r6MzQvtXLbWWt1M4z+v17GXSnOqnJc/DiTjJRk+UEorrOftNwrnhx5zm2TV/8uM6VbuSk 11GLp6fr9dGs+ro5dn4nmDpn8MfeVQvVh4le/l1Ge75ptoydpNyUMZuKw9Zymtt6RrM/X6/e s24j4N+F+TopJufQuBm813iv3oWrM6wdNWnoM3mO+nvYui0Rl2YLizGmozbXwRfsPXNb0227 yMe6Dufl3Zr45aSdKXYrhbhj6iqMfy7UPmk5MU54Xp83pR0QrWHg89UmRhjGHTcZckldiuFu FX7yq0qKz0ykzNaiLyb/APKHddfluU9YQxjHpusUsU+m6Zwoj2HF/JNx9ZF4QUX8NzElcyuf 5iC8v1uhxZOqnceN9+glHC7aX3CNxVd1c4RkSg63bT5wGTDP/gL8Zol+te/B9RnpTbr8Zol+ td/B9RBUu7Y637ybz3C+mZBfp2fxMtff3C6GBD/+3f0zD/8AuPpxD4bD6X7yTz3H04kVF57f 6cR8dx6feJvCw+v3kmu3uF0P3gQa7NjrfvLPj3HUyt9yz1v3oua/M3H4WBW+5Y637yUu/uOp +8i/07D6X7yya/M3HUwI8Nv1v3hLLcdf1h8O3637xyWG56/rAlDG7t/wlX/z3Pxovt/q2Pwl H/zz/wAxAaKf+x1W/wC6Z0vyLf42aG/zpv8A8f8AdK4qsLEebbAVzPcfTiStr82yvuP6wm04 35c3p9pZCKV2C+W1X3gZ4qLhaUnpTc8eTLnVuWqNZJfnQ+ZfMiMFptW246oJS1robzJqLTjF S7Sxs3PmXysIVG3FJpyp+XN5Tj8kukiqUVMu7jw+5L+6x1jpbaatt/mw425fMugk61epapJd tf8Ach8y6UFEZfT6e063ltyOmUG8a1SORTl2nTVF/PH/APJe0sty0tOL+9F/T2mN9Jvr4j0X ZpmRqk6GTaW5buqtyUZRzi/ejU/LL/zI+dePaXFa7ptJ8Q0pqof7bfpTWgXl1/LWqE8NmsE9 NKNgkiL8qvP41Uf+2bjTTXFvmXw2MHRPjgNJJEl5fepRuIPy+9p0qaWNch4bJhGqyTwHQJeW 3W6qaXoBeXXl8aaJ4bLgtKTBNZE/9vuP4kiL8uvfOqdQ8NjCMop4N4EUksiz/bbvCaD/AG27 wkkPt7GENKzYZEn5df8AnQf7dfr30Pt7GCWAah/7duK99dOAn5df4SQ8NkFasepPMa2N9POI /wBjep8NR4bGEapgnUT2O54aQ/Z7tqj0+seGxhJNBVNUIPY7nPD1jWz3K5esnjt7GKakPUuJ B7XdcEqdYLbbrjFU6y+Gy4TqhqSzZV+33KVFFesX7bdPBxXrHjsYZvM0ow8TTrgu/HivvRfB +x8Ti3ttG5DxrT1w+biuia4deR6P9tusU4JpqmZ5ndWb3lW47PZbVVxTi+D5lxcPTxSbzwv1 TsxuEoPky6zfpgzVB2t7hBKF3/t1wf4H/dfoZiuWnBtNOq9Zcs7aXW9WyikqrFEGjNbuuDNk ZKfWSxhXQrnBS6y9xINEVnUnDsyyDTTtQxXtRdKKlgyhxladeBco0QvRurTc9ZXcszsVcMYv P6fWQop4xwly5llncOHZllyN5l6bf1SZ1udVEJO3Wlblp9+2810otewdyKuWH4kH611ls7Cn +ZZdGURcoy1Qfh3ONMFL7GSyx6+Hm/t27f8ASie2u2e1paNu3utrHFe007beX43VZ3NHrVYt ZnSs7GxcvNzqnJ5fCzOc93q2mP5a/vGO21LI127ijg8Dp3fJtvPGCduX3ciNvye1B1lKU+sv jXn+7re6NiSuYxTaN9qNWTjYjFUWRdFJZFmrjtvPRzvOpabEYcZTivVictG3zS8rtxWl/h4t 9LMSM73q9vBr46dfXqdQADDsE2smWKb4lYys7a67dNplclVVTJOqKYSpiaNcVxzI+XzcN47n X6ajRkk3HNEHJJ5jdyPMOHVJSTDUiOqLQ6xGTNPVFcA1JirFjdBkzQ2kGtZUE3HgDlEZM0a1 XkS1KpFTi8BuksEi5PKpaukSuDVlvgPwH0GprtfQ8x4jDXUhct6aJdqpLwl0HWcO9Z+5Gfe7 +1s0pXZUUsFQr8w3ErG2/c2nqrTB5NGLzHZXN3NeJGsY92jHct3rm2/auHY6z1TjknjiMeXr lZO3GduO4tdnVnFZGO9Zt3sbscVlKOaJWPKpJLGUdLwWrAvna03KPijjeO6zu767Tbp6qtvZ jbeqTUlwZ09u5YaYuj6TmJNdpdlmm1u5Wmo3MOT4GPm6ZrpblWoQbudUVm5c0vtPFxrtr/4Z HR84vbycXOaWh4OVvFJcucV7zmT7Vu3Pilof8uX/AC0FmJlnOV/m9rTdVxZS+vE5bkqUR29w v3WyUuMMPVj9pwXibYgrh0kVmSoPRgGsIAOg9OIMFFtOqzR6zyXzlX/yL7pP4W8pfxPKONAS qZslMPpClWvNYMjxZ5DZec3ts6TlKUeFcV6eg9bbuRuxVyDrGSqjtLlxuuGPyXG7e5O79R1b vfl1nM8hVZXHzuyOncxnLrY9UvZLaqt1ekd6cXGSrimVwm7b1LNHPtXHZTd3Gc25aUXHqmW2 D0y1PJGa7u0m9GLIuM7uNx0Xyopm0sjXRnKrVPGrbGpS6S2xad6ahHjxOjvNlasJOFceZOmc Lm4y5OqXANUzUksaFFx8B0TyqHiTWbDxp8yvNgXEXNWy3EuAobqSVGVjomhiGVi3kkSW8SM2 qJfZtxmtTWBMQyse7jNOMuKaPJwpan2lqUXRpnqntoNNrCh5vewUL84rFVr6zlyTpmOnHeuH X8k3ipdtpKMXLXGHKp14NzfZR53yBKe78N/FF+zE9lC0oLAa3ou3dlVqTxkyatpZl0moqrOZ uL8pukS5RscoRzZXdu2LkXbuJSg84s5jhJvtNoHYaxTqE6OV5j5ZHbvxNvLVa+V96P2o5qfF HoaJZoo3PlsNxDxLKUbizXwv7Dntr6x012YHupXqK5i0qV4nQ8uu1TtvhijjThK3LRNOMlwZ dt9y7M1PkZ12xerd6tW4t6ZuK9H1GOaxrzxOhfvQ3C1wzSxXUYrqwquv0Mzt3IpR0dnLVGhz jRtZ6ZU5l0uKm0zHprU3c2qnHGdl6l6M16UdWzJStuUcnijzVjey2blNLVHCUo81x9R2fKtx bu2JwtOqhLD8LxXqyPRlxw0F20/U9BSXbP8AUfUW9kndit/k3Zbd92Wqdr+9H0ZroLLsNcJR 5pr2BubLvRai6TT1QlykvpRktrdV9RnSjb0yjyks0VFWzu+Pt7dzi4pPrWBccry/dWtrbnav TjHROVKvhUq8w8928bM47eeq41RUWCE6rXI87uW796Vy18L0y6zmPFBtpVk7b+Je0isKrkcd u7tr0hRdHU7e3fi29HNU+w4bwZ0dheph6BqbBCaL9zDRcbWUu0UN1MWYd5czJEKExV4MiiC1 KiHCNHUjFuLNdqKaqyjRZks6HQ8q8se5uO9P9Nf8xzuzFVfdWLPRbPz7ZXErdtuNFhFqhN7Z MyXHrfZzt9HTdiBF7aLILf2Hhqp1l0b1ufdkn6TzTm/8k8fgrubZTio1yE9r0mkTZucm3uz4 z2c3eeWvc2blp/FF06+Bg8huSv7XS+9bemSPQ4nA2kFsfNbtn4L68SHXx9pvXl2S6xuduWVD xm4houTi+Emj6KeG87t+HvLq5tS9aNTku1xUxJ2Vtfkt8FE9N5POuxr0tHmcHt2vune/p+Xi bOUFmpGtbJ3a3bWyPFDYo4yXWehwTu94iSu99kACHEBQyYAKQr9pzpKDpcj3X9T6GN8CcswK 7V1XVWlJLCUeTJwzZTetycvFt/qLh8y5P6idi5G7HXH0rk+QVYRlkSIyCLZ8OogSnmRAI94B Q7zGAMs/w4lTyLZYQj1AQIuS1IjO5TBZlU7icKTwo66iWrI1XJxq8SHiQ5nFveZ2Yy0W05yK XvLssoxj1snU6PQwvwg3jmLx7fM86715/EkLXdfxr1DqZj0Xj2+ZO3dhKkE88jy12/etquqq NnlO5nOVy9N9i1By9PAXOMrMV3rk4XVKDeeHpNHl26/cWse9HsyPIW9/ceLaOp5JulC7STwl 2fTwM2Y6Nx34PROnoLpIhejxJweqKZkUTkuPOhFOuosuWq0fTkQhFKLosTfTB6q9Wkyz/Nua eCxl9SNFycYLXLupFVm24Q7Xefal1sbXx1+Nc51qdTBvVDcrw54xzwdMUX37ulUWbMixeOR4 d9vSOsnqlZm9tbcIOil6yqopS1OojFtvdpIdaOpCo6kV5/f2PCuzisq6o+kzWnj1nZ80taox urh2WcRrS+rE7a3MQSVHQu289LI3FqWpFcHRmkeq2V2qTI+d2tUYXlw7LMfl93gdi9b/AHG3 lDjTDrMVJ0ryU1Rm3byrGhluLCpPbSo6Fjda5GaWBraM11FGWVEWWyEq0oO2yDUAVwAD1E4r iytKKyVTtytQlmkUS2uPZyPVGHPSdNVKJY4nHsyc07j+N6jseYqVnbTfGlF6TjRajgslgj08 XrXLdoi1HFkqtceP1fayGjW8ScVV15dr6z0OScIrBt0Sr7cCNvceJJ0fCVF1uhC9c1SilkpR j7Cez2miUJPNyfqWJEbZxpKcF8MI211sz7ncxsppZ09w9zuFFSfFtyORdn4k6PJucfsM/NcZ +SUNy4XZtvJr1NFl647ctXwxkpGBuqjLjKLi+uJruNXIRfzwfrRctY6r7G5jC8mlSlx/8xp2 9+MZWpN9nxJxdTjqelqa+WM/7Jdur7TnCPd1xu+shg3u53ZRtyf5dvXRdTKYNu1GCzuyq+oj 3ZTXS/8AmQWpUcJfJbbNa3BYslcWudxZW1ph15FT7Fu50KMPtJW12LcPmet9SK262k/nuVN5 ZXJ6bsF8kKlEVW3BcZzqW3JfmXpfLHSQgqSsx5JyM5BOX60+b0ImklciuFuFfrM7dbLfzXC2 46SvPlFRGVQtLC0ucmxLFLpulkMLltcIw1FVtdm10zbJVE32Z9Nwd7K91xE3WMv80d7K9+KJ lUp9+a/8a9wW+/Y6mOX6k/8AL+oVrvWOpkFL/wBPLouGh/rz6bf1FD/Qn+Mv/wAd/wCX9RBR /g2vxMvf6m4X3WZ/8C3+NmiS/Ov/AIX7gqp/p2Ot+8sa7e46it/pWX95lrX5u4X3WBW+5YfS /eWNfmbhdEip/pWXyky9r86+vuyApkvybL+8y5r86/8AhZTL/T2nykzS1/7F5c4P3AZ2/wAm z+Jls1W7uF91lT/09p/fZfNfnX191+4Cr4Nv1v3kpf8A0df1kf8ADsfiZOS7W4X0zH6/5RO2 vzbH4TO1/wCvP/MRfbf5m3fRQob/ACJLlcKNDj+fJf8Aj/ulVttRsS5SaL5S/NvPlb+oglWO 3hzbl7SCmWFq8uU17y+cqTutcLaXsK5pO3fksnNe8dyLTur/AMcQLaOKjK3jKEFqg+MXmQag o87E3g+NuX09aJus5R8Ps3oxi4feXL6ZkVJJO7FVtywvW/lfNfUA3r140d6K9F2BFJUjodIt /lSfwS+R9BPSko2pS7L7Vi7y6Pt5EXV6249r/Gt8/vR6QBf2e1//AE7n/wCMh4vBLS26pfLc 5dUiOLa+JtYf+SPL8SGmmvmw9Mor+/EK07XcOxdjdjl3qcafFH0cD1tncW9xBXLTTizxadHW tcVKvPp9OUuku226ns5qdvJVTj8yzRz318vmsuHsdQaiqxehftq7DusswPO6HqDUhUQYAPUg 1IWAYAGpBqQYBgAakGpBgFUAakGpBUKgGpBqCoVANQagqFQDUGoNQagDUGoKjqAtQah1CoC1 BqY6hUA1MNTCoVANT5HE/qPZ+PYV5LtW3j+FnbqKUVNOMsU1RhvTbx2m3s+YyjjRm+1vo3Eo bqrphG6sZL8XzL2rgHmWze0vStS4ZPmuBgpXBZnCzHR9Sybz59m+/tJW6NUcZd2S7sup/VmZ otwf1F8N7Lb24RSUoyrrhLJ/Y+lGm5tY3oeLZq4tatL70ftXSvSjMrycnDdfp6xTC8mu16yx x48DE04MttXWsvVzLjLzLWiLRaqTVV6iDRFZp2qYxBSU8J58y8rnaUsVmERjOVl/SjND0blc pGVScezJVXINOntRdUbm3p6JhNpwaVz4cYSWa+1dB29vuFfWNFL39RyYXlcWmYnCVp1WMfp9 KkuvrOz0cXNdem3Z7LZbrxF4c+8snzNdDx+237hjJuUVjX4o9fNdPrPVbHex3cKqjfQXW+la 5dZ/7NPp9fg0IjudwttDU8X8K5snduxtQc5YJHA3F+W4nrfoXJGrcM8XHeS5v0xVKrk5ydW3 VjAjck44xi5Pkji+kkBRGV+WcIpfixLVq40IqTGRSdcSQQRZt2CtzbhOKbeVTDHMlZm4PUs0 zUuK58mnnrdXbe0svOCD9nZ+RFsJq5FTWTRI9GI+RenRnWysrKKF+wsfKaBjERkflth/D7Rv YWnmvaagGIMj8vtZ0frIvyyy+frNoE8Z7Dh+Z7eO0t1sJyuPJVPOy8wvx/WnKD4aUdzzbe24 X3CUqaUcHzHd2r8YxtrFcTrr46zt1STN+DFPzC+3jdl6wtbybkvEuS0lFuzWSi1i3Q9TG1BJ x0KkUjczfVdsa+jz1zfTUvy7kqdIR8wv8Js9DGzblLS4I4HmNuC3ElBUSoi3M9U1ut6YXW/M NxSrmvST/wB4uRdJewwRhbm0m6LielsWNtbUVFKVUJtfc2kno5sfNpTyZat85SSkvSbLqt20 tVuLrxocjzXb2bVLtpuLbxjwLtczGU1knXGHTm061OVuN5N3KQeWfSKzc3MbTnKLVvJSlz6D GqxUrsvQcMe7ra6e28zpKldEl6YvoNF3a2NxBqH5UpPVh3a9X2HBgqLHiXba9Kw1JvsNqsTN mOx3dTZ2bljXYvLCS1RaxTpyOFcsu3clb+VnobO7Wp2spJuqeXoIbjZWtxLXB6LmTjLuv7CT aYwmOrhRtVZNx04s23bErL0zWl+x9TMl/Ki4h2kkmWZRqutjUask1TDkTgtKq82ViRVNUwHC OIN1fUXWbdVVg9VcopNrmdDynzSWyn4VyrtOtUuDMlyOJnlmmWM7R7n+nlWOrhKc5D3Fy7eu SjaemKbTkYfJt/K3Yg4Rrp7LLru5lN0cWo50pmdZfVwsWwcktFpuT+Kci6FqNvHN8WzOt6oq ijQrnu9XQPJjFX3r6WCMjk2RcoviNaeZZYYrVY7PGhov7lS70qtHMmpPJ4FTtTL0TDct0sTP duquBR4MyPhz4oGFjuUHaam+06IpcZciLUlwZVTnco6J1RFXpRyIaWxaXUIm7lXU6GwmpJ2+ eJywVyUH2XiS9Vw27rdOvhW+88GcvzPay28oOXxxr6jueW7Gj8SeMmP+p9v/AOrburOE6Pqk jG/bDekxXA8qveBvLM+GtRfVLA9/LB0Pmjk49pZrH1H0Sd9Stq7wlFS9aOWjpsweY7nT2UZN vd7Gp4tFFyfi3HJ8CVh0bjzOjMaHuFfWlKj6RrAyu1pq64miEqpMMWKr8eKIWJ6ZaXkzS0mn XEwdQWNF7bW90vDurFZSWaOFvNnPaT0zxi+7JcTu68plfmNn9xYbj3o9uP1mdtZY1my/BxoS haurw3qi8Cco0k7b6UZIJ3HSCrLgka7stUYXV6etHCuzMOEqNMldVJYZPErREdiEk1GTyyfU yNhX/LruuKpGWC5Po9JVtJao6Tbe3FbMYUxfHqPRnMyxO/i6+18xsbq34iko070ZPIqf9RbT aSdG7jp8CPM3bWn8yGKl3o+8os7eN6elS0rkbll6bM+PXo6W4/qbcz/SjG2vWyu3GW9tSlK5 LxJ5utFrX2olDaWrWSq+bLKqK5Ibbezc0kc67tZQtVuLLHDExywidS7C7pk1KturjJL7ywfU cuSwN8fWVnZSpOMlJZpmq/hPUspYmRo0112U+MXQ479252VywLbEqSpzK3iqkYujqYHdvfm2 Fc4x9zMTNuykricHlJU9Zio4txlmnRmtvdrjvTx9kXUiyxsqnpiqyZh0pqTRP92o4P2GCdxy dI4IlbjTE76cXl3cduTHZrvbp3I6VgjFrJSlhQe1tq7dUXkd7jWY1cpna5q+zv71tU1Nrkzd a8zbzdGcvcbd2JU+F5Mqqcbx6b9brGs2er1FrzW7bVYywOlsvMtxcj4jo6/CzxEbko5M6e08 3uWEoySlH1M5bfja9+PWZd+HfWW/d6+z3FjzGFx6ZrTL2GD+oYO0rO9hnZmq/hkc3bbuG77m a+F5m2/unc209tcWpTi4xZ59tNtdsY6+ztycWvj9zjv8W3debRjFeDjKSrXkeW8znKd7XN1b SNvlVxXtulLvR7LMfmcdM4dKZ2nHNevr7vF5ZpRf5TpyZZ5X5pLy+07iWqPZ1R+wrsKtvHBU Zn2Ft34O0s2nQxjNxXSvabfdWPM7fi7d48Vx9JG2vzEnmeHtXb3l93xbL0zj3o8z2/l29teZ xjuLeElhOPI1rbpfG/Tf+GLM9Ylc776yJKb7T6yB6HIRyAI90AFxRN5kEu0iTzARS4Stt3re L+OHzLn1ouHbwiARnGcVODrF5CfAomnt27scYPvx5feX1lyepxaxTyYFs8yI55kWAQzYxQ4g ApZFl6WiMW+RVN0RTvrynpjHkBW54OT4nB8z3spPwoPM6m8ueHGi4I5HlO3jvNxO5c7kFUnx VpVuFi0rcVjnKRTK5CHSxpu/LTHidGztIW1iqsjLl+O+EQ8afynZjtbcouVMai/bW+QwZjjy vSSxVTfb/K8vbpR350p92JpdiCWRs3FtQULVMIR9rFnosvevNzShFuho2WMarPMn5w4wtxil jJ+4jseykcuS4ejinlHsbN393YU4ujfvRO1N6mpZvkcfyvdrb3Xt592XaizrXezKozmM2Yq9 qpTPsLDiWa+KyZG7SSpxNxm3owbjTduQtRy78/Rl62XXGlGpm2/ac7vzPSuqI95c0wS5nPk2 634JrGC7c1SbISdI04vEUVrko88+oLjTdYvBt0XJcDx9+rqjUBAQMYgCo3bfjQlb5r2nm7io 031M9MnQ4nmFnRdkllNal9Os3peuEZYZU5FclTAnB4rpC5Hidhr2d2jTPS7S5U8jYlR0PQ7G 7VIxWa53mFjwr04cHivSYbb0s7/nNqqheX4WcCaoyN95l0ouqKrqFYnWJOWKNDDOqyIQZbdi UrBkGuvZqBVXsgB9LAAPSw5Xnzptqc5R+36jg2+nJna8/l+Xbhxc6+pM41peJKMUs2kevi+l x37rYttUXGvu/iSvXPDtyiuVX6MCUp6apZybMybudKcJe87ObTtrHiXpU+ZNf2TVfvQtNQhw 7NevMyLcOw2o8Tm3tzKSryUJ/aSmMpbi9K4mucZU9DM0nXU1xUbi61mNvS6/JKv8sgjHS1Hl Jw9EjGcukhXHTVTg43F6cy+N5RtL7k/ZILMFcStyzlCUV1oNts5XYTTdH4eXSioqhg9L4SlD 0SIqstKfxRlB9aJXVKDlqVJaYS9QpPS2+U1L+0FRctVZfNBP0xJJVcYripR+sVKNLlKcPWRi 2pRfJRl9RBZbeqVvk4Nekri/ybf42Sj2HF/LccfQyGVtL5bhqVE7jwv9a95NfrR6LdfYV3f8 frXvJv8AV/8A1/UXKKo/pWlzmx3XVX395L2ih3LP4mE32LvTNe8CbwuT6Lf1Ctd6wuhsc8Lk /wDL+oVvv2fwsmVVxxtx6bg7rrG8/vJe0Vt/l2/8wdzuXvxoCyf6k/8AL+ojDPb+knJfm3P8 v6iMMHt/SZVU1+Tc6Jo0f/R/+v6ih/pXfxo0L/UL/L+oDN/gQ/GaWvz7v4H7jN/88fxmp/6i 5+B+4DO/0LT+8y6X6178L9xS/wDTW/xs0P8A1F38D9wGeX6Fr8TNP/0XvwP3GZ/6e3+Nmr/6 bn4H/wBIGZ/6aD++zVT/ANq4vuf3TK/9LH8f1Gv/AOqX4P7oqM3/AM1v8bNM1/7F38H1Gb/5 Y/j+o1S/1Nz8H90DP/g2X95lk+9uer6yv/As/jZdc7+56gCCTnt10fWVSinavP76p6y2339v 1fWVP9CfTcQ/X/InKLd1r57X1EbU8dvLriaMP3D+7b/ulCjS1Zpm5sCv/BcXxu0Zfekv/Ykv uwK78aRvU+Gal7SV5Vd5cKQn7gJaW6WbjpLvWbiy6q8vcySlKTdyKpejhdh865/b6yFIxioS dbE+5PjCX0zJ0nOShJ6dxDuS+dfTIoj2IxqsdvN+m3L6etEqT1KNfzoY25cJx+n2CU1SV2Mc HhftfWvpgxOKSVty7Dxs3PlfJ/WAnoa8RL8uT/Mgs4S5r6dAO3JS0vGT7Sa+PlJcpe8nqlVz a/Mjhet/NHmvp0iUVRW69mXasT5P5WQQTrisnl18VTp4r0onF1zG5pt3JrB9m/Hk+EgcdNdX eg+10xeUvtKOz5DdalcsPKmuP1ncPLbDdLaXtUlh3JfT2nqNSeKxTyZ5uSYufd01vQwFUDm0 B0EADEAVAYEdceYvFhzAmBB3YLiJ34LiBZQKFX7m3zEt1beTJmC6gFP7mBF7uCGZ7jRQDK97 AP3sSeU9xrAxvfLkRe+wwQ8p7jcBz/375C/fyeSJ56+46IHPe9nyIre3eSHnqOkBzf3d3kP9 zd5Dz1HRA5q3V1vIHfvcCeeop/qDZfuLPjRXbt59Mf4ZniauEq8j3fi3ng8sjynmmxe2uYd1 4x+wzttNuz3fjb/2X9mLeU8TDJqvrL9xdlatWZQbjJNtNZmGTbeJo3kvy7K6GzPs9luZtXUk re5inOkLjjqbyhLr+V9OXMw39vOzJqSaa4D3E6W3H/xx9rNXl0/Fsq3e7UY935o9XR0ZGfRx 5eCbX+HszWpqTo3SXB/T3F7fCeD58GR3Wxlb7Sxi8pLL+D6PUU29xp7NzGOXSi93hut1uKuc aEaFlKLVHtQ9q+33hpTVViiMqJQUsylxdtmpoi0UZ88Vgy21fccHkQnbpjEjqrn6yy4Zw1O3 Xt2niX7Le/t5qcezNPFZRl18n7GYITlbZp7N9cpG+l7d29N7p8noN3upbhpyWmK4GJ3m8LcW +l4IwWN3PbtQurVDh0dX2HT1K5FSi6xfE53Oer6XFvpZJr/RCSuNYTUX+Go7cZxrrnq9FDds 91GxVTinF5viaYKE5qMrGnVlX6YGtdPL1Xbkutudenv0c0Edd+X2/kf9sP2FpqjttdKlia+3 fg5f7Gnx/wCP/lyEgRq3W0lt+0u1B8eXWZVkc7LO7vrtNp5a9YXSKGDkiSFFY16CNN+x3Stp wnlwNct9bXM4rlTFczZrqk+Zqb2TDwfkceL5z17ty3tt8w/eW+Zh1N5MKviX7lePDo/uYcw/ cw5nO9RFpZl+58DDpfuocw/dQzOYkmJwWXAfc+CYrz3mN93bs20sXmc2Vp8C7dt27slXJmXx jvN8tzWJwjOElJYtOp0P92v8Yo5njsfjMvkvjl1P93u/Ijm3ZTuSc2sZOpHxmNXx5E0whom+ BO3ri+y2pdBq2di9vp6LSol3pPJHpdn5dY2SrBap8ZyzN665Tayd3L2nlW5uqt+bhDk8WdOz 5btbD1KOuXzTdTW3XMiztNZHG21x/PrzmoWsl3mcG+tVILrZ1PObmq61XJJdSOXKacqtdS+0 4bXNbkxBKNXRFy27ksh2LbuYs3qiVEc666xzt3FxlGfGUV61gdTxXO1C4scKOvQY93HXa6Yv V6Hg/qLPLp67crb4YmZOuPdnbpctVvcKS8OaUov4ZfUZ73lUbr1bZ0kv8Kf91/b6zmz3Eoyc WsU6eovtb+UaKWKXrQ6xvH+LNKxKEtFxOMq5MslZ1qiO1Dc293HTNKaXB95dRmvbGVHLbPWv leEv4jussnSudHaQTxLlFJGSc51o8GuDIq5NlwZi/Q5y6kZJZ0NVq84vHIr3MaSqsmIzXY/p ndaZT28u7PFdZ193LcbT8yC8W1x+aP2nktlcdm7GazTR7xSaPRp1jz798uD/AL1xcMBx85sy 70S/f+WQbd23gn3oowx8q1YpMtkjMaP9028s4j/d7SSrQyR8vt51ZZ+yjzJiF+C9XNrLJ0JO NmtFN+szfsIviL/b48GTEM1rVlSxhcyDwrnCSZlWxplJoFs5xxjNjEMtMoTh34+plcZ2rmCm 4vpIO1uG66yqW2vJpVTrwJeky1rPK+OOtb3s7yxjJNEHZvrNRZDbWbidZTbS4Hct7TXBT1VT MzaVvfh20+qOHK3dpTQqi2myerVc4Hols4rMktvBcDWXPCvbqKK/O7SvbC9FZqOtfy4mvwor gKVpXIytvKUXH1ozVfOFij23k81udjbUlWkXD+yeJScey81h6j1H9NXNVi5DjCdfRJHLXpcN 7dmZRduThLNFkHS5ToOlvtmr3bWDMUNhKMk65HViIzZZbppRJ7eVajVmQKcKVxME46W1wNjs yKpbSbdUEkZ4vChp29yuBWtpcXASsXYvINd44u5tS2m4ejCj1w6jobzTdtq9FJKeL6xeZ7eT grrzjg+pmfbXHKzKw+Haic7MyxuelZpqsE+MXQqZogqvTwkjOca00bSemVOZ0ZrVCS5dtfWc eEtLqdm1NPTJ5ZPqZ147mYY26XKiEdL0vj2kZtxtq9u3nyNG4uKw9MnimQdzXc8JUgn8cskj bSmPmE4wcWqyWRz7u4nefbeHI2StKfddZdBlna1Z4S95ZcI0bfePb26ZqWHoM96UYSaWKzRX TsaXmmarezubiK8ONVTFvBI3LIlmWRLUql23eLg8pKhrt+T3I9+cIr1lN2zZstaJuclxSojG 9lnxa16d2aPGLFGMpukVV9BZKUXJySzNOw2tzdXNFvsrOUlwOSrdk5wk7ck1KLo0XeYQcbni JOklV9Z6C1YhYWmC6282TdHg8UdPTDMuLl4y5e0mSTcnVnovM/JozTvbZUksZQ59R56qyZvT WG21pItToivAWqp3lw52ZNupu8tt4ufLAwHe20Y+DDRxXtMbdmte43Fjx7bjxzRw6cz1Vi1V nA8wsq1fnFZPtImjWzIixEYKtWTtdpvoO+rlV9puLUoujXFHZ227dxrV3l7TjW8TVB0aazOm 3HN58fSs+dn8c9L6N+1krG9nb+G6tcSHnsdEYXOUiG8dI291HOEqS6mafOfzNo5rnGR4bMZl a9ZWTa422+so8pnpux6yzy+TlbpwMeylpmnyZ553d72dzzLZ+IvFgu0s+lHH2e8ueWX1uLXd ffjzR6ds4Hmm2VmTml2JexnbaZjhrcdHrVchfhHcWnWE8RM8z/TPmXhXHs7r/Ln3ehnp7kXB uLM6Wz+G3edvjGtp6wl3QHwRE6sHDGQ3mO1jL0EQAlHukXkS+FAKpnjTbTX/AGm/7L+wvYQS ckniuIEpZiKE/Al4cu432Hy6H9RcwHDJgEO76Sm9ubdhVuSSAldlSJl2yhcvrxHSKVR3L6ux Uo5MptYRlLngRY5vmt+kZNfSph2N/wAKxKEO9N4h5pcq0ub9wvL7ac46nRFo6Fm7b2kay7zC fmtV2I4kd/ZcrmqFGqGCLbwSxJGcZ6ti80vpaaKho23mbnJQuKleJgdq4km45lcm4NVVGUxH qbNvxLsY9OI7s9c3Lmx7R0tSvP4Y0XWyvLPJE9Wb2cDzq8nfUOEI+1maHmFyHdSouZmv3nfu yuP4m2QeBx2617dP46yO8tyt3Y8a2qXbFJSjzi82uj3Hqtpf/d2I3Fi+J4Lym/4G5hJ92XYm ucZYM9T/AE9d/b3bmxm+6+z0rh7CYxcM7ZvV37XyvNEN1SFudx8ExSuaZ9RX5j2rcba+OcY+ jM3O7nezNZpZlb286rVDCVMNXFMzb6alcUFX5fSdStKs8zcsfnyvKcqOWrTyfQcNrMfyWNt3 bXNq34nFUi17TOW3r87ihKcqvFlKlSvScNsZ/j2bhgmRqFTIlUKkQqFSMXmVvVaVxZwfsZrq DippweTVCzojzbVG/WW95dZXOLhWMs4vSyUMqcUdxVF6XU7Gxu0dDk3Fj1mra3KUJUelvQ/c becONKr0HmLmSZ6bZ3KpHC3tnwrs4cK1XUZXX1imw+RoqYoYM2RbpiVVNxVM0oNGy4ZJigq6 AKqoBB9L/cQyTq/u4+4rluklWlFXTWTSx9pi8TcYubUZNyUIruwis5vn0VMtjfK7d8CHZtNO Ntv5s9T62e3xc1XnNyUr0VKi0xbS63/A59i54b1cUnQs3t+d+5KV1JTSUGlwoZli+g9Wkxq4 7d10cafiS9ZK1+XBOXCsV6ymw/EdV9x+piv3caJ4Jr1M3lnCF7cVepcNDfUyhLS0nlFuD/DL IUVVqLWeq1L6hPGOObiv+VmO7ZpVSi+KlbfWsgbbWpZuMZf2TZZ23b1XFh4i9qL7e3saVqjW kLmTZcJlkgm5JRwammn0SL4bh7ZXm8ZODijS9rt6aquEfy4vrzORJqSuuLentUryqX4J3O42 9VXV+EiM8VPoUBzXe/ykKfx//rCpTwlJ8pxIpY0XKcQuYuXTcRKv5n/7JL2EqozlVSfNQuCu /wCJ0SjMjCNYpc4zj6ht6lJ/NbT9RBK7le6XFk5fqy/y/qK7mKn0wiyb/Vl/lfUVELeVjrfv Iy/SufjJW1+h6feRf6U/8wosufqXHyt/UFvCVr8Egn3734Ah3rX4JEFcF+Xa6ZsLncvfjQ7W PgLpZGWNqb53ALpfq3Oi39RCOe39PvJz/UvfgFDvbddfvIquWNq7+Ne8vX+oj/l/UUP9G7+N Ghf6mP8Al/UQZf8A5o/j+o1v/Uz/AAf3TKl/6y/H9Rr/APpn+D+6Bla/9aH42aX/AKm5+B/9 Jma/9aH4zV/9U/wf3QMz/wBND8bNS/1Uvwf3TL/8sfx/Ua//AKnT5P7pRl/+Vfj+o1pf+31w /umT/wCX+f6jWv8AVL8H90Iyr/SL/M+o1SX/ALM/8v8AumVf6X+f6jZL/Uv/AC/7ooy//Pa/ Gy6539z1FK/09v8AGy+4vzNx+H7AC2+3t+r6yh/6eX+Yi2GD276/eVzVLNxcriKL5ypdvf5f 1IVvF7aPDF+0J/q3em39QWlR7Z/i95BXN1tXHxlNe8unFu7dUFVqEVTPkZkvy103KGpKU7t5 QdJ1SjjxXICClFJzSrZlhdt/K+a+r1BKCSjanLsvGzd+p/TAkpuVb9tdpYXrfPp+3kR7EY0f a28/XCX09ZUOs5ybpTcQ70fnX09ZGsFFySbsSfbjxty5/Z6hyi21auSpNY2bvCS5N/Sg4uUp OcY0vRwu23lNc/t9aClSSlGDl+YsbN3hJcn9OgXZ0yens/41vjB/NEVIRhxlt5P+a3L6essp PUotrxkvy58LkeT+nQBHtalipTa7L4XYcvxCjjTTisVDVxXGEunkHY0uqat17ceNqXNdA5Rd WpdqVKyS/wASPzx+8gBOuWKpTp7P1x480dXy/fTjHwa4Lu9XI5Tdca1rjVfFT4l95fEuJKE5 ReqOeeGX/B+x4GNtfKWK9BLd3KYYEXurj4mWxejfVXhJZotelZHzdrvrfHbu6Tqm70/meItc 695kNSZCUqqizM5vuLlKfzMacmu8zNSVcWNJ8GM33F2njUXUyCwBtLIipKTqHSQTrkWqlcSC NUgqNxiwcYdIXArhkKtckPTyJRty4AwrfKhJTayRJqeTBxpgwYS1trIKyQJLiPDmFwFVi0yq L0kdT5gwsduTzYaGuJDUs6kXKoOi7HiyNGsalequAakDonWXMj23xBzWQRmnhQGIi1LjIq3G 3W4g7c31PpL9UXmmKq4DJLi5jx24syszcJqjRTek5NLkqHqfMtktzb1RXbivWjy040kjpLl9 HXfz1z6+q7dSrOi4Rijf5bKioct4yZv2c6SoS9np0udsu5beFODzTyZzr21t3pyhawuR+Dj/ AC8/w58qm60zmb7s7mq4pMyb8U3vjf6s8Jz27wy5cGaYSjd7Vp0l8UX9PadG7YhulWeE38XP 8X25nIvba5t5cU+FPqfFfRlfN5OK6fJoVJ4ZSXBkHEVu/G9SNzsy4S+mXuLHWOFz0SK4qmiu dpSywZocaEGgMlXHCSJJ0xRdKKlgyiUXB9ARpjeU1puY9JKErm1eq26x4r7ftMidS63eccM1 y+w3mXpt/Ulutzq7FjcQ3EawwfGPH+J6W1dk7UJTwTjWTPDu3X8yy6Ncvpgbtv5h4v5V56ZL n3X9nuLP4d3p8pzya7XxsduPmkqdqNX0SoTh5okqOD9DOZlgxmfOvVeHjvo6lzzK002oybap R5HLSoqAwJdre7Wmk0+n1CBDRF8DLZPJl1qS045lTxqOy8aEY5dfLjs/dcnHMPGXFEnGnFEa UzI+STurggUq4ktDp0CUAhqXQNNi0OvEloCvM/1DtnanG/H48Gjha5Hrf6hsN7ZT+SSZ5CTq erjudUqWqQa3yIqTRPWjog8R8jRstvc3t1Wbaxeb5LmOG0u3Ia4xrF9J67yjYLY2cV+ZPGb+ o1rJtTOGnbba3tLas2lgs3zZYSItpHpnRi3IEgbqJqsZPgk2xkeQ315Xbs7nw1ekwq5jqaqa dxZcnLQ8Cm1axxPJbl2xh1dtJeGmk6sUrrjFtqj4Yl8cIpEJJNY4mHRjhKTuJXMpdh/zYfxF sJ+FeUZYfDIju1Jy5IW4f5iur40p+nj7UzN6YrG0HmdpW72p/Gq+lYMyOSXE6vmcVfsRur4a P14P20OQoceB0qa3o02W33c1xNq8wnaf5q1fejhL+Jls29HvYXo644Zo52dXXGY67nY38PzP zIrKccJx+nTgc/ceV3LSc7L8WHDT3kumP2HOjW1LXFuLWTidLbeaaGvEwfzw+tF6z4uePZz4 XIywHLFJYnevWdv5gtVyinwvWuP4l9GY5eX3LDUpUlbXxxy9K4Gs5GDZxUtxbgsayR7ip5Dy ey3u4yWUG3U9bU9HF2cN1idTNuL89tjBVXMsUic464uPNG9pliOXcuu46tUFUprzGmc8KtUi VSmpJMC5SVBVIVLY2ZyVUiAT4mN3LkpOdv0Fu4k0vD4sVneW7MZQUcZR048Djy7XGNZl7/xO Of8As2+WpbO7KN1a8K51O9ubb2soztPsyPMJO5OLdaLidyzf1WFCXDI5vbtrb1769r8XUsbi N5cpci1o4cb2h6ovI61ndRvQ1ceJ012y+fz8Ph/KfTf+FrEnR1IO6iLuo08rw3mVnwd5dt5L XX0SxOn5BSxurllSUtUK9nnFlH9RxS3auL44RfpWBk8pu+DvLUuDel/zHPts331e0bFUi5oi 5o6uabaIOaTo3iQnLkZL240usrbVOIV0KmPdeZ2Ntg3ql8sTkb3zSd1eHaemPFrNnLyVTF2x 2dddM9a7MvP7lezajTpZda/qCzL9S24voxR55yoRa1YmPKul01eyt3bG9jKMGmmqNcV6Dybc ttuGp5wlpl1f8BR122mm4y58TY4rcS8XcYyapyr1mvJjwwp3VnwLkoLFJqUX0PFGa8qSqspd o231Fyjpypp9Rkmqw6YunoZyp2UHS2ktUNPoOczTs56Z05l0uKm0zGjeRt61cuptTg4rTwnH +BVtWmlJrVKPZa6DTu4O5t5qOcKXI+jP2HBjflGul01LE62dWdb0daM7evXSjWVMxbm7bvw0 NUxrVZnOtylzJ4vic7l1mPY/AtrFVfWWrcuHZhguRnoAyqdy/KeFSFqzK66RpgKgLDIzkFy2 7bcXmj1fle0/a2En35dqR5/y+x+43EIPKuqXoPWt41OmvuxsTABdZtkZM89515coS/dW12Zd 9cnz9J6FkZRjci4TVYyVGiy4uUrwsscEGmhp3W1e0uytS4ZPmuBTQ9MmerBPBHY8mWu2+hnF eLO3/T+NydvoUjO0y1Oju24aI1PPeaw1ONzpaPQbqeiNEc3fWl+ylN5qUaGZ9Ui3ta863pjQ nZwg3zKZurLZdmKR2l6/Jzvb5rrD7DfSabbwTMtrC2ukvsvsLrPRrekc9nc8v2EfMLd205Ud MPSZrcL1/YXYUq7ScZrk4/8AA3/03P8APa5w9zLZRW08xvWZYW91bcl+LJnzPydrry7Y9Z0d tJLrHA8sxtmGy6S9Ju8qX5dONaGFJxuSTzTZw9Xa9norm7nGlIN4Ijb31m5GUNzBpNNG3aeU /vNvC6puLayKrv8ATu4+G5U397Xta4+FeOhJ2pqS+Fn0CO68faeKqa4LE85e/pjcpt5mJ2N3 s7sbcozz7qrSSM3fXazx2mY3i4ey0XGl21WhStzpvft59+lVQwuG6vVfgzVV2TmWdnvXuVea aksG5cjvOTTbprZb8HKa7evZ6yznJ9BFE9sqKVc6ETQi8iyWEV1Fcsi25hTqCKyVrvkSVnvv qFEZxU04yVUymEnbfhXHX5Jc+jrLyFy2rkXGX/ACyOEDyu8tXL+6UJp0bw6j0tq46K1cwmsn 8y5/aK7GLo2sVkM4XDFdShFRWSGo0io+kV1Nsn8XUZjVeV8xr4iT4VK4XFTE9bc2tq9+pFMp fk21l8Jpl5xTSyY1JcGegfkW1fB+sX/8Pbd5N+sGHE8edKanRClJyxk6nbf9OWXlOXrIv+mY vBXGMwwnLdfsvL7PiYyutz9CyOZf86lctyio0qqVO55n5M95OEYz0xtRUIo8vv8Aa/s7727e rTRv0mM4mfVqay7Ftdhcv0pSK5yDd7K9tWldWDyksiS312OEKJGuz5i7sXY3XatzVK8Yvg/Q cJ5Zy9dxjDl23omnyaZ2/Mb0rW5/c2W9UaKWGXy48dSOG8Hia4eaSlZnZvVakopNfcyqas9X P08Xttrv4b+CuRwkl2ol1yWu5aT+HXL1Kn1nj/K9w4SVHR5fYet2t5X1X4uKLc/VPVx+Ce4l ptyZwpM7W/7NpdZybEFcvQg8nJVPPv12kahXlSWl/Ckist3NPGuUy1SKTntMXDUMBAQMQAQM KiFUDl+ZWtN3XwmvajFB0Z2N/b8Sy2s49pfWcd515nbW5gncjh1CsukqEoOuDKsYvqND0Owu 1Dze3jC6uK0sxbO5Ro7F+KvbeSaq0tS60Z+CTpXmZLTI0WpFV1ZSC3KgjVaJmWUamt4ozyVG UZ6AT0vVQDI9r51JxhFxVI3MJvjhlHqZxX14nUsze/292zL9SviR+nsMKtTXbSrFY6o4r1nu cao3V13rjuNUk1GvS6Zme46RpzxL90pKfazkq+spa1SVckenXtHO91q02rf3m16qmN9tU+aL j6Ykr09bb5qv9lk4W3OXZy1J/wBpF7kVwi7kuzm9EvTkdG1towi3nLTJ/wDMOzZhCCjF0l2M /WXxklGnGkF65GsJanbS1KuP5mPoiEYJRTX/AG5f80iSfaT+9cb9CMO53GiEbUc2rcX1ZhlT ur6nNW4dxXKV50Rhj+lc6v7xOGcf8yRXH9O5XivrDSybxl/lxHJVbXOcV6kRud6X+XEmu/H8 b9iIqFa6em6xxz//AGsVvHwumcmFvHT/AJjALecH9+ZG2qqPSpxJQf6fTKbFa/wlzcyYUN1S 6bXuJLGfXa+ojDux/BNEoYyi+dpkCtZ2PSVv9F/5hZZzsekr/wAF/wCYVFs+/e/COPftL7jF c71/qQ4/qWvwMiobfOz/ADFePgr71wssLGz/ADEY4wtr/wAjKLJ9+/1UHDv7fq+sUsXuH9Mx wwnY6iCv/Bu/jXvNEf8AUx/AvcZ/8C7+Ne80R/1EP8te4gzf/Mvx/Ual/qZfg/umX/5v5zWl /wC112/7ooyf/NH8f1Gtf6qX4P7pk/8AmX4/qNf/ANMvwf3QMv8A8q/H9Rr/APq/k/umX/5V +P6jXHHdfyf3RRlX+kf417jVH/VQ/AvcZo/6R/jXuNUV/wC1D8C9xUZV/pH+NGuS/wDZ67f9 0yr/AEsv8xe41f8A0x/y/wC6BmX+nt/5jL7i/M3H4fsM6/00XyuF9x9u+ucU/cUEFWW2+nEq kq2bv40XW8bm3/D9ZT/88nzuL6yfr/kXSjW81ztY/wBkhYk//Wk8qyRdL9a4/lt0/wCUrtrs 7dfek/aBVB0hGuSvYjWm5duQk9M3JuEuFen7Qkvyptf95ULLih4tyNxdiUu/8r+maKiSc7kt S7O5h3l86+33kFJJO9aVYPC7a5fw5PgScXJqzdem9H9O5wkuCr7mCc5Tc4rRuI96Pz/TiuIE WowhR1nt5PCXxQl9PWE61jG5Kk/8K8spLk/pgO3JJO9ZXZf6tp/TL3DpCEKpa9tJ4x4wf1Pp 4gJSk5OUY0uU/NtcJrmvp0oXYUOMtvJ5/Fbl9PWOdtQUYzk3bf6V5Zx6H9a9QmpxnSVFca/k ur7ekKnSetJteMl2ZfDdjy6yHZ0pqqtp/wA1mf8A+JHs6XB18NPGPx2pfXEtUpSlXB3afy3o fb9MwIvCqlhR6pKPB8Jx6OY6Y40rxpljxX3ZexijppFxdIV/Lm/gl8sugGtNcNOl0lH5K/3J ewC21NwmprhmjrS0cDiY5cfp9OnM6lqSnBS5YUPJ+Tr0mzetTrEipr1DlHGrISXI8TSzGROM aspVXgSyVQqbt1zH4aWCyCOCwJpqWHIi9FUrTWKEotF6rxyIywWYMK1GXBhSXF1LKxCsa9CB hGuI4yo8cieqGYqwfEKi7jyB3FzB6SKRE6m5pEfFjWg3F8SPh0dWDNPxEsyeuL4UE4J5LEHB t5VC5pSzyJegThPihY0q82DJ9qPATcskgcpAm3ixlMwKuFRYktb4cAUniF6FRrjQKOmJLtNK glVOjdQhKEm88Dy27tUm3yZ62lDze/jS7NdJvV7Pxu+0c6mLZdYlSRWwg6M0906O/YdUYfNF S5CXNUNW2dUU+bLsQlydDEdtu+W3by1QT6DPvbzsSjVarcu9F81xXJ9I9hPVbQvM4arOr5Wm GdpLcXsy39mnDxrWMH61+L7ciq1uHb7FxVjy4o6HllysKLgPc7KNzuJKXLh6OXuLK8XL+Pi3 w/ozqKpqtvVD6fShGieKMy8TbSqsOaf1mu3ON/u4TWcfpmV4rMK2iDRe01mQcQjLO1TGJFS5 mlornbUsVgwhQuOLr7ftND0X8HhL6esxVcXRk4vlly+w3NvT0TDdY3c9vS3e7UOD5dX2HTjJ SSlF1i8mjjQvKa0zxT4koO5tXrtusHnH6e8l19dez1cX5Fn8d3YGUWNxC+qwzWcXmvtRcnUw 98sszDITdPWTK7uXpCzunHEisJBBiuZkXHXCEvMLik4q08CD8wvvK06HTt0lFMmkkq1Lmez4 u+uNrPi4lzzXcxw0UM7823Fc0j0crcXnTEpntrUlSUUzU21/xYxXnv8AddzH4kVy8y3Lx1Ho VsrPyKhF+VWJfCa89fYxXmNxu71+DhOTafA5rtSPavyjbvBoon5Nab7JqcmsMV5DRJEXF8T1 z8ijXPAla8itwuRnJ1inWhvXebXxh1ZfJPL7k9N67WNuPcg/i/gejbpiyMp0xZncnNnqmNZh nGVzuCSbCNvmWW0pz0Lrb5F+NXt2Fu25uiL99Y8LZXks9DNllQj3MaFO+k7ltwisJVTqcttr bidiPBWY1tumdSM7WmVVlmabtmW18S284uvoKtsnKEpPu1wOE6V6tuvVptSrFE8GU2K1dS1l SKpW1JYma/bStYfBL2S/ivabnkVadeq386cfTmvaiXstmYezav2JWpdK9ZhhCEHSeMi3y25S 5p+ZULL+izem5KrlSS9OftL31cdOm1iGlUrHIikTV2Eo0isuZF3KZEejPRTdhCtMmV/tW8al ty5C7Fqna5kbdxrBlZmE9vadqWqMmn0HVs7txz7L58H1mGEidakTaOlY8K3N3IxUXLNxyZ0Y yUlVM5XlChOzKElWkjU7E7T1WnVfKejW7az/ACjzbSW+1aky6LqjDb3MZdmXZl05M1QZ0m02 nRiyzucvCTpKibE7Nh5UM3me3letJ21WcXl0HI8HdRztv0Ml2wz4u89raeVBrYRlkef17iOc Jokt7fhxmvQTy+B4/F3peWx5sT2Dhiptek4n+6Xl8T9KN2zv7i/2rjpAZhit9jyX9xW5ObVf cR3H9P6auE6/iRrs7ucFpWRLxpywbOXj1y9M599ZNdb0jhw2F+vh1WDOpa8rvpPU02abNqkt UczpqqXaMbayOs/J5Mejz/8Atm4csl6zXa2FzbJybTXJG793GuTIz3ltxadSeOLlN/yNt9fH bGGSTIA3UidHkcX+o7dY2rnJuL9J56M3Bqazi1L1Hq/O4a9pJ/K4yPJtVOW/fLpr2e5ctXaW Tx9ZBszbC8rm2tSfy09WBc7qOmWMG5HH803zm/Bg8F3jVvt34Nuq70sEefrXElrppr6pojN0 CtEQT1M593bOCrVVJwloxzZHPHhwDrM1U+03qZKVx8WU1eaAlqWpa3WvI0SitdOE0Y5SNKlq sxnxg6EYrOOEtLT5Fl+NJ1WUsSrIiO3amsJPLJ9TOHdtKzOVt5xbR09pPVDTywM/mcO3C786 o/xR/gei3OuWNem2GKoVEBxy6gAAigBAB3PILWNy6/wo7Zg8nt+HtYvjJuRtk6YnednO9w3y M9y7CF6FudFrUmm8atcC9ZY5kXGMmm0m1l0FQ9NO7gOtRMSYHO862vi2fGj3ref4f4Hm2z2+ DweKeDPL7uwts5wcUqOkXzqdtNunizY50UdryJad1/IzlW4nV8nwvylygzvjGtrGerp7meqd CjzmXhbKMOM5L2E4/mXKc2Zf6kn3ILhU4698um3bDgQjqkSuuroEOyiMe1M6emPdj1aZdmCX QW2cLa6zPflwNEMLcUd53+Tnezr+Q3/D3cVwfZ9Z2f6ls0tW90s7Usfwywf1HlNrd8O/GXJp n0HdWI7qzOzLKcWvWfO/N/jtpv8Aro68fax4na2/CncistVV1M5jwuSX3mdTa1p2u9FaJdcX Q5l5Uuy6zhe7t6R7j+nbmrZpfLKSOlC9C5XS06HD/pedbVyPJpnVt7C1buu9GuputK4Hl374 RqKN1FUjcpjCSf1GgjOOuLi+JjEVMz7ixrWqPeLxnTXbFzEw51juzKzbdgoRk1xMZ9DTbynk 47TFwhIvv5pdBS+HWX7jvehG0Uk7OcuogTs/E+gUQE8hik8Ag3EFO3HhJYxfJmaN/wARUmqS XeRrvyUYpPkYL0ddHHvLJ/Uc9r0b1RpWZOOLqVW5623k1mi2JrXsVaiSIokjTKSJIhlmRluL cO9JIlsir0XWVWXQsTlT842tv4qvoIx86k01ZszlqVK0MXaeiyOldvqxbnfnlFOTPn87sr9y V6eMpvUzq+b+aX70XtbkdGKco8eg5CRm3PR10mOqcFVl9KIjagSvOiI2yXMSqlEOUyclVKvE XokX7K7Rr1HqLF9xSuQzPHwemXQzt7bdSem003CWenvV6+Rda5bR63eShe2sbqzdGvrMHl0N W6h0KUjn+YeYbiFq3DspLDTFcjL5d5xOxuFcud3TNOnVh7TG+v8APVZ2bpOrb6WKpyf90nTC KIvzK6+Rw21t2t+LU7OuBxHvrz4kHu7r+JmfCq7wVS4nnneuPOTIOcnm2XwHoncis2iuW5tL OSPPsi0XwHf/AH23S7U1yocfCj04pPDqMzRZYljQ1NcIsi9LJ3Y41KpKjoaI9uBRLbXKeg9F s7ikqPJnlrctMjt7G6ZqVi3Nrw5StvgzNHBnX80t/mRucJLHrRx2tMqBrvMtkHVFdxUyHYdc CdxUKKdKrXoAnqwyfLMCDueXXvCuWrmFJpVdeEvsN9+1+1c9LcUnrjSVI0k/qZwPJ5yntU2p OEHpk49Z6i7CEo29vcnJSljGXF04P1ntcnE80cZbiLjitEcUqVfM508E2s5fUdfzizG3uYxg qJwr7Tj3JdroTO+l/jHO9yjHXLDJt+qSNtqkbdFnh7Ima0tNOeHsqWatOHr/ALJ0jNXJVdMe H/SXReqOmXHwseRRCSrVZ0f/AEF8XqpJ4JO3j1IqFdu+BBTz/Voct1lNVz8RexFm4uu7XkqK P80itPtRf/kYWIwddD+/Mh/hS/Cv+olDKH45EX+nL8MfeRU7mM59EIk49+PXNkLnfn+CI60d eUbgCsVbs9cmKziofimyVuqlaXKDZC06Rg+ibAcMPD6IyYWe9a6IyYZLqte8cMJL7tpgRtZW 68VMdrF2/wAEkFlY2l92Qbf/AAulTRKotZ2H0sh/gv8AzCdvBWH96RGX6cl/5QJ3M7/Uhw/V tr/x/aK5/j+glHC7b/B9pBXt/wDB65Ct4Rj/AJg7OVl/ekJOkF/mgSlhG/1pe0ml+ZYX3SFz CN5feXvLUv8A2LS5RQRR/g3fxo0R/wBRD8C9xnX6Fz8SNMf9RD8C9wqsq/0z/GbP/qj+Be4y L/TP8aNS/wBVD8C9xKMv/wAz/GjTH/UP8H90zf8AzS/GjSsdwum39Qoz/wDyr8f1GyP+q/k/ umP/AOZfj+o11puX+D+6VGZf6T+de41R/wBVH8C9xl/+RdM/qNa/1fVD+6KMq/0r/GjX/wDS q/8Ab/umT/5euf1Gx4bl9Fv+6KMa/wBKv8z6jTJVv3E/+3/dM/8A8semf1GqeF+70W/qAotO ngT5NxIZWHHldLNP5diPFyb9oXIVV+mSkmvWUTuuk9w/ur6iUP1NuuUalc05TmvntqXqJWp1 u2Zc4NelVGBXbxtW1811sm7kou5K4tVmU2pLk+fQyuzLsWP8x1JW3KMrk4UlSUvEt/dr7fqC JSUYxVq662n+ndXD6cUOSbat33pmv073BrhV8ungJUhFzgte3l34cYv6ZMeFuNJfmbeT7Mvi g/qfRkwDtu58m5j6p/xfqYQk23OyqSX6tl8uNOj2oJxUUrd56rb/AE70eH8Oa4BKMnJRuPTd X6d1ZSXCr+v1gEZRhFyinKxLvw4wf0yZJqMYq1ceqzLG3c+V/TNCWpzelaL6wlD4Z/Tlx4Ch JKMpQWq0/wBW0849K+31gT0ylJW5vTfj+nPhJcnzrw9RV4eqLcVRxdZ2snH70OXSiTUVFQnK tl/p3flfJ/WvSidbkprhuIZf+RfW/egqqrrqdJKeDrhG50P5Z+8anSlMadmLlxX/AG59PJkt VujuJVszwuw+SXNfV6gdp18OqlOnYfC5Dk+nkBBUwSyWEa/9D5NfCzXtb6g2ufEy01JNYqXZ Wr/on/dkN5ca9Ofp6TO2s2l1vqsdeM3nJEqxdHTEzbNzdtKWWNH0F8k2qcT5e2vjbr7OhKKr WoOiw4hl1Cax6zJ1Gp5LiRd18EWJNYiaaqwdUPEbWPEM3jUtUVlIJTVaAODglRphcSeNtURF TUsFgCwxqFyi44J8Rx50LFGopWk8nQhgV1YLAtaapQoVt51G9Va1BlaqyFRlVZRwqT106QqT i60Bxao60I6nmwbQDcnzBY5irzGnV4AJxolQsdulKcSNVUjrbYElF6sciehLgVa2GtyWeIwd FqaRFxjSvErTrmLVTApmJ+HxbOB5kvzp9Z3VKpwfMP1p9a9xrV6vxvrvyc2QiUiBX0HX2Uqo t8yjq276GmY9jPGh0NxHXZmuhmfV1vWRm8tnWNDdeh4luUeaOV5ZLNHYiyF9K5Plk6T0nWuL icaH5G6a6fedt4xBt6VTctRvKk8+EuP8UcrcbOdh1Xoa+r7DrrAlJKSaeK5B5+Tim/wrk2d2 p9m9g/m+0unBx6hbrYVrO3j0cf4+8y2dxKx2Wqw+X7C5fP30ulxsvcSDRoSjcjrtuq+mfIra 4cSuaiUVLBlEoO3jwNbRGgFClqxWD+mZfbvOLo8+RTO1TGHqIxmngyy4Zsa3bq/EsvTJfT0e 417beq49F3s3OeSf2P2HOhccM8uZe1G8qSz4P6e43ibduldOPl2478HX6yF3FHPs7ue3pbvd qHwyXD6cjc5KcNUXWPBo5WYfT4uTXfrDgO5kRiO6+zUjt6te3dYIuUUY7MnpVOJfrbdCPk88 xybLMF0hqadGitPEco1xDiu1xaoRcuWRUlzDDqCLdcc2GpFCSqDjTEDRrqsCEnQpUpJU4EpP gd+D6rfgd1dyTkyVx+Dbqu88ERpiXSgpJYVaxSPajDCdxS0W3+JnYtRt7e2rlcXF1XzMxbG2 9Um41fFL6zo7mwpRilGMkk01WmZhOuc1FXZLbJxw+Z8hX7qlGL40ouvmS8K5SMVFNadLtt0X WQu65QcKRSaemjZmR0u0sxJ69Hkr0pa7kpY0lSXUycLCgpW491YrrK1fhF2rMmm56nPolXCp pg3GVJZtmLOrcuYpsxaTqSlgXPMpuYEEHIz3Ljhis1iWsyX6vIy3krr8O9rjlKk49Usf4G3z KGuEbseDo+qX8TBJVsxbzg3B9T7S+s6W2/8AY27t8aOPpzRde9jzbdLK5Dk45MHJyeORNdpJ 6Rq1J4xg6FdrEVGjwFIlccrPeiQhJXMQi61Ns0Jma3Ghc2SLXa8shS25c2bq0K9vHTZgvuos PdrMSPJt1qFy1G6qTXp4lDhdsfpvUkasgTM7aS9e191lx8kLO8hc7MsGUu+4ycW8i+7t4Xu8 qS+ZGS7bnZwmlOHDmcr5a/V1nuuJey39y3xH49SiEIy/TdejiFCzF7MXMaPEjLgiUZIzoCjd CaNFrts5NaGvbzoyD0Fm2oIL0qRoZrV50zI3LtTnjq3nopIMbmQcyoG6MRCcipJkE9zDxbNy 380WeJWSPbQzPHX7fh3Jw+WTRz3b1advvL0LHhWo1o3jyqVO/ecknJqRs8knSdy3zSl6i/zW ULcY4LW8uo1rehjq51+87slV1pgVUCK4g2c7cu8mEZyosCC7Kx4g3qeOSIaquppmrIunUNoj FE3kc9kycLsracYuilmUuXBA5YrjTgTu3lLBRSZJMivLFmjZy1OVt/EvaZScJOElJcCmGmS1 W03nF0KWbGk5uK7txVRka4GUaNnPTOnM17y34liaWcaXI/X7Dmwlpaa4HZtyWDeWT6mdtOsw xt0uXnwJXLTszlbecW0ROVdYAAAAHkOhK3HXOMebSA9dt4eHahDlFDnwRN5lbxk36Du5mFRV FUqG2KoqkWwqyL4HJ89sOUYXlknpl6cjddvqxHW8qpesv3NlXYTsvGqpXp4GtbiypXlIrSjd 5S8bsuhIwzqsHmjb5ZhC4+lHs5LjVz07uvsI6rlWcrz56ri6m/adry+OlSlyRwvPP1oR+4mz jo3t3cqToiW3XEqk6s0wWmJ0167fJi9Iqm6yNbwjFGNYyNlx0odNPWs7ekQ1UkfS9rLXZhLn GL9h8xT7R9D8mueJsrT5KnqPF+Z10lvps6aOHv7C2+9uJZTpcXW8/ajz+5VLsus9V52qbuEu dt+xnmN7Gl1vnR+s8enWOzv/ANLXaXJwfGNfUepqeL/p2SW6inxTR7OiOXJjJEhCq11C8SJz VIZGtTH5rvlsdvK7m8orpJkadyqwMJyf6f8AM727jdt33qfeizrHv4cyWbejjv6ElWUV0l24 /UZXBVnHrJbqajclVpHfPVj0Vsna7kmY7m+sW+9NGf8A3zbxi4xrNv5VUnlDDoEZZHM/3K/c /SsS/mwHTzC6m6Qgul1M7byTN7NTW24aLt6rWrqIuaTqzny224km5XceUUV7XaW78FcuOT51 Zytuzr44aru4swerWlLj0oX+6WsoKU+pFlvaWYJaYKpa07f5kF+KK4nWTb3crYzfvN1c/Tst dMnQfhb+5nKMF0Ym6E1NKUXVMma8fdMuevK5z/VvSfVgWw8o2scZRcn951NiJVHjDNRtbazb 7kIr0Fl/ex21iVySordcObeQk22oxVW8jzPnnmct/d8KCpCGFFxksBcRrWZcu9elfuSu3HWU nVjhCppteV35rVRIbsSsy0zVGcM5r04xDhHSim9JFkpUVDLJ1ZplGME30LMUnqdfUXXFoXhr PORXQxanwVSR0PL9xomnxeFDG4lbTg1OODTqhL1ZszHZ8zua2opUUXQw+HOHalFpOqTawNFy 8pab7TalJyZofmEFtZ7OCclOWvW+HoZ0slvWsTpHLAEBwbABjStHTmAUgGAEREhAQaFF6ZJk 2iEkWC+5nUssSo6FMZa4J8sBxdHUiLLq0yN2zu4pmS4tUaht50dBeyO/u4+Lt2+MHU4d7NPm d3aTU1peUlQ49+246ovOLMNTthXZlRmqaqjFCTRtjSaNCnj0AS0dugAaP6Z3FyPj7aCq5R1x j0p0fsPW3Y3rly1chBUinXU6Ub9Z47eXv9q83ldtUcdWpqvCea9Z63aTubybncacFlGOFH9O Z7K5uV5upR3ClOSbcZYL4VyORSp3PP7ULUoOCSb1VoszjRWB20vSOe0xRqeX04lilV1fL+6V RVZfTmSiknjlRe5nVhZbnow4Uar/AChubtE7aeHZk/REFOPh9vJVp16TNceDb5P6kURn2U+h 2weD6rvvC9lc67ZKUdUmudyPsRFRiqU6JzIvuXPwRJJ10vm7kiM8IXOqCKJz78vwQFLJv7s/ eFzvT6IRC53ZdT95A8p/htfUVrCMf8uRZcwdx8oRiQuKia5W17Soc8NS/wDEh17z/wDEhtdu X+V9RBYwb/8AF9ZlUod6C5W2/eFnDwOnUP41/lfUFlY2OqQEbfdtdFxkX+m/80drK3/mMT7k v80Knd/x+tEofrQ/yyN3K/1xJx/Xh/l/UQVWO7Z/GxZW1/mjs10WvxsTXYp/5QJXf8frXvLo f6iD+4vcU3cr76V7y6L/AD4f5a9wGaOG2k+c4mqP+pt/gXuMy/038/1GmP8Aqo/hXuLUZ1/p pfjRpX+ph0wXuMscdtL8aNS/1Nv8MSVWZf6aX40aP/oh+Be4zx/08/xo00ruLfTBEoy57b+f 6jX/APTT7n90yL/TvomjWv8AVR6YL/pAz57aK+/9Rqf+puPlB/8ASZI/6fqmjTJ0u339z6jV RS/9NBc5s1Tf/sXnyg/cZ87ViPOTftLZSrPcy6GvbQgpkvyLUecmaJut3cPlFor01/bw9PtD VhuJ88PXIfr/AJErXf26fKvtIJvwJy4zml9ZZFfmWF936yqGNqC53GUaKUvtfJb/ALpVZjRb frkOcn/7E/5fWyyCpcsQ+WOr1kGWK/LhThdZZoXjXFblpuqb0cn0dZGD/LtvndbFNw8W5C6q Vk6TWcftRUWwbcnO0tN1d+08pc6L6vUEXpTu7dVj/i2X9MunNEZ1qo33R/4d6P1817UN69af cvrGMl3Z/wAfeUOLjCLnbWuw+/becfpwl6wrGENM3r28n2ZLvQf0zWTCFbkvEsdi8u/b586L 3xHDtVubdLL82y8muj6VRA5JOlq+/wDKvL6Ze2I1Gc7lH2NzHjwudfT7ytaVCsU5WH3o/Fbf P6Z8STo1G3cl2X+je+p/TABReEpQj2f8az9a+mHUKkdEVJ1tN/lXeMHyf06UW1nclXu7mH/+ Rfb70RUoqLvQjW28L1rl1fVyAO3rbovGS7cPhux5rpI9jSlV+E32JcbcuT6CUoKKjblLsPtW bvy9D+vlmOsm5ScV4iX51vhNc19OkKi9UnKqrOn5kOFyPzR6Qp06u7SXNPKvSsmNJRS0vVFf mWZcUl3og3R/Tnq9xBfYvKCcZVo/YaFLingc6hr27pCnWeTn45j7k7+rS/HNiU2nisR1fDgH iacKVPEZS1qTSJq8k9JWpRrWSHSIXKxyWfAlg6Fb00wCqYXJ+FHiNwVKVHqTyEp1wBk3Fxyz JRfZerPgRklmmKrToEyTlKqwSQ3KmYaatN4snoTq6ZARS1UaG4uSqhxolgh6qZhVaTpiTk48 QqhxlHkBX4iaoiSVMBt1WAtXPiVcoqmrPAeWCY041pQWpcfQQPRXGotKXSxtxHSKxAhpYqIn xfIK0AjRYUOJ5mqXp9Ok7eqLwaocfzhJTi1xRrXu9P49/n+zkyIMnIgbfSX7WemaO7HtRpzR 5yEqOp6Dbz1RTMV01vRyNg9Nyh3IM4lPD3Ul947Ft4i92p9Pyc7zOOi7G4uK9x1bM9cE+aMn mVvXa1cYupLy25qtJciJ6NPEkhPMaCBYGbc7ON9VWEvYzUAZ2k2mK8/+ZtZ/LL3/AGo22b0N x2aaZ/L/APi/qOheswvR03FVcOaONutlPb45w4SX18ivBycN1669Y1Sjp72XMrlGhCxvfhvf 2/t5mmVuirHFPh9hXmZmiudtT6GaHGuRBoDIpOLpImpacsUWyipKjKHF230BGuF1SVJYpjjr 29ZW+1B5x+nvMifFGi1eplnyOmZemyS3W51dGxdjeVYPrjxX8OklffYZg8PU/EtPTNFv7nxo +HPs3K9Sf2P2GNtbH0+D8ib2TfpXS2/dRp5ma09DVTVGbkqxic3m/Kn88+8EYKToPw3zJxt3 HwxH+3uydaULivKr8MatdJOe33HBVRU7d5ZwY8aqfhRqLw4xwqRainWakvQXfuNs8ZZrmh4i MYxSxZmu0q2jepbW5i2jDvXFSejJ5Ho4pikUW3WVDTJtKi7zyMW1bckmFy+3deNFFcT061bG 7Z2/Dtyak3LCUuVDXK5F6oxdO1FU9pzNopbiHhrHpb0x/idK3tptJXLiVPlX1ksYu8l/dO4p Jq7CrcXpaFKeqUpQVaRomuZZbsWm29UpNZ1kzFvttahKMorTqzSeBnoTe9NcPO+aWbT3TurB 5t82V2pyvT1SrSLwfM7G/suUPEUdWnBHLjr1Nyi40woyX+UzG5nW+K1lV0skyqbObookVTjU nNkHLAKhajrU4cZRw644/aW+WXKSceeK9BTbk7clNcHUX+n3GGSeHU8vYTOLK57zMSvxdq/O Otxi+1HqeJCd6VKeI/UbfMoVULq/A/evrOfQ3Z1NeusVShcvyrN1Ra0oqiyJxwyIyXAlakwm sKE0nJqPN0K0zd5ba8W/HlHtMuszU2rvtcOQA3yE3Q9zyHmIKNkbly3ZxuSUetkoti+ArsPE g1xWKM0fMdpJ6VdjXrNlucbi1QakuhmKrkuEZZYMmrjyuYvgye4h4dxrg8UVVR57Jnp0rcz6 9UqVVY4oNRBrGsXRkoXIt0vKn3ok88fUeOewqabJGe3nbWtUnD54fWs0O1JG8s4dG3LAJSKY SJSkTJgmxIQJEUnix0CgMArTE8t5ljuZy+btHo9zLRbb4vA4fm8KSty5x0md+y690PJUp7yE G6KSkq+ipm3l/wAe62nVJ0iFy87ijGiWniuPSURWJzl6YdtZ1ytt4CvVSwzJacKlLlqlQz8X X4I4xTrxCMeI+8+gnQt2crCISlwHORHLrMswZdZEBhoAA6Aa4TcrSlxg/YRvRpKqyliR2z7T g8pKhZJVt9MWGVCwOntJaoaeWBzGatnPTKnM1pcVnaZheZw7cbvzqj64/wADCdjfW9dmS4xp cX1nHLvOq6XoAADDbRZ3TtR0qKbxxfSGxhq3FuP3kUGzytV3UOir9hZ3Hp28SmuLLKnO2U7y 1W7kOzqctbz6uo7ObbUQqiqUSqRYVFUBTtxupwmqxfAutywpyKVgycXRgcLzWz4W4bWU+2vr LPLV+VJ85Grzq1qtRurODo+plPlsfyF0tnfyzpGZMbO7tYUtS6cDy3nF1XNzNrKNIeo9Zakr dhyfDH1HhLk3cbk85Nv1mteyXuUFV1LpPslXdVCU3RUOmvSM3qVlVkabrxKdusakrjN6dNWb 3Qi+0dy353c2Wy8G0u25dmXJcThRzNrsSv2Hpzj2jlvpN+PbXbt3alxY6FnzGe/VuV3GcFKL fMy72OqOpZwel+nFFPlLxZrjs71+5flbcdMY6nGXxUXDpPn66zW+OvZ3vbI8mno3Ntr5ke+Z 862F6CalbjOU449nFHqlvPM76rbsxgnxnI83L6LHbxIySp2qUON+z8yvfqX4wXKEQ/2FT/Wv 3JvrocP3V0Z73b2V27kV6TieaeZ7e/KKjOsY8KHRh5LsrSr4ak+csTgXfDV2XhxSjXBI68U8 tvXp1TbpFexux21yT20JTcuB0PG8xu92EYL7zFsE/wBw5fdOo2e7TXu57Xs5trYbvcTUbt/S n8iHPyW2ptXbk50fGR1doq3URuus5dbNzWMZYIeWbW3lbT68TbCEYWqRiljyIss/w11msIrq EnSFOYFV9tQqsaM4fkf+uz3duH65lwv9zlalonGryLdg2taeCb1IxbmanKvE2eXRk1ql6Bx2 2TL1cuuuuu19fR0qZdRJSSE8yuWmtGz0x8+nJ+C9ccYPvJcOn7S9PkVWqZrEVfBf/jf/ACv7 ANCGJGTeeY29pHBqVz4Y/aS3BJb2U+c+Yft7fgW3+bNf2Uc/YbTTHpK9vZnObu3nWUnU69uN MV6Tx8m/lcTs93Fx+M6919mCp1GXzm2lajPinQ3QdEc/zq7SxFPjL3GNe8dNu1ebu3caIssp d7hErlb8TBZt1LZJW4+FH+Zne4kebr3qvPF5sBgckIKDAAjqS0p9nkAwGUAnkMAroWvMY2bc 4wi27kdEoyyXSuZzkqDAt2tmE+JAMCKQDACNBUJBQCmw9MpW3xLSq9FxauLhmWVUsVxNX3Ro svUmiC7EhWpaXUnfjR1MjrbK5wDzCFLurhNGLaXKNHS3a12dXGDr6GYpO7i5OhrsTeSM95Ul XmFqVGVW7T2qgSrhUCos/qrZUcd3F4SeiSeEk3ivrPTeUbl39rauNYyilVc1hiWeZeXQ322n Yl3mqxf3uBwP6S8wcVLYzT1JuUf73qPV3h09G3+o214S4PV7DiLI6nntyU78Yy+FPLpOY8In fTtHHfur1UdSVuEp+j+JHjQlKbSosn/E7ME+X0yRVceD/C3/AMxZCidHzKpdz+T3yKiV3Fz6 ZwRJd9P71x+oHGs+jXH2IjXi/knL+0wIR7seiDfrY7r7N3riNqipyhBetiu927+KIDuPtz/D D6gn3ZfT4hy78+qC9xGfck+r/qIp3sfGfTELuLu9MItE5Rrcuw+aFV6iEO3o+/GUDOVwksbq 6bf1FUcbf/65e8ladXZlx7UH6CMf06fcn7wLPjf+V9QWu9Y/DIbXbf8AlfUKz3rP4ZFELfdt fjYPuyX/AJR2crH4pEfgf+aETu92/wDiiTS/Pj/l/UQu4Rv/AIkTWF/qt/URVVr9O1+Nh8P/ AO0LXcs/jYLJf5oBc7l78a95oj/qY/gXuM9zuXqfOveXxw3EfwfUBQqftW/vr3Glf6qHTBe4 zR/0z/GvcaV/qrf4Y+4VGaP+ml+NGqP+ptfgiZYv/wBef40alhubX4YijPFf+vc/Gi+KX7iy /uIoh/p7n4kXrG9Y/AvrJVZl+hc/GjSv9Tb6YL3FC/QufiiaF/qLP4V9YGeK/wDWl+NFzVb1 Pnt/UUr/AE9zomjSlXcWvwRLlFNqVVt2+EmvaEnS3ffFzS9pCKpYk18FxNE7qxuxXxJXEaRf H/UWo/LBP3szpv8Abyl8819pZGdbuv5rTp6itKtqzD5pNkwrVH/UwXCEF7qlNuvh2q8bg3L8 y/c5JxXuJRj2bEOLbl7SQQuS/Lu9NxfWXSlS/clwhbovVQpkqwuPg7i97JX2vz2sG3CBcCNt VViHOTl7gjOeu7PTqtOT1r08+HWW1Vu7KfCzBJfi/wCLI18DTCMtN1dt1yer4f8AiTIUVog5 WvzLD70HnH7PxITgtDdutyznKHxw6f45cyyC1y12Py7yzt8H1f8A4+oIUuS12vy76+HhLq5P 7pcoqbUknKX4L3FdE/tLe1dnTubmOT4T/j7wqpVuwilwu2+HXTl7iE4RUFWrsvuy+K2+T6Bn IsTdxu5aWm/GviW/m54e9EOzpc4Ktp/qWvl6V9T9DJPVOSjN6by/TuLKa4Y+5+hktUpydy2t N6NfEt/Nzw969IFckkoqUux/hXuMX8svp1FmqepzSpeivzIcJx5/b6xRcYRdyC1WZYXLfy/T 4WHhtOMFLHOxc/uv6YMArCMee3uP025fT1oGppqP+NbxhJfHH6ZeoSlprPTg+zet/WvpgxqD VLSdZRWuxPmuX04hRVZ28n+ZBdPxRItJd3upKSf3OfXF+wlWtHDDV24dE13o+kSlSjhwrKC5 p96BAmqYcvr+rivUWWLqtusu7xKqxS5xSw6bb+uLHinR9X061iLJZijvvYTa1W5Jp4plEtje jjSpb5Juawe2lnHGH4eXoOtU8O3FJcOmJXn527kV2kOFnCvE7zo80RcIvgYvGeMcWioN6Msj qz2tqeDRW9ha4Iz9uniwJQm1wYlbTria7nlyeMWyiWxuxxiZ8NkwrVpJ0qNwTxTDwL6dHEhO 1cjHFMmLPQxUvDxomRWt1SeFRUfoB6k6Iygq8UNXHmyNJUxZFN8AqxXK4cQU23yFJY1Yn2cw LuylmRb4lbwxyHq5OoMpN0WAUdKkYybeONB68cX6AZSx9AsnXmRVxPMauKuWKBlYopY8yLak RUtTyGnQGQ6cjj+cqkodNTsTmkjj+evtW10M1r3ej8f/ANkcmZAm82Vs2+oDtbC5qhicRnQ8 uuUbiTZvS9cDfrRuVLmkzpJ0aZh82j+nP0Gly/LUuozXXX1jVcipJp5PAweXVtznafBm9usa mSUdG4jcWU1R9ZEw3MBMCspDIjCAYqgBz915cpdqzn8v2GGzuJ7d6Wqx4xf0wZ3ijcbSG4WO EvmDzcnBNuuvSqIyheWqD6+a6yuUeefsMdy1d2k65PhJGyxuYbjsypGXL4ZfYV4bLrcVW4kW q4M0ztuPV7UVOPqDLHO244oSerrNVKFM7KeMcGESt3WsOJo7N5UnnwZgrwkWRnTPLmbm2GbH R2+7ltZRV5a7aeDWf06D11i5avwVyy1KL4o8VC7hpljEu2967speNtnWL70Hl6ftzNSTvq1d 7tibenZ7WgUMPl/mdnfx7HZmu9B5+jmjdU0hgKoVCGDhF5pCqFQIuxbecV6jh+ZRUbrjHBYH eRwfMJar0n6DendYyWHpmhWNt+5vPVTBui59ZW8HXkWRn4V9Sk+y3VNG8+PU3zdejdbsOxLt uqkqP7pqsQk7ip2ox4llrbxmtaeqpZCCVXDChzzja79steMus8ds2eq2xBxUsKOTbKtxYV2c dUU9KZot3VPoZw/OPMN1Cbt7RqLjnVZ8TeubejjZ491+6uwsw0KOPJHF3GNbjzbONPzreaqz a1dMSVrzC7uX+Y1RclQ6518fH1NZtNst7kVSZFTqRcjzWPTFcypstliVNEaOKFulWMJ9Gh/y 5ex+wUZ6MHkWSauW5QXCk16M/YyWdEvZsh/7O2a40quuOJz0lmavK7tKx5doovrwbkrfBPDq zXsN95K58dxbqihSI6xSxGG7RU7/AJTY8Oy7ku9P3HF21qN27GE2oxbxbPUKGOhYJYHTSdcu W99DTcnSJl3nmNnZdl9u5wiheZb1bO04wf5ssI9HSecswc5apOrebZvffx6Tuzrpnr6N1zzL d3+Ktx5Rz9ZhlZTdZYvmzTN0wKnI43a3u6ySdlXgRYQhK0625OD5xZNSLE0ZyuG/Z727uIu1 eepxWqMuJfUxWYqNZLB0oiS1LORrrerlcStWoKmVyfMTuOKrUmKmY3Wb07Eq25UNMbtncPt/ lXPmj3X1r7Dhy39uOFavoLY71cmZxjs183clbnZxllwlHGL9JHU2YNt5pG26QlSucZZM6EZ2 b/cfhz5Pufw9wm3uXU9TGmyu43Zem6tLeXJ9TyZKMkzWWcLNTJpaiEaMlK6rMXceSQGHf3a3 YWF+JlXm+31bGO4WcblH1PD3nN2u4e63Mrss3l1HV8x3ijsf2r71x+7Et7JO7zhZFVyKy+0+ zU8z0a91F65pVDPF1Tpmy692mKMaG8zBei61C34cnKVJJ4LmVOQZ4CnFpqqonkZY7oqmbyB4 uoN+oApAMAAAAqGnR1NuDfRNGGprtS1Q6YkFNOBK3LTJPkO8u1VcSvJkR2tSaUn3cn1M4U7b tylbecXQ621lrt6X1GHfRpOM/mVH+KOB326zLGvS4ZQENHJ0NKp0PKI03Kb+WRlhGiN/la/P r91lncdqTwZVUlN0iyrUdWDqBCowJCTxFUaAazJkOKZaBG9b8e1O380WvSc/y+NLMFxOlF0K YW1GelZVN630Vb5jPwdlJ84+88ckke280teLtJ21mo1PES5cT0TpHL1OOLqFxjWCIPFlvYaL KpGpGbJ5KhVI63pMMeojmdby9N1plTE5u2syvT0xPWeX7SNqLhxaGs/jcpttiuHsrHhzuS4K aRTuo3p7h27NXKelaY8anWVrTYuS/wDJD6zNG3L934tt6WlGh8nyxttn0uHqs/jHX2l+xYpY dLdxJKUJYOp6CEuyuo4kYxvut1KbebaOjZSt21FZLI8e9mNrGte7XUVTP4qGpt8GefydMK99 f8GxOfRgeRc9OL6Drf1Fu1bhG1xfa9R5K9uJXH0Hv/G1xrdr6uW/fD13lUlcjK5HLI6LMXkO 3ktjB6c8TfKElwZ7NY47VbsV+b6CqfefWy7y6SlOTXBFTWJr1ZVssl3IkWiya7MUBSV3HJKs cS7SUydJNHD8j6P3dePuyysq46yikyyO3k6KNC2LrmEJeHJSTxROPbp7LtP3V+HOrTWKB2G8 0SnupSm5ZVZGW8nHBUOl5JPUnFtfQK3oVaURXO9BJrPDEzbzfRsqt2Tq8l/A4ly9d3ro+xb4 LoMfdt7T925wyfVc/BsveZyl+Tt26ZavqKbG3pLVN1b4snZsaVpSVTbGNVRnHba16NdZErdt LPM1RwXMqSpnmK7dUVqeCRhtcrhy/Nbc77i44pYJe9llq9+5q13Vn9iN0KRXiyyXdRr6evqx evyeduW5bbsS77XqKaHRvbWd+5K7OXak6sh/t7+Yvk89uWEDb+wfzB+wfzE8ojEBt/YP5g/Y P5h5QYgNn7CXzIP2EvmQzBjA2fsJfMg/Yy+ZDMGMZr/Yz+ZC/Yz5oZgyDNX7GfNB+yuc0MwZ QNP7K50esX7O70esZgzgX/tLvL2h+1u/KXIz0rg8iijtPS8nkza9vd+VkZbaclSUGWWdqihM 1R/Mt04oyStXLKrOL0/NQv288acyh2JUdDubeSuQ0viqHBuLRM6mxu8DGyMs41VHmsCijTxN U5q5OTWTbM0nXPMkbvu1eL+WBmr2aAVH0HbbtOkJ4PJM8rumvKfO1cWFu41J9U8H7cT1G+2X iRc7eE+XP+J5PzjYXNxtf3varbel6k6uPP0P6z163HddprZ5a9PeOt/UMEr9uS4xfsZyp5I0 S3f7/Z7e++9BytT66L30KbixPRp2ebbupaFy+nMkxLgdWSyw5EGqpLn4aJRx9NPrBZxfSn6k BFvBy6bkvqI3MprlGCB9x/5dfWx3c7n4IP1ULkSn3pP70IkLncudNxEm6y/nhL1ohLGE1/5C ZFkv1JP70F7CEu7Nfci/aSznL8f1BHtVXO37iKnB/nW380KFNpPTBfLcoSi8LE+loTWnWvlu JkDt4eH+K4yMe4v8uZKCxiv8xCh3V/lSKJfH/wDq+odnvWfwyIrFrptErT7Vr8EiCFj/AAPx SI/4f/7Sdj/A65EP8L/9hRO/nfpziT/xpP8A8f1Eb2d9dTJZ3X02vqIKoKkLHTJjeCfRdHbx VjrZFYrrugOfcvfiXvLo/rx/y/qKZrsXvxr3l6X/ALFv8C9wGeP+m/nXuNX/ANUPwL3GaP8A pn+NGpf6mH4F7ioyRX/rz/HE2R/1Nr8MTJH/AE0vxo0x/wBTa/DElFCX5F38S95dF/nWPwop jht7r+9H3lsU3esfhQFS/RvfiXvL06X7D+6vrKFhavda95csLu3/AAr3kv6/oqmP6F38SL4/ 6iz+GJRT8q6uUl7zRFf+xZ/CvrAoh/p7v4ol1E79pc4JP2lEf9Pc/GjR/wDRZ/BH6yozQeiE J/JPT6GTX5bSf+FP/lkRUW9vN/fRfct1uXI87ar6EayiqXZt3lx1r1F6pHcQrlbgn7KlDi5p JZ3If80Sanqk5r47XuwYsBaf5MW/iuqo7sm1NvN3VUjFdmxBcW5e0dx1jel99U9ZA5Vlqi/8 S9T1Epu5cldaip29TTjKlfRx9Q4ySvJyytqVx9fAqajG3bVzUtTlcenNcgIwnCapJvSsFJ96 HRLmuk03Kukb+Evgurj1viunNGa5cTeqTrwV1LHqmuJdZuOMXFJTt5ytvGnTH7fWZ7Ve6UnP WtXZvrJ8Jrp+3iEZqFZwj2XhdtPh9OD4CbUYUfbs8H8UPp6mQrKLUk02sIz4TXyy6esl6L3W uEYRUJPVYn3JcYP6ZriNxlKahJ0vx/Tn8y4fwfoIwnGFcH4MnSceMJfw4c0SdtYbe6+znauf Tg/YzUqYCk3W9BUmsL1rmuLp7+QtMaK2n+XPG1J/DLk/p0klrnL5dzb/AOdfb70Qbi4OaX5U v1IcYS+ZdH/AqJO4/wBZrtR7F6PNcxOLinbi8YfmWn90jqalV9qVMf8AyQ6PvIUW+yoOrjjZ lzXGD6SYVY1GbVMIXsY/duL6eoi8Vql2auk/uz4S9PEinGacI4Rm6w+5c+Vk9ak9U8Fc/Lu/ dmsn9OkCDqm21RqWPKMn/dmRlgmsnHLqX1x9xZWmNzgvCu/3ZEW2sZVrCim1mvlmua5lFtm/ K1ON2GcXVfYers3o34K5DJ+w8hpo2ng+NMseK6H7HgdPyzeeBLTLuSwfQ+Zx5Z0y3q9AA3gF Tg2VAoNAwFQAGBGjClcxjQFbhF5orltrcs0aKCJgZZbKDywK3seTN1AoTxnsOfPYyeNU2Uy2 V1cE0dagUJ4ajj3NtNxpobZUts4ruvA7pGUKmftxMRxIW0qrgJ01YI6ctrJ5NEYbWSzoT7fx MRzmqurWIassDrQ26WaRZ4MOQ+2uI5CtyljFD8G63hE6ytRWWAaZJ4MfbMRzYbK43VqhwP6h tOzetxfy19p7PHieP/qh13kVyhH3svhJMu/B9bjvMrZNvEgzL6RMu209E0ypciKdAS46u35h HxNu38rTDbvXt11ErT8ey4840KPLXW04vgzHo7zpt82zby1W6PgK5HVFc06kLD0tou5ojfZZ WqJFcciaDFSAQFQwIhUhhMBJjqVCnCM1pkqpnJ3Xl7t9q3jH3HXK57iFrvOgc9+ObzFcvb75 x7F6rSylxX2o1yt1WqLVHk1kxX9nb3K8Sy0pexmC3dubSTi11xeTK+fycV0+TW4+hlbRphKG 5VYZrOPxL7UVyjTvesOLNO2p558yhpwdHkbZRoQcaqjyAzxenqL7dxxxiUuGjpQYrtRxRZcM 2NiSuSU7T0XVjhh6jueXeeKbVnedmeSnwfXyfsPNKSeJoVyNxabvon9p1ll+bPWfJ7aV1ReK ZF7iKVXU85svNLuwpbu9uzw5rq//ABfoPS2btvcQVy01KL4lVH9xFuizLU0x0QtKAU5q3Fye SPO3nqdXxOn5g0moLkcy4mdNZiZbk6MzWJJRU6Ql6HyE+gruxk4NLFvkbsysqy3fntLn5cm0 vUeg225hvbSce98XQeMhdUU9bfQ1wfSa7Ur22bddVuS7WnM8+211vX9luv7V1/Mt69v+XY7U satfCcuVyVyKuSeptYvmQVy3enWzLTKmMXgyu/B4RyS5Hfi21v05l9q4722fyxfirv2rd6FL irTJmF7J7ZtxeqL9aNbTjWgvEriuJ2sz3c5cMfiaXpZLxODLp6ZLTOKa9pUrNt519ZyujrNx qI1qONiL+JlU4KM3CuVMTF0rc3ix4ijSE1Lgnj1PMraljR1pyIa6mbG/KVo278C/pfB6S7zW 124XVxWl9ccvYZbz1KNxcVR9ccPsOnuF4+1clnFK4vRn7Caescb02lcqKSJVK6kotLFmnRF2 pbm7GxDM9ZduLZ2YquqaWldLOD5DBzvO88lX1s6G9buXG+CwR0lxHPGa5V+Dc9cnVy4koqjN WhSVGZ6LFnH1dZeiM3QpbqObIFRJYk0iCLImWmiHdwKnclQstqhz78pWpuD9HUb1rlyT1WSu 3VkV3L1yWDKXdYncZpzwdilueqWR0XvYcEcvWLUZsy1K2+LBy1NmuHmFi3GlWzjYCwJ4xc16 jaec25LwW04P4LmXrLr2xd56tjccJrOzdy/ll9vrPI0Rs23mN3b0VdUV8MvqfAz42dlz7tlz f7vbTdq9FwmuEiq9v71+OiT7L4HZ2/mdjfwVm6lOP/bud5fhf2eozX/JNVZbKWtLO1PCa6uE veJsYYPLpKF5VyoLdX3dva+CdEKEHbrqTU8qPBoruR7JN9vR149PU2qNoanpi0JuuPNJkJ90 5eqTpQu1jzG0EFgSpXAXubXIjN2WrkaaukV6/O7TW8lh0IU+0+hEHGuJrrhlEZKFK4l6S4EV QoSfAkrT4lwqkFfhLmSVtIdeQsOLKDBE7Uu1jk8CvXFCd1MIumqxa5FHA1N1o/mRnpRtERo2 c6SpzLN/b1QdOHbXuZjty0STXA6l2koauC9zOunWYY26XLhk4NJ4kHHS3HkSRitxb4nQb/KZ ar0vwnNOj5R+rL8P1jXurr3HgVVJ3Mits7MgdRVAqJIaIIsiASyLiGhtF8LdY16CZiyVWliS UO0nzLLCq2mXxjWHVInljaNTXMyy76Xfj91Hk9/BRvNrikz0fmd3w7rfOiOJ5tCkoTXFNHql 6uPo5rYW1V1IvEtgqI6TrUvSJSYo23cdEX2NvK8+g03YeCkoHXxz1c84aPLLejE722faRxdi nTHrOxZeKN2fxw47KtxBR2k+i7H3nLi9O4a6EdnzKUI2JW6rU5xlQ4Up03C6Ynwtp/Pk/wD5 V9CXOut+Du7dnTtzjGFZI5O2xOjG1bvR0Xcq1PPjN8fdYlLfW1gqFE/NLUO9NIp812Fm7tpW 9vRXHSjqech/Tc5P8y7FdSbLOHSfVs6TyvbVm868w/fbhyi6witMTmNnprX9PbZYznKXVgaV 5Z5fbVfDcqfNJnonJprJrr6J9ra9a0eXeXb23tYeFuHFNV0uMWl6zQ9p5msr0JddtfUStbya ioxwgsge6lLiLzL9ipQn5hYddFt8+00S/wBx3nGxB/8A7PtiUS3D5lU7z4Mz9++0WcGvra3r dzl+pbgv5q/UWPeW2u1GrXI5L3CWbxKp7qiJ93dr7Ojp3NxV4JIyzuybxoc97+KzZml5ilxy M27bd61NdNe0jqxuNPMquXXWjOPc82jqyKP9xnclSEaseFXzjvK6kszn7jzOv5dhapZauCKI 7S5cbldemOemLqaoWoQSjFaVn9PpgXEnxOt+DDHbSc9d165c8zXajT7V9OKL/D0pyy5ojoa6 uBc5MYJLUsMzVa6WUKVMg8RVBluUiG6hYnGNu43pblrcc1hg6caMzfuEk1FY8GO3brW5N+n7 BOnVL1mFHl22lbnctxddvWMoznGksOKXsNd+94sqrCKwiiudxzwyjyIVM7beVcLZJ469jqFR VFUwydRkQAYCqFQGFRCqBKohBUoYVFUKgOoVFUKgMBVCoDHUjUKgSqKoqgA02sjHe2Gp69su 2sXaXHpj/wDj6jXUSk4tSi6STqmuDNS4qOZdkpwU0RhuHbjhmW79+HelN9y8ta6JcV6yjY7K e8q1LSlnzfUd8S9fRO6+zPtuPNakO7HGqyLb/l/7eK3Nibu2ItKepUnCv1dKFcVVgc95i59K 3O2PZRUBARH0qNbMYxwUcIpVb9pyvOZ3Lje2hWcbkJaoxXd9RKW5vSsq9JVfyx5jbvOkrXai 1V07x65raxnFeO8puTsXZ7O6qOXB8Jx+1HTu5lX9T7KW13Vvcxr26apffX8DRuF2md+Nz3Za Yi4eomyDxw6vednMo/Z72C4V+mAR4fTKolw6n/0hUPh//USeL/FaFBanBfNbaC06u0+cZQJV JOqT5xh7GOaqmv8AyojHuR/DJepk5NVf44v1oBvvN8HcFZxnb6YyiNYNdF1kYPS7UuU5IUQ/ wIv5Zll7v3elRkRcaRvQ5OvtJTeqVfmte4ga70fxv2ojaXcXROIdP3rch26qUei5NesAt4+H 025ILOdp/ckgsf4X86CxnY/mQEbOCsP70hSwtzXK6EO5a6LjHc7l1criftAneXbv/hT9xK3+ rD71unvCardurnbr7CNtpSsS5poghZfZst8JtBTTH8N3ES7NqX3LiJXv8ZdMZhRcVIX195e8 uX+os/gX1lV1frfyMsX69h/dX1hFC/08vxo1Rf8A7Nv8C9xlSXgXOiaNMMdzb/DEqM6/08/x o0wf/s2n9yJmX+nn+NGiOG4s/hiWimP+nu/iiXrC/Y/CvrM6f5F1fej7y5Spesfhj9YwK4v8 m9+Je8sp+bY/CveVRdLV7rXvLNVbu36l7yfr/gQS/Lv9a95dF/nWPwopT/Lv9f8AeLVjc2/V 9ZL+v6KoVFt7n419Zqil+5tfgj7jPReDeXKa95ph/qLT+4vrJkQsrXG1DhKcpP0Dd2sLt553 Hoj9OorsvRGE+EZuP9pE7ST8GEsoynXrRuxFsYJXbVv5I1l7zPCOmFuf33H0MSnLQ5rG5ek4 +jj6y2MoymoV/Ls4yfN8fsRM2dxXb7Erdf8ADm4P6iFaWZJ5+Ik/aWT7VpzfeuTTj6CV22tV 6LyrH1msoL1JTmpYW9UdXN0WXpHOc46ppqM8E28or5Fg+GZS77UncayfZjzlw9Rb2VVSpKNq Lcq5SuSJYquO6t36qkda+KCon1x/4EI0ty1Wnokvhzp1c4viiN21ctyV1ShF5+ElmuTSy9LL pxtXoK9CsYvCXO2+nnEzRfrbeq2tF196PwT9H0RBablVa7MnhOzLJ9X2ELU0ou1eWqKwUlnH q5oldbovHWqPw3Y5/wAep4i9YIQnpeqlcNM4vil/eRetKirc3W1LG3P5fp8S9JluSali6vB6 18UeD61xLbU40cZ/pydJfcnzX0yMqvcZXH4UsL8O5L5lyr/0sPEcv/YtqlyOF2HCS50/6vWG hypYuOlyP6U+fRXlyI+JKT8eKpdh+pHmuf1SNZBKNtJNfozfZfG3P6etEJW3WUZKs1jOK+Nf NH7xb2IY/wCBdwa+WX8OHQGmf6adL1rGD+aPL60XKKGtVHXUp4an8X3Z8pLhIdW61xr2JauP 3ZcpfLLiW1g1rapaudm4l8Mua95GScaqeM4YT+/b5+gog3J0+ZdjtfEvkl08uY4KmmMelQcu D425dHIbcV2ZNtUx+9Dg/wAUQljXXi6LW18UeFxdK4gJYpJdKhX2230/KWW3VFcquurF0Wun xR4Tj0riST9PTlU5ct6OnHOr0vlm58e1ol3oYejgbqHmthuPAvRk+6+zLqZ6V4HnbswVAGgC EAwAQVGACCowoAh1FQAHUAEAwoIYBQKAKoDoIdQAQqEgAjQ8X/Uz/wDeS+7A9seI/qTHzB/h h7iXs78H1uTXFkWCeLBnJ9Ek6OpK5Gj68SBYpVwYG7y67Tsst2iVu9dt9NUc+xLRLoNqlS9G 4viWlmK7a3MnwalnUsTKNRNMw7r0yaZQmTUis2LagyKYVDGBUBVAKmmSRBMw7zzBWqwhjIs6 s3olv994S8OHefsOQ5N4vFlbk26vNjTOsmHG7Z+TRavTtOsHToOzFQ3tpOSx58UzgxZ1fK59 6H8yM7RZ16Vmv7W5tppxfTFo02N5G72btIy58H18i3fxi5W9TpSvWUz8vneWu1CT9BjLy8vB ieev9Fsrbj9hU41xRTY3crXYuYxXrX05G3TGa1wdVz+0ryMrVCt26YwwfLgzS1weDIOJEZ0q 4xwlxiOMq9DJygpdDXErarhPB8JFyjRbu6VpeMeMWX7e/d2cvG2rqvig/r+3MwanF0l6y2M3 F1To+Z0m3uxjD2Hl/mdrfx7PZuLvQefo5o1bi/DbW5XZ5RVTxWFySnB+HdT7Mlgm/qZfvfMd xvLcdvdSU4vtcNXLo+pm2p1o2/mE724lK7/iPDo5I23UqvH0HMfld624yuyVvjROsjqx3UbS rFVfzSO2mtsXfk1nSdVSs3WqqLpzoYbu9tWbi1So48FjX0F263E9y6XZvT8kXRGZKFp0tpRT 5ROs0scbyWs9/f2ri7Vuer5kqFuzuTupuOpQ+8sPQOq4sjK3GSpWS5UdBtpNvq6k3smI0XqX aKUU6ceJBt+ow3Lt/bLhOHP4gXmFua7NU+RrWa6zGswzc3rerW6TdGiFzbxpUo/d3HwoiXiu XeZrKYVytzWTr1lTlKOaZpbIvpMWNM6vVFKemSuUyzJzsRljkVO3OGWKM2LDlNSlqi6JlU4c Y58SDTg8FhyYvFawaMY9GpV9t67cocY9te5/UdPyy4nHTLJYPqZybF+KuLVk+y+p4GvZSdq9 ofGqONnjt82tusZJ23ZnK284tx9RXeuUjpXE3ecQcLsbiyuR/wCaOD+owxhWsnlHFm1zmOv5 PeW1sy1JtydfQid3fWnJyxSZktXVdtpx4EZW43mnLCS4nWSYc83LU5q5hCSq+HEouKSemjMF 1Stz7WD4M2bbzFrs3H6TPjGvKjwLr+Fh+3ucYmyU28nUqcq4ZMvhDzqlWZ/KyyMHyYozknRO nIdveTlWEu+uHMz9ue7XnV8YNLIxb3bzuNTjFvChpjf1Ych+JVZ4Dwk9Wbva5X7W68osrlal F0kmnyZ1PE0SwZZcnbvJeJGrXE14s5cVxBRbdFizsa45RhGnUT8ZR7kVHqRPFcuZb2F+5lGi 5ywLf9rnwnFvkbLl9qNOLKk1GNC4kOqiPlkvjnGPtJ/7ZBKru+pE7dJOryK797lkMTuLIWNt DGjk1xkzba3nHgvWcqrnJQWXE0TVKQWfExtZNesb1ltdmO5s7+KjfXiUyn3bkft9qMW68puR g7m2fjW+NO+uuP2Ge1B1qa1vpbeSk61+aOf8TyZz3ejF1+n+jj23WK6KolSp6CT2vmS1XO// AN61hL+aPH0+s5u68rv7ZeIvzbX/AHLf95Zr3Fs9nJhEpUdRtrgQMhAAzWTBULFOiIATK4S1 sWpiAgKiGAEQGJlGq09cKcsRXM1LmV7ael0eRdchg48gypeDOntJa7el9RzHik/QatlOktPM 3pcVjadGPdQcZ4kIm7zG3jqXHEwxG3RdeqR0fKP1Z/h+s5x0PKcLsvwmde7bq3PrKmWzVaJD jYbzO2ZEmtvZUSUW8iUoUi+cXQt21Gn0Eu3TKzTriows8y+NtIdCRz83WaYSpQnbyK9WAQmk Z8o140WsJmi3VprpMErjU30Ym6zJtNjfeJppZ3cfzWErspaYt0pkqmLe2pX9smk9UcaUPS+X X34EpVx1S95CVzUy38rF+lNeDPTPZ4Vba6sXCX9lmyx5feu/A0uk9a5JIzyupG9fzNp/ZC/j a3+6sdnZXIRpFJEJ+UXrkqucYr1nRd9UzK/3UeZdvzuXbtJqT8XjnvUbGwjZS1TrTkjbbhbX NmK5vKKhR+/gnmjnfyea/wBy/Y4p/a1eZ2bUoO9oXiLSlL0lWzlFQrRN1zeZivb+Nz8utdRV uN5+27PF8DnbttP5XNWTXWySYjsu+06t4EZ306HnX5nJ8CEt9OWC4GfCunlHoLm5S44C/cxp gzzkr9yWbKnq5l8E8nopb2McEZbm+UuJxXXNsg6LiamkZu7ty8zjbSjjUrfm1GcbUuZONZd2 Mn1I14RnzdKXmsuRnl5hdbqiENrfl3bb9OBdHy3cPvOMfTUYkM2s093elmyt37jzkzpLytZz uN9SL4+X7e3R6dXTJjy1h47VwnOUnxZps+XX72NNK5zwO2lG13Eo/hRXcnliPL2i+HvWS35T bim7knJr5cEbYRhGOmMVFdBJPMIyUU48MzNtvdqSTsnbjV0fVQko8uHd6pL6IzudUk3hhF+g q8fTx4U9KGDLY3gqFbm4P3ozy3KbwFG+k9TyGEtU7vdeHKnHkS21u5Na5ZS7vTzNVxyvwuR8 GDd1JVl3o0yY9pZ/aQUZy1tV0x4KuZvMk+Ln1z1+lNWtCU5ZZKPEJScsWKc3N6pYsjU422s7 bZ6TskBGoVIwYEagESqBCoVAmKpEBgSqFSAATqKpEKjAlUKkaiqiidQqRSbyTfoLFYuvKEvU QRqFSz9rd5JdckH7afGUF639gFdRknYSzu/2Y/ayMrdld6c36UvcigIu5FZyXrK5ftVmm+uT IeNt13baftLgTe6tL4q9RW97b4JsPHXw20v5SL3E+Cii4FV/cRvxUJRwT1LEjC/K3HRbSUa1 yLHKTzfqQtLfBs36YEJbi7JaXN05VwNFt64plXhvkl1k7TSqqqq5GduzWvdDT2qAXae1UDOW sPoNix4cVGWLVS5JLI50/NrddMNU391fWyn/AHlV0qOPXX3Hp8nFq812Ed/tp2XnSsHyksjy 9x1dcuaPRvf3q0UF7Tzc3Vt822ejiucxjdU8yCpx+mJJsiehzJ4L0fV/EF3kvxr/AJQksPQ/ qHH9SP45r2FFdl/oP8USMOzGD+W40EH2LXRNhJUjJcriIJKPw8nciKTqm+cYS9ROeEp9FyL9 ZCmS+7OPqIqVzDU+VyMvWRuKkZfduV9Y7mMZ9MIS9QXFVXVzjGYFklW7dXzQ1FcMVZfNSiWQ db0H80KFMHS3B/LP3gHw9Oj/AKWWZXK8PEi/WiMY4pdNyIJ4J/5bIp28NHROaFZ/wfxSJRwl Ff8AkkRt/wCE/vyKiKwtx6LpO9lfXSmQl+nJcrpZdVZX1zjF+4Cf+N12vqKYP8uzLlJotg63 bT5woUZWIvlMCy4qK/HlKvtHcWqTXzWk/USuKty+lxjUUMZ2X80HEioN6lL71uL9RZDG7Yf3 UVW8Yw6YTj6iUM9u11e0Igo/k3eiS95ogqbi1+BFXwX10/3ixOk9u+j6y/r/AIFCX/r3PxRL lXx7L+7Egv0r0XwkveWxX5th9C95cozxT8K8ule8to/EsPoXvLEkrd/rX/USUU7m3T5L3jP6 /YwyqL0X10/3idWp7dvl9ZZpWi++n+8S8PtbddH1jP6/YwzquncLp/vEqtPbv6ZlihX9w/p3 h+H/AKdfTMZn6+Qq1PTuF0/3i+E1rsS5qntIOFf3H0+Ikrbrt/pxJZP18l6opfk3Y8VKPvJT i9XZzlFXY/iWfrIqLUNw1zX/AFGi2q3Nun8v1iXH6+CMsLkYuD4Rbkvwy+xlcbeqNu08nKTn 6P4F2iPhOSWMbmHUxXdurcp6HTRSa6ma6VFUL8k43aVk3S1DgqFtu9CS8NvOVblx5dRBJ2pR rioJtNfLLj6Cu3CD0LDsqf8Ab4esnj7LlZc20rijKDpJqel9C4+lcTNGO5t6VojKEe0o1wb5 viy5RlFVjJ/p65Pi+joLfEnCutV0qMpU/wCWK+sYoodzdusnG25N11NVftw9hOzO5Oc3ONHR OUVgmuihe5aHWWUHBT9X8TPfuysRjJVU4OikuMXxGDKdiWm5+V2lTCMuK4xfVwLW/i270tvG 1LGv2+8y25RnLxHRKWen4ZLj9pr3EqxTvJOvdvQ+mPvMDHJpuqVI1y5VwkvrNNl6aua1R7l1 e6RTeeNXRt/EspLn18yyzNx7axlFdqL+KH8CK0OKwsSdYvGzc+r6ZMPEl+ssLtvC5Hmuf1P1 lemL/Lr+Vc7VuT+GX0wfrJa5KXiU/Otqk4/NHn9vrCrI6LeD/Qu5P5X9q9wKE2/Dlhet423z WdPrXqIw0Rel/oXcU/ll/Dj0EnCUvynhetdx81y+tFz+v1/yhOaad6Krbl2b1vk+a+rpwDRJ ONuuNPyZ/Mvlf0wY/FS/9iKrF9m9Dr+32MXh4/t5Psy7VmfT/HJ9JpEIJOiXZTfZ+5Pl1MFW ia7NHRfcn8r+7IlOXiKU5qkl2b8fdNdK4hJtVk1qaVLsfnhwkURVM0qJPBV7UJcY/hYw9Orl Li1wr0rIDycm2dvk9OkxE4s9Jspzu2ozbrwfoPNRZ3vJrlYThyal6zEXaOkBKgkVzFQrQAAa YVDAQDCggzAKBRiHUBUY0mCY9QCAdQAKhUMgoACzGFKAIKDoFAEeJ/qRf/8AQf4Y+49vQ8V/ Uip5h1wj9ZL2d+H63DTxGyDwZJnJ75SYqgxAWRlQ0xuZGInGRLGtdsOrG5UtUjDbngjVFnOv VrtloTJplUS1EbTTHUiMMpqS0ONFVtPVxRGogKmFe4vqxbcnnwPPOTk6vNmvzDceLPSu7ExH XWYjzcm2bj2OpJMgSRpyWROj5a/zl0pnMidPyyNbteSZnbs6a93csxi51axSOjBUOXs3rnJ9 NPUdeEao5xz5bisu98qtb5au5d+dcfxfbmeZvWdx5bd0zVH/AMsl9fvPawVCG7tQ3Ft27sVK L4P6uRrDyXrcPL2rtvcqiwlxh9gpRcc8V7UQ8w8pns34lp67f/PHr59a9ItvvlcpG9g+E/tI xZYcoFbjXB5Gudpp4ceHBlLjXr5EZZnHSqPtR9qI0cMVjE0OJW4UdYYPlwZUKMqroZbrUo6L uMeD+KP2roKNNXWGEuMWOM64ZPkamzNjTGcrCWp64Puzz+nUSc6lEJuFaYp5xeROMfis4r4r bz9B6NOWzp3jF1l+aTKpJVwLFJXFWP8AFEMur6fUeuWWZjGME2sxJtkZdl19Y3LiAp5HG3Nn wp4ZPI7VUzJurXiQfNYmdplqMFrcytvmuKOhbuQudqJxycJuDrE567YWx2ul4IhK7bjxqUWl HcR1VdfiRYrMUdMs4P8AcQbokOVxLJEGk+pC7UskTKk7qfArbtvhQs8FsXgogqdKYNelFtyT Uo3Vxo/TxDwUOUPy6fK/f/E48k6fJvVu8xgr211r4Gp+h4P6jnOFLWlfEdXYNXrXhyyacH6c DnW09Ol5xbi+tF169We3RLbw8KGniOizQ3IjVHQWOk1pmqo5t+34MqPJ5M3akKcY3YuDyJVw y2Nzp7EsYv2GhzcXpm6rhI5ty3K1LSzXG47sE1i44NdBJsuF8pOMiG5WKnHBkIy1LS8+BObq qDIcbiuRb40xHGVDLadG1zLIywJkwslLtIsc8DNF49JOUi5FuugaympFyJkwu16nUbk2UqVB uenrJlVrmoKizMtyVcBOVRRi7kqIlpI0beVE7j4vA0W41dWVRhklkjbbjU8++2ej06a4iy1G mJzN9fkpUR05SoqHN0K9JzfdXuMzEW5qvaylDtRbjJ5NHX2nm07TrJ6X88frRx9eu4pZLJLo Lkqltcq7l3a7TfrWqWbj+O3jB9cfsORvNhf2X6sew8rkcYP0/aVQvTtS12217mdXZ+caKwng ng08YP0D5o4ozu3/ACzb7rtbdqzcfwvG1Lqfw+1HI3O1u7SWi/FxbyfB9TyZLBSAARQIYAIB gBETJCAUHSSZurWj9BgaNdqWqPt9RpKhFYuAW5aWpciVzsyUiM1pkRl0dzFXLdeXuZxINpuD zR2tq/Et6H1HJ3UXavKXzHbbr1Y16XDbN7dbfSlqvNxaksNPNPma/J9u5TlJ/KZ9vtXJ1kdr YJRnJL5frPPtv7O2vfqVxeHeS6V7TUkY/MnpnGX0wNWqpNtsyV6dNcXaKtwlGslxSKtvPt05 os3GNuXNKpz43tM4S4OglzMF1xtl1a0FrKJzoRU6nHLthocgjNJmfVXIFJyoo4sZXCdyaV3T zRq8vU9xDsZ0x9ByN1ccL9v1Mu2U5xdyEJOLjOqa6TfT+7s59evj3aLd/wACN2LwpJuhk/3B cSrzK5W/JyeNxKXXTBnMlubawqSa57L5Y7u1uN/FW01mYH5jPisDnyvqXdqxq3uJ923L+ybm nu53f2XXN5cllgV+NN5scfL93PHTTraJf7Tf+OUV6TeJ7xnN9qrcm85FepLN1Nq8oXxXP7KL IeVbdd6Un6R09zG3swbead2KXM0+cNKcW88TU9jYtdqEcVjWrNM0nKrSr0ouZ3jN1uZK85Gc pYRTfUi6Njcyyty9Kodx3GlRP1ENbeLJ5fBrw+LmLy/cyzpHrZYvKZPvXF6Eb1NdY9dCeVXx jGvKbS78pP2Fsdnt4fAn+J1LJzxo2OclRJP6YjN9TEnaHCMYYqEVypFF0rtyXZcqLkjM7sa0 rlQgtym8c8SYyucNKk3hwIuT9Bm/dLMr/dVRcJ5Nim0qvrIu7jR5GL90yuV+UnyRfFnydDxs cfpUoncTfUY5Scsx9ZcYTOW1bmioyqd1SyZnbSIu8lkXBlZObSq3gVxuqTpFVLbOzu7ntONY 8q0r1Fu18tuW5Vu0jHrL/HHW9Wf5Z6TojZsTuutMOf0zN7hb2qrN4vLCrfUEtzi42Flhrl9S Ko20nqfak/iZztLtNe3W+5udy7h3If8AM/sJJKKogAw5W29zAQqhDASaLI2bksoyfoAgBctp deaS62TWzfxTS6lUmRlA2ftrS70pP1Ienbw+Gv4mMjDVIkk5d1N9SNf7u1b7qivQVz81S4jq Ira3n8DXXgTWyufE4r01M0vNK5VZW97dllF+kuKN62cF3p+pD8CxHPU/ScuV69LikQet5y9R fGjr69vDKK9OJF763DupL0HJ8NPNt+kfhwXL04jxG+fmq4Mpl5jKWSbM60rJ+pEoLxJqEVWT yqXxgk93dfChW7l15yOpLYWP2ctxbuPxId6ElT0fYzk62bunji2dzoNMpZtsPB5r1sNbfEEz IkraXIloXN+ghUljTBNjK4voahFtJKreCOpZ8stXdvO5C4ldtrVK3KOX05nFlZvXHWlKZHQl f3N1PxWqtUbSoXXfSfV1a8N72jJrZFtsv/bt5sktsuLOd5NWpxb1lIWnou0fHA3LbwJKzBY0 VTP3I3OHbOcxT7wLNHboBny/6Xx/7eyt+TbWHwanzk2zZbsW7Xcio9SoWEWqulWfQeRn3dyd tOUHlFvHoPI8D03mttR2851eCpnzZ5qeB24p9Vc9/RQ8xZBJ4gsDuyUlRUCH6kX/AOSRKWCK 3g0+V1lRXlaT+W4SuL9ZcmpBcXYvLlNMlJVncXzW0/YArjxuPnCEiWU1X5/+pEUtVPvWmvUK uGrl4cvqIp21WkecJR9QW3r0/etyj6iUXpmvu3Gv7QrPZ8OvwzlD1kCtywsS5NxIyVIXY/LN P2i7tpfcuFtxdu/HnHV9ZQVpNv78X/aRB91/g/6ZA32W/uwl6mSlm/8A9i+sgl8a/wAxP1or jhGHRcZNPFP78PcQeEPw3Sh3F2Ly5TT9pY1W9JfNb+ojdX+oXU/aSjjeg+dv6gIW5foS6XEj NUtXI/LMUXSzbfFTZZdWO4XU/aBZSt9r5rf1FNqVFYk+EnEtg/zrMucaGdYWV9y4QWWo0lGP Kc4+tChlYfKTXtJPs3J9FyL9ZFYKC5XJIKk8tx1/3htdrb9X1hPPcL6Zj47d9H1l/X/CI07N 9dP94sye3fR9YqU/cL6d4cu5YfX7x+v+EOSotwun6yyGN+x+FfWRnGtzcR6JMjCVJbef8vtL 3/XwCg/yLr5yj7zRFfn2Y8ox+sy5Wb0eU17zTF/+za/BH3Es/X7GVKf5FyXzSS+s0JLx7UPl gn9ZkTptp/jiak67mPTbX/SSxcqFL/15S4ymk/eaKU3CXC3Cq9VTIv8AS/z/AFGptvcS6bf9 0YMqKtbdc7k8fQaG9N+b4WoYehfaZljZs/jf1F1x9rcv6Ziwyrp+Tbt8bkq+rAulJOd6fBR0 fUK3+pt192vtZTq/9ecuMri+sYF1uCcrEeLi0+pmbwIuEZP5tD6uHqNbem/J/wDbt4f2f4lU FWFmHzScvqLLUZvBnF0ripOD6/4kWppPGqpT0L7DZN61ckuN2NPWS0LxG1l41F6ViaymGNKd a1xwjV9OWr5ovnmhuFI6aUVXRfLJZrqZao1glzhJeqWBO6k26fNL2URcmHKlPw55YNVRttXW 4vQ1HUq6Zd2Xr4mLzJeHolwxQ7V9KFdNYxpqi+K5rl0nK92p2WX3TspaXxjw60T27ba04Sr2 Ovl6UVTt6bjtvJZPoll6iduUUqSTp9XPri/YRWzVGMHRVtt9uHGD5r6dDISnKLwdZ21qjL54 A7kquVNU4LtfftviQjWEuyq6e3Dpg80QabahFaZYWbvai/ll/Dj0EmpyrbeF+13X80eXozXQ Ri4KkJfoXcvuS/hx5objOX5bwv2u4/mX0y6CoPESpuYqsJdm9Dr+3NdIeGl/68nWEu1Zn1/b k+TIq6l+elWE+zeh9PWukl4SX/ryfYl2rNzr+3J8maElOU63KfnWsLkX8Uf4cfWRpp0uFdPe tSXJ5xfUJXJtq53b9t6ZV+JfTB80OkavSqJutORjffxmPVvTXN+AEMDyPSaOt5M/zZLnH3M5 KOp5P+u/wv6ixnbs7lWFQbCppyOoVEIBjFQMQJVEKgJAOgCHVgDCghgAMAbSAAI61zHrQDCo tcQrECVRVYOgAFTyP9VRpu7c+dv3Nnrszzn9WWNULN9fDJwf83/Al7OnFcbx5C5nXmJMbxXU QOb6GeqbEDxQECGmIANNqeBttyOZB0ZstTqZsd+PZ0YMtRlhI0RZzepYhiQwyRi3278KOmPe YbvextdmOMjjTm5vVJ1bN665cuTk8ek7lWoCA6vGkSQoQlN0im30G215ZfnmtK+8S2RqS3sz xR0/L+xG5dp3YkrflUY/qSr1G61CNlONtYPMzblvy1172ZPyl9ireZ2Fu7UFnV9ByNTyWBB1 eZnFct99Nr610rvmso/pRX8zMc95fud+XojgU0Cgw5+UnXWSHreZjv7GNztW+zJ5rg/sNTaW YvEii4Tba7fV1c61ubm2/LuKsPlfDqOhSF6OuD1R5rNdZC7S6qSXpMWi5tZa7Tp7mTs5XX2b JRpn6HwK5RLrG4t7nsrsz4weT6hu245ZcuKDmySgpdfMrlGuE8HwkanFNVRW48GQUanF0n6G WKqaawfBicGlTOPIrxhisYmpWbGmsbrq3ou/NwfWJp10TWmXLn1FSamuaLVdVNF1aocHxR11 3s7M2ItcH9PoyHdLpxcVVuseFxcPxFc4tZ+g9eu82+bFipSph9PpwCSUl0hWuOQLo+n0xRpH H3Nh2ZUfHEpOn5hDVbU1wZzDjtMV0i3b3nZmpcMmdZOqweDOIdDZXtUfDeayLrfRLGzTyE6g mySlXA6MoOpEsa5ESKiOOL0/MqfT0gyL9pmzosWeXT0zcHxHvY+HuJcriVxe6XtKHLw7yucH j6zZ5pGtmF5Z25Uf4ZfxXtOOlx09i92XWuIUiQb1RqsmQbOqrHAg6xEpNDbqQE4K/CjzWTME XK1LpRtjLSyrdW69tEVLC7HUs0LU2sczPCbtvUvSXXGs1kwIRdJEq0wKwbxMqsi6Mk3iVJj1 1KJNkWxNiqQT1EHKpFsF0ZgSxk6LNm2FrRHSs3myNi14aq+88+g0whqfQcd9vR3009adq3XF 5GuMdKC3FIo31+VqCUM26VOM63EdbcRXuLjfYWbz6ijcflpWV1y+weynVTuz7sfayltybk83 iaxjp7OdvT5oU4llXOIqAk1kXLm3ve21CajbxnHT2so/hMCQYvMYtykW2dxcs9x4cYvI6228 0jOPhXEnF527mMX1PgziATKu9PyuxdhP9qqTkqRt3JZP7svqfrOHdtTsTdu7Fwms4yLbO6nZ wWMflf1cjr2fMLW7h4N+KmuEZ95fhkazL3RwQOtf8mcu1s5eIv8AtSwuLq4S95ymmm4yTUlm ng0ZswqIDAgQDACNKkttKk5Qf4kIqm3bnG56zevszW25Hs9RXLGKfLAuqnlxRVBd6BEX7KdJ 6eZv818t1bSV/wCKD1eh5mTy6K1amei38k9heX3GS73GPilnq5UaaYtcUvcaNk/zeuLMkO5F fdj7jV5fHxLsnHFwWPpODrr9ULzf9KM1zp6yyxPVbjLmi7c27d2PhzWFahGxG1bSiqLrGf44 e3GNsqZdqLXNM4Vyf5MJcqo9BFQefEUbFi2lFW406cS63CbTLKpqcYy5pMnGLeSZvjGCSokl 0EZbhVoszDeWRWpyyRdYhdtPXCifCpNX6LEh42rAsyzbnor3uznvrkbs5KEk6vSq1HDaQt3J T1NuSoyDuKGKbqCv1bqzdze7ExOkG4sWLtHchq05VbIRtWIdy1GvSi2VyKwKJXop0JPYuO7R Gb+GkepJFctWbdTLc3Cgyv8AeJVRrB5NMul0ZFtZe0yy3iaK5bpyyVGXFZy2OVCuM65mCV+S ZBXJvCpvxZ8nRlKqeJbfdHHqOVqda1Nm/rSAwzb1hS3EVhyIfuU/4GWiCiGIua0fuaPAqnuH LIg6cyLaRZEtqfiSeDE5S5lUrqjwEr7fA1is5nuvUXnUTRV4reSE5SYxVzFrklmLXF8SicW1 XMVu1J5ouJjOWc3OMLnJCc0sh+A+OAK3F4avViTovVXOTl0Irt9rnU6ENlcn3Lc5fy095qt+ WbqOUYw/FJfxHnJGMdc2sNrayljLsx5yNUHtrGSdyXM0f7RKTrdvL0Jv7C+Hl23h3nKXqRzu 8vr/AEXzx2jF+6u3H+XGgKw5dq9LU+XA6dNvD4fWxPd2reSivQZ8vaM3a3vWSMHLupvqRatr dfwv04Ep+aJcTPLzOuSbJ19mWlbK5xcV6akls4LvT9SOe99dlkiDv3pcaDFHV8GxHOr62HiW IZRj6cfecfTclnJ+gP2/OvpY8firqy8yhDJpdRRPzVdLMSsxXIlpjHGvsL4wWy8xk8kyuW7v S4UHtXZv3HbnLRh2ZSybNO6ViOhWlRqNJ41TZrxmMoxOd2WcheFOWbbLtVOIYvmzOZGpM9lX gLj7WNW4rl6izRJ5IkrMmTznu1OPa/21ROcbaq2zs7Ly7b6de6rolHVCalh6vojlS2Wt1lIs htVBadUmuVSzl1nxa+zvfgzNibNy28eTZZHbcooxeWZzhufj7etczMkrcnkmdRWWuSCcdPGr Mfe+DU/Hnrs5vgXHkhR2d3Up6lGSdU1wOlGDkyzwo9JPvbNzg1Zbvj3/ANW5WudFQqW1jxbN /hR6Q8JGby7X1anFpPRiW2giSswXBGrwkQnGMcOJnyt9WvGTtIqUUuA6Fkbbl1FqilkS1rCh Qb4E1afEuAmRWrS44k1BLJIYyZVCelYtIpSc3gXShqdW8CSSWCLlFXgLUupgXAPKpiPYDAD7 D5Tmedypt1H5pRX1/UebuM7fntztWofil9RwpuvpPTx9NXLbupf09o1iJvH0koo6Ijd7r6vr RXdwjLouJk7vdl1fWiF7/FXJxkVDurG+uqRKON2P3rf1CuYzu9ME/cFt0uWXzjQKhaxVp/ii KK1Qpzg16YsUHptxfy3CyK0ypynKP9olEZuqlJcVCfqJXMNdOEoT9ZG2qqMXynbGu2vx2vbE ii6uxejykpesszvfjt/UQ7+v79tS9Q4PtWJ804lRVHG2n9yS9TJy4/z+5EbapHTyc4k5Y19P /SApYY8pw9wXFSF1cppiuPsyfTbfsJXV+uuqQErirO90wTC3+pZfOLQJ1uN/Na+oVrOw30gV U/Ij0XDRNVu31zjUpa/ImvlmaP8A6PxW/qJRVF08CXo9pC4qQvL5Zp+0VfyLb+WbLby7e4jz WoCN7v3H92EvcK5hXouJ+tDfakvvWvcQk625PohL6iKul39x1fWPKFh9fvD/ABb3TCvuISl+ TafKUkajNXyX5m4XRIrl+hZfKUvqLZL/ANi8ucJe4pb/APWt9E5AaJfr3lzjL3GeX6Np8pyN L/1M+mD/AOkyvHbR6J/UIVbcj29xHmtX1jtut6xJ8Y09RNrVuLi+aH90ohKkLE+UmizrEJU/ b3F9+JpX+osvnBfWUSWmF+PKS95dD9fb/hX1i/r+isyX/rSXKaNUX/7KXO3/AHTPH9C4vvr6 zRD/AFNt84L3MUZ4/oW3yuFt3vblen2lS/0y6Ln1F1z9bcLnF/UEEJfmbd/dp7TO3TbyXy3F 9ZbH/wCd9LXtFKNIX1ykveX9f8iydXdu/et19iFaq3t31+8lLszlJ8LP1Ano0/8AjtOXpkRT sYuPJ3JXPREVqVFCT5XLrHDBxXKzJ+upBLsJc7Sj/akA44UXKMF63qYcPp1v2+4eePBuv1L2 IjWpBg83VbEeevD1HKtXJWnzjxR1vMlXw48KavWZfBqjhvcbO2muYs8VSgpLFRyfOPJ9KLIv 1p59L+qXvMk4uyqxVU80y6zfhdaTWl00yVc10dQm89UulbIPu6MJKvh19sH9QQ+Hw8MdVqvP jBkIxbwlxwr0rKX2k66u9gpd+nCS+JGsz3ZxfZdGUEv/ABTeK/7c/p7CajKf5UnS9bxty+Zc v/x9RUpNvVJVb7N1cJL5l0jXdUXjpfYlk0uRPOT1Xwt9E/ETfjRVdXZvW/r9PsYaVpdl9qFd UHxX04h3m5PN5jRzvJf7ejpOOevVJtydZOrAQzi6gBgAI63k1FOcn8tPacpHZ8tsJ2nOXxP2 Iucd2duzqqSYzL+3SydA8OayZrynu5YrUwZmUprMl49MKFF1MCDg3jqaIfuFyY1fg8Spk/Ce epliVMCKuxfEkpIigbBDAjkMaDMCIMYMCOlcg0LkSYICLtoShQnUGwFUrlOayjUuoKjAwbvz B7VJyhVvgVPcWfM7UtvcVNS9VOKIearxJOPyo87ur07Fpyty0yXE666yz4sW2bTDjOlWk6qu BBlKm4limmee64fQ15JtMXummCIjqZdcmAARTRptMzIuttIlb1vV0bbNMGYbczfZtXZ92L9O Byr2a7THVZVJVZzd35h8Fv1nTflN/cYTmox5RxZZHyfZ7VVuLU/vOvsM/c0nrm+0cd+X+3R5 aKlcdIpyb5Ym215PurmLjoXOboegV/QqWoqEehFbk5Yt1N/ct7dHDx93Mj5JFfqXKv7q+01W vLtvb+HU/vGkeRqZves247HFKKpFJLoGQ1xQnd5I3MRw222271MKFLuSZBtvMXZnxXuUVxIO 4uBUBnLWEncZFyb4iERQAAA0E5UVOYq0K264sZTCi9ZXeTpQvs77FQ3Houfb9pl3s6JQ54se 0sO9FR56m28lyN68dszr/Rx321m2L/V052q4rBvismVOONGqMzW7t3ZPQ1qh8n1xf06TfCVu /DVB1jy4x6+RjHp6ssrjQrceKzNUoOOeK5/aVygQZHBp1jg+RKE1LDJ8i1xK521Lr5lTCUJy suscuMWWqMZqtnFcbb4fhMym4vTP0MnRp6ouj95ubYZsRlDNxxi8+afT1lSfP6fRm2N1XX2u zc58+sovbSr7C0z+Xn+H7D1a8me7FiiaVyDjzRxDsQlpdHw5nN3ENFxr0mt1iknauO1JTXAg BzadtNSSayZFmfY3dUdD+HI1HaXMYKo6pipXINM+QtkWSk1QrdS5Rl0CdtmLtGvGqbnahXk6 evH7Tp7dLdbd2n8cXH08PakYlbdGua9xZ5Zc0tx5Yo49tvmm06OdtJtVtyweaL5KmQvMbHh3 5acKvXH+bEIS8RVWfE6kJdKG6A8COLI0eD4BVSweQgIKLm2oqwxXIqi8DWpUKZ20nWOTCKkD 5jpQjwIpkUweRGoEm6irxEShB3HSOXMgSq3RZm6zZ8PF4y9wWrStrDF8zRCNTntt7O2mnrTj CuBrhCmArduhc6QVWea13Rk1BVeSOfjuZ1yiufIsnN7qWiPd95XuLsaeDb7q7z5v7DU6fNi3 1V3biklbt4W45dPSVgBXK3IAYBCAYAAAAAFKgAGqzvrlqifaS9a9J1P3W38wWncx1cprC5H0 8V60cEOksuB0Nx5Rdtxdyw/GtrPSu3Hrj9aqc5OuRu23mNyy6tttZSWZ0Z/tfMlruLTP/u28 JfzRyfv6S9L8EcERt3fll7ax8TC5a/7kMv5lnH0+sxrHFEswpEZw1xaJjUW8ETOBVtb1Fpea L59iakib8u8RalLTPpyKp6o/l3Vpml6zWZezDXt5aLjjwzOvvLtdlKPzONv+0zgRlhGfLBlu 83iuW1ajkmm30mcZ2Ks3e70twt55NmjyG94firnTE4zNXl9125ypyJjEsdtOmzvK/jiy+5fi 7dKnCV2bxfEs/dUg08zHi9Hk2eMorBg9xHUqvBnK8STG46szXiz5OlPcUVa4ZFL3KWJka5kd UchiGa2fvEQe84ozJCbSLiJmr3fnJJJEJTm8E6FL3CjkUT3kk8EWa29ozdpO7a7k+LK5Ny4m dblvFoPGk8kXxp5RfLHMhhzKXKcjNR6qYmpqzdsejc2uBFyXFlXhyeVSX7eTHT3OvsUrqjli QV6pb4GGaXpIxsRtd6afUXOrNzn4Dxcjf5k34cKY4/UYdVrJVbOpuLU70IKEXN50j1EL83Fl VquSI2qydEdqHl24edtRX35oth5XKOcrcPwpy+weckTpnOXGVuTJ/t5PmdteX2137sn+FRj9 pNbfawzTl+Ob/gY+4udXCe2lTkxWdjN5VfVid/x7FruxgvQRl5ouDfoH3NmfKd8OdDyu88oS 9PZ95evKbnHRHrlX3E5eYSeSZVLeXXyRM7HnWiPlkV3ri/kh9rLFs9tBUbnLrlT3GB3LsuL9 CIuE3m36yYvunlXRptLeKtwrzl2veP8A3KFvCDS/Cqe45fhx4te8dIrmMe9Run5pXmyiXmE3 kilU5CcrlaQt+lkxqs1t7JvdXpZEK3pZsug7rjSVuKl81X7iPgXHmxdtZ7NTj2v9qrwZPNh4 MFmy9bXmyS28ebM/cjc4d2dRgiE70YYJVfI2qxBcCcbUeEfYT7sbnBfWxn2t7bySd1S1J4xx 0tdDRBuTb0qi4I3aHyDS+RLzZ9Gp+PPWsWi4+Y1Yl0GzS+QOLWLRj7lbnDr8WZWHzB7ZSwk2 zSlXBEvCkZ877tTi0noyra21wJq1FcDSrPNklbiiXe+7U1k9GZRRNQbyRoolkhmctM7g4qrC MHJ4FrhqdWTywQyIK3FcCSSXBDAmQCGBAngsPQVxtcZFoi5BlggACAAAACOhVqyQAAAAAAAA AAAAxAAwEAHr3q6ApLmvUPQh0PtPkPNebzb3NHjpil68TlyN/mr/APaufyr2I58uB69e0cb3 VPKvQyxIg8U11r3k4mkVXe7L8L96I3cfG6YxfuJTxUvwz95GWc+m0mUTWNyXTa+ohB0Vh9LR O3jct/et095TF/k23ymwHNUt3Oi4id6qldpwcJiurC+ulP2juYyl962mRTb0zb5TjL0SCHYc fuXHF9UiMsU/vW1L+yFx99/5cyCVpUlCL5XIFUXS1afyzaLW9M0+V33orkqWrkfknUom1S5J ffl7UJZV6I/9LJSf5jfNwl6yMVTD6cQFOuia6LZO73rv+XH6iE8rnTCDLM5tP4rX1AOCrch0 2yqHcsy5SaJ2pY2Jc04leVlfduATkuxfXKSftLF+tZfOKQ2vzL0ecalalSNifJtEFVPyJdEz RNVvyXzW/wC6VyVI34cnq9pZF/nWX80KAV2qN2XzjKBXDGGnnCS/sslbwhD7txolCNJRX3rk PWRVlp6rq+9a+oqrXaxfKf1E9s+3YfRKBWv9PKPGM0aiVsf+pf3of3TKsdsuif1GlP8A9m0+ cImWOG3muU4mmWtf6qnOH90yr/S9U17jTGX/ALNp84x9xniv/XuLlOJFal/q10wX/SZV/pq/ LNe40x/1Np84R9xmh/pprlOP1kgvu9+8vmhGXuHbf5m3fR9Y2tV62vntqPsKYSpGzJ5xk4s0 gS/Ivfjj7y+H69l/cX1lUlSG4jykn7S22vzrH4V9ZL+v6Kof+nfRcXuNEv8AUXvwP3Gdr8if RNfWXy/Wufetf3RRXHuWH95/USu92/8AjXvIx7lj8T96He7t/wDzF72P1/yJ7jO90RhH3BLG dxf+Je5CvurvdMYP3Dl35PnZ+oBLCkv/AAv60OXY9C/6Y/awpWkX8tuP95irVpvkm/S3L3IA ktPow/s4e8XNL7y9iYNVXX9PeNUw/FdfqQHP3s1KSrmsF0ojaxRRvptK3GWeLT+68iyw9WR5 eX6no4/pWSt6k0yj9umuk3JBpzocXVns3Wn4c8XwZpRlvWm3VYNFlm74kamVaUSRWmTTKJoZ FEkBIZEkAAA0EShByajHNuiPUQ2ytwUF8Kocvyfba5u/LKOEev8Agdtm457X0UO0+DBRks2X jYxGGbtch4rNF+AURPGLms9E80RduEsGamiLgh4/Eyz+BClBeDTJmjw1wErfSOvudPZS4zWQ a7i4FrUhOqLmnRX40lmiTv45Ek+gXZeYz8DHxCvxeZNXYPiV6YMeiI8omKt1ReQynQKUJcGM wxV4MzqVxDV2SzKLqAilblMf7iFQZcvcSTuTxylRnlfNZRmnhnKifUekv2lC9dmu7Ptek8dv L0q+GnhmzRGOWC9JFMcidnb3Lzpbi5dSJnDWMkpNE1NM6lj+nd5ezioL7x1tv/SUFjem30LA 47b6f/p31858vi8umabW1vXv04N+g9rt/Jtrt+7BVN0YRj3UkcbyX0jt5yPG2P6e3FzGbUV6 zp2f6es28ZtyfS/sPQMraqebk5N/SrN2S1srVnCEUupFz021V0SKdxuo2uzHGRzblyV11m6n LXi3367XoXb3ar3mDfZtf2jG6t1k6sBHq14tdey+ePph1QahCOmJGbvabkyIxGmQIAABAKqI GIWoWoZXCQiNREyuEqibEBMmCAGRlLSm+QVldmW5uSksIxomzbtvyrShHFvj0HP2duV2Txen 4kuJ0pUgtKxk8z6XHMR83e5uSk4vs01Gd27m3fi23R8/tXIuc9KxxdMllkKkpur6fevqRrfj 1379/dNdrr8vZo2+6jfel9i58vCXV9nqJytU7vpi/pgc+7ZjJVTx5cP4F1jfOP5e4q0vj+KP 4ua6Tw76XTpt/V3ll66rWk/QVtGycFJKVar4ZxKZRphL+BzGaUFLBlPatdMTXKJBoIrwmq/8 ScLtOxdWqPAqlbcXqgOE1PB4PkalwzYsv7dXI6m68riz/nX1nH8xtShKLksWvQ+p8TrQnKy6 wZa7dvcxcYpNPO0+fOL4M7679MI8uW2NtdvuluLfTwO3Y8u28MYpzaz15rop7maXLCiy5L6c fed9dZZnKWudtvKpWnrnNJ8om52LdMF6X9PWTrhz+v8A4r2izzx+n1r3HTEnZnKqPVRodGTa o03xwfWvtQ9NWeTbpcPVr1irwyXhtGmNuoTVItrnRGWmVRMNt+DfXKuk6ag/Uc/zC24yUua9 xL7sbzo37m2rijJqtOy/evrKFtI5qNGarEvFtJ817UEoPM6WsadZj2Yp7SrrUqntZxxiqnR8 OVBeFInk6eMcaUnF0kqMjrOzK1qzo+spns7cs449BfJPCubVMi6PqN/+3JZSY35dbSdZOozE 8K4004uhGpfOHCWaKVanJ9lBlBsSq3RYs0w2jb7T9CNduwoLsqhm7SNTS1jt7bjP1GuMMKJU RcrbLYWzltu7a6SKo23kaoQoSjboE5xgqydDjbl07JalBVZxtzO5euVVXV9lG3t7l0pSPL7Q nuVa7NrGXGXLqN6/xvvXPbr36IXJuzHw132u0+XQZkg6XmAc7cgYhhAAAAAAAAAAAAAAAAAA 4txdYujEAHR2vmtyy6t0fzL60ap7fab5a40s3OMoL8t9ceHWvUcSpK1KalWDozUqL9zsL+1a V2PZeVyOMH6fqeJdZsqOLNm13l2ytLxi+9HOL9DLvBsbj9Fq1P5JPsPqecfajNmfpGSpC5bj ej4dzLg+MXzX1osu2p2ZaLsXF8OnqeTMW5v6exHPizElz8UYFPw9dqeLWGHNFU9UcJJquVTR tnC1uIzuYR58mdDzCcFZlCTjKTppWb60ejMlnxMdMuUnqSZOzc8K4pcOPUSjapFIHCKzM0lx 1brtxRqkY47yro0arTlctxaVeHqM89rBS1Tkl0E1x/c77Z6XU3f5IfjOWCiWK9BKkYt9OQvF fCKJ+yeU91TlcfCiMdyElLJs6HjSXL1Ce5bwqvQjUtnozbrfWqY2Z04k/wBvKuPvLY2b13uw nL+Vl0fK9zL4FH8UkiZ+J5T2Y/BSzaI3NvCXxHVj5Pc+OcI9VX9hbHyqzHv3JP8ACkvtM+cn ql2+DkRhCKpiwd2Mfhx6ztLabOGcXL8Un/Aa3G1s9yEF6ETynxPOuLC7KeEIV6k2aIbXd3O7 aa6WkvedKXmvCNfQUy8xnLJMmb7J5VQvKdzPvyhHrlX3Fi8lj/iXv7MftZF7u7LkiDlelnL1 IfyZy0x8r2kO85y65U9xYreztZW4fzdr3mDw5PNv1jW3rwFz67LJb2dD/cbdvCGlfhS+opje 8C3GSxqqFCsPgvqLXDXagmSeOL1+bXht6zujLeXHwp1sg9xclx9SLFZS4+wfhLi2zHnpHScG 7O3cebZBw+Z+01+FHkSUUskifdnpGp+PfWsSjHhj1Ikot5Qk/YbQJ92+zc/HnrWPwrryil1s fgXvmS6ka6VJ+FIzeXZucGjF+2k8JTfoQ1tIrNt+k2eFIasviZvJt7tTi0n9rKtvBcCStxXA 1K0l0kZKr0xRnyt9WvGTtFNCxWn1FkYKOObJktaVKz0jVlcywCZEFaiRnpjgliWioq14kyKo Wq4vIuWGQAMgGIAGUyjKb5IuAZEYxUchjEAAAEAADKEAAAAABAIYAIBiAAAAAAAAAAAAAQDA AAAEADAAAAAAPZABVuL3gwcqVfwx5vkfafIeW8yf/s3fxL3Iws1XrdyNfHp4j7UtLqqsys9m vZxvdHMnDL0Irr9PUWt0j6CooeLf4bgo4tdNol8X/wDUXsFaVZWum217yqdp9qw+hxKaUstf LcJ23SFmXKbQpqkL0eUk/aETuYyvLnBP3BHGVv71tr3jeM302vqI26VsPrRFRgqq30wnEHjF 9NtP1MdrBW3ynKIW13Y/jtgF7FXKfcuIdzGV1fNBSCHb8OvxRlbfoC09Tt1+KMrb9BFRbrR8 7a9jJcX1/aQtvsQ/DOJJYunSVBnq6bXuJwxna6YNEYYuPTbkvVULTxsPrQCt9yy+UmgmqQur 5Z1IrC1HouFk41d+PpAtjjuPxQ+ozf8Azp/LMvi/zLMucaFVPybseUkBbJfm3o/NCvsK1Ls2 Jcm17S2ON6P3rf1Gf/57b+WbIHc7MLq+W4n7SU3olJ8pwl6x3lWW4j0KRG5jV87cZf2SKf6b T+S77xuNI348mn7SN7/Fp9yZa8bl1fPb1Fgbfb28uhexkNNFuIcnX1SFJ/lWZcm17S1x/Ovx 5xk/rNfr/lkRfb28/wCX1MhTTbvx5Ne8Sf5NmXKbXuLJrtbiPRX2l/X/ACiSl+dt3zUfeyuM aWr65SX/AFEk/wDTy9H/ADA//pX07xP1/wAqmqK7t392PvZTp/Ku0+CakvWTrjt30f3h0w3E eX/5Cfr+olJ1le+9BT9wW5fmbaXRT2hHGVv79px95XCXYsS5Ta9xUH+Bd6Jr6zQlW/Hptf3S i5GkNxHlJP2l8W3fh02vqZFZ4Nq1Zlym/qJ3FhuIvmn/AMxWv9PD8b9xddVJ7nq+tFQTxcq8 bKCSrXm7cIf2mOaqpUz8O3bX8wSkq6llqbXVbVPeRRLi199r/oQpKtUuL0r3e73hkqclFfX7 2SjhKC5y0/8ALX6wK5Som/lUH6Kle4krUJV4Ta9E0StrWoV+JSsy61kZr91OduE1WLUfE9VE VBO1tZUsbqUoyiqRnFYaeH0p6THtezKUa10uleZqlByvOLxcEoeobs0aksDx8l/lXq450i1E o50JOvBEUmqtnHLrhTfwTZj2r0qhq3LoqPjgiiEdLKla0yaZTFlsWQWpkkytE0FTHUjQaQQ6 1NG228txNW4ZvN8lzIWbMrslC2qyZ6XZ7OO0hRYyfelz/gWRm3C63ajZgrcMIxROgswTNuQf QHABJgSEmMVAGJgMAT4B1BiLFAPoCiAQDaRHQnmOtR1qBB2kLwSwdQKXba4i0yLkxuSJiDO2 1g0GsvbSzIOUTNmrUyq1RYtEXwG6PgKhi7SdrW5rb3U7nbKarHPKh563/ScZycr1xpN10w+0 9PVIi5o53lx6tTSOdt/Idlt8rak+c8ToQtQtqkYpBrFVnDblnzdJFlSOpEAOV5b6LhLULUxF V6/Gyqy9Rjy226LhY5JKrdEc7cb5y7NvBczPf3MrzxwjyKT0acWP5b9b7GQIGyOtHoRIRFzF rZMxcJiIamInkuE6oWpEAJlcJahVYgJlcAAERQACKAAAAEAFQijdS02304F5VKCuXYQl3VWc upG9JnaRjkuNbVtm3+3tRXxyx9ZJJvCPW5dRZRzblLN+7kgawo8uR9SR81XG2o4RVXz9ASjX N/Sn2e8k36hUl9Ppz9xpEXhw+mf2IjKClg10J+z7SzS19Pp1kXTnT6fYSyWYrUuOym1cubV1 hjB5xfdf2M6Nm7b3C/Lz425Zr7TE6cq8/p1YFcrEsJQqpLHDNdR4t+G69dOs9naby9+ldCVu iqsV7Spx4rIjY8wUuzf7MuFxLD08jVctY1WDfqZ52mRoquWlLHianHhSj5FbiQZo3HF6Z+sk 48UWSgpYMo7VrpiXLOGmN1Ta1vTNZXF9ZKUcdEqRk/7L6V6eBQqSVYkoXNK0SWqHLl1HXXex mxOaeCSo3/xXtqgrwj9OK+tDaVNVdUMtXGPWPS28OOT68V0YS956td5szgaa9XD6vZh6C6EM CtKuK9HvWPXVYGmFKYZcDnyT1deO+iUI0K3HVT0snO4oRcm6JIxLzPbuOE0ee12jWoGTzKzW zq+R19DHHzTbpVc0VX/N7E4OCrJSVMhksQ8rn2JQ4w7S6jqNKlTh+X3f2+6i5d19mXSnh7jT 5lcv7fTGDou1CXXH7Ub76/Jx16bY92+d2FvGTojPc8xsRXeRw5xncxuSbCNmPIy7YroS81tV 4v0EJ+aR+CLZl8Fchu3REzGuq7/c5P4Cq5vLl15URKNupLwh5LiqpXJzpqYJekvVqvAkrLM3 YmquMHmXxiyyFqhNpRVW6I53ZvBRgSpQrnu7cVnXqM7vXLz0wVF7TOLTJ7zdu1GlvGXF8ija p7nt3HhHNl07Vm0tN3F/KsSKuxktFNMFior6zpMYxJ193K3F639lk7niLRDCHtZU9tVdnMsW lvMnpXBs1JGLcss7Eo4pYFRuk3HGpW3CtHEYRlAsdrPTzK2miAAAIAAAAAAAAAAAKibAYTIq FAqTj2ioULbm8DfZsaERtyjBFnit4JGbcizSJqgtzC/tdPjR061WLzqVJX59yEn1RJZYNkPM PCXhXaThL4Z5fwKr3lEL3a2cqSePhXH/ANMuPU/WZv8AbN5ddZRS/FJI1bfyy/ZpW7BLljL7 Dc2k70cq5b8Ju1di4yWcZKjK1GEe6j0t+anHw9zGN638L+KPU817hW/Ktm46rEHd+7KT1erC v0wLmYzqjzbnzYRjK53IuX4U2d9bnbWnSEIRa+6q+0Jea8I1p0GPL4K5dvY7xx0wtyUXjj2f eWw8l3HFwj1yr7jTLzCbyRW9zekM7CUfJkv1L39mP2ssXlu0h3nOXXKnuM1bss2xeFJ5tv0k /l7jareytZW4/wA2PvJf7jbt4W1FfhX2GFbVPNE47dLgZuPXZuabXtKvn5pJ5VZTLfXZZL2k laSJaEZ8tI3OHes7vXpcSLVyWcma9C5DpQn3Z6Rufj31rH4Fc8faTjt0uBpAz92+kbnBr62q VZJK0kWAZvJt7uk4dJ6IqCQaVyJAZu1vq3NdZ2kCAAMtBCh3I/ze8YoLsJ8nI7cfbf5OXJ30 +ZgAHF1AE1bbJq0lmMiklGDl1F+lDJlSjFRyGAGQAAAIAAAAAAAAAgAAAAAAAAABgAAAAAAA AAAAAAgAAAAKgAAABDEAAAAAAAAIYgAAAAAAAAAAAYgAAAAPXKU3wPFefea/urzjCVIWnpj0 y+J/Uex385W9tdnDvKE2vUfLXik+B9ue75Dt+X3Fc27xq1LGvSWGDyl43I9CftN/M9OvZy27 oMsmuyQeZOfcZtlXHvrplc9xCz/gP8SJrC5D8cl7Cq26QtvlcaKqLws/huF1xdu+uaT9xXNU t3Vymn7S1qt2X3rf1AK3jctfette8rtv8uy+U2idp0dh9a9pXTTa/DdAJdmMvu3Scnpc38tx P1ivZXlynFjvZ3uqD9xAPsYfJd9kgXYaXyXWvQxXv8R/dtyC9/idduRFEVRU5TmvYSjmute8 Jd6X+Z70LhV/d95UFpY21z8SIrborNPmkSXZcfu3WvWJdlR+7daAjLC1PouFzX51xfND6iqS pC9+Je8uTrfg/mgBVF0t2ZcpNE5qkr8PSVf/ADLnGZfLG/NfND6gI23+bYfNUKafkSXyzJwd I2J8pNDlGkb8eUk/aBOeN6S+a39RVDtK196Molqxu2W/ihT3lMHS3afyzaIBYxdfite2Jda7 9pv4oOBXBUovlnKHokEHSNl/LJx9pFLPbJfJP3mnPd0+ePviUSjhfhyer1MtjL8+xPnGK+o0 imNf2v4Zo0SVb9xfPbr7CmEfyr0OTXsZfH9a0/mhp96NMqK/k2ZcpyXuLri/M3Eeak/bUzx/ 034bnvRql/qLv3rbf/KKKXhbsPk5e9F81Se5XQ/eUP8AQtP70vqNFx/mbnqf1E/X/KoxdJbb q/vFEuzamvkuVL4d7bfT4ip/p36/Mv8AqZf1/wAosu9+/H5oKfuY7TrcsdMNPvJJJ3kudn+6 V2P/AJ395r2gVJ/+vFcrj9xov97c/wAq9qKtP5Mo8fFX1l80ncnXJ3MeqCqyKUnpk38rcv7E aL2kXFJKPKEY/wBrtS9gJOS0cZaE/wCZ6n7B4XJOnxPD+bBf8qAhOXZk+hv6esL1V4lO9CUL i6qBXxGo/wDchOnXX+BCFzU7d15NeDc+nUWInKkXOXwvReX1nP2svEuO5P8ATudh9HL1Fm9u StWlaXe7UX+FSDa2ksF3Lqw6JL6eoKhByV+TlnXS/RgbLrUIOTOc9xbc3m5VbfBVK4SnupVm 8FkuCPDv1tevW4mHYs4+hEJvF0C1ZklnRFM64xRzdMst/wDMlhksEWQ7S6SStklChWAo0JpD SJqJFCLEiKiXWrc7r024uT+6AkjTtdpc3MtNtYLOTyR0Nr5M+9uH/JH639h14QVtKEElFcEa kYu3sq2u1t7SOmGLfek82X1FgOhpzLgOoNVE0AxUohhQAyGkRxCgDBMKgljUATqMWYZAOoqh 0ickA6BUhqE5Mzdo1NatfSR1oqclxZB3EcryyNzjXOfIjVlTmyNWzjtzuk0i1yRFzRWBxvLb 2awk5sVWxAc7tb3q4ACqha0c7YuEgIOYtTM+UXCwVUVN8zn7re/Bb9LLrna41Xxadzv42uzD GRyp3nN6pYsrEezTWa9u/uYSc2KrEBvK4AAAAAAAgGIgAAAoAAAQDEAAFAoUIBgBEBiAQ7EN U5TeSpH6xGjapK1qbom3J16z0/jzO2fZ5/yLjXHvU6PPi8Si5etwzdehBcnK7lhHONM3T6iE VBZKqx9X09J9F4FUt4+EXTjw6WKM9zewUUubk/Tl7C+FH+Y1V40JuWOP0xIqvwcO3KvNLLmW KMFw+lSKf09gZ/TmvtAknj1EVJ58/wDiFa48/wDiLJVX04kyuEJ21cb4PmK1fubR6JLVb+X/ APEtWD6uvh/ATSo01X+H8Ok4cnFNus6bOmu2Ol6xsi7d+GqD1R/5o9ZXKLWeK+b7TE7M7L8W y8VXFfXwZs2+9je7M6QuP+zLq+w8dllxt0rp8Z2QlEg0apWnHCKp937CpxrkZGOVtweqHqHG anhky9xKblpS6+YTBxlK3KsXR+x9ZdFqfc7MuNt5PqMquOL03PWTcfUbm2GbGyD1NtVqq4Pv Lj7+XMjf3EdtDXLLFJc+XvKo3q0V2uHduR7y+1dBDf2J34wWDadYyXdnhTDk/us7+XlMGvSu VuNzd3XedI/KsilWTarOnCmJLw2efyevxY1ZLI2lkaY2myyNmhPJfFju1jSSzVH6jsbhK/YU 0s0prrjg/YYNxbSin00fpNXllxO1K3LOD9jwf06DppczHu8vJPHbPt1ZfDqEbfI0yioNwbSa dArHmjhbXr6KVboSdqqHK9bji2iiXmUE9Ki30iZvYtk7rlZ5E4265mf98uTIy3c33VTrGKZj ZhHMg7sY4to5O48S7StZF0ds4xUp9ldJfDEzaz5XPZpnvVlHExbmVy8uL6EX1tRyTk+nBC8e eUaRX3UanTrIzttL0t/oLW3VqKne7PKPEJ7mTWmC0R6M/WVOrdW6vpEXGetYu3TE7BYE4sgO tAwuUkTUyhSoSVynAq5W1bzEyvxnyQfuJ8MPQXB5J1wrQhJ1L9ttLu7ppklqbSrzXPkZMcnm hYmTFQG6Ea1wWPUZwZSFqRbDZ7i53LU3/Kdfy3aXrC/NtpOMtcayjj0S6CdPWnVw9SeQVOp/ s05ScrlyEatukE3SvqLY+UbaPfuTl1Uj9pm7ajjVZFySzZ3ltdjb+DV+KTZNbrb2v04QXVFE 856Qcbabb9y5UrhTBLP/AIGm/wCUXoXZQsRc7apSbpH3m+fmjeCqUy39yWSL53GPEZ4+S333 3CP81fcaYeUxh37v9mP2lb3F6XQRpdlm2T+VGtbPbR7zlL009xJT2tl1jFJ83iYlt5SzxJrZ vijPbvs1Ndr2la5eaJJJNtRwiuXUVS8zk8kypWESVpIzdtPW5bnDvfRB7y7LJEHcvS40L1BI lRE+5rO0bn4+3rYy6Ljzb9ZZbU4ZMuCpPu+0dJ+PPXZZO/C+v/bhVr/EjhNenj1MjLYNJztN XIc495dcfsqiNQhKVt6oNpo3OaXpv0+KbcGOuvX4VBQWaHpRp8a1ef560T/7kPrWT9jIXdvO 0teEocJxy9PL0mdpv3l8p8GtPt248cbe1VUQAOhwy9GMdgIelhpZAgHpY9DAiBPw2HhMCAFq tMfgkyKQLvBH4SGTCgDR4aBW0MrhnHpbNCih0GTChW2RhGvZ5SkaSm335fifuOnHfr//AIuX J/Z//JJWlxJqKWQwOOXUAAAAAAAAAAAMQAIYgAAAAAACAAAAAAAAAAAYhgAAIAAAAYgAAAAA AACoAAQDAQAMQAAAAAAhiAAAAAAAAAAAAAAAAAD2MoqacXk1RnzV7GVm7OxcWMJaV08vWer8 z83uLZTlZrG92VVcm8Wjh7OMrk3cuNyks5SxdT7faPkI7XZS27lJ0o1TAs+I2z7rMXFnfj66 ue3dGhKfdI5jvPsHVhW3SUXyusqeFuS+W4Tucei6gvL9dcpJ+0qncWN+PQpEoY3bb+a3T3ik q3Zr5rdfYK08dvLrj7SCEHS3afKbQ7qpG90XEyLwstfLcJ3sr/XFlQX873VB+4J967020/cF 7O5024v3D70302vqIpSxr02fcRuOqm+cIDj2vD6bckRzg+m0vYwJy70vxQfsE+7J9H2DnnP/ APWwllJfdYBdw19FyL9YXf8AE6LkWK7irn4bch3v8b+RgSmsb8eqRKv5liXRT2hSt2a+a3X2 Fal2LMuUmgCn5V6PKVfaXV/OtP5oFcljuF9MwUqeBLrXtCKlhYj924XzX5l9c41+sqkvyrsf lmn7S7O9+O39QVDVT9vPlVe0rkqW7i+S4mDf5FuXKbLLq7W4jzWoURuYO6+UoTFcwhL7tyv9 ok+02vnte4jLtQf3oKXpiZVe1W/dj80G/ZUpUvy7M/lk4l1t6tzB/PBe6hnp/wCs6/BP3mka KUnuIdDf1iTorE+UmvaTi67l/ft/3SjF7ZP5Z/UWJU2qQvwXCSftLYOt62+E7en2UBxrfmnl chX2FKnS1auL4JtfWaRH/wCZVzhc96NM3W/eSznCq9SZXK32r9rhTxI+jEnaxuWJ/NHS/RgB CM8NvJcG17QmlGF9ffXvZFdmyn8lz3/8C28qvcLql7SCxYX10Wf7pXYVVt19+X1E8rut8LNf +UjGsFGmcI4fjn/DEilbapFvLXO6+qI0tSUXm8H+KeMvVEIqOWce71xhjJ+lkdTUXJ5q3Kfp m/sAevBzWdG/TN6Y+pBqVpxfCNzS/RGhG6tKuRXwxtSXUiM2rk5R+C8lKL5S/wCJqREJKUYu C79iWqP4SyietruXI+Iuhp4kISfZutdqD8O4uj6YFe8k7MFbSqlKal+GuAoyyuO7ce5WNH2o vkbbMFF6I9ybjO31p5fUZHJQkrsMYSwkjXtkrclbb7KlG5CXRXH2EV1tz/SNq5ec7d1whJ1c dNX6Gb935HZuwtxsvw5Wlpi6VTXT76nWbUsUHA8Lvlx9r5LGL1X5a/uxy9LLZ+R7SeSlH8Mv tqdJYCpiDNceX9O233bkl1pMg/6dayur+x/E7jqHEmDyrhL+n5f91f2P4lkf6fiu9db6opfa dkBhfKsFvyfbW8WnP8T+o2xUYLTBKK5JUJdAuhlTOTTBqhHS1kwc6Z4BEhA2gT4ASWGAlQMh MCdRZiEmA0+Y2R1CcjPlGvGrKVFUqdxLiQdxcDneXWNTjq5yE5FDuNkW2zjef2dJxxc5riyL uLgVgcbzbVuaxJzZFtsQtSOV3t71rBgR1icmY8ouKmFUVVYGfJcLNaI6yIGfKriHqYgAzkIB gRSFKSiqvBCuXI2lqkzkbjcyvvlHkdNOO7/IWbreO52YYRMgCPdrrNZiIAADQAEADAQEUxAM BAMAEAAAAAAAAIoYgAAABFAJjEwiLdFUtcqwt2lk465LmuXWUXMIvqHbdXNvhot550VcOR6v x/V5fyPSCc6YZyfqpy/D08yN1PC0njLGfOn0yZO3FN6311X1fXEohOrd2mLyR7Xlap0VFy92 XuBKvpC9wSyH9PrAM/T9eIdP05h1fTj9Kjyx+mH8HwJlRl6Pqx93MO7j9MOnq5DpTDl9XRks HxDLF/SmGfVyM5AuyqP1dXR1cxJcHjT05YPoWBJqmD9Kp6Hhn6wboscefH7r+6gIzk10v19D xy9RU9r4scKauXP7OslBO49Uvbj9MjQpU4ZcH68sl0GdtZtMbLLdezNY3s7P5d9OUVx+KP2o 3NRnFTi6xeU0ZJrxWovHlw9XJPmyrTd2ktdp1Tz5NdK+s8m+l1+OrtLNu3f2bJR4PB+wrcS2 xuLe57McJ8bb+rmOUGssVy4o5jJOCaoyjtWumJtceKxRXKNSCpNSVYkoXJWk0sYPvQeT+nPM pnBweqOBOFxTweDNSs2NMrcb0dVpt04PGcP/AMo9OaOdc3LsvTOOPBrJ9RqVYyUoNxksmi1y t7paLqUZv0Rl/wDi+lYGsTbv3a13uvT0cz99LgjNd3t3VROnQbdxY/bPtQbp9PoynxLbdfDq +sziS9dXW7Sz6ijduTajLuvBl2z3Hg34zaqn2Zr2Mre6ku7GK9oOMJJ1dG3qqJ0+DnvirfNd pKdy3dtptTVH1x/h7iv9lJLtunWzTt9xO/Zlt69uK122ujNek52rVi8es3vbes7JpZJj1XeD ajnNVIeBZctUpvqSIVBsxM+7V2+EXu5bXdjXrYfuZcEl6CzdQ28YRdppzk60i8o9PSZtEnkm LJDy2vZN35vjTqK264vF9JYtvdeUWTWzuvNJekz5az2Xx329LVUISuOkeCriSvWJ7eWi4qOi l6GabG0u25qcJLUuipfPy69fm7lxtylm6UL9zXC/a39Zj5uXUKnXj5P8z9bLY+VWV3mY+5E8 Md9o4VTVsXZ1Px2ks8VWvR6TrrZ7aGar6h69tbyjH0j7ntExr/l/w4MlqlJwi1Ft6VyROG1v T7sJP0Ha/wBwtx7qXoRCXmbeSY87fQ/j8XPj5VuZfDT8TRdHyW58c4R9bLHvbkskQ8W9P/gM 7J09mmxsP28ZRV+SUu8oxX1kY7DZW81KX4pfYZ/Duyzb9Yftq5sXPrsSW9o1atna7tuHpVfe S/3OMcIKn4VQzLbRRJWYrgYt19dm5xb3+2pS8ynLg/Syp7q7LLAtUIrgiVDPnpG5wb3vhm1X p5ti8Gbzb9ZqAn3Z6auk/H99mZbZcSa28UXEoxqZvLfRucGvrlXGxHkXKxFE0qDMXk2vq6Ti 0n9qKtx5EZR1OiVEWAY8re9bmsnaYEVpwRVclXBFkngUMkUgGk3kWK1zKKgL1bRLShkZqMNL NVEBMmGdW2TVl8S0ZMmFXgriO3G5YeqzKnQWCNa77a/TWdtNdum0EZ2brpcXhXOrsP0cPR6i U7Tt4yWDyksU/SRcVJUkqojB3bH6TrF5wlkzr5acn1fx29/Rzxvp9P8APX29UqCoicJ2r2Ef y5/JLu+h8PSE4StvTNUfSc9uPbXv2929d9du3f2RAAOboAAAGIAAAAAAAAIBDABFMP1JL731 FxQv1X+L+6duLvt//GuXJ/b/APyi8AA5OoAAAAAAAAGACGIAEMQAAAAAABAAAAAAAAAAAAAA AAAAABQAAAACAIAAAAAAAAAAAAAAAABAMQAAAAAAAAAACAAAAAANu+dm3JzhXTBap2/vvuxM lm3KEUpd59qT6WY/Nt3aluN2rkpKeqKtxj3W44YmeW2t+Cr3iOSp2nwT5cz7t1y+Nl07lxJx hzZneBxLG6jCdZJv5aOlHz6Tu3FR+k7cfSYY2QQX6qPoCOWItx3G+g6sqruCudE4slcXbvrn FS9wrq/WXRB+4k1quv71r6goh2rlvpt095TB0t2pfLNostS/Ql0uPtK2qWnH5bgDuqkby5TT 9pK7/j9UH7gv/wCP0SixyVZ3V81tP3AEsZSXO0h21qnafzQcfeKGMrb+a24isPCw+UpRIFZy s/zxFFdmPTbmvUSs4eH0XJIjb7seq4gG/i/BbY6Y9eHvFz6bUSUc11/WBGWKm+duLHPHX024 yElWNOduS9TJRxlj/wBkCdt1uwfzW6FC/Qi+Uy2w6SsS60V0/JmvlmgjS1+fdj80X7jO3Wza fKTRor/7EH80F7jMv9O/uzQFs1278eaqFt9uxLmtJNqt+X3oV9hRWlm1JfDNhSkv/XnH5Zov a1X5fet/3SM1juIfzBbl27MucWiCNl1dmTyalAjDCFuvwylbfpI2sIW3yuDkqQufduJjAshK krDecW4P0MTilC/Hk0/+YV3sylThOM/RItklr3C5qvtqIHGVLm3nzjT20K0qWbsPlkn7aBVq G3nybXtLHHt7iPQ36nUv6/5RNfrWZvjFL6ilR/Jux+WSf1E3KkLE+Ta9pNxo9xDo1e2pr9f8 osoneb/8OP8AZI2Yr/11y1T9H0QKWM3zsqgRdGmuFl09oEYx124xWd25X0L/AIkrstauyXxz jbj6P+Aoy0OLXwWXNdbCHY0Lhbtu71yZA5UlJrg+z/Jbz9bFGTbjJ56Z3n15L1EYLGMV8VmV Ot1qK3JN2m+7KErT6y4DisFFcbLp9ZGqm4p5Xbej0ohG44RjOnatNxmvusXhpvwU+zLt2pdP I0g8RpRu07Vv8u7HoGrXesLFU8S1IcZ1cb0lhL8u6vrJ2ou24xedq5p/lkA+/WS/xIRl/Mmc 65Nzk7tvvf4kH9Mvca7tGlaxi2npl0qWRjm5XZVXZvxzXzfx95FQUey528YPvR+X6czTs564 u2849qH1oz25NvxLSpNd6HP6cjTatxg43beEZOj6HyIPR+ReYeIv2l3OK/LlzXL0e47ifPI8 HGUrU1KOEouqa6D2213C3VqN5cViuniebk1xcztXXW+i/AKkdNMhN8MqHJpPMjWrCtMAzAYU FmFQGxPAbEwHggzFUTkS2RZLScKvDAqV2cXonB9Djiix3EQd3kc7y6xucdWKVR1KHNsjmcbz +zc44vdxcyDu8isVUcbzbVuaxN3GyNWyOpC1HK7571vCYFepiOfkuFlULUiAE8quEtQqsQGc 0AABlSAKickFMCLmheIDFTAr1sjVjC+K4WpIpGML4rNaKb26jaVXmQvX1aVXmcq5cdx6pHXT i8ut7FkiV69K86y9RWAHskx0jIEAAAAAAAAAAAAAAAAAAAAAFAACAAAAAAAoAoMdAiNBNE6C aJlcKpL6Mps/o1ok5yk6fTOPPii+WT6nmKzbpbtR6K/Tk/Yz2fj9r83j5+8+Q3FY29KeLovp 08nyHYSh6KfTiO8tU1hXTj9PpgONY1XP0ZHreYruMlxa6/r6iVaej/j7vSEu8/p09ZJdn0fV 05LDkRSS04cuHV0dT4jWGPLjXlhn1cENKmD/AONMMs3hzHlnwzfseOS9BAlHg/V7Hh9bHTi/ S6/yvH7AS4P6cHh9bH0t+nrwz6+RAnRKj45+54Z+srUXeeKw6cvpgScXcdHgn9fR18y7CKww 6eVf48gCtOzHCn09CeXMplL4Y+j6n6MqsJSrgsPq59VHxeJKEeePury6a5rgAW4LN8fo+tp+ gr1Tu3GlhBZ9P0zSLZvQnLOT4/T2riRUHFKHF4yJaqq9tYSScXR8PtRK1vZQejc+i4vr5lm4 seMqRbjJKioYU7umMbii6d6uZ5OXWa/ynT4O+md/43v7utO2n2otY8VlIpceDVHyMVudzbY2 u1B5wZ0LV63uo9nNZxea+nM5Sy9lut1uKocTNcs8Ym6cXHPFc/tK3EMscbvwyLWk1j6x3LKn 0MzqUrToy5TDTG7pWi4tUOHNdX2Ge/stK8Sz2o/T1FsZKWC9RO1GcXW3lyNZ92eznrY3ZY4L 0inbnZkoOjbS6jux2buY28JfJw9Bg3e2baU004p4c+X2nOXbzk7616MaXS3XptPSuctxO3ON xZxxNNy3tIy7zpLtpdEsTRa8n1wc3Jx0SSuV70YyWEqcV6cije7Pw7Vu4ucrbpzX8VI67Tpj s5S4ucS/Nos7G1dVYJPrkaF5al8MF6TkW7k4tK26Nl8d3eeDZ57pfd1nLZ211/o6i2ajxiup EvAtrOT9GBzZXZUT8RSbWMVWsev+AkpSzbZnwnqfd3va/wBHTb28c8etkf3lmHdUfUYVY51L FZS4e0fxnquOXb/JfLzP5U/cVS385ZIFbS4IklQnlpCcG9U/uL0uj0Cpelm2aKsCfcnpHSfj 31rN+2k+8/aSW2is2XgT7t9I3Px9fW1WrEOOJJW4rJEgM3k2925w6T0CSQABm7W966TTWdpA AAZaAAAAAAAABKMagEY1LUqAlQZkAABFAAABSotKGMoE6cB0rihAnTEgAJNcUIgAAAEMQAMQ xAAAAEZwjPvL08R27l2wtP6lr5ZcPp0DA6acm2nbt7Oe3Hrt37+6cPDvfoukv+3N4+h8fTiR acXpkqNcGVztRni8HzRJbi5bWm8vEtrKXxR9P0R0xpydv4be3oxnfT6v56+/qYEkoTWq1LUu KfeX2+gicttNtLjaOuu02mdbkAAGGgAAAAAAAhiCApyuvrXuLihr830x9x24u9//AI1y5O2v /wDKLwADk6gAAAAAABiABiGIAABAAAAAAAEAAAAAgAYCGAAAAAAAAAAUAAIIAAAAAAAAAAAA AAAAAAAAQAAAAAAAAAAgAIAAAoAACPObjdSvylKfxPVRFd+FmMYKzJybXbwok+jmOztp305x XYjmyucNLofdy+QrPSW5+Latz5o85Q7PlF7Xbdl5xepdTOnHcVnadG3JVI7h9iS+6ycniVN6 np+aE0j0XDlA1Wc189qvsFbdZWHzTiFppysyeTi4ELUtMbbfwTcWZaRhhbh0XGSu92+uU0/a KS025R4wuV9ZZezvrmoyXsZQrirK8ucIy9w4Ulctv54afehrG7H79qnsK7UuzYlyk4kBZdFZ b4TcRR7MUvlug+zH8N0dzBXOi7FgSSo+q8RtqmnruIk+P+cgjnH/ADJoCCxUem0ySeFfT7UK 2v0/wzQRxj1r6v4ASiu0l/mRC1i4dNuSGn2k/vf9URWO9Z/nQEYuluzLlJljh+vD+b2lWVhf duGiWN+4vmhX2AR1UlYn6PaQapC/Dk6+0Tf5FqXKTLJx/MvrnGoQ0141l840M7/09OVwuWDs T9HtK5qlq7H5ZpgXOP511c4P3Fdt9mxLlJosWN/8Vv8AulC/08HymwoktNqa+W4mSur9Zc1G YX/8ePTGRKScriXzWvqIFcWqWlfHaXrRZbeu4389r6iFt1lYlzi4i2uE7P8APAKG67aD+Wb9 xpp/7NxfNB+2Jmiv/WmuMZx+w0p/+xafzQj7qFZZ/wD5ov5Z+9Gt47ia+eH90yRX/r3I/LKL +o0xf/sWZfNGP2FELPa8OvxW5w9Q7GPhfehOBCHYtqX/AG7vvJL8qS5W7vskaQW+14X37c4e ojbn+lOWTUrMxOsFJLvWZ6l+Fho1ylaXdurXDokVEayhD79iX/KDipN2l3bnbtPlLl9Q4Sq7 d98fy7n06glacIThxtTrH0gR1Vpfax7l2JKVvTGdtPG21cg+gvuxVby4Sgp+nAcWpXYJ5Tta fY0TKqpx1uaWVyCuLrRKUq1nSratzw6P+BGw6xtS5OUH6SDlKKTj3rajKnOPECm64vsyf5dz tQl8suP8TLNOUvDuYXF3Z8/pwZdccYKmdieK5xf09aKdKVLV11i+5Pl/D3CkW2oyuyr3b8Mf xU+v3mtabiwwjd/5biKrcJyeiWF6GMJfMuX2FySmnJZXI6qcpxASdc8zseQ7hRuSsvKfaivv L7UcqdG3JZOj9f8AEdi67FyN5Zxab6jG0zMLOj2ixzyFOKkqMXiRkk44p4g5nhu0j0TWsV+7 utrW4oK7arjGOEor6y61u4XoKcVL8LVGWSmngyOumCRzvLI3NPdOEnLGSoSckUuTZFs53nan HFzuIg7hXqQtRx25rfVuaSJubYiFWI43fLeE6oWpEQMXZcHqFqYCqZzTAqAtSFrRnLWEgIax a2DFWCK9TFUi4W1QtaKgC4T1i1siAXEPWxVYCCgAAoAAAoAAIApv31aXSLcbhWlTicuUnN6p Znbj4/LreyW4Oc3N6pZkQEepgxAAAAAAAAAAAAAAAAAAwEADGQgGBMxcUgGA8ouCAYieR4gK ABPNfE10j1IiInlV8YlqFqEBPKrgpNtNUrXgWQVIwfKNMV9PpiVl6xgug9v4u/fW/N4vydO2 0+SiSrOS6FTD6IadHX7F08MRXFSanzVOHDrJJpPPDr+zoZ7cvGemja+mHRm8OY0qZ8PqwfQs BpJYPjn7nhm/SNLn9OD6F7wCnB8c+ng+l8OgOv0+nB9C9GJKlc+Ofu9/oBdPH68/byII5+n6 8PfzFRzxfH6+nr5E6Vz6ar3/AG4jx9P095FFVFY5fSv2lb1SfTy9/VXPmTpx9v09ToSUUlh9 PpwGRBW1Bc3z4dfT01JRXP6fTgxt0+n0xFVRWLoiWrjKKjqet+j6fSo6KJTc3OrCKojPnnie bfn1nbrXo04Nr36RqubhUpHFmWg0h0PHvyXfu9mmk0nQLAhK3V64PTNZNFiGc5bOsaus2mKt sb9N6Nx2ZfPwfXy9xonace76uHoMMoKapIVq/c2vZfbtcuK6vpQ9Gu8vS93k34rr1nWNLVci ucFJUZqjKF+OuDqufGPWVyjTP18DbiwTtaXX4TftpLj6yDjQrScHWPqM0d21QvuW7e4jouqq 5nGsbqh0bV5SOXWXKOZ5hZ3GxjVJ3bbcXKeFaR7qf3TDJXd1s66cbd1S5VVytfb7z1SkmY7+ zat3PCTerT2fwupv7lvdZJmZechs5/E0vay+O2txzVesu6HmBwu+1fQ14tNfTPzJJRySQ6gB h1AABFMAABDEMAAAAAAAAAAAAAAAAAAAJxiARjUsSoCVAIAAAimABQgACgUYAgEMoYCGQSTo DVMsgGuTyIIgNqmAAIQwAQAAAAAAAAAAAAFc7EZuq7MuaIu9O1+stUfmWf06y4Dtry3WeN/l r7Vy245b5T+O3vE3brHXbeuHNZrrXAgVeE4PVZeiXRkyP7iUHpvqnKUTXhrv/wCu4v8AjWfP bT/2Tp/lF4EpW2oqaxg8pRy/h6SJwut1uNuldpZZmdYAACKQAAQFL/Vf8pcUT/V/s/WduH6v 2rly/T+8XgAHJ1AAAAAAAAAAAAAAIYgAAAIAAAAAABAAwEMBAMAAAAAAAAChAABAAAAAAAAA AAAAAAAAAAACAAAAAAAAAAEMAhAAAAAABbtxswVuC7KXrOLv9r4Tqu68jsVZGcFci4TxTPt5 fKw8szT5fqW4jo9PVxHu9rKxOjyeTNvlW30wd55y7MeridNJmsbXEbr0lFp8Kwr6ymrt0lxt TafVIncjqlOHOCa64kV+ZKL4XYNP8UTvXOIzi4xnBf4clcj1MlcSk7kVlOKuR60Fp6nbb+OL tyI2ZUVqT+GTtyCn+o3/AOW3X+aP/AcHqdt/PB231ohF+HGL/wC3ccfQwktEZRX+HcTXpCJW 5UVmfyt25EGtNqS427iJXlRXUuE4yXpHeVPHX4H6cCgv4eN+KMxXn+r1wkO//i//AK4+4L2L uU4zhH1FwC5gp9FyDG8H1XRXX+p/mRCecui6gCHeiuUriI2u6v5fsJxXaX+bIhDJdS/6iB1o k+PZfqdCccJQfK5JFcuX07xKeCryugKS/LvLlNe80Rx3EfvQ+ormsdxD+YlGXbsT6KAU0/8A W/DMveO4f3rf90q0vwr0eUk/aWwf51mXzQoBRX8i2/lnQtnDHcQ6NRVltpL5Zov/AMdr57f1 ARhKtyxLnHSUtf8Arzj8twcZUt2ZcpNEriotxH7yftAV7F3XzhB+4tgq37VeMF7mU3MdT52k W2/1rP4PtAohKlq3L5blCyvhzr8l3/qKqf8ArdVxe4tvrtXl0Rn7hROlHuIen1MNeO3n6PUy UWnen9+3X2FDl/69t8VNliLkqfuIen1MsT/08vR6mNL8+6vmjL3VIL9Gy+U2vcUSlGkNwuUk /aO7DxJyj89tS9KX8CV1U/cfiXvJ5XV92z9RMimHbuW5vK5Fwl7iEU4wtvjC44l1lf6ePTKX tIRxtw+9dZcoV2GmF6KyVyNCd/O/1Q+ojefYvP8A8i+sdx6r1yH/AHIVXqqP1/0G3W7p/wC5 aSXq/gZ4zbtWrizty0v3i8Ru3avLOD0P3lrt6fGt8KxnH1/xKJSStOaeUblfQ/8AiUS1Qxj3 7L/tQZdJqU254KTlbl6VgZZubywvWsGvmS+nqLEUTaitcMbUu9Hl9ODC3GMFpn2rMspcYv6Z irndsrD47f04e4utRjb7S7VieElxi/pkRV0YTivDb7dvt25fNEtbSbnHLs3l7pEUpQVM5Wmp xfODzLUlGSXwqUoeiaqgIpKPY4RdP5ZOqItUpTj9WAKVYpPKUfDfRKLH9ePp+L7SK7/lW48T bqLeMOz6OBs1HC8su+HecHlNe07OpHxfys6clnpese7i66p6hVZDWha2eO7u2EwK9bFVmcrh YLUisDOVwnrQtZACZXES1sWpiALgVYAAUgACAAAABDABAMQUAAAAAACAK0Iu5FZyQEgKnuLa +JEHvLS41L432Ggz7jcq0qLGRTc36pSCdekwuTk6vM66cfrsWnKTk6vMQCPTmMYAABPJcAAA eRgAAE8lwAAB5UwAACZq4AAAyAYAQAAAUAAAAhgRSAYgAAAAAAABDAKRO1Kjo8mQAuu3jZtP RnbWbS631XTjg0QS4ejN9XBdRZGWtdKI6fUfV13m0zHy9tbrfGlGNcMq/Xh158ydK5/SuD9o 0uf05+p4kvp9Ohm8sYKnP0/X9oP6fTpH9Pp9MQJlcCnH6fTmRa+n09hIHRZktWRHMeXQVSvU yKpzlPM8+3PrO3Wu+vBte/SLrl2McsWZpSc3WQUA8m/Ltv8AJ69OPXTt39yoFCQHF1KgDAAA YBTAAIKfDlal4ll6ZGuxu4XuxNKFz5X3X1cuorK7lmNxYnbXkx02effhz10bZW6YcuHFFTjx WKKbe6nZpC9WUOEvij9psoprXFpp/Esn1nfpezyWWdKyyjxLLV9weJKUcaUo+RVKHAzZlHVs 7lPM2QucUecjN2+o6FjdVOV1G/c7O3usV2bnPmca7ZnZlouKjOzC6pFs4wvx0XVVGLM9+7rx 8t06d9fZ54DRvNpLayVcYSwjL6mZznZh79dptM6gAAjQAAAYCGAAAAAAAAAAAAAAAATjEAjE sSoAEAGWLyM97dxt4R7UvYYLl6d3vP0G9eO34RcOhPeW4YJ6n0GaW/m+6kjIB3nHrPi1hbLc 3ZZyfoK3OTzb9ZEDckinqfN+slG9cjlJkAGINEd7dWbT60Xw8wWVyNHzRzxmbprfRHZhehcx g0y632l1Hn8sVgzVt99O06y7S48zltw3+1l2FnRknEoVyF5aoOqLLdyuDzPNZYJ0rhx4ECbQ n2usggAxFCAAAAAAAAAAAAAAAAAM1R4oAKK4xnZeqxLS+MXkyyN+3dema8K5/wAr+z0AKUVN Ukqo7Tl6ePJPKf8ALjePr5cd8b/wnO3K3TUsHk1in1MiQg7lj9N6oPOEicLlq86R/Ln8ksvQ +Hp9ZbxzbrxXPw9UnJZ05Jj4+hASlGUHSSo+kicMYdgUz/U9EfeXGe8/zUucfdI68P1/1cuX 6f3jQAMDk6gAAAAAAAAAAAAAABBAAAACAZQAAAIAAAAAABgAAACAAAAAAAIAAAAAAAEMQDAA AAAAAAAAEAAAAAAAAAAAgGIYBCAYAPSGg4b81ucIRXpZXLzTcPKiXQfcfJdvcbWO4g4S9D5C jbUYqEe7FKKMXlW5v7qUncl2IrlxOjclpVIno4+ky5b9bhli9V23J5NSj7yqzhGy+U5L3E49 mUK5K57JFcF2Ix5Xjc6oF2IfgvfT3DuLTG4l8N1fWOmuq+a97gj+Y41/xLrn6EawhXv8VL/u RHdxdzpuRQQfiaG/juSm+pBbepwb4yldfUi4Bc7XiL5rkY+oVztO5965GPqHa+By5zvPqFB6 dLfwqV2XW8hgOXacqfFdSXoDv4L4rvuFHsaW/gi7j/FLII/l0/8AHByf4pDBkd+n37vuHFa3 FfPccvQgS8NxX/bg5PrYQWlxXy23L0sBW3q0y53XQSeHofskSsxp4S5RlMhbXZtrmpszVSlg n0fbULvcudE4sG6x619Q5Yxu9UJEFzjW9NfND6iqtLNqfyyaLLb/ADrTfGFClKu3kvlmgNEl +beh80W/rKlKkLE1wk0XRVdxF/NBe4y//P8AhmBbNYbiHJ6vaSg63rUvmhQJU8W7H57dfYV2 5/oS6WgK4/oRfK4XXF29wuaqUywtXFwVzAvk/wA65/l4/wBkCulXBfNbaJWHW7Yf3ftI2nV2 K/eQ9u6O0+U5RAp/+d/5n1Gi4q3bkedv6ihr8j/9n1Gmf6918oP/AKSoVh1uWZfNBxKkv/Wp xjc+odrLb/ifvHbjqtXn99Mdhtiq7lP5of3Sq3jasr/yP6i6K/OtP/x/Uyq13bH439Q/X/YL sqwvvncXvJ3XSd7otpexFMv0r3+YvrLZut6cfnt/3S/r/pBbf5lj8D+so1U28JfLcBXaW7N3 5JOL94pxq71j+ePo/gUTu0c79v5lrj7yp3aKzuPl7EvR/AFco7O4/kl6P4D8Gkb1n5e3H0fw KH4Sj41ngu3H0fwLZ9ppcZRhH1Ko64xn81lp+4rbaTlHOOma/ldGSCLlGSSlhG6ljynEy3HK 49L7N+H/ADU+v3mi9oVbcv0rnbty+V/TMyyi7j8K5hdj3Zc+j7GaqCFZvxbeFyPfjz6ftRqt 6I9tL8m52Zx+V/TIphquPWsL8M1838eZqtqLxWFu92WvlkZVKCcKRnnB+G+mEshKLklF4al4 b/HDIcU5JRl3mpWn+KOMQf5uGSuqq6LkQIrt45a+zJcrkftH3lqWbTdOmP2ofe7T/wARKvRO LDWo1n8s3VdGTAFLQ43I5qj9B6FSUkpLJ4nnqaU4PODon0PL1nY8vua7KXy4Hzfz9M6Tk/xv /b1/j7dbr7tQhgfFe0gGJtLMKAIu7BZyXrIPc2l8aGKLRGd76yvir6CD8wt8E2XxvsNYGF+Y x4RZB+Yy4RXrL4bK6IHMfmFx5JIre9vPjT0F+3R1wocV7m6/iZF3JvOT9Zft33HbbpmQd2Cz kvWcXPMVC/b+I7D3VpfEiD31pcW/QcoC/bg6T8whwTZB+Y8o+0wAa8NRsfmE+EUQe9uvil6D OIvjr7C57m6/iZF3ZvOT9ZWMuIG8c2KiCpJBSoJ4EpYEAEAwKhAMAEAwIEAwCkAwAQDAAAAC gAAAAAAAGACAYgoAAIAAEAAMQAAAFAABACGIBp0dUWa6lQHTTkunbs578c379/dOW5UO8n6i Md3am9Oqj6frELSuWZ6Z+Rr6yvNfx76WL5ScM2vSScqLgmUVE8Rt+TPTVZ+Nf7tkncfHEjJu WYAeXbk22716dePXX6Z+6IUGBzbRoBIVAEMAAAGBFADEADAAoAAAGk8ypKe3euy+uLyZcBrX a69nPfSb91tncQ3C0pUlxtv+6yUo8c1z4rrMdyyp4rB8ydveOD07j0XF/e5+89Ou82eLfjun fsslAqo4uqNkralRxpjivll1FTSeHFcOJqxzTsbqmDwZ0bV9SOLKBK1uHB0Zyuo9A1G9B2p4 xkqNM4lmw7jlbg/zI17LzwzX2G6zuKnL3Fx29xK9bzjNyQ1mc63t6fBddrrc6pZYPMDu7nbW t2tS7M2qqXXzONeszsS0XFR+84XXHye/j5Zv07beysBiMOxgAAAAAAAAAAAAAUBIsjEAjEmA NqKq8kQDaiqvBHO3G7dzswwj7yG43DvPDCKyRQejTjx127tSAAA7KAAAEAwAQAAAABQqENAG QROMnF1i6M3WN0pvTPCXPgzABnbWbdzDvRlVUYVoc3bbvTSFzLhI6J49tPGiTxxREadAa5ZH MIQxAAABQAAAAAAQAAAAEZzUIucsoqrObLz2wsoyfqNa6bbfTMs7b66/VcOoBxpefx+G2/TI 6Gy3X7u14tKOrVDW3FvrPLaYjOvJrtfHW9WkjOEbmEl6eJIDnLjrHSzPSoRndsrT+rb+WWa+ nQS8WzPG3Kj+SWfryYzJvcEmkul/UejXf7lmnJM/+Xq4ba3T+XHcf+Potu7mzZwuTUXy4+ow X93G7dtztYxSalXDjwK7ytXo/mp6qdma4HKvR8N95SXNHo04JrfKW2uG3Nb02mI9grcp2/Gi k4VphJN+owXvM7FmWi5qUlwcWji7XTNUnnwZPey1WkrknKUXSFeXIf6+nxX722MzDfLzywso yfqKpefR+G365HDA6T8bj9nK8+/u68vPrnwwivWzXsfNoX3ovUhPg/hf2HnQLfx+OzEmPiTm 3lznL2rVMwOBsPN5WqW79ZQ4S4x+1HejKM4qUGpReTR8/k49uO9e3u92nJN507+xgAHJ0Ahg AgGIqAAAAAAABDAAABAMAAAAAAQDEEAAAAAAAAAAACGAhgAAAAAAIAGIAAAAAAAAAAAABDEA AABHlahKtKLN4CpQt2y13oJ8z7j5L0W0sra2VHi8WQlKuLLr0sDK2d+0kcu9yP4P1BGNGnym 5+v7BUHQS2CMU4pc4xn/AG3/AAyE+wuz8MYxh/NmywM1zNzephXJadSjwpZj9bCa72nmrMer iTccU/vxl9RGC7qf/dZubZTBXFVTpxlG0upBcx8T8cYehBDFR6brHDGn3rz9hchXsfE6bkY+ oL/+N+KKFnFdN0LmMbr53EQSvd69+GP1BPCU+i0gvZ330RXuC4sbn+XEihYNdFpijho6Lch5 N9Fojkl0WmAQjXD7v90cXqX47fuHDvJc6e1CsqsrfVOJBODo7E/R7QpSN+HJ19TK1XwLcvlk 0aHH868l8UW/ZUIgmlKxPop7SpwSt3ofLJP2jf6NqXyyaLLi7d9c1qAdFK9Gnx2qewqg0rdq XyzaZbB0nt581p9pU40tXI8YTTCi7Gkb0OUlInP9Wf3rWHqI3Kt3emEZEq1uR6bX1AQt57dL pftIRdIauV0ss1/9d/iRXp/Jp/5MSiV1UU48rnvLbn6t/wDB9hG+qyvrgkpeom+1OTXx2qky IWlWW2S6feWQjos3q/MveQsNJ7ebyTfvLLj7N+HFS1e01+v+WV9aXorla+oojLTasy5Tf1Ev G/Ns3OEo6fqM+luzO287ctX1FkF81juLf8y9DI+JSdi88mtL9Aal41u6+7cjpl7mU+G/CuWv ity1Lq4gScexes8YvXH0Elc7dq/wa0y9GHuHrpdt3Xlcjpl7mQVtq1ctPO3LUvcVD8KkL1n5 HrX06jTHG7F/Pax9QktV2v8A3LX1CtPC0/uT+siq26QhXhD+8Em7VZ5+HJqS5wkOKUlGLya8 P1xwK53HGKvJVovDuxNRFN3TD8uTrZnjCXy/TiVqGp+BddGv05/TgN6beD7VieX3X9qLIWv/ AJ7mTxtT+nBkVZHVLtZX7WfSi7Sp1UO7dWuHRJEU5U8R/q2nSa5xJuOjUo/A1dh1PMgUpOac 45ySuL8UcwklLUo5SXjW+tZocnorKPwNXF+GWZJRUHpWUZdn8M0Arnajcp/mL00BaXdq8rkV J/WO2u1BPKcZWzOp6bUJvO3JxfUyC2lI0eOmtuXviX7bcTsqWniQmqXKxynGvpj/AAK01Gre CSZz5NZvptrfWOml8d9b8Wr99dlm6dRCW4uP4mZFepijTLRct+JbVGsJx6+KPg+OPR9WbTOE Xck85P1kcyNQqGjohkagBKoVIjAYVEBQwqIAhgAAAABQAAAAAAAADAQDEAFkLlIuLRWAsyBu oAAAAAAAAwEAwAQDAikAwAQDoFGAgBtLNog71tZyXrKZTGUvdWV8aIve2Vxr6DXjtfSs+Ws9 Y0AV2r0byco5J0LDNlnStS56wAAEUCGYfMN27CULb7bxb5I1rrdr4xNtprPKto6M8+97flnN kHfuvOcvWdv9fb3jh/sa+1eiaE5RWbS9J5xybzb9YqGv9f8A8mf9j/xehd+0s5x9ZW95YXxo 4dAoX/XnvU/2L7R2nv7C4t+glZ3du9LTGqfScVE1VYrMXg1x6k59vV3gM213XjLTLv8AvNR5 NtbrcV69dptMwgGIy0AAAAAAgQwAAEMCBAABQIYAIBgAAMQAAAFAAAAAwAAACAFKKkqMYDsl melUQdzbV0dqDzg/p7Tbbu29zGsW6r+1H7UUlNyzjrg9Mlk0ejTl9Nnl5OHHXT+jXJNd70SW TKrlrgws73HRfWmT4/C+vl1ovlbp3cvl+w7PKxK7OxjnyZTGbeHF/WbZQ1ZekyOGiWtcOBOw 9LauKiXJJF8lC9HRcVY+1HC2+7qdG1fqcbMDDuttLbT0vGD7svqfSUnU30m7TaeKxM9vbrd2 vFs4TXehz6jF0zPLX+j1cfP/AG8n/wDl/wDLGANNOjVGuDA5vWAACKAAAAaQJFijQBRiTACA Odu7+t6I91e01bu94cKLvSOYduPX+6/ssIAA9DQAZC5cVtVfqLJnpEtkmb2SK5X4R6X0GW5d lczy5FZ6NeH/ACeHf8r045+9aHupfCkit37j4lYHWaaz0eW8u+3fap+LP5mSW4uLiVAXxnsk 5N5/dWmO6fxL1F0LsJ5PHkzABzvFre3R21/J3nf+UdIDJa3DhhLFGuLUlVYo4baXXu93Hy68 nbv7GAAYdQbNputDVufd4PkYx0rmZus2mKO9poqgnTB5GTZ3/Ejofej7jSeLbW63FQNUESWO HqEZQJVdDztzzvcpuPZVHTunolgzyG+ho3FyP3mer8fXXa2bTLz/AJG22sl1uF8vN91L46dS Ru8q8ylcm7N+VXLuSfPkcIadMVme3bh0s8fGR49eXaXyza9qBk8v3q3lqr/UjhP7TWfK21ut 8b3fT12m08oAAFjgZVzPOr/h2FbWc37EecN/m248bcSp3Ydhej+JgPq8GnjpPe9XzObby3vw 6A9B5DKtmceUk/Wv4Hnzs+QS7dyHOKfqf8RzzPHsvBcbx3QAD5T6QOX5tv1aj4EMZvvP5f4n UPL+aQ0bq4ubr6zvwazbfr6dXDn2uuvT16Ha3c7rUKLU8madhaltL0L7TpGX5mGOnJ5nIOr5 VdlOc3JuTpxxPp3p1jwZz0q+NvZyuu1NtaG4qSwdOp4FG98nvwTu2n49pfFDNdcc17uk7G32 lqxBRjFN5uTWNSfg6Ja7Lduf3cjyz8nXy6zp7vRfx9vHpevs8nHbXZ92En6GWx8t3Msrcj1n 7qrpuFpb/wASGXpX/BkpW5Jak1KPzRxXp5eku/NvJ5ayXX3NeLS/x2tm3s8Zf213btK7Fxby Kj2V21C/Dw7irFnlN5t/216VqtVF4M3w833P436mOXi8Os+lQd/yGdbVyHJp+s4B1/IZ0uzh zjX1M1zzPHszw3G8d4AA+S+mAAAgEMQAAAUAAAAAAAAAAAAAAAAEAhiAAAAAAAAAAABAADAA AAAAAAAAEMQAAAAAAAAAAAAAAgGAHmHYazzLtha/9mK5lim5ZrE0bFPxa5UTZ+k8Y+F5V0Lr q2ZpOmeWGPuf1MvkymWGNK54c1xX1ikLo48vq+tEnh6iuDo86qio/u8H6MmWyWHoGFAVwCmP p+wiub+mDLgSzWnrIywaf34y9YYr6fdCfdfOlf7NGOwIYOK/8siMMFDouSJXHTW+Uo3V6SM1 TUuVxP8AtGsoSyj/AJrCfduf5qJTVHJcryFcVVP/ADUUO9lf6ZRQr2d7ojBe4d3HxKcbkUK9 j4tOM4xEQ7uDudFuKFPDV0W4oL/+N1wiO7nd6FCIDXZl1O2Fvszt8tc0FaTf44e4jJ6f5bvv Io0/kzj8k0aU/wD2IP54L3UKnHHcQ/m9oKWO3n/L6mBUl/60l8s0aM9wvv2/qKqUhuIcnX2k 4Ot2y+caBFSl+Rbl8s2iy4vzL8ecdX1lVP8A15r5Zo0Nar/4rf1CqrXalD71toVrOzLmnAVp 4WJcm4g1otv/AMdwgI9m1F8bcydyH61tdFxDlHVK7bXxR1r3jUqu1c4STtyIoaU7nRdt+0jb kkrM+CrCQquFuMuNqel9TJThhdtrg1ciBCUXC3KPG1OvoZqdJbnoux96K6qc4t5XoaX1kFJx hCfxWpaZdRZUQo3tnzty95dg78X8N6OPpJKC8W7aWU4uUfeUN128JrOEmvrNy5Zwi4t2HH4r U/eX1Xjxlwuxo/TgScE9xKHC7GvrVfeZ61sQnxtyp6y9wKP5EovvW519eBqardn9+1q9hGcV rvcpQ1/WNYOL5WZV9oChKihLlamw7uiPK1/1EZ9m3/8Aqiv7UiU5UuTl8nhx9wENOtOCznGM 4fiiZrt2v58Ma4XYF060dqOF21Jyh0ozKTnJ37Wf+JD6cDSBKNvtLtWJ5rl/FGiFr/55Oqfa tTIQUba8SONmeEo8vpwLlaaUrFauP5lqXQRU4yrpuSz/AEbn1BHsKMpf4bdqf4WSkvEbp/ix 1L8URRfitPhdjpf44kDhHS4p5Jysy6nkRTpFVzoov0Nk06qr4q3L0p0IT7UZpZ6Na/tAK63G M6d61c1ehkdCldlD4b0dUev/AIkpTTuRm+5ejpl15FVZQtr57EvYBdCWqxGfG3Kj9xG72Yy5 E7NHdnbXdurVEi8Y454JnLkvjptfg6cczvrPiy2r0ITrNVjyNe2cXK5TuOEqfUZZWSy3WNVw aofF2sszH0prcpphUQzm6nUBDAAAAAAGUAAAQAAAMAAAABlAAAAAAAAhgAgAAGFDLvbjilFZ vEwVfNnXXju0y5bcs1uMOxVLNoE08Vicah0dk/yqcmxvx+MzlNOTyuMNIABydwZru7VuThpq 0aTnb1Uu15pHTjk2uK5cluuuYm9++ESL30+CRmA9H29fZ5vube697y7zXqIS3V1/EVCZqaa+ yee3vRK/dfxMzynJ5yfrLJFTNyT2Ytvui8RpIRJGmUkixEESRR0vLnhNdKZtOf5c+1Jc0dA8 HN9de/hudIAADi7K716NiDuS4ZLmzz1ycrknOWbxNW+3Pjzou5HL7TGz38PH4zN714ebk8ri doQxDO7gYAMAGA0ZAiaEiSRGklhiszp7Xcq8tMu+vacxBVp1WaOW+k3nxdNN7pc+juAVbe67 ttTeeTLT59mLivoS5mYQDERQAxAADEQAAAUAAAAAAAAAAAABQAAAhgAQAABQAAQAwCjAQDow AhO3Gao0Vwu3Nth3rftX09ReJqp015Lr8nLfim3wq6EoX1rg8fpmiu5b1YSwlwfAzSsuEtdp 6Zew0Wd3G5+XdWmXTk/sPTLNp0eLbW63GzFcjK1LHA02N3wkaZ2cKNao8nmjBd2zh2oYxFjD o3912NJd5U9KdMmcNXHk8UdTZXFCNY4oxZ0wOxf29vdLtYS4TX1nIv7ee3lpuLqfBnTt3lIv rG5HRNaovgzjZnv/AFdePlunx19nAoOjK/NvJ9xaTvbOcp2+MK9qP2o82txdjLUpOq6TprwX aZm0d/8AZntXpxpGXY72O7Wl4XFw59RvSocNtbrfHbu9Gu02mdexJUJABhoABTurmi2+bwQk zcDBfu+LNy4ZIqAD2yYmGwABgsWUV3bitqvHgjDKTk6vMlcn4ktXqIns49PGfF8nm5byXE+m diGAHV5wAAAAFUMBAAEATt3HbdV6UQAWZalsuZ3dGE1NViMw2rjtyrw4m/pR499PG/B9Th5f uTr9U7gAGc3oStzduSms0deMlNKSyZxjbsbudt9cTly65mfZLG0l3usiM8rJHmfOYad1J80n 7D1DVcUef8+hS7CfOPuPR+Nccnzjz/kTOnyrjgAH1HzmjabqW1uq5H0rmj1kLkbsVcg6xkqo 8WdbyffeDLwLj7Esnyl/E8v5HF5Ty1+qPTwcnjfG9q9AVbq/+3szu8lh1vItapgcXz2/RQsL 8cvqPBx6+e81e3k28dbs4da4sAA+w+SDpeST07pL5oyX1nNNfls9G6tv7yXrwMckzptPg3x3 G2t+L1YA8GB8Z9Yjz/ncabhS+aKPQHG8+j+lP8UTv+Pcck+LhzzOlcRnS8ndJz/Cc1nQ8p/U l+E+nez587vSACyXUB8a931h0PIrUJW3rsS0PlwZYBddrr11qbazaY2mSW4hJ6by8KfzLuv6 dHqOX5n5Rfv3vFhp0NLtVwZ1Gk1R4rkyEIzsutiVE84SxX06z0acmufL6dvf0cNuPbGPq19v X+rix8hu/FOK9Zs2Plb2lzxdalg1SnM6Mb1u49M14U+T7r+z2olOEoYSVK5cn1F5N+XHW51v rDj148/xn8p6XuQAB5HoAAAAAAUIBiAAAAAAAAAAAAAAAAAIBAAAAAAAAAAAACAYAIYAAAAA AAACAYAIAAAAAAAAAAAABAAAcRXlxNO0mtT6jG7dQt6rU1NY0xofper4TquXEUlk1hy6GQjN TWpZciSaao8V9PeZVWsMssWly+aP1o0LFegoaa68PWvtRbaa0dHAoOPp+sglXDn9cSTZDWo5 FyJJV9NPaqAnx496nPhJEPETyX0+nqF4j9z/AIkyLFFUo8qaW/uvJicXKvNpL+aP2i1OtKc1 6eKF4mHRSvo/gTIlcddUlxcbq+sJLGXLxIy9YnOv05/aJSlTTJV+H+H2FyJUo8eF7EjTFJ/9 3ElrUsHxXu49aG6TrisaSr0rj6S+RhClVjxu4hLFS5yu0JyWqrXFqa/EuATXea5q6vrL5JhC bwb/APIF1dm70TTJXY1jcS5q6uolcWqV1LKcFMZFme4lT47df+Uz6vyLb5TZdblW7ZlzjQz0 /wDXa5XCwXz/AFNxHnGv1kIOj27+mZZKNb9xfNb/ALpTVK3Znyk0EP8Aw78eUl7y2ON6y+cK EX3txFcq+0VX/wCu/pmX9f8AArSpYq/guYl8oxdy7b4TjrXvKqdjcL7yftLY/rWn80KEsUo3 f0bnPsSISVLVyHG3PUiOVj8EzRJVvXI8LkK+wmBGcdbuR+eKuLrQ4S7dq48pLRIjanRWbjyq 7chOFLdy1xty1IgNLjblH4rUqrqLHBTuTisrsdUesalquwk8rsaPryKotxtKXxWp09AVNXNP g3uK7Eg0U8exy7a9H8CUoKUp2llNeJDrzCNxOVu+8pLw5+4ZCc6Kxe5dl+hj8Ojv2v5l6HUr lBqzct8bcq+g0J13EJcLkEvZQ3L+v+WcIKWrU+dn3BJ5vnYI2sFFPCjlbl6RRmoqEpZLVama ZSmtVYL4rUXH+UhclGTrJ0heiseUkKso0S/UtZL5okJuCVHjZuYr7siit6rklbl2b0O7Ln9O A4Jzbuw7N2Hfjz6ftJRsub8C6+1nbmWxk6K9/iW3pudKCnGMVJNfpXsGuUhqtuKb71mWl/hZ J2127McmvEtklS7KL4XYaX+JEEZJ21JRztyU4/hkSlHTKUVkpRuw9IWlr0V+KMrUutZCTbhb lxScH6GA49qcY9EvrZnV7TG3d4R/Lmh3rlFqh37ctXoZGkdf/jvLDol/xKg8Lv7fl+Zb+nUS U1JwvvKa8O4RTkoKf+JZel/hLZWk/EtxykldgFFpeFpTztXEv5ZE7yo2umXvIP8AMxX+Jb/5 oEr8tU69CPH+Vtjjvx6PT+PM7/JWAAfHfSAAAAMAAAAAAYAVAADAAACgABgAABFAABUAwABC GxAAxFe4ueHbb4vBFkzcJbiZc+/c8S45cMkVgB7pMTDwW5uQbti+zJdJhNmweMl0IxyfTXTi v8o2gAHje0GHfrtRfQbjJv1hF9Z047/KOfJ9FYQAD2PCQmSDRJ5J+oLiqZFTNXgXXlFi/ZX3 8DHlJ6njtfSso0al5fffwpekqu2JWJaZ0rSuBZtrbiUum0mbEUSRFEzbDVsHS7TmmdQ5Wyi3 eTXBNs6p4ef6v2e7g+j9wZt/KUbEnHmk+o0lG9WqxPqqctPqnzddvpvycFkSRE+o+YC6zt7l 6vhxqkVwhK5JQjmz0Nm0rMFbjw9rOPLyeE6d67cXH53r2jkLy6/yXrJryy9xcV6Trgeb7+/w en7GnxcteVz4yRNeWPjP2HRAx97f3a+zp7OTuNm7C1J6o8egoR3c8Hijl7rbqzLDuvI7cfL5 fx27uPLxeP8ALXsoAAO7zOjsHW21yZqMXlzwmupm48HLP519Hi66QgADk6ABDAAACBAABQAx AAAAAAAADEAAAAAAAAAABFAAMDL5hdlasOUXSVUkziS3V55zl6zqebypbhHnL3HFZ7/x9Z4Z s9Xg59r54l9Endm85P1npNvd8a1G5zWPWeYOv5PeqpWX+JfWPyNM6+U9Dg3xti+rqDEM8D3g ruWY3FRlgFls6xLrNpiqbe4ubbCfahwfFfTkbVpurXbax9Xp5MoaqZlGVubdh9pd6HQenTkm 3S93i5OK69Z1i29ttVXHsy5GWMp2ZcnyOhZ3UNwtE8J8vsf1BesJqk8V83I6WOBbfdKXGjOl Z3FcGefu2JWcc1zRdZ3bWEjndR6aFymKOZ5p5Ha31btqlu9z+GXX9oWN0dCF1MxM63Oo+f3r F7Z3NFxOFyOX2o7/AJbvnu4tTXbhSr5ne3e0s7634d5VXB8Y9TODtvLLvl1+Sl2rU49ma6OD 5M6b768ml8vrnZ24bZvJ6VtGIZ4n0AYN/Ksox5KpvOXu3W7LowOnFP5LFAAB6mgUbmdI6VxN Bgvy1TfJYHXjmdvk8/5G/jp073orAAPY+UAyGeg/p/yhX/8A276rBPsRfF8yDJ5d5Ff3q1y/ LtfM831I9HY8h2VlUcNb+aeJ0wMZVjflezlg7MPUYtx/Tezur8utuX3XVepnYAZHh/MPJdxs Vrfbt/PHh1o5p9L6OB5Tz3yVWE91tl+X/iQXw9K6DUqPPAMCoRq2tz/Df8pmBNxdVmjO2vlM OnHvdNptHSAUZa0pLiSPFZh9mXMzAShNwkpLNEQI07SaaTWTxGZtlPVbo/hdDSeHaYuGKE6H I/qC32Lc1lVr1nXOf51Gu1rylFm+K45Nb8XLlmdNnmQAD675RAat7tJbW5peMWlKL5pmYSyz MWyy4r03lO9/c29Fx/mQWPTHn6OJ5/eX/wBxelc4N4dXAqjKUHWLaeWBE5acU1323nq6bcl2 1mt9AAHWltNHl3iNdqUlL0ZI3ttNcZ9bhnXW7Z+Ey5JO1LROMuTTIAarL2882IhanrtwnzjF +wkfEsxcPr9wc3zuGrbxkvhl70dMOh4oum3jtNvZNtfLW6+7xbN/lH6zXQat/wCT53NssOMP sMvlC/8AY9DPq6767651fN20um2NnT23mttuVq+9EotpS4NL6y2Xmm1j8depM89vouO4uKSo 9TM5yv42m18usdJz7yYell51tllqfoKpee2V3YSfqPPgWfjcfxT/AGN3cl5+vhteuRZtfOoX Jab0VBPKSy9J58DX+vx4xhJz75zl7ScFJUkk0Rh4lhUtPVDjbn9PpzPP+X+aS235dztWvbHq +w9DCcbsVO29UXk0ePbXfhv/AI/8PVrdOWde/wDynGdq7hF+HP5J5eh/b6wlGUHpkqMhOEbi pJVCM7tlaV+Zb+SXDq/hQz/Df/w2/wCGv56f+ev/AD/9pASg7d79J0lxtzz9D4iacXpkqPkz G2m2v1N67zb6SAAMNAAABAAAAAAAAAEAhgACAYCAdAo/qAAHpYaQEIdAouYCAeAYAIAwBNAA hp9AVAACrCrXoAKBRhV+oQD0t+kKe0QAOnSFFxYgAeAYCAB4A2sRAA6rlmGr3CAA1P6gAAOG rqVR+LGTI6U+BHw8KUP0vV8HouV1LGOZfG7GeEc1w5rl9hiVqT4Felolyrqy7a6fevp6mODp D08fp/xMMNyoRbuN54PjX7OZphdVy3WPX/wMqJyb6ueP2Coo5/T6ZpoVuPFYPo+i91C5Q5lF Lk60WeHrTp7it1cW+j3yNSgk11r6ytRqkufhr2lkCnXXP/MghQfbVMvEkvQSWaf3p3H/AClc ewk+MYOb65FwZODrGK5wmn6Mgc6xb521P0piktCa+SCj6ZDuKimlwULXpGBKcmnJrg4TXpzH XQ8Mlc0+iRG4quaXGUIL0DfalhxvL2EwqUJUcU8tUrT6uAW7km4pvF6o+lcSEe040yldk/UO 1i7b5zmyYE7d5vS6VrGS/gSs3Yy0NZpPDnH+BTawVt9MydlKMrLXFUYFqWmMaY+HLUumLCcO zeguiceozRbjZnTBxmaFP8zSstOqPqxRc2IsjjehL5rdPYZ//nj0TJ27qUYS5OsH70OSjKM4 xeEnqj18jU2TCxr82+ucGyqvYsPk37y+PauqXCcNP81DPSlmHOE2mWUTksdyvpmNOj28uj6y co/m31zjUqb/AC7EuTa9pf1/wga7F6PKSftLU/z7MvmikRku1uF0V9pGtP28vR7R+v8AgQWG 3mvkmmaM77X/AHLf1FLXZ3EemvtLIP8ANsS5xoMCpSas258YToXyj+ZfgvijqXvM9P8A17i+ WaNEXXcx+9b+olgjGdPAu8uyyLjSF638stS9ZV/80X8szU1W/divihX2DChS13IvhdhpfWVq bVuEuNuWlkU6WbNz5ZNFjh2r8OfaXvJjAnchW7dtr4u3HrzK5SjJ1f6d3vdEi2M6Oze/lfoH 4C/Nscu3H0fwNy+6YUaZOsf8W1jF84hSOE/8K5hJfLItcqK1uOKeiX06ibtJO7YWXfh7y5RS rLUJ2XjK324PoLsJXIyfdvR0y/EOM1W1deT/AC5FTi1bnb+K1LUuoBxk4wjN961LTLqHJeGp xXwSVyPUydFO46d29H/m/wCIra1qDecoTtv0EDn2JSfBThc9EhTWnVHgpy9oPGFedr/pZK4q ylTi1/0gYr0tLjf4fpXUK3DVCdjjD8yD6CNxtTcZZXY+1D2Leu1deTrbZaRphS5OMuF6GmX4 gtOiszfwyduQJeHBLjbu0HdWmF5L4ZqQCtrStL/w7jj6JEcy640p3PvqEkVHzPzN83XT93v/ ABdcS7fsQAB4HsIBgAAAwhDAAAAAAGAFAADAAAAABgRQAAVAJgxAAwAoDBvZ6pKCyj7zc5KK cnkjktuTcnmztxa5ufZx5dsTHuQhgel5CNOydLlOaM5dtXS7Ezv9Nb06bT5umAAeF7wRlCM8 JKtCQBEFagsooajFZJEgGaYhDqAiNCoAADWJwL9zxbsp83h1HY3d3wrMpcaUXpOFE9XBr32/ Z5fyNu2v7rESIoket5HR8vt0g583T1Gwjbh4cFDkiR83fby2tfS018dZqCF6Oq3Nc4smFK4c zDbzPAAyw5CPrPlNnlrpuF0pnbOBspab8H00O+zwfkfVPk9349/jfmBDA870AAAgDF5guzF9 JsM2+VbVeTRvjuNoxyTOmzmgAH0Hzmvy90nJc0dE5eydLq6UzqHi5vq/Z7+C/wACAYjg7AAA AAAIoABAMAAAEMQAAAADEMBAMRAAAFAAAQMAAK5PnEu1CPJNnKZ0PNJVv05RSMFKunM+nwzH Hq+Zy9d9ju2pWpaZZ4P1k9re8C7G5wTx6joec2aOFxctD9ByS6bTk0zfXub6/b3xPTs9Y0Bl 2F7xrEW849l+g1HzNp426+z6UvlJtPUAAGWgcjzVytXoXINp6c10HXOX5zHC3LrR24Prnxce b6KVne2912b/AGLnCfB9Z0Le6nYei9jHhL6Z+88ydzyt+LYcZY0lTHkevkk0nlO3s8ek+5fH +51dKktVuji+HAx3dqpY28H8rI6Lm2eq1l8pptX4bnDuzMyzaZjN1utxWGFyVt0Z0dvuyNy2 pdm4seZlnYlbyM3Vl37V9SNGE1RnnbW5cHSWDOpY3KkcrqHf2rhjDFcjMdSE6lV7aq52o4M4 3V6uPm9N/wCrAjkXnW5J9J2HFxdJKjONPvS62b4u9e2XKIAB6GhWmJzc8Toy7r6mc1Hp4fV4 Py79M+YGAHd4Fu3sPcXYWY5zaifRIW42oxtwwjFaUeN/py2p76LfwxlI9oZ2UAIZkAAAAJpS TjJVi1RroGAHgPMtk9juJWPh70PwsxnqP6qsVjavrNN2370eYOkQgACjZtZVg48n7y8ybR9p rmjWeLkmNn1vx7njnw6AAA5vS17GXalHmq+o6CZy9rKl2PqOmeblnVnYzL5jHXtbi6K+o1EL sNducOcWjlrcWX2rG0zLHjRMayCh9p8h6a5tlv8AZ218ehOL6TzMouLcZYNYM9R5VPVtIdGq PtMfnOy1L9zBYrvr6zw8XJ4b7ce3bPR7OTTz0nJO+OrhAMR7niWbey792NpfE6HqPMLae1uQ jko4fynM8i29ZSvvh2Y9bO1cjrhKPOMl7D5/5G/85P8AF7+HT+Fv+TxYAB9B4HrPLp69rbfJ Nepmo53kstW1p8smjonx+WY32nxfV47nTW/AAAHNsGW9YhG5HcJUnXTKnGppK9xjBfiidOO2 bTHuxyTOteX39uVu/NSVKuqM1Kns1CNyMXKKk6cVUnGKXdSXoPXfysdPHs80/Gz18njFZnLK LfoLY7HcSyty9R7BtoMeLM38q+mrX+tr67V5SPlW6l/htddDLdszsycLipJcD2lOko3Wzt7y Oifep2ZcUxr+Vc/znT4G348x/G9fi8eadnvbm0lWGMX3ovJlEouMnF5p0Inusm0xeseKWy5n d7Hb347i2rsMnwfBlhzvI5127j8s37UdKp8jk18drrPR9TS+Ws2QuW43O8sefESuXbapJeLb X9pdX09BZUHJjXk216d57G2k26+vudtRvqtl6vuPvfx+mAqPLiQnajcep4S+ZZj8e5bVLy8S CyksJR+npOmNN/p/jfa9mM76fV/Ke87pUYUf1jilcWq1LUuXxL0fYQOW2t1uNo6TabTOvU2q A1TiAjLR0XPiGAgAeHEKoQAFejgDYAENyb9InJv0gAA22IAKAAAgAAAAAAAAVVzDUuZQwI64 hrQEgIeIuQeJ0DCJgV+I+QvEYwZWAVa5BrlzGDK0KFOp8wqy4MrgKAGDK6q5hqXMpAYTK3Wu YeJEqEMGVviICoBgy5ylFZA7jSdEUp0eRapaj9Jl8MqPJsruQaXSi16o/YOMlPB8iDCoO9KN pcWbZyonKKaUexHlRFdiHh7qFcq4PrRd4blbeuVaVw5GcdWs9GvYWZX7UrqS7L00JIh5bvv2 2q029EsZdBr803CVzxFHsUjV/WaskSWs+P09BFRxTfOPvYK7CeCfo6PpiKSks86T9cePp4k+ SloemnHRJemuPsC5BS1cm7f9kjOTSbSxXhtdcuApujdOFxRXpzRrqLHbrKj43cergQtwbcK8 bk5P0FcptJ6aulzSulCnflHU4utLnZGaLbMa+E3xlObCwv0elzkQe58NydKq3LD+bNDhubdt qqf5f/TL6xkSspfk9c2G3pWy+mY7d20nDtLst/2ZcSduOnQ81CTT6pZEzBXt3+lhhrkgi6W4 P5LjRLT4cVXOFzHqYrkXGF1fLcUvWUK5Givx6a+0cV+ba/B9pK7jO8ucFL3BBVuWemD+smBk WFiNP+4TvNrxlykn6Qivyof5hO6v9R+Je8YBK5JSmq/AproeGI1fcqRkqq5HXLrXEbjqnJc7 X1DswTlZbylFxJhU7W6tzlC5LDWnbaE4/kKKo3bnjTkyhWmrUJU7lyjJ3NtKLvRTafeWnkM2 JhrlH866vnhVeopf6Vl8pMVuc1csutYuNFX3EVdTszUlp0zqjU2TC+UaXNxHmmyFaR28+Ta9 pemp3lNZXIU9NCin/rqucJ+8suUwk4f6iHp9pKFFOxPo0stSruZLhch70Zk3+3i+MJ+8B+HS 1dt8YyUi+L/OtT4TjpfuJUruJR4XIe9Gere3jLjbl7wp+H+VctcYST+ov1J3rc/hnHS/cSSX 7iVcrsfevtM1W9unxtz95BOMfyblt525V+ov1pXbV3hJJP3AoV3Eo8LsfeirF7fpty94DVuk Ltl/C9S9BPXSVm9zWiXoJ4PcJ8LsfejOv9PKPyT94yYS8Ps3rPGL1R9H8CSklO3efduLRP3E p3oW7yuTdIyh2n6Dmf7h2Y20loT1uufV6R5JhvinbSi+9auexlsexNclK7Iqtuel3dw+3Okq cor7ckKV1VtJPCfZr1vtfYazk7HKSt28eFtL+0ym9dcpxjJ6VKLuNLqwXqM92+3C9TjJe9lk NvK7fSnl4eH9k1jHdGawpXZ2XLJuXvN1m14VlxecbqJ7eylbsLjrf1E5PVCTXxXsCZBfWF/o uRYXlWV9c4xl7h31X9xTGsor01J3Uozu6mlWMba6XgZtkmb+uyyZ6RTN1004RimRGI+Jybee 129319NfHWa+xAMDm0QAAAAwKEAwAAAYCGAAAAAAMAAAAAoBgIIAAAAAGgMu9nSKguPuMJbf n4k2+CwRUe3jmNXi5NvLYABZctuCi38SqayxjKsnZdLkX0kBp0afJi9idK64AwPA+iAACAAA ABDABAA1iFcvzW7jC0vxM56J7m7412U+DdF1IhE+jx6+Osj53Jt5bWrEadnb13VyWLM6Ol5f CkXPm6E5NvHW049fLeNogA+e+iBrMQEV5y8tNya5SZWaN8tO4mumvrM59TW51nyfL3mNrPis tS0zi+UkeklmeXPRbfcR3ENcc+K5Hm/InbZ6fx731WgIZ43rAAIAKd0q2pesuMm9v6V4azef Ub0lu0wzvZNblzwAD6D5q3bOl2PWdc4tt0nF9KO08zx8/eV7eC9KBAB53oAAAAAARQAAAAAA AAACABkAAAAgGIAAYgGIYAAANZhXnt9LVfm+mnqKbEdd2EeckFyWqUpc2y7y+OrcQ66n1fp0 +UfL+rf57O1vbXj2px495daPMnrE6M83vbPg3pQ4Vqupnm/G276fu9P5Ovbf9mrye9puO08p rDrR2jytu47clOOadT1SkppTjlJVRj8nXG3l7tfj7Z18fYAAHleoGLzS27lisVXS6+g2jRrX bxs29mdtfKXX3eTNWx3stpOucH3om/f+V1rdsLH4ofYcY+nrtry6/wDcfN2124tv+q9O/M9p TGdV1Myu9ttxOludJ8G1SpwgOev481+natbc12+qR6a3upWn4e4WHzGqlFWPaief23mLivDv rXDnxR0bbnZXiWJa7bJZZ02Zxnrq1TtKa5opTlZdXiuZdavwv4x7M+RNqro8GSzLK7b7vgzo 27qZwZWnHGHqLrO5cczltqO3OEbqpI8/vthc2zc+9bb7y4dZ2LW4UjSpJqjyOczrcuvHy3T5 ezyIjtb3yitbm29MPs+w4zVHR4NZo7Sy9n0NN5vMwnimug5h1Ec6cdMmuTPTw3vHk/Ln01EA A9Dwuz/TUtO+S+aEkexPnuy3H7XcW7/CMlXq4n0N0eKyeKM7AAAMgAAKAAADkf1JFPYtvhON Dxh63+qLunbQtcZzr6InkjU7IQABoXbb9RdTNpi2v6i6mbqHk5vq/Z9T8X6P3AAOhxetKzhc i+lHXZyrC/Mj1o6romefl7xnYDjmIEcGXjrkdE5R5SaIGvzC2o7m4vvV9Zl0o+zrc6y/B8na Ytnxeg8jlWxKPyz96Ong8Hing0cbyGVPFh+FnZqz5nPMcmz6PDc6avLeYbJ7S7RdyWMH9XoM qtyeUW/QezrXMNTO2v5NkxZm+7lfx5bmXHwUbPb/ALezG3xSrLrZoisURBHk2t2tt9XpkxMR 469DRclHlJohpZr8yjo3VxdNfWZD7GlzrL8Hydpi2fF3fIJdi5B8HFnYwOB5FP8AOnHnD3M7 x838iY5K+hwXOkOq5BXoEB53YV5tcijcXIyjRSTdY4JnC85hp3UulRkUeX4biB7ePg6a8nl8 Xk35rm6Y+D01q5GXYjKsortLkWHL2U//AHr0ecfdQ6pw5dfHb59Xfi28tZf2AABydACwYBSo Hkt/DRuLkfvMzG/zVxnupuGKwrTnQxaHyPscdzpr8nyt5/Lb5u15BPC7D8MjsnA8kbhfaeCl Bne1I+f+RP8A/pfi93Bf4RICOtC1o8+HdIZDX0C19BcAlaTepVjL5oje4kv9RHUv+5DP0/T0 i1sNbOuu+0mL119q57aS3ynTb3i1R1R122px5rh1oiZ9OmWu29EuaLf3ClhfWl/9yH1ovhrt 9Fxf8az57a/XMz/KJgQlCSWpPVH5o5fw9JA53Wy4rpNpZmLRVXMrAmFWakLWisBgWa0LxFyI AMIn4nQLWyIFwHrYa2RAYD1PmKrAAAAAAAAAAAAAQxBAAAAgGIAAAKAAAAAAABAAAAABzox5 kopBgnVDcqdXM/SdHwhKK45FdKY82XJvJklCuHEgybmuhT+KDrU23bUW5XIrF0mvTmQv21KG KoW7O452bbrSlYP0ZGO1anZndukouOUsKcUdLw9e3jLOi0uplxjCFM1Kh0rCpa9ZjkvZdY89 fsu33e78r+p/UyqO5nDBSafJnXv208jm3bSyfqJK1glvbtKOjy4csi+3vXPtaY4T158eJgnZ ce6W7ezOidWm64rkXN9DDXG/pirmjswk5VUlx+srhvLC01UqRnqyzTKrkGrSrKuuWFegxxai 6Zms1MR0vFsONKv9TVlmguOzJXKSxlJSWGcTDgx9SLmmG+dm1KVzRJOsVo+wjHax1RUZYaMM eJirxyJJqq1PDPBkyNluN1qCVyuvCVcchq/eUHOSUqvw3wMvhQbopOvPUsBXX4M3BSco548x mGHQ/daZvxIPsR0Ta4ocNzbirbrSUG6VWcWc3xXJuuNc8P4i1p0b4Ll/EmTDptQcJQg06S8S HSi6drXO6o4q5HVHrRxqxWKwpghRk40cW1TKjZfIw7MO9ZnwlFwZXRxsyWUrU/Yc5bmcY6VN 0rWnSXrzC7qlJqMtSpLDMeSYdCqlecKdm9Gvp/4lavtW1d+O29EumJiXmEtMU4rVB9mVX6i6 PmVvXNuD0zVJxT9qGYYrXqgpq3lCfatv5WQ8aMo3Krt/HHg+ldJje8tStK24yrF1g8CcvMLf iRuRi9Xx5UY6HVdcnbULV2OKi6V+plk71uNycJS7Fxaot8zD+9hDUoW1ol8MnX3Fb3j8Pw3p 01qsMUTorrQu4W7v/bemXVwJeHRXrX88ThLdXZOkZOlKaeBfa3O5hNTT6KPFUM/cx3WaWus5 08C9y7PqZJW8b9n+ZejExR3ClacJrS09Uae41rfWvGV2ro4pT7PRRnT7mt9U8dvZOVzsWbq4 PS/QTVrt3rPzLVH0YmRbq2rUrVJPtVjgWPzBa4XFF1ikpVeZLya+5NNvZfq/LtXVnB6X70Tc Erl23wktUfec/wDeNQnBRVJOueQpb+7qjNaYuKoYvJqvhs1Tmo2rd5uml6X7zPPfWI3LsdS0 zyaxVTBcnF9+VTNduW6Uhi2Z883pGvDHett2zf3umKeqEcI6VgX2dpCxFXGvEk5USfdT5vmc WM5w7jcepsfi3ksJSpHFYuiOnlhjD0l3xHcvxxdIvP0FPgy/9Zyoljm6fEcxyvTSn4k6XFV9 rMVzbQ7WurpHUvozfncdIz4ujr21uF1SuRbc1px6Syfmm2hJyjOtIaI0TzpSp59yh8MEuvFk ZOpyvJa3NHorfmNhaHGapBNKvN5yf1cTHPziNuMI2Y6nFuXayr9ZxmBm71qaRsn5nuZqmuir q7KpiG1uNXYzk23XNmRFkHQ475s6uukkvR6ZoQoS1QjLmkM8D2gQwCkAwAQDABAMAAAAAAAA BgAAAAAAMi2AAAAAAAAV37nhwb45IsMO9nWShyN6a+W0jG+3jrazAAz2vCnah4k1H1mnfLCL 60PZ26JzfHBD3q/LT5M892zySez066447fdgBgB6HmdeLrFPoQyuw624voLDwXu+jOsgAAMq AAQDAQABTu7vhWZT40outlxy/N7vdtfzP6jemvltIzvt462uYsC2JSi6J9F81akdu3Dw4KPJ HL2cNd1clidY8nPt21ev8fXpdgAAeZ6gAARXI80sSU/GWMXRPoZzz0zSknGSqnmjh73ZvbOs cbbyfLoPZw8uZ4Xv6PHzcf8Afr+7Ki3b35WJ64+lcykZ6bJZivNLi5jrPzWHCD9Yv91XCHtO WFTj9nT2dfvb+7p/7q+EF6w/3Obyijmpk0Ptaex93f3bv9wuPgjPKTm3J5sgiSLNNdfpjN32 2+qmAF23seNKnwrMtskzSS24i/ZWP8WX8pvFlgsgPnb7Xa5fR01msxDEMDLQEAAAABFAAAAA AQAAACAAAYCGACGACAAABgIBkZy0wlLkmMo3ktNib6KessmbIW4lrz/A2eVRrfryi2ZGdDye PbnLlGh9PluNNvk+bxTO+rrnL85s1Ubq/C/qOoVbm141qVvi1VdaPnce3jtNn0OTXy1urzB3 vKr3iWdDzg/Yzgm3yu94V9J5S7LPoc2vlpfh1eDh28d58ejvgPIEqny30gkWRiOMGT0siksD m+YeVq/W7ZwucVwl/E6dAoa12ul8te7O2s2njt2eXXlm6fwMsXk+6fwpek9J6R4Hf/Z3+Dj/ AK+nxedXkm4ebivSXQ8u3WzTuWpJtZwXE7mAVRm/kb3vjCzg0nbLi2rtredz8u78r49Rqt7t wfh7hekwedWYwuwuQVHJY9aIWPMFJeHuVqjwnxR6dZnWb69r6e3/AMvJvJNrre/v7u7TCq7U eaKp21LH2oyQlPb9u09dt+r0my1ejfxt4S4xY7sWY7owuStvtYdPA6FncGJxrhTHkV9q1jHF fL9hm6o70Llcind7G3u1V9mfCS+sw2NypKsXX3o327ykcbLOsa12utzHntxtrm2louKnJ8Gc 3dQ0zrzPczhC/HRcVUzz3mnlE7cHO1WcFj0o78XJ/Lr0d9+Scml1v1TrHAAE6jPoPCD1/wDT nmC3Fr9rcf5lvu/ej/A8gTtXZ2Zq5bdJxdUyXqPo+A8Dl+V+dWt+lCdIXlnHg+o6jVDCjAKr kAgHXoBOoU9R5vzvztOL221da4Tmvch3HL8836325bj3ILRHp5s5gZAdEAhiA07RdpvkjWU7 aOmFeeJceLkudq+xwa+PHPj1AwA5u63bKt2PWdQ52yX5lXwR0Ko83L3Y2PIBakLUjlhl5/zm OndN/NGLMEU1izredRrOE1hVNHL0c2fU4bnj1fN5ZjfZv8klTcOPzQZ6A815a1a3MJLi9PrP Ra2eT8mfzz8Hq/Hv8MfFMCvWw1M82HoysEV6nzFVjBlw/OoU3NfmjFnNozs+bxxhLoaOY2z6 nDf4avm8sxvs0+US0bqNfiUo+w9FqXM8tYnovW58pI9JPs1b4VZ5vyZ/KX4PT+Pf42fFbrQa 0cv/AHfb8FJ+gt22/huZ+HFNOjePQcLxbTrZXWcmtuJsx+dRUrkJ5VjT1GPZwSvwdeJ2d5tf 3MUk6Sjkcm1blavxjNUkmezh2l08fWPJy62b+XpU93OVndyuQlSSa9x0rXm9qca3OzLiqe45 m/w3EueHuMtTptx67yeTGvJtpf4u8/NbC4t+gg/OLXBSZxAMf6+nxb+/u7D85jwhL1lF7zaV yDjCOlv4qnNzChqcOk9Gbzb31GRKoqFtqzK7NQgsWdezlJnpGjy6MpX4yisI97qOzcmrcXOW SxZGxYjYgoR9L5slchrhKPNNHz+Teb7Z9H0OPS6a49WN+a2OGp+gs2+/huJ+HBNOlcTgqLoa /L3o3EG3nWPrO+3BrJbO7z68212kvZ3QADxvaQDABAMAiMdVt6rT0v2EvFhLC6vDn80e6/Rw 9HqATVcHijpN722/lHO6TOdf41OdqVvF5PKSxXrIUFDXadbTpXOL7rJqdu46SXhT5Zwf2F8J t/67+yed1/8AZP3nZEROdtwdJKlcuTInKzHd1zkgGACAAABDABAAEAAAAAAAAAACAYAIBiKg AAABDABAAAAAAAAAAgGAHMlOLk9OCrgPWX7jZS29yVuXwvDpRQrR+gfDTjcRKM3wpUgrcV1j WlYjJhdGaVU1kR2L/JdOM20Z7u5UY6F2pvBGlNbW3GL+FYrpZi1uJbm6rcVqksHqa4nS2zT2 8WuKqeZuN3Lrc1i+B3/Lp1sq281XT1Gd50XVXdMV7pNl7MwXpYnNtkuYVoa09MKv5UjFceBs lL8pv8KN6pWXfKitQr8LfrZl0LgzR5g/zYrlCJkLb1J2WUksgUpIrq0PWx5GE3ddKMtsLXqf JL2lHiM1bZrRV4Vl7kWXKYwm9v3YxpqkU7qik6NN1p6jfalW9HHBfUjkOSbbebZbcJOqxTJq RR2ekOzzJkw0akLDoKMOYYcxkw0eoKU5GfDmFVzGTC+nUNRVTPXpDV0jyhhoUE82hqKrmjNq 6Rah5Qw0uK5oT0rkZ6hiTyXxabNyMJpmt7y2uJy8QozntPK5blxMOi99DpIvfLgjFQfoRPCL 51pe9lwRH91OWRWsOC9RPXL5ma8dWfKpJ3p5V9wpWpfFJLrZW6vNthgXp7J1WKFqOcq/hQ9d uOUW+tlQFymFnjy+FJegruXJOLqxELjwGaYdG3+haz+MlJptJfFBrPoK9vLVt19yTXrLI0/L fJ0Z0nZi93PSBRqOS0trkwcjk6oMiSfSSjbbyXrJjK5QWOROEHJ0WLL7dmub9WBcpRtdmPqR qcdv1J5ydnVs3I6YwyaSRa0c+zacX4l3Nd2PLr+w6DrzPNz8OunXX1eji5dtulVzuaesdreK L7cVKPFcfQVXsG8K8iKnCUVFLtczzWTDrm/JtvW1bl2XWLSlF9DKyx42LPNKS9pWYdJcwAAw pAAAAwAAAAAAAAAYgqAMQAAAABAAAFDaiqvJHIlJzbk+Ju3s9MFFZyMCPTxTp5PLzbdfFIcY 6morNkTXs4VbnyyOu18Zly118rhsjFRSiuBVulW0+ihcV3lW3JdB4pesr3WdLPg5YgEe9890 9o62l0VReZdi/wAtrkzUeHf6q9+n0wAAGGwIAAAAAoWJ5zd3fGuynwboupHc3d3wbMp8aUXW zzp6uDXvs8vPt21/c0WxKkya6D1PI7Hl0KQc+eCNpC1b8KEYckSPm77eW1r6emvjrNTAQGGj ABEUyM1GUWp92naqM5nmm5p+RHrn9hvTW7bSRnfaazyrlypV6e7XDqAQH1HzEgEBBImitFia IJomiCaJpoy0Zft9w7Lx7rzM9egK9BLJZirLZcx3E1JVWKYHK226dl0kuw/YdVOqqsjwb6XS /B79N5vPiAADm6AAAigAAAAAAAEMgBAAAMQAAwABAMAEAAAAMQAY/MnSxTm0bDn+aS7MI9LZ 04pnfX5ufLcabOQ6mjab17XV2dWqnsKGQZ9PbWbTx27Pna7XW+Wvd0n5zPhBEf8AebyyjE5o HP7PH/i397f/ACOUtTcnxdRJ0dVmAHVzeqsXPHtxuL4l7eJojE5fkd3XblaecXqXUzrHyeTX x2ur6mm3lrNgCQAcnRx73nM7U5W/DXZbWZUvPLra7MUqmXzOOndXFzdfWYz6enDx3WXx7x87 bl3m1nl2r2jVGBm2e8huoJp0ml2omip87bWy+N7voSyzM7GAnJCdyK4r1kxVcvzyNbduXJtH FR1vNdyr1LMMourfSc3wek+nwSzjnk+bzWXe4dbyZKducXg000+suvbNp6oYPoy/gZvKPy5z jXvL3HW1M83LtdeS47V6NNNd+OZ7slvd/wCHuFiviWZolgqvGPzr6yu7YjcWRmU7m0dY4xfq 9PI6a7zZ59+O6fL3aZ2nXXF0lzJ2dzjpl2ZcuDI2rkLv6WEuNt/UE7cbqa4rhxRbMubpWr/M 1wuHnoX52Go3MVwkdG1frRp5nLbQVeY+RQ3Nbu3pC5xXwy+xnmLlqdmbt3IuMlmme4t3iO72 dnfQ03Viu7JZo6cfPdP479df+izLw1GPSzfvvLruxfbxg8prL08mYz3TaWZ17OeEdLWKwa4n Y2v9QbuwlGdLkV82frOSMuTD0sf6oh8dl16GRuf1Rh+Xax+8zzgEGzeeabreYXJ0j8sMEYdF CQimC0oWlEhDIVEShDXJREa7NvQqvNmNtsR149PPb4eq3LLIAA8r6ZgIANmzj2XLm6Gkjbho gokjyb3NtUAAGEc/zWNbUZcpe85FDvb+OqxPox9Rwqnu4L/HHtXi55/LPvDtvROMuTTPSyzP MuEpKiT9R6O1LXbjKmLijH5E+mt/j/3RIAA8j1AQwAweaRrZUuUl7Tjnodza8a27daN0xMK8 pfGa9R6+Hk111xtfV5eXj222zrHIm6eg9VF60pcJJP1o5n+zxec36joW4eHCME66VSpnm313 k8fRrh020z5ery7g4SceTaNfl09G4g3k24+s6kvLbE5Ock226vEnDY2INSjDFYrE3ebWzHVz nBtNs5nStJXetxnFuSxiqxfIsIzfYl1Hl1uLHq27VyvNLcncV1rsuKSa+swJJ5Js9O2mkksE qAeq8/jfHHZ5pwTaTbPd5pWpPKEn6CxbW68rbPQ1YVM/7F9mv9fX3rgrY7h5W6E15duOSXpO 0BPv7fBfsafFyF5Xf4uKN+02q20aZzebNAGNuXbaYvZvXj11uZ3MBAcnRhXlVni5P0llvy+z bkpRTqnVYmoDd5Nv8qz4az+2GAgMNAAAAAAABDEAA0mqPFAABblO1hB1jxhLFEou3ddI9ify Ty9D+31kRNJ5nWcmem/X/tyumOvHfH4eiU4yg9M00+kiTV6cY6GlOHyvNdRJW4Xf0Xj8ks/Q +JLpnrpcrN8dN54/9KgG04vS1RrgxHN0AABAgAAABiAAAAAAAAAAAAACoQAAAAAAgAAAAAAA AAAAAJ+eblXb6wotKfSzkPVmd3z7beHKN6nZktL6zjo/Q46PhRViK5Jwi5ckWtMpvLsRj800 StRWktpjndon+Gv1kZzuTScmscaF+87smqYzb6SGiLinKSUXRYdBiNVKFrVLqdGzZek4Ti4/ DgK0oN0WCQr2Kqs0dGWpX4bjvYS5mPcWJLFYrmZ50nHpRBX7lvJ16zjtx47Ok291EnV0fM3X I/l0TzlQolehcprjR1zWBfcmqLokNei3qwb7/UTWdHT1FBduY1vzpzZU4tZozViIh1EAjftl SEfSYDqWI0hCnFfWXXulWrCc38sJM4x1ptKF5rkl7Tkl2SAAAyoGhAQSoiVIkKhUKswCiK6j qBZgOhVUeoC0KlWoNQFgiGoWoCTGiAwidRkEiSTAkIeljVtgRAlpXFoKR6WBGpXcZe6fCvWU Sg82zWKdG3YJytXY8tMvaanBq3Tipoq8ut0s3G1m4xRqVtSSivilX1G9WK5922/FkkuLzIqx KT+wuuycpSlWixzCyrkqu1FtfNLBGvGepmlatpPLtdJNpJtZj8CnbuXKy5QRdcpayWGDVTUx 2ZqhW3O5G0sHLiWWIO03RJp6u3x7OZDXpvW5vDEhHcuM3oVUq0T6zNzmYanatkrjgk5vs8Ir Ns2W7mpLVhLkc5W23rnjJ8TTCVFWmKM8nHN9fGtab+G2WmUVJYlfhuORcB8ns+liUk3RJ8FQ YYBgRSAeAYEUhhgFUAhhVBVcgAAr0BUAAKhqAKiBuogGAgCGAgCmACl3XTkyo5u4ueJcb4LB FYIZ7pMTDwW5uSOrat+HBR9Zy8ibuz+ZmN9bt0jpx7zXrXUE1VNdDOX4k+bE5y5s5fZvu6/e nsrQhsTPS8rd5e8JLqNlVzOET27auwfScd+LNu2XfTlxJrh2gGxHkesAAAAgGgrlebXV2bX8 zOXWPSXbu7412U+FaLqRnPo8evjrI+dybeW1qSaNmwtq7eiqYLtP0GFHZ8pt0hK4/idF6Ccu 3jravFr5bR0WwAD5z6AAACgAAgq3F7wLcrmdMjzzk5NyeLeLO9vVqsTXRU8/VHt/Hkxb6vH+ RbmT0OomwqjV5fbhdvpSyScvUeja+Mu19Hn1nlZr7t2z2EFbUryrKWNHwRqW0sL4EXNiPmbc m1ucvpa6ayYwrW3tL4I+okrVtZRXqJVCpnyvu1iewUIr4V6incbdXVWOElkXgJvZcyl1lmK4 rqnR5oDT5n+Wo3Es3RnN/cvkfQ0289fKPn76+G3i0M37CVYSjyZx/wBxLkb/ACq85zlB8VX1 GeafwrXDf5x1QEB8/L6BgICZDEADIAAYyEAwGQgGACAYDKgQwGQAADIKCoMYCoFBgQKhx/N5 uNyMfunZOF5u/wA+nKKPRwfW4c/0MLmzobfyuV+2rmtJS4HNPTbFU29vq+s9XPvdNZdfd5uH Sb7WbezCvJVxuewkvJYcZv1HUA8f3uT/ACev7PH/AIuY/JbdHpk9VMDjUpgz1pwPM7PhXtSy n2vTxO/By3bbx3ufZw5+OSeWsx7qdpfe3uxuLLKXUelb5ZHlDv8Alt/xbOl96HZfVwL+Tp0m /wDU/H276f0aJX7cHSUknybCF+1cemEk3yRyfNoabyl80fcVeXT0biHT2fWc5wy6ecvo3eaz fwx6tPm21m5ePFVjRKVOFDk1PW5HK33leqtywseMPsN8PNJPDb9qzzcNv89P3jkRk4usXR80 T8WbzlL1leWeDHhzPZiPHmp1bzb9Y0RRYoSeSfqHQ6miawCNm48ov1G3ZbOUp6ripFcHxMbb yTNreum21xhp2G30LxJd55dRZvLs7UFKHOjNJTurbu2nGOeFD5/l5b+Wz3+Pjp46uc97e+b2 HUVJxUuaRy1sLz4L1nS28JQtxjPNYHXl8cTwxn4OfFNs3zzj4s13atOtvB8vsf1Dt7uvZvVq vj+JdZtpVUZRe28bmefPj/Ezryem39Wd+H10/osdJLt0cXlJZP7DO4T2zrDGHIpjK5tXjjF+ pmu1eUlWOXy/YdnmaNvuo3Fgzdbu0ONc2+p+JZdJLgSsbzHRc7MjG2qO/WNyLjJJxeaZ5/zD yJ263dr2o8bfFdXPqOnbv0NkLlcjGt247nX+h37vCjPVeYeU295+ZDsXefB9f2nmb9i5t5+H djpkvb1Ht4+TXft39mbMKwADqhAABABONqU8sjTC1GHSzG28jtpxbbfCe6Fqzp7Us+CLhgee 225r366zWY1IBgRsi/bW9cqvKJSlV0WZ0rVvw46fWc99sT4iQUGB5ggGIAomCSWSQAA6iAAA AABAAAIBiIAQxAAAADIXO5LqZIVzuS6mIl7HDuoYoYxT6BnTf6qxp9OvyAABhsDEAAAAAAAA AAAAAAAAAAAAACAAAAAAAAAgCMoqWfrJAWXHYxk1emlpufmRWVe8vSSjCN3Gy684PvfxKxSi pdD5o6ec26ck/dy8Lr/67+17GBLxXSl1a18y7yGretVtPWuXxL0C8frp/KLN/Tb+NQEFQOTo AAAAAAAAAAAAAgAAAQDEAAAAAZAIoAAAAAAAAAA9duNrDc2pWp4qS9p4u9tpWJytzWKwZ7vT RYnF882PiR/cW12o97pR93Tbr418Ox5aUHHEzXJa3GKWMXV9fA6kYricy7HRKSg+Lx6X9iOm y6qJtyng6pGnb6dEqcXlyKnbfw5Flisap5PgZVrttx4UrgVzn2qIlKVJW+nUvYVTlVmoii5h kQcuDLpqqxKFHMoWBoutaa8pGbQ5NRWLZZKcqNNOlamNmoo3qpfl1lSrwL98vzXJcSqKMYy1 lCUXmRcWs1maJYRzHfTWiPGhPEyy0OptmlGD6F7zDQ2WZdiKWL/iWTBlK462rvoftOXTpOs+ 5ejTHT9ZzIxTJZkiGnpHofQWq0nxH4K5k8auYp8Nh4cuRf4K+YatcNTGKZjP4cuQeHLkalaf CTDwn8zJimYzeHLkHhSNSs1fefqH4P3n6i+NMxl8KQeFI1+D95hGynxdR40zGbwmPwWafBjx b9YvBgPCp5Rn8HpDw480Xu1Hg0SWlYpx9RNpY1LKzqEObZNQXCLZoV9Ll6mC3HS/7Jnr7NYn uqVm48oesmtvc6ET/cVr3vUJ7hvJMY29kzr7mtrJ96XqJrZ213nUqU5y4etsbjdeVFjyL4bH lquULMOCKLtyM1RKiTzI6JZSkR7EeNTU47nNrN3naQaU8veRTjCak1gscOZJXa4Qj7Cx+HhO cnJJ5UwOtw5xp8O40oZRzq3jJvNkr0rkcYtQXcTxwXEqlf3F6soqiKXbbp4k6PlmZkq5Sj4c HRJyk/in9gN3L0aylSmBdSU5KUY0wzZGtu0m5dp1NpkoU0qEU3R9qhdjK1XBaG49Jmu7m5KN IYRHtouMu066+y/qCK7km6NYtOpNQjBpxb7WLl90sUYQxedciMISuJ21gk6+h/YyiyDrgsS+ NSiDitLjyxZqiq4lRpi6pMZG13ESPkcuuN9p8X1eO501vwAAI5YbAxAMBiEAwZMBAMCQEQGB Ii2AEAAAUAAIgdQqIAp1CogA5GpIPEiWbmCjckueJmlFHvlzJXg2mLYs8aC4i/cQKHEg4o0y 0/uYCe5h0mRxI0GBr/dQ6RfuYcmZBFwjX+4hyYLcxi1KjwaMgxhXqXOuPMNRm2lzxLMJcaUf oLz5dzLZ7PpzFmfdLULUIDOauD1FW5uu1ZnNZ0w9JYYPNZ6bSj8z9xvSeW0nxZ3uNbXH1MVR AfUfMPUz0m3j4dqEOSPPWIeJcjDm0j0zzPH+Tt9Or1/jz6thUBAeJ6zAQAMAAKJR1xcXxTR5 Vqjo+B6tYHnd/b8O/NcK19Z6/wAa9bq8v5E6TZmNGyueHfhLpp6zOCdMT2bTMs93jlxcvVvA CMJ+JGM+aTGfIfWMBAAwEMisvmMNe3l0UkefPUTjri4800eYpTDke78a9Lq8X5E6zYjX5fc0 biD4Ps+syEoy0tSXB1PTtMyz3efW4svs9QAatXaXHED5D6oAAAAAAAAqFQAYgAYCABgIAGAA ADEADAQwAAAAOZvfL7u4vOcaaaJYs6YG9N7pfLVnbWbTG3ZxV5Nd4yidexb8K3G284qhMZrf k23mNmdOPXTrqAADk6GUbnbQ3UVGdVR1TReBqWy5ndLJZisC8pscXJ+kvsbO3t25W61ao6s0 AavJtel2Zmms6yRVe21u/TxFWmRCOxsQalGGKxWJoAk22kxL0a8Z3wAADKou1BurjFvnQahF ZRXqJAXNQLqQ6iAKdWAhgAAAQAAAAAAEZQUl1+0xT27i9Vmqazjx/idAhO2p9DWTOmm+Pk57 8c3+fuyW9wp59mfs/gWXFC92bnZnwZG7bU8LnZnwkuJS5Tsdi6tUeH8GeiXLxb6XXusheubd 6LmKOjZ3Ca1RdUc1x1x/LepcnmiNp0fZ7MuXBizLD0Vq8pdY9xtrW7houqvLmuo5NrcVdHhJ cDoWtxwZxuuOsHE3flT2zri4cJL6zJ+2jzZ7BSUlR4pnL3nlVKzsemH2HXXm27bV30ul6b6z 5uItvDpJq3GOSJ5YPBiN+Vvq9U01naQAAEaAAAAAGyxt9PannwRnbaazqp7ezo7cs2aAA8tt tzQAAEAAAACGACAAAAAAEAxAAhiIAQAAAAEAKXdfUxg8n1MqFb7q6kSIWu4upEzpyfVWOP6Y AADDZiAYCAYAIAAAAAAAAAoAACAAABAAwEAAAAAAAABAgGIAIuOOpPTLmiQFls6xLJelS8Wv 6yr9+OfpB221qg9Uea+tESKjpeqD0y5o6+Wu31zr7xz8dtfo6z/GmBPxIzwurS/nj9aCVtxW rOPzRy/gZulnWdZ7xZvL0vS+1QAAOboAAAgAAKAAAgBAAAAAAAAAIAAoAAAAAAD0D3l+48I0 XSQnK64SUnWqyNyrJ4YElaqus+/mR8DrXhr7uRjJLNYHPU9cqcEsD1nm9q3buqSarJYo8ZDv umQvu6auhbiqZ0YOCrUjFugpSAvcXK06ZxeqPoKNdUpZpm1p24RazWJhvw8CeqP6cvYyxUtX FZEJJCZFrkVE4ScJKUXiixbq0pJztuiecePoM4OVDNjUqN2SvXJTxxeFSLilwaLMHn7BJKuA EWnTB8cuI77/ADnwokixwrKP4vSRu08WdeZFVOlCxRlGKksGlk+kJUfAujupqNGk0sEmuApB auNOWpYSTqYoqjosUbv3rcJW9EFq4lNOoRFaQ6ssVcHgFH0GsIjWqQRJPrSCmOYwJJvJcQaq KqpmDSGESWDboGfAJaU+IuzQuA9WFAQk4pZDTVa0AElm2Naa4iU+gcZtYUAEk8kOlFWhHxKZ 0QlfrhHtPoQyJN15EksCMY3pcNK5ydCDjR0ncw+6TJhZhxIK7BNpYsjPwrbo4tv7xZK7NQUr aUYt8ETK4KPitdmNFzeAaHJ/mXKfhxYmpRkvEdYvkKNuMJpwbbTGaKWoVdW3iatjZs3JNXey lSmOZG5ZnOepRz4VoP8AbNd9xj1Y5GcWrlVd1Sckm3FN04KhZZi1F0SaeBZGFrLTqa4yHKVc MlXgamqWkotJa5UjyiOM4wVIxSfPiQ0VxrgWKKXpN4ZyqlclJYsi0lRZljXBizyAnaXQRcm2 4ZJ44cxwS9I3CTaeCAnc/No1xWr7QglRp5UYrWWmTrRv24ijJRdOOJFSWiCpFUdePBF9aJmS MdKlO48cKIsuXaRkwLdnuXO9K08uHWjec/y6w41vTwcsjoHg/Ik8pfd7uC3xs9iEMR5XoAgA AAAIAAEFMAAAAAIAAAAEMRAAABQAAQZ9xtvGadaNYFL8vr8RtA3OTaTEZumtubGF+XJ/ERfl ifxew6Ai/d390+3p7Of/ALXH5/YL/ao/O/UdECfd391+1p/i5G68uVi27kZN0aqjnHpbsPEt yhzTPNHp4d7tL5d483NpNbPHsDp7by+3etRuOTq8zmHX8puVhKHJ19ZrmtmudbhOGS7Y2mWv b7dbeLhFtqtcS4QHzrbbmvfJJ0hgICKDkebTrcjDkvedc8/vbniX5vpp6j0fjzO+fZw57jTH uzgAH0HgbfK4ar6fyps7hzPKIUjOfOkTpnzee53vwfQ4ZjSfEAAHB3AAAQwEAUzkebwpOM+a p6jrmHzSGqxq+V+868NxvHLlmdK4YAB9N853vLbquWVGvajhToNh5m1dlakpwdGjtWfMLVyN ZtRlxTPBy8Vl8tesr3cXLLPHbpY2CKf3lj50R/e2PnRw8dvau3lr7xoGZf31j5x/v9v8/sL4 bf41PPX3jUjzW4cXdk4d2rodLeeYQdvRZdXLN9ByT1fj6WZ2vTLzc+8uNYAAD1vM9Dsp67EH yVPUaDneUzrblDk6+s6B8rkmN9p8X0uO51lMBDOboBDAoAACAAAAAAAgAACgYhgAAAAMAAAA AAAABgIYAAAADEMAAAKAAAAAAABiGAAAFAADCAAAAAAABiGAAAAKUVJUaqil2nFUXag84svA 1NrEslmK50tu49uy26fD8S+0I34XcLuEvmR0HFPHiZ7+2jcxyl832nfXkl6V5d+HHXT+hu3q SUs/hkhRuysulzL5jKp3Ns9Mlg+HB9Rrt3o3VTNcnn/E6YeZus7imWRut3VLI4OiVrtW8Y8j TY3KlijntqN+62NvdKq7M/mOFfsT28tNxU5PgzvWtwnmXThC9HRNVTMTa6/J205br0vZ5cDd vPLZ2O1DtQ9qMkLUp5I6zaWZezXabTMQJW7crjpFGmG0Sxm69BpSSVFgjG3JJ2aVWrEbeOb5 loAcLbe4AACAAAAAAAAAABAMQAAAAgAAEAAAgACAAAIAYhoorsfposKtv+mi06cn1Vz4/pgA AMNgBgACGIBiAAAAAAAAAAAAAAAAEMAEAAAAAEAAAACGIAAAAAAAAUdVt6rb0v2DEam116xm 6zbpsnrhPvrRLmu6xTtyhi8nk1kRCEpWv03RPOLxTOmddvq/jfdjG2v0/wAp7UATrbnh3Jcn 3WRnFwdJIxtpdevp7ta7zbp6+yIDEYaMQAAAAAAAAAAAAgAAAAABAAFHb3Xn9iw3G03OWWGR zL/mO/3Ueynbt9HH0nYseVW7dGko8FgXbi/ttlBu40lSmOb6j73Sdur4PzeJv3PDhKVayeFe lnPtJGnezVyeiOEVil1lUItFvd0nZfVcR9i3FTnjJvsQ+t9AopQg7tzGKwS+ZmJXZXrylIdi TLszucyictKertQl3lyIq4pKnIHc1Kj55cxSKJ2JQxtPVHlxRWrqyyZdRrtQ7zl7BzuapuE4 qVOIyuFSdcagq8xK3Zn3W4v1h4VxYxal0cRkwTbIrMauacJpoaknJUKLcrkcMa5lc6eNPrLW 3g0sNWDRXP8AVn1mQuIs0DVWNVeBQlHoJNLKgaHzDRgENU+jDCmBGmGYm1zAsrwoEc8UivxI 8WCuKvZx9AyLHlwE1XJj8O7JYQaVM5YArUmsZpUGTBUXEfZWbeQeHapWUpP2L6x/lwWuNvDn J1GVwg7ltc2+RNanircqfewQ5XpqClGiX3UKMZTrrlR0w1MZD7SrjGNfSxNQo5SlKX4VREbK UKqbVGsR2qRTiouSeRArcoSdIQT/ABE7Vyd38uulckRhalB1VI04jSjWs3WvIYCs1hN+Jisi NyMJOsM+ov7CVYqr6QndcuivA1hMoXVK4ozccuyGlpOLfZTyRKNXWLeZGLSdBhMpNW6YKq6W S1ulFRLMrpgTgsKs1hBJt1qxaEqPmTSqqegcWtOKyYCfBgsaidWvtIal1gOTT6SadVXgVZvA lFpYZsCbxwKuJdKqlhmVSXPBANMk5VRCJbGOrDJAVWpKM6LFsncWl6sP5SXhwiqJVk8UwcYu aTWpSpJKuBm2TrWpLezJ4mp4pucngkbrW30pT3GC+G2s/SKzfq27UYxosXxIq45vTHtTrWvI ZGyN53JpZRX0RqMdq24tQi641kzYzxfkzrrXs/HvSwhDEeR6QIAAAAAEAAQAAAAAAFAABAAA AAAIimIAIAAEFAAIgYgAimnRnnd3b8O9OPT7z0JyfNoUnGfNU9R34LjbHu480zrn2c42+WXN F7TwkmjEStT8OcZrg0z27zy1urx63G0r0oA3XFZMD5L6gAAAUpaE5PgmzzDdXXmd/fz0WJdP ZOAe38adLs8f5F6zUAAJVdFxPW8rv7CGixHprI0hGOhKK4JID5G1zbfd9XWYknsYABlohiGV AAARQRu2/FhK38yoSGOyPM3bMrMtE1Rogej3G2huY6ZZ8HyOBfsTsS0TX8T6XFyzeYv1PByc V06z6VYAB2cQADCgAAAAAIAANOz237i5R91YyJtZrM3ssltxHQ8r27twdyWc8l0HQDoQHy99 rtbtX09dfGeMIYAYaAAAAAAAAAAAAAAAwAAAAAAGAAAAAAAAAAUAxDAAAAAYAAAAAAAAAAAA DEMoAAAAYhhAAAAAAAAxDAAAAAAAAGAAQnbU1Rqq5HOu7eVp6o1a9qOoJpPM6a73X5OW/HNu vaufa3XzPHn9pc4KfajhL3kb+zr2oZmSNyVp6X6meiWbdnj21utxXQt7hxemeDOha3FMzlxu wvKkv4oFKdjPGPMl1yw9DC4mugz3tpq7VvPkY7G44pm+1fUjjdWtdrrcxgaadHgxHTuWo3lj nzMFy1K08cuZze3Tkm3wqsAAjqAAAAACgAABQAEPLMi5xXxL1hMmBB3raznH1hC9buPTCSb6 C4pme6YEblyNqOueCRTDeWbklCLbb6BNbesiXaS4t6rwGIigQxBSAwbjfTs3HBRWBln5rfWS j6jrOHfaZjjebWXDsgeffmu5fFL0BHzPcp11V6KF/wBff4M/f1+L0A0ZtrvIbpYYTWcfsNKz ONl16V2lm0zOyrb9xFpVY7npLTfJ9VZ4/pgAAMNgYAACGIAAYgAAAAAAAAAAAAAAEAAAAAAA AQAAACAAAAAAAAAAEAAAAAA1XBhGUreEcY8YyyADWu117M7azbuktE8I9mXyy+pkZRcXSSox NJqjxHGcoLT3o/LL6jf8dv8Axv8Awx/LX/yn/JATSjc7jx+WWZBqjo8GY21uvdrXabdgAAZa ACABiAAAAAAAAAAEAHed3d7x0tLw4cZyzp0IT8u21i1cuT/Mnpk3cni8Pca53dOEcThf1FuZ WtsrTdJ3nkvlWZ+g/wCHwJ3eW1O49eHaxqy1txWrNMph8tOlGq3aldrF0SeOHAkdavnZW420 YxaUlV4nMW0u25Vca9WPuOlej4aWjlxMjuOLeFXzQvdYqc3HBpokriJy3FxrBvkRtKF6ei52 W8NVPeayYWwevPgJzbeD9YSirNyVuMtSXErcSYE+wmqxaoqYYlahSK0PEK50BvDrJhcrYznG NZ4rkxOFp40cJdGRO3VZNPokE9Lq5KjfLIgqcZw0vNd7D7CvxNdyUopurOjs4O24UpjGVWc7 VLxJJZ5jIu8K7LFxp1tIbsSzlOMerEj4UpR1N0b4tj8KOlNyWBcoSs2+Nx+iJGUbMc3Jln5e tSTrzohzgpt0i8cMcAqpq1Gj0OnSxqdldrw0CrRYLAk01VUjSRASvu3lCMeOSJTuXlpaeDxW ngCk6JNpUwBOmDm8AJThpkqvs8dTM7iqtV6i7Vbjwr1si7te6kl0FwmVibnb0OMpch+HKMND SVMSpynLN5YCcZPMuEym4pVjKXZzI1t0WbdAVtccSbt0TLgyNVKNRS4kZOTeLzLKdnqIyeFS or08WS0VdaEskx0wVQh0XH1EZOqpyHqQSVGURiw06W6dY06ccOoG1hhgBdLHHDFEYySwIa6L qIO8k8wLYzbqmR1UTXIhbjcnKsIOXCpb+3bdbk1F/LHtP7CZXCuc0syEHO66W05dSNMYWk6W 41l81zH2Ze8grzuS0OTceJMrhBbe48ZNRXr/AIe0FbtRXalj0S4+hMnZ26vvttzpwrgi6VpW LdW0qVwRjNvq10noN1OLcHBPu4VMzXMncdXGmSiitvCr4HSdmDhjnwJRnR4cCOODHxqsSomq uTaeJZBu3JSpjFujeWPElt8cHxzHPurUqrKn4X/Em0l6VZcFHaqtZOtXjpLYR0rSlpRKUVDC OFCCdX7xgy0W6LItM6nRo0PB0PF+TLnV7Px702IAA8b1EAAACAAAAAAAAAAEBAxAAAAARQAg IoABEDAQBQACIGIAIoMfmUNdmvyupsIzgpxcJZNUZdb47Tb2TaZlnu82B2f9ss/e9Yf7ZZ+9 6z2/f0+LyfY3+C/aXPEswlxpR+guKrFiNiOiFaVriWnh2xm47PZrmSS9wAAZac7zadIwhzbZ yT0F/Zw3ElKdapUwKv8Aa7H3vWezj5dNNZre7y8nFtvt5TGHENGyh4l+C6a+o6f+12Pvests bK3YlrhWtKYmtufWyyZyzrwbSy3GGgAA8L2GAhhSGIYQAAEAMQwoKr9iG4jon6HyLQLLZcwx npXnNxt57eWifofMpPS3rML8dE1VGX/a7PT6z2a/kTH8+7x7cFz/AA7OKB2v9rsdPrH/ALXY 6fWb/wBjT4s/Y2+DiAdv/bLHT6w/2yxyfrJ/safFfsbfBxAO5/tljk/WH+2WOT9Y/wBjT4n2 Nvg4iTbos2eh2u3W3tqPxPGRG1sbNqSnFYrmaThy8vn017O/FxeHXbuAADzOxDAAEMACgAAA ABgIAABgAAAAAAMAAAAAAAAoAAAgGIYAAAFAxDAAAAAAAAA5u48znZuSt6F2XzOknVJriqm7 pdZLe17MTabWyegGYN/v3tWoQo5PF14IPL91e3TcppKC5LiX7e3j5+ieevl4ereBVuZyhalO Heiqo43+6bh/EvUXTj23mdU35NdOmzvDOB/uO4fx+wf76+/jOn+vv8HP/Y19q7wGDy7cSu61 OVWqND8wlOGiUG0nVOhz+3fLw9XT7k8PuNwGTy+45wlqdWmazO2vjfFrW+Um3uYABloVXNAc fzCFLz6UmdLay1WYPop6jrtpjWb57uWu+drpjsuABnJ1BRLd2YtqUqNZovMW/wBr4i8SC7Sz 6Ub1ktxsxvdpM6tiaklJYp5DOV5futD8Kb7L7r5M6rwLvpdLg03m8z/VXevRsx1zyyMyvWt3 Lw1F5VryKfM7lZRtrh2mW+WW6Qdx/E6LqR0ms10+56+jldrtv9v+31U3dtO12ljFcVmh2ty1 hLFHSoZL+zU+1DCXsf2F15Je/SuW/DZ116wlH47eXuL7O554M5qlOzKj7L5Fyuxn0S9jN2OD uWtxwkaqqao8UcC3dcOlcuKN1nc8U6o57aiW72122te3Snzg8/QcV+Z3ctKTXBnp7d1SyM29 8ts7ztNUn8y49ZnXxn165+Lp9ze/3PPvzK9931EX5hffxJeg3y8rtW3SSlXrBbCwvh9p08+L /F18OS/3/wDK6xPxLcZvNrE5u9u3Ld5xUmlg0dSFuNuKhFUSOb5nGk4y5qnqMceLv8K6csvh 8Y17GbnZTbq02jJ5mmpxkq4qnqLfK5VhOPJ19YeaRrbjLk/eWfx5f3Zv8uLPwcujfNjVqTyi /UbfK5Uuyjzj7jq1Ou/L4Xxw58fFN55ZefW3uPKD9Rr2Fm5bvJyi1Fpps6tQOW3NbMY7u2vD NbLnsp3MNdqcehnFsT0XIS5NHfpXDmeca01XJmuDrNtXPn6XXZ6NrEQRlqipc0mB5cYeoCGI Dk+ZRpdT5x9xXs9nb3OrW32aZGrzSPZhLk2ijyuVLso84+49mtv2czvHksn3cXtV68p26z1P 0lO88utW7Mp200445nUIXoa7co84s805Nsy3avRePXFk1jg7Gei/bl009Z6PJ0PKwlppLk0z 1VauvPE7fkTrK4/j3pYqsdz0v3lpVY7r/E/eWnHf6nbT6QMQGGzAAAQwAAEMQAAAAAAAAAAA AAAgAAAAAAAAIAAEAxAAAAAAAAgAAAAAAAAAAAQxBCaUsySnJKku3H2oQG9d7r8vZnbWbfP3 TUFPG26/deZATipZ58yfiOlLi1L5l3jWNdu38b7ejOdte/8AKe/qgBNQ1Ktt6ly4ogYut17t yzbrAAAZUAIAGIAAAAAPVK0ngjw3nm7/AHW7lpdYW/y4ejN+s9h5pvHstrcvLv00R/FLD+J8 +SwofffD1nqlaTlOKWdTpxtxtLw4ZZt8zNsYaVK61j3Yml9ldLN6z1Wqr9yWWa5Gbx4r4MeJ bcl/wM7kqdZKsTszg59qqVG2WRVuU01ilWRkipVco4tFu3g4XG5OiUXJ09xhpXGbnccmX5me ysKs0JYUWBqJUaYdYUo+onHB9Q6ccuIRXpdKL0lGfQXuWHWQXsCtG2vuEIuWCi6auJlvVjdf FPGvNF0oLQ1qpGvdHuoxjOOnu6FQzhcq1pi6tNlquLhFL0FUVqVSVWjWGU3emnVEZzkwlES5 MCuSdQaRJ8GFKVQEJUiLxFzNCko2ou3BSlVqUpY+wh+e2qJL+VDK4QV5UeQ1fi8ySvXYOklH lTSixXE46nGDSePZJkwr8eNKDV6NS+LsypW1HFVw/wCJU42qKXhpVwzZcmEXf4LIfirHmyUr VqPet0/mYlG1hW3nl2mMmChNNUZF3aFjjZjjo/52OcbcMNEV0tt/WPJMKY3lmxrcKlEXK5C3 FSUIerEnLc9nVGix4f8AAZMM8bk3hBN15Ifh3X8Lr04E/wB0595y50r/ABI2p9tdldbGVwfh TVdTivTX3D8JPCUpeiNPeFtzUqcKMlC1ckmsW3mMmC0W4LU41X3pP6qFqu6JKMIxVVXsr/iy DsLT2qYc2Sk7UaVlw+FE6nQSu3LlatvkiNpSdeL9ZN3YVWmDeGcn9RX491ppSonyLhMpW7Wh OTajwrJ4kbd5eIowWtL0L1EfBinWWJZCuPwrki4TJ6n484tujeUCq9YiknJ4utIhGTszaj6W RV1PNamBbdS1qvyx9xVXS8OJY2nP+WNfUVzWFVzKEnyZdGNV0lKquRZB9qjCLbUqPOpPcS0t x51fsKtOPQKUW5VkssKlo0XppuvFitusqszpuiryRdatylnggNEYubq8kehsab9mLlFNUOC5 JLDJI9Ns4Jbe1T5VU4cvaOmjLLY2XjRqpXLytNVhL0M6TwePMJJJs8/jL6O032nq4s/Lr0a0 pKhnnZuW+9Fo77i1hzGpNUUssjF443OWvN1A9C7Nm5XVFGeXllqTbxUeFDN4/auk5Z6uMB05 +UP4J+tGeflt+OSUuoxdNmpvrfVjAnKzch3otegrqZssbzkwARlTEAgGAgqRQAgIGAqiIpgI ApgICKAACAAAIoGIYAAAADEBFMQDAAAAAAABgIYUAABAAAQAxAAwAAoAAAAAAAAAAAAAYABA AABSAYBAAAFAxDAAEMAAAAAAAgAACmAhlAAAAxDABAMAhDAAAAABgAAAAAUAABHE81hS/X5o pnT299R2sbssoxx9Bk84jhCfXE50txJ2VY+FPUeya/c49J7PJdvt77/FXcnPcXHLOU3gel29 hbe2ra4Z9ZyfJ7MZ3JXHnBYLr4naM8+3Wcc7Rvg16ed77E4604800ea2ySuwU1VaqNHp1gzz W6h4V+aXCVfrL+Peu2vvE/I/t29q7/7Own+nEa29pZQj6jJ/u9p/DKof7rby0s5+HJ8XT7nH 7xujbjDGMUuozeYRrZryaZrKtxHXamug563G0re0zrYxeWS7Uo81U6Rx9hKl6PTVHYOvPMbf Ny4LnT5GAAcHdzfM44wl0NF3lsq2muT94eZRraT5Mq8rl2px6Ez0zrxfJ5u3N83RGIDzPSYC GByN/tfDfiR7ks+hmvYbrxV4c32o+1GqUVNOMsUzh37EtvPS/wCV9B6dLOTXw27ztXm3l49v ua9r3hXrjvXJSXxPA7lu34UIwXBHJ2FrxLyrlHtHZHNcY0nocM7731AAB5npQuW43Fpmqr2r qOdf2srPaj2oc+K6zqB0rM668lnS9Y478U26zpXHjekqY5ZGm1cU3WPZny4Mnf2UZ9q3SMuX wv7DBJSty0yTUlwO8svWPHtrdbjZ17W4o6ZS5HQtbhSweZwIbiqpcVeT4mqF1xVW6x5ozdcs u5KMbipIxXtvK3isYhZ3PqNsLikjhdXTTkuvycww+ZxrbjLlL3navbVPtW8+RzN9BuzNPNY+ oaXG0vxeq7TfTbHsw+VypclHnH3GzfR1WJdGPqObspab8Hzw9Z2bkdUZRfFNHXm6bzZji/lx 3Vwtvedm4riVacDY/NXwgvWc5ZHU/wBqj879R35PDpd3Hj+5ZjRU/NLnyxOr0mD/AGu3xlI3 RWlKPJUPLyXTp4PTxzeZ8wcLdx03prpr6zunI8yjS9Xmka4L/LHvGeefxz8XQ2ctViD5KnqL zF5ZKtpx5S95tOfJMbbOmlzrrfgQABhtk8wjWy3yaZzNlLRuIPm9PrOzfhrtSjzTPPqeiUZ8 mmevh66bavLzdN9dnogWY5ZiPE9bzNyGicocm0ei2s9dm3L7q9hxN/HTuJ9NH6zqeWS1WEvl bR7OX+XHrs8fD05NtWixlL8TLSqz8X4mWnDfv+0ejTt+9/7AABhsAAAMQwAAAAEAAAAAAAAA CGIAAAAAAAAAACBAAAAAAAIYgAAAAAAABAADABAMQAAAAAAhgERaxrk+aLPFqqXVX78c/SQA 3rvZ07z2YukvXtfeJu26aoPVHmvrRWFKPVF0lzRZ4sZfqqj+eH1o1467fT0vtU8ttfq6z3n/ AMKwJyttLUmpR+aP0wIGLLOlbll6wAAGVAAAHR83uW9xGNiaw7/2Hl9xtZWnhjHmdndXVevz msk9MepYFFeB971fFnZnilatxjxzISlgW7h1lTkZLlTpnoiE3qzKmlwJupCvLMypKWmGHFk4 tq3ck83SPrI3LbVOok1S3CHzNyfuIpwjQnTHoGkLFZGkSWXWJumC4jpXoI1pjyAhLkKlFWoS rTDIKURA2lOLqsie4SUraWWkzu7JRaWTL9w34ka0wgsiKIvgDq1WoopurJNUyWBUGFMQSpwH R0+oKVRQnHsv2EHF5k1Tn1hFrEgrt4N1yoaLd61Li0yqDcJJ8K+8onKkqcjOOrS6d2CnSL7P F6cScvCxSnRcqZmavpoS7EuAwZWwhB0pJV5DdlUonGla5kNKQOMS4TK2djUqykm+sJWME6p0 XMhGKoRUVz4jBlLwVPtOnXUlK1F4uSrQr8Mi44cRgyv0Q0519AJW6dqTwpgkQhHAk4NLAYTN PVBZ1ZJ341wiKUKijGjTLhMp+POvZwquCFqlJUqOONB0aqUVKFH9pLSo4JVqhyweLE6VXEB6 knT3AlSqSIyVHgSSwoioeKxpgQSb4k5YLkJ04v6gK1acp6W6VRf4dmwu22yq45uacVR0pUjB W6PXWTRFWXO+muMYkHjVMsnJ1jTCsIlONa8ygVEqcSSRFJ1rkSTSeIF1U8vYTdttLjiVwknh iWznSKUc2/YVDhajXq5ktep9BU50j1BBqmBBoTwfpPT7bdR8OEaPCMVgjzFvF0WJ6Xy25WxB vhVHLl7Omi/9wpYuEujAl4qbbduSJueCrxyE3nxPO6KndnLFW210sjJ3UlS3h+IuclQKJUpi BROVx/Ak30kPEvrDTHHpNfEh2sUiinXfjRdlYkLn7h1SlFdSL523lyxYkk8eAELNq9GLbuJv piKe28Rtyaba+VFsm3iTjPglkBzoeU2qVcpFb8qr3Zv0o6mtuKphQafCtGZusvo3N9p6uHPy y/HJKXUzNc292334Neg9LqabZJyagq1cq5GLx61qcuzyTkgPVK3CbrOCfWjLc8r20sEqP7rM Xi9q6TmnrHnwN2+8ult1GVpSmnn0HM8WKdHgzF4tp6ZdJya31WBUipp8SRyss7ukuewAQEUw ACAAAIoAAAYABFAxAAwAAoAAIGAhgAAAAMQwoAAIgAAAAAAGAAFAAAAAAAAAAADAgAAAAAAA AAAAAYAAAFAAAQAAAAAAAAAUMAAAGIAGAhgAAAAAAADEMAAAAAAAoAACMfmkNW3b+VpnEt25 XZKEFVs9HuIeJanHnFnF8rnp3EelOJ7OHbGm3weTl1zvrntVKlc2V7lKLxXNHorV2N6CuQyZ l8x2f7iGuP6kfauRzvLd5+3non3JZ9DJtPu6ec+vXuut+1t4X6L2d44fmsNO4r80UzuM5fnE P059cTnwXG8+LpzzOl+CrbeW+PbVzXSvChf/ALT9/wBhPyq4vBcW0mpcek3a4/MvWb35N5tZ lnTj0usuDSoknwQ6Vw5kfEh8y9ZKMk8U6o8/V6OjhW34dxP5ZHeeZw93HTdmump1obm24puS Toj0cs8prtHm4b43bWrgKf3VlfGhPd2V8aOHjfau/lr7w93HVZmuivqOb5fKl5feTR12tSa5 o4NmfhXIyfwvE78XXXbVw5em2mzvgZnv7HzP1C/3CxzfqOPht/jXbz1/yjUMyw39mclFVq3T I1Ess7zCzaX6bkGLzKNbSlyZtKN3HXZmuivqLpcbS/FN5nWz4MXlcqTlHmjqHF2EtN+PTgdo 6c8/k58Fzp8gAAcHcAAABC5ajdWmaqvauomBZbLmM3WbTFcq/tZWe0u1D5uXWVQm44p0Ovdk 7cXOOaVeswqza3a1bd6Z8YPL+B6tdvKezxb8fjenUrW4pnh7jfZ3PL1HHlGUHpmmpLgxxm45 FscnqLW4Uyd6xDcRcZYVVKnCsbqubozp2d1wkcttFlscLd7C7sJKUu1BNUmvr5HXedTpKUbk aPGLzRlu7XSq28uRnfa7SeXeO/DtNcz3eVvQ0TnHk2d2zNTtQk2sYo5O/jpvy6aMzaG+DPRd fuaa9cM67Xj22xMvQ64r4l6yLvW1nOPrOD4M38L9RJba4/gfqMfZ1/yb+9t6au7C5G5VwadO Rg81j3J9aJeW2523NTi0mkXb6zK7a0wVZJpnOSack69Pd0ud+O5nX2YdhuIWHJXHRNI2vzGw uL9Rz/2F/wCX2j/26++C9Z22149r5XZy1vJrPGatr8ys/e9Qo+Y25SUUni6GX/bb3GnrGvLb qadY4Opnw4v8mvLl9nVa4HmbsaVjybR6ZupzbvlviTlLVRN1yMcO81t8mubS7SeLN/vMkktC qklWof7zN5QXrJ/7MuNz2El5NbWc2bt4P1ljHN7/APTnXr8r83cnmzr+V25W7TcsFJ1RG35V Zg023KnBnQMcnJrdfDTs1x8dm3nv3QtfH+JlhVazn+IsOe/efKOunb97/wBmADMtABiCgAAg BDEAAAAAAAAAAAgAAAAAAAAABABAAAAAAIAAAAAAQDEAAAAAAACAYgAAAACAAAAAAAAAAElp eqD0voG5p/qKj+aOXpQCOk3vbbrGLpM516VKUWlXNPisiIo1hjB6fc/QPXF95aXz+EvjNvov 7VPK6/XP3gAlofo58AMeN9mvKe7O5IUXig6RReKqfbfJwp3TrNmV4mi/3mZ2lQ2yhkVtMuZW niFQdxx7JdNUuaflikK3FXpxqqVkEJanKXNkFqCieQoupJPBlQm8HUroW3E2l0kK40WQFb6R SWFUTphUhNPIBVTUYtZyLtw9V+XJUSIQdZ24pUxHNPxrifMihOmBJYrMis8SUcXQ0gGQeD6h vJASpjgJYSClcButUBXNUaZZJRUm5cyNzJsLkFKdXxSZASo44EXGjxzHphTDFg1jXoATyRJ9 OQmySksAGlVEefIsg4tPAjLPABLJg6rAadaobWPEqIxdORZToIRfAuwAVK4rAGsKsk0sMPaD wdOQEW6NAk69ZC43g3mHelXmwK5yxHTihTi9XQT09mioA5Imk/YLNZsklRIqCSpgsyuTS+0t pWnIhLDjkBVcjqcVV4osW1dvF44cSE2moupCF6TdOFCKtm6eH0w+sjKuITTcLfLS/eNJtZ8S iDVUJuqwJaklVDUXTBYATtYSVPaW3IywpmuJTFNZ58jRcmrdebRUVTwrXFjtWpSwyRG5KM3q XFFlqTaweCINlqKj0s73l04uwot4ps89bfLlmdvyeEbniRmqpJNHPk+lvXu6adahCNMXxIys uPcZB3bkVVrI8zqvaSXJhJqJVavq7GssS1PGvB4AKtHiOtOAPsvTmx0bXUAnm3LIraTdOZYp VYow4p8QI6aUoqEVRvEsa9Y41z4AVJ0VFjgJurLkopalxzFppiqMCvGlOWJLxJOkqBTmEksO fAoeptUlzE5QphmsROGFXnwE4UdK8MQGpJrssqvbSxexuQT4VJSi1ljFAqUo8wMcvJNo3SlF wdTJe/p9xblauPoizs6li6VWA9eLeSLk7PK3NjvbLeq3WPNYmZ7jT3lQ9bc3UbOcjk+aeY7e 5HQ4qXUTw1276tTk2n9zlK/DmTVyMsmjC3FPsrAg8HUxfx9b2tjc/I29Zl0xnOUksmycb9xO jeBzv419K6T8iesbgKLV/V3uBdCs+FDleDeejrObS+pgJY8CVHmcrptO8rpNtb2sACGYaAxA AwACKBiGAAAAMAAAAAIAAAAAAAYAAUAAAADABDACAAAAAAAAAAAAAABgAAAAAAAFAAAAAAAM BDAAAAABgAAAAAABQAAAAxDAAAAAAGAhgAAjzcVKzeWD7M/rPSDOnHv4Z6Zy576eeOuMB51R xfMtk4y8W2qqXeS4M7I8iab3S+UXfSbzFc/y2/OUfCuppx7razRPzK07lnsqrTTwNtagW7/y 85MHj/Hwtz8XnFtbr+CXqJraXfkfqPQVYVOv+xfaOP8Ar6+9cJbS78jOnsYyha0zTTTNQGN+ W7zFjppxTS5lc7e7e5cuaoRqmsTP+yvfIdoC6822sxE24ddrm56uN+xvfL7Q/YX38K9Z2QL9 /b4J9jX4lbqox1ZpKpzLnl92U5ONKNtrE6gHLXe622erptpNpjb0cn/bbvOPrH/tt3nE6ozp 97dj7Ojlx8tuxaepYOp1HiAHPbe7fU3rpNfpApLUmuaoMDDbn2/LfDkpa8nXI6DADW212+pn XWa/SAADLQAAAAAAE1VNczJHy61Bppyquk2Aam1nas3WXvELtqN5aZqq4Pijm39rOz2l2ofM vrOqGWKN68lnTbrHLfim3XXpXDXNF1rcyt4PFGu/sY3O1apGXy/C/sOdKMoPTNUkuDO/SzM6 vHdbrcbO3t92nimdG3eUus8nGTg6xwZ0Ntva4PBmLqjt3dvG52lhIxTi4OjVDRZ3KeDNLUbq o8Ucbq7act16Xs5lWFS+7t5W8VjEoMPZrtNpmAAAKBDEAAAgEIkRIExDEQMEIYELfen1lpTb 78+tFx129PlGNe1+dNEiKJoy0VBUJtkWURAYjKgQAAAAAAAAAAAAgAAAAAAABAAABAAAgGIA ABAAAAAAAAAAgABgIAGIAAAAAAAEEMBAADEADEAAAAAEdKy4cuAEgN+e3uz4a+zI5OtGSi0q UI8RJ414H2Hy1d9tTZnk+Zo3CrNmaWR0cx1EYKrxJOpFdrDIKnaWiUpLJRk0V21pgh2YSiri fyMI91dSAnElkuY4oOgAeKWJCmJOlfUCrxCI0WCISWJZRVryIyXtAsstSvWo0pxKW3qm+Opl 9uei7aqUyVLs1lSTzEUmugko1abJUqHAqIzVXUKYVJyo8SMXQBJE5qqx4BTHAdFxoBXLFCmt VuD5NxLMMVXIjC3qjOPKkyUiEHFYN1YsknzJrbx7zYSSUcHkwpY06CSbWJFrDBk1gkyoccc+ As22NOjw4iVdQAoY0JNZ5ihWq6SaXrCK12W+CLk60qVSTTfFk0+TyKHVUoh8MMCDlhyFGTp0 gRuN5Jii9ISTf/AEsihSWOPvLI1ySSQpRyfHIdG3j7CCzClFUVaUS5AnRdIVpQIjWtKkJyeR KS4im1WvrCi5D8qMq5PIvjpeCWP2mS5crbSSdajVi9JpydOOLoBZc7tqvCLXtFFqISSStqTw 01w6WRlQoeOSFVulW3XAjPHtCiq1xzILYrHANwm5YYko0bTJyfbryZpFTi3Gr4cCdlpMm34k acSFh6XiQbbdtvPI7Pk0tM5RXFe448JVzdEdbyZ1utL5WY5PprWvd20waqGQ+o8juqdr5cKi 0OJZKoAVObSrTIrW8t3Xg/YaE9WHArlt4MIlbSkm0NL5cmUeC44wePEcZOEu16Ci5NKqpihR WGOQlcq2nmNPVgA1TJehjSwxeJFJ5LPgSlPHkAm28GRbpRrAlGNMMwpRpNYcAK+1Jjaa60Tq 60WQS4gQT1dDfAcUs8+aZRf3UbarLhwRw935rNt+HGSjwdCyZR279+FlVZxt154sVDGpx7t+ 5cq5N48CtUTVeJ0mqZTu7md51k6IpSwxHi10IVE30GkLCtai1N4D01VQkqsohm8cBylXLFkn yz6SFaJ0zA6vlyj4TnNYtl8Ep9p5cDDsbrlbcOTLJSuQ7NtqjxM5XDWrdXngSnHsNcDnS8Wy 1cbwNsLnjpY0Rco0WoJptqpC/G3BVpiSUlabpxM9+5hzfEl1l7xZttO1YZb1wkoyjgyz93BN p1VDDcnSeOKCVJPA43g0vo7Tm3nq6UdxbkqqRYpJ5NHHTw6BvLkc7+Lr6Vufk31jsAcuNx8G yyF67lqq+k538Xb0sdJ+Tr6yuiBgjvLjdKJli3qpjE538fkno6Tn0vq1jKFuYccCcb8JYqSO V49531rc31vbaLAEmnkMw2AACAABhQAAADEMAAAIAAAAAAAAGACCgwAQwAAAAAAACgABgIYA AhgACGAAAAMoQwAAAAAAAAAAABgAAAAADAAAAAAAAABgIYAAAAAAAAAAAMAAAAAAAABgIYAA AAAAAAAAAAAAAAAAAAAAAAAAwEQuWo3VpuKq4c11EwLNrr1jO2s2mNnKv7SdntLtQ5rh1mY7 +WKMd/YRudq32ZfL8L+w9Ou826XpXj34rr1nWMlndSt4PFe06+33ilimcGcJW5aZpqS4BCbg 6xdDV1cXrrd1SIXdqp9qGD5HF22/4SOxZ3Klxqjhtq1rtdbmMjTi6PBiOndhG6sc+ZguWZW8 8jnh7NOWbdL0qsAAjqQAACIkmJgRENiMgGRGBC3+pP0FpVD9SfVEtOu39vyjGvr86aY6kRmW kqhUiMKYgAgAAQAAAAAAAAhiAAAAAAEAAAAAAIgAAAAAEAAAAAhiAYgAAAAAAAAAAAAABAAA AQAAAAAAUAAAAAAQAIAMlCSqFuE7rpbTk+g6VnyHdXaVSgul4n2svlORulSboZGdHzfbrbX3 a1PBLgc19El6TpL0c8CuFRJVom6KvEE006tepkJZVxa9QyYXWYyjKcZPOEiEJViuonYTjNJY 6k1XrKrfdEGiMqIk3wK9I26NfWVE6Yr1A+y+kjKVCTxRFORCSwwJprPiJ4gVSlKNGvhdS3cR 035PKtGKVHCSpVtVJ35anam8dUaeoCOnGtcBxTy4C1VCvQVE4PgVTjTEnWuQTbdKlEYrrBpp 4Ci3k2SASqpZoaVLii8pYMG/WRnJKUZrGjQFajF5sk6YqPQxXrL1tV4jtx00VK8CKSfRUkqU y4kVHFolHighxo2KTabeI1jGq4DuIoa7NKk4tRaxKniq4FkpUVQITePWNPikK5jjXiC4hCep t4DgmnV5klCjxBRSqkqgRksMwjSmZJ4r0kF01KLXHH6wkscR5JPLAVcqYgRVOY9WBByo61WZ GLrwbxAJurCSbXXgKSrjhHreIJKlcXR9X8SZMJ0St6K1lXBLMWuUcbmKXRVhorHOj+WP094v 3LglFy4ZR+0jSVymqDyTgsCFPUSu9pwlXBwWHIjSqx4Gp2ZqLxrFiWfUJ0qmShmRWi3hKi5k br0tviycFWknj0kMW6UwNsnb1Nx4py0+tCrR4YKhKSUVVcJRLXZgnhLHHAznqpxnqodrymVN zHpUkcWxbq6vJG/b3JQkpwdJLIbTMsJ0r1ks8SJ5uH9Q3o1V2KlR0qjXa/qKxLCdU2eOyu+Y 68qscUkY/wDdNvJqMZpNmmFy3cWEkzKp6lWlCGtvgWKDQUVAK6riSiqDaQUxKIXLUbmOTRVK zJYxdeg0acQQGRX7ltpqLqiXjqXfwb5mtlc4wffSoAQmnGkXiRk6OsuBh3e4sW8U6S6Dgbrz e+pUT1R4GpMpl6W/vrVnFtVRxtx527j02u8zhTv+LjczBzbWBuaxnL0u0t3Lr13JJ14HUhZh LCUapnjLe7uwfZlRcTXY82v2uzWpLrTL0c/LdtdbUorA5+7/AKftuVLVUiqz/UKrSceg6Vrz excax4Yk/lF6OHf8kvWcIepnOubS9brqi/Qe3jubd3jUklCbokpF86Yj5/R8cOsSXP1nudxs bE4OsVVnn97sdvbdYumBqbZTDjUphiyElV04llcSuWGRoPbXvCk+ktv7xRXYzZlnb5ZlLg88 zKrnvLssJOqN+13Siqr1HJoySUlkEdx7pyxeCM243cUtNvFmDRN0q8CxW0lhmVEUq4+stUqO jEo8QxrVlBOgOWCQ5R+IFzbAkpasOCyHKNaUYtLWXETxKJNpYrBiq440qiKdcyaajiQNZVeP EHgnRYCTyHFp4rgUJyo0yUb1xN6W6CnJZtYBRJUXEzZL3WWzstW6uLN1LI76S70TLRcwfWc7 xaXvq6Tl3n9zct7DCqaqWLc226VxOc1wkCo3ic7+Npe2Y6T8jed8V1VcjLJokcdUq0hqUo5N pnK/i+2zc/J99XXA5X7q5H4sCyG9uVo6M538bf0xXSfkaeuY6QGKG+bVXH1MsW9g800c7wck /tdJzaX+5pApjubUspestUovJo53Tad5W5tre1hjCjAy0AAAAAAAAAAAAYAAAAAAAAAAAADK EAwCAAAKAAAgAACgBgAgAYQAABQMAAAAAAAAAGIAGAhgAAAAAAAAAAMAAAAAABgAAAAAAAAA AAAAAAAAAAAAAAAAAAAAxDAQAAAAwAhctwux03FqXDmupnM3OynZ7Ue3b58V1nWBNrFHXXls 6bdY4b8M2669K8+aLG6nZeeBuv7CF7tW6Qny+F/Ycu5CVuWiapJcGejptMzrHjut1uK7+23q uZPHkb43FNUZ5CM3B1R09r5h8M/WcttEdW7tvih6jLlgzZavponctRurk+ZxuuHo05cdNmAR ZctytujIGXqll6wiLJEWFRZEkyJkACGBCH6suqJaVR/Vl+FFp12/t+TGvr86YxDMNgYhgAAA AIYgAAAAAAAQAAAAAAgAAAAAAEMRAAAAAhiAAAAEAAAAAgGAgAAAAAAAAAAAAAAgABAMAEAw EADEIAGAgKPbQjC0tMIqK6ES1ENL54i0H03y3kf6mtpbpTXxRRwHjnJeo9V/VFmnhTS5xZ5l o9GvaOd7qarn6kJpUwVUuboToRUK5msJk7UpQuRpFYvp4iS0uUeTYKUoOMnkmWTjS7OPTUSL VlHSqEopvHIaXZGliVlGXBDxo6DapJBpw6wH15oFj1jpXF9Iq0yAinjj1ClKu2jzhP2DpmWR /Mdy3H441XWiKhSqqHSsMKisusU+aLIx5ZlRFY5hmq1Hpo6VBKlQKqUeJZgxSVcyaQCa4rIr abjQv08SEkk8gI61pU2q8H6CGuU41UaJPVUnGCctDXZl7yqMZSo3qplQinOiergwT0sHRdmu KfHgKjdWsfSMmFkc6cyblhkUxzyfpJVT4r1FRKHKhJ1celEV6fUSSxa94yYRdfWDbwq+mhHO qxdPQNNYJRq+SxwfWMmFjnhXkUznqlSNW3jRCeDevD7vEi5P/DwXKuPpZMrg1JPLMcXTMjCG rtS7K+bh1dLLUowb0tdDrST+nQMmFii4rHB9OfqIylFLGrpwbovYKLwaqvRVjahT5uv7EaRB XFDJRT4cX7SNJSrSsiyrWVFXkvrKmqvGrwJgSlFp5JZ5/wAAbXCs3RdC+0I5AnWtC4Mp+Enb cpOi4RWX8Sm1dajoUE65l9uMXCs+ZCzrxjapHF9qWdCgnTTbqsdL95BMlLCNt54S95FvEIhN 45klVCnmOFfQIrVbTim3gVTdONWW92268SmTUvUaZWWrqWHH6xw1SuShKmpN0fWVQnG204xq 1xkWXnrvSk8a6X7DNmVlw120kqLgXQbrQoUdXQiyElWiKjNuIfmyrkV0SyNG876fNFCa4nC9 3aCiyHbuODwbXUReYl0kG2Pme4h3Zt9Zrtf1BehhcSkcgKUJiD0tr+oLUqK5Fo3WvNNtdwU0 n0njViFaGfGLmvewuQl3ZJiuXY28ZM8JG5KHdbXpJvcXZ4OTaJ4GXpNz5xbtukMWcbc+ZXrr p3UYEuI3Vm5rIFJturdRLFkqBQ0iMoLJlTtci3oGBn8OQlJp1NLIO2mBDCSrkxtLPihO1yIS jKORUXRuzjSja9Jpt+Zbi1k69Jg8V0o0SU40weZMDoT81vTwcqYGGUnLGVW2FKqq4CTeMa4M SYEXVUaCilnmydVguRGKqugojo9JFxwbRbKGGAqNYcCKr08hUT6CdUsxtUAikk6ZoEqPoCWD qkDpUArTPJhTgEliKLCJKPAHCj5Di9S6hVVShxVcgzxGqZrMG6urz4gRa0vmga7OI3zWRJxq sMwK65UxqGbXAnTooRUQFVhLOvEk4t4LGgmlLiBKieAgjBviRWGeaAknXFg0kRwePEbpkA8n QMWRjJVxGpJgGrClCKwJJSSrwJaepBSUuXqElXMMhMByXDhzG2hOTpRekI44gS8RwVVJk4bu 8smUyWAVpXmZusveLNrO1a4b+7XFJrqLI+YVXah6mYNWnIkm+GZzvDx3+10nNvP7nRW/tPOq LI7qzLKXrORV6uQ7joqJ1Zzv42l943PyN/hXaU4yykn6SWlnB1VVHwJxuyS7MmkjnfxZ6bOk /Jvrq7dAOTDdXIvGTZb+9uxeNGuoxfxdvSxufk6+srogYY+Y40lH1E15ha4po53g5J6Nzm0v q1gU/u7PzU6yxXYPKS9Zzum07yuk31vaxIB0rkFDKkMAAAAZQgGACABgAAAAAAAAAAMAAAAA IAAGFIAAAAAABgAAAAAAAAAxDAAAAAAAAGIYAAAAAAAAAAAAAAAAAAAAAAAAAAwABAAwACAA AAAAAEK5CN6Oi4tS4c11EgNa7XW5jO2s2mNnJ3OxnZ7Ue3DnxXWZK8T0KbTqjHuNjC72rfZn /wAr+w9WvJNul6V49+K69Z1jJt95K06PFHa2+7U1g/QednCVuWmaox27krbrFluri9cpRmqM zXds44wxXI5+18wUsJYM6tu9U891dNd7r2YSLOjd28buKwZhuW3bdJHOvXpyTb5qmQJtIi6G XQgDAMCiMX+a/wAKLSmNPG/lLlQ3t21+TGvr8zQwSTClDLZgIYAAAAAAAIAAAEAAAAAAIYgA AAAABAMQAQAAIBiAAAAEAAAAAgAAAAAAAAAAAAAQAMBAEMBDAQDoFGAgCjEUAgYgHUBAVHua 4CbbXQVuaYSuPgfSfMc3+obCubXVm4NP0HjManvd2vGtStt5o8JODhJriduO9MMbKWsBKCbw wJvDIg61OjKMozo4p4LgWX/1m/mUWvUQlFPv4V4ondepW7nCjj6gHFtDUuRGvJ4AmXCLHKvW NOuZBLME2mRVsBNPigUqOoN41AJRequY7c3CcJrg6PqYpZphJReaqgFpdu7O1wTrGnSSxr0k b03OEL1MYdif1FmaqAm0sg4VWYY/WixKqqBTx6AT4cScsAlHV2kEFNPQJvpJJ8WKVcvYBXJc VXDJiu1aTSdHjKj4luLVJZEILS9HPGPWSrFC0qONeoi1zZa5wk5RSpLh6AnVtSwxQFai2sMu gn22sK8whGLeKLFbXIuDKrT8zSfSyccFVP1JlqTVKBHrGEyruLjR8sSMqyVK0XLIvwdcsCmS VCipxQsU1XInJUaqsBUTXIApqeWC7qJ6O0TcEs3hmOTWfEsCVOvoQSdFTAcHTJkZtLBFQk20 R5EorNMSxTRQlVsaiuJJp1rkDVOtMBx1SVIriUyjGc34ra6i7XJQrVKjxK4ubnWCTk1xICVF C2ll26esg8cScqqEK95SnUrbpVEVHPAttxqsKlUayZqgq5LgWJU7jaglxKUqLgX38Wk80imM XwRpBFKmVeotnFu4m1RaVgKDcVg6BOkqNvHT9ZBqfRjhmEHTqCNNK4KgrbwwKI7p10voM6L9 x2lH04lNDht3dZ2FMAQ6oGZaAxUHTkAISzoS6hU5gN41YkSToqIK1ASfAK8AdMuIsgG+sios eRLVTLIIinQeocqYEXyTAFRMiFWssxV4FDVRMHnQfSBFwWZVK3TEuxJSSXHEDHXiiam0n0l7 iuKIu3F5FRWpxonx4knchJKKwaFKy80ypW2saYhVyhXGuDFSuC4FScoFuuLWdGAKOFWGlUGp YUrgJtUICmJFUriSqkulg4060AkqxxyGko4LFA3XGmA6csiogujMcUqjXGuQ+p1AhowqEVUl jkRWqmOQCVchujeDwJPBYCopV5gNSazxEsFRBKFOsilXACcVp4sUXXBLFgm31DTxrkwIqFKN jlSTwJVfMjHi0gIU4jokSVXhwYU0rECGbqNJVJUomRpXMB6nHFelMccU+YmlWjQn0gSo3iqC bUekVa9YVpTgwJrOqw6xQkm2mHarXgglTOgAsM+I5KqrwI6nRJ5EvE0rDICKpLBDcmuojGVF gOqWQUsdL4iiqqqVCVcMSKlRNSWPAAxXSxtN0boqCXvCley2AaueY026JiSpRVE28UA3JVwH VyeRFp8qEa0AsdGscjHealKqLJTbwKmkSgjOUe62vSaLe8vxymzNQsVXgYusveNTaztW2Pme 4WbT60dXa7hO7GG7WiEspxyOPY22vM7tidIaLiU4mPt6f4tfc3/ydLzHy39pa8ezW5Fd5cac 0cm5ubdlJ3W4V5o6G38we0i4Qalao+xPh1fYea3nmF3fwhC4lptV00zZnbh0vphrXn3nxdWO 6syxVyJaqPJp9TPMKCbxNF2xpcfDxVOBy/156bOs/Ivrq9DpfIRxLTuKWiU5RrkzQr+5tvw5 PHhIzfxr6VqfkT1ldMCja3Ll9VclVZ4Ha2e32tz8u/hcfdxpXqJ/r7fBr/Y0+Lmgdfd+TeHH XZbaWcXn6AXkUnFPXR0yoZ+xsv3tPdyANc/L70ZONEyl7a6vhZi8e09HSb631ioCbtXFnF+o g01mmZ8b7NZgAKhUigAGQIYAABgAiKdB06SIwCg6MQAOjCjEADoFAqwqwAAqwqwAB1CoCGFQ r0AABgGAAAYBgAAGA8AEA8BUAAHQVAAB0FQAAdAoAgHQKAAh0ChAhhQCgAKAQABQAAAoAAAA BC7Zjdjpkqr6ZHK3Gylaxj2o+1HXB4nbTls6bdY4b8U2669K8+nxRt22+lbwlkaNxsFc7VvC Ry5wcHpkqM9GJtMx47LrcV6WxulJYM2dm6qSR5G1eladUdja79TweZx21WfBo3Gzlb7UMYmO h2LW4TzI39nG72oYSON1ejTl9NnJFQtnalCVJKjIuOBh6O6lfq/y/WXILCi70ncVY+G0uafB jijttOmvyY1ubt8wix4pMjQklhQ5uhAOjDSwEA6MVAAQ6BQBAOnSLAAEPAMAEA8BVQCAdUFV yAQBXoCvQAgHUVWAAGphqf1ECAep/UJtsAowoxNsAHR/UFGRACVBUEADp0hRcxCAlRcww5iE ESw5hgRACWHSLDpEADqvYFVyEIolq6A1CEBJSYamqUeREAHqfqFViCoDbEICoBAAAAgKPYN1 yK5VeFSTjUPUkfQfMLVyOF5j5VK63esKvOP2HelDLkgVWalsMZeCmnGsWqU4cSqWB7rc7Gxu v1o1fzLM4W8/pmUY67E9a+SWfrOs3lYurgycaV1Eml4UlF1UZKXrIvTB6VHtDtzo1GSxktLX R/A3lEk6ixfAjbfB8MCUVVG2TjTimNSx4gojlGlM6gSVXyDLASbXEbaqZwJUUl0jI0pkSrXD iRSjRy0zq1NaX18CNqqTg8JRwdQlimnk/eE5Vpe/luL6wLViSiyFNLCSriniVFlUiL7OWQ4u qxzCnHigFSuKE3TPMjWjqSbSyVeQBhxVSE6tVpisiTq4kURUbklCk1GurLr4kUlKtVRZqvSW Rbxtp0bxi+khqycpank+gCFaMujljmV3UnRx4ZjhJcOJpFjo8AhypmGKxWQYplRPS3woil9R Juroyt1xWRFRfImo5ojwxJxo/SILKUipFU3WhbgkVSRpByy5Ep40xDNYe4UpVS6CojpxxBeg i3yWQOVH0kVNLDOhGbSdOJKMJSrF5ZhVKiaw5gEaOqUai1R8RcnGj6B27zUWk1FLOTz9BThS jelPN8WTK4RjJ6Yr70sQmycp1SilSMcufpKZurIqyysnxNsViZbcXTBYm63GlK0WFTUZqq7n gUt59ZZcxeJU41kzSJQVcyUmnpfQxQ58CaVadLYGi3jFdRJLU8ERhiqrgWQxb6AIXlS3qfBm XPE3tarUuo59eZx37umvY31YhXiDfISfAw2lUdaEaUCoE1IVSNRgSxYsyPTxCoEqDxyZFS5j 1cAHWgtXETYqAOTbzIvMeY6FQquIlVZkqcApXEBV9Y6cxPEb6AHXiJ44ipwHWoDYdQlL0jqA NEteFKEQb5gJxRTO26luqNcGN5VQGVxa4A2aa8QcE8aAZtRNSUn1kpWnwKnFrgUXNpYL1CUM ccCpOmPEk7zbrLECccgxpiqVFqVKJ5ko9quNUERawwzCjeDJPg1kHelRZgRkscQpjhmOkqvk FElV5gRaeZKri6oGmsHiJOuYEacQbxxWHQSbpliiMZN4ACel4Era18aCckpdpZg0vSAk8+Y5 SyWNA0tZ5iiBJtZISxwElxFVrPICTo1gKrrRg8MiTr3ksAISVXUGm8Kk+rJgpRqgEnpw4MNK 4vqQp4UpkS0POmDAg48GGjkOEXWjDFYoB4RisceRHpSwHk+YqU9IDk06EU1J5ZBk6olok1r4 ARS5EXFrEnVJUZFVbqyKWa6QTQPHIG6YICUo17TeHIzN1LJTbwZW4sBCZLS+RosbG9edIwk/ QBnjBydEdCztKYna8t/p6b7VykFzlmXb+1YtuNuw3J5PpZDLm24KJp222vbmTVmLaWcuCOns fIpXWp7jsw+Ti+vkd+Xh7e026RtxWPBJEHzzzFO1Lw5nNbXAt8z3s9/edx91dmC5R4Fe0tVl igrTHZx0pydWyX7NLGEmmaNNCWWZUZ27ttUuR1x5o27adtpPNkIySNm30vCgoz27PgbiqwhP 3nU7LjplGoW9nDc1jN0axj1l09nOMdSak1mkQbPK7t6ctGqtuKx1Z9VTrXLitxcmYtrF7Owt S7cnVr6ciVxymlKWfIzRnlL24lmrVGvB5FeLlR58gvNvurFEVbR0q2JRUkovGrKnXpyG3OmC oAOxBVWlVK/AttY20XSVZJPOhOMc1UYi5vuyfsLNHVNU5Ff+223HUpOh0KN29UfSVxUlGqSo jN01vo3OTef3Vg/22MsFOnWL/ap1pqVTqaNVHgiueEs8eBn7Wnsv3t/dxNzYe1/Uy5oyrcWX lJHodwlNdrFPDA8pvdstvcpRqLyJ9jS+8bn5G874b7a8TudrqJuzcTo4upy9nf8ABuJru1PV 7e8rsa8eZm/j6z1rX+xfaOO4SWafqInolPS0q9I3RppRWOeBn/Xnuv8Asf8Ai85UKnfduEqU gsCEdtCWLgqsn+v8V/2J/i4gHYe1srCUcVyCWys56cGZ/wBe+7X+xr7VxwN72lutE3mTl5fB ZN4k+xt8F+/p8XNA6MvLUng3QX+3p92fsJ9jdfv6e7ngbJbCaxi00Z7li7bVdDa6CfZ39mvv af5IAZ7m8t25aZqUX0oa3tl/EZ+1v/jV+5p/lF4FS3Vp/EH7i18yJ4bf41fPX/KLQIePa+Ze sFdt/MvWTxvtV8p7pgLXF8V6xqUea9ZMVcwCJVQURFRAlQKARGOgUAQDoFCBAMAEABgAwAAA QxNAOoqgFCgqOoUDAAVRpc2LVTIQE6pZFV21buqlxYc1mhjdVma1t1udWdtZtMbOXufLrlla 4du3zX1oxxlR1R6C3dlbxiZN4rdyrlbSlwlF5nqnJrtOvSvFtxba3p1irbb1rM61neJ5eo8x G4lKiNMN1GOEsH0GNtPZJi9+71DlbvqkjNd2rjlijm292+DrQ0WfOYRkozZzumVm10+MXeW+ GtxLxUpwktFMymiTenu1dK8jNt95ON+TpRuTo+g23oqFxxSenONeRvl6a66+zrxXO1t9UBxB DSxPO9KIDoFEFIRKiDACIidFyfqEknwZcX2TKIFmh/K/URlGmLTXWi+N9qmZ7ogWeBcrTRKv US/b3f8Aty9RfDb2p5a+8UAXraXmqq3Kgftr1K6HQeG3+NTz1/yigDTHZ35puMG0ulBHZX5Z Q9pft7/41PPX/KMwUNS8v3Hyr1kl5ffaqkvWPtb/AOKfc0/yjEFDd/tt7Ls+sm/KryVaxL9n f2Pu6f5OdRhRnQl5ZdjSslR8R3fKbsIuUZKXRkPs7+yfe0/yc6gaTNc3jt4uLa5oqfmPKPtM /b39mvPX3btNRaDFHzCvCnpJ/upch9vY89WlxoFBba9buYXMGdixtdpPvRr6SeFnSrnpmORQ R1N75Pc/U2ck1xty+pkvK9kru317iK16mqNYqh004bt6xxvNrPSuSKq5npL+x28rWnRpb+JZ ozRitnGm4tqdtf4sY4r8SOv+tf8AJj/Zns4lVzHVHqYQtSipxUZJ5OKJq1FvCKT6i/63/kn+ x/4vKLHJP1BxpTFnq4w9a4lG429u8mrqXWX/AFp/kn+z/wCLz62915W5eoktnfeVuR1pO/sk 5xmrtpfDJ9pLr4mja+YWNzb1QmuquKL/AK2vvU/2b7Rw1sdw1Xw3Qrtba5fuSswX5kVVxeDo d6e9sRwncVHyZh8x3Ni8vEtSpet4wlFOtOKNf6+vxZ/2dvgy/wC2bj5V6yq/tLliHiXKaVn0 Grb+bOEkrmq5BqviQi8PxGtbza7tPTqnbktMtMa+sv8Ar6ex/sb/AAYl5TddO1GjLI+SzlHU 7sV6GR2e8dqL2t2M3O33XTFw4M0X/N7ViNbsJqPNov2NPZn7+/u5l7aytbhbZduq1OUFkuos 2+zjfuTtKfahTCmafEx3/P8AwdzLc2I1TioKpjl/UF+/fhdlSDjhqiuD5l+zp7H3uT3eij5P DVSU5Jc6Ix3LFm1dnYblOcaOOjimc/f+db1Tdu41RUrp+KJs2/m+1n4UrMfDuxlpkn8UX0l+ 1p7J93f3bNv5VqWu9hF5JZl17y/Z7dO5Ny00yqbdxeW3i3JdhGFR8dfuN2moJdhcullnHr/i l5d/8nn1uK1u0/JU1GvGjr9gHU/YQ/2/xODl4vtz9QF+3p/jE+5v/lXpHBrMjSmNC93aZopc tTwMCMn/ABFkS0cQUNWaAqq10koOrXSXeHyZBQaeAHz7cNQuThOrSlLrWJGNzwnqsxq+csX6 i/zWGnd3YrJSftMVp0lgerGerkHflVuSq3mThuYLBpojK606NVRCkJdDCtcbsJYJkqc8TDKw 1liQTnDJtDKYdLTyyBxo2Yo7u5HOjLlvIS7yoMmGmjT6CGMWKNy3J4Mk17wh98hFqDdVWLwk gToPChFOCcVpeNMulElgQjKmDyXd+nInJUZRKtHXiiSdHVcegqoqjToghzVBwdVRBqXpIVoy hxdK5BVpg3jiNJcSCNxNUksWsSuVJzi4pLXg3yZekghCMH23Rd6L5PpFVnjCaclVOmFCMNWO Bb2dddSb5xw95Oak1qi25Lo+wmTCPaaaafoE9XyvIl4knNU4rHDArdySg8mk+ZrKYJypmqBJ 1Y3d7KwweFRz0SaS9ZMqj1E1gJW9OCfrG7c45pFRJyqngVyE9TawGrd3FUpiVCboutCinJOK RZpSpXF1oSacJNYIuRT4WL1P0FsEotNLoqyuuvGOaCMZXrbfFNdVCZXCcbktTceRXCEpvVVJ LNvIteictS7T9UV9orkvmxayXBdSGAlpTrFYv4pfUvtKZqmPEk5NvEjcKK22yMViNE4pmVWw VaUNkXpiZrSrH0mlPTRI3GGeabVekgu9QtnHCVSvBtFE4ci2j0qvBlVaYIuil4az7wFtrJ8y 2KpJ14ldpaVJZE1xYEovsy6mc3PA6Me46cmc9NPI5bumpVoOoUqgWKObZsCNR1AYN4g5CAG+ YVFQVagSB4BQK8AAFgJ4jqBKoCryE2BLAKcyLdRrH0BDryBUoxVSyCvIoOsQccEPoAK4DUks yOIPgA9aG3yIpVFSgEtEQ6mRyYVqwJvpFV06BNj1cABMeoj6QbYA4RlmR8KCeAV5kukAonmR dundJ0oLUgKVVYNYEldVdWRZqaVGJpPMCCeFa1Jt1ePAh4UeGAqSWLxAnKlOkI5VZXqdNLJq 7VaeABl1MKRw5occE4iUWqVKiLb1VWTG1V45jk6UqN4+kgj1AqosdunSVy5Ioi1h0Da4cSaV aUzE3XMCKxq8iblzILMddWABXGqFjR8yUU8UFcaARqsiSelcxdLBNAHJhGGp9l4ilg0nkSiq 4PLMBKLVXxFSvEk8O0q9AOSaT4rMBLnLFizzGnVdPMJUdKARda5EXlV4ElCWlvPHMFSlCKrq +BFyrmTpTEjKGYFd5xwp6SCb4DnFihLS60yINe2vSi01Q9Ps95vbiUbVtuvFR+sPLf6k2bil ftq3JLvacDuw862U12bsSZ+AxR8q3W4x3FzSvljj/A6e08us7TGCrL5pYsql5rapW2pT/Cvt KLu53F10TVqD5YyJkw6G43drbrtvHhFZv0HD86uXNztZOScY56a+/wCwus7RQlVOsnnKWLOR /Ud3w4xspusnV9RM+y493npQSzN1qNaQislmYbcPEnGGdS2y7lq84wdGsMSjY4ND8NyNcdze h+pBNG7bb2x3pWky5RyoWXXKp1tn5XeuYuOlc5YHQ/3izBdi3R+hC/ebvdYWYaV838X9RUF2 xDYyhJSrKtGjTtdi43pbiTwfdj9YbXy3RJXL8tc/YvtOg2li8DOVjLvIuWnGhSqvNYIL17xJ YZLIUZOS0tVZlSkksOIozxXMhcUtXSWTwSks2BOUm2lTEi4S1YvCgN1xTxIzgn3nwAjdUk68 ibTS1ZNkFHFQrwzJyjRLU20uZQ4JurI/ceQkmqtZBroqqrqBK3JrAjKEW6sIpJ6lxQTpm5VV ALISVKPIweabWV+Fa4o0qaj2Uq8alja48UB4ZqMJ09Z1fKN/GEvCk+on5v5f/i21SmfScWMp Raks0b7xHuoxUqcuA6NJxTzOd5Zv3egoyxZ1IJ07WTMKhJ6ElJY8ydcawdcKihSLo1VLAF2U 3EBRrLHOpJtUo3lkJy0qmT6CLm49NAKr8cVcXHMlG4u98JPW2qyRVqTkoPBAWxk8dIQt1dXg wUlJ0WDFVSrDkBGFukmnghwep1+FEtTrRjrqWl5AVXrdqWEorHiZrvlm3vrVpSfNG5vGlE6A rE2nR0wA4s/JLU49luLMd/yK9bWqNJ+89GoydaoduTToa8qmHjJbG/DGVqVF0GabUVSS4n0G Um1jwM7s2rrlKUFV9A8jDwiVZYE5xXFZnsH5Rt5tNwWGGBnl5Jt5S7NUuvAuYPMVp2c0Qep4 xk0egl/TzxcJ4v5jJLyXc23p0qSfJjodXOTknpbePSPXc4SeHSQu27lvszTTT4oiuaLiexmr ldni9T9Y43rix1OhDGlKYkNXFInjPaL5X3qz9xerTWwt7q8+9NkIy145ElSUeTJ4a/4xfPb/ ACq97m5V9oX7m7ppqozKk3jTEnraq+KHhr/jDz2/yrda387cdUoqSOla802s9Ou3pwxPPxlV YZgm0qjw19k89vevXW7mzvLXHT1Gn9tYSxgmmeJi0u28sjRb3l2KTjcao8ETwh57e71sdlYk q0wfAs/ZWNK7K6zhWPPZRmvG7rwdDpWfNtrelp1U5VM+M9l877rnsrEq6YhDZWlWMoYl8Lib pBponqSwl6x4z2Xz296oWxsPHQqEYbCw33cDTFKUaZJEsXF1xWQ8Z7Hnt71ins7GrCOHvJXN hYTSUcy6VuselPAnq8WlVRoeM9jz296yz2FlJJRTbJPYWIxVYY9Zapx1N5OtAlccsHnXAYns nlfdwvOdrPaxV7bYxXfi+HScGW+vNUdKPoPdSXacZ46l6zzPndu9tKQSXgyylT2HLfjneau/ HyX6dr8nmncxeonHcJYIhC34l3RzZde2kVByjhQ3ZHLr1dLYWHvdxG1F6apv1GbzCxPZX3Zu 0eCknSmDJ7HzeG3cJuNLkME+Zm808xn5nf8AHuLSktKXQSa/BLfZ0vL1c3M4qNNUmkq9BVu/ Ntz4rstKluUo9Js8mnHVZcfikkusf9SbG3tr0blp43G3NcpVWPpE11t6xrbazHwYtpd3F9T1 So4umROU9xHjVHfvbOMtXhr8xJV+8qe85KjG40ngk8Trx6cW86TFndnk35NL1txeyqxfvKSr WnHUXS3l1qXYWpd2hp0xhOkspLsscdstxGWDjNYJ5HWaeP0OXnnrtn+qq3Kd6mtaGzr7StNG FeZyl5bvbkdEI4r49WBXBbry5qN2sZqsscU/SM9MbSJfeV6tTosCKopZGGG/pFSv25wTXeSq vYa7O4tX3S1NSosDk2mpuleBRf28dzCVqeUlTq6S1vTRvBMckn2kBl2W4uX7bjPC7a/Lu9ay fpzNcLjcaPFowbrVtr8dylS1NeHef/TL6jck4rsdbAlbk2uSCK09LFqbWrJMIyinXiA9OirX HMjF19A3LVhxBRrnxAJNPGOLIJJyqsFTEk40bogdXjzAUtMqYYrgF2sHVZE6uSolR8yOqjpL EBVentYhdk4RdVwZNJQeeApxUk8eDA+bW91O02s4tusWaUrd5VtPHjE58+810sgm4uqdGNtc 1vXaxsacXiWQuUFavK7H8zPmKdvTisjjdcO82laE64o17ffTtYPFHMhJrIujNS6zFkvduWzs 9Xs/MFLJnUjcjdVU6S5nhLdyVt1idbaeZ8JYM42XXrq3Zrv8K7Lhv1hKUGlk9PtHG1uGsLy6 VoJ7feqSxNLipKsD0ac0vTZ5N+K6uYvKbttzuWL8oyljRx7Neoz2Ls29G8uTtyfFYRbXJnYj KUc+Irkbc4+HNKUXwawPRlxww2tip4yuTcX94cfLLL7LTkvvSYre3ueX42fzLX/ab7Ufwv6j Tt79u827bx+KLwkvQBGHl21g6KGKXGrI3/LdrcTUrUUvu4GtN1wVekVc1LIDmvaT2cKW4xvW 1lXvxX1mvbbm3e/Ra1L4GqSRbKDhKscalV7b2txR3I6ZJ4SjhJekDNt5T224lqVI3Xqj+Liv rL3saar22l4V1975ZdaKL8NxCDtyTuwXahNYTi+GHENt5rC7aV2fZa7M4/Fq6gMm630rM4X7 8dF2HZmljGUJcn0ZnB8+81/d3PDtP8qPtZ6Dfxv77bzclotJN0+J0PF64zXbKQSbdtdYlYWG qSRN2+xhikyCjUjTVcj48Y21LVKOEZfd5egq3Wyv7Kat3lRtalTFNFaTjis0a5TldcZXJNqm mNeBcIvfnN+54Vq/Ps2/ipj/ADczueZbreeD4PYlG5GuqPy8zx84u3NqWNH6z0flU4uzO3qr LTSGrNV4ER0PA3f+3+Dohp0d7Vw6gOlSX7XRR6tGmnoADUlXMlpSyJJja5e05NlqVKZsi9Sj wISeli116SBudMOIqSfEWFcSUWmB4/8AqGw7e7bXxRTOMnpaPX/1TZjKxC9HOMtLfQzx7TPV
September 11, 2015 - September 26, 2015
Pietenpol-Archive.digest.vol-ou
