RV-Archive.digest.vol-ba
January 25, 1996 - February 02, 1996
BATTERY: GIL 25Ah
EXHAUST: Alen Tolle SS
ELEVATOR TRIM: Electric - Servo in fuselage. Custom cable required avail from
Spruce & Specialty.
FLAPS: Manual, four 10 degree knotches
BRAKES: Dual TIRE PRESSURE: 35psi
PANEL: KA-134 Audio Panel, KY-97A Comm, KX-125 Nav/Comm, NAV-122
LOC/GS/MARKER, IIMorrow Flybuddy GSP, AT-150 Transponder, IIMorrow Encoder,
KR-86 ADF with KA-42B Ant., Centry I Auto Pilot (doubles as Turn & Bank),
Shadin Miniflo-L Fuel flow meter (GPS interface), Electronics International
Tach, Utlimate Scanner, Oil Pressure/Temp, Voltage/Current gages, SP-400
Intercomm, AI, Air Speed, Rate of Climb/Descent, Panel mounted clock/timer,
Pito Heat. All gauges lighed by internal amps or Whalen post lights. Map
light overhead with knee area lighting .
LIGHTING: Bob Olds Kit both wings. Lights driven by two 40 ADC relays on
center off switch. Taxi @90Watts, Landing @
120Watts. Bulbs available through J.C. Whitney @ $12
each
PAINT: Dupont Chroma One, Varaprime base. Colors: 1987 Ford Smoke White
(Dove Grey), Halopino Red, Conn Edison Blue
INTERIOR: Alexander Drop in
INSURANCE: AUI
OTHER (MISC): Two Piece Wheel Pants
PROBLEMS:
EXHAUST SYSTEM: Welded Tolle exahust system three times: Always broke on #4
cylinder flange. Finally inserted wedges from flange down pipe to releave the
stress in that area. No problems since.
PROP: Changed from Warake prop with dynamic balancer to Sensinich prop and
gained 10 MPH. (Tested same day under same conditions). Warnake prop still
didn't idle low enough.
WHEEL PANTS: Two piece wheel pants had to be re-trimmed when changing over
from McCreary tires to Goodyear tires.
TIRE WEAR: Getting about 150 Hrs out of the tires, but ONLY if brakes are
used sparingly on landings. Find that tires MUST be turned around at 60-70
Hrs to acheive even wear. Wear ALWAYS accurs on OUTSIDE corners.
RADIOS: Still have intermittent problems with NAV-122. No other unit exists
for replacement into 3 1/8" hole that has LOC, GS, MARKERS. Narco
upgrade/rework will cost big bucks. Recommend that new builders increase the
area of the instrument panel by lowering it 2-3", if they want space for more
goodies.
FRONT STRUT: Continue to have problems with trailing edge of stiffener
cracking. Used butt joint method. Plan to re-do with tape wrapping method.
PERFORMANCE DATA:
EMPTY WEIGHT: 1025 lbs
GROSS WEIGHT: 1650 lbs
MAX CRUISE: 195 Mph @ 8000', full trottle.
ECONOMY CRUSE: 165 Mph, 8 Gph
Subject: | 6A tilt canopy / front fuse skin |
I've got a small problem which I'd like an answer to before I start cutting
metal and maybe make the small problem into a big one.
I'm working on the front forward fuselage skin and the front canopy skin on a
6A tilt-up canopy.
The problem is that my sub-panel is either not exactly perpendicular to the
longerons or is slightly warped as it is mounted. Now, when fitting the
forward skin, the plans say to line it up on the subpanel 3/16" forward of
the subpanel's web. Then the front canopy skin butts up to the back of the
that and lays on the top of that 3/16" of the sub-panel flange that was left
uncovered.
My question is how important is it that, that 3/16" spacing on top of the
sub-panel remain constant. As mine is now, if I give 3/16" at the top center
of the subpanel, then at the sides I have only 1/16" of overhang space for
the butt joint of the canopy. However, if I line up the skin to get 3/16"
overhang at the sides, then the top center is almost off the flange,
certainly not enough to set in a line of rivets.
Andy Gold
Where?
> but heck, $200 will buy 200+ gallons
> of avgas.
> -- Ed Bundy
Subject: | Re: Airplane data RV-4 N47RG |
>> In the spirit of Mr. Skinner's idea for data on flying RV's here's
>mine.
>-----snip----
>> Name: Rusty Gossard Cincinnati, Ohio, Based LUK, Work # 513-621-9462
>> E-mail rust47rg(at)one.net
>----snip----
>> Installed capacitive type fuel level senders. I don't like them....the're
>> hard to set and require resetting.
>Rusty, I've ordered Vision Microsystems fuel level system but have
>not installed it yet. Who's did you install?
Westach..... I've found the best guage to be a stopwatch. Considering the
dihedral of the RV wing and the bay layout of the tanks it's hard to get a
very accurate fuel level (IMHO). The E.I. system looks nice with the fuel
flow readout but it's large dollars. I havn't heard anything on the vision
system.
Regards:
Rusty Gossard
N47RG RV4 Flying
From: | "Mike & Shirley Hiscock" <shiscock(at)fox.nstn.ca> |
Subject: | Re: How do you make alodine work |
Date: Wed, 24 Jan 1996 17:37:25 -0800
Subject: Re: RV-List: RV List: How do you make alodine work
>Bob Busick asked about alodyning large parts.
>As far as uneven/different coloring on the large pieces: This happens
>to me too, but after trying several different ways to alleviate it I
Just a little info that my father gave me ( he's quality assurance with a
local airline, and has talked to the sheet metal guys at length).
They normally clean their parts with Alumiprep, then while they are still
wet apply the alodine. They often have an alodine bath and just leave the
parts in there for a while. I've tried the same principle, I pour alodine
into a plastic wash basin then continually wet the pieces that are too big
to soak. After I'm finished I run the alodine through a coffee filter and
it's ready to use again.
PS Thanks to the builder who posted the idea of putting primer in the
frige to keep it longer. Although here in Canada, I just leave it outside
but at least I don't have to make up a new batch for a couple of little
pieces.
mike hiscock
From: | mgamble(at)chiba.netxn.com (Michael Gamble) |
Hi all:
I have just been monitoring this list for a couple of months. I havent'
bought a kit yet, shoot don't even fly yet! But I have always had a big
interest in Aviation. So I was reading along and saw someone make s comment
about someone in Bakersfield. Is there someone building a RV who lives in
Bakersfield? If so I would love to have a look? Maybe even give you a had
with some things that require an extra hand. Thanks!
Mick
|| Michael C. Gamble Fax: (805) 328-3860 ||
|| Happy Troll Computing Phone: (805) 328-3840 ||
|| 5329 Office Center Court Email: mgamble(at)chiba.netxn.com ||
|| Suite 200 ||
|| Bakersfield, CA 93309 ||
Subject: | Re: 6A tilt canopy / front fuse skin |
>6A tilt-up canopy.
>uncovered.
>Andy Gold
Andy,
.... I had a similar effect, and your subpanel is probably mounted
as per the plans. In this case, the instructions are _wrong_ when they say
that a perpendicular subpanel (F-668) will enable the front decking to wrap
evenly around. This would be the case if there was NO taper in the forward
fuselage ... but there is taper, and the effect is exactly as you describe.
I got the exact same dimensional errors you mention ... when there is 3/16
overlap at the center, there is only 1/16 overlap at the edges.
I chose to leave it this way, but did slightly "push" parts of the
F-668 aft as I drilled the skin to give a little more canopy skin overlap
on the radiused portion of the subpanel.
If I repeated that work, I think I would actually mount the
longeron edges of the F-668 1/8 inch aft of "true" and give a little more
overlap at the ends of the canopy skin. In effect, this would bow the
outer edges of the subpanel away from the firewall. In my case, the
subpanel would have actually fitted better this way. The two F-668 pieces
were the most warped and twisted parts of my whole kit.
However, if you look _really_ closely at the pictures in the
instructions, I think you can see the prototype (with a different canopy
frame though) was built with a reduced overlap at the edges. Unfortunately
there are no close-up photos of this area with the production canopy frame.
I did find that quite large shims were needed here at the edges (
more than 0.060 ) when the canopy skin was installed on the frame, so the
canopy skin can be "adjusted" in height. The one good thing is that I
believe the gas strut kit will "push" the canopy forward and make it mate
tightly against the subpanel, even with 1/16 overlap at the ends
...... can one of the completed RV6 tip-up owners verify this??
...... what can be added to the Frank Justice instructions to help
other builders??
..... good luck ... Gil Alexander
gil(at)rassp.hac.com
RV6A, #20701 .. completed canopy frame .. fiddling with plexiglas
Subject: | Re: Engines Weights |
> >Would an RV-6 with CS prop and solo be (a) hugely different, (b) noticably
> >different but still quite nice for aeros, or (c) only very slightly
> >different? This may be an academic question, because I find your arguments
> >in favour of fixed pitch props convincing.
I don't have extensive experience, but I did get a good chance to
compare the two when I flew to Sun-N-Fun with Van's crew last year, and
I'd have to say it's between (a) and (b). I flew from Oregon to Florida
with Bill Benedict in the Red factory demonstrator RV-6T -- 180hp/cs
prop I flew back with Andy Hanna in the Yellow RV-6B 160/fixed pitch
metal prop. (Bear in mind that this is NOT solo most of it was dual with
the baggage compartment stuffed! -- I can't speak to solo/no baggage.)
Granted the 180 vs 160 was part of the difference. But in general I was
really impressed with the added versatility the CS prop afforded. We
encountered similar scenarios both on the way out and back in terms of
getting up through a relatively small hole, and also back down. Not
only did the CS prop get off the ground a WHOLE lot quicker (especially
in high density altitude situations), but climbing up through a hole in
the clouds was a lot easier -- much better climb performance and also
cooler temps. In a similar situation with the fixed pitch prop the CHTs
were getting really high and we had to baby it up there to keep it cool
enough. And getting DOWN -- again in both planes at one point we found
ourselves looking for a hole -- ANY hole. And in both situations we
found a SMALL one. Getting down through it with the CS prop was just a
matter of pointing the nose down -- the prop flattens out and acts like
a speed brake. With the fixed pitch we couldn't do that and ended up
having to set up as if for landing, with the "touch down point" being
the edge of the hole. Then, flaps down, throttled back, we sunk through
it. Same thing goes for slowing down in the pattern -- much easier
with the CS prop.
Another example would by my buddy Don Wentz. He has a 180/fixed pitch
wood prop and never seems to be satisfied. He's had it re-pitched once
(twice?) and just never seems to be quite happy with the performance he
gets out of it, but now that he's got it on there he's reluctant to
bite the bullet and buy a CS. This isn't to say that fixed pitch props
are bad, but just to reiterate what someone else mentioned, which is that
it can be difficult to get just the right combination.
Can you guess which one _I'm_ going to use? :-)
Randall Henderson
RV-6
Subject: | Re: re: piping air in shop... |
> The workshop will be about 9' x 17'. Is that big enough? The extra bedroom
> will be storing finished components . When final assy. comes along I will
> knock down the workshop and park on the street till completion.
I started with a 12 x 18 single car garage and that was pretty cramped,
but worked for my tail. Once I got to the wings I got sick of no space
and built a temporary extension onto the front -- 8x10. Then I got sick
of fogging up my whole garage every time I primed, so I built another
12x12 extension off the back as a paint room. Now I'm pretty
comfortable.
I'm not saying you CAN'T build in that small of a space, I know people
have managed it. But I found it really slowed me down having to keep
rearranging things so I could get around. I hated to take the time and
money to build these extra temporary structures but now that I've done
it all I'm really glad I did. My wings are stored under plastic in the
"paint room" which has a downdraft fan/filter arrangement and wire
screen table for priming parts. I also keep my compressor in there
cause it's so loud. My tail parts are stored in various places in the
house. And I STILL wouldn't mind having more space (that fuselage jig
takes up a lot!)
Just more "real world" data -- food for thought.
Hint: they make some pretty inexpensive car covers these days....
Randall Henderson
RV-6
Subject: | Re: Aircraft Data |
You wrote:
> This is a pass at outlining my aircraft data. Hope it helps......
>Fred Stucklen RV-6A N925RV
(snip)
Fred,
I'm close to the elevator/trim tab construction, can you elaborate on
your sevo location and custom cable? Also, what was your reason for
manual versus electric flaps?
Ed Cole RV6 24430 Empennage
ecole(at)ix.netcom.com
From: | "Richard Chandler" <mauser(at)Claris.COM> |
Subject: | Re: waiting on the -8 |
> IMHO, there is a cure for this waiting kitted by that fella in
> Bakersfield... Check six!
I just hope that news of the -8 doesn't do to Vans what it did to Osborne.
"Wait a minute, you expect us innocent children to climb up dangerous
scaffolding and paint naked people all over a church? We'll do it!!"
-- Yakko Warner, Animaniacs
"Yeah, I've got ADD, you wanna make something of.... oooh, cool. Look!"
From: | csanchez(at)BayNetworks.com (Cheryl Sanchez) |
Subject: | Fixed vs. Constant Speed Prop. |
This is just my two cents worth.
1) I don't really feel comfortalbe with wooden props due to
the occasional failure. Granted, this can be reduced with
frequent maintenance. But here in New England the humidity
often changes a great deal in a short time.
2) I'm dissapointed with the RPM limitations of the Sensenich
metal props. I worry that I will not be able to get full
power with them.
3) A number of years ago I flow several different Decatholons.
One had 180/CS, one had 160/CS and the other had 150/fixed.
I REALLY liked the 180/CS. When I pushed the throttle and
pulled back we went up. Right Now! The others seemed so
much more anemic, especially the 150.
4) I am attacted to the versatility of the constant speed
prop. I figure in cruise at altitude I can save some gas.
So on the -6A that I took over, I will put on a constant
speed prop this spring. I will do this even though the project
came with a wood prop. I am going to do this even though it
means that I will have to remove and sell the current engine
and get another.
Cheryl Sanchez
csanchez(at)world.std.com
From: | Scott Johnson <rvgasj(at)popmail.mcs.net> |
Subject: | Ok RV Inovators, whats the best way to ... |
Whats the best way to ventilate a 20 foot by 20 foot workspace so that the
cloud of primer spray does not get on everything in the workshop. Mounting
an exhaust van in the wall is a start but I am concerned about the primer
being blown out onto my neighbors house. Has anybody made some type of paint
trap so that the overspray exhaust will not fly on something outside ? Also,
since the fine mist is highly explosive, how can you be sure the fan you get
doesn't spark from brushes etc ? (Note: I do have a fresh air system so I am
not concerned about breathing this stuff). Any comments or suggestions would
be greatly appreciated.
Thanks ... Scott Johnson
P.S. I am particularily interested on your ideas on how to trap the paint
from the exhausted workshop air.
Subject: | Re: Nose or Tail drag. |
On Thu, 25 Jan 1996 aol.com!EBundy2620(at)matronics.com wrote:
> Back when I originally started thinking about this project, Avemco quoted me
> something like $200/yr difference in insurance for the 6 vs the 6A. I opted
> for the 6A for handling reasons mainly, but heck, $200 will buy 200+ gallons
> of avgas.
So Ed just where do you get this avgas at that this price. We buy autogas
for our club planes wholesale at $1.05 a gallon. If I can get Avgas
cheaper I would use it.
Bob Busick
RV-6
Subject: | Re: Ok RV Inovators, whats the best way to ... |
Here's what I did:
I cut a hole in the wall near the floor and put a 16" x 20" attic type
louvered vent in it. I also put a similar vent in the opposite wall for
incoming air. Then I got a 16" box fan (plain old free standing
household use, $20 or so) and put it right against the vent near the
floor. Then I put a fiberglass furnace filter against the inside screen
of the fan. The furnace filter traps most of the paint spray, and I
haven't seen any overspray on the outside of my house or anything. I
have primed all my tail, wing and fuselage parts so far, as well as
some other people who've come over to use my setup to do their parts.
I also built a a box into the corner around where the fan is, about 6'
long by 2.5' wide by 30" high, out of scrap plywood, with a 1/4" wire
screen top. I just put the parts on the screen and spray them and
virtually all of the overspray gets sucked down and out through the
vent. I do find I have to change the furnace filter frequently, about
once per quart of paint.
I'm not sure just how much risk there is of explosion due to sparks
from the brushes, etc. I may be being foolish about this, but
statistically there doesn't seem to be much risk of using regular old
fans in this sort of work, based on how many people I know who have
used the same or similar set-up without incident.
Randall Henderson
RV-6
Buy a low pressure high volume spray system....very little overspray and
does a good job.
I have seen two RV's painted with a high volume low pressure gun that didn't
leave any bad overspray on anything in the garage.
Joe Hine
joehine(at)mi.net
506-452-1072 Home
506-452-3495 Work
From: | "JEFFREY A. HALL" <76476.733(at)compuserve.com> |
FAR 61.31(g) States that you must have an endorsement by a qualified CFI to
operate a tailwheel airplane, unless you have logged tailwheel time prior to
April 15, 1991. Interestingly, you are required to be competent in wheel
landings unless the manufacturer recommends against them, but no requirement
regarding threepointers! (Unless that is your definition of a normal or
crosswind TO or L.)
Jeff Hall CFIAI
RV4 wings and stuff
Ft. Collins, Co.
Subject: | Piper PA24 Parts Help Needed |
Sorry for using the list for this message but I didn't know where else to
start. My RV building helper and consultant is rebuilding a Piper
Commanche and has exhausted all the usual parts suppliers including all
listed in Trade A Plane trying to obtain some front baffles and oil cooler
and oilcooler mounts for his project. If anyone can direct me to an
address (e-mail, web site, or a newsgroup) from which we can get help
obtaining these components (we have serial no. and parts nos.) I would
appreciate the help. PLEASE e-mail me direct in order to keep this stuff
off the RV list.
Chet Razer
crazer(at)midwest.net
From: | Steve Mayer <72652.670(at)compuserve.com> |
.be greatly appreciated.
Scott,
About trapping paint... At work, we have a paint booth to exhaust the conformal
coat that we spray on pcb's. we use paper filters that look similar furnace
filters. You might try a furnace filter or something similar.
I've also seen cloth bags in the exhaust of woodworking shops, but I don't know
if that would work for paint. It would probably muffle the explosion, though.
Steve Mayer
From: | "Terence Gannon" <Terence_Gannon(at)msn.com> |
Subject: | Explosion Proof Fans |
I'm now heading into my first priming, and my spray tent is ready to
go...except for one last detail, that is a method of evacuating the fumes. I
guess I'm reluctant to use the garden variety 'Nutone' or some such thing, and
have gone in seach of an "explosion proof" fan...ie. one that uses a sealed
motor with no possibility of a spark, and a low static blade.
The problem is, of course, that these things run at a pretty high capacity,
and are quite pricey...$500 Canadian. I was wondering if anybody has any
ideas as a less expensive source of supply, or something that they've finished
with, and might be willing to part with for a reasonable sum.
What with all the priming discussion, I realize not everybody is interested in
this discussion...feel free to send replies to me directly, if you so choose!
Terry in Calgary
S/N 24414
"Working on Empennage"
PS. You read the title right! Turns out that's what they call these things
in the Alberta oil patch, primarily for the well site applications where's the
possibility of explosive gas...I figure if it's safe for that application, it
might just work for my lil' old spray tent.
From: | Robert Acker <75104.3077(at)compuserve.com> |
Subject: | Re: Building space (was...Piping air in shop...) |
>> I started with a 12 x 18 single car garage and that was pretty cramped... <<
Well, that certainly puts things in perspective. Come to think of it...I once
built a 3.5 meter r/c sailplane on a 8x10 work surface, and that lacked room at
one point or another. I'll have to re-evaluate the situation. Thanks a lot
>> Hint: they make some pretty inexpensive car covers these days.... <<
Heck, that's not the problem. The truck can stay outside (it gets 100+
miles/day anyway, so the paint will still be shining when it dies)...its having
to find a parking spot on the street and then *walking* to the front door of my
first house that bugs me....reminds me of all this time in apartments !
Rob.
>> Is there someone building a RV who lives in Bakersfield? <<
There's more RV's in Bakersfield than cars, literally.
Seriously, I drove through and visited once. I can't remember the exact name of
the airfield, but I think its M(something) Field, south part of the city and
east of the 5 if I remember correctly. Look for the largest hanger...they're
all in there.
Enjoy, Rob.
From: | kightdm(at)harvey.carol.net (danny kight) |
Subject: | Re: Elevator Trim |
>I've recently started on the left elevator, and am looking for advice as to a
>good way to cut out the trim tab - tools to use, sequence, etc. How did you
>do it??
>Thanks in advance.
>Dick Flunker
>RV-6A, Wing on order (RFLUNKER(at)AOL.COM)
Dick,
I recently finished the left elevator/trim tab on my -6, and this is what I
can recommend:
First of all, don't cut out the trim tab until after you rivet the
stiffeners on. After the trim is cut out, the skin gets very flimsy and
harder to handle.
I used offset aviation tinsnips to cut the tab out and got good results. A
die grinder with a cutoff blade should also work well, but based on my
experience trimming fiberglass, would be a little harder to get a precise
cut unless you have a very steady hand. BE SURE to leave material for the
fold-over tabs on the elevator.
Take Van's advice in the plans, and make a posterboard (from Wal-Mart,
Eckerds, etc.) template of the trim tab. Cut the little ears, fold it, and
tape it together to make sure it fits OK. Repeat this step as needed to get
it right!
Unfold the template, lay it over the aluminum, draw around the edges with
your trusty Sharpie pen, then cut it out.
Use the elevator jig V-blocks/wedge pieces to hold the end of the trim tab
and elevator so you can bend the tabs down. There is a picture of this in
the instructions and it works well. Use a block of wood or plastic mallet
to fold/tap the tabs over.
Don't forget to add the reinforcement piece around the corner of the trim
tab where the control horn mounts. This is not in my plans (6 months old)
but is detailed in the RVator a couple of issues back.
If you are using the manual trim cable (like me) don't cut the hole in the
elevator skin, or rivet the skin to the skeleton until you have the trim
cable in hand. Being able to trim and fit everything before riveting is a
great help. If I had followed the dimensions on the plans I would have cut
the hole in the wrong place!
Hope this helps,
Danny Kight kightdm(at)carol.net
Putting the (ugh) fiberglass tips on the empennage.
> of avgas.
> -- Ed Bundy
Maybe you meant auto fuel. 100LL goes for $2.00/gal. at my home base of
Anderson, SC. However, the fine folks who run the FBO in Washington, GA
(40 miles south of me) sell it for $1.52/gal!!!!! My Sonerai only holds 10
gallons, but it is still worth the trip to refuel. It will be even more
worthwhile when I get my -6 flying.
Putting the (ugh) fiberglass on the empennage now. I'm showing unusual
discipline by finishing the empennage completely (except for final paint)
before I hang that beautiful Phlogiston spar on the jig.
Thought for the day: Time flies like an arrow, but fruit flies like a banana.
From: | Randy Crothers <rcrothers(at)rcrothers.seanet.com> |
Subject: | Partial compl. kits |
As I prepare to start the big project (RV-6) I keep hearing of mostly
completed (90% etc..) tail kits that are for sale for not much more than the
price of the parts. On the plus side I see this as a way to get one heck of
a jump start on the project and maybe save a few dollars. On the other side
I realize that I may not be a very good judge of the quality of work that
has been completed (although I think I could get some good help). Also,
there is the question of the 51% rule etc.. Is it important to begin your
learning curve on the empenage? I would sure appreciate hearing from some of
you builders that may have started out this way and how is has worked out
for you. I wonder if there may be some important issues I havn't considered.
Thanks in advance.
Subject: | FAA and tailwheel endorsement |
All
As a flight instructor I checked with FAA headquarters about a tailwheel
endorsements needed for a experimental, below is Rick Cremer replay to my
post on Compuserve, Rick is with FAA HDQ. and is very active in the FAA
section of the AVSIG forum on Compuserve.
>1/23/96
Jerry Springer ask
Rick
Am I reading FAR 61.31[h](3) right when it says that if we are flying a
experimental (read homebuilt) that we do not need a tailwheel endorsement to
fly a tailwheel homebuilt airplane
Jerry Springer<
>>1/24/96
Rick Cremer replied
That's the way I read it although we've never (to my knowledge) said that in
a written document anywhere including our inspector's handbook or legal
interpretation. Also, I looked at Amendment 61-90 which is the amendment that
affected 61.31(h) and we don't explain it in the preamble either. So, in the
absence of any other guidance I would say that you are reading the regulation
correctly. At least that's my opinion.
Best Regards
Rick Cremer
FAA HDQ <<
Subject: | Re: old RV3 kit (aka replacement skin..) |
You wrote:
> Finn, I see you have an old RV-3 kit.
> I hope you are aware of the mods to beef up the rear spar attach
> point on the RV3's. While you have the skin off this would be
> the time to make that change.
Thanks. Yes I've glanced at that. I believe one of the mod methods can
be done without removing the skins.
Finn
>This is good, real world, news...thanks! I have never even held a rivet gun
>or
>know how loud they are...have only heard them on the Orndorf (sp?) videos.
If you're worried about noise you probably don't want to get an oilless
compressor. They practically wake the dead.
>manner...letsee...how do I describe this...a bunch of lollipops off a main
>street, each having eight houses around it...geezzzz...it's a California
>too-many-people kinda thing). So, my neighbors can not only see whats in
the
>garage everytime I open it but hear it as well.
>pull my truck in, hide the project, and deaden the sound all at once.
Where 'bouts in CA do you live? My wife and I are recent escapee's. We
lived in the San Fernando valley in So. Cal. Got all my flight training at
Van Nuys. Boy, when you learn to fly there, everywhere else is a breeze!
3.5 years ago we moved to Idaho (a little town called Eagle, about 20nm
North of Boise. We absolutely love it here. We live on 5 acres, and the
nearest house is 200 yds away. I don't have to worry too much about noise...
will
It'll be okay for the wings and tail. I built my wings and tail in a spare
bedroom (very understanding wife) with 8X12 working space, not including
tables, etc. It was VERY tight. I think that would be the absolute minimum.
I don't know if you can build your fuse there. The fuse takes up 4X15 during
construction, and you need room to get around it and work on it. As long as
you can park on the street you may need to do that when you start
construction on the fuse. Believe me, it'll be worth it. I built a 2+ car
garage to build my fuse, and store parts, tools, etc. Both cars are out in
the snow until the airplane's done...
Which one are you going to build?
-- Ed Bundy
Subject: | Re: Partial compl. kits |
Randy,
when you look at a partial kit be careful of the workman ship and care to
detail the tail kit is 50% control surfaces.Also there is a lot of learning
that goes on with tail kit, remember that the most expensive part of the tail
kit is only $30 if you mess up, easy to fix , you don't need to try to fix a
mess up on the wing. If you stick to it you can complete a tail kit a 3 or 4
months. Partial completed kits can speed things up and can also slow things
down you have to deside what it is worth...George & Becki Orndorff
Scott,
Here's some ideas, first on your fans place on both sides filters like the
ones used on furnaces, next use a high volume low presure spray gun (harbor
frieght has one for $89 that works great), you can also vent the air from
the fans into water .I think you will find that the HVLP gun will do the most
to help you out .Keep up the good work..
Subject: | Re: FAA and tailwheel endorsement |
writes:
>>1/23/96
>Jerry Springer ask
>Rick
>Thanks
>Jerry Springer<
>>>1/24/96
>Rick Cremer replied
that
regulation
>Best Regards
>Rick Cremer
>FAA HDQ <<
Dear Jerry and Rick,
I just read 61.31 and this is MY interpretation. Read PARAGRAPH [(h)] the
part which reads "Exception. This section does not require a class rating
for.......etc..". "In addition, the rating limitations of this section do
not apply to:...(3) The holder of a pilot cert, when operating an aircraft
under the authority of an experimental or provisional type certificate."
The "exception" is only referring to the requirement for the pilot to have
a type certificate. They are saying that when flying an experimental or
provisional aircraft, the pilot is not required to have a type certificate
for that aircraft, regardless of whether that kind of aircraft (size, weight,
seats, etc.) would normally require the pilot to have a type rating.
It has nothing to do with the PARAGRAPH [(g)] Tailwheel Airplanes, which
stands alone and refers to "no person", which in government lingo means
"everyone must".
I am a practicing flight instructor and have been interpreting it this way
since it first came about. Actually, it's quite clear and requires no
interpretation if you can digest the whole section 61.31. And you don't get
indigestion!
Jim Stugart
DerFlieger(at)aol.com
>6A tilt-up canopy.
>uncovered.
>Andy Gold
Andy,I had a similar thing occur on my 6-tilt up. After positionaing the
skin, I didn't feel like Van gave me quite enough material so I ordered a
sheet from Airparts. I made my own forward skin and canopy skin and also
canopy sides (because I wanted the canopy sides to overlap the fuselage
sides and wanted them to line up with the bottom edge of the forward top
skin and the skin where the rear glass is at the roll bar location.) My
firewall is straight up, not bent forward. I would have had to shave some
aluminum off of the sides so there was a uniform gap of 3/16 and wih the
original factory skin, just didn't feel like there was any room at all for
any shifting. I was afraid that the factory piece would end up like so many
elevator skins, (not enough material to go clear to the edge, IOW, not a
square corner.)hence the new skin.
I'm building another tip up and am thinking about the following idea and
would appreciate other builders' opinions on this: If you build according
to plans, you will have notches in the flange of the sub-panel that will
leak air if not sealed somehow. This area where the front of the canopy
skin mates will also rub paint off. What would you think about riveting a
strip of maybe .020" onto the flange of the subpanel to seal gaps and to
maybe provide more of a bearing area for the canopy front skin. Probably
wouldn't hold paint much better but would perhaps give a smoother bearing
surface for the canopy front skin than the flange of the sub-panel with all
it's small bumps and bulges. Bob Skinner RV-6
>good way to cut out the trim tab - >tools to use, sequence, etc. How did you
>do it?? > > >Thanks in advance. > >Dick Flunker >RV-6A, >Wing on order
(RFLUNKERck,
Dick,
Rather than bend the edges of the trim tab over and try to get them to line up
perfectly, I made my own small end ribs for the trim tab from scrap and riveted
them in. I did have to make this part twice tho because it warped after
riveting the skin to the spar - watch out for this.
bruce stobbe
fuse skel
>FROM: Randy Crothers, INTERNET:rcrothers(at)rcrothers.seanet.com
>As I prepare to start the big project (RV-6) I keep hearing of mostly completed
(90% etc..) tail kits that are >for sale for not much more than the price of the
Randy,
I think that building the tail section is an excellent introduction to the
techniques and methods you will need to develop as you progress towards the more
complicated assemblies. I would not have wanted to start the wings without the
experiences and insight I gained from building the emmpenage.
bruce stobbe
fuse skeleton
Subject: | Re: RV-6 longerons |
Van's is correct...make it fit. It is normal (as per plans) for the longeron
to *twist* in this forward location. If you look at the plans, you will see
that the weldments are cocked to the sides. Remember, this is the
transistion spot where the fuselage goes from being slab-sided to curved.
Gary
Great to see you guys waiting! I'll fly my 4 and wait for you to get the
bugs out of the 8 before I build one.
Dan Boudro
RV-4 N9167Z
>a
>>6A tilt-up canopy.
left
>>uncovered.
center
>>Andy Gold
>Andy,
>other builders??
From what you have discribed I think that you are both correct on your
assesments. I not only had to ship the outside edges, but also had the same
overlaping problem. The one thing I don't agree with is the concept of the
gas struts pushing the conopy skin forward. In fact, as the canopy initially
lifts the conopy skin center section actually has to arch forward. This
requires that you leave a slight gap between the canopy skin and the fuselage
skin. This fact IN NOT clear in the plans. Before you drill the forward skin
into place, be sure that you have the canopy completed, mounted and
completely functional. I found that by substituting a temporary skin in place
of the F-671 skin helped to properly fit the canopy.
Another area that isn't covered in the plans (at least my copy) is the
fact that the canopy "V" strip seal drip edge MUST be installed such that it
is waterproof. I used ProSeal on this join, to seal it as well as fill in any
holes dues to bulkhead forming. If you don't seal it, it will leak,
especially when you OPEN the canopy when it's wet.
Hope this helps...
wstucklen(at)aol.com
Subject: | Re: Elevator trim cable |
>Fred,
>Thanks,
Sure! I mounted the servo on a bracket on the F-614 aft deck (Dwg #34,
upper left corner) on the starbord side. The bracket positions the MAC servo
such that it's push/pull actuator points at the end of a custom cable that
comes throught the forward HS spare (as shown in section D-D in lower right
corner). I also constructed a bracket that mounts to the rear of this spar.
(The feed trhoug hole in the spar web did get moved inboard a bit.) This
bracket is used to terminate the end of the custom cable.
The custom cable has terminations that are the same as the end of the
manual trim cable provided by Van's. It can be purchased through Spruce &
specialty.(Part Number A-1550, 28 7/8" long inside cable, with a 2" travel.)
Be sure NOT to specify that it as an elevator trim cable as Spruce's
subcontractor (ACS Products Co.) has a legal problem with this concept.
Better to specify it just as a push-pull cable. Cost of the cable in early
1993 was $48.00.
I did make a print of the cable so that there would be no mixups in it's
construction. I'll be glad to send it to you if you would like. Just send me
a SASE....
Hope this helps....
Wstucklen(at)aol.com
148 winkler Rd.
E. Windsor, Ct. 06088
END OF COMMANDS
END OF COMMANDS
Subject: | Re: Explosion Proof Fans |
>fumes. I guess I'm reluctant to use the garden variety 'Nutone' or
>some such thing, and have gone in seach of an "explosion proof"
>fan...ie. one that uses a sealed motor with no possibility of a
If you have a "tent" as you say, you can possibly turn everything
around (i.e. have a positive pressure ventilation system). Put a
filter on the exhaust and use a simple fan as discussed in other posts
for the fresh inlet air. One possible problem would be if your tent
were not sealed - the overspray fumes will be forced in every nick and
cranny in the shop, including into your arcing and sparking devices
such as wall switches and the like (don't turn on anything with fumes
present).
I personally would not have a problem using a regular $20 fan as an
exhaust. Since these are alternating current motors there should not
be any sparks (although there is some heat build-up) if they are
operating correctly. I also know quite a few of these have been used
with no big boom yet.
Disclaimer:
HOWEVER, down here in the states we have a bunch of money-hungry,
blood-sucking lawyers, so my official CMA recommendation would be to
build a paint booth in accordance with the National Electrical Code,
Article 516 (or whatever codes and regulations you operate under).
This can probably be done for about the same cost as building an RV-6.
In addition, don't forget your air emissions permit to satisfy the
environmental folk.
Sorry for rambling....back to lurking..................
Mike Grubb
Designing work shop.
Work shop construction this year. RV-? construction starting next
year.
From: | JIM SCHMIDT <JIM.SCHMIDT(at)mail.mei.com> |
Subject: | Introduction -Reply |
Bruce
Are you Don Stobbe of marquette electronics
brother?
I hired Don into Marquette. I am now in
Jupiter, Fl building an RV6.
Subject: | Re: piping air in shop... |
noise...
Yes, if you learn to fly in socal you can fly anywhere...I got my ppl at
Torrance airport. I live in south orange county. You live in a beautiful
place...I've visited Eagle a few times and its on my "move" list when I get
outta' here (gotta finish the degree while my employer is paying for it ).
>> Which one are you going to build? <<
RV-6. Do you know a Andy Hall in Nampa (RV-4)?
Rob.
>Terry in Calgary
>S/N 24414
Terry,
How about setting up the fan to blow into the tent (set up adeflection
system so the air is not blowing directlt at you) This way the fan would
not be exposed to high concentrations of fumes.
Ross Mickey Phone: 541-342-1892
2300 Oakmont Way #205 Fax: 541-342-5492
Eugene, Oregon 97401 email: rmickey(at)ix.netcom.com
Subject: | Re: Pre-built tail |
the
This is what I did and boy did I regret it. Take it
from me, BUILD YOUR OWN! Unless you know exactly what
to look for, you may wing up buying the tail kit
anyway. The tail I bought was useless, although to
the untrained eye it looked fine.
Besides, you learn alot building the tail and it
really is a small portion of the overall effort
required to build the airplane.
Just my opinion,
Mark
* Mark Richardson Software Kinetics Ltd *
* Project Manager 65 Iber Rd. *
* Defence Systems Stittsville, Ont *
* VOX 613-831-0888 K2S 1E7 *
* FAX 613-831-1836 richards(at)sofkin.ca *
* RV-6 20819 '85 Virago 750 *
* EAA# - 367635 DoD# - 1506 *
>Thanks in advance.
I don't believe the 51% rule would be a problem since Vans kits are so far
below this. Your other observations are right on. I would be concerned
about workmanship, but you could get some help with EAA tech Counselors and
local builders. The experience thing is really valid. The Emp requires you
to do most if not all of the proceedures used in he rest of the plane. It
is nice to gain experience on these smaler parts which can be replaced
rather cheaply. Also the Emp portion of Van's manual is the most detailed.
In the rest of the manual you don't get alot of help. Frank Justices manual
helps alot in this area.
<199601260514.VAA01210(at)seanet.com>
I never built an airplane before the RV-6A I'm working on now, but I can
say unequivocally that if this is your first homebuilt you should start by
building the empennage. The learning curve at first is simply too damned
steep to start on the wings; mistakes there can be a lot more costly than
the few empennage parts that you might need to replace due to screwups.
I've only been at it for about six months but I've learned an enormous
amount on the empennage and I'm certain that the empennage is exactly
where I should have learned it.
Good Luck.
Jack Abell
RV-6A Rudder (but not much longer)
I am ready to rivet my fuel tanks together and have a couple of questions.
The ribs have a little bit of oxidation showing on them and I am wondering
what to do since the inside of the tank does not get primed.
1) should I alumi-prep the parts to clean them of oxidation?
2) should I alodine the parts?
3) would both the alumi-prep and alodine procedure help with adhesion(SP??)
of the pro-seal?
I plan on using only Pro-seal in sealing the tanks as I have heard many a
horror story when using Randolf's sloshing sealer. Any thoughts on this
subject would be greatly apreciated . Thanks in advance
Gary Zilik zilik(at)aol.com
RV-6A s/n 22993
**** a "Tip of the Week" is near the end ****
*** Andy's problem cut ***
>>>Andy Gold
>>Andy,
*** my original response cut ***
>>other builders??
I too noticed this, and presently have about an 0.040 gap here.
For this clearance though, the gap only needs to exist in the slightly
'raised' portion of the subpanel that is in between the two hinges. I
think this is an artifact of the change to the "gooseneck" hinges that have
a hinge point different from the original straight hinges. Sort of funny
though, I fitted the canopy for a perfect fit here, and then had to cut
away edges to get the canopy to lift ... but it's easier to add than
subtract (see my last week's mistake!)
> Hope this helps...
Two other points:
1. The 1/2 x 0.025 angle that holds the weatherstrip should be
extended all of the way down to the cockpit rails to be truly effective.
This means that the end of it should stop _behind_ the 4 inch long 3/4 x
1/16 angle that attaches the F-668 to the longerons/cockpit rail. I added
a 0.025 shim behind this 3/4 angle to fill in the gap, and arranged for the
outboard 3/4 angle/subpanel rivet to also be the end rivet on the
weatherstrip 1/2 angle. As per the note above, this 1/2 angle should be
sealed with ProSeal, something Fred reminded me of just in time ... thanks
Fred!
2. I didn't have any angle drilling tool that could drill the D hole
through the canopy hinge holes into the plastic blocks. Long drills just
didn't fit either
... so "Tip of the Week" ...
Your mini angle die grinder makes an excellent angle drill for 1/4
inch drill bits (or letter D - 0.0246 - bits) since they can be held
directly by the 1/4 inch collet. I just used it at 30 psi, and it was as
better than any angle drill attachment .... all for only $30 from Harbor
Freight! ... and it even came with a 1/8 collet for #30 drills.
hope this helps others .... Gil Alexander ... fitting plexiglas
RV6A, #20701
First, I would use a positive pressure system. That is, blow fresh air
INTO the painting area. If the only exit is through your hole in the wall,
that's where the air will flow out. This means you won't have the paint
fumes moving towards your fan, possibly causing interesting results.
Next, I would filter both the air in and air out. Easiest method? How
about a furnace filter. They're *very* cheap and designed for filtering
dust and such. This should keep your fan from blowing dust into your
paint area and your paint from blowing onto your neighbor's car.
Finally, I think I would use a box-like structure for the outgoing air.
Basically, make a hole in the wall. Extend the hole so it's an 18 inch
long "tunnel". Put furnace filters on both ends of the tunnel. This will
give the paint-laden air additional opportunity to settle.
I don't know if any of this is sufficient. But lacking any other real
answers, this is what I would do.
-Joe
Joe Larson jpl(at)showpg.mn.org 612-595-9690(w)
Showpage Software, Inc.
435 Ford Rd, Suite 315
St. Louis Park, Mn 55426 Future RV-6A pilot.
From: | "Christopher Krieg" <christopher_krieg(at)aoce.austin.apple.com> |
Subject: | Polished Alum. under clearcoat? 1 |
>Sounds like a good idea to me! I'd probably try using clear coat from
>Sherman Williams or somewhere (just don't spray the color). I'd clean
>the AL with SW Ultra Clean or similar to get the wax off from the
>polishing process first. Try it on a large sheet of scrap AL and
>see what happens.
Also do a bend test on the AL scrap. Most of the items you listed that were
clear coated were pretty thick, rigged item. AL, being thin, is constantly
bendind and flexing and the coating may begin to crack or chip. This may be
why you don't see many natural AL aircraft clearcoated.
Just something to think about.
Chris Krieg
Building an RV tail is a really good introduction to the skills needed
to build the rest of the airplane.
That being said, I think you can save some money by finding a tail
kit/tools that someone has given up on. These can often be found at 10%
or greater savings. I think it's best if you can find one that's barely
been worked on -- in that case if the work isn't up to par you can just
buy a few new parts and still come out ahead. Also try to get a recent
kit -- the improvements Van has made in the last year will save you
TONS of time over a kit that was manufactured earlier. And I STRONGLY
recommend getting an experienced RV builder to look at any partially
completed kit unless it's not far enough along that you couldn't scrap
what's been done if need be.
And bear in mind that people who have given up early in the project
may not have great building skills....
Randall Henderson
RV-6
App-Message-Id:
>see what happens.
Chris Krieg
From: | "Dave Mumert" <Dave.Mumert(at)cadvision.com> |
> Date: Fri, 26 Jan 96 02:31:00 UT
> From: "Terence Gannon" <msn.com!Terence_Gannon(at)matronics.com>
> To: "RV-LIST"
> Subject: RV-List: Explosion Proof Fans
> Reply-to: rv-list(at)matronics.com
> Terry in Calgary
> S/N 24414
Hi Terry
The agricultural industry also uses explosion proof fans for
ventilating pig barns. Try at the UFA Co-op (United Farmers of
Alberta). They are on 1 Street SW between 42 and 50 Avenue. That is
EAST of McLeod Trail and south of 42 avenue. They have lots of good
stuff usually at good prices. It is a farmers outlet so most city
folks don't know it is there.
These fans are usually not very pretty and will probably move too
much air. They are built using a sealed moter and a metal (Aluminum)
fan with self closing shutters. Princess Auto on 32 Avenue NE may
also have them.
I just bought a DeVilbiss 3/8 air drill at Sears for $39.00. It was
marked down to 49.99 and I got a Scratch-and-Save coupon worh another
20%. The same drill with Sears brand is over $100.
See Ya
Dave
Dave Mumert
mumertd(at)cadvision.com
Date: Fri, 26 Jan 1996 19:16:11 -0800
From: ammeterj(at)ammeterj.seanet.com (John Ammeter)
Subject: Re: RV-List: Partial compl. kits
>Thanks in advance.
I know of a local builder that purchased a partially completed empennage.
It had been built by an A & P and, supposedly, was of superior workmanship.
I felt bad for the purchaser since I had recommended he buy the empennage; I
hadn't seen it but since the builder was an A & P it had to be well built,
right???
When he got it home he first found that the plans weren't there and and then
found that the workmanship was very poor. As a result he lost interest in
completing the RV. He's still going to build, though. A friend of his is
almost finished with a Rebel so he'll soon start on a Rebel.
So, my recommendation is that you ask a local RV builder to check out any
potential empennage kits with you. It's really frustrating to have to
disassemble part of an empennage to repair a faux pas done by someone else;
it's bad enough to fix your own mistakes.
John Ammeter
Seattle WA, USA
RV-6 N16JA
Flying 5 years
It certainly would save time; but not a huge amount. I spent 240 hours on my
emp kit, my friend spent 225. This probably represents about 8%-12% of the
time that a first time builder will spend on the project.
I wrestled with this as well, and in the end bought the kit from Van's. I'm
glad I did. IMO what I learned building (and screwing up on) the tail kit
helped prepare me, at least psychologically, for building the wing spars and
other "critical" parts. There are so many questions that came up about what
is "good/ok/unacceptable" that I'd be uncomfortable using someone else's work
without knowing how conservative they might be. There are lots of things
hidden from view in the tail, and while probably fine, would still worry me a
tad. I tend to be very conservative - your mileage may vary.
I don't feel the emp is any less critical than any other part, but the pieces
tend to be less expensive to replace and I'd rather "practice" on them than
on the wing spar.
-- Ed Bundy
From: | ammeterj(at)ammeterj.seanet.com (John Ammeter) |
Subject: | Re: Majordomo results: Majordomo re |
>Anyone else getting these?
>On Fri, 26 Jan 1996 majordomo(at)matronics.com wrote a lot of these:
>> END OF COMMANDS
Yup, literally hundreds of them. How do we stop them????
John Ammeter
Seattle WA, USA
RV-6 N16JA
Flying 5 years
Yes - looks like hundreds of them!!!
>> END OF COMMANDS
From: | Ronald Vandervort <rvanderv(at)linknet.kitsap.lib.wa.us> |
Subject: | Summary of RV project |
Am just beginning. Am doing an RV-6 and RV-6A simultaniously. Am
retired and live on airpark with 3 other RV builders on the field. I'm
going to have to hurry to catch up to them. They have been at it for two
years. Two of those three will be flying this summer.
As a current builder I would be reluctant to recommend_anyone_buy a
completed empennage kit to start their project for several reasons:
It is by far the cheapest of the subkits and a good way to find if building
the RV is really suited to you without a large expenditure of money. For
this reason and also because of the improvements Vans is constantly making
in the kits and the really reasonable price increases, I would also
recommend you not buy more than the next subkit you need at any one time.
These empennage kits that are for sale are evidence that some "builders" do
find the project is not for them. The question then is why not? Too much
time involved? (Probably not bad; most likely they were very careful and
built it well.) Too difficult? (I don't think I'd want this one holding up
the back of my RV.) Not comfortable with their work? (This one should
probably be sold for scrap aluminum prices.) If I were really going to buy
a finished kit I'd want to know why it was being sold and have someone
knowledgeable in metal aircraft construction and RV's in particular look at it.
Assuming you have not done this kind of work before, you are going to have
to learn metal working skills somewhere. Unless you buy the already built
Phlogiston(?) spars (I'd rather spend the $800 on something else for my RV),
your critical wing spars become the first thing you build! I would not want
to do this. Having already built the empennage though, I felt very
comfortable doing this task.
This is just an ego thing with me, but when my RV is done, I want to say
that I built it,_all of it_. Not that I won't need extra hands along the
way, but I'll have been in charge of the whole thing.
Whatever you decide to do, consider this. You mention starting
the_big_project, and it is a big project. It helps a lot to constantly
think of it as a lot of little projects, each of which when you complete you
can find satisfaction with. I think many of those kits that are for sale
are by builders who are looking at the_big_project. Because I have two
teenage children and a very time intensive job ten months of the year as
well as many honeydo jobs, I started this project with the idea that it
would be a five year project minimally. I can do that because I'm doing it
for the fun of the project as well as to have a great airplane when I'm
finished. Without this mindset, I'm sure I'd be better off looking for a
good used Grumman Yankee of some such thing instead.
These are my opinions only based on my motivation for building. You need to
look at why you want to build, your available time, your resources, etc.,
etc., etc. I'm sure you'll get some different opinions from others on this
list and that's why this is such a great resource to have also!
>Thanks in advance.
i> yes, i'm getting lots of these too !!
>> END OF COMMANDS
I'd like to add something.
Building this airplane is *fun*. I am having the time of my life. The amount
of time you save buy purchasing a completed empennage isn't worth what you
would lose.
I would buy a new one from Van's.
-J
From: | "ALFRED B. WERTZ" <71674.332(at)compuserve.com> |
Hi....I'm an rv6-A.builder.. would like to know more about your group.
regards..... Al.
Subject: | Re: Majordomo...blah, blah, blah |
Would somone please attend to the mailing list so that the 100 plus error
messages that have been dumped into my mailbox the last day or so will be the
last??? This is REALLY annoying.
Everybody loves to get mail... but this is ridiculous.
Jim Campbell
What causes jillons of "majordomo results"? I logged on, went to the"reading
room" and finally shut the thing off??
Just curious
Howard Kidwell
howardrv(at)aol.com
I am almost ready to pro-seal and rivet my tanks together. The ribs as they
came from Van's have a little oxidation on them and since they are not to be
primed I was wondering how to treat them.
1) Should I alumi-prep them to remove the oxidation?
2) Should I Alodine them after alumi-prep?
3) Should I just clean the parts real good and put the tanks together?
Also, due to horror stories, I plan on using the pro-seal only and any
suggestions on the proper way to leak free tanks would be appreciated.
Gary Zilik Riveting tanks
RV-6A s/n 22993
zilik(at)aol.com
Subject: | Re: Summary of RV project |
Ron,
I've heard of people that can't make up their mind but-----. Do you have
room for the -8; maybe you'll want to build it, too.
John Ammeter
Seattle WA, USA
RV-6 N16JA
Flying 5 years
Subject: | Re: Majordomo re |
>END OF COMMANDS
Are these mailings going to continue? 140 yesterday and 180 today.
Stan
From: | dougweil(at)mail.pressenter.com (Doug Weiler) |
Gary:
Since I just completed my tanks with great success, I'll give you my 2 cents
worth. Personally I would just justr scotchbrite pads to clean off the
corrosion and not worry about it. I guess you could aluma-prep and then
alodine, but I'm not totally convinced that alodining tanks is such a great
idea. Some of our South Dakota builder's who are burning ethanol have done
this.
Scotchbrite and or sand (400 grip) all mating parts. Clean with Naptha or
Coleman fuel using "Scott-Free" lint-less paper towels (should be available
at most grocery stores). No finger prints allowed... keep it sterile. Use
rubber gloves with no talc. Mix Proseal 1 Tablespoon to 1/2 teaspoon. Use
lots of it. Seal especially the outer corners of the tanks. Be generous
and you should have good results. Mine were leak free and the whole job was
not near as bad as I thought it would have been.
Good luck
= Doug Weiler, pres. MN Wing Van's AirForce, RV-4 wings in progress
= 347 Krattley Lane
= Hudson, WI 54016
= 715-386-1239
= email: dougweil(at)mail.pressenter.com
Ed,
Read your post (following) and noted you live in Eagle, ID. My folks live in
Eagle (off Beacon Light Rd.) and I live off Glenwood by the river in Boise. I
would love to see your project (since I'm in the neighborhood all the time)!
Please e-mail or call me if you would like to show it off.
Gordon Pratt
GDPratt(at)dmi.net
376-7666
>>or
>the
>will
>-- Ed Bundy
On Fri, 26 Jan 96, "Terence Gannon"
ETC, ETC.
Here's a thought: Try a squirrel-cage blower installed to *Pressurize* the
spray booth and cover the exhaust holes with filters. That way, the motor is
working in clean, filtered air outside the booth.
Gordon Pratt
Lurking
My wife just reminded me that I was insane to be building an airplane I had
never seen. Yes that's right. Wings 75% finished and fuse kit 6 weeks
from delivery and I have yet to see my first 6A other than photos. If
anyone in 6A finds themselves x-country thru Sparta Illinois (SAR) please
stop by for lunch on me.
Fitting Fuse attach angle on 2nd tank and prepping for final tank assembly
and sealing.
Chet Razer
First of all, is the list back on line? Things sure seem to be slow. Guess
everyone is out working on their planes
I've been spending the last few days changing exhaust systems on my RV-6.
I'm replacing the Vetterman 4-pipe mild steel with a Vetterman stainless
cross over system. It's been slow going, non-heated hanger and typical
Nebraska winter.
The stainless cross-over is really a thing of beauty. I'm replacing the
4-pipe, hoping that I can generate more heat in the cabin by having a heat
muff on each pipe (2). I'll be collecting heat off of 4 cylinders now
instead of one cylinder as I was able to on the 4-pipe system.
I bought the 4-pipe steel because I figured the RV-6 with a wood prop
could use a little more weight up front and I already had a lot of money
tied up in exhaust systems. (I had purchased a Tolle cross-over system which
I decided I wouldn't use on my airplane because of all of the trouble with
them.) The 4-pipe mild steel Vetterman was a low cost alternative. Anyway,
I've got the cross-over on and am working on the two heat muffs. Looking
forward to more heat!
The 4-pipe Vetterman system is for sale if anyone is interested. I'd
imagine it would be best for those living where the temps are more moderate.
The pipes are drilled for four exhaust probes and are in good shape. They
have 200 hours on them. These pipes fit the O-320 with the Dynafocal engine
mounts.
Bob Skinner RV-6
Subject: | Re: Exhaust system |
> Nebraska winter.
Bob, I'm replying on the list because others may be interested in my
questions.
1. Are you drawing cabin heat air from the high pressure side of the
baffles (with attendant risk of CO fumes), or from another source?
2. Are you using carby heat? If so, where do you draw the hot air
from?
Peter Bennett
Sydney Australia
RV6 skinning fuselage
From: | "Thomas N. Martin" <103212.65(at)compuserve.com> |
Tom Martin
R.R.#8 St.Thomas,Ontario
N5P-3T3
519-631-1369
MODEL: RV-4
DATE FINISHED: May 25,1995
TOTAL TIME: 82hrs
ENGINE: I0-360 Lycoming
PROP: Warnke 70-74 plus Landoll harmonic balancer
STARTER: Mark Landoll
ALTERNATOR:Landoll
BATTERY: RG concorde
EXHAUST: Vetterman 4 pipe SS
ELEVATOR TRIM: manual
FLAPS: manual
BRAKES: std TIRE PRESSURE: 25-30
PANEL: basic 6 flight inst., terra com, telex intercom, 360apolloGPS, EI
OAT/CHT/EGt, AVspark exhaust sensor(never leave home without it), vans' digital
tach. plus compass and standard oil pressure and temp. all above fits in
standard panel with some room left
LIGHTING:Next year
PAINT:Black, trim not yet applied
Weight: empty 982lbs
INTERIOR:Grey with Lauritsen seats and canopy cover(very nice)
INSURANCE: Avemco
Cruise; 2500 RPM 8000MSL 180 mph true fuel burn 7.5g/hr
at 2000 ft I can redline the airspeed,213, at 2800rpm straight and level
PROBLEMS: I am just painting now and spent a lot of time making little changes
to cowlings and farings during first six months of flight.
Engine failure at 60 hrs do to failure of rebuilt bendix fuel infector. I was
on a test flight and landed safely at airport. No problems wiht plane except
sink rate with out engine is at least double idle sink rate. This is important
as it was greater then I was led to believe from literature.
I was not afraid at the time but it took me a week to "pass" the seat cushion
Subject: | Re: Ice, fuel, primers |
Suggestion on checking the fuel tanks..............
Use the "balloon method"....i.e., seal
all the outlets. you can use al lines
and plastic hoses, and over the filler
holes, DUCT TAPE will usually seal.
Then, perhaps using a valve in line...
blow up a balloon (or condom) to about
8 to 12 inches and let it sit.
Ifn you got no leaks.....balloon should stay
same size, with allowances for baroemetic
pressure.
Good luck, Marvin N63Tx(at)aol.com
Subject: | HS-610 and HS-614 |
Listers -- I spent yesterday cutting and filing the HS-610 and HS-614s for the
horizontal stab. It went well, except I'm wondering about one thing...why is
it that the '614, when complete, has a flange that extends a little past the
the bend line, whereas the '610 is cut straight at the bend line (more or less
anyway). I would have thought one or the other technique would have been good
for both.
Van need not worry, my intention is stick to the plans (EXACTLY), it was more
a question of curiosity.
Back to the shop!
Terry in Calgary
S/N 24414
"Horizontal Stabilizer (AND LOVING IT!)"
snip...
>questions.
>from?
>Regards
>Peter Bennett
>Sydney Australia
Peter:
What gives you the idea that there is a "attendant risk of CO fumes" by taking
air from the high pressure side of the baffle? This is common practice...
....(IMHO)The large fresh airflow on the high pressure side of the baffle
makes the possibility of introducing CO quite remote. Any leak from the
engine will be forced down and out the negative side. The only way you
could introduce exhaust gas from the engine compartment would be to have a
massive failure of the baffle structure and that still may not allow CO into
the heat inlet. You are more likely to introduce CO from a crack in the
exhaust stack inside the heat muff.
As far as carb heat, I have a 4 pipe system and Vetterman offers a small muff
that fits over the #1 stack(or which ever pipe you choose) and can be used
to for this purpose.
Regards:
Rusty Gossard
N47RG RV-4 Flying
From: | bcos(at)ix.netcom.com (William Costello ) |
Subject: | Re: HS-610 and HS-614 |
>for the horizontal stab. It went well, except I'm wondering about one
>thing...why is it that the '614, when complete, has a flange that
>extends a little past the the bend line, whereas the '610 is cut
>straight at the bend line (more or less anyway). I would have thought
>one or the other technique would have been good for both.
>was more a question of curiosity.
>Back to the shop!
>Terry in Calgary
>S/N 24414
Hi Terry,
You doubtless have noted that the 614 is larger. It is the one that
goes on the bottom when the horiz stab is mounted. The 614 gets
drilled for bolts and the extra length is for support and clearance of
the bolts. I forget what drawing it is, but if you look into the
drawings for the fuselage construction you will see this.
I think your decision to keep it 'by the book' is a wise one. I am
trying to do the same thing. Last time I looked I didn't see a degree
in aeronautical(?) engineering next to my name and I sure don't feel
qualified to design my own.
Best of luck to you.
Bill Costello
___ _______________________
\ \ _ _ / /
\ /? \ / \ / Bill Costello \
X-*#####*******......./ Chicago /
o/\ \ \_\ \ RV-6 on emp. \
\__\ \ bcos(at)ix.netcom.com /
\______________________\
>snip...
>>questions.
>>from?
>>Regards
>>Peter Bennett
>>Sydney Australia
>Peter:
>Regards:
>Rusty Gossard
>N47RG RV-4 Flying
>Rusty: Much better answer than I gave. Bottom line, a very low risk
installation. How much RPM drop do you get with the little muff for carb
heat? I improved the heat gathering ability of both the carb muff and cabin
muff by wraping an expanded mesh product around the pipes. The material is
an "aluminumized" steel mesh sold at Wal Mart and it's used to cover rain
gutters to keep leaves out. I beleive you get about 15' for 5 or 6 bucks.
I cut the appropriate lengths and layered them on top of each other. I
compressed a lot of layers with some hose clamps, wrapped safety wire around
the material then removed the clamps. This improved heating somewhat (not
as much as I'd hoped, but you could notice the difference). I plan on using
this under all of the muffs on the SS crossover I have on the plane now.
Bob Skinner RV-6
You would have gotten much better engine out cruise if you had stopped the
prop. It's a curious effect, but a windmilling prop has greater drag than a
solid disk of the same diameter.
From: | "Mark D Hiatt" <OttoPilot_MSN(at)msn.com> |
I got to thinking, with everyone introducing themselves here,
before the big looping trouble, that I never did. I'm Mark
Hiatt, Aviation Forum Manager on the new Microsoft Network.
I'm responsible for kit NB1382, which is probably going to
become an RV-6A. Anyway, at this point I'm an NB, but hope
to get my paperwork back, soon. I don't think I've got quite
enough hair on my, er, chest for a taildragger at this point,
and one day my longsuffering wife Kathie will probably want
to take her training in it, too. Seems best for me at this
point to keep as many things as I can as simple as I can.
With that in mind, I'm leaning heavily (pardon the irony) to
the 320-series engines, with a fixed-pitch prop, tilting
canopy, and probably no more than day/night VFR outfitting.
I live in Lincoln, Nebraska, and have been known to buy gas
and burgers for folks who fly into LNK on their way around
the country. That goes especially for you, Mr.Skinner, as I
figure how much gas can you burn in half an hour, getting
here? :-\ I'd be very interested in seeing any of the lists
airplanes if you're ever in the neighborhood, and talking
with any Nebraska/Iowa/Kansas -area builders, especially of
RV-6s.
Sure is nice to have something to do while the weather is
bad, isn't it?
Mark D Hiatt
OttoPilot_MSN
Aviation Forum Manager,
The Microsoft Network.
I was browsing around through some woodworking pages and found a
couple of sites on HVLP spray guns
Check out Apollo at http://orion.adnc.com/~websites/apollo/
also Lex-Aire at http://www1.usa1.com/~stephenb/2002.html
both these companies have guns which use a great deal less air than
the DeVilbiss. Both claim to be able to use a 3 HP compressor. (8 CFM
at 45 PSI) The Lex-Aire is available for $349 for Internet users.
Dave Mumert
Subject: | Heat-Carb muff efficiency |
Bob:
(responding to carb heat question)
I get a slight RPM drop when I apply carb heat of about 50 RPM. I really
watch the carb temp readout on my engine scanner where you see a rise of 10
degrees f
or so. I'm not too concerned about carb ice with the lycoming...they tend, by
design, not to be as prone to the problem as a continental. I use it more as a
prevention of impact ice on the filter when I'm in a situation where that may
happen. I modified the carb heat inlet on Van's airbox to give a more positive
seal.
As for cabin heat...I flew yesterday morning and it was 21 degrees f on the
ground when I took off. I didn't even wear a jacket. I have a 2 tube stock
muff on a vetterman 4 pipe system and I was warm. I'm surprise you have had
all of the problems getting heat in your 6. (must be something about those
wide body RV's :-) )I've flown at 11 degrees f (with jacket, no gloves) and
was warm enough to have fun.
Regards:
Rusty Gossard
N47RG RV-4 Flying
We put Larry's stainless cross-over on our second plane with two heat
muffs and have been more than satisfied with the amount of heat we get.
Went flying last week when it was about 25 on the ground and we were very
comfortable in the plane. One of the tricks is to drill fewer holes in the
outlet of the muff than in the inlet. This gives the air time to heat up
before it blows through. If you use Robbins Wings muffs, pop rivet the ends
on. We had a very cold trip to Lakeland last spring when the ends fell out
of the muff. Sure was glad to get to Florida!
Becki Orndorff
>Nebraska winter.
>mounts.
>Bob Skinner RV-6
Becki Orndorff
NCI-FCRDC, Computer & Statistical Services
On 1/24/96 Bob Skinner wrote a reply on how to calculate the true calibrated
airspeed of your aircraft using the ground speed data off the GPS or Loran,
and flying three headings at 90 degree increments. The formula he gave did
not take into account the effects of density altitude and outside air
temperature. Does anyone know how to translate the results from this
formula,(true, calibrated airspeed at a given altitude, barometric pressure,
and tempurature), into a true, calibrated airspeed for STANDARD DAY
conditions?
On Mon, 29 Jan 1996 aol.com!DerFlieger(at)matronics.com wrote:
> I don't have a spiffy online service for my email. I have no capability to
> do multiple deletes. Plus, I must do 2 mouse operations for each delete. I
> guess I spent more than a half hour this weekend deleting one by one these
> majordomo things and now the message not deliverable stuff. Shouldn't these
> messages be routed to you instead of the net? Or back to the sender? Who
> else gives a damn?
Not attempting to overstep Matt, but the short answers are yes, no, and
probably quite a few of us.
Let me explain, if I may. I also have Majordomo running on my machine
for another mailing list. Matt had already explained that someone had
tried to subscribe "rv-list-request" to the majordomo list server. This
action created a mail loop in the system. The server was mailing
stuff out to the list. Since rv-liat-request was also on the list, it
mailed a coy of an item back to itself and then reprocessed it to mail it
out again. Any other stuff that we sent in also got inserted into the loop.
Since majordomo saw each outgoing message as input immediately after a
send, I would suspect that his system was going nuts processing all this
stuff! He had previously stated that he had trouble logging in to stop the
loop.
If you examine the header in a message from the rv-list, you will see
that he has an Errors-To: line in the header which should catch any
errors in mailing, such as bounces due to full mailboxes or unknown
users, back to another address. Unfortunately, this loop, as far as
majordomo was concerned, was not an error. It was doing exactly as it
was told. (1) It mailed out a message. (2) It mailed one copy of the
message to it's own address. (3) The message showed up as input to
majordomo. (4) It processed the message. (5) It mailed out the message...
See where I'm going?
Now then, yes, today we are seeing two more items come back, one that
says that a mailbox was full, the other is some uuencoded letter that
comes from a bounce. Why isn't this going to Matt's Errors-To: address?
Because the recipients' mail servers don't process the
recipients' end that Matt has no control over.
- Alan Reichert
Wannabe RV-6 builder and fellow majordomo administrator.
>From: compuserve.com!70743.2727(at)matronics.com (COROTEC)
>Fellow builders and flyers,
>I would appreciate your input on the following:
>1. I have not pressure tested my fuel tanks. Should I? Do they usually leak
on
>first check? (Note: I did NOT use slosh - only pro-seal per Van's
>recommendation).
You should pressure check the tanks. On method is to close off all openings,
ie vent & caps, then put a balloon on the vent exit point. Use your
compressor set at the lowest possible pressure setting to blow air into the
main fuel line. The pressure souldn't be any more than you would use to
inflate the balloon. Cap off the fuel line, then use soapy water to look for
leaks. Typically the caps leak a little, but no other leaks should be seen at
any other point.
>2. I have been using Mar-Hyde 5111 self-etching primer on all my parts
>(airplane, that is), prepping with scotchbrite and cleaning with naptha.
>Anyone else doing this? Any comments?
>3. The archive indicates some of you regularly fly in IMC. How is the
>airframe for icing? The wing LE looks like it would be a poor ice
collector, but the
>HS looks like it would be a pretty good one....
>bruce stobbe
Bruce:
The RV Series are not intended to be flown into icing conditions. PERIOD.
Are you located in Winstead CT?
Subject: | Back riveting top wing skin |
I back riveted the top wing skin on my left
wing Saturday. Looks real nice I must say.
Someone on the list mentioned that the Avery
tool did not have enough bend.
I found that my tool had the same problem. I
called Bob Avery and explained that it
appeared that the set was a degree or two
short to get around the rib flange.
Bob said that he had specified 4 degrees +-1
degree for the bend. He sent me a new tool
that was bent to 6 degrees and it worked
fine. It takes a little skill to hold that
long set steady but as the literatue states
it takes no skill to buck on the outside.
Well it did take a little while to teach my
wife not to let the bar bounce like you do
when bucking to form a shop head.
If anyone bought the set and it bends the
rivets towards the rib web I would talk to
Bob and he will fix it. Or if you have a
torch, Just heat it and wack it another 2
degrees or so.
Jim Schmidt
RV6 Skinning both wings
Subject: | Re: Taildragger FAR |
This may be a legal interpretation of the FAR but what will the pilot's
insurance company do when he/she files for hull damage and they find out he/she
was flying a T-dragger w/o the proper signoff for same? If the pilot is going
to invest $20,000 to $40,000 and a couple thousand hours of time building the
dream airplane, why on earth would they be so tight(stupid :>)) that they would
even consider risking it all with out proper training in a T-dragger? I must
have missed something that caused interest in this discussion. It is more
interesting than the majordomo notes; however, but not much. :^)
Let's all get properly trained to protect our flying machines, our necks and
Homebuilders reputations, OK.
R. W. ( Bob ) Veit
Flying Eagle Estates Airpark
bobveit(at)interserv.com
I for one will be real interested in finding out how much that helps. Is
that the same system that Van's advertises as High Country Exhausts?
According to the catalog they are the "overwhelming choice of RV builders".
I'm heading for the finishing kit now, and I don't know much about the RV
exhaust systems except to stay away from the Tolle systems. Any info would
be much appreciated.
-- Ed Bundy
Jim, stop sending these messages. You are only adding to the problem!!!
Talk to the mail admin instead. He sent a not stating what the problem
was. Your broadcasting messages just makes the pile deeper.
Herman
> From root Mon Jan 29 10:16:06 1996
> Errors-To: bounces(at)matronics.com
> Date: Mon, 29 Jan 1996 08:35:46 -0600
> From: JIM SCHMIDT <mail.mei.com!JIM.SCHMIDT(at)matronics.com>
> Subject: Majordomo results: Majordomo results: RV-List: Majordomo re
> Message-Id:
> Mime-Version: 1.0
> X-Mailer: Novell GroupWise 4.1
> Content-Type: TEXT/PLAIN; CHARSET=US-ASCII
> Content-Transfer-Encoding: 7BIT
> Sender: owner-rv-list(at)matronics.com
> Precedence: junk
> Reply-To: rv-list(at)matronics.com
> -Reply
> stop flooding the list with this
Herman Dierks, Dept. E54S, AWSD, Austin, Texas
mail: dierks(at)austin.ibm.com
Somebody posted a summary of an RV4 with an IO360. I accidentally deleted
the post while trying to purge the 150 "majordomo" error messages.
A couple of questions?
Is this a 200hp angle valve 360?? If so, how difficult was it to fit?
What kind of climb rate are you getting? What kind of fuel burn are you
getting at full/climb power? Was it difficult to find/expensive?
thanks
Subject: | Re: Back riveting top wing skin |
I also back riveted my wing shins except for that area near the trailing
edge where the back riveting set didn't have enough bend. The skins turned
out nice and I was very pleased with the result. However, I started using
a technique I think was mentioned by Don Wentz (??) that essentilally
obviates the need to back rivet; rivet the normal way and then use a
piece of wood ( I used a 3/4"x 3/4" x 12" piece of oak) and lightly tap the
rivets from the shop head side with a hammer. The indentations that
normally occur from front riveting disappear and you get a nice smooth
surface, and it only takes a couple minutes. I've done my whole fuselage
this way and all the skins are just as smooth as my back riveted wing
skins.
This is one real advantage of back riveting; the skill level of the bucker
is almost nil, not that I would tell my wife she has nil skill...
I found the Avery back riveting set a potentially wicked tool and it took
a lot of concentration and skill to make it work well. For this reason I
now favor the simpler "wood" approach.
Rich, RV 4
Subject: | Re: Heat-Carb muff efficiency |
>Bob:
>degrees f
as a
>seal.
>Regards:
>Rusty Gossard
>N47RG RV-4 Flying
>Rusty: Combination of wide body, low metabolism, I guess:) Vetterman
doesn't have a dual muff for the 4-pipe on the 6. One thing that really
helps on the 6 (in the winter) is having sun come through the canopy. Makes
things a lot more comfortable. When the sun goes down or behand a cloud,
the temps drop big time. I'd sure like to test the dual muffs on the
cross-over but it's -8 degrees and the winds blowing 11 kts. Yikes!
Guess I'll work on the 6-A. Thanks, Bob Skinner RV-6
>Bob,
> Becki Orndorff
Becki: Thanks for the reply. Do you have the dual muffs hooked together in
series or does each one go to a cabin outlet. When you pop riveted the ends
on, I assume you don't fasten the two halves with the screws. Would
grinding off the flanges for the screws make installation and removal a
little easier? Did you use anything wrapped around your pipes under the
muffs to increase surface area. Thanks, Bob Skinner RV-6
JimX_Thompson(at)ccm.jf.intel.com, randall(at)edt.com
Subject: | Pacific City Airport -- SAFE! |
I talked to Betty Stansbury at Oregon Aeronautics and she told me
that there was a town meeting at Pacific City and there was almost
universal support for the airport. The "close the airport" faction
is apparently pretty small. In addition, the letters received by the
Aeronautics division helped confirm that the pilot community is aware
of the potential problems and willing to rise up in support when needed.
Currently work is being done to address the safety issues, and she
indicated that support would be asked for in the future, probably in
terms of education and also financially, as some alternatives may
involve the purchase of new equipment or even real estate.
Thanks to all who responded.
Randall Henderson
randall(at)edt.com
I alimi-prepped because it's an easy way to get most of the dirt off
of there before doing the REAL cleaning.
I alodyned for a couple of reasons. One being that I knew I'd
scotch-brited off some of that protective layer. Also, even though I
will have fuel in the tanks which will displace moisture, It's not
going to be in there for a long time, and in the meantime they're stored
in a cold, somewhat damp garage.
BUT Alodyne does leave a chalky residue if you let it "dwell" for any
length of time, and that might interfere with the adhesion of the
pro-seal. You could deal with this in two ways: 1) just do a "brief"
alodyne (30 seconds or so of "dwell" time before rinsing), or 2) Rivet
the tanks together, then slosh with alodyne afterwards. You might want
to NOT have the fuel sender in when you do this however.
I did it the first way on one tank, the second way on the other. I think
if I had it to do over I'd do them the second way. Both tanks passed the
"balloon" test.
Randall Henderson
RV-6.
Subject: | Re: Carb/Cabin Heat |
>degrees f or so. I'm not too concerned about carb ice with the
>by design, not to be as prone to the problem as a continental. I use it
more as a
may
positive seal.
I have found that the original carb heat system that Van suggests in his
plans is not sufficiently hot enough for solving carb ice problems while
flying IFR. The FAR's require certified aircraft to have a 90 degree f rise
in carb air when carb heat is applied ( they do not specify under what
conditions). After one esperience (with a lycoming engine) in IMC, I was
convinced a re-design was in order.
What I have done is install a hose adapter on the top of the airbox, using
all the original hinge and flap hardware. It is necessary that the flap fit
snuggly when closed (or in the alternate air position). The hose is connected
to a muff, much like the cabin heat muff, that is located on the crossover
portion of the exhaust system, directly over the carburator. Under this muff
(as well as the cabin heat muff) I have installed a slightly strecthed out
screen door spring that has been painted with high temp exhaust paint. This
increases the effective surface area of the exhaust pipe, allowing hotter air
to exit.
The end result is a inlet air rise of about 60 degrees f while in cruise
configuration. Hotter rises occur when idling on the ground. Since
installation, I have not had any occurance of carb icing even when airframe
icing has occured (with carb heat on). All other occurances of carb ice
problems have alway gone away when carb heat was applied.
For those of you that are having trouble getting enough heat out of your
exhaust pipe heat muffs, try limitig the air leaks in the cabin first. In the
RV-6 there is considerable air leak potential from both the flap extension
mechanism and the aileron control push rod exit points.
Those of you that are still working on your wings and/or fuselage, should
consider a method to eliminate the outside air from getting into the cabin
floor area. For the aileron push-pull tubes, try constructing a flexible,
conical boot that mounts to the outside of the fuselage in the wing root
area. Ths could be constructed from a piece of leather or nogahyde (sp)
material. Attach to the fuselage with a metal compression ring and
screws/nutplates, and to the push-pull tube with a hose clamp. The length of
the conical material should be long enough to stretch out for the maximum
aileron control movement.
The flap extension mechanism hole could be sealed in a similar manner,
but it may require that the leather of nagahyde material be glued to the
inside skin. A velcro 'zipper' could be installed on both boots to allow
better serviceability.
In my finished RV-6A, I've had to struggle with stopping all the air
leaks from getting out of the large void area under the floor. This results
in a cold floor all the time, and drafts that are hard to find and stop. In
hindsight, I would definately try to incorporate these changes to eliminate
the drafts.
The single heat muff (from Van's option catalog) with the door spring
adder, supplies enough hot air to warm the cabin area sufficently in the New
England area IF the air leaks can be eliminated.
Hope these suggestions help anybody planning on flying in the cold
latitudes.......
Fred Stucklen RV-6A N925RV
What type of bar did you use for bucking? Shape/Lbs?
Chris
cruble(at)cisco.com
>-- Ed Bundy
Ed: Yes, High Country Exhaust is Larry Vetterman. It's a very nice system
and Larry is a great person to do business with. (He's a fellow RVer, you
know). Yeah, there's a lot of us that wish someone would have tipped us off
on the Tolle system. Alan Tolle is very personable and I like him and his
wife and they've done a lot for RV's, but after hearing and seeing all of
the trouble with his exhaust systems, I sure didn't want to put one on my
airplane. By the way, there is a RV-6A here at Lexington that just blew #4
stack after 100 hrs. The weld at the flange completely separated. Anyway,
I think you'd be very pleased with the Vetterman system. I'll let you know
what I find out about heat production on the new system as soon as I know.
Bob Skinner RV-6
I was able to get really good results with an offset mushroom set. I
did bend over a few rivets before I realized I had to over-angle the
set to compensate for the direction of the burst from the gun. I
back-riveted my top skins this way, as well as a couple of friends'
wing skins.
Randall Henderson
RV-6
>on
>>recommendation).
>any other point.
I got nervous about getting near my tanks with the air hose. I sealed over
the gas cap with plastic under duct tape then attached a fitting on the vent
(1/4" alum tube)
and plugged all other holes. Then, I blew up the ballon and slide it over
the 1/4" alum tube and taped it on. Just didn't want to take any chances of
something going "boom".
Bob Skinner RV-6
>degrees or so.
>Jim Schmidt
>Jim: Good idea, but I wonder if heating the set would soften the metal and
allow the set to keep on bending? I helped a couple of friends with back
riveting their top skins. We set one # 4 rivet at the top of the rear spar
to the trailing web of the main ribs and clecoed the other three holes.
Once riveting progressed towards the trailing edge, we pulled the clecos and
was able to move the rib out of the way so we could get a straighter shot
with the offset-set. I also rounded the corners of the set on a Scotch
brite wheel and generally polished the end. This lessens marking of the
underlying material in case the rivet set gets cocked off a little. Bob
Skinner RV-6
From: | csanchez(at)BayNetworks.com (Cheryl Sanchez) |
Subject: | How to remove prop extension? |
This past weekend I removed the propeller from my prop
extension. But the extension seemed to be "stuck" on the crankshaft.
We didn't want to damage it so no attempt was made to force it off
in any way. Does anyone know how to get it off? Thanks.
Cheryl Sanchez
csanchez(at)world.std.com
Subject: | Re: True Airspeed |
>conditions?
Fred: I, too, wondered about this. I did log the outside temps and
computed density altitude. Of course, each run does take DA and temp into
account because that's the conditions that prevailed at the time. I don't
know if converting everything to a standard day would reveal that much. I
wonder if there would be more impact on the data caused by accurate leaning
was performed, turbulence, load conditions and pilot technique? From the
data that I have, the only effect density altitude has on the figures is
that the airspeed error is greater at high DA conditions.
By the way, I have a spreadsheet with 30 speed runs on it. I'm sure there
is a way to import this spreadsheet data into Eudora and distribute it to
the RV-list. I just don't know how to do it. If anyone has an interest in
the data and can tell me how to import/send it, I'd be happy to post it.
(You might want to contact me off-list at : BSkinner(at)ltec.net) I'd like to
get comments from fellow listers on these figures.
>skins.
Could you explain this in a bit more detail, I am interested in trying this,
I'm just about ready to do the main skins on the left wing. Are you saying
you place the piece of wood against the outside of the skin and just tap it
to remove any indentation?
-Steve Day
sday(at)pharmcomp.com
(CK ID - RV6a RV for short)
Subject: | RV builder-partner(s) WANTED in Virginia |
In Hampton Roads..to share tools, expertise, costs, etc. building personal
and resale models. Contact email or 804-867-7244
I
>> else gives a damn?
>loop.
>Errors-To: line in the header properly - a configuration problem on the
>- Alan Reichert
Alan: Is it proper, allowable, etc. for a RV-lister to un-subscribe the
person who has a full mail box or other problem that is corrupting the list
or is this something that only the administrator of a list is allowed to do?
I assume that Matt is very busy with his business and does not have time to
be constantly monitoring the list to see if anything is wrong. Matt: if
you're reading this, are there some instructions that you could give us
"listers" so if the problem occurs in the future, we could put a stop to it?
*** Fred's good stuff cut ***
The sailplane guys have been doing this for years for performance reasons.
I have use chamois leather in my Mini-Numbus for better flexibility, and
others use sailcloth for the same reasons. Both can be glued into a
conical shape with good contact cement. You want this cone to not
introduce any "drag" on the controls. I think either of these materials
would be a little better performance and easier to fabricate.
*** snip ***
>latitudes.......
From: | RUSS_NICHOLS(at)fire.ca.gov (RUSS NICHOLS) |
Subject: | EAA Technical Advisors |
I'm ready (finally) to close my Horizontal Stabilizer. I want to have
an "official" EAA Technical Advisor take a look at my work. While my
EAA chapter (52) has a number of people with whom I feel confident,
none of them are registered as Technical Advisors.
So...
1. Does anyone know of a Technical Advisor in the Sacramento, CA
area?
2. Does anyone know the requirements for becoming an Advisor?
I am interested in becoming an Advisor, but all of my experience to
date is still on my jig. I'm probably just a little green... :^)
thanks,
Russ Nichols
russ_nichols(at)fire.ca.gov
SNIP...
>>Regards:
>>Rusty Gossard
>>N47RG RV-4 Flying
Bob;
Now I get the picture...didn't know you couldn't use a 2 tube. Thats
another good reason I could have used on my wife when I "convinced" her a 4
was the way to go.
Let us know how the 4 tube vs. the crossover is in performance. I've always
thought a crossover would out perform a straight pipe but Larry said it
wasn't so when I bought mine in 1993. Has he changed his thinking? I know
one thing...
I haven't had one problem with his pipes.
Regards:
Rusty Gossard
N47RG RV-4 Flying
From: | Dave Mumert <dmumert(at)softnc1.softnc.com> |
Subject: | Change of address |
My e-mail address has changed from mumertd(at)cadvision.com to
dmumert(at)softnc.com. I am now using my employers Internet feed.
The Calgary RAA now has it's own Web page. It is on Ken Beanlands
Christavia page at http://www.dcs-systems.com/~ken/christavia.html
Those in the Alberta area may want to monitor this page. Ken has a nice
page for the Christavia planes. The white tube fuselage is his plane,
or will one day be a plane.
From: | bataller(at)tif623.ed.ray.com (Gary Bataller) |
Subject: | Re: How to remove prop extension? |
Hello there Cheryl!
Bolt the prop back on and then slowly (and softly) rock the
prop at the root. I went through this many times taking it
on and off.
Gary Bataller
Side note: I previously unsubscribed from this newgroup, but somehow
a few days ago I got back on it (with the ton of garbage messages).
> Cheryl Sanchez
Subject: | How to remove prop extension? (fwd) |
Simply tap with a rubber mallet.
Another method would be to use a block of wood (2x4) against
it and then hit the 2x4 with a hammer.
It should not take too much to get it off as the bushings should
just be a snug fit.
I assume you took the 6 bolts out that bolt the extension to the
crankshaft.
Herman
> From root Mon Jan 29 18:07:00 1996
> Date: Mon, 29 Jan 96 15:55:47 EST
> From: BayNetworks.com!csanchez(at)matronics.com (Cheryl Sanchez)
> Message-Id: <9601292055.AA19578(at)pobox.BayNetworks.com>
> Subject: RV-List: How to remove prop extension?
> Cheryl Sanchez
*NOTICE for internet mail*: Any ideas or thoughts expressed here are my
own and are independent of my employer.
Subject: | pressure testing fuel tanks |
Do not use any compressed air to test the tanks.
It is very easy to over pressure a fuel tank and buldge it out.
This is due to the area of the tank times the pressure = a lot of force.
Here is what I did and it worked OK. The plane is flying now and no leaks.
I cut the end off of a baloon and slipped it over the inside of the fuel
cap and then put the cap back on. This seals the cap. Could use a thin
latex glove or whatever.
I put a AN cap over either the vent or fuel outlet fitting to plug it.
If you don't have the AN fitting to plug it with then maybe another piece
of a baloon and safetywire wrap around the fitting.
Get a good baloon and inflate it and have it ready. Then use you lungs
to blow into the remaining open fitting to compress the air. Plug it with
your finger then quickly slip the baloon over it the fitting.
Wrap some .025 safety wire around the baloon to seal it to the fitting.
Let it set a day or so at near constant temperature.
There may be a little loss due to your hot breath cooling down some.
>Cheryl Sanchez
Cheryl: You might try heating the aluminum extension with a heat gun.
Don't think that a hair dryer would get hot enough. I'm refering to the
kind of heat gun that is used to strip paint. One with a varible control
would be nice. The extension should heat up readily and hopefully the crank
flange will stay cool because of the large heat sink. Maybe a light tap
with a wood mallet while someone else pulls on the extension.
Bob Skinner
From: | Scott Johnson <rvgasj(at)popmail.mcs.net> |
Subject: | RV6A is a pain to move without wings ... ? |
I currently am working on the wings of my RV6A. However, I was looking ahead
at the plans and realized that the main gear of an RV6A is mounted to the
wing spar. This brings up a few questions:
1) If I go ahead and build a wood pseudo spar to attach the landing gear to
when I am done fitting the gear legs to the real wing, at least I could roll
the fuselage around in the workshop and install the engine and instruments,
but ...
with all that weight on the fuselage, how will I support it so I dont damage
the fuselage skin when it comes time to pull the psuedo wood spar out and
put the wing in ?
2) I am also planning on taking the wings off to bring the plane home over
the next few winters to paint it and continue refining it in the workshop.
If I built an RV6 it is my understanding that I could just pull the wings
off and roll it right into a U-Haul van and bring it to my workshop. The
RV6A would be a pain for the above mentioned reasons.
3) Since I have 1000 hours in tricycle gear (0 hours in a tailwheel), and I
liked the looks of an RV6A better, I chose it. However, if I can't find an
easy way to move it without the wings, I am going to strongly consider
switching to an RV6. I would greatly appreciate any comments as I will be
ordering the fuselage kit soon.
PS. Is the RV6 really that easy to fly in cross winds ... I heard tail
dragger pilots don't wonder if they will ever ground loop, but only when ...
Thanks for your comments .... on the fence, Scott Johnson
From: | "Dan and Myrna Toupal" <DMToupal(at)msn.com> |
Subject: | Majordomo...blah, blah, blah |
Quit whining or you'll get the job . . .
aol.com!CAP10ZOOM(at)matronics.com
Sent: Saturday, January 27, 1996 9:19 AM
Subject: Re: RV-List: Majordomo...blah, blah, blah
Jim Campbell
Subject: | RV-List Proceedures... |
>Alan: Is it proper, allowable, etc. for a RV-Lister to un-subscribe the
>person who has a full mail box or other problem that is corrupting the List
>or is this something that only the administrator of a List is allowed to do?
>be constantly monitoring the List to see if anything is wrong. Matt: if
>"Listers" so if the problem occurs in the future, we could put a stop to it?
Hello RV-ers,
I've been out of town since early Saturday morning and this is my first chance
to read any email - sorry for the delay. Normally, I try to keep a close eye
on the List and its operation, checking things at least a couple of times a day
- yes things go wrong that often. People are always sending bogus messages to
the rv-List-request address that cause problems. The problem Friday morning
was the worse I've ever seen and I appoligize to *everyone* for all the email
that went out before I could get it stopped.
The automated operation of the List is so straight forward it seems incredable
that there would be so many problems, but that's the Internet for you...
To answer Bob Skinner's question, "yes" anyone on the List can subscribe or
unsubscribe anyone else from the List. Generally, I would prefer that people
didn't just start unsubscribing people from the List when they 'think'
something might be wrong. I try to keep a pretty close eye on the List
operation to make sure that it runs smoothly, so generally that should be
sufficiant. In anycase, to subscribe or unsubscribe someone from the List
whether its yourself or someone else, the easyest way is to send a message
"rv-list-request(at)matronics.com"
and put the following in the body of the message:
"subscribe username(at)machine.domain"
-or-
"unsubscribe username(at)machine.domain"
*AND THAT'S IT*! Nothing else. If you have automatic signauture files,
*TURN THEM OFF*. The messages are read by a machine, so don't put any
friendly message text in it either.
Remember, what you unsubscribe with must match *EXACTLY* what you subscribed
with. For example, If I subscribed myself with:
"subscribe dralle(at)roxy.matronics.com"
then later tried to unsubscribe with:
"unsubscribe dralle(at)matronics.com"
*it wouldn't work* even though both might be valid email addresses.
Anyway, I hope this message didn't sound too 'bitchy', I didn't really mean it
to. Let's keep up those RV discussions!!
RV-List Admin.
Subject: | Re: EAA Technical Advisors |
> So...
> area?
> thanks,
> Russ Nichols
Contact Ben Owen at the EAA National office. He'll be happy to tell you
about the Tech Advisor program. If all you've done on aircraft so far is
work on the HS Stab you're probably not _quite_ ready to assume the lofty
duties and responsibilities of a Technical Advisor. But, keep up the faith,
after you've finished the RV you'll be more than ready.
I'd be happy to inspect your project but I am sure there are some TA closer
to Sacramento.
John Ammeter
Seattle WA, USA
RV-6 N16JA
Flying 5 years
Subject: | Re: list problem |
On Mon. 29 Jan 1996 Alan Reichert wrote:
>From: "A. Reichert" <clark.net!reichera(at)matronics.com>
>Subject: RV-List: Re: Garbage
>(my comments about the Majordomo etc. situation )
loop.
- Alan Reichert
OK. Thanks for the enlightenment Alan. I know it must (is) that way. I
apologize to you, Matt . I know its not your fault, and I really didn't
mean to imply that it was. I know that some have multiple delete capability
and that would make it better to deal with. I probably wouldn't even mind.
Makes me wonder though. Can't some control systems techniques be used on
Majordomo? Such as limiting the number of resends allowed in a given time.
Or recognizing the same message passing through more than once or twice.
Maybe use some artificial intelligence? No useful control system output is
allowed to grow without bound when there is a perturbation on it's input.
Can't the loop be closed with negative feedback?
Thanks for your comments Deene.
Jim Stugart
DerFlieger(at)aol.com
Subject: | Re: RV6A is a pain to move without wings ... ? |
>but ...
>put the wing in ?
Of course the RV-6 is easy to fly in cross winds. If fact, you won't be
able to tell the difference between a -6 and a-6A no matter what the winds
are. That is until you decide to land it. Then there is a _slight_
difference in the _landing charactoristics_. Actually, the minor difficulty
you will have occasionally is more than offset by the points you'll gain by
flying a taildragger.
Only a macho chauvinist would even think of pointing out that _some_ TD
pilots refer to the wheel on the front of a nose-dragger as the 'training
wheel'; I certainly wouldn't condone that type of demeaning description.
John Ammeter
Seattle WA, USA
RV-6 N16JA
Flying 5 years
From: | kightdm(at)harvey.carol.net (danny kight) |
Rich,
I am about to start my first wing, (RV-6) and am interested in back riveting
the skins also. You say to ....
>surface, and it only takes a couple minutes. ...
What flush set are you using? I did my empennage with an Avery swivel flush
set with the rubber cup. I am very impressed with the results... there are
no indentions that I can see.
Danny Kight kightdm(at)carol.net
finishing up (ugh) fiberglass on empennage
A
>Bob;
>was the way to go.
>one thing...
>Regards:
>Rusty Gossard
>N47RG RV-4 Flying
>Rusty: Larry has not changed his thinking. I'll run a few tests (when the
weather warms up) and let you know if there is any difference. Bob Skinner
2nd try, first message didn't go through?
In a message dated 1/29/96 you wrote:
=Bruce:
= The RV Series are not intended to be flown into icing conditions. PERIOD.
= Are you located in Winstead CT?
=Fred Stucklen RV-6A N925RV wstucklenol.com
Hi Fred,
Yes, I am in Winsted and am still plugging along on my RV-6. It was nice to see
your name in some of the previous correspondence, considering the much
appreciated help/advice/encouragement you have given me in the past.
Although I do realize that the RVs are not intended to be flown in icing
conditions, it seems that if you fly in IMC in the winter months, and you are as
lucky :-) as I am, you may sometimes find yourself in icing conditions despite
your best efforts to avoid it. I was just curious as to whether anyone else has
had this kind of luck in an RV, and how it might compare to other GA aircraft in
terms of accumulation rates, etc.
BTW, baggage floor ribs - has anyone else had the F-625s end up too wide at the
F606 - like 1/4 in too high compared with the other baggage floor ribs when
properly aligned with the bottom of F606? I contacted Van's today and they
advised that they had not heard of any problems - but I checked and the rib is
wider than the prints say it should be, and since they are all formed in the
same fixture, someone should have had this happen besides me, unless I'm missing
something!? If so, what did you do - remove the flange and rivet on a
replacement .063 angle at the correct height?
Happy building/flying,
Bruce Stobbe
(flying in imagination; building in reality)
fuse skeleton (still)
Subject: | HVLP gun from Harbor Freight |
Hi Folks,
A few days ago Geo Orndorff mentioned that he used an HVLP gun from HF
that cost $89 and got good results (talking about priming -- not sure
about fininhing).
Has anyone else used this gun and had good results with it? And is it
the one for $89.99 called in my 'flyer' catalog, 'Industrial HVLP Spray
Gun' mfg by Central Pneumatic with the name Professional under the mfg
name?
Would appreciate your feedback, since I will be priming wing parts soon
and am very interested in reducing over-spray. Thanks.
Bill Costello
\ \ _ _ / /
Subject: | Re: RV6 for sale |
For sale RV6 completed airframe for sale for more info call George & Becki
Orndorff 301-293-1505
>but ...
>put the wing in ?
I built a cart, complete with large castering wheels, from the fuselage jig
lumber. By positioning it in the center of the fuselage bottom, at the
balance point, I was able to easily move the fuselage around when
installing/removing the wings. The rest of the time I had the wood pseudo
spar in place with the weight of the fuselage on the landing gear.
Of coarse, hosting the fuselage up onto the cart was not an easy task, but
there are several methods you could use. I just jacked it up by stacking a
base of timbers under the front belly pan and around the rear wing attachment
area, jacked it up and slipped under the cart. You could jack it up from the
gear legs, or, with strapping around the balance points, use a fork truck to
lift it. It really is easy once you think about it.
Might be easyer to paint it with the wings on. There are some 75 bolts you
must remove to get the wings off, some of which are close tolerance bolts.
Don't think I would do what you plan.
Still think I would stick to the -6A. I have over 1000 Hrs tailwheel time,
and, for safety reasons, would stick to the trike. But that's a VERY
subjective decision....
Hope that helps.......
wstucklen(at)aol.com
From: | JIM SCHMIDT <JIM.SCHMIDT(at)mail.mei.com> |
Subject: | To JIM SCHMIDT -Reply |
Sorry Herman stopped after I got the message
from Matt
Scott,
The wood pseudo spar is a good idea, even if it is just to maintain the
spacing so your wings will fit into the fuselage when the time comes. We
faced our wood spar with a layer of metal to help prevent crushing.
We finished all the engine, instruments, interior, etc with the wood
spars in place and on the gear. When we took the plane to the airport, we
jacked it up with a 6" x 6" support block covered with carpet under the 604
bulkhead (where the wing spar attaches).
As for taking the wings off and bringing it home, you may want to
reconsider after you have put the wings on. For both our planes, it was a
two day process to put the wings on the first time. The 6A is slightly more
time consuming due to the gear, but both planes have the same number of
bolts in the spar. I imagine a finished plane would require more time for
removal of control tubes, fairings, fuel lines, vent lines, electrical
connections. You may want to consider doing your work at the airport.
Besides, its cool to hang out at the airport and be an airport rat. My dog
thinks its the greatest thing since dog biscuits!
Becki Orndorff
>but ...
>put the wing in ?
Becki Orndorff
Subject: | Re: Back riveting top wing skin -Reply |
>>> Rich Ward 01/29/96
11:49am >>>
potentially wicked tool and it took a lot
well. For this reason I now favor the
I know what you mean, Now looking at the
right wing I will have to either hold the
gun in my wrong hand or loop my other arm
around to steady the tool. I will try the
method you describe. I happen to have some
3/4 in oak around.
Jim
>>> Bob Skinner 01/29/96
02:16pm >>>
the set would soften the metal and allow the
of friends with back riveting their top
the rear spar to the trailing web of the
trailing edge, we pulled the clecos and was
could get a straighter shot with the
the set on a Scotch brite wheel and
marking of the underlying material in case
Skinner RV-6
I asked Bob and he said that the end whas
heat treated but he would douse it in water
or oil and that would harden it again.
Mine was so far off I couln't even rivet the
ones at the full depth of the rib where it
is 8 inches thick.
Yes I also saw that sharp edge and buffed it
off with the scotch brite wheel.
Jim
With the concept that each person could control the temperature on their
side of the plane, we put a muff on each side of the engine and each side of
the plane has a control box and cable to control the heat.
For installation, (and we didn't intend to remove the muffs, so didn't
provide for that), starting at the engine baffle, only cut a 1" hole as the
entrance to the scat tube that goes to the muff, one per muff. We cut our
holes low on the engine baffle to get air that has passed through the
cylinder fins. We assembled the muff with the screws in the end plates.
Attached the flanges. Drilled 6 1/4" holes into the muff for the air inlet
and 5 1/4" holes for the hot air outlet. We used pop rivets to attach the
ends to the muff. This could be done with sheet metal screws for easier
removal. Then use hose clamps to hold the muff in place.
As for putting anything inside the muff, (and I don't want to restart
this conversation about wrapping pipes), we haven't. I wonder if something
inside the muff might cause a hot spot and damage the pipes.
I also agree with Fred (I think it was Fred) that interior finishing
helps control temperature. We didn't try to block the air coming into the
fuselage from the wing, but our seat cushions surround the stick hole and
the stick boot is fairly tight to seal that air access. We build foam
panels, covered with fabric for the sidewalls beside in the section where
the arm rest is, and insulate the floor with sleeping bag pads under the
carpet. I'm sure the combination of all these things helps keep the plane warm.
Becki Orndorff
Becki Orndorff
>Hi Fred,
see
Hey, when you want to go for another ride?
are as
>despite your best efforts to avoid it. I was just curious as to whether
anyone else
>has had this kind of luck in an RV, and how it might compare to other GA
aircraft
>in terms of accumulation rates, etc.
The one time I've been in ICE was some what uneventfull. The ice accumilated
on the windshield, and up the leading edge of the wings to about the spar.
There didn't seem to be any abnormal flying characteristics, but then I
wasn't in it long enough to get severe accumilation or to test fly the
aircraft. I would like to believe that it would handle much like a Cherokee,
or any other thick cord wing design.
>the F606 - like 1/4 in too high compared with the other baggage floor ribs
when
>is wider than the prints say it should be, and since they are all formed in
the
>missing something!? If so, what did you do - remove the flange and rivet on
a
>Bruce Stobbe
Bruce, sounds like you may have the wrong rib at that location. Check all the
dimensions for the other ribs.
>>> Chris Ruble 01/29/96
02:21pm >>>
bucking? Shape/Lbs?
I've sold my soul to Avery. He sells one
just for the purpose. It is a turned
cylindrical piece about 1.5 inches in
diameter about 8 inches long with a round
flat face with the edges nicley radiused.
I'd guess about 3 lbs.
Interestingly enough BoB Avery told me he
gave up on his project use of the backrivet
tool. he could not use it.
From: | "B F Gibbons" <bfgibbons(at)intellinet.com> |
Subject: | RV Archive Search Engine |
I've put a Windows program on an FTP server which searches the
archive files. You can download it from:
FTP.INTELLINET.COM
the directory is pub/users/bfgibbons
There is a subdirectory there called RVSEARCH. This directory
contains a zipped file with the EXE and a Word 7.0 document with
instructions. Download in binary format.
Put the rvsearch.exe in a subdirectory (I put it in c:\rvsearch) and
put the archive file in the same subdirectory. The archive must be in
the same subdirectory or the program will not run. The archive file
must be the RV-Archive.digest.complete (or complete.zip) file. This
file (either zipped or not) contain page breaks and have e-mail
header information removed. If you use another archive file the
program will not run. Matt is working on getting the new FTP site
on-line so if you don't have this file already you'll have to wait
until the FTP site is available.
The Word document has fairly good instructions on how to use the
program. If you need help, please e-mail me directly at
bfgibbons(at)intellinet.com.
Subject: | Re: RV-List - Thanks Matt |
>Matt Dralle
>RV-List Admin.
Hey Matt!
Don't apologize too much, it's you that has been getting the bitchy mail as far
as I have seen recently...sure the list "glitched" but....
the last time I checked, I wasn't sending you any subscription. As far as I am
concerned, the list is excellent, THE "A # 1" way for me to get info and
contacts regarding my hobby/passion/fixation - RV's.
Sometimes it is all too easy to criticize, and we all do from time to time! -
What we don't do very often is to take enough time to recognize someone for a
job well done. Well here goes..... Matt - thanks for running the list and for
providing the software and hardware to make it happen. Its a joy every time I
log in. Keep up the good work!!!
Rob Lee - RV6A - Painting now imminent
You might try soaking it with a penatrating oil for a few hours. Than put a
piece of wood on the extention and tap the wood with your favorite hammer.
Work your way around and it should "pop" off.
If that doesn't work...get a BIGGER hammer :)
Gary
H E L P !
I need a cover photo for the upcoming 16 Year's of the RV-Ator Book! ! ! ! !
In Flight Close-up ???
Formation ???
Construction photo ???
That RV grin ???
Something that shows what RVing is all about.
Heck, I'll even pay you for it!
Andy Gold
Easy Publishing
328 Luscombe Dr
Los Lunas, NM 87031
(505) 865-3466
Subject: | Certification procedure |
Can someone please direct me to a good source of information for certifying
a experimental aircraft? I have read a few books and talked to a few people
but there seems to be alot of gray area about the "absoulutly have to's" and
"should do's" concerning documentation while building. I would like to have
all the ducks in a nice neat row for that final inspection.
Dan Shades
RV-4 Waiting on wing kit
dls27(at)psu.edu
From: | "David A. Barnhart" <barnhart(at)crl.com> |
Danny:
I highly recommend the Avery swivel flush set that you already have.
Just this past wekend, I enlisted my father-in-law (who had never handled
a rivet gun in his life) to help me rivet my top wing skins. He did a
beautiful job.
Best Regards,
Dave Barnhart
rv-6 sn 23744
Subject: | Tailwheels are easy |
With all this talk about tailgraggers vs nose draggers, I thought I would
chime in here. I am in the middle of getting a tailwheel checkout. I've
had about 2.5 hours in a Champ, and I figure it will take another couple
of hours before my landings are consistently greasers.
Pssst! This taildragger stuff is easy! A heck of a lot easier than
shooting a partial-panel NDB approach in moderate turbulence. Don't let
the 'tail draggers are hard to fly' myth stop anyone from building a -6.
Best regards,
Dave Barnhart
rv-6 sn 23744
This has got to be the best RV builders "trick" yet. I went home last night and
tried this on my .025 LE skins, WOW! they look great. Thanks for re-posting this
info.
Chris
I have a couple of trips planned, and I'd like to meet some other RVer's if
possible. I'll be in Portland on Jan 31 (short notice, huh?) and plan on
going to the Van's factory in the A.M. I then have to drive over to Eagle
Creek on some business. I'll only be there for the day, but maybe we can
have lunch, or if you're close by I can drop by and see your project.
I'll also be in Phoenix on April 4th, and in Eloy the 5th-7th for a skydiving
meet. If there's anyone in the area, I'd love to say Hi! Also........ there
is an airport in Eloy, if anyone just HAPPENS to fly in there, I'd give up a
first born child (if I had one, but I'll certainly spring for lunch) for a
ride.
Ed Bundy
No, you do not put anything on the flat head side of the rivet. After you
are finshed riveting the normal way with a flat set and bucking bar, you
simply take a piece of wood and place it on the driven side (shop head) of
the rivet and tap the wood lightly a couple times with a hammer. The
cupping or indentation created by the flat set will get bent back out and
the surface will then be flat. Couple hints:
1. Slightly round or bevel the end of the piece of wood so you can
approach the rivet from a slight angle if required
2. Only do it on rivets. If you do it on the flanges between
rivets you will get dents in the skin the shape of your wood. This works so
well, one tends to get carried away and wants to use it in other places.
Trust me don't, I learned from experience.
3. Harder wood seems to work better than the softer ones; you don't
get little cups in the wood the shape of the shop heads. If you don't have
any hard wood go ahead and use a softer one - just refinsh the end once in
a while.
4. 3/4" x 3/4" by 6 to 12 inches work fine. A piece of dow would
work well too.
5. If you already have a back riveting set, try both approaches and
judge for yourself.
-- Rich
I use the same rivet set. When I rivet the thinner skins, I tend to get
very slight indentations the shape of the rivet set. I use the wood to
knock these out. Maybe it is my riveting technique or maybe I use too much
pressure (40-45 psi) ?? In any case, if you get them you can use the wood
to knock them out or you can back rivet to avoid them.
-- Rich
Subject: | Thanks to Jeff Hall |
Hello all--
I wanted to extend my thanks to Jeff Hall for showing myself and a
friend around his shop last night. Jeff's RV-4 is coming along nicely
and his workmanship is very fine IMHO.
Seeing a project underway where the workshop is very organized and the
builder's attitude is positive is a great motivator to those of us about
to take the plunge. The first ride gave me the permanent RV-grin, but
seeing a project underway really makes me want to start building. I'd
encourage all rv-listers to show off their project-in-progress... it's a
great motivator!
Also... I'm the one who initiated the "nose or tail" thread about a week
ago. Thanks to all who responded. I've decided to go for the -8. I
called Van's on 1/25/96. Sounds like the tail kits might be ready to go
by the end of April, beginning of May!
Rod Woodard
Loveland, Colorado
RWoodard(at)lawyernet.com
P.S. TO JEFF HALL: I've misplaced your e-mail address. Could you please
send it to me. Thanks... Rod
From: | "Richard E Steffens" <resteffe(at)dpcmail.dukepower.com> |
I back-riveted the top skins on both my wings using the Avery rivet
set. Worked great. I had no dings. Had to keep the mind and eye on
handling the gun and develop a good rhythm with the helper. Took a
little over two hours to rivet the top skins on the second wing. I'll
be ready to rivet the fuse skins soon and plan to back-rivet where I
can. It would help to have a bit more bend in the rivet set.
Dick Steffens
RV-6 North Carolina
*** snip ***
Vans Hotline - Short memories and lack of logging builder's comments!! I
still have an outstanding bet with Frank Justice (a pint of premium brew)
that Vans hotline does not log buiders problems in any consistent manner
(after my tip-up canopy/electric flap design error -- "you are the third
one this week") -- see the RV-list archives.
Did you talk to Ken "hit it with a bigger hammer" Scott, or Tom "just make
it fit" Green? .... :^)
Every local builder has had this problem on kits that date back over 2
years and as recent as 6 months old. One side is worse than the other.
The standard fix that Vans hotline recommends (funny they haven't heard of
it before, but they have a standard fix) is to move the baggage floor ribs
inwards until they fit. For one side this fix is either impossible, or
needs an excessive movement. Locally, most builders have been doing what
you say below, removing the flange, and riveting another flange in it's
place. This replacement flange can just be bent from some scrap 0.025
stock - no need to use 0.063.
Also, when you line up the bottom skin side flange of the baggage ribs at
the baggage bulkhead end, remember to allow for the 0.025 skin thickness of
the aft skins that will be "under" the baggage area skins at the overlap.
You are right, the parts don't meet the prints. Since all of the flanges
on these parts are straight lines, I suspect that they have been bent in a
brake, and not over hard tooling. My parts were shiny Alclad, not dull
like the parts that have been heat treated after forming.
>missing
It is happening to lots of others.
>Bruce Stobbe
...... wishing Van would actually log builders problems for
correlation and analysis. The two local builders at this stage are finding
_exactly_ the same dimensional errors I found 15 months ago.
... Gil Alexander, RV6A, #20701 gil(at)rassp.hac.com
Subject: | Re: pressure testing fuel tanks |
It's really not a big deal if you're careful. I used a fitting that
another builder had made that has a bicycle valve tapped into it and
screws into the quick-drain port. I put a balloon on the fuel pickup
port. I turned my regulator down to just a few lbs and stuck it on the
bicycle valve. It's easy to just give a quick "squirt" of air with one
of these valves to make sure it isn't going in too fast, but I found
that I had to turn it up a bit or it would take too long (a minute or
more) just to blow up the balloon.
Randall Henderson
RV-6
Subject: | looking for a friend |
I'm looking for an old friend, Lee Taylor. He's a CFI, works for the
railroad I believe and has moved to Colorado in the last couple of years.
If anyone can get me help on where to look I'd appreciate it. If you
happen to know him please give him my name a number. TIA
He use to live near Sacramento, CA. (me too)
Dan Boudro
2913 Rhode Island NE
Albuquerque, NM 87110-3705
home (505) 275-3179
office (505) 889-7241
fax (505) 889-7430
dboudro(at)nmia.com
RV-4 N9167Z
Subject: Hazards of Fire Extinguishers & A/C Engines
Subject: Hazards of dry powder fire extinguishers
Can anyone direct me to information on the hazards of using dry powder B/C
and A/B/C fire extinguishers around a/c engines? Thanks. Please reply to
lewisjw(at)hqsocom.af.mil
>>Matt Dralle
>>RV-List Admin.
>Hey Matt!
far
*** DITTO *** Bob Skinner
Subject: | Re: Exhaust system |
A As for putting anything inside the muff, (and I don't want to restart
> Becki Orndorff
Becki: Thank you for your very detailed replay. Yes, let's not get the
pipe wrapping thing going again.
I started with screen door springs wrapped under the muff, then switched
to an expanded steel put on in layers. I had 200 hrs on the mild steel
Vetterman system which I had painted with VHT paint. The paint was rubbed
off in a few places but did not really feel that it looked like any damage
was being done to the pipe, but it's something that should be inspected if
you are going to do it. I don't think I have room to hang anything more on
the firewall or instrument panel, so I think I'll try hooking two muffs up
in series.
Well said Rob! I couldn't have said it better myself.
YAY MATT!
Randall Henderson
RV-6
> Hey Matt!
Subject: | Cruise performance data |
>Date: Tue, 30 Jan 1996 15:18:47 -0600
>X-Sender: bs65802(at)mail.ltec.net
>To: BSkinner(at)ltec.net
>From: Bob Skinner <BSkinner(at)ltec.net>
>Subject: Cruise performance data
>Here is the cruise performance data that I've collected to date:
> Den % lean Ind True Cal
>Temp Alt Alt RPM MP Pwr to: A.S. Airspeed Notes
>53 4500 5200 1900 NA NA NA 82 81
>55 4500 5200 2270 21.3 62% peak 152 151.6
>55 4500 5200 2434 25 78 peak 165 164.6
>56 4500 5200 2614 25.5 88 100r 177 181.1 F.T.
>56 4500 5200 2614 25.5 88 100r 178 179.5 F.T.
>51 5500 6250 2350 21.3 65 peak 155 159.6 1 pas>1/2 fuel
>51 5500 6250 2450 24.3 78 peak 165 167.5 1 pas>1/2 fuel
>86 5500 8000 2465 23.8 75 b.p. 159 167.1 1 p/FF/*2nd prop
>52 5500 6250 2600 24.8 85 b.p. 175 178.6 F.T.>1/2 fuel
>86 5500 8000 2620 24.8 85 b.p. 172 180 F.T.*2nd prop
>46 6500 7100 2350 21 65 peak 154 158.9
>77 6500 9000 2440 22.3 72 peak 154 166.7 *2nd prop/1 hr FB
>47 6500 7100 2465 23.5 75 peak 160 167.7
>59 6500 8000 2560 23.8 78 b.p. 168 177.5 F.T.
>77 6500 9000 2580 23.8 82 b.p. 165 179.1 F.T.*2nd/1hr FB
>47 6500 7100 2580 23.8 82 b.p. 171 176.8 F.T.
>47 6500 7100 2600 23.8 82 b.p. 173 178.1 F.T.
>90 6500 10000 2630 23.5 82 b.p. 162 175.5 F.T.*2nd/1hr FB
>40 7500 8000 2350 22.3 68 peak 150 157.1 FF/1 210# pas
>40 7500 8000 2450 22.5 72 peak 157 164.1 FF/1 210# pas
>86 7500 11000 2470 22.0 72 peak 153 166.7 *2nd /1 hr FB
>36 7500 7500 2500 23.0 75 b.p. 163 170.8 F.T./ full fuel
>40 7500 8000 2520 22.8 75 100r 162 170.8 F.T./FF/210#pas
>43 7500 8000 2600 22.8 78 100r 174 177.6 F.T./ > 1/2 fuel
>86 7500 11000 2600 22.5 78 100r 160 177 F.T./*2nd/40min FB
>55 7500 8500 2720 22.3 78 b.p. 160 170.8 F.T./1/2 fuel-Fel
>36 8500 9000 2370 21.5 65 peak 148 156.6 1/2 fuel/210# pas
>36 8500 9000 2460 21.8 68 peak 154 166.4 1/2 fuel/210# pas
>40 8500 9200 2500 20.0 65 b.p. 147 157 Felix prop
>36 8500 9000 2505 21.8 72 100r 160 168.9 F.T.-1/2F.-210#pas
>NA 8500 NA 2542 21.5 72 b.p. 155 NA F.T. cruise
>40 8500 9200 2712 22 78 b.p. 160 170.1 F.T.-Fel Prp-1/2fuel
>70 9500 12000 2500 21 68 b.p. 155 NA F.T. cruise
>NA 10500 NA 2502 20.3 65 b.p. 150 NA F.T. cruise
>This is for my 150 hp, RV-6. Empty weight: 1080 Pilot wt. 210#
>*2nd= after the prop was re-pitched the 2nd time
>F.T.= Full throttle operation
>FB= fuel burn FF= full fuel pas=pasenger Fel=Felix prop
>The only effect I found that density altitude seem to have was on the
>difference between indicated and true, calibrated airspeed. Airspeed error
>was greater for higher density altitude (thinner air?)
>I should be getting my prop back any day now from the 3rd re-pitching.
>Hopefully, will get some improvement. I'd be interested in my fellow RVer's
>comments about the above. (Anything to keep converstaion going on the
>RV-list, right?)
>I envy all of you who get the right prop the first time. The more of this I
>go through, the more thought I give to putting a constant speed on the 6-A
>I'm building now. I might even put one on this 6. When the weather gets
>warmer, I might even try to find an old governor and wee if it fits the
>recess I made in the firewall. The only other problem I have with a
>constant speed is that I would have to go to the Hartzell with the 3.8 G
>restriction extension. This would probably hurt the resale value, right? I
>wouldn't face as much of a weight penalty as one would think. I have the
>Landoll harmonic dampner on and I made a 1/4" extension plate for my front
>spinner bulkhead out of steel to help with the aft CG problem.
>Boy, I wish I could figure out how to format this thing in Eudora. I've
been sending a copy to myself and it looks good going out and comes in
goofed up. I'm so frustrated, I think I'll go work on my airplane. Bob
Skinner
Subject: | RV Archive Search Engine -Reply |
That FTP site won't let me access it. I am
trying to use anoymous login.
Subject: | Re: Tailwheels are easy |
SHHHHH! Dammit, you want EVERYONE to know???? There goes my "taildragger
pilot mystique!"
Randall Henderson
RV-6
I am a newcomer to the list, but I would like to thank Matt and echo Rob
Lee's resent message. Although I wondered at all the garbage coming in, I
appreciate all those that volunteer to provide the service and learned a lot
puzzling over the cause and seeing the resoloution. I already feel I know
some of you after reading teh mail for just a few days. Hope this is the
place to introduce myself by providing a profile and list my
interests/concerns with my RV6 project.
Profile:
Peter Hanna, 2-425 Kingscourt, Waterloo, Ont., Canada, N2K3R4, H 519.746.9882
B 519 746 8483 X224, Business email: peterh(at)rdmcorp.com
I have taken over an RV6 project; wings and tailfeathers were done. I am
starting fuselage, firewall complete; just aquired a jig. Plan on a sliding
canopy and an IO-320 160, CS. I have done some metalwork and riveting, but I
already feel the lack of experience in not having built the wings and tail.
Also own a modified L2-M Taylorcraft which I have flown for 23 years and
rebuilt 10 years ago.
Immediate interest/concern: Smoking rivets at the base of firewall; Any
ideas on beefing up structure of cabin floor or sidewall between firewall
and spar, in addition to more rivets than the plan calls for? Loose rivets
here seem likely due to the structure's inability to absorb the strain of
rough field landing gear loads and/or heavy engine + prop. Is anyone
considering thicker skins, 1/8 rather than 1/16 stiffners in floor,
additional structure, etc?
General interest:
1. A four-into-one exhaust system for increased power and noise reduction.
Has anyone put one on a 6?
2. Front injector and inlet in lower front of canopy.
3. Quietness inside through sound attenuation materials.
4. Sealing the sliding canopy and any other drafts.
5. Seat material to provide both comfort and visibility over nose.
6. Any ideas on drag reduction, such as restricting cooling airflow with
cowl vents in cruise, fairings at the wing junction, alternatives to springs
and chain to tail wheel, any "lopresti" type improvements.
7. Availability of a simple angle-of-attack indicator, or a design for one.
From: | Gary Standley <Gary_Standley(at)ccm.ssd.intel.com> |
Subject: | Re: Certification procedure |
Text item:
NOW IS THE TIME TO GET FRIENDLY WITH THE FAA INSPECTOR AND FIND OUT WHAT THEY
REALLY WANT. I HAVE HEARD OF DIFFERING REQUIREMENTS DEPENDING ON THE INSPECTOR,
AREA OF THE COUNTRY ETC. SINCE THE FEDS HAVE THE FINAL WORD THEY ARE THE BEST
SOURCE AS TO WHAT THEY WILL REQUIRE. ANOTHER THING YOU CAN DO IS CONTACT AN RV
COMPLETER IN YOUR AREA AND FIND OUT WHAT THEY HAD TO GO THROUGH. IT CAN BE VERY
SUBJECTIVE ON THE PART OF THE INSPECTOR.
Dan Shades
dls27(at)psu.edu
Text item: External Message Header
The following mail header is for administrative use
and may be ignored unless there are problems.
***IF THERE ARE PROBLEMS SAVE THESE HEADERS***.
Subject: RV-List: Certification procedure
Date: Tue, 30 Jan 1996 10:30:46 -0500
tel.com (8.6.12/8.6.12) with ESMTP id NAA07984 for <Gary_Standley_at_hfccm4@ccm.
From: | justjas(at)applevalley.mn.frontiercomm.net |
Subject: | RE: Tailwheels are easy (most times) |
IMHO tail draggers are great when the wind is calm or down the runway. With a cross
wind it is another story. My experience is 70 recent hours in a Citabria,
so this may not apply totally to an RV. My point is that tail draggers are FUN,
but they are not nose wheelers and complacency should be avoided (as is the
case in any flying activity) lest you become the next "ground looper."
I got my tailwheel signoff with only fours hours dual in Mike
Seagers RV-6. At the time I had about 75 hours total time. I would not
fly in a 25 kt crosswind, not sure you can taxi an RV-6 in that kind of
wind. But for sport flying, an RV-6 is not that hard to land or takeoff.
Backing my C-172 into a tight hanger is much more difficult.
Bob Busick
RV-6
> Best regards,
> Dave Barnhart
> rv-6 sn 23744
Subject: | Re: RV-List- RV photo wanted |
Reply to: RE>RV-List: RV photo wanted
give me your email address... I have just the shot for you...
Doug
dougm(at)pogo.wv.tek.com
Date: 1/30/96 2:34 PM
H E L P !
Formation ???
That RV grin ???
Andy Gold
Easy Publishing
328 Luscombe Dr
Los Lunas, NM 87031
(505) 865-3466
------------------ RFC822 Header Follows ------------------
Date: Tue, 30 Jan 1996 10:08:54 -0500
Subject: RV-List: RV photo wanted
> pilot mystique!"
(Chuckle) I'm drooling with anticipation of the day I can taxi up to a
bunch of my nosedragger friends, cut the mixture while booting the left
rudder to unlock the full-swivel tailwheel, coast to a top at the end of
90 degrees rotation, and slide the canopy back.
Ah, yes!
Best Regards,
Dave Barnhart
rv-6 sn 23744
a
for
I
Couldn't have said it better...thanks from me, too.
Dana Breda
N138DB
Subject: | Re: Thanks to Matt |
A
>General interest:
>Peter: I have a few smoking rivets on the angle stiffners on the belly,
none around the firewall. On the one I'm building now, I'll probably dimple
instead of machine countersink, space the #3 rivets closer together or
possibly use #4's.
Exhaust-I'm pretty much a Larry Vetterman, High Country Exhaust fan. I
figured that these airplanes take long enough to build with out me having to
experiment with exhaust systems. Everyone I've talked to has high praise
for Vetterman's system (stainless steel cross-over).
I chose not to install any type of sound deadening material in the cockpit
and instead bought a Telex 4000 ANR. Saves a little weight and I felt there
was more bang for the buck (and a greater chance of saving what's left of my
hearing) by buying a good headset.
I used the 3-layer Temperfoam seat cushions and a sunmate 1" back cusion.
I overlaid these with generic 2" med density foam. I flew the 40 hr test
period with the Temperfoam stuck in a pillow case. I was disappointed with
the comfort. I purchased this foam for safety reasons but also because
people said it was confortable. Hence, the 2" additional layers-installed
for comfort only. In the winter, Temperfoam is as hard as a concrete park
bench. Takes awhile for your body heat to cause the foam to form.
Bob Skinner RV-6 flying RV-6A building
>> pilot mystique!"
>Ah, yes!
>Best Regards,
>Dave Barnhart
>rv-6 sn 23744
The problem is, you can do some of those turns when you aren't trying to.
Then you can slide the canopy back, hop out and go get a change of clothes.
Come out to Nebraska (Motto: "Wyoming ain't got nothin on us") and we'll go
flying in a 30 kt wind.
(Note: Bring your own taildragger, you can't fly mine.) Heh heh heh. Bob
Skinner
From: | ammeterj(at)ammeterj.seanet.com (John Ammeter) |
>> pilot mystique!"
>Ah, yes!
>Best Regards,
>Dave Barnhart
>rv-6 sn 23744
Yes!!! YES!!! That is the true feeling of mastering and flying a
Taildragger. None of that 'let the plane land itself' Cessna hype; it takes
a _real_ man (or woman) to land a Taildragger. People will fall to their
knees in awe as you step down from your RV Taildragger. You won't be able
to buy that $50.00 hamburger; the masses will be falling all over themselves
as they compete for the honor of sitting at your table and treating you to
whatever you want. Hamburgers------no, they'll be buying you steak -n-
lobster as they bask in your shadow.
Ah yes, the mystique of the 'Taildragger'; never let anyone attempt to
discredit the skills and abilities needed to master the secrets of the dance
of the two feet. Nose dragger pilots, and I use the term 'pilots'
generously, will never appreciate what they have not experienced.
John Ammeter
Seattle WA, USA
RV-6 N16JA
Flying 5 years
From: | bcon(at)ix.netcom.com (Robert M. Cornacchia ) |
Subject: | Re: HVLP gun from Harbor Freight |
You wrote:
>Hi Folks,
>about fininhing).
Spray
>name?
soon
>Bill Costello
> ___ _______________________
> \ \ _ _ / /
> \ /? \ / \ / Bill Costello \
> X-*#####*******......./ Chicago /
> o/\ \ \_\ \ RV-6 on emp. \
> \__\ \ bcos(at)ix.netcom.com /
> \______________________\
Here's another question that could be answered locally if you would
ask. I have had the fortune to see this gun work. The painter that
comes in the shop to paint our Jetski's has one of these guns. It works
great. The gun in Harbor Freight catalog is a central pheumatic and he
uses it for finishing with good results. If you would like to talk to
him let me know and I will get you his phone number.
Bob Cornacchia
Subject: | Re: Engines Weights |
Randall:
Thanks for you comments on the engine/prop question. I'm leaning toward the
fixed pitch prop initially, largely for cost but also for handling
considerations (aeros). Is it realistic to think about starting with a
fixed pitch prop and then perhaps switching to CS down the road, or would
the change be horrendous? I guess the main concern I have about changing
to a CS prop later are choosing the right engine initially; are there
other big considerations I'm missing?
Can anyone provide any information about the cost and effort of
maintaining a CS prop relative to a fixed pitch prop?
Tedd McHenry
Edmonton, Canada
tedd(at)idacom.hp.com
> I got a chance to see a beautiful setup of an IO-320 in a Lancair
> this weekend. One of the things that caught my eye was that the
> builder had wrapped all of the exhaust system, from the exhaust port
> down the stack to the bottom of the cowl including the cabin heat
> muff, with a heat wrap. He gave
> two reasons: 1) the tightly cowled Lancair needs all the heat
> protection it can get; and 2) maintaining the temperature of the
> exhaust gas in the pipe helps with horsepower. He says this is
> because exhaust gas slows as it cools, and that causes back pressure
> at the cyl. He wants the exhaust gas to retain as much heat as
> possible until it hits the air under the airplane.
> Makes sense to me, but so does the flat tax so what do I know? Any
> of you engine types have comments?
> He says the wrap can be purchased from Spruce and he used it on his
> race cars. I asked if he was worried about not catching any cracks in the
> exhaust system because of the wrap. He's not but I think I would be.
This is very commong practive with race cars. I don't know what the
power gain is, but few people in racing seem to question the validity of
it.
However, I have heard that it does accelerate the rotting out of your
exhaust system a lot, because of the much higher temps the steel is
exposed to. I wouldn't use it on an airplane for that reason. (The
racers know how to make power, but cracked headers are not uncommon!)
Tedd McHenry
Edmonton, Canada
From: | Ronald Vandervort <rvanderv(at)linknet.kitsap.lib.wa.us> |
Subject: | Tech Advisor, Att. John Ammeter |
I lost your e-mail address, if I had it, John.
The RV-8 in addition to the 6 and 6A..yeah that's tempting...!
As I am about to close up the skin on my horizontal, and seeing the
question about tech inspection posed by another builder: I ask you, do I
need some expert to look in on my horizontal before I close it up? I am
keeping a log of my activities as I go with pictures and signatures.
I live at Apex. Drop in sometime with that nimble aeromachine of yours.
I'll hide the RV-6A parts...!
Ron Vandervort
From: | bcos(at)ix.netcom.com (William Costello ) |
Subject: | Bob Gibbons Archive Search Engine |
Hi Folks,
I have downloaded, decompressed, installed and printed out the info
sheets on Bob Gibbons' Archive Search Engine program (very impressive
documentation, Bob). Sure looks like it is JUST what I have been
hoping for.
However, I don't know where to get the RV-Archive.digest.complete.zip
file. Looks like roxy.llnl.gov is out of business. At least, I can't
get to it via Anonymous FTP. (Seems like info about this was on the RV
List a while back, but can't remember -- sorry, guys, too much priming
in close quarters. Also, if I just had this search engine, I could
find the message . . .).
Also, Bob mentioned that someone was qoing to put the archive file(s)
on an FTP site in the near(?) future. Is there a way to get it right
now? Not the UNIX version -- can't deal with that. Thanks for any
info.
\ \ _ _ / /
Gil, I agree about the LENGTH of the ribs, but as I read it he has
problems with the WIDTH. Haven't heard of this before. I wonder if he
has them in the right sequence?
Peter Bennett
Sydney Australia
RV6 skinning fuselage
the
is
> >missing
> >Bruce Stobbe
Subject: | Re: RV6 stuff (was Thanks to Matt) |
To help you stop worrying and start building....
I understand smoking rivets are seen on RV4s used for aerobatics.
Bill Benedict advised no evidence yet on -6s as they are beefed up at
the firewall/fuse join compared to the -4. Nevertheless he advises
1/8 rivets around bottom front skin, not just firewall. Floor
stiffeners of 1/8 are useful to reduce noise generated by floor
drumming. Plywood panels between stiffeners also help.
I have made a leading edge stall warning indicator but haven't flight
tested it. It works down to below 70kph (~40 knots) out the car
window! Will get around to drawing it one day as I have to get it approved by
a licenced engineer. It looks a bit like those used here on Cherokees
and uses a photo-optic switch interrupted by the tab and driving a
simple oscillator in the cabin. Otherwise it uses scrap 2024 and PVC
drain pipe.
Peter Bennett
Sydney Australia
> General interest:
>>> pilot mystique!"
>>Ah, yes!
>>Best Regards,
>>Dave Barnhart
>>rv-6 sn 23744
SNIP>
>John Ammeter
>Seattle WA, USA
>RV-6 N16JA
>Flying 5 years
Chuckle, Chuckle, ..... I'm sorry, but you have to permit those of us that have
a "few" more hours with the little wheel in the back to sit back and smile.
Yea we all learned and you can too. But time will teach you something else
about a ship with a wheel on the tail. RESPECT.
I don't have a billion hours in a coventional (yea tailwheeled birds are
conventional) aircraft, but I've flown a bunch of different ones and they
vary all over the board in "pucker factor".
Here's my sampler...The RV is (IMHO) a 3 on a 1 to 10 (10 being the
toughest ) The champ is a 4, citabria & decathlon a 5, skybolt with 540 a
7, luscombe an 8, Pitts a 9, and a Beech 18 with the left one out, off the
scale.
The funny thing is on a given day for no known reason any of the above can
act up and scare hell out of you. There is a a local faa examiner (That
shall go unnamed) that has a billion hours in taildraggers and gives
checkrides in among other things DC-3's that recently lost a champ while
checking out a new guy. Lost it on a take off and it wasn't even windy. Go
figure.
Any way....just about anybody can learn... and I keep learning.
But I still have to smile.
Regards:
Rusty Gossard
N47RG RV-4 Flying
Subject: | Interior Finishing |
Peter Hanna raised the subject of interior finishing and sound
deadening. George and I have finished two planes of our own and here is
what we learned from the experience. Many of you want to keep your planes
light so won't put full interiors in. We have found, with the fabric on the
sidewalls, 1/4" foam panels beside the occupants (covered with fabric) and
carpet on the floor (over two layers of sleeping bag underlayment roll to
fill up to the top of the floor stiffeners in a 6) that the noise level in
the cockpit is very reasonable and climate control is much easier and more
efficient. The sleeping bag underlayment is a roll of 3/8" foam used under
sleeping bags and available at outdoor and camping stores. Many times I
remove my headset while George taxis over to the gas pumps and am not
uncomfortable at all. We also used a foam to insulate the firewall which
helps to reduce noise.
We have also discovered that the comfort of the seats is more
contributed to the shape of the seat than the foam the seat is made of. Our
first plane used temper foam and it was hard as a rock in cool weather.
Also, because of the shape of the seat bottom, I was squirming after 90
minutes. Our second plane uses a medium density foam with the seat bottom
at a different angle and we have flown for well over 2 1/2 hours without a
thought of squirming. Unfortunately, we haven't taken this plane on a long
trip yet, so I can't say how 3+ hours will be, but from the current
experience I think my first requirement when we arrive will be the restroom,
not a chiropractor. When we build seats for others, we strive to build the
seat bottom so the pilot's head will be only a couple inches from the
canopy, giving the best visibility and leaving room for turbulance. When
the seat bottom gets beyond a certain thickness, we use a very firm foam on
the bottom of the cushion to prevent the continued compression that occurs
with only medium weight foam.
As for sealing the sliding canopy, getting the rear skins as tight as
possible seems to be critical. We shimmed the frame while fitting the skins
so when it was closed it would fit that much more tightly. And we did do
two sets of skins before we got it right.
Becki Orndorff
Becki Orndorff
NCI-FCRDC, Computer & Statistical Services
Subject: | Re: Tailwheels are easy -Reply |
>>> David A. Barnhart
01/30/96 08:34pm >>>
the day I can taxi up to a bunch of my
booting the left rudder to unlock the
end of 90 degrees rotation, and slide the
canopy back.
Ah, yes!
Yes, after planting a wheel landing and
motoring up the lenght of the runway tothe
taxi way with the tail held up. Just don't
over swing the tail and knock over the fuel
pump.:{
Jim
RV6 skinning wings
Subject: | Re: Bob Gibbons Archive Search Engine |
>Hi Folks,
>hoping for.
>info.
> Bill
Okay okay! I wasn't quite ready to announce it yet, but the archives are now
available at "ftp.matronics.com" under "/pub/business/matronics". You
should see a significant increase in performance on the new site as well. I
plan to add Bob's search engine to the site as soon as I get a chance. In the
interest of conserving space on the new ftp site, the only versions of the
archive that available are the digested files. The complete version is
available in a couple of version and then there are the small, broken up
versions. Let me know if you have any problems. I will still officially
announce the site later when the search engine is available there.
Happy downloading,
RV-List Admin.
Doug,
My E-mail address is PFPA(at)aol.com. Thanks in advannce for the picture.
Andy Gold
I can't speak from experience, so this advice is worth what you pay for
it. Here's what I know: For a CS prop you need an engine with a hollow
crank; some engines have them but there is a plug in the end for fixed
pitch props and you can take it out for CS. Others have a solid crank
that will have to be replaced.
CS props I THINK have something like a 500 hour TBO, I don't know what
it costs, but I suspect it's something you want your local prop shop to
do instead of doing yourself.
It is certainly possible to start with a fixed pitch and change to a
CS. There are a few guys around here who have done this, but probably
just as many who intended to do so but just haven't been able to bite
the bullet and make the change. I don't suppose it's trivial, but
neither is building an airplane :-)
I'm not so sure about handling -- my experience with aerobatics
(admittedly not much) is that you can do a lot without yanking the
plane around or pulling many Gs. And with a fixed pitch it can actually
be EASIER in some ways, since you just set the throttle and the prop
changes pitch as you climb or descend so it won't overspeed. I've flown
with Bill Benedict a lot and he does some nice stuff in the factory
RV-6T/ fixed pitch. But as I say, my experience is pretty much limited
to looking/riding at this point.
Randall Henderson
RV-6
Subject: | Baggage ribs (was: RVs and ice) |
>Peter Bennett
>Sydney Australia
Peter, it is a width problem.
There is also a length problem, but I didn't mention that because
it is quite easy to rebend the ends (the aft end in particular) to the
shorter dimension needed, as well as re-adjusting the angle of the aft end.
This is impossible - at least for me - on the longer lengths of the skin
flange. I could have forced one side to fit, but the other side was over
1/8 in out (in the width direction of the part), so I just cut both
flanges off and riveted a bent 0.025 angle on. I used 3/23 rivets and kept
the same spacing as the skin rivets for no strength loss. The compromise
here is between a flat bottom skin and a flat baggage floor.
Again, I think these parts were bent in a brake one flange at a
time, and we are just seeing the effects of a sizeable batch of bad parts.
The print dimensions do seem better than the part dimensions!
The other local error on almost all of the -6 fuselages is the
outer seat ribs (F-615 L&R) being about 1/8 low. I am guessing that folks
either distort the seat pan down as they rivet/bolt, or add 1/8 shims to
it's upper flange.
... keep on skinning .... Gil Alexander
RV6A, #20701 ... plexiglas (waiting for a warm
day) and interior stuff
>>wide at the
>>rib is
>> >missing
>> >Bruce Stobbe
I've updated the RV search program to GPF on anyone who calls me Bob.
Not that I have anything against the name Bob, it's just not mine.
BF Gibbons
SNIP...
>Tedd McHenry
>Edmonton, Canada
Ted:
I run an HC C2yk Hartzell on my 180 hp 4.
You need to have an engine with a governor mount pad and a hollow crank.
The designator on a Lycoming is "1" as in 0-360 A1A. You can mount a fixed
pitch to
a hollow crank but there are some things you do that make it hard to go back
and put a C/S on later. If you are going to do it, do it from the start as
there are cowl considerations. You can change, but again its work.
As far as care and feeding....anual maintenance is no big deal. Inspect and
grease. TBO's vary but usually are 5 years or 500 hours suggested.
Governors are 2000 hours. Hartzell will get mine at 500 hours. I have not
priced it. It's worth whatever they charge.
Aerobatics....most competition aerobatic aircraft have C/S props. It's
the way to go. Basically it helps you go up and slows you going down. Nice.
Performance.....I.M.H.O. the only way to go. I've flown RV's with fixed and
they are nice but the C/S is great. Climbout is spectacular, you don't wind
the engine out at altitude, you can slow the aircraft better, but all this
costs $$$$$. It's a personal decision.
Whatever you do, you will have a great airplane.
Regards:
Rusty Gossard
N47RG RV-4 Flying
Any of you guys back drill the wing skins? If you did, did you do the whole
thing, or just the top and bottom hole of each rib then line the holes up,
measure, and drill the skins?
Howard Kidwell
howardrv(at)aol.com
Subject: | Re: Engines Weights (fwd) |
Whom ever had the question on CS vs fixed pitch.
Now that Van's had standardized on one cowl (the CS cowl) it will
make it easier to change back and forth between FP and CS.
There use to be two different cowls; FP and CS.
The fixed pitch used a 4 inch extension.
Now Vans is just using the CS cowl and therefore you use something
like a 2 inch extension for the fixed pitch prop.
You of course have to have the proper engine setup to go to CS
(right crank and the prop governer).
Herman
Herman Dierks, Dept. E54S, AWSD, Austin, Texas
mail: dierks(at)austin.ibm.com
From: | "Elon Ormsby" <Elon.Ormsby(at)quickmail.llnl.gov> |
Subject: | Exhaust wrapping |
REGARDING Exhaust wrapping
Even though I am opposed to wrapping an exhaust system - for the very same
reasons there is merit to consider wrapping your heat muff(s).
The wrap slows the heat transfer (i.e., radiation/conduction) through your
tubes and they cook at much elevated temperatures - drastically lowering
their cycle life. However, for the heat muff(s) this is exactly what you want
to do. The idea is to impart as much heat to the muff air as possible. By
slowing the transfer of the heat through the muff outer shell it will run
hotter. Wrapping is the only way to do this. Of course, deterioration will be
faster than an unwrapped part but the outer shell is a non-critical part (if
it leaks) and inspection and/or replacement is easier compared to the exhaust
system. Elon.
This is NOT the case. I have seen an early effect on a -6A, and the
previous RV-list archive discussions will point you to many references of
this on -6 and -6As
Early -4s had actual structural failures in this area, at least we
are only talking smoking rivets here ... :^)
This is interesting. there has been no plans update distributed to
change these rivets. 3/32 are still called out on the firewall flange.
1/8 have always been called out along the sides of the floorboard skins. I
am interpreting "around bottom front skin" to mean that the floorboard
rivets to the F-604 main bulkhead are now recommended to be 1/8 - the plans
still show 3/32 at this skin overlap??
Question for Portland locals:
Has Van stopped giving plans updates in the RVator? I think there
have been none in the past 3 issues.
If so, how are plans updates getting distributed.? Are slower
builders just missing out on updates since everyone now gets a "fresh" set
of plans with every kit, and no further info?
Any other factory "recommendations" around there not published to
the world?
Gil Alexander ..... RV6A, #20701
*** snip ***
>Peter Bennett
>Sydney Australia
*** snip ***
Subject: | Search Engine by B F Gibbons |
If you haven't tried his new archive search program, give it a whirl.
I think he deserves the most useful rv-list tool of the year award. :-)
Maybe someone could convince Van's Aircraft to hand out a free rv for the
best rv-list tool award. (yeah right)
Either that, or maybe award a golden rivet. hehe
Great job Sir, I think this archive search tool is gonna come in really
handy when I get further along in the project and start needing questions
answered that have probably already been beaten to death. (kinda like the
primer thing :-)
-Steve Day
sday(at)pharmcomp.com
(CK ID - RV6a RV for short)
Subject: | Re: Engines Weights) |
(Randall Henderson) writes:
I've had the C2YK CS from the beginning. I also have the ORIGINAL cowl which
had to have 1 3/4 inches removed from the rear to accomodate the non-extended
CS prop. I have considered going to a fixed pitch prop for reasons below.
Problem is that the standard prop extension from Van's put the prop too far
forward. So I would have to mess with the cowl, or get a special extension
made. So I scrapped the plan. I'm not sure what Van is selling now, I heard
that it is a shorter cowl than the original. SO he must be providing a
shorter extension. SO, maybe new builders have the option of either prop
with the same cowl.?? Doesn't help me much.
After flying several 6's and 6A's with a variety of props I conclude that I
like the way the airplane handles better with a fixed pitch prop. It's a
distinctly different feeling airplane and the differences are somewhat hard
to describe. The fixed pitch feels more agile to me, meaning that the a/c
changes direction and attitude more quickly and easily. The CS a/c feels a
little more like a Mooney, except not nearly so heavy on the controls.
I like my CS a lot because of the pitch range. At cruise power settings you
will have considerably less noise and vibration than the FP running at your
same airspeed.
Since most of the FP props have much more blade area, you will have a double
advantage at altitudes where the air gets thinner. All things considered
(including the variety of props available) I think the CS is still the best.
Since I have a 180, the range of props available to me is less than those
with the 150/160. Of course some are not averse to using the re-made metal
props which perform very well, but they have lost their appeal to me. Martin
Sutter in Dallas has a certified wood Sensenich on his 180/RV6 which was
designed for that aircraft. It has much larger blades than most of the other
wood props you see, and he reports good numbers on it.
Jim Stugart
From: | Frank K Justice <Frank_K_Justice(at)ccm.ssd.intel.com> |
Subject: | Baggage ribs too wide, RV6 |
Text item:
Van's has heard of the problem described below and they have several opininons
depending on who you talk to. It is actually not a big deal if the floor is not
flat, but if you want it to be, move the outer baggage ribs inboard a little bit
from the location shown in the plans and they will be the right width. The parts
are made on a mold which has not changed; some people have noticed the problem
but most have not since the discrepancy is small and the result insignificant.
And no, Van's still does not log problem calls.
FKJ
>Peter Bennett
>Sydney Australia
it's upper flange.
>>wide at the
>>rib is
formed in the
>> >missing
>> >Bruce Stobbe
Subject: RV-List: Baggage ribs (was: RVs and ice)
From: rassp.hac.com!gil(at)matronics.com (Gil Alexander)
Date: Wed, 31 Jan 1996 12:08:07 -0800
4.1)
Fellow builders,
I'm starting the elevators real soon and have purchased the electric
trim option. I would like your inputs on location of the servo vs. the
factory method. I've read about fuselage mounting with custom cables.
Any and all inputs appreciated. TIA
Ed Cole RV6 24430 Empennage
ecole(at)ix.netcom.com
I taped the skin in place and drew the outline of the ribs on the
inside of the skin. I used a red sharpie for the flange side and a
blue sharpe for the web side. Removed the skin and marked where the
holes were to go by Measuring 5/16 from the red line and drew a center
line. I then used a template to mark the cord-wise location of the
holes. Drilled the skin undersize (#45) on the bench. Put the skin
back in place and drilled #40 through the #45 holes and into the ribs.
All of the holes ended up on the center line of the rib and only one
didnt hit the mark that I had on the ribs. That is to say, not more
that a sharpie line width off from where I planed for the hole to go.
I also made some small clamps from .032 that work great to hold the
main skin flat against the main spar. See the Dwg. below.
This Dwg assumes that the LE skins have been drilled to the spar.
Slide one of these things on a cleco and put in a hole in the LE
skin. This keeps the main skin pressed in place while you locate it.
Bend the ends of the clamp to allow sliding the main skin in place
from below. If you drill a #40 in one end, and a #30 in the other,
you can use them for both sizes of cleco. I made about 20 of the
clamps and used one every 10 inches or so along the skin.
Chris
| <--- LE skin
______ | _________
Spar-->||| <---Cleco Here | o |<--- Drill #40 here
||| <---Clamp | |
||| | O | <--Drill #30
||\ |_________|
| <--- Main Skin
> Thanks
> Howard Kidwell
> howardrv(at)aol.com
Subject: | Smoking rivets?? |
What are "smoking rivits"????
Finn
Subject: | Re: Baggage ribs (was: RVs and ice) |
umm....
Just in defence of Van's aircraft. I think this problem might be fixed. My
fuselage kit (shipped in June 95 seems to be OK. The bottom skins are on and
if I lie a straight edge along the baggage floor it looks OK too. I had
been warned about the problem and spent an anguished night searching for the
misfit when it wasn't there.
Leo
>>Peter Bennett
>>Sydney Australia
>it's upper flange.
>>>wide at the
>>>rib is
in the
>>> >missing
>>> >Bruce Stobbe
From: | "Earl Brabandt" <cwbraban(at)ichips.intel.com> |
Randall sez:
Hartzels often get overhauled at 1500 hours or 5 years whichever
comes first due to a now rescinded AD. Costs vary, but $1k isn't
unheard-of. Corrosion was the original impetus behind the AD but
anti-corrosion processes at Hartzel have improved the situation such
that few problems have been found in the field recently. By the way,
if you fly a lot of x/c, you should be able to pay for your prop
overhauls in fuel savings with a C/S prop.
All-out aerobatic airplanes generally have constant speed props because
they don't require attention to prevent ergine overspeed and they produce
more drag in a dive helping to limit airspeed and the extra prop disc
mass is desirable for gyroscopics. The RVs aren't all-out aerobatic
airplanes though. Still, I'll second Randall's previously posted opinions
on c/s prop merits. My personal order of preference is a 180 HP w/ CS
first. Next would be a 160 HP w/ CS and lastly, anything with a
fixed pitch prop.
An interesting factory airplane comparison is a 180 HP Mooney
against a 180 HP Grumman Tiger. The service ceiling of the Mooney
is about 4000' higher and it typically climbs about 200' per minute
faster. It's also usually about 10 mph faster in cruise than the
Tiger particularly at high altitude where the Tiger loses horsepower
to the Mooney because its prop can't spin fast enough to allow the
engine to produce as much power. Is the performance difference due
to the clean aerodynamic, retractable design of the Mooney? Partly yes,
but I suspect that the bulk of the performance edge is due to the C/S
prop of the Mooney over the fixed pitch prop of the Tiger.
Cal
Subject: | Re: Baggage ribs too wide, RV6 |
MAIL DELETED BECAUSE OF LACK OF DISK SPACE
RegarFrom owner-rv-list Wed Jan 31 18:00:00 1996
Date: Wed, 31 Jan 1996 20:34:28 -0500
Subject: RV-List: Emp Skins For Sale
I have a set of .016 RV-6 Rudder and Elevator skins for sale at a very
reasonable price. If you are interested contact me directly at
RFLUNKER(at)AOL.COM
From: | James Kelley <72466.1355(at)compuserve.com> |
Subject: | Re: Back riveting top wing skin |
> However, I started using
>a technique I think was mentioned by Don Wentz (??) that essentilally
>obviates the need to back rivet; rivet the normal way and then use a
>piece of wood ( I used a 3/4"x 3/4" x 12" piece of oak) and lightly tap the
>rivets from the shop head side with a hammer. The indentations that
>normally occur from front riveting disappear and you get a nice smooth
>surface, and it only takes a couple minutes. I've done my whole fuselage
>this way and all the skins are just as smooth as my back riveted wing
>skins.
I talked to a builder in Blairsville GA and he did something like the above
idea. He used the rivet gun and placed the flat set to the shop head letting the
gun gently push the skin back out. I guess that a piece of wood would have the
same effect, just in slow motion and maybe with more control. Sounds like an
excellent idea though, I'll be trying it when the time comes.
James Kelley (Building main spars.)
Atlanta, GA.
From: | "Thomas N. Martin" <103212.65(at)compuserve.com> |
I have about 400 hours on tail wheel aircraft over 10 years. 85 hours is in my
new RV-4.
I had forgotten how much "status" there seems to be with tail wheels. I would
not let pride get in the way of deciding whether to go with a 6 or a 6A. The
RV-4 is an easy aircraft to handle on the ground. In your first hour or so of
check out it seems that you will never get it right. And then of course you do.
NEVER forget that when you least expect it a tail wheel aircraft will make you
feel like you are in your first hour again. Enough said on this topic IMHO
Tom Martin
Subject: | Re: RV6 stuff (was Thanks to Matt) bad header info reply |
conserns cracked fusaloge skins
I know of at least one person in the Bakersfield EAA bunch who installed a
couple of extra longerons to "stiffen up" the belly skins and stop oil canning.
He would up with cracks in his fusaloge skins. Said that the problem was not
carrying them all the way to the bulkhead. I havent checked back with him
lately to see if he's had any more trouble or if his fix worked. In any case,
if you start stiffening things up you better be sure you have some place for the
stress to go else you'll have an unpleasant supprise. By which I mean be real
careful changeing the design.
Bill Lea
>the world?
Gil
Actually us *Home Wing* guys (Portland Rvators) just keep all the good
secrets to ourselves, all the neat little tricks that we learn from the
master himself as we go to breakfast with him on Sat. Morns. and and to all
the local flyins, we do this so our airplanes are better than the rest of the
worlds. :=).
In reality you learn about updates about the same way we do here, either by
word of mouth or if there is something in the RVato or through our local RV
builders group.
I will try to get a answer for you this weekend from one of the people who
work for Van or maybe from Van himself.
Jerry Springer RV-6 N906GS First flight July 14,1989
Subject: | Re: Smoking rivets?? |
>Finn
Finn:
"Smoking rivets" are rivets that have loosened up in service and
vibrated in their hole to the point where a trail of aluminum dust,
resembling smoke, has deposited on the skin downstream. The ominous
connotation is rightly diserved as, to me, it indicates a serious deficiency
in structural integrity in the spar to firewall area. All the stresses of
the wing carrying the heavy engine around pass through here, as well as the
(perhaps much greater) stresses in the opposite direction of the weight of
the aircraft, passengers and fuel during a hard landing. This is occurring
at alarmingly low hours on an airframe we expect to last many thousands of
hours.
What say we compile a database on aircraft showing sighs of loose rivets
including: hours, model (4,6,6A), engine, prop, aerobatics or no, field
environment(rough, pavement, etc.), landing incident history, landing
technique, what else? I assume Van's could use this data, along with some
structural analysis, to guide them to an official fix and drawing change. I
will volunteer to start a spread sheet and keep track if you all think it's
a good idea.
H 519.746.9882, B 519 746 8483 X224, Business email: peterh(at)rdmcorp.com
RV6, started fuselage.
I'm just getting started with the building of an RV6. This is the tool
procurement stage. I will order the empanage in April. Will I need a
band saw? Will a Sears & Roebuck 1/3 HP 10" Constant speed do the job?
What items will need to be cut? I told you I was just starting. It's
hard to read the small size drawings in the review package.
Thanks in advance. This listing is very helpful. I liked the comments
about conventional aircraft pilots. I currently own & fly a
Luscombe 8A. I can't wait to get behind an RV6.
Gary Tree
Subject: | Search Engine Instructions |
I have posted instructions in word perfect (yea, right) format for those of you
who requested it. The file is wpinstr.zip on ftp.intellinet.com
pub/users/bfgibbons/rvsource. The rvsearch.zip file now only
contains the exe. wordinst.zip is the word file.
Thanks to everyone who offered thoughts on my questions about engines and
props. I'm really early on in the process (still preparing my workshop),
so I'm probably jumping the gun to be worrying about engine and prop
choice already. Still, it's a fascinating area of compromise, and you've
all given me lots to think about.
Tedd McHenry
Edmonton, Canada
Subject: | Trailing Edge Bend |
Hello All,
I'm working on my rudder at this time and having just riveted the
stiffeners to the rudder skin I attempted to make the trailing edge bend. I
used the wooden bending brake as suggested by the manual but I'm not happy
with the results. I was able to make a bend, but the skin is not in the
final shape that I feel it needs to be, ie it is nowhere close to being near
the rudder spar. I bent the skin enough to contact the opposite side, but it
has alot of "springback". I even put the skin in the rudder jig and there is
so much resistance to being forced into the jig shape that there is a bow in
between the jig supports.
I know there has to be a better way. Can I use my hand seamer? That should
work but I doubt I could be consitent with the bend along the edge. It would
be nice to figure this out as I'll need to do a bunch more times before it's
all done!
Thanks in advance for any and all help.
Larry RV-6 23782
Subject: | interior finishing |
Just to pass along something that might be of interest regarding sound deadening
materials.
Mooney aircraft used to use a type of sound deadening insulation on some of the
M20C airplanes built in the '60s and '70s. While I am not sure of the exact
nature of the material, I believe it had the ability to retain moisture both in
the material, and in the gaps between the material and the structure. This
caused significant corrosion problems in aircraft so equipped, and Mooney
eventually issued a service bulletin mandating the removal of the insulating
materials. Early compliance with this SB is something all prospective
used-Mooney owners look for now (along with leaking fuel tanks).
Since the Mooney fuselage consists partly of a welded steel tube frame, it might
be more susceptible to corrosion from exposure to this type of moisture.
Something to consider at any rate....
Bruce Stobbe
fuselage skeleton
Subject: | Re: Band Saw Size |
> Gary Tree
My band saw is a freestanding Taiwanese generic brand 4 speed with 14
inch throat. Any smaller throat would be frustrating. It is intended
for wood cutting and I use it on the slowest speed with a 24TPI blade
for aluminum. I use it all the time. Indispensible.
Peter BennettDate: | Feb 01, 1996 |
From: | JIM SCHMIDT <JIM.SCHMIDT(at)mail.mei.com> |
Subject: | Trailing Edge Bend -Reply |
Larry I think I has the same diffculty also.
Are you using the wooden brake flat side or
the edge to do the squeesing. There are two
different jigs shown at different places in
the manual and sketches.
I used the flat way so I can't comment on
the other.
Be sure you hold the bend back into the
corner as close to the hinge line of the
brake as possible and don't be afraid to put
some weight into it.
>>> Larry Groom
02/01/96 12:17am >>>
Hello All,
having just riveted the stiffeners to the
edge bend. I used the wooden bending brake
but the skin is not in the final shape that
close to being near the rudder spar. I bent
side, but it has alot of "springback". I
there is so much resistance to being forced
use my hand seamer? That should work but I
along the edge. It would be nice to figure
times before it's all done!
Larry RV-6 23782
I back drill the whole rib.
Dan Boudro
> Thanks
> Howard Kidwell
> howardrv(at)aol.com
From: | "Gene Gottschalk (286-0708)" <geneg(at)rattler.gsfc.nasa.gov> |
I don't know of problem specifically relating to aircraft engines,but I had
dry powder fire extinguisher used on a motorcycle I crashed while racing.
An over zealous corner worker was quick on the trigger, and as it turned out
there was no fire, just steam from a broken radiator. I took months of
effort to get it even close to operating properly. It is like blowing fine
sand into everything. I couldn't find anything that would adequately wash
it out. First I washed everything in kerosene. That got the bulk of it
washed off, but such things a throttle slides, carb linkage, or anything
else with close operating clearances would not work reliably. I
disassembled the carbs and washed them repeatedly without success. Then I
tried hot water with marginally better results. Than soaked them in a
bucked of carb cleaner. I never did get the carbs to work as well as
before, and ultimately swapped them for another set. BTW, it seems the
stuff is also caustic, and hard on skin. Aluminum part started to corrode
immediately. Maybe a call to the fire extinguisher co. would result in a
recommendation for the best cleaning procedure.
-Gene
>To: rv-list(at)matronics.com
>From: lewisjw
I'm sure you will get many opinions, so here is mine. I have a small Sears
band saw that I used for RC models. I bought one of the 1 hp type on sale
(still expensive of course) but with a metal cutting blade, It really goes
through the heavier stuff that is used. As I plan on using it for other
stuff, I didn't have a problem with the purchase but their is no doubt that
one could spend lots of$$ on tools so it's caution here. The "must" is the
Scotch brite wheel that Avery's/Van's sell. I use it on a radial arm saw but
of course it will work on a grinder. A small band sander is also great. I
had a 4" sander and put a 60 grit on it and boy does it take off the Alum.
It's easy to get carried away with the tools but of course some are needed.
And for you younger types, you will probably build another anyway!!
Howard Kidwell
howardrv(at)aol.com
>Gary Tree
I am using the Delta free-standing 16" three wheel bandsaw. This unit has
been used for the entire construction of my -6A, from emp to finish kit.
There were no areas of construction where this bandsaw did not perform
flawlessly. I looked at the smaller bench-top Delta and Sears, along with
the free-standing Sears. The bench-top units break blades very easy, other
RV builders in my chapter confirmed this. Also, these small units just
didn't seem to have the umph needed to cut large amounts of aluminum.
Believe me, there will be times when an entire building session will be
infront of that bandsaw. The free-standing Sears seemed crappy when I
looked at it. Angled cuts are made by leaving the table stationary and
tilting the entire blade and drive unit. There are probably good reasons
why Sears is the only company to do this while Delta and the other
industrial quality manufacturers tilt the table only. If I remember
correctly, there was only a few dollars difference from the Sears to Delta.
Any tools that I buy for the RV, I will be able to use for other projects
after the plane is finished. I started when I was 23, so I expect to get 40
years out of them. I am building in a two car garage, where room is
available for free-standings tools ( bandsaw and drill press). This all
influenced my decision for the larger tools. When buying tools, the main
thing that I learned is NEVER BUY CHEAP TOOLS, repeat NEVER BUY CHEAP TOOLS.
You get what you pay for and it does show in the finished product. Most
cheap tools wind up getting replaced, thus costing more in the long run.
Hope this helps.
Scott N506RV (Rigging wings to fuse)
From: | mike casmey <102023.1363(at)compuserve.com> |
Subject: | Backriveting tool |
Some of you said that your Avery backrivet tool was not bent correctly. I
measured mine at 4 degrees and then tried it for the first time. Sure enough it
was too shallow and my rivets slanted toward the rib web. If I heat this thing
up and bang it 2 more degrees will it be correct for all the angles it is
required to rivet. ie. both around the ribs and under the main spar?
Are there any better ways to solve the angle problem?
Mike Casmey RV-4 Mpls,MN
Subject: | Re: Trailing Edge Bend |
On Thu, 1 Feb 1996, Larry Groom wrote:
> Hello All,
> all done!
I also found it difficult to get the proper bend in the control surfaces.
What worked for me was the method used inthe Orndorf video, which is to
put a 1/8" dowel (wood is fine, I used music wire) along the inside of
the trailing edge, and to keep moving the brake closer to the trailing
edge after each bend attempt:
o|\ \ o| \ \
1st bend 2nd bend etc...
This helps to wrap the trailing edge around the dowel, and with enough
attempts, I was able to get the skin formed so that it was within a 1/2 " or
so of the spar, after springback.
Curt Reimer
> Larry RV-6 23782
Larry: I wouldn't reccomend using a hand seamer. Put your trailing edge
close to the hinge. Do you have long handles on your 2x4 brake? Some
builders put a small dowel in the trailing edge. I've not used this method,
but I'll bet other "listers" have and can tell us how this works. Bob
Skinner RV-6
>Thanks
>Howard Kidwell
>howardrv(at)aol.com
Howard: I believe that you'll get a "truer" hole by not back drilling. I
would suggest marking rib locations on the skin and then pilot drilling
skins, off the wing, with a smaller than # 41 drill bit. (Where can you buy
smaller diameter, split point bits?) Then, put the wing skin back on and
drill #42 through the pilot holes. Bob Skinner RV-6
>a good idea.
Peter: Good idea. I've got 200 hrs. on my RV-6, 150 hp Lycoming with wood
prop. I've had 4 or 5 landings that were harder than I would've liked to
had and probably 10 landings on sod strips that were fairly rough. I
generally wheel land. The plane has never been used for acrobatics. I have
5 or 6 #3 flush rivets in the belly skin stiffner area that are smoking and
5 rivets in the lap between the belly skin and the one aft (under the spar
bulkhead) where the paint has cracked. So far, I have no problems with
rivets at the firewall. On the 6-A I'm building now, I think I'll use #4
rivets with the same spacing as the #3's and will dimple on the belly
stiffners. Don't know what I'll do on the lap joint under the spar. Bob
Skinner RV-6
> ??? Now I'm confused... :-(
> Fixed pitch? Did they change it? Or are you talking about the Yellow one?
> Confused,
> Jeremy :-)
Yeah you're right Jeremy I obviously a fit of dyslexia there or
something: I meant the _CS_ can be easier... and yes, the RV-6B
(yellow plane) is (was) fixed pitch, RV-6T (red) is CS.
I stand corrected. (Man you can't get away with ANYTHING on this list! :-)
Randall
Subject: | Here is a 'how to certify your homebuilt' |
Here is some info I put together for our EAA Ch 187 based on what I did
to certify my RV4 in Dec 95.
There have been some questions on this lately so this may help. Herman
CERTIFICATION of AMATURE-BUILT AIRCRAFT. Page 1 of 2
Feb, 1, 1996
Herman Dierks
Reference: FAA Advisory Circular 20-27D 6/22/90 (may not be latest).
This document was a little confusing. Below is my 'flow chart'
of what needs to be done.
1) RESERVE N-NUMBER 60 to 90 days before completion.
Send $10.00 and a list of 5 possible N-numbers to
FAA Aircraft Registry, P.O. Box 25504, Oklahoma City, OK 73125
(see example form attached below curtisy of Gil Alexander, which
is simpler than that published in 20-27D but they don't need to
know what the model of the plane, etc is at this point as you
can put the number on what ever plane you choose when you register it.
You can call 405-954-3116 to see if a number is available.
You can look up N-numbers on the Web of Registered (not reserved)
N-numbers at http://acro.harvard.edu/GA/search_nnr.html
You can also get there via the IAC home page:
Go to http://acro.harvard.edu/IAC/iac_homepg.html
and then select 'Other General Aviation related information' and
then select 'N-Number lookup'.
Note that a N-number is reserved for up to 1 year. They will
send you a notice when it is about to expire. You can keep sending
in $10.00 a year to hold it until you are ready for step 2.
2) FAA will send back a confirmation of what N number is reserved
and will also send you a copy of:
Form 8050-88, Affidavit of Ownership for Amateur-Built Aircraft.
Form 8050-1, Aircraft Registration Appication
Fill out 8050-88 and have it Notarized. Fill out 8050-1 and send
the two forms and $5.00 to the address on form 8050-1.
You keep the 'pink' copy and this is the 'Registration' form
that can be used in the aircraft for 90 days.
You may also want to send a copy of the Kit Bill of Sale or
authority to build the kit. This should be done a few weeks
before the aircraft is ready to fly.
3) The FAA will send you back form 8050-3 which is your official
'Certificate of Aircraft Registration' which you put in the
aircraft (to replace the pink copy). Check it for errors and
notify FAA at 405-954-3116 if any errors are found.
4) Radio Station License. At the same time you do step 2, you
should apply for the radio license. Obtain a current 'FCC 404'
form from your local avionics shop. Get their help on how to
fill it out. For example, you need to put 'PAAR' in box 8
but this is only defined in a special book which you don't have.
Send this form to the FCC along with $75.00 ( the current fee
for this 'non-service' or tax which may be repealed).
5) Other requirements before the FAA signoff.
1) N-number on plane. 3 inches high or 12 inches if Cruse > 180K.
2) EXPERIMENTAL 2 inch high sticker.
3) 'Passenger Warning' placard (except single place).
4) Fireproof 'Data Plate' (builders name is the manufacture).
5) Logbooks for airframe and engine.
6) Placard and operating limitations. (check-lists?).
7) Weight and Balance
Page 2 of 2
6) 'FAA' inspection
The FAA can inspect the plane (for free) or you can use a
DAR which is a private individual approved by the FAA.
Our local DAR is Richard Dumler 512-441-0629.
The DAR will charge a fee, about $225.00 for the service.
Why us a DAR? He is local and will probably come out when you
want him to (the FAA shows up when they want to). Dick will
show up when he says he will. He will come out twice.
He will give you the test area you want, within reason.
The DAR provided the following forms and will help you fill it out
or you can get them from the GADO and have them filled out
before the inspector shows up. Know what flight test area you want.
Form 8130-6, Application for Airworthiness Certificate
Form 8610-2, Airman Certificate &/or Rating Application
(this is for your 'repairman' certificate).
These forms will be filled out and signed by both of you
and the DAR will send them in to the FAA.
He will also want copies of your Weight & Balance form and
copies of several pages of your log books and copies of
of the N-number and Registration forms from above.
7) The Inspector (DAR) will give you the signed Airworthiness Cert.
He will also give you two other forms.
8130-1, Experimental Operating Limitations (Phase 1 for
the flight test period).
8130-1, Same form, but this one is Phase 2 which begins after
the flight test period is signed off by the builder.
These are part of the 'Operating Limitations' and go in the
aircraft.
You now have all the 'ARROW' documents!
Other Notes:
Have project inspected 3 times by EAA 'Technical Counselor'
and receive a 10% discount on insurance from Avemco/National.
( I deleted names of our CH 187 TC's here).
Work with an EAA 'Flight Advisor' and complete the associated
paperwork and the first 10 hours will also be covered by above
insurance company (otherwise it is excluded).
(I deleted names of our CH 187 FA's here)
Form letter to reserve N number:
RESERVATION OF AN "N" NUMBER
I wish to reserve a Registration Number to be
used at a later date. The fee to reserve a Registration
Number is $10 per year.
My choices are:
1.
2.
3.
4.
5.
Signature: ____________________________
Address: ______________________________
Phone: ________________________________
Mail request and Fee to:
PO Box 25504
Smaller bandsaws do go through blades more quickly. The reason is the
blades are made thinner to handle the tighter radiuses of the smaller
wheels. However just about any bandsaw that will cut wood, will cut
aluminum. The speed for cutting wood works fine with aluminum. Just
use a blade 3tpi hook toothed blade when cutting thicker pieces. The
courser blade will not gum up quickly, like a fine toothed metal blade
and will cut the soft aluminum just fine.
I also believe in buying the best tool you can afford. But I plan on
using my tools for many other projects after finishing and while
working on my airplane.
| Bill Downey International Business Machines
| billd(at)ibmoto.com SOMERSET Design Center
>Hello All,
>all done!
> Larry RV-6 23782
The "brake" I used was borrowed and consisted of 2 --2"X8" douglas fir held
together with three door hindges. I placed a small dowel inside the skin to
prevent overbending. I placed the brake on the floor and held the skin
while I litterally jumped on the brake. I had to move the skin so that only
the trailing edge was in the brake to get the final bend. I was surprised
at how much pressure I needed to apply. I think I had my wife come out and
stand on the brake also.
Ross Mickey Phone: 541-342-1892
2300 Oakmont Way #205 Fax: 541-342-5492
Eugene, Oregon 97401 email: rmickey(at)ix.netcom.com
>Gary Tree
I bought one from Freight Harbor which has a 12" throat that works just
fine. If you can scan the arcives, there has been EXHAUSTIVE discussion on
tools. If you can get the serach engine up an running on the archive, I'm
sure this will help. I am still trying to download and unzip the files. I
am getting a mesage that I need to run pkzipfix on the file.
> Will I need a band saw?
IMHO, YES! I'd probably even give up my "favorite tool" (pneumatic squeezer)
before I'd give up my band saw.
That's kind of minimal but should handle most of what you do with it. I
had the sears 10" variable speed, it was pretty cheezy and lightweight,
I took it back when it stopped working right (within the first year)
and got a delta tabletop 12". MUCH better.
Not a lot on the empennage -- the notch in the VS bar, notching and
tapering the HS forward spar angles. Still its easier than using a
hacksaw or table saw.
The wings, you use it to cut the spreader angles, make the fuel tank
reinforcement plates and forward wing attach angle, taper the rear spar
flange strips, trim various doubler plates, etc. (some of that stuff
is already done for you "new builder" types :-). Some people use a
bandsaw to taper the spar flange strips although your Sears 1/3hp
probably wouldn't be up to that (I used a table saw).
The fuselage -- all KINDS of stuff. Lots of 1/8" and 1/4" angle to
cut, notch, etc. I got away without a bandsaw on my tail, was glad to
have it on the wings, and REALLY wouldn't want to be without it on the
fuselage.
My man!
Randall Henderson
RV-6
Subject: | baggage ribs revisited |
Thanks to everyone who responded to my original question regarding oversize
baggage floor ribs. Your help and comments are greatly appreciated.
I did verify that the ribs were installed in the proper sequence, and that they
were numbered properly - ie; the tallest rib is the centermost (at the F606).
It was also verified that the F625 (furthest outboard) rib is 3/16 taller at the
-606 than the print calls for, and this is what is causing the misalignment of
the baggage floor.
For reference, my fuselage kit was delivered in June '95. Since some of you
indicated that you had no problems in kits that were shipped both before and
after mine, it appears that the problem comes and goes.
I intend to remove the offending flange and rivet on a replacement made from a
piece of .025 scrap (scrap? what's scrap? :-) ) as some of you suggested.
Thanks again for the help.
Bruce Stobbe
RV-6 fuselage
>>Thanks
>>Howard Kidwell
>>howardrv(at)aol.com
A.T.S. --- their tools may be bad, but I've found them to be a good
supplier of drill bits. All sizes I've wanted have been in stock, and they
sell the prefered 118 degree split point bits for alum. sheet.
... Gil Alexander
> a good idea.
Great idea Peter!
My plane, alas, isn't finished yet. But you should contact Don Wentz
(don_wentz(at)ccm.hf.intel.com -- he's not on the rv-list) -- he went through
this with less than 100 hours on his 180hp fixed pitch RV-6. Also
I think Tom Green at Vans (RV-6) (72640.3005(at)compuserve.com).
Randall Henderson
RV-6
Subject: | Re: Backriveting tool |
it
I don't know if I've mentioned it before, but I had much better luck
using an offset mushroom set to backrivet the wing skins. I tried the
Avery thing and didn't like it (first thing of Avery's I HAVEN't liked
though....). As long as you "over-angle" it to compensate for the
offset, they come out really nice, even when I could only get the edge
of the set on the rivet. "Home Wing" members take note -- I got mine
for $5 at Wacky Willy's Westside. Probably Seattle types could find one
at Boeing Surplus. Everyone else -- AC Spruce.
Randall Henderson
RV-6
Subject: | Backriveting tool -Reply |
IT's the only way I know. Mine is now at
about 6 degrees and it works fine on the
spar and down at the trailing edge of the
rib is the most highest angle.
02/01/96 09:18am >>>
tool was not bent correctly. I measured mine
time. Sure enough it was too shallow and my
this thing up and bang it 2 more degrees
problem?
tool
job?
comments
>Gary Tree
Gary,
I have an inexpensive Home Depot bandsaw much like the one you
describe. I use it with a wood cutting blade and have had no problems
cutting material for the empennage. I can't speak for the rest of the
project as I'm completeing the empennage myself. It's always nice to
have the biggest and best equipment available, but you can get by fine
with the Sears model. Some builders have opted for the variable spped
model. AMT (Woodworking tools) has on sale a nice floor model drill
press for $199 in their last catalog. I believe it is 16 speed. Buy the
hand tools from Avery's and get started!!!
Subject: | Re: Search Engine Instructions |
those of you
I downloaded your program and got it up and running. You are to be
commended for an excellent piece of work. It is now a pleasure
searching through 5 years of email.
Ed Cole RV6 24430
Downloaded the search engine last night....Yessir it be fine!!!!
I'm always envious of those with the skills to make the pixels do what they are
told ....Thanks for a great new tool BF!
Rob Lee
From: | Carolynn E Hiatt <hiatt001(at)gold.tc.umn.edu> |
Subject: | Re: Tailwheels are easy |
I agree with you about taildraggers. I learned to fly in a T-6. Talk
about a high pucker factor, try landing those things in a crosswind --
about a 15 on the 1-10 scale. Everybody be safe and don't do nothing dumb.
Fred
> >>> SHHHHH! Dammit, you want EVERYONE to know???? There goes my "taildragger
> >>> pilot mystique!"
> >>Ah, yes!
> >>Best Regards,
> >>Dave Barnhart
> >>rv-6 sn 23744
> SNIP>
> >John Ammeter
> >Seattle WA, USA
> >RV-6 N16JA
> >Flying 5 years
> scale.
> figure.
> Regards:
> Rusty Gossard
> N47RG RV-4 Flying
From: | "Terence Gannon" <Terence_Gannon(at)msn.com> |
You old hands are probably laughing your heads off at the frequency and the
mundanicity* of my questions...I'm making steady progress on the HS, and now
I have three more questions;
1) When bending the ends of the HS-610, I managed to get one right on the
money (6 degree angle), and one I over bent by about a 1/16" of an inch,
measured at the the tip of the '610. George and Becki talk about "aluminum
not taking kindly to be being bent back", but I couldn't resist the temptation
to have the bends at the two ends match, each at 6 degrees, so I brought it
back the 1/16". Does this make the part a throwaway? I'm guessing a failure
of 610 would make for a spectacular conclusion to my flying career.
2) I've looked and looked, and I can't seem to find the size of the lightening
holes in the HS-405. While I think it's probably obvious (just cut out the
flat part), I'm wondering what anybody else has used as a size.
3) The measurement from the HS-603 to the HS-602 at the centreline...that's 12
3/16 to the back of the HS-602, or the back of the 610 and the 614? My
drawing looks like it was copied one too many times and I can't quite make it
out. I know the difference is only the thickness of the 602, but y'know, ya
wanna get it right, doncha...
That's it for now. Hope everybody is having as much fun as me!! Cheers...
Terry in Calgary
S/N 24414
"Horizontal Stabilizer"
*That's a made up word...defined as "of a mundane nature"
PS. My final decision on priming...mild solution of Alumiprep, and then go
directly to Endura etching primer. I'm going to skip the Alodining...that
"known carcinogen" stuff on the label just scared the bejeesus out of me...I
had visions of having a Grand Champion RV-6 with a carcinoma to match...
From: | Ron Caldwell <74504.1365(at)compuserve.com> |
Just to introduce myself, My name is Ron Caldwell and I just ordered a RV6A.
I'm told that I will be one of the first to receive the new prepunched empennage
kits. I have my jig built , so I'm anxiously awaiting the kit to arrive. I
live in Salt Lake City and belong to our local EAA chapter. I also own a piper
cherokee so at least I won't be without wings while I'm building the RV. I'm
very excited to embark on this journey and look forward to conversing with
everyone.
I tapered all of my spar flange strips on a cheap 3 wheel band saw with the
approriate cutting fluid. It had an old blade in it and made it through all
of the strips. The cutting fluid makes a lot of difference IMO. Bob
Skinner RV-6
>I've got a cheap 3 wheel band saw and use a blade with 14 tpi. I've found
that laying a bead of LPS cutting fluid down the cut line extends blade life
considerably. Be sure to use a cutting fluid that indicates that it can be
used for aluminum. Bob Skinner
From: | "B F Gibbons" <bfgibbons(at)intellinet.com> |
Subject: | Wing skins (again) |
On the trailing edge of the fuel tank there are two rows of screws.
The bottom row stops about 12 inches from the wing root.
How does the tank skin stay flush against the spar? What holds
the trailing couple of inches of the inboard 12 inches of the skin down?
Thanks in advance.
I think the idea of such a database is great. (Looking through the
rv-list archive I noticed someone at one point had downloaded incident
data from the NSTB (?) BBS on RVs.)
Building an RV-3, I'm definitely concerned about this area, as there
were several reports about this area (wing/fuselage attachment).
Modifications were designed for that area, which I do intend to
implement (Van's CN-1)
deficiency
of
as the
weight of
occurring
thousands of
>hours.
rivets
field
some
change. I
it's
>a good idea.
>Peter Hanna, 2-425 Kingscourt, Waterloo, Ont., Canada, N2K3R4,
You wrote:
>>Hello All,
>>bend. I used the wooden bending brake as suggested by the manual but
>>I'm not happy with the results.
>> Larry RV-6 23782
Larry, I used a 2 X 8 cedar board cut very carefully at a mill so the
faces were very smooth and parallel. I used a 1/8" dowel (steel) and
used long (about 3 ft) pipes with pipe clamps so I could get a LOT of
leverage when bending down. Mostly followed the Orndorff suggestion on
the tape for positioning of the trailing edge. Mine seemed to work
fine.
I had a big discussion with another builder whether the dowel should be
1/8" or 3/16" and neither one of us changed our opinion, but I think my
1/8 worked fine.
Hope this helps. Bill Costello
\ \ _ _ / /
Hi Gary,
I'm using the el-cheep-o $99.00 variable speed bandsaw with 62" blade and 12"
throat from Harbor Freight. So far it has done a good job. I think it cuts kinda
slow, at least compared to the more expensive two wheel ones I have used in the
past, but the result is the same. If I had the extra money, like I have extra
time, I would have a better saw. In conversations with cabinet makers and
machinist, they told me that any three wheel saw will break the blades more
often (bend radus of the blade). Where blades are concerned: I have used an 18
tpi and a 6 tpi blade, both worked just fine. I had a better result with the 18
tpi because it cut slower and the control was better because of this. In most
cases I would tend to agree with the statement: NEVER BUY CHEEP TOOLS! But, with
certian tools I feels you can get away with cheeper ones. I think this happens
to be the case here. My #1 rule: I always cut on the outside of the line and
file or sand to the correct size, just like I would do with any saw. This allows
me not to be so accurate with the cut and just remove the bulk of the material.
I have seen excellent workmanship with cheep tools and bad workmanship with
expensive tools. One very true statement is: NEVER BUY CHEEP HAND TOOLS THAT ARE
GOING TO BE USED OVER AND OVER. (like squeezers, flange tool, de-burring tools,
etc.) So far Avery has the best hand tools I have found!
James Kelley (Working on main spars.)
O.K. I don't feel so bad about asking this after the "what are smoking rivets?"
question. What does IMHO mean?
James Kelley
Subject: | Pre-punched Wing Skins Tip |
I am in the process of drilling the pre-punched wing skins to the wing rips
and spar.
Van's instructions suggest several methods. One of them which I followed
was to drill and cleco the 2 main-skin-tops then teh 2 main-skin-bottoms
first and then fit and drill the leading-edge-skin last. The rationale was
that by doing the main-skins first, the wing assembly became very strong
and this helped pull the leading edge skin into position with straps
without distorting the wing.
I have found that when the leading-edge-skin is pulled down with straps,
the trailing edge overlaps the main-skins. The instructions say that this
is intented and the leading edge skins are ".040 to .050 oversize and just
trim them to fit."
If I trim (shorten) both the lower surface of the leading-edge-skin and the
bottom-main-skin at the butt joint in order to remove enough to get a good
fit, I will have edge distances for the prepunched holes of less than 2
diameters on both the leading-edge-skin and the main-skin at the bottom
butt joint . The solution appears to be trim both top and bottom
skins/edges for both the leading-edge-skin edges and the main-skin edges.
This is not easy to do and very time consuming.
I would now rather have: (1.) Drilled and clecoed the top-main-skins to
create a very rigided wing assembly. This could also include the
inboard-lower-main-skin. (2.) Drilled and cleoed the leading-edge-skin
with a nice tight butt joint with the top-outboard-main-skin. 3. Finally
butting, drilling and clecoing the outboard-lower-main-skin to the
leading-edge-skin.
Another solution would be if the prepunched skins did not have the bottom
trailing edge line of holes prepunched. Then this edge could be trimmed to
fit and then drilled to the spar flange maintaining proper hole edge
distance. This is an easy line of holes to mark and drill.
Bob Haan Office 503-531-2366
Pacific Northwest Mobile 503-720-1132
Account Manager FAX 503-690-6906
Synopsys Modeling Group E-mail bobh(at)synopsys.com
------ =_NextPart_000_01BAF0EC.454667A0
Hey gang, there are two key factors involved in using a band saw =
successfully.
The first and most important is getting the correct blade pitch. It =
is realy quite simple, there must be at least two teeth in contact with =
the metal at all times, more,of course is better. Simply divide the =
metal thickness in thousndths into 1.000 and round up to the nearest =
whole number, for the minimum number of teeth/inch.
The second of course is blade speed. Most people think that a band =
saw should scream as it cuts, not so.Generaly when cutting metal , the =
higher the noise pitch the shorter the life of the cutting tool and the =
rougher the cut, noise is vibration, and the higer the frequency the =
more energy the tool must absorb.Slowing the saw down will give you a =
better cut and more control, within reason.
A somewhat messy, but very effective coolant for cutting aluminum =
is varsol. Inexpensive.
In general, buy the best tools you can afford and never part with =
them except to replace with a better quality tool later.=20
I hope this has been of some help,
Ernie Amadio
>>a good idea.
>Skinner RV-6
Bob: Thanks for information. You are first and I will start an Excel
spreadsheet. With luck a pattern will emerge and I can spread the word.
As a newcomer to the list I don't know what outcome was of the last go
around on this smoking rivet topic - maybe someone could summarize it to get
everyone up to speed on what we are concerned about.
Is it possible that the cause is engine vibration and oilcaning of the floor
pan? Everyone responding: please include whether the floor pan is deadened
by stick-on sound attenuating material, supported or in contact with
plywood, foam, etc. What color is belly painted? (It might be evident only
with some colors) If belly is cleaned, how many hours/landings/etc., before
the evidnece reappears? Engine mount type. As well, where exhaust exits.
What has been done to correct it? Was it effective? Anything else?
How much vibration is evident in flight? Reach down and touch floor (or a
passenger) at different rps, during landing, fast taxi up on mains, etc. You
can tell I am already flying my 6 vicariously and that I like problem solving.
Someone mentioned that it is occurrring on a 6A - that's interesting as it
would seem that the landing loads thru the belly area from the mains are in
reverse to the 6, that is, in compression on the 6A rather than in tension
on the 6. In the 6A the wheels support the A/c weight at the same point as
the wing does. In the 6A, however, landing loads from nose wheel on rough
ground could be a factor. Do those of you flying 6As hold that nose wheel
off as much as possible during TO and landing on rough ground?
Bob: What's it like to wheel land the 6? At what speed do you approach and
"put" those mains on the runway? Does it tend to bounce? I love doin wheel
landings with my tandem T'craft, except when I have someone in the back -
then it's hard to avoid a bounce as the tail goes down slightly. (my L2 is
solo'ed from the front) Is that a probelem on the 4, anyone?
To simplify responding on "smoking rivets" I will put all the questions
raised above in a questionaire format and send it out under separate cover
to eliminate all this preamble.
I will be away from my connection for two weeks so won't be responding to
anyone until after Feb 18. Hope there is lots of info waiting for me.
Subject: | Re: Wing skins (again) |
That inboard piece of .032 skin is pretty stiff once the tank is assembled
and screwed to the spar. With a slight bit of preload bent into it, it fits
quite snugly against the spar.
Curt Reimer
RV6A.
>empennage
I was just at the factory on 1/31, and Tom showed me the pre-punched emp
skins. Very nice. He said the cutoff date was 2/1. Sure would hate to be
the guy that ordered his on 1/31...
Good luck with your new project. Mine has been a fascinating, frustrating,
exstatic, agonizing 15 months of my life so far.
Ed Bundy
Installing flap actuator
Subject: | Re: RV Building 101 |
>temptation
failure
Nope. You don't want to bend aluminum anymore than you have to, but small
corrections won't hurt anything.
>lightening
I don't remember the exact size, but all the lightening holes that you need
to cut yourself are just the flat part. Technically you can take out up to
25% of the ring also, but I wouldn't.
>12
it
Well, they must have revised the dimension since my drawing. Mine shows it
at 12 1/8, and the dimension is inside to inside. That must be why they
changed it, my HS is 1/16 to long, and overhangs the attach point a bit. Ah,
progress.
Welcome to the net Ron...
JMP
Subject: | Re: Search Engine Test |
Well, I did give the program a whirl. Yes, I did manage to crash it. Over all
it's quite impressive. Good speed... the messages have all the stuff... First
I'll tell you about the crash.
I began searching on accident while stepping through the string I got an error
of "Can't Insert a line" I seemed to beable to hop over it but maybe I'm not
sure just where I am in the list. Then I searched on blea trying to find my own
inane postings about this time everything just stopped and I had to kill the
process. Windows didn't die, so it wasn't the dreaded GPF (I never called you
Bob... ;-))
I do have a couple of suggestions:
1. There seems to be too much space between the top section of the window and
the message text. It is most appartent when the window is zoomed to full
extent. In a perfict world I suppose you could make this a sort of splitter
window where the division was user variable but I don't know if it's possible
with the system you're using. In any case a fixed division is probably ok only
I
would put it a little higher than you now have it.
2. I was a bit confused by the arrows. At first I thought that the first and
last arrow applied to the searched list, but after a time it began to look as if
they moved you to the front and back of the whole database. I think you should
add a message counter/position indicator of the type "Message 1 of 20" so you
could see where you are and know how many messages you have selected.
3. Starting a new search seemed a bit awkward too. I just poked the forward and
back arrows at random until it took. I think that a new search should be
instigated whenever the edit control has been changed and looses focus or gets
a
4. An option for whole word searching wouold be nice too. When looking for my
inane postings blea turned up quite a few split words.
Overall It is a very impressive program and I'm sure everyone will enjoy using
it. I'll keep at it for a while and if I have any more suggestions or
repeatable crash instructions I send em along as I come up with them.
Oh, one final thing I think it needs a version number (didn't remember one on
the startup screen and didn't check the about box so if it's there ignore this
one.)
>James Kelley
> In my humble opinion---as in "IMHO, the only dumb question is the one that
isn't asked" Bob Skinner
>Thanks in advance.
B.F.: Your expert metal craftsmanship:) I wondered about that, too.
Before the last time the tanks went on, I used a hand seamer to put a slight
bend in the skin. You don't want to bend it from the rear baffle, in other
words be careful not to bend the skin down at the baffle or you will crease
your skin. You kind of use an arching motion to put a slight curve in the
skin. You may need to place some thin material (.016 alum) on the spar to
help guide the tank skin over the spar. Bob Skinner RV-6
> The ominous
>hours.
This has been addressed in great detail here on the list and I for one do not
think that it is a *serious deficiency in structural integrity* and to say so
in my opinion is probably causing a lot of builders to worry needlessly. I
have over 700 hrs on my airframe and yes I have some rivets that appears to
be lose but that is caused from my own building technique, I think that Van
does need to call out for dimple in this area rather than countersink.
Jerry Springer
A>Is it possible that the cause is engine vibration and oilcaning of the floor
Peter: I have only carpet glued to my floorboards. Plane is painted white.
I've just had a few stiffner rivets smoking. Looked under airplane
yesterday and notice paint cracked around 5-6 rivets in skin overlap area.
This occured in the last few hours (est. after 185 hrs.)
I usually come over the threshold at 80 when wheel landing and seem to be
able to do a better job wheel landing than 3 point. Bob Skinner RV-6
>rivets
I
it's
>> a good idea.
Its a good idea!
RV6 Completed 1991
Started smoking rivets @ 200 hours
Approx 20 hrs rough fields, 180 hrs pavement
Lots of gear shake, ultimately traced to doubler sleeve spot weld failure
180HP CS
Rolls only
Mostly 3 point landings, some wheel landings
Smokers mostly in the forward third of the bottom skin, some in firewall
flange
Pan was countersunk
I have only carpet on the floor, and always noticed a lot of buzzing under my
feet, particularly when diving and even on descents with lower power
settings. I believe the riveting job to have been first class.
I replaced all rivets in the pan with 1/8 inch rivets, countersinking the 040
material, which is allowed but at the limit. I also doubled the number
across the front angle.
Jim Stugart
DerFlieger(at)aol.com
Van needs to listen to some of these problems instead of chalking them up to
poor builder technique.
From: | Ross Rebgetz <Ross.Rebgetz(at)tvl.tcp.csiro.au> |
What are the active ingredients of alodine. My local paint supplier didn't
know the name so it must be called something else here.
Thanks in advance
Ross
Phone: +61 077 538570 W
+61 077 753192 H
Fax : +61 077 538600 W
Email: Ross.Rebgetz(at)tvl.tcp.csiro.au
Mail : CSIRO
Davies Laboratory
Private Mail Bag
Aitkenvale Qld 4814
Australia
Subject: | Re: Engines Weights |
Re:
Gee, $4-5K for a constant speed prop and who knows how much more for a
retract gear (and its higher maintenance requirements and cost); and you
get 10 mph and 200 fpm. Outta my way - that money's burnin' a hole in my
pocket!!!
Seriously, a constant speed vs fixed pitch prop decision can't be based
on an apples to oranges comparison as this Mooney to Tiger example. Use a
Decathalon 150hp with CS prop and with fixed pitch prop for a better
comparison, or some other aircraft with prop choice being the only
variable.
Next month's topic - why the glass cockpit in my F-15E makes it a better
performer than the J-3 Cub...
Okay, maybe a bit sarcastic.
Mike Kukulski (kukulskim(at)aol.com)
RV-4 Fuselage (attaching empennage - planning on a fixed pitch prop,
spent all my money on the engine!)
From: | Jim Ayers <102337.2252(at)compuserve.com> |
I hope everyone has received their RVator by now. I found the two page
"centerfold" article on the Ivoprop "Magnum" propeller interesting, but
misleading. I could really relate to what was being described, since I went
through the same thought processes myself in the initial installation of the
Ivoprop.
The Magnum propeller comes with very specific installation instructions. It is
very important that they be followed completely. What we do to install wood, or
metal, propellers is not necessarily going to work the same on the Magnum prop.
For example, on my wood prop, I installed the spinner backplate between the prop
extension and the wood blade. It just seems natural to install the spinner
backplate between the Magnum blades and the rear "crush" plate on the Magnum
prop. (The Magnum prop blades are captured between a front and a rear crush
plate.) However, the spinner backplate needs to be installed behind the rear
crush plate. And, yes, the blades are farther forward in the spinner, which
requires longer cutouts for the blades.
Also, the aluminum parts provided with the Magnum prop are bare aluminum, not
even alclad, and are expected to be used bare. No alodine, iradite, anodize,
primer or paint. BTW, did you know that the spinner backplate (bare aluminum)
should be left bare for a wood, or metal, prop installation for the area that is
sandwiched in the installation (bare faying surface)?
I have been providing Ivo with performance information on his "Magnum" propeller
for the last two years. (I had the prototype case mount alternator bracket from
Pelican Aviation on my Lyc O-290 (Six years without a problem), and have the
prototype LOM M332A engine installation in my rv-3. I just do these things that
catch my interest. How else would you define a hobby?) I can fly his propeller
a little faster on my rv-3 than he can on his Cessna 172. And he has been able
to confirm my findings by putting his two bladed ground adjustable prop on a Lyc
O-360 powered Glasair to see for himself.
I guess I just feel its more important to help identify the problems so they can
be resolved. Ivo has a customer with a three blade Magnum prop on his Lyc.
O-720 (yes, 720, not 320).
It is the four cylinder four cycle engines that break the tape. I usually break
the tape in the first half hour of flight. And the latest set of blades haven't
broken the tape yet.
Jim Ayers
LOM RV-3 N47RV (15 pound prop on dry prop flange, 10 ounce governor) (Now if I
could just get the vibration level down too were I like it. But a wood prop
balanced within FAA specs runs to rough to me.)
Matt, please send the instructions to
>From: jp(at)europa.com (John Peaslee)
>Subject: RV emailgroup
>Guys ... email me the particulars
>for subscribing to the RV email group
>send it to jp(at)europa.com
>thanks
> - JP -
Subject: | Wing skins (again) -Reply |
A slight inward bend in that area.
>>> B F Gibbons
02/01/96 06:16am >>>
are two rows of screws. The bottom row
the spar? What holds the trailing couple
skin down?
Thanks in advance.
Subject: | Re: RVator/Ivoprop |
Jim,
What is the LOM engine? You have referred to it several times and I
just thought it was some acronym that I wasn't getting. In your latest
posting you refer to it as a prototype. I'd love to know about it. Thanks!
Becki Orndorff
Becki Orndorff
NCI-FCRDC, Computer & Statistical Services
Ross -- at least one of the ingrediants (the main one, I think) is Chromic
Acid, I believe...the manufacturer of the product here in Canada is
Amchem...you may have more luck with a "coatings" company located near an
airport...that's where I found mine. When you find it, read the label
carefully...it looks like nasty stuff to me. Best of luck! Cheers...
Terry in Calgary
S/N 24414
From: owner-rv-list(at)matronics.com on behalf of Ross Rebgetz
Sent: February 2, 1996 13:53 PM
Subject: RV-List: Alodine
Thanks in advance
Ross
+61 077 753192 H
Mail : CSIRO
Davies Laboratory
Private Mail Bag
Aitkenvale Qld 4814
Australia
From: | bcos(at)ix.netcom.com (William Costello ) |
Subject: | BF Gibbons' Archive Search |
Hi Folks,
Don't want to thrash this subject, but I think I owe my comment.
I just finished downloading and unzipping everything to use the
'Gibbons' Archive search program and I want to say I think it is
fantastic -- bothe the use and efficiency of the program and the fact
that BF and Matt Dralle have made this available to us.
What this means is that we have all the combined wisdom, experience,
and suggestions of all the RV builders on this list over the last 5
years at our fingertips. It will certainly save me a lot of head-
scratching time and mistakes.
So thanks much, guys, I am sure I am not the only one who greatly
appreciates what you have done. And if anyone out there wonders about
the value of getting this set up, my strong suggestion is JUST DO IT!
Bill Costello
___ _______________________
\ \ _ _ / /
\ /? \ / \ / Bill Costello \
X-*#####*******......./ Chicago /
o/\ \ \_\ \ RV-6 on emp. \
\__\ \ bcos(at)ix.netcom.com /
\______________________\
From: | William French <wfrench(at)freenet.npiec.on.ca> |
Subject: | RV-Search program |
Could someone please tell me the FTP address for the RV-Search
program by B.F. Gibbons
Much thanks in advance.
Bill French
Decathlon C-GJXT
Subject: | Re: RV-Search program |
>Bill French
>Decathlon C-GJXT
Both the Archives and the Search program are now available at:
ftp.matronics.com
under:
/pub/business/matronics
rivets?"
>>James Kelley
aha....thanks. As a Canadian newcomer to this list and to email/internet in
general, I had never run across this acronym. Peter Hanna
From: | "David A. Barnhart" <barnhart(at)crl.com> |
Give the tank skin in that area a slight bend inward so that its natural
tendency is to press on the spar. You should be able to do it so that
when the tank is installed, the bend is not noticable. Mine isn't.
Best Regards,
Dave Barnhart
rv-6 sn 23744
Subject: | Re: Pre-punched Wing Skins Tip |
> and spar....
I received one of the first wing kits with the pre-punched skins, so
things may have changed, but I found the fit of the skins to be pretty
good. MY sequence was:
1. draw the 'leading-edge-to-main-skin' mating line on the spar.
2. Fit the main skins (but don't drill them) during skeleton assembly so
that you get the ribs exactly lined up with the pre-punched holes.
3. install the Leading edge skin, drawing it down to the mating line.
Completely assemble the leading edge (rivet skin to ribs), but just
cleco it to the spar, don't rivet it down.
4. Build the fuel tank. Again, because of the pre-punched holes for the
back baffle and screws, you can tell exactly how much to draw it down
onto the spar.
5. Fit the Top main skins.
6. Fit the bottom main skins.
If there is any skin trimming that needs to be done, then you can trim
off BOTH the leading edge/tank skin AND the main skin. That way you have
to remove only a few thousands from each skin, and can maintain edge
distance for the pre-punched holes.
BTW, I think it is a good idea to have about 1/32-inch clearance between
the tank skin and its adjacent skins. That way if I have to remove the
tank later, I'm less apt to damage the paint.
Best Regards,
Dave Barnhart
rv-6 sn 23744
The PPG Part number is DX503
Best Regards,
Dave Barnhart
rv-6 sn 23744
Bend it slightly so it hugs the spar.
Dan Boudro
> Thanks in advance.
For those of you about to get started...
I had a lot of trouble with my emp. jig twisting (rebuilt it three
times). On the wing jig I took a sheet of 1/2 plywood and ripped it
into strips to encase the 4x4 cedar posts. I glued and screwed them
on. After three months, no warping, twisting, turning. Worked
great.
I also saw a fuse jig made entirely out of 3/4 inch plywood laid up
into 'home made' 2x4's. Strong and straight. Worked great.
propeller
that
propeller
a Lyc
>Jim Ayers
>Jim: Would you share the performance data that you've collected on the Ivo
Prop over the last 2 years? Thanks, Bob Skinner RV-6
>trim them to fit."
Hmmm. That sounds like a pain. I got one of the first Pre-punched wing kits,
and this is how I did it: (It won't help you unfortunately, but it may help
someone else)
I drew the 1" line horizontally all the way across the spar, then pulled the
L.E. skin down to it with straps. ( It could have gone a BIT farther, but
would have require a LOT of pressure ) After riveting, I did the same with
the tank skin. After the tank was installed I merely butted the main skins
up to the L.E. skins, and they fit perfectly. All the holes lined up, and I
didn't have to trim anything.
-- Ed Bundy
Subject: | Re: Explosion Proof Fans |
your are right ... pressuized ventilation is the only way to go. there is NO
WAY you can suck fumes through a fan without the possibility of an explosion
whish could wipe out everything you have..an explosion of paint "dust" is
rapid and hot you would not have time to react to save your project. remember
everythimg around you may have a fine mist of paint on it including you..and
if you really want to hear a great laugh, wait till you try to explain it to
your insurance co. not saying that i don't play these games to but, be real
careful....
jimnjac (fireman) hillsboro or.
Anyboby have the scoop on Catto Props? Early RV List posting indicate that
they have been used on RV's. I jsut noticed a Cozy Mark IV in Kitplanes
with a 180HP Lycoming and a three blade Catto prop. Comments?
Terry ,
You are more then likely or with that bend back, the reason is that the bend
was not that much to start with. Just check of any sign of cracks ....George
Orndorff
Those of you having problems with 4 x 4's, might try nailing two 2 x 4's
together, maybe even glueing them, too. We got our wood way ahead of time
and kept it near the wood stove to dry out before we build a jig with it.
Becki Orndorff
>great.
Becki Orndorff
>great.
The fuse jig I am useing was made of 2x8 glue lam. This is commercially
produced by gluing plywood veneer together. Very strong. I am the fourth
user and it is still straight and true.
Is it possible that there are stresses built into the airframe when we construct
the fuselage. After all when we rivet the fuse together there is no 350lb weight
hanging on the end of it. Perhaps it is only natural that the loads sort of
reposition themselves in the first few hours. I know that this might be
unsightly, but what about repacing some of these loose rivets with small pan
head screws and nuts?
Tom Martin RV-4 85 hrs no smokers yet!
>great.
There seems to be a lot of trouble in this area, I know you can shim etc. to get
it right, but I for one was not happy, especially with the 4x4's specified for
the wing & emp. jigs. I could only find warped /split/wet lumber at several
yards.
I would think that the guys in the Pacific North West area probably have no
trouble finding good quality lumber, but this is not so in other areas, and
certainly here in Texas.
I wound up using 2X6" boards, screwing two together at about 8" intervals, in an
attempt to minimize any warpage (Glueing them as well would be even better I
suppose - but I didn't). For the vertical end posts I faced the "cup" of the
grains toward each other, so that any tendency to warp would be countered by the
other board. The "crossbar" on the emp. jig I again used 2 2x6, but this time
arranged them in a "T" shape (when viewed from the end)for better span support
It worked well for me, and did not appreciably move throughout building.
Rob Lee- presently frozen out of the shop - IN HOUSTON !!!!
In My Humble Opinion ???
Ross,
The DuPont product ID is 226S -- and they call it a Metal
Conditioner for Aluminium (well, they actually spell it differently ...
... good luck ... Gil Alexander
Flash: Just found the MSDS (Material Safety Data Sheet),
DuPont's _only_ active ingredients in 226S are:
Chromic Acid (1%)
Water
For their acid etch (225S):
Ethylene glycol monobutyl ether (14%)
Octylphenoxpolyethoxyethanol surfactant ... must be a typing test ... :^)
Phoshoric acid (22%)
Pottasium flouride
Water
Both Items should be stored under OSHA Class IIIB .. can anyone elaborate
on this?
... hope this answers your questions ... Gil Alexander
gil(at)rassp.hac.com
>Thanks in advance
>Ross
>x 4's
>time and kept it near the wood stove to dry out before we build a jig
>with it.
> Becki Orndorff
>Becki Orndorff
Hi Becky,
How did you keep it from warping while it dried out? Did you clamp it
somehow, keep buying more till some of it didn't warp, or just get very
lucky?
Bill Costello
\ \ _ _ / /
My theory is that the smoking rivets in this area are caused by the acoustic
noise coming from the exhaust pipes which are only a few inches away. The
vibration of the skins loosens the rivets which would otherwise be of
adequate size and rivet spacing.
Phil Arter
arter(at)acd.ucar.edu
I guess I should introduce myself, although I am reluctant to do so and
clutter up the list.
Phil Arter
Project Engineer, EOS HIRDLS Program
Atmospheric Chemistry Division
National Center for Atmospheric Research
Boulder, CO
BS Aerospace Engineering
Commercial Pilot - ASEL
Instrument Rating
Private Pilot - Glider
CFI from 1982-1991
A&P since 1978
IA from 1982-1989
I am waiting patiently for the RV-8 empennage kits to start shipping,
sometime around Easter is the latest word, although I'm not holding my
breath. I can't help but wonder how Van's will decide who is worthy of
getting the first shipments since they decline to take deposits in advance,
and don't have a waiting list. Does anybody know what they did in the past,
like when the RV-6 came out?
FYI - I bought an O-360 A1D out of a '60 Mooney M20A with 391 SMOH, 1441 TT
including Bendix mags, new Marvel Schebler carb, Nippon Denso starter, and
Woodward governor for $7500. I am now looking for a Hartzell C/S prop.
At your service-
Phil
>>great.
to get
>yards.
in an
by the
support -
>Regards,
Rob: Frozen in Houston? Come on, y'al don't know cold. We had wind chill
of -70 in Nebr. It was so cold (how cold was it?) that we couldn't carry on
conversations outside. The words just froze & we had to take them inside to
thaw out so we could converse. For the crosspiece on the wing jig, I got
three reasonably straight 2x4's and glued and screwed them together on a
very flay floor. I detected no shifting or warping when building this last
HS and VS. Bob Skinner RV-6
Subject: | Re: RV Drag Reduction |
On Tue, 30 Jan 1996, Peter Hanna wrote:
> 6. Any ideas on drag reduction, such as restricting cooling airflow with
> cowl vents in cruise, fairings at the wing junction, alternatives to springs
> and chain to tail wheel, any "lopresti" type improvements.
Get a copy of Kent Paser's book "Speed with Economy." He tells you
how he did this with an O-320 Mustang II. The mods he made increased
his top speed by 64 MPH without adding any HP. Obvioulsly the
Mustang II is a pretty high drag aircraft if he can get a 64 mph
improvement. Many of his mods are all ready incorporated in the RV designs.
But some great info on cooling drag reduction is explained as well as other
airframe drag reduction ideas. Lots of raw data that you can interpet
for yourself if you are so inclined.
I highly recommend the book to all RV builders who are interested
in improving performance of their RV. You can order the book direct from
Paser Publications. Check in the classified ads of Sport Aviation.
Bob Busick
RV-6
rbusick(at)nmsu.edu
There has been some discussion regarding trimming the wing skins and I wanted to
pass along something that works well for me - especially when you only need to
trim a small amount from the skin.
Since it is difficult to trim or file a perfectly straight line on the skins
(well, for me it is!), I used a router with a straight bit. I clamped the skin
to a table top using a piece of 1/8 thick foam to keep from scratching it, then
clamped a straight-edge the correct distance from the edge to follow with the
router base, and carefully ran the router along the edge.
Presto, a perfectly straight trimming job.
Practice on some scrap first if you are going to try this. There is a little
technique involved in maintaining a consistent speed with the router....but it's
not too difficult.
Hope this helps....
Bruce Stobbe
RV-6 fuselage
Subject: | Re: Wing skins (again) (fwd) |
> Reply-To: rv-list(at)matronics.com
> Curt Reimer
The other thing that will help hold down the tank trailing edge is
the wing root fairing. On my RV4, this 12 inch area did not want
to lay down properly. I think part of the problem was that Phlogisten
did not line up the web's as close as they should have been.
Anyway, I saw a plane from San Antonio and he had put number 4 nut
plates in this area. You have to be careful, but there is room for
about 3 nutplates such that the hole in the tank skins are quite close
to the trailing edge. Don't know if this will work on a -6 but I would
expect it would. The number 4 screws are small but they hold down this
skin nicely. I did this to my plane and it worked OK.
Herman
*NOTICE for internet mail*: Any ideas or thoughts expressed here are my
own and are independent of my employer.
Herman Dierks, Dept. E54S, AWSD, Austin, Texas
mail: dierks(at)austin.ibm.com
From: | "Elon Ormsby" <Elon.Ormsby(at)quickmail.llnl.gov> |
Subject: | Explosive Environment |
REGARDING Explosive Environment
There has been a lot of concern about explosions when painting in confined
spaces. Some recommendations have been excellent. However, I still don't
think we have been exposed to the magnitude of the problem (or even if there
is a problem). Just because we hear about a rare garage explosion still
doesn't put it into perspective on how safe or unsafe the practice is. I
would like to offer additional information in the hopes that someone (more
qualified than I) can put some numbers to the risk or at least explain it
clearly so I can make an educated decision on how to proceed.
Spontaneous combustion is explicitly not part of this discussion. (partly
because it confuses the issue and partly because it is not the problem we are
dealing with. Some one else can bring up the oily-rag issue).
The single ingredient left out of all past postings is that of "flammability
range". As we all know you CANNOT HAVE COMBUSTION unless all conditions
support combustion. Generally that means you must have (1) an ignition source,
(2) a flammable material, and (3) the presence of oxygen.
Taken one at a time:
(1) Is there an ignition source? Yes, A static discharge from the gun may
build up with time. With low pressure guns this may not be a problem. With
high pressure (1,000psi) the high pressure line is wire reinforced and
grounded to the sprayer to minimize this risk. And of course, you have
potential arcing from anything electrical (fans, compressor, don't forget that
hot filament when you break that light bulb!!).
(2) Do we have a flammable material? Obviously,
(3) Is oxygen present and in what amount? This is the KEY QUESTION, folks.
All materials have a very specific range of concentration when they will burn.
Outside of that envelope they will NOT IGNITE. A classic example is
hydrogen. It has the widest range of flammability of any material (2%-98%).
Nothing else comes close. Something we are all familiar with is gasoline.
Look at the mix in your a/c. Most of us (who know what that mixture knob
does) know that fuel/air mixtures can range about 12:1 to 15:1. On some new
cars with that O^2 sensor the electronics may lean up to 18:1. But, bottom
line, gas will not burn unless the AIR/FUEL mixture is generally between
6%-10%. That is a pretty narrow range. For gasoline that means you need 15
Lb. of AIR for each 1LB of GAS to get complete combustion. (best power(not
economy) is produced about 12:1 or 8% fuel to air). Notice my gasoline
numbers are based on the WEIGHT of the constituents not the volume. Other
materials will vary, but by how much I don't know.
So what?
If your enclosed paint booth is introducing a LARGE VOLUME of fresh air then
the flammable material will never get close to its flammable concentration
level and therefore will be perfectly safe. Some questions are: (1) what are
the flammable concentrations for some of our paint materials (2) How do you
calculate the fresh air CFM needed for the enclosed space to keep the dilution
below explosive levels? I would feel perfectly confortable about painting in
a confined space if I knew my environmental controls were adequate and safe.
Can any of you Industrial Hygienists (or others) "paint" a better picture.
Does anyone know the fresh air flow requirements for commercial paint booths?
How do we scale that down to size for a smaller booth? I know my gun CFM but
is that even important? Is the expansion rate of the molecules more
important? Is this subject too exhausting, too boring or too dangerous to
explore on this list?
Sorry for the diatribe - I am building my shop now and am very concerned. I
loved some of the great ideas presented. That screen table over the vent idea
- beautiful!.
Elon, ormsby1(at)llnl.gov
Subject: | Re: Alodine (fwd) |
> Chromic Acid (1%)
> Water
FYI, a local A&P/IA said they bought alodine in powder form
and mixed it with water. I suspect they just bought Chromic
acid (powder) and mixed it with water. He also said you could
mix it a little stronger and reduce the dwell time.
Like a lot of things we buy, the acid etich (phosphoric acid)
and alodine (chromic acid) are probably a rip-off for the
price we pay.
Herman Dierks
From: | "Richard Chandler" <mauser(at)Claris.COM> |
> have no trouble finding good quality lumber, but this is not so in
> other areas, and certainly here in Texas.
January 25, 1996 - February 02, 1996
RV-Archive.digest.vol-ba
