RV-Archive.digest.vol-cn
February 21, 1997 - March 03, 1997
John Top #5372
(619) 549-3356
Subject: | Re: Superior O-360 |
> All the parts for a new O-360 for under $10,000!!!!!!!
> No flames here, I love the idea. But that means that if the certified parts
can
> be sold for $9500 and the assembled engine costs $19,300, then the cost to
> assemble an engine at Lycoming is about $10,000. Where did they burn that much
> money?
> Bob Fritz
Employee wages and insurence. If you assemble it, you don't have to pay
yourself or taxes (yet). You also are not likely to drag yourself into court
if you screw up the assembly.
Chris
Sorry, I don't beleive this under $10,000 stuff.
I can cost you around 8,000 just for the parts for an overhaul and
that means starting with a core which has the crank, rods, case,
accessories, etc. The core for a O360 would be around 7,000.
In the $8,000, that is using all Superior parts already.
So 8,000 plus 7,000 for the core is 15,000 just to OH one.
I doubt the 10K would have all the accessories and everything you need.
There are lots of small expensive pieces like all the gears in the accessory
case that normally don't have a problem on an OH. You start adding up
these small pieces and you get quite a price tag.
They might come up with an engine for about 20K, but not 10K.
I mean a complete engine, not just a subset of parts.
Herman
> Hi Bob,
can
> money?
> Cheers,
> Bob Fritz
From: | Mailer-Daemon(at)KTEH.pbs.org (Mailer-Daemon) |
Subject: | Re: gear leg air leak; ATC designator |
Sorry. Your message could not be delivered to:
=BF=0Fda (1017)
Subject: | Re: GYROS AND AEROBATICS |
=BF=0Fda (1017)
Subject: | Re: -6a wing attach question |
=BF=0Fda (1017)
=BF=0Fda (1017)
=BF=0Fda (1017)
From: | Michael Angiulo <mikeang(at)MICROSOFT.com> |
I would think that a large part of the additional 10K it takes to get a
new certified engine goes into product liability trust and
certification/testing costs. The company's exposure to litigation is
much larger (and lasts longer) with a certified engine than with a crate
full of parts.
I'm totally excited about the possibility of assembling my own engine
with supervision. I think it would be fun, I'd learn a lot and save a
fortune. Anyone know if this is a reality or just a fantasy?
[SMTP:CompuServe.COM!75303.1623(at)matronics.com]
Sent: Friday, February 21, 1997 8:08 AM
To: INTERNET:rv-list(at)matronics.com
Subject: Re: RV-List: Superior O-360
<75303.1623(at)CompuServe.COM>
Hi Bob,
the certified parts can
money?
Bob Fritz
=BF=0Fda (1017)
Subject: | Re: RV4 parts For Sale |
=BF=0Fda (1017)
Subject: | Re: lightweight filler |
=BF=0Fda (1017)
=BF=0Fda (1017)
=BF=0Fda (1017)
From: | "Ray Murphy, Jr." <murphy(at)mail.coos.or.us> |
Sorry, I incorrectly stated that the rudder blocks were built using .030
riveted to angle. The correct thickness is .045. He used those winged
Dzusus fasteners so that he can remove them when he takes taller friends flying.
Nancy & Ray Murphy, Jr.
RV-6A empennage
North Bend, Oregon
541-756-7230
Subject: | Rudder Petal Blocks |
Greetings all,
Awhile back I mentioned that RV6 builder Cliff Goldman (6'2") and his
wife (5'2") both fly the RV6. I was finally able to connect with him on how
he installed the blocks on her rudder petals. He used temporary foam blocks
to allow her the opportunity to get the right feel for how big the rudder
should be. They are installed with two winged type Dzus fastners on the
upper portion of each petal. Using two pieces of al angle he riveted them
to a piece of .030 to get the extention length. He then fastened another
piece of .030 to the front angle to give her a steady foot plate. A similar
arrangement was used on the bottom to rest against to bottom of the rudder
petal. The bottom is free floating.
_________top
rudder petal| |front plate
||_______||
Sorry, but as you can see drawing in Eudora is not easy and I'm not the
artistic type.
RV-6A empennage
North Bend, Oregon
541-756-7230
RV-6A empennage
North Bend, Oregon
541-756-7230
Robert Fritz wrote:
> Hi Bob,
can
> money?
> Cheers,
> Bob Fritz
100$ went to the guy who built the motor, $9,900 went to the lawyers,
and liability insurance.
Craig Hiers
RV-4 N143CH
Tallahassee, FL.
Date: Thu, 20 Feb 1997 18:05:08 -0600
Subject: Address?
Can anyone tell me the address for donating some money for the rv-list
upkeep? I had it, but I print so much of this stuff I can never find
what I'm looking for..Thanks!
Also, Does anyone know the percentage you deduct for inefficiency when
figuring speeds with different props? I read where one guy with a -4
and 0-320 was running a 68x68 wood prop at 190 mph. The way I figure
it, at 100% efficiency, he would have to be turning 2950 RPM. Is that
correct?
From: | Frank van der Hulst <frankv(at)pec.co.nz> |
Subject: | glue-on stiffeners |
Hi all,
I just had a thought regarding the guy (can't recall his name) who's glueing
on the control-surface stiffeners...
If you're aiming to do the same thing with the ailerons (as I seem to
recall), you'd better ask Vans for undrilled aileron skins & stiffeners. The
RV-6 ones are all predrilled.
Frank.
frankv(at)pec.co.nzZ (without the anti-email-spam Z, of course)
http://www.pec.co.nz/~frankv/
Frank van der Hulst, Software Engineer, Cardax, PEC(NZ) Ltd, Marton
"Knowledge=Power=Energy=Matter=Mass; A good bookshop is just a genteel
Black Hole that knows how to read". Terry Pratchett, "Guards! Guards!"
Superior says ALL parts would be included except sump, accessory case,
and rods. Only time will tell if this is fact or hype.
On the other hand, they know their market for this kit is homebuilders,
particularly RV's, and they know we can buy a brand new Lyc. for $19,300.
Why would they waste their time developing a $20,000 kit that won't
sell?
Bob Reiff
> However, I can't see why the attach pieces on the flap should interfere.
> You mention moving the whole flap outboard, how can you do that without
> interfering with the aileron? The out board bracket of the aileron is in
> a fixed position due to the end wing rib so unless the end rib is too far
> inboard I don't see how the aileron/flap could be too far inboard. Maybe
> your aileron is too wide?
I had the same problem today -- my flap bracket (that attaches to the
flap pushrod) hit the side of the fuselage. I had to move the flap
outboard 1/8". I did this by removing the flaps's piano hinge,
installing a new piece of hinge, and then rearanging the spacer
washers on the aileron to preserve about 1/4" space between the
aileron and the flap.
The factory had warned me about this during construction, so I'd
installed the flap a little further outboard than called for in the
plans. Not enough, I guess.
Tim Lewis
RV-6AQ #60023
timrv6a(at)earthlink.net
<< All the parts for a new O-360 for under $10,000!!!!!!!
can
much money? >>
Overhead, profit and miscellaneous.
-GV
From: | Robert Fritz <75303.1623(at)CompuServe.COM> |
OhpleaseOhpleaseOhplease!!!
I Wanna believe in a $10K Lycoming......I really do.
So, trying to account for the cost of parts for an overhaul on a certified
engine vs. the parts to build a non-certified engine. Let's see, the end result
in the first case is FAA certified lawyer bait vs. the second case closer to
"hey, buddy, you built it yerself just like the airplane, buzz off!"
Possible?
How 'bout having the guys who're planing on offering this chimera come on-line
and straighten us out!!
Cheers
Bob having-trouble-with-the-physical Fritz
p.s. My wife sez I should build an RV-6 even if I never get the ticket and just
go flying with a buddy. Is she trying to keep me out of the bars?
I neglected to use my Whelan stobes for over 4 years while I sold my Sea
Hawker, which they came out of, and built my RV-6A. The first time I turned
them on, they worked like a charm!
Jim Cone, RV-6A flying
jamescone(at)aol.com
I will be in Seattle next week and would like to go to Boeing salvage. I would
appreciate information such as hours and directions.
Terry
RV-6A 294RV
Terry
Subject: | Problem with fuse center bottom skin |
Situation:-
6A. Have the fuse F677 left center bottom skin (under the seat and baggage
ribs) drilled and clecoed. I am positioning the F676 right center bottom
skin (the narrower one.) At final assembly, it is screwed into platenuts in
the wing bottom skins and root rib between the main and rear spars. In
checking the distance this skin extends out past the fuselage, it is 5/16
short. Plans 31 shows 23 5/15 from the center line of the fuse to the
outside edge of this skin. It is only 23 inches. Per the plans this skin,
F676, is 22 inches wide and it is.
Question:- Is there enough tolerance in the extension of this bottom skin
that although 5/16 short it can still be attached to the platenuts in the
bottom of the wing between the main and rear spars?
Bob Haan
bobh(at)cdac.com
Portland, OR
503-636-3550
RV6A drilling the fuselage skins
Subject: | Lycoming Oil System |
Disclaimers First:
This is a somewhat lengthy post. If you are not interested in the
details of the Lycoming oil system - read no futher. I do not _know_
exactly how the Lycoming oiling system works so please consider the
following to be conjecture as a basis for futher discussions. I have
torn down and rebuilt an IO-360 for use in my RV-4, and in the process,
spent some time looking at the engine guts as wells as several
generations of Lycoming manuals. BTW, older Lyc docs can be worthwile
additions to the later ones. My old docs are have more information
(particularly on superscedures) and better pictures. They are also a
great help in identifying parts from the 'older' engines that we
budget-minded homebuilders often use.
I am curious about several aspects of the lubrication system in the
Lycoming O-320 and O-360 series engines. For the purposes of discussion
let's assume the engine is fitted with the Lycoming Oil Filter adapter
that incorporates the Vernatherm.
The Vernatherm (sp?) appears to serve both as a thermostat and oil
cooler bypass valve. The Lycoming manuals indicate that the
spring/plunger arrangement that serves as the oil cooler bypass valve on
non-vernatherm engines is not required (or desired) with Vernatherm
equipped engines
Is this correct?
It believe that the original purpose of the oil cooler bypass valve was
to ensure oil supply in the event that the oil cooler became clogged.
After studying the accessory, a friend and I came to the conclusion that
the original bypass valve was aptly named, that is, it does not prevent
oil from going to or returning from the oil cooler, but merely provides
an alternative (probably lower resistance) path.
My conjecture is that the Vernatherm operates as follows:
It bypasses the oil cooler whenever the cooler is clogged or when the
oil temperature is too low. It appears to me that unless the oil cooler
is truly clogged, _some_ oil will flow through the cooler even when the
oil temp is too low.
This could account for installation of oil cooler airflow restrictions
in an attempt to raise oil temps on vernatherm-equipped engines.
Presumably, an oil filter is at least as likely to clog as an oil
cooler. Does
the vernatherm bypass the oil filter also, resulting in little/no oil
filtration when the oil is cold? Same story if the engine has an oil
screen instead of an oil filter?
On a related matter, I can tell by inspection that the pipe thread
connection in the lower center of the accessory case is located right at
the outlet of the oil pump. There is little doubt that this is a
pressure port and my Lycoming manual labels this as the 'to oil cooler'
port. There is a similar pipe thread fitting in the upper left of the
accessory case that my manual identifies as the 'from oil cooler port'.
My present intent is to hook my oil cooler up this way.
For Vernatherm-equipped engines, there is another port that could
possibly be used. Vernatherm engines have a simple straight-thread plug
(not pipe thread) in the place that used to contain the spring and
plunger that made up the bypass valve (as stated above, I believe this
bypass function is now integral to the vernatherm). From looking at the
drawings of this spring/plunger arrangement, I come to the conclusion
that this must be a pressure port, and thus an alternative the the 'to
oil cooler' port mentioned above. However, this requires that the
simple plug be replaced with a very special (and rumoured expensive)
straight thread/AN flare fitting. There is a local RV-6 pilot flying
with a new engine from Van's with this setup and he is quite satisfied.
I should add for completeness that a veteran IA whose opinion I respect
believes that some Cessna installations used this port to _return_ oil
from the oil cooler, but I have not been able to substantiate this, nor
can I make any sense of it.
I would like to know the flow rate of oil through the O-320 and O-360.
Anybody know or have a good way to estimate?
One last interesting note: My IA friend tells me to expect higher oil
temps because my engine is equipped with piston cooling oil squirts.
These are little nozzles mounted inside the crankase. They open at 40
PSI and squirt a jet of Oil to the underside of the piston, thus cooling
the piston and heating the oil.
Interested in any repsonses, including futher conjectures if identified
as such :)
Long before I thought I would be one of those kooks that builds in his
basement something that he has to take walls to get out. Or something that
would cost more than first class, bi-monthly airfares to just about any
where.
I went to a FAA hosted seminar at Syracuse's Hancock airport. I believe it
was fall of 1992 or 3?. Lots of neat experimental builder type questions
floating around. (gosh how I thought those nuts even looked wacky!
Building your own plane geezzzz...who they kidding??? Now wished I paid
more attention.)
The guest speakers included Senchrich Props and the Lycoming factory. Prop
stuff was neat. But..............
During the Lycoming talk, this fella had discussed on how he had taken the
stand, under oath in defense of lawsuits over Lycoming engine changes through
out the years, in what some might consider ambulance chasing. He discussed
factory reluctancy in pursuit of electronic ignition, for they'd have to, or
be placed to defend, in suit statements like ..... "So you've made this
change for greater benefits Hmmm, then noticing the lack of same in older
designs, why didn't you update all engines out in the field for this now
known "safety defect" that Lycomng has put out in Mag ignitions?". Note:
This talk was prior to the passage of 17 year product liability laws, effect
now???
He frankly stated that Lycoming has documented $4,000 per engine in product
liability costs. That comment stuck with me!
He also discussed the "infamous" 0320H2AD". (mine is already on site). Many
of those comments stuck with me, cause I thought wouldn't a "Skyhawk" just be
the greatest...Oh was I dreaming....
Almost afraid to sign this one. But here goes:
David McManmon Cicero NY McManD(at)aol.com
A kook (wife and employer probably agree) with a RV6 wing in cellar, 2nd in
with numerous other stuff, in plane storage facility, AKA; the guest room,
and a fuselage with dash panel fitting in garage. Cars out in snow.
Subject: | Re: Lycoming Oil System |
For those of you who are interested in more information on the
Lycoming's oiling problems, there is a very good discussion on one of
the web pages at the Grumman Gang site. The address for the
discussions:
http://gtravis.ucs.indiana.edu/Engines/Marvel/
We Grumman owners have had our share of problems with Lyc.
engines. It kinda makes one want to look at alternative engines. In
fact, I would if I could be sure it would hold up.
Jim Sears
RV-6A (building fuse jig)
AA5A Cheetah N26276
Subject: | Re: Problem with fuse center bottom skin |
skin
bottom of the wing between the main and rear spars?<<
I haven't gotten to this point yet but I may have an answer for you. How
about measuring from a known point (like one of the attach holes in the
spar) to your inboard rib flange, and then comparing that to a
measurement from the same hole in F604 to the edge of the skin? You
could also measure from the edge of the rear spar attach clevis to the
rib, and then compare that to a measurement from the inside of the clevis
on F605 to the edge of the skin. This would be a worst case measurement
since it sounds like most people have to trim a bit off this clevis to
eliminate forward sweep, and that will bring the rib even closer to the
fuselage.
Bruce Stobbe
RV-6
inside fuselage
Subject: | Chatter: VFR GPS direct-to clrnc |
Fred,
I think the gotcha here is that ATC doesn't care what equipment you have
on board when they give you a clearance because, if you accept it, it's
your responsibility to have the equipment necessary to be able to execute
it legally and safely.
On the other hand, who wants to refuse a direct-to clearance, especially
here along the upper East Coast?
Also, as your flight progresses from one sector to another, I don't
believe that the comments portion of your flight plan gets passed along
with you, but I could be mistaken (I remember reading somewhere that some
of the information gets left behind, but I can't remember exactly which
info it is). Even though I have to file as a /A I routinely get asked if
I am RNAV equipped. I often wonder if this is ATC's way of saying "hey,
a white lie here can shave some miles off your route, so let me tempt you
a little with a question we both know the answer to".
Like you I started putting "Loran equipped" in the comments box of all my
flight plans even though my aircraft type box states "PA34/A" to see if I
would get offered more direct-to clearances (not that I would accept
them, mind you ;>). Result: it didn't make any difference so now I leave
it off.
Bruce Stobbe
RV-6
fly-by-july (probably of '98 tho :>(
Not much of a CAD 3d designer here, but utilizer in many programs extensively
in project managment in manufacturing of products.
I for one think a 3D parametrically created solids model of the RV6 for one
is way over due and owed, this due to its success and continued support of
builders sales and refferals, certianly a more simpilier CAD design should be
comlpeted. For example as the fuel tank drawing has been updtaed and done.
I think the factory should support and underwrite this, to be
professionally done, not a hobby/read customer supplied item.
These constant discussions on the RV list re:fit and interference problems
have gone on to long. If attention were paid, needed changes would get
ironed out much easier and more accurately. In CAD ie: 3d solids, revisions
then would note the effect across all the parts and assemblies, further
issues could be found rather easily.
Van's you listening? I mean really how much would you spend to have a
budding Pro-E or ACAD Mechanical Desk top, designer take your current plans,
digitize and place them into a data base. Iron out the fit issues, modify
some problem areas and then you'd need to replace any tooling/parts that are
out of tolerance.
My perception is that CAD is being utilized in the RV8. I don't know if
something like a solids modeling is being used for design build and reviews.
I anxiously await to purchase the completed preview plans for the RV8 and to
see if my perception of if this CAD and CNC machined tools? now being
utilized? (again factory comments?) with implementation of same boosts the
quality of the kits/assembly and finally the instruction package.
I seem to see this already. Just listen to the raves RV listers of 8's have.
One first time local RV8 builder was hours from box to skin fitting on his
tail HS, flooring us "old" RV builders out here. Gosh the RV8 sounds
great!!! But what about 6's and 4's?
I didn't intend this to PO folks but as I re-read it, I'm sure it will. The
folks at Van's do a great job and do in fact offer a great plane kit. But
nobody would claim it to be perfect. Please Van's don't let a Glasstar steel
your future!
From: | catbird(at)taylortel.com (TTC Carroll A. Bird) |
I got my strobe/clearance kit in Feb. 96. After reading this
thread, I decided that I had better see if they still worked. I hooked
them to a battery (12 Volt) and a battery charger and let them flash for
about an hour,(till they were about to drive me crazy). I could not see
any thing wrong with them.
Carroll Bird
RV-4 #3919
Buffalo Gap, TX
Subject: | Re: Navaid Devices |
<< would be interested in hearing how others have mounted the Navaid
>Devices Auto-pilot S-2 servo under the seat. Did you mount it to the
>ribs?, belly skin?,with or without a doubler etc.
>Chris Brooks
> BrooksRV6(at)webtv.net
Chris :
You should contact BillAkin(at)aol.com about installing the Navaid autopilot.
Akin has one of the outstanding RV6A in Texas; an airplane with about 800
problem free hours. His Navaid is not installed on the bottom of the belly
skin but on brackets riveted or bolted to the seat ribs.
It is a great autopilot especially when hooked up to the GPS.
BClary
N75TX flying.
Subject: | Re: Boeing salvage |
Terry,
You'll love it at Boeing Surplus Sales. Take along an extra suitcase,etc.
to haul supplies in. They are open from 1100-1800 on Tues thru Fri and
0900-1600 on Sat. Their address is: 20651 85thS. phone 206-773-9684
Take Orilla Rd from I-5 near Seatac and go southeast for a few miles.
When you almost reach the ridge turn left on 85thS and it's on your left
a couple of blocks down. Have fun and allow plenty of time for shopping.
Unless your wife,etc is a very patient person, don't take her along.
Leave her at the mall near Seatac.
Mal rvbildr(at)juno.com
Subject: | Re: Strobes - fact and fiction |
<< Sure. This is a piece of hagar-lore that has been fertilized too much.
Strobe light systems in airplanes and cameras are brothers >>
Thanks Bob,
I've wondered about that for more years than I care to mention. I am not
going to bother to run my strobes once a month any more. next time as part
of defying gravity ala RV 6-A
Gene Francis
cafgef(at)aol.com
I suggested exactly that when I talked to them. I told Gary Greenwood
at Superior that I think a lot of RV builders would like to know more
about it, and that I think there will be a lot of interest in this kit IF
they keep the price down to the figure he stated. I told him about this
list, which he was unaware of, and he asked for the address, which I
provided. So...they may be listening as we speak.
I also gave you folks his phone number and E-mail address, hoping that he
would receive some "encouragement" from RV builders.
Bob Reiff
Blake,
WOW, when you want to know something you go all out. If an oil filter
adapter is being installed (and I know better than to say this is fact this
time) the bypass spring and ball are removed and cap is reinstalled. If you
look inside of the oil filter adapter housing you will see a check ball and
spring arangement built inside. This should be the bypass in the event of a
clogged filter. I belive most of what your saying about the vernatherm is
true as far as leakage and temperature.
Ryan
> Sorry, I don't believe this under $10,000 stuff.
> It can cost you around 8,000 just for the parts for an overhaul and
> accessories, etc.
I agree with you Herman. I think we, as builders are very susceptible to
overly optimistic claims from manufacturers *especially* when it comes to
aircraft engines. Engines are outrageously expensive when compared with
the cost of the airframe. One thing we have to remember is that we are
doing the VAST majority of the labor on the airframe. The engine, even
if we build it up ourselves, has a lot of labor into it in the form of
pre-fabbed parts. (pistons, rings, castings, certification, insurance,
etc...) I'm not defending these costs, but by comparison, the airframe is
raw materials.
Look at how many people have touted their particular auto conversion as
being the death of the "big two" for experimentals. I've seen wild
claims for these things for 20 years now, with very little progress so
far. (Please hold the flames; this is MY opinion, and I haven't seen
anything *I* would feel comfortable with in my bird) I know, the Chevy
V6 is looking good, but I'll reserve my judgement until there are some
real longevity numbers. I for one hope that auto conversions DO start
replacing LyCon's in large numbers, but I'll believe it when I see it.
I certainly think that an aircraft engine CAN be made for less money than
is currently available, but I don't think it will ever be completely
palatable.
I would love to see a $10k engine but I think the Superior engine price
(all up and ready to go) will probably end up within spitting distance
of a new engine from Van's.
Ed Bundy RV6A N427EM first flight 11/20/96
ebundy(at)juno.com
Blake-
Based on my investigation of the same subject on the Lyc O-320 and O-360,
your post is correct on all counts. I too have called and talked with many
"experts" concerning this issue (Lycoming, Sacramento Sky Ranch, Van's, RV
builders and various EAA Technical Counselors).
I also have an acquaintance who uses the small bypass plunger port and the -6
hoses to go to the oil cooler and claims to have no problems on an O-360 c/s.
He bought the engine as a rebuilt and the small fitting was already
installed even though it also had a Spin-on oil filter with vernatherm.
This small port is actually the opposite end of the same oil gallery as the
high flow port but I believe that the preferred way (best flow) is to use the
3/8" NPT high ports coming straight out of the rear of the engines and -8
hoses.
Use steel or Stainless Steel AN816-8 fittings. If you have the Spin-on oil
filter, you will need to use a 45 degree end fitting on the hose which
attaches to the lower "oil out to cooler" port fitting. I used AN823-8D
fittings in the ports on the Van's Niagara oil cooler which is mounted on the
rear baffle behind #4. Hoses are -8 Aeroquip AQP with firesleeve and they
route nicely thru the area.
However, there may be some forgiveness here because everyone I know runs
cooler in the RV, being that they cruise much faster than the Cessnas and
Pipers. I believe that our RVs are most like Mooneys and would use their
engine plumbing and installation as a more of a guideline than I would a
Cessna or Piper.
Your description of the Vernatherm is accurate and most people who want to
get their oil temperatures up further in cold weather will use an oil cooler
blockoff rear door controllable by a locking cable.
E-mail me direct if you still need additional info.
Gary VanRemortel
vanremog(at)aol.com
From: | Jerry Springer <jsflyrv(at)ix.netcom.com> |
Subject: | Re: 3d CAD drawings |
Why do you think it is owed? You get more than your moneies worth now,
if you want Van's to do all of this fancy stuff for you it would
defeat his purpose and that is to provide a good airplane kit at a
very resonable price...
Actually it depends on how you describe perfect, it is a perfect
airplane for me. I have never looked up and seen 5 or 6 Lancairs
or Glasairs or any other homebuilt for that matter flying over in
a group as I did the RV's today, Van's must be doing something right.
> Please Van's don't let a Glasstar steel your future!
Ha ha, have you compared prices of a GlaStar and a RV?
I've talked to a lot of potential builders that won't build a GlaStar
because of the big ugly elevator that had to be put on due to a design
screwup.
Why didn't you sign your name??
Jerry Springer RV-6 N906GS First flight July 14, 1989 :-) Hillsboro, OR
Michael, I think it was $900, I am not sure as I try to forget prices ASAP,
otherwise I would find building is not cost effective - it might save money
to just go and buy a Lear Jet.
Offsetting the cost of the unit, is the fact that you do not need to buy a
Turn and Bank, as they are included.
A really cost effective unit is a Avmix - which allows a precise scientific
adjustment for mixture, and should pay for itself in fuel savings. It is in
the Aircraft Spruce Catalog.
John (Only a finite number of jobs to do before painting)
From: | Mark LaBoyteaux <tailspin(at)ix.netcom.com> |
Bob Haan wrote:
> Situation:-
> Bob Haan
> bobh(at)cdac.com
> Portland, OR
> 503-636-3550
Since I just drilled the bottom skins to my wings this week, I went
out and measured mine. My right bottom skin overhangs the fuselage side
by 2 1/4". The centerline of the screw holes that I drilled to mate the
skin to the wing are 11/16" from the edge at the aft end and 5/8" from
the edge at the front.
Now, one thing I missed while building the wings, was to leave out
every other rivet on the inboard rib bottom for the platenuts. So before
I mated the wings to the fuse, I had to drill out these rivets. After I
had the wing aligned, and the rear spar bolted in place, I had to take a
12" long 1/16" drill and back drill these holes from the top, and then
finish drill them from the bottom. I'll be able to install the plate
nuts after I remove the wings for transport to the airport. I know I'm
not the only builder to fall for this one, another builder called me
last week with the same problem. Hope this helps.
Mark LaBoyteaux
RV-6A N106RV
> where.
> more attention.)
> now???
What did he say about the H2AD? Mine is on it's way here now. I always
like to here good news, which this has got to be. HA!
Does anyone know the formula for figuring what prop and pitch to use on
a new plane?
From: | "P. D. Danclovic" <pauldan(at)mindspring.com> |
I already have an Avery hand squeezer with the standard 1 1/2" yoke
and a pneumatic squeezer with the same yoke and would like to know
if I was only going to buy 1 more yoke, which would be more useful?
2 1/2" standard
2 1/2" no-hole nose
longeron yoke
thanks in advance.
P. D. Danclovic
RV-8.....just really getting started
I had this same problem on my 6 and had to trim
and splice in a 2" strip.
>raw materials.
>palatable.
>ebundy(at)juno.com
Ed, When I read this I was expecting to see Van's name at the end (just
kidding, he doesn't e-mail). Everything is true by my observations.
Conversions have been around for a while, even many on RV's. But once they
start flying, we do not hear a lot from them. Yes they fly, but the
performance from their horses do not match up with the performance from the
Lyc horses. Maybe Chev and Buick use ponies. I personally think the time
is near for an effective auto conversion and unless these guys put them in
aircraft and debug them we will never find out.
The Superior engine for under 10K is missing a lot of expensive parts. Once
these (I believe the carb, mags, starter, alt, etc) parts are added
along with the other items identified, the price will be within spitting
distance, as you stated. I know that if I go to the auto parts store and
buy parts to assemble an engine for my automobile, it will cost a lot more
than going to an engine assembly shop and buying the complete assembly, so
why is this box of parts going to cost less than an assembled engine?
If you want to build an airplane to fly, install an aircraft engine. If
you want to build an airplane as a project, put an auto conversion on, and
you will have something to tinker with.
My hat is off to those people with conversions, but I hope everyone will
read Ed's message again. Bill
Bill N894RV with over 400 hours behind a O-320, Over
1000 RV flying hours. RV-4-180 soon.
These opinions are mine and do not necessarily represent the opinions or
position of my employer.
From: | "Mike Fulkerson" <mfulker(at)caverns.com> |
Help/Advice: I have just had an O-360 A4A engine overhauled that required
the crank to be reground. After assembly by a reputable engine shop
(local) the plug on the front of the hollow shaft crank "blew out"- after
approximately 1 hour of ground run time - during take-off. This
"blow-out" was repeated approximately five tach hours later. Reviewing
Tony Bingelis on Engines indicated that a hole needs to be punched in the
back seal approximately six inches back of the front seal. Two mechanics
that worked on it said not necessary. Question?? What is necessary?
Mike Fulkerson --- mfulker(at)caverns.com
Carlsbad,NM PA28-180
RV-6A- gleam
>screwup.
Jerry:
Be nice.
Check out http://www.insync.net/~sidl/floats.html
John Top #5372
(619) 549-3356
From: | "Eric O. Caldwell" <cirenewo(at)nexus.flash.net> |
Subject: | HVLP Paint Systems |
First off I would like to introduce myself. My name is Eric Caldwell and
I am located in Arlington, Texas. I am employed by a major tactical
aircraft manufacturer in the Engineering Test Laboratory. In my job I
have, I'm not making this up, fired a 4 pound chicken at over 650 mph
into a canopy. The canopy survied, the chicken didn't.
I have spent the last 1-1/2 years looking into experimental airplanes
and settled on a RV-6A as the best comprimise of performance, range,
cost, and reliability for my needs.
I have received my empennage kit and have collected most of the tools I
will require to build the airplane. I still have to construct a shed to
store all the yard tools so I can have room in the garage for my new
hobby. I am taking the high end approach to building by purchasing the
best tools I can get for the best price. I have visited Bob Avery's
establishment and have spent quite a few bucks there. I have personally
met Bob and his wife and I am impressed with their commitment to the
home builder. Now if I can just get my pneumatic rivet squeezer off back
order.
Enough about me. My question deals with HVLP paint systems. I have
looked in the archives and read what I could find on these sprayers. I
am considering two systems, one from Binks and one from Croix. If
anyone has any experience with either systems and specific models I
would appreciate your input. I would also appreciate any information on
who carries these systems, besides AS&S, and who sells them at a low
price.
If you would like to contact me direct I can be reached at
cirenewo(at)flash.net
Thanks in advance for your help.
Eric O. Caldwell
RV-6A Getting Started
Arlington, Texas
Subject: | Re: Bendix/King KT 76A Retrofit |
I got some interesting info off the Kitfox (yes, my slow plane is a rag wing)
list the other day and thought I'd pass it along, because it was news to me.
I have not seen the actual article in question and cannot vouch for the
accuracy, so take it as informed rumour until confirmed.
The February 97 issue of Aviation Consumer had an article regarding a problem
with KT 76A Transponders having S/Ns from 93000 thru 109999. Apparently an
internal resistor network is subject to deterioration and may cause the
transponder to transmit incorrect altitudes and/or squawk codes. The
corrective action is to remove and replace with a pair of glass encapsulated
components. AlliedSignal will reportedly pick up the tab to the tune of 2.5
labor hours and compliance by July 1, 1997 is required. Your local
Bendix/King dealer should be aware of the situation.
FYI, I bought mine thru Van's about 18 months ago and it is affected. I will
call my local avionics shop on Monday to get the full story.
Gary VanRemortel
vanremog(at)aol.com
Subject: | Re: Engine options |
> >Are there any fliers out there with a HIO-360C1A under the cowl of
> >their RV? I am interested to hear of compatibility problems with the
> >standard engine mount, rear facing air intake etc. This engine has
> >come out of a Enstrom F28A and the flange end on the crank-shaft is
> >heavy walled (1 inch centre bore).
> >L. Coats ZK-RVL RV6 flying :-) 169.9hr
> I am using a HIO-360-B1A in my RV-6. I got it as a core and rebuilt
> it. Had to get a new crank shaft so I got one that has provision for a
> constant speed (I'm using a fixed pitch wood prop) and with a thicker
> prop flange without lightening holes. I also put in a new camshaft.......
Dear Richard,
Many thanks for the detailed reply. My apologises for the slowness in
replying. You have indicated that there is quite a bit of work involved but
there should be a way around the problems. I wonder if there are not so
many of these engines put into planes with the lack of response to the
original posting. I have passed your posting to a builder in the U.K. who
has been offered a HIO-360C1A so your post has gone half way around the
world again!
Louise Coats
Subject: | Re: HVLP Paint Systems |
> price.
Eric,
Check out http://www1.usa1.com/~stephenb/2002.html for an interesting
page on another HVLP option. I haven't tried it, but it looks
quality.
Aloha,
Russ Werner
Maui Hawaii USA
mailto:russ(at)maui.net sends to me
mailto:RV-List(at)matronics.com sends to the RV List
>before I mated the wings to the fuse, I had to drill out these rivets.
When I was ready to rivet the inboard ribs, I sent a note to Van's and
asked about which ones to leave out. Their answer was that it was
easier to add the rivets to every hole and drill them out later. That
way, you could be flexible with it. The hole was going to be bigger,
anyway. No big deal. I took their suggestion and riveted every one.
Jim Sears
RV-6A #22220 (About to start on fuse)
AA5A Cheetah N26276
<< I
price. >>
One of the best sources of mail order wood workers tools is a place in
Minnesota called 'Tools on Sale'. They carry Croix HVLP and they are cheaper
than ACS. Also, they pay the freight. The price you see is what you pay.
When I was building my house they got most of my tool $'s. I usually get my
phoned in order in 5 - 8 days. They have specials very often and they
advertise them in Fine Homebuilding and Fine Woodworking magazines. You can
find other discounters in these magazines as well. Their phone number is
800-328-0457. They will only send you a catalog if you ask for it.
While we're on the subject of tools, has anyone purchased the Grizzly $199.00
Horiz./Vert. band saw?
Brian Eckstein
6A - priming ailerons parts today
From: | rudy.albachten(at)amd.com (Rudy Albachten) |
Subject: | Fuel Tank Boo-Boo |
Well, I missed something on the plans, and now I'm
looking for advice. I had something sitting on the
fuel tank plans, and it covered up the note about
different rivets and spacing for the end ribs where
they rivet to the baffle. So... instead of 3/4" spaced
AN427AD3 rivets I have already drilled for 1" spaced
1/8" rivets.
Would you just use 8 AN470AD4 rivets?
Add 7 more AN427AD3 rivets (1/2" spacing)?
Any other suggestion?
Call Van's?
I'll be out of town till next Friday. The first thing
I'll do when I get back is look for your suggestions.
Thanks!!!!
- Rudy Albachten
(RV-6A - Building gas tanks)
From: | "les williams" <lesliebwilliams(at)msn.com> |
Rudy,
I would dimple the 1/8" holes for AN426-AD4 rivets and add the extra
AN426-AD3 rivets in between them.
Les Williams
RV-6AQB #60027
From: owner-rv-list(at)matronics.com on behalf of Rudy Albachten
Sent: Sunday, February 23, 1997 7:00 AM
Subject: RV-List: Fuel Tank Boo-Boo
1/8" rivets.
Call Van's?
Thanks!!!!
- Rudy Albachten
Mike,
If you have a constant speed prop, the inner plug should not have a hole in
it. If you have a fixed pitch, there should be a hole in it to allow oil to
get to the front bearing. If it is a fixed pitch, does your engine have a
governor pump and steel line running to the front bearing housing? What do
the two mechanics say about it? Who installed the plug(s)?
From: owner-rv-list(at)matronics.com on behalf of Mike Fulkerson
Sent: Saturday, February 22, 1997 5:53 PM
Subject: RV-List: Lycoming Oil System
RV-6A- gleam
From: | bcos(at)ix.netcom.com (William Costello ) |
Subject: | Re: Fuel Tank Boo-Boo |
>1/8" rivets.
> Thanks!!!!
> - Rudy Albachten
Hi Rudy,
I would definitely call Van's on this one. I hate to
re-design things without okay. And if you do, please let
us know what the word is.
Best regards,
Bill Costello
Bill Costello | bcos(at)ix.netcom.com | Building RV-6 | Reserv N97WC
Want an extra hour and a half of energy per day with Super Blue
Green products? Email for info or call 800-325-7544 Chicago
>2 1/2" standard
>2 1/2" no-hole nose
>longeron yoke
Very definitely the longeron yoke is the most useful.
If ordering a second yoke, the 4" standard.
Bob Haan
bobh(at)cdac.com
Portland, OR
503-636-3550
>RV-6A- gleam
Mike, The answer seems obvious. About 3-4 years ago the RVator had an
article about these two plugs. I will send you a copy of Lyc's instructions
about these plugs if you are in Van's data base (sorry, I don't remember
everyones name. We have about 4500 people actively building). In a nut
shell it goes like this:
The hallow crank has a plug internally about 5-6 inches behind the crank
flange. In a constant speed prop application, the oil pressure that
changes the pitch of the prop is injected into the crank forward of this
plug. The plug will not allow the oil to go aft in the crank, so it moves
forward into the prop where it does its thing (rotates the blade to the
desired pitch). In a fixed pitch application, this plug must be pierced
(not drilled)or totally removed because oil from the front bearing
lubrication port will also find its way into this hollow crank. With the
oil pressure these engines run, the buildup will cause the front plug to
blow out and pump all the engine oil overboard in a short time. You can
guess the rest of the story! The hollow crank has drains behind this plug,
allowing the oil that gets into the crank to drain out. Care must be taken
when working within the crank, because there is a tube running across the
inside of the crank from side to side. The plug must be fished past this
tube when replacing the plug for C/S applications. Looks like an impossible
task, but it can be done.
Vans carries two plugs for the crank. PN: EA 61510 ($11.00) is the plug
that fits down inside the crank and is needed when converting from a fixed
pitch to a constant speed application. PN: EA STD1211 PLUG ($2.00) is the
plug on the front of the crank and is used to seal the crank after the
internal plug is pierced. This is the plug that keeps getting blown out
from oil pressure. Bill
>after
>Reviewing
>the
>mechanics
Lycoming strongly recommends that the governor pad and line to the front
of the engine case be removed when using a f/p prop. If you don't need
this stuff, it can't break and dump all of your oil overboard.
The rear seal is also supposed to be punched, or even completely removed
so that (as you may have guessed) pressure won't build up and blow the
front seal. The only reasons for that plug are so that: A) Lycoming can
test a hollow crank engine with a test club and B) to keep FOD out of
the hollow crank when running a f/p prop. It is not designed to hold any
pressure for any significant length of time.
The rep. that I spoke with at Lycoming says that it's very unusual for
that seal to go more than 5 hours without blowing if the rear seal isn't
relieved. In fact, once in a while they blow one during the 1hour test
period on a new engine.
Be sure to pierce, not drill, a 3/16"-1/4" hole in the rear seal, and
don't damage the oil transfer tube on the inside of the crank. Lycoming
has an S.I. for the complete details.
ebundy(at)juno.com
>lubrication port will also find its way into this hollow crank. The
hollow crank has >drains behind this plug, allowing the oil that gets
How does the oil get from the front bearing into the crank? I thought
the reason for the hollow crank AD was because in f/p applications the
interior of the crank doesn't get any oil and starts to corode.
ebundy(at)juno.com
> >2 1/2" standard
> >2 1/2" no-hole nose
> >longeron yoke
I've found the 3" standard to be indespensible. In a couple of
spots anything shorter wouldn't have reached. (Actually, I borrowed
a 3" yoke, liked it, and bought my own).
Tim Lewis
RV-6AQ #60023
I installed a polly tubing in the wings. This is what you can buy at your
local HW store, and is white in color. You need it large enough to get
the strobe wire (about 1/4 inch) plus the nav and landing light wire inside
of it. I don't recall the size, probably 3/8 ID or so. You find a position where
you
want to run the wires and then drill the holes in the ribs with a unibit.
You then slide in one long piece of the clear poly tubing from the outboard
wing rib to about a foot or two past the root rib. When I install the wings,
you drill a hole in the fuselage and run the tubing right into the fuselage.
Now all you have to do is slide the wire inside this tubing in your wing.
I think I found some tubing that just fit inside the 7/16 snap in bushings
that Vans gives you and I used the busings in the holes and the slid the
tubing inside of that. You may have to use a length of plain ol wire
to pull the wire bundle thru the tub. With my landing wire +nav wire
plus strobe wire it was a tight fit.
My tubing was positioned behind the rear spar and I think closer to the
top of the wing to clear the bellcrank area.
Do this before you close the wing.
Herman
> >Very intresting thread,I dont have set of plans and always trying to visualize
what this stuff looks like.Do the wires that go through ribs
> and thing's get a little brackets with foam padding like I've seen
> somewhere on another airplane?????.
> David Price
>ebundy(at)juno.com
Ed, I don't have the drawing here, so from memory (and that isn't too
good) the oil is pumped through a lubricating hole in the bearing where it
comes into contact with the crank. It then migrates down the crank to the
hole in the crank where the C/S oil is injected into the center of the
crank. This is all within the length of the bearing.
In FP applications, when the plug is pulled, usually there is enough
sludge in this cavity to make you gag. It has to be removed with a scraper
just to get back to the rear plug. I think that bulletin (did it make it to
AD?) was an over reaction to one possible incident in the UK. Bill
Ed,
The oil does get to the forward part of the hollow crank, but in such small
quantity that sludge tends to collect there. The sludge is what causes the
corrosion. I inspected my 0-320 with less than 200 hrs on it and was amazed
at how much had collected in that few hours. One thing that probably
contributes to the sludge build-up is not running the engine at high enough
temperature, which is something I now pay real close attention to.
Les Williams
RV-6AQB #60027
From: owner-rv-list(at)matronics.com on behalf of Ed Bundy
Sent: Sunday, February 23, 1997 10:53 AM
Subject: Re: RV-List: Lycoming Oil System
ebundy(at)juno.com
In the hollow crank with a CS prop, the oil is constantly circulated through
this area in order to run the prop. With a fixed pich prop, the oil still
circulates through the area (which is why you PUNCH a hole in the back plug:
to give the oil somewhere to go) but at a much slower rate....which allows
muck and sludge and junk to accumulate. The byproducts of combustion are
corrosive if not burned out of the oil (which is why we should go flying in
the winter, among other reasons). Some of them inevitably remain (one of
the reasons we drain our oil at 25 or so hours) and, if caught in the
muck/sludge/junk, will begin to eat away at whatever they are resting up
against...including a crankshaft.
NOW: if this was General Motors, and a design flaw was discovered in their
engines, and they required their engines to be torn down and an new crank
installed, or inspected every 10,000 miles, what do you think the general
public would do?? I believe the word would be freak-out.
Just a thought..........
Michael
RV-4 232 SQ
mikel(at)dimensional.com
Subject: | Electric aileron trim installation |
I'm a bit confused with the instructions that come with the electric aileron
trim kit. The first instruction tells the installer to replace the inboard
root reinforcement plate with the provided spar doubler. The drawing appears
to show the trim being installed not on the inboard end, but instead on the
outboard end of the aileron. What the ???
Any advice out there?
Brian Eckstein
6a
Mike:
Refer these two so-called mechanics to Lycoming Service Instruction 1435.
I quote:
"When changing from a constant speed to a fixed pitch propeller, it is
necessary to pierce a 1/8" to 1/4" hole in (or remove) the plug behind the
oil return tube, and install an expansion plug in the front of the
crankshaft."
Frankly, if it were me, I would be very concerned about the condition of my
engine after two incidences of total loss of oil pressure - one at full
power. I suggest that you talk to this "reputable engine shop" and ask
them why they chose not to comply with SI 1435. If they are not willing to
re-overhaul your engine at no expense to you(including parts), then I would
sick my lawyer on them and make noises with the FAA.
Best Regards,
Dave Barnhart
rv-6 sn 23744
You two are taking about different engines.
The -C1A is an angle valve engine, 200 HP (or maybe 205 if the helecoptor
version). All the -Bxx engines are 180 HP and are the parallel valve
engines. Any of the rear mounted engines can be converted to front
or bottom injector. Some by simply machining the front pad and putting
a plate on the rear pad or by changing the sump.
Herman
dierks(at)austin.ibm.com
> Dear Richard,
> world again!
> Louise Coats
Subject: | Re: 3d CAD drawings & Gyro pull out |
Wow, interesting conversations here!.
John,
I like the float plane!!! Neat paint job. We got a Glasstar being build in
SYR, he almost bought an RV, it was only a choice between one or the other.
Between the two the're both tough to beat, (like an RV each have their good
and bad points). It is going up real fast though.
I'll add my $.02 re: CAD stuff for RV's But not fuel for flames, rather:
Didn't do 3d, but did ACADr12 (r = revsion 12) a RV6 dash panel, with 4
flush, removable plates, holding sections of gages. This for service and
future upgrades. And I'm just about done with the metal working portion of
mine now. I'll probalbly update the drawing to my actual dimensions prior to
permanent mounting of mine into plane.
I also believe a blank plate could be used when gages are pulled to do that
upside down stuff if one wants. Cause if I remember previous on list,
spinning gages are what you want, not shut off vacum and go loop de loop.
Plus caging is just to "Right" a gyro upon completion of aerobatics right?.
So would be Sean Tuckers, intersted a ACADr12 .dwg file, your's for the
asking, I'll attach a file to a e'mail to whom ever.
As well as I have some inherited ACADr10 .dwg dash panel stuff that go into
a great deal of detail, but 2d only. Right down to the lettering in the
"Experimental ... passenger warning placard". Again ask and you shall
receive.
Advise what drawings (you must have ACAD at thet rev level or greater to read
files.) specifically you want.
Also have some hand drawn faxes which can be viewed in MS windows 95 fax
viewer or the like, which I can attach per your request. These are of what a
bunch of have made up in one form or similar, as the 5th crotch strap mount
point to be used. Again ask.
Email me at McManD(at)aol.com
David McManmon RV6 Cicero NY, over 90% done, only 90% to go.
Subject: | Re: on the sludge buildup in the crank |
I think it is due to two factors. One is that the crank acts like
a mini centrifuge. The oil that gets in there is spun around and the
heavy particles sling to the outside (which is against the wall of
the inside of the crank). These particles are very compacted, which
you will see if you clean one out. The sludge is dark grey and I
think it contains a lot of lead (which gets into the oil from the
fuel) and it is forced out of the oil at this point, along with
carbon and other contaminates.
I once had a Honda 305 cc motorcycle (Early 70's) and this engine
had a small oil filter which was just a can that was spun around
by a small chain drive and the oil went into this can and the
centrifical force slung all the heavy particals to the outside
of the can. The 'can' was made of aluminum and had a O ring and
lid that sealed it. This was a very good oil filter but took some
time to dissemble and clean. Anyway, I think the Lyc crank works
in much the same way to trap sludge from the oil.
The second reason is due to the small hole in the rear plug, that
the oil velocity slows down when in the crank area and this causes
it to 'dump' any suspended particles. This works just like water
flowing from a narrow river into a larger lake, it slows and dumps
out what ever it is carrying. I think the centrifuge is the main
effect and the slowing of the oil a secondary effect.
I just cleaned out the end of a crank over the week end for a
friend on his RV6 with an O320 (160 HP) with fixed pitch prop as he
wanted to comply with the 505 SB.
I took an old hacksaw blade and used the smooth side.
The crud is quite hard and very compacted to the wall of the crank.
Once all the crud was physically scraped out, I flushed it with
a strong spray of carb cleaner (the kind you buy in a spray can).
They held the tail up and this let the carb cleaner run back out
the front. Cleaned up the inside with some paper towls and more
carb cleaner. In this engine, the inside was A OK.
Oil temperature has a lot to do with sludge build up in the oil
and this does leave a lot of water in the oil which will cause
corrosion. This moisture will get traped in the crank as well.
But even with hot oil, there will be a lot of crud that builds
up in the end of the crank.
FYI, one of the articles I read from a Jan 2x Pacific Coast
Flyer (or one of those newspaper flying rags) said that
Lycoming was working on a coating that could be used to coat
the inside of the crank. They said it would be avail in about 6 to 8
weeks or so. Given the types of epoxies we have, this would be
a good used for some epoxy paing coating. There is little chance
this would ever come loose due to the centrifical force inside this
cavity. It also said only 160 HP and higher engines would be
affected by the AD (excluding 150 HP O320's and all O235's and
290's from the 505 SB and AD).
Also pitts would be allowed now up to some limit unless cracks were
found. Stay posted for a lot more in the news on the 505 SB and
associated AD.
To answer another question on how the oil gets into this area,
there is a small tube that goes across this hole in the crank
(you will see it once you pull out the front plug and look inside).
This tube has a hole cut it it. This tube carries oil from the
main bearing (that comes from the cases) and into this cavity.
The hole punched into the plug at the rear of the crank cavity
lets the oil flow back into the case.
Herman
> Ed,
> Les Williams
> RV-6AQB #60027
> ebundy(at)juno.com
Subject: | Re: Electric aileron trim installation |
Warning-this is lengthy
Brian. The first instruction on my drawing reads "Replace aileron spar
outboard root reinforcement plate with EAT-603 plate (6" length). Trim
upper flange as shown." Drawing EAT-1 is a mess because Vans moved the
tab from the aileron inboard to the outboard and did not update the
dimensions on the drawing to reflect the change.
*Drwg.16 shows inboard aileron L.E.rib edge distance as 1 5/16" and
outboard L.E. rib edge distance as 3/4"
*Drwg EAT1 section A-A shows the EAT-601A mount against the side of the
L.E.rib (I put a nut-plate in the 601-A and secured it to the rib with a
screw for more rigidity)
If you trim the EAT-603 doubler back
1 7/8" as called for in Drwg.EAT-1 your EAT-601 mount will be located
9/16" from the L.E.rib and there will be a 9/16" gap in the doubler
flange at the rib.
My solution was to :
*find the L.E.rib location on the spar
*trim the doubler flange back just enough to clear the L.E.rib
*make your cut-out in the doubler & spar so the EAT-601 mount rest
against the L.E.rib
*shorten your EAT 604 & EAT-605 dimensions to fit the opening.
If you do this your EAT-606 acuator arms will have to be moved
outboard on the piano hinge to align with the servo.
Your access cover will also be about 9/16" narrower.
I also added fairings from Avery's to cover the servo rod exits on my
aileron & elevator, I think they added a nice touch.
Chris Brooks
From: | Greg Puckett <71155.2336(at)CompuServe.COM> |
I was also contemplating how to save my gyro's. Although the vacume shutoff
valve would work, I think you would never want to shut off the vacume in flight.
I remember an instrument overhaul guy telling me once that there is much more
bearing wear in a gyro when the A/C is moving and the gyro is not turning at
rated speed, he used to say to always wait to push your A/C back into the hangar
until the gyro's had completely spun down unless you were pushing it absolutely
staight back. I suppose you could just fly absolutely straight for several
minutes and then yank & bank. The possibility also exists that this guy was full
of #$@$. Has anyone else ever heard of this?
Greg Puckett 80081 (spars are here, ribs
drilled to them)
From: | Stephen Jackson Soule <ssoule(at)vbimail.champlain.edu> |
I would accept the holes as drilled and do an extra-nice job with the
Pro-Seal. I would also call Van's and run it by them.
Steve Soule
(Left wing done
right wing in the jig.)
Subject: | Re: Chatter: VFR GPS direct-to clrnc |
From: | wstucklen1(at)juno.com (Frederic W Stucklen) |
>Fred, I think the gotcha here is that ATC doesn't care what equipment
>you have on board when they give you a clearance because, if you accept
it, it's
execute
I agree with you here. A couple of times, wnen given a "direct" 've
suggested back
the heading. Sometimes they amend the clearance to "Heading xxx,
direct when able".
That keeps it leagal.
The other thing to remember is that, when off airways and in the
area of VORS (like
most places on the East Coast) as long as one has DME, you can
leagaly go direct
by manually performing the RNAV functions with the VOR's. This
obvoiusly is a lot
of math in the cockpit, something I don't believe in, but it works.
*** SNIP ****
> Even though I
>have to file as a /A I routinely get asked if I am RNAV equipped. I
you
>a little with a question we both know the answer to". Like you I
>started putting "Loran equipped" in the comments box of all my flight
leave
>it off.
I do find putting "VFR GPS" in the remarks box results in being
offered
the "direct" routings. This has happened more often while flying in
the
midwest, and least often here on the upper East coast. I get it
most often
traffic is light and it's VFR at or above MVA at the destination
end.
Fred Stucklen RV-6A N925RV
Hi folks,
This stuff about engines is fascinating. I like to learn about the
technologies and you people seem to have a wealth of information on these
airplane subjects. I wont be able, however, to pop for a ten K +
engine so I hope I can get away with next best. Except I don't know what
that is. I'm told that the 94 Buick has a supercharged engine, and that
the s-10 Chevy has a 4.3 liter engine that would crank up at least 180hp.
Can any of you set me straight on what I should be looking for in the
area of cost, performance, Hp., accessories etc., that I might stick to
the front of an R/V.
Larry lm4(at)juno.com
From: | "Timothy J. Etherington" <tjetheri(at)cca.rockwell.com> |
<< fired a 4 pound chicken at over 650 mph
At lockheed, way back when I worked there, the chicken had its head dipped
into liquid nitrogen to kill it before firing it via air canon at a C-130
windshield. I had to mention that before someone deceided that there was
some gross treatment of chickens involved.
Avweb has an interview with the president of Lycoming. After reading that,=
I guesstimated product liablity cost at $4k/engine. A recent note indicat=
es that Lycoming has come out and said $4k/engine. Let's for a moment pret=
end that the parts that make up a Lycoming are not airplane engine parts bu=
t just machined parts. What do you think they cost?? I would guess $3k ma=
x!! I'd say Lycoming is doing very well $$ wise for such a small market. =
Also note that the president said the same thing. They are very healthy fi=
nancially.
So, let's look at the Superior "clone". No liability tail. No certificati=
on costs ( it's a clone the cert is going to be trivial). No development c=
osts to speak of ( it's a clone). This leads me to conclude... $10K IS TOO=
DAMNED MUCH!!!! (1/2g).
Lastly, someone asked what's the next best option to a $10k+ Lycoming. The=
answer is a loan to buy the $10k+ Lycoming (IMHO). =20
John ( who will almost certainly get in line for a Superior engine)
I get a newsletter named "Contact!". It's about experimental aircraft
using Alternative motors. They also have a great book that deals with
different installations and different motors. Lately, there has been allot
of RV articles.
Contact !
2900 East Weymouth
Tucson, AZ 85716-1249
Phone # 520.881.2232
I highly recommend it!
Ernesto Sanchez
es12043(at)utech.net
> From: Larry Mac Donald <juno.com!lm4(at)matronics.com>
> Subject: RV-List: engines
> Date: Monday, February 24, 1997 6:31 AM
> Hi folks,
flight.
hangar
full
>drilled to them)
Gary:
I believe Herman already touched on this, but I'll do it again. There is no
cheap way to do aerobatics with gyros, period. If you disable the vacuum
they just flop around and tear themselves apart. The cheapest way is build
a removable sub panel. Some competition planes use removable panels for
ferry flights between events.
Regards:
Rusty Gossard
N47RG RV-4 Flying since 8-94
From: | J.Ken_Hitchmough(at)magic.ca (J.Ken Hitchmough) |
Subject: | Van's Sun 'n Fun banquet |
Does someone please have the date, time etc for Van's banquet at Sun 'n fun=
. Also, a contact for registering would be good too.
Ken
RV6A Flying
This message sent using the FirstClass SMTP/NNTP Gateway for Mac OS.
Their hours are Tues-Fri 11-6, Sat 9-4 and phone is 206-393-4060. They are
just South of Kent, Wa on the East side of the Kent Auburn valley about 8
miles south of the Renton airport and 4 miles north of the Auburn airport.
Give them a call for the address and driving directions. I'm told they
usually put "new" stuff out early in the week so you might plan to visit
then. If you need more info let me know.
MikeT RV-6 lh wing about ready for skin
To All RV-8-ers Who Have Wing Kits:
What is the necessary spacing between jig uprights? Initially, the
empennage kit said something like 109" for the HS, but subsequent
references seemed to indicate that more is required for the wing jig.
--Don
mcnamara(at)sbt.infi.net
Subject: | Re: chicken chatter |
I am from Iowa but I did not grow up on the farm, from what I hear chickens
don't ever fly more than a few yards. Are we really in danger of hitting
them in airplanes! Are you the guys that supply McD's with the nuggets?
> From: aol.com!Cafgef(at)matronics.com
> Subject: Re: RV-List: HVLP Paint Systems
> Date: Monday, February 24, 1997 9:38 AM
dipped
Then there was the Irish AIrcraft company that just couldn't get their cano=
py to resist the chicken. They kept making the canopy thicker and thicker, =
but still the chicken would shatter it.
Then someone suggested they should try defrosting the chicken before they f=
ired it.
Ken RV6A (half Irish)
I am from Iowa but I did not grow up on the farm, from what I hear chickens=
them in airplanes=21 Are you the guys that supply McD's with the nuggets? =
20
> From: aol.com=21Cafgef=40matronics.com
> To: rv-list=40matronics.com
>=20
> =3D=3D> RV-List message posted by: Cafgef=40aol.com
>=20
>=20
> <<<< fired a 4 pound chicken at over 650 mph
dipped
> into liquid nitrogen to kill it before firing it via air canon at a C-130=
> windshield. I had to mention that before someone deceided that there was=
> some gross treatment of chickens involved. =20
Subject: | I picked up my Quick Build kit at the factory |
I picked up my RV6AQ at Van's in North Plains on Valentine's Day. So I guess we
name it Valentine! My wife has changed from thinking I'm crazy for buying
another plane that is more work than the Debonair, to willing to help a bit.
PICKING IT UP AT THE FACTORY:
What fun! Van's is a really nice group of people in a typical little Pacific
Northwest mill town. I asked them where we could get lunch and they suggested
Portland or Seattle. Actually, the tavern restaurant on Main has decent
sandwiches.
We jetted to PDX and cabbed to North Plains for $20 more than the estimated $35
and rented a U-Haul 24 foot van. A real big rig that loves gas. $175 for five
days and more than enough mileage to get home. Oh, and $56 for insurance.
Before leaving I bought insurance for the kit for $255 a year.
Van's people packed the truck - perfectly! It isn't often that you get work
done and it is totally without flaw. California I-5 is as bumpy as any logging
road but the kit didn't suffer at all. We did, though. I'm sure the 600 pounds
of kit never flexed the springs. We could have avoided that and probably
made enough to cover rental if we had bought three or four slings of plywood and
sold it down here.
WHAT THE BUSINESS LOOKS LIKE:
It has a tiny sign - the oval jacket patch enlarged to a foot long. My
impression is that it is a thriving business with happy employees. Mostly, they
are in the design and packaging business. I think we got distracted and missed
the actual "make things" building. QB fuselages are up on the top row and other
stuff below. Mountains of Lycomings - no wonder Van thinks they are so great.
They have a new sheet metal punch - stick in a floppy with the layout and it
cuts out the parts for you.
INVENTORY YOUR KIT!:
Easier said than done! The packing list is in what us software engineers call
"heap sort", basically thrown on the heap. Gross parts are easy like here are
two wings, three wheels, two nose gear inner tubes (?) etc. Some parts are
unmarked, however, especially the steel. The thing that looks like a tomahawk
is the rollover bar support - must be as there's nothing else left. The real
killer is the baggies. 96 zillion small brown paper bags each with a number
like Q605 or 902-1 packed in no order. The list tells what is in each so just
pick up a bag and search thru the 10 page unsorted list. Open bag and see if
the contents shown on the list are there. This one contains "misc hardware".
The next one contains " " - oops no entry. Doing inventory helps you learn
what is in your airplane.
How, I asked myself, does one find the part while building?? One bag, for
example, has four screws in it. Truss head, 3/16 by one inch, drilled. I don't
really know the AN... I'll see a callout on the drawing, look in my little
mechanic bible for what it looks like, and start going thru baggies.? I went
out and bought six plastic divided boxes. I've had some little drawer cabinets
for a long time - they're almost worse than brown baggies. Van's must know, at
some point, what goes into the bags. Maybe they could print a list for us -
sorted. I suspect they would save money by buying boxes like I got and packing
the tiny parts in them. It would save a lot of stapling and unstapling time!
All the components look like top quality to me. So far, I'm quite impressed.
The construction that has been done looks very fine. From now on, I am in awe
of all you who have built all this with your own hands! I almost feel guilty
doing the quickbuild.
ENGINES:
I got the kit without the motor mount. I like what I see about the Chevy V-6,
especially if I use the aluminum block and heads. Then it would probably weigh
less than a Lycoming. It would certainly cost less than a new Lycoming but the
all aluminum option would not be as cheap as a patched up junkyard Lycoming.
I'm an engineer by training and profession and licensed in the State of
Washington - though fees aren't paid up. I am open minded about this. I want
a
powerplant that is reliable and reasonable in cost. Durability is not a high
order requirement as I will probably not fly more than 200 hours a year. If I
can go all year on one low priced engine, that would be ok.
If I wasn't confidant that I could work out development problems, I've
overhauled and prepared for racing over 200 engines of all types, I would not
undertake a non-standard engine installation. It will be an experiment and a
big project in itself.
INSTRUMENTS:
My Valentine will be a platform for testing and showing off a computer and
software related product. It will involve instruments, human factors,
navigation, human factors, flying skill and human factors. I'll be looking for
input from this exciting forum!
Developing the technology for the airplanes that today's Young Eagles will fly
has been left up to us.
Hal Kempthorne halk(at)sybase.com Santa Clara, CA. (SJC)
Debonair N6134V A zillion RV-6AQ parts in the "hangar" we call home.
I'm looking for the Orndorff videos for the fuselage and finish kit.
Anybody have one for sale? You can respond personally to address below.
Ed Cole RV6A Wings
emcole(at)concentric.net
Larry writes:
Richard Van Grunsven, the brilliant engineer who designed this fine machine
suggests a Lycoming in the 150 to 180 hp range (200 for the RV8). I don't
believe you will have a real great engine for under $10,000. That will buy a
decent overhaul but you still need a core. I guess $10K would buy a core and a
good top and accessories overhaul.
You can probably get that Chevy V6 for around $10K. No, not the 500hp job, the
220 hp one. The modified racing engine only had a TBO of ten hours which you
might find unacceptable anyway. With enough money, you can make this engine
*LIGHTER* than the Lycoming 180 with constant speed prop. I understand that
Belted Air Power of Las Vegas is selling the package with everything but the
Chevy long block for about $8K. The long block is about $1600. Twist their
arms and I'll bet they'll give you very good support.
Without someone like BAP to guide you, I believe that you would need significant
skill, time, and money to install a non-standard powerplant. You might,
however, discover the true meaning of experimental, learn, and have fun.
From: | John Morrissey <John.Morrissey(at)its.csiro.au> |
This one had us rolling around the office laughing :-)
>dipped
I'm not sure which one I'd prefer if I was a chicken - being fired out of a
cannon while I was still alive or having my head dipped in liquid nitrogen.
I'd reckon the chook would have a pretty startled look on its face no
matter what method of dispatch was used.
Happy RV'ing!!
John Morrissey
John Morrissey
CSIRO ITS
Data Communications Manager
Phone:- 06 2766811
Fax:- 06 2766617
Mobile:- 018 628804
Email:- John.Morrissey(at)its.csiro.au
CSIRO ---- AUSTRALIA'S SCIENCE, AUSTRALIA'S FUTURE!
From: | Frank van der Hulst <frankv(at)pec.co.nz> |
Hi Ken,
Something funny with your mailer... I get 2 copies of your messages to the
RVlist, and a message saying that there are faulty attachments. Do you have
MIME enabled or something?
Frank.
cano= py to resist the chicken. They kept making the canopy thicker and
thicker, = but still the chicken would shatter it.
f= ired it.
>them in airplanes=21 Are you the guys that supply McD's with the nuggets? = 20
>>=20
>>=20
>>=20
>dipped
frankv(at)pec.co.nzZ (without the anti-email-spam Z, of course)
http://www.pec.co.nz/~frankv/
Frank van der Hulst, Software Engineer, Cardax, PEC(NZ) Ltd, Marton
"Knowledge=Power=Energy=Matter=Mass; A good bookshop is just a genteel
Black Hole that knows how to read". Terry Pratchett, "Guards! Guards!"
Subject: | Re: I picked up my Quick Build kit at the factory |
>The real
know, at
packing
I wonder whether Vans might like to give us the option of having all the
'baggie' parts in some sort of labelled, plastic drawer cabinet or similar.
It would be worth a few extra dollars to me.
>I almost feel guilty doing the quickbuild.
And so you should :-)
>INSTRUMENTS:
for
Hey, this is one of the aims for my RV-6. Like you, I'm a software engineer
too. I'd love to share/swap ideas and tricks/traps. It'll be a while before
I get near the point of having much to offer though. In the meantime, you
might like to join the Glass-Panel list and/or visit the Aero Computer page
at http://www.evansville.net/~newtech/
Frank (building elevators & ailerons)
If I ever have to be executed, that's the way I want to go. (Dip my head
in nitrogen) Ha. I still like my chicken fried!!
Subject: | Re: Superior O-360 |
> How about giving us that e-mail address for Gary Greenwood at Superior one more
> time. I sure as heck will inquire!
Several people E-mailed me for this, so I'll re-post:
Phone: 800-487-4884
E-mail: sapi(at)airmail.net
Bob Reiff
From: | Michael Angiulo <mikeang(at)MICROSOFT.com> |
The 109" is as long as you really want to go. The problem is that you have
to "stand off" the support brackets on the outboard wing tip by an inch or
two to clear the overhang of the top skin. If your braces are farther
apart than 109" you might not get enough meat on the lower spar support at
the inboard end. The standoffs only need to be angle that's a couple
inches wide. The drawings in the plans wouldn't suggest this for a second.
I built my jig and totally leveled the wing to find the top skin didn't
fit. That was a real head scratcher. I had to take the whole wing off
just to move the arms out an inch.
-Mike
From: Don McNamara [SMTP:sbt.infi.net!mcnamara(at)matronics.com]
Sent: Monday, February 24, 1997 9:31 AM
Subject: RV-List: RV-8 jig
--Don
Subject: | Re: Van's Sun 'n Fun banquet |
J.Ken Hitchmough wrote:
> Hitchmough)
> 'n fun. Also, a contact for registering would be good too.
> Thanks
> Ken
> RV6A Flying
Ken
I talked with John at vans last week, and he said it should be on
tuesday april 8. I have to make vacation plans well in advance so
I wanted to know too. Van's was still not taking reservations at
that time, but they should by now.
Craig Hiers
Tallahassee,FL.
Driving to Sun-N-Fun for the last time ( I hope )
Subject: | Jigging Fuse Bulkhead Measurements |
I have clamped my RV6A firewall, bulkheads, and longerons into a Steven
Frey Metal Jig. I've begun checking the centering, height, and spacing
between measurements of the bulkheads. My firewall is exactly plumbed,
centered, and at the prescibed height. When I check the height of the
F-604 bulkhead, it measures 24.50 inches. DWG 23 indicates it should be
25.16. I could move the f-604 up to the 25.16 but then the outside support
of the F-604 would not be able to attach to the longeron. Can anyone tell
me what I'm do wrong and how precise should these heights measurements be.
Also my F607 and f-608 bulkheads are too low. The longeron has been fitted
into the slots of the bulkheads but I suspect that you cut the slot out
even further to bring the bulkhead up to the prescribed height. Thanks in
advance for any guidance.
Ron Caldwell
RV6A - N655RV Reserved
rlcaldwell@utah-inter.net
From: | Brian McShurley <bmcshurley(at)www.sfgate.com> |
Subject: | Re: Boeing Surplus |
My father visited them last week and picked up some ods and ends.
Note....They do not sell any AN hardware or fittings. They are required
to return these to the manufacturer as a result of the bogus air parts
situation of a year ago.
But were able to pick up some good (one was new, just needed a setscrew)
microstop countersinks, and some long drills. Drills are something like
$1 a pound for the standard length. Stepped drills on the order of $5 a
pound.
He said there is lots to see (buy), and lots of junk to avoid....
Caveat Emptor....(let the buyer beware)
Brian McShurley
S-51D Mustang, N514BM
Subject: | Prop Governors - new, overhauled, "experimental" |
Folks,
I'm looking for recommendations on buying a prop governor (I've
ordered an O-360 and C/S prop from Van's). My options are:
1. New Woodward governor from Van's, $1200
2. Overhauled (yellow tagged), nearly $1200 (I hear) -- pointless
3. "Experimental" (non yellow tagged) $450-$700
I know some folks on the list have found experimental governors for
somewhere around $500.
I've talked to an overhauler who indicated that he could put
together a servicable governor for around $650-$700. He indicated
that a fairly recent (2 yrs) service bulletin (not an AD, a service
bulletin) from Woodward has required that most governors in for
overhaul have the drive gear spline and pilot spool replaced due to
wear limits. This gentleman's opinion is that Woodward is pursuing
their agenda (parts sales?), and safety of flight isn't impacted by
keeping a drive gear and spline that have some excess wear.
I don't mind paying for new/yellow tagged if safety or reliability
requires it, but I'm interested in saving the bucks if possible and
safe. What's the experience of the folks on the list who know
governors? What have you experienced?
Tim Lewis
RV-6AQ #60023
timrv6a(at)earthlink.net
From: | wmills(at)southwind.net (William H. Mills) |
Subject: | Re: Performance Equations |
> I'm trying to come up with a spread sheet to calculate aircraft
>performance characteristics. I need formulas to compute density altitude
>and CAS, given Altitude, OTA, Baraometer, etc. Does anybody have these
>in a practical form?
Fred (and fellow Listers):
Sorry about the "staleness" of this post, but I sent it once before and it
disappeared into cyberspace or something, never did see it show up. Also
please forgive the *very* long post...and relatively heavy-duty math.
These will give you what you want and more...
Note, these are good only below the tropopause (36,089 ft); if anybody
REALLY thinks they'll be operating up there, I CAN give those equations
also....
Some definitions:
* Multiply
^ Raise to the power of
sqrt Take the square root of (no negative numbers!)
PALT Pressure Altitude, ft
DALT Density Altitude, ft
ELEV Field elevation, ft
OATC Outside air temperature, degrees C
OATF Outside air temperature, degrees F
ISA International Standard Atmosphere (15C/59F, 29.92 in.
Hg/14.695972 psia at sea level)
DISAC Temperature variation from ISA, degrees C
DISAF Temperature variation from ISA, degrees F
KIAS Indicated airspeed, knots (airspeed on indicator, corrected for
instrument error)
KCAS Calibrated airspeed, knots (IAS corrected for position error
(unique to your aircraft)
KEAS Equivalent airspeed, knots (Mach * 661.48 corrected for pressure
variation from sea level ISA)
KTAS True Airspeed, knots (Mach * 661.48 corrected for temperature
661.48 Speed of sound at sea level ISA, knots
Mach Ratio of true airspeed to speed of sound at sea level ISA
INHG Altimeter setting or barometric pressure, in Hg
delta Ratio of atmospheric pressure at condition to sea level ISA pressure
theta Ratio of atmospheric temperature (absolute) at condition to sea
level ISA temperature (absolute)
You can get pressure altitude one of two ways: by setting your altimeter
to 29.92 and reading the resulting altitude, or (if you're on the ground
and not in your airplane, for instance) taking the local altimeter setting
(or barometer reading) and the local field elevation and applying this
equation (taken from the chart in the Density Altitude AC):
PALT = ELEV + 27954.29 - (933.94 * INHG)
Next, given PALT and OAT (either degrees F or C):
delta = (1 - (6.87535*10^-6 * PALT))^5.2561
theta = (OATC + 273.15) / 288.15 = (OATF + 459.67) / 518.67
DALT = (1 - ((delta / theta)^(1/4.2561))) / 6.87535*10^-6
DISAC = (theta - (1 - (6.87535*10^-6 * PALT))) * 288.15
DISAF = (theta - (1 - (6.87535*10^-6 * PALT))) *518.67
You have now defined the atmospheric properties for your flight condition.
For the airspeeds: If you know your position correction, you should take
IAS and compute CAS using that correction. If you don't know it, you can
approximate CAS by using IAS until you define that correction. If you know
CAS, you can compute EAS, TAS, and Mach accurately; if you don't know CAS,
there will be some error in this until you establish the position
correction. Given KCAS:
Mach = sqrt(((((((1 + (0.2 * ((KCAS / 661.48)^2)))^3.5) - 1) * (1 /
delta) + 1)^(1/3.5)) - 1) * 5)
note: there are 7 open parenthesis there!
KEAS = 661.48 * Mach * sqrt(delta)
KTAS = 661.48 * Mach * sqrt(theta)
Now, if you know Ground Speed (in knots), heading and course, and the wind
at your flight condition, you can figure KTAS courtesy of the ol' E6B (or
electronic equivalent). Once KTAS is known, you can back-calculate to get
KCAS (incidentally, this is one way the pros use to get their airspeed
calibration (run several IAS over a known course and use GS to get TAS
(note: helps to have VERY LIGHT winds!)); the other alternative is a
pitot/static boom with a trailing cone):
Mach = KTAS / (661.48 * sqrt(theta))
KCAS = sqrt((((((((1 + (0.2 * Mach^2))^3.5) - 1) * delta) + 1)^(1 /
3.5)) -1) * 5 * (661.48^2))
note: there are 8 open parenthesis there!
Good luck on the spreadsheets!
Bill Mills
STILL RV-8 Dreaming
A36 (Flying Club) Flying
Wichita
Subject: | Re: Jigging Fuse Bulkhead Measurements |
Ron, the outside support of the F-604 does not attach to the longeron,
it attaches to the F-604F that rivets to the longeron. see Drwg.31,
Detail"A" upper left hand corner.
If you enlarge the longeron slot in the bulkhead to align the bottoms
you may unalign the tops. My F-607 was a little short on the top and
bottom so I relocated it 3/8" aft.
Chris Brooks
BrooksRV6(at)webtv.net
Subject: | Re: Prop Governors - new, overhauled, "experimental" |
Tim Lewis wrote:
> Folks,
If you do decide to by a used governor, consider getting a Woodward with
the rear housing held on by screws, rather than a V-band clamp. This
will allow you to use Van's governor bracket (or make a screw-attached
bracket yourself). The governor end of your prop cable housing should
be attached to the engine/governor assembly so as to avoid changes in
prop RPM as the engine moves around on its mounts.
You will find that the control arm of rear-mounted governors is so far
aft, that the only reasonable bracket mounting point is the rear cover
of the governor itself. Hence my recommendation to obtain one with
screws that can be used to mount a bracket.
I had a Woodward with the V-Band clamp, but found a overhaul shop who
agreed to an overhaul/exchange for the other type. The person at the
shop that I spoke to seemed knowledgable and easy to deal with. I am
expecting the governor back in a week or so. If things look OK, maybe
I'll give the outfit a plug on the list.
Don:
On my RV-8 wing jigs I used an inside dimension of 112.25". If you study the
jig drawing carefully, you will note that the root end of the mainspar will
rest on an aluminum or steel angle, which is bolted to the jig vertical post.
The wingtip end uses an angle that is bolted to the tip rib, which rests on
top of the angle bolted to the jig vertical post. I used 1.5" wide aluminum
angles, two of those equal 3", plus the rear spar width of 109" totaling
112", the .25" extra is for ease of removal from the jig.
Bear in mind that no crosspiece is used in the wing jig, so you have to make
changes to the empennage jig anyway. Will you be building both wings
simultaneously? I have elected to do so, and have placed both wing jigs far
enough away from the wall to permit easy access to both sides of each wing
panel during construction. Of course I am fortunate enough to have a heated
hangar to work in, with space not being a problem.
Best,
Jon Ross
RV-80094 - Empennage complete, wing jigs complete, starting wings...
From: | "Dave and/or Diane Irwin" <dirwin(at)ibm.net> |
Subject: | RV-6 fuselage jig for sale |
I have a RV-6 welded steel fuselage jig for sale. It is made from steel
angle and has been painted. It has built 2 RV-6's so far and can be picked
up for $150 (Canadian). Please contact me for more information.
Dave Irwin dirwin(at)ibm.net 519-433-2327
London, Ontario
RV-6A 22607 (fuselage - cockpit floor)
Grumman AA-1B
Frank van der Hulst,frankv=40pec.co.nz,Internet writes:
Hi Ken,
RVlist, and a message saying that there are faulty attachments. Do you have=
Frank.
Frank, does it happen with ALL my messages?
Theres nothing (to my knowledge ) wrong with my mailer (although I did have=
a crash while composing it and had to do it again)...could be something to=
do with that.
How did this message get through?
Ken
=20
Robert Fritz wrote:
> Hi Bob,
> All the parts for a new O-360 for under $10,000!!!!!!!
> No flames here, I love the idea. But that means that if the certified parts
can
> be sold for $9500 and the assembled engine costs $19,300, then the cost to
> assemble an engine at Lycoming is about $10,000. Where did they burn that much
> money?
> Cheers,
> Bob Fritz
Unfortunately, that 10 grand probably goes to thier liability insurance!
Check that your accounting for the metal plates on the frey jig. I belive
that you have to at either 1/8 or 1/4" to account for the plate that is not
sitting on the same line as the longeron
Don Mack
RV-6A
donmack(at)flash.net
http://www.flash.net/~donmack/
> From: Ron Caldwell <utah-inter.net!rlcaldwell(at)matronics.com>
> Subject: RV-List: Jigging Fuse Bulkhead Measurements
> Date: Monday, February 24, 1997 9:17 PM
support
tell
be.
fitted
in
> Ron Caldwell
Why not? Granted, there *shouldn't* be one, but then there shouldn't be
one for a 15 year old airplane either. Sure, you (probably) can't sue
for assembly-related failures, but what happens if a wrist pin or
crankshaft fails? Every single part in that engine is going to have a
liability trail just as if it rolled off of Lycoming's line as a complete
engine.
As long as there are airplanes there are going to be lawyers waiting for
something to break...
Ed Bundy RV6A N427EM first flight 11/20/96
ebundy(at)juno.com
Ron,
Did you construct the bulkheads according to S. Frey's suggested method?
I recently did mine his way and used a Frey jig and the fell right into
place with the proper height and width. Double check the width of your
longerons at each station. You can also enlarge the notches for the
longerons, if necessary. Mal
From: | Charlie & Tupper England <england(at)vicksburg.com> |
Subject: | Re: GYROS AND AEROBATICS |
>Talked to an RV-4 driver the other day. Asked him how he prevents
>damaging his gyros when doing aerobatics. His answer was that they
>are damaged!
>There must be a better way. Anybody installing/using "cageable"
>gyros out there? How much more does this equipment cost?
For what it's worth:
I was in a partnership for ~1 1/2 years with an airline pilot who flys
airshows on the weekends & acro several times a week for fun. We owned a
big-engine Globe Swift (200 HP). I learned acro in this plane, he has put
probably 200 hours or more of acro time on it, the plane has several
thousand hours TT, and he flys it in hardball IFR traveling to/from work
every week. It has what he calls a "non-tumbling gyro" horizon. I'm no
expert, but apparently most horizons will "tumble" if taken much beyond
normal attitudes. The other gyros are plain vanila. Obviously, acro is
harder (it's also harder on your airframe), but this guy trusts the plane
with his life in IFR on a regular basis, and I've never heard him mention
replacing a gyro in the 10+ years he's owned the plane (vacuum pumps,yes.
gyros, no).
Charlie England RV-4, bought flying
PS:
Would you guys please edit quotes to the minimum required to show context?
If I have to scroll through many more posts of 60 to 100 lines to get to
something like "I agree" followed by a signature, I think I'll buy a boat.
From: | Alan Carroll <carroll(at)geology.wisc.edu> |
Subject: | Franklin Engines |
The recent RVator mentions the Franklin 6 cylinder, "220 hp" engine as a
possible alternative to the Lycoming 200 hp IO-360 for the RV-8. It also
suggests, however, that builder interest in this option is not sufficient
to justify the the R&D expense of a new mount, cowling, etc.
Given the large price differential between these engines I find this a
rather surprising statement. My understanding is that the Franklin
installation should weigh about the same as the Lycoming (330 lbs.),
produce at least as much power (205-210 hp?), run more smoothly, and give
you a certified aircraft engine for about $10K less than a new Lycoming.
Am I missing something?
At the least I'd like to know more about the reliability, real-world
performance, and installation issues for this engine. I can find very few
previous posts in the archives.
Alan Carroll
RV-8 #80177 (Empenage)
Anybody got any information on RST's new #564 audio panel
Chet Razer
crazer(at)egyptian.net
How do I take myself of the rv-list? Can you do it for me? Tom
From: | Cheryl Sanchez <csanchez(at)BayNetworks.COM> |
Subject: | Oil cooler hookup question |
Hi,
I am about to order the parts I need to do my oil cooler
hookup and I'm not quite sure what to get. My engine is a new
O-360 that I got from Van's. As I understand it, one of the
connections to the engine, near the oil filter, needs a 45 degree
fitting. My question is: is the 45 degree fitting the part that
screws into the engine or the fitting that goes on the end of
the Aeroquip hose?
Thanks.
Cheryl Sanchez
csanchez(at)world.std.com
Does anyone have an RV6 fuselage jig for sale within 200 miles of San
Jose, CA. ? Please respond to me directly.
Ed Cole
Hi again,
I received *3* copies of this message! The 'faulty attachment' message
belongs to one of them... it's hard to tell which one. It's also possible
that one of the messages is the faulty attachment (I told Eudora to convert
it to text for me).
Here's bits of the headers from the 3 messages that might be relevant:
The quoted-printable version had some hex-encoded characters in it. Here's a
bit of it:
Hi Ken,
HTH,
Frank.
Subject: | Re: Barnard Aircraft Components |
Just a couple of comments on the BAC option. Ken has always been negative on
the BAC option even before the pre-punched skins. I purchased the BAC kit
and am glad I did. There has been virtually no problem with any of my
alignments(ailerons, ribs, etc.). A friend here who purchased a second
kit(his second RV) has been poor mouthing the pre-punched skins, because of
the critical drilling of the spars( all done on the BAC Kit). The undrilled
skins which is what I have, leave some room for adjustment.
The quality of all the prefabricated pieces, many anodized, is another plus.
I continue evaluated whether I would choose this much more expensive
alternative and still believe it is money well spent.
Shelby in Nashville.
What is S. Frey's method?
What is a Frey jig?
Bob Haan
bobh(at)cdac.com
Portland, OR
503-636-3550
RV6A 24461 drilling the fuselage skins
OK, wing experts---------
I'm close to attaching the flap to the left wing on my RV6A. Van's
suggests attaching without the top skin attached to the flap, and Frank
Justice's manual has you complete the flap before attachment. What are
the pro's and con's of either method? I'm ready to finish skinning the
flap so I need to decide now.
Also any tips for hanging the ailerons and flaps would be appreciated. Is
it easier to do with the wing hanging vertically or horizontally on a set
of saw horse?
Thanks in advance,
Ed Cole RV6A Wings
I have had a couple of inquiries about a source for Deft Primer in small
quantities.
Dan White has it available in both 2 Qt and 1 Gal quantities.
3131 SW Martin Downs Blvd
Suite 374
Palm City FL 34990
(407) 223-8915
duba(at)gate.net
John Top #5372
(619) 549-3356
From: | ken hitchmough <j.ken_hitchmough(at)mail.magic.ca> |
Subject: | Re: Terra Transponder |
> ken hitchmough wrote:
> > I've had a Terra transponder and encoder on order from Aircraft Spruce
> > since before Christmas, having been given a January dlivery date of back
> > ordered transponders.
> > I'm now being told by Spruce that they won't get transponders until the
> > end of March...another delay of two months.
> > I'm wondering if this is a sign of something else! Anyone know why?
An update.
After several letters of advice I finally called Trimble. The story
seems to be that they still have some back orders all the way to July of
last year. There are something like about 300 transponders on back order
plus other units too, with an expected lead time of over 9 weeks. Even
though I had mine on order with Spruce end of December, it was suggested
to me that I should forget March and it may even be April or May before
I would see one.
Everyone at Trimble seems upset at the situation and they seem to be
doing their best to get back on track.
The certification issue seems to have been solved, its now purely a
manufacturing capacity issue.
Pity really because I REALLY wanted the Terra. Due to an urgent need
though, I've had to cancel my order and get something else.
Thanks to all who responded.
Ken
Subject: | Re: Franklin Engines |
>My understanding is that the Franklin installation should weigh about the
same as the Lycoming (330 lbs.), produce at least as much power (205-210
hp?), run more smoothly, and give you a certified aircraft engine for about
My thoughts, too. I have flown behind one of the old Franklins and it was
one of the smoooothest engines I have flown with. Granted, that was a USA
built one that was factory installed in the airplane. Who out there knows
about these engines and why aren't more being used??
Michael
RV4 232 SQ
Subject: | Re: EDIT your reply |
AMEN!!! It sure takes up a lot of archive memory for things to be repeated!!!
I made a couple of phone calls and got some costs for the items excluded
from Superior's alleged kit:
New Used
Accessory case $1290 350
Oil sump 1093 300
Conn rods (each) 250 95
Carb 3000 1300 (rebuilt)
Fuel pump 157 ?
Oil pump 252 ?
Mags (no exchange)
L 630 ?
R 563 ?
Ignition harness 146
Lightweight starter 375
Total 8506
Superior kit 9500
Grand total 18006
With a used accessory case and oil sump, and a rebuilt carb, the total
price would be about $14,573
If you replace the carb with an Airflow Performance fuel injection and
replace one mag with the Electroair electronic ignition the total would
be about $16,000
The new Lycoming parts prices were obtained from Intermountain Sales, a
major Lycoming parts distributor. The used prices were from Preferred
Air Parts. I have no idea if these are the best prices or if the used
parts are decent since I didn't spend time shopping around - I just
wanted some quick & dirty info. For example, I suspect carbs are
available for less than $3000. When I asked Van's if I can delete the
carb from a new Lycoming, they said they would just keep it and give me
an $800 credit.
The big questions remain to be answered...will Superior actually sell the
kit they say they will, and for what price?
Bob Reiff
Subject: | Turn coordinator/Radio noise |
Hi,
I am working on my instrument panel and today I noticed that
when I power up my turn coordinator it generates a significant
amount of radio noise. The radio is a handheld Icom ic-a20 that
I purchased six or seven years ago. Is this normal? Do I have a
bad turn coordinator? Should I use shielded wire for the power
hookups?
Thanks.
Cheryl Sanchez
From: | Stan Blanton <75472.372(at)CompuServe.COM> |
RV Builders:
Van's Aircraft shows Aeroquip 701 series hoses available. Can anyone explain the
differences between these and the 601 or 666 series hoses I found in Wicks and
Aircraft Spruce catalogs? Pros and cons?
I checked the Aeroquip homepage but it had no listings or technical data, only
info on finding a dealer or distributor.
Stan Blanton
RV-6
Fuselage top skins
Lubbock, TX
75472.372(at)compuserve.com
Subject: | Re: RST Audio Panel |
> Chet Razer
No news yet... I am waiting for this unit. I should have it by the 2nd
week of January. Wait a minute January has come and gone. Hey Jim where
is my kit !!!!
I'll let you know......
Rick Osgood
Hennipen Technical College
Eden Prairie, MN
Hi Ken,
This posting seems to be fine. Did you change something?
Frank.
>An update.
[snip]
Subject: | O-360 Fuel Injection |
Hi,
We are just starting our RV-6 quickbuild. We plan on installing a
Bendix Fuel Injector onto a factory new O-360 A1A. Here are some
questions I have...
1) Where can the fuel injector be purchased?
2) How much will it cost?
3) What type of modifications to the fuel system will I need to make
(pump type, etc.)
4) Should I consider using a different brand of fuel injector?
Thank you in advance,
Glenn & Judi Gordon
Ed ,if you have the prepunched flap skins there is no adjustment to the
top skin so you may as well finish them.
Some tips:
Mount the aileron first; secure the aileron brackets to the aileron
with clecoes and secure both hinges to aileon brackets with bolts and
spacers. Drill the out board hinge to the rear spar with the hinge line
1 5/8" below the chord line (Drw16).
Use the aieron itself to locate the position of the inboard hinge, and
set it's hinge line 1 5/8" below the chord line.
Put on female airfoil templates and adjust aileron brackets to aileron
for final drilling for bolts.
Install flap using female airfoil templates and fit to aileron.
Chris Brooks
Hi Ed ...
I installed the flap on my left wing following the Frank Justice
instructions and found that (1) it was easy to lose track of where the
flap brace was ending up and (2)it was hard to keep track of where the
flap was ending up in relation to the aileron. I think I will use Van's
method on the right wing.
Steve Soule
Huntington, Vermont
(right wing in the jig)
From: | lsmith(at)coastalnet.com (Louis E. Smith Jr.) |
Subject: | Re: Bendix/King KT 76A Retrofit |
>The February 97 issue of Aviation Consumer had an article regarding a problem
>with KT 76A Transponders having S/Ns from 93000 thru 109999. Apparently an
>internal resistor network is subject to deterioration and may cause the
>transponder to transmit incorrect altitudes and/or squawk codes. The
>corrective action is to remove and replace with a pair of glass encapsulated
>components. AlliedSignal will reportedly pick up the tab to the tune of 2.5
>labor hours and compliance by July 1, 1997 is required. Your local
>Bendix/King dealer should be aware of the situation.
Gary,
I too have one of the KT 76A Transponders waiting to go in my plane. I
checked and sure enough mine fell within the above serial numbers. I
purchased my transponder this summer at Oshkosh. My local avionics dealer
has the service bulletin. Everything you mentioned above is fact. Check
the data tag on the unit. If it is marked as having a mod 7, your unit was
caught at the factory and has already been repaired. My unit had the mod 7
already complyed with.
Louis Smith
Rocky Mount, NC
RV-8 #80126 wings N801RV reserved
RV-4 #2844 N102LS sold
Look at the last issue of Sport Aviation. There is an article on the
CompMonster (or Comp something, Son of CompMonster ?).
This is the 4 place all composite, looks kind of like a Cessna 182.
Anyway, they said that they were going to use the Franklin 220 engine.
I remember that they said the engine is imported without a fuel system
(no carb or injector). They put a bendix FI on it and modified the
cylinders (drilled holes in the intake ports) for the injectors.
They said it was running fine.
You might be able to talk to those folks on more details.
Herman
> Michael
> RV4 232 SQ
Subject: | control cables, oil pressure fittings |
I'm lashing up the controls to the O-320 and discover that the mixture
control I got from Van has a wire dia. of .075 in., but the collet gizmo that
grips the wire and terminates in a threaded (10-32?) rod end accepts only a
.050 wire or smaller. Yipes! Should I make an adapter from rod stock and
set-screws to couple two different sizes of wire, start over with a new
cable, bug-nut the cable I have now, or somehow narrow that .075 wire down to
.050 on the end? Can I do that without unaccepteble stress-risers?
Second question: Confession--- despite having read NUMEROUS warnings not to
do this, I installed my engine without first putting the oil-pressure fitting
in! I've read all the archive data on this subject but am unclear on one
point: Is there any fitting that will allow installation "as-is" without any
disassembly? AN-823? AN-915? Weatherhead 45 deg street elbow? Why all the
insistence that these fittings be steel or stainless??
Bill Boyd -- RV-6A
Good info. Bob, here are some other items that I wonder if they
come in the 'kit' or if they would have to be added to your
extra cost list?
The gears that go into the acc. case, the lifters, the push rods,
the intake tubes. (I expect the intake tube would be seperate
if the kit does not contain the oil sump).
I also expect you need the oil pump body if you have to buy the
acc case and the oil pump. Those babies are about $350 new.
Also the Superior Cylinders do not contain rocker arms or valve
covers so that may be a missing item.
What about the starter hub and ring gear? Those are about 225-150 used.
There are other odd/ends like the inter-cylinder baffels and so on.
Herman
> New Used
> Oil sump 1093 300
> Fuel pump 157 ?
> Oil pump 252 ?
> Mags (no exchange)
> L 630 ?
> R 563 ?
> Total 8506
> Superior kit 9500
> Grand total 18006
> (rest DELETED)
>Folks,
Tim,
Try EMI Aircraft Accessories in Tulsa, 1-800-851-4392. I bought one
overhauled less yellow tag for $325.00. Looks like a brand new unit!
Louis Smith
Rocky Mount, NC
RV-8 #80126 N801RV reserved Wings in jig with skins being riveted on!
Subject: | rv-list:Brake Fluid |
Any comments would be welcomed.I have been told 3 times that (Type A )
automatic transmission fluid is an acceptable substitute for aircraft brake
fluid .Have others used this in the past? Thanks in advance.
Tim Presley N64TX RV-4/160
First flight Aug '97(I
HOPE)
Subject: | Re: Aeroquip hoses |
The Sacramento sky Ranch home page has a bunch of stuff about aircraft
hoses. I'm not certain the answer to your question can be found
there, but it would be worth a try. The URL is:
http://www.sierra.net/skyranch/
Links to this and other informative pages can be found on the Van's
Air Force, Home Wing Home page:
http://www.edt.com/homewing
Randall Henderson, RV-6
randall(at)edt.com
From: | Kevin & Theresa Horton <khorton(at)cyberus.ca> |
<--snip-->
I am also extremely interested in the Franklin option for the RV-8. I
suggest that all interested parties let Van know of our interest. If
enough interest is expressed maybe he will develope a Franklin option.
Kevin Horton
future RV-8 builder (lurking and gathering info, tools, etc)
Engineering Test Pilot
Transport Canada
Ottawa, Canada
From: | Mark Reisdorfer <73101.73(at)CompuServe.COM> |
RE: The Franklin Engine for RV's
I have a friend building a Velocity and has installed the 220 Franklin. One
thing to keep in mind however the price for the Franklin includes the motor
only. You must add all the accessories, carb, mags, alt, vac pump etc....
We have run the engine recently and so far it looks great. He however benefited
from the factory demonstrator being re-engined and the engine mount was
available.
His is not injected, does anyone know if these can have fuel injection? I also
think this engine is heavier with all the goodies added than the Lyc. It also
has quite a low TBO me thinks it is 1000 or 1200 hours.
I too would be interested in the Franklin or the Cont. IO-360, as the six
cylinder engines sure are smooth.
His engine mount did not look too involved possibly a little help from all the
knowledge available on the list a Lyc. IO360 mount could be modified to hold the
Franklin.
Mark Reisdorfer
RV8 #80020
I just went through this.
(By the way, while $1200 for a new Woodward governor from Van's may seem
expensive, some prop shops told me that was BELOW their cost.)
Many of the governors in use today (Woodward, Garwin, Edo-Aire, McCauley)
are based upon the same design, and in fact some/many of the parts are
interchangable. For example, Woodward parts can be used to overhaul a
Garwin governor. (Garwin and Edo-Aire are out of business). And it's also
true that Woodward tends to issue service bullitens that entirely obsolete
older governors. For example, an SB will require a change in a casting,
but the price of the newer casting is so outrageous you are better off
buying the newer model governor.
I don't know if you have ever looked at a prop governor, but there is
almost nothing that can go wrong with them. They are pretty simple devices.
Here are the options *i* found available:
1. EMI will sell you a 'flushed and resealed' Garwin for $375 This is
probably the most cost-effective route.
2. Warner Propeller (Tucson Arizona) put together an overhauled Garwin for
me for $500.
3. Warner (and a lot of other prop shops) will sell you an overhauled,
yellow-tagged McCauley or older Woodward for around $750.
4. Most prop shops will sell you an overhauled, yellow-tagged Woodward that
is maybe one generation older that current for about $900-$1000.
I spent a lot of time on the phone with Dennis Warner at Warner Propeller.
He seemed more willing to spend time with me, more willing to share his
knowledge, and also seemed more knowledgable than most. I have no
connection with Warner Propeller, but Dennis Warner treated me right, and I
can certainly recommend him. His phone number is 520-294-5671
This is an area that (in my humble opinion) it makes perfect sense to save
a lot of money. Clearly there is no 'safety of flight' issue with any of
these options. Our airplanes' status as 'experimental allows us to use
parts that are perfectly airworthy except for paperwork (yellow tag).
Best Regards,
Dave Barnhart
rv-6 sn 23744
>Just a couple of comments on the BAC option...
It all boils down to this: which do you have more of: time or money?
My RV-6 wing kit was one of the first out of the factory with the
pre-punched skins. It made some things harder and some things easier. The
pre-punched skins mean that a little more time must be spent getting the
wing ribs positioned to match up with the pre-punched holes in the skins.
On the other hand, the former heaaache of getting tank skins positioned
properly is now a piece of cake.
My philosphy is that there is a scale that looks something like this:
Designer -------- Builder -------- Assembler
Each time to move to the right on that scale, you spend a little less time
and a little more money. Yes, the quality of the BAC stuff is higher than
most of us can do, but that level of quality is not critical nor required
in this area. Mere mortals *can* build good solid RV wings. All you are
really doing is getting someone else to do some of the work for you. There
is nothing wrong with that, but it needs to be understood from the outset.
BEst Regards,
Dave Barnhart
rv-6 sn 23744
>of saw horse?
There are pros and cons to doing it either way.
I attached my flaps before fitting the top skin. This allows you to clamp
the flp in place (clamp the flap brace to the wing's rear spar), get it all
lined up, and then drill the flap brace to the rear spar.
By 'get it all lined up', I mean:
1. The outboard end of the flap is perfectly aligned with the inboard end
of the aileron. It should be aligned so that their bottom skins are even,
and so that their trailing edges are aligned in the fore/aft direction.
2. The inboard end of the flap is positioned vertically properly. (The
easiest way to do this is to make sure that the tooling holes in the
inboard flap rib and the inboard main wing rib for a straight line.
With the top flap skin off, you can drill the flap brace to the rear spar
while the flap is clamped in this position.
The only negative to doing it this way is that until the top skin is
riveted to the flap, the flap can flex or twist. What I did was go ahead
and drill the top skin to the flap, leave it off while getting the
flap/flap brace positioned and clamped, then pulled the hinge pin to remove
the flap, re-attached the top skin, and put the flap back in place to make
sure that I had not introduced any twist in the flap.
Best Regards,
Dave Barnhart
rv-6 sn 23744
I'm pretty sure I know what the problem is because the same thing happened
to me and it drove me nuts: The F604 bulkhead sits ON TOP OF the longerons
in the jig, while all the others nestle down in them. The F604 bulkhead
attaches to the longerons with a couple od splice plates.
The important thing about these bulkheads is that the line formed by the
tops (aircraft top) of the centers of the F606, 607, and 608 bulkheads
forms a straight line. When the aircraft is finished, that will be the top
of the 'turtledeck' and will be very visible. You want that to be nice and
straight. Conversly, no one looks at the bottom of the fuselage, so a
little lck of straightness there is not important.
Best Regards,
Dave Barnhart
rv-6 sn 23744
Let me put my $.02 in here, as this is close to what I make my living at:
>it to text for me).
>Mime-Version: 1.0
>Content-Type: text/enriched; charset=us-ascii
>Content-Transfer-Encoding: Quoted-printable
>Mime-Version: 1.0
>Mime-Version: 1.0
Ken, if you could turn off "Rich Text" or something similar, maybe that
would help. Some fancy email programs have an option similar to "strip
rich text when sending". Not all your message come through with problems,
Ken. Only once in a while. And the problem is not restricted to just your
messages, either. (I finally got fed up with the "MIME Encoding Errors"
and started tracking this problem a few days ago.)
>bit of it:
That's exactly what quoted-printable is supposed to do. MIME assumes that
the only safe email transport channel is 7-bit ASCII. MIME-aware email
programs will *encode* anything else (binary files or even
'extended-character-set ASCII') using 7-bit ASCII characters. an '=' at
the end of a line indicates a soft line break, and a '=' followed by two
hex digits represents the 8-bit octet specified by the two hex digits.
I *think* the fact that we are seeing the quoted-printable is just a red
herring. What happens to me is that Eudora will complain about a MIME
encoding error in a message and ask me if I want it to re-fetch the mesage
without doing any MIME decoding. So the Quoted-Printable shows up in the
second copy of the message, as expected.
So far, there is no consistency in where these messages are coming from.
This one was from Ken Hitchmough, but most of Ken's messages are just fine,
and not all of the faulty messages are from Ken. So far, the only common
thread is that every one of the faulty messages is MIME-encoded.
I'm going to track this over the next couple of weeks and see if I can come
to any conclusions.
(And Ken, please don't stop posting messages. It is VERY unlikely that
this problem is caused by anything at your end.)
Best Regards,
Dave Barnhart
rv-6 sn 23744
(MIME, S/MIME, PGP/MIME, and RFC 1847 expert in my other life)
Michael and Alan,
I too, was somewhat interested in the Franklin engines after
having flown in an airplane with one. It was a Stinson with the 165 hp
Franklin. It is for sure a VERY SMOOTH running engine. For the RV-8
builders, the Franklin that is currently being offered from PZL may work
out quite well if an engine mount can be built for it. For the builders
like myself (-6A) and -6's, I might agree with Van's statement of it
being too heavy (330 lbs). I don't know the weight of the IO-360
Lycoming that it's being compared with. I also don't know the weight of
an O-320. The prices Van's quotes are pretty accurate for the
PZL-Franklin. It is manufactured in Poland. The original Franklin
engines were built in Liverpool NY, just outside of Syracuse. The only
problem with the original engines, is that some parts are extremely
difficult to find these days (or nights for that matter). Also keep in
mind that the Lycoming Van is talking about is the IO-360. The
PZL-Franklin will have a carb. According to Atlas Motors, the U.S.
distributer for the PZL-Franklin engines, they will work with you for
other things such as fuel injection and installations. Maybe other
things too. Hope I haven't added any confusion to the idea of Franklin
powered RV's.
Allan Pomeroy CNY
AB6A(at)juno.com
H S Skeleton
dimensional.com!mikel(at)matronics.com writes:
>the
>(205-210
>about
>was
>USA
>knows
>Michael
>RV4 232 SQ
Subject: | Re: rv-list:Brake Fluid |
Okay. You got my curiosity up. What is the advantage of using a substitute
for brake fluid???
John Top
Phone: (619) 549-3556
Ed, I measured and eyeballed and hung my ailerons just like the book
said. After I removed my wing from the jig and placed it horizontally
on a roll away work bench I was not pleased with the fit. I reinstalled
both of them with the wing horizontal on a table and will do the same if
I build again
Chet Razer
Subject: | What have we become (Chatter) |
My apologies in advance. This is pure Chatter. Respond directly (if you must)
- no need to
further abuse the list. Due to nausea I have abbreviated where possible.
Well, I just bought a new Sears Lawn Mower. There is one page of safety warnings.
I guess it
would be humorous if it wasnt such a sad and sobering look at the kind of litigious
society we
have become. You just know every bulleted item was the result of a law-suit. You
are not going
to believe this!!! Honest, these are pure quotes!!
Reference: Craftsman Owners manual Mod. No. 917.386230, Page 2.
TRAINING:
*Never allow adults to use mower without proper instruction.
*keep the area clear of...especially small children and pets.
*Always have damage repaired before using mower.
*The blade turns when the engine is running.
PREPARATION:
*clear the area of sticks/stones etc.. they can be thrown by the blade and cause
injury.
*Dress Properly. Do not operate mower when barefoot or wearing sandals. Wear only
solid shoes
with good traction when mowing.
*clean off any spilled gasoline before starting
*Mow only in daylight...
OPERATION
*Keep your mind...on your mower. Dont get distracted.
*Do not put hands or feet under rotating parts.
*Never direct discharge of material toward bystanders
*Do not operate mower if it vibrates abnormally
*Do not run indoors. Exhaust fumes are dangerous.
WARNING:
The engine exhaust from this product contains chemicals known to the State of California
to cause
cancer, birth defects or other reproductive harm.
I wonder why Lycoming and Continental dont try more innovative and good-for-the-consumer
technologies.
Elon
elon.o(at)worldnet.att.net
Subject: | Re: Oil cooler hookup question |
<< My question is: is the 45 degree fitting the part that
the Aeroquip hose? >>
Cheryl-
I used straight S/S fittings out of the case for the outlet and the inlet and
a 45 degree fitting on the hose end attached to the outlet. Works great and
clears filter easily.
-GV
Cheryl Sanchez wrote:
> Hi,
> the Aeroquip hose?
> Thanks.
> Cheryl Sanchez
I am going to use an AN823-8 fitting in the accessory case. This should
allow a hose with a straight fitting to clear the oil filter. Where
angled fittings are necessary, I am trying to have the angle fittings in
the crankcase or accessory, rather than in the hoses. These angled pipe
thread - to - AN 37 deg flare fittings are cheaper than the angled hose
fittings. Also, hoses with angled fittings must be custom 'clocked' for
your particular installation in order to avoid twists in the installed
hose. Of course, there will always be a few cases where the angled hose
fitting is the best solution.
Blake Harral
Subject: | Re: O-360 Fuel Injection |
Glenn & Judi wrote:
> Hi,
> questions I have...
> (pump type, etc.)
> Glenn & Judi Gordon
Airflow Performance supplies fuel injection systems that will fit your
engine. I have a friend who has one of their systems in his RV-4 and is
quite satisfied. The owner is also intimately familiar with Bendix fuel
injectors (he used to work for Bendix). He provides overhaul services
for (experimental) Bendix injectors and may have overhauled units
available for sale. I don't have contact information in front of me at
the moment, perhaps someone else can post it.
I sent my RS5AD1 Bendix injector (I believe this to be an appropriate
model number for your installation) to Airflow Performance for overhaul.
I have not run the engine yet, but I was quite impressed with the work.
All replaced parts were returned. The unit was tested on a flowbench
and the test data was supplied. They even provided me with a copy of
the operator's manual.
I'm guessing it will cost $1500+ for a new or newly overhauled injection
system - not including fuel pumps. Awfully expensive IMHO, but I was
also shocked by the cost of an overhauled carb ($1000+, I think).
You will need to replace your mechanical pump with a high pressure unit.
The Bendix injectors need about 21 psi, whereas a carb needs about 6
psi. The price for the high-pressure mechanical fuel pumps is about the
same as for the low pressure ones. The electric boost pump is quite a
different story, however. The cheapest suitable electric boost pump I
have located is an Airflow Performance unit at about $300. Other
popular options are the uncertified Weldon pump (about $500-$600), or
the very expensive certified pumps (Airborne, Dukes, etc.) Compare
these figures to the $30-$50 boost pumps available for carb engines.
I have been looking for a suitable automotive electric boost pump (for
the reasons of cost and also availability in the event a replacement is
required). I have not yet had any success. The bendix manual states
that the injector is fairly insensitive to higher input pressures, I'm
guessing 35 psi would still be OK. I am told some of the automotive
injection systems use pressures up to 100 psi.
Blake Harral
I'm not receiving any RV-e,ail any more
I'm not to sure why.
please resubscribe me to the list.
John Bunn
JTB520(at)aol.com
Subject: | Re: Turn coordinator/Radio noise |
From: | wstucklen1(at)juno.com (Frederic W Stucklen) |
Cheryl:
I also had a significant amount of noise generated by the turn
coordinator. I placed a .1uF, 50VDC, ceramic disk capacitor across the
power leads inside the cannon connector and it eliminated most of the
noise. You can get the cap at Radio Shack. Be sure to mount the cap in a
manner such that it doesn't short out to the shell of the connector.
writes:
>Hi,
>hookups?
> Thanks.
>Cheryl Sanchez
As I understand the issue, the key to aviation brake fluid is not to
attract water which will freeze at the temperatures often reached at
altitude. Commonly used auto brake fluid will attract and retain
moisture and is not acceptable.
J. E. Rehler RV6A flying
>the Aeroquip hose?
Cheryl, I finally gave up trying to collect all of the parts I needed for
system installations. I ordered every AN fitting and hose that I thought
I'd possibly need and ended up ordering more on 2 or more separate
occasions. I also ended up with a lot of parts that I didn't use.
You might as well install the cooler first, then figure out your hose
runs and the types of fittings you MIGHT need. I found that once you
start plumbing, the ideas you had don't always pan out. I mounted my
cooler on the firewall and used 2 90's on the cooler, a straight fitting
and a 45 on the engine, and all hoses had straight fittings. (the angled
hose fittings are VERY expensive, don't use them unless you must.
I also used a suggestion on the list and used industrial (as opposed to
aircraft) Aeroquip hose. Same or better specs, and a LOT cheaper. Very
chic blue cover too. I believe the designation is FC300. I found a
local supplier, and I just ran over there every time I needed something
else. It saved me a ton in shipping.
Have fun,
ebundy(at)juno.com
Listers,
For those interested, I offer the following additional
information regarding the PZL-Franklin engines. This info is from what
apparently is a brochure from Atlas Motors, the U.S. distributer of
these engines. (I received this info package from another gentleman.)
The RVator talks of a 220 hp 6 cylinder engine. This brochure in one
place refers to the same thing, in another place, the spec sheet, it
talks of a 205 hp engine. I'm assuming they (Atlas Motors) are talking
of the same engine here. The 6 cylinder is a 350 cu. in. engine rated at
205 + 5% hp at 2800 rpm. I'm not sure what they mean by the "+5%". This
engine has 10.5 to 1 compression ratio which requires 100 octane fuel.
They say that on special request, you can order this engine with the
four cylinder pistons, which are 8.5 to 1 C.R. This will allow the use
of 87 octane fuel, but the engine is "derated" to about 180 hp (within
Van's recommendation of under 200 hp). They say the EGT rises and the
fuel burned per horse power increases by about 25%. If using a fixed
pitch prop, they also recommend using a different camshaft.
For the RV-3 builders, PZl-Franklin has a 4 cylinder that puts
out 116 hp. The reverse can be done to that engine also. The 6 cylinder
pistons can be put into that engine and you get about 142 hp. But with
those being a higher compression ratio piston, you get a rougher running
engine at low rpm.
For those of you that are really interested in using Franklin
engines in your RV's, I would suggest letting Van know. The RVator
stated that Atlas claimed there was a large interest while Van's has not
heard many questions regarding it.
Allan Pomeroy CNY
AB6A(at)juno.com
-6A H S Skeleton
Try to use straight fittings where ever you can.
The 45 or 90 degree fittings are a pain, because if the fitting is
not tight enough in the desired position, then you must go one more full
turn and sometimes that is too much and you risk twisting it off or
stripping the threads.
In many cases, putting the 45 or 90 on the hose is better as long as
you have a straight fitting on the other end of the hose. This way you
can rotate the hose fitting as needed to clear and then tighten up the
hose fitting.
A little hard to explain, but you will see...
Herman
> > Hi,
> > the Aeroquip hose?
> > Thanks.
> > Cheryl Sanchez
> Regards,
> Blake Harral
Subject: | Re: control cables, oil pressure fittings |
Just drill out the hole in the bug nut a little larger to accept the .075
wire. A 10/32 screw will still have enough material left to handle this.
Remember, on the bug nut, the bolt must be LOOSE on the mixture arm so
it can move. The nut must just snug up on the wire. You can ben the end
of the wire some as a safety.
Herman
> Bill Boyd -- RV-6A
WOW!
What do those poor folks in Montana do??
Or Nebraska??
Or .....
hal
Regarding the BAC components:
Correct me if I am wrong, I recall the complete BAC package costing on the
order of $4.5K. It seems the quickbuild's $8K premium (over the std. kit)
vs. BAC's premium offers much more value.
I think my airframe will be *completed* at the 350-400 hour mark (and I'm a
slowwwww builder), does BAC even save that amount of time?
The QB has no beautifully anodized parts, but there's a top skin and paint
covering them all up anyway so does that matter? A safe, corrosion
protected structure underneath in both cases.
I think both the standard and quickbuild kits provide outstanding values
depending on an individuals time/money ratio...the BAC kit not enough
bang/buck. Just my $0.02...
Rob Acker / r.acker(at)ix.netcom.com / RV-6Q project:
http://ourworld.compuserve.com/homepages/rob_acker
(last update 12/23/96 - Oshkosh '96 RV pictures)
>I think I will use Van's method on the right wing.
>Steve Soule
Ha!...which one of Van's methods ? What I did (sorry listers for the
long post, but this was a real sticky part for me and hopefully it helps
others):
1) Used the female templates only for holding things in place while I lined
things up properly. They did not match my wing at all.
2) Mounted aileron brackets on ailerons located exactly as per plans with
#30 holes/clecoes (provides some margin for error if things don't line up,
drill out to #12 later).
3) Located outboard aileron mount exactly as per plan, temporarily clamped
in place.
4) Temporarily clamped inboard aileron mount in position, mounted aileron
with all associated spacers/washers/bearings. I had to move the inboard
mount 1/8" from plans position to fit the aileron length perfectly.
5) Locked aileron into neutral position via pinned bellcrank. Checked
outboard end inline with tooling hole chord line. Used flexible rule laid
along every rib extended to aileron, top and bottom of wing, to assure
inboard end of aileron aligned correctly.
6) Drilled/clecoed inboard and outboard mounts in place (using four #40
holes for each, again providing some room for error later if needed).
7) Temporarily clamped flap in place on rear skin at both ends. Set flap
t.e. exactly in line with aileron t.e. Assured aileron/flap joint alignment
by using three "clecoe clamps" on top skins at joint (most visible) as
outlined in 16 years of RVator.
8) Used a taught string drawn from outboard aileron to inboard flap t.e.,
to accurately locate flap t.e. at wing root. Double checked flap position
with string, flexible rule, and tooling hole chord line. Drilled flap hinge
in place.
9) Removed flap, drilled flap brace to hinge, remounted as an assembly and
aligned as in step 8. Drilled flap brace to spar at root and outboard ends.
Removed flap, clecoed flap brace back into position on hinge line and these
two holes (this assures the rear skin is in the proper position at both ends
of the flap brace).
10) Used straight steel bar clamped to rear skin to force it into proper
position along entire span. Drilled a hole in the middle of the flap
brace/rear spar, clecoed. Remounted flap to assure everything was in
position. Remove flap, drill remaining flap brace/rear spar holes.
11) Mounted aileron and flap, rechecked alignment (whew...it lined up!),
finish drill all flap/aileron holes.
Everything on my quickbuild seems to be +/- 1/8" from plans everywhere so I
have to "eyeball" some things in place, regardless of what the plumb lines
and squares say. So far the naked eye can't tell, and hopefully the flight
controls and airspeed indicator won't either .
snipped
There's a Globe Swift flying with one & most Swifters say it's the fastest
Swift short of the LoPresti prototype (includes lots of Lyc 200's & Cont 210's).
From: | Scott Johnson <rvgasj(at)popmail.mcs.net> |
Subject: | I hate to admit what I did with my new RV6A yesterday ... |
Well I have 11 hours on my RV6A since it was given an airworthiness
certificate last week.
As I was flying along in my large 25 mile test area the other day, a
beautifully painted shiny Piper Arrow went zinging by me in the opposite
direction. I couldn't help noticing how sleek and fast that Arrow looked
with its retractable wheels up in the wings. Well, I am not sure why I did
this, and I hate even to admit it to this group, but I did a 180 degree turn
and firewalled my 6A towards this Arrow on a parallel course. I was
pleasantly surprised at how quickly I caught up. As I came abreast the
Arrow about 3/4 mile out on a parallel course, I slowed down to his speed.
He saw me, and wiggled his wings. Having been previously sad that I sold a
similar Piper years ago, thinking I would never have as good a plane again,
I realized how my 6A was significantly better than that Piper for my needs.
I also realized how fast an RV6A is compared to most general aviation
aircraft. I especially noticed this when going by Cessna 172's and Warriors
like their standing still.
Whats really incredible though, shortly after takeoff, I am climbing twice
as fast as the popular spam cams, and climbing at a speed faster than their
cruise speed (1,300 FPM @ 145 MPH). Match this with a stall speed of 50 MPH
and I now know what VAN means by Total Performance ! Also, the visibility of
the tip up canopy and control feel are unmatched on anything else I have flown.
Yes ... all the long hours were worth it !
Looking forward to being released out of my large 25 mile test area in 29
hours ...
Scott Johnson / Chicago
rvgasj(at)mcs.com
Project Status: I wonder if VAN will give a second time builder a discount
on an RV-8 ?
> HOPE)
Can I use automotive brake fluid?
Why not just use aircraft hydraulic fluid? I have had other people ask
me this question and this is the question I always answer with.
MIL-H-5606 is not expensive, will not eat or swell seals, is not
corrosive, will not remove paint, won't attack your skin, etc. It is
what your system was designed to use. It works... very well. Why use
that automotive junk -some if not most of which has the negative
properties above?
Scott
N4ZW
A&P CFII etc.
Cheryl,
A lot of radio noise will disappear when the engine is started and the
alternator is putting out 14 volts or so. I had an Icom wired up into the
electrical system and the intercom system and it had noise until the
engine/alternator was started. The turn coordinator doesn't need a shielded
wire. I would wait and see if you still have noise after you crank up the
engine.
Dave D
Subject: | Deft primer 44GN11 |
TO: Michael Angiulo
I have a 1 gallon kit of Deft primer 44GN11. date mfgd: 12/96 ex
09/97
The next batch I will have will not be available from Deft until the
second week in March. If you would like to purchase this last kit please
give me a call. The price is $110 plus S/H for the l gallon kit./Quart
kits $38 plus S/H
Danny White AIRLINK 407 2238915
Mmdf-Warning: Parse error in original version of preceding line at relay-7.mail.demon.net
From: | Rob Hatwell <hatters(at)overvne.demon.co.uk> |
NZ builders on the list
There are a couple of questions that I would like to know the answers to
in relation to NZ permits for homebuilts.
1. Do you have a separate category of certificate of airworthiness for
homebuilts or are they the same as say for a cessna.
2. If the C of A's are different what are the differences.
3. Do you have any problems with the crank shaft AD.
4. Can you set up a homebuilt to fly IFR or are they restricted to VFR.
5. What are the inspection procedures for getting a permit.
Reasons for questions.
I might end up back in NZ at some time and it could be before I finish
the RV8
All the best
Rob Hatwell
Subject: | Re: I hate to admit what I did with my new RV6A yesterday ... |
Boy, I hate it when people brag! :-) I can't wait to get there!
Jim Sears
RV-6A #22220 (Fuse jig built. About to start building fuse.)
AA5A Cheetah N26276
Subject: | Parts for Desoutter drill |
G'day
I am fairly new to the list but a friend of mine ( Kieth Ellis RV-4,
VH-KME ) is in need of assistance and I thought it would be the ideal chance
for me to try it. He has a Desoutter angle drill which has broken the shaft
that the collet screws into. I would like to know of any mail order parts
suppliers that might have this part, preferably with an e-mail address.
Thanks David Peck, SAAA TC & RV-6A dreamer
dpeck(at)ozemail.com.au
Someone asks:
And a certified A&P answers:
I agree. It *is* an aircraft standard.
But then the certified A&P says:
>Why use that automotive junk -some if not most of which has the negative
> properties above?
I have to ask for evidence that R3 or better automotive brake fluid is junk.
The stuff is used in some very expensive machines whose brakes suffer
considerably more strenuous duty than airplane brakes. They get into lotsa
water. Then there's the extreme heat in the case of 18 wheelers in Arizona's
Rockies in the summer and the numbing cold of Montana's in the winter.
Hal Kempthorne halk(at)sybase.com Santa Clara, CA. (SJC)
Debonair N6134V A zillion RV-6AQ parts in the "hangar" we call home.
> RV-List message posted by: Herman Dierks
> wire.
Herman: thanks for your input; I guess I wasn't clear. I'm not using a bug
nut (at least not yet). I have the fancy pin-vise gizmo that Van sells to
make the transition from cable to threaded end and it flat out won't accept
this larger diameter wire. A bug nut might be the best option, but not as
slick as the pin-vise (if it worked).
And this just in from Randall:
>all it takes is to undo the top
>engine mounts (or maybe even just the one on the side where the oil
>fitting is) and let the thing drop forward a bit and you can install
>the fitting.
Randall- I'm hoping that won't be necessary! The mounts aren't that easy to
re-align once they pop into their uncompressed position. Using my former
technique, I would have to remove all 4 bolts (or at least 3) and start over
with the top mounts first,then the bottom ones using the Tri-State Wing
Newsletter nifty alignment tool. Possible but not fun- and all for such a
tiny little pipe fitting! I'm still hoping for an easier way out.
Re-torquing all those mount bolts from the wrong end again- Ugh!
Subject: | Re: Cowling question: |
I'm going to start my cowl fitting any day now (once I finish the endless
fiberglassing phase I seem to be stuck [pun alert] in now; anyone else have
to split the front of the nose gear fairing to get it to fit on the rear
half?!)
I plan to do the cowl attach hardware per plans and by the book; no fancy
fasteners. How many vote for doing the top half first and how many for
working from the bottom up? I've seen arguments both ways. Feel free to
respond off-list. I know it's a sort-of no right or wrong answers kind of
question. Your input may give me the push I need to start drilling holes in
one of the last remaining loose parts of my kit.
Bill Boyd
Subject: | Re: Parts for Desoutter drill |
David, you might try U.S. Industrial Tool
web page.....www.ustool.com
E-mail.........info(at)ustool.com
Chris Brooks
Subject: | Re: I hate to admit what I did with my new RV6A |
yesterday ...
>..... Having been previously sad that I sold a
>rvgasj(at)mcs.com
>on an RV-8 ?
Scott, You betcha. Once you finish and fly an RV we are waiting for the
next order to come in. I think it has something to do with the blood
brother ritual you went through when you cut yourself on the aluminum. I
have noticed that I have a thing for drill bits. Just can't pass up a good
deal on bits. Must be a result of one of the times the #30 or #40 drill bit
went through my finger while holding the back side of a longeron while
drilling through from the outside.
I would guess that between 10 and 20% of the current builders are "repeat
offenders". We love ya. Bill
PS: I think the spouses realize they get to watch their choice of TV
programs if you are out in the garage building. That is the real reason
they encourage you to build again.
Bill N894RV with over 400 hours behind a O-320, Over
1000 RV flying hours. RV-4-180 soon.
These opinions are mine and do not necessarily represent the opinions or
position of my employer.
Subject: | engine mounting made easy (well, easier) |
(I don't think this made it to the list, so I'm resending it 3 weeks
later...)
Listers: having just completed the task of hanging the O-320 on the nose of
my -6A, I can vouch for the effectiveness of a simple little tool depicted in
last years Tri-State Wing Newsletter (contact jamescone@aol to subscribe.
James: where is my first 97 issue?!) Basically the tool is a hardware store
7/16ths bolt cut off and turned down to a bullet shape to be used as a guide
to align the Barry mounts with the ears on the engine case as the mount bolts
are tapped home. Without this or similar tool the job is most difficult;
with it, one man can do it with ease. Use a shop crane (engine hoist,
"cherry picker") for max flexibility in holding the engine in place while you
work. The first two (upper) bolts go in rather easily without any alignment
tool needed. For the bottom two, the tool will prove its worth!
There are two things underemphasized or omitted in the article which you
should know, however. First, there is a lot of shear on the alignment tool
as it is tapped into the holes by the mounting bolt behind it. A brisk tap
is required to seat the tip of the AN bolt into the bore of the crankcase
mounting ear in one rapid motion as the alignment tool clears the last of the
Barry mount structure. If this is not done quickly, the parts will spring
instantly back to their resting, nonaligned position and your efforts to seat
the bolt will only bugger-up the bolt or the ear. To hold the bolt's nose in
position, it is necessary to relieve the base of the alignment tool in
concave fashion at least 1/16th in. depth, with rather sharp edges, so the
bolt can't wander sideways behind the "bullet" tool. This is essential. A
Dremel tool with rouond burr will work if no lathe is handy. Likewise the
profile shaping can all be done with grindstone and Scotchbrite wheel. Give
it a nice ogive (bullet nose) shape so it won't scratch things up too much.
Secondly, as I learned the hard way, although the tool in the newsletter
is shown alongside a rule indicating a length of almost 3in., it will not
clear the base of the dipstick/oil-fill mounting boss on the lower right side
of the O-320 crankcase unless shortened to a max length of 1-1/2 inches!!
Failure to observe this max length may result in a cracked case or at least
a jammed alignment tool requiring removal of the other three mount bolts to
retrieve it, or careful surgery with a cutoff wheel on a long extension (I
chose the latter and got away with it. You do NOT want to do this.)
At 1-1/2 in. by 7/16th in, the tool looks just like a silver bullet for
a .50 cal Browning machine gun. Very formidable. Just imagine 8 streams of
these things ripping through a Me-109 in the sights of a Thunderbolt at 2500
fps and you will understand why gun camera footage shows so much exploding
debris!
Hope this helps. Do it right and you won't have to pester your neighbor
or wife to help horse the engine into its mounts :-)
Bill Boyd
Both will work, but the 45 degree hose fitting is a lot more expensive than
the 45 degre AN part.
Bruce Patton
barely ahead of you
Rob,
Some more thoughts on the various options:
BAC's kit will make your $3500 wings $8000 wings. It has no impact
on the rest of the airplane. But there isn't a QB kit from VANS for
the RV3, RV4, RV8 or the Rocket II. Maybe the QB RV6 is a better
deal - seems to be, IF that is the plane you want to build.
I figure it is saving me several hundred hours (probably a year of my
building time) on my wings. My plane will still take me years to
build.
You're absoultly right.
The BAC kit is great value for what it is. For my project it is the
only option, and it is working out great. If I were building a 6,
I'd be rowing the same boat you are. I think we both made good
choices. The market is obviously wanting more work pre-built,
otherwise Van wouldn't be offering it and neither would all the other
sucessful kit companies. Van's standard kit keeps the "cheap" option
open for those who want to invest a bit (lot) more sweat equity. I
just wish Vans would go back and clean up the plans where we continue
to read that there are errors or could use clarification. More
photos and language in the assembly manual would eliminate hundreds
of hours of head scratching!
Aloha,
Russ Werner
Maui Hawaii USA
mailto:russ(at)maui.net sends to me
mailto:RV-List(at)matronics.com sends to the RV List
Subject: | Building wings - sequence |
I am looking for opinions on what to build/drill in what order. The
items in question are:
1. Outboard leading edge skin
2. Fuel tank
3. Top Skins
4. Bottom Skins
An RV6 builder locally (he has PP skins) is doing it in the above
order. I seem to read that 3,4,1,2, is better/more common/in the
instructions/in Hovan's directions. Any ideas here?
Another question for those who have been there: What tool did you use
on the gun to back-rivet the top skins (assuming you back-riveted
them)?
Aloha,
Russ Werner
Maui Hawaii USA
Hal,
18 wheelers do not use brake fluid. They use an air brake system.
And if they're going over the Rockies, they should have an engine brake
also, or a very large life insurance policy.
Allan Pomeroy CNY
AB6A(at)juno.com
<< As I understand the issue, the key to aviation brake fluid is not to
moisture and is not acceptable. >>
The original post said nothing about using auto brake fluid. Please read the
posts more carefully. He asked if automatic transmission fluid could be used
in lieu of MIL-H-5606 hydraulic brake fluid.
Who cares if it could be? The right stuff is cheap, why sub?
-GV
Subject: | Re: Building wings - sequence |
>2. Fuel tank
>3. Top Skins
>4. Bottom Skins
I did 3,4,1,2 per the manual. I understood that the reason was that by
installing the Top and Bottom Skins the wing structure was stronger and
would be better (stiffer) for pulling the outboard leading edge skin into
position with cargo straps.
Next time I will do 1,3,4,2 because the fit of the aft leading edge joint
to the top and bottom skins can be easily done by pushing the top and
bottom skins up tightly to the clecoed leading edge. Any tolerance stack
up occurs at the trailing edge where it can be trimmed. Van's should leave
the pre punched holes off the trailing edge of the top and bottom skins so
any trimming of the trailing edge does not cause an edge distance problem.
It is easy to mark and drill this one line of rivet holes.
Bob Haan
bobh(at)cdac.com
Portland, OR
503-636-3550
I went the 1 2 3 4 route you mentioned and it seems to work out quite well.
In fact I havn't yet fitted the bottom skins as they go on later after
initial fitting of wings to fuselage. I will probably pop rivet the bottom
skins on as this is the way of my French Guru, Michel Jaoul. We tend to
think that a pop rivet is more reliable than using a standard rivet which
you can not visually inspect.
I back riveted the top part of the Outboard Leading edge skins. This was an
idea someone on the list came up with a few months ago I tried it and it
worked ok for me.
Averys sells a long bent tool that goes in the rivet gun for back riveting.
Barry Ward ward(at)axime.com working on ailerons.
>2. Fuel tank
>3. Top Skins
>4. Bottom Skins
Phil,
I'll bet the extra parts that were included in your wing kit were W 425 R&L,
two each. I called Van's last week and was told that these were RV-4 parts,
and were
sent in error. So... I'm returning them to Van's.
I also got confused when the revision page that was included with the wing
kit stipulated the use of AA3 3/4 X 3/4 X 17 aluminum angle. According to the
parts numbering system Van's uses, this would be 2024 T3 aluminum angle. The
only thing I did have included was a piece of 6061 T6 that was of the same
physical dimension... So I called Van's and was told by Bill Benedict the
part was indeed supposed to be 6061 T6, the revision sheet was incorrect, and
that no 2024 T3 aluminum angle of that dimension was used in the entire
aircraft. Concerned about the mixup, Bill said that he was going to correct
the revision sheet right away.
I was also missing the 4 steel aileron bellcrank brackets (823PP?) These were
promptly shipped by Van's at no cost. When you consider the number of
components included with the wing kit, it is amazing what few errors there
were. Everything is first class... especially the long awaited spars. One
local RV-6 builder who has seen and helped on my project says: "I'm buying an
RV-8" All he has to do is convince his bride to be as to the prudence of such
as decision...
Anyone going with capacitance fuel senders?
Jon Ross - RV-80094 Starting on wings...
Yes, 3% off all subsequent projects.
Subject: | Alternative Engines, was Franklin Engines |
On the subject of Van's engine recommendations for engines,
it occurs to me that perhaps the excellent discount Van offers
on Lycomings somehow involves Lycoming being the primary/only
engine "officially recommended".
Not trying to imply anything underhanded, mind you; it's just
my impression that a lot of distribution agreements work that
way.
Henry Bibb
RV builder wanna-be
writes:
>Cheryl,
the
the
shielded
the
>engine.
>Dave D
Dave,
I have to take exception to this. If the noise is present while
running on just a battery, it will also be present while running on a
charging battery, only masked by other noise (alternator whine, ignition
noises). Never the less, the noise is still there. What you are probably
hearing in your system is the summation of all wiring noise. While this
level of noise in some installations is acceptable, it may not be in
others. Our approach to building up an instrument panel should always be
to identify potential noise sources, and be knowledgable in methods of
their elimination.
While the turn coordinator noise may not be significant, its
elimination, and the elimination of other noise sources (alternator
whine) will increase all your radios receiver sensitivity (ie, its
ability to receive lower level signals). By isolating and elimination of
noise sources, you should see better comm receiver performance, and
maybe less noise (as perceived by those listening) when transmitting.
I didn't use a shielded wire on my turn coordinator either. But adding
the cap across its supply input allowed for the "noise" to be contained
in the instrument itself, and not out into the wiring harness where it
could easily be coupled into other radios. I also installed a filter
(rated at 70 Amps) on the alternator output to eliminate its whine (which
increased the ADF's receive range and eliminated comm transmission
noise).
One way to test for alternator noise while flying is to open the
squelch on you comm radio while on an open frequency. Switch you
alternator field ON/OFF and note the difference in the noise level. Also
run the same check on an ADF if you have one. (Do this while listening to
a distant station.) The ADF will be more susceptible to the alternator
noise.
Another check easily performed is having someone close listen to you
comm transmissions while your flying. Sometimes alternator whine can be
heard by them if you have a problem.
Another important item is the transponder antenna location relative to
any ignition noise souces. Sometimes, a noisy mag or ignition lead will
cause the transponder to transmit randomly without prompting from an ATC
radar. While ATC radars seem to be capable of handling this to some
extent, what would they say if we all had the problem? Better to keep the
transponder antenna away from the engine compartment/firewall (while
keeping its lead as short as possible).
Sorry to get so long winded.....
Fred Stucklen RV-6A N925RV
Oops...guess I should have made myself clearer, my message was directed
towards those considering a std, BAC, or QB RV-6.
>I just wish Vans would go back and clean up the plans where we continue
DITTO! I have the utmost respect for those completing the std kit, I have
enough troubles getting through the plans on the QB . The next one will
be a std kit since I already have something to fly (what I am waiting for is
an RV-8 with a smoother, cheaper O-540 option).
Subject: | Credit due to Flightcom. |
I decided to use the Flightcom Intercom unit, as it is so small, and does
everything I require, but I seemed to make heavy weather out of fitting it.
There is a standard 25 pin plug, the type for computers, and I tried to
solder all the required leads using a soldering iron which was too large,
and too hot.
Next I checked each lead was to the right pin about ten times. I should have
checked eleven times, as the 12v was on the wrong pin. It only took me four
or five hours to work that out. Next the intercom still did not work. It was
too loud on the passenger side, and not loud enough on the pilot side..
Getting frustrated by now, I called customer service at Flightcom.
They were most helpful, and offered to have the unit back. They checked it
over, and sent it back overnight courier at their expense, even though the
problem was clearly my fault.
On re-assembly, it still did not work, and I found the solution. When I
mounted the socket for the transmit plug, one of the "lugs" was touching the
aircraft panel, and shorting it out.
Now, despite the abuse, the unit works extremely well.
Summary :
1. Use the right equipment, in this case the right soldering iron.
2. Engage brain before starting work.
John C-GDOC, almosr ready to paint.
RIDER Magazine (a magazine for us two wheel types) did an excellent article
on brake fluid (automotive type) about six months ago. Try to find it if you
can.
I was amazed how much water the fluid DOT 3 will absorb.
Gary Corde
RV-6 N211GC - NJ
Subject: | Re: Missing Parts |
>Regards,
Jon,
Besides your original concern about the longevity of the capacitance
senders, remember that they will be installed through all the bays.
Probably from the outboard top slanting to the inboard rear end for the most
accuracy. That alignment, while possible, won't be that easy. If you are
still planning on flop tubes, the capacitance senders will have to end in
the next to the last bay on the root end. Overall, I found the floats from
Van's to be easy to install. IMHO, if you are planning on installing a fuel
flow/ totalizer, I see no reason to incur the additional expense and trouble
with the capacitance senders.
Hope this helps.
Scott Gesele (N506RV- It WILL fly this Spring)
>to respond off-list. I know it's a sort-of no right or wrong answers
>kind of question. Your input may give me the push I need to start
drilling
>holes in one of the last remaining loose parts of my kit.
HI Bill. I would definitely recommend starting with the top first. The
first half is easier to fit than the second half (more places to fit) and
by doing the top first, gravity will help keep it there rather than
hinder.
Getting the alignment with the spinner is the a tricky area, and by
installing the top first, you can cleco a small tab onto the front top of
the cowl and rest the tab on the spinner backplate. Then you can adjust
the tab for the proper spinner/cowl line height. (Don't forget to allow
for the thickness of the spinner fiberglass) I installed my spinner
about 3/8" higher than the cowl. In the 60 hours I've put on the
airplane, the spinner has come down a about 11/32". The fit is perfect
unless you really get in there and look, and the extra 1/32" is in the
bank if it settles more. That part is a black art, I know people that
had settling anywhere from 0 (if the engine was installed for a long
time) to 1/4". Caveat Emptor (let the installer beware).
Ed Bundy RV6A N427EM first flight 11/20/96
ebundy(at)juno.com
easy to
>former technique, I would have to remove all 4 bolts (or at least 3) and
>start over with the top mounts first,then the bottom ones using the
Tri-State
>Wing Newsletter nifty alignment tool. Possible but not fun- and all for
>such a tiny little pipe fitting! I'm still hoping for an easier way
out.
I don't have my airplane in front of me right now, and I forgot to
install the fitting first also, but I'm pretty sure I was able to put in
a straight fitting after the engine was installed. I used a steel
pipe-to-flare fitting with the hole soldered up and a #60 hole drilled
through the solder for a restrictor. I then ran an Aeroquip hose to a
sender mounted on the firewall.
It is possible I may have installed the fitting when I removed the engine
mounts... I had the engine all mounted, torqued and happy when I noticed
that I had installed the lower Barry mounts upside-down! AAAARRRGGH! I
triple-checked the orientation of the mounts when I installed them, and
STILL managed to install the bottom ones wrong. Ugh.
ebundy(at)juno.com
Subject: | Re: Alternative Engines, was Franklin Engines |
>way.
Actually, I think it probably has something to do with the fact that
Van's moves more 0-320's and 0-360's than anyone on the planet. It's
like anything else; if you sell a whole bunch of Corn Flakes, you'll get
a big discount from Kelloggs.
ebundy(at)juno.com
> ebundy(at)juno.com
Van's price is the standard OEM discount offered to any Mfg.
Chris
cruble(at)cisco.com
Fred, The instructions on my PMC 2000 said that the 14 volts would get rid of
any noise that I had by just running on the battery. In my case, they were
right. All of the noise did go away. I'm not saying that this will work in
all cases, but just wanted to point out that this may be a possibility since
most avionics are designed for 14 volts, not 12. I'm mot an expert on the
subject, just offering my experiences.
Dave D
> way.
> Henry Bibb
> RV builder wanna-be
I agree with the above statement. I don't believe RV builders would be
getting as good as deal on their new engines if Van's was recommending
anything else. And that's a great deal for the majority of builders.
I think us "Alternative Engine Guys" are going to be on our own. That's
part of the fun of building experimental aircraft.
Ernesto Sanchez
RV-6 with Alum Buick V-8 maybe ??
es12043(at)utech.net
The instructions on my intercom , PMC2000, said that when the voltage goes up
to 14 volts, the noise would go away, and in my case it did. I'm not say
From: | Owens(at)aerovironment.com (Owens, Laird) |
>Phil,
>Regards,
Jon,
I'm using the Skysports capacitance probes with Mitchell gauges. I mounted
them off the rear baffle, in the bay just outside the inverted pickup. The
installation worked out very nicely.
Laird owens(at)aerovironment.com
RV-6 22923, hanging the ailerons and flaps (fuselage kit waiting attention)
Subject: | Re:Turn coordinator/Radio noise |
I missed most of the original posts on this subject....but I'll be glad to
answer a question that I didn't even hear:).
If you have a battery charger connected to a battery while you are testing
equipment in your RV you will get a lot of noise from the conversion of AC to
DC. When I first installed my Navaid A/P I sent it back to Doug because it
seemed to be all out of wack (ground testing in my garage). The Navaid people
called me at home to let me know that the head unit bench-tested fine. I
said "no way" something has to be wrong. Then they asked what I was using
for a power source and I told them my charger.
Problem Solved.
Next Point. Every piece of avionics I have in my RV uses one common ground
location. This reduces the possibility of noise. If you have multiple
ground points it can be hard to isolate the problem. My common point is
where the longerons meet the firewall. This gave all of my grounds the
shortest wire length.
My avionics are wisper quiet.
Gary Corde
RV-6 N211GC - NJ
Subject: | Rod End Lubrication |
Should the rod end bearing surfaces be lubricated on the control rods and
flaps ? If they were lubricated , will this collect dirt and lead to more
wear?
Tony Partain
N17PT RV-4
From: | John Morrissey <John.Morrissey(at)its.csiro.au> |
Hi Russ,
I built my first wing using the "Vans instruction's" way and my second
using the "Hovan's directions" method. I found the second method to be a
bit easier, especially in lining everything up. The main difference is you
will find it a lot easier fitting the nose section as it is basically
pulled down to contact the edge of the top and bottom skins.
I vote for the second method!!
John Morrissey
Awaiting the arrival of the fuse and finishing kits.
>2. Fuel tank
>3. Top Skins
>4. Bottom Skins
>them)?
>Aloha,
>Russ Werner
>Maui Hawaii USA
John Morrissey
CSIRO ITS
Data Communications Manager
Phone:- 06 2766811
Fax:- 06 2766617
Mobile:- 018 628804
Email:- John.Morrissey(at)its.csiro.au
CSIRO ---- AUSTRALIA'S SCIENCE, AUSTRALIA'S FUTURE!
From: | Cheryl Sanchez <csanchez(at)BayNetworks.COM> |
Just to clarify things a bit. I have a power supply that will put
out up to about 20 amps at 13.4 volts. This is what I am using, not
a battery. I am doing this in my home on a table. With my handheld
radio on, I can hear the turn coordinator spinning up. If I pull the
fuse for it the radio is instantly clear.
Cheryl Sanchez
csanchez(at)world.std.com
Attention listers!
The latest revision of the RV Builder's Yeller Pages is available at:
http://www.sound.net/~hartmann/yelrpage.htm
For your convenience, this edition includes links to the entities with
either web pages or e-mail addresses. Thanks to Gary VanRemortel for the list.
- Mike
hartmann(at)sound.net
Subject: | Re: engine mounting made easy (well, easier) |
A few comments to add to this. I came up with this same idea on my
own and later saw it in Sport Aviation and several other places.
I knew the long version they showed would cause problems.
You want to grind the the rounded shape on the end of the bolt BEFORE
you cut it off. Also, it only needs to be about 1/2 inch long.
This is just enought to get the two parts to allign and short enough
to fall out the other side when the bolt is driven through.
You can also do this with the engine laying on the floor (on an old
tire, upside down). Then you just picke up the entire assembly and
slip in the 4 bolts that bolt the engine to the firewall.
I did one this way and it worked fine.
You can also do it with a hoist while it goes onto the plane as the
note below suggests.
I have done two engines by myself so this device makes it a simple
one person operation. I have heard of others that took 4 adults
to get the mount on.
Herman
> later...)
> debris!
> Bill Boyd
From: | Mike Kukulski <kukulski(at)highfiber.com> |
Re:
of
my -6A, I can vouch for the effectiveness of a simple little tool...
This is not intended to deride another engine mounting method that
evidently has proven successful for many others, but examine your
situation and determine whether Tony Bingelis' recommended method isn't
easier for you.
Specifically, first bolt the engine mount to the engine while the engine
is in a storage cradle or hanging from the hoist. Then bolt the engine
mount to the firewall.
I just did this two weeks ago on my RV-4. Engine mount attached by just
myself in under one hour with no problems at all. (You align the
approximately 10 lb (?) mount to the engine vice the 300+ lb engine to a
stationary mount.) A friend (Dan Boudro from this list) happened to stop
by and help bolt the mount/engine assembly to the firewall and then
install the gear legs (wheels already installed on legs). Lowered the
fuselage/engine combo off the hoist onto the wheels. Dan's help was
welcome, but the job could easily have been done solo.
By the way, the Ordnorff video was also helpful regarding bolt and nut
tightening sequence even with this method.
Result, engine mounted and airplane on gear in a few hours.
Mike Kukulski
RV-4 N96MK
Albuquerque, NM
Russ, I'm ' where you are now, riveting the top skins on both wings at
the same time. Also just finished my fuselage jig and ordered that kit. I
get it in June.
I ordered that backrivet tool, you talk about, for the rivet gun from
averys. Great tool supplier by the way. My daughter and I started with
me doing the back riveting and her the bucker. I had bad results and am
redoing about 50 rivets. I switched to her riveting on the top with the
head that has the rubber bumper on it, while I bucked on the bottom.
perfect rivets.
Two things tho., I used an old rusty huge bucking bar I got at the
flymart in Oshkosh last summer for $5 and polished up.
The other thing is, that I placed 50% of the rivets in place and covered
with a 1" piece of electricians tape. Result, no (none) scratches to the
skin.
Some of those rivets that I'm removing were because I flattened them to
much. I went to the next size rivet. That may be the reason I had a hard
time with the Avery tool. However the Avery tool made some marks on the
rib too. If I had stuck it out longer I might have gotten the hang of
it. But I decided to stop at fifty bad rivets. Ha.
I'm going to get the fuselage ready to come out of the jig before I close
the wings up. That way I can have tech counselor over to look at both at
the same time.
Cecil Hatfield
Thousand Oaks, California
RV-6A
=Another question for those who have been there: What tool did you use
=on the gun to back-rivet the top skins (assuming you back-riveted
=them)?
=Aloha,
=Russ Werner
=Maui Hawaii USA
mailto:ru
Subject: | Pneumatic squeezer |
Anyone know the names of manufacturers of pneumatic squeezers? Chicago
pneumatic is one, any other (cheaper) makers? Rob
What are some suggestions for cleaning the grime off of the bottom of the
fuselage?
ebundy(at)juno.com
Subject: | Plastic covering |
Hi Everyone,
Nothing real serious, but I had some well intentioned help backfire on me,
and am hoping someone has an idea. After carefully explaining how I used the
sodering gun to remove plastic strips along the rivet lines, and having my
friend actually do several long lines, I later asked that he remove the
plastic strips from the side skin. Apparently he didn't hear the word
strips, or completely forgot what he had done 15 minutes earlier, but you
guessed it, he removed all of the protective plastic. Not a serious item I
know, but I am wondering if anyone is aware of a self-adhesive plastic that
would be useable to reapply?
Dick Flunker, RV-6A, Skinning Fuselage - still..
Fellow RVers,
I would have thought everyone was "lubed" by now, but the orders keep
coming in. I just emptied another can so will have to order another one
tommorrow. Hopefully, the next can will be here as fast as the last one
was. I ran out of 35 mm flim canisters so will have to round some of them
up as well. Please be patient and I'll get you covered as soon as I can.
(I need a little break so my hands can have time to heal---boy, is that
stuff thick!)
Thanks, Bob Skinner RV-6 BSkinner@navix
Dear Henry,
It is my experience that Richard Van Grunsven speaks little, carefully and
truthfully. I would be inclined to believe the reasons he gives for the
engines he recommends.
Leo Davies
6A: Trimming canopy.
>way.
>Henry Bibb
>RV builder wanna-be
Quit making us so jelous, were trying to build airplanes down here.
Frank Smidler
Subject: | Re: Rod End Lubrication |
>wear? Tony Partain N17PT RV-4
Tony,
A good question. I've wondered the same thing. Several months ago when I
was pre-flighting my RV-6, I heard noise that I suspected was rod end noise
when I moved my rudder. I gave each bearing a shot of LPS and things got
quiet. I would have thought that the lubrication in the bearing would last
a long time, especially in an airplane that is always hangered.
I think I've seen a tool that is used to lubricate rod end bearings. I'm
sure this would be the preferred method but, taking everything apart would
be a pain. I guess I'd rather chance a little wear due to the spray method
that dis-assemble my airplane. Lubrication does tend to attract dirt but
I'm thinking that with the tight clearences that a rod end bearing operates
under, maybe this dirt gets swiped off. Lubrication of piano hinges is a
different matter. I'm sure we've all seen worn piano hinge on factory
ships. By the way, I've read that WD-40 can actually be corrosive and the
article recommend CRC, instead. I used LPS 1, I believe.
Bob Skinner RV-6 BSkinner(at)navix.net
From: | William Yamokoski <wiyst1(at)vms.cis.pitt.edu> |
Subject: | Re: Pneumatic squeezer |
Rob,
I got my squeezer from Action Air Parts, Inc. It's a little
place in Port Huron, Michigan. Offers rebuilt and reconditioned
tools. I paid $289.50 for a squeezer with a 2 1/2" yolk and I've
loved every minute I get to work with it. The phone number is
810-364-5885. Call and he'll send you a small flyer with some of
their tools listed.
By the way, I'm just a lowly Glastar builder, but hey....a
squeezer's a squeezer, no matter what plane you use it on.
I answered this message on the list for the benefit of any lurkers
who are wondering about tools.
William Yamokoski
4608 Windbrook Dr.
Murrysville, PA 15668
>> way.
>> Henry Bibb
>> RV builder wanna-be
>Ernesto Sanchez
Henry and Ernesto, I've watched several postings but gotta put in my $0.02
worth. Van was a Lyc man even before he was offering engines. The fact
that we sell Lyc engines has very little to do with his statements about
alternative engines just like it has nothing to do with the pricing we get
from Lyc. I am confident that all the kit manufacturers get the same price
from Lyc. Van's just skims less off the top than the others do.
A lot of his feeling are due to the fact that there have been claims that
the 'alternative engine' has finally arrived for years, and it is still not
here running around with us on the weekends. But I am convinced that it is
out there, and it is up to you "alternative engine" types to identify and
develop it. Bill
>>Regards,
>Jon,
>Hope this helps.
Scott, I will add a comment about the fuel totalizer. Of all the
instruments Van has put on the airplanes, the fuel monitoring system
(Electronics International FP-5) is the one I use the most other than the
GPS. On the -8, I use it as a check that I am not too lean. When the
totalizer indicates I am out, I am dry. I think it is only off about 0.3
gal on a fill-up of 25 to 30 gallons. At this point, the fuel gauges
become a secondary instrument to the fuel flow totalizer. We have one of
Matts instruments in one aircraft and set the warning such that it alerts us
to switch tanks every 30 minutes on a cross country. If you have $500 to
$800 burning a hole in your pocket, a totalizer is the item to buy. Bill
I appreciate the plug that Bill Boyd gave to my newsletter and the tool that
I invented to help mount the engine. I sent the prototype of the tool to Bob
Avery and he has made some up and they are available from him. Call
1-800-652-8379 to order one. I donated this idea to the RV community and do
not get any royalties other than the satisfaction that I have helped RV'ers
mount their engines easier so that they can join me in the joys of flying
their own RV. My prototype is not 3" long, it is only about 1 1/2", as are
the ones that Avery sells. In the instruction sheet that comes with the
tool, it specifically says that your should tap the alignment tool in place
and then just before it goes into the mount, to give it a sharp rap to drive
it in with the bolt following. The tool does have to have a concave end
where the bolt pushes on the alignment tool so that the bolt can get into the
engine mount before the parts try to jump out of alignment. This tool
allowed me to get my engine mount bolts into the engine in about 15 minutes,
where before I made this, I spent more than 4 hours trying to get the last
bolt in without success. Necessity really is the mother of invention.
Jim Cone, RV-6A Flying!!!
jamescone(at)aol.com
From: | "Paul Osterman III" <PineRanch(at)msn.com> |
Russ,
The order you mentioned, top skin, bottom, leading edge & then fuel tank is
how I did it. Seemed
to work well. Riveting was LE, top skin, bottom, then (still working) fuel
tank work.
I had planned on using a 6" section of railroad track for back riveting, and
even bought the long bent rivet set Avery's sells that another lister
mentioned. Once I read the builder beware note that came with it about
possible pitfalls I ended up not back riveting. Instead I used Avery's flush
rivet set with the rubber grommet and the long skinny arms of my 13 year old
daughter to hold the bucking bar. The first top skin took a little over an
hour as I recall, but then we're not really hurrying. Enjoying the building
too much.
Paul Osterman III
RV6A-buidling ailerons and flaps
Anderson, CA
1. Outboard leading edge skin 2. Fuel tank 3. Top Skins 4. Bottom Skins
I seem to read that 3,4,1,2, is better...Any ideas here?
What tool did you use on the gun to back-rivet the top skins (assuming you
back-riveted
them)?
------ =_NextPart_000_01BC2503.4E95C8E0
If a non corrosive lubricant is used, can a 'boot' of some sort be used =
to contain the lubricant and isolate the linkage from abrasive dust and =
contamination? =20
Issues:
Accessability and maintenance of the boot.=20
Possible boot materials.
I'm just starting. Laugh gently if you must.=20
Jerry Prado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==
------ =_NextPart_000_01BC2503.4E95C8E0--
Ed, Simple Green works great and wont hurt your paint.
Ryan
Bill, I've been wondering for sometime why it is that there seems to be such
a stigma against Continental engines? I've been flying for almost 20 years
and never heard the same level of complaints with Lycoming. Perhaps it has
something to do with prehistoric engine lore. This doesn't make sense.
Mooney for example uses both engines.
The Airplane Factory
Robert/Tammie Dieck
Wausau WI USA
dieck(at)dwave.net
From: | J.Ken_Hitchmough(at)magic.ca (J.Ken Hitchmough) |
Second question: Confession--- despite having read NUMEROUS warnings not t=
o
do this, I installed my engine without first putting the oil-pressure fitti=
ng
in=21 I've read all the archive data on this subject but am unclear on one=
point: Is there any fitting that will allow installation =22as-is=22 witho=
ut any
disassembly? AN-823? AN-915? Weatherhead 45 deg street elbow? Why all t=
he
insistence that these fittings be steel or stainless??
Bill, there was quite a bit of chatter about this some time ago. I too made=
the same booboo.
My way around it was to buy a right angle brass male pipe to female pipe th=
read street fitting. Byjust filing off the corners I was just able to get t=
his in without removing engine mounts. A straight flare fitting will now fi=
t nicely into this. Another builder, David Fried did the same thing. If I r=
ecall, he undid one mount (closest to the fitting) and used a lever to push=
it away (David, please correct me if I'm wrong here).
I also believe new engines have another hole.
Ken
RV6A Flying
50 hour inspection this weekend.....yippee it'll be above zero degrees C.
This message sent using the FirstClass SMTP/NNTP Gateway for Mac OS.
<< What are some suggestions for cleaning the grime off of the bottom of the
fuselage? >>
Fellas, and ladies:
I asked a friend who has cleaned many more a/c than most of us have ever
thought we would, except for maybe some of you mil-spec types.
WD-40.
I tried it, and it's amazing. Even takes the exhaust off, which is what my
friend said it would ( that's normally the hardest part to clean). Much
better than the
Carbon-Tetrochloride my dad had me using when I was little, and didn't know
any better...
Check six!
Mark
From: | Alan Carroll <carroll(at)geology.wisc.edu> |
I bought a rebult Chicago Pneumatic 3x rivet gun and a Rockwell drill rom
AAP and have been very happy with them.
Do you know what he charges for a squeezer without a yoke?
>Rob,
Alan Carroll
RV-8 #80177 (Empenage)
Hal Kempthorne wrote:
> Someone asks:
> > properties above?
OK, so I should have probably said that if you use this stuff in your
aircraft, then the seals, etc. will be JUNK. Have fun flushing your
system and putting in the 5606 you should have used first. Automotive
fluid is GREAT -in automobiles. Incidently, I use automotive gasoline in
my low compression aircraft engine (and have for years/hundreds of
hours) with better results than 100LL -so I don't necessarily think
that if it's aviation quality it's always best for every situation.
Go ahead, Flame me! I can take it! Really.
Scott
N4ZW
(the A&P)
Subject: | Re: Plastic covering |
<< Apparently he didn't hear the word
Go to KMart and get clear plastic shelf paper, the stuff your wife uses in
the kitchen. It is self adhesive and provides great protection. It goes
on/off very easily. Before Van started putting on the protective plastic, I
did this myself for all my skins.
Bob Busick
RV-6
From: | "Larry D. Hoatson" <lhoatson(at)e2.empirenet.com> |
I've been using a solution called BIG ORANGE (Purchased at Smart &
Final). It's biodegradeable, made from citrus (and who knows what
else), and even smells good. It takes ALL the grease and grime off of
anything I've used it on. Runs about $8 a gallon, and a little bit goes
a long why. My IA started me on it, as it is non-corrosive. We used it
exclusively to bathe 45 years worth of crud out of the belly of the
C-170 project. Spray it on, wash it off!
Larry
Larry D. Hoatson Yucaipa, CA Redlands (L12) Airport
KC6WYF via packet at: KC6WYF(at)W6JBT.SOCAL.CA.USA.NOAM
Restoring 1950 Cessna 170A N9948A
Looking forward to RV-6
From: | "Robert L. Nuckolls, III" <72770.552(at)CompuServe.COM> |
Subject: | Flight System Reliability |
Aircraft Electrical Systems:
a Philosophy for Reliability
I have presented numerous forums at Oshkosh, EAA chapter meetings
and kit type gatherings around the country on the topic of electri-
cal system reliability. This is a prominent issue on most aircraft
builder's list of concerns for several reasons: First, the electri-
cal system is generally the least understood of all airplane sys-
tems. Second, some electrical system components are useful (if not
critical) to safe termination of flight during an electrical system
failure.
I will often begin a presentation with questions to the audience
about their own ideas for achieving reliable operation. It's not
surprising to find heavy emphasis on quality (cost) of components
and workmanship. Nearly every magazine on electrical system fabrica-
tion or installation will list tasks to be accomplished or mistakes
to be avoided in the interest of producing a reliable installation.
Reliability discussions often include matters of cost, convenience,
and perceptions founded on incomplete or inaccurate data. For this
article to arrive at its intended conclusion, let us agree that a
reliable flight system permits comfortable termination of flight
(preferably at the intended destination) irrespective of any single
failure of a system component.
It's easy to visualize a situation where one airplane owner is
always doing some kind of work on his airplane but seems to fly
where he wants when he wants without mishap. Contrast this with
another pilot who suffers maintenance conditions causing repairs off
his home base. Worse yet, his problems may precipitate unplanned
arrivals with the earth! These airplanes may be identical and
experience the same problems. Never-the-less, when compared with the
other, one of these aircraft might be perceived very unreliable.
I've often asked groups of pilots and builders to prioritize their
personal flight system reliability requirements. The first consen-
sus is that airframe failures of any type are not tolerable; design
goals require an airframe to withstand normal operations with an
expectation of zero failures. Airframe systems include structure,
skin, gear, flight controls, etc. Second on most everyone's list is
the power plant which would include engine, prop, fuel system,
ignition, etc. The electrical system usually comes in third. Under
electrical systems, people tend to jump on radios as "most desira-
ble."
Consider please my personal list:
I. Airframe
(1) Structure
(2) Flight Controls
(3) Flight Instruments
(a) Airspeed
(b) Turn Coord.
(c) Compass
(d) Altimeter
(e) Gyros
(f) etc.
(3) Gear
(4) etc.
II. Pilot/Builder
(1) Skills
(2) Knowledge
(3) Health
III. Power Plant
(1) Engine
(2) Prop
(3) Ignition
(4) Fuel System
(5) etc.
IV. Electrical System
(1) Battery
(2) Instrument Lights
(3) Turn Coordinator
(4) Engine Support (boost pumps . .
etc.)
(5) Nav/ILS/Comm
(6) Transponder (optional)
(7) Landing Light
(8) Alternator
(9) Position and Strobe Lights
(10) Stereo System
Note that I have added the pilot and his/her "subsystems" at II on
the list. First, consider that when everything thing else (lower on
the list) has gone belly-up, an adequately trained and proficient
pilot has an excellent chance of living to tell the grand-children a
true life, wing-and-a-prayer survival story! The pilot's tool box
must contain knowledge and skills along with a body capable of
utilizing them. Note also that electrical systems and components
thereof are a distant fourth place on the list. Other items are
conspicuous by their absence. Note that engine instrumentation and
fuel gauges are not even on the list. I know of no immediate hazard
to flight posed by failure of these kinds of devices. I do not imply
that electrical systems need not be reliable. I just want to place
them in proper perspective with respect to other flight systems.
Further, I do emphasize a pilot's very important position as a
component in the total flight system.
Your personal list may vary from mine as well it should, provided
you have a rational basis for development along different lines,
unique to your assets. One goal of this article is to suggest tools
for development of your own reliability priorities list. Accom-
plishment requires knowledge of personal needs and skills combined
with an intimate familiarity with your airplane's systems and per-
formance envelopes. This, ladies and gentlemen, is what separates
us from Pilot John Public who has become bored with scuba diving and
decides it would be nice to add flying to his recreational activi-
ties.
As builder/pilots we are permitted alternate approaches to systems
design. Powers-that-be recognize that a majority of Pilot John
Public will never be as familiar with their airplanes as you are
with yours! The inference to be drawn suggests that our personal
flight systems are automatically more reliable. I would say it's
true to a point. It's a sure bet that most of us do understand more
about airplanes than the general pilot population; after all it's
our avocation, perhaps even vocation.
Consider that most of us learned to fly in certified, production
airplanes. We are not permitted to modify these airplanes, they're
accepted as-is. Furthermore, these machines were certified under
rules giving Pilot John Public the best possible chances of survival
knowing that for some, piloting skills (from the systems viewpoint)
will not advance beyond manipulation of levers and knobs.
Since most of us learned to fly in the padded-cockpit environment,
it is possible that we bring detrimental attitudes with us into
amateur-built aviation. For example: existence of a pilot's operat-
ing handbook with mandated topics is intended to afford great com-
fort as we launch into the blue. By federal decree, everything we
must know about that airplane is between covers of the book! If you
can recite emergency procedures, performance and weight/balance
calculations in your sleep, your spouse and offspring may wave you
off wearing broad smiles. These attitudes have been mulched into
fertile soil for the plaintiff bar. "Well now, Mr. Cessna, explain
to this court and jury why you didn't . . . . ."
The most important attribute to be cultivated in amateur built
aviation is the ability to think beyond the present in considering
all "what-if?" scenarios. Yeah, I know, as students we were all
admonished to "stay ahead of the airplane," that's not what I'm
talking about. What-if's I am considering relate to pieces and
parts of the airplane. For example: when building, modifying or
just maintaining any part of your airplane, operate two progressions
of thought. The first involves doing a quality job on a task at
hand. The second is, "what if this part fails?" Go over the ways in
which the part may fail and deduce whether or not any failure
presents a hazard to successful termination of flight. Analyze how
the failure will manifest itself to the pilot (handling qualities,
strange noises, engine roughness, dead radio, etc. etc.) And final-
ly, is the failure pre-flight detectable?
While designing products for the big guys, I've expended hundreds of
hours going over these points. The fancy name for this procedure is
Failure Mode Effects Analysis or FMEA for short. If any failure
does present a hazard, what is the best means for dealing with it?
Re-design may be in order. Example: if the head of a broken screw
is likely to drop into an intake manifold, perhaps a nut plate
installed to bring the screw in from the other side is in order. If
a failure is not pre-flight detectable, is the item is buried too
deep to visually inspect or simply not on your check list?
Note:
Whether you fly factory or home-built airplanes, published check
lists are the MINIMUM to meet bureaucratic and/or institutional
requirements. Nobody says you cannot EXPAND an existing list to
cover items you'd like to peek at before launch time.
Let's suppose failure of an item simply makes some component or
system inoperative. Can you do without it? If not, what system
backs it up? In other words, develop a "plan B" perhaps even "plan
C" to back up most needed components and systems.
This technique is applicable to all airframe systems but let's get
back to the original topic of electrical systems. Referring to the
list I gave earlier, let us agree that if the airframe is in good
shape, engine is running well, you are skilled, rested and ate your
Wheaties this morning, there's no reason for this to become a bad
day in the cockpit. Let's examine the electrical system priorities
in my earlier list:
Numero uno is the battery; your single most reliable source of power
(assuming the battery has been properly maintained). Next comes
instrument lights. Why lights? Recall the admonition: "Aviate,
navigate, then communicate?" "Aviating" at night becomes a jaw
breaking chore of aiming a flashlight with your teeth. Therefore,
number two on my list is instrument flood lighting. I would choose
not to power up a 3-amp string of post lights. Instead, use one or
two, 80-milliamp bulbs rigged to flood the panel with basic light-
ing. Instrument lights on a C-150 are just that. Not elegant but
they work, consume little power and don't make your lower jaw ache.
Flashlights are good only for peering into fuel tanks and reading
maps!
Number three is the turn-coordinator; quite often your only electri-
cally driven flight instrument and capable of literally saving your
buns (you ARE current in needle, ball and airspeed technique, no?).
Fourth, I would support any electrical item needed to keep the
engine running such as electronic ignition (if you have one) and
fuel boost pump. Putting these devices on the list of "essential"
equipment recognizes a remote possibility of double failure . . . an
electrical system condition followed by an engine condition.
Aha! We finally get to THE radio; not the whole 20 kilo-buck stack
of avionics. Remember, we're trying to get home on a power budget
with finite limits. It does you little credit to navigate to final
approach fix with millimeter precision and have everything go dark
over the outer marker! Until favorable outcome of your adventure is
assured, don't turn on anything you don't truly NEED. See why a
PILOT must included in a systems reliability equation? A better
understanding or a little practice may be key to reducing a hazard-
ous situation to a challenging inconvenience.
The transponder I list as optional. Recall that it is more a serv-
ice to ATC than it is to you. It benefits you only if you need ATC
assistance in navigating which assumes he isn't tracking you as a
primary target. Even then, the transponder doesn't do you any good
if you're not talking to the ground and it uses much more energy
than your navigation receiver. However, if you do have the power
budget, a 7600 or 7700 squawk may get you more elbow room.
Landing light is another optional consideration. If you're headed
for an unlighted field or you haven't honed your skills for night
landings without light, then illuminating a landing light just
before you flare is justified (Consider your own personal FMEA, what
will you do if the bulb is out?).
Next is the alternator because it has to be running if you're going
to have any external lights on. [Assume the alternator to be least
reliable of all electrical equipment. It handles lots of electrical
and mechanical power, it sees extremes of temperature cycles and
gets its itty-bitty diodes rattled by being bolted to the engine!
What else could we do to it?] Nav lights use more ENERGY than any
other system in your airplane including landing lights, electric
flaps or landing gear! Six to eight amps continuous drain for the
duration of flight. Even a strobe light may draw more than your
entire compliment of necessary radios. External lights do not help
you get where you are going and have a very low probability of being
useful for being seen. If YOU have the problem and YOU are flying
"dark", then keep your own eyes peeled for the guy who presently
enjoys a luxury of showing external lights!
Now that I've outlined one philosophy of electrical essentials.
Let's consider the hammer-and-tongs aspects of implementing it.
In Figure 1, (see February 93 issue of Sport Aviation or drop 32-
cent SASE to address below. I'll be happy to send you a paper copy
of the figure.) I show a basic power distribution diagram illustrat-
ing the foregoing text. To begin with, if we've done our FMEA
exercise, a way is needed to KNOW when the alternator has failed.
If no device already exists to give an active warning of alternator
failure then consider a low voltage warning light mounted prominent-
ly on the panel. Further, this device should be set to illuminate
the light very soon after alternator failure; when voltage falls
below 13 volts.
When the light does come on, you have several options: If comfort-
able haven is close by and your battery is a known quantity, then
perhaps no special action is needed other than to turn the alterna-
tor off to reduce its field circuit load on the battery. It would
be wise at this time to dump unnecessary loads but a fairly relaxed
activity to get on the ground is appropriate. Most alternators re-
quire a battery to be on line for voltage stabilization and noise
reduction. If (for a variety of reasons) the battery contactor
fails to keep the battery on line, the alternator should be shut
down and ordinary load reductions made.
In event of either alternator OR battery contactor failure, AND if a
desired location for landing is some distance away, make the most of
finite energy stored in the battery. Open both BATTERY MASTER &
ALTERNATOR switches. Pull the ESSENTIAL BUS PRIMARY FEED breaker
and close the ESSENTIAL BUS ALTERNATE FEED breakers. Taking a
battery contactor off-line reduces load on the battery by several
hundred milliamps (equal to several solid state nav receivers!).
Setting the breakers in this manner isolates the essential bus and
provides a direct path to the battery. If a voltmeter is part of
your electrical instrumentation, it should feed from the essential
bus; battery voltage should be monitored during battery only opera-
tions.
Figure 1 illustrates a number of departures from traditional tech-
niques for aircraft power distribution. The most notable variant is
the lack of an AVIONICS MASTER, a device who's time has gone by.
This (and other features) will be topics for future articles. In
the mean time, if you subscribe to the avionics master switch phi-
losophy, certainly all avionics may be fed from the essential bus
and "protected" by opening the PRIMARY FEED breaker during engine
cranking. Just remember, when battery life needs to be maximized,
turn OFF everything not truly needed to get you home.
All this writing may seem like a long way around to a rather simple
concept. I suggest that it's truly simple only if one understands
how it is used and useful only if it adequately addresses require-
ments established by personal FMEA studies. Primary goals for this
article are (1) to encourage builder/pilots to accomplish FMEA
studies in light of their equipment and personal skills, (2) relieve
pressure to purchase the most expensive components in an effort to
improve "reliability", (3) encourage design for failure tolerance
(cheap) instead of striving for failure proof (very expensive and
nearly impossible). Properly implemented, these techniques will
reduce to near zero, probability that any electrical problem will
ruin your day.
The original article text was uploaded without modification. Since
the article was published, conversations and deliberations with
other designers and builders have modified the philosophy somewhat.
We now believe that the normal feedpath from main bus to essential
bus should include a diode that *prevents* the essential bus from
backfeeding the main bus. Poor pilot technique during a perceived
emergency could result in inadverted overloading of essential bus
alternate feed path and leaving one totally in the dark! Given that
the original need for avionics master switches disappeard about 15
years ago, the idea of making a solid connection between main bus
and essential bus via diode makes sense. Any time the main bus is
hot, the essential bus is too. The main bus can be shut down at any
time to conserve finite battery energy with zero risk of backfeeding
from the essential bus and blowing the altnernate feed protection.
Comments and discussion are welcome!
AeroElectric Connection
(o o)
==========oOOo=(_)=oOOo==========
| Nuckolls' first law of air- |
| craft systems design and fab-|
| rication: "Things break!" |
72770.552(at)compuserve.com
http://www.aeroelectric.com
Subject: | NARCO AT 150 Transponder |
Hi listers,
Not being able to get a Terra in time, I'm obtaining a used Narco that come=
s sans manual....so....
Does anyone have a Narco AT150 manual that they would be willing to copy fo=
r me. I'd be happy to pay copying and mail costs?
Ken
RV6A Flying
> Ryan
For light cleaning simple green works well, but when it comes to heavy
grime on the bottom of the plane, I've found that it only works so-so.
When you put it on it cuts the grime where it first hits, but once you
try to wipe it off, especially with water on the rag, it will lose
strength quickly and tend to do as much smearing as cleaning. Also if
it's warm out it will dry faster than you can clean it (and the grime)
off.
The A&Ps I've worked with just used some kind of solvent, such as
mineral spirits. I don't know if that's so good for the paint but
that's what I've seen used (and used myself).
Randall Henderson
If it has Citric acid then it is somewhat corrosive.
Herman
Gee, things have sure changed. I don't recall ANY of my skins having a plas=
tic film on them. They turned out ok just the same.
Ken
RV6A Flying
SNIP>
Not a serious item I know, but I am wondering if anyone is aware of a self=
Subject: | Re: Alternative Engines - Diesels |
I am curious/interested in all the new diesels. Continental, Lycoming,
Aerospeciale/Renault all have announced plans to offerr these. They run on
Jet A, have fewer electronics, and are more fuel efficient. I have had
great experience with auto diesels(Peugeot & Mercedes) and so am very
receptive to the potential of these new powerplants.
I remember when Mercedes came out with their 5 cylinder diesel in 1975. It
raised a lot of eyebrows at the time, but became legendary for its durability
and long term economy. The Renault is supposedly to have a 3000 hour TBO.
Shelby In Nashville.
Subject: | Re: Pnuematic Squeezer - Action Air Parts, Inc. |
Well, including me and two other 'listers, that makes 5 that are happy
with Action Air P. Squeezers (mine's a rebuilt Chicago imitation, built
in So. Cal., and works just great). I got mine with 1-1/2" yoke for
$249 from AAP. Between myself and 2 -6 builders, we have a no-hole
yoke, a 4", and a 2-1/2" longeron yoke to lend each other.
Subject: | More on Governors |
I took Dave Barnhart's advice and contacted Warner Propeller in
Tucson. Here's what Dennis Warner told me about governors:
He can provide an overhauled McCauley D2 governor for about $500.
The D2 is no longer manufactured, but most of the parts for it are
available. The head, pump cover, and housing are difficult to find,
so if one breaks you can probably say goodbye to your governor.
McCauley governors are not made from hardened steel, so Dennis thinks
they should be overhauled no later than 1800 hours.
Dennis considers the Woodward governor from Van's to be a very good
deal. He says the Woodward governor is the best governor made. The
parts are hardened steel, and should easily last 3000 hours. He's
taken apart a 4000+ hour Woodward and found virtually no wear.
Woodward doesn't offer parts price breaks to dealers, so field
overhaulers aren't too enamored of Woodward. Furthermore, Woodward
is well known for issuing service bulletins requiring parts
replacement at overhaul, even if the part is different only because
Woodward changed their manufacturing process and modified the part a
bit for ease of manufacturing. This can mean more expense for the
owner IF he/she needs a yellow tagged governor.
Warner Propeller is at 520-294-4671.
Tim Lewis
RV-6AQ #60023
timrv6a(at)earthlink.net
From: | "Joe C. Marshall III" <doufly(at)apex.net> |
first of all...
as a proffesional pilot (ATP, 10 years an 6000 hrs experience) who is
currently working toward his A&P certificate, WHY on earth would anyone
want to do somthing in, or to an airplane, just because it is CHEAPER?
The amount of money saved by automotive parts, fluids, or powerplants is
so inconsequential to the grand scheme. I am interested in building an
airplane because I want something better, not worse than what I can get
from Witchita. I have yet to see any of these alternative powerplants
that I would trust my family's, my passenger's, or my own life with!
Next, (and last)....
as a newcomer to the wonderful world of RV's, What is a Phlogistone
(sp?) spar?
Thanks!
Joe Marshall, ATP C-421 N918WK
Dreaming of a RV-8 with a 200 hp Lycoming!
------------61B92BDA22920
I am working on the 6A floor ribs.
Question:
The plans call for only the F619L to be split.
George O. video splits both.
Do both need to be split?
For those lucky ones out there with a completed plane and only the
left split,
how hard is it to get the spar plates in if only the left is split?
Don Mack
RV-6A
donmack(at)flash.net
http://www.flash.net/~donmack/
Question:
plane and only the left split,
the left is split?
Don Mack
RV-6A
------------61B92BDA22920--
From: | Scott Johnson <rvgasj(at)popmail.mcs.net> |
Subject: | Advice needed on gear fairings, tires, primer lines, wheel |
fairings
Well I've got 15 hours on N345RV (RV6A) and its running great. Now for some
jobs I have been putting off.
Question 1:
Does anybody have a method to put the gear fairing on a 6A without having to
take it off the main gear. I am very hesitant about lifting a great working
plane up in the air 2 feet and putting it back on it jig to rig the
fairings. The plane is fairly heavy at 1106 pounds and I would rather not
do it if at all possible. If I must put it back on the jig, can I lift the
entire plane by placing a lift hook between the top two dynafocal engine
mounts ( with someone holding the tail ) and lift the entire plane. Has
anybody done this?
Question 2:
Does anybody have an idea how to make a jack so that I can take a wheel off
the main. Will I have to take the gear leg fairing off to use it ?
Question 3:
I would like to change my primer lines to copper with the nipple fitting
that have very tiny holes. I had used regular AN fittings with aluminum and
it just doesn't work that well (AN fitting hole is to big, no fuel
atomization, and uneven priming occurs due to different primer line lengths
to cylinders and not enough back pressure from the fitting). It does not
allow me to start the engine at 20 degrees F.
The question I have is: can you flair the copper tubing with an aircraft
flair where it connects to the electric primer switch with a regular AN
aluminum fitting. Because they are different metals, will it corrode fast ?
Somehow the copper tubing has to connect to the aluminum fuel line. How did
you do it ?
Question 4:
I wonder if its really worth putting the wheel pants on because I will be in
and out of fields that may be bouncy and a little muddy. VANS plans say you
will lose 4 MPH without the pants, and I could care less about that. But the
plans say you will lose 8 MPH without the gear fairings and that to me is
more significant. Can anybody tell me what they found with and without
fairings and if the wheel pants might not be a great idea on rough, somewhat
muddy grass fields ( or snowy taxiways ).
Thanks to all who respond -- I'm looking forward to fine tuning this
incredible machine.
Only 25 more hours and the FEDS release me from my large 25 mile test area !
USA watchout ...
Scott Johnson / Chicago
rvgasj(at)mcs.com
check out the king KT76C transponder:
http://www.Bay-Avionics.com/
Chet Razer
crazer(at)egyptian.net
Top Job is one of the best cleaners around. There is almost nothing that it
won't clean. Grease and oil just disolve when using this stuff. It is
available at Wal Mart and other variety stores.
Subject: | Re: Franklin Engines |
> I am also extremely interested in the Franklin option for the RV-8. I
> suggest that all interested parties let Van know of our interest. If
> enough interest is expressed maybe he will develope a Franklin option.
> Kevin Horton
> future RV-8 builder (lurking and gathering info, tools, etc)
> khorton(at)cyberus.ca
> Engineering Test Pilot
> Transport Canada
> Ottawa, Canada
I too have been following this thread with a great deal of interest. I
would
like to know more about the Franklin and I think it would be interesting
if
there was a mount for it. A fellow stopped by my hangar last summer and
showed
me some info on the Franklin. The first thing I noticed was that, being
a 6 cyl,
it was a few inches longer than the Lycoming. I lost interest pretty
quick
because I didn't want to get into any re-designing. Building is
challenging
enough for me.
IMHO the Continental is the same scenario.
Roy Burkhead
80096
Wing should be shipped in March.
I also bought a pneumatic squeezer from Action Air Parts for $250. It
was reconditioned very nicely and works great!
Ed Cole RV6A Wings
>Bob
>Robert/Tammie Dieck
>Wausau WI USA
>dieck(at)dwave.net
Van got started with Lyc's using GPU's that had been converted. These were
relatively inexpensive units and would allow you to get in the air for little
money. As the business grew, the Lyc was the engine he was most familiar with.
He stated once that Lyc's were the most abundant engine in those days for
homebuilders to acquire, since many were used on the light twins, and they
whould
often be switched out at TBO rather than rebuilt.
I have two Continentals and tops on these engines are not unusual at annual
time, whereas
the Lyc seems to make it through to almost TBO with seldom needing to be
opened up. Bill
Bill N894RV with over 400 hours behind a O-320, Over
1000 RV flying hours. RV-4-180 soon.
These opinions are mine and do not necessarily represent the opinions or
position of my employer.
> (sp?) spar?
Phlogiston Products, Inc will preassemble the RV-4/RV-6/RV-6A/RV-8 spar.
The last price of the labor that I got was $765. This option will
reduce your building time and give you a very high quality wing spar.
Phlogiston Products, Inc.
P.O. Box 9, Gaston, OR 97119
(503) 985-3212
Brian Bland
Dreaming of RV-6A
From: | Charlie & Tupper England <england(at)vicksburg.com> |
> fuselage? >>
>WD-40.
I can't verify the story, but an older friend of mine recently told me that
decades ago someone who maintained bank vaults, etc. gave him some WD40 (it
wasn't on the market yet), & told him it was a great cleaner which they used
to clean & shine the exposed surfaces of vaults. Supposedly, the lubricating
properties were an unexpected bonus which later resulted in it being
marketed to the public.
RV-4
Subject: | Re: F619 Floor Ribs |
> Question:
> left split,
> split?
Don,
I split only the left rib. You can get the controls in with only a
little effort but it would be much easier if both were split. If I were
to do it over I'd spend the little extra time and split both.
Frank Smidler
RV-6, Ready to install canopy
Cleaner: Dow makes a spray-on cleaner called Scrubbing Bubbles (who ARE
these guys that think of these names) which is a bathroom cleaner that seems
to work well on underbellies. It goes through wax and everything so
rewaxing the bottom will help keep the mess easier to remove in the first place.
Michael
RV-4 232 SQ
From: | Michael Angiulo <mikeang(at)MICROSOFT.com> |
I was reading the Aircraft Spruce catalog and they claim to have a Pro-Seal
equivalent that comes in tubes and can be dispensed through a gun. Has
anyone used this or know if it is as good as the stuff Van's sells? Looks
like it would be a lot easier to mix and apply.
Also AS&S sells Stitts Epoxy primer so I bought some to try it. The can
says that you need to use "E-500 Epoxy Reducer" to clean the gun and that
MEK won't do it completely. I can't find E-500 Epoxy reducer anywhere. Is
that just a Stitts attempt to sell another jar of something? I don't want
to ruin my gun testing that theory though. Suggestions?
-Mike
>split?
Hi Don. It does make things a little bit trickier. When it comes time
to install the splice plates you will need to enlarge some of the holes
in the F619's here and there to get them in. You just need to be careful
and do it a little at a time.
It probably ended up taking the same amount of time to get the plates in
that way as it would have to make two split 619's, but my kit didn't have
enough of the splice plate to do two, and I didn't want to add the extra
weight if I didn't have to. It isn't a LOT of weight, but a little here
and a little there adds up quickly.
ebundy(at)juno.com
Subject: | Re: Advice needed on gear fairings, tires, primer |
lines, wheel fairings
>having to take it off the main gear. I am very hesitant about lifting a
great
>working plane up in the air 2 feet and putting it back on it jig to rig
the
I've just finished doing all of the things you mentioned. With 60 hours
on the airplane I figured it was time to start cleaning it up.. :) I
didn't like the idea of lifting the airframe either. So I jacked up one
side (a floor jack with a round concave "lift area" under the wing tie
down works great) to see just how (and how much) the gear leg changes
attitude when weight is off of the leg. My opinion is that the flex is
not very great, and most of the attitude change is side-to-side rather
than rotational. i.e.: the aerodynamic attitude of the fairing is
virtually unchanged with weight on or off of the gear. So I just mounted
the fairings with the airplane sitting on the ground.
>wheel off the main. Will I have to take the gear leg fairing off to use
it ?
I stacked 2 steel reinforced milk crates (mouth down) with a small sheet
of 1" plywood across the top, then put the aforementioned floor jack on
top of that. I REALLY recommend using a jack that has a "cup" shaped
lifting area rather than a flat top for obvious reasons.
> and it just doesn't work that well (AN fitting hole is to big, no fuel
> It does not allow me to start the engine at 20 degrees F.
I used the AN fittings too, and had the same problems. However, I've
found that giving 2-3 shots of accelerator pump while cranking will start
the engine very easily. BTW, you should NEVER start your engine at 20
degrees if you can avoid it. Pre-heating will not only make starting
easier, it will spare a LOT of wear on your engine.
>somewhat muddy grass fields ( or snowy taxiways ).
I put the 3 wheel fairings on first, and picked up about 3mph. With the
main gear fairings on it went up about 5 more. I don't know if this is
exclusive, or if they somehow work together. I haven't yet installed the
nose gear fairing or the intersection fairings yet. (I HATE fiberglass)
I'm not planning on doing a lot of rough field work, but the fairings on
the factory airplanes don't seem to mind the grass strip at Van's. The
fairings seem to be very solid, and you can cut the wheel openings larger
if you think dirt or snow might be a problem.
>area !
I was able to weasel a 40 mile test area and IT wasn't anywhere near big
enough. I think 100 would be more appropriate. :)
ebundy(at)juno.com
I used the 2.5 oz size (Kit A P/N 0938500) last week. It is enough to
install one baffle plate on a fuel tanks. It is easy and quick to mix;
no measurement of components required. It fits in a standard caulking
"gun" you can get at any hardware store. It is more expensive than
buying the stuff from Vans and mixing it your self.
Jack Gageby
RV4 tanks done....putting skins on both wings.
Anyone building an RV4 within 25 miles of Simi Valley, Ca?
> to ruin my gun testing that theory though. Suggests> Thanks,
> -Mike
Mike...I use the SYSTEM THREE epoxy primer. It thins and cleans with
water and/or alcohol. Seems to give a good "hard shell" coating. I
repare al parts by scuffing surface to be painted with scotch brite pad
and cleaning with MEK. I keep plastic squeeze bottles with the 2 System
Three epoxy primer components to make it easy to mix small quantities to
shoot with touch-up gun or air brush. System Three is at 800-333-5514
(also in ACS catalog)
Subject: | GLASTARNET: Sun 'n Fun Price increases |
A recent posting from the GlaStar net that is probably of interest to more
than 1 RVer
>From: "Sid & Mari Lloyd" <sidl(at)insync.net>
>In case you haven't heard, Sun 'n Fun is increasing prices dramatically.
>A week pass is $70 for non-members, $60 for members. However, there
>will no longer be family discounts. The spouse will have to pay full fare.
>There will still be discounts for kids.
>The other major change is in camping. $60 for the week, no refunds. Even
>if you only stay one night!
>Ouch!
>You can let your feelings be known about this by contacting them at
>Sun 'n Fun EAA Fly-In
>P.O. Box 6750
>Lakeland, FL 33807
>Tel: 941-644-2431
>Fax: 941-644-9737
>or linking to http://www.sun-n-fun.com/info.html and using their email
>form.
>Sid
John Top
Phone: (619) 549-3556
From: | bcon(at)ix.netcom.com (Robert M. Cornacchia ) |
Subject: | Re: NARCO AT 150 Transponder |
You wrote:
Hitchmough)
>Hi listers,
come=
copy fo=
>Thanks
>Ken
>RV6A Flying
Hi Ken,
I have a Narco AT 150 installation manual that I could copy for you.
e-mail me.
Bob Cornacchia
RV6
<< I was reading the Aircraft Spruce catalog and they claim to have a
Pro-Seal
Man, you got that right. I've got one of those guns, and buy the sealant in
the tubes. It's a LOT faster (important when you work by the job, not the
hour), and a lot more civilized. Several companies sell the tubes, and I'd
recommend the B-4 (4 hour setup).
Use U.S.Paints epoxy (mil-spec), clean up with laquer thinner. Search the
archives for more primer stuff.
Check six!
Mark
<< Also ACS sells Stits Epoxy primer so I bought some to try it. The can
to ruin my gun testing that theory though. Suggestions? >>
Mike-
ACS used to sell the E-500. I think the Polyfiber (formerly Stits) guys are
on the net but I don't know the URL. Try a search. The MEK will clean the
gun fine but don't use it to reduce the material for spraying. I remember
that the mixed material was quite viscous and sprayed better with a little
reduction with only E-500 after the induction period. I use this for all my
steel parts. Top coat within 48 hours and you don't have to sand.
The green Stits Strontium Chromate primer goes on better than the yellow. I
think they also have an off-white but I haven't used it.
Gary VanRemortel
vanremog(at)aol.com
Subject: | Exp-BUS DC Load Center |
I saw this item advertised at the top of page 124 of the March issue of
Sport Aviation. Since I'm beginning to think about wiring my 6A it was
of interest. I checked it out at the following web site:
http://www.controlvision.com/page20.htm
If anyone is using one in their aircraft or has knowledge of the item
would you please comment on it.
Chet Razer
Subject: | Re: control cables, oil pressure fittings |
> thread street fitting. Byjust filing off the corners I was just able to get
> this in without removing engine mounts. A straight flare fitting will now
fit
> recall, he undid one mount (closest to the fitting) and used a lever to
push
> it away
I have tried the hardware-store variety street fitting and it ain't gonna go
without doing at least what David did with a pry bar. My quandry is
wondering how far to go with the search for the "right" fitting since it
seems I have to unbolt the mounts, or at least one of them, anyway... May as
well do it right if I have to redo it. Why the stainless steel fittings,
guys? Have the brass and aluminum ones been breaking off?
Bill Boyd
It's not stigma, it's emperical data. Some examples:
1. An FBO near here flys both Continental- and Lycoming-equippped aircraft.
They keep entire spare sets of Continental cylinders on the shelf, but not
even one single Lycoming cylinder.
2. Caphart (sp) (an engine overhauler in Mena, Arkansas) specializes in the
big Continentals. He specializes in modifications and machining that
increase reliability and smoothness. When asked why he does not also do
this for big Lycomings, he replied that the Lycs don't need it.
3. I have service bulletin subscriptions from both Continental and
Lycoming. I see a lot more 'we screwed up' SB's from COntinental than I do
from Lycoming.
Continental *does* make some good engines, though. The -470 and IO550 are
pretty darn good engines. I'd take either one any day. I know of no
aircraft engine with a stronger more reliable bottom end than the 470. If
Cessna had but a pair of O-470's on the Skymaster instead of those stinking
Continental IO360's, they would have had one hell of an airplane. (On the
other hand, the IO346, which was 2/3 of an IO520, was also a darned good
engine).
Best Regards,
Dave Barnhart
rv-6 sn 23744
I'd like to brag about what I did today:
I landed an RV-6 for the first time. My good friend, Richard DeWitt, owner
of RV6 N106RJ allowed me to fly his RV-6 left seat to the Antique Aircraft
Association FLy-In at Casa Grande, AZ today.
Granted, I have about 40 recent hours of tailwheel time (Aeronca CHamp and
Cessna 120), but landing the RV-6 was a piece of cake. It was a beautiful
morning too: smooth as glass with visibility that must have been a hundred
miles.
No back to building so that next year we can take MY RV-6 instead.
Best Regards,
Dave Barnhart
rv-6 sn 23744
Speaking of this, what is the general consensus of what kind of recent and
total experience it takes to fly one of these? Since I spend most of my
free time building I'm sure that if I don't plan to have a set # of total,
high performance, and tailwheel hours by the time my plane is ready I'll
have close to none.
I know that the more experience the better, but what do most people seem to
think is adequate for taking (perhaps not the very first ) flights in an
RV8, 6 or 4? I have a funny feeling that 100 total, 6 in tailwheel isn't
quite going to cut it :-)
You can reply just to me if you want. I'll compile the suggested average.
-Mike
Pondering the wingwalk reinforcement
mikeang(at)microsoft.com
Subject: | Re: Exp-BUS DC Load Center |
Thanks I think if that unit can hold up to all the vibration it can save
alot of panel space,and if it can I'm shure alot of RV'rs wish they had
gone with it.I wonder what the optional panel looks like??????
( With the optional indicator module, the ExpBUS also provides an
ammeter, adjustable panel lighting output, as well as high and low
voltage warning lights, and an indicator bank to show
the status of the individual outputs.)
David Price(soon RV-4 start)
Subject: | Re: Advice needed on gear fairings, tires, primer lines, wheel |
fairings
I took a 2" pipe cap and drilled a hole in the center of it. I then used JB
Weld and secured a bolt in it with the threads comming out the end of the
cap. I put some padding on the end of the cap around the bolt. This then
screws into the tiedown fixture in the wing. I then use a long ram jack
mounted on a board so that it is stable to lift one wing at a time to change
tires, etc. The end of the ram fits into the pipe cap so that it won't slip
off the jack. Total cost of this setup was about $35.00. This works great.
Jim Cone
I strongly recommend that you take the Mike Seager checkout course in the
RV-6. Mike is really good and is easy to work with. Even a three turn spin
to the left, (the fast way), with the nose pointed straight down didn't faze
him. He will check you out and you will be confident from the first flight.
I flew with Mike for about four hours and at the end of that time I felt in
total control of the plane. I could spot land and stop easliy in less than
1000 ft. Mike will be giving checkouts in the St. Louis area from March 31st
to April 2nd. Mike will be my guest during that time so you can call me to
set up a time and I will put you on the list. I have 22 checkouts scheduled
and several demo rides. I hope to have my test time flown off so that I can
give demo rides as well. Mike will also be giving rides in other areas on
his way to Sun-N-Fun. Call Van's to find out about other possibilities.
Jim Cone (314) 928-8703
RV-6A flying!!!
Randal
I think your watering it down to much. If anyone has experience with oil on
the belly of their airplane its me. When I first started flying I might as
well have been flying behind an old round engine. I was dumping a horendous
amount of oil. any way the simple green has always worked well I mix a little
stronger than recomended.
Ryan
> From: Paul Quick <paulq(at)global.co.za>
> To: rv_list(at)matronics.com
> Subject: subscribe
> Date: Sunday, March 02, 1997 9:10 AM
> would really like imfo on fuse construction rv4
From: | "Dave and/or Diane Irwin" <dirwin(at)ibm.net> |
Subject: | RV-6A F632/F632B |
Can someone tell me what the .032 spacer that fits between the F632B
angle and F606 is supposed to do and what it's dimensions are? Plans say
that it is 4 inches - assume this is 4 inches wide and 1 inch long to fit
on top of the F632B angle(?). My F606 has an indent at top-dead-centre on
the flange and the F632B and the spacer will hit up against it. Where does
the F632B and it's spacer go in relation to this indent (which is about 1
inch wide)?
Dave Irwin dirwin(at)ibm.net
RV-6A 22607
Grumman AA-1B
Is anyone out there building or flying an RV with fuel injection on it?
I want to put fuel injection on my RV and am in need of advice.
Glenn Gordon
flyers@anet-chi.com
Hi,
I would like to hear from people who have used powder coating on parts
of their RV, ie. rudder pedals, instrument panel, etc.
Are there any places that powerder coating shouldn't be used?
Thanks in advance,
Glenn Gordon
flyers@anet-chi.com
<< Question:
left split,
I'm curious. What happens if you don't split any of them. I put my plates
in before I rivited things together. They seem to fit OK. Am I overlooking
something?
Gene
cafgef(at)aol.com
<< If it has Citric acid then it is somewhat corrosive.
Herman
> else), and even smells good. >>
The electronics industry has looked into using citrus oil solvents as a
substitute for freon solvents. Some of them are very good, no acid, rinse
off with no residual film and do not cause any corrosion problems if used
correctly. There is a great variety of citrus oil products out there and
some of them are junk. There was a great rush to get a substitute for freon
and lots af stuff came onto the market.
The easiest way to determine if there is much of a corrosion problem with the
citrus solvent is to check its pH. You can get some pH paper at a swiming
pool supply house, high school chemistry class,or maybe a drug store. You
might have to call around. Another way is to clamp some solvent between a
couple of pieces of aluminum and let it set for a couple of weeks, then
examine the aluminum for corrosion. The good stuff is used as follows:
Apply solvent
Water is used as the rinse
Dry thoughly
Gene Francis cafgef(at)aol.com
fitting all that stuff in the frount end together, waiting for warmer
temperatures to do the canopy
From: | chinkley(at)ix.netcom.com (Curtis R. Hinkley) |
Mike,
Most home or paint stores carry the Parks line of thinners, Parks #2213
Epoxy & Lacquer Thinner will cut any Epoxy primer. Just remember to
clean up as soon as you stop spraying.
I would also discourage the use of MEK, the above thinner will work
just as well without the hazards associated with MEK.
Curtis Hinkley
RV8
Pro-Seal equivalent that comes in tubes and can be dispensed through a
gun. Has anyone used this or know if it is as good as the stuff Van's
sells? Looks like it would be a lot easier to mix and apply.
can says that you need to use "E-500 Epoxy Reducer" to clean the gun
and that MEK won't do it completely. I can't find E-500 Epoxy reducer
anywhere. Is that just a Stitts attempt to sell another jar of
something? I don't want to ruin my gun testing that theory though.
Suggestions?
>Thanks,
>-Mike
Subject: | Wag-Aero Nav/Com |
Is anyone using or have experience with the Wag-Aero ICS Nav/Com radio?
This looks, from their catalog, to be an excellent unit to put in an RV with
glideslope and 2 place intercom included for $1450. It even has built in CDI
and GS indicators.
John Henley (j.henley(at)worldnet.att.net)
RV6 standing on it's own legs
Subject: | Turn coordinator noise . . |
>Hi,
> I am working on my instrument panel and today I
>noticed that when I power up my turn coordinator it
>generates a significant amount of radio noise. The radio
>is a handheld Icom ic-a20 that I purchased six or seven
>years ago. Is this normal? Do I have a bad turn coordinator?
>Should I use shielded wire for the power hookups?
> Cheryl Sanchez
>>I also had a significant amount of noise generated by the turn
>>coordinator. I placed a .1uF, 50VDC, ceramic disk capacitor
>>across the power leads inside the cannon connector and it
>>eliminated most of the noise. You can get the cap at
>>Radio Shack. Be sure to mount the cap in a manner such
>>that it doesn't short out to the shell of the connector.
>>Fred Stucklen
With a handheld radio on a "rubber duck" antenna, you're
more likely to pick up panel generated noises that are
radiated as opposed to conducted. If you're using an
external antenna on the hand held while in flight, the
t/c's noise should be much less, if at all noticable.
Fred's suggestion is a good start. You CAN get capacitors
that are so tiny that they will fit totally inside the
connector's backshell. If you cannot find any, drop me
an SASE with the words "TC Noise Filter Capactior" on
the back and I'll send you some from my junk box.
It might also require some more aggressive filtering
but I doubt it. If you expect to use the hand held
quite a bit and with it's own antenna inside the
cockpit, go ahead and send me the SASE. I'll include
some extra components that are tiny enough to fully
filter the T/C's noise from the wiring. Shielding
the wires might help but a filter is a sure bet.
Regarding the History of RV Aircraft:
Have any designs or prototypes by Vans used the designations of RV-2,
RV-5, or RV-7?
Just curious.
Thanks in advance,
Glenn Gordon
From: | Mike Kukulski <kukulski(at)highfiber.com> |
RE:
I asked about this a couple of months ago on the list; an interesting
short thread resulted with good points raised by Bob Nuckolls. Recommend
checking the list archive to get the total thread discussion.
Mike Kukulski
RV-4 N96MK
Albuquerque, NM
Eric I've been trying to E-mail you direct at ERIC_BARNS(at)tandem.com and
it doesn't go through.
Cecil Hatfield
cecilth(at)juno.com
From: | Frank van der Hulst <frankv(at)pec.co.nz> |
Subject: | Re: RV Geneology |
>RV-5, or RV-7?
I wondered about this too.
The 1997 RV calendar shows the RV-5 on the April page (reg no is N5RV). It's
an all-metal single-place shoulder-wing tailwheel aircraft, with RV-4-like
cheek cowls, constant-chord wings and tailplane. The cockpit is kindof a
bubble above & forward of the leading edge, with the back half faired down
to the fuselage aft of the wing's TE... IMHO, fairly ugly. There's a couple
of small photos showing the wing being rotated back to parallel with the
fuselage. Here's the caption:
"The long awaited new model from Van's revealed here for the first time!!
OK, Little April Fool;s joke.....but it really is one of Van's designs,
circa 1976. The RV-5 was designed as a test bed for the Carr Twin engine,
one of the first 1/2 VW conversions, and built by Van and a handful of EAA
Chapter 105 members. The non-traditional styling was determined by the
unique "swing wing", which pivoted to legal highway width for easy
trailering. The 2 cylinder engine encountered development problems, so the
aircraft was retired after about 75 hours. In 1983 it was resurrected with a
40 hp Rotax 447 and flew several more years before permanent retirement. The
RV-5 weighed 307 pounds empty. Take off took only 175 feet and it climbed at
1200 fpm. Stall speed was 41 mph and it topped out at 120-125 mph. Photos:
Dick VanGrunsven"
I'm also wondering about the RV-9 rumoured in the latest RVator; how about a
sweepstake as to what it will be?
My guess is an RV-8 with retractable gear.
Frank.
I think I remember seeing the RV-5. There is a piece of a tail of an
airplane hanging in the barn where the factory prototypes lived. The
guy giving me the tour said something about it, and that it was the only
one. He didn't get into the details though (probably didn't want to
scare me).
-Mike
>From: Glenn & Judi[SMTP:anet-chi.com!flyers(at)matronics.com]
>Sent: Sunday, March 02, 1997 10:25 AM
>To: rv-list(at)matronics.com
>Subject: RV-List: RV Geneology
>RV-5, or RV-7?
>Just curious.
>Thanks in advance,
>Glenn Gordon
I really doubt it will be a retract. It seems like Van's methodology is
to keep assembly simple, rugged and safe. It's not like the RV series
is suffering from low speeds either...
I bet between building the RV8A, the quickbuild RV8, and maybe
ressurecting the RV3 with an updated kit I think they're going to have
their hands full for quite some time.
I'm not sure what it would look like but I wonder if they've ever
considered doing something with more seats? Looks like the homebuilt
market treats 4 place planes well.
Real Question: VS on RV 6
Note: Looked in the archive, but was overwelmed and unable to get to
the answer. I know it is there...but it is huge and unweildy!
The question: My old unpunched RV-6 VS stuff and drawings and
instructions present a conflict.
The instructions say: to use a level and set the top rib 1.5 inches
from vertical from the rib spar junction.
I note that the spar is not level when mounted to the level jig...ok.
Maybe. The rib is notched at the tip...
The drawings say: 1.5 inches from the perpendicular from the end of the
spar to the front end of the top rib. The difference is perpendicular
and the junction point.
What is the right setup? I am going out to the shop to play with
geometry, but in the meantime, you gus who've long past that point, any
help?
Ken Smith
kpsmith(at)cnsnet.com
RV6 Status obvious.
Subject: | Re: Powder Coating |
Glenn & Judi wrote:
> Hi,
> Thanks in advance,
> Glenn Gordon
> flyers@anet-chi.com
Glenn
I know my experience with powder coating is not typical but......
I had several steel parts powder coated by a company called
Southern Powder Coating in Moultrie,GA. This is the same company
that powder coat's all of Maule aircraft's airframe's.
I paid about 60$ to get it done, then I paid another 50$ to get it
sand blasted off. Why, because it was peeling off in sheets, I
mean big area's that would almost fall off.The section's that
stayed on you could not get off with sandpaper or a file.
I could have taken it back, but I was not about to take a chance
with parts on my RV.
If you have parts powder coated I hope you have better luck
than I did
Craig Hiers
RV-4 N143CH
Tallahassee,FL.
>>RV-5, or RV-7?
>Frank.
>I believe the RV-9 may be a powered glider.
Tom Giertz
Subject: | Re: Wag-Aero Nav/Com |
John,
I posted a message about this radio a while back, I can send you a couple of
"product reviews" from someone using them in his tri-pacer for IFR work and
long-ez (same bubble canopy/sunlight problem). His reports are *very*
favorable.
When did the $1450 price come in? Last time I checked, they were $1595 new
and $1175 refurbed. Vicky's Pilot Shop has them for $1495 new.
Rob Acker / r.acker(at)ix.netcom.com / RV-6Q
From: | Greg Puckett <71155.2336(at)CompuServe.COM> |
Subject: | Steel Parts in fuel tank |
Hey Everyone,
I was just preparing all my fuel tank parts and was wondering what to do with
the nut-plates that go on the inside of the fuel tank that are used for the
cover plate/sender ring. Should these nut-plates be primed or left bare? If so
what should they be primed with? I can't imagine that the self-eching auto
primer I'm using on other steel pieces holding up to avgas.
Greg Puckett RV-8 80081
71155.2336(at)compuserve.com
>RV-5, or RV-7?
>Just curious.
>Thanks in advance,
>Glenn Gordon
Glenn, Since you asked, the -2 (I think) was a glider but was never
completed. The wings are ready for covering and have been in a barn for the
last 25 or more years. The -5 was a single place pop-riveted swing
wing/tow-it-home on Sunday evening 1/2VW powered "thing". It flew about 40
hours but there was not a decent engine available for it. Also, the
cockpit was not really large enough for an average person. The -7 was/is a
design Van may someday put on paper, so we will not discuss it at this
time. Bill
Subject: | Shadowed Today By a Berkut Canard - RV6A pulled a Top Gun |
Maneuver
Trundling along today in my large 25 mile test area, I had a most unusual
experience. Out of the corner of my eye I saw what looked like a star wars
spaceship swooping down from high altitude behind me ( I would have never
seen this had I not been turning ). Wondering what the heck it was, I turned
left then right and could not find it anywhere. This was kind of spooky, and
I had to think twice wondering if it had been a bird or something else. Then
I thought I bet some other crazy experimental is tailing me for the heck of
it. Thinking in Top Gun how the one jet slowed, and the other one passed, I
slowed to 60 MPH. Sure enough, a Berkut canard went zooming by me. I
firewalled it and caught up to him and slowly started going by. My airspeed
indicator was indicating about 195 MPH when I went by. I called on 122.75
and he replied. Smugly I thought, I am faster than him, serves him right for
tailing me. When I asked him if he was at full power, he said heck no, and
then went zooming by me. Apparently, he had a 180 HP fuel injected engine in
it and told me he routinely gets 220 MPH out of it. Beautiful looking plane
he had. We talked for a while and flew together and then we split to return
to our own airports. I will definitely be stoping by his hangar in the
future to get a closeup of that plane. Don't get me wrong, I wouldn't trade
my RV for his stall speed or takeoff distance though.
On a different note today, I took off behind a Mooney 201, and an
experimental sidewinder. These were both friends of mine and we were racing
to an airport for lunch. My RV6A guickly went by both in climb and got
considerably ahead. After about 10 minutes, the Mooney 201 went by me slowly
(much slower than the Berkut) , and the sidewinder was a little behind. It
was a lot of fun, and gives me more impetus to clean up the drag on my
airframe even more.
Now if Van would only design that RV8 retractable, with the 250 HP ...
Scott Johnson
N345RV RV6A 20 hours Total Time and Building Fast
<< I would like to hear from people who have used powder coating on parts
Are there any places that powder coating shouldn't be used? >>
My opinion is that powder coating is a wonderful "cosmetic" coating. It is
not really a good anticorrosion coating in that it has no sacrificial
capability, it merely protects by having low permeability to moisture
comparable to any good sprayed on top coat applied to an equivalent dry film
thickness. There are a different polymers used in powder coating, epoxies,
polyesters and others. Some are more flexible than others and could
theoretically hide underlying substrate fractures with no apparent surface
indication.
It is this thickness, flexibility and hiding power that makes it a good
cosmetic finish. Very thick flexible powder coatings IMHO should not be
applied to motor mounts or any highly stressed structure. It will provide a
lasting finish in benign environments, but probably not in salt spray or
other corrosive conditions as well as would a properly applied strontium
chromate primer with urethane top coat.
That said, the only powder coating I used on my 6A is for the instrument
panel. If you are using a color that the powder coater has on-hand, great.
Otherwise you are going to have to buy hundreds of dollars worth (there is a
minimum buy) of power to get your stuff done.
Look in the phone book for your area. There are many powder coaters in the
Silicon Gulch area but I don't know how plentiful they are in your neck of
the woods. The one I used primarily restores patio furniture.
Gary VanRemortel
vanremog(at)aol.com
<< I would also discourage the use of MEK, the above thinner will work
just as well without the hazards associated with MEK. >>
Just curious as to what you think those unique hazards might be. The MSDS
for MEK does not read sufficiently different in terms of hazards than other
organic solvents or blends having similarly high solvency. I prefer using
Acetone but MEK has no unique problems of which I am aware. We use 5 gallon
cans of it at work.
Yes it's flammable, yes it defats the skin, yes it's a suspected carcinogen.
So are other ketones (like acetone), glycol ethers, aromatics, alcohols,
etc. You should be careful of them all.
Gary VanRemortel
vanremog(at)aol.com
Scott:
Larry Vetterman makes and sells (as do Van's and/or Avery-saw it for sale in
one of their catalogs) a neat little jacking device that slides into the
axle. You have to modify the axle nut, but that's no big deal. I much
prefer this method to jack pads on the wing. Awhile back, we got to see
what happens when a jack goes through the wing of a Bonanza. Not a pretty
sight.
>you do it ?
I used copper and flared the tube with a Rolo Flare---no problem. I came
off the gascolator to the primer valve and from the primer valve to 3 ports,
all with copper line and aluminum fittings (except, of course, the primer
port fittings). Some people recommend annealing copper lines every couple
of years or so and this would be a good time to check for corrosion. As
cheap as the copper line is, you could just make new lines every couple of
years.
Bob Skinner RV-6 BSkinner(at)navix.net
Subject: | RV4 Kit For Sale |
G'day,
Due to family matters, I am unfortunately forced to sell some of my toys which
includes my RV4 complete
kit. Tail finished. The wings are mostly finished, need to do the final closure
(all drilled, dimpled and
primed). All parts are primed with self etching zinc chromate primer. Workmanship
is above average, I had
a very experienced bucker to assist me for all of the skin riveting. The engine
is part of the package. It
is a 0 SMOH bendix injected O-320, 160 hp. Overhaul done by Don George, Inc., Orlando,
Florida. It
includes new accessories (needs generator and vacuum pump), new cylinders, pistons,
rings, ect.
This is a copy of my Trade-A-Plane ad. I can also be reached at: smbr(at)digital.net.
I'm located in Ft.
Pierce, Florida.
RV4 COMPLETE KIT, includes 0 SMOH 160hp IO-320 with Bendix inject., new access.,
tail 100%, wings 95%,
primed in/out, very good workmanship, elect. elev. trim, elect. flaps, dual lights,
whelen 4-strobe, many
extras, over $27,000 invested, first $25,000. 561, 466-8209 eve., 234-1303 day.
From: | "Darrell L. Anderson" <d.l.anderson(at)worldnet.att.net> |
primer I'm using on other steel pieces holding up to avgas.<
I can't imagine that the nutplates would NOT be covered with Pro Seal. Mine ended
up that way. Anyway, they are Cad plated I believe.
D. Anderson
RV-4, wings, Montana
Subject: | Re: Steel Parts in fuel tank |
Greg Puckett wrote:
> Hey Everyone,
Prime NO parts for the fuel tank. After it is assembled, you will etch
and prime the exterior (unless you are building a polished aluminum
plane), but you don't want primer anywhere inside your tanks.
PatK - RV-6A - Waiting for weather to warm up so I can work outside.
Subject: | Advice needed on gear fairings, tires, primerlines, wheel |
fairings
prefer this method to jack pads on the wing. <
I've seen this jack adapter in the catalogs, but for the life of me, I can't see
how you're supposed to get the wheel off the axle when the jack adapter is stuck
on the end of it holding up the aircraft. It seems to me that you need to pick
the
gear up from the inboard side of the axle. Is the point to only get the tire off
the ground, and then drop down on some sort of cribbing?
Not far enough to need it yet...
RV-4, wings
D.Anderson
About two weeks ago I requested information from some of you old timers
informations about using a IO-360 200HP engine in my RV6. I appreciatte
all the advice that was given to me. It appears this engine would require
quite a bit of extra work for my RV6 which is beyond my abilities. However
this would be an excellent buy for someone building the RV8 so here is the
information which I will pass on.
I personally Know this individaul and the following information to be true.
The engine came out of a 1987 Mooney 201 which has been converted into a
300 missile.
This engine did not come out of a damaged airplane or prop strike. It has
1122 hours since new it is complete with all accessories mount exhaust etc.
the asking price is $12,500 firm. The engine is crated ready to be shipped
with all papers and documents avialable.
contact Mat Simon Phone 941 475 1676 Florida
Or Email me joe(at)flnet.com
Aero Electric Bob Nuckolls did a review on this item about 6 months ago.
Should be in the Archives, he did not recommend it.
Bob Busick
Rv-6
Glen,
I used powder coating on all my steel parts, and my experience is a good
one. Ive listened to pro's and con's for sometime. I would not recomend
powder coating aluminum parts, I had a freind who did his instrument panel
and his RV4 seat back. He is a fairly light person and after a few hours of
flying he found his seatback supports( the eighth inch angle running up and
down the sides) bent in a curved shape. The only thing he could atribute this
to, was the temp that the powder coating was curred at somehow affected the
temper of the aluminum.Some people believe that if you have cracks they will
not show up on the surface. I do not agree I believe if you use a light color
such as white or gray the cracks will show up. They should appear in the form
of a thin dark colored line.
Ryan
RV4131RB(at)aol.com
I'm not certain that MEK is any more hazardous than acetone. Its one
advantage over acetone is that it has an additional methylene group present
in its structure, which makes is a bit less volatile so it doesn't evaporate
as rapidly.
Greg,
I believe the nut plates are cad plated (thats the blackish gray color on
the nut plate) they should require no further treatment. That is as long as
their not scratched or dinged.
Ryan
Subject: | Advice needed on gear fairings, tires, |
primerlines, wheel fairings
can't see
stuck
pick the
tire off
>D.Anderson
Darrell,
You modify the axle nut by cutting a hole in it and fitting a nut plate
that is removable. To jack the plane up, you remove the nut plate, insert
rod on the jacking tool, remove the axle nut which slides onto the shaft as
does the wheel. Then you set the horizontal part of the axle on some blocks
of wood and remove the jacking tool, nut and tire/wheel.
Bob Skinner RV-6 Bskinner(at)navix.net
Recently, I sent an e-Mail to Zoche, asking for an RV-6 engine....
1/21/97
"We are currently in the concurrent JAR-E (European) and FAR 33
certification
program. The usual way would have been to address the European (JAR-E)
certification first before handling the US (FAR 33) certification
procedure.
With both the German and US aviation authorities having agreed upon a
concurrent
certification, we expect to have both Type Certificates available within
one
year's time - but, as with any leading edge technology, precise schedules
are
difficult to predict. Still, we do not anticipate to sell engines during
1997.
It is part of our company policy to sell certified engines only; we
consider the
certification as a further proof of the design validity and production
quality.
Prices will be competitive to e.g. Lycoming engines.There is considerable
interest in our engines from RV6 builders.
To obtain further data you might want to poll our brochure from our fax
(++49 89
342451) or visit our webpage at: http://193.26.97.194/
Sincerely,
Dr. Stefan Ittner"
Bill Watson
Licensing Operations
Phone: 408 974-7216
Fax: 408 974-0604
Page: 800-240-6371
email:watson1(at)apple.com
|___|
____(+)____
"I'd rather be flying"
> Question 4:
I had the same thoughts as you, but that was before I flew Ken Scott's
RV-6 into the Flying M Ranch, a short narrow one-way gravel stip in
the foothills of the Oregon coast range, without them on. I was not
happy to discover that the wheels had kicked up some rocks and dinged
the bottoms of the flaps and leading edge of the h-stab.
You probably want to stay away from the fancy two-piece ones however
if you are going to fly into rough/soft fields.
Randall Henderson, RV-6
randall(at)edt.com
Hey,Glen: I powder coated my rollover structure in the -4 and it looks
GREAT!! It has already suffered a fair amount of grief and still looks good.
(By the way: it is BLACK which has a tenedency NOT to reflect off the canopy
in the sunlight, making visibility MUCH nicer for my GIB). My mount is
coated a light grey (and has suffered even more greif and still looks good)
and, I agree with Ryan in that if the metal under the coating is cracking,
the coating will also crack as it is adherent to the metal under it. A lot
of the tubular steel fuselage kits (KitFox, etc) have powder coated
fuselages from the factory.
I looked and asked around and found a company I liked. (Ask around your
local builders or EAA groups). They will slip your stuff into a batch of
things they are already doing, if you like the color they are using, and it
costs MUCH less doing it that way. You may have to wait a little longer but
the savings can be substantial. They do a lot of black, grey and white things.
Steel is best to coat as the temperatures used are high and can change the
temper of aluminum. THICK aluminum that isn't being stressed may be OK.
Keep building.......
Michael
From: | sburch(at)norfolk.infi.net (stan burchett) |
Subject: | Spray gun QUESTION? |
Rechargeable spray guns sound ideal for priming...portability, no clean-up,
always ready. Just recharge/refill as needed. Harbor Freight has a 1 qt.
brass for $40. Has anyone tried these that knows a down side?
Stan from Yorktown,VA -6A
Subject: | RV4 curved seat back problem (was Power Coating) |
Be advised that the RV4 seat back with the 3/4 inch angles ARE TOO WEAK
and will bend. Mine bent in the first year of use and mine are NOT power
coated.
Van's published a plans change about 2 yrs ago (I can look it up if
needed) to go to 1 inch x 1 inch angle on the RV4 seat back.
I made this change about 2 months ago and this version is much stronger.
FYI, I weigh about 170 to 172 and have pulled a max of 5 G's in my RV4.
The 1 inch angles are still straight.
Expect to see more about the RV4 seat backs. I sent van a long note
on a problem I had on the RV4 seat back.
I almost put someone into the baggage area doing aerobatics.
The rear seat back went completely into the baggage area.
Waiting to hear van's response.
The rear seat back and bulkhead in the RV4 are NOT designed to take
much G-load.
Herman
> Glen,
February 21, 1997 - March 03, 1997
RV-Archive.digest.vol-cn
