Pietenpol-Archive.digest.vol-pc
October 31, 2015 - November 14, 2015
      > http://forums.matronics.com//files/img_2996_medium_149.jpg
Subject: Re: TC Piet progress
Date: Oct 31, 2015
Ray: interesting to see the barrier strip for wiring on your firewall. I have a similar setup, but fewer wires. Picture here: http://www.flysquirrel.net/piets/engine/A75final002.jpg I have a grounding stud on the metal firewall, lock-nutted both sides of the metal, and I landed the braided shields of the ignition switch wires on the barrier strip and then a common ground to the stud. I ran a flexible braided grounding strap from the engine block to the same stud so everything should be at the same ground potential. I don't have ignition noise on the radio, so it must be doing some good. In the picture there is a piece of blue tape (temporary) on the firewall just below the terminal strip where I marked all the wires when I was doing the hookup. Also in that photo on my webpage, note that I attempted to fabricate the metal firewall in two sections joined by a conventional standing seam. The intent was to make the lower section removable to give me easier access to the area under the fuel tank and up by the passenger's rudder pedals, but I didn't think far enough ahead and when everything was mounted, it became evident that I needed to trim the firewall around the lower engine mounts and cowling mount 'horns', but by then it was too late and the lower section of the firewall was as locked in as the rest of it is. I guess I could go back and trim around the engine mounts and anything else that captures that section of the firewall, but a certain amount of laziness has set in. I still have it in me to crawl down into the front cockpit when I have to, although it's no fun and I too have almost gotten myself stuck down in there. Then I remembered the movie "127 Hours" and made a tremendous effort to get myself out of there quickly before I had to cut something off to get back out ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448431#448431 ________________________________________________________________________________
Date: Oct 31, 2015
Oscar, Although I have a 12V battery, I have no starter, generator or "electrical system"; so no ELT needed (?). The strip looks more complicated than it is because I have and old style mag switch that I use as a "master switch" to power the strip. All the battery does is power the oil pressure and temp gauges and a cigarette lighter outlet on the panel. The gauges were sent to me by mistake when I ordered mechanical gauges, so I just used them. So the mag switches and the OT and OP gauges are all that are connected from the bar strip to the engine. Of course, there is the ground lug. I think the ground for the Eisemann mags is separate from the ground for the OT, OP and cig lighter which will be used for the radio....I hope. To pull the engine I just have to disconnect four wires from the bar strip, the throttle and carb heat cable and the fuel line. Then remove the four motor mount bolts from the fuselage and hoist the engine off. This will only be necessary if I can't fix the problem through the hole in the firewall (which is covered by the battery box). The "best laid plans of men....." It might all work about as well as your firewall plan! Thanks for the comments. That's what makes this forum so much fun! Ray Krause Almost finished taping the last wing half on the SkyScout. Sent from my iPad > On Oct 31, 2015, at 8:09 PM, taildrags wrote: > > > Ray: interesting to see the barrier strip for wiring on your firewall. I have a similar setup, but fewer wires. Picture here: > > http://www.flysquirrel.net/piets/engine/A75final002.jpg > > I have a grounding stud on the metal firewall, lock-nutted both sides of the metal, and I landed the braided shields of the ignition switch wires on the barrier strip and then a common ground to the stud. I ran a flexible braided grounding strap from the engine block to the same stud so everything should be at the same ground potential. I don't have ignition noise on the radio, so it must be doing some good. In the picture there is a piece of blue tape (temporary) on the firewall just below the terminal strip where I marked all the wires when I was doing the hookup. > > Also in that photo on my webpage, note that I attempted to fabricate the metal firewall in two sections joined by a conventional standing seam. The intent was to make the lower section removable to give me easier access to the area under the fuel tank and up by the passenger's rudder pedals, but I didn't think far enough ahead and when everything was mounted, it became evident that I needed to trim the firewall around the lower engine mounts and cowling mount 'horns', but by then it was too late and the lower section of the firewall was as locked in as the rest of it is. I guess I could go back and trim around the engine mounts and anything else that captures that section of the firewall, but a certain amount of laziness has set in. I still have it in me to crawl down into the front cockpit when I have to, although it's no fun and I too have almost gotten myself stuck down in there. Then I remembered the movie "127 Hours" and made a tremendous effort to get myself out of! > there quickly before I had to cut something off to get back out ;o) > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=448431#448431 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 01, 2015
Subject: PLEASE READ - Matronics Email List Fund Raiser During
November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Andy is a very generous guy and I encourage you to visit his web site. I would like publicly to thank Andy for his generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 01, 2015
Ray, An ELT is required whether or not you have an electrical system. Check out FAR 91.207. I don't agree with it (I think the sum total of pilots and passengers that have been saved by their ELT is zero), but that's the law. I have one in my Pietenpol, even though like you I have a 12 v battery but no way to charge it in flight. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause Sent: Sunday, November 1, 2015 12:40 AM Subject: Re: Pietenpol-List: Re: TC Piet progress --> Oscar, Although I have a 12V battery, I have no starter, generator or "electrical system"; so no ELT needed (?). The strip looks more complicated than it is because I have and old style mag switch that I use as a "master switch" to power the strip. All the battery does is power the oil pressure and temp gauges and a cigarette lighter outlet on the panel. The gauges were sent to me by mistake when I ordered mechanical gauges, so I just used them. So the mag switches and the OT and OP gauges are all that are connected from the bar strip to the engine. Of course, there is the ground lug. I think the ground for the Eisemann mags is separate from the ground for the OT, OP and cig lighter which will be used for the radio....I hope. To pull the engine I just have to disconnect four wires from the bar strip, the throttle and carb heat cable and the fuel line. Then remove the four motor mount bolts from the fuselage and hoist the engine off. This will only be necessary if I can't fix t! he problem through the hole in the firewall (which is covered by the battery box). The "best laid plans of men....." It might all work about as well as your firewall plan! Thanks for the comments. That's what makes this forum so much fun! Ray Krause Almost finished taping the last wing half on the SkyScout. Sent from my iPad > On Oct 31, 2015, at 8:09 PM, taildrags wrote: > > --> > > Ray: interesting to see the barrier strip for wiring on your firewall. I have a similar setup, but fewer wires. Picture here: > > http://www.flysquirrel.net/piets/engine/A75final002.jpg > > I have a grounding stud on the metal firewall, lock-nutted both sides of the metal, and I landed the braided shields of the ignition switch wires on the barrier strip and then a common ground to the stud. I ran a flexible braided grounding strap from the engine block to the same stud so everything should be at the same ground potential. I don't have ignition noise on the radio, so it must be doing some good. In the picture there is a piece of blue tape (temporary) on the firewall just below the terminal strip where I marked all the wires when I was doing the hookup. > > Also in that photo on my webpage, note that I attempted to fabricate the metal firewall in two sections joined by a conventional standing seam. The intent was to make the lower section removable to give me easier access to the area under the fuel tank and up by the passenger's rudder pedals, but I didn't think far enough ahead and when everything was mounted, it became evident that I needed to trim the firewall around the lower engine mounts and cowling mount 'horns', but by then it was too late and the lower section of the firewall was as locked in as the rest of it is. I guess I could go back and trim around the engine mounts and anything else that captures that section of the firewall, but a certain amount of laziness has set in. I still have it in me to crawl down into the front cockpit when I have to, although it's no fun and I too have almost gotten myself stuck down in there. Then I remembered the movie "127 Hours" and made a tremendous effort to get myself out ! of! > there quickly before I had to cut something off to get back out ;o) > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=448431#448431 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 01, 2015
Ah, but Jack- you forget that Ray is building a Sky Scout. FAR 91.207 specifically excludes single-place aircraft from the ELT requirement ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448548#448548 ________________________________________________________________________________
Date: Nov 01, 2015
I wish the faa would catch up with the technology and allow PLBs. Small, light, affordable and efficient. On Nov 1, 2015 1:04 PM, "Jack Philips" wrote: > jack(at)bedfordlandings.com> > > Ray, An ELT is required whether or not you have an electrical system. > Check out FAR 91.207. I don't agree with it (I think the sum total of > pilots and passengers that have been saved by their ELT is zero), but > that's > the law. I have one in my Pietenpol, even though like you I have a 12 v > battery but no way to charge it in flight. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause > Sent: Sunday, November 1, 2015 12:40 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: TC Piet progress > > --> > > Oscar, > > Although I have a 12V battery, I have no starter, generator or "electrical > system"; so no ELT needed (?). The strip looks more complicated than it is > because I have and old style mag switch that I use as a "master switch" to > power the strip. All the battery does is power the oil pressure and temp > gauges and a cigarette lighter outlet on the panel. The gauges were sent > to > me by mistake when I ordered mechanical gauges, so I just used them. So the > mag switches and the OT and OP gauges are all that are connected from the > bar strip to the engine. Of course, there is the ground lug. I think the > ground for the Eisemann mags is separate from the ground for the OT, OP and > cig lighter which will be used for the radio....I hope. To pull the engine > I > just have to disconnect four wires from the bar strip, the throttle and > carb > heat cable and the fuel line. Then remove the four motor mount bolts from > the fuselage and hoist the engine off. This will only be necessary if I > can't fix t! > he problem through the hole in the firewall (which is covered by the > battery box). > > The "best laid plans of men....." It might all work about as well as your > firewall plan! > > Thanks for the comments. That's what makes this forum so much fun! > > Ray Krause > Almost finished taping the last wing half on the SkyScout. > > Sent from my iPad > > > On Oct 31, 2015, at 8:09 PM, taildrags wrote: > > > > --> > > > > Ray: interesting to see the barrier strip for wiring on your firewall. I > have a similar setup, but fewer wires. Picture here: > > > > http://www.flysquirrel.net/piets/engine/A75final002.jpg > > > > I have a grounding stud on the metal firewall, lock-nutted both sides of > the metal, and I landed the braided shields of the ignition switch wires on > the barrier strip and then a common ground to the stud. I ran a flexible > braided grounding strap from the engine block to the same stud so > everything > should be at the same ground potential. I don't have ignition noise on the > radio, so it must be doing some good. In the picture there is a piece of > blue tape (temporary) on the firewall just below the terminal strip where I > marked all the wires when I was doing the hookup. > > > > Also in that photo on my webpage, note that I attempted to fabricate the > metal firewall in two sections joined by a conventional standing seam. The > intent was to make the lower section removable to give me easier access to > the area under the fuel tank and up by the passenger's rudder pedals, but I > didn't think far enough ahead and when everything was mounted, it became > evident that I needed to trim the firewall around the lower engine mounts > and cowling mount 'horns', but by then it was too late and the lower > section > of the firewall was as locked in as the rest of it is. I guess I could go > back and trim around the engine mounts and anything else that captures that > section of the firewall, but a certain amount of laziness has set in. I > still have it in me to crawl down into the front cockpit when I have to, > although it's no fun and I too have almost gotten myself stuck down in > there. Then I remembered the movie "127 Hours" and made a tremendous > effort > to get myself out ! > of! > > there quickly before I had to cut something off to get back out ;o) > > > > -------- > > Oscar Zuniga > > Medford, OR > > Air Camper NX41CC "Scout" > > A75 power > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=448431#448431 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 01, 2015
Jack, Thanks, I was wrong (my wife thinks I never have said that!). I had not referenced the actual FAR, I was just going on faulty memory or hearsay. And thanks to Oscar for pointing out the exception that applies to my SkyScout. I do carry a "personal locator beacon" with me when flying, especially in the Waiex. Can't seem to remember it when in the Aeronca. I plan to use it in the SkyScout, but I may never get more than 20 miles from home base. But then, around here, that's far enough away to be lost! Thanks to all, I really appreciate all the help, Ray Krause Sent from my iPad > On Nov 1, 2015, at 11:01 AM, Jack Philips wrote: > > > Ray, An ELT is required whether or not you have an electrical system. > Check out FAR 91.207. I don't agree with it (I think the sum total of > pilots and passengers that have been saved by their ELT is zero), but that's > the law. I have one in my Pietenpol, even though like you I have a 12 v > battery but no way to charge it in flight. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause > Sent: Sunday, November 1, 2015 12:40 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: TC Piet progress > > --> > > Oscar, > > Although I have a 12V battery, I have no starter, generator or "electrical > system"; so no ELT needed (?). The strip looks more complicated than it is > because I have and old style mag switch that I use as a "master switch" to > power the strip. All the battery does is power the oil pressure and temp > gauges and a cigarette lighter outlet on the panel. The gauges were sent to > me by mistake when I ordered mechanical gauges, so I just used them. So the > mag switches and the OT and OP gauges are all that are connected from the > bar strip to the engine. Of course, there is the ground lug. I think the > ground for the Eisemann mags is separate from the ground for the OT, OP and > cig lighter which will be used for the radio....I hope. To pull the engine I > just have to disconnect four wires from the bar strip, the throttle and carb > heat cable and the fuel line. Then remove the four motor mount bolts from > the fuselage and hoist the engine off. This will only be necessary if I > can't fix t! > he problem through the hole in the firewall (which is covered by the > battery box). > > The "best laid plans of men....." It might all work about as well as your > firewall plan! > > Thanks for the comments. That's what makes this forum so much fun! > > Ray Krause > Almost finished taping the last wing half on the SkyScout. > > Sent from my iPad > >> On Oct 31, 2015, at 8:09 PM, taildrags wrote: >> >> --> >> >> Ray: interesting to see the barrier strip for wiring on your firewall. I > have a similar setup, but fewer wires. Picture here: >> >> http://www.flysquirrel.net/piets/engine/A75final002.jpg >> >> I have a grounding stud on the metal firewall, lock-nutted both sides of > the metal, and I landed the braided shields of the ignition switch wires on > the barrier strip and then a common ground to the stud. I ran a flexible > braided grounding strap from the engine block to the same stud so everything > should be at the same ground potential. I don't have ignition noise on the > radio, so it must be doing some good. In the picture there is a piece of > blue tape (temporary) on the firewall just below the terminal strip where I > marked all the wires when I was doing the hookup. >> >> Also in that photo on my webpage, note that I attempted to fabricate the > metal firewall in two sections joined by a conventional standing seam. The > intent was to make the lower section removable to give me easier access to > the area under the fuel tank and up by the passenger's rudder pedals, but I > didn't think far enough ahead and when everything was mounted, it became > evident that I needed to trim the firewall around the lower engine mounts > and cowling mount 'horns', but by then it was too late and the lower section > of the firewall was as locked in as the rest of it is. I guess I could go > back and trim around the engine mounts and anything else that captures that > section of the firewall, but a certain amount of laziness has set in. I > still have it in me to crawl down into the front cockpit when I have to, > although it's no fun and I too have almost gotten myself stuck down in > there. Then I remembered the movie "127 Hours" and made a tremendous effort > to get myself out ! > of! >> there quickly before I had to cut something off to get back out ;o) >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=448431#448431 > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 01, 2015
Subject: Re: the unleaded ethanol report
Steven-- I second your comment that making food into fuel is stupid. With a third of US children undernourished, and well over half of the other people on this planet starving, it is not surprising that lots of folks have a poor opinion of Americans. And on top of that, we little people are subsidizing the cost of producing the alcohol. --Mac in Newport From: "Steven Dortch" <steven.d.dortch(at)gmail.com> Sent: Wednesday, October 28, 2015 10:21:13 PM Subject: Pietenpol-List: the unleaded ethanol report Well, I have had the opportunity to run various fuels in two of my vehicles. Drumroll please: My 1989 Chevy Suburban with a 350 V8 2WD got somewhat better gas mileage with 100% gas vs 10% ethanol with a mix of town and highway driving.. Actually 16 MPG with pure gas and just under 14 with 10% ethanol. Not enough difference to make up the 45 cent difference in price. My 2013 Ford Explorer 4wd. has somewhat similar results with one slight change. On pure gas I got just under 23MPG but that was highway driving with a car topper and hitch rack into a 20-30 MPH wind. On E10 I got 20 to 21 MPG with more into town driving than highway driving. On E85 I got 18 MPG with a mix of in town and highway driving. The E85 was $1.339 the E10 was $1.999 and the Pure gas was $2.499. So per mile E85 was the cost per mile. Except that the $1.339 E85 was only at one gas station I happened upon. Everywhere else in San Antonio it is more expensive than E10. When I go to Oklahoma again I will get pure gas and see what it does without the cartopper and headwind. Please note the Pure gas I bought was in Oklahoma where it is plentiful. It is not available here in Texas. I still think turning food into fuel is stupid. -- Blue Skies, Steve D ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Nov 02, 2015
Getting stuck in a Piet, Too funny, I happen to have got stuck in mine just last week. I went into the front cockpit headfirst and on my back trying to reach the firewall. My brother-in-law grabbed me by my ankles an pulled me out. I went to plan "B" to install that bolt "a long stick with the bolt taped to it". I am still bruised, but laughing about now. Cheers all, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448575#448575 ________________________________________________________________________________
Date: Nov 02, 2015
Pictures please! -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Monday, November 02, 2015 8:40 AM Subject: Pietenpol-List: Re: TC Piet progress --> Getting stuck in a Piet, Too funny, I happen to have got stuck in mine just last week. I went into the front cockpit headfirst and on my back trying to reach the firewall. My brother-in-law grabbed me by my ankles an pulled me out. I went to plan "B" to install that bolt "a long stick with the bolt taped to it". I am still bruised, but laughing about now. Cheers all, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448575#448575 ________________________________________________________________________________
Date: Nov 02, 2015
Funny Jack, My wife wanted Pics too. Sorry, none were taken. And I don't plan on a re-enactment anytime soon, so put your camera's down please. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448577#448577 ________________________________________________________________________________
Subject: Re: Finally on the Gear!
Date: Nov 02, 2015
Jack, Your plane looks perfect. Keep plugging away at it. Are the yellow landing gear springs an indication of the paint colors to follow???????? -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448578#448578 ________________________________________________________________________________
Date: Nov 02, 2015
Thanks Scott actually no, planning on boots to cover. BTW yours looks great! -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Monday, November 02, 2015 9:13 AM Subject: Pietenpol-List: Re: Finally on the Gear! --> Jack, Your plane looks perfect. Keep plugging away at it. Are the yellow landing gear springs an indication of the paint colors to follow???????? -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448578#448578 ________________________________________________________________________________
Date: Nov 02, 2015
Dave, I finished adding the fingerstraps although they were not absolutely mandatory. Peace of mind. On the photo you sent the link of, the bottom tubes transfer torque. They apparently belong to a side-by-side two (or more) seater where the left pilot's left pedals motion is transferred to the rudder by twisting the bottom tube (torque). Where on a Piet you just push the wire itself. See the photo and please tell if you are satisfied. Regards and happy landings, Semih Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448580#448580 Attachments: http://forums.matronics.com//files/img_3025_medium_208.jpg ________________________________________________________________________________
Date: Nov 02, 2015
If I'm not mistaken, there is some sort of color code for die springs to indicate the spring compliance. I don't know what it is, but I do know that the springs on my little Flying Squirrel are white. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448591#448591 ________________________________________________________________________________
Date: Nov 03, 2015
Here in Turkey, they go like this (This is an ISO norm): Yellow: Strongest Red: Weaker Blue: Weaker Green: Weakest Light green (rarely used): Weaker than green They have standard sizes. This means, for instance, if yellow turns out to be too strong, you can replace them with weaker reds. They fit in exactly the same place=8B. We use them for machine tools. Semih 2015-11-03 0:12 GMT+02:00 taildrags : > > If I'm not mistaken, there is some sort of color code for die springs to > indicate the spring compliance. I don't know what it is, but I do know > that the springs on my little Flying Squirrel are white. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=448591#448591 > > =========== =========== =========== =========== =========== > > -- Semih Oksay ________________________________________________________________________________
From: Charles Burkholder <born2fly(at)abcmailbox.net>
Date: Nov 03, 2015
Looks great Jack. I am almost off the saw horses and on the landing gear too but discovered a bit of toe-in that I need to fix. After having a jig that had everything perfectly straight and square for welding it still managed to toe when I put it on the fuselage. Charles On 10/30/2015 7:23 PM, Jack Textor wrote: > > Kind of fun times! Long way to go > > Jack Textor > > West Des Moines, IA > > 515-490-5177 > > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Nov 03, 2015
Have seen articles re toe in that a little is good. Mine is a fraction out. Sent from my iPad Jack Textor > On Nov 3, 2015, at 3:11 PM, Charles Burkholder w rote: > > Looks great Jack. I am almost off the saw horses and on the landing gear t oo but discovered a bit of toe-in that I need to fix. After having a jig tha t had everything perfectly straight and square for welding it still managed t o toe when I put it on the fuselage. > Charles > >> On 10/30/2015 7:23 PM, Jack Textor wrote: >> Kind of fun times! Long way to go >> >> Jack Textor >> West Des Moines, IA >> 515-490-5177 >> >> >> >> No virus found in this message. >> Checked by AVG - www.avg.com >> Date: 07/10/15 > ________________________________________________________________________________
Subject: Wavy Okoume Plywood Leading Edge
Date: Nov 04, 2015
Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (trammeled with ribs, compression struts and leading edge glued). I used cargo straps around each rib and clamps on the font edge to secure it while curing. Brought the wing to Florida for the winter and found the plywood was sunken or wavy between several of the ribs (picture). The other wing seems OK with a slight bulge on the plywood away from the leading edge. I am at a loss to determine how this happened unless I got the cargo straps too tight. I assume this deformation will transmit through the fabric (not having covered an airplane before). I want to remove it and try over. Any ideas of what went wrong? Any ideas on how to remove it? Tim White Ocklawaha, Fl ________________________________________________________________________________
Date: Nov 04, 2015
Tim, Were the cargo straps directly on top of the ribs? If so, I don't think they could have caused the deformation. You said you glued them two weeks ago and then moved them to Florida. How long have they been in Florida? I suspect that Florida is the culprit. Being very humid, the Florida air will make the plywood swell and deform between the ribs. Can you move the wing(s) into a heated space and let them acclimate for a couple of weeks? If so, I expect you'll find that they smooth right out. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tim White Sent: Wednesday, November 4, 2015 8:54 AM Subject: Pietenpol-List: Wavy Okoume Plywood Leading Edge Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (trammeled with ribs, compression struts and leading edge glued). I used cargo straps around each rib and clamps on the font edge to secure it while curing. Brought the wing to Florida for the winter and found the plywood was sunken or wavy between several of the ribs (picture). The other wing seems OK with a slight bulge on the plywood away from the leading edge. I am at a loss to determine how this happened unless I got the cargo straps too tight. I assume this deformation will transmit through the fabric (not having covered an airplane before). I want to remove it and try over. Any ideas of what went wrong? Any ideas on how to remove it? Tim White Ocklawaha, Fl ________________________________________________________________________________
Date: Nov 04, 2015
How to remove it: Heat the plywood surface over a glue joint with a hot ir on. The joint will separate like peeling a post-it note. Lorenzo > To: pietenpol-list(at)matronics.com > From: aa5flyer(at)gmail.com > Subject: Pietenpol-List: Wavy Okoume Plywood Leading Edge > Date: Wed=2C 4 Nov 2015 08:53:47 -0500 > > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge > (trammeled with ribs=2C compression struts and leading edge glued). I > used cargo straps around each rib and clamps on the font edge to secure > it while curing. Brought the wing to Florida for the winter and found > the plywood was sunken or wavy between several of the ribs (picture). > The other wing seems OK with a slight bulge on the plywood away from the > leading edge. I am at a loss to determine how this happened unless I > got the cargo straps too tight. I assume this deformation will transmit > through the fabric (not having covered an airplane before). I want to > remove it and try over. Any ideas of what went wrong? Any ideas on how > to remove it? > > Tim White > Ocklawaha=2C Fl ________________________________________________________________________________
Date: Nov 04, 2015
Toe-in is BAD for a tailwheel airplane. Imagine this, While on the runway you loose directional control. The plane heads off to the right, the left wheel will be carrying the majority of the loads. If that wheel is "Toed-in" it will have the tendency to tuck in under the plane. Another words, it will want to turn right. Hold your hands out in front of you, on a vertical plane. These are your wheels, Toe your hands in, Now turn right with both hands. You will see that the outside hand will want to turn tighter since it is aimed at a different direction then the forward direction of the fuselage. The best adjustment will be to have both wheels pointed straight ahead. Zero toe-in or toe-out. The trick is to get the wheels straight while the plane is in the 3pt attitude and while in the level position. This is why a straight axle arrangement works so well. Happy landings, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448629#448629 ________________________________________________________________________________
Date: Nov 04, 2015
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Re: Wavy Okoume Plywood Leading Edge
Date: Nov 04, 2015
Tim when I did mine, same conditions, temp, humidity, etc, I had one turn out perfect and the other with a dip in each bay. Hoping the fabric pulls it down... Sent from my iPad Jack Textor > On Nov 4, 2015, at 7:53 AM, Tim White wrote: > > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (trammeled with ribs, compression struts and leading edge glued). I used cargo straps around each rib and clamps on the font edge to secure it while curing. Brought the wing to Florida for the winter and found the plywood was sunken or wavy between several of the ribs (picture). The other wing seems OK with a slight bulge on the plywood away from the leading edge. I am at a loss to determine how this happened unless I got the cargo straps too tight. I assume this deformation will transmit through the fabric (not having covered an airplane before). I want to remove it and try over. Any ideas of what went wrong? Any ideas on how to remove it? > > Tim White > Ocklawaha, Fl > ________________________________________________________________________________
Date: Nov 04, 2015
Mine have done the same thing. I'm in South Carolina, I hung them on the wa ll nice and smooth, took them down a few months later and they are like tha t. Most are bowed up and I don't think those will be an issue but a few are bowed down all the way to the leading edge of the wing. I really don't wan t to take the plywood off, any suggestions? Thanks, Keith Goff ----- Original Message ----- From: "Jack Philips" <jack(at)bedfordlandings.com> Sent: Wednesday, November 4, 2015 9:17:08 AM Subject: RE: Pietenpol-List: Wavy Okoume Plywood Leading Edge com> Tim, Were the cargo straps directly on top of the ribs? =C2-If so, I don't thi nk they could have caused the deformation. =C2- =C2-You said you glued them two weeks ago and then moved them to Florida. =C2-How long have they been in Florida? =C2-I suspect that Florida is the culprit. =C2-Being very humid, the Florida air will make the plywood swell and deform between the ribs. =C2-Can you move the wing(s) into a heated space and let them a cclimate for a couple of weeks? =C2-If so, I expect you'll find that they smooth right out. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Tim White Sent: Wednesday, November 4, 2015 8:54 AM Subject: Pietenpol-List: Wavy Okoume Plywood Leading Edge Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (tramm eled with ribs, compression struts and leading edge glued). =C2-I used ca rgo straps around each rib and clamps on the font edge to secure it while c uring. =C2-Brought the wing to Florida for the winter and found the plywo od was sunken or wavy between several of the ribs (picture). =C2- The other wing seems OK with a slight bulge on the plywood away from the le ading edge. =C2-I am at a loss to determine how this happened unless I go t the cargo straps too tight. =C2-I assume this deformation will transmit through the fabric (not having covered an airplane before). =C2-I want t o remove it and try over. =C2-Any ideas of what went wrong? =C2-Any ide as on how to remove it? Tim White Ocklawaha, Fl =========== =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Date: Nov 04, 2015
Tim just an idea... If you have not varnished yet, wet the underside of one bay with a cloth and see how it dries. Maybe heat with an iron??? Sent from my iPad Jack Textor > On Nov 4, 2015, at 7:53 AM, Tim White wrote: > > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (trammeled with ribs, compression struts and leading edge glued). I used cargo straps around each rib and clamps on the font edge to secure it while curing. Brought the wing to Florida for the winter and found the plywood was sunken or wavy between several of the ribs (picture). The other wing seems OK with a slight bulge on the plywood away from the leading edge. I am at a loss to determine how this happened unless I got the cargo straps too tight. I assume this deformation will transmit through the fabric (not having covered an airplane before). I want to remove it and try over. Any ideas of what went wrong? Any ideas on how to remove it? > > Tim White > Ocklawaha, Fl > ________________________________________________________________________________
Subject: Is this meant to be a Piet?
Date: Nov 04, 2015
http://www.cnn.com/2015/10/22/africa/asmelash-zeferu-plane-ethiopia/?iid=ob_article_footer_expansion&iref=obinsite This is the plane that Asmelash Zeferu will attempt to take off in -- despite having never flown before. The Ethiopian researched for over 10 years before spending 570 days building the plane, modeled on one used to train pilots in the U.S. during the 1920s and 30s. /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAMCAgMCAgMDAwMEAwMEBQgFBQQEBQoHBwYIDAoM DAsKCwsNDhIQDQ4RDgsLEBYQERMUFRUVDA8XGBYUGBIUFRT/2wBDAQMEBAUEBQkFBQkUDQsN FBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBT/wAAR CAG2AwwDASIAAhEBAxEB/8QAHgAAAAYDAQEAAAAAAAAAAAAAAAMEBQYHAQIICQr/xABNEAAC AQMDAgQEBAQDBgUCAA8BAgMEBREAEiEGMQcTIkEIFFFhMnGBkRUjQqFSscEWM2LR4fAJJENy gheS8SU0U6IYGbImRIOTs8LS/8QAHAEAAgMBAQEBAAAAAAAAAAAAAgMAAQQFBgcI/8QAPhEA AQQABAIIBQQDAAAGAQUAAQACAxEEEiExBUETIlFhcYGR8DKhscHRBhRC4RUj8RZDUmKCkjM0 cqKy0v/aAAwDAQACEQMRAD8A9U9DQ0NRRDWNZ0NRRasPvrUn9NGa1KZP21FEUZca1833xo5o wdamAf8A4dFYQUUX5v6/lrDS4OtZIijcDjRTe4OjABQ2QjjLjH1+msebg8HjSfP20CT9MaKl SO83Pc8ayJc++iMnP11nPfOpSiVibk863WQnJ0izg6NV84wNCWogUp80LrAlz7/vpMXH5jQV vVznVZVLKVh9Z3fbRAmH050BLkjjQ0itKAc6zokShdZWT9dVSmYI3Q1oHydbZGqRLOhoaGoo hoaxkazqKIaGhoaiiGsEZ1nQ1FFrsGs9hrOhqKIawdZ1jjtqKLUEjWu/B+uNbPxjRZOR+WiG qW40txJj6nW4bOiM86yDj/rqUqDij9DRe/j6a2LccaFMtbaGtVYHWe+orWdDQ1qWwdRRZzxo BvrotnHGNY3EnV0gzI3OgNFbse5/TQDEDvqUpmR2hrQNnGdbDtqkQNrOhoawSdRWs6GsA/XQ zqKLOhoaGoohoaGhqKIaGhoaiiGhoaGoohoaGhqKIaGhoaiiGhoaGoohoaGhqKIaGhoaiiGh oaGoohoaGhqKIaGhoaiiGhoaGoohoaGhqKIaGhoaiiGhoaGoohoaGhqKIawe2s61bnj66iiL JLEnH76HllhxwNblASPqNb6K0GXtRAhO7k5GjdnGPbWTxzoD651RNoqpQXrzq3qHpa62qisv R9T1KLnDURxVUVUIYaesVofIjqG2MYoGjapkefB2Cl2Kkss0MTvfS19PVPTFnvQt1xs4uVFD W/w67QeRWUvmRq/lTx5OyVN21lycMCM8ap/4k+hr/wBT9bdEXDpt+sLddaeir6KlunSlfSUy LPJU26ojp60z0lR5dM/yTSyTAYCUrw7J3qY4JLG8FLJQ2LwZ6BttsorvbrbRdP2+mpaPqKJY rlBElNGqR1SKAFnVQA6gABgwGrB7UJbpop1rXcNa7ieNZAznQo1sTjWFOO+fz1kDjB1jb+Wo os5zrOsDtzrOoohoaGhqKIa1Man21toaiiKMAOsGmXR2hq7Kqgk7UoJ440Pk19j++lGhq7Kl BEiAKOOSPrpNICpPfn3Ol+i5It+edQGjqqISEk51jdz376Nkp2UZBz9saIZSvfjThRS9lsGz 740N2tBoEdu+rpRGh/1H56MEmPy++kwbBzrYNjVEKJUJP01uHz786SB9GB/20JClpRvxoBs6 LDA/mPbW+4floKV2VvrPtrQMedYzqqRZkaG5+2ttECTRgcaohWCFvoa1LcffWN+PcapXa31j RZf6awZDnvq6VZgjtDRW/PfWyyZ1KUzArDqSeNYERz30boalqZQdUQybSB31koQM/wBtG4zr DDIxq7VZUTg+2twpIz/rrB4J0EbHGrQCuaAJU62Dk8a2xuHOseXx30OiKiNlgvntnWrEE51u I8e+s7Bq7ClE7orBOs7SdGgY0AMaq1eVElSugOP10djPGtDHq7QlpWuew+mt0HA1ptwfroxV IAzqFW0G1trGOdZ0NCmLU51oW9s6MxrUoOTqwhI7EFOfbj6631qowNbapWO9DQ0NDUVoaGho aiiGhoaGoohoaGhqKIaGhoaiiGsZzoN+E603YP5++oqulvnWdag61Z//AMGrUtb5B99AsNFF ue+sZ1KQ5kbuHtjWdFqc8azv576lKwUZoaL3899bBtUiW2hrAOdZ1FENDQ0NRRDQ0NDUUQ0N DQ1FENDQ0NRRDQ0NDUUQ0NDQ1FENDQ0NRRDQ0NDUUXL/AMaPS116tuvh5Q0fh5Z+uaaomqqY vWUdkqK2CV2py8dKt1dULGiS41CrGrEzUNKZMwLMj9AeHtpWwdAdNWxKKotyUVspqZaOripY poAkSqI3SkAp1ZcYKwARAghPTjXL/wAed86TsPUvhrPfOprh0tej8x/DquG7UFupW23K0SJ5 0lXS1OfLrY7ZO2xBsp4KyRvMEYhl6g8Pa6a59AdNVlRc6e9VFRbKaaS50lXHVw1bNEpMyTRx QpKrk7g6RRqwIIRAQoiid56mOmHcbj7Z01z9QJTT5l3R02xmadvwJjnk/vqjb98RlXXb1tvT kUaHtNcH3kj29K4/z1Cr9171F1VSPT3G4SfKt3p6YeXHj6YHcfnnXmp+LRt1j1K60WBcfi0X QV98XbH09MsNTeaV5pl3RxwAyMB9SB/r99RA/EVNJOkcFrVwpw8hY7X/APb7/qRqiaeiipCf KReTnRq3CqppAUp1kUezMRrmf5SZzvioLaMJGBta6jofFiCRB81b5ozjOYHDj++DqUUnVVrq 4VlFWkak4/m5Tn6c65Fo+v7hSVB3xP5X+FsNjn27HT7bPESmqa5JJRIkgXaV3eg/fB99daPi 0ZoE6rG/AkWQF1jHKkqhkdXU9ipyDrbOqFtHVtBMQ0Vb8vLjO4MUP7jUpo+s6+lGY641a+yN iQfuOf767DMQx4sELnuhc00VaWhqEU3iDMgX5mkR8/1RPtP7HP8Anp2ouuLbVcSGSmb6SJnP 6jOtAcClFpCkOhpLS3Sjrf8AcVMUv2RwSP00q0SFDQ0NDUUQ1g86zoaii12jRMtNvPHfSjQ1 YNKiLSEUjk88a1enZBnGdLz20VKrFDg6MPKAtSAjWv4dGMv10Wy/bTkCyG/TWwb7aK1sCe2o qRofGti/bRS9tbrz+uhpWttxz3P6a23HGOTosg9u+s7sAaihKUBgf+ehuGNJwxxnvoB+NDSi P8wf/h1gy/ronfnvrXJI1dKWjzJ3xrXzD9caJ3e2s6lKkd5h499bh8j/AF0nBJOANHJGffVU Aoj43yRnto3RKqRj6aNHA0o7prbpZ1gjOs6xnGqRoqRcnjtrVeDzoxm1lBnJ0d6JZFlbDsNZ 1jWdAmIaGhoaiiGhoaGoohrGdYYkdhxodx+X01FVrPvoA51j76AOTqKLbWDyNAHPtoHtqK1q G5Gs7sg/XWuc/vrXdg6ukGbVGKT+mttFg5B/LWc851EQK2zjvxrOtCcjWcn9NUpa20NDQ1Fa GhoaGoohoaGhqKIaGhrVmAB1FEHOB30Vofi59tY7HRgJRNoFiB+Whn30NA++rQrUHn8tDBB1 vtGtgnGf31LVgWtQM6ByD31vtOODx99ashGhV0hrIJA41qut8DnUVhBX0ZolT6u2jCc9tUQi aVtoawDkazqkSGhoaGoohoaGhqKIaGhoaiiGkd2utPZaCarqWIiiGSFXcx/IDvqNXnqSqmvN IlAB8hBIfmanzkVWI7oAck/fA/8AkOdV31/1vWdZU9zs3T9woGmqYBElPVAwM6NkMVkcd/bj J40t78gRNFmiplS+MlrruoYrXCkihuPPlACbs8D8X56mEd/oagyiGsgYwECXLcDIyOf1GuPf Dux0/wDDGt95qrlT1YnFNG1vETxq2dxYF1YAdgeBjnPfU167vtX01fqFZq2KyW7BpjKwMvzh wDueRffOeMfqO2ufFPKGF8tab92teymOYM1NXTcE6VEYdHRx9UORo3UC8Iq56yxSb7tDdwr8 TxyKxA9gVUkKMduSfrqe66LHZm2k7oaGhrXd9tGoud/iY6wv3TPiX0BB071peOlq6ptl0mem oeiq7qmmrIoau1M/m01JKrxtg+UJSjAR1NQFeKRoy1v+E9uqLP4WdG0FXd7h1BV0tlooJrvd qaamrK51gRWnnhmzLHK5BZkk9asxDcg6p/4rqS5dRdQ+H9hst3p7TXSzzV06zdc3bpdqqmjq KOD5eOWihkidpairo4f5wLhZXSACSXzYbc8Kb7R9SeF3R13t8nnUFfZqKrp5PnKis3RyQIyn z6lUnmyCP5kyrI3d1DEjUVLkuMMpG85HvrdnEYGASnvgZxo2OPjnvrYIFPHI+nbXyxexBWAA 6bt24fXWoUDggj6a2H8tgw7HvjWzkEgjIB7g6Aohrsi3i354BPbt30UtIoGSuPqcaMEhUYAy daSCQo2SXJ52DgDQ2EYCMSripSHQBiMEhONOtJ1dBNFJCIZKapRfxD2+nI4zplSEmPaVVAfZ NZjUx5ESrn6fXTWSuZYGyFzA4ap6p+vb3QrkuKmMcAOf9Dp3ofF4M8YqaIqwGOMjn++oa8If mTK63AhWMBV5+pGtDMbiI9npLsPE7dqtO2+I1lqcr56wsTkoRzk9zjUut3WaBVFLdVwPwr52 Mf8AxP8Ay1zlPboJpSzepv8AhOtoqCaFwYamVVH9KtxrpRcZlYKcAVkdgWO2NLq2m66q0KeY kcyn6qQf3HA/bTrD1zTMcTU8sf1KkMB/kf7a5VpL3fKGPENcxX6MD/oRpyh8Rb7TnE7R1K7l JJXkge2Rj9/89dSLjkJ0eCFkfw54+EhdV03UttqyQtUqEe0oKf54zpwSVZQCjK6n3U5GuZqb xeo4w4qqWSFTyXUEk/kNP1i8SLJWLvprlLTytnAlDRvt98fUf5a6cfEcNJ8L1jdhZWbtV/aG quh63qlpy1Nco5QoyQ7BsfnnnTrSde1wj3T0sMvGcLlMfrzn9hra2VrvhKzlhG6nmhqL0XXd PKmaqllpSO5UiRf7c/2080l+t9cF8mrjLN2Rjtb/AO04OmWChohHzRDOR/fSZxyBpeyhvfRT 0+edNDq3Si1IvKz986yYSPbSzZsUDH66wXA+w/PRZihIpJhEx9saPWEAD3P01tn9NZzg599U SSotWhAGANJ3j2H6D76VZHvrR0DjPvqAlQ6pJrBbj2++gTgaLYEHjTgEK3D4+p0N/wBO310T nIHsdZHJGNFlUu0fnJ1sqk+2sRgn2xnSpEI9udKJpRFRjaeBo5JRnWwjOc6wY+edLu0VEI0P k62/LRW3A451sGI76AhMB7Vs3I4760JI4I0Zn7a0YFz9tQKHXZAAHW4GNYVQus51CVYWdDWM g++huGqVrOsaxu0BgtqKIMfbWu/GgfSeNBlDc551aA3yWC+dYLZ/XWCO3J0F1aCyVsMkD/M6 2VhnWhfP5axn76lK81IxjxoYbGDrCsPfWwYE6pGNVoSVOtSBo085+utdgxnnOrtDXYtQcDWM /TQI2nWQPcjjVoddlqCc6NQnHOtDgaCtj7DUKsGkdoaKMuM476HmE/l9NDRR5gjO+huH11oH +51ruzqUpmCNyPqNAn6HReG+msHIHbUpS1sz4/6aLzk++sgbtAjB50QpASTqsaAGgv5/21uF ye2NXsq3WuP7aGMnRmzWwUDQ2iylahcjWQDrPbWdCjoLA1h+2ttDUVogf20ASNbvgcawDgjR JVLBydZDfodbgg6BQfTUtGBWywG1kHnQK8cDGtQjfbH01SvVb7hrOtMY78/nrYdtUrWdDWu7 Q3H6f31FFtoa1DfXjQcnY2BkgcDUUVB+P1dXUNxIsFxa1XSVFE0flbjUR54kU5/p5HAyM5+m q3tFN1PfesIGpbpRVs4SNquSgWCYlM8tJ5jE7vT2Udxqadb2O63rxDiRoprjTzOXrI56vEND EjfiLLtx6TwpPOT3wdMXVXTloob1dLH09FHR3IQLV01wcpuiQ4BWJ8DIIbsx4z765+Ib1nOP Ku3U/nl5rS2qyqRXXoGwRzUVXSWGCpNPGa2ojlhUNO4b0Rys5wcn6HIxjGOCS1TW9edWR03V PSBrAY1amo0LxrThhyfMC7WOBySw7cDJxqF2KtvdcLQoin6hoJ4mVqKGQrUBVAAMiq23buzy cleD7gDo7pK01Vr6bWielpaUeWEpaeOQyCEbf6mIGefoP306O56cRl9jf5pLjlNWq/8AD6qk 6Tv89ns9DFDbo6iQGmoBH5NOg4CyMGOGzn2BwOe2rvoKtqumSV0EbnugYMB+o765r608HL3P 1NbUoZnoxNKsU9dTVEg3/wBRcxBgP8QxzxknjXSFpppaK20tPPN8xNFGqPMBjeQOTjJ7/np+ VzZHCtNwgNXoloOR21qfpnWCw1qzcg6YAhJCpbx6unhU/VHSlh8SOgP9uKqro7hXWxj0dJ1H 8okL0iTjy4YZpYt5qIPUE2Hy8MwOwNafSyWuLpezpZaD+FWZaKEUNB8i9D8tB5a+XF8u6I0O 1dq+WyqUxtKgjGqD+MC89aWyq6Mj6Uu2yml+ZNdZKKouqV9Ygmow8sa2yiqqjyhTNWUzSFVS GSvppg3nR05F5+H9RFV9B9Nz089PVU8lspXjnpLtJdYZFMSkMlbIA9UpHIncBpBhyMsdWN0J Gi5G89U43DP0HJ0HmJKlQP17aRRTuQCyqQR2zpWuSDu4HfGvkpcSvbUEWzyMAq4P1xkaN8ub A4Cj3HfWwOOAeftxrbfwee300J1RXWiyg2Lzwe3Os7BnsufrrAkAGSMn651guHH+vtqK1lwQ cYBA++tQGBBCc623gjv29j21neB3YAf30PNWtl2rgmMk9+NFsYjksTGPp76284du/wBcawHV mx2P31LKi1ji8wYQDHuR/wA9KFiaFeyk/wBhpPLUrT8s6Rr9TpBU3yKJCVk8z8u2hzK07tLh fqffGkdXWqjhB6nOAPfUabqJkZ2lciM9o4wQf30rpr9QycmJsgclzk/31amycqiBKkKkpcp3 xGSv+WjKisiMQh8r0qPSnc/nopLhHVoPLbbH7FBkn9fbSOm+SoHkkoo5ZpJDlirZDn75PJ+/ f21Y7FEo82pppEZZZYkTlV8wn988fpp3tfXnUFLLiGuPlj2dQV/LB4/tprVPOCu4ZmIztYcD 7caWxwKgVpOG77dGyR8ZtjiELmtdo4WplQ+LVwiwtTQJMueWTv8A6f5aeKTxVtMob5ylelLY BOQRx9c4+v8AfVay1PIVAFb6nSSZzJIA0W/H9IH9zrox8TxUf878VkdhIXfxpX1ZfEq2VBRa e8GmK42pJI0YA9uDxqawdbVMxVopaeoU+y+ofoQdctwPDHkLQpUPnLKeM8ds98aeXlg+SU0k NRb6jsw84so/IZP+mutDxx9f7Gg14hY5OHtvqkrpyHrZQQJ6YqO2UfJ/Y4/z04w9SW2pJUzC Ju5Eq7f79v765Tp+r75bAwFfI6EYCu27P/3Z/tpzpfFWvpHVqmhp6ruAyKY2A/Mbv8tdCPje Hd8VhZjw6S9KK6mhlp6gnypkkI7hHBxrcxH2bXPNJ4s2icD5mGpopjgh8CQD9eG/tqU2vxXp tqxUd8pppc8QVj7Sft6wG/Y66sePgk+B4KxPwsjfiaraZGHcE60JYexGovF4gyiCNnod7HG5 kb0Y+oIz+2P10723rK3XAMGc0zqMss5Ax+ufz/bW0SArLkpOBRWx7ax8uHXvrSa82yJoRLVw RGc4i3yBd5+2e+lvlfQ6YHoMpSF6THI7fbW8dLz20sCYHI1kFV9tXnKmVFxwbR2/XRipjvrb I0CT7aWTaMNAQwNDaNAEEcazqkSxtGtSP11vrGoqWAvGsngcaAGNZ1FaLJPP11gsRozGfprS RQF+mrCAgrXfjWN/1OPvrRm2Ecawrbjo6S7KM3H/AK6yHIOtScfbWNw+o1KV2jN+M9tYL86K L88e2s+YD+WplUslbnuNYzxnWnmfbGtTJkf8tXSpG51gtosvkawG5wdSlSNz2zxrIP3/AFGi dxxrIY6lKI9W51vvxx76ID5x76zv5+2hpEDSOUbuT31tjRIcg6280H31RBRhwW3ljGtTGc6x 5gHfjWfM451NVDS2WMD76w0WTxxoeZxoBhntqtVfVW4XAxoYGsA8c99Df39/pqlazwNYOM6x +I51nbjUUQ288cD7aG39dZXtrOorWuwfTWQMazoaiiGhoaGoohoaGsEZ1FEM6wxxjWO/trBU 6tVa1Y5PtoAD30AvY++htAH+urQUsqdp1uGB99Jw6uoZHDjOMg51sDyftqUpmpH7hrG4aLBJ /L7a1II9tVSvMjSdYzg99aDLayNXSmZbBsnQOhke2tCce/GooTS2z3ydE1kwSnkTzxTyMjbX 4JHHcA98ay7iNGdjtUDJJ9hqg+u+tLPc+pqaoS7U8trgYySxmJqj1A7W2sD/AC88DHuR2Oly PbG23H519UTQXbKzntCRRm6tUTy1Uqxwyz04ZnqUB4Hl/hGcnJA45+mmbxGo7b030vVyUtrp 55YKciKneQLyxxznk9zwDk8jTf4Y+IUF8vF6tTVsk9O0pa3zlGVJEKglUfjJUnBx2OR7aV3L pJbZY7zXXZIpKoM08dQZZKhVyMYVZG4bAwPbnjRNkthLO/8A73o2avAKrC1dP1Hhp0hR10FD NbKGff8AxKSSdZK2mCqceUjLyGJPuSAR39mDozxC6k6e6sqaiRYRQ1AUfMU9QGoZIfaUkYAd VwCBjP8Ac3vF04twpqOaenljWiYSxU0EqmcOwIIm7g5BB+2q8n6XttN1BMlD1HTQ9ORttnsN TRGZEctxtDHAJbnt/nwD8OCwZDVdnuvfkhLgQbU08Oqi7dUdU3bqA3RRbHdI4qFqORVeMIMS AvjDEk8jdxjP0Fp7v+uq18Nen7larzdnvwpqislZXpp4YsKYgMDadoC47FeT75ORqyPMzzjT wDzSOaySSe+B9takke2sk5Gc6RXS7U9piEk8qpuIChvf641YVqiPinvf8Mv/AIfxzdFdUX+j lnm+bvPSCXhK6ipzPRwywCe14ljVknasKuTHL/C/LEZkeKSG8elv4ZD0xZ47LQC1WZaKEUVB 8k1D8tB5a+XF8u6o0O1dq+WyqUxtKgjGuY/jwhqKei6GvMl2p7dYaeeop6mK6x217fPK8lLK scgrrtb1LSwU9ZTMqmUvTVddGdiyEtmo8YksVt6fpLdDQ0dGLJbZI4bU0dLRqr0kTKII4Jp4 liAYBRHNKgAAWRwAxx4jEMwrc79k5kZk0Ch6pHCfx8/fRiyA+5/XQEkbr6SMd+NbYXtjOvl9 L2F6rHmFidp7cEjWyluMg4PtrYkAgctx2xrVpMYAGPz1VBXa3GAO2CfvrJbAzkD76INQo7nn 2yNIqqsjHDTpH34DY0JVgpxaoReS4A0kluCZIG1wO4PGmWoulIqn+cZv/acab2uEsuPJQ+Xz 6gO/6njVVaIa7J3rb3URsRHtUe7EZx/fTZWXisn/ANzWiNO2/Zj++k0wklUiaSNEPcZBJ0Ru UMY0VqkngITgf2/56lBGAiJZGmfC3LzpvoqFv9dExwSNyKrzD7Ls9X6AadKe0VUwKlIoEY52 sc/2060/TCBR5jtJ7YHoH9hn++rtWT2Jjp5mRfKij82U8kP3/wDtGnKisVyqsvUBIIzwEc4A /QZ0+U9qWkUrCViT6RKB/c6NMAXkyhR9+ToS5UT2JNSWBYpA7yjjkbPSP+elczU0RwwEzHHP vnWInghRgXJz9RjSiFQ/ZFUfYDQaqIpKySOMGOPBP6nRS3OWWTYCjSfRzg/sNOAhUDn8/wBd bKkMbZREBPfaOdWFSTRxO/M8ygHuiKQP+el8FPHGnpGQfpxrR6pU7kD9hrQVhbgfuBqWolqO EQ/hC/QcaElTuwOOPtpEZC7fix+egsxQkKN33GpalJSV3nP4M9yeToxY0ix6e/3yTpunkqGI 2TJF9fTn/UaEVUxXaZlc/wCIA8/9/nqWqopbPIixlduMgj0jk6b/AJNMbhFvk4A2EjH5aNer okyHqI9/0ckH9jrdKiKVQUkSRR7IRj9dS1Bol9grHt86AS1lMdhEkkUuBk/me/HsNLz4g9RU 1SI0ngroF7rUxc4/Mc/300tUlQNx7dgp7aLNYRnZnc3vnWlmJljHUcQluja/VwtTei8V6mFs V1uWKPv/ACJSeff0kH/PUhtPjBY5JFRbhU258gAFSFz9PQST+3tqoXDSfiJGR2U5P5fbWPlk jADYB/wjuddKLi+Kj0Lr8QsbsHC7lS6WtHiLJUVDrHcqGvjJBADAMox2xwe/POe+pPB1jCU/ nRMjf4cHn8vb9yNcgRiOFsKRGB7ISMfpp6tXUU9CCsVwq6YpkjDHZ/y/fXUi46dpGehWV/Dx /By6wp+prfPt3OYSxIAcfT7jI9j+x05xTxTqDFIrjvlTnXKVH4qX2kkO4RVkOcgyxBT98Y75 1IaDxuJ3R1lsnp4n9LNDJuHPvt5B/XXTj4xhX/ESPELI7AzN2Fro8DGs55xqmbX43WeRCn8Y +Xd+0dWhBH5Ef9dS209ffOR+ZHNDXx4wWgkVwD+nv+Z11I8TDKLY8HzWR0MjPibSnOs6jlL1 rTSxbpoXjfdjYnqO3PDe315H+enOlvlDV8JUANz6WBU8cnv30+7Sk4aGtI5EmQPG6uh5BU5B 1sc+2rUWdYIyNAnGiDUBmaIMFlAyB34+urVJPcqhaOmeV84UFsDkkAEnA9zgHjSKguHzVujq mAUsDwGB5zjuOOf9dQbxG65p6SyGargaQUdYs58pmjKxRzbZJDjkbF9RBwGVscbjtrG4+Lb2 boy0WWggWCejlWrrCIcuKRZA6SY3OrvM2MEOclssQdwGZ+KZFebkgy3suinuSybUp282SRiq lcEDH4m79gTz9+NKSGUA4OPvpg8PqVqa0h5mU1NQwklhSTfFTHy1xCjZO7AAJIOCxduM4Emq JgJooB+NzntwAOT/AKD9ftrWHWAaVZUSmWP2+mtnQqSRnGlShR7ADQAGrzKZUh3Y+x1jfz30 pkhDHPY6TvTvnGM6MEFDVLXI/PW27AA1r8s/0P6a1MLj20WipGeZ9P30Nwz3Oi/l5Mdu2sqj D2J+upQURwcAfbWDJk/8tFhHI7dtbBGJPB41VBRbBgPfGs/fPtrVY2J7a2MTKfrqlEMt/wBd ZQg8nOsiNj9vz1ssJPfVWFFrv+mjA3AB+usiIr2GtljPvobCuisDJ1su099Dae2gQR+mhRaj dGDHtrOtByCM4++sQyeYCD3Xg8aFMRmhoaGorQ0NDQ1FENYJxrOhqKLQvj21qZNGY1qyZ9tX ohIPIrVXydbgk6124/PWc4ydQqDvWQMjnSe41JoqOSYQyVDIMiKMAs32GhV18dDTtPMSEGB2 557arvrDryst96p7KrSJ5u6pasp4x/LhVeQ2c4OSvJAGGGPfQuOUWVdqt7h4o3e49Z/L0cMt siNeaT5aTKyeaI2YsCfQU2qx45zqzui/Eug6kuMVNQ1MVYXkaKWSPHDKoII+oI/v9tcn9T+J F1F/TqG2p59VTVciKkUYSBYHiJ3NuXsAvsMnbwdPnhxcqvo66WfqGYS3A3oGOE28RRxVETKT lWcqTLuZchwuQTgnHHP6R0brabBOt9isgHYLsuG6wyXKWiHMsYBIHsPqfp/0OlpONU14MXqt vF7us0iVAgf1P8w8LGKQnOzKnJGPr75Htq4Me/bXRac4tLzUaC3ySOMDWpHOsAEff89AHgY5 OmUh3QIPt31gcDuPz0CCTrGO+Tzq1S1qUEtPKh5DKVIyR/capC2+C1uuNTezU2qitMbTI1LV 29nYyKuD6wzZJ9iMDPP11d5PPOolNTV1T1e8DTobZBAJRTpAykZ7ZfsTle2qLGvFOFhMa4t2 SCip7XSWmqho6SGiraHaqt5DMyjuHCZDYPfAP176Zbp1rBeOlKSWuuNJK6XGH5gUkbx+lJA/ 4XOcEAfbv30xdUdRpNXCue4xWqjinaaCOrpJN1URwQckHvwNv1zjVT9VdXp1D1nZqehsdQWq qpDU0ruHEibSAAMEhB3xjnB76w4rEdGMg7x5bcuzv35LTGwE5jyXUVt6ki6krK6lpqcpSlCF nD4M57ErjkBeBnOk1v8ADy22vqKapgeP+dGfMpR6WJPdsggtn/izj2I7apq2ms8Hqp66126q vVAu+WorIq2MQRJn/dCM8hVJBLADt+mry6av5utDbbhcrU9vq6qMOjSES7GYfhVlLYyBnvjW qOV/wPGvvms7hWg2TvbbQlpRooXYUwx5VPtXbCMdlwM8/fOlwXntnWxYMM41gtnGmpSBbjA1 TXin4j1FpvfyFJFJlU5dGONvucZxwfzx9tWB1VfGo5YaenqdlS3aBCqu/wBwX4I+v56548cI KYw/xWpWoprvSSAuiNHkrjnywcq36c99KnzdC7IadXv+loioO1Tf459UdH9ZWDp+99Q9V0vR 11oarNor/wDaO2WqomaGooqySECvWWKRRPS26YkR7gYkXdskdHpPxf8AFv5zrFJq6suT1clu oXeojr6aqWqVqaNkqBLTIsD+ahSXMSqnr9KgcafevOvJemPCXo+ZuqbhRRx9X+YlbNdKC2Wj z/MoYYRVzVVBWK8sDVPzUcXlqAlJU1Gd9JEdM/jL0lbes/ECovF164jq66pt1reWqoqhaqCo Jt1MTMk8UMUcyuSXEiRRqwYEIg9I4koL8Mx0zifL+rTAQ0mtFKaGa5oylo1ZOwJwNPDVIiXd JIF+uew1FZeoa+Bz59LVUw9w8IcY/MaSf7RUM7CKouMzSOCdrROinH6YGvDFp2peqpSyW90w Pocsft2Okn+0kaNjaGIOCAeT+2dR9Ut9cFjp62nUngbJ1Y/ljOla9KTOiiK5Mh+m3C/sANBS LvKdKm6CrRUWAxyOcANzj9jn+2kkdnifl5Gkf/Cwxo6g6fp7cvmTTiSTvvzjOlc9/o6QkEvM R2Kr/rofBFdbIiC0KcEqiKvbZ6j+50vjtVOQc75M8fzO40jXqanYD0iHd2D4GdGJdUclVAJP /FqjaiUpZ6RSdlNGPqzDJ1uKKKMnOR9l4GkxrdpAaEt+mg9wTIxFz9QSMaqld2liGOmHojBx /i0XJcSFxtAb6d86Sq7Sj0vIp+/I1tTieKXcHXH0Yc/2GhU3WfMq52G2IquPcY1k0lQDucID 750paWpbJA38cBQToRuZR6lZW91ZSv8AnqlYo6omONU5JTdjkqCT/fRxnI4B/TP/AC0YKYE5 IJH56OSNRjHGPoNSirSHzp3wEyM/Rf8AnrZYKhxhpDj88/20sIxnHv8AXWwAYYHH5caqiqSR YliALSEn7DRuFIA3ED7ca2kCYwybyOwAzooI5J2wYP1J1KVrdZFiBAXefrnP+esmeVhwihfq STrVY5T+NAv0I1lqYscs2f8Av76mUq9E21s8kQLiMBvqAf8AXTPLNUzSj0ufv3//AAalHkIC PSM98nRTQRk5ebAHGORolNAmCZqqZVWRdwHu6g4/Xv8A30neMDLM5DD/APNjn+2pMFo4OS5k P3OdY+ZpGYBIgT9Qmf76ilqMJLc1fFMZmBAIYk4/bnT1bbhcoCprGjIx/u8Yc/30smrUUEEe 2cbsj9tJ3roAVXk5H4UGANTdVaU/7QPMuILdURlj+OTAH+ej4qmol3Dy44j75lGf2Gmx6lJA Nisv/ubn9tEyM2CS2fudDuqUnpoWEY3Fc/bn/ppWI1Pt29z7agzyTbcwBg3+JfY6C1F4bmGo m3LwTKw4/TRqUVODLEmSSMe+dJ5aqLAUHcx54GTqJfM3kLtapi+hk2ksv6Dg/uNLo65wVV3e QgDdsAUsfyHP99RTZOEtHC8paoYKD/RnJOtHpoFMfy9K499yfyyPp9DpP8xI+W2GHPO1sf5D v+ukdZdmtytNVVEEEC8+a0wXaMe5bAH99QHsUJpTGgvt5tDpJbbxXQDuYJmE0efyYH+2pbbP Fu7QwIlyho6pgfU8StEzfQ/iIH6aqKzdQNerdHW2yogrqSUkJUQSiaNsHBwynB5+mlX8XCSj 5mQBufSOO3fW6PGYiH4Hke+xZnwRybtCvS3eLluLBpIqqml3ZLxvzn79s/fUsovGCilQKt4p Wk7KKpdhP2OMDXM8dfHVxHy1Vef6mwCPtjv+mj4aSeQkuySA5wozjP1/7xrqR8axLRTqPvuW N3D4jtYXWFt8RWqmw1H5643b6aUSDknGDx9O3fTxH1fa5ZUE3mQS+3mwn05/4gMf31yMqzQK oido5B2aNiCP208UXWnUFAUWG4ySqP6Zv5nH69tb4+Nj/wAxnokO4cf4uV9dZ+E/R3iYJzVu /wAxKnlmaiqyrDvg7clc5Oe3O0A5AxqFdQfDA9Slo/hd+Vhao1ipobrAZkZUjVUDlWUsAQWK /hJJ9PJJjVF4rXWnBWrt9NWKR2TKH/l/lqS2/wAaQuFdauifjbx5y9u2OP0+n31vbxHAzAh9 a9o+/wDazHBzs2FqcUHTl38OelLXQ2Wl/wBoHt1H5JiLx07Vc7MpeVmPC9nY8Ekvz2J069C2 m60iXC4XqVmrq+VXanJysAVQmEOThG27gOMbuRuzqMWvxhpZ5PLe4QCTBJWoiaPHb8h9Tgfl +UqoOu4K1nAhEirjmnmEme/GeBng8flrqRSxSV0bgaWF0TmaOCk+4c41ruyeSdNsXUltnC5l 8sscDepXn8+2lUNbTV8bfK1UbMQQCGBII+32yP3GtNhKIclGQTydDcqkD66w0bBcjBbTZd6u SiWGX5SoqFBbckC7ycDI4+599EKKHVO24ayeRpKsjrTiSWPbJtyUDZ5+g/y1mKXd+I4Jzhfp jUpXZ5o/K617H760jk80EjtnAP11lnClQeMnAP31dICtw/250nWoXz51Y7SgDEHtjnn+2P00 aRkY5Go3fa00NxpnkqIFiU4eOVdplBye+7C4Kg5IwcEe+pSu7Ul3Zx99Zzpst9e10LvGGWFW I7YGR9Dj1fmOPudOG7GAe+O3vqDXZUtw2PbWyMca0OhnGqpWCUdu+us5zokNzrYSZOhpGHBG 6Gi/M1gS8kZyRqUrsIz2Oe2mynl8uukWOMeWTksi4UfXJ+vGlstQsSMzkKo5JJ7ailsulvqO o6tIZoQrBGeErwrernHszFhnPJCjvnUUsKYg51nWhlVFJYhQBkkntouCQzASHhSPSCMHH3B1 SJH6GsFgO51gtqKLbQ1pu550N+oqWTkY7aHOsF8a1DjjVqWFnn6ayQTka0L6G8jtq9UNhRfx A6spul7ZE01fS0U80irH82Mq3PI78H6E8Z1yb8QtR1CtHQV9jqqapp5FeYxCUU1VPLIwXgAA sFzjn0kHn21aXxSdA33rV6R7bSf+Ugj3z1LzYUqMkqB/ScHOTkdxrnPrrxPqL3R3MxzR1N3s 1OjGVgYkgyyqSrLkPuBwR9vrjXMxUz2EsLbB2+9pzWje1Geq2nslFB0wi5vtc0K1FKkeIo2Y gbAwB3ZZiDhuMcjTZYLDcOnkpKW53Sgpqa3yASBWBMWW4XkD+Yp4JYHg9tJv9rrf1b57Xujm eGFT5jTNuWQbs5DknJz/AFMMfrpJtW/TinW8JPRKP5cVSB61KgjJHDAHjJIP2GuM6RpZlqk/ Te7XU3w/+GX+2d6e/wBFeBQ2KnuLVVZTUMq7q6oAIAfaoHlkEMcE7jntrpqnuZpb3UUk04l3 KZFUAnYBgYz+uuR/hW61h6WW42rp+GnpqKtk880YbdDFMVALDA3Ip2++Rx9Tqxb54kvR1Qqp qOSmqWjYVs0TkpGvITGe44PHvjuNdfC4mNsWZ137/KyubmcSF0fG6yqGU+n662I4441Rvw/+ PVJ4g7bRHGFenLRFiwBLL3IGSSNXk0gPOulHIJW5mpNUsZIPPfWuc/bWxf6H99YMgPtnTlFq x9+2ov1t1HHZbMa2K6Q0bQsspV9pEyDunPbIzg8c6ea6vpZ5JaEzxpUlQfLcctn6ZIz29jrn HrPpnqToy8XWQrWXmO9CSnpaWkj8uOkiJG0OxLDILEjHHfgaVI9zW20X293emsZm3UR6g61r uvut6ynWU1UkTsVLpCJI4RyNrg5QDuOcnRt06IrrRdrZerbPMk0RVVjMp81GIIcITuyMHI4/ 11L/AA76WunT9tr1r7FbumUmXyxdYCtSHJOC7MQDk5/Dnv7amlwti3TqO1RVF1iQUNJP8xUU GKeKQZQKrkElRjOSO321zGQOkjzSk5iR3VqPei2tkDXGhpR+iebT0FF1HYbI1VVT09HGVqJq WIrmqYY2+c2MnnJOMZOM9ubGUbFAXgAYGqg6d8P6fw1vcl6tt1u18NRjfbpJvmVXOSywcqEO TnnuAdWlXXJ6WgjqVoKqUvjMSKC6Z9yM+321122NCFzqKMuN0prTTGeqmjgTsvmOFDH2AJ99 Mg6orpWgeK3fyoyPm9z4CAjujHAIHc6RdU2+g6qpKZakVM9FI42ywAgBs4w2BlcH34x76iV8 tqeEkgrnnnrLFK2Kmmml3kKVwM729QH0++qkcWC+XPtH/EYaDoN04eKdRTVFr/i8c8G+mXfA XJeOb6jKgkEfXVAX/rX+OWCvaO1XGgeq2PEISrFJQfT5a8bCx75HOc6Ku/j1YutOqZ7dEamn tynyQCAopx7lcKQB24BOqqv9/ulvvNa7xtL07KxjjraR2HnnjDGUoCDjvx++uNiMYZCOi2Gh PM94HYFoazkd1ZVZ1HPa7Z01QS9E9bVNHHf6pLxL0XU3+GSMH+GRv5otTLmTyqp6pXlDqVoJ YY1D1AeOJdeeF94vt+iuN+vT0NwqaCibyKeGrbbEKaNIvMNay1Rl2Ku8zjzN+7dzozrXrHpt egbFX3iO23GGa8XFKW0+IFPZai1SAU9Bvn+TrrpbxLOhG2KojdyiT1Ksv85W079Z11ilr7Xs qLreoxZbXsuNzqIrhV1KGggKyT1MDtFPKykM0kbMjMSykggl0uQRNp2niPwVTfi1Frt25dPW SaMtWWyimXnmSnVv9NUH13aul5aukMFppKJ6uQKiLL5Thc4J24IwME59uAw5A1MPGu5X6grK d6CnqZUBaFJKAGWSMOvDOigkqCpJAVuFz7Y1yvefFeTqO32+vhvkdikeqlt8xqNsMKSsRIZP MSNjCvqLszLliRuXG4xslDJiWOZfjSBsj2ahxXQDfD90Fe+mKC4yxVNNLUlYvMOAm9mwGKsC RkkAAkHkDudQ+y/Ddbr71BWWymuVRapqSGN3kVXUb2AJUEFcgZX789hxlRYfGmg6loKbpkXY V9xozA5mk855KsBDK+IWAfO5doxk8ggg8CyPDComvdZcL68dBBT2qaaOpyoknnmQECoLD/d7 1bcFAJCvjLKwAn7DCSknIKHZp9O9ahi5m/yVY374W+pun4llperoSpbagqpC5c98fzAfp9dV y3h74hR3aW3UtTbrrVRruejaEF/xsoIVSpxlW9vbPbXZvXM0l46Tpa6hr4IInAlEhO5ZAyHY FPbO4qQftgYLZ1SfR/Rctw8R6S50l4p6+p2w1Yipbp6zGjor+cgjK5JDNkEEncpPJZsD+EYZ 8gaBXb7NprMdMNwCqEvlH1Z066JdOl4xI67gI6loCy/VVZWyOD740iTqXyWZJ7DdQi99scbn 7/1A8a6I8faySqqIbZSioFVWMJJzFBIEgyYwssbhdsZDKGbLkDfk5yGWpn6e6uusN96KuMGH pbSl1pqx6hkjgfBljXfIrNueRp1O4qxRecBQByJ+EBlmMk9nlr2/ZbIsfmID20PFRSn62tNQ 0QFS9J5hwkdU/lMTjOAG7nAPbPbTvTXqhmwY66KTnGDOpP8An31XXhitNcb1R1dxqLlWUxk8 tFp0MlQZXGFWNCHwSWC+kD8WfbV8dLdXeGfUdpqLdVeGtxrb/b6z5aspqGnq5ZYUGSzSN5a7 W7oqtyzbclQSy48Nwt2KYXtcB4rdicQzCv6NwvwTAKxUQFYJXGPxAek/31o1VVSq7kJSwqMs 7N+Efc+366tyj+F3ovqikglsk9wpKqaBZFqIKlWplBxuIOP5mPopIzgErnOtJPgmYT7ofEC4 TvFysVTT7kRu4IAfA/Mgn76Y7geKZ2HzShjYDzryK5g8VOnL11R0tcZbc1SppqeWeOR5/IjY qpOQCDvXj3AUj3xzqO+BVi61tnT5rOpKuXfIsfykbMadRCAcfy8ZB+xUAjBBOTrqLqf4S/EB +nLnTRdT26qE9LNCQYvUAyFf8AJPP21G+nvBzxAntCfL2213engRYd9JOpJKqBggOccYPb37 aUcJi44zEY/umtnhJsOCjK9VVkGF+UlmbHdTGf8ANx/lrLdcyRPtloKscA8QucfqFK/31IK7 ozqe0RPLc+ja2mgjBZ5lUlVUdyWK4A/M6apaqniILUtXA47boQRn8wTxrlPifGae0j5J4II0 NoQda0m4CeYUhIz/ADiF/uT/AH0+U1RFWR+ZHLvT/EpBH76aIb3SKQHrxGo/plBj/wAwBo+K GxV0hlhioaqX+pwsZb9SATpVDmoU7bowOJMZ9tGBxghXBz99Nstkt7cmnaDPG6nmkhP6lGXW fkadgI1rZkVeyh13fqWUk/qdFQUshL5XWLlmYfYA6TGrUHCEhvuh0n/hzRZEdyMjE8CpRXx/ 9oX++tXpZZGJNfTyD2ApyD++/VZVM3chM0z9pN36Y0UKUtw8pyfvjOizR3kShkp6J4l5JStk DH/4eUQP/u0dPU3CHcVs1TMO2IpYAf8A9KRRjVBhKmZZFHFGPSAW+w3f5a1NNG7EBGB+6bc6 a7h1rHZ2H8Ssd8o4veZaE1aLgf1GnMpA++Mflpjj8dekXu6WuK5I9a8DVCwhMMY12ktjuOGD cgZAY9gdEInnYWqLxsprFQSYXACj6nj/AE0YaFQcHLE9wo01WDrW3dR0sdXbJhV08gBSVUIV wQGBG4DIwQc6e4Ji49eV/wDjqiyjRCrMTqi46P2EeFx2zrb+F+YwKgr/APIaONfTxZ3SY/8A j/01obvH/wCjA8jd+cqP31MqvN2LAsqljmUgd8Z0aluiXPqLH7Hj+2kkt0qGAJpYo/1Lkflw B/fWG+cqcBS5U89wP9CdTKFdkpeaSGP2UkfXnRFRPEqkfX2HpB/fRaWecLudndvpvbH7Hj+2 iWsdQzZWEMPqZNv9h31Mvcp5pPO8DArI6gH3LZxqF+I/TFJ1l0zWWQvvSpaNZNrmPEYkUyAP tbBKqy9vf6Z1YaWHgecsafYHSiKzU0ZzsRyPdhnRNtrg4cldjYqu+kenunYrT0xZeiqxujLb RVSpXW4RpJFO6FTJFUF/UGkHoLk8kR4BBB053Hw9ktl+liieoeJCDEHkOTF/QG3NzgAAj2Ix jUtmsVE8RRIoqZyS6yxIAQx7k/4s+4PfWlruJBjs8sXy9StUsrSSM22pRpEeWSJgSdx9QIOM FzkcjOwOM1hx1RNDf4mkVbKSSlh2T08TLj+hP+XGnKOaGnA9Plj/AAL/AMhpXdKB7aiSuyrT yHCSNjv/AITycH7f9hv+ZjXP84H7Kv8Ay51ncwtNFKLilxuFOsZd2CIBktIdgH741mmrYKwn yJ1l4BwjDHPbnTf8xGSWERYjnJX/AJ6ytcOFRGU/RU9/20FK7T4McjdgfbuP11qFhVsld5zw WOcflntpsWrwwySv03kDP99GpVhuAQ2O4HbVqr7EvkWOY+rn7HtreJRE6vG7xOvYxOVI/Udt IPnFQgM6rn2OtzXxDBL5BPH56LvVWpB/tLczDJA1Y9RE6bGjqFEylTnKkMOQc8jsffOnf/6i 3BtoqKSkqsjnzU2tnn6HB7k4++octWABxj6AA/31sJAzAkqB+XfWtmKnZo15SjDG7UtCs63e LixSI8i1tMy4U4mMikDOPTkAcke2fbUotfi/RSbEFxUgEf8A5ZGwOMjjcMc/nn686o9SpXHB H6DW5RiciXZ+QzroRcVxLNCQfJZnYKJ22i6YouuqWrVi6xSjPoMEquPyPP8A3/msPVdtC7ZU kUN6cCIsCMfb27/941zBLM1SkQ3NlAAHXKHP1zwc/fS2lv12o2UwXKoXGcCRvMX9myP310Wc ZH82eiyOwB/i5dQ011t9TEjx1UahuwY7D7DscEdxpRLT+fGyMcq3bb3GuZI/Em8U0fktPTyy krvlNMzMF3c5EbLj7du320rp/GW5U5US2qdxEAVNHUbTxyCEJ45++CO/GRroM4rh3cyFkOCl Bql0OKapeAxycHBAdD3+n5E/bUU6gpZ5amres3Cjj2tlS0OwAhixkVD3A5weNvcZ4iNr8baf bDG09XT4zhayAu2PuQWJ79wfz1LKDxTpalY1f5SQ5AkYT7Dz9EIJ5PYEjW5mLhk+FwKQ6B7N 2lLOnJZa6PdSTu4DB2eQsUKsc4DHlyBxkYAz2OCNSeOJKcbQTlu5Y+pjppg6st+3a8MtOvfK pkfXgLz/AG0dJV2muRY1q4PMl4QSP6jn6Akc/TTc1CmpeQHdOZGftrXJHY6Y6WnvtrKCXy6+ HcQ7BiX2+zAEd/qM/cZ7aco7pCTskIjmBAaPk4J7e3v+Q1GTNdo4Ue9R8Lm/CbHclOWGfcfn rBdh9Cdbt6k9DLn2zyNaQyLKzLwJEI3LnJGtCRSyJM5I50lragU6JUE4EZAJ+x41Heueq4el aGWpqClPKiM8LNJt3tg4UcertyPy0wdK+JlH11060dUfkJnQxVEzt5UeT6TsfJwckD7H76Qc RE2UQk9ar8keR2XNyVgVVUs9LOsZWVgpBRSpPb6HjVNdCXurvPXNzgSqqaW1hgJJFpghEiAq 0TthinGG3ZHvjjTveOvKUxVVtra7+F3Gh3rPFtI9PPlujAKWVht5T39JweNc/WqovXQviLWx 04N4qJY2p46lKcwIA58xVfzAqlyfqTkZGfbWXEThr21qAde1Ma05SF1xU3NJamRDK5ooQqiO Ih2nY4PsScYxyce+eNGL1FJPULSWuKOunLYlkjceTTLjPrPufoo5P2HIqPp/qq/dV11VY3qa G0LSbI56tX83YQP9ygXGSe5PpOT3OMas6zwR2enSmoxHGmUjLsjLvUA7SrEkEH25+vc6dFL0 9lmg7/shIrdSqnjdVBmdZ5fdwuAPsB7aPySe+iaVFhgRQQ2B3HudGhgc49taqS7QzoZ0M86w Wx/01FSyTzrO7OtNx+n66wzEflq6UtGZwPz0ju9eLZbp6nBcxqSABnJ9ho0k4/10lulZHR26 pnll8pEjYlyM4wP7/lqUrBXMniT8VkdRFebIsEtmjWEwmplJjlEnZtgyCRzwftrj3p2uvN+6 xlpenZGFRc3aKq27UUwSEDDvnCqcZ7jkY1dfiHfOnuv7vPWR27zHiK76+SSUVMs3YsUOEGQB 6QOARyOBqvKzrKGkrporRXUVA0bBJQ/l7G2nDLIcZGMnuSDxnXl55yJaLs1fJbGtGXTRRrqT ofqHw0gqI7pSeVWeYd8TyrMjREkEngZUkDgZH5Hu3dRvQ081uFguk1ZWVMbSViPThYZDnCrC gOSFx2IB/MdrK6vpZ+pOoqvqTqC2W6xtbERnpZMxi4uD/JlVTkJ2bOzgkc99Z61S1XHpm63G pstts0tNAlaKcSCOWSUEMGiI5TcvsAA2tLo2ussbuOY9+9kQF0OxVbY+oa2thSitrmzQPlau 40jsNwJyUIGCFIyNh+upfQeIN9qhDb7hVSrEJ/LgdGwXQYx3PB+2NUj07fbbWdR1rmqdUr5M U9HA7CRmz3YnOOeffnVkdK2W59bdXUdmtdE9038zmV1hNIRgGYE47ZJKjWD9uXvDaQ5gGnVd XdCGm6ToZ+srfQT2yjeMGquYgJI59atgE4yuSR7jnGupOi+raXrOww3KiLNTvwrN3Yex+35a 5vt69P8AQXSdm6c6l6gSsqtpV6bZtqaoFvwhAzKW45IPPfGr78MKSmobA8VJbprTTGTfHTTF dwQgbTtUkLn6a9LDH0ZDQeWqxOddEqZF/vob8Dvos59tazR+dEyH+oEcjOttBRV/4z9VV3R1 nprrb6SSqqVfy2+X2vKqEjO1CfV7E49hqrbV171P4q1otvm28U0MxVWrj5TOCp5KA8nI7HII 1JvFDp8U709EKyoqqlaV2iCxCbb6ssZFHKp2A2njJ1AKLoO7yS2C6SvboVqnKRVUjGNkVj2C DGcAnGT31zMSyQydWyK2vT3qtLaDb5pJ1b1NcaC603S81zmqIElWCeKmCim3buRgKMkckngZ 79tWh0pQef4k19DDXST2iC3KoaY70JfuPTgfX8Wc5PbVMda9a19JWVNooP4dXJYKkREVUMa7 93JkbcB6jnuOCec51G63q6932/qtA0FIYo9nycsYXzxjvlFJxxzu47fnrjOxAw8xa0l2o8q5 A+7WtrSWnStPuu3umbZD05QmnSZRGzl1j81nVCe4UsSdvuB7dhxpZWXdqYN5dNLUBV3M0YB4 +w7nUB8Ees6rqvpCnWvtdVbauBdjrURMqMB2ZSQAQR7gnUu6hFyltrfwWWnStjdGX5hSyMuf UPSc8jOvVROErQ6t1zLrRM9tuW+vlpLnXwijqKbKUbHbIckk4X8XAxz31X3xK9fdN2PppYbj b5ruHj4ipwTIPoTghuOTjBzq4EiElNDVzQ7ZEjJaGJc5Pcge/wCn31zh8Rfi3QUNvpqGppoL XT1Mw86eqpfMkxnDDy8g5I47r9c+2gnLWMcb3TIySbVI1HQ1H/DI770w8dClPGs8kUkLRzyA 8/jPIOMjnv8ATS3qGgo+trBFWwW35KpkUSOVqGWLCjllU43k/YDOc51O4ek6Y01PV2OGGttV ZTefFcpmTAccqu3uB3HOSMcar2aKS21NZLVzFLpIMEmRdqBjhcrkHA+mM/Uc680+OTDR5iOq ee4Py08R4LY1wcbB1UntdLdbn0N0501bKfr2t6fN5muc1b0ZUWVFiraSotEtAkz3RPLyZ23R okysxiZTHKpby5X4nT+JND1V/wDi+StRJaGikmF2pKeWtM3ysSyeeaWNoPN3KdwiPl5zs9O3 UVsPTdRX3HpmmpOp7n07e6c3L+F1fTV+t9FXXIj+H1dTSCjqKaaWbb8hSyMI15R2RwyOVKak 6j6g6Ut1s6ctNJX2S22K3UVop6C7sFrI46elihQzHZHuZlRX3bFyHGABjXRgIZAxrwfL8pT7 LiVfHiH400HT1PPPdU82CKRxDVKr7GSN8NuO3gh1XcVGVBQrnI1TdtqfD7xno7jd7jbf41bL ncBEY9s8ZhIMqfMLKBgsF7NlF2jkl4xmJeKFPN0pRUdXSdR0wq0ukirR3GNHBKyLG8hUMJDm QzOAmVYLklQANDpTxSsZ6e/gfyFOnUbR1Hy9TEMW+sqZWTckyMrNFueKPbjCjbtGwDA0sk1d 0h5aD0Se9Sj4arx0T4edW/7FXSH5Dq631ASkutypEp5qtC4RIgwbc2Q8gKkEenPB2gX71H4k dJ3qxXS10lUZHmKTwzWtkBlcSErErbvW2Y2DDgbc8451x/4H+JS+IPWN1i6ktlVcrlTqiRXe mpnlFtZ45GSU7cFcZKjB+/HLGZXTqy69N9RXWnpp3ustMhlLU9Wk8lHOZpBDRkb5MwtJGCFz vQyhQxzqPmc2AGQcvf5R1dKV0vWtfL0tUUq1ktLJT3nZHRUSGWNYlijZXidB6k9SspY/hKLk Eep46CuYh6rcVFPAZL3M1CRPMKZKWmSMs7LgkyFlkACjJUhiWGCBTNVeq4UUtVd6aGOOqWEz z1VI007sgVZiQ4AMrDJ3Mhx5kmGHIKzw58RJbE1RVtTrdaMhxJCk/lKCVCCSLgHLKxBIK4wS OAcefw2KDcTvZOnp9yB3LUWEtpX4aultdsrJquola4QV7VEdZQsoV6aBXfygUcqDgOrDJGXf HIO2vfHeqW72CohrLjHHa6BYFNRtXhHppj6GIAdgVRwnmHGCSyqDiT9T08/WVin6ks9JZ6iO 22+ShqIHlkknhEPO2FpN0bSA+b6yeGReSM4598WKuqstNJXXYy097oqPyJpaWRpYnjSOUYbB U7opEhi78kBlJ/FrtSuLBTh4d6Q0WQq08YekuoLLdbXQdEs9yo7ujTUtbbHLyS1GXWUq4cgs /l78AnG8rk8Zsz4cLH1t1l11QUnV0VbVNabjLFcFmqGjWnGN2+WJNqtiTOWZZFfzGBI41jo2 /XS4+F9LFdI6ei6sspmopb9Xus08AdWnk8tyzEqIFfnHIB2MWJUTroHr6x13iBYGp7m1D0/I k0UtFaY6iVUeN0/m1LyIrw/gii9Ksdrbd5AO1sOHjgdY5m050znVm1Oy6ruNzSkuVOTXSUoM pFK5YBN/JK7BhjGq7924juMc4IbPCnxNbqLqTqOnrKRbdDABMsrvwy7mVWOcd0CnIyMDvgjV EdS9dPb+t/lIKKaSrmqHDikiFTFSRmJVi8mNQqlG81v6id0YYgH0mIUniHc7beo7j8hVjz4Y FrqmOFaemgMnmKqAKGfazxyqGb0KzhgQNQz9bTlyWWrC7uv9UsNtFUJl+WXPmHaWTGCPVjsP rqD9AVop+sq23U8n/kwpY5G1Wkcs48sHuuATu7sck57hB0T1jDYemYun787NWLRioqHp4MiE SOwxgAoNv+EEn0nAIGTVVz8R6zw66knutHb4pLOssplrxLiJlZgwl2nLAHzQMkeheAz7kBc6 QNOqrnSuvxC8U6Xpfpi4VcrQxS0rPugqpWp94X2RjgnJxgjjn7HUS8E66o6wutVX1Vqhe0zw FTI6LIryhyQQcn07JAmcd4XGFAUa416k63vfUvVV1llubNQV2KinnK7EVld2pyzEYVfM85io 9LNGG5ILG3/hVgu3TEtyvVbU1FXQ/KyyippnaOlkhCgeoMA6kSRyAhFLBhzrmQ4kzTajQD03 1TA3K21Ynj/S9OdLyRxUUNCKg1cYlggiTenoeUxEKDhTGjckLgYO7jihYoxca2mhq7Si1dSE mSnWlPlmORmjjKt+IL5gA3MMFcHI8wYcvH/r2k65qludZW1XT1VAzRRNTSyQAuxOYZEkClcK CWyEL+bESwVQBS/g1QV9D0rJPSvPW/xOJI6f5NXbyaeGri/mEkYAKpzgkrtJIy2NLkggmcXZ QfJEyeVgoOPqui+tej+junLHQ3C3VlwElQnzHlec0TRQCQI0hXK4UA5DHjPpJBKgtvQ9BQdc yxx2rqyffIgZSVWWH8IJzIRyB7/Q9+4GmzqWyw9ZeGEFabiZJErzi63eCRohElIJ0TCjKIxx IM7iCW/GwC6hPhb1PFP4Z1aCurLPN88kc1FSN5flRCPh4GYcymRivbaC0hbPoOsr+HxPfmDB Vd6e3GSg0530Voda2z/YOglqKjq+xXFFG9i1PLlFwe7LtX2xjk5OoDYPEOLqaFJ7dRx1Ucpx uhNXD2ODyYSv7sNXJbfh+E/REnUlTcZxUQK0pSrVZfNGC3oYuu1iAuc4wSR7EajUdvjjkcUw WpRYmcSBGjDFQDsG8fjO5No7HcOe+OLPw+drrEdeB9ldpmKgLazWfCk32stI6yyUdZRueFDS g/8A+2nyJml/3hkHP9QXn9tLoegOpblVNT0Np8yVQrsqVUJkUH3aMtuUfmPtweNFz9N3O2SJ HX0FRTPIxWMbGO4gZOCBzwRrG7CYhnxMPoU0Sxu2cPVJ5oYXKmRd4U8DPH7e/wCuqT678Cbd 1R1hUV5gaqS51KyPUxny6qjKj0osgJJhJL8DaV45fAGrz+XggLKSkbLw244YH6HOlIgzH3O0 8ZHGlsLmHTQotwqM8CvDe4+FdnuXT4ZJ7fT1HmIXlPnMxUZ4IwoPtzjHGDyzXBSf+ZgSSHJQ qDhvxfkfppbWWyOrHpzHPjCyqvK/p7j7ftpvo0nt1Wsc8awzHgSAnZKuT7fUcffnHGeGOcZX FzzqUrVmgGicBDuHMC/mRjRsVKI+RHGv3Ax/fR0UhqHZVwki/iQ5Jx9e3I/5a28ktkNNj9uN LLKOqMG9UWoVTj0g/bW4h3ZJC/mO+gYUBwBu/M62SIZBACflqAUitYNOSeAdaNTZ7j88nSjY 2CN2PvnWkknkLmSTaM4xyT+w1FEU1Nt5Cn98aKkCjPP/ANulHnjkoJHP0CEf562bfIMNHtX6 ucaqlKTdI0aHk4I/xDTZchSVsWyZ2ODlWUMGRv8AEpxgH8+PrkcaeZKKm35Zcc/+mW/56yaC EknErL2y3OP3OqoqwaSLpzrVKcC1XthULL6IppV2pUD6fZgBnHfjue+lHUdrq7TLHPbYo6y2 S/hl7vGePSw7e/B9/wDNt6tr7NZunblXXOF5bdRwPUVHlIWZI0G5nGMEFQCcg5GOOdI/C7xZ pK+kp/5k1ZYqr0xTVVPsdfW6bZU9juRwQQDlTx3GtbQJG5ZPXsWgFsug+L6pZ8zXNH6aaNH9 2LAL+o76L8qvlb1PFjsQgJx+p1Obp00kUXzdGFekPqK9yg+v/t+/f6/XTU1MirklT9sdtJfC YzTlmzKPJRTYAKh8+5RQf8tGfwqRmydufqck/vp8Yxr3YL9u2i2dB/V+uMDQ5AhzJoNokI/3 /ln3CLz/AH0oSgWFyytJk98yHSlquIcb1J+mseaADtXH1wp/5avKAqtamPPAyQPc9taSRkr3 P2wOBpQoZuSp1tgnkL+50WVXeqgfVy3evb5S1i/0ZSohWa603lRwRxmWMy4Eh3yYj34aNGUE /i4OJ1SfxOJXNdFFBUtLIVigkZwse4iPcW7PtA3YypIJBIOBpUZkppkVhuZGXbjOcjTpfZUq I7XVDcY56KNgRyD6m+vvjH76aGgtOmyDMbq0R8w4PrKgn6tz+mtzPGRlyxH3OFH6abywzxhf 11lGQEFixP2O3Sw1XmpKy3mEbJvLX6RqMn9TpRFE5JA3bT35/tn/AKfrpAKxV5XaD9uTrR6+ Rjw7Y+v/AE1MpCmZPqRybf8AeLGB3xz/AK86OjqBJH5D1LVIU5KAgY+uQP8AXUeatPllRNty MZZuP20dFdxTwqC4CKOWVMD/AD0QBCokKRQo9OA8NTPSY/8AzMzL/YcadaDqq50T+m4zzpsI HnRRkfYFtuSO311Wdx8SrBaWIrLxTRSdtjVCb/2znUHvfxUdF2F5g9y8xYVy0oHBPsoH4mP3 wF+hPbT43vaeo4+Sjo8wst08Puulrf4o3ejjjSahO6L1N8lO0afoGwp/L276fU8Vae5Qg10V SGj5ZJadWCexIZcNwCTkEftnXEknxodJPFKaW4M0qRtIrGBjwBknbxtA9yc/kRnS23/HZ4YW 1o57D0F1R4jdUIykmqijio4TgZKbS3GRkFlz75GujDLiicrjQ7xosz4YwAQ3XlW67qpOtJIB QE/NrHcVeaknjpXnidOOD5alo+SpDOpUrj1Etxrf6/qPyzd7OiVlVThUqqOmdZo5RnO0cCRX Gc4OBhux1yd0J8VniF4odUm5Xuy2Ppe1wQukNqjleorACwwWkBCqCVUt3ztQYXubotfi/S1Z U3GiDSqRiREEmAD6SCefvx21uGOhB6PMfL2Uh+ClLSXMrx3+yk/ipWVNXY6a6U3T9cKZWjnq 4Yxio8vI9LQYP1yScEBTomOK11PTNClLO0FWYxT0zO6xU1RGwwwi/mBH7g55PA4ONbUnV3St z+WjqyGliUrFVy1MiVYBIPpnZhKO3YMMjjBGnaWmvFrnlqLP1HJXUUkgdrZdqcSCJe5WN0Tc AechllY8epeTroRzRSHMKcfmsJw7mUCa8dlz/J0RPR0lXfr1UXGe2RtPDBTyur+SSSQu9c7Q TjLPt5BxkEEw+ioKGruFTa7hWVFq31h86qmmb5aBY0jxHgZbO5i3GeXB7HXVLeGfTfUcs90k o5KGtqH3VFRaKrKyMpI2vExdD+WM8DOPw6jfUHw9XGntYbojqmlpLmasVPz1xpi0n4dpAeMh R6crkxnjjWI4Rrn20cte/wB+KE5mjdN9jvvTfQ1VJ07ZmqOpbszJJBAsbRwiXGQzZyWZQAck HgDudWx0B0u1hp6qrulzN0udVMZXqNhVUGBhEHso+g9yTqJdAeAs/R9zq6v+I1M9ZVOXqLlJ W+c82ccbPLVQVwcE5/Ec57amPVnUtSlK9JRq1HO7iFTPGVkkJIGUH+Hk5Y+2SO2unCwsGd4q tgNh+fdLK7XZSGW8wyztSwVEXngZILZIGeePb8/vpbFNCiqokX8899MVisVL0tSPIzfMTsDh iq7yByFGAM6cqWX5whzEo993BwDyAP7Z1vbZGoStOSXmpQH8a8fU61aqjHBkX99a7EH9Cgfl rBjQn/dr+w0VBUVs9ZEBkugX3y2sCZJT6GU5H9JB0ydSUirSVE6lQZolpCpHpAZsZ4IwfV/b S1LLAla9VkmVo0iOQCNqkkd/ux1eihCXEgainiRdR0909PeJZ5Ep6NcmFY0cOxICn1fQ/Q6k TxtCjESFVUZJzn+xzrnH4kvGK3x9LLRUNSJLjHOj+SCv4fqc5U89/cY1nxEogjLr15eKZG0u cuS/Err2WpudbX3WGKnvTOxaO1U4p4HyxKE4bLOB3JbuMc99VtQ22bqC+01HBNFTw+YGeqrX CQsxBblgOScHCnnOruqrGOvqB3pxSrfp5v5VLSLJO9UyggKuAUVRyS3GCM9tPfWPVkXSHgn0 ZburOlno70aqVqaGnQozxENuJK+oNlh6QTnvj6cGCMz3I7z/AAexaKURpelrteejK5q9Kism MYnlpJIy7vAE3K0THspYfYjafrqO33r+wdS+HXSdqgthpL7RU5k+apW2LUQMSAjqE9TDaMsc 9jjOdOFc1fdrPe7NC9X0zRmqhnWmqalsNBtGxc7SwxnnJGQdTegvNHVU9paeK3utvpDRxpTQ 7YwDjOF5IwR3HPOjdiIsKyhvt2804sOgcud5fDCplu8ESW2S3dQR1BhipKZ495MihlbaT3we wAxnnHtPvEz4d+pOgybnP1ItsoUo46kSvG4WaoK+ofyydgJAG445zxxqyeuOqbn4fXCe+1Fi avutYaSCOMxN51bz6AjqMq2CBnvqguvvEXq3rWiutPW9P11z8uoMTy0qSfMUIcsqU8mzAIDD +pckjnTcM5kmcuB3oXpSCQVVbUl3SF4qjZUqHr/4hHb5RLKIpGypY8DaeCw9zwfz16O/Df4r VPif0/UyT0ElAKER0+ySMpyF7gH2IOdec/gb8NnXnXVdQF2+UorpV/8AnKpEMktG6qSvmqCp j3DsRnGefpr1E8JfCi1eD/Ssdktk1TWHcZJ6ytcPNM592IA7dgAAABrbho3Ah7TYKwv1Ndim vbkawecnWckdjjSK7XelslG1TWSmKFTyyoWPP2AJ109BqVW5pUx8RNVXUdwt1XbrXVyVdPBI 0ddFUtDDECMEsVU8jg4PB7c6pyq8d6ar6YnsVzik6kq5HSkaGUmBoXY4VixYBQTzvyDq+vFK n6m6h6Wt9H03dpPLraxWqa9owXigznZsUDuOMkce+O4jFv8Ahh6LuN7qLpWUkVTVAKwpZFZI 2YD8cqFuefqAPz1z5oJpH5oX16V/fzWoPY1ozDVUVcvDm51dukts1sE1ynMSJUBnm5LYGXRs EY/qb/Thr6JvdX4O9dXumSMXWWij8u5GmrmRZIwAWeMlCQ0ecNyM410ZfvC6oMUlFaJWoIUb zP4lEoiMK4I8sHLApnkgjjUT+Hnw9pKnqTrOqu3my3GhrGgnmlCiKp3D1qykEYPGcfmNY24H oHsFHfe+4n3y5LQ6QOjcT3KW9GdW3PrSonmlFJR2ihACxXNGjhnhY+hgyvgEZAJK+331e1PA irHII40fywv8r8OPoPtphtdjt0MVNDblhW3xReRJRrJvSMDG0DuAV0811xpbXTNNVVCU8Mak s8jYGAOdd1rXAdZ1lckkE6BNHUfWlvsgaKQtI5UghARg/wDu7D99cc+LvTH/ANS7lU19ipo/ mYJMVNFXTswlP0jIG4Z+vIP6a6e63NPdLJU3G2mouDQYlRrU6LNIcj+Xjswx33Dt251zT1zR VVJ1gKqGaalDoqS22rZcQdzuCnhu/vz9Ma5XEZSxgoW0+9Dr/wAW6FoKZJa+4W7paG03Z2tU 9A5kWnp8AkHvvXk4x34576h8nWpvdTS3BElRqOXd8/TxAxxxjkcFcZOOM4/LUkp/DcVVylvj X2l6heoGGoiGgCKB/USQPtgYx/lMOm/Ak1/TlZTfIrZ4KiBqhYXjkeRwBncjFsHnHpOT+Wdc YYZ7yGXfIc/K9fmn2ApP03QVfjLarFQtarB1HDXS3MTWjqOplSBZFS3BK2rtizLFcKeAF8o6 O4nloQj04eSeNFB4Q2vrmloOoUsVkpkudut9Ulvgb5qnt8bUUBjpIJqMLBLBCm2ON41wyIpy 2dxijeEctutnT6Xq2dP3a2W2quk812v3X9f0s1FOkFproo1npNzSELQzVRUxMqChSXzIzHh3 68Xi62GS3WrpOkoafpmhtFrp7bHZ7385RiAUFOUEFQ6hp4wDhZWALqAxAzjXYeZIo29ILcs7 xZ3UDHRFV1pV1lPfLRW2Goemapp5qiV3VQuxWBfcI3UhPMkY7TJvJVhkAwHxZ8JKvomzRUtN TSVDU9onqDeaNyDPHNJuRJtyRYJOFVV3cM6ksqHHQNx+KboWq6W6jlgku38emoqiMU1bQspG Vk2xEIrIApYj1Ej8O4kDhXevE/w76vplT/ailNIvyW6irbdURII4pgpMczooOQzBlAOfWp4z ijQaQN/+/wBbLldNibAMengVzT8JfTb37xwgudvvlutM1MC9TZq0sDLmN4JIzuOWfJyAeP5o +m3VqW6kW5dbzV18s89KsNxNFdb67SyLWEmONvxCJ41CICXIKAGQMN20GV3G69JWSsorlaOq +k6esqKOae7Rz2t6gVNX/KjkqInjdJI2YD2POwkDduOqx6r65tXVHWdyj6g6qsbU4raaWBzH 82xcpIWpd59UUZZ5GWVT/LDKpII2hUszQGsAur8N1pE8jSMzK9+CZOuBeb/JRSWiaarmNOpm pohiqEzb2kUp+AhSP6WJwyjlQBqF9HeI9xpWoqSZKq3QVMm6OpjDbQ6Zc+YRu2hQqlgASq5Y htMdX11SST1ENE0iUzUsqolUgJjZXBDcY2s2eSG3ZYglsEnF3s1JI1ousfXFhhNTDFVRW+qh qxHEIqiSFWHmI44COCO2QwKsuGPDigaXh7xrd/NdIy5W33Lsbw78Q6Hp/pfrlJK6QRwiZblX 0uxUhLOQssVPsydxdiuEAbncX/EGbxj8Epuv4JRLdaJrhf0iVp5IYRNTUyRyzTF3RRh/MSRd mRkhRkBSdVNb7tRvef4303N/C6a6YNRS2iVy07el/NKSR+ny5WVm2Fsb96MpHq6M6Q8ZYKqq phNT0lNc4alTR2uKdEkqXqFO2WTYAWA89GLKuVVpvxnXpRJFMA1xF/j86JTHZusFRXTvSl0u Hh11V09crA1XcpY3FD1FUCCVPLjkKI8VTtXzSgkRFIV2XDbGHEOkPhT1xS2+e69QXH+LxdXv FIJ3r7es9FUMkcitOdkZeP0U2WVXZnaORWCgnV9+J/SVq6b8L6Wbo+D+J1QKJb0q6tWpqeRK qOaSWp3OSzpJFIxCsPxsCuFLK1UvhFa7P4Pmnt14rqm3moqnrLNa90NVVQuWjdpFdBIXWR0d z6VK+khlRFOl4OrgeSom7Kqq6Pb7t8lelNRT0F7pPmDR0z5hWrQbYVJAxiVI1aKJuf6QFDbT dHUXT9+6K6TthuF3tVNWQpGt+qaqggmeOOVESExxq2fLTMoJcEDbMQcADVF9fXmotU1i6IsV sttbRWh1opLpsiKVMqzeasBdsoDI21ctwzFjsyBss3xH6U6kl6nq+qbpdUooGq6CgtNrrJo2 knD1FPvjjkWaQlwYk54GXJ9HqOs7SMpyC9VbmkBOFg8dFv1fTzRy+aUE9JFPLuWd5CXBip4M Fgrf+WdfMDIqsq+puNRZesYbF1perJBBU1drvdOVp6dKk06QKKcqsUinDMhhSIZxuAeTbk4z Ganwj6y8MfFGytb7fHUW6nvEtTEsMJf/AM0WBUzOMsRIEXBZv5QaTO5QGc7xlsdf07erDcKe 3SVwp6CGSGGlhO51VRLGZckoG5kOEJBVCpAxjSJHOADvL1CEajVVgt5q46mWAW9ae708Zt08 T5Ms6xh1UvGDncd4yxXLenBGCWtLwn6yHU1FNZWuMFKlyq0hqI6WYUvkMrrGJFZwQSqxSAg4 3gouBg7qbpOks+IN8uFTWUqUdXUTyKg85ZcyxsmwtjJw02PuUcgnacSvwi8ApOoIa9YLpQ0c JuMUFNTSzmaqgkkclMsrLukwgK7CCPMLEqrPrFA3/acos7ojmy0VcfxDeAslkrKaOz2qfqSi +TRquupq1Pnad46iad3Odq7SPQOARwF/q1SnhdeHtvRN7ppa+8w2G0EQmS4QxjzZT8wVEKlS A7M4BiYlv57sxIGTcXXt/vFgsfQNHTXKqW4UNPFWV5rjl5pngjQx1C5TzGDbss+0ZcKSWJ21 f0ZTXqHo/wATGjsjU9ReVFRV1FZX5iWaB/5kgB5COJWVNpywSUZbgL0XdGQ9g5Wl66kK3+mO p7fP4ZUMVB1DYqS1KszVVI1PIt0L+UxkWBN+SPWy5Uq+Nw3M3dX4U9P081mnhToagplit1bB J1DUFC1RL5snnKqZLmMhyPXtJG9TgjBoyq62u9D0habZt+Rt9xooIlSzpEiwzrtbYr5cebJE QWKsjNkKwyrZun4VPEuTpSrlpOoVucPSUsZFprqsExlC5eGPeCCCyrv81wEO4H0Bsysi+Kjy Vbq2+u/FR7B4C3O7wT1FzujTRil8svLA8gfYfIbbGZIwEL5GfrzrlKl62n6bunSNzue+50Ms okejmhQsyR1ErKGKcZ9AlOMkmTjIGNdYfEXbLFeqnpa619zls/T1BXvTlqdKyOfzwruFjSCE t6gD/M3D05KnkhqU6utPw63nquW63S+11HQQcRUVvtVRSBzg5Esky+t2J3ZUJwCCSCcjM5ua 3Or3ujjY4m2i1OOmuv7m/T1ruVvcU9rqHeoqrr8zGHmQIEJIkct5rSq4BHAji2rnacOdt6pp bp17d7hdoluMsEix0NutVMZnkrYVVnLPHFz69oYjGTjCgfigVX8UHgD4f26W3UNnn6q8uaVz V3q5wyrUNIQZGP8AMkcglc8x9yT3YklUP/iedHdOUaW+y9FUNFRQgrFBR1UyRqPoFWkAH6aE 4hv8D8imiF3MfMD6q3Ld4Z9d36b+JTQMausqlrRLVSfLpH+MMDGwLKSBFglCy4AwAMasnpjw QgoritZdYrXMoZ91NDSK/mAqAu+VhvZgdxJ7HI44zrjvqP8A8Uq6Ttus1mo6SI/+m9DLUv25 9bSwjv8A8J1VN7/8SHxiuRmjtUyU0s8g8stSwgRqM4CrsY85GSWPbjGskTYmuzAE+ITS2Ro0 08D+F6cN4K9IOjCW2s5JJz8xImMnt6WAwNQbrnwz8OLMpa8dVrYKM4xTVNfCoBAwNpcb89/c nk684b141+NnW1EjXHq+rhpJ4t8kEUrmM7sHDIzMv5cfXTfYeia3qvArq+tq0JKyI8u2MH3y gwvc/TRPZA7/AMseiJvTj+S6xfrDpqG+TWm09SU/UNGo82nnRWgmVO2GRgDwMAsAVORyPwg3 q7qh+jbKLulmrr9bl5ke1hGkiH+J0Yr6f+IEgYycDXPvSvhTS2eoFXDCkNTTPiKVPSykf1DH uRq5+neq6uwywLW1EYh2AyHbhATkAk54JOPtk+3A1w8RhQDmAsdnYtscjgKvVGWXxq6dvFP5 jU1wtZOMfxCnGGz942cD9cae6TxAslxm8uO5RKMZ3ONg+w9eM6S3XpC31pNbYkjOFLS29AoU 5HBQf08+wwPy94e9LEKYRttO1mDLt2lTjkEd+Dxz9DqMwUMozNcUf7hzdCFatNWUNYcxzxS5 +sikf2OlqwbDui2Iv/AgH9++qmpqPZna3pVSCqjPt34/LRhjmpd7xyyRMfWzxkqFzzjjQu4c f4u+SMYocwrYMLquSN35HtrUUgb+nj6arGlu1xoaZqqGtkjkIycqCTj7EHPv31pcevOr7dDu opbZJIw9K1tO20//ANt0I0g4GUbUUfTs71aopVH9JH5DWvyqjPpB59+dUTU/FBeOmsJ1J0FL U4J3VNorNyt+Ubruz243HUh6B+KfovreralNU1jqxtxTVoILHnIGFLZHuSNv374V+1mug1EJ o981Kyrv0/R361VlsrqczUNbC9PURKzIZInG11yORlSRwc899Qvw58NrR0vHdVpqEMajFNN5 mGBQO7Ff1dmc++5jjjAEjvni10r03BFUXmqkoqOZlRK1YJamBiewEsSMmftu/PWLN1f07blr 66qvltprVV1RNNXT1KRwSliWCq7EAkjdx39Le40kskb1SCO5E17btpBR1Fdrj0PKA8j1FlJI V2BeSA8BVY57ewbH2ODgtJrhY4a+lWvtbExFQ0lMhBKHnlfqOM/5cds0E1Be4WNDPTV8RGGM LpKjA+2VJGO+o7W0lf4f1C3C2LLVWePDT0UXMsAyTlP8UYz2PK/deFJkjaySbfRawOmoHQ9v 5W4ocgAFsHttOP8ALWhoY2B3Jn7nUoRqXqKjFbRDdKw3SQrxn7hfY/Vf+y3Lba2uVWobJdK9 JASslPTu0bY/48bR++qfE5poa+CUQW2HaJl+XSEZAAP20W8u3HcfQf8A4NDqSqg6Sp5ajqi6 2no6GMHdHdarzaojsrLBFlipPGcjHfnVHdZ/FB0pYUghorrJX1UgDAmi8rzQexjhRpX2nuCS O40GV/Ifn03RsiL9vXl67K63nwck4P30naoA7vn7a52bx96iukkL2/py71MQUPIJKUUSNz+F XqGT29wDj6H3jNX4jeJN0Vnka02XOQsclS0zqD9QqOh/fQa8/qE79pIdR9/+Lqie4rT7izbQ vqLNwAPqSeBo/qnqq22ToTpesrrpSUVKRNFFJUzoivgJyhPfIXOBn/PXnv4i9PXyvtE1Xcuo krY45Q/8Oo6Q01MpPBbaHC57Z9GT9ddKXe1RdYfBB4eSMZVa0VsETzUwjyFEc8J/GrADcI/b 6a6McTTG5+a/Ls1XOdbcS3DuFHQ+R0Uuunjx0jaqJ6qS8CSIDK+VE58w4/CpIALH6Z0w1/xG 2WOES09BWVEZGS9TNBTFDnsVkcP+ynVE0lhp6aMpLRQzP3FQYYxIfzKqB+wH30huHS0Uyb4d m37ekj9NYLbdWu8MJGBqD6/0rlq/ifo4l4Nvgffjyo3lqTgA85CIBz9z+Wo9VfFXVzgiCCGA AcMFJOfzPbn7HVJXLpuSAn0kH8tNn8PdTjHf660tiYdS4qFrW7MH1+tq2pviB6mrRJuuyEMx KKHli2KTwCYyu7H1GNMdz8QKy67mrLk07nA3Ydiv1wXdzz9yf01AzROPbn30VLupxuI9PudF 0DDomNkLNQK8NFJP4lTVGBJU1sy+6GXCn8woGdNDUdqrbkahaRflabciK7MRJKeCxG7svYY9 8n6aYl6ippCy0lRHLMfSiqd3qPA7fc6kFos81TRwDf5UGMKJhsJ9skEZzrQGdA0u25JDpGzu DN+Z+ynHQlja4dLV9r6ZpjRXC7yinpxTwwGWdW3hqeSRo9xDMFypIGFYHHOhEKugkMMkIo3j laNoEQR+W6HDIQOxB/sQffTFY6arsBgrqeoKQSVId1hkZCswkIjlUjHI4zg/4SO2rP6jV+qa O3dTeWjz3MtSV7RkKoqkG5JiBwu8ZB7BfUeBtA0zxmZm9lfMeGcZk4fjMs5tjnOAcedch2Fu 9DcaVqKQUvU8lAY5Gdy6nKlW2kfqNOa+JF7+YWaGqKKn/wCfO8Y/fThYvArqq8wrJUx26xIy 5AqpDNN/9iZA/wDkc/bSi/8Awo1tfap4j1Y89RLxCEpGjYOSAuNr4wCeSQQByeO3CZhwTrov rb8dHXb77VvZPGiWgnda28MAwZjtywx7KqjPP5/vqwun/Gme3RQz2m4jZUMAIqZysrsOy+Uv JbI4BGeONcxeGHRX+x/UFL1NfaJuqOjaGompZailbKMFZozK0Z/3ihsPnIPIzjtruHpRLHRW yKp6ep6GkoapBIktviWJZQRwTtAyccYPI7HGt8mGMBBzX3rgDiMU7nMyUew1qO1PfR/Xl66u oRdbrb62zVsUnkwzVsSU9XUQ7csrKgyse/aQCQ2UzwOC9t1LWUDK9NVtTvnO1TkH9OdMBuPO AxZvoNaxTzKfTHGgPcjg6oyk8zok5R2KeW3xVv1HHvleOpbj0yIyjv8AYjt9xqRW/wAdK/zf /NW6RlPd4JBtH/xbJ/Y/pqqfPQL6mJP1J3aBaBuT6m9t/wDy0wYyduz/AH5pZw8Tt2q728VL Jd1jS5wNTyQgskk6kEkjHDxE7fvkDv21Kenur+n3pYqWgngVFA2xJOpYfchiGP5ka5lnqhGy gozM34Q525/TGf7aPiu09PEUEkas3vGnP7nn9ta2cVlabeAfqsr8Cw/CV1r83BgHzQB/xggf v21vI+yLeAWGMjZ6v8tclUN+r7U5akqamnBOWEU5jDfoO5/MakdL4u3+mfipE0X/AOanRXz+ pGf763M41H/5ja+f4WV3DnfxKuutmNLQVDzOWiFRFLuXJH4weB37e2pNFMk8ayxsHRwGVgc5 B1R9N43TyCNbhbKatUNkAMQRjkH1A45+n01J7V4z2RKZFkpJrdAgxwgaMDHYAHP7LrezieFk PxV4rM/BzNHwqYdY26a69PVVLFNLTmQYd4c7wvvjHOfyz+R1wr4vWep6Zmigq0Souu875RGV RF3naQGXGSuCe3J12m3XnTXU9DJSRXmKnMy7d3nGJ1PcFSQNUR4v+A3XPW9WlTaLnabpQpKj qvzBSoCD8SjK7W/MuM6zY/JioQIesb5IY2OYadouZ+nr7fLH4m26psM9JT3GM5jApmIKg5dW wCFBGQSvtznXSXi7DauubQqUd7SmWOlDTW6Ko8000py3mgk+htxAJ5x3x76rjqvwN626eje4 VHS9ZVOAsESWWBZoiPczRxuzkEZ5XsftqZeDFte2WfqXpe6WakjjpIfLkq4jmogkde5VvUAV buD7HTMCHxR9GVHgNcHBVL1XTVb3yKoqo2mNbMIpqiQ+ehaIAbldTgBhjuBpsuPT9BFDHJVw zU01am+mjRsAjJyWZOQ2VJx9PbU66hEVClVaaedHqaWSUJVSeppI1bAzxg4x3+mmun6Yt1+r 3jrwJIaE/NTxwbl/lmPLEOWCsckek9+edefkIfM5ux+/brutT6F2m/qXqFerKelqpqc2eanp hBBIjmQxlDjcO23IA9ieD2zoWu5rSXOiMdquMaVSDzrvbN0lQHxljkkArxuKHLYyRpJN0xao po6KOtuMt9DLBTSQDiSGbALlfxAAAc8jg5+urupfB+92w2+moblS3mKJGjlt8sZjEKbMCWV9 5GQc4HJOePfWbDxSyvMr7IGtDmbofLXT72hc8AZBv9kd4EVXR0U1zunSVCa+6VEwaepeR2aV weTleygknBB7/oOqKRpJaSJ5gizMoLCMkrn7EgHVT2i72DozrXpfp5bPS09xvVvqJmrIwFYP F5Q2AEc7gWJweNo4Oc6spY5J5GCv5ZUYMcZ5H/ubt+mvcYUFrMr3ajkOXP37K572m7rdOYGe DqGeI9HZbtaaikrK2KjuAVZIpEfE0ZB4PBzt9j7YzqVCOaNRtOQPYjOf9dV54g+IFF0vKHqg sdTsDpSS0+DOA3u5GMfqMHGtUjmsaXPIA71TA4nQKlOh+kOta68XwA3Pppof/MUtYmJaecqe Qycl1J9lbODq6vCmmvdbZK89U09HBeklbzqqg2+VMnsNv4gB7q3IPvqSdNXqO42mmn/h8lqO zMMMmGHlnnuuQB/lpPNbFF0r7lHcGhiq4DHiKUIFYdxjGCfv30GHw7ImgxnTf1VudnNlU6nx AWCe+3K0VdyqqdzLNDNVvSOlKm3ICFT7kcggknHfVYfCX1t1BNYLpbbdSzXihermkbbDnzYw 20NHJJIBnAztI9saO8cvB6e6xXOe1dRSpZ5Ueomp6jky1Cg8ROQR78BvfsR7O3w6+JvTXhp4 amjvdMDcUlaSaI04SXyych8kYYflrnzYkNnYx7gBqQVv6EugL2i6IV/9AWm40a3O/wBxWClj rQsi0/yphkhRRyHUM+WPckEflqvOrOuKrqTq/wDhsES3W2bm2quUwAPUQd4zweDzqS1XxEdM 1HT9uqUlkakubtTxyU48x4xj8TBe35HVAdTeINus95qFtkcU1NUT+btdggLADkEjknuMHnGj xc4ZGMrtzrVX7KxxtGppWV/9WLNVvJSWqwRy3FYDTpLIPmZRj/28lew5IOoTRwXfrbqNqS/1 FHa6eGk8svJGI2nJ4IG4n8IAzgg89tLOiLH/ABWtmvQWGKQsP/MU6hWQn2ZR3yf+ejqGy19v 6gu0MtwqL6VYy0dPGAYhKwyd7e/0weONYbmkYCdQT4fTwWgZRq3ko54ZzVXhzX1kt/rKO5UU lS6QUhAkkaP+nacEc4Hf7avI321db2gWyie6WWKSkLRQxSmJI3248vIJyMHOAcDHGqz8Xeib V050xF1Pcqpbe2zdJQBhTea7YBCEjg8ZwMk86g/R3U9rm6evN2quq5jV0zh0opqkH+XjgCXb yw+uOfrzrS0y4VzbqjyPZvz27KQnK85giur+k6eLoPw/vtz6/sXSF7atralKnqDrejsZqDHV Wupj2fM22uE/ly22ic7fL27VDb1lIHVlqgsHUvT1hu16oJ2uVba6Oeb/AGppIaa6gtAhxVxR hUjnGfWiKqq2QAAANUHZ2vL+GnTFBR10lyhjludSOm7VfrpaJ69EiimNWKm0wTVeKdQ8RgMY ile4QAsZhAjyy++ItfD/AAqlW5UPWk1Pa6JZ+pIaWJYrtI1Okhq41iDRqk28SAIxUBwBrZgp YxG18hoEIJBmedea5363+H3w5p6ChrKTpilhle62+haaGaZUeOWeOKVAquAcqzAnHHOCGGQt 6Y+Hbw5vFJPSP0XTIkMsqSszyhtqzSKoDGTdlyPvlUcen05ebZ4f3+xUdJbI7jSlGqaGsZai gljKGnYSSBN8AzucDaTzgYZsZGmlaXqr+LT1VruVrtdbBPMKqlr7l5EgzIpYiNsxmPcHwyHB 384IYayR42Fzta53t3f2nGCTKQCozdvCjwe6fvs9krLWsi+RG6WsVcuFmJl80q/mhySBAAN2 3GeM8rXHib0D0V/Ea5aamm6fqYYxWQ0s88paeN1QorPIdiBQ+OCSdjjOSo1cXiV4W3rr/rqO 8WOnttVKNlMKWW808zMmx9xUB1ClcI3IORKwwwUBjb34cXXqq8tUdQ2OtaKlt8VHClFLTHdM ZMSRyETbn9WAG2jndjjDHK9+Z4siut57Jghd0Rcd7H0K5UTpenS7RU9PV7fJgqG8ipidCBuh wynauSdxO3GRsJP4hh7vHUAjqugbQlnt08B6caVp2epRyI3qZWA2TopGVJ5BySTnnGrJuvgb d9/zkNgutwoEoZadKWGGqZ6aQlGHlFFIZGIxjauA2eRkGNdXdNWa3dY2K2VFn6kpa6nttRTR 1cUHneWGWoDRSRMyFSFLPnLHHpAONBFIw5XDn9gUxjTqPDt7VV9F1qj0dxuJsFnoloVQJJTP XK5ZpAAm81J29nbODyvbnItPr1rTernS0sVruM14rqynsNLDDeVhpxHDRQGQ+uCTAXzYxgBi 3JBHYsHSvh/boLL1A8EVDXGgrKVqimrKySNMx+bKVdqinSMfh9S7j6SwJUAnT51B0jcabxCt VRDartXwU16ulwetoqf5qnhIl8kK8iHb+GlBIJBUMM/TWkuY5+m39AojGQ3X3rSrHpKt6Z6o 6gslqbpe7w1lZc6eCOaoukcg9cqqVCpBHkHd9T7Y1J+hOqLT1Re7rLV2251jys0jyISpAd8D Ded+IgkBSvb8hp7+H7w5htt8tnVVQZHtUUS3CGrrqWFVxHVxRsUzIx3qyt6gPSGUkjcAWLoK stNB0l1ALDKyQwtSRSVkkL+dVuyy9ychUHr9Kr2C5JOWDXFmaquq+Z/pAGHKL71Ydzk6H6c8 OJ6i7U99poZrrS0s/wDD6yJ9ziOcgq2Jcd5dy84JXtzlx8GLj4Y9aXSt6coqOqudWI2kja42 1apkjjK5AbMfIyDkDtn6gCoer6kReEdNbfmqWFJ7+KgcSeorAMggpnILA/TkanHwliCm8R+n 6uRPLVelq1i0YZ3mY18sYkYBcjvt5z+Ac8gaKKGJ7zY3/CW9xBvuV69ddJdA9GdP1N+r6KGC Kghjhf8A/Ez+S8mIo1be7qoBk7glRy2c41VNuvvh9LT3FKe90dbeooKqpEKQqkUxVS4O5Kh0 B2K3Y49bADU++Ke9x1fgfe6HCzfMw0VQW8w+otVBypGRjK7GBHfkew1ytB05TWqyWS6LZCGP StZMd6sIZZ5LhPSFpWGGIWGUYwcjbH7DGlPhjLLCq3EnMNvZVtdM1ydQ1L3OOpqHooqOaEVB p5EZEKfgVi2GG/naxbgZAwNWD4c9c3fwZvPStVS9KW++VlziX5ippadFuCt58gODKx9W1eX4 AULk5PNbCjo+leg6LbTCwVUlrieaig3GmmWZBIrKcHzHKyKN/JBIUcLkp+uOrblZek+nhLSJ EaqxybaAszLHKZ6gsWVuQdpUnK+ojuCMjmxCSKcuj2uuSW5zRdhTCprLN1/1b/C6esqIqy4z QFpKqYM8FRK6RFIw/J5mZnXODh8DAJNieAdt/wDqZ0ZWWxKagoZJ7f8APRrLNFOh/wDNyCb/ AMvu/lxKjKoHcAOcse1KdMJL/td4PiFpYlS+U7zICUBxa7XOd2O5JEhOfcn6nVx/B54ddB2i NeoOt2kqr47hqeH5j/ysJmSXDsMhlZlTGG9HEbckjZ0mhsbsjq81cjWsZn2A/r8q0OsPAvrX rforom2xVCUnUlBd5K+RYTJFTpH8sQBNIpYO2VRCw7BmVRtJOkXUXhKema2x3O73Cl6XFupn gt9xtu+oo6eCRhK8bglNgAdlEhKZDoqqxOBO6a301mnSit01bDTUjTGGOeqlqNm+pmA/3hbj y1ibn/EfcnKa93FqmaqoJKmR4I6aM+VMiPEQzykDYUIJ/lHHH9QHGt4Byl47e3s/4srXtfWU 6HX7K3ZPEbpT/YCtmoOounq9zTSyJFT3KKEOmC2CwY4bbnJGOdx415/9eeENFeLBcDT32g6n Skm8wS0D+bFGfKJ/GGKls5G0ElVjU5HmBR1H/CKCOnhiWlowhbyVHyUWGB/pwqjjbu/TP11H +q7PRwWm6Q0VFS0FPTZl2UkflozvtGSuSM+gd9ZsYC3U++adh8rzdriC1eA3mSJvhVQR2wBj 8/311T8NfwEdMdedOp1D1RVVS0sjyRw2+kURFtuAJGkOeM7/AEgD257jW8NukjnERiVtm2Mk e5VQpOf012j4M0Atnh5YafADmkWdhnnMhZ+R+vf89Iw9PJzLbJ/rbYVZW/4CfBi3QzBumJK+ WRSokrK6dtue2ArqOP3++uIus/BOi6P8R7xRUtIfkqS5VMFNCSWfyd7BAS3f0beT316x64r8 e7HDReLF2ihpwvnMKhFCjBZoULH9X3ZP30eIaAAQEmFxc6nFc2VtppwYabymghRFQ5YEsRnH GnXwuMUFPXneruX9SvhnwDxgew+/20q6yskkFfV1DCOKKJhFgygncE3NgfYEfluH11t4UwzC hr2+VlnWRgRt9QXauTlf1PPGMazg2nlTmjpkaqBWEbXG/hMjPv8An9c6zNSjdIJlJUx7dhwV YfcHg/lqFXXpePqLr6gikrKykDQJAY6ardAF/mkZx3JPufrqRXPpSfo6/QwRXaur6KaCZ/Jq KkzLHhodn4uQcMRjPv8Arpr4XMaJDsUlsgcSzsRbz3XpynnnttdHBG34JqhGkSny3dhnmLnv /Rj1fy+Yp7bbLD1bSyzVIWC8eZvZWI9a7VABHAHA7ADHGdxyzVr1TRXKrs8tLZaiWOvkZPlw H2MMMpbn/wBm7jtpi6fsHX/QdYJagSVVshxvjDqxgG3nYBnCKTggcYBwOBhcfD5Zv92HodxI F+qOTGMib0Mg77q/n9lYtfbzRVMkE0D0rwjl2XBKkntk8/nyB/kliTz38sgxYAIRmPP551N7 T1FS9YW6KK5ReWjRh6avIUEhh3Q85GcZBH0IzwdMl56YnsdU8lTJ5kU7ZhqogSj/AE/JsD8P /LOs7JA8d6YWlu6anBG2GEho+AF3AA8/XWJqalmZGbczbgoXf3P0++jYRGsaZA8oMCd49+3A xpQskcsS7Fdp2BGEQlic/wDLTVW6KqOnqSujZ5YF3NH6Dx9exHscHVH+K/hJ07c7NU1KwwR1 zMscQiIDFmbG4H7c/tq/Umc0K+XGwJI4Hf655+2dUXc0a4Xqqrn3FI6qeXbIxQDaSQMc7Txo a7FOWqgXSXS3iv4WrVLb77NcAiFZ6WqZGRlx6TICSWTJbCsCMBuOdTjrWt874ZrZX9YWSmuT w3xf4jCqeSoRpKrMke3GzJ2429wfodRC8dS9Q2ysjrKNqVbY5jlYyuaiWYIuVwXHGNz5J+vb UxHVV16y+D/r+7VRRKgSiog2+srEk0BbOeCQGl4+4/LXHjfPiCOkII7tEkFozV2KrKGr6BsF xpqyXpQ2uTd5ySzOVMWckEgdueQDngD76fOpfH2519FHS9PdV3Sz0UJCVEtPO1RIByCyru7E kcDGO+uXJrw1fQSTz1dRNXFiQJX4A4AOSck9+NIaOumeonQSiM43knGDz2J9tbxw1pOZ7iSO 3X6pbZXDQLvDwn8d16Ip7db5r8a22eaYorvNuyDuwqSgqOcEDdn+jPHfXRvXdkrvGqyUk9r6 v6ht9bQoshtFnvj0dPWFSGByuCGBA2nIGRzg8jz18PKWq6et8clWVa1PJ/MZayMwkDPEmeBg twRzk8dtXV4afEDN0f1HJT1NUam1ybZElgZX8gZw3JxkAckcnB+wxziXRPcxpJbzr7VsV1YM WHZWTDbYkX69oWn+xfQEt7mNwsXm3p5GSVup5Zamo8zOWDCodiGznPGc50+09FaLM3ydqpIK NmH/AOTWynVTg+5WMcDjucDjvq5vEnw7tHxCdMLdbTVwW/qnyF+XrBIWpqwbSVWbB7ZIAkHK 8fiHpHBfU9f1P0Z1BeLBdYa6119uyZaSZi7q4Awzc8oRzuB2kEEZGNYXcLkn6zJSR36r0DeN Mw2j4AO8LpdenJpFwkewZ4V+cfsTrceHtTWo26SmiwMsZWKj+41zB0n4zVMEM9FX3KlpJJRi OqngM6sScbScnaP+Ln9MasX4cfAm4eOb3m6T+ItV0l01aisU81AGmqZKljxFDGjAkbPUW9sq MHkhLeETsJzvAA50r/z8LzTYj6hSTxO6Ba0dC3e4i4Uc3y8ayItPMCxbeoUDjHcjVpeCtiuP WXwg3vp+hppqutp7iixQwQtLJIPmoXbCKCcj1kgDgA+w04eL3hf4Z+FXwo36isdzv1+v9TXU sq1vUEsvmyzyTR+ZIsfCA7I2GWBYAkZ9Rza/w118tk8LrFU2pJHuNNYpqiMTIBHNMaiqqAAq tnaTUBf6SRngcY7WFw7Ym9GZM2a9R4V/a8ri8YZ+JtlazLkZt/8AJUnavhI8Ua2BZabpqZYn xg1M8VORn3KSMrD8sadv/wBSzxOQEyWihBOchrjESfy5Ouja7xa6tvFOJIbvDRwyqGRqCmQB lI4OX3n3B4OofcqmvrKdoq+5XG5q5xsqqt5NxPtgnj3P2GfprAYsMNsx8wPsvQ/vcUdw0ep+ 65i8R/h56i8P+n7peL5U2ehpbdA1RPGbnC0zBVLEJGDuZsDsBntqi+gnt3iV1DFabLK09dLv 8uKSJo92xN7AFsAkKCcd9dSfETJcaTwt63pIKKnpY2tEzGvLAjy9gOxc8KWKyJjO44BAIyVq H4Eeg7fO11vlVSq9bbyEo3cgmEyeYjsDjklVxn2yRrQyCPoXP17tf6WGbiMzZmRadbuP57li p8B79T04lNGsikbtkbr5nbP+7JDZ+2M/bUd6f6In6ltkdwtdsrrlQyu6JLDQysHK/iwNueM/ 2P0Ou5mpAQcjv7EZ1q9D5xYMkcgfBYMo5/PWHKe0rpjFu7AuCepOkqmjqrVRG218EstQxETU ckZxGhZgFKjs3l9vt9tL+l/DC/dWVz01us1ZvTaXlrIjTxqGAI9T4ByCDhcnB7a65vNnjqPF PpNSApprVdajCEqRl6OLIK4I4dudTCGlYTRKtQ64YYD+sd/3/vrQ5tMaL92lDFEucQ0ewuVP Cbwuoet7fV2m6y1EIpJ33tRMFJKsy4DEcDdg9snHtqYdO22DoDrBLY0Py9ivtO7wQyEui1Ef 8uoh3MSWViNwY91kX6aV/D1JtrLzIAzAySuWVScHzTzgcnv/AH1K/Eboulq+lJaWzxxx1NJM a+iiicnbVIGYp7gCSMugU4A2pjjGN/SCOYXtQXyyHAv4jweUR/G2R7mf/uB09VIOlpkloZKN VKvQP8seSdy7Q0b8kn1IyHBJwcj20rvRqPl1paN9lbUECNi5XYikF3JHqwAQPTzl1GRnIiHR 3WNNXrZrn5mYLlT/ACz5JIDqC6HPt/6qknvlNTKzzrWI9xwR83gxFlI2w/8ApjBAIyPWQRwX I9hpGKj6KS+3Vel/T2PbxDAsdsW6Ednd5bd9Lj6weD95rOvOsumLDdqi32ky1YFDDO4gqpYG QKsgZjy+WBY8cj2HFmeBl7k6SqKOzVLTm2VwKD5soXp6kOUIwGJUFhghgCu6PP4lJdfCLFR4 s9bznaHW53Bcgckefj/QacuqOkqKLxAq7fVSrbrT1bEZKat/ClFdI14ZsDhZBtY++SzjlAdb 2vEj+hk5heccZGtdxJh1jkc09mW69Bz7u8K28bRjLYHHsMfprXGM8e/1zjTVYLtLdLNSzTDZ VAGKoXIO2ZCUkXPvhlbnSiSZs53Af/Hcf764cgMbi07hfQoZGYiNsrNnCx5pW0gc/iY/l2/5 aJkK7T5jd+MFv9BpK9Qrj1K7ewy3/I6ws4XJGAPfaMnSrK0CkzdKdAt01XX68wXysqKarrfO W1jCx07OpBIJJLD8IA4xt9/aQLXvDJleCe+cEn89L7H0VfrzU1VfSWi41FHPSx+W8SzGKUo7 EFdvobIfuf8AD31I6Dwm6vrULRdP1EYx/wCqY4j+zsNNMMr6IaT5FCZI27kKJJdZC3qhLj6g 40elyQ+lkZBqcQeBPWM8ZY26KH/glqo8k/8AxJGjI/h36ymgMsz2elIBJheqc5/NxGQP/tOr GDxDtoyg/cRD+QUCe72+nDGWqWMg8841rT9TWSpuZt9LcKSe5eV55pUmUy7M43Fc5xkjVJ9a fEr4T9HXirtc1xl6mrKaUxTS2GlNTS7gcHbNK8W8cd1Ug+xOtuj7/wCDXUVkhPSrS1t7nq3u NXRUcDpUx+pXKGJ+ZYwQOFDKAvtqjhJYwXStIA8EQmjdQa7VX2lRMpJBEYPuvJ/6a2gqJqSQ SQTSQyA53xuVb9CDqJ0vXdolgeWSaa3RRYVv4hSyUir/AMIMqqD+QOnGhvtJdUPyNwpKof4o ZVl/yOuYS4bp1A7Kb0viL1Dbs+Td6hwv9Ex84f8A6edOsfjRejGi1FDRVaAYPnxk/wBt2NV3 80VO0qXI9/f9h/row1isu3BjbHIIyRpzMZOw9V59UswRndoUjlovDC/XKK4XHoyShqY33q1B UyKg+v8ALyE5+w1jprwy6Gt94lqrT1TNT0Uyuj0F2o1l25zhVf0jaM8Bgx++o/HG9WvEilB/ hOSf19tK4LZGB/u8k/T3/TWlnEJARmaDWu1fSlmfg43a2Qm1fh66sor+1dYKuxXCj4SGqoq1 46pI888Ou1Tj6MT31a9toZelLbBFeV/hFroIfma6SmBkWqmP4SZACScg8HHtj2AqW89e2PpW q+Ue4IlwUbjS0z7pkH1bH4R/n7ad/CfxOl626ymp6q/vT9LU9Ozv8wrfz/szNnaAOccfca6O ExEbn6MomhuP6NdvcuZiImx7uSnqq5V9z608NOtKryaOyU99W2JDFJlYUmjYMHcYzkoufYEA c66ipJ2rQZAPKpB/uVUnLj/EfoPtrmnxr8Srf1N0YZKKWCnorBe6KRg345FSYB5FK8AFWJHv j9tdBW65NXXKSkgkaKOJVk3EYaVfbaPp7bv7a9PhS0uJDs11r2mz8lhkPVb6fP8AtKOqbxSW u2T/ADFR5BeNihByRgd8fTUa+Rt/ilY0Nw9DUoKxzxgZEhH41P2+nb66r74gOrBar3SwUzwL UeU0StuBy5Gdj8ZUkZxng6ojpPr65dHWGvoZJhVVnmN5VNE7NJGjdsDdj9Rzq8Xi24UjPsij iLqy7rsyxfwqhtdup1rBcYREwWvqNrb9vBy2MZ/5ar/xE8S7LaJqmitsa11QVKSiCby8MRxg dm/vqpbR4gTV3QtD08LnXWi6UJM1PVMFCTvz6JQwOT/b31UPXvUk1jqKmWscJLtZiFQ7mccg D2OT+XfXCxfHf9YjwvxH5eR/CfDha60mwVuv1xJfel54aGWokllgaGoo65NgQjj0nO327Y1T h6RpqvyRPdGS6GT+rMhWPBLRspIwuQOR9NRyz+KV5uVPB8lbGM9Q5DSKu8KAO5Kk7Wz3DAae +l7nd6r5iS7LHSMMowQ72K/8DcgfkdeQnxGJPWlI0XahMXRdE26O6ldTWUVD0pXtHPHW1VJG DO0ckjA/0qUOM59s541UdDYam8ilhlrpKKmlqkBNUJJBHzncJAOx+41N6PrKhpZYqmgomQNK Y5WMYleWQDIDLnLA4PAweNFWSqvNsapuU9lFDHNOXiZ5fLaBskjYCcgcng544xrtYefNG0Sm j3n50sksQshgvwCvHw8uFl8P0hWkuqPcpI9pmlYTRTAE4XaO32YHnU8tlqsfUnVdNdLbU/Iz s29qygozDFNIc7lJLd/rkZP37a47ul/WoupuNK8LTqMCGFsCRMc5zwMfl9NOfSfjzdOjZ+fM qKJi2xlm2sTjjcRxkfbXaixuU5CwZOz39VgMYrQ6/JXL479Y9Z0twqOmRFR3KjmkcebNCzBl Iyu5TkggHuOM64skrrr0xfKo1EQSGZmSaP8ACSv9hj8xzrqjrfxmsPX9ttZaA2zqWKIA3B29 GffcB3HvkZxzqpvHWltNustDVw3OK83OqI3RwjzIHUd5FkXkODt9LcEZ7a1SlmJc5zHWKsWd u5Rurmtqipz0N1G3TvRtJSXWBplVjU0VTbq+qs9RRLKFEkfzdJURTGOTyoC8RYozQxNt3IDq pep+uuqrx1XeKimoqK0UomSCnt1OkdPBSQRwxxwwwxo6qsaRJGqgDsvOTnWYLxJY5rG9/qp6 uhriZnoJHU+Q6AbGIdWwv1Hv99RjqaKl6vvtZd4Yo6NKlgdlEUWJiAF3BdowTjnjvk++gY7O zKOSKSMMFHcrrW9eK3RNt6skqK6Jo6xJM09hoatRLvwuQkLlXHLBlVMgEHk426dJKzpe4T+a K25V7UbzOzW0tJLRSlCQVkRODkY2yL695DJuDLqZSw2+ot3U/UJttQz1M61UM8Nqp6kSIN3l sfPjKAIJSzHf3DbGC4BQ+LHjFeunKe2dL2qmtjvX21F6fo6dzFUVdWqoMPuVIIok3A8MQWCh MkFQs4XDgBwZbh9/+JluJpOa2aD+H2Wshjrw81UsK1c0zhRFJMgjnlJQJvLL+BQF/mEZJw2q t6mh6i6WuFFTXajpUKVTeWsLUrSzxESkYh3M6guVIIA5IAGcDT94h/xO0U1Ct564utNPIyLW W2gpaeW3mQqjyQs7eXIysDkHcCAx5JDHTJ4RtaaHr4TUvUFxran5Rw3z5FSa912kIpEMbKUC B1JzkxgDbgE55cBDMaAqr28By25b9/gmCTSif7Tp09aPEK89Z2y10NgntNsp4vOq628k0Ykh xgupUAvglchAcbk3bRjUH6n6NWfqeaoprlbOt2gHNdYJI6tYCWZgsztwrgksOeTgnJ1E/jD8 cpLp1XcelaR56ultTwU5it9VFFVRtvQ1DIMBvWjyQlBwcBjwMaP6wrb/AFL3S51Ngr7ZST1U kxo6mpgMsAZ9yJIqyEbskDAJII5xwdAzhzA3qOI3150ldI5mtp3oPCu+27pn5G42K7SLcpBB GtZEW+UeSQAGUSkxEbXxjaMA7SHIzrXqD4bK9uoaW+09Jbqa4U0tTMzJci1RUPI0syIkIiCp iWTdkgtjAwSADG6jxz696QtlNQ2K30V4p5Z0Ga2Z2mSV+CDhlOziPBDgD1bgQRtQv4jdV0Fj tFAK3qBruasTTV9CwZhhSfKRElJZA2wbTGFI7DAVT0I8OI9ASVbZiNdFYPT/AIKdWUHT91oL v1JbGucsFc8NTWSy1Kq0saDyKjMZWXBjiIKIBmAgoTJqMdF+DfU1ttP8KudNZ7z/ABiVJEFP 08bVTLIqPtCvJFAWYowx6c4Mvp4BZ/6Svtwu9RaaI0fUSV0X/ma6ntsdZb/mQCEAxUSKhz3O wgnBA9sTW6dYdNWux09tudzvtmjgIpKZlmq6R4HUsAiSFDuILhQpZ/woeQNNNMN1uoZHnS1S 3iH8KPWksVqtFL0t09cZpKkv5MN3f/y/8oKdzGoVmbcgJCqdozjODqXeEPw/9V+G/UkVLW9M 00EkFqNrjr7dWmWnZvn3mKKko87afMLGQ+k7kUZIBM66L6htdRLXJWdd1FZLT1/kUkVbNSUn lCERyCPCRRh3V3ZjheMgMDgZmNz8Sa623a4W6p6rohFUwCaGjqEglZUdWyE2hC6elgpOSSME 8jLBIQQQSk3Yo0q56x8O+q/EHoero7ZDbLbVTzpBC1yNPUxL5SiFElEoOM4CfgzgrjeWOaM6 g8CFt3hxb7LXUt+oq6OxpSNXUVsFygX/AM8Khwhil2sxdjwOyDLFTlR0J1h4i1PRvT09RA1N UXBJY/mq25Wc0rSByQzQywkOGA9IXB9sEjvDbj4011ZN81R0cnyk0aGptoO6mwUG9d0myQcE 7jtzuLEZGCVhhcAL2rVE6QZrrQqG9UWSc3JrTb6alu7yny4KSooqpmDwwJEkYWGIrxsYMqsQ AM5+lLdeS3VurrNPJe7TS1yW+COWKOWSn8hssV9JVcAcfhXI3EkAYOvQCyeINlE3W3Ud7uF2 6Ot9zulJRR1dQ0Y+WBpaZYw7+sIWJ4c+kB1yd3Z/6+No6i6AMvU1hhjnoYENJUXy3xz1MJAB Zdzs26QrnDDK7gd2NZxCI7edVHAPNVuuT+g7W9X4hSrV9QU7xpfYloFjlaYNItsmhkDKcNEC I2bLAjMIG3hiLJfwUvNWldBbblQSxCUq88zzLLMzkSK3pjIP8t44+PZDj8RGrK6m6J6asTUN 6ipKG1w/IGqqLtUBqmOcK3lqyxKwKZWokICKAfmMbT6hrFZZLt0pTvW1t0pa+Jq2GH5ehRsx kQozI4I3Z4/4uyDA51z8fJM09IGWABrei2MkY0ZE0dH9MXLp20x0l7qIoaiSclJ7bK/luQq+ lmIDblWMnBH4SvcgALamkjme4bau4yNGKNXfy0cSKSzBufbJf6ffSl69r5baWRYZ6NaKpcKI RysciyoAAW52sid8kb2GAG1FT1dsu4svn3aNZI9orKiigmpSEGCqSE5DKXA2kNjkgcjLocfE 3DiO6NXptr5dqQ5gMgd4fUd6ljyChlopmutXNSyOAZJqaEJCTG7B3ZSODtxk8DIPGM6mfRdV Ry0nUFuqZIamoZklMYjIVow20g7u5BIz9Ny/UaglNBWlfkhPHdop4mcx1NMFMqKuzcNqR8fz iCDnv2+j/RU80XR10rmEVuqYLkaSVi4Yy0lSscbMGYtyCyP93gI7HTpeIQYm443Wd9fCvqih hLCCRy+6k/TVjjhoLZGKaBK5oI0aRIQGMhUBjnGeTkE6vKg2Wynq2kcpTUwChmYnCKgyT/f9 tVl0jLHVdRULxpuiDF8RjOMD8vrtGdSPxVvH8H8K+r6iokamxaZlR2b1iWRGRRwcA7mUDB7+ +tuBHULjzKHGHUNUys16oeobZDcbZVxV1DOC0VRAwZHAOMgjvyDqrfFfpujqep6WqqKOGYzw bd7xBmDAn/mul3T3U9F4VfDzZrxcfTFQWanfyl4MkrIu2MfdnYD6DOTxnTN17fLhTeHvRPUF 2oZXvFSaSkqaOLEe2WpCK3DdtrcYP1Ot2MiIY6tgfussHVlFeC5X8bvlKa71lFSAxQwmSXDf 4pAMnP8A7UTH2xnknRPhAgp+j7zWxgvI8SW9VKkFDMxYkZ4OUhkGfvp18dbIa64NVzXKlo1M ZdEqVkVV3Lu5ZUYZPJ5Y9xx30T0RQwUHhrbaH+I29pJqmatcpJI6yBVESEHZ9Vl4/wBdckOG QBbspslNENME60jr55FSljaI/wAtvWChJOB+mnK6yPd+rT5qlUgieEqR+Fy2CgAJxgD6/qdK YLPS1NfHI1ZQuxdd8Ydt5XPOAygA8fXSqnpHqa56sNTu0jl2YVURznk9m786e7EOeBG7YIGw 11gNSsUVHDR1tLLhEVJPMdnOc4UkLz9ThR9209T1jVNJUSSK3mFWLHIOTg599IvlZGZI0i81 XYF8EMNoyRnB+oBx9hp2qbYZLdJH5S05kjKmRkwqEjAY/Yd9dPAOGQm1y8ZG7MBShlZaaixQ WvyYzPT/ACcE0tFFGSYzIpm3IoIJP8wFlAycnbggq8t6Y6opjRrTXCOOts9SqsHPqUKcbW3D sDuGHHGcdiQCg6uYt1hcfIp5lgp2FPF5gP4I0WMEcc5CA59/7aaaJKyiF2rKOlkmSSlYTUyL nexdMtGOwc55U8NjPpOSeAWgjM06+911zvRGiknU3REtph+ct7PW2pju3jHm0/vhucYwM7v3 +pYaZpaeWSSPsqMpO7P4lK4/QsO3P7acOj+uqixlAgkmpCceU6ffBC5H5gqeQRj/AIdSaPpq ivNpqbpYJPnJHRmeh4Hl5fcTGOOFXKhT7Ack8lrXX1TulHQgnZV7LVNTQzOzGOGJTKxGSSAM n+w9tV9NTrSWO7VXmb6g0UtbPIqg+XJJA0hUcn8O7Gf8SnU76kr46K1Vp5kYIwkh5BOOCGH7 jB1DvFtZ7N0v1hcI5y8Nba6q5QNjAeOWJ2XH3BJU+4IOm/ypVs0lcX2/qaLymt9JVPU0kG1h JJGkaghuXwPxfhBwcZzz211n4SpB1F8IPVkTyN5D2C5VTHABCrLUuDj25h1wGzS0VRSPUU7R xugaMTDAccjI/Ig/trv/AOCmCj608MqnpWqlcrd7RVUC4HqWDzqmJ2I7ek1i+/II441b4Awg t7QkMNhw7lxZfOioBXwUttuNPcMpvknQkRpn23fhP07kk/TUday3Cy15apppaXzIVeNpouWj f8LYI5DDJB7aOtNTWUFQYoE3Msf4GPHqxj89TXx3iWLxOrbOhMwtkFHa42R+xhp41b2/xB9P ZnaQ0m0AbpaW9H9U3W3U9VRUNQ1PO0G+F5ZGCLt7kAjB+mO37DTtdrg94WmmraeCvqJCWj2T EShSMEswGCefce2q3jurPeKWr+XklDMII4owWAIwq4Hvroi1XGOo8BepqBJ6Z6mW/Q7q6OJd zoiMxBJ5ODyAeMY41gmjDHZq3RNaTYtJvDvx8uvgjeKOjnlqrhY3YM9LLs3wx52rhVJHcEkc E98c89YdedAdHfF30ZSVcM8NJf4afFBeIM4Kk58mYD8ce4Hg+pTkqByDwP13crevTsAo62Gu cqxklXmVnLFm3jtj6dhqa9O+IN18B/Gu90HTVRJcOmVqFlNMu4qIWVXDoW5BAbbn3GOchWCY 2PDekj0PMdv4K1RyW3o5dRyPZ/X0VZdfeDHUXhx1NcOnOpYEtVxhIKNIf5VTGc4kjfsyHBw3 1BBAIIDAorujDG1PVT0FwjOBU08hjZFIxjcuDnOf316T1tw6D+LTw8hoq2sjWujG6iucIHzF vn43AA4JHbdG3B47HYw4h+IrwevHhV1jVWy6xzCjfEtsqZT5i1iYALq4UAtuySCAVyMgZGt0 c/TeHMJEsBi15JP0p4m9XdXdMVvT96vtfdbZT1cE0UdZK0jxvlwBuYk4wG412T8D/jfU9f8A XVf0LVQ04gsVsEdLUQxlWljDrEwf1YOMpyAO54OuIvCaJxZKiaYIYmq1jUgYJMauzk/U/wA5 f0A1bX/h59ZTWr4j6SiwJIrzR1KyvtGVdQJcg/fyjkfkfYahijzkgbLj4aRzsbLrsGhWvYPj 16Sp0jo79ZrrZq2NpIXRESoij2OygFlIYYAHGzVk9M/Ex4d9VUhraTqW2syny1gmqhTSKT7B ZQh54y34R9eCTxt4m+G8UXjL4tS3e3vQ01PVXqW2vIDGtTUiqIhEeSN3Dk8ZGEOdUJPZjbpB HUROJDHujaIBlL4yVJ7ZHY6yOwEDiQxxB9V6QYmdjQ5zbHavUjx8IHgB15UoUleotMitOjkq 5fao244xghQe+AOT31AvgwsotfSXURaR2D1caDfjPG8+3/u1yh4R9EpePDHrfqOW63GkNsrb XRxUMFQI4agVEriQSxn8QARSAOxGSNSlfiC6p8HaS1UXT70Tw1NOauakrqXeJHLsoO4EMOB2 B0p2Fe2MxNNm/DsXKmxQdj4HOFCj9CF6GAFRkDt9dFs5GNcn3X4xbr0D1XW9PdU2CGrnoWRK itslWxRiyK5CxyjPG7H4h21YvRHxVdHdX2a53Oaqls9HbGiWpkr4mzH5jFYydqngkHnPHvjX NdFMzVzDXdr9F6Zssb9A7VTmWUy+NFMg5EPTMrAfeStjB/8A8Q1MYS4qIvSfxDtrm/qjrRuv PE+tPTtbM1qp7HBTT1EI2x1YaombaH4YICCDtwWKEdtSu19M1dPH8zU1tUWIBZXlIAA/4Rga f0Jdl5Ggga7dN3w6MiUdZK7qgdCS7EDu+dWxWpRXSJ41nUy8bZacLJImCDwCrD2xgg8apvwN tT3G1xxDJCxgtxxydXxarAaOPdGpHtkAAnW84Tp324rx/wCnMR0fDQeZc8//AMiqVayt0/fK 2yxx1FDbb1GLpahUxGJopAwaSIqRwUdQ23HAKjj2vDo3pqs6ystJcIZ4qZJl/mRyTNIySA4d TkHkHI76YPEXpGr6g6Veemic3u0v/EKEAj1FR64/vvTcu3/EE+mpF8NF8hudxq7dFNFDb7jT rdqIzvtQPkLMgIHGDsbH311DhInAMl1A2XAjndwXjLmM0ixGo7A/n6/dKvDD4QxaOpr1cD1L LVG5VM1VIiUqxrCJZN2M7mzjkDgZx7Y1bN3+GjoRrG79QyVtfS0jitMstR5PlNGCdw8sKRgZ 9ycEj31bVktiWyiVEcSM/rZx2Y4Hb7carvx56vTpuyxpIivTrHJVyq4ykroVWCE45G6V0bPb ELA8HS54YImmYt29he0wWGOIkGDiGkjtR2l2+/b6LmHrSSy2utLdHQxWZJKgTVdLWRTVc042 bVV3efEZI2MQibh6QW7grKahgrLXVXj5tKOz0yqZZpcFt5Xf5aDOGIHckrjuex1XNNSVt86h pKKkfzLjcpxEjSHAaR25Y49snJx251MPE+80VBe6ToyinIoenl8oZwVqakofMc+xxuIx9d2v KFz5rkevuMv6b4bho4sBhW06rvk0DTbx0A8TyUIj8WbLV9cUdhgmiqIbgrCiraWpFQrzKQGh kCDCOcjAywJZR3PPX3hl8PMFF8pdOplWepH8xbWQGjQ8FfMPZiPcDjPucapH4VfAnpCfq623 CCx0itbJWuoZowzRVCjy0QN3wpkZlznGB3wCO4gMDGuzgMLFMOlIsDTXtHP+l8g4i+XDyuw7 tCND+FgKAABwB7azjWdDXpFwkNci/wDiM+MNT0b4UN0baZHiunU0UiVEsbbWio1H8wAg5Bck J913++Ndck415TfE747WHxg+Irqzom4rFb7PQVq289QCQJUQGkWTMUZY7AGmeZeQdxkXP4Rq jtadEBmsrguts0lghguFO7SwSIDKp/oJxx+mRpTbOqavp+501ztdbJb6+mcPDU08hV0b6qR+ 33Bxq6/hn8NaTxj8XH6V6hrJWsltqJTW0lLGNxhjXjBHJUuADtycc8DJFr+K3iT4I9BXuzWa 09PdL1fT7TGK6xU+2vrBuRsM5jxFtRguVilP1HuDYhzA5irzgHTkpx4JeNMfjf0eZ6lkS7UG 2O50aQARqTnbKpIb0vtY912kEfQmb0VFZqYMaJaeMVDFfMoQDLIfcBkOSftvb8tc0+E3h9N0 X4oU3V3TVZbpei69FgqaKillLrTuADIqyoxwHAkCltwAKg51f978Z/Dnw2iaOOsjmrJTu+Rt dOXqZWJ7vnGCf+Ig68LxDAvgnLY2ktO1bLuQTB0Yc87KS2q3V1qgMNEJKSGQ7jNcqmSrmz7B IycL/b8jqRpsoreZq+o2xRKWkqakrGvHcnGAP21Q9y+I263KZorXZhaKd0YpVz4llAHc/wCE EfTB1Hq3qE3yC41Qvc1xvNPSu0iVBLRyoQAVA7L34K65v7d5cM/5RjEMsNZqrc6r+IDpTpmF 1ona7VI4CUw2RE8f1kdvyB1z74jfEr1f1XXQ2yz3an6fpJ2MMsUB28njBlxv5+q476aOooEt 1PQ081R/DamGPKTQN5scpznErfrgfrnVS3a0Vl/vNfU08SpFAyiVvMVQrdhgD7/TXbw2DhYM xPmVy5sXI+22rC6bqH6NpLn/AByLzK6Kba0UUjMxC4Y+rnIOffnT9Q+MFzr54apa4UNlMn82 KCQr6SQCgI7k9v19tVewv8RW8XmKZ0iZKSUsQFwOBk+5+/vpTaej+t/FO81VFY7DLSUlKGch 8QRMMEgAdiTjgj99a4cNG9znyOHeQfkEiON87ssYJ8FdvUXxPW2CiuVn6ft9WlmrUVJJJpo1 qWKkFSQu4jBz79sfXGun/CD/AMQPo7rvq60pe6OXpWoeE0rzyVCzU0jcbAZABtJ5PI/XXmZ4 ndJ9SeF12jpL9RfIzzRrNEGlDBkAGGBHfn2POoZ/tFOWEgdI8ZJkRiDyeCfqfyA7c9869FHH Gxv+rQIJYy3qPFEf0vUbxH68gqvGq4CllqrnTxuZ9s0ILKNqgENxwPbPsNM/U/UklfV07yRi WmSRCSgVC4GcY+o57ZHbVD+Afixcr34YzKaasr6+3S/KpUQHcXQjcu845ABxyewGrOsNbUtL 83cN1A8qEH5WVSY/p6GyPodeK4iZBI4O7ffvVbYS0jRSunropmPlSedDIPN2N+JW/wAKN3H6 5/PUVvlwuc8dVb7VSx1N0j//ACc15BMi9yre35HW9Vcqu20vnzVsE0MhJhnVSqyS/wCEsO37 aqi7+IT27qrZFH/55gUnnklPlg4/4fp9ca82yF87y4an34LQ+QNAadE82O4npm4VtfFQXShu E5HzETyGJIpF/EvqPqyc4+2p10zb7pc7yt4uU1NQW2ow8dM7Eyh/b7bexxnUIoK6LrtaI1HU lrerpWHn0VSyyDywc+kYB3fnpLcfEpzfYKS1SUkXlkqTBF5aOM4xg5B0csUkpIYKdWvd6qmP bGA52wKsaGrrZeo5knv1DbaRZtu5VQySAdiox3xxqQVFxpnmdY3juUco9FJHGZGYD/GGJA59 xzquemFkLzVt8r4KRWY7aOIDzGGRgg9vf21NLN4myWcU0tHd4qGsMjPBTySI0px28zcNoB+m c6jICXgD5AJjZyb+5P8AaoS/1MlfXmN/MoKdZi0MLSbi3PbgZGOfc6db3cbheum5zBBJ8nEw ghljjO1T/i3j/Uanni/4lXLr2op5btQdL0NZHMrtNbrcKe4VA9keRpNjA8dx37Y1U9f1LWw3 yqNPRCjiqAWkp0lTaCOMHnGfyzr15DQAItQsXRvJNhXD07LT1HhLRdO3S4RJVx1BrKOtbZs5 DEpv4IOeMA5+3Gon4vdN2y3xwXKhrHanZE3mOrWoxJgcqeCV7dwCDqtbd1dX26GUPFLGsrOK eQqHTPuCvOe/tpNduoKm5dO1nnwN5sJ9IiXEY4HqGO/761mUlmQjuUigIdasW20dmFjqKvqW lmqxULHDDcmGJIPVkhie25QcEqdVRfeqobfeKyHp0SyWdZD8u85UuV+pIAH9u2NMVx+JTq1O nJ+lTBSPRy4WWdYSZnH9IZi2OPbgajtF4lXuWJlhpaRFiYxkbMZI7k899bOhpjRWyyOe+yvW brW2p4F9CLV2u92u8Wehp/JqOkL3O8lPXv8Ai2wyEM6yek4BzECc7EzkUl4T9e2V6uS63GzX 3p+krKkVFlsKSSQxx+oJUmnk9Lv/AFkqrBQSfQMgiwzZbklSomrKVy6/hSn2jBC5GCxweM8/ XggaxW9G1FzglgrBRyg+tFalbZGwztk9LBtwOSCCCP3OvDO4+XG3N+af0hBJAVD9S+Jl36l6 trJK+9TW2yXCqV3+atlPcXSJGKp/NEi79o3LkDdjdjJJzEuq77WwtT2u7Us1FI0HziT9HVMs L1EZGUaNp/NLx7Q5LoAvHfg66ej6BZDFHG4VEg8ldlGsZcZLBickjGFOFK5JOc4Gl9u6fqrb aFoflqGsolkmAd4B8wIZBkrvxtALsCwC/wBK8g5ZtbOORVRGo7/6R9INqTd1H4UU/iP0rJLf BBcqiGGGlNbW1M1JUvIiKVLwslNFPKC+5ZGyCFVWQ4BNdeKXQ9+qrRUT3frqop5Z6qJaRZrf 5SV8zPu9FQnm04bA3iMbi/4NqEgi8BNcaekFDbKqotdC3DCOVTLKMDh32EY9IA2jcFAAZfdk v/SsXU9PR0V0gjr7XDmYUdY5qDLUsSr1DswBLbNqj8W0DjGSdMdx6BxOp8NN+5HcZBtuviub Ld0jdbxHR3qnkmht6M5jmqa6kgpJjgoxDSFN4XdjhsA/caxPS3zp5oKi53awtMC6pFbnjqhj GVLeVUvt7c5IHJAzg6vKi8F+mbNVG4Wuwvbq2VXT5q1TtCxU84DJIvB44+3bGmweEZonTyLV STJLKDNNU0iJUIMKW/mU5iZgMsMuJWJU+nGCzY+Owu309FOjYf8AtqrovFu/tNLittFNVyRC jlaKCSoM0eQ3csrDOSCPoTydM0/ipK0j0twr6O7PcncIIyYjIQBkNGdyn8PdmHC8Anvdd28F rCGgeDpSjncqZJG85huJJKqWMT5z6gM4HfPJ42t3hXQWiaB6boLp2oQCLchXy5WB3ZG8wADG AT6T/fU/zcTiNPmEHRdiqJ7pfqG2Ggfoe4ChnhHy7PAr04jXPlweY7HahKIMkYyo57gi0Dpi yWWkpmsFLNV7YqeSWookd6mQRne6kM2A2GPOPb3xrqua9dQVNmaavuF0UrtWSipp5KhmyuGX aDlxjHBGBnnvkwK/eGXStzPlVPTk1YxAXz6ehNLLGQDkqT5ecjIyAeCcZB5pvHYzu3TxH0tU YXWqFPSvTFbdpa+hjaKKGUM0HyqGNJwoDLseM7l+xBX1EjudHVFmvZe22XpJUqbvcq5KeGlq 49wKuGaTaqbMYxu7hVAPYDInPUfgD0ff6d1PTfVsjbJqeAs6wpTvJj1xgktuX04PK8Hg6k3h 94RL4OV9Nd7JUQxVNvpZKWCpnUzSL5ijzJD5MSys+BtDdh6s++NzeL4YtsGj2afYlQQkjrHR V9buuOtelKe7UXUV3tMFgmta1lA9eonq62alVYTMMTKUlZolYAs7IYl9Pct0F4b9Wyllrqt7 9VR1jN5QW6xNGF8x5Dx8uq5YAnJckjaS2VBFTR9GV3U1mo6qu6pe3xQtM1vgihiFRShmYu0b OrOu8+ojdnlCSCOEy9GUd8goaefqFbisKSL8zcYJ46mRip2s0nmqP+LBAJDYABOdZ38Ri0Gf Ub0Cfsn20XQ9+StCz/OX/rGx11t6wKWu/n5qigrEFZTLPHI88kckUbCGHb5UXEeDlMlizNmb rY73U+KUsitHaIIaRJaiwyQ7KC7tvmUSCeNM5RHXLALhtpZMEYp6gt9T0jarJD0o7WWcVU3k VMtLGoMsqS4Us0fmcepssWHq4xnGpxS9U9eUFbRSXpUuCwxNA0FlljimqZWYl55zMqRsQETC qCMu30048Rwj2AOfob0PPklaClIanqm8XKl6ea3dJtHbqzK1MCRiavhlL7ZdhBBKRs6pkr/6 WTx6tOydM0lwoFrKGV7jidogjUYLrjJYjO7jnkd+c4Oc6iFu6lu7Sz1dZRJSVda+J1nRZG8q OQtSqzxuAGRXYEBD/T6vTp/W99SSw0dfQ0j1tRE0iCBKx/LkhJyWKtiNXUj8T49Loc4Gsboc DjNG8tBR1HkD9UbDmFA7JVP0XLvWrjtc8RjypaJGR5NwAPckHOAOFJ47d9IYaBRURfMfM7Yo tg3qrGOLIJUgAMqkrtwVJ9Y2q+TiIUXilc/mb2bfNWSLLULcK6tngMUdLEkQVUpgyLukwE2h 1G/1EBdu7W0fj1T19NNNVWm9U4SfazTUchdmON3mrtGWHBLKMbSOPfWN+AbAA6N2cjkSAPl+ U1ji74TQ8Qrz8Ib7W3TreSgiqaae3UMGZFMZSYNtwsjb/U28MDwABjGT3L78UNQaHwO6hI5a f5aAffdPGNNHgetHcOqLncKd45ylqpF82CTepWV3dVztXkbSTx/UBzjRfxjXNqHw2tkKPsea 6RNweSI45HH5+pU/fXuOGB4hYZRqTZHmsGJP+yistRR+KHiTaelYHWTpToVIJ65l5FRXhdsU XbsgDbsHuzKRqY/EBQ1tT4aVctspRV19JVUtVDGylsFKiMlsDk7V3H9NbeAPTFD074Y2mWkq zcZron8Tq69iS1TPKAzuSeSecc88c86lfWtoa/dIXq3JEsz1VFNCsbnCsWQgA/bJ10sUS4Fg 5X68z75Us4dlcO5cQX7qzqq8rPHfbZ0/eI5QYnarplRJgezCQhD2Bwcgc6bbvR826CPp+JqK gtqPAtJBO8Ku/wDMMIZXIfDyEEg98kntq1zPLN6mlyp7FlGSDnnI9/7aJeHfWzODBh5GkO1e 5LZPI/M/fXzM8XcBeQepXVLiNGj7qq+ip0h6jlrT035FVb4pJNoedCHYbEGJWK7vUxHb8Gec aYbxb4LQCZYb7Z6Z8COTzAVwRxhioU4JUZB5/XVyVloxJDOpjeSN2Yo8xUcqQe6n69v+WlcV LAsLRGlEBkARpaYqgK44V1HpZftga0M422wSz0KUSS0AjXyVKUT0trrrVRR3KvapkoY2kqq+ GF/MLO0glJR8/hYKAR2UcDOdSzp6/Rm60i1F9oJqeN0llpko5DNKgJZ0wGzgqj5O08H6afpu kLbdYVe423ddAGQytSRxp5YKqijy24O1V4wR6O/bMjssM/TdBJJR1NRQ26ncSzfJRIZnKjOE VgdxIXHbJHGQNbP8rGHBjCbPZVaoxlLqc2/fiqvrVHUlmjoFv8nzdNiKmeDcYHZjkRsrf1Ac KeMgkHsoEeounxaorhi5xXQrCEdYq9EMcnmJyqbCV4Lfi5/EO54tKtuMPXsHzNRC1I8crqGq 6Xy5ztY4bD7sKe47d8kDtoqTpGkmFTNVUtJMlS4EzSUyYmY5b1lVBJyA2Sfz50scUia7I9p0 7K+tqhK15OXfw/6qttNHUVNWIY2+WLvtmFJcPXKSMDJYbcjaBuwOFxg8FJr0vX11lSG5Wh6q rVpdvmyOsjSYBLB0UA+nH4hkgnBDDG2XdOdF2Hp2skrxabWWKr5DRUcMhXGTlVYek/cgfbSx aC23Zp5rrRUFTcpFdXp38t4SrMAGJZFKyGJQodB6WDnDA4LRj4JNjXjp+UwAOGpSW+WKz+LN rqBHIlrvygJK8gLLKMDlwrDcSOzg8gg8jVQ+IvS0R8Mqrpu4TVdreTzqTNfRnEakIZRFsaTj btcEEqd3GSdWB1LDP59OnSHRoipoJGR657tFHWQAHIQRM5RlG45UkBuGRgCGLrUVYvUNNa+q Vqaabb5kM0VSVkKjg+Uyk7jhSGU55Zf+FhtixDZxlunJY/13WoXAniJ4I9O22+dPMepunaCL Z5kUbUtdUmrC4OXCUwAHbPb8R1098Mtus3T3iPZrTZZqGanp7XXwxR0UNREAzSUMpJ89Qcl1 P/3DjVpJ0baOmrnNba223C5xSl56SvadaxcZG6JWYKV2A52k5wTjOCdb9LQUMHWkVZTWryKm hiFGjVDiOWCJh55WKNAVO87WLMx7jHbGsrceemEL2kV29/cjyx5HOaffqvOKr8NKey9U3aih lo5Kqnu5gWB6jy2VFkwyuJUUNgjGB3OeONOvXHTF26i8QOoqyjsslTTLc62XzkYYm3TELzk9 hyDx299dodceCvSjdd3q6zdLXSesa4y14niqIWWV3k88EKZEYDLfhJxp9unhn4avdKKW2eGM l7lqqQpXvU0EkrkPkmQAGQmXcW9fcYAHGtQ4hGZHAmiDWv2pJaIw0UuZOjPAfpuwVEcFQsVf CkkTyN8tKzuGZwUGHAI2qrkg45x9czXr3pxX8MaUtSRUBqKh5I6ZgI2dC7AMFXgAIgUduGHc 6sy3+Elj6Uhpo5Xu9pSGJBJBUKYpQvO5njlIYjAADkf0tjgac7H0/wCH3UfU9RWXRamDpuFV FMKWWQs7xknYwQsRvBTjjsf8WsbZXPJcSa70YxOGbcQkGbssLkvr7wlg6dqaKae1Vlvs01J5 cElUhEVVIIuCrYG4bWPIyMqPfu/QeHdv6w6/vl1q6upiobVa0kFIyqshWOkg24L5zknByCcA Y5Ous+p+uU6i+VuNw6Xrr9Z0SNaPpl3p/NoXBYM5MqFQMBMAHcPV+kO6x6L6b8QBdZ7L1F/D L3XE28x0M9S1NSIH3M8o/CZFC7PSdnI4408zhzTUg9/lF1Vz3aegKjw3rbRdOloLvbp6q1Ut bW0Tr5iySyyeUfOBwV4BYEdtx9iRrpUXbpLx5sdb0D1tFFNUpK8ancEnimXcqTwtz5blQWGf xK3IZTzC6vo6puPUtPbrJeUjuFTSQTTJSVUrrbYAQd0ityHJIxCcZJ9WAMGz6Hwwt1ptC22k tdRPvmapapTLVBqG/FUPIeTIf8XPBxjHGgY6QkOGrvt3/ZaWtbkp23vZcxeJPgA3hH1D0xZK WBp7NcKwOlxaIJBLLIyAoRztIUL6WJOMnLDnVr9JzQ9JdTdOSeVT0Uf8QhgSOniWIb5WCABU GOcnPbIH051b1tuM9NTt091fbZKqhmlVIqqpiKJOVAdXU5ysinByMHKkr2Ooj1b8Pt5rfEPp O72+uSSwWWsW5vI8mDIVljwHVVJL+X5oGAF+47a2D/aNAbG4WPC4dmHklkzWJKPoKpVX8Sdu pKfxlv1VAgjW6Q0VTHKOS+aaNScn2Lq5/X76qu99K2rqWniaWNHqeyVJXOBkHaQSN68HKn9C DgiRf+IilXQeLfhL1DFWz09oryKd6cNlJHgqFfzsg4YMlUoH0Cn66bIpadHiQ7gOWQFcBu+M /fI/trNiYzHJ0gO+q7eFlE0XRuHw0NVG7LYk6X8C+orazQivqesKBZYI3JdESJ3R+Tyjerac exBOQcQHrToOt6hngraaRI/lLZAFjkON6nex2n6j/UatLru2QSx0N1TdsjkWKXawUBG3LG5B 4JR37nsrvqV9I9E3W4+H8U0FBUl6B1poj8gJlnT1q5D4ycE4OMgY/Mad+6DIw873S8xicJl4 oyx1cpr1/tUD459OSSeJXU1dG4qJquv2LCY2TbgIAGJAHvjg+x1cvw9+BVwMd2q77bDS0VY1 PsomDKZGhcush+27GByTyTgYzb0XhbV9X9S1k3U9FIlDHc2qoYag+souDCo2ngE+s/bV42Ww RUMUKRwpCMYSJBgKPbA9vy1fTOmAjZuup0LGOzlVF0H0WkPW/XNc8CCKGehoI41HAaOmE7sf vmqxnUnu1M8Fuqp9m2NIXfCjuAp76cvB+gNwsfUtydhMt06kulQjAf8AppUNTpz7jbAuMe2s +LVN/B+grxL58lLHFTFWkj5f/wBo7/iwE+vrz31p6E1Q2CQZRRcVX3wzUrS2+VBGX200BJGP 8Tf9/prpKlthEQyM5441yP4CtdK/ruwUFrqnpITQNPODnYQkij1ISM8bh7HBIBG7OuzoxJEx URlwOwBGSPsPprq4doLV4j9OuMmBawci6/8A7EpvltuynaRPQ47Huc+2qR6Tp7p0t4hdW2iw 09J87Txi7WlZJNhhaTO+FV27cZDKASAAV4OBjpOCjEjAN2ODj9dc8dd2Cu8O+oKrxPuELWel p6qChnppKoz7oJpivmk5PJkeI47BVIwNXKC2iEv9R4Z2JwdRNuRvWHcW6+p2HfS7Y6T6mtvU VqppKCdCfISRqYsPNhVshQy9xyrDn3U/TXIPxS9arffEO5W2mnDU9AIKdzGQQWjVnPI/4pyr D6xD310h4SWODpixXX5MB2rZ3uHy6yZ8tpACUCn8OXEj+wJcnuxx589ZWC/eHVFQw9WWeTp6 vq6aSsliqKmKTc7SO8z7kYgZdyQDgjKj21yeIPcYQ0Dc6+S+r/oANnmbiMRQeGWB2uIH0Fq1 PAFY6e53rrCqgNRTdN256iNWYgtPIpCgH/2iQf8AzXVUXSaepvwrJJTNU1FQ29yD6pGbLN+r Z/fU2ut3g6N+GijpYyzXHqq4efJGUyTTxYwMjsp8tDz7yHVXwXOK5RLNENhXaoRT2Axka5Dw xsbQT3r6bh8XeJmmJFE5R4D8kld1fB3awnSV7ujo6y1FatMC34WWNAcr+sjD/wCP210HqvfA Cziy+DfScONplolqiMY5mJlP/wC/qwtenwrOjha33rqvinFMR+7x003a4+mw+SGhoaGta5aR 3e5QWa11lwqpBFS0kLzyu3ZUVSzE/kAdfP8A+Lfh74hdK3E9cXOimktHUs5uaXSmxKA0zGQC THMbndkBsZzwTg49rvi6vidPfDL4l1TyiHfYqqlRz7PMhiX/APSca8V18YOuL14fjw/juslV BNIIGmkrRE704UBaYyyEKkXpAIbOQqqDjjVEGlojoNJKiPT/AIjQ0PifUVF3o4Kq2VlHFQ1V JBHJsqFSJAjMiyxGRi0ascuoZjntxrfrjxHofEOpp0tdHFYKWFzkTCJZJkAbA2xRxxxjBI2q vJYli3fTv1f0Aw6Rt9onrOmJLwtcaxr5/HaZUooHjTNKkaO0jqrhjwpwd20HcSZR/wDQ3p66 WnpC9QTVFxs1e8lNUpbaiMGWuTf5qedOIfKR0QOCVPLsBnAyeYgVdJYBc7QLpL4Desuj774V 3W49W0FFLc6KveF/OBdmooqVpI0CsSoJdcEqBuAwdUDfY+oHrnu3UNTDPS3VWqaCsQxYNOXL IFVCfL2MWXYQMDgcAaRX+32zpPw+vV16KE9htN1qrRtpKqtM70s4StFRTyOBuz/LU8js47Aj SayQ0986fgg6bjp6WGSoQMzgtIhMQUhsnOQxf68DjjXOnaaq9F0Yg18LmEa6G+5Odk6hNzkR GrJJI4TvaPB2sRngn76mVlulv6at9xuCUK0VdMqwsKjczS+osGQYxkDj6EaHS/gh1jIxqqiz RXCjiTPqkjjeQAdvxKcHHuPbTFX9YdUWmp/hMVuKPV4W3bozKwYnARSeTzwDnXnXtLnERVXP VCInwm+SVdVXK03e0QyJampZxB5LRruXzSf6yv1786qO42iWit9TPHUtTVCyZWkKn+Yowc7u 2ftq2Ll0/wCIFAxpLj0PNSVoUlalI2YMWGdoySvPJ41AR0N1fNLDcZrDdHt0k2VmjpWeIP74 IGM5H9tbYS4DLY9Vk6N/YkXR1ddOoqodPRxAGskDl6sthMY/c41b1k8WKGw3iWjm6nttFPGx jSOZ2CenK+s9gePftqDUfRnVdynF5o7ZVywToKp65qd0VDnaAhA57dhrPij0103aumbbW3m1 V8/UVZOUeJaWWITqMesTkABgO4IY8rwO+lSRsmcGuFeC9BwbETYN8jmAajn3dnqmPxvoeo/E Uy35q6ku0VOSq/KzibC8cAgn6aq6k6W/hccn8UgLmanMqMpOKc98nB7nkcgj7HV4VXjh0lD0 dS9HWDpqos1uijJnMsv86SfjdI5xknjgHsONQyCtp7vD8squI3O1iT+NPodb4nvZEG1QC2Ym OGbEdKSHOO/MX5qReAPUFf014a3WNI6dVvFWohepwnqiAIKNjjuRqZWDxUqKarmo6y3ua8SA PPHtPpHfceOfp7ajHUvTMNt6F6QobdI1XBSoQu9N6vM5LyJwcFlJIxwR+urJ6Y6Mt1da7fM9 FdKe/wAfq80VEPlyjbkEgE5H2PPGpNh2y5nu5ry0YIcG80k6n8SYoIaNLWzUMcj4nknkLK+e xK9gM/TUB6s60rqC9vVQ01Gkkn/80kW6Q7hyRuzqwfEbpG03KSnpqS5UqxRp8xtjYxsWGf6j wO51VPUMNtpqZ5o6udrhDlVZsYcY9/rj6jXDw4hJoN+SOVr2vIKZ7N4k1dNU1xliCGUbHdEy dp78+xOkkF+pqe8IbXuNNEAVfc25vc5B9/8AlpvtlOlXKlIlXU1RJ3bEQ4LZ+nfGnCWljSgq pykMFejjy0RSSy9jz/oddno4waA3WbKXaK++j7ta77Y5rtceqrTSywxei0TtM079sMuY+Tz2 DaknQsHhzfIjU3TxDkgnmhc1FPBTCOaOQE8JuUh1wM/U5/QNfhp0vYLh4XUr18EUd5WoQRVM kzxSzQnlkK7iOOeeNUZZoHqa28ugK08LyJHN5gD434BPOc8jSoIom2Q3bxWvoXNDSTuup7D0 h4VdUSVFLTdR3atuEUiBah6ZnBHG7aDDkY51LbB8O3SVTV1kq9RVSrEFamk2xozgk5Zsx57c 6prwm6ZpYbbbJpJ7h83UvuWUyuceraSrBgVGPvq6+nKZ2q7tAK26TmhIRUevnMZHPqxu47aN 87R/EAe+9b2Q0BbvfopF0z4KdEwdQ22oN7nucp3CWColQxhWUguoRFI5A99Vd1j0D0x074n2 23vcxJapEc1Txs0qoP6QhyT9QQxyManIpY+naz5hDURmoRVdIKhl7Y9auT76r3qay1gvJlUF lUM4UPveQE937/v99cmTGtdmYANaoqAZSQCSqS6p6O6a/wBoXiianMT1JDTTTFEEQbAyd3uv 6jWLt0H05aq+VIunTUU0h8yCaKvkZZE7bgQD3IOmnq+pt8VzrpamxyjI3pHUOUiHtnHBP10X b65qOkj2UYEUoEkaRguqAjGAeMcg8a7kExydcX6f2kuja92mi9JZJCSqlB5Z4L5/DydwCgE8 g/3P0wQzKcN/L3hslo2IwM5Hccnn6/XGliwJJMWlZk3D1Rspxz2wftnvnHPOthEImikOCrjc oJBUqfbv78ZGM+/vr43aWR2pFHSxwyCbJO5AdhYkSclgO/bP/TjjRnmCOclI/JTlx+I/TAJP OODwSe2ffSlXAZipDsxJZuxY5ye/5jk/6aJNLAkwkiSNXRzveMbSDjH9wf3A4zqF5dodkNXr SBG0K427wNoYngDbxnnn255762jlcVCh5QN+SJY02qRg4BBIwee2exP0538mHywFjUZxyvZe O/1zwef7DOtl3QozTRIj7s42ghSc4/vnn9vc6oOAPar0SKQTU8ErLTipl2giNHxvI4Ygk4z3 5+me3shoK+rlk8+q6flpMStFvjlWUbQmA6gdgdxXkZ44znh9qMOCxLKWO5S47DHb7H7e/wBu 2t/LctJvTzMjgBWAXGDjGPbH3/bRNkygirtG002knQ+YkihWYc7iO4IzknI57e/5a1+a8vDI ruDllXKg5APYAjPYj8j7d9HNDCwy6lMkKzq5zyRzj8sDnnlhnvrHlw1S5TnZ6zwBgn3OP/d/ 10G2qCtdEUs61cbKiFNoIVaj8RGePf3H3+g/PIopZpCCNvrPoAyCBjIxnsc6MMCCUOu45HZG OSozyB+Xtx20fJlXJxIzBmAJA5Awwzj9v8u+NC42bCtwJNpE0LBzKCu8cE47qWOP8/751lKU ZRlkO5jn0jIGTx3z9wDo4szvOGRPJOxlHAKnLDk8jueBx9zxrKs8Uyb0aMSNxuVWCL3559ue Dgce/sIu6VVSxLTb8bv5gP4sqPt/buPf8tJhRw4DiNVZskugGQc9844/6d++lT1MU07wKjtI pwU2bQ3HdSe/GP8AsaUpU7WYSbFcDJUqGPP0/Lnv+WivLoj3TVDa4/MGYI9md5VIVBJwMHtk 5x9+w0ZHbackB6eIgr5bfy1z7ZGPbHGnKCFTITFGXIwTuAKgAj1MSMKAT3PHcZ1sJo4IUeGP zHOP5pAABxk7VPPvwWAP0CkA6a2yMztAhy3okYs0MEaNUIsMMnqCRplpAccjg44x6sfkGwQN 46Tzy7RRrRwsPUyRHDnaQcju7YZxyezMMgaepel6q3rSVVc8kEFVH8z5gk3OFPJJXd3OCcn2 78naUdWpNQI4pMKUykciYMYGckgbhnAycZJHOt7o5YR1mlvdzPjzr33ofApK6GoUbYQiAuUX OTz3JPck5GfyHAwAE1ZQx1CGNkmXCbd0ExTA7ELtPf2z34050lA9bF/KdZFLA75MLJtOc+nO D/Sfy5JAydZqbPX0MKVXyFWx24DRUsj5Pc7dq89ieO+dI6KYgSEGjzV0fNWX4H28WqwXGeHd JJPXxxsJ5Wc7fTnk55Acn9PbuGr4j7ZF1R1Z4YdPTwCpgrrq8k8TcBokCeZzn/C5/vqe+Fdq kt3S9IKmMpNLLJMUcepcnAPP2A/fUZ6+ZLl8QPhtSIwMtBT19XKnvtkQIp/eNv8AvGftHCGG PDQh24APytYXm3pi+Gi41XSVy6o8NbrJmex1kktA8mFeandt27aBj+pH4/8Azv73zIMo3OOO +qB8d+nbt0x4k9J+IPTturrjUQuKSvgoYDMzRjOPSoJ9SNKpJ4yI+xxm/IZVqYFkAYK6hgHU qcEe4PIP2Oug85gHevvvSz2rl662v+F3KvpEMsMNPM6JtwFUKxA/MYH2/bSGMIpaJzMxABVv Kwp5x9CTx7Dn9dS7r2kSk6zuuxMfzVf75ZAx59vU2o+YY92Au7By38zBwADr4rinGKeSOhoS PQrrRuBaCdU2+VVRyqEigmjIZWLOVZc9iOOSAOxwD9RpTU0JiqSYZKnyyO8iQrj8vxH99LI0 KbTsjwB7HJ7k5/y/7OsRwAKu0qyt+Hbkgnv++soe2rDQVVDmmiWluZnlkj+U8ovuiRY3Hpz+ BiWPOMjdgc4O32OtZHcKimV4aanpaog7iXaVBt7YwAeR+3309mORJRvQ7TyO4x+f2+2j6ahq rgWShppKxjjeEVmKnjuFzjt209uIJ6oYP/qFZBHNRf5avCnzDEJ1ByArFTzxzkfbJx9e+k6w X0mNJHt9XEozsZZE59xwW+wzjnGeM4Fl03h91FdA+LU6wDOxppBHnAHdWIIyftjT3QeDNzlX FTPSUqkZBQmVh9iuAP13HW9mDxko6sPyr6pDnAaZgqegpbhtkV6ShMjgspjnkVE7gcYy3GDn K88aE9LdpNjE04wMYjDBHIwBj7fY5+ur4ofBCkjcGsuUs4HIWGIJ+hyWyP7/AH1Jbb4ZdN2x t6WxJnxjNQzS/rhiQP0A11YeCYx4pzWtHfv8r+qV0zW6AD0XKFwpb7HKs1DS0JqwfLmmmkZd 6ZOFI91GTjJ4JJB5IK6k6XuHVFGUWzP8w0qyz/JQGQhihWNlde5BKkSgkAKw9J3AdeQ2K204 Ait9LGAdw2QqMH69u+lMsG8AqfLkH4WAzj/prqRcBew2ZAPAa/MlX+4A+FtLlqS19S9DUHkd VUFRHZJ8U6XSGfbKgIICO8bFo2JPDA4JOeGO3UZsvgdH0rfq/q6fxDrK+3w05kFBdKfzpZXZ QnmPU7uQqPtwEyAM9u/Ys0MNwp5qOsgjmjlRkkhlAZJEPBBB7gg8j76o7r/w3qOgaWquVrHz nSaoXraCdstRoMkupJG+MDJIJyuM+r+ntug6NgD+sBzO49KVRzO2aaJ+ajqdH9FwXiqvfU9d f562rRFmtMV28ugjIQIDFGGRlyFBOT3J1KavxW6f6a6VnpOlqeGyJNGyxVzR+aFcKFMjAZ81 lVRyXz6RngafPDbqnputgiqVpbYu8nybpBHH6vY+YyjAPtnsSCDtOAebfjC69NV4uU9oLj5W gpViCOoPqb1OU9sN6FJ4/wB2wPdcrkIjZ00ddbmBv5rn47FNwUZMgN3QF1r6dibKHwtsfWd6 WA37qLqK81BZitvjWBp9xy5kZwxbO7LMzY7dvewbJ8PdX0zNM9u6TvdB5yKsji8wRh+Mf0SZ Bx3wB31NfhMsNLZPDi49U1Kok1XJJGk+cBKaDK4HsPWJCfrx7AYoB/jivNw6kmhpbbDUwSSO DRtIwZcE7TG49ioGQV78gDPOYaMa47n3ztJwPD8POwTPiaDvzO+vPmpr1zf38O7tBbbv02lA 00InhllqGnSVAQG2lA2SpK7h39Q4wQTAJfEWGuuooKDoe01Ly+lal6ONkeZt22MFgMliCT9A GY9jqYyw3/qZ63rHqO6W239MQ03zdTFcGbFE0akL5Y2neHVnRsYJ3KQCyINE+F1FSda+T1j8 v5UDrKltgaFUEaMRukGMk5Chc7ucOcKG2rlDWs+FlAjfQa+QC9GyIBxaR/xSiih6idAs97hp 6fZlaa20AhMbcZG4u4POf6Rnvreaz1swSN73dC7jkiZFx+yDTxGFp9xlcBjxgjg6jnWBqL5Y 7zRWmraOq+WdPmIHKMkm04RGUZ3A9yO3b8R41taXDV3zUflbZDVx3efFHrDrTxBtVjpb5cor Td7rHHTRxFZGWmx5gc7hn0qOWP8AhLfbXSnR/jlT9O9WVHR/UNZDJGzvDTytMEaVcchtvIbH ZhjPsAQdVp4WeAVZ0h4jJ1LXwh7PDRSyU8voV/mpJY1KhA27PlxsM453ke+NMF88IevK2evn ltUU9dVTSTwTNcwjwrJIWMQXPbbhWBJByRzk6p4AqSMgEfNYeE5mNLcfdOJ53l3o7+VClCvj 68KuvI7J071FbGe8eGdoqJWo0EQ+ctLTOuBPjLeUVjiVGJ9IVVcK59TdDKLhDSVEEp2SqHWQ 4XKsob8v+z9ddPdB9R9X9DdPf/xjbqWrsLL5UzRSioRICNrGUbcFOSGPqAB59OSGrqT4arTe KxL10ZdIKSwz7Xa2GIzLTnjHlkOPR29Pde2cfhCR4nYABRby/C7kFQ5n5ra7mue60KbfUUVY vnUcyCOYcBRGxCsffgAk/lk+2lXRtL1Fc6u3WiOtqWNM3kyxwVGACo3O6DuNwO4AgZ3Dg51c kPw5tId1RdG8qQBDCaHbkMMEEFz3H1xjt76mHh34KUvRVc90M1XXXH5YUvmTlArEDHmBV/rK +jcT247d1QvMZOl39e1DPLDNRB6w+nP7KZ2Gz0tkgpaQJ5UFMihA2CAR3bcSSc8gk8nPfS7q fqin6S6XvN88yGeaippJo49wxLLj+VGCO5eQoo+pYflpdBbpmj2xoSSPwE4GfzPbTF1V0ZdL 7c7FBuja00FSK+oj5/nzR806/wDtR/5hBzlkj+hzohzMPVbY7VjkeH7mk6eHdp/2R6HsPT8p WaqttBDT1Ekf4HmCDzWB98vuOfvpB4w+GyeJnSMNsMi0iCrhqfPKtIylHVs7ARuOVxg8cn9Z LR2SpaBDKxicEZw3P5Hj39/f8jp8paF9qbpMupHHfH/fGugx0zhRZusMgjILc2h0VaeHnw8/ /T+6/wAepeoIrtc0oDS0yVlIYowxYlmYhye2AB7frqybWbvLSwmvCw1b/wC8SnlAiA9sAq5+ nv8AXTpHSS7lwwZfbORjWyQTQSn/ANQMePqP+/rqdHLnDhmbpVA6ePNJwkWHwMHQQNbV3tr2 b2j4ZKqGImV9u3+pJVJP57oRp96MSWpuiR/OyriFn3Exn6dgYh9e+ozWXaO10dZUyszrQI00 6xpuO0IWK47lschRg8r9dPnRVSGu1vIheJXVxtlXBAKk4Oex7ce2tLYZHDK4k+dfhG6UbgBS Xpzp+W11FwkNRNT+bWEB0CHeg5UfhxgFiP01zP8AHz05JWi11k1uF9tEVqrZa+MSxU9TDGjw qskEu3Od06jaVdTxlQcMvU3S+75G5rOx2GtnKM39I3HH7HjVKfFn1dJYqHpigrKikorFe6mW z3CorYTJEpYRyJllOY+I5DvIKgj1ADkBNC1sbi2/Un5HRdDhuJMeMje46X4b941v3suTaC+U PWNhtsNlq5apKSFaJLfXxmlrVdfS6fLOcuQRg+SZFGOSNN8nT8FNWy0FTQvRVrJ6IWjMUmT6 R6eD3I7j30+3q69KN1Vcn62uaWyz1UclRQymNZILjtHpKNnZMhCnJR8kleRzqy/DC2dDTdW9 G0Nr63q6v5+rhlobVaZ3ippFRy7ZieSXChUbhduMZ77SPPZWO6tEE8t/x913JJJGEvzXXPb6 f0u5LTQRWu10dFAgjhpoUhRF7KqgAAfoNK9YX8I1nXrQKFBeLQ0NDWDq1FyV/wCJ/wBSy2P4 XKughiSV71daShKyOEUKrNOSSeP/AEMc/XXkdZLEPE3qmwdBWQU1ruVzlEP8Qusfy8E9Q49K rxmNFxtU4LMWJ9IbavpJ/wCKxLH1O3hp0VNdJbdBWvXV48qm+YD1EaxRwB0U+ZtJmkGY1dhk kI2OOU7B0He/DvoWjs3UVhlt95p755tJcmjMqNGPLHlxyKDk7iCFB3ByOAd2lSuLGghao2Zu r3Lmy8+HXUXSHUtXQzWGeK62GrZLhPsBpkCPtyzuDGFJRgGPBxjBOrKvdytPRnRCw9P1Nur5 5ra9bTVF2i+YLCaqjikFMJEQM42sC7xg4WUgDOdR7xwuVDcPHfqurrbNH1RJeJtlIoeeGaOQ qqD+Wuw+YDgAMMZ5IbsSPE6vbp/rGXo+EmgXpm3RWaU0o27ZkQmrBfAdgaiSb3x747aZd6hK IyPy7e/7Vh/E14q2Lr/pfp2Lprpej6ZhSq2XBKRFVJqiCFUQDbgYRJMAgcgj6aL+GWyzXWju 1TBVpBNbZYZxDKDtlR1kV/sD6Rpk8Ha5L54fXqG42azVdZI0YtVwu6M6Qyxw4ZAoYbt6CMMf 6SVbHAwh8FOrHpuqv4XFQb6a7KqBYg3mwTBiBGOf5ilmI59WADngg55A1zcruS2RBzP9h2I/ C6x6i66LU70ctwrYJhGkSKmx1ZdpB5xkHkc6gFn6brqK/wBgunmx1ENvqln+XqUYkoDxjB5/ I4B1MenfDmunRRNba6nUZkw9LICh+mTxn7alzWw9O0qz09jqalWzCSYznkc541zBHhQC2IjX vWoPv4k5yeNNputcoqLkV9LLIj0D5jwCAdobnvjjUYt3jBF050zZbZTj+OQpHI09KqSQGmkG SAA2dx5z35xpjrLccPts0tLUMdzzFOTgcY/t20w1rVy+cn/mKeVDhxIjD9+P7aBvDMMfhJ9Q gc89quXo2+UVy6KtNFFV3FVmiEAjkSWLeV5Y7Pbv376SeO1P1VW+FN2Xp6Woqb1SeTNRQwlm disg3hdwByYy2ADk9uc4NNEGVlZK3ypd3DJkyAge2nrqPr5/DXousv1dW3C9TxwhoLfNUyGn DZAXzF3c5JAx+eg/xTxKHRv07wiY81Y0pcOdefxqz9XVcN7t9Rbby+2WeCqTy5AzjcGZe4yD nn66vn4U/h26t+IHqGC32OAxW2NlWvu8ynyaUYyf/c2Oyj6jOM6jfT/hpYOpPFOkr/F7qa59 Py32rWprfk7d56xiTEhG9XzH6So4jYJnBHpOvQDoHxqs3gp19Z7f0fRGDwxtSSWz5Kjw8lXu 9T1WWYBm3qCCTyu7H4tejdgy1vX5fNYmYiQlzmb9vvmrL8XfAvw68H/BLprp6agFVFR1ypTO 8BqJ5GfLTytghskBmJB9lAHYa57r7Z0uC1TZLElDBtaKmnpmYmoO4f8Ap4O04z3PGdSjxr+I SPxWuEV6udv/ANlrNb1eGhWurFaRwzZMrgAKjkKg2qX7fiOoHQ3RqJWvNlrKYwFg0wqMPTzY /wDzgbGcf4hgj6jS8ThzK0dGadXl771thblYM+6Zesekun77DLRNabhAVQ7lgIaTPfd6lI/Y 6pCLw2pqd6hfPqUD1Jjp6avjxIeRjO1cAEHka7B6W656a8Uq1BbILYtdTgRVtLTTLIyEn0sC vJQ/U8+xHbLv1x4fWuOKEmgpYpHdWVthOTuHBI+3vrwz8e6CToJGZXJ76ldmrVc79G+Au2p6 pmmtFHdWpaNJYZKKvMCwsc5UErywxnv9NI4PAa4UxsshtEMNXVVagTNWq5YEbsMDg888nVq2 7omrreobvSWiWlorbXPGrBCZNjYJGDuBwcHOpH1J4P8ATlLafnLnbbhUVFIFE0lFXzKqtnAY KWyB78dtA7Gta/U2Ty8vFNeWZG5BqLv7Ksrz4fUtQ9qt1T07XxSRQuzVKiKbzRgjkK2OCRye dM9h6HstioaGnraJUiQeY9R8qrzFScfhUFjjIJ9+P11PKDwW6C6zmrfloeo5noXKkvWysn1x kt/lp4pfAvpLoCjq7zb7BWxVECec1XNVzBQoHOdzkEY9iDrQziETKZZvbb+0AcHU54199ygd B03bqC//AP4qs3m0VTIW+bts3mJ+EcvG2GTdjJ+51KbNXQwJcJ6+GqtuwKjGCGSEyEf4Qk5V h+QHftqeQUFqrLdE1P09cYmaMSR1UEowynnIP0+mNZtdtho6CemFFel3jehq6iZwpzn0qGI0 Bx0b9AtjXxUDfyUYlrKHq+kT5S6VXzEal4meJtzBRkqA2Tn7Zzqs5r1Fe7rWpFc6OVwcQPOH jZWB9QO5cKCM8hsavCvv81JbK6KitE9uIRmjklt00iwvjG5cKcZznPPvqH2m33a02KSWveOs qHmDiSNIkMhYZ5UxHn7jGfc6SwRb1RRSMhI/H/VQ3U/TV5r+oRS3ivsRtqxAx0f8Zp3xzyRh sjj7+2pHQeCfzlHFJRX8RUpX0R/OxOEH0DKcEffVoVdBeZZYblXS22RvL2tJV2pQ5yc53LHt +vvg/bGiXsvXU+JKTpyOamcZR4aKREI+oEZ2/rrqDEsAAbosYa1q6TFPLDRmWXckLv8AyHeP CuM8kHsT+/8AnrXbKqoUO6Q5YgZO4jt7E+3Pt347ZZbV1o12ttIiyxiKpimljWdRKdisvls4 B/EVKuQTnLHsedOSXGmTyBUHyA+wb2BPlseNm3uxwCBtBHp+2uZ+pf0dP+njG7Pna+xdUQRy Pjy15Feb4djxxEuZVOH0/pKvIcwx7F8wclTLFn1DB7Hv7f8A4Rrc08ieqNFEezBIUhVXIyRw B7Djjv8ATunW40qTLG1eiVDb2SnndVdkBALqCR6R9+QeMcgBQ8M0YkwF+ZiySCuxQctgcKNv cjgdvr7+CfCY9XCl2jFIxECoWPIqvNjRdhaWWLuzEAj3wQMHPbk+/IzC0s8Yk8mSmkCt/vE2 uvcc7sHHv+RGO+ksUNxqWqBWUFCIY2UgxSvNvUY5YFPQQRu7nkd+AdLVjndVVx5bvHuaVRgY 5xjC8jB9hzzqEMyit1WV5ABaVq675ysspUjkLGODznAB44yB+Wfy1hEZ8phmmH4SuW28YJye Rzycn/D31vMGGfMyjfXZ24HYD6/T6gnjGixMxkyPl0iHrZpY9pVOTkke3Y84xx99Jyi6CEN1 pyKLtBIESCRlyQCnIz7ZzyPpkjjBBOlLvhcqhZnBBATHG8HHb6g9+caPim3xoWUR+j1kKwJ+ pAIH1z9P1GiKmSN2T1RtKG2qMAYYjHY9x24x3PHHOjo3QUc1taIRxsyLHMqk7VXzO27sSD74 OMffP7lyQmOZAIw6D8ex1UZ/qZQcE5HsM8DjUvtnhbdeoFlH8LelpmcuBdGKrn7KSWB4BGAA OTkk6ldu8GKV5pUq7sXqFCl0hHAP33E5OMc4AP0+nbw/BsbiBmbHp36fVDmiGpOqqgW5llMb x+Q0bDDFhkjPbHH04wDnP5aTf+Wp6dWmrQsauFdweQCQNx9xgkZP0B5AHF0r4K0KyLI9yqiy jYqEIFK5z2B/T640ml8FqUVcsgvkyGUFEQomyMd+AT7n6c+x41t/8PYzTq/MflC2SK+5VNBQ rvhhnZledNzDdtGM7SCSeCpGB2OAT2Gjaikeh5mZod2QUIG5sAnaDjAX0qctj3IDdjdND4a0 dpjhVa2KSFSxG5ArMSpVdxH+8VScgN9F5AXBiJ6TtF2fzhcJqmpjXY0sUke4kHgkgntgDn6a 1v8A09M1gLBbjyJFDx1192qDmm6UIeqggSKGSdaaQqWipBtLLgEBiWOScHIPqOG9hp36YsYu 13hp5XFOrKsrqrq7FDuwAMZO4I2Dx+E+/GppQdJ2eCLNVTz1wHCs1WYwFHZcKBnvjnPHHbjT tQ3K20N3qRTiliqmQEUsc6AxxduAFBALDOSDz7+2t+E/T7hIJMXWlaX9f6KLpG0coKhPiFVV lL1HI0BeMwQiRl2qQr7W5II/CAyg/wBIABx2ww1M9NE1aj0cbxNM4V4ZGjGA2fTuyvuvG0bQ BgDIInd+6ftdyu09yqq2qpZKhkGEroURGACqVLQk54A7nSGO2WCNm82+moRiQI57nAyg4xkf yAfvjOOO2ONFiuG4yaaR4qiSRZuhqNjtYKU2iBdqH+THWRI6ERMTgRyplcchcOgJJxsz6V/M 6W0KXOgkP8PlaSWUHYKRvMD8fiMandkfcD/PUrZ+mPJkjNytski4yzyUrugx7EIO+B3HsNF1 Np6TrFwLtR0Qcc/LVUIDfo4b/v8ATGH/AAWIaQ9pAPcaP3CMOrtU/wDD6mlS1U0sskssksCS s0srucsAOCzHj05x9/udSN7LQS3RLm9DTNckj8latoVMypknaHxkDk8Z9zqGWjqu0wRLFT3K jenhjWIsKhWLFcAcj9c/c/mNP0XWVHMAEnpX5xlahT+uvoMJa1gbeyySMc52YBSHGhjGmP8A 2ppmIUy06seMeevH/f5aU0N8grKk00ckckkaBpCrg7fpkffn9jp2YFKyO3pVp4jWX5rrRXj8 xSaQzt5Q3ZKbhyv9WdyqAMktt4IzqO0XRd/uMixx2meLY+d0qLCF/U4yM/T8/pq/Rs3FsAMe MkYzrLMN2337nXnZ+CQ4iUyucRZO3spomIFUqdoPB+4VdXipqaamhU/zDAS7g98YwBzkHv76 mNF4S9P0sZWSOoq8jBM07D/93A1Li8dPE8jERxrkk+wA7/5awlUrOFCv/wC5htH99a4eE4KD aME9+qEyPcme39CWC1qRBaqYk59cyea3PtufJx9u2n1I1jUKqhQBgADAGttNXVl7PTXS93u4 iE5oKSWpERbaH2IWxn2zjXTZFHEKjaB4aJRJO6dAMDGs6q+t8XquDwzsN8itkcl+v8sdNbbY JDteSRjtyTg7Qg3E8dscZ1ZlP5pgj87Z520b9mdu7HOM+2daC0t3VIzQ1S128Qev+o/Fbqjp Toz/AGchhsEVI9RJe6eoLFpo94CtG+Dx9hj6nUtPTvXtR0TWUU3VtDTdTT1CyQ3Sltg8mmi3 IWjETsd/AcZJz6h9NDsop5oao6lj676J8VeibbfOum6mor3JXCWmW1xUiIsVPvXlSxJ3EHuP fvjUfWj6kqOmOmOt6nrW/wAlRcOoKRI7Yk8cdE9LPcVVAURAxHklDy31B4JXUV0ujJo1mXGS GByGXuD9RpHLcKbzFo6tlLzAooZTtl4JKj2JwCSv0B9gdVP40XO5U/iT0CaFmWkoauKWucSO FCz1dPTIpAYAlt8mNwPCPj31Z3U9dRW2x1M9TDJVJuSNIYWCySSu4WNEYlQrF2UBiwAJByMZ 0LgdwoqquXglH0nZaJ+hW+Vq6GCOGW2MBHDX7UClgBhY5CATkDaxzuAJ3CpesPDGxeL9zguM tfWWK5UCGnrKMQBmQDBwY2KlWXt3/D7Hga6S6M6xkurVlFcKeWCrt1T8lO7FWAk8uORdzIAv qSVWBAwc8hG9AI8QvC6k61K3C31Js/UNOuIrhGu4SAZxHKv9afT3U9jyQcMkBo0LHZ+OwoZo 4sW3JiBY+irpfCiTpfwOovDWC8Vk9uqEqhPdqaRY6lw8/mso9LBQTIykYbhfrqm7Z8GXQtor BWLS3Wap96qouk0cg47jyWjAPb27auSz9RVlsubWO/0yU13gyzU7N/LmUnHmxN7qdvf7YYAj hV1j1y1srLJSWm009ZVVsrNKlTKtOlPEjxLISdrEtmaMKoHOc5A5KWwGTVju7v8ABa2ubC0N rZQS2/DX049OpnsqXGCRT/LudbU1sDD7pPK4OeMcalkXSZt0MNvo7fDFBEoCRxbUjjUYAQD2 5z2/LThTeIlnu13rKOluHmVNCJDKiK4UhH2SbG2hZNjeltpbYxw2Cca5v6r8Y/Fb5/qK2rde kaKptEdHulp6GceXPUMViUNI7AcF8ll429hxpgwcbtCTfvuV/uHA6K+f9nZ45fKjfygpzNUK Bxz+Be3PBBPIHbk8rq/TkNrSIJIFRE8ilpgh/mHbnavJLNhWOcdtxPAJ1Ax4uRU9rBSsjEds qbtW1kMcaP51BSCZSmSuF9bwDPcqjck5zLOk4L3U2h6ifqs1l8NHFBUJXUMOKCoZUlbasW0f gkBKEtu/lksMaMYSKqKrp3nVLa/pLbTLJVGOVlGUgH4YzgZ/M8Ebs+5AAyxYxbbFTossrBSC Il2pkk/TuPfH9tQa23Tqvqzqm/wRdcQQ27pq+Q0U8MVlg/8ANxiGCeaNmJYqcSsgK8gjP21B uuvGGpnvbz2p1nZ6l6G2UsI2tLIqM26Ut+GNQrsxHOADySAGftYyKGiDpnXZV7y2+ONi7MxI yBzjUAk6QqPDhqiv6Wp2qLPIWepsUahjFk5ZqbAztzkmIZxklP8ACWjpnxkvlgtSzdfR2yAv Kwims0M8oeMRh2Yph39IDlm7BcE7c41LLn4r09BNUqKdZ44bxQWsOkxDMKpYcOOCCVM2cdiq 9wdB+2icK2KNs8kZsHRKrLXWrqi2rcbbM0rNGDNEjAlMjIOD9Rn9u2lJomZfRGUzxk5xj29t VJ1j150wtDWdbdEX1ahaStjpLtDSqxGZc7HRSMlncKo2BkctnjDOLK6G8QqTqq2qVUwzxP5M 0TrtkjccFWU8qc8FSAQf7qjLYndHM0dx5FaXwiVnTQHxHMKQUlKyquGYj6g6VJC7uyjPtzga OSpB9sjHBB1uXVhlQMnXRBB2XMWFgOwkY7aPhdEddv8ANbHCrjcf+/zGmKsvn/48jstHEam5 ND58krqTDSxnhTIRjliDtQcnaScDnTzHbqySNC10MYHqJjp0/bnP5aMamlE40s5dHPkuoU/1 YP68E6WpllUq2COcZ4/751Bqvw+oLjdbbcL0xvVdbqgVVJNIogMUoYlSBHtG0A/hOd2AWyQN SeC5CSW5RvH5KUUyRK5P48xxSbvbHLlcZPb741qa0CrQGzazUW01EvywbC53zlSATznH6+/2 0/WaKNL7ZhGoUB2zj/2N/wBNMFnmesiqMbWd5nbk5bGcZ/L/APBp2t1UtB1BbArb1UkMzHPd SBg/31p3aUvmrJsKlLbGduwvudgfqxzn+51RXxw2OSfwXqrtToGktlUtQHL7PJMkclN5uQCc J5+7A5O3A76v20qEt1Mo4IjX/LVJ/HJG8nwreIAjJDLSxPle+BURE/21yJWCRjmHmt+FkMUz HjkQvOHrGOzr0fZ7p0xQvXdG19OtNdbXdP8AzMEFwUbZAwzmNyACsqsj4PpYZxqQ/BX0j09H 8WHQ11slZNbYo5KwvYK+V5hGTSThTTzY/mKCclZArL7F+TqnPCTrqDo28V1uvRnrOkb5GtNd aZpC3lgfgnTJzuQgH8vy10t8EvhLXWH4u46a41z11NaLVU3WgqRGoWpjcLDG4IH+Gdsjnka4 oYQ4OYeYXdmfmjcJBsNF6gKQRwc620mqrhTUFO01TPHBCveSRgqj9Tqq+sPHymgtM0nSFGnU dcEZolllMEcgHfYSMsfcDgEdm115JmQi3lcODDyYl4jj5mtSANe0mgPMq3CcDOsBgRkHI1yp /wDWU+I9VcLPdIahp6ZC9XaKmJqbEZx6l2khh6lwGJJBz21dvhTdoaq0S0tPUSS0tMqhI6hz JJD3yC5PKngjPbkcDA1ngxkeINRlacZw/EcPf0eJaWn7HYg8weRXDv8A4nnRHTviL19bqK43 GWlvdu6cM1uhVgIy8lQ/qbucYiI4HvnPGuEvhmr+qKvxmsPTlrrLpWVlyrqWKKnileVfQwIk KE7W8pVJBYYXbnjGvTj4lPD3p3qTxuj6gvPiRHZ6Se309BF09ZrZT3C61syPIcoZI3KfjUAK rdieNQy737ojwFtdbPa3tXhRUV8LGe63Rv4t1VW5xngsfKDYzgvgHugPZ8zgAWvNfX8/bvSQ C+sgvx22VdeL3QFEl5+Ia42+60Z6o6Riprgt9mpopqhHamz5azMuUkxGUDR7NuVIBPbzwEqQ WyOsMtPNNUu8Egedd2CM7nGcjk9zwfr31e/jl4+iTpis6Q6NornZOnLvVPX3G6XWQyV99lOF 8ydwAuNowIkAReO/GKKrep6unt1DQib5ulgBmekrqdAI33biik5JBAGc4zkjH1GOzZ5E6I5s oocwNVN+jL8trtXT0UcIrIaaunEsceOVaOEMVJO0kruwT/loyK9Wyk8W6Kr6frpelum3u8VZ TVFRF8y9CqynDMpJLlcsSNxB578HUO6Uvkfzk6PT09BHODNBHUOqwr6SMbn4x2wT7r9camPh BffC60X683XxEprherdSKlHRUNrMX81pElEkpRirEKeVdWBU7c9xrPLbWvdRPcOd/JMfIwxN aPfJesVpvNJfrVSXKgqEq6GriWaKpiOUkU+4+n5ex49tKV2HJYYz7MONc9fCX1jBdB1lYunb lL1F0HZJ6WOyXSWDynKyRbnhb0qGKEAE4BPc99dD5mfkRduPVyDr47ioTh5nRb1666+vahzM OwWop4gCuxCF4ACj+2sVEFPOzmWKN2PJLqCT/bRrrgHCLwcd/fRcisrbQAeec6y53XuVdtqk z39LbbLHc7lNRU2KSllqGYxrwFQnOcfbXMnhj4YT+MPUVj6TqD/JkZrvdHYA/wAuIh1jIPs0 zRLj6E47auP4iuqIbD4dVlA0vkV11jaJFQgsYhje2D/TyFJ/4tb/AAHpHNV9XXcxKEhFHQwS OR6eXkcc/XEWf019V/ScMgiMr/5HS+weyglPRwuI5+/okPiL4K9MeCHh7/GL7SUlz8Rby89L 82KppoVLsWmmjUqpXauAOOGYAk9zzz1RW114hp7JYInFyqkHn3DBEdupz+KQk8FyB6B3yM+2 rL+KDxKufXvizPaemLbN1LWUGbdbbVRI0jVNS2ZJyqj2D5DN2Cxd9QW1/Cj8Q9Z0kKGKwPZJ LqzS11fc66np1R275UMZABwoCp2HbXvMVK58mQmyEMIZEyjudVzn4kdZUFx67itzytH0x05A kFLShyRI4Hdie575PPb76aur+uLtdrbTNUNJDSzgJaLLHw0ik48+RR3B/pB7n7Dky8+Dd98M /FHqKwXmKhvd2szRb/lHMtPJK8ayj1OFG1VYbmcYHP56kXR9FBYZq3rS6VCXOtVmH8XmQmnS Xt5dImR5rDtvwFXHAOAdYCHAkbK8xerg+CnpKo6V8WjbJZWavjs09XdcD0xu7RhIcj3XAJ++ R7a7iktqVIHmMZATyjjcPzzriT4FrtWdQ+MXVVaFcU0toJlL5zu85Nufv+L++u40Vl3AYOOT zxr5N+opS3iDgOQH0VsLhYaUzP0baldn/h8KOTnciBTnRFT0PaK5t81MZeMNmeRc/sdSECRS qiPJHPbj99ZBO4ggE4/p153p3jmm9JINyVEKbwzt1FJJJb6y6UHmHcyQVzsjHt2JOnmOzPTQ yQvU1FXFLGYnirD5isGGCCG47acy79hwD9tbrOTgMeRwMnH6aL9xJea9UJebsHVE0NN/DqWG GJIoqeNdiR7NoVR7ccY0nagUXf8AihQvJ5flbFY7MfXb+ul7yY/qIJ9geNaJIVfIlYDHKMOD qum7yrMpJq1pFilXdDTP5aIw5YkgE5P6aCyUsyiQUEUn/EEU5/XGs8hcp3U8HHOjPMDevIP0 JxqGbv1V53VodUVB8nECjUm5SThABgZ+300YHip/TAJaWPv5cTNGv6BSBraORCQSQw+m0axt hBOc/pqxiH3oUPSv7Vzn0ZbL34L9b01g6ovVdfqOujp4rPVMA4kYwgVBO1eFjKZJYjbHsJzx q+rPfYDMKZqhArs2zc+N+0gMVH9WDgZwQMj7aYfF7pmnv/SktW1T5NRb99UJTCwcRbNtQilB uwYi3AIywQHA41C/Dvw+uN/6irK+5W2qsdNSmEUc7TstZXU7qQiEbj5KKsbKBgS4Zf8AdsrM 33+P9RcM/UH6Yf8A52QiRvVNC3Fw1a4CxvYs7XmGy86/huJgxwlwjdN+6tqJ9lXQPLeNiqpK yEFZcL5kZ5ByTn6+wGCT+p1PBK8rPLOJMriLj8IJA2jjsCTznvwT9MBVDtDLIxEzYQB+3PY4 75/XHGDnuIfKZUDKwOSxJIBAI7Dn25z7Zx+R/N+a+a9iM17pPPDHJJE7xukiO0igHAViMbgC BjuAVHt7Y77TxVOYhFLFBGUIYOvDcHawIHBBwe/J4yMZ0p2mLYmCiOAp2sTtGV9+eBj7dh7d 94Y4EXeVG9UAdlJC9uxP17+/1ydWJHjS7RW4c0nioniISNoI6fJUKg9OOw28DAB3c4OcffSm GhFVVK3neRvb8DshAyMZORyBkcDPce+NbecjVK+YXHpOA65J4Axjvxxg/wCXfWsTUrgRt5jS byu2JFYZwCThT9O+R/ri2u62Y6jsV5RzUquFR4e9G0oqLv1EblUlTthpX5lwf6dmT7jndx76 jdR490dpTy+jOlo6fco3VNwOZM9uApYkY/4vc8fVPFLDvLRxeTKGACovqJwAeBgk+w5POBrF NVK4B8llKKATtXK8rx6WI989yOPbXoRxkR//AKWFrO8an1ItCyOIayW7z09AozfPE3r/AKkc 76+6RK3/AKFsppIlOO+WVcnsc86ij2m91U5nNFUmpY/7yr3K59s85Pvq15CY1dghR1wQWHrG cYwfb65+x+ut4jmZC0YWEkbXG4nOfw8Y7ccH7/bWF/FZpfjJJ8VvZiGM+BgCqZui75UuGlt6 OwU4JEYOOM+pz27duO2j6XoK4+YHa3QRsmMNI8eRn3GG+n+v31alJAilHQIodwNqnGMf9F1p LStLMynMe9d3cZ27j7HnPHbHY/fSf30x2Cp2KedAAq4rfC6puJlFUtOskkDQGTzWDqh5O3Cn B7YI5BxqJ3zpXqfpK1CvjgS9U1J6EoTOI6uduEwrFSjeljKdxByGGO2Lz8pJJGBP80/hRRlu /GDxn8QH3x9ONHhNgRVkV+3CneM7uMEnB9/0zoo+ITtdZFhK6Z7jV15KrLf0LYesoKqH503C Jf5dXStShXQFc7JI5BuGQcgkcggg4Zc1N4heDM3hr0xYFS/Vdw6bokeklklkIjRN/mQNIEz2 QujOFKkRqeMnHStTa6KVaenrIUroty1EMs0YPky5DAKRjYck7WUjn05HpBaPEDpH/abpG9Wt Ekklqo2aNBN6lnVwyDDZRsuEXlRwvP11oixxEgDicpIsaH8K48RJG8PB7veiQeG/R3Tc/h/Y qyntsANRSQyiQAIspPDthTtwThgRngg886lEFks8QKRW+mG1gwLQbgw7djng4/z7e1R9A9f2 ykstJTiKalrZBUq8tNbajy4mjkB2Som47XaUdufWCfxqotm39U2u+RARzylg5BG1gcqfVglf yJ4GOCR2APGtmZM465bNevogkmeXEXzS9BaaapM5oKSgaKZIYXMEQZpSVVcYGQd5AGfqNKaC opJpaeBfKWWWeOJEK7F3lgq8bSPxFe/fI9u7fa5mq7rUTyENCuyCnjfDkYOXdscjcSo9zhBk KcgyHptYJOoLcZQImhdZVLLg5T+Y3PcZRefsBnvoICZMRFFe7hfmR9lndI8Akrhv4y76erPH qoqaZVNvoJXtdOsDMNyxFldn9ixmeXkd1VffOi7dYae8W+KmG+eYgP5lV/MlCEZGSec6ivVN zpKtIa2lcxusbVNXFUA5ikZ3kL7vdWJYjHYAA88meeGkz9QWC41EdL5chogI4pjgo0nG0t7Y x3+3tr2+Ic9xsdq72GiDY3WLoDdJ+ivCSjmrqloIHqZJdiM8rMxeRmOdqscLncoB7c84GvQL 4aegqXofpKoipadacSGNZAoAEjhdxfAA77wozztRd3OQOffB7pRLfS27bAUiijVVjkOSvowA T9VUIv8A8s9xx2H0FF5VhB/xys3P7f6a7vD4tHSuN8lwMfLljEI05n6p/KAAnAXH3xohRUYJ 2oCxzkscgfTt9NKH9RC/Xk6DEtwv15OuvS8+kBmlikYOFkj3ElYlbK+/PBz9fb8tUjWeFd0v 3xO0viJdK6rHTlhsqwWe1q7RhqyRpVmcpkZxGV9uS6jnYRq+4UCIdq4GSfz1XVi8bKPqLxiv nh3BZLlT3KzQLVVdXViNIGhcDy3iwxZwxOBgcbW3YIAYS2zunMdV0FObHdWvFClT8pPSRvyg qAAzL7NgE4B+/P1A1C/iGvLWPwZ6onT8UtOtIP8A+s6xEj7gOT+mrEAxqnPinDV/h9bLJHII pL3eqS3q5/pJLOD+6DTWC3AJZIJ0FJm8AoqXr67Q9RGQyUHSlJH0/aKZ1AKt5MZqKojkgvlV XkegHIBJ1ctR1hYqTqCCxTXihivU67orc1QoncYJyEzk8Ant7H6aq7wbtdJ0T4q+I3S1FElH bw9HcKKmDf0vFiQgZ7Bto/bVov0fYpb+t9ks1BJelAC3FqZDUKACoAkxuHBI79jopDbrVKB3 DwMkl666h6qtnWV8sFbffIFXFb1p9hEUYjQDzImIwAT399K/h1vtx6k8H7JX3avmudaz1UTV VRjzHWOpljTcQACQqqCcc4zp46O8Trb1xP1TFQ09VTjp64TWyokqVVVklj/EUwxyv3OPy1Fv B260fQnw12C8VzbKOishuU7DuVKmZj9ycn8ydBWhtUircW6w+IS93VpZJbT0fa1t1OpjHlLX VH82oZXxyyxLCpGeN3tk5R2yliq/CbwbpGViJ6i0Sou4ZLR05n7n6eUT+mtPCmKr6d+He69U V4Q3i+Utb1NWbFITzZ0aUAAnOAgRcZPbTo1DHaaXwTsyzLOaapUBsY3pFaapd2PzZP3GrOiJ NHWXm19666uk7hqW3XfpygRUHqRYKinq3Zvtirz/APHVq3q2G608kSy/LyK8c8bsm5Q8ciup IBGRuUZGRkEjIzkc83joy3dT+E3X/XlZV3SW4NcrlXxLHcZ46YrS1LRQ7qdXETER00a5ZSTj OeBjoHqqjjuFonie4SWiMgSCvjdVMTIwdWywK4BXJDcEcEEE6DkqKqnqqC59WVsdjWzWVauO aSS40lykkFBVyeXG8U42qDMNrOcOMBom5zGraU3Oar6Yt61K3usvBszWu3R1TVjKkkkskaym eNSEcyRzx4dt2Mg+kje0pj6Bs1dJJS3C6NfblUymvEktT5UysqCL+UYSpjjVH2YXuJG3Fi7Z mlBbaeGlVPlo4slWZFUYJUAKe3sFXH5D6aHUjVDS5E6pNmrbpPS23qNrvXVtNaYZ7zd6x2mo 6t5a1pCyb1NPJtXaIV2AO6KVAJGtKPqqjvMVHTdRRLMlPcZqe2XoNsEs1NUlSrFGBBLQq+w+ lhtPJGF6W6xtdNb6aCNaBKm3kPvgEW8xL6Pwpj1KMfh5P+EcBdV91NFTdSW6SzUkdurqLyw8 0DuCPLOQvlgH/Ev4xwCuAdw9K3xfzYacmNdWh2VTPPfaPre61ErTV9MbVOIK+GPFFSxiWM/L wYJZpGXYXcksShwBtUCH09nu136jusrWKU26op7TSU0tdLEVkSkqZZJZGXcx8thJgMQGxkAZ 1YNb830DQG0yobt08oXLnLva+ePMxyyYJwwwcD1EA79Sfpay2+22xRSTNX08knmpPIcv2Ay+ DgkcDOO2AOABpfShwJ5jdF0RBAVNp4adSf7O+NG2ihr7jdqWqorCIZFBmjl86WTG5iI98k+z aSM+SufqZ34b1O2G5NReG9y6IoqmpWdqepNLG0svlbHcQpMQihYYVyD6i2dvdi/yeI9lg6Wq b9VNUU1BBWz28qtO80jSxVb0gCxxhmbdInAUE4YcaQw+IlBcbr0ytvmhqrXe6arlhqCCrtJF 5bKmGwVO0z7lI3Ax4OMEaW6UdqIMd2KuvAmm6l8zxKa99J3iwC8dQ113oprmYB5kUiRxxxFU lZgwCc8bcYwx1TXV/Slxp57Vc7bAk9zt1a0i0ckvl/MJLDJG6K3YOAwYZ9PBycY12SK5XLnv /wC1hwNQe9dGWmS6fPeT5bFlUJuOB9OBxnJB7e+PpoenbyKLondiqfoqPrStnt3UT9Hyme2R 1lGlpqbjCk80cwpnSfdkouHpyhXOdjluTwXii8Nr9S0FJbXpY6k09dYq1546pQuIIYoagBWA OU8reM/iDjHI1ZkNyeiqZY4Y1ipsZ9Qxg+2Bx9+/fGlFLWy1PMQGfclSQfvxqnStGtqxG4mi FVPhx4TdQ9PdHXCyXC0WeWehlomoK9LvVrNVvBuXzvNIZqYrHsCooZAfNXGxxh3Hhb1fLcIL +3UtvW/S0vkXCJo2kjqTHJIYf5iiNdxRold/KGTCCAAxGrRgqHaNNqxgNzgodGpLMYATFtkI /CcYz98Z/wBdLdJHK2nahGwSRPzNNFMnQvXydTQ1FJWRPbb7ROYqy21ICyxMBw3BIZWGCGBw c8HUuMjq+Mkfp7ag/WXQlN1UaatSdrZfqI5orrCoMkY943H9cZ90P1OMHWnTPWldVXGezdQ0 iWu+Q7dhDZjnQcCSNgBuRv3BGCAcjSY5+iOU6jl/a2ywsnGePR3Mfju+imcNs2XP5tpGZpTt dccHjC/2Ua26p6pHTFtpakiOQyVkMBjdgDteRVdhkjsGJJ9hz9tJXkdEd2fcTjAU5HH+f6ah nUfQtV1jWWS61ElTbjbqhn8iQHzJkOzAOCdoypPGPbOdbW4o/wDpWAwVuVcUXl1JbEkbE8gg 8Z9tN1VEwdklU+W2cjGc5/8Aw41kW4uGjgOG7rxnH5/X9dax0MyIPm2jlnUkK6QlM/oST/f2 1uixEjtmWs7o2jco+1qtFHEikhwMHHbt/wA9K7eGqr9SMSQokQEj8x2/799b0tKFiBAGQQDz kjn3/bSql8qK505I2jzkyqjAzvGtJfOQeqkhrO1WpTywU0ccYOM+hQBnOPsNVb8XFsqL38Nv XtFSRmaqqLeUijUZLMXXAA1Yt/6ksvTlEJrxX01HCTlRM4yxHI2r3J49udVV1l4oUPXlquFj paIvQSHy5zUkqzgEMAAD6QeDknJHtrmSTti+Nws8lqjY4kOaNAvJK0eD3Wt8vdXZ6Gw1TV9I /l1UdRCYlgOf62YgD9+RyM676+HOz3jwZ6etK1UlBc7zTU0tItVsciKCSRXaJCWGQCi8kDt7 8alNTA8MhRmYiPKgE7sAdgO+ePprWCojiym7bnjHAPH2149+NeXUNKXo8jnM0FrN/wCoLgOo IZ7xUVVdG6hY66NwHpycbSAMLtJyCAMH3H0WVrKYY66nhRJVkPnxwKFDkg5IGM8/b66YeqBB LRwTVNLLUUyPgrE673HcqC3AYgYBPYkE8aYLL111bf5PlLNT27w6o1XYspX+I3ZtvBzK/wDL jJGOwbWqGQSML5Xbb7m1kkaWOGQbqwYrdRWZZeoK4Ulits8QEtxu0gphgEkL6iGYEsSCoOfr wNUN4t+JviN19e6m2dB3q5VHQ1PEkUNXRotHFM20bv5sgBZQQRlVY/8AF76db/0NEtyjulVU 1V8vkBLxXG+TtVyBxypAJ2rz/gVdRue7+KdVfqKO6Xux1EVRGzIy2kTQAowG0qSo4yCMjnGt cUscIzROy3zon5D8lLldJKf9vWI035DbdRKs8HfEu39H3+bp27S2m8+UskklioJKyeuXaGdD V+qUPgjCgIuRjjOdLPCr4YaOltFLcr/4e9T3q9SQrVS1N4gMCn3wXmkjVW4yckY7YPfVp264 eI9+vb2e5eJN5iRyqwCzwU1Eu3A3g4jYrt4Oc9s/TXPPxf8ASXU1q8Q7PLB1teqnpCso48SV dxSWo86ILHIUQdy42ODj+piccjTckeJaQHOoeV+f9LaJXRhrmsF7amxfbWlfNSXrKu6M8LrT fbh1PB05KpiUUtpohHXVm5WBAnny8UQGOI4Wf8XLca4L8UfEOTxP6vunUdRGlPLVsrGKNdqp tUKoH5BQNdH2Tws8O/FGiekc32NaCf8A891BLcJKmpUCJmbEHleX5WTksBuAjJPHePyeD/w4 UNuqvP8AErqGS6A/ykpo4lXP3SaOMnB5/Ev0+53RyQx6NB+q50omkAa6lQF0jp6u00M0nmbY aFFUKPS8hfGCfYYyT+WPfOo/HTDHHcHORq5m8FOl79eZoKHxQtcNE2DHPW0oi3HtyqSvj6k8 ++n3w6+Fmlvd+Au/WNHU2iKNpZFsIEtVIqnnaspRQPqckjj0n2dJiooW5nlZWYaWQkMba6H/ APD28WaGr6cfw7rFgW4K81fSSxxkPUEnfJ5h5BYex44XHsNdqU0ccSnzA0vcYxjOqu8Gvhh6 G8EWE3T1NPLc5UKtdLhL5lQUPJAwAqD8lz9dWopSMmSeRhCnMkseMIv+I5IGPr9s6+Q8Rmix eLMmGbQJ59vb3LXDC800C0RthaYBwQcfTtrfykddsbbscEgZzppqerLZJb6eqtsNTVx1BwmH UrxnO2VQYWPHA8wZ9ueNaPfK2nro4J7cj08kRljmEyxlgBkI6MeJM8HGQRg5ByulHAzt/jr4 rsf4jGFpJjHquU/jWudfautOnCIfOpHiWkPf0rMSP09QH6jVq/DZ1jY+hfh98ReobmkU6Ud1 mFLHNDvWSqihgECjg7SJSMHjBwc65Z8Sm62m65qpbnT3bqyy3RylRHJTO70knmMwMZRMbY8g AE5wODxxIOv+oq/oz4A7bZ4IZ6W89VdR1LVVE8eJ4YvPkf1gjcpxFD3xkN76+48Hg/awsjcf gb9vNedxINhlc/oCqM6V+IjqbpHxfj6n6UuYt01tglpoqySCObdv4d8SKygscYOM4H3OpD1/ 8ePjl1HBNTVPiJdIIGB4o44KZj+TRRqf76p6m6RuFmtTPJBsmn5CHuFHbntqKVVJWVkkscEM tSY1LyCFC2xfcnHYc99HndZdeqSe0jVWP0hRnrWWe89UXqeriWT5qteqkeSWokOAu+RvxZAH GcnUwvl9n6xrIDPWT2y10ieXS0lJTKdigex4XP5aYumxblstHFf7Pb6y3zkokS1UtFUUL8f1 uRG52gPhiM54PGNP8dmsVPXw2rpzrJ7hU10yUlLajAWLO7BRmUYAAJznGhLqBc4+KezQarsH 4Hugms/hvXdUuHeW/VR2NUjLmniJRCdv1Yuf210rHSv3by9v24z/AMtN3SPStL0X0laOn6Uf +UtdLHSxsxwW2KASce5OT+unNJSR62DAc4I/118MxmL/AHU75j/I/Ll8kbY2kC90TJEwmwEA BGQVb6floCk2jCIwYnv76VARhs7tufvnWRCwQMDkfUawh4ChhCQ+W6Z3Kx57A40NyNuCr6iP fsD+el9Qq06xP56O034VHfj2xouSNiN2O4zjGBo7o6hQQubuURGgO3cdueM9xrYqqvgYP3K/ 6a3lkdEDeWWzxhMax8uHblgGGT35GpbdyEJa4aImWFVYEkKDz2I40WYEOTuUj8+f21malkLg +acj6qDpX5aNGHY88Aj21Ry8kJjdySMwg5GA/wBACB/n/wA9ammJ9iv5Mul4hLLwSRj66KMa A/7zafcEjVdUpZbIN1X/AErH1x0/JTQ3mppaq0xgmerjqZq2oBBJJ2lBJk/8RZVGMlQMFFYu qr0l6qrfujhoaOUR09dURzyGOMhnaWQEq87LhYwkRITO8ngatOKeKWVXykjbywjhhwwPLH0j tyB9AQMgDBOtfmGYko0a7AGRlZlWMgsQAMZI798Z+nPPaj4kyEk9GDm37++q3XoRKWt6OtCb Pf3eCiNL4s9KVPUVFYKO80tzusg82WOiZpfL2AlizxhhGRgkBuTjAHONS4vEInCli49PmLkA YwD+nH349/rsoRoVlMR2xbnhSI72xjPG3uTkgDn2+uNZjpR5TiKUMxVRvdcKQQCCuT6jx7Z+ mO+ubiDG7rRRlvnaAmwdEVujb1bWEgVnjjEgGxi2TkHkA7u3vk8cjRsUTU8asHlwzCMyMAQq kHcCRgcDP7AY4wx60U8Ugfy4wBuY7n2cdzk9+MLz3GdLHV/JzO0Ic5BclAnOFwTxnP0OcnPB BzpTYw7WjaHo2uGyaoFXzHWSQVUasvAfa65/EdxGM5/YNj66UGmyFhEalChHl+VuVwOEGBhi PuffvnSiqopJpBEkzxqynf5WyUsAAwCnnkZ++M5GDzrekSopEDPJuDZOx1UEnOF/q5PPPfgn t730NHTkoIU2xeREu8IUcEsY/qTknuMZxkY78d8jBMVqaAxbVaRHVWAVvoAQxIPJO0j9TpWI x5hQvOpWXy2B4YHJI5yM/wBJz2IAHYjCelszR7S1XX1DTI0QErjBJdWORtIyORkexAxgY1bY DWpRdHdm9VosiyqzpCHVcFnBJwScZ+uc7fr++j2LEOjEtu9G4DBYf1AgZ45PJ+/J0o+Xkq0+ ZLCRacHZIYs+UWAHc4C/iHpOPxcEjOiflEwWZEYhckPwcH2XcO3K/l+2gdG5pCXRvdaxJF6m 2DiMx5bbgHA7jB/xA/t9eMyQuTKjwEb024OJM5we4A3ZyD+pB+oLmFM4d2HmMVYswVVY5IOS CrcH0g54GfYHhVC9OUkaJWKu4Zdy+kHI4BGOTn254PHfC8tjdUNTZRDxSRuqIpBZQq7U/wB3 z9z2/wCf660SSWJg7wGCRX5fbwWI9OOxPt6h+nHdVHWfKMcyhHBViquoLduAO4OdnPI7/kNi xqIlhVo2XAUMzsA4JPfBBU/bn251A1WNfhSKbyqp1DN5ruWKtkgDOBng/TsRzxxyBrRpqwQK Vkicd1nkj3v+ewKFBI4OCOQOMejTusDeW0gb1E/j3bju3HB4AAz7c9mIB7a0pxA9TuOwtjDI zZOR2yCR+xHuM44wTWuGmmqsN1q0xL05RtbhDT03yibXkklijKsJHUiRyUweQVztIOQpBGAV ZK+6VVnhnuNyMcjwUyFkAJqgFDMUOMeYQWIjKAkM2S5DEtPVMJChg+1WJd48jt+JSQTyeO/b n9UpiDRU8KyeXK0ih9r4/DuKj0n08qitnIwSPfOtbHyA5SbBUe0kpmjoqeqCR1UaVyr62NTA GkjHduCPUCxABTPYAZ0xde1kVh6XqaykNPRSR09ViSkGPU1HUBSu3AxnH15x2951FQefFJvS F1Dgs8rFdjbjyV9zn3xxn9o91L08teaSmloI7lTvMRJSVW2YSJ8vLgSc4fHAyQDnGXwdFA50 cjZDyN+iW5hA12Xmrf8Aqy4Wjq6e3R+RKlYkVuDVVNHMI1KxuThkbP8AhPGCD2OBrpH4Yup4 +qqO/QwW6lEFNLSwRSPTtD5pAlZh/JaMDau04xgblGO2onbKaeh8SeprTbaWGO31NzknqUas LGWjgDLHHGzDdKvqBypJ/FnnkdGeGXStNYqSWempbbTpUfzIzbYSiMGwS2/P83cBGd5/w/XX 0iMCYN7CF6J8rY8O5xABO2uvorY6Zoo4mWNKaGEZ3Eru/wBWPtgflq+elkdbFTbSqj1d1P8A iP31Q1kmdpo4lljp5lP4JFxnn6nIOrgsF1ucduo/mYVFLtKhoVLNheCWx9SCeB7j8teiiprK peImtxslS5CzgkYPOM9tbkle4AA+h1CarxBjp+tbX0zSslfX11NNWsImUfLwIVXfISc+pm2q Apyc9gpOpIJJZJFaR8YBAAAxn65x9P8AXvpwWSkveQxKVVS8mOFzjP5n20gg6dtydQzX0UMK XaWnWkerCDzDErFghbvjcxONa0Ts8kjs7sXduM9trFePtwOPudHuCTkO3/3EavmoCRsnDVYe KvQl3606w6Eq6Mw/wqz1xra1ZpGBJDRlNqgcnAfBOMZ+/M8lHoPJI47tn3++tIYVXsuMcdzn VglpsKBQ25dDXJPHO0dY0C0xoXtUlruJlkKuqhjJGUUD1EsVByey6sNqhVz/AGGeTpKkKqAQ MH66UKvPtz9NVZIoqKiOoPg+6R6mvF2r6m99RIt0q5K6opIKyJYfNdmYnb5RzjcQCSTj686n XVXhDaeq/DSk6AklrqPp6nip6c/KzKJXih27EZnRieVUkjBJXv3BnwxrYD3xqjZ5qWmy4WCl uNgnsbwJFa56VqKSCLKYiZNm1SpG30nHHb21EelPBXp/oq5UFbao6s1FFG0FO1fcKmqSCNgA VjjklKpwAMgduPfVg4z9tDUpS1GLd0BZLL0XH0nQ21ILAqPF8juLKUZizKxYsSGLHOTk5OnS qpKe5Wh6KspoKulmjMM1NNHvR0I2lWVsgjuDn205MuVxqKdV23+PWm9WWarq7fTXCnkoTWUM vlTwebHt3xt7ON3BxwcaFzbUtcvfCYxPgDXfJ2ux9Ey3KyVXk9RUdxRq6peHdEatolRdqRsd xJkyCew351vW+KfXvU3TvhTWWK6XVbx1LX3inuNBDLFC1BV+S9TT0UgmX0iFogCSu4xq5H+8 UF78PPDPwYo+p5KHo2wW2GutlO1rr4JKeenqnpZAyutTDKFaaN03+t1ZWKggkgYsVOlrF4i3 Hp7qe0Tl7bT14vUNxowImqKhqR6bLZXLEQSbCcBlMarncpCJ5pmwtUrVeJfXt56o60Wbq6O0 2ygr7hYIqOtWlp1NVFTqtL8iCzTvI7DzSXyuH2qGI3GMyV9y/wBiqG70d3Y3q79D13UldWxR LDJT7RQVHk0skaDy1BmkOw7mJkDOSW3HqDqLw36Y6gutP1NS9OWs3ajjEUV9FHGagxkbNkL4 ztw3LHICkhc7iVbae12Xp1LVbqWCitwp4Wo7dTqFRkiABaOIHkjCKSB/hBPYanRE81A+uS5M vVT190v074g2iz1t36guFTFW1tPSVdTKZI46O67J0j27XUy0FVTNlDvZgzKd7A6knQvUdx6S 6etdXaIq+5WeO120Sw3OjninrJJ6qalMkaNuZFZ4YZArZO2YMSPe46/xFsUviDJ0vQVVTJ1T TRxPVRQW+plpokkXei1M6IY4iyqSrM2Rx3BKs72rqakv8Va1JK7SUVQ9LVQnIeGVeGU/X7Ec H21XRXrdEK85VP3PpSnpehuqOoOgYq2vvdVVLXw0FTN89HRztOrTyU1PO4jSQb55QuVzJwTg ABj6Bs/VtTD0i92sV1pntXWVxnlmuEcMM8lFVUNXKKmRIyUUCWrEZVSeU7A+kWbcek6n+J1l 3sNWaO+NM0klPOxNNVYJADDuhIA9QP6YPDj0x1PDf3rKacSUV4hcGptlTtDU/pVcKR+JSVLB uQd/B7DSwxrzThr8j77FeZw2KWihQuW3HeQASQM4+h+3f9zpNXURnDevBx6XXg6d/LJAAGMf X20mqQ0ADFeT2AOc6puHjJ2UMru1M8dqLiKIndEWz6m9sZ/1OnCmtqUm2NHJVe+T3/6awhEc cMqqdh55PbP/AC50eakKAzkKvYZ09sTG8kBe47lbNRxHspzj3zxoS0voxHge5yM6PhcSRhhy M8FToMARj8I+3GNQMYzYfJUXOPNJAjRsTgNn3yf9dN3UXS1D1VQilr4yChLw1EJAlgf/ABIf 8xyCOCDp5cxuMlhjtx30TLOkSkHLY7AAkn9NNyhwykaFRrnNNg6qC9N9QVfQ1XSWDqhlcPuF Hc402wz85AHJ2MBjKE+/GRgmyqeTzUUh1dG5DpyD+uod1bdLGvT1QvVL0dJa5B6nr5VjUEdi pP8AUO42857aqXw58d7La+q5rFHcZblZKh1FJV1EJhL8YAwQCre2cAMfYEgHAc2Cdrqw+o/I XYZG3HR0BUnLsd/f1XTtNM0gkRGIYEdv76PCiJjU1BXzOy7htB47n2+muS/HnxS8WPDW4S11 uu1J/srWtto6+lt0bGBu4STcGKyewJyrdxg8CgZLrW9bVAuN2ulVca5RlpaudpmHPcbicfkN dL98xopotcr9q4nrGl6C3/xi6S6SlaKvvUE9ZgsKaiImkbn6LwOT7kai968Vqy9TxpbkNsp5 l8yKVcO78cEMRtB98AZH99cgwQv8hFTRn+bEheklzkuvJaP/ADI/UalfQHirJblS23D1U6jE TKfUB7EH31ysbisTMyoTl7v7W3Dwwxu/2C+9W7RVtXd6StjuFRNW3Wld6Weqq3Lyy4AKOSeT uQof3+mnKw9QfK1VkrS+2CvWOkbJwFmHKDt7jcv/AMVGoqvUdA91husFSXpJWSgrBtI8qUkm CTHsG3Mh9s7Pppza1fO2W5WeGUiUky0rtgGOTO9SPyf+w15JwIdb9L9ldoURQ99itK9IriKY bX3ruQqTyv1/f6aZIkZpGYSF42XAjdc4weefrz7/AEH30s6Quw656Zt7wkB5zscbtqRTg7JV J9gGBz9h76kdy8OrzYSokpzjtiE7wffOR/r9NNkwz5SXMBIG6VHiGwjK7dQdnRa75CpVHpqx SoWb2b6jPvx/bUGt9N/CeppozIQYN0rq2ckMcFhkkbdwxj2+mDnU36mejSqS3yXBEupYyUsV P/NdXXkbtudvbndjjUXrLJWXLqae9xSNQIu1ZYpSrDechgNw/Cc5xg8857abCxzTlISZXNLd Sn2aBq+CF5B6GUbTEQWJHcAc5/vrSh6LvE13kintdRa6aUoU+ZYOqezMo4J5y2Dzzx7ZPs/X dq6OFPFFcqc3RyZEjeFWLhQW3lnHCDbu7gcHVQ+L3x5NaqS4xWFbP1RXO7RSSxArTxHbgnep wxHH4ePVnd9OlAxpGV4Jvu09bSybst0Hfurpr6Q9ISXa3SVULCVUjnqmUxgxY3bFbJG07vVz ztXjVV9R+BMHjbYqmmpZDT0FRJmnvFI3lqCCMsAcCQ8MmQOx/XVW9HeIniJferukr3b+mUt9 LVUa11whujq1teOSRwJ13ZZCyAEc7zt/CVAJ6Qu3jvaLfA9PbJI41izG0nHBH9KjjGM/fVTO DXHrEdw1ruWxkbT8Pw9p0+W5RHh38PnQngvbgLbTrJXqgjkqGIaabBySzZzjI9to47caZvED oXp7ruqea/2yhu1PGMQU1fTJKkYx9W5z9xj21H7/AOOVPHE00pd8/wDqTNt3fkP9O+qb6n8V Oq+t5HprPbZlpAceZKWpofzOfW/9tcR0T5X5h1e+9V0OkjazI2isdX/DH4IXC4NPUQzWSYZ3 QWqpZY2/4irBwuPoMasHoj4X6fp+ioZ/DutttBaa9FWpujRZqjEeGMUwyWOCeBtGR3HOq3s3 hVPdWWqv9xlrS2CKKn/lU4P/ALB+L82J12l0VaI6DoiwQUUSRQQ0USIq4woKD/nrJxDGT4WI COQm9NdfRYHdHG4ODRfgnOGOWjiijR1k8tFRSV7gDGcfpoyFHijP/lo13HJUA7fvxrDUkrgY G1vcn66LZZ4JBGGDE8c/ca8QHOaUgPDe1ctfELZ6XwmrIq7o3pylYQUTVFZR2Soe31lGu4KJ dsJAkU7iMyo/3ODps6P+K/p/qGmqagPNGy04aaK51AkVcLyOFBHIP257DXSnUvRdm6qhVLvQ S1VSrmUVUWUlaY5wA8ZzHEo5IJUHtg+9C9SfAX0x1VdKCas6ju1KKWlENS9up4IJa2bPMu4A gJ7BCCeM5517GDHYURhsztue59F608QZhIQ+J+Y1tpZ9+9bVI0PxE2Rq2NKq4pFFKMGQLwG+ +NRLr3xv6c6kY2W51dRU25qmOSWqgOQoRsgEZyVI4ODnt31RPjV0I3hT4jXrpWe6016qLdKI pKqkyELbQxXBAOVzg/Qgj20f4meElR4c9N9I33+NUN5t3UlIamnNG/8AMhKqhdJF5wVZ9vfu rcDGvqUT+kYHx6ir8l89fO6yDurWvPWSWTzB5gbp+9QgPFOhno0lB5IA/CCefRjhuNGW3xXo oq6WC3220dPTmDyail3/AC4OBlZEkUruU8fhYNznHGdc92Lrm9dNwTU9BcJYqSZSslLIA8Lg /VGBU/tp46e6VrOuYjJ/GbPSKhIEFbUiN1zzhUxnH5caLMg6Wzopj1r15d7nIlD1KklRQvCY oKyZQ8jKDlQZQMSAEnB7jPOlHwzW2O+ePHQ8LL+O7QNwOcI24n/9HTx038GHiR1dahU2KW1X OBm4hiryhJ/JgB/fUo+G3w4v/hL8W/R1i6wtv8KucUxcQvKkikPDJsYMhKnJ+h76xcQztwcs lGg0/RKJLjqvUcyJPIWUZOd3IO0/vooLEVch8Mc7CoLD/v7a13s3cs+Dzg/3xrQ7Y3JRW2nv tAH6ka+FNcByXUGUa0jFpnVRuYH2BI1q0UqM2EBQ91HB1rHMkhGxyw57DGTo0TMzENkEZxj3 1CUJbmKKkDKEYh2YjGMdtbLK5G3+ZGB7OdDy90gcSSAoMjDYGfy1uQVRyW3fUMMjVZtNkWSg tVQyvtR8n6r9NEs8JlEZmh8znapcbiPy7nRphjOX2rjvxlTpJNY7ZUOsklvpppEORIyAt++M 6JpZ/K0QHaUe8TKynBPPBHtrYxeWpO0gnk45B1kqjPghlC/nrCwRq7SCMs543MQf+ugtAGXz QiRl2kxqyN9HOP0xoSRKGwqqB9yf+WjiQ0DKIw2fqe320mDeUAuXwO23JH+ervRA5jq0WadP m4zMk0agEhI1Idxg4PH58Yxjtye+lcEklvqI3kqfIQet3jKkxkKec49sj3+uOw0asNP5UbLO k25thMz5UNn8PJJzuIH1PPbtrMk6tVrH5sMJZipYksB/gCgrjt3Gftjkga2QujcC00Quj0Qc iZpaiurAJLoamolG8LNKHkJBAIVu5TcwBIIxx3BGjZoHRQkhZpiPLQooVcE42hsY5Le+cllA GRpU1D8wJmaNIk2B2ZFAcL6hncF55HH1HGBnlGHSnjPkxSLOSVUzN5bSZ3NtDYywBDEqOwJP O0jTzH1i5xJJ3VtjYBoUbPJJThY4pyAXVlZcyZJOF5OTycAHuckc9jislqEfY1PPI6AMQUw2 3jIwSDjBPA78jHbSNIqyjh3SrT0/mvsjeZmTzHO7hsD1HOBjGeQCOM6z5mUAq0XyGJC+VNgt knd/hOBjGQOcj0/UQK5popxNFL5asqqv5MzBT/u1Qvn3IIyc/iA9X0PsdCNo4oxhXVFIVuCw OcgZyePfA9+CRrSSaSOBmR3nj2hfKSMElsbjjce+BnuMYY5J7m0gQzsXkeZo127JAxyD6+O5 4AXsT9PylOPJEDSNFwhkSIyRiRI1yGAwEJ49h2285z7kHtkaRsrSupjaZkQB5ASXHPGfqc47 kdsfmVUSuMNIpjKsVJVVPmEckeog+7DjjI9s41mhBqGHlEGZVZxGm1yrKSj8jP4XO04HvyOT kw2R7soF+A1QnKLJ+n3RU0rSQhZpZ0IcMUSRirMCSOV787T+gP00ajySh3hVcLkIoXYQffIG SDkMMEj8h21Dbv4z2uh6wpOn0WouC1LSQVdVbElqRRTKAQkirGT6sbQVY8g8dzqTUd5pOoIY bhSSrW0MpDoUXenI9wy8cYPcHIAO4aZNhJsM0OkFA8/XTnXgaSmuiN5SlizkiBjFIsSEbctt yQMqB34znA7+2NB8LG0cx3Ak7ZSwkkOByOQe4HJB+vbWEqWjgVEQZUKHBQDnBAGOcDAHvk4A A+hHzbCRXU7cj0PLJgOMLkDAIOcg9+c+xzjC6TLrdqraOVpVKViUbZo6cqWcOpVdmWG4n+nu STx9ANFUdGKY+iUENny08oABjgjAUc8er3IPOD7aCcQnMdQyKdzsFOAGwSBuxjPfuv74zo3B Ks4QNtZk3+YTtJAYcDB/C2OPz0npLOmqovsnRZXMKLB6WYZGWTnOO5JBy2SMnj8WPzTmqkgj WdEWJ3b+l9wbJxke5GCeT347ngbxHeJBDNHIseSSGJypbjBz2J5H5ccY0rR50lJdQ6sATGTw WPGOf+LIwe/P00BmN6qU06kpPBK26NZVp3R5AMtISwJJXkkc7RnA55HJ1oI0S4rPGUjEUMil QSANzgucexBjzzj8Xt30e5lYDOEU8NIQfQuDyeeMEADPt+WCiucpoHhrJU8iOMmEmZtoAbDs DnGeVHOeASeADo2SGRwYwWT3IDRIy2lUtyhtsQkqqyKmo8BJpKmUYUfhxu9h7cn3BONIr1eP lYhLG/8AEKxYiYac1GxnlODGg4/CxR/UPSoVieM6ZKzxDstD0/U3GZxVBRUJT0kTI1RWvGxj 2QAHJLsDtCjkMpx7ao/w/wCoPEHxO8Ur9deq6Gm6J8OFpkp0guNfTxzjAUbEIdSHkJyzleFG 0Y16HCcOnkcRM0gN35k9wHNOeJWC3NIHM8h2Wa5qt/8A6I9a9ZdQVHUsnzXUFuppfKFRbhDG ssycYpySrNGhwvzG0uSD6TyBengnaev+naah/i1C16tVaxBNNJCGom3EF13lGeJ8E8rvB9WD ubVpT9U9OWOgpngq6emtwBhiFJFK8KBdp2DYmzAUgEA8ZXtnOo9WeMNCIYjQUdfeZmkkEs1J CGdCXyG2lvWO5w23AJ7bsa7kU3EtTHDlF6ZqGnfZCzzYwSNa2T+IrTnrf3Vo2mOju0JNOy1E aOY2A7o47qR3BHuD21N7dco+iumnuU9Y/kl/JipOGeZ/UwVMnvyeMhQAzMQASOWKzrfra/32 3QdH9A3k3mWrjgmq7pC1FE0KhQ+XXPHqyCd4UD8Lc5jnxreM1R4a+HNus9LeJrx1BeTU0MFz AWPZSgbquWEKAMKhWNXOC7HdyEXXs8NM6eMaDNzo2AuQ8NAuz4H3S6y8DvESk8XpOpuoqSKK aCKtFsirKcDY6RxqxCNjc6b5Hwx4bkj0lSbMkJCo2cMCCu48c8c/vri74ePEi1eDHhv0hYCk dtus1IzmKrrJIYDI0jJKzblZVLSQswJHG7YAAci2r98V1p6Jro7d1XaalJKkuaartMqyLLs4 Y7XK7eeBgncQSO2ifioIpDCXaj3vsrGHlkGZo0V6UZaGhpSwHKjzCeDkjJ//AEsfv9tK8AnH J1Bui/Gronrq0w1Fqv8ASZIA8molWKUEckFTjnA9tTpAH2OhVkcZDKcj7c61NkZJq02szmOY acKQwduPb66CnDcfc/bWZT5cLMxAC9z9BrUEA8jv9dGgSgD2z+WtuP8A8OiPMywAB/LRm7Cj Jx7/AH1FEZ741nWF9R4Gsk6iiGMnv++hoZwORjWcZHGONRRY5x9T9tNdwiWslkp3OYpEwdpw c5IOD+2nQ6iXVT1l5ttxp7PchaZBDNTrdvJ80wzkbUCIcByrd+e42jLElaUXK9spZKH4nuo+ tRabrBR3nqN+kZ76SBSR0cdHSrGgy2Q7VtO0QcLj+a43bimLJ6Opbh1n1j0PTz3iuFmji6ja rpYK1/LqvlbpDHTwyAEfg8zB9yIyjAqSNS2w+AlvpOg6Ppl7ve47XFXm7EPUIaqoqTMZ/Nml 2d/P2yhVwAwwdynaLJt3TFos9XLU0Nqo6Somllmkmp6dEd3lKmV2IAJLmOMse52LntpeXXMU V6UuVpYLN1B4EdUVFJ1JUx9a3O9Uc3U7U12kFZbwt3VJYwhcmnSKPzEUALhVHfvqvviwrunf CM0tworNRx3Kgp7SbfLXVZiaKOmrmcRW5PLZpZT6hMoZP5bxZJzrt6u6Kspa7TwWugp6q6AG tnjpkD1RAwplOMvgcDdnHOoVM4ZQZNjsOQWGSPv9tWAdlS5+6Cst4i+IfxZgk6xrpKCnqbZW PbhSUqiqWai2DfIIt6qvk7V2MpGzJJJJLX4VWiz9GeJfW3T9Z1zdq3qiO4BbbTX24iWWanlo 4ahpI4cL5uXE6scE4hHIIDavsWqhgrqquio6eCsqyhqKiKJVknKLtTew5bA4GScDjWKiipTU JVGCGSpjUqk7RL5igjkBsZA5Pv76JRM9DO0zNDUQpTVYTdtVt3mIMZdCQMrkgfVcgEDIyg6m 6Vp+oBDPHNJb7tTgimuMPLx++1h/WhPdD+mDzp7rYoqlAk6hwPUpJIKH6qwOVOPcEHnTcatq B1hq2LqTiKpwPX/wuAOGx9OGA9jxpT2gjVECb0TFaer6uKuWz36OOhu+Mo45hrFGMvG3v37H BGRkDvqSyL5kybsbQDkft+2kt9sVF1LazRXCEyRZEiOuUkicZw6MOVYfUfcHIyNROk6hr+jq yG2dSzGegkPk0d8QYDseBHKOyvn9G/p9wLY4t+P1/KjgDspdURMIxiUgqwwQvtnXODdS3HwN 8Ya+mvFQ8/QnV1WahKqobIoa9u6M/ZFbbgZ4wo7bWI6TqCZKIoZAfPjKpKvY5GM59u41AOue kKXq+2Xe1XeiStt1TvSaGYEIwySpDexHBDD8J0xz8h0GqoNvdTGllp6ylDKCqg52jgg/Qj66 PpY2pskyNIh7b23f59tc12jrC/8Aw5PDbesJqjqDw+OxaDq2JDLLQA4CwVqrk7QThZRn2Hvh ehbZe6W70FNW0U8NZS1MYkhqKeQPHKh7MrDgg/bV2SaQpxmAkcNhSMccY/vqoviT8TLt4bdI 0H8AlNJd7jVGKOoMKyCONF3P+MFQTlcZGe59tWyJeAwbYMdsZ1DPFbo2j8SOi7hZKgqjyDzK ao94J1GUf8s8H6qWGgfeXREwgEErgmvvt46oq5rnebnPcKiMjM9bU7nUtnGwMSSOPwqMDPtk aLV2roHkWRWG7AUJjH6e3vouqt1fap6u31lBJDWwMyVELj8JUjt+oPPuDpPZTHBWNAm0JOuQ wf0lscga5413W4kmjavfwd8bJLaT0p1gi3npqrUwmSrXekOfaQn8UZ9yfwkZ7dnrrb4eanpK 5RXTpCOS9dM1xIEMTebPRt32Mf6k44f27Hnk0LSCWof5dS8MsY27oiAdvHA9jxq+vBjxZvXT 8UlLLTT3fp6ijMkrQwtIlPGQWJdgMKBhvxew+mswaYia+Hs7PD8LoyYgYqul0f29vj39/Pnr qq7tdHN071rTWe7wzUVYUNTFSVDYcoCQJFxkYyGGM5BXkDSvxGsa2q9skSrCKtPmadk7HJ9Q +3I7dudWx4t9L0fXlqoOs7XWNUU1ol8+KOCnEs9PketBjDPEwHIPqQgsMgHTz1D8NVz6+uks Fyv38Je1TeUI6emEwIZVberllOCB2I9tGOs/MzULO4ZGlj91QtgvlRRVcMNdMRTVEHy00sed zRn+vA4LodpHvlR9dXJ0P1hcOor1FRwUFTc6qSLEgttO0xWWNtkhIQHCscMDjsy/XXRPhz8H nh/HYLfV3inqeoapG3E18xji3KSP93HtBHHZt3fHI1bMNz6Z6Ftpt9rp6K2wxDIpqKJY0Tnt tUAd/wDPRPwQn6ztFmZi3R6NXO3hlZarp+t6hast8UNBVVfnxIjKJlkeICRZFGSp3gnke540 /dZ+MnULW1Kf+Kw216keTDS0i7KmUHjcGJLcf4lxz76iXVfij0t0V1FcKmsvFZbrqKmdValo 0qPOjaZpIwY2OXwrj2yMnBGdU11f40dNVnVK3eyW409aA6yJFG0mZDxuaPIWLj2LHGTrMzPE 1zYzr75prml7g6Qae9k7V3UtfYep7FBQW610ksk8k9VUNGzkIOWMzs2CTk+w599PV16yvvVd UkVpoIq/cX/8zWTfK0cIA752sWyeM4xxyewNLXjxkoqdnds11ae7VChgrZ7Ki8D8zzpgbra+ dRwSVFTLVVyEhlpkG2NcnAUIMZP7nvpTYHubcrtOwaWU+2h1Rj15JF4j2vrW+9VT0d2W21lE WEs0lPcFeLcMgRb1iVio4JQq35jnTTH4V2Kpr4qyvoqX+Uqj+H0EIhpSRzlwBmQ5J5OM/TR/ it1DcPD60WWtrqWKd7mZVhpI5TEItgXlyOSMsOAR+eo70F1Rd+pbzDLUTmJQ25KeBdqcdh9T +ZOugzCTBn/pb798kmTERNOhzH375rqaPwk6v6sitMTw/wAPEVOsTefUhYYI0AES7QSVcKOU UDGBkKcjU/6e+HLpa30ri6mqu1Wwy0zSNFGpP+EIc8/UnOpv0tSVFtssFEz7nVQ8hXk+Y4Ds SB2O5m/MadYqdh5rlxJK3pIJ4H04zxr5rj+JzGd0cRpo2rmORvvWxswNEqCt8O/Q+Yy9urAB wrfOySYP5ltKF8DukshIoJ0ZecfMvz++pzAPTkoq+2AQBrZ5GUF/Lxn/AAnIz9dck4yYjrPP qUQljoUoVH4R9OU4crBU+aMctUH9sEdtSSgtslspYaaNoxFBEsUayMd+0cDP/PThHLIFBxIT 3AI5A1o9WZmJYMSOCSOT+ekPmdJWd19llC5zDpa23vGYlBC5GW5BJ0XUyM6lmjzg8ErwdB1U RNIqnkdwOQfp9f00nLMI0MTlXxtPHGgJNJebsWywE4ZYkHHcHv8AX/s6b+repqHojpe89Q1y f+UtVJLVygAAlY0Lf3wB+ul8FRKuUMYUkZ3KxGMa5e/8RXxAk6U+Hw2ZXxWdR3COlAzhhCn8 1yPqMqgP/u1twGG/c4lkPJx18OaszAC+xea1XD1D4zeINwqqSgqLvfbxWS1bwUULOzO7l2IV ewBP6DVn+O/hw3hH0v0h0XX9TWe/XymaqrrhQ2s+a1qkl8pRBLKCVY4iztABU7u4IOq86Mvd 06Bst3vdDcqu01FVAaCGSknaF5t2N65UglQMEjt2B76jVld6p6iMo89RLhwSckkZz/n/AG19 5aGRx1Wp9KXC1c6yhJRBe69/cc61Wk3dtrD89LcSx53Dj98aLLr/AISD9tITKW1G1RQtmCaW A45Mblf8tTTw86xq+letrLfzPLNU2+shqQ0jliQjg4yftkahYkz/AFkk/XSulcLzkk/Qap4D 2ljtiqoL3Li+VrIIKqmlEkU6rNEfYqwBHP662ZFRn9B3Z/GgPP8ApqtfhY6gPVHw+dD1kjMJ 0oBTO59W4xMY/f7KNWZJEyM385JABlgrZ418HlgdDI5lbEj00XZa3O0EBR9J+oYqmRZKChmp wxI8mYhtueDyO/2/vp42KVA/mMwGScZK/n9RpVGUz/LkBB75X3+mt/LicjzZFjAwfSCSBqnd eiWgeCLKTrVJHkMoVPU555BGR/poCHcu9WLEN7sT+mlHyscxZfOyAODkg6wlukdysHYD8Sn/ AD0uuxA6LsWWjZyNp9OORntrQ08xx2UDs3tjWz0kuWEy+bJuyN+eD9saEavEWHl7Oc7Vb3/L VuDQVC0DmVrJ+HO8A/8AHwNFsVGQMgNzkAY1u4kwCuCxP9Xf9jovErMzMg2qeQFAA0vTZBl7 Cs4EagiTGOSSNZEmeSwP3C5zrEUqqpyBkZ98cfUdtauXLemSMD74zoSO9A6+ZQlpIDA0tTSA 7RhWUGbB7lQxxtwcDI49Wd3vrSGnoqhxUJTrIMNGKp5VYexIwG9QxwQfbOSOCXba00LPUPA2 4bQzqeGHJOCuSc5ILFfqe3BCOqK0ylUZyIvNCHHfHpJ3ZA9/YD74Ouu62Gwu85uXYrMlA0kr QzLvZQu/dGWwucbue+Rxnj8R54Os1VAlOFSKPapcJlxlWB+zd+wOMd8dyc63JSSNykUm5sll 83JYDhSAO/PGe3PbPICw7XkbeSxG6USAeYRk4yQAcE/1Ef64AOc0aIKLdWhExbIGEwjKvMo3 vgAlO+c5wwGRyMZAzzkgmKkh3SFGUsBtw+AxGMKSASPvwfyxzrdqh3KYlmNWB5nG0xsDxuVi +5vfsCfyJA1mGU+co3O0iuNvkIy7MkA4LDjB4559JPp1Ruwqaxx1CJ2bhJI1LvyuxsSgqS2F 2kA7c5AwfSQM4x7iF4mXZJGXMbtJsKqwbA447jjHfj7D22kDT1CtHE8kchCHfEuCecs3p3be +dv27Z1qrbcTLC0LgsuPM3sV5AYjOPfORz6ufchObUJRiN6pXHSSTRIkNRLJEzMYo85AQAbs AHLcngHJBIwRxpAYf4jVbqqkp6mnD7Q8yllzgLnBUkD1OpAI7gZI7q6isM8PkTSSbc7UfBbj GSM5OR+EkseeTx74pqtWJkSPE0YAZowCHOBggkD39PsOODkAFolN0xCGkaHZbW+lWmoI4FiS KjVDiBfKVFwpBBAAGAAe2BxnA7aJFUiGR3qVqZHUZkWQEhWPp24xkZ+vHHbjk6uqg0wAjzLg oWBG3OMsOV3HI+o7jjQFyMwkHkQsFQsPNmLIV7HABxgkY/XUMt6XdJrWmt0k89pFMyTwuMr5 cYZ8kMCeeeSVGB7HngYwD5JZQCPlkVmKjkqG9QIHvxkZYc4zjP3EUyl1JEcZjjUkMZEwMLkZ ycc8cAcY55BGVWWWRkHkyDb6dgLFAeM47YBPJyBzjjvoKHI2mdGK3QhcmaWWOWKMJ3JLDYu4 lFCtn2DcDAP0GdFVFppKmraaerqIPJjK5pZpaePbnsyIRyMZByTj3GtqiooTMWWUROCNy7Mg 8MQCD37HI75OcYOt41p5ZnSONQUkP8tl4X0naMjgfnu9wDxzoxrrz8VTYy2yi0trRwqUjqGk DKXWWqZ0blcnnODkMR2GV+pIBqxS0+DU1LCUgqqmIHMoAyMjsOMAH3xycga1eo8+KOLenO5/ LkQbmH4QOcc8Dt3H01rT3lJJKpEctKg2+g+kg54Pfv8AfnsDjnVExu6zirLQdyEehDYUI0jN 6UEiCM7iDuz34BH64PHB1yx48zr4nXa42m9dM1xpLTcYharo9cBRVux3DkRKcFl2bSxLD1tu CEhddFXiWpks1e1HUj59YSsE8EY/lymPClgSRgMy59v5TE9tUv4v+H80TT2G2wVVdJPOLDbL YDKdqSRs7s0mAFCRISCXJKhcgn8XouDYESh8sQ10A7r3PkB81owMmFwuMZLjNWNBdlP8iPhb 5uIvlV3ouauouo6+9+IH+ynS/TM1Rea2eFF6gFc9JNVMZTGlVGkYHlovB3MfWAsjjLLjsroz 4e/D/o2uuFYlshvVfV1If5+9Rx1TI2QMruBwPU3qPqJPqJABFT9DM1f8aF3tEeZrN0h01FRU s6r6UkdaZScsQDIW84cnsnAJBOukpLrFQSQQRGWpebYZBTU5IU+kIMjPDAr7tjcAe/Onjs0o kbhYDVDWudrjNk6cvnedSSdtN+XYtqC101Ksojp6SndmQeTDTJBncMDOwA8YJPJ5Uj6ZXwRV rVASCdvPLA7HU7ZZCST78fhPHtz9AQjojWXe5okELmTeVji84MwXGGIzz2ZW9zwPc41Ufjb4 vXAdRN4PdAVaXXry/mY3CqLo0VmpW9cyMVyNwRGG0ZY8fiygPEwHDMTj5eibYH8ilPeI25jv yCl9/wDGemiq1svStX85PUylZLlAxnWbymiDwxHgeQHkjQv/AOoxZQAqga4l8ZL8fiG+MOpp lge5Wigqv4ZT0sUjfzKWjBnqkB/EHfbtB+rEZ99dBdRdC9LfC/4PdQ9eXe8Vl96tqWWmpLzU zBnqposPFBAnZYPNVOF9RCsw9Kgij/8Aw9+mGq/E2+dS1brIlrt0tuAqMM0tVUAtKwPbCtkE 98SKOc6+z4fDMwsbYIhsuI55e7M5dB+M/TVXV/w5a2pWprrbb46WeSjCrEzLliMEDtuABGMg LpgTw9vPXXT/AEnUQKJpYwLbTzVUSwx08YJEZG44KKN+51GSQuAWJzI/GfxKTpbqOS3VdPDJ WwVGKOEwhkeLbEzSOo4Zd7SAZxl9/suNSfwWuHUXWVHR37qSria2zx76S1pSKrOuSVkZipIU jG1QfUApPGQ3j8bHiJ8W5mHA1OpJ0C7MWJbFEAd1dtLTrTq0ykbJdvlxZ4wcN78AdsfvpSau SOqMkTvSSsxd2ppWjYknJyR3GfY8aazeI5ZNxJCnBKsfWDkc4IGR308WymFzmjSLaS27BXOS QCcf/onXZ4fw+LAxCGLzPae1c+WRzzmKk9xs/VF3ozPZuo5rTH8qFEVTQx1W1wxLEFmDbiMK QTjsRg51Gn6z6ytNUUnq7Lc3VAQDbpqYkfdhNJ+vp9iTjGrVpqgCn8n0mPBBIH175/799Vl4 nWC8XCaWHpqmhnunlrIsdS5SEgsVYM4BwQAxBIPOeOc6PiMU5gccIaf7vfRVBI1sg6XbwQXx eudHDCJrAatUTMjW2uR342+0wjBBycnPt9+MUfxEUMVTOt06b6mtccbYDyWs1KcDn1UzS+/u dNnUlkrvC3wyuHUtygpuob1TrC4oVZ46clpFVwMnc2FZjlu+M7Rk6rHpvxfpq23y1d+oqewq FCSvDVF4kYvhWVpE9QJ3Dk5ByduASPLPxnE8EwdO5pceXP5Cl3WYfD4lrpI2GhzG3zNroHpL x66G6pk+Uh6hpaS5DvQ3DdSTfokwRmH3A+nbUyor9RV08kUFdSzSRbQ6xTKxDEZwRnI4IP5E a5rpup7L1VAy2+ppbnAqoRJvjmVSwxgruODyRj79+caRXXwp6L6kkFVV9MWusqG5EppI1YnJ OCVCknJP5nH6jH+pXCmzRa9x/KUeGMdq11e/JdSVt9o6GeKCWojFRKQEiLgM2TjIBPPOlscy yIrAEKQCMjHfXJFB4OdLWSpD0dLWUcrc+barlWUpYfT0yKccL9R+Z0fPFdaar8u1db9U0UG5 kKfxX5rzW7NHGJ1dgU/qfcAp4BLZCaIf1LC57hI0gctvnqkycOaAMjvGwul7lc46xXjinkjp lcxSTwN65XBO6GLHO7ghmH4eQDkEoEtkpEFTJCqCEgQUUZGyFcEA/QvgjJ7AcD3LUjbb51ba IEaHqa210ixCPZX2VpRTx9vLTy5IhtyvPpycDPAUB9h8UusA5SWCxVUi7NjpJPT7efXuUq4O R254PHPcbR+oMAf5fJZf2EnIg+auH5kJyQwOCQuOSNFG6RNO0PmAyqOVHJHGef7arCDxlvMB ZKzpyluEQBzLaq9VYcDA2TBOef8AFxjTNeviHqLertS+F3U1dKOG2yUm1scfiSZifyxp/wDm sG6i2UedhV+xlG9f/Zv5VuPdtoLOjKu7apYY3Y76r2pZzLULEB/LZhhuCcE9v+/rqL0vxJVt wiArPCLq+k9QBWOopcA/TInHHH5abbn4t3GtrJzQ+G3UMRmkBAqqqkQ78Y4zMf8AXvp/+Uww A/2N9UsYWQnb36qWyGQsSy7fYg9tElieM/oDnUIfxMvscgUeGV4mkDFZFF1oMg/Qfz+/HbI0 49P9V3K9CN63oqXp8xlgsdbc0llPBHAh3qe/uwx3wcaW7i2GaLMg9fwmDBSHkpBJEJFyCAB/ caSzUNLcKaopqylStpJozFNBNGHjkQ8FWB4II1pNcqwN/JoqNIlJBYzuxYnngbPz4+2twZ6g BvNt6q+CQY5WYsCMYxj6c/l76z/53BO06Qeh/CgwUgOyIKUlBDBS0sS09PAgjhhhQKkaKMKq gdgAAAPoNNs9EtwpJYaynWeiqV2vDIoKyAnsQfz1Ceoet/Eug8S6Lpyz9F2O426aietfqOsq JYqaLDbWiwoZt/Kewzu7YU6leeraxZ/Nlsltp8xiJ6emkqSM/iJDtGFweBw31P0MdxfCsHWk FHsFohg5CdG6+Khtzrrh4VLLPGKq69LEBpHdt9RblB45OfMjB9+SP6sj1aZ7l8Z/h9aqi0ww UVffoK8kQ11njWXfKAC8LozK6MN6cYPcasJrZ1Q9KYZeq6FQ7KvzEFkKSqm7kAmcryBgnB47 Y1QdN8AXQ0FYKqDqnqenqFqHqI1p5aZEjPmEoOY23YGBlj7c41nPHcPEdH35cuzVbGYDcSt1 8VfFghoetLO96WhanobyPONuqYshoWXCB0wfxJtLKc8sc6rS4fDjeOhq+e7eEN9XpmWaQyVH St1VprNVNnDFBy8BP1TPYAbRqTyXG++FdHYum+n/AC7nQUlDsqK64U7SvGqtiPeVmQZwSW2r zyeO2ob1548dQ2a4U1BVVZp6mvpJxSrFb0paR5VQ5VpJZvNyN8WGjOBk98ED0MOLjxEbZGc1 yHwuY8tPJHUHxGR9GTw0Pi10zdfD2uf0iskQ1NsnbGQEqI84YjJ2t2xydXh0+3T3VdnW42S7 0l5t8nC1dHUxzIxxz6gTz+euJH8KuqOounUfqzx8lp5p4QlXS/LxNGSRyN+/1j7451HLF8If h9bXHzniXdJ5ZD6WtrRUytxkekqw7A++mfumgdYX770YwrnatXanVttstJHFUSQWJ77S7zT1 NVVCCREbIKlwkgkBX+lk9+4IB1yt114WWG4ddfxJOoLH01STw76yKpuMfkRVAYlmjRWyQw9X O3HPbONQ+t+DboWpMj1PipfPI5l2NRb2jXk+pgSCQBycAaaIvhn+HERk3DxmuE8mc5jngQn/ AO5CRpZkZJo1NGHkYNQr56NtPgD07UpW3zr62dSXGJlkAo2cKCuDnbGSSBj6/nnU98QvFiG5 eHlypPDXpq53C4V8Sx0TVVhqI7bIrsA7ySkLkFC3qJI7Z4zqnfDzovw28M7PHN0j4gdSW221 Uq0q3WioqPdVSOSViFT8oWckg4Xd7YA41OeqOnrjBbHkt1/8TL/XFlRKK5PNHFJjJYemFEOA M474B1gkxD2OpuQDtJ171pbhDobs+S56pupfFi11FQaLpe6NFd6do4WoaLalVgsPOCuWUBg3 BQDJZcZ5B6e6V+KGmgtcVT1BQf7P3oUcUFcbrIUhqJIlYZikClTKRk7GK7sDYXxnSroK01PT tsttVdrZc6a+rSGlpRUu7pVlFebyVkYZjICswBwo7Atpr8Qehbn13e7bSV9mV6q9Uc1B5Ncy SSxRbkmml2plEwoKBw2SZV+g0iORoYXB47yNk8XM8CQbJ7uPjhfuqel7dWWKK53SlucrJRRQ NHTQOoUuX3TNHtXAPrIIJwAcnGqo688RfEah6WuFfPL0jYmgheX5W8dSxzVdTtBOxBEcbjgA DcPzGnCm/wDD58Pb7UV81Veb9T1CVkoNut8sSxwITujVSyOSNhXnPOfbkaM60+C7wc8MujLp ehbrxea6npy1NDU3IgSS/wBJJRVAGSMnGAPvrgycQifJ0fSE69n9rUMOGi2/QLji4+M3V/iV cAlYtss9DCD8y8aybXIPAc7sk8n37Hn210/8OHglUeMPRdbWdTTXmyUyyoLfJaVhpKeoj2sG KEo/mAEctnOeOOdc7fEP0x4W2zpvpqj6Nv1Vc+tZDm7UcMjS0mZNz/7xzxIhKpgE5A5wc5uC u8d+p/hI8MeiLN0/RUtdZbnRGuj/AIyJJnpakFRPChR09BZg4yMjzG766+JbiJ4A3BnI49uh oeu65zcgcTJrXYlnxg+DHTHhl090l/AYa56qdp1qKuoq5ZmqNioRvG7aCS2fSoH29tQbwouM E9ChnmJuseQFZvXIg4Gc4yRnHGov4ofGv1R4y9NRWi/Wmx0phmE0VVboZY6iEjvtLOy4YcHj Q8PvEez38263XW7S0iqwdaqV90kUgOMEdtpGAQQQQdej4Wx8WAZBiNZQTrvdnTXfuXKxOsxd H8J5JR8XPUQq+o+jaCNmiFLb2qJI3GCjyyEHI+4RdKvB63VD9RWMQ0lRI89TEmETAIZl5H1H Oop42NQL4qzJIIrrTNBTuPl1LGbdGGyhycLz9ddXfBDYOmb4a+9GgrKS6WYrFT0FTG2yNJFx 5oJyCThgAO2PuNaOMTMwGFfM42QNufYEjDtdNIGtG66ro9lVLUmFXbZLsZ3G3cyekgY9hjH5 g6Nkp9tQoT8BXAB+/wB/f9db01up6SBadGkdmZpHYALl2csQQMY5Y6EtDFIsjONspGF75U/m T+uvgD3B7j72XpugcdysIoYhn35BI9K8/wDec6bbzdnslKKkW6vuBXB8iiQPI31wCQP0zp3d WjiEckPo44Y9zjvkf9862fyjHtdWUDBX+sfb34/fQ2wb/dWIq5pJa7tbbxblq42qFjlXKrNG 0RTvkOGG5SO3I9tGmPlwzxeSQu1o3y2775GMaN8mnqAp3Heg4CZx+X56EVNHEzssnlkHBRgS Nw9iO+rzA6UFWQ1VBb0zxtJgKsxHG5lPb7HRElPvkCooizk4UZ3HTdfa260ska2qzLeFLfzh FWLC0QP2ZcMf1Gl0JaWiRhEKSRlBMUo7H8xkH9NW5oLb/CblA5aLaW2CUEvEu8D6YOPzH21y T8Vvw53Txj60rr71Pd/9lvC3o21NNHJCVmqKtynmTSInZOQqZbJ9AwDnXWzVHcEbWz2yRnGf cdxrmr/xAurBbPANrP8AMJSNeKpYZmIzmKPEpVfflxGPyzrr8Iz/ALxjYTRdpe9DnXkEEojL esF5S3a4S3KaHcgiiijCJEhO1eOTye5OSfz0f05UJQXqjnMy06o+fMkzgce+AdE1EfPYjj20 lJ2en319lJJ3XndlPr9BV3mP5phTqSoK+Sw5GNRRo1Rm3HBHB0jhrpoECAkqOwz21n52R2JC cn76FMLgUpVTIR2A+unCjiLcd29gO5/TTSJpieyqNegH/hq9BBrF1b1bXUFNLG00NJRVM9Kr yI6gmTy2IyB6lBx3x9tc3iGNbgMOZ3C6rTa7VsaXuACuT4G4bxQfD/R01wt09A8ddMaVKyIx mSF9rBlzg7cluftroXzJwi5CxsnpbZyD/wA9EPL54yV3bR7rjP3xrEKR0eEgj8gjkshIz/39 NfHcRiTiZXSEVmJPqu3GzKA20reaOR8R7gz4ABAOD7g/XSFUV2ZnChu4Lkgcdxo9/wDd+pWb PuoyV0SKVI08pnnlBzgySBsg+31/TWXpNOsU4ZqolGpEhVjtKjtw5b9hrSnklU5MmFBzgnGB 9tGLTPEuEYjHZXHcfY6z5MixuSkJzkhucn886AvN7pbgQVqJH8z+YQeQeTg/9dbmujBIcgjP B27sftrDQNlC2GWPngkgD9tFVOd+1SJITn0ohyP11ebmqAflsBKBM8pTlXCjA7jGi46mFnJK qxyQVORj9dESK0aqFkYMnJBbBI+nbWhljiYrysh77fp9TqA3qqD2/wAglL0n8vzQrbB3U5xo qU+r0RgLj3yNZhvVTSIVinnWPd6yuR+/sdCOtTb/AP8AWf8ATQmhsEBczvW6MUuEYjqpHqAH cv5C5ULjKZJPfjG4+wHGNaxXGonEuKmZaZWKbZfKKyYXIUKQ32H4l5H050nvVyoLFSVddcKy kp7ZTQPPJLUSoXjRAdzDbjCgKGzjPPYntTMHxueCYrFY9cxIjRmM4tNYrBi2d7P5XPG3sAc5 O4ZGPSQMxGIswxknuBO66r52M0kItXiWrKoeU01Wad3x5SkLx3yBz6e5PJ74xxjSyqpvNxHN /NaFDIYxiN1x3z9McHOfp+lF1fxieDAZIk64Wu8skPNR0VXMWz32jyOxyfxf9dTe1eMPT/UE goop622bP5qS9QWWsoogwJ2uDUxxoW9QICvuyoIzg6dLgsWB/tieP/iVYxMT6GYa+Cm0lRJS KfLmEUjKw3SBOMY7EqQf6vfHtnsdGFPM9SNKgnICRxOUQAg4yCFyTjtznbj30UtWiU8MpmzF K7kTQhZHICgndsDA+nHqz9scYGKiSKjBRnUTsdhbawKoQODggAgFTk5Hpbt/TyshrXVNyEhN rmSWqiMFC4VSAW80jzAD3UY2N/UcsQOAQG76PkqJPPYsoiUnHl5DMo445ckk98DAG0jOMEmz Q0dMjn5ekRVZiNzAtnO7hQQSSAvC5B4IyMZI+ZkQRuqyPGGyqwSosZXJyFbgE9u5PuO+ciYq qh9lZgcdWn1W811nhlAepZSrspjH4ywHYsCRgkZOQSuSPtpJSXMTrEBMisjbfKkbJdx6gD3O PwnHJO085GAonWKZpYnETsYSF2xmXC8AHadqkc42knse4BxuberEzCGIiMBnl3lcqCOQWIyO ABycDuTjmMiL3hrWkuJ2Gv0CyODmav0HNaPcHijeby2EoAGJM7F5GcYJxwe+3OF4HbTVUX64 M+wW4Rbl8zfDVRI7DOAMMAW2lkOcbRuA/wAQ1D7/AOOXQKdVy9NQdUUNzu6ANU+RPHPFASGI DShuDuVck+pcAf1DMmtHUVpv4jemvNuelkOEjIAVowABh8KG257DAwD9ca7X+Cx8bekMBI8L 9aOnmsgnheazj6KOdQeK3UHTsNTM3RVVWxx4Bhp6pJS3cDHYenaeCey4PsdZtXXPVN+o6OWH pmsoHDsTQVjFpQiOiLJgDA9RxgngKTkA8T2KChpZFVAYKSJ1aRdvltMPScsxBBUENnGc+rB4 5ZHhp40iNRPWQywwfzXmlA81corCRxHtcE4UAjn9VGuXbPhe0X536WmdG4mnHRRG4dc9Z00T 11TZoKKpoy8jx1DMY55AVGV5GQd6qT2weTgHVaXT4gOtqK4yPDV08yyII44VjHy5w3dQWBBC uBkAg7VPvu1el/N2rTkVgo1hXZGXl8xDg5ypHCYLbTkdgDkEBlr7qrwKXqismrVvcKVFSRNU 2+rKVESuV4jBKliAfUf9DtJ1x/t9nAIJojdA7Krrh479YVtI4a+gxTMsXmKiiRtp9R/B+LK4 H/uPuclLP4+dYQVVEFvMzsih8vDE6kZDFiDzuBGQcf4ffu83Hwa6rsqTyQWWnr6eGo/l1lHF E5kXbtUrEFJjQjOARyW4wMahFxt16oKJqC4W6mip/wAflS0dPHUK47K2Rvfk5AwMHPHBx0oW 4dxtoafT8LOC8JfN43dXRU7777UoVYMjRphVX2wFOG3flnGR7nLx1D8X3V3UMU0cFstMHUsd M9PDff4aXqKYbi3l4B7L6CquSMx7mDYB1D3q76KiWGGurINsjBYKSZosMOCQuApPqHqXt9h3 Z2S7rUTOk9ZXzysadpPMaMyI24lW3Ox5IJOTg89jrr4eUwAtj0vkP+JLqebJN++9Qjw8vfXH h1TXqLpu810lRcalauvlakSSSpkTJRWZtwIG5+Mkepu+dXd0bdfHfqKgqbtbpqaWKO6Q26ZA IpTE8kQlWUghgsZCoWcnJZ+xI4r7/ZW81709NT09wnnqZREIoql9xcn0hVyC4P2xzgexx1L4 XdEXvwUo7nZGoLd/H6wwyTV0tSTCkgiG1RCOCkTSMNzyR7mZsMRhW6uFwox8pLwCOZr5LJIe haACVa1hs18qegounYLzNZLzX0mLjX2pFFbNKV9cdNJIXWFFJ5YKzEEsPL4AhPht8MvTvw/z 11xtLXK+zXWUQV8twnjmleIEuwUqil0LgF8ZLeWoGe2rg6SprlYLXVsrUlNUPtae4VBDucDn LHaCoY7sqsYx+GMZLar7qfq/p6ouEk9v6uhpZLZRh6qYTSPHNPgoSSihJGK4wFDACLCovlg6 9nDhosMAyBmUBYHOc824rnb/AMQDruzSr09a5ZaK5C2CrraqjpCzfL1EcUcdPGxxjPzFRvZC c7EwwUnB1+Gvw8u3h94YWvz4aVZ7lRfx5RNUhl2ztEFkIQ71KosIZcDJOMnnEe8YfC8eNnxK dN/xC8XCPoe6U8swi5IgaFVQ+REN3lrO7QsDgnLsSvpCnpXpR7VWW7+AGhlpI6XFKlYj798a ZQbcDIUbISQGIYxIQPrGAlxNaqDQLjr4pup66fx56wm3sIWljjjgZWYIvlRk4JOBjLE4Pdjg c6ffh88ebjbJk6PvtwSntcjZtcjz4SCYkkxHthXPbPAPHZsixfFH4YLj4hda3i/2+vio6WpC pTmrXzJ5PJhjiXeEHDuFZsYz6gMZJ21TePhS63tmY5oqSvdS21Y6ldz43EBUOGz6WwCBnHGv Cv4hBDintuiCQRqtLWTZdGEg9y7ZsdXIIVASNlAUMTKrKGz7YP3Gp30l1KYLijM6pHKpVSDk ow7Zz9DkY/P768ramw3vw/vLR+fXWK4qQxSEtBlccDGAOeOD9OdTfw++IPrPw0kMTs99tKs+ 6lueAwdnJYpIuGU5J7gjJPGupHj4nUQgzDZy9XqXqSKBWjVSwA3bc4HbsP20/wBhrTcJGmSJ mY4LMCAAcZ9z2515v9I/HlK9wp4L5ZGp6YHy3rKKfzGUYPBjKjcDx/Vnk/XXSPhr8VvRnV9v BorvGswYxNS1JEExI99jHODgEHBH34OtrMS2TQFMyAjRWv8AEJdYWsFnt4dHkqa0vKhG4eSk Tlzj3GSg4/xDUP8ABOyRWfo+S5Gnip6m4zSOkcf/AKcIO1VHsM7N2BgDd7kbjAfGq8R9d1tp u9HcZ6ZbVSV1IzRTjHmTmKMFuf6dm8d8bQfYZsjoyrp6DpSyUSVEU8sVFEk7ooTfKFHmPt9t zbmP3Y648DW4jiD5DrlAHmV3pWnD8MY0H4ySR4dvyVWeKPwoG/3eO4dFT22ywVCla2grA6xI /B8yHy1OAfdOADgj6aM6a+HHxLsKoKPxCol4A+XkNQ0QOBxgqR398Z1flFcUkGNwJ7gg99FV F7F2lmoaNEdImCVFQQfL3Yztzkbh23AE5ztOASR05eFYaYlxbuuA2Z7NGlRDo3oPqWpSGlvn UdBW1QTZIttpXjAUNg7Zm/pO3G4ICTuCcgutu2Dw2slmpXKwCokePyS9QqlQgBCoigYVACQA Bxk5ySSU1nalt9OkMLkFvU0pIBkbABY4wOwAAAAAAAAAAD3DeFjVVDAge5P21IuD4SAWyIX3 6qPxEzxTnFQ+/wDQrU0jyWeQxysPVSv6d2BnCP7dhw3HHcY1Bq81lLVmmusE0MisCIpCcbfq Tk59+2QOdXX/ABiNiBkSEDsc51WPjH8RPhN4W11utfiLe6GgqquB6ukp6mhkqSUU7Sw2Rtt5 yB2zg4zrh4/9ORS2/DnITy/j6cvp3LXBjZI+q4Zvqo5K9KCDhN8UnCkkkjB9/wBx+mgvy0ZD AGowxIxIqqN3IAXb9B9TqddI2zoLxUskd96Ru0Nwt8wwJrbVEhMgNsZDkxsMj0EAjsQNG3Dw cLsr0N7qqZ1OdlRBHMv6YVSOw9/bXlX/AKcxrDYa0+B/NLotxmHcetp5fhV49QJI2RlO2LIU ht2OeMfTsOf762pWiWoDiJGjK+pUZihJ/M/qfzOnq4dB361UzebSGsjRseZTDf6cd9oG/wDs ec6Y6iWOCs+Wf+SVH8zauxlGeMA4O7AHBHOP34cuFmhflkFeIpdGNjJTbHg+aE06NK7KzM4X cdhDMcD6tyffB5/TQhq3pJykGCxyAsrerJyeQDohmkkqnWCOWeNwDGrweZj7bgR37Edhz391 C1ctLU7ahJFiTDAPGfTnkHOBn/TP20t0bwdSnmAgUSlVLIiwtmDyhvw20+oEf1fXse3bj76L RApHkl1Y85WXPp98e+j4qqhkRHgn2tkAlkAYHOM5UHHt3/fGk4nljbfC6qc5KqdyliM5+nb3 5GffPGrMbtLPmq6AuKKYTKC4dPKEhXDZB3c/55zz7jRwE1Nw4aU5GxScbR9x9c/bRjXqRl8h vKUsDGsscAGCBnPbvwf150kaYyyqJ5WqFydrSE7v1PHH0+mTrMQ0c0IYWJSKhYtryBo2KAys V7g9uR2/77Y0X82Ix6HOyQZBLE/TngcDjWUEkhaVYvMbJJO0nnGT7jjJH20W1XEkT1BDIQQA x3N3HuPtospOya1l6jVJJrbFcZJQVcSSxsgmUFxF6TyQfT2+o9uxzrma69OUVp6esln696ch vdBbr+8lRdqrMJuDxElfKcYbcq5XLAKVjb2yR1Q9QnkiIyKx77H4RvfPPGD/AKaq34gOselu g+jEuvUJL3Snl86zRUzZq5qkDbiMEEBcHDEgrtf6ka7/AA3GTROGHbbr0q9vD3skTYeNv+w8 lZjXmnvdKLnTSpLaapBLFgFlWNlBUlmGcYPv2z7DjVTdUfEn4Y9A1DRf7ZQmtjbyxb6JGrUL Hunp9C4/4XXBPOe2uPuu/EfrnxsuNVbFFRFTTylo+nLMS0bjcv8AvpFOHJOCSQEJXIxk6d+h vhA6ynqaWpuVvSjtAYTTrC8cdQuRlsPJtX2A3DeBnjXdh/TrC8uneT3D39qXHkxtHqD1V5H/ AMQjo2KrZZbFe2hWTyklg8kiTt/SZBjP0yfz1T1NL8OXitbbhQ36y1fSkzXuoulPPS0u0FHP FOZKdXwhAB27fQTwSAcyGm+FeVJ4yl1sFZESc2j+LokjEgncjtuKMDjON2cY4HGov1D8KHXN D1UlUlvo6W3Tu8kM/m5WnBP/AKskYKnjbyO/svca67OE4eEHosze8ErO7FPfo6q8E/2/4dek 7rbrsnhhWr1J0rOTTXTp2apenr4juDDZMpXzlBClRKGHpypJ1Z/TfVNxrLBa+lYL/NUziZbf svqutypX2s582ZWXeNqMmTGGw3JPvyd/Cb54edbQWytrXpLhb61Y5bnEQzoN4BaNgpMiFSDj GTk5HONdg2y3WzxBe0m+XGSS8Sr5VJ1LYpWjiq2DOiBxgpuVg+APSSTgDIBTiInQs/3DpGDW 66ze/v8AehQ2HnMzqn5K86B7vcLnHDX0VLRUxViXpq9pi2MELtMSek88542/fIbLRb5Lf1Bd OoblWGp+ZVaaihYfy6enEhOV5JLSEIScDO1B7cpa2X/6OeEjXPqm6Jca+CRYjWtGIi7NJsQB RnB2tzjPZjrFk6tpOpaIValTE8YYbVEwgQjspQnDEcMSBgHH58XGYSfDYLJhwS0klxrWuVjc d/sLXFMzPbjqozf+i73fOsZ+rrf1fN0bStHFSSU1NSQSO1HGSWd5JFbaxJ3AgYUKB3J155+L vjjW/wC3XUVps/V176p6ZWSKF6uuqBI9b5ZY/TAiMjEhRgHK59sda/Hz4zr0D4PLZrTVutz6 okelWencr5VMu1puf+IMqY+jNrjH4Y/BybxE6hNyqI91LSyKkAljLo8x5ywHLKvGRg5/TW3g MLjAcTPtsBQ2HNIxUrs3RtKY/DzwB6p8SrjBUlTa46uTfCZ/VO4yTuVTjgAZ3MQMDOddV23w Nq/FFOofC/rWqkprlZbjT19FO0g3IkkGHAYbsowIIVeAcDPA10r0XZ7B0jZ4yHoTXQORUVUj gGQqSCSG5BUNgD6E44bUI6l6rs8fjl0zdKKrjqjXU0llm8vH8plIlhycfXzE/IrnRDicmLxR ijblFGie3t8FBEIWEv1tcr+NHwO2zwxscV3PVLwUMtQaYTyIZkRhnG5QoIHB5BJ47a596w8M upPD+CG4SiK5WOXHk3e3OZKd8gEAnupwezAa76+K3r9+qeipemBZ6kVAqJqhqhIy0YaKCXOS Bx6jjnknGNc3dEU1TYjDJVMkdurbbEtRRSnclYojC4MX9Qz/AFcfY69dwbDYrGYVrpT/ALLI 9DpsuTiZY4XkDZVp4e+I9LTyQUl6iSopz6VqwAaiED8IVm/p5OV7H2wdeiPwrtFaOkL/AFSy 08kdTXgw1KTBfMjESkbSSMjLHj2OR7a86/Fjw8oenAvUvTHmv03NUPS1FJJy9BUKSDGWP4kP dW/TuMm5/A/q/HT1pt1RK0sdVB5lMJo2j8qbcUwi9nV9uCR/XjtnSuKQvxmDkwp0P4N0mwOb HKJCLC9BZPEawQ0ayPckiZWw0aneTjuMDOmSv+IDpOmnVQaieE7l3JDxkew5BGuWobxMC0rT M2SEEMQYng/XHt9xo15I6qQNNLNFhdwKqUDD64PB18zj4exuh1XfGJdsAKXVFL43dJVA8s1d VSbmBV5qZ9v9s6faTr/p6v2NBeaFwvrPnSeW2382A1yZR1dFTUVQKuWrat2f+VlSIeWWB/rz zjHbH002C4yTvGjvDGgbHleXwf8AIjVnh0VaWEQnrUhdq011tlyHmJeaPcWztWoQgZ+mDz+W nOKgqLnKVpIoZJNgYsJAPbuGZhrhv5tmkcFEZYyGBGFA+x550qbqOsMMfk3CWFcFNkc7Iw4+ x0r/ABjNNdPfvZQ4mm/Dqu3JiLfI0FWksUhxkI4b2GORkEaRSVNOzpFK4jldS6qB6mGe+uQb V4l3zp+EGlvdZE+z8L1BkTH23ZGdPVN8QF+iSMPXw1Dx8gyQhzz+RHH5aQeHP/jt730UbiWE dYLqlqWN2YLKJiBna644/wDw64A/8TLqKFuoul7CFbNNRNOsWfTGXcgkj3OEXH5nV7U3xF3e ERz/AMOoPMb8Zyy7mH68a43+MvqWTr3rAdR1ESU9Q7JTeQjFwoWMDAY44yGPbu2u7+n8EWYw yOGwPz0SMTNE+Ihg1XMs8Q9ROPrg6bZQA2R/YadZwSpyT+Q03T4GcZz9/bX0dcAhZiXcR9Mf vpTHHnsMac7v0dcul7bZK6viEcN3pjV02Cc7A7JhuODwD+TKffRdGyxQTFkBLjYGPtoAQ4WC iAPNIlUZ163/AAU9E1fRPw89ORVdUJzcd91RFORFHLyqD9Bk/cnXkiBtcA5C5wde53h3R0Ns 8POmqK3yCeghttNHTsVzlPKUA68V+qHF0UUV7kn0/wCrdhIhI82dk4yROsuV3FhwBt4Axnvo lagswV42Ve7NEAw4+unXzIIIvJEqIcZYjcAp/wBB9s63VIAqTLWxOB/SithgfuQNfPeiGpFe /NdJ0WuhTXG7vlyW2hidxP8Aln/LWyGQbk2q4HO7Axn2/LTlUx0qhJZAJFPGdxJBHbjvjRTr HMF8sBfcBmAx9e/bQmKtUAhcNc2iQxSo8hMk7rnPv21h/NhyVcAZ4YsPw/ljWZKWWWoAPmeX gkEYXH66wYJ5uJFcKBx6eSPf350kNsKgxxO6E0c5hAErFTg7gQp1pNLURqnlgbVXlieT+eNZ gpS0TJG7SKFIaHacn77T31imgIDKkm+NTtKsh9J/01eUgWCoBJlOl+qKhuIQlJ1d24KyImR3 5BHcay10ggk82QwiA8GTdt/Lv2Oj4YXnaRJIy+Bz5fLfbjSaWlgZlYxrvHKnjg++hNinEIS9 5A7vfNag0UzecAsdS5wfWYmb/wB3OO2lirQsozMN3Y+Xlh++dFJQLLEVZN4HdX5B0mj6diVc KI1H0GBjTM42olXmaazBcw+JF26j8V/DCWg6ut9Z03a1rporwOi4jXPUIgQpJt5/lE7zv3MD sx2I1vYfgL8D+jYaHqLqa8XGsom8tTQdQ3aCggMzDAjfYFbcTkhQ4PGDnB1NuiIqeLommq+h 6SXqCeOKWlqrLJJFbLjLXArUxxSU/wDLWKQbagbFBDRnjzAFDeffxU+MXWXiJ1NTUPUUElkW 2PIBZAjRfLy7sHereouBgZbn6Yzr9HZMPhjpGLOvZ4ns130C884vedSvWnoaht9iSro+nqO0 Wiz07BYqSyxJFCSed+xVABxxkFgeT7DTobs9TMZYDUrtP+8jXcmfoQONea/wIeN6dG2uu6br HqWp5a75nZTzNG4BQDOe2AVPHuSPrrue4+PfQfTUdBNcqw/O1yE0gliYeYAcFUl2iMkcAgEk e+uyx7HND2pTmFWMlwd1HnqxYuSrw5yPfv3zx9dFtaKsV4q6GpkqIWAQQPAEkjwDyP5hMmBn Ppzj8himur/jA6M6et3zRs3UVzZSQy0zIgQ59yHA7/Vf0Gqtu/8A4lNhtE8SweH94eB8gzXO 6+Uuf/jFJx+n+WuZi8LgcSD00bSfAfm06KWePVjiPNdb2u03CsmHzJitlfvZvJjyFYZ9shN2 c5O4dzkkaIuttrLXLm4GuoDEdkswRcRFgSXbbx23HO9h2Cgkga5E6c/8QezXO6BrnR9O22iZ AVihStmmH+NdwEa7mOMEqAMck8ZvK1+Mvh940U1to6PxCpHMcbPJR1EkNG7S8sS6Mw2Qxgeo qN7Dcc9jrjT/AKe4diGgwjL20T9CT75rox8SxcerjfiivFj4gejvB/psV96ray4UgkWmhjoV 3TzuVzgZ2rwqn1BiUypzlueCvil+Oe/+MkIsVgjn6a6XRTG0QlPzFauThpSCdoII/lgsAc+o 8YaPjV8aqLxB8U4qW2yJ/DLFTx0yrTOJYnqiimofPY+obCRkHy8gkHXM4aSsnIVS8jtgAdzo IMJDggWYcefM+fYs82IlxJzSHy5J66cuYt1U8nzctDOwwlXCWDRZ7n0nJyMj9Trsj4LfD2p6 36+uzzdVdQ1VrC06mqp3aOKtnfzCi+XNG/mgRqpyyrtJOMjDFk8JPgmpbXS2q++IPUlus1wq QjU3T9cqmTzGbgsmT5hUFf5bADc3O8KUfoa7fEF4S/CDUy0FsjrOo+oo4vVT08m6QSkD1Tzt gq7FfV3IAUBVCAa60TTGQ5+gWdXb19SV/gr0Jb2grKCsqIykctZFQCjklLbsekOwYgRuzZxt wBgZ4r7pf4kOn6+pRr9Qy0BJXfVRxeatQAu1Q4zlQRnI5yT+eqgn/wDEGpPGynFj6g6Th6Zt wjeIXKC4GaWJZXXzNxkCr6lTZu42gn2ODYvQ3QnQXUlxqWtnUVpuSQAH5RLtTVLAONwGY25I yFyQMHIBOAdJm4fheI30zA47XsfUUfWwmRTy4d2aMq3rZ4pdET1crUF9glp6L01ES0z7QRIq IeIvwHG1W5HKgZ4Onnp+9W7qKmc2mdblJBE0rusbImARySVPJJibBBOPqFGmaviezdOGnt6w W6miBiEc9OkkUZBYhxGw2nBJwR3y3POdcgeK3jX1f4edTzWfrqmmrBUpmmuFojFLFJGF/EIw ojmxuwQCD7EjAGuDN+leHxAgueb7x+PutX+RlfoQPfmu740tk1JFU211kpEcSGSkZGGQDt24 GCw9H7Y7aTy26zXWSR6y3w1rlZCfOpiUyQu1gp/CxxweOMewGuHfDPr2etpLZS2a8vSVbwxp JPRTvEyoAo3f0mQYznjuoIBwSvTts8ap7n1k1ujWjktfy9RUtUVQ2CERwb9gPZVyrbic4RTh TnGuDL+k5mtL8LICByOh+4+i3R8Qi2kBBPZVKWVHhd0rUnzWsNugYCRjLSLsYgqSfw4AIXbx yBj6jGkh8EegKyqkWPpSnwimBZDIN2dy5VSjcNkHkKCBgZ7jXL/WXxCdd9T/ABZ0ts8M1WW3 0fT0U1bZ54hNR14QyVI2hiNhzNGgkBRlbODkAGa/EPfeoOofCW7XjoG83qiS7yruhhkanltc cfplonRUBUpIs+51CsV8sMWBJ0eH/TsmVpklI7Rz05A3868kMmNjaCGsvvTx4xeN3Sfgn1A1 p/8Axb0/JBTLMKi2WYVNTTzM5VVYjKx7kVshiH/ARwcA2z/EN1deOipL7bqnpSwUziN6K59T 29bSaoEgGZEErM4APLlFTlsMcHPEFm8COvulauK8VXTM9wussQntyO0VygmlbtLKF8xSq+rh xjftDcBsOtB4RV3iFPXXjxV8XrbZKtapqVrU9Q10ujzK21VWkhYkKcEL2GFGBtKk+0wsTMHC IYW0B632k9q473GRxc7dW31R/FvGkV1d11472mhtMBUPSW2vSdBJzsURxOtMGOGIzKXIQnGM 6aOr+kPDfwR6jkpr71fdLlS2oQmpSimEtdWvJGHjiMbN5aGQF+TjykpATlpUJiF88DqWnpqm y9PXG6COxwtdpzdaCK3zUkxLLHEyh2bzHTbJvfDIihggBGqJ6yqb70vdHhr7dTq47x1hir1Y MQxZXIKhjgAsmCcEE8Eae59a80ul1D4EeNNN4gePd2uMtRc7Zdr3SzU9HQSlDSUqIyEJEVxt 8uCNhkjnBOd2M9WdP3Gx9XdXmO31H8RFNmnlalk/lxDPCs6khic/hH0PqyMa80fDfrWmret7 PX3GhoY2pWVkWGJKfztvpWPCAA5z37kA53dteh1B4ldE2TwMF+vVnp7S1ZQ010qbnZcwEPLI Ul8sQY9W8R4jJAXzlVlCprVC6m5io4KTdd+MVH4d3Ortd6ss1RK8yC001BTb5J4vKjBkdjwP 5pmTg52heM90EvxCWmG6xJebV1JZZd3mrTVNEI5Gzko5UPngnA9JHpztBOBzb1X/AOJFZ3sd fDbOiZq69mGSior9ca1Y6qBWTa8ypHFiIscEIjHBXlm41XviD8bl7uVm6dr+m3o6PqWKSYy1 M1uhnlpoyqjy0eRTgMxc4GcKq4I3MNeKxvAMPiJJZ2u6zjY5b+H4XSixjmtawjQaL0CqKC1+ IFJS1rWynaOR2857vayGMZDnCo43eWWKnaw/pDYxyIZ1d8OPSXUMlZJFaKmyVbSmZpKSM7fu Bu9JPpHsOCffgTbobqS8QWbp2i66p6Wkv9wpUMJM5p3qpCnIeIriObYFYxqWwHJGNpAVVfiZ 01aKG73CXqKlrFtdKZ5aOOVWZlJIjIUMAFPmKOcqDt+vPjxwXikchiiYdOY29TQ96rpOfhHs zFwHlr8tVzz1N8Ic9U1RNZbtBVRK+UhnjMbNkktlgSuVAH0z6vw8A1X1T8N3UXSEZne2y1hi UtJ8q+/ZgEnO3vyrDt3wM5bnpfor4hqHxMuU8Nk6UuckKbyK+J0k+Xkdh2j4U7guGBfG3tk8 ilOo/jgufRfXd06ev1poOp620VT0YayTzQZAVR6CThiCAGUglWU7Sw7ddnC+LwtBc5p7r19a r5rjvEDichTp4bdR2/p/wTqqGqaGKpBq66WnY7pZmViFDA88ooXDfRMfaHJ8UPXtBBRz21kp XpwPmZaxVnFT9AFREVFz/h57er69NWPpuzdeVtpuM9jSKor0gqjFO+HjbyQ6pIcjdghY/qcn 6nREngb0n1TFJX0VljhpIVKJVUTCP5h+wZB+FkXj1kEEqcAg7tYYMe7DyPLhV6k9n5XquJYZ joMPFBYLWDNfad6rlpzTH0n8YdtvbW6zdVOnRNyreJJVkLowJAUBwv8AJLkty/4QAc8g66Ci uxsUaW2lh2wRJmCOH0jA9gR9ee+fr765h6j+D2zVMFW9BU1tFcSRFKlZD50LTcElj6T3O0cN lj2JA1IeiJvEXw6NtsV8SHrbpyKJkWrtrCSto413BQSMbwNuAhBbB4Ppxr1mE47hpKbI6vH7 8l56TBSsbmAtXpT+L1op6gR/Nv5oHMbnBXAy3f6ak1s8SqXqaFpLXiqjRmBkVwVyBlgWzgYB BP5j3IGqzobtYLzDFi5QQTzE7UroBTVbkHARVmUMxyPxHOCDzqL+IHVFBB03WUtF1ZZKOyUp C1sNNc4xJKxOfLd+Su4k5PJJJJB7a9RHNG5l5wR3flcxwcDsrlvXjvZOnbVdK6Wo86ntcEk9 TLF6vwrnYnbcxHYZ515I/Ej41TeO3ivc+qq2M08UwSClow+4U9Oq4RN3u3djj+pm1KPiJ8RK nxAmprNaqwnp6lIlK0yvHDNPjuqttYhFO0FhljvY9wBz9UUVTCxzC7AkkOF3Z5PcDP01zpcQ 2R2Vp2To6G6s/wAJfHnqPwYvUFX0tfa6y1C4WUU8m5ZEzwHRso+MnAYEc9teo/wef+IFaviE rqTpHqS3Cx9buj+W1Od1JXlE3OU/qjbAZtjZGF4Y9teKVRUzR1JaNJUGcK20gnVjeBfip1P4 N+J1n68sFtprlcrb5vlw3BCYnEkbRsSFZTna7YIPf66oOA3KN1OC+iLzY3OwgDjOAdYNLC5y CST7liTj99edXRX/AIoHSXU1J/D+vugb30zUSSCRqiyytPCeQfMLxmKRfUOwDdu51070F8TP h14m0tJT9L+IKR1MhMcVDPURpWkj2MNTH5jHjv7/AF1MxOwvwI+9JeUcir2aj2DieRPyI/1G k09PUhfRVCQH+mQDt+f/AE1X3UPV1R09Z6q6VvWdptNvpYzLNV11tzsReSc/MAZx9B+ntqtb P4/2TqV2ltXjHYJ42UbVmp1pWUk+4YHP2GdZMRiOiADonG+yv/8AS0Q4d0mocNO4/hdCi0CV T50NPKc52zRhxpDP0/04EkkqLdbIvLGSfLRQo+/b++qv/hN06qijqX8QjUx53AUcLNER9PRI Aw/Me2kc/hdG8h8m4WyeE4O6pZ4GQg5GMRn9ydcefETAdTBlw/8AdX2tbGQMb8U1HuB/pS3r e4dJw9OV1PQyWyK4EKUeKNc7t4HBHvyf76rc7nMeIwT32+bwCMexx7f66eafwku0qp5TUdwE ef8A8nrQSuD6cBlAPG7uf+id+i+pKCdU/hcsdQ84Ify2KqCcZZ4ww7Ej7Y14viAxWJeJH4fI NtAV2sIYYm5WyA32lJYkTZ5ix08TllGG3ZXv+LA49+ew+ugWljXn0OHGDnO7Hbn2/Y6WXGyT W92jq6q0wzbxKN1YInbtndkAngfbtpO1C7JvF0oPLY5yaxGGPt75AJ/POuO5sm2Vbg50m1V4 qK9b9dWnw/6VuPUN6aSnoaCNXJjy7TEkBUUHGWYkKB/11x90PYbp8TfXNV1F1Zd4KeSqV4rf BRyI706q5IjSIZKKo5LNtLEjkgnM2+Lq4DrnxQ6e8M7XfKbyqGFq65TSx4iEjRNIm4kZYogY gfWUc/SxbVRW/wAK/DuKS0uKRWo2RGixL8tAP99MGAUs7FdoJ77BjbuwPofAuHiGH9xIOs75 D+15vH4gyyCMcli22Sx+H1VF0v0BY4Ki/YCvNIgkhoyT+OaQZLuPuQFBAGOxeIPCgXe7VEHW l2rOq61I46hRNK8dGhYuMLAmFxmNhk/sCM6abR130H0LQGnn6ko4bmzZkLOyyK59Srtw24Dj uD6i3I3al9y63iqbFTX1IfOR6XzHlo4jN5iRyREqV5ZCN0uO4GSSwxosXPNjIpG4e25SK/8A cOfu0ccIw729IN/kUm/+m3S9OnmpY7TDHUx/w+UQ0MZKZYiNgGU4bexUnGTvXJwg072i20Vp qj/BIP4DT0CPDHHaSUiqZWOWZ1PpcptCjIOCX7HBFS9R/EDBe6D5Wx0aJJXEKzVc7MW9QJ8s L7bQx76Y08eOpFVbYJ7dSmMeXJNIwQ+kACU7iTlt244BOWPB15WCHGAtc15B8V15XQbGiPBX V1X4f2bruib5m02mp6iVY5vm5KVVp5pUIIG4ZaPONu5W7d/tUFzrJ7Pdbmb3bLxUS0zSNNY9 i+Wq42JOq4U5G3aTlVHL4yDqJXnr+o+bBXqGrratVLJKZGjWI990cS8nBA9Tf/aDzq6eoLmv jr4JWXxRtMEct/tJNsu6Qqwjq4QxjMi5ALAnsRxyy59J17XByTSR/wC+sw5jmPz4LiStja/q DQps6x8Rvnul5ulutaePqK2wx+WsmAYquIgDMjZz5kfADD3IbuATzH0/1N1R4L9US/wiWobp ycmooagsaoUcftDMF5ZBxiQD25B9rFvVAaWirLfHRmktFIGuEE9VP55qY5W2lEkLl8jHYgAe X2zjVfNTNRs0W6UtE+SPN28A/wCEHIH2OpiJH4aT9xG74vqPpp90siMs6N42Tv1inTnxkPTL L1GOl/EC3U5SCKdxNbKwctgoSdhJ/qBPbs2MBVarFUfD/wBIdP8ATlyeGl6jr6o7oIhG0Uh5 Lyhh/SAox/7sYB41yj42TS9PeJcdwtEklJVywRzFoT2l5BAx3PAz9yddY+Fl/wDEPquw9OQV nhvdOvLTWUZmqGqKRYzSndszFM2FJIIYAFWAz37667Mk+HAAAseWvv8Apc/N0cma9kxdXdfy WMCoNM1TWTSEeRTyYYnHDAHkggY/QZ7acum79Sda9PT1SVMkV+tr+b5JpzFItQj7lLZwTuCg EfXOpdP8NV9PU093uVRauiKFZHp7Ra71XrUypEVG6Q7S2XPPp5IH9R1FOo7J4WdASw3q8eJV 2r6uJPJefp23GH5h1fKjfJlHIwQWJz2z9NZ4cH0ej2/b0Wh8rZDbfor6vUp6ns/T92pqmqhW 4UyVoqKRC0ZkXanfOM4cEKwwSM5yOKS8R+iJ+s56+8pans9dbzxWwYZbnSqW3o8Y5imQDjjn OOcA6fPhy8RbV1N0ddum4al5YbZVvWWinr3R6lKcFtwfbxtILDB55I7FdK+qOqbJFc7jUtVT +bR22pryEVgk8ZjKNuBAGWIyB7kkjPGuzhcQ+GQFjqIWKSISMoi1zL08aSXr+42a8V9FLSdT BrdX0gkGyiYginKA4yyPt9WPr75Ool0TXVnQrX/pyrkqoaq315hqGQb4FWNm3A8ZQlgCGBxl RkatT4OvDw+MvU94nvlfcKW1UKxzLHTqMNK7ttVDIpAUbW7a7ag+EPwtuHVld1HcbDNX3KuK vOaiskET4AHMasAc4yQcg50yYte4OYbPNLZYBBC5Lt1aep6OCS3wy1E1Qqv5cK+a7Oe4wvJP /edWdQfDN4gdSWqWpiscojVML81IsMj5I4VWcEfqBrt3o7p6w9IUa0tmsVvtcCgBVpYEhAH0 wq86lKP5g2sm33PqwNcZvCGSPL3ONXsFr/cPaBS8z+qPCy89HQhL1RXS2IG2ZrVlEbHPAEud v7E6SUPR94vdJJU0dNJWU1OAJZIBvdc/Rc5I474OvT6ahSrp5IXjEkTjDQy4ZT+YPB/XVXdX /Db0J1AklRFa6jpqtfB+csExh2H6+SMp/wDo/rrPLwZzdYX346H8JrcVejwuAyJaOoWklgl9 Y27ZE9R/f76S1dFQC6Cetgpo2QbdrIVkRj7gqQc/fXSnWXwreIEIH+z3VcHU1ERv21VQ1NOp HYKp3KfY8uOfbVS9SeEniD0/LLJfukLlOuNzVEFOavP3Lx7sfvrjvws8OjmkJ7Jb0DlF6eSj np18qojmhU94ZfVntggn99KlSOan4hQEsMMxOCOPftpipbfZv5rrSqjsSHEajv8AdTjJ/wBd OsJjWOOKGoiAIGzeNu38hz/prHkvZPDS4WBYRstvC07FJDTqOXTIwRj+3565o8Zb7TXuhimi n80/MZwg9sH9vbXSdbCyW6rMk67BE/oUbAwwffH+R1xXdrksFPUxOpfcykAe3313uEtyh5Pc skwyjxUdmclcBR37nk6efDroyXrjrO32tFZonfzKgg8iJeWP7Z/fSBJqeZDmQQjYeWGct7DX Z3wa/DH1JdOlp+q5aWkpIbwAlJLVy7JBCD+MLjszfXGQM624/FNwsJeTROg8VniidM8Maq7+ KG2o3QlkkjpvKW3VggjAbd5cbIRtH2/lr+2ucp4mgpUB4JG7GvULxk+FaiqvBfq+mFTLc7pD QtWUywgDE8Q8wKAM5zgrjv6teZF1dWcbfw7RrDwbEtngLW/xP9rRiYHQuGbmmtl82NmHBxyP vr2B8A+jxZvDHo6rWoq3qHs9KSKiZtqsYwcBc4wNeTnh5YqfqbrixWernFLTXCthppJmOAgZ wM59vz17S2m1VVHRRUirBT0tOiQRRqS7hFAGDnAzxrz/AOqZnNEUbe8/RFhIy8l3YnETu7At UMWc+pXQcY/z0bGPKYeoKh57AKeexx20hq7VFJHFDK8qAjI2sYyw+h2n7aURRSUkce0hoxwo ycgfTJ7n89fPS4nddToz2pcqM9ON0ZZ939R40nlo4KsFammDuD6c9/0OtgkYplRJfIc8qxyo P2Pf/v30YjSSxkSMrMOFkVtu06uyDYROYd7RqyCKnCpmGLGNy4OOPrraCSI5KszFCRtZPUfo R9dJlpBIrbtrHdlQ2OCfy9tGLEYpA0pBYEhQV7fT9NEM3MKhmA3SlDK7eY+EVgCABgAj662M fEhaYK0n9O3kj8/caT/OI+9JffgFBwD79zrDVFKyKI/MLDkqx/66uyVVknQomSlp7kDDVSTK QwbdDK0bjHtuRlOPtnGt5oIIgvy85aNe3HqP2I7nWk705CtnazHawkTGR9jo+aOnEW0Q71xz uA3D788fX31OkkrKdlV2ViPfJudWzIuAVJxj9NFyJJM5fD8/RT/oNaRW40rboZJCw49bE/uD nW8mUIEhCtjsvb/LUzZt1HszgWPouXOtviJ8GevfCqzWa19H3Xr+sFFS5jYuklK0cY2rPUgA 71Z2O9NxyWGQGxrk3qXwiofFy7msh8Q5YWoaYQTU3UkMk1VQKrEsXdBvlp1XcRIqOygKGVV9 QW/Cn4s9L9I2Weh6svMFloYZfMLbTI9QufweWgY7wc4YrjDEZAHNh+K3xkeHPWaUtPSWG7zy 27miun8uKeJ9wIMbZLIMAe4z+mv0rI2JwD3EU7Wr/v6+q8rrah3SXhRX+Hl0tTWmGjvtgiin ln6g6cuQuETOkJLySMsaeUo3KcHJQAEn+ovNJ4/9F+L/AEbR9C3uKayXOGeVKeWtYPCxZiVa MjAjfceVYchQAxyRqpLn4ldP3K/VHUHTVs6k6VvENMWrLnZ6+KKGbLBDJJTCLHqLqrIHCsT2 GTqlLy3zVynqIJTUyMxlYiERg55JCLwoH0GAMcaxdKGdXcc/+/0PBFVjVdPWnxRofBcSUNYv 8YmkGJraspkilXJKvv3DYCO2w4IIJB4OmvqH4j+hbyJ3bwtkiqZV2iX+N7wnHsrQEEfZ932x k554e81FdIaiueaaaTvNIS5fAA7n6DH9tESVoIOM8jIyP76U6Zx0RAKV9SdRWO8TGW32F7G5 52QVJljY+3DDI/f/AJai1XXbIyikBj+pGtI4aioheaKKRokYK0gGQCc4BP1OG4+gJ9jog0VR 7xHdnHq4x+mk2LsqbIgrubnVpeA3U1j8O7vdOrbpQQ3e62unU2igqA3lipZuJ2xxiMA4Gc7n UjkZFfWmBkro0aNJnZwqI2SGY8Ae3vjXUdD01V9C9VSdN9RVvTvWtno9gr7dfri/kw1BRGmi pwrGVCgfyt4BG6N/cAafGCesFFTHWvjZ1T4h3c3LqK51NTLuDIKbESIRnaAi4UY9jjP66gU8 8tVMZmzliWPc8n7nkn766o8WvBPw1ont1d0jcLjbY7vTx1lPSrMKqGBGeRXRtw3AxlApJYZ7 8ZwK7qPhx6scySUVHBcqWOngqZqjz1phAJhmNZPOK7SeMclSWADE8ajo3gnMFQKp15Zav0q2 UAxtz/npfYuqKzp2p82ALuAwr8hk+hBUg5H7fUHVydI/C31Xca+km6lsp6ZtM7mMVl8lFGuR 32qSHfnAyBtGQWZRlhPepvg56a8Iaa43bxH6zp4bfT5kpKCwK0tRXqc+WIjIAMsQccMAOWwO TQY4DMpah3R3xK1vS8Ua/wAcvc9IQMxzSeaT9QoLHH074+2pT1p8V3TfihYI+nrnYLrdmklR 4ZXVBUwznjMJUtnJOMEeoYBGcHVZW0dKdL0S1NX0fVXa9XCVXtvT8jK1J5Ad4v58gxPLK0kZ ysJiA7hhnYH282i6dP1VLb+nLRRv1dUL5U9fYqIRin8zOKWlI5ZsNhphlyMKDtDNI7pXhtE2 FRFrqLwp6M6StfTRrbTe2qOobftNVYJSgno4WY+ZNVFGdYyjAbsP6Qw3YJ2if9B9Y9PX95rl DfaOakoZSs7RuVeIKAN7BgF8sZ/3mdpIIG4jaeMPCSr6hsXV/wDsbaBbkttJGtX1IL3DGYJW BG5JQy7x5ZdYgincG3spUsSvV/jD1z4adJeCdhuV/qEt9BXobhB0faTirvEoJRCznJSE/jLy fhGAFZht0QxwgAAF3yR9EXgu7E19QdTXr4hPEK7VHhu1F0lQNTU9su/XdUf/ADs8QO2OGOQg GNXkcKqqBI5C+42Cq7v4w2/wRo67pK0xStb7c0tNsnfMtTVxyESS5xkBpAwJwp2qn+ELpl+H jxlvniB40Ut/u1DRUPTHSVvuHUFL01aKZIaamjjp9m7B9Uj5KYeVmbPvjXMdw6lqr3cK6sqJ JKyvnkZ3kcl2Z2bczEnuc5/fXOinmOJc53Z5Ak/XT5pr2sEYDeas+5+OXiN4gOOn4rk1R/Fp lp4aCAJEFZnG0BzzycAlm7d+2pH4SeAt6r0rq6G8Wuk6gpmkYU8kpZo1RUJKSJlTUEzDZGSC dp75UGkOmr3XWOslqqTet02NHTsCV+WLDDSk/XaWAH3J9hnoOw+PXRvQEHTcVvpYayW10i+b GYTIlXVs0Mk00sn4su8QUkZ/lkoAAc63Ah/WeUiuxWhcrr0x4M+DvU8V0Y07XKKOntLwKs1V LVl1MzgkhvRGSrMTzvUewA5T8avHy8+LlTQU70y2zp+1kmltiTNKqSMAGO5uwwAqxrhUUAAZ 3M0f8UvEO/eKHU9Rd7lL6DlKenhUpDBFkkJGvsuSTzkkkkkkk6x4VdDVvXXVVHaaerS35Jea rZd3y6cBmK+/cAD6n276B8nSOpqgHajOkaG2X67Uoq7lSWm3KVEzzbXkA3EttjJG47ScZKjg eoe1ieI3iLZ7d0aOmLReq/qmBIEpqasuluSj+TpROah4YQssm8STFWMjYYeUFBIZhq/r58A3 QlL4f0VYvW1fUdQTJG09dOIvl4ZJtpgjkiALRqRvJcvgeW/PAzCPDX/w8OpepeuIrV1xerd4 f2xJVQvVVCTVNSpJGYo0dlAyAu92CgsANx40RY8dWlLFrlmx2upvd1pKSjt8l0r6p0ipaGlj MkksjY2qqLyxJIGO5Ouufhl+Gm79JdfU/W/ip0zW0VFa4WrbPZcxxTVtajDy0ZSQI1QgsfMK chPxDI1dfjXL0p8BvS9NavDXoquTq6tpp6YX640aytEwZVareY7tx9IaOJQsfr3sgwoPGVJ8 RniutZNVf7Uz1sjP5sj18cc5Zs5HLqT37DPbI7catmRp6/yQ6nZehlDRdS+KTUd68SKj+CdS UFwmrOm6KziKempR8uS0LeYm6TiKVZDko+8+rKpsa+mPEbrrxqsFHJ0/4JW2emijeao6hvlG 0tEIiAT5EETEOwCKuxXdyUVWyRkcGf8A603WciPS9RXWtulM0gkMcNQI0DDP9KqBxubjtzrp X4W/i5qOmbSvSdqgp6CxXCsWWprrhNPQUlv8whSzyIkiKjEAYwBnPPPDw5ruqx1eKlXur0uP V9V4TeFN1vVnW0XSRZREq2+j8lKWSUbPNq6R1/k+vAJ9QG9QM41wh4aXboq6VtJJ1R0yt16n FZKalluUwmvNTPM3lgqBtRVGAdnqYtncCNdZ9SfHH0J1dSVVqoErVExaKSatpQIjD2J3K5Yh hnIIHBOdczeB/RFnpviBa9xRm6W+jqaq5UiRALToFDyRM5YADjbtHpIfb2wRrHj5WNAN3Wy0 4VjnOqt/ou2/CJk8Qq2ajqKNre1CkhkoZCIxNT7lWOMj8TKECFwByfScqSptu5pb7XEbhcbj FQwRt5IeoK08ak425YlRgYAxg5yAOwzUXTPhxSdTNRXW7T3Yy2+E0ppqWpalhqUdQ7q7rhx3 TgFeYxnJwBJem/Bbprpqqa4Wi43WmjkmG2ja7TNCBtUMrAvkqdicEnOBkgYA+QvbA/8A/K5w rkACP/7D6L6PjA+Sdz8PGA3QCz/Sn1DW0NwFYlJcqSpnpuJUpa1ZpYcgEAqc49+fscZ40qga H5RdrybnyCdm8k+rJ++O/PsRz203UNvNBFTw2+CLyXYySoqiVpRhsYk3gLtJA749PbJxpWkk eBOu1ItwBbnCMGxnIP3Axx7a5bo42vOQGu+kiLDNq5BqexI5LW/zIkp91LFO53QBYyrMRjKs RlWIYAk9wqjGQdRuv6C6LudQk95stkCmMrJugjUkOzbt3YE4QepjkENjHJMwZ4KreUq4g8+w eZUeYEZiMgKAo9iOO3IP1xoYTLFHMXwineTE6MMqMcAk4HqfIyDjH56hbl6xcQrkwULviPr/ AGqpuPwyeH92tk9LFbY6KukZwr0tU7uBtXDqpbkBst7gjGcFiorW4fArTzEww9SfzJnVo42o 9pIwCQxWQ4PKkYH14Pt0xKCriBp5JQVebyINu0bGT0g9gTvPBODgjOtbXHb6Glm+aiieCJNk i1ZllRlOTgAKRjdySMds/fTmYrEMsRvI+f1WF3DIsx7FyDdvgmvlsuRp5rhQytK0m2IU7xTM gIKna5CnJI/qxx76J6C+Gu5dMdZx0nU3R8d7t10pSsVbBWtDBRSKNxV5VGY2YYAJx3wvBJ12 fa6OCgd/4G01ioJGDyQx1WyFiQ24iPeQvO4/h7qM8ZBSz2ieOoq5Em+aSbcSs0pmUq2dwy/q GQcY7ADA+o1jiuIjBEmvlXv0WNvD2RODqJIXEFV4B3Pw8vFwvF+s/iLRWeKZpIaC1yCtSFBg nzZF4ZByMjkjnSypufRl5pEo6HxMiih8oPHSXW3Usu0HOPXLEG3e2CcjXYFTc+nOmOoIepLp 1FT2msFKYIxLXMsTKzK5/lAbN2EGSOdpweDgUa6+D8dRJfaeWO53ieVxM8Nu2SVO44ZnRB5S gDdnCKcgkc9+izirpBmfEfIJhiDGihXbaqu5eHvhvVWo1NT1JboI4goaqYRTKjkd2BYjkgkK AO3Gqei6V6CpL6tN031N1DfKghlkkoLdvgP/AMSVY/8AfOrc616d8LOqKdqe09FVlrrJAxV5 aiNGU7ePSGYsCwz+LPcZXULg6KHTNDIKesudNEmc/JVLIyZ7KAXGfpxka7EWKaWEkEHyXPzN HWDPT2FKLT4fdaW8mbpTryON0YI3lxsmw/8AFhjyOOMe+p/a/Er4g+modkt4tHUEMZyN80kM jjv3ICjVHx9Q32k3GG/32nRVyscjiQHPPCkvnv3P10spvEXrighndb2KtY2RFiqrXGd/Bzgx lff6/wCmmtkkHwu9+S0tnhI6wI+Y+6vei+LzxXsOWuPSVxqCBykYp6yMD6gRiNwOf8R0p/8A 2pF76Woy128PbhTyI7KshrpII5VB7qrxtg4z6Sf11Qv/ANdOo6Ab6/pazzwg58xjPA3392B/ TjSmLx3pZ3Jm6BwkgJZoa9ZOfbCtGO+tkeJmZuL8/wApD/20mz68vwusej//ABVuiL5DSm9U N7tBmUeYZqGOrp4z9N0Tbz/9mftq1aD4o/B3rakWZb90YVmGWNWq00v6rJtYH9NeZPU/W9T1 hU0+en7dYYIJC6xxxrJLKeRzIMDjvgDTbUVrQRSGSfe6owj2vg5APJ4x39tOdiGSaSxg/Nc0 lrH/AOs+Y0V5+EyL4nePHV/WFDcongjuFTNRUjNieeKUyRwDYe8SZiVu+Nyj8ujrz0knWl6T py3dSf7OpRUyKsjU3nK1PEqxlcZC7S0kQIbg4PB5xzx8EdnpZ5b9d5pttfTyU1FCsKYjCSyp 5jAjHsoHYYJH1Gnr4tY6633mwXGjqZrf5FNMTVU1Q0ErEyn0rtdSwH2z754A11iGxYcmtNtO zbRZc3Xsq4up/htuE9LKJB0vcaymf5uCc0U1G7sNuGRo3IR9wA4HHpPY8Smj6crfDzomNOk+ nx1RVipBajSuRUif0pI2+Ujao9WcAkMeRycc4fDR4hdQ9X9apaLzd66vigovMhkqqosyBNqn g8htpI3KQcM2cnDCd+MHXvV/gv4MNPSXKWs6tFQq3G+UMfnmmRsKxRGVUJAESZIz+MkAkk8W KOBriYwQO86ei6XSOlaHEqU+L9R0TSdP9MV/iZ07LY62uqHtctwskqTLZZsboxNOoXvGynBV gOSARyeWPFfozqPwR6uktd6mkv8AaZCXpq9I9jTQcHfuBG4ruwyk8bhyBg66X8EPFSfxo+Gq +1filRRXyjt0dXJXfML5NRV0CR745/LGPWWRlVvTynBB51THxlXOxX3w68Juo7VHJS0dZQP8 rSzALLHS+WhWJxzkDOMhsDPY5GNjY2k5SNCkkkAm1Wfhx1Va/ErrNLBDVt0xQPHireaEvLIe P5S+WOCzEgMecY/q7+hPhNTWLw4g6Z8MaCB3pLra56WpqNoQg7XaF2O31MfLmC+w+/fXH/gB QdNdJ+Elt6+u/T9tpKqzrU1EtQYzNPW4lYI5YBmiRQAgK8kjO1savX4UfHLp3xAhs90mukVd 1bV16QXGOqp5BURN+GGNAkZCR7cKHZlDMTnkkac1kbDQ0vRIJcRfv2FF/GGmht1/oq+BK+uq kcw1C0CuqRPIrRt5qHKHbhmEhyOeRnUY8Oa/pH+HPb7r4b3Pq7rCKqmUxS1PlxCMEHB5HIDL u9P3zzjU++JqliorffKisr6igWZpSlXFCrtIm8RjcCpxuZWUMAMHsdQv4cujJfEC3deiy9WV vTkkN0QxyRKsqSh4t3Jb1gg5zhh7ZzjWeNhkBblv0P1NJ+IAAHv3snu89adcW2vt9PYOkOgf DGmnDqLnc6fzXiVRuO1wADx9eDo2zeKVJf55rNcvFGp8Q7zErTvS9O7KSFEVSTnY3YfYk8dt c/fEN0VB0xe5bdVdY2/qarqoJIppllknenBwPUGJCMfYA541zJ0ldLl4S+IMVbbqsxV9DKHp phwlQnfB/wDcP78a24ecC46II8PtQWF7MtFdT+LPW/UVmq660dLdNQUN1hqY5HqpKppquPI5 KyMSWRwQQwbga5V6kuFd1RepI+ornLb1apeSSMQAwI7N6iAp/wC8a7XMvT3xHdCxXOwTQ2m7 UMbCSIgmSCRjlopADkxn1bWwSu7HbXPXVvRN3tN2np7/AGBFdMoqT7lMjk+kIy8MPfPIx+el Sukid19WnmmNcHKSeHZtXgRaE6qs96a6VtxV7ay0myQTxMoMgRSScqdh45019feOd6FxtcNN co7XQTUiTbFgEnmncy79/fuvbCkHORkajN5jPStDDUwUlBW0VSFWqojHlI5k3oWUdgG2kg47 5HtqXdJ2+3+LVNZemYek6i6TyQrKtPTSBJ6ZTKyvIjsCABsGQSoIP1xoekOzfX/qbHkB6wB9 V274H9FfwG3TV0ccb1lesb1VcsYjE5C8P9hycD76vC1mQMq+oowzuPGfy1D+iunG6U6Zt9vy 07UkEcIZzlSyqAD9+2pxbaSZVEjqZpmGc5yP+utkbTSzuLeSkNJEwCkgDIzn30vVVpsMJQrH 2JP+emWCephO4oykfQY1kVstQ5LsSAfqM509prUaIKCk0NaWKESh8+6ntpfFXMzYKLnnnGol BvUkmRsjtnS+Cs2kAyNnPY51obJaAhL6i0w3BmMqjf3UocEH6g9x/fRS2+vDlVlw39Du2Mj6 H/npZDX5AyFP30pWqjIGVUZ457Z08tY7UIdVW3WHQHT/AFj5lL1D09SVUyjh3jCy/pIuGH76 o/rX4OpKiCSs6Nuyu6gkWu6sAcd9qTAfoNw9+W411+5inAWWKORf+L2/LWIrbT72eEsjH2J3 KPy1zJ8HHLq4eexTo5nM2K87Zfh+6tFou1Pcbc9h8mlncJXsCzsFb8ABO4fcZGvNe5yiSQ8/ 1YJPvr6O67p2K8UM1JWeVLBJGyeVMm5TkEcZHHf2OvnPv9nnttyrqOYBZ6aokidMe6sVP+Ws GFwj8MX262kiu5apZmysbQ1G6b7HXvYb7brktPDW/J1MdR8vUrujl2MG2sPcHGCPode4nSNx N06YtNb/AAsUC11DDOKDdt8gMgPlqFwBtzjjH5a8Mgdo3AkMvOPy17Z+EHV1H174TdIXeiJq Y6q1wO8jEA71QLIGULgEMrD047ca8x+pAGiKQ94+n9ro8KkDJHBSymU7yuAzqdoAyCye/wCe NeIHWiRJ1JdxAnlwLVzCNP8ACu9sD9te4kG8yAJU4Q9kkIz3/L++NeIHiNTG2dd9Q0ZGDT3G phIBz+GVh/ppf6Ze0mUDu+608VIc1tJntlQ1PW09TESk0MiyKynBBUggjXt/aaz+I2+iq3DF aqGKbesmd2UBzkD/AKHXh3SgCaMjI9Qzr3J6etlJTdN2KaB5DClDBtO0j0+WO4H5aL9SGui/ +X2SuE/G++xbvDHU1WY2kkZvxAHO7HY6PjEM0ZWFIypOdrA5/X/po56WJZgqALG542IMZP1z z+2syWZ4wXjp2JU/71c4z9x7a8M5uawF3nRiSwEm89YnQGUgL2A9QH2/to9JfPXLK6IBgGPI 575Ot1leGVRJCjJzuJPqB9++NGyT+VEVVlIB3bUYg4/X8/roBG0Cis/Q0KO6LamkdAYgSndt 5wR/zH30WE8pcNFIZH4VtvH1wOcaMdWjkjdxJGoHYgg8/caDuY5AZldkIwZGZfUQfyzqxG1V 0QOhQp2TKq0BXA/9TII/LaedJppljbLgF/wk7j+2ex0rimqImlR49yuQQQ4cj6EH7/noj5o0 8mwyEqwAIJx+x+ukZDyWboiTYNhElI1pypEpVTyGOSPvnRqTIHEm9o9owuz6/Q54I0dIPLhD K7ID6QzFWHPsffSU7ahdm8ZQ4ZRyPzxoaynZIyZTZFJWxjkQZKoB2IYbj/3986J/DwrIFHbd IAcfcZ0TSpGMykBSCQQQeNGCkkmywJIBxjOcfbQOcQluDrsLy4s3wJ9T114npbnKtDKokl3g b0kVSMKrkqoZsnG4gZHJGdS6yfArZq9JJK+5XahBEwMc9PHDJEVZdrsA7L5Y9Q75Y7cEAgnv eq6doOprbJTTUaLSyU700kcrrGrKwAYAhiw3fi3Dg+lsnbjSCj6aFrpIqRflqj5WNqeiSanC lU3ehGByBxvBZSoOS2BjXsDxzFFoDnUe7/pWJuHYBlIvvv7Lmmw/BZ4d0dgp4qihe6PRyPJL LLLIi17IfLw4VlEYV94wjsPwsTtwDJ6r4XOlLdRwQ1VmoaeWOJ0ZqaKOIeW6NHIGCBSfTKRu Cbt44wAuOhqCxCOopaiGvpVuEZCRqKTbCct6o0DElN4woLNg7Tk49Ok8ljappyztBSs8olNC Q0jgf8D72RHAVTuGMeo4xzrDLjcS4ZjL28/vp6fZA+2GgBS5k6g+E/pCpp6alhs8dJQ0yFYI TOyO0hUGSQvhjuBHGHZeVyFVeCX+DLoKl/hcLdOXCSseeOZpfmVLxxKoAWRHTbhj3AycjAHI U9C0PStS3T8drM1PWTOsjN/5gO4YIRFJ5bDDHAPcc++AuSukkkhpIKaggmaBIsyt5hdpD5Sr 5eFJ3hdpJfcwGA2W9JKxjcQW5hMfXfmsoOmrVQC/Cd0StmqadaCvq2rFO+V49sysxjO7zFUL lgFj+uJSTtLlihq/hM6Gu8Bjloaikpo6hUjakMSNGMDaC53GQYJzk5OMkgAEdHUhudvsUlO1 VuLKVzTtkyBQWMahvT5amTbt5PDAA7gA2VVXVyR0cxSfdJviieCJjCNzLu3bPVgkjf8AgJGT xhzIH77EXfSlX0RJulzr058EPTiGp+bepY1bg000SKZKPY4KSoNzMwyApQEkqxJAOzMN8Ruk PFJuoEpbr4cUnWlHbKhzBcoqSKqqJlADF5MHLHYyA+YGyVTlm5PXlJSV9UKOpq4Kw0rkvIkp 80yRltyosW0/QZAOSTnYARpzpqmqWniRY0qVQeY5WJomOXAKDAySWywYZyJCQHBwetheO4rD Gg7MP/cL7EIi0srz36p69uHWdlrenXI6TsNuCmoo7nFW08ckrhiIysMTeoeWcKxQFs4BwTqx vCH4o/C/wG8OqSSi6Z6hvd7cuI7hWRxrKAwxupg5lWGIFWU5GW34y+0lewquB79QyQ1VupLh S1R8gx1SxyCdYyVBIkJLLnt35JI450y3Dw+gqoqkp0jQSVSIGWEwkxu3lBDlQwI9CqrISSyo q8hGOu4z9WPOvRDXv5eip2HI3XJd1+Jyy+JU9Dcb5SXGwpWxOkLVm2eHYMJtHlKrKnIUEoAe ee+uYuvevqm93+YU96qf4ZGPl0qY5nBNOnpCruOSNowqnsOMDXphU+D9oqIQ1X0nZ6umKU0c kj0qz06gAZjUEsSCIo0DAHAVQf6tNtL8MfhjdJo3rug7JHVKoaOWNGgp3A3kkiMhWyQi7cAr 6t2QDpv/AIpjkoPjPkliIgry5rutK6s6vS7UEMlMtONlLCqCTyIUTCDtg7UHLY55budTnovx 5vnT1wWGqu9wW3yzqaqkpwoWZdw3ofTldy5GVwVPIBOvQul+GTwq6fr4Xg6Wo0p4EaJ6mKao JGQ3mK5D8hgcFTlirMuMDlp6s+Bvwq6wvDVBtldYpZCZhBbp1jEu8lm5ZWA2s3cdl4xxwbP1 LCHUWuHp+VYjJGi4H6Goaa53G79UdVzM9noHNfcsyfzK+pdiY6ZW5JLt3PsNzE9tRzrDrWv6 +6nr+or1IjT1JUIkQBSBFXbHEgJ4VEVVXJzgZznnXcVb/wCHl0iLy8rX6rprdKDMbeaRg0BB z/LfzGIwSRsYMSFbkH1BluX/AIfttanht9pvguVTDJMRJXL5avgMCgCFj6eWGFIzvBOjbxzB Z8xcb222980wRvIyhcc9JddV/RtFf6WyMI5b3Rm3VdV5bNJ8sxBkiB7BXITce+FwCATkmj6e u9woiyRpSU+MjaAhb++B3/trsiw/ATdaOVGuFbRxlCqeWExtmALfzMEqFVAp2A5bcRke1ydB /Cv0n0lezUV7NfbzSsJJIokWGgba7Dd5JBUbgoON+MHsvACZ+PYdlmM2UyPDueaK5S8Dfgth 8TbO926g6jPT9qiqDEqtTlpZ9oDMyk4RVxnDc5IPGBrqroP4G/CTphFpai2P1TXxN5gqLjK2 xxtXepiGxRwynkkjI9Xtq7qHoyClshFHaaCnpoWISGKJIY0cI2SRwqpxkn3yMHjSkWaGapE8 vnzuczSFY+TuABJyPSw27vVyBxtyvHlMTxXF4hxJJa30/C7EcMTALZ2aqrbF8LvhTYZZko+i o6dpYhlpIZqg+TuB2kyM8fLrgYJJGAOTkr//ANWnwtuFDFjw7tdFLKi1KzQo1LKhZQ6qjxtv 3ZOCAcALnJBOrKtcNNaLXtpqGmtKkRiNfOUYVSdodVwD6VOASfzBGCpneVn8meb+RHGhSFg5 9jt2OOC2VAyoJ7E4DayfucQTma8k+J/K6IbG4Cmt07guavFXwA6zW2Qw+HHWstqgq4xJ/Buo 5RUbooSDCsDshlWNWdv95kDcDkDOq6r/ABE+MnpF2kbpq318DRRxyx01FTTpMdgXe3ltuZjt yTnHfgAYHZNO1XHa1aaGmlq1LtvlkcyStGQQSAPSMg55ZiC2OCcpUqbhOq0b7HYSJF80rmE7 htUoBtYbihQ8cgfYka9BBx/HQty5w6v/AFa+/O1km4bE63DRec/WvxVePdl6gWbrTpS1TR+Y yJRXXppHhJQKCEcjfgKU/C/Yr9tXH4OeMfgZ4x2e3Qdd9H2uwX9WEdRU/IU4o9zHaJS7Deqc kncCAduS3Zuv6N6aoUnzh8u43LDLITx3wg29gAMjcDwcZJB0z3Honp+50L/NdOWW4QRgmJKu 1QyRoQMkEN2LEsc8Zy/09PQi/Vkn/nRB3bR/r7rnO4Y3YOXBHjf1j4W+HvWF16e6Q6J6Y6pe lVYYq+mUy08zbdySK8bkluQGAcqdp7nLGu+lfCnx38VLVcK6iobrNZ6yEQTPcZRBTPGjeasa GQquxWTgL6VOBxnXqVbelrZbrdFDS2q10rU/liOKipY4GjdYgnC7GyMZVdoyCwXjOzR/yNTM YnBjkqaN3ZZp0ARSFZVdlK9twDHaWxgAH3CcR+ppiajjAHj9gAmx8LaD13ei8zrD8B/iBKXq a6rttmrVMZipZ5yWYt2GYg4ByVHJwM8ka6a6KNz+H7wXo+m+tp4aOrqBU1cCvKoSNcB/KbHq dywPCD0iT1lRsz0tR09RJG7RBqeNdoUTN5yqwwFTI/FtUN7bj6ec7TqI9brQz0ksFzpbbcqJ ZeIkpgI924gAK5YAjgE8f065DuKS41wZNRbvWxC7mCwsOHma5oJ7QSkfgHcZ7j4c2Cjgr42d XebzSkj4hapcRsDyH3JC2QMksVztyNWfULN8yJaMu1KiKMIVY7uM4LY4wGwMYPfnnEEXxQ6V 6bs1voTX0la1NClOEtxdo1CxbfLj9JCHCkAEkYPb3DNcPHi02rzVFBU1sxIjhkhKR+fjdtBL HKHDMefdQfrjlvilxEhc0aE+9wtEuIfNK6R7gLJNDv8AVWXUGmanSVZXhhl2gs0SjgMQfSVO 0eoc85z7aQujDMkVTBI8ZMyieOQb0JIO0hiRyoJzye/GqfunxFw08fm2/p+CCREyyPUlmVRn IKrgsOGJHY+n3xphu/jpergJqCiqoKU+bIr1NFncwOPwliQigqvJJOcHOmNwk7dwK8f6Sf3Q j52PHVdKCvWslR3rAtQjBafy4AoK5O1Qd4Ldif1J5B013XqK02GqeGStt9P/ACw7VU0wUrk/ gwSSB6QRxjt9DjlG79ZdW1e1JKyrmp5dzS+bXqu5snsAeBj14IPGP1b47v5khmck7iQQ8T8E 5ABbPHGTg/fkDs/9jfxkapRxtfxtdGV/ir0ZbZI4orhFDuXzFNEJZI/N52nAXaM45HBBOCNR S6/EDR0dRHDarVVVaxIVjq6mRcO+QexBYDOMnvx9uaXe8tTvLmqiq0bA8p5V9IQ4A55J5BwS QPfWRvuE7ZStiw2/iVFjLFgcEYAUAZbPsMDnGtLcHE3UhK/fPJHKlZVZ4/dVSNTywQ0EBhGS 0MRZlJz/AFOTjkfTJx99MN48YOo7oIaKaoqZllZZAYanYgUcqhQBSSBjGex5/Kub9cKHp+aj paiGrFbOwCozHZzgbiwHlpgj1MdvHB7E6eK2kliI8iFYackMgd2zkAYyEyO5OPzxrZ0DIzYb v3JbsS4us2kd+q6+6SwyxW+mhRnUNPLIZZGGCRkkZB5HGew+2m+jtcq1lRTSrUxpG+1JU9UW Q2fURnIzjPHPbTzWVFTTQuKgClqY1zK0DyIXAOCOQOPt/wBdM0F2kr5D8s7oIgqu6I+FB5wG Axjg8KPYj305g0OiUZWuJcURNb6pRPOJY6iQF/L2eoYI/GoAyp+5OPy02/w+61NMlPNJMokY 740Eg3JkH8RBGeMcY7akNDXkRzSUzJHNuBaSqChFRicu/bGOCRwTntpA15q7lWyZNIvpULI1 R5jSgEZO3+lfw8HP99Na4lJMrapF0tgMY8/MFOVIcGUFmACk7Qfryc8f6aa5onb0ReVUO53S SBsjdt44zz+eNOtddq6UBjUCmPp5IVQOAQRk4GOOMHv7aZ6wx/MSK9xp6ZXAURxO8asp7kgH aeSOwIGhaATqshfGXUE23TfTjyKyp8oSgO3kofw/QZyM88D89J5GhicfzUh3r61d8MATkE7h xkY5P104yIkD+ZF5FUsJMjB32hTySCeTjsdIrktqrZVeehpjKh80PHGJUYkknJC+3H5/rxoF e/wqdThbRqi1gKziR6eFlYH+ZLkIVYbRkKB9Tg/YaZaemPmyJlaQxEKokc7vzB9z2+49tO0s cBp4/lhMqMuBEjjynBxkBSM47H6AdtJ5YTSmCSNS6Mo/mmXBU/Qqx9iO/wCXOjaSCkFrgTor j+DfrOR6+4WKYUtuo6OjmuKxQ8GV1qqaR1OS2/CQkKO4Bb6nVhfGp0XHU2O3Xmngkkngqwnn pJhYoZdxAIxg+ox5Oe7D6nXLXhL15UeEviUL7BQRSB0YoJh2VyDvTOSGR1z2wcEdm16CXGip vGnwikpLPdZYJJ4UjiqUZl2kDdHvx349Le24MO6ka9cyp8OWDchYzo7MuBvCnxDq/CzxAsvU T0s8tFSzE1ESMqu8TpskCjIyecgEjJAGurLT4dzwdOde9SdGdVxdTdJXajnvVFaqZd1XS3Jk djtBPp44CnncqcArluSuqOlqzpaurKS4JUUtzgrXp2ocAyAJgk8cY3HggkHDHJ1p0/1p1H0L WGs6bvU9rr1UDKEK8ozjDjs2Pow+mvPhwHUIWpj8pFLq3wYvVZ4t9KX+3dbdHTdG+HdXZo/n LpVXLZNX1CmJTKzrsVRsh/w49s+og80fFJ4zW/xH8QLVYemHiTpnpqgS10EKI3kAYXzM7tpB GFjPt/LyCQRpu6s8Qur/ABGgSlv1/ra9Tk/KwuY4dxLZLIuAxKsyk/Q/TUepLCtJBBVQ0lHS wmIb1MZ3kMF2l+eByuMjnkZyDrUJ2tbYGypzu+062+mguNvt1FU3R6KzgvTJPKsktNCwG4gr H3Y+n6nHOONdHfB14Z2ebxvsl7oevLHVGxwVNdU0VLQ1sE5i8pos+ZJEqbd0iZBbkex1zv07 PFaxcbfXtBLY6zBqqamYKX2ZKyIDwHXcxUntyDlWYHuj4Z/BpPCXw/uXUNbUWyol6hIqaW6x grJ/C1RHXCNg7pWwPL9t4JJ2nSGHO8EctUFZyFEPiq6kqKHpCWB7hHbJ6WjFGkYQs9QrSPIe zqdwJYAgEYzkcgjiu2dXdQU9pqKKivNTR0VdVCWeFH2CVlBUZI57fp9e2rr+LHxDlvFbBbIa 2jmiq5jWmkClpIUx5aAOVxyAWyrA5ZhjGNUNDTRQ02wtvdQP68jnuQO/PP5aaXGOOu1OnNuA CS1vzAdyJ3WUPsMUZBz9xjTJfLLNf6WNZnni8okqZhnyyfuNSWSlkcBIgiqSOSSDx35z31mq pJKYqsUUrlhu2JyG9vr9/b6aTG7ajqshPIAqKdJzX7o6+C52u6tSViKyiaE7d5A/C6ngqex1 ex+KtLn04bd1d0zFWMEyKy3hd0bAja6q+cEH6Ee+qlq0SCNJHjUbTn1jt9sHkc60akMwhMaC SNjlXRcYPGeftka2NxT9nbKg3mVdNN4jeBFXTbKmK5hQGX5dPM8tg2CVI5IG4ZHOQdTTwP8A G/oyp8ULVYeh+k5LaogkSoutZK3nLTrlyoyc43n+/wC3Kc9tjSVi8YaXuHPODqd/D9XQ9MeN VqvFXU/Ks4lhaockAvIhUKxP1OBz9dObNHsGgKFpXqpa4FqqKGRsD75xn9/fTpFXx7kigVmm XjIGFz/rqJ0fU9Ijo8ldSjAysfmBv39hpXJ1/HLIRGY4Ex6mVgcjXSBFXaHKVMZG8sfzmDS/ /m07Z+50UgMrEyVAjK9inIH5aitReocIXlEiuOH3blxpdW1ctBGvmJ/JPJcjPt7H6aTICdQm MrZPkFQYpjGZvMUdnxjTtExKB0wQvBI5xqFJWQoqN50bbuy7hnThTXGWMFtxU44APOlsfl3R ltlTWlqI58AuF49Q7HSioq0VVRSdnb1L7aitFXTKVlDBcDIyNLBdTUo43Hv27D89b2uzDTdZ yKUlo5BVMqq2Yhw3HOnISNRTRMnqR22kexH/AE1DbZcSJPSd6qeWTnB/PUip635giISOGchQ +MjB1nc4jVNDQVKIagSSBJMjPsdeCPxi9Mp0l8SHiRbEQQpFe6iaJV7KkreaoH6ONe7NRUqH 3Y/mwNkqOMjsca8bf/ExskFi+LG83CJ1mivNDSVk0cZBMbCPySPscQhv/loy8PaqDCAVyQW3 Hn8Y7HXqz8BPU8F9+GyyQLGYqq1VdTQyEDBJ3+YCD91kH99eYcnSqT0hraOriqqNVLM28I8f 2ZTzn8tehX/hyXy13/wmunTVFQ1T3C2VzVNcy7XEqygCNlGQRwhXAB/DnPOvI/qSJ0mCBaLI cD9Qt2BB6YX2FdaMYpHQJOyk4UDkjg68YPHZ6JvG7r1qMl6T+N1nlkdj/Ob+2c69jamk/hiV U0kbx7AztG2VYbQSCQRndga8Pb5dmut8uNZJl3qamSZ2PuWYk/564v6VY4PmcewD6rbxGw1o KU2SMVV0pE2th50Xb9QWHGvcS3kRUlNCFKOsaBPTlQoGMa8XvDOJa3xD6RhaMwrJcqZMNzkG Vede1pmkSVwTIVB7qwUqNX+qJP8AbCzuJ+iHhpou8kVDXyjeJ1CQL6QSOO5wcHJ0r+ekji/k zyNv9LlovVj2wRjWganlJjqD5pcHDsc/cdhpMFMUyCVgEU5V1Qkd/rz/AH14wPc3Wl2+mOYE CvJKpXnkpWkRtzAcrzhvvtPOdbQOKmm5LqWBZiucqw/0P30poprfJI8rQ5kU5LLMMSDPYxt2 +nB/TUst/V/S09ERPbkiq0/lkLSnDD2IYA4/f661Qta80XBvio6ZzR8NlQt6hKiNAXDSDj1E 4x7ADn/TWHmlqY41U0xGDjcmH/LnT1cLVa7g7S2aoSCoPJo6iYq5++JMcfkcaR1fTlyipzPV W0xpH6mddpU/c4ONLIkJurHaLIQGQO308U1OaR3MK7Y5l91c7m591P8Ay1iXyozseQFHxkA8 j6d9KK9VZYGWGN9owVmBdf8A4nuNIJgoCss0dMAwLIvPf+n64/y0pzb+EojG0jM0i0o81Qp/ 8wspByox/bSj5WprIhURwOm7j0kMSfoRnOD+WkVRVChcqJA6PgYePBx/r+h0pgljP9D+rnCO WR19x30sGvi9/VZtA0goyphliT+ZD/T68EKVI+o9v7aNopqdIANyvk5zw3+eipq2SRZBI+Vx /L3HLDHtz7aSqlPOM+XKMcYyFx++o92WiNklw5pDBHOKZ5oahYmkEpVm3bQzEgYK4zj/AAnO MggAlcME9HE84F52GaMFFZJJI2hV8gIBtG8bcEFssPVtxkHUijWO20oopHMW6RZTGmKnzgWy GUAcnvxxyAc4AOiYLc1fO0VRb6mthSNnSthp3Ic5kwC23dyACTyozjcTty/M8u6gv3rvqPYS H5STZHv5oyiiilg+XWnpTKQUYBSF/EjDyz27KuMk+o59iNaQSwmJ46ulFBJKVmRpYDCefV6h sIH4SODgEAEcnDZR1ElXVqYrX5U8ax4nMAIZWVhneWGG3Ajv6cfhG4EKaOiqKWkjRjVzCSIu 0piOZhu2gsGY5XGFySSe4xuOgkzD4m/Lksxa8izpaC2+mlhICQQOkoEUs0ahcBSF2qVxvx/S OwJIBJBY6Vt8k1M8ccqTHzBTSpxEWQFmBVcHcx55Gc+2QBiW2KlTDMPnZpZJVZmDeWFUhRu2 f1gcuEwxznHOSVb06CnmT5yjq1plURqVEjBVD/iKsccD6Nzk9uAk6AFtojC+qCb5KdbczxUt I8al1V4pX27mLKVCFmBVSYxhQNpAG4hVxrY0ZpaWiWCE0DYMQcpJN92AAwAGYH1YweeTk5Po auolkFHA67EIBT5c+pcsoIY8rzgkn7/mdBXUVXPOklQ9REyNFP8AKbmTnjbt7kgNtBGDlgAP bQtDjsrIbFqQPn+UfSXKnqVVqaGc1CMplA2sSPqXb0kqqDJZwOckAldFVxkmogayV6Sh2bPM qHKIPqdnq4A3Dk4G7ILejWlNV0QiqIaWekVAiFNgUGOMMcsoJ243rnI24wSO40tFygraWjNb IxZyX2AEDYMAKRnlsj6A+rgDk60ZhrY1+XYoJ4zdAeqYpbMJqZoYKgy08LMrxSxFuEIPqL+p sBS2RlsEhS2MskvN+ltVRN5VNcbnGIIiywxSOfMYnkhQCMB8keruB3404UrQR2k01ucRxSzJ NCkMq7ZDkMuBt9Ody4OSPSxHY7jGudTT2pah6ipV0SN8+jZs2kSMGT0uEBcnb6h6RnJyLjiG +v45JBkiIOtJto62suSLM1nmo6XdtUTIuSWAEgY87OFzgjGNvJJON7hd4Ldf44qW4SUqPsYw xVDI7FUBClRguQfLQ8fhP1505VV9h6frzH8zXGSST+VVA75OcEkDH4BuUKx9OByPxZB6rt8L 1LhJYKeWNoBNUxhYpEXO5wXIGzBGCfTjJxjZqwHM56926A9EWkC0zJHNBLG1LVFKtXcx1II4 GW/E2MOwKjLnGQQDztBUbB/vLbCtNTu3mVcSMUYyHKOzhxlScooPcYQ/8WlaWyJ6ySrhqKym lgp/91C+BwTgHlW7DO1v8TAcgnWnyNxlooZqp6epeMhXECLDGjFgdyDJUgYGVDYBb6c6S1zq JkJ9/wDEkN1019/JGmouNtp9vy7BURYQF8yN5PTlH2lSc5DDLKBkEknbgZr3vFNKWVoTSpJJ lTG5YKASuBjPIKqG5HuMbQumy4R4rqSFp4IFr22kyqWMiblG0nIyxXJBbH+7G5eSNHyU5ra+ SA0zPBDL5bfMlqeSPHOCOWCDezD6+ZkkBSQ6Ql4IOiN7dnAeiLjuE8zXCpkDpHMis5WMv5ki /Q7vSdowGB7g45By6y1DWuVQp81HjbzahCqRuxLEhyQecFOcZLFe/O1vobbPUTVclTJEmzER hYkNGu87gMtg4MgAXJBypAyvKuBqSeeRngSudwAV8sxIwIdPUCOAPLCqcg+wJ7nL1m1mIUjJ AsmlhzR3GmmkicTs+YFTAIlbGCyx+wUENtGedx4OScV9UknlyjFNJBHkeXUS+Vu4HqXsVAPf +nzMkgsNx7JT0kBqC5mSURSfzcyCWMqCqYJbBCrzg8kZGAvKaogaqklfyik0zZRZHOGzvVAq kDy8YGMA4IAwTndoMt2L9E3pHuOh2ThBW1tTOs7uWppm/k+kDejJxwCrEFm/EP6lA2gjOjaK Sqjp0gkRkpp9x2lF2wrgghQuQuAowMkNtwM6b0aWleWQ1oqnkX+RHWOFSNS0auc5O8jDIBgE kt23FiwX7xO6X6em+RqqtZJYIm86CBCqop2q2FGEXKllU7iByMjJBvK+Q6e/FM6YtbeZTKkr kWlQTQGeMiORiqF9vLbuVB5wVO1cYzzhfUUt0gadIYkVVhWIxSRtHloYiApUNnO7b6iPUece nIOoLTfEx0jb6aqJ6crpVpWGw01YnlOduQrYZdpAK+x5A99Qbrb4o3rI6X/Z+y0vTluRfU86 LLUSuVK7VdeFUEKw9ztU8cjXRbgJqz5h87+ie3GltVqrmkrHMLSymK5PQl2kkI8lQyt7A7zn dtGzIHJGOAAwXnr+xWOGSjqbhBI0i/zIKWQyL5CsFAdkJJIyW2hlHpO086oO4eIs/WdVNFcb g2xwDP8ALl0D+rj8OcYGe654JUfRjutZSPDL5skW+ORA6MmXRdpypHcZ79+ASeAdMbg7IzoX Y87tFq4upfHuOirUFBZ5auEMAs95k2CbOEBKgtlSVYHd2A5x3DU3xGXO6jzntdJQM8mUYIZM ZyW4HA4dSSMbipIPB1VDXd6MKYXiWrJCbojhlIwDuUZHb2P+Ij3IKeRP4tUySVrs9E7CWRai NfKUbiTuyvfJ2jHZh7++4QQk9ZqEcQc51nT34KdVvif1B1aZNlWx8pMtBBI0O8AkLvC91AV2 IJ4APYEAaV03U9mtcEUskYs9XOjzBZEJ8v0OxTIZvUBJ27HByccxaj6QrKyjZY54rTHEj1Ed RVxELIwH4AwIJYhgFJxnPJHbUy8V6mOjsFotylXWICCneWHzMLGAgdwMHGVBJ5wT2AOnZGCs my7GAxZiZNO5t9WutrvzA7bCj01XBcK1BHU1LIxCbVYEJuIIw2MseBnn3b2bTVX3l5mmBppC QQhSGIFhgkjbgBecE4YdyuTjST+NrNCYZagVDRkllpVkKjkc5PbIUAYBGQf8IyhmuVOIPMRx PUKTsVWBVt2R6kjAxkE84+5xjWhrXArk9M8pzq6mtkiXcIRRJF5fmMU8wEKWYMwwG9XHA+nH OdJKykrHrPJ+clSRAE8xQsZUAEYHK71y+SOBxgdtCG9UqROlLAkikjEy1Zxyc4zycZJ44I3d h21imvlvMStU00jwRzGJ8SNIEYAZycdyT+WWwOcAGGuB2V2/4b3WY6p5BJG5eVShKAkqygZB YMM8k/c47jvrWhq4vl3VWqFjiJcpWzSq6nnCAkdxk4GAPUMg50hr61rjHLCkEkk8R4C5jXHd SxPqQYxkEA9xn30uFeIo1hioIZIVC8pMXkU4wc54XsexPOmFhaDqqss0tFxy1LVMaJAAjDKR h0cAEjLH6429hnHI4PGiTVeRsdkhDessIYSXGOSeARz9RjOfz06W3xB6nsNFELQKSehilKx0 dVGs6bnc5YOJEce+Apx3ONNHUPV156vvC11XZ4LbVCmMMot9XJKtQVZsHYyegntlieAO+NXk IFivVMfGwMzMOvh91tcr/BSzQU0kM0tQAGWKKpSVo1wTlsOAnB7Z+5PbS3MMMizwSGmYIHl3 OZA4GSrek4yfvz3030kdQVdpUkjnn5dZVBQhmJwxVRgY5OQc57862njqJp44khq2gABY7gkY JHDbM8gAYxgY3HtjVObY0WVwcScug9+CX0tuljqWmcU0kW1kWIwllBOfUGB9RIQdsYB/M6Jl usFGi00CxKwjwPLcDb6jg855G4nH1zppq4aOS6VOyNknD75YoHYFgRzmIcD8PYDuARxnRr08 M1ZWtmpWiiD+SkmzzlAYgNjHdVGCAPcc5GhDA4UUbGgiuxKvnDdqp3LKYGUiNdpVDycYJ/pO Bk/Q5540lp4YzLiBIQQxVmRSgXscMxOMdweBjcv01paYmiSW4QJLOWQBQ7KyLz6ggbBwD7ZO eO2lNW9NTVK7mCVByqyxjByQCV9JOSMjOPrjUoNNIeiY06i0gE0FHQbKWZHeR1VzKy45yRnH IxjvgD3+mUNSXjWYUaU9TK8RUqiSho8D2YrtPB9u2dLisccUUcRqzNuKgNSKWkPOAvpz2Izn +3bSeGhpyY0SGtAkYbkUtESQvODjtj2OmjK06IwI2/CEyJ0o0EkLyIBI8e2OFD/MIPBLMSuc 8ggjB++hUWyGCkMbSPTQIdsqLL5e45wMBWA/QjUgUSU5jMcYhjmKhCwJdo/xdn7E88DA9WdI 62kKypXVKQS8ggS+kHsOfScE84z79+OdMEhu7Q5tdCmiKpES4WNmEOYz6mBOckMeO32576TL coKmRZmjy+chHRiGbHvkZPb99PsUNPKkU0XnRxsrEKrj6ZIwAA4H1GONNpsMaztNb6tUM0od WkUAM/uvp55Hfnn9ObDhsUhzyBrsob1PRqY4q6mImkgXzNqsVZkxgptPfHBH5cZzrsD4UPH+ 33m0W+0VVSlBcqCGCgippJ0CVkZU+lc4JYkFlznBJUEByDy3dLLNCY4Yw5cgZYhjk4LHGck9 vtjOofcbPXdJ18lXTJ5NCsgkY05y4fgZjKnnkA8H2yMa7eAxIZTXeSwOdZ10Xoj8QXgQnjBQ L1X0vVM99gg+XSll2KkxXdiKQuCY5FLnv+LhTtyG1xb1p0RUdLTJY7jA8d3gCy3HzOfIc4KR 7hjgDGTyNzEf082T4b/GFe7faaaOouBV2bzpJmVZW2k8+YpHrQkscZDKcgEDv0XQ+P3RHV9J cKbqCnoblQeU0AnWNWSqXgnYkwDpkAHbvyOM4ONbcRh2zOzxGnFMa2lxP1XQ0lu6muElEfLp 5ZFmjSGTescMih0UHP8AhYD9OdO9vlrbUen6mzQCa411ukjEDx+clePmZ43hkiI9YYKqbcf0 DHO0jpa5UfgDfaj5x+l7pUTU9HHTBKWoZF8pF2IcCYjcqrjLHPAzzqZ9D0VBWm2wdDdE2Xpq kpYJktt7vjpW1qlS8pWFGY875Cd2843duMaxtwMgdq4fX6IKICpzwt+Gm12ystHWnUNFPR0E sU7RdK1tM8lXUShWXYoOAYSG372CsF4Pbfq3PHPxPo7F03QwV1/p7dPBRhqpjGXhgYHCQRY/ HwVxsBYKWbaMYFJfEx4zXSw3WyVFJfIGM1MstQnnrLX70bJjmBVQV9wm0Rtg8N3NHVHUXVfx BViWy1tUUfTdGiNUU05QRxvuzncqgu3A2kjKr6c4HL5WshZROg3K14dhLuqLJTHc+oZ/ELq+ 4dQVkNPEJZGctRwiNGz2A4BOBjkjJxzzo1bEKRlgp5jIki8AoG7/AHwQfb6d9Wf074VVnTAh lgko6h4Su2B1IVec7gdrZPA7jU6oPC+xzy/MVMU4ZzvaKOoYID9guBjk9tcV+MiLrcTXcP7C 6rOG4mQbDz/pUb/BZYbcqvSSlT6jJsJXcecnIwO3fOk1PSKlSxjqcfyyWSVQf7A9vvrqmj8C rF1FTKKfp6qaJh6ZaeN03Z7neO4/M6cKP4Hv4r5jpeJrOkgwVq1WoIGOMBSp/dtc2TiOGadC ffgmO4RPGM1A+Br6rjwV6SQSBp1fcAhXbuyv0Gfbg/XSPyKaJgyQQthzs3OTye4A7Dk/212U /wAAL01HJjrCKo8oM0cUVtALHHA9Un58Z/bTbVfBwlqpWNXUOqRGKQyqGVGbAB9B45z3zx2+ +lO4rhmg6n0KyOwMzRbguPJdi1AdhFFH2JZuTj30XVWCKbe6uxYscEEkngdhrruD4TrQJqmi F1C1i7FMpiUBmf1AfiPsR759tMl1+FO8Wpx5FbBUrguwkO3acDa3I7nOMDtohxbD3QdXisph fqSFUdh8ceuenrZFRNX0VQI4xDH89R7X2AYGXBBbjGSeffvo2o+ILrJNoM9sjU/hZAzrvH5t /wBNSm9eCt/6aqc1tsqH3JwY03gZA7kZIOSOP20wVXhhVmkir2tM/l+ZtSYwtswfb8OAeNdJ vEg4aO0QZCOSltj+MO8207bj07RzynG9qedoo3PudpBAJ+x11T4S+MdN4l9KW2sgilo5KjdH 8tM28xurlducduPf2OuFKvpiC5bYnp4ctlUVhxu/t9dSzwx6qu/hI08dPAJrdWne8MjkhJBw JEPtwCD+n0GunhuJZXDpDosr2E7L0Gudqs1qnSSV4Wrjj+SjAKM/4h/y0VNcpkdIo4REh4Hl Ln++uE5vFvriG5hpKylrJpCWkaopd7ofbkMD2xpxpviS68sTOmLfcEwCYWhki2/Ubgx5/TXT /wAhhCdNL7lDE8Cyu+0uCG2O1QwdX/lBT3ORz+w0mp1pzUs0U7MnYI3t/wAxri+D4sescIz9 OW8QNjYslU7lM59woONH03xd9TiuSWKzUHof1hXdlbAyMcDTX43CULdt4oGtdsusK3xJ6Ttl yanufUttoZoOGp56+ONlP1ZCc6cj8TPh7Z4VX/bKyMCcnZVKG+ntnXmhfad+pep7vepgslTW zyVUmFLGPcxO0HuQM4H2Gt46KnZAZKRJBjkgYzjtxriP4izOcrfmtrWxkalej1X8UPhvUQvU Q9VRuU9JAilJPtx6ef01w5/4hdj6Z8TKe3+IPSbQVctFC0d2nSq2s6kr5RKPjkEsPTkncONM Nss7VTxmko55YD6TgMAn1wcYx9j7ate5/D706PC2svfihWVFH02sbTUtuoyI6ycqDhwSOEDM ME5zgjHbK48ZLNK2m+/VdKLCCUFrRv3+fYvNILMYvMREMTcEK3+Y119/4efQzdUdSdU3Goj8 qnpKaKKOYSEFZWbI4Ug9gffXMHUvTaWq5yG2yrNSSZZI9+XhBPCOeAWA7410/wD+HFRUy+Ld 7jraqsSqNtLxU0MmIJlDAN5iY9RG4FfoQdN4u/NgJCw1p9wsmHw8kWIaHjY+9V3alj6htr1E Nq6hqKWZ4+JJJnqYpFB7GOXzADg44I+uvJvxd8NaTonxD6jgoKpa/p2jrnihrcBBIQcsij+r axK5HB25HGvYO+1YtNouNRNOlrEdM7fPMAViIU4k259S8AkZ9iM68TuteoLrebtJHcWKNTuy bShXnJyxB9ydcL9NGWQyue4kCgtvFHAhoKlfgS1FX+NXR7XSlq6uh/ikDSwUEbSTFQ2fQq8n GAcDng69gqTxJ6PuMiFuoKm2kuVYXq2VFEiccbnkTavbuT9teTfwjdLX7qbx26VNjnpop6Cq WvlnlbCpEhG/I4JyDjA+uvW6rqLgFleGfyTG2JVAWXd9OP8AlpH6ikj/AHDGObm07TpqezRV wxucHxTtSm3V+17bcrTcFb0+bR3CJ+fbILYOfy99Zbpy5syhqCnnWPLAwzJuVSO2ASSPoNV9 J0j07fqmCreyWirp23ee9LQxOXPbJIGQefp+emKv8A+ihK8kNvq6epHAWCvqqNQnOFyr9u/t xnXlg3CuFEOA7i0/YLvmGQiirea2zUxDyxEbDtyVLAA/Rl7H650kQ0tQ/lyskk6/h2ybd324 IJ/v7ajPR1FXdJ2w09p6juq26L0w0NdOKtIeeVWVgJfrjcx9sY407R11yq697hVXAMGi2eUY l4Pfcp25z7HOfz0osjB6pPmB+UkRFrb08CnVWKRENSKp7hpF34X8+w0mME0yxhPLdAQVjPoK c/3/AL6IS41ALsjSOzZBBkJznvjJ7fbJ1vLUuKdS9LISc4QZQgfY8jOs5prqNrPmAJbICPol qw1MccsTrKmASFSUEH7c8/8AffRYlhdwwdFnAAdXJH9+2m+oq6uWgZNwhVRiNkAmIPtkcf8A edNFVcLtRQUk9FaKO+SoQKotP8pI6e+EcMpI+hbTC3NQbumGNjm77KTSxvtO6HywcerIYEfX j/PSb1xbCEYxueXOAB9+/wDbRsUkBQOkslOwAdImK5UEcqRnj++hNLMQf5qAEE4hwufrjnH7 ftpT4yN1nfCWHalrOiU43CUiPPq28D8x30jappUOJZWc+x+Xzx+2lMLJTQIXjVo395FZXU/Q 8kH8+NESRyNIxffGSeyxkgj653DQdCXfCR6pBwrnElrk5z1L1sxijlWSCQBVbdtbgAhQuAC3 qPv2Bz3yCqlkgqQCKsf/AJuTYXaSTOONwdvQWyOOOMD202VsdTS01HSTmLZLKsEKToseSuQx Ee7BIyPSPVjJGOBpEbpFbIKmKRIzUuHqBTUiLKylsnzGQbVDf4Q4JwoJbvrpjDZW5yDqff1T skbG5jt5p5NZPTU6xxNUQqWVR5DMjRL3LbQBnk9s4I78jQqquousrTba2HcDBG9TEM1LFVXK AYbuByGGCDxjkoah4rbVRzVEzhHISSnniBZDycbYkHsA+7JONxGBzpclfBJNuqvlmkVFlihp 1klUBuxbn1AkrggE5PfkAqzOyGK+e3u1ZAA5LEkrww0zwzK9NtBLqV89EDZHDeooM92wecg8 jKCqqUo41gqJo2geUqp2sfUMkdwct2JOOQF9idLK+seabbPTQPBIoaNUnV9wzkOSdvHHcE4O ThtbwrLM4WlWQkjkxRt2C5/EwyoAwAGPOPp3zPeWmneiSZHRm/sPfvZN81TFUhllmqJBG/NV EfOiRwxEjtIynDAB8KAcc52/0k22rsvkrWoCZCjmes2rPHJEDlnaVUHpAA5OTxj25dYqhaep f5Y+Y8QL+WwEYyCu5lAyceoADtkDHsNM93oqW6T09LcBLJCA0ohXETEgqVwxz6trMp/IjPAy 6OeNpyHnz9/ZXHJGRkeN0uqo4vlGNGacxqBK1dI+9RIOV3tj09g/PcEEc502nyZx5CsjpV7U eocBsJtUgxMhG/OxmJAyNzN2wDvDBYun46ht0FupNhk82q9EcZJxyzkjA2lcAkYUcHOozP4u 9PLWIvzC3sMrMkRZ5FJKMAWXO0g4cMuQAW5HBwwxOc6w00ee6RJhW3vl9+Kk0dvparZURQb4 mXPzEbtujJyV28ZBPmcEdgq7c4BYukpq6O8yiKOCvimIEpVPLfYQ4CsAccFnYbTk7drbSAdR C4+O/S94vHysbVdyqKiUvAkKP5ScHhDuA5AbjGQvBK7eGP8A+uPTMFa9M9C61MlQFDNuKI45 GFQ5OAFClePrgc6a3CSl1AGvfK0LsFC42XadwVsQ0NKkIpf4cdkaMHjmjfcOQNqvjDAs2G4w AckA5y2LX2GunhqHSCaU7YzUxOJfLffkxqGVsDYeMYB57cAV3e/H+ZIkgobRRpMqsoPmIQzb mBAXLOM4P4uPf+kkM138WbpPQz+VT0MX80GaYUa+p2fgOzAZ52ZOOcDkncdUcG88lT2wscK1 HcP7V2CO2W+4yyvT0sdQm6OKsrNizREqzbcsnO4EOAfbf9wut0iNDS1dXFJMsZiBZmkbY6jH OxTtI3FMdiSzccE653uXiBcKisZRV/IoI1/8uacu6lGUjaO7AF1G3BX8vxFlud36grrepiqp qmiMwh2xysHRTub1q24H8L8Zx7ZAJBZ+xkdRLlndYBDQaXVsVxhiempFqEqbgZC8ocPuUnG3 cAzbRtJ4wMkEDliWa67q3pvp144Kutkpwsblqd0TzkYFTwA3PBzgZPBHPGOW3uU1VUSQTNUS GKGXfLETI7ucD1LvC+oeZjsM7snS+kWWrgjWNfOeNgWl2bCQDgFUO7Pr9snuc5AXLhw7m4gh Z80jusFd9X44WxrjHSW4XK6pI4mlWGlJ98NEo+qj2GeMANgBtIajx0tnzcMFstFTXedv2xgr 6iVJJwWO4KcE47YBxwdUXV3eno4vLgxHJNKzNG+8L5rNkDzGPJJUcAEEkYPfKWnuTVMZq3gN UqgEK8ZlR+cMVyMMpIHYDOzgck6JuDjDrSbdVVatq4eMV0eFGt9FBRrCok856jz3HZ1Ut+Ig szkqykA7PfcRGb511emooI5L9HVPGXqKuKAgpGDGiLHG/DEgZye4bKDldxgVULeSk0ddVR02 FZ5KeaWD+Z+EGMAkj1ZPOOM8fhGjKNKdKc0xetgpkYOrSR5VG+qhx+HuMDnOM9sjS2BjGkNH y/KG70TjVdQXS6D5SevuVdC43yJGrSOQBzvP4cAKOTgjaPpy2T3asSSXNvQB18qZlkDIcYIJ B7jd7ZJ9S6WotKYzHO7SoJA8u9UJmZQfWSoJzg45wPoMaJqamkqoFFrpqdYEA3SySnKpnn6g jDHuRngY4yXjKRYQuiNXaY6q+T1dM8DyPWTugcwwxsCfUMHJweOcc98jseEs98aumhSSlRHG T5TJljn1INpySDhuPuM4GdOfzlZTsacUUdRGrvERGQocsmxWyxz7sAD3LDtxjNVdp2mSSGoS mgKAeZGQrbwu0KpH4sg4yQeM47+mxV387WfLaTW+ghoaN6iCjhRGRi7vKZJM4PGBkFiQ3oBH KDAPbQDRXBgjStVQlNyzRR7toB2+jPCYyeD3IPPPKpKRKiraWSvM3p9UYQxDb/XgDBXkkk/8 II0graWGn2s9XPSAwqY5alWYRqQDhigHO72zkbwD2zqAZyobOlJRWx2uKuhEZh+YpmllImG8 gso5I9xx7cDdxg7spEuLzIZILg3zE+2Xa6BQu4kjnk/haPJKj3545fOkrB0V/EVl6jqLmTJO m2joEESy7ckq0g3SEEKBtUA+oev3EibrjoZLxVeR0HNXQgGMJcJJahCn4g5WSYscnGCQcZ1q axuUFzvXsTGMBBtwUOsFBPdr7FQ2yrjrakPsiiaqGCyqJGdlGQMLGeM4OH78a36mv1WK9Ib9 5L1kaMlOKpvJU8guA6nByxH9wM51afQvilVdZdVyeZ0rYLLQ0lJLJ8zFQIlVHjChBIqIEB3H KkEld3POoT191R/EqVrXS9PUKtDUlam6sGepf1cBCONvPKnP14wNKcAHijengvRxziDhEkNA 9I4U4g5urrQPK+aiCTUy7kWLEkky7JY0YkE4ClmJPpHpJHbB+mir507bKC3AlliJi3xMikFY 1jTeSw5A3A85zmT9dEmgoLhNFNUUUmd5jEaEv+AA5UdsZLd+eOdKt9PlaRoPIp2kLg1EjJJu HC5Vj2CNkc4Hp406N9HUrixTFt3r78FHPKpLJX10NdI9IPl1qkLqZF8tgm/aA43nLN2IYMMH PtIbPUyldtPFUUhpUCxtUxCJgFwAqqWBx6clvquMjsGx6GimqZRRRiJJQM+UWQyHupIwOQSf 1LfXTjQsa4yTpTUqRJuB84OGIYtnG5DkANJgg/X761Oe14TjiW2QAlbVjy4eWponSJmSRJq1 l2Z7EjPGQeCD3257DWa65W1QiYIhkDtEtJUg+c34cBGJLdmGQdoHJ011fkF6l/k0FKnqkSNc nB78HjgnuD/T+R0RW19zWVp4rPEr+gSzNWursG9J4BIxn1HnPt9DpTQ0mymNkjI1Ujtltpyk UlttMlbMJMIJahmEUuANuVIXjIGQO5HHfRlfLEHkqquikpJFkcFIoQxjYfiYZBPJ39wRgDOm ue73y7maSWT5WmG2ELDGkSrlc+kqfURjB3D3HP0cljnpKd4YZGglkjOKguHw27kHaBk8YIx7 cEHJ1RNHUo+mFHsSyunkgkiiSI09SOD6dxjJY8YzgjGR3AGex0z0lCtVBMJ555N6boVeaMu2 XyTkMBtKqTk5Ofsc6Sz3QW5auSeukqIAu0pk7iAB6QQNxzuA+3PbjWsFykbExgaNVVWZAI1K rxxuJOWGe4yOfYaE6NvdCZxuNUspqdgscUlIZssI2Rn3Bs8YXgbmwc8D8tHtBDTLUx+TUU87 uSszqittyR3z+pOc5THGDpOl2WFllnSGOYNu8xdpbOOX+wwT9e+O3c2ekpbhSvA1MlSEU1Lu +4ofwKFx3ySWbt6gPsCBDr3Cpjmk7Wm2pnjMJ+ZmWnY5bzG4BdvV7ZXBJwcn+n68aPmV2cUZ gWrllRRSkN5cYJKrhSCXbPDYHB55GANGUFsJqKiqpjSrLGGkJY7VJOTuJxtHZjyMgA9vfSX5 yk2z+VLBC2StS0yKuPwnAIyeG9h2B0bT3Jofzy6In5A0Kos8JppJAqLB5zMQ6oMgA88HPHPt jOkV6vl5AXdRx1oYYEtO4UhOG4xjOSDnAHA7aW1VBV3UM0FM4SNBLDP5jSsF4UsqfcknH2By Boumoa2lao2XYx04iEkkZAztUAYAII9RZeABj786aHDdygfpWyULdPMhgmqKKaAGRSzMcpEh wdpHGBjcNx5HH5a0L09bSRSUdVCG9TMhcPtUHuASd3CuCCBnAAzxpzuVjmNRNLMI6mmikMQl Ks6+WQQxwBnHHIx9RpjrKe31td/DDGKBTt/8vDsBYnkc8nb+EgD3ye50LTetLNcjjmqgkFDR 3CtMSwRUkgpnBBjDoiOclTu2D04zlSc88jTsKOaUssQEkAbaxZVKgZyoxwT2Y+/sNOEXS8dv q54qOq8qnKlzTLJgu+AwYndhfw45A7HsdJ6myyUleZllqKwMisI6iSMDKnG3lckexAPs3HfR Oka/UfRMeC4XXyTVdZKiJmFLDMWG1FKMgBJ42ElgGJHbjPHB76Iaz26SpqqKoSGStijzJFuA MfbIf9+wz3+3LzSx0cTiNZYYml9T/wAwEKAM5247+kn786NSzSVtY0sQVzsO8x7gOMAHhe3H Y57E8EaEOFdiW2LM0khRy6dDW9oH8mnRN4xAIgZOODyowW3fTnSFeh1knnhhlqIDLGpiXy/L A3YPpPHcEc4wAe2p5DbYzNEQ8wgJaSV4JPQR9FzjByByPqeDwNLI6Jq+YUdLGLlUOoHyzxnc pPbJ9h+HkjBxqv3BYKa4pZgbdNUIprfcRTQ0kNHLNCHYMyOm9CMLuMgw3fPbjg8ZOdM9DWdf 2lK2msVzorZFPGInaMtM8wydzRu+SkhymSgUjYpyCOb4tPhF1bVrEFsaUeCzfzZkVVXJO4ZO WJ+gGfcgY4sPpH4aYqmaGS71yjbiXZSgbBwOGLDkfl74576S7jLoL61/NE3BYg7NPiuEOsej Oob/ANRz9Q9S16VlXUTiWdpo+H4A9ZQLlmxyRjJycknUvo4bt07V0zUHS01oqFUmGst+5DIN uTuRx6lIBYbieATr0Mtfhf0/Y5Y5lo6dZV/l+bUEjHJwcEADjGD9T+okFFbYo40jmeJQQFaK Nxgf69iMZ+v5a57/ANQPkpro799y2wYeeG8p18PfyXFvg54pU3XN3lsd3sNdNd44jMq2xSPO QAZIXa5BGQcDIxyNW20UNoqzOkM1rjidSklfmN42xkbsgDP6D8tXjV9K2qSolqI6OkiqGXb8 7RhoZ9o7qJUw+MDlc4OTpjXwk6PoqZZza4Lh8zuiIq5ZKwYAwCFkZgeMjO3OPvrnu4kyR1hh Hdv79F6KLFvYzLK23dybugvHpKq6xWquulDdmZghEGGlj+5EeRx9wPz1bx6ltiwO8FNX1DAE hUo5V38ZwC4AyfuRqJWCzW3pO2qLas1npFYLHHEQiA/Qg54PpH69h7qq+vqqyNo56uZoxtkM IVU2MCcZYAE8jPJwf0wefJMx5JDa9+S0nFREWQbHK6tNtV4mdSVFV5ds6RpIacAf+YuVyClC c8MiK3P4exIIbOeMaR0t466uglir7zbbX5o2hLTby5jAOSRJM5BO3PePH208rUxzSbflj6EP KLt3Hn8J/U4B4/LnRVUIqZAZ5GX1bVczbVlyuF7gng8/nkdtZumeT1QB5LkSS4mSy3Tu96/N IKamWKhCLP8APVChXqCyiOTd7uwAAAbk4UYHsBgaPqY4o6OFkaONNqmSKnXOAx9OVJwARnnk 4x9NLEt8TUSmSOWStLhlAXkkLgbivAAH3wdHwU1GDMaSnZZhldhTB7gn2/CePp20FGllqVrd RumsRwTv5bRs0r8EIDIcYOAM44GMcZxj8tJDFR0zKzySlThGlRiABkZDDPb04PHvj31JY0cU iGaEHcAT5P7gZ4J7HRiNHBF5TFZwx3NGjrmNSOSwHbHvnQZXO1C0ZXOFA+u6i9Z0Fb7wjM1n oZfNcsxmp43Axn6jO0g9/wA9Q2u+HnpmthEflVNJMrBozGxWPaAdwIPOCM9+RxjVxT0wr4RN ByFXbKN/YZznB7j084HfSOCB5zI0js1RuWPaoDo6H6ng+/64763RiWMAtcQr/Ztc0GwudKr4 aqCUJHTXTZLGSjmSEbTnJyc+rtjHJ9tRO4/DX1JbY5XWSGqIJwYnYNtAyWywB+o4zrqY0Bhk QNCSUOYiqYG3d7gHGPv3yOdKRSN5xQkmNm2eZsby3HYnjsdOGMxUZoutYX4OnUuPI/AO7oHl iHmOWwMyhvUBlQwP4SRnj7aZKvwr6mpXLfwqumdHCyU8UBYrxycAZOPtrtunsJqzKztFGrf7 6B8EsMDAUe4GPz1pHRz0tFKqu25QzKeGZTxt7ZyO3561DiM7QC4Wq/x+U3quCJLTUUNOFdai mqdxG6ojXcf17nn7al9qnrrL0jcK6g6Im6iqJKiJllp7Z5rQkjBIODkEjtjg+/ONdeVMQqEz WU1LLGVKSrLAjcE4xz2wMnj7aUrFBSmKCkh8pZF2lkXCjA9JDD2IHPtnTv8AKuBDgwX4p+Gw joHdKw6jwPqCuJX+JyKwRmluvS1QLrMh2xTU0sQUFcoREqAEh9rZ+gI7HinvErx36g8YbvT0 c93qKcTM3m/OO5po8nOAoBIXIXgL3A16bVVKlNAwalSaUndtdQQnONwIPPtznkHTTW9M26R3 YRCnqFbAJjjU7885DDA/7/Tof+InNbl6HXuP9LsOGJd1WOAvu/vReVPX3hbTdHG3hOraa5VN Qmaimiop4Xp2PIyJFG5T9e/299Wl8HN8t/hX17c73cKh6ySe3PS09NBD5ju5YN/8R6f767nr KOlVzHVUlHcDKW2xV9MjI4HfJPbv9dV11PYup+jKxa3w/wCh7FPHPEzSusgp6mln3YPlMQAV K8lW474x205nFm4uP9viRQO5JA+wWUYF8bw57tPAn5KwekLvcOsbNNdeuKGC39G7SJ7fTSeb UVPJ2xtkZGeBt4JGdpzrlD4n6TpnxYrrteo7FDbKwxLDbVtMGxm2jaocYwwCjJJ54/LUzntn i3fLrKty6KqmknTLSwV8G1vuTnA/I6a7/wCBnilfqaWko+nY7M86gS1dZWROoB4IwpODyOfc Z11cPPg8KwNieBzJsfbl9V28uGEbmnr6ULafkDse+hsFzj4CWqPp+/3ByxesEJXCnYEXIB++ c4GPvq/4upq6GNZKeunyeyeb/u2HseeffnTh0r8FXVXR081Zbrxa7nUVCiOqinLxsucEjBBB /MHUmT4ZuslqFcU9uozGQVX5kYlOeB3IPGlT47DTPz515I4WRugYQExUHiT1IYGb56qiAwzM khV/pwRj/vGpRa/iPv1HGkEldDcmXLK1ZGo3Ad1LL9PfjOmmp8Ees6OqOLLPhH9XybIwBzwR tPb9vy0ZcPDrqVg5mslTWBMbtkBVs55JBHft+eNc95wjxWnyQZsSwZWE0rH6e+JxHuUH8Ssa ikII8yhcTMsntxxqy7P4hWfqqnJoZ0lqi2TDkxzxfcoRn68jI/fXMNDHNYaiaRraSz+ny56M sxzxyCPv37jGnWy0FassUv8ADZ4Kgg4qot6sSPbv2+3B1nfgsK5tjRaoMTI01IL9F1Wk8FQB TyyxA44IUtg47NnBH5j662emWlTJBaHYSWSU8flqnOn7p4kJdYxJYnkt5lCs1VKoKD/EobaT xnHOD21bFupZaZd1UJ5H2kMsCfy/ruRTzj7Ekg5HIwx40+H6LRjwfMLodK1zaFg962mjzAZP MlhjYlg64PGPwjAxoi22y4SSzulXFVU5RQI9h7YPBB5Gfro+anjr1ihIeTHOzaVDD6nR9JbR HIUBkaQN6FB7A87T9v7axiZzQQOe+3JQljqdWoRIpxNIykqkhUAKxHA98NxkD3B0bNRRyQLD iNCBgqqcMMd8/wDI6NqaZlqwzwIPfYCTz9eSedHU5ilbaY2T3WNsc/Xvx/lpPWO2qElxFgoi irKiN/l6iOORFHoLBW2fr3+/P5Z0smZw+Ho0lIGA2CvH5LxpKw+Tkdo1AI4TC7cD7+3B+50a tagRd0cMjY5LPg5+nfViajqaWYzFx/4mipudpNK9wYlqKVQDHCZW2BXGQu0nADPggkgjjPAB Ig6s+ZDRQo8pkleLO4FIIy+Dl/LXvkDHqAAbLM2ucZ+s62Slip6m6VUr1K+TPJA42vgcO6hy cELkH22jJ7Zb6KCWdq97rer3VXDch+Z+UR49uCCjCSQHK7hxG3A+nYenbhWUb8vfvwShLHJV cvL+leDeNFNZ696XbU1mAZJlMgeOPC/gLgKAwO3nJHq/F3w2yeMNsnU1FNYJqqoK/wAunU4Z cc4DPkcEkjcAMdiDgGmKjqG01NRIKG4RwJJEyPG77+c5UiRGIIDkElhkY99JY62upaWpiuFW JomCK1NIsm3aOcK4XsTk7R6jjvqm4RtgEXSytmkvYUrel8d7jWPLIsC0YlH8pqyVWCxrzsAj /M8kj7Z76bbb42X2qrGngMFRSKru1vemIlp5GIyFcOA4wBjcwJznIxkVLLXWyRJzHBU0vlS+ uPbIjsAQdyqfxhipBYZx6eMEYNkn8ym3LEaiYhZFp0ieTB7cbss5PIyqgk4PYYJmFuoLAlGe aTUgae9laF166vkzb6uvr4AMPEE2xnA2nejrG25OVyquRgkH6BLUV18q6JpDc7jUQrll+ckW VFXIKn08ByQAFZsHBJGThYHcWliaSoM5oRBAoaKWTygobCqm8ldnYjHcgt6RnGjWt9XUV0Ny qKu2UEbzllSnOJQ5AOQQEQgjDFQwJB5J5w6PDsdtt4JnRBzqc42pPJRVlqcyylCp/wB2JI3Y om05wNvJOQ2MEDcoBA4KWOnlZlaqmYVcuxBXSQn+YduFGY1CkrGWAAUEfXJ9UUutZep0ernr qujpljBho7hiQytwGCoFZWVjgncFBOckjnQo7nWPNEHVKmlMTMKks+8p9g2/DHDAttPqYgY9 mftTejkwQObpaPtko+bo4YWqa6jml2+TIvlLGg8ttz7iMqMbQVQH0khTgAHVN6jmNXCJXWCB PNigkYPF5jZReWKkljgnPPIwVPZLeuqIKedY5GoZo3MaGKZxkxEBVLtkBFUjjIz6Rkc8mtP8 xSw09QFpxUxmRUEzOjK427NrHDEYwDvH+8IKlQzaMxnTMEOVrdwtHgepjqpVlkeljHlyZlMS OzBgUX0ArGM7SQ5P+E401PWQpdlmDNIoxI8s9S0tPKCQTuIcE9x+FuTt57EZazS3ERQGaR6O LeFLLtjEnOI41UnaSVCkhvovPJLpJRVFVJCKaaR5vNEkbzyeZlmdcHGcIduTgjOG5zxgw5ka JsgaNESbhSU0ZV7hDLWSkbPmwZgjHBdfQhJwuN319A54JfbnUyvbAtdAtJFEvzW2vQw7QGYA geohFbzOfcuCRn1KwSR0IL1Fdva4zFikoJMhJKksQFPDEFuePUgzkE6LpqGnpoGqRtlqIpS+ 9qhd7gsCfWVJL+pQWZie2PZQH+s7WhBiGoG6VNV2S+PG9LcLd8vDI/mTjf5D52twWwQv+8XO zP4c4XJ1rFmGoZqV6unqo2ZRFAcZUnG3CgHOe3GRj3HGiDZp0eR6KpqLdNO/lHZDHsgXYVfA OVQHecbADnsMcaOp5qSit3yAlmqC6IZEY+YZCJSFDA8Bcp2xjHbjA1HltU1KkeHD4UZPRW2C uWrloqgSRRMjSl14U7gxy3OMHd6SM59+2s1uyCWQyGWASFQVdgWYMmCBuAwCV77TgIB9c6RI Et77KKfeA0gEuSCV7NgFVJbOBg8HHAxjRz28zVsFSaKKOV6dFB3f7oKu3sVOX785PfuewVQc N1mAHwpFWUVXUz7onon8lBKUkgibZhduNw9TNntxj1ZyMjRMFTWCUM1QjSLmOQxxiNZdxbCu p5wVY8Kp9O46OpoKuhpYWmpqSSmG3cZI1AY4zgnGSOW4xgg84BxrelNHLUBoqWiU0rEvIKYT NO+SwMbA8HgHfgkcHPYaoAu76UbHndY5LFLbGUxVYniYLKil5XVjgMCzApuBHp28jJBBOCDo 6Tp+qSV/mKiCkqxJJ5weqcNDsLbpHdwQcYY4Qe2MbsZbK2Ge93Gm86shjjoz5wjoZYxLu4yw QkEgMSSBtztYk41vFBc43Se2lqSVlRZS6kmJCn4JQyngeXu2kkEKDngZY2IEWntiYNHWtpen bTS0VHT0tznvCpHITPAj8k7sH+ZGvq5A7YHlpnBydE2q1T0800kdVLO+8RkBtyrnsNuV4LBs AAjOMZzpFdo6u93B2u1bGhj5j2UgiJwc5ZVwDgg5yeR3J5Olz1D1lGIq7MsKlRKeEGxFIBZh wCMt7HkZBYkgEW6UCs80DdXR7BJasXKnqkp6WplnEYZkMBiDKpIGSNo2nLHtxwGIJGdGmsni klmlqKh5jnaTGxDAEgekn8XGMn3+nfRsVPV1KRrTxTU8FP6mmmlUFF2gspXk4yc+rGcjHfSC pnwJZUrI6YqS7soQs6e+Tnd3Puvt2yAQDiQarVYaLXUVsKyrUCMNtmV3lDw7RKoZAWPrPfCj BzgFueOdIpYIaiIsXlo5So2Tx4Lx4XucE++RwCOw0RcKGkeo21FqilgJSVWEQLFQrOWY45Oe OzZUEcehSwT9UwUtbikpYYoZD5bVETO4UnBUuQCPxLwc4++ASWhrnDqhKo3qLVkWmztdqeok qLmaBHUUtOs0gAqZtjysoQAH0ouWPJ7cA94eZJYadf5izbVOQzbzwAEb0g4xk5578DtqddJT xXDp6sublCtHFWVUZMYVyT6OBzhisGMDP4xjjGq8guVueoiaMwNOudxVlUxqX5Bzk7R9Pbdx 7DSWspxIC9DxDFzDhuEwbj1G5nAUN3Hn80tWOaqhljrJ3wcFfIg28/iGeftn0++RgdtaVUFN iKdHEYXaY4y6MyrkjJDZAyF9vrnBA1srfPOVkn+YDFT5QQHPfkD6YYE88cex0cKWjWWCqqbf M+/ZGZKdAv8ALTC49WRkDJ5AzjnOMaK70C81bn7IiOGkq5GMSOHiYSqk4ORuYlCQCBnCsBkE 4+nGip6WIsWU+QyqEVySIxyNo/4uQ3PIx3+mlMaVF4k20Mrox4UbMS7Qexzk55LHP0Axg5Gn 8IFJPT0/mzncCPmXQ8DdggD8s5HfK/TOb11sobIOqLNQrKY4mh8qPavzUeFJHP8AvPfALZ4z 3zzk60hr9kEcgkM8jusgEkpHJ5Pt3yw7+ynnsNJp6eup66RcLU0pifeIEyq+tccc7x27AcD6 HR1oguPqp5aYTFommY7lPoUFsDnkBM5OcYGBnOjAAFkqC9+aURVFTUU8sz06LHuaLzIyY40A POHICkgkgjuAD30nFyV6d4Fepp5i8YwlVG8cgYE4wSoBwR3wMAHByTpdablW2Zp0irahKWU7 ZKRWV4JI9u3lD6WPIHIJGec+29DTUUlTKtbT0z+ZIXSmEapEhBB2lFxkHG3C/XjjtYoWmiRg GhN9/wBkyydMxRIYlmd/UyySs0nm4I4Bjz5ee3YZz7/Ry374ZmhlWZIGMbRsNokB5wN3GQBj vwRjngk1mtdawp4Ip6evhjZA0kwZpZdrBpgdmN2GA2d8rnJ0mhoKiUv5ctbVFVaWSWZ1JkXf wBxjkMO309+c263aFUX2NUbR1Mscyr8hvU/zCUPAYn8OcjcTuBz/AMX17E1vUUdBcXgWITny lBKRjbhCeCrEMTzjAOO3bGQljo3nnnjVIl2gJLAsLIzDHOMEqSMgZBOMHkHOjqWRLd580FXV TRBd0izM0pBOQACAMtg+2Pwk50WVoOuqa2XKdk71VX89WyClWH5UghowJE8pSoKq+UAbOQPS W7McjTdPTT1lNB5ZlpBFGkDxEDEae3uBntgqeAB9NCu+aNJKKNA/mZRWSRY0Q8hSCQMjG7kZ wPbWbUbrJTVLVFrktbQRZbZ5crDYQG3uRgMSyAE/U5BPOiaNNNFqje55AGy1qek5HkDPTrG0 ZB8qjfYZc8qwbgZAfnOD7HtrV6Waeutk0lXNRrFMUelDIA3pxGWOcICc88ZDDUotk01NDJUm tjkkeEMUuWQC3BBAOBjGPw98g7s5Gt5KanvFUklfTPUwyRlo5SY/MTOPwr39JAzke55JIOiD 3NPWNrphpA65TfZZqhULO1FS0kLKHDVId19JJO5GwxOE+mMdu50teYKUiqqOUyQkzlY3cCNd wAG5gCMbfYE4HJ5GhX0FNNFcmpmkoah40hiVd6xysrAjLJu9WzeM4/E3sMg2f0B4Q3m9oDeJ P4ZRKuYkcmSY4HKNjvmRTgEe/wBsHNK9jB0hKcxgeepqqjovKkqKv5VEpF80LmOoJMkXDbiD 3GWx9fsNWfaPA+r6wSlaKjNN5eZUra6NzGqMWYyR+/AA4Ug8gnPq1d3T/hH03YK+huNPboZK 6lYoaqRS8sa5bzCBwPUS3GM7cDkcankMlRSrCJQ6CRnMixxknGO+AQck54GQeOORriz45zv/ AMWi2MwupzFc+0Hw0XChaKX5qjp6aRXZp0mL5AHpRTlRz2GSAPrjGp8vgh01bRDI8FTWP7yI 5TLHuVLYBGPSQM9+/A1P0kAby08uOExFiGcFVYnGBlsDuCSAeDoqeuEDQmdJJWkJjgRUZ0jb IyxVR6VHLe3BHAyNZRNLJdk/RbIsNECWgfZRCn8GemKGjiU2ZK9Z4keR6qZXCEDDHBxjGFJ2 +7cdtSSj6Xt3TNslo7REtPFEWAZo1OUwCDk7i3APfGMac/P81ZYzJC8W5ZQBhditxyMZx24z +LtrNFWzUU5p98IMgKRmFGB3ZyecHafVkcYHGhfbhTjZ9960dC0HSgQsU1As6VC1iI7upZtw yjqcY4Leock4B44x3xpBNRxm6I70lSkiKgaZJFWNOBjdznsTgc/fTvLDCsNKKuJUCqW+Wlj9 SuWGWUL9QR2GOCe+dCO6KzGTyI4nQbkJ3Lt2jBVsjjJ44/t7Y5CA/X7/APPmkukFrG5YKZHK L6HJ8oYXu3dTyBgfU98/lpvqrW/yscgaNJQ53SAAEnHDBgeAMkFSccZ0puFbQUxkRInafcyy eTMEPJA/GT6zjOcZIOBnA0hKwVE67CAzAoHgmwQ3vuwcFuPz4PGoWGPU6fVHmoZnAj0RfkXW 2XBEMdM6PHnbJISSCTzuDHHucHPvpzqqU3OFlqAYI+5VT6SBnCjHIGWyB9vfSWO3tTUmyORc kZInG5pMjA3tuPbOckfmdEDcKURRgsyyMoMS4ZQD9wQSMe2ftoXszGghc1r6tbigiVQwdkKD e4IBAx2ySc8Y/uPvjanK1MrVLVMkqopwEiB2qSeDyG785PHIxoWxLlTUdO1TioqFUF22eUzK WOMp9h7j6E4zpfFG0NcJZokpZQT5bjg7WySc44z/AKnQOA1DyfL+0NNF59ffqkaSMssSiWWF 0O5JZDkfcAnPbAAyPrpQKgvHNUzFDLJ6VnKbznPZf19jwM8nS35VaeEwLFStAMMBUR8A/bcM juf1zokU6PwigrGCzOhHo5znIAHft+f3GqyZaoqdVhFJGH3zv/PV2U7BuAIc498j7+/3xot6 I10k8pldJidoYMCse05HYA5zn6/5ad4qaCJpmbzEkjT0sijGcEHIPcEH20RPA0cKOZXWQEA+ k7cAcbSfrj2POdX26qAAkkaJMhlSIZk3uqbgZP5R/wCLGO30x9+da1kTxuCjKJAcn1bSo4ye O2fr9tGzTNUF2hcXHAyBGwYqG5JIOO2DzkE6Pand5g7KZKgBd7N6VH5d/wA+Pz1ABdE/hOLc u59+aTQzVI8tEo0EBZgpWRgDkkghgQeB9BngaT00Miyu8siwvIAVkAGGHGSAuMcjGSB37aVV sE0G9zCaxl4U+jGW4B5ABxg+/wCulEcqtTukUvpZSPKjO3nHcqc5yAeB9PfTide7wQEm9Bp4 JLOIxTMHZIpnRlG9m/mPjg5X8OQD2++impqQUMDx5bcA8qgjarBSWPP+nP29tHfIRMcFIvJJ UALwO2f0Ix3IHB0TNRxLVeSUqI94wSqeYM4/92Ox+o76IAOGyY1rC00i4J46qfZG211O0eYc lew5x7/n9Nbw1BLE+a0MiuBIfI2iTnnA+/P/AE0traSOqjaZJkkaFBhWbY5XOF4OM9vfvjTe fmPJklDxyYyUV48qGwMngg/rnuNC5oJpwrvVuY0nUUjXiaSQPLSxqzR4JIBJHYgjJA9u2i6l XDLGixQxhQ3ksCCvq7KeR9B+ejaOhlqSXkLRwlFBCKWR2/xE9/fsc40bWW6WI+WadCFwd743 5J4I9vp20t0XbqCgMYrQ3fYkMNHFBUyEIeCGw7ZwMk8LgYxnHGhLbYqnKzqKoM3qIXAUe2M8 5GlclNPICwgKDGx3ZOGA/wAODwfz41mGHyHJqBEBjIRCQGAP4iPbBGPtjQiMgWgLXRtu7+qS fIeegEckkUhxgj04579u/OjikyRMGXzpHb8UsXAIPOMY54/T76cMCZcxvLEysqqsYyQCTj7/ APfH01rl2afMjVNRGNzKH7kcdz7f5aENAF/ZWJCW/wBJGHp6yJ5UYJUj/wBKMYbGeRyMf39+ w1ushowjSU/zEJPlhigGfoM476U0skaTCWoUM4bAymxlOPqBjTbX9UCKSKCuphbIt2xZCNyS HJ7bSQv5e/OmA2ExmWTqhOUc0AUSrSgsFKsiOdxUjHB44+xx+eiJrVWxRiSIYgCkbH9OVz7c kHt3zraoVeDJJSNSkeYjqPLYjjIJzyRrcQtLArlpfMBKrtU7MHH2OMj6gcjTBJXVOyEOc3qg pHEgqWGYJIBsIdWb8Qz6SpBOfy/PW4hkdAUkAkX0nzM4zz3/AL6V1L+REBIzNgDEjQnkjuDj RPmNKR5bAOnpQxKeSOcHPY6zvdRo6BZXyEGnaBbzFZqeHCRmojOGlMeN37/r20kDKkm1o0fP aEqAcfUex/tjP66cEjQO4VxJKcvtbgFs47EcflnW216enaLIRMh2SZF45xn78/8Afvpxpws6 qOp1lIqYufKV2BOCBFL6CvtjIOPpxo944/LmmgI3nAZPcH64OkpqWSFhPGkqNn0AbgR9v+en K2V9LTrKxgKpjaFaLgH8yPv/ANNRpYeqTSDpIz1ToUlgBkp9pzIozhidpX7bTg4/voR0TTSm SKB5eNsbDDIftnAYfqDo+tliLJ6xMzKQpVQGPP0+nfjJ0nSJ4kCxxuqJ2x/SPoBzoTlaapBm ymi2/otyV+YCiJ1TcA6A5BI7++tvJp5y52yxsnqPlkH3+nf+356SGeP5xH3mUcqCo5BI5z7Y 0sesZ0SOUKp/9J/LByfuOP8AP9NW0DmFWmttWxSGFTI2QrHCkrtP58H/AE0TNWSxSFEXgf8A Co0p8p3jjVJndQMmFiFZWPuuRz+/vjW7mSUgpTSzDGNzxhj+/Go5o5JDzrpp77lyzePBO6WC IRWm3C4RyoUWqQokZjKouGVmwckkDZ3AIyecQ+TpLqSdya6jFuVBtSSWnEbAggAIqHdzgnJw MHvxx1dU36FJZPLeOKRI2CyVBMjxblwXIwFI4GADk45b08qblJTX63TUtZTU1YZohHUQyKZd 4YHIzhQMluDtGcE8jOum3iDgOsQfr+PksV5zWy4znsdslrmjSCStiViyMs6cZAZlLEAE5BP1 OAcd9PFPYY6WjjWghnpKhQGEVKmwSAFsqrjCldxzzgjk8DBN73/wbsUlFUU1LF/D1gUNL8vt OPSTtCg+2Rg4J3dh6RmD3vwzvdNbagULee8arhYk88M2S4UK6j1YIIHJHJwADjYzFxv0sjx/ opFDMdioHT0sVclQskR8t4fLmFSVlkPH9UoVAuMtgqRn33digho4leqjomqxSPI4/wDNVLs3 K5G4sefYfgGNvuTnTuLHWVEkRuSfw+aPDTJXTosjLlWfIC4XnA2+wyO7aSzUlsuEFM1HUUJi CSS05p6QNLAEQAFWd1KKcbhks5GeckDWwPsVm0SicpDb17lH4TRVdXLTw0f8XZHSTzK2p4hK j0sM8nBB9mPqPPIGiuoWulRTRC2UFNcKKpaNq96mSOJljGCFXcgZSWAAYg42jIxjB9RPRFIp KSme6KCHihuMoIdnYDap55yQcbAo7ZOBh9ijqCmyalgilG1IysLhkOwuQ8mWMe0bRu7f+3IG nh7mU4G/FNDpCLB+yidou1BbrvBR3C2yeZEwSrYXBA8aFdqqm4H08YAfO0AEDDcTfqGvsV2i mlpbJNEaUPLLLLcFqhMuCV3RrSlVwMt6dvpXI5A0ipnqvkndqerRINiGuV1JdPUr4fkA78D8 WTnBAzjTe+6eKtaoSVXifaI5WEexdrM2cKNxxljksDjjAXLQzB46w1HimMnP89lIIL9SIpJo 5poWJaGXaSZIwoI2sigKoK8KSoGBkE5GjYo6KSjgeoeaJqhTJ8pCoGA3CZVmLHkn359m9OTF 5Lij07q9OtdMWI8iLkLIp/AcscAHk+Yf6OxYegmS9eXIoqH+WgALEwmUzOcsdsiJ34VsBgQ3 4SQAToOs4UBXv6ohOXCiE8zV1F5jUkMlfTT4/nQ0zEbFj/Edo5CbsFfVsyDn30a15iiigeOq q6xCuyJR5jeZkA4U4CqPVt9Q4JJZiDyJr5FV0UkcpW5bWYqKhagOG3BcK7pgn1f07gMkAnA0 2SXymWCALT2+3U8S+Wi0sitOxVByAF9AyQSfTnIYlM41dWDoUVMcL5++5OMNLHXSxMY3qac9 5G/qdue6k7WARhkhiCSe3OtLlAktWaIkuBtUPEVlfAQbmHeM4GcYGcIAecEMktDMs8lwho6O asZpW3TXADzKrb2KAKnpck7WyuHYEDOhUQ1tzEVF5S0ME4YyT09S8nAwSvko3OFVvSGPMvB9 WjybU76I8oI0ItKbdXVVOQy1vzEcUeJJZIgFLjJOBuHP0+n7k5NRVyKZqigmikmOFSnkxGnL FiSPTkKQAc45BJOsU7Qw26pho0+ZpIdqmeFSDI3G4OmewyMAf4cHPOEk1BSRVUcho5GnLbRJ VEloywADKQrYY4fjHBJ0oEtccw09+iQXanML+iVo0TTTtA0pqHkcPBTCNyrHJHqJftg5AwcA 49iqCmq62sgjelgqBSxl9jAxUqxkABWIYjAYhMkgYGCd3A1IYbfbi9C4p1kbzGRYjGqFG3Eb dzHLMwxliCe4+uk9V0xBX2/y1pILdSbMOsa7jjIZlDIShHY5HGQBxgHUEreatrmfy3TXLOoq pTMkq0VXmOaqoSrwjJLkEOQXAC9s4JwAwyNPMTutIaRDHUQzhU2SuqhHBymcsu7G8cE+6++c syNTUEEkkXycaR5L/L05Qp6WDenO7I9LBe5BB+4UVF5/hVT5VPad4Ebu1WZAEIBOEfjKk7F5 I5AOMqNFvoB781VN1r39Uo+Zihk/8m3zEs8DFUqIwiq25QGAUgE5B4ACgED1HTbUUytXykpL FTxeUVk3PgFtxH8wEEYHGNq44BzxpVT1Fbc675yiVqZpA8sscc6Okr8YblgFA9lXH9P0xo6k stRTUEFNLJGuwCVJqeLfv3Fmk24JwTkMMD6nI9irKOsiLcrdSmitimpIGEU1LG4Kyb3kMmVC hnJKbjgesgfUZ53YLhUW2lkM1K0pj8lZHBUF8OyZB2qCd59P4fxenngAlVdt+VrKgVT1VCIx KoSELFsYYJzkjdgFgCe5UY9QGlNntdDbqQVZX5mplCRNLII25UMScLt4yzN3OT+IttBMpoba EtbKNfqm6eGg9MavJEqYAiRJAg3AHHp9LnKZ+vH1OtIqC3pMjyRU8dOQ8YWVDjORlwu8KhJG SeSQe5A07Xa0RJPun/l1cKgrH5eWZuQwb1KVHIBAH9Tc4XloqTU0qzeYaV3SNJVlGArSZOAG QH+nknJ5GSMkarmKKxvjIPVRl1jWoI+XraymgMzqDCVaWNtvLCQHjbgDIHJwRgZUQfqjpGer kram3XCmFU0hP8HqW3QNKSqkOxxgqD2b3Aycd5vSUkcsO4XCGq85PT5UuY42JJ3K4TcANqhs jJ3kd+DstgW4IJI4gKkqYVmgUs77cHBLjBAyxwQDyPrpjZCzmqGdurTqq/m6Oro+kKKxw3KG G6YJrJi7NEkaruwqgZySCo9gAvbBwrpOmRBXvM6z1YnZfNrag7MMxyznaAQfSgOMZHfOAdS+ KyKjyJ5blBIQGeZCszAsfxe/fBH0RQfTt1laCnqKkPUVKijpuVRMbJHwPSMcsDsOM54yRnhd NErgTWx1WvF4rE40s/cGwwBrdOQ2CjtXZs/KTh3BcIofIlCovBUkDKHkYYZP4vTjOF9BTVlI sUkKM1KE3SSVUjtLIwKsI9/pPckdx7kYCnL4Fkpo6NfLqJ4hIvl10hEgleXCohThpEwh24BA GMHnOklJBbqJnqVikpZGkZWEOCFJIwF+oG1DxnBJxocxy7JGVzG2AffvuTW98kpJqiOupoae iSIFtzyH8OxnBZVJzwoIA5986SJcqGKtj8+AxzuuWSTAUMTu4YOQyc47Aeo8YGQ6gGgoI2ln kkxu8r5hWiEZ7NnDc/7xeTz6vYHGif4fDc45kjkliTOHUyOEO5CgAwQD+JfSMdxg8Z1LaeSy EDZIp6h5pJYaScwRhnEAl9DYJ7o3OCR7dgSvPuRUStZ6V53kWNWi+WzHMHZQc9uRvBJbsOB3 +g2qLTOk8VTRyPS06TBHYudsaZUBsKuONrDkgHIJJHGnmAzuwEzJIXVd05QhsEnYCFzuxgcg AHn7DQUGarOG66qPzW+oioOauUSDasSQUoLRYGSzDnv78D+rtpZRQVlNTwQV5+bqUGPmTH5a xps5HP8AUTnHf379gpFlmqv58leI0hdpXnkjWNtmN5UgqclVVyCcHAHI9957dBURNiWQxiQn 5umUBVfsMs7EnnPtg7RxzoXGhVgqy0Aa/O01iCktkUs5mgZRE7eWT/UrHgHnPJI7Z9Zx2xre OqQULyeY8BEePP8AIDquCF2nBxjcvC57BSONOdPZKkxQsKtlmmkZIDIoc7QWBGQSBtO1uSOQ 3YqdIJ+l2WkdHo6xo0bejFxMdpBO4kMc8KfdiMj7asAE07dW5gAqlk1UELpTSQmF4z5KLTMN jTYz6cng+vOP0ydEm0pdwtKKJqtYWV2jqaoptIEnq4ILEED+r/Makdx6UW2Sjz56WanpysiT TtvaRh+JtxPv6gGPqx7nOAmhp6egaSSn3RBX8yMCEJ5Z3khgoOR6j33HGDnHGrBDTbVTmFo3 TfDbhapmNJFFDKxhBWNSrAg8g4OANuO3I+h0vpKivuDS+cjJWzSLE0iMcx+gHO0Dthh6gATg E9yArhgNaUgRZ5K5kb0eS6owAGWG1STghsnH1JODq1emPAqtrVWsvl6gpII3VxAjimhVSAWV 5WZ1jAYlcd/T24KlEmJjiADjry7U+IHYBVJbrVWXGVLZT0Mk1TXypLHCsrM7jEjFsEYUDD7g SBgg8e9rdLeA1VdGo466WjtlCoWOWlFXJFKSQ5O3ev4uMbVPuxGRq8G8PrJ0vcYaG1wwpVrE 0NXJGYyxYn0KWEm7dkod27dg/wBRzhfc6KmrRUYgkZFkEkz09Ttfa643gY5J3ZGMLxycghed LxF/wgV7+S7MbmMP+zrfZRGydJ2fpuWJbXTUnnoY1kapjaYQxbVJMRyx2YUj2wX3E55M0pLO Y3jFTJTVBkiWmlm27fQFAYJg8+oseckDIGO4VUlG1PQ5jq6pVUsFhhWJqeBgG7Rt3APpI7k+ +ToujrkaX5qhKVUsiKPPWRTKcbtpERiGzd68lfcuRkg6wFzXDfVdhrmUMoA9+CUrQVdtLS0c S/JwGJYJ/Q2MDGFABJ9R/CTwEP4R3R0PzCXKanqUqoZWkMKSrl2jQ7SQCg/4Dzzjvg85dlrq mCpjAlKVMilgiSsyrtG0hsr27YYgfiUjJydHwVdPUUjyeY7CUmNoJDt2elmyc8YBBIPbn6/i NrqN1on53u1cLSMW6kjJcKkcbykvNURLG0oJ9TbTjI79gSRt4IOQfcifmSaWaNknJ3AlJIy2 Tt2vwScDGCMYU9t2TrUXmkSljpT5jec0RRVi80xEg7c+nCkHIGQM4IzwBpbBQU1bVedR00bs z+YU2bedwDMAcjPOcDsc/XVPpugG6p5e3VM7VTUNQMU4YFE82ZYxEGwWA3K5UkA4OMdiAO3K if5OsqI5qKBERZAQkkPlgs2A3l5B9zk+x7Z41mYNT1cQRYRUiSXioXYEBBX7llbI74PP1GCc kFZGjy10DhW3FsOoCYGNoyOwIzgkHuMd9C8lw0H1TCQQHVqs0dsSvfbLThZxtdZIyPMOD6T2 Ptg4z9/6daxQSMZikjNEA74Q7do43KW7k85yAPsDzrEVR/5JUVmjp5GIg8zBXtncMEZBBBzn AHvzpNNfaijkQyVkbBHylPLUHchA9I5ypGcc4wcggHGlta11NO6XTya7VmK1U9pklcUuFq6j EjxIgLEoRuO3v2/Yc9hrBSNUEksYyP5QLEh2bJHKnHHfuO+PodK4bzK1FDUfIzyM4XzniiwA w7nnH35wP7a1kkpAVkmkmhG3zRGU3shX1AH6NnBK7tpw3Bzoi02A0Ky6UD4SmzyK+pt7TIiq sBAaWRuUAzkkK2DkMQMAfhwQfcVcDS4JZW85d7Q1jD0f0jHscH+n3xxjBydXCoSir6aDzJXj QxeZFGzSIO5TB3AEDnf2OQMEkYYJKqluMgkiVFZCWBeVo3QhSAGY5xgsQCCMZGRjRhmYdiKO QS3rXZonalqK+2jzJhJNTO3/AKOW3If8PJ2gcZ3nuDpdRztUMYlqCkwwy00qtuBHK5AXtgd+ e4755ZGqa6KF1CFwjOu1IxI7nuFYD6DGBzkMOe2lNvqqyqooZBSPC20LGskXlyoSMYAJH5kE HH56jsPl1dr3/wDEb2sAIzWe67+6fVR0p2mO2eTazEFwuQMbgSwHPvgj278aTUyqjFUpmjVw QWWMBguTkK3Yc5OP+h1pTJVziUGZPOHr2RyIpKA5xknIOCeP8tGW+oc0E1Q8Ttt3Kqead3b2 GM5HPbsQfvrP0DgNNe9KAduDY+a1aaOgaNnllRpDxG/4WAOTgH37YI98jHOt/m6y6y4iLKpV i5lVlXkhckMOcH2zxnW890jSUPCxZywVmeFiqsSMBvT37ckj3GtpKmO2RefEKUEru8qaUqQp A4GcDOCeM/TViPNQA8/uipztANUmraOouOyVGiTyW5woXA9JYg+/Ge3vj8tGxPKk0qyxCdc5 jljQhsDvgjPHt99HwXbyzPsIYKBlQMpg8bg7Hg8kjnHGsw19LVzI6VK4cFY/LICsT3BXccfb /s6hhJ3KcGvHxBJZ1kt6NiCML6gWdlwo43ZyRlf7j99FzVMFVCsbII5GbOIlCt3xzkY5OT+5 +unWCF6OoqZoq1NsON8UuJNh+vJ44OcY/fWVpJQpaGfc0i+WuShAP3yeDxx+fGjMZI03QGyP BIqWCOdmljmDbmPolYKwBGCMHuO37aymVqXeVSxBAEoYMJFHuMAn8x/wn21vU2oO6PUOkEwj 3OuFIwTg/ljI9/r99FtRsg2JIyg84jYgDGSMgHGTntj99ZXAs0ISMxGhRAgkli3Rk+rZIu5A fUO2Tkn2HGPbWtRDNWSCcmnRgD5jvlQxyDg44Xtxn3GlqCOuEcatJGqp3ZgVPOQvOfywB3+u nKn6eq0qGjKzoSAyBQpTv9c4/t+g0bWS31dUZkczf5phT5qF41jdpKgcbYyNpHORtHI7axT3 GsLsZlNOY243K5BzzggAgf6c/TTw9Hhpi6EeWxALDcce+MjHHb6/vrFbIsMqlJ8xmPbvgG8o 3vnBJOPcAZGiGejYTWzZhVApogchnnCzSzphVWOXcpB7+n/l9v0MihW4O0mxolHqM3pVg3Yj 7/8AI++l1JcKqn80fLB1VfVnIDKSAMHuDnt/odH3CshrEjzgTAqHMgzjnngAjjQ9J1Nd0vp8 goD5pMtMDOAzBBtBAQKpYg8kEDg9vprW5xxyeh5ZWOdwdjg4OPqMg88/loHaBmCZiU3ZdxuD 7u36/t2Oi6modYPNcRKgUl49jH9uOD/3zpbpCRSWZHP1GiNEDvHKIC/kRAbXY/kcjvxx9/fW ZlZkjliIilkVeHVsY/Mdv20ltcvzEbR/yqaJscrl949hxz/Y++lgraWlkQTEOFTagEasW9sn /wDDnvqBwIQl5I70gmWkqGplenVJlJbMkoIQ55xgfp20vtVIZlEs9Ou8NhfLclcgfpz+X/TR TTUlXCZGWMjAAWKnUAL+ZPP+ejany6RoJYZ42G4HCPg9ser9sZ0THAa6UpnPxbIuvURKDUVE uZV9PmEoq88AHtkH20m8uSKXaibXkjwqn1gfXkfXTrQ1Mr71Plq8gyFkUmOUH2YgnB79xj76 SVTRwMweI0rYCmKJ8/quRz/3xo3lh6xO6tzxmtInqCZmWpZllKnOcbs/XB+2t6SNEpJBAxqE TDL6ArL9QByD9dGyGCphQTTTzOMDBUjj2IPY/loupo6czMaUKu5Ax2OBJxwQV+319+P0TbTs LHvvS+kaTsiqeRkcywqkqK4z5KFgOOcg/wDXTjAKeakmKrmFQWLhSNv1BHcccY/bRFshajkd 54wxLBv5ZIYDHuDnP/Y0QlaryFVUhN5CtuHp++R2H2OiLWgXSCRjC0gNNLaY00v8yNofLDAq yBvyODnn9udL6RJdqyRoWDDnDcke2M9/+/fTNLHugNOJQBE5LRqoBB+oYf5/b66WCqPl+YWa aJDu3eaVcfmO2f8Apqg5jXUdEgljCNN1m6000VSatUWUMMMwOX+mc+/H+WkqytETIY6ho0UA hVEiEZ+nGfrx+2no1ZhBb5okkbhtxhu3Ib69vSe+m2rhePMlOSuW9QZQRk/QqMfpgflp7mtF kJxDQLGvn7+iJ+WSViQFjA/CpJGP3IIH240XV1VZSyBKanrpY8ZLQGF1z+bOh/cH8zo6ZGMi yVbBmPPl+TwR/wB/941pFPTwxqmyKEDsGD8/centpNF5008yPokh5vkEz1NXFUTrcaJZIabz kEULSMrEhDyxU4A2gDbg578FQTra1j8xXESFIIXlLSrvL8nI2cKD6sA88cY0NDTf5BqyyPcX FvL/AIjqmipLwZRSzV8FXI253kqWKqMquUwRg8A4x3yc5503dQV/yAQTtKxnVI1aJ8HcxTDH 27t2x7Y59hoaqVjRkI51ayFxsD3zSW9WNL5PNNcaeCrWKAx7XJDOFV5FJYAYyCQQPqeWGMRO +eGvTNS9XMIbhSTBokaOCrPlrLgPuUYB2lSMrkDI+oDaGhq4SRGHA0dea1saHNzEa0U0XHwT hloZP4TUeXOYtlTU1Eh3YIUjauGznc2cFQPbkk6qe0We0S3J7fLHMlVbtjbgPMiDs2F2IzY7 SEEkcfRsY0NDXZwUj3xFzjqlRfFde7S+vhS3VIMxBrUJfzYk/Fz2IJwM5JJVQcnRF5oi9R5N vnkEUmxXil2xho3x6Mqp47DkN+Jj/hAGhpocbBVtAr0USvVXZejLRT3uuqq+Op/3DpTUi1DG N9zKFkkmXBwGBYqTzjscDPTfU3TnWUD263117nWnRZZKmvpYopAHDMAAkrB+y5LYPp4I0NDX ZoGLOd1vDQCnSg6hpXpq96KJ0jR8xFo1U4DsoVhlvSDg8HPfJ506XC2UM9HQ7YnRwiyEq+Aw YqCWXlWOTnG3A5xjOdDQ1meA2yO5ZCAG6diTx23ySktDCpgYyGVJpiheMPgoPLUYw25Q2Sdp zwcgimnnjSKnlSmEagQTAxeb5xChwWBKr22ZO3uo745GhqbxuPMLG1xLTfvVJLv0z/EaU0c0 4FPHCHlhKb08vAcIgyNoCucd+VAzjGN7XSC0W6egp5JZFiIVmlcYAByVRQMIDuOCMYwODoaG svSvyVapzjbghabq90q5qaH/AMpLStEZQqgoVLMMg8MWyhJYn3/PKaS91Nr6hhtFCiBJUmeM O2AwJZNjnB4JYZIGSATwcEDQ1ojjZ0lVyTY2NoaIqomr7G8Qm+V3TxH1U8KLzzHgjYAeVIzj djBznAU2o8wR29RMxmbdIEI9O4kqG3HOD/UfSeWYZxkMNDRE0CUtziBokFBb6ea+MYqY0dfW yFp5IaqQK0GEOMcDOBnaQVJA5HBVtu19u1sr5KRKpHqPKKqY0aBRKzBN2FYqMHb/AEHcFycH BA0NOjcS+jqiY9xcQVmrgrrVcquCKtnqKKmX5d3mqH82WVdyO/uFBJbAUjAC9udHtPHSdO1V yeorqoReWi+bLgqQFYEAf4d3Yk5x3GToaGm0NPJPApwpFWfqEVctdGWrKJB6x5FSzttKq+0s SDj1A+nbnke+dSGSGpoZI7oKmSeQSgsJpOCRuy2AMDaAuFGAct+EBQBoaCZxEtDuRPOoCbGv lNcagUEE08NRPI+J/l13elC/cuQOOB6SPsTzpaVmt9PTSRvHWMYHkd51ZCwR8hcBiBkKVzgk LgD30NDVhjdRSzEBjwWomolpZKynlSnShSClmZkoVaPaHQMhUlySdhCndke3IC4S2erutfD8 vHcnh3QCrZZUWYbmYcLuGEILHDAEnLZ5JJGhoZNAtEmyWFZKapgSaeXBqgsiI5MQLNgME43F V4BLc9iMaZrX09c740Bplt5qquBZZ6icOOC5hKogBVcBiQR2PtwNDQ1cJzMNrKSc5CE1BWNT UpqZ8BW2B4HIIRUV3CrjapPpwSG5XsNOKWYiioE+bm8vZLIrkjOxAp2sBgE+pff65zoaGklx 0CQdwtqmT5WGZoi1USmDJUhQfVwMKF45Unue/v7p7PVTWuVXk9QyzO6uSzFosleeMZx9/wBt DQ0ljibWaz0hCUJMlxSrenMioTjY7cRszAqVzu/CR+oAH1yor4ae005ZoxNKZ0jIaOMl22Du xXPfngc57DjA0NHQDtEcnVLqSD+K/NK4p5flGinERSOnUDftZwwIYcHL5GM9ueeNqemq/nqe iWoCzz+crzLlfMYEgs2OeT27hc++BoaGljms5Fg2p5Yuh7h1LEZaivVJZKalrPKXOPJqJFVQ rYG1gZHBG04HIbPAs+2eD1qttLHHNtq6kKF/mISm4hnLghhzweCCB/TtLMdDQ153G4maOVrG OoFPEbVYNr6Vp7XcaanjKQOsL5gEfnRh/MVAQ7kucYl78HeCRkaUU9vSCJkd5Y4Wj88LG5Lq rMFPr4JOFAye/fOeCNDXPlJIDuZTX9iXJQUkNKlYDKC7yBlOGwyOqHnOSuWBAyMZ4xtAOBek p54kiWeOaokjp1k80ldzRpt9H4VHo5wD2zg7joaGg+HLXOlVloFJfSW+KpmEbSz4RWZovMIi fYEcHaCMNt9+eSRgjBCSttRq/l5K3bmNZPJEH4D+JgGRgeCBggk+x5IO4aGt9kBlc104XONE lKBDBURwy+QjTLvplBG0IchfSR7EoPbjAwOCGLo6mlt0klLIZ2kjjSeRmCzYZ3wGUvzk7iSO w4A4AwNDVyAB1BbgS12h96p7prtTVUaxxLPFIziNXLBgsiso3heAO4P7/XOklwtoZqlpJ5B5 MbMyAcnl1wrgjb6R7DOefbQ0NPAAYCukzqfD72RUqTWthKm2oikYeQtQxZgdinLseT+Fxxj+ k8knB9sklq6KrnmiSUwOiZaZ8lZHZMH/ABYJLcnuBoaGt0cLDhQ8jX+lVWR5fUJLeaR7fMJ0 SHz1KRscZDDDHI447dsEcL9NJKGgpHgjjqlmn8yMsw84hW2kBjgdid2RjGD20NDWBzGn33LW 5jer77E4UzsJKmkkDM8dQ0ORK21soCuQc5GM9+Mnsck6Z4LhT3+huExWZIo5fLKhghDq2CBs 25U9+fyxydDQ0daI4xYN+9U+0c9TBS5hqSJ0d5UaSPcMnDDPOTwv6Ht9i5bxW70kmaGoXymc pJAhXON2cYzn8iPpx30NDUeeqQuTiAADQ5qPoaOaKSOnoKaOcSYKiPYrFcDcWU5/rBxgnuMn AOlkc1PGIqqSMhvLEmzAYKMDAHbsF/z+p0NDXM6R7fhK4+Ele55sraptAkqaerpiIq9R5byZ 2rIpbHYdgT3XtxnjtpwsdDHBDC7ooTcfM2+ol8nGM9vxH37840NDXTEjnAWV14pXvjaXH3Sb K9KfzaWik3xS1bIEMKgjeSQAzE7sA55HOD+msNcFoqVYajzAzS+Xvg2/jAP2Hp44+/8AYaGn tjaQCQutGLj8kpoJaupqEgp5V8pY1ZpJs72BPpJHPIB7gj6dtOv+z0dWPOlIWQ4b+WCqHhcE qMc5H1+nvoaGgf1XBoS3ktOiIWF4pmkBZYWOGAlYkgZzwR9zj/TRsM8MrOsYaNvSRIEXdtbJ xkd+3v8AbQ0NLLQXi0J1dZRaTyG5B2fdslZRvG/IxnOCcA4I/LJ+g05TW6WKWTc4G+EMArkg jgnOeQcccHQ0NYqs33rM4AmyhT0po544POZfPGFVdzKm37Fvr7/lxwNb1ME1NBM8iRM8DEI+ 8sVPfjI+h/79xoaKTSMEe9Ep/JIjULVsiPGgmPHm4Oc559xxz+40nuT/AC0kbVwV22sA0Ckb sEglgT3z9O+hoazBxIHfStrjoljFVjjECsVcFJGkbJxk+2CDyP0/tpLLcI2mQMJXMmCu5hwD j9u/toaGmOA1CqUkX4o+KnDcq7L/ACx++Tz/AG7Z4++trbTm5RzGnd1mSPcTM2Vbg5z78j9j +WhoatjQ19AImkgaJJOotVdsBwWBU7csDwOOTwAeQdJ3mkjq41dEKSE42MRz35Bz9O+hoa19 ExzqI2TwA6rSudZKeVoiVycruXPq4PcH3+/9udYvVQaytglKRxy0uE9KgjOO/bkHQ0NcvOW2 AsbXEOWsDmZT8wzLEW2jYdzKT+eM9vtreannpN6VAhqAdwR2JZl4z3P2B9+Pv30NDTXNAsqn gB2iJpa6KeiTdSoUcbCeAwzwD2/XBzpYLc0cNOA6v5UudrL7EHPP7+2P8gNDVxgHU9ibuATz RMqNI0zmOFsFfS4zt44wRg+2irReHqJflRCkEgIAK4YerPB4Bx3/AOuhoabEcztVdZiQUfXU syzRSzyKIgwCmIYYOeB9MjtnJ/Q6KZSLrLB5SGVQFfLkK6n34A5/POfroaGjyNJshZcjaGnN aJTyq4hGxBFn0bmcA9/STyBj27e2PfSmCVFZVjVkJy0bAjgjkgjHb20NDWYtF2q6NrboJWPK eaIxLtknBfkDacfUcgfoP20WZihIMMMvPeVdxH2ydDQ1ol6pFI6DW6L/2Q= ________________________________________________________________________________
Date: Nov 04, 2015
Subject: Re: Is this meant to be a Piet?
Built to plans. Heck I may try the exhaust shield. On Nov 4, 2015 2:20 PM, "David" wrote: > > http://www.cnn.com/2015/10/22/africa/asmelash-zeferu-plane-ethiopia/?iid=ob_article_footer_expansion&iref=obinsite > > [image: This is the plane that Asmelash Zeferu will attempt to take off in > -- despite having never flown before. The Ethiopian researched for over 10 > years before spending 570 days building the plane, modeled on one used to > train pilots in the U.S. during the 1920s and 30s.] > /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAMCAgMCAgMDAwMEAwMEBQgFBQQEBQoHBwYIDAoMDAsK CwsNDhIQDQ4RDgsLEBYQERMUFRUVDA8XGBYUGBIUFRT/2wBDAQMEBAUEBQkFBQkUDQsNFBQUFBQU FBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBT/wAARCAG2AwwDASIA AhEBAxEB/8QAHgAAAAYDAQEAAAAAAAAAAAAAAAMEBQYHAQIICQr/xABNEAACAQMDAgQEBAQDBgUC AA8BAgMEBREAEiEGMQcTIkEIFFFhMnGBkRUjQqFSscEWM2LR4fAJJENygheS8SU0U6IYGbImRIOT s8LS/8QAHAEAAgMBAQEBAAAAAAAAAAAAAgMAAQQFBgcI/8QAPhEAAQQABAIIBQQDAAAGAQUAAQAC AxEEEiExBUETIlFhcYGR8DKhscHRBhRC4RUj8RZDUmKCkjM0cqKy0v/aAAwDAQACEQMRAD8A9U9D Q0NRRDWNZ0NRRasPvrUn9NGa1KZP21FEUZca1833xo5owdamAf8A4dFYQUUX5v6/lrDS4OtZIijc DjRTe4OjABQ2QjjLjH1+msebg8HjSfP20CT9MaKlSO83Pc8ayJc++iMnP11nPfOpSiVibk863WQn J0izg6NV84wNCWogUp80LrAlz7/vpMXH5jQVvVznVZVLKVh9Z3fbRAmH050BLkjjQ0itKAc6zokS hdZWT9dVSmYI3Q1oHydbZGqRLOhoaGoohoaxkazqKIaGhoaiiGsEZ1nQ1FFrsGs9hrOhqKIawdZ1 jjtqKLUEjWu/B+uNbPxjRZOR+WiGqW40txJj6nW4bOiM86yDj/rqUqDij9DRe/j6a2LccaFMtbaG tVYHWe+orWdDQ1qWwdRRZzxoBvrotnHGNY3EnV0gzI3OgNFbse5/TQDEDvqUpmR2hrQNnGdbDtqk QNrOhoawSdRWs6GsA/XQzqKLOhoaGoohoaGhqKIaGhoaiiGhoaGoohoaGhqKIaGhoaiiGhoaGooh oaGhqKIaGhoaiiGhoaGoohoaGhqKIaGhoaiiGhoaGoohoaGhqKIaGhoaiiGhoaGoohoaGhqKIawe 2s61bnj66iiLJLEnH76HllhxwNblASPqNb6K0GXtRAhO7k5GjdnGPbWTxzoD651RNoqpQXrzq3qH pa62qisvR9T1KLnDURxVUVUIYaesVofIjqG2MYoGjapkefB2Cl2Kkss0MTvfS19PVPTFnvQt1xs4 uVFDW/w67QeRWUvmRq/lTx5OyVN21lycMCM8ap/4k+hr/wBT9bdEXDpt+sLddaeir6KlunSlfSUy LPJU26ojp60z0lR5dM/yTSyTAYCUrw7J3qY4JLG8FLJQ2LwZ6BttsorvbrbRdP2+mpaPqKJYrlBE lNGqR1SKAFnVQA6gABgwGrB7UJbpop1rXcNa7ieNZAznQo1sTjWFOO+fz1kDjB1jb+Woos5zrOsD tzrOoohoaGhqKIa1Man21toaiiKMAOsGmXR2hq7Kqgk7UoJ440Pk19j++lGhq7KlBEiAKOOSPrpN ICpPfn3Ol+i5It+edQGjqqISEk51jdz376Nkp2UZBz9saIZSvfjThRS9lsGz740N2tBoEdu+rpRG h/1H56MEmPy++kwbBzrYNjVEKJUJP01uHz786SB9GB/20JClpRvxoBs6LDA/mPbW+4floKV2VvrP trQMedYzqqRZkaG5+2ttECTRgcaohWCFvoa1LcffWN+PcapXa31jRZf6awZDnvq6VZgjtDRW/PfW yyZ1KUzArDqSeNYERz30boalqZQdUQybSB31koQM/wBtG4zrDDIxq7VZUTg+2twpIz/rrB4J0EbH GrQCuaAJU62Dk8a2xuHOseXx30OiKiNlgvntnWrEE51uI8e+s7Bq7ClE7orBOs7SdGgY0AMaq1eV ElSugOP10djPGtDHq7QlpWuew+mt0HA1ptwfroxVIAzqFW0G1trGOdZ0NCmLU51oW9s6MxrUoOTq whI7EFOfbj6631qowNbapWO9DQ0NDUVoaGhoaiiGhoaGoohoaGhqKIaGhoaiiGsZzoN+E603YP5+ +oqulvnWdag61Z//AMGrUtb5B99AsNFFue+sZ1KQ5kbuHtjWdFqc8azv576lKwUZoaL3899bBtUi W2hrAOdZ1FENDQ0NRRDQ0NDUUQ0NDQ1FENDQ0NRRDQ0NDUUQ0NDQ1FENDQ0NRRDQ0NDUUXL/AMaP S116tuvh5Q0fh5Z+uaaomqqYvWUdkqK2CV2py8dKt1dULGiS41CrGrEzUNKZMwLMj9AeHtpWwdAd NWxKKotyUVspqZaOripYpoAkSqI3SkAp1ZcYKwARAghPTjXL/wAed86TsPUvhrPfOprh0tej8x/D quG7UFupW23K0SJ50lXS1OfLrY7ZO2xBsp4KyRvMEYhl6g8Pa6a59AdNVlRc6e9VFRbKaaS50lXH Vw1bNEpMyTRxQpKrk7g6RRqwIIRAQoiid56mOmHcbj7Z01z9QJTT5l3R02xmadvwJjnk/vqjb98R lXXb1tvTkUaHtNcH3kj29K4/z1Cr9171F1VSPT3G4SfKt3p6YeXHj6YHcfnnXmp+LRt1j1K60WBc fi0XQV98XbH09MsNTeaV5pl3RxwAyMB9SB/r99RA/EVNJOkcFrVwpw8hY7X/APb7/qRqiaeiipCf KReTnRq3CqppAUp1kUezMRrmf5SZzvioLaMJGBta6jofFiCRB81b5ozjOYHDj++DqUUnVVrq4VlF Wkak4/m5Tn6c65Fo+v7hSVB3xP5X+FsNjn27HT7bPESmqa5JJRIkgXaV3eg/fB99daPi0ZoE6rG/ AkWQF1jHKkqhkdXU9ipyDrbOqFtHVtBMQ0Vb8vLjO4MUP7jUpo+s6+lGY641a+yNiQfuOf767DMQ x4sELnuhc00VaWhqEU3iDMgX5mkR8/1RPtP7HP8Anp2ouuLbVcSGSmb6SJnP6jOtAcClFpCkOhpL S3Sjrf8AcVMUv2RwSP00q0SFDQ0NDUUQ1g86zoaii12jRMtNvPHfSjQ1YNKiLSEUjk88a1enZBnG dLz20VKrFDg6MPKAtSAjWv4dGMv10Wy/bTkCyG/TWwb7aK1sCe2oqRofGti/bRS9tbrz+uhpWttx z3P6a23HGOTosg9u+s7sAaihKUBgf+ehuGNJwxxnvoB+NDSiP8wf/h1gy/ronfnvrXJI1dKWjzJ3 xrXzD9caJ3e2s6lKkd5h499bh8j/AF0nBJOANHJGffVUAoj43yRnto3RKqRj6aNHA0o7prbpZ1gj Os6xnGqRoqRcnjtrVeDzoxm1lBnJ0d6JZFlbDsNZ1jWdAmIaGhoaiiGhoaGoohrGdYYkdhxodx+X 01FVrPvoA51j76AOTqKLbWDyNAHPtoHtqK1qG5Gs7sg/XWuc/vrXdg6ukGbVGKT+mttFg5B/LWc8 51EQK2zjvxrOtCcjWcn9NUpa20NDQ1FaGhoaGoohoaGhqKIaGhrVmAB1FEHOB30Vofi59tY7HRgJ RNoFiB+Whn30NA++rQrUHn8tDBB1vtGtgnGf31LVgWtQM6ByD31vtOODx99ashGhV0hrIJA41qut 8DnUVhBX0ZolT6u2jCc9tUQiaVtoawDkazqkSGhoaGoohoaGhqKIaGhoaiiGkd2utPZaCarqWIii GSFXcx/IDvqNXnqSqmvNIlAB8hBIfmanzkVWI7oAck/fA/8AkOdV31/1vWdZU9zs3T9woGmqYBEl PVAwM6NkMVkcd/bjJ40t78gRNFmiplS+MlrruoYrXCkihuPPlACbs8D8X56mEd/oagyiGsgYwECX LcDIyOf1GuPfDux0/wDDGt95qrlT1YnFNG1vETxq2dxYF1YAdgeBjnPfU167vtX01fqFZq2KyW7B pjKwMvzhwDueRffOeMfqO2ufFPKGF8tab92teymOYM1NXTcE6VEYdHRx9UORo3UC8Iq56yxSb7tD dwr8TxyKxA9gVUkKMduSfrqe66LHZm2k7oaGhrXd9tGoud/iY6wv3TPiX0BB071peOlq6ptl0mem oeiq7qmmrIoau1M/m01JKrxtg+UJSjAR1NQFeKRoy1v+E9uqLP4WdG0FXd7h1BV0tlooJrvdqaam rK51gRWnnhmzLHK5BZkk9asxDcg6p/4rqS5dRdQ+H9hst3p7TXSzzV06zdc3bpdqqmjqKOD5eOWi hkidpairo4f5wLhZXSACSXzYbc8Kb7R9SeF3R13t8nnUFfZqKrp5PnKis3RyQIynz6lUnmyCP5ky rI3d1DEjUVLkuMMpG85HvrdnEYGASnvgZxo2OPjnvrYIFPHI+nbXyxexBWAA6bt24fXWoUDggj6a 2H8tgw7HvjWzkEgjIB7g6Aohrsi3i354BPbt30UtIoGSuPqcaMEhUYAydaSCQo2SXJ52DgDQ2EYC MSripSHQBiMEhONOtJ1dBNFJCIZKapRfxD2+nI4zplSEmPaVVAfZNZjUx5ESrn6fXTWSuZYGyFzA 4ap6p+vb3QrkuKmMcAOf9Dp3ofF4M8YqaIqwGOMjn++oa8IfmTK63AhWMBV5+pGtDMbiI9npLsPE 7dqtO2+I1lqcr56wsTkoRzk9zjUut3WaBVFLdVwPwr52Mf8AxP8Ay1zlPboJpSzepv8AhOtoqCaF wYamVVH9KtxrpRcZlYKcAVkdgWO2NLq2m66q0KeYkcyn6qQf3HA/bTrD1zTMcTU8sf1KkMB/kf7a 5VpL3fKGPENcxX6MD/oRpyh8Rb7TnE7R1K7lJJXkge2Rj9/89dSLjkJ0eCFkfw54+EhdV03Uttqy QtUqEe0oKf54zpwSVZQCjK6n3U5GuZqbxeo4w4qqWSFTyXUEk/kNP1i8SLJWLvprlLTytnAlDRvt 98fUf5a6cfEcNJ8L1jdhZWbtV/aGquh63qlpy1Nco5QoyQ7BsfnnnTrSde1wj3T0sMvGcLlMfrzn 9hra2VrvhKzlhG6nmhqL0XXdPKmaqllpSO5UiRf7c/2080l+t9cF8mrjLN2Rjtb/AO04OmWChohH zRDOR/fSZxyBpeyhvfRT0+edNDq3Si1IvKz986yYSPbSzZsUDH66wXA+w/PRZihIpJhEx9saPWEA D3P01tn9NZzg599USSotWhAGANJ3j2H6D76VZHvrR0DjPvqAlQ6pJrBbj2++gTgaLYEHjTgEK3D4 +p0N/wBO310TnIHsdZHJGNFlUu0fnJ1sqk+2sRgn2xnSpEI9udKJpRFRjaeBo5JRnWwjOc6wY+ed Lu0VEI0Pk62/LRW3A451sGI76AhMB7Vs3I4760JI4I0Zn7a0YFz9tQKHXZAAHW4GNYVQus51CVYW dDWMg++huGqVrOsaxu0BgtqKIMfbWu/GgfSeNBlDc551aA3yWC+dYLZ/XWCO3J0F1aCyVsMkD/M6 2VhnWhfP5axn76lK81IxjxoYbGDrCsPfWwYE6pGNVoSVOtSBo085+utdgxnnOrtDXYtQcDWM/TQI 2nWQPcjjVoddlqCc6NQnHOtDgaCtj7DUKsGkdoaKMuM476HmE/l9NDRR5gjO+huH11oH+51ruzqU pmCNyPqNAn6HReG+msHIHbUpS1sz4/6aLzk++sgbtAjB50QpASTqsaAGgv5/21uFye2NXsq3WuP7 aGMnRmzWwUDQ2iylahcjWQDrPbWdCjoLA1h+2ttDUVogf20ASNbvgcawDgjRJVLBydZDfodbgg6B QfTUtGBWywG1kHnQK8cDGtQjfbH01SvVb7hrOtMY78/nrYdtUrWdDWu7Q3H6f31FFtoa1DfXjQcn Y2BkgcDUUVB+P1dXUNxIsFxa1XSVFE0flbjUR54kU5/p5HAyM5+mq3tFN1PfesIGpbpRVs4SNquS gWCYlM8tJ5jE7vT2Udxqadb2O63rxDiRoprjTzOXrI56vENDEjfiLLtx6TwpPOT3wdMXVXTloob1 dLH09FHR3IQLV01wcpuiQ4BWJ8DIIbsx4z765+Ib1nOPKu3U/nl5rS2qyqRXXoGwRzUVXSWGCpNP Ga2ojlhUNO4b0Rys5wcn6HIxjGOCS1TW9edWR03VPSBrAY1amo0LxrThhyfMC7WOBySw7cDJxqF2 KtvdcLQoin6hoJ4mVqKGQrUBVAAMiq23buzycleD7gDo7pK01Vr6bWielpaUeWEpaeOQyCEbf6mI GefoP306O56cRl9jf5pLjlNWq/8AD6qk6Tv89ns9DFDbo6iQGmoBH5NOg4CyMGOGzn2BwOe2rvoK tqumSV0EbnugYMB+o765r608HL3P1NbUoZnoxNKsU9dTVEg3/wBRcxBgP8QxzxknjXSFpppaK20t PPN8xNFGqPMBjeQOTjJ7/np+VzZHCtNwgNXoloOR21qfpnWCw1qzcg6YAhJCpbx6unhU/VHSlh8S OgP9uKqro7hXWxj0dJ1H8okL0iTjy4YZpYt5qIPUE2Hy8MwOwNafSyWuLpezpZaD+FWZaKEUNB8i 9D8tB5a+XF8u6I0O1dq+WyqUxtKgjGqD+MC89aWyq6Mj6Uu2yml+ZNdZKKouqV9Ygmow8sa2yiqq jyhTNWUzSFVSGSvppg3nR05F5+H9RFV9B9Nz089PVU8lspXjnpLtJdYZFMSkMlbIA9UpHIncBpBh yMsdWN0JGi5G89U43DP0HJ0HmJKlQP17aRRTuQCyqQR2zpWuSDu4HfGvkpcSvbUEWzyMAq4P1xka N8ubA4Cj3HfWwOOAeftxrbfwee300J1RXWiyg2Lzwe3Os7BnsufrrAkAGSMn651guHH+vtqK1lwQ cYBA++tQGBBCc623gjv29j21neB3YAf30PNWtl2rgmMk9+NFsYjksTGPp76284du/wBcawHVmx2P 31LKi1ji8wYQDHuR/wA9KFiaFeyk/wBhpPLUrT8s6Rr9TpBU3yKJCVk8z8u2hzK07tLhfqffGkdX WqjhB6nOAPfUabqJkZ2lciM9o4wQf30rpr9QycmJsgclzk/31amycqiBKkKkpcp3xGSv+WjKisiM Qh8r0qPSnc/nopLhHVoPLbbH7FBkn9fbSOm+SoHkkoo5ZpJDlirZDn75PJ+/f21Y7FEo82pppEZZ ZYkTlV8wn988fpp3tfXnUFLLiGuPlj2dQV/LB4/tprVPOCu4ZmIztYcD7caWxwKgVpOG77dGyR8Z tjiELmtdo4WplQ+LVwiwtTQJMueWTv8A6f5aeKTxVtMob5ylelLYBOQRx9c4+v8AfVay1PIVAFb6 nSSZzJIA0W/H9IH9zrox8TxUf878VkdhIXfxpX1ZfEq2VBRae8GmK42pJI0YA9uDxqawdbVMxVop aeoU+y+ofoQdctwPDHkLQpUPnLKeM8ds98aeXlg+SU0kNRb6jsw84so/IZP+mutDxx9f7Gg14hY5 OHtvqkrpyHrZQQJ6YqO2UfJ/Y4/z04w9SW2pJUzCJu5Eq7f79v765Tp+r75bAwFfI6EYCu27P/3Z /tpzpfFWvpHVqmhp6ruAyKY2A/Mbv8tdCPjeHd8VhZjw6S9KK6mhlp6gnypkkI7hHBxrcxH2bXPN J4s2icD5mGpopjgh8CQD9eG/tqU2vxXptqxUd8pppc8QVj7Sft6wG/Y66sePgk+B4KxPwsjfiara ZGHcE60JYexGovF4gyiCNnod7HG5kb0Y+oIz+2P10723rK3XAMGc0zqMss5Ax+ufz/bW0SArLkpO BRWx7ax8uHXvrSa82yJoRLVwRGc4i3yBd5+2e+lvlfQ6YHoMpSF6THI7fbW8dLz20sCYHI1kFV9t XnKmVFxwbR2/XRipjvrbI0CT7aWTaMNAQwNDaNAEEcazqkSxtGtSP11vrGoqWAvGsngcaAGNZ1Fa LJPP11gsRozGfprSRQF+mrCAgrXfjWN/1OPvrRm2Ecawrbjo6S7KM3H/AK6yHIOtScfbWNw+o1KV 2jN+M9tYL86KL88e2s+YD+WplUslbnuNYzxnWnmfbGtTJkf8tXSpG51gtosvkawG5wdSlSNz2zxr IP3/AFGidxxrIY6lKI9W51vvxx76ID5x76zv5+2hpEDSOUbuT31tjRIcg6280H31RBRhwW3ljGtT Gc6x5gHfjWfM451NVDS2WMD76w0WTxxoeZxoBhntqtVfVW4XAxoYGsA8c99Df39/pqlazwNYOM6x +I51nbjUUQ288cD7aG39dZXtrOorWuwfTWQMazoaiiGhoaGoohoaGsEZ1FEM6wxxjWO/trBU6tVa 1Y5PtoAD30AvY++htAH+urQUsqdp1uGB99Jw6uoZHDjOMg51sDyftqUpmpH7hrG4aLBJ/L7a1II9 tVSvMjSdYzg99aDLayNXSmZbBsnQOhke2tCce/GooTS2z3ydE1kwSnkTzxTyMjbX4JHHcA98ay7i NGdjtUDJJ9hqg+u+tLPc+pqaoS7U8trgYySxmJqj1A7W2sD/AC88DHuR2OlyPbG23H519UTQXbKz ntCRRm6tUTy1Uqxwyz04ZnqUB4Hl/hGcnJA45+mmbxGo7b030vVyUtrp55YKciKneQLyxxznk9zw Dk8jTf4Y+IUF8vF6tTVsk9O0pa3zlGVJEKglUfjJUnBx2OR7aV3LpJbZY7zXXZIpKoM08dQZZKhV yMYVZG4bAwPbnjRNkthLO/8A73o2avAKrC1dP1Hhp0hR10FDNbKGff8AxKSSdZK2mCqceUjLyGJP uSAR39mDozxC6k6e6sqaiRYRQ1AUfMU9QGoZIfaUkYAdVwCBjP8Ac3vF04twpqOaenljWiYSxU0E qmcOwIIm7g5BB+2q8n6XttN1BMlD1HTQ9ORttnsNTRGZEctxtDHAJbnt/nwD8OCwZDVdnuvfkhLg QbU08Oqi7dUdU3bqA3RRbHdI4qFqORVeMIMSAvjDEk8jdxjP0Fp7v+uq18Nen7larzdnvwpqislZ Xpp4YsKYgMDadoC47FeT75ORqyPMzzjTwDzSOaySSe+B9takke2sk5Gc6RXS7U9piEk8qpuIChvf 641YVqiPinvf8Mv/AIfxzdFdUX+jlnm+bvPSCXhK6ipzPRwywCe14ljVknasKuTHL/C/LEZkeKSG 8elv4ZD0xZ47LQC1WZaKEUVB8k1D8tB5a+XF8u6o0O1dq+WyqUxtKgjGuY/jwhqKei6GvMl2p7dY aeeop6mK6x217fPK8lLKscgrrtb1LSwU9ZTMqmUvTVddGdiyEtmo8YksVt6fpLdDQ0dGLJbZI4bU 0dLRqr0kTKII4Jp4liAYBRHNKgAAWRwAxx4jEMwrc79k5kZk0Ch6pHCfx8/fRiyA+5/XQEkbr6SM d+NbYXtjOvl9L2F6rHmFidp7cEjWyluMg4PtrYkAgctx2xrVpMYAGPz1VBXa3GAO2CfvrJbAzkD7 6INQo7nn2yNIqqsjHDTpH34DY0JVgpxaoReS4A0kluCZIG1wO4PGmWoulIqn+cZv/acab2uEsuPJ Q+Xz6gO/6njVVaIa7J3rb3URsRHtUe7EZx/fTZWXisn/ANzWiNO2/Zj++k0wklUiaSNEPcZBJ0Ru UMY0VqkngITgf2/56lBGAiJZGmfC3LzpvoqFv9dExwSNyKrzD7Ls9X6AadKe0VUwKlIoEY52sc/2 060/TCBR5jtJ7YHoH9hn++rtWT2Jjp5mRfKij82U8kP3/wDtGnKisVyqsvUBIIzwEc4A/QZ0+U9q WkUrCViT6RKB/c6NMAXkyhR9+ToS5UT2JNSWBYpA7yjjkbPSP+elczU0RwwEzHHPvnWInghRgXJz 9RjSiFQ/ZFUfYDQaqIpKySOMGOPBP6nRS3OWWTYCjSfRzg/sNOAhUDn8/wBdbKkMbZREBPfaOdWF STRxO/M8ygHuiKQP+el8FPHGnpGQfpxrR6pU7kD9hrQVhbgfuBqWolqOEQ/hC/QcaElTuwOOPtpE ZC7fix+egsxQkKN33GpalJSV3nP4M9yeToxY0ix6e/3yTpunkqGI2TJF9fTn/UaEVUxXaZlc/wCI A8/9/nqWqopbPIixlduMgj0jk6b/AJNMbhFvk4A2EjH5aNerokyHqI9/0ckH9jrdKiKVQUkSRR7I Rj9dS1Bol9grHt86AS1lMdhEkkUuBk/me/HsNLz4g9RU1SI0ngroF7rUxc4/Mc/300tUlQNx7dgp 7aLNYRnZnc3vnWlmJljHUcQluja/VwtTei8V6mFsV1uWKPv/ACJSeff0kH/PUhtPjBY5JFRbhU25 8gAFSFz9PQST+3tqoXDSfiJGR2U5P5fbWPlkjADYB/wjuddKLi+Kj0Lr8QsbsHC7lS6WtHiLJUVD rHcqGvjJBADAMox2xwe/POe+pPB1jCU/nRMjf4cHn8vb9yNcgRiOFsKRGB7ISMfpp6tXUU9CCsVw q6YpkjDHZ/y/fXUi46dpGehWV/Dx/By6wp+prfPt3OYSxIAcfT7jI9j+x05xTxTqDFIrjvlTnXKV H4qX2kkO4RVkOcgyxBT98Y751IaDxuJ3R1lsnp4n9LNDJuHPvt5B/XXTj4xhX/ESPELI7AzN2Fro 8DGs55xqmbX43WeRCn8Y+Xd+0dWhBH5Ef9dS209ffOR+ZHNDXx4wWgkVwD+nv+Z11I8TDKLY8HzW R0MjPibSnOs6jlL1rTSxbpoXjfdjYnqO3PDe315H+enOlvlDV8JUANz6WBU8cnv30+7Sk4aGtI5E mQPG6uh5BU5B1sc+2rUWdYIyNAnGiDUBmaIMFlAyB34+urVJPcqhaOmeV84UFsDkkAEnA9zgHjSK guHzVujqmAUsDwGB5zjuOOf9dQbxG65p6SyGargaQUdYs58pmjKxRzbZJDjkbF9RBwGVscbjtrG4 +Lb2boy0WWggWCejlWrrCIcuKRZA6SY3OrvM2MEOclssQdwGZ+KZFebkgy3suinuSybUp282SRiq lcEDH4m79gTz9+NKSGUA4OPvpg8PqVqa0h5mU1NQwklhSTfFTHy1xCjZO7AAJIOCxduM4EmqJgJo oB+NzntwAOT/AKD9ftrWHWAaVZUSmWP2+mtnQqSRnGlShR7ADQAGrzKZUh3Y+x1jfz30pkhDHPY6 TvTvnGM6MEFDVLXI/PW27AA1r8s/0P6a1MLj20WipGeZ9P30Nwz3Oi/l5Mdu2sqjD2J+upQURwcA fbWDJk/8tFhHI7dtbBGJPB41VBRbBgPfGs/fPtrVY2J7a2MTKfrqlEMt/wBdZQg8nOsiNj9vz1ss JPfVWFFrv+mjA3AB+usiIr2GtljPvobCuisDJ1su099Dae2gQR+mhRajdGDHtrOtByCM4++sQyeY CD3Xg8aFMRmhoaGorQ0NDQ1FENYJxrOhqKLQvj21qZNGY1qyZ9tXohIPIrVXydbgk6124/PWc4yd QqDvWQMjnSe41JoqOSYQyVDIMiKMAs32GhV18dDTtPMSEGB2557arvrDryst96p7KrSJ5u6pasp4 x/LhVeQ2c4OSvJAGGGPfQuOUWVdqt7h4o3e49Z/L0cMtsiNeaT5aTKyeaI2YsCfQU2qx45zqzui/ Eug6kuMVNQ1MVYXkaKWSPHDKoII+oI/v9tcn9T+JF1F/TqG2p59VTVciKkUYSBYHiJ3NuXsAvsMn bwdPnhxcqvo66WfqGYS3A3oGOE28RRxVETKTlWcqTLuZchwuQTgnHHP6R0brabBOt9isgHYLsuG6 wyXKWiHMsYBIHsPqfp/0OlpONU14MXqtvF7us0iVAgf1P8w8LGKQnOzKnJGPr75Htq4Me/bXRac4 tLzUaC3ySOMDWpHOsAEff89AHgY5OmUh3QIPt31gcDuPz0CCTrGO+Tzq1S1qUEtPKh5DKVIyR/ca pC2+C1uuNTezU2qitMbTI1LV29nYyKuD6wzZJ9iMDPP11d5PPOolNTV1T1e8DTobZBAJRTpAykZ7 ZfsTle2qLGvFOFhMa4t2SCip7XSWmqho6SGiraHaqt5DMyjuHCZDYPfAP176Zbp1rBeOlKSWuuNJ K6XGH5gUkbx+lJA/4XOcEAfbv30xdUdRpNXCue4xWqjinaaCOrpJN1URwQckHvwNv1zjVT9VdXp1 D1nZqehsdQWqqpDU0ruHEibSAAMEhB3xjnB76w4rEdGMg7x5bcuzv35LTGwE5jyXUVt6ki6krK6l pqcpSlCFnD4M57ErjkBeBnOk1v8ADy22vqKapgeP+dGfMpR6WJPdsggtn/izj2I7apq2ms8Hqp66 126qvVAu+WorIq2MQRJn/dCM8hVJBLADt+mry6av5utDbbhcrU9vq6qMOjSES7GYfhVlLYyBnvjW qOV/wPGvvms7hWg2TvbbQlpRooXYUwx5VPtXbCMdlwM8/fOlwXntnWxYMM41gtnGmpSBbjA1TXin 4j1FpvfyFJFJlU5dGONvucZxwfzx9tWB1VfGo5YaenqdlS3aBCqu/wBwX4I+v56548cIKYw/xWpW oprvSSAuiNHkrjnywcq36c99KnzdC7IadXv+loioO1Tf459UdH9ZWDp+99Q9V0vR11oarNor/wDa O2WqomaGooqySECvWWKRRPS26YkR7gYkXdskdHpPxf8AFv5zrFJq6suT1cluoXeojr6aqWqVqaNk qBLTIsD+ahSXMSqnr9KgcafevOvJemPCXo+ZuqbhRRx9X+YlbNdKC2Wjz/MoYYRVzVVBWK8sDVPz UcXlqAlJU1Gd9JEdM/jL0lbes/ECovF164jq66pt1reWqoqhaqCoJt1MTMk8UMUcyuSXEiRRqwYE Ig9I4koL8Mx0zifL+rTAQ0mtFKaGa5oylo1ZOwJwNPDVIiXdJIF+uew1FZeoa+Bz59LVUw9w8IcY /MaSf7RUM7CKouMzSOCdrROinH6YGvDFp2peqpSyW90wPocsft2Okn+0kaNjaGIOCAeT+2dR9Ut9 cFjp62nUngbJ1Y/ljOla9KTOiiK5Mh+m3C/sANBSLvKdKm6CrRUWAxyOcANzj9jn+2kkdnifl5Gk f/Cwxo6g6fp7cvmTTiSTvvzjOlc9/o6QkEvMR2Kr/rofBFdbIiC0KcEqiKvbZ6j+50vjtVOQc75M 8fzO40jXqanYD0iHd2D4GdGJdUclVAJP/FqjaiUpZ6RSdlNGPqzDJ1uKKKMnOR9l4GkxrdpAaEt+ mg9wTIxFz9QSMaqld2liGOmHojBx/i0XJcSFxtAb6d86Sq7Sj0vIp+/I1tTieKXcHXH0Yc/2GhU3 WfMq52G2IquPcY1k0lQDucID750paWpbJA38cBQToRuZR6lZW91ZSv8AnqlYo6omONU5JTdjkqCT /fRxnI4B/TP/AC0YKYE5IJH56OSNRjHGPoNSirSHzp3wEyM/Rf8AnrZYKhxhpDj88/20sIxnHv8A XWwAYYHH5caqiqSRYliALSEn7DRuFIA3ED7ca2kCYwybyOwAzooI5J2wYP1J1KVrdZFiBAXefrnP +esmeVhwihfqSTrVY5T+NAv0I1lqYscs2f8Av76mUq9E21s8kQLiMBvqAf8AXTPLNUzSj0ufv3// AAalHkICPSM98nRTQRk5ebAHGORolNAmCZqqZVWRdwHu6g4/Xv8A30neMDLM5DD/APNjn+2pMFo4 OS5kP3OdY+ZpGYBIgT9Qmf76ilqMJLc1fFMZmBAIYk4/bnT1bbhcoCprGjIx/u8Yc/30smrUUEEe 2cbsj9tJ3roAVXk5H4UGANTdVaU/7QPMuILdURlj+OTAH+ej4qmol3Dy44j75lGf2Gmx6lJANisv /ubn9tEyM2CS2fudDuqUnpoWEY3Fc/bn/ppWI1Pt29z7agzyTbcwBg3+JfY6C1F4bmGom3LwTKw4 /TRqUVODLEmSSMe+dJ5aqLAUHcx54GTqJfM3kLtapi+hk2ksv6Dg/uNLo65wVV3eQgDdsAUsfyHP 99RTZOEtHC8paoYKD/RnJOtHpoFMfy9K499yfyyPp9DpP8xI+W2GHPO1sf5Dv+ukdZdmtytNVVEE EC8+a0wXaMe5bAH99QHsUJpTGgvt5tDpJbbxXQDuYJmE0efyYH+2pbbPFu7QwIlyho6pgfU8StEz fQ/iIH6aqKzdQNerdHW2yogrqSUkJUQSiaNsHBwynB5+mlX8XCSj5mQBufSOO3fW6PGYiH4Hke+x ZnwRybtCvS3eLluLBpIqqml3ZLxvzn79s/fUsovGCilQKt4pWk7KKpdhP2OMDXM8dfHVxHy1Vef6 mwCPtjv+mj4aSeQkuySA5wozjP1/7xrqR8axLRTqPvuWN3D4jtYXWFt8RWqmw1H5643b6aUSDknG Dx9O3fTxH1fa5ZUE3mQS+3mwn05/4gMf31yMqzQKoido5B2aNiCP208UXWnUFAUWG4ySqP6Zv5nH 69tb4+Nj/wAxnokO4cf4uV9dZ+E/R3iYJzVu/wAxKnlmaiqyrDvg7clc5Oe3O0A5AxqFdQfDA9Sl o/hd+Vhao1ipobrAZkZUjVUDlWUsAQWK/hJJ9PJJjVF4rXWnBWrt9NWKR2TKH/l/lqS2/wAaQuFd auifjbx5y9u2OP0+n31vbxHAzAh9a9o+/wDazHBzs2FqcUHTl38OelLXQ2Wl/wBoHt1H5JiLx07V c7MpeVmPC9nY8Ekvz2J069C2m60iXC4XqVmrq+VXanJysAVQmEOThG27gOMbuRuzqMWvxhpZ5PLe 4QCTBJWoiaPHb8h9Tgfl+UqoOu4K1nAhEirjmnmEme/GeBng8flrqRSxSV0bgaWF0TmaOCk+4c41 ruyeSdNsXUltnC5l8sscDepXn8+2lUNbTV8bfK1UbMQQCGBII+32yP3GtNhKIclGQTydDcqkD66w 0bBcjBbTZd6uSiWGX5SoqFBbckC7ycDI4+599EKKHVO24ayeRpKsjrTiSWPbJtyUDZ5+g/y1mKXd +I4JzhfpjUpXZ5o/K617H760jk80EjtnAP11lnClQeMnAP31dICtw/250nWoXz51Y7SgDEHtjnn+ 2P00aRkY5Go3fa00NxpnkqIFiU4eOVdplBye+7C4Kg5IwcEe+pSu7Ul3Zx99Zzpst9e10LvGGWFW I7YGR9Dj1fmOPudOG7GAe+O3vqDXZUtw2PbWyMca0OhnGqpWCUdu+us5zokNzrYSZOhpGHBG6Gi/ M1gS8kZyRqUrsIz2Oe2mynl8uukWOMeWTksi4UfXJ+vGlstQsSMzkKo5JJ7ailsulvqOo6tIZoQr BGeErwrernHszFhnPJCjvnUUsKYg51nWhlVFJYhQBkkntouCQzASHhSPSCMHH3B1SJH6GsFgO51g tqKLbQ1pu550N+oqWTkY7aHOsF8a1DjjVqWFnn6ayQTka0L6G8jtq9UNhRfxA6spul7ZE01fS0U8 0irH82Mq3PI78H6E8Z1yb8QtR1CtHQV9jqqapp5FeYxCUU1VPLIwXgAAsFzjn0kHn21aXxSdA33r V6R7bSf+Ugj3z1LzYUqMkqB/ScHOTkdxrnPrrxPqL3R3MxzR1N3s1OjGVgYkgyyqSrLkPuBwR9vr jXMxUz2EsLbB2+9pzWje1Geq2nslFB0wi5vtc0K1FKkeIo2YgbAwB3ZZiDhuMcjTZYLDcOnkpKW5 3Sgpqa3yASBWBMWW4XkD+Yp4JYHg9tJv9rrf1b57XujmeGFT5jTNuWQbs5DknJz/AFMMfrpJtW/T inW8JPRKP5cVSB61KgjJHDAHjJIP2GuM6RpZlqk/Te7XU3w/+GX+2d6e/wBFeBQ2KnuLVVZTUMq7 q6oAIAfaoHlkEMcE7jntrpqnuZpb3UUk04l3KZFUAnYBgYz+uuR/hW61h6WW42rp+GnpqKtk880Y bdDFMVALDA3Ip2++Rx9Tqxb54kvR1QqpqOSmqWjYVs0TkpGvITGe44PHvjuNdfC4mNsWZ137/Kyu bmcSF0fG6yqGU+n662I4441Rvw/+PVJ4g7bRHGFenLRFiwBLL3IGSSNXk0gPOulHIJW5mpNUsZIP PfWuc/bWxf6H99YMgPtnTlFqx9+2ov1t1HHZbMa2K6Q0bQsspV9pEyDunPbIzg8c6ea6vpZ5JaEz xpUlQfLcctn6ZIz29jrnHrPpnqToy8XWQrWXmO9CSnpaWkj8uOkiJG0OxLDILEjHHfgaVI9zW20X 293emsZm3UR6g61ruvut6ynWU1UkTsVLpCJI4RyNrg5QDuOcnRt06IrrRdrZerbPMk0RVVjMp81G IIcITuyMHI4/11L/AA76WunT9tr1r7FbumUmXyxdYCtSHJOC7MQDk5/Dnv7amlwti3TqO1RVF1iQ UNJP8xUUGKeKQZQKrkElRjOSO321zGQOkjzSk5iR3VqPei2tkDXGhpR+iebT0FF1HYbI1VVT09HG VqJqWIrmqYY2+c2MnnJOMZOM9ubGUbFAXgAYGqg6d8P6fw1vcl6tt1u18NRjfbpJvmVXOSywcqEO TnnuAdWlXXJ6WgjqVoKqUvjMSKC6Z9yM+321122NCFzqKMuN0prTTGeqmjgTsvmOFDH2AJ99Mg6o rpWgeK3fyoyPm9z4CAjujHAIHc6RdU2+g6qpKZakVM9FI42ywAgBs4w2BlcH34x76iV8tqeEkgrn nnrLFK2Kmmml3kKVwM729QH0++qkcWC+XPtH/EYaDoN04eKdRTVFr/i8c8G+mXfAXJeOb6jKgkEf XVAX/rX+OWCvaO1XGgeq2PEISrFJQfT5a8bCx75HOc6Ku/j1YutOqZ7dEamntynyQCAopx7lcKQB 24BOqqv9/ulvvNa7xtL07KxjjraR2HnnjDGUoCDjvx++uNiMYZCOi2GhPM94HYFoazkd1ZVZ1HPa 7Z01QS9E9bVNHHf6pLxL0XU3+GSMH+GRv5otTLmTyqp6pXlDqVoJYY1D1AeOJdeeF94vt+iuN+vT 0NwqaCibyKeGrbbEKaNIvMNay1Rl2Ku8zjzN+7dzozrXrHptegbFX3iO23GGa8XFKW0+IFPZai1S AU9Bvn+TrrpbxLOhG2KojdyiT1Ksv85W079Z11ilr7XsqLreoxZbXsuNzqIrhV1KGggKyT1MDtFP KykM0kbMjMSykggl0uQRNp2niPwVTfi1Frt25dPWSaMtWWyimXnmSnVv9NUH13aul5aukMFppKJ6 uQKiLL5Thc4J24IwME59uAw5A1MPGu5X6grKd6CnqZUBaFJKAGWSMOvDOigkqCpJAVuFz7Y1yvef FeTqO32+vhvkdikeqlt8xqNsMKSsRIZPMSNjCvqLszLliRuXG4xslDJiWOZfjSBsj2ahxXQDfD90 Fe+mKC4yxVNNLUlYvMOAm9mwGKsCRkkAAkHkDudQ+y/Ddbr71BWWymuVRapqSGN3kVXUb2AJUEFc gZX789hxlRYfGmg6loKbpkXYV9xozA5mk855KsBDK+IWAfO5doxk8ggg8CyPDComvdZcL68dBBT2 qaaOpyoknnmQECoLD/d71bcFAJCvjLKwAn7DCSknIKHZp9O9ahi5m/yVY374W+pun4llperoSpba gqpC5c98fzAfp9dVy3h74hR3aW3UtTbrrVRruejaEF/xsoIVSpxlW9vbPbXZvXM0l46Tpa6hr4II nAlEhO5ZAyHYFPbO4qQftgYLZ1SfR/Rctw8R6S50l4p6+p2w1Yipbp6zGjor+cgjK5JDNkEEncpP JZsD+EYZ8gaBXb7NprMdMNwCqEvlH1Z066JdOl4xI67gI6loCy/VVZWyOD740iTqXyWZJ7DdQi99 scbn7/1A8a6I8faySqqIbZSioFVWMJJzFBIEgyYwssbhdsZDKGbLkDfk5yGWpn6e6uusN96KuMGH pbSl1pqx6hkjgfBljXfIrNueRp1O4qxRecBQByJ+EBlmMk9nlr2/ZbIsfmID20PFRSn62tNQ0QFS 9J5hwkdU/lMTjOAG7nAPbPbTvTXqhmwY66KTnGDOpP8An31XXhitNcb1R1dxqLlWUxk8tFp0MlQZ XGFWNCHwSWC+kD8WfbV8dLdXeGfUdpqLdVeGtxrb/b6z5aspqGnq5ZYUGSzSN5a7W7oqtyzbclQS y48Nwt2KYXtcB4rdicQzCv6NwvwTAKxUQFYJXGPxAek/31o1VVSq7kJSwqMs7N+Efc+366tyj+F3 ovqikglsk9wpKqaBZFqIKlWplBxuIOP5mPopIzgErnOtJPgmYT7ofEC4TvFysVTT7kRu4IAfA/Mg n76Y7geKZ2HzShjYDzryK5g8VOnL11R0tcZbc1SppqeWeOR5/IjYqpOQCDvXj3AUj3xzqO+BVi61 tnT5rOpKuXfIsfykbMadRCAcfy8ZB+xUAjBBOTrqLqf4S/EB+nLnTRdT26qE9LNCQYvUAyFf8AJP P21G+nvBzxAntCfL2213engRYd9JOpJKqBggOccYPb37aUcJi44zEY/umtnhJsOCjK9VVkGF+Ulm bHdTGf8ANx/lrLdcyRPtloKscA8QucfqFK/31IK7ozqe0RPLc+ja2mgjBZ5lUlVUdyWK4A/M6apa qniILUtXA47boQRn8wTxrlPifGae0j5J4II0NoQda0m4CeYUhIz/ADiF/uT/AH0+U1RFWR+ZHLvT /EpBH76aIb3SKQHrxGo/plBj/wAwBo+KGxV0hlhioaqX+pwsZb9SATpVDmoU7bowOJMZ9tGBxghX Bz99Nstkt7cmnaDPG6nmkhP6lGXWfkadgI1rZkVeyh13fqWUk/qdFQUshL5XWLlmYfYA6TGrUHCE hvuh0n/hzRZEdyMjE8CpRXx/9oX++tXpZZGJNfTyD2ApyD++/VZVM3chM0z9pN36Y0UKUtw8pyfv jOizR3kShkp6J4l5JStkDH/4eUQP/u0dPU3CHcVs1TMO2IpYAf8A9KRRjVBhKmZZFHFGPSAW+w3f 5a1NNG7EBGB+6bc6a7h1rHZ2H8Ssd8o4veZaE1aLgf1GnMpA++Mflpjj8dekXu6WuK5I9a8DVCwh MMY12ktjuOGDcgZAY9gdEInnYWqLxsprFQSYXACj6nj/AE0YaFQcHLE9wo01WDrW3dR0sdXbJhV0 8gBSVUIVwQGBG4DIwQc6e4Ji49eV/wDjqiyjRCrMTqi46P2EeFx2zrb+F+YwKgr/APIaONfTxZ3S Y/8Aj/01obvH/wCjA8jd+cqP31MqvN2LAsqljmUgd8Z0aluiXPqLH7Hj+2kkt0qGAJpYo/1Lkflw B/fWG+cqcBS5U89wP9CdTKFdkpeaSGP2UkfXnRFRPEqkfX2HpB/fRaWecLudndvpvbH7Hj+2iWsd QzZWEMPqZNv9h31Mvcp5pPO8DArI6gH3LZxqF+I/TFJ1l0zWWQvvSpaNZNrmPEYkUyAPtbBKqy9v f6Z1YaWHgecsafYHSiKzU0ZzsRyPdhnRNtrg4cldjYqu+kenunYrT0xZeiqxujLbRVSpXW4RpJFO 6FTJFUF/UGkHoLk8kR4BBB053Hw9ktl+liieoeJCDEHkOTF/QG3NzgAAj2IxjUtmsVE8RRIoqZyS 6yxIAQx7k/4s+4PfWlruJBjs8sXy9StUsrSSM22pRpEeWSJgSdx9QIOMFzkcjOwOM1hx1RNDf4mk VbKSSlh2T08TLj+hP+XGnKOaGnA9Plj/AAL/AMhpXdKB7aiSuyrTyHCSNjv/AITycH7f9hv+ZjXP 84H7Kv8Ay51ncwtNFKLilxuFOsZd2CIBktIdgH741mmrYKwnyJ1l4BwjDHPbnTf8xGSWERYjnJX/ AJ6ytcOFRGU/RU9/20FK7T4McjdgfbuP11qFhVsld5zwWOcflntpsWrwwySv03kDP99GpVhuAQ2O 4HbVqr7EvkWOY+rn7HtreJRE6vG7xOvYxOVI/UdtIPnFQgM6rn2OtzXxDBL5BPH56LvVWpB/tLcz DJA1Y9RE6bGjqFEylTnKkMOQc8jsffOnf/6i3BtoqKSkqsjnzU2tnn6HB7k4++octWABxj6AA/31 sJAzAkqB+XfWtmKnZo15SjDG7UtCs63eLixSI8i1tMy4U4mMikDOPTkAcke2fbUotfi/RSbEFxUg Ef8A5ZGwOMjjcMc/nn686o9SpXHBH6DW5RiciXZ+QzroRcVxLNCQfJZnYKJ22i6YouuqWrVi6xSj PoMEquPyPP8A3/msPVdtC7ZUkUN6cCIsCMfb27/941zBLM1SkQ3NlAAHXKHP1zwc/fS2lv12o2Uw XKoXGcCRvMX9myP310WcZH82eiyOwB/i5dQ011t9TEjx1UahuwY7D7DscEdxpRLT+fGyMcq3bb3G uZI/Em8U0fktPTyykrvlNMzMF3c5EbLj7du320rp/GW5U5US2qdxEAVNHUbTxyCEJ45++CO/GRro M4rh3cyFkOClBql0OKapeAxycHBAdD3+n5E/bUU6gpZ5amres3Cjj2tlS0OwAhixkVD3A5weNvcZ 4iNr8bafbDG09XT4zhayAu2PuQWJ79wfz1LKDxTpalY1f5SQ5AkYT7Dz9EIJ5PYEjW5mLhk+FwKQ 6B7N2lLOnJZa6PdSTu4DB2eQsUKsc4DHlyBxkYAz2OCNSeOJKcbQTlu5Y+pjppg6st+3a8MtOvfK pkfXgLz/AG0dJV2muRY1q4PMl4QSP6jn6Akc/TTc1CmpeQHdOZGftrXJHY6Y6WnvtrKCXy6+HcQ7 BiX2+zAEd/qM/cZ7aco7pCTskIjmBAaPk4J7e3v+Q1GTNdo4Ue9R8Lm/CbHclOWGfcfnrBdh9Cdb t6k9DLn2zyNaQyLKzLwJEI3LnJGtCRSyJM5I50lragU6JUE4EZAJ+x41Heueq4elaGWpqClPKiM8 LNJt3tg4UcertyPy0wdK+JlH11060dUfkJnQxVEzt5UeT6TsfJwckD7H76QcRE2UQk9ar8keR2XN yVgVVUs9LOsZWVgpBRSpPb6HjVNdCXurvPXNzgSqqaW1hgJJFpghEiAq0TthinGG3ZHvjjTveOvK UxVVtra7+F3Gh3rPFtI9PPlujAKWVht5T39JweNc/WqovXQviLWx04N4qJY2p46lKcwIA58xVfzA qlyfqTkZGfbWXEThr21qAde1Ma05SF1xU3NJamRDK5ooQqiOIh2nY4PsScYxyce+eNGL1FJPULSW uKOunLYlkjceTTLjPrPufoo5P2HIqPp/qq/dV11VY3qaG0LSbI56tX83YQP9ygXGSe5PpOT3OMas 6zwR2enSmoxHGmUjLsjLvUA7SrEkEH25+vc6dFL09lmg7/shIrdSqnjdVBmdZ5fdwuAPsB7aPySe +iaVFhgRQQ2B3HudGhgc49taqS7QzoZ0M86wWx/01FSyTzrO7OtNx+n66wzEflq6UtGZwPz0ju9e LZbp6nBcxqSABnJ9ho0k4/10lulZHR26pnll8pEjYlyM4wP7/lqUrBXMniT8VkdRFebIsEtmjWEw mplJjlEnZtgyCRzwftrj3p2uvN+6xlpenZGFRc3aKq27UUwSEDDvnCqcZ7jkY1dfiHfOnuv7vPWR 27zHiK76+SSUVMs3YsUOEGQB6QOARyOBqvKzrKGkrporRXUVA0bBJQ/l7G2nDLIcZGMnuSDxnXl5 5yJaLs1fJbGtGXTRRrqTofqHw0gqI7pSeVWeYd8TyrMjREkEngZUkDgZH5Hu3dRvQ081uFguk1ZW VMbSViPThYZDnCrCgOSFx2IB/MdrK6vpZ+pOoqvqTqC2W6xtbERnpZMxi4uD/JlVTkJ2bOzgkc99 Z61S1XHpm63Gpstts0tNAlaKcSCOWSUEMGiI5TcvsAA2tLo2ussbuOY9+9kQF0OxVbY+oa2thSit rmzQPlau40jsNwJyUIGCFIyNh+upfQeIN9qhDb7hVSrEJ/LgdGwXQYx3PB+2NUj07fbbWdR1rmqd Ur5MU9HA7CRmz3YnOOeffnVkdK2W59bdXUdmtdE9038zmV1hNIRgGYE47ZJKjWD9uXvDaQ5gGnVd XdCGm6ToZ+srfQT2yjeMGquYgJI59atgE4yuSR7jnGupOi+raXrOww3KiLNTvwrN3Yex+35a5vt6 9P8AQXSdm6c6l6gSsqtpV6bZtqaoFvwhAzKW45IPPfGr78MKSmobA8VJbprTTGTfHTTFdwQgbTtU kLn6a9LDH0ZDQeWqxOddEqZF/vob8Dvos59tazR+dEyH+oEcjOttBRV/4z9VV3R1nprrb6SSqqVf y2+X2vKqEjO1CfV7E49hqrbV171P4q1otvm28U0MxVWrj5TOCp5KA8nI7HII1JvFDp8U709EKyoq qlaV2iCxCbb6ssZFHKp2A2njJ1AKLoO7yS2C6SvboVqnKRVUjGNkVj2CDGcAnGT31zMSyQydWyK2 vT3qtLaDb5pJ1b1NcaC603S81zmqIElWCeKmCim3buRgKMkckngZ79tWh0pQef4k19DDXST2iC3K oaY70JfuPTgfX8Wc5PbVMda9a19JWVNooP4dXJYKkREVUMa793JkbcB6jnuOCec51G63q6932/qt A0FIYo9nycsYXzxjvlFJxxzu47fnrjOxAw8xa0l2o8q5A+7WtrSWnStPuu3umbZD05QmnSZRGzl1 j81nVCe4UsSdvuB7dhxpZWXdqYN5dNLUBV3M0YB4+w7nUB8Ees6rqvpCnWvtdVbauBdjrURMqMB2 ZSQAQR7gnUu6hFyltrfwWWnStjdGX5hSyMufUPSc8jOvVROErQ6t1zLrRM9tuW+vlpLnXwijqKbK UbHbIckk4X8XAxz31X3xK9fdN2PppYbjb5ruHj4ipwTIPoTghuOTjBzq4EiElNDVzQ7ZEjJaGJc5 Pcge/wCn31zh8Rfi3QUNvpqGppoLXT1Mw86eqpfMkxnDDy8g5I47r9c+2gnLWMcb3TIySbVI1HQ1 H/DI770w8dClPGs8kUkLRzyA8/jPIOMjnv8ATS3qGgo+trBFWwW35KpkUSOVqGWLCjllU43k/YDO c51O4ek6Y01PV2OGGttVZTefFcpmTAccqu3uB3HOSMcar2aKS21NZLVzFLpIMEmRdqBjhcrkHA+m M/Uc680+OTDR5iOqee4Py08R4LY1wcbB1UntdLdbn0N0501bKfr2t6fN5muc1b0ZUWVFiraSotEt Akz3RPLyZ23RokysxiZTHKpby5X4nT+JND1V/wDi+StRJaGikmF2pKeWtM3ysSyeeaWNoPN3Kdwi Pl5zs9O3UVsPTdRX3HpmmpOp7n07e6c3L+F1fTV+t9FXXIj+H1dTSCjqKaaWbb8hSyMI15R2RwyO VKak6j6g6Ut1s6ctNJX2S22K3UVop6C7sFrI46elihQzHZHuZlRX3bFyHGABjXRgIZAxrwfL8pT7 LiVfHiH400HT1PPPdU82CKRxDVKr7GSN8NuO3gh1XcVGVBQrnI1TdtqfD7xno7jd7jbf41bLncBE Y9s8ZhIMqfMLKBgsF7NlF2jkl4xmJeKFPN0pRUdXSdR0wq0ukirR3GNHBKyLG8hUMJDmQzOAmVYL klQANDpTxSsZ6e/gfyFOnUbR1Hy9TEMW+sqZWTckyMrNFueKPbjCjbtGwDA0sk1d0h5aD0Se9Sj4 arx0T4edW/7FXSH5Dq631ASkutypEp5qtC4RIgwbc2Q8gKkEenPB2gX71H4kdJ3qxXS10lUZHmKT wzWtkBlcSErErbvW2Y2DDgbc8451x/4H+JS+IPWN1i6ktlVcrlTqiRXempnlFtZ45GSU7cFcZKjB +/HLGZXTqy69N9RXWnpp3ustMhlLU9Wk8lHOZpBDRkb5MwtJGCFzvQyhQxzqPmc2AGQcvf5R1dKV 0vWtfL0tUUq1ktLJT3nZHRUSGWNYlijZXidB6k9SspY/hKLkEep46CuYh6rcVFPAZL3M1CRPMKZK WmSMs7LgkyFlkACjJUhiWGCBTNVeq4UUtVd6aGOOqWEzz1VI007sgVZiQ4AMrDJ3Mhx5kmGHIKzw 58RJbE1RVtTrdaMhxJCk/lKCVCCSLgHLKxBIK4wSOAcefw2KDcTvZOnp9yB3LUWEtpX4aultdsrJ quola4QV7VEdZQsoV6aBXfygUcqDgOrDJGXfHIO2vfHeqW72CohrLjHHa6BYFNRtXhHppj6GIAdg VRwnmHGCSyqDiT9T08/WVin6ks9JZ6iO22+ShqIHlkknhEPO2FpN0bSA+b6yeGReSM4598WKuqst NJXXYy097oqPyJpaWRpYnjSOUYbBU7opEhi78kBlJ/FrtSuLBTh4d6Q0WQq08YekuoLLdbXQdEs9 yo7ujTUtbbHLyS1GXWUq4cgs/l78AnG8rk8Zsz4cLH1t1l11QUnV0VbVNabjLFcFmqGjWnGN2+WJ NqtiTOWZZFfzGBI41jo2/XS4+F9LFdI6ei6sspmopb9Xus08AdWnk8tyzEqIFfnHIB2MWJUTroHr 6x13iBYGp7m1D0/Ik0UtFaY6iVUeN0/m1LyIrw/gii9Ksdrbd5AO1sOHjgdY5m050znVm1Oy6ruN zSkuVOTXSUoMpFK5YBN/JK7BhjGq7924juMc4IbPCnxNbqLqTqOnrKRbdDABMsrvwy7mVWOcd0Cn IyMDvgjVEdS9dPb+t/lIKKaSrmqHDikiFTFSRmJVi8mNQqlG81v6id0YYgH0mIUniHc7beo7j8hV jz4YFrqmOFaemgMnmKqAKGfazxyqGb0KzhgQNQz9bTlyWWrC7uv9UsNtFUJl+WXPmHaWTGCPVjsP rqD9AVop+sq23U8n/kwpY5G1Wkcs48sHuuATu7sck57hB0T1jDYemYun787NWLRioqHp4MiESOwx gAoNv+EEn0nAIGTVVz8R6zw66knutHb4pLOssplrxLiJlZgwl2nLAHzQMkeheAz7kBc6QNOqrnSu vxC8U6Xpfpi4VcrQxS0rPugqpWp94X2RjgnJxgjjn7HUS8E66o6wutVX1Vqhe0zwFTI6LIryhyQQ cn07JAmcd4XGFAUa416k63vfUvVV1llubNQV2KinnK7EVld2pyzEYVfM85io9LNGG5ILG3/hVgu3 TEtyvVbU1FXQ/KyyippnaOlkhCgeoMA6kSRyAhFLBhzrmQ4kzTajQD031TA3K21Ynj/S9OdLyRxU UNCKg1cYlggiTenoeUxEKDhTGjckLgYO7jihYoxca2mhq7Si1dSEmSnWlPlmORmjjKt+IL5gA3MM FcHI8wYcvH/r2k65qludZW1XT1VAzRRNTSyQAuxOYZEkClcKCWyEL+bESwVQBS/g1QV9D0rJPSvP W/xOJI6f5NXbyaeGri/mEkYAKpzgkrtJIy2NLkggmcXZQfJEyeVgoOPqui+tej+junLHQ3C3VlwE lQnzHlec0TRQCQI0hXK4UA5DHjPpJBKgtvQ9BQdcyxx2rqyffIgZSVWWH8IJzIRyB7/Q9+4GmzqW yw9ZeGEFabiZJErzi63eCRohElIJ0TCjKIxxIM7iCW/GwC6hPhb1PFP4Z1aCurLPN88kc1FSN5fl RCPh4GYcymRivbaC0hbPoOsr+HxPfmDBVd6e3GSg0530Voda2z/YOglqKjq+xXFFG9i1PLlFwe7L tX2xjk5OoDYPEOLqaFJ7dRx1UcpxuhNXD2ODyYSv7sNXJbfh+E/REnUlTcZxUQK0pSrVZfNGC3oY uu1iAuc4wSR7EajUdvjjkcUwWpRYmcSBGjDFQDsG8fjO5No7HcOe+OLPw+drrEdeB9ldpmKgLazW fCk32stI6yyUdZRueFDSg/8A+2nyJml/3hkHP9QXn9tLoegOpblVNT0Np8yVQrsqVUJkUH3aMtuU fmPtweNFz9N3O2SJHX0FRTPIxWMbGO4gZOCBzwRrG7CYhnxMPoU0Sxu2cPVJ5oYXKmRd4U8DPH7e /wCuqT678Cbd1R1hUV5gaqS51KyPUxny6qjKj0osgJJhJL8DaV45fAGrz+XggLKSkbLw244YH6HO lIgzH3O08ZHGlsLmHTQotwqM8CvDe4+FdnuXT4ZJ7fT1HmIXlPnMxUZ4IwoPtzjHGDyzXBSf+ZgS SHJQqDhvxfkfppbWWyOrHpzHPjCyqvK/p7j7ftpvo0nt1Wsc8awzHgSAnZKuT7fUcffnHGeGOcZX FzzqUrVmgGicBDuHMC/mRjRsVKI+RHGv3Ax/fR0UhqHZVwki/iQ5Jx9e3I/5a28ktkNNj9uNLLKO qMG9UWoVTj0g/bW4h3ZJC/mO+gYUBwBu/M62SIZBACflqAUitYNOSeAdaNTZ7j88nSjY2CN2PvnW kknkLmSTaM4xyT+w1FEU1Nt5Cn98aKkCjPP/ANulHnjkoJHP0CEf562bfIMNHtX6ucaqlKTdI0aH k4I/xDTZchSVsWyZ2ODlWUMGRv8AEpxgH8+PrkcaeZKKm35Zcc/+mW/56yaCEknErL2y3OP3Oqoq waSLpzrVKcC1XthULL6IppV2pUD6fZgBnHfjue+lHUdrq7TLHPbYo6y2S/hl7vGePSw7e/B9/wDN t6tr7NZunblXXOF5bdRwPUVHlIWZI0G5nGMEFQCcg5GOOdI/C7xZpK+kp/5k1ZYqr0xTVVPsdfW6 bZU9juRwQQDlTx3GtbQJG5ZPXsWgFsug+L6pZ8zXNH6aaNH92LAL+o76L8qvlb1PFjsQgJx+p1Ob p00kUXzdGFekPqK9yg+v/t+/f6/XTU1MirklT9sdtJfCYzTlmzKPJRTYAKh8+5RQf8tGfwqRmydu fqck/vp8Yxr3YL9u2i2dB/V+uMDQ5AhzJoNokI/3/ln3CLz/AH0oSgWFyytJk98yHSlquIcb1J+m seaADtXH1wp/5avKAqtamPPAyQPc9taSRkr3P2wOBpQoZuSp1tgnkL+50WVXeqgfVy3evb5S1i/0 ZSohWa603lRwRxmWMy4Eh3yYj34aNGUE/i4OJ1SfxOJXNdFFBUtLIVigkZwse4iPcW7PtA3YypIJ BIOBpUZkppkVhuZGXbjOcjTpfZUqI7XVDcY56KNgRyD6m+vvjH76aGgtOmyDMbq0R8w4PrKgn6tz +mtzPGRlyxH3OFH6abywzxhf11lGQEFixP2O3Sw1XmpKy3mEbJvLX6RqMn9TpRFE5JA3bT35/tn/ AKfrpAKxV5XaD9uTrR6+Rjw7Y+v/AE1MpCmZPqRybf8AeLGB3xz/AK86OjqBJH5D1LVIU5KAgY+u QP8AXUeatPllRNtyMZZuP20dFdxTwqC4CKOWVMD/AD0QBCokKRQo9OA8NTPSY/8AzMzL/YcadaDq q50T+m4zzpsIHnRRkfYFtuSO311Wdx8SrBaWIrLxTRSdtjVCb/2znUHvfxUdF2F5g9y8xYVy0oHB PsoH4mP3wF+hPbT43vaeo4+Sjo8wst08Puulrf4o3ejjjSahO6L1N8lO0afoGwp/L276fU8Vae5Q g10VSGj5ZJadWCexIZcNwCTkEftnXEknxodJPFKaW4M0qRtIrGBjwBknbxtA9yc/kRnS23/HZ4YW 1o57D0F1R4jdUIykmqijio4TgZKbS3GRkFlz75GujDLiicrjQ7xosz4YwAQ3XlW67qpOtJIBQE/N rHcVeaknjpXnidOOD5alo+SpDOpUrj1Etxrf6/qPyzd7OiVlVThUqqOmdZo5RnO0cCRXGc4OBhux 1yd0J8VniF4odUm5Xuy2Ppe1wQukNqjleorACwwWkBCqCVUt3ztQYXubotfi/S1ZU3GiDSqRiREE mAD6SCefvx21uGOhB6PMfL2Uh+ClLSXMrx3+yk/ipWVNXY6a6U3T9cKZWjnq4Yxio8vI9LQYP1yS cEBTomOK11PTNClLO0FWYxT0zO6xU1RGwwwi/mBH7g55PA4ONbUnV3Stz+WjqyGliUrFVy1MiVYB IPpnZhKO3YMMjjBGnaWmvFrnlqLP1HJXUUkgdrZdqcSCJe5WN0TcAechllY8epeTroRzRSHMKcfm sJw7mUCa8dlz/J0RPR0lXfr1UXGe2RtPDBTyur+SSSQu9c7QTjLPt5BxkEEw+ioKGruFTa7hWVFq 31h86qmmb5aBY0jxHgZbO5i3GeXB7HXVLeGfTfUcs90ko5KGtqH3VFRaKrKyMpI2vExdD+WM8DOP w6jfUHw9XGntYbojqmlpLmasVPz1xpi0n4dpAeMhR6crkxnjjWI4Rrn20cte/wB+KE5mjdN9jvvT fQ1VJ07ZmqOpbszJJBAsbRwiXGQzZyWZQAckHgDudWx0B0u1hp6qrulzN0udVMZXqNhVUGBhEHso +g9yTqJdAeAs/R9zq6v+I1M9ZVOXqLlJW+c82ccbPLVQVwcE5/Ec57amPVnUtSlK9JRq1HO7iFTP GVkkJIGUH+Hk5Y+2SO2unCwsGd4qtgNh+fdLK7XZSGW8wyztSwVEXngZILZIGeePb8/vpbFNCiqo kX8899MVisVL0tSPIzfMTsDhiq7yByFGAM6cqWX5whzEo993BwDyAP7Z1vbZGoStOSXmpQH8a8fU 61aqjHBkX99a7EH9CgflrBjQn/dr+w0VBUVs9ZEBkugX3y2sCZJT6GU5H9JB0ydSUirSVE6lQZol pCpHpAZsZ4IwfV/bS1LLAla9VkmVo0iOQCNqkkd/ux1eihCXEgainiRdR0909PeJZ5Ep6NcmFY0c OxICn1fQ/Q6kTxtCjESFVUZJzn+xzrnH4kvGK3x9LLRUNSJLjHOj+SCv4fqc5U89/cY1nxEogjLr 15eKZG0ucuS/Err2WpudbX3WGKnvTOxaO1U4p4HyxKE4bLOB3JbuMc99VtQ22bqC+01HBNFTw+YG eqrXCQsxBblgOScHCnnOruqrGOvqB3pxSrfp5v5VLSLJO9UyggKuAUVRyS3GCM9tPfWPVkXSHgn0 ZburOlno70aqVqaGnQozxENuJK+oNlh6QTnvj6cGCMz3I7z/AAexaKURpelrteejK5q9KismMYnl pJIy7vAE3K0THspYfYjafrqO33r+wdS+HXSdqgthpL7RU5k+apW2LUQMSAjqE9TDaMsc9jjOdOFc 1fdrPe7NC9X0zRmqhnWmqalsNBtGxc7SwxnnJGQdTegvNHVU9paeK3utvpDRxpTQ7YwDjOF5IwR3 HPOjdiIsKyhvt2804sOgcud5fDCplu8ESW2S3dQR1BhipKZ495MihlbaT3wewAxnnHtPvEz4d+pO gybnP1ItsoUo46kSvG4WaoK+ofyydgJAG445zxxqyeuOqbn4fXCe+1FiavutYaSCOMxN51bz6Ajq Mq2CBnvqguvvEXq3rWiutPW9P11z8uoMTy0qSfMUIcsqU8mzAIDD+pckjnTcM5kmcuB3oXpSCQVV bUl3SF4qjZUqHr/4hHb5RLKIpGypY8DaeCw9zwfz16O/Df4rVPif0/UyT0ElAKER0+ySMpyF7gH2 IOdec/gb8NnXnXVdQF2+UorpV/8AnKpEMktG6qSvmqCpj3DsRnGefpr1E8JfCi1eD/Ssdktk1TWH cZJ6ytcPNM592IA7dgAAABrbho3Ah7TYKwv1NdimvbkawecnWckdjjSK7XelslG1TWSmKFTyyoWP P2AJ109BqVW5pUx8RNVXUdwt1XbrXVyVdPBI0ddFUtDDECMEsVU8jg4PB7c6pyq8d6ar6YnsVzik 6kq5HSkaGUmBoXY4VixYBQTzvyDq+vFKn6m6h6Wt9H03dpPLraxWqa9owXigznZsUDuOMkce+O4j Fv8Ahh6LuN7qLpWUkVTVAKwpZFZI2YD8cqFuefqAPz1z5oJpH5oX16V/fzWoPY1ozDVUVcvDm51d ukts1sE1ynMSJUBnm5LYGXRsEY/qb/Thr6JvdX4O9dXumSMXWWij8u5GmrmRZIwAWeMlCQ0ecNyM 410ZfvC6oMUlFaJWoIUbzP4lEoiMK4I8sHLApnkgjjUT+Hnw9pKnqTrOqu3my3GhrGgnmlCiKp3D 1qykEYPGcfmNY24HoHsFHfe+4n3y5LQ6QOjcT3KW9GdW3PrSonmlFJR2ihACxXNGjhnhY+hgyvgE ZAJK+331e1PAirHII40fywv8r8OPoPtphtdjt0MVNDblhW3xReRJRrJvSMDG0DuAV0811xpbXTNN VVCU8Maks8jYGAOdd1rXAdZ1lckkE6BNHUfWlvsgaKQtI5UghARg/wDu7D99cc+LvTH/ANS7lU19 ipo/mYJMVNFXTswlP0jIG4Z+vIP6a6e63NPdLJU3G2mouDQYlRrU6LNIcj+Xjswx33Dt251zT1zR VVJ1gKqGaalDoqS22rZcQdzuCnhu/vz9Ma5XEZSxgoW0+9Dr/wAW6FoKZJa+4W7paG03Z2tU9A5k Wnp8AkHvvXk4x34576h8nWpvdTS3BElRqOXd8/TxAxxxjkcFcZOOM4/LUkp/DcVVylvjX2l6heoG GoiGgCKB/USQPtgYx/lMOm/Ak1/TlZTfIrZ4KiBqhYXjkeRwBncjFsHnHpOT+WdcYYZ7yGXfIc/K 9fmn2ApP03QVfjLarFQtarB1HDXS3MTWjqOplSBZFS3BK2rtizLFcKeAF8o6O4nloQj04eSeNFB4 Q2vrmloOoUsVkpkudut9Ulvgb5qnt8bUUBjpIJqMLBLBCm2ON41wyIpy2dxijeEctutnT6Xq2dP3 a2W2quk812v3X9f0s1FOkFproo1npNzSELQzVRUxMqChSXzIzHh368Xi62GS3WrpOkoafpmhtFrp 7bHZ7385RiAUFOUEFQ6hp4wDhZWALqAxAzjXYeZIo29ILcs7xZ3UDHRFV1pV1lPfLRW2Goemapp5 qiV3VQuxWBfcI3UhPMkY7TJvJVhkAwHxZ8JKvomzRUtNTSVDU9onqDeaNyDPHNJuRJtyRYJOFVV3 cM6ksqHHQNx+KboWq6W6jlgku38emoqiMU1bQspGVk2xEIrIApYj1Ej8O4kDhXevE/w76vplT/ai lNIvyW6irbdURII4pgpMczooOQzBlAOfWp4zijQaQN/+/wBbLldNibAMengVzT8JfTb37xwgudvv lutM1MC9TZq0sDLmN4JIzuOWfJyAeP5o+m3VqW6kW5dbzV18s89KsNxNFdb67SyLWEmONvxCJ41C ICXIKAGQMN20GV3G69JWSsorlaOq+k6esqKOae7Rz2t6gVNX/KjkqInjdJI2YD2POwkDduOqx6r6 5tXVHWdyj6g6qsbU4raaWBzH82xcpIWpd59UUZZ5GWVT/LDKpII2hUszQGsAur8N1pE8jSMzK9+C ZOuBeb/JRSWiaarmNOpmpohiqEzb2kUp+AhSP6WJwyjlQBqF9HeI9xpWoqSZKq3QVMm6OpjDbQ6Z c+YRu2hQqlgASq5YhtMdX11SST1ENE0iUzUsqolUgJjZXBDcY2s2eSG3ZYglsEnF3s1JI1ousfXF hhNTDFVRW+qhqxHEIqiSFWHmI44COCO2QwKsuGPDigaXh7xrd/NdIy5W33Lsbw78Q6Hp/pfrlJK6 QRwiZblX0uxUhLOQssVPsydxdiuEAbncX/EGbxj8Epuv4JRLdaJrhf0iVp5IYRNTUyRyzTF3RRh/ MSRdmRkhRkBSdVNb7tRvef4303N/C6a6YNRS2iVy07el/NKSR+ny5WVm2Fsb96MpHq6M6Q8ZYKqq phNT0lNc4alTR2uKdEkqXqFO2WTYAWA89GLKuVVpvxnXpRJFMA1xF/j86JTHZusFRXTvSl0uHh11 V09crA1XcpY3FD1FUCCVPLjkKI8VTtXzSgkRFIV2XDbGHEOkPhT1xS2+e69QXH+LxdXvFIJ3r7es 9FUMkcitOdkZeP0U2WVXZnaORWCgnV9+J/SVq6b8L6Wbo+D+J1QKJb0q6tWpqeRKqOaSWp3OSzpJ FIxCsPxsCuFLK1UvhFa7P4Pmnt14rqm3moqnrLNa90NVVQuWjdpFdBIXWR0dz6VK+khlRFOl4Org eSom7Kqq6Pb7t8lelNRT0F7pPmDR0z5hWrQbYVJAxiVI1aKJuf6QFDbTdHUXT9+6K6TthuF3tVNW QpGt+qaqggmeOOVESExxq2fLTMoJcEDbMQcADVF9fXmotU1i6IsVsttbRWh1opLpsiKVMqzeasBd soDI21ctwzFjsyBss3xH6U6kl6nq+qbpdUooGq6CgtNrrJo2knD1FPvjjkWaQlwYk54GXJ9HqOs7 SMpyC9VbmkBOFg8dFv1fTzRy+aUE9JFPLuWd5CXBip4MFgrf+WdfMDIqsq+puNRZesYbF1perJBB U1drvdOVp6dKk06QKKcqsUinDMhhSIZxuAeTbk4zGanwj6y8MfFGytb7fHUW6nvEtTEsMJf/AM0W BUzOMsRIEXBZv5QaTO5QGc7xlsdf07erDcKe3SVwp6CGSGGlhO51VRLGZckoG5kOEJBVCpAxjSJH OADvL1CEajVVgt5q46mWAW9ae708Zt08T5Ms6xh1UvGDncd4yxXLenBGCWtLwn6yHU1FNZWuMFKl yq0hqI6WYUvkMrrGJFZwQSqxSAg43gouBg7qbpOks+IN8uFTWUqUdXUTyKg85ZcyxsmwtjJw02Pu UcgnacSvwi8ApOoIa9YLpQ0cJuMUFNTSzmaqgkkclMsrLukwgK7CCPMLEqrPrFA3/acos7ojmy0V cfxDeAslkrKaOz2qfqSi+TRquupq1Pnad46iad3Odq7SPQOARwF/q1SnhdeHtvRN7ppa+8w2G0EQ mS4QxjzZT8wVEKlSA7M4BiYlv57sxIGTcXXt/vFgsfQNHTXKqW4UNPFWV5rjl5pngjQx1C5TzGDb ss+0ZcKSWJ21f0ZTXqHo/wATGjsjU9ReVFRV1FZX5iWaB/5kgB5COJWVNpywSUZbgL0XdGQ9g5Wl 66kK3+mOp7fP4ZUMVB1DYqS1KszVVI1PIt0L+UxkWBN+SPWy5Uq+Nw3M3dX4U9P081mnhToagpli t1bBJ1DUFC1RL5snnKqZLmMhyPXtJG9TgjBoyq62u9D0habZt+Rt9xooIlSzpEiwzrtbYr5cebJE QWKsjNkKwyrZun4VPEuTpSrlpOoVucPSUsZFprqsExlC5eGPeCCCyrv81wEO4H0Bsysi+KjyVbq2 +u/FR7B4C3O7wT1FzujTRil8svLA8gfYfIbbGZIwEL5GfrzrlKl62n6bunSNzue+50MsokejmhQs yR1ErKGKcZ9AlOMkmTjIGNdYfEXbLFeqnpa619zls/T1BXvTlqdKyOfzwruFjSCEt6gD/M3D05Kn khqU6utPw63nquW63S+11HQQcRUVvtVRSBzg5Esky+t2J3ZUJwCCSCcjM5ua3Or3ujjY4m2i1OOm uv7m/T1ruVvcU9rqHeoqrr8zGHmQIEJIkct5rSq4BHAji2rnacOdt6ppbp17d7hdoluMsEix0Nut VMZnkrYVVnLPHFz69oYjGTjCgfigVX8UHgD4f26W3UNnn6q8uaVzV3q5wyrUNIQZGP8AMkcglc8x 9yT3YklUP/iedHdOUaW+y9FUNFRQgrFBR1UyRqPoFWkAH6aE4hv8D8imiF3MfMD6q3Ld4Z9d36b+ JTQMausqlrRLVSfLpH+MMDGwLKSBFglCy4AwAMasnpjwQgoritZdYrXMoZ91NDSK/mAqAu+VhvZg dxJ7HI44zrjvqP8A8Uq6Ttus1mo6SI/+m9DLUv259bSwjv8A8J1VN7/8SHxiuRmjtUyU0s8g8stS wgRqM4CrsY85GSWPbjGskTYmuzAE+ITS2Ro008D+F6cN4K9IOjCW2s5JJz8xImMnt6WAwNQbrnwz 8OLMpa8dVrYKM4xTVNfCoBAwNpcb89/cnk684b141+NnW1EjXHq+rhpJ4t8kEUrmM7sHDIzMv5cf XTfYeia3qvArq+tq0JKyI8u2MH3ygwvc/TRPZA7/AMseiJvTj+S6xfrDpqG+TWm09SU/UNGo82nn RWgmVO2GRgDwMAsAVORyPwg3q7qh+jbKLulmrr9bl5ke1hGkiH+J0Yr6f+IEgYycDXPvSvhTS2eo FXDCkNTTPiKVPSykf1DHuRq5+neq6uwywLW1EYh2AyHbhATkAk54JOPtk+3A1w8RhQDmAsdnYtsc jgKvVGWXxq6dvFP5jU1wtZOMfxCnGGz942cD9cae6TxAslxm8uO5RKMZ3ONg+w9eM6S3XpC31pNb YkjOFLS29AoU5HBQf08+wwPy94e9LEKYRttO1mDLt2lTjkEd+Dxz9DqMwUMozNcUf7hzdCFatNWU NYcxzxS5+sikf2OlqwbDui2Iv/AgH9++qmpqPZna3pVSCqjPt34/LRhjmpd7xyyRMfWzxkqFzzjj Qu4cf4u+SMYocwrYMLquSN35HtrUUgb+nj6arGlu1xoaZqqGtkjkIycqCTj7EHPv31pcevOr7dDu opbZJIw9K1tO20//ANt0I0g4GUbUUfTs71aopVH9JH5DWvyqjPpB59+dUTU/FBeOmsJ1J0FLU4J3 VNorNyt+Ubruz243HUh6B+KfovreralNU1jqxtxTVoILHnIGFLZHuSNv374V+1mug1EJo981Kyrv 0/R361VlsrqczUNbC9PURKzIZInG11yORlSRwc899Qvw58NrR0vHdVpqEMajFNN5mGBQO7Ff1dmc ++5jjjAEjvni10r03BFUXmqkoqOZlRK1YJamBiewEsSMmftu/PWLN1f07blr66qvltprVV1RNNXT 1KRwSliWCq7EAkjdx39Le40kskb1SCO5E17btpBR1Fdrj0PKA8j1FlJIV2BeSA8BVY57ewbH2ODg tJrhY4a+lWvtbExFQ0lMhBKHnlfqOM/5cds0E1Be4WNDPTV8RGGMLpKjA+2VJGO+o7W0lf4f1C3C 2LLVWePDT0UXMsAyTlP8UYz2PK/deFJkjaySbfRawOmoHQ9v5W4ocgAFsHttOP8ALWhoY2B3Jn7n UoRqXqKjFbRDdKw3SQrxn7hfY/Vf+y3Lba2uVWobJdK9JASslPTu0bY/48bR++qfE5poa+CUQW2H aJl+XSEZAAP20W8u3HcfQf8A4NDqSqg6Sp5ajqi62no6GMHdHdarzaojsrLBFlipPGcjHfnVHdZ/ FB0pYUghorrJX1UgDAmi8rzQexjhRpX2nuCSO40GV/Ifn03RsiL9vXl67K63nwck4P30naoA7vn7 a52bx96iukkL2/py71MQUPIJKUUSNz+FXqGT29wDj6H3jNX4jeJN0Vnka02XOQsclS0zqD9QqOh/ fQa8/qE79pIdR9/+Lqie4rT7izbQvqLNwAPqSeBo/qnqq22ToTpesrrpSUVKRNFFJUzoivgJyhPf IXOBn/PXnv4i9PXyvtE1XcuokrY45Q/8Oo6Q01MpPBbaHC57Z9GT9ddKXe1RdYfBB4eSMZVa0VsE TzUwjyFEc8J/GrADcI/b6a6McTTG5+a/Ls1XOdbcS3DuFHQ+R0Uuunjx0jaqJ6qS8CSIDK+VE58w 4/CpIALH6Z0w1/xG2WOES09BWVEZGS9TNBTFDnsVkcP+ynVE0lhp6aMpLRQzP3FQYYxIfzKqB+wH 30huHS0Uyb4dm37ekj9NYLbdWu8MJGBqD6/0rlq/ifo4l4Nvgffjyo3lqTgA85CIBz9z+Wo9VfFX VzgiCCGAAcMFJOfzPbn7HVJXLpuSAn0kH8tNn8PdTjHf660tiYdS4qFrW7MH1+tq2pviB6mrRJuu yEMxKKHli2KTwCYyu7H1GNMdz8QKy67mrLk07nA3Ydiv1wXdzz9yf01AzROPbn30VLupxuI9PudF 0DDomNkLNQK8NFJP4lTVGBJU1sy+6GXCn8woGdNDUdqrbkahaRflabciK7MRJKeCxG7svYY98n6a Yl6ippCy0lRHLMfSiqd3qPA7fc6kFos81TRwDf5UGMKJhsJ9skEZzrQGdA0u25JDpGzuDN+Z+ynH Qlja4dLV9r6ZpjRXC7yinpxTwwGWdW3hqeSRo9xDMFypIGFYHHOhEKugkMMkIo3jlaNoEQR+W6HD IQOxB/sQffTFY6arsBgrqeoKQSVId1hkZCswkIjlUjHI4zg/4SO2rP6jV+qaO3dTeWjz3MtSV7Rk KoqkG5JiBwu8ZB7BfUeBtA0zxmZm9lfMeGcZk4fjMs5tjnOAcedch2Fu9DcaVqKQUvU8lAY5Gdy6 nKlW2kfqNOa+JF7+YWaGqKKn/wCfO8Y/fThYvArqq8wrJUx26xIy5AqpDNN/9iZA/wDkc/bSi/8A wo1tfap4j1Y89RLxCEpGjYOSAuNr4wCeSQQByeO3CZhwTrovrb8dHXb77VvZPGiWgnda28MAwZjt ywx7KqjPP5/vqwun/Gme3RQz2m4jZUMAIqZysrsOy+UvJbI4BGeONcxeGHRX+x/UFL1NfaJuqOja GompZailbKMFZozK0Z/3ihsPnIPIzjtruHpRLHRWyKp6ep6GkoapBIktviWJZQRwTtAyccYPI7HG t8mGMBBzX3rgDiMU7nMyUew1qO1PfR/Xl66uoRdbrb62zVsUnkwzVsSU9XUQ7csrKgyse/aQCQ2U zwOC9t1LWUDK9NVtTvnO1TkH9OdMBuPOAxZvoNaxTzKfTHGgPcjg6oyk8zok5R2KeW3xVv1HHvle Opbj0yIyjv8AYjt9xqRW/wAdK/zf/NW6RlPd4JBtH/xbJ/Y/pqqfPQL6mJP1J3aBaBuT6m9t/wDy 0wYyduz/AH5pZw8Tt2q728VLJd1jS5wNTyQgskk6kEkjHDxE7fvkDv21Kenur+n3pYqWgngVFA2x JOpYfchiGP5ka5lnqhGygozM34Q525/TGf7aPiu09PEUEkas3vGnP7nn9ta2cVlabeAfqsr8Cw/C V1r83BgHzQB/xggfv21vI+yLeAWGMjZ6v8tclUN+r7U5akqamnBOWEU5jDfoO5/MakdL4u3+mfip E0X/AOanRXz+pGf763M41H/5ja+f4WV3DnfxKuutmNLQVDzOWiFRFLuXJH4weB37e2pNFMk8ayxs HRwGVgc5B1R9N43TyCNbhbKatUNkAMQRjkH1A45+n01J7V4z2RKZFkpJrdAgxwgaMDHYAHP7Lrez ieFkPxV4rM/BzNHwqYdY26a69PVVLFNLTmQYd4c7wvvjHOfyz+R1wr4vWep6Zmigq0Souu875RGV RF3naQGXGSuCe3J12m3XnTXU9DJSRXmKnMy7d3nGJ1PcFSQNUR4v+A3XPW9WlTaLnabpQpKjqvzB SoCD8SjK7W/MuM6zY/JioQIesb5IY2OYadouZ+nr7fLH4m26psM9JT3GM5jApmIKg5dWwCFBGQSv tznXSXi7DauubQqUd7SmWOlDTW6Ko8000py3mgk+htxAJ5x3x76rjqvwN626eje4VHS9ZVOAsESW WBZoiPczRxuzkEZ5XsftqZeDFte2WfqXpe6WakjjpIfLkq4jmogkde5VvUAVbuD7HTMCHxR9GVHg NcHBVL1XTVb3yKoqo2mNbMIpqiQ+ehaIAbldTgBhjuBpsuPT9BFDHJVwzU01am+mjRsAjJyWZOQ2 VJx9PbU66hEVClVaaedHqaWSUJVSeppI1bAzxg4x3+mmun6Yt1+r3jrwJIaE/NTxwbl/lmPLEOWC sckek9+edefkIfM5ux+/brutT6F2m/qXqFerKelqpqc2eanphBBIjmQxlDjcO23IA9ieD2zoWu5r SXOiMdquMaVSDzrvbN0lQHxljkkArxuKHLYyRpJN0xaopo6KOtuMt9DLBTSQDiSGbALlfxAAAc8j g5+urupfB+92w2+moblS3mKJGjlt8sZjEKbMCWV95GQc4HJOePfWbDxSyvMr7IGtDmbofLXT72hc 8AZBv9kd4EVXR0U1zunSVCa+6VEwaepeR2aVweTleygknBB7/oOqKRpJaSJ5gizMoLCMkrn7EgHV T2i72DozrXpfp5bPS09xvVvqJmrIwFYPF5Q2AEc7gWJweNo4Oc6spY5J5GCv5ZUYMcZ5H/ubt+mv cYUFrMr3ajkOXP37K572m7rdOYGeDqGeI9HZbtaaikrK2KjuAVZIpEfE0ZB4PBzt9j7YzqVCOaNR tOQPYjOf9dV54g+IFF0vKHqgsdTsDpSS0+DOA3u5GMfqMHGtUjmsaXPIA71TA4nQKlOh+kOta68X wA3Pppof/MUtYmJaecqeQycl1J9lbODq6vCmmvdbZK89U09HBeklbzqqg2+VMnsNv4gB7q3IPvqS dNXqO42mmn/h8lqOzMMMmGHlnnuuQB/lpPNbFF0r7lHcGhiq4DHiKUIFYdxjGCfv30GHw7ImgxnT f1VudnNlU6nxAWCe+3K0VdyqqdzLNDNVvSOlKm3ICFT7kcggknHfVYfCX1t1BNYLpbbdSzXiherm kbbDnzYw20NHJJIBnAztI9saO8cvB6e6xXOe1dRSpZ5Ueomp6jky1Cg8ROQR78BvfsR7O3w6+JvT Xhp4amjvdMDcUlaSaI04SXyych8kYYflrnzYkNnYx7gBqQVv6EugL2i6IV/9AWm40a3O/wBxWClj rQsi0/yphkhRRyHUM+WPckEflqvOrOuKrqTq/wDhsES3W2bm2quUwAPUQd4zweDzqS1XxEdM1HT9 uqUlkakubtTxyU48x4xj8TBe35HVAdTeINus95qFtkcU1NUT+btdggLADkEjknuMHnGjxc4ZGMrt zrVX7KxxtGppWV/9WLNVvJSWqwRy3FYDTpLIPmZRj/28lew5IOoTRwXfrbqNqS/1FHa6eGk8svJG I2nJ4IG4n8IAzgg89tLOiLH/ABWtmvQWGKQsP/MU6hWQn2ZR3yf+ejqGy19v6gu0MtwqL6VYy0dP GAYhKwyd7e/0weONYbmkYCdQT4fTwWgZRq3ko54ZzVXhzX1kt/rKO5UUlS6QUhAkkaP+nacEc4Hf 7avI321db2gWyie6WWKSkLRQxSmJI3248vIJyMHOAcDHGqz8XeibV050xF1Pcqpbe2zdJQBhTea7 YBCEjg8ZwMk86g/R3U9rm6evN2quq5jV0zh0opqkH+XjgCXbyw+uOfrzrS0y4VzbqjyPZvz27KQn K85giur+k6eLoPw/vtz6/sXSF7atralKnqDrejsZqDHVWupj2fM22uE/ly22ic7fL27VDb1lIHVl qgsHUvT1hu16oJ2uVba6Oeb/AGppIaa6gtAhxVxRhUjnGfWiKqq2QAAANUHZ2vL+GnTFBR10lyhj ludSOm7VfrpaJ69EiimNWKm0wTVeKdQ8RgMYile4QAsZhAjyy++ItfD/AAqlW5UPWk1Pa6JZ+pIa WJYrtI1Okhq41iDRqk28SAIxUBwBrZgpYxG18hoEIJBmedea5363+H3w5p6ChrKTpilhle62+haa GaZUeOWeOKVAquAcqzAnHHOCGGQt6Y+Hbw5vFJPSP0XTIkMsqSszyhtqzSKoDGTdlyPvlUcen05e bZ4f3+xUdJbI7jSlGqaGsZaigljKGnYSSBN8AzucDaTzgYZsZGmlaXqr+LT1VruVrtdbBPMKqlr7 l5EgzIpYiNsxmPcHwyHB384IYayR42Fzta53t3f2nGCTKQCozdvCjwe6fvs9krLWsi+RG6WsVcuF mJl80q/mhySBAAN23GeM8rXHib0D0V/Ea5aamm6fqYYxWQ0s88paeN1QorPIdiBQ+OCSdjjOSo1c XiV4W3rr/rqO8WOnttVKNlMKWW808zMmx9xUB1ClcI3IORKwwwUBjb34cXXqq8tUdQ2OtaKlt8VH ClFLTHdMZMSRyETbn9WAG2jndjjDHK9+Z4siut57Jghd0Rcd7H0K5UTpenS7RU9PV7fJgqG8ipid CBuhwynauSdxO3GRsJP4hh7vHUAjqugbQlnt08B6caVp2epRyI3qZWA2TopGVJ5BySTnnGrJuvgb d9/zkNgutwoEoZadKWGGqZ6aQlGHlFFIZGIxjauA2eRkGNdXdNWa3dY2K2VFn6kpa6nttRTR1cUH neWGWoDRSRMyFSFLPnLHHpAONBFIw5XDn9gUxjTqPDt7VV9F1qj0dxuJsFnoloVQJJTPXK5ZpAAm 81J29nbODyvbnItPr1rTernS0sVruM14rqynsNLDDeVhpxHDRQGQ+uCTAXzYxgBi3JBHYsHSvh/b oLL1A8EVDXGgrKVqimrKySNMx+bKVdqinSMfh9S7j6SwJUAnT51B0jcabxCtVRDartXwU16ulwet oqf5qnhIl8kK8iHb+GlBIJBUMM/TWkuY5+m39AojGQ3X3rSrHpKt6Z6o6gslqbpe7w1lZc6eCOao ukcg9cqqVCpBHkHd9T7Y1J+hOqLT1Re7rLV2251jys0jyISpAd8DDed+IgkBSvb8hp7+H7w5htt8 tnVVQZHtUUS3CGrrqWFVxHVxRsUzIx3qyt6gPSGUkjcAWLoKstNB0l1ALDKyQwtSRSVkkL+dVuyy 9ychUHr9Kr2C5JOWDXFmaquq+Z/pAGHKL71Ydzk6H6c8OJ6i7U99poZrrS0s/wDD6yJ9ziOcgq2J cd5dy84JXtzlx8GLj4Y9aXSt6coqOqudWI2kja421apkjjK5AbMfIyDkDtn6gCoer6kReEdNbfmq WFJ7+KgcSeorAMggpnILA/TkanHwliCm8R+n6uRPLVelq1i0YZ3mY18sYkYBcjvt5z+Ac8gaKKGJ 7zY3/CW9xBvuV69ddJdA9GdP1N+r6KGCKghjhf8A/Ez+S8mIo1be7qoBk7glRy2c41VNuvvh9LT3 FKe90dbeooKqpEKQqkUxVS4O5Kh0B2K3Y49bADU++Ke9x1fgfe6HCzfMw0VQW8w+otVBypGRjK7G BHfkew1ytB05TWqyWS6LZCGPStZMd6sIZZ5LhPSFpWGGIWGUYwcjbH7DGlPhjLLCq3EnMNvZVtdM 1ydQ1L3OOpqHooqOaEVBp5EZEKfgVi2GG/naxbgZAwNWD4c9c3fwZvPStVS9KW++VlziX5ippadF uCt58gODKx9W1eX4AULk5PNbCjo+leg6LbTCwVUlrieaig3GmmWZBIrKcHzHKyKN/JBIUcLkp+uO rblZek+nhLSJEaqxybaAszLHKZ6gsWVuQdpUnK+ojuCMjmxCSKcuj2uuSW5zRdhTCprLN1/1b/C6 esqIqy4zQFpKqYM8FRK6RFIw/J5mZnXODh8DAJNieAdt/wDqZ0ZWWxKagoZJ7f8APRrLNFOh/wDN yCb/AMvu/lxKjKoHcAOcse1KdMJL/td4PiFpYlS+U7zICUBxa7XOd2O5JEhOfcn6nVx/B54ddB2i NeoOt2kqr47hqeH5j/ysJmSXDsMhlZlTGG9HEbckjZ0mhsbsjq81cjWsZn2A/r8q0OsPAvrXrfor om2xVCUnUlBd5K+RYTJFTpH8sQBNIpYO2VRCw7BmVRtJOkXUXhKema2x3O73Cl6XFupngt9xtu+o o6eCRhK8bglNgAdlEhKZDoqqxOBO6a301mnSit01bDTUjTGGOeqlqNm+pmA/3hbjy1ibn/EfcnKa 93FqmaqoJKmR4I6aM+VMiPEQzykDYUIJ/lHHH9QHGt4Byl47e3s/4srXtfWU6HX7K3ZPEbpT/YCt moOounq9zTSyJFT3KKEOmC2CwY4bbnJGOdx415/9eeENFeLBcDT32g6nSkm8wS0D+bFGfKJ/GGKl s5G0ElVjU5HmBR1H/CKCOnhiWlowhbyVHyUWGB/pwqjjbu/TP11H+q7PRwWm6Q0VFS0FPTZl2Ukf lozvtGSuSM+gd9ZsYC3U++adh8rzdriC1eA3mSJvhVQR2wBj8/311T8NfwEdMdedOp1D1RVVS0sj yRw2+kURFtuAJGkOeM7/AEgD257jW8NukjnERiVtm2Mke5VQpOf012j4M0Atnh5YafADmkWdhnnM hZ+R+vf89Iw9PJzLbJ/rbYVZW/4CfBi3QzBumJK+WRSokrK6dtue2ArqOP3++uIus/BOi6P8R7xR UtIfkqS5VMFNCSWfyd7BAS3f0beT316x64r8e7HDReLF2ihpwvnMKhFCjBZoULH9X3ZP30eIaAAQ EmFxc6nFc2VtppwYabymghRFQ5YEsRnHGnXwuMUFPXneruX9SvhnwDxgew+/20q6yskkFfV1DCOK KJhFgygncE3NgfYEfluH11t4UwzChr2+VlnWRgRt9QXauTlf1PPGMazg2nlTmjpkaqBWEbXG/hMj Pv8An9c6zNSjdIJlJUx7dhwVYfcHg/lqFXXpePqLr6gikrKykDQJAY6ardAF/mkZx3JPufrqRXPp Sfo6/QwRXaur6KaCZ/JqKkzLHhodn4uQcMRjPv8Arpr4XMaJDsUlsgcSzsRbz3XpynnnttdHBG34 JqhGkSny3dhnmLnv/Rj1fy+Yp7bbLD1bSyzVIWC8eZvZWI9a7VABHAHA7ADHGdxyzVr1TRXKrs8t LZaiWOvkZPlwH2MMMpbn/wBm7jtpi6fsHX/QdYJagSVVshxvjDqxgG3nYBnCKTggcYBwOBhcfD5Z v92HodxIF+qOTGMib0Mg77q/n9lYtfbzRVMkE0D0rwjl2XBKkntk8/nyB/kliTz38sgxYAIRmPP5 51N7T1FS9YW6KK5ReWjRh6avIUEhh3Q85GcZBH0IzwdMl56YnsdU8lTJ5kU7ZhqogSj/AE/JsD8P /LOs7JA8d6YWlu6anBG2GEho+AF3AA8/XWJqalmZGbczbgoXf3P0++jYRGsaZA8oMCd49+3AxpQs kcsS7Fdp2BGEQlic/wDLTVW6KqOnqSujZ5YF3NH6Dx9exHscHVH+K/hJ07c7NU1KwwR1zMscQiID FmbG4H7c/tq/Umc0K+XGwJI4Hf655+2dUXc0a4Xqqrn3FI6qeXbIxQDaSQMc7Txoa7FOWqgXSXS3 iv4WrVLb77NcAiFZ6WqZGRlx6TICSWTJbCsCMBuOdTjrWt874ZrZX9YWSmuTw3xf4jCqeSoRpKrM ke3GzJ2429wfodRC8dS9Q2ysjrKNqVbY5jlYyuaiWYIuVwXHGNz5J+vbUxHVV16y+D/r+7VRRKgS iog2+srEk0BbOeCQGl4+4/LXHjfPiCOkII7tEkFozV2KrKGr6BsFxpqyXpQ2uTd5ySzOVMWckEgd ueQDngD76fOpfH2519FHS9PdV3Sz0UJCVEtPO1RIByCyru7EkcDGO+uXJrw1fQSTz1dRNXFiQJX4 A4AOSck9+NIaOumeonQSiM43knGDz2J9tbxw1pOZ7iSO3X6pbZXDQLvDwn8d16Ip7db5r8a22eaY orvNuyDuwqSgqOcEDdn+jPHfXRvXdkrvGqyUk9r6v6ht9bQoshtFnvj0dPWFSGByuCGBA2nIGRzg 8jz18PKWq6et8clWVa1PJ/MZayMwkDPEmeBgtwRzk8dtXV4afEDN0f1HJT1NUam1ybZElgZX8gZw 3JxkAckcnB+wxziXRPcxpJbzr7VsV1YMWHZWTDbYkX69oWn+xfQEt7mNwsXm3p5GSVup5Zamo8zO WDCodiGznPGc50+09FaLM3ydqpIKNmH/AOTWynVTg+5WMcDjucDjvq5vEnw7tHxCdMLdbTVwW/qn yF+XrBIWpqwbSVWbB7ZIAkHK8fiHpHBfU9f1P0Z1BeLBdYa6119uyZaSZi7q4Awzc8oRzuB2kEEZ GNYXcLkn6zJSR36r0DeNMw2j4AO8LpdenJpFwkewZ4V+cfsTrceHtTWo26SmiwMsZWKj+41zB0n4 zVMEM9FX3KlpJJRiOqngM6sScbScnaP+Ln9MasX4cfAm4eOb3m6T+ItV0l01aisU81AGmqZKljxF DGjAkbPUW9sqMHkhLeETsJzvAA50r/z8LzTYj6hSTxO6Ba0dC3e4i4Uc3y8ayItPMCxbeoUDjHcj VpeCtiuPWXwg3vp+hppqutp7iixQwQtLJIPmoXbCKCcj1kgDgA+w04eL3hf4Z+FXwo36isdzv1+v 9TXUsq1vUEsvmyzyTR+ZIsfCA7I2GWBYAkZ9Rza/w118tk8LrFU2pJHuNNYpqiMTIBHNMaiqqAAq tnaTUBf6SRngcY7WFw7Ym9GZM2a9R4V/a8ri8YZ+JtlazLkZt/8AJUnavhI8Ua2BZabpqZYnxg1M 8VORn3KSMrD8sadv/wBSzxOQEyWihBOchrjESfy5Ouja7xa6tvFOJIbvDRwyqGRqCmQBlI4OX3n3 B4OofcqmvrKdoq+5XG5q5xsqqt5NxPtgnj3P2GfprAYsMNsx8wPsvQ/vcUdw0ep+65i8R/h56i8P +n7peL5U2ehpbdA1RPGbnC0zBVLEJGDuZsDsBntqi+gnt3iV1DFabLK09dLv8uKSJo92xN7AFsAk KCcd9dSfETJcaTwt63pIKKnpY2tEzGvLAjy9gOxc8KWKyJjO44BAIyVqH4Eeg7fO11vlVSq9bbyE o3cgmEyeYjsDjklVxn2yRrQyCPoXP17tf6WGbiMzZmRadbuP57lip8B79T04lNGsikbtkbr5nbP+ 7JDZ+2M/bUd6f6In6ltkdwtdsrrlQyu6JLDQysHK/iwNueM/2P0Ou5mpAQcjv7EZ1q9D5xYMkcgf BYMo5/PWHKe0rpjFu7AuCepOkqmjqrVRG218EstQxETUckZxGhZgFKjs3l9vt9tL+l/DC/dWVz01 us1ZvTaXlrIjTxqGAI9T4ByCDhcnB7a65vNnjqPFPpNSApprVdajCEqRl6OLIK4I4dudTCGlYTRK tQ64YYD+sd/3/vrQ5tMaL92lDFEucQ0ewuVPCbwuoet7fV2m6y1EIpJ33tRMFJKsy4DEcDdg9snH tqYdO22DoDrBLY0Py9ivtO7wQyEui1Ef8uoh3MSWViNwY91kX6aV/D1JtrLzIAzAySuWVScHzTzg cnv/AH1K/Eboulq+lJaWzxxx1NJMa+iiicnbVIGYp7gCSMugU4A2pjjGN/SCOYXtQXyyHAv4jweU R/G2R7mf/uB09VIOlpkloZKNVKvQP8seSdy7Q0b8kn1IyHBJwcj20rvRqPl1paN9lbUECNi5XYik F3JHqwAQPTzl1GRnIiHR3WNNXrZrn5mYLlT/ACz5JIDqC6HPt/6qknvlNTKzzrWI9xwR83gxFlI2 w/8ApjBAIyPWQRwXI9hpGKj6KS+3Vel/T2PbxDAsdsW6Ednd5bd9Lj6weD95rOvOsumLDdqi32ky 1YFDDO4gqpYGQKsgZjy+WBY8cj2HFmeBl7k6SqKOzVLTm2VwKD5soXp6kOUIwGJUFhghgCu6PP4l JdfCLFR4s9bznaHW53Bcgckefj/QacuqOkqKLxAq7fVSrbrT1bEZKat/ClFdI14ZsDhZBtY++Szj lAdb2vEj+hk5heccZGtdxJh1jkc09mW69Bz7u8K28bRjLYHHsMfprXGM8e/1zjTVYLtLdLNSzTDZ VAGKoXIO2ZCUkXPvhlbnSiSZs53Af/Hcf764cgMbi07hfQoZGYiNsrNnCx5pW0gc/iY/l2/5aJkK 7T5jd+MFv9BpK9Qrj1K7ewy3/I6ws4XJGAPfaMnSrK0CkzdKdAt01XX68wXysqKarrfOW1jCx07O pBIJJLD8IA4xt9/aQLXvDJleCe+cEn89L7H0VfrzU1VfSWi41FHPSx+W8SzGKUo7EFdvobIfuf8A D31I6Dwm6vrULRdP1EYx/wCqY4j+zsNNMMr6IaT5FCZI27kKJJdZC3qhLj6g40elyQ+lkZBqcQeB PWM8ZY26KH/glqo8k/8AxJGjI/h36ymgMsz2elIBJheqc5/NxGQP/tOrGDxDtoyg/cRD+QUCe72+ nDGWqWMg8841rT9TWSpuZt9LcKSe5eV55pUmUy7M43Fc5xkjVJ9afEr4T9HXirtc1xl6mrKaUxTS 2GlNTS7gcHbNK8W8cd1Ug+xOtuj7/wCDXUVkhPSrS1t7nq3uNXRUcDpUx+pXKGJ+ZYwQOFDKAvtq jhJYwXStIA8EQmjdQa7VX2lRMpJBEYPuvJ/6a2gqJqSQSQTSQyA53xuVb9CDqJ0vXdolgeWSaa3R RYVv4hSyUir/AMIMqqD+QOnGhvtJdUPyNwpKof4oZVl/yOuYS4bp1A7Kb0viL1Dbs+Td6hwv9Ex8 4f8A6edOsfjRejGi1FDRVaAYPnxk/wBt2NV380VO0qXI9/f9h/row1isu3BjbHIIyRpzMZOw9V59 UswRndoUjlovDC/XKK4XHoyShqY33q1BUyKg+v8ALyE5+w1jprwy6Gt94lqrT1TNT0Uyuj0F2o1l 25zhVf0jaM8Bgx++o/HG9WvEilB/hOSf19tK4LZGB/u8k/T3/TWlnEJARmaDWu1fSlmfg43a2Qm1 fh66sor+1dYKuxXCj4SGqoq146pI888Ou1Tj6MT31a9toZelLbBFeV/hFroIfma6SmBkWqmP4SZA CScg8HHtj2AqW89e2PpWq+Ue4IlwUbjS0z7pkH1bH4R/n7ad/CfxOl626ymp6q/vT9LU9Ozv8wrf z/szNnaAOccfca6OExEbn6MomhuP6NdvcuZiImx7uSnqq5V9z608NOtKryaOyU99W2JDFJlYUmjY MHcYzkoufYEAc66ipJ2rQZAPKpB/uVUnLj/EfoPtrmnxr8Srf1N0YZKKWCnorBe6KRg345FSYB5F K8AFWJHvj9tdBW65NXXKSkgkaKOJVk3EYaVfbaPp7bv7a9PhS0uJDs11r2mz8lhkPVb6fP8AtKOq bxSWu2T/ADFR5BeNihByRgd8fTUa+Rt/ilY0Nw9DUoKxzxgZEhH41P2+nb66r74gOrBar3SwUzwL UeU0StuBy5Gdj8ZUkZxng6ojpPr65dHWGvoZJhVVnmN5VNE7NJGjdsDdj9Rzq8Xi24UjPsijiLqy 7rsyxfwqhtdup1rBcYREwWvqNrb9vBy2MZ/5ar/xE8S7LaJqmitsa11QVKSiCby8MRxgdm/vqpbR 4gTV3QtD08LnXWi6UJM1PVMFCTvz6JQwOT/b31UPXvUk1jqKmWscJLtZiFQ7mccgD2OT+XfXCxfH f9YjwvxH5eR/CfDha60mwVuv1xJfel54aGWokllgaGoo65NgQjj0nO327Y1Th6RpqvyRPdGS6GT+ rMhWPBLRspIwuQOR9NRyz+KV5uVPB8lbGM9Q5DSKu8KAO5Kk7Wz3DAae+l7nd6r5iS7LHSMMowQ7 2K/8DcgfkdeQnxGJPWlI0XahMXRdE26O6ldTWUVD0pXtHPHW1VJGDO0ckjA/0qUOM59s541UdDYa m8ilhlrpKKmlqkBNUJJBHzncJAOx+41N6PrKhpZYqmgomQNKY5WMYleWQDIDLnLA4PAweNFWSqvN sapuU9lFDHNOXiZ5fLaBskjYCcgcng544xrtYefNG0Smj3n50sksQshgvwCvHw8uFl8P0hWkuqPc pI9pmlYTRTAE4XaO32YHnU8tlqsfUnVdNdLbU/Izs29qygozDFNIc7lJLd/rkZP37a47ul/Woupu NK8LTqMCGFsCRMc5zwMfl9NOfSfjzdOjZ+fMqKJi2xlm2sTjjcRxkfbXaixuU5CwZOz39VgMYrQ6 /JXL479Y9Z0twqOmRFR3KjmkcebNCzBlIyu5TkggHuOM64skrrr0xfKo1EQSGZmSaP8ACSv9hj8x zrqjrfxmsPX9ttZaA2zqWKIA3B29GffcB3HvkZxzqpvHWltNustDVw3OK83OqI3RwjzIHUd5FkXk ODt9LcEZ7a1SlmJc5zHWKsWdu5Rurmtqipz0N1G3TvRtJSXWBplVjU0VTbq+qs9RRLKFEkfzdJUR TGOTyoC8RYozQxNt3IDqpep+uuqrx1XeKimoqK0UomSCnt1OkdPBSQRwxxwwwxo6qsaRJGqgDsvO TnWYLxJY5rG9/qp6uhriZnoJHU+Q6AbGIdWwv1Hv99RjqaKl6vvtZd4Yo6NKlgdlEUWJiAF3Bdow Tjnjvk++gY7OzKOSKSMMFHcrrW9eK3RNt6skqK6Jo6xJM09hoatRLvwuQkLlXHLBlVMgEHk426dJ Kzpe4T+aK25V7UbzOzW0tJLRSlCQVkRODkY2yL695DJuDLqZSw2+ot3U/UJttQz1M61UM8Nqp6kS IN3lsfPjKAIJSzHf3DbGC4BQ+LHjFeunKe2dL2qmtjvX21F6fo6dzFUVdWqoMPuVIIok3A8MQWCh MkFQs4XDgBwZbh9/+JluJpOa2aD+H2Wshjrw81UsK1c0zhRFJMgjnlJQJvLL+BQF/mEZJw2qt6mh 6i6WuFFTXajpUKVTeWsLUrSzxESkYh3M6guVIIA5IAGcDT94h/xO0U1Ct564utNPIyLWW2gpaeW3 mQqjyQs7eXIysDkHcCAx5JDHTJ4RtaaHr4TUvUFxran5Rw3z5FSa912kIpEMbKUCB1JzkxgDbgE5 5cBDMaAqr28By25b9/gmCTSif7Tp09aPEK89Z2y10NgntNsp4vOq628k0YkhxgupUAvglchAcbk3 bRjUH6n6NWfqeaoprlbOt2gHNdYJI6tYCWZgsztwrgksOeTgnJ1E/jD8cpLp1XcelaR56ultTwU5 it9VFFVRtvQ1DIMBvWjyQlBwcBjwMaP6wrb/AFL3S51Ngr7ZST1Ukxo6mpgMsAZ9yJIqyEbskDAJ II5xwdAzhzA3qOI3150ldI5mtp3oPCu+27pn5G42K7SLcpBBGtZEW+UeSQAGUSkxEbXxjaMA7SHI zrXqD4bK9uoaW+09Jbqa4U0tTMzJci1RUPI0syIkIiCpiWTdkgtjAwSADG6jxz696QtlNQ2K30V4 p5Z0Ga2Z2mSV+CDhlOziPBDgD1bgQRtQv4jdV0FjtFAK3qBruasTTV9CwZhhSfKRElJZA2wbTGFI 7DAVT0I8OI9ASVbZiNdFYPT/AIKdWUHT91oLv1JbGucsFc8NTWSy1Kq0saDyKjMZWXBjiIKIBmAg oTJqMdF+DfU1ttP8KudNZ7z/ABiVJEFP08bVTLIqPtCvJFAWYowx6c4Mvp4BZ/6Svtwu9RaaI0fU SV0X/ma6ntsdZb/mQCEAxUSKhz3OwgnBA9sTW6dYdNWux09tudzvtmjgIpKZlmq6R4HUsAiSFDuI LhQpZ/woeQNNNMN1uoZHnS1S3iH8KPWksVqtFL0t09cZpKkv5MN3f/y/8oKdzGoVmbcgJCqdozjO DqXeEPw/9V+G/UkVLW9M00EkFqNrjr7dWmWnZvn3mKKko87afMLGQ+k7kUZIBM66L6htdRLXJWdd 1FZLT1/kUkVbNSUnlCERyCPCRRh3V3ZjheMgMDgZmNz8Sa623a4W6p6rohFUwCaGjqEglZUdWyE2 hC6elgpOSSME8jLBIQQQSk3Yo0q56x8O+q/EHoero7ZDbLbVTzpBC1yNPUxL5SiFElEoOM4Cfgzg rjeWOaM6g8CFt3hxb7LXUt+oq6OxpSNXUVsFygX/AM8Khwhil2sxdjwOyDLFTlR0J1h4i1PRvT09 RA1NUXBJY/mq25Wc0rSByQzQywkOGA9IXB9sEjvDbj4011ZN81R0cnyk0aGptoO6mwUG9d0myQcE 7jtzuLEZGCVhhcAL2rVE6QZrrQqG9UWSc3JrTb6alu7yny4KSooqpmDwwJEkYWGIrxsYMqsQAM5+ lLdeS3VurrNPJe7TS1yW+COWKOWSn8hssV9JVcAcfhXI3EkAYOvQCyeINlE3W3Ud7uF26Ot9zulJ RR1dQ0Y+WBpaZYw7+sIWJ4c+kB1yd3Z/6+No6i6AMvU1hhjnoYENJUXy3xz1MJABZdzs26QrnDDK 7gd2NZxCI7edVHAPNVuuT+g7W9X4hSrV9QU7xpfYloFjlaYNItsmhkDKcNECI2bLAjMIG3hiLJfw UvNWldBbblQSxCUq88zzLLMzkSK3pjIP8t44+PZDj8RGrK6m6J6asTUN6ipKG1w/IGqqLtUBqmOc K3lqyxKwKZWokICKAfmMbT6hrFZZLt0pTvW1t0pa+Jq2GH5ehRsxkQozI4I3Z4/4uyDA51z8fJM0 9IGWABrei2MkY0ZE0dH9MXLp20x0l7qIoaiSclJ7bK/luQq+lmIDblWMnBH4SvcgALamkjme4bau 4yNGKNXfy0cSKSzBufbJf6ffSl69r5baWRYZ6NaKpcKIRysciyoAAW52sid8kb2GAG1FT1dsu4sv n3aNZI9orKiigmpSEGCqSE5DKXA2kNjkgcjLocfE3DiO6NXptr5dqQ5gMgd4fUd6ljyChlopmutX NSyOAZJqaEJCTG7B3ZSODtxk8DIPGM6mfRdVRy0nUFuqZIamoZklMYjIVow20g7u5BIz9Ny/Uagl NBWlfkhPHdop4mcx1NMFMqKuzcNqR8fziCDnv2+j/RU80XR10rmEVuqYLkaSVi4Yy0lSscbMGYty CyP93gI7HTpeIQYm443Wd9fCvqihhLCCRy+6k/TVjjhoLZGKaBK5oI0aRIQGMhUBjnGeTkE6vKg2 Wynq2kcpTUwChmYnCKgyT/f9tVl0jLHVdRULxpuiDF8RjOMD8vrtGdSPxVvH8H8K+r6iokamxaZl R2b1iWRGRRwcA7mUDB7++tuBHULjzKHGHUNUys16oeobZDcbZVxV1DOC0VRAwZHAOMgjvyDqrfFf pujqep6WqqKOGYzwbd7xBmDAn/mul3T3U9F4VfDzZrxcfTFQWanfyl4MkrIu2MfdnYD6DOTxnTN1 7fLhTeHvRPUF2oZXvFSaSkqaOLEe2WpCK3DdtrcYP1Ot2MiIY6tgfussHVlFeC5X8bvlKa71lFSA xQwmSXDf4pAMnP8A7UTH2xnknRPhAgp+j7zWxgvI8SW9VKkFDMxYkZ4OUhkGfvp18dbIa64NVzXK lo1MZdEqVkVV3Lu5ZUYZPJ5Y9xx30T0RQwUHhrbaH+I29pJqmatcpJI6yBVESEHZ9Vl4/wBdckOG QBbspslNENME60jr55FSljaI/wAtvWChJOB+mnK6yPd+rT5qlUgieEqR+Fy2CgAJxgD6/qdKYLPS 1NfHI1ZQuxdd8Ydt5XPOAygA8fXSqnpHqa56sNTu0jl2YVURznk9m786e7EOeBG7YIGw11gNSsUV HDR1tLLhEVJPMdnOc4UkLz9ThR9209T1jVNJUSSK3mFWLHIOTg599IvlZGZI0i81XYF8EMNoyRnB +oBx9hp2qbYZLdJH5S05kjKmRkwqEjAY/Yd9dPAOGQm1y8ZG7MBShlZaaixQWvyYzPT/ACcE0tFF GSYzIpm3IoIJP8wFlAycnbggq8t6Y6opjRrTXCOOts9SqsHPqUKcbW3DsDuGHHGcdiQCg6uYt1hc fIp5lgp2FPF5gP4I0WMEcc5CA59/7aaaJKyiF2rKOlkmSSlYTUyLnexdMtGOwc55U8NjPpOSeAWg jM06+911zvRGiknU3REtph+ct7PW2pju3jHm0/vhucYwM7v3+pYaZpaeWSSPsqMpO7P4lK4/QsO3 P7acOj+uqixlAgkmpCceU6ffBC5H5gqeQRj/AIdSaPpqivNpqbpYJPnJHRmeh4Hl5fcTGOOFXKhT 7Ack8lrXX1TulHQgnZV7LVNTQzOzGOGJTKxGSSAMn+w9tV9NTrSWO7VXmb6g0UtbPIqg+XJJA0hU cn8O7Gf8SnU76kr46K1Vp5kYIwkh5BOOCGH7jB1DvFtZ7N0v1hcI5y8Nba6q5QNjAeOWJ2XH3BJU +4IOm/ypVs0lcX2/qaLymt9JVPU0kG1hJJGkaghuXwPxfhBwcZzz211n4SpB1F8IPVkTyN5D2C5V THABCrLUuDj25h1wGzS0VRSPUU7RxugaMTDAccjI/Ig/trv/AOCmCj608MqnpWqlcrd7RVUC4HqW DzqmJ2I7ek1i+/II441b4Awgt7QkMNhw7lxZfOioBXwUttuNPcMpvknQkRpn23fhP07kk/TUday3 Cy15apppaXzIVeNpouWjf8LYI5DDJB7aOtNTWUFQYoE3Msf4GPHqxj89TXx3iWLxOrbOhMwtkFHa 42R+xhp41b2/xB9PZnaQ0m0AbpaW9H9U3W3U9VRUNQ1PO0G+F5ZGCLt7kAjB+mO37DTtdrg94Wmm raeCvqJCWj2TEShSMEswGCefce2q3jurPeKWr+XklDMII4owWAIwq4Hvroi1XGOo8BepqBJ6Z6mW /Q7q6OJdzoiMxBJ5ODyAeMY41gmjDHZq3RNaTYtJvDvx8uvgjeKOjnlqrhY3YM9LLs3wx52rhVJH cEkcE98c89YdedAdHfF30ZSVcM8NJf4afFBeIM4Kk58mYD8ce4Hg+pTkqByDwP13crevTsAo62Gu cqxklXmVnLFm3jtj6dhqa9O+IN18B/Gu90HTVRJcOmVqFlNMu4qIWVXDoW5BAbbn3GOchWCY2PDe kj0PMdv4K1RyW3o5dRyPZ/X0VZdfeDHUXhx1NcOnOpYEtVxhIKNIf5VTGc4kjfsyHBw31BBAIIDA orujDG1PVT0FwjOBU08hjZFIxjcuDnOf316T1tw6D+LTw8hoq2sjWujG6iucIHzFvn43AA4JHbdG 3B47HYw4h+IrwevHhV1jVWy6xzCjfEtsqZT5i1iYALq4UAtuySCAVyMgZGt0c/TeHMJEsBi15JP0 p4m9XdXdMVvT96vtfdbZT1cE0UdZK0jxvlwBuYk4wG412T8D/jfU9f8AXVf0LVQ04gsVsEdLUQxl WljDrEwf1YOMpyAO54OuIvCaJxZKiaYIYmq1jUgYJMauzk/U/wA5f0A1bX/h59ZTWr4j6SiwJIrz R1KyvtGVdQJcg/fyjkfkfYahijzkgbLj4aRzsbLrsGhWvYPj16Sp0jo79ZrrZq2NpIXRESoij2Oy gFlIYYAHGzVk9M/Ex4d9VUhraTqW2syny1gmqhTSKT7BZQh54y34R9eCTxt4m+G8UXjL4tS3e3vQ 01PVXqW2vIDGtTUiqIhEeSN3Dk8ZGEOdUJPZjbpBHUROJDHujaIBlL4yVJ7ZHY6yOwEDiQxxB9V6 QYmdjQ5zbHavUjx8IHgB15UoUleotMitOjkq5fao244xghQe+AOT31AvgwsotfSXURaR2D1caDfj PG8+3/u1yh4R9EpePDHrfqOW63GkNsrbXRxUMFQI4agVEriQSxn8QARSAOxGSNSlfiC6p8HaS1UX T70Tw1NOauakrqXeJHLsoO4EMOB2B0p2Fe2MxNNm/DsXKmxQdj4HOFCj9CF6GAFRkDt9dFs5GNcn 3X4xbr0D1XW9PdU2CGrnoWRKitslWxRiyK5CxyjPG7H4h21YvRHxVdHdX2a53Oaqls9HbGiWpkr4 mzH5jFYydqngkHnPHvjXNdFMzVzDXdr9F6Zssb9A7VTmWUy+NFMg5EPTMrAfeStjB/8A8Q1MYS4q IvSfxDtrm/qjrRuvPE+tPTtbM1qp7HBTT1EI2x1YaombaH4YICCDtwWKEdtSu19M1dPH8zU1tUWI BZXlIAA/4Rgaf0Jdl5Ggga7dN3w6MiUdZK7qgdCS7EDu+dWxWpRXSJ41nUy8bZacLJImCDwCrD2x gg8apvwNtT3G1xxDJCxgtxxydXxarAaOPdGpHtkAAnW84Tp324rx/wCnMR0fDQeZc8//AMiqVayt 0/fK2yxx1FDbb1GLpahUxGJopAwaSIqRwUdQ23HAKjj2vDo3pqs6ystJcIZ4qZJl/mRyTNIySA4d TkHkHI76YPEXpGr6g6Veemic3u0v/EKEAj1FR64/vvTcu3/EE+mpF8NF8hudxq7dFNFDb7jTrdqI zvtQPkLMgIHGDsbH311DhInAMl1A2XAjndwXjLmM0ixGo7A/n6/dKvDD4QxaOpr1cD1LLVG5VM1V IiUqxrCJZN2M7mzjkDgZx7Y1bN3+GjoRrG79QyVtfS0jitMstR5PlNGCdw8sKRgZ9ycEj31bVkti WyiVEcSM/rZx2Y4Hb7carvx56vTpuyxpIivTrHJVyq4ykroVWCE45G6V0bPbELA8HS54YImmYt29 he0wWGOIkGDiGkjtR2l2+/b6LmHrSSy2utLdHQxWZJKgTVdLWRTVc042bVV3efEZI2MQibh6QW7g rKahgrLXVXj5tKOz0yqZZpcFt5Xf5aDOGIHckrjuex1XNNSVt86hpKKkfzLjcpxEjSHAaR25Y49s nJx251MPE+80VBe6ToyinIoenl8oZwVqakofMc+xxuIx9d2vKFz5rkevuMv6b4bho4sBhW06rvk0 DTbx0A8TyUIj8WbLV9cUdhgmiqIbgrCiraWpFQrzKQGhkCDCOcjAywJZR3PPX3hl8PMFF8pdOplW epH8xbWQGjQ8FfMPZiPcDjPucapH4VfAnpCfq623CCx0itbJWuoZowzRVCjy0QN3wpkZlznGB3wC O4gMDGuzgMLFMOlIsDTXtHP+l8g4i+XDyuw7tCND+FgKAABwB7azjWdDXpFwkNci/wDiM+MNT0b4 UN0baZHiunU0UiVEsbbWio1H8wAg5BckJ913++Ndck415TfE747WHxg+Irqzom4rFb7PQVq289QC QJUQGkWTMUZY7AGmeZeQdxkXP4RqjtadEBmsrguts0lghguFO7SwSIDKp/oJxx+mRpTbOqavp+50 1ztdbJb6+mcPDU08hV0b6qR+33Bxq6/hn8NaTxj8XH6V6hrJWsltqJTW0lLGNxhjXjBHJUuADtyc c8DJFr+K3iT4I9BXuzWa09PdL1fT7TGK6xU+2vrBuRsM5jxFtRguVilP1HuDYhzA5irzgHTkpx4J eNMfjf0eZ6lkS7UG2O50aQARqTnbKpIb0vtY912kEfQmb0VFZqYMaJaeMVDFfMoQDLIfcBkOSftv b8tc0+E3h9N0X4oU3V3TVZbpei69FgqaKillLrTuADIqyoxwHAkCltwAKg51f978Z/Dnw2iaOOsj mrJTu+RtdOXqZWJ7vnGCf+Ig68LxDAvgnLY2ktO1bLuQTB0Yc87KS2q3V1qgMNEJKSGQ7jNcqmSr mz7BIycL/b8jqRpsoreZq+o2xRKWkqakrGvHcnGAP21Q9y+I263KZorXZhaKd0YpVz4llAHc/wCE EfTB1Hq3qE3yC41Qvc1xvNPSu0iVBLRyoQAVA7L34K65v7d5cM/5RjEMsNZqrc6r+IDpTpmF1ona 7VI4CUw2RE8f1kdvyB1z74jfEr1f1XXQ2yz3an6fpJ2MMsUB28njBlxv5+q476aOooEt1PQ081R/ DamGPKTQN5scpznErfrgfrnVS3a0Vl/vNfU08SpFAyiVvMVQrdhgD7/TXbw2DhYMxPmVy5sXI+22 rC6bqH6NpLn/AByLzK6Kba0UUjMxC4Y+rnIOffnT9Q+MFzr54apa4UNlMn82KCQr6SQCgI7k9v19 tVewv8RW8XmKZ0iZKSUsQFwOBk+5+/vpTaej+t/FO81VFY7DLSUlKGch8QRMMEgAdiTjgj99a4cN G9znyOHeQfkEiON87ssYJ8FdvUXxPW2CiuVn6ft9WlmrUVJJJpo1qWKkFSQu4jBz79sfXGun/CD/ AMQPo7rvq60pe6OXpWoeE0rzyVCzU0jcbAZABtJ5PI/XXmZ4ndJ9SeF12jpL9RfIzzRrNEGlDBkA GGBHfn2POoZ/tFOWEgdI8ZJkRiDyeCfqfyA7c9869FHHGxv+rQIJYy3qPFEf0vUbxH68gqvGq4Cl lqrnTxuZ9s0ILKNqgENxwPbPsNM/U/UklfV07yRiWmSRCSgVC4GcY+o57ZHbVD+Afixcr34YzKaa sr6+3S/KpUQHcXQjcu845ABxyewGrOsNbUtL83cN1A8qEH5WVSY/p6GyPodeK4iZBI4O7ffvVbYS 0jRSunropmPlSedDIPN2N+JW/wAKN3H65/PUVvlwuc8dVb7VSx1N0j//ACc15BMi9yre35HW9Vcq u20vnzVsE0MhJhnVSqyS/wCEsO37aqi7+IT27qrZFH/55gUnnklPlg4/4fp9ca82yF87y4an34LQ +QNAadE82O4npm4VtfFQXShuE5HzETyGJIpF/EvqPqyc4+2p10zb7pc7yt4uU1NQW2ow8dM7Eyh/ b7bexxnUIoK6LrtaI1HUlrerpWHn0VSyyDywc+kYB3fnpLcfEpzfYKS1SUkXlkqTBF5aOM4xg5B0 csUkpIYKdWvd6qmPbGA52wKsaGrrZeo5knv1DbaRZtu5VQySAdiox3xxqQVFxpnmdY3juUco9FJH GZGYD/GGJA59xzquemFkLzVt8r4KRWY7aOIDzGGRgg9vf21NLN4myWcU0tHd4qGsMjPBTySI0px2 8zcNoB+mc6jICXgD5AJjZyb+5P8AaoS/1MlfXmN/MoKdZi0MLSbi3PbgZGOfc6db3cbheum5zBBJ 8nEwghljjO1T/i3j/Uanni/4lXLr2op5btQdL0NZHMrtNbrcKe4VA9keRpNjA8dx37Y1U9f1LWw3 yqNPRCjiqAWkp0lTaCOMHnGfyzr15DQAItQsXRvJNhXD07LT1HhLRdO3S4RJVx1BrKOtbZs5DEpv 4IOeMA5+3Gon4vdN2y3xwXKhrHanZE3mOrWoxJgcqeCV7dwCDqtbd1dX26GUPFLGsrOKeQqHTPuC vOe/tpNduoKm5dO1nnwN5sJ9IiXEY4HqGO/761mUlmQjuUigIdasW20dmFjqKvqWlmqxULHDDcmG JIPVkhie25QcEqdVRfeqobfeKyHp0SyWdZD8u85UuV+pIAH9u2NMVx+JTq1OnJ+lTBSPRy4WWdYS ZnH9IZi2OPbgajtF4lXuWJlhpaRFiYxkbMZI7k899bOhpjRWyyOe+yvWbrW2p4F9CLV2u92u8Weh p/JqOkL3O8lPXv8Ai2wyEM6yek4BzECc7EzkUl4T9e2V6uS63GzX3p+krKkVFlsKSSQxx+oJUmnk 9Lv/AFkqrBQSfQMgiwzZbklSomrKVy6/hSn2jBC5GCxweM8/XggaxW9G1FzglgrBRyg+tFalbZGw ztk9LBtwOSCCCP3OvDO4+XG3N+af0hBJAVD9S+Jl36l6trJK+9TW2yXCqV3+atlPcXSJGKp/NEi7 9o3LkDdjdjJJzEuq77WwtT2u7Us1FI0HziT9HVMsL1EZGUaNp/NLx7Q5LoAvHfg66ej6BZDFHG4V Eg8ldlGsZcZLBickjGFOFK5JOc4Gl9u6fqrbaFoflqGsolkmAd4B8wIZBkrvxtALsCwC/wBK8g5Z tbOORVRGo7/6R9INqTd1H4UU/iP0rJLfBBcqiGGGlNbW1M1JUvIiKVLwslNFPKC+5ZGyCFVWQ4BN deKXQ9+qrRUT3frqop5Z6qJaRZrf5SV8zPu9FQnm04bA3iMbi/4NqEgi8BNcaekFDbKqotdC3DCO VTLKMDh32EY9IA2jcFAAZfdkv/SsXU9PR0V0gjr7XDmYUdY5qDLUsSr1DswBLbNqj8W0DjGSdMdx 6BxOp8NN+5HcZBtuviubLd0jdbxHR3qnkmht6M5jmqa6kgpJjgoxDSFN4XdjhsA/caxPS3zp5oKi 53awtMC6pFbnjqhjGVLeVUvt7c5IHJAzg6vKi8F+mbNVG4Wuwvbq2VXT5q1TtCxU84DJIvB44+3b GmweEZonTyLVSTJLKDNNU0iJUIMKW/mU5iZgMsMuJWJU+nGCzY+Owu309FOjYf8AtqrovFu/tNLi ttFNVyRCjlaKCSoM0eQ3csrDOSCPoTydM0/ipK0j0twr6O7PcncIIyYjIQBkNGdyn8PdmHC8Anvd d28FrCGgeDpSjncqZJG85huJJKqWMT5z6gM4HfPJ42t3hXQWiaB6boLp2oQCLchXy5WB3ZG8wADG AT6T/fU/zcTiNPmEHRdiqJ7pfqG2Ggfoe4ChnhHy7PAr04jXPlweY7HahKIMkYyo57gi0DpiyWWk pmsFLNV7YqeSWookd6mQRne6kM2A2GPOPb3xrqua9dQVNmaavuF0UrtWSipp5KhmyuGXaDlxjHBG BnnvkwK/eGXStzPlVPTk1YxAXz6ehNLLGQDkqT5ecjIyAeCcZB5pvHYzu3TxH0tUYXWqFPSvTFbd pa+hjaKKGUM0HyqGNJwoDLseM7l+xBX1EjudHVFmvZe22XpJUqbvcq5KeGlq49wKuGaTaqbMYxu7 hVAPYDInPUfgD0ff6d1PTfVsjbJqeAs6wpTvJj1xgktuX04PK8Hg6k3h94RL4OV9Nd7JUQxVNvpZ KWCpnUzSL5ijzJD5MSys+BtDdh6s++NzeL4YtsGj2afYlQQkjrHRV9buuOtelKe7UXUV3tMFgmta 1lA9eonq62alVYTMMTKUlZolYAs7IYl9Pct0F4b9Wyllrqt79VR1jN5QW6xNGF8x5Dx8uq5YAnJc kjaS2VBFTR9GV3U1mo6qu6pe3xQtM1vgihiFRShmYu0bOrOu8+ojdnlCSCOEy9GUd8goaefqFbis KSL8zcYJ46mRip2s0nmqP+LBAJDYABOdZ38Ri0GfUb0Cfsn20XQ9+StCz/OX/rGx11t6wKWu/n5q igrEFZTLPHI88kckUbCGHb5UXEeDlMlizNmbrY73U+KUsitHaIIaRJaiwyQ7KC7tvmUSCeNM5RHX LALhtpZMEYp6gt9T0jarJD0o7WWcVU3kVMtLGoMsqS4Us0fmcepssWHq4xnGpxS9U9eUFbRSXpUu CwxNA0FlljimqZWYl55zMqRsQETCqCMu30048Rwj2AOfob0PPklaClIanqm8XKl6ea3dJtHbqzK1 MCRiavhlL7ZdhBBKRs6pkr/6WTx6tOydM0lwoFrKGV7jidogjUYLrjJYjO7jnkd+c4Oc6iFu6lu7 Sz1dZRJSVda+J1nRZG8qOQtSqzxuAGRXYEBD/T6vTp/W99SSw0dfQ0j1tRE0iCBKx/LkhJyWKtiN XUj8T49Loc4GsbocDjNG8tBR1HkD9UbDmFA7JVP0XLvWrjtc8RjypaJGR5NwAPckHOAOFJ47d9IY aBRURfMfM7Yotg3qrGOLIJUgAMqkrtwVJ9Y2q+TiIUXilc/mb2bfNWSLLULcK6tngMUdLEkQVUpg yLukwE2h1G/1EBdu7W0fj1T19NNNVWm9U4SfazTUchdmON3mrtGWHBLKMbSOPfWN+AbAA6N2cjkS APl+U1ji74TQ8Qrz8Ib7W3TreSgiqaae3UMGZFMZSYNtwsjb/U28MDwABjGT3L78UNQaHwO6hI5a f5aAffdPGNNHgetHcOqLncKd45ylqpF82CTepWV3dVztXkbSTx/UBzjRfxjXNqHw2tkKPsea6RNw eSI45HH5+pU/fXuOGB4hYZRqTZHmsGJP+yistRR+KHiTaelYHWTpToVIJ65l5FRXhdsUXbsgDbsH uzKRqY/EBQ1tT4aVctspRV19JVUtVDGylsFKiMlsDk7V3H9NbeAPTFD074Y2mWkqzcZron8Tq69i S1TPKAzuSeSecc88c86lfWtoa/dIXq3JEsz1VFNCsbnCsWQgA/bJ10sUS4Fg5X68z75Us4dlcO5c QX7qzqq8rPHfbZ0/eI5QYnarplRJgezCQhD2Bwcgc6bbvR826CPp+JqKgtqPAtJBO8Ku/wDMMIZX IfDyEEg98kntq1zPLN6mlyp7FlGSDnnI9/7aJeHfWzODBh5GkO1e5LZPI/M/fXzM8XcBeQepXVLi NGj7qq+ip0h6jlrT035FVb4pJNoedCHYbEGJWK7vUxHb8GecaYbxb4LQCZYb7Z6Z8COTzAVwRxhi oU4JUZB5/XVyVloxJDOpjeSN2Yo8xUcqQe6n69v+WlcVLAsLRGlEBkARpaYqgK44V1HpZftga0M4 22wSz0KUSS0AjXyVKUT0trrrVRR3KvapkoY2kqq+GF/MLO0glJR8/hYKAR2UcDOdSzp6/Rm60i1F 9oJqeN0llpko5DNKgJZ0wGzgqj5O08H6afpukLbdYVe423ddAGQytSRxp5YKqijy24O1V4wR6O/b MjssM/TdBJJR1NRQ26ncSzfJRIZnKjOEVgdxIXHbJHGQNbP8rGHBjCbPZVaoxlLqc2/fiqvrVHUl mjoFv8nzdNiKmeDcYHZjkRsrf1AcKeMgkHsoEeounxaorhi5xXQrCEdYq9EMcnmJyqbCV4Lfi5/E O54tKtuMPXsHzNRC1I8crqGq6Xy5ztY4bD7sKe47d8kDtoqTpGkmFTNVUtJMlS4EzSUyYmY5b1lV BJyA2Sfz50scUia7I9p07K+tqhK15OXfw/6qttNHUVNWIY2+WLvtmFJcPXKSMDJYbcjaBuwOFxg8 FJr0vX11lSG5Wh6qrVpdvmyOsjSYBLB0UA+nH4hkgnBDDG2XdOdF2Hp2skrxabWWKr5DRUcMhXGT lVYek/cgfbSxaC23Zp5rrRUFTcpFdXp38t4SrMAGJZFKyGJQodB6WDnDA4LRj4JNjXjp+UwAOGpS W+WKz+LNrqBHIlrvygJK8gLLKMDlwrDcSOzg8gg8jVQ+IvS0R8Mqrpu4TVdreTzqTNfRnEakIZRF saTjbtcEEqd3GSdWB1LDP59OnSHRoipoJGR657tFHWQAHIQRM5RlG45UkBuGRgCGLrUVYvUNNa+q Vqaabb5kM0VSVkKjg+Uyk7jhSGU55Zf+FhtixDZxlunJY/13WoXAniJ4I9O22+dPMepunaCLZ5kU bUtdUmrC4OXCUwAHbPb8R1098Mtus3T3iPZrTZZqGanp7XXwxR0UNREAzSUMpJ89Qcl1P/3DjVpJ 0baOmrnNba223C5xSl56SvadaxcZG6JWYKV2A52k5wTjOCdb9LQUMHWkVZTWryKmhiFGjVDiOWCJ h55WKNAVO87WLMx7jHbGsrceemEL2kV29/cjyx5HOaffqvOKr8NKey9U3aihlo5Kqnu5gWB6jy2V FkwyuJUUNgjGB3OeONOvXHTF26i8QOoqyjsslTTLc62XzkYYm3TELzk9hyDx299dodceCvSjdd3q 6zdLXSesa4y14niqIWWV3k88EKZEYDLfhJxp9unhn4avdKKW2eGMl7lqqQpXvU0EkrkPkmQAGQmX cW9fcYAHGtQ4hGZHAmiDWv2pJaIw0UuZOjPAfpuwVEcFQsVfCkkTyN8tKzuGZwUGHAI2qrkg45x9 czXr3pxX8MaUtSRUBqKh5I6ZgI2dC7AMFXgAIgUduGHc6sy3+Elj6Uhpo5Xu9pSGJBJBUKYpQvO5 njlIYjAADkf0tjgac7H0/wCH3UfU9RWXRamDpuFVFMKWWQs7xknYwQsRvBTjjsf8WsbZXPJcSa70 YxOGbcQkGbssLkvr7wlg6dqaKae1Vlvs01J5cElUhEVVIIuCrYG4bWPIyMqPfu/QeHdv6w6/vl1q 6upiobVa0kFIyqshWOkg24L5zknByCcAY5Ous+p+uU6i+VuNw6Xrr9Z0SNaPpl3p/NoXBYM5MqFQ MBMAHcPV+kO6x6L6b8QBdZ7L1F/DL3XE28x0M9S1NSIH3M8o/CZFC7PSdnI4408zhzTUg9/lF1Vz 3aegKjw3rbRdOloLvbp6q1UtbW0Tr5iySyyeUfOBwV4BYEdtx9iRrpUXbpLx5sdb0D1tFFNUpK8a ncEnimXcqTwtz5blQWGfxK3IZTzC6vo6puPUtPbrJeUjuFTSQTTJSVUrrbYAQd0ityHJIxCcZJ9W AMGz6Hwwt1ptC22ktdRPvmapapTLVBqG/FUPIeTIf8XPBxjHGgY6QkOGrvt3/ZaWtbkp23vZcxeJ PgA3hH1D0xZKWBp7NcKwOlxaIJBLLIyAoRztIUL6WJOMnLDnVr9JzQ9JdTdOSeVT0Uf8QhgSOniW Ib5WCABUGOcnPbIH051b1tuM9NTt091fbZKqhmlVIqqpiKJOVAdXU5ysinByMHKkr2Ooj1b8Pt5r fEPpO72+uSSwWWsW5vI8mDIVljwHVVJL+X5oGAF+47a2D/aNAbG4WPC4dmHklkzWJKPoKpVX8Sdu pKfxlv1VAgjW6Q0VTHKOS+aaNScn2Lq5/X76qu99K2rqWniaWNHqeyVJXOBkHaQSN68HKn9CDgiR f+IilXQeLfhL1DFWz09oryKd6cNlJHgqFfzsg4YMlUoH0Cn66bIpadHiQ7gOWQFcBu+M/fI/trNi YzHJ0gO+q7eFlE0XRuHw0NVG7LYk6X8C+orazQivqesKBZYI3JdESJ3R+TyjeracexBOQcQHrToO t6hngraaRI/lLZAFjkON6nex2n6j/UatLru2QSx0N1TdsjkWKXawUBG3LG5B4JR37nsrvqV9I9E3 W4+H8U0FBUl6B1poj8gJlnT1q5D4ycE4OMgY/Mad+6DIw873S8xicJl4oyx1cpr1/tUD459OSSeJ XU1dG4qJquv2LCY2TbgIAGJAHvjg+x1cvw9+BVwMd2q77bDS0VY1PsomDKZGhcush+27GByTyTgY zb0XhbV9X9S1k3U9FIlDHc2qoYag+souDCo2ngE+s/bV42WwRUMUKRwpCMYSJBgKPbA9vy1fTOmA jZuup0LGOzlVF0H0WkPW/XNc8CCKGehoI41HAaOmE7sfvmqxnUnu1M8Fuqp9m2NIXfCjuAp76cvB +gNwsfUtydhMt06kulQjAf8AppUNTpz7jbAuMe2s+LVN/B+grxL58lLHFTFWkj5f/wBo7/iwE+vr z31p6E1Q2CQZRRcVX3wzUrS2+VBGX200BJGP8Tf9/prpKlthEQyM5441yP4CtdK/ruwUFrqnpITQ NPODnYQkij1ISM8bh7HBIBG7OuzoxJExURlwOwBGSPsPprq4doLV4j9OuMmBawci6/8A7Epvltuy naRPQ47Huc+2qR6Tp7p0t4hdW2iw09J87Txi7WlZJNhhaTO+FV27cZDKASAAV4OBjpOCjEjAN2OD j9dc8dd2Cu8O+oKrxPuELWelp6qChnppKoz7oJpivmk5PJkeI47BVIwNXKC2iEv9R4Z2JwdRNuRv WHcW6+p2HfS7Y6T6mtvUVqppKCdCfISRqYsPNhVshQy9xyrDn3U/TXIPxS9arffEO5W2mnDU9AIK dzGQQWjVnPI/4pyrD6xD310h4SWODpixXX5MB2rZ3uHy6yZ8tpACUCn8OXEj+wJcnuxx589ZWC/e HVFQw9WWeTp6vq6aSsliqKmKTc7SO8z7kYgZdyQDgjKj21yeIPcYQ0Dc6+S+r/oANnmbiMRQeGWB 2uIH0Fq1PAFY6e53rrCqgNRTdN256iNWYgtPIpCgH/2iQf8AzXVUXSaepvwrJJTNU1FQ29yD6pGb LN+rZ/fU2ut3g6N+GijpYyzXHqq4efJGUyTTxYwMjsp8tDz7yHVXwXOK5RLNENhXaoRT2Axka5Dw xsbQT3r6bh8XeJmmJFE5R4D8kld1fB3awnSV7ujo6y1FatMC34WWNAcr+sjD/wCP210HqvfACziy +DfScONplolqiMY5mJlP/wC/qwtenwrOjha33rqvinFMR+7x003a4+mw+SGhoaGta5aR3e5QWa11 lwqpBFS0kLzyu3ZUVSzE/kAdfP8A+Lfh74hdK3E9cXOimktHUs5uaXSmxKA0zGQCTHMbndkBsZzw Tg49rvi6vidPfDL4l1TyiHfYqqlRz7PMhiX/APSca8V18YOuL14fjw/juslVBNIIGmkrRE704UBa YyyEKkXpAIbOQqqDjjVEGlojoNJKiPT/AIjQ0PifUVF3o4Kq2VlHFQ1VJBHJsqFSJAjMiyxGRi0a scuoZjntxrfrjxHofEOpp0tdHFYKWFzkTCJZJkAbA2xRxxxjBI2qvJYli3fTv1f0Aw6Rt9onrOmJ Lwtcaxr5/HaZUooHjTNKkaO0jqrhjwpwd20HcSZR/wDQ3p66WnpC9QTVFxs1e8lNUpbaiMGWuTf5 qedOIfKR0QOCVPLsBnAyeYgVdJYBc7QLpL4Desuj774V3W49W0FFLc6KveF/OBdmooqVpI0CsSoJ dcEqBuAwdUDfY+oHrnu3UNTDPS3VWqaCsQxYNOXLIFVCfL2MWXYQMDgcAaRX+32zpPw+vV16KE9h tN1qrRtpKqtM70s4StFRTyOBuz/LU8js47AjSayQ0986fgg6bjp6WGSoQMzgtIhMQUhsnOQxf68D jjXOnaaq9F0Yg18LmEa6G+5Odk6hNzkRGrJJI4TvaPB2sRngn76mVlulv6at9xuCUK0VdMqwsKjc zS+osGQYxkDj6EaHS/gh1jIxqqizRXCjiTPqkjjeQAdvxKcHHuPbTFX9YdUWmp/hMVuKPV4W3boz KwYnARSeTzwDnXnXtLnERVXPVCInwm+SVdVXK03e0QyJampZxB5LRruXzSf6yv1786qO42iWit9T PHUtTVCyZWkKn+Yowc7u2ftq2Ll0/wCIFAxpLj0PNSVoUlalI2YMWGdoySvPJ41AR0N1fNLDcZrD dHt0k2VmjpWeIP74IGM5H9tbYS4DLY9Vk6N/YkXR1ddOoqodPRxAGskDl6sthMY/c41b1k8WKGw3 iWjm6nttFPGxjSOZ2CenK+s9gePftqDUfRnVdynF5o7ZVywToKp65qd0VDnaAhA57dhrPij0103a umbbW3m1V8/UVZOUeJaWWITqMesTkABgO4IY8rwO+lSRsmcGuFeC9BwbETYN8jmAajn3dnqmPxvo eo/EUy35q6ku0VOSq/KzibC8cAgn6aq6k6W/hccn8UgLmanMqMpOKc98nB7nkcgj7HV4VXjh0lD0 dS9HWDpqos1uijJnMsv86SfjdI5xknjgHsONQyCtp7vD8squI3O1iT+NPodb4nvZEG1QC2YmOGbE dKSHOO/MX5qReAPUFf014a3WNI6dVvFWohepwnqiAIKNjjuRqZWDxUqKarmo6y3ua8SAPPHtPpHf ceOfp7ajHUvTMNt6F6QobdI1XBSoQu9N6vM5LyJwcFlJIxwR+urJ6Y6Mt1da7fM9FdKe/wAfq80V EPlyjbkEgE5H2PPGpNh2y5nu5ry0YIcG80k6n8SYoIaNLWzUMcj4nknkLK+exK9gM/TUB6s60rqC 9vVQ01Gkkn/80kW6Q7hyRuzqwfEbpG03KSnpqS5UqxRp8xtjYxsWGf6jwO51VPUMNtpqZ5o6udrh DlVZsYcY9/rj6jXDw4hJoN+SOVr2vIKZ7N4k1dNU1xliCGUbHdEydp78+xOkkF+pqe8IbXuNNEAV fc25vc5B9/8AlpvtlOlXKlIlXU1RJ3bEQ4LZ+nfGnCWljSgqpykMFejjy0RSSy9jz/oddno4waA3 WbKXaK++j7ta77Y5rtceqrTSywxei0TtM079sMuY+Tz2DaknQsHhzfIjU3TxDkgnmhc1FPBTCOaO QE8JuUh1wM/U5/QNfhp0vYLh4XUr18EUd5WoQRVMkzxSzQnlkK7iOOeeNUZZoHqa28ugK08LyJHN 5gD434BPOc8jSoIom2Q3bxWvoXNDSTuup7D0h4VdUSVFLTdR3atuEUiBah6ZnBHG7aDDkY51LbB8 O3SVTV1kq9RVSrEFamk2xozgk5Zsx57c6prwm6ZpYbbbJpJ7h83UvuWUyuceraSrBgVGPvq6+nKZ 2q7tAK26TmhIRUevnMZHPqxu47aN87R/EAe+9b2Q0BbvfopF0z4KdEwdQ22oN7nucp3CWColQxhW UguoRFI5A99Vd1j0D0x074n223vcxJapEc1Txs0qoP6QhyT9QQxyManIpY+naz5hDURmoRVdIKhl 7Y9auT76r3qay1gvJlUFlUM4UPveQE937/v99cmTGtdmYANaoqAZSQCSqS6p6O6a/wBoXiianMT1 JDTTTFEEQbAyd3uv6jWLt0H05aq+VIunTUU0h8yCaKvkZZE7bgQD3IOmnq+pt8VzrpamxyjI3pHU OUiHtnHBP10Xb65qOkj2UYEUoEkaRguqAjGAeMcg8a7kExydcX6f2kuja92mi9JZJCSqlB5Z4L5/ DydwCgE8g/3P0wQzKcN/L3hslo2IwM5Hccnn6/XGliwJJMWlZk3D1Rspxz2wftnvnHPOthEImikO CrjcoJBUqfbv78ZGM+/vr43aWR2pFHSxwyCbJO5AdhYkSclgO/bP/TjjRnmCOclI/JTlx+I/TAJP OODwSe2ffSlXAZipDsxJZuxY5ye/5jk/6aJNLAkwkiSNXRzveMbSDjH9wf3A4zqF5dodkNXrSBG0 K427wNoYngDbxnnn255762jlcVCh5QN+SJY02qRg4BBIwee2exP0538mHywFjUZxyvZeO/1zwef7 DOtl3QozTRIj7s42ghSc4/vnn9vc6oOAPar0SKQTU8ErLTipl2giNHxvI4Ygk4z35+me3shoK+rl k8+q6flpMStFvjlWUbQmA6gdgdxXkZ44znh9qMOCxLKWO5S47DHb7H7e/wBu2t/LctJvTzMjgBWA XGDjGPbH3/bRNkygirtG002knQ+YkihWYc7iO4IzknI57e/5a1+a8vDIruDllXKg5APYAjPYj8j7 d9HNDCwy6lMkKzq5zyRzj8sDnnlhnvrHlw1S5TnZ6zwBgn3OP/d/10G2qCtdEUs61cbKiFNoIVaj 8RGePf3H3+g/PIopZpCCNvrPoAyCBjIxnsc6MMCCUOu45HZGOSozyB+Xtx20fJlXJxIzBmAJA5Aw wzj9v8u+NC42bCtwJNpE0LBzKCu8cE47qWOP8/751lKUZRlkO5jn0jIGTx3z9wDo4szvOGRPJOxl HAKnLDk8jueBx9zxrKs8Uyb0aMSNxuVWCL3559ueDgce/sIu6VVSxLTb8bv5gP4sqPt/buPf8tJh Rw4DiNVZskugGQc9844/6d++lT1MU07wKjtIpwU2bQ3HdSe/GP8AsaUpU7WYSbFcDJUqGPP0/Lnv +WivLoj3TVDa4/MGYI9md5VIVBJwMHtk5x9+w0ZHbackB6eIgr5bfy1z7ZGPbHGnKCFTITFGXIwT uAKgAj1MSMKAT3PHcZ1sJo4IUeGPzHOP5pAABxk7VPPvwWAP0CkA6a2yMztAhy3okYs0MEaNUIsM MnqCRplpAccjg44x6sfkGwQN46Tzy7RRrRwsPUyRHDnaQcju7YZxyezMMgaepel6q3rSVVc8kEFV H8z5gk3OFPJJXd3OCcn278naUdWpNQI4pMKUykciYMYGckgbhnAycZJHOt7o5YR1mlvdzPjzr33o fApK6GoUbYQiAuUXOTz3JPck5GfyHAwAE1ZQx1CGNkmXCbd0ExTA7ELtPf2z34050lA9bF/KdZFL A75MLJtOc+nOD/Sfy5JAydZqbPX0MKVXyFWx24DRUsj5Pc7dq89ieO+dI6KYgSEGjzV0fNWX4H28 WqwXGeHdJJPXxxsJ5Wc7fTnk55Acn9PbuGr4j7ZF1R1Z4YdPTwCpgrrq8k8TcBokCeZzn/C5/vqe +Fdqkt3S9IKmMpNLLJMUcepcnAPP2A/fUZ6+ZLl8QPhtSIwMtBT19XKnvtkQIp/eNv8AvGftHCGG PDQh24APytYXm3pi+Gi41XSVy6o8NbrJmex1kktA8mFeandt27aBj+pH4/8Azv73zIMo3OOO+qB8 d+nbt0x4k9J+IPTturrjUQuKSvgoYDMzRjOPSoJ9SNKpJ4yI+xxm/IZVqYFkAYK6hgHUqcEe4PIP 2Oug85gHevvvSz2rl662v+F3KvpEMsMNPM6JtwFUKxA/MYH2/bSGMIpaJzMxABVvKwp5x9CTx7Dn 9dS7r2kSk6zuuxMfzVf75ZAx59vU2o+YY92Au7By38zBwADr4rinGKeSOhoSPQrrRuBaCdU2+VVR yqEigmjIZWLOVZc9iOOSAOxwD9RpTU0JiqSYZKnyyO8iQrj8vxH99LI0KbTsjwB7HJ7k5/y/7OsR wAKu0qyt+Hbkgnv++soe2rDQVVDmmiWluZnlkj+U8ovuiRY3Hpz+BiWPOMjdgc4O32OtZHcKimV4 aanpaog7iXaVBt7YwAeR+3309mORJRvQ7TyO4x+f2+2j6ahqrgWShppKxjjeEVmKnjuFzjt209uI J6oYP/qFZBHNRf5avCnzDEJ1ByArFTzxzkfbJx9e+k6wX0mNJHt9XEozsZZE59xwW+wzjnGeM4Fl 03h91FdA+LU6wDOxppBHnAHdWIIyftjT3QeDNzlXFTPSUqkZBQmVh9iuAP13HW9mDxko6sPyr6pD nAaZgqegpbhtkV6ShMjgspjnkVE7gcYy3GDnK88aE9LdpNjE04wMYjDBHIwBj7fY5+ur4ofBCkjc GsuUs4HIWGIJ+hyWyP7/AH1Jbb4ZdN2xt6WxJnxjNQzS/rhiQP0A11YeCYx4pzWtHfv8r+qV0zW6 AD0XKFwpb7HKs1DS0JqwfLmmmkZd6ZOFI91GTjJ4JJB5IK6k6XuHVFGUWzP8w0qyz/JQGQhihWNl de5BKkSgkAKw9J3AdeQ2K204Ait9LGAdw2QqMH69u+lMsG8AqfLkH4WAzj/prqRcBew2ZAPAa/Ml X+4A+FtLlqS19S9DUHkdVUFRHZJ8U6XSGfbKgIICO8bFo2JPDA4JOeGO3UZsvgdH0rfq/q6fxDrK +3w05kFBdKfzpZXZQnmPU7uQqPtwEyAM9u/Ys0MNwp5qOsgjmjlRkkhlAZJEPBBB7gg8j76o7r/w 3qOgaWquVrHznSaoXraCdstRoMkupJG+MDJIJyuM+r+ntug6NgD+sBzO49KVRzO2aaJ+ajqdH9Fw XiqvfU9df562rRFmtMV28ugjIQIDFGGRlyFBOT3J1KavxW6f6a6VnpOlqeGyJNGyxVzR+aFcKFMj AZ81lVRyXz6RngafPDbqnputgiqVpbYu8nybpBHH6vY+YyjAPtnsSCDtOAebfjC69NV4uU9oLj5W gpViCOoPqb1OU9sN6FJ4/wB2wPdcrkIjZ00ddbmBv5rn47FNwUZMgN3QF1r6dibKHwtsfWd6WA37 qLqK81BZitvjWBp9xy5kZwxbO7LMzY7dvewbJ8PdX0zNM9u6TvdB5yKsji8wRh+Mf0SZBx3wB31N fhMsNLZPDi49U1Kok1XJJGk+cBKaDK4HsPWJCfrx7AYoB/jivNw6kmhpbbDUwSSODRtIwZcE7TG4 9ioGQV78gDPOYaMa47n3ztJwPD8POwTPiaDvzO+vPmpr1zf38O7tBbbv02lA00InhllqGnSVAQG2 lA2SpK7h39Q4wQTAJfEWGuuooKDoe01Ly+lal6ONkeZt22MFgMliCT9AGY9jqYyw3/qZ63rHqO6W 239MQ03zdTFcGbFE0akL5Y2neHVnRsYJ3KQCyINE+F1FSda+T1j8v5UDrKltgaFUEaMRukGMk5Ch c7ucOcKG2rlDWs+FlAjfQa+QC9GyIBxaR/xSiih6idAs97hp6fZlaa20AhMbcZG4u4POf6Rnvrea z1swSN73dC7jkiZFx+yDTxGFp9xlcBjxgjg6jnWBqL5Y7zRWmraOq+WdPmIHKMkm04RGUZ3A9yO3 b8R41taXDV3zUflbZDVx3efFHrDrTxBtVjpb5corTd7rHHTRxFZGWmx5gc7hn0qOWP8AhLfbXSnR /jlT9O9WVHR/UNZDJGzvDTytMEaVcchtvIbHZhjPsAQdVp4WeAVZ0h4jJ1LXwh7PDRSyU8voV/mp JY1KhA27PlxsM453ke+NMF88IevK2evnltUU9dVTSTwTNcwjwrJIWMQXPbbhWBJByRzk6p4AqSMg EfNYeE5mNLcfdOJ53l3o7+VClCvj68KuvI7J071FbGe8eGdoqJWo0EQ+ctLTOuBPjLeUVjiVGJ9I VVcK59TdDKLhDSVEEp2SqHWQ4XKsob8v+z9ddPdB9R9X9DdPf/xjbqWrsLL5UzRSioRICNrGUbcF OSGPqAB59OSGrqT4arTeKxL10ZdIKSwz7Xa2GIzLTnjHlkOPR29Pde2cfhCR4nYABRby/C7kFQ5n 5ra7mue60KbfUUVYvnUcyCOYcBRGxCsffgAk/lk+2lXRtL1Fc6u3WiOtqWNM3kyxwVGACo3O6DuN wO4AgZ3Dg51ckPw5tId1RdG8qQBDCaHbkMMEEFz3H1xjt76mHh34KUvRVc90M1XXXH5YUvmTlArE DHmBV/rK+jcT247d1QvMZOl39e1DPLDNRB6w+nP7KZ2Gz0tkgpaQJ5UFMihA2CAR3bcSSc8gk8nP fS7qfqin6S6XvN88yGeaippJo49wxLLj+VGCO5eQoo+pYflpdBbpmj2xoSSPwE4GfzPbTF1V0ZdL 7c7FBuja00FSK+oj5/nzR806/wDtR/5hBzlkj+hzohzMPVbY7VjkeH7mk6eHdp/2R6HsPT8pWaqt tBDT1Ekf4HmCDzWB98vuOfvpB4w+GyeJnSMNsMi0iCrhqfPKtIylHVs7ARuOVxg8cn9ZLR2SpaBD KxicEZw3P5Hj39/f8jp8paF9qbpMupHHfH/fGugx0zhRZusMgjILc2h0VaeHnw8//T+6/wAepeoI rtc0oDS0yVlIYowxYlmYhye2AB7frqybWbvLSwmvCw1b/wC8SnlAiA9sAq5+nv8AXTpHSS7lwwZf bORjWyQTQSn/ANQMePqP+/rqdHLnDhmbpVA6ePNJwkWHwMHQQNbV3tr2b2j4ZKqGImV9u3+pJVJP 57oRp96MSWpuiR/OyriFn3Exn6dgYh9e+ozWXaO10dZUyszrQI006xpuO0IWK47lschRg8r9dPnR VSGu1vIheJXVxtlXBAKk4Oex7ce2tLYZHDK4k+dfhG6UbgBSXpzp+W11FwkNRNT+bWEB0CHeg5Uf hxgFiP01zP8AHz05JWi11k1uF9tEVqrZa+MSxU9TDGjwqskEu3Od06jaVdTxlQcMvU3S+75G5rOx 2GtnKM39I3HH7HjVKfFn1dJYqHpigrKikorFe6mWz3CorYTJEpYRyJllOY+I5DvIKgj1ADkBNC1s bi2/Un5HRdDhuJMeMje46X4b941v3suTaC+UPWNhtsNlq5apKSFaJLfXxmlrVdfS6fLOcuQRg+SZ FGOSNN8nT8FNWy0FTQvRVrJ6IWjMUmT6R6eD3I7j30+3q69KN1Vcn62uaWyz1UclRQymNZILjtHp KNnZMhCnJR8kleRzqy/DC2dDTdW9G0Nr63q6v5+rhlobVaZ3ippFRy7ZieSXChUbhduMZ77SPPZW O6tEE8t/x913JJJGEvzXXPb6f0u5LTQRWu10dFAgjhpoUhRF7KqgAAfoNK9YX8I1nXrQKFBeLQ0N DWDq1FyV/wCJ/wBSy2P4XKughiSV71daShKyOEUKrNOSSeP/AEMc/XXkdZLEPE3qmwdBWQU1ruVz lEP8Qusfy8E9Q49KrxmNFxtU4LMWJ9IbavpJ/wCKxLH1O3hp0VNdJbdBWvXV48qm+YD1EaxRwB0U +ZtJmkGY1dhkkI2OOU7B0He/DvoWjs3UVhlt95p755tJcmjMqNGPLHlxyKDk7iCFB3ByOAd2lSuL Gghao2Zur3Lmy8+HXUXSHUtXQzWGeK62GrZLhPsBpkCPtyzuDGFJRgGPBxjBOrKvdytPRnRCw9P1 Nur55ra9bTVF2i+YLCaqjikFMJEQM42sC7xg4WUgDOdR7xwuVDcPHfqurrbNH1RJeJtlIoeeGaOQ qqD+Wuw+YDgAMMZ5IbsSPE6vbp/rGXo+EmgXpm3RWaU0o27ZkQmrBfAdgaiSb3x747aZd6hKIyPy 7e/7Vh/E14q2Lr/pfp2Lprpej6ZhSq2XBKRFVJqiCFUQDbgYRJMAgcgj6aL+GWyzXWju1TBVpBNb ZYZxDKDtlR1kV/sD6Rpk8Ha5L54fXqG42azVdZI0YtVwu6M6Qyxw4ZAoYbt6CMMf6SVbHAwh8FOr Hpuqv4XFQb6a7KqBYg3mwTBiBGOf5ilmI59WADngg55A1zcruS2RBzP9h2I/C6x6i66LU70ctwrY JhGkSKmx1ZdpB5xkHkc6gFn6brqK/wBgunmx1ENvqln+XqUYkoDxjB5/I4B1MenfDmunRRNba6nU Zkw9LICh+mTxn7alzWw9O0qz09jqalWzCSYznkc541zBHhQC2IjXvWoPv4k5yeNNputcoqLkV9LL Ij0D5jwCAdobnvjjUYt3jBF050zZbZTj+OQpHI09KqSQGmkGSAA2dx5z35xpjrLccPts0tLUMdzz FOTgcY/t20w1rVy+cn/mKeVDhxIjD9+P7aBvDMMfhJ9Qgc89quXo2+UVy6KtNFFV3FVmiEAjkSWL eV5Y7Pbv376SeO1P1VW+FN2Xp6Woqb1SeTNRQwlmdisg3hdwByYy2ADk9uc4NNEGVlZK3ypd3DJk yAge2nrqPr5/DXousv1dW3C9TxwhoLfNUyGnDZAXzF3c5JAx+eg/xTxKHRv07wiY81Y0pcOdefxq z9XVcN7t9Rbby+2WeCqTy5AzjcGZe4yDnn66vn4U/h26t+IHqGC32OAxW2NlWvu8ynyaUYyf/c2O yj6jOM6jfT/hpYOpPFOkr/F7qa59Py32rWprfk7d56xiTEhG9XzH6So4jYJnBHpOvQDoHxqs3gp1 9Z7f0fRGDwxtSSWz5Kjw8lXu9T1WWYBm3qCCTyu7H4tejdgy1vX5fNYmYiQlzmb9vvmrL8XfAvw6 8H/BLprp6agFVFR1ypTO8BqJ5GfLTytghskBmJB9lAHYa57r7Z0uC1TZLElDBtaKmnpmYmoO4f8A p4O04z3PGdSjxr+ISPxWuEV6udv/ANlrNb1eGhWurFaRwzZMrgAKjkKg2qX7fiOoHQ3RqJWvNlrK YwFg0wqMPTzY/wDzgbGcf4hgj6jS8ThzK0dGadXl771thblYM+6Zesekun77DLRNabhAVQ7lgIaT Pfd6lI/Y6pCLw2pqd6hfPqUD1Jjp6avjxIeRjO1cAEHka7B6W656a8Uq1BbILYtdTgRVtLTTLIyE n0sCvJQ/U8+xHbLv1x4fWuOKEmgpYpHdWVthOTuHBI+3vrwz8e6CToJGZXJ76ldmrVc79G+Au2p6 pmmtFHdWpaNJYZKKvMCwsc5UErywxnv9NI4PAa4UxsshtEMNXVVagTNWq5YEbsMDg888nVq27omr reobvSWiWlorbXPGrBCZNjYJGDuBwcHOpH1J4P8ATlLafnLnbbhUVFIFE0lFXzKqtnAYKWyB78dt A7Gta/U2Ty8vFNeWZG5BqLv7Ksrz4fUtQ9qt1T07XxSRQuzVKiKbzRgjkK2OCRyedM9h6HstioaG nraJUiQeY9R8qrzFScfhUFjjIJ9+P11PKDwW6C6zmrfloeo5noXKkvWysn1xkt/lp4pfAvpLoCjq 7zb7BWxVECec1XNVzBQoHOdzkEY9iDrQziETKZZvbb+0AcHU54199ygdB03bqC//AP4qs3m0VTIW +bts3mJ+EcvG2GTdjJ+51KbNXQwJcJ6+GqtuwKjGCGSEyEf4Qk5Vh+QHftqeQUFqrLdE1P09cYma MSR1UEowynnIP0+mNZtdtho6CemFFel3jehq6iZwpzn0qGI0Bx0b9AtjXxUDfyUYlrKHq+kT5S6V XzEal4meJtzBRkqA2Tn7Zzqs5r1Fe7rWpFc6OVwcQPOHjZWB9QO5cKCM8hsavCvv81JbK6KitE9u IRmjklt00iwvjG5cKcZznPPvqH2m33a02KSWveOsqHmDiSNIkMhYZ5UxHn7jGfc6SwRb1RRSMhI/ H/VQ3U/TV5r+oRS3ivsRtqxAx0f8Zp3xzyRhsjj7+2pHQeCfzlHFJRX8RUpX0R/OxOEH0DKcEffV oVdBeZZYblXS22RvL2tJV2pQ5yc53LHt+vvg/bGiXsvXU+JKTpyOamcZR4aKREI+oEZ2/rrqDEsA AbosYa1q6TFPLDRmWXckLv8AyHePCuM8kHsT+/8AnrXbKqoUO6Q5YgZO4jt7E+3Pt347ZZbV1o12 ttIiyxiKpimljWdRKdisvls4B/EVKuQTnLHsedOSXGmTyBUHyA+wb2BPlseNm3uxwCBtBHp+2uZ+ pf0dP+njG7Pna+xdUQRyPjy15Feb4djxxEuZVOH0/pKvIcwx7F8wclTLFn1DB7Hv7f8A4Rrc08ie qNFEezBIUhVXIyRwB7Djjv8ATunW40qTLG1eiVDb2SnndVdkBALqCR6R9+QeMcgBQ8M0YkwF+Ziy SCuxQctgcKNvcjgdvr7+CfCY9XCl2jFIxECoWPIqvNjRdhaWWLuzEAj3wQMHPbk+/IzC0s8Yk8mS mkCt/vE2uvcc7sHHv+RGO+ksUNxqWqBWUFCIY2UgxSvNvUY5YFPQQRu7nkd+AdLVjndVVx5bvHua VRgY5xjC8jB9hzzqEMyit1WV5ABaVq675ysspUjkLGODznAB44yB+Wfy1hEZ8phmmH4SuW28YJye Rzycn/D31vMGGfMyjfXZ24HYD6/T6gnjGixMxkyPl0iHrZpY9pVOTkke3Y84xx99Jyi6CEN1pyKL tBIESCRlyQCnIz7ZzyPpkjjBBOlLvhcqhZnBBATHG8HHb6g9+caPim3xoWUR+j1kKwJ+pAIH1z9P 1GiKmSN2T1RtKG2qMAYYjHY9x24x3PHHOjo3QUc1taIRxsyLHMqk7VXzO27sSD74OMffP7lyQmOZ AIw6D8ex1UZ/qZQcE5HsM8DjUvtnhbdeoFlH8LelpmcuBdGKrn7KSWB4BGAAOTkk6ldu8GKV5pUq 7sXqFCl0hHAP33E5OMc4AP0+nbw/BsbiBmbHp36fVDmiGpOqqgW5llMbx+Q0bDDFhkjPbHH04wDn P5aTf+Wp6dWmrQsauFdweQCQNx9xgkZP0B5AHF0r4K0KyLI9yqiyjYqEIFK5z2B/T640ml8FqUVc sgvkyGUFEQomyMd+AT7n6c+x41t/8PYzTq/MflC2SK+5VNBQrvhhnZledNzDdtGM7SCSeCpGB2OA T2Gjaikeh5mZod2QUIG5sAnaDjAX0qctj3IDdjdND4a0dpjhVa2KSFSxG5ArMSpVdxH+8VScgN9F 5AXBiJ6TtF2fzhcJqmpjXY0sUke4kHgkgntgDn6a1v8A09M1gLBbjyJFDx1192qDmm6UIeqggSKG SdaaQqWipBtLLgEBiWOScHIPqOG9hp36YsYu13hp5XFOrKsrqrq7FDuwAMZO4I2Dx+E+/GppQdJ2 eCLNVTz1wHCs1WYwFHZcKBnvjnPHHbjTtQ3K20N3qRTiliqmQEUsc6AxxduAFBALDOSDz7+2t+E/ T7hIJMXWlaX9f6KLpG0coKhPiFVVlL1HI0BeMwQiRl2qQr7W5II/CAyg/wBIABx2ww1M9NE1aj0c bxNM4V4ZGjGA2fTuyvuvG0bQBgDIInd+6ftdyu09yqq2qpZKhkGEroURGACqVLQk54A7nSGO2WCN m82+moRiQI57nAyg4xkfyAfvjOOO2ONFiuG4yaaR4qiSRZuhqNjtYKU2iBdqH+THWRI6ERMTgRyp lcchcOgJJxsz6V/M6W0KXOgkP8PlaSWUHYKRvMD8fiMandkfcD/PUrZ+mPJkjNytski4yzyUrugx 7EIO+B3HsNF1Np6TrFwLtR0Qcc/LVUIDfo4b/v8ATGH/AAWIaQ9pAPcaP3CMOrtU/wDD6mlS1U0s skssksCSs0srucsAOCzHj05x9/udSN7LQS3RLm9DTNckj8latoVMypknaHxkDk8Z9zqGWjqu0wRL FT3KjenhjWIsKhWLFcAcj9c/c/mNP0XWVHMAEnpX5xlahT+uvoMJa1gbeyySMc52YBSHGhjGmP8A 2ppmIUy06seMeevH/f5aU0N8grKk00ckckkaBpCrg7fpkffn9jp2YFKyO3pVp4jWX5rrRXj8xSaQ zt5Q3ZKbhyv9WdyqAMktt4IzqO0XRd/uMixx2meLY+d0qLCF/U4yM/T8/pq/Rs3FsAMeMkYzrLMN 2337nXnZ+CQ4iUyucRZO3spomIFUqdoPB+4VdXipqaamhU/zDAS7g98YwBzkHv76mNF4S9P0sZWS Ooq8jBM07D/93A1Li8dPE8jERxrkk+wA7/5awlUrOFCv/wC5htH99a4eE4KDaME9+qEyPcme39CW C1qRBaqYk59cyea3PtufJx9u2n1I1jUKqhQBgADAGttNXVl7PTXS93u4iE5oKSWpERbaH2IWxn2z jXTZFHEKjaB4aJRJO6dAMDGs6q+t8XquDwzsN8itkcl+v8sdNbbYJDteSRjtyTg7Qg3E8dscZ1Zl P5pgj87Z520b9mdu7HOM+2daC0t3VIzQ1S128Qev+o/FbqjpToz/AGchhsEVI9RJe6eoLFpo94Ct G+Dx9hj6nUtPTvXtR0TWUU3VtDTdTT1CyQ3Sltg8mmi3IWjETsd/AcZJz6h9NDsop5oao6lj676J 8VeibbfOum6mor3JXCWmW1xUiIsVPvXlSxJ3EHuPfvjUfWj6kqOmOmOt6nrW/wAlRcOoKRI7Yk8c dE9LPcVVAURAxHklDy31B4JXUV0ujJo1mXGSGByGXuD9RpHLcKbzFo6tlLzAooZTtl4JKj2JwCSv 0B9gdVP40XO5U/iT0CaFmWkoauKWucSOFCz1dPTIpAYAlt8mNwPCPj31Z3U9dRW2x1M9TDJVJuSN IYWCySSu4WNEYlQrF2UBiwAJByMZ0LgdwoqquXglH0nZaJ+hW+Vq6GCOGW2MBHDX7UClgBhY5CAT kDaxzuAJ3CpesPDGxeL9zguMtfWWK5UCGnrKMQBmQDBwY2KlWXt3/D7Hga6S6M6xkurVlFcKeWCr t1T8lO7FWAk8uORdzIAvqSVWBAwc8hG9AI8QvC6k61K3C31Js/UNOuIrhGu4SAZxHKv9afT3U9jy QcMkBo0LHZ+OwoZo4sW3JiBY+irpfCiTpfwOovDWC8Vk9uqEqhPdqaRY6lw8/mso9LBQTIykYbhf rqm7Z8GXQtorBWLS3Wap96qouk0cg47jyWjAPb27auSz9RVlsubWO/0yU13gyzU7N/LmUnHmxN7q dvf7YYAjhV1j1y1srLJSWm009ZVVsrNKlTKtOlPEjxLISdrEtmaMKoHOc5A5KWwGTVju7v8ABa2u bC0NrZQS2/DX049OpnsqXGCRT/LudbU1sDD7pPK4OeMcalkXSZt0MNvo7fDFBEoCRxbUjjUYAQD2 5z2/LThTeIlnu13rKOluHmVNCJDKiK4UhH2SbG2hZNjeltpbYxw2Cca5v6r8Y/Fb5/qK2rdekaKp tEdHulp6GceXPUMViUNI7AcF8ll429hxpgwcbtCTfvuV/uHA6K+f9nZ45fKjfygpzNUKBxz+Be3P BBPIHbk8rq/TkNrSIJIFRE8ilpgh/mHbnavJLNhWOcdtxPAJ1Ax4uRU9rBSsjEdsqbtW1kMcaP51 BSCZSmSuF9bwDPcqjck5zLOk4L3U2h6ifqs1l8NHFBUJXUMOKCoZUlbasW0fgkBKEtu/lksMaMYS KqKrp3nVLa/pLbTLJVGOVlGUgH4YzgZ/M8Ebs+5AAyxYxbbFTossrBSCIl2pkk/TuPfH9tQa23Tq vqzqm/wRdcQQ27pq+Q0U8MVlg/8ANxiGCeaNmJYqcSsgK8gjP21BuuvGGpnvbz2p1nZ6l6G2UsI2 tLIqM26Ut+GNQrsxHOADySAGftYyKGiDpnXZV7y2+ONi7MxIyBzjUAk6QqPDhqiv6Wp2qLPIWeps UahjFk5ZqbAztzkmIZxklP8ACWjpnxkvlgtSzdfR2yAvKwims0M8oeMRh2Yph39IDlm7BcE7c41L Ln4r09BNUqKdZ44bxQWsOkxDMKpYcOOCCVM2cdiq9wdB+2icK2KNs8kZsHRKrLXWrqi2rcbbM0rN GDNEjAlMjIOD9Rn9u2lJomZfRGUzxk5xj29tVJ1j150wtDWdbdEX1ahaStjpLtDSqxGZc7HRSMln cKo2BkctnjDOLK6G8QqTqq2qVUwzxP5M0TrtkjccFWU8qc8FSAQf7qjLYndHM0dx5FaXwiVnTQHx HMKQUlKyquGYj6g6VJC7uyjPtzgaOSpB9sjHBB1uXVhlQMnXRBB2XMWFgOwkY7aPhdEddv8ANbHC rjcf+/zGmKsvn/48jstHEam5ND58krqTDSxnhTIRjliDtQcnaScDnTzHbqySNC10MYHqJjp0/bnP 5aMamlE40s5dHPkuoU/1YP68E6WpllUq2COcZ4/751Bqvw+oLjdbbcL0xvVdbqgVVJNIogMUoYlS BHtG0A/hOd2AWyQNSeC5CSW5RvH5KUUyRK5P48xxSbvbHLlcZPb741qa0CrQGzazUW01EvywbC53 zlSATznH6+/20/WaKNL7ZhGoUB2zj/2N/wBNMFnmesiqMbWd5nbk5bGcZ/L/APBp2t1UtB1BbArb 1UkMzHPdSBg/31p3aUvmrJsKlLbGduwvudgfqxzn+51RXxw2OSfwXqrtToGktlUtQHL7PJMkclN5 uQCcJ5+7A5O3A76v20qEt1Mo4IjX/LVJ/HJG8nwreIAjJDLSxPle+BURE/21yJWCRjmHmt+FkMUz HjkQvOHrGOzr0fZ7p0xQvXdG19OtNdbXdP8AzMEFwUbZAwzmNyACsqsj4PpYZxqQ/BX0j09H8WHQ 11slZNbYo5KwvYK+V5hGTSThTTzY/mKCclZArL7F+TqnPCTrqDo28V1uvRnrOkb5GtNdaZpC3lgf gnTJzuQgH8vy10t8EvhLXWH4u46a41z11NaLVU3WgqRGoWpjcLDG4IH+Gdsjnka4oYQ4OYeYXdmf mjcJBsNF6gKQRwc620mqrhTUFO01TPHBCveSRgqj9Tqq+sPHymgtM0nSFGnUdcEZolllMEcgHfYS MsfcDgEdm115JmQi3lcODDyYl4jj5mtSANe0mgPMq3CcDOsBgRkHI1yp/wDWU+I9VcLPdIahp6ZC 9XaKmJqbEZx6l2khh6lwGJJBz21dvhTdoaq0S0tPUSS0tMqhI6hzJJD3yC5PKngjPbkcDA1ngxke INRlacZw/EcPf0eJaWn7HYg8weRXDv8A4nnRHTviL19bqK43GWlvdu6cM1uhVgIy8lQ/qbucYiI4 HvnPGuEvhmr+qKvxmsPTlrrLpWVlyrqWKKnileVfQwIkKE7W8pVJBYYXbnjGvTj4lPD3p3qTxuj6 gvPiRHZ6Se309BF09ZrZT3C61syPIcoZI3KfjUAKrdieNQy737ojwFtdbPa3tXhRUV8LGe63Rv4t 1VW5xngsfKDYzgvgHugPZ8zgAWvNfX8/bvSQC+sgvx22VdeL3QFEl5+Ia42+60Z6o6Riprgt9mpo pqhHamz5azMuUkxGUDR7NuVIBPbzwEqQWyOsMtPNNUu8Egedd2CM7nGcjk9zwfr31e/jl4+iTpis 6Q6NornZOnLvVPX3G6XWQyV99lOF8ydwAuNowIkAReO/GKKrep6unt1DQib5ulgBmekrqdAI33bi ik5JBAGc4zkjH1GOzZ5E6I5soocwNVN+jL8trtXT0UcIrIaaunEsceOVaOEMVJO0kruwT/loyK9W yk8W6Kr6frpelum3u8VZTVFRF8y9CqynDMpJLlcsSNxB578HUO6Uvkfzk6PT09BHODNBHUOqwr6S Mbn4x2wT7r9camPhBffC60X683XxEprherdSKlHRUNrMX81pElEkpRirEKeVdWBU7c9xrPLbWvdR PcOd/JMfIwxNaPfJesVpvNJfrVSXKgqEq6GriWaKpiOUkU+4+n5ex49tKV2HJYYz7MONc9fCX1jB dB1lYunblL1F0HZJ6WOyXSWDynKyRbnhb0qGKEAE4BPc99dD5mfkRduPVyDr47ioTh5nRb1666+v ahzMOwWop4gCuxCF4ACj+2sVEFPOzmWKN2PJLqCT/bRrrgHCLwcd/fRcisrbQAeec6y53XuVdtqk z39LbbLHc7lNRU2KSllqGYxrwFQnOcfbXMnhj4YT+MPUVj6TqD/JkZrvdHYA/wAuIh1jIPs0zRLj 6E47auP4iuqIbD4dVlA0vkV11jaJFQgsYhje2D/TyFJ/4tb/AAHpHNV9XXcxKEhFHQwSOR6eXkcc /XEWf019V/ScMgiMr/5HS+weyglPRwuI5+/okPiL4K9MeCHh7/GL7SUlz8Rby89L82KppoVLsWmm jUqpXauAOOGYAk9zzz1RW114hp7JYInFyqkHn3DBEdupz+KQk8FyB6B3yM+2rL+KDxKufXvizPae mLbN1LWUGbdbbVRI0jVNS2ZJyqj2D5DN2Cxd9QW1/Cj8Q9Z0kKGKwPZJLqzS11fc66np1R275UMZ ABwoCp2HbXvMVK58mQmyEMIZEyjudVzn4kdZUFx67itzytH0x05AkFLShyRI4Hdie575PPb76aur +uLtdrbTNUNJDSzgJaLLHw0ik48+RR3B/pB7n7Dky8+Dd98M/FHqKwXmKhvd2szRb/lHMtPJK8ay j1OFG1VYbmcYHP56kXR9FBYZq3rS6VCXOtVmH8XmQmnSXt5dImR5rDtvwFXHAOAdYCHAkbK8xerg +CnpKo6V8WjbJZWavjs09XdcD0xu7RhIcj3XAJ++R7a7iktqVIHmMZATyjjcPzzriT4FrtWdQ+MX VVaFcU0toJlL5zu85Nufv+L++u40Vl3AYOOTzxr5N+opS3iDgOQH0VsLhYaUzP0baldn/h8KOTnc iBTnRFT0PaK5t81MZeMNmeRc/sdSECRSqiPJHPbj99ZBO4ggE4/p153p3jmm9JINyVEKbwzt1FJJ Jb6y6UHmHcyQVzsjHt2JOnmOzPTQyQvU1FXFLGYnirD5isGGCCG47acy79hwD9tbrOTgMeRwMnH6 aL9xJea9UJebsHVE0NN/DqWGGJIoqeNdiR7NoVR7ccY0nagUXf8AihQvJ5flbFY7MfXb+ul7yY/q IJ9geNaJIVfIlYDHKMODqum7yrMpJq1pFilXdDTP5aIw5YkgE5P6aCyUsyiQUEUn/EEU5/XGs8hc p3U8HHOjPMDevIP0JxqGbv1V53VodUVB8nECjUm5SThABgZ+300YHip/TAJaWPv5cTNGv6BSBraO RCQSQw+m0axthBOc/pqxiH3oUPSv7Vzn0ZbL34L9b01g6ovVdfqOujp4rPVMA4kYwgVBO1eFjKZJ YjbHsJzxq+rPfYDMKZqhArs2zc+N+0gMVH9WDgZwQMj7aYfF7pmnv/SktW1T5NRb99UJTCwcRbNt QilBuwYi3AIywQHA41C/Dvw+uN/6irK+5W2qsdNSmEUc7TstZXU7qQiEbj5KKsbKBgS4Zf8AdsrM 33+P9RcM/UH6Yf8A52QiRvVNC3Fw1a4CxvYs7XmGy86/huJgxwlwjdN+6tqJ9lXQPLeNiqpKyEFZ cL5kZ5ByTn6+wGCT+p1PBK8rPLOJMriLj8IJA2jjsCTznvwT9MBVDtDLIxEzYQB+3PY475/XHGDn uIfKZUDKwOSxJIBAI7Dn25z7Zx+R/N+a+a9iM17pPPDHJJE7xukiO0igHAViMbgCBjuAVHt7Y77T xVOYhFLFBGUIYOvDcHawIHBBwe/J4yMZ0p2mLYmCiOAp2sTtGV9+eBj7dh7d94Y4EXeVG9UAdlJC 9uxP17+/1ydWJHjS7RW4c0nioniISNoI6fJUKg9OOw28DAB3c4OcffSmGhFVVK3neRvb8DshAyMZ ORyBkcDPce+NbecjVK+YXHpOA65J4Axjvxxg/wCXfWsTUrgRt5jSbyu2JFYZwCThT9O+R/ri2u62 Y6jsV5RzUquFR4e9G0oqLv1EblUlTthpX5lwf6dmT7jndx76jdR490dpTy+jOlo6fco3VNwOZM9u ApYkY/4vc8fVPFLDvLRxeTKGACovqJwAeBgk+w5POBrFNVK4B8llKKATtXK8rx6WI989yOPbXoRx kR//AKWFrO8an1ItCyOIayW7z09AozfPE3r/AKkc76+6RK3/AKFsppIlOO+WVcnsc86ij2m91U5n NFUmpY/7yr3K59s85Pvq15CY1dghR1wQWHrGcYwfb65+x+ut4jmZC0YWEkbXG4nOfw8Y7ccH7/bW F/FZpfjJJ8VvZiGM+BgCqZui75UuGlt6OwU4JEYOOM+pz27duO2j6XoK4+YHa3QRsmMNI8eRn3GG +n+v31alJAilHQIodwNqnGMf9F1pLStLMynMe9d3cZ27j7HnPHbHY/fSf30x2Cp2KedAAq4rfC6p uJlFUtOskkDQGTzWDqh5O3CnB7YI5BxqJ3zpXqfpK1CvjgS9U1J6EoTOI6uduEwrFSjeljKdxByG GO2Lz8pJJGBP80/hRRlu/GDxn8QH3x9ONHhNgRVkV+3CneM7uMEnB9/0zoo+ITtdZFhK6Z7jV15K rLf0LYesoKqH503CJf5dXStShXQFc7JI5BuGQcgkcggg4Zc1N4heDM3hr0xYFS/Vdw6bokeklklk IjRN/mQNIEz2QujOFKkRqeMnHStTa6KVaenrIUroty1EMs0YPky5DAKRjYck7WUjn05HpBaPEDpH /abpG9WtEkklqo2aNBN6lnVwyDDZRsuEXlRwvP11oixxEgDicpIsaH8K48RJG8PB7veiQeG/R3Tc /h/YqyntsANRSQyiQAIspPDthTtwThgRngg886lEFks8QKRW+mG1gwLQbgw7djng4/z7e1R9A9f2 ykstJTiKalrZBUq8tNbajy4mjkB2Som47XaUdufWCfxqotm39U2u+RARzylg5BG1gcqfVglfyJ4G OCR2APGtmZM465bNevogkmeXEXzS9BaaapM5oKSgaKZIYXMEQZpSVVcYGQd5AGfqNKaCopJpaeBf KWWWeOJEK7F3lgq8bSPxFe/fI9u7fa5mq7rUTyENCuyCnjfDkYOXdscjcSo9zhBkKcgyHptYJOoL cZQImhdZVLLg5T+Y3PcZRefsBnvoICZMRFFe7hfmR9lndI8Akrhv4y76erPHqoqaZVNvoJXtdOsD MNyxFldn9ixmeXkd1VffOi7dYae8W+KmG+eYgP5lV/MlCEZGSec6ivVNzpKtIa2lcxusbVNXFUA5 ikZ3kL7vdWJYjHYAA88meeGkz9QWC41EdL5chogI4pjgo0nG0t7Yx3+3tr2+Ic9xsdq72GiDY3WL oDdJ+ivCSjmrqloIHqZJdiM8rMxeRmOdqscLncoB7c84GvQL4aegqXofpKoipadacSGNZAoAEjhd xfAA77wozztRd3OQOffB7pRLfS27bAUiijVVjkOSvowAT9VUIv8A8s9xx2H0FF5VhB/xys3P7f6a 7vD4tHSuN8lwMfLljEI05n6p/KAAnAXH3xohRUYJ2oCxzkscgfTt9NKH9RC/Xk6DEtwv15OuvS8+ kBmlikYOFkj3ElYlbK+/PBz9fb8tUjWeFd0v3xO0viJdK6rHTlhsqwWe1q7RhqyRpVmcpkZxGV9u S6jnYRq+4UCIdq4GSfz1XVi8bKPqLxivnh3BZLlT3KzQLVVdXViNIGhcDy3iwxZwxOBgcbW3YIAY S2zunMdV0FObHdWvFClT8pPSRvygqAAzL7NgE4B+/P1A1C/iGvLWPwZ6onT8UtOtIP8A+s6xEj7g OT+mrEAxqnPinDV/h9bLJHIIpL3eqS3q5/pJLOD+6DTWC3AJZIJ0FJm8AoqXr67Q9RGQyUHSlJH0 /aKZ1AKt5MZqKojkgvlVXkegHIBJ1ctR1hYqTqCCxTXihivU67orc1QoncYJyEzk8Ant7H6aq7wb tdJ0T4q+I3S1FElHbw9HcKKmDf0vFiQgZ7Bto/bVov0fYpb+t9ks1BJelAC3FqZDUKACoAkxuHBI 79jopDbrVKB3DwMkl666h6qtnWV8sFbffIFXFb1p9hEUYjQDzImIwAT399K/h1vtx6k8H7JX3avm udaz1UTVVRjzHWOpljTcQACQqqCcc4zp46O8Trb1xP1TFQ09VTjp64TWyokqVVVklj/EUwxyv3OP y1FvB260fQnw12C8VzbKOishuU7DuVKmZj9ycn8ydBWhtUircW6w+IS93VpZJbT0fa1t1OpjHlLX VH82oZXxyyxLCpGeN3tk5R2yliq/CbwbpGViJ6i0Sou4ZLR05n7n6eUT+mtPCmKr6d+He69UV4Q3 i+Utb1NWbFITzZ0aUAAnOAgRcZPbTo1DHaaXwTsyzLOaapUBsY3pFaapd2PzZP3GrOiJNHWXm196 66uk7hqW3XfpygRUHqRYKinq3Zvtirz/APHVq3q2G608kSy/LyK8c8bsm5Q8ciupIBGRuUZGRkEj Izkc83joy3dT+E3X/XlZV3SW4NcrlXxLHcZ46YrS1LRQ7qdXETER00a5ZSTjOeBjoHqqjjuFonie 4SWiMgSCvjdVMTIwdWywK4BXJDcEcEEE6DkqKqnqqC59WVsdjWzWVauOaSS40lykkFBVyeXG8U42 qDMNrOcOMBom5zGraU3Oar6Yt61K3usvBszWu3R1TVjKkkkskaymeNSEcyRzx4dt2Mg+kje0pj6B s1dJJS3C6NfblUymvEktT5UysqCL+UYSpjjVH2YXuJG3Fi7ZmlBbaeGlVPlo4slWZFUYJUAKe3sF XH5D6aHUjVDS5E6pNmrbpPS23qNrvXVtNaYZ7zd6x2mo6t5a1pCyb1NPJtXaIV2AO6KVAJGtKPqq jvMVHTdRRLMlPcZqe2XoNsEs1NUlSrFGBBLQq+w+lhtPJGF6W6xtdNb6aCNaBKm3kPvgEW8xL6Pw pj1KMfh5P+EcBdV91NFTdSW6SzUkdurqLyw80DuCPLOQvlgH/Ev4xwCuAdw9K3xfzYacmNdWh2VT PPfaPre61ErTV9MbVOIK+GPFFSxiWM/LwYJZpGXYXcksShwBtUCH09nu136jusrWKU26op7TSU0t dLEVkSkqZZJZGXcx8thJgMQGxkAZ1YNb830DQG0yobt08oXLnLva+ePMxyyYJwwwcD1EA79Sfpay 2+22xRSTNX08knmpPIcv2Ay+DgkcDOO2AOABpfShwJ5jdF0RBAVNp4adSf7O+NG2ihr7jdqWqorC IZFBmjl86WTG5iI98k+zaSM+SufqZ34b1O2G5NReG9y6IoqmpWdqepNLG0svlbHcQpMQihYYVyD6 i2dvdi/yeI9lg6Wqb9VNUU1BBWz28qtO80jSxVb0gCxxhmbdInAUE4YcaQw+IlBcbr0ytvmhqrXe 6arlhqCCrtJF5bKmGwVO0z7lI3Ax4OMEaW6UdqIMd2KuvAmm6l8zxKa99J3iwC8dQ113oprmYB5k UiRxxxFUlZgwCc8bcYwx1TXV/Slxp57Vc7bAk9zt1a0i0ckvl/MJLDJG6K3YOAwYZ9PBycY12SK5 XLnv/wC1hwNQe9dGWmS6fPeT5bFlUJuOB9OBxnJB7e+PpoenbyKLondiqfoqPrStnt3UT9Hyme2R 1lGlpqbjCk80cwpnSfdkouHpyhXOdjluTwXii8Nr9S0FJbXpY6k09dYq1546pQuIIYoagBWAOU8r eM/iDjHI1ZkNyeiqZY4Y1ipsZ9Qxg+2Bx9+/fGlFLWy1PMQGfclSQfvxqnStGtqxG4miFVPhx4Td Q9PdHXCyXC0WeWehlomoK9LvVrNVvBuXzvNIZqYrHsCooZAfNXGxxh3Hhb1fLcIL+3UtvW/S0vkX CJo2kjqTHJIYf5iiNdxRold/KGTCCAAxGrRgqHaNNqxgNzgodGpLMYATFtkI/CcYz98Z/wBdLdJH K2nahGwSRPzNNFMnQvXydTQ1FJWRPbb7ROYqy21ICyxMBw3BIZWGCGBwc8HUuMjq+Mkfp7ag/WXQ lN1UaatSdrZfqI5orrCoMkY943H9cZ90P1OMHWnTPWldVXGezdQ0iWu+Q7dhDZjnQcCSNgBuRv3B GCAcjSY5+iOU6jl/a2ywsnGePR3Mfju+imcNs2XP5tpGZpTtdccHjC/2Ua26p6pHTFtpakiOQyVk MBjdgDteRVdhkjsGJJ9hz9tJXkdEd2fcTjAU5HH+f6ahnUfQtV1jWWS61ElTbjbqhn8iQHzJkOzA OCdoypPGPbOdbW4o/wDpWAwVuVcUXl1JbEkbE8gg8Z9tN1VEwdklU+W2cjGc5/8Aw41kW4uGjgOG 7rxnH5/X9dax0MyIPm2jlnUkK6QlM/oST/f21uixEjtmWs7o2jco+1qtFHEikhwMHHbt/wA9K7eG qr9SMSQokQEj8x2/799b0tKFiBAGQQDzkjn3/bSql8qK505I2jzkyqjAzvGtJfOQeqkhrO1WpTyw U0ccYOM+hQBnOPsNVb8XFsqL38NvXtFSRmaqqLeUijUZLMXXAA1Yt/6ksvTlEJrxX01HCTlRM4yx HI2r3J49udVV1l4oUPXlquFjpaIvQSHy5zUkqzgEMAAD6QeDknJHtrmSTti+Nws8lqjY4kOaNAvJ K0eD3Wt8vdXZ6Gw1TV9I/l1UdRCYlgOf62YgD9+RyM676+HOz3jwZ6etK1UlBc7zTU0tItVsciKC SRXaJCWGQCi8kDt78alNTA8MhRmYiPKgE7sAdgO+ePprWCojiym7bnjHAPH2149+NeXUNKXo8jnM 0FrN/wCoLgOoIZ7xUVVdG6hY66NwHpycbSAMLtJyCAMH3H0WVrKYY66nhRJVkPnxwKFDkg5IGM8/ b66YeqBBLRwTVNLLUUyPgrE673HcqC3AYgYBPYkE8aYLL111bf5PlLNT27w6o1XYspX+I3ZtvBzK /wDLjJGOwbWqGQSML5Xbb7m1kkaWOGQbqwYrdRWZZeoK4Ulits8QEtxu0gphgEkL6iGYEsSCoOfr wNUN4t+JviN19e6m2dB3q5VHQ1PEkUNXRotHFM20bv5sgBZQQRlVY/8AF76db/0NEtyjulVU1V8v kBLxXG+TtVyBxypAJ2rz/gVdRue7+KdVfqKO6Xux1EVRGzIy2kTQAowG0qSo4yCMjnGtcUscIzRO y3zon5D8lLldJKf9vWI035DbdRKs8HfEu39H3+bp27S2m8+UskklioJKyeuXaGdDV+qUPgjCgIuR jjOdLPCr4YaOltFLcr/4e9T3q9SQrVS1N4gMCn3wXmkjVW4yckY7YPfVp264eI9+vb2e5eJN5iRy qwCzwU1Eu3A3g4jYrt4Oc9s/TXPPxf8ASXU1q8Q7PLB1teqnpCso48SVdxSWo86ILHIUQdy42ODj +piccjTckeJaQHOoeV+f9LaJXRhrmsF7amxfbWlfNSXrKu6M8LrTfbh1PB05KpiUUtpohHXVm5WB Anny8UQGOI4Wf8XLca4L8UfEOTxP6vunUdRGlPLVsrGKNdqptUKoH5BQNdH2Tws8O/FGiekc32Na Cf8A891BLcJKmpUCJmbEHleX5WTksBuAjJPHePyeD/w4UNuqvP8AErqGS6A/ykpo4lXP3SaOMnB5 /Ev0+53RyQx6NB+q50omkAa6lQF0jp6u00M0nmbYaFFUKPS8hfGCfYYyT+WPfOo/HTDHHcHORq5m 8FOl79eZoKHxQtcNE2DHPW0oi3HtyqSvj6k8++n3w6+Fmlvd+Au/WNHU2iKNpZFsIEtVIqnnaspR QPqckjj0n2dJiooW5nlZWYaWQkMba6H/APD28WaGr6cfw7rFgW4K81fSSxxkPUEnfJ5h5BYex44X HsNdqU0ccSnzA0vcYxjOqu8Gvhh6G8EWE3T1NPLc5UKtdLhL5lQUPJAwAqD8lz9dWopSMmSeRhCn MkseMIv+I5IGPr9s6+Q8RmixeLMmGbQJ59vb3LXDC800C0RthaYBwQcfTtrfykddsbbscEgZzppq erLZJb6eqtsNTVx1BwmHUrxnO2VQYWPHA8wZ9ueNaPfK2nro4J7cj08kRljmEyxlgBkI6MeJM8HG QRg5ByulHAzt/jr4rsf4jGFpJjHquU/jWudfautOnCIfOpHiWkPf0rMSP09QH6jVq/DZ1jY+hfh9 8ReobmkU6Ud1mFLHNDvWSqihgECjg7SJSMHjBwc65Z8Sm62m65qpbnT3bqyy3RylRHJTO70knmMw MZRMbY8gAE5wODxxIOv+oq/oz4A7bZ4IZ6W89VdR1LVVE8eJ4YvPkf1gjcpxFD3xkN76+48Hg/aw sjcfgb9vNedxINhlc/oCqM6V+IjqbpHxfj6n6UuYt01tglpoqySCObdv4d8SKygscYOM4H3OpD1/ 8ePjl1HBNTVPiJdIIGB4o44KZj+TRRqf76p6m6RuFmtTPJBsmn5CHuFHbntqKVVJWVkkscEMtSY1 LyCFC2xfcnHYc99HndZdeqSe0jVWP0hRnrWWe89UXqeriWT5qteqkeSWokOAu+RvxZAHGcnUwvl9 n6xrIDPWT2y10ieXS0lJTKdigex4XP5aYumxblstHFf7Pb6y3zkokS1UtFUUL8f1uRG52gPhiM54 PGNP8dmsVPXw2rpzrJ7hU10yUlLajAWLO7BRmUYAAJznGhLqBc4+KezQarsH4Hugms/hvXdUuHeW /VR2NUjLmniJRCdv1Yuf210rHSv3by9v24z/AMtN3SPStL0X0laOn6Uf+UtdLHSxsxwW2KASce5O T+unNJSR62DAc4I/118MxmL/AHU75j/I/Ll8kbY2kC90TJEwmwEABGQVb6floCk2jCIwYnv76VAR hs7tufvnWRCwQMDkfUawh4ChhCQ+W6Z3Kx57A40NyNuCr6iPfsD+el9Qq06xP56O034VHfj2xouS NiN2O4zjGBo7o6hQQubuURGgO3cdueM9xrYqqvgYP3K/6a3lkdEDeWWzxhMax8uHblgGGT35Gpbd yEJa4aImWFVYEkKDz2I40WYEOTuUj8+f21malkLg+acj6qDpX5aNGHY88Aj21Ry8kJjdySMwg5GA /wBACB/n/wA9ammJ9iv5Mul4hLLwSRj66KMaA/7zafcEjVdUpZbIN1X/AErH1x0/JTQ3mppaq0xg merjqZq2oBBJJ2lBJk/8RZVGMlQMFFYuqr0l6qrfujhoaOUR09dURzyGOMhnaWQEq87LhYwkRITO 8ngatOKeKWVXykjbywjhhwwPLH0jtyB9AQMgDBOtfmGYko0a7AGRlZlWMgsQAMZI798Z+nPPaj4k yEk9GDm37++q3XoRKWt6OtCbPf3eCiNL4s9KVPUVFYKO80tzusg82WOiZpfL2AlizxhhGRgkBuTj AHONS4vEInCli49PmLkAYwD+nH349/rsoRoVlMR2xbnhSI72xjPG3uTkgDn2+uNZjpR5TiKUMxVR vdcKQQCCuT6jx7Z+mO+ubiDG7rRRlvnaAmwdEVujb1bWEgVnjjEgGxi2TkHkA7u3vk8cjRsUTU8a sHlwzCMyMAQqkHcCRgcDP7AY4wx60U8Ugfy4wBuY7n2cdzk9+MLz3GdLHV/JzO0Ic5BclAnOFwTx nP0OcnPBBzpTYw7WjaHo2uGyaoFXzHWSQVUasvAfa65/EdxGM5/YNj66UGmyFhEalChHl+VuVwOE GBhiPuffvnSiqopJpBEkzxqynf5WyUsAAwCnnkZ++M5GDzrekSopEDPJuDZOx1UEnOF/q5PPPfgn t730NHTkoIU2xeREu8IUcEsY/qTknuMZxkY78d8jBMVqaAxbVaRHVWAVvoAQxIPJO0j9TpWIx5hQ vOpWXy2B4YHJI5yM/wBJz2IAHYjCelszR7S1XX1DTI0QErjBJdWORtIyORkexAxgY1bYDWpRdHdm 9VosiyqzpCHVcFnBJwScZ+uc7fr++j2LEOjEtu9G4DBYf1AgZ45PJ+/J0o+Xkq0+ZLCRacHZIYs+ UWAHc4C/iHpOPxcEjOiflEwWZEYhckPwcH2XcO3K/l+2gdG5pCXRvdaxJF6m2DiMx5bbgHA7jB/x A/t9eMyQuTKjwEb024OJM5we4A3ZyD+pB+oLmFM4d2HmMVYswVVY5IOSCrcH0g54GfYHhVC9OUka JWKu4Zdy+kHI4BGOTn254PHfC8tjdUNTZRDxSRuqIpBZQq7U/wB3z9z2/wCf660SSWJg7wGCRX5f bwWI9OOxPt6h+nHdVHWfKMcyhHBViquoLduAO4OdnPI7/kNixqIlhVo2XAUMzsA4JPfBBU/bn251 A1WNfhSKbyqp1DN5ruWKtkgDOBng/TsRzxxyBrRpqwQKVkicd1nkj3v+ewKFBI4OCOQOMejTusDe W0gb1E/j3bju3HB4AAz7c9mIB7a0pxA9TuOwtjDIzZOR2yCR+xHuM44wTWuGmmqsN1q0xL05Rtbh DT03yibXkklijKsJHUiRyUweQVztIOQpBGAVZK+6VVnhnuNyMcjwUyFkAJqgFDMUOMeYQWIjKAkM 2S5DEtPVMJChg+1WJd48jt+JSQTyeO/bn9UpiDRU8KyeXK0ih9r4/DuKj0n08qitnIwSPfOtbHyA 5SbBUe0kpmjoqeqCR1UaVyr62NTAGkjHduCPUCxABTPYAZ0xde1kVh6XqaykNPRSR09ViSkGPU1H UBSu3AxnH15x2951FQefFJvSF1Dgs8rFdjbjyV9zn3xxn9o91L08teaSmloI7lTvMRJSVW2YSJ8v LgSc4fHAyQDnGXwdFA50cjZDyN+iW5hA12Xmrf8Aqy4Wjq6e3R+RKlYkVuDVVNHMI1KxuThkbP8A hPGCD2OBrpH4Yup4+qqO/QwW6lEFNLSwRSPTtD5pAlZh/JaMDau04xgblGO2onbKaeh8SeprTbaW GO31NzknqUasLGWjgDLHHGzDdKvqBypJ/FnnkdGeGXStNYqSWempbbTpUfzIzbYSiMGwS2/P83cB Gd5/w/XX0iMCYN7CF6J8rY8O5xABO2uvorY6Zoo4mWNKaGEZ3Eru/wBWPtgflq+elkdbFTbSqj1d 1P8AiP31Q1kmdpo4lljp5lP4JFxnn6nIOrgsF1ucduo/mYVFLtKhoVLNheCWx9SCeB7j8teiiprK peImtxslS5CzgkYPOM9tbkle4AA+h1CarxBjp+tbX0zSslfX11NNWsImUfLwIVXfISc+pm2qApyc 9gpOpIJJZJFaR8YBAAAxn65x9P8AXvpwWSkveQxKVVS8mOFzjP5n20gg6dtydQzX0UMKXaWnWker CDzDErFghbvjcxONa0Ts8kjs7sXduM9trFePtwOPudHuCTkO3/3EavmoCRsnDVYeKvQl3606w6Eq 6Mw/wqz1xra1ZpGBJDRlNqgcnAfBOMZ+/M8lHoPJI47tn3++tIYVXsuMcdznVglpsKBQ25dDXJPH O0dY0C0xoXtUlruJlkKuqhjJGUUD1EsVByey6sNqhVz/AGGeTpKkKqAQMH66UKvPtz9NVZIoqKiO oPg+6R6mvF2r6m99RIt0q5K6opIKyJYfNdmYnb5RzjcQCSTj686nXVXhDaeq/DSk6AklrqPp6nip 6c/KzKJXih27EZnRieVUkjBJXv3BnwxrYD3xqjZ5qWmy4WCluNgnsbwJFa56VqKSCLKYiZNm1SpG 30nHHb21EelPBXp/oq5UFbao6s1FFG0FO1fcKmqSCNgAVjjklKpwAMgduPfVg4z9tDUpS1GLd0BZ LL0XH0nQ21ILAqPF8juLKUZizKxYsSGLHOTk5OnSqpKe5Wh6KspoKulmjMM1NNHvR0I2lWVsgjuD n205MuVxqKdV23+PWm9WWarq7fTXCnkoTWUMvlTwebHt3xt7ON3BxwcaFzbUtcvfCYxPgDXfJ2ux 9Ey3KyVXk9RUdxRq6peHdEatolRdqRsdxJkyCew351vW+KfXvU3TvhTWWK6XVbx1LX3inuNBDLFC 1BV+S9TT0UgmX0iFogCSu4xq5H+8UF78PPDPwYo+p5KHo2wW2GutlO1rr4JKeenqnpZAyutTDKFa aN03+t1ZWKggkgYsVOlrF4i3Hp7qe0Tl7bT14vUNxowImqKhqR6bLZXLEQSbCcBlMarncpCJ5pmw tUrVeJfXt56o60Wbq6O02ygr7hYIqOtWlp1NVFTqtL8iCzTvI7DzSXyuH2qGI3GMyV9y/wBiqG70 d3Y3q79D13UldWxRLDJT7RQVHk0skaDy1BmkOw7mJkDOSW3HqDqLw36Y6gutP1NS9OWs3ajjEUV9 FHGagxkbNkL4ztw3LHICkhc7iVbae12Xp1LVbqWCitwp4Wo7dTqFRkiABaOIHkjCKSB/hBPYanRE 81A+uS5MvVT190v074g2iz1t36guFTFW1tPSVdTKZI46O67J0j27XUy0FVTNlDvZgzKd7A6knQvU dx6S6etdXaIq+5WeO120Sw3OjninrJJ6qalMkaNuZFZ4YZArZO2YMSPe46/xFsUviDJ0vQVVTJ1T TRxPVRQW+plpokkXei1M6IY4iyqSrM2Rx3BKs72rqakv8Va1JK7SUVQ9LVQnIeGVeGU/X7EcH21X RXrdEK85VP3PpSnpehuqOoOgYq2vvdVVLXw0FTN89HRztOrTyU1PO4jSQb55QuVzJwTgABj6Bs/V tTD0i92sV1pntXWVxnlmuEcMM8lFVUNXKKmRIyUUCWrEZVSeU7A+kWbcek6n+J1l3sNWaO+NM0kl POxNNVYJADDuhIA9QP6YPDj0x1PDf3rKacSUV4hcGptlTtDU/pVcKR+JSVLBuQd/B7DSwxrzThr8 j77FeZw2KWihQuW3HeQASQM4+h+3f9zpNXURnDevBx6XXg6d/LJAAGMfX20mqQ0ADFeT2AOc6puH jJ2UMru1M8dqLiKIndEWz6m9sZ/1OnCmtqUm2NHJVe+T3/6awhEccMqqdh55PbP/AC50eakKAzkK vYZ09sTG8kBe47lbNRxHspzj3zxoS0voxHge5yM6PhcSRhhyM8FToMARj8I+3GNQMYzYfJUXOPNJ AjRsTgNn3yf9dN3UXS1D1VQilr4yChLw1EJAlgf/ABIf8xyCOCDp5cxuMlhjtx30TLOkSkHLY7AA kn9NNyhwykaFRrnNNg6qC9N9QVfQ1XSWDqhlcPuFHc402wz85AHJ2MBjKE+/GRgmyqeTzUUh1dG5 DpyD+uod1bdLGvT1QvVL0dJa5B6nr5VjUEdipP8AUO42857aqXw58d7La+q5rFHcZblZKh1FJV1E JhL8YAwQCre2cAMfYEgHAc2Cdrqw+o/IXYZG3HR0BUnLsd/f1XTtNM0gkRGIYEdv76PCiJjU1BXz Oy7htB47n2+muS/HnxS8WPDW4S11uu1J/srWtto6+lt0bGBu4STcGKyewJyrdxg8CgZLrW9bVAuN 2ulVca5RlpaudpmHPcbicfkNdL98xopotcr9q4nrGl6C3/xi6S6SlaKvvUE9ZgsKaiImkbn6LwOT 7kai968Vqy9TxpbkNsp5l8yKVcO78cEMRtB98AZH99cgwQv8hFTRn+bEheklzkuvJaP/ADI/Ualf QHirJblS23D1U6jETKfUB7EH31ysbisTMyoTl7v7W3Dwwxu/2C+9W7RVtXd6StjuFRNW3Wld6Weq q3Lyy4AKOSeTuQof3+mnKw9QfK1VkrS+2CvWOkbJwFmHKDt7jcv/AMVGoqvUdA91husFSXpJWSgr BtI8qUkmCTHsG3Mh9s7Pppza1fO2W5WeGUiUky0rtgGOTO9SPyf+w15JwIdb9L9ldoURQ99itK9I riKYbX3ruQqTyv1/f6aZIkZpGYSF42XAjdc4weefrz7/AEH30s6Quw656Zt7wkB5zscbtqRTg7JV J9gGBz9h76kdy8OrzYSokpzjtiE7wffOR/r9NNkwz5SXMBIG6VHiGwjK7dQdnRa75CpVHpqxSoWb 2b6jPvx/bUGt9N/CeppozIQYN0rq2ckMcFhkkbdwxj2+mDnU36mejSqS3yXBEupYyUsVP/NdXXkb tudvbndjjUXrLJWXLqae9xSNQIu1ZYpSrDechgNw/Cc5xg8857abCxzTlISZXNLdSn2aBq+CF5B6 GUbTEQWJHcAc5/vrSh6LvE13kintdRa6aUoU+ZYOqezMo4J5y2Dzzx7ZPs/Xdq6OFPFFcqc3RyZE jeFWLhQW3lnHCDbu7gcHVQ+L3x5NaqS4xWFbP1RXO7RSSxArTxHbgnepwxHH4ePVnd9OlAxpGV4J vu09bSybst0Hfurpr6Q9ISXa3SVULCVUjnqmUxgxY3bFbJG07vVzztXjVV9R+BMHjbYqmmpZDT0F RJmnvFI3lqCCMsAcCQ8MmQOx/XVW9HeIniJferukr3b+mUt9LVUa11whujq1teOSRwJ13ZZCyAEc 7zt/CVAJ6Qu3jvaLfA9PbJI41izG0nHBH9KjjGM/fVTODXHrEdw1ruWxkbT8Pw9p0+W5RHh38PnQ ngvbgLbTrJXqgjkqGIaabBySzZzjI9to47caZvEDoXp7ruqea/2yhu1PGMQU1fTJKkYx9W5z9xj2 1H7/AOOVPHE00pd8/wDqTNt3fkP9O+qb6n8VOq+t5HprPbZlpAceZKWpofzOfW/9tcR0T5X5h1e+ 9V0OkjazI2isdX/DH4IXC4NPUQzWSYZ3QWqpZY2/4irBwuPoMasHoj4X6fp+ioZ/DutttBaa9FWp ujRZqjEeGMUwyWOCeBtGR3HOq3s3hVPdWWqv9xlrS2CKKn/lU4P/ALB+L82J12l0VaI6DoiwQUUS RQQ0USIq4woKD/nrJxDGT4WICOQm9NdfRYHdHG4ODRfgnOGOWjiijR1k8tFRSV7gDGcfpoyFHijP /lo13HJUA7fvxrDUkrgYG1vcn66LZZ4JBGGDE8c/ca8QHOaUgPDe1ctfELZ6XwmrIq7o3pylYQUT VFZR2Soe31lGu4KJdsJAkU7iMyo/3ODps6P+K/p/qGmqagPNGy04aaK51AkVcLyOFBHIP257DXSn UvRdm6qhVLvQS1VSrmUVUWUlaY5wA8ZzHEo5IJUHtg+9C9SfAX0x1VdKCas6ju1KKWlENS9up4IJ a2bPMu4AgJ7BCCeM5517GDHYURhsztue59F608QZhIQ+J+Y1tpZ9+9bVI0PxE2Rq2NKq4pFFKMGQ LwG++NRLr3xv6c6kY2W51dRU25qmOSWqgOQoRsgEZyVI4ODnt31RPjV0I3hT4jXrpWe6016qLdKI pKqkyELbQxXBAOVzg/Qgj20f4meElR4c9N9I33+NUN5t3UlIamnNG/8AMhKqhdJF5wVZ9vfurcDG vqUT+kYHx6ir8l89fO6yDurWvPWSWTzB5gbp+9QgPFOhno0lB5IA/CCefRjhuNGW3xXooq6WC322 0dPTmDyail3/AC4OBlZEkUruU8fhYNznHGdc92Lrm9dNwTU9BcJYqSZSslLIA8Lg/VGBU/tp46e6 VrOuYjJ/GbPSKhIEFbUiN1zzhUxnH5caLMg6Wzopj1r15d7nIlD1KklRQvCYoKyZQ8jKDlQZQMSA EnB7jPOlHwzW2O+ePHQ8LL+O7QNwOcI24n/9HTx038GHiR1dahU2KW1XOBm4hiryhJ/JgB/fUo+G 3w4v/hL8W/R1i6wtv8KucUxcQvKkikPDJsYMhKnJ+h76xcQztwcslGg0/RKJLjqvUcyJPIWUZOd3 IO0/vooLEVch8Mc7CoLD/v7a13s3cs+Dzg/3xrQ7Y3JRW2nvtAH6ka+FNcByXUGUa0jFpnVRuYH2 BI1q0UqM2EBQ91HB1rHMkhGxyw57DGTo0TMzENkEZxj31CUJbmKKkDKEYh2YjGMdtbLK5G3+ZGB7 OdDy90gcSSAoMjDYGfy1uQVRyW3fUMMjVZtNkWSgtVQyvtR8n6r9NEs8JlEZmh8znapcbiPy7nRp hjOX2rjvxlTpJNY7ZUOsklvpppEORIyAt++M6JpZ/K0QHaUe8TKynBPPBHtrYxeWpO0gnk45B1kq jPghlC/nrCwRq7SCMs543MQf+ugtAGXzQiRl2kxqyN9HOP0xoSRKGwqqB9yf+WjiQ0DKIw2fqe32 0mDeUAuXwO23JH+ervRA5jq0WadPm4zMk0agEhI1Idxg4PH58Yxjtye+lcEklvqI3kqfIQet3jKk xkKec49sj3+uOw0asNP5UbLOk25thMz5UNn8PJJzuIH1PPbtrMk6tVrH5sMJZipYksB/gCgrjt3G ftjkga2QujcC00Quj0QciZpaiurAJLoamolG8LNKHkJBAIVu5TcwBIIxx3BGjZoHRQkhZpiPLQoo VcE42hsY5Le+cllAGRpU1D8wJmaNIk2B2ZFAcL6hncF55HH1HGBnlGHSnjPkxSLOSVUzN5bSZ3Nt DYywBDEqOwJPO0jTzH1i5xJJ3VtjYBoUbPJJThY4pyAXVlZcyZJOF5OTycAHuckc9jislqEfY1PP I6AMQUw23jIwSDjBPA78jHbSNIqyjh3SrT0/mvsjeZmTzHO7hsD1HOBjGeQCOM6z5mUAq0XyGJC+ VNgtknd/hOBjGQOcj0/UQK5popxNFL5asqqv5MzBT/u1Qvn3IIyc/iA9X0PsdCNo4oxhXVFIVuCw OcgZyePfA9+CRrSSaSOBmR3nj2hfKSMElsbjjce+BnuMYY5J7m0gQzsXkeZo127JAxyD6+O54AXs T9PylOPJEDSNFwhkSIyRiRI1yGAwEJ49h2285z7kHtkaRsrSupjaZkQB5ASXHPGfqc47kdsfmVUS uMNIpjKsVJVVPmEckeog+7DjjI9s41mhBqGHlEGZVZxGm1yrKSj8jP4XO04HvyOTkw2R7soF+A1Q nKLJ+n3RU0rSQhZpZ0IcMUSRirMCSOV787T+gP00ajySh3hVcLkIoXYQffIGSDkMMEj8h21Dbv4z 2uh6wpOn0WouC1LSQVdVbElqRRTKAQkirGT6sbQVY8g8dzqTUd5pOoIYbhSSrW0MpDoUXenI9wy8 cYPcHIAO4aZNhJsM0OkFA8/XTnXgaSmuiN5SlizkiBjFIsSEbcttyQMqB34znA7+2NB8LG0cx3Ak 7ZSwkkOByOQe4HJB+vbWEqWjgVEQZUKHBQDnBAGOcDAHvk4AA+hHzbCRXU7cj0PLJgOMLkDAIOcg 9+c+xzjC6TLrdqraOVpVKViUbZo6cqWcOpVdmWG4n+nuSTx9ANFUdGKY+iUENny08oABjgjAUc8e r3IPOD7aCcQnMdQyKdzsFOAGwSBuxjPfuv74zo3BKs4QNtZk3+YTtJAYcDB/C2OPz0npLOmqovsn RZXMKLB6WYZGWTnOO5JBy2SMnj8WPzTmqkgjWdEWJ3b+l9wbJxke5GCeT347ngbxHeJBDNHIseSS GJypbjBz2J5H5ccY0rR50lJdQ6sATGTwWPGOf+LIwe/P00BmN6qU06kpPBK26NZVp3R5AMtISwJJ Xkkc7RnA55HJ1oI0S4rPGUjEUMilQSANzgucexBjzzj8Xt30e5lYDOEU8NIQfQuDyeeMEADPt+WC iucpoHhrJU8iOMmEmZtoAbDsDnGeVHOeASeADo2SGRwYwWT3IDRIy2lUtyhtsQkqqyKmo8BJpKmU YUfhxu9h7cn3BONIr1ePlYhLG/8AEKxYiYac1GxnlODGg4/CxR/UPSoVieM6ZKzxDstD0/U3GZxV BRUJT0kTI1RWvGxj2QAHJLsDtCjkMpx7ao/w/wCoPEHxO8Ur9deq6Gm6J8OFpkp0guNfTxzjAUbE IdSHkJyzleFG0Y16HCcOnkcRM0gN35k9wHNOeJWC3NIHM8h2Wa5qt/8A6I9a9ZdQVHUsnzXUFupp fKFRbhDGssycYpySrNGhwvzG0uSD6TyBengnaev+naah/i1C16tVaxBNNJCGom3EF13lGeJ8E8rv B9WDubVpT9U9OWOgpngq6emtwBhiFJFK8KBdp2DYmzAUgEA8ZXtnOo9WeMNCIYjQUdfeZmkkEs1J CGdCXyG2lvWO5w23AJ7bsa7kU3EtTHDlF6ZqGnfZCzzYwSNa2T+IrTnrf3Vo2mOju0JNOy1EaOY2 A7o47qR3BHuD21N7dco+iumnuU9Y/kl/JipOGeZ/UwVMnvyeMhQAzMQASOWKzrfra/323QdH9A3k 3mWrjgmq7pC1FE0KhQ+XXPHqyCd4UD8Lc5jnxreM1R4a+HNus9LeJrx1BeTU0MFzAWPZSgbquWEK AMKhWNXOC7HdyEXXs8NM6eMaDNzo2AuQ8NAuz4H3S6y8DvESk8XpOpuoqSKKaCKtFsirKcDY6Rxq xCNjc6b5Hwx4bkj0lSbMkJCo2cMCCu48c8c/vri74ePEi1eDHhv0hYCkdtus1IzmKrrJIYDI0jJK zblZVLSQswJHG7YAAci2r98V1p6Jro7d1XaalJKkuaartMqyLLs4Y7XK7eeBgncQSO2ifioIpDCX aj3vsrGHlkGZo0V6UZaGhpSwHKjzCeDkjJ//AEsfv9tK8AnHJ1Bui/Gronrq0w1Fqv8ASZIA8mol WKUEckFTjnA9tTpAH2OhVkcZDKcj7c61NkZJq02szmOYacKQwduPb66CnDcfc/bWZT5cLMxAC9z9 BrUEA8jv9dGgSgD2z+WtuP8A8OiPMywAB/LRm7CjJx7/AH1FEZ741nWF9R4Gsk6iiGMnv++hoZwO RjWcZHGONRRY5x9T9tNdwiWslkp3OYpEwdpwc5IOD+2nQ6iXVT1l5ttxp7PchaZBDNTrdvJ80wzk bUCIcByrd+e42jLElaUXK9spZKH4nuo+tRabrBR3nqN+kZ76SBSR0cdHSrGgy2Q7VtO0QcLj+a43 bimLJ6Opbh1n1j0PTz3iuFmji6jarpYK1/LqvlbpDHTwyAEfg8zB9yIyjAqSNS2w+AlvpOg6Ppl7 ve47XFXm7EPUIaqoqTMZ/Nml2d/P2yhVwAwwdynaLJt3TFos9XLU0Nqo6Somllmkmp6dEd3lKmV2 IAJLmOMse52LntpeXXMUV6UuVpYLN1B4EdUVFJ1JUx9a3O9Uc3U7U12kFZbwt3VJYwhcmnSKPzEU ALhVHfvqvviwrunfCM0tworNRx3Kgp7SbfLXVZiaKOmrmcRW5PLZpZT6hMoZP5bxZJzrt6u6Kspa 7TwWugp6q6AGtnjpkD1RAwplOMvgcDdnHOoVM4ZQZNjsOQWGSPv9tWAdlS5+6Cst4i+IfxZgk6xr pKCnqbZWPbhSUqiqWai2DfIIt6qvk7V2MpGzJJJJLX4VWiz9GeJfW3T9Z1zdq3qiO4BbbTX24iWW anlo4ahpI4cL5uXE6scE4hHIIDavsWqhgrqquio6eCsqyhqKiKJVknKLtTew5bA4GScDjWKiipTU JVGCGSpjUqk7RL5igjkBsZA5Pv76JRM9DO0zNDUQpTVYTdtVt3mIMZdCQMrkgfVcgEDIyg6m6Vp+ oBDPHNJb7tTgimuMPLx++1h/WhPdD+mDzp7rYoqlAk6hwPUpJIKH6qwOVOPcEHnTcatqB1hq2LqT iKpwPX/wuAOGx9OGA9jxpT2gjVECb0TFaer6uKuWz36OOhu+Mo45hrFGMvG3v37HBGRkDvqSyL5k ybsbQDkft+2kt9sVF1LazRXCEyRZEiOuUkicZw6MOVYfUfcHIyNROk6hr+jqyG2dSzGegkPk0d8Q YDseBHKOyvn9G/p9wLY4t+P1/KjgDspdURMIxiUgqwwQvtnXODdS3HwN8Ya+mvFQ8/QnV1WahKqo bIoa9u6M/ZFbbgZ4wo7bWI6TqCZKIoZAfPjKpKvY5GM59u41AOuekKXq+2Xe1XeiStt1TvSaGYEI wySpDexHBDD8J0xz8h0GqoNvdTGllp6ylDKCqg52jgg/Qj66PpY2pskyNIh7b23f59tc12jrC/8A w5PDbesJqjqDw+OxaDq2JDLLQA4CwVqrk7QThZRn2HvhehbZe6W70FNW0U8NZS1MYkhqKeQPHKh7 MrDgg/bV2SaQpxmAkcNhSMccY/vqoviT8TLt4bdI0H8AlNJd7jVGKOoMKyCONF3P+MFQTlcZGe59 tWyJeAwbYMdsZ1DPFbo2j8SOi7hZKgqjyDzKao94J1GUf8s8H6qWGgfeXREwgEErgmvvt46oq5rn ebnPcKiMjM9bU7nUtnGwMSSOPwqMDPtkaLV2roHkWRWG7AUJjH6e3vouqt1fap6u31lBJDWwMyVE Lj8JUjt+oPPuDpPZTHBWNAm0JOuQwf0lscga5413W4kmjavfwd8bJLaT0p1gi3npqrUwmSrXekOf aQn8UZ9yfwkZ7dnrrb4eanpK5RXTpCOS9dM1xIEMTebPRt32Mf6k44f27Hnk0LSCWof5dS8MsY27 oiAdvHA9jxq+vBjxZvXT8UlLLTT3fp6ijMkrQwtIlPGQWJdgMKBhvxew+mswaYia+Hs7PD8LoyYg Yqul0f29vj39/Pnrqq7tdHN071rTWe7wzUVYUNTFSVDYcoCQJFxkYyGGM5BXkDSvxGsa2q9skSrC KtPmadk7HJ9Q+3I7dudWx4t9L0fXlqoOs7XWNUU1ol8+KOCnEs9PketBjDPEwHIPqQgsMgHTz1D8 NVz6+uksFyv38Je1TeUI6emEwIZVberllOCB2I9tGOs/MzULO4ZGlj91QtgvlRRVcMNdMRTVEHy0 0sedzRn+vA4LodpHvlR9dXJ0P1hcOor1FRwUFTc6qSLEgttO0xWWNtkhIQHCscMDjsy/XXRPhz8H nh/HYLfV3inqeoapG3E18xji3KSP93HtBHHZt3fHI1bMNz6Z6Ftpt9rp6K2wxDIpqKJY0TnttUAd /wDPRPwQn6ztFmZi3R6NXO3hlZarp+t6hast8UNBVVfnxIjKJlkeICRZFGSp3gnke540/dZ+MnUL W1Kf+Kw216keTDS0i7KmUHjcGJLcf4lxz76iXVfij0t0V1FcKmsvFZbrqKmdValo0qPOjaZpIwY2 OXwrj2yMnBGdU11f40dNVnVK3eyW409aA6yJFG0mZDxuaPIWLj2LHGTrMzPE1zYzr75prml7g6Qa e9k7V3UtfYep7FBQW610ksk8k9VUNGzkIOWMzs2CTk+w599PV16yvvVdUkVpoIq/cX/8zWTfK0cI A752sWyeM4xxyewNLXjxkoqdnds11ae7VChgrZ7Ki8D8zzpgbra+dRwSVFTLVVyEhlpkG2NcnAUI MZP7nvpTYHubcrtOwaWU+2h1Rj15JF4j2vrW+9VT0d2W21lEWEs0lPcFeLcMgRb1iVio4JQq35jn TTH4V2Kpr4qyvoqX+Uqj+H0EIhpSRzlwBmQ5J5OM/TR/it1DcPD60WWtrqWKd7mZVhpI5TEItgXl yOSMsOAR+eo70F1Rd+pbzDLUTmJQ25KeBdqcdh9T+ZOugzCTBn/pb798kmTERNOhzH375rqaPwk6 v6sitMTw/wAPEVOsTefUhYYI0AES7QSVcKOUUDGBkKcjU/6e+HLpa30ri6mqu1Wwy0zSNFGpP+EI c8/UnOpv0tSVFtssFEz7nVQ8hXk+Y4DsSB2O5m/MadYqdh5rlxJK3pIJ4H04zxr5rj+JzGd0cRpo 2rmORvvWxswNEqCt8O/Q+Yy9urABwrfOySYP5ltKF8DukshIoJ0ZecfMvz++pzAPTkoq+2AQBrZ5 GUF/Lxn/AAnIz9dck4yYjrPPqUQljoUoVH4R9OU4crBU+aMctUH9sEdtSSgtslspYaaNoxFBEsUa yMd+0cDP/PThHLIFBxIT3AI5A1o9WZmJYMSOCSOT+ekPmdJWd19llC5zDpa23vGYlBC5GW5BJ0XU yM6lmjzg8ErwdB1URNIqnkdwOQfp9f00nLMI0MTlXxtPHGgJNJebsWywE4ZYkHHcHv8AX/s6b+re pqHojpe89Q1yf+UtVJLVygAAlY0Lf3wB+ul8FRKuUMYUkZ3KxGMa5e/8RXxAk6U+Hw2ZXxWdR3CO lAzhhCn81yPqMqgP/u1twGG/c4lkPJx18OaszAC+xea1XD1D4zeINwqqSgqLvfbxWS1bwUULOzO7 l2IVewBP6DVn+O/hw3hH0v0h0XX9TWe/XymaqrrhQ2s+a1qkl8pRBLKCVY4iztABU7u4IOq86Mvd 06Bst3vdDcqu01FVAaCGSknaF5t2N65UglQMEjt2B76jVld6p6iMo89RLhwSckkZz/n/AG195aGR x1Wp9KXC1c6yhJRBe69/cc61Wk3dtrD89LcSx53Dj98aLLr/AISD9tITKW1G1RQtmCaWA45Mblf8 tTTw86xq+letrLfzPLNU2+shqQ0jliQjg4yftkahYkz/AFkk/XSulcLzkk/Qap4D2ljtiqoL3Li+ VrIIKqmlEkU6rNEfYqwBHP662ZFRn9B3Z/GgPP8ApqtfhY6gPVHw+dD1kjMJ0oBTO59W4xMY/f7K NWZJEyM385JABlgrZ418HlgdDI5lbEj00XZa3O0EBR9J+oYqmRZKChmpwxI8mYhtueDyO/2/vp42 KVA/mMwGScZK/n9RpVGUz/LkBB75X3+mt/LicjzZFjAwfSCSBqndeiWgeCLKTrVJHkMoVPU555BG R/poCHcu9WLEN7sT+mlHyscxZfOyAODkg6wlukdysHYD8Sn/AD0uuxA6LsWWjZyNp9OORntrQ08x x2UDs3tjWz0kuWEy+bJuyN+eD9saEavEWHl7Oc7Vb3/LVuDQVC0DmVrJ+HO8A/8AHwNFsVGQMgNz kAY1u4kwCuCxP9Xf9jovErMzMg2qeQFAA0vTZBl7Cs4EagiTGOSSNZEmeSwP3C5zrEUqqpyBkZ98 cfUdtauXLemSMD74zoSO9A6+ZQlpIDA0tTSA7RhWUGbB7lQxxtwcDI49Wd3vrSGnoqhxUJTrIMNG Kp5VYexIwG9QxwQfbOSOCXba00LPUPA24bQzqeGHJOCuSc5ILFfqe3BCOqK0ylUZyIvNCHHfHpJ3 ZA9/YD74Ouu62Gwu85uXYrMlA0krQzLvZQu/dGWwucbue+Rxnj8R54Os1VAlOFSKPapcJlxlWB+z d+wOMd8dyc63JSSNykUm5sll83JYDhSAO/PGe3PbPICw7XkbeSxG6USAeYRk4yQAcE/1Ef64AOc0 aIKLdWhExbIGEwjKvMo3vgAlO+c5wwGRyMZAzzkgmKkh3SFGUsBtw+AxGMKSASPvwfyxzrdqh3KY lmNWB5nG0xsDxuVi+5vfsCfyJA1mGU+co3O0iuNvkIy7MkA4LDjB4559JPp1Ruwqaxx1CJ2bhJI1 LvyuxsSgqS2F2kA7c5AwfSQM4x7iF4mXZJGXMbtJsKqwbA447jjHfj7D22kDT1CtHE8kchCHfEuC ecs3p3be+dv27Z1qrbcTLC0LgsuPM3sV5AYjOPfORz6ufchObUJRiN6pXHSSTRIkNRLJEzMYo85A QAbsAHLcngHJBIwRxpAYf4jVbqqkp6mnD7Q8yllzgLnBUkD1OpAI7gZI7q6isM8PkTSSbc7UfBbj GSM5OR+EkseeTx74pqtWJkSPE0YAZowCHOBggkD39PsOODkAFolN0xCGkaHZbW+lWmoI4FiSKjVD iBfKVFwpBBAAGAAe2BxnA7aJFUiGR3qVqZHUZkWQEhWPp24xkZ+vHHbjk6uqg0wAjzLgoWBG3OMs OV3HI+o7jjQFyMwkHkQsFQsPNmLIV7HABxgkY/XUMt6XdJrWmt0k89pFMyTwuMr5cYZ8kMCeeeSV GB7HngYwD5JZQCPlkVmKjkqG9QIHvxkZYc4zjP3EUyl1JEcZjjUkMZEwMLkZycc8cAcY55BGVWWW RkHkyDb6dgLFAeM47YBPJyBzjjvoKHI2mdGK3QhcmaWWOWKMJ3JLDYu4lFCtn2DcDAP0GdFVFppK mraaerqIPJjK5pZpaePbnsyIRyMZByTj3GtqiooTMWWUROCNy7Mg8MQCD37HI75OcYOt41p5ZnSO NQUkP8tl4X0naMjgfnu9wDxzoxrrz8VTYy2yi0trRwqUjqGkDKXWWqZ0blcnnODkMR2GV+pIBqxS 0+DU1LCUgqqmIHMoAyMjsOMAH3xycga1eo8+KOLenO5/LkQbmH4QOcc8Dt3H01rT3lJJKpEctKg2 +g+kg54Pfv8AfnsDjnVExu6zirLQdyEehDYUI0jN6UEiCM7iDuz34BH64PHB1yx48zr4nXa42m9d M1xpLTcYharo9cBRVux3DkRKcFl2bSxLD1tuCEhddFXiWpks1e1HUj59YSsE8EY/lymPClgSRgMy 59v5TE9tUv4v+H80TT2G2wVVdJPOLDbLYDKdqSRs7s0mAFCRISCXJKhcgn8XouDYESh8sQ10A7r3 PkB81owMmFwuMZLjNWNBdlP8iPhb5uIvlV3ouauouo6+9+IH+ynS/TM1Rea2eFF6gFc9JNVMZTGl VGkYHlovB3MfWAsjjLLjsroz4e/D/o2uuFYlshvVfV1If5+9Rx1TI2QMruBwPU3qPqJPqJABFT9D M1f8aF3tEeZrN0h01FRUs6r6UkdaZScsQDIW84cnsnAJBOukpLrFQSQQRGWpebYZBTU5IU+kIMjP DAr7tjcAe/Onjs0okbhYDVDWudrjNk6cvnedSSdtN+XYtqC101Ksojp6SndmQeTDTJBncMDOwA8Y JPJ5Uj6ZXwRVrVASCdvPLA7HU7ZZCST78fhPHtz9AQjojWXe5okELmTeVji84MwXGGIzz2ZW9zwP c41Ufjb4vXAdRN4PdAVaXXry/mY3CqLo0VmpW9cyMVyNwRGG0ZY8fiygPEwHDMTj5eibYH8ilPeI 25jvyCl9/wDGemiq1svStX85PUylZLlAxnWbymiDwxHgeQHkjQv/AOoxZQAqga4l8ZL8fiG+MOpp lge5Wigqv4ZT0sUjfzKWjBnqkB/EHfbtB+rEZ99dBdRdC9LfC/4PdQ9eXe8Vl96tqWWmpLzUzBnq posPFBAnZYPNVOF9RCsw9Kgij/8Aw9+mGq/E2+dS1brIlrt0tuAqMM0tVUAtKwPbCtkE98SKOc6+ z4fDMwsbYIhsuI55e7M5dB+M/TVXV/w5a2pWprrbb46WeSjCrEzLliMEDtuABGMgLpgTw9vPXXT/ AEnUQKJpYwLbTzVUSwx08YJEZG44KKN+51GSQuAWJzI/GfxKTpbqOS3VdPDJWwVGKOEwhkeLbEzS Oo4Zd7SAZxl9/suNSfwWuHUXWVHR37qSria2zx76S1pSKrOuSVkZipIUjG1QfUApPGQ3j8bHiJ8W 5mHA1OpJ0C7MWJbFEAd1dtLTrTq0ykbJdvlxZ4wcN78AdsfvpSauSOqMkTvSSsxd2ppWjYknJyR3 GfY8aazeI5ZNxJCnBKsfWDkc4IGR308WymFzmjSLaS27BXOSQCcf/onXZ4fw+LAxCGLzPae1c+WR zzmKk9xs/VF3ozPZuo5rTH8qFEVTQx1W1wxLEFmDbiMKQTjsRg51Gn6z6ytNUUnq7Lc3VAQDbpqY kfdhNJ+vp9iTjGrVpqgCn8n0mPBBIH175/799Vl4nWC8XCaWHpqmhnunlrIsdS5SEgsVYM4BwQAx BIPOeOc6PiMU5gccIaf7vfRVBI1sg6XbwQXxeudHDCJrAatUTMjW2uR342+0wjBBycnPt9+MUfxE UMVTOt06b6mtccbYDyWs1KcDn1UzS+/udNnUlkrvC3wyuHUtygpuob1TrC4oVZ46clpFVwMnc2FZ jlu+M7Rk6rHpvxfpq23y1d+oqewqFCSvDVF4kYvhWVpE9QJ3Dk5ByduASPLPxnE8EwdO5pceXP5C l3WYfD4lrpI2GhzG3zNroHpLx66G6pk+Uh6hpaS5DvQ3DdSTfokwRmH3A+nbUyor9RV08kUFdSzS RbQ6xTKxDEZwRnI4IP5Ea5rpup7L1VAy2+ppbnAqoRJvjmVSwxgruODyRj79+caRXXwp6L6kkFVV 9MWusqG5EppI1YnJOCVCknJP5nH6jH+pXCmzRa9x/KUeGMdq11e/JdSVt9o6GeKCWojFRKQEiLgM 2TjIBPPOlscyyIrAEKQCMjHfXJFB4OdLWSpD0dLWUcrc+barlWUpYfT0yKccL9R+Z0fPFdaar8u1 db9U0UG5kKfxX5rzW7NHGJ1dgU/qfcAp4BLZCaIf1LC57hI0gctvnqkycOaAMjvGwul7lc46xXji nkjplcxSTwN65XBO6GLHO7ghmH4eQDkEoEtkpEFTJCqCEgQUUZGyFcEA/QvgjJ7AcD3LUjbb51ba IEaHqa210ixCPZX2VpRTx9vLTy5IhtyvPpycDPAUB9h8UusA5SWCxVUi7NjpJPT7efXuUq4OR254 PHPcbR+oMAf5fJZf2EnIg+auH5kJyQwOCQuOSNFG6RNO0PmAyqOVHJHGef7arCDxlvMBZKzpyluE QBzLaq9VYcDA2TBOef8AFxjTNeviHqLertS+F3U1dKOG2yUm1scfiSZifyxp/wDmsG6i2UedhV+x lG9f/Zv5VuPdtoLOjKu7apYY3Y76r2pZzLULEB/LZhhuCcE9v+/rqL0vxJVtwiArPCLq+k9QBWOo pcA/TInHHH5abbn4t3GtrJzQ+G3UMRmkBAqqqkQ78Y4zMf8AXvp/+UwwA/2N9UsYWQnb36qWyGQs Sy7fYg9tElieM/oDnUIfxMvscgUeGV4mkDFZFF1oMg/Qfz+/HbI049P9V3K9CN63oqXp8xlgsdbc 0llPBHAh3qe/uwx3wcaW7i2GaLMg9fwmDBSHkpBJEJFyCAB/caSzUNLcKaopqylStpJozFNBNGHj kQ8FWB4II1pNcqwN/JoqNIlJBYzuxYnngbPz4+2twZ6gBvNt6q+CQY5WYsCMYxj6c/l76z/53BO0 6Qeh/CgwUgOyIKUlBDBS0sS09PAgjhhhQKkaKMKqgdgAAAPoNNs9EtwpJYaynWeiqV2vDIoKyAns Qfz1Ceoet/Eug8S6Lpyz9F2O426aietfqOsqJYqaLDbWiwoZt/Kewzu7YU6leeraxZ/Nlsltp8xi J6emkqSM/iJDtGFweBw31P0MdxfCsHWkFHsFohg5CdG6+Khtzrrh4VLLPGKq69LEBpHdt9RblB45 OfMjB9+SP6sj1aZ7l8Z/h9aqi0wwUVffoK8kQ11njWXfKAC8LozK6MN6cYPcasJrZ1Q9KYZeq6FQ 7KvzEFkKSqm7kAmcryBgnB47Y1QdN8AXQ0FYKqDqnqenqFqHqI1p5aZEjPmEoOY23YGBlj7c41nP HcPEdH35cuzVbGYDcSt18VfFghoetLO96WhanobyPONuqYshoWXCB0wfxJtLKc8sc6rS4fDjeOhq +e7eEN9XpmWaQyVHSt1VprNVNnDFBy8BP1TPYAbRqTyXG++FdHYum+n/AC7nQUlDsqK64U7SvGqt iPeVmQZwSW2rzyeO2ob1548dQ2a4U1BVVZp6mvpJxSrFb0paR5VQ5VpJZvNyN8WGjOBk98ED0MOL jxEbZGc1yHwuY8tPJHUHxGR9GTw0Pi10zdfD2uf0iskQ1NsnbGQEqI84YjJ2t2xydXh0+3T3VdnW 42S70l5t8nC1dHUxzIxxz6gTz+euJH8KuqOounUfqzx8lp5p4QlXS/LxNGSRyN+/1j7451HLF8If h9bXHzniXdJ5ZD6WtrRUytxkekqw7A++mfumgdYX770YwrnatXanVttstJHFUSQWJ77S7zT1NVVC CREbIKlwkgkBX+lk9+4IB1yt114WWG4ddfxJOoLH01STw76yKpuMfkRVAYlmjRWyQw9XO3HPbONQ +t+DboWpMj1PipfPI5l2NRb2jXk+pgSCQBycAaaIvhn+HERk3DxmuE8mc5jngQn/AO5CRpZkZJo1 NGHkYNQr56NtPgD07UpW3zr62dSXGJlkAo2cKCuDnbGSSBj6/nnU98QvFiG5eHlypPDXpq53C4V8 Sx0TVVhqI7bIrsA7ySkLkFC3qJI7Z4zqnfDzovw28M7PHN0j4gdSW221Uq0q3WioqPdVSOSViFT8 oWckg4Xd7YA41OeqOnrjBbHkt1/8TL/XFlRKK5PNHFJjJYemFEOAM474B1gkxD2OpuQDtJ171pbh Dobs+S56pupfFi11FQaLpe6NFd6do4WoaLalVgsPOCuWUBg3BQDJZcZ5B6e6V+KGmgtcVT1BQf7P 3oUcUFcbrIUhqJIlYZikClTKRk7GK7sDYXxnSroK01PTtsttVdrZc6a+rSGlpRUu7pVlFebyVkYZ jICswBwo7Atpr8Qehbn13e7bSV9mV6q9Uc1B5NcySSxRbkmml2plEwoKBw2SZV+g0iORoYXB47yN k8XM8CQbJ7uPjhfuqel7dWWKK53SlucrJRRQNHTQOoUuX3TNHtXAPrIIJwAcnGqo688RfEah6WuF fPL0jYmgheX5W8dSxzVdTtBOxBEcbjgADcPzGnCm/wDD58Pb7UV81Veb9T1CVkoNut8sSxwITujV SyOSNhXnPOfbkaM60+C7wc8MujLpehbrxea6npy1NDU3IgSS/wBJJRVAGSMnGAPvrgycQifJ0fSE 69n9rUMOGi2/QLji4+M3V/iVcAlYtss9DCD8y8aybXIPAc7sk8n37Hn210/8OHglUeMPRdbWdTTX myUyyoLfJaVhpKeoj2sGKEo/mAEctnOeOOdc7fEP0x4W2zpvpqj6Nv1Vc+tZDm7UcMjS0mZNz/7x zxIhKpgE5A5wc5uCu8d+p/hI8MeiLN0/RUtdZbnRGuj/AIyJJnpakFRPChR09BZg4yMjzG766+Jb iJ4A3BnI49uhoeu65zcgcTJrXYlnxg+DHTHhl090l/AYa56qdp1qKuoq5ZmqNioRvG7aCS2fSoH2 9tQbwouME9ChnmJuseQFZvXIg4Gc4yRnHGov4ofGv1R4y9NRWi/Wmx0phmE0VVboZY6iEjvtLOy4 YcHjQ8PvEez38263XW7S0iqwdaqV90kUgOMEdtpGAQQQQdej4Wx8WAZBiNZQTrvdnTXfuXKxOsxd H8J5JR8XPUQq+o+jaCNmiFLb2qJI3GCjyyEHI+4RdKvB63VD9RWMQ0lRI89TEmETAIZl5H1HOop4 2NQL4qzJIIrrTNBTuPl1LGbdGGyhycLz9ddXfBDYOmb4a+9GgrKS6WYrFT0FTG2yNJFx5oJyCThg AO2PuNaOMTMwGFfM42QNufYEjDtdNIGtG66ro9lVLUmFXbZLsZ3G3cyekgY9hjH5g6Nkp9tQoT8B XAB+/wB/f9db01up6SBadGkdmZpHYALl2csQQMY5Y6EtDFIsjONspGF75U/mT+uvgD3B7j72Xpug cdysIoYhn35BI9K8/wDec6bbzdnslKKkW6vuBXB8iiQPI31wCQP0zp3dWjiEckPo44Y9zjvkf986 2fyjHtdWUDBX+sfb34/fQ2wb/dWIq5pJa7tbbxblq42qFjlXKrNG0RTvkOGG5SO3I9tGmPlwzxeS Qu1o3y2775GMaN8mnqAp3Heg4CZx+X56EVNHEzssnlkHBRgSNw9iO+rzA6UFWQ1VBb0zxtJgKsxH G5lPb7HRElPvkCooizk4UZ3HTdfa260ska2qzLeFLfzhFWLC0QP2ZcMf1Gl0JaWiRhEKSRlBMUo7 H8xkH9NW5oLb/CblA5aLaW2CUEvEu8D6YOPzH21yT8Vvw53Txj60rr71Pd/9lvC3o21NNHJCVmqK tynmTSInZOQqZbJ9AwDnXWzVHcEbWz2yRnGfcdxrmr/xAurBbPANrP8AMJSNeKpYZmIzmKPEpVff lxGPyzrr8Iz/ALxjYTRdpe9DnXkEEojLesF5S3a4S3KaHcgiiijCJEhO1eOTye5OSfz0f05UJQXq jnMy06o+fMkzgce+AdE1EfPYjj20lJ2en319lJJ3XndlPr9BV3mP5phTqSoK+Sw5GNRRo1Rm3HBH B0jhrpoECAkqOwz21n52R2JCcn76FMLgUpVTIR2A+unCjiLcd29gO5/TTSJpieyqNegH/hq9BBrF 1b1bXUFNLG00NJRVM9KryI6gmTy2IyB6lBx3x9tc3iGNbgMOZ3C6rTa7VsaXuACuT4G4bxQfD/R0 1wt09A8ddMaVKyIxmSF9rBlzg7cluftroXzJwi5CxsnpbZyD/wA9EPL54yV3bR7rjP3xrEKR0eEg j8gjkshIz/39NfHcRiTiZXSEVmJPqu3GzKA20reaOR8R7gz4ABAOD7g/XSFUV2ZnChu4Lkgcdxo9 /wDd+pWbPuoyV0SKVI08pnnlBzgySBsg+31/TWXpNOsU4ZqolGpEhVjtKjtw5b9hrSnklU5MmFBz gnGB9tGLTPEuEYjHZXHcfY6z5MixuSkJzkhucn886AvN7pbgQVqJH8z+YQeQeTg/9dbmujBIcgjP B27sftrDQNlC2GWPngkgD9tFVOd+1SJITn0ohyP11ebmqAflsBKBM8pTlXCjA7jGi46mFnJKqxyQ VORj9dESK0aqFkYMnJBbBI+nbWhljiYrysh77fp9TqA3qqD2/wAglL0n8vzQrbB3U5xoqU+r0RgL j3yNZhvVTSIVinnWPd6yuR+/sdCOtTb/AP8AWf8ATQmhsEBczvW6MUuEYjqpHqAHcv5C5ULjKZJP fjG4+wHGNaxXGonEuKmZaZWKbZfKKyYXIUKQ32H4l5H050nvVyoLFSVddcKykp7ZTQPPJLUSoXjR AdzDbjCgKGzjPPYntTMHxueCYrFY9cxIjRmM4tNYrBi2d7P5XPG3sAc5O4ZGPSQMxGIswxknuBO6 6r52M0kItXiWrKoeU01Wad3x5SkLx3yBz6e5PJ74xxjSyqpvNxHN/NaFDIYxiN1x3z9McHOfp+lF 1fxieDAZIk64Wu8skPNR0VXMWz32jyOxyfxf9dTe1eMPT/UEgoop622bP5qS9QWWsoogwJ2uDUxx oW9QICvuyoIzg6dLgsWB/tieP/iVYxMT6GYa+Cm0lRJSKfLmEUjKw3SBOMY7EqQf6vfHtnsdGFPM 9SNKgnICRxOUQAg4yCFyTjtznbj30UtWiU8MpmzFK7kTQhZHICgndsDA+nHqz9scYGKiSKjBRnUT sdhbawKoQODggAgFTk5Hpbt/TyshrXVNyEhNrmSWqiMFC4VSAW80jzAD3UY2N/UcsQOAQG76PkqJ PPYsoiUnHl5DMo445ckk98DAG0jOMEmzQ0dMjn5ekRVZiNzAtnO7hQQSSAvC5B4IyMZI+ZkQRuqy PGGyqwSosZXJyFbgE9u5PuO+ciYqqh9lZgcdWn1W811nhlAepZSrspjH4ywHYsCRgkZOQSuSPtpJ SXMTrEBMisjbfKkbJdx6gD3OPwnHJO085GAonWKZpYnETsYSF2xmXC8AHadqkc42knse4BxuberE zCGIiMBnl3lcqCOQWIyOABycDuTjmMiL3hrWkuJ2Gv0CyODmav0HNaPcHijeby2EoAGJM7F5GcYJ xwe+3OF4HbTVUX64M+wW4Rbl8zfDVRI7DOAMMAW2lkOcbRuA/wAQ1D7/AOOXQKdVy9NQdUUNzu6A NU+RPHPFASGIDShuDuVck+pcAf1DMmtHUVpv4jemvNuelkOEjIAVowABh8KG257DAwD9ca7X+Cx8 bekMBI8L9aOnmsgnheazj6KOdQeK3UHTsNTM3RVVWxx4Bhp6pJS3cDHYenaeCey4PsdZtXXPVN+o 6OWHpmsoHDsTQVjFpQiOiLJgDA9RxgngKTkA8T2KChpZFVAYKSJ1aRdvltMPScsxBBUENnGc+rB4 5ZHhp40iNRPWQywwfzXmlA81corCRxHtcE4UAjn9VGuXbPhe0X536WmdG4mnHRRG4dc9Z00T11TZ oKKpoy8jx1DMY55AVGV5GQd6qT2weTgHVaXT4gOtqK4yPDV08yyII44VjHy5w3dQWBBCuBkAg7VP vu1el/N2rTkVgo1hXZGXl8xDg5ypHCYLbTkdgDkEBlr7qrwKXqismrVvcKVFSRNU2+rKVESuV4jB KliAfUf9DtJ1x/t9nAIJojdA7Krrh479YVtI4a+gxTMsXmKiiRtp9R/B+LK4H/uPuclLP4+dYQVV EFvMzsih8vDE6kZDFiDzuBGQcf4ffu83Hwa6rsqTyQWWnr6eGo/l1lHFE5kXbtUrEFJjQjOARyW4 wMahFxt16oKJqC4W6mip/wAflS0dPHUK47K2Rvfk5AwMHPHBx0oW4dxtoafT8LOC8JfN43dXRU77 77UoVYMjRphVX2wFOG3flnGR7nLx1D8X3V3UMU0cFstMHUsdM9PDff4aXqKYbi3l4B7L6CquSMx7 mDYB1D3q76KiWGGurINsjBYKSZosMOCQuApPqHqXt9h3Z2S7rUTOk9ZXzysadpPMaMyI24lW3Ox5 IJOTg89jrr4eUwAtj0vkP+JLqebJN++9Qjw8vfXHh1TXqLpu810lRcalauvlakSSSpkTJRWZtwIG 5+Mkepu+dXd0bdfHfqKgqbtbpqaWKO6Q26ZAIpTE8kQlWUghgsZCoWcnJZ+xI4r7/ZW81709NT09 wnnqZREIoql9xcn0hVyC4P2xzgexx1L4XdEXvwUo7nZGoLd/H6wwyTV0tSTCkgiG1RCOCkTSMNzy R7mZsMRhW6uFwox8pLwCOZr5LJIehaACVa1hs18qegounYLzNZLzX0mLjX2pFFbNKV9cdNJIXWFF J5YKzEEsPL4AhPht8MvTvw/z11xtLXK+zXWUQV8twnjmleIEuwUqil0LgF8ZLeWoGe2rg6SprlYL XVsrUlNUPtae4VBDucDnLHaCoY7sqsYx+GMZLar7qfq/p6ouEk9v6uhpZLZRh6qYTSPHNPgoSSih JGK4wFDACLCovlg69nDhosMAyBmUBYHOc824rnb/AMQDruzSr09a5ZaK5C2CrraqjpCzfL1EcUcd PGxxjPzFRvZCc7EwwUnB1+Gvw8u3h94YWvz4aVZ7lRfx5RNUhl2ztEFkIQ71KosIZcDJOMnnEe8Y fC8eNnxKdN/xC8XCPoe6U8swi5IgaFVQ+REN3lrO7QsDgnLsSvpCnpXpR7VWW7+AGhlpI6XFKlYj 798aZQbcDIUbISQGIYxIQPrGAlxNaqDQLjr4pup66fx56wm3sIWljjjgZWYIvlRk4JOBjLE4Pdjg c6ffh88ebjbJk6PvtwSntcjZtcjz4SCYkkxHthXPbPAPHZsixfFH4YLj4hda3i/2+vio6WpCpTmr XzJ5PJhjiXeEHDuFZsYz6gMZJ21TePhS63tmY5oqSvdS21Y6ldz43EBUOGz6WwCBnHGvCv4hBDin tuiCQRqtLWTZdGEg9y7ZsdXIIVASNlAUMTKrKGz7YP3Gp30l1KYLijM6pHKpVSDkow7Zz9DkY/P7 68ramw3vw/vLR+fXWK4qQxSEtBlccDGAOeOD9OdTfw++IPrPw0kMTs99tKs+6lueAwdnJYpIuGU5 J7gjJPGupHj4nUQgzDZy9XqXqSKBWjVSwA3bc4HbsP20/wBhrTcJGmSJmY4LMCAAcZ9z2515v9I/ HlK9wp4L5ZGp6YHy3rKKfzGUYPBjKjcDx/Vnk/XXSPhr8VvRnV9vBorvGswYxNS1JEExI99jHODg EHBH34OtrMS2TQFMyAjRWv8AEJdYWsFnt4dHkqa0vKhG4eSkTlzj3GSg4/xDUP8ABOyRWfo+S5Gn ip6m4zSOkcf/AKcIO1VHsM7N2BgDd7kbjAfGq8R9d1tpu9HcZ6ZbVSV1IzRTjHmTmKMFuf6dm8d8 bQfYZsjoyrp6DpSyUSVEU8sVFEk7ooTfKFHmPt9tzbmP3Y648DW4jiD5DrlAHmV3pWnD8MY0H4yS R4dvyVWeKPwoG/3eO4dFT22ywVCla2grA6xI/B8yHy1OAfdOADgj6aM6a+HHxLsKoKPxCol4A+Xk NQ0QOBxgqR398Z1flFcUkGNwJ7gg99FVF7F2lmoaNEdImCVFQQfL3Yztzkbh23AE5ztOASR05eFY aYlxbuuA2Z7NGlRDo3oPqWpSGlvnUdBW1QTZIttpXjAUNg7Zm/pO3G4ICTuCcgutu2Dw2slmpXKw CokePyS9QqlQgBCoigYVACQABxk5ySSU1nalt9OkMLkFvU0pIBkbABY4wOwAAAAAAAAAAD3DeFjV VDAge5P21IuD4SAWyIX36qPxEzxTnFQ+/wDQrU0jyWeQxysPVSv6d2BnCP7dhw3HHcY1Bq81lLVm musE0MisCIpCcbfqTk59+2QOdXX/ABiNiBkSEDsc51WPjH8RPhN4W11utfiLe6GgqquB6ukp6mhk qSUU7Sw2Rtt5yB2zg4zrh4/9ORS2/DnITy/j6cvp3LXBjZI+q4Zvqo5K9KCDhN8UnCkkkjB9/wBx +mgvy0ZDAGowxIxIqqN3IAXb9B9TqddI2zoLxUskd96Ru0Nwt8wwJrbVEhMgNsZDkxsMj0EAjsQN G3DwcLsr0N7qqZ1OdlRBHMv6YVSOw9/bXlX/AKcxrDYa0+B/NLotxmHcetp5fhV49QJI2RlO2LIU ht2OeMfTsOf762pWiWoDiJGjK+pUZihJ/M/qfzOnq4dB361UzebSGsjRseZTDf6cd9oG/wDsec6Y 6iWOCs+Wf+SVH8zauxlGeMA4O7AHBHOP34cuFmhflkFeIpdGNjJTbHg+aE06NK7KzM4XcdhDMcD6 tyffB5/TQhq3pJykGCxyAsrerJyeQDohmkkqnWCOWeNwDGrweZj7bgR37Edhz391C1ctLU7ahJFi TDAPGfTnkHOBn/TP20t0bwdSnmAgUSlVLIiwtmDyhvw20+oEf1fXse3bj76LRApHkl1Y85WXPp98 e+j4qqhkRHgn2tkAlkAYHOM5UHHt3/fGk4nljbfC6qc5KqdyliM5+nb35GffPGrMbtLPmq6AuKKY TKC4dPKEhXDZB3c/55zz7jRwE1Nw4aU5GxScbR9x9c/bRjXqRl8hvKUsDGsscAGCBnPbvwf150ka YyyqJ5WqFydrSE7v1PHH0+mTrMQ0c0IYWJSKhYtryBo2KAysV7g9uR2/77Y0X82Ix6HOyQZBLE/T ngcDjWUEkhaVYvMbJJO0nnGT7jjJH20W1XEkT1BDIQQAx3N3HuPtospOya1l6jVJJrbFcZJQVcSS xsgmUFxF6TyQfT2+o9uxzrma69OUVp6esln696chvdBbr+8lRdqrMJuDxElfKcYbcq5XLAKVjb2y R1Q9QnkiIyKx77H4RvfPPGD/AKaq34gOselug+jEuvUJL3Snl86zRUzZq5qkDbiMEEBcHDEgrtf6 ka7/AA3GTROGHbbr0q9vD3skTYeNv+w8lZjXmnvdKLnTSpLaapBLFgFlWNlBUlmGcYPv2z7DjVTd UfEn4Y9A1DRf7ZQmtjbyxb6JGrULHunp9C4/4XXBPOe2uPuu/EfrnxsuNVbFFRFTTylo+nLMS0bj cv8AvpFOHJOCSQEJXIxk6d+hvhA6ynqaWpuVvSjtAYTTrC8cdQuRlsPJtX2A3DeBnjXdh/TrC8un eT3D39qXHkxtHqD1V5H/AMQjo2KrZZbFe2hWTyklg8kiTt/SZBjP0yfz1T1NL8OXitbbhQ36y1fS kzXuoulPPS0u0FHPFOZKdXwhAB27fQTwSAcyGm+FeVJ4yl1sFZESc2j+LokjEgncjtuKMDjON2cY 4HGov1D8KHXND1UlUlvo6W3Tu8kM/m5WnBP/AKskYKnjbyO/svca67OE4eEHosze8ErO7FPfo6q8 E/2/4dek7rbrsnhhWr1J0rOTTXTp2apenr4juDDZMpXzlBClRKGHpypJ1Z/TfVNxrLBa+lYL/NUz iZbfsvqutypX2s582ZWXeNqMmTGGw3JPvyd/Cb54edbQWytrXpLhb61Y5bnEQzoN4BaNgpMiFSDj GTk5HONdg2y3WzxBe0m+XGSS8Sr5VJ1LYpWjiq2DOiBxgpuVg+APSSTgDIBTiInQs/3DpGDW66ze /v8AehQ2HnMzqn5K86B7vcLnHDX0VLRUxViXpq9pi2MELtMSek88542/fIbLRb5Lf1BdOoblWGp+ ZVaaihYfy6enEhOV5JLSEIScDO1B7cpa2X/6OeEjXPqm6Jca+CRYjWtGIi7NJsQBRnB2tzjPZjrF k6tpOpaIValTE8YYbVEwgQjspQnDEcMSBgHH58XGYSfDYLJhwS0klxrWuVjcd/sLXFMzPbjqozf+ i73fOsZ+rrf1fN0bStHFSSU1NSQSO1HGSWd5JFbaxJ3AgYUKB3J155+LvjjW/wC3XUVps/V176p6 ZWSKF6uuqBI9b5ZY/TAiMjEhRgHK59sda/Hz4zr0D4PLZrTVutz6okelWencr5VMu1puf+IMqY+j NrjH4Y/BybxE6hNyqI91LSyKkAljLo8x5ywHLKvGRg5/TW3gMLjAcTPtsBQ2HNIxUrs3RtKY/Dzw B6p8SrjBUlTa46uTfCZ/VO4yTuVTjgAZ3MQMDOddV23wNq/FFOofC/rWqkprlZbjT19FO0g3IkkG HAYbsowIIVeAcDPA10r0XZ7B0jZ4yHoTXQORUVUjgGQqSCSG5BUNgD6E44bUI6l6rs8fjl0zdKKr jqjXU0llm8vH8plIlhycfXzE/IrnRDicmLxRijblFGie3t8FBEIWEv1tcr+NHwO2zwxscV3PVLwU MtQaYTyIZkRhnG5QoIHB5BJ47a596w8MupPD+CG4SiK5WOXHk3e3OZKd8gEAnupwezAa76+K3r9+ qeipemBZ6kVAqJqhqhIy0YaKCXOSBx6jjnknGNc3dEU1TYjDJVMkdurbbEtRRSnclYojC4MX9Qz/ AFcfY69dwbDYrGYVrpT/ALLI9DpsuTiZY4XkDZVp4e+I9LTyQUl6iSopz6VqwAaiED8IVm/p5OV7 H2wdeiPwrtFaOkL/AFSy08kdTXgw1KTBfMjESkbSSMjLHj2OR7a86/Fjw8oenAvUvTHmv03NUPS1 FJJy9BUKSDGWP4kPdW/TuMm5/A/q/HT1pt1RK0sdVB5lMJo2j8qbcUwi9nV9uCR/XjtnSuKQvxmD kwp0P4N0mwObHKJCLC9BZPEawQ0ayPckiZWw0aneTjuMDOmSv+IDpOmnVQaieE7l3JDxkew5BGuW obxMC0rTM2SEEMQYng/XHt9xo15I6qQNNLNFhdwKqUDD64PB18zj4exuh1XfGJdsAKXVFL43dJVA 8s1dVSbmBV5qZ9v9s6faTr/p6v2NBeaFwvrPnSeW2382A1yZR1dFTUVQKuWrat2f+VlSIeWWB/rz zjHbH002C4yTvGjvDGgbHleXwf8AIjVnh0VaWEQnrUhdq011tlyHmJeaPcWztWoQgZ+mDz+WnOKg qLnKVpIoZJNgYsJAPbuGZhrhv5tmkcFEZYyGBGFA+x550qbqOsMMfk3CWFcFNkc7Iw4+x0r/ABjN NdPfvZQ4mm/Dqu3JiLfI0FWksUhxkI4b2GORkEaRSVNOzpFK4jldS6qB6mGe+uQbV4l3zp+EGlvd ZE+z8L1BkTH23ZGdPVN8QF+iSMPXw1Dx8gyQhzz+RHH5aQeHP/jt730UbiWEdYLqlqWN2YLKJiBn a644/wDw64A/8TLqKFuoul7CFbNNRNOsWfTGXcgkj3OEXH5nV7U3xF3eERz/AMOoPMb8Zyy7mH68 a43+MvqWTr3rAdR1ESU9Q7JTeQjFwoWMDAY44yGPbu2u7+n8EWYwyOGwPz0SMTNE+Ihg1XMs8Q9R OPrg6bZQA2R/YadZwSpyT+Q03T4GcZz9/bX0dcAhZiXcR9MfvpTHHnsMac7v0dcul7bZK6viEcN3 pjV02Cc7A7JhuODwD+TKffRdGyxQTFkBLjYGPtoAQ4WCiAPNIlUZ163/AAU9E1fRPw89ORVdUJzc d91RFORFHLyqD9Bk/cnXkiBtcA5C5wde53h3R0Ns8POmqK3yCeghttNHTsVzlPKUA68V+qHF0UUV 7kn0/wCrdhIhI82dk4yROsuV3FhwBt4AxnvolagswV42Ve7NEAw4+unXzIIIvJEqIcZYjcAp/wBB 9s63VIAqTLWxOB/SithgfuQNfPeiGpFe/NdJ0WuhTXG7vlyW2hidxP8Aln/LWyGQbk2q4HO7Axn2 /LTlUx0qhJZAJFPGdxJBHbjvjRTrHMF8sBfcBmAx9e/bQmKtUAhcNc2iQxSo8hMk7rnPv21h/Nhy VcAZ4YsPw/ljWZKWWWoAPmeXgkEYXH66wYJ5uJFcKBx6eSPf350kNsKgxxO6E0c5hAErFTg7gQp1 pNLURqnlgbVXlieT+eNZgpS0TJG7SKFIaHacn77T31imgIDKkm+NTtKsh9J/01eUgWCoBJlOl+qK huIQlJ1d24KyImR35BHcay10ggk82QwiA8GTdt/Lv2Oj4YXnaRJIy+Bz5fLfbjSaWlgZlYxrvHKn jg++hNinEIS95A7vfNag0UzecAsdS5wfWYmb/wB3OO2lirQsozMN3Y+Xlh++dFJQLLEVZN4HdX5B 0mj6diVcKI1H0GBjTM42olXmaazBcw+JF26j8V/DCWg6ut9Z03a1rporwOi4jXPUIgQpJt5/lE7z v3MDsx2I1vYfgL8D+jYaHqLqa8XGsom8tTQdQ3aCggMzDAjfYFbcTkhQ4PGDnB1NuiIqeLommq+h 6SXqCeOKWlqrLJJFbLjLXArUxxSU/wDLWKQbagbFBDRnjzAFDeffxU+MXWXiJ1NTUPUUElkW2PIB ZAjRfLy7sHereouBgZbn6Yzr9HZMPhjpGLOvZ4ns130C884vedSvWnoaht9iSro+nqO0Wiz07BYq SyxJFCSed+xVABxxkFgeT7DTobs9TMZYDUrtP+8jXcmfoQONea/wIeN6dG2uu6brHqWp5a75nZTz NG4BQDOe2AVPHuSPrrue4+PfQfTUdBNcqw/O1yE0gliYeYAcFUl2iMkcAgEke+uyx7HND2pTmFWM lwd1HnqxYuSrw5yPfv3zx9dFtaKsV4q6GpkqIWAQQPAEkjwDyP5hMmBnPpzj8himur/jA6M6et3z Rs3UVzZSQy0zIgQ59yHA7/Vf0Gqtu/8A4lNhtE8SweH94eB8gzXO6+Uuf/jFJx+n+WuZi8LgcSD0 0bSfAfm06KWePVjiPNdb2u03CsmHzJitlfvZvJjyFYZ9shN2c5O4dzkkaIuttrLXLm4GuoDEdksw RcRFgSXbbx23HO9h2Cgkga5E6c/8QezXO6BrnR9O22iZAVihStmmH+NdwEa7mOMEqAMck8ZvK1+M vh940U1to6PxCpHMcbPJR1EkNG7S8sS6Mw2QxgeoqN7Dcc9jrjT/AKe4diGgwjL20T9CT75rox8S xcerjfiivFj4gejvB/psV96ray4UgkWmhjoV3TzuVzgZ2rwqn1BiUypzlueCvil+Oe/+MkIsVgjn 6a6XRTG0QlPzFauThpSCdoII/lgsAc+o8YaPjV8aqLxB8U4qW2yJ/DLFTx0yrTOJYnqiimofPY+o bCRkHy8gkHXM4aSsnIVS8jtgAdzoIMJDggWYcefM+fYs82IlxJzSHy5J66cuYt1U8nzctDOwwlXC WDRZ7n0nJyMj9Trsj4LfD2p636+uzzdVdQ1VrC06mqp3aOKtnfzCi+XNG/mgRqpyyrtJOMjDFk8J PgmpbXS2q++IPUlus1wqQjU3T9cqmTzGbgsmT5hUFf5bADc3O8KUfoa7fEF4S/CDUy0FsjrOo+oo 4vVT08m6QSkD1Tztgq7FfV3IAUBVCAa60TTGQ5+gWdXb19SV/gr0Jb2grKCsqIykctZFQCjklLbs ekOwYgRuzZxtwBgZ4r7pf4kOn6+pRr9Qy0BJXfVRxeatQAu1Q4zlQRnI5yT+eqgn/wDEGpPGynFj 6g6Th6ZtwjeIXKC4GaWJZXXzNxkCr6lTZu42gn2ODYvQ3QnQXUlxqWtnUVpuSQAH5RLtTVLAONwG Y25IyFyQMHIBOAdJm4fheI30zA47XsfUUfWwmRTy4d2aMq3rZ4pdET1crUF9glp6L01ES0z7QRIq IeIvwHG1W5HKgZ4Onnp+9W7qKmc2mdblJBE0rusbImARySVPJJibBBOPqFGmaviezdOGnt6wW6mi BiEc9OkkUZBYhxGw2nBJwR3y3POdcgeK3jX1f4edTzWfrqmmrBUpmmuFojFLFJGF/EIwojmxuwQC D7EjAGuDN+leHxAgueb7x+PutX+RlfoQPfmu740tk1JFU211kpEcSGSkZGGQDt24GCw9H7Y7aTy2 6zXWSR6y3w1rlZCfOpiUyQu1gp/CxxweOMewGuHfDPr2etpLZS2a8vSVbwxpJPRTvEyoAo3f0mQY znjuoIBwSvTts8ap7n1k1ujWjktfy9RUtUVQ2CERwb9gPZVyrbic4RThTnGuDL+k5mtL8LICByOh +4+i3R8Qi2kBBPZVKWVHhd0rUnzWsNugYCRjLSLsYgqSfw4AIXbxyBj6jGkh8EegKyqkWPpSnwim BZDIN2dy5VSjcNkHkKCBgZ7jXL/WXxCdd9T/ABZ0ts8M1WW30fT0U1bZ54hNR14QyVI2hiNhzNGg kBRlbODkAGa/EPfeoOofCW7XjoG83qiS7yruhhkanltccfplonRUBUpIs+51CsV8sMWBJ0eH/Tsm VpklI7Rz05A3868kMmNjaCGsvvTx4xeN3Sfgn1A1p/8Axb0/JBTLMKi2WYVNTTzM5VVYjKx7kVsh iH/ARwcA2z/EN1deOipL7bqnpSwUziN6K59T29bSaoEgGZEErM4APLlFTlsMcHPEFm8COvulauK8 VXTM9wussQntyO0VygmlbtLKF8xSq+rhxjftDcBsOtB4RV3iFPXXjxV8XrbZKtapqVrU9Q10ujzK 21VWkhYkKcEL2GFGBtKk+0wsTMHCIYW0B632k9q473GRxc7dW31R/FvGkV1d11472mhtMBUPSW2v SdBJzsURxOtMGOGIzKXIQnGM6aOr+kPDfwR6jkpr71fdLlS2oQmpSimEtdWvJGHjiMbN5aGQF+Tj ykpATlpUJiF88DqWnpqmy9PXG6COxwtdpzdaCK3zUkxLLHEyh2bzHTbJvfDIihggBGqJ6yqb70vd Hhr7dTq47x1hir1YMQxZXIKhjgAsmCcEE8Eae59a80ul1D4EeNNN4gePd2uMtRc7Zdr3SzU9HQSl DSUqIyEJEVxt8uCNhkjnBOd2M9WdP3Gx9XdXmO31H8RFNmnlalk/lxDPCs6khic/hH0PqyMa80fD frWmret7PX3GhoY2pWVkWGJKfztvpWPCAA5z37kA53dteh1B4ldE2TwMF+vVnp7S1ZQ010qbnZcw EPLIUl8sQY9W8R4jJAXzlVlCprVC6m5io4KTdd+MVH4d3Ortd6ss1RK8yC001BTb5J4vKjBkdjwP 5pmTg52heM90EvxCWmG6xJebV1JZZd3mrTVNEI5Gzko5UPngnA9JHpztBOBzb1X/AOJFZ3sdfDbO iZq69mGSior9ca1Y6qBWTa8ypHFiIscEIjHBXlm41XviD8bl7uVm6dr+m3o6PqWKSYy1M1uhnlpo yqjy0eRTgMxc4GcKq4I3MNeKxvAMPiJJZ2u6zjY5b+H4XSixjmtawjQaL0CqKC1+IFJS1rWynaOR 2857vayGMZDnCo43eWWKnaw/pDYxyIZ1d8OPSXUMlZJFaKmyVbSmZpKSM7fuBu9JPpHsOCffgTbo bqS8QWbp2i66p6Wkv9wpUMJM5p3qpCnIeIriObYFYxqWwHJGNpAVVfiZ01aKG73CXqKlrFtdKZ5a OOVWZlJIjIUMAFPmKOcqDt+vPjxwXikchiiYdOY29TQ96rpOfhHszFwHlr8tVzz1N8Ic9U1RNZbt BVRK+UhnjMbNkktlgSuVAH0z6vw8A1X1T8N3UXSEZne2y1hiUtJ8q+/ZgEnO3vyrDt3wM5bnpfor 4hqHxMuU8Nk6UuckKbyK+J0k+Xkdh2j4U7guGBfG3tk8ilOo/jgufRfXd06ev1poOp620VT0YayT zQZAVR6CThiCAGUglWU7Sw7ddnC+LwtBc5p7r19ar5rjvEDichTp4bdR2/p/wTqqGqaGKpBq66Wn Y7pZmViFDA88ooXDfRMfaHJ8UPXtBBRz21kpXpwPmZaxVnFT9AFREVFz/h57er69NWPpuzdeVtpu M9jSKor0gqjFO+HjbyQ6pIcjdghY/qcn6nREngb0n1TFJX0VljhpIVKJVUTCP5h+wZB+FkXj1kEE qcAg7tYYMe7DyPLhV6k9n5XquJYZjoMPFBYLWDNfad6rlpzTH0n8YdtvbW6zdVOnRNyreJJVkLow JAUBwv8AJLkty/4QAc8g66CiuxsUaW2lh2wRJmCOH0jA9gR9ee+fr765h6j+D2zVMFW9BU1tFcSR FKlZD50LTcElj6T3O0cNlj2JA1IeiJvEXw6NtsV8SHrbpyKJkWrtrCSto413BQSMbwNuAhBbB4Pp xr1mE47hpKbI6vH78l56TBSsbmAtXpT+L1op6gR/Nv5oHMbnBXAy3f6ak1s8SqXqaFpLXiqjRmBk VwVyBlgWzgYBBP5j3IGqzobtYLzDFi5QQTzE7UroBTVbkHARVmUMxyPxHOCDzqL+IHVFBB03WUtF 1ZZKOyUpC1sNNc4xJKxOfLd+Su4k5PJJJJB7a9RHNG5l5wR3flcxwcDsrlvXjvZOnbVdK6Wo86nt cEk9TLF6vwrnYnbcxHYZ515I/Ej41TeO3ivc+qq2M08UwSClow+4U9Oq4RN3u3djj+pm1KPiJ8RK nxAmprNaqwnp6lIlK0yvHDNPjuqttYhFO0FhljvY9wBz9UUVTCxzC7AkkOF3Z5PcDP01zpcQ2R2V p2To6G6s/wAJfHnqPwYvUFX0tfa6y1C4WUU8m5ZEzwHRso+MnAYEc9teo/wef+IFaviErqTpHqS3 Cx9buj+W1Od1JXlE3OU/qjbAZtjZGF4Y9teKVRUzR1JaNJUGcK20gnVjeBfip1P4N+J1n68sFtpr lcrb5vlw3BCYnEkbRsSFZTna7YIPf66oOA3KN1OC+iLzY3OwgDjOAdYNLC5yCST7liTj99edXRX/ AIoHSXU1J/D+vugb30zUSSCRqiyytPCeQfMLxmKRfUOwDdu51070F8TPh14m0tJT9L+IKR1MhMcV DPURpWkj2MNTH5jHjv7/AF1MxOwvwI+9JeUcir2aj2DieRPyI/1Gk09PUhfRVCQH+mQDt+f/AE1X 3UPV1R09Z6q6VvWdptNvpYzLNV11tzsReSc/MAZx9B+ntqtbP4/2TqV2ltXjHYJ42UbVmp1pWUk+ 4YHP2GdZMRiOiADonG+yv/8AS0Q4d0mocNO4/hdCi0CVT50NPKc52zRhxpDP0/04EkkqLdbIvLGS fLRQo+/b++qv/hN06qijqX8QjUx53AUcLNER9PRIAw/Me2kc/hdG8h8m4WyeE4O6pZ4GQg5GMRn9 ydcefETAdTBlw/8AdX2tbGQMb8U1HuB/pS3re4dJw9OV1PQyWyK4EKUeKNc7t4HBHvyf76rc7nMe IwT32+bwCMexx7f66eafwku0qp5TUdwEef8A8nrQSuD6cBlAPG7uf+id+i+pKCdU/hcsdQ84Ify2 KqCcZZ4ww7Ej7Y14viAxWJeJH4fINtAV2sIYYm5WyA32lJYkTZ5ix08TllGG3ZXv+LA49+ew+ugW ljXn0OHGDnO7Hbn2/Y6WXGyTW92jq6q0wzbxKN1YInbtndkAngfbtpO1C7JvF0oPLY5yaxGGPt75 AJ/POuO5sm2Vbg50m1V4qK9b9dWnw/6VuPUN6aSnoaCNXJjy7TEkBUUHGWYkKB/11x90PYbp8TfX NV1F1Zd4KeSqV4rfBRyI706q5IjSIZKKo5LNtLEjkgnM2+Lq4DrnxQ6e8M7XfKbyqGFq65TSx4iE jRNIm4kZYogYgfWUc/SxbVRW/wAK/DuKS0uKRWo2RGixL8tAP99MGAUs7FdoJ77BjbuwPofAuHiG H9xIOs75D+15vH4gyyCMcli22Sx+H1VF0v0BY4Ki/YCvNIgkhoyT+OaQZLuPuQFBAGOxeIPCgXe7 VEHWl2rOq61I46hRNK8dGhYuMLAmFxmNhk/sCM6abR130H0LQGnn6ko4bmzZkLOyyK59Srtw24Dj uD6i3I3al9y63iqbFTX1IfOR6XzHlo4jN5iRyREqV5ZCN0uO4GSSwxosXPNjIpG4e25SK/8AcOfu 0ccIw729IN/kUm/+m3S9OnmpY7TDHUx/w+UQ0MZKZYiNgGU4bexUnGTvXJwg072i20Vpqj/BIP4D T0CPDHHaSUiqZWOWZ1PpcptCjIOCX7HBFS9R/EDBe6D5Wx0aJJXEKzVc7MW9QJ8sL7bQx76Y08eO pFVbYJ7dSmMeXJNIwQ+kACU7iTlt244BOWPB15WCHGAtc15B8V15XQbGiPBXV1X4f2bruib5m02m p6iVY5vm5KVVp5pUIIG4ZaPONu5W7d/tUFzrJ7Pdbmb3bLxUS0zSNNY9i+Wq42JOq4U5G3aTlVHL 4yDqJXnr+o+bBXqGrratVLJKZGjWI990cS8nBA9Tf/aDzq6eoLmvjr4JWXxRtMEct/tJNsu6Qqwj q4QxjMi5ALAnsRxyy59J17XByTSR/wC+sw5jmPz4LiStja/qDQps6x8Rvnul5ulutaePqK2wx+Ws mAYquIgDMjZz5kfADD3IbuATzH0/1N1R4L9US/wiWobpycmooagsaoUcftDMF5ZBxiQD25B9rFvV AaWirLfHRmktFIGuEE9VP55qY5W2lEkLl8jHYgAeX2zjVfNTNRs0W6UtE+SPN28A/wCEHIH2OpiJ H4aT9xG74vqPpp90siMs6N42Tv1inTnxkPTLL1GOl/EC3U5SCKdxNbKwctgoSdhJ/qBPbs2MBVar FUfD/wBIdP8ATlyeGl6jr6o7oIhG0Uh5Lyhh/SAox/7sYB41yj42TS9PeJcdwtEklJVywRzFoT2l 5BAx3PAz9yddY+Fl/wDEPquw9OQVnhvdOvLTWUZmqGqKRYzSndszFM2FJIIYAFWAz37667Mk+HAA AseWvv8Apc/N0cma9kxdXdfyWMCoNM1TWTSEeRTyYYnHDAHkggY/QZ7acum79Sda9PT1SVMkV+tr +b5JpzFItQj7lLZwTuCgEfXOpdP8NV9PU093uVRauiKFZHp7Ra71XrUypEVG6Q7S2XPPp5IH9R1F Oo7J4WdASw3q8eJV2r6uJPJefp23GH5h1fKjfJlHIwQWJz2z9NZ4cH0ej2/b0Wh8rZDbfor6vUp6 ns/T92pqmqhW4UyVoqKRC0ZkXanfOM4cEKwwSM5yOKS8R+iJ+s56+8pans9dbzxWwYZbnSqW3o8Y 5imQDjjnOOcA6fPhy8RbV1N0ddum4al5YbZVvWWinr3R6lKcFtwfbxtILDB55I7FdK+qOqbJFc7j UtVT+bR22pryEVgk8ZjKNuBAGWIyB7kkjPGuzhcQ+GQFjqIWKSISMoi1zL08aSXr+42a8V9FLSdT BrdX0gkGyiYginKA4yyPt9WPr75Ool0TXVnQrX/pyrkqoaq315hqGQb4FWNm3A8ZQlgCGBxlRkat T4OvDw+MvU94nvlfcKW1UKxzLHTqMNK7ttVDIpAUbW7a7ag+EPwtuHVld1HcbDNX3KuKvOaiskET 4AHMasAc4yQcg50yYte4OYbPNLZYBBC5Lt1aep6OCS3wy1E1Qqv5cK+a7Oe4wvJP/edWdQfDN4gd SWqWpiscojVML81IsMj5I4VWcEfqBrt3o7p6w9IUa0tmsVvtcCgBVpYEhAH0wq86lKP5g2sm33Pq wNcZvCGSPL3ONXsFr/cPaBS8z+qPCy89HQhL1RXS2IG2ZrVlEbHPAEudv7E6SUPR94vdJJU0dNJW U1OAJZIBvdc/Rc5I474OvT6ahSrp5IXjEkTjDQy4ZT+YPB/XVXdX/Db0J1AklRFa6jpqtfB+csEx h2H6+SMp/wDo/rrPLwZzdYX346H8JrcVejwuAyJaOoWklgl9Y27ZE9R/f76S1dFQC6Cetgpo2Qbd rIVkRj7gqQc/fXSnWXwreIEIH+z3VcHU1ERv21VQ1NOpHYKp3KfY8uOfbVS9SeEniD0/LLJfukLl OuNzVEFOavP3Lx7sfvrjvws8OjmkJ7Jb0DlF6eSjnp18qojmhU94ZfVntggn99KlSOan4hQEsMMx OCOPftpipbfZv5rrSqjsSHEajv8AdTjJ/wBdOsJjWOOKGoiAIGzeNu38hz/prHkvZPDS4WBYRstv C07FJDTqOXTIwRj+3565o8Zb7TXuhimin80/MZwg9sH9vbXSdbCyW6rMk67BE/oUbAwwffH+R1xX drksFPUxOpfcykAe3313uEtyh5PcskwyjxUdmclcBR37nk6efDroyXrjrO32tFZonfzKgg8iJeWP 7Z/fSBJqeZDmQQjYeWGct7DXZ3wa/DH1JdOlp+q5aWkpIbwAlJLVy7JBCD+MLjszfXGQM624/FNw sJeTROg8VniidM8Maq7+KG2o3QlkkjpvKW3VggjAbd5cbIRtH2/lr+2ucp4mgpUB4JG7GvULxk+F aiqvBfq+mFTLc7pDQtWUywgDE8Q8wKAM5zgrjv6teZF1dWcbfw7RrDwbEtngLW/xP9rRiYHQuGbm mtl82NmHBxyPvr2B8A+jxZvDHo6rWoq3qHs9KSKiZtqsYwcBc4wNeTnh5YqfqbrixWernFLTXCth ppJmOAgZwM59vz17S2m1VVHRRUirBT0tOiQRRqS7hFAGDnAzxrz/AOqZnNEUbe8/RFhIy8l3YnET u7AtUMWc+pXQcY/z0bGPKYeoKh57AKeexx20hq7VFJHFDK8qAjI2sYyw+h2n7aURRSUkce0hoxwo ycgfTJ7n89fPS4nddToz2pcqM9ON0ZZ939R40nlo4KsFammDuD6c9/0OtgkYplRJfIc8qxyoP2Pf /v30YjSSxkSMrMOFkVtu06uyDYROYd7RqyCKnCpmGLGNy4OOPrraCSI5KszFCRtZPUfoR9dJlpBI rbtrHdlQ2OCfy9tGLEYpA0pBYEhQV7fT9NEM3MKhmA3SlDK7eY+EVgCABgAj662MfEhaYK0n9O3k j8/caT/OI+9JffgFBwD79zrDVFKyKI/MLDkqx/66uyVVknQomSlp7kDDVSTKQwbdDK0bjHtuRlOP tnGt5oIIgvy85aNe3HqP2I7nWk705CtnazHawkTGR9jo+aOnEW0Q71xzuA3D788fX31OkkrKdlV2 ViPfJudWzIuAVJxj9NFyJJM5fD8/RT/oNaRW40rboZJCw49bE/uDnW8mUIEhCtjsvb/LUzZt1Hsz gWPouXOtviJ8GevfCqzWa19H3Xr+sFFS5jYuklK0cY2rPUgA71Z2O9NxyWGQGxrk3qXwiofFy7ms h8Q5YWoaYQTU3UkMk1VQKrEsXdBvlp1XcRIqOygKGVV9QW/Cn4s9L9I2Weh6svMFloYZfMLbTI9Q ufweWgY7wc4YrjDEZAHNh+K3xkeHPWaUtPSWG7zy27miun8uKeJ9wIMbZLIMAe4z+mv0rI2JwD3E U7Wr/v6+q8rrah3SXhRX+Hl0tTWmGjvtgiinln6g6cuQuETOkJLySMsaeUo3KcHJQAEn+ovNJ4/9 F+L/AEbR9C3uKayXOGeVKeWtYPCxZiVaMjAjfceVYchQAxyRqpLn4ldP3K/VHUHTVs6k6VvENMWr LnZ6+KKGbLBDJJTCLHqLqrIHCsT2GTqlLy3zVynqIJTUyMxlYiERg55JCLwoH0GAMcaxdKGdXcc/ +/0PBFVjVdPWnxRofBcSUNYv8YmkGJraspkilXJKvv3DYCO2w4IIJB4OmvqH4j+hbyJ3bwtkiqZV 2iX+N7wnHsrQEEfZ932xk554e81FdIaiueaaaTvNIS5fAA7n6DH9tESVoIOM8jIyP76U6Zx0RAKV 9SdRWO8TGW32F7G552QVJljY+3DDI/f/AJai1XXbIyikBj+pGtI4aioheaKKRokYK0gGQCc4BP1O G4+gJ9jog0VR7xHdnHq4x+mk2LsqbIgrubnVpeA3U1j8O7vdOrbpQQ3e62unU2igqA3lipZuJ2xx iMA4Gc7nUjkZFfWmBkro0aNJnZwqI2SGY8Ae3vjXUdD01V9C9VSdN9RVvTvWtno9gr7dfri/kw1B RGmipwrGVCgfyt4BG6N/cAafGCesFFTHWvjZ1T4h3c3LqK51NTLuDIKbESIRnaAi4UY9jjP66gU8 8tVMZmzliWPc8n7nkn766o8WvBPw1ont1d0jcLjbY7vTx1lPSrMKqGBGeRXRtw3AxlApJYZ78ZwK 7qPhx6scySUVHBcqWOngqZqjz1phAJhmNZPOK7SeMclSWADE8ajo3gnMFQKp15Zav0q2UAxtz/np fYuqKzp2p82ALuAwr8hk+hBUg5H7fUHVydI/C31Xca+km6lsp6ZtM7mMVl8lFGuR32qSHfnAyBtG QWZRlhPepvg56a8Iaa43bxH6zp4bfT5kpKCwK0tRXqc+WIjIAMsQccMAOWwOTQY4DMpah3R3xK1v S8Ua/wAcvc9IQMxzSeaT9QoLHH074+2pT1p8V3TfihYI+nrnYLrdmklR4ZXVBUwznjMJUtnJOMEe oYBGcHVZW0dKdL0S1NX0fVXa9XCVXtvT8jK1J5Ad4v58gxPLK0kZysJiA7hhnYH282i6dP1VLb+n LRRv1dUL5U9fYqIRin8zOKWlI5ZsNhphlyMKDtDNI7pXhtE2FRFrqLwp6M6StfTRrbTe2qOobftN VYJSgno4WY+ZNVFGdYyjAbsP6Qw3YJ2if9B9Y9PX95rlDfaOakoZSs7RuVeIKAN7BgF8sZ/3mdpI IG4jaeMPCSr6hsXV/wDsbaBbkttJGtX1IL3DGYJWBG5JQy7x5ZdYgincG3spUsSvV/jD1z4adJeC dhuV/qEt9BXobhB0faTirvEoJRCznJSE/jLyfhGAFZht0QxwgAAF3yR9EXgu7E19QdTXr4hPEK7V Hhu1F0lQNTU9su/XdUf/ADs8QO2OGOQgGNXkcKqqBI5C+42Cq7v4w2/wRo67pK0xStb7c0tNsnfM tTVxyESS5xkBpAwJwp2qn+ELpl+HjxlvniB40Ut/u1DRUPTHSVvuHUFL01aKZIaamjjp9m7B9Uj5 KYeVmbPvjXMdw6lqr3cK6sqJJKyvnkZ3kcl2Z2bczEnuc5/fXOinmOJc53Z5Ak/XT5pr2sEYDeas +5+OXiN4gOOn4rk1R/Fplp4aCAJEFZnG0BzzycAlm7d+2pH4SeAt6r0rq6G8Wuk6gpmkYU8kpZo1 RUJKSJlTUEzDZGSCdp75UGkOmr3XWOslqqTet02NHTsCV+WLDDSk/XaWAH3J9hnoOw+PXRvQEHTc VvpYayW10i+bGYTIlXVs0Mk00sn4su8QUkZ/lkoAAc63Ah/WeUiuxWhcrr0x4M+DvU8V0Y07XKKO ntLwKs1VLVl1MzgkhvRGSrMTzvUewA5T8avHy8+LlTQU70y2zp+1kmltiTNKqSMAGO5uwwAqxrhU UAAZ3M0f8UvEO/eKHU9Rd7lL6DlKenhUpDBFkkJGvsuSTzkkkkkkk6x4VdDVvXXVVHaaerS35Jea rZd3y6cBmK+/cAD6n276B8nSOpqgHajOkaG2X67Uoq7lSWm3KVEzzbXkA3EttjJG47ScZKjgeoe1 ieI3iLZ7d0aOmLReq/qmBIEpqasuluSj+TpROah4YQssm8STFWMjYYeUFBIZhq/r58A3QlL4f0VY vW1fUdQTJG09dOIvl4ZJtpgjkiALRqRvJcvgeW/PAzCPDX/w8OpepeuIrV1xerd4f2xJVQvVVCTV NSpJGYo0dlAyAu92CgsANx40RY8dWlLFrlmx2upvd1pKSjt8l0r6p0ipaGljMkksjY2qqLyxJIGO 5Ouufhl+Gm79JdfU/W/ip0zW0VFa4WrbPZcxxTVtajDy0ZSQI1QgsfMKchPxDI1dfjXL0p8BvS9N avDXoquTq6tpp6YX640aytEwZVareY7tx9IaOJQsfr3sgwoPGVJ8RniutZNVf7Uz1sjP5sj18cc5 Zs5HLqT37DPbI7catmRp6/yQ6nZehlDRdS+KTUd68SKj+CdSUFwmrOm6KziKempR8uS0LeYm6TiK VZDko+8+rKpsa+mPEbrrxqsFHJ0/4JW2emijeao6hvlG0tEIiAT5EETEOwCKuxXdyUVWyRkcGf8A 603WciPS9RXWtulM0gkMcNQI0DDP9KqBxubjtzrpX4W/i5qOmbSvSdqgp6CxXCsWWprrhNPQUlv8 whSzyIkiKjEAYwBnPPPDw5ruqx1eKlXur0uPV9V4TeFN1vVnW0XSRZREq2+j8lKWSUbPNq6R1/k+ vAJ9QG9QM41wh4aXboq6VtJJ1R0yt16nFZKalluUwmvNTPM3lgqBtRVGAdnqYtncCNdZ9SfHH0J1 dSVVqoErVExaKSatpQIjD2J3K5YhhnIIHBOdczeB/RFnpviBa9xRm6W+jqaq5UiRALToFDyRM5YA DjbtHpIfb2wRrHj5WNAN3Wy04VjnOqt/ou2/CJk8Qq2ajqKNre1CkhkoZCIxNT7lWOMj8TKECFwB yfScqSptu5pb7XEbhcbjFQwRt5IeoK08ak425YlRgYAxg5yAOwzUXTPhxSdTNRXW7T3Yy2+E0ppq WpalhqUdQ7q7rhx3TgFeYxnJwBJem/Bbprpqqa4Wi43WmjkmG2ja7TNCBtUMrAvkqdicEnOBkgYA +QvbA/8A/K5wrkACP/7D6L6PjA+Sdz8PGA3QCz/Sn1DW0NwFYlJcqSpnpuJUpa1ZpYcgEAqc49+f scZ40qgaH5RdrybnyCdm8k+rJ++O/PsRz203UNvNBFTw2+CLyXYySoqiVpRhsYk3gLtJA749PbJx pWkkeBOu1ItwBbnCMGxnIP3Axx7a5bo42vOQGu+kiLDNq5BqexI5LW/zIkp91LFO53QBYyrMRjKs RlWIYAk9wqjGQdRuv6C6LudQk95stkCmMrJugjUkOzbt3YE4QepjkENjHJMwZ4KreUq4g8+weZUe YEZiMgKAo9iOO3IP1xoYTLFHMXwineTE6MMqMcAk4HqfIyDjH56hbl6xcQrkwULviPr/AGqpuPwy eH92tk9LFbY6KukZwr0tU7uBtXDqpbkBst7gjGcFiorW4fArTzEww9SfzJnVo42o9pIwCQxWQ4PK kYH14Pt0xKCriBp5JQVebyINu0bGT0g9gTvPBODgjOtbXHb6Glm+aiieCJNki1ZllRlOTgAKRjdy SMds/fTmYrEMsRvI+f1WF3DIsx7FyDdvgmvlsuRp5rhQytK0m2IU7xTMgIKna5CnJI/qxx76J6C+ Gu5dMdZx0nU3R8d7t10pSsVbBWtDBRSKNxV5VGY2YYAJx3wvBJ12fa6OCgd/4G01ioJGDyQx1WyF iQ24iPeQvO4/h7qM8ZBSz2ieOoq5Em+aSbcSs0pmUq2dwy/qGQcY7ADA+o1jiuIjBEmvlXv0WNvD 2RODqJIXEFV4B3Pw8vFwvF+s/iLRWeKZpIaC1yCtSFBgnzZF4ZByMjkjnSypufRl5pEo6HxMiih8 oPHSXW3Usu0HOPXLEG3e2CcjXYFTc+nOmOoIepLp1FT2msFKYIxLXMsTKzK5/lAbN2EGSOdpweDg Ua6+D8dRJfaeWO53ieVxM8Nu2SVO44ZnRB5SgDdnCKcgkc9+izirpBmfEfIJhiDGihXbaqu5eHvh vVWo1NT1JboI4goaqYRTKjkd2BYjkgkKAO3Gqei6V6CpL6tN031N1DfKghlkkoLdvgP/AMSVY/8A fOrc616d8LOqKdqe09FVlrrJAxV5aiNGU7ePSGYsCwz+LPcZXULg6KHTNDIKesudNEmc/JVLIyZ7 KAXGfpxka7EWKaWEkEHyXPzNHWDPT2FKLT4fdaW8mbpTryON0YI3lxsmw/8AFhjyOOMe+p/a/Er4 g+modkt4tHUEMZyN80kMjjv3ICjVHx9Q32k3GG/32nRVyscjiQHPPCkvnv3P10spvEXrighndb2K tY2RFiqrXGd/Bzgxlff6/wCmmtkkHwu9+S0tnhI6wI+Y+6vei+LzxXsOWuPSVxqCBykYp6yMD6gR iNwOf8R0p/8A2pF76Woy128PbhTyI7KshrpII5VB7qrxtg4z6Sf11Qv/ANdOo6Ab6/pazzwg58xj PA3392B/TjSmLx3pZ3Jm6BwkgJZoa9ZOfbCtGO+tkeJmZuL8/wApD/20mz68vwusej//ABVuiL5D Sm9UN7tBmUeYZqGOrp4z9N0Tbz/9mftq1aD4o/B3rakWZb90YVmGWNWq00v6rJtYH9NeZPU/W9T1 hU0+en7dYYIJC6xxxrJLKeRzIMDjvgDTbUVrQRSGSfe6owj2vg5APJ4x39tOdiGSaSxg/Nc0lrH/ AOs+Y0V5+EyL4nePHV/WFDcongjuFTNRUjNieeKUyRwDYe8SZiVu+Nyj8ujrz0knWl6Tpy3dSf7O pRUyKsjU3nK1PEqxlcZC7S0kQIbg4PB5xzx8EdnpZ5b9d5pttfTyU1FCsKYjCSyp5jAjHsoHYYJH 1Gnr4tY6633mwXGjqZrf5FNMTVU1Q0ErEyn0rtdSwH2z754A11iGxYcmtNtOzbRZc3Xsq4up/htu E9LKJB0vcaymf5uCc0U1G7sNuGRo3IR9wA4HHpPY8Smj6crfDzomNOk+nx1RVipBajSuRUif0pI2 +Ujao9WcAkMeRycc4fDR4hdQ9X9apaLzd66vigovMhkqqosyBNqng8htpI3KQcM2cnDCd+MHXvV/ gv4MNPSXKWs6tFQq3G+UMfnmmRsKxRGVUJAESZIz+MkAkk8WKOBriYwQO86ei6XSOlaHEqU+L9R0 TSdP9MV/iZ07LY62uqHtctwskqTLZZsboxNOoXvGynBVgOSARyeWPFfozqPwR6uktd6mkv8AaZCX pq9I9jTQcHfuBG4ruwyk8bhyBg66X8EPFSfxo+Gq+1filRRXyjt0dXJXfML5NRV0CR745/LGPWWR lVvTynBB51THxlXOxX3w68Juo7VHJS0dZQP8rSzALLHS+WhWJxzkDOMhsDPY5GNjY2k5SNCkkkAm 1Wfhx1Va/ErrNLBDVt0xQPHireaEvLIeP5S+WOCzEgMecY/q7+hPhNTWLw4g6Z8MaCB3pLra56Wp qNoQg7XaF2O31MfLmC+w+/fXH/gBQdNdJ+Elt6+u/T9tpKqzrU1EtQYzNPW4lYI5YBmiRQAgK8kj O1savX4UfHLp3xAhs90mukVd1bV16QXGOqp5BURN+GGNAkZCR7cKHZlDMTnkkac1kbDQ0vRIJcRf v2FF/GGmht1/oq+BK+uqkcw1C0CuqRPIrRt5qHKHbhmEhyOeRnUY8Oa/pH+HPb7r4b3Pq7rCKqmU xS1PlxCMEHB5HIDLu9P3zzjU++JqliorffKisr6igWZpSlXFCrtIm8RjcCpxuZWUMAMHsdQv4cuj JfEC3deiy9WVvTkkN0QxyRKsqSh4t3Jb1gg5zhh7ZzjWeNhkBblv0P1NJ+IAAHv3snu89adcW2vt 9PYOkOgfDGmnDqLnc6fzXiVRuO1wADx9eDo2zeKVJf55rNcvFGp8Q7zErTvS9O7KSFEVSTnY3YfY k8dtc/fEN0VB0xe5bdVdY2/qarqoJIppllknenBwPUGJCMfYA541zJ0ldLl4S+IMVbbqsxV9DKHp phwlQnfB/wDcP78a24ecC46II8PtQWF7MtFdT+LPW/UVmq660dLdNQUN1hqY5HqpKppquPI5KyMS WRwQQwbga5V6kuFd1RepI+ornLb1apeSSMQAwI7N6iAp/wC8a7XMvT3xHdCxXOwTQ2m7UMbCSIgm SCRjlopADkxn1bWwSu7HbXPXVvRN3tN2np7/AGBFdMoqT7lMjk+kIy8MPfPIx+elSukid19WnmmN cHKSeHZtXgRaE6qs96a6VtxV7ay0myQTxMoMgRSScqdh45019feOd6FxtcNNco7XQTUiTbFgEnmn cy79/fuvbCkHORkajN5jPStDDUwUlBW0VSFWqojHlI5k3oWUdgG2kg475HtqXdJ2+3+LVNZemYek 6i6TyQrKtPTSBJ6ZTKyvIjsCABsGQSoIP1xoekOzfX/qbHkB6wB9V274H9FfwG3TV0ccb1lesb1V csYjE5C8P9hycD76vC1mQMq+oowzuPGfy1D+iunG6U6Zt9vy07UkEcIZzlSyqAD9+2pxbaSZVEjq ZpmGc5yP+utkbTSzuLeSkNJEwCkgDIzn30vVVpsMJQrH2JP+emWCephO4oykfQY1kVstQ5LsSAfq M509prUaIKCk0NaWKESh8+6ntpfFXMzYKLnnnGolBvUkmRsjtnS+Cs2kAyNnPY51obJaAhL6i0w3 BmMqjf3UocEH6g9x/fRS2+vDlVlw39Du2Mj6H/npZDX5AyFP30pWqjIGVUZ457Z08tY7UIdVW3WH QHT/AFj5lL1D09SVUyjh3jCy/pIuGH76o/rX4OpKiCSs6Nuyu6gkWu6sAcd9qTAfoNw9+W411+5i nAWWKORf+L2/LWIrbT72eEsjH2J3KPy1zJ8HHLq4eexTo5nM2K87Zfh+6tFou1Pcbc9h8mlncJXs CzsFb8ABO4fcZGvNe5yiSQ8/1YJPvr6O67p2K8UM1JWeVLBJGyeVMm5TkEcZHHf2OvnPv9nnttyr qOYBZ6aokidMe6sVP+WsGFwj8MX262kiu5apZmysbQ1G6b7HXvYb7brktPDW/J1MdR8vUrujl2MG 2sPcHGCPode4nSNxN06YtNb/AAsUC11DDOKDdt8gMgPlqFwBtzjjH5a8Mgdo3AkMvOPy17Z+EHV1 H174TdIXeiJqY6q1wO8jEA71QLIGULgEMrD047ca8x+pAGiKQ94+n9ro8KkDJHBSymU7yuAzqdoA yCye/wCeNeIHWiRJ1JdxAnlwLVzCNP8ACu9sD9te4kG8yAJU4Q9kkIz3/L++NeIHiNTG2dd9Q0ZG DT3GphIBz+GVh/ppf6Ze0mUDu+608VIc1tJntlQ1PW09TESk0MiyKynBBUggjXt/aaz+I2+iq3DF aqGKbesmd2UBzkD/AKHXh3SgCaMjI9Qzr3J6etlJTdN2KaB5DClDBtO0j0+WO4H5aL9SGui/+X2S uE/G++xbvDHU1WY2kkZvxAHO7HY6PjEM0ZWFIypOdrA5/X/po56WJZgqALG542IMZP1zz+2syWZ4 wXjp2JU/71c4z9x7a8M5uawF3nRiSwEm89YnQGUgL2A9QH2/to9JfPXLK6IBgGPI575Ot1leGVRJ CjJzuJPqB9++NGyT+VEVVlIB3bUYg4/X8/roBG0Cis/Q0KO6LamkdAYgSndt5wR/zH30WE8pcNFI ZH4VtvH1wOcaMdWjkjdxJGoHYgg8/caDuY5AZldkIwZGZfUQfyzqxG1V0QOhQp2TKq0BXA/9TII/ LaedJppljbLgF/wk7j+2ex0rimqImlR49yuQQQ4cj6EH7/noj5o08mwyEqwAIJx+x+ukZDyWboiT YNhElI1pypEpVTyGOSPvnRqTIHEm9o9owuz6/Q54I0dIPLhDK7ID6QzFWHPsffSU7ahdm8ZQ4ZRy PzxoaynZIyZTZFJWxjkQZKoB2IYbj/3986J/DwrIFHbdIAcfcZ0TSpGMykBSCQQQeNGCkkmywJIB xjOcfbQOcQluDrsLy4s3wJ9T114npbnKtDKokl3gb0kVSMKrkqoZsnG4gZHJGdS6yfArZq9JJK+5 XahBEwMc9PHDJEVZdrsA7L5Y9Q75Y7cEAgnveq6doOprbJTTUaLSyU700kcrrGrKwAYAhiw3fi3D g+lsnbjSCj6aFrpIqRflqj5WNqeiSanClU3ehGByBxvBZSoOS2BjXsDxzFFoDnUe7/pWJuHYBlIv vv7Lmmw/BZ4d0dgp4qihe6PRyPJLLLLIi17IfLw4VlEYV94wjsPwsTtwDJ6r4XOlLdRwQ1VmoaeW OJ0ZqaKOIeW6NHIGCBSfTKRuCbt44wAuOhqCxCOopaiGvpVuEZCRqKTbCct6o0DElN4woLNg7Tk4 9Ok8ljappyztBSs8olNCQ0jgf8D72RHAVTuGMeo4xzrDLjcS4ZjL28/vp6fZA+2GgBS5k6g+E/pC pp6alhs8dJQ0yFYITOyO0hUGSQvhjuBHGHZeVyFVeCX+DLoKl/hcLdOXCSseeOZpfmVLxxKoAWRH Tbhj3AycjAHIU9C0PStS3T8drM1PWTOsjN/5gO4YIRFJ5bDDHAPcc++AuSukkkhpIKaggmaBIsyt 5hdpD5Sr5eFJ3hdpJfcwGA2W9JKxjcQW5hMfXfmsoOmrVQC/Cd0StmqadaCvq2rFO+V49sysxjO7 zFULlgFj+uJSTtLlihq/hM6Gu8Bjloaikpo6hUjakMSNGMDaC53GQYJzk5OMkgAEdHUhudvsUlO1 VuLKVzTtkyBQWMahvT5amTbt5PDAA7gA2VVXVyR0cxSfdJviieCJjCNzLu3bPVgkjf8AgJGTxhzI H77EXfSlX0RJulzr058EPTiGp+bepY1bg000SKZKPY4KSoNzMwyApQEkqxJAOzMN8RukPFJuoEpb r4cUnWlHbKhzBcoqSKqqJlADF5MHLHYyA+YGyVTlm5PXlJSV9UKOpq4Kw0rkvIkp80yRltyosW0/ QZAOSTnYARpzpqmqWniRY0qVQeY5WJomOXAKDAySWywYZyJCQHBwetheO4rDGg7MP/cL7EIi0srz 36p69uHWdlrenXI6TsNuCmoo7nFW08ckrhiIysMTeoeWcKxQFs4BwTqxvCH4o/C/wG8OqSSi6Z6h vd7cuI7hWRxrKAwxupg5lWGIFWU5GW34y+0lewquB79QyQ1VupLhS1R8gx1SxyCdYyVBIkJLLnt3 5JI450y3Dw+gqoqkp0jQSVSIGWEwkxu3lBDlQwI9CqrISSyoq8hGOu4z9WPOvRDXv5eip2HI3XJd 1+Jyy+JU9Dcb5SXGwpWxOkLVm2eHYMJtHlKrKnIUEoAeee+uYuvevqm93+YU96qf4ZGPl0qY5nBN OnpCruOSNowqnsOMDXphU+D9oqIQ1X0nZ6umKU0ckj0qz06gAZjUEsSCIo0DAHAVQf6tNtL8Mfhj dJo3rug7JHVKoaOWNGgp3A3kkiMhWyQi7cAr6t2QDpv/AIpjkoPjPkliIgry5rutK6s6vS7UEMlM tONlLCqCTyIUTCDtg7UHLY55budTnovx5vnT1wWGqu9wW3yzqaqkpwoWZdw3ofTldy5GVwVPIBOv Qul+GTwq6fr4Xg6Wo0p4EaJ6mKaoJGQ3mK5D8hgcFTlirMuMDlp6s+Bvwq6wvDVBtldYpZCZhBbp 1jEu8lm5ZWA2s3cdl4xxwbP1LCHUWuHp+VYjJGi4H6Goaa53G79UdVzM9noHNfcsyfzK+pdiY6ZW 5JLt3PsNzE9tRzrDrWv6+6nr+or1IjT1JUIkQBSBFXbHEgJ4VEVVXJzgZznnXcVb/wCHl0iLy8rX 6rprdKDMbeaRg0BBz/LfzGIwSRsYMSFbkH1BluX/AIfttanht9pvguVTDJMRJXL5avgMCgCFj6eW GFIzvBOjbxzBZ8xcb222980wRvIyhcc9JddV/RtFf6WyMI5b3Rm3VdV5bNJ8sxBkiB7BXITce+Fw CATkmj6eu9woiyRpSU+MjaAhb++B3/trsiw/ATdaOVGuFbRxlCqeWExtmALfzMEqFVAp2A5bcRke 1ydB/Cv0n0lezUV7NfbzSsJJIokWGgba7Dd5JBUbgoON+MHsvACZ+PYdlmM2UyPDueaK5S8Dfgth 8TbO926g6jPT9qiqDEqtTlpZ9oDMyk4RVxnDc5IPGBrqroP4G/CTphFpai2P1TXxN5gqLjK2xxtX epiGxRwynkkjI9Xtq7qHoyClshFHaaCnpoWISGKJIY0cI2SRwqpxkn3yMHjSkWaGapE8vnzuczSF Y+TuABJyPSw27vVyBxtyvHlMTxXF4hxJJa30/C7EcMTALZ2aqrbF8LvhTYZZko+io6dpYhlpIZqg +TuB2kyM8fLrgYJJGAOTkr//ANWnwtuFDFjw7tdFLKi1KzQo1LKhZQ6qjxtv3ZOCAcALnJBOrKtc NNaLXtpqGmtKkRiNfOUYVSdodVwD6VOASfzBGCpneVn8meb+RHGhSFg59jt2OOC2VAyoJ7E4Dayf ucQTma8k+J/K6IbG4Cmt07guavFXwA6zW2Qw+HHWstqgq4xJ/Buo5RUbooSDCsDshlWNWdv95kDc DkDOq6r/ABE+MnpF2kbpq318DRRxyx01FTTpMdgXe3ltuZjtyTnHfgAYHZNO1XHa1aaGmlq1Ltvl kcyStGQQSAPSMg55ZiC2OCcpUqbhOq0b7HYSJF80rmE7htUoBtYbihQ8cgfYka9BBx/HQty5w6v/ AFa+/O1km4bE63DRec/WvxVePdl6gWbrTpS1TR+YyJRXXppHhJQKCEcjfgKU/C/Yr9tXH4OeMfgZ 4x2e3Qdd9H2uwX9WEdRU/IU4o9zHaJS7DeqckncCAduS3Zuv6N6aoUnzh8u43LDLITx3wg29gAMj cDwcZJB0z3Honp+50L/NdOWW4QRgmJKu1QyRoQMkEN2LEsc8Zy/09PQi/Vkn/nRB3bR/r7rnO4Y3 YOXBHjf1j4W+HvWF16e6Q6J6Y6pelVYYq+mUy08zbdySK8bkluQGAcqdp7nLGu+lfCnx38VLVcK6 iobrNZ6yEQTPcZRBTPGjeasaGQquxWTgL6VOBxnXqVbelrZbrdFDS2q10rU/liOKipY4GjdYgnC7 GyMZVdoyCwXjOzR/yNTMYnBjkqaN3ZZp0ARSFZVdlK9twDHaWxgAH3CcR+ppiajjAHj9gAmx8LaD 13ei8zrD8B/iBKXqa6rttmrVMZipZ5yWYt2GYg4ByVHJwM8ka6a6KNz+H7wXo+m+tp4aOrqBU1cC vKoSNcB/KbHqdywPCD0iT1lRsz0tR09RJG7RBqeNdoUTN5yqwwFTI/FtUN7bj6ec7TqI9brQz0ks FzpbbcqJZeIkpgI924gAK5YAjgE8f065DuKS41wZNRbvWxC7mCwsOHma5oJ7QSkfgHcZ7j4c2Cjg r42dXebzSkj4hapcRsDyH3JC2QMksVztyNWfULN8yJaMu1KiKMIVY7uM4LY4wGwMYPfnnEEXxQ6V 6bs1voTX0la1NClOEtxdo1CxbfLj9JCHCkAEkYPb3DNcPHi02rzVFBU1sxIjhkhKR+fjdtBLHKHD MefdQfrjlvilxEhc0aE+9wtEuIfNK6R7gLJNDv8AVWXUGmanSVZXhhl2gs0SjgMQfSVO0eoc85z7 aQujDMkVTBI8ZMyieOQb0JIO0hiRyoJzye/GqfunxFw08fm2/p+CCREyyPUlmVRnIKrgsOGJHY+n 3xphu/jpergJqCiqoKU+bIr1NFncwOPwliQigqvJJOcHOmNwk7dwK8f6Sf3Qj52PHVdKCvWslR3r AtQjBafy4AoK5O1Qd4Ldif1J5B013XqK02GqeGStt9P/ACw7VU0wUrk/gwSSB6QRxjt9DjlG79Zd W1e1JKyrmp5dzS+bXqu5snsAeBj14IPGP1b47v5khmck7iQQ8T8E5ABbPHGTg/fkDs/9jfxkapRx tfxtdGV/ir0ZbZI4orhFDuXzFNEJZI/N52nAXaM45HBBOCNRS6/EDR0dRHDarVVVaxIVjq6mRcO+ QexBYDOMnvx9uaXe8tTvLmqiq0bA8p5V9IQ4A55J5BwSQPfWRvuE7ZStiw2/iVFjLFgcEYAUAZbP sMDnGtLcHE3UhK/fPJHKlZVZ4/dVSNTywQ0EBhGS0MRZlJz/AFOTjkfTJx99MN48YOo7oIaKaoqZ llZZAYanYgUcqhQBSSBjGex5/Kub9cKHp+ajpaiGrFbOwCozHZzgbiwHlpgj1MdvHB7E6eK2kliI 8iFYackMgd2zkAYyEyO5OPzxrZ0DIzYbv3JbsS4us2kd+q6+6SwyxW+mhRnUNPLIZZGGCRkkZB5H Gew+2m+jtcq1lRTSrUxpG+1JU9UWQ2fURnIzjPHPbTzWVFTTQuKgClqY1zK0DyIXAOCOQOPt/wBd M0F2kr5D8s7oIgqu6I+FB5wGAxjg8KPYj305g0OiUZWuJcURNb6pRPOJY6iQF/L2eoYI/GoAyp+5 OPy02/w+61NMlPNJMokY740Eg3JkH8RBGeMcY7akNDXkRzSUzJHNuBaSqChFRicu/bGOCRwTntpA 15q7lWyZNIvpULI1R5jSgEZO3+lfw8HP99Na4lJMrapF0tgMY8/MFOVIcGUFmACk7Qfryc8f6aa5 onb0ReVUO53SSBsjdt44zz+eNOtddq6UBjUCmPp5IVQOAQRk4GOOMHv7aZ6wx/MSK9xp6ZXAURxO 8asp7kgHaeSOwIGhaATqshfGXUE23TfTjyKyp8oSgO3kofw/QZyM88D89J5GhicfzUh3r61d8MAT kE7hxkY5P104yIkD+ZF5FUsJMjB32hTySCeTjsdIrktqrZVeehpjKh80PHGJUYkknJC+3H5/rxoF e/wqdThbRqi1gKziR6eFlYH+ZLkIVYbRkKB9Tg/YaZaemPmyJlaQxEKokc7vzB9z2+49tO0scBp4 /lhMqMuBEjjynBxkBSM47H6AdtJ5YTSmCSNS6Mo/mmXBU/Qqx9iO/wCXOjaSCkFrgTorj+DfrOR6 +4WKYUtuo6OjmuKxQ8GV1qqaR1OS2/CQkKO4Bb6nVhfGp0XHU2O3XmngkkngqwnnpJhYoZdxAIxg +ox5Oe7D6nXLXhL15UeEviUL7BQRSB0YoJh2VyDvTOSGR1z2wcEdm16CXGipvGnwikpLPdZYJJ4U jiqUZl2kDdHvx349Le24MO6ka9cyp8OWDchYzo7MuBvCnxDq/CzxAsvUT0s8tFSzE1ESMqu8Tpsk CjIyecgEjJAGurLT4dzwdOde9SdGdVxdTdJXajnvVFaqZd1XS3JkdjtBPp44CnncqcArluSuqOlq zpaurKS4JUUtzgrXp2ocAyAJgk8cY3HggkHDHJ1p0/1p1H0LWGs6bvU9rr1UDKEK8ozjDjs2Pow+ mvPhwHUIWpj8pFLq3wYvVZ4t9KX+3dbdHTdG+HdXZo/nLpVXLZNX1CmJTKzrsVRsh/w49s+og80f FJ4zW/xH8QLVYemHiTpnpqgS10EKI3kAYXzM7tpBGFjPt/LyCQRpu6s8Qur/ABGgSlv1/ra9Tk/K wuY4dxLZLIuAxKsyk/Q/TUepLCtJBBVQ0lHSwmIb1MZ3kMF2l+eByuMjnkZyDrUJ2tbYGypzu+06 2+mguNvt1FU3R6KzgvTJPKsktNCwG4grH3Y+n6nHOONdHfB14Z2ebxvsl7oevLHVGxwVNdU0VLQ1 sE5i8pos+ZJEqbd0iZBbkex1zv07PFaxcbfXtBLY6zBqqamYKX2ZKyIDwHXcxUntyDlWYHuj4Z/B pPCXw/uXUNbUWyol6hIqaW6xgrJ/C1RHXCNg7pWwPL9t4JJ2nSGHO8EctUFZyFEPiq6kqKHpCWB7 hHbJ6WjFGkYQs9QrSPIezqdwJYAgEYzkcgjiu2dXdQU9pqKKivNTR0VdVCWeFH2CVlBUZI57fp9e 2rr+LHxDlvFbBbIa2jmiq5jWmkClpIUx5aAOVxyAWyrA5ZhjGNUNDTRQ02wtvdQP68jnuQO/PP5a aXGOOu1OnNuACS1vzAdyJ3WUPsMUZBz9xjTJfLLNf6WNZnni8okqZhnyyfuNSWSlkcBIgiqSOSSD x35z31mqpJKYqsUUrlhu2JyG9vr9/b6aTG7ajqshPIAqKdJzX7o6+C52u6tSViKyiaE7d5A/C6ng qex1ex+KtLn04bd1d0zFWMEyKy3hd0bAja6q+cEH6Ee+qlq0SCNJHjUbTn1jt9sHkc60akMwhMaC SNjlXRcYPGeftka2NxT9nbKg3mVdNN4jeBFXTbKmK5hQGX5dPM8tg2CVI5IG4ZHOQdTTwP8AG/oy p8ULVYeh+k5LaogkSoutZK3nLTrlyoyc43n+/wC3Kc9tjSVi8YaXuHPODqd/D9XQ9MeNVqvFXU/K s4lhaockAvIhUKxP1OBz9dObNHsGgKFpXqpa4FqqKGRsD75xn9/fTpFXx7kigVmmXjIGFz/rqJ0f U9Ijo8ldSjAysfmBv39hpXJ1/HLIRGY4Ex6mVgcjXSBFXaHKVMZG8sfzmDS//m07Z+50UgMrEyVA jK9inIH5aitReocIXlEiuOH3blxpdW1ctBGvmJ/JPJcjPt7H6aTICdQmMrZPkFQYpjGZvMUdnxjT tExKB0wQvBI5xqFJWQoqN50bbuy7hnThTXGWMFtxU44APOlsfl3RltlTWlqI58AuF49Q7HSioq0V VRSdnb1L7aitFXTKVlDBcDIyNLBdTUo43Hv27D89b2uzDTdZyKUlo5BVMqq2Yhw3HOnISNRTRMnq R22kexH/AE1DbZcSJPSd6qeWTnB/PUip635giISOGchQ+MjB1nc4jVNDQVKIagSSBJMjPsdeCPxi 9Mp0l8SHiRbEQQpFe6iaJV7KkreaoH6ONe7NRUqH3Y/mwNkqOMjsca8bf/ExskFi+LG83CJ1mivN DSVk0cZBMbCPySPscQhv/loy8PaqDCAVyQW3Hn8Y7HXqz8BPU8F9+GyyQLGYqq1VdTQyEDBJ3+YC D91kH99eYcnSqT0hraOriqqNVLM28I8f2ZTzn8tehX/hyXy13/wmunTVFQ1T3C2VzVNcy7XEqygC NlGQRwhXAB/DnPOvI/qSJ0mCBaLIcD9Qt2BB6YX2FdaMYpHQJOyk4UDkjg68YPHZ6JvG7r1qMl6T +N1nlkdj/Ob+2c69jamk/hiVU0kbx7AztG2VYbQSCQRndga8Pb5dmut8uNZJl3qamSZ2PuWYk/56 4v6VY4PmcewD6rbxGw1oKU2SMVV0pE2th50Xb9QWHGvcS3kRUlNCFKOsaBPTlQoGMa8XvDOJa3xD 6RhaMwrJcqZMNzkGVede1pmkSVwTIVB7qwUqNX+qJP8AbCzuJ+iHhpou8kVDXyjeJ1CQL6QSOO5w cHJ0r+ekji/kzyNv9LlovVj2wRjWganlJjqD5pcHDsc/cdhpMFMUyCVgEU5V1Qkd/rz/AH14wPc3 Wl2+mOYECvJKpXnkpWkRtzAcrzhvvtPOdbQOKmm5LqWBZiucqw/0P30poprfJI8rQ5kU5LLMMSDP Yxt2+nB/TUst/V/S09ERPbkiq0/lkLSnDD2IYA4/f661Qta80XBvio6ZzR8NlQt6hKiNAXDSDj1E 4x7ADn/TWHmlqY41U0xGDjcmH/LnT1cLVa7g7S2aoSCoPJo6iYq5++JMcfkcaR1fTlyipzPVW0xp H6mddpU/c4ONLIkJurHaLIQGQO308U1OaR3MK7Y5l91c7m591P8Ay1iXyozseQFHxkA8j6d9KK9V ZYGWGN9owVmBdf8A4nuNIJgoCss0dMAwLIvPf+n64/y0pzb+EojG0jM0i0o81Qp/8wspByox/bSj 5WprIhURwOm7j0kMSfoRnOD+WkVRVChcqJA6PgYePBx/r+h0pgljP9D+rnCOWR19x30sGvi9/VZt A0goyphliT+ZD/T68EKVI+o9v7aNopqdIANyvk5zw3+eipq2SRZBI+Vx/L3HLDHtz7aSqlPOM+XK McYyFx++o92WiNklw5pDBHOKZ5oahYmkEpVm3bQzEgYK4zj/AAnOMggAlcME9HE84F52GaMFFZJJ I2hV8gIBtG8bcEFssPVtxkHUijWO20oopHMW6RZTGmKnzgWyGUAcnvxxyAc4AOiYLc1fO0VRb6mt hSNnSthp3Ic5kwC23dyACTyozjcTty/M8u6gv3rvqPYSH5STZHv5oyiiilg+XWnpTKQUYBSF/EjD yz27KuMk+o59iNaQSwmJ46ulFBJKVmRpYDCefV6hsIH4SODgEAEcnDZR1ElXVqYrX5U8ax4nMAIZ WVhneWGG3Ajv6cfhG4EKaOiqKWkjRjVzCSIu0piOZhu2gsGY5XGFySSe4xuOgkzD4m/Lksxa8izp aC2+mlhICQQOkoEUs0ahcBSF2qVxvx/SOwJIBJBY6Vt8k1M8ccqTHzBTSpxEWQFmBVcHcx55Gc+2 QBiW2KlTDMPnZpZJVZmDeWFUhRu2f1gcuEwxznHOSVb06CnmT5yjq1plURqVEjBVD/iKsccD6Nzk 9uAk6AFtojC+qCb5KdbczxUtI8al1V4pX27mLKVCFmBVSYxhQNpAG4hVxrY0ZpaWiWCE0DYMQcpJ N92AAwAGYH1YweeTk5PoauolkFHA67EIBT5c+pcsoIY8rzgkn7/mdBXUVXPOklQ9REyNFP8AKbmT njbt7kgNtBGDlgAPbQtDjsrIbFqQPn+UfSXKnqVVqaGc1CMplA2sSPqXb0kqqDJZwOckAldFVxkm ogayV6Sh2bPMqHKIPqdnq4A3Dk4G7ILejWlNV0QiqIaWekVAiFNgUGOMMcsoJ243rnI24wSO40tF ygraWjNbIxZyX2AEDYMAKRnlsj6A+rgDk60ZhrY1+XYoJ4zdAeqYpbMJqZoYKgy08LMrxSxFuEIP qL+psBS2RlsEhS2MskvN+ltVRN5VNcbnGIIiywxSOfMYnkhQCMB8keruB3404UrQR2k01ucRxSzJ NCkMq7ZDkMuBt9Ody4OSPSxHY7jGudTT2pah6ipV0SN8+jZs2kSMGT0uEBcnb6h6RnJyLjiG+v45 JBkiIOtJto62suSLM1nmo6XdtUTIuSWAEgY87OFzgjGNvJJON7hd4Ldf44qW4SUqPsYwxVDI7FUB ClRguQfLQ8fhP1505VV9h6frzH8zXGSST+VVA75OcEkDH4BuUKx9OByPxZB6rt8L1LhJYKeWNoBN UxhYpEXO5wXIGzBGCfTjJxjZqwHM56926A9EWkC0zJHNBLG1LVFKtXcx1II4GW/E2MOwKjLnGQQD ztBUbB/vLbCtNTu3mVcSMUYyHKOzhxlScooPcYQ/8WlaWyJ6ySrhqKymlgp/91C+BwTgHlW7DO1v 8TAcgnWnyNxlooZqp6epeMhXECLDGjFgdyDJUgYGVDYBb6c6S1zqJkJ9/wDEkN1019/JGmouNtp9 vy7BURYQF8yN5PTlH2lSc5DDLKBkEknbgZr3vFNKWVoTSpJJlTG5YKASuBjPIKqG5HuMbQumy4R4 rqSFp4IFr22kyqWMiblG0nIyxXJBbH+7G5eSNHyU5ra+SA0zPBDL5bfMlqeSPHOCOWCDezD6+Zkk BSQ6Ql4IOiN7dnAeiLjuE8zXCpkDpHMis5WMv5ki/Q7vSdowGB7g45By6y1DWuVQp81HjbzahCqR uxLEhyQecFOcZLFe/O1vobbPUTVclTJEmzERhYkNGu87gMtg4MgAXJBypAyvKuBqSeeRngSudwAV 8sxIwIdPUCOAPLCqcg+wJ7nL1m1mIUjJAsmlhzR3GmmkicTs+YFTAIlbGCyx+wUENtGedx4OScV9 UknlyjFNJBHkeXUS+Vu4HqXsVAPf+nzMkgsNx7JT0kBqC5mSURSfzcyCWMqCqYJbBCrzg8kZGAvK aogaqklfyik0zZRZHOGzvVAqkDy8YGMA4IAwTndoMt2L9E3pHuOh2ThBW1tTOs7uWppm/k+kDejJ xwCrEFm/EP6lA2gjOjaKSqjp0gkRkpp9x2lF2wrgghQuQuAowMkNtwM6b0aWleWQ1oqnkX+RHWOF SNS0auc5O8jDIBgEkt23FiwX7xO6X6em+RqqtZJYIm86CBCqop2q2FGEXKllU7iByMjJBvK+Q6e/ FM6YtbeZTKkrkWlQTQGeMiORiqF9vLbuVB5wVO1cYzzhfUUt0gadIYkVVhWIxSRtHloYiApUNnO7 b6iPUecenIOoLTfEx0jb6aqJ6crpVpWGw01YnlOduQrYZdpAK+x5A99Qbrb4o3rI6X/Z+y0vTluR fU86LLUSuVK7VdeFUEKw9ztU8cjXRbgJqz5h87+ie3GltVqrmkrHMLSymK5PQl2kkI8lQyt7A7zn dtGzIHJGOAAwXnr+xWOGSjqbhBI0i/zIKWQyL5CsFAdkJJIyW2hlHpO086oO4eIs/WdVNFcbg2xw DP8ALl0D+rj8OcYGe654JUfRjutZSPDL5skW+ORA6MmXRdpypHcZ79+ASeAdMbg7IzoXY87tFq4u pfHuOirUFBZ5auEMAs95k2CbOEBKgtlSVYHd2A5x3DU3xGXO6jzntdJQM8mUYIZMZyW4HA4dSSMb ipIPB1VDXd6MKYXiWrJCbojhlIwDuUZHb2P+Ij3IKeRP4tUySVrs9E7CWRaiNfKUbiTuyvfJ2jHZ h7++4QQk9ZqEcQc51nT34KdVvif1B1aZNlWx8pMtBBI0O8AkLvC91AV2IJ4APYEAaV03U9mtcEUs kYs9XOjzBZEJ8v0OxTIZvUBJ27HByccxaj6QrKyjZY54rTHEj1EdRVxELIwH4AwIJYhgFJxnPJHb Uy8V6mOjsFotylXWICCneWHzMLGAgdwMHGVBJ5wT2AOnZGCsmy7GAxZiZNO5t9WutrvzA7bCj01X BcK1BHU1LIxCbVYEJuIIw2MseBnn3b2bTVX3l5mmBppCQQhSGIFhgkjbgBecE4YdyuTjST+NrNCY ZagVDRkllpVkKjkc5PbIUAYBGQf8IyhmuVOIPMRxPUKTsVWBVt2R6kjAxkE84+5xjWhrXArk9M8p zq6mtkiXcIRRJF5fmMU8wEKWYMwwG9XHA+nHOdJKykrHrPJ+clSRAE8xQsZUAEYHK71y+SOBxgdt CG9UqROlLAkikjEy1Zxyc4zycZJ44I3dh21imvlvMStU00jwRzGJ8SNIEYAZycdyT+WWwOcAGGuB 2V2/4b3WY6p5BJG5eVShKAkqygZBYMM8k/c47jvrWhq4vl3VWqFjiJcpWzSq6nnCAkdxk4GAPUMg 50hr61rjHLCkEkk8R4C5jXHdSxPqQYxkEA9xn30uFeIo1hioIZIVC8pMXkU4wc54XsexPOmFhaDq qss0tFxy1LVMaJAAjDKRh0cAEjLH6429hnHI4PGiTVeRsdkhDessIYSXGOSeARz9RjOfz06W3xB6 nsNFELQKSehilKx0dVGs6bnc5YOJEce+Apx3ONNHUPV156vvC11XZ4LbVCmMMot9XJKtQVZsHYye gntlieAO+NXkIFivVMfGwMzMOvh91tcr/BSzQU0kM0tQAGWKKpSVo1wTlsOAnB7Z+5PbS3MMMizw SGmYIHl3OZA4GSrek4yfvz3030kdQVdpUkjnn5dZVBQhmJwxVRgY5OQc57862njqJp44khq2gABY 7gkYJHDbM8gAYxgY3HtjVObY0WVwcScug9+CX0tuljqWmcU0kW1kWIwllBOfUGB9RIQdsYB/M6Jl usFGi00CxKwjwPLcDb6jg855G4nH1zppq4aOS6VOyNknD75YoHYFgRzmIcD8PYDuARxnRr08M1ZW tmpWiiD+SkmzzlAYgNjHdVGCAPcc5GhDA4UUbGgiuxKvnDdqp3LKYGUiNdpVDycYJ/pOBk/Q5540 lp4YzLiBIQQxVmRSgXscMxOMdweBjcv01paYmiSW4QJLOWQBQ7KyLz6ggbBwD7ZOeO2lNW9NTVK7 mCVByqyxjByQCV9JOSMjOPrjUoNNIeiY06i0gE0FHQbKWZHeR1VzKy45yRnHIxjvgD3+mUNSXjWY UaU9TK8RUqiSho8D2YrtPB9u2dLisccUUcRqzNuKgNSKWkPOAvpz2Izn+3bSeGhpyY0SGtAkYbkU tESQvODjtj2OmjK06IwI2/CEyJ0o0EkLyIBI8e2OFD/MIPBLMSuc8ggjB++hUWyGCkMbSPTQIdsq LL5e45wMBWA/QjUgUSU5jMcYhjmKhCwJdo/xdn7E88DA9WdI62kKypXVKQS8ggS+kHsOfScE84z7 9+OdMEhu7Q5tdCmiKpES4WNmEOYz6mBOckMeO32576TLcoKmRZmjy+chHRiGbHvkZPb99PsUNPKk U0XnRxsrEKrj6ZIwAA4H1GONNpsMaztNb6tUM0odWkUAM/uvp55Hfnn9ObDhsUhzyBrsob1PRqY4 q6mImkgXzNqsVZkxgptPfHBH5cZzrsD4UPH+33m0W+0VVSlBcqCGCgippJ0CVkZU+lc4JYkFlznB JUEByDy3dLLNCY4Yw5cgZYhjk4LHGck9vtjOofcbPXdJ18lXTJ5NCsgkY05y4fgZjKnnkA8H2yMa 7eAxIZTXeSwOdZ10Xoj8QXgQnjBQL1X0vVM99gg+XSll2KkxXdiKQuCY5FLnv+LhTtyG1xb1p0RU dLTJY7jA8d3gCy3HzOfIc4KR7hjgDGTyNzEf082T4b/GFe7faaaOouBV2bzpJmVZW2k8+YpHrQks cZDKcgEDv0XQ+P3RHV9JcKbqCnoblQeU0AnWNWSqXgnYkwDpkAHbvyOM4ONbcRh2zOzxGnFMa2lx P1XQ0lu6muElEfLp5ZFmjSGTescMih0UHP8AhYD9OdO9vlrbUen6mzQCa411ukjEDx+clePmZ43h kiI9YYKqbcf0DHO0jpa5UfgDfaj5x+l7pUTU9HHTBKWoZF8pF2IcCYjcqrjLHPAzzqZ9D0VBWm2w dDdE2XpqkpYJktt7vjpW1qlS8pWFGY875Cd2843duMaxtwMgdq4fX6IKICpzwt+Gm12ystHWnUNF PR0EsU7RdK1tM8lXUShWXYoOAYSG372CsF4Pbfq3PHPxPo7F03QwV1/p7dPBRhqpjGXhgYHCQRY/ HwVxsBYKWbaMYFJfEx4zXSw3WyVFJfIGM1MstQnnrLX70bJjmBVQV9wm0Rtg8N3NHVHUXVfxBViW y1tUUfTdGiNUU05QRxvuzncqgu3A2kjKr6c4HL5WshZROg3K14dhLuqLJTHc+oZ/ELq+4dQVkNPE JZGctRwiNGz2A4BOBjkjJxzzo1bEKRlgp5jIki8AoG7/AHwQfb6d9Wf074VVnTAhlgko6h4Su2B1 IVec7gdrZPA7jU6oPC+xzy/MVMU4ZzvaKOoYID9guBjk9tcV+MiLrcTXcP7C6rOG4mQbDz/pUb/B ZYbcqvSSlT6jJsJXcecnIwO3fOk1PSKlSxjqcfyyWSVQf7A9vvrqmj8CrF1FTKKfp6qaJh6ZaeN0 3Z7neO4/M6cKP4Hv4r5jpeJrOkgwVq1WoIGOMBSp/dtc2TiOGadCffgmO4RPGM1A+Br6rjwV6SQS Bp1fcAhXbuyv0Gfbg/XSPyKaJgyQQthzs3OTye4A7Dk/212U/wAAL01HJjrCKo8oM0cUVtALHHA9 Un58Z/bTbVfBwlqpWNXUOqRGKQyqGVGbAB9B45z3zx2++lO4rhmg6n0KyOwMzRbguPJdi1AdhFFH 2JZuTj30XVWCKbe6uxYscEEkngdhrruD4TrQJqmiF1C1i7FMpiUBmf1AfiPsR759tMl1+FO8Wpx5 FbBUrguwkO3acDa3I7nOMDtohxbD3QdXisphfqSFUdh8ceuenrZFRNX0VQI4xDH89R7X2AYGXBBb jGSeffvo2o+ILrJNoM9sjU/hZAzrvH5t/wBNSm9eCt/6aqc1tsqH3JwY03gZA7kZIOSOP20wVXhh Vmkir2tM/l+ZtSYwtswfb8OAeNdJvEg4aO0QZCOSltj+MO8207bj07RzynG9qedoo3PudpBAJ+x1 1T4S+MdN4l9KW2sgilo5KjdH8tM28xurlducduPf2OuFKvpiC5bYnp4ctlUVhxu/t9dSzwx6qu/h I08dPAJrdWne8MjkhJBwJEPtwCD+n0GunhuJZXDpDosr2E7L0Gudqs1qnSSV4Wrjj+SjAKM/4h/y 0VNcpkdIo4REh4HlLn++uE5vFvriG5hpKylrJpCWkaopd7ofbkMD2xpxpviS68sTOmLfcEwCYWhk i2/Ubgx5/TXT/wAhhCdNL7lDE8Cyu+0uCG2O1QwdX/lBT3ORz+w0mp1pzUs0U7MnYI3t/wAxri+D 4sescIz9OW8QNjYslU7lM59woONH03xd9TiuSWKzUHof1hXdlbAyMcDTX43CULdt4oGtdsusK3xJ 6TtlyanufUttoZoOGp56+ONlP1ZCc6cj8TPh7Z4VX/bKyMCcnZVKG+ntnXmhfad+pep7vepgslTW zyVUmFLGPcxO0HuQM4H2Gt46KnZAZKRJBjkgYzjtxriP4izOcrfmtrWxkalej1X8UPhvUQvUQ9VR uU9JAilJPtx6ef01w5/4hdj6Z8TKe3+IPSbQVctFC0d2nSq2s6kr5RKPjkEsPTkncONMNss7VTxm ko55YD6TgMAn1wcYx9j7ate5/D706PC2svfihWVFH02sbTUtuoyI6ycqDhwSOEDMME5zgjHbK48Z LNK2m+/VdKLCCUFrRv3+fYvNILMYvMREMTcEK3+Y119/4efQzdUdSdU3Goj8qnpKaKKOYSEFZWbI 4Ug9gffXMHUvTaWq5yG2yrNSSZZI9+XhBPCOeAWA7410/wD+HFRUy+Ld7jraqsSqNtLxU0MmIJlD AN5iY9RG4FfoQdN4u/NgJCw1p9wsmHw8kWIaHjY+9V3alj6htr1ENq6hqKWZ4+JJJnqYpFB7GOXz ADg44I+uvJvxd8NaTonxD6jgoKpa/p2jrnihrcBBIQcsij+raxK5HB25HGvYO+1YtNouNRNOlrEd M7fPMAViIU4k259S8AkZ9iM68TuteoLrebtJHcWKNTuybShXnJyxB9ydcL9NGWQyue4kCgtvFHAh oKlfgS1FX+NXR7XSlq6uh/ikDSwUEbSTFQ2fQq8nGAcDng69gqTxJ6PuMiFuoKm2kuVYXq2VFEic cbnkTavbuT9teTfwjdLX7qbx26VNjnpop6CqWvlnlbCpEhG/I4JyDjA+uvW6rqLgFleGfyTG2JVA WXd9OP8AlpH6ikj/AHDGObm07TpqezRVwxucHxTtSm3V+17bcrTcFb0+bR3CJ+fbILYOfy99Zbpy 5syhqCnnWPLAwzJuVSO2ASSPoNV9J0j07fqmCreyWirp23ee9LQxOXPbJIGQefp+emKv8A+ihK8k Nvq6epHAWCvqqNQnOFyr9u/txnXlg3CuFEOA7i0/YLvmGQiirea2zUxDyxEbDtyVLAA/Rl7H650k Q0tQ/lyskk6/h2ybd324IJ/v7ajPR1FXdJ2w09p6juq26L0w0NdOKtIeeVWVgJfrjcx9sY407R11 yq697hVXAMGi2eUYl4Pfcp25z7HOfz0osjB6pPmB+UkRFrb08CnVWKRENSKp7hpF34X8+w0mME0y xhPLdAQVjPoKc/3/AL6IS41ALsjSOzZBBkJznvjJ7fbJ1vLUuKdS9LISc4QZQgfY8jOs5prqNrPm AJbICPolqw1MccsTrKmASFSUEH7c8/8AffRYlhdwwdFnAAdXJH9+2m+oq6uWgZNwhVRiNkAmIPtk cf8AedNFVcLtRQUk9FaKO+SoQKotP8pI6e+EcMpI+hbTC3NQbumGNjm77KTSxvtO6HywcerIYEfX j/PSb1xbCEYxueXOAB9+/wDbRsUkBQOkslOwAdImK5UEcqRnj++hNLMQf5qAEE4hwufrjnH7ftpT 4yN1nfCWHalrOiU43CUiPPq28D8x30jappUOJZWc+x+Xzx+2lMLJTQIXjVo395FZXU/Q8kH8+NES RyNIxffGSeyxkgj653DQdCXfCR6pBwrnElrk5z1L1sxijlWSCQBVbdtbgAhQuAC3qPv2Bz3yCqlk gqQCKsf/AJuTYXaSTOONwdvQWyOOOMD202VsdTS01HSTmLZLKsEKToseSuQxEe7BIyPSPVjJGOBp EbpFbIKmKRIzUuHqBTUiLKylsnzGQbVDf4Q4JwoJbvrpjDZW5yDqff1TskbG5jt5p5NZPTU6xxNU QqWVR5DMjRL3LbQBnk9s4I78jQqquousrTba2HcDBG9TEM1LFVXKAYbuByGGCDxjkoah4rbVRzVE zhHISSnniBZDycbYkHsA+7JONxGBzpclfBJNuqvlmkVFlihp1klUBuxbn1AkrggE5PfkAqzOyGK+ e3u1ZAA5LEkrww0zwzK9NtBLqV89EDZHDeooM92wecg8jKCqqUo41gqJo2geUqp2sfUMkdwct2JO OQF9idLK+seabbPTQPBIoaNUnV9wzkOSdvHHcE4OThtbwrLM4WlWQkjkxRt2C5/EwyoAwAGPOPp3 zPeWmneiSZHRm/sPfvZN81TFUhllmqJBG/NVEfOiRwxEjtIynDAB8KAcc52/0k22rsvkrWoCZCjm es2rPHJEDlnaVUHpAA5OTxj25dYqhaepf5Y+Y8QL+WwEYyCu5lAyceoADtkDHsNM93oqW6T09LcB LJCA0ohXETEgqVwxz6trMp/IjPAy6OeNpyHnz9/ZXHJGRkeN0uqo4vlGNGacxqBK1dI+9RIOV3tj 09g/PcEEc502nyZx5CsjpV7UeocBsJtUgxMhG/OxmJAyNzN2wDvDBYun46ht0FupNhk82q9EcZJx yzkjA2lcAkYUcHOozP4u9PLWIvzC3sMrMkRZ5FJKMAWXO0g4cMuQAW5HBwwxOc6w00ee6RJhW3vl 9+Kk0dvparZURQb4mXPzEbtujJyV28ZBPmcEdgq7c4BYukpq6O8yiKOCvimIEpVPLfYQ4CsAccFn YbTk7drbSAdRC4+O/S94vHysbVdyqKiUvAkKP5ScHhDuA5AbjGQvBK7eGP8A+uPTMFa9M9C61MlQ FDNuKI45GFQ5OAFClePrgc6a3CSl1AGvfK0LsFC42XadwVsQ0NKkIpf4cdkaMHjmjfcOQNqvjDAs 2G4wAckA5y2LX2GunhqHSCaU7YzUxOJfLffkxqGVsDYeMYB57cAV3e/H+ZIkgobRRpMqsoPmIQzb mBAXLOM4P4uPf+kkM138WbpPQz+VT0MX80GaYUa+p2fgOzAZ52ZOOcDkncdUcG88lT2wscK1HcP7 V2CO2W+4yyvT0sdQm6OKsrNizREqzbcsnO4EOAfbf9wut0iNDS1dXFJMsZiBZmkbY6jHOxTtI3FM diSzccE653uXiBcKisZRV/IoI1/8uacu6lGUjaO7AF1G3BX8vxFlud36grrepiqpqmiMwh2xysHR Tub1q24H8L8Zx7ZAJBZ+xkdRLlndYBDQaXVsVxhiempFqEqbgZC8ocPuUnG3cAzbRtJ4wMkEDliW a67q3pvp144Kutkpwsblqd0TzkYFTwA3PBzgZPBHPGOW3uU1VUSQTNUSGKGXfLETI7ucD1LvC+oe ZjsM7snS+kWWrgjWNfOeNgWl2bCQDgFUO7Pr9snuc5AXLhw7m4ghZ80jusFd9X44WxrjHSW4XK6p I4mlWGlJ98NEo+qj2GeMANgBtIajx0tnzcMFstFTXedv2xgr6iVJJwWO4KcE47YBxwdUXV3eno4v LgxHJNKzNG+8L5rNkDzGPJJUcAEEkYPfKWnuTVMZq3gNUqgEK8ZlR+cMVyMMpIHYDOzgck6JuDjD rSbdVVatq4eMV0eFGt9FBRrCok856jz3HZ1Ut+IgszkqykA7PfcRGb511emooI5L9HVPGXqKuKAg pGDGiLHG/DEgZye4bKDldxgVULeSk0ddVR02FZ5KeaWD+Z+EGMAkj1ZPOOM8fhGjKNKdKc0xetgp kYOrSR5VG+qhx+HuMDnOM9sjS2BjGkNHy/KG70TjVdQXS6D5SevuVdC43yJGrSOQBzvP4cAKOTgj aPpy2T3asSSXNvQB18qZlkDIcYIJB7jd7ZJ9S6WotKYzHO7SoJA8u9UJmZQfWSoJzg45wPoMaJqa mkqoFFrpqdYEA3SySnKpnn6gjDHuRngY4yXjKRYQuiNXaY6q+T1dM8DyPWTugcwwxsCfUMHJweOc c98jseEs98aumhSSlRHGT5TJljn1INpySDhuPuM4GdOfzlZTsacUUdRGrvERGQocsmxWyxz7sAD3 LDtxjNVdp2mSSGoSmgKAeZGQrbwu0KpH4sg4yQeM47+mxV387WfLaTW+ghoaN6iCjhRGRi7vKZJM 4PGBkFiQ3oBHKDAPbQDRXBgjStVQlNyzRR7toB2+jPCYyeD3IPPPKpKRKiraWSvM3p9UYQxDb/Xg DBXkkk/8II0graWGn2s9XPSAwqY5alWYRqQDhigHO72zkbwD2zqAZyobOlJRWx2uKuhEZh+Ypmll ImG8gso5I9xx7cDdxg7spEuLzIZILg3zE+2Xa6BQu4kjnk/haPJKj3545fOkrB0V/EVl6jqLmTJO m2joEESy7ckq0g3SEEKBtUA+oev3EibrjoZLxVeR0HNXQgGMJcJJahCn4g5WSYscnGCQcZ1qaxuU FzvXsTGMBBtwUOsFBPdr7FQ2yrjrakPsiiaqGCyqJGdlGQMLGeM4OH78a36mv1WK9Ib95L1kaMlO KpvJU8guA6nByxH9wM51afQvilVdZdVyeZ0rYLLQ0lJLJ8zFQIlVHjChBIqIEB3HKkEld3POoT19 1R/EqVrXS9PUKtDUlam6sGepf1cBCONvPKnP14wNKcAHijengvRxziDhEkNA9I4U4g5urrQPK+ai CTUy7kWLEkky7JY0YkE4ClmJPpHpJHbB+mir507bKC3AlliJi3xMikFY1jTeSw5A3A85zmT9dEmg oLhNFNUUUmd5jEaEv+AA5UdsZLd+eOdKt9PlaRoPIp2kLg1EjJJuHC5Vj2CNkc4Hp406N9HUrixT Ft3r78FHPKpLJX10NdI9IPl1qkLqZF8tgm/aA43nLN2IYMMHPtIbPUyldtPFUUhpUCxtUxCJgFwA qqWBx6clvquMjsGx6GimqZRRRiJJQM+UWQyHupIwOQSf1LfXTjQsa4yTpTUqRJuB84OGIYtnG5Dk ANJgg/X761Oe14TjiW2QAlbVjy4eWponSJmSRJq1l2Z7EjPGQeCD3257DWa65W1QiYIhkDtEtJUg +c34cBGJLdmGQdoHJ011fkF6l/k0FKnqkSNcnB78HjgnuD/T+R0RW19zWVp4rPEr+gSzNWursG9J 4BIxn1HnPt9DpTQ0mymNkjI1UjtltpykUlttMlbMJMIJahmEUuANuVIXjIGQO5HHfRlfLEHkqqui kpJFkcFIoQxjYfiYZBPJ39wRgDOmue73y7maSWT5WmG2ELDGkSrlc+kqfURjB3D3HP0cljnpKd4Y ZGglkjOKguHw27kHaBk8YIx7cEHJ1RNHUo+mFHsSyunkgkiiSI09SOD6dxjJY8YzgjGR3AGex0z0 lCtVBMJ555N6boVeaMu2XyTkMBtKqTk5Ofsc6Sz3QW5auSeukqIAu0pk7iAB6QQNxzuA+3PbjWsF ykbExgaNVVWZAI1KrxxuJOWGe4yOfYaE6NvdCZxuNUspqdgscUlIZssI2Rn3Bs8YXgbmwc8D8tHt BDTLUx+TUU87uSszqittyR3z+pOc5THGDpOl2WFllnSGOYNu8xdpbOOX+wwT9e+O3c2ekpbhSvA1 MlSEU1Lu+4ofwKFx3ySWbt6gPsCBDr3Cpjmk7Wm2pnjMJ+ZmWnY5bzG4BdvV7ZXBJwcn+n68aPmV 2cUZgWrllRRSkN5cYJKrhSCXbPDYHB55GANGUFsJqKiqpjSrLGGkJY7VJOTuJxtHZjyMgA9vfSX5 yk2z+VLBC2StS0yKuPwnAIyeG9h2B0bT3Jofzy6In5A0Kos8JppJAqLB5zMQ6oMgA88HPHPtjOkV 6vl5AXdRx1oYYEtO4UhOG4xjOSDnAHA7aW1VBV3UM0FM4SNBLDP5jSsF4UsqfcknH2ByBoumoa2l ao2XYx04iEkkZAztUAYAII9RZeABj786aHDdygfpWyULdPMhgmqKKaAGRSzMcpEhwdpHGBjcNx5H H5a0L09bSRSUdVCG9TMhcPtUHuASd3CuCCBnAAzxpzuVjmNRNLMI6mmikMQlKs6+WQQxwBnHHIx9 RpjrKe31td/DDGKBTt/8vDsBYnkc8nb+EgD3ye50LTetLNcjjmqgkFDR3CtMSwRUkgpnBBjDoiOc lTu2D04zlSc88jTsKOaUssQEkAbaxZVKgZyoxwT2Y+/sNOEXS8dvq54qOq8qnKlzTLJgu+AwYndh fw45A7HsdJ6myyUleZllqKwMisI6iSMDKnG3lckexAPs3HfROka/UfRMeC4XXyTVdZKiJmFLDMWG 1FKMgBJ42ElgGJHbjPHB76Iaz26SpqqKoSGStijzJFuAMfbIf9+wz3+3LzSx0cTiNZYYml9T/wAw EKAM5247+kn786NSzSVtY0sQVzsO8x7gOMAHhe3HY57E8EaEOFdiW2LM0khRy6dDW9oH8mnRN4xA IgZOODyowW3fTnSFeh1knnhhlqIDLGpiXy/LA3YPpPHcEc4wAe2p5DbYzNEQ8wgJaSV4JPQR9Fzj ByByPqeDwNLI6Jq+YUdLGLlUOoHyzxncpPbJ9h+HkjBxqv3BYKa4pZgbdNUIprfcRTQ0kNHLNCHY MyOm9CMLuMgw3fPbjg8ZOdM9DWdf2lK2msVzorZFPGInaMtM8wydzRu+SkhymSgUjYpyCOb4tPhF 1bVrEFsaUeCzfzZkVVXJO4ZOWJ+gGfcgY4sPpH4aYqmaGS71yjbiXZSgbBwOGLDkfl74576S7jLo L61/NE3BYg7NPiuEOsejOob/ANRz9Q9S16VlXUTiWdpo+H4A9ZQLlmxyRjJycknUvo4bt07V0zUH S01oqFUmGst+5DINuTuRx6lIBYbieATr0Mtfhf0/Y5Y5lo6dZV/l+bUEjHJwcEADjGD9T+okFFbY o40jmeJQQFaKNxgf69iMZ+v5a57/ANQPkpro799y2wYeeG8p18PfyXFvg54pU3XN3lsd3sNdNd44 jMq2xSPOQAZIXa5BGQcDIxyNW20UNoqzOkM1rjidSklfmN42xkbsgDP6D8tXjV9K2qSolqI6Okiq GXb87RhoZ9o7qJUw+MDlc4OTpjXwk6PoqZZza4Lh8zuiIq5ZKwYAwCFkZgeMjO3OPvrnu4kyR1hh Hdv79F6KLFvYzLK23dybugvHpKq6xWquulDdmZghEGGlj+5EeRx9wPz1bx6ltiwO8FNX1DAEhUo5 V38ZwC4AyfuRqJWCzW3pO2qLas1npFYLHHEQiA/Qg54PpH69h7qq+vqqyNo56uZoxtkMIVU2MCcZ YAE8jPJwf0wefJMx5JDa9+S0nFREWQbHK6tNtV4mdSVFV5ds6RpIacAf+YuVyClCc8MiK3P4exII bOeMaR0t466uglir7zbbX5o2hLTby5jAOSRJM5BO3PePH208rUxzSbflj6EPKLt3Hn8J/U4B4/Ln RVUIqZAZ5GX1bVczbVlyuF7gng8/nkdtZumeT1QB5LkSS4mSy3Tu96/NIKamWKhCLP8APVChXqCy iOTd7uwAAAbk4UYHsBgaPqY4o6OFkaONNqmSKnXOAx9OVJwARnnk4x9NLEt8TUSmSOWStLhlAXkk LgbivAAH3wdHwU1GDMaSnZZhldhTB7gn2/CePp20FGllqVrdRumsRwTv5bRs0r8EIDIcYOAM44GM cZxj8tJDFR0zKzySlThGlRiABkZDDPb04PHvj31JY0cUiGaEHcAT5P7gZ4J7HRiNHBF5TFZwx3NG jrmNSOSwHbHvnQZXO1C0ZXOFA+u6i9Z0Fb7wjM1noZfNcsxmp43Axn6jO0g9/wA9Q2u+HnpmthEf lVNJMrBozGxWPaAdwIPOCM9+RxjVxT0wr4RNByFXbKN/YZznB7j084HfSOCB5zI0js1RuWPaoDo6 H6ng+/64763RiWMAtcQr/Ztc0GwudKr4aqCUJHTXTZLGSjmSEbTnJyc+rtjHJ9tRO4/DX1JbY5XW SGqIJwYnYNtAyWywB+o4zrqY0BhkQNCSUOYiqYG3d7gHGPv3yOdKRSN5xQkmNm2eZsby3HYnjsdO GMxUZoutYX4OnUuPI/AO7oHliHmOWwMyhvUBlQwP4SRnj7aZKvwr6mpXLfwqumdHCyU8UBYrxycA ZOPtrtunsJqzKztFGrf76B8EsMDAUe4GPz1pHRz0tFKqu25QzKeGZTxt7ZyO3561DiM7QC4Wq/x+ U3quCJLTUUNOFdaimqdxG6ojXcf17nn7al9qnrrL0jcK6g6Im6iqJKiJllp7Z5rQkjBIODkEjtjg +/ONdeVMQqEzWU1LLGVKSrLAjcE4xz2wMnj7aUrFBSmKCkh8pZF2lkXCjA9JDD2IHPtnTv8AKuBD gwX4p+GwjoHdKw6jwPqCuJX+JyKwRmluvS1QLrMh2xTU0sQUFcoREqAEh9rZ+gI7HinvErx36g8Y bvT0c93qKcTM3m/OO5po8nOAoBIXIXgL3A16bVVKlNAwalSaUndtdQQnONwIPPtznkHTTW9M26R3 YRCnqFbAJjjU7885DDA/7/Tof+InNbl6HXuP9LsOGJd1WOAvu/vReVPX3hbTdHG3hOraa5VNQmai miop4Xp2PIyJFG5T9e/299Wl8HN8t/hX17c73cKh6ySe3PS09NBD5ju5YN/8R6f767nrKOlVzHVU lHcDKW2xV9MjI4HfJPbv9dV11PYup+jKxa3w/wCh7FPHPEzSusgp6mln3YPlMQAVK8lW474x205n Fm4uP9viRQO5JA+wWUYF8bw57tPAn5KwekLvcOsbNNdeuKGC39G7SJ7fTSebUVPJ2xtkZGeBt4JG dpzrlD4n6TpnxYrrteo7FDbKwxLDbVtMGxm2jaocYwwCjJJ54/LUzntni3fLrKty6KqmknTLSwV8 G1vuTnA/I6a7/wCBnilfqaWko+nY7M86gS1dZWROoB4IwpODyOfcZ11cPPg8KwNieBzJsfbl9V28 uGEbmnr6ULafkDse+hsFzj4CWqPp+/3ByxesEJXCnYEXIB++c4GPvq/4upq6GNZKeunyeyeb/u2H seeffnTh0r8FXVXR081Zbrxa7nUVCiOqinLxsucEjBBB/MHUmT4ZuslqFcU9uozGQVX5kYlOeB3I PGlT47DTPz515I4WRugYQExUHiT1IYGb56qiAwzMkhV/pwRj/vGpRa/iPv1HGkEldDcmXLK1ZGo3 Ad1LL9PfjOmmp8Ees6OqOLLPhH9XybIwBzwRtPb9vy0ZcPDrqVg5mslTWBMbtkBVs55JBHft+eNc 95wjxWnyQZsSwZWE0rH6e+JxHuUH8SsaikII8yhcTMsntxxqy7P4hWfqqnJoZ0lqi2TDkxzxfcoR n68jI/fXMNDHNYaiaRraSz+ny56MsxzxyCPv37jGnWy0FassUv8ADZ4Kgg4qot6sSPbv2+3B1nfg sK5tjRaoMTI01IL9F1Wk8FQBTyyxA44IUtg47NnBH5j662emWlTJBaHYSWSU8flqnOn7p4kJdYxJ Ynkt5lCs1VKoKD/EobaTxnHOD21bFupZaZd1UJ5H2kMsCfy/ruRTzj7Ekg5HIwx40+H6LRjwfMLo dK1zaFg962mjzAZPMlhjYlg64PGPwjAxoi22y4SSzulXFVU5RQI9h7YPBB5Gfro+anjr1ihIeTHO zaVDD6nR9JbRHIUBkaQN6FB7A87T9v7axiZzQQOe+3JQljqdWoRIpxNIykqkhUAKxHA98NxkD3B0 bNRRyQLDiNCBgqqcMMd8/wDI6NqaZlqwzwIPfYCTz9eSedHU5ilbaY2T3WNsc/Xvx/lpPWO2qElx FgoiirKiN/l6iOORFHoLBW2fr3+/P5Z0smZw+Ho0lIGA2CvH5LxpKw+Tkdo1AI4TC7cD7+3B+50a tagRd0cMjY5LPg5+nfViajqaWYzFx/4mipudpNK9wYlqKVQDHCZW2BXGQu0nADPggkgjjPABIg6s +ZDRQo8pkleLO4FIIy+Dl/LXvkDHqAAbLM2ucZ+s62Slip6m6VUr1K+TPJA42vgcO6hycELkH22j J7Zb6KCWdq97rer3VXDch+Z+UR49uCCjCSQHK7hxG3A+nYenbhWUb8vfvwShLHJVcvL+leDeNFNZ 696XbU1mAZJlMgeOPC/gLgKAwO3nJHq/F3w2yeMNsnU1FNYJqqoK/wAunU4Zcc4DPkcEkjcAMdiD gGmKjqG01NRIKG4RwJJEyPG77+c5UiRGIIDkElhkY99JY62upaWpiuFWJomCK1NIsm3aOcK4XsTk 7R6jjvqm4RtgEXSytmkvYUrel8d7jWPLIsC0YlH8pqyVWCxrzsAj/M8kj7Z76bbb42X2qrGngMFR SKru1vemIlp5GIyFcOA4wBjcwJznIxkVLLXWyRJzHBU0vlS+uPbIjsAQdyqfxhipBYZx6eMEYNkn 8ym3LEaiYhZFp0ieTB7cbss5PIyqgk4PYYJmFuoLAlGeaTUgae9laF166vkzb6uvr4AMPEE2xnA2 nejrG25OVyquRgkH6BLUV18q6JpDc7jUQrll+ckWVFXIKn08ByQAFZsHBJGThYHcWliaSoM5oRBA oaKWTygobCqm8ldnYjHcgt6RnGjWt9XUV0NyqKu2UEbzllSnOJQ5AOQQEQgjDFQwJB5J5w6PDsdt t4JnRBzqc42pPJRVlqcyylCp/wB2JI3Yom05wNvJOQ2MEDcoBA4KWOnlZlaqmYVcuxBXSQn+YduF GY1CkrGWAAUEfXJ9UUutZep0ernrqujpljBho7hiQytwGCoFZWVjgncFBOckjnQo7nWPNEHVKmlM TMKks+8p9g2/DHDAttPqYgY9mftTejkwQObpaPtko+bo4YWqa6jml2+TIvlLGg8ttz7iMqMbQVQH 0khTgAHVN6jmNXCJXWCBPNigkYPF5jZReWKkljgnPPIwVPZLeuqIKedY5GoZo3MaGKZxkxEBVLtk BFUjjIz6Rkc8mtP8xSw09QFpxUxmRUEzOjK427NrHDEYwDvH+8IKlQzaMxnTMEOVrdwtHgepjqpV lkeljHlyZlMSOzBgUX0ArGM7SQ5P+E401PWQpdlmDNIoxI8s9S0tPKCQTuIcE9x+FuTt57EZazS3 ERQGaR6OLeFLLtjEnOI41UnaSVCkhvovPJLpJRVFVJCKaaR5vNEkbzyeZlmdcHGcIduTgjOG5zxg w5kaJsgaNESbhSU0ZV7hDLWSkbPmwZgjHBdfQhJwuN319A54JfbnUyvbAtdAtJFEvzW2vQw7QGYA geohFbzOfcuCRn1KwSR0IL1Fdva4zFikoJMhJKksQFPDEFuePUgzkE6LpqGnpoGqRtlqIpS+9qhd 7gsCfWVJL+pQWZie2PZQH+s7WhBiGoG6VNV2S+PG9LcLd8vDI/mTjf5D52twWwQv+8XOzP4c4XJ1 rFmGoZqV6unqo2ZRFAcZUnG3CgHOe3GRj3HGiDZp0eR6KpqLdNO/lHZDHsgXYVfAOVQHecbADnsM caOp5qSit3yAlmqC6IZEY+YZCJSFDA8Bcp2xjHbjA1HltU1KkeHD4UZPRW2CuWrloqgSRRMjSl14 U7gxy3OMHd6SM59+2s1uyCWQyGWASFQVdgWYMmCBuAwCV77TgIB9c6RIEt77KKfeA0gEuSCV7NgF VJbOBg8HHAxjRz28zVsFSaKKOV6dFB3f7oKu3sVOX785PfuewVQcN1mAHwpFWUVXUz7onon8lBKU kgibZhduNw9TNntxj1ZyMjRMFTWCUM1QjSLmOQxxiNZdxbCup5wVY8Kp9O46OpoKuhpYWmpqSSmG 3cZI1AY4zgnGSOW4xgg84BxrelNHLUBoqWiU0rEvIKYTNO+SwMbA8HgHfgkcHPYaoAu76UbHndY5 LFLbGUxVYniYLKil5XVjgMCzApuBHp28jJBBOCDo6Tp+qSV/mKiCkqxJJ5weqcNDsLbpHdwQcYY4 Qe2MbsZbK2Ge93Gm86shjjoz5wjoZYxLu4ywQkEgMSSBtztYk41vFBc43Se2lqSVlRZS6kmJCn4J QyngeXu2kkEKDngZY2IEWntiYNHWtpenbTS0VHT0tznvCpHITPAj8k7sH+ZGvq5A7YHlpnBydE2q 1T0800kdVLO+8RkBtyrnsNuV4LBsAAjOMZzpFdo6u93B2u1bGhj5j2UgiJwc5ZVwDgg5yeR3J5Ol z1D1lGIq7MsKlRKeEGxFIBZhwCMt7HkZBYkgEW6UCs80DdXR7BJasXKnqkp6WplnEYZkMBiDKpIG SNo2nLHtxwGIJGdGmsniklmlqKh5jnaTGxDAEgekn8XGMn3+nfRsVPV1KRrTxTU8FP6mmmlUFF2g spXk4yc+rGcjHfSCpnwJZUrI6YqS7soQs6e+Tnd3Puvt2yAQDiQarVYaLXUVsKyrUCMNtmV3lDw7 RKoZAWPrPfCjBzgFueOdIpYIaiIsXlo5So2Tx4Lx4XucE++RwCOw0RcKGkeo21FqilgJSVWEQLFQ rOWY45OeOzZUEcehSwT9UwUtbikpYYoZD5bVETO4UnBUuQCPxLwc4++ASWhrnDqhKo3qLVkWmztd qeokqLmaBHUUtOs0gAqZtjysoQAH0ouWPJ7cA94eZJYadf5izbVOQzbzwAEb0g4xk5578DtqddJT xXDp6sublCtHFWVUZMYVyT6OBzhisGMDP4xjjGq8guVueoiaMwNOudxVlUxqX5Bzk7R9Pbdx7DSW spxIC9DxDFzDhuEwbj1G5nAUN3Hn80tWOaqhljrJ3wcFfIg28/iGeftn0++RgdtaVUFNiKdHEYXa Y4y6MyrkjJDZAyF9vrnBA1srfPOVkn+YDFT5QQHPfkD6YYE88cex0cKWjWWCqqbfM+/ZGZKdAv8A LTC49WRkDJ5AzjnOMaK70C81bn7IiOGkq5GMSOHiYSqk4ORuYlCQCBnCsBkE4+nGip6WIsWU+Qyq EVySIxyNo/4uQ3PIx3+mlMaVF4k20Mrox4UbMS7Qexzk55LHP0Axg5Gn8IFJPT0/mzncCPmXQ8Dd ggD8s5HfK/TOb11sobIOqLNQrKY4mh8qPavzUeFJHP8AvPfALZ4z3zzk60hr9kEcgkM8jusgEkpH J5Pt3yw7+ynnsNJp6eup66RcLU0pifeIEyq+tccc7x27AcD6HR1oguPqp5aYTFommY7lPoUFsDnk BM5OcYGBnOjAAFkqC9+aURVFTUU8sz06LHuaLzIyY40APOHICkgkgjuAD30nFyV6d4Fepp5i8Ywl VG8cgYE4wSoBwR3wMAHByTpdablW2Zp0irahKWU7ZKRWV4JI9u3lD6WPIHIJGec+29DTUUlTKtbT 0z+ZIXSmEapEhBB2lFxkHG3C/XjjtYoWmiRgGhN9/wBkyydMxRIYlmd/UyySs0nm4I4Bjz5ee3YZ z7/Ry374ZmhlWZIGMbRsNokB5wN3GQBjvwRjngk1mtdawp4Ip6evhjZA0kwZpZdrBpgdmN2GA2d8 rnJ0mhoKiUv5ctbVFVaWSWZ1JkXfwBxjkMO309+c263aFUX2NUbR1Mscyr8hvU/zCUPAYn8OcjcT uBz/AMX17E1vUUdBcXgWITnylBKRjbhCeCrEMTzjAOO3bGQljo3nnnjVIl2gJLAsLIzDHOMEqSMg ZBOMHkHOjqWRLd580FXVTRBd0izM0pBOQACAMtg+2Pwk50WVoOuqa2XKdk71VX89WyClWH5Ughow JE8pSoKq+UAbOQPSW7McjTdPTT1lNB5ZlpBFGkDxEDEae3uBntgqeAB9NCu+aNJKKNA/mZRWSRY0 Q8hSCQMjG7kZwPbWbUbrJTVLVFrktbQRZbZ5crDYQG3uRgMSyAE/U5BPOiaNNNFqje55AGy1qek5 HkDPTrG0ZB8qjfYZc8qwbgZAfnOD7HtrV6Waeutk0lXNRrFMUelDIA3pxGWOcICc88ZDDUotk01N DJUmtjkkeEMUuWQC3BBAOBjGPw98g7s5Gt5KanvFUklfTPUwyRlo5SY/MTOPwr39JAzke55JIOiD 3NPWNrphpA65TfZZqhULO1FS0kLKHDVId19JJO5GwxOE+mMdu50teYKUiqqOUyQkzlY3cCNdwAG5 gCMbfYE4HJ5GhX0FNNFcmpmkoah40hiVd6xysrAjLJu9WzeM4/E3sMg2f0B4Q3m9oDeJP4ZRKuYk cmSY4HKNjvmRTgEe/wBsHNK9jB0hKcxgeepqqjovKkqKv5VEpF80LmOoJMkXDbiD3GWx9fsNWfaP A+r6wSlaKjNN5eZUra6NzGqMWYyR+/AA4Ug8gnPq1d3T/hH03YK+huNPboZK6lYoaqRS8sa5bzCB wPUS3GM7cDkcankMlRSrCJQ6CRnMixxknGO+AQck54GQeOORriz45zv/AMWi2MwupzFc+0Hw0XCh aKX5qjp6aRXZp0mL5AHpRTlRz2GSAPrjGp8vgh01bRDI8FTWP7yI5TLHuVLYBGPSQM9+/A1P0kAb y08uOExFiGcFVYnGBlsDuCSAeDoqeuEDQmdJJWkJjgRUZ0jbIyxVR6VHLe3BHAyNZRNLJdk/RbIs NECWgfZRCn8GemKGjiU2ZK9Z4keR6qZXCEDDHBxjGFJ2+7cdtSSj6Xt3TNslo7REtPFEWAZo1OUw CDk7i3APfGMac/P81ZYzJC8W5ZQBhditxyMZx24z+LtrNFWzUU5p98IMgKRmFGB3ZyecHafVkcYH GhfbhTjZ9960dC0HSgQsU1As6VC1iI7upZtwyjqcY4Leock4B44x3xpBNRxm6I70lSkiKgaZJFWN OBjdznsTgc/fTvLDCsNKKuJUCqW+Wlj9SuWGWUL9QR2GOCe+dCO6KzGTyI4nQbkJ3Lt2jBVsjjJ4 4/t7Y5CA/X7/APPmkukFrG5YKZHKL6HJ8oYXu3dTyBgfU98/lpvqrW/yscgaNJQ53SAAEnHDBgeA MkFSccZ0puFbQUxkRInafcyyeTMEPJA/GT6zjOcZIOBnA0hKwVE67CAzAoHgmwQ3vuwcFuPz4PGo WGPU6fVHmoZnAj0RfkXW2XBEMdM6PHnbJISSCTzuDHHucHPvpzqqU3OFlqAYI+5VT6SBnCjHIGWy B9vfSWO3tTUmyORckZInG5pMjA3tuPbOckfmdEDcKURRgsyyMoMS4ZQD9wQSMe2ftoXszGghc1r6 tbigiVQwdkKDe4IBAx2ySc8Y/uPvjanK1MrVLVMkqopwEiB2qSeDyG785PHIxoWxLlTUdO1TioqF UF22eUzKWOMp9h7j6E4zpfFG0NcJZokpZQT5bjg7WySc44z/AKnQOA1DyfL+0NNF59ffqkaSMssS iWWF0O5JZDkfcAnPbAAyPrpQKgvHNUzFDLJ6VnKbznPZf19jwM8nS35VaeEwLFStAMMBUR8A/bcM juf1zokU6PwigrGCzOhHo5znIAHft+f3GqyZaoqdVhFJGH3zv/PV2U7BuAIc498j7+/3xot6I10k 8pldJidoYMCse05HYA5zn6/5ad4qaCJpmbzEkjT0sijGcEHIPcEH20RPA0cKOZXWQEA+k7cAcbSf rj2POdX26qAAkkaJMhlSIZk3uqbgZP5R/wCLGO30x9+da1kTxuCjKJAcn1bSo4yeO2fr9tGzTNUF 2hcXHAyBGwYqG5JIOO2DzkE6Pand5g7KZKgBd7N6VH5d/wA+Pz1ABdE/hOLcu59+aTQzVI8tEo0E BZgpWRgDkkghgQeB9BngaT00Miyu8siwvIAVkAGGHGSAuMcjGSB37aVVsE0G9zCaxl4U+jGW4B5A Bxg+/wCulEcqtTukUvpZSPKjO3nHcqc5yAeB9PfTide7wQEm9Bp4JLOIxTMHZIpnRlG9m/mPjg5X 8OQD2++impqQUMDx5bcA8qgjarBSWPP+nP29tHfIRMcFIvJJUALwO2f0Ix3IHB0TNRxLVeSUqI94 wSqeYM4/92Ox+o76IAOGyY1rC00i4J46qfZG211O0eYclew5x7/n9Nbw1BLE+a0MiuBIfI2iTnnA +/P/AE0traSOqjaZJkkaFBhWbY5XOF4OM9vfvjTefmPJklDxyYyUV48qGwMngg/rnuNC5oJpwrvV uY0nUUjXiaSQPLSxqzR4JIBJHYgjJA9u2i6lXDLGixQxhQ3ksCCvq7KeR9B+ejaOhlqSXkLRwlFB CKWR2/xE9/fsc40bWW6WI+WadCFwd7435J4I9vp20t0XbqCgMYrQ3fYkMNHFBUyEIeCGw7ZwMk8L gYxnHGhLbYqnKzqKoM3qIXAUe2M85GlclNPICwgKDGx3ZOGA/wAODwfz41mGHyHJqBEBjIRCQGAP 4iPbBGPtjQiMgWgLXRtu7+qSfIeegEckkUhxgj04579u/OjikyRMGXzpHb8UsXAIPOMY54/T76cM CZcxvLEysqqsYyQCTj7/APfH01rl2afMjVNRGNzKH7kcdz7f5aENAF/ZWJCW/wBJGHp6yJ5UYJUj /wBKMYbGeRyMf39+w1ushowjSU/zEJPlhigGfoM476U0skaTCWoUM4bAymxlOPqBjTbX9UCKSKCu phbIt2xZCNySHJ7bSQv5e/OmA2ExmWTqhOUc0AUSrSgsFKsiOdxUjHB44+xx+eiJrVWxRiSIYgCk bH9OVz7ckHt3zraoVeDJJSNSkeYjqPLYjjIJzyRrcQtLArlpfMBKrtU7MHH2OMj6gcjTBJXVOyEO c3qgpHEgqWGYJIBsIdWb8Qz6SpBOfy/PW4hkdAUkAkX0nzM4zz3/AL6V1L+REBIzNgDEjQnkjuDj RPmNKR5bAOnpQxKeSOcHPY6zvdRo6BZXyEGnaBbzFZqeHCRmojOGlMeN37/r20kDKkm1o0fPaEqA cfUex/tjP66cEjQO4VxJKcvtbgFs47EcflnW216enaLIRMh2SZF45xn78/8Afvpxpws6qOp1lIqY ufKV2BOCBFL6CvtjIOPpxo944/LmmgI3nAZPcH64OkpqWSFhPGkqNn0AbgR9v+enK2V9LTrKxgKp jaFaLgH8yPv/ANNRpYeqTSDpIz1ToUlgBkp9pzIozhidpX7bTg4/voR0TTSmSKB5eNsbDDIftnAY fqDo+tliLJ6xMzKQpVQGPP0+nfjJ0nSJ4kCxxuqJ2x/SPoBzoTlaapBmymi2/otyV+YCiJ1TcA6A 5BI7++tvJp5y52yxsnqPlkH3+nf+356SGeP5xH3mUcqCo5BI5z7Y0sesZ0SOUKp/9J/LByfuOP8A P9NW0DmFWmttWxSGFTI2QrHCkrtP58H/AE0TNWSxSFEXgf8ACo0p8p3jjVJndQMmFiFZWPuuRz+/ vjW7mSUgpTSzDGNzxhj+/Go5o5JDzrpp77lyzePBO6WCIRWm3C4RyoUWqQokZjKouGVmwckkDZ3A IyecQ+TpLqSdya6jFuVBtSSWnEbAggAIqHdzgnJwMHvxx1dU36FJZPLeOKRI2CyVBMjxblwXIwFI 4GADk45b08qblJTX63TUtZTU1YZohHUQyKZd4YHIzhQMluDtGcE8jOum3iDgOsQfr+PksV5zWy4z nsdslrmjSCStiViyMs6cZAZlLEAE5BP1OAcd9PFPYY6WjjWghnpKhQGEVKmwSAFsqrjCldxzzgjk 8DBN73/wbsUlFUU1LF/D1gUNL8vtOPSTtCg+2Rg4J3dh6RmD3vwzvdNbagULee8arhYk88M2S4UK 6j1YIIHJHJwADjYzFxv0sjx/opFDMdioHT0sVclQskR8t4fLmFSVlkPH9UoVAuMtgqRn33digho4 leqjomqxSPI4/wDNVLs3K5G4sefYfgGNvuTnTuLHWVEkRuSfw+aPDTJXTosjLlWfIC4XnA2+wyO7 aSzUlsuEFM1HUUJiCSS05p6QNLAEQAFWd1KKcbhks5GeckDWwPsVm0SicpDb17lH4TRVdXLTw0f8 XZHSTzK2p4hKj0sM8nBB9mPqPPIGiuoWulRTRC2UFNcKKpaNq96mSOJljGCFXcgZSWAAYg42jIxj B9RPRFIpKSme6KCHihuMoIdnYDap55yQcbAo7ZOBh9ijqCmyalgilG1IysLhkOwuQ8mWMe0bRu7f +3IGnh7mU4G/FNDpCLB+yidou1BbrvBR3C2yeZEwSrYXBA8aFdqqm4H08YAfO0AEDDcTfqGvsV2i mlpbJNEaUPLLLLcFqhMuCV3RrSlVwMt6dvpXI5A0ipnqvkndqerRINiGuV1JdPUr4fkA78D8WTnB AzjTe+6eKtaoSVXifaI5WEexdrM2cKNxxljksDjjAXLQzB46w1HimMnP89lIIL9SIpJo5poWJaGX aSZIwoI2sigKoK8KSoGBkE5GjYo6KSjgeoeaJqhTJ8pCoGA3CZVmLHkn359m9OTF5Lij07q9OtdM WI8iLkLIp/AcscAHk+Yf6OxYegmS9eXIoqH+WgALEwmUzOcsdsiJ34VsBgQ34SQAToOs4UBXv6oh OXCiE8zV1F5jUkMlfTT4/nQ0zEbFj/Edo5CbsFfVsyDn30a15iiigeOqq6xCuyJR5jeZkA4U4CqP Vt9Q4JJZiDyJr5FV0UkcpW5bWYqKhagOG3BcK7pgn1f07gMkAnA02SXymWCALT2+3U8S+Wi0sitO xVByAF9AyQSfTnIYlM41dWDoUVMcL5++5OMNLHXSxMY3qac95G/qdue6k7WARhkhiCSe3OtLlAkt WaIkuBtUPEVlfAQbmHeM4GcYGcIAecEMktDMs8lwho6OasZpW3TXADzKrb2KAKnpck7WyuHYEDOh UQ1tzEVF5S0ME4YyT09S8nAwSvko3OFVvSGPMvB9WjybU76I8oI0ItKbdXVVOQy1vzEcUeJJZIgF LjJOBuHP0+n7k5NRVyKZqigmikmOFSnkxGnLFiSPTkKQAc45BJOsU7Qw26pho0+ZpIdqmeFSDI3G 4OmewyMAf4cHPOEk1BSRVUcho5GnLbRJVEloywADKQrYY4fjHBJ0oEtccw09+iQXanML+iVo0TTT tA0pqHkcPBTCNyrHJHqJftg5AwcA49iqCmq62sgjelgqBSxl9jAxUqxkABWIYjAYhMkgYGCd3A1I Ybfbi9C4p1kbzGRYjGqFG3EbdzHLMwxliCe4+uk9V0xBX2/y1pILdSbMOsa7jjIZlDIShHY5HGQB xgHUEreatrmfy3TXLOoqpTMkq0VXmOaqoSrwjJLkEOQXAC9s4JwAwyNPMTutIaRDHUQzhU2SuqhH Bymcsu7G8cE+6++csyNTUEEkkXycaR5L/L05Qp6WDenO7I9LBe5BB+4UVF5/hVT5VPad4Ebu1WZA EIBOEfjKk7F5I5AOMqNFvoB781VN1r39Uo+Zihk/8m3zEs8DFUqIwiq25QGAUgE5B4ACgED1HTbU UytXykpLFTxeUVk3PgFtxH8wEEYHGNq44BzxpVT1Fbc675yiVqZpA8sscc6Okr8YblgFA9lXH9P0 xo6kstRTUEFNLJGuwCVJqeLfv3Fmk24JwTkMMD6nI9irKOsiLcrdSmitimpIGEU1LG4Kyb3kMmVC hnJKbjgesgfUZ53YLhUW2lkM1K0pj8lZHBUF8OyZB2qCd59P4fxenngAlVdt+VrKgVT1VCIxKoSE LFsYYJzkjdgFgCe5UY9QGlNntdDbqQVZX5mplCRNLII25UMScLt4yzN3OT+IttBMpobaEtbKNfqm 6eGg9MavJEqYAiRJAg3AHHp9LnKZ+vH1OtIqC3pMjyRU8dOQ8YWVDjORlwu8KhJGSeSQe5A07Xa0 RJPun/l1cKgrH5eWZuQwb1KVHIBAH9Tc4XloqTU0qzeYaV3SNJVlGArSZOAGQH+nknJ5GSMkarmK KxvjIPVRl1jWoI+XraymgMzqDCVaWNtvLCQHjbgDIHJwRgZUQfqjpGerkram3XCmFU0hP8HqW3QN KSqkOxxgqD2b3Aycd5vSUkcsO4XCGq85PT5UuY42JJ3K4TcANqhsjJ3kd+DstgW4IJI4gKkqYVmg Us77cHBLjBAyxwQDyPrpjZCzmqGdurTqq/m6Oro+kKKxw3KGG6YJrJi7NEkaruwqgZySCo9gAvbB wrpOmRBXvM6z1YnZfNrag7MMxyznaAQfSgOMZHfOAdS+KyKjyJ5blBIQGeZCszAsfxe/fBH0RQfT t1laCnqKkPUVKijpuVRMbJHwPSMcsDsOM54yRnhdNErgTWx1WvF4rE40s/cGwwBrdOQ2CjtXZs/K Th3BcIofIlCovBUkDKHkYYZP4vTjOF9BTVlIsUkKM1KE3SSVUjtLIwKsI9/pPckdx7kYCnL4Fkpo 6NfLqJ4hIvl10hEgleXCohThpEwh24BAGMHnOklJBbqJnqVikpZGkZWEOCFJIwF+oG1DxnBJxocx y7JGVzG2AffvuTW98kpJqiOupoaeiSIFtzyH8OxnBZVJzwoIA5986SJcqGKtj8+AxzuuWSTAUMTu 4YOQyc47Aeo8YGQ6gGgoI2lnkkxu8r5hWiEZ7NnDc/7xeTz6vYHGif4fDc45kjkliTOHUyOEO5Cg AwQD+JfSMdxg8Z1LaeSyEDZIp6h5pJYaScwRhnEAl9DYJ7o3OCR7dgSvPuRUStZ6V53kWNWi+WzH MHZQc9uRvBJbsOB3+g2qLTOk8VTRyPS06TBHYudsaZUBsKuONrDkgHIJJHGnmAzuwEzJIXVd05Qh sEnYCFzuxgcgAHn7DQUGarOG66qPzW+oioOauUSDasSQUoLRYGSzDnv78D+rtpZRQVlNTwQV5+bq UGPmTH5axps5HP8AUTnHf379gpFlmqv58leI0hdpXnkjWNtmN5UgqclVVyCcHAHI9957dBURNiWQ xiQn5umUBVfsMs7EnnPtg7RxzoXGhVgqy0Aa/O01iCktkUs5mgZRE7eWT/UrHgHnPJI7Z9Zx2xre OqQULyeY8BEePP8AIDquCF2nBxjcvC57BSONOdPZKkxQsKtlmmkZIDIoc7QWBGQSBtO1uSOQ3Yqd IJ+l2WkdHo6xo0bejFxMdpBO4kMc8KfdiMj7asAE07dW5gAqlk1UELpTSQmF4z5KLTMNjTYz6cng +vOP0ydEm0pdwtKKJqtYWV2jqaoptIEnq4ILEED+r/Makdx6UW2Sjz56WanpysiTTtvaRh+JtxPv 6gGPqx7nOAmhp6egaSSn3RBX8yMCEJ5Z3khgoOR6j33HGDnHGrBDTbVTmFo3TfDbhapmNJFFDKxh BWNSrAg8g4OANuO3I+h0vpKivuDS+cjJWzSLE0iMcx+gHO0Dthh6gATgE9yArhgNaUgRZ5K5kb0e S6owAGWG1STghsnH1JODq1emPAqtrVWsvl6gpII3VxAjimhVSAWV5WZ1jAYlcd/T24KlEmJjiADj ry7U+IHYBVJbrVWXGVLZT0Mk1TXypLHCsrM7jEjFsEYUDD7gSBgg8e9rdLeA1VdGo466WjtlCoWO WlFXJFKSQ5O3ev4uMbVPuxGRq8G8PrJ0vcYaG1wwpVrE0NXJGYyxYn0KWEm7dkod27dg/wBRzhfc 6KmrRUYgkZFkEkz09Ttfa643gY5J3ZGMLxycghedLxF/wgV7+S7MbmMP+zrfZRGydJ2fpuWJbXTU nnoY1kapjaYQxbVJMRyx2YUj2wX3E55M0pLOY3jFTJTVBkiWmlm27fQFAYJg8+oseckDIGO4VUlG 1PQ5jq6pVUsFhhWJqeBgG7Rt3APpI7k++ToujrkaX5qhKVUsiKPPWRTKcbtpERiGzd68lfcuRkg6 wFzXDfVdhrmUMoA9+CUrQVdtLS0cS/JwGJYJ/Q2MDGFABJ9R/CTwEP4R3R0PzCXKanqUqoZWkMKS rl2jQ7SQCg/4Dzzjvg85dlrqmCpjAlKVMilgiSsyrtG0hsr27YYgfiUjJydHwVdPUUjyeY7CUmNo JDt2elmyc8YBBIPbn6/iNrqN1on53u1cLSMW6kjJcKkcbykvNURLG0oJ9TbTjI79gSRt4IOQfcif mSaWaNknJ3AlJIy2Tt2vwScDGCMYU9t2TrUXmkSljpT5jec0RRVi80xEg7c+nCkHIGQM4IzwBpbB QU1bVedR00bsz+YU2bedwDMAcjPOcDsc/XVPpugG6p5e3VM7VTUNQMU4YFE82ZYxEGwWA3K5UkA4 OMdiAO3Kif5OsqI5qKBERZAQkkPlgs2A3l5B9zk+x7Z41mYNT1cQRYRUiSXioXYEBBX7llbI74PP 1GCckFZGjy10DhW3FsOoCYGNoyOwIzgkHuMd9C8lw0H1TCQQHVqs0dsSvfbLThZxtdZIyPMOD6T2 Ptg4z9/6daxQSMZikjNEA74Q7do43KW7k85yAPsDzrEVR/5JUVmjp5GIg8zBXtncMEZBBBznAHvz pNNfaijkQyVkbBHylPLUHchA9I5ypGcc4wcggHGlta11NO6XTya7VmK1U9pklcUuFq6jEjxIgLEo RuO3v2/Yc9hrBSNUEksYyP5QLEh2bJHKnHHfuO+PodK4bzK1FDUfIzyM4XzniiwAw7nnH35wP7a1 kkpAVkmkmhG3zRGU3shX1AH6NnBK7tpw3Bzoi02A0Ky6UD4SmzyK+pt7TIiqsBAaWRuUAzkkK2Dk MQMAfhwQfcVcDS4JZW85d7Q1jD0f0jHscH+n3xxjBydXCoSir6aDzJXjQxeZFGzSIO5TB3AEDnf2 OQMEkYYJKqluMgkiVFZCWBeVo3QhSAGY5xgsQCCMZGRjRhmYdiKOQS3rXZonalqK+2jzJhJNTO3/ AKOW3If8PJ2gcZ3nuDpdRztUMYlqCkwwy00qtuBHK5AXtgd+e4755ZGqa6KF1CFwjOu1IxI7nuFY D6DGBzkMOe2lNvqqyqooZBSPC20LGskXlyoSMYAJH5kEHH56jsPl1dr3/wDEb2sAIzWe67+6fVR0 p2mO2eTazEFwuQMbgSwHPvgj278aTUyqjFUpmjVwQWWMBguTkK3Yc5OP+h1pTJVziUGZPOHr2RyI pKA5xknIOCeP8tGW+oc0E1Q8Ttt3Kqead3b2GM5HPbsQfvrP0DgNNe9KAduDY+a1aaOgaNnllRpD xG/4WAOTgH37YI98jHOt/m6y6y4iLKpVi5lVlXkhckMOcH2zxnW890jSUPCxZywVmeFiqsSMBvT3 7ckj3GtpKmO2RefEKUEru8qaUqQpA4GcDOCeM/TViPNQA8/uipztANUmraOouOyVGiTyW5woXA9J Yg+/Ge3vj8tGxPKk0qyxCdc5jljQhsDvgjPHt99HwXbyzPsIYKBlQMpg8bg7Hg8kjnHGsw19LVzI 6VK4cFY/LICsT3BXccfb/s6hhJ3KcGvHxBJZ1kt6NiCML6gWdlwo43ZyRlf7j99FzVMFVCsbII5G bOIlCt3xzkY5OT+5+unWCF6OoqZoq1NsON8UuJNh+vJ44OcY/fWVpJQpaGfc0i+WuShAP3yeDxx+ fGjMZI03QGyPBIqWCOdmljmDbmPolYKwBGCMHuO37aymVqXeVSxBAEoYMJFHuMAn8x/wn21vU2oO 6PUOkEwj3OuFIwTg/ljI9/r99FtRsg2JIyg84jYgDGSMgHGTntj99ZXAs0ISMxGhRAgkli3Rk+rZ Iu5AfUO2Tkn2HGPbWtRDNWSCcmnRgD5jvlQxyDg44Xtxn3GlqCOuEcatJGqp3ZgVPOQvOfywB3+u nKn6eq0qGjKzoSAyBQpTv9c4/t+g0bWS31dUZkczf5phT5qF41jdpKgcbYyNpHORtHI7axT3GsLs ZlNOY243K5BzzggAgf6c/TTw9Hhpi6EeWxALDcce+MjHHb6/vrFbIsMqlJ8xmPbvgG8o3vnBJOPc AZGiGejYTWzZhVApogchnnCzSzphVWOXcpB7+n/l9v0MihW4O0mxolHqM3pVg3Yj7/8AI++l1JcK qn80fLB1VfVnIDKSAMHuDnt/odH3CshrEjzgTAqHMgzjnngAjjQ9J1Nd0vp8goD5pMtMDOAzBBtB AQKpYg8kEDg9vprW5xxyeh5ZWOdwdjg4OPqMg88/loHaBmCZiU3ZdxuD7u36/t2Oi6modYPNcRKg Ul49jH9uOD/3zpbpCRSWZHP1GiNEDvHKIC/kRAbXY/kcjvxx9/fWZlZkjliIilkVeHVsY/Mdv20l tcvzEbR/yqaJscrl949hxz/Y++lgraWlkQTEOFTagEasW9sn/wDDnvqBwIQl5I70gmWkqGplenVJ lJbMkoIQ55xgfp20vtVIZlEs9Ou8NhfLclcgfpz+X/TRTTUlXCZGWMjAAWKnUAL+ZPP+ejany6Ro JYZ42G4HCPg9ser9sZ0THAa6UpnPxbIuvURKDUVEuZV9PmEoq88AHtkH20m8uSKXaibXkjwqn1gf XkfXTrQ1Mr71Plq8gyFkUmOUH2YgnB79xj76SVTRwMweI0rYCmKJ8/quRz/3xo3lh6xO6tzxmtIn qCZmWpZllKnOcbs/XB+2t6SNEpJBAxqETDL6ArL9QByD9dGyGCphQTTTzOMDBUjj2IPY/loupo6c zMaUKu5Ax2OBJxwQV+319+P0TbTsLHvvS+kaTsiqeRkcywqkqK4z5KFgOOcg/wDXTjAKeakmKrmF QWLhSNv1BHcccY/bRFshajkd54wxLBv5ZIYDHuDnP/Y0QlaryFVUhN5CtuHp++R2H2OiLWgXSCRj C0gNNLaY00v8yNofLDAqyBvyODnn9udL6RJdqyRoWDDnDcke2M9/+/fTNLHugNOJQBE5LRqoBB+o Yf5/b66WCqPl+YWaaJDu3eaVcfmO2f8Apqg5jXUdEgljCNN1m6000VSatUWUMMMwOX+mc+/H+Wkq ytETIY6ho0UAhVEiEZ+nGfrx+2no1ZhBb5okkbhtxhu3Ib69vSe+m2rhePMlOSuW9QZQRk/QqMfp gflp7mtFkJxDQLGvn7+iJ+WSViQFjA/CpJGP3IIH240XV1VZSyBKanrpY8ZLQGF1z+bOh/cH8zo6 ZGMiyVbBmPPl+TwR/wB/941pFPTwxqmyKEDsGD8/centpNF5008yPokh5vkEz1NXFUTrcaJZIabz kEULSMrEhDyxU4A2gDbg578FQTra1j8xXESFIIXlLSrvL8nI2cKD6sA88cY0NDTf5BqyyPcXFvL/ AIjqmipLwZRSzV8FXI253kqWKqMquUwRg8A4x3yc5503dQV/yAQTtKxnVI1aJ8HcxTDH27t2x7Y5 9hoaqVjRkI51ayFxsD3zSW9WNL5PNNcaeCrWKAx7XJDOFV5FJYAYyCQQPqeWGMRO+eGvTNS9XMIb hSTBokaOCrPlrLgPuUYB2lSMrkDI+oDaGhq4SRGHA0dea1saHNzEa0U0XHwThloZP4TUeXOYtlTU 1Eh3YIUjauGznc2cFQPbkk6qe0We0S3J7fLHMlVbtjbgPMiDs2F2IzY7SEEkcfRsY0NDXZwUj3xF zjqlRfFde7S+vhS3VIMxBrUJfzYk/Fz2IJwM5JJVQcnRF5oi9R5NvnkEUmxXil2xho3x6Mqp47Dk N+Jj/hAGhpocbBVtAr0USvVXZejLRT3uuqq+Op/3DpTUi1DGN9zKFkkmXBwGBYqTzjscDPTfU3Tn WUD263117nWnRZZKmvpYopAHDMAAkrB+y5LYPp4I0NDXZoGLOd1vDQCnSg6hpXpq96KJ0jR8xFo1 U4DsoVhlvSDg8HPfJ506XC2UM9HQ7YnRwiyEq+AwYqCWXlWOTnG3A5xjOdDQ1meA2yO5ZCAG6diT x23ySktDCpgYyGVJpiheMPgoPLUYw25Q2SdpzwcgimnnjSKnlSmEagQTAxeb5xChwWBKr22ZO3uo 745GhqbxuPMLG1xLTfvVJLv0z/EaU0c04FPHCHlhKb08vAcIgyNoCucd+VAzjGN7XSC0W6egp5JZ FiIVmlcYAByVRQMIDuOCMYwODoaGsvSvyVapzjbghabq90q5qaH/AMpLStEZQqgoVLMMg8MWyhJY n3/PKaS91Nr6hhtFCiBJUmeMO2AwJZNjnB4JYZIGSATwcEDQ1ojjZ0lVyTY2NoaIqomr7G8Qm+V3 TxH1U8KLzzHgjYAeVIzjdjBznAU2o8wR29RMxmbdIEI9O4kqG3HOD/UfSeWYZxkMNDRE0CUtziBo kFBb6ea+MYqY0dfWyFp5IaqQK0GEOMcDOBnaQVJA5HBVtu19u1sr5KRKpHqPKKqY0aBRKzBN2FYq MHb/AEHcFycHBA0NOjcS+jqiY9xcQVmrgrrVcquCKtnqKKmX5d3mqH82WVdyO/uFBJbAUjAC9udH tPHSdO1VyeorqoReWi+bLgqQFYEAf4d3Yk5x3GToaGm0NPJPApwpFWfqEVctdGWrKJB6x5FSzttK q+0sSDj1A+nbnke+dSGSGpoZI7oKmSeQSgsJpOCRuy2AMDaAuFGAct+EBQBoaCZxEtDuRPOoCbGv lNcagUEE08NRPI+J/l13elC/cuQOOB6SPsTzpaVmt9PTSRvHWMYHkd51ZCwR8hcBiBkKVzgkLgD3 0NDVhjdRSzEBjwWomolpZKynlSnShSClmZkoVaPaHQMhUlySdhCndke3IC4S2erutfD8vHcnh3QC rZZUWYbmYcLuGEILHDAEnLZ5JJGhoZNAtEmyWFZKapgSaeXBqgsiI5MQLNgME43FV4BLc9iMaZrX 09c740Bplt5qquBZZ6icOOC5hKogBVcBiQR2PtwNDQ1cJzMNrKSc5CE1BWNTUpqZ8BW2B4HIIRUV 3CrjapPpwSG5XsNOKWYiioE+bm8vZLIrkjOxAp2sBgE+pff65zoaGklx0CQdwtqmT5WGZoi1USmD JUhQfVwMKF45Unue/v7p7PVTWuVXk9QyzO6uSzFosleeMZx9/wBtDQ0ljibWaz0hCUJMlxSrenMi oTjY7cRszAqVzu/CR+oAH1yor4ae005ZoxNKZ0jIaOMl22DuxXPfngc57DjA0NHQDtEcnVLqSD+K /NK4p5flGinERSOnUDftZwwIYcHL5GM9ueeNqemq/nqeiWoCzz+crzLlfMYEgs2OeT27hc++BoaG ljms5Fg2p5Yuh7h1LEZaivVJZKalrPKXOPJqJFVQrYG1gZHBG04HIbPAs+2eD1qttLHHNtq6kKF/ mISm4hnLghhzweCCB/TtLMdDQ153G4maOVrGOoFPEbVYNr6Vp7XcaanjKQOsL5gEfnRh/MVAQ7ku cYl78HeCRkaUU9vSCJkd5Y4Wj88LG5LqrMFPr4JOFAye/fOeCNDXPlJIDuZTX9iXJQUkNKlYDKC7 yBlOGwyOqHnOSuWBAyMZ4xtAOBekp54kiWeOaokjp1k80ldzRpt9H4VHo5wD2zg7joaGg+HLXOlV loFJfSW+KpmEbSz4RWZovMIifYEcHaCMNt9+eSRgjBCSttRq/l5K3bmNZPJEH4D+JgGRgeCBggk+ x5IO4aGt9kBlc104XONElKBDBURwy+QjTLvplBG0IchfSR7EoPbjAwOCGLo6mlt0klLIZ2kjjSeR mCzYZ3wGUvzk7iSOw4A4AwNDVyAB1BbgS12h96p7prtTVUaxxLPFIziNXLBgsiso3heAO4P7/XOk lwtoZqlpJ5B5MbMyAcnl1wrgjb6R7DOefbQ0NPAAYCukzqfD72RUqTWthKm2oikYeQtQxZgdinLs eT+Fxxj+k8knB9sklq6KrnmiSUwOiZaZ8lZHZMH/ABYJLcnuBoaGt0cLDhQ8jX+lVWR5fUJLeaR7 fMJ0SHz1KRscZDDDHI447dsEcL9NJKGgpHgjjqlmn8yMsw84hW2kBjgdid2RjGD20NDWBzGn33LW 5jer77E4UzsJKmkkDM8dQ0ORK21soCuQc5GM9+Mnsck6Z4LhT3+huExWZIo5fLKhghDq2CBs25U9 +fyxydDQ0daI4xYN+9U+0c9TBS5hqSJ0d5UaSPcMnDDPOTwv6Ht9i5bxW70kmaGoXymcpJAhXON2 cYzn8iPpx30NDUeeqQuTiAADQ5qPoaOaKSOnoKaOcSYKiPYrFcDcWU5/rBxgnuMnAOlkc1PGIqqS MhvLEmzAYKMDAHbsF/z+p0NDXM6R7fhK4+Ele55sraptAkqaerpiIq9R5byZ2rIpbHYdgT3Xtxnj tpwsdDHBDC7ooTcfM2+ol8nGM9vxH37840NDXTEjnAWV14pXvjaXH3SbK9KfzaWik3xS1bIEMKgj eSQAzE7sA55HOD+msNcFoqVYajzAzS+Xvg2/jAP2Hp44+/8AYaGntjaQCQutGLj8kpoJaupqEgp5 V8pY1ZpJs72BPpJHPIB7gj6dtOv+z0dWPOlIWQ4b+WCqHhcEqMc5H1+nvoaGgf1XBoS3ktOiIWF4 pmkBZYWOGAlYkgZzwR9zj/TRsM8MrOsYaNvSRIEXdtbJxkd+3v8AbQ0NLLQXi0J1dZRaTyG5B2fd slZRvG/IxnOCcA4I/LJ+g05TW6WKWTc4G+EMArkgjgnOeQcccHQ0NYqs33rM4AmyhT0po544POZf PGFVdzKm37Fvr7/lxwNb1ME1NBM8iRM8DEI+8sVPfjI+h/79xoaKTSMEe9Ep/JIjULVsiPGgmPHm 4Oc559xxz+40nuT/AC0kbVwV22sA0CkbsEglgT3z9O+hoazBxIHfStrjoljFVjjECsVcFJGkbJxk +2CDyP0/tpLLcI2mQMJXMmCu5hwDj9u/toaGmOA1CqUkX4o+KnDcq7L/ACx++Tz/AG7Z4++trbTm 5RzGnd1mSPcTM2Vbg5z78j9j+WhoatjQ19AImkgaJJOotVdsBwWBU7csDwOOTwAeQdJ3mkjq41dE KSE42MRz35Bz9O+hoa19ExzqI2TwA6rSudZKeVoiVycruXPq4PcH3+/9udYvVQaytglKRxy0uE9K gjOO/bkHQ0NcvOW2AsbXEOWsDmZT8wzLEW2jYdzKT+eM9vtreannpN6VAhqAdwR2JZl4z3P2B9+P v30NDTXNAsqngB2iJpa6KeiTdSoUcbCeAwzwD2/XBzpYLc0cNOA6v5UudrL7EHPP7+2P8gNDVxgH U9ibuATzRMqNI0zmOFsFfS4zt44wRg+2irReHqJflRCkEgIAK4YerPB4Bx3/AOuhoabEcztVdZiQ UfXUsyzRSzyKIgwCmIYYOeB9MjtnJ/Q6KZSLrLB5SGVQFfLkK6n34A5/POfroaGjyNJshZcjaGnN aJTyq4hGxBFn0bmcA9/STyBj27e2PfSmCVFZVjVkJy0bAjgjkgjHb20NDWYtF2q6NrboJWPKeaIx LtknBfkDacfUcgfoP20WZihIMMMvPeVdxH2ydDQ1ol6pFI6DW6L/2Q= ________________________________________________________________________________
Subject: Re: Is this meant to be a Piet?
Date: Nov 04, 2015
A GN-1...obviously the town stud... Sent from my iPad Jack Textor > On Nov 4, 2015, at 3:29 PM, Steven Dortch wrot e: > > Built to plans. Heck I may try the exhaust shield. >> On Nov 4, 2015 2:20 PM, "David" wrote: >> http://www.cnn.com/2015/10/22/africa/asmelash-zeferu-plane-ethiopia/?iid= ob_article_footer_expansion&iref=obinsite >> >> ________________________________________________________________________________
Date: Nov 04, 2015
Subject: Re: Wavy Okoume Plywood Leading Edge
From: "Charles N. Campbell" <charlescampbell1924(at)gmail.com>
Next time make sure the cargo straps are on a rib location. C On Wed, Nov 4, 2015 at 11:53 AM, Tim White wrote: > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge > (trammeled with ribs, compression struts and leading edge glued). I used > cargo straps around each rib and clamps on the font edge to secure it while > curing. Brought the wing to Florida for the winter and found the plywood > was sunken or wavy between several of the ribs (picture). The other wing > seems OK with a slight bulge on the plywood away from the leading edge. I > am at a loss to determine how this happened unless I got the cargo straps > too tight. I assume this deformation will transmit through the fabric (not > having covered an airplane before). I want to remove it and try over. Any > ideas of what went wrong? Any ideas on how to remove it? > > Tim White > Ocklawaha, Fl > ________________________________________________________________________________
Subject: Is this meant to be a Piet?
Date: Nov 04, 2015
He might save some weight by taking the sprockets off the motorcycle wheels. From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Sent: Wednesday, November 04, 2015 1:41 PM Subject: Re: Pietenpol-List: Is this meant to be a Piet? A GN-1...obviously the town stud... Sent from my iPad Jack Textor On Nov 4, 2015, at 3:29 PM, Steven Dortch wrote: Built to plans. Heck I may try the exhaust shield. On Nov 4, 2015 2:20 PM, "David" wrote: http://www.cnn.com/2015/10/22/africa/asmelash-zeferu-plane-ethiopia/?iid= ob_article_footer_expansion <http://www.cnn.com/2015/10/22/africa/asmelash-zeferu-plane-ethiopia/?iid =ob_article_footer_expansion&iref=obinsite> &iref=obinsite ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Nov 04, 2015
He could be one of us on this list. He obviously has access to a computer to watch youtube. Makes a guy want to go down there and help they poor fella out. We could take up a collection and at least send him a suitable engine. On second thought, he won't get too hurt with only a VDub engine. It's safer for him that way. Gives a new meaning to "Your results may vary" -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448730#448730 ________________________________________________________________________________
Date: Nov 04, 2015
Charles I used brads on mine... Sent from my iPhone > On Nov 4, 2015, at 3:55 PM, "Charles N. Campbell" wrote: > > Next time make sure the cargo straps are on a rib location. C > >> On Wed, Nov 4, 2015 at 11:53 AM, Tim White wrote: >> Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (tra mmeled with ribs, compression struts and leading edge glued). I used cargo s traps around each rib and clamps on the font edge to secure it while curing. Brought the wing to Florida for the winter and found the plywood was sunke n or wavy between several of the ribs (picture). The other wing seems OK wi th a slight bulge on the plywood away from the leading edge. I am at a loss to determine how this happened unless I got the cargo straps too tight. I a ssume this deformation will transmit through the fabric (not having covered a n airplane before). I want to remove it and try over. Any ideas of what we nt wrong? Any ideas on how to remove it? >> >> Tim White >> Ocklawaha, Fl > ________________________________________________________________________________
Subject: Re: Finally on the Gear!
Date: Nov 04, 2015
Here's a link to a previous discussion on toe-in/toe-out. At the end there's an article from the old SAA magazine "To Fly." http://forums.matronics.com/viewtopic.php?t=102433&highlight=toein Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448747#448747 ________________________________________________________________________________
Date: Nov 04, 2015
Looks like the plywood swelled. If heating removes it successfully, might lay back down alright. Maybe get the wing somewhere air conditioned and see if the problem corrects itself. Then varnish it. Under tension, should be alright, as in if it moves to a condition of less humidity. Aluminum skins can do the same thing if installed cold, and then put in the sun. Recommend varnishing as soon as practical after installation to help stabilize the wood with respect to moisture content. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448753#448753 ________________________________________________________________________________
Date: Nov 05, 2015
Looks ok compared to some homebuilts. I would check cg very carefully =8B and the power plant? Obviously a Piet inspired project. Can we reach and warn him about at least cg if all else is fine? Semih 2015-11-05 0:04 GMT+02:00 The real bike Mike : > He might save some weight by taking the sprockets off the motorcycle > wheels. > > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Jack > *Sent:* Wednesday, November 04, 2015 1:41 PM > *To:* pietenpol-list(at)matronics.com > *Subject:* Re: Pietenpol-List: Is this meant to be a Piet? > > > A GN-1...obviously the town stud... > > Sent from my iPad > > Jack Textor > > > On Nov 4, 2015, at 3:29 PM, Steven Dortch > wrote: > > Built to plans. Heck I may try the exhaust shield. > > On Nov 4, 2015 2:20 PM, "David" wrote: > > > http://www.cnn.com/2015/10/22/africa/asmelash-zeferu-plane-ethiopia/?iid =ob_article_footer_expansion&iref=obinsite > > > > -- Semih Oksay ________________________________________________________________________________
Date: Nov 05, 2015
I looked at the photo carefully. The plywood was glued correctly. This is not a cargo strap location error. It seems like moisture problem. I have been to Florida and know about the humidity. Heating is a solution but I do not recommend local heating with a gun. A few days in a dry room should make it fine. If you have a problem about drying the room, please contact me. In addition, never varnish one side of a thin plywood or veneer and forget it. It curves towards the varnished side because one day moisture swells the unvarnished side. my 2=8B cents Happy landings Semih 2015-11-05 1:05 GMT+02:00 Jack : > Charles I used brads on mine... > > Sent from my iPhone > > On Nov 4, 2015, at 3:55 PM, "Charles N. Campbell" < > charlescampbell1924(at)gmail.com> wrote: > > Next time make sure the cargo straps are on a rib location. C > > On Wed, Nov 4, 2015 at 11:53 AM, Tim White wrote: > >> Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge >> (trammeled with ribs, compression struts and leading edge glued). I use d >> cargo straps around each rib and clamps on the font edge to secure it wh ile >> curing. Brought the wing to Florida for the winter and found the plywoo d >> was sunken or wavy between several of the ribs (picture). The other win g >> seems OK with a slight bulge on the plywood away from the leading edge. I >> am at a loss to determine how this happened unless I got the cargo strap s >> too tight. I assume this deformation will transmit through the fabric ( not >> having covered an airplane before). I want to remove it and try over. Any >> ideas of what went wrong? Any ideas on how to remove it? >> >> Tim White >> Ocklawaha, Fl >> > > -- Semih Oksay ________________________________________________________________________________
Date: Nov 05, 2015
Bill thanks once again for your thoughtful info... Sent from my iPad Jack Textor > On Nov 4, 2015, at 8:52 PM, "Bill Church" wrote: > > > Here's a link to a previous discussion on toe-in/toe-out. At the end there's an article from the old SAA magazine "To Fly." > http://forums.matronics.com/viewtopic.php?t=102433&highlight=toein > > Bill C. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=448747#448747 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 05, 2015
they were On 11/4/2015 4:55 PM, Charles N. Campbell wrote: > Next time make sure the cargo straps are on a rib location. C > > On Wed, Nov 4, 2015 at 11:53 AM, Tim White > wrote: > > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading > edge (trammeled with ribs, compression struts and leading edge > glued). I used cargo straps around each rib and clamps on the > font edge to secure it while curing. Brought the wing to Florida > for the winter and found the plywood was sunken or wavy between > several of the ribs (picture). The other wing seems OK with a > slight bulge on the plywood away from the leading edge. I am at a > loss to determine how this happened unless I got the cargo straps > too tight. I assume this deformation will transmit through the > fabric (not having covered an airplane before). I want to remove > it and try over. Any ideas of what went wrong? Any ideas on how > to remove it? > > Tim White > Ocklawaha, Fl > > ________________________________________________________________________________
Date: Nov 05, 2015
Jack, It is 90 degrees with up to 100% humidity (some places setting records). I was very careful to put the straps directly on the ribs. I'm going back to Ohio for the holidays, think I'll let them sit until the heat and humidity go down in January. Thanks much for your help. Tim On 11/4/2015 9:17 AM, Jack Philips wrote: > > Tim, > > Were the cargo straps directly on top of the ribs? If so, I don't think they could have caused the deformation. You said you glued them two weeks ago and then moved them to Florida. How long have they been in Florida? I suspect that Florida is the culprit. Being very humid, the Florida air will make the plywood swell and deform between the ribs. Can you move the wing(s) into a heated space and let them acclimate for a couple of weeks? If so, I expect you'll find that they smooth right out. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tim White > Sent: Wednesday, November 4, 2015 8:54 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Wavy Okoume Plywood Leading Edge > > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (trammeled with ribs, compression struts and leading edge glued). I used cargo straps around each rib and clamps on the font edge to secure it while curing. Brought the wing to Florida for the winter and found the plywood was sunken or wavy between several of the ribs (picture). > The other wing seems OK with a slight bulge on the plywood away from the leading edge. I am at a loss to determine how this happened unless I got the cargo straps too tight. I assume this deformation will transmit through the fabric (not having covered an airplane before). I want to remove it and try over. Any ideas of what went wrong? Any ideas on how to remove it? > > Tim White > Ocklawaha, Fl > > ________________________________________________________________________________
Date: Nov 05, 2015
Lorenzo, Thanks for the tip. I'm going to let it sit for a while until the heat and humidity goes down and see what happens. Might still have to take it off. Tim On 11/4/2015 9:20 AM, larharris2 Harris wrote: > How to remove it: Heat the plywood surface over a glue joint with a > hot iron. The joint will separate like peeling a post-it note. > > Lorenzo > > > > To: pietenpol-list(at)matronics.com > > From: aa5flyer(at)gmail.com > > Subject: Pietenpol-List: Wavy Okoume Plywood Leading Edge > > Date: Wed, 4 Nov 2015 08:53:47 -0500 > > > > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge > > (trammeled with ribs, compression struts and leading edge glued). I > > used cargo straps around each rib and clamps on the font edge to secure > > it while curing. Brought the wing to Florida for the winter and found > > the plywood was sunken or wavy between several of the ribs (picture). > > The other wing seems OK with a slight bulge on the plywood away from > the > > leading edge. I am at a loss to determine how this happened unless I > > got the cargo straps too tight. I assume this deformation will transmit > > through the fabric (not having covered an airplane before). I want to > > remove it and try over. Any ideas of what went wrong? Any ideas on how > > to remove it? > > > > Tim White > > Ocklawaha, Fl ________________________________________________________________________________
Date: Nov 05, 2015
Think I'm going to wait until the heat and humidity goes down. Meanwhile, I'll work on the center section. Thanks to all who replied. Tim White On 11/5/2015 2:09 AM, Semih Oksay wrote: > I looked at the photo carefully. The plywood was glued correctly. This > is not a cargo strap location error. It seems like moisture problem. I > have been to Florida and know about the humidity. Heating is a > solution but I do not recommend local heating with a gun. A few days > in a dry room should make it fine. If you have a problem about drying > the room, please contact me. In addition, never varnish one side of a > thin plywood or veneer and forget it. It curves towards the varnished > side because one day moisture swells the unvarnished side. > > my 2 cents > > Happy landings > > Semih > > 2015-11-05 1:05 GMT+02:00 Jack >: > > Charles I used brads on mine... > > Sent from my iPhone > > On Nov 4, 2015, at 3:55 PM, "Charles N. Campbell" > > wrote: > >> Next time make sure the cargo straps are on a rib location. C >> >> On Wed, Nov 4, 2015 at 11:53 AM, Tim White > > wrote: >> >> Two weeks ago I glued (T-88) 1/16" Okoume plywood to my >> leading edge (trammeled with ribs, compression struts and >> leading edge glued). I used cargo straps around each rib and >> clamps on the font edge to secure it while curing. Brought >> the wing to Florida for the winter and found the plywood was >> sunken or wavy between several of the ribs (picture). The >> other wing seems OK with a slight bulge on the plywood away >> from the leading edge. I am at a loss to determine how this >> happened unless I got the cargo straps too tight. I assume >> this deformation will transmit through the fabric (not having >> covered an airplane before). I want to remove it and try >> over. Any ideas of what went wrong? Any ideas on how to >> remove it? >> >> Tim White >> Ocklawaha, Fl >> >> > > > -- > Semih Oksay ________________________________________________________________________________
Date: Nov 05, 2015
Jack, If waiting for heat and humidity to go down doesn't work, I'll try it. Thanks, Tim On 11/4/2015 2:23 PM, Jack wrote: > > Tim just an idea... If you have not varnished yet, wet the underside of one bay with a cloth and see how it dries. Maybe heat with an iron??? > > Sent from my iPad > Jack Textor > >> On Nov 4, 2015, at 7:53 AM, Tim White wrote: >> >> Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (trammeled with ribs, compression struts and leading edge glued). I used cargo straps around each rib and clamps on the font edge to secure it while curing. Brought the wing to Florida for the winter and found the plywood was sunken or wavy between several of the ribs (picture). The other wing seems OK with a slight bulge on the plywood away from the leading edge. I am at a loss to determine how this happened unless I got the cargo straps too tight. I assume this deformation will transmit through the fabric (not having covered an airplane before). I want to remove it and try over. Any ideas of what went wrong? Any ideas on how to remove it? >> >> Tim White >> Ocklawaha, Fl >> > > ________________________________________________________________________________
Subject: Re: Wheel alignment....
Date: Nov 05, 2015
Excellent article Bill, great input. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448770#448770 ________________________________________________________________________________
Date: Nov 05, 2015
I think this would certainly be an act of kindness. Maybe some of our expert s that we rely on could help him. I think Scott L or Oscar Z would be the be st sources. I fear that the maximum weight might be the main culprit. It see ms that the metal used, as well as the "lumber" might have resulted in excee ding the MTOW, whatever that might be. If it might get off the ground with h is power source, we don't want him to hurt himself, or others. He certainly is to be admired! I've been to rather "backward" countries and could not even imagine trying such a project. His ambition puts me to shame , for sure. Ray Krause Sent from my iPad > On Nov 4, 2015, at 10:57 PM, Semih Oksay wrote: > > Looks ok compared to some homebuilts. I would check cg very carefully =8B and the power plant? Obviously a Piet inspired project. Can we reach and warn him about at least cg if all else is fine? > > Semih > > 2015-11-05 0:04 GMT+02:00 The real bike Mike : >> He might save some weight by taking the sprockets off the motorcycle whee ls. >> >> >> >> From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-l ist-server(at)matronics.com] On Behalf Of Jack >> Sent: Wednesday, November 04, 2015 1:41 PM >> To: pietenpol-list(at)matronics.com >> Subject: Re: Pietenpol-List: Is this meant to be a Piet? >> >> >> >> A GN-1...obviously the town stud... >> >> Sent from my iPad >> >> Jack Textor >> >> >> On Nov 4, 2015, at 3:29 PM, Steven Dortch wro te: >> >> Built to plans. Heck I may try the exhaust shield. >> >> On Nov 4, 2015 2:20 PM, "David" wrote: >> >> http://www.cnn.com/2015/10/22/africa/asmelash-zeferu-plane-ethiopia/?iid= ob_article_footer_expansion&iref=obinsite >> >> >> > > > > -- > Semih Oksay ________________________________________________________________________________
Date: Nov 05, 2015
Does this mean that you may fly only in hot, dry areas? Maybe the leading ed ges should be installed only during maximum humidity conditions? I live in h ot, dry California where I installed my leading edges. What will happen if I fly back to Brodhead? Assuming, of course, that I would/could do such a th ing? Ray Krause Sent from my iPad > On Nov 5, 2015, at 4:07 AM, Tim White wrote: > > > Jack, > > It is 90 degrees with up to 100% humidity (some places setting records). I was very careful to put the straps directly on the ribs. I'm going back to Ohio for the holidays, think I'll let them sit until the heat and humidity g o down in January. Thanks much for your help. > > Tim > >> On 11/4/2015 9:17 AM, Jack Philips wrote: s.com> >> >> Tim, >> >> Were the cargo straps directly on top of the ribs? If so, I don't think t hey could have caused the deformation. You said you glued them two weeks a go and then moved them to Florida. How long have they been in Florida? I s uspect that Florida is the culprit. Being very humid, the Florida air will m ake the plywood swell and deform between the ribs. Can you move the wing(s) into a heated space and let them acclimate for a couple of weeks? If so, I expect you'll find that they smooth right out. >> >> Jack Phillips >> NX899JP >> Smith Mountain Lake, Virginia >> >> -----Original Message----- >> From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-l ist-server(at)matronics.com] On Behalf Of Tim White >> Sent: Wednesday, November 4, 2015 8:54 AM >> To: pietenpol-list(at)matronics.com >> Subject: Pietenpol-List: Wavy Okoume Plywood Leading Edge >> >> Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (tra mmeled with ribs, compression struts and leading edge glued). I used cargo s traps around each rib and clamps on the font edge to secure it while curing. Brought the wing to Florida for the winter and found the plywood was sunke n or wavy between several of the ribs (picture). >> The other wing seems OK with a slight bulge on the plywood away from the l eading edge. I am at a loss to determine how this happened unless I got the cargo straps too tight. I assume this deformation will transmit through th e fabric (not having covered an airplane before). I want to remove it and t ry over. Any ideas of what went wrong? Any ideas on how to remove it? >> >> Tim White >> Ocklawaha, Fl > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Nov 05, 2015
I can't imagine how difficult it would be to acquire quality building materials and tools to build with there. It makes me appreciate even more everything I have access to here. That said, it looks like his left wing trailing edge is warped downwards pretty bad...hopefully that gets corrected before he attempts flight again (which I think is this month?) -------- Jon Jones Ironton, MO Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448780#448780 ________________________________________________________________________________
Date: Nov 05, 2015
Here is difference in angle that I see. -------- Jon Jones Ironton, MO Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448781#448781 Attachments: http://forums.matronics.com//files/angle_125.jpg ________________________________________________________________________________
Date: Nov 05, 2015
Subject: Coming Soon - The List of Contributors - Please Make A
Contribution Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 05, 2015
The lead edge is very critical to the airflow and must be have a very smooth transition or you will not have an laminar airflow which could stall the wing at higher airspeed. Issue with not using aircraft grade plywood ... ? Did a plywood leading edge on my Piper L-4, still smooth as when I applied it. See pictures on my link below. Remove and start over .... no covering will help it and if reworked with heat, will come back later with humidity changes. Apply new skins and seal right away to stabilize the wood. Be safe! WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448863#448863 ________________________________________________________________________________
Date: Nov 05, 2015
Hmmm... Good post. My GN-1 always seems a bit squirrely on hard surface landings...gotta dance on the rudder pedals much more so than in a Cub or a Champ. The right J3 gear leg always had a twist in it since a previous owner wiped out in a takeoff incident back in 2000. When it was repaired, it looks like they might have stuck it in a vice and eyeballed it. I am considering buying a new RH gear for my next annual..unless I can find a decent used one. Lar -------- KLNC A65-8 N2308C Slick 4330's AN Hardware Airframe 755TT W72CK-42 Sensenich Standard Factory GN-1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448864#448864 Attachments: http://forums.matronics.com//files/img_7206_159.png ________________________________________________________________________________
Date: Nov 05, 2015
Is there a way to see if he is on this forum? Is it possible to get his email address? Come on, you computer geeks? Ray Krause Sent from my iPad > On Nov 5, 2015, at 9:25 AM, wheelharp wrote: > > > Here is difference in angle that I see. > > -------- > Jon Jones > Ironton, MO > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=448781#448781 > > > > > Attachments: > > http://forums.matronics.com//files/angle_125.jpg > > > > > > > ________________________________________________________________________________
Date: Nov 05, 2015
WF2, Laminar flow? Really? On a Pietenpol wing? Wonder how 6-ply hard cardboard might fare. You know, as shown in the plans. I don't think the use of Okoume vs Aircraft ply is an issue here. BC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448871#448871 ________________________________________________________________________________
Date: Nov 06, 2015
This morning while fueling my Pietenpol as I looked down both wings the plywood is pulled down between each rib by the fabric. I used Okoume plywood too, but I don't remember it being warped prior to covering. It still flies very nicely. Just my $.02 Ben Charvet NX 866BC. 275 hrs Bill Church wrote: > >WF2, > >Laminar flow? Really? >On a Pietenpol wing? > >Wonder how 6-ply hard cardboard might fare. >You know, as shown in the plans. > >I don't think the use of Okoume vs Aircraft ply is an issue here. > >BC > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=448871#448871 > > ________________________________________________________________________________
Date: Nov 06, 2015
WF2, In your wing pic, there are two aets of green structural items; one of which is clearly part of the wing itself. The other appears to be some form of wing stand... Would you care to show a few pics of the stand, and tell us how is works, etc.? Thanks! -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448878#448878 ________________________________________________________________________________
Date: Nov 06, 2015
This guy has great ambitions. I picked up the phone yesterday and called EAA to see if they knew about this fella. I'm thinking that it would be a kind jester to bring him to Osh next year so he can see how it should be done. Long story short, It was lunch time in Osh so I didn't get a chance to speak with anyone. If you look closely you can see all the nails or screws he use to attach the covering material to the longerons. I think at best this gentleman has something he might be able to taxi around a little. There is not enough power there to even get the tail off the ground. Nothing is straight and all the cables are just kinda tied on with knots. I may try and call EAA again today if I get a chance. I think the best help we can offer him is to mentor him for his next project. He has registration numbers on it so I'm sure EAA could find him that way. I don't think that CNN would give up the guys contact information to any of us common folk. Maybe to EAA, but not us. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448879#448879 ________________________________________________________________________________
Date: Nov 06, 2015
What plywood did you use? Source? Thickness? Tim White On 11/5/2015 3:54 PM, womenfly2 wrote: > > The lead edge is very critical to the airflow and must be have a very smooth transition or you will not have an laminar airflow which could stall the wing at higher airspeed. > > Issue with not using aircraft grade plywood ... ? Did a plywood leading edge on my Piper L-4, still smooth as when I applied it. See pictures on my link below. > > Remove and start over .... no covering will help it and if reworked with heat, will come back later with humidity changes. Apply new skins and seal right away to stabilize the wood. > > Be safe! > WF2 > > -------- > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=448863#448863 > > ________________________________________________________________________________
Date: Nov 06, 2015
No link on my computer! C On Thu, Nov 5, 2015 at 6:54 PM, womenfly2 wrote: > > The lead edge is very critical to the airflow and must be have a very > smooth transition or you will not have an laminar airflow which could stall > the wing at higher airspeed. > > Issue with not using aircraft grade plywood ... ? Did a plywood leading > edge on my Piper L-4, still smooth as when I applied it. See pictures on my > link below. > > Remove and start over .... no covering will help it and if reworked with > heat, will come back later with humidity changes. Apply new skins and seal > right away to stabilize the wood. > > Be safe! > WF2 > > -------- > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=448863#448863 > > ________________________________________________________________________________
Date: Nov 06, 2015
Just a thought and not advice. At least when I do something the second time I do it much better and faster. Blue Skies, Steve D On Fri, Nov 6, 2015 at 8:55 AM, Charles N. Campbell < charlescampbell1924(at)gmail.com> wrote: > No link on my computer! C > > On Thu, Nov 5, 2015 at 6:54 PM, womenfly2 wrote: > >> > >> >> The lead edge is very critical to the airflow and must be have a very >> smooth transition or you will not have an laminar airflow which could stall >> the wing at higher airspeed. >> >> Issue with not using aircraft grade plywood ... ? Did a plywood leading >> edge on my Piper L-4, still smooth as when I applied it. See pictures on my >> link below. >> >> Remove and start over .... no covering will help it and if reworked with >> heat, will come back later with humidity changes. Apply new skins and seal >> right away to stabilize the wood. >> >> Be safe! >> WF2 >> >> -------- >> >> >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=448863#448863 >> >> >> >> >> >> >> >> ========== >> br> fts!) >> r> > w.buildersbooks.com" rel="noreferrer" target="_blank"> >> www.buildersbooks.com >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> -Matt Dralle, List Admin. >> ========== >> br> enpol-List" rel="noreferrer" target="_blank"> >> http://www.matronics.com/Navigator?Pietenpol-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > -- Blue Skies, Steve D ________________________________________________________________________________
Subject: Introducing myself and question about lumber purchase...
Date: Nov 06, 2015
Hello. My name is Bill Kendrick from San Antonio, TX. I am new to the list and just wanted to introduce myself. I made the decision a few weeks ago to start a Pietenpol build. I have only constructed my work benches and purchased the set of plans. I plan to start with the fuselage but have not purchased any materials yet. Can any of you offer suggestions as to what to purchase first regarding lumber? I have priced the A.S. fuselage kit ($1085 I believe) but was wondering if the bargain bag would be a better way to go given the much lower price. I guess my question is will there be enough footage in the bargain bag (or multiple bargain bags) to do the fuselage or at least get started? Thanks, Bill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448886#448886 ________________________________________________________________________________
Subject: Ethiopian Piet type video
Date: Nov 06, 2015
This is how the prop broke. Wow, first weak link is gone. EAA national knows of the guy and they say that they are in no position to help. Although, If we got this guy to the OSH fly-in they might be able to provide tickets for him to attend. Pretty weak response from them as far as I am concerned. https://www.youtube.com/watch?v=dgMMfcnI3A4 -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448890#448890 ________________________________________________________________________________
Subject: Re: Introducing myself and question about lumber purchase...
Date: Nov 06, 2015
I've not heard anyone complain about the bargain bag. But, not enough to build a fuse I don't think. So, where are ya and what are your capabilities and goals? If you are a well connected or equipped woodworker, I'd try to buy rough lumber locally and mill yourself. If you aren't, or want to build quicker, just get the kit. So it really depends as you see. Doug fir is pretty easy to get if you don't mind the weight penalty, which may be moot if you're not going to install batteries, transponders, radios... If you're using a hunnert horse corvair, may not matter. If you're using a ford, it might. If you live near Madison wi, spruce is available locally. Maybe also so out west or merely a very well stocked lumber yard. If you live near Atlanta, shipping that stuff won't matter because you can pick up locally. Same for other vendors. Great choice of plane. Also consider getting an abandoned project as a kick start, unless one of your goals is doing it all yourself. Cheers, Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448891#448891 ________________________________________________________________________________
Date: Nov 06, 2015
Oh, sorry, just saw location. Is Alamo hardwoods still in business? Used to be the best stocked lumberyard I EVER saw. Probably has spruce... Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448892#448892 ________________________________________________________________________________
Date: Nov 06, 2015
Subject: Re: Ethiopian Piet type video
Someone should start a "Go Fund Me" doo dad.... On Fri, Nov 6, 2015 at 2:32 PM, AircamperN11MS wrote: > Scott.liefeld(at)lacity.org> > > This is how the prop broke. Wow, first weak link is gone. > > EAA national knows of the guy and they say that they are in no position to > help. Although, If we got this guy to the OSH fly-in they might be able to > provide tickets for him to attend. Pretty weak response from them as far > as I am concerned. > > https://www.youtube.com/watch?v=dgMMfcnI3A4 > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=448890#448890 > > ________________________________________________________________________________
Date: Nov 06, 2015
Tim, I used 1/16th inch thick plywood from Aircraft Spruce (not the type you mentioned). I put on two coats of varnish after completion of the structure and have never had any problems with it. Just finished the covering and painting and it looks pretty good. I would suggest you remove the bent plywood and start over. As soon as possible after completing the structure give it a couple of coats of varnish and everything will be OK. Chuck On Fri, Nov 6, 2015 at 12:28 PM, Tim White wrote: > > What plywood did you use? Source? Thickness? > > Tim White > > On 11/5/2015 3:54 PM, womenfly2 wrote: > >> > >> >> The lead edge is very critical to the airflow and must be have a very >> smooth transition or you will not have an laminar airflow which could stall >> the wing at higher airspeed. >> >> Issue with not using aircraft grade plywood ... ? Did a plywood leading >> edge on my Piper L-4, still smooth as when I applied it. See pictures on my >> link below. >> >> Remove and start over .... no covering will help it and if reworked with >> heat, will come back later with humidity changes. Apply new skins and seal >> right away to stabilize the wood. >> >> Be safe! >> WF2 >> >> -------- >> >> >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=448863#448863 >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Nov 06, 2015
All we would like to do is communicate with this fellow. Help him in his project and encourage him in his efforts. Would the operator (Matt) of this forum have any way to know if he has looked at this forum or tried to join? His coming to OSH would be a triumph in publicity for EAA, but that is not what this fellow needs. Coming from such a poor country, he would be overwhelmed at OSH and probably deeply depressed and ashamed of his efforts. If he just had the plans for a Piet, or GN-1, or maybe even a MiniMax would be a great help. Ship him some Spruce, chromoly, some fabric, some T-88. Maybe even an Aerovee engine, a close to-run-out A-65, an old prop...maybe even some encouragement! How about Michael P's set of building videos? Maybe an old Nicopress tool, cable, screen door turnbuckles! Anything would be better than cables tied in knots! Let's try to help, not use him or try to show him what great things we can do in this country...with virtually unlimited resources! Enough of my preaching, Ray Krause Sent from my iPad > On Nov 6, 2015, at 11:32 AM, AircamperN11MS wrote: > > > This is how the prop broke. Wow, first weak link is gone. > > EAA national knows of the guy and they say that they are in no position to help. Although, If we got this guy to the OSH fly-in they might be able to provide tickets for him to attend. Pretty weak response from them as far as I am concerned. > > https://www.youtube.com/watch?v=dgMMfcnI3A4 > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=448890#448890 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 06, 2015
Hi Bill, You can NOT build a fuselage from bargain bags of spruce from Aircraft Spruce. The wood in the bargain bags is all good quality Sitka, but every piece is a random size, obtained from offcuts. The longest pieces in the bargain bag are 5 feet in length, with thicknesses varying from 1/4" to 1". The longerons of the fuselage are 1" x 1" x about 16 feet long. Having said that, one or two "bargain bags" would be a wise purchase if you're building a Piet, (assuming you have a table saw, or some means to re-saw to the sizes you need). Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448898#448898 ________________________________________________________________________________
Date: Nov 06, 2015
https://www.facebook.com/asmelash.zeferu Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448899#448899 ________________________________________________________________________________
Date: Nov 07, 2015
I am only studying to build a piet for now. Seeing this phenomena is interesting. A thought to remove the moisture could be to bag the wing and pull a low vacum on it removing any moisture from it. Some painters plastic, some duct tape to seal the bag. A simple vacuum Venturi and compressor to pull it down. It may remove the moisture. I do think though if this occurred with a heavy UV load and the glue within the wood softened and re hardened, then there are other concerns. Interesting subject. I hope the repair however it is accomplished is simple for you. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448900#448900 ________________________________________________________________________________
Date: Nov 07, 2015
Welcome to the club Bill. As others have mentioned the bargain bag won't work. I started with the ribs which allowed me to gain experience, find out if building from plans was a good idea and the cost for rib parts was pretty minimal. I used Douglas fir for my fuselage longerons and wish I used spruce. Starting with the fuselage will raise many questions early on, like which engine, gear, long or short fuselage, etc. However you begin, as time goes on you may find deals on partially completed projects, wood from projects never started, etc. good luck and enjoy! Jack Sent from my iPad Jack Textor > On Nov 6, 2015, at 12:09 PM, "bkendr01" wrote: > > > Hello. My name is Bill Kendrick from San Antonio, TX. I am new to the list and just wanted to introduce myself. I made the decision a few weeks ago to start a Pietenpol build. I have only constructed my work benches and purchased the set of plans. I plan to start with the fuselage but have not purchased any materials yet. Can any of you offer suggestions as to what to purchase first regarding lumber? I have priced the A.S. fuselage kit ($1085 I believe) but was wondering if the bargain bag would be a better way to go given the much lower price. I guess my question is will there be enough footage in the bargain bag (or multiple bargain bags) to do the fuselage or at least get started? > > Thanks, > Bill > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=448886#448886 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 07, 2015
Bill, I forgot about Alamo hardwood here in San Antonio. You will have to learn how to select the wood. Grain, ring count and so on. The cost of the wood will be only a part of the cost. Remember, I am doing a restoration so I did not need big wood. The bargan bag gives you good cheap wood to practice and screw up. You may have to wait some for your bag. They wait until they have enough scraps to fill a box. To start you might do the tail or ribs. For me, seeing a part that looks like a plane part is good motivation. But it is your build. Blue Skies, Steve D On Nov 7, 2015 8:26 AM, "Jack" wrote: > > Welcome to the club Bill. As others have mentioned the bargain bag won't > work. I started with the ribs which allowed me to gain experience, find > out if building from plans was a good idea and the cost for rib parts was > pretty minimal. I used Douglas fir for my fuselage longerons and wish I > used spruce. Starting with the fuselage will raise many questions early > on, like which engine, gear, long or short fuselage, etc. However you > begin, as time goes on you may find deals on partially completed projects, > wood from projects never started, etc. good luck and enjoy! > Jack > > Sent from my iPad > Jack Textor > > > On Nov 6, 2015, at 12:09 PM, "bkendr01" wrote: > > > bill_kendrick(at)yahoo.com> > > > > Hello. My name is Bill Kendrick from San Antonio, TX. I am new to the > list and just wanted to introduce myself. I made the decision a few weeks > ago to start a Pietenpol build. I have only constructed my work benches > and purchased the set of plans. I plan to start with the fuselage but have > not purchased any materials yet. Can any of you offer suggestions as to > what to purchase first regarding lumber? I have priced the A.S. fuselage > kit ($1085 I believe) but was wondering if the bargain bag would be a > better way to go given the much lower price. I guess my question is will > there be enough footage in the bargain bag (or multiple bargain bags) to do > the fuselage or at least get started? > > > > Thanks, > > Bill > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=448886#448886 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 07, 2015
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2015
Ryan, Thanks for the link. I sent him a message. Let's see what happens. Ray Krause Sent from my iPad > On Nov 6, 2015, at 9:36 PM, Ryan Mueller wrote: > > > https://www.facebook.com/asmelash.zeferu > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=448899#448899 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 07, 2015
Bill; Too bad you didn't make your decision to start building a Piet a few years ago when I lived in San Antonio. I had my Piet out at San Geronimo (8T8) and had (still have) all of the plywood and rough lumber (Douglas fir) to build a another Piet fuselage, wings, and tail surfaces. Would have been easier for me to pass it on to a new builder than load and haul it 2300 miles to sit in my hangar here in Oregon ;o) However, several others have mentioned that it is possible to find already-started projects in a good state of progress at a very reasonable price. In fact, the one that Tom Brant was offering for $1500 would be worth looking into and would save you a lot of time and money. He is in the Minneapolis area but you could drive up there over the holidays with a trailer and have it back in time to start on it as a New Year's resolution. There are only three pictures of Tom's project on Westcoastpiet but from what I see in the pictures, it's excellent material and workmanship. Check it out: http://westcoastpiet.com/images/Tom%20Brant/Tom%20Brant.htm . By the way, you will want to bookmark the Westcoastpiet site because if you ever have a question about how something is built or what it looks like, you will absolutely, positively be able to find a picture of it by browsing the pictures there. It is the Air Camper's "Treasure of the Sierra Madre" ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448986#448986 ________________________________________________________________________________
Date: Nov 07, 2015
Oscar, bill came by my Hangar and sat in NX3379. He also looked at Lew Mason's flybaby. He elected to build a Pietenpol. Blue skies, Steve D On Nov 7, 2015 12:14 PM, "taildrags" wrote: > > Bill; > > Too bad you didn't make your decision to start building a Piet a few > years ago when I lived in San Antonio. I had my Piet out at San Geronimo > (8T8) and had (still have) all of the plywood and rough lumber (Douglas > fir) to build a another Piet fuselage, wings, and tail surfaces. Would > have been easier for me to pass it on to a new builder than load and haul > it 2300 miles to sit in my hangar here in Oregon ;o) > > However, several others have mentioned that it is possible to find > already-started projects in a good state of progress at a very reasonable > price. In fact, the one that Tom Brant was offering for $1500 would be > worth looking into and would save you a lot of time and money. He is in > the Minneapolis area but you could drive up there over the holidays with a > trailer and have it back in time to start on it as a New Year's > resolution. There are only three pictures of Tom's project on > Westcoastpiet but from what I see in the pictures, it's excellent material > and workmanship. Check it out: > http://westcoastpiet.com/images/Tom%20Brant/Tom%20Brant.htm . By the > way, you will want to bookmark the Westcoastpiet site because if you ever > have a question about how something is built or what it looks like, you > will absolutely, positively be able to find a picture of it by browsing the > pictures there. It is the Air Camper's "Treasure of the Sierra Madre" ;o) > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=448986#448986 > > ________________________________________________________________________________
Date: Nov 07, 2015
Steve: there are only two types of people in aviation: high-wingers and low-wingers. In south Texas, high-wingers have shade wherever they go ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448988#448988 ________________________________________________________________________________
Date: Nov 07, 2015
People have dreamed of flying since the creation. This gentleman in Ethiopia is doing better than a lot have done, but the world does not have a duty to help every dreamer make every contraption safe any more than it has a responsibility for what the results of the experiment are. You can bore yourself watching vintage videos of early attempts at flight, but here's a 7-minute sampling: https://www.youtube.com/watch?v=Sp7MHZY2ADI Some are entertaining, some are sad, a few are novel, a few were successful. The Ethiopian fellow's project is just one more in an almost timeless progression of attempts to make wings and fly. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448989#448989 ________________________________________________________________________________
Date: Nov 07, 2015
Oscar/Steve, Thanks for the info. I really considered the Flybaby because of the leg room but, although I seldom have a passenger, I like having the extra seat just in case. And yes, the shade will be handy;) Thanks, Bill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448990#448990 ________________________________________________________________________________
Date: Nov 07, 2015
I used Finnish plywood of 1mm thick about 3/64" from Aircraft Spruce. Their P/N: 02-50000 My web site should work click on lnk below, but if not copy and paste in your browser: Your wing surface should be smooth as possible. Good luck. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448991#448991 ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Date: Nov 07, 2015
The world does not have a duty... Big time engineer named Octave sure helped a couple of quack brothers from some weird place in Oh-hi-yo a few years ago... Sent from an iPhone with a spelling problem > On Nov 7, 2015, at 8:08 PM, taildrags wrote: > > > People have dreamed of flying since the creation. This gentleman in Ethiopia is doing better than a lot have done, but the world does not have a duty to help every dreamer make every contraption safe any more than it has a responsibility for what the results of the experiment are. You can bore yourself watching vintage videos of early attempts at flight, but here's a 7-minute sampling: > > https://www.youtube.com/watch?v=Sp7MHZY2ADI > > Some are entertaining, some are sad, a few are novel, a few were successful. The Ethiopian fellow's project is just one more in an almost timeless progression of attempts to make wings and fly. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=448989#448989 > > ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Nov 07, 2015
Bill Church wrote: > WF2, > > Laminar flow? Really? > On a Pietenpol wing? > > Wonder how 6-ply hard cardboard might fare. > You know, as shown in the plans. > > I don't think the use of Okoume vs Aircraft ply is an issue here. > > BC Yes, really. All airfoils rely on laminar flow. That is different than a laminar flow airfoil, which is specifically designed to exploit laminar flow. The opposite of laminar flow is turbulent flow, as seen during boundary layer separation, which nearly defines a stall. Do the original plans call for gluing or nailing the leading edge skins? Nailing would allow the skin to move with moisture content variation. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448993#448993 ________________________________________________________________________________
Date: Nov 07, 2015
Okay, maybe I misread the original statement. Having a smooth transition between the leading edge and the plywood attached to it is important, since this is the only part of the wing that will experience laminar flow (probably not more than the first 6" or so of the Pietenpol airfoil will experience laminar flow), and roughness or sharp edges would disrupt that. However, after the covering is applied, the fabric will pull down on the plywood between the ribs, effectively changing the airfoil. But it's been that way for over 80 years, and seems to be working all right so far. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448994#448994 ________________________________________________________________________________
Date: Nov 08, 2015
It is wishful thinking that the plywood will pull down when the fabric is applied. Never seen that happen, what ever the structures is under the fabric it will be that way when finished. Every aircraft manufacture will tell you the leading edge needs to be smooth. In my experience I have no knowledge of it being like that for 80 years, not what I have seen. There is no excuse for not correcting the issues and making it right, deep down we all what it to be right. Even dents on a Cubs leading edge can make the wing loose lift and needs to be corrected. Be helpful and truthful, all aircraft need to be built with the best skill and practices possible. If its not right correct it, its your life up there and your passenger if you take one .... their entrusting you with their life. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448998#448998 ________________________________________________________________________________
Date: Nov 08, 2015
Maybe there is some confusion by the question. Clearly, the plywood pulls down between the ribs, even though it starts out as straight. It is said that it is preferred not to be supported by a filler on the spar, between the ribs, to allow for it to be pulled down and make a smoother transition. I know for fact that my wing 'grows' during Winter, as I can see the aileron butt gap get closer when the humidity rises for an extended time (CA). Jack Phillips made the best suggestion, to allow it some time in a heated environment, and see if the plywood straightens up...then varnish! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of womenfly2 Sent: Sunday, November 08, 2015 9:47 AM Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge --> It is wishful thinking that the plywood will pull down when the fabric is applied. Never seen that happen, what ever the structures is under the fabric it will be that way when finished. Every aircraft manufacture will tell you the leading edge needs to be smooth. In my experience I have no knowledge of it being like that for 80 years, not what I have seen. There is no excuse for not correcting the issues and making it right, deep down we all what it to be right. Even dents on a Cubs leading edge can make the wing loose lift and needs to be corrected. Be helpful and truthful, all aircraft need to be built with the best skill and practices possible. If its not right correct it, its your life up there and your passenger if you take one .... their entrusting you with their life. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448998#448998 ________________________________________________________________________________
Date: Nov 08, 2015
On my Piet I used 45 degree mahogany plywood, I know its expensive, but I had no issues with it. It stayed pretty smooth in all temperature and humidity conditions here in NH. One thing is to add some stringers on the leading edge as in a model plane to give the plywood some support between the ribs too. Helps to keep the shape. But I really do not see the need for them on a Piet, the sheet area is pretty short and only on the top. If the wood is dried properly it should absorb very little moisture in the bare condition. Seal it as soon as its applied will help stabilize it too .... sealing both sides at the same time helps. All good input, WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=449001#449001 ________________________________________________________________________________
Date: Nov 08, 2015
Call it wishful thinking if you want. I prefer to call it observing details. If the plywood skin at the leading edge of the wing is installed per the plans (with no reinforcing at the back edge), the fabric will naturally pull the plywood down between the ribs, in the same way that the fabric pulls down between the ribs. This is not a drastic deflection, but it certainly is observable. In fact, the two photos supplied by Gary illustrate my point. The first photo shows the uncovered wing structure, with flat plywood. In the second photo, with the wing covered, the deflection of the plywood can be seen at the right hand side of the photo. For another example, see this photo: http://www.westcoastpiet.com/images/Jack%20Phillips/images/Brodhead2008_136.JPG In this aircraft, with the airfoil that it has, the trailing edge of the plywood in question is most likely no longer in the area of laminar flow. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=449002#449002 ________________________________________________________________________________
Date: Nov 08, 2015
At the risk of getting Dan Helsper mad at me, I'm going to post a picture of his wing turner because it is based on the same principle as WF2's wing-turning rotisserie but Dan's is made mostly of wood. Of course, his was almost a necessity since he built his wing all as one piece and turning that thing over requires a lot more work and planning than just handling one wing panel at a time. You'll get the gist of it from the photo. Basically a sturdy "chassis" on casters so you can move it around in the shop. On each end of the chassis are some sort of rollers in which two large circular jigs can roll. The wing assembly is attached to the circular jigs with struts onto the wing mounting points and the whole thing can be turned to any angle needed to work the fabric, paint, ribs, or whatever else. At the conclusion of the project it can be used as a huge rotisserie at the "first flight cookout", and is large enough to hold more grillable things than you can imagine. If you make yours out of wood, you'll need to grill fast and plan for just a single cookout. Metal ones might be good for more grilling sessions. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=449003#449003 Attachments: http://forums.matronics.com//files/wingjig_107.jpg ________________________________________________________________________________
Date: Nov 08, 2015
Jeff (Boatright)- thank you for taking me down a notch. As a result of being on this list I have low and slow aviation friends all over the world and I am much the richer for it. My intention in making the statement that the world does not owe me (or any other experimental aircraft builder) a duty to help in our success does not mean that we shouldn't jump in and help when we can. It certainly does NOT mean that we shouldn't try, either. It just means that sometimes we get individual ideas and visions in our heads and we push forward with them no matter what the world around us says. In those cases, we just have to do what is in our hearts and heads to do, and failure is certainly an option when we buck the trend and the best advice and just push forward anyway. In fact, sometimes our instinct tells us that something probably won't work but we have to try it to see why it doesn't work and to see if we can find out how we might be able to make it work. I know this is how "Aviken" feels with his Jeep engine Air Camper project, and how some of the rest of you feel with your personalized, "different", custom, unusual, or unorthodox approaches to things. I think that the Ethiopian chap did what he did, the way he did it, because he doesn't have a Wicks, or an Aircraft Spruce, or even a Lowe's or Home Depot or Harbor Freight, or an eBay, or Amazon, or Barnstormers, or a credit card available to him. He has a dream and he put it together the best way he knew how, with what he had available, in spite of what he DIDN'T have. We laugh when we watch the video and the prop flies off just after he fires up the engine, but deep inside we didn't want it to just end there. Maybe we would still have laughed if a wheel fell off after he warmed it up and taxied out, or if any number of other awkward things would have happened later- but the video would have gone absolutely viral if his rig would have made it to the runway, and he throttled it up, and he stumbled and bumbled and bumped it down the runway far enough to where it came up onto the mains and got even a foot or two of air under the tires for even just a few seconds before something else happened and it came crashing back to the ground. And granted, with as much questionable stuff as he had on it, there is no doubt that it would have come down sooner rather than later. We would have cheered the fact that he flew it. We would have felt what he felt, because we have felt it too. We would have welcomed him into the fraternity of aviators, because he earned it. And maybe he will. Far be it from me to deprive this man from any part of what he has put his heart and soul to do, and to attempt. I hope he makes it. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=449007#449007 ________________________________________________________________________________
Date: Nov 09, 2015
SGkgT3NjYXIsDQoNCkkgZGlkbuKAmXQgaW50ZW5kIHRvIHRha2UgYW55b25lIGRvd24gYSBub3Rj aCDigJQgZXNwZWNpYWxseSB5b3UhIE9UT0gsIEkgaGF2ZSB0byBzYXkgdGhhdCBJIGFtIGdsYWQg dGhhdCBteSBwb29yIGF0dGVtcHQgYXQgaHVtb3IgcmVzdWx0ZWQgaW4geW91IHBvc3RpbmcgdGhl IHRleHQgYmVsb3cuIEl0IHNheXMgYSBsb3Qgb2YgaG93IEkgYW0gdGhpbmtpbmcgYWJvdXQgdGhp cyBndXkgKGFuZCBvdGhlcnMgSeKAmXZlIG1ldCBpbiB2ZXJ5IHBvb3IgY291bnRyaWVzIHdobyBo YWQgZGlmZmVyZW50IGRyZWFtcyBidXQgbm93IGxlc3MgY2hhbGxlbmdpbmcpLg0KDQpUaGFua3Ms DQoNCkplZmYNCg0KDQpGcm9tOiB0YWlsZHJhZ3MgPHRhaWxkcmFnc0Bob3RtYWlsLmNvbTxtYWls dG86dGFpbGRyYWdzQGhvdG1haWwuY29tPj4NClJlcGx5LVRvOiAicGlldGVucG9sLWxpc3RAbWF0 cm9uaWNzLmNvbTxtYWlsdG86cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbT4iIDxwaWV0ZW5w b2wtbGlzdEBtYXRyb25pY3MuY29tPG1haWx0bzpwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29t Pj4NCkRhdGU6IE1vbmRheSwgTm92ZW1iZXIgOSwgMjAxNSBhdCAxOjAyIEFNDQpUbzogInBpZXRl bnBvbC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5j b20+IiA8cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cGlldGVucG9sLWxpc3RA bWF0cm9uaWNzLmNvbT4+DQpTdWJqZWN0OiBQaWV0ZW5wb2wtTGlzdDogUmU6IEV0aGlvcGlhbiBQ aWV0IHR5cGUgdmlkZW8NCg0KLS0+IFBpZXRlbnBvbC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAi dGFpbGRyYWdzIiA8dGFpbGRyYWdzQGhvdG1haWwuY29tPG1haWx0bzp0YWlsZHJhZ3NAaG90bWFp bC5jb20+Pg0KDQpKZWZmIChCb2F0cmlnaHQpLSB0aGFuayB5b3UgZm9yIHRha2luZyBtZSBkb3du IGEgbm90Y2guICBBcyBhIHJlc3VsdCBvZiBiZWluZyBvbiB0aGlzIGxpc3QgSSBoYXZlIGxvdyBh bmQgc2xvdyBhdmlhdGlvbiBmcmllbmRzIGFsbCBvdmVyIHRoZSB3b3JsZCBhbmQgSSBhbSBtdWNo IHRoZSByaWNoZXIgZm9yIGl0LiAgTXkgaW50ZW50aW9uIGluIG1ha2luZyB0aGUgc3RhdGVtZW50 IHRoYXQgdGhlIHdvcmxkIGRvZXMgbm90IG93ZSBtZSAob3IgYW55IG90aGVyIGV4cGVyaW1lbnRh bCBhaXJjcmFmdCBidWlsZGVyKSBhIGR1dHkgdG8gaGVscCBpbiBvdXIgc3VjY2VzcyBkb2VzIG5v dCBtZWFuIHRoYXQgd2Ugc2hvdWxkbid0IGp1bXAgaW4gYW5kIGhlbHAgd2hlbiB3ZSBjYW4uICBJ dCBjZXJ0YWlubHkgZG9lcyBOT1QgbWVhbiB0aGF0IHdlIHNob3VsZG4ndCB0cnksIGVpdGhlci4g IEl0IGp1c3QgbWVhbnMgdGhhdCBzb21ldGltZXMgd2UgZ2V0IGluZGl2aWR1YWwgaWRlYXMgYW5k IHZpc2lvbnMgaW4gb3VyIGhlYWRzIGFuZCB3ZSBwdXNoIGZvcndhcmQgd2l0aCB0aGVtIG5vIG1h dHRlciB3aGF0IHRoZSB3b3JsZCBhcm91bmQgdXMgc2F5cy4gIEluIHRob3NlIGNhc2VzLCB3ZSBq dXN0IGhhdmUgdG8gZG8gd2hhdCBpcyBpbiBvdXIgaGVhcnRzIGFuZCBoZWFkcyB0byBkbywgYW5k IGZhaWx1cmUgaXMgY2VydGFpbmx5IGFuIG9wdGlvbiB3aGVuIHdlIGJ1Y2sgdGhlIHRyZW5kIGFu ZCB0aGUgYmVzdCBhZHZpY2UgYW5kIGp1c3QgcHVzaCBmb3J3YXJkIGFueXdheS4gIEluIGZhY3Qs IHNvbWV0aW1lcyBvdXIgaW5zdGluY3QgdGVsbHMgdXMgdGhhdCBzb21ldGhpbmcgcHJvYmFibHkg d29uJ3Qgd29yayBidXQgd2UgaGF2ZSB0byB0cnkgaXQgdG8gc2VlIHdoeSBpdCBkb2Vzbid0IHdv cmsgYW5kIHRvIHNlZSBpZiB3ZSBjYW4gZmluZCBvdXQgaG93IHdlIG1pZ2h0IGJlIGFibGUgdG8g bWFrZSBpdCB3b3JrLiAgSSBrbm93IHRoaXMgaXMgaCENCm93ICJBdmlrZW4iIGZlZWxzIHdpdGgg aGlzIEplZXAgZW5naW5lIEFpciBDYW1wZXIgcHJvamVjdCwgYW5kIGhvdyBzb21lIG9mIHRoZSBy ZXN0IG9mIHlvdSBmZWVsIHdpdGggeW91ciBwZXJzb25hbGl6ZWQsICJkaWZmZXJlbnQiLCBjdXN0 b20sIHVudXN1YWwsIG9yIHVub3J0aG9kb3ggYXBwcm9hY2hlcyB0byB0aGluZ3MuDQoNCkkgdGhp bmsgdGhhdCB0aGUgRXRoaW9waWFuIGNoYXAgZGlkIHdoYXQgaGUgZGlkLCB0aGUgd2F5IGhlIGRp ZCBpdCwgYmVjYXVzZSBoZSBkb2Vzbid0IGhhdmUgYSBXaWNrcywgb3IgYW4gQWlyY3JhZnQgU3By dWNlLCBvciBldmVuIGEgTG93ZSdzIG9yIEhvbWUgRGVwb3Qgb3IgSGFyYm9yIEZyZWlnaHQsIG9y IGFuIGVCYXksIG9yIEFtYXpvbiwgb3IgQmFybnN0b3JtZXJzLCBvciBhIGNyZWRpdCBjYXJkIGF2 YWlsYWJsZSB0byBoaW0uICBIZSBoYXMgYSBkcmVhbSBhbmQgaGUgcHV0IGl0IHRvZ2V0aGVyIHRo ZSBiZXN0IHdheSBoZSBrbmV3IGhvdywgd2l0aCB3aGF0IGhlIGhhZCBhdmFpbGFibGUsIGluIHNw aXRlIG9mIHdoYXQgaGUgRElETidUIGhhdmUuICBXZSBsYXVnaCB3aGVuIHdlIHdhdGNoIHRoZSB2 aWRlbyBhbmQgdGhlIHByb3AgZmxpZXMgb2ZmIGp1c3QgYWZ0ZXIgaGUgZmlyZXMgdXAgdGhlIGVu Z2luZSwgYnV0IGRlZXAgaW5zaWRlIHdlIGRpZG4ndCB3YW50IGl0IHRvIGp1c3QgZW5kIHRoZXJl LiAgTWF5YmUgd2Ugd291bGQgc3RpbGwgaGF2ZSBsYXVnaGVkIGlmIGEgd2hlZWwgZmVsbCBvZmYg YWZ0ZXIgaGUgd2FybWVkIGl0IHVwIGFuZCB0YXhpZWQgb3V0LCBvciBpZiBhbnkgbnVtYmVyIG9m IG90aGVyIGF3a3dhcmQgdGhpbmdzIHdvdWxkIGhhdmUgaGFwcGVuZWQgbGF0ZXItIGJ1dCB0aGUg dmlkZW8gd291bGQgaGF2ZSBnb25lIGFic29sdXRlbHkgdmlyYWwgaWYgaGlzIHJpZyB3b3VsZCBo YXZlIG1hZGUgaXQgdG8gdGhlIHJ1bndheSwgYW5kIGhlIHRocm90dGxlZCBpdCB1cCwgYW5kIGhl IHN0dW1ibGVkIGFuZCBidW1ibGVkIGFuZCBidW1wZWQgaXQgZG93biB0aGUgcnVud2F5IGZhciBl bm91Z2ggdG8gd2hlcmUgaXQgY2FtZSB1cCBvbnRvIHRoZSBtYWlucyBhbmQgZ290IGV2ZW4gYSBm b290IG9yIHR3byBvZiBhaXIgdW5kZXIgdGhlIHRpcmVzIGZvciBldmVuIGp1c3QgYSBmZXcgc2Vj b25kcyBiZWZvcmUgc29tIQ0KZXRoaW5nIGVsc2UgaGFwcGVuZWQgYW5kIGl0IGNhbWUgY3Jhc2hp bmcgYmFjayB0byB0aGUgZ3JvdW5kLiAgQW5kIGdyYW50ZWQsIHdpdGggYXMgbXVjaCBxdWVzdGlv bmFibGUgc3R1ZmYgYXMgaGUgaGFkIG9uIGl0LCB0aGVyZSBpcyBubyBkb3VidCB0aGF0IGl0IHdv dWxkIGhhdmUgY29tZSBkb3duIHNvb25lciByYXRoZXIgdGhhbiBsYXRlci4NCg0KV2Ugd291bGQg aGF2ZSBjaGVlcmVkIHRoZSBmYWN0IHRoYXQgaGUgZmxldyBpdC4gIFdlIHdvdWxkIGhhdmUgZmVs dCB3aGF0IGhlIGZlbHQsIGJlY2F1c2Ugd2UgaGF2ZSBmZWx0IGl0IHRvby4gIFdlIHdvdWxkIGhh dmUgd2VsY29tZWQgaGltIGludG8gdGhlIGZyYXRlcm5pdHkgb2YgYXZpYXRvcnMsIGJlY2F1c2Ug aGUgZWFybmVkIGl0LiAgQW5kIG1heWJlIGhlIHdpbGwuDQoNCkZhciBiZSBpdCBmcm9tIG1lIHRv IGRlcHJpdmUgdGhpcyBtYW4gZnJvbSBhbnkgcGFydCBvZiB3aGF0IGhlIGhhcyBwdXQgaGlzIGhl YXJ0IGFuZCBzb3VsIHRvIGRvLCBhbmQgdG8gYXR0ZW1wdC4gIEkgaG9wZSBoZSBtYWtlcyBpdC4N Cg0KLS0tLS0tLS0NCk9zY2FyIFp1bmlnYQ0KTWVkZm9yZCwgT1INCkFpciBDYW1wZXIgTlg0MUND ICZxdW90O1Njb3V0JnF1b3Q7DQpBNzUgcG93ZXINCg0KDQoNCg0KUmVhZCB0aGlzIHRvcGljIG9u bGluZSBoZXJlOg0KDQpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9w PTQ0OTAwNyM0NDkwMDcNCg0KDQoNCg0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPQ0KXy09ICAgICAgIC0tIFBs ZWFzZSBTdXBwb3J0IFlvdXIgTGlzdHMgVGhpcyBNb250aCAtLQ0KXy09ICAgICAgICAgICAoQW5k IEdldCBTb21lIEFXRVNPTUUgRlJFRSBHaWZ0cyEpDQpfLT0NCl8tPSAgIE5vdmVtYmVyIGlzIHRo ZSBBbm51YWwgTGlzdCBGdW5kIFJhaXNlci4gIENsaWNrIG9uDQpfLT0gICB0aGUgQ29udHJpYnV0 aW9uIGxpbmsgYmVsb3cgdG8gZmluZCBvdXQgbW9yZSBhYm91dA0KXy09ICAgdGhpcyB5ZWFyJ3Mg VGVycmlmaWMgRnJlZSBJbmNlbnRpdmUgR2lmdHMgcHJvdmlkZWQNCl8tPSAgIGJ5Og0KXy09DQpf LT0gICAgICogVGhlIEJ1aWxkZXIncyBCb29rc3RvcmUgd3d3LmJ1aWxkZXJzYm9va3MuY29tDQpf LT0NCl8tPSAgIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlOg0KXy09DQpfLT0gICAtLT4gaHR0 cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09DQpfLT0gICBUaGFuayB5b3Ug Zm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPQ0KXy09ICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KXy09DQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAg ICAgIC0gVGhlIFBpZXRlbnBvbC1MaXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2UgdGhlIE1hdHJv bmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCl8tPSB0aGUgbWFueSBMaXN0 IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KXy09IEFyY2hpdmUgU2Vh cmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rvc2hhcmUs IGFuZCBtdWNoIG11Y2ggbW9yZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNz LmNvbS9OYXZpZ2F0b3I/UGlldGVucG9sLUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAg ICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNv IGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vZm9y dW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExpc3QgQ29u dHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1 cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExp c3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlv bg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCg0KDQoNCg0KDQpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KDQpU aGlzIGUtbWFpbCBtZXNzYWdlIChpbmNsdWRpbmcgYW55IGF0dGFjaG1lbnRzKSBpcyBmb3IgdGhl IHNvbGUgdXNlIG9mDQp0aGUgaW50ZW5kZWQgcmVjaXBpZW50KHMpIGFuZCBtYXkgY29udGFpbiBj b25maWRlbnRpYWwgYW5kIHByaXZpbGVnZWQNCmluZm9ybWF0aW9uLiBJZiB0aGUgcmVhZGVyIG9m IHRoaXMgbWVzc2FnZSBpcyBub3QgdGhlIGludGVuZGVkDQpyZWNpcGllbnQsIHlvdSBhcmUgaGVy ZWJ5IG5vdGlmaWVkIHRoYXQgYW55IGRpc3NlbWluYXRpb24sIGRpc3RyaWJ1dGlvbg0Kb3IgY29w eWluZyBvZiB0aGlzIG1lc3NhZ2UgKGluY2x1ZGluZyBhbnkgYXR0YWNobWVudHMpIGlzIHN0cmlj dGx5DQpwcm9oaWJpdGVkLg0KDQpJZiB5b3UgaGF2ZSByZWNlaXZlZCB0aGlzIG1lc3NhZ2UgaW4g ZXJyb3IsIHBsZWFzZSBjb250YWN0DQp0aGUgc2VuZGVyIGJ5IHJlcGx5IGUtbWFpbCBtZXNzYWdl IGFuZCBkZXN0cm95IGFsbCBjb3BpZXMgb2YgdGhlDQpvcmlnaW5hbCBtZXNzYWdlIChpbmNsdWRp bmcgYXR0YWNobWVudHMpLg0K ________________________________________________________________________________
Date: Nov 09, 2015
IMHO very well said Oscar. Semih=8B 2015-11-09 8:57 GMT+02:00 Boatright, Jeffrey : > Hi Oscar, > > I didn=99t intend to take anyone down a notch =94 especially you! OTOH, I have > to say that I *am* glad that my poor attempt at humor resulted in you > posting the text below. It says a lot of how I am thinking about this guy > (and others I=99ve met in very poor countries who had different dre ams but > now less challenging). > > Thanks, > > Jeff > > > From: taildrags <taildrags(at)hotmail.com> > Reply-To: "pietenpol-list(at)matronics.com" > Date: Monday, November 9, 2015 at 1:02 AM > To: "pietenpol-list(at)matronics.com" > Subject: Pietenpol-List: Re: Ethiopian Piet type video > > > Jeff (Boatright)- thank you for taking me down a notch. As a result of > being on this list I have low and slow aviation friends all over the worl d > and I am much the richer for it. My intention in making the statement th at > the world does not owe me (or any other experimental aircraft builder) a > duty to help in our success does not mean that we shouldn't jump in and > help when we can. It certainly does NOT mean that we shouldn't try, > either. It just means that sometimes we get individual ideas and visions > in our heads and we push forward with them no matter what the world aroun d > us says. In those cases, we just have to do what is in our hearts and > heads to do, and failure is certainly an option when we buck the trend an d > the best advice and just push forward anyway. In fact, sometimes our > instinct tells us that something probably won't work but we have to try i t > to see why it doesn't work and to see if we can find out how we might be > able to make it work. I know this is h! > ow "Aviken" feels with his Jeep engine Air Camper project, and how some o f > the rest of you feel with your personalized, "different", custom, unusual , > or unorthodox approaches to things. > > I think that the Ethiopian chap did what he did, the way he did it, > because he doesn't have a Wicks, or an Aircraft Spruce, or even a Lowe's or > Home Depot or Harbor Freight, or an eBay, or Amazon, or Barnstormers, or a > credit card available to him. He has a dream and he put it together the > best way he knew how, with what he had available, in spite of what he > DIDN'T have. We laugh when we watch the video and the prop flies off jus t > after he fires up the engine, but deep inside we didn't want it to just e nd > there. Maybe we would still have laughed if a wheel fell off after he > warmed it up and taxied out, or if any number of other awkward things wou ld > have happened later- but the video would have gone absolutely viral if hi s > rig would have made it to the runway, and he throttled it up, and he > stumbled and bumbled and bumped it down the runway far enough to where it > came up onto the mains and got even a foot or two of air under the tires > for even just a few seconds before som! > ething else happened and it came crashing back to the ground. And > granted, with as much questionable stuff as he had on it, there is no dou bt > that it would have come down sooner rather than later. > > We would have cheered the fact that he flew it. We would have felt what > he felt, because we have felt it too. We would have welcomed him into th e > fraternity of aviators, because he earned it. And maybe he will. > > Far be it from me to deprive this man from any part of what he has put hi s > heart and soul to do, and to attempt. I hope he makes it. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=449007#449007 > > =========== =========== =========== =========== =========== > > > ------------------------------ > > This e-mail message (including any attachments) is for the sole use of > the intended recipient(s) and may contain confidential and privileged > information. If the reader of this message is not the intended > recipient, you are hereby notified that any dissemination, distribution > or copying of this message (including any attachments) is strictly > prohibited. > > If you have received this message in error, please contact > the sender by reply e-mail message and destroy all copies of the > original message (including attachments). > -- Semih Oksay ________________________________________________________________________________
Date: Nov 09, 2015
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 09, 2015
Oscar and Jeff, I have made email contact with Asmelash Zeferu in Africa, thanks to Ryan' s sleuthing! I sent you a copy of my email to him giving him directions to join the PIETENPOL Forum. I hope that if he joins the Forum, our members will be helpful and recognize the great effort he has gone through under very trying circumstances. I have lived in similar countries with like resources, so I recognize his determination! We should be able to offer helpful encouragement. He says he has calculated the W/B. Thanks, Ray Krause Sent from my iPad > On Nov 8, 2015, at 10:02 PM, taildrags wrote: > > > Jeff (Boatright)- thank you for taking me down a notch. As a result of being on this list I have low and slow aviation friends all over the world and I am much the richer for it. My intention in making the statement that the world does not owe me (or any other experimental aircraft builder) a duty to help in our success does not mean that we shouldn't jump in and help when we can. It certainly does NOT mean that we shouldn't try, either. It just means that sometimes we get individual ideas and visions in our heads and we push forward with them no matter what the world around us says. In those cases, we just have to do what is in our hearts and heads to do, and failure is certainly an option when we buck the trend and the best advice and just push forward anyway. In fact, sometimes our instinct tells us that something probably won't work but we have to try it to see why it doesn't work and to see if we can find out how we might be able to make it work. I know this is h! > ow "Aviken" feels with his Jeep engine Air Camper project, and how some of the rest of you feel with your personalized, "different", custom, unusual, or unorthodox approaches to things. > > I think that the Ethiopian chap did what he did, the way he did it, because he doesn't have a Wicks, or an Aircraft Spruce, or even a Lowe's or Home Depot or Harbor Freight, or an eBay, or Amazon, or Barnstormers, or a credit card available to him. He has a dream and he put it together the best way he knew how, with what he had available, in spite of what he DIDN'T have. We laugh when we watch the video and the prop flies off just after he fires up the engine, but deep inside we didn't want it to just end there. Maybe we would still have laughed if a wheel fell off after he warmed it up and taxied out, or if any number of other awkward things would have happened later- but the video would have gone absolutely viral if his rig would have made it to the runway, and he throttled it up, and he stumbled and bumbled and bumped it down the runway far enough to where it came up onto the mains and got even a foot or two of air under the tires for even just a few seconds before som! > ething else happened and it came crashing back to the ground. And granted, with as much questionable stuff as he had on it, there is no doubt that it would have come down sooner rather than later. > > We would have cheered the fact that he flew it. We would have felt what he felt, because we have felt it too. We would have welcomed him into the fraternity of aviators, because he earned it. And maybe he will. > > Far be it from me to deprive this man from any part of what he has put his heart and soul to do, and to attempt. I hope he makes it. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=449007#449007 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 09, 2015
Ok. I think I have a few words to say: =8BI am building my Piet in a country which is slightly better than Ethiopia in aircraft materials. This is based on my lifetime experience: If someone asks for help, do it. If not, forget it. Question: does Asmelash Zeferu speak (or at least understand) English? If he seeks help, I am sure he can reach it. You guys (Ray) say he has an e-mail, this means he has access to internet. Since I am closer to Africa compared to you guys, I think I know them better. There is no difference in between the people of this planet. There are good, curious and productive guys and there are others. So IMHO if we can communicate with him and he is opn to advice, we should do what we can. Please forgive the philosophy Regards Semih 2015-11-09 20:06 GMT+02:00 Ray Krause : > raykrause(at)frontiernet.net> > > Oscar and Jeff, > > I have made email contact with Asmelash Zeferu in Africa, thanks to Ryan' > s sleuthing! I sent you a copy of my email to him giving him directions t o > join the PIETENPOL Forum. I hope that if he joins the Forum, our members > will be helpful and recognize the great effort he has gone through under > very trying circumstances. I have lived in similar countries with like > resources, so I recognize his determination! We should be able to offer > helpful encouragement. > > He says he has calculated the W/B. > > Thanks, > > Ray Krause > > Sent from my iPad > > > On Nov 8, 2015, at 10:02 PM, taildrags wrote: > > m > > > > > > Jeff (Boatright)- thank you for taking me down a notch. As a result of > being on this list I have low and slow aviation friends all over the worl d > and I am much the richer for it. My intention in making the statement th at > the world does not owe me (or any other experimental aircraft builder) a > duty to help in our success does not mean that we shouldn't jump in and > help when we can. It certainly does NOT mean that we shouldn't try, > either. It just means that sometimes we get individual ideas and visions > in our heads and we push forward with them no matter what the world aroun d > us says. In those cases, we just have to do what is in our hearts and > heads to do, and failure is certainly an option when we buck the trend an d > the best advice and just push forward anyway. In fact, sometimes our > instinct tells us that something probably won't work but we have to try i t > to see why it doesn't work and to see if we can find out how we might be > able to make it work. I know this is! > h! > > ow "Aviken" feels with his Jeep engine Air Camper project, and how some > of the rest of you feel with your personalized, "different", custom, > unusual, or unorthodox approaches to things. > > > > I think that the Ethiopian chap did what he did, the way he did it, > because he doesn't have a Wicks, or an Aircraft Spruce, or even a Lowe's or > Home Depot or Harbor Freight, or an eBay, or Amazon, or Barnstormers, or a > credit card available to him. He has a dream and he put it together the > best way he knew how, with what he had available, in spite of what he > DIDN'T have. We laugh when we watch the video and the prop flies off jus t > after he fires up the engine, but deep inside we didn't want it to just e nd > there. Maybe we would still have laughed if a wheel fell off after he > warmed it up and taxied out, or if any number of other awkward things wou ld > have happened later- but the video would have gone absolutely viral if hi s > rig would have made it to the runway, and he throttled it up, and he > stumbled and bumbled and bumped it down the runway far enough to where it > came up onto the mains and got even a foot or two of air under the tires > for even just a few seconds before s! > om! > > ething else happened and it came crashing back to the ground. And > granted, with as much questionable stuff as he had on it, there is no dou bt > that it would have come down sooner rather than later. > > > > We would have cheered the fact that he flew it. We would have felt wha t > he felt, because we have felt it too. We would have welcomed him into th e > fraternity of aviators, because he earned it. And maybe he will. > > > > Far be it from me to deprive this man from any part of what he has put > his heart and soul to do, and to attempt. I hope he makes it. > > > > -------- > > Oscar Zuniga > > Medford, OR > > Air Camper NX41CC "Scout" > > A75 power > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=449007#449007 > > > > > > > > > > > > > > > > > > > > > > =========== =========== =========== =========== =========== > > -- Semih Oksay ________________________________________________________________________________
Date: Nov 09, 2015
Ray in response to your note to Asmelash I signed him up for the Pietenpol page and sent him a note with that info and the EAA site. Sent from my iPad Jack Textor > On Nov 9, 2015, at 12:06 PM, Ray Krause wrote: > > > Oscar and Jeff, > > I have made email contact with Asmelash Zeferu in Africa, thanks to Ryan' s sleuthing! I sent you a copy of my email to him giving him directions to join the PIETENPOL Forum. I hope that if he joins the Forum, our members will be helpful and recognize the great effort he has gone through under very trying circumstances. I have lived in similar countries with like resources, so I recognize his determination! We should be able to offer helpful encouragement. > > He says he has calculated the W/B. > > Thanks, > > Ray Krause > > Sent from my iPad > >> On Nov 8, 2015, at 10:02 PM, taildrags wrote: >> >> >> Jeff (Boatright)- thank you for taking me down a notch. As a result of being on this list I have low and slow aviation friends all over the world and I am much the richer for it. My intention in making the statement that the world does not owe me (or any other experimental aircraft builder) a duty to help in our success does not mean that we shouldn't jump in and help when we can. It certainly does NOT mean that we shouldn't try, either. It just means that sometimes we get individual ideas and visions in our heads and we push forward with them no matter what the world around us says. In those cases, we just have to do what is in our hearts and heads to do, and failure is certainly an option when we buck the trend and the best advice and just push forward anyway. In fact, sometimes our instinct tells us that something probably won't work but we have to try it to see why it doesn't work and to see if we can find out how we might be able to make it work. I know this is! > h! >> ow "Aviken" feels with his Jeep engine Air Camper project, and how some of the rest of you feel with your personalized, "different", custom, unusual, or unorthodox approaches to things. >> >> I think that the Ethiopian chap did what he did, the way he did it, because he doesn't have a Wicks, or an Aircraft Spruce, or even a Lowe's or Home Depot or Harbor Freight, or an eBay, or Amazon, or Barnstormers, or a credit card available to him. He has a dream and he put it together the best way he knew how, with what he had available, in spite of what he DIDN'T have. We laugh when we watch the video and the prop flies off just after he fires up the engine, but deep inside we didn't want it to just end there. Maybe we would still have laughed if a wheel fell off after he warmed it up and taxied out, or if any number of other awkward things would have happened later- but the video would have gone absolutely viral if his rig would have made it to the runway, and he throttled it up, and he stumbled and bumbled and bumped it down the runway far enough to where it came up onto the mains and got even a foot or two of air under the tires for even just a few seconds before s! > om! >> ething else happened and it came crashing back to the ground. And granted, with as much questionable stuff as he had on it, there is no doubt that it would have come down sooner rather than later. >> >> We would have cheered the fact that he flew it. We would have felt what he felt, because we have felt it too. We would have welcomed him into the fraternity of aviators, because he earned it. And maybe he will. >> >> Far be it from me to deprive this man from any part of what he has put his heart and soul to do, and to attempt. I hope he makes it. >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=449007#449007 > > > > > ________________________________________________________________________________
Date: Nov 09, 2015
Seminar, Asmelash writes in perfect English and has internet access. I'm sure he will be on the Forum right away. I will ask him if it is OK to share his email a ddress. Thanks, Ray Krause Sent from my iPad > On Nov 9, 2015, at 11:14 AM, Semih Oksay wrote: > > Ok. I think I have a few words to say: =8BI am building my Piet in a country which is slightly better than Ethiopia in aircraft materials. > This is based on my lifetime experience: If someone asks for help, do it. I f not, forget it. > Question: does Asmelash Zeferu speak (or at least understand) English? > If he seeks help, I am sure he can reach it. You guys (Ray) say he has an e -mail, this means he has access to internet. Since I am closer to Africa com pared to you guys, I think I know them better. There is no difference in bet ween the people of this planet. There are good, curious and productive guys a nd there are others. So IMHO if we can communicate with him and he is opn to advice, we should do what we can. > > Please forgive the philosophy > > Regards > > Semih > > 2015-11-09 20:06 GMT+02:00 Ray Krause : et> >> >> Oscar and Jeff, >> >> I have made email contact with Asmelash Zeferu in Africa, thanks to Ryan' s sleuthing! I sent you a copy of my email to him giving him directions to j oin the PIETENPOL Forum. I hope that if he joins the Forum, our members will be helpful and recognize the great effort he has gone through under very tr ying circumstances. I have lived in similar countries with like resources, s o I recognize his determination! We should be able to offer helpful encourag ement. >> >> He says he has calculated the W/B. >> >> Thanks, >> >> Ray Krause >> >> Sent from my iPad >> >> > On Nov 8, 2015, at 10:02 PM, taildrags wrote: >> > m> >> > >> > Jeff (Boatright)- thank you for taking me down a notch. As a result of being on this list I have low and slow aviation friends all over the world a nd I am much the richer for it. My intention in making the statement that t he world does not owe me (or any other experimental aircraft builder) a duty to help in our success does not mean that we shouldn't jump in and help whe n we can. It certainly does NOT mean that we shouldn't try, either. It jus t means that sometimes we get individual ideas and visions in our heads and w e push forward with them no matter what the world around us says. In those c ases, we just have to do what is in our hearts and heads to do, and failure i s certainly an option when we buck the trend and the best advice and just pu sh forward anyway. In fact, sometimes our instinct tells us that something p robably won't work but we have to try it to see why it doesn't work and to s ee if we can find out how we might be able to make it work. I know this is! >> h! >> > ow "Aviken" feels with his Jeep engine Air Camper project, and how some of the rest of you feel with your personalized, "different", custom, unusua l, or unorthodox approaches to things. >> > >> > I think that the Ethiopian chap did what he did, the way he did it, bec ause he doesn't have a Wicks, or an Aircraft Spruce, or even a Lowe's or Hom e Depot or Harbor Freight, or an eBay, or Amazon, or Barnstormers, or a cred it card available to him. He has a dream and he put it together the best wa y he knew how, with what he had available, in spite of what he DIDN'T have. We laugh when we watch the video and the prop flies off just after he fires up the engine, but deep inside we didn't want it to just end there. Maybe w e would still have laughed if a wheel fell off after he warmed it up and tax ied out, or if any number of other awkward things would have happened later- but the video would have gone absolutely viral if his rig would have made i t to the runway, and he throttled it up, and he stumbled and bumbled and bum ped it down the runway far enough to where it came up onto the mains and got even a foot or two of air under the tires for even just a few seconds befor e s! >> om! >> > ething else happened and it came crashing back to the ground. And gran ted, with as much questionable stuff as he had on it, there is no doubt that it would have come down sooner rather than later. >> > >> > We would have cheered the fact that he flew it. We would have felt wha t he felt, because we have felt it too. We would have welcomed him into the fraternity of aviators, because he earned it. And maybe he will. >> > >> > Far be it from me to deprive this man from any part of what he has put h is heart and soul to do, and to attempt. I hope he makes it. >> > >> > -------- >> > Oscar Zuniga >> > Medford, OR >> > Air Camper NX41CC "Scout" >> > A75 power >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=449007#449007 >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> >> >> ========== >> br> fts!) >> r> > w.buildersbooks.com" target="_blank" rel="noreferrer">www.builde rsbooks.com >> target="_blank" rel="noreferrer">http://www.matronics.com/contributio n >> -Matt Dralle, List Admin. >> ========== >> br> enpol-List" target="_blank" rel="noreferrer">http://www.matronics .com/Navigator?Pietenpol-List >> ========== >> FORUMS - >> _blank" rel="noreferrer">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank" rel="noreferrer">http://www.matronics.com/contributio n >> ========== > > > > -- > Semih Oksay ________________________________________________________________________________
Subject: Re: Ethiopian Piet type video
Date: Nov 09, 2015
Jack, He sounds very pleased to be making contact with us. I hope we can sincerely help him in his quest. On his face page he has a lot of pictures of his build. It all looks quite familiar! Ray Sent from my iPad > On Nov 9, 2015, at 11:36 AM, Jack wrote: > > > Ray in response to your note to Asmelash I signed him up for the Pietenpol page and sent him a note with that info and the EAA site. > > Sent from my iPad > Jack Textor > >> On Nov 9, 2015, at 12:06 PM, Ray Krause wrote: >> >> >> Oscar and Jeff, >> >> I have made email contact with Asmelash Zeferu in Africa, thanks to Ryan' s sleuthing! I sent you a copy of my email to him giving him directions to join the PIETENPOL Forum. I hope that if he joins the Forum, our members will be helpful and recognize the great effort he has gone through under very trying circumstances. I have lived in similar countries with like resources, so I recognize his determination! We should be able to offer helpful encouragement. >> >> He says he has calculated the W/B. >> >> Thanks, >> >> Ray Krause >> >> Sent from my iPad >> >>> On Nov 8, 2015, at 10:02 PM, taildrags wrote: >>> >>> >>> Jeff (Boatright)- thank you for taking me down a notch. As a result of being on this list I have low and slow aviation friends all over the world and I am much the richer for it. My intention in making the statement that the world does not owe me (or any other experimental aircraft builder) a duty to help in our success does not mean that we shouldn't jump in and help when we can. It certainly does NOT mean that we shouldn't try, either. It just means that sometimes we get individual ideas and visions in our heads and we push forward with them no matter what the world around us says. In those cases, we just have to do what is in our hearts and heads to do, and failure is certainly an option when we buck the trend and the best advice and just push forward anyway. In fact, sometimes our instinct tells us that something probably won't work but we have to try it to see why it doesn't work and to see if we can find out how we might be able to make it work. I know this i! > s! >> h! >>> ow "Aviken" feels with his Jeep engine Air Camper project, and how some of the rest of you feel with your personalized, "different", custom, unusual, or unorthodox approaches to things. >>> >>> I think that the Ethiopian chap did what he did, the way he did it, because he doesn't have a Wicks, or an Aircraft Spruce, or even a Lowe's or Home Depot or Harbor Freight, or an eBay, or Amazon, or Barnstormers, or a credit card available to him. He has a dream and he put it together the best way he knew how, with what he had available, in spite of what he DIDN'T have. We laugh when we watch the video and the prop flies off just after he fires up the engine, but deep inside we didn't want it to just end there. Maybe we would still have laughed if a wheel fell off after he warmed it up and taxied out, or if any number of other awkward things would have happened later- but the video would have gone absolutely viral if his rig would have made it to the runway, and he throttled it up, and he stumbled and bumbled and bumped it down the runway far enough to where it came up onto the mains and got even a foot or two of air under the tires for even just a few seconds before ! > s! >> om! >>> ething else happened and it came crashing back to the ground. And granted, with as much questionable stuff as he had on it, there is no doubt that it would have come down sooner rather than later. >>> >>> We would have cheered the fact that he flew it. We would have felt what he felt, because we have felt it too. We would have welcomed him into the fraternity of aviators, because he earned it. And maybe he will. >>> >>> Far be it from me to deprive this man from any part of what he has put his heart and soul to do, and to attempt. I hope he makes it. >>> >>> -------- >>> Oscar Zuniga >>> Medford, OR >>> Air Camper NX41CC "Scout" >>> A75 power >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=449007#449007 > > > > > ________________________________________________________________________________
Subject: Re: Wavy Okoume Plywood Leading Edge
Date: Nov 09, 2015
Don't the plans show 28 ga aluminum, which would eliminate any of the seasonal expansion? -------- Jon Jones Ironton, MO Read this topic online here: http://forums.matronics.com/viewtopic.php?p=449124#449124 ________________________________________________________________________________
Date: Nov 10, 2015
Jon, No, the plans do not show 28ga aluminum. They call for the use of 6-ply hard cardboard or 1/16" plywood. Don't think anybody has used the cardboard option for many years, though. Some have used aluminum, but there are issues to contend with if you choose to go that route. One issue is figuring out how to attach the aluminum to the wooden ribs. Glue will not work (in the long run), and nails will eventually work their way out. Another issue is that aluminum and wood will expand and contract at different rates, as the temperature rises and falls. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=449127#449127 ________________________________________________________________________________
Date: Nov 10, 2015
Bill, I agree with you on all the reasons not to use aluminum, but I wonder what the reference to aluminum is on the wing drawing in the flying and glider manual? Personally, I will probably just use the best quality ply I can find, apply it in the middle or upper humidity range I expect it to live in on average (so if any change occurs it will err towards tightening) and then seal it asap. -------- Jon Jones Ironton, MO Read this topic online here: http://forums.matronics.com/viewtopic.php?p=449128#449128 ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Nov 10, 2015
Ray, Thanks for contacting him. I do not have facebook. It is great that he is offered this site as another resource to him. We need to also let him know about www.westcoastpiet.com as well. As others have said, if he reaches out to us, we should do everything we can to help him with his quest. Asmelash has great ambition and a great drive. He has proven that to me. When I look at the Youtube video, I can't help but wonder which of all those young faces in that group he is influencing????? I wonder who influenced him? I wonder if a plane from this group is what gave him inspiration? Maybe he had seen Mike Cuy's, Gary Boothe's, Tools, or even my plane? Hard to say. But we all are the guys and gals who are keeping Bernie Pietenpol's dream alive. It looks like it may be his turn in Africa to keep the dream alive. I hope to see him on this forum asking questions. Cheers all, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=449129#449129 ________________________________________________________________________________
Date: Nov 10, 2015
Scot and Ray I mentioned WestCoast Piet to him also... Sent from my iPad Jack Textor > On Nov 10, 2015, at 11:51 AM, "AircamperN11MS" wrote: > > > Ray, > > Thanks for contacting him. I do not have facebook. It is great that he is offered this site as another resource to him. We need to also let him know about www.westcoastpiet.com as well. > > As others have said, if he reaches out to us, we should do everything we can to help him with his quest. > > Asmelash has great ambition and a great drive. He has proven that to me. When I look at the Youtube video, I can't help but wonder which of all those young faces in that group he is influencing????? I wonder who influenced him? I wonder if a plane from this group is what gave him inspiration? Maybe he had seen Mike Cuy's, Gary Boothe's, Tools, or even my plane? Hard to say. But we all are the guys and gals who are keeping Bernie Pietenpol's dream alive. It looks like it may be his turn in Africa to keep the dream alive. > > I hope to see him on this forum asking questions. > > Cheers all, > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=449129#449129 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 10, 2015
Hmmm... I never noticed that before. The Flying and Glider plans actually do say to use 28ga aluminum on the leading edge of the wing. I have no idea how anyone manages to actually build an airplane using only the plans in the Flying and Glider reprints. Those drawings are so small. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=449131#449131 ________________________________________________________________________________
Date: Nov 10, 2015
Hmmm... I never noticed that before. The Flying and Glider plans actually do say to use 28ga aluminum on the leading edge of the wing. I have no idea how anyone manages to actually build an airplane using only the plans in the Flying and Glider reprints. Those drawings are so small. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=449132#449132 ________________________________________________________________________________
Subject: Rudder Post
Date: Nov 11, 2015
Hi Piet friends, I'm redoing my rudder post as per Jack Phillips. As I looked at my existing post it's not fabricated per the Flying and Glider Manual. My existing one is done with 1" at the top and bottom tabs. I can't find a matching layout in my plans. Can anyone point me to a layout? Thanks! Jack Sent from my iPad Jack Textor ________________________________________________________________________________
Date: Nov 11, 2015
Subject: Re: Rudder Post
I do not have that drawing in my plans!!!! I bought my plans in March of this year!! Tony Crawford On Nov 11, 2015 11:43 AM, "Jack" wrote: > Hi Piet friends, > I'm redoing my rudder post as per Jack Phillips. As I looked at my > existing post it's not fabricated per the Flying and Glider Manual. My > existing one is done with 1" at the top and bottom tabs. I can't find a > matching layout in my plans. Can anyone point me to a layout? > Thanks! > Jack > > > Sent from my iPad > Jack Textor > ________________________________________________________________________________
Date: Nov 11, 2015
I'm set on build up that post this weekend. On Nov 11, 2015 12:01 PM, "Tony Crawford" wrote: > I do not have that drawing in my plans!!!! I bought my plans in March of > this year!! > > Tony Crawford > On Nov 11, 2015 11:43 AM, "Jack" wrote: > >> Hi Piet friends, >> I'm redoing my rudder post as per Jack Phillips. As I looked at my >> existing post it's not fabricated per the Flying and Glider Manual. My >> existing one is done with 1" at the top and bottom tabs. I can't find a >> matching layout in my plans. Can anyone point me to a layout? >> Thanks! >> Jack >> >> >> >> >> >> Sent from my iPad >> Jack Textor >> > ________________________________________________________________________________
Date: Nov 11, 2015
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that ilk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 11, 2015
Tony here is what I found on drawing 4. I'm more perplexed because my exist ing post is 5 1/2" between the floor bolts. Not sure where I came up with t hat years ago... Jack Sent from my iPad Jack Textor ________________________________________________________________________________
Date: Nov 11, 2015
Hi, Do you live anywhere near northern Alabama? Tony On Wed, Nov 11, 2015 at 1:26 PM, Jack wrote: > Tony here is what I found on drawing 4. I'm more perplexed because my > existing post is 5 1/2" between the floor bolts. Not sure where I came up > with that years ago... > Jack > > > Sent from my iPad > Jack Textor > ________________________________________________________________________________
Date: Nov 11, 2015
In Des Moines IA Sent from my iPhone > On Nov 11, 2015, at 2:46 PM, Tony Crawford wrote: > > Hi, > Do you live anywhere near northern Alabama? > > Tony > >> On Wed, Nov 11, 2015 at 1:26 PM, Jack wrote: >> Tony here is what I found on drawing 4. I'm more perplexed because my ex isting post is 5 1/2" between the floor bolts. Not sure where I came up wit h that years ago... >> Jack >> >> >> >> >> >> Sent from my iPad >> Jack Textor > ________________________________________________________________________________
Date: Nov 11, 2015
Bill; yet another drawback of aluminum for leading edges is that when you bump the hangar door or anything else with it, you have a dent. You can sometimes pop them back out if you can get to the backside to push them out, but they are never smooth again. I've seen a case were a builder wanted to go the ultra-cheap route and used the dead-soft aluminum that you buy in a roll at the hardware store and can cut with scissors. That stuff is absolutely unforgiving when it comes to dents. You can use good aircraft sheet aluminum and it's more resistant to dents, but it needs to be a bit heavier and stiffer and that makes it more difficult to form and install the leading edges. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=449218#449218 ________________________________________________________________________________
Date: Nov 11, 2015
Those are tough questions, Jack. :) I wouldn't be too worried about the tabs being 1" instead of 1 1/4". Since the 1934 plans don't even provide a dimension, most builders probably just eyeball it - which probably is what you did. It looks like about an inch, relatively speaking. Funny how both the FGM plans and the 1934 plans both provide incomplete information for this component - but they are incomplete in different ways. Not sure why your mounting bolts are spaced at 5 1/2" instead of 6 1/2". One possible scenario is that you may have done the calculations, laid out the part, cut it, drilled it, and bent it, and when you were finished, in order to maintain the required height, that's just the way it worked. If you were to open up the bends to maintain 6 1/2", the height would probably be too short. And, since you most likely already have the floor drilled, there's no point in trying to change it now. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=449227#449227 ________________________________________________________________________________
Date: Nov 12, 2015
Bill you nailed it! Fabricated another yesterday and naturally it's not quite right! Will get it right eventually! Sent from my iPad Jack Textor > On Nov 11, 2015, at 8:39 PM, "Bill Church" wrote: > > > Those are tough questions, Jack. :) > > I wouldn't be too worried about the tabs being 1" instead of 1 1/4". Since the 1934 plans don't even provide a dimension, most builders probably just eyeball it - which probably is what you did. It looks like about an inch, relatively speaking. Funny how both the FGM plans and the 1934 plans both provide incomplete information for this component - but they are incomplete in different ways. > Not sure why your mounting bolts are spaced at 5 1/2" instead of 6 1/2". One possible scenario is that you may have done the calculations, laid out the part, cut it, drilled it, and bent it, and when you were finished, in order to maintain the required height, that's just the way it worked. If you were to open up the bends to maintain 6 1/2", the height would probably be too short. And, since you most likely already have the floor drilled, there's no point in trying to change it now. > > Bill C. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=449227#449227 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 12, 2015
Tonyp51, the drawing is not on the plans because it is from the 1932-33 Flying Manual, Page 27. The plans are not the same as the magazine but they are close. If you look to the left at the control stick, you can see the aileron cables come off at the same place as the elevator cables, not from a horn like the plans. Scott Read this topic online here: http://forums.matronics.com/viewtopic.php?p=449236#449236 ________________________________________________________________________________
Date: Nov 13, 2015
Subject: Make Sure You're Listed! List of Contributors Published
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 13, 2015
Subject: Arizona Piet
Hi, I'm new to the Pietenpol list and would like to see a project or flying Piet. I was at the Copper State fly-in on Saturday this year and didn't see any Piets there. I live in Mesa AZ and go to Payson AZ quite often. Thank you. Don Koehnlein -------------------------------------------- On Thu, 11/12/15, Pietenpol-List Digest Server wrote: Subject: Pietenpol-List Digest: 9 Msgs - 11/11/15 To: "Pietenpol-List Digest List" Date: Thursday, November 12, 2015, 1:03 AM * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Pietenpol-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Pietenpol-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-11-11&Archive=Pietenpol Text Version:
October 31, 2015 - November 14, 2015
Pietenpol-Archive.digest.vol-pc
