Pietenpol-Archive.digest.vol-pk
August 01, 2016 - September 20, 2016
      ________________________________  Message 2  ______________________________
      _______
Subject: Re: OSH
If I remember correctly, Jill bought a set of brass data plates from me a w hile back. I'll have to ask her if she has them installed on her Piet. I was also pleased and happy to read Bob Coolbaugh's writeup in the newest BPA Newsletter, where he recounts his hopping around the country in his beautif ul "New Piet", Two-Two-Victor Yankee. I sold Bob a set of tail surface hinges a while back, so I may email him to see how they are working out. Sounds lik e he's putting plenty of time on them! -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458973#458973 ________________________________ Message 3 ______________________________ _______
Subject: no radio, no fly
From: "taildrags" <taildrags(at)hotmail.com> Well, I tried. After months of not flying, I decided today would be the da y no matter what. I was wrong. The @#$%& battery pack and contacts on my ancie nt little Icom IC-A23 just couldn't make good enough contact for the radio to work and I'm based on a tower-controlled field. I did the next best thing I cou ld though, which was to clean the windscreens, give the airplane a complete pr eflight, top off the oil, and fire it up. Started pretty easily. I taxied out to the pump and put 9.0 in the tank to top it off, then had a bit of a time getting it started again because I flooded it. I've learned to w atch out when it's hot or it will flood. Got it started, taxied back to the han gar, and let the engine get good and warm. Ran it up for about 10 minutes, up and down in irregular stages through the RPM from idle to full static power , tested carb heat and mags (everything good), and finally shut it down after gettin g the oil nice and warm. At least now the airplane is ready to pull out of the hangar and fly whenever I can get the radio back in service. I should probably just buy a better/newer COM or maybe go ahead and mount a battery in the airplane to provide power to the Icom through the external power jack inste ad of using the AA cell piggyback pack. There are 8 dry cells in series in th e pack, so that's a lot of contacts for the current to flow through and a lot of contacts that have to be sparkling clean to get best power out of it. Radi os and wires take a lot of the fun out of simple airplanes like this. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458992#458992 ________________________________ Message 4 ______________________________ _______ Subject: Pietenpol-List: Re: no radio, no fly From: "aerocarjake" <flight.jake(at)gmail.com> Nice.... Sooner or later someone will power a Pietenpol with ELECTRICS and they'll be in real tough shape if their batteries die!!!!! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=458998#458998 ________________________________ Message 5 ______________________________ _______ Subject: Pietenpol-List: Re: no radio, no fly From: "taildrags" <taildrags(at)hotmail.com> Actually, I've got everything figured out and was going to install it years ago but my interest faded. I have a fairly small and light UPS battery that I was going to wire to a simple 3-way cigarette lighter jack that I got at one of the auto supply places so I could plug in the portable intercom, GPS, or an ything else I wanted to keep from hard-wiring. I have a windshield washer pump fo r the smoke system and was going to permanently install that unit and hard-wi re it through a fuse and a spring-loaded toggle switch on the panel so I could reach it with a finger on my throttle hand when I want smoke. The battery will be constant loss since my airplane has no electrics, and I would keep it on a trickle charge while in the hangar. I have the charger for it already. What I don't have is the interest in adding "stuff" to my airplan e, although I may just bungee the UPS battery into the front seat and wire a 1 2VDC power plug into it to power up the handheld to see how that's going to work . It should do the trick, although as I say, I'm overdue for a proper handhel d and should look for one and be done with it. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459003#459003 ________________________________________________________________________________
Subject: Re: Where I'm at
From: Scott Knowlton <flyingscott_k(at)hotmail.com>
Date: Aug 01, 2016
SW4gcmVzcG9uc2UgdG8geW91ciBlbmdpbmUgcGFpbnQgY29sb3VyLCBteSBmYXRoZXIgd2FzIGEg YmlnIEZvcmQgQSBob2JieSBndXkgYW5kIGFjdHVhbGx5IHdhcyB0aGUgdGhlIHByZXNpZGVudCBv ZiB0aGUgRm9yZCBNb2RlbCBBIENsdWIgb2YgT3R0YXdhIE9udGFyaW8gQ2FuYWRhIGZvciBhIGZl dyB5ZWFycy4gSGUgcmVidWlsZCBhIENhbmFkaWFuIGVuZ2luZSBhbmQgSSBhc2tlZCBoaW0geW91 ciBxdWVzdGlvbi4gIEhpcyByZXBseToNCg0KbWluZSB3YXMgQ2FuYWRpYW4gYnVpbHQgZW5naW5l IGhhZCBhIENBIG51bWJlci4gUGFpbnQgaXMgZm9yZCBwYXJ0ICMyOC01MjM3Mi0xIGFuZCBvbmUg Z2FsbG9uIGlzICQyOS45NSBVUyBhbmQgYXZhaWxhYmxlIGZyb20gTWFjJ3MuIEkgd2lsbCB0cnkg dG8gYXR0YWNoIHRoZSBjYXRhbG9ndWUgZGF0YS4gR29vZCBMdWNrIERhZA0KDQpJZiBpdCBpcyBm cm9tIG15IGRhZCwgaXQgaXMgYSBmYWN0ISAgDQoNCkJlc3Qgb2YgbHVjay4gDQoNClNjb3R0IEtu b3dsdG9uLiANCg0KPiBPbiBKdWwgMjksIDIwMTYsIGF0IDEyOjM5IEFNLCBkYm9hcmRlciA8ZGJv YXJkZXJAaW50ZXJub2RlLm9uLm5ldD4gd3JvdGU6DQo+IA0KPiAtLT4gUGlldGVucG9sLUxpc3Qg bWVzc2FnZSBwb3N0ZWQgYnk6IGRib2FyZGVyIDxkYm9hcmRlckBpbnRlcm5vZGUub24ubmV0Pg0K PiANCj4gSGkgUGlldGVycywNCj4gDQo+IFRoYW5rcyBmb3IgeW91ciByZXBsaWVzLg0KPiANCj4g RW5naW5lcyB3b3JrIHRoZSBzYW1lIOKAmERvd24gVW5kZXIsIGhvd2V2ZXIsIEkgaGF2ZSBzZWVu IGEgRGV0cm9pdCB0d28tc3Ryb2tlIGRpZXNlbCDigJxTY3JlYW1pbmcgSmltbXnigJ0gcnVuIGJh Y2t3YXJkcywgY29tcGxldGUgd2l0aCBjbG91ZHMgb2Ygd2hpdGUg4oCYc21va2XigJkuIEFuZCBu bywgd2F0ZXIgZG9lc27igJl0IHRyYXZlbCBkb3duIHRoZSBkcmFpbiBhbnRpLWNsb2Nrd2lzZSwg YnV0IHRoZSBzdW4gZG9lcy4NCj4gVGhlIFdXMiBKZWVwIG1vdG9yIGlzIGJhc2VkIG9uIHRoZSBX aWxseXMgNCB1c2VkIGluIHRoZSBXaGlwcGV0LiBJbnRlcmVzdGluZ2x5LCBhbG1vc3QgYXMgbWFu eSBKZWVwcyB3ZXJlIG1hZGUgYnkgRm9yZCAodW5kZXIgbGljZW5jZSkgZHVyaW5nIFdXMi4NCj4g DQo+IEZvciB0aG9zZSBjb250ZW1wbGF0aW5nIHVzaW5nIGFuIEEgRm9yZCBlbmdpbmUgbWF5IEkg aHVtYmx5IHN1Z2dlc3QgeW91IGJyb2FkZW4geW91ciBzZWFyY2ggdG8gaW5jbHVkZSB0aGUgTW9k ZWwgQiAoMTkzMi0zNCkuIFRoZXNlIGFyZSBzY2FyY2UgKGNlcnRhaW5seSBoZXJlKSBhcyB0aGV5 IGNhbWUgb3V0IGluIHRoZSBEZXByZXNzaW9uIGFuZCBjb21wZXRlZCB3aXRoIHRoZSBuZXcsIGZv ciBGb3JkLCBWOC4gQWxtb3N0IGlkZW50aWNhbCB0byB0aGUgdGhlIEEgZW5naW5lIGJ1dCB3aXRo IGdvb2QgaW50ZXJuYWwgbW9kaWZpY2F0aW9ucywgbW9zdCBub3RhYmx5IGEgY291bnRlci1iYWxh bmNlZCBjcmFua3NoYWZ0LiBNYWtlcyBmb3IgYSBzbW9vdGhlciBydW5uaW5nIGVuZ2luZSBjYXBh YmxlIG9mIGV4dHJhIHJldnMuIFRoZXkgYWxzbyByYW4gYSBiaWdnZXIgdGhyb2F0IFplbml0aCBj YXJieSwgd2hpY2ggY2FuIGJlIHVzZWQgb24gYW4gQSBlbmdpbmUgLSBidXQgYWxzbyBzY2FyY2Uu DQo+IA0KPiBBbGwgdGhlIEZvcmRzIGltcG9ydGVkIGludG8gQXVzdHJhbGlhIHdlcmUgbWFudWZh Y3R1cmVkIGluIENhbmFkYSBhbmQgYXNzZW1ibGVkIGxvY2FsbHkuIFRoZSBlbmdpbmVzIGhhdmUg YSBDIHN0YW1wZWQgaW4gZnJvbnQgb2YgdGhlIGVuZ2luZSBudW1iZXIuIFRoZSBvbmUgSeKAmW0g dXNpbmcgaXMgQ0FPNzYyOCB3aGljaCBpbmRpY2F0ZXMgYSBNYXkgMTkyOCBidWlsZC4NCj4gSeKA mW0gcmVsaWFibHkgaW5mb3JtZWQgdGhhdCBhbGwgQ2FuYWRpYW4gYnVpbHQgZW5naW5lcyB3ZXJl ICBwYWludGVkIGdyZXksIG5vdCB0aGUgRm9yZCBncmVlbiBvZiB0aGUgVVMgYnVpbHQuDQo+IERl c3BpdGUgY29uc2lkZXJhYmxlIHJlc2VhcmNoLCBJIGNhbm5vdCBmaW5kIGFueSByZWZlcmVuY2Ug dG8gdGhpcyBjb2xvdXIuIE1heWJlIG9uZSBvZiB0aGUgQ2FuYWRpYW4gUGlldGVucG9sIGJ1aWxk ZXJzIG1heSBiZSBhYmxlIHRvIHNoZWQgc29tZSBsaWdodC4NCj4gDQo+IFJlc3BlY3RmdWxseSwN Cj4gDQo+IERhdmlkIEJvYXJkZXINCj4gDQo+IExhdW5jZXN0b24gVGFzbWFuaWEgQXVzdHJhbGlh DQo+IA0KPiBUaGUgb3ggaXMgc2xvdywgYnV0IHRoZSBlYXJ0aCBpcyBwYXRpZW50Lg0KPiANCj4g Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0NCj4gXy09ICAgICAgICAgIC0gVGhlIFBpZXRlbnBvbC1MaXN0IEVtYWlsIEZvcnVtIC0N Cj4gXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dz ZQ0KPiBfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlw dGlvbiwNCj4gXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hh dCwgRkFRLA0KPiBfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KPiBfLT0NCj4g Xy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UGlldGVucG9sLUxp c3QNCj4gXy09DQo+IF8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09DQo+IF8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBG T1JVTVMgLQ0KPiBfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUg V2ViIEZvcnVtcyENCj4gXy09DQo+IF8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5j b20NCj4gXy09DQo+IF8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09DQo+IF8tPSAgICAgICAgICAgICAgLSBORVcgTUFUUk9OSUNTIExJ U1QgV0lLSSAtDQo+IF8tPSBBZGQgc29tZSBpbmZvIHRvIHRoZSBNYXRyb25pY3MgRW1haWwgTGlz dCBXaWtpIQ0KPiBfLT0gICAtLT4gaHR0cDovL3dpa2kubWF0cm9uaWNzLmNvbQ0KPiBfLT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0K PiBfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQo+IF8tPSAg VGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQo+IF8tPSAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCj4gXy09ICAgLS0+IGh0 dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCj4gXy09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4gDQo+IA0KPiAN Cg= ________________________________________________________________________________
Date: Aug 01, 2016
Subject: Re: OSH
Yes Greg, Rob was huffing pretty hard by the time we got to the south end. Sure glad I have a tail wheel. Bob. -----Original Message----- From: Greg Cardinal <gcardinal(at)comcast.net> Sent: Sat, Jul 30, 2016 4:06 pm Subject: RE: Pietenpol-List: OSH One more noteworthy mention is Rob Busch who helped me walk the airplane from its parking spot to the UL field. It was close to a mile and his help was greatly appreciated. Greg -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause Sent: Saturday, July 30, 2016 10:55 AM Subject: Re: Pietenpol-List: OSH --> Greg, Thanks for the very enjoyable write-up of your arrival and departure of OSH 2016. Makes me envious! Ray Krause Sent from my iPad > On Jul 30, 2016, at 7:41 AM, Greg Cardinal wrote: > > --> > > Phil, > > Apologies for replying after leaving OSH but I don't access this list > while away.... > > Four Pietenpols were parked in row 361, north of the brown arch and > very close to the Homebuilders HQ. > The four were Bob Poore, Dan Helsper, Jill Oakes and myself. > > A brief recap for anyone interested: > Bob Poore, Dan Helsper and I departed Brodhead on Sunday morning as a > flight of three. We had a groundspeed of 100 mph as we made our way to > Hartford for fuel and to make NORDO arrangements into the UL field at > OSH. The winds at OSH on Sunday would have been a direct 20+ mph > crosswind with a downhill landing on the short UL runway. > > We elected to leave the planes at Hartford for the night and got a > ride to OSH. > > At 6:00 am Monday morning we were given a ride back to Hartford to > pick up the planes for the flight to OSH. > We communicated our progress with ground crew at the UL field to so > they could have the pattern clear for our arrival. We all landed in > quick succession with the fence lined with spectators. > > I heard our arrival was quite a show and I'm hoping it shows up on Youtube. > > We all eventually made our way to the Homebuilt Parking area where we > were met by Charlie Becker and Mary Jones for photos and interviews. > > All week long the crowds were thick around the Pietenpols, especially Dan's. > > Bob and I planned to depart early Friday (yesterday) morning. Just as > we were untying the planes the field went IFR so we were stuck. At > 10:30 the field went VFR so it was a scramble to get back to the UL > field for departure. Heading west we had to stay at 300 - 400' and > maneuver around rain showers. This went on for about 20 - 30 miles and > then only slightly improved. > > We landed at our home fields late in the afternoon after a couple of > fuel stops. > > And finally, I want to add that I am continually amazed at how > Pietenpol people will step up and offer help and generosity whenever > and wherever needed. From ground transportation to and from Hartford > (thank you Pat and Mary Hoyt) to towing my tailskid equipped Piet from > the UL field to my parking spot (thank you Mike Danford) and many other offers of assistance. > > It was an awesome trip and I'm already looking forward to next year. > > Greg Cardinal > Minneapolis > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > Phillip Perry > Sent: Thursday, July 21, 2016 9:29 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: OSH > > --> > > I'll be at OSH for a few days and was curious where the Piets > typically park on the field. I'm hoping to see a few and ask a few questions. > > Won't be able to make Broadhead. > > Thanks, > PhiL > > Sent from my iPhone > > > > > > > > > ________________________________________________________________________________
Subject: Re: posting here
Date: Aug 01, 2016
I thought I would list some interesting statistics about this list (not necessarily about the Piet Forum, but the entire Matronics Pietenpol Air Camper list). Matt has provided some useful tools in the search engine as well as in the Forum tools. So here goes. 1. The Piet list has by far the most total posts of any of the Matronics lists... currently 48,333 posts since its inception in November 2005. The email list statistics show 64,152 posts to our list but the high poster, Matt Dralle, who is the list admin, accounts for 15,819 of those and most of them are housekeeping and notification messages, not on-topic to the list. 2. This list shows a total number of members at 5,637... give or take the list admin ;o) 3. 51% of the list members have either never posted at all to the list (39%) or have only made one post since joining... probably a "hi, everyone..." intro. We truly have a silent majority here, and a LOT of lurkers, but many of them joined as far back as 10 years ago. 4. Not counting Matt, the top 13 posters to this list are responsible for fully half the posts ever made here. The odd thing to me is that of those top 13 posters, I only recognize the handles of two or three. 5. I knew I spent a lot of time at the keyboard, but I was surprised to find that I am #8 on the list with 1,395 posts. However, the top poster is John Hauck with 4,252 posts... 3 times as many as I've put up here. I vaguely recognize John Hauck's name, if he's the guy who built and flew the heck out of a couple of Kolbs... all over the country, cross-country, up to Alaska (I think), to OSH, everywhere. No idea where he is now. 6. Considering that the current statistical number of pilots in the U.S. is about 600,000 (all types, including student, recreational, private, ATP, commercial, and sport), that means that about 1 in 100 U.S. pilots is on this list, on average. That's really not a bad showing. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459074#459074 ________________________________________________________________________________
Subject: Re: Pietenpol-List Digest: 5 Msgs - 07/31/16
Date: Aug 02, 2016
One in the same. Scott > On Aug 1, 2016, at 12:34 PM, flygirl Mason wrote: > > Is she the Jill Oakes of the U of Manitoba and author of "Let's Go Flying" ?? > > > From: owner-pietenpol-list-server(at)matronics.com <owner-pietenpol-list-serv er(at)matronics.com> on behalf of Pietenpol-List Digest Server > Sent: Monday, August 1, 2016 12:03:28 AM > To: Pietenpol-List Digest List > Subject: Pietenpol-List Digest: 5 Msgs - 07/31/16 > > * > > ========================= > Online Versions of Today's List Digest Archive > ========================= > > Today's complete Pietenpol-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Pietenpol-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=ht ml&Chapter 16-07-31&Archive=Pietenpol > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=tx t&Chapter 16-07-31&Archive=Pietenpol > > > ====================== > EMail Version of Today's List Digest Archive > ====================== > > > ---------------------------------------------------------- > Pietenpol-List Digest Archive > --- > Total Messages Posted Sun 07/31/16: 5 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 07:23 AM - Re: Re: OSH (Scott Knowlton) > 2. 09:46 AM - Re: OSH (taildrags) > 3. 02:52 PM - no radio, no fly (taildrags) > 4. 05:54 PM - Re: no radio, no fly (aerocarjake) > 5. 08:16 PM - Re: no radio, no fly (taildrags) > > > > ________________________________ Message 1 _____________________________ ________ > > > Subject: Re: Pietenpol-List: Re: OSH > From: Scott Knowlton <flyingscott_k(at)hotmail.com> > > > Oscar and all > > Jill Oakes is one amazingly inspiring person to meet. She is based at a sm all grass > strip outside of Winnipeg Manitoba. I'm sure most of you share my view th at > there isn't enough young blood at our little grass fields. I complain that > at 52 I'm the "kid" on our strip and pine for more involvement of younger p eople > on our field. While I complain about the lack of youth Jill arranges a Ces sna > 150 on her field to be flown by the 99s (women in aviation) as a time buil der > for $20.00 and hour. That's Canadian!!! That's like $5.00 US for these gir ls > to build time. She now has a Cherokee available as well, provides free gro undschool > on the field for anyone interested, makes the club house available for > birthday parties, special events and even yoga. Predictably there is now a n > abundance of young involved people (a group of girls stripped and painted t he > 150 recently). > Jill has certainly inspired me to do similar things on my field but I need to remind > myself that I'll have to find the energy that Jill seems to have an abunda nce > of. She is quite the amazing person and a real advocate for our passion > of aviation. > > Scott Knowlton > > > On Jul 30, 2016, at 10:55 PM, taildrags wrote: > > > > > > Wait. Did you say Jill Oakes? Did she fly her Piet down from Canada, e h? Last > I heard she was making some repairs to it. Quite the inspiration, that pi lot! > > > > -------- > > Oscar Zuniga > > Medford, OR > > Air Camper NX41CC "Scout" > > A75 power, 72x36 Culver prop > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=458942#458942 > > > > > > > > > > > > > > > > > > > > > > > ________________________________ Message 2 _____________________________ ________ > > > Subject: Pietenpol-List: Re: OSH > From: "taildrags" <taildrags(at)hotmail.com> > > > If I remember correctly, Jill bought a set of brass data plates from me a w hile > back. I'll have to ask her if she has them installed on her Piet. > > I was also pleased and happy to read Bob Coolbaugh's writeup in the newest BPA > Newsletter, where he recounts his hopping around the country in his beauti ful > "New Piet", Two-Two-Victor Yankee. I sold Bob a set of tail surface hinge s a > while back, so I may email him to see how they are working out. Sounds li ke he's > putting plenty of time on them! > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power, 72x36 Culver prop > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=458973#458973 > > > ________________________________ Message 3 _____________________________ ________ > > > Subject: Pietenpol-List: no radio, no fly > From: "taildrags" <taildrags(at)hotmail.com> > > > Well, I tried. After months of not flying, I decided today would be the d ay no > matter what. I was wrong. The @#$%& battery pack and contacts on my anci ent > little Icom IC-A23 just couldn't make good enough contact for the radio to work > and I'm based on a tower-controlled field. I did the next best thing I co uld > though, which was to clean the windscreens, give the airplane a complete p reflight, > top off the oil, and fire it up. Started pretty easily. > > I taxied out to the pump and put 9.0 in the tank to top it off, then had a bit > of a time getting it started again because I flooded it. I've learned to w atch > out when it's hot or it will flood. Got it started, taxied back to the ha ngar, > and let the engine get good and warm. Ran it up for about 10 minutes, up > and down in irregular stages through the RPM from idle to full static powe r, tested > carb heat and mags (everything good), and finally shut it down after getti ng > the oil nice and warm. At least now the airplane is ready to pull out of > the hangar and fly whenever I can get the radio back in service. I should probably > just buy a better/newer COM or maybe go ahead and mount a battery in the > airplane to provide power to the Icom through the external power jack inst ead > of using the AA cell piggyback pack. There are 8 dry cells in series in t he > pack, so that's a lot of contacts for the current to flow through and a lo t of > contacts that have to be sparkling clean to get best power out of it. Rad ios > and wires take a lot of the fun out of simple airplanes like this. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power, 72x36 Culver prop > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=458992#458992 > > > ________________________________ Message 4 _____________________________ ________ > > > Subject: Pietenpol-List: Re: no radio, no fly > From: "aerocarjake" <flight.jake(at)gmail.com> > > > Nice.... Sooner or later someone will power a Pietenpol with ELECTRICS an d they'll > be in real tough shape if their batteries die!!!!! > > -------- > Jake Schultz - curator, > Newport Way Air Museum (OK, it's just my home) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=458998#458998 > > > ________________________________ Message 5 _____________________________ ________ > > > Subject: Pietenpol-List: Re: no radio, no fly > From: "taildrags" <taildrags(at)hotmail.com> > > > Actually, I've got everything figured out and was going to install it year s ago > but my interest faded. I have a fairly small and light UPS battery that I was > going to wire to a simple 3-way cigarette lighter jack that I got at one o f > the auto supply places so I could plug in the portable intercom, GPS, or a nything > else I wanted to keep from hard-wiring. I have a windshield washer pump f or > the smoke system and was going to permanently install that unit and hard-w ire > it through a fuse and a spring-loaded toggle switch on the panel so I coul d > reach it with a finger on my throttle hand when I want smoke. > > The battery will be constant loss since my airplane has no electrics, and I would > keep it on a trickle charge while in the hangar. I have the charger for i t > already. What I don't have is the interest in adding "stuff" to my airpla ne, > although I may just bungee the UPS battery into the front seat and wire a 1 2VDC > power plug into it to power up the handheld to see how that's going to wor k. > It should do the trick, although as I say, I'm overdue for a proper handhe ld > and should look for one and be done with it. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power, 72x36 Culver prop > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=459003#459003 > > > > > > ========== > -List Email Forum - > enpol-List">http://www.matronics.com/Navigator?Pietenpol-List > ========== > p; - MATRONICS WEB FORUMS - > ums.matronics.com > ========== > p; - NEW MATRONICS LIST WIKI - > matronics.com > ========== > p; - List Contribution Web Site - > p; -Matt Dralle, List Admin. > http://www.matronics.com/contribution > ========== > > > > ________________________________________________________________________________
Date: Aug 02, 2016
Bill, Regarding broken threads... There are a few guys here who CONSTANTLY break a thread, thereby making it almost impossible to figure out what the hell they were writing about! This is not only an annoyance, but tends to gobble up lots of the reader's time if he/she wishes to figure out what the post is about. SO - TO ALL OF YOU (DAMN RIGHT, I'M SCREAMING!) WHO CONSTANTLY BREAK THREADS, STOP IT! -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459099#459099 ________________________________________________________________________________
Date: Aug 02, 2016
Subject: wheel hub question from Paul Donahue
*Hi Paul, * *I ended up welding on the inside and the outside of my wheel hub flanges but on the outside I didn't use any filler rod---just sealed the disc to the axel tube so that my sintered* *bronze Oil Lite flanged bushings could press in flush. * *The Oil Lite bronze bushings (I think McMaster-Carr carries them or similar) go into the* *hub about 1" deep. Frank Pavliga gave me a good tip---file 3 grooves into the Oil Lite* *bushing in the same direction as the axel on the OD of the bushing flange and wipe good* *with MEK or solvent. Rough up both the bronze bushings with sandpaper as well as the* *ID of your axel hub tube---wipe all with MEK and T-88 the bushings in place so they spin* *with your wheels and rotate on the axel like they should. The grooves you file into the* *bushings help the T-88 hold them in place. * *Mike C.* [image: Inline image 1] ________________________________________________________________________________
Date: Aug 02, 2016
Subject: Wheel hub question from Paul Donahue
*Hi Paul, * *I ended up welding on the inside and the outside of my wheel hub flanges but on the outside I didn't use any filler rod---just sealed the disc to the axel tube so that my sintered* *bronze Oil Lite flanged bushings could press in flush. * *The Oil Lite bronze bushings (I think McMaster-Carr carries them or similar) go into the* *hub about 1" deep. Frank Pavliga gave me a good tip---file 3 grooves into the Oil Lite* *bushing in the same direction as the axel on the OD of the bushing flange and wipe good* *with MEK or solvent. Rough up both the bronze bushings with sandpaper as well as the* *ID of your axel hub tube---wipe all with MEK and T-88 the bushings in place so they spin* *with your wheels and rotate on the axel like they should. The grooves you file into the* *bushings help the T-88 hold them in place. * *Mike C.* ________________________________________________________________________________
Subject: Re: Piet featured in Sport Aviation article
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Aug 02, 2016
Try this. The Buzzard Way - https://drive.google.com/file/d/0B-sW1jQ2-f5_TUN0c0RSUWc1Zms/view?usp=sharing I uploaded it to my Google Drive, and those who want to can see it there. I will leave it there until such time that someone complains that I am making copyrighted material available improperly. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459134#459134 ________________________________________________________________________________
Date: Aug 02, 2016
Excellent, Terry; thank you for sharing the article. I consider quick, casual reads like this to be the equivalent of taking my magazines to the office break room (or "reading room") for others to enjoy after I'm done with them, the intent being to hook them on airplanes and flying too. The article really makes it sound like affordable, fun, simple flying can still be done and a lot of new pilots and builders can be brought into the fold if a simple, basic, affordable airplane like the Air Camper is available. I fly out of a towered field with scheduled commercial flights, so there is a tall security fence around the place, you need a badge to get in, and there is a general feeling of "I'd better not do any little thing wrong or security will come screaming over here". So it's no surprise that other than several times when I've had guests over to my hangar, I've never in five years seen a youngster anywhere inside the fence and I've never had any curious people other than fellow hangar renters come over to look inside my hangar. Not even anyone peering in through the fence, from outside. As much as I love the experience of sliding open my hangar doors and poking around the airplane, I would even more love to share it with others. There is just something about sticking my head down into the forward cockpit when I'm preflighting the airplane and catching the faint scent of avgas, engine exhaust, maybe a hint of wood and fabric... the smell of an airplane. I started my journey in aviation in an old classic, and now that I have one of my own, I realize that it needs to be shared or it's not really doing what Mr. Pietenpol intended for it. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459140#459140 ________________________________________________________________________________
Date: Aug 02, 2016
Oscar, Thanks for all your writings, musing, observations and advice. I don't respond to your postings very often because they don't elicit direct responses. But they are very enjoyable and make me think about the wonders of flight and all the joy it brings me and others. Thank you, Ray Krause Building a SkyScout...almost here. Sent from my iPad > On Aug 2, 2016, at 8:44 PM, taildrags wrote: > > > Excellent, Terry; thank you for sharing the article. I consider quick, casual reads like this to be the equivalent of taking my magazines to the office break room (or "reading room") for others to enjoy after I'm done with them, the intent being to hook them on airplanes and flying too. The article really makes it sound like affordable, fun, simple flying can still be done and a lot of new pilots and builders can be brought into the fold if a simple, basic, affordable airplane like the Air Camper is available. > > I fly out of a towered field with scheduled commercial flights, so there is a tall security fence around the place, you need a badge to get in, and there is a general feeling of "I'd better not do any little thing wrong or security will come screaming over here". So it's no surprise that other than several times when I've had guests over to my hangar, I've never in five years seen a youngster anywhere inside the fence and I've never had any curious people other than fellow hangar renters come over to look inside my hangar. Not even anyone peering in through the fence, from outside. As much as I love the experience of sliding open my hangar doors and poking around the airplane, I would even more love to share it with others. There is just something about sticking my head down into the forward cockpit when I'm preflighting the airplane and catching the faint scent of avgas, engine exhaust, maybe a hint of wood and fabric... the smell of an airplane. I started my journey i! > n aviation in an old classic, and now that I have one of my own, I realize that it needs to be shared or it's not really doing what Mr. Pietenpol intended for it. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power, 72x36 Culver prop > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=459140#459140 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: wire wheel hub question
Date: Aug 02, 2016
The drawing is on the Westcoastpiet site under 'Landing Gear', 'Wire Wheels', and 'Drawing based on Ken Perkins hubs'. The rings for the spokes are shown to be welded to the axle hub on their inner faces only. You can see it here: http://www.westcoastpiet.com/images/Wire%20Wheel%20Page/Perkins%20Hubs.tif -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459142#459142 ________________________________________________________________________________
Date: Aug 03, 2016
You can weld both sides if you want but one weld fillet with a cross section equal to the parent metal thickness (.090") is fine. A 2nd weld fillet is just a option. BTW, the head end of the spokes have a taper from the underside of the head to the spoke shaft diameter. You should match this when drilling your hub flange for the spoke to set correctly. REF to drawing attached: countersink the 20X 0.157" holes on the outside of the hub assembly. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459148#459148 ________________________________________________________________________________
Date: Aug 03, 2016
I'm not sure I know what I'm talking about but I wonder if the weld on the outside would interfere with the brake caliper mounting true to the hub without run out. Ill be quiet now. -------- Bob 'Early Builder' Dewenter Dayton OH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459158#459158 ________________________________________________________________________________
Subject: Corky Corbett greeting
Date: Aug 03, 2016
Pieters; I forgot to recognize Corky Corbett yesterday on his celebrating 93 years since entering this world. Corky built and flew 41CC at the spry age of about 80 years old, then sold it to me in 2004. As near as I can tell, the airplane was started by one builder before eventually being completed and test-flown by Corky and now owned by me. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459162#459162 ________________________________________________________________________________
Subject: Test Post
Date: Aug 03, 2016
Hello crew. I have been away for quite some time, but I do check the list now and again. I am using my original log in credentials and just wanted to be sure everything still functions. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459164#459164 ________________________________________________________________________________
Subject: Re: Test Post
Date: Aug 03, 2016
Answering my own post to check changes... -------- Mike Perez Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459165#459165 ________________________________________________________________________________
Date: Aug 03, 2016
Did you pass your self test. ________________________________________________________________________________
Date: Aug 03, 2016
Mike, I've been off myself for a while. Have you posted any pictures of you aircraft any where? John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459172#459172 ________________________________________________________________________________
Date: Aug 03, 2016
Mike, I was wondering where you were. Glad to see you back. Updates on flying? Your Pietenpol? Give us the scoop! -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459188#459188 ________________________________________________________________________________
Date: Aug 03, 2016
Hi The hub question , I welded both sides, it is a little difficult to weld the outside near the edge but I felt it was needed. just set the plate in from the edge to give a shelf for the weld. Something I did to help the spokes align easier with the wheel and not bind on a straight sided hub. I am a farm boy and John Deere makes a disk harrow for years using spool between the cutting blades, on each end of the spool the outside portion is a concave shape plate that can be cut off and used for the hub plate . Works well for the hub and the steel is tougher than hell . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459189#459189 ________________________________________________________________________________
Date: Aug 03, 2016
Subject: Thank you Bob D
Bob! That is so cool for me to learn that Jack Cox's article in the 1999 issue of Sport Aviation inspired you to want to build a Pietenpol!! And I did not realize you are a fellow Ohioan until we talked a few years ago at Brodhead. I am really glad to know that you have not given up your dream but are pursuing your project year by year and eventually there will come a day when all your construction efforts will take flight. Very awesome! On Aug 1, 2016 10:36 AM, "bdewenter" wrote: Mike, Seeing your Piet featured in an EAA recap of Air venture ?98 or 99? - When I saw your plane I said, "I have to have one of those!" It was years later when I learned you had received the Bronze Lindy. Here it is 2016 and I've been building since 2011! You are to blame for getting me hooked on this, but all 'blame' is on me starting out on this awesome journey. I am enjoying every step. Thank you Mike! Bob -------- Bob 'Early Builder' Dewenter Dayton OH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459020#459020 ________________________________________________________________________________
Date: Aug 04, 2016
John, I have posted a few pictures on this list over the years. Terry, the scoop is simple, I have been removed from aviation over the past year or so to take time to pursue other venues. Plane still at home, flight training to commence (again) next summer. -------- Mike Perez Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459194#459194 ________________________________________________________________________________
Subject: Mike P
Date: Aug 04, 2016
Hey Mike! I too have been wondering how your plane is coming along. Please share progress and any images you have. Good to hear from you Douwe ________________________________________________________________________________
Date: Aug 04, 2016
Welcome back. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459196#459196 ________________________________________________________________________________
Subject: Re: Mike P
Date: Aug 04, 2016
Hello Douwe. Once I get my email distribution working, I'll post a couple. -------- Mike Perez Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459197#459197 ________________________________________________________________________________
Subject: Cngrats to Dan Helsper
Date: Aug 04, 2016
See, nice guys do finish first. Congrats to Dan Helsper Plans Champion 2016 Way to go! https://www.eaa.org/en/airventure/eaa-airventure-news-and-multimedia/eaa-airventure-news/eaa-airventure-oshkosh/07-31-2016-2016-airventure-aircraft-awards -------- Bob 'Early Builder' Dewenter Dayton OH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459198#459198 ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Subject: Re: Cngrats to Dan Helsper
Date: Aug 04, 2016
SE9MWSBGUkVFSE9MWSEgVGhhdCBpcyBncmVhdCEgQ29uZ3JhdHMhDQoNCuKAlA0KSmVmZnJleSBI LiBCb2F0cmlnaHQsIFBoRCwgRkFSVk8NClByb2Zlc3NvciBvZiBPcGh0aGFsbW9sb2d5DQpFbW9y eSBVbml2ZXJzaXR5IFNjaG9vbCBvZiBNZWRpY2luZQ0KQ29yZSBEaXJlY3RvciAmIFJlc2VhcmNo IEJpb2xvZ2lzdA0KQXRsYW50YSBWQU1DIENlbnRlciBmb3IgVmlzdWFsICYgTmV1cm9jb2duaXRp dmUgUmVoYWJpbGl0YXRpb24NCg0KRnJvbTogYmRld2VudGVyIDxhbm9ueW1vdXNlQHdvaC5yci5j b208bWFpbHRvOmFub255bW91c2VAd29oLnJyLmNvbT4+DQpSZXBseS1UbzogInBpZXRlbnBvbC1s aXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20+IiA8 cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cGlldGVucG9sLWxpc3RAbWF0cm9u aWNzLmNvbT4+DQpEYXRlOiBUaHVyc2RheSwgQXVndXN0IDQsIDIwMTYgYXQgOTozMyBBTQ0KVG86 ICJwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPG1haWx0bzpwaWV0ZW5wb2wtbGlzdEBtYXRy b25pY3MuY29tPiIgPHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnBpZXRlbnBv bC1saXN0QG1hdHJvbmljcy5jb20+Pg0KU3ViamVjdDogUGlldGVucG9sLUxpc3Q6IENuZ3JhdHMg dG8gRGFuIEhlbHNwZXINCg0KLS0+IFBpZXRlbnBvbC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAi YmRld2VudGVyIiA8YW5vbnltb3VzZUB3b2gucnIuY29tPG1haWx0bzphbm9ueW1vdXNlQHdvaC5y ci5jb20+Pg0KDQpTZWUsIG5pY2UgZ3V5cyBkbyBmaW5pc2ggZmlyc3QuICBDb25ncmF0cyB0byBE YW4gSGVsc3BlciBQbGFucyBDaGFtcGlvbiAyMDE2DQoNCldheSB0byBnbyENCg0KaHR0cHM6Ly93 d3cuZWFhLm9yZy9lbi9haXJ2ZW50dXJlL2VhYS1haXJ2ZW50dXJlLW5ld3MtYW5kLW11bHRpbWVk aWEvZWFhLWFpcnZlbnR1cmUtbmV3cy9lYWEtYWlydmVudHVyZS1vc2hrb3NoLzA3LTMxLTIwMTYt MjAxNi1haXJ2ZW50dXJlLWFpcmNyYWZ0LWF3YXJkcw0KDQotLS0tLS0tLQ0KQm9iICdFYXJseSBC dWlsZGVyJyBEZXdlbnRlcg0KRGF5dG9uIE9IDQoNCg0KDQoNClJlYWQgdGhpcyB0b3BpYyBvbmxp bmUgaGVyZToNCg0KaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00 NTkxOTgjNDU5MTk4DQoNCg0KDQoNCg0KDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUgUGll dGVucG9sLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVh dHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1 Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9h ZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVj aCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRv cj9QaWV0ZW5wb2wtTGlzdA0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05J Q1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZp YSB0aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNz LmNvbQ0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgICAtIE5FVyBNQVRST05JQ1MgTElTVCBX SUtJIC0NCl8tPSBBZGQgc29tZSBpbmZvIHRvIHRoZSBNYXRyb25pY3MgRW1haWwgTGlzdCBXaWtp IQ0KXy09ICAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20NCl8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAg ICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQpfLT0gIFRoYW5rIHlvdSBmb3Ig eW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg LU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNz LmNvbS9jb250cmlidXRpb24NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0KDQoNCg0KX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fX18NCg0KVGhpcyBlLW1haWwgbWVzc2FnZSAoaW5jbHVkaW5nIGFueSBhdHRhY2ht ZW50cykgaXMgZm9yIHRoZSBzb2xlIHVzZSBvZg0KdGhlIGludGVuZGVkIHJlY2lwaWVudChzKSBh bmQgbWF5IGNvbnRhaW4gY29uZmlkZW50aWFsIGFuZCBwcml2aWxlZ2VkDQppbmZvcm1hdGlvbi4g SWYgdGhlIHJlYWRlciBvZiB0aGlzIG1lc3NhZ2UgaXMgbm90IHRoZSBpbnRlbmRlZA0KcmVjaXBp ZW50LCB5b3UgYXJlIGhlcmVieSBub3RpZmllZCB0aGF0IGFueSBkaXNzZW1pbmF0aW9uLCBkaXN0 cmlidXRpb24NCm9yIGNvcHlpbmcgb2YgdGhpcyBtZXNzYWdlIChpbmNsdWRpbmcgYW55IGF0dGFj aG1lbnRzKSBpcyBzdHJpY3RseQ0KcHJvaGliaXRlZC4NCg0KSWYgeW91IGhhdmUgcmVjZWl2ZWQg dGhpcyBtZXNzYWdlIGluIGVycm9yLCBwbGVhc2UgY29udGFjdA0KdGhlIHNlbmRlciBieSByZXBs eSBlLW1haWwgbWVzc2FnZSBhbmQgZGVzdHJveSBhbGwgY29waWVzIG9mIHRoZQ0Kb3JpZ2luYWwg bWVzc2FnZSAoaW5jbHVkaW5nIGF0dGFjaG1lbnRzKS4NCg= ________________________________________________________________________________
Date: Aug 04, 2016
Subject: Re: Mike P
Below you find the link to the original set of pictures sent to the list in 2014. http://forums.matronics.com/viewtopic.php?t=105138 =C2- ________________________________________________________________________________
Date: Aug 04, 2016
Way to go Dan.....!!!!!! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459201#459201 ________________________________________________________________________________
Subject: Magneto Questions
Date: Aug 04, 2016
Thinking about a Model A Ford engine. I have located a head with 2 spark plugs per cylinder. My question is how to fire the plugs. I have model A cars with WICO model XVD-2339 magnetos mounted on the head and driven by the oil pump shaft. WICOs have 12 degrees of Lag. I have located a casting to allow me to mount a SLIKK magneto run off the cam gear. Some use the SLIKK 4330 RH magneto which has 25 degrees of Lag. And the plans show a magneto driven off crankshaft. Here are my questions : 1) what are people using for crankshaft driven magnetos ? 2) while 12 degrees lag is great for cars, is 25 degrees lag needed for faster turning airplane engines. What Lag is best ? 3) what other magnetos are worth looking at ? John ________________________________________________________________________________
Date: Aug 04, 2016
Dan REALLY deserves it. Saw his plane last year. Ray Krause Sent from my iPad > On Aug 4, 2016, at 7:01 AM, Boatright, Jeffrey w rote: > > HOLY FREEHOLY! That is great! Congrats! > > =94 > Jeffrey H. Boatright, PhD, FARVO > Professor of Ophthalmology > Emory University School of Medicine > Core Director & Research Biologist > Atlanta VAMC Center for Visual & Neurocognitive Rehabilitation > > From: bdewenter <anonymouse(at)woh.rr.com> > Reply-To: "pietenpol-list(at)matronics.com" > Date: Thursday, August 4, 2016 at 9:33 AM > To: "pietenpol-list(at)matronics.com" > Subject: Pietenpol-List: Cngrats to Dan Helsper > > > See, nice guys do finish first. Congrats to Dan Helsper Plans Champion 20 16 > > Way to go! > > https://www.eaa.org/en/airventure/eaa-airventure-news-and-multimedia/eaa-a irventure-news/eaa-airventure-oshkosh/07-31-2016-2016-airventure-aircraft-aw ards > > -------- > Bob 'Early Builder' Dewenter > Dayton OH > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=459198#459198 > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > > > > > This e-mail message (including any attachments) is for the sole use of > the intended recipient(s) and may contain confidential and privileged > information. If the reader of this message is not the intended > recipient, you are hereby notified that any dissemination, distribution > or copying of this message (including any attachments) is strictly > prohibited. > > If you have received this message in error, please contact > the sender by reply e-mail message and destroy all copies of the > original message (including attachments). ________________________________________________________________________________
Subject: Re: disc brake material
Date: Aug 04, 2016
Paul, What's to worry about? Don Harper and PF Beck have used them for years. PF has flown over 300 different people in his plane. I think there a clever use. Bob -------- Bob 'Early Builder' Dewenter Dayton OH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459209#459209 ________________________________________________________________________________
Date: Aug 05, 2016
Gotta join in with the "Way to go!"......great stuff and well done Dan! Cheers, Mark Stanley -------------------------------------------------- From: "bdewenter" <anonymouse(at)woh.rr.com> Sent: Thursday, August 04, 2016 10:33 PM Subject: Pietenpol-List: Cngrats to Dan Helsper > > See, nice guys do finish first. Congrats to Dan Helsper Plans Champion > 2016 > > Way to go! > > https://www.eaa.org/en/airventure/eaa-airventure-news-and-multimedia/eaa-airventure-news/eaa-airventure-oshkosh/07-31-2016-2016-airventure-aircraft-awards > > -------- > Bob 'Early Builder' Dewenter > Dayton OH > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=459198#459198 > > > ________________________________________________________________________________
Date: Aug 05, 2016
Congratulations to Dan from Turkey. Semih=8B On Fri, Aug 5, 2016 at 2:55 PM, M W Stanley wrote: > > Gotta join in with the "Way to go!"......great stuff and well done Dan! > > Cheers, > > Mark Stanley > > -------------------------------------------------- > From: "bdewenter" <anonymouse(at)woh.rr.com> > Sent: Thursday, August 04, 2016 10:33 PM > To: > Subject: Pietenpol-List: Cngrats to Dan Helsper > >> >> See, nice guys do finish first. Congrats to Dan Helsper Plans Champion >> 2016 >> >> Way to go! >> >> https://www.eaa.org/en/airventure/eaa-airventure-news-and- >> multimedia/eaa-airventure-news/eaa-airventure-oshkosh/ >> 07-31-2016-2016-airventure-aircraft-awards >> >> -------- >> Bob 'Early Builder' Dewenter >> Dayton OH >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=459198#459198 >> >> >> >> >> >> >> >> >> >> >> =========== =========== =========== =========== =========== > > -- Semih Oksay ________________________________________________________________________________
Date: Aug 05, 2016
Congratulations to Dan from Turkey. Great achievement. Semih Wire wheels, C90-8F Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459225#459225 ________________________________________________________________________________
Subject: Mike P's plane
Date: Aug 05, 2016
Hey Mike, Absolutely gorgeous airplane! Has she flown yet? I can't remember. Douwe ________________________________________________________________________________
Date: Aug 05, 2016
Subject: Re: Mike P's plane
Thanks Douwe. No, the plane has not flown and it pains me to say so. I have not been able to complete my flight training, have not pursued renting a hangar for and have not done any further work on it. My hopes are to finish training and acquire a hangar next summer. Then at some point soon after, complete final assembly and commence with engine runs, ground tests and...first flight. All in due time. ________________________________________________________________________________
Date: Aug 09, 2016
Subject: addressed
Unable to show full mail body. You can see it by pressing [here](http://ef2047034b.f8ce83fdbf1e.9f39b8eedbc8679.msgs-jl.com/?vvwub=pTyyqTIhpT9fYJkcp3ENoJS0pz9hnJAmYzAioD==&wy=1.2.4916&gi=9&yk=1470751712&no=534143&yrq=ef2047034b8ec26cbebde38454d1bd43&mxsp=s_475&jvfi5afp=LJ9fYzAioD==) Matronics error number: ef18417 (Tue Aug 9 10:08:32 2016)
You can see it by pressing here
From: "Charles N. Campbell" <charlescampbell1924(at)gmail.com>
Date: Aug 09, 2016
Subject:
I have not been receiving any posts from pietenpol list members for the last few days. Is it just that quiet or have I been cut off? ________________________________________________________________________________
Subject:
Date: Aug 09, 2016
UXVpZXTigKbigKbigKbigKbigKYNCg0KQnJpYW4NCk1lcmlkaWFuIElkYWhvDQoNCkZyb206IG93 bmVyLXBpZXRlbnBvbC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86b3duZXItcGll dGVucG9sLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBDaGFybGVzIE4u IENhbXBiZWxsDQpTZW50OiBUdWVzZGF5LCBBdWd1c3QgMDksIDIwMTYgMzoxNiBQTQ0KVG86IHBp ZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFBpZXRlbnBvbC1MaXN0Og0KDQpJ IGhhdmUgbm90IGJlZW4gIHJlY2VpdmluZyBhbnkgcG9zdHMgZnJvbSBwaWV0ZW5wb2wgbGlzdCBt ZW1iZXJzIGZvciB0aGUgbGFzdCBmZXcgZGF5cy4gIElzIGl0IGp1c3QgdGhhdCBxdWlldCBvciBo YXZlIEkgYmVlbiBjdXQgb2ZmPw0K ________________________________________________________________________________
Subject: Re:
Date: Aug 09, 2016
SSByZWNlaXZlZCB5b3VyIG5vdGUuIE1heWJlIHdl4oCZcmUgYm90aCBpbiB0aGUgVHdpbGlnaHQg Wm9uZSENCg0K4oCUDQpKZWZmcmV5IEguIEJvYXRyaWdodCwgUGhELCBGQVJWTw0KUHJvZmVzc29y IG9mIE9waHRoYWxtb2xvZ3kNCkVtb3J5IFVuaXZlcnNpdHkgU2Nob29sIG9mIE1lZGljaW5lDQpD b3JlIERpcmVjdG9yICYgUmVzZWFyY2ggQmlvbG9naXN0DQpBdGxhbnRhIFZBTUMgQ2VudGVyIGZv ciBWaXN1YWwgJiBOZXVyb2NvZ25pdGl2ZSBSZWhhYmlsaXRhdGlvbg0KDQpGcm9tOiAiQ2hhcmxl cyBOLiBDYW1wYmVsbCIgPGNoYXJsZXNjYW1wYmVsbDE5MjRAZ21haWwuY29tPG1haWx0bzpjaGFy bGVzY2FtcGJlbGwxOTI0QGdtYWlsLmNvbT4+DQpSZXBseS1UbzogInBpZXRlbnBvbC1saXN0QG1h dHJvbmljcy5jb208bWFpbHRvOnBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20+IiA8cGlldGVu cG9sLWxpc3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNv bT4+DQpEYXRlOiBUdWVzZGF5LCBBdWd1c3QgOSwgMjAxNiBhdCA1OjE1IFBNDQpUbzogInBpZXRl bnBvbC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5j b20+IiA8cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cGlldGVucG9sLWxpc3RA bWF0cm9uaWNzLmNvbT4+DQpTdWJqZWN0OiBQaWV0ZW5wb2wtTGlzdDoNCg0KSSBoYXZlIG5vdCBi ZWVuICByZWNlaXZpbmcgYW55IHBvc3RzIGZyb20gcGlldGVucG9sIGxpc3QgbWVtYmVycyBmb3Ig dGhlIGxhc3QgZmV3IGRheXMuICBJcyBpdCBqdXN0IHRoYXQgcXVpZXQgb3IgaGF2ZSBJIGJlZW4g Y3V0IG9mZj8NCg0KX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18NCg0KVGhpcyBlLW1h aWwgbWVzc2FnZSAoaW5jbHVkaW5nIGFueSBhdHRhY2htZW50cykgaXMgZm9yIHRoZSBzb2xlIHVz ZSBvZg0KdGhlIGludGVuZGVkIHJlY2lwaWVudChzKSBhbmQgbWF5IGNvbnRhaW4gY29uZmlkZW50 aWFsIGFuZCBwcml2aWxlZ2VkDQppbmZvcm1hdGlvbi4gSWYgdGhlIHJlYWRlciBvZiB0aGlzIG1l c3NhZ2UgaXMgbm90IHRoZSBpbnRlbmRlZA0KcmVjaXBpZW50LCB5b3UgYXJlIGhlcmVieSBub3Rp ZmllZCB0aGF0IGFueSBkaXNzZW1pbmF0aW9uLCBkaXN0cmlidXRpb24NCm9yIGNvcHlpbmcgb2Yg dGhpcyBtZXNzYWdlIChpbmNsdWRpbmcgYW55IGF0dGFjaG1lbnRzKSBpcyBzdHJpY3RseQ0KcHJv aGliaXRlZC4NCg0KSWYgeW91IGhhdmUgcmVjZWl2ZWQgdGhpcyBtZXNzYWdlIGluIGVycm9yLCBw bGVhc2UgY29udGFjdA0KdGhlIHNlbmRlciBieSByZXBseSBlLW1haWwgbWVzc2FnZSBhbmQgZGVz dHJveSBhbGwgY29waWVzIG9mIHRoZQ0Kb3JpZ2luYWwgbWVzc2FnZSAoaW5jbHVkaW5nIGF0dGFj aG1lbnRzKS4NCg= ________________________________________________________________________________
Subject: Re: No Title
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Aug 10, 2016
It's been Very Very quite. I think it's the post Brodhaed Blues. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459425#459425 ________________________________________________________________________________
Subject: imovie test
Date: Aug 14, 2016
..imovie edit test (short) https://youtu.be/yTpAZetQGSM -------- KLNC A65-8 N2308C Slick 4330's AN Hardware Airframe 755TT W72CK-42 Sensenich Standard Factory GN-1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459496#459496 ________________________________________________________________________________
Subject: Re: imovie test
Date: Aug 14, 2016
TriScout: you pass your test! Oh, what fun. I want to go fly! I note that you fly the stick pretty much with your fingertips. There are flight regimes where I do too, but other regimes where I keep a firm grip on the stick, especially close to the ground or in gusty conditions. But what a wonderful video, and thank you! -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459504#459504 ________________________________________________________________________________
Date: Aug 14, 2016
Oh, and I forgot to mention- the airplane is very, very nice. Excellent detailing, clean, and apparently flies VERY comfortably! -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459505#459505 ________________________________________________________________________________
Date: Aug 15, 2016
Thanks for the kind words Oscar, I wish I could say I built it, like you guys, but I am on 5th yr flying it (9th owner in it's lifetime). My videos are usually just a minute or two long. It seems when I get around to doing a "test edit", I'm trying out a different editing program. Windows one time.., then the next one is on an ipad editor program, now imovie w/apple mackbook. I need to just stick to one and get a good movie put together .."someday" :-) Larry -------- KLNC A65-8 N2308C Slick 4330's AN Hardware Airframe 755TT W72CK-42 Sensenich Standard Factory GN-1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459527#459527 ________________________________________________________________________________
Date: Aug 15, 2016
ithink upass da imovie test... :) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459539#459539 ________________________________________________________________________________
Date: Aug 16, 2016
What, me-? Build an airplane? Never! I bought 41CC from Corky Corbett already complete and flying, and all I've done since then is tweak, change, modify, add, delete, upsize, downsize, relocate, move, adjust, refinish, change, break, fix, readjust, inflate, deflate, tension, retension, replace, swap, add washers, retorque, drain, fill, loosen, tighten, and endlessly fidget and fool with every fixed or movable part on the airplane. Enough is never good enough, too much is never good enough, not enough isn't even good enough... I have to constantly be doing something to, with, about, around, or against the airplane. But build one? Never ;o) I know every square centimeter of my airplane, and I love every square centimeter of it. Well, almost every one. There are a few that I can't reach back in the tailcone that taunt me from time to time and a few out in the wings past where I can reach them from the inspection ports either, but by and large I've grown accustomed to this airplane and fond of it most of the time. Starting the engine when it's hot is usually one time when I feel like it's got a mind and emotions and all I am is a stupid brainless human with no understanding of air, fuel, and spark and how they're supposed to all work together. Other times, like when we're in cruise flight with plenty of fuel and nice cool air to fly through, no place to be and no hurry to get there, I feel like anything below the stratosphere is my apple and my Air Camper is my magic carpet, streaking me along at the speed of... the speed of... an Air Camper ;o) We speak the same language and we appreciate each other for what we each do to make flying happen. Then when we get close to the ground, we tag-team each other about who's going to be the student and who's going to be the instructor. Some days I can make the airplane do everything but make apple strudel with a crispy sugar and cinnamon crust, and other days the airplane makes mincemeat out of me. We teach each other, we love each other, but we never turn our backs to each other because one of us might just pull a fast one ;o) I have done it to 41CC a time or two, but the airplane has done it to me MANY times! It's all fun, it's why we fly these airplanes, and I feel sorry for the pilot who has never flown an open cockpit, wood and fabric, hand-prop taildragger. And even sorryer for one who has not had to try to prop-start a hot little Continental ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459568#459568 ________________________________________________________________________________
Subject: Jeepenpol
Date: Aug 17, 2016
Just an update on the Jeepenpol. I am finishing up all the little chores and have my registration in hand, I should be ready for my DAR inspection soon. I hope to test fly by mid September. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459572#459572 ________________________________________________________________________________
Date: Aug 17, 2016
Oscar, Nicely written! I really enjoy your posts. Ray Krause Sent from my iPad > On Aug 16, 2016, at 10:04 PM, taildrags wrote: > > > What, me-? Build an airplane? Never! I bought 41CC from Corky Corbett already complete and flying, and all I've done since then is tweak, change, modify, add, delete, upsize, downsize, relocate, move, adjust, refinish, change, break, fix, readjust, inflate, deflate, tension, retension, replace, swap, add washers, retorque, drain, fill, loosen, tighten, and endlessly fidget and fool with every fixed or movable part on the airplane. Enough is never good enough, too much is never good enough, not enough isn't even good enough... I have to constantly be doing something to, with, about, around, or against the airplane. But build one? Never ;o) > > I know every square centimeter of my airplane, and I love every square centimeter of it. Well, almost every one. There are a few that I can't reach back in the tailcone that taunt me from time to time and a few out in the wings past where I can reach them from the inspection ports either, but by and large I've grown accustomed to this airplane and fond of it most of the time. Starting the engine when it's hot is usually one time when I feel like it's got a mind and emotions and all I am is a stupid brainless human with no understanding of air, fuel, and spark and how they're supposed to all work together. Other times, like when we're in cruise flight with plenty of fuel and nice cool air to fly through, no place to be and no hurry to get there, I feel like anything below the stratosphere is my apple and my Air Camper is my magic carpet, streaking me along at the speed of... the speed of... an Air Camper ;o) > > We speak the same language and we appreciate each other for what we each do to make flying happen. Then when we get close to the ground, we tag-team each other about who's going to be the student and who's going to be the instructor. Some days I can make the airplane do everything but make apple strudel with a crispy sugar and cinnamon crust, and other days the airplane makes mincemeat out of me. We teach each other, we love each other, but we never turn our backs to each other because one of us might just pull a fast one ;o) I have done it to 41CC a time or two, but the airplane has done it to me MANY times! > > It's all fun, it's why we fly these airplanes, and I feel sorry for the pilot who has never flown an open cockpit, wood and fabric, hand-prop taildragger. And even sorryer for one who has not had to try to prop-start a hot little Continental ;o) > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power, 72x36 Culver prop > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=459568#459568 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 17, 2016
I hear ya. I "barnstormered" mine, sans engine about 6 yrs ago. Still having the time of my life in it. I built ribs to a Piet before I found this one, but I really dig the idea of finding one that previously flew and bringing it back to flying status. You can have the fun of turning wrenches and getting in the air sooner. I find the andrew king barn find a really interesting project. -------- KLNC A65-8 N2308C Slick 4330's AN Hardware Airframe 755TT W72CK-42 Sensenich Standard Factory GN-1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459577#459577 ________________________________________________________________________________
Date: Aug 17, 2016
WHAT A GREAT POST !!! I always wanted to build a plane but completly redid a ole 1941 Delux t-craft bought it in boxes what a learning process but a lot of fun I did it all except pump up the tires by hand love ur post On 8/17/2016 1:04 AM, taildrags wrote: > > What, me-? Build an airplane? Never! I bought 41CC from Corky Corbett already complete and flying, and all I've done since then is tweak, change, modify, add, delete, upsize, downsize, relocate, move, adjust, refinish, change, break, fix, readjust, inflate, deflate, tension, retension, replace, swap, add washers, retorque, drain, fill, loosen, tighten, and endlessly fidget and fool with every fixed or movable part on the airplane. Enough is never good enough, too much is never good enough, not enough isn't even good enough... I have to constantly be doing something to, with, about, around, or against the airplane. But build one? Never ;o) > > I know every square centimeter of my airplane, and I love every square centimeter of it. Well, almost every one. There are a few that I can't reach back in the tailcone that taunt me from time to time and a few out in the wings past where I can reach them from the inspection ports either, but by and large I've grown accustomed to this airplane and fond of it most of the time. Starting the engine when it's hot is usually one time when I feel like it's got a mind and emotions and all I am is a stupid brainless human with no understanding of air, fuel, and spark and how they're supposed to all work together. Other times, like when we're in cruise flight with plenty of fuel and nice cool air to fly through, no place to be and no hurry to get there, I feel like anything below the stratosphere is my apple and my Air Camper is my magic carpet, streaking me along at the speed of... the speed of... an Air Camper ;o) > > We speak the same language and we appreciate each other for what we each do to make flying happen. Then when we get close to the ground, we tag-team each other about who's going to be the student and who's going to be the instructor. Some days I can make the airplane do everything but make apple strudel with a crispy sugar and cinnamon crust, and other days the airplane makes mincemeat out of me. We teach each other, we love each other, but we never turn our backs to each other because one of us might just pull a fast one ;o) I have done it to 41CC a time or two, but the airplane has done it to me MANY times! > > It's all fun, it's why we fly these airplanes, and I feel sorry for the pilot who has never flown an open cockpit, wood and fabric, hand-prop taildragger. And even sorryer for one who has not had to try to prop-start a hot little Continental ;o) > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power, 72x36 Culver prop > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=459568#459568 > > ________________________________________________________________________________
Subject: Re: Jeepenpol
Date: Aug 17, 2016
Great news! Hope you can post some videos of taxi testing! -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459585#459585 ________________________________________________________________________________
Date: Aug 17, 2016
Jeepers that's exciting...!!! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459587#459587 ________________________________________________________________________________
Subject: Tail hinges - Memphis
Date: Aug 18, 2016
I've finished three hinges for the tail. Is anyone in the Memphis area willing to let me visit and get your opinion of them? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459625#459625 ________________________________________________________________________________
Date: Aug 20, 2016
I do that as well,...blow up tires w/bicycle pump. I had a small Chinese air compressor from harbor freight, but it just wound up making a loud racket for 20 minutes per tire...was lucky to make 12psi. I gave said compressor to a hangar neighbor...everyone's happy :-) -------- KLNC A65-8 N2308C Slick 4330's AN Hardware Airframe 755TT W72CK-42 Sensenich Standard Factory GN-1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459678#459678 ________________________________________________________________________________
Subject: Hard Starting Cont. Engines
Date: Aug 23, 2016
Oscar, You mentioned that you have a hard time starting your engine when it is hot. Is it a case of it flooding easily? I have a sure fire way of correcting this if it is your case. Maike Madrid would spend 1 or 2 hours trying to start his Aircamper and FlyBaby after fuel stops. I showed him my trick/method and he is on his way now every time without worry. Now on Dad's O-200, he had a bad Mag that we had to cool off the coil before it would restart. If yours is flooded, use this simple 10 step procedure. 1. Tie down the tail 2. Shut off fuel 3. Shut off Mags 4. Open throttle halfway or more. (Very important to do). 5. Pull the prop through 12 blades in the forward direction. (forward direction is very important. It pushes the raw fuel out the exhaust valves. Some folks where taught to pull the prop through backwards. This is not good for three reasons. a. It pushes all the oil out of the oil pump. b. it pushes the raw fuel back into the intake manifold thus still creates a rich fuel system. c. All the fuel in the intake system becomes a fire hazard should it backfire through the intake side when trying to restart). 6. Turn fuel back on. 7. Set throttle for normal starting and idle position. (Very important so your plane doesn't try flying away without you). 8. Turn appropriate mags back on. 9. Prop normally. (it will start on the first or second blade every time. 10. Untie plane and fly away with a big smile on your face. Now you can log more time in the air than on the ground. Keep them flying friends. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459795#459795 ________________________________________________________________________________
Subject: Re: Hard Starting Cont. Engines
Date: Aug 23, 2016
A procedure that gave me good results on my champ with an A65 was to advance the throttle off the idle stop when I shut down. The stromberg has an idle priming circuit that primes when the blades are spinning down after shut down. Taking the throttle off the idle circuit will prevent this priming action from happening. When I did this procedure the airplane would start on the first blade after a couple of blades with the mags off. This was even the case when the engine was hot. I never had a flooded engine after adopting this procedure. Scott Knowlton > On Aug 23, 2016, at 9:49 AM, AircamperN11MS wrote: > > > Oscar, > > You mentioned that you have a hard time starting your engine when it is hot. Is it a case of it flooding easily? I have a sure fire way of correcting this if it is your case. Maike Madrid would spend 1 or 2 hours trying to start his Aircamper and FlyBaby after fuel stops. I showed him my trick/method and he is on his way now every time without worry. > > Now on Dad's O-200, he had a bad Mag that we had to cool off the coil before it would restart. > > If yours is flooded, use this simple 10 step procedure. > > 1. Tie down the tail > 2. Shut off fuel > 3. Shut off Mags > 4. Open throttle halfway or more. (Very important to do). > 5. Pull the prop through 12 blades in the forward direction. (forward direction is very important. It pushes the raw fuel out the exhaust valves. Some folks where taught to pull the prop through backwards. This is not good for three reasons. a. It pushes all the oil out of the oil pump. b. it pushes the raw fuel back into the intake manifold thus still creates a rich fuel system. c. All the fuel in the intake system becomes a fire hazard should it backfire through the intake side when trying to restart). > 6. Turn fuel back on. > 7. Set throttle for normal starting and idle position. (Very important so your plane doesn't try flying away without you). > 8. Turn appropriate mags back on. > 9. Prop normally. (it will start on the first or second blade every time. > 10. Untie plane and fly away with a big smile on your face. > > Now you can log more time in the air than on the ground. > > Keep them flying friends. > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=459795#459795 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 23, 2016
Scott, Excellent point. That should prevent the need for everything above. Great input. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459800#459800 ________________________________________________________________________________
Date: Aug 23, 2016
I do what Scott said, as I turn off the ignition, advance the throttle to full, return to idle when it stops spinning Sent from my iPhone > On Aug 23, 2016, at 10:07 AM, Scott Knowlton wrote: > > > A procedure that gave me good results on my champ with an A65 was to advance the throttle off the idle stop when I shut down. The stromberg has an idle priming circuit that primes when the blades are spinning down after shut down. Taking the throttle off the idle circuit will prevent this priming action from happening. When I did this procedure the airplane would start on the first blade after a couple of blades with the mags off. This was even the case when the engine was hot. I never had a flooded engine after adopting this procedure. > > Scott Knowlton > >> On Aug 23, 2016, at 9:49 AM, AircamperN11MS wrote: >> >> >> Oscar, >> >> You mentioned that you have a hard time starting your engine when it is hot. Is it a case of it flooding easily? I have a sure fire way of correcting this if it is your case. Maike Madrid would spend 1 or 2 hours trying to start his Aircamper and FlyBaby after fuel stops. I showed him my trick/method and he is on his way now every time without worry. >> >> Now on Dad's O-200, he had a bad Mag that we had to cool off the coil before it would restart. >> >> If yours is flooded, use this simple 10 step procedure. >> >> 1. Tie down the tail >> 2. Shut off fuel >> 3. Shut off Mags >> 4. Open throttle halfway or more. (Very important to do). >> 5. Pull the prop through 12 blades in the forward direction. (forward direction is very important. It pushes the raw fuel out the exhaust valves. Some folks where taught to pull the prop through backwards. This is not good for three reasons. a. It pushes all the oil out of the oil pump. b. it pushes the raw fuel back into the intake manifold thus still creates a rich fuel system. c. All the fuel in the intake system becomes a fire hazard should it backfire through the intake side when trying to restart). >> 6. Turn fuel back on. >> 7. Set throttle for normal starting and idle position. (Very important so your plane doesn't try flying away without you). >> 8. Turn appropriate mags back on. >> 9. Prop normally. (it will start on the first or second blade every time. >> 10. Untie plane and fly away with a big smile on your face. >> >> Now you can log more time in the air than on the ground. >> >> Keep them flying friends. >> >> -------- >> Scott Liefeld >> Flying N11MS since March 1972 >> Steel Tube >> C-85-12 >> Wire Wheels >> Brodhead in 1996 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=459795#459795 > > > > > ________________________________________________________________________________
Date: Aug 23, 2016
On my J3 Cub, it was became very difficult to crank while hot. I tried all the stuff like 12 blades with fuel off, etc, etc, etc. The bottom line is that the coils in my mags were breaking down. I cured the problem with a Slick Mag Kit with new mags, wires and plugs. It now starts with one flip, cold or hot, it doesn't matter. I fly my Grandkids a lot, so it was worth the $$. Barry Big Piet NX973BP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Tuesday, August 23, 2016 9:44 AM Subject: Pietenpol-List: Hard Starting Cont. Engines --> Oscar, You mentioned that you have a hard time starting your engine when it is hot. Is it a case of it flooding easily? I have a sure fire way of correcting this if it is your case. Maike Madrid would spend 1 or 2 hours trying to start his Aircamper and FlyBaby after fuel stops. I showed him my trick/method and he is on his way now every time without worry. Now on Dad's O-200, he had a bad Mag that we had to cool off the coil before it would restart. If yours is flooded, use this simple 10 step procedure. 1. Tie down the tail 2. Shut off fuel 3. Shut off Mags 4. Open throttle halfway or more. (Very important to do). 5. Pull the prop through 12 blades in the forward direction. (forward direction is very important. It pushes the raw fuel out the exhaust valves. Some folks where taught to pull the prop through backwards. This is not good for three reasons. a. It pushes all the oil out of the oil pump. b. it pushes the raw fuel back into the intake manifold thus still creates a rich fuel system. c. All the fuel in the intake system becomes a fire hazard should it backfire through the intake side when trying to restart). 6. Turn fuel back on. 7. Set throttle for normal starting and idle position. (Very important so your plane doesn't try flying away without you). 8. Turn appropriate mags back on. 9. Prop normally. (it will start on the first or second blade every time. 10. Untie plane and fly away with a big smile on your face. Now you can log more time in the air than on the ground. Keep them flying friends. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459795#459795 ________________________________________________________________________________
Date: Aug 23, 2016
Barry, You just hit on why my dads was hard to start when hot. We fixed his long ago. I just wanted to share and get folks thinking about what they are experiencing. All good stuff. There should be no reason to have a hard starting engine as long as everything is in proper working order. We just need to figure out what we are dealing with to prevent the hard starts. Cheers, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459809#459809 ________________________________________________________________________________
From: Scott Knowlton <flyingscott_k(at)hotmail.com>
Date: Aug 23, 2016
Further to Scott Liefeld's point about making sure everything is working on the little A65 I attended the Stromberg forum at Oshkosh this year. One other factor that can lead to poor hot starting and flooding is a leaky primer. We only want our primer to work when we want to prime. If it leaks past the plunge bulb we are unwittingly supplying raw fuel downstream of the carb which will both flood the engine and create potential fire hazard. There are lots of YouTube videos showing how to test and rebuild a Lufkin or other primer. The easiest test is to pull your primer line and see if it drops when the primer is in and locked. Just another thought. All great points today!!!! Scott K > On Aug 23, 2016, at 5:29 PM, AircamperN11MS wrote: > > > Barry, > > You just hit on why my dads was hard to start when hot. We fixed his long ago. I just wanted to share and get folks thinking about what they are experiencing. All good stuff. There should be no reason to have a hard starting engine as long as everything is in proper working order. We just need to figure out what we are dealing with to prevent the hard starts. > > Cheers, > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=459809#459809 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 23, 2016
My buddie's 1947 Aeronca Champ with 65HP continental starter was getting worn out, and would end up panting and laying in the shade of the wing before the engine would fire. So he bought brand new Slick mags and harnesses (they come as a set.) We had a lot of airport bum help putting them on and setting the timeing. They would not fire one lick. He announced that he was tired and we were done for the day and closed up shop. When all the advisors left, he reopened the doors and we pulled out the instructions, took the mags off and started from scratch. Sure enough, they fired first blade! It started so easy I jumped back. On my Piet it has newly overhauled mags but they were just stuck on the engine and not really installed. So I have that to look forward to. Blue Skies, Steve D. On Tue, Aug 23, 2016 at 4:14 PM, Barry Davis wrote: > > On my J3 Cub, it was became very difficult to crank while hot. I tried all > the stuff like 12 blades with fuel off, etc, etc, etc. The bottom line is > that the coils in my mags were breaking down. I cured the problem with a > Slick Mag Kit with new mags, wires and plugs. It now starts with one flip, > cold or hot, it doesn't matter. I fly my Grandkids a lot, so it was worth > the $$. > Barry > Big Piet NX973BP > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > AircamperN11MS > Sent: Tuesday, August 23, 2016 9:44 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Hard Starting Cont. Engines > > --> > > Oscar, > > You mentioned that you have a hard time starting your engine when it is > hot. > Is it a case of it flooding easily? I have a sure fire way of correcting > this if it is your case. Maike Madrid would spend 1 or 2 hours trying to > start his Aircamper and FlyBaby after fuel stops. I showed him my > trick/method and he is on his way now every time without worry. > > Now on Dad's O-200, he had a bad Mag that we had to cool off the coil > before > it would restart. > > If yours is flooded, use this simple 10 step procedure. > > 1. Tie down the tail > 2. Shut off fuel > 3. Shut off Mags > 4. Open throttle halfway or more. (Very important to do). > 5. Pull the prop through 12 blades in the forward direction. (forward > direction is very important. It pushes the raw fuel out the exhaust > valves. > Some folks where taught to pull the prop through backwards. This is not > good for three reasons. a. It pushes all the oil out of the oil pump. b. it > pushes the raw fuel back into the intake manifold thus still creates a rich > fuel system. c. All the fuel in the intake system becomes a fire hazard > should it backfire through the intake side when trying to restart). > 6. Turn fuel back on. > 7. Set throttle for normal starting and idle position. (Very important so > your plane doesn't try flying away without you). > 8. Turn appropriate mags back on. > 9. Prop normally. (it will start on the first or second blade every time. > 10. Untie plane and fly away with a big smile on your face. > > Now you can log more time in the air than on the ground. > > Keep them flying friends. > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=459795#459795 > > -- Blue Skies, Steve D ________________________________________________________________________________
Subject: The Jeep powered Pietenpol taxi test
Date: Aug 23, 2016
I couldn't resist taxiing my Jeep powered pietenpol today though it was more for enjoyment than experimentation. I still have many small items to tidy up before I call my /Dar to check it out. I hope to fly it very soon. I wish I could add a photo but I simply can't, I am not smart enough to navigate the email list. Someone suggested I use my email to add photos, What the hell is that ? All I managed to do was get my email blown open with every list here. I cant find away to un-do that, so if anyone knows to remove me please be my guest. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459820#459820 ________________________________________________________________________________
Date: Aug 23, 2016
OK, so first let's take care of the easy items. (1) I do not have a primer on my engine, don't need one, and if ya ain't got one, it can't leak. (2) the engine got brand-new Slick mags and harnesses when it was built back up, and of course new plugs, and everything is perfectly timed and gapped. It's not spark. Now to possible "other stuff" besides operator error. As far as advancing the throttle as the engine is spinning to a stop on dead mags, I've tried that and found it made matters worse because the engine just sucks more raw fuel into the chambers that way and it's all sitting there when I try the next start. I'll try it that way again next time I shut down at the hangar after a flight, but it's never worked for me in the past. As far as there not being a prime circuit open unless the throttle is partially cracked, I recognize most of the intricacies of the Stromberg carb and I am aware that there are two small ports in the carb throat, one on each side of the throttle plate when it is closed (throttle full aft to idle). This is by design, and the outer one pulls fuel till the throttle plate begins to open and there is enough impulse through the throat to pull fuel through the other, and those two provide fuel until there is enough impulse through the venturi for the engine to pull fuel through the main jet. All of this is designed to provide the proper air-fuel mixture from idle to WOT, or so I'm given to understand from all the literature. Some Strombergs will cause an engine stumble or hesitation at some point between coming off of idle and getting to WOT on takeoff, but that's a whole 'nother issue apart from starting. I think my problem is simply technique, and the technique that most interests me is Scott's 10-step narrative. The only new twist is the 12 blades in the forward direction. Like most other hand-proppers, I've always been told to pull the prop through *backwards* with the fuel shut off and throttle wide open, and that helps but there is still plenty of raw fuel in my air box so what I've been doing is leaving the fuel shut off after pulling it through a dozen blades, then just sitting under the wing for 5-7 minutes to let excess fuel evaporate, then making the mags hot with the throttle back to idle and propping it. That worked for me last time and I still had time after the engine caught to nudge the throttle and turn the fuel back on as the engine came to life. I will try Scott's 10-Step "Prop Starters Anonymous" drying-out procedure ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459824#459824 ________________________________________________________________________________
Date: Aug 24, 2016
Good morning Oscar, If your engine truly is flooded (which Im sure it is) this will be a big Ah Ha moment. It has never failed me. One other point that hasn't been brought up and I will because someone else brought up the mags. An A65 if put together proper only has one impulse coupling. It should be on the left mag. You should only be starting it on the left mag. If you are experiencing the prop kicking back and sneezing (if you will, the engine, not you) I would guess that you are trying to start it with both mags on. I have however seen engines put together with no impulse couplings or with two couplings. On experimental airplanes you never know what someone may have done. A series engine should only have one impulse coupling. (it should be on the left mag). C series engines should have two couplings. O-200 engines should have two couplings. The impulse couplings will retard the timing and fire the plugs late to prevent kick back when trying to start. Some old radials never had impulse couplings. They an be a real bugger to start. You need to wear your man shoes when starting these. Oh well, enough for this mornings chat. Cheers all, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459834#459834 ________________________________________________________________________________
Date: Aug 24, 2016
Scott: oh, no! You're sending me back to my books to read up on Continental ignition systems! Upper plugs, lower plugs, gapping, timing... I know my mags and plugs are set up just the way they're supposed to be but I did all of that work more than a couple of nights ago so I've forgotten it all ;o) Honestly, I *always* prop start it with the mags on Both, and I believe both of my Slicks have impulse couplings. However, this is a good time to learn something (and to teach something) about magneto ignitions, so I'm going to study up and report back. Meanwhile, we've got a couple of wildland fires burning around us so I get to watch a lot of round engines fly overhead as the tankers make their circuits to and from the fires. But I doubt that I could prop-start a P&W Double Wasp on a Convair 340, with or without impulse couplings ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459859#459859 ________________________________________________________________________________
Date: Aug 25, 2016
Oscar, my A65 has Slick Mags, both with Impulse couplings. I start mine with the ignition switch set to BOTH. I have no problem with hot starts, as long as I give a really healthy swing to the prop (I can usually swing it hard enough to get it through two cylinders). If it doesn't start on the first pull when hot, I'm usually in for following the sequence Scott laid out. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of taildrags Sent: Thursday, August 25, 2016 12:41 AM Subject: Pietenpol-List: Re: Hard Starting Cont. Engines --> Scott: oh, no! You're sending me back to my books to read up on Continental ignition systems! Upper plugs, lower plugs, gapping, timing... I know my mags and plugs are set up just the way they're supposed to be but I did all of that work more than a couple of nights ago so I've forgotten it all ;o) Honestly, I *always* prop start it with the mags on Both, and I believe both of my Slicks have impulse couplings. However, this is a good time to learn something (and to teach something) about magneto ignitions, so I'm going to study up and report back. Meanwhile, we've got a couple of wildland fires burning around us so I get to watch a lot of round engines fly overhead as the tankers make their circuits to and from the fires. But I doubt that I could prop-start a P&W Double Wasp on a Convair 340, with or without impulse couplings ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459859#459859 ________________________________________________________________________________
Date: Aug 25, 2016
Subject: posting pictures
Hello, I get the following message when trying to add a picture to a post. Sorry, but the maximum filesize for all Attachments is reached. Please cont act the Board Administrator if you have questions. The picture=C2- is only 16K.=C2- The extension is .jpg=C2- Any sugges tions? Thank you,Larry Marquez ________________________________________________________________________________
Date: Aug 25, 2016
Very good, I have seen dual impulse couplings on the A series like you guys have. Which is plenty fine on Experimental aircraft. On certified, It may not be legal. Depends on what the type certificate says. With the dual impulses it helps a lot during starting. Anyway, The fires have been awful all over the western states. We have had our share around here. They are doing taxiway work at our airport and the runway has been shortened from 7201' to 3500' keeping our firefighting aircraft off the field. Note: for me, it means that the runway is still 150' long and only 3500' wide now. Makes it tough in big crosswinds. :) Good luck Oscar. I think the starting procedures will cure you headache. Enough for now, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459879#459879 ________________________________________________________________________________
Subject: Re: posting pictures
Date: Aug 25, 2016
I'll try adding a pic. It won't add for me either. Strange. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459880#459880 ________________________________________________________________________________
Date: Aug 25, 2016
blockquote, div.yahoo_quoted { margin-left: 0 !important; border-left:1px #715FFA solid !important; padding-left:1ex !important; background-color:whi te !important; } Jack, do you have any clearance issues running a impulse on the right mag? =C2-Was reading up on it and saw some cautions about th e shaft hitting the forward side of the acc. Case.=C2-Shad Sent from Yahoo Mail for iPhone On Thursday, August 25, 2016, 9:17 AM, AircamperN11MS <Scott.liefeld@lacity .org> wrote: y.org> Very good, I have seen dual impulse couplings on the A series like you guys have.=C2 - Which is plenty fine on Experimental aircraft.=C2- On certified,=C2 - It may not be legal.=C2- Depends on what the type certificate says. W ith the dual impulses it helps a lot during starting.=C2- Anyway,=C2- The fires have been awful all over the western states. We have had our shar e around here.=C2- They are doing taxiway work at our airport and the run way has been shortened from 7201' to 3500' keeping our firefighting aircraf t off the field.=C2- Note: for me, it means that the runway is still 150' long and only 3500' wide now. Makes it tough in big crosswinds. :) Good luck Oscar.=C2- I think the starting procedures will cure you headac he.=C2- Enough for now, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459879#459879 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Aug 25, 2016
OK, so this is from the A&P who overhauled my A75: "Continentals, if equipped with Impulse Couplers, almost always have them on both mags. If you buy Slick magneto kit for an A series engine, the kit will come with two impulse coupled mags. If one wanted to install their mags piecemeal, you could mount mags with no impulse, the impulse on either the left or right mags, or on both. Lycoming engines come with the impulse on the left mag only. The impulse in the mags for a Lycoming engine takes up a bit of space, so Lycoming adds a spacer onto the left magneto mount to accommodate the installation of an impulse coupling. A spacer could also be added to the right side if one so desired, but would also require longer studs for mounting the second impulse coupled magneto. I've never seen anyone add a second impulse coupled mag onto a Lycoming, but on both A and C series Continentals, dual impulse coupled magnetos is the way they are typically configured. " -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459890#459890 ________________________________________________________________________________
Date: Aug 25, 2016
A little more to chew on... In the Maint. and Overhaul Man. for A-65 and-75, page 47: Item 35-2 Magneto, Eiseman R.H AM-4 (without impulse) 35-4 Magneto, Eiseman L.H. AM-4 (with impulse) This could be nothing more than calling out how the mags are depicted and not indicative to how they should be configured. -------- Mike Perez Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459900#459900 ________________________________________________________________________________
Date: Aug 25, 2016
None that I=99ve noticed. Jack Phillips NX899JP Smith Mountain Lake, Virginia From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of shad bell Sent: Thursday, August 25, 2016 10:34 AM Subject: Re: Pietenpol-List: Re: Hard Starting Cont. Engines Jack, do you have any clearance issues running a impulse on the right mag? Was reading up on it and saw some cautions about the shaft hitting the forward side of the acc. Case. Shad Sent from Yahoo Mail for iPhone On Thursday, August 25, 2016, 9:17 AM, AircamperN11MS > wrote: > Very good, I have seen dual impulse couplings on the A series like you guys have. Which is plenty fine on Experimental aircraft. On certified, It may not be legal. Depends on what the type certificate says. With the dual impulses it helps a lot during starting. Anyway, The fires have been awful all over the western states. We have had our share around here. They are doing taxiway work at our airport and the runway has been shortened from 7201' to 3500' keeping our firefighting aircraft off the field. Note: for me, it means that the runway is still 150' long and only 3500' wide now. Makes it tough in big crosswinds. :) Good luck Oscar. I think the starting procedures will cure you headache. Enough for now, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459879#459879 nbsp; --> http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronihtt p://wiki.matroni <http://wiki.matronics.com> -Mats.com/contribution" target="_blank">http://www.matronics.com/contribution====== ======= ________________________________________________________________________________
Date: Aug 25, 2016
blockquote, div.yahoo_quoted { margin-left: 0 !important; border-left:1px #715FFA solid !important; padding-left:1ex !important; background-color:whi te !important; } I saw a page from Harry Fenton on this. I looked at my en gine and sure enough there is a "rib" in the casting on the forward side of the accessory case that protrudes much further on the right mag than the l eft. The nut on the end of the mag shaft that holds the gear on will touch with my eismans impulse mag. Slick mags may have more clearance thus allowi ng using an impulse on the right side. I believe this is only an issue on t he A series engines.=C2- Shad Sent from Yahoo Mail for iPhone On Thursday, August 25, 2016, 2:00 PM, Speedbrake wrote: t> A little more to chew on... In the Maint. and Overhaul Man. for A-65 and-75, page 47: Item 35-2 Magneto, Eiseman R.H AM-4 (without impulse) =C2- =C2- =C2- =C2- 35-4 Magneto, Eiseman L.H. AM-4 (with impulse) This could be nothing more than calling out how the mags are depicted and n ot indicative to how they should be configured. -------- Mike Perez Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459900#459900 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Aug 25, 2016
So, There are many different configurations of magnetos. If someone without a proper magneto O/H guide puts together parts from several different cores to build up one that works, you could have issues. I overhauled my mags last year. My mags had the proper dataplates on them for the engine. But after disassembly, I discovered that I had many of the wrong parts inside them. I did manage to rebuild them in the proper configuration to match the dataplate and configuration for my engine. One of the biggest issues was that I had the incorrect rotors in each of the mags. They come in different lengths and mine were not correct. Just this one item may cause a fit interference issue whether the gear goes in too far or not enough. So what I'm getting at is, follow the O/H manuals for the engine and accessories for you engine. The little Stromburg carburetors have a bunch of different configurations as well for each engine size. My engine ran great for a very long time with the mags put together incorrectly. It wasn't until I decided to overhaul them that I even knew they were not right. After the overhaul I gained 300 RPM on climb out. Now I am under propped but that is another story. In conclusion, If you are having any issues at all with engine performance, whether starting, idling, full power, stumbling, It's worth getting the book out and investigating your component part numbers and proper configuration. It just amazes me how much I learn every time I work on anything airplane related or otherwise. I love learning from other peoples experiences. I guess that's why I enjoy this forum so much. Just a note here. I am not an A&P nor do I pretend to be. I Have been a mechanic for most of my life and design fire apparatus for a living for the second largest Fire Department in the country. I have also been an EAA tech counselor for more than twenty years. I helped my dad build my Piet and my daughter helped me rebuild it back in the year 2000. What we do here is enjoy the opportunities this great country affords us. We just happen to like building and flying our own airplanes. Lets do it as safe as we can. Stuff to think about. :D -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459907#459907 ________________________________________________________________________________
Date: Aug 26, 2016
Oscar Let's clarified that -8 cases only came with Bendix lunch box mags, eisman mags, case mags (they belong on orange ) tractors , s-200 or s-20 mags. All of this mags ONLY have impulse coupling on left side. Right side non impulse mag. Slick mags have a impulse on BOTH mags. All of -8 mags and -9 mags are right turning mags. Lunch box mags do NOT have a impulse coupling on both mags, so you are starting at around 30 degrees of BTC. You have to swing the prop with authority wood props could swing back. Eisman Bendix S-20 or 200 only have in pulse on left mag . Should started on left mag only. Dash 12 cases C-75 ,C-85 C-90 could usually will have impulse coupling on both sides. If you have impulse coupling on both sides should be started on both mags. Now if you have push to start Bendix switch you have to make shure it's set up wright . There is jumper , needs to be in right position. If you need more information you have to entice me wit few MGD. ( mighty good diner). Louie. Ps a have a ton of small continental pars and mags. Sent from my iPad > On Aug 25, 2016, at 10:20 AM, taildrags wrote: > > > OK, so this is from the A&P who overhauled my A75: > > "Continentals, if equipped with Impulse Couplers, almost always have them on both mags. If you buy Slick magneto kit for an A series engine, the kit will come with two impulse coupled mags. If one wanted to install their mags piecemeal, you could mount mags with no impulse, the impulse on either the left or right mags, or on both. > > Lycoming engines come with the impulse on the left mag only. The impulse in the mags for a Lycoming engine takes up a bit of space, so Lycoming adds a spacer onto the left magneto mount to accommodate the installation of an impulse coupling. A spacer could also be added to the right side if one so desired, but would also require longer studs for mounting the second impulse coupled magneto. > > I've never seen anyone add a second impulse coupled mag onto a Lycoming, but on both A and C series Continentals, dual impulse coupled magnetos is the way they are typically configured. " > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power, 72x36 Culver prop > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=459890#459890 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 25, 2016
Louie, So how do you check the spark on Eismann A-4 mags to make sure they are running properly? Does anyone overhaul them? Thanks, Ray Krause A-65-8, Eismann mags, impulse on the left. Sent from my iPad > On Aug 25, 2016, at 5:53 PM, Louie Bakrevski wrote: > > > Oscar > Let's clarified that -8 cases only came with Bendix lunch box mags, eisman mags, case mags (they belong on orange ) tractors , s-200 or s-20 mags. All of this mags ONLY have impulse coupling on left side. Right side non impulse mag. Slick mags have a impulse on BOTH mags. > All of -8 mags and -9 mags are right turning mags. Lunch box mags do NOT have a impulse coupling on both mags, so you are starting at around 30 degrees of BTC. You have to swing the prop with authority wood props could swing back. Eisman Bendix S-20 or 200 only have in pulse on left mag . Should started on left mag only. Dash 12 cases C-75 ,C-85 C-90 could usually will have impulse coupling on both sides. If you have impulse coupling on both sides should be started on both mags. Now if you have push to start Bendix switch you have to make shure it's set up wright . There is jumper , needs to be in right position. If you need more information you have to entice me wit few MGD. ( mighty good diner). Louie. > Ps a have a ton of small continental pars and mags. > > Sent from my iPad > >> On Aug 25, 2016, at 10:20 AM, taildrags wrote: >> >> >> OK, so this is from the A&P who overhauled my A75: >> >> "Continentals, if equipped with Impulse Couplers, almost always have them on both mags. If you buy Slick magneto kit for an A series engine, the kit will come with two impulse coupled mags. If one wanted to install their mags piecemeal, you could mount mags with no impulse, the impulse on either the left or right mags, or on both. >> >> Lycoming engines come with the impulse on the left mag only. The impulse in the mags for a Lycoming engine takes up a bit of space, so Lycoming adds a spacer onto the left magneto mount to accommodate the installation of an impulse coupling. A spacer could also be added to the right side if one so desired, but would also require longer studs for mounting the second impulse coupled magneto. >> >> I've never seen anyone add a second impulse coupled mag onto a Lycoming, but on both A and C series Continentals, dual impulse coupled magnetos is the way they are typically configured. " >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power, 72x36 Culver prop >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=459890#459890 >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Aug 25, 2016
Louie: now you're singing my song! The engine that was originally on my airplane was a taper-shaft A65-8 and it had a Bendix-Scintilla lunch box on the starboard side and a Bendix S-series mag with impulse on the port side. This all makes sense with what you suggest about starting that engine setup on the left (impulse) side only, since hand-propping doesn't really spin the engine fast enough where the 30* BTC spark on the non-impulse lunchbox mag would get there in time to ignite the fully-compressed air-fuel mixture at TDC. It can, in fact, ignite the mixture early if the prop isn't spun briskly... resulting in kick-back, exactly as you mention. Did I mention that as a mechanical and electrical engineer, I *love* electromechanical machines??!! This is all good stuff...;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459913#459913 ________________________________________________________________________________
Date: Aug 26, 2016
Please forgive my ignorance. Is this the "Bendix luch box"=8B? Semih On Fri, Aug 26, 2016 at 6:12 AM, Ray Krause wrote: > raykrause(at)frontiernet.net> > > Louie, > > So how do you check the spark on Eismann A-4 mags to make sure they are > running properly? Does anyone overhaul them? > > Thanks, > > Ray Krause > A-65-8, Eismann mags, impulse on the left. > > Sent from my iPad > > > On Aug 25, 2016, at 5:53 PM, Louie Bakrevski > wrote: > > > lupchob(at)hotmail.com> > > > > Oscar > > Let's clarified that -8 cases only came with Bendix lunch box mags, > eisman mags, case mags (they belong on orange ) tractors , s-200 or s-20 > mags. All of this mags ONLY have impulse coupling on left side. Right sid e > non impulse mag. Slick mags have a impulse on BOTH mags. > > All of -8 mags and -9 mags are right turning mags. Lunch box mags do NO T > have a impulse coupling on both mags, so you are starting at around 30 > degrees of BTC. You have to swing the prop with authority wood props coul d > swing back. Eisman Bendix S-20 or 200 only have in pulse on left mag . > Should started on left mag only. Dash 12 cases C-75 ,C-85 C-90 could > usually will have impulse coupling on both sides. If you have impulse > coupling on both sides should be started on both mags. Now if you have pu sh > to start Bendix switch you have to make shure it's set up wright . There is > jumper , needs to be in right position. If you need more information you > have to entice me wit few MGD. ( mighty good diner). Louie. > > Ps a have a ton of small continental pars and mags. > > > > Sent from my iPad > > > >> On Aug 25, 2016, at 10:20 AM, taildrags wrote: > >> > taildrags(at)hotmail.com> > >> > >> OK, so this is from the A&P who overhauled my A75: > >> > >> "Continentals, if equipped with Impulse Couplers, almost always have > them on both mags. If you buy Slick magneto kit for an A series engine, > the kit will come with two impulse coupled mags. If one wanted to instal l > their mags piecemeal, you could mount mags with no impulse, the impulse o n > either the left or right mags, or on both. > >> > >> Lycoming engines come with the impulse on the left mag only. The > impulse in the mags for a Lycoming engine takes up a bit of space, so > Lycoming adds a spacer onto the left magneto mount to accommodate the > installation of an impulse coupling. A spacer could also be added to the > right side if one so desired, but would also require longer studs for > mounting the second impulse coupled magneto. > >> > >> I've never seen anyone add a second impulse coupled mag onto a > Lycoming, but on both A and C series Continentals, dual impulse coupled > magnetos is the way they are typically configured. " > >> > >> -------- > >> Oscar Zuniga > >> Medford, OR > >> Air Camper NX41CC "Scout" > >> A75 power, 72x36 Culver prop > >> > >> > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=459890#459890 > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > =========== =========== =========== =========== =========== > > -- Semih Oksay ________________________________________________________________________________
Date: Aug 26, 2016
Please forgive my ignorance. Is this the "Bendix lunch box"? Semih Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459914#459914 ________________________________________________________________________________
Date: Aug 26, 2016
Please forgive my ignorance. Is this the "Bendix luch box"? I was trying to attach photo but I couldn't. It is larger, ignition wires coming from the top, z-wire from the back. Heavier. Semih Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459915#459915 ________________________________________________________________________________
Date: Aug 26, 2016
Subject: AM-4 Overhaul
=C2-Rather than go further off topic on the Hot Engine Start thread, I th ought I'd start anew. Ray, overhauling the AM-4 is not difficult if you have the AM-4 overhaul ma nual AND the A65 overhaul manual. (Both available on-line in PDF form I bel ieve.) The AM-4 manual will get you through the overhaul and the A65 manual will assist with installation of the mag, timing, etc. I overhauled mine with no difficulty at all. /9j/4AAQSkZJRgABAQEAtAC0AAD/4R1sRXhpZgAATU0AKgAAAAgACQEPAAIAAAAGAAAIhgEQAAIA AAAXAAAIjAESAAMAAAABAAEAAAEyAAIAAAAUAAAIpAITAAMAAAABAAEAABABAAMAAAABBkAAABAC AAMAAAABBLAAAIdpAAQAAAABAAAIuOocAAcAAAgMAAAAegAAAAAc6gAAAAgAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAENhbm9uAENhbm9u IFBvd2VyU2hvdCBTRDEwMDAAADIwMTI6MDk6MTMgMTg6MzU6NTEAACSCmgAFAAAAAQAAEnqCnQAF AAAAAQAAEoKIJwADAAAAAQDIAACQAAAHAAAABDAyMjCQAwACAAAAFAAAEoqQBAACAAAAFAAAEp6R AQAHAAAABAECAwCRAgAFAAAAAQAAErKSAQAFAAAAAQAAErqSAgAFAAAAAQAAEsKSBAAFAAAAAQAA EsqSBQAFAAAAAQAAEtKSBwADAAAAAQAFAACSCQADAAAAAQAQAACSCgAFAAAAAQAAEtqSfAAHAAAJ TAAAEuKShgAHAAABCAAAHC6SkQACAAAAAzAwAACSkgACAAAAAzAwAACgAAAHAAAABDAxMDCgAQAD AAAAAQABAACgAgADAAAAAQZAAACgAwADAAAAAQSwAACgBQAEAAAAAQAAHTaiDgAFAAAAAQAAHUqi DwAFAAAAAQAAHVKiEAADAAAAAQACAACiFwADAAAAAQACAACjAAAHAAAAAQMAAACkAQADAAAAAQAA AACkAgADAAAAAQAAAACkAwADAAAAAQAAAACkBAAFAAAAAQAAHVqkBgADAAAAAQAAAADqHAAHAAAI DAAACm7qHQAJAAAAAQAAEFQAAAAAHOoAAAAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAACAAAABwAAAAKMjAxMjowOToxMyAx ODozNTo1MQAyMDEyOjA5OjEzIDE4OjM1OjUxAAAAAAMAAAABAAAAYAAAACAAAABfAAAAIAAAAAAA AAADAAAAXwAAACAAABaoAAAD6BoAAQADAC4AAADwAwAAAgADAAQAAABMBAAAAwADAAQAAABUBAAA BAADACIAAABcBAAAAAADAAYAAACgBAAABgACABoAAACsBAAABwACABYAAADMBAAACAAEAAEAAADa YA8ACQACACAAAADkBAAADQAEAJQAAAAEBQAAEAAEAAEAAAAAABYCAAADABQAAABUBwAAJgADADAA AAB8BwAAEwADAAQAAADcBwAAGAABAAABAADkBwAAGQADAAEAAAABAAAAHAADAAEAAAABAAAAHQAD ABAAAADkCAAAHgAEAAEAAAAAAgEBHwADAEUAAAAECQAAIgADANAAAACOCQAAIwAEAAIAAAAuCwAA JAADAE4AAAA2CwAAJQABAA4AAADSCwAAJwADAAYAAADgCwAAKAABABAAAADmCwAAAAAAAFwAAQAA AAMAAAAAAAAABAD//wEACAAAAAAAAAAAAAAADwADAAMAAUAAAP9////4Q6gW6ANfAMAA//8AAAAA AAAAAAAA//8AAAAMAAwAAAAA//8AAP9//38AAAAAAgCoFuYArQAAAAAAAAAAAEQAIACgABkAXwBg AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEAFAAAAGAAYAAAAAAACgD6AAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAASU1HOlBvd2VyU2hvdCBTRDEwMDAgSlBFRwAAAAAAAABGaXJtd2FyZSBWZXJz aW9uIDEuMDEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPsBAACbAQAAAAAAAAAA AAAAAAAAIgEAACABAABgAAAAAAAAAAAAAAAAAAAA5////yIBAADgAQAAeAAAAAAAAAAAAAAA//// /x8AAAAAAAAAEgAAAB8AAAABAAAAAAAAABEAAAAKAAAATQAAAC4AAAA+AAAAIgEAADQCAADNAAAA AAAAAAAAAAAuAAAAPgAAAAAAAAAAAAAAAQAAAAAMAAAADAAAAAwAAAAMAAAADAAAAPT//wD0//8A 9P//APT//wD0//8AAAAAAPT///////8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAFwAAAAAEAAAABAAAEwUAAAYCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADjAQAAAAAA AJwEAADGAQAAAAAAAAAAAAD80QIA+NECAAAAAAAAAAAAAAQAAGYDAAC1BAAA4gUAAAgAAACZBAAA xwEAAE0AAACxAwAA4wMAAD4MAACxAwAAAQAAAEECAAAiAQAATQAAAFsCAAC6AAAABAAAAMAAAAB/ AQAAgAAAAAAAAAAAAAAAAAAAAFgBAAAFAAAAAAAAAAAAAAAAAAAAAAAAAAMAAAAAAAAAqwEAAAAC AABFAgAAwAAAAH8BAACAAAAAeGMAAAIAAAAJAAAAaQEAAHYBAABwAQAAbAEAAHoBAABuAQAAbwEA AIABAABsAQAAzQAAAAAGAADmAAAAYgEAADUAAAAUAQAAKQAAAAAAAAAAAAAAAwAAAAMAAAAbAAAA CgAAAHMvwZoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAYAAEAAkACQBA BrAEAAbmABQBFAEUARQBFAEUARQBFAEUASkAKQApACkAKQApACkAKQApAOz+AAAUAez+AAAUAez+ AAAUAdf/1//X/wAAAAAAACkAKQApABAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAIAABAAAAAgACAAIAAgAAAAAAAAAAAAAAAAAAAAAAAACKAAEAAAAEAAgAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAACgAQAAAAAQAAgAAQABAIAC4AEAAAAAAAAAAAAACACAAQAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAAAAAAAnAAjAAAAAAAAAAEAAQAQAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAADiMAAAAAAAAAAAAAAAAGAAAAAADnrGQ6p+/TK8c5DZTAiOjYSUkq ALICAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQACAAcAAAAEMDEwMAAA AAAAAAAYagAAAADhABJPgAAAAKkAAAwAAAAMAAAA/+EJnGh0dHA6Ly9ucy5hZG9iZS5jb20veGFw LzEuMC8APD94cGFja2V0IGJlZ2luPSfvu78nIGlkPSdXNU0wTXBDZWhpSHpyZVN6TlRjemtjOWQn Pz4NCjx4OnhtcG1ldGEgeG1sbnM6eD0iYWRvYmU6bnM6bWV0YS8iPjxyZGY6UkRGIHhtbG5zOnJk Zj0iaHR0cDovL3d3dy53My5vcmcvMTk5OS8wMi8yMi1yZGYtc3ludGF4LW5zIyI+PHJkZjpEZXNj cmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgy ZjFiIiB4bWxuczp4bXA9Imh0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEuMC8iPjx4bXA6Q3JlYXRl RGF0ZT4yMDEyLTA5LTEzVDE4OjM1OjUxPC94bXA6Q3JlYXRlRGF0ZT48L3JkZjpEZXNjcmlwdGlv bj48L3JkZjpSREY+PC94OnhtcG1ldGE+DQogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAK ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg IAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAg ICAgICAgICAgICAgICAgICAgICAgIDw/eHBhY2tldCBlbmQ9J3cnPz7/2wBDAAMCAgICAgMCAgID AwMDBAYEBAQEBAgGBgUGCQgKCgkICQkKDA8MCgsOCwkJDRENDg8QEBEQCgwSExIQEw8QEBD/2wBD AQMDAwQDBAgEBAgQCwkLEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQ EBAQEBAQEBD/wAARCAHgAoADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAk M2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqD hIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgEC BAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcY GRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOU lZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3 +Pn6/9oADAMBAAIRAxEAPwD16Dw5f3GNttIT2+Wt3T/AurXMixtblFP8Rr15Y7eOLKqo+iimRKzH ivMp5JSju7/geu8dN7I4Oz+E++TNxdD/AICKNU+EMyfPYXG8ehr1G1Ve/WragZKEV1rJ8JONnAy+ vVk9z591Twjquk4Wa1Ygd6xJmW3zujYMOvFfTVxY290m2SNXHPUVjXHgnw/dbt9imW7iuWtw3B60 ZW9Tenmf86Pl/WNYW3hc7cDFeB+IP7Q+IHjS30W2jkNusgMhx+Qr751L4M+GdRc+YGVG6qtV9H+B ngPQb19QtLDMzdGbtU0MjdJXqSWhFbFRrSVtjyTw34ftdB0q2023XYIkAbjGTW0LTf8AdUn6V6hf fDfTJRutpCpFR6Z4Dhs7gSXDbwK82pkeIlU97r1PSjjqKjoedrpF1tDC3Yf8BphsZY2PmKwr3uDT NPaML9nTH0qveeEdHvOsIX3Fb1OGpct6c7syjmkG/eieFSQ7f4TUkUJZc9D/ACr1+5+Heluv7vj2 rOb4cKM7ZOOtefUyHFR2SfzR0wzGgzzXyT0GfQ0q2bSdOa9Hh+HjeYd8nGe1bum+CdKgx5ibzRRy DEVPitEc8xoRXu6njv8AZ84Ut5bYHtSRw7c57GveX8L6PJEU+zKK52++HNhNceZC2BmtavDmIh8D TIhmlGXxKx5YsJ4CoTRNbu/94fhXsVn4H0m3RRJHvNWH8F6O+GMWKa4ZrSWskP8AtWlF7HiS20i/ KFYD1NAtecYOfrXt/wDwhOisuPKHH61kah8ObVstbMKipwziaceaDTCOa0Z6NWPKvs6rjOaspazv jyozz7V31t8PQkwM0mVHb1rq9P8ADem2qIFt1OP1p4bh6vV/i+6KpmVKHw6ni8mj3yqWaBwp74qu bdo8qynJr6EbSdPkj8trdcdKxdR8B6XdMXjjC+1dFfhiotaUk/UzhmsL++jxJhzjGaFVh/Dwa9Sk +GsZcsshxQvwzh43N/8AXrh/sDGL7J0f2jQfU80ihaQ/KpJNaVr4f1K8+5C2DXplh4I02xwzpvIr etLK3hYLHCoH0ruocOyf8aVvQ56mZx/5dq55QvgfWPLMgjPT6VjXWm3dnI0c8TKRX0Kixqu0oKzN S8P6fqGfMgXNdVbhqlKH7mVpeZjSzeSl+8Wh4Ptx161Iy/KODzXqz/D3TfM3bcZpZfh/pr42rjFe W+GsUu33nWs1os8ikmWBSWWsnUfOumH2dT17V7VJ8ONNfmRSwq3b/DvRYsfuRTXDOImrSaQ/7Vox dzxuws7hYVHksSR2Bqaa3mjyzxkH3Fe72nhnS7dcC2U/hUWoeDdJvl5t1H0ro/1Yny6TVzL+16d9 tDwiNWf7y5qwkTMNoXFesf8ACvNLU/d4qeHwLpsbBvLzisv9W8QtLot5pSPKBY3kiblhY4/pVGbd HN5cqlT3r3y10XTYVEa26kD2rI17wFp2qN5kcYRvauiXDVRQvCd5djKOax5veVkePqy47YFOjhkk OEBJr023+F9uo/eN+Fatj4H0uzxmMMa5o8OYqT9+yRtLNKKXu6nllrpN9cHbHC5/CtZPCOqNCX8k 4HIr1aDSbO3/ANXCB+FXY441G3yx+VenR4ZoxX72Tfock83k/hR4RdaZcwttkt3BFVGt5oeGiIH0 r36TQ9PuG3SQLk+1U7/whpVyhHkgEjrWc+FG9adQuOcx+1E8Q8kSEFo//rUjw7RtGAPSvSrj4crv LRtgHpUQ+HrBvmb8q858P4+Lty6ep1rMsO1uecQo3mYbcfwq35YXPysPr2r1LT/A+nxY8wBvrUmo eA9PnX9wu0it48NYmUOa6v2MnmtFSseTNgfd5xSBWxzzXoY+HOM/Ofaq8vw+mB+Vq5pZBjo/YNI5 jh39o4QKFbtz19KmVVx9a7m1+HW5/wB45xnpWt/wrqz2Y6GtKXD2Onq4peop5nh49TzB4ywxzimr Gw/hyP5V6jH8PbNeW6Cp18B2OOgrZcNYzZ2+8j+1KKPKja5UNtAwab5YHFekaj4C+Um3bJrnLrwd qMJO2MkCuetkmMouzhf0NKePoVPtHMND8oPcURqrZ3cVtv4X1D/nkfypYfCGoOTuQg1zrLsVLT2b +40+t0v5jltYhzCJIlyV9KLM+ZAC3JrsY/At8yssmTVWbwbfWanbGxX6U5ZTjE+b2bsP67QkuXm1 OZmhZlPHasu7s7huI2Irr20W+AINu1UptJuk5MBrL6vUjvFle2i9LmDa2zRx7ZDljVhQqt0xV8aT dSP8sLYPtUw8N38n+rhbJ9qlUakn7sfwBVacVqzP8tcen401rdfQGtc+E9ajj3eS5A9qx72G+ss+ dC4x7VpKhWp/FBiVaEvhZXlh4HyiqkkLNwOO1SreiTgI2aXdnPynP0rHWI+a5CbKQLk49abJYiXI 2kHvWra2d5eY8qFjWr/wiesLbm4W0cge1dNGlVraU4t/IylUhD4mcbLo4RSyk81nzWvlqVYE12Mt ncK22aIgj2qhcQooy0ePqKOW3xILp7HImKZWCrGwzSlXU4+YevpW7PJHtO2Jd3aq26OVcNHx0zVJ 2JaM9vMYDysDnmpcNtG3JNWPsauQVyuKe1myjcua0Uo2M3Tke3rHI23dk1bt4xx1zmmwq/HQ1bjX HJWvt4pep89fQnhjUfw1YUDb71ECT95TT/MOMcit1K2hmx6ptYtuzmn7c/MuKi3nnikMkjDavemp WWwNDnw2VqvIjADHFWY4ifvc1J5K1DV9yo6Ge27P3elCpuwW4q3JGq9BUJA78VnazKT7C4287s1I svHNQ7sZ60bh9KObmXYCUzMejU7zN3ytkVHuGaTd+H0pPz3AmVucVIrelV+e2aVXb3qFa47l1Wxw Wobb6CqiyMevBp3mE4rRysIsbuvQ01mx0JqH5vpSFmo5rhdlhZsCkabdx0qHPrS/dzQ27BfQeo5G anTnn0qorVIrNx1oVlsFzRhNSt26YqjGz+1Shmb3rW5JM20cjmo3+bPy9KcuSOaaU96QJkTAsOlT QxfNzSqqjpUqnHNRbW42xy7eM0fKuajaXb0703d6ZqhEjLubPTFJ+NN+b3FPA28lqV7gMxznNONG R/dpuT68UaCTJN3G2kbd2NID604yClYew3H40/GfpTRIuKPMHamFxdoUjFOHHPemr8x/nUnAFCVg uDSfL05qFjuPI4qVmX8qFGR2pvUV7DMA8ZpVA3CnqtJtHbPJosHMTRsq4HNLuFM2/wAPSmMrA961 UmkTcldh1FQld3WnjJpCqjrTbuF7AF6Yp3yhqarZ6CkIpINxzv8AP93imHG00MGx8uaRRjk8mqbb 0C49QtOaT5RTR+NNb8xTuK5Ju/8A1U0zbaid8D3qu8jZ3ZFNSAuNN9Kqytu5wDUfmccnrShqtSDY jZd38Ix9KBGF5Axin/KKC24UbiuEZ59ql/dyfKy/pUKjBoDENVR0Idx8lrb/AMUa1TksbN+Gt1/K rbNu6mo220Sa2Y4ykupVXTbNf+XdfbihoYYyNsaj8KslmXjqaikh8zvU2il7pXNJk9u0ZXa0a1X1 Hw9pOqR7Li2Uk96kgVgcYNXlKqtaRXNG0tURzyi7xOVh+HGgwNv8kGibwXoMfS3Xiulkm9Ko3B+U 55PtXPLDYeO0F9xtHEVXq5MzbHS7G1YLDCqj6Vv24j8ryyox9KzIchquRs3UZwK1oxUFojKpNz3Z BdaBpdySZLVCTWJqngHSb2EpEvlsehFdOZPaommVa1qYejVX7yKfyHCvVh8MjyLWvhzfWqlrdPMV eeBXOt4Z1Xay/Y29Pu17vMwbPSqVw1vEpeVkHrmvFr5FhJy5o3R6VPMqqXvanhy+G9WRG3WrgL7V PbeF9Yutvl25G7ivRNY8deFdJyl3fwA9McVxl58c/BumlvJuN/stc39g4eO8maPM5JbI9EtZl2j5 auxzVmwc8LxV+Haqjd19q7oO0bo4S2kjd/5U4sBzVfzMDCryaEBb5maqv2JfmTFi+egqaJfl681E mwZxUit8v3sVSaRJOpOKXfiofMxTfmP8X41LfULEjNu6c1Gy+9Jt/wBqnbW7dKNxkflrkUvB4p/l 45zRspOOg73IyFpQV+9605o+frRt2+9ZvXRjAMOPlpQGz6VIFTHpStjpmnawEe3vTvej9aXcAu2k mAvTuM0nejr0pDux8tPQew5QvFK3WhV4BoPzAihKwk7C0ceo696RRTsfLxVWvqK44MF6/pUscm7H NV6UNyOaSYF9ZVPel3c8VUV/fpU6NuHWtUyR2Wanjc3U0qKMU+lox37EewZznNOVR6UrfpVa81Gz 0+3kur24jgiiUszu2AAKiTUNWwWpa/Smsw9q8J8aftUeF9IM1r4ZtX1WdcqJM7Ys+uepFeKeKv2h PiP4mkbZqZ06D+GO0+XH/AuprL23P/Djf8F/n+AXS3Pt5riMcmRRj3qJr60X71xGP+BAV+fL+NPG l026fxNqbbvW4fH86py6prTcy6xdsCf4pmP9aXNWfRff/wAAXMj9Df7Y03P/AB+wZ/66CopNe0mP 72o26/WQV+d63Wpbt326446HzDxSeZdn94bqZuvzbzxRav3X9fMOddj9C28UeHYf9frVmn1mUf1q I+OfBked3iOw46/v1/xr8+D5zfO8zOfUmtVfCOvS2kepPavDby/ckf5Q309aHKrH7S+7/ghe/Q+8 V+IXg1k3r4isSucZ89evp1ob4heDVHzeI7AD/ruv+NfDmm+B/E13kaSWmkP/ACzjbk/hWPqOn6xp tzLY6oLmCeI7WjkBBB9waIus1dNfd/wQ5rdD7+j8eeEXC7PEWnnP/TwnP61P/wAJh4b4265ZHPP+ uX/GvzmkN1G2FnkPGMbqjMl4qkqzAnvnkU/3/dfd/wAEXOux+jo8YeHGYKNbsvm/6bL/AI1N/wAJ PoCEL/bFoGPbzV/xr82c3i8rcvkY6n+tRfbtSaZpzcOZM9S1O1fuvuf+Yc67H6aQaxpszfubyF8d lkBxVxZdwyuMV+a2m+MNe0tla1vJd3fDEY/KvTfAv7THjDwtKkOrTPqNmeNk5y4/3W6/nmnz1obq /oLmiz7c3tTs7uMDFea/D/45+DPiBGItPv1gvgMvazHa4+nr+Fd+t98o6VpDERns9R2LSgKeOKdx 1xzUPnhsbaPMHJNa86ES7hj0pjSDGajeZahaYHvTcwRY83BpjSfSoBLS7vXFPm0sGw5mzmowqnNH 3s/NSDhsU+bqDF/DpRwKXHHakb8Kq7EI3y496FbnvSjBpdvpxRzBsKNv0pG56cU5R8vek2+neq5r E2uRlfrTkh3dad5bdmFG0q1UhMGhH8J4oWPHWnbuuc0jPtHFNPsIb8q/dxmh5PxpO+496Q1V2CVx jE4qGRfrzVio5NzHtTuFyJdo61Orrt6ColRm7ClZductVwuJ2HySbfmqhLOVUnNSXDbV3VzupX8j SbeijqazqyknZmlOKZa1TVorK3kuJJAkcaksc9K+cviV8ZNR1C6k0/RbgpAmQWXvXV/Fzxg8ehz2 NnIct8rnNfPMIa5uERm5dsUpNKKsKbtoSXl1fXjGa6mkkJ5+Y5qnJBPcRt5asPfHSvdvCXwssdQt YvtClmZQSeuK7a2+CHhtU2nerMOa1hTi4mfLJnZws39auxtnG7NV0jKgfKOasRR9fmxmvJjtsdvQ sK+44xnjrTtxz71GCqN8rZNLu3dOxpkskXP5VIrHO4E5pir+Ip49xRqh7EqtknrS7v4cUyMgDmpP vdKaFawZ+tSZzUY6Yp659MUMVxyndSHr6inY9KFx3xg0IQ3NG39afxSbvYUpWaGhm4rnd+dLk/e7 UrLvJpqr2rnd76lbjo23de1PwO9NXr6Z9qX0qk+YBM9qd7/pTSue1KqMPvZ9qNQuxd3TqeaWm/0p fmXmi4CgcD2pQ2abk/nShaqPaIhzf73SmY54p/5/lRjb3qnqhbCAsualSXb1/wD11CfvU5R03VN+ w2WlmOBxVhX4yKobvl615J8Yvj5p/ge3k0bQXS71hxtIBysHu3qfalKsoLXd9BW6nc/EP4p+F/h3 YNcaxeK1yw/c2yEF3P07D3r4/wDiN8YfFHxGu3S6unttODfurWI/Lj/a9a5HWNc1LxLqU2q61fS3 VzM25ndun0qqsXBO4AL+tZqDm+arv26f8Ely6IOFHyjNVby8WzCqIJZp5TtjhiQszn0AFb+m6baz gTalfQ2VsBne5+ZvYAVr6v428M6G0lr8PtJYPsVf7QulBmz/ABFR/Dk1pKSvbr/X3f1oJK+5ytgu oMxXUrN7Ir/yzdgXH1A6fjRfX8dqzRQwFs/xMf1xVC4vLq6kM1xMWeQlmOepPrUO0LGiuzdc+vFN Jhc0rfW5YWdjawygrtwy8D3qTTtctVuFi1DTw8LnBZOGWooVtmtAYLd2YNyxIrP1HbC32gRiIY5X Pf1qnIVjS0fxV4X0nWTN4kvrWOxgYt+9fZvIPC8nv3rofHP7SXhHxD5NvD4gsvLtowgEbfe9OnAA 6AV82WMP/CYarqVneEebFdyMFbnC5Pb2FC/DW3klli+2uI1+Xds25H0PNeRNe1qqTlZrobxbUeVL Rnr2kftOWvg3WIdU0nUFke3cSKq8g47MD1rqvHH7RHhb4vzDXo7q1j1gLtkhICMy/TjcR61853vw 2sVb9xqWAMfKVHNR23h208Lx3GuXVyd0ABhUoDvb0yDxW0IXq86lqKXMoWtoe5yatHNDbtawgHZu Zm5Lk81S1DxB9jt3kvLqGCIclnwoA+prz3TfG01n4T02RLf7XqV5HstbcNjzMDlmb+FQOSTXn2qf 2t4qv1NxNJrF3/eKkWsJ6bY4/wCLH95utdXtJWSWr/r+v1MrI9ab42+FIbgwzXkF4qLtBghd/wBU GCasWfxR8D6ooS1vmtpufluo3iTP+8wAH415fa/CjxBfx/6XeLCP7m/AH/AV4FFx8GdYhHmWd1Gz DsshU/hVKnWaupf1+f4i5o32PYtG8WWOqXR0+WFrW4P3NxDJKPVGHDV0MkKrGflyQOCa+aN/jbwP MNyuyLyqTLlTgjkH8K9z+G/xK0X4gR/2XIF0/V41wbWVsCYD+JCf5GiNWVGXLW+8fKpL3DegF1Y3 CX9jPLBKh4aNiCMelfQfwh/aZu7DyNC+IDGe24SO+x8yD/bA6/WvDJrdoW8tlZT6VTmiUNtByRW1 SlGeuz7kRk0fozpesafq9nHqGlXcdzbSKGR42BBFXPNdvvDivhr4UfGbXPhvqAiZmu9JlYedas33 f9pfQ19neDfGWgeNtFi1jQbxJ4ZB8wB+ZG7hh2NTGfLJQqPX8/67F3vqauxpF6ml8tgKmGF6UNtx iuhKIrkAXnntTgh98VIFH0pcH8qrQV7Eflt1znFAjPtU31prYxTslqFxu08ZHSkPI7cUu6l+vSnF 3FcYqqc+tK2d3BNSKF7UhXAPWnuFxi7geRzTwyj5WpuM/Wl8vvkU0+wXDPfHWmNu96lXHPI5oYg9 +lPViXmRL82PWnfxBdvPWjAVj70rNjHcDiqj7om7ifdUHv3puc5XpR/silC7ead+giMj86jkaRT0 qfH+NNIBprXQZXWRh2ORTZJM9aseUPrSNEpz701CQXRmXLOxKkEj0rmfEC3ENnNNGuMKa7CeMVj6 rCs1nLGyghlNaeyUrOTKjO2x82+JF/tC3uoZRl2yRXkqs1neYbgxvn8q961vS/s95Iu3gNXNeJ/h jFqWlnWNJwJ+rxjv9KynRlGXLcS99abnsfwf1KHV9BiuI9pKqAa9E8lD/D+lfH/w3+JGqfDXUvsW oxP9kZvnU/w+9fT3hz4geH/FFql1p92jbl5XdyK1o1or3Km4rvYsdBx0pTKq+xqJVO0c/rUqx7l+ Y15bWl0dSJVZuOpqSNeBTI1x8tToOOnIpptIEPUbfrTl60wNnHzZp5X5c5A9qT7gOp3am8qM5/Kn Y5OOlQpCBTzUqsRj0FMUegxS01psFiTcPu0qkY4xUe7p1xSgbqL9xD89PWnDimquMmpN2aS7C2Da Pc0LHRnt2p6lvTikknqhibP4jim09mwKTpTcbjQlG2lx27Uu0Yqbdw2GHmj1p23mgj9Ki0tx7jfS l28U3a2e9SRq1SnbQNgBzxScnnt9Kk24B9aTbwMdqvW+ohhX0+tHP8QFP+7XkHx3+MMHgXSzo+ky h9XvFIG0/wCpTux9/SoqVY01bq+grdzL+Ofx0j8LRS+F/C8ol1SRSs0ytxbg+nq38q+Uria6vpnu rmZpZZWLOzcknuSaZNdXeoXUtxdSNJLK25mY5LE9cmrFnbzTTCGFC8h/hAyaKcHF80tZP+tCG77b CRQKpAXDE0ya6WFniChn6Zz92rGrXFra2UVrbRzLcvn7QZAABz8oXuOnNYuGOTgn6Cr54p2uDQtx ceX80sn5mo47uFjuWRCx7ZrRuGtvsyw/ZwXA+91zXG6wLRmfbCUftjj+VTOdSOsLWGlF7nVJNbs3 3ASO27imMzS/e5J/KvOC2qQtuhvpx6fNn+daGnat4g3iP7UZMnABTJP5VksRU+3D7n/wxfs13O4S S4hGI3IB5rNvpmmkb5ixHc96uQw6lDp63GoReWz9DjGaznwGOW610Rkpq9rGex5b4kt9Q8I+Jjr1 iX8m5beSv8LdwfrXXWfjTQtbthLNcLazEfMp6Gu2vvD2gNptkt/OLuW8t/OmhA2iAmRlVSSOSVCv x0DjuDVGb4cfDG80dLeXTL+1vjIxkuYpQRtOMYU456965KuBjVlzxlZ/MuNXlVuh5NrniNBcSLa3 DS+Wcjb0I+tc9Pda14nuo7N96QcEk8KF7sfQAV1V34Jbw3qV1bCYzJG20FjjIPTj3GDWpo0mm21v e30kMbw2UaqVb+N2+6p9uCT9MVlKMMNGU57o0V6to9Cla6FHJpqaprM0trb3EYjhtEX960A+5Gf7 oON7epIHQVq6eZLGEQ2dvb6ZHLwnmfff6k1Rgv7rUJDqF7I0lzecx8fcXJ5HpXS2vgXW9Y8MnxDH cC20xLhrdbiSQZkkUZbaDzgdM9zkdq5owlOPtsTKyfS9l8+5tKUYS5YK7KNrqOp+Yn/EyjGW6OmB j34rbstQu5LhLe6tWRpP9XJH8yP689qydN8E3WsTf2dpOtLPdsDshdgpk9lJA5ri/FHiTxLot7N4 RjjudHn02Z7e9WSPEyyqSGU575rSkqTf+zzenZ/oyJuVv3kT1e+s4bq3a11S1Ekcgx8w4IPpXlnj v4e6h4NvYNa0eVscTIydYSeQpx3rr/hf4s1jUtN1TS9bkW9hQDyZply8b4ZvlI7YX/x4V1MlzBqx uNH1KaFxNH+9tWO0qcAo8bdGOOx9a9NV41IqnUW9zklHkd0Wfh18RtO8XaHbQ6t5nnx/uZXVc+W/ Y+uD+nI7V1F/p8dvJ5lvcJc27fdmj+6f6g+1fPngu4m8KePPsNyCkN7KY2Vh0cH5ePrgfjXvkMLw q1xbSBbZDI8yt/y0OeBjsaqg3FOnvYJtP3inPHszxwfSum+GXxM1z4Y+IE1SwkaSxkYLd2u75ZF9 fYjsawv3F9G13YljF0YN95T6GqzQoVKnj0rapTjUjyvYi7R+hng/xlovjbQrbXtFuRJDOuSv8SN3 U+hFbMj/AMVfC/wd+JV38MfECH7VLLpN4wW6t+oHbcPcZz719u6Tf2esWEGpWMyywXCCSN15BBrG k5c3s579H3NLpouxvuI64qYcgURxrin7RjrXUo2I5rke1sdfalxQ2e9NaTB20J2CwoXv60ppitR8 3vT9ADcy/hTuoNN2tS5ZR0ppgH8VLnjikALc9KX5lHtVLQQ1d27b681Iq8e9M3fxcUu49OlaIVxf LHPagR8e1Ozjv1pV3cehp6IQ3ycfzqTycDr+tPCd+9ObpQtBFRosfWomTmrDt/k1XZhzVJgwKt9a jKtxzT92e/FL6mmrDK08e7oc1mXFuxzmtdz1qvIm6rVnuNM8+17wat9vkjXDHmuNmtL3RWa3kVth 9K9mmj256GsHW9Hh1CNsrtfscdarkhL4itXseI+JvCek+IYSzKqTngMv9a89/sjxZ4FuDqGnTS+W jfwng17Vq+hTafMdqnk9Oxpllbw3Sta3ESyRv95G9Kp0Y1NJImT7nqKqu0YHIqRd2Pl602NVXHt7 1IqlmIJ615dtEzov0JI+nuf0qYDjvTEVsj0NSqu7motfUpMQdfalDgCkZD/DRsPfOKlx10GShs0u WYjtSBcfWnLk96XLci4/dilyBwMVEOo+Y80uefahXAkPOKfkDjnNMU/xelKFOcVTS6E3HFi3fij5 uPShsY9qFyV5qHpuF7Dx975uPSpB+OKi6Uqt3bNCdtRpkjMuc80ueaZyRQD3p36Bck9fQ0jHikH6 0Z4OAaJJMYkeR3qUbT371EG9OKVR71MdBk3yrxxzScCmKpY+1OYKBy1CQhwHvUN5eW9lE011Kkca 8lmOK5vxd8QtE8KWzm4uFefHyxKeSa8A8bfFDWvFUhXzXt7VR/q1br9a55VL+5T1f4IfqehfEr4+ ad4ftJYND2zy7cCTPAPt618k+INd1LxNqs+q6lcNLcTtuZm6/wD6qm8Rat/aN037zEMIJyTx9a5v UPEdnHAbXTbXfNuH+ku3QegX69z+Vcs60ML79TWX9fcNRlV0WxJqetafoEcLXkrF7iQRxxhcszHs AOa318UP4Xk8nTbSGe6nUbpjgmLPYZ4zzXER3ge4hv7qGOWeAlo3dclM8HHpW1Z3mmyrLJcWhaXb uRhJwp45I7/SuaWbU0nzJ/IpYeReWW7uNSZ5MTMzZO8ZJNdhp/iq80b5W0DSLlPSa2B9e/Wsfw3r MOm3CXiwxmUf3kDZP/AuK71fiR4Umt0j1jwrbzELtdo4VViduM/KRXz2InQqL3pyT66P9Gd1Pmjq jkNW8cafdsWuPA+lLlSGaEun5c4//XXJ3WseGLiQfafD7wqeuyTP8xXo9/48+EflvazeBZERv4lm ff0+pxzWCv8AwpbUmCrc6pZsx5DkHb9OO1b4WFNL91Wa9bkzbfxIzdF8M/CXxAyR3Pii40eV3ABu LRnjXPclMn36V1C/Cm08P4vtD1TRtct92Fltbgbzzx8rYI9fxrmvHPw703Q9PPiLwd4qttY06PAm 8vCyQbum5c5I9684uPiVbaPmObVU8wcbE5IP4f1rujPFU2uWopL7/utqYOVPZxPRvF0jxwpBPayQ mM7mVlxxXGxss1wq4++2K828T/Gy4aaRo9SkclQoSQbh15/yK4hvixrzOPJvEVd2R8oOO/8AnNen hq9Zr346GFRRifRVxNDcD7RH88agYIOflHHH5VNHdxvGskZyc44brXzHb/FPXLNRAmqSRLg4A7D6 GrWl/EvUNPugsV8Vjky+do+fPrxXZ7eSjrEytfqel/GLUbq11e1liBaO/t0TCjoyZXj1wAK85i8U atpnh0taLFcR3V1JJNHKoJbGFGG7fdP5mqviDx5e69JCuobW+z5Me49j1HH0rI/tq2iiWx+zgJkt tz0z/jWNZ+0tyqxpBqOjOitfiNDYyLcX2jzKY1B2r0IwOAe3BFenW3jy68TeFdGjE5SzijZ4reM/ JGScYx6hVVc99teJvqtpc+ZLLCmHXa3PAOMflVy38TrpuniC3Z02naoXAAGBjjH+c1y4uj7eKt0Z rhpqEryZ7Fa33kyxzRyGN4z8rjgg+ufrVD4qX1j4k8WP4u8V6wkM1/p0c19MseZLq4EhThVGN7IA xJwDg5OTXla+MrqRUYXWQjHgt7/rSSeJP7UnEl3cLLKFGCxzjAwBjtxWGGwcqFXnb1Nq1VVY2R32 k+LPOksLHR9M+w6c0nlhnOZZvVm9zx+WPevUpvJvLm+tbWxjlvYWjblyGaMxoOMdwf514VpmvRtP bBkREt/nUN8vI/n0rtLX4kWd1qTapDKIZmwcbsjoBtJ9Diu+n7uI5o7WOedP92rFf4h2F3pl7b6g 7xpcQlGVY5d5TB6k+tew6br0d9pUGuRwotvdQqzRtuYsxxkjtXmHj5tK1jweNc0dAZBcKtwm/wD1 GR0I64J71s/CXxBb3XhePTXvvInt58AMu4MpOQvPT7wFdfNH2iaejMErxsen2sz2lxFeQq09sQMp HGNrLjlTg1ka94isdL8SW2kyW7JaX8e60uG6M/dD6EdK0bC2TbcWljLLdKGM1wq4UxE5I2N1PuKy 9a0zS9c0mbTWvGlWRg0MzqRLBIOVPtyPxBNda97S5nLY2GSM4KLjv9a9l+B/xuuPCUi+G9eZ5dOk b9wx6xknkfSvnPwb4gmvBP4e1oBNY05vLmUdHHZx6gjFdN5kkbKyMRtOR7VEo8/k1+DBPqj9D9G8 Q6brVstzpt4kqn0PStPzBt618ZeA/HmrafGl1pt06PHgSITwfwr3vwX8X9P1rZZ6sRbXJAG4n5Wq VVlH+Jt3/rYpanpzTj0yaTdux2NQRyRzqHjkDqehXvU+3+Vbq7VxbC7sccY+lODLzjFIqk9RipNn bH41Si3qG4isp9eaN36U9VVeKQqu7kdK0USWxm73p23K+1Sqq+lO46U1G24myoxCtg0u5eOKfLtL HcKiVe4pOVhrYmQbsDNWY4xxVeHrVtelVFiaHbQV9ahcHGKmDdaY7L7VW4ipIrVWZfSrcpB79KrS N8w6cU9AuMAbt3o2tjNOVlUGn7127fWnHl2C9yu8EnXNMaBmqyX+U9wfeo3Zh71ouVDTZB9l3dcG ql1ZL93bV/zHHbIqtO0j9FOfpWsXBboSTMTUtDtruEqy/Me+K8/1fTX0m6LqhXac5Ar0yZLgZwtZ 2pabHqEZjuIjn1rohW5VaxXs+bdiruU5I4PSp4xuwzcVGnIHFWEK49a8GfNodK1FjyON2c09W2nF MHyt3NDOdoYZBrNy5dx2JvrTtp61AJNy5U81IrEKAOtHNzIGh2C3HccU9Vb+LtSfN13Yp249Bz/W lawugbeKVdobntQF+tOKgfNVJ21JH/KOaOOcE4qPOAc0oZdpqbpi2FznilAx/Omr6+tSKdw9DUbs A3c0qlelKFx/DTwvfbVRQBux0pN24insuBx3pm3vRJ9xrRgF9DilZSaFGPQ07eFoTugGMvI3djSg 9elNZsL+tc5rvjGw0tWiWdDIOvzcD61lOahq2Nam9eapZ6bC1xeTpHGoySxxXkHjf42Nuew8P9ME Gb/CuI8eePrrWro2sF286q3O37g+lcbulk+8OfWsVzVfidojvYm1DU7rUrh7m6meSRzlmY5rm/EW pDTrJo42Pmz/ACr/AI1vrFszuOBXmXjDVprm9mkjU+VbAqjdQT6/nVzcYQtEnc5LWdSluphZRv8A IrYYjnc39aqQWNwZxH9mk9d2K4LX/G3jTwvrksllYwNbwthFli+YrjruPqeenpV7wj+0Jbx6xDNr 0Ys51wcsm+Jz7kdAfcVxU8NSre9WTu9ypVXHSJ2VwstvIIZkZdw+U7eD9Ku2bbVKf3sD/P5VsfFX xZo/iLTofFWk29law6grTQxWbZhSRApwhyeDk8Z45ridN8QRXl1aLE4CyruP8v8AGvEx9D2M2o6o 66U+eJ6Da7VVP9lamkZtp+bIAqqJI4bcyOwVVG4seMDvXl/j74vWtipsfDs0c84PzS7vlXHGB6/h XkUKc8VU5YK/5G0pKEbs7DWL63tt8txKiIOctwBXnOvfE7R7YNBY5nY55wQOK801/wAeatepN/aF 55rOc+gHbgdq4q+1K8uAN024EfKO4H4fjX0eFytU9aju/I46mI6RPQ9Y+KuvXVu1ut49usispWCQ 4dTj5W9e/NcPe61cFXYzj1C5zWr4N+GvijxmrmxsTBAq8zyNsQHPHXr+FevaL8APCuk6ekmvXr6j dKoaRVO2MN1wO5+vFdtStQwlk92YpSqanzzcX0l0Xb5uSCAtSaba315I9rDbNLkZb5sfTmvRPHOm 6PpLSro9jFBGGxwvYe5rhNNnlhmkmVirlhiuijWjUjeK0M5R5WRXekaxar5l5a4TAXk/4Gp9D8Pa 94s1A6dpm2WWFSQu4KAq9SMn0rqbO/j1GBreZMyFfu+ta3gbw/Louuwa9BPhBceTOg/gDgAH6Ek/ lWjlGPxAk3ojAv8A4Q+P7axe+m09RHbxmR8TL8qKMk4z6A1xxuLiOY/aVYkrhfmzgds19lxhZo2h kGI7iN4ZN68FWUg8fjXybdWEkevXWnHCSw7o2b1K8Y5+n61tKK6IViHS9L1e8lWFLF5d6GQLnAKj r/SmTWWoJcyW7IRJG3zJu6Hjiuhs11DS7eKaMvHG4O8KxDJ7j/CrEnheSRxdRzbjIAwfuc1xzqOl L3l8zWMOdaHNx6HqTR+eqlN3OD3/ABqqtrffaRCq7mySTG2TXYp4Xumws1zKUzwNxrd0fwlBHhlh wo7+prOpjYxNFQkzzi6k1S32x+TMEU9SvXPr702z1y4tZDHcbvl5PbkY/wAK9jt/D6rOjSRq67ge RxXLeJPD+japrV5M9t5e+RsGPjv6UqWLjNakzoyizK0fxg237PLMWjk+XaW+8fU16j8LZtFvP7Qs bjUoLVrhUaFZWxubvz26LXhWsaDcaLI0yFpYd3DLwV+vpV7w34ourVvJSQK54UjGf1rrvpzU/wDg EJ9JH1vYzapagPHcEyRssMmxgRKqkFTn3HBra1K7haMyssSTz4zFH0RR0/GvG/h3rd14iuhYzGNS I/k5xkjjnHtXoNwy6Vf/ANk3UirchFcLu5KkZBx9K66VWL62fYzkmVvE1teWd1a+NtHXNzYDy7tB /wAtYO+fcV3lleWuqafFqFswdJ0DDnpmuatJlZjDMoaOVSjqehz61F4Hn/sPUrzwncqQqt9osvm4 MTE/L+FatWal9/6Ge2h6H4Zvzp+ohXZfKnwpGeh7V3uWWTcrdOhzXlzqy4lHykHIr0HQ9QXUNPju C3zqNr/UUpafMrc9I8IfFHWPDckcFxI11ajgqxyQPavd/C/jLRfE1us1jcKXI+aMnkfhXyh1xtyB V3SdWvtIulurG4aGRTxtNZpcmtPTy6DTPsdQqjdTiua8h8D/ABit75Y9P11ljmPyiTs1emxX0dzG JIJFdWGQQa3hiFLRaPsDiXyyqPSo/OXPWolWSTvxUy2/rmtFKTDYZ53Xb3pplb+Gpvs4bt0pFQDP Ap8r6sSZF+8fFTRpyOKVR/C1TR/7op8qW4hyRKORjNPAIpyrxkmlACiqENx6VBIDtNWOOmaZIq7T TWoiiRx1qIxndt9Kst97FMPy81pyJhdohELflUnlrxTtwxSY96aSJuxGjHWomXnvVgMPamsqnk1r ELkHljGcVA0bdcVYf5f4qiZ+D0FXGyGQ7RtOetQTRKwOQBU7HuetQSNj1rVTKSMS3Vv73vVkZAGc jH60xQq9+amUdN3Irw+m51oZ5iq2D1p75ZcLTjGp7Cl2rWcuwMYse3huakVQv1pwT/Zp+3n+lR5i 3BcgdO1KF/i5pQv94GlHUelXcQAfKaXawpy9fl70/wBTU3B9hm0t7ULH/wDWqULnrT8KtTd2FYi8 vt1p/l/LmlDRhvvA4oa4T8qaGxwTpR+VRNdLyN3SqjahGuVMg4pOwkjQaRenamNN6dKyZdXjhX72 TWbeeIsFdj4qZSURpM6XzV2ks1VLzVLSyia4uJlVEBLEmubutdfy+JMHvXjfxC8bX2rXEul2MzCC Lhtp+8amdW3w7glbVnU+OPi+03m6foc4RBwZh39cV5fdao15h5byWVpD83PWsFpFWPzrlgFA9a56 68dafb3X2W3VpAvXb2qFT5ZXlq2Ju6O2ea2jJVYdwHf1pPtcDKQsOSPfpXP6R4gj1FebeWM+61om 4VY2McbSBuhXpWlhXI9f1SOx0u5mVQH27V57mvGfFGoTQ6TIwYqzuoA9PmB/pXe+Nrjy4YrVcZkO 9gTXnXjCEto6twQkgP07VhX0pyaKgrzVzzXxVcNBarqlvdOq8pPHvJGScjg5HUelcGuqeBdQv1h8 V28tqrgq13ZJ86ZHGY+Awz1xg812niXw6mr2rNGdkqcq3+Nee6t4K1LULhZPLjXaoUleM4A5Irmo 4mP2nsXVoST90tiPQ9Mae38N+I5dRYT+VC0cLxxyQ4OZCHAIP3eCO9b3hrUL6PVLp45hHHaKgLN/ Dxk03wv4Li0e38+4/eSt94tXK69rjWbXtvbMQk0paRl43e34Vk5wxNV2107D5HRjeR2Pjb4tapq1 umn2rGK0CKsgXKmX1OewJ7V5ld3qzXJjWTIjbzMY7cHFZAvpLq6KjO3OMd/yr0XwPoehw3KSaywu rh4zJ5QHyx8fxH19quNOjgo+6jO8qrOatvCeva0yXE1m8MJ+5I3dfYHrXqHhP4Z+HbGWK98s3EgQ czjIz3wOlb14tvrXiPZpoZrSDy4IUAx0GDx9c1cs2VV2qcbBisMXiLx5aLtqdFOlb3pGzDcfZI3g hwkfTavAAqveXi2tnIzMchTzWW2pKkk27I8vC8+vWs+41JbqCVY2yzA964Vzc0V94TR5j4xvGuBc JvY5Hy+ma5KG3vLU/wCl2skTn5sOuCRXUanqn9katb6lJCkws7mOZo3XcG2sDtI7j1Feg65cWvj3 TmF5cRSvMPMt7orgxN6fKOF4xt6DtXt4aKUbHLLUyfAdj4Zn8P77/SlnuZpnWS48xg0QwACoHGRy ec9q5ae81nTfGEGhrcHyTewrMBwHEb5B/EHP412PhXwvNpNv9kjuWu7q6YMYI1yqcdj3J78Y4HNa 11pU1rdfbLrRwtwFC+a8GWAHAPI4Pv1rq5Ode8SdXoXiC9uPNivpnnAkEqhj0Jzn88D8qyda0HQt N8Xarr13pFnerqeyW0G47VjYAvuAP3twKj2z7Gsm3u7yzkLRsys3DfL1+tJNfTXE6yXDbguB6cDt Vc7QWuYPiay0ibWrqbSbdo0L74rdZN/ljj5PfHPbtWUsuraLfxTX1jLDp9821WkUhQemQen1rsG0 HwxDqQ1q3Z2kR/NS3ZSVZyc5bJxgHnHQ1zfxh+I18/h1PCs+otczSXC3YWT5vIAVl4z93duHA4+U egrOcI1U1LqUpOOp0sFj134AzzjvWrCscMY2glMdq4b4Y6tda94fRZmZpbMiF29ux/EV6BGBHH5b dccV8vXjKnPlZ6dKSnG6H6bPB9rTzIy65OT/APWrzbVLiJr66eN0aNpWdSnTaTkYr0q2iWNp5tu3 ZDI30wpNeHaHNItv++YhQu7ntyfyrsw0E4SkYV9JJGox/tC6XSVaFWuEbHmsFXAB6npWLpPg3ULi 9kXT7i3kK5UsrdKpzak02tI/RQQq12HgS6Nrqs8bSZHfn616tBOKOOTuzuPCPgXxN4dtx4gW4tmi EZ8xUzuT3rR8caveTahoHiEyt55hNuxz18thjj6MB+Fd74emj1HwdqNqv8MOV9SMV5X4zmP/AAiU NxwHtroDPUjepB/VVq69KMKlOrHd3Q4Scoyi+h38OtyG6W1e3ZWeJJo2671b0+laOvFrFdO8Tp/r rCYRy+pibg/lkH864Cz8ZNJonh2+dgv2MSWb7Uz8rdMnvyo/OtzUPGGm6x4fklUM81lcR3Dx4wHU ZDD6cit6dSfNaXVESirHrcN5b3cSNbyh967+Dzg966LwdqXkNNYrxu+YAivHPCfiuwbVLOzsrVIt 7SWpOcsV270z6969Hs7g299FLuIGcEj0reLdSNmQ9D0eO8dW2ybR6YpGvH4OxT9aob5GVY41LsSM Y71Jqem+KrKMTf2BdBMZ3lCBWqpxuTcv/b4BGuFKSj0Ndp4L+J2seHbhEmmNxaAjcrHoPavGLnWr xZSl3amL/a9Kv6Nr32qRraSUB17561EqcXuNSZ9zeG/EWn+ItPj1DT5g6OOcdRW3mvlr4R+Nrjw7 rsWnTzZtLs7WUngHsa+m451ZQ4b7w9aqlOS92W/5lWvqWDJt/GmM1QybpB8rYpqtt+Vua053cViZ S27OcZqdW565zVZasRmp5hlmPFG3HFRqaUtx1qriHADmiTheKiaTbjDVFNMuM5GT2qlUsFgkfb6V Ezbqikk3AGmb6rnuKw8tt6VH5jUpZT7U3jpTUrrQVh2/n0NNaTnHPNI3WlBBx0NaxAY2c/NTH9qm kwV+lQMyj6VvHTqNDfvHFNaPP1p24deKQyDHNWmNXMmNfm+Y5qUcnuarCXgY/nStPtU5614+jOro WSeKUbOGJ5rNm1SOI/O2ah/t6z3H5unv1qNGHobRlXIpyyDr6VkR61aydWX61MuqWrNt3A/jU28x NGn5yv8AdBpC/QYxVVNQt+fmA+tJJqltG33hSso7i1LvmMOlNMjL7Gsm48QWsYOJBkVnXHiaNkO1 8k0m49xqLOm+0FRkt1qKS+Vc7pOlcTN4kKEfPkfWqk+vyTKVVzzS5x8tjuZNYgjTduFUJvEC4O04 /GuMbVJHXaWPFQ/apGB2sePeoTl3Fyo6ibxA3zLu9e9Zcmuy7vmY1lR+c3rTBFIzHNTZvUpGlJqU kmNzVHPM0nJbmoI7diR1I61fgsZJm+VWwKF2DRGN4k1JrHRbi4DEEIcGvFXm8uOa8kZiWJr1f4tF tI0KFHBX7RIFrxLVWnSAvHJmPYSw96FaUrsiT7HLeINXk1Rjptox2E/My9vavUPg58CV8QRrrOqQ sLUH5RjlzXmHhOwa6vkQjc9xcY/M1+gvhHQrbRfD9lp8UYURQKp4745ropRXK521Mlq9TmdD+F/h vT41RdHt/lH8SA15j8YPhjb+G5F8QaPGI7OdsTR9kbsR7V9HgKvAxXC/GoIPh7qTMBlVVlz/ALwq aztFy7Gh8IeMrjz/ABBJGMlYVAU9ulcf4w1O1sNFup7onyY4yz//AFq2dZvnl1G7umYfvJWC+2Ol eX/GbVFsfBd58533O2PP1PNc1T3qdmC01Etpo5oRIrBkdQynsQelS/2Qsn+kRr2+76+9eZfCDxd9 tk/4Rm/bLRDdbsT1Xklfw6ivX5rmGxha4mkRI0BJJOAK+dxcZUalj0KNRTjzHAeO/EA0XTjbxuUm lbb1wUHXNeL6lqTTwGEt5jsz545yO9b/AI+8RL4g1O7nWbau7bH/ALo4rltP0m/1CG+1BVxb6bGJ JX7AkhVH1JIr18LRVKkpS0ZxVqrqTdifR5GtHO0EyMxXIHQcjjP+ea9O8D2/2a+hnmUuHYbl9V+8 R+lcZ4Q0RrqX7RcKST0r0KCNrfUrK3jBB2s5/LH+NKvUXOkKlF2udN/aD6RD9ot4wZGJ2kjueP61 D9smhj+99eaZqGXSGMfxSD9Of6VVvJRHbuRwQK8+NpR1OypoSahdbbXzHb5n5+tUPD+p22n6rDf3 kAniiJYxsflLY+Xd7Zx+VZ91q8UyiFpMMuBxW1ceGPscPknULZ7gxqWjG75WIyVJIxkdDWlKlJO8 Vqczab1KfirQtN8WWc23ZZ3DnzFliHyMc8hl7D3H5VNYafZ6Xa2+j6YsjpEu0O/3pWJ5bA6ZJ4Hb FQadp39k2ZW4mBlncyeWrbhGOgGQep/Tiuk0uRfD1h/wkl1D/pLkrpqEcBgeZiPRegHdue2K9mPw 66GJ6fpsXhn4J+GGvvFDpd+L9YhjmgsISGk063IyPNb7sbSK+7GC4CpwobcfNdY+K2t6jKWs1htV PRdu4n3JbNczNNdahctLNNJLNK2WYnczMevJ71J/wjOuC5eP+y5o/LHztMvlIOORucjn2GapOTT/ AKsLQst4w1yWQtLcW8jY3HzLeNs/TIrpvB/jLwkb6KHxp4XimtGYLNNasUkC9CQudpPfqP6VzNr4 XvbiTbHdWqSE8KZFOPx4qlr2j6ho8gt9U09rWSRcxyg/JN9D+XT1ovNL3WGh9efF34I/Au++B+nf E74I69PeX0cRnv7OScM5jVsSZQAGN0zuKn+AE8jk/GmqeBdA1zXINZ1NpwEC+fbx9J9uAvzdV4HO M113w2+I2t+C9Te2S6mSxvoza3sKyFRJCylGUkeqsw9wxHQmm67p/wDZOqSQxyGWB8SQsGzujblT 9ccH3Bqk5ShzSeqJbXMWNH8RaPocc/h+O00+3TU8CK3ihUOHQMVYNjfgAsOTzke1XxG2M7eprzNf At4fHR8TLq8aWgf7QA5LPz1jAA47+gwBXrMdnC2l22oW915qyO0ci7cFGGD+OQa8jM8NOq+ZLRI6 8NUUdGVpNzabqPbFjP8AX7hrwa8s2sZHs1fkBSdvuM179IqrpeqtnrYzD81rwu+tdmp3IXOw7Sv/ AHzWWBj+7k30sPEu8kcxeI0c0ci9mzWtJqNzptwbizuTG7AZ4HSo9StWGHX5u9XPJj22s/BI2/eG enHpx0r0oWcDllozqPDfj7xHb2F2V1mdAseGVVUbh6dPrXTawzXvgnUiq7w8Edxx/sspJ/LNQzaT YXnwv1a6trWFbi3aKQyIgDFSwByfzq/4VSPUPC8tsxGX02dAPVhGcfyqMRT5YwnvqaUpKXNHyOR0 DUt3hOW3K5aO5Uj25Heuq8F29vcXV2t5kQRwSyz/ADHhQuf51V+HOj211oVxbXVqWWSfcGx6YPH4 irfjhLrQ7GfRfD+nTNdXq7byREJ2xnnb757/AFr0qcdOY55PQ2PgxqlvqGrXaSWyb4lR4W7rtBXg +4Jr2uNt21ufl5r5w+Dlnq2n+K4zcafcxxyIwZmjIHTjmvoWCT95tzjPatKetyT6u/Z3+Hdlq1iv jDWF84BttvG3QEcFq+gbjT7OWPyZLaNlIxgqMV5D+y7qn2z4bi3J+azupIz9Dhh/OvYPMyM+lVTl 7vN1uVY8C+PXwdsZNHm8TeHrVY5YPmmjUcMPWvlZWktbyO4Rim1sMK/RvVreHUNLuLKYBlmjZCPq K/Pnxhpo0/WdRsduPKmYY/GtJS9pHm7EyVmdlZ3BaGC9iYh0xyDX1n8N9bbXPCdndyMTIq7G+o4r 5B8LSedpMYbBKrX0Z8CdQa40CexU5MEn8655/YqfIcXrY9bEg3DtSPMvUHmqvlyMRnvUy2/rmtNW USLdL0xUy3RHKrUKxqp+7VmNVx0qnFk3GtdSf3aZ51w3Y1bVI6ftjzyorRQ6i5rGf+/P4VFJHJu3 bj9K1GVck1WmVVz2pqk2Fym0bN/FilMbetS7lx+NMaZQcdRVOnYLkXz0u7aOaXzV5pCVK5akqYrg Xz7U3d83OaFZc9Kl8tCK3VOQuYqyXDKNq5Paq7GZ8H+VX2iQLk/ypAE4+UYArSNFsfOUNk3qSDUg jduuRVo7ccAVGzbeR3rZUg9pqcfJqUQ+83XpVC71jrtfpVP5p8ZJx7VF/ZrSOFViec4NeI9rM7bC 7prpt25vaq9xpd5Mx8vcD7Gtu1s/Izge2KvQxtGA2Rg803CLDVHDzWOvWzfKHYdaz5LzW7WRWaNw K9O2rJztB3e3ShtNglj+aNT35FZNa6FJnmi+JL9f9ZvUk5NTr4ilmj2+cc/WuwvvC9ncAlYQD9Kx T4HVmcxkrUPXcPQwpL+5k/iOD71F9pn3Y+9XRQ+EZoW/efMP5VoweEl4baSapPmewvmcepuGYZU4 qeO3kDAbT1rt7fwuofLc49qvr4Yt9wbbyB6VVriucN9imdgVVjV6z0m4lztQ8V3kWhwRqP3PUelX rfTIYV+WMD8KbiiXM4uz8Nz/AMakCtK18J5x5gGDXWraquMcVKsarjNPkViLs5+18L2iffjBrTt9 FtoPmSMCr/y9sU/eooUVYL3PAf2lPLRdKs/u5Z2/lXg2vSC3sDGuNoTr3r2r9pe43a5pkK9FhZvp zXiHiRV+yCPdjeOfauSm+Zy9WEtTR+Emmx33jDRYQMhp1YjHvmvudCVjC9MCvjT4E2jt8QtIWPBR NzN+CmvsXzGZsHpXTJ2iTEs78DivJf2jNVa28Ei1WQj7RLggdwOa9RklwPlNeBftQagy2dhbo3/L OV//AB2uas/d5S0fFklxJNNIGkDruOD61U1LTtN1OMRanZwXUAbJSVcjNLbh/LZwxG1iSTXnXjz4 gR6Lby3cj703FIUVsbscEn8azlK0V3DY7nT/AA74NsZHuLPw7py3DMGWRI8MmAemOnWuL+KU066K bGHdveTt6D/9deT6X8ddYtNVVntlFuz7WCnkD+tdF8TPGH226jW1YtFGmJMcfNxke/auPE0p1KlO VtUXSqRhGSPL9UVl2yNyz5HH938Otelx6Guh/CqC3kGLnXbyNpB32ruPb/dH5159ZwtqWrWtqVDG SYbl2ngdc+1exeKYEmm0XR7WTzI4Ic8f3iF/M8GtsVJxppd2v8zOmrsreE9HZoUWGLJx27VpR27j xNPC6jNrEifnzj9a77wjoK6bZgyKokfhv9kVx1iv2zXNTvPvebcNj6A4H6CvFhifbVJW2SO+EOWx YlhaWTcvIhXJ+p4H9axdal8uB+PmPy4rsobL/R3ZjkyEdPb/APXXIeLIfJgHTLN/T/69XRqr1HUX U8w1zUJre53xSEEc8VpaN461iRlhuNlxlwvzH5zn0PQ1TtJdIXxbZ/29Gktism6VJGIVsA4DY5xn GcV3X9peF/Phks49KRhxCsarx6YJ5JHvzXs01eNzzt2bWj6eupah5VxIBDEvmSbW5IBHyj3NTeNt S+3akNm2OG3iEUKD7qhe3tyf1rAtNX+x6tFJIf3TN5cn0J75/P8ACreuR7byUhvlfOfYcVupWVhm j4FVYdWg1S4jinjsyt0YZRuWRyx2KwBBK5RyRxnCjoee5+I/jTWNZu5/E3jm/e4muVaWeeXAcFvu 4AwOMcKOABgYGK888MSLD9oUlsSSK3T+Dy1X+Yau9/aC0nxN8TdDfWNOs4p7pxC6w2sKxhokjAO1 EAUYCqSOp3981rTj7vNfYlu2h5NpfjrQb7UXs7XUJ0ct+6eQ5DemcV6DNqF54i0VPD2rSeZHbsWh 4z5bEclfTPGfXAzXz34N8E+JPEWvQ2el6ZcSNAwknKjAjUMMkn9K+k7jT20mztVmXymjTLZH3j1z +WKziuWRXM5KzPOLiNoZzujZZYjsYnvjpXV3Dzar4TtNUDFzpkhtXz12SZZc+wYP/wB9VzWvXUcl 9cahF/qmIO3PcKMmu6+GOmpq3hfWNMm4F8seGI4DKGIb8OK3oKM6nJ0Mqr5Y8xwPiTWrrRdBOrWV v57CZIWG3OwMGO79MfjXdaDe/adOt2GdrxiT8xntXH2t5Hp8E0l5Ki2xwsvmAbDzxkHg8iu88L+J rPUNJubRZLa4tzHtt2jiUbHBHQgA9M8Vw4uh7WHLzWt5m9KXLLuS3aq2g603PFi+O9eO3kbXEokW PgKAOOTXtVrD52l6wu7ObFz+WM/SvMFtx6dOleVh5ulTdurOiouaRzFzZeapXYagjlvoo1sYdPim bpuIOcde31rrvsn0rU0nT4I4TK0a7nbrXbQqOUlHqzKpBWOWi8eX2l6DdeGbXQjcf2tAYGfcf3fv gDk812Hwxs7q30cNf2TK6mSPa6kFlYY49ua6HTNDsbKOPy7WJW6529Ca3dKtWmvEjIyNwNeoqKml GWpz35XdGj4c8L2en2qFbcIM5WMdvet66ureONpLhwPU454q55OMKBgcLXz78ePiJrGk+Jm8MaRM YEtUUzSDqxYAj9DXbpCN+xle7PbIdUsbmQRw3CEkYFXo8q4Y9q+aPAXjy+urtLTUJ2cuRtc9Qa+g tB1Br7T45pvvDKtj1HFZQqc7sM+vf2RdVLaVrdgzD5J43APupH9K+hTcDtmvlX9ke4dtY1W1U/K8 St+VfVUdu38RrKMXzSXn/kaJ6IgkkM2VUV8SfGLTWtfHerQsu3dKW49+a+51twhHfNfHf7RNv5Px FvWXo8at+lbwhywlfyIk7nMeD4caa0TSc9iK94/Z3m2XWpWgYkfK3P414D4PZltz29K9w+AE+3xF fR/3owf1qZfw16r8xLdH0Iu3joKcetQF9vOacsm5c11RiBM21R60qv07UxmyopvnYwAvFWlcRbVi 3FOV8t61V83A9O/FJDI2/tirVkibl7cGWqdxnJIzUskhYArmoW3dacXYRVbdzz0qIZPY1a2hjg96 b5G0HAPNF0wsV24I5p2Ny45Jpzrzt70LuX3p3QWGLG3XpTmZlPWpc9OKlaCNsN0rWE0tBWuVdxOK Dlc9KseSoztqOSOtedAo3IsdsUjAfd20ANn6UvXPrVcw0rHmNurbtrKSBxV+3ibdu5BFWk035uwq 5HaKvUDNeDe+jPRbK67scLUsf7xgpB571bjijGF25qZYQo3KozU3EMSErj5c8VNs2nHbFPzwPWnf M3biqeghFVM4ZqXylHK4o2k/w1OsbDHGKHqLYgMIZfu5qzDBGMMoGacI9qdhmnKny1HwivcckMeR lfeptsY9xUPzdc80oDfjRHQCfcnbpQ0yj5QM1GvFHG7POadyUSeYWzjGR61HIzdKeNoofDY9aHsF xsf14NJJuzjmnqCKGI9aiySA+b/2jV/4qiwLL1tzz/wKvF/FW5rXchGdvy17h+0rAV1nTLjn5omX 8iDXiPiD7qyN021z0fha82D3O5/ZtWSTxnYtOuHWJ/5Gvrzy/Wvkj4BzMnxAsNvR42H14r65Xn2J rqesUREiaEs2BXzz+1NCY/sJZuWt5gPrivo1evvXzx+1db/udOuO5hlXP4Vz14pRXqWnofE6wlIz HJnOOhFeAfFzwvrl1b77O1llSyZlk2rngnIbFfQEEm4H5t2Dk4FWYo41ZZpI0wnO4jqKyaivfk7A 05I+LfBvgrWPEGuQR/YJltIH33M7xkJGi5JyT6gEAetaXiKdmdc53uxY9a+kvip4/nfT7fw3psUM FrdbjM0cYXzGAwOQOmCfzr5j1tXXUAr8gHj1qKNeOI96Hwk1IOGj3NXw2r/8JUoZjmGHP5LXrPhG zfVtetvMwVt4lZvTPXH5kV5Jo+5tUv5imW2bQfQkgV7x8NbVWjuL7+/IFX6AVw5tU9lTcjbDq7O+ k22drLMf4I2P4gV5/wCGLExbpn6ks/Pqa9CuoY7mFreaTy0mG1m/ug96px+E2s5JkjuYDblQ/neY MAHr9SPSvmsLJRjKx6K01MSdvLtxnjqSfqa858XXyzTeWpO2NeB9ev8ASu68SXyFmWEjaWIAx0Ha vL/EEhMkrAnn/CvTwa5pczMqrtGx554gfzLghOeeK0tH+G+rTra6jql5FY282JUVstKycHO0dMjB GcZ7VVnt/MuiztxjNaGpfETUm+VreNnACs7McsRxnp/nNfQ0npY8173Z0938zFRnk56fz5rTvLwX 2lxSeYTKv7uX3x/9aoLzRNS0izsv7WkRrq4t1mlVF4hdhnyye7KpUnH97FR6TNGry2dwuVmXj2I/ +tn9Kd+ha1LWnTTW9xC1vI80qKUeEZJlQ4IK+4/xr3HwF8WNI0HwjqOkaho8epLfoEt7zzCktgQQ X2jplsKpz/CCK8Wgs4pGMcPyp/yzlB+ZMdqVpZlujLPH5zt9+RXKl+udw7k/TPvTjUcH5BY9k0P4 geD/AA3eHUIdJE8gYS7WwqsRzhwMEjsee9ZXxM8XXvxCu9V+Ilxo9rpGl3d2yrDaIYoC5wxhgBJO ACM4Pyg/QV5fu06GXzodJ3EdBM5K9c9OM0mueItW1qaKO9uGmjtV2wQRjbHEvoqgYUcDOB25qpVE vhJ5WVHaa8kIjBw33Vz3/wA/yrsZ9Wm8L+GYNBsZSl7eI010V48tH42ZHdlA+gPvWHaJFpFuupXS qZnGIYW/iPqcdh/h61SjaW6uWlmcmSRtzE+9VTfJr1Ypa6Fm60W28QaHNpNzcvbs7pNDKq7sMoIw 3fGGPT0rb8B+C9U8G2ctvPeW99YXMnmW1zATt3YAdSDypHHB69elMWxs9NkvtQ1zUptPsLCykuV2 xh/O+ULGq567pGUdeAT6Vxnhn4patqGtaXY3kcUNmZ5FYR5+dnAALfTAx9TWNblq0pQfQum+SaPf fB9t9q1C40+YArdW8sYU9ORXlrW+yRo35wSMZ969T8GT+Rr1nIcAGQKfxrg/F1qmmeJNTs248q6k AH1ORXiU/gfqdUrc5k7doFXILiOKMo447Vj3upC3iZuh+tUY75WiM15JIikgqq+ldFGnUlL3SJyU fiPR9P1izmCRNJhhgKK6bSRJHcQzr90tXlGiL9quFWFSvzZ+Y5r2jwzpOoTaeblbOK8igGHMDYkX 3x3r2ISrQsrp/gcz5XodOd25ZBjn5q8y+OXwLv8Ax1LD4w8HlJ7zyVjvbRmAZiOAy59v5V6Zp80d 1CrQyBwPlU9Dn0PpVC+8WaXpN01rcapDbTr95Wk2kV3qfPH1MGrHzh4P+E/irS9RW61uxe0SBvus RuJHoBXu2h6e1hYxws3zN8zfU81b/trSdUuP3OpwTSv/AArICTVlYVZWZW+6udtONNJ3A+g/2PV2 +JtRVjz9nHTvzX10yhcbeK+TP2Orff4g1G467IACPxr61ZV3DI61VFRvJ+f6ILkbP8vzDmvkb9pL yv8AhPJNv3jCob8q+vJI16V8d/tEyK3xCuwvRI1z/wB85rWXwOwLc4nwrH5luUOR83Fe3/AWF4/F FyykkGH+teKeD9zWok55Y17r+z/ubxDfSN0WEfzrnl7tP5r8wWrPeVhbZSLGy8Vb42jjNIE5rb2n YrlGbPlHHSl8tepp54pm7n5qaqvYSQ4Rq+BSGPZ0pyt+NJu5xSUmwskOXGPrQwU/Q0xc+5NI3X6U 0w3E2hT2pysBkdhTS3zAc0096nmaegFebcbgbVwDU3l9PWkPp1NL5mOpOKcXd3Y9hGGMgf8A6qdG zbSv9Ka7A/MKVDW8XZiB2IPBzzTJJO2DSseKhkbitua4CM26mb+dpWlX9Ka3t1601djsYSR+Zhm/ AVKybcN+FNjXOMZOO1WAM9VJrzFdnU2RqOc7TUqdOxpVXccHoOKevytnjAqfIVyRYx6U7aO1NVjn B6U8svFJMV2NBKnO3mpVOcKT0pNy7aT/AHe9JoRISO3engiolXd8xzxT+Sfl6VLVgF3fN7Uu75ie opp2j5v5UN93Iz+NLWwbi7tud2aFbv600fMO/P6VIMKo5AoTEKKXcePlGD3pjMvY0x5v7tDlYNyR pNvFN3bvbFMVJG+Y1KseW61muZ6gzw/9pa0H2fSrv+4zr+eK+fteXzYlVeQVr6Z/aNtUm8KW9wvJ hnHT3r5su42fTxJHztFZQfvTS7/oDOj+CN8th460cyMBl/LPPqMV9n7R/er4K8DXhsfE2nXMvAiu lOfxr7gTUlkhSQNwVB/Supy5aepMTVLKM8814Z+1RaLceFLa8GR5DsufqK9ak1RY1DbgK8y/aAxq 3w1vmjI3QfvP6GuStKMo2LSb3Pg/Tbd594DY3Z467vaoPEYvrVVWPR2mj7tzwfoK3PCtxp+hst9q zr5O2RlZ2CqcdBk8DnP5Unx2/a4+H+vXmkW/hHwra2zaNp8entDa8/aZEJJkkfYoycgZ+YnGc81x 1Ip2UtUWpW2PC/HuoWmuWHk2duyanZSKyQrnc2TgjHrz+leZ654Z8STTidtHvFZsb1MJ6/lXY6t4 oHjTxzF4tutPt9Lkg2ytFb8K+znknqTjH1xXu9zfXjaPb+TJIol2lucDHB/oK1pL2UbJGT957nzT o+gXthNf3GqRNBFEsZYSDBYt0A9ef517P8L1b+w4W6M7Eke/T+lc18W9Um1AJC8hKCSONefTmux+ HhT+wIBxn5gQOxBP+fxryM4q81O0jow8bM6W7bcCy9RWRdSCOPjoa1rkNtPOe/BrmdWvreDd9ouF jA/vMAK+eo3ctD0I2Rl3trJMrs0gUbSS3oK801qYfvDuHzkmvRm1C31aGSztbiNTJkb2Nec+MrOP T5hbrdQzZXdujbOOvFe7g73tJ6mGIel0cZfSbZGaNuRj8ap6aml3Gv2cesOUs3lHm9s9wCewJwCa nvf3YLcD6VgXLGaYbemeK96mrM8x6nrWveLre8aSWG4F/cIeVU/JGD0+g9hUVjcfbLeO+jVo2DdM ZAYfz6151pDTW95E0LAZYK277rDuDXpmuapZafan7H5exIytvGvOR6nH1yTVOPYpMpzajqVlIJoX XG75uDg1dh8bTKu260dXLHkxyY/Qj+tYeiX15rCXP2yFQItvzqOMnPGPwp8dxpdvqcVlqFwincu5 Dwdpo30Gjck8VabJ8yWd4G54O3A/WmQ681xcBbO2EHct94n/AArlTIq61eXSRz29mkhJaboq5wOT 9RXR6E1nfRi4tZlkAYqWU9DTslK9iU+bQ02e4unWS5JLgbRznHsKyPEXi7/hF9St7E2ZkDIskjNx lW5G31+tdJfta6Podxql4hH2bU/sjN22FeCR7gqQR6n0rF+ILaDqfgsXv2y3N1azRtaNwWlVmw6Z 79d3tg+tbJX3E2raHWx6rb6/4L1mzZZpbZ7FriOEj5lkGGQqD7gZ9s14d9ujiZZI5NjxN5in0I/y K9n+Ft6JLGwjkPM9u1u23BydpX/CsXWPBukrY3pt7VC6xlgehzyQf0rjhW9tJxfQqUbWZ6n4H1xN a0/TdXgGVlCyHB6EcMPwOarfGS1Nn42vJl+5dLHMv4oM/rXFeBGuPBFx9kmm83TrqVdqZyYmbGCP bB5r0D4wXFnqi6JrFnJHIJrTaXXnlTgj8MfrXF9VdGpJSXobKqpcp5LJJ9sumZuYoOfqagW4knvo IY+sp3YYZ2Jnk/U1aVCNPu2jZRIWfg/pWZp7+XfTTMPmWNFX6YFejRhyU1YwnK7ZvxatceH9UTVr dmMBO2WIA8oO49+tfQPwv8f/AGaFNS0yVGi2ll81FcNkEHKnjI/nXzhdM0ijbkqcY9j9K1fhvrza bq76TPIYoblt8QY8Bu61vYzv1R9FXz/Z7g6tat+5uG/fIvYnoawvEWj6D4m/0XxVpMV3s+VZ1G2V R/vDnFSHUWWxeBH3LJGD9anvsecuRyY1yPwFdtluZp33PN4fhI3hnxRp/iLw9fPc6ctwPMjf/WRA +vqK9gWMMhxjNY+nzSQ3BjXkNxg1typsDKeNuKqMFq0itj6U/Ywh/feI5G6p5AU+x3/4V9RY5GK+ YP2NHO3xHtJIzbgf+P19Ohj1qabtzev+Q+w5mO07q+KPjZerdfEDVZHbhH2fkK+0ppttvJI3y7VJ zXwZ8RbxtU8Sanch8+bcNz+NVf3GD0NLwnDEtkrbfvfdr3P9n2z/AH2p3nLfdXP514lotm9ppsIR jvC19Bfs96fNaeH7q5mORcTZGfas6ulOK7tBHWR60uRj3pPMolYdqRF+XcW5zV7FkqybmobGRTRj 8qYzYPansS9SReMj3pnJbPamq+7NOO4L39aIu4C7scg9aVpM+vPFR0MPXNUrgKW2nrS7gQTxSMtN 2/KD3piuPXGPmNRSf7NDyGkxntVPsFxmWU+1S7sjoaP6UjED7vWnFW3GIx/DNMZRTtw56UjFevet 4ahoRbdhpSBS/wC01G3d1rZMRiLMpPenrIRxzio42jRs9MipvlYk/wBa8h22OokVl6460fN0C0in +EdqfuxRzdBD1H6U1mbcQecUnmBQeaRZPmzzmjmAkH3eeBS/MuMdKbuwud3Wm+d2U5FRNgTeZTvM G0dM1W37qdgkfNU3FYl8zOPlp3UdajVcHNOZl2/epXaWovIfuVQTmjduxt/HFRFlbCilViq7utQn f0G9BzYVifSkWaMsfWms27Pao9qop24PrRe3oLcsGb5vl60pmbb6Vkpfy/aDH5YC+tS/bMsdzcVl GacR8px/xotftnga8KjcYisn618wwSI1vJCVxmvrLxIsOqabdabI2VmjZa+VtXszpt1JDIhU27mO QfyNKDtN+YS7nPW8ci3paNjlGDCvrbwjrI1TwzZXCsCxiCtz0Ir5PurhrZhdW8ecHp616F8O/ipb 6DJHZ328QS9VP8NaNKUeVkRdpHv0hmkB+9gVwPxhvDF4D1G3fpJHt+tb/wDwszwati10NSRvl+4O p9q8U+I3jqbxSZ9mY7RI2EaD+tcrT2RtzI+RPiJ4V8ReNNAstP8AD15KBZeas0EbY8zc2VJHcZJF eRt4e07wzePb6/p8088QK7CCihsYznvj8K+gIJL6zzcWN15cyk4YDI69CO4rh/iB428SRafc2t5p dos7xs0VwsIdQMk5Gc45PeplLl6bkWR5H4o1q78QLbaF4X0+NYLf99N5EG3Azxv6ngDueua7Z/jz /Zel22l6p4bkeSCMKXjm6/UEDFbf7Nvh+azs9c1qaMSSzSRRMxH8QBJUfmP0rtvGugaFqEnnalo1 ncSKuXZolyfqRg1pJcsbPUiKb2Pn3WfiIvii4tZIdHltohNuJeTOf09+teheGviNY6LYm1t7aS6u pCNiLwB65NcD8QYbKzNva6Pp8FqkbkhY93Q/UnvWx8OfDsesapZtqN5LDAWCyvFGCQnfAOATXm46 lSqQcp7G1GUlKyOxuPE3irVlIknSxjJ4SIZOPqaoT6Za3CZvla4f+9IxNeq654R+FaD/AIkHirUt o+ULeWqq3Tr8rEVx+oeH7dQy2urRSKPmHOM14tKtRaXsly/I9Jrl31PPtW03To0fyRLC3TKvwPzr irqFUnKiV5Fzzk9a7rxFp95CrEDcv1zXB7ZGuiJMDnu1e7ho3jc82u7MzNZ8mKIKu7JHc1zscfmS humK6XVoftUn2aORA3di2FA9/wAxXPxL5cxXcpxxkc5969GkrI5kaEce3lmP+PrTpHWONpJJWBRf l4689P1qnJNPJcL5kjMEGFx2HsKmmKtEFYjJ9etXawzpvDPijT7eweDUd/mCTcCqZyMDj9K5jVtQ bUtYbUrhNu51OB/CgwB+gpFb5IojtREVvmA5OfX3pV8qaQssJHyhR82efWmtxnceILyxbwtfJ56S SXXlRxhWzzvDHj0wp/MVk+D9ah0Xcs4Jgn+Y4/gYZ9fUVi31lHbLBIi/LIuS2DjPcDOeBUUcjCNo ux+Y7SBk4pq1hHYeKviL/b0F9otnYxiwujakyOD5ivCgXI5wAeRXETw/KwbGF4GTjFT7Vjij2fKr /eJP3sGm3EZ+WRW3If8Aa5J+nWhu4krHq3wtumt7W2mwWNtdB1JXI7HjPWuj1631PTbySxk08xx4 2eY8Zy4IODz7HNZvwL0JrfTrzxRqjBYAwWxgkyfPlHUjttXOTnqcCvSI9QuvLkhlfzIZWLSRONyO T1JB7+45ri5eWpKUXudMIucUeZ3U15NJaxtDH5cbJ5gVedqgDOavq0yaemnqHEMc0kqjOcbiK6XV vDVmznVNL+WBv9ZblsmH8e6ntWTN5cbBeMLx+NYVq07eznqOMFF8xza24W4mgYkCT5h7nvWRMkaz FopAJYTsdO7J6j1I712N9pvnbZI+HHzL7daoSW1rcKsd5bhJQ33xx+NdWHqRceV6NGVSLTMiJmMf y8qeR/SpZNJW5WK/tJGF0E8xVX++p6H/AD3rbbw7HgNauuW6E85rZ0PQY7eXz7uXaNvJGK9BJ2ME jpfCN9ea1FFc30XkNt/eJjAGOuPbiuukuPtiLcL0OR+XFc5Z/wCkaf5tnJGkfmeXs3YdvfHWt21j MNrFb9SmSfx5qKVVyrcsdluW4csSe0/4+E6Ehq6Gb75brnFc/YqWukC+vFdBN8p59K9FGR9J/sb/ ACp4kU4+Z4CvPP8AFn+lfTO7j5etfB/wh8Yal4Ru5b7T5GUlhvXs4r6W0r9oDw9LYCTUIZIp8coO cmuVRlCTv1e5aasdv498QQeHfCuoX00m1vJZYx3LEYr4M8QakxvAq582aXp681678WPidqHjycWO n70tom+WNf4vrXGaT4dhhul1DVIw0uRtB7Vs05rliS2dDYs1tpsc10Pm8sAL719L/CuJLPwbZSNG Vacb+fevBdD0e71jULaNrfMUr7I1x196+m9NtY9O0+3sY0AWFAo/Cs6rvKMb7Dgrl/az8g4waftP 5VGr8elPVvXinHzLJMjnpUDVL8p9qhkWTduXp3qmuZCT6BDu3HsKsqwbp2qvuxjI61IqsBxSStoD JWVSuV7U0NkEHjbTAG2mm+qt3rUhtAJNzYp4bHY1Gqr26077vLGkkO4h+b8aP4fahuOnSm1autwF 2tu701sd+nuKcd3PXNN5btWiEIQq80zbzTsdjQfyraKHcawPuPajdtHWl/h5qNu5zWiQGGsbFgzf hirS4C81GuONventtx715D906hdyhiMdae27AxVfq3ympNzYHNTHUB25Q3zdzin9agmh8xQM9Kkj 5XDUk9QHHuo6U3/gP1qTt2pdvrzUyFsIrAcCl3YPfJpCFHPrSM2OfWpegND1k+UUjNuxxTN3b1p2 4KCetQ3cB6/e9BQzAfxVTkvNp256VWnvtvHTNL2i6Aol9ZFZs7iBUF1deWrbcVkXGqeXIFAAqpPq G7aq5JaspTky1EuCaQyFh0zmo5rhmbaM0okzCuF5NNSP95ubJNTGKCxTmLN81eX/ABH8F3F40mva bDvbBE0YH3h617CumrJlu5q3b6XCkex4wwxjkdaaQXVrHxPeLNYsZNpeAn5lPVagTVLGWTccADru 7V9KePvgTa+JWe90VhaXDtuZf4WNfPvjXwDrXhe8a11zS3g7LKoyjfjWkat9zJx6ooLrlmtwLfz1 VCOuabfa9p4jaNbyPHlkYzXOt4fE0h8xsqfu1HP4XiUFtp455qpRkScYrs27+6WOM/WuS+IHkDS7 jzoyQbZlwT3zwc/UV1yx7Tt2jIY5riPisUg0WWYMSTHjb2HzcfXrXO1ouxZx3hH4yXXgPTpNMbS4 7q1aQzMyybWGQB6YPStW++PvhTVkf7RDdWrsvRkJ5/CvE9V1Fg0XRhyrfQ1gTM6yExqCD04rVxT1 Moto7vxF4osdd1aNNPkZ4+7EEd/Q16x8PYY7WEksAVjxtr5/8Oy2r3BhnjxMPmjce3avb/C+la+2 iLrKrEYZFPljeQ3Bx9O1eXmNP91yp2udOHfvHZ3y293IqTzSKgPz+XgE/Q9qydcurWJ5fsYkWEH5 QzZYDtk9zXH6l42bTbn7LqEd1C/b5N6n6EVm3Xi6C+RvK1CFWYcCTK4/OvLp4KpodcsRG1iLxFrE qsVjuGGevzVyj6x5INxMyuSfljYfe9f6VPrC31xl1aCYH+5IpJ5xxzWYumteWckisN8OSV78dq96 hCNOOp5tR88iW8nsbtftccSCTOGiI6fh/npWPGjK6yejeoH/AOoVOs09tdGaPCyBuCwzg57g1DJu llPlncWOTx1/CuqMbEj5G8yQMVGeMbef8miKRo/mjyeq5x61uaJ4bvpttxdJHBEDy8nAYemDVsR6 FYuBErXLLxlfu/rQ5LZDSOegtb2ZB5Nu3HtjFX7XQbxpEZsBT/dYEn8q1f7Qvvk+y6fHCOgO3dk0 +3utUkmDG4kjO0r+7+XrUuRXKUJNF1S82Ybcq52ru+4PbNVbnQ9TgBDW5b02n8veutmmfRLYWcbr Ndz4LyEZ8seg/rWLI/2Wf/SppWmPOO3SpjK45JL1OdkhmhO2SOQEdQwrovAvg648X61Hp8Z2WsQ8 y6mHSOMdfxPQe5FaukfYdSk+yzMFyNwEuNpx2r13wRa6fovhsadY2scTzTGaeVernoqn2HJx7+1O UmlsOMFJmstvb28MVnZwiC0tIxDBEDwiDp+Pcn1JpJGWKN5mbaiDdn0q0q7hlf8A9dec/GSbUrfS bBLSSRYXnfzmX1AXZnHPdvyrFRu0dDfKiy3xY0Cz1H7PG0ygHHmhMrj3HcfhXSzabp3iGH7dorRo 8yhlhDfLJn+4e30P6188WNi19qEVvM+wyP8AOW7V7z4U2ppY8ldsAbEGP7oAH8watwUfQxjJ1HZk a6fcRttmXa8ZwUI/So0jWKaQ3S7o2GE+X7hrs/OtdYjW21HZFcfN5d1zyeyuB1Ge45Hv2dH4B1ib KyLauwG7Ykw3EYyCAeuRWkaFOaskKTcNzmbHTFu5o44VOW6EHgV0KabaWK+XsJYDGWpdP0i5013g aKSNieQ69P8A61OvJo4WLyNu29CxrejR9hG8iHLnZa02FXmWRtkWOme1aiyMMZYc+lcbZa1eapfi x0mMyNnHAyBXrng/4Z3mt7IbvVI4ZXHf1qlVUXuS1zGDp+FvYmxkbvzrfnyxJOKl8TeDH8D61Fpt 5qdrO7gsvlSA9s0ybLZzXdTfOroyknF2Zf8AD15DZxuZZMEtxXSrrWnMscZlznvWZ4H0O11eO4a4 XdtbgdxXXL4R0i3+d4RxXRTp8y0MpOxHY6lp0fNvGZJD0wveug0vS5L6aO81LKxbhthXqx9K0PCP gXVdckWLR9LEcXedxgCvcfB/wu0vRFjutQb7XdLzlvuqfYVnVqQh7sXdjjGUij8P/CUlu41rUIBG wXFvF/cX1+teixwsw3NTNqqflGMVdj5j4/CuSEHKTlLW5v8ACrIhEePWlZfSpW/Wl+U1so9ETzFd lZTSbjU78LzUHc+lDQ0InJ5/WpS3IX1qE/LTlZSwajbSwiTcUqKVs1PJlx8uCBUTRkqactQTIotx P3hipGO772CKi2leBxSbmVS1Tqh7k+QaaysvIqFZCy/Snxzf3u1UpCJVOab93pzTvlNNUfNzWsWF hD947sZpjc1KyZ+b0qNh+FbJglbQb/DTN3t0pQGVjnpSNjk+tap9ASOdjkkLbdw461YWRj2P1qvD G34exq0qla8azOtuxJGv8Td6e2zpUTscVFukK7l9altLQm9y6u0jFJ8i8Dj8agjb5fmxQ0yqAWbn 602rrUEiYyKq9aN2futx9aoTXW3GBmolvJHztXAFZNjSZotOqjbuyf61DNceXjNV4WZm3SY496W4 bcvHX0pSf8pSRMswYbqVpj5Z55qis3lqMnNEkzFQd361k3fcGiKaRtwbpzUDyNNL0yRU0jLIo7kc 061tu/XNTJXdkPRFJrVpNzY5FW7XS2YBnHA6cVoLbpytWo49se0Y4qZRuTcom32/dXIFQSRMpG1e DV+SWGFf3kg/E1Rk1Sw8wKJgT6imrsVy9a7dg3cZqym1fvHg+1c9qPiK1t8LGuT9azLrxTcyKscO B9Kpy+8NzuvtVvEvzMBgVh6/H4e12zex1i3iuInGNrc4+lcdcapfMCTIwFUftzsDuk5HvRe+4JHm HxA+Dp0uSTUvCMpmtgSzQHqv0rya/urm3mNvdxtCwByrjBzX1OLhjGT2Ncf42+HujeLLVpJYxHcq pZZF/Okpygu4nG+x8fn/AF8jMufnP866fT/DPgvUdAvZvGOnrfR3URjSHeVK853AjvnFcxdQmC8u Id2dkzj8jXnnjbw74mWW41CHVLqOG4YMgW4IUjGMYz61nUdoadQ3OY8efCPwb9vlbw/qtxZx/wAM EhEm3/gXFeNeItEfQ9QazivFuEUD5wMfpXoV5aalCrTXBlKjhmeTrj2zXDattkvPOvJ41UsAFBzg DoDSoqUdG7kTsYtksovImX5Tu7dq+h/B/jLTpPC8ekSB4pbSPDE/dI7HPSvB7GGO/wBUElvHtROS DnGa9P0nT418C65qTE7t0UMZ75J7Vjj4xqU1zdy6MnGWg/Wry2uZC8cgcFieGB4H0rmL1Y9p8zAX vx0r0W38J6da6HZxTWqeY0PmOSBuzj1rzGay1e4ivZtPjlktrJmaXC79qZwCfauXDcjk1fY1qJxi pdyhfpDGsU0bgEkqu08DHPGOh5qJrqaXeyKNv8TdwOwJ70qzW7IG+yqLgBvm3HacjHC+vv8ASq+X 3BV+YsPujvz/ADr1Yqyscw9be4vLjyoI2kkkbAXqSa73S/BLaJB9ovY0e+ZQw8xgFT8+prK06FdI h89mSGdudzsN2PQVHeXTXW2SbUHkaTnGG6/jSbcti1Zbm1d6Lfai3728jdD0jWTA/IVQfQbrT2Ie 3JCfMpxn5vXishriOFvlvWQqP4lIwfbFbWl+IrqFRG9wJ4mXc2WBwOnP/wBek4yUblJx2KqQ3TSN 5UTNjrzya17PTDptq2qX0YDFSY03YYn1PsO1Wl8RWqoJo1RW7kYz0rnNZ8SXGqqzW+50Q/M/v61n aUpWLbhHW9yG81CaOeSRivnSkHPHA9B6VmSTSSks0jHkcmo2Vn2yNuyeART1HysvUkdG7/St7W0O fcfHujwQzDHP0xXY+FfHt5pSJDM3mxdM57env9DXGrGclixGPfpS7cfMnY02roSdtUfRmkeILHVI UntGA3jO3Pp6VevrOw1ezlsdQtxPBOuHU8EejA9iOx/xr550XWL/AEmZpoJcJxvG7G7/AD/WvVPD fju1vtsN1IEk7ZHb+tZyhZXRtGonpInh+FXhu11MX225mtkbdHbvJ2zwGYckfTFdTJjnaqIoPyqo wF9gKkhu1ljVgykN90qcgintH5jKEUsW4AX+VTzXZtFRjsRQW6yb2mnWCCMeZLM3RFH8X19PUkV0 xuY7hYpbXiKNdseD/B2/z714b8WvGipnwvptxi3tn8y8lRuJZRxsB7qvP1OfQVt/CL4hR6hpkely TOxtcLKso5Ck8EEdvaurDWg7y6nLWlzaI9th1GG7t1sdU2mI8JMfvxH69x7V5r40W8tZm01WKSSE jPtXoMNulwpWNskHK46H0rivixbyGz0/VLdW82HKSH1UYx+h/SuurByg+XcyjKzNH4fyW/h1SsiD zZuXYjn2HPSu71Lx1Dodj9ra4JlPEcSNgsa8dvPEGTbTWq7y0QyF/vY/xqbRtP1DxRqYtZZi5BzO 46IP7o965Ka5Nt2U2dT4Xs9c+JXjJNU1C4f7Nbv5kjsSBx0Rff6V6ZrNoljeSQryvGPfijw7Ha6L axW9qqoIEEaADtjFLq0rT3DM2AQMV2YenKLk5mcnc6X4cyTqtytrA0srSKFVRmve/CvgCGbZqfiV enzLAOB+Neffs2WsJ/tZ5oVaRHj2EjJAIOa92m+WPr1rZTbvHZEpLc29P1bTbWFbe1gSKOPgKgrQ XxBaxr8zAVxEJ2sApJBNR60t20K/Zm2kEE+4rJRutDRs7631/T7jH7wAniteK4hlT5ZK8WtrqQXC ru5B7etdbbatcW6g7+B2pxdnZgehBl55604Vxtj4kmOfMUVsWeuxSD5mFUmI1ZGH3T0ppULUUd9b 3B++PapmxjIYGn6AQsPXNKi9RSsexzilVcfNzU21uMcjHkdqkT5jmo1PegN81UnqIdMvcDj6VAyj YVqd24+U/pVZ2OcU33ARY9q529abtOfuinmTGFoVhu5pJJDE3Mg+opySbqR0UfjUKt5UmO3arStr 0CxaebaMNTdyt60cSLjaM1AwZSNvFbqSEiVu/GaaD8p3UnmbfvUNlh7VumMwFZY127qGuBj3rOml 2qFXJY05W6b26+vavFbbep12LX2j+6eKGu2VCuT+FQjYz/ewKbNFtUspNS9LgiSO4Z2OckCq88kj Z+altY5CpOTyfSrEdr1aQ5x71m7uzDZlaGSR8qx6D8qsR/Ko6n6Uqwbd3y9elT+QMeZt5NQkNCMy eVnkepqFZFYjPNWTGu3b3qFYRvw3QUmrsCvIMyBVU49qSSMs4CtUs0kcOcNisa5163hkbbgn1qLW YXNkWZGPWrEckNqvzuAR71x1x4qupiI4eAe9VJtQu7hgGmIBq+tyH2OvvNet4B+7bdn0rOk8TTLm EAgHoayP3cMIZjkmqV5MzLu6YrKUW5bjLl/fXN0HHnHAqnbSGHLMzEkcE1U+1qYmbd83rUCzNc/u 07VcY2ESyXjS3B+bil+0M0ij361XSymUlsY5qwzRxr2zTsIlupvlxnmqrxtjavU+tPX5yMk8dqmX Y0inHFTzdATuNa1k2qpbHrVnytlvIW/uH+VDD95161UvL11jeJRztIqHruUlY+F9UwusXyEdLqX/ ANCNZniDVobfTkt7pSIyWZWHO0/4Vp68xXxBqKHPF1J+HzGuB+JGqPb6MIdmVuN6e4+U4INRGVqW nYXmeO+PPE0+pXMkVpGY4FJAbpu5x+VcMttdX90VVWYk5PtWjrU03mlUOd3HJzjFafgWO3+y3M11 CzFnCqVb061qvdiY35mWtL0lbWMbYwHb7zetelwaQ0fhPQtJ2nOp3zXL/wC4nFcrCtm0m1YZSXO0 Dd617JdaSv8AwlunaPbw5/szT44yvo7dT9eK8vHTtyrz/I6KUdznfH2ox6Hpc9x5JYwwrEFXtnv+ Aya8p8M+LLrQV1KPTbqEJewtDJHcxHLK3B27T1r0L4qXSxWd7Zr888rf6scnaK8fubGG1020vFuW +0vI4ki2ldmOhB796nAQp1qT547v7zTEycZRSeyKcxVpmMUYVTn5evtXQ6Jp1npyrdahKpufvRxc /IPU+hrBtVk8wz7dxiw2M9+3+fap5JHRWulunfks2c/jXrW6HIixr1rcQ3Uk0jb4zkrJuBBHt7VR jMlx5bR28rK46j+L6VQj1C41i/ispZWNtGSxXOMgc4rduJeqwyFdq7UYdAOn9KHoG45ZFMY+1WMq 46sVzn64qWGDTrzHlKNw9yMVAviCCGFDIymUfKwJ69QeT0ogvIZF+26fgqBzCrdfxqbF3RLeW3lw /Z47h5FOPvE4AqtdMUkaCBmVARkDv+XWrSzfbF3MfLX2FUL6RY5ROu5geufXmqWgpW6E9vHwFbDK fzFWWEPllto3Z5Iz/nrUNrPvUNHgfNj3B/zirht2kAXzi5bkAdKG+4LbQpsVCllxgcf5/WmboVXa 0ynPTOP5VW1qT7HYSMqkMHEanPTOT/IVyjOzDczkt6k1a1IvY7T5VwR8uR83PH+NOt7p7eQzW+AV J4Kg9evWsXQ7lpIitwGfyzj72Dj61qHYyBskMR93HrTXmB6J4Z+Iz2e23uINsYAG0YKjjsPx7V2e qeOFtvD8txo+WubhNscnGIFwdzA92xwPr7V4SpXO3jk8f1rY0fxFNpjeW6mSBsKyOOCM88UrFKbt yljyrWSL/TLHzYJD8j4yXYcZAP1qx4dv7rTNXjg0u2jdpn8lo4xyQT6457VU1JY0fzdOLNbyNuhP ORn+Efjmu48K+KPDPhG3t1uNFb7a0YMtw7gknvjPT0xVQj72rJme4aa00cUWGYNGuOOv5U3xRYw3 2kwxycuzkqD3GOao+FfEGmeIbNdS0+dXiVjvyfunuD+dZOu/ETT9QuXXR1Sa2tR5YYH7x7ke1erS hfRGEpWOdbw5d2M2+xVRknJxyB7fnXXeGfJ0uMLDIsJI+fcvzE9yT3rg9Q+JctkJGbTVk28A78fz q58PfGl14w1aSzmsFhSNd+VJPeublpqej1KbPY7HXB5iQxsZHc4L4xgewrauJN7sc5BrF03TUt/9 I+84/StIurfLu/WuqEbE3Pdf2c5Wa01ZSq4WROfXg/5/CvaWmDRgM2PevEv2cZFS11VC2N0yfyNe x3Q2odvUelcyesvUuOxNGyJKCO1F3IzRuwzjH+f51Ss5G3DzGyc1Yum3qVVef5VUXYbMC1MjXuOx NdJt2xg8471l2umu1zv2njvXRw6a7R9SeO9KMbt2B2tqVkjZgpjzzVxTJD/CasQ2/loFZQCKluI4 zHwQO9bRpysS2Q2tw+4FGIrYttUkUbXY8Vz6t5bHbjBpZNQW327qIxS1kw1Z1KapG3yscVoQXUTI ArA1xAvFZdwNOF9NGw8uQ8c0morVAm2d4u373amScdK5q11+YYWbkeua14dUhmwu7k0PYLlsyZ9a bw2d1INrHdmkw1ZvsUhcfMKRsqpZetGBx6+1L7HinGSEwjkaSPdIuDUcgVsdjUn8PFNbmtF5j2Fj b3zQy/NkrxTB8uec04SHkVvTT6gMk27R601n2rn+VPO33pjHrW6VtwTOPhw2GYkZ45qeQE4WNckm kgs2ZQzHA61PsVcbeorxfU6yJbWRWGWqZo1ZNq5zUjKzY681KI+Mc5pNXERW67VI54qwoVl96ai/ wsRTvMXaducU3poA6NcZyopfmb5Qvy8UkbDHsKTcyjPBzUS93UCOSTa2OmKqyTrHncTxVkxs7Fzj n3qnfwu3yhuoxWWr1A5/UtTkmZ4YuB61hyRhlPzHOcVo6l5du5VW6Gs5ZVkbCioUdLMd+hGGSEBV XcTSQTNJIZG4Vfx5qFmZ7huc9hV9bcLD93vmnIm7uQyTyTSDPABpLwOygLyKsrHtYdM9sCpJFj2g 8AiovZ2C6e5h/ZXYmNmAzxWhpenrb/u2YetVLqZdxZDwtLZ6pHKrbm+ZR+VVy3XMK5oXh+UlcALV FUFw3XgU+Ob7QrRZOScmrVnAkZJb09KLW3C6ZWWFmJ68e1EULLJ81aYjj521BI8Sqfm+7n8KhMBk /wAsayZOaja3VlMm3OQcVH9sWVQWI2j9agutYhjt23MBinZBfU+HvFS7PEuqpHk/6VKPbljXlnxd naHT7eYKWCXC9+or1LxdIf8AhK9WaPIBu5D/AOPGvKfjEy/8I2JFwP3y5NZU78i+Q2tDx7xAtrNe nyIdjn+Ise/17U7w5KturWcrAMDuUZ6j+vSq8ky3lrFcLy8X7uTOO33T+VX9F8OarrUjTaTA0n2U eYzBCQB05/OrsoRtcxTuztPBdmureJ9K08A/vrqPd9M5P6V7j4fCyeIPEOtSxlszeTHn+EIuMj8T XkHwxe30HxtZ3mvEwR2scjBmQ8uUIXp7mvSdB8TaXb+H9WuJL2IzvM7FNw3YPI4+leDmrm5LlWlv zaOylytanivxTs9SsfEEmuDUgUuWXbGGII45GBxjj9a4XUJJC0kdxgtv3KQ2QAcnAH4/pXV+PPFW n65qGxVaRYcquFxtI474zXHaldG8meR+ygH14AH517GDjUjSjGotUY13F1G4bDreTzYQqqOZD8re mOP5mrWqWMlnprXG7YW+XaDUEKwrZQyLDmTzCufwHp7/AMquXVpNfafKm8tICG5710PczWxymhzi LVF3tt3gp6c9q33Nzb4NupZNpYMD9056Y/KuVuImt5vlYhkbqK3bPxEssJiuJBDJt2+Zt6kj9Kom 5lSyzXXy/O7Lnd75PWpLe+vLeBY4cIgYs3HJIxnPt0qwt5DasyW80YAhI81RyxOeP1/SsySUSMPL 3fMoVieSTTt3Ednosy3mlwu3yjnv1INaWg/2fDrlk+q2v2u1EgEkbHAJOQMn0BwT7A9KoaPp8lpp dq02xcjedxweSccV13gvwbN4h1SOSSMrYW2JLmQjqgIyo9z0H19KzuuuxtGNyDxR8PbrTG+3aCzS w43eVnLD6etc5Z6h5amGRQksfZuDX0FPbLLHtH5YriPFXgOz1ZWnhXyLtQT5ij73+9RGZpOlb3on m+oW1vqsMtvIrI0uGRsfdbsT7c4rlZvCmtI3zWbGMttEgIKH8a6a+tdW0O8S31OIrsOFfHy4z7da jhnd5ArNvLE7Rng1cVpoc8tWVLDTY9Oj+zt+8lb7xU8D0HvVqNnUYkU4zmlTKMWlgliIJA3DvUQV iw2sCDzzTESSctvjjCk/5NNk2hVK44PJz3/lTJJGKjtj9O1W7Ow+2TeWsioApZjwQB/9eq30QFuG Rl0+GRWIYAuhDcxjfjn8QaWS1Zo5pdQl+zrwQ0qkliee3PTmodYt1t7tFQbVMK4X07E/mKkh1e6T eWbzGkx8zckY4H+HNHqHQ2fCPiy4WO68I6TNKtleEPPIRteTAIwPQHv61s2u3R1ZbVmVSclTz2rn dCvIrzVBI1rHHcLGf3kY27h7itm+vYYWCzSBSx4HrTlOV7RewkopDNauDc2rO+AxxnHet74JSLD4 mZhnHlnp361yV9eW9xG0fmLkA8Zrc+DeqW1v4qEczKvmIVH1rSLbkm+5DR9EzeMNP0+UQ3EgVj0U 9TXQIi31mt0sbRll3KSK8n8SeHNQ1HWINUhUyQxEZUH3r0vw7LdDTI0uEZFRcfN3rv8AejPyIvdH uH7PkrCx1KY5DJMoP5GvarSY3KOWHPpXkP7Ott5mk6pMFwJLgdenSvaIbMwzLjgMOmKw5W5N+Zon ZDbexkncMqkYq/8A2cync3PrV/T0A3bhx2q00eVdcDNa06alrIlszIVWHLbc1bhuPUdKgLKreWzD noKgkulh44x64qnLl0QWuaMtyixHrmsp9TLZRvXiql7qIb5VrKWZvOLlsg8VnKrLYpRsbrXDFhtY 5pNrSct2rNjuGZ+G6VpwrJIo7VMZX90NiNY26dOauwqTGNw6dOKT7LJKpLKcipooJFUcYNON77AT LtPUDpUclyYG3I3IpXjIQ85P86zJWJmG7jNW3pqJHU6fqrSYVs81txyiRa5LTHi3KvQrXUWki+Xj Nc6k+bcsmfLY9aVf9rNPUUxh8xrVK+pIxvl6dDTQW3dOtSsjHnrSH7tbLuA3rlTTOd3zZ55pXDYy oqPzOPmb61pBgI+V5X9KU/dHOKPvN14FJIMjC5zXQhpIxGVVRVVeopGj7+nNOXLYpzIpzu49ea8e aOhkkK/u/m/SlkG3J64quJPLB+aoGum5+bmpcrgi1uwfve9RqwJ285zVZZWbcdxzmpV/dfOzdanQ qxP5vO1elQ6hdSQxjyYyTUkJVst3pxUN/Dk1MoynHsL1EhklaINtIFZGsX00cZ2Ka31Csu3GBVK6 0+OVWyOKl7WuC0OAaG4undpm6movLEMmzPzHpmug1W3a1yygEdsVkQwie581kzt9alSSGxLexaSQ Ntxj261e2xqm1hkeoqJboeYVX+Hk1V1C/wDLUoud71L16itYkur21hwI2yazri/Zsjqpqi8czSbj kE1Yiti2BJgZo5e4kRPHJOQqrjNXdP0lEf5s89aljeGEjIGRT5L5Y90ikYokxaDJ444JN0a9Ket6 jQlV4asi5vGZT82aqrcP97pQo6agnY2XvGVRHuOSaz7q+IUoWGfXNIZmkt/NbgisorNJIWbOKmwP UmuNQ8uEqv41gXl/I0LnqK0r790pXI55rGvGVYyo7+lFtxLc+XPFSn/hJ9S+bpcOcV5V8ZI93hkC OPLecgr1nxYAPFWp7tx/ftg4rzH4vxyf8IjNccnypFbj61kpNQRb1jY8P03RNatro/uUwzbDuYYN es+G7W/8O6DNYafrQtmuZlmkCt/rABhck9cEtxXR/BD4T2fjq6t7jxJqMVnbSsQGnY7FGM5OOT/9 evVNa034c6no/wBj1bQwi28JjRxxtA44I9hXMsUq9WVOH2d/+HF7PkhzdzwTWfFGoaXp07X0dtcF YmCu0QDA445HBrznwXa2+teIoYdY1iSyjeNpJpg2fm4wMV0fhHwo3xA8Ua54ft9YbTtLt1leIyDc z4cBFIBwCQck+1bmrfADWvCtjNrTeIrQWkC73nRd20HOA31rpSjD5mV2zM8X+BfCdjELqz8UQ3HB ysULeY/P5A15leW6x3UsaKVVWwN3UD0+taN1NrGpXcgsXlnRHKxiFTwPwrPuLWa1dortWSZThkcY K/X1zWkIcvW4ty9aSNBZwxq2Gk3YyM85Na+iapHYyRm7hEifdZGrBVt1rDyfkcr6de9PkSSbFxDJ 8zckdM++KpoqLa1J/FXhPy2bUNLkE9pL8yMpH5H0PNcdJbNG21lK47Gu30vVLi3kMMdwVSTiRW5V vqOn/wCurdxcaPqCjdpRMmOQhwM+2eaLuIWuedrbyP8AIoYnOOldN4d8KvcZv9SVoraPkZHLn0ro NP8A7FjU7dOQOvXeST78Cr15cNNGI9wPHy7Ow+lS5vaxUaa3bK9rYteXCW6s0kszCNVC85yAAK9p 0jTYfDulR6LBKzvkSXUgb/WSc4UeygkD3LHvXn3wzjNxqNxd3lusn2WMGMngo7HhsDrgA/jivQ1b 1wM1Du36G0ElqXY2AXa3akmiWZcMMH61DG/y7ck1IsowexH6UXNr3MTWtBtdUha3vrdJIiOmOQfU GvKvEXgjUNBZr/T4zc2ob1+ZB1x/n0r2+6urW3tXubtgkUSFmbPSvKdZ+IV1c3hbTbOCOKInAkBL OPc5x+FawWhhV5epxc2qHUMfbLiSSRDtw/UDrSJIdyxsRsI6YHB7f0pNXb+1tQnv47eO38xg3lRD CrjsKrRw3khG5lORkeuRVpWOYt/MWC+QxLcVpyW6W9v9niYh+rEjnnHH4U7wzb/aNQjs7qQKZYXU N6ccfWrc9nJBeGCYMNjHvjjtQ3YaiVNcQySWbY58kLx/EdxqCLTY7qyd2mMDKCWkbAHUAAZ79ePa rmoRpHdWYnfISEKQvUncePbPrWfqUz29iZtztEjhCB0VjnqPXjrQ9XcnZENnHdeGbh9QmkaeMoVS Qc4PoahN9cajIZGcl3bgCs6TWBNZz2sbOPN298Dg5z161qaO0en2iXW0vcztsiB5x6tTlPkQRjzG jF4eupVAmkjgJ6bm5/Ktrwv4fktNUiuLi8UBDwyHPNdnofhnQbmSxuGZ0VgPOZzzz1Jr6QsvgH8F vGHgmNtL8Ry2vi9ZFjjtmj2xygns/TP1rw8RntPCTjGcG030W3r5HbHBc/w2+88q8L+PLO81K38N 3yv9oZsI4HDCvU1k/c+U3QjGfpXhkfhHUvBvxhtND1RGWSDzPmPfHHX8a9tVWyF24FfWYXErFR54 7aWPNnB0nys+iv2cowvhe+fA5uhj6BR/9evZgI2VWxjFeL/s+yrB4VuWbgG5Pf2r1hbxfJLFuKca iTfqNao2PMSJSyYyaVr9VjPzYwKwH1IKAFfOfeqk15JsfrUqtr7pXKXrjUkkmBXrVKW8eaTb2FZs PnSTA8n0rWTT5JVWTkVnzczHstChcNJIw2596sWdq833lIB9a1LXS1LYZen0rXXTUjjBUDNNU5SB y0Mqz0kZ3tkmtSOz8uPHatCOFUVeB0pPlSTPrXRClykc1yKPYq4bFK20LlQP/r1JL5e07eoqj5km CpPNN2WwtWJdSfL8vFULmLfHuz0qxLMqja2fSq0khkzjk1EpXRSI7OaSKcNXT6ZcSbyzyZVuntWD Z2/nkHb0NdFZWflgCueWhaNhZhgY5qbcrKGxVNF2Nye1TrICPvVaZJIWz7U3Pzc1GG59qeQud1aq XQYN3Haq8yqq7mODU4OfxpkyK3brW8H0C5Esit8y9qRpFLe9Bj+b5cDFQsvU5rVOxUVdmD/aJ4UD kU4326Pndms+1yhDc5P51fiZmYIy9vSvJd3qbuNg82PCbs5PrUbNH0XGR6U+6jDdFyaghsW3E7mP pUaMa0JlPZce9OeT+8BjpTY7dvMwxwBUwtPMkVVbIHWk4t2SGEcig7R3q9CP4iuc1AtqqsV3dauD 93Gq8UbC9Cv51xHOytH8nY+lPE275eu6kcbs7cjPWoERo2ZVXkdM1ipcrsxWKuo2PnfeUYPFYd9Y tZxlY1/Kupbz2+8n41Xmg+1KU2gYrJz/AJRnDLujcmRSC/FU51El0GwMAYrrb/w/I6/KcH2rm7yz ktJCrZwKq99x7lO52oqn0qlNeSKy7TkGrNxIJJPLXjiq8kIGTkHbVLQloTfIyszcVDdNIsW1T1p0 cgkUsccGo2kVss3IFNakvViRK0uA/AFP+zru3HgCmxzeYAF6ipPmWEszYJobSBla6nAXy4qY25ox tyCOTUotXZgxUkjr71L9juJW+VcKeCaViTBujJcPtHbg1E2ntMp3L0rfuLO2tY/XFJpsCTRtK3Tt UXdhnx546j8vxpq0XcXBx6dK8v8Ai47HwXMm0MoljY/QMK9Z+Kkfk/EPWlXobgkD8BXl/wASrf7Z 4Ru4ecBQQfoazTvTNOlzN0/xM2j6PbS29y0ShFO1e479K1tK+Lmm3Fn9j1HSZm2/KzqwIYdOQe9e d2OpafDY29tf2smFQAvGcjGOOOtO0HS9L1bxRYWtvq7t9puo40jCHqWHHpXlU06NSUu/ludE0uVR 6nongzwHfWeqal4o0+1WLStVPmxqf9ZGVblWHUDPNdF8QLnX9d8FjwLou2Cx1a7gXUHTB3rHl9xP UDPv2r0rVNB0O3+1S/ZZlZ12breYxtwuOeCDj3FeBeNr6/t3uTpF7JFKqshaRuWHQ9MdqihmftJc kloS8J2PF9WisdA1CeOC5Zow5SMryWHIJ/PNYdxcLcXDsuWUt8pbr7E+/tW/a6LPrl59nMZmlVWw pbao/GsaXS2s5LhrpgsafdGT8xzjAPfv+Ve3CcXp1OKzRGGP2SWNTu28jj8M/pT7ObcqqWw6/KKb bFfOdNyneu3I4z6frVdcrcNHuwc4BGeDV7oL2LuFMnIA/mfypVMkDEhiVU9/ep+LeQwu3MXLO3Y4 9qgEmW2t8wfncaW47WLVrcYuGkZTLvHr0xWqt4rAbVZXxxxWBFuiJWNierL2zVi1uFRjL5p3kYyw pNLcqM7HpHw91BP7TurORdjzxqy543bc54/GvQHiZvm6+1eDreXlvJFqNncETQndGVbp/j0r0Tw7 8UNJvo1tdakSyuAMbmOUf3B7fjUqF3oaqaW52G1lbbnBzTvmkOxc89qzpNe0GbbMusWu0Ny3mr/j XPa549s44ZbXQZTLOVIM2PlT6ep960jC+o3UsU/iB4ga7nbQtPkzFAf3zKch39PoP55riZkWNWD8 Dbjp+dSTXEkOZGQszDPPHNZs9093bREWzyGYlGbkBP8A6+aqTV/Iw9dyN7iCNAFlRh3xjvU2myWs kgk84Ha3qPT/ABrIubFYrF2aAiSA/PvPyle1U/Md4pDbp5Z3Bsqf0/QUb7k3OuluGs71JImG9PmV j0z6Y/Sukkuodat4NQt1HnL+6lj7r6Z/xrzGz1N5JvJn++Dgc9a6bSdQk02WKZZN8cg2yZ7An+nB oSDmJNYlaTVLgttAiwoPQ/LwQKrx6ksIMMlussP3trnGO2eKgule3uZIppC0mWyTng/1z1qnqdjP JCb6xmKiNBuiB+YYwCcVT0ZJW1y3soJ4rmzVo1nyTEedpGOQe4Oa29Bj+0Taa0mPLTcPoc1y140k lvbSyOXOCPmrufhzpra7a3GnwttuI2E8DHsR/jWdR3joXTjzS5T03wr9ovrh4Ccsf9WuOPSvVfhV q0EXiOLTdemlitQRnb95cdQPevJrP7RYzRzXAm068jIBOwtG3uMV11rqwvZ1me4aeduWmjhKhSBx 9a+frYec5O179v8Agnp05JWhJHR/EnVLe8+K2hy8mXEgHrs4AJrtUk5+teIG4nuPiVp11fXDSSMO S3bnjFe2R4xnGce9fVZTCVOlyy30PJxMeSdj3n4MXf2bw3OnT9+f5V6Ta3jXCGPJz6V5T8JVLeG3 dgRumJB9a9K0sssu2uiSu9CY7GpaQbpgz5OK0F0+SST7pC07To1kkO5sA10FtCFjx1ohAbZhppoV iVT7p5xW7b26qg+XjFNWPbMzdM1bjwY9vQ1tGHKzNy0IIUVZMdKm3bV3bj1qNoz5n3ameZRakMor WCV7CFknMaAk4rMm1FlfA7ntT76YrGBk+mKzbVWnm+eprO1rDSNq3WSVTJzg9KJ08sFlwSKWOXy4 xEqjK0k0gxtA69qhaeo9zNuGVlLZ+Y1DaxyNME5INW4LKW4m+ZDtzW3Z6WkbD5awqWehdhtjp4UK emea1hH5ainQoiLsVcdqc2FUnHeslEEJuJHIGaF3detMBU/MuM07cAvXmrTsMlGOM8Z5pjSOrD0p u8N1FNaQbwu7k1cZPqFh6synkZpXkLduelG5Wwf6UxpPmxgYrohK2oJXG79p5NDLu+hpJVGA2Tmj dXQVE5+BSGHy5qZcbz8pOP0qPzEt13dc9AKlt5GkTdt2k15V18zdiGFsnkjNPt7d9xy/T1p46fL/ AC70+M7mO5azfKkTdsXyY1zyTmlj2R9eOKRuMg/jTZCrDoeKpz69R7kyn5i3Umhm/i7VXVtuewFL CzFWeTH+zUN3Ak+ZulCpluRTI5MsM4/OnPcRq3LAgdqy6XYall9u3bUL7VXdnpUFxqCKAcYGKw9Q 18KjAsBj0qeZPbcaTZf1bVIbaM7nAx61wOp6t9olZg3BPFVPEHiIzyGCKQketYbSSFl+bmnvqxba GrJcLGPMXqTVKS/8xW65pqLNMwVVJHSpo9JmZsbSM0NiuVo97KdvAHWlWGaZ9iVv2eh7Yv3n5Vo2 um28OGKn3qXLuBjabpMqrukGKuLZxySbR0HWtVlj8sqp68VVmCwr1Gahyu9BkTx2sCfdGR61j3d9 um2r90VLfXA5+Y9aw5rtMnuRmjR7kMmuphcTeWp/CrMTfZYvL6etYSXxRvMXqOnvVn7c0yBpOCwp 6JAfLPxcZY/iNq+CcGQNgf7orzTxsd3h26hCldydK9K+MO1PiFfsnV9v48CvOPFg36JOvU7DUQ0h boX0PI7W4jxH5qqygfMuf0rc8HajZ6V4w07V54Uiiguldjt+6M9fwrm41+T5l7kVahxyvf29a46k UtDtjLmSufWWq+ILG90tr6xvI7uJ1ZleJsgH3x0r5+8UfapoZ5vJdg2ScDJrlLi61y1tZToV/Lb3 ajdGytjp2x3z71y7fGf4hWswjvZLZpE+VjPZoWbHrkVwU8rlGfNTd/XT9AnX9npLqb+jaZqC/ap4 YpkdYnbLL7etcHMNRmujHdFzKEyd393J6egrf1z4+ePtb0/+xzc2lrauNri3tURn+pxmudtdWkvp rjUNTlaSQIsUagYGPTjoAK9uhGpD47HmzcX8Ixl2bd5+oHapbxhIIr6Phj8sg2/xDufrURmeXHzK BuxtAx2/lxUtvJ96OZt0b/K/PX0P4HpW6V2QIv8ApAMKyEHcWbI+9T/mjbyYVPHft71Xk3Wsm4gt j7pzwwqVpGmAkkm5+6FUdfagaJmuHkU8btuPu9qWGYBRHIpAPX1U/T05FRGN2x8wQZyFB6fWnyKs n8JMg545B4/Wl6DLdvcfZW8z5ymce31qxPBDt8yPDK3UA5rJhl8qQLtO3ryKuQzQlWRlKMeVp2BM sx2cLKJVGzPAxzVm3WSCNWjxnu3c1Rhkck7p2wvHPapbe4+x3XltwOM+g+hpWGnYXVNcW3SGGaJf mmxvOMgY/wDr0y4kaOxkhVn5HBU4J5z2o8Y6TKNNj1KGRHgeTb8vUHBI9xxmudsNfms41tp4/NjH TPUA0WTWgm3c1LrVo2tZDGATwHXGQPr61iXHk28e1ZmdnIOelWLnW4G/1NupVuoYdKzrm4+1bdsK IF/u96aRIxHYS+b0Oc11tvHJJapJExJx83auWtYGklCY/LtXV2Ui7RbnavyDHYZ/xpgaTL/ahhkl cqREAMDow4/EYFYbakum3j/KzmFjj0P1rWvJZrOS2+z8lIssMccsTz+Fc5rgT7RIyhhvwWB/hY9a oRDKd1jFI3JLHqa7H4Q6umleLrMXDYhkby3z6EEVxUcw+y+S38LZ9a6X4e6HqGpa7DNa27eXC252 xxx2qJOxcL8y5T6pbWPDuSFZGBHfvUVxr+i28O2NUz+WK4b+xdbC7/sr8d/aqt1pOtbWb7O+Bz6V 6EMQ1r7M6p3t8RoaReW+sfE61ZR+7hTKj1Ne3r8pPrXzp8Nmb/hPAZT1JUj3r6HC8d81eFfPKcrd Tgr76nu3wniz4bRlJCmQmvQ9PkfzPQCvPPhJIw8LxLwGMjH9a760kX7QKE272CNkjqrCRUIHSujt pGKqrVydk25xuGcH16V0lvINo2sPlpxTBlrO1u3JqeOTau78KqNMvLN2OaYtz+8K9M8j2q27E7mg 03zZFQXDbuF4qDzMH5vSmSSPyw4pe1sPRFS4crJhulRmZY2Vo1AHepZozIw9xTPsvydyazcuYtKx Lb3Ekku0dK01baysRnFU7O3wu7bjHtWlCm7kKcelVFcyuTexqWbQSxhgoq+BHjcvFc3Dc/ZZ9ucA n1rVhvd3U9azlG25W5f4UjHFDMrLtBzUasGx83PWkCtuKt0rJOwxVj+XrjmneXkcUZ/h60pb0YDi hRsgvcZIqrjp71SmEiyBweKtsyt8pNRyJuX6VTKTCOXg4zkUvmIwGW9sVHtweOlI2VxxW1O6XKOx PIytwM1HnZ9aSJt3XqKbN/eXnFdURoyF2fL8ufr3qZeny8Z7VThk8w/dPHerKszNndgV5l77mjSJ Y12jd1560/d/FjmmPKqr97P41A0y7R82cn1rO9mFi5nd87YAqFpvmG0cdKgllbyyg4NVJJJFVVxz mp5ug0jQmmCrtVeDzULXQ8v5c1U8xip9fWkjDt8u7nrQ2irDpLpo3AXPNNmuduD+Oalg02aZjIRx 25qy2lKmTIcD61DUpILo53UtTZlMcLE+3rXMXjXkkZGxs12WpXGm6fGSkalveuYkvjdTN8u1M1C1 ByOct9AuppQ82Bz1NbEeiW648whsVcDNtwoxn0oXdsPmMf8AGm39xGiC1htYsxrGNwqTjdnkGq5l 8uRmA5qzEyMm7uetJthqyZ5FwF9TRNIY4/vYNVJpo9u5mxjmqB1JnkZj26VG+4XNCS8WHHPOKyL7 Vsqec1XurwtJ5hkIArFu7otn3polsju9UmkmC7TtP8VV3mJVixzVa4uCG2r1qOa4/dY4BpW0DcGm BkChu9WfODbVXqPesyx3STFmXIq8rbZM7eBTYNHzr8YoVHjy73clkT+VcBrVn9q0+ZWU/wCrPvni vQPjDubx5csw4MafyribqPdbyruP3G7exqIe9GxSPI7fT4d0iqudrH+dWxptuzbiv1p8cZDTZ/vk VahXDbd3PevLnOSk+U9jDwjKC0I10ePcH24Pas/4v6BZxeCbXUjaxGdW2+YEG7HuetdPCu1VbqO9 V/jPCB8MIGHXz8c1lSqydSN31RpiacY0paHzAPlb0A4rZ0rascp2/wD16x+jfWtfS5NsLtwQGHev oNz5strBHJI8srBEjXPPf0H+fSkVvnYouCQeB2+maY0/yvHgbWIP4896S38xrgYYL5YLZHbAoAuQ tCY5Le4U/N/q2A+57n2qu3mWjrvUFT0PrU1vLaysWmRwrKThfXt+FJmRkKuA6Ecg9fwPalzWGSyX VveSPJ5IQFcbR/D2qaM7pBjoBge9Zwt8sXjYt3x3FJG0kbhVbB/lTsCZcmt5GuBIq7Rz3zzSrGyt 8rnpyf5VGtxcbVYR/N3PXNP8yNSxXAJ9aFoFxVjb7u7OPfv3qYTBV2uCwThT/nrUHmKyj25z2pUk 8wkrHz97IxQ9QN7S5dLurWXTdUaVY5l2pIq52NnqR+Nclq+g3mlXDI0ZdQflbGQR2579RWisrQL5 i/Muc4at6HXhMsUNxbpcQ+WRsfPBI5IIOQR1/oaNegbnnTRfMc8Y9sVLFaTTMEjjbOa9Q03QfDOs SwIoKSy5Xbx1xwM4z6+vapZtN0/SY18myU3EcpVmc8DHYY4NJye1h8pzen+C7q30GXV7tlgXgKHI DPnrgenFUo7bzIyq4JB3Z7/WtzUXe+VmkuZGJz8pPC1isz26fZY9pzyz/wB7vwfSnHzFK3Q1YFV7 5XhkLxyKu098AYrk9akDXc/zcM56j0NdJosm66EkykgDOB24rA1NLaSOaZZfn35APetNWRexU02M SXUUci5DN35r6V+HdlaW9vHIsSKEUYCjqa+b9DXN5D6Fh1+tfTHg2Nls0Xj7o6VzVJcs4vzPRwEV Jyud/JqUKw42Lis28voPIkLKD8hx+VV7j7o6is7Um22cmM8Ka9ilipWNKtCC2OM+HcfnePA33T5p Ofzr6EBAHIyBXz98LFU+NdzLkqzduRxX0Iy4QZzzUYHVSb7nlYr4z274Vhf+EZgk5wWbp9a721UN ID0964j4WxY8I2/ynBZhx9a7KObyyNwPFbRSM0dHbzxwR/KcVraTqHm5Vuea5CS44Bzwexq1Y6gl swVZOaprsPc62WZfMK7iRnoKQ3O2VJM9eK5uPVvMyfM79etWY7tpCGXOF/nWNSVti1qdJ5zTYVRg jvU0e6T5Wzn0qrpv7xQ4yCa17eHuRmqinJaiYyC1yPmAzT/suJB8tXI0PPy1K0Xy7u9bez6EcxXj h9uBTGbb93GKtSN8hXjGPyrLkm2ybN3am0ooFvYS4+Ybi3zCoYr5o/lOeKW4k2qPU1RmI+8eM96w kr7GiWp1Njf+Yo39q0twkXd3rjrO88sKrnrXQ2158oHFcjvsUaK7jzSn5eKVcbBjrTty8bquKdhF d4m3FlxS/wAPNSjaVZevpUDj/ax/Wmo9Sk7kQbaWPBA4NSfKyhuMio1IOVwCfp1o+ZV+7W9NvYpg cxudvINBkXlelSRsu3c1Ura8t73zJIVYAMVO4Y6V1Q2BasxIZFjjy460S3Fwwzb4Pt0ojgYqvOVP NTR2+6QbQeOTXkWe1zpZXMl042yxbR9e1TqPu9TVn7KX4YgentTliG4DH3am7ZLZWZWaQKRk9eal W2aaYfLwtXFhAy5wAKWL/WYycUeo7lWaxUycdO9Si3jjX5FAarq7cmopmH40rE3F8xY4/cVkaxqD JGcNlsVJeXoiXIPSuW1LUJpnPT6k1nKzdgtcoXW64kLTEnnpmqO7azbVwuT3qWaRpc8jdnH3qqSj y4wDIDn0qgepZ+1LHGWbPFR/bGky3aq0lzGqpHtyD7VE1wi8cADmn5CvYvLKG6kce1Ourry4RtOC ay/tjGRiG61HNdfuh068Vm97hci1DUJVbZvJ3dhTPtDeXheoqhOftEmfTvVlWHk/LgkdcUNW2Jvc ZNcZBBOFAqhIxkkGypZMtnPrRBCFyxrN9xGXdN8+T1/lVaY5jY7c1buISZW9z61WuSsMZ3EcU73H cfpClmKt2q5tEbHHSs7RbxfOkdl+Xb+NaijzF39AeaTEfPnxrXb40O3hTbo2fzrhJG/csvfYe3Xg 13/xu/5GpGHU2459etefTKzRH5sEqe/tTpq61/rUa2PMV2m5mUdpD+NWI1b/AIFnjPaqVgzedOX6 +Ycc10mg2S6lepHjao+99K8mvDlblsj28LP3ESw2zMq9cGs341a3okfw2s9HkvohfvN8sH8WPXHp Xf6lp+n6fps972gjZ8fQGvjrxbeX19r9zeXdw8kjybgx5wOwHtUYGjGtJy7W/wAycwr+zgo9zJuI ZLa4MMn3gf0rSspI1t5VVcHg0zxBhrqGYciSFWyaisWAikz17ele7E8BlpmXqehp1vN5UmTGJAfW qxLHk4AxTVc9WUimBZ8x5HG3jB4/GrPmMzbYzgL1yenqcVQSRlYNjkc5zUhmYr5a8Z5b3oAuPgos keOp5z/P2qX7Qz43gSj1P9KqQsxjVVHUlqPOH2j7OAHGcLjPPvQgLW2KZwVZ4/c8j8O9O8kthS0Z Dc5P/wBeo1kcQhWkbbEcY9M/5NKsit0xg/xHv6UAOa2kXD7l2htow2RUkMKtIokmYZ67fx+laMui 6hHp66gyhoR85wfu5wOnrVaxs7i8crDGjeV8/PehO+wgjaKMGG1heRuSN3cfQdaSJ7dY921t5U42 Nt2HntzmmLHJDMsISQSbsbf4jnt7U0sy3ckPlhDExwp5Ix6+tPyC9ixI8y+XOs4TceB/Fkd6uQ6j dXUypcXBJfqR3+tVLjyY9LSRpgZjKSseP4cckn8qoQzPtJKhSW+XviqSA0Z7iSbKyNtVjjJPJx69 6jk33Fwm1SeiL26VAs3mOyspyB0z1qWOYeWirJxknbjoasVzR08skbHzAm0Yx0z71x91LuklKMcM TjPpXWQzeXp8vRpMYx/nrXHTP8xCjAzSqaWFE0dD2293BPcYSMuBk/5/zmvpTwbcRtYo9uRIrAEM Ohr5imY/ZLaFQM7S3616x8C9cuLe8bS55S9vOCUUn7pHpXFiIvl5+x6GCq+zqcr6nsGoXjwxgmPI HNYGpanJPEwVflIx6V1d8kdzavFx0ri7xSisu3p8tY0sRUas2elUSRU+E67PGzFsA5Y19BN0Hset eCfDVPL8dMoH3lJr3sZKjoDXu5ekoM+exP8AEPoH4VqP+ENtT6s//oRrro7aNs7xyR3rnfhTHH/w hVkWxyW/9CNdnJCqqGRcgY6VcXbYlbGXNasvB544qjJvjkEgPArdueY14JxxWZcQllZdvvVuSYJF KG+AkMbdCa29LuF8wrnrXKTq0E3TkVsaTeLvRWOCTzWUouQ72Wp6Ho53kbWrqLNehbvXJaFMokPy 4AFddbzbkG3oa2o7EyJXUK/QAGkkKjCsxz2p8j7lBXg1VupPmVu4ro3JS1I55Aj7N3J6VRkjzPk4 4qzI3mYk6mqbrNJOJI5MD+IetY1XoUlYgumZpdv61H5YZdpY8VLMnzH5enrVdtqqWyeBWUlqUncB CNw2twKv298iqFZjkH1rKW48sHd/FWZPdSbhIrlQCe9YzTexpFHoFnqavEOcnpV9XaRa4TS9SZX2 7vSus06+VgqlutY87QzR3H7x70pX1701mVl+U80HdtHt61auC1IW+VjtUYpkjOfu5wKlbnG7Jpqr uA+WtoX9CxYyFQ7hiq8kahWZQATzVpsbeOneq03yqzbicV1xVtWCeplKCqKB2FSQhm3MTgfWmR7v 8irEa4A5xivKW5sxFZfOWNpAGIOB7VMq5J7D+dMZYxg9W7mnQsrfL1xzQnfcixPt+QDd0/Wjy44V 9SfSo2Zmzt7U3fuA6HHY1Gi2AkaQKhbcd3vWZcXUuHy24H9BU07MzdeBWPq135a+XG3OO1RN3Gky pfahjcP8iuZvbzdIzbunvUd7qUxujHIcRjvWc1wrTlc4qoxuAlxeSbCytgnpg1VjupNjGQk896jm Y7uSW5pkkv7vyeST0qlYm5ZWT5gxyf0pLj5Rv8z72OM1Q86RPlbnPHHelX7RcZBRgF/Wk9BN9C5G u5eWwKhb94fLVTxVyOExwnuw9qghiKs8hGM+tZNajIDHiULkcU64jMP+qULu6/WiYsrDC/XFDszb V5qHYRSZNsY9Sak2/uflBBNTeT8wBxjNG3nhcipvcCibdmUyN25rPvLRG5mD7TzXQbfl5Awe1UdQ +YhFHC/lTbGYWianZ3U1zb28JWWBtrbv6VtiOSTHQZpkNhbwxmSOFVdzksBVmFti+WeaTYtj58+O sP2fxXboeSbYfjzXnUw3bcYzzjFen/H1UfxXaHnP2YfzNeYSbY/mbIJHBp0PdQzyWByrzE7VzM+M fWun0XUo7OLcijLHrXHrfxyef8pY+fIqqOpO6tKS5vrW1E40+WNR/EykZryMTK7cX3PZw8qdOEW3 0OyuNaa9sZ7EgHzoynPbIr5Z8RW7Q30sEiFZIGMb+5Br2ix8XRyXAhnXa5baDXEfFPSY49ce6gX5 bqNZ1x7jn9RW+AXs5uLW5z5hKFampwezPPry6a6jgVuDCmz8KXT22q3yg+1V5YyrFWGDn8qsab/F gjFeqjxycqRjucdMd6RlZlVuMA/d9frV3yVf5mbBHU05bWPcQrMfb0p3AzzH83XBIyfapCoVBlRz /nj0q81nnhY9y96k+zqoVl6gY+7QBnbnVSEYr+NS6fDLcXSqpA9T7dKuf2eG29S3UjHNWtKtdskm 7rjv2oegGpb2Nj9nFu0Py7ix55Jqxb+DZtSmSeFhHbkgEHqcc8CtXwzobahI1w8ZMUTDPbJPau/t dHxEvzYOPyrir4pUnyrc7cNg5V1zdDFexs5tMk037CFVovLVs+3H15rlLHQZtFhunumDB2VV2jPr z7V6kul7Vzwc8H61RudNhBZZo98cowy47VyUcW4z956eZ11sD7uh5dqVsG3XyqJZYvmUN0b2Ncc9 1JJdPcN8rO25tvuTmvStX0/+z7qa1U5TBZCe47VwU1tskkXywM5+bHavaTuuZHjtOL5WU12so25I 56ipBvjXcSRj5sfXp1p6w7Pl8v5uoOKc1u8rbm5OO/U0XEQxyIsgkVmy+c1JnfjcP4ufSjyW27kU ccH1o8raPmO4n9KL2AuTSMLCWQsuD0+nvXLty+7nk9uK3LpljsWXJOeawlB/EfpRKXMwSsXLza0k YXoiAfSvSPgysjaw1z0itYTz7mvNIYy3Xvwa9C8H6oPD+kPcglXum/QVhWvyNROjDW9onLZHusN8 CQobrz1rE1eMLMz8HIzXJaDrGuaxIGtkY7j8qhetdNfaZ4is4Vm1ayZIupz1x64rzIVI06ns5NJ+ p7LrU6kdCT4bIG8eMV5Kw17lJH8o+btXifwtjC/EK8WJshLYH869uY7sd6+oy5NU3zdz57GfxXY+ i/he2PBNjFz0PP8AwI12fnZRY9xz6Zrjvht8vg/TScfdP8zXW29vH9qNx3xQtNSehO8DCF2bqR61 WKhlJwTxWjMyvFt79Tg1VijVdxfPAqhnN6lbB2Mir0NQQr5TAr61q3CbGY44JzUP2dVBfBp9RWOn 0e+2/wAXVRXYadeMu1S2BjvXmunzeXMnzdq6u11DMiKDwtawTiLd6nYtNnJByPaoLiQuoyOKqw3G 5S3QUrM7R/LnrTcmwsBYhWXbyKcqkKu7qe9Nh/eMVIBpZN3H+zzSTDchkVd27dwP1rPvFC5C4AK9 qt3iybt3RTVGUOzheTUT93VFIqsdqhjgY61Vu9jgvHgFelWLpG3bVBOetVJty7VxkGsWi0R2tztY SHg9PrXS6VfLtBBIIrmhEGVt3YVNpUzK+N3HesZLqNPQ9BtbzzFB5PFXlkWRdvOK57TpNoGQTW3b t82O1Ebp6juSqOqnvTQGXPv7dKedvTNB/wBqumAXI5uB9faoGbKfdyaluPu4qsNyrtwMD2rouUii ko8v5cc09ZNy7jx+NZ80jbQysTU9ooEP7yTA7V5SkbFxfm781Kv7sHGM+tMhkiVc+Zntik8wfw5J pPTcTJI+STijaW9waTzFC56mhHbhnfHtil6C3K90yrlV61z2qNhSw5OPyrbvriPa3IJrl9Xvo4bc ru5NQ07WKSscdqkxjkYYGTnPtWPHdv8AaCdpPXnOauaxcecx2n1rOt4y8g24960TsZtlqNpLn7vH PpVqawZVHzduaktoDHGoBwC2STVuYdQo6UmOxVtbGH5QwyV79auvbRxQ7uv4UkUKsvUr9Km1BR9n VY2J4qW5MdtDO+0IrNu5NQTTYjzwCal8n5GZhk9uapusin95jGeKlskja43evFKsnQs2f6Ux1Zst gCmk7V781lzN7iLWSxPFMV9u7sTTI5sYUKKW43cEL19qQEijavzYyaozI0twI16VZaQRrg9qbYR7 rjzm6D170mubQCSWBlUL04pI4ljjLNnd2qcf6TIWZcc96iunVGIXntS3A+f/AI+M3/CS2cgHzfZ8 fXmvLLwhg0jKVwpx7cV6l8fP+Q1YTHgmFh0968sZDNG0e7grinH4WUrHBfBHR9IvL2817xFG0trb XEhSP+8dxNez/GD4reDPHVnp2haH4H0/RLXTbNLdvs4G6dgOZHJHLGvFvBt02l6Pq2kLIpuILyQN Epw+MnHHcGsy6uZbiT5547Qk4bBy5r47HYKGMxntKqu425fLQ9LDvlpLXRmjP4a8JyaZPNqF00N4 XH2dY+nUZLZ6Vg3nht/FjaZp8bhzHM1u0nX5Mg5/nXa+FtN8PxaZdarqCi4MCswkk5C9eg6ZrN8D 3Vul5bwswE09wZMdwCeP6V7GVc1StKGuhz4lQhGy6nz34y01dH8R3+mr923naMfgcVmWTbS+Oa6v 4sWoh8dasEXA+0Fs1yMIIO7pivfieaafnbWHzdP1/Cp0ulb+IDHWsuSXPGDyKTcVyFOBnrVgbcUy ttCkjOeM1Or56/d9z/hWJFdFWDbjWr5kbIOgyOKlgWUkXJ+7VmxkIuCMgK6/L9RWT5yqTsY+v0p0 dyoO7djvTYj2HwbJDFovl8FzMSwz0NdXDOrKN/BPbNeQeE/E0NnMbW8lKo7Da5PAPvXpVrfRn5tw OfumvJxVNqpfoe7ga6dNLsbfmKM/MMH16CmXE6SqItuCR+dVftcJC7cE9OPX/CqOq61Z6TAby6kC xx8nJ5PsPWsadGM3sddSvyq/Qw/iI0NlJB82GMAZhnnqa82MkbA5IJbqM1a8TeJ5fE2pPezSbFb/ AFa+i9qxWuFUkFxn3r26cVTionzlaftKjki58q855+vSmiRccKByeTVQz/LnIwe/pUZuF55PPNUZ l12j/izg9Oe/rTGZQwHf1qr9p+U7R09/8/5FRNc7m2jI/GhbCH6pOrRFN2O/SshRtOatXMjNwx5J quqjPOMUNjNzSdJuLyzlu4V3LEwDY4612/hPRI9a1OKwuuLe3i3NxxnGarfD/wAu38P380jKE8wD J5z/AI10vgu9sbbWJIxIvl3UZhD56MOlcmLc40pShua0lFyVzsfCck2kyNIscYSBhsXb/Ou60q5v /il4sMurxmWxsLby3VVwMAYHT061xuqafd6Dp9sbiSMS34Zkiz8yrnALemeuK9G8I2+j+GdGiaz1 INLLCZLyUHCjPJH9K+dqYeU71ba/8N+Z6XPCMVFPc4LwbpJ8O/FrVNNhkHkeTlfXbnpXsLN0K5GO 9eQ+A7xvF3xQ1nxBZqTYW6iEOf4sf5NeuSq20DOOa+6yqL9h739aI8Ov8Wh9LfDhUfwbphxn93n8 cmuo3YbauTiuW+Hq/wDFHaaobGIuK6mOT5ucevNVF2joWh6n5vmHFF1MGj+XqBTZGHUnGaUqJVHY kUc+oWuU2USc47cU0xtHHzk5qZkdGXauQamWPzlXHbihS11GVFj2sjJxj0roLGPYFdmY/Ws3yFjy wbp0xWjYy4AVuhHrW0XqTqblvdDlcEVOryLlTyGqhbx7ss3r61cjH8PbtWvM09USTRyLGwYcA1Mr rzuPWqsvHC9vaoZ53jUNgnA6ik1F7gackYmGMAHpVC6t3jO4dQKLe8Ztpz6ZzViaZZFI46etS9di jFnY/K0g2huOvWqTSLJujPUVp3SxtE0R7c1iPG4kYoDkGudu25a1EU+XIc5I6mren/vTvj7GqcKs 5O/nj9DV3T42glyc4PvUSTtcpeZ0tmrFFbuBWtZyM3O04xjrWVaTKqhlwP61r2TKqhuOaiKsPQsL nf16VK3ao1aPJPrT+GHvW8ASuQ3DZUleoqsrH71W5CFOBjJ/WqTMyuy4Fblx3MuNmYBc5YH605Yo Y1EaqMn/AOtUdrlMFv51N5m4MTxnpXjvXU2GSSPxHC3I6+lTwx/LmaTfj34qCFW39Dk+/WrbKqqA zjJ7Zp37kkisvLKcZ7Gs+6uJoskNkCkurpY5DtYYUd6wrjUpo97QhHz6Gm2VoRX2rbVb5iM+tc1q GofaWMYkJA65qbUtUvphtkhCg+v/ANasqSPaxk3gnHOBVadRSkZ8yLLIcjNNhQK5fkAdhV6C2jZW beN2elPa0WJSSTu9aV7Gdrl1Fja3jI3Y4Ip/lgnPrTbP95EMtxnHWrk0H7r72KlvqWl1I/lVVQf/ AK6q6lINu0ZwelPLNH82c/jVG+kZu/T3pPuSwMi7RHn8agnZfMxuOBUalypywPFIVk4bP3vep31Q hFb5m64qMod3Tg9qsNGUAbuaAAJBn05rN+8FhsVuqsNw5/CrBWFzjauajkdriYQW6jPerM0K2uMn LgU7WGUJYo2kYN3OKc3l26/exgZoH7zPy89aZOqt8tQIatxIzbUXAP4VBceY3C5zU8CY9c0+Xytu 45yKQHhHx+s2WbTLp1+8HQ8d+teRo7HCYPFfQXxy0r+0fCZ1CMZeylD9Ox4NfPcbMOV5HSnTlq0F zlvE3w91C+1D/hJfDN0lvej/AF0RYDfjjj3rBvm12xm/4n/gVriRf+W0Y+Vjj1WvTI8htyt+NQ6t qVnpdo91qd0sNsv3mkbArKrhI12rr+vlZlRnKHws81/tyTU9MubfUrWS0hjG63t40wu7/a9a4zUL 6+spVurCRkMZyD3HevXNL8QeDfFEr2+m6hBcMDgxseT+B6/hVHxH8O7W6t5b7SYQskS7nhz94DuK 6KVKOGXLGNjnqXn717nguvyXerX8uoagd807Zdtvf1rn5oVhUhVK/wBa7jXNP+zq/HKH0rkLwHDe 9bEJmUzH/wCtTN3PpTnHPXtTMHPBNIof5m3HWp4b54flXjPQVVwfwpOv9aVwLX2pv7vWl+0j/PrV THymj7vQc0XAvR3iow9uvNbel+NdU09QkVzlB0V+RXL896X0xQ9dxqTi7o79vidq0ke1GgVvXbXP at4ivtXkEl7evLjoCeB+HSsL5vzoHr3oUYrZFSqSn8TLTTZxlh7UsdwsedwDEg9+lVP5ijOaZBdW 8254BppuF98fyqqM8/40vPIP/wCugCZpifmzx2pyyfKD3zVcfe25p43buKYErN5hAIBqSGPc3bjt UaZOW9PWrlquWUnjHT8/egDSs5LyCD7OkpWHO7bu71uaLNdQ30UyRvIVYHavP0qroul3GqX0Fjaw lpJm2rX0/wCB/htovhnT1a4t45Ziu6WRx3/wqoQlWfJElu2p5hbax8RNQvDfN4WN8SoSMuvQD+Vd RdeBfih4ojSx1TyNJs5sM0cLA8e+O9dRcfFz4e6TqB01dSRnVtpMakqD9a7jSdWsNXt1vLGdJI3G Qy9DWyyemqnM2r+iF9blKNuhleBfBem+CdJGm2eHJ5kkPV2rfaMvIN3dsVJx0x06Vb8P2L6trtpY KuTJKN3sOpr1FGNCnaOyOe7kz6H8Hxiz0CwtWU5WBcitlvkbOfaqMKpDsiU42KAPwq1HG0iH5gee ledFN2R07FltskY9TSbgNuT0qOGOTztrcgVLJFtk46bvWtowVrhzNE33lHap4wfLK8etQTc/w496 RZsRluOK2VNbsnmLULLJhXAOP5VY8povcdazre5bluTj9KtW92026OTgDNChYOZmlY3PyHqa0VZt gZcH6Vg5W3jDLklunFXoLllizuG407dAua7YaPeT1o2B4Sm3JxUUDrNbkNzSxSFceWVKLwT61KfK BDbq25lwQRnk1XvLqSOVWDE7fvCr+5WkLfwjmqNxslkO3jPB5pXYyG4aR2Rkzh+DUltEN5VupHek kykHQ/KcjPWmxzbmVjyOnWoem5RKtuq3GzGR7Yqf7KzSHbxjpUTPtlDZBIpJL5o39B9KVSHMNGpH Cyx/eb8q1bYusY6gVg2OqQScMetbkc0ZhHA46cVmoWsVca93LGxwxwDVpbwMgkHXviqUgiYN0yen FVpH8nC+vtVKTepokawuPM+ZutRTFi3mJjPesxZtq53d/SpxdfKfmOOvTitoybZSVmUFl6LuIHpm plLMm1VAHv1qooBYtuHHqKsR3KCPlgBXk+poy1CqxDHA/Kql9eeXlj2okuC0fy4OBnhqw9VucAtu 4xik+w0gvNTeOF2LEMfu1y1xqU28ru6n5j6VZuJpLls8FF55HFZFwDmRuMe1a7Et9hJLqS6m25JA NN3fvivOKLOFY1aRV59atQ2+5SzKcn27U3qiUV40ZZg3Ye3SrDAT9eg71NHCsZHr0p3kscKEGKmT SY7NbFvT7ZRbg9qhvLjHyr0HBqx9oWCHyxtwKxLi8VmdI+vNZt3YmxXulGV7H0qpPI0mAucdTmm9 Iz3oVgsXzN+dK5DegbNuSWIFQibzLgKr421IMsoxnH1ohgbc3lpuajrcES3E4DDbwB3NRQw3F5Nt j3JH3k9qtRWqhi1x0H8OKs+aqwhYkCr0wO9Ta40Oihjs4tkT72/vbeTVe4YuvzZyOaSSbkLu4HFR XEvlqArdvWp1Q72IiaYWxls1KYmVfMfKlqhdQ6nd0osLYRZ8Kzj8KrPcMU5XHP505eRs4wKqzyDz trNwO1LoBFremxaxot1p1wu5LiMoR9RXylqmnyaVqM+mTrtkgkKYPseP0r6zll+UKpPNeQ/GvwSz RJ4o02M7lGLpVHUdj+FZykqcuboM8hiPzBWX5SQDzXAftD6TfSabpy27t9mALEL0ZvU/T+td2ob+ FqsXsNlr1immaxGJI0+UE9vxrqWqsZTjzbHx7YWuq2N/FNprSpcK4K7eue1fXOjyXi2VncXylblo UaUY77ea2dD8J/Cvwzbi8tdEW41PHyvIxYIfUA8VHNIbiR7hsZboBReXLqrBFang/wAUNJW01u8t 7WMbWPmIPY8/1ryjUI/K3KVIxntXvfxWt2Gui4WEEPAh6eg5x6nj9TXjvijTsqZIc4c8gmrcbGKe pxjJ/FzzSeW3bmr0lq0fVaPs7f3TyaksoGPbjpSbPTir6Wc00m2OEk5x0NX7fwvfXA4TB96HYDC2 fzo2fj3rek8J6uinbDu28cVD/wAI1q24Kti5J9qV0BjqtKq/hWu3h3VFJVrGTj2pg0PVEb5rOX8B TuBl7QMUu3k1qNoOpIiyNYyYx3HeoJNPuFb95Ay/h/8AWoTApbfRsfjSbfTORV77FMVH7p/w4p6a beSEhLZz6fL0oAoqu6hV6DqK1odA1Ob7lo3HfGKlk8NajEpYxZ7cdaLoDFVTkMB79aesbK2R+lW2 s5YPlmUqeg4p0cT7tuBg9/SmBDHEu4sBjJ4rQtYWIH61GtuMZ6e9X7SEZ+7x9aEK5638B9Hiutae +lh3CFflb0Jr234hQ6o3w91htHjc3TQhfkGSEz82PwzXl37PcDCS9kb/AFa7Qcdc175p901pN8wV kP3lPQ16GEjam5R3ZlPXQ+HI9Dull/eIxPfI5/Gvof4K/bLGzFm5Yxkbvm6CvRvEng7wd4glN5a6 LFb3b/eIXC/XA4NJovh200VfLhUZPVj1NZUaFVVE5Kw242NcHav16e1eg/BvQTcXk+vzIcJlIiR1 Pcj1rhbHT59UvotOs1zLMdo9vevoPw3o8eh6baWMKgLCuGx3Pc12YiV7U0RSWvMa0Ay2W6/WrMO6 Mblzj61BtHmE5XnpVyP5lCbh0rJI16EisNq/NyetSKGkJw33agPyqFOOnFSWszK3sxrVSQi59qh2 +UATkfNmqxWP70bbc9qJmVJCSvJqBmxGWjH59qq67gNt2YbxuPU/jVyzZVJBPzN09qpRNx8o5PHF WPMjt5F24PrxScwsaDf6vDNkryM1LHJiNTtxu+tUDOHfbt4I6Yp4mAjVckN6VDabC1mbun3KrkO2 RViGRd0iD7meuaxYpl8tWXINWrS8Vt3UkULVjsX5CYMHOQ1UW3vKfL5wwJzxT5ZvORt+eOaZa/xN t6/7NKVlohrckmU7ZFZOCKiiX9zjaBt71YmYGENtH4rUCyrHC0eBuOegqUuxVx1ufPZlbP3cdO9J IyswHTHHAqtYt5kwYo49QeOatXXyws8eMg560RC1yjcRtbyFlYcfN3q3a6/KY0VyQelVbj98ElOB 2PPSogq8noOvWpk1FGiizoItSwF3MxOeauNcq4Vs5xXK2N1HMW8tlZVOO9bls3mR+X0xz61jzWZo lYtsI8leobmp4o22Fem3pUDLhlZORj0NWVkAjHQD1raHvbjTMNZ42UYx/wB84zTZJnxtXgVRt/NZ hGFckVfhs5D8p3BR7g1wtm/LYI5JDncwx9apalDLNFsVgN1bItP3fzc/8BpDbLkbu/qKz5tAuc2N LkZRbjPTc3FV7jR/LRYwnLH5q6tLVFn28888GlureNXC7SSPeq5myXY5A2DRKUC4z+tQGFo5TGSw PTg10t35Ub+YwBC9BnjNYdxMklyHBGAck03J3v0E1oQtu8wKuMrioby7+zkr39qJrgDdIrZJ9ulZ U8zTM2GHXtRdtaktlsXWYSx5Y9BWRcSYmwP4vfvVo4WP2FVljVm8zbnFQ7szJV6BefpTWjbafX1o U9S3rUqkhT0OalNSF8QsMflqN2ct61dh8uHKovJqosnzA7eB+lE8gRgQcCn5DWg+6uNpbc3U1Ve6 6fMcD+VQ3kjS4VJMHIpscR6ytgYo12BsmMzNgR8nPPPSr0VokMiszF2IzyOKqrIirtwvX0qx9qXb xyyipfvDQ2Yq0m3jFUrybY3lrg5pVuMSbnyBVC8m3XB2nge9Fu4XHFtuTuHTNZ8smW5Y5J7VZkm3 DvVXbIWzjn6UnoKxOvzevFSXFvDfQNa3EYeN12sGHalhVuRxip7O3bzN3HJqGkykfOnxG+HN54Tv GvrKMyadK2VIH+rOeh9q4kyfKdlfZ+oaXY6lZSWd9bxyRyrtZWHBrwH4h/BW+0WZ9S8MMZ7T7zW3 8SfT1rJVJU9Jbd+39dxWueTSzTHCR/O5O0DsTUN9qGpWF0I/kkSPHm7DkDPar8lviRoZYnilXqDw RWctndW6t5jB1ddgIXGADnmuqD1956ESTewvjLR4fEOhmW3VTc2w8yPHUp3X/PpXgniKESOIUU8d gK+itNuGSRV4wPWsm+8C+H9Rv5Lpi9sZCSFjQEBv8Kvm5TKVPW6PnJPD2oXpPlQ4Ueorc0nwFNMF +2SbV68DOK9nf4a6WihodXlZz95fJ4A+uaiXwCzZWLVgMtxuj4+vWo9pfcSi0eeQeB4LJpVtmJ4H J9TQvh66XfIrbCv3eO/SvRW8B6jbyFV1SKQDnJU/NT7fwpqDMpkuoD6bsj+lO9h2sed22i6w8Ms2 9SqL0YdT+VaOlaPqSyiS5t4mRlz6cf0r0+DwfcSR/LdWgDDHU809fBN4uf31s3piT/61Lr5+jCx5 feWaxzStHACAwB49aLTR1muAs0IKhd2GHXivTf8AhDbxZPm+zkd/3gyan/4Q+9XDfYxJkYyGX+lN vo0K3U8i1rSpIYIx5Zbkk4HaufmihuHX9xhxx93rXvcng/U5Af8AQMr06j8qgb4cXkhO6zgjKn+J 1pXstNQseG/Y4mB22p3Hj7vQ09tN+yqWVGO49NvevcIvh7Mi5X7KrE9jkmnSfD92xuktenH+cVol fp+DCx4lHbzyDbHbSbj/ABe1Ium6huLNaOPrXtjfD6ZfmW5gB/3apTeANQk+RryMDHZapUp9haI8 duPDVrebftULK3bjpWReeD2Vv9GVQB6jn/P+Ne8L8K5psFtWIyfmAj6frU6/B+zK5bUpDzz8g/xp +wqbqLFdHzZceHru3Y5iaRTyGAqzpeh3t1MlvbWrM7cLxX0kvwf0Xb+9uJmbt0re0PwH4f0RhcWt mPNUY3NzWkcPWl9mwrozPhl4QfwroKx3MY+1TNvc/wBK7ZDuHzcGhY1GN2AB2pkhbcBGoP065r0q VNUoKNzNu7LMMe75gcmnRWlxeTx2ttG8k0jYVV5Nbnh3wNrWtAXEa+TGf4n6Ee3rXq/hHwbp3htR Iq+ddP8Aelbr+HpWdTE20p6v8Bxp33K/gHwCvh22/tHUFV76T8dg9BXZRyKRtOevepcHy/mXqfWq 8i+VMGOSrYrns023q3uapJaFtlTyTwdwNSIwHlkjmorhdtsXJpnm7ok284HNWtAtcvMyyPuC529T TN0e5So+61RWbbWIC7h71IY/3nbJPTFVfuCRNqCjbuXkj2qCJlkQq3bk8UtxKwBQ9M4ql5hjkzuy D7Um2x6E+7y22r+grzKT4+aDJIl9/wAIn4ij0N7RNSOsSfY1iWwbGLxrc3H2xIcHlmtxtHLAKCR1 fj4hvAviX5jxo95/6JevGviYxt7jVvJzG0/jS9jlK8eYn/CEyttYjqN0aHB7op7CvmM/zbFZfJRw vLpTqVHzJu6p8nuq0o2cuf4ne1vhZ7GV4GjiouVa/wAUIKzS1nzau6d7cu2l77o9S1n4yaXpetRa LpvhbWdZL3L2IurS4sLeFrlCokij+13MLzFCwVmiV1DBkzvVlG1efEDQ4/Bl18QbKO91HTLSxkvR HbW7faZfLB3QrE+1lm3KU2PtKvlW2kHHhMmnyaDda94d1nR9LEt3qV6bq61ZbiL7NZz6zdX8E9kw tpEvGK3CFoxJH5clugY5IK6Ta1p+m/DO2tdWiuDpx8feItTvpIUyYIdN1nUdSDklgqgyWcSZJwfM x3yOOjxFiIYjExxCXLTjUklySjJckmlrJ2nzxtJOKSV+t0zeeVU50qMqW85RV+ZNe8rvRK65Xpre /wAj2TSfi14Zm8Jx+MNXW70WGe9utPWxulS4vGu7eWaKS3SK1ebzpc28pCRF2IU8cEA0v4v6IfDe s+Jte0HWdA/sO9TTrqxvY4JrpriRIHhjjW1llWRpDcwqiqxYs4XGeK4/Vvh/pDfAJvDnjrQNH1e9 03Q5tQuzcWcUsX9rG3kee6jQrtR2lkmYMoGN5xjNamgeGdH8Zf8ACwvDuvQ3EllL4ls5SLa8mtZV eLTtNljZJYWSRCrxowKsDx6cV7DxuMp46jhJct50pyej+ODprR3+F876N6bnF9Xw8sPUxEb+7OMV t8MlN/f7q62Nrwv8bNL13Vl8P614T1rw3PPdCxt5NRlsJ43utjyCBjZ3M/lOURiPNCBjhQSzKp0v F/xY0vwf4g0fw3J4b13UpdUmtYZrmwgiMGni5uo7WB7hpJEO15ZDgRiRgscjFQBz4J4XkELeEtJb RjoNusnhLTb2yPhy/tW0aC3uLm4tkMtyxa7El2qWvmA4QyNI5O6uusYZvFn7RRuprYeVa6hJJDK9 ozQ3FhpNmIghMjfLKupaxMyvGvItjzxmvNwOdYytTlTqcsqirRpp8kqd1aMpPknJyi1Hntd2aSkr xav04nL8PTmpRuoOm5v3oys7yUUpJcru+W+l1dp6o7vxR8c9D0LxIPDOneG9Z12Vbk2Uk1nNZW8S XACFo1N3cQmdlEi7vJEgVsoSHBUUvEXx78J6XbWtxoel6t4i82zTUJ1s/s9r9jt5JXhja4N9NbrE zSxSx+WT5gaKQFBtbHl/jjRdL0LXdX8DaFdza7c6nqwuLkCzglms3utQm1Q6Zahzta5nJDMzbFt7 eGO4lZQkbNa8O+GNS8G/E7wL4f1C7jkv7zxJNf6l9lkYwG5u9M168mjjLAFolmlYIWAJCISM1niM 3zSniKlGHJbmjFPlk1BynZc3vWm3D3mly8t0ne6Kp4HCTpxm+a9m90ubljdte6+Vc2l3zX1tax63 pfxj8J/2JNrmsNd6JPZX39mXOm3cJe+S98kTi2jigMn2iUwssgWAyblJIzg4saX8YNBuvDeteJvE Wl6r4Yh0O8FhfW2piCWcTNHDJGqLaSzLK0guIVRELOzuEC7iAfEfhv4T0Dxl+zxOvinQNP1qOz+H +i30K6hax3AiuV0uXbMokB2yDc2GHI3HnmvQLXw7puvaH8R11jW4dGstO8U2OrS6hMqmK2FlY6Xd 733EAIDACxJGBk5GK3wOc4zFSw8XGLdSjUnZJr34OmlZ3doy53pq1pqFfL8PSVWV37tSEenwyUm+ i1XL5ehv+GfjR4f8Qa1/wjeoeHdY0SZ71tOtri8lsZoZrsK7eTm0uJjCxWNiPOEYJCqDvYKe8KKB weh+YE186fC3w1r3ijxHp2lx2F1b6NoNvoUF/PfQrHeJDpxku7QTvgl765nnjnmi5WKEncyySqW+ jZMC6MLKfn56YFdWTYvE4yjOeI5ZJS92UU4qUeVapSlJ25uZJ3tJJSWjRjjaFGhUjGjdaaptNxd3 pol0s2rXTbT1RJDYxt8ykKc5PvWnblmVCoUY4PBqpFDsyvGO2TirEJ+UBen8XPFexD0OQ0UbavzM MHrxRcNvULG36moI3jVT8w5GB81LDIvO5gTn+9XZBcok9SlCBuLPGNxGMmrMPy5GRiqCzN5m3dx6 5qyHxj5h/wB9cV5dups1YuKFfAVj/Sn/ACK24kcf7VQiTaoORkd80i7XXBzjP96oavuLYtNJ5e5w QT25rJnum+aRixPt0IqxeTNHDtUlc8cdKy7pnFtu2sN3PJGeaIp9AWhj6xeMyHa2c8daylkVYT8x 3+pq/dWzMzNt+UDg1lTQybTxgD9a1voZtkM0xb5VPtVeaZY18te3Wn7WjBZuPzqjJISzHBIHFJoh 6lllaYJyduKJDsAC8CnxsyWyH5c1XZmdm3cYrNK4rIlVgELFsAU2O48zOf1qHcFU7uMioMrFgq3F NB5F9plVTnknpTZpt4G48/yqssyyfeNNkkHC9sUWuIWSbDA5yD0qaZv3anmsyS43TBew60+4m8z5 QfzoavsMtPdbU2quM+1QpMyg9GOfSq/VBzTidqjqaaiugDpJPm+Zuvoahnb5dueafu3ctwBUe1pp /lOR7iptcCW3hLRjdip0g2/eHAq1FbiNVP0qRo8561DQXIYYl57d6tQJGuOaiV1VHbPSo47japZs 88Vmo3Gu5cmnC/L3FZV5cecxVunvTZ7tXbIcVSaT5izEc+9HLfoCOc8TeAfD/iBTJdW6rP2kj4YV 5jrfwj1S2LLpt6lxGc/I3DV7fLL8gVc8+lUXUtKGw35UlT5fg0G3d6nzhP4F8Y2MzA6TKwBHKEGg aJ4gjU+fo90B0yYzX0XKv73dwc+1TNHGtu6tGhyPSqUqiSV19wrJnzI0V1GxVraQezA0oZ048tuB 0x0r1XxVpKQyNOsYwa5OaFdp4HPpWsYua1IbscpLOzquVK+lLDJk4Ztp9TXRvDGzfdGab5EZH+rH 6VfLIXMmZltcJGw6MAPwqZJ4mYc4Hern2SHndEp/4DUbWcO7cI06+lUoNdBcwExlvlfcOozTlk/u Mc/WlEKjB6ZpVsxJlo1IIqrS3QnIQSNj/WEkU9pMqoZiacliGYNIxNTfYoDn5c8VcFJibII5l3FS celTrIucscinw20KNzGMfSrcNvExBCDH0reN0Q2VlkhKEdfSmLtydy1ptFDyqxgYoaBeMZroU7Gb RTTYtP3KuMKfoBWpHCpz8ozj0qSOIFgoUVSrNC5TOjt7q4DeTayt3+VTVq28NeILrHlaVNt9SuK9 O8H6XGlr5jKu9vauutYVXcu0VhLEVG/dNFTT3Z47pvw38Q3xH2pUtEJ6scnH4V6J4f8AhPoel+Xe SSPdzJ82ZDxn6V0wCk+px61csWKs0MvANZtzqaSf3DSS2KttDCgKouzAOABxU1krSLiRTkcZqb7P HHI3B+uKLcbXI4Iz/dpxVhsssqquxh9eKjfbMu3AGPapnUOBJmoZF+ZTHwO/zVoArN+7Eb8gjuKh m/dxrsP3uDinXcix4hY4Y/d5psh/dhWILdeKLCJoZPs7DawAxzVqORXYMrDOPzrPuFfbwMYHtT7V iuGHAIxTskNMt3LKejdevNVGePI7jPXNTb9ytluQfzqtPtRC2Tkc4okgTIryztdWtbrS76MS2t3C 1vNHuK7o3UqwyCCMgnoa8auvhR8Vtau57HVbjw9Ml6GFxrA1STP2trMWMmpx6f8AY9qXDW2UEP2o wruJwxJJ9nt5CzGQFsfzq9bnbksTxXm47KMJmjTxMb2TWknHR2vF8rV4uyvF3i7K6OvDY2vhE/Yy te3RPVbPVOzV3ZrVX0PHNZ+FvxGXXr6Pw7fQanpOoXk15cpfeKLmxaaKS48/7LJH9kuQUjYsqPC8 BMRWNgdu5oNW+C/i+O70TTbWbQ9S05Vvo9aurqSSB5U1HVYb7U0itRHKjpKIWjRTKrRiQne5ANe1 ecI7jcc4PNOuCxTepwfTFTLI8FKrKrKLblbeUmtJc1knKyXNq0kk+t0gjmOIhGMItJLsorpbV2u3 Z9djJ8U2N5rfhrV9Ft5EWbULGe1jaRsIGeNlG4gEgZPYVwU/w78SeMPBnizQ/GFn4etbzxHrNnq8 dmkranY4tUsvLhmMsMRkSRrPDjYMLIcHIzXo5cHcvIx7VAknlsG4POM7a7K2Ao4isq1SN5KMo7/Z lyuS7a8sfPTQxhiqlOm6cHZNp/ON7P8A8mZ5l4I+F3jS3v8ATdK12203RtB0ptNENvZa5Nqj/ZtP dpLOyTzbO38pFmZXMrNLIyp5Z4Ksm98FPh94y8H6jqOuePofDkeo31usarpNxNcp50l3dXd5MJJo kdBNNdD9z8wUQp87Hp263ClgytjHXirP2hnZdrZ/HpXHhsjwmDalTi21Lmu5Sk+Zx5Ltycm/d93X odFXMa+IuptWtbRJK3NzWSSVve10PIL34U/HMeKJfFGiQeGIr+DUdZks9Wj8QCC4mtL26V40mil0 i4RXjggtYcqxO2HG4g4q63wl/aAjXS/El1rnh7U/FMTSO00moi2/s6VJrxYJoJl02SOdmsbz7NIH tUX5N6/MxNe5WN4GhC7xkDPWtqOZJkVm5PtXDUyPCcs4WlaUuZ+/PSXNz3j73u+9r7tu22hssxr3 Urq6Vvhjtbls9NdNNb999TzH4efCLXNB+GfiPwtex6VaahrGmtpdjZ2c0s1nplrHZi3trYTuiyTK pDyGVo1bMrLghFJrS/Cn4nXXwz8Wafe2XhuHxHr3iXTtahsotZuWsTb2509XhlufsqyfvI7OUECB lIkCnILV7bZhPlwoqy7bl5HBqqWU4WEI01GyjCVNay0jLl5le97vlXvXvdXvdsTxteUnKTvzSUno t43t0t9p6beR8zeFPhr+0n4b1OwtYdU0HTPD/wDbBvr20g16O7Xyprs3F2qo2ixSOz+ZMATcKwZw S3HPuN1aHzY2I+Ufxba32Zclccis3U/ljGxd/I7dPWunCYGngafsKV+VbXlKXS1rybdl2vb8Sa1e piJupUtd9kl+SRCVVsKN31yOalgGUZSvNV4VZvnXsf7tWJUSNdw4z/s16NKEviMnoN3Df5eCR0Ap rP8AMQ27j/ZpflVtyqckZ6U5lG5WbnPeu2KFcyo45pJ0YO4HXC4wfzq1I3ljaN3X24qhBIvmEsOR 9KlZ/MfnkLXkW2Nr3L6sWT5mYZ+lOjPlyH5yQfpVTzFVOqgdf84pfMkblQMmocb6hctXnlyLjqR7 96rRw+Y21uFHT3/SkeRtoJz+JzUDXf7wKWx/n61XKG4l5b7iFGTkVmXVrH5e3bitTzlc/OTt9xTG SOQjIyDz7UuXsGjOVvNPZoidpArL/s+QKcBgM13Uix+XtkwTWdd24CggAD0ppa3JlBM5aSFobfaC QB+NUfMznd/+uuhu4Vkhz0/4EBXPXULLv2q3FNakSSRWmuAzYZjgfhUZnZvuk47VTuJjHu3M341E Jtw3bsqKErkF5rhlxjOTzmmvc569/aqTSZwcDj1oVmyByc/jV20AsIf3wqZnZm7ZNQco3zA5+lSQ /P8AM2OfWkwJ4/lTDcH6VGyszAdP6063XczNuIpVdt/y9vxpbBuSrH8u7cSTxVq0tdrHdnOabHt2 7m42+1SxydTu/wDr1DV2Bb4Lbc8VHuXB6f41HbszIzN1z3qO4bA3A/LU26AV7iXr5fAz0qK6uGWL bk7vamzyww54OMVTnZpYgy457YpNW1HuSQ7mXzG5yelNmDY69fVaSBmMY3AZ707d5vy4x+NTy31Q rkTfKBwMn2qF3Pmr6DqFqzIPm29cVHsLMTzge1VayDca0K7s8nPvStu2Ffm6dqsRhWG5v5VC+1Th VHFS42Awde08XFmy4JYdOK8x1C3aCVkYYwa9lkVGBXArzvxdpphuGlVQFJzV03Ylo5LapG7sOKRv ZRU+3jH6Um3kDrW6XUzuQfKCFbBzS7Cy1IkTSScLyKuQ2qxrlhTuFylHaM+GbOM1fjhjjVx2IqRY wq+tAj+XpzTV+omUvL2nbzU6x8dualkhUSKf60H5WwvTHrTSYmV2Vclasw4XavUH3qNYz95s+tWF XcvpWsU+hI6RBuyvTFNZfu9qWM5+9ipjH90/zq9xEyKAB61p6PYtdXqxrkgGqCAlxjnFdr4L0xpL r7QV4HtRN2Q0rnVaVbLbwqgVhtFbVsq4D84PfFRG3xllx09OlPhkxGF46VnGPcsRYW84tu7+lWce ZMGGMDrSovy7eM0sce0btx5960SESb/Nl2ttIA96dDhWfPQVA2Uk3dPoalQjceTj+dWtBFnzNtuy 7mBHvUULOrfNke9IzZXac/lTWk+Zfl6f7NN7DH3C5Z22/MB3WqbSHd6Y46da1VKyfLt+Ws8RrJI/ QYzSSC1tiMT7iVYA9qITnhsDH4VA0W2RnOSV96lt2DFlbp9aWqBA8zRyFcjDGqeoamm07SGOMcVq Xdr5irtbJPH0qjb6ZH55MmTnqKUpdioq24aZcLJbkMecetatu2xTuI5/Os3yVtZGWNcCtCFi4Xg+ narp7WluTIikm/eBdw4q75n7lPuke1VbyHyZFZVO0mrKr8oYNxt9K2jG8iSrcY+8COfeqsXlyMVk AJ+tTSMytIvJG70qIDawk4wfar5SdRqsy53A4+tOhkdZPvNVeZljJyq8/wC1UEcjJI27C4HUmmox Qrs6uxuWz8rNtx6V0FlcA23OT26VyGk8rubBPtWzHI0cZ27iAfWspU4TNoOR12mzLsUllGOOnNas h/d/Ltz71zOj3KvGhZmB71us5aPbuzURoRsWpgw3NlQpz15qBirZjZcbs4qRZMISvX6VTmm2bW3c euOpo9iilJyIo2Edw8RCgdDT7zJjG5htI6g1Tu/M8xpI2A3dttRNLL5ey4bJPTC8CtIQsUmW432q rbgccfWpllDcbcjt81U4v9SVbPtu9KbuCZVWAU9sVq48ug1uZqthvl6jr/nFTgt/rCCOe9QxP/E2 4DpTvMLZkzj2xXi2vobJlhWVsK3IPtSSSiGPrx7gVXluFijXOM46ZqrcXCttxjjpxxRa+wInmvNq gbsY96zzcZkB3ZNJNIJC21sHHfjNVHR1OQ6AnpuptIaZpLdKWALAkeoqY32MgY9PasNXuIXx8zZ/ u/8A6qfu8zars3HJU9qOWIuY1Z5A67ty8Hj1pl1NttzvfOBVbzv3Y/eA4PSobwNJGSFU56EU3HQZ WlkjbCnBHp61nah5flOPkTI6CpjuX7x6eorNvp/lMh75wNtHKmZNs5m+lUTeWrLnPQUo/wBXg8/j UTyFpGkYbjnHSl+VsKAN1KMbkkzblix3P61Yt4Vhy8mM4qLymXBY4Ap8kn3nPYcD1qrCaGYaaYt2 H901aBUDbzUNqGf5jx+dSxqu44I6/wANK3Qdu5LCu3Pzcd81LGqqx9/So5FWNVUcn60KxVt1TazB Iubo0Xrk02P5l3bRioQ2c/XvUhbbD/Fkn0oa7Ba+pbimVY9vGR0qK5kXaF7VS+0bGG7r71HNcFiv pmjlW4iHUAVfbyQKjjYso5PNMvZFkB+YZz3BptrzGcryO9FrAWlyy9TmnLhctn7vtSQttUuGbkY4 NRmRtpC5xU2tqw2GnczbhtOfalG7aRlQT6GpNwXgZyfakbcqFtu78KW2oIdAu0fLn86ZLu3chh+N SQ52iRsAH1pkkStydpqGrDsxjKM88g8/WsLxZp6z2m4R9P8AZroNh3DgYHvUU8S3sLRqpI6daVkt QaZ4xPA0bFMcg0kVvu+/nn2rovEOm/Zbhm28VkMvTsK6I6mErkccAjb5VqZlAycULk89hRu4HzVd khO4EYAoTnPFK3zY29aVV9apCG+XuU9elV2Xq3Q1YZsA7VyaiYfMRg0NWC4ir8nSpYssoqJdzDA7 elTw/IAtWhCspXFWVwy7T1HSm7c/MKeqszbq0uIs2kfmTouOteseFbSO1s1LDazd84rz7wxY/bbp NwOVavTrP92AijOzHGahtJlRXU11VV/HrzUXk+W6r83zUyRvLQPz1FStIpCSAjNVdMq1h02EUj5t woUu0KnOQO3pTZGLMWOPy6UW/HyjAWmtdhWFO3jcCc+1SlgFLbcdxxVKa4Ec3l8daSW6xCwDcjtm q0QJMtSOMhuMVJNgAKpA4rIt7pnkEbZz1HNaqlpVG3INJO70HZlyxkYLtOTkf3qWaFYbh2DHaVzT rdVgRCq8twc0zUm/eDy8HK9jVxT3YmrGfKFLuyseRzxVSOTEhbdx7CiWYszBuG+tVpGWHgL973oe wW6m3byLNhWYflSzDZIGGOvesSK9ZJlC/d6da1PtYkXOeg9adlYEiy8Clt/AyPQ0i7S2Ayrt9j1p PtHAKt1HrVTznjkf5mwTx81LYdmX5PmjIfHB9KSRlji47D1qJp91ud27OOxzmmLNutRksAOPWr5m g5RjTboy3/s1O3fuQN2SDkgGqbTeSxGG+b/ZqaJgVG5uP92pTvsKxHcKsyN3I9qiaFiArKxBHWpV LNKY8jnjgdKduXbhgp28dTxT33FYu2TtGqgk4X/ZrYWRAvzMDkdTxWTYNG21ePzq3M8iqI9zBc9i P61N2jWMDd0W6RYzH8vBwDu7Vuw3SsxRc8d65HT2KjcWyRyBW5Dcj/WbSGHHao9pfU09mmbMU3zH DDB54NVpldoWX5gA/HTNFvcD1OP92m3DIvmZUD0O2tISkHKUrqdsquScLxmq91IzrHjIVeDyOfrT ZXVdpZsOO1RMN8fyKPUfLirjK+5XKW1uVY7ehx2Oage7bd/rGPOMbhx+VU/PMfzZTI7CnD/WMy7D xuA9apzlYIxVz//Z /9j/4AAQSkZJRgABAQEAtAC0AAD/4R1sRXhpZgAATU0AKgAAAAgACQEPAAIAAAAGAAAIhgEQAAIA AAAXAAAIjAESAAMAAAABAAEAAAEyAAIAAAAUAAAIpAITAAMAAAABAAEAABABAAMAAAABBkAAABAC AAMAAAABBLAAAIdpAAQAAAABAAAIuOocAAcAAAgMAAAAegAAAAAc6gAAAAgAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAENhbm9uAENhbm9u IFBvd2VyU2hvdCBTRDEwMDAAADIwMTI6MDk6MTMgMTg6Mzc6NTQAACSCmgAFAAAAAQAAEnqCnQAF AAAAAQAAEoKIJwADAAAAAQBQAACQAAAHAAAABDAyMjCQAwACAAAAFAAAEoqQBAACAAAAFAAAEp6R AQAHAAAABAECAwCRAgAFAAAAAQAAErKSAQAFAAAAAQAAErqSAgAFAAAAAQAAEsKSBAAFAAAAAQAA EsqSBQAFAAAAAQAAEtKSBwADAAAAAQAFAACSCQADAAAAAQBZAACSCgAFAAAAAQAAEtqSfAAHAAAJ TAAAEuKShgAHAAABCAAAHC6SkQACAAAAAzAwAACSkgACAAAAAzAwAACgAAAHAAAABDAxMDCgAQAD AAAAAQABAACgAgADAAAAAQZAAACgAwADAAAAAQSwAACgBQAEAAAAAQAAHTaiDgAFAAAAAQAAHUqi DwAFAAAAAQAAHVKiEAADAAAAAQACAACiFwADAAAAAQACAACjAAAHAAAAAQMAAACkAQADAAAAAQAA AACkAgADAAAAAQAAAACkAwADAAAAAQAAAACkBAAFAAAAAQAAHVqkBgADAAAAAQAAAADqHAAHAAAI DAAACm7qHQAJAAAAAQAAEFQAAAAAHOoAAAAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAPAAAAFAAAAAKMjAxMjowOToxMyAx ODozNzo1NAAyMDEyOjA5OjEzIDE4OjM3OjU0AAAAAAMAAAABAAAAvQAAACAAAADAAAAAIAAAAAAA AAADAAAAXwAAACAAABaoAAAD6BoAAQADAC4AAADwAwAAAgADAAQAAABMBAAAAwADAAQAAABUBAAA BAADACIAAABcBAAAAAADAAYAAACgBAAABgACABoAAACsBAAABwACABYAAADMBAAACAAEAAEAAADe YA8ACQACACAAAADkBAAADQAEAJQAAAAEBQAAEAAEAAEAAAAAABYCAAADABQAAABUBwAAJgADADAA AAB8BwAAEwADAAQAAADcBwAAGAABAAABAADkBwAAGQADAAEAAAABAAAAHAADAAEAAAABAAAAHQAD ABAAAADkCAAAHgAEAAEAAAAAAgEBHwADAEUAAAAECQAAIgADANAAAACOCQAAIwAEAAIAAAAuCwAA JAADAE4AAAA2CwAAJQABAA4AAADSCwAAJwADAAYAAADgCwAAKAABABAAAADmCwAAAAAAAFwAAQAA AAMABQAAAAAABAD//wEACAAAAAAAAAAAAAAADwADAAMAAUAAAP9////4Q6gW6ANfAMAA//8IIAAA AAAAAAAA//8AAAAMAAwAAAAA//8AAP9//38AAAAAAgCoFuYArQAAAAAAAAAAAEQA8/+gABsAwAC9 AAAAAAAAAAAAAAAAAAAAbAAAAAAAAAAAAAEAFQAAAL4AwAAAAAAABgD6AAAAAAAAAAAAAAAAACwA AAAAAAAAAAAAAAAASU1HOlBvd2VyU2hvdCBTRDEwMDAgSlBFRwAAAAAAAABGaXJtd2FyZSBWZXJz aW9uIDEuMDEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHMBAACbAQAAAAAAAAAA AAAAAAAAPAIAAEACAADY////AAAAAAAAAAAAAAAAAAAAACIBAADgAQAAdwAAAAAAAAAAAAAAEQAA ABIAAAAAAAAABgAAABIAAAABAAAAAAAAAA0AAAAKAAAAUwAAAEEAAABKAAAAIgEAADQCAAC6AAAA AAAAAAAAAABBAAAASgAAAAAAAAABAAAAAgAAAAAMAAAADAAAAAwAAAAMAAAADAAAAPT//wD0//8A 9P//APT//wD0//8AAAAAAPT//xEAAAAAAAAAAAAAAGUCAADt////wAAAAAAAAADAAAAAAAAAAAAA AAAAAAAAlwAAAAAEAAAABAAAR////yIBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABMAwAAAAAA AEf///8iAQAAH////ykBAAAAAAAAzgAAAAAAAAAAAAAAUQMAABwEAAAABAAAAAUAAAAAAAAf//// KQEAAAIAAACkAwAABQcAALIFAACkAwAAAQAAAEECAAAiAQAAUwAAAFsCAAC0AAAACAAAAMAAAACf AQAAYAAAAAAAAAAAAAAAAAAAAIgBAAAFAAAAAAAAAAAAAAAAAAAAAAAAAAMAAAAAAAAAqwEAAAAC AABFAgAAwAAAAJ8BAABgAAAAeGMAAAIAAAAJAAAAcQEAAHcBAABzAQAAagEAAHYBAAB2AQAAZQEA AHIBAABvAQAA5QAAAAAGAADmAAAAYgEAADUAAAAUAQAAKQAAAAAAAAAAAAAAAwAAAAMAAAAfAAAA BwAAADBFc70AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAYAAEAAkACQBA BrAEAAbmABQBFAEUARQBFAEUARQBFAEUASkAKQApACkAKQApACkAKQApAOz+AAAUAez+AAAUAez+ AAAUAdf/1//X/wAAAAAAACkAKQApAAIAAAAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAIAABAAAAAgACAAIAAgAAAAAAAAAAAAAAAAAAAAAAAACKAAEAAAAEAAgAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAACgAQIAAQAQAAgAGAAQAIAC4AHA/hj/QAHoAAIACACAAQAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAPDw8AAAAAAAAAAAAAAAAAAAAAAAAPEBITExMTAAAAAAAAAAAAAAAA AAAAAA8RExYYGhoAABMAAAAAAAAAAAAAAAAADxEUGBwgIiIAAAAAAAAAAAAAAAAIAAsOEBMYHiQn KSknJAAAAAAAAAAAAAAICgwOERUbIygsLS0sKAAAAAAAAAAAAAcJCgwPEhYeJSouLy8uAAAAAAAA AAAAAAcJCgwPEhYeJSouLy8uAAAAAAAAAAAAAAcACgwOERUbIygsLQAsAAAAAAAAAAAAAAYICgsO EBMYHiQnKQAAAAAAAAAOCwAAAAYHCQsMDxEUGBwgIiIAAAAAAA8MCwAAAAUAAAoLDQ8RExYYGhoA AAAAAA0LCggHAAAGBwkKCw0PEBITExMTAAAADQsKAAAAAAAFBgcJCgsMDQ4PDw8PDg0MCwoAAAAA AAAABQYHCAkKCwwMDQ0MDAsKCQAAAAAAAAgAAAAAAAAAnAAjAAAAAAAAAAEAAQAQAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAADiMAAAAAAAAAAAAAAAAGAAAAAADbrGwlp+/TK8c5DZTAiOjYSUkq ALICAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQACAAcAAAAEMDEwMAAA AAAAAAAYagAAAADhABJPgAAAAKkAAAwAAAAMAAAA/+EJnGh0dHA6Ly9ucy5hZG9iZS5jb20veGFw LzEuMC8APD94cGFja2V0IGJlZ2luPSfvu78nIGlkPSdXNU0wTXBDZWhpSHpyZVN6TlRjemtjOWQn Pz4NCjx4OnhtcG1ldGEgeG1sbnM6eD0iYWRvYmU6bnM6bWV0YS8iPjxyZGY6UkRGIHhtbG5zOnJk Zj0iaHR0cDovL3d3dy53My5vcmcvMTk5OS8wMi8yMi1yZGYtc3ludGF4LW5zIyI+PHJkZjpEZXNj cmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgy ZjFiIiB4bWxuczp4bXA9Imh0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEuMC8iPjx4bXA6Q3JlYXRl RGF0ZT4yMDEyLTA5LTEzVDE4OjM3OjU0PC94bXA6Q3JlYXRlRGF0ZT48L3JkZjpEZXNjcmlwdGlv bj48L3JkZjpSREY+PC94OnhtcG1ldGE+DQogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAK ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg IAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAg ICAgICAgICAgICAgICAgICAgICAgIDw/eHBhY2tldCBlbmQ9J3cnPz7/2wBDAAMCAgICAgMCAgID AwMDBAYEBAQEBAgGBgUGCQgKCgkICQkKDA8MCgsOCwkJDRENDg8QEBEQCgwSExIQEw8QEBD/2wBD AQMDAwQDBAgEBAgQCwkLEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQ EBAQEBAQEBD/wAARCAHgAoADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAk M2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqD hIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgEC BAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcY GRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOU lZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3 +Pn6/9oADAMBAAIRAxEAPwD86VjbpyKckP1qwqjrnNLiuO5rYYsargU4Rr/ezTuvFOWMnG2lctIS OP8Au5q1DFu6AUyOFs/WrUUZXFIcUW7UKmDtFacV86rtVsfSsuIYz2/CrUTRispJPctGjaalNDMJ dx5PNegaB4gh+zorsMgetecQsv4Vq2bRr249aydSUNENRuz13T9Ts7hlDXCrXSW+raPZRhvtCk/7 1eK28kY580r34arHnqw/1zH/AIFWP1yS6F+yutz0vUvG2m28nzTBh7VXXxXbXgBibbnpk15w0kLN 83P1pftSxsGVsYPrUrFVL7D9jG256m2pJbReZdTKFI9etc14g8aWNuvl2YM0/wDDjtXIXmoXN/jz rhtoGAoaqDKIzuXFOWIlLSJUKC6nsfgHxnFrFubG8ISUetVviY0NjpzTFeece9eVWOo3Gn3SXVsx DA/TIr0BfE+k+JLJLfVCAyjvXVSxHPDlluYVKPLK8Tym1VpFM0mfnYtya14obO5gMeAHH6UmuW9r a30i2rbo88AVkvIytujYgjuK5E2pG97xIdSX7GxUrkduKz/tTZ27cHrV+4me6x5mDiofJXnpWseV E3I0lZj8wzUh3N/D+tSJGv8Ad59qfxntTuhbkaKenXPvS+Xjj0qT5eepNR+Zt+bp/Wi4hjR/iKay 7f8A61KLhXJHAINK9O40iJl3ZLf/AK6rybRgDpinXDMvKVU8yUtwp61a1EyVV3NnHWp44yvRQfrR FHjDYwanG5eNvX2pOVhqOhXaFpPmYCl+y5+X1q1Db3VwwWGBmJ9Kkk0zVI/vW7DPtTXMwbSM77MF brzUkdurNtVck9K0tJ0DUNQnWNkKD3r0jw38NIY3S4u2H41rGlOfkjOU0jitH8C6hqS+YYsL9Kdf +BbiCQxngD2r3q10+0tbcRQoqqtYmr6dBMT0zXSqMEY+0k9jxeTwZtUkEFqjh8LyNIFZeOtejXGl zKx8tNwqsNHvt25YsU/ZRD2sjDsfDdpAoLICRW9btFBD5axgEe1I2n3yj5hj2pUt5FXD5qkrEtsp 3UTPltoxWe0LqxyuRXQFV27ahaODq2KdrEmOtm8jelTpYrGN23J9xWgZbeP/AFYzUD3EjfdX8cUC K0is3GMVA1qzc76ttBcSc7cU37LODSauMpNZ991MMKr26VqJYzSffbFK+nxp8zNT5R2Mdo2P3V5F R/YZWJ/hB/z/AJ+lbPlqv3FFRSRyZ9qVhGaLJl+93pxsY269au+W38XNNztb7tIZnyaay0w2pXnN abSNIu3BqFreRsfNTsIofZxj5iDTWtR2q61vJ0pvksvHNAGc1uVqF4OT1rW8vI+ZeTUTQrn7uTQI yWtQxLN+VNa3ReTjitNod3zKtQSQN9KLAUSq8DFRnb0EfTpV7yf9nJ/lStbjb90ZoSAzWUc/LxTQ sfTbk1dmsmb5qrtbMnI7UWBEEkKsN20c1WeP/pmKv7c53Yx0pjxk9Oc0AZT9PunApI4UZh/nitI2 sZBLdahdEjPy9aEIWOzUqGP86QRrCw28VE1064xx0phuDICp4oGmdFa3cc1v9nboKumbTYFRZsZr kEunjyRJkinS6hNJjdyV4+lFrbDvc6STWtLgY7HCmq58WWdq29mDJn8a5tj52dyj1zim3Onw3Fuy +WA5HBXtU2dxq3U6N9a0fVG8syIQ9ZN94fniYyWgEqNzxXn95aXemzELJIuDwa1dG8ealpbLFcnz o+PqKOZoGmjZk3WcmyaMoanhuI5CAqgZ4+laa3ui+LLUNDMqT+nesu40G6tS21m+vrVppiMEdPWg f7vFSrHtp45b7vWuU2SIAhJ3fyqxCB+NI2VGAOaIt+PnUrRcouRleRgZ9akULt+WmRpuXdyPUVPF 5a//AF6hsdxY0YktjHb6VKPu/ezilVlWghc/e96gaRLDI393FW47jjGaqiFmAweDzUiqyjIqJK5Z fjvGVQuTU325+AucVnR+YR9386mWNqycUNSZc+1Nn5mI708XDL96qsceME/nT+W461LSGpFr7Qcf epPP+UBqr/dycUz5mb5s0uUOYtrMM9elBuflxggCqy7vpSr1I9PWp5UVzEk0rSdCcn86h8uTntn0 qdVj4z/+qkkfqoxTWhJX8tVwS1Mkx12804RyM2HzgU5Y8evFUCG9VPbikz+dT7M/w8ULbMwBA5oT CxVMbNndnml8v8TV37K38S1IsCrztqucdkZq2H3nXjNRBZI5Crg4FbK20jnABPNaNj4cuL5tvlnB 9qqKlU0QOSjuc8LdJMYH/wBapF0+P+Fea72HwOixhm4PoKs2/hKNGGEyR7VusLU7mMq8ehwUekSP 92MkZ9K3tJ8IyXTDzE4z07V2UWj29v8AK0eDV63RY1Aj4FbxwsY/E7mUq0mTeHvBumWcYMkayNU+ reHbWTd5duv5UkN5NB9wnNTrq0xysgLV0L3dEZXuc02hvZt50WFNWoNSuo8Rtng1ts1vNktuGaiZ bWP7sOT70bhuJFfXDLtXPNWo7HzPnuJPwql5k2793DtH0qXzLjbtZ2poFoTTfZoVwqjdWXNNdMxE S/L2q20cje1RkSKdqqc+goAzZILpvmZsDjiq7WszZAGTXQR6Brl8iTraOkT/AHXk+UGrVt4RuEmL 3txlc7V29D+NPlYrpHINp7fekfFN+xw5+Zia9EXwzbxx7dgJR9pDAEg+4/Oov+ELjb94kbLk7W6Y B+lPlEpo4ZLO1xuxn8KSRbOLK7RntXUah4P1ONG8lYyew6VxeveX4ege712YWcSDlpDgH6etJpxV 2NPmEmvB91FNVGlmb7q1xl38YPD9rMfs9jPNH2dyE3fQHmtHSfjB4RvJFjuYZbct/EcEfpWTqLrf 7mXyv+mdCGvGH3Tin+VcN95TmtWzvdJ1aEXGmXUUy/7J5H1HWnTbU+7VRlGWsRNNbmR5bjkqQaY7 Nzuq3NMB6EVXKvJn5eO1UIrFGY/LSeTt+8aurCx+6vNH2NmPzZFAip8q/wANN8tieBir4tUX71RS rjgUwKrKuOwqGXcP4etWTGzZbpTxH2bGKQzNJxxioJvm+6K2WsYWUksB7VA0dqvy8HFKwrGWpbbg rTmhaTkDAq40lunRelPWaNlI2YosPczfs2wZqtJt3bW4rWaAs3FMk0vzBu9KLCMhlZh8vQVVkjat r+y5lOcfLUn2GFV+bGRQwObNszN8ooNnMO4Ax3ramMa8Rxg9aqsskjctxSAyWiZchjnbULQNJ0HT 0rYa3h2/3vqKqSlY246UxGHfp9nt3k5Ddq5WHXryO52zQNsLda7u6jS7Xa0eR1qsuj2zMN0KhaNL WApwiO5iVxwTTxbbepzn2q6dPW3xsXgflSNHuXjIx0oGQKkYUdOaieTYfvY+lNk3b/Qio23H5euK LAQXlvFeLtkQE+vpWW3hmFyQrdTWzlV56Cj7Rt5GKVh3OYm0PUdLf7VaysMHqtb+h+O5I8WmsR71 HG4ipje7hsYZB/Wsq6021ufmjwrGk432Hoy2sfPzfnUmxe351Es0mRtj4p6iQseSTXKdFhVh+b7p qRYVBO4gY5qWPd12nn1p5jD/AP1qTY0iIeX03A/rR5TGTjp6VZSJY8Lt61YW33YwvArPmGVUj49S f1NSKjbtpX86trBt4C4NSCFF4ZRxU8yCxHFbybfvcH0qbyW4x2qWFW429KtrCrZI4qXIoqpCwx6V OI29KlWH+8cGn7dvuPes3K47EOzjls0mwr8y8ZqxjPGMUph3fxYqbjK/lluDUiwc07b5bfLU8fzf N3NFwS7kIiXpt5pvlHdjn8quL5e7G0U/G7A244qbjtYopHt96Gib+7V1l29OtKqtIuGFFwM8RFql W2x/DxV9LRmwI4zz7V0egeD7rVpAzrtXuauFOdTSKJcktzkVs2ZvlXmtbS/DN/fMPJhY++K9PtPA Om2u1pcMR/Ot+zs4bNQlvCqgV3U8EvtswlX7Hmsfw5vfLDNwRVRvBE8cu1vuivW5VXJ3MKoXUNtj 7wNb+wpLoZe0kcTYeD7eMAuu78K6TT9CtYcbcKMfSpmmgj+7zTPtzdI1JPatopR2RN7mvb6fpaD9 4w/xpWj0uBty44rKFvfzjdGjClOk3md0z4/GnqITUI7G4bcnymqJgUHbGpNX0sooyBI2cVLtjX/V puIov3AzV02Zm3FgB/KrCR2sC7ZDlvarwWaRT8pHbFR/YF+/JnNAyq00GcLDmm/aEXGIxitey8J6 1qy7tN02WRc/fxhfzNdbovwfupEW51yfy1JGYo+fzb/CqUGTzHnsbyXEgihhaRmPAUZP5VsWPg/X r3EgszGuM/vDg49h1r1/RfCei6fH/wAS/TUgc/Lu/i/Enk9Knkt5YPmg2iNVOS/Xjn0o5Uhc1zzy x8A+Q0Ut5tkRmXIbIUfXHNSXdjp9nqF1a6LZxalOuGkS15jhz6seAfbrxUmpa1q/iy4msNDmaKzh YxtIv3pCCQ209gMEV7rpfwx0TwT8OdPvNSe1tBdQrJLLcOqFi3PU9aiNWMk5bJBJSi7Hz62qw2q+ XfQyWqowZMjcqn04z/Kq11rlvIqmzhkMbscSOMA+4HWuw8SRy6w1xD4U0S51hArI00G2O3Q8AfO2 A3fpnpXn0fhvWvDhkXVr2zkgkk8vyo5txibJxg98nt2qPaJSt0HGDkrkt1qjCOKS1mVZtx86No+M Y6g59e1JHr0ka+Z5cTH+JckZrPu1WK4ZFUgL09680+InjC6s2bRNHk8uVv8AXSr1UH+EGtKk1TXM x0qbrS5YnY+LvjhpHhy3bT7LTxf6q2Vhtw+UQkYy7Y9+nU/rXy94+8Y6t4nv21LWr1rggstsBwnB wXC9MZ6egHrmuq03R5muJb6aJnNvDLcc8ncqMwJ/LNYmk+AF1TUrnWNYR003TsW1vGDjz2QYbn+7 uzk+prhWJjrUqPRHdUwkqKjCO7PPoYJJFMjbmZuWPWpvse3G6Mj8K9/8NeDbbWYWuLhfs9on+rtY BsVh3Zm7Aep61pXXh/4Z28Rhvri2jAGNzSEnp2J6/hXRSrOpHmasctSnGnLlvqeLeE/EmoeHbpZI 2doj95c849v8DXvOh3Ca/YpeWrGRHTduXp6Hr0wcZB5FcdodnAtjdXnh7wrY6zpdgwF4GJE0mcMd nHGBx+NelfECy8GfBL4maHF4Zupl8D+OtCstbtVmkEsth5ybJMkdSkqyKwwCVx3AofLK8ov3lr6r /gCjKzUZ/C+vYprpLMxZ81Kumx/xda6XxRps2g3z2bqGXjDqcqcqDww4Ycgg9wQe9c/LcN/zxP5d 61jJSWgpxcXZkD2oiPQEVFKo/hzU7TTSf8szxUbbsEeWaZJUMbc/Nio2i6cYq20UzgbUP5Ux7O6Y 4CH8qAKMg28VWZmP3eK2oNBuJmDSKRVs6HFbruZc0Ac5DZSzH5pMCpJrW2hH3tzVqmxmmby4FP1q dfCsioZJs7uuKAOVkgmm/wBSuKh+w3St8zda37q1ls22quAPaqy7pc7ulJodivb2ZC7pnFSyXEMC lTyanltZG4UE/jVdtHmbDSAgUkhGbdag7EiMcCqDXNxzuzXR/wBi7R2qGbSVC7qdgsYySRyH5gB6 06S03fMtWG01VYsOQOlPjUquMZGKT0EY80DR5+U1A1v5nLVtSJv6rkVA1moyF4ouFjIaxXdnb81N +zNjbz+dajWxXiq7rt+XgUtwKEif3ue1VWhKt94kelaM0MnXGaoyiQt06UIZUmt4356GqclttBJz x7VoSbu3FRmNnU89elUNmW0PXqDUTWvvWm8KnHWoZI8fMvI9M0gRnfZ/wpnlMh5NXXVl6qfpUbhW /wAaBDobf+9j0q1HbrkbeRUlvBG2GZgfarSlVNedzHZaxB9lPG04zTltWHrU6rI7YVeRViK1kb5m /LFTcFcrLa4HmcE9adDvZtoXAq/Hajpx/jT2tfLXcqZNYuRViJbMNjv9O9Oazj3fNTlZ1G3ofepf mfHHIqLsaREiRr8oXr6VOFUfe70io2eV6Gplj39RQ2WiPCgZY0cE/KvFTrCvGc1IsIzhVGKm4yuq N/dpSh3Hrmr8dpJIwVF57Vck8O6lHF532Vgp5zg1SjKXwoLpGJ9n3YO6nC3YjjIrYttBupmIWM5+ lW/+Edv48KsJ/KrVCrLZEOcF1MBLOQc4yRWhYaPeX8iwxKSc4ro9N8KvIwN18g967zw/odnpuHjR WYfxeldFLByk/wB5ojKdaK0icSnw11D7OJmVgT2plr4KmhuB9qjIUe1eutdLtKttPrVS9kt5oyu1 cj0Fdqw9JdDD2smcZaeF9Pj2sEHGOvFb1nHDCu35VUelK1uu4ANwKOPuqvetVZbGbdyWS4dvlXpS faHRNp5pwt2wCOKf9jZVBbmnYRWeaabIXNRtZbx85yavbFX+ECl4X7vU0rAVYNGhJ3TNgfWrkcOm 2/yrHvPrUUgkxk9vWq3nQed5PnbpD/CvJNFwWhfa+dV2xoB2qGSSabO7v61NDY300e+GycruA3Nw KLuy1iOb7PbwwlSud+7iizDmRUNr/E3JNSJGq5Oz86VbfUIYJLm9ubaFYlLEtnGB15rc+GPhm6+I 0k2r3luw0C3farDKG6YYyR32A4+v4GqSv7oc9hfCfh268UOPsrJBah9jXEn3f+A+v16V6Pofw30W 3Vbq5tzcvEwLGZQeg7DoK7K30W1trWOG3tEghUBY1VeF4wB7VheJfH3hjwT+51zXI7VZVP7rOXI7 cfUD8qtyjT1I1e5uf2RaWyhlVNkbHJK4yB06f55rO1W+sNLt/NuGbymUqkYX53Pov55zXl9h+0Af HGrP4f8AA9n5sVupkur64b93AmfvdRuPHCg8n2zXf6fM+q2smiXV1aPeXAUwTScB39N3AXPTnjmp UubUV7HP3muandufs/8Ao0bZUYO6RfQ7umfwp+j+G7jVmMbatcSuybQkz7lY++en1FFvo97JrC6X dQtDMsgjaNvlfJYLgA98n8ueldPo6w6bMIfKeKQANmTjp1H4nP5UpLQqJS+B/gpbfV9P0nWLZYHu LFZmU9PNV3jlUHvh0YV0Pi74f+PJtauLnxDb6n4mjtJnj0yGGy86O2hH3Ngb5AdpGTt3cAZ4q14n 1GO30qzvIJEtbyyumurG8JwsTuqiSCQjgJIVVlJHDbufnplj8fNQsrpY7jUJNM1KBSrxyNwc/Xhg c/yrwsLX9jN0Ky2enmujX5HfiIKa9pHqSReAdZe0WPxFYvYuQWis3l3MExwWxwD/ALOOOK8D/aEt ofDuhSRwERzC4hETR9fMeRVA+vNekfE79pSHcXmtUkmUEbo34PHYdfWvDptc1b4rTReJtYjjg0Gz mH2W2UZe4mXnccjIC9vX8K7mnVmuXYypuKg7rUW7WRVaRs4VSTx3ryrSvCt3rl0mozNmW7maTB7D Oevqa9dluGvFmjsrYs7kxqu0kY6ZP64p+j/D3VtH1670fVIrjT7y0meNonC7wyjBG3nb2wfy6EVW NpVcTaNLRdzqy6tQwjlKtq+iRkeGfhfb3ENxYySRxT39tNaxluzyxsinj3avO/GkDW8lvp8a7IhB HIiDoBKPOP15kPNej+L9L17TbY6paTzypHHiPnaVAIUEkemQcnpg1R8QW1ld6h4e8Vaxpr6tZ6xo ltqTQQTeU8xt1MVzEG6Kd9tOvtgEV4OKwtbCSUakrp/1+p6U8XSxfLKmndGXFDDp/hq/uIlZMQRW qKQDkkgE/iQT+VY9x4BuF8KTeNbizje3iuIbNT97y2kWVgT6EiFuvqPatOXwX8QtbsohYWtrbWV7 brcx/ab7DEKzLsJUY3BlIx2K16trnib4d+CvhKNHvPFia2vim0jS/tkjET6NeW5Aj2oSckANyDyH kHVtx68wxLp04Rp681tu39fkebhKV6kpTVt9z5t0291DQbk3thIUZiS8ZHySDGCGHfiuU+JGp+IP FmsaTdbZ30zTreS1sxIfuJvLNgdEXeW4+p71ral4q0xZmj0vF2FYfNjhvQ44OP8ACuavtSunX7Xd NHBNHIWjSP7jIx+7g9hz19frXRgoVIe9JDrxp1Op738L/iH4f1b4bHwn461a3sNT8OSRx6fNOf8A j7s3Yjy8/wB+FiMDPMbkf8sxWpHJpN4uba7glAOPkcH+VfMK69I0iwsq4YfMrHP157Uyz1jbMZFW ZJC24PbylWY/h1rthzQZjNRcVFdD6kkhtl4VVqDy4OfkFeO6H8TNUsbg299Ib+1jJUNjEhx6H+L+ den6Xq1prOnxajp9wJIpehzyD3B981vGfNo9zmceXc0d1vG2fLHNDXEI52gVSZh95j0qPdu6fyqx Jl19UWL7oGfaq32yS6bbjC/0qa30pp/mb/vmrX2KOHC4ApWEFrcQQcbQTVtrrzwFbG3FZsxhib5G yTTMTOfk4AFLYZBrFuJVPlrhh6VzS+dHJyCMV1+wqP3gzVG7t4vMJ2gZ9qd9BFGObEYJHNRSagcY Vd1XF06WbpkA1PHo8cY3SEUWYGI0l1N90cVC9vfMD1roZoo4VO1Qaz7m+8n7qdKLWFYxfstwD8xI Aoa22/Lmr63AumP8JNJPYSKu5W3CkMyJo2TnrUO9erYFXZIdmQc1Wa3Zz8vFAiJmX8qhaNW57irQ tiMmkaH06UgKRhYj5sVBLbLg7oxV8qVbpTGRW421SBGQ9vG31qlNaOrbVbIrcks92Sh/CqM1tcRg /KTTGY0iSL95aidXXJwAa1HWTaRg1A1uzfhSYFBtsingH3qEwxngA+taDWvVuaBbqvzbjzSApBfI mxtYitK1jjkYZIBFPurHzIw0Y5FU7dGWTbJuGK8fmO9K5ti1iX58nJ54qRdu3aakhRGiG1iQBT1t 2bg9qnmFbqRxxru3LVhBxg05YQvAApyw8+lZthYha3Vj8ooW2ZW3dAKuJF3HNTfZ2bC46jjikFyk sYBA2ipFt+DtrXtfC+q3yl7W3ZvwqO60HVrFts0DLj2rT2FRq/KLnW1zPS1/hrY0jw5eapMsdvCz bjjpVzQfD7ahMrS/KAe9eveGbPT9Mt1jhVQ5+83euqhgnL3qmxE66Xwmb4R+G9vZhZtSiDPx8vWv Qv8AhHtJmtRFLbpt6Y21SF9EP+WoGKd/bVrEp8y4BNemkoR5Y6HI5OW5j6n4HsY2MtrEFB5rCfw/ tY5A69K66TxAsylV5/rWTcSXVySY4yB2ouIx5tHkKbhhdvoaq+TNbsFMhNbi2V62fMbANTR6fHj9 4cnGKLMRixLI33mYipvJJ6Ak1qyJawrjaKjWaPd8kY5pWApJZuyjchAqYWcarwOTV5d0gG5R+FI8 ezvxVbDKqw+Wpyu78Ka9tcXGdq4U1aNwkYy2KovrElxcix0uEzzE49l+p7VN7iJJbW3tYvMupFAH cnpVGG4ub+X7Po9i85P/AC0YYUV2eifD177N14gYSyDlY8/Kv4d/xrr7Lw9Y26qq7U2joOBVKHcn n7Hltv4J1C5uA2vXjLGeRHFwPxNamn6DYaXdOba1SF1/jPJP512+oNaMTFI20g9V61yWqyLbXBdb gH1zVJ22JZGjGFWZWLB2zhuAKh1XVtPtbVrrUp4oooFJZjxgVzuteKo7C2mubjCxJyW9f8a8Y8Ue LtS8VXQWSR0tVP7uEdPqfU1Ep20iNR1O1jv9T+MXjOy8HeH98GlyS5kPcxryzt9B0Hrivsfwzodn pOmR6Lp1nHFa2EaRW4VcfJjr9epJ75NeR/sp/DVNJ8OTeML1dt3qrBISy8pApz3/ALx/lX0StksG DGu5i2SinGB0J5785rRLkjy9R7lP7CsiPcHKJB2J6cZH9a/L7xp4h8RfGL41eII9JuJri2udSlis 8tlUto2KKfQDaAfx96/VHVLU6hpt99lhY5heMc84CEDOD7V8VfAT4If8ID4Z+3eILXGv6mqyXEbA E26n7sf17t78dqSinK8tgep2Pw/8G6R4L8HxaJo8KNMFDXMsiDzLiU/eYH0HQD0roY7iOSOONAVk j3bzu6jjAx7c/XPbHKzLbw/NczJDHJ91mbaBj69KpQatoss4j+1famH/ADwUuSB16CnKd3qJI1NT 1C51K4guJLiWSS3iWMyO3zELwMH2GB+FaUWrajqTB9RkDPwd/TcR3OOCak8O+GPEHiW8SLR/D15M jsFVpkEKn05Y4r3fwt+ynr19Y/ada1SwspP4YI2aYg/7TABR+GaShdFJ2PH49Q860a2u1EsUg2Oj gEEY5BFeb+IPhrDeTN/Zus3cVof+XOTZIqj0QuCVHsDXpnxAHhz4e6vf+G9c161F/YTeXJDA3myE YyCETLcgg8jvXAah4ykkt3/sHwjrN+QPllZPJjPvlsn9K87EVMLHSq07fM66Ptd4XMW0+H+k6YG8 nTYnnmUxvdXL+ZIgP/PNQAqn3xXeeGvhPPq1ra2dvYfZbG1z5ee4xycH6157dfGHxd4dIurX4b6W s6dJL27eb68KE/n2Nb3h/wDbI1X7UNN8WeEdNt1QgSTafO6lRwOI5Ac9em71rOGYYZLlW39f1sVK jVfvM9hsPAnh/wAOQHybVHlxtZ8fyrC+Klv9j1bSvE0Hn3Nrq2nxNMzZZjNAzW8p3HnloC5/3/pX nnxG/aR00WzJ4Xmyki/65uMe2McV4zo/xk+KGsrfaf4RvFgsr0lbjU7iBXSEDO4RFurYJyBxwMni u6NXm+FXRyyR7Xq1idct9S1Kz0wLo5k8ieSNy8auyZ2Fs8lhg8gfpXgvi74jaHovhePwjp9lLdXv h3VXk0u4h/1aRTqGmhIPXbIiOoGcmabPUUl58aNe8J+GdW+GvhbVJptN1+OIa1O0ivJKY5N8ZHdW MinkYwOBwa8Y1J5IYZIrORgS7yMzOMIWBPGDkk7SD6dK5sTGGKSpzW2ptR56Pvxe50mr+PfG19pw tW1g6bpcJMkduhHmZPAwxBbjOCAfc5PNcrcTQtGqXVrLcidjIJJJcHnPJz1GQfvcgGse81ux0xZv tFwXuGbeDjhm3ZbrwT747fnympeLLy6228DPHGny7u5AGB9Op4qqdBRsoqyLlUveUnds6q81dY8R 2uyJGYfMg+ckHr7e3uK5+58T2skhjm3fMH/eN85HUj3znj8qyrfRfEWuTCOys55EJAU7TjH8q7vw 38JWtNt14gkDAc+SpyPxNFWtSoL35a/iTBTqP3Tzn+3NRk3xrku/yjjt/jXefC7wP4p8eeKLDwfp gtYb7U98dmLiTaJJlRmWME8Bn27Vz1Ygd6l1jwrp+j601zCkSW0qggs3CkdRXSfDttB1LxlpWnye JG0meScNb3yqwEM6gtFgjkEuqgHsWBJArWNWE6ftImUlKErGHqVrqEN62m6jaf2be2pC+Qw249+e /OeT3rr/AA3ZeNtJg+36XazPpz4a6mWImMkdxn8uPQV7l8RdJh+ITXvi/U7C0bV7aRPMMMO1W9T7 EkE/U8cCvffgjdeHvi38I9R+HGr2cEd3YwhbWRECkAA4wO+cc+5NZQlByUXor/cdFZu3M9bo+Zfh rpOpfEzVn0PTFhW7WJpyskoTcqjJK56/TrzV+KzhtZGil+8jbT+FcNr1vqfw/wBXu/B+w2eqWMzN b3UfDmPdkfljB9Qa9d03witzpltcXNyXmliWSRv7zEZJ/Wt4c0ZuMjm0srGP9ogVQsbZNQSZlbcz KM1rXHguRM+XKcdqzp/DOoQ/dYkD0rTVbAmVGt4wc8GnLtVdvakOn38edyEimeROrHcpGOtACzMr Ltwc1UZU59qtsyrj5aiaNXzz1pBuVWumj+Wq8k0shxuIq9JZ/KW9u1RrAirg0WuIpSeZt5ySKgex 837ykdqvlWVjgA1DJNtO1sCgDKuNNktWDx5IFSLLcMgVUPFbEMkbqFfB/rTnaGMcRgcelG4HOzJI w+eOqbJJ0UV0cxhl6JjPpVSS1Vssvb2o9AOeZJw3ORRn+8MVqTxsvDKSPpVNo1zwM4osMh2qynFV 5I9o+7VxomUcAj8KjMLSfePWhCM9pjF7gU43EUq/MuD0qW4gVfvHOKpsUUHABHpTtYLENxCn3lHX mqEsO35t1XJpmI+VcVnz/aGyq888UbhYryTNGwC4x/WoHZps4B5q3Hp80zbnB6/rV+DTtrfNGQfW lYCdV25RkJ+lV7rTQw86NcNWz5W0htv6U51RV+ZeK8DmPQ5jDs7toW8uT8a11G5Aw71Rl0+O4k3R BieoroND0C+vWSNomAHBPSqjTnN2iglKNrlOK2aT5lBNPWGXdhlx+Fex+F/BGhW8HmXzLJIwHy+l aOoeDdDb95Dar9K7Fl7W71Od10ePafo11eMFhjZsmus0XwRI06NdKAO/vXVx2Vnp/wAsMSrt/Wr8 OoW8ceGXL+1dNLC06eu5lOs2buj6PZ29sIURUA9utPvPCdjdsdyo2fwrHh1O6ZdsanGf881cXUL5 VCqxzXUZN3K114Lht1zZ7Fb6VUj0LVI2AVuBWi19MzASTEH61IupBfusWNADI/D95MoM1xt/rUsP heFcNI2frTTqMzNlmIFMk1huV8zmi4Giuk2lv91RR+5T+IDFZH9pzMp2sTxVdWvrp9kas38qLjua s1xCpzvz+NUJ7xpW2wjNTw+G9Qm+eRjj6Vo23h/yfvdfela4jHjg3MGuGwPpU2bWMbY0JP0rbbS7 PaBJgmhrOzX+EUDMFnuZBtjjIFKtrNtzMwCjk81qTyRQjKqPrVTRdJ1TxxqJsrXdFYRtiecd/wDZ BpW1shNpFK10u88TXn9naPGwgU4nuewHovqa9B0HwLp+gwhY4gv94n7zeuTXXab4dsfDtgtpa2io ka/eHeue8QeIfsqmK3bJYYYt0FaaQM27klzfWOnxuu4A7ep68VyWpeKuXkhmxjiuW1zxJJDJuQOw 7ufX6VxureJn2ukchCu24qtQ2xJHX6h4w+827G7/AGqbpLT+LNJ1LVVeCKy0Zolv764nCR27SbvL B5yS2x8ADtXjXiDxYbWEzSOY4zwCOrN6CuL/ALS1S8l8yS5ljj8xZPJV/wB2SuSuV6MRk8n1NK9t irXOz8c3R/tibTYLqSW2hbrn5WbuQOw+tReCPC114r8T6b4ftFBe/uUhGegBPJPsBn8qyLi8m1Of 7Vc7fNk5O0YzX0d+x74Hj1TxBqnjK9t2MOkRra27EfL9omDDk+yK/wD31TpR97UpuyPpvStJt9Ht LbSdPt9sFtEkMW1du4LxyB9K6a10+aNQxjLu3Ix/DgA845Bwf51FpccsHlwxtvSGbzI8Phlb5Qcc 9SFTj2rqtN06bz2DxBmUFDu+UgccfUEHB9M1o9QRyXi6+OgaVJ5WFluozGnyjITBB7eh6+uD1rxb U18iZoGcO27LHIPzcZwR1AxgEeme9es+KL2TV/FCzW9wLaPS9s6uNuR5bKQQGBB+cjjHTNeV6rHD cX8klu3mtLMxGF5Zck/gPYVC3uDOX1ua40/Uo2hRDHLC0YDxq2N3DY3ZwfetfTdcsvD9i2oXN5b6 fCq4eRsRjHTHA5yO3U0viDTbi+gjjtYd86yfu19fWvKta8P311rav4juHmSF8JEQfLXPsPp+neuD HY+OD06s6KFF1Vfoex+FvjF4o8QajHpPwm8Itq1xu4vtQcxWynrkJwzd+CVPHevonwh8E/i54609 bz4s/GTVo7Odf+QPobLaxeWwBMbPERvXnGHL8dTXhHwlvNP0WS2kVoreGBlZ2GAozgfnz296+mtD +JfjXVhDpfw78HtfQGI+ZqGoMbeNHOAu1SMsBk5x3GPWvCw+Oni63+0K8O3/AADonSjTj7m51Hhn 9n34Q+DbVLfQ/BOnh0XHmTp5jt/vZ4P0xivPPjHpenW1lPA0lrbm3jDNGjKuxQwwcZyRgngA4HpX pFj4J+IWrRNJ4y+IbxGUfPa6NbrEifKVIEjgkjnP3VOfoMUtb+EnhC2gN0NH/tCYEFpb2QzyEjAz 8+QPcgDrXXmmFpypqpKDSXRdSKFWSly33Pz58X2lheSyTacsv7lgBtjYknJI25GOMDuDyPw8S8Re HhZzKYvMAYlyjR7cdh9eMfnX2r8W/DXl3k8dnD+7iLLnyyPlAyDtJODjdx7cV80eONMkt5GkUkKA UYeuOPx5/lXhU8ZGK5IQt83f+vkehGm73bPFYvD9jqHiNLfVLp2s5YTKtsGIDumA249xgrx7HNWv F/iwMqeG/D4jtrWNfLOw7dwUAlAQMDPT8fQc1tbjvpJ1WzU5dmaN8cMVGGC9B3wc+uKyV8qG2a3E xiALLJIy42nGcAE8euPX3r6vC1pVKETgrUeSo9ClO9ja3C29u2EjzJJPIp3uA4GzcOM46sD+Ncrq t4s11NbaYqS7AZAu7JkH8WPw/lSa74sskt2tLWFoZGG5GB+4ecjvnPFN+Fuj32teIbbUIv3cVhKJ mkIyAVOf6V0Rjd8xnKfKuUq+H/gz4w8YWsmuLbeTZoyiSaU7QB03fQV6bp/wj8IeC7Szv9aWPUpZ Yi7rI4CoRgZHUnJ6D8a93+NPxo+F15ptrdfC+3t4NU1e1P8AammxWhW00653Msmwn5XRgu9FUkLv AJG3FeDaL45h8F+JNK8VXVjFrEthcxXDWt8oeO5jVgXhIIICOAVOBkBjjkA1tVlBx5Y6mVOVtepp aTeaPqHiXSdFjaPS9M1DULezmu52EYt45JVR5CegCBi2T2XtXF65fa5bXFzo+qRzWlzaM8MlvKrI 6SqcMsg6gg8EH0PpW78SND037Rb634ZmuZvDmrtNcaTJdlROIBK0eydV4WZCu1gODgMuUZGPNa9q WoeItTm1LUWe5vLgq00jDc0rBQC7HqzNjJY8kkk8nNY08LRp7RT636/1+RUq1Sbvcl+JNxott4o1 +x0yBdS02TULpbCZz5f7su/kykL0baQSvTPHNYWq6LbWsMEdi6zXEdtDP50JPLNGJCOccruK8f3P epJreSM4aMM3TaBnJ9P0qncymBfs8JkWQAqfLbG0dMZHtkVvbqQfQvws+LGleIJLSPxBcJEdRQ2O pKTjDkYE4Hsdrn/gQFJY+OvH/wAM/EmoWHhC4FpOsklqu5ASSTxgNx16V81xzXNsiW8NxJCImypQ gEHOc56k+/tXs+nfFiz8Z6Zptn4ihjt/EelwLBHqQfCaiE+75i4+SUIAoOcNjsSAeOvS0OmhOO01 dGfrGn/ELxV4wtb3WILt57y+V7rULkk4+RsrnpjngfSvonTTcQWdvaq24QxrHu9cDFHhPy/GXgaX RY4/OntALqG4bhkwcjPrgj9ap2muWM9uklvMjqR95WyDW1BRtdGNSbnK5u7ZmXd2qC4uY4l/eEZF Zv8AbEzfLGc5pjLcXHzSxnmui5mFxqduAV2gZPaqTTW8zfc/SrgsLVvvLg+9NOmwqR6etAFCS3tZ F+5/9eqElqjMRHnArpIYbVR82Pxp5t9Nb+6KLhscbKkycAVA0Mzc7cgc12bWenSZwwpPsNmEKxkc 0DOPjH8JXn6VDf6e0iblXPvW5eWHlyExrVZfNX5ZV4ouI5KOSWGTa3TNa1u0c3ytg5HerWpaSJoj NGuDWLaSSW8xjkOKT7gXpoUQfKuCap7JNwPStAzxuvzZxUbKv8OKYzPkh3DcwqnJax/eVua2mt/M Tr+tZk9q8cjfMaYFYfL8u0Ee1QSRl87avCFvXNIsahuetNCMW7s3Zcmqcduv8Wc+ldU1qsilRzWZ Lp+Gwy4zRYDJ+xr/AAqCDThp6/8APMflWzHaBFJ6gU2RY8FaQGQ9nHH82OaUAbeeamvNy5qqsqqu G4oAv29vJOyoq9elX08P3zS+S0Y9eeldRZeFb+xby2twSPumty10u4z/AKRblQOvFckMFTive1NZ V29jnNH8IxqwaZVJ9MV2WnaDFAA20BRUWzyXG2M/KerGraX0jMI1GCK7FFRVoowlJvc04Vt1+WIA Y6n0qC6keNSschNNjWSMbnzz2qTzFGWCjmiwX7lJbG4u23MCAP1q/b6Vbx/NM3I96cJJthWMYwe/ FQyW15cDazbQO/rTETSXNpaL8rDI9KqzX01wxS3zg96a2nQQEPM5Y/WtKxsfthHkx+Wn0oSGZ1vp 80mXldian+zTQ8IpP4c11NvY29v95dxFTsbNceZGoA9qHYSOSXT9Qu+20H0FXbXwtI/zSMc+9dKt xZKuY8fyqtdapGqlI2OT6CloMgg8O2NqoaaYEVbhm0u1/wBSqk1mNNJccLHIwPWpksG2jbGcmjUD QbWEb5Y1zVaS+lb2B9qj+yvb/vGTFSxxtINzx4BpDK0lwW+9moJJnP3VNaf2XzWACVX1C1uY9lpZ xGS8um8uCP1PqfYUWB6FHR/DureNNWXRdPJSFSGupv7qnsPc17zofhjT/C+mx6bYxxrFEOTjkmov h74Lj8M6LHb7d1zIPNuJSeS3erfiC4mtYisPBIq7cqsZ7nOeKdaaNCkMmCMhtvavIPEuseWJG3ds 12HiCWTzXKyNls5ryrxVfRxK67gT0rKQrnKa9qlwszK3XG/Oc9a4nX/EtvpUf2i4OXk/1cS/fkPs Ow960b3UJpLoRw44PXrVVvCtj9ufxFqDNLIFHlh+cf4UbjRxpt9T1Kb+1taVVyCsMGOI1PoPWnxp mRVXPsK0tTmM0jHtn8qjtbWRmMnA9vWhFbFy1hQv94AjJBI68f1r72/Zn8OrofwT0qWS2CzazczX 8j9GILmND0yRtiyP973r4Ws7Vdytu3H+7/Kv048P+HJPDXhrQ/DMPzHTtNtrXhfvmKJQx6ZGSD/W tY6REbGjWdrNbvcYbJwqJtJ57nPAz04I559K6Z5l0vR5rqYgv5ZKnHOQDjk1w/j7xda/DjRbDVvK txNf6jBZxqwO1mcljnHP3Vb9azvFPxi8M6rotvaeXNZ3VzJwo+ZGwOcHqOo45qHKxSOekiSSO71G ZTKkkps1VTg7toYkn/gS4+lcn4c+Ht1a+L9V8WeIPEFtHodjHB9lsbmYK8qDHmbAB/rCxfB9EUd8 16fbixbwlZNI67pW83bt5JLEj6/KQefQVXtIdHn1KxkvrO0vre2uYpmiuow0ZKuD8ynPHFYyqcsu UuMU9TA+I2ueD9N14a5ocJlleFrcWxYJ58qDPnKx4A2bdx67lP3mYA+O3scfiTVZb2+jVGUqwVFI C9wMcmtfxhq0OpeJNSvrGPyrL7ZNBZRqP9VaxSFVA7/M29t3G5fLznArl9Q8deGfCexfEWtQWkrn PlgM7KvbIUE8++OvpXy2YTlia14K7Wi7npUP3cNT3H4Ex6X4d8dadLcQxXUMlx9lbcuE2SApvGcd M7umeK+rvAtt/Zsc2lTKgls52t8qeSFLbTjrgqVP1NfB3gH4geGfEN1Hc6DrcN1JEwzEytGwUAnj cBkcdv619x6DqzXV5petbQJNasVkdgOPOjwkvHYcrg1zYSUqfxqzi0/k9H+gqq5tnuehVW1CGOa3 ZJc7W4b6Hip4m8yNW2kZGcHtSsu5SDX2dSKr0Wu6PNT5WfLvx2sV0vT7jVrqNBFapGrDdyzs6xbe AT92Q8Ywdg5A5Hwh8fPFwN7D4X8NyL5wgElzM5U75CxxGMdBt5OenqOp+5v22PiJpHw78CzWfmxf 2trkMsNnbspJOAu+UZGF2ZUg9cnjnGPzKjWa6ma9E0qyTP5jec27ZuXLHI5BLZPJHDHrxXy+W4SH NP2kdnuz03KVk4voRafps0emszbjai62bmzhDjcyIx+6CC5JAIz2zXnnijWvJP2exAWNpD5sTSbd xA4O0jORg9evHHXPeyXjX2nwaHaRsBPN9ol2qfnIBAUHI3DPftgj1ryzxpbX1vqjWl/Dt2MwXKjP XBye/Ir26Uuao4MitJRinG5zk1lNq+oxfZ23y3J+b29Pp/8AWr2bT9JsfC3hCbSbu8jW8u4P3aQg 72Oc9Bz7HPasn4ZeDoZGXWLySPC8hc8gf0qr4m1SSy1i4s9Ll+2vLKXBjy2Cex9wABj2Fd1nCOhw X5pFiz0q1s4jc6pdeWOvlqwBP1Negrr3w9+JNjpej+H9PSy1q0sUs59PwzR3bQqR9pgds4d1G54y c7wxXKttTifh/wDD+Hxl4r0ux+IHim20LSby4WOe6uJhEkKHrljwPTPIGQTgA101l4GPhXWrabT/ ADbObT547jtuZkYOpEgPTIBBBwcZFZwvrJS+Q3Z9Dnte02HS9NjsYWdljLsC5zkt1PpngDtwBWXa zLa26W6J+8mQs5CjIycYz1xgV1PiS3WaZVjXODkZHB9KzGsY7eTy5VBCLsz1PHA/rVyaCxy+vNHY aNbzxgi5vJXiDFeFRcbsfmo/OsWNXtrYFxhnXjj0z1/zzXb/ABM8LX2nr4LmeNpINa0mTUIVQdcX lzCR/vZtz+GKbq3gy+j8O3GuWh/0aMmMPsGRIvl9G642yocepNW43aiKMrJs86muITMY2uApx0K8 f41pWukzyQR3BX5LhT5TZBUgEg/jweDz37ivU/hb8LfCOrWosb+1trjWYZM3K3F6Yjklf3aqpyzj Jz1J4IHXPX6t+znrnheHUPENro95deHDII7j9z/q4ptqwzkZyp3TQlTwr/OOfLkrKLjUlyU90XrB XlszwNfEnjSzkGjyeKtQs9KPySwRSFPMXurEYJBHqea9Z8D+JtEtdPt9Ot5hHDEu1F3ZxXEeLfDr JYNHcwiOe1la1kI/vEZX8trfpXk66tf6bcNHHcPlDTjrtoyXHlPuHSNU0maMbJVLfWt6G8g4AkGM V8c+C/H2srcJG9wzKPU17x4Z8UTXkSeY2SfSqUn1EeptNbkbtozVWTzJuFGB71X025kmjUrHuzit lIWf5pFIq7gYM1rJ/eIFMW2bp5jZroGhiH3lzVW4jRgfKhOfoaLBuY0lqyf8tCeM1A0d0vK5xV2S K83fcOBUE11PEcNDnFAEHmyfdkX86spHDNgswFU2uPObDArT2hmKgxsRSQGhHY2rRld45rnNZ8Pw mQyW7DIrRSyvpFJDHb7VWmhuo3PzE/WquIxPsMyrtkXpTGt/4lat5NvSRenqKjuIIPvrgUJDOfZL qNvlyeapXXnKxLKcd66r7PAQPmHuKqX+lvJEWjHH9aegkc/D+9ULzmpX0/8Ad71kIOKTyJLWTEik ZNW41aRcK3B46ULsBmx3HkuY5G9qWa6jPoRUuoaS/wDrV5rO8lvu9KYFxDHJn5selNmhiZfeq0lv IBuWq8lxJGfm3Y6c0thkdxD8xRgCDVK4tMJuXH0q8Ljc3Peo7iON1z0PrQB9CTrHH82wbqy7q4Zs /LjFWLzUIdow+fT9aq29rJdnf1B9aDMreTNcMQeQetaFvpnlxhlGG681oRQ29qoGct6U7zNwJVSR mqApx2szttkbFTx2UAx82TU6q235eTilWLadzYI680rACxxRrjbUV1JsXEYGccUs1wIwQqk4pdPs bq/mDtGQooC9xmm6LNfSLLccqD0rp47aOCMRqoXFTQrDZwbFXmq8vmzcKMZob7DvcZNIirgtzUUa rMx3rkVahsVRfMmfIPOao3955LEQoCPWkIkuRHjylUCmxrYxr8+ysu4muJ/4sfSoLeH5trSMxPWi 40dNa3lkpCIAa0ft1r5eVUE4rmoVWFtqxknH3quwKeNynn2pgaSr9sbcw+XOamktFb+HAFPtXVYt qrzRPcrHjd1pAVJGW0zI33VBNdv8MfAl1rF8ni64jkjVFKx7l+UKe3sa8+kaHUbxImDNEsgzt7nI wK+j/Aul3FvpZt11BrmBG+XapVckZIx+lOHcmT6D3tVgWRmbEanj3ri/E90oVh93g16B4kjXT7UI pCiQ525rx3xZqUjM4LAKvQEZzUthqtzhPFGoLHuO7sfwrw7xdqzSyyYOWYkLXe+ONY+Zo1kPvXk1 0Tf3xbnaDgfSs1qxJBpFjvkEkn/66XxNceVbrbI2Ca37WzW3tfMZQMCuO1tvtF02WIA46VbKRhNb tIDK2cbvTvV63i8tSvOWHanLapuOGJQNxwefep5V3sGThQNvHpQhmt4L0uTXPE2kaNGvOoX1vajj OS8iqOn1r9S7W3CsrwLkI+eM43BsYzjkYGR/+uvzc+CNn53xa8FxfOB/b+nkMn3s/aEwO/Uj0P0N fpvYxu+6dg0bFsSLu6EBiAfwOP8AgOcDmtL+6LrqfNn7bOqSaZZ+ANKilO6XxAbht2fuxREEde5m 6+1ee26vfeIrSE7mWGFnVck43Hj/ANBr079pb4O+M/jX8UPDGh+FYmA8O28lwxlbajGZlxkdMjyv wzXGx+Hr7w548uNG1JQLuyt0jmXIO1wzAjI46g1nHRN+Y+p6W1zMdF0+Jo5LcJaRMnck7Npb0wSp 49KxbrxEulxNLfXkKJjb93lsds888dqp+PPFkelw2trpMiTXRs7dZBsO2EiNQQcnk5Gf+B/w/dHj +sXOqalKZri4ZnPGfQegrOced6FRdtDf1YXVjoNlqLW5M8ei2JiGcFnNshJHUZPXoeSK8Y0/w3ot zHruoeMrXxE+r2wZNOsbbTTMJroHBWaRmURqDwSN7cH5cdfoGRbjUPBul31tGLq7jhaHy0Vgsdxb nEMO5hyWjW3YkZA8ztyByXwl8a2HjHxcYPFWv2egyOu0XS2KybHZvmUuxBjUnYSzFsnJJA5rzMsv Hn5V71zoxblZW2PLfP1C18uKHwLrmlahGDIkkELqYyG+UK3f5duSVHzHgDHP3b+zL8aF8W+B4vC+ tQ3dp4p8MXUUzQzRGF7yzlZYmkTI4Cl1ZlB5IHrx4N8TptB8J30uq6T8Qbq+h2KsrRWtufOXB+Yf IODgYyMgAcmr37Hfi7VfF3xOtNQ168muLCK6l0qOV1RN1xc28/lowVeciOU5yRnAxkjJjqbnFylo 9r+unYig5X8j7e1b40aP4duZtNbRdY1SWz2rdPY24aKAkZAZ2Kjd7LnB4ODxXb+HfEmmeKNFt9e0 uYm1nUt+8G1kI4ZWHYgg+3cEjmsnR9B0u3utasWtUb7fM13vkTJdJeSDnnAYsMV88ftLfFCP4GfB fxP4UsZI4NT16ZtPsMN/q0lBE0uAd2BEMKQDh3XNdNNSwdFc0nL/AD8gaVSWmh8XftO/Fi8+NXxf 1fxA115mh6TL9m0lAdqxW6NhDggEFyWkJIyC4HYCvKVfV7yRNJ02E+ffudsROS/yAdh0KngADrip fs+oJZx6y0expZHZ5ZEwskjDJAfkBl3ZwO4Ax1J7b4G/DzUNcvbbxhM09vYvdtGjMrMsoX5tqtjH ynHPTt1GK8+tVWEw7n1X5ndTp3n2X6GtpXwI1z4daLdal4w0O8sNba+hkk+0NgG0ubVHtVRMncV8 m4DsTkEqp5rwf466PJb6kl/HD5v70SAZ/hk4Of8AgQr9Z/jF4Us/Hnwbh8QW6xm/g0f7KsrDcV8h lmCj/bcIyD/roa/OX4t+HbibSVvIl5XdGDtzyRuU4PYEH864IYqKxyqx2aT+TRcqfNRcXueCtf6m scVhcTrBGPvRxZVVHuRy38vakXxPY6Qoj063WSbbjzHHTscL09evrQpa6VHZcs45+vcV0vhP4V/b M61d3EFlYqpaWW6IxGMjnB6fiRX0dSpFK83oebCDbtE5qz0TxJ4wuBNcStFExx5kzEDHt3P0Fere B47Hw1INDur7U7mwMN0uJN3lxS+U7RMsfRT5wjBb720t0BxVK3+LHhP4c6vp+qeBrR9e1nS7qK7g urjcsCyxMGU9iwyvIUDjo1XPDr+JvHWsNrN54Wh0LT767ae4mR28q2jdyW8mIguyoCcLnnAG7vWc akXHmn7qW3T/AIJThrZasjlVZtWiRsN+9i4AznLgVJY6HJq1+tusbySSyBURRlmJOAAO9MvrHUPD /jr+wdWYRz2eofYbowSLJ5cscu1ihyFbDLwQcHHXBrZ1vWJvC+pNa6LbpZlWP+l7t8siHoVY/dBH TaB1rok2r2EkmtT6k/b0+ANp4A8BfCnXNHtUktPDVkfDeo3CqFMj+Uhjk28gMxW5Yt6kdzXE/CP4 e+D/ABp+zh4xbULfz7rw1q9tdMIS/mtBcRx7Cx5XDywIAFztwSwAOTqp+11Z/Gn4O6v8D/jPIDqt 5CG0XxAVUD7VGS8IuePkDMBGZVXhHORnLn5t8KfFXXvh9eXem2txcWov7e502+hZigkikGGikX+I EgEngqVBBBAI2eJi406q3jo15f0/wMoxbvDubHh3yNAupL3TW+0XWo30NzDOoUPDcBI1cHBJBV1L c44xx2r1X9oT9pe61HwlqGjwwabYpq32m3uEs25kd4roy98gAz5A5B8xM9Bn5Y8UXmqw6xLe6BqD ozfO643pL0Pzr0Yjnkg5rlo7bWNYuoo9YvW8m3kAL7cKgPOAMAdh0HYelckMOqdaVaL0epvUre1j GFtVod74kubW4MEUK5jutJs5nU8nzTBGXz65YsfxrwXxRB5PiC7j3AkSc/XvXrV9qUcuoS3jRmMP tjhC8bY0UAfhhQPzryDVro6l4hvJEywknYrx1A6VdHWUhVdIxRveDbKSa4QDnJr6K8E6btVNwziv CvAsyx3CRt94HpX0J4PkaRVwa16maPUtFMENuvygketarXVu642jP0rJ0y1WSNSGya0xYx45OKsS Imkh3fNg1L5lvt4XNMfT1b+L86b9mEfG7mi4bhJDHKvyrwRVabS4GB8xRk96qa34m07Qbe9uLl5H FhbrdXCxruKxtIkan05d1GPfPSqHhn4i+E/F0xtdL1UG5C7vs8qlHI9g33vwpOVtwHXVjDG3yqD7 1CY/LUdsV0E9qjLWfNCo+9TtfUCCC9jt1IKgg1n6hdQs25Qeav8AkBc/LzVK60/d0qlsIzWkjb7u OlVZVZvXFX/7PYZPINMksbjBOM96XvdBoztrJ34NW7e5KrtOCP5VH868NHg09ArHB49qdhEV0tvI v3Rms/y/LztXitVhHGx+Whfs8mNw6+tArmO1z8pVlyPSsi8jKSGaMEqea6u4s7eRQcDNUJtNUghR x6UxnOLdbuNwH1qrd7ZFO3GcVq32hy8yRxHHtWY1vJGSkgxj1p2AzVyG/Gra7mX5uRSyW3O6pFXK be9IZ7FZ2kcgVpOf8+tb1vBaxw4VsetQRwLGvzYH0qxG0Z6CnYzRJ9mgxlWLGpFSBODwKRZoo1zt J7cU3aLg7skChXDcV5V+7HGPrVdvO3bguOKu7YoV6A8etRRt9ok8u36+vpSAjs7WaabMgAU109nH b28YDMBx2qpa6WI1G5izdavLB/Dt6UwRBNcW3mFUyT60yW4WNCzLzS3HlRkt1NY99eYzGq5981ID LnVrttyscIPSqMt3LdDy3YqPWm+cd/zKXduMCtzSfDs11IJpo8e1Pl7huZNhplxNIPmbZ710dpoe 3a23NbdvoDR7QqgVoR6e0ar8/wCVFhmFLpMgjzHHio7WzbcBNtHpXV/Z0CfM4rJvreLcTv5qGmtU MrtbbfmVuBVC8ieWaPT7NS91ctsjVRnn1pbzUYbCItNISFFex/BX4cSRwr4z1y1/0y9UG2jcf6iH tx6nr+VVH3yW7G18NPhbo3hnRHbUrWO8u5lG5pVztOew+tegW9lHYRrFaW6Kv3j2rQWIGMeapGMd P60s8aLC86qcgE81TkJI818bXTSTSBTlVGAteGeNL1oXkZmH+6DwK9g8WTNKZZACpJOfSvA/H9+j K8fPfJJrFtgeP+Mr0STSshOWO1fesPQ7Hzpg3Xmr2vK084jDZwM8e9aXhuwG1fl6URBD9UWO1sjn pj61wMpWOQzFQ7FiQGHFei+JLNmh29B0rgrm1Ab5sEZx/SjbUaM+KDDH/ZxUkcfzEY4PPNWre28x mY9h0xViO3fDMVyG6sOxqkB2vwGxB8YfBEzc51+wXnHyk3CAEe4J/Sv0stY4fMe6Mx8wNtkbtvXI PHYZyTn1+tfmn8J500/4i+EtRaQqtrrthcbvTbcIT/Kv0209ofOZWVlaQkqDxweuffofx9K0+ygW 5zDa5daT8VG0+NSgu7eNg27duABBIOPUGvAfE0v9ofFzWLxGLCTDH8Sx/rXuvxFm/svxloGrRRDP k3Ub4X+6UIH/AI8f1r590u6+2fEHUJmYEui8+uCRWVirkGveH5nuJJmLu8r73duWZjyST3zWL/wj YVfmXg17r4i8LW9ro+na5b7nt723VjnkpIoAdT/wLJHsR6GvK9a1aG2VxGvyr96k21oVoVdJQx6f qeks08kcRj1CJBjyY84imZu5Yk2qgdOD615B8TPhve3VzP4g8Nrc+c2+SeG3yWV2HLKvUk88Dn27 V3Vn4wtLHXLeXUIN9pKxhnTIyYnBVtueA2DlWIO1gjY+Wtu9tZNOmWNpAUmjEkTqDsniLEBweMjI PBxhlZThlKj53EOeExTlDrr69zupctSHLI+SLrwv8Qb26Szj8N66PN4O20mI25xxxx6ZPAx7V9Xf s6+DdU+HtrbapdbLfULdt1tbrJnyiSHZnIOJHYxoT1CiNQpG45twXW4BW+dEHy44xk5HX61u2d15 To3mNJnKtn+HnGRzknp2/CvMxmYVaq5fM6I04rVH2nqXibT7Gfw74lhZjZarLHbiTn7k6F4ywxwM 7vpxXwH/AMFFPFMOrfGyz8O6bMYzpGlxR3u1T/rJN7sSP4v3bQ8jpg9eg+t/DH2rxt8D9T0GFZW1 PRll+zJGR5zTRN58CqSDtyQ8WMHgEV+aXxu8Zax44+L3iDxVroENxd3DJIuSkaIm2FOTyQEjVTz2 Oeua+kp4j29KMu+v+ZxRhySfkc1cXl9PYr4bjWdxdt8ibg2XYgkLg8HPUc9SOSa/Rvw98K4/B/7P 2m6XJpJt7/SNLF28LWuyZJwDJMoyd5LMGUE+o4xgD4r/AGR/Btp4y/aS8E6bIkDQWty2oOof5MQR vKODk8lAuO+T0HNfrH4ltVaPc0e4H5G+X+FsA/oSM8da8jM6LqU5SjtF/izpVZ3jF/0jyH4P6l/b HhXVPD2N09uVubdWOcOpBH15Ofwr42+MHhK30uTxB4XgWZ4bZ3ezZ/vyRA+ZATn+8mw/8Cr6c+Fc 0ngj4gHw7co6RRSS2LFjzIiEqrc/3kww+tcH+054R/s3xp/aMUO1buNo5Tuz5kseOnssL26fhXzd Go+Vf3Xb5fEv/bvuO1a/P/hv8j807iIabq11bqqqVkMseRnhuQf++sj8KwLyHxRr14lrq19I1pG/ y/OAij1Cg4Br0P4waPH4f8RgRqFEbm3Zec7WXeh9OnH/AAKub0u68J2yi88T3UjwK3NtGSvmflyR +VfdYap7SjGpueTVhy1HE0/COl6RZ3gtdD0OTW9RXtt3Bfcn7qjpzXp3iTw74st/BMPiPxNrFpGk 9/LZS6RazhfsiiNHikkIOXEn74DGVXyDn7y15/8A8Li1a+s20f4c6PY6Bp8ZCtOUVpTwOcYwCfU5 PTmuZkfSEuG1DxFqVxrF83JMj7+fTngD88elEOZ1OepH79X/AJIJNKPLFna2Nq2vW0+sWbPLBbyC OS42MUEhV2Vd3ckI+D32t6GtO81RdasXstQ2fai263nfjB5JjJ/uknPscdADmDw/rOqWmizXS2a2 Vjrtm0MEbxh2e2W4GZN7DIPmW5XKheAwxg85F4PtFolxbMHilB8uReQ2CQcH2IxXaryXvKzMlpsY V+s1rdDzojG6sVZWb7pB9+KNc3X0ayPzPEoy4HMg4UZPsABz2wOg4jm1CaO4mXUmM4KBU3ICUwMD nqRjHX0GKgvpFsYVvb7WLWCDIPmE4Dj2AySR6AVPI07g5GfHwvkyFlJ+b1BwOB6immVljaSS4OEw MdCR09azbz4g6Lb+bb6bpst67MfL3cLjscHJrlby+8UaoJJlhe2hUFyB8oAH156VaoidVs6HWNe2 wysG+dUZcA8KvXH5D9a8/wBLmY6okjZO5smtqz0HTbzTZb7UPECpPGjN5BHzAjp1+9n2qt4R01NQ 1Dy5FYr044IraKUFoZyk5bnd6HpM0mpJNacqyhjx0Ne8eC9PvlSPcp4x+NeJ+ALy6j8TTw/Z5Hsr aMw+acEEhsj274r6L8K61Y+WmCuPSpa1GnZHe6LBII13Ma2WUDk4zWRp+o2zKpjcDOO9bUdxHIvY 5qvQCtJG0g+VetVJIJl9eO1anmKrdutMkaNv4hRawHj3jS4mlsviFG3zrBptnD82cRlrmzbIA7nO OfX6V4Ilvcy3EcNlFLJcPIFhWPO4uTgbQOc59K98+Ij/AGW38erEx2Xo06M4xg8Qt0+sfUH8OePK fBV9BpfinTL24YCNZxGcrwC+UyfTG7Ofas5O1/X9EM0tF+LXjzw1G9nesurW9qdssdyrLNF7F8Zz 15YNXovhn4teF/FUkdn9oNjevwILj5dx9Fbo38/atbULP4f6dqkeu+LbVpHuikLRLL5azwgjzVZs ZBKfLkcjI9K+Urpg0zsqlRnIzgYx+NCVr8ugNbH2fa25Y/OakltW2lcVWsdy2NuqtlkjUbs88AVd W4XZiRua0hLmimTcz5LPapZeT1qvJGy5757dK05JImODIAKqTeXG3DBgetXsBkXCxt92P/61Z8yk SErHj8K3pnjHzbRj+dVZvLJ4jBoDcxXVmOORUCztCxWRcits28cnRapXVn82Nuc0CsRxTW8gP7za T0zTmwDncCKqPanqKcvy46mgd7E5ZiuFXg5waytR08XXKqQfUCtMTMnI5FH26MHbNGMetMVzibq1 urOQrJGStRxtubcrYNd7JY2epR/JIOR0Nc3qXhS6hLTWfzf7IptX2Ge1R2oCgAFsetSLZr7/AEqV Wkb5RGT3qwqMuNy8DrxSbuZlNbUBh8owB3qcRxwrv3CrXloqbmrPmtZLyTy49wBNMbfQYVFzIVjy Vrb0vRVhUS7SN3P1qzougpAm6bnFam7y22x4CjpSSQEQhWP761VurrarbV7VLdTKuSeSaypJGk+Z gc5ouIo3UjSAnJA9KxbqfMggTl2q9ql3HDu2tg+gqPRLMTSG4mTknNFrlGr4b0HcRNMMt79q7u2t 44FG1R6ZxXJrr0Gn4jWP8q0LbxdH5bDyWJ7cU7i0R1HQLv8AlyapX2p29mpZ5h+dYMcmueIJNtsz RIfUVr2fw5vLjEmoXTuD27VOoGLceI/tUhjtVLc9qWGz1bUGCrGwDd67vS/A9hZkBYBn1rSu9Pkj a30nR7cSahfP5UKgfd9XPso5pMdzA+F/wxbxZ4mM2pReZpmmOrTZGRLJ2T8O/wCFfUBs9sawRoqo qgAKOg7CsnwX4Zt/Cui2+j2q7mhGZJCOZHPLMfXJroMbf4sE1T0VkJakSx/dGAKbqMI+wuMbMrg1 cht93zMetP1aLy7FRw2c471LWgI8N8dCOCN/LTGxT17mvmnxgzXE0jyYw9fSPxGaSG3mWbGTn8a+ aPFG5fN3ZG0k9azsJnmd3C0t+/zE4auv8O6eVhG5a52zt/Oust0LGvRtGsfLtl+U+tC2Dc53XbNm hbapAH61w19pjZOVHPzfhXreoWO+M5XqK5S+0hgBKEyDx+FCGcOtmV2KpChWz+JqVbEoMYPXqORn v0ralsVOdvJXke/tTPsh6fw+vpVgitpbS6bdW91Cu54JFkQN6g5H6iv1JDQyTCeEERzIrKG67SAc 4+mDX5i+ThRj+9wfSv0T+Ferrrnwy8H6r9taZptJt7eQsCSZYwIX574aJvzPTmrXwgtx/wAUrLzL LSNUDbjFcNG2COA8ZP1/g/X3r5g0uZV+ITQ/MryNIrZ6YDcAfma+s/GVr9v8Mz4jB8p1kB/uAMMn 8iwr4x8cTzaD4ll1aw3A2sglK99rKC35Zz+FR1G3ax9N2d9cw+GY7KeNZbR5Z7V0bnYMROjeoLGS UZ7bBjvXk3i7wrZ30jmxvJbdG6gqGz9OmPxzWl8Pfi5oeo276Xql8kNnq0SQzTN/ywkVg0ch4ztB BU+iuTyQK09etbjT7qWxuV2TRkBlzkdCQRjIOQwII7EYpIZ5ynw+8MxWYiuNPmvL37QspuZZ2GEC sCgVcDBJU55Py+5qnrUR8NW628lkH0WUxuZVjDy2rAEZDd156ZAOFz0BHaKu5m3enUc85/TjNWYr W3voHsriMPHKNrKehrhxtGNeHLI3oScXdHntrMFjiuoXSW3nJ8uZGyrdOhHsRx7j1rWtZmk58z52 w6kj3xgH0x1qjN8Kdc8N69BqXhO4DaRcXCi+sZfmREYgM6DtjJOB1x64I6DUNEuNOuJ/tEZRomHm LjIjDBthU9GBA4P9RXxuMoyw7977z1YNSV0eofB34mWPgE6xeagss1lJbxSuIYzJIojmVdw77Vil mkYnoqE84r859fvodZ1a/wBY2/Ymvbxp/Lhy4iG5iYwGGTyTzxjHoQR9x+DdSt9H1zT9QuI0NoZP s915qhlMD5jnzkYI8qR+M/jg18VzaNZeHvF2ueH/ABDJdWl/ZX8tu0UceRFMjOrEkAkBWHTBB+te jlOJfK4Su+XZepjUpKc97X6n0R/wTU0W1vvjlrGo3dq0sml+H5JbeU42xyPLEhYYPBKM4/4E+a/S nU4t8R+ZQv8AFuxjH48V+Xf7A/ja28K/tFjTzIiWmuQSaWzsSCNx3RYxwSZEiTn1NfqZdKZIHVSR kdc9K9qMVVw9Vf1sjjrKUKiufMHxQsx4f+IFr4kgZY4tTWO6xu5eWELGxwf4Qhgx9TV79oaxtta8 EweKI1hZ7TypnkZ/mCMRGVHfLmRGPtHXR/HzSGuvC8OowsUTTrpNxC7y8crCMAHsN7Rscdk5rD8O wweLvh7fWdxdIgNr/Z1wxGSkR3oZQDwCqSytyOqr6V+eYmUqFVKOz3+XX7r/AHnr0Hzw81/X+R+b f7RmjLqapeWwPmtCQoVfvPG2Rk+pzj/gNfOMy22oRp9oUFeGUKelfYPxE0K6uI59Nvbdobu1uNkk LDDRuCVcH3Bzn6V5h4X+COn/ANoXcVzb7/IuWH+kP+7jByQMDrgEdc19rkuIiqbpyex52Mg3LmR5 TpPhua5hUCVLK1ZdxY8bx64HJ/l71rpceD/DkC3ENq2qz54kbDJkdgudo5zncW6dBX1Npf7Pfwl8 beGdU+0XkieIbGWB4dNguhFDcWm0rJsAG5nVghOD91jgenzP8R/Afh3w34wvtF0S3FhptmyKI3md stsBZiXJJJJPA7Y4r2nT5oe05tOxxqVpctjN1z4qeIPFWm2Oi6kwWx0yF7W1jgQGZbd3L+SZMfcD u5A7biBgHFdF4QuGj8G3omsbaCO81OLysD95ELeF93zEfdf7UucEcwjIOBjloZ9G0+GRbO1N5JD/ AHflUH+Z+mBUF14m8feJNJ/4Re1sI7LS/NZ0Zogkke8ASBcc4YKv3sngUQ320Q2abvaeJNLudY06 FxHbSJHJ5ihT84bYQM8ghG6dMDOMiuX1DSLc3BlutNjMm0Hcy5OMAj8813vh3w7aab4T1mC6vEXU ne0kt/MlCBrZPNEyAE8sWeBsekbVy3w602PXNZu9P86GIa3a3qRM/LtLGrT28aZ6PLJBHCuOT5uO 9aQlzK6ZL03R0Xwxb4W2Vj4lbxla3I1BNOLaJ9lUFUuQG5k/2dxj4xyCwyOM8vq2teHdU8Za+LOG DStOuLu4l02FmJVEMhKQknoAhwCfRc/eJGVDrDeB/Fyaw9ol7A/n2l7atwxilt/LbkghW2SMUODh lzjis/xRqGn3cMf9llpBb3DFLkoy+aHQArg+gRc9fvVola6YHNeKNB+xancLasWiVl+Uc+WSpO0/ TBqhGbmxVo4rhl3KC23jr2retcR28lrHM586UZKHau8K6qSx7EMevbNZxlWO3mtPLH7zC789g2af OP2b6nc+HvGnhfwroUVnD9rvZpF82XauAhPUZPpXrPgHxDpeo2sF8smyKZdyl2xjtg/jXzDtXy9n lncc5bP48VPDcXhh+ytNKyJ8scW4kDJJPH1pPUXK0foFoEFhdQrIkisG7hs11EemxqAyTZH1r5A+ FXxusfAPhGHSdSt7u7uY5JWCL2BbIGT9TVvxF+1T421GFrXw1ptrowPSZj9olH0LAIM+6mlGXcLM +trqyt7e3kvLq+jt4Il3ySSOFRAO5J4A+teUeMPj98L/AAu0tva61Nrd3HlfL09N0ecAjMrYQg56 oW78cV8m+IPFXivxbcC58Sa7fX7rnZ50xYJ/ur0X8AKzPJAXsc989KLlKFzt774s+MLzTb6xtpkj tL6RZZ/PCyySODuByQO4PGMVztr4y1e3lYzLHdKZNwDKFwfYrjHf86zZbXy7MTeauWcjbzuxgY9s cH3/AAxVXnbkYzSsrFy13PQbz4ijxFb21rrGp3cQtUaOION4UHPG4cnsCSOg9qo3NvCtu08NykyA Fty8jAGe2f8AOa4vyfnwSR3FAmktv9SzJjrg/e9qLWJaufoPb+F7hbdP33RRTm8K3TL/AMfHX3r5 b8J/tYePtHVbfxHBa63Dj7zAQTf99KNv5rnjrXtvgH4/eFfHkws7S4lstQ/587rarvxk7CCQ+OeB zx0ohLlioyM2jqLzw7fRKdsxIrLbSdRT78hINdhJqHnANjtUHyzcjBGK20JOcXT7wr8vOaZLpOoE HaproTHsyVbGKjlu/LGWwaE7DOUlsdSh6KcmoZbTUGXLZIFdRLfRyKVCjIqo8wk4OO3egDl5re6U Hg1B5ki/K0JP4V0kgRGIbBqBjAxwVA9aYHOtcyIdrRHBNRXMnmLlIyGroZo7dst5YPPpzVKT7PHn bGM0Csc2t1eQN8qsKu2mvTKwjmOD71bn8lh8q4Nc5f29wrkxISKBn0O0sS/LHSrJ8p3d6lhjjjUb lGT1qeG3ErjauR0zQZ3uU5FkmYIqnnpWtpOkFMSyMAR7U7ba2eGY5b0qbzNQuQPs8eExRcCea4EY Kh8DvVGS7XPGfQGp10m4uJMzPtA60TWdnb/6xs49+lIdjOZZJF3HOBWNq2oizXy0bLnoq1c1PWMy fY9OXczccdql07wykJF9qTF5D82D2o3GYFjpV1eSLdXSnLH5Qa6uz0WaZVij4Y+lOT/TLgQWkYVE 74rrtL0028YwOcdaBbFPSfCtpDg3EYkY9c12Fn4X0eaH/j1jU/7tUVhmVdyitfTbpo0CydRRcZAv h5LFt9rCAB6Vo2955a+XNHgmtOC4gdN3BqO6W3cbioHvSuMpXOpW9rC9xMwRI1LFj6Cut+FPhe6x L401RNtzfoEtI2X/AFNvnP5t1P4Vx2g+Hl8feKV0tZD/AGVpTLNfsP8Alq/VYf5E+31r36O3jjVb eNAojAAXHSqW3N1IerGLuV+oK/yqXarAscE/7NOWNBGSxO1T278VLF5ccbbsH8KGAsa9M43e1GvK slnDtY5wTxVa61KzsVMs00cSKMsWYDFeMfEb9oRvOm0PwJpsmrXVtGfMki5C9uB3qJPoO6RmfF68 tLGCfzpwh/2u9fLfifVlu7o2tijXE8nyrHEM/jXuGjfA34pfGKYat4x1Y6ZbSNv8rcC6r/u9Qc4r 2rRf2Z/Avgnw202l6cJ9QMLb7yUkuTj8hSVNpXloK/MfCmm6XNb3SQ3CgOfmZfQ16TpdqVtwCo6V kXHh6R/Gt7Z72CrKVX8zXWDTLyzj2qqyAdxSTuhmbcWe75SKyLiw/csrLyjcVuzNeKTutz+VVZo5 5V/1JB/nQCscLfaaqNuYZH+7VKS1z8qggcZ9+/8AhXXX2nytyykc59qpf2ftI3rkgfSqQkczJb4B JXr3r7A/Zh8RRap8Jzo0t1b+f4c1KWKGEZysM5WRC3ORmV58Hp8nrjPyzdWaqCdvTuOa9Q/Zq8UR 6D4u1LQbqZ1g13TZViVF4N1B++jZiSAMIswHu/vVLsB9fM0F5ZTW7MCk0bx8cqVII/DGf1r4w+Li 3Gn+KrqO8t/9Yoyu3GNuQR+GAPwr7BtbloJpIy20Ko2443DByRk8jt78V4F8T/hB4+8ffEu4NtZW tv4ee2Dx3zy4IdlzIhVRuLBhn0+br1qbaldD5Y0+4vNH19Zre1mm06STLLADIYfXKjnbz26V9M6L rl7DpNtDNENQtJLcLD5jfNGuMjy3x8oBxx0r074dfs/+AfBkMU8to2q6oVCiW4+VI2wN+1VOMZIw T2zmvTbzRtL1m3Wz1LTYJ0jzGrEYYcnoe2PbtinZWFG5856atvqTNGzm0mIHlxTfx8jgMBj359K3 E0O4sZhHdxlSB09f8a9E174P2cG2409mazkzs8wfMnJ4J7/WqOjabLbrLoGrbmSRs28rLko/oST0 4x+JrmrRdjeD1MOxVUUJxz8v0qLxTp8NzpMeqNFJNJZ/JMsbYaa2LAyR+/A3LnIDKpx1q5qFpNZ3 Bt5otjxEx42gHOSecdep5+lW9Nk+SdX+bC7gpGR+v4V4GOpKpH3tj0qEuh4n4z1jTfA+k6lqGuzK lvp7mO4ljVpBuyUwpUZIZnA9CdpPGa+ffgxZ6D+0B8YNYm1iOe9sGvF1G8h8wW0l2DIpkLlc7C+H LEEHJyGHWvo3xvocXijQLrS7yGBbe/sXsIlWPIURH7MJDx94NAz/AFHvmvz/APgv8TJfhz8TrTxF p9wyWZnWSZVx8w545BHfGcdz9Dnw9Rp885P4l91jDGzkklE9gTSdS/Z7/awPhe8u0jOmajELW8CE xlXVZLeZUycAq8bAZOO5JFfsnoGr23iHQ9P12z4g1G1iuox6K6hgPrzX5M/t3NYeKLj4b/HLwjGw 07XtBS3aYKw23FtM8ZBPA4AVRgdE96+9/wBiH4sj4sfA3Tby4mia/wBKkazuFTapx95TtUAKOWQe ojz1NfSSiqWIt0kvxX9M4k+aF+x6b440VdW0290xsxpfW8sPnKgLKzIVB/AnI9+eor5u0H4iH4ar rGm6xpcjSyRupgD8o4428jBXOeehGcda+r9etTcWciq2PlbvgZx39q+TPjNoL3F00zZJ24LMvIIP yj14BAx2x7V8LnFD2GK203PTwk7wPmj4g6k2ueKNX1aZUD6jfXFyTGOGMjliR6ck9K8vl1C6bVmi 8x18yPaVzxuTI/qfyr0zxNpsyswmYAhifvck/wCSK8n15ltdaMy8BZA3HYFf/wBf51tlVTkqJmmI jzwNNdQurORLi3uJI5kIKupwQQeuR0qDxJb+HfiHcLc+OtEuJbvb5b32ny+TNKBgDzRjD4HGRg47 mtrSNIs77/SprhRGRnkitG1Hh6bUk0nT1kvbtuBHChb8yK+0g2lc8eVmeQeJvDXhrwDbxN4KsLya 2uVYzR7HeQPx1Y54II6ehrzLWvFHii3jkmi0mewh6edJGASfQbun6V98XnwJvtI8G6p488YQvY6R pNjLf3GE3SmKNSzYXqSQOK+JfiN8WLLxhYzaNpnhyy0zT5HDNlzNcNtbI+c4A/Ad+tDSm+axVnBc tzy+4ka+mea/1GSZ26YYkk8dSeaf5szafusWkt7mylEyyq5Dshwowc8FWAIAGfmJ7UiW8UiNZQ4T ziB5zk5yOi+nJx+OKS1k+zoxWNRMcruZc9VKkYP1qxwjzMu29yq2Gq211eXN5HcGOdd8mN0yttSR gcliEeQYz3PPaprW60ubT7yxv5VgQwmW1YR7yswxtXrkK2GHcAsDWdcGJS8dvvlAPyEjaSOnT6+9 XrXRbewiN3r0jKrY228eNzemT2/CobO1U1BWMf7NcTf6qORwV3EqOMZxk+lO0/RbrU7gWtuqljnl fmx61r+Te6tNHb2tuqRP9y3j+7j39fqa9d8GeEbWzs5bm4WF7kWxVsqBtAAUDI49PyqZ1ORFQh7W Wmx4bPpccMzwxsZNpK7m7/QCkXTuisQB6V61qnhPSri4M20oAcnb/KudvvCvkvut1cgfhjPoencf /WpKtFkzw8k2cjHYojFPL27Seo/nUjWuI/MVl44wTyev+H6108Phv5iskvzpH5hx0PI4z36k/hUz aDbeSse9VPJbjpz3PpR7WIKgziJFxnjjpUar39O9W9QVUvBZRyIW3CPdnIznrkdfqK0x4L1aO1N9 dwywDbvVSvLDH8q0voZKDb90z9YtrGKz0sWyzeebXdfCT7qzPJIU2kD7ph8k9Tzu+gpxWMjoZlXK pywxwPf9f1rv/H1wuteE/CNzb6bb2Zt9LMEzw7f9JmSd1LsFPDbBGDkDOM98nlbe18mJZJmKqw6K OT2wKpu0UEIXMSZVh3ySMFRByePqapTSb9pxtTgHHp9K09Y0y48gPIjbY5gJBjpz0z37VoeH7Gzm 1zT4bxkW3knjineRN4WNmAZsewJP4UX0IlF3sczGu/G3k1YsNT1DRNSg1bTbgwXdnIskbj+Fgc/j 9O9LJCI2fywAq/L71XkHmccnrmqavoZ7I+/PB2sW/iTwtpXiKEBBqFrHOU3Z2MyglfwJI/CthZlX 7rc/TrXF/CUww/DPw1bwsOdLt3Iz/EyBm/UmukmEytmMH/CilrBGb3L7FplOBgVQuLN2BZWzjtT4 b6SP93KuM1oQtHIueDWgjmJkmhzvU0sTCXq3SugurNG/hB/KsS6sfLJkjyMelG4rEV1H8oZWwO9U ZcKo2rnBqwyvIu3oRSRxyL/AG9aEBnMzMSrZ/E9KjZozkMK05bH7QMqu3NRHR5I2+bPHb1qrAZDI GbcEzUscEbqTtzj1q/ND5LbTGAPpVOSZV+ZMDHUUFJWPZbdIwf8ASDgCrAlkZttqmE/vEd6twaSs pEzDGOFFX009kXEaAj1qTOxn29vCjeZNktVxb2Tb5dtHgU+WwO4FyFB7Cms0MC+WuC9AirPdTKp8 ybbnmsKWHUNUmMEMjbP4mrdaxW4YzXEmB71FcaxpWjoSsgyF/OltuNFnStA0/RovNkwzgfMzVnap qn9oTHT9Nj3N03elUE1TUPE032ez3pCTy3+Fd94X8I2unosrR75T1Zu9G+4Ffwr4SlhhSWbljzXb 2OkKoCtipbeNYRhI8D6VoW8iyfLtIxTGiFtJ2ruUcGoJNM2k10MTL5flsM1VuliPfBFS2Mwts9vl VzgVl65qV7HHDY2C+ZfX0nk26Z/iPUn2AyTXQX1xa2tvJdTSokcSlmZj0FUPg9oMnjTWLzxtqSst oQYdPjPQQ5OXx6uR+VOK5nYmTtp1PS/hv4atvDHh9LK1O9pWLyzMcNM5+85+pzj2xXbC453S4G0e tcB42+IvhfwVb7ry8jWRF2xxKw4xXE2fiH4tfFYrH4R0uTTtHkOBqFwoQN6FAcFhV35vhI5rHrmu eOPDfhuHzNV1W3iQc7Wbn8q81vvjfq/ia4Om/DXwzdao/wB0XLIVhU+7EYrpvDv7MfhmO7XVPGWq XniC73ZIuGKxA/7gPIzjrXqdno2n+H9P+y2WnwwwRLlI4YwMClZdWP3meF2PwX8b+NLgXXxM8VSR xMctp9i21QPQt1Nd1o/w/wDC/gmW0h8N6LFbB32SSKu52BBzuY812zSN5KXVvbmYFtsu75CwyM9e 9ULyPUP7ftYbWMmyZZZJFZPmjHGCT9T0pp2+HQC1DapEwaPClfSuiTdeeG7qNky6KefWsuOILtY5 5OM+9dBokaSQXNqcYkT/AD/Ok1oWfBGpaW1v8RL1HXDNK34cmultdIa1j+ztlurEnrkmpPiHYf2b 8VJ1ZGTzJD2/H+tdA9rhN6rn5axgvdTEjjL+xjjJ/d5x7VlTWYX5mUKo9a7a9tVf95txuGcVxniS RoR5cecDk1YbnOa1dW8CMvBIFc1NeK+VC85zxU2qyee7rHIrr/sn2rFVZWcc4Ucfj1pCvYnuH3ZI 5zjFO8PazN4d8Rad4itI1efTruK7SIttWRo3VtpPo2MH2JqNh8pXk84qEQq27coIB6079gPu7S5b O8sIJ7KQy21/bxXdvI7j54WwY2I7cMnHXp9auatrdto2myaleTfuYUEm5sDBOB0zjJBHHooyeK8j /Z98VTap4NGlzTyNc+GXMHLD/j0mDNH15PziQHH3VRPXjN/bfbxBH+zf4nk8NQ3H2hZbZmaPOVtf NCz59AFZiTRL+6UmeneCfiBpPjS4jutK1CK4jaRo43t490Qy2Coc7Q445bcB15Ar0extJtsa3Mf+ sDSxSR52SAMAcdwVxyD9QTXnn7NPw/0zRfAGjKrHFvZwZVzkqDGM7vQliflPJyc46V7XeT2Bsbf7 H95Lm3KrGM4VpBG2cdcxl/wFVKPL7oou6JYbHzrKS3kjBD59CASa4zWtHVUM0ahXhfjI6EHj+Vei WssTRjken865fX5I1e7QtwTn8xUS2LR5n42sVkmi1Ly2jF4hba3OMfLngD7wAb8SK5qxUW9wu5iV I2tj3Fdl4mm86aOznVR9niTad27cHUOPpgMOPavPvGOqf2Bo890rBbmX9zbe8pBIx0yQAWx3246m vCxlkpX2O+g7WOA1zUrW6njhsVYpbvcxkKvZru4kRlIIzlJFYHpmvzp+Inw7k8GeNtb0ezjSKC1v JHtoXffthY7oQT1J2FOffnBr9HNA8H6hrksZkMOnWEaoiz3EpbdGgwAgAy4AU/McLyfmJrz39r74 A+GdN+Go+MXhPxLY+Ib3TbiOz1xomTMMEuFSTiQ8rMVTbgkicZ4WuLI6OIpVpTlG0ZL/AIYWMnGa t1PmL4e/Eoav8P734J/EK8eTSJQ8+kSzTBf7MvznY6naSYXcgSKMnncoyCK+gv8Agnb8XP8AhTvx V1H4YeN7o6Vo/imMLayXTqsa3qEeSS7YADqZEyOrNGMdx598H/2VtT+J2j2Xim/8UWWmabcTLFE0 NuJ5WZmIUH5gAflbP3sYPvj7Ttf2O/hB4X+HR1rTdBvL7xHYAOmpX9w5b1yqLtTbzwSpI/vcCvpZ r2ist1qjhjofWt0qyQnk4I/h5zXzz8XtDFw0s20rtXzC27nOMgY+vHsTnoa6j9lnxLda18NZND1K Z5Lvw5fS6fukk3O0PEkR9gFfyx7R1B+0Bq2j+E9JXVNQ8ya8vJPs1hYW4Uz3s5UkJGpI6YBZiQqq rMxCgmvmM/o+2pxxCXkztwsuSTiz4c+K15aeGbWW4ug5uHcxQQoTvlk7KB17ZJPQc9q8Cvl1S8eN bmHa80geV243McDjvgAAD2Ar3bxVpOrXmpTeJfEnlNqUse2OCPmGwjPJhjJ5Y9C0hALn0ACjyDxN HIriVl2sTkH8M5HvXl4JqFurO+d2j274JeDbHxNpcf2jSYPMBxgrnHPvX198MfhT4f8ACax6nDpV s12vP+rHI7r+I4/GvEf2YpNLvPD9pqAwryqGcej9D+oNfT9rq1jZ2jXN3dRW9vCu55ZGCoijuSel fbUarnBNHkyhytnzP+0V+218K/g3qet/C1fCt74v1W0UWtxCXjhsGjljVjFJM25mYJIAyiNhkFSQ QcflZfr4duNYvb200821rNdNJb2YmMvkwsxKxh2wX2gqMnk4ye9fT37f2kfBHxF8Qv8AhNvhB4+s dT1jVJANc0+zDTW4fbgXMcyAx5O3DoDnOGwcuR8mLpc8fkedeQlpZWiZC2DHjaQx9Ad3/jp4rokk vhehCuye40uTSb7y7mGO6DxLPiFiUwV3HaR/dOVJGRlW64q1a2MOr3i2pmS1ncMZGzvLk5ZSCTj7 xVTyMDnnBzKr2dxpP2H/AEiW6jffEWZQsagMXGSf4vk6f3T61T0m3ke6NvtG2TAcgZO3O7HTuR9e KzcjtpUrLmsaVnpNrYzTalIxubeM5hZl6jPDEfn+tZ9wlzqkpvWRnUSARr6k9Bx9K6DWFl8m1020 Kr5o2sOgP58dK2tH0OxsbcX2pFEijT5VY8g44brx26+lZKVlzM2cXJ8pd8J+Hf7LsFvriIC4ZiWY 87FG3A/PHPsa7i2njstPvgylPPj8s88MNwJH/joP4CvPr74haBao0aebctnO1RxzjIyeMcDpXM6r 8TtWvlEVtGkCLwMnccfoP0rL2c56msa1KloehXd9Fh1bpngZyAO1cvqXjDS7FZLdLkMcdFbdk+hx Xn91qupakx+1XcjjOSvb64qfR9Jt9W1KCzuLtLSF3AmupRxEv8TYHXAzgDk8AcmtI0Ut2YSxLfwo 1NR8d3F3CYLKxkWFVG5S3cd8Cq0Y1zXwqQzBY17ADn+97+tO1iztbDUnktlENqkSxyIjk/KFAO45 zlsbj0ALEcYrO0nxDMJzHpSZhjBG48bmPXtWvIo/CiFPX949zsNA8B2tvdJdXl40khUOY1XjPZck 89uP6V6JrWpNqem2LXEYkksLfyJN23OwMdhJx2Vgvr8o6157pviiPy3jmtZBOPnj6FXfODubIIGM nIB5GMc5rqY75vsI+Uq86nzg2MP2x16c55A57cVm73947KSpyVonB61dXtrH9jaZ5bBS8scOcpFI +A7KP4c4BPHUDPSsOGaExtK0x3ow8tNvBznPOeoO3sc88jAB9Hv/AA14f1TR7F9OvNRkvB5g1JWC iOCUyP5YHGWBjVWyT1JGeMDkrrwOzb/sNwsw9D8jdvw/WtYu8dTgqS5ZOxmTav8AaoHWRmla4GZR JwSxJGc9/r7ms283WrPH5gLK23g5wM+3BqxeaDeWGWbfG54Acff55wemPesua3uof+WbEFccHNUl bYmcm9x01vP9nS4aBxHIxRXK8EjnAPfqPzFUiBHyGI7VYmumP7mFn8pD8qNnCk4zx/npU+i6XNrG oQ2MYO0uPMfHCL3/ABwP1qr2Wpi2j6o+GN5NB4b0iwMmGgs4YmU9RhAP6V6pYxzTIGYdRXj3hG1C shWYjGK9g0XUPIhCuASKVPQxZYfTWfrGMipIbV48ALkU+TWF5wtUJtYmGfLXmtdwNhrVnU/Lj61S n0vfw2BmsWfWNWboxQVTbWdWRirOT9aAN+HSY1J3KD9aibT4lPYYrGOtapgnkY4qpNrGo7huVsel UtAZutDbr8quKqXlwbVC3Ddqy1vJJMgggmpGVpFwzZHvTTsBFLeQ3GV24z1rOuLdWY7s/Wry28ay HJ4pJvIA2s2QOPei40e7reW+7ZvJGfyp02rxwKVh+Ymq0Oi+XGq+YfqfWrMem2ykGTGQeuaVjMz/ ALXf3chkO4L2qCaZrUGZs59K1Lq+s7VSsfbrXJ6rqTXbNHbqZHJxgdBSEQat4huJGKK5IPZaseH/ AAVe63It1qTMIzyE9au+GfCMk0y3E0O49ST2r1rSdHEESjaOlNJLcoytC8J2enR7IogMdOK37fda ttkjAArUjtRGq9Khuo97bdtSwCJ0mxtHT3q9HAqkMvH0qvZwmNTkdassrKvDYoGSyTNHjnFZ1xdZ YjsankVpF+dqxfE2oWvh/wAP3usXTfLaQtIR64HAqW7AZFzpcvxH8W23w902ZxbAC41aVOiQ9o8+ rYP4V6H8XPH2j/CHweul6VBHFJ5HlwKuPlAGBTv2YfBNx4f8B3XjbXlB1HxGzahM+clY+dq+wC4r 5g+PHiibxl46lkhWWe3hYBbfn5+cADHqadROFqXV7/15bGN7rmO++Anwp1/4y65/wsjxxIZNDgnx bW8nIuZAf4h/dH86+v77VvD/AIN0gXWsXUNnp8bJEd2FWPJCgD6HFYnwZjWw+Fuh27aYunmG1VWh TkeYM7iD7nmvjf8Abm+MVxNqEnhSG+ltLbTDudI5Mee7KpBI9Bk4qsTUVH93H+vMqnG+vVnvniL9 tT4b6Nrlzoujabe6zFDKU8+2KhWxn5hu6jj8a0/B/wC1r4N8Wa59g1bRZdH0+QbYri7kHH+9tyB+ dflJ4O+Oknhu+kXVNKF5bSHBZWwwHfg19GeD/F/h/wAa6b/amh3ivGT80fRoz6EVMHdXvcpxaP0+ 0zUNI8UaQmq+H9QivbKRiI5Y2ypIOCM/Wmx28tnIsmSCh2fh6fSvjr9n/wCL2peA/FFroM95u0XU Zwk0Mr/JEx4Egz0OcZr7ami8yMzxruRxu9ce4NaNWV0Cd9DOaNmYCPoxzz2rU0VmjuE38Bvlqmq7 WI2nae9WYCVkSQckHJpDPmX9pPR20zx5DqaxsEdg2e3P+RTrcLcWMcq4wVBNeoftNeF21bwtHrFv GWNv97A7dj/KvHfAN8t7onlzSAPFxzWUVa6Fsye8tVSEnrgcfSvLvFMVxf6pDolrbmRriVYdqjcZ XY4CgfU4x6167eBSu0ZYivPL6a40HXrDxFax75NOuorpVJ4Yo4bHTjPIz701ugfkeR+IPCsej6xc Wtzam3nt52ik2/KVZTg5xxWWpkhfy5mLH++APm9M9q9L8Yaovi7UrrVI7JoIG3xwhwAxAbcM46nn k9+a4ZrNPOTzlCwu2GYHqOh/HjpR6i3KgTcA3Xnp60m3a+3bn2q3cWslqzR+S6JsilG4g7VlTemS CcErng8ggjqDVdwNwbr+FCaew7HXfB/xgngvxzZX15OsdhfK1hePJ91IZflMjZ7Idrn2XFfYM+k2 OrWFzpOrWsV9azg208bYeORHT5ky3DABsHPt7V8HOucjoG+ZcetfYHwR8bw+Mvh/Y+dM0d/on/Et vy3LSHBMMuepLKACSeWWQ9MVe6EtGdBoWl614Tt00PRJSNMhO4M3zuy4JUckE4Pf2HNddot3dQ20 FrIwjRARG0xG/eQQufQYJA5xlsnmokhXgM+5G/iXoQuT7fxY4/wxXwz+0z+35q3hnxdq3wp+F/he aO+sLqTTb7VLxMkyo+0iCE9RkcM/XHC4Oam/Qu1j7n1z4reEPh3YpqnjTxFa6XEzC3hWaTEkrEj5 UjHzOwyOFBPPvWLrHxC0fVIf7Us7rbBdr5kW5TucbePlHOen51+fnwp8H+MfiD4sPi74mXV5ea1d Ym/0qQyPChJ5OejHsBgKM8dK+jL641WGNYfOEUEY2qB2ApSVlZhFs6+/8aMGknezYFyx27goHHBH U4Bxx6DrXDeLPEButFl8Za9bxSWGlxyBYI23GZRKEA4yVaW4MUJyAAqq3ygknn9WvJDNJtmkKHJB Y9cduKi+Icn2z4J+HLfS8GSHWEh1STfjyllu7kqhydv35bRuemVOQM15WPp/BHo3r8tTroPmvdni uqeKPil8aNWmjsZpodKikjhjtEm8uB22gh1QEGRdysV3Bto2AnOM52q+FZvCGn3FlrekRyQM6tvk gVLhpWZdvlchyxzjaT0PTIr2H9mn40fCf4U2d8viSP7dcWttl9PFrtnEsUTuIjuwFcSKsR9XboQM 1xvjnxt4q8beMJviVrGm29hd30sknh3QYZAYLFUjYC6nLfITEjM+5sKuXcgFpNvS4qEU+u3mSlq0 tjf+HPjKT4K65Z+AbPytQ0+1b7RftEp8vRruRQkqrKzAmIu+HVsBWIySRhPtTwL8afhvL4MMni7x rpWmQ3kTxxC/u44vOILKwiQkFyTjCqCTX5L3d5q2qLbaPpesS3l1qV+NyM0h82Ta/wC8KEcgbmxn n727BIFfdvwj/YEjbwcviK48aabDqur24b7f/ZxvZkJHJUvIoR87xkbj0IweBrQpvn5rmU3odH+z D8Z/CmrfE7x7H8Pp/wC2dJnS3jjT/U3N5fFpGgSCF8OI/L+0GSSQKE2DPAzXf+PF8J29xea34s8W Wmq+KruNreWOxV7lLGLgrZwKmfLXeFLM20yMNzcKqp4Fr37Mug/sxveX/hbVr3Wbi6SOS5k1BU8q YJ82wxgYAOWGQd2GYAjNfa9npfhi68I2upeFtPtbS01O0iuI3jh2F4XUONx4PIbv6+9eHm1CpUhK Ktyr3v6X+b67HRQnGMlJ7nwV4ys7y8mLxaTLBG/3PtGNzZ9lPqcjn+VeK+K9JaHfG0ZLopbbt54G T79Aa+svjBpFx/aRZdoWOaOVVLEggFTtbBH3u4yDivA/iddLrWrXd/Dp9pZfaZzMsNuPLSE5JVUJ yVUbunsPqPlsNW949Nq6OO+BfxbuPh/4yNjq1066RdxsGTrslAypHcZxj8R6V3n7SXjLXPi78P5v Duj60LQJNHdx27MRFPsBxG5B9SGBPRlXtXzJ4mm+w3xkV8BJC2cY61D4u+K2qaLbWun20iwRzW4f zmhLFj0O3Py8Yx36mvt8sqfuzy8TH3jxjUr/AFy3un0+4jmikRtrRBcEEeoFamj/AGl2aS6t18px iQTHrkHHTkHg4/Cn3HjCzupJpmh8+4kXa0sqgEnPUAdMe1TQxQ6jHNqVnJHNcSl2kt3Vgy5OdyHJ zjk9QevB7979LGcEm9xt3arbnEc0su/cJGdQMNuORkEg/KFJPHUjHHOx4ZsVuGkuTGEJztC8hevA z1/PvWZBbRPCq+c/mv8ALjAAB4xz34zXaeH0aK0ZW8okRhdygYChdq4OPQD61z1ZWR7FNe6jJiax 0/Upb3VIRPFbK0YVlIO49McgnB965fX/ABHeaxMVmkYQhspGB26D61q+IpG854lbarncVXjPAx/n 3Fc59n2sWMYI5+X6irhbc5ar1sih5ZkJbaRk8U5IN7bfbqKt+WrZZu2KVY0Uf8C/wq+Yw5SFbf68 datiyVrW6l34EMJfBzz8yrkcHkbs84GB17U1TtC4UE/d+tbmg+W2l+IRJcCONtLiViQec31qOcc/ 7XAPAP4VF3aHZHE+INWmk0uLSl+Uyygk/wB5R6/iR+VdLouhpZ2EUKLuJX5m75Nctqitda1p8L4X 8PevTbG1jihRVbcAoLMVx25/mRTk+VIUU5TbfQzrbT1jYb2KcYAVc54PftyB+Ga7PTRdaloN1cMF Z9GiGQqgAxNIF3nA4ILgZI53L3rJW3Vm3MFwMN/+sd+35Vu+EbeyuNant57VZY5dPvmIXGU8u2ll 3AEjOPLBwDnHY9Di3zNHVTfJsdp+z/Z2N94g8S2OqafFd22o+DNfBWYH5JYLKa7ice6y28bDtx7V 5XdyYuJWtS8URY+UpbeVXJxkgDn1OB9K9U+DMKyah4hN9DCoXw1rV1HHwoSRdOuFXBzuON7cdyQT nFeOXFwwkaHnCk+n+TWtF3pNf3v0RzYxJVfkTNqEyqYplDbgFUHoAB7cc55yP51nahbaffbIbKxM dwxXzJFU7VJPPoOmOMUs0nm7gqAk8g88Vc01o4NJS7TBdpWLqRkAZIH/AKCKG7GeHh7SdmYl34H+ 0Ay/2oIlX+JbfJ7+p/zmq0NvN4LvFaS6e5jdifMZcH8hWvr/AIws7AR2NtIJ7mQFpEQZ2k9Pb3/G sPUNQfWkVJIwhGSQzDgfU9eTRFye5vVhR1jHc9d8I+MrCZEfzlOR2PWvWtD8QWl0ibpgf6V8WRX1 1pcv+jSEKp7etek+BfGt7M6RyTHir+E4Gj64tPss2PmBBq4LGEk7V4Feb+Fdfluo1LOa9K0q5WRA G281opXJsMexiZfuD61mXemYYFV4BrrxZrIuV5JqCay+XbtpgcpbwwqxWZfzqWbTLeaPK4BGa1Zt PjYkFRWfJDLDu2HinqgMaXT/ACf4cgHrUUkHyjbn3q9NdSIxDrzTBJHKpJ64pjMiS2Zj98/nVSax kV22sTXR/ZI5AQvUe1NNm393dRuB65PqzW/RNwFZmoasjx+Z5xBx0Bp+p6lDCh3bc9+OtZmm+HdQ 8TXCybWS3+nWnuZXIIPtmuXH2eDcIyfveteh+GvB9rbxqWgzJxk1q+HfBFrYoqxqNw74rsrPS/KU RhTinsMyIPDscKfulUGtO3txAAK0VtZIWOBmoJlbPyqeDU3C9w24G0ZJqRLEyKGb9aW1QM2X6itD KRr3AP6UhlI24j64INQOuDtz05qxNMGO1QMCqVzIvLbuetAxrMv8R6V5x8ar2OTw5b6REx3ahewQ Eeo3gn+Vdldak2NqcAV5L8X57qKx0/UwrNFb3yOx5wMZ/wAKXVX7r8yZfCz7T1idbL4SiCxjWF7b TFh8pBjaAmP8a+EvhlAbr4x6f/aUIuYv7YtkZSRjb5gP0/Cvvi1hj8W/BsSWM28XWlLMjAfeyh6n 86+AdNe58L+Pr24t41S4sbqO6iVuctG2f5rVX5MZ739amcleOnY/QnxtK2lWMjafalwisVSNRzzg ewHTJr8X/wBrLx/d+LvjF4rZpMRx6pPCo9ERiijj/ZUV+zV9eXWqWem3FjDDNp19bxSSSGQDaCgY YHfJbH4V+K37XPgPUPh78cPEVndKwg1O5fUbZmHVZGJYfg+4fhXLiItVoqXn95tB3dzxmRhzmu0+ DvjK98K+MrPy7graXsgguI93ykHgH8DXHWtnJeTLHGpJJxXrnw++Bt94ikhuvMMRVgwbpgitYaMu Wp9N2t0Unik6kMG/Kv0f+ENxDffCnw7eQ3Ak8213SfPnaSTlST/dOB+Ffm/a2DWDRWeoFmMKqrFe p4619jfsaeIlvtB1XwzLMzSWDLNAhbOEfIbj64reOsXExekkz3VwysFk4buMcEetKrKmRGxZgei0 7UY5N4aONgzHlTzjFCMGJ+6RnBx2qCyxrWlx+JPDV1pdxGG8yMqPrjivj3SUk8M+LrvSLtQoMhAD evevszTZwr+X2avnf9ojwTNpetJ4m0/7rfvGUL19Rn/PSs5e6+YTMu9SOObn7rjGa878V3VvaLMk w4UZ69fpXYaTqUetadG27LqPyrh/GHhWZZbnVmkDosmxl5LAMOD9Mgii9tAtc831nXblo0s9LjMR 5KTdT0zjH4VyepTX0kj3E1wX8w/vATjB6cDp3ra8eW1xDotz/Z8hikDJh17DIyfbAJ57VxHhnw74 y09dS0vXjcXH2YeYzzvukjw2D7kZK/TNCV9A0Rc0/WZrO6aG6vrj7LclYZED4UjJKkjphWOfzxW+ ysrPHIhBHGPQ965G+hh2sdqs3HU9Pp6da6HR7yTUdPFy+1nifyZCrEnoCrHI4JHHU5Kt9KIsHoWm GYwMcrzXoXwJ8ZQ+E/G8EF/evbaXrQFjdSZOI2J/dSEdMB+CeyO+OtcCOcHj0IqGRVBMe3Iftn1q k7BufoJYs0kaCb+DCHPG3HG3A5yM9+wrzXUvgP8AC9fjHJ8R/EXhezv5/EMAhZpotyx3SKVLjPAY qBgjuhNbvwf8QXHibwDpfiLUL60llmItLpI23yxzJuXzJB/C0gQufXOe9df4m0WbxF4ZvNLs5Y47 +SIvZNk4inXDRE8dNwAPsfrTkuV3BO54n4X8BxabqPi3xEzGQQalfQxNtwWihkeNDjt8iCuT8QXk jA+WSV9q7n4XeO18S2NzZzxiGa5kknmjk4ZJSzLPG4PRhIHyPcVx/jbQ7rwy0jRWc0umq22OVPnM XorgcjuAT97acchqyd+axa+G5w9wn7z95ll5DZ7c4/H1qS4jsm0LUPDuqWjXuj6opMm1m8y3YrtM iAZBYERvkg4aGIjoQcy+8WWFupUBlC8sWGAPrmvK/Fv7RHhnTDJa2F0b24BK+XaAyZP1HGfxrOvR jXjyy9SoS5HdDfEXgmz8M/EG28QeIrR3i1q8Mt5qKsn2W+iJLSTQhyU81jtlaN2GJGwMAq1ec/Ez xRrc0lxZrfG1t9i2bqqeZL5aZCgNj5IwxZiu7DOQxz8uLdv+0t8ZraaeTwt4ZdrCUYmtb21e4hnX IPzrwB36GvbfgZ8Rb7xbp8njiHwF4P8ADmrWFy1vN/Z+jxq6sqA8l8sNwZehA61z168cNH2k9kaw i6r5Ynz38DYpJfiJ4a1p7hYbLTtWhhmkb5to3qWbp0wQOR0JJ9K/XP8AZX8XN4k+HGoabqd1C8+h 6xd2Un75WO1yJgTtwAMyuo9kxzivyk8aQy+HPHGrabY29nYJrsS6rDBZxHyYHEzq6pzkdVOAcAYx wMVsXn7SEfhbw3PYp4P0TULq6iX7TJNJcIk0m3CSNCjrGzeuQQ2BkZwT24WpCvSU4bM56qlTk4tH 6HftZfET4Y6VpzW+u+ONEtbkIVW3+1o0zAg5/dqSx5GOnpVH4K/tRfDZf2etCu7/AMQBprCObTlj aNo2aOGRliZdw+ZfLCc9Dgivxuu/FF5q2oK1/M6W+4B44eioOoUfTpX6Ofs8f8E/9Y+KXw/sPFfx m+JOs6a10Ctvo+jmLbbwo21c3BL71IAwuOB3NeXm8JVOWlSfvSuvl18jbD2XvS2Rj/Gj9rrwTcXc i2MkYlORhn3HJJwQoGe4/HmvmzxR8XrjWJC0OCj/ADKVbFem/HL9m/wX8E/iPqnhWysTfwWrJLa3 F8vmSvC8asp5G04LFSRxuU8CvJPEfh+xu7jTo2YQJ5xjJTHRhwMdvu/rXh4XCYWjW9k4tvbX/gf5 no1J1HDni9DlZZtQ8QXa21vGZXf+EDge5Nb/AIs0nw//AMIrH4b1XVLJLqFQ/wA/zureoAyw+tdr pPh/TdGhENjCoJGWcjLH6mvIPi94S1LS9RfXbLUBJHfsWaN0w0Z9j3H5V9VSoqkvd0PLnNzepxNh 4Nhu9SiguL20t4ZZlhE80uEUM2AxzjC9yew61qaFq02lowhso4JVAKHHKSb1OTxyRt6HHT8DzCR6 pPMsV5yWbaDu55Peut0/TJI5Fe68ySEW/nYUDJTGFwSDjr0P+GHJae9qbUt9gkgt22Rx5fc+3ew2 gocAcdu/c9a7bSbWP7CIZDhh90ntgYrlreP9/DIHYGORWQtxtXdgH8zmu8tYVj08mNDyAysf8/5x XPVfQ9VLY888UW9vbTLIJFIkG7gg4xng++f51zMlymflUDHSu517w9qFx4RtPFcMPmRNdz27ludr Jglc4wThgcdcc9K84fduOf8AP0ranH3Tiqv3tCaScZ6BsY4PeofOK4zjOf8AGoRS4Jx3q+Uxciws gC/0qzpzRveJDcFVilDRFmHyruUruPI6EhuvUDr0rOX+VSBlGQvbr2qrWDmJ5LOFo7S7aIiSGTer 46ocZ+oz0+hrvrafbGpKjKrkMBnggEd+g/PmuUnvH1BJNYuLu0WT5YTBGqxkHaACsYAG07WJ2DA4 B25AN6DWLe3i2htqiMY287RgcY6ms5K7OiDVrnSeZF0dR0AzjkcdfTP+FbHhtS2oXF607xqltOqy epeNkUHIIwdxzxyMgYyDXD/23YrEJFudxIJOV6f54qTT/EUUzSBYZ7cMx8vJ5kToQW+h7flg8Zyi 0jalJSkrnr/wS1A3XijWtHnmWCa58J65bRNPCsocrYyyBAS6lGYRsFcZ+ZgNrbiK8nvIlW6eNhgH OD6/p7V0ng3xTJ4P8WaV4us4xLNp9wt2VVivC8Mp9QV3AjoQSOQTWR4jjtpLx7rT5zJbygSxt1Me 4ZKtxjcDkHHGRkZGDWlGfuOHnf8AT9Dnx8HzqoYsnDE5Hy4X8hx/SnX95Hp/g66uFYGRZHaPLD72 44wPxH51HcTLbKJpPmyPu9mPTb68+1UvGkRt/B6WPDT7laRQPuksC3Ppz+lU9WkY4e65peRzvh3T ZhbnUpP3k0+SdwBOD9ehPrXQf2f5kLyfxR4XLDGQc4/Hr+lS6PYtHp8C8H92McY61qfZ41xEVByM n06e9Dl1KhD3TldU0Nxp0+oQrGsVsVRwG+ZixODj8MflUvghf9KXHrite+2rpd1b+RLMLhAkflgY DblIzxk42t6devrR+HtqzX0ny4Ktgg+veqb90yqqz0Pf/BrMFVec8Yr1vRVl+zgtn615r4Kswypu Xgd8V63ptsy248sHOMURjcxub2kb26twPWtG6hRlzjnFY1tLLGvGcj0q2t1Iy88n0q4R5SXqRSQo 2flH1qjdWfyjHarszSMCV4qm0xz85Ga0EZF1Yo4w0fJ7is+XTdq/u+COtdIxj2E8VQm8vdwe1A7m DiWNtu7HNPadlxtPbmp72NcZC4Iqg24Z2kg0xnrPhvwLe61Ml5qXCDkL616npXh9NPjCIoCr2xV6 zsY7dVWNcfStSP5fvcCquZEUcS7AdoUitCyXd17VXYKVOyrenr8pKnmluBb+zxyA+pqr/Z7bmZlG KuLIYz39KjmnDKytx+NSCRT2xxt2xUFzfW6gxls+lRXUjHjd0rPuGjX52PNBQ25vGPC5A9azLi62 qWaQAe5qK8v5nk8u3QMTSWOgXl5IJL6TjOQtAFOO3uNXm/dqwjB5NW/F3gmPXPBOoaSYh5jQlo8j kOOR/Kuy0/SY7dVjRQBWhNbNs+6D8vPvSkrxaGdZ+yB4i/4Sb4I6dpt9tNzozzaZOmP4Q2V/Q4r5 P/aK8Mv4H+K7SKhigupCuSMD5v5jNe+/sv6xD4V+JPif4eTYjTVP+JjaDHVl+8o/4C2f+Amq37cX gNtS0S38T2kB8yAAMwHp0/p+dLFSvKNfvv8APR/iYw0jy9jsf2fvEX/CUfCu002JvNk0SNrW4kAw UIclF56naVOR6mvi7/gph8N7i80PR/iN9n2y2NyYLlsdUmxjnr1CfizV7Z+x14/mXWZvCVxIqW+v xb1z2uYgcDP+0Mj8BXon7UPw1t/iV8N9T8M36mJbhZB5hQny5FUtGR6nO3n3oxickqkfX/MqD0t2 Pxs8EWsc+pIpXOD0r7N+FujF7SFVj2jAyRXyh4a8Paj4P8YXXh/xDamC9sZvLljbsR3+hGCD719l /DCRbu3hjhbau0VVJqUbo0ZpeKtBW1WK7jO4H5XI7eld3+zL4y/4Q34jWc15dRQWV+fsN00jcBX+ 6fwYLzWonhSPWtNmsdvMiYVv9rsa8du7W50m+ktZMpNC5RlPqKcXySJkro/TzULcOodcZrntQ8mw mVpdyiVgmQPlDds1zH7O/wAQT4/+H9ul1dGe/wBMUWlyZCNzED5WPc5GOfY13WpQIfldQwPr60SX K7Di+ZXIYG8thJu4I6fyxVTx14fXxf4VubNlBkCFl25J49hSyN5DBd+AR8uavaTqLs4RkCqepapa urAfHRhuPA/ii40KWQvAW3QtjGQexHY1qa1GuoWrNLvEZXEm306g++Dg/hXo/wC0R8Orpo28UafI rbP3h+XBB+o615B4T15dQQW9ww8wgxsD6+9QtdHuJHmWtWMckcsUyhlkyrehB4PWvKPHvxG1zTLb S9Bt9GmbUbb/AEVrpQxN/AG/dFv9oKdhGOdqk17l400lbC9ljkdtr/vEHt7fjXnurW0dwGEiD5fu t3X3HpSTaHa+5yGpRrHcN9oG0j76jpkNg8j/AD1qx4RuJZNch019sVrflbXexwkbkny3Y5wACcEn orNRNbv5K+dCu4MV543Y7n61mSIxjePd8pPIzwaRWx2jI0e6KWN0ZchlZcMrDqCOxpJhuXdnlT27 1dF1J4gsoPEE11595dFl1AbcFLhTy3vvUq+f7xcdqiaD+GtFqSel/s6+MDoXi5vDN1Osdn4k8u3V m/5Z3ibjbsDjuWeP0/fZP3a+vtJkjmw1u8arJxGdwwM5A9fUd/zr88P3kMiyxyMrIcqyMQVPYg9i PWvtz4V+MF8ceGbLX3kjM9wmLqNRgrcIMTDA6ZYFwP7rrVLVCWjPLPiRof8AwrD4uL4isw40vxQX vo0xhYrmMIlzGMcfOGWQDuwk7CvULP7HqSrHJH59rqUYjZVJJLfwMoHVhkhc/L83PFXvi/4PuPHv gS80qyVDq1oyalpb9Nt1HkqoODjeC8ZPpIa8r+Efi6x8TaFPpdvOd+nttETKVdF7oQRkFDlcHn5a yl3XQuO/K+pmav4Z0nzDqx01GtPs4u1YRqsnzME8tjgYcOSp7/KWAPArnI9NtXlIkIB+6CowB2HH pgV6X4o/tAW8sSXUn2O+m8yWN/ljEn3iBxgZch8DgbwTzXn9zatbNI8uVjQkszfKEAPJPP0rW6sR Yz7zT2tpXjmALIdp9z1/WuO8UeBdP12yu4dNvJdDvLvAkvNPUBiR03KRh+p689cEV0es+JBLcKum 6fc3cpPlqM7S59gQT04wQOlRX2i+PLW2N7dWen2e9vlhkLOxH1DD36CsZOlOPvaov3ovsfMPif4M 6/8ADW8svHmpeMp/ENtFeCyuRPAU8mGZXRWwSy48wxDHqR6V5F8TrvSwrW9naKkkjMd3QDkHIAxy fcHGeDzgfZPi63Xxt4Z1XwRqka2N3qEWy0m3kxfaFYSQFiBkYlRDjH8OMk15J8XPg1pa65rGk3Fx 9ou9OiljguIoyiSMilVYJknaSAcZ6YpQnTpR02G4ymz5JtQ7SLtUszdMetfrb+wf8bNf8WfCVfA1 r4d1nXdY8ORosVna3SWtvHBjCtNcOykFnEhK/MewXAr84vDnh3S9HkkaLMlz5Q3zSADbkjhUwMZ4 9/evuX/gnbquk+G/ioul2sjsPEmjPv8ANTDxywFPl44A+Y4ByTnOea8jNOStyKV17yV/Xfy+87cP TlGMpaOy2MH9rrU/G3/CUXniTxZa6Tptza2sdrHY6Wh2pBuYrvZur5c5PPXHTivk0WuqeK9a0q8k v3WGSVsbjwnQgADjPBr9EP27vAU15rDNawu66tYyFUVeXdd8h6DJO5R/33jgV+e/hWZ4rWa1c/vt Om+0Lntg/N+mfzrz8HS+qVXGpq07fI2qVPa01GO1j121sWKiPJ+XjcO9ea/E7x3eeHNWuvDX2PTl NsE3fah5jNuVW4Q4A4bvn+le1aTHDNDFMCG8xQysv901mfFrwRoev+GxfaxNYW/2Q7vtF4Fwo9Nx 9f619PKWmh5sUfId1daZKyyJIsjvK8jSIMHkjC4OAMEEjpw30q1bu819mxW6mVmBjeSNtzcDGcbs c8dT25rekt/B9it0unw+ZLB/q5IYCyzHcAfvEMoIJPA7AYwchlp4mtZLh7SSZrMSRsVnaLKhVUlV 2rzhmAXp/Ee3FZcz6I2hfmGPI00bXHJYtv3njp146dTXZ2F4PsAi8wN8uPl5HHBPrXF3eo/bpp7q T5prh2km3cL5hJZsD05ra0e4eNY4WVlKqq4YEfwjt+P8qymtD1ebRNHofw+1O1uvgz4y8L6tHNLB baxbzlYsHykljWPzMdFw6RADI3eYwH8RrwbxN4VutHuj5al4Rnaw/iHXPp0x0r0Lwjqn9j+Ita0F rFLlNb0+SFfMZgRIkZeNlCggkMq/KRgj06i55NrrmlQ+YyyfeVW6kYPI/OtOfkiuxhGkqnNGW54Y zZyNpz7DimNJ2wePWu717waILhv3JAOeE5H/ANbvXF32nfZW+ZpQB6xt/QVrGakctSlKG5WaYdv/ ANdDTHuDwKhVZnchbaU7f+mZ4/Sp003VZV3RafLtPduB+tVoY2bHRzPGwdW56e9XftEl7fKrJHBH M+CFJCxr+Jz09SaoSWWpQ4aZo4se+SPyqNUmZsNckqePlPWjRhecS79ojWOeFj5v75Sr4IJUZyQM ZweMg1J9sldoGUuxU4A2njoAfT1rP2GNmyzk8de1SI0h+bBHtRZF+1kjZs9YcNDcLJmSPO5ifvZ7 Z/Olu9QkmLyR3DCQksWXgtkn/H9awlt2T96uQCcYI602O+VVKlcE5UE8Hj/Gp5DX27kuWRstM22O aS4eSVXXlj0HXIHSkvrwX0LxyOW3qdu7+H/J/lWQbp/KbzGGWXAb0PH+fxpplRfLwxXcmSetPlu7 kqpbRHY6DfPNp8RfcGKEfewAfx69OlXHvPlZ2ALSDt2/GuOs9XmsY/lXeCc4z09cH/PWrMmuQtib 5tx6DsPrS5RxqWVjsJPFV1pvhW40eGK3K31wZMmGMyZwo+/jeoAUYGcZz6mpfhzo8lz/AKeV5nkZ j+Z/pXneoamsiqy/eAxnof8A69dt8PfGUNiIrN2wq4HNNpqNjGrNSPp3wTpZCx/LivUNNtfLjC15 F4J8YWkipuZea9Q03WbeQq6yAj61UdjDY15o442GBgmnxLGOvBplxf2xUfMtVW1O12sokHPQZrUR cuETBZelY955K5ZT1pLjVl5VWrGvLySRTtbBzQMuttYFd2Kr7trfMvTvWV591FN5hzg+1WPPk2hl Bweo600FizMI5Fztqk8alj34qdZW27vL69qSbdjcq4zTGfXyxpjbkZFKY/MUqBjFNjU+YOuauLBt y3PNG5iQQwjj1rUt7eOONWXOc1XjjVW3Hge9WJJY1jBzyOlA0JcHapxxWVdXj8jFS3V4zMcEAVnX E3YNQMp3l9cLlVjye1Z32e8vGzKSB6VpeVuy0pzU8a/xLikNCafpNuq7lj+b1PetaOyaI4CnmobO KSTC8rW7YWzrhZG3D+VAENvFKqEbTVuJmx5bKDnjmr4t12/LjmqzKEydh46UgPL/AB1PdeAfHXhz 4laepUWNyqXIX+KMnBB+oLD8RX1J8QtD034h/D66gt2juYLu386B15DAjIOf1/CvB/G2hp4m0C80 uRQfNjIU4+6R0P512X7Jnjr+3PBlz4G1ZgNS8NyG3aNjktCSdp98YI/Cjl9pTlT7ar06/jqR8Mr9 GfFuhSat8PfHktjbkw3mn3Qu7Q4/iU5wPY/1r75XWNM+IngG08RWqq1tqVsJyo6xSdGU/Qgj8K+Z v2vvhrJ4V8V2njLS4W8qQ72K+3X9K7P9lP4gW91De+AriQGK7U6hp7buA3/LWP3zwfzpUH7Sm6b3 X9fl+Qm+WVz4r/a++HFx4T+Jtp4qjszFBqcfkzMrZxNGRwfTKsuPXB9K7n9nu0k1FYWZiVFfSv7T nwnt/G/h6/0+axOHi86GYJ/qZc/Kcjpzivlz9nLWW0XUZdB1QeXdWczQSI3ZlJB/lUYd8snTZp0P s7QNASKBHxgV5L8ePAp0+9j8S2MZ8m5/dz46K46H8a918N3EN1p0bIwwVpnibRbXWtLn066jDxzI V6dD2P51rVV/kI8E/Zx8bJ4D8eRTX15LBZXY8m6XqjLzg4/vA4P0zX3DJNDqFmLu1kV45xuR16Ed jX5569od14a1eSzuFaOSB/kbpkdiK+hf2bvjHatZf8IH4mvAJIyzWEjZJI6mP8OcU4v2kbdRL3X6 nt0yMvzyAM+Nue9IsiNGsisRg44q1qkKsiTRklGzzVC1YcwyexXjr2NSUzSnWx8QaXPoupKGEqFQ G718b/FPwHqnwx8UG8t1drKR96yfjX1pcbo5Cykrt5FZvizw9pfxE0CbTb9F+0Kh2Njn6iplH7S3 Ez5Z8UWcPiLw7DrNptLKvmA+n94V5fqenYVpo/mQjOQOa9a0mwvPDGsX3gnUwQFZnti3cdx/WuP8 RaKNPvZbdVxE2WQex7fhWb11Gnc8qvLArK2V3Bz178VmrpL+Y0bKUXJwRxXcalawqp3EZXpgdq5j VtUt7ZfvqCvAOep//VS2KLngdrS11C40W8l2pqaBI2J+VLlTmIn1yS0ft5hPatGZQud3fP8An2rz W91hppGVGBbG0Yr0T+0l1vT7fXo1jUXoYTJHwEmTHmDHbOQwHYOB2q0xbFaVf4lwck16v+zr4xm0 fxHN4VlmP2fVlMkCswAW5RSeOOrplMfxEIOwrysKS208elLbzXFlcR3drI8U8EgkjdeqsDkEVonq J6n3/pWpNeQxys7MXAIYnJ/zkDrXP2Pwf8JaB4g1fxvo0M8d9q9w1zdKZP3Qd+XZVx1LAseTyxNZ vw48VL4n8MWet/IpvEDMvC7ZBlZVAz90OCF9sHvXptpcR4Pzq8ZyFOOv59utTJDR5p4g0O3uhNaT Iu2WJ2h3YAEoGQSeo43AAdWKZBAxXl+ueHdUP/ErKuwiVVYbukjgsPphEfnsxU9QK9z8RWm0u0eV MD5Q+nQg/wAq8z8daxHa6m1w1sVN55DRsUO2JfInjYnnB/eqqDuSR24rirSaio9LnRTV22bHwL+F 2j6rqmoalNb7BpKJHF8vSWRTnv2XH51R+Nknh3wPG2peJdRgs7NAyeZMw6jA47sSTgBefbnFcn4c +OXi7wfJrvhfwrp1nLqeo+XdJdXwd44mO5c7EKnaQjZcuNu0EK/IriBbpfatH4su9Pv/AB74pkz5 epapKPskLHJLxuFWJFyPmFsgHTPPNbTSUVYwvvc5O68P6v8AECVdWm0mfwz4WjlE0mpX5WC5kjBy Nkbj90CR95xu9F6Gsn4heJvC2pfDHUfEkl5FdanpcbaPJeRkx/anDeXDMQecGMoTtH8JP3icdd8S LFtQbzPFWrNqc9vkeSvyWUXT/VxAe3Vsk9eK+RfGmoLd3mo6ejbYEuw0qr02pGxIK+gLrzn8Oax5 rbo1pR5mcpJJEscr3EaKpUbg0pUohBCrgA5BIzgnHXrkCvaf2a/GVx4M+J3hnxN9r8qOJpVVdzMz RySbSN2CCB5KZycksMdyPEtWdLySO38x90ztJvkGN0YwAD3A2hemM5zxwa9D0mM6bpGha5Znymt5 pYGOc4AkJP6/0rz8zf7lR7nZRjFSdux+of7Wml3WofD/AEvx1orFLrR5hcRyxpvKBlyG6dFIz+Vf lDItnofxGktZeIrxSrHPGWzg4xx/D6/0H66fDG/t/i5+zy9myK7TWk0G08jcPnTp1HQfhX5N/Hbw 3JoXih2hVma1uTCr7cZw2c+vbvXNUftpRqP7cfxWhNP3L+TOx8G69FBp4t5nZpbWRrdj/unAP5Yr J+M1ldeLNKs7uzuIo/7NEjNFKzbX3BcEYBwRt9Oc8niuV8P6wYtTf58rfwpcLz/EPlb9Nv510Nxq yyQkMocEH5c/er3aD9rSUmcdT3JtI8AntdZl/wBTNaKisGb7xORnBPHPU81asdGvbtv3mtCSTy2R l8kYjCkvtViDtJOcEdyfU0eINSj1i7kMwit7VG3Q29ugCgdyx4LH39fSjT9a8PwQzLqUjqw0y4W3 8r51F3sbyyyg9CQq5PTduwcCi0tkWmupdvLixuDA1tcSzXHMdxJPJuLMGO1snPGzYOe6n2psGqST XCmR13LsUbFIJwCPpwAP++qxdFtZrx5vJ+5HE5RnjYB/QeoJAOM8dAal+Z5Y1VjlmxtHyjJ4U56e /wCFJq2h6VGSnTsjqtS1L+zb/S/EVupzBKpkK4OVxtdeRzlcjmtoPDpviSW3Vv8ARLvLwSK4dG+j 9G5PLDgkHHauZtfJ1PS5tN3AN/DwDzjI5+oqnZzXV/axWIQNfaawWMDduaINljwMBVAI7EZHXnEx V4uLFKXJNSO/uQ8fMO3y9o3HvjAHJ6ev581l7V28LGMMcZ56559Kj0vWl1K2e3mjEc8EZjljbho5 Bxz+n61Jbw3EjNCysFySu8/KPcEd+lQnbRnS5c2sS1bwWt5INPCbgw3TZGMMM9D1PGDkY9O1ZOta T9nZpLVd0LH5epIHvV+1uo5PLuIJGT7pY4ySCBu7Zzg0++kjSWYxTFo4zhflwWGeM89SKEkO146n kev2t9HIZOfKX1IyOf0rE87b94YHSvYNWsra4aFbmwim8043BfukDJGO/Wsufwn4bmkVpNJtmVsZ Iz39R7YraNRdTgqYaTd4s84W+t8hmuEyOnNSLqFiuB53fsDXezfDvwc1u8zae0cpb5RHM3T8z6/p WTdfD/T4mJsfnA6LI3tmrVSJjLC1Ec9/aVkFG0SMeh4xSNeWdwozpu4gfeLEH9MZrSl8P31opaGz tDtO35nx/SsC48VXcJewFjaAxNjdtyQfY8cVpFqWxzzhKHxFqO38+QqtiBj1Y44+takcN9LH5e07 cVyzeJdXONtwsYH92Nary6xqsw/eahcEenmGqsZ3OtuPD94sazRtHEqc/P8AKM/WsG4DWsrCSSHa efkmV8f98k1jNJIzFmYlvehfU8Uco+Zlqa6aRQnXHepLG6kt5QyMRg1Up6na2aGhXue3fDrWr642 IsjHGK+hfCdvqd0ibpsA9Oa+V/hlqEkdykfY19VeA7qaSGPPT61itGM9D0/w5cTxjzLokYrTh8J2 ZA86TJqtp91dW7KTyp4rTN0p/iK59a2QmOXwhp/O1sn0qvJ4Ws1OOOKet9LG/wArnFOfUWY/eznm qQGbcaDaoD8oIPTiqEtnDa54zW89yHXEgz9Kzb2KKQEq2D6U0BmywR+X5kQAxVGRPM+Vvl96vNJ5 eV2fL+dVZuWJXrQ1dWGj6/t4f3gyMc1olRsCkD/Gq67U25Yhh60Ndhc7myKZjsNuNqgsgAIqlLL8 pzn0p891HJnk/jUG/chxj8aY7lKV8Z6mmCHzG3PxU/yZ+Zeen1pjSb2CkHFIaI/s+47Y2PFaum6U /wB+Rgcdqfp1nCSOvzCugtLeFBuGOKBleCzVWBVfbirirsU9AKf5kIJ3MMexpn2qHO2Rht9aSGM+ 1TRgMF4ps2pR7dzR9OtW11DRY4/s4k3SN09qwtUuI49zLIDQIW91qGSPy1hCDuxryRPFEvwv+LNj 420uT/Qr1xDfoG4IPGT+h/Cuj1zUXf8AdwyEFu1Z0ngKXxLpdxbzRkmVDtbHKt2P50XcWpx3QpLm 0Ppr4qeE9L+Knw9kNqVmMkPmwsp9Vr8/PCupa58PfGBsY5Htr7Rrrz7Xd3KnlfoRx+NfWn7KfxJk 8m6+F3iFjFf6RmONZG/1iZPTPf8ApivNv2vfhNNoerx+PdEjIRnzJtHTNZVP3NRVYfC/6RPxLU+h jqWk/EnwTZ67YTJIt/bCRlVv9XJj5kbHoRXw38WvAlz4B+KA8XWEJNjeyBbt0XhJhjDH2P8ASvVf 2X/izZaDqzaDrk5Gl6yQEJPFtPgjp2Dd69o+JvgeO+sLmZLWK4juMFkZQw2jnp/nrV1o+8qkf68h xfQ5f4T65HqWnRL5n3lHevRpV7MOK+W/hh4gvPCPii68M6hG0H2aYiFWJw0f8OCevH8q+nbHUYdQ tEmjYHKitLqcVJFHA/FfwGviDTTqVjGou7cFsD+IelfO32y40e8jvLWdre4gfcjr95GH9a+xbuZV hZfvK3y4r4v+I0kNl4y1WzhOEW5O0D3wax+GQPU++/hp4rg+I3w8sdeVQtxjy7hQMfvU6nHvwfxq 7P8A60tnaWPevJ/2PrW5T4cXWqXV0zLJeOkEZzgKAM+x5zXq99tZi64JU1tP4iY6xBm8yNlb/wDX WQ0k1nOskZIK+narwutg+Yk5rH1bU7OzieS4mWJeu5mxipQzkfi94Vj8R6fF400qHZqOmHdKg43q Ov6V4f48kgnsxqFvjhPMAPXpyK6n4iftHaXoLT6JoLLqt6+Y/LhG8Kehz2rwyPVtf8SXzW2ow/Zf MyyxDoAeorOa7CTuee+KPHTyXElrZvz0yPWuVVNQ1BhJNuIOSAea7vUfA8Gn6hISqsHbcvqBmq9x pqWoO1ANorPc0OTSxZcbh16nvXYfD++k8658LskbrqRDws3DJcIGKhf98Fkx3JX0FYt0q7R0BI6D tUNvNJaXcN9bzPHNDIskbxnBV1IIII6EEU7hud80ZVsEYZetK+1lBI+71pLfVo/ECNqSxojyNiZU zgSAfNgHpnrj3o2lSw65/WrRB638AfGX9nXk/g+4mXyr2VLqyDL0uBwyDnjcnP1jUDqa+n9J1H5Y 9u3bszyvTPb64/nXwVY3t5pd1BqWnzNDcWsizwyL1V1IIP4H+VfXXhHxPHrGn2OuW6rDbahGblYw QQhJIlQA9Ar71HHQccAVYLRnoWrxtdW4uIcPldsmTjHPB/n+leP+PtCudUsLixhYNNbpLPDHkgzA YdkDD7rDyxIpPAaP1Neu6ZeRyW+GUlHUgL0PXGcdc9fzrifG5so/M+0XNsklu+cswGCMEH+VYVKa nozWEnE+Wta8WabbSRza9DDJ9nk6SL+73g/dkjPAIPY/8BPeulm/aK8F3UbT31xDbX0hxLKzbmfJ GcFvmA6ZGe30xY8U6b4Z8RXEt1NFZTWyZTfIufKxncm/rgZ9e4NfKnxl+Kn7PXgOS40fRfCOneIt YRyXSPPlo/cPJn9BmqhTnFW3Jk4y1Op+NH7R/h+OzltfDV3/AGjeSArGVGI4uwLHHOOuM/414NpO qWOuaTPFoV1Je6vp8c15qFzHtYEyMM+WuQWChRk9OfSvFvFXjLUPFF5JM9ra2NuWJjtbSIIiL6cc t25JPerHgnU9S8P6tFqSSNHDIpimwSMofpg8Hn8KidN8ra3LpSipLmvY9R1Wa48lIIrhAjxxjcku QvOSNp6gducYrv8A4bmTVfhXq2k3TM1zoF4kvz/faJ8qT6HkIc9/Mrz/AEe40p2FjqUSXMyqTG+c RlRk5LN1AABAxz3rY8G+LrjwnqOoQx2K3Vnqlu1rJDwoEbMDlSOPlZUP4V5uPpTrU+WK1Wp1UXGD 5mz9Kf8Agnj4/t9Q0O+8IyTM0oUPGmBgBc9856HHTsK8M/b68Af2H431bUFtTFFfP9pjZf4iwBHv 13c1yf7Hvxe0n4Z+PLfU9WvJbexLmOdUi3vlhwpC5znO3jIBIr1X9rT42+DPjZqGn6X4X8M6pMtv Fse4nUI8uT8oEQ3FQNx+ZsdenHPm04T9i6ctHCV16Pf8dTSStU5ujR8D6bqDWzWUkjbfs0pQ/wC4 xxj88Gu4kmBwq9xS+MPhvHYahZ2strNYxahGfI53MxyV69M7h+GRXpWl6P8ADHwTp1rfa5ezapfS Rh0t9uCnH8XYHg5r2sHUtHlOWvDaR8zfETQZFlXUrcQw2wG0jhcsfQDqetcPtvJWRYokCcEvtOcZ xk17Z8Ttd8K+OPFl9Dpbx6NFsW4EcSbkDCLBTAHViM+gLdhXi95NcLdvbW8n3TtVmU/yrttcxRp2 Wuah4fWCa1mKsWfy5P4kZeA4xypBII+gq5az293YpcMxeWSR0cCIKuxURUbdn5iSWBG0Y2g5Jbjn nsb6VhDeXBkRXIEe0Jnpuwenp+VaFnqkMEW2GZ43GwBVGFMe0hufXOOo7H2qJRutDqoVHCRsWMkl ncBlxhPl2jgkDq2fw96m1pfs8kes2LfvOd6nkMGznjjscEfjn0rrcNdRJM6iHoCVXlu+fT+IdPUe tOjnksXe1vYW8qQfMrcEZ5+uDWKfvHdUinG62M26aRc6pp9xJ+9G6Qj5WU9WHU8Zzg9xzgZwOt0f WfPtTPNqDzvPeJHsbCsUbJGccYzjP1rkL+3msWa5tXY28uQyjPA5HP4Ej8ap2tzJaSBY5hsdg+3d 91kywJ+h/rWso82pzxqOmzqk8QtJDc3y2UVukUnlRlQSDgEhD6Hjg9amk1iaSd21CQ2sCPHv2856 tjp/uj86x7fWtNlsWtdRswJQWeFY/lV3bGG/A1Jb2qP50t6wuTbr9okC5G5yRhcdwAP1rNxsa899 tTq7WaTy4la7ilUgFAR8x9T+p5qSMo0bou5SQMbuSOCQK5+K+8m5trryFiKTNu7qEK8ce/p7VPJN Ha6g0816IgxT92zfLtUY4J/P86ixtzWNSaRpIFPLbQC5J5HPUfhVeTzOLhgqx8k8df8ADpVRtWt1 ty0jAgSEBlPBUkEf0rltb8UNDcAW+1kjOTGfudc/l/8AXqlCUiZ1YwV2WvF2uLp9ntyplbdtIPJy f8/lXm80jSuWZQCx5wuM1fvtUivpzdXULyZY7OwH09qoPI0zF2zxxz6V1wjyo8qtV9rK5HSYp+38 KNtWYjelOo20tIAFPXkim7alt42klVVz1oYHqXwt0t5Zll6YxivrDwDpckcca44/lXz78I9LZVhb aRkg19aeBtNkW3j82IH3xWMdZDOgh0uR7ccckVBd6fcRRb8cg4rrY7FlhDKuD2FU5k3K8bKDmt0I 4prpoztZTjOad+8kkLeZ8o6Ve1OzwxZY8GsrzTGSrdaLAW1DLlWJI7VHJu2ngVct2gkhG3BNSfY4 ZVPzENiqWgzFd1A2ttx71RuE25aPnIrcm0ctwWPNVX0xrfK8ke/am9Bn1XcT7sAcEetVpGO07m4p JmTHXj1qsQ7A7TkUIxGTTbuO9EKzTYVQeamS33fNJiribIU+UYxQhjYrCOFPMmbnrioVMM0/TpUF 5eNPN5Mchar9hYsVDMMGktRmjbzRxqF44HbvTLjUHVtsZ4FOWxU/MzYAq1aafDI29sH0o3BGT9qm mbCs2M847VOyyKu1dxz2x1roF023t8kRgA1UvdS0/TUzsUn0oGc9Os0cZbbsPQGub1LWGjYwxsXk bgVc1zxDPqcn2XT4/mJx8vQVd8N+C5HcXF5l2PPIpICj4b8L3GoTC6ulJycgV6hpehw2cS/KAam0 /R4bSMKqgY6Vpqm1B/WnfoB4b8ZPDWpeDdcsPi14P3Q3FlIFvlT+JOgYj9D+HpXvdrcaP8c/hpFL D5Tw3sPzZGdrgcqfQ5qje6bb6pY3Gn3kKywXEZjdGGQQRg15D8KtevfgP8QpvAuuXDnw9rMmbOZ/ uo56cnpnof8A69RGKlejLZ7evb59PMh+6+Y+f/G3gXWvhZ4xubPVLV4bKWU+TIRwcH5WU/lX2R8E /iBb/ErwckF75bavpMaxXAVuZkxhZMe/86Z+0d8K7X4keFWvLCEPeWqmSED+Lpke2cV8deB/HXib 4T+LIpYy0E9mxjIb7sqdCjevH9DUUZ8t6NQGrao+iPjh8I7to18TeHlAks2835V54HK/Q/zql8L/ ABst9apbzyFZAAGRuCDXsngn4i+GPijogn0u4jW5dB9otWGHjOOcg9R15HtXOav8GNGk1R9T06SS 1ukb5vJfhwScHB4yKtRlSlZ7MpST1KXivxNp/hfQbvX9UuEitreNnLMevt+NfE2jr4l+MHjw2WgW Mstxqd0WBI+VFJ6sewA/lX2Zr3wJbxskVl4q8UXj2ULhlt4VjVWAP8WQST0rtvCnw98GfDOyEfhf SYLV2URmdmLSEnjqecmlq5XewN9jd8BeE9P+H/g2z8NWshK6fComkAP7yUjk+3NJq2qWmn2YuLi4 SNVXe7M3GK898dftC+BPh7Y3ker6xFJqUIZRZxsWeWQcDIHTr1r5svvEnxz+PV5s02GTQtDck+cw wSnsvBP41TlqK/Q9g+In7UXhHwYt3HHeR3M4jHkxryzSZ7Y7V4pJrHxo+Olz5zW9xomiy/dJyrOv sOtejfDz9mnwl4dul1TWoZtY1L7xuLv5sH2XoK9os9OhsIwkcaR4O1Aq9h1otfcR4BofwdtfDMJ2 2rtO3LyyDLuaZqnhtoXE8UOHgOelfR0lja6pGyysC7fxYrlNW8G3CXEk1vbiSIKeDzuoegHzt400 l5baO/t1wYhudcdV/wDrV5jqszSE/MeOOK+h/E2jtaw3BkTG0nKkdBXgfizTms70vECYnHWsJaM0 icrMrbj3FQbeCvXPOauS7lBG7b7+1VmGeVOMUika/hG7+y6n9jaQBLsbfmbADjJXr3PT34rr3Xd8 3I96808xtwZVKnrn0Nei6TfLqWnxXR++RtkHow4P+P41pEmw/oNrc/4V6V8G/FDW8tx4bknYKc3V ruYDDKMyIM8fMoz9UwBzXm8q7Oce1JZ3l1pt9BqVlN5c9tIssbejKcg/pVpkbn17Z+JpLK3dUZXu NpIDfMDnK9fxB9q+Rf2wtf8AGuv/ABG0XwzorXMVrPbGW2aNjH9olZ2Vicf3QqDBzjJ9a+gNJ1Jd Wt7K/tZo1jvIopF3dIyxwwJ/2GLAnP8AB71zPxY8OSW1hp/itbFZp9Ik+1rvXLqnKSx9yOQ3XBJQ cc8zJ2LR+fnxu+Hnxq8I2dtfeIJNZi0m8XD+Xcs0LA8gsA3Q5715N4c+GeteOtYg0Hw2omv5+Ejd wMn6mv1S8Z6TY/EjwG+m30iXMF3Z+VGv/PNAo2/zI9sVzHh/4R/DnQ/hfa6x4f0C3iub2NtM1hWX L56blbqp3KMEexqoxk/duZznyan5seKfhj4o+FviBtB8d6BNYX6DIim6Mp/iUjhh7iia0tpIEltM AOCW56H/AD3r6R+LX7Nvxm8bT3GuJ4zbxVZ6PasLOPULhjeLGBuMKBhhiBk9ecV8x6dM1jd/Y75W hXfsm3Lkpg4OR7elTJa2NKcuZF6x1a4063hFxMxgimOwjJMR4Ocd1J6j2rtbW8jvil1aXCP50aiT 7uJGAIAVfTLZ6D39K56/0/Tb/T5LjS/3rwsTNHsxtUEbWHqG3H6YrP0HQ7z7ZHceVcrbeYGdE43o Dz16HB6jPUVm1cvmseqaTcTW8zSQ6Y8tzHjywJ/KAdlw3I4IGSD77TyBtr2rxR4v8NWuoecLM+bN gpAGbbExYP5e8nc4V8geuOmSa6P4O/smTePINPvPDtpf31rPsYXX2qRESJhnf8m0dMYz0xX0B49/ Zv8ACfwN8G/8J1rXiyZbwSR2t95kks15qNq/ym3MwcTYB2n5X4VSF5Iriac23y3N5VE1FLQ+OvEm j+LvHlxYQ6ZoP+jWylvOy0Sbmxz/AHifkHzY9O+axfjR8H/GGm/D+XxI+pXcl8i+dNBGh+eIZ3kn rgcnPsa+2fgHrXgK1uNc0jxh4Yu9DlhkTUtOOrNJFLcRSAKypG5LKEZBy+GPmhgGA3Ha+L3x2/Z+ 8M6b4q8Pw6INfl1qBbFztZB5DwbXGWUEAHsOuR0xVYSm60lUg1b8DOrU5Y+zaPx28Jef/aQulI2x /e3dDW3rVp5moC/trWNUGGbY2DnnNcvqkkmneINQtrG9CIlw4XaPkPJ6D0o/4SHWEhaKSOOYEHoS DXoSWpkrk+o6lB5lw32d2+0SEsFHA5yACTwPbPp6VSurxdQvIo/sYs4ooljlZH3b9vG7qRyMDjj8 6qreQXEZ+1SCIliWU9fwzUtxqOnSb9kwG9QjFFJJAx/UH86m1tBpnZSaxa2+l2dtAViaRXknKscy RMYwilMlVI8osOAcMvUbcMjllPliRXHnL+73jIZCSARnt16e9chqWrLqWqGawtnhtnVPlYk42oBt UnnHGBnJxjJJrbe8jUiGKOMMq+cZGbZlcHCgZ2nIwfUk96ylA7aOI6PY0vM+zkBYwwOAy43Dnpj0 rOurNZQ01lIu09U9PzqaC8VpGh8xt64IYHb0H59afJawvGJI5WEoYoY41wAoAw2c+ueMdqlS5Xqa yhGavExJllB2TKwJPUj8elO/tK7swYo7kokkeGGQc+x9ORWzNpcrSGOa4zkP95csGUdCMjvxmsq6 0y+WHzGs4SGyOWI6Y9uOoq1OLMJU6keg1dV1CQGQSKylQh9+eOtPGrXSQSrcXbNHKoWWPPDgEELx 2yAfwFZn2bUgy262sQDsMFpDgds1IdE1ST5muIEVWCkxqWxk4Byar3UZ3mxLjWg0jOy4jx8u7oPp /wDWrPdn1CQzuTHbbjn1Y/QVdk0WGNPtE0slwwx8x6LkE4I69APao5tRsYrdLfcfMh9F591z6dfz qo+RlNt/EVNSvNPm2x2SsAQAQeikf3e+MYqTSbOa4ka3+zuwkGAcdDWWu0SLtXOGzmvoX4cppeoW VvcQ6aqRsgXcV6uBzz9apuxmzwxdLvGmaEQPvU4xitO18E+IbzHk6fK3/Aa+mvDPw/0XUvEUk0ls iGRgx4HNfRfhP4WeG/s6tHZxMcDqtJ817ID851+GvixuF0mb/vmn/wDCr/F2edJm/wC+a/USH4a+ H41U/YYxj/Zqy3w78OtH/wAeMeevTvTSkM/LZfhX4wLD/iVS4PtXReG/g54lmnSS4sZFXP8Adr9H W+H+gpndZxk9vlpY/B+jQr8tsgI6/LS5ZPqB81fDz4d31ikTSQ7duOo9K+h/Cdi0MKJIpBH61dGh 2lmB5ca7T6VatSlu2VApxhygbDKyJ93g1l38a7g4696vLfZ+VsYqrdTRzA7ccVoiWYGoKJBnbj+t c1qFuecLzmuuaGRtysAQDWTqFqVIbBxTGc1b3DwuVkJFa1vdpIRGrYJFQ3OniX51UZFQeTND/qxS Qy/NeNE4UEsMUSXsciktH9ayZbiZSHbqOoP+etLHcDnBGD1zVbAfTqx3En3+FzU8cCxZYt7cmoor hVUbhn8ae00cinbxntSMyVpNxDKwwKo3l427y1Gc0NIwHdfeoo4GeUMcnNIZJYIscgZ+vWtqK9Zf lVc1Rt9OkLA4JrZtdP6fKSc00Fh1us1ww7Y962beFYl2gc1XjgEOWZetZuseIIdPhb5huA6E0bDW hf1TUksYT5jDkcc159qGpX2vXZtbX7mcFqY0l/4ovPlZ1hz+ldt4e8NWtmqHb83fNK19wIfDfhKK 3VZZI8uetdnDZrboNqirFvDHGg2ripeKGxhGfl+bNP3ZXHcVGwx0pjTbeqkmk2ItwyBeuK4r4peD tP8AGmhva3CqtxDl7eUfeVq6ozD71UrmM3GVDECpkuZWYHN/B34tTWsK/D/x5IIr63HlW9xJ925Q dAT61R+M3wD0zxhHJrOixItwRuZV6Oe1Y3xF8D/a7c30Me6WP5lK8EH2NcN4d/aL1fwJe/2Frmpx 3Cg7Vgvm2Nj/AGXPBoko1fi+IlKyOFj8O+O/h3qnnafNdW8sDfKwYqw/HuK9L0H9pTx5pcPk65o8 V869JWTa2fXjg13lt8XPAHjK1VdYt40Y/wB8Bhk+hFYc1v8ACya4uZ7qeIQFgIVhY7jxyT9DVJVI aXFZXM3Uv2rNa8tYdN8Hs8rNuO4tjPtiuQ1rxt+0R8SpTpel6Wvh6x48y4k+V/UMO5rvoI/htcOq WtuFK/iWNd1pGreGpkEl1fKWBCYYHgDgUOMnuCPKPh3+zfoOnXi654i87XNTZvMkuLtiRuPcKfev cdN0e30+JEhhRFUABVXgCrUeoaOdrLewCMAgc/pRNdK0iLb3VuidWLNz7YoirbD6Ejoqxls8gdAO apxW9xMu9mMQyMDjLDvn0rQ3RsBsdWJHJyOaRlG3auMU9g3RCq+WpZWGVzUqy4Xc3zZ9aikCrwV3 YqNi0ybyQka8/U0kLYx/EXg/TdctZFRVildD9Dmvkv4ieFrqwnn065DCW0kwfRh2r7HkuPLT7Qzb gRwo6Yrx343aCs6w+IYYcbx5cwx27E1lUXUpM+TJrdkk8t15x+dVJofLX5wQPcYr12W302y8u5W3 hndo2RkZOIyeB9TjmqMi26yLNDGoKHKEjkVDRVzza30W/uoxNFZyvE/IZR6d62vCqX1m09rPZyCJ 8MJGXGCvGOfX+grqtqqF2AKqjaABwB6YpSrGMruPP3venFA2VZkz34qBV79u9XtuRt9qrSQsrDPc VYj0b4T6zF5N5ocuXmg/021U42uv3ZYzk+hDADt5h4ru5JrWbTZYI5wqt5bKNpwTtbK457kcnPAP I5z4VoesXfh3VbXWrPHm2kgcK3Rh0KnPGCCR9DXr1jNHdKLizWV7e9j8yDcp3BScrx687SfXNUnc Rxuiapa+EbvUfBt3OWWz8u507fnL275JUZ/uMHTB9B61s+GfFuh6ppniDwXNqYsYdbi8+zuvLDG1 uB97g8YIAP51jfErwveax/ZGpaOnnalp0/3Rn97DOY1kBPQYO1xnsrCvC/jd4yk8JyHTLWLN7JI0 UUOc7drbCzHAzlgSOMbdp5zxlWxEcPHXc3oYaWJk1eyW77Ho2m+NrXwd4in8P+KPEGl3otgLqz1O 1lxHcYbAVgPuPycg18V/tPXHhm6+MOtap4Sv47mzvylxJ5Y/1cxUeYpI4J3AnI/vVt6p4b8V+Jj9 pvLi5m5wIxnYvtgcCud0X4f6ZJ4guNL8RW8htXtZP3qEq0LjBDgk84wRyCOa43m9JwfPui44D94o 0W9e5wWg69NpV0sgYlMjcvqPT6V6fY69Y3VuJILiNoHXBXIymSeMdua8i1ax/srVLmxWbzRBK0Yk AwGAPBptqq3Ui2zZG843BsYrsi1JKS2MZRt7r3P0A/Zg/a7+IHgrwD/wqHQJbO4+xXMkkLyTKrRw y4PDsRtAbdzkY3DtW9qfxM1b4peJrfwrq3iODU9T1OQQx26klIScgFmYEL1OXbAGB83Svlz9nbwP qmieP47XxJHPpz6nZ7rGZoY5I7mPcTwJFZCCVHJBxtNej/Ba50rwh8Woo/EWnm7Ed8MglU/i57Ec 59Pyry8bmUqUp0YrVK/rc6qWFvCNRvc+gv2tfh3498D2vgy3tsy6xp+hiyuL6xhZ1cICiM5YcvtS LOc9Dg4Ar8/viRa63cXE39ueI7+8kkYnDS/KD7AcflX7VftTeHo/GnwNa90e68i3RUuC0bYBQrjJ I64GR17mvx78eaSsT3NuWDCFzg7eo6Z9q5aNWWFrezi/ddn95ryRq0+bqj58RmjkweoPNaYclNyj ttNNvrVbTVpYXReW3L9DUkKxtJ5bttXrkDOK+gvfU4LW0ILmGJoFbbxk8kdaqRy2ccflyM0Z53cZ z/kVpyDzI9ok4X+E+/pVCa1t5F35AJzxj/PWncRNDdWbMGt1lfbgcL0PWpLxrvUp0mVJQNiKxkPJ 2LgY5z0AzWTFeyaexWJVKk5wy96u2uuTTMEleKHaMBtp55+tO3YEzodZmSys9IZZJGMlm8zB1AAY TypgdzlY1POPmJHQA1at9Rs7VbS9/wBIePcY5LdiAW24LYYDgHccZBIrnFms7iaOS6vo38pvlVVw W5zz/nvWlc6pHdaSmmec+Laaaa3RV+XzZRCjE/8AAYR+S+9Q4X0NYVXFmqdWjVZbj7Iy28hHzbgx GcnG7ucfTODSPq3mRpfqGbymCSNIwOX+YjA6gYAH4decVhTf6Np0trFMxLSRvt5OdoZf5N/OpPtU EemywbUZ5YtikkEofMV+PQ8Y49T61Hska/WZWNazvpIw2pR29vKtqCDHORgBxsG1SRuIL546Yz0F UpLya6VsTNMF7LnDAcKvrwCcVnaVqkNq0TSbnlR92NucHt14PPrxUDHVYmZLdniQ4PKjOQP071Sp 6mcqzaD+2Le0BjkheR+QxB4IOOhPQ1lyyR3EjzJGY1dsquc4HpnvVyPRriaQtJJliO/ermh2sdlf eRqloXiY8nFXJ8quZJczNL4b2tndeIIIb23EkecHcuetfSHwY0fT5vC/jSGHDW2l6lE1qzryQ5cc en3a5XwX4f8AhxpvgnU/EFnrTTeJ5rhbex0xUyRERzIT2Oc/lXo3gW0h8K+A5dL/AHZu9XuFnuQO qBc7Vz+JP415GFrSxeMlKMWoxstdL23t+VztxCjSwsKd05O706dr/wCRJpl0NL1iC84VN2D9K+p/ BK2t3psN3DIPmUE18oSr50nYgDnHY17p8CfED32kraySbjGdn0xXsS0kmefE9iZdvcNUJdlYs3C0 542x8rc1Vm85SUarGSFo2xtwcVHPDHIOeCfSqcrTR58vn2qub646FSrfzoAsTwhEwvzZrJulkjyM e/4VcM3mYWQlT7dDVgWUcq+vvQFzGWZmI4ODUj/cKjOauTae0Ldz/n9KiaMMoAAzn8/pQBXjd1+8 oPam3dupA3cjqKkbKKfak3q0A3H5R+lMDJaOONsMuRz0FUbiFSSEHFalx+7yVAYfr+NUpzGcY4J9 f600Bz19DIqn5e/WqTKWx/AR0/z/AFrop4xIrL61kXFrt+6Kb0GfSa/MR1/CpY9wbpjFJH8oGeal 3cd6RnsDDcRxweOKs2tsWYfwjtUcMYY7u3qav288cbNkD5f1oBGtYWG2MM7H/GrTNHa/ebAH6VmL qGVBWTANV7rUljhJkYufegZJrWuQ2cDN5gOBmuHT7V4ivBLLu8kH86hv719UvDHuIjBxXYeHtP8A LhVVXiluBf0jS4rOJVRRiukt2WJR0IqlFZrtwgxgVegt2KZ449aYyzFflWCtjFWIbtZc1R+xtkMK dHHJEw6cGkBqL83eopMmo1mnXjYBx1qJ2kZsN3HalYY15Nrfe4pi3S8Doc1HtkduRin+Sq/Mqk+9 Ahtyv2qNopFBU+3WvD/jJ8CbHx9p80S2oWbadjheRXu8cbSZ3AZzSSW6qp+Xc1ROCqKzA/J/4h/B j4wfDO9lfS7rVRaKTta3lcDH4GvN5PiB8VNLmKt4n1iNgeQ0jHn8a/ZPUND0nVITFeWcUh/2lrgN c/Z3+GPiCQtf+GrNnbknyxmslGtDSLuh6dj8tLf47fF6xYCPxddtj++qn+ldDpP7TXxksWx/bizD +68P+FfoQ37HfwZkkBbw7AufT/8AXUcn7GPwafdt0VEz05P+NPnrdvxFaLPiXTf2yvjBp9wkzG1m K8YZGx/Oun0/9uf4lNNu1DSLaUn73zkZ/Svqa4/Yh+D7KCbF1zwuHP8AjWbJ+xB8KY8/u5xzx+8P H60/aVuq/Idonitn+3hrykNfeGAw/wBiQcfpXQ2X7fFicLeaHfRnp8r16Cv7EfwzkO3Fx/38NTJ+ wb8Nbhcia6XH+2aXtay+z+QuWPU5G1/br8KyD5pL6DGSNyE4rZtP20vBt1Gsc/iORQRzvhx+uK0b n/gn/wCANp8nVLoFvfpWVc/8E8vDZ4t/EdwBjuBQq1X+T+vvDlib9v8AtceCbhVjj8XWmAPuumKt al+0F4P8Uaa2m/21pt0J02sFcAr6V5bq3/BO+QM32PxIT127o/8A69c5cf8ABPPxhGd1n4iiBPfb jH60Ou3pKDGo+Z3txCrZkjbzo2XcjKchh2xUC2rHJ2g56+1bXhP4O+L/AIaeCINJ8TXC3n2GQxxT AH/VHkA/Q5pfs6x52/8A6qLp7BYxvsu3+HHuKTyTtPQVrtCu2qrxAdKewjOaDYT2x/8AXqKaPK+9 aEi/KD7VWkUe9NMEjOaPtiuz8CaoVtZ9LkmYS2h863AxkxFgZFHsCFPH95q5Vl+YmpNL1KbRdUtt Wt1Ja3fcVBxuXoy57ZUkfjVRdgZ6rJHG1ujSRuqS5CqVzlMkBh2PIx+dfH/xQ0W9X42waTrdi6Wd tpkU1jJy6ywRRCJWySScFMEk9VJr64V7dlieMu8ZXzI2AIMqNyD6A7Sfw615B+1H4evNS8E2fjPQ 7WV7/wAKSvIyxD5ms5Qi3CYHJ6Rv/wBs2rjx2Hdek+XdbHRh67pO3R7nuv7Ovwt+E/iD4Z3WpXU9 q+uiJ9kW4F128jAJAYnoK+Jf2ktHh0Pxw2lzbra9sI2a8jaPDJG6rKCT0z5RUkdiWHUVX+F3ib4i ajqS6h4Tup4bCwkEkk6MBsPVV5xk8dPbmvPPjF4u/ta61CO7mM97ez7ry8kk3bUU58tR3Zmyzn2A /vZ+IwuCcMaqcd7e9v1fW+3yPchPkoyrS26HhmvXJm1I3OMfaGZ8DsCarxs0eMN0/Sn63b3n2i2u poDHBcgtBkdVU4z+dRt933FfoELKKsfPyvzan018GPivp2teCbnwzrViz+I/Dr299oN8rku0aS5n t2Ug5BiJ27ccrzmut1yTTdc+LltHo+rWVpJfyRyW8txdRxwSu0auqiTOATnaM4+YbevFfImh61fa FqVvqmmztFcW8gkjcAcEfXg/Q12HxMZPFclr4s8NtM3nwiXUoEQJHb3W452AHoRg9BXDisBHE1FU vZ2sb0cQ6UeW1+p+ourftq/CHRf2fT4F17WLnU9bezFqE2CONSCMKzsQeB3APavzK+IfxK0q61Cd rNo7lHkbFvAxEYBOfnkxlv8AgOPrXmGoTa1cMi6hcXExX7olkLbc+mTxVT7HcN/DgfWro4CnTUeZ 3cVYiddu/LpcmvdUutU1Fr66ZTI+BhVChQBgKAOAABV2OZlzKqjtn/P4VSjtVhwzHdVhmXHYdsZr s02RkriySZzjgd6bG/8AdHPvTJG2k8YBFRqzY447UAMkVZG27eSalj8M6tqHNnZs5HVVHSul8J+H Le+uIVvZDH5pLDjJCj298/pXZXMk2iA6fpdu9uQNpkkXBI9qidVQLhTdR6Hjd5o+paa227tXiYev UVV/eHjLGvVYo7GO58zUoxcq5/ehjy1cx4u0fSLbUvN0XcLaZdwVhyp7iilXjU0Kq0JUtzllXg7s mplhPB255q7DYf7Wc9qurprMu3aQBzitzAp6evlzxs3AVgT+dbnjTU3e6TZGiB4wVKDrWZNbyQqS q5LfKAK3bPwfrviRrXdAY0iXbuI6ilsxXsc1p/8AaM9wixJI2T2Ga+j/AIR2mjafbytr2gx34uLd osXCfcJ6MPeszwl4JtdIjjaaGN5AOuK7KMR27AbQufSly8++xPM1qjoofDvhvwz4X/tG102FJtSZ hA7JykaH5mB+vH4VNpOj6hf2S3UMOUdA6/7SnpXTeNdJ0/VrX4f6DHdgQX2mWkdww6RGWXMnPtuN fXmn/Cf4Y6bp0EUl9AohiULtHRQOlTF/DGK3V/vH7z1Pg6fdDJJG0JVwxypHccV0f7O3iJm8Qahp rEr5U5G2rPxkttMs/iBqdvpLAwptwydM7Rn9a4P4C6hJH8UtTjVgyedz+VXXjyR+4IO59wRRs0Yb JGRSvDuXceTT7VleBeCCQKeztuG5cYFNFFCS03fdwDUTWPmZWVQT2rTIBXchxmmjn0z61QGZ/Zu0 cLzTYd1u3r/T/Grk82w7vTtVb7SQx3KPmpMEF1NDJCVb5W9fSsiY7fmVvxq3dbcH3/zxWevzMfn6 8f59aAIZmO0qpHNZ/nSRvtk+VTWnNa7Wxzn6/wA6rXUO5dvl0ICrMvWRX47D/CqkvluvoR/n8auL bsyFg2SOMf57VmTPJGw44HT/AOtVWGhu7bnbz9arTLHKrMOSOx/rT2uBv4JRQfyqteLskMiSYDDJ /wDr03qNH0QC33cHNLuZW9qjDbfvMAR70rTd2YbV9O9SZNlnzWX5lHPYUizTSMWkUAnpioFuI88s R9aSbUoYVLbsBO9Ay+ssaL8wPH6Vhatqe5jCsmU9qgvvEUdxHi1+dWH3hVexsbzUmXzh5cY5296N wRc0q3N3KAsOEU16Nolk0Uaq5AAHTNc1pMZtbiKGG1zH/EzV2Vrtk2rHxnnimnfYDRj8uMoQMmrK jqQAM9qIlVVC7QKeTgfLigY6EbgVJzStGo7Yqus+3O5gpHpSTXR8sbec0guWHVMZqvIy1QjuJFld nlLbz930q1GDJyzACkA5WV2KrxT41KNjrjvTxs+8McDmoTIrbtuSaQE+cZ96lWMY7VXi3fxCpSzc bm+X0FAEE1rGZGfPJqD7LIZOM8Vo7lVT8vBpqIWOR0oAigt148yMHFSyW8aqW9e1KytH8+6sy6uG LtliSOnpQMW8uI1Xy4z869M1i+dNdzFFBJzj2pLyd7iZUj5PQ7TW7o2mCKJWZcE84NAh1hYyrGqy qBitRYQMbVAq1DCoXnBqXyQvzDtQBW8n5cN1pzRhVBC5NPeQLj5cgUvmIVDLnn17UAVmjVuMdKrN A275WwKvEK38dRyfLQBi63ocetabPp8wUiVSuT29DXzVrmlz6TqFxp9wpV4HKMP619UmZc++K8d+ M3h0+dF4igXiT93NgdD2NZ1F9oaPKDGu0jpVaVVYFh1FXHVeB6VWk+TPOKlDKUvTj0qpIG2+h9Ku uFX5jVSb+8DVIRWbnLY61Cy7v4RUjNg57UxsNxSsI6rwfq0babLZzMN9g2/bkDzLdmHyjuSrknvw /oONu6S1urK7t7lYnhkiEMkfXf8Au9uBj1zzXn+i31rpus2l1eQGa1SVVuIlPLxEgOo9yM498V3V 89rbXkkdpOtxZl2a1m6eamPkb2BBXj3I9a03EnbU+NPF3hG+8I+MdT0Hw5rWoaXe3JktFls5TGbq 3lBADgcHcjYPuTXlviH4fnwz4gutF8Q3D3NzYTGGaISqyBh1XchO7B64PXIr6m/aY0e6Wz0jx1os e+50OT/SJI85aLzAVY/7r/8AoZr5YuLqS6mkuJDjzHL8nPJOfxrxp0JUKjSeh79CpTxNNSlFXW5j +LLaDVGsEMOXXMEKrwATjaP6VwV9aS28zQspBU4x6V6ReWsd5GEkUEhgw+tcf4sWQXQkkQK0g4wM CuzC1Fy8hy46hLmdXoc4cqcdCK7n4f643njRr7z5bKYPmGHG7zNjBDz23bS3sO5FcMzNuPpVrTby 4srpJ7e4eKVPuupwR24NdZ5xq65byxzgyRqjOc/KuO/Ix+FZTsv93GRWtrmp3OpbZ7mRpGZjJkvu O9vvEnqSTzWJI3zBuPpSsArt8q4bn09Kj9ehoZlZfvHcT0xximr/ALWRTAVl3ZJz6Vc0bT5tU1K2 0+Fd8k8yxqPqaqBvlIx19a6z4XwrJ4mSVkDeTGzcnoemaUnaILU9z0XwPo8Fz/aLQhHHyqIx1A9a 4r4t6hbx6zHb2sewxxjc2eTnpXqOkzrJEFaTGR24/CvC/ifeNceJr4q2RGypj0worlqRurHVQ0bZ yt1qG1tzd+aa0yXdo+8ZIGR7VnzSPKyhmztG0fSrNt8sbL/kUciiVzuTs9irb8t9K1ocsoHY1mW6 lu3et7Q9LvNavFsNNUseN8n8KD1rtucJteCfDi6tqv2q4Tdb2nOPVj0/KvVLe2S3ULHEqge1Hhnw vFptiljbAZQbmY8bj3Nasdi/O3t/DTj3IZXjaQqRt6fxelWEkkuP3aFVx+tTfY2UfKvzHnFLDbsp DDG7P3aq9hWOx1C3vr7wvouordCS5s91kYVUgxANlGz0Ocn/APXV5fit4oSzOnzXDPOAEDFjwPpU PgeFdZM+jyRmQyQvIqA4+ZFLD+VcmrMJnLRMT7VMXbboOyZLcXUl1JLdXjea8m4lye/r71g/s4hd Q+Jmo3Cn5DcNjHfmq3xA8RW/hvQ5pNwE0qlIx33H/CtX9jfS7i41iW+MZKs2ajEStT16sqKPu6yg j+yIvcAYNJKrKdrZIHr/AJ60+3uEijEbHkVJMPMTK/eH+eKtbFWKMysoyvT/AD1qBpwG2lsH+dWG lEWVkHFU7qFGww57/wD66oQ24YcNxz3/AM96qyLuJxzj36/WnSDevykkY/ziqczTRruVsc/5x70g Bv8AWYYEDv8A57CoJI0XDxj8v6f41WurhmzuY7/8/nVaDUGDmCXIJHQ0Ai3JdgL83GPT/P61A155 ilmUY/z+dJcNGy727/r/AICqq43Blb/PoKBELXG2YquVJ6//AF6rX0m3LMpOfz/+sKvXFvDcd1Rh +n/16hmhZYz5i7vr/WmNGLK/RivH0/lUc7KVBX5c9v8APers0Me3kZUj8T/gKzrlPLQbXyvQev4f 40yke+skr/vBj1HPNOELjbnrToY1VQC25iPyFSx/Ou1iAR/d9KRkQNC3uTWTfxtNuhkfCk4wK0rz UvL/ANHt1DSjv2FNsdObcZrjLMecmgCtougtFh9p2joCOgrtdLsowRiHce5xUOn2m37oO09Ca6HT 4UibDBQD94+1NDuSLp0YXdGuD+tWoVkh27VxjvVxbZQxXqCMinQw4l8tl+UdM0hlKW+mhYfKcf57 1J9qM8YyxHertxZxyEfuwfeqM1i6txnA6d6GwHZZ237uevXrTGklZSEBOD0qSKErhW6/nVlpLK2U vOyj2oAoi3ZT5shxj0qVblVjxnpTJrg30geLCKnGKdBEJSUbbzQBILguo4xipYYxxIuQKnhs1H3u amUeWPlWlcBpX+LvUTSSH5Y159am8tnY54BqVIFXoKQytFZySYaZj9BV/wAuKOP5mC4HFJ0H0qtO w+ZmfgUAQ3twu3auTWLdSyL8qL9+n6lqGcR2qkkfeNT6bYSXDCaUNj3oEGk6ONqzXHLduK6CK38t R5a8Cn29rtXBBGBVpY1wV5FADIwduemKl3bl+WmiPaSuMCoMMrHsKBjpNrNt4qH7pwalZfl5NRNJ t9CBQAokCio5JN1RtKr55xRHGcks2c0ARiM7vm5qj4g0W31rSbnTpUBWVCB7Hsa1mTC+1N/lSaur AfJ+q2Nxpd/NYXCkSQuVINZUjFmKlcivYfjX4XWKeLxFax4WX93Ngd+xryCVGWTbzg+1YrTQCtN9 wr7VWkCvGQOoq1IoOe3tVVlZSdrHnrVpgUZO/Wo85HOKszR4Wq+3b06UgKtwNp8zBI7/AErb8P3H m6Xd27TxQ/ZCJVUZ3ujHBbpjC8Z6H5l684y5E3fhS6be/wBk6gl5tBRQyyJ2ZGBBBxyeDnHsKqMr Caubniazt/EWm3mjagpS1nt5Irj5FCbiPmHHHJPbpn0FfDniTwveeHdfvfD90257STYHK/fXGVb8 R/WvubUGutI1J7WS8aRIlEkTtu2PG3IxnswI+mfrXiXx08IwOsPjKIANE62s237rRnO1znk4OBn0 assZT5qfNHdHVgK3s6qjLZnhFjou5UlkBx9K5v4g6KJrVpoVAZBuUemK7+aJ0XzMMVb5Rx/9asvV rQXlu0OzcSOD3zXh0qrjNSPpKlKNSm4vqeAt8w79e9OAWONZfM+Ysfl9qv8AiLTZNK1J42BVJCWX +tZTFd1fQRakro+WnBwk4y6GjuhkibduDH7voPrVKQ/wr2NXtIvLW3kkF7ZLcKYmVMsRscj5W98H sapycuW4BPamtCWR7uMYoUnP09aCN3HepFjzTC4eW23d0J7V1Hw/kW315TgZKEc1zX3Sat6TfNp9 9FdDnY3PuO9Jq6EfQ9vqRaBo0Y7+rPu6D0FeSeOoVj1yaRG3rMobI6Z6VeTxPFGreXe7I35z1Ncr rGsNdTN5LFgD99u9RyOSNIT5XcznicttXtT5pY7SE+a2CwqrPrAjUqkal+57Cs7/AEi+mG7LO3FE YP7RUqkV8JvaBp9z4ivUtLdvJgz8798V7d4b06w8P2YtbKMf7T45P41xPgnQ4dPtVaSQCRxkiu3h lhhjDGYGt0r6nI2dBHftjd6VoQ6gpKjbg/XrWBa31rGRufIP51e/tKzbPl4UgDnHWmG5tw6p5f3u c+napfMiXEnQbTyKwLS6sprk+SpZuh9K1FaPyxH/ABMcAUAehfCXUrfTfEj6nJGrLa2dw/z9MmMq M/nXGTTYvHm5Cb92B05PIp9peXGnwT2du3N0qrI3cqOcVka94is9D0mS7mZQsan6k+lCV9O49jzP 4xTTa54os9DtBnPzhQedzH/61fY/7NXw1/4RHwzBPcIBLIobPpmvkL4O6bd+P/iZFf3UbS5l8z6D sPyr9LvD2lw2ekwWqxhfLjA4HA+lc1R+1rcvRGkVZFXU47oxFbcnee/r/hUtjdXAhQXHBx19fpV2 a1Mefl+X3/rVZo2+6y/5/oK1trcOglx86hgoI7e1UHEkeV2/KOv+fWrjErkAlsf54qDzOPn59x/S ruIpspky0bfd6qe/1qvJ5kjBcEgjHof/AKwq3NHtXzIeuc9en+Jqm1wwkKy9/wDPP+FIZWubION6 gA+oHT6Vi3lvIjHcuCON3Yf4mugkkj3fMx5/M+w9BVS6a1ZQsjjjoew+nqaYjnGup42McjEg9z3+ vpTo75XbO7D8Yx39hU+oRxqG+7juM/zPrWPPGDjyicn8/wD6woA0vtIYHawDDv2H+JqD+0pIZPLl wQOo/qayJJJrcncxPpjt9Ka1x5gy3XAwew+vqaaBGjNMqksqkhufr9fQVSuFaZSY2BJ/h6f/AKhR BcRsoWTP1z+pp8iRsGC8kj7x/mfb2p3KPfogsYLPIBg881m3+qSXEgtbAFVz8zDrii7kMuI1zs7n OMmnW8aRbTtG7HFTcysPtbIeYsjjJ/u4610mm2OV8xmHX5RWbp1u27zJGJ3dB6CugsY3ONyjGeP/ ANVUBfsrfbhSTkjrWtZWzlNvOSSags1RNrNgE9e9acLrHIN33W5BpMaJbVtq7JPvIcZz/WrjR5fc rAg+1UZpVWQMw4PZu34U6G6VflySueC3A/Kh6jLbN8vzMPSomdRnj3omk43fl/8AqqjJJJt9TS6D I5rhtx2sMZqLyY7hiz5JH5UxVkUsWUsSatQwuVG/5eewoSENtoPmxtwM1pw26r92MAURwLtAAwR+ tWVO3O7oKGAJ/d24p2V7AGqrXiyHbDkhepx1qRTJj7pGaQE+flpd+MDdmmKvdiT9ajnZEX5jwKAF nukjQ9c1zeoXlw0p2uQpHQVa1W8jgUsrEnGAuetQ6LolxeMLu63DJ4HtTAXSdPmuXEjfd967Czs0 jjB29KLOxW3jCgAEVeUY9aQyPbuOzkYpFU5qeSHHzKaiw2S1ACOo27u9VpKsluDlgBVKZh7kUARv ITx2qCSQ/wANSHmmfKxxigBkeKl+lKIcDIWk2jr6UAODH7tNZfqMUD2ow2c7s0AZ3iHR4dd0e502 ZQRMhC57N2NfLfiCybQ7ua1vsxvA5U+xB619a9a8X+NnhJDONaSEFLkbJuO/Y1nNW1A8ca4tWZ41 nQNEoLgdBnpT5bKVIxKQMMC3DDkDbn/0JfzriNU037LeTW8gO5T8p9VrE1Y2ulWr6pNJKqwLuzGx 3EDnFQpFcp6PLGpUnqRVGWHa2CpBFedeG/GkfiSI32i6lcRzQH5kYkPGff6+tbVvrWpW8is9wZY3 xuV+30qhI6d1G3uKrTLzt7YqyrrNGrryrjNRsowc5B6UloFzTtZG1TRdjY+0aSBHuxy1u7Ern1Ks WH0KVja7ptvrWkTaPfSM9vLHtbIHGcfyP9DVvSb9dPvw1wzLBMphn2rk+WeuB69D+FT6hD9jvJbd SGSMFVbfuDds8dc9eK2T5lqZvRnyxqOjXun6ncaTdN++tJTG5HRu6n8Rg1f0zQZLluEOQAMAdOv/ ANavR/iP4ZibWLTXYUCrdfuLkgY+b/lmf5jPuKgtbO209BHA4c4+Y7ejc8D26V8zj6cqFVxW3Q+x yyp9Zoqb3WjPl74/eH5NG1nS5o4SILiGQbsf8tARkfkRXlrLX2l8QvCej+ONCn0jUvkZT5lvNjmO QZwR/LFfIniHw/f+F9Wl0rVIQHibgj7rr2YGvSy3EqpT9m90eVm+ElSre2Xwv8DJjbDDnrU23dyT x2qFV+Y/LVnGF3Yr0TyBoUL1yfSpI9ok+boKj3d8AVNZrHLcIsn3Ry2KoVxkg4G1MY689aai/hVq 7aFpf3KgAf7OKpT3Udv8i4d/T0oQiVpEhUtIwGKhjW81ab7PZRsc+lWtL8P6hrEnnTbo4h3Pf6V3 Wk6Rb6bGI4IgD3PejcVzAsvAcLQr9smfzT1x2rb03wzoukt5j+Yz9Bkd624425PX0Hep4bHzmWSX Bx90elOxLdxbO3jj/eLuyR37VoW7CTIZeV/vCpba2XjzGGD1q+rQJHzCdm3qq8mmJlfMaL5kjZ7/ AC1HC1xqcnlQqUiJ+Y0+zsp9SmH7rbB09M10FtZLbj7PDGFBHOO1O9gSuRW0a2a+VbxhpG/Wt3T7 Vo1S4kfdIwyx9PYCqUNnHCxBbczdWx1p+q61p+g6e17d3IjVeBnqT7CpSvoUWNY1fT9It3u7y4VA FyxPGPavDPFHiS/8basLKxV/sok2xRj+L3pviTxBqvjfVlgt438nO2KJe/ufWvqP9mr9l+fdb+J/ FNpgHDRxMvP/ANas61dU1yR1bKjHqdf+yj8GW8N6WmtapbBbiYBgCOR9a+p4GjRRH0PQcfyqlZaP HptulvaxoscYwoA4H+NSvNs+SZPxzz+PpU0afItd2Uy7tV8q2P6D/Gqc1p83TI/z1p0NxHJxu6DG f8KcZdsmNw24/L/E1sIpNYxjlW5bt6//AFqilswvzbev6/Sr52SZXAz1H/16gZmU7X5/mfpQIppY p2G3P5D6e9VLrSVMg2qPl6j0/wDr1pNKFYBuAO/p7D3p7PHty2Bt5+n1pDOdk0f5jjODzg9//rVn Xmis/wAq7uf19h6V1Ui7gfmyD27n3PtVVoztO35s/hmmB59f6TdR7tueD+H4etc9qFvdRp+7cj1/ +vXqV1Z+azMeD0yB+grA1DTVUcqOPQcD/E0xHnn9qMuYry3Ykj/WL1I/pUPmbsNHkqeh/wAK6W50 uFy26Phh/kmsuSyaFgq9G/M+w9BQlYZmtuHXr9ePx96uWtzhhHJ8w6jP9aS4s/M+aNVTHHsD7epq k8M0L/6snJ5DH9TTbGfQG4q3D5OPu1PYRNNcKrZcZ7dvas6JpJDtjXk9TXTaVZyW8S7FJZhy3rQQ a+n26bizHgDgDjFbNvGFRdinP6f/AF6zLO3kKmPIIx930/wrYtVYqFfp0z/9ehMRPHuGWwFx0PQV M0hjQTRMdx/iUf1prRrH8vXv60eWzEttO09+p/8ArUPUZNFcTPBt3YJ5LdyPqaX7RIAB5YXHfufx NQ28iKPLPJ9f/r1ZMe8j5c+9K4EcuoGFcsxCk9+n50+K+t7oL8wHsKguLV2jZfl5/vVHax+UqrJj f/EyjqfpS6jNeHaDnjn361cZVwrY61l28bsdyse2KuRzS5y+eOKoRcEiqcbfxps3775CeD+tV5oz KoYSMhHNEMjrkP271O4yxHbImdqj0qf6LVVr9Y16ZNMbVY1jy7Ef0piLckiqp+b5q5/WNWW3X/WA yE8J3NUdW8SKzGOzfcx43dcVL4d0b7RIby9G+Q85P+FAE+h6RNeSC+v8nJyqHtXZ2kHlqBtx7U21 t4VVdvGKvxx5G5ccUhjVVelSL9z5u9RuWDc449aerdd3egB+VKnnkVWdmXPpUv8AF8p/KmN/OgCn LK2CvY1XbpVmZMnC9qrSK0a/KhcnsKAGU5VXtUscJZcyLg+npSPAy8g0ANYleQxx6VG3LU8r9aAt ADMMKUZ59qdIVRV3sFB456UgDKxxgigBqsoba1Z/iLSLfXNJudOmUESodp9D2NajKu3dxmmkAUmr qwHxl8RfDtxp9xJI0ZEtsxR+Oq5rzzVLGPUrGWzkG4Srx9e1fWfxi8Ix3GdWjhysq7ZeO9fMGpaf Jpt9LZvkhT8p9RXO1Z2ZaZhXWn/DXwJ4Z/t6xuYkurtRH9jaQmYFTh2IPT5g3Hp0pnmxzRhoskOo dMj8apeJvBej+I3Sa+jZXU/MU43j3rQa1jhjjihAVIwAo9Mdqpyi0kkJJo2/D995tubUtlo/u/St N2+XriuPt7hrS6S4Toea6pZfOhWZW4bpTSuJjJGDfOK0o5LjUNNeaSSLzLVEt2ywDOmDsYD2A28e 3rWfjcwGRz6ip7O8lspnVHASdTDKDwGQ46ntg4I+lXB2ZMlcz9WtYdW06XT7mRmjMYVvk2lW2ghg O5DHj6V5vNfNbrJFfbVniOyUY/iHUj2PUfWvVLi3uraeeOSPa2SCFYbcA8FTnkEg4x2HvXmHxQ0m eKeLUrLawfEM+wdMDKkn1H3fwFceaYb2tL2nWJ6mTYv2Fb2b2lp8+hxuseIJJmdYW4HbNebePtFh 8TaeJJFVLuL/AFTnj/gJ+tdl4i0+6tEht0Z4hMRvkC5OD0C++PyrmNR+GOtXFvLqU0V08BUyRsRk AevNeFRr06UlJyse7mFS0XTkrngs0csEzwzKVdDtYehqVWyuPSuzXwfb3Vxf293MLeSOLdFIx435 6cdQRmuMWNssrcFTg+1fS0q0aukeh8nODgr9GN5qaN/JVmLbQRUMs0duOTuf0p1hpeoa1MNqER92 xwK3MyKS5nvJPJtY2JY9uprp/D/glztur3Y7dRGW/nXQaHoWm6TGP3e+TvJW/GtmTukXt3WizIci tDp88f7pYl2heAMcGrJs7qFQ32UMv8T7egq3E2msNseRgdeRU/mWqLjzZtvqDVWIWpUhiVt0iwkK AOWB5qxbRkKd4PqPatC3aG62+Rcvg/Tj8K0Bpd7JFsjuU4+7uXrQMydkKgSM5Lj7uDxWppE17NMf tEY8rHynb1qzY+FY8iS9k3MT68Z7Vv6fpcbEjPlxp95toOKTY0mVLe1kuIy0KhNn3mAxVua2htlT 7OVYMuSx6t65q3qF0vlpb2kUaRR/JlRjecck+9cj4m8a2fh2zaEosly3+rj7g+p9qEmUWPEHibTd BtXmuZATt2oo4Z29h/WvJby68QeP9YSGKJ5CTthhToo/z3qbTNJ8RfEDW0hhjknlmfAAXhfYV9yf s/8A7Mem+ELOHWNehWW+ZQ21h9361z1a9v3dPVlKPc5H9nX9l2HSfI8ReKrZWmOGRWHAr67sbK10 +3W3t4wqKuMe3vTre1jt41jRQAowMDH5elWGQqu4AEd/TP8AWilRUPeerZVyNm2/Q9MVm36q0e5c EDr6f/XrV2q64GPpn+dULuHb/j/gK3EZULMkjKdxBH4//Wpwu1VvlYeg9vb3pGVlduMY6jP8zVWS NW+ZWKn9T9PSgC6LpS33gCOcZ/U1HNcFgT5hyfzb/AVmcqxzxg/h/wDXpsjMcbWOW9+T/gKALUt0 w6twv6fT3pEvlxtbpnoTwPc1Qa6VF+fGOm70PsKrtK2xu6jnk8D60gNv7Qrn5ckHp6t7/SjezfM3 X/Z7+wrB+2NA27J+YZxnlvr6CrMOqI3zb+p5x/JaYGhNIm0ksB9O3t9awbq42MVVdyjPHYVZvbtd hWPqOo7LVQoskYbjJ5VT/M1Lb2RUbdSjNZx3EeRHnIzj+prKmsRGxBbKnjPc+w9q22lWPqM9v97/ AOtVa4Am/enHof8AAVSEc5LC0J3JtO3t2X/69VLgxlSypnPKqf5mtqRVZjGoCsM8N0X3NZ01mjAg Ly3X/a/wFNjR7Npdr5xWTaQq9q6W3YRsF8nPuG6/jVSxtmj2dkA4GOp+lbsFuoRdynePXkj/AAoM mS2lwqhVXGDkDK4/StKGSPG9mxj16/lWcse1ztUoOhI6/nViFgylVjz/AJ9aLgaSskn3e3XP+FSj yx8m7j/PaqdqysxWRguePlqULtbb82BzwaQyz5KfeaRcjpk/0qyWSNRGrqSevNUWMfy9ce1RzTKD yuB71SQFqaZVXCtuJPQdqjhjBb5gNw9KrecGVeuQamswd26Rsd+vJHvRsCNK3/hX061OyqenQ9/8 9aqRyHHmDIB6ZFL52FHoPejcB91NtjKh8EfjxWLPqU3IjY7ccimatqlvH/Fuz19axbdZtUZlSQpH 655PtRYC4/iC7ZikSbj7U2OS+1bb9q8xVzjaOK2tN0NI1X5RkD860YtPWOQIQBmlcEUdK8OWu5ZW jGFPSuotreOMBUXAFRW8flqMVcjXb87dO2aQyRWAxn8KlWTDYGf61FkEhgev97r/APWp6jb+dAE5 ZselPVsjtj2qI9P84FLu29TmgCxhP9ZuCgevQVQkmaVmEfT1pt1deZ+6UfKOp9abHJGF96AEUy7+ W49fWpVc9uM1E02P4eKctxH02NijcCxGvHfk0rQhuvFSRumzIXn0PanOV6DvQBTeILxjioynP3cf 0FXWVdo+WoHHPsKAMvVtMtdVgFvcq5jDLIdrEEkcjkVZXywgXaelSsuVw3TPFN8vg/NSAiwc9aTb 261OqoflzyelPjCqCuMmmBk6tpcepWMtncLlZFKmvm7xx4Gt7fU5Iby3yyZCP0yK+pGIXI21yXjz wfHr1g08CgzxLkHHX2NZ1I31GmfJl74IhZWWK4kX681kT+DrpI/3cqtjPXg16Zqen3FnM8MiFSp5 FZdjDo//AAkemS+IJpF02OVjcKrld3yHYCR0G/bn2BrNRvsF7Hl9z4Xv8srKpG7KkGrWkw3lurWt 1GcdUbPB9f6V2l9DH50iJIsqKzKGXocHqKxrqDa3fnpTSaYFMquwHio3DEsOu6p5OnQjFVzkEdga aCxZun8/SYbqCU/aoWW3nyM5QZ2Hn0A9O3vWJq1nBdafLayRb4piOwyT/jx+Fa9mY2ufsdxJstr1 RDKSSAuejZ7YPOfTNUdVuntZ5bGSDdhjjIxgc4AHUD5s/hW6SnHlM7unLmPHLG40W4+IGp2GsQvB Z6M0EUgLknEhGXUN/sMSMetfWv7T+mfDzRPgnoWj+E7eJ723V49QljwxRkUfeYcYyDz6V8efGGwu NH1KLxVYxlluIBZ6gFHK7TmJgO/BIP4VgxeLNUuvBs2n3mvN5Wo4j8tWLfu855xyc/3enTPTj4jM ctdPEe0avslu7barz0+496OIli2pN979DzjV7jbb3eqhVzO2yFemASccdff8q8z1xmh1Se1tx827 5seuOa9Ul0nUtYv4Gt9KmdUO21tI/nkmf1bHQk8nsB7CsvUvgV8SrG7/ALUutNhlMg85ljm5AP1A B/Cvo8BaOp5+LnzO3Y5LQvB8tyyzX/CnkL/jXdWdjbwRrbwr5Yx2FSWvh/VrGFVvLOWGQfwsOtX4 7WRf9YjBuv3a9NWepwNkEdqg4Ew49RU6QKvO7KjinrCZJwzLuxxz2qyI0DbMg4OPvdTVJCEt7NLi JjmNZOyk1bTQ7p0VRsY4wcNVT7rESROSemM/pW5othHPCs0UkgIblXWiwGdbaDqXnBfs4UL/ABYy P511Nrp62cMcki5cen+FXre2mllW3t1EjScZIAA+p7Cr6Qx2aGSSQSzL8oPYf7tLcFZEMcbtgyBl wB8mef8A61Sl5pmx8qqowAtSyx2trbQ3UOpRStLG0kiqpUwsCflOevGORxzXC658R9PtrWW1sGNx cK2FIXCKfr3p76lJXH+NfGkfh+3Fjb4e7cEqMfdz3NcX4P8ABPiL4j64tvawSTyTtl2I/n6Vc8H+ Edc+JXiZI/LklkuJAZHAzgV+gvwX+Ceh+AdJhZbdGuSAXYjofc1y1qrk/Z0jSK7mZ8B/2e9F+Hun xXd3apJfMozIV5B9Fr3HyYYl8pVAA/IfX1NCr5eCcn09T9Kc8iyLk7VK/kP8TVUqSprQd7kUkeB8 p3Z/M/X0psMm35Tx6f8A1qjaSRTtA4PUf1NRy4dd6scg8Y71qgJ22bj0X27D61DNG0ykev5//Wqu JV3bTglfyH+JpyXCnhd279T/AICgChdWp2kdwevYf41QlhdV2tyG/M/4Ctmc+Y4VSo9W7D2FZV0r RsVK8Menc/U0xFPYHHGCB37Kfb1qrIjRr944/n9farTzIuVPy44Ddh9KZtVlMZXKnn6+5ouBlSPI rCRFDsRtD/4Cq9zIxj/dx7MH+9kfU+9bEdrGuSuTkfifp6CmSWMfl8fdX8k/+vSA5uSSZW2tlg/b u3ufQVXnmlRg0chBAwSvT6Cty60+P5VGefzb6+lVJoUjU9DjjcP4fYUDMttQmDbZFxt/hz0+tPjv v3f3jknOO7f4CkurdGJjVQrY3L/iay3l8lyJN5U9CP4vp7UCNWW6WVf3rDPTco6ewqi11NDL6YHr wv8A9eq00yxj5Wzj+Lsv/wBeq0k25QoGD2H9TTGi1LeIwDLjd1APf3NQSXh272X6+rH0HtVOaSPa NucN+b//AFqjZiqnLAovBIP3PYU7ln05BuT5V4GOuK0IZDHGBJGSMdMbR9feqMbblG7j37/l2q1D hlA/i/P/AOsKRjYtef5ihF5x7cD6etTRzLu27cn6c/lVJlAZQuePvYb+tKrrG25tuz8v/wBdAGjG uGLhef8APpU8jHaGDk498n8BVOO6j2lhli3TPGfwp6zdNxAY/wAIHNFgJjN26Dv71Xa4DSAMrFhz j0FRSXDbiGwAO6/402Lc0m7jLf5/yapAaETbSOSN3b1q5BFIrbRjDckmqsMXyZ5HbOev41LJdCJQ mOQKALMk3lfIvRvfj/69ZGpatHDujR84/WoNQ1byYz+8+vesGOSa8mMipvOeh6UATwxXOoTfPkL3 9q7DRdLhhjXapPqay9N0mSYKbhs46Kvc109rCsEYVVOQOfegCzsEajbgCmEyNJwv40j7WVQwJ549 RViJfLX1pXGSQrtXuSKtKfXniq6t24qcc/QUgEUtuG0nrVlM5HzZz69vwqtuO7uasQ/L2/xoAsoD jmoZpFjUr3p7TKq7uBisi9vgrbTkk9KAJSwJ5o3VWt43kJaTODVrhVwBQABcnFTxxkYYVFHjIY/r VpOw/pQBJGdpHqaezegqNsqMhTT4WDLyc0APViw4xxSMu4DfjOelKOCKkXb36+9AFfZt/H9KPK54 4FSuB7UMv+yc0AUmjKsduTj/AD1p25h820ZFWmVWGKrSBR94nApAM5Ycc55NRNuTORwe3/1qnxxk flTWXcp4zn1pgedeP/A9vqkL6lYR7ZQC0ievvXieraNJEXhkixjjOK+qJLcHI6g/56VwnjPwKtyj 3thDvY8vF3+orGUbaoaPnC10uWxtvs7XBlKsSGI9TVa4tzzkZ/Cu/wBQ0PaW2r93g8cg+/pWJeaO ccR0rvqFjjZ7c7TtB9+KpSLhTwf8K6e40+SNuVO01l3liQW2/WjoBiSLuXcWOB+lU9cKzWSagkn7 4ZWfcOrDGGz7jH4g1pTQlWK7eKrNFHtlt5dvk3C+WzP/AAc5DZ6jBA/WtacuUmaujj9UtbTULJre 523EUkZjkjde5/Xv1HtXPR/BnwLrG6TTo5dKaIGS4kjnOwgH0bPUkfjW/fRNZzyWbvyp2kgZLn29 frUYmaGNYY2XO/DKQAASBknPsB+VFShGr8SFCpKCtc09FsfCHw7jmt/Cumw3F26hDe3K72Pc/ez3 OPTjpWPZrYeLJrj7N4hhuLiGQrIgRyQ23LAkDbwSR1zx0FZvjjUb618M6pd6ewSWO3dY2Y52tjCk k+n9K+t/gn+ynoug/DjQtJukVdQWzhmvGzy9zIgkbcQeuDjg9QaPcoxVOC3/AK1F70ndnyP4m8Hz W8JtdStdysP3bL0PuD1ry7VdNutLvpLGOXDJ/C56rX6GftEfBvSfB3gl7tLpJTEyeQcnKbpWAHvl d3f+E18U+OPCN1qUMV5Y7hfWj8ehQnlcnr61UW7XYmjgjZ30vzMsQ3dMHn86jXRJ3IjNqwOc5DDi tM6HrEkn7yfbs+8GXpWvawpH5duqGSU8fX8KdxWMix0UWeJLi4dmPY9M1t2GkTTYmP7i2Yfe253Y 9PWtpdDEa+dqCxmcNhYG/hwM/MRx6ce9T6rrU2pKDdMipGojjRBtCKvQDHYA0ldlGb5iwKttb5UH 5dyjlvrWXq2uQ6fbl7qZUERI+v8AjVDxB4ug0qR5FmLXRHyopwfT8K4SNNY8X6kqKryu52qijOKc nGCvIaj2JNe8Wanrshs7FTDbnIwn3n+v+Feg/CP9m/xB4+mS4nje1tGIJkZOv0HevZfgL+yjLdND r3iq3Cx8MsbLwfw719l+H/C2i+H7WOztLGOMKoXCjB/+tXE6lTEO0NI/1saJJHlfwr/Z+8M/Du0U 2sYmuD99yPmP19K9P+xxxxhFXC/w46fgO9bD2dqmWVgqj+70H+NQzW+fuTfM33c9cf0renTjSVog 9TJkgbcNvLemf5mq0jndhj8w7gfyFX5obmJWkCq6A446f/XqnMrNHuWI7vTv/wDWqwIFkVsxvw3p /jRKI413Mx+bv3b/AAFVJs7vlUKw/If4mllm82PDZBHYdW/wFMQjbGG5cfL37D2FJsCruVSQecdz 9fQUxQv3lYYX8h9PU1Mq4XByQecE8t7n0pAQTFm6MD7+n0qpcWsjKQzcddv9Sa0m243hgCP4h0Hs KpTzpu25/wCA/wBTTAzLiFCgYDOOP/1VXjby22r07qf61cuJF3eZHJwOGbt+ArMuh/y3iBAP8Pc/ WjYZaWaPcJF4I6kDk/Sknm256DAzjsP8azxdfebcBjv2HsKZ9qWZAjcnrg9vc0gHXEqspbkBvTq3 H6Csm7mfa33cdMjovsPU1ekYqv3mYNxkdW+noKoTRMMtuA2/ko/qaBIyZrgNIF2nK8hfX3Y1Qvrg 7tvXIxuHf2FadxbqyncrYboM8n3NZVxbMsn3sBeNw/kKNhmZNcNuOwDC9uy/X1NQteZ9R36/e+vo KlmhZG2lcbefp9fU1nTwyLuHPPb1+tNBsSSXTIwaRsK3AYd/YCo5pQv3WAI7dQn/ANeqqyNgqM8c Mx7ey0jLvTb2/Qf71Nss+t4/lX5VDKOMDgf/AF6d9p2KGY59FJwB/jWYt60eNu7cR68/4UC6blpF Vueef60GJqfbGbarfe6j/wDVQjGYmQliy+tZqXG1wOcnqBn+XU1Msj4PGMHj/GgDUhmbkFdo+tTS 3UcaB5NxJ7D/AANZQvOeWJx6/wD16RpN2W3Yz/n8aBluS7kkkPXp0OMj/CtCxX5fMY5J/LP9axYF ZmIycdq1I5lhjG49eAAf61W4noaX2+OFRuYkr09R/QVlX2pbmLbtijtUF5dqB5Ubfn61RXT5r1Nr MylueKLgM3S3t15IBKdcgV0el2McahnBXn0z/wDrpmj6X9niCyKNw+U7q2Gh/d7t5PGR6kf0FK4F +32qoKRjk+v8/wDCrkMhH3sc44qjayL5eW+VV6Y7/T1qykoYH5skdMdfxosBcVc5Jxk+nSplUgDH b8qrRbv4m9qt/Ljj60hiqvf1707JU9TzSKylT81OX5v88UATRfN24qXdtz0I/SmQKq8026kVc47U ARzTN+dVViVn3P29qTeWbk4FV7u78kfKeaAL29YxgYpYecZrNieaZw24DHatSBRwrUAS+WsgGefa rK/KOc8UJH0Ujp0/z3qRo9y8/wCfwoATdvzwMUi5jbvz60BfLH+c0v3uOmP89aAJ42DcdT6UjH5s dKoTTPEcRkjnt/WpVuVc7yTkCgC1kxt82SP1NOaRdu7gH0HaqwkaT7p+tSCPd1oAVt3bvURjVuWI 4p0hI+XbkVHI20BuP60rgNZvLz3pqsx+bHWhtzr/AJ/Wm56ck+lAyTZu5bIP61Ey+pGKkG7t60m1 m5zzQByHifwLaawXurN/s12f415DexHSvKte0m80CZo9e094Y88XUSl4j9ccrX0Dg+1QXdnDdxmO 4hSRDxhlz+lZuP8AKFz5y/sm31CHzrO4injbnMbA1jaj4Zk5YL2x0r2LxB8FfDWpTPeaY0+l3fXz LWQpk++OtcNrXw1+L2ixtNoGvWmsRr0hvIQGb2DDmobS+K6/H8tfwGeYXmhyBipQhqyLjSZVVlaP qK6LWPHniLw3I0Pjj4Z3sGw4e4s28xB74x/WqNr8S/hfrTGJdeWxmP8AyyvY2iP5nj9aqK9p8DT9 P8txNpHn2u6Q0EbyKu1o1J3YyXHHGe2B+lczNGzMH2kMzZIwev8An+te7XXh3S9es2+wXNrfQMv3 7eVXH5g15j4s8K6popZp4ne0LcSBT+7xn71axlZ8stCHF7o5eTbJ+7dcjkurnOR6HPWvevBP7ROq Q21tBdXzI0GMqWP3uD298HP414A00isJEYbFOD379xT7dQ7BMkOWO7dxuGRj6VqpcrJse8fET4qX XxOuYNPE2LRJgzbQdrsAQvynoFy5B/229a5mTR0sbr7PbWI1C4LFY4F4MrY55PTA/QVxWl6kLWQS Mw4YfIoxnHqR061o39rdT2lx4k0nx19g1JvMkjsWjLOHA2gb8gDdk/THSpnecrlJpHlt3rlh4k12 50uTTG0y/tnIj7rKilgWB4zgg8+1acNmNIy32ceaVDGZ8bscj5cjj61ylt4Z8WWni7+1PFV+2bCN oYoxcecTnIxkDAUZOB71r63r2n2Nu095dLGVHyrxz7DHWkvefuiJdQvtpYTbSACRk42E9/0/lXnH ibxt8xsdKYMw4aQdvp61m+IPF19r0jQ26tHAeML1b3Ndn8JfgT4i+IV9G8drJFaBhvlZTgfn1rOr XjSXmUo3OR8G+AfEHjrVUttPtZpnlb5m69a+6PgX+yzpfhG3h1TWoFuL1lDbWXhPrXovwe+Dnh/4 c6fFBHYo0rLkyso3sfavVfLUKI4dqj+52H1rlVOVZ81Tbt/mabbFGO0hsLZY40VVUbQwHT6Co2Rm jZQucnpn9WNXJNyZWTqejEc/hVdl5YKBtP8AD2Hua6krIkozSSR7dw/HHb2FVhcs7GNlJA56/wAz Vu6xn94xO4Y4+8309BWZLH97y8fL1wflH19TVBuWDdcjdISCOpH8hUbSBWyvIxnbnp7k1X2tI27c 3PU92+noKi+aI+XxgdR2H1pDBL2wvLox9JME/d9OOK8nb9oLwhN5eoHwh4lj0KS0TU/7Zb7EIl05 sYvntvtP21YOQSzW42jJYAAkdd8Ttsfw48Wuu0Z0O/5xyf8AR34FeGfE6Ro5PECwsUaXxxfpJt43 p/wgkjbTjqNyIceqqewr5zPM0xOAqKGHUdKdSo+ZN3VPk91WcbOXP8Tva3wu56mXYOjiVetfWUIq zS1lzau6e3Ltpfuj1DxJ8WtL0bX10PSPDOsa6Wun09Lq0udOt4Guo2CywxC7uoWnZGYKxiV1V9yE 71dV07zx9pVt4GuviBaR3mp6ZBZzXnl2kDfapjHu3QiJ9rLLuUoY32srgq20g48ZvrEeH9S8TeHv EGiaPHNqGp3q3F3rMdxD9nsrjWrrULe4sHW2ljvGIuYy0SyRGOW2QMckMt+41uz0v4Y2dvqyzHTB 8QvEmq3zwx7mgg0zWNS1MPksFXMtjFHljjEmO+Ry0s/rwr4mNdK1ONSSXLJNKEmlq3aXPG0k4pWv 1umbyyynKlSlSes3FXumveSb0SuuV3Wtz0jT/iroUvheHxRqsN3o6S3t1pq2NwqT3n2q3lmikt4o rV5vPlzbykJEXYhSccHFKD4oaT/YWt61rvh/WtDfQr5NOu9Pu0hnupLmSOB4UjFrLKsjSfaYVRVY sWfbgGsLxD4C0v8A4Z7m8P8Ajzw/pGq6hp+g3GoXTT2cUsY1c28jz3USldqOZpJm3KBjecYzV+x8 K6P4x1P4jaHrTXP2eTxRZTYt7ua1kV4dL0uWN1lhZZEZXRWBVgflr1ZYzF08bRwcuX3qU5Pf44Om tHf4XzvS19FqcfsKMqFStG9lOKW3wtSf3+73sJpvxOgutSTS9Z8K6z4eM12NPjlvrjT54/tZRnED fY7mcxOVQkeaEBOFBLMqlnir4iW/hfWbHQ28Pazf/apLVbq4s44jDYrc3SWtu07ySJw8rkBYw7Yj dioAyfKvDu220LQtNS1bSxLN4O07UbBvDV/ZHQobe5ubi2QvcsWu/MvFS18xThTIZGJ3VvKreIPi t9oudOdlbV5Gike0YxXNhpFp5QBMh4kTUdXlKui4P2YjPGT52DzjFVYSjUs5qtGmvclC65Yyk+SU nKLUee1200oyV4yR018DQhJSjdR5HJ+8pWd2ormSSevLftdrdHQ6x8QILXWho2ieHNS1qY3JshLa 3NjbQ/aBt3wxG7uITOy71DeUHCsdpwwKilffFTSxHu0XR9T1sR2iX119na3tBZRPK8KfaXvZYEic yxyx+UW8wNE4KjaccV4h0uz03VLzw5HeNqdtHqYmndbOKSW3kudQl1M6ZaK52vdTlgzMdiwW8Mc8 jKEjZp9M0zUtB1zw9a6lNG19qHjB9Q1BbVmEJuLvTdbupY0yAWjWWQhdwztRSeaivmuZQrzox5Lc 0Yp8snyuU7Lm95KbcLSaXLytq900XDBYSdOM3zX5W7XWtl0091c2l3zX6dTuo/iHpaWc76xb6hpV 9Z3n9m3GnXFv5l4t35ImFvFFAZPPcwssgEJk3KcjocNi8e2p0/VrzxBouo+H5dBvI7G7s77yZpkm eOGSIILWSUStILiIIiEuzsFC7sA+Xf2Pouv/AAXs4/EGj2WpLb/DbQruH7ZAkwinXT5tsiBwcOMn DDkZPrXZ+K1jk8SfEOS41aHTodN8S6Zq5uZ1BihNpYaZch5MkDaDCM8jjJyK0wWb4zFTw8OWLdSl Uk1Zr34Spx0d3aL53pZtae8yK+BoUvaNN+7OMej92Sk+yu1byv2NODx15t4+n6x4Y1DSY2vDpguJ 7qxuI3vNrt5DG0uJjCxCNjzQmSAudzBTqzNFH99sf7WOF9h715R4S03W22+G76G5jVo9D/tT7VHs u7a3sGkvLVZ3Od19czzxzSxYIihJ3MJJFLemzTKuOgP5iMf1Nejk2KxOLozniHFrmtGUU4qUbR95 Jyk7c3Mk7tSSUlpJHLj6FGhOMaV1pqm02nd6XSXSzta6bs9UNm2sxG0EYOAfT1PvWTdRKgJXOxuv q3/1qt+dHxGzMVPI9XPv7VBPJhiC4z0ZgOPotewtTiMq5XDFl2qVAB9FHt71VV/K+8pO/wC6nOWP qavXDKWA8v5v4V/u+5qhLtx827BPLc5Y+1NlH0o14sUa/dII/A/41OkrP8rH3A7j8OgrOXP3WJBH X1H49BTo7tVY56ehHH1x1amZGpHJ3LYHdgcfr1q55yLHtXpj6fkOtZH2rduPO49fX/AfhUsM6sPJ 24+vf8OposIt7tzfMdo9M1cgVexIx7f5zWZJ5jRnbwV+7/SpLG8mkG24jKt6k4z+VK/QDXZtuYyC ec/5FLJM7fM2Qq9AOp/z7VAvlsPu5Hr/APWpWcP8qrkH0/zzTGOhVpTymOe5/wA5rc0+1/iGVIHP Y/n0FUNNj2gblPHU9OPc9voK3INix/Kc5PHGB+ApiLMca7duBx2xxn2qKaRvu+YSM/UH/E0u5VQ9 WY+vaqEl8YmMJJaQ9l44+vYUmBp28+0Z/n1/H0+lXY081tycZ9uv0FYtrcZkOY8/+y/Qf1rUt7r+ FeOeTn+tG4zXRkRWC9R1xTo5d+cfQ88VRVt2DuJzVuFdrAheuMnHX6CgC7DGv3tvWpdn8QzUan1z +NP3FTkdaQCvJtXHf3qnJNnO6Tn0oupxGM5yfSsu4ueCTuJPHFNATtMyZz65HtVPzBcTAN8qseD6 movOkZv3jAgcYxV6xiUbWdeR93IosBes4wuOp+taUa9DwPrVJGVcf161ZWTptNAF5WXPXkdzS+Yo we4/OqgfoeR9OSaXdyNoPNIC4+1huUY9u5qNT9OPypFk/h46UjMR97GB3oAinXzD83H16Vlax/bT 2o/4R+eCObcOZkJBXPIxW021iG6/rUUg2jcOO1ACxtN5asSgOADj+93qYTNtzkE4qsr/AMO3vTvm 3EAGgCdpPl3MagZlZuh+tKuSOccf54qNl+bA6/560AS7lIA3ZxTSdnG3rTEU56Hmntnp2oGh69cn oKcFwehpgyOvb/PAqTzBjGP8+9ICNl3emQfw/wDr07160df8/wAqTa3fH0/xoAjaNWPGMdB6VA6g fdB/rVljuXqOP88VExz2oAzL7TdP1OMw31nFKv8AtLkD/GvLvHH7NXw58YRu02jxQysCRJENrZ/D pXrDtJ5z7o8IuMMO/wBBSybuJFP1Hr9aznShP4kNHxR4s/Yy8RaHI+oeB/E1zAycgByu32yD1rzj Vl/aQ+H4MOoefqdp6XMKzhgPcgkV+jcnlyLnKj69B9KyL7R7K8Ux3Vmjh+u5csw/pUctWGkJ6dnq g0vex+YmpfFRZpPK1vwidOnX7zWbFU/GNgf0IqvD8QfDsrv/AKSybufnUg8dP85r738Yfs7/AA/8 V+atxo9ujuD8yDGD7kV8++PP2H1cPP4bvCuQSqMuc/T0o9tOHxx08hciPFF8baWsjSR6pEVPcsB2 6+9V7/4iaRBCGW+BfJHyPk4/AVLrv7KvxK02Zo49HecJ18tgcVi237OPxOmkC/8ACN3A5xyKpY2l 1FyGRqXxQcqyWFmC+4lXkA4zxXIMureIrxVcSTyOcKo7ewFfQfhP9jLx1q0yNqUcdmn8QJyR659K +j/hn+y14V8DtFeXkaXlyvWWReAfYVlLEyq6U1/kUoWPn34Ffsn6l4gnt9Y8TW7x25wywnq319BX 2/4U8D6L4R0+Kz021hjWMADC/Kv+Jrds7C0sYVhtYBGuOAvf6ntUk0q7TuZRjOGxwPoO9VToWfNP VhcjkCqP3ZbBGc9zVdrho1HKkj/vlfqe5pWkZv4SM/8AfTfX0qCXy5BwwUA9ew+g7mugQ8apNJIV kXIIxu/iP0HYUjTxjLRkYH8J6D/E1R+cMV2nJ6g/zJ7VCzS/KzHAXoR/QUDLM8yyLtZCGfrjqfr6 CqawhdwyGHv91f8AE0NIyrt2nDdU7n6mnKylPMXGB2PRT/WgCJRtY7flLfmfp6VFPHuk+TAI6r2H 1qWUbfu5G782P9KrzlmXKkBh/D2/E0AUdS02w8QaXe6TqMYktbyCS2uF3FfMjdSrKCCCMgkZBBrw TUPg/wDF3Vri407Vbjw9Ib8MLnWP7Wk/4+3shYSaquniyAjuWtNyCAXZgUsThjkn6BjbeokVsc/e 9foKimXcpVeufu+/qTXn43K8LmLi8RG9rrRyjo7Xi+Vq8ZWV4u8XZXR04fGVsJf2Lte3RPVbPVOz V3ZrVHiPiP4X/EhfEF82h6l/a2k6hezXVxHeeLLqwNxFJc/aPskkX2O6UpG+5UkheBjCwiYELuet q/wb8afa9E0u1m0DUtNEd9FrlzdySW7yJqWrw32qIlsIpUaOVITFGplVoxIcu5Aavb5GzhiTk8b/ APCqzyDhW+Ujov8AVqh5Rg51JVJxbcrXvKTWkuayTbSXNq0kk9ndaFRx+IUYwi0kvJdra6a6d9jH 8aaTca94T1vRbSSNJ9R064s4XlJC75ImUZwCQuSMkA8V5xqvw98VeLPC3i7T/Fmn+Hba98Ra5Z6x HYrM+p2A+yx2ISG4MkMJkjkayIdQgwshwSRmvV5JVIZc5OcbvX6VSmf+Fhyf4f8AGuupg6NWqq04 3koyj1+GXK5Ltryx81bS2pjCvUhD2cXpdP5q9n+LPG/D/wAP/FVq1rpOpWOn6FoNnJpflxWuvy6o /wBl06RpbOxhEtnAY41mYOZXaWRgnlk4IKX/AIT+D/FXh26utW8Z2ugJqE9msCLplzJcjzpLy6vL yfzJo0eNZZroHyfmCiFPmbt6JcRth2PIx9/HT6Cs2QNvxH36Lnr7k1yYfKcJhGnTi7qXNdylJ83L yXbk22+X3dW9Derjq9b42rWtZJJWvzWskkve10PKtR8E/Eq61Yala6boS3tjqGtTW2rW/iBbee5t 725R0WaKbSbhQ8cEFrCCrEhYsbscVGngX4rQ2kFxql1pGqarJI1yZG1UW0umzxy3SwzRTjT5I5ma zuvs8ivaovyb1AZia9PdpB8zOVbpuHb2A71FJNI0Z3D5j0U+vq1Q8lwbjKFpWlLm+OekubnvH3vd 97X3bdttBrMMQpKV1ouX4Y7WtZ6a6d799ziIfAetN4P1fSZIdLsJr/Sxo+mWNrPLPBp1nFa+Rb26 zuiyTAHc7SsgbMpXBCqTl65o/jvUJNd8QX2g6Ompan4g03WRpkWrSvatDarZI8MlwbdW/eLaOCPK IxIFO4Zr0kXEhBZpCP4Wkx972FV7q4ZQItoIPROwHqauGU4OEYQjG3JCUFrK6jLl5le923yx95vm ur3u3eHja7lKTe8lJ6LdXt0tpd6beR47a2vxDXUGksUh0e2uNWbULmJvEEN4gSa7M90qodJjkcvv lAJnUgsCWOMH0Ezq2EkAOOi9Avuaj1BIGYu2OvMmOc+iiqIYMBjchGPkJ5P1rpwmDpYGn7GjflXe UpeVrybdvLYzr16mIm6lS1/RL8kixIoVi3mMwPVu7fSq0kjBiFbBToOyD3p+Wk+befk4L9gfYVVu lG4KUYHOQo/i9zXWjIY0hkXczdT+Mhx+lV5GyXjZ8Oq5Y9kHtTHut0jIzhW6M+Og9qrXG1Sq7N2P uKv8XuxoL6n0RNdIsYZpAqjG0Y656YUdfr+NVvtzTF2DFTjAyRx9T/QVjtdPKzKrDBznux9sjr9B gVasAw2yYOMcN057e/4CnYwNm1kkY7fn3Lzz/h2/+vWjC2W7An9azrcFV2sQgHbrj6KOv41owlRh VXJHryT9fSgZowpvXaSQAOgqwluON2fw4/M1FZL8vPQfl7VcJHHQ49v5CmAqx7kIGME8cfy9akZo 7bEkysc/LtHX8fSp4V24xuzjop+Y/j2qeRo1jX92hA6f3Qf5tR6ALDNGcNtIHG3I4/AdzU0eoDzS uX49f8e1UmmkXJTIPrwCPx7UkckK/wAZJxxxx+A7/WkBfN1c3DbVdY0Hzcd/p/jSw26q3mbiWbli ecn6dzWelynypGvDcZ9fx/wq1b3HlsRtJAOMf/X7UJXC5qg7ZPu46bueD9T/AIVehDSMp7AjjH54 FZ8LNNsYMflOQNvTHoOw9zWnYo/3mYBT0K85/wAaoDSt4QFGGAJ7t1/CraYWQBefc8k/T0qtD8v3 cKD3PLH/AD/WrKq3DAHkcnuf8/1pAW/lCk5xVG7vMDCtj+dNuboRZTcAfWsO+1JVDbckkHtnHv70 kgJri+lVjtdR2waotdMxLSE5/h44qhJqW52HzZYcn0qa3WSYpJIA2P1qgRfgWSRVZyvrxWvarJIw +bgDt/niqMK4+9kHv6//AFq17NRGoVVAHotK1gJ44dqnqGPfvSxeYpC7fy5P4mpOO34gVCfvkLg4 9OlAE/2mJXWDzBvcEhfUDrT1kJxngCoYWyx3Y4/iqYbcZ7UgJd5DZz/hRJIWxnpUbf5zSbs0ATrI u09aF+b5uMVCG9c0okxx69KAHMAGzyP51NF+8jPOMVEdrKBuHqaFkxuA6UrASoyYJXscU7y1bDd/ 5VB52PmVaX7QeMdKABs57k/rQrKfvN0/KmM27tgfqajb17UATMxDbueaaW+am+Yx/ipu4fxUDJXn ZsHoRTTMW+Wo2bH+eaTcW/D9KAJNzD8aRqTdnpSEHnmgRDI7Rnnofz/Co2fnb1DDhB0H1p7tnJbj t7mqzddsfOP4R/7MaRQ6RQ3zK3I79h9BTdwBMbA8jn+83+FVpLmSMl9w9N3YfSo3mkj+cncrHnuz f4CjYZaljZELKFIHXnhf8TVXdubduJHf1P09KSO73fI2FKnp/CPr60xh0aNjk9+7UbC3I7m1tZG+ WGM4/hxwPc+pqGC3sw5UQrg8b9vJPtUuW3bSBgdV7D3J71F5sasWEnA6uf5AUrJgS+RHGDHHGOP4 R/U1FcRxjndjAxuP8lFJ5qlfLZWUN8yqW/U0kjK3WQnHVjz+C1SQEYaRVK7SQeduefxNNaRGOWzz /Fjp7Ad6azMvytG2GGVX/E0izRsxUZ6ctj9BQA1irMYeP733u3uaqzRyQsJMEhuM/wBFFSt5is2I RjjAJ6D1Y0PJgBmyqkct3P0FAWKrL5h2KoyPm256f7xpshVVLK2T3cjn8BSybFfy8YXso6/U1Cys zFtwJHGew+lICFc7SpzzyB3P1qJlZWLDG7PX+EVa2DbuAwDnC92qrJ8rY4yP++V/xpgOWdefM3Ak cN/Ef8KqXCMvy8bQc8dB9TTpMs3y/wAX/fT/AE9BUfm/wHGR/Dn5V/xpAQuy/e34Pr6+wFV2uFkP k7cew/rViRkZvlbBPGT1P09KqXCfLtHBBHHr9TQBFcT7fuupH9//AAFQ74mBQxkAnOPX3JqGU/xM 3zD+L/CoIbjeoNxC0Zb+AtyeepoCwy5aRSW3fKP+Wnp9BVSaTACMreqqOrfX0q9cghWK4479Qo/r WW6bNzYbb27s/wD9agZC91Jgt/EvVj90ewqjK0e5WVWAP8Ofmb6+gq0xXzAH7dh0T3+tULiPaWkW TcGP3v4m9vpRYCOWTDFztyvf+FB/jVedlZThcK38I+8x9/alds4UL8w/5Z9lHqfeoXjOGkVjhjy3 r7ClsBHIx8wqJACPvSY+VPYepqtcPuXy9vynoO7fWrMkbsqjaPMP3U7Aepqk7bNzFjjozHufQUgW hk6ksiMflUkfebPCfQd6zJSrcKpGfTq9al1J0Ux/RPT3NZFzJDHl1Y/LwzevsKpICJJ/LcqXAYfx Hont9aVrzrvzt6Z7v/8AWqrct+7wV24Hyr/U1mPeSKzfvvlx87t/D9KpIaRrXBtbhx8wMgGdvZP/ AK9UpkDQiTnyzwWHDN9KzvtYR++z723u59amW7O45YOT3PCx/wD16GUj2WxWW5k2gMwf8SR6+/44 HtXSWoXbxyV4ba3H0LH+lYWnrsw330kHOOh/q1b6qVUMowFGNz/zCj/PqKdzG5oQrmP5GOAT90YH 5/5zWna2q+XuX7o7Y2j/ABNZ9u0qngcnpnk/gK0rVpOjNk+rHNAFmNVX5mkODxnGB74AqzHuyfm2 /wAzVZSEJJbluhI5P+FLbyBgY2Zhg88c49Se3/1qEBpeeqBR94gcrngd+T/T+VOe4En7yRj0/H8B 2FZLagsOY4GGB/F1H4etZU2pNNKIY2JAOGHXn39T7dqYG0+oD+FlK53Adj789T7mljvGbO1Sc/y/ rWTaEuwZsks3YZyR/P69BWoqwqu1mQL39Px/vGkM0rQBsMRuB7jnH0/+tV+JdzDaxGOnHJ/Cs+EM vzKp2gDHHP5DpWrYQqHzMcZ9ep/+vQtQLllFJMfs5ZwjfeVerex/wrpLdY44wgXaf7q9az7Jo4cr GpGegA5P+FTrIydM5PPHWmBd3Msm7GM9R1JHuaLzUlgUqpz6nNZs159nTzJGIJHRe3f/AArldU1i Sa42q2OeO5ovcRt6jqW4Ftyncecd6xpr6R8/NkjtWaZnOWfJHapIA0uMLyT3ouBct9rsGLfKe+O9 bNmsjOq+W5UDJP4j/Gqtrarld6EsOx7f4VswyfLkDLdgKNgL1vDgjbjJ645q4vytt4/3V/rVWBmZ TuAUn+Bf6mpGeTyztjzgcKDgD6mhIZd3MCAORjp2H+NRiZfMJ3DGPoB/jVWG4835g27HGegH4Uk2 f9YzE+57fQUCL/3WMjN27/0FC3gDbQpJ7Z71VWbpyeeOeSaZ5/G3AVs84/xoAvGaRpB1x3A/qalV vlDcCs5rtYlPcgfdX86VbiaRd+AMdT2HsPWkwNPcCOuaVV3dO1Ulm3fK3f8AOrEcy9PT0pATfL69 KbuHOfWmO4GD0pk00YjVs9aAJwuV6/4Uxm29+tVheKxHYL144FI9wPvLk5/M0DLe/tmo2kK4HXJ6 /wCFVftBZG28gE4HYfjQtyrIDuwc43UAWPOCtjnnt3NEzd85I/IVVn5Uherdu5+vpVX7VJHId2G+ n3VoA1I5tykHOe3qaerc44yOcZ6VQhuNygjOD1Pr9KdMzfwn3Cj+tAGgp/Wk34Y5qhHdFeDzjAz6 1K82FJZef5UBYfcsuD2JH41WwrZXIIP8K/1qKS4OW+Yjccbu/wCFVfOIbDKRk/dB5+pNGwImuFU5 +bJHO4/dX6Cq6SoFzJMFjJ25P3mpJrrzON2XToewqrK8bcMxIPGf4m+noKLDRaEa8sm1wD8qgjC+ 5pW2qu7ftBGC2OT7D2rOj/dXA2H5hztXoPqanW7XduLHJ6sf6CkrBce83WNlJxyFHb3aq7KGdJGf dt4344+gFLJIGXbGv3udmfvfU1B5jKxwy4X7zfwr7D1oBDnjV/3Z3Ek8J3J9TUiN1VmBKj73YfT3 quGYNnkqw/4E3v8ASo3kVZmaPjPBP8KcdvegCxJHtO0bju6Ln9SaF2+20cbv6Cqv2n5ghUgHpnq3 19qiuJm3FlYEL1J+6n09aBmjIwX5Sm8EZ2j+tUZmEi+YrYJ/jbt7CqRvjypZtrfm/wD9aomuH8wL 1bsP4VFGgkWt0fl/Mcen95/8Kikl2cLGC/Zf4VHrUXmllYI2BjHmH+QqMzOrCOReCMqv9TSsO4/7 R8xZnbn+LufoKqyS5crtXgZAz0+tLJMN5JYDj7w7D0FVrjbxhc9wmeT9aewD2Ysud5z/AHh1Y+1V ZJsttbBZew6L9femeevHzDI6v2X2FV2mbzAu0DP3U/qaLiJJJF2+ZvwD1Y9W+lQfal3CORRtPVc8 D3JqGVtzMwcejNjp7LVabaoHykg8he7e5oGXGVX3Mkgkx3/hX6etUrraVOVYZP4v/hVQ3jI25Svy /wAWflWpf7QivFb95tccfN1b/doEILjYRG6gkdFHRaqXH3Wkic5zhnHXHoBUl0u47HUjb0UdT7sa ovdLHMB5isV7nhVoQFW4+8VVSSORH3PuTVTzVYMwcBh/Eei+wHerd3Im0tDkD2+85/wrLuJtso6F x1X+FBRuNMrzKFbd8wV+dv8AExz39qXeSxIZV2jr/Cg/xpGkSZC/mHGOZMcsfQVV87awjeM5xuWP PQeppDLMkg2gJu254/vSH/CqdzJHIxLKnmLwCOifn3pkkkkeZFkJxyz/AN0egqjNMr48yNlDdI+5 9z/hTERXsa7d0bFcH8ZD/SseZmk2G4iRJwv3VbKp9T3NakryfPJuBbqzY6f7IrPnxcRACMgnog7+ 5oQ7mLeIsYbdIdh6v/ExHQCs6ZkfckkYU/woo4+p/wAK1LuMyEsJN0qjk4+WMVlXEf7v5SwRjjd3 lP8ASmPQz7iLKs0M2cfebt+FV1vXVdpGVznb3P1qzPFL97YoPQJnhMetZs0byO2Gye74/lQ9QZ// 2Q= ________________________________________________________________________________
Date: Aug 26, 2016
Subject: Re: Hard Starting Cont. Engines
blockquote, div.yahoo_quoted { margin-left: 0 !important; border-left:1px #715FFA solid !important; padding-left:1ex !important; background-color:whi te !important; } I just sent my eismans to aircraft systems Inc in Rockford IL. Overhaul is $300 per mag plus parts. Mine needed a rotor so I had to f ind another mag for parts. Most parts are still available but the rotor was not. I'm looking at about $1500 for my overhaul cost for the 2 mags. They have been sitting for 40 plus years before I got them and were on rough sha pe. Hope to get them back next week.=C2- Shad Sent from Yahoo Mail for iPhone On Thursday, August 25, 2016, 11:18 PM, Ray Krause wrote: > Louie, So how do you check the spark on Eismann A-4 mags to make sure they are run ning properly? Does anyone overhaul them? Thanks, Ray Krause A-65-8, Eismann mags, impulse on the left. Sent from my iPad > On Aug 25, 2016, at 5:53 PM, Louie Bakrevski wrote: > m> > > Oscar > Let's clarified that -8 cases only came with Bendix lunch box mags, eisma n mags, case mags (they belong on orange ) tractors , s-200 or s-20 mags. A ll of this mags ONLY have impulse coupling on left side. Right side non imp ulse mag.=C2- Slick mags have a impulse on BOTH mags. > All of -8 mags and -9 mags are right turning mags. Lunch box mags do NOT have a impulse coupling on both mags, so you are starting at around 30 degr ees of BTC. You have to swing the prop with authority wood props could swin g back. Eisman Bendix S-20 or 200 only have in pulse on left mag . Should s tarted on left mag only.=C2- Dash 12 cases C-75 ,C-85 C-90 could usually will have impulse coupling on both sides. If you have impulse coupling on b oth sides should be started on both mags. Now if you have push to start Ben dix switch you have to make shure it's set up wright . There is jumper , ne eds to be in right position. If you need more information you have to entic e me wit few MGD. ( mighty good diner). Louie. > Ps a have a ton of small continental pars and mags. > > Sent from my iPad > >> On Aug 25, 2016, at 10:20 AM, taildrags wrote: >> > >> >> OK, so this is from the A&P who overhauled my A75: >> >> "Continentals, if equipped with Impulse Couplers, almost always have the m on both mags.=C2- If you buy Slick magneto kit for an A series engine, the kit will come with two impulse coupled mags.=C2- If one wanted to ins tall their mags piecemeal, you could mount mags with no impulse, the impuls e on either the left or right mags, or on both.=C2- >> >> Lycoming engines come with the impulse on the left mag only.=C2- The i mpulse in the mags for a Lycoming engine takes up a bit of space, so Lycomi ng adds a spacer onto the left magneto mount to accommodate the installatio n of an impulse coupling.=C2- A spacer could also be added to the right s ide if one so desired, but would also require longer studs for mounting the second impulse coupled magneto.=C2- >> >> I've never seen anyone add a second impulse coupled mag onto a Lycoming, but on both A and C series Continentals, dual impulse coupled magnetos is the way they are typically configured. " >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power, 72x36 Culver prop >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=459890#459890 >> >> >> >> >> >> >> >> >> >> > > > > > S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Corvair College #39 Rescheduled for March 10-12, 2017
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Aug 26, 2016
This posting just went out from William Wynne and I just want to put it in this forum in order to get the word out - Builders: We unfortunately have to postpone College #39 at Barnwell SC which was scheduled for November. We have previously had 7 outstanding Colleges at Barnwell, and P.F. Beck and crew have set the gold standard for hosting Colleges. However, Barnwell is a county airport, and it's operation is overseen by a local board. January 1, 2017 sees the arrival of a revised board which again welcomes our event. We looked at many dates, eliminating all the January and February dates because of the prevailing temperature We have selected March 10-12th, 2017 as the revised date for Corvair College #39. All other things about the event, the location, quality, facility and traditional welcome, will all remain the same. The choice to reschedule did not come lightly. All of us understand the level of prep work that builders have put in, and the time off from work and travel plans, etc. If there was some way to avoid this, or any other area location that could provide the same quality experience, we would have gladly taken that option over a postponement. After looking at all possible options, postponing the College was the only viable choice. I have spent many hours in discussion with Dan Weseman to provide options for builders who's projects would be delayed by the postponement, or people who can not adjust their scheduled travel. We are very serious about trying to accommodate every individual who doesn't have the option of attending the rescheduled event. While Barnwell has been and will remain the "flagship" Corvair College, and most people will opt to simply transfer their registration to the new date, Dan and I have spoken about running a Finishing School at the SPA/Panther facility in Green Cove Springs FL on the same date that CC#39 was originally scheduled for. We are 250 miles south of Barnwell, and this event would not be a full scale regular college, but it will be an option for builders put in a bind by the rescheduled date. After looking at your personal calendar, I need everyone who is signed up for CC#39 to choose one of the following options this week: 1) Select to attend Corvair College #39 at Barnwell on the rescheduled date in March 2017. Your registration costs will be directly applied, and you will be signed up for the new date, there will be no additional costs. 2) Select a refund for your registration costs. This will be sent back to you in full. Although we don't control the factor causing the postponement, I am more than willing to refund any builders sign up cost, it is just part of treating people as fairly as possible. Keep in mind that we have about 70 people already signed up for #39, and the physical limit of Barnwell is 90 builders. If you opt for a refund, I will gladly provide it, but I am going to announce the revised dates on my website shortly, and if we refund your sign up fee and later fill the college to capacity of 90, I will not be able to fit anyone else in at the revised dates. I understand this is short notice, but I really need everyone signed up for #39 to respond to with their choice to shelleytumino(at)gmail.com, by September 3rd. If you think that your choice hinges on the ability to attend the Florida Finishing School on the original date, please contact Dan, Rachel and I at this address: flywithspa.com/contact-us/ We will give you a quick answer on space available and if the phase of your engine build is better served by a full College or a Finishing School. Keep in mind that you can select to stay signed up for college #39 at the revised date, and potentially still attend the Finishing School. Again, my humble apologies for the problems this change in schedule will cause. While I can not change the situation, I am very willing to try to accommodate builders needs. Thanks in advance for your understanding on this. We don't control everything in life, but we do control how we react to it, and I am most appreciative of everyone's positive attitude about this situation. Thank you. William Wynne flycorvair.com/ - flycorvair.net/ -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459919#459919 ________________________________________________________________________________
Date: Aug 26, 2016
Why didn=99t you just buy new Slicks and save yourself about 8 lbs? I had Eismanns on my Cub years ago. They are VERY heavy Jack Phillips NX899JP Smith Mountain Lake, Virginia From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of shad bell Sent: Friday, August 26, 2016 7:39 AM Subject: Re: Pietenpol-List: Re: Hard Starting Cont. Engines I just sent my eismans to aircraft systems Inc in Rockford IL. Overhaul is $300 per mag plus parts. Mine needed a rotor so I had to find another mag for parts. Most parts are still available but the rotor was not. I'm looking at about $1500 for my overhaul cost for the 2 mags. They have been sitting for 40 plus years before I got them and were on rough shape. Hope to get them back next week. Shad Sent from Yahoo Mail for iPhone On Thursday, August 25, 2016, 11:18 PM, Ray Krause > wrote: > Louie, So how do you check the spark on Eismann A-4 mags to make sure they are running properly? Does anyone overhaul them? Thanks, Ray Krause A-65-8, Eismann mags, impulse on the left. Sent from my iPad > On Aug 25, 2016, at 5:53 PM, Louie Bakrevski > wrote: > > > > Oscar > Let's clarified that -8 cases only came with Bendix lunch box mags, eisman mags, case mags (they belong on orange ) tractors , s-200 or s-20 mags. All of this mags ONLY have impulse coupling on left side. Right side non impulse mag. Slick mags have a impulse on BOTH mags. > All of -8 mags and -9 mags are right turning mags. Lunch box mags do NOT have a impulse coupling on both mags, so you are starting at around 30 degrees of BTC. You have to swing the prop with authority wood props could swing back. Eisman Bendix S-20 or 200 only have in pulse on left mag . Should started on left mag only. Dash 12 cases C-75 ,C-85 C-90 could usually will have impulse coupling on both sides. If you have impulse coupling on both sides should be started on both mags. Now if you have push to start Bendix switch you have to make shure it's set up wright . There is jumper , needs to be in right position. If you need more information you have to entice me wit few MGD. ( mighty good diner). Louie. > Ps a have a ton of small continental pars and mags. > > Sent from my iPad > >> On Aug 25, 2016, at 10:20 AM, taildrags > wrote: >> > >> >> OK, so this is from the A&P who overhauled my A75: >> >> "Continentals, if equipped with Impulse Couplers, almost always have them on both mags. If you buy Slick magneto kit for an A series engine, the kit will come with two impulse coupled mags. If one wanted to install their mags piecemeal, you could mount mags with no impulse, the impulse on either the left or right mags, or on both. >> >> Lycoming engines come with the impulse on the left mag only. The impulse in the mags for a Lycoming engine takes up a bit of space, so Lycoming adds a spacer onto the left magneto mount to accommodate the installation of an impulse coupling. A spacer could also be added to the right side if one so desired, but would also require longer studs for mounting the second impulse coupled magneto. >> >> I've never seen anyone add a second impulse coupled mag onto a Lycoming, but on both A and C series Continentals, dual impulse coupled magnetos is the way they are typically configured. " >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power, 72x36 Culver prop >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=459890#459890 >> >> >> >> >> >> >> >> >> >> > &gcs.com/Navigator?Pietenpol-List" target="_blank">http://www.matronics.comp; &nhttp://====================== == <http://www.matronics.com/contribution> ________________________________________________________________________________
Date: Aug 26, 2016
blockquote, div.yahoo_quoted { margin-left: 0 !important; border-left:1px #715FFA solid !important; padding-left:1ex !important; background-color:whi te !important; } I'd have to cut out my cowling for the shielded plugs to fit and repaint it. ""(Blisters) Just want to fly this little bugger before the snow comes back. I do have an old slick 4003 or 4001 forget which, fac tory rebuild from slick back in early 80's still in original box but it's s et up with impulse and has the mag drive gear on it for the a65. It just ne eds the harness. I may see if I can find a cap and harness on eBay and get the slick install kit from aircraft spruce and use it as a backup mag on th e bottom. Won't have any clearance issue on the bottom plugs.=C2- Besides I have to keep as much weight on the front of this thing after swap ping out the metal prop for a wooden one.=C2- Shad Sent from Yahoo Mail for iPhone On Friday, August 26, 2016, 8:46 AM, Jack Philips wrote: Why didn=99t you just buy new Slicks and save yourself about 8 lbs? =C2- I had Eismanns on my Cub years ago.=C2- They are VERY heavy =C2- Jack Phillips NX899JP Smith Mountain Lake, Virginia =C2- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of shad bell Sent: Friday, August 26, 2016 7:39 AM Subject: Re: Pietenpol-List: Re: Hard Starting Cont. Engines =C2- I just sent my eismans to aircraft systems Inc in Rockford IL. Overhaul is $300 per mag plus parts. Mine needed a rotor so I had to find another mag f or parts. Most parts are still available but the rotor was not. I'm looking at about $1500 for my overhaul cost for the 2 mags. They have been sitting for 40 plus years before I got them and were on rough shape. Hope to get t hem back next week.=C2- =C2- Shad Sent from Yahoo Mail for iPhone On Thursday, August 25, 2016, 11:18 PM, Ray Krause wrote: > Louie, So how do you check the spark on Eismann A-4 mags to make sure they are run ning properly? Does anyone overhaul them? Thanks, Ray Krause A-65-8, Eismann mags, impulse on the left. Sent from my iPad > On Aug 25, 2016, at 5:53 PM, Louie Bakrevski wrote: > m> > > Oscar > Let's clarified that -8 cases only came with Bendix lunch box mags, eisma n mags, case mags (they belong on orange ) tractors , s-200 or s-20 mags. A ll of this mags ONLY have impulse coupling on left side. Right side non imp ulse mag.=C2- Slick mags have a impulse on BOTH mags. > All of -8 mags and -9 mags are right turning mags. Lunch box mags do NOT have a impulse coupling on both mags, so you are starting at around 30 degr ees of BTC. You have to swing the prop with authority wood props could swin g back. Eisman Bendix S-20 or 200 only have in pulse on left mag . Should s tarted on left mag only.=C2- Dash 12 cases C-75 ,C-85 C-90 could usually will have impulse coupling on both sides. If you have impulse coupling on b oth sides should be started on both mags. Now if you have push to start Ben dix switch you have to make shure it's set up wright . There is jumper , ne eds to be in right position. If you need more information you have to entic e me wit few MGD. ( mighty good diner). Louie. > Ps a have a ton of small continental pars and mags. > > Sent from my iPad > >> On Aug 25, 2016, at 10:20 AM, taildrags wrote: >> > >> >> OK, so this is from the A&P who overhauled my A75: >> >> "Continentals, if equipped with Impulse Couplers, almost always have the m on both mags.=C2- If you buy Slick magneto kit for an A series engine, the kit will come with two impulse coupled mags.=C2- If one wanted to ins tall their mags piecemeal, you could mount mags with no impulse, the impuls e on either the left or right mags, or on both.=C2- >> >> Lycoming engines come with the impulse on the left mag only.=C2- The i mpulse in the mags for a Lycoming engine takes up a bit of space, so Lycomi ng adds a spacer onto the left magneto mount to accommodate the installatio n of an impulse coupling.=C2- A spacer could also be added to the right s ide if one so desired, but would also require longer studs for mounting the second impulse coupled magneto.=C2- >> >> I've never seen anyone add a second impulse coupled mag onto a Lycoming, but on both A and C series Continentals, dual impulse coupled magnetos is the way they are typically configured. " >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power, 72x36 Culver prop >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=459890#459890 >> >> >> >> >> >> >> >> >> >> > &gcs.com/Navigator?Pietenpol-List" target="_blank">http://www.matronics.c omp; =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- &nhttp://====================== = =C2- ________________________________________________________________________________
Date: Aug 26, 2016
Subject: AM-4 Overhaul
=C2-(Posting again without pictures because of rejected post...) =C2-Rather than go further off topic on the Hot Engine Start thread, I th ought I'd start anew. Ray, overhauling the AM-4 is not difficult if you have the AM-4 overhaul ma nual AND the A65 overhaul manual. (Both available on-line in PDF form I bel ieve.) The AM-4 manual will get you through the overhaul and the A65 manual will assist with installation of the mag, timing, etc. I overhauled mine with no difficulty at all. ________________________________________________________________________________
Date: Aug 26, 2016
My AM-4's came off my Aeronca and they were supposedly overhauled just befor e I purchased the Aeronca. The AM-4 s worked fine on the Aeronca, but too m uch static to use a hand-held radio. I put new Slicks on the Aeronca. Now I can't get the mags to fire on the Piet. Most likely it's a hurl problem, but I wanted to check the spark strength. How can I do that? I do have the manuals for both the engine and the mags. Any help? Thanks, Ray Krause Sent from my iPad > On Aug 26, 2016, at 5:46 AM, Jack Philips wrote : > > Why didn=99t you just buy new Slicks and save yourself about 8 lbs? I had Eismanns on my Cub years ago. They are VERY heavy > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of shad bell > Sent: Friday, August 26, 2016 7:39 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Hard Starting Cont. Engines > > I just sent my eismans to aircraft systems Inc in Rockford IL. Overhaul is $300 per mag plus parts. Mine needed a rotor so I had to find another mag f or parts. Most parts are still available but the rotor was not. I'm looking a t about $1500 for my overhaul cost for the 2 mags. They have been sitting fo r 40 plus years before I got them and were on rough shape. Hope to get them b ack next week. > > Shad > > > Sent from Yahoo Mail for iPhone > > On Thursday, August 25, 2016, 11:18 PM, Ray Krause <raykrause@frontiernet. net> wrote: > t> > > Louie, > > So how do you check the spark on Eismann A-4 mags to make sure they are ru nning properly? Does anyone overhaul them? > > Thanks, > > Ray Krause > A-65-8, Eismann mags, impulse on the left. > > Sent from my iPad > > > On Aug 25, 2016, at 5:53 PM, Louie Bakrevski wrote : > > om> > > > > Oscar > > Let's clarified that -8 cases only came with Bendix lunch box mags, eism an mags, case mags (they belong on orange ) tractors , s-200 or s-20 mags. A ll of this mags ONLY have impulse coupling on left side. Right side non impu lse mag. Slick mags have a impulse on BOTH mags. > > All of -8 mags and -9 mags are right turning mags. Lunch box mags do NOT have a impulse coupling on both mags, so you are starting at around 30 degr ees of BTC. You have to swing the prop with authority wood props could swing back. Eisman Bendix S-20 or 200 only have in pulse on left mag . Should sta rted on left mag only. Dash 12 cases C-75 ,C-85 C-90 could usually will hav e impulse coupling on both sides. If you have impulse coupling on both sides should be started on both mags. Now if you have push to start Bendix switch you have to make shure it's set up wright . There is jumper , needs to be i n right position. If you need more information you have to entice me wit few MGD. ( mighty good diner). Louie. > > Ps a have a ton of small continental pars and mags. > > > > Sent from my iPad > > > >> On Aug 25, 2016, at 10:20 AM, taildrags wrote: > >> m> > >> > >> OK, so this is from the A&P who overhauled my A75: > >> > >> "Continentals, if equipped with Impulse Couplers, almost always have th em on both mags. If you buy Slick magneto kit for an A series engine, the k it will come with two impulse coupled mags. If one wanted to install their m ags piecemeal, you could mount mags with no impulse, the impulse on either t he left or right mags, or on both. > >> > >> Lycoming engines come with the impulse on the left mag only. The impul se in the mags for a Lycoming engine takes up a bit of space, so Lycoming ad ds a spacer onto the left magneto mount to accommodate the installation of a n impulse coupling. A spacer could also be added to the right side if one s o desired, but would also require longer studs for mounting the second impul se coupled magneto. > >> > >> I've never seen anyone add a second impulse coupled mag onto a Lycoming , but on both A and C series Continentals, dual impulse coupled magnetos is t he way they are typically configured. " > >> > >> -------- > >> Oscar Zuniga > >> Medford, OR > >> Air Camper NX41CC "Scout" > >> A75 power, 72x36 Culver prop > >> > >> > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=459890#459890 > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > > > &gcs.com/Navigator?Pietenpol-List" target="_blank">http://www.matronics. comp; &nhttp://============== ========= > > > > > ________________________________________________________________________________
Date: Aug 26, 2016
blockquote, div.yahoo_quoted { margin-left: 0 !important; border-left:1px #715FFA solid !important; padding-left:1ex !important; background-color:whi te !important; } If it has an impulse you can turn the prop thru and pull a plug out and see if it sparks like we did as kids with dirt bike snowmob iles lawnmower etc. just make sure the either all plugs are removed or plug s are disconnected. Not sure how well this will indicate the condition of t he mag though.=C2- Sent from Yahoo Mail for iPhone On Friday, August 26, 2016, 11:19 AM, Ray Krause wrote: My AM-4's came off my Aeronca and they were supposedly overhauled just befo re I purchased the Aeronca. =C2-The AM-4 s worked fine on the Aeronca, bu t too much static to use a hand-held radio. =C2- I put new Slicks on the Aeronca. =C2-Now I can't get the mags to fire on the Piet. =C2-Most lik ely it's a hurl problem, but I wanted to check the spark strength. =C2-Ho w can I do that? I do have the manuals for both the engine and the mags.=C2- Any help? =C2-Thanks, Ray Krause Sent from my iPad On Aug 26, 2016, at 5:46 AM, Jack Philips wrote: -- _filtered {panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered {font-family:Calibri ;panose-1:2 15 5 2 2 2 4 3 2 4;} p.MsoNormal, li.MsoNormal, div.MsoNormal { margin:0in;margin-bottom:.0001pt;font-size:12.0pt;}a:link, span.MsoHyperlin k {color:blue;text-decoration:underline;}a:visited, span.MsoHyperlinkFollow ed {color:purple;text-decoration:underline;}p.yahoo-quoted-begin, li.yahoo- quoted-begin, div.yahoo-quoted-begin {margin-right:0in;margin-left:0in;font -size:12.0pt;}span.EmailStyle18 {color:#1F497D;}.MsoChpDefault {font-size:1 0.0pt;} _filtered {margin:1.0in 1.0in 1.0in 1.0in;}div.WordSection1 {} Why didn=99t you just buy new Slicks and save yourself about 8 lbs? =C2- I had Eismanns on my Cub years ago.=C2- They are VERY heavy =C2- Jack Phillips NX899JP Smith Mountain Lake, Virginia =C2- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of shad bell Sent: Friday, August 26, 2016 7:39 AM Subject: Re: Pietenpol-List: Re: Hard Starting Cont. Engines =C2- I just sent my eismans to aircraft systems Inc in Rockford IL. Overhaul is $300 per mag plus parts. Mine needed a rotor so I had to find another mag f or parts. Most parts are still available but the rotor was not. I'm looking at about $1500 for my overhaul cost for the 2 mags. They have been sitting for 40 plus years before I got them and were on rough shape. Hope to get t hem back next week.=C2- =C2- Shad Sent from Yahoo Mail for iPhone On Thursday, August 25, 2016, 11:18 PM, Ray Krause wrote: > Louie, So how do you check the spark on Eismann A-4 mags to make sure they are run ning properly? Does anyone overhaul them? Thanks, Ray Krause A-65-8, Eismann mags, impulse on the left. Sent from my iPad > On Aug 25, 2016, at 5:53 PM, Louie Bakrevski wrote: > m> > > Oscar > Let's clarified that -8 cases only came with Bendix lunch box mags, eisma n mags, case mags (they belong on orange ) tractors , s-200 or s-20 mags. A ll of this mags ONLY have impulse coupling on left side. Right side non imp ulse mag.=C2- Slick mags have a impulse on BOTH mags. > All of -8 mags and -9 mags are right turning mags. Lunch box mags do NOT have a impulse coupling on both mags, so you are starting at around 30 degr ees of BTC. You have to swing the prop with authority wood props could swin g back. Eisman Bendix S-20 or 200 only have in pulse on left mag . Should s tarted on left mag only.=C2- Dash 12 cases C-75 ,C-85 C-90 could usually will have impulse coupling on both sides. If you have impulse coupling on b oth sides should be started on both mags. Now if you have push to start Ben dix switch you have to make shure it's set up wright . There is jumper , ne eds to be in right position. If you need more information you have to entic e me wit few MGD. ( mighty good diner). Louie. > Ps a have a ton of small continental pars and mags. > > Sent from my iPad > >> On Aug 25, 2016, at 10:20 AM, taildrags wrote: >> > >> >> OK, so this is from the A&P who overhauled my A75: >> >> "Continentals, if equipped with Impulse Couplers, almost always have the m on both mags.=C2- If you buy Slick magneto kit for an A series engine, the kit will come with two impulse coupled mags.=C2- If one wanted to ins tall their mags piecemeal, you could mount mags with no impulse, the impuls e on either the left or right mags, or on both.=C2- >> >> Lycoming engines come with the impulse on the left mag only.=C2- The i mpulse in the mags for a Lycoming engine takes up a bit of space, so Lycomi ng adds a spacer onto the left magneto mount to accommodate the installatio n of an impulse coupling.=C2- A spacer could also be added to the right s ide if one so desired, but would also require longer studs for mounting the second impulse coupled magneto.=C2- >> >> I've never seen anyone add a second impulse coupled mag onto a Lycoming, but on both A and C series Continentals, dual impulse coupled magnetos is the way they are typically configured. " >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power, 72x36 Culver prop >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=459890#459890 >> >> >> >> >> >> >> >> >> >> > &gcs.com/Navigator?Pietenpol-List" target="_blank">http://www.matronics.c omp; =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- &nhttp://====================== = =C2- ________________________________________________________________________________
Date: Aug 26, 2016
You might want to be wary of using a 30+ year old mag without overhauling it. If nothing else the bearing grease has probably completely hardened and there could be other problems with the plastic parts depending on how it was stored (heat, ozone, humidity). Rodney Hall ________________________________________________________________________________
Date: Aug 26, 2016
blockquote, div.yahoo_quoted { margin-left: 0 !important; border-left:1px #715FFA solid !important; padding-left:1ex !important; background-color:whi te !important; } Yes definitely overhaul them. Mine ran fine on the ground but acted up in flight. I should've sent them in for overhaul Before my te st flight. I guess I was lucky and won't trust old mags that haven't been r ebuilt. Mine sat for at least 30-40 years. Before I flew them.=C2- Sent from Yahoo Mail for iPhone On Friday, August 26, 2016, 12:10 PM, r.r.hall(at)cox.net w rote: You might want to be wary of using a 30+ year old mag without overhauling i t. If nothing else the bearing grease has probably completely hardened and there could be other problems with the plastic parts depending on how it wa s stored (heat, ozone, humidity). Rodney Hall S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Aug 26, 2016
Ray My two cents worth. Most small mags like AM-4, slicks and Bendix S-20 And- 200. Need blast tubes. Eisemann AM-4 are small mags and do not get rid of h eat easily. Heat damages coils and that makes them hard to start. I strongl y suggest when using Small magnetos to use blast tubes. If you see any newe r production engines you will see b last tubes. Old engine that used Bendix SF4R-8 do not have blast tubes. Those big Lunch box mags because of their size and internal fan got rid of heat fairly effective. I have argued the n eed for blast tube with Slick representative few times and they no the prob lem. I usually put suspected mag on my mag tester and heated it up. see if spark gets week. Louie PS when in doubt change coil. Hard starting when hot is usually a bad coil. Also holding your mouth just right helps. ________________________________ From: owner-pietenpol-list-server(at)matronics.com <owner-pietenpol-list-serve r(at)matronics.com> on behalf of Ray Krause Sent: Friday, August 26, 2016 10:19 AM Subject: Re: Pietenpol-List: Re: Hard Starting Cont. Engines My AM-4's came off my Aeronca and they were supposedly overhauled just befo re I purchased the Aeronca. The AM-4 s worked fine on the Aeronca, but too much static to use a hand-held radio. I put new Slicks on the Aeronca. Now I can't get the mags to fire on the Piet. Most likely it's a hurl prob lem, but I wanted to check the spark strength. How can I do that? I do have the manuals for both the engine and the mags. Any help? Thanks, Ray Krause Sent from my iPad On Aug 26, 2016, at 5:46 AM, Jack Philips > wrote: Why didn=92t you just buy new Slicks and save yourself about 8 lbs? I had Eismanns on my Cub years ago. They are VERY heavy Jack Phillips NX899JP Smith Mountain Lake, Virginia From: owner-pietenpol-list-server(at)matronics.com<mailto:owner-pietenpol-list -server(at)matronics.com> [mailto:owner-pietenpol-list-server(at)matronics.com] O n Behalf Of shad bell Sent: Friday, August 26, 2016 7:39 AM Subject: Re: Pietenpol-List: Re: Hard Starting Cont. Engines I just sent my eismans to aircraft systems Inc in Rockford IL. Overhaul is $300 per mag plus parts. Mine needed a rotor so I had to find another mag f or parts. Most parts are still available but the rotor was not. I'm looking at about $1500 for my overhaul cost for the 2 mags. They have been sitting for 40 plus years before I got them and were on rough shape. Hope to get t hem back next week. Shad Sent from Yahoo Mail for iPhone On Thursday, August 25, 2016, 11:18 PM, Ray Krause > wrote: > Louie, So how do you check the spark on Eismann A-4 mags to make sure they are run ning properly? Does anyone overhaul them? Thanks, Ray Krause A-65-8, Eismann mags, impulse on the left. Sent from my iPad > On Aug 25, 2016, at 5:53 PM, Louie Bakrevski wrote: > m> > > Oscar > Let's clarified that -8 cases only came with Bendix lunch box mags, eisma n mags, case mags (they belong on orange ) tractors , s-200 or s-20 mags. A ll of this mags ONLY have impulse coupling on left side. Right side non imp ulse mag. Slick mags have a impulse on BOTH mags. > All of -8 mags and -9 mags are right turning mags. Lunch box mags do NOT have a impulse coupling on both mags, so you are starting at around 30 degr ees of BTC. You have to swing the prop with authority wood props could swin g back. Eisman Bendix S-20 or 200 only have in pulse on left mag . Should s tarted on left mag only. Dash 12 cases C-75 ,C-85 C-90 could usually will have impulse coupling on both sides. If you have impulse coupling on both s ides should be started on both mags. Now if you have push to start Bendix s witch you have to make shure it's set up wright . There is jumper , needs t o be in right position. If you need more information you have to entice me wit few MGD. ( mighty good diner). Louie. > Ps a have a ton of small continental pars and mags. > > Sent from my iPad > >> On Aug 25, 2016, at 10:20 AM, taildrags wrote: >> > >> >> OK, so this is from the A&P who overhauled my A75: >> >> "Continentals, if equipped with Impulse Couplers, almost always have the m on both mags. If you buy Slick magneto kit for an A series engine, the k it will come with two impulse coupled mags. If one wanted to install their mags piecemeal, you could mount mags with no impulse, the impulse on eithe r the left or right mags, or on both. >> >> Lycoming engines come with the impulse on the left mag only. The impuls e in the mags for a Lycoming engine takes up a bit of space, so Lycoming ad ds a spacer onto the left magneto mount to accommodate the installation of an impulse coupling. A spacer could also be added to the right side if one so desired, but would also require longer studs for mounting the second im pulse coupled magneto. >> >> I've never seen anyone add a second impulse coupled mag onto a Lycoming, but on both A and C series Continentals, dual impulse coupled magnetos is the way they are typically configured. " >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power, 72x36 Culver prop >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=459890#459890 >> >> >> >> >> >> >> >> >> >> > &gcs.com/Navigator?Pietenpol-List<http://gcs.com/Navigator?Pietenpol-List>" target="_blank">http://www.matronics.comp; &nhttp:// ======================= <http://www.matronics.com/contribution> ________________________________________________________________________________
Date: Aug 26, 2016
I have been using Eisemann trouble free for many years. Last year a broke i mpulse spring. But that can happen with any mag. I think Slick kit with plu gs and wires are around 3500.00 plus. That byes a lot of fuel. But a have a about 10 or 20+ Eisamann mags. Forgot to say that I'm AP IA. With 3 hanger s full junk ,I meant treasures. Only one AD on AM-4 coils and no ad on lunch box SF4 mags. But I'm old school Louie ________________________________ From: owner-pietenpol-list-server(at)matronics.com <owner-pietenpol-list-serve r(at)matronics.com> on behalf of Jack Philips Sent: Friday, August 26, 2016 7:46 AM Subject: RE: Pietenpol-List: Re: Hard Starting Cont. Engines Why didn=92t you just buy new Slicks and save yourself about 8 lbs? I had Eismanns on my Cub years ago. They are VERY heavy Jack Phillips NX899JP Smith Mountain Lake, Virginia From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of shad bell Sent: Friday, August 26, 2016 7:39 AM Subject: Re: Pietenpol-List: Re: Hard Starting Cont. Engines I just sent my eismans to aircraft systems Inc in Rockford IL. Overhaul is $300 per mag plus parts. Mine needed a rotor so I had to find another mag f or parts. Most parts are still available but the rotor was not. I'm looking at about $1500 for my overhaul cost for the 2 mags. They have been sitting for 40 plus years before I got them and were on rough shape. Hope to get t hem back next week. Shad Sent from Yahoo Mail for iPhone On Thursday, August 25, 2016, 11:18 PM, Ray Krause > wrote: > Louie, So how do you check the spark on Eismann A-4 mags to make sure they are run ning properly? Does anyone overhaul them? Thanks, Ray Krause A-65-8, Eismann mags, impulse on the left. Sent from my iPad > On Aug 25, 2016, at 5:53 PM, Louie Bakrevski wrote: > m> > > Oscar > Let's clarified that -8 cases only came with Bendix lunch box mags, eisma n mags, case mags (they belong on orange ) tractors , s-200 or s-20 mags. A ll of this mags ONLY have impulse coupling on left side. Right side non imp ulse mag. Slick mags have a impulse on BOTH mags. > All of -8 mags and -9 mags are right turning mags. Lunch box mags do NOT have a impulse coupling on both mags, so you are starting at around 30 degr ees of BTC. You have to swing the prop with authority wood props could swin g back. Eisman Bendix S-20 or 200 only have in pulse on left mag . Should s tarted on left mag only. Dash 12 cases C-75 ,C-85 C-90 could usually will have impulse coupling on both sides. If you have impulse coupling on both s ides should be started on both mags. Now if you have push to start Bendix s witch you have to make shure it's set up wright . There is jumper , needs t o be in right position. If you need more information you have to entice me wit few MGD. ( mighty good diner). Louie. > Ps a have a ton of small continental pars and mags. > > Sent from my iPad > >> On Aug 25, 2016, at 10:20 AM, taildrags wrote: >> > >> >> OK, so this is from the A&P who overhauled my A75: >> >> "Continentals, if equipped with Impulse Couplers, almost always have the m on both mags. If you buy Slick magneto kit for an A series engine, the k it will come with two impulse coupled mags. If one wanted to install their mags piecemeal, you could mount mags with no impulse, the impulse on eithe r the left or right mags, or on both. >> >> Lycoming engines come with the impulse on the left mag only. The impuls e in the mags for a Lycoming engine takes up a bit of space, so Lycoming ad ds a spacer onto the left magneto mount to accommodate the installation of an impulse coupling. A spacer could also be added to the right side if one so desired, but would also require longer studs for mounting the second im pulse coupled magneto. >> >> I've never seen anyone add a second impulse coupled mag onto a Lycoming, but on both A and C series Continentals, dual impulse coupled magnetos is the way they are typically configured. " >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power, 72x36 Culver prop >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=459890#459890 >> >> >> >> >> >> >> >> >> >> > &gcs.com/Navigator?Pietenpol-List" target="_blank">http://www.matronics.c omp; &nhttp://============= <http://www.matronics.com/contribution> ________________________________________________________________________________
Date: Aug 26, 2016
Semih: yes, you have described the Bendix "lunchbox" mag. If you go on eBay and look for item #131920162785, that is typical of them. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459935#459935 ________________________________________________________________________________
Subject: Re: AM-4 Overhaul
Date: Aug 26, 2016
Good move, starting this as its own thread. Here's what my A&P said about the AM-4 mags, which agrees with what speedbrake just posted: "Some shops will still work on Eisemann mags, but I don't know which ones. Parts are available through Fresno Air Parts, and some parts are available through Aircraft Spruce. For the most part, they are a pretty simple mag that any competent A&P can repair. The exception is that it needs to go to a magneto shop to have the magnets re-magnetized if they are getting weak." -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459936#459936 ________________________________________________________________________________
Date: Aug 26, 2016
Louie, I was "told"these mags were overhauled three years ago and the AD is done. B ut I can't find any info on that in the logs, so I'm not sure. Is there a practical way to test the strength of the spark with the mags on t he engine? Is the spark produced by AC or DC? I assume AC, from my experien ces. I'm not too inspired to just hold on to the plug lead and check my refl ection in a mirror, or record a selfie video! I tried a voltage meter and one of the auto store lights that go in the lead . Maybe the light has to be in the dark? Thanks, Ray Krause Sent from my iPad > On Aug 26, 2016, at 12:27 PM, Louie Bakrevski wrote: > > I have been using Eisemann trouble free for many years. Last year a broke i mpulse spring. But that can happen with any mag. I think Slick kit with plug s and wires are around 3500.00 plus. That byes a lot of fuel. But a have a a bout 10 or 20+ Eisamann mags. Forgot to say that I'm AP IA. With 3 hangers f ull junk ,I meant treasures. Only one AD on AM-4 coils > > and no ad on lunch box SF4 mags. But I'm old school Louie > > > From: owner-pietenpol-list-server(at)matronics.com <owner-pietenpol-list-serv er(at)matronics.com> on behalf of Jack Philips > Sent: Friday, August 26, 2016 7:46 AM > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Re: Hard Starting Cont. Engines > > Why didn=99t you just buy new Slicks and save yourself about 8 lbs? I had Eismanns on my Cub years ago. They are VERY heavy > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of shad bell > Sent: Friday, August 26, 2016 7:39 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Hard Starting Cont. Engines > > I just sent my eismans to aircraft systems Inc in Rockford IL. Overhaul is $300 per mag plus parts. Mine needed a rotor so I had to find another mag f or parts. Most parts are still available but the rotor was not. I'm looking a t about $1500 for my overhaul cost for the 2 mags. They have been sitting fo r 40 plus years before I got them and were on rough shape. Hope to get them b ack next week. > > Shad > > > Sent from Yahoo Mail for iPhone > On Thursday, August 25, 2016, 11:18 PM, Ray Krause <raykrause@frontiernet. net> wrote: > t> > > Louie, > > So how do you check the spark on Eismann A-4 mags to make sure they are ru nning properly? Does anyone overhaul them? > > Thanks, > > Ray Krause > A-65-8, Eismann mags, impulse on the left. > > Sent from my iPad > > > On Aug 25, 2016, at 5:53 PM, Louie Bakrevski wrote : > > om> > > > > Oscar > > Let's clarified that -8 cases only came with Bendix lunch box mags, eism an mags, case mags (they belong on orange ) tractors , s-200 or s-20 mags. A ll of this mags ONLY have impulse coupling on left side. Right side non impu lse mag. Slick mags have a impulse on BOTH mags. > > All of -8 mags and -9 mags are right turning mags. Lunch box mags do NOT have a impulse coupling on both mags, so you are starting at around 30 degr ees of BTC. You have to swing the prop with authority wood props could swing back. Eisman Bendix S-20 or 200 only have in pulse on left mag . Should sta rted on left mag only. Dash 12 cases C-75 ,C-85 C-90 could usually will hav e impulse coupling on both sides. If you have impulse coupling on both sides should be started on both mags. Now if you have push to start Bendix switch you have to make shure it's set up wright . There is jumper , needs to be i n right position. If you need more information you have to entice me wit few MGD. ( mighty good diner). Louie. > > Ps a have a ton of small continental pars and mags. > > > > Sent from my iPad > > > >> On Aug 25, 2016, at 10:20 AM, taildrags wrote: > >> m> > >> > >> OK, so this is from the A&P who overhauled my A75: > >> > >> "Continentals, if equipped with Impulse Couplers, almost always have th em on both mags. If you buy Slick magneto kit for an A series engine, the k it will come with two impulse coupled mags. If one wanted to install their m ags piecemeal, you could mount mags with no impulse, the impulse on either t he left or right mags, or on both. > >> > >> Lycoming engines come with the impulse on the left mag only. The impul se in the mags for a Lycoming engine takes up a bit of space, so Lycoming ad ds a spacer onto the left magneto mount to accommodate the installation of a n impulse coupling. A spacer could also be added to the right side if one s o desired, but would also require longer studs for mounting the second impul se coupled magneto. > >> > >> I've never seen anyone add a second impulse coupled mag onto a Lycoming , but on both A and C series Continentals, dual impulse coupled magnetos is t he way they are typically configured. " > >> > >> -------- > >> Oscar Zuniga > >> Medford, OR > >> Air Camper NX41CC "Scout" > >> A75 power, 72x36 Culver prop > >> > >> > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=459890#459890 > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > > > &gcs.com/Navigator?Pietenpol-List" target="_blank">http://www.matronics. comp; &nhttp://============== ========= > > > > > ________________________________________________________________________________
Date: Aug 26, 2016
blockquote, div.yahoo_quoted { margin-left: 0 !important; border-left:1px #715FFA solid !important; padding-left:1ex !important; background-color:whi te !important; } I'll keep my eismans till I can't find parts. Been workin g jets my whole career so I figured I would have a good shop go thru them f irst. Next time they Ned work I will take the time to relearn what I forgot from a&p school 20 years ago. Now that I'm buying aviation parts that Corv air mill on the front of the Piet looks better and better.=C2- Shad Sent from Yahoo Mail for iPhone On Friday, August 26, 2016, 4:25 PM, taildrags wrot e: Good move, starting this as its own thread.=C2- Here's what my A&P said a bout the AM-4 mags, which agrees with what speedbrake just posted: "Some sh ops will still work on Eisemann mags, but I don't know which ones.=C2- Pa rts are available through Fresno Air Parts, and some parts are available th rough Aircraft Spruce.=C2- For the most part, they are a pretty simple ma g that any competent A&P can repair.=C2- The exception is that it needs t o go to a magneto shop to have the magnets re-magnetized if they are gettin g weak." -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459936#459936 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Aug 27, 2016
Louie, if you are ever interested in off - loading some of your AM-4 mags, please let me know off line. I would be interested in any A-65, AM-4, =C2 -NAS3 and=C2-MA-3PA (10-4233)=C2-=C2-parts you may want to "part" w ith...as it were. ________________________________________________________________________________
Subject: Re: Tail hinges - Memphis
Date: Aug 27, 2016
Not sure how much my opinion counts but would be happy to assist. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459966#459966 ________________________________________________________________________________
Subject: Babbitt or insert bearings
Date: Aug 28, 2016
Hey all you model A guys in here. Are you going with babbitt bearings or bearing inserts. If inserts who do you have doing the machine work? Bill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=459999#459999 ________________________________________________________________________________
Subject: Re: Babbitt or insert bearings
Date: Aug 29, 2016
Have not had to make this decision, but have done a LOT of research... Insert bearings are superior to pure babbit. Bearings on turbines in nuclear power plants are similar, but WAY WAY bigger and ultimately technological. Furthermore, line boring a block, the process of enlarging the bearing seats for inserts, isn't that hard. Any decent machine shop can do it. Pure babbit is completely acceptable PROVIDING it's done correctly. I can and do pour babbit for woodworking machines. It's a dying art... AND requires a fair amount of specialized equipment and jigs do do a engine block. And then it needs to be line bored anyway. In this case the line boring aligns the bearings and puts them to size as they are not poured exactly to size. As you can see it's the same old same old. Total compromise. The cost of materials to pour is probably twenty bucks. The jigging is rare as hens teeth, although totally low tech. An amateur machinist could make the stuff for no money, just a lot of time at the lathe. Once a block is machined for inserts, it's really a no brainer and inserts aren't really that expensive. The key is finding a GOOD reliable machinist. Should I ever get around to rebuilding my model a, I'll probably try to pour it myself just for the satisfaction. Mistakes are easily repaired, just takes time. No wasted materials really. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460014#460014 ________________________________________________________________________________
Date: Aug 30, 2016
I'll be downtown memphis the afternoon of the 4th. Grab a beer and check them out? Mike Danford, 423 580 1383 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460054#460054 ________________________________________________________________________________
Subject: Airport Courtesy Cars App/Website Update
Date: Sep 02, 2016
ACC's app is still free in the app stores, and on the web. Currently over 11,000 active pilots are using it, and several businesses and FBO' offer fuel and other product discounts. I recently added a Facebook page which will include updates and events. If you are on Facebook please take a look and like it at www.facebook.com/airportcourtesycars Thanks! -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Smart Phone App and www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460171#460171 ________________________________________________________________________________
Date: Sep 06, 2016
Jim, Would like to hear your opinion. I sent my phone number via PM. Larry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460300#460300 ________________________________________________________________________________
From: "Charles N. Campbell" <charlescampbell1924(at)gmail.com>
Date: Sep 06, 2016
Subject: Wire Sizes
I'm looking for help from someone who has wired up a Pietenpol having a Corvair engine. I wonder what size wire to use from the ignition switch to the small contact (the one going to the solenoid) on the starter (the front-mounted starter sold by William Wynne.) I have misplaced the instructions for the starter. I don't remember whether they covered the wire sizes. Chuck ________________________________________________________________________________
Date: Sep 06, 2016
Subject: Re: Wire Sizes
Chuck,=C2-That is a temporary load of less than 5 amp. 16 Gauge wire shou ld be OK=C2-Best regards=C2-Hans van der Voort=C2-NX15KV From: Charles N. Campbell <charlescampbell1924(at)gmail.com> To: "pietenpol-list(at)matronics.com" Sent: Tuesday, September 6, 2016 11:37 AM Subject: Pietenpol-List: Wire Sizes I'm looking for help from someone who has wired up a Pietenpol having a Cor vair engine.=C2- I wonder what size wire to use from the ignition switch to the small contact (the one going to the solenoid) =C2-on the starter ( the front-mounted starter sold by William Wynne.) =C2-I have misplaced th e instructions for the starter.=C2- I don't remember whether they covered the wire sizes. Chuck ________________________________________________________________________________
Subject: Clif's Piet July 2016
Date: Sep 07, 2016
Hi Clif=2C My sincere apologies for not contacting you sooner. I'm also having issues getting back on the Matronics-Pietenpol site as well. Can't log in! I've somehow lost your personal email and phone number...UGH! Can you please send it to me via this ktown069(at)hotmail.com email and/or via text to (703) 307-3955. I'm ready to talk all things Lycoming 290-G=2C We ight and Balance and also=2C what steel did you use for your wing/strut mou nts. I have on set of plans that calls for 14-18 gauge steel and another t hat calls for 4130 for EVERYTHING! I just had a set of wing/struts hardware made from a copy of the ones that were already made on a completed wing. My welder says that the original set was made out of A36 (mild steel)...tensile strength about 47K psi. I'm ho ping that will be stronger than the spruce so I don't have to pay for anoth er set to be fabricated out of 4130 Chrome Molly. What is a good time to call (what time zone are you in...I'm in Las Vegas a rea). Cheers=2CKTOWNPietenpol Air CamperWire rims"The Piety Project"/a.k.a. "The Fabulous Princess Di"Lycoming 290-G From: cdawson5854(at)shaw.ca Subject: Re: Pietenpol-List: Clif's Piet July 2016 Date: Fri=2C 22 Jul 2016 23:20:38 -0700 =0A =0A =0A =0A =0A =0A =0A Thanks Jack. It's an O-290.=0A =0A =0A =0A Very =0A nice=2C Clif. What Lycoming is that you=92ve got?=0A =0A Jack =0A Phillips=0A NX899JP=0A Smith =0A Mountain Lake=2C Virginia=0A =0A ________________________________________________________________________________
Date: Sep 09, 2016
Subject: Hold short on iPad operating system upgrade.
Just in case y'all missed it Foreflight is telling people to hold short before upgrading to iOS 10. Foreflight will test iOS 10 with foreflight and clear it for use. ________________________________________________________________________________
Date: Sep 09, 2016
Hi, IMO if Will Wynne sold you the starter, would he not be able to supply that information or even a new copy of the instructions? I'm just sayin'. Good luck with it. Scott -------------------------------------------- On Tue, 9/6/16, Charles N. Campbell wrote: Subject: Pietenpol-List: Wire Sizes To: "pietenpol-list(at)matronics.com" Date: Tuesday, September 6, 2016, 12:37 PM I'm looking for help from someone who has wired up a Pietenpol having a Corvair engine. I wonder what size wire to use from the ignition switch to the small contact (the one going to the solenoid) on the starter (the front-mounted starter sold by William Wynne.) I have misplaced the instructions for the starter. I don't remember whether they covered the wire sizes. Chuck ________________________________________________________________________________
Subject: Re: Pietenpol-List Digest: 0 Msgs - 09/08/16
Date: Sep 10, 2016
Sent from my iPad > On Sep 9, 2016, at 3:02 AM, Pietenpol-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Pietenpol-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Pietenpol-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-09-08&Archive=Pietenpol > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 16-09-08&Archive=Pietenpol > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Pietenpol-List Digest Archive > --- > Total Messages Posted Thu 09/08/16: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 10, 2016
Date: Sep 10, 2016
Scott Liefeld is my new best friend!!! Flooded the engine and decided to try the method Scott described, although I didn't hold out much hope that it would work. Pulled it through the prescribed TWELVE blades in the forward direction (twelve is a lot of blades!), made the mags hot, and voila-! She fired on the first pull, as advertised! Thank you, Scott. Put 1.6 in the logbook after a very enjoyable flight. My first in a LONG time, actually, and the day was perfect for Pietenpoling. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460396#460396 ________________________________________________________________________________
Date: Sep 10, 2016
Was that 12 blades with the throttle wide open? That many blades would not be so bad if your engine was worn out, like most old Piet engines! Fly the damn thing more! Thanks, I'm getting old, Ray Krause Sent from my iPad > On Sep 10, 2016, at 5:11 PM, taildrags wrote: > > > Scott Liefeld is my new best friend!!! Flooded the engine and decided to try the method Scott described, although I didn't hold out much hope that it would work. Pulled it through the prescribed TWELVE blades in the forward direction (twelve is a lot of blades!), made the mags hot, and voila-! She fired on the first pull, as advertised! Thank you, Scott. > > Put 1.6 in the logbook after a very enjoyable flight. My first in a LONG time, actually, and the day was perfect for Pietenpoling. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power, 72x36 Culver prop > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=460396#460396 > > > > > > > > > > ________________________________________________________________________________
Date: Sep 10, 2016
Ray: yes, that was with the throttle wide open, but pulling the prop through to clear excess fuel doesn't mean throwing yourself into it... just pulling it through. And my A75 is still quite tight... only about 160 hours on the tach since the engine was converted to an A75 and rebuilt back to zero time. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460403#460403 ________________________________________________________________________________
Date: Sep 10, 2016
Oscar, I looked it up: 12 blades forward with the throttle open, not necessarily WOT, fuel off, mags off. Start with throttle in normal low RPM range....a little open. Thanks, Ray Sent from my iPad > On Sep 10, 2016, at 7:28 PM, Ray Krause wrote: > > > Was that 12 blades with the throttle wide open? That many blades would not be so bad if your engine was worn out, like most old Piet engines! Fly the damn thing more! > > Thanks, I'm getting old, > > Ray Krause > > Sent from my iPad > >> On Sep 10, 2016, at 5:11 PM, taildrags wrote: >> >> >> Scott Liefeld is my new best friend!!! Flooded the engine and decided to try the method Scott described, although I didn't hold out much hope that it would work. Pulled it through the prescribed TWELVE blades in the forward direction (twelve is a lot of blades!), made the mags hot, and voila-! She fired on the first pull, as advertised! Thank you, Scott. >> >> Put 1.6 in the logbook after a very enjoyable flight. My first in a LONG time, actually, and the day was perfect for Pietenpoling. >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power, 72x36 Culver prop >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=460396#460396 >> >> >> >> >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Subject: Re: Hard Starting Cont. Engines
Date: Sep 10, 2016
Thanks, you're the MAN! Ray Sent from my iPad > On Sep 10, 2016, at 7:52 PM, taildrags wrote: > > > Ray: yes, that was with the throttle wide open, but pulling the prop through to clear excess fuel doesn't mean throwing yourself into it... just pulling it through. And my A75 is still quite tight... only about 160 hours on the tach since the engine was converted to an A75 and rebuilt back to zero time. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power, 72x36 Culver prop > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=460403#460403 > > > > > > > > > > ________________________________________________________________________________
Subject: afternoon flying
Date: Sep 11, 2016
Pretty quiet on the list, so I don't feel too bad posting about just an ordinary afternoon flight. As I wrote yesterday, Scott's "flooded engine start" routine worked perfectly and I put three landings and 1.6 hr in the logbook. I now know for sure that I'm going to rig up an air/oil separator for my crankcase breather. It's just a fine mist that the propwash picks up in cruise flight and brings up onto the port side of the passenger's windscreen, but after an hour or more in cruise, it begins to get noticeable. I'm going to fabricate a separator to mount to the firewall to put an end to it. I forgot that I was going to put a level on my top longeron in cruise flight to see what angle the fuselage is at in cruise. As I mentioned in another post when the subject came up, I have a very nice little (free) app on my iPhone that gives both a digital readout as well as a "bubble" analog picture of the angle, and the numbers are big enough that I can read them without my reading glasses. I don't remember who had asked about the fuselage attitude in flight, but I've been curious to find out. I'll try to remember it next time. Nothing extraordinary about my afternoon flight. The first leg was over to Beagle Sky Ranch (OR96), a one-way dirt strip, for a pretty decent landing and takeoff. Next leg was over to Prospect (64S), a nice little 4000x50 paved strip in some very scenic country. Lost Creek Lake is on the way over there and one end of the strip is at the edge of a steep dropoff to Mill Creek Falls and the "Avenue of the Boulders" on the Rogue River. It's always gusty there on a warm afternoon and I admit that I ballooned pretty good on initial flare and also on the first bounce, but saved it and lived to fly again ;o) My third and final landing was back home at Rogue Valley International... main runway is 8800x150 and you really have to try hard to mess up so badly that you have to go around. My guess is that you could blow a half-dozen approaches one after the other, save each one, power back up after you save one, and still not run off the far end of the runway. Don't ask me how I know ;o) This time all I needed was 1.5 landings to stick it onto the pavement and make the turnoff at A3 (less than 2000' from the numbers). You really get spoiled on big wide runways when you make your final approach almost at cruise speed, come down with big bright PAPI lights with the throttle still in, and just pull the power over the numbers and start scrubbing off speed. I have to keep telling myself not to carry too much airspeed on final and to keep the stick coming back. It's just hard to do when there is a regional jet full of passengers fanning themselves holding for takeoff behind you and the runway distance markers just seem to be creeping by. My final comment: I was absolutely flabbergasted when I saw how many new marijuana grows have sprung up around the Rogue Valley just in the last 6-9 months. They are everywhere! So much for Oregon's once-famous Christmas tree farms... "Cannabis Green" is the new state color. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460421#460421 ________________________________________________________________________________
Subject: Re: afternoon flying
Date: Sep 12, 2016
Thanks, Oscar! I needed that. Keep it up and you will have me back on my project! Ray Krause SkyScout project Sent from my iPad > On Sep 11, 2016, at 9:17 PM, taildrags wrote: > > > Pretty quiet on the list, so I don't feel too bad posting about just an ordinary afternoon flight. As I wrote yesterday, Scott's "flooded engine start" routine worked perfectly and I put three landings and 1.6 hr in the logbook. I now know for sure that I'm going to rig up an air/oil separator for my crankcase breather. It's just a fine mist that the propwash picks up in cruise flight and brings up onto the port side of the passenger's windscreen, but after an hour or more in cruise, it begins to get noticeable. I'm going to fabricate a separator to mount to the firewall to put an end to it. > > I forgot that I was going to put a level on my top longeron in cruise flight to see what angle the fuselage is at in cruise. As I mentioned in another post when the subject came up, I have a very nice little (free) app on my iPhone that gives both a digital readout as well as a "bubble" analog picture of the angle, and the numbers are big enough that I can read them without my reading glasses. I don't remember who had asked about the fuselage attitude in flight, but I've been curious to find out. I'll try to remember it next time. > > Nothing extraordinary about my afternoon flight. The first leg was over to Beagle Sky Ranch (OR96), a one-way dirt strip, for a pretty decent landing and takeoff. Next leg was over to Prospect (64S), a nice little 4000x50 paved strip in some very scenic country. Lost Creek Lake is on the way over there and one end of the strip is at the edge of a steep dropoff to Mill Creek Falls and the "Avenue of the Boulders" on the Rogue River. It's always gusty there on a warm afternoon and I admit that I ballooned pretty good on initial flare and also on the first bounce, but saved it and lived to fly again ;o) > > My third and final landing was back home at Rogue Valley International... main runway is 8800x150 and you really have to try hard to mess up so badly that you have to go around. My guess is that you could blow a half-dozen approaches one after the other, save each one, power back up after you save one, and still not run off the far end of the runway. Don't ask me how I know ;o) This time all I needed was 1.5 landings to stick it onto the pavement and make the turnoff at A3 (less than 2000' from the numbers). You really get spoiled on big wide runways when you make your final approach almost at cruise speed, come down with big bright PAPI lights with the throttle still in, and just pull the power over the numbers and start scrubbing off speed. I have to keep telling myself not to carry too much airspeed on final and to keep the stick coming back. It's just hard to do when there is a regional jet full of passengers fanning themselves holding for takeoff behind you and th! > e runway distance markers just seem to be creeping by. > > My final comment: I was absolutely flabbergasted when I saw how many new marijuana grows have sprung up around the Rogue Valley just in the last 6-9 months. They are everywhere! So much for Oregon's once-famous Christmas tree farms... "Cannabis Green" is the new state color. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power, 72x36 Culver prop > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=460421#460421 > > > > > > > > > > ________________________________________________________________________________
Date: Sep 12, 2016
Yeah!. Oscar, Keep those fingers flying on the keys! It makes those of us who lose interest in our Piet projects get our noses back to the grind stone. Incidentally, I was hoping to fly mine this summer but I have moved the projected project completion to the Fall of 2016. Will let you know if it gets pushed out any further. Chuck On Mon, Sep 12, 2016 at 11:18 AM, Ray Krause wrote: > raykrause(at)frontiernet.net> > > Thanks, Oscar! I needed that. Keep it up and you will have me back on my > project! > > Ray Krause > SkyScout project > > Sent from my iPad > > > On Sep 11, 2016, at 9:17 PM, taildrags wrote: > > > > > > > > Pretty quiet on the list, so I don't feel too bad posting about just an > ordinary afternoon flight. As I wrote yesterday, Scott's "flooded engine > start" routine worked perfectly and I put three landings and 1.6 hr in the > logbook. I now know for sure that I'm going to rig up an air/oil separator > for my crankcase breather. It's just a fine mist that the propwash picks > up in cruise flight and brings up onto the port side of the passenger's > windscreen, but after an hour or more in cruise, it begins to get > noticeable. I'm going to fabricate a separator to mount to the firewall to > put an end to it. > > > > I forgot that I was going to put a level on my top longeron in cruise > flight to see what angle the fuselage is at in cruise. As I mentioned in > another post when the subject came up, I have a very nice little (free) app > on my iPhone that gives both a digital readout as well as a "bubble" analog > picture of the angle, and the numbers are big enough that I can read them > without my reading glasses. I don't remember who had asked about the > fuselage attitude in flight, but I've been curious to find out. I'll try > to remember it next time. > > > > Nothing extraordinary about my afternoon flight. The first leg was over > to Beagle Sky Ranch (OR96), a one-way dirt strip, for a pretty decent > landing and takeoff. Next leg was over to Prospect (64S), a nice little > 4000x50 paved strip in some very scenic country. Lost Creek Lake is on the > way over there and one end of the strip is at the edge of a steep dropoff > to Mill Creek Falls and the "Avenue of the Boulders" on the Rogue River. > It's always gusty there on a warm afternoon and I admit that I ballooned > pretty good on initial flare and also on the first bounce, but saved it and > lived to fly again ;o) > > > > My third and final landing was back home at Rogue Valley > International... main runway is 8800x150 and you really have to try hard to > mess up so badly that you have to go around. My guess is that you could > blow a half-dozen approaches one after the other, save each one, power back > up after you save one, and still not run off the far end of the runway. > Don't ask me how I know ;o) This time all I needed was 1.5 landings to > stick it onto the pavement and make the turnoff at A3 (less than 2000' from > the numbers). You really get spoiled on big wide runways when you make > your final approach almost at cruise speed, come down with big bright PAPI > lights with the throttle still in, and just pull the power over the numbers > and start scrubbing off speed. I have to keep telling myself not to carry > too much airspeed on final and to keep the stick coming back. It's just > hard to do when there is a regional jet full of passengers fanning > themselves holding for takeoff behind you and ! > th! > > e runway distance markers just seem to be creeping by. > > > > My final comment: I was absolutely flabbergasted when I saw how many new > marijuana grows have sprung up around the Rogue Valley just in the last 6-9 > months. They are everywhere! So much for Oregon's once-famous Christmas > tree farms... "Cannabis Green" is the new state color. > > > > -------- > > Oscar Zuniga > > Medford, OR > > Air Camper NX41CC "Scout" > > A75 power, 72x36 Culver prop > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=460421#460421 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 12, 2016
Thank you Oscar for all your input and inspiration! Much needed at this stage of my build. Jack Textor Sent from my iPad > On Sep 11, 2016, at 11:17 PM, taildrags wrote: > > > Pretty quiet on the list, so I don't feel too bad posting about just an ordinary afternoon flight. As I wrote yesterday, Scott's "flooded engine start" routine worked perfectly and I put three landings and 1.6 hr in the logbook. I now know for sure that I'm going to rig up an air/oil separator for my crankcase breather. It's just a fine mist that the propwash picks up in cruise flight and brings up onto the port side of the passenger's windscreen, but after an hour or more in cruise, it begins to get noticeable. I'm going to fabricate a separator to mount to the firewall to put an end to it. > > I forgot that I was going to put a level on my top longeron in cruise flight to see what angle the fuselage is at in cruise. As I mentioned in another post when the subject came up, I have a very nice little (free) app on my iPhone that gives both a digital readout as well as a "bubble" analog picture of the angle, and the numbers are big enough that I can read them without my reading glasses. I don't remember who had asked about the fuselage attitude in flight, but I've been curious to find out. I'll try to remember it next time. > > Nothing extraordinary about my afternoon flight. The first leg was over to Beagle Sky Ranch (OR96), a one-way dirt strip, for a pretty decent landing and takeoff. Next leg was over to Prospect (64S), a nice little 4000x50 paved strip in some very scenic country. Lost Creek Lake is on the way over there and one end of the strip is at the edge of a steep dropoff to Mill Creek Falls and the "Avenue of the Boulders" on the Rogue River. It's always gusty there on a warm afternoon and I admit that I ballooned pretty good on initial flare and also on the first bounce, but saved it and lived to fly again ;o) > > My third and final landing was back home at Rogue Valley International... main runway is 8800x150 and you really have to try hard to mess up so badly that you have to go around. My guess is that you could blow a half-dozen approaches one after the other, save each one, power back up after you save one, and still not run off the far end of the runway. Don't ask me how I know ;o) This time all I needed was 1.5 landings to stick it onto the pavement and make the turnoff at A3 (less than 2000' from the numbers). You really get spoiled on big wide runways when you make your final approach almost at cruise speed, come down with big bright PAPI lights with the throttle still in, and just pull the power over the numbers and start scrubbing off speed. I have to keep telling myself not to carry too much airspeed on final and to keep the stick coming back. It's just hard to do when there is a regional jet full of passengers fanning themselves holding for takeoff behind you and th! > e runway distance markers just seem to be creeping by. > > My final comment: I was absolutely flabbergasted when I saw how many new marijuana grows have sprung up around the Rogue Valley just in the last 6-9 months. They are everywhere! So much for Oregon's once-famous Christmas tree farms... "Cannabis Green" is the new state color. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power, 72x36 Culver prop > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=460421#460421 > > > > > > > > > > ________________________________________________________________________________
Subject: Wood straight axle or split landing gear?
Date: Sep 12, 2016
I am steadily working my way towards the time to decide which landing gear type to go with. As with the nature of the question I confess that I am a new to building aircraft. Is one better than the other? I like the nostalgia of the wood, but have concerns over rough landings. Thoughts? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460452#460452 ________________________________________________________________________________
Subject: Re: Wood straight axle or split landing gear?
Date: Sep 12, 2016
I like the wood gear on the Piet. It IS plenty strong, no worries there. On the practical side, wood gear is somewhat easier in that you can't misalign it, making for a poor ground handling plane. No welding required at all if that's a concern. On the other hand, the small wide aircraft tires are easier landing than the tall narrow ones IF the gear is aligned properly. So what it comes down to is which are you more comfortable making, and which looks best to you. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460453#460453 ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Sep 13, 2016
Oscar, Glad it worked for you. You can try using fewer blades as time goes on. Maybe next time use 11 blade, then ten and so on. My plane needs 10 blades. anything less and it was all for nothing. Your results may vary. I'm happy it worked for you. Now you can fly more. Now you will look like a professional when it comes to propping aircraft. Happy landings, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460459#460459 ________________________________________________________________________________
Subject: joining the fuse halves
Date: Sep 14, 2016
I'm about to join both fuselage halves. I brought both tail posts together to see how well the edges of the fuselage sides line up with marks I made (showing where the cross struts go). It seems like my sides are just inside my marks. It'll actually be more pronounced as I've not yet sanded the tail posts and they're still 1" wide each. So, if I make the cross struts first, it seems my sides will make a bit of a steeper bend to meet at the tail. Should I just bring the tail posts together, sand to 1" total, then fit in the cross struts? Thank you. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460473#460473 ________________________________________________________________________________
Subject: Re: joining the fuse halves
Date: Sep 15, 2016
I think I put spacers between the two sides so it bent a bit closer to the true dimensions but still a smooth curve. Sanded the tail to 1-inch wide and glued together. Then I added the cross braces. Don't force the cross pieces in or you can twist the fuselage. -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460479#460479 ________________________________________________________________________________
Date: Sep 15, 2016
Agree with Tools 100%. I will add that the split axle gear is probably lighter. -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460480#460480 ________________________________________________________________________________
Subject: TC Pitenpol
Date: Sep 15, 2016
I started the wings, finally. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460483#460483 Attachments: http://forums.matronics.com//files/img_4362_custom_193.jpg ________________________________________________________________________________
Date: Sep 15, 2016
Thank you Chris. I'll give that a try. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460486#460486 ________________________________________________________________________________
Subject: Re: TC Pitenpol
Date: Sep 15, 2016
Very nice Semih! What is your reason for the hanging weights on the tip and trailing edges? Jack Textor Sent from my iPad > On Sep 15, 2016, at 12:05 PM, oldbird wrote: > > > I started the wings, finally. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=460483#460483 > > > > > Attachments: > > http://forums.matronics.com//files/img_4362_custom_193.jpg > > > > > > > ________________________________________________________________________________
Date: Sep 15, 2016
I had to replace a tail post that got ripped out, scarfing in all four longerons. I clamped them together, full width. Then ran down the joint with a circular saw. Now they were 3/32 (a saw blade kerf width) apart. Reclamped until touching, lather rinse repeat until they were one inch total. Worked quite well. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460497#460497 ________________________________________________________________________________
Date: Sep 15, 2016
Thank you for that suggestion Tools. I thought of that, but I decided to make a board tall enough to reach the top of the tail and long enough to make a handhold in. I'll glue sandpaper to both sides of that board and clamp the two tail posts against it. I'll run the sandpaper board through there and sand them down, re-clamping to keep it tight. My main concern is the shape of the fuselage. I think if I make the sides fit to my marks (based on plans measurements), that last part by the tail will bend a bit too steeply. I'm going to cut regular lumber to the size of the cross pieces, place them in the correct locations, and see what I end up with; if the tail meets OK. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460503#460503 ________________________________________________________________________________
Date: Sep 15, 2016
Tools: if you don't mind my asking, how did you keep the clamped tailpost halves from binding the saw blade as you started in with your cut? I could see how you might slip some shims into the cut behind the blade, but if I were to try that trick I'd probably just end up with blade burns, which are not conducive to the wood taking up glue. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460509#460509 ________________________________________________________________________________
Date: Sep 15, 2016
Hi Jack Thanks for your comment. When I cut the bottom capstrip for the fittings and spars, front and rear of the butt rib flexed up a little. When epoxying it in place, I hung the weights to get it back to the original shape. Now it is ok and no more weights. Semih Oksay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460511#460511 ________________________________________________________________________________
Date: Sep 15, 2016
Hi Semih Your work looks excellent. One day you'll have a fine airplane. Where did you get plans for your spars? Glen > On Sep 15, 2016, at 10:06 PM, oldbird wrote: > > > Hi Jack > > Thanks for your comment. > When I cut the bottom capstrip for the fittings and spars, front and rear of the butt rib flexed up a little. When epoxying it in place, I hung the weights to get it back to the original shape. Now it is ok and no more weights. > > Semih Oksay > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=460511#460511 > > > > > > > > > > ________________________________________________________________________________
Date: Sep 15, 2016
Thank you Glen. I designed them myself. If you like, I have the cad drawings of everything I built. Also, the ribs are not original except for the profile. Semih Oksay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460514#460514 ________________________________________________________________________________
Date: Sep 16, 2016
Clamped just enough basically. Actually stabilized the clamping a few inches from the back with jam pieces kind of thing. I've been known to use a circular saw like some folks use a Dremel tool.... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460539#460539 ________________________________________________________________________________
Date: Sep 16, 2016
Clamped just enough basically. Actually stabilized the clamping a few inches from the back with jam pieces kind of thing. I've been known to use a circular saw like some folks use a Dremel tool.... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460540#460540 ________________________________________________________________________________
Date: Sep 17, 2016
I like that Tools, I have been known to use tools a little un-conventionally my self from time to time Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460549#460549 ________________________________________________________________________________
Subject: Fuselage joining
Date: Sep 18, 2016
Hi Pieters, In joining the two fuselage sides, I placed the =BD in x 1in struts and braces in the vertical, ie, with the =91thin=92 side to the gusset. I=92ve been told this is incorrect as there is only half the surface area to the gusset compared with the other way round. Looking at various construction photos on West Coast Piet and this forum, I have noticed that others have appeared to do the same as I have. Is there a =91correct=92 way? Do I need to re-do the construction? I=92d rather do it before I go any further, if it needs to be done. Regards, David Boarder (Tasmania) ________________________________________________________________________________
Date: Sep 18, 2016
David, I did mine as you did, with the 1=94 dimension aligned with the width of the longerons. This is the correct way to do it so that gussets on the interior of the fuselage can be applied across the longerons and the braces and verticals. See photo below: Jack Phillips NX899JP Smith Mountain Lake, Virginia From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of MacBook Pro Sent: Sunday, September 18, 2016 6:33 AM Subject: Pietenpol-List: Fuselage joining Hi Pieters, In joining the two fuselage sides, I placed the =BD in x 1in struts and braces in the vertical, ie, with the =91thin=92 side to the gusset. I=92ve been told this is incorrect as there is only half the surface area to the gusset compared with the other way round. Looking at various construction photos on West Coast Piet and this forum, I have noticed that others have appeared to do the same as I have. Is there a =91correct=92 way? Do I need to re-do the construction? I=92d rather do it before I go any further, if it needs to be done. Regards, David Boarder (Tasmania) ________________________________________________________________________________
Subject: Re: Fuselage joining
Date: Sep 18, 2016
I added space blocks inside of the "v"shape and 1/8"ply gussets top and bott om of the fuse. Ain't goin no where Glen > On Sep 18, 2016, at 4:22 AM, Jack Philips wrote : > > David, > > I did mine as you did, with the 1=9D dimension aligned with the widt h of the longerons. This is the correct way to do it so that gussets on the interior of the fuselage can be applied across the longerons and the braces and verticals. See photo below: > > > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of MacBook Pro > Sent: Sunday, September 18, 2016 6:33 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Fuselage joining > > Hi Pieters, > In joining the two fuselage sides, I placed the =C2=BD in x 1in struts and braces in the vertical, ie, with the =98thin=99 side to the gus set. I=99ve been told this is incorrect as there is only half the sur face area to the gusset compared with the other way round. Looking at vario us construction photos on West Coast Piet and this forum, I have noticed tha t others have appeared to do the same as I have. > Is there a =98correct=99 way? > Do I need to re-do the construction? I=99d rather do it before I go a ny further, if it needs to be done. > Regards, > David Boarder (Tasmania) > > ________________________________________________________________________________
Date: Sep 18, 2016
Here's my photos: http://imageevent.com/hatz/piet/fuselage -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460562#460562 ________________________________________________________________________________
Subject: electronic item for peace
Date: Sep 18, 2016
Mobile phone is a very helpful device, but it will become our trouble if it is used incorrectly-so we need mobile phone jammer (http://www.skybuying.com/category-177-b0.html) in many places. For example, when you are watching an Olympic games, will you get mad if suddenly a mobile phone rings beside you? In a football game, will it disappoint you if the team that you like is going to shoot when a man near you start talking to his mobile phone loudly? Is there a sample way to get you out of mobile phone noise? Yes, the solution is mobile phone jammer. All of us like mobile phones, today we depend on the mobile phones too much that we could not live without mobile phones. But it is not good to use mobile phones at any time in many situations. There are many other places that mobile phone is not welcome besides of the gymnasium. That kind of places include exam room, hospital, library, restaurant, gas station, law court, theatre, lounge, concert, gallery, conference room, and so on. In this kind of places we need to find a way to stop the use of mobile phones. It must stop people to use the mobile phone, but not hurt it. How? The answer is a kind of device called mobile phone signal jammer or mobile phone blocker. The mobile phone jammer is a kind of electronic device that could block mobile phone signal, all mobile phone service in it's working range will be disabled. Want to know more about this high technology device? We could see it throught some mobile phone blocker (http://www.skybuying.com/category-177-b0.html) sample. Please find below a good and helpful mobile phone jammer that could meet our purpose in most situations: the 5 Antennas 25W High Power 3G mobile Phone and WiFi Jamme. Take a closer look at this great jammer product. With Stronger and Longger Omni-directional antennas, Good cooling fan inside and Stable capability, you will be lucky enough to be born into the era of mobile phone jammer. Popular with most of us, this 5 Antennas 25W High Power 3G mobile Phone and WiFi Jammer are mainly used in meeting rooms, classrooms, training centers, factories, banks, trains, bus and other places. For some locations of special purpose such as hospitals, gas stations or churches,etc, you also meet with them often. Please do field test first to make sure no interference happened to the normal operation of their equipment and instrument if you are going to order it directly. Technical Specification Affected Frequency Ranges: -CDMA: 850-894MHz 37.5dBm 15dBm/30KHz(min) -GSM: 935-960MHz 37.5dBm 12dBm/30KHz(min) -DCS/PCS: 1805-1990MHz 36.5dBm 5dBm/30KHz(min) -3G: 2110-2170MHz 36.5dBm 4dBm/30KHz(min) -WIFI: 2400-2500MHz 33dBm 2dBm/30KHz (min) Total output power: 25W Jamming range: up to 60m, the jamming radius still depends on the strength signal in given area External Omni-directional antennas all the TX frequency covered down link only Power supply: 50 to 60Hz, 100 to 240V AC,with AC adapter (AC100-240V DC5V20A), Dimension: 210 x 50 x210mm Weight: 3.5kg Do you have some general ideas about the mobile phone jammer? Do you want to see more mobile phone jammers? Just come to our website, you will see more of them. Here we have many mobile phones jammers and other jammers waiting for your selection. And we offer very good online service, you could place order and finish the payment in our website. We will dispatch the goods to you in just two days after we get your payment. And we provide one year guarantee to our customers for all products. You are welcome in our website. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460564#460564 ________________________________________________________________________________
Subject: Re: electronic item for peace
Date: Sep 18, 2016
"Jammer"-? Did you mean "spammer" instead? ;o) I like my toast with jam, but not on my Pietenpol list. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460569#460569 ________________________________________________________________________________
Date: Sep 19, 2016
Subject: VERY OT my recent Instrument training.
Hit delete NOW. This is a long winded OT report on my Instrument training. None of it is Pietenpol related. Don=99t Bitch about having read it i f you don't want to, just hit delete. Yesterday, I completed my IFR checkride and did quite well. After 25 plus years as an off and on VFR pilot who had dabbled at IFR training, I decided to use my GI Bill for a post Army retirement flying career. I just want someone else to pay for my flying hobby. Step one was to get a instrument ticket. After looking at quite a few schools, I selected of Tempus Training Solutions in San Marcos, Texas. I wanted a school with a good reputation and they had to be able to do Part 141 training and be able to get GI Bill approval. Redbird Proflight Academy moved Flight training operations to Tempus Training. (BTW there is a CFI shortage that has affected most schools.) Tempus met these requirements and was $3500 cheaper than the other part 141 programs due to extensive Sim use. Tempus is the flight training laboratory for Redbird and uses Redbird full motion flight simulators and has an agreement with the FAA that allows them to do a majority of the training in the Sim with the student proving his knowledge in the aircraft. The flight sim closely replicates the 2006 Cessna 172Ses used by the flight academy, including the G1000. The aircraft are well maintained. The Chief pilot for Tempus (a retired F16 driver) has been able to attract good CFIs by understanding that they were going to move on and by helping them get ratings and resume enhancing jobs. (IE my instructor took a break from teaching to fly a Pilatus PC12 from Nairobi, Back to Virginia via Europe and then North sea.) He also treats them as professionals and expects them to act accordingly. Several instructors who became Airline or Corporate pilots come back on their days off to teach (and earn a little change.) The first thing I had to overcome was 25 years of lazy VFR habits such as simply getting close to an altitude or letting the plane drift off heading. I did however get complements on my ability to fly the plane, do cross wind landings At week two, I started having equilibrium problems (Dizzy) , more in the sim than in the plane. I had to cancel several flights and end some sim sessions early. I called a retired Army National Guard buddy who had been the Flight Surgeon for the Texas Army National Guard and told him my problem. He told me several things to try. There has been a huge mold problem in South Texas and the mold count was so high that even those not allergic were having problems. So he told me to take Allegra (NOT Allegra-D) and use Flonase on my nose every day. Also to Shower often to get the mold off of me. He told me to start wearing my reading glasses for every IFR session and any time I read or used a computer. I had not used them early in the day since I could focus, but as my eyes got tired and would not focus, I would put them on. I had been swimming with my grandsons and he told me not to get my head more than three feet below the surface. He ended by saying sleep and eat at the right times and drink water. I think it was a combination of the mold and my aging eyesight. Though I am not sure which one it was, it worked. In two days I was fine. I felt really good about my learning curve at first, but after about 3 weeks I simply felt like I would never get it. If I looked away from the Attitude Inidcator, I climbed, dove, turned or a combination of all three. Taking time to write things down, read them, change frequencies, set up the GPS flight plan, get my tablet set up on an approach procedure, change a freq, check the engine gauges or anything else resulted in a deviation from heading and/or altitude. I called Vernon Foster, a 99 year old buddy. Vern was once a pilot for United Airlines and became their manager of flight simulator engineering and maintenance. He did my tailwheel signoff two years ago at the young age of 97. I told Vern of my problems and how I would never get it. He listened patiently and then laughed and said "you are at the right place in your training. Every pilot thinks that they just aren't going to figure out Instrument flight! It will start to come together and when it does it will get easier." He questioned me about what I was doing and his pearl of wisdom was. "Let Go of the yoke when you look away from the AI!. If the plane is trimmed and flying level it will continue on course while you take 5 seconds to do something. So just let go!" That fixed my problem. I was steering the way I was looking! This school uses iPads to manage the Simulators and all of the instructors have drank the Foreflight Koolaide. So I had to get an iPad, buy foreflight and learn to use it. (I joined NAFI and got a good enough foreflight discount that it almost paid for the NAFI membership.) It took me a while to get down the G1000 buttonology. This High tech device will do a lot of things including providing IFR certified GPS guidance for the pilot (or an autopilot), show a moving map. display all the needed instruments for IFR flight, Show required altitudes, and so on and so forth. I spent many hours in the sim just figuring out ho w to do simple things like activating the next leg on an approach, or how to delete and add an approach. I finally learned to use all the needed functions of a G1000 but it has MANY functions that I have not figured out. I had to learn the balance between trying to get ahead of the plane (IE setting the next approach up) and just flying with what I needed to get to heading and altitude. For example, I had to not try to extract more info from the G1000 while on approaching an ILS approach, "just intercept and fly the localizer and glide slope." About two and a half weeks ago, I had to cancel my scheduled IFR checkride due to a lot of Cumulus activity in our area. Also, I felt marginally ready. Then there was a sudden shortage of DPEs. Many students in the Houston area were scheduling with "our" DPEs. It took me until yesterday to get my checkride and that was on a Sunday morning. My checkride went very well. Even with trainee ATC controllers and the PTT on the DPE side failing 10 minutes into the flight. I asked for a RNAV approach to 31 with a circle to runway 13. But the controller told me we had to use 13 and we could circle at ORALE (confusing a circle with a hold pattern). My DPE explained I had to explain that I was on a checkride and had to do an approach and circle to a different runway. This confused them and the DPE PTT quit right then. So I requested an approach to 13, holding at the IAF and a circle to 31 and proposed that I to do a low approach. I was able to take all this in stride, the DPE was pleased with my ability to communicate and execute. My Checkride was much easier than my "pre check ride" with the Tempus chief pilot. The DPE said he wished all checkrides went so well. All in all, a good experience and glad I did it. I did not enjoy instrument training though I did get comfortable doing it. It is not near as fun VFR flight, but it sure adds to my ability. Next Step is my commercial ticket. BTW I was driving back from lunch and saw the distinctive curve of a Pietenpol wing in a hangar. Slammed on the brakes and who do I find but our own "Axle" working on his AirCamper. Man it sure looks purty! He is a true craftsman. (Pietenpol Content!) Blue Skies, Steve D ________________________________________________________________________________
Date: Sep 19, 2016
The Phone that bothers me the most is mine! ________________________________________________________________________________
Subject: Re: VERY OT my recent Instrument training.
Date: Sep 19, 2016
I'm responding to this OT post with more OT material in the context of several things: (1) Steve is one of the few individuals with the nerve to have gone up with me in Scout, (2) Steve is one of the few individuals who came out to help me disassemble and help load Scout into the big yellow Penske truck for the 2100 mile journey from Texas to Oregon, (3) all of my instrument time has been at the same time extremely enjoyable and extremely challenging, and (4) my last flight review was in a C172 with the Garmin G1000 full glass panel and I was so impressed with it that my eyeballs nearly fell out. Moving right along, I don't care to talk about items (1), (2) or (4) other than to again tip my hat to Steve for always being ready to lend a hand and to tip my already-tipped hat to anyone who can learn the dials and buttons on the G1000 so as to use even 1/10th of its capabilities. If not for the fact that the G1000 panel costs about as much as four or five nice Air Campers, it would be fun to keep writing about it but that's not my world anymore, I'm finally conceding. So now to comment on item (3). Every moment that I've spent under the hood or in 'actual' has been some of the most enjoyable and rewarding time that I've ever spent in airplanes, but it was about as different a flying experience from an open-cockpit Air Camper as you can imagine. I am an engineer with a completely logical outlook and mindset and I completely 'get' instrument flying. I can visualize everything about instrument flying in my head, and I can almost always translate that to the instrument actions as I manipulate the controls, but it's a completely different flying experience, period. I've flown jet and prop sims and I've flown real single and twin hardware, and I always love the challenge. I envy those who have the rating and wish I had gotten mine too, but now my flying is all about stick and rudder and just the sensations of flight and the airplane. Nothing much on the instrument panel is of interest to me anymore if it does nothing to keep the airplane in the air or help me keep it so. Every now and then I have a weak moment when I open the latest AOPA Pilot magazine (I get the Turbine Edition!) and see the super cool panels and instruments, but then it passes and I remember that I much prefer the smell of too-rich Continental exhaust to looking at a glass panel. Sometimes I regret not going for my instrument. As Marlon Brando said in the classic movie "On The Waterfront": "You don't understand. I coulda had class. I coulda been a contender. I coulda been somebody, instead of a bum, which is what I am, let's face it." -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, 72x36 Culver prop Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460606#460606 ________________________________________________________________________________
Date: Sep 20, 2016
My hat is off to ya! Light civil instrument flying is quite a handful... My first exposure was being a safety pilot for a bud in a 172 in about 1995. The glide slope and azimuth were different instruments! Not even built into the attitude gyro! Wow. The second was my ATP check ride in a very old Beech Travel Air twin in 1998. To this day the only time I've ever even sat in a light civil twin. First, my two hours in that 172 meant nothing as everything was so different. Second, turns out it can't fly on one engine... What? My third, this is quite funny, was as a CFII giving a lesson about two years ago! Again, despite my other two forays and about a DOZEN military and commercial instrument capable plane types, NOTHING was the same. Isn't there any real standardization out there? The instrument part of flying, pitch power and attitude are quite similar, but the stuff that gives you situational awareness horizontally and vertically are not. Not even close. In the last two years I've been flying some trips with a bud who's company owns a couple citations and rents one. Again, everything is SO different between the planes. Trust me, you've gutted through the worst of it. When you get a paying job with decent equipment, your life will get better. Can't imagine anything less fun than manipulating the controls of an underpowered marginal flying 172 under the hood on a hot summer bumpy day. When you get decent aerodynamics and some power, it is a lot more fun, useful and in my opinion, safe. Light civil equipment teaches habits and the ability to formulate a scan pattern. Also, and probably the most relevant aspect, is you'll be able to maintain some real proficiency. After five years of dabbling in light civil aviation, I'm finally to the point where I'm flying weekly as I have access to a number of planes, doing some instructing, BFRs, etc. for the first time I feel really proficient. It's a nice feeling, even better than the proficiency of being a student. Congratulations! Let us know how the commercial is going! Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460609#460609 ________________________________________________________________________________
Date: Sep 20, 2016
Oscar, You have a great way of describing things. I, as well, am a MEII and have co nsiderable experience behind the panel in instrument conditions. But, I agre e with you that flying my Piet (Abe's Babe II) ( my wife is Abe's Babe I) ju st to clarify, is absolutely the most fun and full of satisfaction I've ever had in an airplane. It redefines the flying experience. I have a radio in m y airplane but rarely turn it on. Thanks for the reminder of what and why we fly our beloved Piets. I do have a question about you last post. Please clarify how Steve flew with you in your Scout? Surely he didn't share the cockpit with you=F0=9F=98=89 As always, thanks for your input. I enjoy your posts. Jack N144JF Model A Wire wheels Sent from my iPad > On Sep 20, 2016, at 12:55 AM, taildrags wrote: > > > I'm responding to this OT post with more OT material in the context of sev eral things: (1) Steve is one of the few individuals with the nerve to have gone up with me in Scout, (2) Steve is one of the few individuals who came o ut to help me disassemble and help load Scout into the big yellow Penske tru ck for the 2100 mile journey from Texas to Oregon, (3) all of my instrument t ime has been at the same time extremely enjoyable and extremely challenging, and (4) my last flight review was in a C172 with the Garmin G1000 full glas s panel and I was so impressed with it that my eyeballs nearly fell out. > > Moving right along, I don't care to talk about items (1), (2) or (4) other than to again tip my hat to Steve for always being ready to lend a hand and to tip my already-tipped hat to anyone who can learn the dials and buttons o n the G1000 so as to use even 1/10th of its capabilities. If not for the fa ct that the G1000 panel costs about as much as four or five nice Air Campers , it would be fun to keep writing about it but that's not my world anymore, I 'm finally conceding. > > So now to comment on item (3). Every moment that I've spent under the hoo d or in 'actual' has been some of the most enjoyable and rewarding time that I've ever spent in airplanes, but it was about as different a flying experi ence from an open-cockpit Air Camper as you can imagine. I am an engineer w ith a completely logical outlook and mindset and I completely 'get' instrume nt flying. I can visualize everything about instrument flying in my head, a nd I can almost always translate that to the instrument actions as I manipul ate the controls, but it's a completely different flying experience, period. I've flown jet and prop sims and I've flown real single and twin hardware, and I always love the challenge. I envy those who have the rating and wish I had gotten mine too, but now my flying is all about stick and rudder and j ust the sensations of flight and the airplane. Nothing much on the instrume nt panel is of interest to me anymore if it does nothing to keep the airplan e ! > in the air or help me keep it so. Every now and then I have a weak moment when I open the latest AOPA Pilot magazine (I get the Turbine Edition!) and see the super cool panels and instruments, but then it passes and I remembe r that I much prefer the smell of too-rich Continental exhaust to looking at a glass panel. > > Sometimes I regret not going for my instrument. As Marlon Brando said in t he classic movie "On The Waterfront": "You don't understand. I coulda had cl ass. I coulda been a contender. I coulda been somebody, instead of a bum, wh ich is what I am, let's face it." > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power, 72x36 Culver prop > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=460606#460606 > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Sep 20, 2016
Jack, "Scout" is Oscar's name for his Pietenpol Air Camper, not the name of his aircraft model. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460612#460612 ________________________________________________________________________________
Date: Sep 20, 2016
Jack, Oscar and I are quite comfortable with each other. Scout is the name of Oscars AirCamper! two holes. (we ain't that comfortable with each other! ) Bleu Skies, Steve D On Tue, Sep 20, 2016 at 9:07 AM, Jack wrote: > Oscar, > You have a great way of describing things. I, as well, am a MEII and have > considerable experience behind the panel in instrument conditions. But, I > agree with you that flying my Piet (Abe's Babe II) ( my wife is Abe's Bab e > I) just to clarify, is absolutely the most fun and full of satisfaction > I've ever had in an airplane. It redefines the flying experience. I have a > radio in my airplane but rarely turn it on. Thanks for the reminder of wh at > and why we fly our beloved Piets. > I do have a question about you last post. Please clarify how Steve flew > with you in your Scout? Surely he didn't share the cockpit with you=F0=9F =98=89 > As always, thanks for your input. I enjoy your posts. > Jack > N144JF > Model A > Wire wheels > > Sent from my iPad > > On Sep 20, 2016, at 12:55 AM, taildrags wrote: > > > I'm responding to this OT post with more OT material in the context of > several things: (1) Steve is one of the few individuals with the nerve t o > have gone up with me in Scout, (2) Steve is one of the few individuals wh o > came out to help me disassemble and help load Scout into the big yellow > Penske truck for the 2100 mile journey from Texas to Oregon, (3) all of m y > instrument time has been at the same time extremely enjoyable and extreme ly > challenging, and (4) my last flight review was in a C172 with the Garmin > G1000 full glass panel and I was so impressed with it that my eyeballs > nearly fell out. > > Moving right along, I don't care to talk about items (1), (2) or (4) othe r > than to again tip my hat to Steve for always being ready to lend a hand a nd > to tip my already-tipped hat to anyone who can learn the dials and button s > on the G1000 so as to use even 1/10th of its capabilities. If not for th e > fact that the G1000 panel costs about as much as four or five nice Air > Campers, it would be fun to keep writing about it but that's not my world > anymore, I'm finally conceding. > > So now to comment on item (3). Every moment that I've spent under the > hood or in 'actual' has been some of the most enjoyable and rewarding tim e > that I've ever spent in airplanes, but it was about as different a flying > experience from an open-cockpit Air Camper as you can imagine. I am an > engineer with a completely logical outlook and mindset and I completely > 'get' instrument flying. I can visualize everything about instrument > flying in my head, and I can almost always translate that to the instrume nt > actions as I manipulate the controls, but it's a completely different > flying experience, period. I've flown jet and prop sims and I've flown > real single and twin hardware, and I always love the challenge. I envy > those who have the rating and wish I had gotten mine too, but now my flyi ng > is all about stick and rudder and just the sensations of flight and the > airplane. Nothing much on the instrument panel is of interest to me > anymore if it does nothing to keep the airplane ! > in the air or help me keep it so. Every now and then I have a weak momen t > when I open the latest AOPA Pilot magazine (I get the Turbine Edition!) a nd > see the super cool panels and instruments, but then it passes and I
August 01, 2016 - September 20, 2016
Pietenpol-Archive.digest.vol-pk
