RV-Archive.digest.vol-cm
February 10, 1997 - February 21, 1997
mount it so that it is 5/8 in closer to the firewall than the right side or
cut the left and center tubes on the canopy frame and shorten them so the
left side of the frame is 5/8 in shorter than the right side.
Can anyone provide some words of wisdom that may help?
John Henley (j.henley(at)worldnet.att.net)
On hold for advice
Subject: | Primer Fuzzies... |
Mitch,
I've had the same problem occassionally. You didn't mention what brand
of primer you were using, but if it's Variprime, here's what I did to
fix it.
1. Buy the SLOW drying converter (I forget the number for it)
2. Turn down the pressure to as low as you can, without getting out
glops when you spray. Also, stay close to the piece.
Stephen Heinlein
sheinlein(at)vnet.ibm.com
From: | "Timothy J. Etherington" <tjetheri(at)cca.rockwell.com> |
Subject: | Re: pneumatic squeezer |
Jerry,
I was like you when I first started. I can't believe that it can't be more
scientific but it also tells me that there is a lot of slop either way. Also
some times the tool seems to squeeze a little more or a little less. Usually if
it is set up it will do great work. I have some info written down at home I
will send to you tomorrow if you can wait that will get you in the right ball
park. It was done by rookie so you are warned but it has been giving good
results.
As for where to put the washers, they go over the shaft of the sets and then
insert the shafts into the tool. Put the larger washers on first, the smaller
ones tend to curl. It is flatter closer to the tool than the set.
This is all assuming you are using the flat and rivet sets from Clevland.
Tim Etherington
tjetheri@cedar-rapids.net
Subject: | Re: engine designations |
David Price wrote:
> Bill Benedict wrote:
> > >Is there a chart or something that tells us what all the different
> > >designations mean at the end of an engine number like: D1A, H2AD, E2G, etc.?
> New to this list and I saw this list at
> http://gtravis.ucs.edu/Engines/Lycoming/Lyc_Cert_list.html
> It's a long file (36pg.)But it's somewere to start.
> David PriceSorry wrong address its
http://gtravis.ucs.indiana.edu/Engines/Lycoming/Lyc_Cert_list.html
There is also a list of applications,its
http://gtravis.ucs.indiana.edu/Engines/Lycoming/applic.html
David Price
PP-ASEL
Subject: | Re: Mixture Cables |
<< I have run into a small problem. I have a couple of salvaged mixture
cables, neither of witch will work well with the metal bracket that Vans
sells that attaches them at the carb. >>
I couldn't get Van's bracket to work with my cables either so I got the
bracket to work the old fashioned way - built my own bracket. The result is
a better bracket then the one I bought from Van's.
Gary Corde
RV-6 N211GC - NJ
Subject: | Re: Frederick RV Event |
I have attended this event in the past. I usually stopped on the way to SNF.
The forum is geared towards BUILDERS of RV's. In the past, if you had a
flying RV the event was free if you gave rides. I got the invite in the mail
and to my surprise, they want $40 from everybody this year. Now I hate to
sound like a cheep-skate, but, why would I want to spend $40 to give rides?
Don't get me wrong, if you are thinking about building, or you are building
and RV by all means go. Just don't expect to get a ride.
Gary Corde
RV-6 N211GC - NJ
Subject: | Re: Primer fuzzies |
I assume you are using Variprime. If that's the case, use DuPont 8100s
reducer to slow down the dry time.
Chris
> Hi All -
> I've got a recurring problem with my primer going on "fuzzy" at first.
> I'm shooting with the usual small
> touch-up gun at about 30 PSI, and it's coming out stringy and fuzzy like
> it's drying before it hits the aluminum. After a minute of spraying or
> so, it's fine again. It's always the first minute of spraying. I've
> been trying everything I can think of: cleaning the gun as well as
> possible, spraying straight laquer thinner for a minute first. Doesn't
> help.
> Anybody have any ideas? 's pretty darned
> expensive, I'd hate to waste it by having to prime my plywood board
> every time before my parts.
> Of course, I go to bed every night knowing that *that* board is never
> going to corrode!!!
> Mitchell Faatz San Jose, CA
> N727MF reserved
> RV-6AQME, about to hang left aileron
Subject: | Re: self-tapping sheet metal screws |
I would recommend against using the sheet-metal screws.
I put some stuff under the baggage floor (one side only actually) that
I wanted to have access to, but rather than nut-plate the whole
floorboard, I cut it in half, riveted the aft half in, and nut- plated
the forward half. Saved a _few_ nutplates, although I did have to add
a doubler where the two halves joined. I think the main benefit of
this over just nut-plating the whole floorboard is that it's easier to
maneuver the smaller piece out of there what it would be if it were
the whole floorboard.
Randall Henderson, RV-6
randall(at)edt.com
http://www.edt.com/homewing
From: | Lothar Klingmuller <lothark(at)worldnet.att.net> |
Subject: | RV-LIST: HANDLING RV E-MAIL DATA |
For new subscribers I have outlined a system of how to handle all this
E-mail data.
There should be many on the RV-List who are, like me, on the steep side of
learning the systems. I am using Eudora Light software (obtainable free of
charge from ATT).
I was on the verge of 'unsubscribing' from the RV-List for the simple reason
of being overwhelmed with data . So much interesting reading, so little
time. Printing out for future references would take time and reems of
paper. The question what to keep and what not to keep posed a problem.
Also, non-RV-List E-mails could be trasched without reading. Here is what I
do :
1. Sort all new mail by subject (This is particularly useful when the
mail has accumulated).
2. Check top and bottom of list for non RV-related items and read same.
3. Scan through subjects of current interest.
4. Hightlight all new mail and trasch (will result in blank IN box).
5. Sort the TRASH file by subject and delete sections of no future
interest like mail related to RV-4 when you are building and
RV-6/A ( I do this as needed or every couple of weeks) .
When I need to look something up, I use the subject-sorted trash file and
may print only the best of a certain subject.
Any better ideas, please post these. Thanks.
Lothar* Klingmuller = lothark(at)worldnet.att.net = Denver - (303) 922-2329 h &
FAX~~ -6A continueing w/ fuse'ge when garage is build . *(pron'd: "low-TARR")
Thanks David for pointing to the home page with ALL the Lycoming
engine information.........I've been wondering about how to decode
those engine spec numbers too......but you left something out of the page
address
It should read:
etc.?
>David Price
Subject: | Re: RV6 Sliding Canopy |
My sliding canopy was also slightly "whopper-jawed" when I got it.
But I found that it was necessary to "tweak" it quite a bit to get it
to more closely match the roll bar and longerons, and also to get the
rear pins to come out in the right place. Many hours with a pipe
bender later, it was square with the roll bar.
I don't know if it's really kosher to go bending your frame with a
pipe bender, but I found that was what it took to make it fit. I used
a cheapo conduit bender that was made for aluminum thinwall electrical
conduit. The inner diameter of the bender was too small for the 4130,
so I ground out the inner diameter with a rotary file (the thing is
aluminum and was pretty easy to modify).
I never did get it quite right at the front, so I'm having to do
some shimming to make the main bubble match the windscreen.
randall(at)edt.com
> From: worldnet.att.net!j.henley(at)matronics.com
> Subject: RV-List: RV6 Sliding Canopy
> Date: Sat, 8 Feb 1997 23:30:50 +0000
> I have run into a problem that has me stumped so thought I had better ask
> for help. I mounted my roll bar according to plans. When I put my canopy
> frame on, I find there is a 5/8 in gap between the roll bar and the canopy
> frame on the right side corner. I unbolted the roll bar and squared it up
> with the canopy frame and everything looks fine except that the roll bar is
> 5/8 in closer to the firewall on the left side. I have the center slider
> track installed temporarily on top of the fuselage in the correct position.
> I cannot figure out why I am 5/8 in off. I called Van's and they could not
> offer much help.
> I can see two options:drill new holes for the left side of the roll bar and
> On hold for advice
Subject: | Re: VOR/LOC/GS antenna question |
I'm about to install an antenna for my VOR/LOC/GS. I would like to mount it
on
the belly in the area of the forward stick. Has anyone had any experience
with
this position? I'm concerned about "shadowing" while on an ILS approach.
Dan Boudro
RV-4 N9167Z 130hrs
Albuquerque, NM >>
Hi Dan,
I seem to have lost an Email message from you.
I believe you asked what the price was for the Sportcraft wingtip NAV
antenna. It's $55 plus $5 handling and shipping to NM.
If you are interested in getting a Sportcraft antenna, just mail a check to:
Less Drag Products
P.O. Box 1195
Somis, Ca. 93066
Please identify which wingtip you would like to install it in, and include
the address which you would like to have the antenna sent.
Jim Ayers
LesDrag(at)aol.com
http://member.aol.com/lesdrag/rv3.htm
http://member.aol.com/lesdrag/Ivoprop.htm
Subject: | Re: Pitot Static Tubing - Aluminum to Poly-Flo |
Tim, I just did exactly what you described, I pushed a piece of poly tubing
over the aluminum, and put a small clamp round it.
The chances of it coming off is remote, I can't even pull it off. I did put
a small flange on the aluminum, to make even more sure.
John Almost ready to paint.
> address
> It should read:
> etc.?
> >David Price
Richard thanks for pointing that out(I have a hard time typing no less
copying at the same time).Noticed it this morning and added a list of
applications for engines.
Fellow RVers,
I received 12 orders for fuel lube, filled 7 cans and ran out. I have
some more on order but it could be the end of the month before it is
shipped. So, if anyone who needs the stuff right away would E-mail me
(off-list), I'll make sure you get some. Otherwise, it's first come, first
"lubed". Shucks, now it seems that I'll have another lifetime supply of the
stuff, on hand.
Bob Skinner 43461 Rd 757, Lexington, NE 68850
Thanks, Bob Skinner BSkinner(at)navix.net
I did it this way.
I opened a directory called flight, then a sub-directory called
RV-6, just for my E-mail coming from this list. Then I opened the
following files within the RV-6 directory. Addresses, construction,
antennae, Battery, Cowling, controls, cockpit, c.g., canopy, chemicals,
nav.-com, gear, inst. pnl, flaps, faa, fuel sys. instruments, engine,
legal, misc., oil cooling, oil cooler, paint, props, pro-seal, rivet, and
junocopy.
I move mail of interest to junocopy, so I can look at it more
carefully later. In junocopy.doc I can edit and shorten the pieces, then
cut and paste them to one of the other files.
All of this is no big deal and I wouldn't bother mentioning it
but after I get it edited and shortened I print these files, from time to
time, then punch them and put them in a three ring binder so I can read
them when I get to that part of the project. Right now there are q's @
a's going on about F-405, Oil canning,and Pieces in the baggage hold that
don't fit.
This stuff is going right over the top of my head. But I'll save it and
when I get to that part of the project, I'll have that stuff real handy.
Larry lm4(at)juno.com
From: | Frank van der Hulst <frankv(at)pec.co.nz> |
Subject: | Re: RV-LIST: HANDLING RV E-MAIL DATA |
>E-mail data.
Agreed to first 4 points.
>interest like mail related to RV-4 when you are building and RV-6/A ( I
The above will be good for some people, but doesn't work for me.
I clear out my trash every day. If there's something I need to find, I go to
the archive at http://dunkin.Princeton.EDU/.rvlist/ and search there.
I hardly ever print anything.
Frank.
frankv(at)pec.co.nz | "Knowledge=Power=Energy=Matter=Mass;
Frank van der Hulst | A good bookshop is just a genteel
Software Engineer | Black Hole that knows how to read".
PEC(NZ) Ltd (Cardax), Marton | Terry Pratchett, "Guards! Guards!"
http://www.pec.co.nz/~frankv/ |
Subject: | Re: Flap Linkage |
rvbildr(at)juno.com wrote:
>Has anyone beefed up the small flap links? Has anyone had any trouble
>with them? A 3 1/2" piece of aluminum tubing just doesn't appear to be
>strong enough to operate the flaps. I'm considering substituting a piece
>of solid rod, either aluminum or 4130 and then threading the ends and
>using bearings that will screw onto them. Mal rvbildr(at)juno.com
We hashed this out a few months ago here on the list. Consider that the
thread on the rod-end are in contact with many more threads in the tubing
than they woould be in contact with a standard AN nut. Even though a
single thread in the aluminum is weaker than the steel, the conbined
strength of all the threads in the aluminum (for the full length of the
rod-end) probably exceeds the strength offered by a single AN nut.
And, after all, there are over three thousand of those flap links flying
(two per RV) with no recorded failures.
Best Regards,
Dave Barnhart
The fuselage sure does look pretty up on its gear with the empennage installed!
From: | Stan Blanton <75472.372(at)CompuServe.COM> |
Subject: | Fuselage Jig Available |
RV-List,
I have a RV-6 fuselage jig that needs a new home. It is constructed of wood with
laminated header beam material for the side rails. If you are willing to come
get it and use it it's yours.
I am located in Lubbock, TX (LIA) which is about 120 mi. south of Amarillo, TX.
Anyone within a couple hundred miles interested?
Stan Blanton
RV-6
Fuselage coming out of jig (finally)
Ph. 806-799-4664
75472.372(at)compuserve.com
The canopy frame warps when it is welded up. I think everybody has
problems them.
Don't move your roll bar. Try bending the frame to make it fit. I know
some guys
have cut and rewelded them to get a good fit. In the end you will
probably have
to use shims somewere.
Bud Newhall
__|__
__|__ ____(+)____
____(+)____ ' '
Subject: | HANDLING RV E-MAIL DATA |
------ =_NextPart_000_01BC1792.9252DF60
Well this topic probably got started from my comment about two reems of =
printed data......This is my logic behind that. I read the list two to =
three times per day usually. I at least read it at night before I go to =
bed. If I find something that I feel I'll need when I get to that stage =
of building, I print it and file it under it's proper heading. Like if I =
see some thing on the fuselage in general that I think I better know =
when I get to that part then I print it and file it under fuselage....or =
flaps....or wings......or control surfaces....etc...Then when I get to =
doing that section of the plane I scan that file for the stuff I need to =
watch out for. It works for me...Also I can carry that stuff into the =
shop for hands on referance. Thats how I found that engine data from =
Herman, I looked under engine. Al prober(at)iwaynet.net (Still on the =
Empanage)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------ =_NextPart_000_01BC1792.9252DF60--
Subject: | Hartzell prop home page?? |
Does anyone know Hartzell Propeller home page
or phone number? Reply to my address. Thanks
Herman
dierks(at)austin.ibm.com
Does anyone familiar with the rv-4, or I should say has anyone with an
rv-4 done anything to lengthen the front seat legroom. I don't see an
easy way of getting more than an inch more than the plans call for. I
thought about moving the roll bar back as close to the rear stick as
feasible, then mounting the seat on adjustable rails. Any kind of rails
would take away from head room. Does anyone have any input on this?
I'm open to any suggestions. How much room is between the firewall and
rudder pedals when full rudder deflection is necessary? Thanks in
advance for any input.
Shimming the rivet dies is fine but if you want to do it the really easy way,
you can get a screw adjustible type (simular to a hand rivet squizer ) from
U.S. TOOL SUPPLY. They are a little pricey but are a real time saver. After
I bought one ,I made a few more,one for each yoke I have. Daryl Green
(wings almost done )
At xx yy wrote:
From: Kevin & Theresa Horton <khorton(at)cyberus.ca>
Subject: Re: RV-List: HANDLING RV E-MAIL DATA
>E-mail data.
>charge from ATT).
**snip**
>"low-TARR")
I use Eudora Pro 3.0, and set up a filter which looks at all mail in my In
box, and moves any mail with a Subject containing RV-List to a RV In box.
This leaves all my other mail in the regular In box, so I don't miss any of
it. I set up a series of mailboxes on different subjects, and as I read
the mail I transfer the keepers into the appropriate mailbox.
Kevin Horton
hopeful RV-8 builder (lurking and gather info, tools, etc)
Ottawa, Canada
I purchased the piston for a hand squeezer from Avery's, which is
threaded, for less than $20. I then bought an allen head bolt to fit
this. I haven't tried it out yet, but Ed Cole came up with the idea and
he seems to like it.
EB
------------ ORIGINAL ATTACHMENT --------
SENT 02-10-97 FROM SMTPGATE (DGreen9032(at)aol.com)
Even better than this IMO is to use Bruce Gibbons' search engine and download
the RV archives. I do this once every few months (last done Friday while I
slept and it even had Friday's messages included already!). The search engine
is fast and efficient. The unzipped file is now up to 24,151KB now! Makes me
think twice about "cluttering" it with this!
Bill Garrett (bgarrett(at)fast.net)
Mathematics Teacher
RV6-A (Working on Wings)
Actually, Dave, my suggestion is that you re-scan the paint samples, but at a
lower DPI resolution. Frankly, at an absolute minimum you only need one pixel
of the appropriate color to transmit the color value, so re-scanning the pages
at say, 30 DPI would result in very tiny files.
Richard Chandler
RV-6: Garage bought and being finished, saving for tools and tail kit.
Subject: | Rivet MIL-Spec now on-line |
RV-listers,
The MIL-R-47196A specification titled "Rivets, Buck Type,
Preparation for and Installation of" is now available on-line at my
personal web space.
http://www.flash.net/~gila/
John Hovan has also kindly placed a link to this location from his
excellent RV web site, so you won't have to remember it ..:^) Other web
site managers, please link only to this location.
Many thanks are due to Brian Yablon for the magic scanning, OCR and
gif drawing work. Thank you Brian.
Since this on-line availability is much easier, more efficient and
cheaper than sending me SASEs for hard copies, my "Free Rivet Spec. Offer"
is now formally closed ...:^) ... but the two SASEs I got this week have
been mailed.
... thanks guys, use this information, spread it around to other RV
builders, and form good rivets to get all of the strength that Van designed
into these planes.
... Gil (sent out over 60 harcopies) Alexander
RV6A, #20701 ... tail fairing and little tail stuff ...
PS I get 1 Mb of free web space, and could host other RV related stuff
here if anyone has any ideas ...
gila(at)flash.net
Gil Alexander,
Los Angeles, CA
Subject: | lost message re prop and throttle |
This message was posted several days ago and AOL lost it in cyberspace so I
am posting it even though the thread has not been discussed for a while.
Regarding use of prop and throttle:
I have always believed in the KISS principle. There are so many things that
can cause you grief around an airport that you should have your full
attention outside of the plane as much as possible. If you do things the
simple way and always do them the same way, you are much less likely to
forget something important, like carb heat, fuel pump, or landing gear. I
say that the simplest way to work the prop and throttle is to go to full RPM
as you enter the traffic pattern and forget about the prop for the rest of
the flight. Use the throttle to control your airspeed and rate of decent.
That way full power is always available with the throttle and the prop can
act as an air brake when the throttle is closed. The floating tendency is
much less on landing with flat pitch on the prop, resulting in shorter
landing distances and longer brake life. Aerobatic and race planes run
their
engines above the 2700 RPM red line all the time with no trouble. Things in
the engine don't start to break until about 3450 RPM, so any brief
over-shoot
of 2700 RPM during a rapid application of power will not hurt the engine.
While I am on my soap box, let me suggest another thing about the traffic
pattern. If ANYTHING interupts your normal sequence of events, STOP! Go
back to the beginning of your landing sequence and start over with your
checks. You would be amazed at the number of incidences that occur because
someone caused a pilot to deviate from the normal routine, which then caused
them to forget an important item on the landing checklist. I speak from the
experience of 28 years of military flying, 28 years of aiirline flying, and
36 years of private flying totalling more than 16,000 hours. (Twenty three
of the military years were in the reserves while flying with the airlines,
so
I am not really that old .) Standing by in my Air Force issue Nomex
fireproof flying suit for the flames.
Jim Cone
jamescone(at)aol.com
<< I have run into a problem that has me stumped so thought I had better ask
offer much help.
left side of the frame is 5/8 in shorter than the right side. >>
John-
You quite probably have a "racked" canopy frame. To visualize racking
compare a parallelogram with sides x and y against a rectangle with the same
sides x and y. The parallelogram is what you likely have looking down on the
canopy frame from the side.
You need to get it square by wrestling with it, literally. You have to clamp
parts to an immovable object and lean on it. First get the center spine
normal to the front arch then tweek the sides so they don't fight against
square. Gradually it will come around. There is a certain amount of time it
expects you to spend with it (like the dog and the wife) and you must indulge
it.
Don't even think about moving the rollover bar if it is in the correct
(normal to the a/c centerline) position or you will come to grief.
-Gary VanRemortel
vanremog(at)aol.com
As a fairly new subscriber, I've noticed that a lot of the e-mail I get are
answers to questions, or general discussions, that could better be done
one on one. Our list provider has asked us to help eliminate some of
this because the archive is growing at an alarming rate. As a retired
computer programmer, I know that hardware costs a lot of money. To
help out, I generally send my answers to pleas directly to the person
generating the request. Yes, we don't all get to see it; but, it does keep
down the overload. If we can keep down the general chatter and
jokes, the mail will lessen for all. As a new subscriber, I've thought quite
a bit about dropping out because a goodly portion is bunk, the rest I
can get from Van's. With that said, have a nice day.
Jim Sears
RV-6A #22220 (fuselage to arive today)
Subject: | Re: bolting practices |
--- Forwarded mail from ("Jeffrey Davis")
From: "Jeffrey Davis" <jdavis1(at)av5036.pd8.ford.com>
Date: Mon, 10 Feb 1997 08:26:20 -0500
Subject: Re: RV-List: bolting practices
> >If anyone is interested I can post the equations required to calculate
preload
> >for both nut and bolt torquing.
> >Side note: Many of the fasteners used in Aircraft are not used in tension
and
> >preload is not important. Preload is important only to joints that are
loaded
> >along the axis of the bolt. In shear joints - bolt dia. is the control.
That
> >is why we use safety wire and pins to hold the nuts on - instead of
clampload.
> Interesting - can you please e mail me the equation for calculating
> preload.
> Jan Coulter RV6 builder in England
>-- End of excerpt from Jan Coulter
To calculate the required joint preload for a shear joint use the following
equation:
Ps = K*n*m*T
Ps = Working Shear Load at slip.
K = Coefficient of friction between shear surfaces
n = Number of Slip planes
m = Number of Bolts
Tmin = Minimum clampload/bolt
To "estimate" the torque required to obtain a given preload -
T = Fi*dm * (1+pi*u*dm*sec(a)) + (Fi*uc*dc)
2 (pi*dm-u*l*sec(a)) 2
T = Torque
Fi = Bolt Tensile load
dm = Mean Diameter of bolt
pi = Pi (3.14159.....)
u = Coefficient of friction of the thread interface
a = Thread Helix
uc = Coefficient of friction collar(head on bolt/washer)
dc = Washer face diameter
l = Grip length
This can be simplified to
T = K*Fi*d
K = is the torque Coefficient and ranges between
0.4 to 0.8 for metal to metal
0.005 to 0.2 for lubed joints.
On average K = .2 or u/uc = .15 works well for most applications
Therefore T = 0.2*Fi*d
Of the total torque applied, 40-50% goes to bearing friction, 35-45% goes to
thread friction, this leaves between 5-25% for developing clampload.
About a 5% variation in joint friction (to lube or not to lube) can produce a
30% variation in clampload.... This is why critical joints are tightened to an
"ANGLE" not a torque..
Enough on bolted fasteners..
Jeffrey S. Davis
Senior Research Engineer
Advance Vehicle Technology
Ford Motor Company
Phone (313)845-5224 Fax (313)845-4781
---End of forwarded mail from ("Jeffrey Davis")
Jeffrey S. Davis
Ford Motor Company
Subject: | Re: lost message re prop and throttle |
<< I
RPM
landing distances and longer brake life. Aerobatic and race planes run >>
Jim, and others:
We all have different techniques.
I was warned about treating a counterweighted engine in this manner- in other
words, do not let the prop drive the engine, as much as possible. My prop
control does not move from the cruise position until the RPM starts to drop (
at which point it IS at full pitch). Hey- I'm the one paying the bills
here...
Regarding the floating tendency- I suspect most props will already be at fine
pitch at idle.
Check six!
Mark
From: | wstucklen1(at)juno.com (Frederic W Stucklen) |
Mitchell,
If you're using a siphone type spray gun, be sure that the cup vent is
open.......
Fred Stucklen RV-6A N925RV
>> Hi All -
first.
like
or
Doesn't
>> help.
>> going to corrode!!!
>> N727MF reserved
From: | Richard Meske <rmeske(at)freenet.columbus.oh.us> |
I had the same problem with my veriprime. This was a big headache! I
even took my spray gun in to some local guys. The checked it out for
me. They said it was OK. It was not. I eventually traced it down to the
packing in the gun. Veriprime is much thicker than thinner.
This is what the local shop used to check my gun. It worked OK. When you
use thicker media, air gets sucked right by the gun packing and dries out
the paint in the gun. I replaced the packing and tightened down the
packing nut till the gun needle wouldn't move, then backed it off. It
works great now!
Rich
writes:
>to SNF.
>a
>the mail
>hate to
>rides?
>building
>Gary Corde
>RV-6 N211GC - NJ
It seems like every time an RV related event is scheduled I have to be
somewhere else, and this one looks like no exception. If I was going
though, I'd offer to pay your attendance fee just to have the chance to
get a ride, since I've had to take the flight characteristics of the
airplane I've been working on for the past 4 years on faith to this
point.
Maybe the organizers of this event could ask those who want a ride to pay
a small fee to offset the expenses of those who are gracious enough to
offer this opportunity. I know I'd jump at the chance.
> generating the request. Yes, we don't all get to see it; but, ...
I have to disagree with this. When I go to the archives, I'd rather find
the solutions rather than just that someone had the same problem before.
My opinion is that a big contribution to the bulk is that several
different people seem to answer the same question with the same answer.
This could be reduced if people would read through all of their mail
before responding.
Another problem is that people are including entire contents of previous
posts, when two or three lines would be enough to remind us of what was
already said.
Fred New, Rv-6(A?), dreaming, scheming, looking for a garage & more money
IC Systems, Mustamae tee 12, EE0006 Tallinn, Estonia
fred(at)ics.ee, (372) 656-5477, fax (372) 656-5476
From: | dougweil(at)mail.pressenter.com (Doug Weiler) |
Fellow Listers:
I would like to construct a small paint booth (15' (l) x 6' (w) x 7' (h)) in
my shop. Have any of you desgined such a booth? I assume the best design
is to suck air from it with a filtered inlet. What type of exhaust fan did
you use? How big? Do you have a source for a fan approved for paint booth
application?
Doug
= Doug Weiler, pres. MN Wing, Van's AirForce, RV-4 in progress, N722DW
= 347 Krattley Lane
= Hudson, WI 54016
= 715-386-1239
= email: dougweil(at)mail.pressenter.com
From: | catbird(at)taylortel.com (TTC Carroll A. Bird) |
Michael
I haven't had to move the seat, however I just got thru
installing the rudder, stops, and cables. There are a few things that I
ran into doing this. First in the prints they say that the max. length
of the 4130 X 1/2" links for the cable is 4 3/4 inches between holes.
The clearance for the holes on each end is 1/4" that would make them 5
1/4 inches long. Now they only send 20" of this material and you need
four of them so the max. length you can get is 5" ea.. At this length I
only have about 1/2" clearance from the fire wall to the pedal at full
deflection.
Carroll Bird
Buffalo Gap TX.
Subject: | Re: Re prop and throttle |
<< I was warned about treating a counterweighted engine in this manner- in
other
(at which point it IS at full pitch). Hey- I'm the one paying the bills
here... >>
Mark is 100% correct.
Gary Corde
<< My sliding canopy was also slightly "whopper-jawed" when I got it.
bender later, it was square with the roll bar. >>
Oh yes, I still have fond memories about bending my slider frame. I thought
about the process for about a week. Should I heat the tubes? Should I uses
a pipe bender? Should I build something easy like a Glassair?
After much thought (and a call to Van's) I got out my trusty tools...hand,
foot and floor. After some precise (ya right) manipulation the thing fit
perfect.
Gary Corde
RV-6 N211GC - NJ
Hartzell technical support is at 513-778-4388
Herman
Subject: | Re: prop and throttle use |
Mark, this is good input. Most RV's DO NOT have crankshafts with
counter-weights. Your Harmon Rocket is more the exception than the rule.
However, if you treat the engine as if it does have counter-weights,
then you can fly either type of engine.
I really wonder how much of this is 'ol wives tales' vers engineering
truth with respect to the counter weights. Given the cost of the cranks
and engines, I guess we don't really want to find out so it is easier
to be gentle on it.
Herman
> Jim, and others:
> here...
> pitch at idle.
> Check six!
> Mark
Subject: | True Airspeed using GPS |
Listers:
I've misplaced the formula for calculating true air speed using the
GPS while flying in three directions 90* apart. Does anybody happen to
have it handy?
From: | RELOSVCS!WESTREG!EHENSON(at)cldwell.attmail.com (Henson, Eric) |
Subject: | WANTED-RV-6 WING KIT |
Hi all,
I am about ready to order the rest of my RV-6 kit but thought I would try
and avoid the waiting period on the wing since I'm without metal pieces to
play with, these withdrawals are tough.
If anyone knows of a wing kit that someone would like to part with please
E-Mail me. I'd like as little work done as possible. I'm on the west coast
so it needs to be within a reasonable driving distance.
Thanks in advance,
Eric Henson
Dana Point, Ca
ehenson(at)cldwell.attmail.com
I sent in my application for the Frederick, MD event a short time ago.
But as I recall, gas for those giving RV rides was provided to those
giving rides....maybe in lieu of admission??
As I recall last year, they did drawings for RV rides during the
seminar. Other rides were perhaps arranged for through the goodness
of the hearts of those RV owners that did come to the event. I do know
that George Orndorff gave some of the rides using his plane.
Paul Bilodeau
pmbs(at)probe.mt.att.com
908-957-6611
Since Rvs quite often get more cooling air than needed for regular oil
coolers, some owners have found that a very good smaller cooler is available
for about $79. This is a great cooler of high quality and light weight. It is
called a Setrab, made in Sweden and comes with your choice of female pipe
fittings or male flared aircraft fittings with the 37 degree flare you
require. Many builders in the Portland area fly with them as they are perfect
for their needs in that they are the same dimensions as other coolers only
about 1/2 the thickness. Light in weight, low cost and fit very well almost
anywhere you want to mount them. No I am not a dealer. This is just one of
those suggestions for your consideration since good deals for homebuilders are
not that abundant! Austin Tinckler
Vancouver, B.C.
RV-6 aborning...(90%)
From: | Cheryl Sanchez <csanchez(at)BayNetworks.COM> |
Subject: | RE: Primer fuzzies |
I did some priming yesterday and I had not done so since last
fall. At first my spray gun was "spitting" a bit. It would spray a steady
stream of paint or solvent with interruptions. The gun had been
cleaned meticulously. In frustration I took it apart and it was perfectly
clean internally.
After a while it started working normally. I think the difference is
that the "packing valve" needed to be lightly lubed, as it says in the
manual(RTFM.) So I think that my cleaning had washed out the lube
so the paint valve was not opening reliably. After cleaning and lubing
it was fine.
Cheryl Sanchez
csanchez(at)world.std.com
Subject: | Re: True Airspeed using GPS |
>Listers:
>have it handy?
I don't have that formula but I have a method that is very quick and easy.
Make a very gentle turn to the heading that gives maximum ground speed.
You may have to search back and forth a little bit. Note the ground speed.
Make a 180 degree turn. Note the ground speed. True airspeed is the
average of these two figures.
Larry Pardue
Subject: | Performance Equations |
Listers,
I'm trying to come up with a spread sheet to calculate aircraft
performance characteristics. I need formulas to compute density altitude
and CAS, given Altitude, OTA, Baraometer, etc. Does anybody have these
in a practical form?
Where can I get the power setting curves for the O-320-D1A engine?
> Here is something you pnuematic squeezer guy's might try...
If you have a hand squeezer from Averys, remove the die holder, unscew it
from the threaded actuator, purchase a cap screw with the same threads
and length as the actuator, and for 69 cents you have a fully adjustable
pnueumtic squeezer! No washers required. Be sure to add lubricant to the
threads and cap of the cap screw.
Ed Cole
RV6A Wings
>Listers:
>have it handy?
Here ya go, Fred. ------------------ Bob Skinner
The formula is: V=squareroot of(V1 squared + V2 squared + V3 squared + V1
squared x V3 squared/V2 squared)/2
Example: You can track any course as long as two are 180 degrees from each
other and the other course is perpendicular. I like using GPS, seems to
work better than loran. I usually track 0 / 90 / 180 (sun is in west) or
180 / 270 / 0 (sun in east). This formula eleminates any effect of wind
component.
V1 heading of 0 degrees = 160 groundspeed
V2 heading of 90 degrees = 163 groundspeed
V3 heading of 180 degrees = 125 groundspeed
Your answer should be 144.
I wrote a spreadsheet formula and just log the three speeds while
airborne. I also log: Date, Temp, Altitude, (computed Density alt.), RPM's,
Maniflod pressure, (compute percent power), log where mixture control is
(best power, leaned to peak, etc.), Indicated Airspeed, then the computed
results and the last column shows Airspeed error (difference between
computed and indicated.
Subject: | Re: RV-List:Looking for a 4 |
There is an RV-4 at Double Eagle (AEG) for sale. Contact Tom, the chief
mechanic
at 505.842.7007
>Hello out there
>I am a viper driver (F-16) now flying a desk at MacDill AFB FL. Looking for
>a reasonably priced VFR RV-4.
From: | Michael Angiulo <mikeang(at)MICROSOFT.com> |
I just built a "shed" out of 2X4's and use a pratton whole home air
circulator (giant metal fan from Price Club) with an ordinary $2 furnace
filter in front of it. The filter catches almost all the overspray.
The shed is covered with ordinary blue tarps. I spent about $50 and
have primed every single part on my plane so far without any problems.
I thought for a while about all this explosion proof stuff and decided
that it wouldn't affect me. The shed is in the middle of a well
ventilated hangar. I decided not to smoke while priming in it. Your
mileage may vary. Please no flames (pun intended).
-Mike
From: mail.pressenter.com!dougweil(at)matronics.com
[SMTP:mail.pressenter.com!dougweil(at)matronics.com]
Sent: Tuesday, February 11, 1997 5:56 AM
Subject: RV-List: Paint booth
Fellow Listers:
6' (w) x 7' (h)) in
of exhaust fan did
application?
Doug
progress, N722DW
= 347 Krattley Lane
= Hudson, WI 54016
= 715-386-1239
> Vancouver, B.C.
> RV-6 aborning...(90%)Austin,
Where can you buy such a cooler??
Ed Cole
emcole(at)concentric.net
Hi Doug, first I would only make a booth for finish painting of course. I
paint an occasional car in my garage and what worked well for me was to make
a temporary frame out of small dia. pvc and completely surround the car.
Then just wrap it in plastic, tape an air conditioning filter or two for an
inlet and have the fan taped to the plastic pulling the exhaust out. This
will keep the bugs out and help controll where the paint goes. All said, I'm
not really sure how necessary this is, most of the minor crud in the paint
comes off of you and not the air. You did wash your floor, right? A little
1500 grit and some finessing compound will take away the specks with ease.
Hope it helps,
Eric Henson
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Doug Wrote<<<<<<<<<<<<<<<<<<<<<
Fellow Listers:
From: owner-rv-list(at)matronics.com on behalf of AUSTIN TINCKLER
Sent: Tuesday, February 11, 1997 11:03 AM
Subject: RV-List: Oil Coolers
Vancouver, B.C.
P.S. I forgot to say
where you can get them. Call Jeff at Columbia Airmotive
1601 S.W. Sturges Dr. P.O.Box428
Troutdale,
Ore. 97060 Phone 503-665-4896.
rv-list(at)matronics.com,Internet writes:
Ed Cole
RV6A Wings
How do you adjust it without the whole thing spinning? The hand squeezer has
an indent in the ram that stops the threaded end from turning when you turn
the shaft. The pnumatic has no such facility. I would imagine that the cap
screw would just spin on the ram.
Dann Parks
dann_parks(at)kteh.pbs.org
What about for those in warmer climates...like places where the sun shines?
(No really, I love the Pacific Northwest) Would this provide enough cooling?
Dann Parks
Subject: | Re: RE: Primer fuzzies |
>fall. At first my spray gun was "spitting" a bit....
One of the things that I found when I switched from a siphon feed to
pressure feed is that the adjustment of the packing nut is much more
finicky with pressure feed.
With siphon feed, if the packing nut is a little too tight, it won't
matter. The paint needle will 'drag' (close later than the air valve), but
since no paint flows when the air is shut off, its not a problem.
With pressure feed, however, if the paint needle drags, paint will continue
to flow after the air is shut off at the end of each stroke. (The pros have
a nickname for this behavior, but I won't repeat it here) The packing nut
must be adjusted tight enough to prevent air fron leaking past the packing,
but not so tight as to cause the paint needle to drag.
Best Regards,
Dave Barnhart
From: | Gene Gottschalk <geneg(at)rattler.gsfc.nasa.gov> |
Gary,
As in the past, admission and gas for the rides is still free to RVs that
fly-in. Sorry for any misunderstanding. I took over the preparation of the
registration brochure this year and missed a few things. No matter how many
times you read over your own work you still miss things.
-Gene
>Gary Corde
>RV-6 N211GC - NJ
From: | Sylvan Adamson <sadamson(at)cyberhighway.net> |
>Fellow Listers:
>application?
>Thanks,
>Doug
>= 347 Krattley Lane
>= Hudson, WI 54016
>= 715-386-1239
>Doug, I ran a couple of ropes from I bolts screwed into opposit walls with
a window at one end. I then covered the floor and draped clear plastic over
the ropes to the floor and taped the ends shut and taped it down to the
floor. I used a standard three speed box fan in the window on one end and a
couple of furnace filters on the plastic on the other. Be sure and take the
window screen out or it ends up painted. Works great. Got all the stuff at
the local Home Base store for about 50.00. I've seen this done a number of
times with no problem. Sylvan
From: | James & Mary Mc Phee <bluegum(at)ihug.co.nz> |
Subject: | Re: FW: Lycoming-electronic igntion/fuel injection |
><< In the quest for a more efficient Lycoming, is anyone aware of an
>electronic
> ignition for the Lyc. I have heard of a certified ignition system, however,
>I
> am
> curious if someone has had any luck with an un-certified system for
> the homebuilt crowd. Any info is appreciated.
> Regarding fuel injection, any comments on how the AirFlow Performance
> FI system compares to the factory Lyc FI, price, performance, etc.
> Thanks,
> Garrett Smith
> Calgary,Canada >>
FWIW, I recommend the Claus Savier Light Speed Electronic Ignition sysytem
and I have one in my RV 6 with 100 hours on it. I would not be without it,
other RV owners are impressed at the smoothness and efficiency. It isn't
the cheapest, but the best never ir, neither is the cheapest, it is often
dearer in the long run. The latest offering from Lightspeed is the Plasma
system, onlt 1/3 the size of the old system.
TO all the other knowledgeable RV people out there who don't like the
magnets on the flywheel, I suggest you do not bash it unless you have had it
on your own aircraft.
James Mc Phee RV-6 S/No 20334 ZK - MRV 295Hrs and 4 1/2 yrs Flying.
>I am suppose to send a deposit on an 0320-h2ad Friday. I think it is a
>good price. It is in a late 70ish 172. It has 2000 hrs since new, and
>is being removed for upgrade. I used to be afraid of these engines, but
>have heard more good news than bad, lately. I know the rv-4 mount will
>need to be modified, and something done about the mechanical fuel pump
>mounting area (cowling bubble, I think). I'm also planning on using one
>of the electronic ignition systems. Does anyone want to add anything to
>this, or try to talk me out of buying this engine? Please hurry if
>there is something else I need to consider before I buy this engine.
>Flame away!!!!! thanks
>Buy the engine, keep it's insides nice and clean and you will have a good
engine.
We use Shell 15W-50 semi synthetic oil, used Microlon (teflon) as a i time
treatment as soon as we entered phase 2, have Lightspeed CDI installed and
are currently producing 185 hp from our H2Ad, it's a lovely engine.
The only 2 changes you will require are to the top of the engine mount,
perhaps Van's will swap for you although I do not understand why all the
Dynafocals from Van's are not modified, that way any dynafocal will fit, and
a bubble up front above the fuel pump housing to allow for engine rocking
movement.
Good Luck
Jame Mc Phee RV-6 S/No 20334 ZK-mrv 295 Hrs 4 1/2 yrs.
From: | Jack & Diane Mahler <jax(at)brett.reno.nv.us> |
aol.com!CAGPADDLES(at)matronics.com wrote:
> Has anyone had major delays in getting stuff from Avery's lately? I''ve been
> waiting for the catalog for 3 weeks and have called twice, but no-joy. I've
> seen what seem to be glowing endorsements of them in the archives so maybe
> they just don't like me.
> Jim Brown (RV-6 in
> waiting)Yes, I ordered a Hand Squeezer Yoke three weeks ago with no luck, when
I
called I got the run-a-round from the female on the phone, told me to
call back later, she didn't know what happened to my order. This is the
first time I've ever had trouble with them. I don't know what the
problem is, but I will call again tomorrow. Doing the wings, jax
From: | "Van's Aircraft Inc." <vansac(at)vansaircraft.com> |
Subject: | Van's Aircraft On-Line |
Greetings RV'ers,
Van's Aircraft is pleased to announce the introduction of their
new on-line services:
(Feel free to send any comments to webmaster(at)vansaircraft.com)
WORLD WIDE WEB
http://www.vansaircraft.com *****************************************
The primary feature of the Van's Aircraft On-Line concept is the website.
Enjoy an extensive amount of data, filled with colorful pictures of many
different RV aircraft!
FTP
ftp://ftp.vansaircraft.com ******************************************
For those who desire a quick view of the information on the website, use
the FTP text files. No graphics, but a quick and easy download that
doesn't require a web browser.
ON-LINE E-MAIL INFORMATION SERVICE
info(at)vansaircraft.com ***********************************************
This address is available for asking non-technical questions to Van's
Aircraft. It can be used for a variety of general questions you might have
about the products available from Van's Aircraft.
ON-LINE E-MAIL ORDERING
order(at)vansaircraft.com **********************************************
Available exclusively for established customers for use in ordering parts
and accessories. Please include your name, address, phone number, builder
number, part number(s) desired, and part description(s) in the e-mail.
ON-LINE E-MAIL TECHNICAL SUPPORT
support(at)vansaircraft.com ********************************************
Van's Aircraft is dedicated to ensuring success in your building project.
Send your builder support questions to this address for a prompt response
to any difficulties you may encounter.
AUTOMATIC E-MAIL INFORMATION RETRIEVAL SYSTEM
auto-info(at)vansaircraft.com ******************************************
A new feature that allows you to retrieve most of the information
available on the web site using only e-mail. Just send a blank e-mail to
this address to automatically receive the index of files.
Enjoy your visits to Van's Aircraft On-Line and feel free to leave any
comments (good and bad) about what you see to:
Thanks and hope you enjoy!
Fred,
Take the GPS speed on three different headings 90 degrees apart and plug them
into:
(Sq rt of (X^2+Y^2+Z^2+[(X^2*Z^2)/Y^2])/2=Calibrated airspeed
I put this formula in Excel so I can just plug in the three speeds-it works
great.
Joel Harding(RV8 wings)
ab320flyer(at)aol.com
From: owner-rv-list(at)matronics.com on behalf of Edward Cole
Sent: Tuesday, February 11, 1997 3:30 PM
Subject: Re: RV-List: Oil Coolers
is
perfect
are
> Vancouver, B.C.
Ed Cole
e mcole(at)concentric.net
Columbia Airmotive 1601 S.W. Sturges Dr. P.O. Box 428, Troutdale, Ore. 97060
ask for Jeff (503) 665-4896.
Joel; help me out. If I read this correctly, it is solving for pressure
alt. as well? I'm not very astute in math (basically still in the pie are
round stage), but my E6B left over from the AF days has IAS+or- installation
error=calibrated. CAS +or- pressure alt = true AS. TAS +or- wind = ground
speed. Then there is a compressibility correction at higher AS, but doesn't
have any material effect at our speeds.
I'm not flaming, I just don't understand how the formula corrects for press.
alt. to get cal. AS.
It's part of my problem when I first started flying my 6. The coffee talk
left me with the impression that I had the slowest 6 flying ( I considered
IAS by alt/temp). But when one of the talkers said that his was proven that
fast because the GPS showed he was doing 205 mph, and it didn't make any
difference what his airspeed indicator was showing, I knew we were talking
apples and oranges. He didn't brag about his return trip.
This misunderstanding on my part lead to a letter to Vans, which was never
answered, regarding the, I thought, high 'cruise speed'. To me, the best
cruise speed is the most miles per gallon, best endurance (loiter) is most
minutes per gallon, and fastest speed has to be qualified by alt, temp and
flight attitude (level, diving, etc)and power. I noticed that Johanson had
a speed of about 156mph from HA to CA. I would assume he was after best
cruise speed, I damned sure would have been, over all of that water.
Again, I'm not flaming, but does the intricacies of math solve the pres/temp
thing, or should the CAS be TAS?
John Darby RV6 N61764 flying
Stephenville TX
johnd@our-town.com
Subject: | Re: Van's Aircraft On-Line |
Wow, I'm famous. Just a nit, but it is 'Kelley', not 'Kelly'. Great
page and you can bet it'll be at the top of my links as soon as
possible. Thanks, Van's.
PatK - RV-6A
> engine.
> movement.
> Good Luck
Thanks, Jame? It's on it's way now, and I think Van's does modify the
mount before shipment of the finishing kit if so requested.
> Ed Cole
> RV6A Wings
> Dann Parks
> dann_parks(at)kteh.pbs.orgDann,
I just feather the trigger and turn the shaft. There is enough tension to
keep the whole assemblt from turning on the ram. It has worked very well
for me.
Ed Cole
p.s.
Your rudder with the taped stiffeners looked great at the EAA Mtg. last
night.
Subject: RV-List: Van's Aircraft On-Line
Date: Tuesday, February 11, 1997 9:11PM
Greetings RV'ers,
WORLD WIDE WEB
FTP
From: | annie CHAUVET <106466.3131(at)compuserve.com> |
In the RV-6 construction manual Ibought before ordering my Kit there are 8
pages about all the AVCO LYCOMING Engines explaining the meaning of all the
letters and numbers.
if you are not able to get a copy in STATES I will be pleased to fax all
these info as soon I have your fax number !....
For info I'll install a IO-360 180hp on my plane, when? I dont know, I am
trying to finsh the second wing (right).
Very truly yours
Jean Claude (France)
Subject: | Lyc. IO-360 Sump Swap? |
I just installed my Lycoming IO-360-A1A and need to swap out the sump and
intake tubes. I am not an RV builder, but a Cozy builder, so I need an
updraft sump or maybe one where the servo mounts on the accessory case side
(I'll skip trying to use terms like "front" and "back":-)). It is my
understanding that it is the prop-sided servo mount that goes on easiest for
the RV, so I thought I would check with this group to see if someone wants to
trade.
The engine I am removing the sump/tubes from has 2100 TTSN on it with no
damage history. It all looks clean and straight. So, if you are interested,
please reply back to me by e-mail. FYI, I am in the Seattle area.
Eric Westland
The one I have is one that a friend made for me -- he welded some
extra material on the end and then ground it off so it is roughly the
shape of the race. This keeps it from turning when you spin the
shaft. I would think you could do something similar with the "cap
screw" method.
randall(at)edt.com
> Dann Parks
Dann,
for me.
Ed Cole
Thanks, Ed. I'll try it. I've had a few times when I couldn't find the right
washer combination.
Dann
I made a booth about 4' wide by 3' deep using 2x4's covered with foam
insulation with alum foil on both sides sealed with duct tape. I installed a
bathroom wall fan to the outside with a plenum from the fan to the floor so
the fan draws from the bottom. I put in 2 100 watt light bulbs in each back
corner controlled thru a wall mounted thermostat for an elec baseboard
heater. The bathroom fan doesn't really move as much air as I'd like but it
works. I use a Hobbyair pressure mask system when shooting nasty stuff like
the DP40 primer I'm using. A larger blower (maybe a squirel cage furnace fan)
would be better but it needs to be explosion proof to avoid launching you and
the booth into orbit. I built a shelf out of 2x4's and use egg crate light
fixture diffuser material on the 2x4's when handling small pieces. I put a
rod across the top to hang larger pieces.
Mike Talley - RV-6 lh wing about 25% done
Very nice set up. Could do without Two intro screens before getting to the
real main menu.
Richard Chandler
From: | James Cimino <jcimino1(at)worldnet.att.net> |
Subject: | RV-8 Tail pictures |
I know all you have been waiting, I finally added a few pictures of my
completed tail to my page. In case you can't find your bookmark its
"http://www.geocities.com/MotorCity/5771/"
Jim Cimino
RV-8 sn80039
Subject: | Re: Skyforce SkyMap II |
aol.com!Cafgef(at)matronics.com wrote:
> << Skyforce Avionics >>
> The february issue of AOPA Piolet, on page 117 has a write-up on the
> skymap. It appears that the skymap has a map area diagonal of 3.25 inches
> compared with Garmin 195 of 4 inches. The rest of the display area is used
> to designate buttons. That would give the Garmin 195 a somewhat larger map
> area with more pixels for less $. The question I have is can the Garmin
> antenna be located remotely like some of the other handheld GPS units.
> Gene Francis cafgef(at)aol.com
Gene,
The article isn't entirely accurate. The diagonal of the actual map
portion of the screen on my Skymap is 3.25" in "portrait" display mode,
and 3.75" with the screen set in "landscape" mode.
The diagonal of the entire screen excluding the on-screen button labels
is 4.25" in both modes. This dimension includes the actual map plus the
nav info fields bordering the map, which include CDI, next waypoint,
current position relative to nearest airport, distance to waypoint, ETE,
ETA, GS, bearing, track, map scale, and various other indicators such as
battery strength.
The entire screen including everything is 5" diagonally.
In my opinion, having the button labels on the screen is a nice feature
that is worth the screen space they use.
Hope this helps.
Bob Reiff
From: | "Robert G. Miller, Jr." <rgmiller(at)sprintmail.com> |
Sylvan Adamson wrote:
> >Fellow Listers:
> >application?
> >Thanks,
> >Doug
> >= 347 Krattley Lane
> >= Hudson, WI 54016
> >= 715-386-1239
Doug:
It may be done all the time without an explosion proof fan, but if you
do so, you are literally taking your life in your hands. The vaporized
paint that is coming out of the spray gun is EXTREMELY FLAMMABLE. One
spark from the fan motor will result is an instant flash fire with the
room temperature reaching 1600 degrees F. If you have any doubts,
E-mail me and I will give you the name and telephone number of a friend
who experienced such a flash fire / explosion personally. He received
second and third degree burns over 65% of his body and spent 3 months in
a burn unit. Despite many surgeries, the scaring is still unsightly and
he suffers constant itching, temperature change intollerance and the
inability to withstand direct sunlight.
IT IS WORTH SPENDING THE MONEY. BUY AN EXPLOSION PROOF FAN OR PAINT
OUTDOORS!!!
Robert Miller
Subject: | Re: Lyc. IO-360 Sump Swap? |
Eric: I have an 0-320 B2C with an updraft sump and looking for a "prop side"
injector sump from a 360 for my RV6. I have called both Lycoming and
Mattiuk re interchangability, and they both say the gasket part numbers are
the same, hence it will fit. Others say minor oil pick-up changes are
necesary on any sump interchange, and tubes are generally interchangeable.
Mine is a relatively new engine; 2100 ttsn and had a Lycoming Williamsport
overhaul. If you are interested in a swap, let me know. Regards, Peter Hanna.
>trade.
>Thanks,
>Eric Westland
Peter Hanna, RDM Corp, 4-608 Weber St. North, Waterloo, Canada, N2V1K4.
B: 519-746-8483 X224, 1-800-567-6227 X224, Fax: 519-746-3317.
Email: peterh(at)rdmcorp.com
Presently working on the fuel tank of my rv6. Just got an offer to buy a
1987 200 hp ly engine with 1200hrs total time (no wreck) for $12,000. My
questions is has anybody out there experienced installing this engine in
the rv6, what kind of modifications did it take in the cowling etc. I'm a
first time builder and just threading water so far.
Joe/wingtank
reply to joe(at)flnet.com
I guess the time has come to go public with my RV-8 Web Page:
http://acd.ucar.edu/~arter/RV8.html
I'll be updating it soon with images of my built-in electric aileron
trim tab installation, and hopefully some wing spars.
Phil Arter
philip.arter(at)mci2000.com
From: | "Robert L. Nuckolls, III" <72770.552(at)CompuServe.COM> |
Subject: | A primer on ATTITUDES . . . |
Been watching the dialog on "simple, cheap and low-cost"
attitude indicators. Many folk have already picked up on
the shortcomings of many low cost "attitude indicator"
offerings . . most notably from the ultra-light contingency.
In support of understanding and the exercise of good options
I offer the following:
"Attitude" is generally understood to describe the
positioning of an aircraft with respect to earth surface
(the mean surface, ignoring things like mountains, canyons
and potholes . . . sea level is about as close to mean
surface as one can physically demonstrate). There are
four basic means for deducing attitude (1) local reference
(2) universe reference (3) inertial reference and
(4) gravity reference.
All four of these systems are utilized to various
degrees in the cockpit of most airplanes.
(1) LOCAL REFERENCE is your eyeballs . . . the visual
contact with the outside tells us how well we're doing.
Sources for error: sloping terrain, obstructions to
perception - fog, white-out, glassy seas, etc.
(2) UNIVERSE REFERENCE is gyros . . . unless acted upon
by some outside force, a gyro will point at some fixed
point in space. Obviously, as the earth rotates, a gyro's
indication will change depending on latitude of your current
location -and- direction the gyro was pointed when it was
first spun up. Attitude gyros are fitted with pointing
mechanisms that use gravity reference to keep the critter
right side up. Heading gyros (unless slaved to a magnetic
compass) simply drift as the earth rotates. Hence, they
require occasional annual updating to match the magnetic
compass.
Sources for error: Friction in rotor and gimbal bearings,
wind drag inside the instrument (remember, the thing
turns at 10,000 rpm - 2" diam rotor has perimeter of 6.3
inches. The SURFACE speed of the rotor is over 80 feet per
second!) and mechanically induced errors from
erection/calibration systems. For example, if you
fly in a coordinated 30 degree banked turn for about
15 minutesand then level the wings, you'll find that your
attitude gyro has picked up some error while trying to
erect to a new "gravity" vector.
(3) INERTIAL REFERENCE says, "if I turn at 3 degrees per
second for 10 seconds, I'm now 30 degrees difference from
where I started. Hmmmm . . . this is obviously limited.
This is how your turn coordinator works. It's a rate
sensor that has no idea where you're pointed right now
but it does know how fast your heading is CHANGING.
Angular rate gyros are core components of an inertial
navigation system along with linear rate sensors
(accelerometers). These systems must be initialized
from a known baseline. Like sitting on the ramp before
engine start. The systems may also use data from other
parts of the navigation system (iron gyros, keyboard
input by pilot, pitot-static transducers, GPS, VLF Nav,
Loran, etc.) to decide where we are and what our current
attitude is.
Once the system is "stood up" it keeps track of linear
accelerations (feet per second per second) and rotational
rates (degrees per second) in millisecond slices to deduce
our current position and attitude. The turn coordinator on
the panel is a rate sensor which requires you to INTEGRATE
readings with time to deduce a change in heading.
Sources for error: Most modern inertial sensors have zero
moving parts so things like friction and windage are no
problem. No-moving-parts sensors have calibration drifts
with respect to temperature but this is small and can be
calculated out. The largest source of error is time dependent
and based on limits of sensor resolution and magnitude of
uncertainty in calculations. Fortunately, the short term
stability is VERY good and other sensors such as radio nav
aids and iron gyro platforms can be combined with inertial
sensors to paint and update a VERY accurate navigation
picture for the duration of flight.
The needle portion of turn coordinator is also a gyro but
it turns at a much lower speed than the attitude and heading
gyros. Further, it's constrained with a series of springs
that forces the gyro maintain a fixed position with respect
to the airplane. As you CHANGE direction, the gyro tugs on
the springs with a force that is PROPORTIONAL to your RATE
of turn. Obviously, coupling the gyro frame to a pointer
allows one to display turning rate on the face of the
instrument. This makes your turn-coordinator an INERTIAL
REFERENCE device.
There are important differences between Turn Coordinator
(airplane roll axis displayed on face) and the older Rate of
Turning (single, fat, upward pointing needle) instrument.
A Turn Coordinator's gyro axis is canted up from horizontal
by a few degrees to make it slightly sensitive to ROLL.
The old Turning Rate instrument is insensitive to roll rate.
This enhancement of instrument makes for more accurate
"no gyros" maneuvering.
(4) GRAVITY REFERENCE is a important part of the nav sensor
system but certain things must be known for gravity to be
a useful parameter for display. First, you cannot be
changing direction (turning) because a coordinated turn can
present a new and totally false picture of where the center
of the earth is lies with respect to your aircraft.
This is why the needle and ball are combined on our panels.
To deduce that wings are level, both needle (turn rate)
and ball (gravity vector) values must be zero.
Sources for error: The ball in our turn coordinators
is about as free from error as any device in the airplane
. . . when the ball is centered, you can believe that
the gravity vector is parallel with your yaw axis. Now,
if the rate of turn is ALSO zero, you can believe that
the gravity vector represents an accurate position with
respect to the center of the earth.
With a little thought you can see that as pilots we use a
smoothly integrated combination of local, gravity, and
inertial inputs combined with other senses (sound and stick
forces) to maneuver an airplane. Gravity and inertial senses
in your butt and inner ear are subject to the same confusion
factors that plague instruments. Loss of local sensing is
best replaced with stable platforms (iron gyros) but it's
very possible to get by with a manual integration of
inertial and gravity vector data (needle and ball) to keep
the dirty side down and the pointy end forward.
Obviously, devices offering only gravity referenced displays
cannot be depended upon as sole indicators of aircraft attitude.
THE FUTURE:
A number of manufacturers are offering solid state rate and
linear accelerometers. These may be combined with "slow"
sensors like GPS and LORAN to mathematically deduce everything
you ever wanted to know about where you are, where you're
going and whether or not you're right side up. The trick
is to design a system that can take data from a variety of
simple sensors, deduce what is needed to know and display it,
and be capable of falling back on less accurate but equally
stable modes of flight in case of certain sensor failures;
an electronic reversion to needle-ball-airspeed-position
mode from an attitude-position mode. The micro-controller
combined with the new families of low cost sensors will
make it all possible.
WRAP UP:
Low cost "attitude" displays are not. The turn coordinator
is probably the simplest, most reliable alternative to iron
gyros. On anything less than a CAVU day, the T/C should be
a dispatch item (don't go flying without it) and it should
enjoy two power paths for energy to keep it running. The
critter won't do you any good unless you are practiced in
it's use. Shoot some non-precision approaches under the
hood (make up your own GPS approaches to some little airport
. . or even a stretch of straight highway . . . you just
need some kind of runway-like ground reference) and get
someone to ride shotgun for you several times a year.
It's fun, it's enlightening and it could help you avoid
bending an otherwise perfectly good airplane!
AeroElectric Connection
(o o)
==========oOOo=(_)=oOOo==========
| Go ahead, make my day . . . |
| Show me where I'm wrong. |
72770.552ompuserve.com
http://www.aeroelectric.com
From: | Lothar Klingmuller <lothark(at)worldnet.att.net> |
Subject: | GARAGE & DOOR SIZE FOR BUILDING RV-6A |
I am planning to build a unattached insulated garage (which we call STUDIO
for local zonig, permitting purpose) with radiant warm floor heating using
warm (~110 F) warter. The heat source will be a 20 gl hot water heater
possibly sublimented with warm water from a storage tank. The tank will be
heated during the day from solar collectors..
Size will be 24' x 30' with an 18' x 7' garage door. The size should allow
to complete the AP and roll the eintire AP on dollies out of the door (if my
paper scale plan is correct).
Any experience factor and comments from builders who build their own
garage? What I am after are hints like "why did I not incorporate XYZ".
ALL comments/help are much apprecieated. THANKS!
Lothar* Klingmuller = lothark(at)worldnet.att.net = Denver - (303) 922-2329 h &
FAX~~ -6A continueing w/ fuse'ge when garage is build . *(pron'd: "low-TARR")
Subject: | Re: RV-8 Web Page |
Phil, I don't think you'll have enough room in that workshop....
PatK - RV-6A - insanely jealous of folk with REAL shops.
Subject: | flying and eating |
If you like to flyout for a "$100 hamburger," i just discovered the $100
Hamburger website at http://www.tpwi.com A very extensive list of
airports and eating places which is rapidly expanding and is constantly
up dated.
J. E. Rehler flying RV6A N517RL
You may want to break it into several pages. It's a real memory chomper.
But I have to tell you, that is simply the most GORGEOUS workshop I have ever
seen. Absolutely beautiful. I'm jealous as hell.
"Wait a minute, you expect us innocent children to climb up dangerous
scaffolding and paint naked people all over a church? We'll do it!!"
-- Yakko Warner, Animaniacs
"Yeah, I've got ADD, you wanna make something of.... oooh, cool. Look!"
Pat, don't feel bad. That's not a workshop, it's some kind of weird
warehouse with some airplane parts in the corner. Good lord, I'd never
find the house again if I had a shop like that. Phil, you're a mean
man. Next time you take pictures of your project, could you at least
temporarily put the pieces in a small closet and snap the picture? ;)
Mitch Faatz San Jose, CA
RV-6AQME, working on left wing
>From: Patrick Kelley[SMTP:mail.ic.net!patk(at)matronics.com]
>Sent: Thursday, February 13, 1997 12:09 PM
>To: rv-list(at)matronics.com
>Subject: Re: RV-List: RV-8 Web Page
Subject: | Engine Installation |
Listers
Well I finally came off the money, and sent Eustace Bowhay a check
for a zero time O-320 E2D. the RV-4 airframe I have been working
on for the last 3 1/2 years will be finished in a few weeks.
Now I venture into unknow territory. I have been reading everything
I can about engine installation ( mostly Tony Bingelis ). However
one cannot learn everything from a book. What I need to know right
now, I think, is what do I need to do to the firewall, and the engine
before I hang it on the engine mount. I looked in the archives, but
it's getting so big you could spend weeks going through it.
Any help from someone who has been down this road before would
be of great help.
Craig Hiers
RV-4 N143CH
Tallahassee,FL.
I can't afford to eat, but I've got a motor.
Subject: | Re: GARAGE & DOOR SIZE FOR BUILDING RV-6A |
I built my garage with high ceiling and a star to much storage upstairs.
Think about it.
Cecil RV-6A
Subject: | Re: A primer on ATTITUDES . . . |
> compass.
> attitude is.
> REFERENCE device.
> THE FUTURE:
> WRAP UP:
> Regards,
> Bob . . .
> (o o)
Hey Bob take it to some one who cares like NASA(cant believe I read the
whole thing!!!!!!!!!!)
Dave Price
PP-ASEL
Mitch, hi
Aw, now you're making me feel bad. That is the closet. :^}
Phil Arter, RV-8 #80005
(303)459-0435 home
(303)497-8069 work
Herman
Yes you are correct, it is a first run E2D overhauled to factory
spec's. the motor is coming from Eustace Bowhay who live's in
Blind Bay B.C. I paid 10,700$ U.S. seems like it was about 70 cents
for every canadian dollar, exchange rate. I jumped on this motor
real fast, because here in Florida you will pay about 4,500$-5,000$
for a run out case on it's thrid overhaul. Also Eustace is held in
very high reguard by Van's and a lot of other people. I could not
see myself going wrong here. the motor is also set up to run a constant
speed prop, but I'm going to put the plug in it and run a fixed
pitch prop.
Good luck with your motor, you should not have any problems selling
it.
Craig Hiers
Tallahassee,FL.
RV-4 N143CH
David Price wrote:
> > (o o)
> Dave Price
> PP-ASEL
Hey dave, I read the whole thing and learned something, which is what
the RV list is about, If you don't like it use the delete key,
or better yet unsubscribe yourself. If you don't have something good
to say don't say anything at all.
Craig Hiers
Subject: | Canopy Frame RV-6(Tip-up) |
Please Respond either to this list or to: jbalbierer(at)nysyr.ang.af.mil
My canopy frame on a tip-up canopy is 3/8" inward from the edge of the
fuselage at the front of the frame on both the left and right sides. I
believe that my spacing on the longerons is wide at this point. Note: the
frame will not extend any further without binding the welded tubing. Any
solutions, other than shimming at this point?
Thanks.
From: | Dean & Scott Spencer <dspencer(at)kiva.net> |
David Price wrote:
MUCH SNIPPED...
> > Bob . . .
> > (o o)
> Dave Price
> PP-ASEL
Hey Dave, I can't believe you REPRINTED the whole thing. Give US (and
Matt) a break! Personally, I happen to like Bob's effort.
Get back in your 150!
Scott
Comm & CFII... ASEL,ASES,AMEL,glider & A&P
From: | Shawn Falzarano <falzsf(at)terminal.autobahn.mb.ca> |
Subject: | Cost of a new IO-360 |
Just curios of the cost for new IO-360 engine is? Please state
which funds you taking about too, I live in canada.
Thanks for the info
(just looking into the kit for a future build of one!)
Subject: | Lead time on O-360, C/S prop |
If you are considering buying an engine from Van's, order EARLY. I
ordered an engine and prop a couple of weeks ago. Van's is calling
for the engine to be shipped from the factory 10 June 97, the prop is
supposed to ship 10 May 97.
Tim Lewis
RV-6AQ #60023
timrv6a(at)earthlink.net
> Phil Arter
Phil, is this really your shop or computer enhanced pics of aluminum
over a Sunset Magazine Home of the month. Sorry about that view, it must
be very distracting!
Ed Cole
Working with proseal in a small, cold, unpainted, crowded, messy garage.
Thanks for the up-date. I seem to get some added and more accurate
information when I stir the pot a little. I'm just now starting to look for a
GPS unit for my 6-A so any information helps.
Gene francis cafgef(at)aol.com
> Dave Price
Dave, I can't believe you RE-PRINTED the whole thing. What a waste of Matt's
archive space!
Elon
ps: Nice job Bob.
Subject: | Flaming on the list |
A suggestion for dealing with unwarranted flaming.
Ignore it on the list. Don't give the perpetrator the satisfaction of
a public response.
Send a PRIVATE email. If he gets five private shafts he'll think
twice next time. If he gets five hundred, he might even examine his
behaviour.
You don't have to shout at someone to get stuffed. That only
encourages some of them. Sometimes it's more effective to quietly
invite them to visit a taxidermist.
Peter Bennett
Sydney Australia
RV6 working inside fuselage
Subject: | Re: Engine Installation |
Nothing really. It is almost imperative that you hang the engine before you
start cutting any holes in the firewall otherwise you will end up with holes
that aren't quite in the right place. Your engine probably doesn't have two
ports for oil pressure, so make sure you put the fitting on the engine first
or it's real tough to mount it later.
Hang the engine, then write down EVERYTHING that will need to be plumbed,
wired, hung, and otherwise connected to the engine. There is a great list in
one of Bingellis' books that covers just about everything. Then draw
outlines of everything that mounts on, or holes that go through, the
firewall. Once you're reasonably certain you haven't forgotten anything
(right..) start with one system at a time; i.e., plumb the *entire* fuel
system. Then the alternator system, etc. As much as possible, resist the
urge to bounce from one thing to another. Otherwise it's real easy to forget
to tighten something that you planned on "getting back to".
Remember, every wire and hose has only two ends. Hook up one end, then the
other, then move on.
Ed Bundy RV6A #23834 N427EM - flying
Eagle, ID
ebundy2620(at)aol.com
> > Regards,
> > Bob . . .
> > (o o)
> Bob I'm very,very sorry for the stupid comment I made last night and
the Matt and the rest of the group I hope we can somehow forget I ever
said anything.I'v had a real bad personal problem and wasent thinking
straight or paying attention to the real grasp of the thread that was so
well put ,and took a lot of time and thought.I'm not realy like that!!!.
So I hope you can forgive me,and we can get by this.Will unsuscribe if
neccesary!!!!I do enjoy learning here.
So Sorry,David Price
PP-AS#%$#le
Subject: | Re: Cost of a new IO-360 |
The January 1, 1996 Lycoming Price list shows prices ranging from USD
39,089 to USD 40,595 depending upon model and application.
I'm guessing that Van's price for this engine will be in the mid-$20K range.
Best Regards,
Dave Barnhart
rv-6 sn 23744
Craig, an E2D is not capabable of running a const. speed prop.
It was either modified or is not an E2D.
The E2D's were used on Cessna 172 with fixed pitch and the acc case
does not have provisions for the prop govner and the crank is not
set up for const. speed. I own two E2D's so I know.
It is either some thing like E3D or whatever or someone modified it
or someone is confused.
Herman
> Herman
> pitch prop.
> it.
> Craig Hiers
> Tallahassee,FL.
> RV-4 N143CH
From: | J.Ken_Hitchmough(at)magic.ca (J.Ken Hitchmough) |
Many folks have forgotten the oil pressure line fitting before hanging
older engines(I'm not sure but I think newer engines have an alternate
hole)
Ken
<73101.73(at)CompuServe.COM>
Oh, and by the way, buy yourself a set of RV6 preview plans. It costs
about $25 or so but shows you a very good idea of how these pieces all will
go together. Don't build from them of course, but just take a good look.
If you don't want to buy them I'm sure you can find a 6'er who will loan
them to you for a look. They explained a lot to me.
-Mike
unpacking spars!
From: Mark Reisdorfer [SMTP:73101.73(at)CompuServe.COM]
Sent: Thursday, February 13, 1997 10:33 PM
Bunn #23; Jim Cimino; John Ciolino; Ron Dunn; Mark Goldberg #87; Andy
Hanna; Joel Harting; FC Hollendorfer; Kevin Horton; Brian Huffaker; Steve
Johnson; George Kilishek; Rob Lanier #134; Marc LeFevre; Don McNamara; Dirk
Meulemans; Tony Moradian; John Myrick III; John Perrin #118; Mark
Reisdorfer #20; RV-List; Mike Weller; Rod Woodard
Subject: HS Stab
Help!
I am finally getting to the point of attaching the skins to my HS stab and
have
a question. When attaching the HS-607 to the front spar the drawings show
trimming the flange of the 607 to clear the HS-814, and also trimming the
skin
to clear the HS-814 as well. It looks to me as if there is insufficient
edge
distance on the flange of the 607 if it is they only thing trimmed. Can I
trim
the 814 a little to decrease the amount taken off the 607 flange? This
would
possibly allow proper edge distance.
Have any of you trimmed your HS skins in this area? It is difficult to see
if
this is needed without the preview plans of course.
Mark Reisdorfer
73101.73(at)compuserve.com
80020
>(Again, I'm not flaming)- yeah, sure John
John,
Well, first of all I didn't originate this formula I just passed it on, and
I'm probably worse at this math stuff than you are but I'll try to defend the
logic of it if I can, since I posted it.
What we are really after is an indication in the cockpit that will give us
the closest approximation of our speed through the air and consequently over
the ground that we can get. At sea level (or more desireably just a few
feet above) and standard temperature and pressure our indicated airspeed
should equal ground speed in a zero wind condition except for instrument and
instalation errors. If we apply those we have calibrated airspeed which
should be as accurate a reflection of our groundspeed as we can get. As the
pressure and temperature vary from standard conditions the calibrated
airspeed will have to be corrected to give us this close approximation of our
actual speed, so you're right that it would more accurately reflect true
airspeed. All this formula does is use GPS speeds to factor out the effect
of wind so that we can compare our indicated, calibrated, or true airspeed
(take your pick) to what we are actually doing. But you already know all
this don't you.
If any of what I just said makes sense you're probably just as lost as I am.
Joel Harding
> > > Regards,
> > > Bob . . .
> > > (o o)
> PP-AS#%$#le
Two thumbs up to you, Dave. Welcome back..
all of Bob's stuff snipped
>> Bob . . .
>> (o o)
>Dave Price
>PP-ASEL
I can't believe you reposted the whole thing!!!!
Joe
From: | "Paul Osterman III" <PineRanch(at)msn.com> |
Bob(of Aerolectric fame):
I agree with Craig's sentiments. Thanks for the info on "attitudes" and please
keep it up. I think you'll find most of us appreciate and look forward to your
occasional bits of information and other insights.
Paul Osterman
RV6A
Anderson, Ca
Riveting wing skins
David Price wrote:
> Hey Bob take it to some one who cares like NASA...
> Dave Price PP-ASEL
Craig Hiers
I have a question for the folks with flying RV's.
A friend that is building a -6 is in the over-voltage (OV) portion of his
project. The OV unit that I have in my plane is no longer available at ACS.
He has already purchased his regulator, so is hesitant on buying the
regulator from B&C with OV protection.
The question is how may of you are using OV and what good/bad experiences
have you had with your choice. Also maybe info on where to buy one etc... I
have searched the archives and found a couple of entrys pertaining to this.
Thanks for your help in advance.
Todd N92TM Flying (I plan to be at Sun-N-Fun)
Subject: | Re: Canopy Frame RV-6(Tip-up) |
>solutions, other than shimming at this point? Thanks. John
John,
Can you cut into the "U" channel outboard of the two canopy pivot points,
bend the "U" channel up which will swing the bottom of the channel out so as
to be closer to flush with the fuselage sides. Then, you can rivet on
patches that span the "V" cut and regain the needed strength. I cut one
side of my canopy this way so as to get better alignment. Also, I made new
canopy skirts that extended down, over the fuselage sides. The edges of
these skins matched with the front and rear fuselage skins. I thought this
looked better, was easier to seal and gave more flexability for fit as the
deeper side skins give you some leeway for fit.
Regards, Bob Skinner RV-6 BSkinner(at)navix.net
From: | "KEN HARRILL" <KHarrill(at)worldnet.att.net> |
Thanks for the excellent article on gyros! I am a few years away from
flying, and I am continually looking for information to help in designing
the optimum panel, considering cost and rapidly changing technology.
Please keep coming with this kind information. The large majority of
builders on the RV-List appreciate your efforts, even though there is an
occasional individual who responds negatively.
Ken Harrill
RV - 6, wings
K.Harrill(at)Worldnet.att.net
PS: I sincerely doubt that I will ever make your day!!!
Subject: | David sez he's sorry, Bob sez no sweat! |
>I made last night and the Matt and the rest of
>problem and wasent thinking straight or paying
>was so well put ,and took a lot of time and
>thought. I'm not realy like that!!!.
>by this.Will unsuscribe if neccesary!!!!I
Apology accepted and thank you. Please
don't leave the group . . . do that and
you REALLY make us mad! If you're building
an RV (or any other airplane) we'll
appreciate your participation.
I think this is a good place to END this thread
guys . . and David, how far along are you
on your airplane?
(o o)
72770.552(at)compuserve.com
From: | Meulemans Dirk <100554.1236(at)CompuServe.COM> |
Mark,
I'm about to close the HS skins on my RV-8. the skin is completely clear of
HS 810, but I did have a small overlap with the flanges of HS 814. I decided
not to trim the skin at this stage (i.e. without preview plans) because I
can't see the point of it. That small piece of HS814 doesn't seem to disturb
the overlaying skin profile. However, I just discovered another RV website
(sorry, forgot the name of the owner) that has a very sharp picture of the
piece we're talking about. This guy did trim the skin around the HS 814. Have
a look at: http://acd.ucar.edu/~arter/RV8.html
Dirk Meulemans
Subject: | Re: over-voltage |
I am flying without OV protection.
I guess thats kind of like having unsafe sex.
I expect you don't hear about the ones that have been saved by OV protection.
You only hear about the ones that did not have it and had their avionics fried.
I know of one Cessna that this happend to and it fried all the avionics.
That is the only one I have ever heard about.
Herman
Subject: | Wing Storage "Cart" |
Hello Everyone,
I'm in need of a moveable wing storage cart, but before building one I was
wondering if perhaps someone might have one available in the North Dallas
area. Please e-mail me directly if you have something to share.
Dick Flunker (RFLUNKER(at)AOL.COM)
RV-6A, putting skins on fuse.
Here is what happened.
I have the rear spar "fabricated" and am preparing to attach the HS411PP
with the AN3 bolts. I check the plans, go to my jig, decide what I need to
do, go back to the plans a last time to be sure I know what I am trying to
do, go back to the jig and stand in front of one HS412PP brackets and drill
the holes for the HS411PP AN3 bolts. AFTER the holes are drilled it occurs
to me that I should be standing directly in center of the rear spar
assembly.
(Later my wife tells me she could see me through the kitchen window that
looks directly into my shop. She sees a quizzical look come over my face,
and the word "WHAT" spoken.)
I called Van's and asked if it would be okay to just bolt this HS412PP onto
the rear spar like the HS411PP is, or do I have to start over. Someone
there sent me four bolts, and said they didn't know.
My questions:
1) Is this okay?
2) Since everything else is riveted closed around the 412PP what happens if
the bolts come loose. They are self-locking nuts/bolts, will that be okay?
Sincerely,
Your fellow lister ...
Terry Lorz
The point is it will be very hard to cleanly trim the piece after it is
riveted over the flange of the HS 814. How will you get a file in between
them to smooth out the edge of the skin cutout without disturbing the HS
814 flange?
Mark,
of
decided
> on your airplane?
> Regards,
> Bob . . .
> Hi again,
I'm in the process of selling all my other toy's so I can afford to do this with
out disrupting my
business and wrestling with the price of a 160 lycoming mid-time for a RV-4.I have
alot of tools ,no rivet
tools yet but I am a cabinet maker with some tools that will handle alum.including
milling machine and a
large shop with a good spray booth.At this time I can handle bying rivet tools
and the first kit parts but
have read horror stories of they have you're money and one day you will see the
stuff.I have looked at
aircraft ownership for awhile and think homebuilt is the only way that makes sense
for my finances plus it
seems that this is a better product in the long run than bying a 25 year old piper,less
room but way,way
neater.I am on the fence to when to start in this project (tommorro or next month).I'm
interested in vfr
only and manual trims and maybe backseat rudders,don't know who will be there at
this time.Don't think I
can afford to be arobatic but would love to be one day.Going to get my tailwheel
endorsment soon in a cub
and someone I know that has a RV-4 said that the RV-4 is easy compared to alot
of other taildraggers.He
also has offered to help me with my flying skills when it's time.I have enjoyed
the personal pages people
have put togather with there pride and joy's with all the links from here and hope
in the future to have
my own(if I can learn how to spell and type)thats all for now and I will just read
and sit back and enjoy
all the good info.
David Price
PP-ASEL in northern NJ.
Subject: | Re: Performance Equations |
>Listers,
Here are two density altitude formula's I found in Kitplane magazine.
DA=E+(66*(T-(59-(E*.0054)))) This is for Farenheit
DA=E+(66*(5/9)*(T-(15-E*(5/9)*.0054)))) This is for Celcius
E= Elevation
T= Temperature
I hope this helps.
From: | lsmith(at)coastalnet.com (Louis E. Smith Jr.) |
The RV-4 that I built in 1991 had a 60 amp Nippon Denso alternator with an
internal voltage regulator. I was using no overvoltage protection. On the
return trip from Sun-N-Fun 1992, the voltage regulator died. My com radio
was history. It was a TKM MX-11. I sent it back to the factory and they
fixed it for no charge with no questions asked. I have allready purchased
the "over voltage module" that Bob Nuckolls sell to go in the RV-8 that I am
now building.
Left and right wing skins fitted.
Louis Smith
Rocky Mount, NC
RV-8 #80126 wings N801RV reserved
RV-4 #2844 N102LS sold
I am pretty sure that Bob Nuckols sells what is called a'crow bar' over
voltage cut out. I had expected a crow bar encased in a box with a glass
labeled 'break glass, use crow bar to smash any over volts in cockpit'. But
no, it looks like a package of about 10 or 15 stamps glued together in a
stack with a couple of wires coming out of then. About $35 if bought
assembled, don't remember the kit price. I've had one for some time, and it
is as effective as the elephant protector I have in the a/c, haven't had any
elephants nor over voltage problems.
Bob, can you jump in here with the details? (the OV, not the elephants)
Stephenville TX
johnd@our-town.com
Joel; I understand the GPS/loran method of establishing a true a/s by
washing out the wind effects of ground speed. I do it by 4 headings, and
not as much math, but it works. I just didn't see how the method
established the calibrated a/s, and if it did, I wanted to try and
understand and use it. But from what you have followed up on, I am assuming
it is solving for true a/s. I copy on the TAS and CAS being the same at sea
level, standard day etc. and the foobar that comes up when you go non
standard non sea level etc.
Stephenville TX
johnd@our-town.com
Todd,
I have one of Bob Nuckolls crowbar overvoltage modules installed in my
six. No problems with the unit, it was easy to install and inexpensive.
You might drop Bob an E-mail and check it out.
Subject: | Wing Rotisserie, and storage cart |
Thinking of painting wings off plane. Has any one got plans on the
"rotisserie" ?, yes I had to leave AOL...go to Word, and get this one from
spell checker and come back ; ) . Probably could help if I got some plans
for a wing storage cart too and long as I'm at it.
Thus.... I too am in need of a moveable wing storage cart, so I'll ask also.
Before building one, perhaps someone might have one available in the
Syracuse/central NY area.
Please e-mail me directly if you have some ideas.
David McManmon McManD(at)aol.com
Subject: | Re: Wing Storage "Cart" |
Dick I would be glad to build you one if you can not find one , I'm also
looking into a second class on finsihing up the RV's....George Orndorff
Subject: | Re: Wing Rotisserie, and storage cart |
Dave ,
call me at 817-439-3280 and I can tell you in about 2 minutes now to build
one , I used one to paint my plane and it does a good job....George Orndorff
Hi!
Someone recently posted an article on this list informing us on how an
manifold press. gauge can be used for power information. I wanted to save
it but I guess I deleted it instead. Could that person please repost it
or send it to me at lm4(at)juno.com
Thanks in advance, Larry
The January 1997 Air Power price list says=8A
NEW AIR REMAN
AIR O/H AIR CORE
MODEL LIST POWER LIST POWER
LIST POWER COST
IO-360-A1A $33,627 $27,598 $25,105 $20,680 $17,484
$14,494 $6,700
IO-360-A1B $33,512 $27,505 $25,105 $20,680 $17,197
$14,261 $6,700
IO-360-A1B6 $33,471 $27,472 $25,149 $20,716 $17,197
$14,261 $6,700
IO-360-A2B $33,405 $27,418 $25,990 $21,399 $17,863
$14,801 $6,700
IO-360-A3B6 $34,216 $28,077 $26,647 $21,932 $18,289
$15,147 $6,700
IO-360-B1B $32,513 $26,694 $24,242 $19,980 $16,581
$13,760 $6,700
IO-360-B1E $31,353 $25,752 $23,298 $19,213 $16,138
$13,401 $6,700
IO-360-B1F $31,425 $25,811 $24,242 $19,980 $16,581
$13,760 $6,700
IO-360-C1C $32,618 $26,779 $24,569 $20,245 $16,760
$13,906 $6,700
IO-360-C1C6 $34,058 $27,948 $25,822 $21,262 $17,706
$14,674 $6,700
IO-360-C1D6 $33,791 $27,732 $25,676 $21,144 $17,550
$14,547 $6,700
IO-360-C1E6 $34,742 $28,504 $26,530 $21,837 $18,190
$15,067 $6,700
IO-360-L2A $31,425 $25,811 $24,242 $19,980 $16,581
$13,760 $6,700
John Top
Phone: (619) 549-3556
aol.com!RFlunker(at)matronics.com wrote:
> Hello Everyone,
I will also be in need of a "Wing Cart" this summer. Does anyone have a
drawing of one that may be posted or made available be e-mail.
Rick Osgood
Rick(at)ccc.henn.tec.mn.us
Subject: | Re: HS412PP/HS411PP |
> My questions:
> 1) Is this okay?
> Sincerely,
> Terry Lorz
Man, you ask hard questions. My recollection of AC43.13 is that it is acceptable
practice to replace a rivet
with a bolt or screw. If you're nervoous about not being able to inspect the nut
later, another possibility
is to use AN470-AD6 rivets. Put the factory head against the inside of the spar,
and form the shop head
against the steel bracket. There are many postings in the archives about pounding
#6 rivets.
If it were me though, I would start over. It may seem like a big inconvenience
now, but later in retrospect
you'll be glad you did.
(303)459-0435 home
Interesting article Bob. I bought a digital level to use in constructing
my RV-4. I wondered if the same type of sensor could be used to make an
inexpensive attitude indicator, and quickly answered my own question by
holding it at a 45 degree angle and spinning around in a circle (while no
one was watching, of course) to simulate a coordinated turn. The reading
dropped to much less than 45 degrees, so obviously gravity is the
reference.
A local friend, John Sheldrick, who's new RV-6 was pictured in a recent
RVator, is the retired Engineering Manager of Delco Electronics Avionics
Div., which builds inertial nav systems for military and commercial
heavies. Very interesting guy to talk to and a very interesting topic.
Bob Reiff
RVator canopy repairers!
I post this on behalf of one who is not on the list who has a tip up canopy
that has just had a lower corner piece of the pexiglass approximately 6"X 1"
break off when he was closing it. This has broken along side the pop rivets
in the tilt frame. The archives talk about cracks that can be 'repaired'
but what about sections? Can any of the superglues be used? Any
suggestions are welcome and you can Email me direct at lcoats(at)wave.co.nz and
I can post a summary of 'fixes' back to the list if there are any.....
L. Coats ZK-RVL RV6 flying :-) 168hr
>Dave Price
>PP-ASEL
Hey Dave, I can't believe you reposted the whole thing!
Why? I know it was good, but dang, I was reading your reply to see if you
had something to add. You didn't.
Mike Weller RV-8 (under construction)
midibu(at)hsv.mindspring.com (preferred) or mike.weller(at)msfc.nasa.gov
Subject: | Re: Man.Press.Ga. |
Larry, The info was published in a RVator. I'm not close to my back issues
now so don't have a reference. I did build a table in a spreadsheet to
derive percent power to go along with the true, calibrated airspeed data
(derived by a 3 way run, noting GPS groundspeed as has been recently
discussed on the list). The RVator article gave several different points
like 75, 65 % power, etc. and I interpolated (?) the rest of the points.
I'm not a mathamatician (heck, I can't spell, either) so use this at your
own risk. The article said to add the first two digits of the rpm and of
the manifold presure. If they add up to 48, that equals 75% power. I think
the article also gave a sum of 46 as 68% power and 44 as 62% power.
40 48.0% power
41 52.0%
42 55.0%
43 58.0%
44 62.0%
45 65.0%
46 68.0%
47 72.0%
48 75.0%
49 78.0%
50 82.0%
51 85.0%
Subject: | Re: Broken canopy |
From: | Mike Kukulski <kukulski(at)highfiber.com> |
Previously written:
canopy
1"
rivets
I started a thread about 2 months ago about a crack I put into my canopy
while drilling a rivet hole in it. Lots of discussion and conjecture from
the list, which led me to my local acrylic plastic supplier (I called
Van's re: a replacement canopy, but $480 for an RV-4 canopy plus crating
and shipping seemed too steep versus my vanity over a 3" crack).
The product recommended by the plexiglas supplier was IPS Corporation's
Weld-on 3. There are different numbers for this product, depended on its
viscosity. The #3 version is a clear, water-thin, very fast curing
solvent cement designed for joining acrylic (Methylene Chloride is the
active bonding ingredient required for plexiglass.) The thin Weld-on 3
has a capillary action which draws it into a crack or joint, ensuring the
solvent gets to the mating surfaces. As thin as this solvent is, it is
important to control it carefully, or it will run all over the plexiglas
surface, with a chance of crazing or fogging it. I also bought a squeeze
bottle equipped with a hypodermic needle-type of spout - this product was
called a "Hypo-200", mfg by Gaunt Industries, and was a controllable tool
for applying the cement.
Before gluing my crack, I practiced on some scrap plexiglass to get a
feel for its viscosity and the cured strength of the bond. (Of course, it
was hard to crack the plexiglass on purpose, even whacking it with a
hammer!) Total bonding strength is achieved in 24-48 hours, and I could
not break the glued joints. The plastic supplier claimed the bond would
be as strong as the basic material, but the repaired part will not be as
strong as an undamaged part due to the internal stress resulting from the
original crack. The crack is still visible after the repair, but the glue
is virtually invisible.
In my case, my crack occured on the bottom edge of the canopy right at
the rear seat back. To hide my repaired crack I laid up a non-structural,
cosmetic-only, fiberglass canopy bow at this station of the canopy
(behind the rear seat passenger's head). I think this turned out very
well - not a player for everyone though, depending on the location of the
crack. I can discuss the canopy bow in detail if anyone is interested.
Longer than I expected, but I hope this helps your friend with his canopy
problem.
(Installing the brake lines)
Mike Kukulski
RV-4 N96MK
Albuquerque, NM
From: | Stephen Jackson Soule <ssoule(at)vbimail.champlain.edu> |
Hey Dave ... If you get some plans let me know, I need to build a
cart/storage rack too.
Steve
Huntington, Vermont
Subject: | Re: (no subject) |
> > on your airplane?
> > Regards,
> > Bob . . .
> > Hi again,
with out disrupting my
have alot of tools ,no rivet
David
Your cabinet making skills will pay off big time in building an RV.
As for Bob, I know very little about how aircraft fight instruments
work, so when Bob speaks I listen ( besides he got 32 of my dollars
for his book and it's well worth it ). All is forgiven.
I think it's time for a big group hug.
Craig Hiers
From: | "les williams" <lesliebwilliams(at)msn.com> |
Terry,
I disagree with Phil's advice to "start over". I think that using AN525-10R10
screws would be perfectly acceptable for the application at hand (they are
specified to replace #4 rivets to attach the aileron brackets that were mis-
drilled on the quickbuilds). And you don't need to check them after
installation any more than you do the numerous bolts that attach the ribs to
the main spar which can't be reached either after the wings are skinned.
Only you and the "list" will ever know!
Les Williams
RV-6AQBME #60027 finishing wings
RV-6A #20299 complete 4/92, sold 10/95, 350 terrific hrs
From: owner-rv-list(at)matronics.com on behalf of Phil Arter
Sent: Saturday, February 15, 1997 9:27 AM
Subject: Re: RV-List: HS412PP/HS411PP
> My questions:
> 1) Is this okay?
> Sincerely,
> Terry Lorz
acceptable practice to replace a rivet
nut later, another possibility
spar, and form the shop head
pounding #6 rivets.
inconvenience now, but later in retrospect
(303)459-0435 home
One method I've seen used more than once to repair and cover that area is to
apply a strip of fiberglass "ala Dragonfly" over the entire rear bow and
joint. If he can locate a local builder, they can probably order a molded
strip for him. I imagine someone on the list has more info, but hope this
helps.
Les Williams
RV-6AQBME #60027
RV-6A #20299 Complete 4/92, sold 10/95, 350 terrific hrs.
From: owner-rv-list(at)matronics.com on behalf of L. Coats
Sent: Saturday, February 15, 1997 11:07 AM
Subject: RV-List: Broken canopy
Subject: | Re: Test taxi, flights, etc |
This thread was touched upon recently but not elaborated on.
What is the generel consensus of those of you flying regarding test flight.
High speed taxi tests are not looked on with any favor, it seems. I tried
them in the airplane I have 2000 hours in and it was rather difficult to
navigate down the runway after the power had been pulled. The transition
between full power and no power, even with gradual throttle movements does
not seem to represent the attitudes of the aircraft during landing; and I
believe this is what this exercise is suppose to make you familiar with.
What about "land backs" where one takes off and then immediatly lands. This
is recommended in the Flight Testing book (by Askue). These seemed to
imulate landings better, as that is what you are doing.
I think flight cards are a very good idea to delineate what will take place
on each flight.
Any thoughts??
Today, February 15, 1997 was a red letter day! I flew my RV-6A N929JC for
the first time. The right wing was a bit heavy but I was able to trim this
out with the manual aileron trim. The plane flew just like the factory
plane, light and smooth on the controls and very responsive. I was amazed at
how it wanted to climb and how fast it was. I was flying at 160 Knots before
I could get the throttle back to cruise power. In the pattern, with the
power at idle, I coasted the whole length of the runway before I was slow
enough to put the flaps down. The flight was a real joy! Trust me guys and
gals, all of the effort that goes into building an RV is worth every minute.
Keep pounding those rivets; you'll be glad you did.
Jim Cone RV-6A FLYING!!!
jamescone(at)aol.com
I'd like to touch on this topic. I built an RV-6 and had no TD time when it
was done and ready to fly. I got some time in a Citabria but still felt
that I wanted to 'practice' some more in my RV. I taxied at least 15 miles
around Arlington Airport. I even 'taxied' at 80 mph on Runway 29 at
Arlington; believe me, you have to apply lots of forward stick to stay on
the ground at 80 mph. Now that I've got over 200 hours in my RV I can say
that I didn't get any help from that kind of taxiing. Granted, it is a good
idea to get used to the feel of the aircraft but DON'T try to taxi at
take-off speeds. You're just asking for trouble.
>on each flight.
>Any thoughts??
John Ammeter
ammeterj(at)seanet.com
3233 NE 95th St
Seattle WA, 98115 USA
RV-6 N16JA
First flight August 1990
Subject: | Re: Free at last! |
Hey, Jim, can you tell us the difference between the SeaHawker and the RV?
John Ammeter
3233 NE 95th St
RV-6 N16JA
From: | Jerry Springer <jsflyrv(at)ix.netcom.com> |
> the first time.
***snip***
Jim
Great big handshake and congratulations on flying your bird.
Jerry Springer RV-6 N906GS First Flight July 14, 1989 :-)
From: | Ronald Vandervort <rvanderv(at)linknet.kitsap.lib.wa.us> |
Congratulations Jim, on your first flight. Another grin is now permantly
in place.
I had a chance to observe a first time flight this last week
here in the Seattle area. After that flight it's like my friend has been
to a special place that cannot be properly described with words........so
he just walks around with this great big grin. Whats even better is that
the grin has even gotten bigger after subsequent flights. Boy am I gonna
keep after those pieces of airplane and make them into one.....! I wan't
to go to that place you guys have been. Wonderful....!
Ron Vandervort, RV-6Q rvanderv(at)linknet.kitsap.lib.wa.us
From: | chinkley(at)ix.netcom.com (Curtis R. Hinkley) |
You wrote:
to do this with out disrupting my bbusiness and wrestling with the
price of a 160 lycoming mid-time for a RV-4.I have alot of tools ,no
rivet tools yet but I am a cabinet maker with some tools that will
handle alum.including milling machine and a large shop with a good
spray booth.At this time I can handle bying rivet tools and the first
kit parts but
>David
>Craig Hiers
David,
I would suggest that you look at building an RV one step at a time.
Come on over to the Frederick RV Forum in April and take a look around,
NJ is only 2hrs by car. There will be several shop tours where you can
see RV's in different stages of construction. I plan to have one of my
RV8 wings with the new spars on display so you can see the difference
in the new spar design vers the older spar.
If you ever had any doubts about your ability to build an RV, the
Forum will put them to rest. We will have a good metal shop with hands
on for those that want to try so riveting.
After the Forum, place your order for your tail kit and then order any
tools you might need. You will have a complete list of just what tools
you will need after the Forum. Build the tail and then make your
decision if you want to continue, if you decide that you dont want to
continue you can sell the tail kit and tools. Just think about it one
kit at a time, that lycoming purchase is 18 months away.
Good Luck
Curtis Hinkley
RV8 Dreaming about those SPARS
To all; I'm not going commercial here, just that a friend has put his RV 6A
up for sale. It is a very nice a/c. I know this bird second only to my own.
Limited information: 110 hrs TT, Lyc 0-320-E2D 160 hp 30 hrs out of major
and has c/s crank if you want to go c/s. Has a Pacesetter on it now. Has
gobs of stuff in it including Century 21 auto pilot. I have much more info
but if anyone interested contact the seller, Joe Crutchfield at 972-298-4940
evenings. Also E-mail at:
jc1(at)airmail.net
I know it is well built and nicely finished. He has to have a 4 place due
to family.
Stephenville TX
johnd@our-town.com
From: | Bob_Ungrin(at)on.infoshare.ca (Bob Ungrin) |
To Jim Cone.
Thanks for the encouraging words. Articles like this provide some
welcome encouragement to those of us that are spending every spare
moment in the garage/basement chained to a labour of love. Hope to be
flying my RV-6A within a year.
To Jim Cone.
From: | durbanski(at)juno.com (Daniel R Urbanski) |
Congratulation Jim, Have many happy and safe hours in your bird. Thank's
for the words of encouragement and to persevere.
Dan Urbanski RV6a working on left wing.
Fort Worth TX
writes:
>for
>this
>factory
>amazed at
>before
>the
>slow
>guys and
>minute.
>Hi!
Larry, watch for the Feb '97 RVator. The article I wrote has been
embellished with the power information as was printed in the RVator and
displayed here not long ago. Bill
RV-4-180 soon. N894RV with over 400 hours behind a O-320, Over 1000 RV
flying hours.
These opinions are mine and do not necessarily represent the opinions or
position of my employer.
the first time.
Hey Jim:
Alright Jim...congrats. I'm, well, we're all delighted to see another another
RV fly! All that work has paid off. Sounds like your first flight was great!
Remember though, you're supposed to blink a few times on downwind.
Maybe I will put in a few more hours today. The heck with pruning &
fertilizing the fruit trees, washing the car, mowing the lawn (yes, here in
California it needs it already), fixing the pasture fence....the kids can do
all that!
Paul Osterman III
RV6A Riveting wing skins
Anderson, Ca
From: | Robert Fritz <75303.1623(at)CompuServe.COM> |
Subject: | Re: Ivoprop-electric |
I gather from a signiture of yours that you've an Ivoprop with electrically
controlled pitch.
Please tell us more about it. performance, cost, durability in rain, etc.
Bob Fritz
> the first time.
Hey Jim must be incredible!!!!I think anybody that reads this thread is
smiling ear to ear and dreaming of what it must be like.It must be more
intense than one's first solo, and you're there.I wonder if someone
keeps all the first flight original-post RV-List letters together in a
file.Congrads agian!!!!!!(trying to keep this short)
David Price
From: | Kevin & Theresa Horton <khorton(at)cyberus.ca> |
The whole idea of high speed taxi tests and land backs dates back to the
early days of flight testing. Back then, you were never really sure if the
new design would actually fly, or whether there would be adequate control
authority at low speed. It was thought a good idea to try out the controls
during high speed taxi tests to make sure that the aircraft responded in a
satisfactory manner to the flight controls. These tests were done at
higher and higher speeds and often the aircraft would become airborne
before the power was cut.
In those days, the typical airfield was a large grass field with no defined
runways. You would take-off and land in what ever direction was into wind.
You didn't have to worry about going off the side of the runway.
Today, with most professionally designed, conventional aircraft, we can be
quite confident that the aircraft will fly, and that there will be enough
control authority at low speeds to safely take-off and land in the
conditions that should be present for a first flight (very light, steady
winds). The take-off and landing phases are the most difficult parts of
the flight, and most accidents occur there. The transition from full power
take off to idle power landing can be a difficult one in an aircraft that
is unfamiliar. Many people end up going off the side of the runway doing
high speed taxi tests and land backs.
My advice is to do no more than moderate speed taxi tests. Don't go
anywhere near take-off speed unless you and the aircraft are completely
prepared for flight. The first time you go airborne should be a true
take-off.
>on each flight.
Agree. You should have a very well thought out plan for every test flight.
Flight test cards are the best way to make sure that you remember what the
plan is. The test card should be very clear, should include all necessary
details on test conditions, and should include any safety reminders. It
should also have a place to record the data.
Kevin Horton
hopeful RV-8 builder (lurking and gather info, tools, etc)
Engineering Test Pilot
Transport Canada
Ottawa, Canada
Subject: | RV4 parts For Sale |
Due to circumstances, I have had to put my RV4 parts up for sale. I have
a 1992 tail kit about 60% completed, a 1992 wing kit not started, and
updated plans and manual. I am asking $ 3,500.00 for all.
Jim Lewman
lewman(at)wt.net
281-859-7624
Houston, Texas
Bob Japundza please e-mail me with the address you want messages sent
to.
Frank Smidler
smidler@dcwi
From: | Frank van der Hulst <frankv(at)pec.co.nz> |
>>Dave Price
>>PP-ASEL
Hey guys,
I can't believe you replied to the List!
A reminder to all: *think* before replying to the List; is my reply of
general interest to all, or aimed directly at the original poster? If it's
aimed at one individual, reply just to him.
Frank.
frankv(at)pec.co.nzZ (without the anti-email-spam Z, of course)
http://www.pec.co.nz/~frankv/
Frank van der Hulst, Software Engineer, Cardax, PEC(NZ) Ltd, Marton
"Knowledge=Power=Energy=Matter=Mass; A good bookshop is just a genteel
Black Hole that knows how to read". Terry Pratchett, "Guards! Guards!"
When I did my firewall foreward I started with the larger stuff first. Like
scatt hoses oil coolers and hoses and worked my way down to the smaller
stuff, like wires etc. My reasoning was that it is easier to move something
small and find a alternate place for it than something larger. You must first
have your baffling 100% complete or you will have to redo something. Be sure
to have your oil pressure fitting on the case before final installation. I
made several trips out to the airport and looked at airplanes with their
cowlings off to get ideas.
Chris May
RV-4 N595CM
> >>Dave Price
> >>PP-ASEL
> Hey guys,
> Frank.
Hay Frank
Why didn't you just replay to the people that responded? Also
your signature takes up seven lines of nothing about RV's.
Not flameing just an observation.
Jerry Springer RV-6 N906GS First flight July 14, 1989 :-) Hillsboro, OR
It's very satisfying each time one of us listers' RVs flies for the first
time. I'm sure that, like me, everyone here has followed Jim's trials,
tribulations, and progress. We *all* follow each other's progress. The
reason Jim's right wing was heavy is because the entire rv-list was right
there with him, in the right seat, cheering him on.
Good going, Jim.
Best Regards,
Dave Barnhart
rv-6 sn 23744
I too have read Vaughan Askue's book, and have reservations about extensive
high-speed taxi tests.
1. The new pre-drilled gear legs pretty well rule out any problems caused
by poor gear alignment.
2. It seems as though the RV-series does not require extensive high-speed
taxi tests. You don't hear about a lot of problems discovered during
3. The RV gets airborne at very low speeds and power settings. This makes
high-soeed taxi tests somewhat more hazardous (Becoming airborne
unexpectedly) than for other designs.
One of the purposes of high-speed taxi tests is to let you get the feel of
the airplane. In my case I not only plan to spend some time with MIke
Sieger, a good friend as (very) graciously offered to let me spend some
time in his RV-6 (with him in the right seat). With that, I plan to do a
*small* number of high-speed taxis, then go for it.
Also keep in mind that I've been flying nothing but a Champ and a C120 for
the past year. MY RV-6 will probably fly late this year, and I'll probably
have 50-60 hours of tailwheel time by then.
Best Regards,
Dave Barnhart
rv-6 sn 23744
Installing the systems
Subject: | Be still, my heart! |
All:
Well, coming in from the garage today I was pumped, and that was BEFORE I
read Jim Cone's announcement!
For the first time, my RV-6 is up on its gear with the empennage installed.
Boy, this thing really looks like an airplane now! It really was
exhilarating today standing back and looking at the product of the last two
year's labor. (It was also funny watching all the rubberneckers drive by.)
To those reading this that may be 'on the fence', the exhilaration is
almost indescribable.
Almost all the engine parts are here, the Hartzel CS prop is in the corner,
and the avionics and instruments are arriving as fast as my wallet will
allow. It won't be long now.
Best Regards,
Dave Barnhart
rv-6 sn 23744
Installing the Systems
Subject: | Refused/appealed Medical |
Hi all,
I'm hoping someone out there can advise me as to my next step regarding
appealing a failed medical.
1. I applied for the class three physical and upon disclosing my daily use of
prescribed medications the Medical Examiner stated that he could not issue the
student pilot certificate. He then suggested I get a letter from my regular
physician describing the condition and consequences.
2. I supplied that letter to the ME who sent the request into the FAA.
3. The FAA rejected the physical/letter stating that I had 30 days to appeal.
4. I immediatly sent a registered/return reciept request asking for all
necessary paperwork and instructions and quoting both doctors that "the
pathology does not warrant rejection."
5. I received the return receipt indicating the FAA got my request for appeal
on 1/10/97, well within the 30 days.
6. That's been over 5 weeks and I've heard absolutely nothing.
So here's my question: Can someone give me the name of a warm body at the FAA
that might be able to kick this thing in the butt? I've been out with friends
in two RV-4's, a Cessna 310, a T-34 Mentor, a Duchess, two A-36 Bonanza's, and
a
couple of other nice planes and have offers of just-pay-the-gas lessons! I
gotta get this thing moving!!!!!!!!
Thanks mucho,
Bob Fritz
RV-6 workshop, financing and everything else in place.... EXCEPT for the FAA.
Subject: | starter ring gear |
I need to install a starter ring gear on to the aluminum hub. (O-320) I
assume this is a heat shrink fit type arrangement. Do I need to heat the
ring and freeze the hub or can it be done simply with heat? There appears to
be no points to align, right? How come TDC #1 mark on the forward side of
the hub and the TDC mark on the aft side are maybe 60-70 degrees apart?
Kevin "I'll have more dumb questions tomorrow" N3773
6A (or can I simply say 'A'?)
Subject: | Re: Refused/appealed Medical |
Bob, here is what worked for me. My physical was rejected after the FAA
requested and I sent additional medical records. I called AOPA and they
told me what questions to ask of the FAA. In about four weeks they responded
that I could use my medical until next review if nothing changed. I really
appreciated AOPA. The price was right, too, free.
Ron Calhoun
Palestine, Tx
RV-4 Installing engine, instruments
Ron Calhoun
Palestine, Tx
Subject: | Re: OV protection |
>at ACS. He has already purchased his regulator, so is
>hesitant on buying the >regulator from B&C with OV protection.
>good/bad experiences >have you had with your choice.
See Sport Aviation for Dec 93, page 68. There's an article
I wrote describing the differences/benefits of "crowbar"
ov protection vis-a-vis relays. If you don't have access
to that issue, I can e-mail some stuff sans figures.
(We're working on getting all past articles up on our
website . .. soon we hope).
>>bar' over voltage cut out. I had expected a crow bar encased
>>in a box with a glass labeled 'break glass, use crow bar to
>>smash any over volts in cockpit'. But no, it looks like a
>>package of about 10 or 15 stamps glued together in a stack
Started out with old fashion crowbars but the last increase
in postage triggered a re-design :-)
>>About $35 if bought assembled, don't remember the kit price.
We've not sucessfully marketed this as a kit since it takes
a good, current limited bench supply and digital voltmeter
with .01 resolution to set the critters up. VERY few builders
had access to these tools so we only offer assembed and
calibrated at this time. HOWEVER . . . drop me an SASE
with "CROWBAR OV" marked on the back and I'll send you the
stuff that describes parts, schematic and adjustment
procedures.
>>I've had one for some time, and it is as effective as the
>>elephant protector I have in the a/c, haven't had any elephants
>>nor over voltage problems. Bob, can you jump in here
>>with the details?
OV protection is indeed one of those things that most
EVERYONE agrees they should have (along with an avionics
master switch). It is TRUE that regulator reliability
has improved by an order of magnitude over the past
20 years but failures rates are NOT zero. We've preached
the gospel according to Murphy for years . . . the best
thing to do is ASSUME that the regulator is going to fail
(See Sport Aviation June 94) and plan for an alternative
thats more paletable than overhauling a few killobucks
worth of radios, etc.
Or Russian Roulette . . .
>Denso alternator with an internal voltage regulator.
It's very difficult if not impractical to put ov
protection on an alternator with built in regulator.
Won't go into the gory details here but suffice it
to say this is why B&C does regulectomy on BRAND
NEW Nippon Dienso machines.
>On the return trip from Sun-N-Fun 1992, the voltage regulator
>died. My com radio was history. It was a TKM MX-11.
>I sent it back to the factory and they fixed it for no
>the RV-8 that I am now building.
Bless you my son, may your light bulbs live long and prosper!
That's always been a problem in this business of building
airplans, people are loath to post their mistakes in front
of God and everybody, only their successes . . . so we're often
found repeating the same mistakes over again. I've encouraged
readers (and list-rats) to come forth with the things that
work and the things that don't work . . . it's all GOOD stuff
that adds to the collective knowlege base. However, when it comes
to horror stories, there's little reluctance to pass it on:
"I heard about a guy on our airport who . . . "
We need to recognize "data" which is different from "stories".
I'm yet to discover where this works any better than on the
list servers.
(o o)
===========o00o=(_)=o00o=========
| Go ahead, make my day . . . . |
http:\\www.aeroelectric.com
Subject: | RV and Sea Hawker Compared |
John Ammeter asked me to compare my RV to my Sea Hawker. There is no
comparison!!! The only thing that they have in common as far as flying
characteristics goes is that they both fly. The Sea Hawker is small, very
noisy, and slow. The RV is quiet, comfortable, very fast, incredibly
responsive. In fairness to the Sea Hawker, both airplanes can land on the
water, but the RV can only do it once, while the Sea Hawker can land and then
take off again. I wouldn't trade all the Sea Hawkers in the world for my RV.
It is incredible!!!
Jim Cone, RV-6A flying!!!
When you finish your RV and have had it inspected, you can be sure that it is
going to fly. It may need a bit of tweaking, but it will fly. An RV
accelerates so fast that if you apply full power, you will be airborne in
just a few seconds. A fast taxi will turn into a flight much faster than you
think. Taxi around at a fast walking pace to get the feel of the plane and
then just go for it and take off. Be ready with the right rudder on takeoff
and concentrate on keeping the plane wings level right after liftoff. After
that, it is easy. If you haven't had a ride in an RV before your first
flight, on landing, a good attitude is to hold the top of the spinner on the
horizon.
On an earlier posting, I suggested using the KISS principle and just putting
the prop control to full rpm. I guess that I took too much for granted,
judging from the replies. I assumed that those with a constant speed prop
would know that you should pull the power back before going to flat pitch and
that it should be done smoothly. I stand by my original suggestion, to put
the prop to full rpm as you enter the landing pattern and then just use the
throttle for the rest of the flight. I still have my fireproof suit on.
> > the first time.
> David Price
You can say that again. I can't wait to fly an rv-4/6/8 even if
it ain't mine. Although if it were the one I built the grin would be even
larger!!!!
Shawn Falazarano
saving for rv-4
Subject: | Re: starter ring gear |
Kevin,
There are no dumb questions, at least not very often. You might be able to
remove the old ring by using a drift and hammer and beating it off. This way
it may be salvaged for later use. If its trash any way you can take a hacksaw
and put a few relief cuts between the gears ( carefull not to get the hub),
and it will easily tap off with a hammer.
Installing the new one is a piece of cake! Put your hub in the freezer (
thats right the one in your kitchen) for a half hour or so. Next take a
simple hardware store $4.99 propane torch,set the new ring in a vice and run
the flame in circles around the ring. When you spit on the ring and it sizles
your ready! Have someone bring in your hub from the kitchen and set it on
the bench, take a pair of pliers grab the ring and drop it into place on the
hub. Some slight tapping may be required but generally they just fall into
place.
The marks you see on the back of the hub are timming marks you align with
the split in your crankcase on the top side.
The marks on the front of the hub are also timming marks but the alignment
is with a small hole located on your starter housing. Once the baffling and
everything else is installed on the engine most people find it easier to use
the starter reference for timming, however the rear marks are the prefered
method.
This should get you off and running in the right dirrection.
Ryan Bendure RV4131RB(at)aol.com
Subject: | RV-4 parts for sale |
Could the guy who had the wings and tail for sale E mail me with the info? My
wife accidentally deleted the Item.
Thanks, Ryan Bendure
RV4131RB(at)aol.com
From: | ron.taborek(at)flight642.com (RON TABOREK) |
Craig,
Two items to add:
1) install the drain fitting on the fuel pump before mounting
the engine,
2) check the back of the firewall when planning things on the
front.
Ron Taborek RV-4 Installing O-320 Toronto ron.taborek(at)flight642.com
{ Presentation of the preceding message was made possible by Flight 642 }
{ BBS. Canada's Aviation and Simulation connection. (905)642-2993 }
{ WEB Page: http://www.flight642.com
> **snip**
> Bob . . .
> (o o)
OK Bob
It worked, now you have scared me,I have been flying my
RV-6 for almost eight years and over 800 hrs. with a $45.00
junk yard Chevy Sprint Nippon Dienso with no problems but
I certainly don't want to fry all the goodies in the panel
what would you suggest I do to protect my radios using the
Nippon with A built in voltage regulator? I think you have
touched on this before but I can't find the info.
Jerry Springer RV-6 N906GS First flight July 14,1989:-)
RON TABOREK wrote:
> Craig,
> Two items to add:
> the engine,
> front.
Ron
I read in the RV catalog about a fuel pump with a special fitting
for the vent line. I gather there is a fitment problem with the
footwell on the RV-4. Do I need to purchase this pump or can the
one on the motor be modified. I've got to get this a figured out
real soon.
Craig Hiers
RV-4 N143CH
Tallahassee,FL.
Jim Cone,
If memory serves me right, I think the Air Force position was in agreement
with you. As a 'stud' back in 51, the pre landing check was 'GUMP', gas,
undercarriage, mixture, and prop. Again, if memory is right, gas was to the
fullest tank, U and M I will leave to imagination, and P was prop to the
firewall, max rpm. The reasons taught us was that the engine develops max
hp at max rpm, the flat prop permitted most rapid engine acceleration to max
hp in case needed. This was taught both in T-6s and P-51s.
Now I'm not saying that because the AF taught this that it was right, but
it was a very popular thing to do at the time. And since Burt Strandburg
and Hank Lacey (my instructors) said do it, I wasn't about to question them
and put myself in a position to receive the wrath of their disapproval. Ah
yes, mine was but to do or die, not to reason why.
John Darby RV6 N61764 flying
Stephenville TX
johnd@our-town.com
On Feb 17, 7:54am, John Darby wrote:
> Subject: Re: RV-List: Test taxi, flights, etc
> Jim Cone,
>s.
> Stephenville TX
> johnd@our-town.com
>-- End of excerpt from John Darby
The only time I DO NOT push the props full forward on final are:
1) If you are going way to fast and in doing so will overspeed the engine
2) If I am flying anything with Lyc. geared engines - Props forward will eat
the gears faster than you can possible believe. This equates to BIG BUCKS..
Otherwise GUMP..
Jeffrey S. Davis
Senior Research Engineer
Advance Vehicle Technology
Ford Motor Company
Phone (313)845-5224 Fax (313)845-4781
Subject: | Re: High-Speed taxi tests |
More food for thought about conducting high-speed taxi tests:
I was reading the latest EAA Flight Advisor Newsletter while waiting for my
email to download. I noticed that the "Accident Reports" section contained
no less than three accidents that occured during high-speed taxi tests.
Best Regards,
Dave Barnhart
rv-6 sn 23744
If you don't get the ring gear indexed in the correct position onto
the hub, then the timming marks will be off.
I know of one plane that had this problem, the timing was set but it
would never start hot. After lots of work, it was found that the
timing was off because someone had installed the ring gear onto the
hub improperly.
Does the ring gear have some detent to index it to the hub?
Herman
> Kevin,
> place.
> method.
Jim-
Congratulations on the flight. Did you get to try the rudder trim system. If
so, how did it work.
I'm currently working on the system for my 6A.
Phil Rogerson
6AQ-50057
N936PR reserved
Fernandina Beach, FL
Subject: | rudder pedal reinforcements |
Kevin,
If you have the overhead mounted ones, which it sounds like you do, I haven't
heard of a problem. On the older style floor mounted pedals, gussets of 4130
steel were welded on both sides of the rudder control tube and the Wd-606A
rudder cable attach arm. This mandatory change notice was published in the
Sep '90 RVator, so later shipments had the gussets already added. There were
numerous builders who switched to the overhead style when they became
available so if you want some newer floor mounted ones with the gussets
already included, you might ask around. I think this was discussed here not
long ago and more info should be in the archives.
Les Williams
RV-6AQB #60027
Tacoma, WA
From: owner-rv-list(at)matronics.com on behalf of kevin lane
Sent: Sunday, February 16, 1997 8:46 PM
Subject: RV-List: rudder pedal reinforcements
Don Wentz suggested that I have my rudder pedals gusseted since there have
been some reports of breakage. It would not be too difficult at this point
except they are painted. I was wondering if a cherry rivets solution would
be feasible rather than having things welded. It seems to me that only the
right pedal is being used as a torque tube (when PIC sits left seat) since
the left cable is attached directly to the pedal. Is this where they have
been failing? The upper mounting horns for the brake cylinders would limit
the gusset size on the front of the pedal at least. Too bad the pedal tubes
didn't pass thru the main horizontal tube to provide canterleverage
independent of the welds. If I decide to have them welded, how important is
it to use 4130 steel? Kevin
N3773(at)worldnet.att.net
From: | Rob Hatwell <hatters(at)overvne.demon.co.uk> |
In message <v03020900af2cf246e9e8@[207.134.177.88]>, Kevin & Theresa
Horton writes
>Kevin Horton
>Transport Canada
>Ottawa, Canada
After rebuilding a Luscombe a few years ago I did some high speed taxi
test and very nearly had to rebuild it again. I tried to analyse what
went wrong, and as I recall the aircraft went a bit wild as I closed the
throttle. Could be gyro effect as I closed it rather rapidly or more to
the point my mind was still back in the hanger and not on the runway.
A fool learns by his mistakes.
A wise man learns by other peoples mistakes.
The only time I high speed taxi now is to take off or land.
Happy flying and safe taxiing.
RV8 0n order.
Rob Hatwell
Does anyone know how many wires are required to power and control the
Whelan POS/NAV/STROBE combination lighting? I'd like to run the wiring
while I have the wing open, but don't own the lights yet.
Ed Cole
emcole(at)concentric.net
In message , Bill Benedict @matronics.com> writes
Any chance of getting it before June.
Waiting on RV8 kit 1st in UK.
>Bill
>flying hours.
Rob Hatwell
Subject: | Snap Bushings in Avgas |
Does anyone know how resistant those hard nylon "snap bushings" are to
soaking indefinately in avgas (or mogas). I just noticed they are used
inside the fuel tanks where the vent lines pass through the ribs.
Are you there Gene Francis?
Phil Arter
HIRDLS Project Engineer
arter(at)ncar.ucar.edu
(303)497-8069
I am trying to recall what I did.
If you have the single power supply, there is a single cable that
comes with the strobe kit. This is a shielded cable and it has
the wires needed inside (I think it is just two wires inside for a
power and the return). Ground the shield at one end to limit EMI
(Electro Magnetic Interference).
This wire is quite thick, about 1/4 inch or so in diameter.
There will be 4 ports on the power supply. If you just use wing strobes,
you pick 2 of the ports (determined by alternate or synchrodized flash)
and just run one cable from each port to each wing tip strobe.
They give you the connectors to attach to the end after you pull the
cable thru the wing.
I think the nav light wire must be run seperate and you can just ground
it at the tip wing rib.
I have not looked at the remote power supplies but those would just
take 12v out to the power supply which would probably mount on the
tip rib and use the wing for ground return.
Herman
> Thanks,
> Ed Cole
From: | "Robert L. Nuckolls, III" <72770.552(at)CompuServe.COM> |
>Bob It worked, now you have scared me,I have been
>flying my RV-6 for almost eight years and over
>800 hrs. with a $45.00 junk yard Chevy Sprint
>Nippon Dienso with no problems but I certainly
>using the Nippon with A built in voltage regulator?
>I think you have touched on this before but I can't find
>the info. Thanks
Jerry,
Didn't mean to scare you . . . in support of your
own experience, I can point to millions of Nipon
Dienso machines that go to the junk yards still working
after the rest of the car is scrapped. They are indeed
very reliable machines . . . but what does that mean?
There are thousands of parts on single engine airplanes
that have been shook, baked, spec'd, conformity controlled,
pma'd, stc'd, tso'd, etc. ad nauseum. Does that mean the
part will NEVER break? Of course not . . . lots of these
parts break every day. What's more, because it took so
much thrashing about to get them to market, replacing the
critters with exact duplicates is expensive. Redesigning
a modern component in is unthinkable.
Nuckolls' first law of airplane systems design sez:
"Things break"
The second: "Systems shall be designed such that when things
do break, no immediate hazard is created."
The third: "Things necessary for comfortable termination
of flight require backup."
The forth: "Upgrading the quality, reliability, longevity,
or capability of a part shall be because you're
tired of replacing it, not because it damned near
got you killed."
If these tenants are observed, then it makes no difference
where you buy your parts or how much money you spend on them.
You're free to try any new part with the goal of seeing how
long it will last or how well it will perform. It DOES require
that you make sure that every failure mode is deduced and it's
consequences evaluated.
In the case of your alternator's built in regulator, I cannot
tell you that the critter will never fail . . . indeed, failure
tolerant design philosophy dictates that I assume that it will
fail. Right now, the best way we know for covering ourselves
is to add backup protection (crowbar ov module or ov relay) to
effect timely shutdown and warning of the failure in a manner that
meets rule #2. Then we make sure that rule #3 gets us home so
we can repair the bugger.
There are MANY airplanes out there flying with modern, very
reliable, alternators with built-in regulators. MOST of them
will go the lifetime of the airplane with no unhappy events.
A FEW will experience gross failure that may smoke other goodies
in the airplane but proabably won't get anyone hurt or an airplane
bent . . . but it's SO EASY to avoid. B&C removes the regulators
and brings brush leads to the outside so that ALL power necessary
to excite the field comes through a single, ov protected path.
Adequate external regulators are available for $10-$30. An ov
module is another $35 or build it yourself for about $15. Until
we find a neater way to do it, this is my best recommendation.
AeroElectric Connection
(o o)
==========oOOo=(_)=oOOo==========
| Go ahead, make my day . . . |
| Show me where I'm wrong. |
http://www.aeroelectric.com
Ed,
I would suggest buying the lighting system that you wish to install.=20
The Whelen strobe system I purchased for my Stearman came with the wire
for the strobes. It is NOT regular aircraft wire. Because of the high
voltage that powers the strobes, the wire was sheilded. In addition, it
would help to be able to put your plugs and access loops in place ahead
of time.
Of course this is just the opinion of 1 individual and not necessarily
the opinion of this station. ;-)
Take care,
Glenn Gordon
flyers@anet-chi.com
--=20
MZ=90
Subject: | Adj. Rudder Pedals |
Hi,
I just sold my Stearman and I am all ready to write a check to Vans for
an RV-6 kit. One little problem.....
I am 6'0" and my wife is 5'0". She also flys and would like to be able
to reach the rudder pedals. I have contacted Vans regarding how other
people have dealt with this problem. They couldn't offer any advice
except to find another builder who has done it.
Any help would be greatly appreciated. Our e-mail address is
flyers@anet-chi.com
Thank you,
Glenn & Judi Gordon
From: owner-rv-list(at)matronics.com on behalf of aol.com!RV4131rb(at)matronics.com
Sent: Sunday, February 16, 1997 11:37 PM
Subject: RV-List: RV-4 parts for sale
RV4131RB(at)aol.com
Are you sure
that was accidental ???
Subject: | Re: Engine Installation |
You can use likely use the existing fuel pump, but you must put the
fuel pump drain fitting in before the engine is mounted. The problem
arises because there is only one half inch clearance between the fuel
pump and the firewall step. You can make your own fitting very simply
using a 1/8 pipe thread fitting, or Van's sells a simple fitting for
$6.75 (Part Number OVERFLOW PLUG 1/8).
By the way, did you get my first message? I seem to be having some
problems with messages from the list.
The lights come with their own cable. They have connectors that you
will crimp on the ends after the wire is run. I'd either run some
sort of conduit or drill holes and put bushings in the ribs (the
SB-437s used for the fuel tank vent lines would work fine) and fish
the wire through after you get the lights.
Randall Henderson, RV-6
randall(at)edt.com
http://www.edt.com/homewing
I bought the Whelan lights with the power supply at each wing tip. I
ran conduit so I can easily add more wires later if required. I've
not yet strung the wires, but here's what I believe is required:
- 1 wire for fwd and tail lights (1.9 + 1.8 amps)
- 1 wire for power supply for strobe (2.9 amps)
- 1 wire to synchronize left and right strobes
As far as I know, that's it.
Tim Lewis
RV-6AQ #60023
timrv6a(at)earthlink.net
From: | "Patrick E. Kelley" <patk(at)mail.ic.net> |
> Thanks,
> Ed Cole
Ed, there is one cable, about 1/4" thick, which is supplied with the
lighting kit or you can buy it seperately ahead of time like I did. It
bundles the wires for the lighting and has the connectors at the strobe
head end preattached, you cut to length and add the connectors for the
control/powersupply end. I forget the part number, but Van's or your
Whelan supplier can help you with it. Have fun.
PatK - RV-6A - Working on the flap.
Subject: | RV6(A) Tail kit for sale |
Have tail kit for sale. HS, VS and rudder completed. Can deliver to Sun &
Fun, or
crate and ship.
Jim Olson
Tarpon Springs, FL
e-mail at: phfd400(at)aol.com
>Very intresting thread,I dont have set of plans and always trying to visualize
what this stuff looks like.Do the wires that go through ribs
and thing's get a little brackets with foam padding like I've seen
somewhere on another airplane?????.
David Price
Subject: | lightweight filler |
I just started using Poly Fiber's "Superlight Epoxy Filler", and it is
great stuff. I don't think I'll ever use microballoons again. It's VERY
light (You'd swear the cans are empty), sets up overnight, and sands easily.
Best Regards,
Dave Barnhart
rv-6 sn 23744
Subject: | Re: Adj. Rudder Pedals |
I'm almost 6' but have short legs; my inseam is 29". I have the bottom of
the seat back in the middle position and the top in the back position. A
friend of mine is much shorter, about 5'7" with short legs. He is able to
reach the rudder pedals as they are now. I venture to guess that your wife
would be able to reach the pedals with the seat back bottom all the way
forward and the top of the seat back also all the way forward. If that
doesn't work then a fanny bumper cushion should do the trick.
John Ammeter
3233 NE 95th St
RV-6 N16JA
Herman ,
You couldnt be more wrong! There is no index for installing the ring gear,
the index'es are on the hub.
Ryan
> hub improperly.
mine(D2J) has no index marks or ticks (Brian's E2B does). The ring gear
teeth on one side are cut into the side wall a bit, I assume to aid
engagement of the starter gear. You lost me on how the starter ring gear
affects timing, it doesn't drive anything and it's position appears to be
independent of the timing marks on the hub. I assume the starter gear can
engage anywhere in the 2 1/2 degrees between teeth. I know on the T-craft
the prop always stops at the same place, 1 o'clock. I assume Lycomings do
also. Does this mean that the starter is always engaging at the same teeth
location? kevin
I have a few thoughts on this subject Mike. I'll try to keep it
precise. What follows is a few pointers with comments that relate to
your questions.
1. Detailed planning. Plan the entire test program (write it out)
before you begin. Make a schedule. Don't be worried about staying on
it, but follow it as events allow. Try to predict things that may not
go as planned. When you identify those things, have contigencies in
place.
structured. Data cards are required equipment. Make them prior to each
flight. Include more data points than you will probably be able to
complete. If you don't finish them all, it's no big deal. Just slide
them to the next flight.
2. Ask yourself the benefit you'll get from the test and mentally plot
it versus the risk involved.
speed taxi tests. These test give you feel for the airplane and help
you determine controllability. My advice is to get the "feel" from an
RV that is already flying if possible and perform low to moderate speed
taxiing in your airplane as a check. From the comments I've read, Van
has already given you exceptional controllability. As for
takeoffs/landbacks, its your choice. It's a good step in the crawl,
walk, run process, but be cautious. Determine the runway length and
width you think you'll need, and double it (at least). Then go looking
for the facilities. Remember the contingencies I mentioned in #1 (you
could break and airplane very easily doing this).
3. The science of flight test is to determine the particular
characteristics (envelope, limitations, peculiarities, etc.) of an
aircraft. The art of flight test is to proceed from the known to the
unknown without killing yourself.
with it. It's really not that overwhelming for most pilots to pick up
and there's plenty of written material available. As to the art of
flight test, practice it on a daily basis.
These comments are strictly my own opinion. Use them as you see fit.
Become good friends with your local EAA Flight Advisor and feel free to
Email me off-list if you want a list of references or you just want to
talk more about flight tests or RVs.
Randy Nolin
Flight Test Engineer
US Army
EAA #514770
RV-3 (tools & preview plans; patiently awaiting re-release of kits)
Subject: | Re: First Flight |
Phil Rogerson asked about my rudder trim system and I'll respond here. The
rudder trim system that I designed does work. Just a bit of trim and the
plane flies straight as an arrow. I got the aileron trailing edge squeezed
down on the light wing and I just lucked out because I got it right on the
first try. It now flies straight and level, hands off, with no aileron trim.
Second flight today was slow flight and stalls. Stall speed clean was 55
knots power off and 46 knots power on with 45 degrees of nose up!!! Both
were very gentle and recovery instantaneous with a release of back pressure
on the stick. Slow flight at 60 knots was steady as a rock even in 30 degree
bank turns. On one upwind leg I had less than 30 knots ground speed. It was
quite a different sensation.
Jim Cone, RV-6A Flying!
>Bill
Rob and Shawn Falzarano, The RVator is a nearly bimonthly newsletter
published by Van's Aircraft. It works on a calendar year and the cost is
$15 ($20 outside the US). The six issues start in Feb and end in Dec. The
publish date has nothing to due with the actual date we send the copy to
print nor when you will receive it! The Feb issue just went to the printers
today and should be in the mail by the end of next week.
As far as distribution, we have been trying to hold the cost at the current
rate. During this time we have seen postage go up significantly. As a
result we are now bulk rating in the US and for international, they are
being grouped with other companies and shipped in bulk. Two issues ago they
must have traveled around the world twice by tramp steamer before being put
in the mail system. As a result, we paid a higher rate and they actually
made it within three weeks to NZ and I assume other countries as well.
Those people outside the US who subscribe can send me e-mail directly with
their RVator arrival date so I have a handle on it. We will keep trying
different distributions until we find one that works. Bill
PS: There is a document we sell which is a collection of RVator articles
over the last 16 years. It is appropriately entitled "16 Years of the
RVator and sells for $27.95. Our part number is "RVator, 16 years"
Bill N894RV with over 400 hours behind a O-320, Over
1000 RV flying hours. RV-4-180 soon.
Subject: | Re: Wiring of Strobes |
Ed, Several others have responded to your inquiry but I would like to
comment also. There are several Strobe systems in the Accessories Catalog.
Your first decision would be how do you want to legally illuminate your
aircraft. The Catalog provides a chart from the Whelen catalog showing the
requirements. This includes decisions like:
*Do I have external mounted strobes on the wingtips or do I enclose them.
*Do the strobes mount on the wingtips or does it mount on the stabalizer.
*Do I have a one pack or a two pack system. The power pack is the device
that turns the aircraft 14 volt system into 360 volts that is required for
the flash to operate.
These are just some of the questions that need to be answered. Depending on
the system selected, you can check our Catalog and identify the type of
*installation kit* that is supplied with your strobe selection and order
that installation kit which is listed on one of the following catalog pages.
Then when you order the strobe system for final installation, just delete
the installation kit which has already been purchased.
We have had articles in the RVator during the last 5 years which have been
included in the 16 year collection.
You can buy just the wiring. They have 30' and 60' kits. I recommend the
60' kit since you may not have decided on the placement of the power supply.
The 60' doesn't cost much more than the 30' and you'd really be mad if you
came up a foot short on one side. Ask the supplier if they will discount the
cost of the wire kit from the complete kit later. That's what I did and it
worked out great. You can run the wiring through the wings and buy the
latest and greatest power supply closer to completion time.
Dave D.
Subject: | Bag Content List |
I just received my fuselage kit and need to inventory/organize the hardware
bags - looks like 3-4 times the volume of the wing kit. Can anyone (Van's
maybe???) provide the "Bag Content List" in any electronic format? I can
convert almost any text, database or spreadsheet format. I'm planning to
build my own database and produce labels and cross-references for my parts
cabinets. Any help would be appreciated.
Greg Young - gyoung(at)net1.net
Citabria N90AV
RV-6 s/n 23070 - working on wings
I just left the wing ribs drilled for the bushings and installed the
bushings with a draw string left through them. Much like the instructions
for leaving wiring access in the fin for the strobe. This way you can leave
the hassle of wiring once the construction is done and the benefit of this
is you can sort out the wiring routes after wings and fuselage are assembled
> Herman
>> Thanks,
>> Ed Cole
John Darby wrote:
I stand by my original suggestion, to put the prop to full rpm as you enter the
landing pattern
The only time I DO NOT push the props full forward on final are:... Otherwise GUMP..
Jeffrey S. Davis
I certainly agree with both of your comments keeping the prop forward but so far
no one has
mentioned GUMP-C. That "charlie" stands for CARB HEAT. I know y'all do it but
my CFI taught me
to put a "C" at the end of the GUMP check.
Jeff: In the pattern my MP is way back - I don't ever remember a tendency to overspeed
the
engine. I have not flown a gear-drive but I agree with your caution about RPMing
them. Thanks for
the tip.
Elon
Having been where you're at, I can suggest that you first do some research.
FAR Part 67 is the medical section and it spells out specific items that are
disqualifying. If yours is not listed, I would first challenge the
Aeromedical Examiner who refused to issue you the student certificate to
present the appropriate regulation, and right on up the line until someone can
quote you specifics. If the reason for disqualification is listed, there is a
section providing for a "special issue medical", if you meet the requirements
for this and go through the appropriate steps.
In either case, I would not deal with the local FAA District Aeromedical
Office from my experience. I would contact the Aeromedical Certification
Division, FAA, Mike Monroney Aeronautical Center, P. O .Box 26080, Oklahoma
City, OK 73126. The last I knew, the Manager was Audie W. Davis, M.D. and the
person I dealt with was Nova Green, but that was in 1990. I no longer have
their phone number, but the AME should have it. By the way, five weeks isn't
slow for getting a reply from them, it typically takes much longer.
In my personal experience, I went for seven years with a special issue medical
based upon a local AME's mis-information from the district office. My
application was stuffed in a doctor's desk in Washington, D.C. for months
until I got on the phone and threatened congressional contact. Upon
challenging the "big boys", I now get second-class medicals without any
restrictions.
Best wishes,
Les Williams
RV-6AQBME #60027
RV-6A #20299 sold after 350 great hrs.
From: owner-rv-list(at)matronics.com on behalf of Robert Fritz
Sent: Sunday, February 16, 1997 6:32 PM
Subject: RV-List: Refused/appealed Medical
Hi all,
a
Thanks mucho,
Bob Fritz
From: | wstucklen1(at)juno.com (Frederic W Stucklen) |
Ed,
In my -6A, I have the Whalen power supply in the cockpit, requiring
the Whalen cables to be run out to both wing tips and to the tail for a
tail strobe. I am using the Whalen conbination strobe, nav (reg/green)
and white running light combination on the wing tips.
In addition to the Whalen strobe shielded cable (1/4" diam) I needed
to run one additional wire to the wing tips for the the nav lights
(red/green) and the white running light. These two lights have
individual wires that are joined together at the wing tip. Be sure to
size this wire properly for the combined amperage of the two bulbs. The
ground return is wired to the outside rib using a star washer for a solid
connection.
Fred Stucklen RV-6A N925RV
writes:
>Thanks,
>Ed Cole
Listers,
Audie Davis retired in 1996...... Contact the AOPA for more infor....
On Tue, 18 Feb 97 06:43:26 UT "les williams"
writes:
>Bob,
***** SNIP ******
>Aeromedical Office from my experience. I would contact the Aeromedical
>Certification Division, FAA, Mike Monroney Aeronautical Center, P. O
.Box 26080,
>Oklahoma City, OK 73126. The last I knew, the Manager was Audie W.
Davis, M.D.
>and the person I dealt with was Nova Green, but that was in 1990. I no
longer
>have their phone number, but the AME should have it. By the way, five
>weeks isn't slow for getting a reply from them, it typically takes much
longer.
***** SNIP *******
>Les Williams
>RV-6AQBME #60027
>To: INTERNET:rv-list(at)matronics.com
>Hi all,
>regarding
>daily use of
>issue the
>regular
>FAA.
>appeal.
>all
>"the
>for appeal
>the FAA
>friends
>Bonanza's, and
>a
>lessons! I
>Thanks mucho,
>Bob Fritz
>the FAA.
Subject: | Re: rudder pedal reinforcements |
If you want a set of the old floor mounted RV6 rudder pedals (with gussets)
I'll be more than happy to give them to you for the price of shipping.
Rick McBride
RICKRV6(at)aol.com
<< I wouldn't trade all the Sea Hawkers in the world for my RV.
It is incredible! >>
Jim,
So you still refuse to admitt that you made a mistake in building an RV. OK
then, have it your way. All kidding aside.
I'm sitting here reading this and green with envy. things shouldn't be that
green this time of year. Congratulations
Gene Francis cafgef(at)aol.com
still trying to fit the canopy
>John Ammeter
John,
I'm 6' 2" and my wife says she's 5' 3" (although I think she's shorter).
I too have tried to come up with a solution. When we placed the seat back
all the way forward and padded the seat back, my wife couldn't get any
farther forward because of the stick. In this position, her feet were about
6 inches from the rudder peddals. I don't have brakes on the right side and
would probably gain a couple of inches if I were to add them. The only
solution that I've been able to come up with so far is to glue some blocks
of wood onto the bottom of some old shoes. Or, maybe I could swipe some
foam and fiberglass from the Glastar project and make some lightweight
extensions for her shoes:)
Bob Skinner RV-6 BSkinner(at)navix.net
I don't agree, but I will check tonite.
I recall the ring gear has the timing marks on it.
The hub is 'indexed' to the crank by one of the holes being larger than
the rest. Therefore, the hub is in the correct position, but the
ring gear must also be positioned onto the hub properly.
I will look at mine tonite, but I clearly recall the timing marks being
stamped into the steel ring.
Herman
> Herman ,
> Ryan
Subject: | Cleavelandtools.com |
At long last it works, our domain name that is...
Cleaveland Aircraft Tools' web pages can now be found at
"http://www.cleavelandtool.com" and the online order form works finally.
Hope you enjoy,
Mike Lauritsen
2225 First St.
Boone, IA 50036
1-800-368-1822
clevtool(at)tdsi.net
Subject: | Re: Wing Nav Light Wiring |
I am just at the point of running the wiring in my first wing. The Whelan
combo fixture needs 12VDC for the 2 lamps and the Whelen three conductor
shielded hi voltage cable for the strobe. Whelen sell install kits with the
wiring in various lengths.
MikeT RV-6 left wing
<< I recall the ring gear has the timing marks on it. The hub is 'indexed'
to the crank by one of the holes being larger than the rest. Therefore, the
hub is in the correct position, but the ring gear must also be positioned
onto the hub properly. >>
Herman is correct. The timing marks are on the outside of the starter ring,
one at TDC and one at 25 degrees BTDC. The corresponding mark for 25 degrees
BTDC is on the starter. If you have removed the Prestolite starter you can
line-up the TDC mark to the split on the engine case thus giving you 25 BTDC.
The "hub" at the end of the crankshaft flange has one hole which is larger
than the other 5 holes therefore making it impossible to misalign the starter
ring. These things come off and on easly so I wonder...if you have to
heat-it and beat-it to get it on and off the engine, do you really have it
lined up correctly?
Gary Corde
RV-6 N211GC - NJ
> Gary Corde
> RV-6 N211GC - NJ
I'm holding the ring gear/hub in my lap as I type this. The marks are on
the _hub_...however, I'm almost absolutly sure that the marks are on the
ring gear on '85W. Maybe everybody is right.
Chris
cruble(at)cisco.com
Thanks to all who responded to my request for wiring information. I
wasn't aware that you could buy the installation kit separately. This
looks like the logical thing to do!
Ed Cole
Hey, Gang, know what time it is? It's stupid question time!
Today's stupid question is:
The plans say to dimple the R-803 where the counterbalance is mounted.
How in the world do you dimple a 3/16" hole?
I hope some of you old sages out there can help me...I'd rather not have
to velcro my lead slabs in.
Thanks!
--Don McNamara
#80113
<< The "hub" at the end of the crankshaft flange has one hole which is larger
starter
lined up correctly? >>
Gary-
I think that the original poster was talking about using heat and cold to
facilitate removing the steel ring gear from the aluminum hub and replacing
just the ring gear due to wear, not the removal of the hub from the flange.
Just clarifying, I think.
Gary VanRemortel
vanremog(at)aol.com
I've decided to attent the Textron Lycoming Piston Engine Service School in
Williamsport,PA May 19,20,21,22. I'll be leaving Albuquerque Friday or
Saturday. If anyone is interested in joining me with there own ac; company
is always welcome!
Dan Boudro
RV-4 N9167Z
Albuquerque, NM
Subject: | Re: Big Dimples! |
Don,
Avery sells #10 dimple dies for about $30. A #10 is just another name for
3/16. I have to admit that $30 for two dimples in the project is quite
steep. I don't know if the -8 will use it in another place. My RV-6A never
needed a #10 dimple.
Hope this helps.
Scott Gesele N506RV (Very close to paint)
scottg(at)villagenet.com
Ok Herman,
I should know by now to never tell anyone there wrong. Let me say, on my
airplane the index's are on the hub! I changed the ring gear to facilitate a
different starter tooth arrangement. One hole is larger on the hub to index
it to the crankshaft. By lining up the hub index with the case or starter you
have a reference for timming. The gear is the same all the way around, it
doesent care what position its in. Its only purpose is to give the starter
something to grab on to. There may be more than 1 type, this is what I have
dealt with. Sometimes I read what ive written and it sounds worse on paper
then it does comming out of my head. I didnt mean to sound so abrupt before
you have my appologies.
Ryan
I would be interested in hearing how others have mounted the Navaid
Devices Auto-pilot S-2 servo under the seat. Did you mount it to the
ribs?, belly skin?,with or without a doubler etc.
Chris Brooks
BrooksRV6(at)webtv.net
<< The plans say to dimple the R-803 where the counterbalance is mounted.
>How in the world do you dimple a 3/16" hole? >>
The #8 dies seemed to work for us- I wouldn't spend the bucks for a single
use set of dies.
Check six!
Mark
Randy (or anyone else that has completed RV),
how about a list? I would love some expert input here. No use re-inventing
the wheel.
Royce Craven
>your questions.
>place.
>Randy Nolin
>US Army
>EAA #514770
Subject: | gear leg air leak; ATC designator |
There is a lot of outside air passing thru the juncture of the gear leg
and the fuselage of my RV6A. Not unexpected,of course. What has been used to
seal this area? Eventually I'll fabricate and install a fairing
at this point which should eliminate most of the problem but in the meantime I
wonder if silicon gel wouldn't do the job (it remains flexible
and is relatively easy to remove if the leg should ever be removed).
Has ATC assigned a designator for the RV6/RV6A? I am referring to the designator
used by ATC to set an aircraft's parameters in the ATC system
ie. speed, etc.
J. E. Rehler RV6A flying N517RL
jepilot(at)juno.com
Don ,
I found that you can use a #8 screw dimple set will work ok , you will need
the #8 dimple set any way if you do not have one already. keep up the good
work....george Orndorff
Don, hi
It's easy, and you don't need to buy anything. Countersink the holes in
the lead until the screws heads are a little below flush in the
countersinks. Then bolt the parts together and tighten the nuts. The
screw heads will form their own dimples. You will find the screws
provided are a bit too long, and need a stack of washers. I bought some
shorter ones from Wicks.
Phil Arter, RV-8 #80005
philip.arter(at)mci2000.com
http://acd.ucar.edu/~arter/RV8.html
(303)459-0435 home
Don,
I simply countersunk the lead weight and then used the countersunk bolt to
dimple the skin. It doesn't provide as crisp a dimple as a standard die but
it worked just fine.
Rick McBride
RICKRV6(at)aol.com
RV6 N523JC
RV8 80027
While studying the blueprints the other night I noticed that the tip-up
canopy installation appears to provide a means for emergency canopy
release - apparently you pull a handle and the hinge pins are released
allowing the canopy to fly off.
Have any of you left this feature out of your plane? I'm considering
doing so because it appears to me that this feature isn't too useful if
you're not wearing a parachute at the time.
Or is there some other reason you would want this capability?
Bruce Stobbe
RV-6
> The only
I went just the oppostie direction. I made up some dense foam blocks that
velcro on to the pedals. Works great.
Ed Bundy RV6A #23834 N427EM - flying
Eagle, ID
ebundy2620(at)aol.com
Subject: | Re: Navaid Devices |
<< I would be interested in hearing how others have mounted the Navaid
ribs?, belly skin?,with or without a doubler etc. >>
Chris-
I installed it just like the instructions from Navaid said. I built four
doublers that span between the three outer ribs and rivet to the belly skin
and the ribs. The second starboard rib gets cut out to clear the servo box
outline and a reinforcing angle goes in to restore lost strength. Make sure
you get the crank overhand and as forward as possible without interfering
with push rod motion to put it as much in line with the control tube so the
transverse angle is low (to minimize any pitching tendency). E-mail me
direct if not clear.
Gary VanRemortel
vanremog(at)aol.com
Nope...not so. A #10 is an ANSI standard screw, the 3/16 is a
Whitworth (Brit) standard. There is about .0025 In. difference
in major diameter between the two;
Maj. Diam. #10 = .1900
Maj. Diam. 3/16 = .1875
For the real nit-pickers out there... The AN standards were
developed when the ANSI was called the "American" standard, so
technically, it's not really an ANSI thred.
Chris
> 3/16.
<< .Do the wires that go through ribs
somewhere on another airplane?????. >>
David, some of us use a length of plastic sprinkler tubing as a wire conduit.
It's smooth and you can easily pushwire through. just put it in before you
close the wing. I put my power supply under the luggage floor to isolate the
RFI noise. Probably not needed but it's cute.
Remember that strob power supplys will got bad in storage they need to be
used. Hook the strobes to a battery about once a month and let it blink for
a half an hour. Otherwise the power supply capacitor will need to be
reformed ( whatever that means)
Gene Francis, cafgef(at)aol.com
Subject: | Re: lightweight filler |
<< Poly Fiber's "Superlight Epoxy Filler >>
Sounds like good stuff, Dave. How about a source?
Subject: | Cowling Antenna Mount |
Dear John,
In your Sept 1994 Puget Sound RVator Jerry Heron discusses the
dipole antenna that he installed in the cowl for his VOR. Is Jerry a
local fellow? Would you know how I could get in touch with him? Have you
heard of any other antenna installations in the cowl area?
I would like to do that with a comm antenna for sure, possibly a
VOR, but I'm not too eager to put a VOR in the aircraft at all.
Thanks..!
Ron Vandervort, RV-6Q, rvanderv(at)linknet.kitsap.lib.wa.us
Seattle area
Chris,
I mounted the Navaid on the directly to the floor with a doubler using four
#8 screws.
It has worked fine this way for over with no problems, I also completed a
similliar installation in an RV-6A also encountering no problems.
You will love the autopilot, it is a fine piece of gear that makes x-countrys
a treat.
Regards;
Bill Mahoney
RV-6 N747W
Subject: | Re: Tip-Up Canopy |
> release - SNIP
I would retain the feature in case of an off-airport landing. There is
always a possibility that you could bend the fuselage in such a manner that
would jam the canopy latching mechanism and hinder your exit from the
airplane. That is why you are supposed to open doors on some airplanes
prior to touchdown in an emergency landing. By releasing the hinge pins in
the -6, you could almost guarantee that you will be able exit the plane
provided you are not injured too badly, or the plane is on its back with
the vertical stab deep in the ground! I also plan to carry a
canopy-knife/breakout tool of some kind just in case.
Scott Sellmeyer
RV-6 (tip-up) Horizontal Stab
>allowing the canopy to fly off.>
>Bruce Stobbe
>RV-6
Bruce,
To remove the canopy for maintenance.
Todd tmrv6(at)erols.com RV-6 Flying
Subject: | Re: gear leg air leak; ATC designator |
designator used by ATC to set an aircraft's parameters in the ATC system
ie. speed, etc. >>
ATC has not yet created a specific designator for the RV series. We are
lumped in the EXPERIMENTAL, speed 100-200 Kts category which is -- HXB. I'm
not sure what it takes to get a specific designator, GlasAir and Lancair both
have one and there a certainly more RV's out there than either of those
types.
Any ideas out there of how to accomplish this? A side issue, the FAR's
specifically require the operator of an aircraft issued an Experimental Type
Certificate to "advise each ATC unit of the Experimental nature of the
aircraft." IE: we should all be checking on with ATC as "EXPERIMENTAL RV-_
(N #).
DkSJC
-4 Builder and Air Traffic Control Specialist.
There are probably various versions so, yes we are all correct.
Most builders never have to replace the ring gear on the hub
but if you do, then be sure it is positioned properly IF it has
ANY timing marks stamped onto the steel starter ring.
Herman
> > Gary Corde
> > RV-6 N211GC - NJ
> Chris
> cruble(at)cisco.com
RVators
Are there any fliers out there with a HIO-360C1A under the cowl of their RV?
I am interested to hear of compatibility problems with the standard engine
mount, rear facing air intake etc. This engine has come out of a Enstrom
F28A and the flange end on the crank-shaft is heavy walled (1 inch centre bore).
L. Coats ZK-RVL RV6 flying :-) 169.9hr
Subject: | Barnard Aircraft Components |
Has anyone out there used the BAC fastbuild wing kit option from Vans'? I
would appreciate any comments from anyone who has tried it.
DougMel(at)aol.com
getting ready to order wingkit
From: | "Allan W. Mojzisik" <prober(at)iwaynet.net> |
Gene,
Where did you get your facts for this piece of information? I have a set of
new Whelan's that won't be used for a while yet. I've never heard of this.
Maybe Bob Nuckolls would care to comment? Al prober(at)iwaynet.net
From: aol.com!Cafgef(at)matronics.com[SMTP:aol.com!Cafgef(at)matronics.com]
Sent: Wednesday, February 19, 1997 6:04 AM
Subject: Re: RV-List: Wiring
for a half an hour. Otherwise the power supply capacitor will need to be
begin 600 WINMAIL.DAT
M>)\^(B$6`0:0" `$```````!``$``0>0!@`(````Y 0```````#H``$-@ 0`
M`@````(``@`!!) &`"0!```!````# ````,``# #````"P`/#@`````"`?\/
M`0```$D`````````@2L?I+ZC$!F=;@#=`0]4`@````!R=BUL:7-T0&UA=')O
M;FEC``,P`0```!8```!R=BUL:7-T0&UA=')O;FEC.@$````"`?8/`0````0````````#-#`0.0!@"H! ``$@````L`(P```````P`F
M```````+`"D```````,`-@``````0 `Y`(!.](FS'KP!'@!P``$````4````
M4D4Z(%)6+4QIQ%L^ .BG01
MT(TJ1$535 `````>`!X,`0````4```!33510`````!X`'PP!````$P```'!R
M;V)E)S
M=&5M`H,SMP+D!Q,"@S02S!3%?0J BPC/"=D[%YDQ,C@*(Q\9<0* "H$-L0M@
M;FP=6.::P;P; 0@(T!U;!W@YF,*P!V@=&\H4 -P!X#W`C A`"E@00,@$U G
M0 20^$!I=R;@', E`"IQ"H5!"HML:3$X, +1:? M,30T#? ,T"S#"UD\,38*
MH -@$] >\" M7R[G"H0!X &T"6Q(O,3P"G1'[#$;W"W"X!,D06P81Y 'V%E/-#_', C\2BQ(Z ;?QR 0Z=*W8,C
MTB40($AO;VM/4O],E >1*+$AD$YP`D $D#S0]P&@"& AT6X?\2&0!& ",+IH
M(8!N'> DL 5 :2.!_2P@;E.@'S%07U%O+E&_4N9@J%%L$"`&<```,`$! `````
M`P`1$ ````! ``O % ``@P("4]^+(>O $>`#T``0````4```!2
)13H@`````'1;
end
Bruce, You may want to jetison the canopy if something got on the canopy to
prevent looking out. A massive oil leak could do this as well as unexpected
ice. I had an ocassion where ice almost prevented me from seeing out of the
canopy. A friend and I ( he was in his 4, Me in my 6 ) were returning to
our home base at 3000 ft (airport is 590) and it started to rain. It wasn't
that cold outside at 3000, but when we desended to 2000, the rain turned to
ice on the canopy. Can you spell inversion? It built up very rapidly. We
were lucky to be within a half mile from the airport when this happened. We
both dove down to the runway. We were both HOT ( speed ) he landed first
and I had to do an overhead approach. That 20 seconds it took me to get back
around on a very short pattern ( not really a pattern, more like a constant
360 turn to get back to the runway ) added enough ice that I had to look
out the side to see out. I was just glad that I had 300 hours in the 6.
Temperature on the ground was above freezing. We never expected an
inversion layer, but, it almost had us in a very serious situation.
Anyway, if the ice had continued, I may have had to pop the canopy.
Believe me, I was glad that I had that option if I needed it. If this had
happened at a higher altitude or further from an airport, I may have been
building a new canopy.
Go ahead guys and gals, flame me for flying in these conditions. This
is a "I learned from flying from that".
There are probably other reasons to keep the release handle, such as,
removing the canopy to work behind the panel, water landing, and whatever
else you guys can think of.
Dave D. Sold my RV-6 2 years ago, saw it for sale in Trade a Plane. You
can buy it, and get this, for a measly $96,500. Not a typo, I said 96
thousand five hundred.
From: | "Wallace R. Penney" <wallyp(at)interlog.com> |
Subject: | Lycoming IO-360 Engines |
I am looking for some information on Lycoming IO-360 engines for a =
fellow RV builder who is now in the market for one. From the Lyc. engine =
designations we note that some versions of this engine have a crankshaft =
that is 'counterweighted' for higher order harmonics. We were told that =
this crankshaft permits operation throughout the entire speed range =
while the 'regular' crankshaft is placarded against operation in some =
speed ranges (say 1800 to 2100 rpm???). I find this hard to believe but =
this engine is typically used with a constant speed prop and a =
restriction in the lower rpm range would not impose much hardship. =
However, if the engine were mated to a fixed pitch prop, it certainly =
would be a problem. I suspect that only certain engine/propellor =
combinations have operating restrictions but are there any O-360 owners =
out there who can tell us the full story. Thanks for your help.
Wallace Penney flying RV-3 C-GPNY Toronto wallyp(at)interlog.com
Ammeter John
Subject: | Re: Cowling Antenna Mount |
Jerry and his wife, Kay, live on Queen Anne Hill in Seattle. His phone
number is 206-284-6157. I think he keeps his airplane on Vashon Island and
may have a house over there, too. I add that since I haven't talked to
Jerry for a couple of years now and he may have moved.
JA
>Dear John,
>Thanks..!
>Seattle area
John Ammeter
ammeterj(at)seanet.com
3233 NE 95th St
Seattle WA, 98115 USA
RV-6 N16JA
First flight August 1990
I used this filler for blending the canopy to the forward skins over a
fiberglass skirt. In its favor, it is REALLY sticky so it has few
adherence problems. It is also convenient to use.
BUT!!!! About one month after I used it, I saw small yellow
"greasy-looking" areas appearing all over. It is probably unmixed resin
diffusing from down deep. Believe me - I thought that I mixed the heck
out of the components before applying. It is VERY viscous material and
therefore tiring to mix, but if you are going to use it - mix it well,
then mix it again, then keep on mixing it.
Secondly, I found that it cured to a very hard surface that was more
difficult to sand to a feather edge compared with micro-balloons. Due
to its hardness, it was also difficult to spot fill small depressions
without creating a local swelling. If I had to do it again, I would use
self-mixed epoxy/balloons.
> I am involed with many a hobby and find that I always end up making a
> 3-D digital model of some of the critical Installations and just to make
> sure things fit.Its amasing to see full scale patterns and drawings
> printed to hundreth of an inch or better if you use the center of a
> line.All it takes is a basic inkjet printer and a good cad program like
> Auto-Cad and a few hours of futzing.Seems like once you start building
> alot of time is spent designing and fabricating costom mounts and fill
> in ribs or gussets extra.When I get that far I'm gonna document my parts
> and utilize my plans to render the vitual 3-D RV-4, and with some input
> could do the RV-6 also.A problem could have a solution with full size
> plan and templates if enough listers have 3-D cad capabilities,I'm shure
> there's alot.Answers could simply be a jpeg or whatever that is pulled
> from a 3-D vertual drawing,any place any angle any part in the form of
> picture or drawing in any scale sent email.But before I go on to far and
> long,I was wondering if this has been done or if there is any interest
> in it at all?? Oh boy I went on to far and had a lot of other threads
> here that are on my mind.Soom great stuff here!!!!!!!
> David Price(Got to start soon!!!)
I have read the same thing. I think it even says this in the
owners manual or warrenty info you get with your strobes.
I had mine stored for about 3 yrs and they still worked OK so I
don't think it is a major problem.
This is the classic case of 'use it or loose it'.
Herman
> Gene,
Subject: | Re: Barnard Aircraft Components |
Another benefit of the BAC Kit is Steve Barnard has very accurately pre
drilled all the aileron mounting fittings so that during assembly the
alignment of the ailerons is accurate and automatic including the
positioning of the aileron stops. Also, the end fittings on the aileron
control rods are welded not riveted. I used it and would certainly use it
again.
Bob Haan
bobh(at)cdac.com
Portland, OR
503-636-3550
RV6A drilling the fuselage skins
From: | wstucklen1(at)juno.com (Frederic w Stucklen) |
REHLER) writes:
> ***** SNIP ****
>system ie. speed, etc.
>jepilot(at)juno.com
YES! ATC will accept RV6 for a designator. If, when filing a flight
plan, flight service is not familiar with the RV6, then use HXB
(Experimental under 200Knots).
From: | Frank van der Hulst <frankv(at)pec.co.nz> |
Subject: | Trim-tab cable routing |
Hi to finished RV-6 builders,
A quick point of clarification; in the RV-6 manual, regarding building the
left elevator, Vans say something like "It is easier to route the trim-tab
cable if skins are open for access" or something similar (Damn! I don't have
the manual here with me).
Do they mean that I should not close up the left elevator skins now? I'd
like to get this completed and out of the way, if I can. It doesn't look to
be much of a problem: poke the cable through the hole in the spar, and it
should be easy to grab it through the hole in the E-615 & skin and pull it
through. (My plane will have manual trim).
So, you guys who've completed a -6... what did you do?
Frank.
> To: N5lp
> From: rv-list(at)matronics.com
> Date: 19 Feb 97 17:09:50 -0500
> Subject: RE: RV-List: Wiring
> Gene,
I just helped a friend install Whelens on a LongEZ. The Whelen book
said these exact things. Use the strobes regularly or the capacitor
may need to be reformed. Instructions are included for reforming.
Larry
RV-6 Working on tail
Pacer N8025D
writes:
> ie. speed, etc. >>
ATC will officially accept the RV6 designator with slash
equipment type.
Example: RV6/U
This was instituted last year sometime, and was written
up in either sport aviation or AOPA magazine.
>HXB. I'm
both
>types.
Lancair and GlasAir designators were officail at the
same time the RV6 was accepted. I don't remember their designations.
Type
>RV-_(N #).
>DkSJC
As I recall, this is not entirerly correct. The FAR's specifically
state
that we should identify ourselves as experimental when communicating
with a control tower at a controled field. The FAR's do not specifically
state that we need to identify ourselves as experimental to ATC.
Fred Stucklen RV-6A N925RV 200Hr+ IFR
>Chris Brooks
Chris,
I mounted my servo unit under the passenger seat per plans. I flush
riveted a .040" doubler on the bottom skin. I bent uup the edges of the
doubler making it into a "U" channel for additional strenght. I went from
the servo to the pass. control stick. One RVer had a better idea, I
believe. He used a longer rod and went from the servo to the bottom of the
pilots stick. This method gives a shallower angle that the two rod end
bearings have to operate in as compared to the shorter rod. The shorter rod
means that placement of the servo is exacting because of the wide range of
travel. On my next six, I plan on looking into installing the servo in the
wing.
Regards, Bob Skinner(at)navix.net
Please don't use silicone to seal you'r gear legs. Silicone products will
attack aluminum. I don't know this for a fact but in the loctite users guide
says it will. Daryl Green (wings almost done)
unexpected
> ice.
Fella's, my tip-up has yet to leave terra firma for the first time, but I am
not planning to include the jettison handle even though I have already built
it and all the associated structure. Reason: you cannot jettison the tip-up
in flight. The geometry of the gooseneck hinges is such that the canopy must
be opened nearly 45 degrees to clear the bulkhead flange and allow the front
of the canopy to come free. I contend this would be impossible under flight
speed airloads Then you've got the two gas lift struts to contend with.
Even assuming these break away, the likely result is a tumbling departure of
the canopy which seems guaranteed to rip either your head or the empennage
off. The plexiglass shattering tool seems the way to go. Just bust a peep
hole in front and look through the ice. Hope you brought GOGGLES or you
won't see much in that 300 mph slipstream except the backs of your eyelids!
The above is submitted as speculation, but for now I believe it firmly enough
that I won't bother with the weight and clutter of the jettison handle in my
instrument panel. For service I plan to reach under the panel manually and
pull the pins.
Bill Boyd
Pondering all the engine plumbing details
From: | Scott Johnson <rvgasj(at)popmail.mcs.net> |
Subject: | First Flight Today Of My RV6A - SUCCESS ! |
Well, after 1.5 years of hard work on my RV6A, and super help from my
teenagers, my RV6A was signed off this morning by DAR ED HASCH
(615-824-4704). He did a superb job of inspecting my RV6A, and am indebted
to him for flying all the way up from Nashville to Chicago to do my
certification, since none of the FAA MIDO or FSDO in Chicago could commit to
doing an inspection on a timely basis ( even though they were alerted of
this date 3 months ago ). Ed has built an RV6, so he was especially
knowledgable.
Even though I have over 1000 hours in all types of planes ( including T28,
B17, etc. ), I cannot adequately describe in words how exciting it was to
fly the RV6A. I had taken 10 hours dual in Vans prototype RV6 with Mike
Seager one year ago, so I new I was in store for some fantastic airplane
performane.
I had completed slow taxi tests ( about 25 mph ) two nights before and felt
confident of the ground control. After I received the airworthy
certificate, everybody was asking what time I was going to fly it. Knowing
how hard I worked to get this put together and certified, they were
surprised to hear me say, maybe later after lunch if I feel like it. The
look of disbelief on all their faces was funny. As they all left one by one,
my son and I put the inspection plates back on. My wife arrived back with
the VCR, so only family was present.
Without feeling any pressure, I got in the plane, called the tower, told
them this was my first flight, and said I might abort the takeoff and just
do a taxi test. As I got on the 4800 foot runway, I slowly pushed the
throttle forward, it felt good, I didn't feel pressured to fly, and I felt
confident so I put the throttle to the firewall.
By the time I was at the end of the runway, I was already at 145 MPH,
climbing over 1500 feet per minute. In a very short time, I was leveled off
at 2400 feet indicating 190 MPH (verified by GPS). Incredible machine ! I
did not have the wheel pants on, or landing gear fairings, so I expect it
will not have a hard time hitting 200 MPH when I put them on.
The plane required very little trim on aileron and elevator. As expected, I
had to hold some rudder in at 190 MPH.
The wood prop is incredibly smooth, the tipup canopy gives awesome views,
and the control is very tight and light. The funnest plane I have ever flown !
Today seemed like a dream, that I still find hard to believe would ever come
true. You know the feeling, thinking will it ever get done. But I can tell
you, persistence works !
For those interested, the following stats:
180 HP Lycoming from Vans
Sterba Wood Prop
King IFR equipped
Full Vacuum panel
Backup Electric Attitude Indicator
Electric trim aileron and elevator
Electric flaps
All parts primed
Thick paint job
Heated pitot tube
Heated defrost fan ventilation system
turbo fan cabin ventilation system with Naca Vents
Two High intensity wing landing lights
Whelan strobes and Position Lights
Electric Engine Primer
Rear Cabin flood lights, speaker
For all that good stuff, empty weight was fairly high at 1106 pounds.
Anyway thanks to all on this list who have answered many of my questions and
given me some great ideas and encouragement. Please forgive my memory if I
fail to mention your name, but special thanks go to the following folks who
come to mind:
John McMahon (for finding me DAR Ed Hasch)
George Orndorff
Jerry Springer
Bob Skinner
Gil Alexander
Randall Henderson
Chet Razer (thanks Chet for putting up with my canopy phone calls !)
Scott Gesele
Dan Boudro
Bill Benedict
Dave Barnhart
Frederick Stucklen
Ed Bundy
Vans builder support group: John Morgan, Tom Greene, Ken Scott
... and many more
Anyways, as soon as I get my 40 hours signed off, I hope I can meet some of
you in person this summer as I plan to take off four weeks and RV6A tour the
US with my wife.
Well, I hope this encourages you builders out there. Now for my next project
... (RV8 ?) ( wife says bathrooms, roof, kitchen ) ....
Scott Johnson / Ecstatic in Chicago
rvgasj(at)mcs.com
Subject: | Re: Engine options |
>RVators
bore).
Mz L, I will try to get the activity going on this one. I have heard that
helicopter engines need to have the cam replaced if the engine is going to
be used in a fixed wing. Heli's ususally turn at a higher RPM and the cam
is different to correct the valve timing for the higher RPM's. The rear
facing sump will run directly into the cross member on the engine mount. On
many of the sumps, there are pads on both ends of the sump and you might be
able to move the servo to the front side and put a plate over the opening on
the rear side. Several people have used the rear facing servo's if you use
an elbow immediately and turn upward. One fellow in a -4 did this and then
used SCAT tube to bring air down to the elbow. The -360 can suck so much
air that it collapsed the SCAT tube and the aircraft went down, claiming
the pilot, so be careful. Bill
These opinions are mine and do not necessarily represent the opinions or
position of my employer.
to seal this area? Eventually I'll fabricate and install a fairing
meantime I wonder if silicon gel wouldn't do the job (it remains flexible
>ie. speed, etc.
>jepilot(at)juno.com
The manual calls out using RTV to seal this junction. Just use care because
paint will not stick to any metal the RTV has come into contact with. I've
heard from one ATC type that RV's have an ATC symbol. However, another ATC
type indicated that there is not an RV specific symbol. Bill
Subject: | Re: First Flight Today Of My RV6A - SUCCESS ! |
>(615-824-4704).....
Congratulations Scott. The more you fly it, the more you will like it.
Keep your airspeed up and the dirty side down, unless you want to have even
more fun. Bill
From: | Greg Puckett <71155.2336(at)CompuServe.COM> |
Scott, you better believe it does!!!
Congrats on a job obviously well done. Every now and then a project this big is
bound to get a bit frustrating at times and stories about successfull
completions like yours is no less a contributing factor to the successfull
completion of our own projects as the answers to technical questions.
Thanks for the boost,
Greg Puckett 80081 (Some great looking spars spread about the living room
floor)
Subject: | Re: Trim-tab cable routing |
> Thanks,
> Frank.
Grab it and pull it through, that works fine.
Chet Razer
crazer(at)egyptian.net
From: | Ronald Vandervort <rvanderv(at)linknet.kitsap.lib.wa.us> |
Dear Dave,
Just a thought. The aircraft may be more difficult to fly without
a canopy than obscured with ice. A most undesirable aerodynamic
shape over the fuselage............?
I used both the basic and deluxe Barnard Kits and am well satisfied with
having spent the money. The excellent Barnard work the Phlogistone Spar plus
George O's tapes make the building of the wing almost a pleasure for a first
time builder like me. You still have to proseal the tanks! The people at
Van's tend to think the Deluxe kit is not as useful due to the prepunched
skins now available, but I decided to go for it anyway. When you consider
the total cost of an RV project and the importance of having a well built
set of wings I don't think an extra $4k is too expensive. Another advantage
is the time saved, as if building your RV is not your main occupation you
may have job, wife house etc.
The bottom line is if I was to do it again I would go the same route.
Barry Ward ward(at)axime.com finishing off flaps RV6A
The opinions expressed above do not necessarily reflect those of my wife.
From: | "Joe Edmondson" <Tazman(at)lakemartin.net> |
tazman(at)lakemartin.net
Joe Edmondson
554 Powell Dr.
Jacksons Gap, Al.
36861
Any heavy Bondo-like product (including Proseal) should be mixed on a flat
surface by spreding the material into a thin layer, followed by scraping
it up into a mound again. Keep doing this until you have a uniform color.
Stiring it like waffle batter doesn't work.
It's also inportant to remember when sanding, that you are making a shape,
_not_ sanding out low spots. If you have low spots, rough-up the area with
course sand-paper and fill with another layer of filler. Pin holes should
be filled with laquer-puddy. Laquer-puddy shrinks, so let it sit for a
day or two before sanding. After all this is done, shoot a coat of
fast-build primer and let that sit for at least a week, more if you have
time,as it also shrinks. More pin-holes might show up at this point. Fill
them with laquer-puddy, and sand after sitting for another day.
Finally, when you sand the final surface, sand with a block only (no hand
held paper) and don't get in a hurry. Attempting to sand to fast will cause
ripples in the surface. If you can feel the ripple with your hand, you will
see it when the final coat of paint is applied.
If the part will sit for an extended time with no paint, apply a coat of
sealer. Primer will not seal the surface, and will allow it to soak up
finger prints, air-born oil from your air tools, etc, etc, etc.
Chris
cruble(at)cisco.com
> ie. speed, etc. >>
>types.
>(N #).
>DkSJC
Well I'm not too sure about that....I used to file as an HXB/U but about a
year or so ago I asked this same question to somebody at my friendly flight
service station and was told that the system now accepts an RV-4. I fly a
fair amount of IFR and haven't had a problem filing through Duats or flight
service. The nice thing is the controllers know what they are talking to
now and they don't have to ask. You still need to follow proper radio
procedures ie, Experimental_____. etc.etc. Would be nice if they would
change that too.
Regards:
Rusty Gossard
N47RG RV-4 Flying
Regarding the canopy release. In the event of a crash you may have the
opportunity to release the canopy before your plane hits the ground.
The canopy will offer you a lot of crash protection if its on the plane,
but if your plane ends up upside down you will have to lift the plane off
the canopy to escape the plane. In the early 80s a T-18 stalled and
crashed on Wittman Field's R-27. The plane slammed into the ground,
loosing it's landing gear and flipped over ending up inverted on the
runway. The pilot and his son, for some reason, were not able to remove
the plane from the canopy. There was a fire.
Sometimes we play the" what if " game. I guess that's a very
important "game" when it comes down to life or death decisions.
Larry lm4(at)juno.com
Bill,
I agree with you on the gooseneck hinges catching on the sub-panel. The
benefits of the release mechanism were covered a few months ago. At first,
I was planning on omitting the mechanism and just reaching under the panel
and removing the nuts and bolts that act as the hinge. It was recommended
on this list, and I have to agree, that this operation will be nearly
impossible or at the very least very difficult. The nuts will be in the
corner of the curved portion of the top forward skin. The bolts will be
around the radio stack. You might find them easy to pull out now if the
forward skin isn't rivetted yet, but just imaging lying on your back and
reaching up in that corner around the radios and trying to pop those bolts
back in while two other people hold and position the canopy. This isn't a
pretty sight.
My solution is as follows: The mechanism is installed behind the sub-panel.
No release handle extends back through the instrument panel to save space.
To release to pins, you reach under the panel, remove an AN-3 bolt that
safeties the assembly and rotate Van's mechanism that came with the kit. I
have tried installing and removing the canopy and it works very well. The
only downside is that it can't be jettisoned in flight. As was mentioned, I
doubt that the gooseneck hinges will allow the canopy to jettison anyway.
The modified release mechanism is for maintenance purposes only. The weight
penalty is minimal.
Hope this helps.
Scott Gesele (N506RV- It will fly this Spring)
From: | "Richard E Steffens" <resteffe(at)dpcmail.dukepower.com> |
>their RV? I am interested to hear of compatibility problems with the
>standard engine mount, rear facing air intake etc. This engine has
>come out of a Enstrom F28A and the flange end on the crank-shaft is
I am using a HIO-360-B1A in my RV-6. I got it as a core and rebuilt
it. Had to get a new crank shaft so I got one that has provision for a
constant speed (I'm using a fixed pitch wood prop) and with a thicker
prop flange without lightening holes. I also put in a new camshaft.
The sump with the rear facing injection servo would not work because
and elbow that turns down will hit the motor mount cross tube. The
fuel pump also partially blocks an upturning elbow. I got a sump with
a down facing intake. It was from a 0-320-E2D which uses the same
casting and has the intake hole in the bottom front of the sump. The
intake hole needs to be milled out on a bevel to fit the injector
servo. Also different intake tubes are necessary. I got those parts
from Ilene at N-Parts (800-444-3305).
An elbow coming out of the bottom of the sump will make the servo
front facing. A tube from the servo goes out the front of the cowl.
This tube has a branch and a valve. Valve open gives ram air direct to
the servo. Valve closed is air from inside the cowl thru a cone filter
to the servo. Got the elbow, tube with valve and filter from Don at
AirFlow Specialities (864-576-4512) who also overhauled my servo.
I have heard that you can have the servo come straight down from the
sump, attach it to a tee-tube that fits into the standard scoop with
the front open and the rear to a filter for alternate air.
My -B1A has a conical mount and there was no problem mounting the
engine. I am using an Airwolf remote oil filter and dual electronic
ignition from Jeff Rose (423-622-8825). I haven't run the engine yet,
but I'm close.
Hope this helps....the sumps with down or front facing intakes are
getting hard to find. You could also have yours reworked to make it
the way you want, but I was quoted a price of $450. You may be able to
fine another sump for less than that or perhaps can trade a Cozy or
Velocity guy for one.
Dick Steffens RV-6 North Carolina
Subject: | Shock mounted gyros |
To provide a measure of protection for my gyroscopes, I am going to
mount them on a separate panel isolated from the main panel by a
number of rubber isolators. These are available from ACSS and look
like small rubber cylinders with smaller threaded rods projecting out
of the ends (Lord). To keep things neat I will group six 3.125
instruments on this panel.
What is the best way to apply loads to these? Tension/compression,
shear or some combination. I have seen Tony's articles and would like
to hear what this group has tried before deciding.
David Fried
ddebt(at)pathcom.com
If you can afford it, you won't be disappointed. It's about as
close to perfect as you can get. Every single thing about it looks
great. All your wing skeleton is ready to rivet, including the
flaps, tanks, and ailerons. Just hang it on the jig, prime as you
see fit, and bang it together.
Aloha,
Russ Werner
Maui Hawaii USA
mailto:russ(at)maui.net sends to me
mailto:RV-List(at)matronics.com sends to the RV List
<< Reason: you cannot jettison the tip-up in flight. >>
Has anyone ever tested the jettison device in flight? Someone that has one
of those cracked canopys might want to volunteer. I personally plan on
carrying an ax and forgeting to install the pull handle. I'll still make the
hindge pins pullable but not by the jettison handle.
Jim: CONGRATS!! This is one of the features of the RV series of airplanes
that makes the most sense: flys fast, flys slow. Landing at 45 mph when you
hadn't planed on landing yet is VASTLY different than landing (say, a glass
rocket) at 75-80mph. A SUPER Cub!! Thanks, Van, for such a great design.
Michael
RV-4 232 SQ
Subject: | Re: OV protection |
<< HOWEVER . . . drop me an SASE with "CROWBAR OV" marked on the back and
I'll send you thestuff that describes parts, schematic and adjustment
procedures. >>
Sorry Bob but I can't find your address. And I need all the protection I can
get, OV and otherwise.
Gene Francis
cafgef(at)aol.com
From: | Mark LaBoyteaux <tailspin(at)ix.netcom.com> |
Subject: | -6a wing attach question |
I'm building a -6a, and I just fit my wings to my fuselage this last
weekend. While squaring up the wings, it was obvious that the right wing
rear spar attach point on bulkhead f-605 was contacting the flanges of
the most inboard rib, creating a swept forward condition.(Does that make
sense?) So, I wound up trimming a 1/4" off of the f-604 fittings and a
1/4" off of the rear spar. I spent hours checking and re-checking the
measurements making sure that the wing was square and the angle of
incidence was correct. So I drilled the rear spar attach points, and
reamed them out to the correct dimensions. Cool, it's looking like an
airplane! Now the problem.
When I attached the right flap, it will only retract about half way
before the fl-606b plate contacts the side of the fuselage. The left
flap mounted fine, it's got about a 1/4" clearance between it and the
fuselage. I've spent two days checking and re-checking all of my
measurements. The wing is square with the fuselage, the fuselage
bulkheads are square. So, I removed the fl-606b & c pieces assuming that
I could fabricate new ones that would clear the fuselage. I installed
the flap, and with it fully retracted, it doesn't appear that there will
be enough clearance for this solution either. I've decided to replace
the piano hinge on the flap, which will allow me to move the whole flap
outboard providing the proper clearance.
Now, what bothers me is that I can't find the error that caused the
forward sweep of the right wing in the first place. Have other builders
had a similar problem? Or is it common to have to make adjustments like
this as the project comes together? I searched the archives, but
couldn't find any references to a similar problem.
Mark LaBoyteaux
RV-6a N106RV
From: | "Robert L. Nuckolls, III" <72770.552(at)CompuServe.COM> |
Subject: | Strobes - fact and fiction |
>>>Whelen book said these exact things. Use the strobes
>>>regularly or the capacitor may need to be reformed.
Larry, can you quote us the specific instructions that
Whelen publishes for "reforming"
Sure. This is a piece of hagar-lore that has been fertilized too much.
Strobe light systems in airplanes and cameras are brothers. They utilize
a hollow tube filled with xenon gas and fitted with electrodes at each
end of the tube. A high (300-500 volt) dc potential is placed on the
two electrodes. A third electrode is not even stuck through the glass,
it's simply a wire or band wound around the outside of the glass. The third
electrode is "spiked" with a 2,000 to 5,000 volt pulse (from a tiny coil
that acts like an ignition coil for a VERY small engine) the xenon gas is
driven into conduction and begins to emit an intense, white (acually multi-
colored) light.
The ENERGY in that flash of light is determined by the size of an electrolytic
capacitor and the voltage to which it is charged. The general equation for
energy in a capacitance storage system is C*E*E/2=J where C is capacitance
in Farads, E is volts and J is watt-seconds or Joules. Let's say we're
going to charge a 100 microFarad capacitor to 330 volts. 330 squared times
100 times 10 to the minus 6th power divided by 2 is 5.45 Joules. If the
capacitor is allowed to charge completely between flashes -AND- if the
tube is in good shape, one may expect a 5 joule flash per ignition. Further,
if one wished to get 10 joules per flash, either the size of the capacitor
has to be doubled -OR- the voltage must be raised by about 40%.
Electrolytic capacitors have been around for about 60 years. Back in the
vacuum tube days, all electronic devices required elevated voltages in
the 100 to 300 volt range and capacitors with high voltage ratings were
very common for power supply hum filtering. Nowadays, photoflash systems
are one of the very few systems that still use this venerable technology.
The capacitors are formed by winding two long, thin strips of alluminum up
in a jelly-roll like configuration with a chemical coating between the layers.
When the assembly is complete, a voltage is applied which causes chemical
changes to take place making one connection (+) and the other (-) with
respect to applied voltage. The chemistry also becomes the media in which
electrons are stored. It is true that LONG periods of inactivity should
be avoided for this chemistry to achieve and maintain peak performance.
Back in my early amateur radio days, it was not uncommon to find an old
capacitor whos value had dropped by 50% or more due to inactivity. Further,
it's leakage (losses) current went up.
The fix was to apply rated voltage to the capacitor through a large (100,000
ohm resistor) for up to a day. The resistor would limit current flow
while the power supply gently stirred the chemistry back to life. In a
period of time ranging from hours to days, the capacitor's leakage will
have gone down and it's capacitance would be up.
Modern electrolytics have a "shelf life" rated in years. When I fire
up a stobe system who's vintage and utilization are unknown, I'll run
some quick leakage checks on the capacitors just to be sure they're
not going to overheat. Then, I might cycle the strobe system up with
low bus voltage (9-10 volts) for a few hours and then raise it up to
normal over the next four or five hours. This is an EXTREME measure
that I've seldom had to apply. For the most part, if I know a strobe
system has been inactive for many years . . . I'll simply replace the
capacitors. They're probably dried somewhat and they DO have a service/
storage life limit.
For a new system to require monthly attention is absurd. If a manufacturer
recommends this, you need to write and question their capacitor source.
I suspect it's easier to predict the worst and require the most of customers
for care and feeding of their product - it may help at warranty adjustment
time but if I were building stobe systems, I'd use a good quality photo
flash capacitor and ask my customers to put their system into service
within two years.
Any new system should come out of the starting gate just fine from a
storage period of 2 years. If one measures the light output from
a strobe system that's been in storage, the light output may be down
a few percent but it will recover nicely in the first few hours of usage.
Hope this helps chase a few "gremlins" from the workshop.
AeroElectric Connection
(o o)
===========o00o=(_)=o00o=========
| Go ahead, make my day . . . . |
| Show me where I'm wrong. |
72770.552ompuserve.com
http:\\www.aeroelectric.com
From: | jddyess(at)crystal.cirrus.com (J D Dyess) |
Subject: | GYROS AND AEROBATICS |
Talked to an RV-4 driver the other day. Asked him how he prevents
damaging his gyros when doing aerobatics. His answer was that they
are damaged!
There must be a better way. Anybody installing/using "cageable"
gyros out there? How much more does this equipment cost?
J.D. Dyess (ordering -8 tail March)
Chris, mine is mounted but I have not flown yet.
I mounted the servo under the passenger seat, on a flat piece of aluminum,
between the two ribs, and use some angle to attach it to the ribs.
The position is a bit critical, as the control column has to have a full
range of movement. This range is hard to judge until you have the controls
all mounted.
If you mount it temporarily ,and finalize it later, it works out well.
John- Ready to fly in a month (or two) (or three)
> DougMel(at)aol.com
> getting ready to order wingkitDoug,
With the new prepunched wing kits, most of the time saved with Barnard's
fastbuild kit is eliminated. I had ordered it at first, but Ken at Van's
pretty much talked me out of it. I saved a lot of money and don't regret
not ordering it.
Ed Cole RV6A Wings
Subject: | Re: Strobes - fact and fiction |
I hate to bother my buddy for the sheet right when he is in the process of
readying for a first flight, but my memory tells me it involved something
similar to what you mentioned. Running the system at a reduced supply
voltage for a while. Incidently his system had been stored for a few years
and operation of one of the strobes was intermittent when we fired it up.
Hopefully it will improve with use.
Larry RV-6 Working on tail
Pacer N8025D
Subject: | Re: Lycoming IO-360 Engines |
W.P. go to http://gtravis.ucs.indiana.edu/engines...this guy has all the
explaination you'll ever need on lyc's..It's a great page.
[snip]
[snip snip]
My Whelen strobe system came with a separate sheet of paper that said
you need to run the strobes periodically, and that if they haven't
been run in more than a year they should be brought up slowly, with
low voltage levels at first. This supports Bob's point that
"regularly" doesn't necessarily mean _monthly_.....
But Technical mumbo-jumbo aside, figure it's easy enough to hook em to
a battery every 6 months or so till I get the stinkin' plane done, if
for no other reason that it's kinda neat!
Randall Henderson, RV-6
randall(at)edt.com
http://www.edt.com/homewing
Subject: | Re: GYROS AND AEROBATICS |
>are damaged!
This should stir the pot up again .
I'm having the same questions as I plan my panel. I know some pilots
claiming 10+ years on gyros doing smooth/low "g" aerobatics (the kind I like
to do). No "snap" stuff.
Not convinced, I researched "cageable" gyros. Turns out cageable does not
mean locking the gyro in place, it simply gives you the capability of
resetting the gyro *after* it has tumbled from aerobatics. No protection to
the gyro.
Electronic "gyros" using accelerometers seem the best solution, but are
prohibitively expensive at this time.
Anybody have some first hand, been there, experience? Is a removable
sub-panel the ticket?
Rob Acker / r.acker(at)ix.netcom.com / RV-6Q project:
http://ourworld.compuserve.com/homepages/rob_acker
(last update 12/23/96 - Oshkosh '96 RV pictures)
Can anyone tell me the address for donating some money for the rv-list
upkeep? I had it, but I print so much of this stuff I can never find
what I'm looking for..Thanks!
Also, Does anyone know the percentage you deduct for inefficiency when
figuring speeds with different props? I read where one guy with a -4
and 0-320 was running a 68x68 wood prop at 190 mph. The way I figure
it, at 100% efficiency, he would have to be turning 2950 RPM. Is that
correct?
> ... The FAR's specifically state
Well darned if you aren't right, Fred! At least as far as I can
find, the only thing that's in the FARs is the following:
Sec. 91.319 Aircraft having experimental certificates: Operating
limitations.
(d) Each person operating an aircraft that has an experimental certificate
shall--
(3) Notify the control tower of the experimental nature of the aircraft
when operating the aircraft into or out of airports with operating control
towers.
I wonder why that is -- seems like they'd either want controllers
(tower or whover) to know, or not. I wonder why they specifically call
out tower controllers? Any controller types out there care to comment?
randall(at)edt.com
This has been discussed many times on the list.
I think the consensus is to always leave the gyros ON.
If they are off, they will get hammered against the stops and do more
damage. The 'cageing' will only help reset them if they tumble.
It does not 'lock' them during acro.
I think one of the notes quoted Bill Kershner (?sp), the famous
instructor/writer, as having flown his 152 Aerobat for years with the
same set of gyros and it had a lot of aerobatic time on it.
Herman
> are damaged!
For all you folks keeping your eye on alternative engines, today I
got an update from Gary Greenwood, Technical Rep at Superior Air Parts
(manufacturer of the Millenium cylinders and other PMA parts). As you may
be aware, they are working on a "copy" of the Lycoming O-360-A1A which
they would sell as a kit - a box of new, certified parts that the
customer and/or his A&P assembles.
At Oshkosh 96 they displayed a raw crankshaft forging and crankcase
casting. They told me then they planned to test run the engine for
certification by the end of 96 and sell the kits by mid-97. Gary told me
today this has been pushed back and they now expect to run the
certification tests this summer and should be selling kits by Nov/Dec 97.
Most of the parts are already approved and are available. I believe the
crank and case are the only remaining hurdles.
The kit would include everything needed to assemble a "Lycoming"
O-360-A1A except the oil sump, accessory housing, and connecting rods.
They aren't making those parts, he said, because they are readily
available from other sources at reasonable prices. I didn't ask, but I
assume they also won't supply accessories like starter, carb, etc. The
price is expected to be about $9,500. Van's current price for a Lyc
O-360-A1A is $19,300.
Anyone know off-hand what the costs are for the non-included parts?
If anyone wants to contact Gary:
Phone: 800-487-4884
E-mail: sapi(at)airmail.net
Bob Reiff
RV-4 in (slow) progress
RV-List
Matronics
PO Box 347
Livermore CA, 94551-0347
Thank you!
Matt
510-606-1001 Voice | 510-606-6281 FAX | dralle(at)matronics.com Email
> >are damaged!
> the gyro.
I've read that anyone doing serious stuff uses removable sub-panels for
gyro equipment. (An old flying mag. article, I believe. Don't know
which issue.)
> all mounted.
Can you tell me the cost of this Navaid, and the necessary associated
equipment? Thanks, alot. Michael C. Lott
Hey Bob, Thanks for -not- taking it to NASA. I knew you would have a great
lesson for us all. I am still working on arrangements for a midwest seminar.
Al (N162NV) Res. Working on
Emp.
Subject: RV-List: Strobes - fact and fiction
etc.........................
M>)\^(CH"`0:0" `$```````!``$``0>0!@`(````Y 0```````#H``$-@ 0`
M`@````(``@`!!) &`"0!```!````# ````,``# %````"P`/#@`````"`?\/
M;FEC``,P`0```!8```!R=BUL:7-T0&UA=')O;FEC.@$````"`?8/`0````0````````%.#`' ``0```"@```!213H@4E8M3&ES=#H@4W1R;V)E# $````%````4TU44 `````>`!\,`0```!,```!P6YE="YN970```,`!A#1N)'<`P`'$*(!```>``@0`0```&4```!(15E"
M3T(L5$A!3DM31D]2+4Y/5"U404M)3D=)5%1/3D%304E+3D5764]55T]53$1(
M059%04=214%43$534T].1D]255-!3$Q)04U35$E,3%=/4DM)3D=/3D%24D%.
M1T5-14Y4``````(!"1 !````U0(``-$"```J!0``3%I&=6#8^27_``H!#P(5
M`J@%ZP*#`% "\@D"`&-H"L!S970R-P8`!L,"@S(#Q0(`<')"<1'B
M=P>0!4 1L"C0;@K (J O))8J7RMO+']!`R @*(!.,38R3E8I!_ +!Y BH%BA7AC4!.@KA,]LT
MQE)63"U,! `UH5-T`V!B^P>1(7!F`- %0 !P([ RT)TU$&D"("^E,9TS-AZW
MQQ?1"_(TQCT]/CCWQ
M(C#U(D!M/R!H(J!+3Q]G+(+Y$From: | "Allan W. Mojzisik" <prober(at)iwaynet.net> |
Michael,
The address is: Matt G Dralle
RV-List Netathon
P.O. Box 347
Livermore, CA. 94551
Subject: RV-List: Address? RV-List Donation.
M>)\^(A8"`0:0" `$```````!``$``0>0!@`(````Y 0```````#H``$-@ 0`
M;FEC``,P`0```!8```!R=BUL:7-T0&UA=')O;FEC.@$````"`?8/`0````0````````#-#`' ``0```!8`
M``!213H@4E8M3&ES=#H@061D`!X,`0````4```!33510`````!X`'PP!````
M$P```'!R;V)E)S=&5M`H,S=Q+,!Q,"@S01!1-3#]]F=C4"Y!5%?0J ",\)V3OQ&8DQ
M,C@*(QMA`H *@8,-L0M@;F.8@T$$@1#\DZ-9$
M`B AL&D"("XM+RXS/#,V+Z<7T0OR,*8]/48^).<'@7-A9R 0<,)O$\%D(&)Y
M(- 9(*$"0&UC0&0AL&$3P,D*P"YN$< @*!Z5+'#5*-!,/+$I'QQ#`Y$`4PK1BQ`$YP``,`$! ``````P`1$ $```!
M```#T``0````4```!213H@`````/_[
end
RVers,
The last of the fuel lube shipments went into the mail yesterday---15
containers--- put a big dent in a new can. There is now enough fuel lube in
the hands of RV builders to do the whole fleet. I still have enough left to
do 3 or 4 cans. (Gotta remember to save a can for myself.) If it works
out, maybe you guys could pass around your leftover fuel lube to other
builders when you are done.
I think I got everyone who contacted me taken care of. If you don't
receive the lube in a week or so, let me know.
Subject: | Re: -6a wing attach question |
Hmm. I had some forward sweep problem too. I had to cut about 1/8-1/4
off of the rear spars and also the attach bracket. I purposely made
these pieces just a skooch longer because of horror stories from people
who ended up too short.
However, I can't see why the attach pieces on the flap should interfere.
You mention moving the whole flap outboard, how can you do that without
interfering with the aileron? The out board bracket of the aileron is in
a fixed position due to the end wing rib so unless the end rib is too far
inboard I don't see how the aileron/flap could be too far inboard. Maybe
your aileron is too wide?
Good luck,
Ed Bundy RV6A N427EM first flight 11/20/96
ebundy(at)juno.com
J.D.,
I initially equipped my six with a standard gyro panel, i.e. vacuum horizon
and D.G. and electric turn coordinator. I perform a moderate amount of sport
aerobatics, and have found that the vacuum horizon seems the most susceptible
to damage from aerobatics. After 400 hours and 2 Gyro horizon overhauls later
I had had enough. The D.G. didn,t seem to mind the aerobatics too much,
although it is precessing more than it used to, although well within
tolerable limits. I replaced my turn coordinator with a navaid autopilot, and
I just pull the C.B. when I feel the need.
Regarding the Gyro Horizon, I installed a Sigma-Tek electric cageable unit
with an on off switch. Although quite a bit more expensive than a vacuum
unit, it serves my purpose. Shop around and you might get a good deal on a
used unit.
Another less expensive possibility is to install some sort of vacuum "on off
valve".
Good luck
Bill Mahoney
RV-6 N747W
From: | Robert Fritz <75303.1623(at)compuserve.com> |
Subject: | Skin Stiffeners / where are you? |
Hi all,
Just recently there was a thread regarding the use of materials to eliminate
oil-canning. One of the better techniques was to use a plastic strip that glued
onto the inside surface of the wing.
I'm trying to locate the source of that material and the exact name of it but I
can't seem to find it within the archives.
where are you?
Bob Fritz
From: | Robert Fritz <75303.1623(at)CompuServe.COM> |
Subject: | Re: Superior O-360 |
Hi Bob,
All the parts for a new O-360 for under $10,000!!!!!!!
No flames here, I love the idea. But that means that if the certified parts can
be sold for $9500 and the assembled engine costs $19,300, then the cost to
assemble an engine at Lycoming is about $10,000. Where did they burn that much
money?
Bob Fritz
I found that when mixing stuff like proseal, it was much better if you put
something in a drill like a bit with something flat on it ( like a handle on
a can opener - the old style)and just mix like the wife does when shes'
mixing potatoes. Then your hands don't get worn out.
Tim Sweemer
RV 4 Wings
Subject: | Re: RV4 parts For Sale |
Due to circumstances, I have had to put my RV4 parts up for sale. I have
a 1992 tail kit about 60% completed, a 1992 wing kit not started, and
updated plans and manual. I am asking $ 3,500.00 for all.
Jim Lewman
lewman(at)wt.net
281-859-7624
Houston, Texas
I believe that I've found my problem. Part of it's in the flap, and
part of it's in the wing. Apparently, the trailing edge of the inboard
rib in the flap is angled inward by 1/8" too much. I bought the
pre-fabricated spar for my wings, and during assembly, I noticed that
the pre-drilled holes for the ribs were off by about 1/8". Van's and I
both agreed that this wasn't a problem. However, I didn't take this into
account when I layed out the rib spacing for the rear spar. So, this
caused the trailing edge of the main ribs and rear spar to shift
inboard. I noticed this when I layed the main wing skins in place, but
my plumb bobs said the wing was square so I didn't worry about it.
I've managed to solve the problem by making new FL-606b & c pieces
that provide enough clearance between the fuselage and flap. Problem
solved. Thanks for the replys, they helped me look at it from different
direction.
Mark LaBoyteaux
Bob:
If you still have a thimble full left, I would like to hav it. I am
traveling this week, but will mail you a check as soon as I get home.
February 10, 1997 - February 21, 1997
RV-Archive.digest.vol-cm
