RV-Archive.digest.vol-cd
November 14, 1996 - November 23, 1996
      Conformable Acrylic Foam Tape
      The sample I have is a little thick (45 mils)
      I am still waitning on tech sheets and will post info when received.
      Final note.... I spoke with the 3m rep, slos a pilot who commented that
      it is very good at reducing oil canning. Also, after a cure time of 72
      hours the tape is stronger than rivits due to the total are it covers
      vs. rivits.  Just info.........
      Rick
      Rick(at)ccc.henn.tec.mn.us
      Rick Osgood
      9200 Flying Cloud Dr.
      Eden Prairie, MN 55347
Date: Nov 14, 1996
Subject: Re: Matronics Web Page Update!
subject: super glue a little background on the stuff called super glue or crazyglue. It is a material made from Cyanoacrylate ester. The stuff that glues your fingers together in an instant. The stuff was actually used for a while be doctors to glue wounds together. Worked well because it devolves in water about the same time as the wound heals. Completely disappears in about six weeks. NOTE: it desolves in water over a period of time. Do not use super glue for anything that you want to stay together. Gene Francis RV-6A N23GF (not flying yet) ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Re: backdrilling HS skeleton/skins
Hi Allan, You don't say what type of RV you're building, nor whether it's a pre-drilled kit. I'll assume it's pre-drilled (a -6A perhaps?) > I'm getting close to skinning my horizontal stabilizer. I've read >Van's instructions and looked at George Orndorff's method. I've also >looked at the method in the book "14 Years of The RV-ator". Has anyone >used this method and what kind of results did you have? I was also >thinking of a slight? modification to it by predrilling the skeleton so >there will be pilot holes, then fitting the skins with the clamps over >the outside as Van suggests, to get the proper dimension for the >trailing edge. Start from the center of each side of the spar, >clamping the skin to the rear spar and work outward. At the end and >center of the spar, drill the skin and clecoe each corner to hold the >trailing edge dimension as Van warns to keep a close eye on it. Then >lift one side of the skin at a time and backdrill through the pilot >holes and skin, putting in clecoes as I go. I'm open to ideas and >suggestions. I'd say No. You'd be lucky (or superhumanly accurate in your skeleton construction) if all your pilot holes exactly matched all the holes in the skin. If they don't you'll probably end up with either elongated holes or stress in the skin. FWIW, I just finished skinning my predrilled -6 HS, and had no problem with getting things lined up sufficiently... a few of my holes weren't quite in the centre of the ribs (front half of one root rib especially), but none were out far enough to compromise edge distance. Mark the centreline of the skeleton flanges, and use a Sharpie to put a dot on the skeleton through the skin's predrilled hole. You'll soon see how well things are lined up. IMHO, I think that back-drilling in this case is a *bad* idea. Every hole would be at a slight angle, so you would end up with the entire skin slightly misaligned. . Don't forget you're going to dimple everything too. This comment applies to either predrilled or undrilled skins. Frank. -- -------------------------------------------------------------------- frankv(at)pec.co.nz | "Knowledge=Power=Energy=Matter=Mass; Frank van der Hulst | A good bookshop is just a genteel Software Engineer | Black Hole that knows how to read". PEC(NZ) Ltd (Cardax), Marton | Terry Pratchett, "Guards! Guards!" http://www.pec.co.nz/~frankv/ | -------------------------------------------------------------------- ________________________________________________________________________________
Subject: Re: gas tanks
Date: Nov 14, 1996
From: "Calin Brabandt" <cwbraban(at)ichips.intel.com>
Regarding fuel tanks fire hazard reduction: > I think this is called 'explo-proof' or some such thing. > A word of caution. DO NOT use this if you have a flop tube in your > tank (for aerobatics). It's called "Explosafe", if I remember correctly from my motorcycle road racing days. It works very well in cars and bikes -- always wondered why you never hear about it in aircraft. Maybe it was the incompatability with flop tubes! Cal ________________________________________________________________________________
Date: Nov 14, 1996
Subject: Re: Actual Progress!
Avoid enlarging the tooling holes to get nuts, etc. inadvertantly left in the stabilizer. The inboard ones are used to verify alignment of the chord line with the fuselage. I'd just drill an "inspection hole" between the tooling holes. Randall Henderson, RV-6 randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Nov 14, 1996
From: Terry Mortimore <terry.mortimore(at)sympatico.ca>
kevin lane wrote: > > I was reading about a product that racers use in their fuel tanks, a > scotch-brite-like mesh that makes the tank explosion proof. It uses 1% > of the volume and costs about $1/gal. It said it could be fitted in > anywhere you have a hand-sized hole. Has anyone know/used this? I may regret saying this without looking up the article, but I believe there was a problem with this material retaining moisture. Terry RV-6A ________________________________________________________________________________
Date: Nov 14, 1996
Subject: Re: Advice needed to repair small crack in canopy
Tyvek is a synthetic, water-proof, tear-proof paper substitute used by printers. Probably its most familiar application is the large Fed-X envelope. The least expensive way to get ahold of it is through a paper distributor. Jeff Carpenter ________________________________________________________________________________
Date: Nov 14, 1996
From: lsmith(at)coastalnet.com (Louis E. Smith Jr.)
Subject: Re: Fuel tank brackets
>A common mod is to add an .063 doubler to the inside of the rib at the >inside of the inboard fuel tank nose rib. In fact I believe they are >now shipping kits with a pre-cut piece to put there. My plans don't >show this part, but I think some of the picture pages in the manual >do, and I think it is even discussed in the manual. And newer >plans/manuals may well show it. >Randall Henderson, RV-6 >randall(at)edt.com >http://www.edt.com/homewing > > The kits do indeed now come with the .063 doubler for the inboard fuel tank nose rib. I received my partial wing kit a couple of weeks ago and it was included. Louis Smith RV-8 #80126 Flaps and ailerons completed, waiting on wing spar! lsmith(at)coastalnet.com ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Re: 3m Tape info
>Here is the info that I have so far.... >The product is labeled as follows: > >Scotch VHB >4941F >Conformable Acrylic Foam Tape > >The sample I have is a little thick (45 mils) > >I am still waitning on tech sheets and will post info when received. > >Final note.... I spoke with the 3m rep, slos a pilot who commented that >it is very good at reducing oil canning. Also, after a cure time of 72 >hours the tape is stronger than rivits due to the total are it covers >vs. rivits. Just info......... Out of curiosity: 1. Will the tape stick to fibreglass? Perhaps this is a way to attach tips etc without pop rivets? 2. Once it's stuck down, can you undo it? I mean, with rivets you can drill them out. With this stuff stuck down, would your HS or VS or wing become an unrepairable unit? Frank. -- -------------------------------------------------------------------- frankv(at)pec.co.nz | "Knowledge=Power=Energy=Matter=Mass; Frank van der Hulst | A good bookshop is just a genteel Software Engineer | Black Hole that knows how to read". PEC(NZ) Ltd (Cardax), Marton | Terry Pratchett, "Guards! Guards!" http://www.pec.co.nz/~frankv/ | -------------------------------------------------------------------- ________________________________________________________________________________
Date: Nov 14, 1996
Subject: Re: hvlp,squeezer
> > 2) rivet squeezer vs. pneumatic, advantages disadvantages? > Did you check the FAQ? There's a discussion in there, and also lots about that in the archives. Randall Henderson, RV-6 randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Nov 14, 1996
Subject: Wanted: RV-6 plans
I got the following from a reader of the "Home Wing Home Page".... can anyone help? Send responses to his email, and NOT the rv-list, as I don't think he's on the -list. Randall Henderson, RV-6 randall(at)edt.com http://www.edt.com/homewing ------------- Begin Forwarded Message ------------- Date: Thu, 14 Nov 1996 15:39:59 -0600 (CST) From: "metal(at)netins.net" <Dave.Rice(at)netins.net> Subject: Classified ad Want plans for RV-6 to review and use in my classroom (highschool) e-mail at metal(at)netins.net ------------- End Forwarded Message ------------- ________________________________________________________________________________
Date: Nov 14, 1996
Subject: Fiberglass tape
Would someone send me a phone number for a mail order supplier who handles the 2" fiberglass tape like George uses to glass the canopy in his video. Wicks and Aircraft Spruce are out of stock, -- Chet Razer crazer(at)egyptian.net ________________________________________________________________________________
Date: Nov 14, 1996
>Regarding fuel tanks fire hazard reduction: > >> I think this is called 'explo-proof' or some such thing. >It's called "Explosafe", if I remember correctly from my motorcycle >road racing days. It works very well in cars and bikes -- always >wondered why you never hear about it in aircraft. Maybe it was >the incompatability with flop tubes! I remember a article from the tech councelor, the explo-proof was in a Pitts. Had been in there for a few (?) years, it was determined that it had deteriorated and plugged the fuel lines, at the wrong time. I talked to a racer buddy and he said the stuff was good but needed to be relaced every couple of years, because it would breakdown into fragments and could lodge in a fuel line or filter. Doug Doug Bloomberg RV-6A (in the womb) Denver, CO dougb(at)mail.diac.com (home) doug(at)boulder.vni.com (work) ________________________________________________________________________________
From: J.Ken_Hitchmough(at)magic.ca (J.Ken Hitchmough)
Date: Nov 14, 1996
Subject: Re: Seat cushion fabrication
This is a MIME multipart message. -------------------------------------------------_=_MIME-Boundary_=_ Here are a couple of drawings I made from Bingelis' article. One is a sketch of each part, the other is an assembly drawing. They are in Macintosh PICT format. Unfortunately for those of you with DOS/Windows I'm not sure how you would read them unless a friendly Mac user could print them for you. Ken RV6A Flying -------------------------------------------------_=_MIME-Boundary_=_ UElDVDIwAAQAAwAAAEgASAAAAAAC2gIo/+H/4gL5AkYDRwUoA/wAAgAAAEgASAAAAAAC2gIo AAEAAABkAAAAAQABAQEAAAABJw8AAQABAHVwEgAAAAAAAAAAAAIAGQGQAAAAAABAAAAAAAAA AAAAAQAAAAAAAAAAAAAAAAAAAAAAMABGAtwCoAAAACYAAAABAAEEAwACAAEAAQBIAEgABwAC AAAAACAAAAAQAAAAEAAAACAAAABAAAAAAGQAAABkAABAAAAAEAAAACAAAAEAAwAAAAIAAAAB AAAAAwAAAAYAAAAAAGQAAABkAAYAAAACAAAAAwAAAAAAAAEAAAAAAAAAAAAAAIAAAACAAAAA AAAAAQAAAQAAAAABAAEAAAAAgAAAAIAAAAAAAAACAAABAAAAAAAAAAAAAACAAAAAgAAAAAAA AAAAAAEAAAIAAAAAAAAAAIAAAACAAAAAAAAAAQAAAQAAAgAAAAEAAAAAgAAAAIAAAAAAAAAC AAABAAAAAAAAAAAAAACAAAAAgAAAAAAAAAAAAAAAAAAAHwAAAAAAAQIBAAAAAgABAAoAJgAA /bMAAAAAAAAAAQABAAkAAAAOAAEAAQAAAAAAAAAAAAAAAAEAAAAAAAAAAAAAAAASAAACAQAS AAAAEgAAAszjAODiAOJj6mTsEO4E6RDqZOIlIAAJABECswIIABEC/wwA/////wARAAAACQAA AggAAAKzAAAAAAAAAKAAggChAGQAHk1EMjADhkxheWVyLTEAAAAAAAAAAAAAAAA/AAcAAwCh AGQABk1EMjADhAAa////////AAEACgAJABECswIIAAkAAAAAAAAAAAAxAD8AOwEdAMMAGgAA AAAAAAAJ//////////8AOAChAGQANk1EMjADiwAAAAAAAQIBAAAAAgABAAEAPwAAADqAAAA/ AAAAwYAAARuAAADBgAABG4AAADqAAAChAGQABk1EMjADhQChAGQABk1EMjADhAAgAEAALQES AC0AcQAeADsAKgBAADAAOwAtAEAAKgBAAC0AQAAwADsALQBwAB4AOwAqAEAAMAA7AC0AQAAq AEAALQBAADAAOwAtAHEAHgESACoBFwAwARcALQESACoBEgAtARIAMAEXAC0AcAAeARIAKgEX ADABFwAtARIAKgESAC0BEgAwARcALQChAGQAJE1EMjADigAAAAAAAQIBACIAAgBaADqAAAAt AAABFwAAAC0AAAChAGQABk1EMjADhQChALYABAABAP8AoQCWAAwCAP+mAAD/pgAAAAAAoQCa AAj/+wAAABQAAACQAAQAjwAZAMQALACPABkAxAAsAI8AGQDDACsAAQAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAADAAAAAAAAAAMAAAAAAAAAAAAAAAGIAAACSAAAAigAAAIYAAABCAAA AAAAAAYAAAABgAAAAGAAAAAYAAAAAAAAAAAAAAAAAAAAAAAAA/gAAAEAAAAAAAAAAAAAAABA AAAAQAAAAEAAAABAAAAAAAAAACAAAAP4AAABIAAAAKAAAABgAAAAAAAAAYgAAAJIAAACKAAA AhgAAAEIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEACgAAAAAAAAAAACwACQAB BkdlbmV2YQAAAwABAA0ACQAuAAQAAAAAACsOrgcyNC0xLzIiAKAAlwChALYABAABAAEAoQBk AAZNRDIwA4QAAQAKAAkAEQKzAggAIgEuAEB9AABxAB4BKwA7ATEAQAEuADsBMQBAAS4AQAEr AEABLgA7AHAAHgErADsBMQBAAS4AOwExAEABLgBAASsAQAEuADsAcQAeASsAvQExAMIBLgDC ATEAvQEuAL0BKwC9AS4AwgBwAB4BKwC9ATEAwgEuAMIBMQC9AS4AvQErAL0BLgDCAKEAZAAk TUQyMAOKAAAAAAABAgEAIgACAFoBLYAAADqAAAEtgAAAwYAAAKEAZAAGTUQyMAOFAKEAtgAE AAEA/wArZ3kDMTUiAKEAtgAEAAEAAQChAGQAHE1EMjADnQAAAAAAcgAAAFcAAACVAAAAmQAA AAAAoQCWAAwCAAAAAgAAAAAAAAAAAQAKAHUAWgCSAJYABAEAAA0ADAAoAIEAcgFGAAQAAAAN AAoAKQgCIA0AKACPAF0JU0VBVCBCQUNLAKAAlwABAAoACQARArMCCAAyAJ4AYwCrAJMAAQAK AJ4AYwCrAJMAMgCegAIAq3/+ACsHGQcxIiBGSVJNAKEAZAAGTUQyMAOEAAEACgAJABECswII ADAAPwDvAQ8BFAChAGQANk1EMjADiwAAAAAAAQIBAAAAAgAAAAAAPwAAAO6AAAA/AAABEoAA AQ4AAAESgAABDgAAAO6AAAChAGQABk1EMjADhQChAGQABk1EMjADhAAgAD8BCgEOAQoAoQBk ACRNRDIwA4oAAAAAAAECAQAAAAIAWgA/AAABCYAAAQ4AAAEJgAAAoQBkAAZNRDIwA4UAoQBk AAZNRDIwA4QAoACgAKAApQAiATIA7xv3ACMJAAAjAA4AI9wAACMAAAAjAPsAoAChAKEAZABA TUQyMAOYAAAAAAABAgEAAAACAAAAAAEAATIAAADugAABKQAAAQmAAAEpAAABEoAAATaAAAES gAABNoAAAO6AAAChAGQABk1EMjADhQChAGQABk1EMjADhAAiASUA9BoAAHEAHgEiAO8BKAD0 ASUA7wEoAPQBJQD0ASIA9AElAO8AcAAeASIA7wEoAPQBJQDvASgA9AElAPQBIgD0ASUA7wBx AB4BIgEOASgBEwElARMBKAEOASUBDgEiAQ4BJQETAHAAHgEiAQ4BKAETASUBEwEoAQ4BJQEO ASIBDgElARMAoQBkACRNRDIwA4oAAAAAAAECAQAiAAIAWgEkgAAA7oAAASSAAAESgAAAoQBk AAZNRDIwA4UAoQC2AAQAAQD/AA0ACQArl3YCNCIAAKEAtgAEAAEAAQChAGQAHE1EMjADnQAA AAAAlgAAAPAAAACsAAABBwAAAAAAoQCWAAwBAAAAAgAAAAAAAAAAAQAKAJkA8wCpAQQABAEA AA0ADAAoAKUA9AFBAKAAlwChAGQAHE1EMjADnQAAAAAAtYAAAPAAAADIgAABEwAAAAAAoQCW AAwBAAAAAgAAAAAAAAAAAQAKALkA8wDGARAABAAAAA0ACgAqHgQxLjUiAKAAlwChAGQAHE1E MjADnQAAAAAA0IAAAPAAAADjgAABEwAAAAAAoQCWAAwBAAAAAgAAAAAAAAAAAQAKANQA8wDh ARAAKhsDTUVEAACgAJcAoQBkABxNRDIwA50AAAAAASGAAAEhgAABToAAAXaAAAAAAKEAlgAM AQAAAAIAAAAAAAAAAAEACgElASUBTAF0ACsyUQxFREdFIFNUUklQUw0AACoNDU1BS0UgMiBA IDIzIg0AACoNDE1BS0UgMiBAIDE5IgCgAJcAoQBkAAZNRDIwA4QAAQAKAAkAEQKzAggAMAFf ADsB3gDDAKEAZAA2TUQyMAOLAAAAAAABAgEAAAACAAAAAAFfAAAAOoAAAV8AAADBgAAB3QAA AMGAAAHdAAAAOoAAAKEAZAAGTUQyMAOFAKEAZAAGTUQyMAOEAJAABAAAAAAACwAgAAAAAAAL ACABbAA2AXcAVgABAAAAAAAAAAAAAAAAAAAAAAAAAAAH5+fgAAAAAAAAAAAAAAAAAAAAAAAA AAAAkAAEAAAAAAALACAAAAAAAAsAIAFsAEsBdwBrAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAT8 /OAAAAAAAAAAAAAAAAAAAAAAAAAAAACQAAQAAAAAAAsAIAAAAAAACwAgAWwAYAF3AIAAAQAA AAAAAAAAAAAAAAAAAAAAAAAAB5+fgAAAAAAAAAAAAAAAAAAAAAAAAAAAAJAABAAAAAAACwAg AAAAAAALACABbAB1AXcAlQABAAAAAAAAAAAAAAAAAAAAAAAAAAAD8/PgAAAAAAAAAAAAAAAA AAAAAAAAAAAAkAAEAAAAAAALACAAAAAAAAsAIAFsAIoBdwCqAAEAAAAAAAAAAAAAAAAAAAAA AAAAAAZ+fmAAAAAAAAAAAAAAAAAAAAAAAAAAAACQAAQAAAAAAAsAIAAAAAAACwAgAWwAnwF3 AL8AAQAAAAAAAAAAAAAAAAAAAAAAAAAAB8/PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAJAABAAA AAAACwAYAAAAAAALABQBbAC0AXcAyAABAAAAAAAAAAAAAAAAAAAAAAAAAAAB+AAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAoQBkACRNRDIwA4oAAAAAAAECAQEAAAIAWgFxAAAAOoAAAXEAAADB gAAAoQBkAAZNRDIwA4UAoQBkAAZNRDIwA4QAkAAEAAAAAAALACAAAAAAAAsAIAGrADYBtgBW AAEAAAAAAAAAAAAAAAAAAAAAAAAAAAfn5+AAAAAAAAAAAAAAAAAAAAAAAAAAAACQAAQAAAAA AAsAIAAAAAAACwAgAasASwG2AGsAAQAAAAAAAAAAAAAAAAAAAAAAAAAABPz84AAAAAAAAAAA AAAAAAAAAAAAAAAAAJAABAAAAAAACwAgAAAAAAALACABqwBgAbYAgAABAAAAAAAAAAAAAAAA AAAAAAAAAAAHn5+AAAAAAAAAAAAAAAAAAAAAAAAAAAAAkAAEAAAAAAALACAAAAAAAAsAIAGr AHUBtgCVAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAPz8+AAAAAAAAAAAAAAAAAAAAAAAAAAAACQ AAQAAAAAAAsAIAAAAAAACwAgAasAigG2AKoAAQAAAAAAAAAAAAAAAAAAAAAAAAAABn5+YAAA AAAAAAAAAAAAAAAAAAAAAAAAAJAABAAAAAAACwAgAAAAAAALACABqwCfAbYAvwABAAAAAAAA AAAAAAAAAAAAAAAAAAAHz8/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAkAAEAAAAAAALABgAAAAA AAsAFAGrALQBtgDIAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAH4AAAAAAAAAAAAAAAAAAAAAAAA AAAAAAChAGQAJE1EMjADigAAAAAAAQIBAQAAAgBaAbAAAAA6gAABsAAAAMGAAAChAGQABk1E MjADhQChAGQABk1EMjADhAAiAWQALQB0AHEAHgFfACoBZAAwAV8ALQFkACoBZAAtAWQAMAFf AC0AcAAeAV8AKgFkADABXwAtAWQAKgFkAC0BZAAwAV8ALQBxAB4B2AAqAd0AMAHdAC0B2AAq AdgALQHYADAB3QAtAHAAHgHYACoB3QAwAd0ALQHYACoB2AAtAdgAMAHdAC0AoQBkACRNRDIw A4oAAAAAAAECAQAiAAIAWgFfAAAALQAAAd0AAAAtAAAAoQBkAAZNRDIwA4UAoQC2AAQAAQD/ AKEAlgAMAgD/pgAA/6YAAAAAAKEAmgAI//sAAAALAAAAkAAEAY0AFwGwAC4BjQAXAbAALgGN ABcBrwAtAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMAAAAAAAAAAwAAAAAA AAAACAAAA/4AAAEIAAAAiAAAAEgAAAAoAAAAGAAAAAAAAAAAAAAAAAAAAAAAAAP+AAABAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAoAAAAAAAAAAAAN AAwAKAGjABcDMTQiAKAAlwChALYABAABAAEAoQBkAAZNRDIwA4QAoACgAKAApQABAAoACQAR ArMCCAAiAd0A1ACCACMbEgAjAD8AIwAAACPlLQCgAKEAoQBkADhNRDIwA5gAAAAAAAECAQAA AAIAAAAAAQAB3QAAANOAAAFfAAAA04AAAXEAAADugAABsAAAAO6AAAChAGQABk1EMjADhQCh AGQAHE1EMjADnQAAAAABe4AAAFuAAAGegAAAnIAAAAAAoQCWAAwCAAAAAgAAAAAAAAAAAQAK AX8AXwGcAJoABAEAACgBiwB4AUUABAAAAA0ACgApCAENAAAoAZkAYglTRUFUIEJBU0UAoACX AKEAZAAcTUQyMAOdAAAAAAGfgAAAYAAAAbKAAACWAAAAAAChAJYADAEAAAACAAAAAAAAAAAB AAoBowBjAbAAkwArAhQHMyIgRklSTQCgAJcAoQBkABxNRDIwA50AAAAAAbYAAAEdAAAByQAA ATAAAAAAAKEAlgAMAQAAAAIAAAAAAAAAAAEACgG5ASABxgEtACu9FgIgIAAAoACXAKEAZAAG TUQyMAOEAAEACgAJABECswIIADACDwA7Aq0AwwChAGQANk1EMjADiwAAAAAAAQIBAAAAAgAA AAACDoAAADqAAAIOgAAAwYAAAqwAAADBgAACrAAAADqAAAChAGQABk1EMjADhQChAGQABk1E MjADhACQAAQAAAAAAAsAIAAAAAAACwAgAnoANgKFAFYAAQAAAAAAAAAAAAAAAAAAAAAAAAAA B+fn4AAAAAAAAAAAAAAAAAAAAAAAAAAAAJAABAAAAAAACwAgAAAAAAALACACegBLAoUAawAB AAAAAAAAAAAAAAAAAAAAAAAAAAAE/PzgAAAAAAAAAAAAAAAAAAAAAAAAAAAAkAAEAAAAAAAL ACAAAAAAAAsAIAJ6AGAChQCAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAefn4AAAAAAAAAAAAAA AAAAAAAAAAAAAACQAAQAAAAAAAsAIAAAAAAACwAgAnoAdQKFAJUAAQAAAAAAAAAAAAAAAAAA AAAAAAAAA/Pz4AAAAAAAAAAAAAAAAAAAAAAAAAAAAJAABAAAAAAACwAgAAAAAAALACACegCK AoUAqgABAAAAAAAAAAAAAAAAAAAAAAAAAAAGfn5gAAAAAAAAAAAAAAAAAAAAAAAAAAAAkAAE AAAAAAALACAAAAAAAAsAIAJ6AJ8ChQC/AAEAAAAAAAAAAAAAAAAAAAAAAAAAAAfPz8AAAAAA AAAAAAAAAAAAAAAAAAAAAACQAAQAAAAAAAsAGAAAAAAACwAUAnoAtAKFAMgAAQAAAAAAAAAA AAAAAAAAAAAAAAAAAfgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKEAZAAkTUQyMAOKAAAAAAAB AgEBAAACAFoCfwAAADqAAAJ/AAAAwYAAAKEAZAAGTUQyMAOFAKEAZAAGTUQyMAOEACACEwA7 AhMAwgChAGQAJE1EMjADigAAAAAAAQIBAAAAAgBaAhMAAAA6gAACEwAAAMGAAAChAGQABk1E MjADhQChAGQABk1EMjADhAAgAhQALQKnAC0AcQAeAg8AKgIUADACDwAtAhQAKgIUAC0CFAAw Ag8ALQBwAB4CDwAqAhQAMAIPAC0CFAAqAhQALQIUADACDwAtAHEAHgKnACoCrAAwAqwALQKn ACoCpwAtAqcAMAKsAC0AcAAeAqcAKgKsADACrAAtAqcAKgKnAC0CpwAwAqwALQChAGQAJE1E MjADigAAAAAAAQIBACIAAgBaAg6AAAAtAAACrAAAAC0AAAChAGQABk1EMjADhQChALYABAAB AP8AoQCWAAwCAP+mAAD/pgAAAAAAoQCaAAj/+wAAABoAAACQAAQCPQAXAn4ALgI9ABcCfgAu Aj0AFwJ9AC0AAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAwAAAAAAAAADAAAA AAAAAAAAAAABwgAAAiIAAAISAAACCgAAAQYAAACCAAAAAAAAAAAAAAYAAAABgAAAAGAAAAAY AAAABgAAAAAAAAAAAAAAAAAAAAAAAAP+AAABAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAAIAAA ACAAAAAgAAAAIAAAAAAAAAAAAAADAAAAAsAAAAIwAAACDgAAAgAAAAIAAAAAAAAAAAAAAAAA AAAAAAAAA/4AAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAEACgAAAAAAAAAAAA0ADAAoAmIACAcxNy0xLzIiAKAAlwChALYABAABAAEAoQBkAAZNRDIw A4QAoACgAKAApQABAAoACQARArMCCAAgAhMA1AKsANQAIxLTACMAkAAjAAAAI+4EAKAAoQCh AGQAOE1EMjADmAAAAAAAAQIBAAAAAgAAAAABAAITAAAA04AAAqwAAADTgAACfwAAAOWAAAIO gAAA5YAAAKEAZAAGTUQyMAOFAKEAZAAcTUQyMAOdAAAAAAIrAAAAQIAAAkEAAACfgAAAAACh AJYADAEAAAACAAAAAAAAAAABAAoCLgBEAj4AnQAEAQAAKAI6AEUBRAAEAAAADQAKACkJDSBT RUFUIFBBQ0tJTkcAAKAAlwChAGQAHE1EMjADnQAAAAACQYAAAGAAAAJUgAAAlgAAAAAAoQCW AAwBAAAAAgAAAAAAAAAAAQAKAkUAYwJSAJMAKxYVBzIiIEZJUk0AoACXAKEAZAAGTUQyMAOE AAEACgAJABECswIIADAASAFJAPQB0QChAGQANk1EMjADiwAAAAAAAQIBAAAAAgAAAAAASAAA AUiAAABIAAABz4AAAPMAAAHPgAAA8wAAAUiAAAChAGQABk1EMjADhQChAGQABk1EMjADhAAg AFEBSQBRAdAAoQBkACRNRDIwA4oAAAAAAAECAQAAAAIAWgBRAAABSIAAAFEAAAHPgAAAoQBk AAZNRDIwA4UAoQBkAAZNRDIwA4QAoACgAKAApQAgAFEB7wDzAe8AIxIAACEASAIBACMAAAAj 7gkAoAChAKEAZAA4TUQyMAOYAAAAAAABAgEAAAACAAAAAAEAAFEAAAHvAAAA8wAAAe8AAADz AAACAQAAAEgAAAIBAAAAoQBkAAZNRDIwA4UAoQBkABxNRDIwA50AAAAAAGkAAAFuAAAAjAAA AZMAAAAAAKEAlgAMAgAAAAIAAAAAAAAAAAEACgBsAXEAiQGQAAQBAAANAAwAKAB4AXoBQwAE AAAADQAKACkJAiANACgAhgF0BFNFQVQAAKAAlwChAGQAHE1EMjADnQAAAAAAkQAAAWKAAACk AAABqIAAAAAAoQCWAAwBAAAAAgAAAAAAAAAAAQAKAJQBZgChAaYAKACeAWcJMiIgTUVESVVN AKAAlwChAGQABk1EMjADhAABAAoACQARArMCCAAwAXEBKQG6AbEAoQBkADZNRDIwA4sAAAAA AAECAQAAAAIAAAAAAXEAAAEpAAABcQAAAbAAAAG5AAABsAAAAbkAAAEpAAAAoQBkAAZNRDIw A4UAoQBkAAZNRDIwA4QAoACgAKAApQAiAXEB4u5IACMSAAAjAAAAIwC4AKAAoQChAGQAME1E MjADmAAAAAAAAQIBAAAAAgAAAAABAAFxAAAB4YAAAbkAAAHPgAABuQAAAeGAAAChAGQABk1E MjADhQChAGQAHE1EMjADnQAAAAABgAAAAUEAAAGjAAABlAAAAAAAoQCWAAwCAAAAAgAAAAAA AAAAAQAKAYMBRAGgAZEABAEAAA0ADAAoAY8BZAFCAAQAAAANAAoAKQkCIA0AKAGdAUcMU0VB VCBQQUNLSU5HAACgAJcAoQBkABxNRDIwA50AAAAAAZ+AAAFFgAABsoAAAYuAAAAAAKEAlgAM AQAAAAIAAAAAAAAAAAEACgGjAUkBsAGJACsDEAkyIiBNRURJVU0AoACXAKEAZAAGTUQyMAOE AAEACgAJABECswIIACIBdgHHAD4AcQAeAXEBxAF2AcoBcQHHAXYBxAF2AccBdgHKAXEBxwBw AB4BcQHEAXYBygFxAccBdgHEAXYBxwF2AcoBcQHHAHEAHgG0AcQBuQHKAbkBxwG0AcQBtAHH AbQBygG5AccAcAAeAbQBxAG5AcoBuQHHAbQBxAG0AccBtAHKAbkBxwChAGQAJE1EMjADigAA AAAAAQIBACIAAgBaAXEAAAHGgAABuQAAAcaAAAChAGQABk1EMjADhQChALYABAABAP8AoQCW AAwCAP+mAAD/pgAAAAAAoQCaAAj/+wAAAAcAAACQAAQBiAGwAaMBxwGIAbABowHHAYgBsAGi AcYAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAwAAAAAAAAADAAAAAAAAAAAA AAABvAAAAkIAAAJCAAACQgAAAkIAAAG8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAABAAoAAAAAAAAAAAANAAwAKAGaAbQCOCIAAKAAlwChALYABAABAAEAoQBkAAZNRDIw A4QAAQAKAAkAEQKzAggAIABNAeYA7gHmAHEAHgBIAeMATQHpAEgB5gBNAeMATQHmAE0B6QBI AeYAcAAeAEgB4wBNAekASAHmAE0B4wBNAeYATQHpAEgB5gBxAB4A7gHjAPMB6QDzAeYA7gHj AO4B5gDuAekA8wHmAHAAHgDuAeMA8wHpAPMB5gDuAeMA7gHmAO4B6QDzAeYAoQBkACRNRDIw A4oAAAAAAAECAQAiAAIAWgBIAAAB5gAAAPMAAAHmAAAAoQBkAAZNRDIwA4UAoQC2AAQAAQD/ AKEAlgAMAgD/pgAA/6YAAAAAAKEAmgAI//sAAAALAAAAkAAEAI0B0ACwAecAjQHQALAB5wCN AdAArwHmAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMAAAAAAAAAAwAAAAAA AAAAAAAAAfgAAAIUAAACEgAAAhIAAAISAAAB4AAAAAAAAAAAAAAAAAAAAAAAAAP+AAABAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAoAAAAAAAAAAAAo AKMB0AMxOSIAoACXAKEAtgAEAAEAAQChAGQABk1EMjADhAABAAoACQARArMCCAAwAfgBKQIm AbEAoQBkADZNRDIwA4sAAAAAAAECAQAAAAIAAAAAAfgAAAEpAAAB+AAAAbAAAAIlAAABsAAA AiUAAAEpAAAAoQBkAAZNRDIwA4UAoQBkAAZNRDIwA4QAoACgAKAApQAiAfgB0BIAACMALQAj AAAAI+7TAKAAoQChAGQAME1EMjADmAAAAAAAAQIBAAAAAgAAAAABAAH4AAABz4AAAfgAAAHh gAACJQAAAeGAAAChAGQABk1EMjADhQChAGQAHE1EMjADnQAAAAAB+YAAASqAAAIcgAABaoAA AAAAoQCWAAwCAAAAAgAAAAAAAAAAAQAKAf0BLgIaAWgABAEAACgCCQFGAUcABAAAAA0ACgAp CQENAAAoAhcBMQhIRUFEUkVTVAAAoACXAKEAZAAcTUQyMAOdAAAAAAICgAABbgAAAhWAAAGg AAAAAAChAJYADAEAAAACAAAAAAAAAAABAAoCBgFxAhMBnQAoAhABcgYyIiBNRUQAAKAAlwCh AGQABk1EMjADhAABAAoACQARArMCCAAiAf0BxwAjAHEAHgH4AcQB/QHKAfgBxwH9AcQB/QHH Af0BygH4AccAcAAeAfgBxAH9AcoB+AHHAf0BxAH9AccB/QHKAfgBxwBxAB4CIAHEAiUBygIl AccCIAHEAiABxwIgAcoCJQHHAHAAHgIgAcQCJQHKAiUBxwIgAcQCIAHHAiABygIlAccAoQBk ACRNRDIwA4oAAAAAAAECAQAiAAIAWgH4AAABxoAAAiUAAAHGgAAAoQBkAAZNRDIwA4UAoQC2 AAQAAQD/AKEAlgAMAgD/pgAA/6YAAAAAAKEAmgAI//sAAAAGAAAAkAAEAgMBsgIcAcUCAwGy AhwBxQIDAbICGwHEAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABgAAAAAAAAAGAAAA AAAAAAAAAAAEcAAABIgAAASIAAAEiAAAB5AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAEACgAAAAAAAAAAACtDBAI1IgAAoACXAKEAtgAEAAEAAQChAGQABk1EMjADhAAB AAoACQARArMCCAAwAkUBKQKOAbEAoQBkADZNRDIwA4sAAAAAAAECAQAAAAIAAAAAAkSAAAEp AAACRIAAAbAAAAKMgAABsAAAAoyAAAEpAAAAoQBkAAZNRDIwA4UAoQBkAAZNRDIwA4QAoACg AKAApQAiAkUB4vckACMJJAAjAAAAIwC4AKAAoQChAGQAME1EMjADmAAAAAAAAQIBAAAAAgAA AAABAAJEgAAB4YAAAmiAAAHYgAACjIAAAeGAAAChAGQABk1EMjADhQChAGQAHE1EMjADnQAA AAACRgAAATgAAAJpAAABoAAAAAAAoQCWAAwCAAAAAgAAAAAAAAAAAQAKAkkBOwJmAZ0ABAEA AA0ADAAoAlUBZwFIAAQAAAANAAoAKQkBDQAAKAJjAT4OTFVNQkFSIFNVUFBPUlQAAKAAlwCh AGQAHE1EMjADnQAAAAACZYAAAVMAAAJ4gAABiQAAAAAAoQCWAAwBAAAAAgAAAAAAAAAAAQAK AmkBVgJ2AYYAKxkQBzEiIEZJUk0AoACXAKEAZAAGTUQyMAOEAAEACgAJABECswIIACICSgHH AD4AcQAeAkUBxAJKAcoCRQHHAkoBxAJKAccCSgHKAkUBxwBwAB4CRQHEAkoBygJFAccCSgHE AkoBxwJKAcoCRQHHAHEAHgKIAcQCjQHKAo0BxwKIAcQCiAHHAogBygKNAccAcAAeAogBxAKN AcoCjQHHAogBxAKIAccCiAHKAo0BxwChAGQAJE1EMjADigAAAAAAAQIBACIAAgBaAkSAAAHG gAACjIAAAcaAAAChAGQABk1EMjADhQChALYABAABAP8AoQCWAAwCAP+mAAD/pgAAAAAAoQCa AAj/+wAAAAcAAACQAAQCXAGwAncBxwJcAbACdwHHAlwBsAJ2AcYAAQAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAwAAAAAAAAADAAAAAAAAAAAAAAABvAAAAkIAAAJCAAACQgAA AkIAAAG8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAoAAAAAAAAAAAAN AAwAKAJuAbQCOCIAAKAAlwChALYABAABAAEAoQBkABxNRDIwA50AAAAAAA8AAADDAAAAKAAA AXsAAAAAAKEAlgAMAQAAAAIAAAAAAAAAAAEACgASAMYAJQF4AAQBAAANAA4AKAAgAMcSUlY2 LUEgU0VBVCBERVRBSUxTAACgAJcAoACDAP8= -------------------------------------------------_=_MIME-Boundary_=_ UElDVDIwAAQAAwAAAEgASAAAAAAC2gIo/+H/4gL5AkYDRwUoA/wAAgAAAEgASAAAAAAC2gIo AAEAAABkAAAAAQABAQEAAAABJw8AAQABAHVwEgAAAAAAAAAAAAIAGQGQAAAAAABAAAAAAAAA AAAAAQAAAAAAAAAAAAAAAAAAAAAAmgBBAl0CyAAAAAAAAAABAAEEAwACAAEAAQBIAEgABgAC AAAAACAAAAAQAAAAEAAAACAAAABAAAAAAGQAAABkAABAAAAAEAAAACAAAAEAAwAAAAIAAAAB AAAAAwAAAAYAAAAAAGQAAABkAAYAAAACAAAAAwAAAAAAAAEAAAAAAAAAAAAAAIAAAACAAAAA AAAAAQAAAQAAAAABAAEAAAAAgAAAAIAAAAAAAAACAAABAAAAAAAAAAAAAACAAAAAgAAAAAAA AAAAAAEAAAIAAAAAAAAAAIAAAACAAAAAAAAAAQAAAQAAAgAAAAEAAAAAgAAAAIAAAAAAAAAC AAABAAAAAAAAAAAAAACAAAAAgAAAAAAAAMPAAAAAAAAAHgAAAAAAAQIBAAAAAgABAAwAAAAA /QEAAAAAAAAAAQABAAkAAAAOAAEAAQAAAAAAAAAAAAAAAAEAAAAAAAAAAAAAAAASAAACAQAS AAAAEgAAAszibelub+9yueMA4OQA4eFv6m4gfAACAAUCnQIRABEC/wwA/////wAFAAAAAgAA AhEAAAKdAAAAAAAAAKAAggChAGQAHk1EMjADhkxheWVyLTEAAAAAAAAAAAAAAAA/AAYAAgCh AGQABk1EMjADhAAa////////AAEACgACAAUCnQIRAAkAAAAAAAAAAABxACIAhgFWAi4B/QCG AeAAkAH9Ai4BZgIIAVYCCAFWAIYB4AAaAAAAAAAAAAn//////////wBwACIAhgFWAi4B/QCG AeAAkAH9Ai4BZgIIAVYCCAFWAIYB4AChAGQAOE1EMjADmAFUAAAAAQIBAAAAAgABAAEBAACF 66oB35RYAI/7uQH86I0CLlsxAWWvBAIHwAABVgAAAKEAZAAGTUQyMAOFAKEAZAAGTUQyMAOE ABr///////8ACQAAAAAAAAAAAHEAIgI3AHcCbQFhAjcAdwI3AWECbQFOAm0AxgJtAMYCNwB3 ABoAAAAAAAAACf//////////AHAAIgI3AHcCbQFhAjcAdwI3AWECbQFOAm0AxgJtAMYCNwB3 AKEAZAA4TUQyMAOYAAAAAAABAgEAAAACAAEAAQEAAjcAAAB3cjgCNwAAAWEvEgJtAAABTgai Am0AAADGAAAAoQBkAAZNRDIwA4UAoQBkAAZNRDIwA4QAIgKBAUiDAABxAB4CfgFIAoQBTQKB AU0CfgFIAoEBSAKEAUgCgQFNAHAAHgJ+AUgChAFNAoEBTQJ+AUgCgQFIAoQBSAKBAU0AcQAe An4AxgKEAMsCgQDGAn4AywKBAMsChADLAoEAxgBwAB4CfgDGAoQAywKBAMYCfgDLAoEAywKE AMsCgQDGAKEAZAAkTUQyMAOKAAAAAAABAgEAIgACAFoCgUAAAU0AAAKBQAAAxgAAAKEAZAAG TUQyMAOFAKEAtgAEAAEA/wAa////////AAkAAAAAAAAAAAAxAnAA9AKAASAAGgAAAAAAAAAs AAkAAQZHZW5ldmEAAAMAAQANAAkALgAEAAAAAAAoAn0A+QY3LTEvMiIAAKEAtgAEAAEAAQCh AGQABk1EMjADhAAJ//////////8AIAKWAWMClgAXAHEAHgKTAWMCmQFoApYBaAKTAWMClgFj ApkBYwKWAWgAcAAeApMBYwKZAWgClgFoApMBYwKWAWMCmQFjApYBaABxAB4CkwASApkAFwKW ABICkwAXApYAFwKZABcClgASAHAAHgKTABICmQAXApYAEgKTABcClgAXApkAFwKWABIAoQBk ACRNRDIwA4oAAAAAAAECAQAiAAIAWgKVgAABaAAAApWAAAASAAAAoQBkAAZNRDIwA4UAoQC2 AAQAAQD/ABr///////8ACQAAAAAAAAAAADEChQCwApUAygAaAAAAAAAAACgCkgC0AzE5IgCh ALYABAABAAEAoQBkAAZNRDIwA4QAGv///////wBxACICAwArAjcBYQI3AHcCAwArAi4BYQI3 AWECNwFhAjcAdwAaAAAAAAAAAAn//////////wBwACICAwArAjcBYQI3AHcCAwArAi4BYQI3 AWECNwFhAjcAdwChAGQAOE1EMjADmAAAAAAAAQIBAAAAAgABAAEBAAI3AAAAd3I4AgNAAAAq 0HgCLgAAAWEvEgI3AAABYS8SAKEAZAAGTUQyMAOFAKEAZAAGTUQyMAOEABr///////8ACQAA AAAAAAAAAHEAIgHfABQCLgFhAgMAFAHfABQCDAFTAi4BYQIuAWECAwAUABoAAAAAAAAACf// ////////AHAAIgHfABQCLgFhAgMAFAHfABQCDAFTAi4BYQIuAWECAwAUAKEAZAA4TUQyMAOY AAAAAAABAgEAAAACAAEAAQEAAgNAAAAUUHgB30AAABRQeAIMQAABUtC+Ai4AAAFhLxIAoQBk AAZNRDIwA4UAoQBkAAZNRDIwA4QAGv///////wAJAAAAAAAAAAAAcQAeAbsAFAH0AKYB3wAU AbsAFAH0AKYB9ACmAd8AFAAaAAAAAAAAAAn//////////wBwAB4BuwAUAfQApgHfABQBuwAU AfQApgH0AKYB3wAUAKEAZAAwTUQyMAOYAAAAAAABAgEAAAACAAEAAQEAAd9AAAAUUHgBu0AA ABRQeAHzgAAApmTOAKEAZAAGTUQyMAOFAKEAZAAGTUQyMAOEABr///////8ACQAAAAAAAAAA AHEAHgB+AccAywHgAIYB4AB+AccAywHHAMsBxwCGAeAAGgAAAAAAAAAJ//////////8AcAAe AH4BxwDLAeAAhgHgAH4BxwDLAccAywHHAIYB4AChAGQAME1EMjADmAAAAAAAAQIBAAAAAgAB AAEBAACF66oB35RYAH4AAAHGgAAAyoAAAcaAAAChAGQABk1EMjADhQChAGQABk1EMjADhAAa ////////AAkAAAAAAAAAAABxAB4BgwFWAggBhQIIAVYBwAFkAYMBhQGDAYUCCAFWABoAAAAA AAAACf//////////AHAAHgGDAVYCCAGFAggBVgHAAWQBgwGFAYMBhQIIAVYAoQBkADBNRDIw A5gAAAAAAAECAQAAAAIAAQABAQACB8AAAVYAAAG/wAABY4AAAYMAAAGFQAAAoQBkAAZNRDIw A4UAoQBkAAZNRDIwA4QAGv///////wAJAAAAAAAAAAAAcQBeAHoBVAIIAccCCAFWAd0BVAGu AVgBigFhAW8BcQFWAYMBMAGRAQcBnADzAZ4A1gGjALYBowCZAaAAiQGjAHwBrAB6AbcAfgHH AMgBxwGDAYUBwAFkAcABZAIIAVYAGgAAAAAAAAAJ//////////8AcABeAHoBVAIIAccCCAFW Ad0BVAGuAVgBigFhAW8BcQFWAYMBMAGRAQcBnADzAZ4A1gGjALYBowCZAaAAiQGjAHwBrAB6 AbcAfgHHAMgBxwGDAYUBwAFkAcABZAIIAVYAoQBkALBNRDIwA5gAAAAAAAECAQAAAAIAAQAB AQACB8AAAVYAAAHdAAABU8AAAa3AAAFYQAABicAAAWFAAAFuwAABcQAAAVYAAAGDAAABL8AA AZCAAAEHQAABm8AAAPMAAAGeAAAA1cAAAaKAAAC2QAABooAAAJkAAAGgQAAAiUAAAaKAAAB7 wAABq4AAAHmAAAG2wAAAfgAAAcaAAADIQAABxoAAAYMAAAGFQAABv8AAAWOAAAChAGQABk1E MjADhQChAGQABk1EMjADhAAa////////AAkAAAAAAAAAAABxAGYBrAAUAhEBUwG7ABQBtwAU AbAAHgGsACwBrAA/AbIAWgHCAIAB0ACdAdsAugHoAOAB8QEJAfYBKgH9AT0CBgFOAgwBUwIR ATECDwELAgoA7gIDANEB/QC6AfQApgH0AKYBuwAUABoAAAAAAAAACf//////////AHAAZgGs ABQCEQFTAbsAFAG3ABQBsAAeAawALAGsAD8BsgBaAcIAgAHQAJ0B2wC6AegA4AHxAQkB9gEq Af0BPQIGAU4CDAFTAhEBMQIPAQsCCgDuAgMA0QH9ALoB9ACmAfQApgG7ABQAoQBkAMBNRDIw A5gAAAAAAAECAQAAAAIAAQABAQABu0AAABRQeAG2wAAAFFB4AbAAAAAd5LABq4AAACxDBAGr gAAAP2t0AbJAAABZww4BwgAAAIAT7gHPgAAAnNCWAdrAAAC5jT4B6EAAAN/eHgHxQAABCJQM AfXAAAEqGtAB/IAAAT1DQAIFgAABTgaiAgxAAAFS0L4CEMAAATFJ+gIOgAABCvkaAgoAAADu PHICA0AAANF/ygH8gAAAuY0+AfOAAACmZM4AoQBkAAZNRDIwA4UAoACMAKEAZAAGTUQyMAOE ABr///////8ACQAAAAAAAAAAADEANAAkAUMBVQAaAAAAAAAAAAn//////////wA4AKEAZAA2 TUQyMAOLAAAAAAABAgEAAAACAAEAAQAzwAAAJAAAADPAAAFTv5ABQcBEAVO/kAFBwEQAJAAA AKEAZAAGTUQyMAOFAKEAZAAGTUQyMAOEABr///////8ACQAAAAAAAAAAADEANAAkAHkBVQAa AAAAAAAAAAn//////////wA4AKEAZAA2TUQyMAOLAAAAAAABAgEAAAACAAEAAQAzwAAAJAAA ADPAAAFTv5AAd9u+AVO/kAB3274AJAAAAKEAZAAGTUQyMAOFAKEAZAAGTUQyMAOEABr///// //8ACQAAAAAAAAAAADEA/gAkAUMBVQAaAAAAAAAAAAn//////////wA4AKEAZAA2TUQyMAOL AAAAAAABAgEAAAACAAEAAQD9pIYAJAAAAP2khgFTv5ABQcBEAVO/kAFBwEQAJAAAAKEAZAAG TUQyMAOFAKAAjQChAGQABk1EMjADhAAa////////AAkAAAAAAAAAAAAxADQBVAFDAWsAGgAA AAAAAAAJ//////////8AOAChAGQANk1EMjADiwAAAAAAAQIBAAAAAgABAAEAM8AAAVO/kAAz wAABakAAAUHARAFqQAABQcBEAVO/kAChAGQABk1EMjADhQChAGQABk1EMjADhAAa//////// AAkAAAAAAAAAAAAxABIA8wAVAPQAGgAAAAAAAAAJ//////////8AOAChAGQANk1EMjADiwAA AAAAAQIBAAAAAgABAAEAEgAAAPMAAAASAAAA8wAAABRAAADzAAAAFEAAAPMAAAChAGQABk1E MjADhQChAGQABk1EMjADhAAa////////AAkAAAAAAAAAAABhAJP/8wDhAGQAu/9BABoAAAAA AAAACf//////////AGgAu/9BAKEAZABGTUQyMAOUAAAAAAABAgEAAAACAAEAAQDgJwQAJHi6 AJK2zgAnbgYAupDzAGNxJAC5iLgAK2wjADgKDQAm6zwAuyABAWPqFQChAGQABk1EMjADhQCh AGQABk1EMjADhABgAIT/4QDxAHcAtP9JAKEAZABGTUQyMAOUAAAAAAABAgEAAAACAAAAAADv iLgAK2wjAIOdqwAnVhUAuAwyAHWk7wC5iLgAK2wjAEpAAAA2AAAAtAAAAWTYZQChAGQABk1E MjADhQChAGQABk1EMjADhAAiAIQALfcAAKEAZAAkTUQyMAOKAAAAAAABAgEAAAACAFoAhBg0 ACyl+QCEGDQAJAAAAKEAZAAGTUQyMAOFAKEAZAAGTUQyMAOEACIAkwAt9wAAoQBkACRNRDIw A4oAAAAAAAECAQAAAAIAWgCSttIALK9jAJK20gAkAAAAoQBkAAZNRDIwA4UAoQBkAAZNRDIw A4QAIgDgACv5AAChAGQAJE1EMjADigAAAAAAAQIBAAAAAgBaAOAnHwAqyOUA4CcfACQAAACh AGQABk1EMjADhQChAGQABk1EMjADhAAiAO8AL/UAAKEAZAAkTUQyMAOKAAAAAAABAgEAAAAC AFoA7wxLAC9AAADvDEsAJAAAAKEAZAAGTUQyMAOFAKEAZAAGTUQyMAOEABr///////8ACgAA AAAAAAAAADQAlAAiAN8AKgAaAAAAAAAAAJAABAAAAAAACwAYAAAAAAALABIAjwAdAJoALwAB AAAAAAAAAAAAAAAAAAAAAAAAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkAACAAAAAAAg ABAAAAAAACAACwCPACQArwAvAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJAAAgAAAAAAIAAQAAAAAAAgAAsApAAk AMQALwABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAACQAAIAAAAAACAAEAAAAAAAIAALALkAJADZAC8AAQAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAkAACAAAAAAAWABAAAAAAABYACwDOACQA5AAvAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAACQAAQAAAAIAAsAIAAAAA4ACwAgANkAHQDkAC8AAQAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJAAAgAAAAAAIAAQ AAAAAAAgAAsAxAAdAOQAKAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACQAAIAAAAAACAAEAAAAAAAIAALAK8AHQDP ACgAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAkAACAAAAAAAgABAAAAAAACAACwCaAB0AugAoAAEAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AJAAAgAKAAAAIAAQAAoAAAAgAAsAjwAdAKUAKAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAoQBkADZNRDIwA4sAAAAAAAECAQEAAAIAAgABAJRNXAAh wAAAlE1cACiAAADeBVsAKIAAAN4FWwAhwAAAoQBkAAZNRDIwA4UAoQBkAAZNRDIwA4QAIgIq ABkRAABxAB4CJwAUAi0AGQIqABQCLQAZAioAGQInABkCKgAUAHAAHgInABQCLQAZAioAFAIt ABkCKgAZAicAGQIqABQAcQAeAicAKgItAC8CKgAvAi0AKgIqACoCJwAqAioALwBwAB4CJwAq Ai0ALwIqAC8CLQAqAioAKgInACoCKgAvAKEAZAAkTUQyMAOKAAAAAAABAgEAIgACAFoCKYAA ABRAAAIpgAAAL0AAAKEAZAAGTUQyMAOFAKEAtgAEAAEA/wAoAiYAEQYxLTEvMiIAAKEAtgAE AAEAAQChAGQABk1EMjADhAAgAT0BgwA5AYMAcQAeAT0BgAFCAYYBQgGDAT0BhgE9AYMBPQGA AUIBgwBwAB4BPQGAAUIBhgFCAYMBPQGGAT0BgwE9AYABQgGDAHEAHgA0AYAAOQGGADQBgwA5 AYYAOQGDADkBgAA0AYMAcAAeADQBgAA5AYYANAGDADkBhgA5AYMAOQGAADQBgwChAGQAJE1E MjADigAAAAAAAQIBACIAAgBaAUHAAAGDAAAAM8AAAYMAAAChAGQABk1EMjADhQChALYABAAB AP8AGv///////wAJAAAAAAAAAAAAcQAeAKsBbgDLAYIAywFuAKsBbgCrAYIAywGCAMsBbgCh AJYADAIA/6YAAP+mAAAAAAChAJoACP/7AAAACwAAABoAAAAAAAAAkAAEAKoBbQDNAYQAqgFt AM0BhACqAW0AzAGDAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMAAAAAAAAA AwAAAAAAAAAAAAAAAjwAAAJCAAACQgAAAkIAAAJCAAADxAAAAAAAAAAAAAAAAAAAAAAAAAP+ AAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAoAAAAA AAAAAAANAAwAKADAAW0DMTUiAKAAlwChALYABAABAAEAoQBkABxNRDIwA50AAAAAAcFAAABX AAAB10AAAG0AAAAAAKEAlgAMAQAAAAIAAAAAAAAAAAEACgHEAFoB1ABqACgB0ABbAUEAoACX AKEAZAAcTUQyMAOdAAAAAAHHQAAAG8AAAd1AAAAwwAAAAAChAJYADAEAAAACAAAAAAAAAAAB AAoBygAfAdoALgAoAdYAIAFCAKAAlwChAGQAHE1EMjADnQAAAAAB7kAAADDAAAIEQAAARcAA AAAAoQCWAAwBAAAAAgAAAAAAAAAAAQAKAfEANAIBAEMAKxUnAUMAoACXAKEAZAAcTUQyMAOd AAAAAAIdgAAAcgAAAjOAAACHAAAAAAChAJYADAEAAAACAAAAAAAAAAABAAoCIQB1AjEAhAAr QTABRACgAJcAoQBkABxNRDIwA50AAAAAAk8AAADFQAACZQAAANlAAAAAAKEAlgAMAQAAAAIA AAAAAAAAAAEACgJSAMgCYgDWACtTMQFFAKAAlwChAGQAHE1EMjADnQAAAAAB6cAAAWLAAAH/ wAABdsAAAAAAoQCWAAwBAAAAAgAAAAAAAAAAAQAKAe0BZgH9AXQAKAH5AWcBRgCgAJcAoQBk ABxNRDIwA50AAAAAARiAAAB/gAABLoAAAJWAAAAAAKEAlgAMAQAAAAIAAAAAAAAAAAEACgEc AIMBLACTACgBKACEAUEAoACXAKEAZAAcTUQyMAOdAAAAAACjgAABpkAAALmAAAG8QAAAAACh AJYADAEAAAACAAAAAAAAAAABAAoApwGpALcBuQAoALMBqgFBAKAAlwChAGQAHE1EMjADnQAA AAAAUoAAAL6AAABogAAA1IAAAAAAoQCWAAwBAAAAAgAAAAAAAAAAAQAKAFYAwgBmANIAKABi AMMBQQCgAJcAoQBkAAZNRDIwA4QAAQAKAAIABQKdAhEACf//////////ACAA/gCkAHcApACh AGQAJE1EMjADigAAAAAAAQIBAAAAAgBaAP5AAACkQAAAd0AAAKRAAAChAGQABk1EMjADhQCh AGQABk1EMjADhAAiAAkAogACAKEAZAAkTUQyMAOKAAAAAAABAgEAAAACAFoACQAAAKIAAAAL QAAAogAAAKEAZAAGTUQyMAOFAKEAZAAcTUQyMAOdAAAAAADOQAAAcgAAAORAAACHAAAAAACh AJYADAEAAAACAAAAAAAAAAAa////////AAkAAAAAAAAAAABxAB4AzgByAOQAhwDOAHIAzgCH AOQAhwDkAHIAzgByABoAAAAAAAAAAQAKANEAdQDhAIQAKADdAHYBQgCgAJcAoQBkABxNRDIw A50AAAAAAMnAAAEPgAAA38AAASSAAAAAAKEAlgAMAQAAAAIAAAAAAAAAABr///////8AAQAK AAIABQKdAhEAcQAeAMoBEADgASUAygEQAMoBJQDgASUA4AEQAMoBEAAaAAAAAAAAAAEACgDN ARMA3QEiACgA2QEUAUMAoACXAKEAZAAcTUQyMAOdAAAAAAGCQAAAeMAAAZtAAADtwAAAAACh AJYADAEAAAACAAAAAAAAAAAa////////AAEACgACAAUCnQIRAHEAHgGCAHkBmwDuAYIAeQGC AO4BmwDuAZsAeQGCAHkAGgAAAAAAAAABAAoBhQB8AZgA6wAEAQAADQAOACgBkwB9ClJWNi1B IFNFQVQAAAQAAAANAAwAKWQBIAAAoACXAKEAZAAcTUQyMAOdAAAAAAJGAAAA7cAAAlwAAAEH wAAAAAChAJYADAEAAAACAAAAAAAAAAABAAoCSQDxAlkBBQArEcICMyIAAKAAlwChAGQAHE1E MjADnQAAAAACHYAAAKpAAAIzgAAAxEAAAAAAoQCWAAwBAAAAAgAAAAAAAAAAAQAKAiEArQIx AMEAKAItAK4CMiIAAKAAlwChAGQAHE1EMjADnQAAAAAB8sAAAHjAAAIIwAAAksAAAAAAoQCW AAwBAAAAAgAAAAAAAAAAAQAKAfYAfAIGAJAAKAICAH0CMiIAAKAAlwChAGQAHE1EMjADnQAA AAAB0UAAAC3AAAHnQAAAR8AAAAAAoQCWAAwBAAAAAgAAAAAAAAAAAQAKAdQAMQHkAEUAKAHg ADICMiIAAKAAlwChAGQAHE1EMjADnQAAAAABxcAAAXKAAAHbwAABjIAAAAAAoQCWAAwBAAAA AgAAAAAAAAAAAQAKAckBdgHZAYoAKAHVAXcCMiIAAKAAlwChAGQABk1EMjADhAABAAoAAgAF Ap0CEQAJ//////////8AIAIsAXwBgQG4ACABPgHOAJsCCABxAB4CKgF5AjABfwIwAXoCLAF/ AisBfAIqAXkCMAF6AHAAHgIqAXkCMAF/AjABegIsAX8CKwF8AioBeQIwAXoAcQAeAJcCBQCd AgsAlwIKAJ0CCwCcAggAmwIFAJcCCgBwAB4AlwIFAJ0CCwCXAgoAnQILAJwCCACbAgUAlwIK AKEAZAAkTUQyMAOKAAAAAAABAgEAIgACAAACMEAAAXoAAACWwAACCgAAAKEAZAAGTUQyMAOF AKEAtgAEAAEA/wChAJYADAIA/7kAAP+5X8gAAAChAJoACP/7AAAAHgAAAJAABgE+AbcBigHl AT4BtwGKAeUBPgG3AYkB5AABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAMAAAAAAAAAAAAAAAYAAAAAAAAAAAAAAAAAAAAAAA4AAA AAAAXgAAAAAAQ4AAAAAABAAAAAAAJAAAAAAAFAAAAAAAGAAAAAAAAAAAAAAEAAAAAAAE8AAA AAAIiAAAAAAFBAAAAAABCAAAAAADiAAAAAAA6AAAAAAwAAAAAAAYAAAAAAAAAAAAAAAGAAAA AAACAAAAAAABAAAAAACAwAAAAADAAAAAAACwAAAAAAEAAAAAAAEIAAAAAAEEAAAAAAADAAAA AAAAAAAAAAAAAAAAAAAgAAAAAABAAAAAAABAAAAAAABAAAAAAACAAAAAAAAAAAAAABwAAAAA AAvAAAAAAARwAAAAAATAAAAAAACAAAAAAAKAAAAAAAEAAAAAACAAAAAAAJgAAAAAAIgAAAAA AICAAAAAAISAAAAAAASAAAAAAEMAAAAAAAEAAAAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEACgAAAAAAAAAA ACgBaAGvCDI0LTcvNjQiAACgAJcAoACDAP8= -------------------------------------------------_=_MIME-Boundary_=_-- ________________________________________________________________________________
Date: Nov 14, 1996
At 9:38 AM 11/11/1996, Michael A. Pilla wrote: > >What I have is a a small crack, about 1 1/4 inches starting from the edge. >I drilled a 1/8 inch hole at the end to stop the crack from spreading any >farther. > >Now, do any of the group experts have a suggestion on how to "invisibly >repair" this mess? I know that there are some great epoxy glues that the >auto windshield (glass) chaps use, but would they work for plexiglass? > >Thanks, in advance. > >Mike Pilla >From looking at the RV's in this area, the accepted method is to apply a EAA Sticker of suitable size (small to large) over the crack. I suppose some of the liquid glue from a plastic shop, I also found some at the local wood/hardware store in the plexiglas section squirted in using a hypodermic. Doug Doug Bloomberg RV-6A (in the womb) Denver, CO dougb(at)mail.diac.com (home) doug(at)boulder.vni.com (work) ________________________________________________________________________________
Date: Nov 14, 1996
Subject: Re: RV-List Re: Lower Flap Push Rod End
On Thu, 14 Nov 1996, J.Ken Hitchmough wrote: * snip * > recently by > my EAA Chapter Tech Counselor. He recently inspected a new RV-4 and > expressed to me his surprise at Van's use of studded 1/4" male rod end > bearings (Aurora P/N CM-4MS) in the lower positions of the flap push > tubes. * snip * I'm curious. What does 'studded' mean. Mine are male rod ends threaded into an AL tube. I followed Van's directions on both RV-4's I've built and have personally put 300 hrs between the two without a hint of a problem. Does anyone know if you can "overcome" the effect of a fully deployed flap with ailerons? Dan dboudro(at)nmia.com ________________________________________________________________________________
Date: Nov 14, 1996
RV>I have to admit I did the same thing on my 8. RV>On the tip rib near the leading edge RV>the flanges are cut relieved. I drilled out the rivets forward of these cut RV>outs. Probably only four to six rivets. I then carefully bent the tip of RV>the rib out. This allowed enough room to feed the bolt out from inside of RV>the stab. Then simply bent the rib back in place and riveted. This sounds like a good idea. The only thing I'd worry about is weakening the tip of the rib where you bent it out and then back. Do you feel like you caused any problems in this respect? RV>Now let me tell you about leaving the bucking bar in the root end of the RV>stab. Bad night. Let me guess, you too are now an expert at drilling out rivets! :-) (If not, give me a call, it's a talent I feel I've really developed lately.) RV>Rick McBride Rod Woodard RWoodard(at)lawyernet.com ***LISTERS: Please include your e-mail address in posts to the list*** ________________________________________________________________________________
Date: Nov 14, 1996
Subject: hvlp,squeezer
RV>2) rivet squeezer vs. pneumatic, advantages disadvantages? Pnuematic is heavier and more expensive. (-) Pneumatic has less parts moving around (no big handles) and might be a little easier to operate than a hand squeezer depending on your technique. (+) Pneumatic is very fast when you have to do a large number of essentially the same dimples or the same rivets (+). Pneumatic probably takes a little longer to set up because there isn't an adjustable feature in the yoke/rivet holder. I just use washers and different heights of rivet sets. (-) The bottom line, IMHO: You can buy a used Chicago Pneumatic squeezer for about $250. At the end of your project you can probably sell it to another user for about what you paid for it. If you can afford to be without your $250 for the time you're building, I think it's a worthwhile tool. I have both the pneumatic and the hand squeezer and have _rarely_ used the hand squeezer... but I'm only on the HS. Please understand that this is only my opinion. This question has been booted around the list before (like when I asked the question 8 months ago! :-)) It's kind of like the -6 vs. 6A argument... it all depends on your perspective. Best regards, Rod Woodard RWoodard(at)lawyernet.com RV-8, HS riveted, moving on to VS soon. *** Please include your e-mail address in posts to the rv-list*** ________________________________________________________________________________
Date: Nov 15, 1996
Thanks for the info, Rick. For those who haven't been following this. There has been some discussion about using this adhesive material to attach the control surface skin stiffeners. The possible advantages would be 1) a reduction in oil canning potential because of stretching of skins during dimpling and riveting 2) elimination of skin cracking around the trailing edge rivet 3) perfectly smooth skins. This stuff would be used for the stiffeners ONLY everything else would still be riveted. There are obvious concerns about longevity and I would like to do some environmental testing (albeit unscientific) and it might be a tad heavier. There are not a lot of stress forces on the stiffeners and you could check their adhesion by squeezing the surface. It sounds like this stuff sticks pretty well -- high temperatures would be my concern. Worse case, you could rebuild them. There are a few of us seriously thinking about doing this and would like some advice from the wise men of the list. (someone mentioned that this had been discussed a year ago. I checked the archives and found only the conversation of a month ago which was mostly jokes about taping on the wings... ;^) Thanks all, Dann Parks Sunnyvale, CA dann_parks(at)kteh.pbs.org starting RV6A ________________________________________________________________________________
Date: Nov 14, 1996
Frank van der Hulst wrote: > > >Here is the info that I have so far.... > >The product is labeled as follows: > > > >Scotch VHB > >4941F > >Conformable Acrylic Foam Tape > > > >The sample I have is a little thick (45 mils) > > > >I am still waitning on tech sheets and will post info when received. > > > >Final note.... I spoke with the 3m rep, slos a pilot who commented that > >it is very good at reducing oil canning. Also, after a cure time of 72 > >hours the tape is stronger than rivits due to the total are it covers > >vs. rivits. Just info......... > > Out of curiosity: > > 1. Will the tape stick to fibreglass? Perhaps this is a way to attach tips > etc without pop rivets? > > 2. Once it's stuck down, can you undo it? I mean, with rivets you can drill > them out. With this stuff stuck down, would your HS or VS or wing become an > unrepairable unit? > > Frank. > -- > -------------------------------------------------------------------- > frankv(at)pec.co.nz | "Knowledge=Power=Energy=Matter=Mass; > Frank van der Hulst | A good bookshop is just a genteel > Software Engineer | Black Hole that knows how to read". > PEC(NZ) Ltd (Cardax), Marton | Terry Pratchett, "Guards! Guards!" > http://www.pec.co.nz/~frankv/ | > -------------------------------------------------------------------- According to the small insert in the box of tape QUOTE: Tape will adhere to most clean, dry and well-unified surfaces. Most porous or fibered materials, i.e., cement, wood, will require sealing to provide a unified surface. UNQUOTE According to the rep from 3M, this stuff will not come off easily after the "Dwell time". This is approx 72 hours depending on temperature. More to follow when I get the data sheets.... Rick -- Rick(at)ccc.henn.tec.mn.us Rick Osgood 9200 Flying Cloud Dr. Eden Prairie, MN 55347 ________________________________________________________________________________
Date: Nov 14, 1996
> Tyvek is a synthetic, water-proof, tear-proof paper substitute used > by printers. Probably its most familiar application is the large > Fed-X envelope. The least expensive way to get ahold of it is through > a paper distributor. The material that was spoken of for fiberglassing is simply referred to as Mat, I believe. It's a non-woven bat of fiberglass in no particular arrangement that you work epoxy into and moosh into shape. It's very flexible, and can take odd shapes, but not quite as strong as oriented fibers. Tyvek is also the stuff they wrap around houses now under the siding, so you can get huge rolls of it now if you want. -- (Sorry Randall, no more room for the Yakko Warner quote) Richard Chandler RV-6: Garage bought, saving for tools and tail kit (Christmas?). ________________________________________________________________________________
Date: Nov 14, 1996
uwwvax.uww.edu!fegg2251(at)matronics.com wrote: > > A couple questions. > > 2) rivet squeezer vs. pneumatic, advantages disadvantages? > > > wayne "vulture" f. > rv-6 empenage hi wayne: The first rivet squeezer I purchase was the 1 1/2" U.S. Tool supply and I was pleased with it. I wanted a 3" so I ordered one from U.S. tool, I was not happy with it and sent it back. I then ordered a 3" from Avery tools, I am very pleased with it. If you can only afford one I'd recommend a good quality 3" reach model. As far as a pneumatic sqeezer is concerned if you can afford one, they would be a blessing. My hands ached for 2 weeks after dippling all the wing ribs. Terry RV-6A .....wings done, waiting on the fuselage. ________________________________________________________________________________
Date: Nov 14, 1996
From: Brian McShurley <bmcshurley(at)www.sfgate.com>
Subject: Re: Lower Flap Push Rod End
Herman Dierks wrote: > > I had a local machine shop make my RV4 flap tubes out of stainless > steel. The aluminum ones looked two weak to me. > However, I have never heard of a problem. > I was also told on the RV6 that if you use elect flaps you need to > use the stainless tubes as the motor will strip the aluminum ones > (this is second hand info). > > I don't understand what you are using on the end if you don't use the > Aurora bearing. What is a 'capture washer'???? > Herman > dieks(at)austin.ibm.com > > I will attempt to answer the last first; A capture washer is placed over the bolt with a diameter large enough to prevent the outer frame of the rod end from being passed over the head of the bolt should the rod end's inner race fail. This causes the rod end to be held captive between the attach point and the washer maintaining a mechanical linkup, allbeit a loose one. This is much better than having the tube drop free!!! As for stainless steel; unless you use the proper structural stainless, you are more likely to bend them than a properly formed aluminum one. Stainless is actually a very soft material, and usually requires more material to equal the same strength. I personally would use 4130, properly corrosion protected before using stainless. I would also prefer my rod ends to be in a double shear arrangement rather than relying on the fastener to carry both shear and tension loads. Just my $.01 (the California tax man was here...) Brian McShurley bmcshurley @sfgate.com S-51D / N514BM Still cleaning garage / Awaiting kit ________________________________________________________________________________
Date: Nov 14, 1996
Subject: Re: locked out of my airplane
George advised: << you can make a small lifting handle out of 3/4 x 3/4 x .063 about 2 inch long and tepered in front and put on both sides near the back of the canopy. This will give you something thingto lift with . >> Thanks, George. I was toying with the idea of installing an eye bolt there but your idea seems more streamlined, less expensive and better-looking. Bravo on all 3 counts. I'll drill out a few rivets on the canopy frame sides and back-drill my "lift tabs" tomorrow night! PS: thanks to the others who logged in with the same idea. Bill Boyd ________________________________________________________________________________
Date: Nov 14, 1996
Asymmetric flap deployment can ruin your whole day. > > I wonder about the pushrods themselves. The material is aluminum tube with > threads for the rod end CUT into the material. I thought that we use > aircraft bolts because one of their features was rolled threads. Has anyone > thought of using a heavier wall tube or different material? > > David Fried > I bought some 2024 tube for that reason. Same size but stronger alloy. However 2024 also much more brittle. Aargh! I'm not sure if I'll use it -may go bigger. Interesting these questions made the list -they've been bugging me for some time. Both the rod end and the skinny tube with the cut threads. Scott N4ZW ________________________________________________________________________________
Date: Nov 14, 1996
> Still waiting to hear whether conventional wisdom says it's better to fair > the gear legs on or off the airframe... I would do it with them on the airplane. With the weight off the gear (like it's flying). Misalignment of the gear leg fairings affects the trim of the airplane. Scott N4ZW ________________________________________________________________________________
Date: Nov 14, 1996
Herman Dierks wrote: > I don't understand what you are using on the end if you don't use the > Aurora bearing. What is a 'capture washer'???? I believe they are using the term to describe a large area washer used alongside a rod end bearing to keep the linkage in question attached in the event of a bearing failure. i.e. the 'ball' part leaves the 'housing' due to excessive wear, etc. A VERY good idea, and seen commonly on throttle cable ends, etc. as well as all over the place on helicopters. I always called 'em 'safety washers' -but that's my own term. Scott N4ZW ________________________________________________________________________________
Date: Nov 14, 1996
>Regarding fuel tanks fire hazard reduction: > >> I think this is called 'explo-proof' or some such thing. >> A word of caution. DO NOT use this if you have a flop tube in your >> tank (for aerobatics). > >It's called "Explosafe", if I remember correctly from my motorcycle >road racing days. It works very well in cars and bikes -- always >wondered why you never hear about it in aircraft. Maybe it was >the incompatability with flop tubes! > >Cal There was a problem with the "Explosafe" degrading into tiny little pieces and plugging up filters. There may have been a water retention problem, as well. One article that I read said that it worked but they recommended that the material be replaced on a perodic basis. The original post on the subject may be talking about a new product that accomplishes the same thing as "Explosafe" without the drawbacks. Bob Skinner RV-6 BSkinner(at)krvn.com ________________________________________________________________________________
Date: Nov 14, 1996
He said:" but think that something so easy to solve, should be." 'One who has one problem to solve has a fine day, kiss wife, be happy. One with all problems to solve will make one sorry day, kick dog, drag chin in dirt.' Wai Lee Especially problems which aren't. Risk is the product of probability and consequences. To get anything out of the shop into the market requires decisions as to when better becomes good enough is. There is always a "worst remaining problem." That's what continuous improvement is about. The problem is that it is continuous. Van has my aplause for improving as he goes. Look at detail and value now compared to undrilled kits with untapered or undrilled spar components. Ken Smith RV6 still tail, with an oldie kit for wings... ________________________________________________________________________________
Date: Nov 14, 1996
Subject: Re: Fiberglass tape
http://www.cris.com/~Gougeon/ The above is the home page for Gougeon Brothers, who supply by phone order everything you could ever want in the way of glass, carbon, epoxy, filer, fairing compound, etc. Jan Gougeon should be flying his RV4 by now...btw. Ken Smith rv6 tail, kpsmith(at)cnsnet.com >Would someone send me a phone number for a mail order supplier who >handles the 2" fiberglass tape like George uses to glass the canopy in >his video. Wicks and Aircraft Spruce are out of stock, ________________________________________________________________________________
Date: Nov 14, 1996
> I wonder about the pushrods themselves. The material is aluminum tube >with > threads for the rod end CUT into the material. I thought that we use > aircraft bolts because one of their features was rolled threads. Has >anyone > thought of using a heavier wall tube or different material? Yup. I've thought about it. On one hand, I can have a friend make me a pair of threaded pushrods from some aluminum rod in just a few minutes. On the other hand, there are two or three thousand of these pushrods flying without a problem. Best Regards, Dave Barnhart barnhart(at)a.crl.com rv-6 sn 23744 Trimming the canopy ________________________________________________________________________________
Subject: 3m Tape info
Date: Nov 14, 1996
I wonder why this would be any stronger than just prosealing on your stiffeners. I haven't worked with the stuff much but I understand that it has bond strength which can be considered structural. I asked my IA about this and he said that the biggest problem would be peel and if you riveted the ends of the stiffeners down it would probably be much safer and work but he wouldn't sign off on it. -Mike -----Original Message----- From: KTEH.pbs.org!Dann_Parks(at)matronics.com [SMTP:KTEH.pbs.org!Dann_Parks(at)matronics.com] Sent: Thursday, November 14, 1996 4:33 PM Subject: Re: RV-List: 3m Tape info Thanks for the info, Rick. For those who haven't been following this. There has been some discussion about using this adhesive material to attach the control surface skin stiffeners. The possible advantages would be 1) a reduction in oil canning potential because of stretching of skins during dimpling and riveting 2) elimination of skin cracking around the trailing edge rivet 3) perfectly smooth skins. This stuff would be used for the stiffeners ONLY everything else would still be riveted. There are obvious concerns about longevity and I would like to do some environmental testing (albeit unscientific) and it might be a tad heavier. There are not a lot of stress forces on the stiffeners and you could check their adhesion by squeezing the surface. It sounds like this stuff sticks pretty well -- high temperatures would be my concern. Worse case, you could rebuild them. There are a few of us seriously thinking about doing this and would like some advice from the wise men of the list. (someone mentioned that this had been discussed a year ago. I checked the archives and found only the conversation of a month ago which was mostly jokes about taping on the wings... ;^) Thanks all, Dann Parks Sunnyvale, CA dann_parks(at)kteh.pbs.org starting RV6A ________________________________________________________________________________
Date: Nov 14, 1996
>>From looking at the RV's in this area, the accepted method is to apply a >EAA Sticker of suitable size (small to large) over the crack. Now that's the best advice! I love it. :-) Mike Pilla RV4, #2866, still fiddling with the fit of the skirts on the canopy. Michael Pilla pilla(at)exit109.com v: (908) 566-7604 f: (908) 566-7936 ________________________________________________________________________________
Date: Nov 14, 1996
<< I don't understand what you are using on the end if you don't use the Aurora bearing. What is a 'capture washer'???? Herman >> Herman- Perhaps I didn't get the idea across that the studded lower flap tube rod end bearing (it attaches to the flap root) that Van's specifies does not lend itself to the common practice of boxing in the rod bearing with large pattern washers on both sides so that, if the bearing fails, the joint will not separate completely (and you will hopefully be alive and able to land and fix it). E-mail me direct if still not clear. Regards, Gary VanRemortel ________________________________________________________________________________
Date: Nov 15, 1996
<< I'm curious. What does 'studded' mean. Mine are male rod ends threaded into an AL tube. I followed Van's directions on both RV-4's I've built and have personally put 300 hrs between the two without a hint of a problem. Does anyone know if you can "overcome" the effect of a fully deployed flap with ailerons? Dan dboudro(at)nmia.com >> Jeez, I thought the original post was pretty clear. Apparently the Canadians already are well aware of this issue. Good Job. Dan- By the way, it wasn't Ken's post, it was mine. Look at your plans, people (for the RV-6A it is drawing #42). The lower of the two flap link bearings is Aurora CM-4MS (the trailing S is for studded), in other words, it has a 1/4-28 STUD staked into the rotating portion of the bearing (you do not use a bolt). Then look again at the link upper rod bearing. It is Aurora CM-4M (no S for not studded). The upper bearing is captured on both sides by the geometry of the flap torque tube and doesn't need capture washers. In other applications where, if the bearing races should separate from the rod end (as in a throttle cable attachment), catastrophic results could be expected, capture washers (simply large OD washers on both sides of the rod end) are traditionally installed as a backup against complete separation of a critical linkage. Gary VanRemortel vanremog(at)aol.com ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Horz Stab jig question
On page 6-5, RV-6 manual is states that you should locate and mark the positions for the brackets that will support the HS-603PP (rear spar). It refers to figure 6-5 for distances. I have been unable to find a figure or diagram, with the exception of the original drawing on 3PP that is useful, and no figure 6-5. Does it matter as long as the spar is stable and supported?? The book also says use 3/16" bolts. Where do you get these? Home depot doesn't have them. Once I can find 3/16" bolts, should the bolts be tightened down, ie I don't want to bend the hinges, I think the idea is support and stability. If you use the AN3-7A or 14A bolts that came with the HS, would you be afraid of damaging the threads? Can you use the stop nuts? Can these stop nuts be used over and over without damaging? Last question. The 1/4" bolts that help stabilize the HS in the jig and attached to the tip ribs ...... looks like oerndorf (sp?) drilled his straight out of the 4x4, ie didn't use either method the manual suggests?? Thanks for your help. Not stupid, just ignorant. Steve Smith, Austin, TX Rv-6 prepunched ________________________________________________________________________________
Date: Nov 15, 1996
In the unlikely event that a flap rod end bearing fails or the push tube buckles, a split flap condition may occur. However, those with manual flaps will get an immediate feed back that something is wrong and put the flaps back up without even letting go of the handle. The electric flaps operate very quickly, about five seconds from up to down. This too will give an immediate feedback and allow time to retract them, especially since normal proceedure is to put down only about 20 degrees of flaps on base leg and then full flaps on final approach. I think that the ailerons could overcome a full split flap condition and that the plane would be controlable. Half flaps are limited to 110 MPH and full flaps, 100 MPH. At traffic pattern altitude there would be plenty of altitude and airspeed to effect a recovery. The rule we had when I was a test pilot in the Air Force was if something goes wrong when you activate a control, immediately return it to the position that it was in before the problem occurred. When you fly, pay attention to what is happening and you will stay out of trouble. I have my Nomex fireproof flying suit on in preparation for the flames about to come my way. Jim Cone jamescone(at)aol.com ________________________________________________________________________________
Date: Nov 15, 1996
Wayne and Terry, I am in the market for a squeezer. Do you think even with a prepunched kit it is still worth getting?? I heard Action Air has good prices, but was never able to get them on the phone. I know Avery's will be good. Does anyone have a number for Action Air or comments about them?? They would return calls, but we never got hooked up, and finally they quit returning calls. Steve Smith, RV-6, HS, prepunched ________________________________________________________________________________
Date: Nov 15, 1996
>George advised: > ><< you can make a small lifting handle out of 3/4 x 3/4 x .063 about 2 inch > long and tepered in front and put on both sides near the back of the canopy. > This will give you something thingto lift with . >> > >Thanks, George. I was toying with the idea of installing an eye bolt there >but your idea seems more streamlined, less expensive and better-looking. > Bravo on all 3 counts. I'll drill out a few rivets on the canopy frame >sides and back-drill my "lift tabs" tomorrow night! > >PS: thanks to the others who logged in with the same idea. > >Bill Boyd > >Hey Bill, In the interim, how about using one of those suction-cup dent pullers the auto body guys use. ________________________________________________________________________________
Date: Nov 15, 1996
On Thu, 14 Nov 1996, Dave Barnhart wrote: > > I wonder about the pushrods themselves. The material is aluminum tube > >with > > threads for the rod end CUT into the material. I thought that we use > > aircraft bolts because one of their features was rolled threads. Has > >anyone > > thought of using a heavier wall tube or different material? ************************* Does anyone know if they did something different on these push rods for the Air Beatle military use project? It seems they looked at a number of differnt areas and modified because of their anticipated hard use. Rich Olaon Saratoga Springs, NY rolson(at)capital.net ________________________________________________________________________________
<328BC27D.6584(at)www.sfgate.com>
Date: Nov 15, 1996
What about just doing a good pre-flight? Rod ends don't just fail instantaneously...... Remember the KISS principle? Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com writes: >Herman Dierks wrote: >> >> I had a local machine shop make my RV4 flap tubes out of stainless >> steel. The aluminum ones looked two weak to me. >> However, I have never heard of a problem. >> I was also told on the RV6 that if you use elect flaps you need to >> use the stainless tubes as the motor will strip the aluminum ones >> (this is second hand info). >> >> I don't understand what you are using on the end if you don't use the >> Aurora bearing. What is a 'capture washer'???? >> Herman >> dieks(at)austin.ibm.com >> > > > >I will attempt to answer the last first; A capture washer is placed >over the bolt with a diameter large enough to prevent the outer frame >of >the rod end from being passed over the head of the bolt should the rod >end's inner race fail. This causes the rod end to be held captive >between the attach point and the washer maintaining a mechanical >linkup, >allbeit a loose one. This is much better than having the tube drop >free!!! > >As for stainless steel; unless you use the proper structural >stainless, >you are more likely to bend them than a properly formed aluminum one. >Stainless is actually a very soft material, and usually requires more >material to equal the same strength. > >I personally would use 4130, properly corrosion protected before using >stainless. I would also prefer my rod ends to be in a double shear >arrangement rather than relying on the fastener to carry both shear >and >tension loads. > >Just my $.01 (the California tax man was here...) > >Brian McShurley >bmcshurley @sfgate.com >S-51D / N514BM >Still cleaning garage / Awaiting kit > ________________________________________________________________________________
Date: Nov 15, 1996
Chet, try Alexander Aircraft 1-800-831-2949 thats where I got It from...George Orndorff ________________________________________________________________________________
Date: Nov 15, 1996
Does anyone know if they did something different on these push rods for the Air Beatle military use project? It seems they looked at a number of differnt areas and modified because of their anticipated hard use. Nothing special. They were exactly the sameas the drawings (at least for the first 10 or so...don't know what happened after that) Ken RV6A Flying ________________________________________________________________________________
Date: Nov 15, 1996
From: catbird(at)taylortel.com (TTC Carroll A. Bird)
Subject: Re: Horz Stab jig question
aol.com!SteveRV6(at)matronics.com wrote: > > On page 6-5, RV-6 manual is states that you should locate and mark the > positions for the brackets that will support the HS-603PP (rear spar). It > refers to figure 6-5 for distances. I have been unable to find a figure or > diagram, with the exception of the original drawing on 3PP that is useful, > and no figure 6-5. > > Does it matter as long as the spar is stable and supported?? The book also > says use 3/16" bolts. Where do you get these? Home depot doesn't have them. > Once I can find 3/16" bolts, should the bolts be tightened down, ie I don't > want to bend the hinges, I think the idea is support and stability. > > If you use the AN3-7A or 14A bolts that came with the HS, would you be afraid > of damaging the threads? Can you use the stop nuts? Can these stop nuts be > used over and over without damaging? > > Last question. The 1/4" bolts that help stabilize the HS in the jig and > attached to the tip ribs ...... looks like oerndorf (sp?) drilled his > straight out of the 4x4, ie didn't use either method the manual suggests?? > > Thanks for your help. Not stupid, just ignorant. > > Steve Smith, Austin, TX Rv-6 prepunched To the question about 3/16 bolts. 3/16 bolts is the same size as a 10/32 bolt. They are available at any good hardware store. When I was building my wing spars I used them in the holes that were not to be riveted. I use 10/32 nuts on my aircraft bolts to hold things when I don't want to fix them permanent. The nuts are much softer than the bolts, so I don't think that it damages the bolts. At least, I cannot see any deformity in them. Just DON"T forget and leave one of them in permanently, they are not structural. catbird(at)taylortel.com Carroll Bird Buffalo Gap, TX ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Re: gas tanks
> > It's called "Explosafe", if I remember correctly from my motorcycle > road racing days. It works very well in cars and bikes -- always > wondered why you never hear about it in aircraft. Maybe it was > the incompatability with flop tubes! > > Cal > I remember reading that this stuff has a tendency to break-down after a few years and cause clogs. Chris ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Re:Gear leg fairings
Someone inquired about fairing gear legs on or off airplane. Fair legs on airplane with weight off legs. The fairings are literally fixed trim tabs if mis-aligned. Steve Schmitz RV4 202SS ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Re: Re: Lower Flap Push Rod End
Have about 550 hrs on my Rv4. Have not expierenced a flap rush rod failure, however the flap handle to cross tube weld did fail at about 475 hrs. Failure occured as I deployed the second notch of flaps on the base leg to final turn. The type failure I expierienced resulted in a symmetric failure of both flaps at the same time, a go around, ( suddenly you're too hot and too high) and a normal flaps up landing. My point (if i have one) is that failure of the flap pushrod tube threads, could happen at any time flaps are deployed or being deployed. In either event it would be un-expected, and in a low altitude low airspeed configuration. If the failure occurred during deployment hopefully one would have the presence of mind , and time to simply retract the flaps. If the parted pushrod didn't somehow jam one flap down. Could ailerons overcome one flap down? I don't know , but I'm dubious. If you've flown an RV you know how responsive they are. It seems the airplane would roll away from the deployed flap not now but Right now. Again not much altitude to work with. Perhaps the answer is to closely monitor airspeed , as to not overstress flap system during deployments, and to periodically repace the flap pushrod tubes. Say every two three hundred hours? Then again since I've never heard of this part failing in tension, perhaps Van has already overdesigned it , and the cut threads are not a concern? Hope I have'nt abused the purpose of the list. Steve Schmitz ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Re: Matronics Web Page Update!
aol.com!Cafgef(at)matronics.com wrote: > > subject: super glue > > a little background on the stuff called super glue or crazyglue. It is a > material made from Cyanoacrylate ester. The stuff that glues your fingers > together in an instant. The stuff was actually used for a while be doctors > to glue wounds together. Worked well because it devolves in water about the > same time as the wound heals. Completely disappears in about six weeks. > NOTE: it desolves in water over a period of time. Do not use super glue > for anything that you want to stay together. > > Gene Francis > RV-6A N23GF > (not flying yet) Gene, where did you get this info? First of all, super glue (or CA for short), is a family of glues made from Cyanoacrylate ester base. I have used industrial versions of this stuff for years in model airplanes; it comes in several grades and is available from hobby shops everywhere. Various manufacturers recommend various catalysers (known as kickers) to speed up the curing of this glue as it is 'instant' only with extremely close fitting surfaces. These kickers are often keytone based. By the way, if you ever have difficulty getting the glue to set, try wicking away the excess with a tissue while holding the parts together - it is usually the excess glue that is preventing the bond. The first time I glued my fingers together, I showed up at the Emergency room (gluing fingers is an occupational hazard of using this stuff, no matter how careful you are) and was told to leave it alone. Sure enough, within a couple of hours, I was able to seperate my fingers without losing skin. All traces of the glue were gone within 48 hours, though I quickly replaced it with more. You could always tell the state of my model fleet by looking at my hands. Some notes about this stuff - it is extremely high tensile, but very brittle. When cured, it is solvent resistant, but can be debonded from an applied surface fairly easily. I have seen a friend's model airplane retrieved from being lost in the woods for several months (7 or 8, as I recall), and the airframe was still strong (though the wood was warped and the whole had to be scrapped). I have also seen engine mounts fail in short order because the engine oil had seeped into the wood and caused the joints to debond. I can't imagine this stuff being used on wounds, because it would not bond long enough, and the glue itself would be a barrier to healing. Perhaps you heard of some different version of this stuff. I'd be interested in your source, because the more I learn about this stuff, the more amazing it is. PatK - RV-6A ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Re: hvlp,squeezer
RV>Wayne and Terry, RV> I am in the market for a squeezer. Do you think even with a prepunched ki RV>it is still worth getting?? I heard Action Air has good prices, but was RV>never able to get them on the phone. I know Avery's will be good. Does RV>anyone have a number for Action Air or comments about them?? They would RV>return calls, but we never got hooked up, and finally they quit returning RV>calls. RV>Steve Smith, RV-6, HS, prepunched Hi Steve. I ordered my used CP Squeezer from Action Air Parts and have no complaints. The number I have for them is 810-364-5885. Please feel free to contact me if you have any other questions. Rod Woodard RV-8 (HS finished, VS is next) Loveland, Colorado RWoodard(at)lawyernet.com ***LISTERS: Please include your e-mail address in posts to the list *** ________________________________________________________________________________
Date: Nov 15, 1996
> The rule we had when I was a test pilot in the Air Force was if something >goes wrong when you activate a control, immediately return it to the position >that it was in before the problem occurred. When you fly, pay attention to >what is happening and you will stay out of trouble. I have my Nomex >fireproof flying suit on in preparation for the flames about to come my way. Jim, I'll echo your comment about undoing what you last did. I had a split flap situation in a Commanche and I just raised the flaps, no big deal. As a CFI, I teach that very point; if something you did causes a problem, then undo it - it almost always caused the problem. Sure, think about what is happening, but don't stew about it. I'll share the flames, but I don't have a Nomex fireproof flying suit. :-) Mike Pilla Michael Pilla pilla(at)exit109.com v: (908) 566-7604 f: (908) 566-7936 ________________________________________________________________________________
Date: Nov 15, 1996
aol.com!SteveRV6(at)matronics.com wrote: > > On page 6-5, RV-6 manual is states that you should locate and mark the > positions for the brackets that will support the HS-603PP (rear spar). It > refers to figure 6-5 for distances. I have been unable to find a figure or > diagram, with the exception of the original drawing on 3PP that is useful, > and no figure 6-5. Without my manual handy, can't tell you where this picture is. However, use the spar as a guide and locate the brackets with the hinge brackets. > Does it matter as long as the spar is stable and supported?? The book also > says use 3/16" bolts. Where do you get these? Home depot doesn't have them. > Once I can find 3/16" bolts, should the bolts be tightened down, ie I don't > want to bend the hinges, I think the idea is support and stability. I found bolts at a local ACE Hardware; but not until a later date, for use on the wing spar. I used the bolts from the kit; tightened only a turn or two onto the elastic of the stop nut. To answer the next question; you won't hurt the nuts as long as they apply friction when tightening. If they spin on by hand, then you need to replace them. You can use these nuts many time before that happens. > If you use the AN3-7A or 14A bolts that came with the HS, would you be afraid > of damaging the threads? Can you use the stop nuts? Can these stop nuts be > used over and over without damaging? > > Last question. The 1/4" bolts that help stabilize the HS in the jig and > attached to the tip ribs ...... looks like oerndorf (sp?) drilled his > straight out of the 4x4, ie didn't use either method the manual suggests?? Yes, he did. What's the question? :) Ok, I get it. Use whatever method that suits you. I bought a 3 foot length of 1/4" threaded rod and cut it into two pieces.. I drilled straight through the jig, installed the rod with washers and nuts on both sides of the post and rib. I bent the rod until the rib was aligned, then tightened all the nuts and checked it again. I continued to check while completing the stabilizer; it never moved. That's the important thing; it must hold position. > Thanks for your help. Not stupid, just ignorant. > > Steve Smith, Austin, TX Rv-6 prepunched That's how we all learn. Good luck, Steve. PatK - RV-6A - Gonna get back to the kit this weekend. ________________________________________________________________________________
Date: Nov 15, 1996
RV>On page 6-5, RV-6 manual is states that you should locate and mark the RV>positions for the brackets that will support the HS-603PP (rear spar). It RV>refers to figure 6-5 for distances. I have been unable to find a figure or RV>diagram, with the exception of the original drawing on 3PP that is useful, RV>and no figure 6-5. I built my rear spar including the hinge attach points and then lined up the jig support brackets by laying the spar on the jig. Seemed to work Ok for me. As you said, the biggest concern is that the spar be stable and supported. You don't want the brackets to cause any binding or twist. RV>The book also says use 3/16" bolts. Where do you get these? RV> Once I can find 3/16" bolts, should the bolts be tightened down, ie I don't RV>want to bend the hinges, I think the idea is support and stability. I haven't even put nuts on the bolts. By the time you have the brackets at the jig/hinge point and the all thread at the tips of the ribs and the HS-614 clamped on your additional temporary center upright, you'll have a pretty secure structure. RV>If you use the AN3-7A or 14A bolts that came with the HS, would you be afrai RV>of damaging the threads? Can you use the stop nuts? Can these stop nuts be RV>used over and over without damaging? I used a few bolts that came with the kit. So far I haven't damaged any threads on the bolts. About the only thing I've done is scraped a little of the gold coating off the bolts. If I think I've done too much scratching, I'll just use some new bolts. A friend and I went together on an AN hardware kit from Aircraft Spruce so I've got some spares laying around. RV>Last question. The 1/4" bolts that help stabilize the HS in the jig and RV>attached to the tip ribs ...... looks like oerndorf (sp?) drilled his RV>straight out of the 4x4, ie didn't use either method the manual suggests?? I just drilled straight through my 4 x 4's. The biggest challenge is drilling the holes _straight_ through the 4 x 4's. You then should be very careful to actually drop a string from the tip of the rib down to the spar to make sure you are exactly perpendicular. If the threaded rod isn't exactly right, you should be able to bend it around to make it work. Again, I'm no expert, but so far, so good. Keep up the good work Rod Woodard RWoodard(at)lawyernet.com RV-8, Loveland, Colorado ***LISTERS: Please include your e-mail address in posts to the list *** ________________________________________________________________________________
Date: Nov 15, 1996
aol.com!SteveRV6(at)matronics.com wrote: > > Wayne and Terry, > > I am in the market for a squeezer. Do you think even with a prepunched kit > it is still worth getting?? I heard Action Air has good prices, but was > never able to get them on the phone. I know Avery's will be good. Does > anyone have a number for Action Air or comments about them?? They would > return calls, but we never got hooked up, and finally they quit returning > calls. > > Steve Smith, RV-6, HS, prepunched I am building an RV-4, empannage finished,Wings finished, fuselage being skinned at present. Finish kit on order. I cannot imagine having done all this without a squeezer-dimpler tool. I bought mine from Bob Avery he has always treated me very well. I have a 1 1/4" head and a 3" for the Tatco tool. Carroll Bird RV-4 #3919 Buffalo Gap, TX ________________________________________________________________________________
Date: Nov 15, 1996
I have seen an RV-4 that was groundlooped, and in the process of sliding backwards through the buckwheat, the trailing edge of the flap caught the ground. The resultant impact ripped the flap pushrod AND attach bracket right out of the flap. The flap was destroyed, and the pushrod and bracket remained intact. Stronger than I thought! Bill Mahoney Sherman, CT RV-6 N747W ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Flap push rod
In regards to the aluminum push rod I would like to express my humble opinion. Some one has expressed a concern about the threaded rod, and the possibility of stripping these threads. The most pressure put on this rod is when the flaps are being lowered. The rod is in compression with a jam nut on both ends, I just can't see how theycould be stripped in this condition. The rod could possibly be buckled, and I have no idea how much pressure this would take, however I think if you kept the airspeed within tolerences that this shouldent be a problem. When the flaps are being raised we have the slipstream to assist the raising of the flaps if we are flying, and just the weight of the flaps if we are sitting still. In either case the rod is in tension and this appears to me to be the only time that we could strip the threads from the rod. When we put a steel nut on a bolt or rod end we have only the thickness of the nut holding, about 3/16 inch. On a 32 thread-per inch bolt this equates to about 6 threads holding. When we thread the rod-end into the push rod it goes in about 1 inch which is approximately 5 times the number of threads than those with a steel nut. Has any one ever measured the tension it would take to strip this many threads from the rod, I haven't the equipment to do this with, but to do it with the flap actuator handle you would probably have to stand up and jump on it. Sorry to take up so much space with this diatribe. Thanks for your time. Carroll Bird Buffalo Gap, TX ________________________________________________________________________________
From: "Timothy J. Etherington" <tjetheri(at)cca.rockwell.com>
Date: Nov 15, 1996
Wayne, Hope you will have as musch fun building so far as I have. On the pneumatic squeezer, If you can afford one get one. If you use one even once you will not go back to any other method. For us rookies that have never riveted before it makes VERY consistent work. Tim Etherington RV-6 emp. HS and VS done ________________________________________________________________________________
Date: Nov 15, 1996
>>From: aol.com!SteveRV6(at)matronics.com[SMTP:aol.com!SteveRV6(at)matronics.com] >>Subject: Re: RV-List: hvlp,squeezer > >> I am in the market for a squeezer. Do you think even with a prepunched >>kit >it is still worth getting?? > >>Steve Smith, RV-6, HS, prepunched > I had the chance to trying a pneumatic squeezer before I started my prepunch tailkit, and knew it would be money well spent if I could find a good used one. I did, and I wouldn't give it up now. The prepunched kit does nothing that will lessen the benefits of a pneumatic squeezer since you still have *all* the dimpling and riveting. After using it a bit you get used to how many washers you need for what thicknesses, etc. But after that little setup it's just pft pft pft pft pft down the line, perfect uniform, and straight dimples or rivets. I also found it's easier to rivet and dimple many things because you have one hand free to hold parts. Definitely money well spent. >--------------------- cut here >-------------------------------------------------------------- > >Mitch Faatz mfaatz(at)sagenttech.com San Jose, CA >RV-6AQME N727MF (reserved) Empennage control surfaces completed, ready to hang elevators and rudder! > > ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Continuous improvement
>From Ken: "Van has my aplause for improving as he goes. Look at detail and value now compared to undrilled kits with untapered or undrilled spar components. Ken Smith RV6 still tail, with an oldie kit for wings..." Hi all, My sympathy to Ken for having an old wing kit;^) I bought an old unstarted tail kit for my -6. Rivet layout wasn't that big of a deal with my experence as a Design/Draftsman. It wasn't until I got one of the early "prepunched" wing kits (mine didn't have tapered flanges) that I knew how much the kits have improved. I really have to agree with Ken about the continuous improvement at Van's (thanks Andy Hanna and everyone else there). I just though I'd let the "lurkers" and "wannabe's" out there that Van's has taken a ton of the tricky stuff and missed rivet holes out of the equation, although there are still alot of things that can "get you". I'm sure glad this list is around to help with those things :^) Laird riveting skins on wings after one year of work LairdOwens(at)aol.com ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Pnuematic Squeezer
After using Mitch Faatz's pneumatic squeezer, I'm convinced I can't live wothout one. Avery's has them for $335 but..... does anyone know of a source for used pnuematic sqeezers? Preferrably CP214. You can respond personaaly to my email address. ED Cole RV6A #24430 Wings ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Hear we go....no turning back!
Hello, I've ordered and received the Avery tools needed to build a RV-6, the compressor is in place, the garage floor is painted, I have permission from my wife to proceed, I flip through the preview plans often, and will order the empennage kit in 20 days or so. However, having never contributed to the list I wanted my first submittion to be a special one...so here goes. Yesterday, November 14, 1996, at the age of 31 and with 43.8 hours total, I received my Private Pilot License in Denton (DTO), TX. And now . . . . . . . I build. Thank you for listening. My next post will be when I have the tail kit and have a ligitimate question. -- Doug Reeves - PP-ASEL (1.1 PIC) ;^) ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Re: P-Squeezer
Gang-- At Oshkosh this year, I bought a recondidtioned pneumatic squeezer. Unfortunately, as with most of our tools, it came with no instructions. I've goofed around with it a bit, but don't know if I'm using it correctly. One question: Do you hold it with the stationary die against the manufactured head and let the moving die squeeze the rivet, or the other way around? Or does it even matter? --Don RV-8 ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Re: Pnuematic Squeezer
Me too..... I'd like to know about sources for pneumatic squeezers and prices, new as well as used. There are probably a few others who would too judging from the number of "newbies" I see on the list. Thanks. Paul Bilodeau pmbs(at)probe.mt.att.com 908-957-6611 P.S. Just Ordered Empennage Kit From Van's..... 8<} ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Re: Seat cushion fabrication
> Here are a couple of drawings I made from Bingelis' article. One is > a sketch of each part, the other is an assembly drawing. They are > in Macintosh PICT format. Unfortunately for those of you with DOS/ > Windows I'm not sure how you would read them unless a friendly Mac > user could print them for you. I could convert them to .gif easily enough (And they'd be much smaller I'd wager). But I'm not so sure about sending binaries to the list. Perhaps if there's an ftp site either on John Hovan's or Matt's site. -- "Wait a minute, you expect us innocent children to climb up dangerous scaffolding and paint naked people all over a church? We'll do it!!" -- Yakko Warner, Animaniacs "Yeah, I've got ADD, you wanna make something of.... oooh, cool. Look!" ________________________________________________________________________________
Subject: P-Squeezer
Date: Nov 15, 1996
>>Do you hold it with the stationary die against the manufactured head and >>let the moving die squeeze the rivet, or the other way around? Or does >>it even matter? >> >>--Don RV-8 > It's best to hold the stationary die against the rivet, since you've got more control, but I do it the other way around when I have to with no problems yet. It helps improve those fine motorskills of the thumb when you are trying to geeeeeently advance the ram until contact is made, and then blamo. If you don't have a "feathering" trigger, however, I don't see how you could safely do it this way. You would have to hold the stationary die against the rivet. Don't forget to keep the compressor up around 80 PSI, and the ram develops full pressure right near the end of the stroke. --------------------- cut here -------------------------------------------------------------- Mitch Faatz mfaatz(at)sagenttech.com San Jose, CA RV-6AQME N727MF (reserved) Hanging the elevators to the HS, fabricating the seats. Nice mix, eh? > ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Re: 3m Tape info
>I wonder why this would be any stronger than just prosealing on your >stiffeners. I haven't worked with the stuff much but I understand that it >has bond strength which can be considered structural. I asked my IA about >this and he said that the biggest problem would be peel and if you riveted >the ends of the stiffeners down it would probably be much safer and work >but he wouldn't sign off on it. Sign off? SIGN OFF?! We don't need no steenkeeng SIGN OFF! Check six Mark ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Temperature Considerations
I will be skinning RV6A tail section this winter. Ambient temperature in my hangar will be 40-50F. Is this cold enough to cause problems? Should I use a heat gun or something? Please advise. Thanks. Jim Hurd New Mexico ________________________________________________________________________________
Date: Nov 15, 1996
From: Terry Mortimore <terry.mortimore(at)sympatico.ca>
Subject: Re: Hear we go....no turning back!
Doug Reeves wrote: > > Hello, > > I've ordered and received the Avery tools needed to build a RV-6, the compressor is in place, the garage floor > is painted, I have permission from my wife to proceed, I flip through the preview plans often, and will order > the empennage kit in 20 days or so. However, having never contributed to the list I wanted my first submittion > to be a special one...so here goes. > > Yesterday, November 14, 1996, at the age of 31 and with 43.8 hours total, I received my Private Pilot License > in Denton (DTO), TX. > > And now . . . . . . . I build. > > Thank you for listening. My next post will be when I have the tail kit and have a ligitimate question. > > -- > Doug Reeves - PP-ASEL (1.1 PIC) ;^) congratulations doug, you've already clear the biggest hurdle in your upcoming project. Don't get in a rush and plan on this being a long project and you'll do well. terry, rv-6a, waiting on my fuselage ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Wood Propellers / New Sensenich Metal Propeller for 180 HP
1.) Has anybody heard any comments good or bad on ED STERBA wood propellers. He charges $500 for a 5 lamination wood prop for a 180 HP Lycoming. Also 2.) I called SENSENICH and they said they are seriously working on their 180 HP metal propeller. In two weeks, they will be offering the spacers for their new prop for those who wish to continue working on their cowling finish work. I asked them if they would have it ready to go by APRIL 97 and they said no problem - that they would refund my money for the spacer if it wasnt completed. The problem is that I will need a prop no later than that and I am afraid if they slip I will be without a prop and not able to fly my plane. I have been informed that it took them 18 months last time to build a metal prop for the 160 HP. Does anybody know more than this, or have any advice ? Scott Johnson / Chicago Project Status: Working on finishing kit, brand new 180HP on its way from VANS ! ________________________________________________________________________________
Date: Nov 15, 1996
RV>After using Mitch Faatz's pneumatic squeezer, I'm convinced I can't live RV>wothout one. Avery's has them for $335 but..... RV>does anyone know of a source for used pnuematic sqeezers? Preferrably RV>CP214. RV>You can respond personaaly to my email address. RV>ED Cole RV6A #24430 Wings Hello Ed, I purchased my used CP 214 Squeezer from Action Air for $249.50. The number I have from them is 810-364-5885. BTW, this is my very favorite tool and I wouldn't want to build without it. It can be done, I just wouldn't want to. Re: responding personally... I would have, but my e-mail software does not automatically provide me with your e-mail address. The only return address I have is rv-list(at)matronics.com. I understand that I'm not the only -lister in this situation. That's why in the FAQ's and List Rules request that all of us include our e-mail addresses in our signatures. Take care, Rod Woodard RV-8, HS done, working on VS; Loveland, Colorado RWoodard(at)lawyernet.com ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Re: Temperature Considerations
> > I will be skinning RV6A tail section this winter. Ambient temperature > in my hangar will be 40-50F. Is this cold enough to cause problems? > Should I use a heat gun or something? > > Please advise. Thanks. > > Jim Hurd New Mexico Yes, you should use a heater of some sort. You'll find that your hands work better and you will be more motivated to go out and work on your project if the shop is warm. OOoooohhh -- you meant, like, as far as the metal is concerned? :-) :-) :-) Forget about it. S'not gonna make a difference. Randall Henderson, RV-6 randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Nov 15, 1996
RV>Gang-- RV>At Oshkosh this year, I bought a recondidtioned pneumatic squeezer. RV>Unfortunately, as with most of our tools, it came with no instructions. RV>Do you hold it with the stationary die against the manufactured head and RV>let the moving die squeeze the rivet, or the other way around? Or does RV>it even matter? RV>--Don RV>RV-8 Hi Don, I was in the same boat. My conclusion is that it doesn't really matter. As long as you keep the things square to your rivet or the aluminum, it shouldn't make a bit of difference. It seems easier to me to keep the non-moving part on the manufactured side, but as you'll soon find out (if you haven't already), this isn't always possible due to trying to squeeze around flanges, etc. Happy building, Rod Woodard RV-8; HS finished; VS in progress; Loveland, Colorado RWoodard(at)lawyernet.com ***LISTERS: Please include your e-mail address in all posts to the list *** ________________________________________________________________________________
Date: Nov 15, 1996
Don McNamara wrote: -snip- > Do you hold it with the stationary die against the manufactured head and > let the moving die squeeze the rivet, or the other way around? Or does > it even matter? > > --Don > RV-8 I have a CP squeezer. I've used it both ways, dependin on what I needed to do. IMHO the most important thing is to ensure the sets are centered on the rivet before you hit the button. As long as you're making good rivets, you must be doing it right. Roy RV-8 #80096 ________________________________________________________________________________
Date: Nov 15, 1996
>I will be skinning RV6A tail section this winter. Ambient temperature >in my hangar will be 40-50F. Is this cold enough to cause problems? >Should I use a heat gun or something? > >Please advise. Thanks. > >Jim Hurd New Mexico > > > Hey, one of our builders built his RV-4 in a horse barn. During the winter the temperature was cold enough that he had to wear both insulated long-johns and an insulated snow-mobile suite. John Ammeter ammeterj(at)seanet.com 3233 NE 95th St Seattle WA, 98115 USA RV-6 N16JA First flight August 1990 ________________________________________________________________________________
Date: Nov 15, 1996
Thanks for the several replys. I have used 'capture washers' in a number of places on rod ends, but I never knew what to call them. I am probably not as concerned with the rod end 'popping' off of the ball as I am with the small stud (that bolts into the flap) failing. Given that none have failed yet I don't plan to worry about it. I do think there is a better way to attach the arm, as was suggested, doing it so that the bolt is in double sheer would be better. Also, for the instructor that commented about 'if you move a control and there is a problem, then move it back'. That is true, but the flaps may not fail when you put the flaps down but may fail sometime later into the approach. Then it would take some time to figure out what happened. Given that you have two ailerons to help counteract one flap and the fact that the ailerons are much farther out on the wing (a longer arm), I think the plane should still be controlable. Some brave person could go out and unhook one of the flaps from the control arm and 'wire' that flap up. Then at altitude you could put on the 'one' flap and see if you could control the airplane with the ailerons. It might be fun to see how fast it would roll this way as you would have a full span aileron on one side of the plane. It should roll like crazy one way and hopefully roll very slowly the other way. Herman dierks(at)austin.ibm.com > > << I don't understand what you are using on the end if you don't use the > Aurora bearing. What is a 'capture washer'???? > Herman >> > > Herman- > > Perhaps I didn't get the idea across that the studded lower flap tube rod end > bearing (it attaches to the flap root) that Van's specifies does not lend > itself to the common practice of boxing in the rod bearing with large pattern > washers on both sides so that, if the bearing fails, the joint will not > separate completely (and you will hopefully be alive and able to land and > fix it). > > E-mail me direct if still not clear. > Regards, > Gary VanRemortel > ________________________________________________________________________________
Date: Nov 15, 1996
>> >> I will be skinning RV6A tail section this winter. Ambient temperature >> in my hangar will be 40-50F. Is this cold enough to cause problems? >> Should I use a heat gun or something? >> >> Please advise. Thanks. >> >> Jim Hurd New Mexico > >Yes, you should use a heater of some sort. You'll find that your >hands work better and you will be more motivated to go out and work on >your project if the shop is warm. > >OOoooohhh -- you meant, like, as far as the metal is concerned? >:-) :-) :-) > >Forget about it. S'not gonna make a difference. > >Randall Henderson, RV-6 >randall(at)edt.com >http://www.edt.com/homewing > Jim, I agree with Randall, 50F is what I warm my garage up to in the winter when I work on the aircraft. I was out today doing fiberglass fairings at the top and bottom of the gear legs and it was only 55 degrees. Fiberglass resin takes a little longer to set up but no problem. I can't see any problem with metal work except your hands get cold handling all the cold tools :-) cheers joe joehine(at)nbnet.nb.ca Comp. 9, Site 8, RR#4 506-452-1072 Home Fredericton, NB 506-452-3495 Work Canada, E3B 4X5 ________________________________________________________________________________
Date: Nov 15, 1996
>aol.com!Cafgef(at)matronics.com wrote: >> >> subject: super glue >> >> a little background on the stuff called super glue or crazyglue. It is a >> material made from Cyanoacrylate ester. bunch of stuff deleted here the more I learn about this stuff, >the more amazing it is. > >PatK - RV-6A Sorry everyone, this is way off topic but interesting. Pat, did you know that CA is used in law inforcement in the development of fingerprints on various surfaces. Plastics mainly. The exhibits are suspended in a cabinate and crazy glue is heated with a low heat source along with a scorce on humidity (jug of hot water) and the fumes from the glue polmerize on the latent fingerprints. Before this was discovered, prints were hard to develop on plastics but they are one of the best surfaces with the use of crazy glue. I apologise again for straying from subject. One application for RVs is that if you used CA to glue anything inside and you used any amount of glue, the next day you would have nice white fingerprints on the inside of your canopy that would NOT come off. Cheers joe joehine(at)nbnet.nb.ca Comp. 9, Site 8, RR#4 506-452-1072 Home Fredericton, NB 506-452-3495 Work Canada, E3B 4X5 ________________________________________________________________________________
Date: Nov 15, 1996
Subject: primer, sorry but I can't help it...
Hello all, I've read all of the past 16 years of the RV-ATOR, thanks to the gentleman on Luscombe Drive in New Mexico (what a neat address). I'm still confused about primering the parts. I live in a fairly easy area where primering is not a big thing (northern Alabama). I can work outside with a positive flow air mask most of the time. Please follow... I have read the archives. Thanks, Matt! I'm watching the Orndorff tapes and it doesn't appear that he had any primer on the parts that he was putting together. What am I missing here? What I do know about aluminum is that is "self protecting" in that it forms an oxide which is a grey coat which needs to be polished off before you take the plane to Ottumwa, IA (sp?, it was a special place to go in the 60's before Oshkosh, and the airplane was a PT-22 with the yellow and blue tail). I mean, look at the American Airlines planes with the the shiny finish on their planes. But all of that work is on the outside of the aircraft. I'm inclined to use Zinc Chromate. I like the color and the texture. Just for the inside parts. But for every part? And what about etching before the primer sticks? What does etching really mean? Self etching primers? I'm just a builder like ya'll, looking at the plans for the E-801PP skin, Mike Weller RV 80187 (under construction) midibu(at)hsv.mindspring.com (preferred) or mike.weller(at)msfc.nasa.gov ________________________________________________________________________________
Date: Nov 16, 1996
Subject: Antenna Wires
I have all of my antennas mounted in the rear of my fuselage. VOR/GS, LORAN, TRANSPONDER, and COM. My question is, can all of the coax cables be bundled to get up to the radios in the cockpit or should they be separated. I'm fairly sure that the passive coax cables that come from the VOR/GS and the LORAN can be run together but am not sure about the coax cables that transmit a signal like the COM and TRANSPONDER. Thanks in advance for a response. Jim Cone jamescone(at)aol.com ________________________________________________________________________________
Date: Nov 15, 1996
> I will be skinning RV6A tail section this winter. Ambient temperature > in my hangar will be 40-50F. Is this cold enough to cause problems? > Should I use a heat gun or something? It's only a big issue if the skeleton and skins are drastically different temperatures. If you do the wing skins in that temperature, you might want to heat them. The empennage skins are so small that their coefficient of thermal expansion, as high as it is for aluminum, isn't high enough to make a difference. A bigger problem is going to be cold hands and cold tools (too cold to hold comfortably). If this isn't a problem for you, go for it. -Joe -- Joe Larson jpl(at)showpg.mn.org 612-591-1037 Showpage Software, Inc. http://www.wavefront.com/~showpg 14190 47th Ave N. Plymouth, Mn 55446 Future RV-6A pilot. ________________________________________________________________________________
Date: Nov 15, 1996
Subject: Re: Alternative Engines
You wrote: >As for alternatives to a Lycoming, I think the Belted Air Power engine > is the only one right now that is showing any promise. I beg to disagree. Ross's reduction gear has quite a history by now of reliable service (Tracy Crook's RV4, the guy using his gyrocopter for instruction and quite a few others). Of course I have to say this as I've just taken delivery of a Ross reduction drive - very well make - sturdy. This is for use on Mazda 13B rotary (from RX-7). Finn finnlass(at)ix.netcom.com ________________________________________________________________________________
Date: Nov 15, 1996
>> I will be skinning RV6A tail section this winter. Ambient as far as the metal is concerned? >:-) :-) :-) > >Forget about it. S'not gonna make a difference. > Really? I understand that one way of minimizing oilcanning is to heat up skins prior to drilling/clocoing/riveting! Finn finnlass(at)ix.netcom.com ________________________________________________________________________________
Date: Nov 16, 1996
Subject: R-410 Rudder Brace
While working on my RV-8 rudder, I had difficulty with the R-410 brace that is supplied in the kit as a piece of c-channel with trimming lines drawn on it. After trimming the part to fit, I found that there was insufficient metal to rivet the brace to the lower R-404 rib and skin. Also, the bend lines on R-410 were wrong, it was too loose a fit in the R-404 rib. The drawing 7PP shows the R-410 brace being attached to the outside (bottom) of the R-405PD. I spoke to Tom at Van's, and told him that the part would fit better if it were attached to the inside (top) of the R-405PD. He said that was the way it was supposed to be... Well, he looked at the drawing 7PP on the master set and said that this was in error, the R-410 brace was supposed to be attached to the top of R-405PD. So, a new R-410 is on the way. I think I'll just fabricate one today as I have a 4 ft. brake and some .040 material on hand. In retrospect, I should have made a cardboard template before cutting the c-channel supplied to make the R-410. Has anyone else encountered this? Jon Ross RV80094 working on rudder. ________________________________________________________________________________
Date: Nov 16, 1996
Alexander Aircraft has sold out to Aircraft Spruce East. They harldly have anything in stock there. I think they just wanted to put Alexander out of business. rvbildr(at)juno.com ________________________________________________________________________________
Date: Nov 16, 1996
Subject: Alternative Engines
One "alternative" worth watching is Superior's copy of the Lycoming O-360. They are developing a kit which will allow you to assemble a "Lyc O-360" from Superior's parts, including Millenium cylinders and their own crankcase, crankshaft, cam, and all other parts except the oil sump. Don't know why not the sump - you have to get that on your own. Talked to them last week and they will be test running for certification very soon, and expect to have the kit available mid-97. Cost hasn't been set yet, but he estimated we will save "about $6000" compared to the cost of a new Lyc. 180 from Van's. Anyone know more about it? ________________________________________________________________________________
Date: Nov 16, 1996
James K. Hurd wrote: > > I will be skinning RV6A tail section this winter. Ambient temperature > in my hangar will be 40-50F. Is this cold enough to cause problems? > Should I use a heat gun or something? > > Please advise. Thanks. > > Jim Hurd New Mexico If structure and skin are the same temp it doesn't matter what that temp is. Some folks like to heat the skins, though normally just the large wing skins, because it can make them look tighter. If you are going to heat skins, a heat gun may cause uneven heating which may cause problems. See previous postings and newsletters. Best article I've seen is in 2/93 RVATOR, reprinted in "14 Years of RVATOR". A pad type heater is probably the best practical way to get uniform heating. I can make you one if you want one. See my posting from about a week ago for details. ________________________________________________________________________________
Date: Nov 16, 1996
<< Someone inquired about fairing gear legs on or off airplane. >> Someone was me, and the intent of my Q. was to determine whether there was an advantage to working with the gear leg clamped in a bench vise as shown in several of the construction photo's in Van's manual. It goes w/o saying that the alignment would first be established and indexed on the gear leg before it was removed from the airframe for fiberglassing, etc. The gear legs are tricky to remove and install in the sockets, so I was wonderiing if the easier access to the part was worth the hassle of fitting the legs so many extra times. I know I can do this job sitting on my cold garage floor beside the airframe and get results. I was just hoping to learn which was the *easy* way. Thanks again to all who weighed in with an opinion. At least I've decided to go fiberglass rather than Aluminum. Bill Boyd RV-6A chocked WAY up in the air for gear work. ________________________________________________________________________________
Date: Nov 16, 1996
Subject: Re: Lower Flap Push Rod End
<< Then again since I've never heard of this part failing in tension, perhaps Van has already overdesigned it , and the cut threads are not a concern? >> Isn't this part in constant compression? Would not the slipstream return the flap to neutral (very quickly) if the rod collapsed? Just wondering. Bill Boyd ________________________________________________________________________________
Date: Nov 16, 1996
Subject: Re: Flame-proof Nomex
<< I'll share the flames, but I don't have a Nomex fireproof flying suit. :-) Mike Pilla >> Does anyone out there need one- size 34 R? I did a very foolish thing and ordered one from the CAP on sale despite knowing I probably need a size 40 (they only had 2 sizes on sale) and sure enough, I was singing soprano by the time I stuffed myself into it. I had to have help getting it off of me! It's olive drab, genuine 1st quality GI issue Nomex coverall with more velcro and pockets than Van's has rivets, but you gotta be smaller than me to wear this for long. Lists for $125 in the CAP warehouse catalog, yours for much less, if interested. Email me off list please!! Bill Boyd SportAV8R(at)aol.com ________________________________________________________________________________
Date: Nov 16, 1996
<< I can't imagine this stuff being used on wounds, because it would not bond long enough, and the glue itself would be a barrier to healing. Perhaps you heard of some different version of this stuff. >> Trust me, this stuff IS used in medicine as a tissue repair/wound closure agent and has been used, for example, by neurosurgeons to close the covering layer over the spinal cord after spinal surgery, way back in the early 80's before FDA approval was ever given.. The doc who told me this said he used to carry the stuff in and out of the operating room himself to leave behind no evidence of his "experimental" technique. Cyanoacrylate is now formulated specifically for laceration repair. Seems the stuff lets go about the time the cut heals itself anyway... no stitches to take out. If, like me, you get dry cracked hands during the winter and working with hand tools on your RV only makes matters worse, leading to painful split thumbs and fingertips, try this trick: Carefully apply a small "scab" of Superglue over the split area and allow it to dry. Keeps grease and other workshop hydrocarbons out of your flesh and reinforces the damaged skin to prevent elongation of the crack (*NOTE: do NOT attempt to fix a split fingertip by stop-drilling the crack; it hurts more than you would believe, even with a #40 drill, and is not effective, despite success on plexiglas cracks.) Not exactly hard core RV discussion, but hopefully relevant to the homebuilding community anyhow :^) Bill Boyd SportAV8R(at)aol.com ________________________________________________________________________________
Date: Nov 16, 1996
Subject: Re: Wood Propellers / New Sensenich Metal Propeller for 180 HP
Scott Johnson wrote: > > 1.) Has anybody heard any comments good or bad on ED STERBA wood propellers. > He charges $500 for a 5 lamination wood prop for a 180 HP Lycoming. > > Also > > 2.) I called SENSENICH and they said they are seriously working on their 180 > HP metal propeller. In two weeks, they will be offering the spacers for > their new prop for those who wish to continue working on their cowling > finish work. I asked them if they would have it ready to go by APRIL 97 and > they said no problem - that they would refund my money for the spacer if it > wasnt completed. The problem is that I will need a prop no later than that > and I am afraid if they slip I will be without a prop and not able to fly my > plane. I have been informed that it took them 18 months last time to build a > metal prop for the 160 HP. Does anybody know more than this, or have any > advice ? > > Scott Johnson / Chicago > > Project Status: Working on finishing kit, brand new 180HP on its way from VANS ! I have been to Ed's shop and flown behind a couple different props of his. good guy, good work, good prop. Dougr(at)netins.net looking for a -4 project ________________________________________________________________________________
Date: Nov 16, 1996
>>> I will be skinning RV6A tail section this winter. Ambient as far >as the metal is concerned? >>:-) :-) :-) >> >>Forget about it. S'not gonna make a difference. >> > >Really? I understand that one way of minimizing oilcanning is to heat >up skins prior to drilling/clocoing/riveting! Sigh. Ok, lets talk about *reality*, not theory. (and even the *thoery* really doesn't hold water). 1. The reality is that I have a friend who use the 'heat the skins' method on one wing and not the other. You cannot tell the difference. 2. Even if there *was* a difference on the wing, the surfact area of the empennage are so small that it would have no affect. 3. People talk about heating the skins. Well, if you are gonna heat the skins, then you cannot avoid heating the underlying skeleton. The two are going to expand and contract together. The taughtness of the skin is going to be the same no matter what. BEst Regards, Dave Barnhart barnhart(at)a.crl.com rv-6 sn 23744 Trimming the canopy ________________________________________________________________________________
Date: Nov 16, 1996
Subject: Re: Continuous improvement
Laird, That is so true about the pre-punched kits. But, I got a look at a QB this week, and I am excited about ordering one to strap onto my tail kit when it's complete. Definitely alot of time saved and I was impressed with the quality. Steve Smith, RV6, Austin, TX ________________________________________________________________________________
Date: Nov 16, 1996
Subject: Re: Antenna Wires
aol.com!JamesCone(at)matronics.com wrote: > > I have all of my antennas mounted in the rear of my fuselage. VOR/GS, LORAN, > TRANSPONDER, and COM. My question is, can all of the coax cables be bundled > to get up to the radios in the cockpit or should they be separated. I'm > fairly sure that the passive coax cables that come from the VOR/GS and the > LORAN can be run together but am not sure about the coax cables that transmit > a signal like the COM and TRANSPONDER. Thanks in advance for a response. > > Jim Cone > jamescone(at)aol.com Coaxial cable consists of a center concudtor which carries the signal and a braided outer conductor (shield) which is chasis-grounded. This makes coax very resistant to radiating or receiving electromagnetic energy. You should not have a problem with "cross-talk" between your coax, especially considering the very low power levels and frequencies that the avionics transmits. Most important to a good installation is that you don't over-bend, kink, or smash the coax. This will change the properties of the coax by changing the characteristic impedence (Zo) at the damaged spot which will degrade the performance due to reflections, and that you ensure your coax connectors are correctly built for the same reason. Roy RV-8 #80096 and x-Navy avionics tech/instructor of advanced electronics. ________________________________________________________________________________
Date: Nov 16, 1996
Subject: Re: SuperGlue
> > ><< I can't imagine this stuff being used on wounds, because it would not > bond long enough, and the glue itself would be a barrier to healing. > Perhaps you heard of some different version of this stuff. >> > >Trust me, this stuff IS used in medicine as a tissue repair/wound closure >agent and has been used, for example, by neurosurgeons to close the covering >layer over the spinal cord after spinal surgery, way back in the early 80's >before FDA approval was ever given....... Yikes. Here is a hint from someone who sews up ten or so lacerations a day when not pounding rivets: SuperGlue is not the best thing to be cramming into a wound. There is a type of glue that is being experimented with in Canada to put skin together but is not here yet. I worked with another doctor who was testing the use of superglue to seal lacerations and many fell apart before they were properly healed. If used on a cut not properly cleaned, infection is a big problem. "Don't try this at home." HOWEVER: sealing the drying cracks in thumbs and fingers is effective if it is done before the "cut" gets too deep. Just a medical thought or two.......... ________________________________________________________________________________
Date: Nov 16, 1996
Subject: Re: Aircraft Spruce
>Alexander Aircraft has sold out to Aircraft Spruce East. They harldly have >anything in stock there. I think they just wanted to put Alexander out of >business. >rvbildr(at)juno.com > BINGO!!!! It's called cornering the market. I used to order as much as I could from Alexander because I liked dealing with them and they seemed liked the "small guy" in the market that cared if I got my 1032 nuts or not. Now, another take-over and less competition and less service. Ooops...this is an opinion...sorry to take up space..... ________________________________________________________________________________
Date: Nov 16, 1996
for 180 HP I asked them if they would have it ready to go by APRIL 97 and >they said no problem - that they would refund my money for the spacer if it >wasnt completed. The problem is that I will need a prop no later than that..... Hey Scott: If you are thinking about sticking with the metal prop (there are definite advantages [wish they weren't RPM restricted where the Lycomings are at best power]), go ahead and get the spacer and begin installation of the engine and coweling. It is my experience that, unless you are working full time on your airplane (oh lucky dog if you are), you will have plenty of time to wait for the prop even if it isn't ready by April 97 (which it probably won't be). It sounds like you are at the 90% done 75% of the work left to do stage. My engine is completely installed except for some small tidy-up work and the rest of the airplane is 95% done and I am thinking April may be to soon to be thinking about test flying; we'll see. Michael RV-4 232SQ...should be done by....oh....Thursday, I'd say.......... mikel(at)dimensional.com ________________________________________________________________________________
Date: Nov 16, 1996
> Isn't this part in constant compression? Would not the slipstream return the > flap to neutral (very quickly) if the rod collapsed? Just wondering. That's the problem. It would return THAT flap to neutral. Not the other one. Ed Bundy ________________________________________________________________________________
>><< I can't imagine this stuff being used on wounds, because it would not >> bond long enough, and the glue itself would be a barrier to healing. >> Perhaps you heard of some different version of this stuff. >> >>Trust me, this stuff IS used in medicine as a tissue repair/wound closure >>agent and has been used, for example, by neurosurgeons to close the covering >>layer over the spinal cord after spinal surgery, way back in the early 80's >>before FDA approval was ever given....... > >Yikes. Here is a hint from someone who sews up ten or so lacerations a day >when not pounding rivets: SuperGlue is not the best thing to be cramming >into a wound. There is a type of glue that is being experimented with in >Canada to put skin together but is not here yet. I worked with another >doctor who was testing the use of superglue to seal lacerations and many >fell apart before they were properly healed. If used on a cut not properly >cleaned, infection is a big problem. "Don't try this at home." HOWEVER: >sealing the drying cracks in thumbs and fingers is effective if it is done >before the "cut" gets too deep. If you are going to use this stuff to seal wounds, just rem you don't cram it into the gash like spackle. You pinch it together and apply it over the top. This gives you a stitches like glue joint (can't think how else you'd describe it, sim to butterfly bandage) Depending on how bad it is you can keep adding stitches to the point you have a sean, ie the entire gash is closed. You can't do it in one shot you have to pinch and glue in little segments/stitches. This believe it or not has been used to seal or stitche wounds since the 60's ie the Vietnam war. ________________________________________________________________________________
Date: Nov 16, 1996
Subject: Re: RV-List Re: Lower Flap Push Rod End
>In the unlikely event that a flap rod end bearing fails or the push tube >buckles, a split flap condition may occur. snip >I think that the ailerons could overcome a >full split flap condition and that the plane would be controlable. snip >I have my Nomex >fireproof flying suit on in preparation for the flames about to come my way. > >Jim Cone >jamescone(at)aol.com Jim and all, No need for the Nomex. From my experience, and now I may need the asbestos suit, the split flaps would be overcome by aileron and rudder. And as you put it so well, put the flaps back up if they broke when you put them down. I really do have a fear of something breaking that would make the plane un-flyable. One of the BD-10s was lost because of a split flap configuration. But that is a whole different matter. I flew for 20 years with the "knowledge" that one of my original instructors gave me that "even if the trim runs away, you can always overpower it", and he proceeded to put the trim in the full down position. It was tough, but flyable. I assumed, for a long time, that this was just part of good engineering practice in aircraft design. I was wrong. So, just from looking at the moment-arm of the RV, I would have to say that a split flat configuration would be controllable. But is there anybody who has tested it, or would like to. Enquiring minds like to know. Mike Weller RV 80187 (under construction) midibu(at)hsv.mindspring.com (preferred) or mike.weller(at)msfc.nasa.gov ________________________________________________________________________________
Date: Nov 16, 1996
From: "Anne B. Hiers" <CRAIG-RV-4.@worldnet.att.net>
dimensional.com!mikel(at)matronics.com wrote: > > >Alexander Aircraft has sold out to Aircraft Spruce East. They harldly have > >anything in stock there. I think they just wanted to put Alexander out of > >business. > >rvbildr(at)juno.com > > > BINGO!!!! It's called cornering the market. I used to order as much as I > could from Alexander because I liked dealing with them and they seemed liked > the "small guy" in the market that cared if I got my 1032 nuts or not. Now, > another take-over and less competition and less service. > > Ooops...this is an opinion...sorry to take up space..... I agree, I was in aircraft spruce east last month with a big list and an empty credit card. they had nothing I needed except two bolts, and the guy there could not have cared less if I got those or not. Then last week I wanted to order some 5/8 x 5/8 .016 angle, the lady on the phone said it was $5.50 per foot, I said no way. ( over $100.00 for twenty feet ) I told her that price could not be right, she said it was and take it or leave it. I will not be back. ________________________________________________________________________________
Date: Nov 16, 1996
From: "Robert L. Nuckolls, III" <72770.552(at)CompuServe.COM>
Subject: Re: GPS
On Wed, 11 Sep 1996 joe(at)iu28.arin.k12.pa.us wrote: > Bob Nuckolls, > > We just read your excellent article in the November SPORT > AVIATION on GPS receivers. You indicate the GPS 2000 handles > speeds to over 200 knots. I was under the impression that the > boater's versions updated very slowly and weren't as accurate at > high speed. At Kitfox speeds is this of much concern? The > Lowrance Airmap sells for $900. What appears to be a similar > Eagle AccuMap Sport sells for $600. What's the difference? Mark replies: >>Not true. The boaters versions update every bit as fast as the aircraft >>versions. I'm not familiar with the AccuMap, but I have an AccuNav Sport >>($350) and though it doesn't have maps, it does have plotting and it works >>great! I also have a King KLX135A GPS/COMM and if anything, my Eagle >>updates a little bit faster. I think both have approx 1 second update >>rate. Mark <><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><><> Mark Crafts Melbourne FL mcrafts@digital.net http://digital.net/~mcrafts Very funny, Scotty. Now beam down my clothes. ________________________________________________________________________________
Date: Nov 16, 1996
> aol.com!JamesCone(at)matronics.com wrote: > > I have all of my antennas mounted in the rear of my fuselage. VOR/GS, LORAN, > TRANSPONDER, and COM. My question is, can all of the coax cables be bundled > to get up to the radios in the cockpit or should they be separated. I'm > fairly sure that the passive coax cables that come from the VOR/GS and the > LORAN can be run together but am not sure about the coax cables that transmit > a signal like the COM and TRANSPONDER. Thanks in advance for a response. > >> Roy answers: >>Coaxial cable consists of a center concudtor which carries the signal and a braided >>outer conductor (shield) which is chasis-grounded. This makes coax very resistant to >>radiating or receiving electromagnetic energy. You should not have a problem with >>"cross-talk" between your coax, especially considering the very low power levels and >>frequencies that the avionics transmits. >>Most important to a good installation is that you don't over-bend, kink, or smash the >>coax. This will change the properties of the coax by changing the characteristic >>impedence (Zo) at the damaged spot which will degrade the performance due to >>reflections, and that you ensure your coax connectors are correctly built for the same >>reason. >>Roy >>RV-8 #80096 and x-Navy avionics tech/instructor of advanced electronics. I agree and would add the following observations: A number of builders have experienced interaction between items of avioinics that transmit (com, transponder, dme) and things that receive (com, vor) and indicate (electronic instrumentation of all types). An almost STANDARD fix offered by manufacturers of instruments is to replace all antenna feedlines with double-shielded coax. In my experience, when coax cables "talk" to each other and to other systems, the problem lies with installation. My favorite connector (UG-88/U BNC and its brothers and sisters) can be VERY frustrating for first time installers. It's not uncommon for the outer conductor to be improperly captured by the clamps causing the coax to become just another piece of wire as opposed to the carefully controlled transmission line. Many people have experienced successful elimination of interaction with double-shielded coax but I suspect that the change had more to do with better installation of connectors than from change of wire. Ordinary, garden variety RG-58 coax has been used in tens of thousands of airplanes for over 50 years. When and if undesireable interaction is discovered, check the installation before jerking out the wire bundles. One very common interaction in composite airplanse happens when the (1) comm antenna is mounted too close to the panel and/or (2) installed over an inadequate ground plane. I this case, (1) DIRECT radiation of susceptable systems occurs right from the antenna -or- (2) the SWR is so high on the coax feedline that its shielding qualities are negated. Regards, Bob . . . AeroElectric Connection //// (o o) ==========oOOo=(_)=oOOo========== | | | Go ahead, make my day . . . | | Show me where I'm wrong. | ================================= 72770.552(at)compuserve.com http://www.aeroelectric.com ________________________________________________________________________________
Date: Nov 16, 1996
<< << Then again since I've never heard of this part failing in tension, perhaps Van has already overdesigned it , and the cut threads are not a concern? >> Isn't this part in constant compression? Would not the slipstream return the flap to neutral (very quickly) if the rod collapsed? Just wondering. >> Bill- Yes the failed flap would tend to fall approximately in trail, but the germaine questions are, which flap will fail first, and when? The answers are: Yes, and close to the ground. You folks do what you want. I know what I'm going to do (replace studded lower rod end with standard rod end, spacer, and capture washers and make the flap link out of 5/16" X .058" wall 4130 tube). I could be mistaken (and flame me if you like), but I believe that some of the abrupt force (which could break the flap torque tube and the links) placed on the flap mechanism may be the result of "armstrong" actuation (particularly for you guys with circumsized tubes) in lieu of a gentle linear electric actuation. Gary VanRemortel vanremog(at)aol.com ________________________________________________________________________________
Date: Nov 16, 1996
<328E786C.15CF(at)worldnet.att.net>
<worldnet.att.net!CRAIG-RV-4.@matronics.com> writes: >dimensional.com!mikel(at)matronics.com wrote: >> >> >Alexander Aircraft has sold out to Aircraft Spruce East. They >harldly have >> >anything in stock there. I think they just wanted to put Alexander >out of >> >business. >> >rvbildr(at)juno.com >> > >> BINGO!!!! It's called cornering the market. I used to order as >much as I >> could from Alexander because I liked dealing with them and they >seemed liked >> the "small guy" in the market that cared if I got my 1032 nuts or >not. Now, >> another take-over and less competition and less service. >> >> Ooops...this is an opinion...sorry to take up space..... > > >I agree, I was in aircraft spruce east last month with a big >list and an empty credit card. they had nothing I needed except >two bolts, and the guy there could not have cared less if I got >those or not. Then last week I wanted to order some 5/8 x 5/8 .016 >angle, the lady on the phone said it was $5.50 per foot, I said >no way. ( over $100.00 for twenty feet ) I told her that price could >not be right, she said it was and take it or leave it. >I will not be back. > This lady I think was mixed up as to what you wanted. In my Aircraft Spruce catalog, which is about 4 years old, they do show 5/8 x 5/8 angle, this is an extrusion with a thickness of 1/16", which is about .062. Where you were looking for .016, that leads me to believe you were not looking for extrusion material, but sheet that has been formed to an angle. The price quoted then was $5.60 per foot for the extrusion angle. Allan Pomeroy AB6A(at)juno.com About to rivet hor. stab. ________________________________________________________________________________
Date: Nov 16, 1996
Subject: NACA vent
I am considering a NACA vent for the cabin ventilation. I have a concern about getting water in the vent when flying in rain. Has anyone out there with Van's NACA scoop installed had experience flying through rain with the vent open? Does water come in the vent? A lot or a little? Please reply directly to my Email address. Thanks for the help, Dan Morris Morristec(at)aol.com RV6- completing instrument panel. ________________________________________________________________________________
Date: Nov 16, 1996
Subject: Left elevator trim tab cut
I sent this Email earlier but the addressing was wrong so I'm sending it again. I am working on an older RV-6 empennage, not pre-punched. I'm about ready to start building the left elevator. The construction manual warns about how easy it is screw up the trim tab cut. I can see how it can be a problem because the instructions in the Construction Manual are not very clear. I am referring to drawings SK6-3, 5A and a drawing supplementing SK6-3 which was included with the emp. kit. There are two dimensions for the length of cut, 19 1/2" along and parallel to the Trim Tab mounting spar and another 19 5/8" parallel to the bend line. Which dimension is correct(probably neither one)? What tools should you use for making the lengthwise cut, the crosswise cut? How do you go about cutting out the little folding tabs on the elevator? Can you make the lengthwise cut 1/16" inside the Trim Tab Mouning spar and file the elevator skin down flush with the spar? Should you cut from the inside of the skin or the outside? Are there any "gotchas" I should look out for? I would be grateful for any and all help I can get on this one. ------------------------------------- Name: duane dickson Cortez, CO E-mail: ddickson(at)sisna.com ------------------------------------- ________________________________________________________________________________
Date: Nov 16, 1996
> Yesterday, November 14, 1996, at the age of 31 and with 43.8 hours total, I received my Private Pilot License > in Denton (DTO), TX. > > And now . . . . . . . I build. > > Thank you for listening. My next post will be when I have the tail kit and have a ligitimate question. > > -- > Doug Reeves - PP-ASEL (1.1 PIC) ;^) Cool! I think your first post was legitimate! Congrats. Welcome to the family. Life's just too short not to go for the challenges that capture your imagination. Everyone on this list knows this. Scott N4ZW ________________________________________________________________________________
Date: Nov 16, 1996
Robert L. Nuckolls, III wrote: > > > aol.com!JamesCone(at)matronics.com wrote:-snip- > > My question is, can all of the coax cables be bundled > > to get up to the radios in the cockpit or should they be separated.-snip- > >> Roy answers:-snip- > >>You should not have a problem with > >>"cross-talk" between your coax, especially considering the very low power levels and > >>frequencies that the avionics transmits. > >>Roy > >>RV-8 #80096 and x-Navy avionics tech/instructor of advanced electronics.-snip- > In my experience, when coax cables "talk" to each other and to other systems, > the problem lies with installation. My favorite connector (UG-88/U BNC and > its brothers and sisters) can be VERY frustrating for first time installers. > Regards, > > Bob . . . > AeroElectric Connection-snip- I just had a thought about bundling not related to performance but rather to maintenance. Murphy's Law would probably dictate that the specific coax you want to get to for troubleshooting/maintenance would be the most difficult to reach/separate from the bundle. For what it's worth... Wish I was doin' avionics instead of banging empennage rivets... Roy RV-8 80096 ________________________________________________________________________________
Date: Nov 17, 1996
Subject: NACA vent
I have flown in everything from light drizzle to heavy downpours without any significant problems. However, parked in the same conditions, some water collected in the hoses and blew out with air flow, resulting in a slight annoyance. Les Williams lesliebwilliams(at)msn.com tail complete on 2nd -6A waiting on tip-up fastbuild ---------- From: owner-rv-list(at)matronics.com on behalf of aol.com!Morristec(at)matronics.com Sent: Saturday, November 16, 1996 8:08 PM Subject: RV-List: NACA vent I am considering a NACA vent for the cabin ventilation. I have a concern about getting water in the vent when flying in rain. Has anyone out there with Van's NACA scoop installed had experience flying through rain with the vent open? Does water come in the vent? A lot or a little? Please reply directly to my Email address. Thanks for the help, Dan Morris Morristec(at)aol.com RV6- completing instrument panel. ________________________________________________________________________________
Date: Nov 16, 1996
>Hello, > ________________________________________________________________________________
Date: Nov 16, 1996
At 4:53 PM 11/15/96, James K. Hurd wrote: >I will be skinning RV6A tail section this winter. Ambient temperature >in my hangar will be 40-50F. Is this cold enough to cause problems? >Should I use a heat gun or something? > >Please advise. Thanks. > >Jim Hurd New Mexico I wouldn't advise using a heater on the skin for the tail. There isn't enough structure to prevent twisting and warping when the skin cools down. As to heating the skin, if you do it to the wing, which does make it tighter, Van's old instructions seem to work best. Which are to use several, 3 or 4 heaters directed onto the skin and try to heat the whole sheet at once. A lot of folks try to heat a localized area and it just doesn't give the desired results. I used a couple of step ladders to support the heaters and let them heat the wing skins for 30 min or more. Make sure to wear a long sleeved sweatshirt when you do this as the alum gets really hot and touching the wings skin with your skin can be exciting. Doug Doug Bloomberg RV-6A (in the womb) Denver, CO dougb(at)mail.diac.com (home) doug(at)boulder.vni.com (work) ________________________________________________________________________________
Date: Nov 17, 1996
Subject: RV8 Landing Gear Update
Ok all you RV8 builders, Harmon Lange will be starting to make the first sets of landing gear Dec 13th. He will be working out of his old shop in WI because he doesn't have the right equip. in OR to make the flat gear. Rumour is that there still having problems with drilling the spar strips and caps! If this keeps up you guys will be able to build your fuse. before the wings! Bob RV6a Fuse. Robert/Tammie Dieck Wausau WI USA dieck(at)apexcomm.net ________________________________________________________________________________
Date: Nov 17, 1996
>dimensional.com!mikel(at)matronics.com wrote: >> >> >Alexander Aircraft has sold out to Aircraft Spruce East. They harldly have >> >anything in stock there. I think they just wanted to put Alexander out of >> >business. >> >rvbildr(at)juno.com >> > >> BINGO!!!! It's called cornering the market. I used to order as much as I >> could from Alexander because I liked dealing with them and they seemed liked >> the "small guy" in the market that cared if I got my 1032 nuts or not. Now, >> another take-over and less competition and less service. >> >> Ooops...this is an opinion...sorry to take up space..... > > >I agree, I was in aircraft spruce east last month with a big >list and an empty credit card. they had nothing I needed except >two bolts, and the guy there could not have cared less if I got >those or not. Then last week I wanted to order some 5/8 x 5/8 .016 >angle, the lady on the phone said it was $5.50 per foot, I said >no way. ( over $100.00 for twenty feet ) I told her that price could >not be right, she said it was and take it or leave it. >I will not be back. > > Every time I've tried to do business with Aircraft Spruce I've had a bad experience!!! And this includes just trying to order their catalog!! At Oshkosh a few years back I discovered Freeman Aviation. This is a small family run business (Mr or Mrs Freeman answer the phone most of the time) with a small, simple and plain catalog. They have a small product line but if you need something special they will go out of their way to get it for you. OK that handles the service part, now for the real kicker!!!! They ship a bill with the order! YOU PAY AFTER YOU GET THE PRODUCT!!! No credit cards ect and no min. order. I asked them how they can have this kind of trust, they told me that they have 1 person that their looking for. They are now the first people I call for materials! There still are some people out there that treat their customers with trust and respect. Freeman Aviation, Inc 26 Montgomery Dr Griffin Georgia 30223 404-227-2602 Bob Dieck RV6a Fuse. Robert/Tammie Dieck Wausau WI USA dieck(at)apexcomm.net ________________________________________________________________________________
Date: Nov 17, 1996
The way I see it, if you were to restrict the flaps to the up position, then actuate the flaps to fail something in the system, it would probably be the actuator arm on the cross shaft ------- no split flap condition. All in all I think the system is well designed and has protected us Dufuses quite a while. Ferdfly(at)aol.com Fred LaForge RV-4 Airframe nearly finished, no engine yet. $$$$$$$$ ________________________________________________________________________________
Date: Nov 17, 1996
Anna Freeman is the sole proprietor of Freeman Av. Her husband died at Sun-n-fun a few years ago. She is a very nice lady and tries her best to satisfy her customers. She appreciates any business you can give her. I live only a couple of miles from her and have known her for years. Mal rvbildr(at)juno.com ________________________________________________________________________________
Date: Nov 17, 1996
Subject: Re: Left elevator trim tab cut
You wrote: > >I can see how it can be a problem because the instructions in the >Construction Manual are not very clear. I am referring to drawings >SK6-3, 5A and a drawing supplementing SK6-3 which was included with >the emp. kit. > >There are two dimensions for the length of cut, 19 1/2" along and >parallel to the Trim Tab mounting spar and another 19 5/8" parallel >to the bend line. Which dimension is correct(probably neither one)? Duane, the thing you *really* want to avoid screwing up is the original cut-out of what will become the trim tab. The dimensions on the plans are correct (were on mine) but I had to study them for a *long* time to convince myself of that. This is in part due to the geometry and in part due to the fact that there will be triangular fold-overs on both the remaining elevator and later on the trim tab that will form the surfaces between the outboard edge of the trim tab and edge of the elevator cut-out adjacent to it. >What tools should you use for making the lengthwise cut, the crosswise >cut? How do you go about cutting out the little folding tabs on the >elevator? I used a Dremel tool with a very small cutoff wheel and worked *very* slowly. I think you want to be pretty careful here and work slowly. >Can you make the lengthwise cut 1/16" inside the Trim Tab Mouning spar >and file the elevator skin down flush with the spar? >Should you cut from the inside of the skin or the outside? The trim tab does not take up the whole piece that you originally cut out. There is certainly enough to file away 1/16 inch, but you don't want to get carried away because there probably isn't more than about 1/4 inch 'slack' in some areas. >Are there any "gotchas" I should look out for? I would be grateful for >any and all help I can get on this one. One 'gotcha' that I ran across was I tried to use a small bending brake for the ends of the trim tab and really screwed it up. The good news is new trim tab cutouts are really cheap from Van's. (Forget the price, but I think it was less than $10.) I ended up using a seamer to bend the tabs. The tab was wider than my seamer, but I would work one end about 20 degrees, then the other and back and forth. This put a very slight wave in the folded over end, but I used a bucking bar with a sharp right angle, held it inside the tab and tapped it lightly with a hammer. After pop riveting, they are perfectly flat. >------------------------------------- >Name: duane dickson Cortez, CO >E-mail: ddickson(at)sisna.com >------------------------------------- Hope this helps a little bit. Best regards, Bill -- Bill Costello | bcos(at)ix.netcom.com | Building RV-6 | Reserv N97WC Want an extra hour and a half of energy per day with Super Blue Green products? Email for info or call 800-325-7544 Chicago ________________________________________________________________________________
Date: Nov 17, 1996
From: catbird(at)taylortel.com (TTC Carroll A. Bird)
Robert Dieck wrote: > > >dimensional.com!mikel(at)matronics.com wrote: > >> > >> >Alexander Aircraft has sold out to Aircraft Spruce East. They harldly have > >> >anything in stock there. I think they just wanted to put Alexander out of > >> >business. > >> >rvbildr(at)juno.com > >> > > >> BINGO!!!! It's called cornering the market. I used to order as much as I > >> could from Alexander because I liked dealing with them and they seemed liked > >> the "small guy" in the market that cared if I got my 1032 nuts or not. Now, > >> another take-over and less competition and less service. > >> > >> Ooops...this is an opinion...sorry to take up space..... > > > > > >I agree, I was in aircraft spruce east last month with a big > >list and an empty credit card. they had nothing I needed except > >two bolts, and the guy there could not have cared less if I got > >those or not. Then last week I wanted to order some 5/8 x 5/8 .016 > >angle, the lady on the phone said it was $5.50 per foot, I said > >no way. ( over $100.00 for twenty feet ) I told her that price could > >not be right, she said it was and take it or leave it. > >I will not be back. > > > > > Every time I've tried to do business with Aircraft Spruce I've had a bad > experience!!! > And this includes just trying to order their catalog!! > At Oshkosh a few years back I discovered Freeman Aviation. This is a small > family run business (Mr or Mrs Freeman answer the phone most of the time) > with a small, simple and plain catalog. They have a small product line but > if you need something special they will go out of their way to get it for you. > OK that handles the service part, now for the real kicker!!!! They ship a > bill with the order! YOU PAY AFTER YOU GET THE PRODUCT!!! No credit cards > ect and no min. order. I asked them how they can have this kind of trust, > they told me that they have 1 person that their looking for. They are now > the first people I call for materials! > There still are some people out there that treat their customers with trust > and respect. > > Freeman Aviation, Inc > 26 Montgomery Dr > Griffin Georgia 30223 > 404-227-2602 > > Bob Dieck > RV6a Fuse. > > Robert/Tammie Dieck > Wausau WI USA > dieck(at)apexcomm.net Thanks for this info I have been kinda ticked off at AS&S myself. Carroll Bird catbird(at)taylortel.com ________________________________________________________________________________
Date: Nov 17, 1996
From: spjohnsn(at)ix.netcom.com (Stephen Paul Johnson)
Subject: Re: R-410 Rudder Brace
Jon wrote: > >While working on my RV-8 rudder, I had difficulty with the R-410 brace >I spoke to Tom at Van's, and told him that the part would fit better if it >were attached to the inside (top) of the R-405PD. He said that was the way it >was supposed to be... Well, he looked at the drawing 7PP on the master set >and said that this was in error, the R-410 brace was supposed to be attached >to the top of R-405PD. So, a new R-410 is on the way. This is very timely for me, as I am just about to start working on fabricating the R-410. I was hoping to get some more info from those who have finished their RV-8 empennage. I wonder what Tom said about the error in the plans. Will this be an official correction to the plans? Is either way acceptable? At this point I will fabricate everything about 1/8" oversize and see how it fits. By the way, are people drilling the 3/16" and 1/8" holes at the tips of the R-405PD, or should these be drilled later in assembly? Steve Johnson spjohnsn(at)ix.netcom.com RV-8 #80121 ________________________________________________________________________________
Date: Nov 17, 1996
Steve, Tom said it was not the first of planned revision to the RV-8 plans. Hopefully, with CAD drawings, revistion will be easy. The R-410 definately goes on the top of R-405PD. As for the 3/16 & 1/8 holes, I did not ask, but see no reason why you must drill them now. I will wait for mine to be drilled later. Timely, well, that's the idea about the RV List. Tom said that he gets a call about this about once a month, but it was mainly RV-6 callers. The RV-6 drawing shows the R-410 on the top of R-405PD, I asked Tom to look at the RV-8 master drawing, and he discovered the error. Make a cardboard template, don't put too much faith in the lines drawn on the c-channel Van's supplies with the kit. Work slowly, and you'll get it right. I will use a lightening hole as depicted on the plans so as to use regular (squeezed) rivets. Best, Jon Ross ________________________________________________________________________________
Subject: Lightning Hole
Date: Nov 17, 1996
I need to punch one or more holes in my vertical fin rib (VS407). I need to punch these holes to allow a corrosion inhibitor to flow from one rib bay to other. Has anyone enlarged the tooling holes or added additional holes. I know some where on the rib it's OK to add holes. I guess I could uses the root rib as a go by. I've been following the recent post on "HS inspection holes". Thanks +++++++++++++++++++ Greg Bordelon greg(at)brokersys.com someday.....my other plane is gonna be an RV :-} ________________________________________________________________________________
Date: Nov 17, 1996
>Anna Freeman is the sole proprietor of Freeman Av. Her husband died at >Sun-n-fun a few years ago. She is a very nice lady and tries her best to >satisfy her customers. She appreciates any business you can give her. I live >only a couple of miles from her and have known her for years. Mal >rvbildr(at)juno.com > > Sorry to hear about Mr Freeman. Guess this explains why I've been talking to Mrs Freeman the last several times I've called. I met Mr Freeman at Oshkosh aprox. 5 years ago and was impressed with the way he did business so that's when I first gave them a try. Bob Robert/Tammie Dieck Wausau WI USA dieck(at)apexcomm.net ________________________________________________________________________________
Date: Nov 17, 1996
Subject: UMA tach
Well, here is the end of the UMA tach story. My advise is: If your are using Slick or Bendix mags, DO NOT buy a UMA part # 19-506-11G. This is the 2.25 electric tach that Van's sells. It won't work. Bill Benedict took this bull by the horns for me and tried one of their off the shelf tachs on one of the factory airplanes. He was only able to get it to read to 1000RPM before it went beserk. I was able to get mine up to about 2200. Other listers have had similar problems. UMA *STILL* insists that they have never heard of this problem and it must be due to the installation. They want me to send it back and wait for them to take a look at it. Not too likely. Well, Bill was very accomadating and agreed to send me an E.I. digital tach instead and told me to send the UMA back at my convenience. I have to pay the difference of course, but he already credited the amount from the UMA even though I won't be sending it back for a week or so. Very impressive. Hopefully, N427EM will see air under the tires this week! Ed Bundy ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Re: Horz Stab jig question
>On page 6-5, RV-6 manual is states that you should locate and mark the >positions for the brackets that will support the HS-603PP (rear spar). It >refers to figure 6-5 for distances. I have been unable to find a figure or >diagram, with the exception of the original drawing on 3PP that is useful, >and no figure 6-5. I don't have my plans here, but I do recall reading the distances somewhere (maybe in Frank Justice's building notes?) However, it doesn't matter much... as someone else suggested, just use the spar to find the right places to put the brackets. Face some one way, and some the other so that that spar can't move laterally. Note that the centre brackets need larger holes than the outer brackets. I spent a lot of time getting the brackets (I bought them from Avery's) lined up exactly straight. Without any evidence for or against, I think this time was probably well spent (as opposed to some of my other over-enthusiastic lining-up and exactly-vertical efforts). >Does it matter as long as the spar is stable and supported?? The book also >says use 3/16" bolts. Where do you get these? Home depot doesn't have them. Unbelievable! I can't imagine a hardware store without 3/16" bolts. Maybe look for 3/16" machine screws (a machine screw is like a bolt with a round slotted head, or a bolt is like a machine screw with a hex head) instead. > Once I can find 3/16" bolts, should the bolts be tightened down, ie I don't >want to bend the hinges, I think the idea is support and stability. Yes. >If you use the AN3-7A or 14A bolts that came with the HS, would you be afraid >of damaging the threads? I don't know. That was why I used the hardware store screws. >Can you use the stop nuts? Can these stop nuts be >used over and over without damaging? Dunno. I bought hardware store nuts and washers too. >Last question. The 1/4" bolts that help stabilize the HS in the jig and >attached to the tip ribs ...... looks like oerndorf (sp?) drilled his >straight out of the 4x4, ie didn't use either method the manual suggests?? This doesn't matter too much. You want to support the tip rib so that its centreline is exactly vertical. How you attach the threaded rod to the jig isn't critical. I have T-shaped brackets, with the threaded rod extending from the base of the T. The cross-bar of the T is screwed to the upright of the jig. I found I needed to bend the threaded rod round a bit to get it in exactly the right place. Frank. Marton, NZ. RV-6, VS skeleton in the jig. -- -------------------------------------------------------------------- frankv(at)pec.co.nz | "Knowledge=Power=Energy=Matter=Mass; Frank van der Hulst | A good bookshop is just a genteel Software Engineer | Black Hole that knows how to read". PEC(NZ) Ltd (Cardax), Marton | Terry Pratchett, "Guards! Guards!" http://www.pec.co.nz/~frankv/ | -------------------------------------------------------------------- ________________________________________________________________________________
Date: Nov 17, 1996
Subject: Epoxy in the F607BLKHD, skin overlap joint?
For what is is worth. I'm a big advocate of back drilling and riveting. You could back drill a fuselage skeleton prior to exterior skin fitting. And have great straight lines, optimim placing and perfect flange center lines to rivet placement. Also you might just build much quicker than the fit, trace, drill skin and re-fit and re-drill methods. Also You could forget that 3" rivet spacing along the longeron/side skin (all skins to longerons), only to later come back and drill every 1inch, supposedly avoiding these previously placed rivets (you'd better be a good shot here!) and do what I did.... That was to drill each one inch hole in to longerons. Machine C/S the longeron, and dimple all skins after "easily back drilling/transfering" all these holes into outer skins. Flip it out of your fuselage jig with all holes held with a cleco. Then later, where the longerons overlap into the "upper turtle deck skin(s)", they will also dimpled. I have used a drop of super glue in many areas to temporaily hold pieces in place to drill. If required, it usually breaks apart easily. After primering, full fitting, back drilling, deburring, skin over lapping/mini flange turning down, dimpling (in that order), and refitting of the F675 top (rear most) aft skin to the Bulkheads: F609, F608, F607, J stiringers and longerons. I reinstalled it for the final time with a tiny thread of some PC7 2 part epoxy, it was used sparingly only at/to fit and hold the F675 top skin to the F607BLKHD. I 3/32nd clecoed and clecoe clamped it 100%, and squeezed gingerly with pliars. After curring I then back riveted it all on permantly, but did not rivet same epoxied joint yet. I then fitted and back drilled the entire F674 upper, aft turtle deck skin. What the epoxy did was to hold the F607BLKHD, F674 skin sturdily, to allow back drilling. Rather than leaving this joint to be drilled all 3 skins at once. I only had to fit the F675 skin on once, with the extra 1" trimmed front canopy part trimmed, but no @ 2 3/16" trim on rear end as per plans done until after back drilling. Ready with nomex underware re: 1) friends don't....fly plastic in alum a/c.... 2) corrosoin in epoxied joint, gap potential in same joint listed above.... 3) weaking longerons with @ .030" deeper countersinkas described above.... 4) Not germain topics.... 5) primer .....eeek I used the word.....(BTW I 100% primed right out of the crate prior to 1st cut, without removing and red ink markings, merits&dis-advantages of same). 6) to cold in un-insulated garage, & to tired today, to build, thus 3 rags on list today. ------------------------------------ Name: David McManmon Cicero, NY E-mail: McManD(at)AOL.com Project status: RV6, tip up, 0320H2AD, F/P. on the right side up fuselage, floors, 5th point seat belt hookup, and rear aft top of canopy skin cover ready for dimpling and installation. ------------------------------------- ________________________________________________________________________________
Date: Nov 17, 1996
Subject: 5th point seat belt hookup point + Super Glue?
Some time ago I asked for 5th point hook up information. Reply was it was in the comming RVator issue........ so I waited......... and waited.... finally..... only to get a non descrip-picture of a 6 point hookup. From that I hardly can tell which way is up, say nothing of a plan to follow. Any other interest out there for my 5th point hook up plans? If so can we compare notes, what did you do, are you planning to do? Generally, was it @ 15" forward from the F605, rear spar bulkhead? E-mail direct if you like. BTW... my method invloved super glue!!!!!!! I'll post another builder tip, utilizing epoxies for I too am into adhesives, work and play. AS NOTED IN PREVIOUS THREADS.....YES WATCH OUT FOR "BLOOMING"... This is the drying MA, "super glue's" vapors that sink heavier than air, slow to disapate, that raised the "Latent finger" prints that the Police labs use. It also is a major rejection from many of my companies plastic assemblies rejects. Do indeed watch out around your canopy, if you do use, just be sure to use a fan (X-plo proof primer fan not required, sic) to move air over the surface and vent out throughly! Thanks in advance. (yes... to cold in the garage today) ------------------------------------------------------------------------------ ------------------------------------------ Name: David McManmon, Cicero NY E-mail: McManD(at)AOL.com Project status: RV6, tip up, 0320H2AD, F/P. on the right side up fuselage, floors, 5th point seat belt hookup, and rear aft top of canopy skin cover ready for dimpling and installation. ------------------------------------------------------------------------------ ------------------------------------------ ________________________________________________________________________________
Date: Nov 17, 1996
Subject: Re: L/elev trim cut+tools+1997 RV forum
<< am working on an older RV-6 empennage, not pre-punched. >>I Older, mine was too..... I gave a seminar on my completed tail at 2nd annual RV forum in Oswego NY, Sept 1996. EAA chapter 486, (3 RV's flying out here, and over 6 more in CNY area under construction) in which I'm a member, and there is a 3rd planned for the 2nd weekend in September 1997. Mark your calanders now!!! I'm told that Van's factory is planning representation there some way!!! << What tools should you use for making the lengthwise cut, the crosswise cut?>> <> I used a air powered cutoff grinder and 3" disc for cutting inboard from trailing edge forward. Lenght wise cut, ....I found from Harbor Freight (7/94, P/N 00539 for $7.99) and swear I use this cutter all the time!!! If you can find this one I highly recommend. I have a "blue handle" nibbler. It is not the same as the knotcher/nibbler! It has a cut which cuts directly up and removes @ a .125" kerf, vith minimal edge distortion of both sides of your cut. Thus saving both pieces. Then the Vixen file (now @ $1.5k, Avery tool purchaser, and swaer there great!!!) will flatten/flush off edges to make it brake shear quality! BTW: Harbor freight, 9/95 at $6.99, P/N 07356, for a swing straight or 90* adjustable pull head, Pop riveter (with 30, throw them away!!!) rivets in a case..........has already had @ 50 cherry max rivets thru it. no sign of breakage.....I understand many will not hold up to these...for $7 bucks it was worth it. << How do you go about cutting out the little folding tabs on the elevator?>> As above, be sure to drill end/corners prior to bending to avoid cracking. I used a hand seamer to bend up and the wood "V" cuts removed from Van's particle board jig supplied with kit, with cautiously/minor light tapping, via rubber dead blow hammer forming. << Can you make the lengthwise cut 1/16" inside the Trim Tab Mouning spar and file the elevator. I believe I understand this question. The skins are all longer than need be, and your trimming of the trim tab skin as above will leave you plenty of left over material to build it to plans. Consider making a light card board pattern first. I did cut long and Vixen file into proper shape. << Are there any "gotchas" I should look out for? Keep in mind the continuation of the trailing edge line and the gap parallelism as you bend these flanges into shape. Well if you can not make the turned over flanged ends, do not give up yet and order that new skin. Trim off the wrap over flanges and make 2 little end ribs. Many of the tabs have these little tab ribs, and also the LH elevator inboard, bend over flange, gets screwed up and replaced with a small rib, salvaging this area. Prior to fitting on piano hinge, have all bends and shaping done, with the trailing edge to long, then cut/file into proper trailiing edge allignment. Also look in back issues of RVator for doubler reinforcement aththe trim tab horn area, Enginering Change Order from factory. Good luck ------------------------------------- Name: David McManmon Cicero, NY E-mail: McManD(at)AOL.com Project status: RV6, tip up, 0320H2AD, F/P. on the right side up fuselage, floors, 5th point seat belt hookup, and rear aft top of canopy skin cover ready for dimpling and installation. ------------------------------------- ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Re: Matronics Web Page Update!
> >I can't imagine this stuff being used on wounds, because it would not >bond long enough, and the glue itself would be a barrier to healing. >PatK - RV-6A > Hmmm... This is off track but cyano-acrylate esters are widely used in surgery most commonly in orthopaedics to cement new joints in place Leo Davies ________________________________________________________________________________
Date: Nov 17, 1996
Subject: Constant Speed Prop
I'm thinking about shopping for a used C/S prop for my 6A. What information about a prop is necessary in order to match a C/S to my 0360 A1A from Vans. -- Chet Razer crazer(at)egyptian.net ________________________________________________________________________________
Date: Nov 17, 1996
Subject: Re: GPS and appology
> Bob Nuckolls, > > We just read your excellent article in the November SPORT > AVIATION on GPS receivers. You indicate the GPS 2000 handles > speeds to over 200 knots. I was under the impression that the > boater's versions updated very slowly and weren't as accurate at > high speed. At Kitfox speeds is this of much concern? The > Lowrance Airmap sells for $900. What appears to be a similar > Eagle AccuMap Sport sells for $600. What's the difference? Mark replies: >>Not true. The boaters versions update every bit as fast as the aircraft >>versions. I'm not familiar with the AccuMap, but I have an AccuNav Sport >>($350) and though it doesn't have maps, it does have plotting and it works >>great! I also have a King KLX135A GPS/COMM and if anything, my Eagle >>updates a little bit faster. I think both have approx 1 second update >>rate. Mark Sorry about the "double post" on this item folks . . . I'd prepared a file for appending my comments and then sent it without finishing the job . . . a problem with working until 1 a.m.!!! I've had a lot of e-mail, snail mail and phone traffice about the article. I notice that many folk believe I'm recommending the GPS2000 as THE receiver to buy . . quite the contrary. The intent of the article was to open doors to all commers with low-end GPS products . . the GPS2000 just happend to be the first one I found and tried. Early entries to the low-end GPS product line had some limitations for displayed speed (only two digits in the display) or software limitations that ASSUMED that nobody moving over 99 Kts would be interested in their product. This technology and the commercial offerings are maturing VERY rapidly. My suggestion is to check with your local marine and outdoor recreational product suppliers. Pick ANY GPS product that looks like it might be useful in your airplane and then buy it with the proviso that you can return it for full refund if it doesn't work for you. If you're still building an airplane, forget the GPS shopping until you've been liberated from your limited flight test area and then go shoping. From the time I wrote the article until now, the GPS 2000 street price has droped $40. When you do try out a cheapie, don't expect TOO much. Yes, it may drop out for a minute or two after you execute a 90 degree turn pulling 2g's. It might fuss about the number of satilites it can see if you don't figure out a way to hold it up behind the windshield, etc. etc. The point is that for a pitance in cash, you can probably put a piece of hardware in you flight bag that will provide navigation ability heretofore unheard of at 10 times the price. If anyone finds something OTHER than the GPS2000 to be a useful cockpit accessory, post it here and please let me know about it too. This is where the "lists" can provide and exemplar service . . . spreading the word on what works and what doesn't work. Regards, Bob . . . AeroElectric Connection //// (o o) ==========oOOo=(_)=oOOo========== | | | Go ahead, make my day . . . | | Show me where I'm wrong. | ================================= 72770.552(at)compuserve.com http://www.aeroelectric.com ________________________________________________________________________________
Date: Nov 17, 1996
Subject: NACA vent & water problems
>I have flown in everything from light drizzle to heavy downpours without any >significant problems. However, parked in the same conditions, some >water collected in the hoses and blew out with air flow, resulting in a >slight annoyance. >Les Williams lesliebwilliams(at)msn.com tail complete on 2nd -6A I haven't flown through anything but very light rain and had no problems. To solve the water collection problem while parked, I cover the NACA inlet with some of that "static stick on" sun shade when I park the RV outside. A strip of this same material will work well for sealing gaps in the canopy and as a cover over the fuel caps. Bob Skinner RV-6 BSkinner(at)krvn.com ________________________________________________________________________________
Date: Nov 18, 1996
From: notes.UB.com!Mailer-Daemon(at)matronics.com (by way of Frank van der Hulst <notes.UB.com!Mailer-Daemon(at)matronics.com>)
>On page 6-5, RV-6 manual is states that you should locate and mark the >positions for the brackets that will support the HS-603PP (rear spar). It >refers to figure 6-5 for distances. I have been unable to find a figure or >diagram, with the exception of the original drawing on 3PP that is useful, >and no figure 6-5. I don't have my plans here, but I do recall reading the distances somewhere (maybe in Frank Justice's building notes?) However, it doesn't matter much... as someone else suggested, just use the spar to find the right places to put the brackets. Face some one way, and some the other so that that spar can't move laterally. Note that the centre brackets need larger holes than the outer brackets. I spent a lot of time getting the brackets (I bought them from Avery's) lined up exactly straight. Without any evidence for or against, I think this time was probably well spent (as opposed to some of my other over-enthusiastic lining-up and exactly-vertical efforts). >Does it matter as long as the spar is stable and supported?? The book also >says use 3/16" bolts. Where do you get these? Home depot doesn't have them. Unbelievable! I can't imagine a hardware store without 3/16" bolts. Maybe look for 3/16" machine screws (a machine screw is like a bolt with a round slotted head, or a bolt is like a machine screw with a hex head) instead. > Once I can find 3/16" bolts, should the bolts be tightened down, ie I don't >want to bend the hinges, I think the idea is support and stability. Yes. >If you use the AN3-7A or 14A bolts that came with the HS, would you be afraid >of damaging the threads? I don't know. That was why I used the hardware store screws. >Can you use the stop nuts? Can these stop nuts be >used over and over without damaging? Dunno. I bought hardware store nuts and washers too. >Last question. The 1/4" bolts that help stabilize the HS in the jig and >attached to the tip ribs ...... looks like oerndorf (sp?) drilled his >straight out of the 4x4, ie didn't use either method the manual suggests?? This doesn't matter too much. You want to support the tip rib so that its centreline is exactly vertical. How you attach the threaded rod to the jig isn't critical. I have T-shaped brackets, with the threaded rod extending from the base of the T. The cross-bar of the T is screwed to the upright of the jig. I found I needed to bend the threaded rod round a bit to get it in exactly the right place. Frank. Marton, NZ. RV-6, VS skeleton in the jig. ________________________________________________________________________________
Date: Nov 17, 1996
MiDiBu wrote: > > >In the unlikely event that a flap rod end bearing fails or the push tube > >buckles, a split flap condition may occur. > snip > >I think that the ailerons could overcome a > >full split flap condition and that the plane would be controlable. > snip > >I have my Nomex > >fireproof flying suit on in preparation for the flames about to come my way. > > > >Jim Cone > >jamescone(at)aol.com > > Jim and all, > > No need for the Nomex. From my experience, and now I may need the asbestos > suit, the split flaps would be overcome by aileron and rudder. And as you > put it so well, put the flaps back up if they broke when you put them down. > > I really do have a fear of something breaking that would make the plane > un-flyable. One of the BD-10s was lost because of a split flap > configuration. But that is a whole different matter. I flew for 20 years > with the "knowledge" that one of my original instructors gave me that "even > if the trim runs away, you can always overpower it", and he proceeded to put > the trim in the full down position. It was tough, but flyable. I assumed, > for a long time, that this was just part of good engineering practice in > aircraft design. I was wrong. > > So, just from looking at the moment-arm of the RV, I would have to say that > a split flat configuration would be controllable. > > But is there anybody who has tested it, or would like to. > > Enquiring minds like to know. > > Mike Weller RV 80187 (under construction) > midibu(at)hsv.mindspring.com (preferred) or mike.weller(at)msfc.nasa.gov Maybe one of you lucky guys who has a flying RV could just unhook one of the flaps and go up high and find out what happens when the "good" one is dropped at approach speed and power. Bob Reiff, RV4 #2646 (still in my basement) ________________________________________________________________________________
Date: Nov 17, 1996
Steve, hi I noticed the same thing, and installed it on the inside (top). There wasn't any other way it could go if made like the plans. It's a good idea to sneak up on the final size. You can always take more off, but it's really hard super- glueing all those little chips back on. I went ahead and drilled the holes, but watch your edge distance! Phil #80005 arter(at)ncar.ucar.edu >Jon wrote: >> >>While working on my RV-8 rudder, I had difficulty with the R-410 brace > >>I spoke to Tom at Van's, and told him that the part would fit better >if it >>were attached to the inside (top) of the R-405PD. He said that was the >way it >>was supposed to be... Well, he looked at the drawing 7PP on the master >set >>and said that this was in error, the R-410 brace was supposed to be >attached >>to the top of R-405PD. So, a new R-410 is on the way. > >This is very timely for me, as I am just about to start working on >fabricating the R-410. I was hoping to get some more info from those >who have finished their RV-8 empennage. I wonder what Tom said about >the error in the plans. Will this be an official correction to the >plans? Is either way acceptable? > >At this point I will fabricate everything about 1/8" oversize and see >how it fits. By the way, are people drilling the 3/16" and 1/8" holes >at the tips of the R-405PD, or should these be drilled later in >assembly? > >Steve Johnson >spjohnsn(at)ix.netcom.com >RV-8 #80121 > > ________________________________________________________________________________
Date: Nov 17, 1996
Subject: Re: Aircraft Spruce(good chatter)
I called Aircraft Spruce last Monday, talked to a very nice, but busy man.. He took my order of over 25 different types of fittings, tubes, clamps, drills. At each one he knew it was in stock off the computer, one part was special order, which I expected. He gave me the total cost, I gave him my credit card number, and he said shipping would be that day, (it was about 8:00 A.M.) All the parts arrived two days later via UPS, all were what I ordered (not necessarily what I wanted, but anyone who has put on an motor understands that). The special order part arrived Friday. The price was a few bucks higher than Vans, but the same as Skybolt. The service was just what I would expect. That order was no different than the 50 or more I have given to them over the last two airplanes. As a matter of fact, their service has gotten much faster since the first order in about 1980. Try and buy something from a big Aircraft supplies who would rather deal with Boing. Sorry, but I hate to hear someone slamming a outfit that has been excellent to me over the years. Bruce Patton San Luis Obispo, Ca Hanging motor ________________________________________________________________________________
Date: Nov 17, 1996
Subject: Re: Constant Speed Prop
Chet, hi You need something like an HC-C2YK/7666-2, a Mooney prop. But good luck finding a used one. If you do, and they have an extra one, let me know immediately. I am resigned to buying a new one. Phil #80005 O-360, CS arter(at)ncar.ucar.edu >I'm thinking about shopping for a used C/S prop for my 6A. What >information about a prop is necessary in order to match a C/S to my 0360 >A1A from Vans. >-- >Chet Razer >crazer(at)egyptian.net > > > ________________________________________________________________________________
Date: Nov 17, 1996
Duane: >There are two dimensions for the length of cut, 19 1/2" along and parallel >to the Trim Tab > >mounting spar and another 19 5/8" parallel to the bend line. >Which dimension is correct? They both are correct because they are measurments to different points. The 19-5/8 is the measurement along the bend line. Really, that is the important one. If you are going to forego the little folding tabs and instead make a little rib to put there, then you would not use the 19-1/2 measurment at all. >What tools should you use for making the lengthwise cut, the crosswise cut? I used a pair of Malco shears. They do not have serrated jaws. >How do you go about cutting out the little folding tabs on the elevator? I made little ribs instead. >Can you make the lengthwise cut 1/16" inside the Trim Tab Mouning spar and >file the elevator skin down flush with the spar? Sure. Nothing about this process requires a high level of precision. >Should you cut from the inside of the skin or the outside? I did it from the inside because SK6-3 is of the inside, and I drew my cutting lines on the inside. >Are there any "gotchas" I should look out for? There are two: 1. Trimming the inboard end of the elevator skin (taking out the triangle of material who's apex is 3-15/16 inch from the inboard end of the bend line) BEFORE cutting out the trim tab. This causes you to spend $6 and a few days while you order a new trim tab skin from Van's. 2. Failing to mark the inbaord end of the elevator for trimming prior to cutting out the trim tab. Basically, you have to draw the triangle mentioned in #1 above, then ignore it and cut out the trim tab. THEN trim off what's left of the triangle. >I would be grateful for any and all help I can get on this one. I found it extremely helpful to mock up the trim tab out of posterboard, particularly since I was closing the ends of the trim tab with little ribs instead of trying to do it with fold-over tabs. When I had a mock-up that fit, it was a simple matter to fabricate the real one. Best Regards, Dave Barnhart barnhart(at)a.crl.com rv-6 sn 23744 Trimming the canopy ________________________________________________________________________________
Date: Nov 17, 1996
> Also look in back issues of RVator for doubler reinforcement aththe trim >tab horn area, Enginering Change Order from factory. > > Good luck > > ------------------------------------- >Name: David McManmon Cicero, NY >E-mail: McManD(at)AOL.com Could you share some source for this? It's the first time I've heard of it. John Darby RV6 N61764 flying Stephenville TX johnd@our-town.com ________________________________________________________________________________
Date: Nov 17, 1996
Subject: Prop/spinner clearance
The construction manual recomends leaving 1/16-1/8" clearance between the spinner and the prop. I obviously want the gap as small as practical, but is 1/16" sufficient? It seems awfully close. I imagine the prop doesn't flex much (at all?) at the hub, but I thought I'd get some opinions. Can the spinner flex toward the prop? I'm using a Sensenich fixed-pitch metal prop. Ed Bundy ebundy2620(at)aol.com ________________________________________________________________________________
Date: Nov 17, 1996
> The price was a few bucks higher than Vans, but the same as Skybolt. The > service was just what I would expect. > > That order was no different than the 50 or more I have given to them over > the > last two airplanes. I too, feel that ACS does a very good job considering the volume of merchandise they ship. BTW, if you find a better price somewhere else, tell them and they will at least meet, and usually beat it. Ed Bundy ebundy2620(at)aol.com ________________________________________________________________________________
Date: Nov 17, 1996
Subject: Re: L/elev trim tab horn ECO
In a messages dated 96-11-17, we write: Also look in back issues of RVator for doubler reinforcement at the trim >tab horn area, Enginering Change Order from factory. from: >Name: David McManmon Cicero, NY >E-mail: McManD(at)AOL.com Could you share some source for this? It's the first time I've heard of it. from: John Darby RV6 N61764 flying Stephenville TX johnd@our-town.com Well you made me go in that dark and now much colder garage................ But of course to aid a felow RV'r ........................ Taken from June 1995 RVator, so here goes: "a number of RV4 and RV6's have experienced cracking of the skin adjacent to the actuator bracket at the root end of the trim tab.......caused by a lack of continuity between the end web of the trim tab and its spar. Since the accuator bracket is riveted to the end web and the hinge is riveted to the spar, a twisting can occur which can eventually crack the skin." "Install a doubler plate to tie the end web and spar together." In continuing, what the ECO basically says, in my wording, for there is a sketch which shows most of this, is you: Use a 4" strip of 2024-T3 either .032" or .040" . It's width is same as trim tab spar. Bend in center, to make a 2"X2" angle. Taper down one 2" end to equal that of the pie shaped, folded over flange, trim tab web end. Flyers, remove trim tab horn (accuator bracket) via drilling out rivets. Sandwich the doubler under trim tab horn between folder flange, transfer holes and pop rivet on. Also pop rivet other 2" strip to front face of trim tab spar. Sketck uses @ 12, MD-42-BS pop rivets. On new installation just place in position and drill durring final tab assembly. Flyers, "stop drill" any cracking on skins as spotted. Enjoy!! from: Wish it said flying by my name...................... >Name: David McManmon RV6, fuselage up right, Cicero, NY >E-mail: McManD(at)AOL.com ________________________________________________________________________________
Date: Nov 18, 1996
Hey Bob, I, too, read and enjoyed your "Nailgun" article. I don't think you meant to imply that the speed limitation on the Mag2000 is 200 anything...it is actually according to the specs: "Max velocity: 951 mph, 827 knots" The "entry-level" Garmins do have the 103 mph speed limits although they are also excellent "machines" for many of the same reasons you like the Mag2000. Sorry you didn't stop by our booth at Oshkosh. We sold many of the units there and at Sun 'n' Fun and continue to sell them by mail order all over the world! Keep up the good work! Kate at SkySports (1 800 AIR STUFF)(800 247 7883) -- Friends don't let friends fly plastic airplanes. Van's Air Force - Michigan Wing - http://members.tripod.com/~6Alady/rvmi.html Greater Flint Pilots'Association - http://iavbbs.com/jgh/gfpa.htm ________________________________________________________________________________
Date: Nov 18, 1996
> Could you share some source for this? It's the first time I've heard of it. > John Darby RV6 N61764 flying > Stephenville TX > johnd@our-town.com It is in the June '95 RVAitor, page 14 Carroll Bird Buffalo Gap TX RV-4 #3919 ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Re: primer, sorry but I can't help it...
Mike , I used Vari Prime on all the parts of my airplane before they go together, seems to work good....George Orndorff ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Wood Propellers / New Sensenich Metal Propeller for 180 HP
-Reply Ed Sterba is reputable person. I have heard that many people of very pleased with his props. I pesonally know of at least two flying on RV's. >>> Scott Johnson 11/15/96 06:09pm >>> 1.) Has anybody heard any comments good or bad on ED STERBA wood propellers. He charges $500 for a 5 lamination wood prop for a 180 HP Lycoming. Also 2.) I called SENSENICH and they said they are seriously working on their 180 HP metal propeller. In two weeks, they will be offering the spacers for their new prop for those who wish to continue working on their cowling finish work. I asked them if they would have it ready to go by APRIL 97 and they said no problem - that they would refund my money for the spacer if it wasnt completed. The problem is that I will need a prop no later than that and I am afraid if they slip I will be without a prop and not able to fly my plane. I have been informed that it took them 18 months last time to build a metal prop for the 160 HP. Does anybody know more than this, or have any advice ? Scott Johnson / Chicago Project Status: Working on finishing kit, brand new 180HP on its way from VANS ! ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Re: RV-List Re: Lower Flap Push Rod End
<< Maybe one of you lucky guys who has a flying RV could just unhook one of the flaps and go up high and find out what happens when the "good" one is dropped at approach speed and power. >> Seems the MANUFACTURER would have already done this. Well, fellas? In talking with Paul McReynolds, he told of a time when he flew a friends -4 w/ elec flaps, and accidentally dropped them all the way @ 160 indicated. They stayed on, no damage. The flap system appears to be as overbuilt as the rest of the bird. Now, quit worrying, and get back to work. Check six! Mark ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Crankshafts in the RV-6A Vortec Conversion
Many of the nay-sayers on automobile engine conversions got me wound up this week about crankshafts as you all know. I talked to everyone I could get my hands on about the relative merits of the cast nodular iron crank vs. a forged crank. My final conversation at the Tree House yesterday was with an engineer who owns an engine rebuild shop. He also owns a Commanche and a Cessna 310. He=92s been helping us off and on for= a year with welding and he painted our RV-6a. He sees about 8 to 10 engines each week for rebuilds and he warrants all his rebuilds for 100,000 miles. He=92s been running his shop for about 20 years. So, a simple calculation shows that he=92s seen about 4000-5000 blown engines a= year for 20 years, or about 100,000 engines. He told me that he is just now starting to get the Vortec in for rebuilds. Over the past year or so he=92s seen about 30 of them. I asked him how they failed. He sort o= f got a goofy look on his face and started unloading about how abusive the general public is on engines. Evidently he gets engines that have gone 80 to 100 thousand miles without even one oil change. Virtually all of his engines were destroyed by overheating , lack of lubricant or just plain worn down dirty lubricant. He went on to tell me that he=92s never= seen a broken crank on a Vortec although he=92s seen many on the GM-350. = He said that the crank failures on the 350 usually resulted from extremely over tightened accessory belts. He laughed when I expressed concern over the cast-iron crank in our Vortec. His major comment was that GM built these engines for the public and for extreme abuse. = People start them and floor them while they=92re still cold. These are i= n vans that are driven by people who have no concept of what an engine is or how to maintain it and he still never sees broken cranks or thrown rods. Also, the journals on the Vortec have a larger diameter than the 350. This relates to more overlap between journals than the 350 has. If you look at the rods for both engines you can see it with plain vision when examining the rod-bearing. He went on to talk about the nodular iron casting by saying that the nodular metal will withstand local damage and over stressing perturbations without transmitting those to the surrounding lattice. My understanding of what he said was that forged metal is more crystalline in nature and a local over-strain of the material will be more likely to result in transmitting that down the lattice. = Next, he got off on the abusive public again talking about how his business tripled when full-service gas stations were abandoned. I guess people just don=92t check their oil or coolant. They just go fill-er-up and never look under the hood. So, GM has to design engines for people like that, and they still go 100,000 miles or more. I asked him if he would worry about flying behind the Vortec, and of course he laughed again and said, "That engine was built to take a lot more than you old farts will ever put to it. It had to be built for the stupid general public. I=92ve never seen broken parts on that engine and they=92ve been= out for over 10 years. It=92s such a good design it just hasn=92t been breaking. All of our rebuilds are due to over heating or running out of oil. If you look at the lubrication system it=92s excellent. I think G= M has the best lubrication engineers of all the big manufacturers. Plus they use the 350 pump.", and then he asked me to take him for a ride. = So, there you have one guy=92s opinion who sees thousands blown engines. I asked him about the Ford engine too and he told me the bottom end of the 3.8L is just a bullet-proof. I guess he has seen some rebuilds due to the aluminum heads warping from overheating, (if I caught that right). But, again it was due to abuse, not structural failure during routine operation coupled with good maintenance. My bottom line as one of the test pilots is that I=92m not going to worr= y about the crank or the rods. Today, I=92m actually more worried about th= e weather. Bill Phillips =46rom the Tree House at the OMABP ________________________________________________________________________________
Date: Nov 18, 1996
>What tools should you use for making the lengthwise cut, the crosswise cut? >How do you go about cutting out the little folding tabs on the elevator? >------------------------------------- >Name: duane dickson Cortez, CO >E-mail: ddickson(at)sisna.com >------------------------------------- Duane, I cant remember specifics about dimensions so I wont address that part of your question. I used a Dremel tool with a small abrasive cutoff wheel to seperate the trim tab from the elevator. This worked very well as it removes a minimal amount of material, gives a clean cut(if you have a steady hand), and doesnt leave you with a curled edge like snips can. I placed a piece of duct tape along the cut line and used it as a guide. Make sure you follow the instructions as far as sequence of the cuts. This part is not as hard to make as the instructions lead you to believe. Mine came out beautiful. Just take your time. BTW I have found that for small cuts on thin aluminum nothing beats a sharp pair of sewing scissors. Just dont get caught by the wife while using them. Mike Wills RV-4 (wings) willsm(at)manta.nosc.mil ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Fuel tank brackets, flap push rods, and capture washers
Structural changes to aircraft designed by someone other than yourself = should be approached cautiously. A change, no matter how simple, can have = unforeseen effects and consequences. Before you decide to replace any = structural element you should calculate the loads on the part in question = and determine that the part to be replaced is in fact inadequate. Capture washers. Note that for all the rod end bearings in the other = flight controls Van uses some method to provide capture of the rod end = should the bearing fail. Was the failure to use them on the flaps a = oversight on Van*s part? I don*t think so. I think Van had his reasons and = unless you know what those were or have analyzed the flap system yourself = you may well end up with a part or system that is not as safe or reliable = as the original design. Consider this, the Aurora CM-4MS is designed, = tested, and manufactured for an installation that places the bearing stud = in a bending mode. Aurora publishes the allowable loads that may be placed = on their bearings which Van probably used when he selected this bearing. = If you change to *standard* bearing and AN bolt with a standoff and = capture washers you are placing the AN bolt in a bending mode (the bolt = would be cantilevered off the flap). Most design manuals indicate AN bolts = are intended for shear or axial loads (tension and compression) and advise = against any application that will place the bolt in a bending mode. AN = bolts are a relative high strength steel which does not perform well under = bending loads. Should you use a bearing that has been designed and tested = for the loading conditions or a *standard* bearing with a AN bolt used in = a manner design manuals do not allow? Have you made the design safer by = capturing a failed bearing or is there a greater chance of the AN bolt = failing causing asymmetric flap deployment? Also consider the additional = material that must be removed from the fuselage bottom and sides to allow = clearance for the capture washers. How large can this hole be without = compromising the strength of the fuselage in this area? I*ll stick with = Van*s design. Flap push rods. Also consider that under flight loads these tubes are in = compression, failure would drive the threaded shaft of the rod end bearing = into the tubes not pull them out. But before the bearing shaft is driven = into the tube not only must the aluminum threads fail but the threads on = the steel locking nut must fail also. (See Carroll Bird=27s posting) Here = again I*ll change mine only if reliable calculations indicate the tube is = inadequate.=20 The same goes for the fuel tank brackets. Unless someone is willing to do = a thorough design analysis of the fuel tank system and develop a markedly = better design from that analysis I*ll stick with Van. =20 Note I indicated these individual components are parts of systems. When a = part is altered the designer must account for the effect that change has = on the overall system. There was a very good article in one of the sport = aviation magazines regarding making structural changes a while back. I = subscribe to several and I don*t remember which magazine or date. The gist = of the article was don*t make structural changes unless you absolutely = know what you are doing. By strengthening one area you are altering the = way loads are being distributed and you may end up with one part being = stronger but the overall structure may be weaker.=20 Before I get severally flamed these are experimental aircraft and you may = build them as you see fit. Van is a very capable engineer but not = infallible, change to the plans and kits over the years bear this out = which means there is still room for improvement in the RVs. I also know = there will be no progress unless we keep developing better ways of = skinning the cat. What I am saying is if you do contemplate a change = thoroughly understand ALL the ramifications before you commit to it. Some of the best advice I have seen on this thread is: >>>>>>What about just doing a good pre-flight? Rod ends don=27t just fail = instantaneously...... Remember the KISS principle? Fred Stucklen = RV-6A N925RV <<<<< >>>>>>Then again since I=27ve never heard of this part failing in tension, = perhaps Van has already overdesigned it .... Steve Schmitz <<<<<<< >>>>>The rule we had when I was a test pilot in the Air Force was if = something goes wrong when you activate a control, immediately return it to = the position that it was in before the problem occurred ...... Jim Cone = <<<<<< Charles Fink, RV-6 N548CF flying=20 chfink=40envc.sandia.gov ________________________________________________________________________________
Date: Nov 18, 1996
mgoodwin(at)mv.us.adobe.com, tina(at)3do.com, RV-list(at)matronics.com, sgallimo(at)cisco.com
Subject: Re: Santa Clara County Tax Increase
Part of our business is in aviation and part of our business is being threatened. You can help... ______________________________ Forward Header __________________________________ Subject: Santa Clara County Tax Increase Tomorrow November 19th the County Board of Supervisors is expecting a 3 to 5 vote to close Reid Hillview Airport. This action will cost the county tax payers millions of dollars since the county has been using federal money from the airport to fund other projects. All the money granted by the feds will have to be paid back!! The net result will be an increase in property tax and / or other tax. Reid Hillview is a money making airport both in the community and in additional tax income the lose of this airport will be felt by everyone in the valley. Call all five County Supervisors Today! Attend the public meeting at 70 West Hedding on November 19th, 6:00pm District 1 Mike Honda 299-4296 District 2 Blanco Alvarado 299-2040 District 3 Ron Gonzales 299-2443 District 4 Jim Beall 299-3924 District 5 Diane McKenna 299-3540 CALL NOW! ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Engine tach. drive cover
I am using an electronic tachometer for my 6A. Where can I get a cover to go on the back of the cable drive on the engine? I have looked in the aircraft spruce and Wicks catalogs but did not find it. Thanks. Cheryl Sanchez csanchez(at)world.std.com ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Re: Crankshafts in the RV-6A Vortec Conversion
My understanding of what he said was that > forged metal is more crystalline in nature and a local over-strain of > the material will be more likely to result in transmitting that down the > lattice. Don't believe everything you hear, even if it's from an expert. Ask your friend why GM's truck engines use a forged crank. > Next, he got off on the abusive public again talking about how his > business tripled when full-service gas stations were abandoned. I guess > people just don=92t check their oil or coolant. They just go fill-er-up > and never look under the hood. So, GM has to design engines for people > like that, and they still go 100,000 miles or more. GM has always designed to meet this problem. It's always been a problem. I asked him if he > would worry about flying behind the Vortec, and of course he laughed > again and said, "That engine was built to take a lot more than you old > farts will ever put to it. Get ready for massive use of bandwidth to respond to this one. > > So, there you have one guy's opinion... > Yup. Chris ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Re: Engine tach. drive cover
> > I am using an electronic tachometer for my 6A. Where >can I get a cover to go on the back of the cable drive on the >engine? I have looked in the aircraft spruce and Wicks catalogs >but did not find it. > > Thanks. > >Cheryl Sanchez >csanchez(at)world.std.com > > I just purchased one from George Orndorff for $5. I think Avery carries them also. Scott Gesele N506RV scottg(at)villagenet.com ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Re: Temperature Considerations
> If you are going to heat skins, a heat gun may cause uneven heating > which may cause problems. See previous postings and newsletters. > Best article I've seen is in 2/93 RVATOR, reprinted in "14 Years of > RVATOR". > > A pad type heater is probably the best practical way to get > uniform heating. I can make you one if you want one. See my posting > from about a week ago for details. I got a copy of 16 years of the RVator last week (Great job!) and I remembered the debate on the list from a while ago about heating wing skins. The idea that uneven heating of the skins could cause even worse oilcanning and distortion is something to consider. But I just had another thought. Back when this was debated on the list, it was summer. People discussed ideas like putting the skin out in the sun and such. If Jim Hurd is anticipating a 40-50 degree workshop, he's got a perfect opportunity to acheive a 30-40 degree differential and have even heating.... Store the skin in the living room until just prior to drilling. (I wonder if the plastic coating slows down the rate of heat loss?) -- "Wait a minute, you expect us innocent children to climb up dangerous scaffolding and paint naked people all over a church? We'll do it!!" -- Yakko Warner, Animaniacs "Yeah, I've got ADD, you wanna make something of.... oooh, cool. Look!" ________________________________________________________________________________
Date: Nov 18, 1996
<< I am using an electronic tachometer for my 6A. Where can I get a cover to go on the back of the cable drive on the engine? I have looked in the aircraft spruce and Wicks catalogs but did not find it. Thanks. Cheryl Sanchez >> Cheryl- Averys has the part you need, P/N 6346 Cost $3.00. A bargain. -Gary VanRemortel vanremog(at)aol.com ________________________________________________________________________________
Date: Nov 18, 1996
Cheryl, Avery has one for the O-320 engine. Chech with him.... Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com (Cheryl Sanchez) writes: > > I am using an electronic tachometer for my 6A. Where >can I get a cover to go on the back of the cable drive on the >engine? I have looked in the aircraft spruce and Wicks catalogs >but did not find it. > > Thanks. > >Cheryl Sanchez >csanchez(at)world.std.com > ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Insurance for Military pilots
would you guys give me some feed-back on who you are insuring with. Is USAA even a consideration in this area...thanks...John Lucas ________________________________________________________________________________
Date: Nov 18, 1996
Need to ask a basic question before I do something dumb. I'm in the process of preparing spars on a 6 for riveting. I've got pre-drilled spars. After reading the plans (over and over and over) I can see only 5 components that must be riveted to the assembly in addition to what Van supplied all bolted together. These are the five 7 inch prices of angle mounted beyond sta-68.75. Is this right? I don't want to drill out rivets. Jon Scholl RV6 Wings ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Interior paint type Q.
Guys, I would like to hear from flying RVs what type/brand of paint they used for interior surfaces ... in particular ... How well has it held up to scrapes, dings etc.?? Did you paint a glossy finish?? .. or did you add flattener?? Would you use the same paint again, now it's been in service?? Have you had to touch up any of the paint? ... was it easy? ... did it look OK? NOTE: the above questions for INTERIORS only!! I was considering Imron (Yes, I have a HobbyAir sytem!), but have been told that it might be somewhat easy to chip, and hard to touch-up. I would like to evaluate any other alternatives before buying any expen$ive paint, and found little reference to interior paints in the archives. Interested in any comments, either to the list or privately .. ... thanks .... Gil (got to paint the inside some time soon) Alexander gil(at)rassp.hac.com RV6A, #20701, N64GA rsvd. PS. note I did not ask about (ahem) primer, just the finish coat .... but, since the P*&^%r subject is now mentioned, one local builder actually is using DP40 epoxy primer as the interior finish coat. ________________________________________________________________________________
Date: Nov 18, 1996
>You need something like an HC-C2YK/7666-2, a Mooney prop. But good luck >finding a used one. If you do, and they have an extra one, let me know >immediately. I am resigned to buying a new one. Actually, from looking at the prices in Trade-A-Plane, It appears to me that a brand new Hartzell from Van's is not much more than a used one on the open market. The same appears to be true for Governors, by the way. Shocked at the way the price of the Woodward governor has gone from $875 to $1200 in 15 months, I started looking for a used one. One of the prop shops I called told me that his WHOLESALE price on that governor was $1700. BEst Regards, Dave Barnhart barnhart(at)a.crl.com rv-6 sn 23744 Trimming the canopy ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Re: Left elevator trim tab cut
sisna.com!ddickson(at)matronics.com wrote: > > I sent this Email earlier but the addressing was wrong so I'm sending it again. > > I am working on an older RV-6 empennage, not pre-punched. I'm about ready to start building > > the left elevator. The construction manual warns about how easy it is screw up the trim tab > > cut. I can see how it can be a problem because the instructions in the Construction Manual > > are not very clear. I am referring to drawings SK6-3, 5A and a drawing supplementing SK6-3 > > which was included with the emp. kit. > > There are two dimensions for the length of cut, 19 1/2" along and parallel to the Trim Tab > > mounting spar and another 19 5/8" parallel to the bend line. > Which dimension is correct(probably neither one)? > What tools should you use for making the lengthwise cut, the crosswise cut? > How do you go about cutting out the little folding tabs on the elevator? > Can you make the lengthwise cut 1/16" inside the Trim Tab Mouning spar and file the elevator > > skin down flush with the spar? > Should you cut from the inside of the skin or the outside? > Are there any "gotchas" I should look out for? > > I would be grateful for any and all help I can get on this one. > ------------------------------------- > Name: duane dickson Cortez, CO > E-mail: ddickson(at)sisna.com > -------------------------------------Duane, I used a cut-off wheel using the thin Norton discs that Van's sells for cutting the canopy. It will make very accurate cuts if you go slowly. Don't forget which side of the line you want the kerf on! Make straight cuts, forget about folding the sides, just make a couple of simple ribs out of .032 material. This is what I did on mine and it came out pretty nice. If you want more help, email me personally at emcole(at)concentric.net. Ed Cole RV6A #24430 Wings ________________________________________________________________________________
Subject: Re: Prop/spinner clearance
Date: Nov 18, 1996
I think 1/4 inch is better. There are several things to consider: 1) Your dynafocal mounts will sag over time, so the spinner will slump down. 2) Under G loads, the engine will move around quite a bit. I have the nice RV smile in my cowl where the 4 inch alternator pully (from Bob Avery) chews into the cowl as you pull 4G's in a loop. The spinner will be moving with the engine. 3) When you take the bottom cowl on and off, you need a little room here. I glassed the top gear leg fairings onto my bottom cowl (they are cut at the line of the rear of the cowl and the fuselage). So I have to slip the bottom cowl gear fairing onto the gear leg fairing and then push the front of the cowl behind the spinner and up onto the front of the cylinders. This takes some flexing of the cowl and 1/4 inch is not much to work with. Also be advised that you can file off some of the excess overhang of the fiberglass spinner that hangs behind the back bulkhead. Do this after it is all mounted. I found the rear of my spinner a little uneven. After filing it with the vixen file down to the back edge of the rear bulkhead, it is now nice and straight. Herman (RV4 60hrs) dierks(at)austin.ibm.com > The construction manual recomends leaving 1/16-1/8" clearance between the > spinner and the prop. I obviously want the gap as small as practical, but is > 1/16" sufficient? It seems awfully close. > > I imagine the prop doesn't flex much (at all?) at the hub, but I thought I'd > get some opinions. Can the spinner flex toward the prop? I'm using a > Sensenich fixed-pitch metal prop. > > Ed Bundy > ebundy2620(at)aol.com > ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Re: Alternative Engines]
Date: Sun, 17 Nov 1996 19:09:26 -0800 From: Bob Reiff <Reiff(at)execpc.com> Subject: Re: RV-List: Alternative Engines Robert Fritz wrote: > > Hi Bob, > > This is the first I've heard of Superior's copy of Lycoming. Any additional > info. such as addresses? > > Thanks > > Bob Fritz Phone no. for Superior Air Parts is 800-487-4884. They advertise in Sport Aviation (Nov 96, pg 55) and other mags., and they also display at Oshkosh. This summer they had a raw crankshaft forging and crankcase casting on display. The Lyc. 180 kit was originally planned for a mid-1996 availability, but the rep told me it was delayed by the project to get the A-65 cylinders to market. Perhaps if they got a bunch of calls from RV builders they'd step it up a bit. Don't be surprised if Van's sells the engine kits when they become available - they already carry Superior's Millenium cylinder kits in the RV parts & accessories catalog. I've also wondered what effect, if any, there might be on the price of new Lycomings now that Cessna is cranking out new 172's again (which use a Lyc IO-360). Bob Reiff, RV4 #2646 ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Re: Seat cushion fabrication
boundary="PART.BOUNDARY.0.19598.emout08.mail.aol.com.848373965" --PART.BOUNDARY.0.19598.emout08.mail.aol.com.848373965 > Here are a couple of drawings I made from Bingelis' article. One is a > sketch of each part, the other is an assembly drawing. They are in > Macintosh PICT format. Unfortunately for those of you with DOS/Windows > I'm not sure how you would read them unless a friendly Mac user could > print them for you. > Ken > RV6A Flying Attached are the files converted to .GIF format, then mime encoded. Tim Lewis RV6AQ #60023 --PART.BOUNDARY.0.19598.emout08.mail.aol.com.848373965 name="SEATS.MME" Subject: Seat1.gif =0D This is a MIME encoded message. Decode it with "munpack" or any other MIME reading software. Mpack/munpack is available via anonymous FTP in ftp.andrew.cmu.edu:pub/mpack/ --- =0D R0lGODlhEwK3AoAAAP///wAAACH5BAEAAAAALAAAAAATArcCAAL/hI+py+0Po5y02ouz3rz7 D4biSJbmiabqyrbuC8fyTNf2jef6zvf+DwwKh8Si8YhMKpfMpvMJjUqn1Kr1is1qt9yu9wsO i8fksvmMTqvX7Lb7DY+vAvR6wEBn5PH2e2QP0XfQV6cAyEd4iJCYkHjnqAgQCRi5aCeHmclx uDfpJ/kJGljoQCp62nC5UNkYyhm6CmupSCmLOGirqbsba8ln6Mf6oJqaK4xonOu7jKqnTPwb DcxLXT3s+vmKewHd613Meiy93fwNTJudbL3OPl7LLO59bMosbxvvOW6+rK2Pq9wu4Jta6eAR +hMMICh0gvjdU1juFKNWztwVdBZPoEYz/xPJvbpYKiHCd8X8RZxG8WQ9hwavZdwI80snWTNX 5jloUQIpYf1W7pOosFJPki5jGj1D9B8sdCFxIjSJrJtKnzVDxnKa1OrRrWKyLlwKtmRKlNHC 0Qx7bay4fCm95uQK10tPZGTnna0ozSxZqPXm/mTrFtXLuISd+FXZUKxPpdhwsiXXtJujsZA9 psMqtbDmzZw7e/4MOrTo0aRLmz6NOrXq1axbu34NO7bs2bRr276NO7fu3bx7+/4NPLjw4cSL Gz+OPLny5cybO38OPbr06dSrW7+OPbv27dy7e/8OPrz48eTLmz+PPr369exJQ2wPHwq9+PSl ZK6PX4nT/PyRTP8GB0mAAg5IYIEGHohggvu5oGCD/fHwnx6fvVcChTpJ+KAP71kIE4cieDgM hhlC+MeEMoBYiogj6rChiTGgmIqKK+LQomcwenDjKjLOaEONneW4CQjG8MhiiTaeKOSORM7g I2dAbvDkIkou+aKRPyL5wZA7NMhll15+CSYkGkQ5CApNbkYmBmlKMiUNa+py43xqDpbBmZq9 WcGaWhZ55JxAdmKmlU5iiWObTLpoQWJ5uhJoIIi+oKehhA6a6IKjGNJoiH3CEKmOWz46QUdF eWqCnYXhSUGnmH66KTehBpVpiq0ymCSpOaCKSY4bmhoCr3HhemGWklY5a55pBVuqoGj/Thqk rTSGCW200k4rZ6qKIVuhsncyC+WwnIJqrLeNxBpjsSyoOi6rV9ZZrrUn+AoXsNqOKS6t5oba Lr7vzkuYvI4K6+wN/g5Eb71l7vvvut8CvCqfCrtqMB7kRqzRwLIWGnCP4LqbsabJJkzpwhg3 fOvG+nZ8cbYgL0vsyOk6HDLEKOdLArxcWUxztzNze2rBO//crMcx2+uylOoOHS7QL6ssNMsi d7BnyfdiuzTVI9i8Fc4Up2w0zE7LTLLVH/L7K8/sKk000hyHTTbDXG/bMtRbp6D1GrrmvPLV bd9stppzT9zz2Wgf/HHTcD8ddNUCmyy2xEkz/XbgiOvMtsZT/5MN4sBYH1V35YIrbvnDieJt +Nh5Sw5prZ67yTjmoyNcer99g9211KI/Dnrsqkcue9yJ105j66c7vnbNe2c9++urH3r58Gzi rrfz8SYPPfG2q33y8n9nT3rZvlOeO+vN65454Noj/73P4TN/e/HAH//79ut0vr7y9affu98U aw6/UfS/rz4A1uB/SAmgAHm3u+5ND3/6O9/kUGe/+zkQfArkGwNpR7jr9eg+T7jb/swnQf9R z33WC96zKmMfA2awcQmUnzUIWEIKrnBxJ9SCBwcXQ9PpboEP/NwB2TdAGKbOhz90ofRmCMEW oKuIF2SQENMWQSZOUIVT7NAIuYfEAf/W0IZUfB4Je9W/mAhxiVkU3wa5cMMq5hCMR0RfDxsY Qigy6YlK7GL5YIdAHg6xaGUEYhC3kMY49pGPOFSiogxzxcbR0YhCAskUAilFQcKxgnO0whhb uEYzCoyDiCTiIAsZRVDOYZGQkyMVSanGitkxlGzcoZtQGb03YjCTfjzcLGnJyDx+8kSw1OEe 5SZKEOqRlV7Eoi8pyctqMeGSboukKfN3y2KysJm5vFovW/nL+OGyiW6M5h0Lp8tKVoGZhJQm DV+0k/lchpM/gOQuJRlNZ0LqmpicQz3pac5zSeke0sTnF1n4zVJW80P+BKYsWYlPciLxEfD0 WvW2mUpiytP/iZZMJL8S6kd+LmWZq3xoPRsaEIVqM59aFOdXCMeoJbgToiD950RVyc0vYrSk NMlgQafpvIAar42cs+jwZqpFsCTmpmFEmU5jGc6extSYJNVk2hgKvGxw1JMsfalE3ylGn8YO qJxKJ6C6RlSedu+oxxyoJkQqw6rWcXwIJCs2kbkJr240KgypaSuCcc5sprWptUziP936Uas+ DqrjmmvDGJVSNklVq4FFKInYOtarGjSpMtRo7hYrMcwejI5oPeVj28dUvprVgRYz7D4va1Mv 1nSRnaUqV79GTMBSM5iLUgpKBQiNxd6lpAd96GttGVvJjrSlELNrMfeEWbwWlrd6//Xs0WDr UdmWk7iuEioxkEtXwm7WqWst52/9GlrpThau6tNuP7Oo23RJVbPNtedsRbvUrFIVvhH1qGAX NZOv3vYq7L2MWvH4zElitbvYA6hw90rdFzKWdN+FZnDtO937sqO1Av6ve0FrYAiPd7S5WvCU Guy9CluYf2KVb29l+tkCu07Dw5Xw/DzcMRAPM7oH7qKLFRzfi6YYun+t8XxvXA0K31LGUKKE OeeqitwST7kDVgFaVuxSrfA0rOOEseeILDi87lYiL0uv4wID42f4WMQJDrKVUfvc6JlXMEy2 nnJ168jQ8WV14sXLlIUH4L1iucVcbvNxv7xZLTu0xyxGMP+QqSFkx6a5kY5iaEL0+zwmC3rN 3CV0lDdM2xczkE4k3TOZlwtV0755u452qKUOWGc7i7nEVty0h6JmwrLGqNTn3a5qM6tYryE2 soVelZ+lSGUqtJadaB40pjE0arDaOtKA1mBKYf1SGK0XmcF+pNmIjdsdZ4mdSJYrWI186AQ+ u02pJhlPirqRYSvzw9pOIrFXfel8wZuy1jztXd9sCtMu+sIsUWS7HUzjXv+4ycLaddUknZeb drYqOt53iL055jlLUKFrRnKgUWhsJ/N3MNCWM4/DG3GMAy3RJUR4n9vJrcOw2+EztnRodQIr Vsv6HPg2Mq17gFaVx/jfD//KIcv/WG4pk3aEFr/1zXlOt728pOPMha6F5o3TY5d54CVvdq4p Hev2itjTJoa4wD9N8MZW/dbMpu+ZbazojLcc5F+PZ9jfe/Aljx3nZ0cv0i1I5qCD3cICITmK WY53r8d74+eWOUxPzFSutzrvIWfp5kSY45/evZsPHjza+R7Suq9R8enuqOWpbvauB3jIk1cq 49t+v8eLnsAj5fzhBf/y46l+8VonPeApH/DP/2z2nY/8VksP+dPr/ny8f/3o065B4OY+9lIP 9y78nnjgr97lUT9i8fuu+U5Ln/aVZz5GOHj9zPued67H/nz1brSYuxL3+nxv+cUvfO/Pev2h 5z7r9bz9/97Hv/pCHzmewdl6+Wd8y8d/l1d/+ld7yJd1H5dhwwcZUMdhcgB9/nZ7pgd7Bahe mRR+7TCBDad2gdd9GKhsEJhpOIZ4FPiB7Md2DnhcJFhfHMgzQpFkZfeCeQZeDSh/tuKCU8cL OZdPq7V5Amh++4dubod5MIg//LRc2leBwXeBRShc1ZZCSXgVDCaE8PeEhheF/ydQtMR074eE RKiFLCaFUTBspcN0lQZw1AeFZMiFO6U9SliDAKh8bDiG8VaG8nFtpCKHPPhWdbiCOQh6edhB e4hS4RCBhgaCBNiGePiGSBWATTh9gSiCRniAA9h+3nWFYZiF9KeIRzhh2ZeGff+1hpTYiN5H iJ10gh6YfDcIZYK4d5c4hAnoW5sYiufXeI4IWXB4bGB4i2LoiQaYik3QgZInifZnh8E4iI84 c1tni5oGjPS2jLsIifh3jAgYgqdYfcM4VatojClogdl4h6jIjH/oXODohOKojLHIjSoliolo gOnIiOO4jeUodn+HjpOIg5W4hdTYjLaXj8hoivQIP+2oH+9YgrzIgK/Ij27oj+boWs9ogp0o jexoj3AHkK1YivuojQV5kRGmgHm1kDmVi+T4kC3UbfnFXm8nTIuYjBVpiQaZBDl3EYb1a6BI h65IkqjnkBiWdGrhZwY3h124kQzZkXd2ktQEKEFpb0P/qZCAyJEEiZQ+OTGl9mhthnW+CI0U SV7TSJV5ZpVzl2sJWY06ST4lWY9JyUdhWWu4Rpb/6JIDuY4x+ZEblmw2GYTXiIlyCZP9+JV0 mJJXaXd6OYvq2Jc9qWItWYuEiYWG2ZUWqZbNF5IeB5VGKZX0J5P+gZBOWZZFuZMsqIt/SZTO yJic6JjwSF+ZeQTF+Hul+YtciZob+JrHt5gBiY3zOJd+mZg2GJGuuZWn+ZbUVpd8Vpsa2XO4 eZihuZs52Zu2uZdRmZuIOZK8SZrOWZjI+Zh0GZnEiY/GuXbQmZwmKZpPeY7eGZfgmZ26OZ3M WZ3mqYLoGZtHiWib6Yf3KI8v/5me0lmZitmdC7ifZ8mTyrmeo5mR/mmWbYWWHrmdn9ifIvmf hGdcsKid49mZ7WmgngkgfdiQAvqgBDqZTdehNKeh8plUqmkErEl+EmlmfvJB1Ol8cEKfL4qR 52mZ0cmhB+qhxfks1MKjPeqjA2JHCsKfJloEKGqFVEKZwQmj43ekSKqG9XlWMcqSTnqPREoE RrpyVEp0w8mg0aelW7qg8YiCX0qLstiY91eeZIqmnNmDUoqTauqVy5mjDQqnP2mjs7mmFlqn dhqev5mnBbqnQ8qlYsqKgSqoYQp6XmqofJqfpvmnH7qocPmmK+qNrRmpLjqlfpqJvXiph0qh kkqnnf9apYOaqGMqqqBqpUOApTt3quTJps/npmbaqlMpp66qp7MqmZM6n0yapbg6o7raprzK qr76q7KKp5saicQKksAKq8J6ZcparKkqBKv6rNCaq8aqqfyWrNYqjKTqJz8qreAhm9nKrWkw rhNZrmxwrpSarmgQIUoape2qBqcmo5kQrvJaJ9zmrfgqH/iwr/xaiJcZrADrriTarNM6lgRb qdeJc0ensI/6niVzr046sRoCBJD2sAt7piyCbRlbKuAKsiHLo1fqsaJasSWLsimrsovaGIK2 sjzCCUv4sjOSWI4aizOrh7b1Qpx2LTh7BSNqrx07Cjzrsyeafj0YskVbZf//EGQ/960nq7Qh tW74pSvedld0QXM+dxP5hrUnFbUcSCZEG3duVibzplleNm2Z+rVg+67FM27hEzVoW7ZrOxrr Jm1L82sA0Ydya3V0iyb+yg07cbQL4bV70YLgllxQi6O7OpMcN0lv65ZCA7mCCaXPMbUTloeX K0qiRrYUcrZyx1eK6z9Ci7Ri60Rx8ripFbnmprplx7nnIbKxK7tf0rBPIm1WOwtdOws1y7e7 qx70KrWaO09pIrrpQbrPJ7znYrqNWrTLGwfO2yvQy7x+OxzSe6fUKxyllbq1g1jVokzg9xFz i73zyqivUhmE5WV8yLqHBbpYN75dUb4wd75kt5LO//Jooetr2Pq+U4ipYqFd6PtnKxNq+Fu5 +2sYSVtdCQtn92Zn4puVjWHAtcGW9BvA7PYIlLaDEawabMkIJmdUfdtHxavB7ui6MnuTXpg3 9TvCG5yBTalYcuK09zFU1rvCNWzDN4zDOazDOzywYtm9MpgMPCFU4svDoZEUAAzCyoa3OpJY LlvEoHHEFAxRKcmEnau/Tzw/TqzAFcw1Axy39YrFbXpzC+y7f8FsXyxxYSw7Y0xqPzQkF1zF tyDCalwktNbBoPvBNEhndGzEzbZR6bs8nqvEfAwqTPnDZ+G9UzvEhMzIjezIjwzJkSzJk0zJ lWzJl4zJmazJm8zJnezJn/8MyqEsyqNMyqVsyqeMyqmsyqvMyq3sypq8K7Mry7NMIAlqyZo7 x0l6LKr8buUIx6gMvMy6pByTy53atgUsgfZDw3x8zGCczNCzzIS8royrqKM8zT0MUMVsqNd8 sLGnzXvKzcPMfNFcxOEcr4P3zWRqzvZaY+Scw+vcYV+XzhRrsOJcie5cw/D8zCyIzxqsz89b kvNMs/V8zhJKGZL8z3CAfvBqwLGcZA0xEY4xww9N0RWtknJFEBi9Thd9lYVwxwF60BBCyyNN 0sf7qqmY0AQD0shsnwIJc8Q7kwTNzivtzC19m6mSvLtstALbzRv6qnOqj0Ob0z1LsjxtzyQa VgL/TZvfZ9IhraoyHc+g+dO2SqOR0dSLgbBGXdA+zdLFGtTy6b4XC9X7bNCoea1ffZlhjXJa PdNS3dXLep9uTcQ7fb3oitRBoNQQW9erW6RjDdA0rbbxe5yAfcJ47dcKbcvCTNURe5SFLdZs HdVlzdCgitZ77dhrvdfUzNU17dUuvdkqbNiQTdabHdj8Wdl9SnaredgEddUOKrBJvZ22W9pl KoX9vNQ8CNufOpSg/diZPUoBK9ezzZ5VTY8129eiXTOZudBmzZ2nPb3GXdS+7WTKndhXbNqv 1NoXKtlkq5nIbU1DLYAw3dvtFGeqTag6GNPeTVDAvd1vfdavJHLHXar2/5ve0k031A3Yil2h t1LedH2zMoLSqx297E3a+k3Z8J3G422JNBPg6j3gqtjenA3XQZTdri3V+hbdqG1IFf6k0yvh 721Stq1x5/0+DW7fW33XCt6w8Z3hCx4wJq7hmp3imE3eLP7UJD5DMO7h7Frg1t2/Z5TgNO7i bKPjzK2u1Z3bF+u0/j3kAFTkkz3aM26xug1SQJvVJ97WES7cQM19dHK3U62tRl7GksEYdRU2 FX3b4ZbkA5qfVh7aWC65P9iWXdaUQpnms73mwOXlgHrjcP42lpVtVhxDMLTcUG7Tz8mPoyjk Yr5CgD6Yf2bchI7kb87mW6Poynuj962zqd1p9P9wtut058Ca59umkl22IGR+tZDO3bcgUFs7 D3x+5TGuP8YF3Xi8kpc93Lk06pOFwXM+yP9LxPi2Xz5+5queShlsSJluT9bFteqrtUBYqeK9 6HbJxMWWtkfWvoAMgFiZncg+5X4ub76uwtoO7JKe38TO5bjj6HlpdDkewAOM7gxu7PDk7bOT 0vyFtXiJ72OH5nqN25T+4IX7uc6u7eXgsjVXStweMXq7Sc2cmr7c2dnnKbSOW82ux6s7agpf ja7O8C4FSxgObBA/4aSYJMwObmd+EHaVvpAGLH9iX71U67uU1/6u5gDvMual78U+uFtMgyff 8l0awg7T8eCO2Oe+61D/Y7U5P7aHyO0aT7jpPjjqZ0JDL+s9LeV0R+XyJPU7WqIiD+LOyuM+ tvUtzujmOukqjqHKOPZ9XvVH/do2n/b0BhFPDuaR3eNH/50FOPf13fYo/vZoP9iWt/cb5PD3 3gaFXvcQmfdhNPi67C2EbnNZG2kWb+ARL+pw30jX3uj57unt695cLcgOvtiV7zFazO8XF+S+ J+3fHkumz2Zzt/IJZ+HyZ/j7veXFhe07LxKpH+2Wr7GvU3E1ucQ9L/uOz3+1j6odXmtkrNbK /5Z4r/hlcfFvy/zxPt9Kg/zRf/uvMveCK/BXN+2+Df04svd27P1+3MbNH+b6WfbRqvxFN23q /69Vq4/1QM3Bw29yE+z8mNnjS81ZTUMAAQxPrfdhlJNWmSzEOW/+QdALuZFyHOXZknZxUVIO Tbr86lnfVSvnb4dfT1g0uohA5WR4WRqf0UiTRz1eVy9tD4mU7qynYOdbrlDD5cCanOVC4WZl Ol6Vf+mk9d6nEfIRAKEEPfLuDN3ORO4Y65waISMPZRAfJcEuMzUx7fpwNqPQQEdJFfVCSxdT V0krHf0+WWdEZWsz81xhbS13e81yh9JyS9H2AI3ZApH/jJkJl5WPkVugp6mbnZOnX6q7l62T xuZ8p8jNpYA9Y8/F2tjfOW2WhiXp4X3TTdfvE/X5/92pAmIvEkGArP/ytdsHkNZBh7wW6jDY aOLDUQkhBmQozqJFXOP4VeyoCZG1EXRE1uM48uDHgf9SsiwIBpquiCFXysR5qtNOnRslYisn z2HDnzAp9fR59J4rQTZvNs3J9JxLiS2pLp2lUCBWjVmrJr3a0mRZs2fRplW7lm3bti+ZuI0J ySjYsDy32tW7l2+4jH1rWcULmHBhj1MNtxI7OHFjx+bqPr64mKhky5eJIcZMl3LUzZ9Bq9Ec +lfn0aRRp+7KVfUkxl9bx5bNmsls15Vh29Y9O/JukLjV+RYeu/fwscBpG1f+ufhy5MGhO5cu ufn03P6wW9duuPr22q//ehevt/v4fp7Pm1f/T7X8esHf18dnf9q9aajy8bNsr/790Pz/R9rP vP7SA9BApK7Dj8AtDmwQwegAXNAvBykkR8DxFpyrwg2fuFC8DDkM0UL6+LNPQxFRtM+/Bgk8 McUX6XNRtf5khNFG+LKLsLMab+yxwBUPfI9HH3300DvBhiSyRyO3Q1LJJzlLUD6rkoQSRia1 c6lKK0M0Kcf/tORSzFBqwjHIpLYck8Myw8vvozTV3PApMw3EBc445SRxQBXx7HO1uOQKVNBB CS00LT79TFTRRRlt1NFHIY1U0kkprdTSSzHNVNNNOe3U009BDVXUUUkt1dRTUU1V1VVZbdXV V2GNVdZZaa3V1ltx/81V11157dXXX4ENVthhiS3W2GORTVbZZZlt1tmfDI1W2mmp9VIpDeR6 FrM7qasimTbp1DYxbh9zak4G0RO3L3Idq4RNdPVUNyt2G3P33VfClRcwescNahsgIdR3XQpL Agfc+wQe+BehQsMo34MTnndhblBz+GGEIyZvYuLgChjgjDXGg1/IOv7yY5DBqujb1iy+GF6U 7VL5mpFlaRniCWFmSuYVaEaoZI9fznk+kXmu+GeTgxb6KJG+XZm5o5PDWGmdmMbAaYqaDqcQ Z7hGB+qok55appTuvQ2GKaz2YhCvrwUaZ7EDjLmIk9KOgwVU2ga6Z7h/G/qEs5O4u0O0///U m2+/l24ihpnhIMhmsN8+vCjEFYkh8B/zKjrdNveW/DiqF7F867ARjRffzj1XUXCGiWBYqNf5 MNhtN7rQxaCTuPnBkBpQnz2aaoEPXni16Oo94NWdsJpB5S9fngbWgWQ8GjyGYv7mk40HVMr4 qo69I95pTx5dL9SeMPvMt7D+ZNjOx/bq9RXsEPr2w0O+HPXJr8ME+oHL3+Xk+Pe7YFTIXueS Gjx45w3rqU1606MY5uLmvvIdMEf8sxaghpdBDWqQEu+D3DvAlz7/MBALOBMc5UqXHQvK7np7 Ao/vSMaL8oHDfuobYcq+tpIAko6H3Esh/ECIoxn6YYEi7IcNoZX/Q47sEF8QnNIPKciOEB7h GER8CvNgtzImbg+GZtoilqwjoQ9KkWBK1MgXTXckKDqRjA563D7QyMUSvRBpQXSjGQMSxy5i aI09vAuL8OgOPdbRh3Qc4x/PlDe8DPKQc3wOIRFZp0Cqg5H/q48hLRlDQCqSJ5VsIR8x+cle bFE/k/SEJ4FYyEc2ckR35OQpUBnFS64yk63cZAf/dZVYsnGWhdvjKMvoLwPqYZd+dKQvIanJ RM4Cesw8jBxdSEtR7oKUEfSX/J75SzWGMpWR1NEr+0jNNDYpnJGT4gbRmc5pmXKcNWtnGMtZ zdT5UZ7fi+c8x/bO6YixlvhUJitBKc1u//rTm9MkJzdlSdB/9vND91ToQ8C4T4c+1CvaPKhA E0pRcUIzoMgEqEbdydGGIpSXILVFd3IJT5Ia06QhdVvT6hmYibbUji9lAd20Mae0sYl1OG2c Ck6ojE3w06A0BQVKb2qTFBARY0U84VK7UMQmlmalUzWqS+uoxdEVaKmvcOrL/Jc1czKCqAO9 amakpNXoie9HX9Vf6+ZWwqPO9Kz4GI1aCde1NyQNi0bUnAhrJ9Rb0LWuG7XpX6t3Q74Swq9a qCFQS4o3jEa2sEO9a1LFUIhcTjEbbMDdXusG18FWdayVnWtaQ3vE5jkPIqNTXl+5INVLlDWj ph2tTZvpQGxslf+zq62iY3+aO8uSNqapi6h0aEtZ26pEpNucLEuXy1yLZomw0UXrdFX6XKta d7b6RG51uXta7EqUuOH1WXMv6lGGmpeq4/1uedl73WRGU71Fje/g0Etd+N5XvPPt6ObMyl8f CMO7zkkudEepTgUvOFvgJK1M8zuPrOE0qmJF8HC1W1pbLpOZjgsMgSPcMcCdJ6yp3TCAawtM VwpTwtn0rxxGDK8SP3ChzSVlcSuKy2E+z8Ufba8X1xaIuBZUmzcOpo5zKwJ+6dSScPIgz7Sh 18W1McNGhglmc/y8lDrTpUHlZZqs4Nq1Wa7GRbbnlRH7oM/ZgV6Y7e168bvEEk6ZyC//1rBd 0UxjoMTjJW2+X5Mns5CwyhXPVT5zSLC85zVjYsl57eaWyibjIG/1xGm0MqLTrJVyPmJkn300 AcErlStvWdMPTixEC7ycA2+3zJBJtJrRx4lispq+KFauYZvy6lJnmNM1Q0mqlbPqO6sY03qG 9aZtd9IwHNfAoUYgQ3Qtaj4fh2ZP/jKo9zu5PP8B1Q4WpIWszWxVO7umHI515nrnQXEHm9xU Njeyx9djOOvX0PIGEztlaO8Aj7Te3b7logcz62E7t777xrUkvc0ageM4y5Y+dKxhm75z3VTd vwWqNLS605ntuOB2JvGHLyhLhiva1hc+6bWwGFr87VVrWYg4/1QnHe84A3w1jS74yI9t44fv SOIPXLlswepXmG9t5TM/N24Wju1+a3vNKR/yz1kLlZe/gegynwe+05P0I3f81iefdl9Fd0WJ P9nC+XutFZ3m4YRnROsr5rrJIdx0wDIgyKCdaolzGmWX202yNNehvlNM8JLTutAQn3sKUv4N q8J8tXwfotHh7Wmv+w7nu7bzpQ2PhcBCdu9vBS6hPe0/wru3JPYla4yU/vbRH5yYMLVhA6vu iCxKGm1AV/u0C9ez9lRe2qof+OTfber9Ff6QvH92tht+70x7/M3npXzqB//7uAef183vvY/T G33MI9zYFrX+8d3bbOST/Ju4n0qbQf8c/nGPP+duwnoO/Gzta29d+zsvP8WSPHD4x53jYzV+ uesP8J4ofMJGQvzMfQCN/hxOAGfrbiiMiixs9aKksfaPjg7w5qBvAf1NMRxwrUDLxLCK807n 6KTvx1BPAXWOAbvr8z7uA7tvFcSsAEmw7f4tADdQvhRu0mIsBIUs/3Zn3pzP4+jN97ZPMTrg t16H7qoN62RPBUuQvJYu+forB0WQzoCPBNnHCf/P3WyQ6VKhLjbPCqcPCyEE/UJu/tyuC6UQ w7Bj0ERwDJFt+OAQkrawznysCAMNOtwQ7k5v7QCGBqnv8uxP+cwvIgCR+4hwEN3PD+/jEO9P DcmPEP3uKxz/URIhsf3ihxGlTgszMAVv8BHhrfEi0eCyTwO9EBHJ8Iw4EQXNzAlrLRRF6xSB EAoT0RX/Cxa9DBO7bggv0fIGsBC7ohIXMQpHMROBEY5WMQ1NcQ1/cRLXQRiNsRY/0RJhkeWY MXd2S4Ewbhtdjxs3Lu+88RuxERy7kRy/sQG2QdjwcBidcQygsRkHr5rqsNJMDRbeUZVUTx5Z 0fd6bRpJkRdNRx+VsR4JUBZN772eS57mkfiq8Q2LcRez6+0Uch+jrzbusZdsrZ4Wktja8RMu 8pgyMp8GktfYyiD/MSJRLKY2kvUIsvNMMvBKUY5UkiLPgIW47CUhkhZTEnRGsgQi/03JkrEG T1AkhVLJ+g8HPvIVuai4VvIKW6/vHpIPdfI0cKwp55AkZ/ELgc04iKoqGewrwdIsmBD7ePAg xU+arBJm1o0rSyct1XIrh4Of3BJl1jIuEWUu6RIuhUOM8BJk6nIv71LArhImAfI6+tIv9dI3 DFAwBzMnEdKXDhMxQ+wxoyIyM+YvFdNEGNMpzXL9kMMyLzMxd6NFNrMxpZIy/640y/Ikp5IS VXM1CRMl5ew1g5AsZVMVaRMGRVM3hCQ3dXMyzzIYffM31Y/dAm44tRI4PVMgQPMtldM4iaI5 8/I52XKRkDM5i7M65UE6pzM77bKTrhM7hfA2+4A7E+YMY0OzNcszPC/iJ58QNY+QPVsh/94z OJFSPudTcTpxwPDTCL0TMFuyP70tLAm0QI+SNQU0QRV0QRm0QR30QSE0QiUUCAoAADs=3D =0D ----- Subject: Seat2.gif =0D This is a MIME encoded message. Decode it with "munpack" or any other MIME reading software. Mpack/munpack is available via anonymous FTP in ftp.andrew.cmu.edu:pub/mpack/ --- =0D R0lGODdhDAKbAvcAAP////7+/v39/fz8/Pv7+/r6+vn5+fj4+Pf39/b29vX19fT09PPz8/Ly 8vHx8fDw8O/v7+7u7u3t7ezs7Ovr6+rq6unp6ejo6Ofn5+bm5uXl5eTk5OPj4+Li4uHh4eDg 4N/f397e3t3d3dzc3Nvb29ra2tnZ2djY2NfX19bW1tXV1dTU1NPT09LS0tHR0dDQ0M/Pz87O zs3NzczMzMvLy8rKysnJycjIyMfHx8bGxsXFxcTExMPDw8LCwsHBwcDAwL+/v76+vr29vby8 vLu7u7q6urm5ubi4uLe3t7a2trW1tbS0tLOzs7KysrGxsbCwsK+vr66urq2traysrKurq6qq qqmpqaioqKenp6ampqWlpaSkpKOjo6KioqGhoaCgoJ+fn56enp2dnZycnJubm5qampmZmZiY mJeXl5aWlpWVlZSUlJOTk5KSkpGRkZCQkI+Pj46Ojo2NjYyMjIuLi4qKiomJiYiIiIeHh4aG hoWFhYSEhIODg4KCgoGBgYCAgH9/f35+fn19fXx8fHt7e3p6enl5eXh4eHd3d3Z2dnV1dXR0 dHNzc3JycnFxcXBwcG9vb25ubm1tbWxsbGtra2pqamlpaWhoaGdnZ2ZmZmVlZWRkZGNjY2Ji YmFhYWBgYF9fX15eXl1dXVxcXFtbW1paWllZWVhYWFdXV1ZWVlVVVVRUVFNTU1JSUlFRUVBQ UE9PT05OTk1NTUxMTEtLS0pKSklJSUhISEdHR0ZGRkVFRURERENDQ0JCQkFBQUBAQD8/Pz4+ Pj09PTw8PDs7Ozo6Ojk5OTg4ODc3NzY2NjU1NTQ0NDMzMzIyMjExMTAwMC8vLy4uLi0tLSws LCsrKyoqKikpKSgoKCcnJyYmJiUlJSQkJCMjIyIiIiEhISAgIB8fHx4eHh0dHRwcHBsbGxoa GhkZGRgYGBcXFxYWFhUVFRQUFBMTExISEhERERAQEA8PDw4ODg0NDQwMDAsLCwoKCgkJCQgI CAcHBwYGBgUFBQQEBAMDAwICAgEBAQAAACwAAAAADAKbAgAI/wABCBxIsKDBgwgTKlzIsKHD hxAjSpxIsaLFixgzatzIsaPHjyBDihxJsqTJkyhTqlzJsqXLlzBjypxJs6bNmzhz6tzJs6fP n0CDCh1KtKjRo0iTKl3KtKnTp1CjSp1KtapVqv+uat3KtavTrF7Dih1LlibYsmjTql3Ltq3b t3Djyp1Lt67du3jz6t3Lt6/fv4ADCx5MuLDhwxHPIl7MuLDixpAj730subLly5gza97MubPn z6BDix5NurTp06hTq17NurXr17Bjy55Nu7bt27hz697Nu7fv38CDCx9OvLjx48iTK1/OvLnz 59CjS59Ovbr169iza9/Ovbv37+DDi/8fT768+fPo06tfz769e6z/4sufT7++/fv48+vfz7+/ //8ABijggAQWaOCBCFImkYKxMfgeUQ4yFGFD8t024YNAXZiQhgpVaBuHGPIEokEjkjjfhyEm VSJBKw5kX20tplhTjADQ+CJtNMook40Y5Siajzq+xONFQIJWZJAsDWnRkZ4xiWRKSlbkJGdT PmlSlBRVqZmWVo6E5URcYhZmlyB9uSBuY5LpkZmJoanmT2xClGZlc76pUZwP1RmZnnYSKWWP bva5E54O8dmYoYKC+aefFiaqE6EUBuroTZBKKOmkMy665KWYzlTpQoguFmqnlmYJaKOkmqXp qjimqqqpjKL/6OqOrCqK6qwwfdohp7gmWeuZt/bakq4b8ioslL+2GeyxKhGL0KiHQctsjcnK aey0JTl7kLSOYbuStiRe661I4BbELWHnClsui+KWlq5X67rYLmnvdhWvQPUCli9dWe171b3U Lotav5cB7G9fB8N1VsJTGTxvaAtb5rDA7tZHZ7V5PvzZYwxHNbGsqXF8MaybUjwuuRgXqvHJ G30MI8snudwqzNmmHKnJNHck82wdO7qzbD0n+nODOZM0NGxBC3r0a0n3ubRrTdv5dGtRvzk1 a1WrefVqWZO5tWpdd/l1yEV7aXOpIJf90dgDqx0S26eFbSXcpsn9JN3uul3m2aCu/3yX3XHh TW+ChBdu+OGIJ6744ovzvSvOfAGusOPFQj7ZboJzdGLk3eqW+ZKb4+vh353n9nlio3eYeuCl +x1urEZLuTpbkudUu1unq5xR6GrdTinmlD97peY1xtd765Y/XrLZxLtoPFm+2xT9Wrn3rfO2 z8OLfNrKLv/2mqpPby26wJMcPLDXS5h9VQHyW76t3oO/tpzre4w6fW2Jn1b1236/YP1NARL+ yqI/tPDvdfOTXQED1rLZaWWB0DsfAtO3t005sChh4p1VIDiWA8oLZd67YFDqJMKvvA99EkRb BX9VQhGhpIUqOmH3Umg9/5kPe3ILFQyNwkGxeBBfzLvhhv8A+KhhQbCHYfnhnHJUoh3mSkgF RKL2hIjCO8WOioUioqdiokUIyXB88dvdFeGnwN/tKHpStBcNP9g8EJKRSF381oxul0auKHGM M2wgraR3lDpuxYMkxCLshISTOA7qixkb5KmCSL8EcvE/zfKi59YIxDa6EYwUdMmKLGa0sPnx gZRkoBXxmMhM9tGJWeraJ/8VyikFMo8te4oGYwknROoujLh0ZClN+RVDvrGIkxTkLhfJyFta soYQcmXTVrnBVh7ThsZ85rN8h0r1uTCYv6yiIlcYTVqCypcZOhI4NWnLm+VSmNJUXjrNNctT 7q5nzGSfM71ZTGSuU3QDZMo4v2n/u3KqEJ2w5OY/R6m+aoazRwyLJ1bmSdB6DlGXj9vnUCTa PzOajqENhaY96anOhvkoYQptGEbFSMqOZrRyoDznsPy5UW1uU37WhGlLFyq7TGHTpQFVKUdR ykvh2QtgPZ1ZNnMaSnPO9KUTtCNQd/oygA4UqfdkY1CTqtRUbvGmRB0mMTXqU5matKpDlSNW MelUsgq0q1GVqg+LStKLlvWrOj0pVeVaUQK+1aFCxalZocpUc0EUrlPU6wtZClitbvWvcz0s Wg0Y1sGO1bBZvSs6ucShkPJ0r8h6bDcFO1nFssurl91fY4enWaNK1rSJxazoEFtX6m3yiaV9 amQbSzCV/1J2s4zlbEmbOlrUehaIHy0s3ywr26OS1q29LW61IrZcLVWWdbPFK89G2lYEMjG0 dE1tbqPLVd7qVrlYvFFYnYtb6n23u3nlrnCpKLLwnnWxuDvve9OL2XGSN6lsuq9vaSdf1k73 tNplK3ZF2dcAi7a/UwVasuzrX7nedr/5Q3BamUbd6iJWv+A9nnpB690Nw9fCoKVoef1al9f6 KrYzXVgXMfzXB2dYw6rdLX0hCxbmGji5YWTxemEM2ZqhGK41VquQQWxKEUOYxCWWcIEV7F4G MkjHRW4wkt3n4QlDbcEechCUj7nlG5u3yksmGoCnHGZiGvnFBJ6LicWKXCWTOf+7De2yl3k8 YukyGcc7dvMu5fxZu7RIWsSFyg/TTEEXGze+ev7tnXF6nw8ruq187nOSwVxmCgvyuRxu3pkP PWS5rJnNrntzogdMS0Pnmc51trOY8UzquDIq0p2e3Kj5irQKPxpQm85zoJV8rl2bcMySrrQF pRxsNbOa2JY+dmuF/SdYV7LEfybkj1udamXfD9mEhi6lrUw1W9MajtjO9ltilC5fB9Dbri5j pud84FnfOtmzdnYqnW3uai/7xG3edqzTbdV1szuCwOY21tAt4HDR288F5/fAA/5sgaNuvv/2 4VLffWWGi1vhD/e3qPM3cYp32+LybtPB1WyjfNWbQgb/zay1N/5tMMn75NPEuKq/3HCbrrzY RH5nuBN61YR73K49GTR5Ry7rmr6Kyte8+b59XrydK0yAQ0y5zNcadIJbHHtOxx3UeconmJ9a 2kqvOZxNRXTX5lyqXUd41UEe7jy9nHbinFA+fYz0i4M93m3PIrZhnmsWXUgxafez1GNm9bAb fO+9YxI4AU/4aTs6xldnZ9Y72HfJGzXw+Yb8kSMvr7LDq0r7ZPxxQ41zfT++3wlmOXycO6K5 y/i/hge9zt7+wMFv/uikX/rt3d15xLPP9j22aO7FzvvSo57bR3T921RJWGrvXvMZT73xpQfJ Znmy+ae3d/DP5PlD9nOi2L93//GJb3Tp6x73ZgGc15ECSM3R3icg7WP4I07/r/et+973FB3n r3rt+5+fGjd9wgdFSrF+8sd2zIZyvpchj6RP/CeAz/d/uyJ7EghbRvRrmbd9EbiBAGh+5AdM 33JED3h+nAZ9eheAHwiCMVN5Kpg8zodmFYh1KJiC33clLJh/w2d3HGh/qjN5DNhJfmSAPFR4 MXh4M2g3GQR8kpSBRUiCOxhzM6iDhTR7N7iEObh1Zxd9yGeF81aFB8iET9h/Jnh/CygU+2Ei ygd0YAiDL9iEzuODI4RD4qVtV/hzPAiFHiiFU0g+jid+pueEExiFkiOETEclRMiGDyWIQ8iH a1iCjv+IiHi4hRi0PR02hm0IiSYCh2ZIiTPmhnqIiZaXh7VDiJxnJIf4iInogfvHiHXYcqD4 hor4hYJBiuCHgK6YipK4iINBi5toi1MXilZGTZwIe3hnh5kYi7IYGLwYh75ISV7ohMLIii6Y fWEohoEoigU4jIv2h0XCRO93SowTjuI4juRYjuYojqd4iTKIjTGkN1FYfxBYjbWVi+znju9o jaiojsDIbNOzjMyROyWniZNojw4Xj/nohwqIjO1IkGN3h/jokE2nkPXIkA2pjwipgbgobPrj j8txOuT2jQtJkbf4kBZZf89IgwZZSyJpjIBIjaB4kiASRSvJkij5ii25WhL/GZIzeXNYOGYn +YkyuZM01JMrB5MY2YtCyZM0eZMRyY7nlpRKOZL095MxKUtQGZW/WJNGSI8OeJXbRpRgRpVH iZReWYRgaYmwKHAiWJZjCY9MqZX7WJFwSZZseZBvmZJTCZJdWZeveJYVaJSe2IJ86ZKECZGb pJd7OZglOZeFSZJpyZVPqZiL+YmL+WcUWI3wJ5mGSZOHKZCJqZmOiZeNKZpNCZmRCZqheZdM aZk5iYGoSZqqyZiyKZaBiYOvKZuxSZk3CZi1KZivSTed6ZRSwZHKATfBKZz2c5uwiZuheZwJ mEbEmRzGqYX82EzbRR1s45zVKU/XOR3Z+T+tKWiM/xWdrNSMiEibmMmMEUSe1hl7HoaeNqme VKebxDE22pmFqTmQHZSbvWGf1CmX9KmLScRJ0uGfjZSHAaqfSZSfwGGgbheeyTmfzNmgh9hE iDmcyrmcCZqSFvqOq8SexvE1HYqc3JmhG+qX/wafdpmMt7k1I6qWdmSiE4qijnmhIiWjLnqg JFqiGXo1L/qcaoSjhdd6NnqjJuqjOgqkQXqkVvejABpSIFocU0OknsmjyjmlSQqgGzqRTGqe NXqZ8cmiv0lwVAqhVtqiZJql+MmgOommXtqSvBmmYoqaS1OmO5pSXeqe6hinciqgV+ptTVSl 5ZmnxXiRxwij+ymkb+qka/+qoUsRpfU5lATKmEU6qD26Rspnp0qaqISqb67HqEu5oIoadrOj qQnYnW6qpyTJp/xyjq76qrAaq7I6q/pxWKAqlTKaNw96j7lKL/8Zqr26Mb+Kq8EKMWoKrMVq iMdKrKWZrAXzh4bqrHWzrFn5k9JadwlZkNfaGYHKq9uqrCeorfj0rSOzq+IKXEpIrsaGlk0I eNaqrgBnrqcKkfC6rvKqpT4FqfW6p2A6bPsqjTF1rnH5r39xq1lJsIdCrZiKsIhhsAvbTgx7 Oewqj8+mrxHrsAxXPxZLsPeJrKIXsRILrW6Jk1sKsvF6r42KcvNosqQDngg6sCybF+TmrX4X s37/wZova7MAG67zuo46O2mGN7KO+rMxenz4Sq9E+0fl17Ni965Jm41Gm7KR+LSeBjo023RO S7WPerCjOWUbu6/eeLUE9rXq+lH9iqxa65qlOKFpC7RRi7ZtO24IJbZDG7dqu7Yly592+5ku R7d6u7dt2rc527WAa5VS25ZIW7iBK7gCq7io9rYHm66Oy6VwO7T9IrmTS5dLe7TWlbWZi35c G60347mf23NzO7iTWbqau7mHe42qa6Stm55s+roqqXOo+7e0u3Z3craJRLq5e3exa5M29rvi qUe3S2hkG6zKdLyiFGTEy7fMmrqvk7y5urzM27zUO6rGy7Qr+rwDGLzd/5u43stFa8K746uG 3Cu951u81xtx2futrHeP7wu/ebeD83ut8Zuz9yut+Tuv++us/eu/6xuhs8er/9tLGgRA6wOx GTlNCzypJOs8ELyLa/OMn8Yd2fPAh3pmvvQ8GSx3Wra/Q2fA4KHBj/nBrAuMHgzCDbyzCGW+ 4nscJhzBH8zActiDPouGTybC4GPB4yel7mp5D1xjMdlCRBRHEOu7ono9MKy+0qlixzjDETmH K/xNQ7w6VXyohiF7rNqnMpyGxaOxQRxT9gXFUHjE98vFJBweWazDKvx3c4jDWtRoMKuM6dPE hPscKJzDpdnBY6zFbfzGWuzCFuRKQfvENTvIOP/px4q8yGYcl2LcsHe8xmzMMZQxxzukwCF8 xVl2yZYsyZpGyQN8tyXjwz88yntUaqKMyltbangsuqwsn7FiyhMby7a5PK8stLYMuprSxeG7 yza3SLSMuMDsm2SUy7NbzKaLy4Z8ysocSdWFzHX7zBYIO9KMu9QMaqsyzMSczbyMQtfMtt4M vDcUznk7zvgWQs0ssuiscqxizgcMwIoEz+28unnEzb1Zz6P3S/Sszz/4zutcy/6cztqEz148 0K/XTf2M0EnHzwHdzQwNzUK00BFtzL5F0XRCICt5XXUMYPEswaCDuZhiJhjdsCItwR8NGTML y+wqwr4Lxsey0h1tbe//e9L/o8TqEW0sTcw1PUc2/R46rcuwSb047XIprRcX/JjBm7xZ89Po kdTivNNRzV8TddT22mMPnc/QM4pWXXQ05q0b249FXR3dKtX2qy8LNNYFmlMGfdAS2ktio1rm fM7oK2hq/Y9yPbhh/S9dvcTF1da//LjDedchOmIlHTlO/Sh9bamFldWyC2OEnSSLTVPGBdgx 3J2JXUiR3Z9Hdticg0O1lx5/F9ipSbYszNfmoSERYtlOLNjsFISb3Ymq59mfzbPwwcadrdeE HHWo7R2j3dpDvdsdeNsYrFyO7daoem2/tx2/ncclSdS7u0GTnZlHNdfQ3UCjgiixHTd/rdva /6hu+2yDZF3dx03aEbZ8NQMtmb1qj2fdWwyEKNNr0/3NsVbel03V2aJf5Tbf1exorO3cVftC Xji8msTfK5ViWRQxChLUwh3GVciCcVzg0lnd5hRkl3zIiKZOTgJ87aV/MpxizW13DN7gH+t+ Iw5SBh7eGwfVqykqBZW1210mKa5qTxZZI07i02zFdj3jUrbgs3XjFIxMXcdB670Zq92YIQ7R aqfhUBLjFexPNV5tQB7kTB6CHuPkBftVRczAUz6LLy7fRM7jwuTj2vq/ORTmYh5jnuzdLl7B Cm7iV57mlW3WmGjmjmThbn7lH/dh9g3cdBhnKxjnYGNS/03nMjtzVP8o6NMaWn3u517ttyn8 qHJ+5Mlc2nuCXgKO5j/C6I1u6Idev+TSQ0W+5FTV6Z6OFyG3gqKO5YFV6mx+KAMO0xc42H2t ZZVu6Zfu4KMORUi06zSHX6+esA5swxjE6uUbz1Ge4y0uGUQq6yMkRb7+1mrl3swOR84+KMZ+ 7NGyWKZ+66S+u9dOfb/H1Nwe7MLuJRNMKdmu7fqCVt3u7W6b6cQu4eN+s+5u7ueeK+luRHUU 7aT8x5xr1fC075ku3dF54dgs09UeTuH+5Aa/7nzktfie78nU8O/0of6uuY8c8GIiSwQf3UqV 8Q1dsajb1f3+8fM2oBDvWGg38RRfexY/3D//JfKpTPIuzxj1FuFut2sxn4wEzpmZQYg6j8MG RPMsb/M9u9jEOfR+d3I9r7uVtMmhh7ffjtT7bvTYjvWW9PPL7szxroyTuvL6/vTVzPW42eUq vSd07Glk787O27UK/6zLJ/b8vvQoL9EBs9qohPZpz01CH6VMT3d5z4N8//Lp+3lhLfLMJXeU Nt0ZNBmmrcSLn4+Fb/icm3jo4rkKzvgTO9+Pz34ZTNfZOotj8ubi6vmYXrt4LuCOgZ4ru9RN Ak3Xh81G3fobDlwlH/tzv4oNaPsk9fpAz61XfUbZW3kE8+60H7Jyaztab9eFnPu6v/xB1/wB NLOFfupUft5mSPdw/9KZyD/Vdqx1867u3D/yBQX90f8b4z9uW47+3Er9al/+4n7+ZV4xd88z 8P/sMh/8XHP/TJP/AAFA4ECCBQ0eRJhQ4cF//xI2XBjRoEOJEytexJhR40aOHT1ObBgS4keS JU2eRKlRZEqWLTmOLAizJEWVLm3exJmTociQOn3+BFqRZ1CiJGkOPDrzZVGmTZ0KPMqz51Oq VV9OtZoVQNKkRjd21RpWbEawBKWWHZu26Eq1a2OeRLswblu6aWVGPDu37l6TQ/nejAp36V/C avXKPVtYsVG/iz/SPCz0q2PKVu8yllpZM162mxEH9jrZ8+igkT0mJk06s2bUW5EqFZ1aNv/O y7Rbz3a82rBuhmYfD8Yd3KVpm3mFK87bOOdtiaA7Evd9XDrK2k+NT1+cXHtz3s+jAyeLXTxs uszHb9aONaXzmrHPv1cJvep1+PVjy3/t3v5+uZ7p8wcQqu/C0y9AA5HCr67/DpyOvYsSTJBB 7CIszDwJR3OwOfAulJDCyhbksMIBJSswRAOrgw9EE8fKUCEIVzTRw+MshLGpFh/asMYDUbxQ RR2Xy0/DEn88kcidujNSsCD7GzJJ/nh00kcnSRRQyPam7BDLB5HUsrclEXqxyw5lNFLKJG8c 8UEx2yLzyjWv4rJGyPDK8c2W4gKLIqwcanMnO+Giccc0B7Xyz+H/0LpMz/z4pM3QQ5UDEE3X mnSUPC/T7FOoTCs9EtLx0AyTU5Yg2/MtU4naVNTPPJ3txlBVpc7FU6tkKlVYt4yTshZfvdVS i760law+O8uq1GDFCnSvDCM8llM8B2QVqDbnLHbRSeszU6tl6+w1QCgLbRYjSb1N1sYRee12 PXG1/e1Ly6bMFsglmU33UHHDFdY7d6nC99Nch/sO3XoxI45YfsHrd91b49WXVoEHhjM9ib/9 ieJZE6YS4q3KVfM16EbC2NFowTR4PgKvNVnjVUum02Nh1VP5NJhXtcs0lm0cOeaY/kWZ0Xtz 1lnTexUMOtLbxiV55qJ3DHnp8ojF72an/4ucmkEZla5a0Ky9ZWzrFS32Gremw06R7LLNhhVs tFlbe+G2pRv7bX/lFpvutO1OLW68J5y4b7//BjxwwQcnvHDDD59477sVz43xtPV2vOHInZ2c L8grh/tyzJncXFTNO78U9ErVFh2w0lX9XPTUTw9u9c1dZ71V2COfPXbZat8bd9vz1l3u3ndX DfjihO+VdOI5P37x5Ntd/vHmJX/e8+hPnh71352+vnr/tJeV++KzVxl879Ebn9DyRd5vNZ/f E/981toHWED4lXS/2/ljpbp+++/vmmv9B+ZfaJ70P4gZj3wDJGAB2YfABBYwgFR6YF8aGLMI cqaCvppgvQz4Ff+pUS6DOuvXBbPzwaBtsGMaEyEJdWU6FKpwacfq4Ohc+EJbpZAwNpzhCtWl wBxiL1M4VFYPqzasGNoJiEL80BEbhMStKXFGTGyiE1sFxbBJMW9UrKIVt4fFKqJNi1zU1RdH CEaziVFEZCxjE9G4NhPKcI1snJoZ3xjGoslxjh8q4R19Z8dq6dF3LfQj3RA3SEIW0pBYC2Qi FblIRjbSkY+EZCQlOUlKVtKSl8SknDK5yZWByUvG4mQo89QVRVVpfaG8JKJ+ZT5UVlJPpcJU K1H5rHPJcpbdo1UubZlJWuYSaLsEZjATyMdGCROExAQMMo3plCKeCZHLNNQhpTlNam6MB5qP eya8mnlNMW2TSN7kZjeVaa9wltOc50RnOtW5Tna2053vhGcxoQKTU8ZTkfS01jjtmUeH7VOS UcmmP/WYJ4FCkpQFNahZ9IlQht5xoQmtXhsb2peHYiugE7WNRPFWTY521KMfBWlIRTrSivLt ohgtDjgxp1KUUuekpdNoS68iU5rW1KY3xSkAAgIAOw=3D=3D =0D ----- --PART.BOUNDARY.0.19598.emout08.mail.aol.com.848373965-- ________________________________________________________________________________
Date: Nov 18, 1996
>that uneven heating of the skins could cause even worse oilcanning and >distortion is something to consider. But I just had another thought. > To Any; Along this line, I know of one who places a saw horse under the tip and the inside spar end, then adds weights to the center and then does the wing skin. I realize that this would leave tension from root to tip, but he does get nice tight skins. It doesn't flex much, but sorta like just being a little bit pregnant--it does the intended job. I didn't believe it until I saw the 'sag' when he had it up for skinning. It convinced me that if I build again, I'll do it that way. John Darby RV6 N61764 flying Stephenville TX johnd@our-town.com ________________________________________________________________________________
Date: Nov 18, 1996
> I am using an electronic tachometer for my 6A. Where > can I get a cover to go on the back of the cable drive on the > engine? I have looked in the aircraft spruce and Wicks catalogs > but did not find it. I'd try a local FBO. When I had my (brand new, don't get me started on THAT) engine violated for the Lycoming piston pin debacle I asked if they might have a cover for the governor pad so I could take the CS prop stuff off. He handed me a huge box that had all kinds of used stuff in it and told me to have a look. It had tons of block off plates, tubes, covers etc that were removed when installing stuff on the engine. Ed Bundy ebundy2620(at)aol.com ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Re: Lower Flap Link Rod End Bearing
Because of you true believers out there, on behalf of the RV-List, I spoke today with Harvey Sturkel of Aurora Bearing (630-859-2030) regarding the use of the CM-4MS studded rod end bearing in our flap actuator mechanisms. Please don't deluge him with calls. He said that he could not recommend the CM-4MS because the stud is only made of low alloy steel of 70,000 PSI tensile strength typical (for reference, normal AN4 bolts have a tensile strength of 125,000 PSI minimum). Since the load is acting in single shear, the AN4 spec says that an alloy steel bolt is good for 3,680 lbs rated strength. I agree that the stud is probably still stronger than it needs to be, but it is clear that the AN4 fastener is considerably stronger and more resistant to bending stresses than is the stud which is not really rated as a structural fastening. Since the same AN fastener is used on the top end of the flap link, I find it difficult to believe that Van (in all his wisdom) wanted the bottom attachment to break first ;^). Further, Mr. Sturkel agreed that the inability to use captivating washers with the studded bearing makes it even more undesirable. He recommended using the standard CM-4M (non studded bearing) with an AN bolt and captivating washers, because although these bearings seldom separate, you'd never want to bet your life on it. Regards, Gary VanRemortel vanremog(at)aol.com ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Re: Insurance for Military pilots
At 10:34 PM 11/18/96 GMT, you wrote: > would you guys give me some feed-back on who you are insuring with. >Is USAA even a consideration in this area...thanks...John Lucas > > John; I did have mine with USAA, and then AVEMCO came out with the discount for EAA members. Net results was 15.00/year savings. I will go back to USAA this next year unless the BIG discount is still on. Incidentally, it is a subsidiary of USAA, not the parent firm, but still the excellent name and service. John Darby RV6 N61764 flying Stephenville TX johnd@our-town.com ________________________________________________________________________________
Date: Nov 18, 1996
Subject: Re: Interior paint type Q.
> I would like to hear from flying RVs what type/brand of paint they >used for interior surfaces ... in particular ... >How well has it held up to scrapes, dings etc.?? >Did you paint a glossy finish?? .. or did you add flattener?? >Would you use the same paint again, now it's been in service?? >Have you had to touch up any of the paint? ... was it easy? ... did it look OK? >NOTE: the above questions for INTERIORS only!! > I was considering Imron (Yes, I have a HobbyAir sytem!), but have >been told that it might be somewhat easy to chip, and hard to touch-up. > I would like to evaluate any other alternatives before buying any >expen$ive paint, and found little reference to interior paints in the >archives. Gil rassp.hac.com RV6A, #20701, N64GA rsvd. Gil, I used PPG Durethane for the interior (over Variprime, in case you're interested) and I feel that it is "wearing" pretty good. I have touched up a few nicks on the control sticks and flap handle due to being fumble-fingered when handling the seat belts and shoulder harnesses. If you have any thickness of paint at all, it is hard to make a repair to a nick. I dabbed a little at a time on the end of a match stick and tried to fill in the crater in the paint. Sometimes it works better than others. I'm also a lot more careful with metal objects in the cockpit. I thought about using a flattening agent and discarded the idea. There might be a batch to batch inconsistancy and I thought maybe the slick, shiney paint might wipe down better. As far as chip resistance goes, I'm not too sure you'd be any better off with any other type of paint. Anyway, if the flap handle gets to bugging me, maybe I'll slide a handle bar grip over it:) I intend to use a polyurethane on the next interior when the time comes. Bob Skinner RV-6 BSkinner(at)krvn.com ________________________________________________________________________________
Date: Nov 18, 1996
At 7:19 PM 11/18/96, Herman Dierks wrote: > I think 1/4 inch is better. > There are several things to consider: > 1) Your dynafocal mounts will sag over time, so the spinner will slump > down. > 2) Under G loads, the engine will move around quite a bit. > > 3) When you take the bottom cowl on and off, you need a little room > here. I glassed the top gear leg fairings onto my bottom cowl > > > . > Herman (RV4 60hrs) > dierks(at)austin.ibm.com > >> The construction manual recomends leaving 1/16-1/8" clearance between the >> spinner and the prop. I obviously want the gap as small as practical, but is >> 1/16" sufficient? It seems awfully close. >> >> Ed Bundy >> ebundy2620(at)aol.com >> A friend here just cut the nose off of his cowl and took a 1/4 section out of it to give the needed prop spinner clearance. He has a const speed prop, and only (when fitting the cowl) had a single washer as a spacer between the prop assembly and the aft spinner bulkhead. When he cycled the prop to high pitch, he did this manually, and the prop hit the bulkhead. He had to add another washer for the needed space, which in turn caused the bulkhead to hit the cowl. He was ticked off.... Doug Doug Bloomberg RV-6A (in the womb) Denver, CO dougb(at)mail.diac.com (home) doug(at)boulder.vni.com (work) ________________________________________________________________________________
Date: Nov 18, 1996
At 7:30 AM 11/18/96, Bill Phillips wrote: >Many of the nay-sayers on automobile engine conversions got me wound up >this week about crankshafts as you all know. I talked to everyone I >could get my hands on about the relative merits of the cast nodular iron >crank vs. a forged crank. ... snip ... > My bottom line as one of the test pilots is that I=92m not going to= worry >about the crank or the rods. Today, I=92m actually more worried about the >weather. > >Bill Phillips >From the Tree House at the OMABP Howdy, Please read the November and December "Circle Track" Magazine it's an excellent source for no bull technical articles dealing with Nascar racing. Yeah they talk about suspensions, but there is much talk about engines and building and means to gain power and keep it running. The above articles have 2 very long articles concerning metal (cranks, rods) types, how they were heated, the difference between hardness and toughness. The authors are the head metallurgical engineer at GM's northstar engine pla= nt, and Smoky Yunik (who I think is one of Americas best practical automotive engine men) I like "Cirle Track" a lot and I don't even get a free subscription, darn... Doug Doug Bloomberg RV-6A (in the womb) Denver, CO dougb(at)mail.diac.com (home) doug(at)boulder.vni.com (work) ________________________________________________________________________________
Date: Nov 18, 1996
> I've also wondered what effect, if any, there might be on the price of > new Lycomings now that Cessna is cranking out new 172's again (which use > a Lyc IO-360). At a guess, new parts will be more scarce and expensive because they're all being shipped to Kansas. Then, a few dead doctors later, salvage engines will become available as people with more money than sense bend perfectly good airplanes. (People with more sense than money build RVs). :-) P.S. Nothing against doctors, really. P.P.S. Please don't flame me for calling a 172 a "Perfectly good airplane." :-) -- (Sorry Randall, no more room for the Yakko Warner quote) Richard Chandler RV-6: Garage bought, saving for tools and tail kit (Christmas?). ________________________________________________________________________________
Date: Nov 18, 1996
At 7:13 PM 11/18/96, aol.com!Bcg007(at)matronics.com wrote: >Need to ask a basic question before I do something dumb. > >I'm in the process of preparing spars on a 6 for riveting. I've got >pre-drilled spars. After reading the plans (over and over and over) I can >see only 5 components that must be riveted to the assembly in addition to >what Van supplied all bolted together. These are the five 7 inch prices of >angle mounted beyond sta-68.75. > >Is this right? I don't want to drill out rivets. > >Jon Scholl >RV6 Wings Thats it John, I found that by cutting the angles before placement as shown below, it will give enough clearance to rivet/buck the wing skins, plus you may save all of 4 oz. (I have plans from 1991 s/n 21116 and the photos that came with them shows the angles cut at an angle) rivet | V +----][---- ||\ || \ || \ <-- trim angle here (cutout gives space to buck) Spar web --> || \ || \ || | <-- one of the 5 angles || | || | ~~ ~ dam ascii graphics *&^$$% Remember the spacers between webs, they are important as they transfer load from upper to lower flanges and vs/vs. I used Avery's dimple tool, you know you get one long rod that's flat at one end and turned down on the other. Well the turned down side fits a rivet gun. I think doing the Harbor Freight Arbor thing a waste of effort when a good 3X or 4X gun will really do the trick. There is much more control using the dimple tool and rivet gun. Also, put/place every bolt and nut in the spar before you rivet. Use close tolerance bolts where you can, make sure there is no binding of the rivets in the holes, either use a reamer or a new drill to provide rivet hole clearance, I found that the variprime would get into the holes and would cause a force fit of the rivets. This could cause poorly seated rivets as they couldn't expand properly (It's a real bummer to drill out one of those LONG rivets, set up the drill press, hold the spar, etc etc). The actual riveting took 1 hr per spar (place a sheet of plywood between the dimple tool and garage floor or you may tear up the floor) Support the spar so it is at right angles to the direction the rivets will be driven. Oh yeah, debur every thing, alumiprep, alodine, and variprime every thing. Use something (if you don't like variprime) with zinc chromate to give a chemical plus mechanical corrosion protection to the spar. Congratulations! You have saved $700 (1992 dollars) and have a spar whose fatigue life is DOUBLE the anodized Phlogiston spar. Doug Doug Bloomberg RV-6A (in the womb) Denver, CO dougb(at)mail.diac.com (home) doug(at)boulder.vni.com (work) ________________________________________________________________________________
Date: Nov 19, 1996
Subject: Crankshafts in the Vortec (CHAT)
Hi Bill: I don't know what prompted the crankshaft issue again. There was quite a thread on alternate engines last January. GM makes more than one crank for both styles of V-6. I will give you the part numbers and a brief description. You decide why GM goes to the trouble. It may have no significance at all for your situtation. But this is a fact - these GM parts are stronger than STOCK parts for both styles of V-6. 90 degree V-6: Part No. 14044838 - Raw Crankshaft Forging: "This raw crankshaft forging is forged from vacuum degassed 5140 steel." 60 degree V-6: Part No. 25500008 - Raw Crankshaft Forging: "...it is forged from tough 4340 steel, and it will accommodate strokes from 2.66" to 3.625". The extra large counterweights will provide proper engine balance with heavy-duty piston/rod assemblies." Reference: 1994 GM Performance Parts Catalog, pgs 84 & 96. The above quotes are from this catalog. There is more description that I left out but would be happy to mail you a copy if you e-mail me your address. Like I inferred above, increased strength and/or durability may not apply to your situation but it is a fact these parts are stronger than your current application. Whether you need them or not - thats strictly your call. I have found that a persons "comfort factor" in flying is usually based on their experience and terrain they fly over. Given your geographic situation (flying over that giant sand box) :-) you might feel quite differently than when I fly over the Trinity Alps in Northern California. When I go to Vegas I always feel a lot more comfortable when I cross that last mountain range past Yosemite and see that good old "flat" desert stretching for 1,000's of square miles. Unsuitable terrain always keeps my adrenaline up. Not being a test pilot I cant possibly bring to the task the same experience you have. However, we all want to stack the odds in our favor. Its just that some pilots want (or need) better odds than others to feel comfortable. A good example was a posting from Jim Cimino (I think) who works for GM Canada. He described quite eloquently, a very rugged and robust test cycle that GM puts the Vortec engines through. After 500 hours of severe abuse no Vortec suffered structural failure. He also made a case for the precision and statistical process control (SPC) GM uses in manufacturing. He even stated that Total Indicated Runout (TIR) on the cranks was about 2.5 - 3.0 microns! Sounds very impressive until you learn that GM manufactures .0005" oversize bearings because they "selectively fit" undersize cranks. With SPC they dont throw undersize parts away. Every dollar counts and they have adopted ways that minimize their scrap. Im not saying this is bad. With the economies of mass production, now days, the auto manufactures produce good parts that will not fail within their operating envelope. But is that the same environment for a aircraft motor? What one wants to know is where IS the failure point! What IS the cycle life! If that Vortec engine continued on its merry way and finally failed at 1500 hours one could feel comfortable buying a new one every 500 hours knowing it has a 3:1 safety factor. Since none of these motors have been abused (tested) to their failure points - where is that weak link? If that engine failed at only 600 hours, given the variances of mass production, should one fly that motor to 550 hours before throwing it away? I sincerely appreciate your continued postings to this list. You are collecting and sharing data for all of us and we are all learning from your experiences. Elon elon.o(at)worldnet.att.net ________________________________________________________________________________
Date: Nov 19, 1996
Subject: VS-407/front-spar connection
I need a little help. I just drilled my VS-601 to the VS skeleton. The top (in the jig) holes in the VS-407 centre rib (the ones which also go through the front spar) went through the top edge of the flange of the VS-407. This is due IMHO to the slope of the front spar relative to the rib. Here's a crude ASCII pic of the situation... side-on view... Obviously the spar doesn't really slope that much. The hole is located at the 'v' in the diagram. \ Front \ \ spar \ \ flange \\ \ \X Rivets \ V\\ \ ___-__\\ \| v | \ | | \ |VS-407| |flange| What I'd like to know is how to fix this? Should I rivet a doubler between the spar flange and VS-407; if so, what size/shape should the doubler be? Bear in mind that the holes are too be dimpled for flush rivets through the skin. Having drilled the skin to the skeleton, I guess any disassembly of the skeleton is going to involve a whole new VS :-( I can't believe I'm the first/only person to do this (the holes are dead in the middle of the flanges of both the spar and the rib), but there's no mention of it in the archives, AFAICT. Frank. ________________________________________________________________________________
Date: Nov 19, 1996
Cheryl, I have the tach drive cover you need , cost $5.00 plus shipping. I can be reach at 817-439-3280....George Orndorff ________________________________________________________________________________
Date: Nov 19, 1996
From: "Robert L. Nuckolls, III" <72770.552(at)CompuServe.COM>
Subject: KAB is at the printers . . .
For those who have been asking about the next issue of Kit Aircraft Builder, it goes to press today (Tuesday). We expect our issues in Wichita in about a week. Thank you for your patience . . Bob . . . ________________________________________________________________________________
Date: Nov 19, 1996
From: "Smith, Hal" <smith1h(at)macsmtpgw.spring-branch.isd.tenet.edu>
USAA does offer aircraft insurance but they sub it out. I found that there rates were not very competative on my Varieze (sorry about the plastic). Hal Smith (Working on wings) _______________________________________________________________________________
From: rv-list(at)matronics.com on Mon, Nov 18, 1996 5:16 PM
RFC Header:Received: by macsmtpgw.spring-branch.isd.tenet.edu with SMTP;18 Nov 1996 17:16:45 U
Date: Mon, 18 Nov 1996 22:34:58 GMT Subject: RV-List: Insurance for Military pilots would you guys give me some feed-back on who you are insuring with. Is USAA even a consideration in this area...thanks...John Lucas ________________________________________________________________________________
Date: Nov 19, 1996
>>that uneven heating of the skins could cause even worse oilcanning and >>distortion is something to consider. But I just had another thought. >> >To Any; Along this line, I know of one who places a saw horse under the >tip and the inside spar end, then adds weights to the center and then does >the wing skin. >John Darby RV6 N61764 flying >Stephenville TX >johnd@our-town.com > > John, Are you saying that he skins the wing while the wing is horizontal rather than vertical in the jig? Seems to me it would be very hard to maintain a constant bow in the wing and thus get the skin consistantly tight across the span since the root of the spar is so much stiffer than the tip. Also seems that some uneven stresses could be induced into the structure. Could you please clarify your friends procedure. Mike Wills RV-4 (wings) willsm(at)manta.nosc.mil ________________________________________________________________________________
Date: Nov 19, 1996
Subject: Re: VS-407/front-spar connection
Frank, What I would do is drill out the rivets joining the VS-407 to the front spar, and then trim some off the flange of the VS-407 rib so that it won't interfere with the rivet in spar line.Dimple the hole in the spar before you rivet the rib back to it.Use the factory head of the rivets against the rib flange or it will deform.If you do this in the jig the skin holes will still line up. Chris Brooks RV-6 BrooksRV6(at)webtv.net ________________________________________________________________________________
Subject: Lower Flap Link Rod End Bearing
Date: Nov 19, 1996
>>From: aol.com!Vanremog(at)matronics.com[SMTP:aol.com!Vanremog(at)matronics.com] >>Subject: Re: RV-List: Lower Flap Link Rod End Bearing > >>Because of you true believers out there, on behalf of the RV-List, I spoke >>today with Harvey Sturkel of Aurora Bearing (630-859-2030) regarding the use >>of the CM-4MS studded rod end bearing in our flap actuator mechanisms. > ... Okay, so we hear what you said "Mr. Sturkel" told you, what did Van say? Mr. Sturkel sells bearings. Van designs planes. That being the case, I'd like to hear Van's views on this since he has probably spent a *little* more time considering this problem than Mr. Sturkel. Also, are there any tech counselors out there who have a problem with the current setup? --------------------- cut here -------------------------------------------------------------- Mitch Faatz mfaatz(at)sagenttech.com San Jose, CA RV-6AQME N727MF (reserved) Empennage done, working on floor pans and seats > > ________________________________________________________________________________
Subject: Seat cushion fabrication
Date: Nov 19, 1996
They are also on my website for those who don't know how to convert the below: http://www.aftershock.org/mitch/RVstash/ I'm reworking my website now to handle lots of new pictures, multiple builders and more information, so soon there will be actual links to the above! For know, the above address work for your browser by listing the two files, seat1.gif and seat2.gif. You should be able to click on either to see them. --------------------- cut here -------------------------------------------------------------- Mitch Faatz mfaatz(at)sagenttech.com San Jose, CA RV-6AQME N727MF (reserved) Finished with empennage, working on floor pans and seats >---------- >From: aol.com!TimRV6A(at)matronics.com[SMTP:aol.com!TimRV6A(at)matronics.com] >Sent: Tuesday, November 19, 1996 3:26 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Seat cushion fabrication > ><> > >> Here are a couple of drawings I made from Bingelis' article. One is a >> sketch of each part, the other is an assembly drawing. They are in >> Macintosh PICT format. Unfortunately for those of you with DOS/Windows >> I'm not sure how you would read them unless a friendly Mac user could >> print them for you. >> Ken >> RV6A Flying > >Attached are the files converted to .GIF format, then mime encoded. > >Tim Lewis >RV6AQ #60023 > > ________________________________________________________________________________
Date: Nov 19, 1996
I'm retired military. USAA wasn't even close. Avemco/AUS have served me well for RV-6, Twin Comanche, and Bonanza. Bill Orcutt ________________________________________________________________________________
Date: Nov 19, 1996
>Claris.COM!mauser Hi All, The rv seat cushion pictures have been added to the web page. "rv.austin.apple.com" fyi, John ________________________________________________________________________________
Date: Nov 19, 1996
> Okay, so we hear what you said "Mr. Sturkel" told you, what did Van say? > Mr. Sturkel sells bearings. Van designs planes. That being the > case, I'd like to hear Van's views on this since he has probably spent > a *little* more time considering this problem than Mr. Sturkel. Also, > are there any tech counselors out there who have a problem with > the current setup? I dunno, Van has a LOT of things on his plate to worry about one little bearing he considered convenient, trim, and more than beefy enough. Whereas a salesman on a technical item has to be intimately familiar with the specs and applications of his product. I'd expect Mr. Lycoming (If there were one) to be more expert on engines than Van. There's no question about it, Van has designed one of the best damned kits on the market, and I can hardly wait to have the scratch together to get started on one. But he is not a deity. (If he were, we'd have pre-trimmed and drilled canopies). Has anyone attempted to calculate the load on that bearing at V(fe) and compared it to the spec? Consider that we now have word from the Bearing Manufacturer and Canadian aircraft inspectors that the stud bearing is being used in the wrong application. (By the way, what happens to "Mr. Sturkel sells Bearings" if the normal bearing is cheaper than the studded one? Hmmm? Anyone got prices?). -- (Sorry Randall, no more room for the Yakko Warner quote) Richard Chandler RV-6: Garage bought, saving for tools and tail kit (Christmas?). ________________________________________________________________________________
Date: Nov 19, 1996
From: "Richard E Steffens" <resteffe(at)dpcmail.dukepower.com>
Subject: Fuel tank brackets, flap rods,etc
Charles Fink wrote; Structural changes to aircraft designed by someone other than yourself should be approached cautiously.........snip I agree. Charles says it well. This list is a great forum to get ideas out, but judgement is necessary lest one jumps too quick without thorough consideration of the consequences. I'm leaving my electric flap actuator system just like it was designed, but I'm glad about the discussion. There will always be differences of opinion and interpretation and that's what makes gatherings of RVs so interesting. And Charles, thanks again for the ride in your fine -6. Now a question...How tight did you tighten your engine mount bolts? I think you had a conical mount like I have. I just got the engine on the plane, but I can't find anything on how tight to squeeze the rubber bushings. Anyone else have something definitive? I just tightened the bolts until they looked and felt about right. Dick Steffens resteffe(at)dpcmail.dukepower.com ________________________________________________________________________________
From: J.Ken_Hitchmough(at)magic.ca (J.Ken Hitchmough)
Date: Nov 19, 1996
Thanks to those who converted and posted my seat cushion drawings. A couple of comments to anyone contemplating using them: 1. Watch the thickness of the back. I put 2inches on the drawing but actually ended up with only 1 inch. 2. The width of the seat cushion can be increased if you have electric flaps. 3. The thicknessof the seat is obviously dependent on your height. A good electric carving knife is ok for cutting temperfoam. You need a steady hand but it seemed to work out ok. In the winter, the seats are hard. The right hand seat will fall on your head if you invert with no one sitting in it and its not secure with something like velcro. This happened to a very good friend of mine!!! Ken RV6A Flying ________________________________________________________________________________
Date: Nov 19, 1996
Subject: Where do I put the engine oil cooler ?
I am building an RV6A and I understand there are three places to put the oil cooler. 1) firewall 2) front cowl 3) behind the third cylinder - Orndorf said he had cooling problems behind the third cylinder. Anybody have any recommendations, I am thinking the firewall mount VANS sells may work the best ? Scott Johnson ________________________________________________________________________________
Date: Nov 19, 1996
Subject: What type of paint / primer for the engine mount ?
I am getting ready to paint the engine mount but am not sure what to use. Some builders have used high temperature engine enamel (500 degrees) and have complained that it chips to easy and then rusts. I have an epoxy primer (randolph epibond), but fear that it may not like the intense heat of the engine compartment. If I used variprime first, what would I put over it to stand the high temps ? Any advice greatly appreciated. Scott Johnson ________________________________________________________________________________
Date: Nov 19, 1996
I've insured my RV6 for five years now and have gotten numerous insurance quotes each year. Although I'm a loyal USAA customer, they have never come close to some of the other quotes. My first year was with AVEMCO, and I paid big bucks. The second year I went with COMAV through an agent in Rochester, NY and cut my bill in half. I stayed with COMAV until this year when I switched to the Forest Agency in Illinois. The policy is still underwritten by COMAV but was cheaper than the NY policy. BTW, the year I switched to COMAV I explained to AVEMCO why, their response was "oh well, take it or leave it". AVEMCO won't get my business again. Rick McBride RICKRV6(at)aol.com ________________________________________________________________________________
Date: Nov 19, 1996
I have four airplanes insured with USAA General Agency and find their rates competitive however, they are unable to find an underwriter for my uncompleyed RV-6. ________________________________________________________________________________
Date: Nov 19, 1996
Subject: Re: What type of paint / primer for the engine mount ?
Scott; I've had good luck with a common paint. The spray cans of touch up for kitchen appliances. I think they call it epoxy enamel. I did the usual- wash, use OSPHOS, sand a little, clean with coleman fuel, spray with marhide, spray with the epoxy enamel. One word of caution. The enamel says spray second coat within x minutes or wait x days. Well, I have a custom paint job. My left gear leg mount has crinkled paint. Saw a thin spot and without thinking (the story of my life) grabbed the can and put a little spray on. In about 15 seconds I had my custom crinkle paint on that spot. So far (175 hours almost 3 years) it hasn't changed color and yes, it will chip if you hit it too hard with metal, but what doesn't? It does cure out hard and smooth, just like a refrigerator. John Darby RV6 N61764 flying Stephenville TX johnd@our-town.com ________________________________________________________________________________
Date: Nov 19, 1996
Subject: Re: Temperature Considerations
Mike; I assume he does the wing in the jig and either rivets the bottom skin while in the jig or has it all clecoed, but he had told me in the past that he does the bottom of the wing first. When I saw it on the saw horses, I didn't pay attention as to the bottom skin if it was clecoed or riveted, but it was on. Some of the top was clecoed and he had started to rivet some. As for the unequal stress, I think that is true, but isn't it also true with the heated skin? He is more concerned about the smoothness of the top than he is of the bottom, as are most of us. I had tried the heat method on mine. Two electric heating pads covered with an elec. blanket and a drop light in the 'chamber' I was riveting on. Guess what? The wings have stress wrinkles when I'm flying!!! As for working on the wings out of the jig, mine were mounted on the fuselages when I put the rivets on the top skins. I had put rivets in the bottom, and a jillion clecoes in the top and kept them in a rack until the fuse. was ready for them, put them on and then did the top rivets. Hope this helps some. I have my ideas as to how I would do it next time. John Darby RV6 N61764 flying Stephenville TX johnd@our-town.com ________________________________________________________________________________
Date: Nov 19, 1996
Subject: Interior Painting of the Fuselage
I am also at the stage of needing to paint the interior of my cockpit. Unfortunately, I primed the whole thing with variprime. I believe I may end up with alot of scratches eventually showing green. What kind of durable paint can I put over the variprime that will resist the wear and tear of getting in and out of the cockpit. Scott Johnson ________________________________________________________________________________
Date: Nov 19, 1996
Although it seems that AVEMCO gets a bad rap from time to time, usually due to price (I say that because it very rare that I hear anyone say they left AVEMCO because of bad service, claims or otherwise, or because they were an undependable company), you should give them a call about a construction/reconstruction policy for your RV-6. I doubt very highly that you could come close to getting a better price for insurance on a homebuilt that is in the building stages. And they do have very competitive prices for the RV series even after it's built and flying. Anyway, it can't hurt to give them a call at (800) 638-8440. And yes, I do work for them. ________________________________________________________________________________
Date: Nov 19, 1996
> I think 1/4 inch is better. > There are several things to consider: > 1) Your dynafocal mounts will sag over time, so the spinner will slump > down. > > The construction manual recomends leaving 1/16-1/8" clearance between the > > spinner and the prop. I obviously want the gap as small as practical, but > is > > 1/16" sufficient? It seems awfully close. Oops. I wasn't very clear. Actually I meant the clearance between the spinner and the *prop*. i.e.: where the spinner cutouts go around the blade of the prop. thanks, Ed Bundy ebundy2620(at)aol.com ________________________________________________________________________________
Date: Nov 19, 1996
Subject: Re: Where do I put the engine oil cooler ?
Scott; I have an RV6. I put the cooler on the air shroud behind the left rear cyl. If there is a cooling problem, it's that it stays too cool. I use a 1/8 x1x1 angle bracket that joins the rear cross shroud to the left side shroud as a prime mounting point, then there are also two bolts on the inboard edge of the cooler to the shroud. About half of the cooler is directly behind the cly, the rest is above it. I did grind about 1/8 inch from the inside flange of the cooler to allow for vibration clearance from the eng. mount. It cools so well that I've put a ball valve in the line from the engine to the cooler and adjust while in flight. Works for me, don't know how it would fit the 6A. John Darby RV6 N61764 flying Stephenville TX johnd@our-town.com ________________________________________________________________________________
From: GHLX34A(at)prodigy.com (MR GEORGE T KILISHEK)
Date: Nov 19, 1996
Subject: rv-8 SPARS
Anybody heard any rumors (or, dare one wish, hard data) re: status of these mythical creatures? George Kilishek RV-8 SN 80006 straightening wing ribs ________________________________________________________________________________
Date: Nov 19, 1996
Subject: Where to get Temperfoam?
I'm at the stage where I'm wanting to build my seat cushions. What I want to know is, where is a good source for temperfoam to make the bottom cushions? Thanks, Mark LaBoyteaux RV-6a working sliding canopy N106RV tailspin(at)ix.netcom.com ________________________________________________________________________________
Date: Nov 19, 1996
I had my -6A motor mount powder coated at a total cost of $45. Wide choice of colors, but I took white because it would show cracks better, if they became an issue. Tried to remove a small patch to attach a ground connection, and had to get out the grinder. Stuff is tough!! Bruce Patton ________________________________________________________________________________
Date: Nov 19, 1996
Subject: Re: Where to get Temperfoam?
>-------------- >I'm at the stage where I'm wanting to build my seat cushions. What I >want to know is, where is a good source for temperfoam to make the >bottom cushions? > Thanks, > Mark LaBoyteaux > RV-6a working sliding canopy > N106RV > tailspin(at)ix.netcom.com > >-------------- Try: Temperfoam 402-470-2346 Matt -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 510-606-1001 Voice | 510-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 19, 1996
Scott, You might consider getting your mount powder coated. There are some good shops near your locale. It's a little expensive but it does a great job. Rick McBride RICKRV6(at)aol.com ________________________________________________________________________________
Date: Nov 19, 1996
From: spjohnsn(at)ix.netcom.com (Stephen Paul Johnson)
Scott wrote: > >I am getting ready to paint the engine mount but am not sure what to use. >Some builders have used high temperature engine enamel (500 degrees) and >have complained that it chips to easy and then rusts. I have an epoxy >primer (randolph epibond), but fear that it may not like the intense heat of >the engine compartment. If I used variprime first, what would I put over it >to stand the high temps ? Any advice greatly appreciated. > I would investigate powder coating technology. There is local shop here that did all of the steel parts on my empennage for $40 (the minimum charge) and they turned out great. They do a big business in finishing custom bicycle frames. I don't know how it stands up to heat. They used a light grey color, which I would recommend for crack detection. Steve Johnson RV-8 #80121 ________________________________________________________________________________
Date: Nov 19, 1996
> I am building an RV6A and I understand there are three places to put the oil > cooler. > 1) firewall > 2) front cowl > 3) behind the third cylinder > Anybody have any recommendations, I am thinking the firewall mount VANS > sells may work the best ? I used the mount from Van's on the firewall. It was very easy to install, and I'm told by people using the setup that it works well. I'll let you know tommorrow. :) Ed Bundy (1st flight scheduled for 11/20/96) ebundy2620(at)aol.com ________________________________________________________________________________
Date: Nov 19, 1996
> He said that he could not recommend the CM-4MS because the stud is only made > of low alloy steel of 70,000 PSI tensile strength typical (for reference, > normal AN4 bolts have a tensile strength of 125,000 PSI minimum). Since the > load is acting in single shear, the AN4 spec says that an alloy steel bolt > is > good for 3,680 lbs rated strength. I agree that the stud is probably still > stronger than it needs to be, but it is clear that the AN4 fastener is > considerably stronger Well, an AN5 is even stronger than that. Should we use *it* instead? Please don't take this as a flame, it isn't meant that way. I think people on this list sometimes get carried away with what I (IMHO) consider little details. So that alloy bolt is ONLY good for 3680lbs then. That means we can set the trailing edge of the flap on the ground and pile 3 RV's on top of it before it breaks? I think if you could put that much air load (don't ask me how - a Vne dive with full flaps perhaps?) on the flap you would start popping hinge eyes at the outboard end of the flap (as this end is unsupported by a linkage) LONG before you snapped that #4 bolt. Van's designs have been around a long time and have a very good safety record. If he reccomends it that works for me. He has a lot more knowledge in this area than I do. It would be a losing battle trying to beef up flap links, fuel tank supports, etc. You may end up doing more damage in addition to building an airplane that is too heavy to fly. Ed Bundy ebundy2620(at)aol.com ________________________________________________________________________________
Date: Nov 19, 1996
>I am getting ready to paint the engine mount but am not sure what to use. >Some builders have used high temperature engine enamel (500 degrees) and >have complained that it chips to easy and then rusts. I have an epoxy >primer (randolph epibond), but fear that it may not like the intense heat of >the engine compartment. If I used variprime first, what would I put over it >to stand the high temps ? Any advice greatly appreciated. >Scott Johnson Scott, I primed the mount with variprime and top coated with Centari Enamel. A better choice for a top coat would be a polyurethane as it is a little more servicable. I'd recommend pianting the mount white or some other very light color as any rust resulting from a crack in the finish will show up a little better than it will on a black mount. I've not had any heat damage to the paint on my engine mount. Bob Skinner RV-6 BSkinner(at)krvn.com ________________________________________________________________________________
Date: Nov 20, 1996
> >You might consider getting your mount powder coated. There are some good >shops near your locale. It's a little expensive but it does a great job. There has been some discussion about this previously. Powder coating has some structural properties of its own such that it is possible cracks could develop in an underlying structure but be "papered over" by the powder coat. An aircraft rebuilding shop I trust uses a polyurethane for this purpose and says it has good long term results. They use white to make crack detection easy. I have gone this route but as I haven't flown yet I can't personally vouch for it. Leo Leo(at)icn.su.oz.au ________________________________________________________________________________
Date: Nov 19, 1996
> > I dunno, Van has a LOT of things on his plate to worry about one little > bearing he considered convenient, trim, and more than beefy enough. Whereas a > salesman on a technical item has to be intimately familiar....snip If Van spent some time designing the electric flap assembly the damn thing might actually fit! I disagree with this pedestal view of Van. After modify the flap assembly to avoid having the flap arm hit the support channel I have now encountered what is apparently common knowledge thru the archives that electric flaps and tilt-ups don't mix, and have a serious collision between the flap assembly and the canopy latch torsion tube. What burns me is to yet once again be given the "well the factory retro-fit planes didn't have any problem" insinuating that I'm either imagining the problem, that my plane is so far out of tolerance that I created the problem, or that I must be not be reading the archives correctly because NO ONE else has ever reported such a problem. Because of an errant Chevy Caprice, perhaps my problem will be validated in the near future when electric flaps get selected for the rebuild. Blindly accepting the status quo doesn't seem prudent in any arena. And questioning a man's opinion because he's a salesman vs. a designer?? whoa, last I knew Van got paid selling kits, not designing them. There, I feel better now. kevinlane(at)sprintmail.com, 6A, persuing velcro canopy latch! ________________________________________________________________________________
Date: Nov 20, 1996
Subject: Re: Constant Speed Prop
<< The same appears to be true for Governors, by the way. Shocked at the way the price of the Woodward governor has gone from $875 to $1200 in 15 months, I started looking for a used one. One of the prop shops I called told me that his WHOLESALE price on that governor was $1700. BEst Regards, Dave Barnhart barnhart(at)a.crl.com >> Look for my post on ths gov. prices- EMI in Tulsa will sell you one for $325. Mark ________________________________________________________________________________
Date: Nov 20, 1996
Subject: Re: RV-List Re: RHV Airport Vote
Folks- It is my great pleasure to inform those of you who have followed the long tortuous and sordid story of Reid-Hillview Airport in Silicon Gulch, that the Santa Clara County Supervisors have voted 3 to 2 against the closure of RHV. This is excellent news but somehow I can't believe that the fight is over. For now the planes still fly. The pilot turnout was incredible and for the most part speakers for the airport presented logical arguments to counter the emotional and inflammatory rhetoric provided by several local homeowners and airport detractors. A good time was had by all. vanremog(at)aol.com ________________________________________________________________________________
Date: Nov 20, 1996
<< I am building an RV6A and I understand there are three places to put the oil cooler. 1) firewall 2) front cowl 3) behind the third cylinder - Orndorf said he had cooling problems behind the third cylinder. >> Most of the 6s in my area have the oil cooler mounted behind the 4th cylinder (port side rear). I haven't seen any behind number 3 (I've been told #3 runs the warmest so this would probably be a bad idea). These people with the oil cooler mounted behind #4 have been to Arizona in the summer and had no problems. George actually hooked his lines up different than recommended by Lycoming and used undersized lines so that may have contributed to his difficulties. The correct ports on the new engines are out to cooler thru the port just above the governor pad and in from the cooler thru the port to the left of the crackcase breather on both the O-320 and O-360. Both ports are 3/8" NPT. Follow Lycomings and Van's advise on hook up and line size (1/2") and you'll be okay IMHO. vanremog(at)aol.com ________________________________________________________________________________
Date: Nov 20, 1996
<< So that alloy bolt is ONLY good for 3680lbs>> Go back and read my post. I said that the AN4 bolt is rated at 3680 lbs. Aurora does not rate the stud because they don't consider it a structural fastening. <> Suit yourself. I had an obligation to inform and I have fulfilled it. Thanks for your opinions and observations. Gary VanRemortel vanremog(at)aol.com ________________________________________________________________________________
Date: Nov 20, 1996
Try a medical supply store. There is a chain in Ontario that specializes in supplies for the disabled. Temperfoam and Sunmate are used for cushions and mattress pads. The contour forming material provides comfort for those with restricted mobility. David Fried dfried(at)dehavilland.ca ______________________________ Reply Separator _________________________________ Subject: RV-List: Where to get Temperfoam? Date: 11/19/96 11:26 PM I'm at the stage where I'm wanting to build my seat cushions. What I want to know is, where is a good source for temperfoam to make the bottom cushions? Thanks, Mark LaBoyteaux RV-6a working sliding canopy N106RV tailspin(at)ix.netcom.com ________________________________________________________________________________
Date: Nov 20, 1996
Scott, since I made the video I've talked to alot of people with the cooler behind the #3 and are pleased with the cooling. The best place is ahrd to say all three places work it depends on what you want......george Orndorff ________________________________________________________________________________
Date: Nov 20, 1996
>If Van spent some time designing the electric flap assembly the damn thing might >actually fit! I disagree with this pedestal view of Van. After modify the flap >assembly to avoid having the flap arm hit the support channel I have now encountered >what is apparently common knowledge thru the archives that electric flaps and tilt-ups >don't mix, and have a serious collision between the flap assembly and the canopy latch >torsion tube. Kevin; Certainly not to 'flame' you. But so others who are contemplating installing the elc. flap kit after completion of construction-- I did it and had absolutely no trouble getting it all to go together and clearing other stuff. I did order the modified assembly, my welding looks as if dirt daubers did it. And I do have a tilt up. Please don't take this as an implication that yours is wrong, Hell, with my luck it could be that mine was in error in just the right places and therefore fit together just right. At any rate, I sure can't go along with the idea that Vans didn't design it right. John Darby RV6 N61764 flying Stephenville TX johnd@our-town.com ________________________________________________________________________________
Date: Nov 20, 1996
Subject: What's KAB?
---------- Forwarded Message ---------- From: Larry Portouw, INTERNET:72170.1636(at)compuserve.com RE: Europa_Mail: What's KAB? >What's "Kit Aircraft Builder?" All three of those >words sound interesting... Kit Aircraft Builder is a new publication (now printing its 5th issue) comming on line in California. It's put together by one Charles Coyne who used to publish for the hobby automotive crowd. Chuck and I have co-misserated about the dearth of periodical publications truly devoted to building airplanes. The first issues of Sport Aviation were probably a few sheets of paper run on Paul's mimeograph machine and contained NOTHING but builder help info. Now, if you divide the total pages of current publications (which purport to support builders) by the number of pages devoted to builder issues, I'd be surprised if the number exceeds 20% on most rags, less than 10% on others. Now, I'm NOT whacking on any particular magazine . . . their managers have made personal/business decisions about where their product should be going . . . none-the-less, I believe and many join me in the notion that there's a new opportunity to service the builder INDUSTRY. I've joined the editorial staff of KAB and will supply a feature article plus a regular Q/A column in every issue. I'll also be looking for topical articles from YOU . . . the builders . . . that can be put together for publishing. If you don't fancy yourself a writer, let's co-author something . . . I'll help. If the amateur built industry is to thrive, it must become BETTER that BPC&M ever were. In many respects (performance, cost, regulation) we've achieved that goal but there's a LONG way to go. Timely, open forum communications and sharing of ideas is key to our future success. It's my goal that KAB, along with the AeroElectric Connection, become an integral part of the communciations channel. All of my subscribers will be receiving a sample copy of KAB in the next few weeks (they are off the press yesterday). Sample copies are avialble to anyone who is interested in looking it over . . . drop a note to Charles Coyne at 102125.2540(at)compuserve.com. Anyone with an idea to share or a request for coverage on some topic can forward their thoughts to either Chuck or myself. KAB and/or the 'Connection could go the way of those before us . . . sell advertising, do mass promo mailings, offer credit cards and overpriced insurance, etc. . . . or they can become useful tools to those who pay the price of a subscription. Treat them like your own and let us know what you NEED to see in print or SHARE with those who follow you. Folks, we can do something really good here . . . Regards, Bob . . . AeroElectric Connection //// (o o) ==========oOOo=(_)=oOOo========== | | | Go ahead, make my day . . . | | Show me where I'm wrong. | ================================= 72770.552(at)compuserve.com http://www.aeroelectric.com ________________________________________________________________________________
Date: Nov 20, 1996
Subject: Electric Flaps & Tip-Up
There has been some discussion on the list lately about the interference from the electric flap option and the tip-up canopy's latching mechanism. I'm not sure if this is covered in the archives, but I have both and had no problem installing either. The trick is to install the weldment for the canopy latch prior to fitting the electric flap motor brace. If the flap assembly is installed first and per the drawings, the canopy weldment will hit the flap's diagonal brace. At this pint, I know of no other alternative but to redo the flap brace. If the weldment is already in place, the diagonal channel can be positioned behind the weldment. This involves adding a 3/16" spacer between the diagonal flap motor support and it's attachment tab. As far as the flap weldment hitting the above referenced brace, don't just blindly follow Van's given dimensions for it's position on the floor. Use it as a starting point, hook up a battery and cycle the motor through it's full range. After your satisfied that you have the proper clearances then drill the upper and lower portions of the brace. I'm not flying yet, but my canopy opens and both flaps go up and down. Scott Gesele N506RV scottg(at)villagenet.com ________________________________________________________________________________
Date: Nov 20, 1996
Subject: Re: RV-List:Fly the airplane
Listers: Yesterday they published the transcript of the cockpit voice recorder for the ValuJet incident. It was hard to read but something leaped from the page that was a lesson for us pilots: as the aircraft was developing an obviously serious problem, the recordings show that the business of FLYING THE AIRPLANE was getting done in the front office. The pilots were communicating with tower control and reporting back altitudes and instructions. Amazing, considering the commotion occuring behind them. It seems they flew until the flying couldn't be done any more. The lesson: things happen. Think. FLY THE AIRPLANE. Hats off to them............ Michael ________________________________________________________________________________
Date: Nov 20, 1996
>Van's designs have been around a long time and have a very good safety >record. If he reccomends it that works for me. He has a lot more knowledge >in this area than I do. It would be a losing battle trying to beef up flap >links, fuel tank supports, etc. You may end up doing more damage in addition >to building an airplane that is too heavy to fly. > Hey, flyers: have any of you lucky builders that are flying (or anyone else, for that matter) ever had any evidence of an impending or actual failure of the flap end bearing?? This is sounding like lots of spike about something that might acutally not be a problem. If we are seeing a lot of failures or excessive wear or other indications of a problem, a fix is in order. If this is just an area of worry without evidence of a real problem, perhaps the original disign is adequate and should be left alone. Just a thought............... Michael RV-4 232SQ mikel(at)dimensional.com ________________________________________________________________________________
Date: Nov 20, 1996
Listers: If it isn't broke, don't fix it. I've got over 800 Hr on my -6 with no noticable wear in the flap rod end bearings. Unless I see a bad wear problem, I don't expect it to fail. I ALWAYS put the flaps down 20* at or below 110 MPH, and to 40* at 100 MPH. Again, no noticable wear ANYWHERE in the flap system. I said it before, and I'll say it again. If the original design is adequate, why fix it? AS with the rest of flyings mechaical problems, Good preflight inspection techniques should show you the indications of problems long before they happen. So what's all the fuss about? Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com dimensional.com!mikel(at)matronics.com writes: >Hey, flyers: have any of you lucky builders that are flying (or anyone else, >for that matter) ever had any evidence of an impending or actual failure of >the flap end bearing?? This is sounding like lots of spike about something >that might acutally not be a problem. If we are seeing a lot of failures or >excessive wear or other indications of a problem, a fix is in order. If >this is just an area of worry without evidence of a real problem, perhaps >the original disign is adequate and should be left alone. > >Just a thought............... > >Michael >RV-4 232SQ >mikel(at)dimensional.com > > ________________________________________________________________________________
Date: Nov 20, 1996
> I had tried the heat method on mine. Two electric heating pads > covered with an elec. blanket and a drop light in the 'chamber' I > was riveting on. Guess what? The wings have stress wrinkles when > I'm flying!!! That's because with the drop light you heated the skin unevenly. The article in the 14/16 Years of the RVAtor pointed out how if you were to take a sheet of aluminum and point a heat gun at the middle, it would bulge up. And if you heated one spot on the edge, the whole sheet would warp like a curved peice of slot car track. OTOH, the pre-stressing the wing when skinning the top sounds interesting. Does anyone have any figures for how far the wing tip deflects between rest and cruise? -- (Sorry Randall, no more room for the Yakko Warner quote) Richard Chandler RV-6: Garage bought, saving for tools and tail kit (Christmas?). ________________________________________________________________________________
Date: Nov 20, 1996
Subject: Re: Interior Painting of the Fuselage
<< I am also at the stage of needing to paint the interior of my cockpit. Unfortunately, I primed the whole thing with variprime. I believe I may end up with alot of scratches eventually showing green. What kind of durable paint can I put over the variprime that will resist the wear and tear of getting in and out of the cockpit. >> I used a Dupont paint that contains Vinyl that is used to paint dashboards and other interior surfaces of cars. I used it on my IP and other interior surfaces that are not covered by fabric. It is durable and cleans up real well. It also goes on very nice. Gary Corde RV-6 N211GC ________________________________________________________________________________
Date: Nov 20, 1996
Subject: Rod End Bearings
This will be my last .02 on the rod end bearing issue. Its turning personal which inhibits true exchanges of opinions. This is not intended to flame or criticize anyone. That said here is my response to some issues raised. I don't put Van on a pedestal. He makes mistakes. The changes I have marked on my plans and made to the kit parts (some after the parts were assembled) bear this out. I also don't put IAs on a pedestal but I do respect their opinion. I also evaluate all advice before applying it. As for engineer vs. salesman vs. craftsman, I worked construction quite a few years and have found that on most projects there is at least one instance and very often numerous times that the craftsman constructing the building find engineering errors or have a better way of doing some aspect of the project. Therefore I don't automatically take the word of the engineer over the craftsman or salesman. I consider the knowledge and experience of both and rely on my own judgment as how to proceed. YOU should also. It is your life that is on the line when you fly that plane you built. Look critically at all aspects of your project. Issues: The critical loads on the CM-4MS stud or the AN bolt that will be used to connect the flap to the actuating rood are BENDING loads not shear so the load given for the AN bolt in single shear does not apply in this instance. A bolt loaded in this fashion will fail well below the shingle shear value. Single shear conditions occur when the two items bolted together are in contact with each other. The load enters the bolt near the center of the first item and exits the bolt near the center of second item. This introduces small bending moments in the bolt but these are minor due to the short moment arm (the distance between where the force enters the bolt and where it exits) but the primary load is shear in this case. In the flap case a stand off must be placed between the flap bracket and the bearing to allow clearance between the fuselage side and the bearing. This stand off creates a relative large moment arm (distance between the center of the bearing and center of the bracket) thus the critical loads on this bolt are due to the bending moment. Issue: The stud in the bearing is weaker than the AN bolt therefore the AN bolt is better. Tensile strength is only one parameter to consider when selecting a material for a specific application. Look at the main spar. The bars used to carry the loads are 6061-T6, tensile strength 42 Ksi. This is not just Van's whim 6061 is used throughout the aviation industry for structural members. Why not 2024-T3 at 63 Ksi or 7075-T6 at 70 Ksi? In buildings the standard steel used for members subject to bending loads is 36 Ksi where as reinforcing steel for concrete which is subjected to tension and compression is 60 Ksi and tension only members such as cables for prestressed concrete beams and suspension bridges are typically 100+ Ksi. Why? The basic answer is that the lower strength material PERFORMS better when subjected to moment loading. Its the standard engineering attempt to balance all factors. For an in-depth answer ask a structural or mechanical engineer. They will talk about ductility, brittle fracture, failure modes, fatigue strength ..... Bottom line, the CM-4MS has been tested under the loading conditions that the bearing will be subjected to in the RV. Aurora publishes allowable load tables for this bearing and it will perform very well as long as the loads are within the allowable limits. I don't think there is anything published on allowable bending moments in AN bolts because most design manuals say don't load an AN bolt that way. I do not intend to do the analysis to determine the loads on or stresses in the stud or AN bolt because I built my plane per the original design which appears to be adequate and with over 1,000 planes flying without one recorded failure of that part there is substantial data to validate the design. If you choose to make the change then it is up to you to do the engineering and testing to validate your design. My original intent was to demonstrate that apparently minor changes can have major unforeseen consequences like enlarging the fuselage cut-out for washer clearance, but that thought got lost in the forest while we were looking at the trees. As for those of you living in Canada I would make these points to the IA requiring this change: 1. The bearing in question is being used under loading conditions the bearing was designed and tested for and 2. Capture washers are a good RECOMMENDED construction practice but, installing capture washers in this instance requires using a AN bolt in a critical location in a manner design manuals frown upon. If they persist you have two recourses. Be antagonistic and ask the IA sign his new untested design there by accepting the liability of his change (American FAA inspectors will only make recommendations for this reason), or document the IA's name and required change in your log book so in the remote chance of problems later you have evidence the change was not arbitrary and was not initiated by you. Charles Fink, RV-6 flying chfink(at)envc.sandia.gov Albuquerque, New Mexico, USA ________________________________________________________________________________
Date: Nov 20, 1996
Subject: Re: Lower Flap Link Rod End Bearing
>>If Van spent some time designing the electric flap assembly the damn thing >might >>actually fit! I disagree with this pedestal view of Van. After modify the >flap >>assembly to avoid having the flap arm hit the support channel I have now >encountered >>what is apparently common knowledge thru the archives that electric flaps >and tilt-ups >>don't mix, and have a serious collision between the flap assembly and the >canopy latch >>torsion tube. > >Kevin; Certainly not to 'flame' you. But so others who are contemplating >installing the elc. flap kit after completion of construction-- I did it and >had absolutely no trouble getting it all to go together and clearing other >stuff. I did order the modified assembly, my welding looks as if dirt >daubers did it. And I do have a tilt up. Please don't take this as an >implication that yours is wrong, Hell, with my luck it could be that mine >was in error in just the right places and therefore fit together just right. >At any rate, I sure can't go along with the idea that Vans didn't design it ^^^^^^^^^^^^^^^^^^^^^ >right. ^^^^^ Actually, I disagree with this statement. I made a scale drawing following _all_ of the dimensions given in the plans, and the tilt-up canopy latch bar DOES interfere with the flap drive foward channel. I even sent the drawing to the factory. Since the factory does not always seem to follow their own dimensions (see the factory response to making the baggage floor ribs fit - "just move them"), it's not surprising that designing options using the factory prototypes leads to customer 'misfits', and then justifying it by saying they weren't built correctly. See the archives for more discussion on this subject ( Hotline quote: "you are the third person this week") - I was the person making the original warning in June 1995. Personally, I was hoping that the QuickBuild kits would lead to a flurry of plans changes for the RV6, but the RVator seems to be having less and less plans revisions. I still have not seen any RVator comments on the flap/canopy latch bar interference problem -- which a fair number of us on the RV-list have experienced. I bet a pint of good beer that the assembly operation on the QB kits works to it's own marked up set of prints -- just like Art Chard did with the original RV4 fuselage bulkhead spacing dimensions. Can anyone either confirm or deny this?? .... Gil (prefer accurate dimensions) Alexander gil(at)rassp.hac.com RV6A, #20701, N64GA rsvd. >John Darby RV6 N61764 flying >Stephenville TX >johnd@our-town.com ________________________________________________________________________________
Date: Nov 20, 1996
Subject: primer response
> from earlier, George Orndorff wrote: >Mike , >I used Vari Prime on all the parts of my airplane before they go together, >seems to work good....George Orndorff George and group, When I received the tapes, I treated them like I would do a new technical book. For example, a book on a new or advanced programming language. I read the whole thing and don't attempt to learn it all on the first pass. In rapidly scanning the tapes, I missed your emphasis on priming. I was looking at the project as a whole. Now, I'm really building. The first pass of the tapes convinced me that the project was do-able. Now, many $$$ into tools and stuff, I'm finding that the tapes are saving me a lot of learning curve time and frustration. Thanks for the help, Mike Weller RV 80187 (under construction) midibu(at)hsv.mindspring.com (preferred) or mike.weller(at)msfc.nasa.gov ________________________________________________________________________________
Date: Nov 20, 1996
It would still be nice to have some hard numbers for the Canadian builders to throw back in the face of the Canadian inspectors. Assuming 40 degrees of flaps at 100 MPH, what is the load on the rod end? (It's been a while since someone posted formulas to the list :-) -- "Wait a minute, you expect us innocent children to climb up dangerous scaffolding and paint naked people all over a church? We'll do it!!" -- Yakko Warner, Animaniacs "Yeah, I've got ADD, you wanna make something of.... oooh, cool. Look!" ________________________________________________________________________________
Date: Nov 20, 1996
>I am getting ready to paint the engine mount but am not sure what to use. >Some builders have used high temperature engine enamel (500 degrees) and >have complained that it chips to easy and then rusts. I have an epoxy >primer (randolph epibond), but fear that it may not like the intense heat of >the engine compartment. If I used variprime first, what would I put over it >to stand the high temps ? Any advice greatly appreciated. > >Scott Johnson Dear Scott, I would like to refer you and the rv-list to an article written by John Schwaner of Sacramento Sky Ranch. He has written several articles for the Maintanance Section of AvWeb. This particular article describes the fallicies and truths of paints to be used in the Engine compartment. In particular, John suggests the merits of using white or, better yet, a metallic(aluminum) paint for the engine mounts. He additionally suggest the proper colors to be used on certain accessories in the engine compartment as well as on the inner surface of the cowling. He also explains the merits of shields and doing nothing at all. He does not suggest types of paints to use, but we are already aware of many of these options. Lou Willig ________________________________________________________________________________
Date: Nov 20, 1996
From: lsmith(at)coastalnet.com (Louis E. Smith Jr.)
>Chet, hi > >You need something like an HC-C2YK/7666-2, a Mooney prop. But good luck >finding a used one. If you do, and they have an extra one, let me know >immediately. I am resigned to buying a new one. > >Phil #80005 O-360, CS >arter(at)ncar.ucar.edu > >>I'm thinking about shopping for a used C/S prop for my 6A. What >>information about a prop is necessary in order to match a C/S to my 0360 >>A1A from Vans. >>-- >>Chet Razer >>crazer(at)egyptian.net >> >> >> > > Hi, Contact Whit Whitson at Crossville Flying Service (TN) 615-484-5016. He has a McCauley prop off of a late model Mooney. It only had 67hrs ttsn, but had a prop strike. He has since sent it to a prop shop and has had it repaired. I think it was 73" long, but some guys have cut these props down to 70" without yellow tag. Don't quote me but I think it can be had for some where in the $2500.00 range. Louis Smith lsmith(at)coastalnet.com RV-8 #80126> ________________________________________________________________________________
Date: Nov 20, 1996
>The same appears to be true for Governors, by the way. Shocked at the way >the price of the Woodward governor has gone from $875 to $1200 in 15 >months, I started looking for a used one. One of the prop shops I called >told me that his WHOLESALE price on that governor was $1700. > >BEst Regards, > >Dave Barnhart >barnhart(at)a.crl.com >rv-6 sn 23744 >Trimming the canopy > > > Dave, Mark Frederick put me in touch with EMI in Tulsa, OK. 1-800-851-4392 Tell them you are an experimental and don't need a yellow tag. I just bought a fresh overhauled governor for my IO-360 for 325.00. Louis Smith lsmith(at)coastalnet.com RV-8 #80126> ________________________________________________________________________________
Date: Nov 20, 1996
Subject: Re: Electric Flaps & Tip-Up
Scott Gesele wrote: > > There has been some discussion on the list lately about the interference > from the electric flap option and the tip-up canopy's latching mechanism. The trick is to install the weldment for the > canopy latch prior to fitting the electric flap motor brace. (I didn't thinking if it was included with the fuse kit it was intended to be installed then.)If the flap > assembly is installed first and per the drawings, the canopy weldment will > hit the flap's diagonal brace. (Van's denies this problem exists) At this pint, I know of no other alternative > but to redo the flap brace. If the weldment is already in place, the > diagonal channel can be positioned behind the weldment. This involves > adding a 3/16" spacer between the diagonal flap motor support and it's > attachment tab. > > As far as the flap weldment hitting the above referenced brace, don't just > blindly follow Van's given dimensions for it's position on the floor. Use > it as a starting point, hook up a battery and cycle the motor through it's > full range.(in fact it WILL collide with the brace as drawn) After your satisfied that you have the proper clearances then > drill the upper and lower portions of the brace.(so for $200+ you want drawings too?) > > >LESSON LEARNED? read the directions, um, I mean, read the archives :-) ________________________________________________________________________________
Date: Nov 20, 1996
Subject: AIRBORNE!
Well, after 25 months and a couple of quarts of blood, RV6A N427EM lifted off from the Caldwell, ID airport at 12:30 pm today! The C182 chase plane made a valiant effort, but I had to keep sneaking up on it from behind for the necessary visual inspections and photos. The flight was 100% uneventful. The aircraft flew beautifully straight, with no heavy wing tendancy, and the most difficult part of the flight was trying to keep the power up and lose altitude at the same time. What an amazing airplane! I want to offer my sincere thanks to everyone on this list for their help, moral support, and technical knowledge that got this bird off the ground. Ed Bundy (FLYING!) Boise, ID ebundy2620(at)aol.com ________________________________________________________________________________
Date: Nov 20, 1996
aol.com!RV6junkie(at)matronics.com wrote: > > > << I am also at the stage of needing to paint the interior of my cockpit. > Unfortunately, I primed the whole thing with variprime. I believe I may end > up with alot of scratches eventually showing green. What kind of durable > paint can I put over the variprime that will resist the wear and tear of > getting in and out of the cockpit. > >> > > I used a Dupont paint that contains Vinyl that is used to paint dashboards > and other interior surfaces of cars. I used it on my IP and other interior > surfaces that are not covered by fabric. It is durable and cleans up real > well. It also goes on very nice. > > Gary Corde > RV-6 N211GC I simply painted over my variprime with marhyde. I got the idea from Jim Cone who writes our local newsletter after I saw his project. It's a nice light grey neutral color that does not reflect and If I get tired of it I'll just scuff it up and paint over it since it is a primer. It does scratch however, but I guess most paints do. The nice thing is that it's inexpensive and touch up can be done out of an aerosol can. Chet: Finishing 6A canopy latch -- Chet Razer crazer(at)egyptian.net ________________________________________________________________________________
Date: Nov 20, 1996
>That's because with the drop light you heated the skin unevenly. The article >in the 14/16 Years of the RVAtor pointed out how if you were to take a sheet >of aluminum and point a heat gun at the middle, it would bulge up. And if you >heated one spot on the edge, the whole sheet would warp like a curved peice of >slot car track. Richard; not to argue, but I think you called this one wrong. I don't have the 14/15 year thing, but I have the original article in the RVAtor. The light had a shield on it and it was moved around almost constantly in the chamber. The shield was between the bulb and the skin it was to heat, i.e., and area heater. I didn't use a thermometer on it, but I feel sure the skin was heated fairly even. Regardless, I didn't get the results that I had hoped for, for what ever reason. But I feel that it was not due to lack of attempt to heat the skins evenly. John Darby RV6 N61764 flying Stephenville TX johnd@our-town.com ________________________________________________________________________________
Date: Nov 20, 1996
Subject: Re: Epoxy in the F607BLKHD, skin overlap joint?
Can someone tell me how long the tab of belly skin should be the attaches to the bottom of the wing? I've got a dimension off the dwgs but in the manual it says the tab attaches to the wing between the spars! If that's true the dimension is all wrong! Which is correct? Thanks. Mal rvbildr(at)aol.com ________________________________________________________________________________
Date: Nov 20, 1996
Subject: Re: AIRBORNE!
rv-list(at)matronics.com,Internet writes: Well, after 25 months and a couple of quarts of blood, RV6A N427EM lifted off from the Caldwell, ID airport at 12:30 pm today! Ed Bundy (FLYING!) Congratulations Ed. Doesn't it feel good to write "Flying" after your sig instead of "canopy " or "wings" I still get a kick when I write it. Hows about a quick summary of your configuration. Ken RV6A Flying ________________________________________________________________________________
Date: Nov 20, 1996
aol.com!EBundy2620(at)matronics.com wrote: > Well, after 25 months and a couple of quarts of blood, RV6A N427EM >lifted off from the Caldwell, ID airport at 12:30 pm today! > The C182 chase plane made a valiant effort, but I had to keep sneaking >up on it from behind for the necessary visual inspections and photos. > > The flight was 100% uneventful. The aircraft flew beautifully > > straight, with no heavy wing tendancy, and the most difficult part of > the flight was trying > to keep the power up and lose altitude at the same time. What an > > amazing airplane! > > I want to offer my sincere thanks to everyone on this list for their > help, moral support, and technical knowledge that got this bird off > the ground. > > Ed Bundy (FLYING!) > Boise, ID > ebundy2620(at)aol.com Congrats Ed! Thanx for sharing you success. Well Done!! Fred> -- FC Hollendorfer RV-8, Getting Ready, Garage & Tools Wheat Ridge, CO phredyh(at)ix.netcom.com ________________________________________________________________________________
Date: Nov 20, 1996
Scott Johnson wrote: > > I am getting ready to paint the engine mount but am not sure what to use. > Some builders have used high temperature engine enamel (500 degrees) and > have complained that it chips to easy and then rusts. I have an epoxy > primer (randolph epibond), but fear that it may not like the intense heat of > the engine compartment. If the heat in your engine compartment is that intense then you had better bail out or land and run for a fire extinguisher. I painted the valve covers of the C-85 in my C-140 along with the engine mount using DuPont's Corlar epoxy primer followed by Imron. The 'high heat' paint I used on the cyl. heads discolored (darkened) but after hundreds of hours the Imron on the covers (and mount) still looks 'wet'. I am doing the same with the RV-4, and am also doing the intake tubes, pushrod tubes and misc. other (relatively low-heat) areas with the Imron. O-320. Scott N4ZW ________________________________________________________________________________
Date: Nov 20, 1996
Subject: RV6 Tail spars to jig brackets
My first real q: Time to mount the HS and/or VS spar to the jig to set the rest of the tail skeletons in place. (YEAH, Yeah. they're both done, one at a time in the jig...) the question: Got some 1.5 X 1.5 angle scrap to make the brackets. The plans say 1.5" base to hole centers. I can see no reason 1.25" won't work. If so I can use the scrap angle, save a buck or two. Please advise if 1.25" is high enough. Ken Smith RV6 tail with no holes, cept those I punch in it. kpsmith(at)cnsnet.com ________________________________________________________________________________
Date: Nov 20, 1996
>It would still be nice to have some hard numbers for the Canadian builders to >throw back in the face of the Canadian inspectors. Assuming 40 degrees of >flaps at 100 MPH, what is the load on the rod end? (It's been a while since >someone posted formulas to the list :-) > Ok, this is just an estimate. Assuming that the average person is able to lift 40 pounds with his/her right hand (in the sitting position) then since the flap handle is 18 1/2" from the hinge point to the middle of the grip on the handle end and 7 1/2" to the flap end we can assume that 40 pounds of lift on the handle end will equal approximately 98 2/3 pounds of force on the flap rod. Let's allow that someone built like me could in a panic pull 100 pounds; that still is only 246 2/3 pounds of force on the rod end bearing. That kind of force should not be a problem. By the way, I have had my flaps 20 degrees extended at up to 160 MPH and fully extended during takeoff with no damage or problems. I'd like to say that it was just for test purposes. Sorry, can't say that; it's not good to be distracted at critical times----. John Ammeter ammeterj(at)seanet.com 3233 NE 95th St Seattle WA, 98115 USA RV-6 N16JA First flight August 1990 ________________________________________________________________________________
Date: Nov 21, 1996
Subject: RV-8 Spars Are Close...
Just a quick note to let all of you RV-8 builders that I just got home from helping Wayne Stonecipher at Phlogiston (flow gist on) drill the first set of production RV-8 spars. I know it's been way too long and appologize for the delay. It won't be too long now that the machinery is up and running. A couple of weeks to deburr, anodize and rivet them together and we'll be ready to start shipping. I know I'm more than a little prejudice but, they really look great! We are finishing up the fuselage and getting ready to start on the finishing kit items. I think we are going to have to put together one more fuselage before releasing the kit. Too many little corrections and additions to the pre-punched skins were required for me to be comfortable without building another one. Several of the employees in the company are going to help build it after hours to avoid more delays in the project. Andy Hanna AHanna2(at)aol.com ________________________________________________________________________________
Date: Nov 20, 1996
Scott Johnson wrote: > > I am getting ready to paint the engine mount but am not sure what to use. > Some builders have used high temperature engine enamel (500 degrees) and > have complained that it chips to easy and then rusts. I have an epoxy > primer (randolph epibond), but fear that it may not like the intense heat of > the engine compartment. If I used variprime first, what would I put over it > to stand the high temps ? Any advice greatly appreciated. > > Scott Johnson Have you considered powder coating? I recently did the mount on the Cessna 170A I am restoring, and it turned out nicely. Larry ________________________________________________________________________________
Date: Nov 21, 1996
From: catbird(at)taylortel.com (TTC Carroll A. Bird)
aol.com!EBundy2620(at)matronics.com wrote: > > Well, after 25 months and a couple of quarts of blood, RV6A N427EM lifted off > from the Caldwell, ID airport at 12:30 pm today! > Hi Ed: Congratulations on your's and Seven Echo Mike's maiden flight. I am sure you are on cloud nine. Can't wait till I can write (flying) behind my name. You asked about spinner to propeller clearance. I think that 1/8 would be just about right. The "spirit" of the installation would be a very even clearance around the profile of the prop. In the Oct. 93 issue there is a very good article about spinner installation by Tony Binglis. Once again congrats. The -6A is a good airplane, the middle wheel is just on the wrong end :-) Carroll Bird ________________________________________________________________________________
Date: Nov 21, 1996
Congradulations, Ed. I'm sure you have one of those smiles on you face now! Good luck on future test flights... Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com writes: >Well, after 25 months and a couple of quarts of blood, RV6A N427EM >lifted off >from the Caldwell, ID airport at 12:30 pm today! > >The C182 chase plane made a valiant effort, but I had to keep sneaking up on >it from behind for the necessary visual inspections and photos. > >The flight was 100% uneventful. The aircraft flew beautifully straight, with >no heavy wing tendancy, and the most difficult part of the flight was trying >to keep the power up and lose altitude at the same time. What an amazing >airplane! > >I want to offer my sincere thanks to everyone on this list for their help, >moral support, and technical knowledge that got this bird off the ground. > >Ed Bundy (FLYING!) >Boise, ID >ebundy2620(at)aol.com > ________________________________________________________________________________
Date: Nov 21, 1996
Subject: Re: RV6 Tail spars to jig brackets
<< If so I can use the scrap angle, save a buck or two. Please advise if 1.25" is high enough. Ken Smith RV6 tail with no holes, cept those I punch in it. kpsmith(at)cnsnet.com >> If you have a bucking bar that will reach around the skin to let you shoot the trailing edge rivets, go ahead. You could also shoot/squeeze them after you remove this assy from the jig.... check six! Mark ________________________________________________________________________________
Date: Nov 21, 1996
> the question: Got some 1.5 X 1.5 angle scrap to make the brackets. The > plans say 1.5" base to hole centers. I can see no reason 1.25" won't > work. If so I can use the scrap angle, save a buck or two. Please > advise if 1.25" is high enough. The angle brackets you use must be tall enough so that the trailing edge of the skins when mounted over the skeleton leaves enough clearance to the horizontal member of the jig that you can reach in and squeeze your rivets. Other than that, the airplane hasn't the vaguest clue how you've mounted it for drilling and riveting. More important than this is that the holes you mount to must lie in a straight line -- both horizontally and vertically. Otherwise you'll get binding in the hinge to the control surface. -Joe -- Joe Larson jpl(at)showpg.mn.org 612-591-1037 Showpage Software, Inc. http://www.wavefront.com/~showpg 14190 47th Ave N. Plymouth, Mn 55446 Future RV-6A pilot. ________________________________________________________________________________
Date: Nov 21, 1996
Subject: AIRBORNE!
>>>>Well, after 25 months and a couple of quarts of blood, RV6A N427EM lifted off from the Caldwell, ID airport at 12:30 pm today! Ed Bundy (FLYING!)<<<<<< Way to go Ed! Now if you need a destination for your first cross-country next month come on down to New Mexico and some of us RVers will show you around. Charles Fink, RV-6 flying chfink(at)envc.sandia.gov Albuquerque, NM, USA ________________________________________________________________________________
Date: Nov 21, 1996
>the question: Got some 1.5 X 1.5 angle scrap to make the brackets. The >plans say 1.5" base to hole centers. I can see no reason 1.25" won't >work. If so I can use the scrap angle, save a buck or two. Please >advise if 1.25" is high enough. > >Ken Smith RV6 kpsmith(at)cnsnet.com Ken, This would probably work but might be a little cramped for setting the trailing edge rivets. You might think about mounting your angles on some blocks of wood that would raise the assembly an inch or so higher and then screwing the blocks to the cross member. Bob Skinner RV-6 350 hours BSkinner(at)krvn.com ________________________________________________________________________________
Date: Nov 21, 1996
>Well, after 25 months....The aircraft flew beautifully....What an amazing >airplane! >Ed Bundy (FLYING!) >Boise, ID >ebundy2620(at)aol.com YES!!!!!!!!!!! So, it IS possible....these multiple slabs of aluminum brought together can actually clear the ground!!! Me Next, Me Next (wishful thinking). Now, Ed, PLEASE don't forget your friends here on the list that lust for the feeling of the first flight. Not that you would. I, for one, have enjoyed your postings and look forward to hearing about the adventures of test flying. We ground-pounders need the vicarious flight hours you will provide. WAY TO GO Mr. BUNDY!!!! Micheal RV-4 232 SQ mikel(at)dimensional.com ________________________________________________________________________________
Subject: AIRBORNE!
Date: Nov 21, 1996
------ =_NextPart_000_01BBD79E.9201B290 Way to go Ed! That's the way to do it. Phil arter(at)ncar.ucar.edu ---------- From: aol.com!EBundy2620(at)matronics.com Sent: Wednesday, 1996 November, 20 19:25 Subject: RV-List: AIRBORNE! Well, after 25 months and a couple of quarts of blood, RV6A N427EM lifted off from the Caldwell, ID airport at 12:30 pm today! The C182 chase plane made a valiant effort, but I had to keep sneaking up on it from behind for the necessary visual inspections and photos. The flight was 100% uneventful. The aircraft flew beautifully straight, with no heavy wing tendancy, and the most difficult part of the flight was trying to keep the power up and lose altitude at the same time. What an amazing airplane! I want to offer my sincere thanks to everyone on this list for their help, moral support, and technical knowledge that got this bird off the ground. Ed Bundy (FLYING!) Boise, ID ebundy2620(at)aol.com ------ =_NextPart_000_01BBD79E.9201B290 eJ8+IiESAQaQCAAEAAAAAAABAAEAAQeQBgAIAAAA5AQAAAAAAADoAAEIgAcAGAAAAElQTS5NaWNy b3NvZnQgTWFpbC5Ob3RlADEIAQ2ABAACAAAAAgACAAEEkAYAJAEAAAEAAAAMAAAAAwAAMAIAAAAL AA8OAAAAAAIB/w8BAAAASQAAAAAAAACBKx+kvqMQGZ1uAN0BD1QCAAAAAHJ2LWxpc3RAbWF0cm9u aWNzLmNvbQBTTVRQAHJ2LWxpc3RAbWF0cm9uaWNzLmNvbQAAAAAeAAIwAQAAAAUAAABTTVRQAAAA AB4AAzABAAAAFgAAAHJ2LWxpc3RAbWF0cm9uaWNzLmNvbQAAAAMAFQwBAAAAAwD+DwYAAAAeAAEw AQAAABgAAAAncnYtbGlzdEBtYXRyb25pY3MuY29tJwACAQswAQAAABsAAABTTVRQOlJWLUxJU1RA TUFUUk9OSUNTLkNPTQAAAwAAOQAAAAALAEA6AQAAAAIB9g8BAAAABAAAAAAAAAIyNwEEgAEAFwAA AFJFOiBSVi1MaXN0OiBBSVJCT1JORSEALwYBBYADAA4AAADMBwsAFQALABgAIAAEADoBASCAAwAO AAAAzAcLABUACwAVAB4ABAA1AQEJgAEAIQAAADkzQjM1MTQyQzg0M0QwMTE4MDMxMDA2MDk3MUU1 RjI2AMAGAQOQBgCMBQAAFAAAAAsAIwAAAAAAAwAmAAAAAAALACkAAAAAAAMALgAAAAAAAwA2AAAA AABAADkAULWtPdnXuwEeAHAAAQAAABcAAABSRTogUlYtTGlzdDogQUlSQk9STkUhAAACAXEAAQAA ABYAAAABu9fZPa1CUbObQ8gR0IAxAGCXHl8mAAAeAB4MAQAAAAUAAABTTVRQAAAAAB4AHwwBAAAA FAAAAGFydGVyQG5jYXIudWNhci5lZHUAAwAGEJ7gdgwDAAcQ5wIAAB4ACBABAAAAZQAAAFdBWVRP R09FRFRIQVRTVEhFV0FZVE9ET0lUUEhJTEFSVEVSQE5DQVJVQ0FSRURVLS0tLS0tLS0tLUZST006 QU9MQ09NRUJVTkRZMjYyMEBNQVRST05JQ1NDT01TRU5UOldFRE4AAAAAAgEJEAEAAAACBAAA/gMA AJ0GAABMWkZ1epeKiv8ACgEPAhUCpAPkBesCgwBQEwNUAgBjaArAc2V07jIGAAbDAoMyA8YHEwKD EjMTD2Y0D3poZWzRAyBEbGcCgH0KgAjPxQnZOxefMjU1AoAKgYMNsQtgbmcxMDMUIBcLChLyDAFj AEAgV2FAeSB0byBnHNBFIGQhICBUEcB0J6UEIHQWICB3HJRkHNCYaXQuCoUKhVBoAxCLCoUKwHQE kEBuYwrAbC51IPIJgHUe/Ar0bBBpMTgwAtFpLTE8NDQN8AzQI5MLWTE21wqgA2AgoGMFQC0ltwqH 1yRrDDAlNkYDYTomviU2FwyCIHAG8C4FoG0hRYBCdW5keTI2AdCaQADAdANgAwBjcyqivyZfJ20G YAIwKJ8pq1cJgApuB5BkHJAsIDE5xDk2B7BvdmUG0ASQdzEgAdAxMToZ0Cx/J21URm8uvymrcnYt IvBzjnQrnzLvLbt1YmolccM03ymrUlYtTDbxOnAAQUlSQk9STkXmISG/IsMzNiQ3FCIMAe8lNjCQ FkAxIGEBgASQMiBsNSAEYAIwaAQgAHBkNSBwIAWgdQtQHgBvZnggcXUggQQgQqECYG8nBHAxIDxQ NkEHsDQy8DdFTSAi8EDhQfBCoC5mCoUDUh3TQwdAZHeJQINJRCBwaXJwF0FDIHAFQDEyOjMyQHD/ ReEEcByQPW0dcEYhIxASIP8RsRHwSBAagR4AAMANsEIB7nYHQAcwAjAgDcEXQTEg5GJ1BUBJIBHA QfAcwSJrCeBwIHMwwGFr2QuAZyBCUEKQbgqFHsB/RaQx4B/gQeFL8R3TMMBj7QeQcwrAHKB2BABC 4AMgaQuAc3AlcWkCIEG0cHpoJVBvN7BIv0WgIvBnnmgFQB4gBCAawDAlTfDnMMAxsAIwZnUqkB1S SxG/RyAFAEDRU8EH0THgYUxg+waQVVBsHKA3AFYgU/IxIDcD8B3gCoVuHNAWIGF2vxygA/BN0SCg KyAAcGMxEX9B0h3iBGA3AB6ABpAjYGP/VVAFQAqxBUBCoR3iU9k3UP55TcEKhUz2HeJHQEaABcA/ TgFB0hcwSlEHQFGgdHX/SwIFQB3iUIAHgBywB3FVcd5XHYFBwSBwAMB6XWhHEv9Kkj1tTJAeIEuh HMFFEUEBfm1XYQuAUFAXoB3RAHBr/x3BHNBU8VCgAiBCgQOgHeA/BABEkVrxT7VHIFjxbHC+LAqF BGBWIAMgUPBwR0JbWjUFkGg3gVERa1jQd/lCcGRnZgMFQBzwYIJnof5iRyBE8x3TCcAIYCsgHu0F HSAgKwMgKEZMWSBJTkchKQqFQm/tBABlRsIKhWVMUCsmKnV/Hvw97yQ3G9UlNgqFFsEAAXbAAAAD ABAQAAAAAAMAERAAAAAAQAAHMLB5+9DY17sBQAAIMLB5+9DY17sBHgA9AAEAAAAFAAAAUkU6IAAA AAADAA00/TcAAMul ------ =_NextPart_000_01BBD79E.9201B290-- ________________________________________________________________________________
Subject: Crankshafts in the RV-6A Vortec Conversion
Date: Nov 21, 1996
------ =_NextPart_000_01BBD7B8.34E381A0 Bill Phillips: I have been watching the progress of your conversion = since you first started posting to the list and am convinced it is the = way to go. You may have seen the dyno test data I supplied to the = list during the earlier discussions. If you would reply to me directly = with your E-mail address I may be able to help with specific information = re: the engines' durability. We currently are running a long term (520 = hour) durability test on the latest series engine. Hope to here from you soon. Ernie Amadio Cessna C-170-B C-FJJK e_amadio(at)vaxxine.com ------ =_NextPart_000_01BBD7B8.34E381A0 eJ8+IgQTAQaQCAAEAAAAAAABAAEAAQeQBgAIAAAA5AQAAAAAAADoAAENgAQAAgAAAAIAAgABBJAG ACQBAAABAAAADAAAAAMAADADAAAACwAPDgAAAAACAf8PAQAAAEkAAAAAAAAAgSsfpL6jEBmdbgDd AQ9UAgAAAABydi1saXN0QG1hdHJvbmljcy5jb20AU01UUABydi1saXN0QG1hdHJvbmljcy5jb20A AAAAHgACMAEAAAAFAAAAU01UUAAAAAAeAAMwAQAAABYAAABydi1saXN0QG1hdHJvbmljcy5jb20A AAADABUMAQAAAAMA/g8GAAAAHgABMAEAAAAYAAAAJ3J2LWxpc3RAbWF0cm9uaWNzLmNvbScAAgEL MAEAAAAbAAAAU01UUDpSVi1MSVNUQE1BVFJPTklDUy5DT00AAAMAADkAAAAACwBAOgEAAAACAfYP AQAAAAQAAAAAAAADNDcBCIAHABgAAABJUE0uTWljcm9zb2Z0IE1haWwuTm90ZQAxCAEEgAEAOAAA AFJFOiBSVi1MaXN0OiBDcmFua3NoYWZ0cyBpbiB0aGUgUlYtNkEgVm9ydGVjIENvbnZlcnNpb24A 0RIBBYADAA4AAADMBwsAFQAOAAIANwAEAD4BASCAAwAOAAAAzAcLABUADQA1AAwABABFAQEJgAEA IQAAAEVFOUNERDYyQTU0M0QwMTFCN0I4NDQ0NTUzNTQwMDAwAP4GAQOQBgDsAwAAEgAAAAsAIwAA AAAAAwAmAAAAAAALACkAAAAAAAMANgAAAAAAQAA5AMCOcJre17sBHgBwAAEAAAA4AAAAUkU6IFJW LUxpc3Q6IENyYW5rc2hhZnRzIGluIHRoZSBSVi02QSBWb3J0ZWMgQ29udmVyc2lvbgACAXEAAQAA ABYAAAABu9feml9i3ZzvQ6UR0Le4REVTVAAAAAAeAB4MAQAAAAUAAABTTVRQAAAAAB4AHwwBAAAA FQAAAGVfYW1hZGlvQHZheHhpbmUuY29tAAAAAAMABhB0mX0VAwAHEMIBAAAeAAgQAQAAAGUAAABC SUxMUEhJTExJUFM6SUhBVkVCRUVOV0FUQ0hJTkdUSEVQUk9HUkVTU09GWU9VUkNPTlZFUlNJT05T SU5DRVlPVUZJUlNUU1RBUlRFRFBPU1RJTkdUT1RIRUxJU1RBTkRBTUNPAAAAAAIBCRABAAAATwIA AEsCAAB4AwAATFpGdb2JCRz/AAoBDwIVAqgF6wKDAFAC8gkCAGNoCsBzZXQyNwYABsMCgzIDxQIA cHJCcRHic3RlbQKDM/cC5AcTAoB9CoAIzwnZAoAHCoENsQtgbmcxMDPPFFALChRRC/EgQgMQAyDM UGgZcQUgczoKhQqFCRseSSARgHZlIGJhCeEgd2F0EXALgGfYIHRoHHATUG8JwQQRUG9mIHkIYSAF oG4rHGARoGkCICAAkG5j4xxwHnEgZmkRoAVAE8BrCsAT0GQdoG8TwB0zb58dYxnwIEEAcCDQYW0e s3sfgiDQaQVABAAdYxzgebEhYmdvLhpPJWxZH+E/AMAkABxDEbAcsR1yZHmubiGBB5AFQGQc8GEc EXhzdXALUAiQINAhemS7CHEdRWUKwCkhBcBkBADMY3UEEB8xcy4cEB5T+xzQCGBsINAWEAtQJAMH gPMrURYQY3QtMQPwHXAeZIxFLQDAAxFhZGQd8/8cICayHJAiIAJgHHAhcR2AZGxwLkRzcAWQBpBp 6mMjMG4CEHIAwCEgH0G9FhA6KpQXwAuAB5AnKiLXAaADECNAeSwQVxxwK5A+chYQAjAtMQrAHHBy df5uAwAdQSigFaAdQgSQIoDUKDUZMWgIYSkz6SgU/x9BIaMc8CgyEbAIgQQgM2TzJH87b0hvMaAw tDWRA1LZH8NzbwIgOm1FBKAIkFcUsADAK2BvCoVDHgFuASigQy0xNzAtQkM7cECwRkpKSwqFZQZf InA/kkB2YXh4WzoyBaBtOnwVMQBEcAADABAQAAAAAAMAERAAAAAAQAAHMKBBsz7d17sBQAAIMKBB sz7d17sBHgA9AAEAAAAFAAAAUkU6IAAAAABJDw== ------ =_NextPart_000_01BBD7B8.34E381A0-- ________________________________________________________________________________
Date: Nov 21, 1996
Subject: Re: What type of paint / primer for the engine mount ?
[snip!] > There has been some discussion about this previously. Powder coating has > some structural properties of its own such that it is possible cracks could > develop in an underlying structure but be "papered over" by the powder coat. [snip!] > Leo(at)icn.su.oz.au I remember this discussion on the rv-list. As I recall, there was one person who said he had first-hand knowledge of this in his experience with auto racing. Someone else later "theorized" about it. Funny how this sort of thing sometimes gets propogated until it is a "known fact". I'm not claiming that these people are wrong, but based on this small amount of data I wouldn't be too quick to throw out powder coating as an option for my engine mount. Randall Henderson, RV-6 randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Nov 21, 1996
Subject: Re: RV-List:ELT palcement
O.K. I know this has been touched on before but I need to know a consensus. The RV's are more critical as far as locating built-in weight, especially the RV-4. Conventional wisdom/custom is to locate the ELT somewhere in the tail of the aircraft under the assumption that, if all else is destroyed, the tail and the ELT will servive (yikes). I have resigned to locate the ELT in the baggage compartment which will stick 3.3 permanent pounds back there and be rather in the way. I need thoughts on locating it forward, say on the sidewall with the attach nuts for the bracket under the cheek fairings. Is this not wise? If the airplane meets the ground hard enough to distroy the ELT, isn't most everything else gonna go too (again yikes)? Michael RV-4 232SQ mikel(at)dimensional.com ________________________________________________________________________________
Date: Nov 22, 1996
Subject: what type of paint/primer for the engine mount
The following article by Ben Owen appeared in EAA Technical Counselor News, Summer 1996, Safety Section: "Powder coating of steel tube structures makes them look very attractive, but it may not be the best solution for checking out the structure underneath. Many kit manufatururers are using Mig welding with powder coating over this, and unfortunately, the welds cannot be seen. As these aircraft age, it is almost essential to remove the powder coating to check the welds from time to time. Also, many of these welds have not been normalized after welding, which is still the recommended aircraft process. MIG welding is known to require extremely competent welders, and if cracks do generate in MIG welding, it is usually at the beginning or end of the weld. It would be particularly important when inspecting a landing gear. This is starting to show up on some two place high-wing aircraft; where MIG welds were not normalized after welding and then were powder coated." As for my first RV-6A, I used PPG/Ditzler DP-40 primer followed by Krylon automotive engine spray paint in a grey color which almost matched the Lycoming grey engine paint. Easy to apply, it left a medium gloss finish that was not prone to chipping. I intend to use this again, but maybe in a lighter color, if available. Les Williams lesliebwilliams(at)msn.com Empennage complete, RV-6A #2 ________________________________________________________________________________
Date: Nov 21, 1996
I put mine in the baggage area on the 'shelf' structure. I have the sensensich metal prop so I am not that worried about the weight at the aft end. I can still cram a lot of stuff in the baggage area and I find it is not a problem. It has a remote switch wired up in the front of the cockpit. I put the antenna inside the cockpit, next to the roll over bar. That way it has no external drag and it the plane flips over it it protected by the roll bar. Herman RV4 flying > O.K. I know this has been touched on before but I need to know a consensus. > The RV's are more critical as far as locating built-in weight, especially > the RV-4. Conventional wisdom/custom is to locate the ELT somewhere in the > tail of the aircraft under the assumption that, if all else is destroyed, > the tail and the ELT will servive (yikes). I have resigned to locate the > ELT in the baggage compartment which will stick 3.3 permanent pounds back > there and be rather in the way. I need thoughts on locating it forward, say > on the sidewall with the attach nuts for the bracket under the cheek > fairings. Is this not wise? If the airplane meets the ground hard enough > to distroy the ELT, isn't most everything else gonna go too (again yikes)? > > Michael > RV-4 232SQ > mikel(at)dimensional.com > > ________________________________________________________________________________
Date: Nov 21, 1996
>I remember this discussion on the rv-list. As I recall, there was one >person who said he had first-hand knowledge of this in his experience >with auto racing. Someone else later "theorized" about it. Funny how >this sort of thing sometimes gets propogated until it is a "known >fact". I'm not claiming that these people are wrong, but based on >this small amount of data I wouldn't be too quick to throw out powder >coating as an option for my engine mount. > >Randall Henderson, RV-6 randall@edt.com http://www.edt.com/homewing Randall, I remember asking someone at Van's factory several years ago about powder coating when I attemded the builder's workshop. It sounded like an attractive option as it was my understanding that, besides being very durable, it could be flexed quite a bit without cracking. I thought this would be ideal for the gear legs. They advised against it but I'm not sure I remeber why. It may have been because of the temps involved. Or, maybe it was just because it had not been done by the factory and therfore they had no first hand knowledge of the pluses and minuses of the process. Bob Skinner RV-6 350 hours BSkinner(at)krvn.com ________________________________________________________________________________
Date: Nov 22, 1996
[snip!] > There has been some discussion about this previously. Powder coating has > some structural properties of its own such that it is possible cracks could > develop in an underlying structure but be "papered over" by the powder coat. [snip!] > Leo(at)icn.su.oz.au >I remember this discussion on the rv-list. As I recall, there was one >person who said he had first-hand knowledge of this in his experience >with auto racing. Someone else later "theorized" about it. Funny how >this sort of thing sometimes gets propogated until it is a "known >fact". I'm not claiming that these people are wrong, but based on >this small amount of data I wouldn't be too quick to throw out powder >coating as an option for my engine mount. >Randall Henderson, RV-6 >randall(at)edt.com >http://www.edt.com/homewing I believe that Maule Aircraft now powder coats the entire fuselage of all their aircraft.. It was an option, but they had such success with it that they have made it standard. -- Jeffrey S. Davis - Phone (313)845-5224 Senior Research Engineer Advance Vehicle Technology Ford Motor Company ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Quickbuild Kits
Does anybody have a quickbuild kit in their possession, or on order? If so, what is your opinion of it? If possible, can you compare it with an owner-built project. Thanks Larry - finishing C170A restoration, and looking ahead ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Re: Quickbuild Kits
My RV-6A has been flying three years now . I built it from a kit furnished prior to all the fabrication being done for you now. I have a friend now building one of the original ten RV-6 quick build kits. Van's was not totally pleased, as I understand, with the quality of the first ten shipped and discounted them to those builders. I have had occasion to look it over pretty good and the quality is good. If the next ones off the line are even better and I were to build another ( by the way mine is an award winner), I would buy the quick build in a heartbeat even though I like building OK. The work you get for the price is unbeatable. Hope this helps. Bill Akin RV-6A N85TX ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Tools
I'm just in the planning stages of my RV6A project. I have the preview plans and will be ordering the empennage kit soon. I am looking for some help in deciding on the type of air gun that is best for the type of riveting done with this kit. Avery has the 2X and 3X and recommends checking with local builders for the particular project. Does anyone have a preference? Thanks, John Hsu RV6A starting hsubox(at)proaxis.com ________________________________________________________________________________
Date: Nov 22, 1996
> Congratulations on your's and Seven Echo Mike's maiden flight. > I am sure you are on cloud nine. Can't wait till I can write (flying) > behind my name. Thanks Carroll, it is an amazing feeling. Ed Bundy (flying) ...still have trouble believing it.... ________________________________________________________________________________
Date: Nov 22, 1996
> Congradulations, Ed. I'm sure you have one of those smiles on you face > now! > Good luck on future test flights... Thanks Fred! It is an AMAZING feeling. Ed ________________________________________________________________________________
Date: Nov 22, 1996
Subject: RV form
MODEL: RV6A DATE FINISHED: 11-19-96 (not sure if it will ever be "finished") TOTAL TIME: 3.3 ENGINE: 0320-D1A from Van's PROP: Sensenich fixed metal CANOPY: Slider STARTER: Stock Lyc ALTERNATOR: Van's VOLT. REG.: Van's solid state BATTERY: Concord RG 25 EXHAUST: Vettermans SS crossover ELEVATOR TRIM: manual FLAPS: manual BRAKES: Pilot side only TIRE PRESSURE: 30 PANEL: VFR, E.I. tach and ultimate analyzer, TKM comm, Narco Xpdr, Magellan GPS, AM/FM/cassete, G meter, (oil p&t, ammeter, voltmeter all Van's auto-type) LIGHTING: Whelen wingtip nav/strobe/position PAINT: None yet INTERIOR: See paint INSURANCE: Avemco (ouch!) but they cover 1st 10 hours. OTHER (MISC): I mounted the oil cooler on the firewall with Van's kit - installation was very easy, and with a cockpit actuated block off door the temps stay at 180 with OAT of 20F. Used Rick Robbins' heat muffs, they work well. PROBLEMS: Nothing major. Trying to keep MAP high (for engine break-in) while descending in the pattern is tough, speed brakes would be nice :) Ed Bundy RV6A flying ebundy2620(at)aol.com ________________________________________________________________________________
Date: Nov 22, 1996
I've got one, and the quality is *excellent*. I've built my own empennage and consider myself to be more anal retentive than many, and I'd say the quickbuild is as good or better than my own work. The flaps and ailerons are beautiful. Don't know what else I can tell you, were you wondering about anything specific? --------------------- cut here -------------------------------------------------------------- Mitch Faatz mfaatz(at)sagenttech.com San Jose, CA RV-6AQME N727MF (reserved) Finished with empennage, working on floor pans and seats >---------- >From: Larry Hoatson[SMTP:deltanet.com!lhoatson(at)matronics.com] >Sent: Friday, November 22, 1996 3:19 PM >To: rv-list(at)matronics.com >Subject: RV-List: Quickbuild Kits > >Does anybody have a quickbuild kit in their possession, or on order? > >If so, what is your opinion of it? If possible, can you compare it with >an owner-built project. > >Thanks >Larry - finishing C170A restoration, and looking ahead > > ________________________________________________________________________________
Subject: Re: Tools
Date: Nov 22, 1996
I used a 2x gun for my entire RV4 project and it worked fine. Sid Golden, long time tool supplier to the large aircraft companies and fellow RV builder, recommended the 2x gun. I think the 2x means it is suited for 1/8 inch rivets. The RV is built with 1/8 inch and the smaller 3/32 rivits. Sid's point was that the 2x is a little smaller and easier to work with than the 2x. Either size has enough power to destroy AL in a microsecond :). If you rivet your own spar, that is best done with another tool as described in Tony's article (the arbor press and a large hammer). The only place I felt my 2x gun was maybe underpowered was trying to back rivit the top wing. I did not like this method as you hve to driver a long dog-leg rivet set on the inside of the wing. I ended up doing it per the published plans and it worked fine. Herman dierks(at)austin.ibm.com > I'm just in the planning stages of my RV6A project. I have the preview plans > and will be ordering the empennage kit soon. I am looking for some help in > deciding on the type of air gun that is best for the type of riveting done > with this kit. Avery has the 2X and 3X and recommends checking with local > builders for the particular project. Does anyone have a preference? > > Thanks, > > John Hsu RV6A starting > hsubox(at)proaxis.com > > ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Re: Tools
You wrote: > >Avery has the 2X and 3X and recommends checking with local >builders for the particular project. Does anyone have a preference? > >Thanks, > >John Hsu RV6A starting >hsubox(at)proaxis.com John, I have a 3X and think I would go with a 2X if I had it to do again. I got over-aggressive with some rivets, which is easier to do with a 3X. On the larger rivets, it might take an extra half second to set the rivet properly, but I think it helps avoid dinging the metal. Having said that, I think you can work with either gun. Hope this helps some. Best regards, Bill Costello -- Bill Costello | bcos(at)ix.netcom.com | Building RV-6 | Reserv N97WC Want an extra hour and a half of energy per day with Super Blue Green products? Email for info or call 800-325-7544 Chicago ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Re: Tools
I built two rv-4's with a used 3X; then I helped a friend who had a 2X with a swivel head flush set. We riveted both wings without a ding in either, I'm sold! Next AC I'll be buying a 2X to complement my 3X (I think a 2X is a little light for the -4 rivets) Dan Boudro RV-4 N9167Z Albuquerque, NM dboudro(at)nmia.com On Fri, 22 Nov 1996, John Hsu wrote: > I'm just in the planning stages of my RV6A project. I have the preview plans > and will be ordering the empennage kit soon. I am looking for some help in > deciding on the type of air gun that is best for the type of riveting done > with this kit. Avery has the 2X and 3X and recommends checking with local > builders for the particular project. Does anyone have a preference? > > Thanks, > > John Hsu RV6A starting > hsubox(at)proaxis.com > > ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Where do I put the engine oil cooler?
I also mounted my oil cooler behind #4 cyl on the baffle and, like John Darby, my 0-320 ran too cool. I ended up blocking off the air inlet, like a lot of other RVers in the northwest have, to increase the temperature. I've always wondered why this worked, just like the ball valve worked for John, since there is a thermostatic valve in the engine which, I understand, should control the oil flow to maintain a minimum operating oil temperature? Does anyone have an answer to this? Also, does anyone know of an RV-6 or 6-A with an 0-360 that has experienced high oil temperatures with the oil cooler installed as above? Les Williams lesliebwilliams(at)msn.com Empennage complete, RV-6A #2 Waiting on QB tip-up 6A ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Re: Tools
The 2X gun is plenty big. Besides, it has a shorter nose piece which puts you closer to the work thus making the gun more stable. One problem I see all the time is many people use too much air pressure when setting 1/8" and 3/32" rivets and therefore beat dents into the .032 and less skins used on the RV. Use as little air pressure as possible to get a good set of the rivet. Takes a little practice. When you paint the airplane (or even before), you'll be glad. I am sure you know, but there is not a better tool supplier for this project than Bob Avery. He ain't the cheapest, but you can't beat the value of the tools he has. Good Luck Bill Akin RV-6A 85TX ________________________________________________________________________________
Date: Nov 22, 1996
From: "Calin Brabandt" <cwbraban(at)ichips.intel.com>
In response to Larry Hoatson's question about QB kits: I do not have one in my possession, but I've looked at several at Van's and they are of excellent quality. Better than most first-time builders could do, but they would probably not bring home trophies at OSH. Realistically, most builders should probably give up the fantasy of capturing such a trophy. In fact, they usually give up such delusions by the time they complete the tail kit. I think most QB kits will turn out better than the average non-QB kit, but only time will tell. With the the traditional kit however, the builder has the advantage of first acquiring skills on smaller, less expensive parts and I think the learning curve is more of a progressive "building block" kind of experience with the traditional kit. Either way, you'll get a great airplane in the end. Cal N66VR (about to start finishing kit) ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Re: Tools
John Hsu wrote: > > I'm just in the planning stages of my RV6A project. I have the preview plans > and will be ordering the empennage kit soon. I am looking for some help in > deciding on the type of air gun that is best for the type of riveting done > with this kit. Avery has the 2X and 3X and recommends checking with local > builders for the particular project. Does anyone have a preference? > > Thanks, > > John Hsu RV6A starting > hsubox(at)proaxis.com Hi John.... This is one of the standard questions (one of many) that all new builders ask. Let me suggest that you connect to WWW.Matronics.com and use the search tools at that site. This site is hosted by Matt Dralle (sp) as is this list. He mantains a database of all these questions and answers. To answer your question thou... I would get a 3x gun. Most jobs can be done with a 2x but some are easier with a 3x. Chicago Phneunatic's are among the best. Where are you located??? -- Rick(at)ccc.henn.tec.mn.us ________________________________________________________________________________
Date: Nov 22, 1996
The afternoon that I bought my tail kit from Van, there were two guys walking around and around the RV-6Q out in the front yard. Well, actually, there was always a crowd there but two guys in particular I remember helping one another up and down and looking under this and inside that and sighting down the fuselage from back-to-front and eyeballing the wingtips and so on. Finally, one of them said to the other "Well, Hell. I've got three years and *lots* more than $20,000 in my project, and it's not this done and doesn't look this good!" I've all but decided that when I finish my tail, I'm in for the discounted Q-bird, now. Mark D Hiatt OttoPilot_MSN(at)msn.com Aviation Forum Manager, The Microsoft Network "Lincoln Nebraska's Largest Manufacturer of Personal Aircraft" ---------- From: owner-rv-list(at)matronics.com on behalf of aol.com!BillAkin(at)matronics.com Sent: Friday, November 22, 1996 10:40 AM Subject: Re: RV-List: Quickbuild Kits My RV-6A has been flying three years now . I built it from a kit furnished prior to all the fabrication being done for you now. I have a friend now building one of the original ten RV-6 quick build kits. Van's was not totally pleased, as I understand, with the quality of the first ten shipped and discounted them to those builders. I have had occasion to look it over pretty good and the quality is good. If the next ones off the line are even better and I were to build another ( by the way mine is an award winner), I would buy the quick build in a heartbeat even though I like building OK. The work you get for the price is unbeatable. Hope this helps. Bill Akin RV-6A N85TX ________________________________________________________________________________
Date: Nov 22, 1996
> Does anybody have a quickbuild kit in their possession, or on order? > > If so, what is your opinion of it? If possible, can you compare it with > an owner-built project. I do NOT have a quick-build kit, but my plane is built up to quick- build stage. I have had the opportunity to look pretty closely at the quick builds however. I would have to say that if I had to make a choice between starting with a quick build and someone else's partially built first effort, I'd probably go with the quick build. One thing to remember is that when you're first starting out, you don't have an eye for the details that someone who has built or partially built one will have. Couple this with the fact that you may be going to some other state to get the thing, or even buying it sight-unseen, and it makes difficult to really know for sure what you're getting. On the other hand, the quick-build business is monitored by Vans and every kit comes through their shop and is inspected before going out to a customer. I have to admit that even though I take a lot of pride and care with my project, in many respects (not all however) the quick builds (excepting maybe the 10 or so in the first batch) look better than mine does. The primary differences are that they have worked out the "gotchas", and use a lot of tooling in the form of jigs, templates, etc, which makes for a much more consistent product and a lot fewer of the kind of mistakes that first time builders like me make. I have been able to recover from several boo-boos, but still they are "fixes" that you will not find on the quick-builds. The one area that I think my plane is a little better is in the rivet setting itself. Only a little, but I think overall I have just a little bit smoother dimples. BUT... I also have a couple of dents where the bucking bar slipped off (AARGH!!!). I suppose there may be a few of those on the quick builds but I never spotted any. Randall Henderson, RV-6 randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Nov 22, 1996
From: Jack & Diane Mahler & Joy <jax(at)brett.reno.nv.us>
Subject: Re: Tools
John, I have a 2x and 3x. I started with the 3x and found I had to dial the air down to near nothing to prevent over hitting the rivet, and had a couple of runaways (; The 2x hits faster, but is easier to control and has all the power necessary for everything but the spar, and is easier to control. Hope this helps Jax, on my 6-A wings. ________________________________________________________________________________
Date: Nov 22, 1996
<< lding one of the original ten RV-6 quick build kits. Van's was not totally pleased, as I understand, with the quality of the first ten shipped and discounted them to those builders. I have had occasion to look it over pretty good and the quality is good. If the next ones off the line are even better and I were to build another ( by the way mine is an award winner), I would buy the quick build in a heartbeat even though I like building OK. The work you get for the price is unbeatable. Hope this helps. Bill Akin RV-6A N85TX >> Bill, I agree. I don't own a quick build (working on the tail now), but saw one in San Antonio. There is no doubt I will finish using the quick build. The owner told me there was a light coating of rust on the wing spar, but he resanded as best he could and reprimed. I guess these kits go across the ocean twice. The primer the quickbuild uses is Sherman Williams (that's my understanding, and I also believe Van's uses a different mixture than recommended). So, maybe the rust is an indicator that the Sherman Williams primer is not that great or the mixture could be different. Anyway, I will still order it, take a good look at the spar for rust and reprime as necessary. I really like the Dupont Variprime. Steve, Austin, Tejas ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Re: RV form
> > MODEL: RV6A > DATE FINISHED: 11-19-96 (not sure if it will ever be "finished") > TOTAL TIME: 3.3 > ENGINE: 0320-D1A from Van's > PROP: Sensenich fixed metal > CANOPY: Slider Ed, Thanks for the info. You must have saved a blank form or pulled it off the archives? For any new listers with flying RVs, we have a blank form to fill in data about your airplane, if you'd like to participate. I don't know what key word for a search you would use for the blank form but if any of you would like one, E-mail me off list and I'll send it to you. Please post it back to the list as I'm sure there are others who would be interested. Also, feel free to add anything additional about your airplane that is not on the form. Bob Skinner RV-6 350 hrs. BSkinner(at)krvn.com ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Re: Tools
>I built two rv-4's with a used 3X; then I helped a friend who had a 2X >with a swivel head flush set. We riveted both wings without a ding in >either, I'm sold! Next AC I'll be buying a 2X to complement my 3X (I >think a 2X is a little light for the -4 rivets) > >Dan Boudro >RV-4 N9167Z >Albuquerque, NM >dboudro(at)nmia.com Dan, I agree about the 2X possibly being a little light for the #4 rivets. It seemed to be that it took too long to set them. It got the job done but I worried a little about work hardening the #4s. I built my six with a 3X and just turned the air down for the #3s. The first time I used a 2X was on the Glastar that I'm building now. The size is an advantage on the 2X and I havn't used the 2X on #4's since we got the more powerful air compressor, so maybe it will work better, now. In response to an earlier post: An earlier post talked about setting the #6 spar rivets with a 3X or 4X gun. I've never tried a #4 to set #6 rivets, but my gut feeling is that a 5 or 6X would be better. I plan on sticking with the Avery tool to set the #6 rivets. The tool works great and saves the expense of buying an arbor press. Bob Skinner RV-6 350 hrs. BSkinner(at)krvn.com ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Re: Tools
To all that responded to my questions on the air tools.... Thanks, you were all very helpful. I can't wait to get started on my project. I sounds like the quick-build will be the best way to go. I will be starting with the empennage kit to gain experience working with metal. Thanks again everyone. Regards, John > I used a 2x gun for my entire RV4 project and it worked fine. > Sid Golden, long time tool supplier to the large aircraft companies > and fellow RV builder, recommended the 2x gun. > I think the 2x means it is suited for 1/8 inch rivets. The RV is > built with 1/8 inch and the smaller 3/32 rivits. > Sid's point was that the 2x is a little smaller and easier to work > with than the 2x. Either size has enough power to destroy AL in > a microsecond :). > > If you rivet your own spar, that is best done with another tool as > described in Tony's article (the arbor press and a large hammer). > > The only place I felt my 2x gun was maybe underpowered was trying > to back rivit the top wing. I did not like this method as you hve > to driver a long dog-leg rivet set on the inside of the wing. > I ended up doing it per the published plans and it worked fine. > > Herman > dierks(at)austin.ibm.com > >> I'm just in the planning stages of my RV6A project. I have the preview plans >> and will be ordering the empennage kit soon. I am looking for some help in >> deciding on the type of air gun that is best for the type of riveting done >> with this kit. Avery has the 2X and 3X and recommends checking with local >> builders for the particular project. Does anyone have a preference? >> >> Thanks, >> >> John Hsu RV6A starting >> hsubox(at)proaxis.com >> >> > > > ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Re: Tools
Hi Rick, Thanks for the info and the reply. I am located in Corvallis Oregon. I will be looking into the WWW.Matronics.com for additional info. Thanks again. John >John Hsu wrote: >> >> I'm just in the planning stages of my RV6A project. I have the preview plans >> and will be ordering the empennage kit soon. I am looking for some help in >> deciding on the type of air gun that is best for the type of riveting done >> with this kit. Avery has the 2X and 3X and recommends checking with local >> builders for the particular project. Does anyone have a preference? >> >> Thanks, >> >> John Hsu RV6A starting >> hsubox(at)proaxis.com > >Hi John.... This is one of the standard questions (one of many) that all >new builders ask. Let me suggest that you connect to WWW.Matronics.com >and use the search tools at that site. This site is hosted by Matt >Dralle (sp) as is this list. He mantains a database of all these >questions and answers. To answer your question thou... I would get a 3x >gun. Most jobs can be done with a 2x but some are easier with a 3x. >Chicago Phneunatic's are among the best. > >Where are you located??? >-- >Rick(at)ccc.henn.tec.mn.us > > ________________________________________________________________________________
Date: Nov 22, 1996
In reference to the QB kits, I said: > The one area that I think my plane is a little better is in the rivet > setting itself. Only a little, but I think overall I have just a > little bit smoother dimples. Well, I just stopped by there to deliver some VAF mugs (order yours today!) and they were crating up a QB fuselage, and I looked it over, and... well, I'm not so sure about the above. I don't think my rivets look any _worse_ than the QBs, but I'm not so sure they look better any more either... :-( Not surprising I guess -- they've built a few of them by now so they have a lot more practice than I do! Randall Henderson, RV-6 randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Re: Tools
>I'm just in the planning stages of my RV6A project. I have the preview plans >and will be ordering the empennage kit soon. I am looking for some help in >deciding on the type of air gun that is best for the type of riveting done >with this kit. Avery has the 2X and 3X and recommends checking with local >builders for the particular project. Does anyone have a preference? > >Thanks, > >John Hsu RV6A starting >hsubox(at)proaxis.com John: If you can accept an input from an outsider (GlaStar builder) who has been reading your mail for a week or so, there are two tools that you are going to be living with for the next year or so (your rivet gun and your drill). You shoul get the best of each that you can afford. A 2x gun is all that you will need and will be much easier to control than the bigger gun. You should look for a surplus Chicago Pneumatic gun that has been reconditioned. (new ones cost several hundred dollars) There is no comparison between these guns and the new imports. They are much much better. Clinton has been a good source. You will probably spend more time with your drill and the best available is the little 1/4" Sioux. It is a little more expensive than the imports, but there is no comparison. Both Avery and Cleaveland carry them and they are both outstanding dealers. I buy from both of them and have bought Sioux drills from each. Cleaveland carrys the 3,600 rpm version though and Bob Avery does not (did not) and that is the one you want. The extra 1,000 rpm makes a big difference. Again excuse the intrusion of a lowlife GlaStar builder, but I could not figure out how to haul my girl friend, camping and fishing gear plus a folding kayak to Baja in an RV. John Top Phone: (619) 549-3556 ________________________________________________________________________________
Date: Nov 22, 1996
> the question: Got some 1.5 X 1.5 angle scrap to make the brackets. The > plans say 1.5" base to hole centers. I can see no reason 1.25" won't > work. If so I can use the scrap angle, save a buck or two. Please > advise if 1.25" is high enough. > I don't remember if 1.5" was mandatory for some clearance reason, but the brackets are not supporting much weight and do not need to be very beefy. I just bent sufficiently sized pieces of .032 aluminum into an angle and used that. Worked perfectly. Just make sure you align the holes as perfectly as possible. Dental floss works well. Ed Bundy - RV6A N427EM flying 3 days ebundy2620(at)aol.com ________________________________________________________________________________
Date: Nov 22, 1996
From: dougweil(at)mail.pressenter.com (Doug Weiler)
Subject: Baffling material
Fellow Listers: A quick question: I'm about to replace the aluminum baffling in my Citabria and was looking in the RV plans to see what material is used. I didn't see any specified. My past experience with 2024T-3 is that is a very susceptable to cracking when used as a baffle. I previously tried 6061T-6 with very good results in my 180. Opinions??? Doug -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= = Doug Weiler, pres. MN Wing, Van's AirForce, RV-4 in progress, N722DW = 347 Krattley Lane = Hudson, WI 54016 = 715-386-1239 = email: dougweil(at)mail.pressenter.com -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Re: Tools
Bob Skinner wrote: > An earlier post talked about setting the #6 spar rivets with a 3X or 4X > gun. I've never tried a #4 to set #6 rivets, but my gut feeling is that a 5 > or 6X would be better. I plan on sticking with the Avery tool to set the #6 > rivets. The tool works great and saves the expense of buying an arbor press. > > Bob Skinner RV-6 350 hrs. BSkinner(at)krvn.com I agree about the deepthroat rivet tool of Avery's. I riveted my -4 wing spars with it and I don't think you could do a much better job with any tool. I looked at a ready made spar and the rivits are not set as uniform as mine. Carroll Bird - fuselage out of jig. ________________________________________________________________________________
Date: Nov 22, 1996
Subject: Re: Tools
>If you can accept an input from an outsider (GlaStar builder) who has been >reading your mail for a week or so, there are two tools that you are going >to be living with for the next year or so (your rivet gun and your drill). >You will probably spend more time with your drill and the best available is >the little 1/4" Sioux. It is a little more expensive than the imports, but >there is no comparison. Both Avery and Cleaveland carry them and they are >both outstanding dealers. I buy from both of them and have bought Sioux >drills from each. Cleaveland carrys the 3,600 rpm version though and Bob >Avery does not (did not) and that is the one you want. The extra 1,000 rpm >makes a big difference. > >Again excuse the intrusion of a lowlife GlaStar builder, but I could not >John Top >Phone: (619) 549-3556 John, The RVer's don't mind a Glastar builder on the list once in awhile (as long as you've built a RV, first.) John is right about that Sioux drill. Being a conservative RV-6 builder and one with highly varible income (cattle business), I bought a generic, 3/8" drill and I guess it works 'cause the airplane has 350 hrs on it. However, the guy who owns the Glastar kit that I'm helping build bought the high speed 1/4" Sioux drill (from Cleaveland?) and it's a dynamite drill. Small, easy to handle and quiet when compared to mine, I told him he'd better keep an eye on it when I move to Wyoming next summer. It may just hop into my toolbox. Since I've been a very good boy, this year, I probably owe myself this little treat (approx. $ 245.00). It's been a long time since I bought anything from Avery and I'm sure he misses me. Bob Skinner RV-6 BSkinner(at)krvn.com ________________________________________________________________________________
Date: Nov 23, 1996
From: "James E. Clark" <James.E.Clark(at)worldnet.att.net>
Larry Hoatson wrote: > > Does anybody have a quickbuild kit in their possession, or on order? > RV6A Quickbuid in possesion. Purchased during OSHKOSH timeframe. > If so, what is your opinion of it? If possible, can you compare it with > an owner-built project. We have a few very experienced builders locally who have built some nice RV's. Without exception they say the quality of my QB kit is great! These are retired guys who have a LOT of experience with metal things that cheat gravity and guys who had the time to build a total of three RV's rather nicely. I am new to this but I must say that if the quality of **my** riveting etc, is anywhere near as good as that on the QB already, I will be ecstatic. Therefore, I can recommend it without hesitation. Now I must say that I have noticed some little things that I may eventually suggest to Van's as "improvements for newbies", but I want to be confident that they really make sense and are not simply weaknesses on my part. > > Thanks > Larry - finishing C170A restoration, and looking ahead James E. Clark "Marooned in seat bottoms ..." James.E.Clark(at)worldnet.att.net ________________________________________________________________________________
Date: Nov 23, 1996
Subject: Yeller Page revision online
RV listers. Gary's 11/22/96 revision of the Yeller Pages is available online at http://www.sound.net/~hartmann/yelrpage.htm - Mike hartmann(at)sound.net http://www.sound.net/~hartmann ________________________________________________________________________________
Date: Nov 23, 1996
From: Ronald Vandervort <rvanderv(at)linknet.kitsap.lib.wa.us>
Larry, I have just finished the empenage, non-prepunched, and have moved on to a quickbuild for the balance of the project. I am at about 100 hours into the quickbuild and am pleased with what I have worked with and have seen so far. It is great to be working on big assemblys for a change. I believe it is a good value..! Ron Vandervort,RV-6 ________________________________________________________________________________
Date: Nov 23, 1996
Subject: Re: Where do I put the engine oil cooler?
>there is a thermostatic valve in the engine which, I understand, should >control the oil flow to maintain a minimum operating oil temperature? Does >anyone have an answer to this? Also, does anyone know of an RV-6 or 6-A with >an 0-360 that has experienced high oil temperatures with the oil cooler >installed as above? > >Les Williams Les; I thought like you do, that the thermostatic valve would control the temp. if it had a cooler in the loop. Studying the oil system layout in the overhaul manual, it sure appeared that way. But no soap. All that I can think of is that the valve is not that well adjusted or is not sensitive enough to do the trick. Therefore, I had to add the ball valve. John Darby RV6 N61764 flying Stephenville TX johnd@our-town.com ________________________________________________________________________________
Date: Nov 23, 1996
Subject: Re: Baffling material
<< My past experience with 2024T-3 is that is a very susceptable to cracking when used as a baffle. I previously tried 6061T-6 with very good results in my 180. >> 6061 will last longer, as you noted. Mark ________________________________________________________________________________
Date: Aug 09, 1996
Subject: Re: Tools
John Top wrote: > > >I'm just in the planning stages of my RV6A project. I have the preview plans > >and will be ordering the empennage kit soon. I am looking for some help in > >deciding on the type of air gun that is best for the type of riveting done > >with this kit. Avery has the 2X and 3X and recommends checking with local > >builders for the particular project. Does anyone have a preference? > > > >Thanks, > > > >John Hsu RV6A starting > >hsubox(at)proaxis.com > > John: > > If you can accept an input from an outsider (GlaStar builder) who has been > reading your mail for a week or so, there are two tools that you are going > to be living with for the next year or so (your rivet gun and your drill). > You shoul get the best of each that you can afford. A 2x gun is all that > you will need and will be much easier to control than the bigger gun. You > should look for a surplus Chicago Pneumatic gun that has been > reconditioned. (new ones cost several hundred dollars) There is no > comparison between these guns and the new imports. They are much much > better. Clinton has been a good source. > > You will probably spend more time with your drill and the best available is > the little 1/4" Sioux. It is a little more expensive than the imports, but > there is no comparison. Both Avery and Cleaveland carry them and they are > both outstanding dealers. I buy from both of them and have bought Sioux > drills from each. Cleaveland carrys the 3,600 rpm version though and Bob > Avery does not (did not) and that is the one you want. The extra 1,000 rpm > makes a big difference. > > Again excuse the intrusion of a lowlife GlaStar builder, but I could not > figure out how to haul my girl friend, camping and fishing gear plus a > folding kayak to Baja in an RV. > > John Top > Phone: (619) 549-3556 John, Who is Clinton, and how do you get ahold of him/them. A good source for air tools?? Ed Cole emcole(at)concentric.net ________________________________________________________________________________
Subject: Re: Pearlescent Paint Process ? (2)
Date: Nov 23, 1996
>>Good Topic Bill, >> >>Learning to paint pearlescent is high on my list of priorities. I am=20 >>absolutely taken with the paint job on Nemisis and every time a = Cadillac or=20 >>Lexus passes me I say "oooh baby, that's what my plane is going to look= =20 >>like". >> >>If anyone has experience painting pearl I'd love to ask you some dumb=20 >>questions about the process. Also if someone happens to know the exact = paint=20 >>that the two guys from Nebraska (Sport Av. August, I believe) used I'd=20 >>greatly appreciate the info. >> >>Eric Henson >>>>>While you're at it, comment on the difference between settling rate = of=20 >>the >>newer mica-based pearlescent finishes vs aluminum metalflake.<<<<<<< >> >>Bill Boyd >>RV-6A canopy >>SportAV8R(at)aol.com I am experimenting with a PPG (I think) material which is called Sunfire, a polyurethene 2 part paint which has (I'm told) extraordinary properties due to the mica based pearlesent suspended in it. It is mixed to order and I am trying to duplicate bright aluminum as seen on polished aircraft. (Having had one, I know what it takes to keep it that way!), It is quite expensive at $175 a gallon plus $40 a gal for haderner..... But should be very durable and may provide the finish I'm looking for. I will apply this with my HVLP Lexaire gun, which spays with shop air and expect to apply it over an exopy primer made by Proline, a marine paint mfgr that is local to here in San Diego. I have found automotive paints not to be suitable, due to durablity (parking a plane outdoors for a number of years show the paint detrioration plainly), Same with the highly touted aitplane paints. Marine polyurethene very durable but a really high gloss is hard to get. The new water based paints are gorgeous, but the long term durability has not been determined. I'm hoping this new paint is the answer and will keep those interested informed..... Bill Nash AIRCRAFT REMANUFACTURING=20 VISTA, CA. 92084 (619) 749 0239 FAX: 749 6384 Sales Directory: Infobot(at)pdsig.com ________________________________________________________________________________
Subject: Re: 0-320's in Cessna 172's info
Date: Nov 23, 1996
A very informative article about 0-320 Lycomings in 172's (and others) is available from http://gtravis.ucs.indiana.edu/Aviation/C172.ENGINES.txt In particular it discusses in detail the H2AD model which has been severely maligned here on the list by the "experts"...... It is copyrighted or I would make it available myself through our "infobot".... Bill Nash AIRCRAFT REMANUFACTURING=20 VISTA, CA. 92084 (619) 749 0239 FAX: 749 6384 Sales Directory: Infobot(at)pdsig.com ________________________________________________________________________________
Date: Nov 23, 1996
Subject: Re: Constant Speed Prop
Louis: >Mark Frederick put me in touch with EMI in Tulsa, OK. 1-800-851-4392 Tell >them you are an experimental and don't need a yellow tag. I just bought a >fresh overhauled governor for my IO-360 for 325.00. Thanks. I'v gotton a similar deal from Warner Props in Tucson AZ. Best Regards, Dave Barnhart
November 14, 1996 - November 23, 1996
RV-Archive.digest.vol-cd
