RV-Archive.digest.vol-da
June 18, 1997 - June 26, 1997
      charge you extra?
      I really seriously doubt that the early failure was caused by panel angle!  Do
      you suppose Van doesn't know about tilted gyros??
      Maybe I'll make my panel vertical.
      Hal Kempthorne   RV-6AQ --  On main gear
      halk(at)sybase.com     Santa Clara, CA. Debonair N6134V @ SJC
      >    While the angle you have calculated does indeed represent
      > the 4.2 degrees from vertical, how does this relate to the angle
      > of the panel while in the cruse configuration. The original Atificial
      > Horizon that I purchased (from Van's) didn't have any tilt factored
      > in, and it failed within the first 100 hours of flight. The next one had
      > the 8 degrees of tilt designed in, and is still operational.
Date: Jun 18, 1997
Subject: Re: Plexiglass paint removal
--> RV-List message posted by: randall(at)edt.com (Randall Henderson) > I bought my RV-4 already built, and there is a slight dusting of paint on the > entire inside of the canopy. Should I do the Micro-mesh treatment to remove > this? Will anything else cut the paint without damaging the plexi? I'd definitely call Vans and have them connect you with the place that makes the canopies and get their advice. I was told you could use isopropyl alcohol or Naptha on the canopy. I used Naptha with no problem to clean off some excess sealant around the edges. I don't know how well it will work on dried paint however. I used micro-mesh to polish out some scratches in my canopy. Be forewarned -- if you intend to micro-mesh the whole canopy you are in for many many hours of hard work! The stuff does work, but only if you read the directions and adhere strictly to them! You can't cut corners with this stuff. I'd definitely try to get the paint off some other way first. Randall Henderson, RV-6 randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Jun 18, 1997
Subject: Re: cabin air
--> RV-List message posted by: Mlfred(at)aol.com << On my RV-4 I have no problem getting air into the cockpit. My question is where does the air go? On my current project I am at the stage where I could put in some vents in the right location, if there is one, >> Tom: I could say something like: It simply disappears, like one of each pair of my socks do, when I put them in the washer. Altho, sometimes they turn into hangers.... Think of it like this: Where is there low pressure? I'm sure the air is at least 'trying' to go there. Air comes in the front, and presumably out the back. OK, but thow does it get there? On the -4, it would flow around the rear seat back, thru the luggage compartment, and out near the tail. So, where is the low pressure area at the tail? Under the horiz stab, of course. I see many folks with a nice seal under the stab, but this is where I think most of the cabin air exits the fuse. You should put some 1/8" hardware cloth in this area to keep the critters out, tho. You may also want to put an outlet in the rear baggage bulkhead, say 4" dia, and also use hardware cloth here. I'm not sure the "leakage" around the rudder/v stab is enough. So, how are you getting the air in? -4 listers would like to know. Check six! Mark ________________________________________________________________________________
Date: Jun 18, 1997
Subject: Re: Question about washers
--> RV-List message posted by: randall(at)edt.com (Randall Henderson) > >Does anyone know why the plans call out two large 970-3 washers in = the=20 > >inboard aileron hinge assembly?...I am wondering why I can't use = smaller=20 > >diameter washers to bear against the bearings. The oversize washers are intended to "capture" the bearing in case it fails. Good redundantcy/safety feature. You may actually only need one per side. If you look at dwg 21, detail 'A', you will see it says "AN970-3 2 REQ'D". Generally this means two total. I am guessing this is because if you do it like the plans show, with one long spacer on the same side as the big washer, then if the bearing fails, the spacer and washer will keep things in place on that side, and on the other side the face of the aileron bracket will do the job. Interestingly, they call out "4 REQ'D" for the spacers, which some people do -- even length spacers on each side of the bearing. I guess it would depend on which way you do it. > >If I can use the smaller diameter washers I can avoid having to place = =20 > >a minimum order for =BC pound or 100 of the 970-3's just to get the = two=20 > >I need. I never had a problem with minimum orders for this stuff....? Just ask them to stick a couple of em in an envelope...! Randall Henderson, RV-6 randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Subject: Question about washers
Date: Jun 18, 1997
--> RV-List message posted by: "Stephen J. Soule" Hi Mike, I talked to Van's today and you are absolutely correct. The purpose of the large washer is to capture the rod end in case of a bearing failure. With the large washer in place the aileron control rod will 'flop' from side to side only a fraction of an inch instead of sliding from side to side along the whole one inch length of the bolt/spacer. The advise I got was to keep a couple of dozen of the large washers on hand for similar applications. One example was on the throttle cable. Steve Soule Huntington, Vermont ________________________________________________________________________________
Date: Jun 18, 1997
Subject: Re: spar construction
--> RV-List message posted by: "John C. Devlin" Craig, This hydraulic press method worked very well for me and I recommend it to you. In retrospect, I would weld or bolt metal braces to keep the press frame perfectly vertical during operation. Also the addition of limiter vise grip clamps at the base of the hydraulic bottle jack to prevent it from walking during operation is recommended. I taped 1/8 inch luan plywood shims between the frame and traveling part of the press to reduce the slop. They had to be periodically repositioned during operation. The spar needs to be checked for level in both directions prior to each press. I set the press up so that the shop head was up and the manufactured head down. So from top to bottom the order was hydraulic press rod, shop head, spar, manufactured head, die, 3/4 in tempered rod, and backing plates. The manufactured head die was fitted into a 6 in long piece of 3/4 in steel rod that I tempered. The tempering consisted of simply repeatedly(about three times) heating the rod to cherry red with a propane torch and plunging it into used motor oil until cool. (Drill the hole for the die before tempering). This rod was placed in a wooden block as described in the Klee article and backed by the stock backing plates sold with the press. The wooden block was held in place with wood carpenter clamps that Harbor Freight also sells. The rod mushroomed a small amount but didn't interfer with the process. Paint was removed from the end of the press's rod end with sand paper. This was to prevent slipping and prevent paint from being pressed into the rivet. A platform was made from two courses of cinder blocks for the press frame. This was to bring the working area to eye level and reduce personal fatique. Three courses might have worked better because my legs were really sore the next day from doing six hours of deep knee bends. Both spars only took six hours and the results look excellent. Roller in feed and out feeds are, in my opinion, a necessity. They can be made or purchased and are useful throughout the shop. These feeds were adjusted so that the manufactured head die is very slightly higher than the feeds but not enough to effect the level. The rivets were held in place by masking tape which was removed as the rivet and spar were moved over the die prior to pressing. A feeler guage was used initially to insure a complete press but after a few rivets a MK1A eyeball and feeling the hydraulic jack handle resistance was sufficient. While pressing, the rivet deformation was observed to abort the press if the rivet started to deform to one side. If this was the case, the press was raised a bit and level checked/corrected and pressing restarted. Many of the rivets needed to be shortened to the accepatble length prior to pressing because deformation to one side was a certainty if too long. None of the rivets needed to be drilled out using this method. The process took no more than six hours and the results were excellent. Mr. Klee had a great idea and I thank him for sharing it with me. Hope this helps, John Devlin RV6A, skinning wings, fuselage on order, really enjoying building, can't wait to fly it ________________________________________________________________________________
Date: Jun 18, 1997
--> RV-List message posted by: John Ammeter The reason for the wider washers is to hold the bearing together if it were to come apart on you. Since that is the only purpose for the washers I suppose you could make a couple washers from 0.032 2024 T4 stock. I've got a bunch of 970-4's but that won't help you. JA >--> RV-List message posted by: "Stephen J. Soule" > >Does anyone know why the plans call out two large 970-3 washers in the=20 >inboard aileron hinge assembly? I only got two of these large washers=20 >with my RV-6 kit and used both of them on the left wing. I am now=20 >working on the right wing and I am wondering why I can't use smaller=20 >diameter washers to bear against the bearings. > >If I can use the smaller diameter washers I can avoid having to place=20 >a minimum order for =BC pound or 100 of the 970-3's just to get the two=20 >I need. > >Steve Soule >Huntington Vermont > > > > John Ammeter ammeterj(at)seanet.com 3233 NE 95th St Seattle WA, 98115 USA 206-525-5445 RV-6 N16JA First flight August 1990 ________________________________________________________________________________
Date: Jun 18, 1997
Subject: Re: Computers on board?
--> RV-List message posted by: John Ammeter Dennis, I'm sure you know more than I'll ever know about radios. That said, I just tried exactly what you said. I took my ICOM handheld (set to 122.775, if that matters) and held it near my P-75 computer. I got no increase in static and it didn't break squelch when I set the squelch with the radio over 6 feet from the computer. I've got a full size tower (Zeos) BTW. John >--> RV-List message posted by: "Dennis Persyk" > > > >---------- >> From: Chris Hinch <dcc.govt.nz!chris(at)matronics.com> >> To: 'smtp:rv-list(at)matronics.com' >> Subject: RV-List: Computers on board? >> Date: Tuesday, June 17, 1997 5:53 PM >> >> --> RV-List message posted by: Chris Hinch >> >> >> >> Will a CPU upset other avionics? What about a stable power supply? Are >> there any regulations that affect my ability to do this? > >Chris: A Pentium processor is a pretty good jamming device. If you have a >handheld aircraft band transceiver, turn it on and bring it near an >operating CPU. If you can get closer than 10 feet without breaking squelch >you have an extraordinarily-well shielded computer. The RFI from the CPU >is both radiated and conducted from the source, making shielding >challenging. >You might obtain some application notes from Intel on shielding. Low EMI >(Electromagnetic Interference) enclosures for CPUs are commonplace. >Dennis (amateur radio N9DP) 6A fuselage > >> Chris Hinch (RV8 to be - garage being turned into a workshop, buying >tools) >> Management Information Systems >> Dunedin, Dunedin City Council >> Internet : chris(at)dcc.govt.nz > > John Ammeter ammeterj(at)seanet.com 3233 NE 95th St Seattle WA, 98115 USA 206-525-5445 RV-6 N16JA First flight August 1990 ________________________________________________________________________________
Date: Jun 18, 1997
--> RV-List message posted by: Steve Miceli <102630.1237(at)CompuServe.COM> GET A HOLD OF A MAY '93 SPORT AVIATION MAGAZINE (CALL EAA FOR A BACK ISSUE IF NECESSARY). IT IS EXPLAINED VERY NICELY BY TONY BINGELIS. BY THE WAY, I AM CURRENTLY USING THE ARBOR PRESS METHOD, IT WORKS GREAT. BEAUTIFUL SHOP HEADS EVERY TIME. PRACTICE ON A PIECE OF SCRAP FIRST TO CALIBRATE YOUR ARM. GOOD LUCK! ________________________________________________________________________________
Date: Jun 18, 1997
Subject: LED Dimmer
--> RV-List message posted by: "Mark S. Malone" I need some help from the electronics gurus. I'm putting .125" LED's above each switch on my panel. The LED will light when the switch is energizes the equipment, i.e., pitot heat, nav lights, strobe lights, etc. I would like to be able to dim the LED's with a single dimmer. I know I can do this with a relay for each switch or a double pole switch. Is there anyway to do this with switching transitors? My Radio Shack rep suggested this when we were discussing mounting the solid state relays to a pc board. Obviously the transistors would be lighter. Any ideas would be greatly appreciated. Mark Malone RV6A - Working on panel. mmalone(at)dialus.com Fax(417)881-0053 ________________________________________________________________________________
Date: Jun 18, 1997
Subject: Re: Carb mounting
--> RV-List message posted by: Jmcada(at)aol.com REPLY TO CHET RAZER Re: Carb mounting Chet, Things might have changed, but RTV and gasoline do not like each other. The RTV will swell up, two to three times normal size, and peel of in long thin strands. Generally gum up the works.Try taking the RTV and sticking some in a cup of gas overnight - see what happens. I used to use a product, on race car fuel cells, that I believe was called "HYLIMAR", made by Rolls Royce of England. It was blue, sticky. never got hard, and never leaked. It may still be around ( or somethingf that does the same job). Try a road racing, race car shop. ________________________________________________________________________________
Date: Jun 18, 1997
Subject: Re: Rivet gun size
--> RV-List message posted by: Finn Lassen Thanks Scott. After I posted the first question, I took a 1/2" thick piece of ALU and set an AN470AD6- rivet in that against a bucking bar laying on the floor. Using both hands on the rivet gun it was no problem. I then went out and bought a 7.5 lbs piece of steel for a bucking bar. I also duct taped a 1 - 2 lbs round bucking bar to the top of the rivit gun. With that I managed to set the rivets in the spar. Scott Lawson wrote: > > --> RV-List message posted by: "Scott Lawson" > > It is a 4x gun and CP guns are usually strong hitting. Two possible > solutions. If you use an in-line oiler or put oil directly into the gun, > try using some contact cleaner in it. They can gum up over time. If you > bought it used it is possible that someone has taken it apart before. Guns > can be tuned for optimum performance by turning the barrel and it may have > been put back together without consideration for this. > > --> RV-List message posted by: Finn Lassen > > I'm having a hard time setting the AN470AD6- rivets. My rivet gun is > > a Chicago Pneumatic CP-4444 AERO S CYL. Is that a 4x gun? It was > > sold as a 3/16" capacity but... ________________________________________________________________________________
Date: Jun 18, 1997
From: landings-diginews(at)landings.com (LANDINGS DIGI-NEWS)
Subject: LANDINGS: Correction/Apology
--> RV-List message posted by: landings-diginews(at)landings.com (LANDINGS DIGI-NEWS) Greetings, We would like to offer a correction and an apology to those of you who have received the first issue of the LANDINGS DIGI-NEWS with a wrong reply address. The correct reply address should have been landings-diginews(at)landings.com (as specified at the end of the mailing). Instead it appeared as NoReply(at)NoReply.org. This was an unintentional, unfortunate error for which we would like to offer our most sincere apology. We hope that you found the content of the LANDINGS DIGI-NEWS of interest and of value. Thanks for your forbearance :-) LANDINGS.COM (landings(at)landings.com) P.S If you received multiple copies of this notice please do the following: send email to: landings-diginews(at)landings.com in the body of the email include: unsub emailaddress to add a different address do the following: send email to: landings-diginews(at)landings.com in the body of the email include: subscribe emailaddress ________________________________________________________________________________
Date: Jun 18, 1997
Subject: Re: Prop bolt lock-plate/torque wrench
--> RV-List message posted by: Bob Skinner >--> RV-List message posted by: MAlexan533(at)aol.com > >Does anyone know where to buy the prop bolt lock plates? Or do you have to go >have one made by a machinist? I'm getting tired of removing my spinner to >check bolt torques. Also, can I use an end wrench extension on a torque >wrench so that I don't have to remove the cowling to check the torque? Would >this still be reasonably accurate? Thanks. Van's sells the grooved crush plate. You may have to buy new bolts. When I was running a wood prop, I removed the top cowl to check torque. I used a "crowfoot (?)" (a really short extension) on my torque wrench. My Craftsman torque wrench had the formula to use if you use extensions with the torque wrench. Bob Skinner RV-6 BSkinner(at)navix.net ________________________________________________________________________________
Date: Jun 18, 1997
Subject: Re: question on floor
--> RV-List message posted by: ed loveday >--> RV-List message posted by: Leo Davies > >> >>>Also in fitting the floor covers under the seats, the ribs are not level. >>>It looks like if the floor gets riveted down it will be pulling on the >>>flanges or bend the floor panels. Did anyone else run into this?? >> >>I thought they had fixed this, guess not. On mine all the ribs were >>fine except the end ones, which came out approx. 1/8" to 3/16" low. I >>just riveted some shims to the tops of the rib flanges. >> >>Randall Henderson, RV-6 >>randall(at)edt.com >>http://www.edt.com/homewing >> >Randall, > >I'm delighted that mine will not be the only RV with 1/8 shims on top of the >outboard seat rib flanges. > >Leo Davies > >leo(at)icn.su.oz.au > > Hi, When I asked Van about the same problem with mine, he sounded genuinely surprised, and agreed that 1/8 shims should be the proper fix. Y'all are'nt alone! Ed Loveday eloveday(at)ici.net ________________________________________________________________________________
Date: Jun 18, 1997
--> RV-List message posted by: ed loveday At 11:53 18/06/97 NZT, you wrote: >--> RV-List message posted by: Chris Hinch > > >Without wanting to sound too much like a *complete* nerd, what difficulties >are involved in integrating a PC into my RV-8 to be? The potential >application is a custom developed GPS/moving map display/flight mgmt system >connected to a 6" panel mounted active matrix screen driven from a P100 >cpu/motherboard (no "essential" functions). > >Given the assumptions that (1) the board is mounted in an appropriate >manner regarding cooling, (2) that the hard disk wuld be replaced with a >solid state hard disk (fewer power demands, no moving parts to get upset by >aerobatics), (3) that I can develop robust/stable code (it may not be >pretty, but it *will* be robust) and (4) that I understand it may not be >cost effective to do so, what other hidden traps are there? > >Will a CPU upset other avionics? What about a stable power supply? Are >there any regulations that affect my ability to do this? > >I'll get in first with the "Intel Inside" jokes - maybe I could hide some of >those canopy cracks I've been reading about with one of those little >stickers.... > >Many thanks to the list in advance >_______________________________________________________ > >Chris Hinch (RV8 to be - garage being turned into a workshop, buying tools) >Management Information Systems >Dunedin, Dunedin City Council >Internet : chris(at)dcc.govt.nz > > Chris, Don't remember just who it was, but someone has been displaying just such a rig at Oshkosh for the past 2 years. Still in development, but most definitely a panel mount PC. I'll bet I can find a flier around here on it if that'll be any help-just let me know & I'll start digging. Regards, Ed Loveday RV-6 fuselage - 90%done - 45% to go! eloveday(at)ici.net ________________________________________________________________________________
Date: Jun 18, 1997
Subject: Re: Sliding Canopy Skirt Cap (Crass Commercialism)
--> RV-List message posted by: Vanremog(at)aol.com If anyone is interested, I have made a form for that little joining piece (cap) that joins, sits atop the rear skirts and is shaped to clear the canopy rail. I will sell hydraulically formed caps (3"W X 5"L formed of .032" thk 2024-T4 alclad) for $10 each if you want them. They are planar for the first 3.5" and then the center 1"W gradually raises up out of plane in a 3/8" high wedge over the last 1.5". So order now, I'm hoping to retire early and live on the profits. -Gary VanRemortel vanremog(at)aol.com ________________________________________________________________________________
Date: Jun 18, 1997
Subject: Re: In strument Panel Tilt and Attitude Gyros
--> RV-List message posted by: Vanremog(at)aol.com << I talked with an engineer at R. C. Allen this morning who alleges that tilt correction has the sole purpose of centering the artificial horizon on the miniature "airplane" in the gyro case and has nothing to do with reliability. >> I believe your information to be correct. I got the same info from both IFR and my local gyro tech when I ordered my 10 degree gyro. Incidentally I've always set the AG in trigears while on the ground just before takeoff so that the miniature airplane is centered on the artificial horizon. Is this imprecise and is it considered better form to adjust it in the air when you know you're level at cruise? You guys should have told me that I've been doing it wrong all these years. Oh, the embarassment..... -GV ________________________________________________________________________________
From: "Tim Lewis" <timrv6a@germany-c.it.earthlink.net>
Date: Jun 18, 1997
Subject: Alternator modifications, Avionics order
--> RV-List message posted by: "Tim Lewis" <timrv6a@germany-c.it.earthlink.net> Listers, I ordered most of my panel today. My wallet is unconscious. It may have stopped breathing. Call 911! Thanks to all who shared ideas on gyros for tilted panels, gyro hookups, GPS suggestions, etc. I appreciate it. Alternator: I need a big alternator (60 A) to run my night/IFR electrical load. I have the mounting kit from Van's, which suggests a Mazda 323 alternator (65 amps). That's fine, except it has an internal regulator. Does anybody have any experience to share on either disabling internal regulators or finding automotive alternators without internal regualtors? Thanks, Tim --------------------- Tim Lewis RV-6AQ #60023 San Antonio TX timrv6a(at)earthlink.net or timrv6a(at)iname.com ----------------------- ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Date: Jun 18, 1997
--> RV-List message posted by: "Dennis Persyk" John, When I bring my Icom near my Gateway P133 I get all kinds of pulse interference. The ANL button (automatic noise limiter) is in the off position to get the interference. The interference is strongest near CRT, but it seems to come from both the case and the CRT. Perhaps the Zeos is better shielded than the Gateway. I'm glad to hear that not all computers are as noisy as mine. It sounds as though Chris will have less of a potential problem with RFI than I thought. Thanks for the good news! Any other listers try the handheld test? Dennis ---------- > From: John Ammeter <seanet.com!ammeterj(at)matronics.com> > To: rv-list(at)matronics.com > Subject: Re: RV-List: Computers on board? > Date: Wednesday, June 18, 1997 4:19 PM > > --> RV-List message posted by: John Ammeter > > Dennis, > > I'm sure you know more than I'll ever know about radios. That said, I just > tried exactly what you said. I took my ICOM handheld (set to 122.775, if > that matters) and held it near my P-75 computer. I got no increase in > static and it didn't break squelch when I set the squelch with the radio > over 6 feet from the computer. > > I've got a full size tower (Zeos) BTW. > > John > > > > > >--> RV-List message posted by: "Dennis Persyk" > > > > > > > >---------- > >> From: Chris Hinch <dcc.govt.nz!chris(at)matronics.com> > >> To: 'smtp:rv-list(at)matronics.com' > >> Subject: RV-List: Computers on board? > >> Date: Tuesday, June 17, 1997 5:53 PM > >> > >> --> RV-List message posted by: Chris Hinch > >> > >> > >> > >> Will a CPU upset other avionics? What about a stable power supply? Are > >> there any regulations that affect my ability to do this? > > > >Chris: A Pentium processor is a pretty good jamming device. If you have a > >handheld aircraft band transceiver, turn it on and bring it near an > >operating CPU. If you can get closer than 10 feet without breaking squelch > >you have an extraordinarily-well shielded computer. The RFI from the CPU > >is both radiated and conducted from the source, making shielding > >challenging. > >You might obtain some application notes from Intel on shielding. Low EMI > >(Electromagnetic Interference) enclosures for CPUs are commonplace. > >Dennis (amateur radio N9DP) 6A fuselage > > > >> Chris Hinch (RV8 to be - garage being turned into a workshop, buying > >tools) > >> Management Information Systems > >> Dunedin, Dunedin City Council > >> Internet : chris(at)dcc.govt.nz > > > > > John Ammeter > ammeterj(at)seanet.com > 3233 NE 95th St > Seattle WA, 98115 USA > 206-525-5445 > RV-6 N16JA > First flight August 1990 ________________________________________________________________________________
Date: Jun 18, 1997
--> RV-List message posted by: chester razer aol.com!Jmcada(at)matronics.com wrote: > > --> RV-List message posted by: Jmcada(at)aol.com > > REPLY TO CHET RAZER Re: Carb mounting > > Chet, > > Things might have changed, but RTV and gasoline do not like each other. The > RTV will swell up, two to three times normal size, and peel of in long thin > strands. Generally gum up the works.Try taking the RTV and sticking some in a > cup of gas overnight - see what happens. > I used to use a product, on race car fuel cells, that I believe was called > "HYLIMAR", made by Rolls Royce of England. It was blue, sticky. never got > hard, and never leaked. It may still be around ( or somethingf that does the > same job). Try a road racing, race car shop. Thanks for the tip, I'll peel off the Red RTV tomorrow and replace it with something that is fuel resistant. -- Chet Razer crazer(at)egyptian.net ________________________________________________________________________________
Subject: Elevator travel
Date: Jun 19, 1997
--> RV-List message posted by: Ian Dadd Hi, I was lurking, waiting for a concensus on the right method to get 25 = degrees down elevator travel when I fell off the RV-List. Back on now = and can't access the archive for this info. Notch the Wd405's or the = HS603's ? It won't need to be much in my case - just enough to get = about 5-7 degrees. Not only but also: I am making that great pilgramage = to Oshkosh and would like to catch up with other RV-Listers. Is there a = quiet bar close handy? See your there. Cheers, Ian RV-6 just finishing off the empennage - opening the wing box! Broome West Australia ________________________________________________________________________________
Date: Jun 18, 1997
--> RV-List message posted by: Elon John Ammeter wrote: I'm sure you know more than I'll ever know about radios. That said, I just > tried exactly what you said. I took my ICOM handheld (set to 122.775, if > that matters) and held it near my P-75 computer. I got no increase in > static and it didn't break squelch when I set the squelch with the radio > over 6 feet from the computer. ------------------------------- I just had to try it too. Funny thing John, I set my handheld ICOM to 121.5 (If there is one frequency that I want to work it's that one) and got blown out of the airwaves. Specifically, I turned up the squelch to get the background static and then moved the antenna near and about my RUNNING 133Mhz computer. I didn't notice any change in the static. I then turned OFF the computer. WOW! what a change (much less). Now try this. I then put the radio antenna right next to the cpu (case cover removed) and turned on the switch. What a blast listening that thing boot-up THROUGH MY RADIO. I could almost hear it single-stepping through the boot program. (Just kidding). However, it did change pitch numerous times during the boot process and then settled down to stable background noise. I had no idea it produced so much RF. I don't even want to compute in the nude anymore! :-) -Elon ________________________________________________________________________________
Date: Jun 19, 1997
Subject: Re: Elevator travel
--> RV-List message posted by: Leo Davies Ian, Notch the HS603s Leo Davies, Sydney leo(at)icn.su.oz.au Missing Cable Beach already At 11:46 AM 6/19/97 +-800, you wrote: >--> RV-List message posted by: Ian Dadd > >Hi, >I was lurking, waiting for a concensus on the right method to get 25 degrees down elevator travel when I fell off the RV-List. Back on now and can't access the archive for this info. Notch the Wd405's or the HS603's ? It won't need to be much in my case - just enough to get about 5-7 degrees. Not only but also: I am making that great pilgramage to Oshkosh and would like to catch up with other RV-Listers. Is there a quiet bar close handy? See your there. >Cheers, >Ian >RV-6 just finishing off the empennage - opening the wing box! >Broome West Australia > > ________________________________________________________________________________
Date: Jun 19, 1997
--> RV-List message posted by: Chris Hinch >position to get the interference. The interference is strongest near CRT, >but it seems to come from both the case and the CRT. Perhaps the Zeos is >better shielded than the Gateway. I'm glad to hear that not all computers >are as noisy as mine. It sounds as though Chris will have less of a >potential problem with RFI than I thought. Thanks for the good news! Thanks to the list for all the help to date. The RF issue was one that I wasn't sure about. My thoughts were sparked by seeing the new Libretto (Toshiba?), which cries out to be the display/computational component of an small GPS/flight management system - or is it just me? Industrialise and shield the case, split the screen from the body and panel mount it, connect a slimline COM/GPS, spend a few sleepless months writing code and ta-dah! (although I agree that my time would be probably better spent with rivet gun in hand, well, I guess, the tools you know....) A colleague tells me that active matrix screens are worse than the CPU at screaming RFI, and certain frequencies are worse than others... I guess the only way is to get one airborne, and see what happens. Once again, many thanks to the list for your input. This is a superb resource for RVers - my apologies for my somewhat off-topic question. Chris chris(at)dcc.govt.nz ________________________________________________________________________________
Date: Jun 19, 1997
--> RV-List message posted by: Leo Davies Anyone building a slider should take Gary up on this offer. It took me a weekend and 30 iterations of bending Alclad with a hand seamer to get one I could live with and even then I don't like it much. Would that I had not rivited mine on. Aaaaarrrgghh Leo Davies leo(at)icn.su.oz.au >--> RV-List message posted by: Vanremog(at)aol.com > >If anyone is interested, I have made a form for that little joining piece >(cap) that joins, sits atop the rear skirts and is shaped to clear the canopy >rail. I will sell hydraulically formed caps (3"W X 5"L formed of .032" thk >2024-T4 alclad) for $10 each if you want them. They are planar for the first >3.5" and then the center 1"W gradually raises up out of plane in a 3/8" high >wedge over the last 1.5". So order now, I'm hoping to retire early and live >on the profits. > >-Gary VanRemortel >vanremog(at)aol.com > > > > ________________________________________________________________________________
Date: Jun 19, 1997
--> RV-List message posted by: cfggg That reversed NACA vent is just an odd shaped submerged outlet. The shaped ramp walls are designed for flow going toward the inlet. A straight sided ramp (parallel) would probably be more effective and create less drag. The idea of venting the cabin is a good one. David Fried > I can't say anything on drag on cabin outflow. There is a RV-6 I >have seen with a NACA airflow unit installed in reverse on the bottom of the >fuselage near the tail. If recall correctly it had a door install for >control. It has been a couple of years since I saw it. At the time he >remarked that it greatly improved both heating and cooling, I believe he >remarked that his canopy didn't bulge as much in flight. > > If he is on the net maybe he could correct anything I was wrong on. > >Has anyone else played with that idea? > > > >Have good day! > >Denny >RV-6/ Fuselage (R)N641DH >Lebanon, OR > > ________________________________________________________________________________
Date: Jun 19, 1997
From: catbird(at)taylortel.com (TTC Carroll A. Bird)
--> RV-List message posted by: catbird(at)taylortel.com (TTC Carroll A. Bird) Stephen J. Soule wrote: > > --> RV-List message posted by: "Stephen J. Soule" > > I only got two of these large washers > with my RV-6 kit and used both of them on the left wing. > > Steve Soule > Huntington Vermont They still havn't fixed this problem. I had the same thing on my RV-4. Just call or e-mail Van's and they will send you two more. In fact, there has been several shortages, and too short bolts, and they have sent me what I needed without charge. Carroll ________________________________________________________________________________
Date: Jun 19, 1997
--> RV-List message posted by: Frank van der Hulst I have a *little* experience and knowledge of this stuff. Firstly, a lot of the RF from computers comes from the high-voltage circuitry in the CRT screen. If the intereference varies depending on what's on the screen, then the screen is the source of the problem. If you have an LCD screen, I believe this is a non-issue. Secondly, a fair amount of the rest comes from the power supply. I think that a computer running off its batteries (which are being recharged from the 12V DC supply) won't generate much noise from the power supply compared to a 220V power supply. Thirdly, the higher clock speed CPUs generate RF direct from the motherboard. However, many of these (and especially on laptops) now run on 3V instead of 5V. Maybe they'll be less noisy? Fourthly, I think good design can remove/reduce the RF. A cheap PC with a cheap power supply will be much noisier than a quality machine. Direct experience: my old Taiwanese 8088 caused my neighbour across the road to complain about how it interfered with his TV. However, this only affected one channel (of two). So the RF emitted may be on only a few frequencies. In this case, I figured the problem was the PC's power supply. Fifthly, I have used a laptop (IBM Thinkpad 720C) as a moving map and logger for my GPS a couple of times in a C172. On neither occasion did I notice any adverse effects on the radios (or anything else). However, I didn't do much in the way of checking for these adverse effects. As I said, my knowledge is limited; I'm open to correction. My experience is more in terms of software than hardware. Frank. ________________________________________________________________________________
Date: Jun 19, 1997
--> RV-List message posted by: catbird(at)taylortel.com (TTC Carroll A. Bird) Randall Henderson wrote: > > > You may actually only need one per side. If you look at dwg 21, detail > 'A', you will see it says "AN970-3 2 REQ'D". No. You need two per side. One for the aileron hinge mount, and one for the push rod. Carroll ________________________________________________________________________________
Date: Jun 19, 1997
--> RV-List message posted by: catbird(at)taylortel.com (TTC Carroll A. Bird) Elon wrote: > > > I don't even want to compute in the nude anymore! :-) > -Elon Do you think clothes will protect you from RF emissions? Maybe you should wear lead drawers. :-) Carroll ________________________________________________________________________________
Date: Jun 19, 1997
--> RV-List message posted by: catbird(at)taylortel.com (TTC Carroll A. Bird) law.ua.edu!jcolquit(at)matronics.com wrote: > > --> RV-List message posted by: jcolquit(at)law.ua.edu > > Tom Martin asked: > > > > The round alumimum disks are extremely light and readily available - > and they fit neatly into an inspection plate so no structure is > affected on the aircraft fuselage. > > Joseph A. (Joe) Colquitt Where do you get these round aluminum disks? How do you get the air in the -4? Carroll, RV-4 Fuselage on the gear. ________________________________________________________________________________
Date: Jun 19, 1997
--> RV-List message posted by: Tom Martin >--> RV-List message posted by: Mlfred(at)aol.com > > ><< On my RV-4 I have no problem getting air into the cockpit. My question is > where does the air go? > > On my current project I am at the stage where I could put in some > vents in the right location, if there is one, > >> > >Tom: > > > >Think of it like this: Where is there low pressure? I'm sure the air is at >least 'trying' to go there. > >Air comes in the front, and presumably out the back. OK, but thow does it get >there? On the -4, it would flow around the rear seat back, thru the luggage >compartment, and out near the tail. So, where is the low pressure area at the >tail? Under the horiz stab, of course. I see many folks with a nice seal >under the stab, but this is where I think most of the cabin air exits the >fuse. You should put some 1/8" hardware cloth in this area to keep the >critters out, tho. You may also want to put an outlet in the rear baggage >bulkhead, say 4" dia, and also use hardware cloth here. > >I'm not sure the "leakage" around the rudder/v stab is enough. > >So, how are you getting the air in? -4 listers would like to know. > >Check six! >Mark I agree with what you have said above Mark and it is what I have on my current RV-4. The air comes from two tubes hooked up to the back engine baffle. I am not sure if the right place to dump the exit air is the rear stab area. Check out a real Spitfire. Everything is sealed and all control rods have boots. I am sure that they did not want air getting out at the wrong place. what about an out let on the fuse bottom as someone suggested? Tom Martin ________________________________________________________________________________
Date: Jun 19, 1997
Subject: Tailwheel Transition Story
--> RV-List message posted by: RodWoodard Hello folks: I've watched several "nose vs. tailwheel" discussions over the past few years. Since I sold my Cherokee and I'm building (slowly) an RV-8, I thought it'd be a good idea to get a tailwheel checkout. I really had no idea what to expect. Like most people, I'd heard stories ranging from ex-B52 flyers who said they soloed some T-craft or whatever in 3 hours to others who've told me it took them 20+ hours to transition to tailwheels after 1000's of hours in nosedraggers. For anyone who's interested, here's my story of transitioning: First, my statistics: 640 hours total time, private pilot, single engine in August 1990, instrument in 1997. Most of my time has been in my Cherokee 140 (approx. 560 hours), with the balance spread out in various Cessnas. Within the last year or so I've been flying approximately 10-15 hours per month. Last August I found a local fish & game pilot who was offering lessons in his SuperCub. I flew 2.2 hours with him at that time. He wasn't all that wild about renting the Cub after the signoff so I didn't continue the lessons with him. Since I sold the Cherokee and was (am) suffering from serious airplane withdrawal, I started looking for a local tailwheel airplane for rent. I found a Citabria GCBC at a nearby airport. $48/hour wet with no club fees or dues. Rental requirement was a checkout with one of their instructors. No minimum number of hours or hours in make and model required. I started flying on Wednesday and Sunday each week. I've taken a total of 5 lessons (approx. 6 hours) and my instructor informed me last night that he's going to solo me on Sunday. To anyone worrying about whether or not to build a tailwheel version of whatever RV, let me just offer the following: TAILWHEEL FLYING IS NOT THAT DIFFICULT. I am no superpilot and I will transition in less than 10 hours! I don't know if this is longer or shorter than usual. I might be setting myself up for ridicule admitting that it took me a whole 10 hours, but it doesn't really matter to me. I just wanted all of you who are out there wondering just what's really involved to hear a real-life recent story of a mere mortal pilot transitioning to a tailwheel bird. Happy flying to everybody. Rod Woodard Loveland, Colorado RV-8, #80033 (wings arriving in 3 weeks?!?) ________________________________________________________________________________
Date: Jun 19, 1997
Subject: !! Virginia State EAA Regional Fly-In !!
--> RV-List message posted by: Kevin Shelton CALLING ALL RV ENTHUSIASTS! Mark your calendars. June 28-29, 1997 Virginia is having its First Annual State Fly-in!! Virginia State EAA Regional Fly-In sponsored by the Virginia Council of EAA chapters, with support from the Virginia Department of Aviation, will take place at Petersburg-Dinwiddie Airport (KPTB). Pancake breakfast Sunday morning from 8:00 a.m.- 11 a.m. Homebuilts, War Birds, Ultralights. Forums, workshops, seminars. Aircraft Judging and Awards. Aviation fun for everyone! They are really trying to make it the Mid-East coast sun'n fun, but not so huge to make it difficult to get in and out. PTB is ~20nm SSE of Richmond (KRIC). Lets see a great RV turn-out and have a good time! Hope to see you there. More info at http://members.aol.com/N100RV/EAA_Council.html Kevin Shelton KA4UWE NASA Langley Research Center, Hampton VA (757) 864-4470 k.j.shelton(at)larc.nasa.gov http://members.aol.com/EAA156 ________________________________________________________________________________
Subject: Re: Master & battery relays on Battery Box?
Date: Jun 19, 1997
--> RV-List message posted by: ebundy(at)juno.com (Ed Bundy) >I need some input from those of you who have mounted your master and >battery relays on the battery box. It appears that this would make it >difficult to remove the battery box and gain access to the battery >without disconnecting cables from the relays. > >How did you do it? WHere and how did you run the cable from the >battery to the master relay, and the cable from the starter relay to the starter? Hi Dave. I wondered about that too. I ended up mounting both relays on the firewall (inside) within a few inches of the battery box. The cables enter the side of the box at the front. These go through thick grommets placed in a "U" shaped hole in the box so the box can be pulled rearward leaving the cable and it's grommet intact next to the firewall. If this is unclear I can try again. The master relay is on the right side of the box, and the starter relay is on the left side. The cable from the starter relay goes directly from the starter to the relay, eliminating any bends or twists inside the firewall. Ed Bundy RV6A - first flight 11/20/96 ebundy(at)juno.com - Eagle, ID ________________________________________________________________________________
Subject: cabin air
Date: Jun 19, 1997
--> RV-List message posted by: "Stephen J. Soule" There was a good write-up in Sport Aviation about high and low pressure mapping of Steve Barnard's RV last month. It might reveal the location of high and low pressure areas on your RV-4's. Steve Soule Huntington, Vermont ________________________________________________________________________________
Date: Jun 19, 1997
--> RV-List message posted by: Charlie Kuss Chet, I'm not the "spelling police" but it might be easier to find the product refered to below if you know that it's called HYLOMAR. Locktite makes it under licinse from Rolls Royce. I get it at my local auto parts store. i think it's a great product too. One advantage it has over other sealers is that if you are sealing a surface that has an oil or cooling passageway going through it, there is no chance of plugging the passageway up if you use too much Hylomar near it. Since it never becomes totally hard, any excess which blocks the passageway (like an oil galley/return) will be pushed through by the passing fluid. Gasoline definitely desolves RTV. Charlie Kuss RV-8 tail kit came yesterday REPLY TO CHET RAZER Re: Carb mounting Chet, Things might have changed, but RTV and gasoline do not like each other. I used to use a product, on race car fuel cells, that I believe was called "HYLIMAR", made by Rolls Royce of England. ________________________________________________________________________________
Date: Jun 19, 1997
From: dougm(at)mailhost.physio-control.com (Doug Medema)
Subject: Part numbers
--> RV-List message posted by: dougm(at)mailhost.physio-control.com (Doug Medema) I need a favor: I can't find my dang optional parts catalog and want to order a couple of things. Specifically: Could someone email me with the part numbers (and listed price) for the left and right steps? Thanks in advance. Doug Medema email: dougm@physio-control.com -6A, skinning the fuselage. P.S. Sure would be nice if VANS would get the whole parts catalog on their web page. Hint, Hint! ________________________________________________________________________________
Date: Jun 19, 1997
Subject: Re: LED Dimmer
--> RV-List message posted by: Charlie Kuss Mark, A very simple way to accomplish this would be to tie all the ground leads of your LED's together. Run one common wire to a rheostat. Run another wire from the rheostat to ground. This is how the dome light circuit on your car works. Most circuits have constant ground and a switched power source. This circuit merely installs a variable resistor (rheostat) into the path from the LED's to ground. Mercedes Benz, Honda and others use seperate instrument panel dimmer switches (rheostats). One of these would work great. Charlie Kuss RV-8 tail kit came yesterday Mark S. Malone wrote: snipped > I need some help from the electronics gurus. I'm putting .125" LED's > above each switch on my panel. The LED will light when the switch is > energizes the equipment, i.e., pitot heat, nav lights, strobe lights, > etc. I would like to be able to dim the LED's with a single dimmer. ________________________________________________________________________________
From: "Darrell L. Anderson" <d.l.anderson(at)worldnet.att.net>
Subject: Master & battery relays on Battery Box?
Date: Jun 19, 1997
--> RV-List message posted by: "Darrell L. Anderson" --> RV-List message posted by: Bob Skinner -Snip- The two relays are mounted side by side with the terminals verticlely. -Snip- I seem to remember reading somewhere that relays should be mounted with the terminals horizontal, so that the solenoid armature would not drag in the coil due to gravity. Can anybody help on this. Vertical will probably work...for a while. D. Anderson RV-4 (wings) ________________________________________________________________________________
Date: Jun 19, 1997
Subject: Re: Tailwheel Transition Story
--> RV-List message posted by: Robert Acker >To anyone worrying about whether or not to build a tailwheel version of >whatever RV, let me just offer the following: TAILWHEEL FLYING IS NOT THAT >DIFFICULT. > >Rod Woodard Thanks Ron! Now I won't feel so bad when I look at my tailspring. It regularly taunts me with "think you can handle it Mr. Nosegear?" type jabs...but no more . Rob Acker / r.acker(at)ix.netcom.com / RV-6Q ________________________________________________________________________________
Date: Jun 19, 1997
--> RV-List message posted by: Mike Wills Its my understanding that the ideal place for an outlet is in a low pressure turbulent flow point on the airframe. The intent is to allow the low pressure to help draw the air out. If placed correctly the exit can be smaller ofr the same amount of airflow. Typically the bottom of the fuse is a high pressure point. In fact according to theory (as told by far more knowledgeable people than me) the cooling system used on our RV's is all wrong and is a concession to aesthetics. Air should enter at the bottom of the cowl, flow up through the engine baffling, and out at the top or sides of the cowl. Look at the AR-5 or Rutan's Boomerang and see how the exits were done. Tony B. also has some examples in one of his books. Mike Wills RV-4 (wings) willsm(at)manta.nosc.mil >boots. I am sure that they did not want air getting out at the wrong place. >what about an out let on the fuse bottom as someone suggested? > >Tom Martin > > > ________________________________________________________________________________
Date: Jun 19, 1997
Subject: Re: LANDINGS: Correction/Apology
--> RV-List message posted by: mauser(at)claris.com (Richard Chandler) > We would like to offer a correction and an apology to those of you > who have received the first issue of the LANDINGS DIGI-NEWS with a > wrong reply address. > > The correct reply address should have been landings-diginews@ > landings.com (as specified at the end of the mailing). Instead > it appeared as NoReply(at)NoReply.org. This was an > unintentional, unfortunate error for which we would like to offer our > most sincere apology. > > We hope that you found the content of the LANDINGS DIGI-NEWS of > interest and of value. > > Thanks for your forbearance :-) So basically you're telling us that you used the RV list to generate a mailing list that you used for the spam I received this morning? Yeah, I got two copies of the message that claimed to contain news (And may have) but consisted mainly of teasers to make people go to your web site to read the rest of the articles. Even if your spirit is pure, spam is wrong, and using the RV-List to gather addresses is personally offensive to me. AND you patronized the creators of spam-generating software, designed to forge headers and duck resposibility for messages (NoReply.org). You gave money to the lowest of the low, the people who are ruining the net for everyone. I remember seeing your site ages ago and commenting about some bad HTML practices, like the nearly 500 character title you had in the tag. I sent you mail telling you how that might cause some browsers to crash since they all set the window title to the <TITLE>. No response, and no change. -- On the Internet, nobody knows you're a dog... but they can tell right off the bat if you're an idiot! -- Me <a target="otherpages" href="http://www.teleport.com/~mauser/">http://www.teleport.com/~mauser/</a> Gallery Web Page "Yeah, I've got ADD, wanna make something of.... oooh, cool. Look!" ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Edward Cole <emcole(at)concentric.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Part numbers</u></b></i></font></td></tr></table> --> RV-List message posted by: Edward Cole <emcole(at)concentric.net> Doug Medema wrote: > > --> RV-List message posted by: dougm(at)mailhost.physio-control.com (Doug Medema) > > I need a favor: I can't find my dang optional parts > catalog and want to order a couple of things. > > Specifically: Could someone email me with the part > numbers (and listed price) for the left and right steps? > > Thanks in advance. > > Doug Medema email: <a href="mailto:dougm@physio-control.com">dougm@physio-control.com</a> > -6A, skinning the fuselage. > > P.S. Sure would be nice if VANS would get the whole > parts catalog on their web page. Hint, Hint! I don't have the catalog in front of me but I believe they are $79 each Ed Cole ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"les williams" <lesliebwilliams(at)msn.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Part numbers</u></b></i></font></td></tr></table> --> RV-List message posted by: "les williams" <lesliebwilliams(at)msn.com> RV-6/6A STEP KIT LEFT $79.50 RV-6/6A STEP KIT RT $79.50 (Taken from April '97 Accessories Catalog) Les ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Grant E. Young" <gyoung(at)crl.nmsu.edu></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Tailwheel Transition Story</u></b></i></font></td></tr></table> --> RV-List message posted by: "Grant E. Young" <gyoung(at)crl.nmsu.edu> Hi, I would just like to second Ron's tailwheel transition story...I just had my first "conventional gear" lesson on Monday, and to be honest, I was a bit nervous about it. However, it was great. Granted, we only did a few landings and about 15 minutes of taxiing, but it was just no problem at all. My only impression is that you have to have your feet on the rudder peddles all the time and really be ready to use them. I have little doubt that after a few more lessons, I'll definitely be ready for my RV-6 (but, will it be ready for me???). BTW, I only have 230 hours TT. On another note, just curious what people have used to fill in the pop rivet holes after priming and before painting. grant in NM ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Michael Gamble" <Micky_G(at)msn.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Computers on board?</u></b></i></font></td></tr></table> --> RV-List message posted by: "Michael Gamble" <Micky_G(at)msn.com> I may be blowing smoke here, I'm not sure, but wouldn't the interference from the computer discounting the power supply, and monitor, be confined to what ever the clock rate of the computer? I mean if the processor is running at 133mhz, wouldn't the crystal that sets the rate be emitting at 133mhz? I guess I really don't understand the problem. When I get the opportunity, to build a plane, I'd like to be able to do some experimenting with a computer on board. I think the biggest problem with any installation and one that makes me curious about the other computer installations, is a reliable power supply? Anyone who has seen the inside of a good computer power supply will understand how much filtering is done to get a reliable 5 volt DC supply. Mick ---------- From: owner-rv-list(at)matronics.com on behalf of Frank van der Hulst Sent: Thursday, June 19, 1997 3:20 AM Subject: Re: RV-List: Computers on board? --> RV-List message posted by: Frank van der Hulst <frankv(at)pec.co.nz> I have a *little* experience and knowledge of this stuff. Firstly, a lot of the RF from computers comes from the high-voltage circuitry in the CRT screen. If the intereference varies depending on what's on the screen, then the screen is the source of the problem. If you have an LCD screen, I believe this is a non-issue. Secondly, a fair amount of the rest comes from the power supply. I think that a computer running off its batteries (which are being recharged from the 12V DC supply) won't generate much noise from the power supply compared to a 220V power supply. Thirdly, the higher clock speed CPUs generate RF direct from the motherboard. However, many of these (and especially on laptops) now run on 3V instead of 5V. Maybe they'll be less noisy? Fourthly, I think good design can remove/reduce the RF. A cheap PC with a cheap power supply will be much noisier than a quality machine. Direct experience: my old Taiwanese 8088 caused my neighbour across the road to complain about how it interfered with his TV. However, this only affected one channel (of two). So the RF emitted may be on only a few frequencies. In this case, I figured the problem was the PC's power supply. Fifthly, I have used a laptop (IBM Thinkpad 720C) as a moving map and logger for my GPS a couple of times in a C172. On neither occasion did I notice any adverse effects on the radios (or anything else). However, I didn't do much in the way of checking for these adverse effects. As I said, my knowledge is limited; I'm open to correction. My experience is more in terms of software than hardware. Frank. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Mark S. Jennings" <markjenn(at)halcyon.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>In strument Panel Tilt and Attitude Gyros</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "Mark S. Jennings" <markjenn(at)halcyon.com> >> Incidentally I've always set the AG in trigears while on the ground just >> before takeoff so that the miniature airplane is centered on the artificial >> horizon. Is this imprecise and is it considered better form to adjust it in >> the air when you know you're level at cruise? For VFR, is doesn't matter much. But for IFR, I think it is very important. It IS NOT critical that you adjust it to any absolute position; it IS critical that you adjust it once, leave it alone, and use this calibration to develop a set of power settings and pitch attitudes that result in predicatable climb/descent performance for the different phases of IFR flight: initial climb, cruise climb, cruise, cruise descent, glideslope descent, and go-around. I fly IFR infrequently and having these "numbers" memorized is the only way I can fly comfortably and smoothly. Your settings will make most sense if you adjust the airplane to lay on the horizon when you are in normal cruise. All explained in much greater detail in "Positive Flying" by Taylor/Gunther. Recommended, although the data in the book is for production stuff, not homebuilts. It does lay out what you need to do to calibrate your own plane. - Mark (RV8 wannabe) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>halk(at)sybase.com (Hal Kempthorne)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Master & battery relays - horizontal?</u></b></i></font></td></tr></table> --> RV-List message posted by: halk(at)sybase.com (Hal Kempthorne) My Debonair has gotten along alright with the original 1965 relays - but it is not the aerobatic version. hal > > I seem to remember reading somewhere that relays should be > mounted with the terminals horizontal, so that the solenoid > armature would not drag in the coil due to gravity. > Can anybody help on this. > > Vertical will probably work...for a while. > > D. Anderson > RV-4 (wings) > > > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>halk(at)sybase.com (Hal Kempthorne)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: cabin air</u></b></i></font></td></tr></table> --> RV-List message posted by: halk(at)sybase.com (Hal Kempthorne) Maybe Van just copied the way it is done on his Bonanza - in high & out low. Here is an interesting URL: <a target="otherpages" href="http://www.inforamp.net/~raac/CoolingSystems/CoolingSystemsIndex.HTML">http://www.inforamp.net/~raac/CoolingSystems/CoolingSystemsIndex.HTML</a> It is about liquid cooling but some of the stuff about airflow thru is applicable to air cooled too. hal > In fact according to theory (as told by far more knowledgeable people than > me) the cooling system used on our RV's is all wrong and is a concession to > aesthetics. Air should enter at the bottom of the cowl, flow up through the > engine baffling, and out at the top or sides of the cowl. Look at the AR-5 > or Rutan's Boomerang and see how the exits were done. Tony B. also has some > examples in one of his books. > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RELOSVCS!WESTREG!EHENSON(at)cldwell.attmail.com (Henson, Eric)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RE: Tailwheel Transition Story</u></b></i></font></td></tr></table> --> RV-List message posted by: RELOSVCS!WESTREG!EHENSON(at)cldwell.attmail.com (Henson, Eric) >>>>>Reply to Ron Woodard's excellent post on his tailwheel checkout:<<<<< Great Post Ron, us tailwheelers need more positive propaganda sent our way. Let me see if I can fill in the story, it took a total of 1hour to figure out how to taxi the thing, a couple of landings to master the 3 point landing and roll out, and then 8 or so hours to force yourself into the unnatural act they refer to as the crosswind wheels landing. "You want me to do what with this airplane?" Getting comfortable at forcing in down on the pavement while adding power was not the easiest thing I've ever done. Know what I mean? Eric Henson Dana Point, CA Skinning Right Wing ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Tailwheel Transition Story</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>tcraig-stearman(at)juno.com (John T. Craig-Stearman)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table> --> RV-List message posted by: tcraig-stearman(at)juno.com (John T. Craig-Stearman) >To anyone worrying about whether or not to build a tailwheel version >of >whatever RV, let me just offer the following: TAILWHEEL FLYING IS NOT >THAT >DIFFICULT. I am no superpilot and I will transition in less than 10 >hours! Bravo, Rod. There is absolutely no reason to be afraid of a tailwheel, especially one as gentle as an RV. Like any other new skill, it simply requires training to master. The improved awareness of your airplane's flight parameters makes you a better pilot. Happy landings, Tom Craig-Stearman tcraig-stearman(at)juno.com RV-4 on the gear ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"mcomeaux" <mcomeaux(at)cmc.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RV6</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "mcomeaux" <mcomeaux(at)cmc.net> Someone was advertising a RV6A or a straight 6 the other night is it still available? Ideleted the message and unable to find. I believe the wing and emmpenage was completed and it included the fuselage. Please send response to. mcomeaux(at)cmc.net Thanks--------Mike Comeaux ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"John B. Ciolino" <jbc1(at)ziplink.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Lex-aire HVLP spray gun</u></b></i></font></td></tr></table> --> RV-List message posted by: "John B. Ciolino" <jbc1(at)ziplink.net> RV Listers, I have been looking for a HVLP conversion paint gun ( i.e. runs off a standard compressor) and have some literature on a Lex-aire 2002 gun. I've searched the archives but can't find much in the way of recommendations on HVLP guns. Does anyone have experience with the Lex-aire gun? Any recommendations for a good HVLP gun? TIA John Ciolino jbc1(at)Ziplink.net RV-8 Working on Empannage ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Frank van der Hulst <frankv(at)pec.co.nz></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Computers on board?</u></b></i></font></td></tr></table> --> RV-List message posted by: Frank van der Hulst <frankv(at)pec.co.nz> msn.com!Micky_G(at)matronics.com wrote: > --> RV-List message posted by: "Michael Gamble" <Micky_G(at)msn.com> > > I may be blowing smoke here, I'm not sure, but wouldn't the > interference > from the computer discounting the power supply, and monitor, be > confined to > what ever the clock rate of the computer? I mean if the processor is > running at 133mhz, wouldn't the crystal that sets the rate be emitting > at > 133mhz? I guess I really don't understand the problem. Yes, the crystal runs at 133MHz (or maybe a multiple of that). But it's not that simple. Firstly, the 133MHz clock signal is a square wave, which can be thought of as lots of sine waves added together. These sine waves are multiples of the 133MHz, and called harmonics. IIRC, a square wave is made up of the fundamental (f, say 133MHz) + 1/3 f^3 + 1/9 f^9 + .... Secondly, there's other crystals too (1.8432MHz for the serial port, for example) and their harmonics. Then there's the beat frequencies generated by any two frequencies, which occur at lower frequencies than the original two. Thirdly, the 133MHz is the maximum rate at which changes happen on the bus. Depending on instructions, etc, any bus line may have transitions on it at any lower frequency whose period is a multiple of the 133MHz period (ie generate frequencies of 66.5MHz, 44MHz, 33.25MHz, 26.5MHz, etc.) These are of course square waves, so their harmonics apply. They will also generate beat frequencies with other signals. Frank (partially-sighted, leading the blind... where is Bob Nuckolls when you need him???) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Finn Lassen <finnlass(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RV-3 wet wings</u></b></i></font></td></tr></table> --> RV-List message posted by: Finn Lassen <finnlass(at)ix.netcom.com> I want to turn part of my tank-less wings into fuel tanks. If anybody has experience - good or bad - with glass (epoxy) to aluminum bonding, please let me know. I'd also appreciate any ideas on alternative materials - could I make bladders out of some kind of rubber or other material? Plastic? I imagine I could connect bladders through the rib lightening holes - two rings of ALU bolted or rivited together. I saw fuel bladders at Sun'n'Fun but unfortunately didn't pay close attention to them. Finn (strenghtening the wing spars) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Finn Lassen <finnlass(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Computers on board?</u></b></i></font></td></tr></table> --> RV-List message posted by: Finn Lassen <finnlass(at)ix.netcom.com> Michael Gamble wrote: > I may be blowing smoke here, I'm not sure, but wouldn't the interference from > the computer discounting the power supply, and monitor, be confined to what > ever the clock rate of the computer? I mean if the processor is running at > 133mhz, wouldn't the crystal that sets the rate be emitting at 133mhz? No. The 133 MHz gets "divided" down to for example 33 MHz on the PCI bus, in addition to a mutitude of other frquencies, depending on activities on the various busses (memory, I/O, etc.). Each of the above signals are close to being square wawes (or going from 0 to 5 volts, and 5 volts to 0 volts very quickly, thus also containing odd harmonics of their basic frequencies (e.g. 3 x 133 Mhz, 5 x 133 MHz, etc.). In summary, you have a very broad spectrum of frequencies ranging from very low, up through multiples of the (highest) clock frequencies (CPU, video card, etc.). Lowest overall intensity when CPU is idling and highest with lots of computing and I/O activity. Really the solution is metal (ALU will do) enclosures, with numerous small cooling holes and filtered in and outputs (signal and power lines), using shielded (and grounded) cables. I do not believe that even an LCD screen is exempt for radiating. But again that can be handled with a metal enclosure and a fine metal mesh in front on the screen. None of this is unhandable and is probably best done on a trial and error basis, with basic shielding as above, then sitting in the plane with a handheld scanner (108 - 137 MHz) to see if your're picking up and serious interference (compared with somewhat distant normally audible stations). ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"les williams" <lesliebwilliams(at)msn.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Tailwheel Transition Story</u></b></i></font></td></tr></table> --> RV-List message posted by: "les williams" <lesliebwilliams(at)msn.com> In the couple that I wanted to pretend weren't pop rivets, I used Duraglas (chopped fiberglass strand filler) sanded down smooth, followed by a glazing type filler. Otherwise, I let pop rivets be pop rivets, and did nothing! Les Williams/RV-6AQ/N24LW (res)/RV6-A N299LJ sold 10/95 ---------- From: owner-rv-list(at)matronics.com on behalf of Grant E. Young Sent: Thursday, June 19, 1997 1:33 PM Subject: Re: RV-List: Tailwheel Transition Story --> RV-List message posted by: "Grant E. Young" <gyoung(at)crl.nmsu.edu> Hi, I would just like to second Ron's tailwheel transition story...I just had my first "conventional gear" lesson on Monday, and to be honest, I was a bit nervous about it. However, it was great. Granted, we only did a few landings and about 15 minutes of taxiing, but it was just no problem at all. My only impression is that you have to have your feet on the rudder peddles all the time and really be ready to use them. I have little doubt that after a few more lessons, I'll definitely be ready for my RV-6 (but, will it be ready for me???). BTW, I only have 230 hours TT. On another note, just curious what people have used to fill in the pop rivet holes after priming and before painting. grant in NM ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Bob Skinner <BSkinner(at)navix.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Master & battery relays on Battery Box?</u></b></i></font></td></tr></table> --> RV-List message posted by: Bob Skinner <BSkinner(at)navix.net> >I seem to remember reading somewhere that relays should be >mounted with the terminals horizontal, so that the solenoid >armature would not drag in the coil due to gravity. >Can anybody help on this. > >Vertical will probably work...for a while. > >D. Anderson >RV-4 (wings) I think it's the other way around but I could be wrong. I mounted mine vertically because that's how I felt it worked out best and after the fact, I think I read that this is the way it should be done. I remember thinking, "boy, lucked out on that one". Bob Skinner RV-6 BSkinner(at)navix.net ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>colquitt(at)ns1.onramp.tuscaloosa.al.us</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: cabin air</u></b></i></font></td></tr></table> --> RV-List message posted by: colquitt(at)ns1.onramp.tuscaloosa.al.us Carroll A. Bird asked me: > Where do you get these round aluminum disks? Probably a Home Depot or Lowe's Building Supply or the equivalent in your area. Just look for a *big* building supply store. My air egress vent is in an inspection panel 4 inches below the horiz stab. I can't speak for Spitfires but it works in an RV. I've flown other canopied airplanes, and if you look at the trailing edge of the canopy in flight you will notice that it is raised due to being pressurized by the incoming air not having an exit point other than leaks and pushing up the canopy. I first noticed this on the way to Oshkosh in 1980 while flying a Mustang II in a rain. We kept getting wet - the rainwater would run down the canopy and tuck under at the back where the canopy had raised off the fuselage due to pressure inside and lifting force on the outside - the canopy is shaped like an airfoil, is it not. The airflow then would "throw" the rain forward and hit us in the back of the head and neck. Talk about drag - I'd like for an aeronautical engineer to calculate that! Joe Colquitt Flying - well ventilated - RV-3, but a Spitfire it ain't. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>colquitt(at)ns1.onramp.tuscaloosa.al.us</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Tailwheel Transition Story</u></b></i></font></td></tr></table> --> RV-List message posted by: colquitt(at)ns1.onramp.tuscaloosa.al.us > I found a Citabria GCBC at a nearby airport. I used to own a Citabria 7KCAB (the aerobatic, 150hp version Citabria). They're *harder* to handle than an RV. > I've taken a total of 5 lessons (approx. 6 hours) and my instructor informed me last night that > he's going to solo me on Sunday. > > To anyone worrying about whether or not to build a tailwheel version of > whatever RV, let me just offer the following: TAILWHEEL FLYING IS NOT THAT > DIFFICULT. Just remember Rod, that the day you get comfortable and complacent, and the wind is just right, or the brakes are just wrong, or something, tailwheel airplanes will make you humble. I've owned a number of them and have flown others, including taking and giving instructions in them - and yes, while checking myself out in a Hyperbipe that I once owned I got reminded with a nice no-damage 270 degree turn off the runway. And I've seen better pilots in the grass - two upside down - one killed. Tailwheel airplanes just ask for respect - and attention. The RV series is one of the best behaved of the bunch. Personally, I own a taildragger and I'm building another one. They're not dangerous - just pay attention - all of the time, please. Joe Colquitt Flying RV-3A ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Craig Nelson <cgn(at)pond.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Alternator modifications, Avionics order</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table> --> RV-List message posted by: Craig Nelson <cgn(at)pond.net> Tim, My '85 VW Vanagon camper has a 95 amp alternator. I can't remember thought if it is internal or external regulated cgn(at)pond.net Craig G. Nelson Eugene, OR building RV-6 empenage, nearly completed wing kit in the shop ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>dralle(at)matronics.com (Matt Dralle 510-606-1001)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Source For Special Washer...</u></b></i></font></td></tr></table> --> RV-List message posted by: dralle(at)matronics.com (Matt Dralle 510-606-1001) Does anyone know where I could obtain some #6 black plastic/nylon washers? I found some nice nylon washers that would work, but there are white and would be very ugly. Thanks for any tips... Matt Dralle RV-4 N442RV (Soon...) -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 510-606-1001 Voice | 510-606-6281 FAX | dralle(at)matronics.com Email <a target="otherpages" href="http://www.matronics.com/">http://www.matronics.com/</a> W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Tim Lewis" <<a href="mailto:timrv6a@germany-c.it.earthlink.net">timrv6a@germany-c.it.earthlink.net</a>></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV-3 wet wings</u></b></i></font></td></tr></table> --> RV-List message posted by: "Tim Lewis" <<a href="mailto:timrv6a@germany-c.it.earthlink.net">timrv6a@germany-c.it.earthlink.net</a>> > I > imagine I could connect bladders through the rib lightening holes - two > rings of ALU bolted or rivited together. I saw fuel bladders at > Sun'n'Fun but unfortunately didn't pay close attention to them. Here's an idea, perhaps you can use it: There exists an STC for the Grumman AA1 which uses a long tube (as big around as the existing rib lightening holes) as an auxiliary fuel tank. I don't know what it's made of for sure, but I think it's aluminum. Perhaps the Grumman design could serve as a basis for an RV implementation. If you'd like more info I'll dig thru my old Grumman info and find a contact. One thing I didn't like about that fuel tank design: A fuel imbalance imparts quite a rolling moment to the aircraft. One either switches tanks frequently or uses the armstrong method to hold wings level. Tim --------------------- Tim Lewis RV-6AQ #60023 San Antonio TX timrv6a(at)earthlink.net or timrv6a(at)iname.com ----------------------- ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RodWoodard <rodwoodard(at)mcione.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RE: Tailwheel Transition Story</u></b></i></font></td></tr></table> --> RV-List message posted by: RodWoodard <rodwoodard(at)mcione.com> ---------- > --> RV-List message posted by: RELOSVCS!WESTREG!EHENSON(at)cldwell.attmail.com (Henson, Eric) > > >>>>>Reply to Ron Woodard's excellent post on his tailwheel checkout:<<<<< > > > Getting comfortable at forcing in down on the pavement while adding power > was not the easiest thing I've ever done. Know what I mean? Yes I _do_ know what you mean. I can grease the thing on every time with a three point. Out of my last 30 landings, I think 25 of them have been wheel landings... or at least attempts at wheel landings. I kind of do things by feel when I fly and I think I've finally got the "feel" of a wheel landing. I just finished watching a video tape of Wednesday's session and there was only one landing that I cringed at when I reviewed the tape. I kind of forced the thing on the ground, got the predictible bounce and balloon and ended up adding a little power and converting it into a 3-point. It didn't even look that bad on the video tape! Take care... and wish me luck! :-) Rod Woodard RV-8, #80033 Loveland, Colorado ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Tom Martin <fairlea(at)execulink.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: cabin air</u></b></i></font></td></tr></table> --> RV-List message posted by: Tom Martin <fairlea(at)execulink.com> >--> RV-List message posted by: colquitt(at)ns1.onramp.tuscaloosa.al.us > > >My air egress vent is in an inspection panel 4 inches below the horiz >stab. I can't speak for Spitfires but it works in an RV. > >I've flown other canopied airplanes, and if you look at the trailing >edge of the canopy in flight you will notice that it is raised due to >being pressurized by the incoming air not having an exit point other >than leaks and pushing up the canopy. > >I first noticed this on the way to Oshkosh in 1980 while flying a >Mustang II in a rain. We kept getting wet - the rainwater would run >down the canopy and tuck under at the back where the canopy had >raised off the fuselage due to pressure inside and lifting force on >the outside - the canopy is shaped like an airfoil, is it not. The >airflow then would "throw" the rain forward and hit us in the back of >the head and neck. Talk about drag - I'd like for an aeronautical >engineer to calculate that! > I too had the problem with the canopy rear skirt raising. I solved that by putting faring the rear portion of the skirt into the turtle deck. No drafts in the winter and it looks better too. Tom martin RV-4 still looking for other cabin air vent ideas ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>catbird(at)taylortel.com (TTC Carroll A. Bird)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Lex-aire HVLP spray gun</u></b></i></font></td></tr></table> --> RV-List message posted by: catbird(at)taylortel.com (TTC Carroll A. Bird) John B. Ciolino wrote: > > --> RV-List message posted by: "John B. Ciolino" <jbc1(at)ziplink.net> > > RV Listers, > > > > Does anyone have experience with the Lex-aire gun? Any recommendations for > a good HVLP gun? > > TIA > > John Ciolino > jbc1(at)Ziplink.net > RV-8 Working on Empannage I bought a Lex-Aire about two months ago. I have painted the cockpit a light gray with a clear coat. It handeled these materials quite well. It is very easy to use. I had never painted any thing with a sprayer except the primer on my -4. I had a little problem with the trigger sticking, and called them about it, they sent me a new one right away. Works fine now. If you get one you will be surprised at how well it performs. Carroll Bird RV-4 on the gear. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>John Darby <<a href="mailto:johnd@our-town.com">johnd@our-town.com</a>></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Master & battery relays on Battery Box?</u></b></i></font></td></tr></table> --> RV-List message posted by: John Darby <<a href="mailto:johnd@our-town.com">johnd@our-town.com</a>> >>I seem to remember reading somewhere that relays should be >>mounted with the terminals horizontal, so that the solenoid >>armature would not drag in the coil due to gravity. >>Can anybody help on this. D. Anderson; For what it's worth, I think this can be placed in the file of things to discuss on a rainy day while sitting around the fire with nothing to do because the wx is 0-0. I heard the same type of argument when I was a very young boy, the talkers were the mechanics who argued as to straight fours and sixes vs. V-8s when they (V-8s) first came out. That the pistons would too soon wear out on one side because of gravity (on the V-8s). You can tell the results, because I'm sure you have noticed, there are almost no successful V or slant type engines, not even many flat opposed engines.:-) When you say the terminals horizontal, I assume then the piston inside the relay is operating in the vertical plane. The argument I've heard in the past recent years is that the G forces, along with the spring force, would cause the piston to override the magnetic force and cause the piston to move down and results-disconnect of the points. So the argument is that the piston should be DOWN (below the terminals) so that the G forces would tend to keep the points connected. I think that this, although very unlikely unless Gs caused by catastrophic impact, is not to be worried about. Stop and think about the inside construction of the unit. If in question, go to your nearest auto parts store (NAPA?) and ask to see the book that has the info on the relays/solenoids and study that a little. It has schematics, location of points, spring, etc. A little reasoning helped me make up my own mind on it. Added to that was my complete tear down of the first one that failed on me. It was the points that went bad, not drag etc. John Darby RV6 sold Stephenville TX <a href="mailto:johnd@our-town.com">johnd@our-town.com</a> ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Darrell L. Anderson" <d.l.anderson(at)worldnet.att.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Master & battery relays on Battery Box?</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "Darrell L. Anderson" <d.l.anderson(at)worldnet.att.net> With more thought on this, you are probably right. A horizontally installed armature would be less susceptible to + or - G shock that would tend to push/pull the contacts out of their preferred position. Also, they seem to have no obvious drain or vent that needs to be in any particular orientation. Bob Nuckolls' Aeroelectric Connection, section 11 "Switches Relays and Contactors" says nothing on installation orientation, but gives lots of info on selection, operational theory, etc. He may have some personal insight on this. --> RV-List message posted by: Bob Skinner <BSkinner(at)navix.net> >I seem to remember reading somewhere that relays should be >mounted with the terminals horizontal, so that the solenoid >armature would not drag in the coil due to gravity. >Can anybody help on this. > >Vertical will probably work...for a while. > >D. Anderson >RV-4 (wings) I think it's the other way around but I could be wrong. I mounted mine vertically because that's how I felt it worked out best and after the fact, I think I read that this is the way it should be done. I remember thinking, "boy, lucked out on that one". Bob Skinner RV-6 BSkinner(at)navix.net ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Darrell L. Anderson" <d.l.anderson(at)worldnet.att.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RV-3 wet wings</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "Darrell L. Anderson" <d.l.anderson(at)worldnet.att.net> I saw a magazine article somewhere, maybe Kitplanes or Sport Aviation, that showed sealing of the aft rib bay of, I think, a Midget Mustang? They used Pro Seal, just like the RV's, to seal up the structure. I would think you would have to add some stiffeners to the skin to support the added weight of the fuel, rivet in covers for the lightening holes, add fuel filler, vent, pickup, drain, and gauge sender, and seal up the access cover. The most difficult thing on an already constructed wing might be getting the metal clean for the Pro Seal application. There is a thinner consistency ProSeal, (A-2 instead of B-2) that is brushable and also a brushable air-dry top coat called PR-1000 that may be of help where "sloshing" is impractical. Check with Courtauld's Aerospace, they make Pro Seal. D. Anderson RV-4 (wings...fuel tanks done) --> RV-List message posted by: Finn Lassen <finnlass(at)ix.netcom.com> I want to turn part of my tank-less wings into fuel tanks. If anybody has experience - good or bad - with glass (epoxy) to aluminum bonding, please let me know. I'd also appreciate any ideas on alternative materials - could I make bladders out of some kind of rubber or other material? Plastic? I imagine I could connect bladders through the rib lightening holes - two rings of ALU bolted or rivited together. I saw fuel bladders at Sun'n'Fun but unfortunately didn't pay close attention to them. Finn (strenghtening the wing spars) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Jim Tennison" <jtennison.cmrl(at)veda.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>cabin air</u></b></i></font></td></tr></table> charset=US-ASCII --> RV-List message posted by: "Jim Tennison" <jtennison.cmrl(at)veda.com> Carefull, aircraft pressure mappings are very sensitive to the aircraft configuration. The RV-4 and RV-6 have different fuselage pressure distributions and relying on the RV-6 map to locate your RV-4 vents could result in poor vent performance. I recommend looking at an RV-4 pressure distribution during cruise conditions to locate an acceptable vent outlet. If there's enough interest from the list, I can help get this information for you. (I was planning to do it someday anyway). Jim Tennison RV-4 Horizontal Stab - Ex Northrop YF-23 Aerodynamicist ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Larry D. Hoatson" <lhoatson(at)e2.empirenet.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: spar construction]</u></b></i></font></td></tr></table> --> RV-List message posted by: "Larry D. Hoatson" <lhoatson(at)e2.empirenet.com> > more than six hours and the results were excellent. Mr. Klee had a great idea and I thank him for sharing it with me. When was the original "harbor freight press" posting? Any tips on where I can find it? Thanks, Larry -- Larry D. Hoatson Yucaipa, CA Redlands (L12) Airport lhoatson(at)empirenet.com KC6WYF via packet at: KC6WYF(at)W6JBT.SOCAL.CA.USA.NOAM Restoring 1950 Cessna 170A N9948A... Looking forward to RV-6 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: cabin air</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>less_drag(at)juno.com (JAMES E AYERS)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table> --> RV-List message posted by: less_drag(at)juno.com (JAMES E AYERS) ns1.onramp.tuscaloosa.al.us!colquitt(at)matronics.com writes: (Snip) >The airflow then would "throw" the rain forward and hit us in the back of >the head and neck. Talk about drag - I'd like for an aeronautical >engineer to calculate that! > >Joe Colquitt >Flying - well ventilated - RV-3, but a Spitfire it ain't. > > Hi All, Jerry VanGrunsven already determined this empirically, it costs 5 mph on an RV-3. I believe it was in a mid or late 1970's RVator. Jim Ayers Less_Drag(at)juno.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>steve(at)barnardaircraft.com (barnardaircraft)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: cabin air</u></b></i></font></td></tr></table> --> RV-List message posted by: steve(at)barnardaircraft.com (barnardaircraft) Hi Mike, The reason Rutan's Boomerang has cooling air outlets on the top of the cowlings is because he uses Lycoming turbocharged engines which are designed for updraft cooling, ie. most of the cooling fins are located on the bottom of the cylinder. Notice he also uses the somewhat standard location for the inlets even though they are rotated 90 degree's and much closer to the spinner. Mike Arnold's AR-5 uses water cooling with the Rotax so he has the convenience of locating them anywhere around the periphery of the fuselage. He chose the side which is neither increasing or decreasing in size. If you've seen any air flow diagrams of airplanes the front end is a very high pressure area for cooling inlets, and not the bottom of the cowling. It's hard to believe that Lancair IV's, Mooney Ovations, RV's have the incorrect location of cooling inlets. The Lycomings we use for our installations are designed for downdraft cooling. Van installed a lower inlet scoop below the spinner on the prototype and later changed to the standard location. Wonder why? Ask the man. The more I experiment with cooling inlets and outlets, some of the standard rules of thumb for cooling systems is becoming obsolete. One day we may have a more modern engine designed for airplanes that will let us take advantage of revised cooling systems. This is an area for great improvement even today. Note: Radial engines exit cooling air all around the periphery of the cowling. >Its my understanding that the ideal place for an outlet is in a low pressure >turbulent flow point on the airframe. The intent is to allow the low >pressure to help draw the air out. If placed correctly the exit can be >smaller ofr the same amount of airflow. Typically the bottom of the fuse is >a high pressure point. > In fact according to theory (as told by far more knowledgeable people than >me) the cooling system used on our RV's is all wrong and is a concession to >aesthetics. Air should enter at the bottom of the cowl, flow up through the >engine baffling, and out at the top or sides of the cowl. Look at the AR-5 >or Rutan's Boomerang and see how the exits were done. Tony B. also has some >examples in one of his books. > >Mike Wills >RV-4 (wings) >willsm(at)manta.nosc.mil Respectfully, Steve Barnard Barnard Aircraft Components RV-6A N157ST 1000 hrs flying steve(at)barnardaircraft.com <a target="otherpages" href="http://www.barnardaircraft.com">http://www.barnardaircraft.com</a> ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>halk(at)sybase.com (Hal Kempthorne)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Lex-aire HVLP spray gun</u></b></i></font></td></tr></table> --> RV-List message posted by: halk(at)sybase.com (Hal Kempthorne) Hi all, At our last EAA Chapter meeting, a Mr. Jim Body gave a sales pitch for Alumnigrip and gave lotsa lessons on painting. Someone asked for equipment recommendations. First and without hesitation, he praised Binks as his favorite. Mainly the Mach 1 HVLP gun which is not a conversion of a standard gun but an HVLP design. It runs on a compressor of 1.5 or 2 hp or more. I was surprised he did not mention Sharpe but not surprised he did not mention Lexaire. I wrote to Lexaire and asked them why I should buy their gun rather than the Binks which is the same money. In fact, if you talked sweet to a dealer it might be less. I asked how I would handle a warranty problem. I asked how I might suppose they would be there tomorrow, suggesting they might be a "fly by night" outfit. (What is wrong with flying by night?) I see that AC Sruce has Binks. Remove those Sharpie marks before painting as they may react with the paint. Hal Kempthorne RV-6AQ -- On main gear halk(at)sybase.com Santa Clara, CA. Debonair N6134V @ SJC > > I have been looking for a HVLP conversion paint gun ( i.e. runs off a > standard compressor) and have some literature on a Lex-aire 2002 gun. I've > searched the archives but can't find much in the way of recommendations on > HVLP guns. > > Does anyone have experience with the Lex-aire gun? Any recommendations for > a good HVLP gun? > > TIA > > > John Ciolino > jbc1(at)Ziplink.net > RV-8 Working on Empannage > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"David Moore" <dmoore8(at)tuelectric.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Master & battery relays on Battery Box?</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "David Moore" <dmoore8(at)tuelectric.com> > >I seem to remember reading somewhere that relays should be > >mounted with the terminals horizontal, so that the solenoid > >armature would not drag in the coil due to gravity. > >Can anybody help on this. > > I think it's the other way around but I could be wrong. I mounted mine > vertically because that's how I felt it worked out best and after the fact, > I think I read that this is the way it should be done. I remember thinking, > "boy, lucked out on that one". Horizontal/vertical - you are probably all saying the same thing (ie., what is you reference point - the casing or the terminal connections?). Try this - the cap on the housing should be on top. The terminal connections on a standard master are on the sides, not top and bottom. It is spring loaded and the solenoid works against the spring. Orientation may be critical during high G maneuvers. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RELOSVCS!WESTREG!EHENSON(at)cldwell.attmail.com (Henson, Eric)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RE: Lex-aire HVLP spray gun</u></b></i></font></td></tr></table> --> RV-List message posted by: RELOSVCS!WESTREG!EHENSON(at)cldwell.attmail.com (Henson, Eric) Hi John, If you can access the archives we had a great discussion on this about 6 months ago. If not I have used both Sharpe and DeVilvis gravity feed HVLP guns and they work as well as the painters technique will allow them. Prices run about $230.00 to $350.00. No gun is going to make up for lack of knowledge about paint aplication. My recomendation is to buy a good quality gun and then spend the money you saved by not buying a hot shot system on practice paint. This of course assumes your'e a newbie at the paint game, as I was a year ago. I now feel confident enough to paint my entire aircraft. Oh, any respectable dual stage compressor should handle the air volume. Eric Henson Dana Point, CA Wing Skins On ehenson(at)cldwell.attmail.com ---------- From: John B. Ciolino Subject: RV-List: Lex-aire HVLP spray gun Date: Thursday, June 19, 1997 8:40PM --> RV-List message posted by: "John B. Ciolino" <jbc1(at)ziplink.net> RV Listers, I have been looking for a HVLP conversion paint gun ( i.e. runs off a standard compressor) and have some literature on a Lex-aire 2002 gun. I've searched the archives but can't find much in the way of recommendations on HVLP guns. Does anyone have experience with the Lex-aire gun? Any recommendations for a good HVLP gun? TIA John Ciolino jbc1(at)Ziplink.net RV-8 Working on Empannage ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>LesDrag(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Cockpit Air Exit</u></b></i></font></td></tr></table> --> RV-List message posted by: LesDrag(at)aol.com << Hey Mr. Maurauder, In all of you "less drag" travels have you run into the cockpit ventilation exit issue? Thought I'd get your take on it, makes an interesting discussion. Thanks in advance, Eric Henson Dana Point, CA >> Hi Eric and all, The fuselage vertical skin joints on my RV-3 are all sealed (because the aft skin is on top of the front skin (to decrease drag by 1/3 per "Drag" by Hoerner)), so there is no air leakage. The horizontal skin joints are not sealed. Cockpit exit air can; 1. Go out the rear of the canopy. I have a side hinge canopy (similar to the RV-4). I can see the front seal rise off the front cowl by about 1/16" in flight. I haven't been able to "see" the rear seal. 2. Go through the baggage compartment and exit the tail cone at the existing clearance holes for the elevator. I've tried to encourage the air to leave this way by adding holes near the top of the rear baggage compartment close-out bulkhead. The HS spar in this area should act as a low pressure generator. However, I defeated this to some extent by installing an elevator fairing on the elevator root ribs. Rudder cable fairings can promote a low pressure area for exit air. However, my RV-3 doesn't have rudder cables, control horns, chains or springs outside the fuselage. (The rudder pedals should be modified to accomodate this, and two cable pulleys should to be installed.) Jim Ayers LOM M332A engine Maroon Ivoprop VP Prop "Sportcraft Antenna don't show" RV-3 N47RV Maroon Marauder LesDrag(at)aol.com Thousand Oaks, California USA <a target="otherpages" href="http://member.aol.com/lesdrag/rv3.htm">http://member.aol.com/lesdrag/rv3.htm</a> <a target="otherpages" href="http://member.aol.com/lesdrag/Ivoprop.htm">http://member.aol.com/lesdrag/Ivoprop.htm</a> ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Glenn & Judi <<a href="mailto:flyers@anet-chi.com">flyers@anet-chi.com</a>></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RV6 Panel mod.</u></b></i></font></td></tr></table> --> RV-List message posted by: Glenn & Judi <<a href="mailto:flyers@anet-chi.com">flyers@anet-chi.com</a>> Hi, RE: RV6 instrument panel sub-panel. How large would a sub panel have to be that would incorporate the carb heat, throttle and mixture controls in a horizontal configuration? Thanks in advance, Glenn Gordon ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Glenn & Judi <<a href="mailto:flyers@anet-chi.com">flyers@anet-chi.com</a>></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Elev Trim Control RV-6</u></b></i></font></td></tr></table> --> RV-List message posted by: Glenn & Judi <<a href="mailto:flyers@anet-chi.com">flyers@anet-chi.com</a>> RE: Manual elevator trim on the RV-6 Hi, Where are some alternative mounting locations for the manual elev trim control? Thanks in advnace, Glenn Gordon ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Don McNamara <mcnamara(at)sbt.infi.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>N-numbers</u></b></i></font></td></tr></table> --> RV-List message posted by: Don McNamara <mcnamara(at)sbt.infi.net> Listers-- I've noticed that many of you already have your N-numbers reserved. How did you go about doing this? --Don mcnamara(at)sbt.infi.net #80113 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Vanremog(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Source For Special Washer...</u></b></i></font></td></tr></table> --> RV-List message posted by: Vanremog(at)aol.com << Does anyone know where I could obtain some #6 black plastic/nylon washers? I found some nice nylon washers that would work, but there are white and would be very ugly. >> Matt- I get black .031 thk ones from Olander in Sunnyvale and have some in the hangar. I'll be out there this weekend if you want a few. Call me. 408-946-5381 -GV ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>JamesCone(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Canopy , Part Deux</u></b></i></font></td></tr></table> --> RV-List message posted by: JamesCone(at)aol.com << Dear Jim, I received a reply message to mine, but no words that responded to the question were enclosed. Could you try again. Thanks Ron Vandervort The question was regarding raising the canopy frame to roll-bar allignment and without the canopy setting on the assembly how does one know the angle of the plexiglas over the frame and roll-bar? >> Ron and Listers, I wondered what happened to the message I sent to you and posted a copy of to the list. It must have disappeared into cyperspace. As I said before, thanks for your comments about my newsletter. To answer you question about the canopy alignment, after you cut the top of the tube that goes through the center bar of the frame off, you can lay the Plexiglas on the roll bar and frame. You can then see that the slider part of the frame needs to be raised above the roll bar in order to line up with the Plexiglas. Don't drill the slider frame to the rollers until you figure out how high it needs to be. You can use short pieces of pipe as spacers to raise the slider frame into position for drilling. The articles in my newsletter show how to get a good fit on your canopy by yourself, without any help. You can do all of the trimming, fitting, and installation of the sides and rear skirts by yourself using the proceedures that I describe. My canopy fits perfectly and has no air or water leaks anywhere. I don't have any sealing material anywhere; not at the roll bar, not on the sides and not at the rear. I don't need any. If you follow my proceedures, you can get the same results without any help from anyone. One man canopy installation is a peice of cake if you know how to do it. Hope this helps. Sorry about loosing the first reply. Jim Cone, Editor Van's Air Force, Tri-State Wing Newsletter 422 Savannah Ridge Drive St. Charles, MO 63303 (314) 928-8703 jamescone(at)aol.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 19, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Jerry H. Prado" <jerryprado(at)wa.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Computers on board?</u></b></i></font></td></tr></table> --> RV-List message posted by: "Jerry H. Prado" <jerryprado(at)wa.net> Robert Acker wrote: > --> RV-List message posted by: Robert Acker <r.acker(at)ix.netcom.com> > > >> are involved in integrating a PC into my RV-8 to be? The > potential > >> application is a custom developed GPS/moving map display/flight > mgmt system > >> connected to a 6" panel mounted active matrix screen driven from a > P100 > >> cpu/motherboard (no "essential" functions). > > These devices already exist (Silvaire, Avidyne, Archangel, Peavy, > etc.). > They have screens optimized for direct sunlight viewing, flight > management > software developed & debugged, etc. > > If the objective is to have an airplane flying in a reasonable amount > of > time, you may want to consider one of these. I imagine rolling your > own > "flight PC" would take hundreds, if not thousands, of hours for > software > development alone. > > Rob Acker / r.acker(at)ix.netcom.com / RV-6Q I've been toying with moving maps for a long time and have been able to address most of the noise, cooling and space problems. What is keeping this from being affordable at this time is the cost of the displays. While a high-end active matrix display could be used, it will dissapear in direct sunlight. Some of the units that Rob mentions are backlit with an inverter and higher intensity lighting. Since there is a minmum 1:1 ratio of drive transistor to pixel, there is a substantial amount of noise radiated from the front of the panel. Some of these vendors use a metalized screen as a combination touch sensor and "shield". If I had the panel depth, power and money, I would use a real CRT in the panel and mount the CPU and storage device(s) remotely. The recent thread concerning a transient triggering an aborted reset in the RMI microMonitor made me think about some active power conditioning. Since the electronics in a PC operate on 5 volts, you would have to regulate it down. In the case of a Pentium, it gets dropped again to 3 volts. This much regulation would in effect, act as a conditioner. As far as software goes, you can buy several off the shelf packages that handle the moving map and flight management/planning. I can't imagine developing the software to handle anything other than these. Flightstar by MentorPlus is pretty decent but still locks up or crashes Windows occasionally. At least one of the vendors Rob mentions uses this product in a modified form. Jerry Prado 6A ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"les williams" <lesliebwilliams(at)msn.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RMI microEncoder & voltage transients</u></b></i></font></td></tr></table> --> RV-List message posted by: "les williams" <lesliebwilliams(at)msn.com> As a follow-up to my posting, I received only one direct response and there was one subsequent posting to the list. Both were positive. Must not be many users out there or mum's the word. I'm waiting for the update from RMI before I proceed one way or the other. Thanks. Les ---------- From: owner-rv-list(at)matronics.com on behalf of les williams Sent: Wednesday, June 11, 1997 7:08 PM Subject: RV-List: RMI microEncoder & voltage transients --> RV-List message posted by: "les williams" <lesliebwilliams(at)msn.com> WOW! This is the real POWER OF THE LIST in action. I just last week received my microEncoder kit, and after reading Bill's comments, I really questioned whether or not I should keep it or return it. I certainly don't want an electronic gismo that might go blip out in the middle of nowhere when I am using it for a primary flight instrument! It isn't like you can pull it and run to the nearest aviation supply store and pick up a replacement! I'm glad that Mr. Mowrer responded so quickly and offered up a "fix" for their product. But I wonder how long it would have been, and under what other circumstances this reaction would have been taken, if it were not for the "list"? I like the features of the microEncoder and hope that the experiences of Van's as related by Bill, is an isolated case. I would still like to use it, I think! Does anybody have any other comments, good or bad about it? Thanks, Les Williams/RV-6AQ/N24LW (res)/finish kit/RV-6A N299LJ sold 10/95 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>David Kerzie <dckerzie(at)qnet.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Installation - Constant Speed Spinner</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 20, 1997</i></b></font></td></tr></table> --> RV-List message posted by: David Kerzie <dckerzie(at)qnet.com> I've come across a couple of stumbling blocks while trying to install = the spinner to my constant speed prop (HC-C2YK-1BF/F7666A-4). =20 1. When placing the S-602B rear doubler ring over the four mounting = bolts, I found that the doubler strikes the prop hub before coming to = rest on the 1/4" spacers. Is it that I need longer spacers? The = constant speed spinner instructions mention a 1/4" spacer , but they = also mention a S-604 from Van's. Is the S-604 spacer longer? 2. Am I supposed to remove the inner 7.2" of S-601-1 so that it will = clear the prop mount and attach to S-602? The constant speed spinner = instructions mention in small print on the diagram that the center = portion is to be removed, but I just wanted to make sure that that was = standard practice. I don't want to hack away too much. Thanks for your help, Dave Kerzie RV-6 - engine mounted yesterday (thanks for the help, Jack!) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Jerry Springer <jsflyrv(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV6 Panel mod.</u></b></i></font></td></tr></table> --> RV-List message posted by: Jerry Springer <jsflyrv(at)ix.netcom.com> Glenn & Judi wrote: > > --> RV-List message posted by: Glenn & Judi <<a href="mailto:flyers@anet-chi.com">flyers@anet-chi.com</a>> > > Hi, > > RE: RV6 instrument panel sub-panel. > > How large would a sub panel have to be that would incorporate the carb > heat, throttle and mixture controls in a horizontal configuration? > > Thanks in advance, > Glenn Gordon Glen If you go to Matt's homepage you can find some pictures of examples of panels with the engines controls in the horizontal configuration. The picture of the panel of my RV-6 shows that I made my panel about 1.5" lower at the bottom and put the engine controls in the horizontal configuration. There is some good pictures of panels that show some other good ways of doing what you want. I never did like the vertical setup so removed it, and it makes much more leg room to move around and stretch on those long I've included a link to the RV-List homepage and to the picture of my panel. <<a target="otherpages" href="http://www.matronics.com/rv-list/index.htm">http://www.matronics.com/rv-list/index.htm</a>> <<a target="otherpages" href="http://www.matronics.com/ftp/Scans/RV/896jerry.jpg">http://www.matronics.com/ftp/Scans/RV/896jerry.jpg</a>> -- Jerry Springer RV-6 N906GS First flight July 14, 1989 :-) Hillsboro, OR jsflyrv(at)ix.netcom.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Stephen J. Soule" <SSoule(at)pfclaw.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RV-3 wet wings</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "Stephen J. Soule" <SSoule(at)pfclaw.com> With those long tubular fuel tanks, beware of fuel surging from wingtip to fuselage every time you bank. If you are going to put a long tube in the wing for gasoline, you might want to install some baffles inside the tube. A short tube may not pose the same problem. Steve ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Stephen J. Soule" <SSoule(at)pfclaw.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RE: RMI</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "Stephen J. Soule" <SSoule(at)pfclaw.com> Does RMI have a web page? What's the address? Steve ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>catbird(at)taylortel.com (TTC Carroll A. Bird)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: N-numbers</u></b></i></font></td></tr></table> --> RV-List message posted by: catbird(at)taylortel.com (TTC Carroll A. Bird) Don McNamara wrote: > > --> RV-List message posted by: Don McNamara <mcnamara(at)sbt.infi.net> > > Listers-- > > I've noticed that many of you already have your N-numbers reserved. How > did you go about doing this? > > --Don > mcnamara(at)sbt.infi.net > #80113Call the FAA in Ok City. They will be happy to help you. Carroll ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Denny Harjehausen <retflygtiger(at)proaxis.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: N-numbers</u></b></i></font></td></tr></table> --> RV-List message posted by: Denny Harjehausen <retflygtiger(at)proaxis.com> >--> RV-List message posted by: Don McNamara <mcnamara(at)sbt.infi.net> > >Listers-- > >I've noticed that many of you already have your N-numbers reserved. How >did you go about doing this? Don, Ijust went through that, and with the kind help of the net I finally got it right and my second choice. Which is good enough. You can check the numbers availablity thru sportflyer.com or www.avweb.com in their data pages. Write or phone FAA (405)954-3116 to get the paper work. You can check with the FAA if the selected numbers are available from your research. Msil it in and sha-bang you got it. Have Great Day! Denny RV-6 (R)N641DH Fuselage top side Lebanon, OR ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Cafgef(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: How much Time?</u></b></i></font></td></tr></table> --> RV-List message posted by: Cafgef(at)aol.com << "What's your projected completion date?" >> My projected completion date is June of 1996 and I'm sticking to that no matter what. Gene, 4 years into a 2 1/2 year project, still counting and still having fun. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Tim Lewis" <<a href="mailto:timrv6a@sweden-c.it.earthlink.net">timrv6a@sweden-c.it.earthlink.net</a>></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RMI microEncoder & voltage transients</u></b></i></font></td></tr></table> --> RV-List message posted by: "Tim Lewis" <<a href="mailto:timrv6a@sweden-c.it.earthlink.net">timrv6a@sweden-c.it.earthlink.net</a>> > --> RV-List message posted by: "les williams" <lesliebwilliams(at)msn.com> > > As a follow-up to my posting, I received only one direct response and there > was one subsequent posting to the list. Both were positive. Must not be many > users out there or mum's the word. I'm waiting for the update from RMI before > I proceed one way or the other. Thanks. > > Les Les, I elected to go with the EIS system from Grand Rapids Technology. My reasons: - EIS displays CHT, EGT, and OAT in Farenheit, umonitor is Celsius only - EIS displays two EGT and two CHT simultaneously (switchable to the other two cylinders, switch is free), with an upgrade to 4 CHT and 4 EGT simultaneously in the works. Rocky Mountain said they have no plans to upgrade their unit from 1 CHT and 1EGT at a time (switchable, switch costs extra and doesn't come with knob) - EIS will apply the full purchase price of the current system toward the price of the upgraded system, including probes. They put it in writing. - EIS may be returned for a full refund anytime within the first year (even after it's installed and running), vs 30 day examination period on umonitor - EIS was less expensive, even after I added the price of a couple of separate gauges to cover the functions it doesn't monitor in the configuration I bought. - Grand Rapids answered my questions thoroughly and accurately the first time, expressing enthusiasm for my inputs for the next product upgrade cycle. Rocky Mountain answered my questions with "I think" and "I'm pretty sure" (the answers turned out to be wrong), and expressed no interest in upgrading to monitor all cylinders simultaneously. GRT has some advantages, however: - more monitored functions - auxiliary inputs for alarms - a built in clock and timer. That built in clock/timer really irritated me, because it tells time in thenths of a minute rather than seconds... not good enough to meet FAR 91.205 requirements for IFR. It's a judgement call. Many people pick Rocky Mountain and report being very satisfied. I recommend investigating both units. Grand Rapids Technology is at 616-531-4893. Tim Lewis On 21 Jun 97 at 1:35, les williams wrote: > > ---------- > From: owner-rv-list(at)matronics.com on behalf of les williams > Sent: Wednesday, June 11, 1997 7:08 PM > To: rv-list(at)matronics.com > Subject: RV-List: RMI microEncoder & voltage transients > > --> RV-List message posted by: "les williams" <lesliebwilliams(at)msn.com> > > WOW! This is the real POWER OF THE LIST in action. I just last week received > > my microEncoder kit, and after reading Bill's comments, I really questioned > whether or not I should keep it or return it. I certainly don't want > an electronic gismo that might go blip out in the middle of nowhere when I > am using it for a primary flight instrument! It isn't like you can pull it > and run > to the nearest aviation supply store and pick up a replacement! > > I'm glad that Mr. Mowrer responded so quickly and offered up a "fix" for > their product. But I wonder how long it would have been, and under what other > > circumstances this reaction would have been taken, if it were not for the > "list"? > > I like the features of the microEncoder and hope that the experiences of Van's > > as related by Bill, is an isolated case. I would still like to use it, I > think! Does anybody have any other comments, good or bad about it? > > Thanks, > > Les Williams/RV-6AQ/N24LW (res)/finish kit/RV-6A N299LJ sold 10/95 > > > --------------------- Tim Lewis RV-6AQ #60023 San Antonio TX timrv6a(at)earthlink.net or timrv6a(at)iname.com ----------------------- ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"les williams" <lesliebwilliams(at)msn.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RE: RMI</u></b></i></font></td></tr></table> --> RV-List message posted by: "les williams" <lesliebwilliams(at)msn.com> <a target="otherpages" href="http://rkymtn.com">http://rkymtn.com</a> Les Williams/RV6-AQ/N24LW (res)/canopy stuff ---------- From: owner-rv-list(at)matronics.com on behalf of Stephen J. Soule Sent: Saturday, June 21, 1997 1:41 AM Subject: RV-List: RE: RMI --> RV-List message posted by: "Stephen J. Soule" <SSoule(at)pfclaw.com> Does RMI have a web page? What's the address? Steve ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>catbird(at)taylortel.com (TTC Carroll A. Bird)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RE: RMI</u></b></i></font></td></tr></table> --> RV-List message posted by: catbird(at)taylortel.com (TTC Carroll A. Bird) Stephen J. Soule wrote: > > --> RV-List message posted by: "Stephen J. Soule" <SSoule(at)pfclaw.com> > > Does RMI have a web page? What's the address? > > Stevewww.rkymtn.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Bumflyer(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Elev Trim Control RV-6</u></b></i></font></td></tr></table> --> RV-List message posted by: Bumflyer(at)aol.com I saw one at OSH in 93 which was mounted on the seat floor and about even with the seat back. It was a straight shot to the tail with no loop. I wound up using electric trim which I really like, and didn't pursue it further but that was the one that appealed to me the most. Probably not do able if you have electric flaps. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Denny Harjehausen <retflygtiger(at)proaxis.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RE: RMI</u></b></i></font></td></tr></table> --> RV-List message posted by: Denny Harjehausen <retflygtiger(at)proaxis.com> >--> RV-List message posted by: "Stephen J. Soule" <SSoule(at)pfclaw.com> > >Does RMI have a web page? What's the address? Steve It is rkymtn.com/rm.htm according to my address book. Have Great Day! Denny RV-6 (R)N641DH Fuselage top side Lebanon, OR ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RV6AIR(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV6 Panel mod.</u></b></i></font></td></tr></table> --> RV-List message posted by: RV6AIR(at)aol.com Glenn: M & H Machinery & Welding Tel:512-930-9059 makes a nice "Z" chanel for this purpose. $10.00. They also make an instrument sub panel machined on CNC. Both very nice and well worth the money. Bob Lovering RV-6 N7LA ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Al Mojzisik <prober(at)iwaynet.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RV-3 wet wings</u></b></i></font></td></tr></table> ge.pfclaw.com> --> RV-List message posted by: Al Mojzisik <prober(at)iwaynet.net> >--> RV-List message posted by: "Stephen J. Soule" <SSoule(at)pfclaw.com> > >With those long tubular fuel tanks, beware of fuel surging from >wingtip to fuselage every time you bank. If you are going to put a >long tube in the wing for gasoline, you might want to install some >baffles inside the tube. A short tube may not pose the same problem. > >Steve > It's funny you should mention this. I learned to fly at Cuyahoga County Airport east of Cleveland and Jim Bede was working out of that airport. I remember when I saw the local EAA chapter (back in the 60's) building a BD-4 with it's long tubular wing spar that had the fiberglass airfoils glassed to them and it was also the fuel tank. I remember the fuel tank baffels that were installed by slipping them in from the outboard end of the spar before it was capped. This was my first awareness of fuel tank baffels and what their purpose was. My point is that in a tubular fuel cell the baffels were very easy to manufacture and install. Al. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"jacquelyn eastburn" <jimnjax(at)worldnet.att.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>lex-aire HVLP</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "jacquelyn eastburn" <jimnjax(at)worldnet.att.net> the only major drawback to the lex-aire gun is it's pneumatic trigger. you cannot feather the trigger. it's either on or off.. my choice, binks mach 1 jim e. RV-8 #80079 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>mikel(at)dimensional.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Tailwheel Transition Story</u></b></i></font></td></tr></table> --> RV-List message posted by: mikel(at)dimensional.com >On another note, just curious what people have used to fill in the pop >rivet holes after priming and before painting. Grant: Air works really well: I suggest not filling them with anything as it takes a LOT of time to fill all those little holes and a LOT of time to sand the filling and they will STILL look like pop rivets, which is, after all, what they are. And that's OK. Michael ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>mikel(at)dimensional.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Master & battery relays on Battery Box?</u></b></i></font></td></tr></table> --> RV-List message posted by: mikel(at)dimensional.com >I mounted mine vertically because that's how I felt it worked out best and >after the fact, I think I read that this is the way it should be done. I >remember thinking, "boy, lucked out on that one". > > Mount them vertically. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RV6junkie(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Vacuum fittings and highway robbery</u></b></i></font></td></tr></table> --> RV-List message posted by: RV6junkie(at)aol.com << I'm sure this arrangement will work, but consider that your gyros will remain healthier if not starved for air flow. The Airborne fittings are designed to facilitate maximum flow in the system. I believe that they have an ID slightly greater than that of 3/8" dia aluminum tubing (>.205"). 3/8" barb fittings are of somewhat smaller ID. A buddy of mine is a Gyro tech and recommends the full flow fittings highly >> I'm sure he does! My gyros operate at normal vacuum. Remember the the reulator is adjustable. Additionally, you can polish in inside of the AN fittings (I didn't). What is worse...using AN fitting with a clean filter or Airborne fittings with a dirty filter? My point is that the vacuum environment is hostile to begin with (how many of us are doing acro with our gyros?) so I would not worry about a few thousands of an inch. Gary Corde RV-6 N211GC ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>JVanLaak(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: HVLP spray gun</u></b></i></font></td></tr></table> --> RV-List message posted by: JVanLaak(at)aol.com Has anyone here used a lower cost HVLP system built by Campbell Hausfeld? It typically sell for about $200 at builder supply stores and so on. Years ago I owned a Crois system (CX-9 or 10) and it was very nice but more than I really need for my own use. A smaller and less expensive unit for general home use would be easy to justify. $5-700 is much harder. If the lower cost unit can produce decent results I would consider it. I definitely prefer HVLP to painting with a small standard compressor, although I have painted 3 planes with a 1 hp Sears unit and gotten pretty darn good results. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Vanremog(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Installation - Constant Speed Spinner</u></b></i></font></td></tr></table> --> RV-List message posted by: Vanremog(at)aol.com << 1. When placing the S-602B rear doubler ring over the four mounting bolts, I found that the doubler strikes the prop hub before coming to rest on the 1/4" spacers. Is it that I need longer spacers? The constant speed spinner instructions mention a 1/4" spacer , but they also mention a S-604 from Van's. Is the S-604 spacer longer?>> Dave- You need spacers that are long enough so that, when the blades are turned to their most coarse pitch, the blades do not touch the rear spinner bulkhead. I added one aluminum washer AN960-XXPD (I forget which size they are, 3/8"?) to each spacer. They are available from ACS. << 2. Am I supposed to remove the inner 7.2" of S-601-1 so that it will clear the prop mount and attach to S-602? The constant speed spinner instructions mention in small print on the diagram that the center portion is to be removed, but I just wanted to make sure that that was standard practice. I don't want to hack away too much. >> Yes, you must cut it away to match the ID of the stiffener ring. -GV ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Dave Barnhart <barnhart(at)A.crl.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re:Wheel Landings</u></b></i></font></td></tr></table> --> RV-List message posted by: Dave Barnhart <barnhart(at)A.crl.com> During my early wheel landings, I used the 'force it on' technique, but I got tired of being hit over the head with a rolled-up newspaper by my instructor in the back seat. What I strive for now is to have a zero descent rate when I touch down. Then I apply just enough forward stick to reduce the angle of attack a bit. Granted, this technique uses a lot of runway, and it is not applicable to crosswinds, but it makes for nice smooth wheel landings. Best Regards, Dave Barnhart rv-6 sn 23744 N601DB installing electrical and avionics ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RELOSVCS!WESTREG!EHENSON(at)cldwell.attmail.com (Henson, Eric)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: HVLP spray gun</u></b></i></font></td></tr></table> --> RV-List message posted by: RELOSVCS!WESTREG!EHENSON(at)cldwell.attmail.com (Henson, Eric) I have had great results with one of the lower of the line Sharpe HVLP guns. I have seen them in discount papers at the local auto paint stores for around $220.00. Having nearly destroyed my Sharpe after dropping a tool box on it, I can say they are pretty tough and easily repaired. Sharpe UPS'd the parts out to me next day. Hope it helps, Eric Henson >>>>Has anyone here used a lower cost HVLP system built by Campbell Hausfeld? It typically sell for about $200 at builder supply stores and so on. << >>>If the lower cost unit can produce decent results I would consider it. << ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Mark & Candy LaBoyteaux <tailspin(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Bendix FI Installation Questions</u></b></i></font></td></tr></table> --> RV-List message posted by: Mark & Candy LaBoyteaux <tailspin(at)ix.netcom.com> I have a few questions for those of you who are using Bendix RSA5AD1 fuel injection units on your RV's. I have a IO-320B1A engine that I've modified to a straight riser oil sump in order to mount the metering unit on the bottom of the sump. I've purchased the filtered air box from Van's that's supposed to be for 0-360 and IO-320 engines. 1. What orientation did you use? I've got mine installed with the throttle control located on the left side and the mixture control on the right side. 2. The fuel inlet is located just above the mixture control arm. Thus the arm has to be installed pointing down. It extends below the flange that the filtered air box bolts to and interferes with it. Were any of you able to install the filtered air box from Van's on your injection units? 3. With the mixture control arm mounted pointing down, pulling it aft rotates the mixture control to full rich, so I can't run the control cable straight from the instrument panel. I'll either have to rig up a reversing bellcrank under the forward structure, or route the mixture cable up the left side and around the front of the metering unit where the cable is pointing aft and connect it to the mixture control arm. It would be so simple to just mount the control arm pointing up, but the fuel inlet is located right in the way. I'm planning on calling Don at Airflow Performance on Monday to talk to him about possible solutions, but I thought maybe someone on the list might be able to provide me with some hints or tips to think about. Mark LaBoyteaux RV-6A N106RV tailspin(at)ix.netcom.com engine mounted, now what? ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Thomas Velvick <tvelvick(at)caljet.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>storage life of vari-prime</u></b></i></font></td></tr></table> --> RV-List message posted by: Thomas Velvick <tvelvick(at)caljet.com> Hi everyone After I had finished some priming wih Dupont Variprime, I usually have some left over. I save it in a glass jar with lid and have used it for some touchups with q-tips. Does anyone know if you can still use it for starndard painting or do you have to paint within a certain amount of time after mixing the primer and the converter together. Thanks Tom Velvick tvelvick(at)caljet.com RV-6a rudder ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>JamesCone(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV6 Panel mod.</u></b></i></font></td></tr></table> --> RV-List message posted by: JamesCone(at)aol.com My subpanel is 1 7/8" tall. I made it so that PB switch/CB's would fit in the channel. The throttle and other engine controls fit well in this space. Jim Cone jamescone(at)aol.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Craig Hiers <<a href="mailto:CRAIG-RV-4.@worldnet.att.net">CRAIG-RV-4.@worldnet.att.net</a>></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: cabin air</u></b></i></font></td></tr></table> --> RV-List message posted by: Craig Hiers <<a href="mailto:CRAIG-RV-4.@worldnet.att.net">CRAIG-RV-4.@worldnet.att.net</a>> Tom Martin wrote: > > I too had the problem with the canopy rear skirt raising. I solved that by > putting faring the rear portion of the skirt into the turtle deck. No drafts > in the winter and it looks better too. > > Tom martin > RV-4 > Tom Could you be more specific about what you mean by faring the rear portion of the skirt into the turtle deck. If this is going to help keep it from leaking might as well do it now and get it over with. Craig Hiers RV-4 N143CH ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Bob Skinner <BSkinner(at)navix.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Sealing pop rivets</u></b></i></font></td></tr></table> --> RV-List message posted by: Bob Skinner <BSkinner(at)navix.net> >Grant: Air works really well: I suggest not filling them with anything as it >takes a LOT of time to fill all those little holes and a LOT of time to sand >the filling and they will STILL look like pop rivets, which is, after all, >what they are. And that's OK. > >Michael Of course, with a little moisture and a steel mandrel, there could be a little rust, right? Bob Skinner RV-6 BSkinner(at)navix.net ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Bob Skinner <BSkinner(at)navix.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: storage life of vari-prime</u></b></i></font></td></tr></table> --> RV-List message posted by: Bob Skinner <BSkinner(at)navix.net> >After I had finished some priming wih Dupont Variprime, I usually have some >left over. I save it in a glass jar with lid and have used it for some >touchups with q-tips. Does anyone know if you can still use it for >starndard painting or do you have to paint within a certain amount of time >after mixing the primer and the converter together. >Tom Velvick Tom, If I remember correctly, Variprime has a pot life after being mixed of 4 days. Been awhile since I've used it, though. Bob Skinner RV-6 BSkinner(at)navix.net ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: cabin air</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>sdrivers(at)juno.com (Stuart S Driver)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table> --> RV-List message posted by: sdrivers(at)juno.com (Stuart S Driver) Jim I would be very interested in such a project, here in Florida we need all the air we can get in the cockpit. TIA SSD RV4 Builder ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Doug Rozendaal" <dougr(at)netins.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re:Wheel Landings</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>May 16, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "Doug Rozendaal" <dougr(at)netins.net> > > --> RV-List message posted by: Dave Barnhart <barnhart(at)A.crl.com> > > What I strive for now is to have a zero descent rate when I touch down. > Then I apply just enough forward stick to reduce the angle of attack a bit. > > Granted, this technique uses a lot of runway, and it is not applicable to > crosswinds, but it makes for nice smooth wheel landings. I dare to differ with you, The wheel landing you describe is in fact the correct one and can be performed in fairly short distances with practice, and as for the cross winds, It was the only method the DC-3 and Beech 18 drivers had. Tailwinds, Doug Rozendaal RV-4 N240 a flyer not a builder and a retired frieght dog (BE-18, DC-3) dougr(at)netins.net www.petroblend.com/dougr ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Scott A. Jordan" <71341.3505(at)CompuServe.COM></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: N-numbers</u></b></i></font></td></tr></table> --> RV-List message posted by: "Scott A. Jordan" <71341.3505(at)CompuServe.COM> Don, Get AC -20-27D, it explains the whole certification process. Basically, write a letter to FAA Aeronautical Center FAA Aircraft Registry P.O. Box 25504 Oklahoma City, OK 73125 State the type aircraft you are building to include make, model and Serial Number ( remember, you are the manufacturer so the number is probably 1). Include the statement: This aircraft has not been previously registered anywhere. (FAR section 47.15) This is a special registration and cost $10 per year to reserve it. Include a check. List several choices, despite the research others have suggested, availability changes daily. If you have found your first choice is not avalable, include it anyway, it may be by the time the FAA gets the letter. If you have a friend at a FSDO enlist thier help. They can sit down at a computer and see the latest availablity. Good Luck Scott A. Jordan RV-8 80331 N733JJ Horizontal stab done, Vertical goes on the jig tomorrow. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>David Kerzie <dckerzie(at)qnet.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Governor Cable</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table> --> RV-List message posted by: David Kerzie <dckerzie(at)qnet.com> Does anybody have any bright ideas on how to secure an Aircraft Spruce = supplied governor cable (V970) to a Van's supplied VA-153 governor = control bracket? Van's picture shows using a jam nut ... my cable has = no provisions for one.=20 Thanks for any ideas, Dave Kerzie=20 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: In strument Panel Tilt and Attitude Gyros</u></b></i></font></td></tr></table> <33A7BA8B.75D1(at)ix.netcom.com> <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>wstucklen1(at)juno.com (Frederic w Stucklen)</i></b></font></td></tr></table> --> RV-List message posted by: wstucklen1(at)juno.com (Frederic w Stucklen) Jack, The unit that I had that failed was not an R.C.Allen unit. It was a IFR unit purchased from Van's. Initial units that Van sold did not have the tilt, and were later found to fail because of the lack of built in tilt. Possible the RCAllen units are more capable of dealing with this problem, but, according to the IFR people, their's is not. In any case, I do not recommend and IFR unit as I have had more trouble with it than it's worth. The next unit will be an RCALLEN... Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com <ix.netcom.com!jbabell(at)matronics.com> writes: >--> RV-List message posted by: "John B. Abell" <jbabell(at)ix.netcom.com> > >Many thanks to Bill Benedict for pointing out the convergence between >the fuselage top skin and the longeron. > >Fred Stucklen asks an interesting question to which I don't know the >answer simply because I don't know the relationship between the >waterline of the aircraft and its position in "cruise." Problem number >one is to define what "cruise" really means. The best I can do as a >builder without that information is to install the gyro corrected for >the angle between the instrument panel and the waterline. (I believe >the waterline parallels the longeron defining the canopy rail.) Even if >I knew the position of the waterline in "cruise," I might not specify >the gyro correction differently. > >A remaining question, of course, is whether Fred's first gyro failed >because it was not corrected for tilt; I doubt it. I talked with an >engineer at R. C. Allen this morning who alleges that tilt correction >has the sole purpose of centering the artificial horizon on the >miniature "airplane" in the gyro case and has nothing to do with >reliability. He also claims that he rarely receives a failed vacuum >gyro (22 series, the kind now being sold) but sometimes receives >electric gyros for repair. He says the vacuum gyros he's getting back >now are 21 series gyros made back around 1968 and they're being sent >back for overhaul, not repair, an impressive observation. BTW, he also >said that they can correct for up to 17 degrees of tilt. Apparently, >helicopters often have panels with very substantial tilt. > >In summary, I'm taking Bill's advice and correcting yesterday's >mistake >with the purchase of a gyro with eight degrees of tilt correction. >Sorry for the misleading information, but I hope someone besides me >benefitted from these postings and Bill's input. > >Jack Abell >RV-6A N333JA (Reserved) > > > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Alternator modifications, Avionics order</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>wstucklen1(at)juno.com (Frederic w Stucklen)</i></b></font></td></tr></table> --> RV-List message posted by: wstucklen1(at)juno.com (Frederic w Stucklen) Tim, B & C Specialties has a 60 Amp alternator. You coould also save yourself a LOT of money by going down to your local alternator service shop. Tell them you want a Nippon 60 or 70 Amp alternator but with the regulator disabled and rewired as a "B" circuit. Then you can use an off the shelp (appropriately rated) regulator (that has over voltage protection). You'll have to come up with your own mounting bracket and belt.... Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com <germany-c.it.earthlink.net!timrv6a(at)matronics.com> writes: >--> RV-List message posted by: "Tim Lewis" ><<a href="mailto:timrv6a@germany-c.it.earthlink.net">timrv6a@germany-c.it.earthlink.net</a>> > >Listers, > >I ordered most of my panel today. My wallet is unconscious. It may >have stopped breathing. Call 911! Thanks to all who shared ideas on >gyros for tilted panels, gyro hookups, GPS suggestions, etc. I >appreciate it. > >Alternator: I need a big alternator (60 A) to run my night/IFR >electrical load. I have the mounting kit from Van's, which suggests >a Mazda 323 alternator (65 amps). That's fine, except it has an >internal regulator. Does anybody have any experience to share on >either disabling internal regulators or finding automotive >alternators without internal regualtors? > >Thanks, > >Tim >--------------------- >Tim Lewis >RV-6AQ #60023 >San Antonio TX >timrv6a(at)earthlink.net or >timrv6a(at)iname.com >----------------------- > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Jerry Springer <jsflyrv(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: N-numbers</u></b></i></font></td></tr></table> --> RV-List message posted by: Jerry Springer <jsflyrv(at)ix.netcom.com> Scott A. Jordan wrote: > > State the type aircraft you are building to include make, model and Serial > Number ( remember, you are the manufacturer so the number is probably 1). > > > Scott A. Jordan > RV-8 > 80331 > N733JJ > Horizontal stab done, Vertical goes on the jig tomorrow. I guess you could use any serial number you wanted to but it is usually the same number that Van's assigns to your set of plans. For example mine is 20241. -- Jerry Springer RV-6 N906GS First flight July 14, 1989 :-) Hillsboro, OR jsflyrv(at)ix.netcom.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Bill Benedict <billb(at)europa.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Installation - Constant Speed Spinner</u></b></i></font></td></tr></table> --> RV-List message posted by: Bill Benedict <billb(at)europa.com> Dave, I know you received other mail on this subject and it is correct, but I would like to add some comments. As was pointed out, the critical issue is to be sure the blade does not hit the bulkhead (S-601-1) when it is in the max pitch position. You can force the blades to rotate to the stop by hand to check for clearance. Sometimes it takes two people with most of their might to rotate the blades. We had a number of F-601's that dished when they were turned. This happens periodically. Lay a straight edge over the web and if it is not flat, just press it flat. >I've come across a couple of stumbling blocks while trying to install the spinner to my constant speed prop (HC-C2YK-1BF/F7666A-4). > >1. When placing the S-602B rear doubler ring over the four mounting bolts, I found that the doubler strikes the prop hub before coming to rest on the 1/4" spacers. Is it that I need longer spacers? The constant speed spinner instructions mention a 1/4" spacer , but they also mention a S-604 from Van's. Is the S-604 spacer longer? Two things. Add a washer as mentioned by another builder, or relieve the web where it interferes with the hub if the bolts are not long enough for the washers. The 1/4 spacers are the S-604's. If the blade still strikes the S-602/S-601-1, why not put the doubler on the front of S-601-1, thereby moving S-601-1 aft by the thickness of the doubler. This should keep the blades from hitting the bulkhead (S-601-1). >2. Am I supposed to remove the inner 7.2" of S-601-1 so that it will clear the prop mount and attach to S-602? The constant speed spinner instructions mention in small print on the diagram that the center portion is to be removed, but I just wanted to make sure that that was standard practice. I don't want to hack away too much. You betch, just whack away. >Thanks for your help, >Dave Kerzie >RV-6 - engine mounted yesterday (thanks for the help, Jack!) > > > Bill <billb(at)europa.com> RV-4-180 soon. N894RV with over 400 hours behind a O-320, Over 1000 RV flying hours. These opinions are mine and do not necessarily represent the opinions or position of my employer. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Bill Benedict <billb(at)europa.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: cabin air</u></b></i></font></td></tr></table> --> RV-List message posted by: Bill Benedict <billb(at)europa.com> RV-List, I took an extra altimeter with me in my RV-4 several years ago that was just vented to the cockpit. When my speed was indicating about 160, the altimeter vented in the cockpit was indicating 300 feet higher than the aircraft system altimeter. Slow the -4 down to 80 mph, and the altitude difference was less than 100 feet. Take the same altimeter in my truck, and on a level highway, I can change the indicated altitude several hundred feet just by rolling the windows up or down. So, in responding to the statement below: >I've flown other canopied airplanes, and if you look at the trailing >edge of the canopy in flight you will notice that it is raised due to >being pressurized by the incoming air not having an exit point other >than leaks and pushing up the canopy. The canopy is raised because it has lift, not because of the positive pressure inside. The altimeter experiment proved to me that the cockpit of the -4 is at a slight vacuum and the amount of vacuum is proportional to airspeed. >I first noticed this on the way to Oshkosh in 1980 while flying a >Mustang II in a rain. We kept getting wet - the rainwater would run >down the canopy and tuck under at the back where the canopy had >raised off the fuselage due to pressure inside and lifting force on >the outside - the canopy is shaped like an airfoil, is it not. The >airflow then would "throw" the rain forward and hit us in the back of >the head and neck. Talk about drag - I'd like for an aeronautical >engineer to calculate that! The rain coming in at the back is another sign that the canopy is not pressurized. If it was, the water would not enter. However, with a slight vacuum, it would tend to suck the water in at this point. The -4, sliding canopied 6 and 6A, and the RV-8 all have this characteristic. In the first -8, it felt like a hurricane blowing on your neck in the cooler latitudes and altitudes. Most of the air is coming in around the track that supports the canopy track on the -6/6A and -8. Bill > >Joe Colquitt >Flying - well ventilated - RV-3, but a Spitfire it ain't. > > > Bill <billb(at)europa.com> RV-4-180 soon. N894RV with over 400 hours behind a O-320, Over 1000 RV flying hours. These opinions are mine and do not necessarily represent the opinions or position of my employer. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"John B. Abell" <jbabell(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: In strument Panel Tilt and Attitude Gyros</u></b></i></font></td></tr></table> <33A7BA8B.75D1(at)ix.netcom.com> <19970621.222716.10175.1.wstucklen1(at)juno.com> --> RV-List message posted by: "John B. Abell" <jbabell(at)ix.netcom.com> Fred, Thanks for the additional information on your failed attitude gyro. Your comments are interesting. Since my original posting on the subject of instrument panel tilt and gyros, I found out that turn coordinators apparently have the same problem, i.e., the need for tilt correction. I'm installing an S-Tec System 50 autopilot in my -6A and it turns out that S-Tec supplies turn coordinators with no tilt correction or with 8 degrees correction. When I bought my system, it was supplied with a turn coordinator with no tilt correction. I guess I'm going to have to try to swap it for one with the correction or have mine modified. I'm going to try to find out more about the tilt issue at Oshkosh. I'd like to understand it better than I do. I tentatively plan to fly up to visit Avionics West in Santa Maria, Calif. on Tuesday. I'll see what I can find out there from Tom Rogers. Better luck with your future R. C. Allen or whatever. Jack Abell RV-6A N333JA (Reserved) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>vern(at)ldd.net (VERN LEMASTERS)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: storage life of vari-prime</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table> --> RV-List message posted by: vern(at)ldd.net (VERN LEMASTERS) ---------- > From: Thomas Velvick <caljet.com!tvelvick(at)matronics.com> > To: rv-list(at)matronics.com > Subject: RV-List: storage life of vari-prime > Date: Saturday, June 21, 1997 4:22 PM > > --> RV-List message posted by: Thomas Velvick <tvelvick(at)caljet.com> > Vari-prime has a pot life of 3-5 days depending on the temperature. It is still okay to use as primer after that but it is no longer self-etching, or at least that is what my dupont rep tells me. Vern Lemasters Lemasters Electronics 1008 N. Radcliffe Marion, IL 62959 618-993-8689 fax 618-997-5726 e-mail vern(at)ldd.net > Hi everyone > > After I had finished some priming wih Dupont Variprime, I usually have some > left over. I save it in a glass jar with lid and have used it for some > touchups with q-tips. Does anyone know if you can still use it for > starndard painting or do you have to paint within a certain amount of time > after mixing the primer and the converter together. > > Thanks > Tom Velvick > tvelvick(at)caljet.com > RV-6a rudder ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>rust47rg(at)one.net</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Governor Cable</u></b></i></font></td></tr></table> --> RV-List message posted by: rust47rg(at)one.net >--> RV-List message posted by: David Kerzie <dckerzie(at)qnet.com> > > >Does anybody have any bright ideas on how to secure an Aircraft Spruce supplied governor cable (V970) to a Van's supplied VA-153 governor control bracket? Van's picture shows using a jam nut ... my cable has no provisions for one. > >Thanks for any ideas, >Dave Kerzie > Dave: Get a cablecraft cable. Regards: Rusty Gossard N47RG RV-4 Flying since 8-94 180 C/S ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Tom Martin <fairlea(at)execulink.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Bendix FI Installation Questions</u></b></i></font></td></tr></table> --> RV-List message posted by: Tom Martin <fairlea(at)execulink.com> > 1. What orientation did you use? I've got mine installed with the >throttle control located on the left side and the mixture control on the >right side. Mine is revesed but I don't think it matters > > 2. The fuel inlet is located just above the mixture control arm. Thus >the arm has to be installed pointing down. It extends below the flange >that the filtered air box bolts to and interferes with it. Were any of >you able to install the filtered air box from Van's on your injection >units? I believe that if you look at the other side of the controller you will see a plug. the Fuel can go in there and move the plug to the other side > > 3. With the mixture control arm mounted pointing down, pulling it aft >rotates the mixture control to full rich, so I can't run the control >cable straight from the instrument panel. I'll either have to rig up a >reversing bellcrank under the forward structure, or route the mixture >cable up the left side and around the front of the metering unit where >the cable is pointing aft and connect it to the mixture control arm. It >would be so simple to just mount the control arm pointing up, but the >fuel inlet is located right in the way. > I made a longer arm on my trottle quatrant that extended down. I then hooked the cable to that, this revesed the movement and the thing works now. It took many days of pondering to come up with this solution! Tom Martin RV-4 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Tom Martin <fairlea(at)execulink.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: cabin air</u></b></i></font></td></tr></table> --> RV-List message posted by: Tom Martin <fairlea(at)execulink.com> >> > >Tom >Could you be more specific about what you mean by faring the rear >portion of the skirt into the turtle deck. >If this is going to help keep it from leaking might as well do it >now and get it over with. > >Craig Hiers >RV-4 N143CH On the rear skirt I put an epoxy fibreglass faring. It wraps around the back of the skirt for about 10 inches on each side. It extends about 2 inches farther then the original metal one at the tip and tapers to the metal on the sides. I made it so that there is a nice large radius faring the rear of the canopy skirt into the turtle deck. My canopy no longer raises up. I think that I must have resolved the turbulence that causes the skirt to lift in flight. Cold air no longer freezes the neck of the passenger and because it was a lot of work I think my plane is faster ;) It took a lot of sanding to make it look good, and it has about 170 hours on it now with now problems Tom Martin RV-4 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Phil Arter <philip.arter(at)mci2000.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV8 - Pitot tube line</u></b></i></font></td></tr></table> --> RV-List message posted by: Phil Arter <philip.arter(at)mci2000.com> John A Myrick III wrote: > > --> RV-List message posted by: tmyrick(at)juno.com (John A Myrick III) > > I am about to drill the 7/16th holes in my ribs to run the pitot line. > On plans #15 it shows to measure back 5/8th inch from the main spar > web > and drill the hole in the rib there. This will leave almost no edge > distance at the front of the rib. I want to move the hole back away > from > the edge of the rib and center it over the main spar flange. Is there > anything that I am overlooking that will cause problems later? I > don't > know this is the same setup on the -6 and -4 or just on the -8. This > may > seem like a trivial question but I want to confirm with others before > I > drill. Thanks. > > Tripp Myrick > RV8 #80085 - Left wing > tmyrick(at)juno.com Tripp, hi I'm with you. I drilled mine about 1" from the front of the ribs and 1" from the bottom. The only consideration is the clearance between the end of the bolt on the aileron bellcrank and the pitot line. 1" still leaves you plenty of clearance. -- Phil Arter, RV-8 #80005 philip.arter(at)mci2000.com <a target="otherpages" href="http://acd.ucar.edu/~arter/RV8.html">http://acd.ucar.edu/~arter/RV8.html</a> (303)459-0435 home ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Ken_Hitchmough(at)magic.ca (Ken Hitchmough)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Bendix FI Installation Questions</u></b></i></font></td></tr></table> --> RV-List message posted by: Ken_Hitchmough(at)magic.ca (Ken Hitchmough) <snip> 2. The fuel inlet is located just above the mixture control arm. Thus the arm has to be installed pointing down. It extends below the flange that the filtered air box bolts to and interferes with it. Were any of you able to install the filtered air box from Van's on your injection units? <snip> I made an attachment to the current mixture arm that effectivelyreversed its direction. This worked fine for ensuring the mixture control cable worked in the correct sense, but it ment that I had to put a small bump on the cowl to incorporate the increased size of the arm. I know of at least one other that has a similar arrangement. I used Van's airbox. Ken RV6A Flying ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Todd <tmrv6(at)pop.erols.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Elev Trim Control RV-6</u></b></i></font></td></tr></table> --> RV-List message posted by: Todd <tmrv6(at)pop.erols.com> Glenn, This probably won't help you unless you have access to a lathe and milling machine, but, for the sake of diversity... I made a rack and pinion assembly, with a 3.5" hand wheel mounted on the pinion gear. The unit mounts on the left side of the fuselage, just above the pilots thigh. I used a throttle quadrant cable that is used in the RV-3(it turns out it was just the right length). The unit is easily accessable by the pilots right hand. On the front side of the rack, I have a piece of R/C aircraft control tube that runs up to the inst. panel for a trim indicator. One drawback is that a right seat driver would have to reach accross the fuse. to use the trim. In my world, it works fantastic. 175 hours, no problems. If anybody is interested I have the plans (somewhere), although the originals are hand written, I have started to move them to AutoCAD(I'll probably finish by the year 2000). -- Todd tmrv6(at)erols.com RV-6 N92TM Flying Glenn & Judi wrote: > > --> RV-List message posted by: Glenn & Judi <<a href="mailto:flyers@anet-chi.com">flyers@anet-chi.com</a>> > > RE: Manual elevator trim on the RV-6 > > Hi, > > Where are some alternative mounting locations for the manual elev trim > control? > > Thanks in advnace, > Glenn Gordon ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Darrell L. Anderson" <d.l.anderson(at)worldnet.att.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>storage life of vari-prime</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "Darrell L. Anderson" <d.l.anderson(at)worldnet.att.net> --> RV-List message posted by: Thomas Velvick <tvelvick(at)caljet.com> >After I had finished some priming wih Dupont Variprime, I usually have some left over. I save it in a glass jar with lid and have used it for some touchups with q-tips. Does anyone know if you can still use it for starndard painting or do you have to paint within a certain amount of time after mixing the primer and the converter together.< The Spec sheet I could readily lay my hands on says that it has a mixed pot life of three to four days. There is a more comprehensive publication that has, for the moment, time-traveled to some other place and time in my shop, that says you can re-activate previously mixed Variprime by adding more converter. I don't remember the amount they recommend adding, I'll try to find it unless someone else has the info nailed to the wall. The self-etching quality is what suffers from age. D. Anderson RV-4, wings ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Bumflyer(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Governor Cable</u></b></i></font></td></tr></table> --> RV-List message posted by: Bumflyer(at)aol.com I used a cable safe . Part # 05-16250 from ACS. Had to hog out the hole in the bracket with a unibit. Works good. Used another where it came through the firewall. D Walsh. RV-6A 27 hours. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Vanremog(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Governor Cable</u></b></i></font></td></tr></table> --> RV-List message posted by: Vanremog(at)aol.com << Does anybody have any bright ideas on how to secure an Aircraft Spruce supplied governor cable (V970) to a Van's supplied VA-153 governor control bracket? Van's picture shows using a jam nut ... my cable has no provisions for one. >> Dave- If you have a teleflex type ferrule on your cable(s), you need the special bracket that I have designed and documented (send me your address if you want a copy), a teleflex saddle clamp and a teleflex spacer, which are available from Airstar. I also have the same thing in a throttle/mixture bracket for the O-360-A1A. Let me know if you want that too. Check the Yeller Pages at <a target="otherpages" href="http://www.sound.net/~hartmann/yelrpage.htm">http://www.sound.net/~hartmann/yelrpage.htm</a> for Airstar's ph#. The P/Ns are in the archives. Try searching on "teleflex", "saddle clamps" or "Airstar". -GV ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Brian.Carrigan(at)Sciatl.COM</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: LED Dimmer</u></b></i></font></td></tr></table> --> RV-List message posted by: Brian.Carrigan(at)Sciatl.COM Date: Thu, 19 Jun 1997 10:34 -0500 (EST) From: "sprintmail.com!charliekuss(at)matronics.com%PMDF"(at)INTER.corp.sciatl.com Subject: Re: RV-List: LED Dimmer --Boundary (ID 4R9JDT7bsmoOEtfFGwQM9w) Mark: I would caution you about using one common rheostat on the LED grounds, as suggested by Charlie Kuss. First of all, most automotive dimmer switches are not simply rheostats. More on that later. Second of all, the brightness of your LEDS at a given rheostat setting will depend on how many are lit at any one time. This could be an annoyance if you switch on an indicator, and then have to re-adjust the dimmer switch, because all your LEDs went blank! Third, what are you doing with the relays? What I would suggest is something like a simple transistor circuit for each LED (2n3904 is sufficient, and readily available). The emmitter of the transistor goes to GND. The collector goes to the LED. The other side of the LED goes to the current limiting resistor (try 1K ohm). The other side of the resistor goes to your power supply (+12V). The base of the transistor has two connections: one to the SPDT switch you are using to control the auxillary, and one to a series resistor (try 10K). The idea for the switch is that when the switch is OFF, it will be grounding the base of the transistor, and when the switch is ON, the base will be left floating. The other side of the series resistor goes to the circuit which causes the dimming. This is nothing more than a variable duty cycle oscillator which can go from 0% to 100%. Probably Radio Shack can provide you with the circuit. The dimmer knob controls the duty cycle of the oscillator. All the transistors are connected to the same oscillator. Since they will all have the same duty cycle, they will all appear the same brightness (provided that they are all equally bright to begin with - note that different colours of LEDs will require different current limiting resistors). Hope this helps... Brian J. Carrigan; RV-6 in progress. ______________________________ Forward Header __________________________________ Subject: Re: RV-List: LED Dimmer Date: 6/19/97 10:34 AM --> RV-List message posted by: Charlie Kuss <charliekuss(at)sprintmail.com> Mark, A very simple way to accomplish this would be to tie all the ground leads of your LED's together. Run one common wire to a rheostat. Run another wire from the rheostat to ground. This is how the dome light circuit on your car works. Most circuits have constant ground and a switched power source. This circuit merely installs a variable resistor (rheostat) into the path from the LED's to ground. Mercedes Benz, Honda and others use seperate instrument panel dimmer switches (rheostats). One of these would work great. Charlie Kuss RV-8 tail kit came yesterday Mark S. Malone wrote: snipped > I need some help from the electronics gurus. I'm putting .125" LED's > above each switch on my panel. The LED will light when the switch is > energizes the equipment, i.e., pitot heat, nav lights, strobe lights, > etc. I would like to be able to dim the LED's with a single dimmer. --Boundary (ID 4R9JDT7bsmoOEtfFGwQM9w) <owner-rv-list(at)matronics.com> id QAA15784; Thu Jun 19 16:37:30 1997 Date: Thu, 19 Jun 1997 11:34:58 -0400 From: Charlie Kuss <sprintmail.com!charliekuss(at)matronics.com> Subject: Re: RV-List: LED Dimmer --Boundary (ID 4R9JDT7bsmoOEtfFGwQM9w)-- ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Dave Barnhart <barnhart(at)A.crl.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Governor Cable</u></b></i></font></td></tr></table> --> RV-List message posted by: Dave Barnhart <barnhart(at)A.crl.com> Dave: >Does anybody have any bright ideas on how to secure an Aircraft Spruce >supplied governor cable (V970) to a Van's supplied VA-153 governor control >bracket? Van's picture shows using a jam nut ... my cable has no >provisions for one. I don't believe it can be done. At least I understand that Van's bracket and the ACS cables are not compatible. The bracket I have on my governor came from a Mooney. instead of using a jamb nut, the bracket has a flat area so the cable can be clamped to it. Best Regards, Dave Barnhart rv-6 sn 23744 N601DB installing electrical and avionics ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 21, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Dave Barnhart <barnhart(at)A.crl.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re:Wheel Landings</u></b></i></font></td></tr></table> --> RV-List message posted by: Dave Barnhart <barnhart(at)A.crl.com> I wrote: > Granted, this technique uses a lot of runway, and it is not applicable to > crosswinds, but it makes for nice smooth wheel landings. And Doug Rozendaal replied: >I dare to differ with you, The wheel landing you describe is in fact the >correct one and can be performed in fairly short distances with practice, >and as for the cross winds... Well, *I* certainly seem to use a lot of runway :-) Of course, I've only been wrestling with a tailwheel for about 50 hours. Best Regards, Dave Barnhart rv-6 sn 23744 N601DB installing electrical and avionics ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>BigCfly001(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>pneumatic squeezers</u></b></i></font></td></tr></table> --> RV-List message posted by: BigCfly001(at)aol.com Does anyone know of a source of used airtools?I'm looking for a pneumatic sqeezer.used is preffered.thanks in advance. chris marion rv-6 building rudder cincy oh ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RV4Brown(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Navaid - Installation question - RV4</u></b></i></font></td></tr></table> --> RV-List message posted by: RV4Brown(at)aol.com I was reviewing the advertising literature for the Navaid. The pictures show a small servo box with an actuator arm. Has anyone on the list installed one of these autopilots on an RV-4 equipped with electric flaps? Where did you install the Navaid actuator box and what type of linkage setup is used to connect the actuator arm to the controls. How do you like to performance of the device? Do you use the GPS interconnect? Tom Brown RV-4 fuselage in jig - hoping to need instruments someday ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Stan Mehrhoff" <99789978(at)msn.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RV 8 center section</u></b></i></font></td></tr></table> --> RV-List message posted by: "Stan Mehrhoff" <99789978(at)msn.com> Has anyone completed their center section? I am confused with the placement and hole size in F-804-J . Dimensions on Drawing 11, dated 9/26/96 shows top of F-804 J 2 and 29/32 below top of center section. If this dimension is held, the holes will not fall in the center of the angle. Drawing 18 original shows F-804 J with 8 1/8" holes. Revision # 1 of sheet 18 shows 6 1/8" holes and 1 3/16" hole. Revision # 1 and 2 to sheet # 11 show 3/16" hole enlarged to 5/8" for rudder cable. F 804 J is 3/4 by 3/4 by 1/16" . A 5.8" hole will essentially cut it in two. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Ron Caldwell" <<a href="mailto:rlcaldwell@utah-inter.net">rlcaldwell@utah-inter.net</a>></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Prop Governors</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "Ron Caldwell" <<a href="mailto:rlcaldwell@utah-inter.net">rlcaldwell@utah-inter.net</a>> I have a Prop Governor which came off a Twin Commanche which had Lyc. 0-320 150 fuel injected engines. I would like to install it on my 0-320 D3G 160 hp. Any ideas on how I could go about finding out if it will work on my engine? Should I call Lycoming or Hartzell or someone else. Appreciate any ideas. Thanks. Ron Caldwell <a href="mailto:rlcaldwell@utah-inter.net">rlcaldwell@utah-inter.net</a> ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 22, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Patrick Hurley <patrick.hurley(at)wco.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Unsubscribing</u></b></i></font></td></tr></table> --> RV-List message posted by: Patrick Hurley <patrick.hurley(at)wco.com> How do I unsubscribe? ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>KBoatri144(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: KBoatri144(at)aol.com Help me avoid a mistake on wire runs in the wings, as I'm about to drill the ribs for conduit runs, but I want to make sure I use an appropriately sized conduit. I expect to use the Whelen strobe system with the single power supply. Am I correct in assuming that in addition to the shielded wire for the strobes, I'll need to install a separate run of wire to the wingtips for the postion lights? Replies appreciated. Kyle Boatright RV-6 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>JMJN01(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Wanted to buy: RV-4</u></b></i></font></td></tr></table> --> RV-List message posted by: JMJN01(at)aol.com Looking to buy an RV-4. Would like an 0-360 powered RV but will consider any. Day/Night VFR between $35,000 - $45,000. JMJN01(at)AOL.Com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Dennis Jaynes <<a href="mailto:dljaynes@inter-linc.com">dljaynes@inter-linc.com</a>></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Unsubscribing</u></b></i></font></td></tr></table> --> RV-List message posted by: Dennis Jaynes <<a href="mailto:dljaynes@inter-linc.com">dljaynes@inter-linc.com</a>> How do I unsubscribe? ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Joe Colquitt" <jcolquit(at)law.ua.edu></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: pneumatic squeezers</u></b></i></font></td></tr></table> --> RV-List message posted by: "Joe Colquitt" <jcolquit(at)law.ua.edu> > From: aol.com!BigCfly001(at)matronics.com > Date: Sun, 22 Jun 1997 19:57:23 -0400 (EDT) > To: rv-list(at)matronics.com > Subject: RV-List: pneumatic squeezers > Reply-to: rv-list(at)matronics.com > --> RV-List message posted by: BigCfly001(at)aol.com > > Does anyone know of a source of used airtools?I'm looking for a pneumatic > sqeezer.used is preffered.thanks in advance. > Chris, tons of such things are available. Some of the bigger companies selling used pneumatic equipment include Clinton (Atlanta), Brown (Texas, Dallas?), and USATCO (California). All of these companies advertise in Trade-a-Plane. I bought a nice pneumatic squeezer from USATCO. They had the best price when I was looking. ;-) Avery sells a hand squeezer that uses the same heads so you get double duty from those expensive little jewels. (I've got three!). Joe Colquitt Flying RV-3A Joseph A. (Joe) Colquitt ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>catbird(at)taylortel.com (TTC Carroll A. Bird)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: catbird(at)taylortel.com (TTC Carroll A. Bird) aol.com!KBoatri144(at)matronics.com wrote: > > --> Am I > correct in assuming that in addition to the shielded wire for the strobes, > I'll need to install a separate run of wire to the wingtips for the postion > lights? > > Replies appreciated. > > Kyle Boatright > RV-6 Yes, you will have to run an extra wire if you ground the pos. lights at the wingtip. If you want to use the ground device that Bob Nuckolls recommends then you will need two wires. 18awg fused to 10 amps is what I will be using. Carroll ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"I THINK, THEREFORE YOU ARE" <PKIRKPATRICK(at)FAB9.intel.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>pneumatic squeezers</u></b></i></font></td></tr></table> --> RV-List message posted by: "I THINK, THEREFORE YOU ARE" <PKIRKPATRICK(at)FAB9.intel.com> Greetings, I got my used pneumatic squeezer from Bill Williams Tool Co. in Fort Worth TX. It is a Chicago Pneumatic 214. Cost me $250.00 with whichever yoke I wanted. It isn't pretty but it works fine. Bill Williams specializes in surplus tools. They have all kinds of stuff including clecoes at the best price (.16) I've found. A little warning on the clecoes... They are definatly surplus. Some have paint on them others Pro Seal type stuff. Out of the last order I got, 98% were usable, thats better than the new ones I purchasesd in Febuary from Avery's, but they will not guarantee them. They will guarantee thier tools to work though. I should get a order of clecoes today (30 dozen) I'll let everyone know if the quality has gone downhill. Don't have the phone # handy because I'm at work but its probably in the Yeller Pages. If you can't find it email me back and I will dig it up and post it. They do have an Avery catalog so they can cross reference part numbers. Yokes are only $50 for any size. Later, Pat Kirkpatrick Rio Rancho, NM 6A- starting to skin both wings N97WK (res) PKIRKPATRICK(at)FAB9.INTEL.COM --OR-- KUFU(at)SWCP.COM ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Mlfred(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Governor Cable ATTACH</u></b></i></font></td></tr></table> --> RV-List message posted by: Mlfred(at)aol.com << Van's picture shows using a jam nut ... my cable has no provisions for one. > >Thanks for any ideas, >Dave Kerzie > Dave: Get a cablecraft cable. >> Dave: Summit racing has the end pcs you need. CSI is the brand, p/n 60017 clamp & shim for morse cable. You might find these at another speed shop, or a boat shop. Check six! Mark ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Mlfred(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Prop Governors</u></b></i></font></td></tr></table> --> RV-List message posted by: Mlfred(at)aol.com << I have a Prop Governor which came off a Twin Commanche which had Lyc. 0-320 150 fuel injected engines. I would like to install it on my 0-320 D3G 160 hp. Any ideas on how I could go about finding out if it will work on my engine? Should I call Lycoming or Hartzell or someone else. Appreciate any ideas. Thanks. Ron Caldwell <a href="mailto:rlcaldwell@utah-inter.net">rlcaldwell@utah-inter.net</a> >> Call John Buck @ EMI for info/exchange rates : 800-851-4392 Be sure to tell him that you don't need a yellow tag, if that's OK with you. I don't think it will work, as most twins have props that work backwards (oil press for fine pitch: feather in an engine failure) as compared to sgl engine types (oil press for coarse pitch: full RPM in an engine failure/loss of pressure-aerobatic types excluded). Check six! Mark ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>ejansen(at)austin.asc.slb.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Sealing pop rivets</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table> --> RV-List message posted by: ejansen(at)austin.asc.slb.com One technique when using steel pop rivets in aluminum is to dip the pop rivet in a rather thick solution zinc chromate primer just before installation. This is to reduce the amount electrolysis between the aluminum and the steel rivet. the operation is somewhat messy but nobody ever promised that airplane building was a clean business. Errol Jansen > ---------- > From: Bob Skinner[SMTP:navix.net!BSkinner(at)matronics.com] > Sent: Saturday, June 21, 1997 6:46 PM > To: rv-list(at)matronics.com > Subject: RV-List: Sealing pop rivets > > --> RV-List message posted by: Bob Skinner <BSkinner(at)navix.net> > > >Grant: Air works really well: I suggest not filling them with > anything as it > >takes a LOT of time to fill all those little holes and a LOT of time > to sand > >the filling and they will STILL look like pop rivets, which is, after > all, > >what they are. And that's OK. > > > >Michael > > Of course, with a little moisture and a steel mandrel, there could > be a > little rust, right? > > Bob Skinner RV-6 BSkinner(at)navix.net > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Mlfred(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Navaid - Installation question - RV4</u></b></i></font></td></tr></table> --> RV-List message posted by: Mlfred(at)aol.com << Where did you install the Navaid actuator box and what type of linkage setup is used to connect the actuator arm to the controls. How do you like to performance of the device? Do you use the GPS interconnect? >> I didn't like the actuator attach either. We drilled a hole just above where the ail pushtubes attach to the torque tube, and attached there with a AN3 bolt and a spacer. We had to knock out the reducing bushing in one of the rod ends, too. The servo mounts to a flattened "U" bracket attached to the belly skin. Tuning the thing was no fun (two on board, floor not installed). The thing will track heading, GPS, VOR, or a localizer very well! Check six! Mark ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Scott Gesele <scottg(at)icsnet.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Governor Cable</u></b></i></font></td></tr></table> --> RV-List message posted by: Scott Gesele <scottg(at)icsnet.com> >--> RV-List message posted by: Dave Barnhart <barnhart(at)A.crl.com> > >Dave: > >>Does anybody have any bright ideas on how to secure an Aircraft Spruce >>supplied governor cable (V970) to a Van's supplied VA-153 governor control >>bracket? Van's picture shows using a jam nut ... my cable has no >>provisions for one. > >I don't believe it can be done. At least I understand that Van's bracket >and the ACS cables are not compatible. The bracket I have on my governor >came from a Mooney. instead of using a jamb nut, the bracket has a flat >area so the cable can be clamped to it. > >Best Regards, >Dave Barnhart >rv-6 sn 23744 N601DB >installing electrical and avionics > Dave, It can be done, with a bunch of modifications. I have ACS cables installed for my MPT on Van's brackets. An extension needed to be fabricated for both of Van's brackets and retaining clips made to hold the ACS cables. I also used an Adel clamp as a secondary attachment for the cables to the modified bracket. It took an entire Saturday to fabricate these things, but appears to work quite well on the ground. The controls move with no binding. Even though the Van's brackets needed modifications, they were a good starting point. The attachments for the bracket to the engine/ governor are taken care of when using these brackets. Hope this helps. Scott Gesele N506RV (Still painting) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Mark LaBoyteaux <tailspin(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Pitot Heat Resistance</u></b></i></font></td></tr></table> --> RV-List message posted by: Mark LaBoyteaux <tailspin(at)ix.netcom.com> I've purchased a used heated pitot head, and checked the resistance of the heater to make sure it was serviceable. With a digital meter, I read 9 ohms resistance. So, for 12 volt supply, it will draw about 1.3 amps. This translates into about 16 watts of power. This sounds a little low to me, I was under the impression that the pitot heat would draw around 5 amps. Does anyone know what the resistance for the heater should be? Mark LaBoyteaux RV-6A N106RV tailspin(at)ix.netcom.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>osmith(at)seas.ucla.edu (Owen Smith)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: pneumatic squeezers</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table> --> RV-List message posted by: osmith(at)seas.ucla.edu (Owen Smith) Try Clinton Tool & Supply (404-766-3222) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>pmbs(at)probe.mt.att.com (Paul M Bilodeau +1 +1 908 957 6611)</i></b></font></td></tr></table> Original-Cc: probe!pmbs <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Aluminum dust in your eyes</u></b></i></font></td></tr></table> --> RV-List message posted by: pmbs(at)probe.mt.att.com (Paul M Bilodeau +1 +1 908 957 6611) > The solution I came up with is as follows: I adapted a Sears dust > collector from my radial arm saw that connects to my shop vac to collect the > particulate as it is produced. This seems to help. With warmer weather, I > will open the wndows as well. I also noticed the aluminum dust all over my nice "new" tools and tried two different methods of fixing the problem....first a shower drain inverted and pop riveted over a hole cut in the grinder end cover (ugly and didn't quite fit the hose of my shop vac). The second version used one of Van's 2" aluminum ventilation flanges (see the catalog - pg 16). It fit the hose much better and if you order it with something else, is reasonable in cost, even with shipping. Even though there is lots less aluminum dust in the air these days and I don't have to keep cleaning off the tops of my power tools, I still wear the equivalent of a 3M dust mask while doing lots of polishing to keep whatever junk there is in the air out of my lungs also. If you are using a shop vac to collect the dust you might want to get collection bags for ultra fine dust.....in our case aluminum dust, but your shop vac manual may mention other fine material e.g. pickup of cement and residue of the same consistency. Some shop vacs will allow the dust to pass through to the bearings of the motors therby shortening the life of the shop vac motor. Paul Bilodeau pmbs(at)probe.mt.att.com 908-957-6611 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RV6junkie(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV-3 wet wings</u></b></i></font></td></tr></table> --> RV-List message posted by: RV6junkie(at)aol.com I see a problem with making the aft ribs in the wing sealable for fuel. Your wet wings might send the CG to far aft when full. Normally the RV-3 wet wings are forward of the CG and the Header Tank is infront of the cockpit, well ahead of the CG. I would look at the weight and balance of such a configuration before going ahead with any modification. Gary Corde RV-6 N211GC - NJ ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Mike Wills <willsm(at)manta.nosc.mil></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RE: Lex-aire HVLP spray gun</u></b></i></font></td></tr></table> --> RV-List message posted by: Mike Wills <willsm(at)manta.nosc.mil> Eric, I'm the one who started that thread about 6 months ago and I still havent bought a gun. I looked at the Sharpe gravity feed HVLP and almost bought but my compressor doesnt provide the volume of air listed by Sharpe in the spec sheet. I had the feeling that the salesman was simply trying to sell me what he had, as he told me there would be no problem with my compressor, but he wouldnt agree to let me try the gun and take it back if it didnt work out. I have a 6 hp single stage with 60 gal tank; its the largest single stage that Home Depot sells. I think its rated at about <a href="mailto:10scfm@45psi.">10scfm@45psi.</a> Whats your opinion on this? BTW I spoke to a guy at Camarillo last weekend (did you go?) who had a beautiful yellow -4 which he had painted. He also had built and painted an equally beautiful Glassair III which was parked next to him. He had a lot of painting experience, used a De Vilbiss OMX gun and Dupont Chroma One. He said he hated the whole process; the paint was too expensive and hard to apply, and the hvlp was very hard to get decent atomization with. Kind of a depressing conversation for a guy like me with little painting experience. Mike Wills RV-4 (wings) willsm(at)manta.nosc.mil >--> RV-List message posted by: RELOSVCS!WESTREG!EHENSON(at)cldwell.attmail.com (Henson, Eric) > > >Hi John, > >If you can access the archives we had a great discussion on this about 6 >months ago. If not I have used both Sharpe and DeVilvis gravity feed HVLP >guns and they work as well as the painters technique will allow them. Prices >run about $230.00 to $350.00. No gun is going to make up for lack of >knowledge about paint aplication. My recomendation is to buy a good quality >gun and then spend the money you saved by not buying a hot shot system on >practice paint. This of course assumes your'e a newbie at the paint game, as >I was a year ago. I now feel confident enough to paint my entire aircraft. >Oh, any respectable dual stage compressor should handle the air volume. > >Eric Henson >Dana Point, CA >Wing Skins On > >ehenson(at)cldwell.attmail.com > ---------- >From: John B. Ciolino >To: matronics.com!rv-list; EHENSON >Subject: RV-List: Lex-aire HVLP spray gun >Date: Thursday, June 19, 1997 8:40PM > > --> RV-List message posted by: "John B. Ciolino" <jbc1(at)ziplink.net> > >RV Listers, > >I have been looking for a HVLP conversion paint gun ( i.e. runs off a >standard compressor) and have some literature on a Lex-aire 2002 gun. I've >searched the archives but can't find much in the way of recommendations on >HVLP guns. > >Does anyone have experience with the Lex-aire gun? Any recommendations for >a good HVLP gun? > >TIA > > >John Ciolino >jbc1(at)Ziplink.net >RV-8 Working on Empannage > > > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Steven Spruell" <SSPRUELL(at)us.oracle.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: "Steven Spruell" <SSPRUELL(at)us.oracle.com> --=_ORCL_22152428_0_11919706231439550 Kyle, I found some very thin-wall PVC at Home Depot which I am using. It is 7/8" OD and ~3/4" ID, but weighs less than 1/2" SCH 40. I used a Unibit to drill a 7/8" hole about 1.5" down from the top main rib flange and about 2.5" back from the spar. Make sure that your holes will clear the spar reinforcment angles on ribs 1-6. I made a little template out of scrap aluminum to pilot drill a #40 hole in the correct location on all the ribs, then finished up with the Unibit on the drill press. The pipe slid right in when it was on the jig. I'm using a dab of RTV at each rib to secure the pipe. Yes, you will need a separate wire for the position lights. These are switched separately from your strobes. ************************************************************************* * Steven Spruell League City, TX * * sspruell(at)us.oracle.com RV-6A #24721 (Wings) * * * * Houston Bay Area RVators: <a target="otherpages" href="http://www.iwl.net/customers/markr/hbar">http://www.iwl.net/customers/markr/hbar</a> * ************************************************************************* --=_ORCL_22152428_0_11919706231439550 Date: 23 Jun 97 00:06:13 From:"aol.com!KBoatri144(at)matronics.com" <owner-rv-list(at)matronics.com> Subject:RV-List: Wire Runs --> RV-List message posted by: KBoatri144(at)aol.com Help me avoid a mistake on wire runs in the wings, as I'm about to drill the ribs for conduit runs, but I want to make sure I use an appropriately sized conduit. I expect to use the Whelen strobe system with the single power supply. Am I correct in assuming that in addition to the shielded wire for the strobes, I'll need to install a separate run of wire to the wingtips for the postion lights? Replies appreciated. Kyle Boatright RV-6 --=_ORCL_22152428_0_11919706231439550-- ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Boris <smbr(at)digital.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: Boris <smbr(at)digital.net> I was just about to close my wings and I ordered the whelen install kit. I originally drilled for one set of the plastic grommets than Van supplied. The Whelen wire is much larger than I thought and it takes up the whole grommet. So, I am drilling a second run on the top side of the rib for the position and landing light wires (16 and 20 gauge). aol.com!KBoatri144(at)matronics.com wrote: > > --> RV-List message posted by: KBoatri144(at)aol.com > > Help me avoid a mistake on wire runs in the wings, as I'm about to drill the > ribs for conduit runs, but I want to make sure I use an appropriately sized > conduit. > > I expect to use the Whelen strobe system with the single power supply. Am I > correct in assuming that in addition to the shielded wire for the strobes, > I'll need to install a separate run of wire to the wingtips for the postion > lights? > > Replies appreciated. > > Kyle Boatright > RV-6 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Dr John Cocker <jcocker(at)medhumor.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>First Flight C-GDOC</u></b></i></font></td></tr></table> --> RV-List message posted by: Dr John Cocker <jcocker(at)medhumor.com> I have been looking forward to send this message for a long time. C-GDOC final made it into the air yesterday, following three years of building, with many helpers. The final inspection was a month ago, and there was then a very frustrating wait for the paperwork to be completed. Larry Weeks was the test pilot, and there were no hitches, unless you would count a slighly heavy right wind, and a complete radio failure caused by the radio sliding out of its tray. Larry also did the first flight on Ken Hitchmoughs similar RV 6A one year ago. The heavy wing was cured instantly by squeezing the trailing edge of the aileron on the light side. It is hard to believe that such a small squeeze can make such a big difference. The final inspection revealed two snags. The word "Canadian" was not on the ident plate, and I had not fitted the strut from the starter to the alternator bracket (- I didn't know there was one.) I will post further information when I am on the ground long enough, but thanks to the rv-list for a lot of useful advice (and entertainment( John. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"John C. Devlin" <jdevlin(at)americus.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: spar construction]</u></b></i></font></td></tr></table> --> RV-List message posted by: "John C. Devlin" <jdevlin(at)americus.net> Larry, Go to Hovan's Homepage <a target="otherpages" href="http://rv.austin.apple.com/jhovan/home.html">http://rv.austin.apple.com/jhovan/home.html</a> and look for Rich Klee's article under building tips. Send me an email off list if you want more info. Hope this helps, John Devlin ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>mikel(at)dimensional.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: mikel(at)dimensional.com >I expect to use the Whelen strobe system with the single power supply. Am I >correct in assuming that in addition to the shielded wire for the strobes, >I'll need to install a separate run of wire to the wingtips for the postion >lights? Yes, you need a single wire for the position lights. A single wire will do, even if you have the red/green/white combo lights. Ground the units on the end wing rib. Michael ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Boris <smbr(at)digital.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re:Wheel Landings</u></b></i></font></td></tr></table> --> RV-List message posted by: Boris <smbr(at)digital.net> Doug Rozendaal wrote: > > I dare to differ with you, The wheel landing you describe is in fact the > correct one and can be performed in fairly short distances with practice, > and as for the cross winds, It was the only method the DC-3 and Beech 18 > drivers had. > Doug, A few years back I was having lunch with three local old pilots who were telling stories about their flying days and we got on the subject of full stall (three point) vs wheel landings. These guys all started flying during the thirties. Dick Spalding, a retired airline pilot, and Bob Lloyd, also an old airline (and just about everything else) pilot, both said that, originally, all the landings were typically full stall, especially in strong winds. At some point the airlines mandated that they make wheel landings unless absolutely necessary. Bob said that in some of the small fields in South America he could only do full stall (flying the DC-3). Wheelies were done because it was easier on the passengers, and in a competitive market, better makes more money. Check out the really old clips on 'Weekday Wings' and, in fact, most of the old shots, even B-17's, were three-point. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RV6Russ(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Computers on board?</u></b></i></font></td></tr></table> --> RV-List message posted by: RV6Russ(at)aol.com Burt Rutan has his "Boomerang" equipet with a Mac Power Book and it runs almost everything in the airplane - maybe we could find out how he shields against RF ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>BARNES_ERIC(at)tandem.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>pneumatic squeezers</u></b></i></font></td></tr></table> --> RV-List message posted by: BARNES_ERIC(at)tandem.com Didn't check the Yeller Pages, but I had this in a folder. Ed Cole and I purchased squeezers from this guy, as did one or two others on the list - can't remember who. There are at least 4-5 happy campers however, and no one I know of who got a bad deal. $249 when I bought it, including a 1 1/2" yoke (other sizes available for substitute). Jerry @ Action Air Parts, Inc. 810-364-5885 106 N. Airport Dr. Port Huron, Michigan 48074 Hope this helps, EB #80131 ------------ ORIGINAL ATTACHMENT -------- SENT 06-22-97 FROM SMTPGATE (BigCfly001(at)aol.com) --> RV-List message posted by: BigCfly001(at)aol.com Does anyone know of a source of used airtools?I'm looking for a pneumatic sqeezer.used is preffered.thanks in advance. chris marion rv-6 building rudder cincy oh ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"David Moore" <dmoore8(at)tuelectric.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wire Runs</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "David Moore" <dmoore8(at)tuelectric.com> Kyle Boatwright asked: > Help me avoid a mistake on wire runs in the wings, as I'm about to drill the > ribs for conduit runs, but I want to make sure I use an appropriately sized > conduit. > > I expect to use the Whelen strobe system with the single power supply. Am I > correct in assuming that in addition to the shielded wire for the strobes, > I'll need to install a separate run of wire to the wingtips for the postion > lights? > You are correct. Van's sell a plastic, ribbed conduit (1/2 or 3/4 in., can't remember) which is light weight and works well. It will hold 100 wires, more than you will ever need. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RICKRV6(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Antenna Corrosion</u></b></i></font></td></tr></table> --> RV-List message posted by: RICKRV6(at)aol.com I hope someone can solve this problem. I have a Dorne and Margolin com antenna mounted on my RV6 floorboard directly behind the battery box. I have and RG58 cable run underneath the battery box floor which attaches to a 90 degree BNC connector which then connects to the antenna. This arrangement has worked well for the last five years. A few months ago however, corrosion began to collect on the 90 degree BNC connector where it attaches to the antenna and to the antenna connector. The corrosion is a thick white powder. The corrosion does not collect on the BNC connector of the RG58 cable. I have removed the antenna, cleaned the corrosion and replaced the 90 degree fitting. Most of the plating on the antenna connector is now gone. I checked yesterday and the corrosion is back. I'm certain the corrosion is not battery related. The white powder doesn't have the same smell as battery corrosion plus the carpet which covers the antenna is in contact with the corrosion is not effected. The battery is a gell cell and is not leaking. I can only assume there is an incompatability problem and the antenna may need to be replaced. Help. Rick McBride RICKRV6(at)aol.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RV6junkie(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: RV6junkie(at)aol.com << I expect to use the Whelen strobe system with the single power supply. Am I correct in assuming that in addition to the shielded wire for the strobes, I'll need to install a separate run of wire to the wingtips for the postion lights? >> The 5/8" ribbed conduit that Van's sells works well. You will run some or all of the following through each wing: Postion Strobe Landing Taxi (if installed) Pitot Heat (if installed) I have all of the above wires and the 5/8" conduit is works fine. All of the above are grounded locally so no returns are necessary. I would suggest that you drill for the conduit on the leading edge side of the spar, thus reducing the number of wires that will have to pass through the spar. This will also reduce the chance of interference with the control sticks. Gary Corde RV-6 N211GC - NJ ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>dralle(at)matronics.com (Matt Dralle 510-606-1001)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Computers on board?</u></b></i></font></td></tr></table> --> RV-List message posted by: dralle(at)matronics.com (Matt Dralle 510-606-1001) >-------------- >--> RV-List message posted by: RV6Russ(at)aol.com > >Burt Rutan has his "Boomerang" equipet with a Mac Power Book and it runs >almost everything in the airplane - maybe we could find out how he shields >against RF >-------------- Actually, I'd be more interested to know how he can get a mac powerbook to run everything in the airplane... I can't get my PB to even run MS Excel... Now, if it were my Dell... Yuck yuck yuck... ;-) [Disclaimer - My intent with this message was not to start a PC vs Mac thread on the RV-list. Please resist! -Matt] -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 510-606-1001 Voice | 510-606-6281 FAX | dralle(at)matronics.com Email <a target="otherpages" href="http://www.matronics.com/">http://www.matronics.com/</a> W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>randall(at)edt.com (Randall Henderson)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV6 Panel mod.</u></b></i></font></td></tr></table> --> RV-List message posted by: randall(at)edt.com (Randall Henderson) I too have some questions about dimensions for a throttle/mixture/prop sub-panel. Specifically, I am wondering what's a reasonable center to center distance between the controls. Anyone? Randall ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>randall(at)edt.com (Randall Henderson)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: randall(at)edt.com (Randall Henderson) > I expect to use the Whelen strobe system with the single power supply. Am I > correct in assuming that in addition to the shielded wire for the strobes, > I'll need to install a separate run of wire to the wingtips for the postion > lights? Negative. All the wires are contained in an outer insulating jacket, out 1/4" dia. You can order the wire kit separately from Van's I think. Randall Henderson, RV-6 randall(at)edt.com <a target="otherpages" href="http://www.edt.com/homewing">http://www.edt.com/homewing</a> ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Wis Support <support(at)wa.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Unsubscribing</u></b></i></font></td></tr></table> --> RV-List message posted by: Wis Support <support(at)wa.net> You need to contact the administrator of the list to unsuscribe. >--> RV-List message posted by: Dennis Jaynes <<a href="mailto:dljaynes@inter-linc.com">dljaynes@inter-linc.com</a>> > >How do I unsubscribe? > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Dennis Persyk" <dpersyk(at)worldnet.att.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: pneumatic squeezers</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "Dennis Persyk" <dpersyk(at)worldnet.att.net> Action Air Parts, Port Huron Mich., 313-364-5885 (as of two years ago), Jerry Williams. Jerry sells rebuilt squeezers, drills and rivet guns at reasonable prices. Get to him before OSH! Dennis 6A fuselage in jig ---------- > From: aol.com!BigCfly001(at)matronics.com > To: rv-list(at)matronics.com > Subject: RV-List: pneumatic squeezers > Date: Sunday, June 22, 1997 5:57 PM > > --> RV-List message posted by: BigCfly001(at)aol.com > > Does anyone know of a source of used airtools?I'm looking for a pneumatic > sqeezer.used is preffered.thanks in advance. > > chris marion > rv-6 building rudder > cincy oh ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>randall(at)edt.com (Randall Henderson)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: randall(at)edt.com (Randall Henderson) > Yes, you will have to run an extra wire if you ground the pos. lights > at the wingtip. If you want to use the ground device that Bob Nuckolls > recommends then you will need two wires. 18awg fused to 10 amps is what > I will be using. This is something I have wondered about. I know Nuckolls recommends grounding everything at a common place. But as I recall he did say that some remote things may be grounded locally (he may have even mentioned the wingtip or landing lights -- I don't remember exactly). So what's the real deal here? Is it reasonable to run ground wires from the wingtips all the way back to the panel to get to a common ground, or is that overkill? Bob? Randall Henderson, RV-6 randall(at)edt.com <a target="otherpages" href="http://www.edt.com/homewing">http://www.edt.com/homewing</a> ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Edward Cole <emcole(at)concentric.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: pneumatic squeezers</u></b></i></font></td></tr></table> --> RV-List message posted by: Edward Cole <emcole(at)concentric.net> I THINK, THEREFORE YOU ARE wrote: > > --> RV-List message posted by: "I THINK, THEREFORE YOU ARE" <PKIRKPATRICK(at)FAB9.intel.com> > > Greetings, > > I got my used pneumatic squeezer from Bill Williams Tool Co. in Fort Worth TX. > It is a Chicago Pneumatic 214. Cost me $250.00 with whichever yoke I wanted. > It isn't pretty but it works fine. Bill Williams specializes in surplus tools. > They have all kinds of stuff including clecoes at the best price (.16) I've > found. A little warning on the clecoes... They are definatly surplus. Some have > paint on them others Pro Seal type stuff. Out of the last order I got, 98% > were usable, thats better than the new ones I purchasesd in Febuary from > Avery's, but they will not guarantee them. They will guarantee thier tools to > work though. I should get a order of clecoes today (30 dozen) I'll let everyone > know if the quality has gone downhill. > > Don't have the phone # handy because I'm at work but its probably in the Yeller > Pages. If you can't find it email me back and I will dig it up and post it. > > They do have an Avery catalog so they can cross reference part numbers. Yokes > are only $50 for any size. > > Later, > > Pat Kirkpatrick > Rio Rancho, NM > 6A- starting to skin both wings > N97WK (res) > PKIRKPATRICK(at)FAB9.INTEL.COM --OR-- KUFU(at)SWCP.COM Action Air Parts in Michigan is where I got my pneumatic squeezer. The price was the same and the quality was good. Another friend also got his there and is satisfied. Their number should be in the archives. Ed Cole---One wing down , one to go! RV6A ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>WAF <wayneaf(at)inwave.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>h-s questions</u></b></i></font></td></tr></table> --> RV-List message posted by: WAF <wayneaf(at)inwave.com> 1.) E-603 rib odes not have fluting marks extending the length as other ribs do. Is it acceptable to carry the marks to the end to flatten? 2.) Elevator directions in manual call for drilling th e spar to the skin. A few paragraphs later this is done while parts are in the "v" blocks . which is correct? 3.) Speaking of elevator jig---- center measured from otside edges of wood or perpendicular to center of the v itself. Wayne Feggestad H-S ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RELOSVCS!WESTREG!EHENSON(at)cldwell.attmail.com (Henson, Eric)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Locking Fuel Caps</u></b></i></font></td></tr></table> --> RV-List message posted by: RELOSVCS!WESTREG!EHENSON(at)cldwell.attmail.com (Henson, Eric) Hi Gang, A few weeks ago I asked the list if anyone had any experience with the locking fuel caps that Wicks and ACS carries, as far as installing them. The problem is they have a six hole configuration on the flanges and now days most of our kits have pre-drilled tank skins with ten hole positions. As there has been much discussion about the shortcomings found in the standard caps, I have vowed to somehow install these very nice locking caps. If you have never seen them they are very nicely crafted and the opening mechanism reminded me of the bolt on my 30-06 rifle. Very, very smooth. I am currently talking with Wicks about ordering a limited quantity of these caps with undrilled flanges, this would make it a no brainer (I need that sometimes) to install into you uncompleted kits. If anyone is interested the cost is $92.00 per cap, all the info I have is what's in the ACS catalogue and what I saw at Sun N Fun. I need to give an estimate of how many is needed this week. If interested please e-mail me privately, PLEASE don't reply to the list. Thanks, Eric Henson Leading edge skins going on. ehenson(at)cldwell.attmail.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>William Costello <bcos(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: pneumatic squeezers</u></b></i></font></td></tr></table> --> RV-List message posted by: William Costello <bcos(at)ix.netcom.com> Owen Smith wrote: > > --> RV-List message posted by: osmith(at)seas.ucla.edu (Owen Smith) > > Try Clinton Tool & Supply (404-766-3222) I'd be VERY careful about Clinton T & S. I got reamed by them with a bunch of junk when I first started out -- 'precision' tools with bent shafts (only vound this out later); completely the wrong used tools like they didn't know what I wanted when I know darned sure they did. Just trying to palm stuff off on a newbie. I wouldn't buy anything else from them under any circumstances. Best regards, Bill Costello -- Bill Costello | bcos(at)ix.netcom.com | Building RV-6 | Reserv N97WC Want an extra hour and a half of energy per day with Super Blue Green products? Email for info or call 800-325-7544 Chicago ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Finn Lassen <finnlass(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV-3 wet wings</u></b></i></font></td></tr></table> --> RV-List message posted by: Finn Lassen <finnlass(at)ix.netcom.com> aol.com!RV6junkie(at)matronics.com wrote: > > --> RV-List message posted by: RV6junkie(at)aol.com > No, no. It's the bays forward of the main wing spar I want to use for fuel. Pretty much like standard RV wing tanks, except they will not be removable and leading edge skins and ribs are already all riveted. I'm simply looking for best way to seal them (in terms of minimum weight and work). I'm pretty sure that covering all of the inside with glass cloth would do the job, but because of weight and work I'd prefer only covering the joints (skin/ribs and skin/spar), if I knew I could trust the glass/alu bonding. Once a bay is done and the next bay is started, there is no way to go back and fix leaks. Right now I only have the fuselage tank. Probably the easiest way would be to use bladders (rubber?) but I don't know about weight, cost and availability. Are materials available for one to make his own fuel bladders? Finn > I see a problem with making the aft ribs in the wing sealable for fuel. Your > wet wings might send the CG to far aft when full. Normally the RV-3 wet > wings are forward of the CG and the Header Tank is infront of the cockpit, > well ahead of the CG. > > I would look at the weight and balance of such a configuration before going > ahead with any modification. > > Gary Corde > RV-6 N211GC - NJ ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"les williams" <lesliebwilliams(at)msn.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: "les williams" <lesliebwilliams(at)msn.com> Yes, you will need a separate circuit for the navigation lights. And also one for landing/taxi lights. And one each for anything else you plan on putting out in the wing, unless you're going to use one switch and a large wire for everything else other than the strobe high voltage cable! Les Williams/RV-6AQ ---------- From: owner-rv-list(at)matronics.com on behalf of aol.com!KBoatri144(at)matronics.com Sent: Sunday, June 22, 1997 9:06 PM Subject: RV-List: Wire Runs --> RV-List message posted by: KBoatri144(at)aol.com Help me avoid a mistake on wire runs in the wings, as I'm about to drill the ribs for conduit runs, but I want to make sure I use an appropriately sized conduit. I expect to use the Whelen strobe system with the single power supply. Am I correct in assuming that in addition to the shielded wire for the strobes, I'll need to install a separate run of wire to the wingtips for the postion lights? Replies appreciated. Kyle Boatright RV-6 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Larry D. Hoatson" <lhoatson(at)e2.empirenet.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: "Larry D. Hoatson" <lhoatson(at)e2.empirenet.com> Randall Henderson wrote: > > --> RV-List message posted by: randall(at)edt.com (Randall Henderson) > > > I expect to use the Whelen strobe system with the single power supply. Am I > > correct in assuming that in addition to the shielded wire for the strobes, > > I'll need to install a separate run of wire to the wingtips for the postion > > lights? > You are correct. The Whelen kit comes complete with all wires bundled for the stobe installation. This does not include wiring for the nav light. 1 extra wire to each tip and tail is required. Larry -- Larry D. Hoatson Yucaipa, CA Redlands (L12) Airport lhoatson(at)empirenet.com KC6WYF via packet at: KC6WYF(at)W6JBT.SOCAL.CA.USA.NOAM Restoring 1950 Cessna 170A N9948A... Looking forward to RV-6 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"John B. Ciolino" <jbc1(at)ziplink.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RV-8 Rudder</u></b></i></font></td></tr></table> --> RV-List message posted by: "John B. Ciolino" <jbc1(at)ziplink.net> RVer's: I am getting ready to close up the rudder and Van's instructions calls for placing a dab of RTV at the trailing edge of each stiffener to provide additional support. Question: won't this block the flow of any water (rain, condensation) which gets in the rudder? John Ciolino jbc1(at)Ziplink.net RV-8 Working on Empannage ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Ken_Hitchmough(at)magic.ca (Ken Hitchmough)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: First Flight C-GDOC</u></b></i></font></td></tr></table> --> RV-List message posted by: Ken_Hitchmough(at)magic.ca (Ken Hitchmough) <snip> I have been looking forward to send this message for a long time. C-GDOC final made it into the air yesterday, following three years of building, with many helpers. <snip> Congratulations John in having completed the best RV6A without AirBeetle gear in Ontario! At the rate you're going, you'll have the 25 hrs flown off in no time at all! Ken ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>chester razer <crazer(at)egyptian.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Blast tube</u></b></i></font></td></tr></table> --> RV-List message posted by: chester razer <crazer(at)egyptian.net> Has anyone used the plastic lightweight wiring conduit Vans supplies in their wiring kits as blast tube to cool mags, fuel pump, gascolator, etc. The catalog states it is suitable for use in the engine compartment as long as it remains 4-6" from exhaust pipes. -- Chet Razer crazer(at)egyptian.net ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Tom Martin <fairlea(at)execulink.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>engine failure</u></b></i></font></td></tr></table> --> RV-List message posted by: Tom Martin <fairlea(at)execulink.com> Tonight while flying home from a local flight the engine in my RV-4 quit. I was with a friend, John, also my mechanic, at 3000 ft descending to circuit height. We had just done a high rpm run of 2900 rpm for about four or five minutes. The engine was running beautifully and we were both enjoying the sound of a well behaved engine on a perfect flying night. I slowly reduced power and at 2500 rpm it started to run rough, some slight shaking. "What's that". All of a sudden not such a perfect flying night. I reduced power further and it was clear that we had a major problem, Both mags on, fuel on, boost pump on, switch tanks, no difference. For a fleeting moment I was convinced that we still had partial power, but it was just the noise of the engine windmilling. As our speed decreased it got too quiet. The airport was three miles ahead and I thought that I could make it, but not for long! We were going down and quick. As luck would have it our farm was coming up and I planned a descent to a recently planted soybean field. I called our unicom and did a mayday call three times. Local planes in the air and the airport staff both replied and I gave my position. I had been watching my airspeed closely but was getting distracted as the radio got busy, During this John was very calm and offered suggestions about different things to try. We were getting close to the ground and John suggested that I turn off the fuel. I did this and then told him politely to let me fly the plane. We were descending faster then I thought we would and my airspeed had dropped to 65 mph. I was not happy with this as my target was 75 mph at this point. We were coming down in a quiet glide and cleared hydro wires with room to spare. The plane settled quickly, bounced slightly, and rolled to a stop. Somewhere along the way I had put on 20 degrees of flaps. Always the farmer I remember wondering if we were rolling on the rows of soybeans. I radioed the airport and told them that we were safe and on the ground. I dragged the plane backwards out of the field and up the laneway. What happened. All I know at this point is that when you turn the prop there is only compression on two cylinders. It sounds expensive. There is absolutely no damage to the airframe. It was a good landing in a soft field. This is my second dead stick landing in this aircraft, the first due to a faulty fuel controller. This engine was rebuild 260 hours ago by someone who is supposed to know what he is doing. I am sorry that this is such a long post but I had to write it down and I thought that it would interest the readers of this list. I love this plane, I have however lost a lot of respect for this engine! Tom Martin RV-4 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Curt Reimer <Curt_Reimer(at)mbnet.mb.ca></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Source For Special Washer...</u></b></i></font></td></tr></table> --> RV-List message posted by: Curt Reimer <Curt_Reimer(at)mbnet.mb.ca> Matt Dralle 510-606-1001 wrote: > > --> RV-List message posted by: dralle(at)matronics.com (Matt Dralle 510-606-1001) > > Does anyone know where I could obtain some #6 black plastic/nylon washers? > I found some nice nylon washers that would work, but there are white and > would be very ugly. Thanks for any tips... > To make white nylon into black, or any other color, just buy some RIT fabric dye in the color of your choice. Simmer some water, dump in the dye, dissolve it, and add your nylon parts. You need to cook them for a few minutes and voila, the nylon parts will be saturated through with the coloured dye. Works great. Curt ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Frank van der Hulst <frankv(at)pec.co.nz></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: Frank van der Hulst <frankv(at)pec.co.nz> us.oracle.com!SSPRUELL(at)matronics.com wrote: > I found some very thin-wall PVC at Home Depot which I am using. It is > 7/8" > OD and ~3/4" ID, but weighs less than 1/2" SCH 40. I used a Unibit to > > drill a 7/8" hole about 1.5" down from the top main rib flange and > about > 2.5" back from the spar. I'm doing the same, except I'll put my PVC pipe in front of the main spar. I'll make up a couple of little brackets to hold it between the spar and tank. This was recommended to me by Bill Benedict. It apparently helps solve some wire routing issues in the cockpit. > I'm using a dab of RTV at each rib to secure the pipe. Are you worried about the pipe chafing on the rib, particularly since the wing is likely to move a little relative to the pipe? Maybe some little gussets (someone suggested PVC of a slightly larger diameter) or is this overkill? I'm thinking of aerobatics, and maybe the difference between the fuselage hanging off the wings in flight and the wings hanging off the fuselage on the ground. How much do the tips move up and down? Frank. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"The French's" <<a href="mailto:french@mag-net.com">french@mag-net.com</a>></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>first flight</u></b></i></font></td></tr></table> --> RV-List message posted by: "The French's" <<a href="mailto:french@mag-net.com">french@mag-net.com</a>> Hi All This post is to inform all that Les Vaughan of Hixon BC flew his RV-6 for the first time on June 15th. Les spent 5 years building. Reg is C-FYQD. Took a while to get the grin unpasted from his face, but he's back to normal now... Good to have some company Ted French Prince George BC RV-6A 100+ hrs ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Frank van der Hulst <frankv(at)pec.co.nz></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: h-s questions</u></b></i></font></td></tr></table> --> RV-List message posted by: Frank van der Hulst <frankv(at)pec.co.nz> inwave.com!wayneaf(at)matronics.com wrote: > 1.) E-603 rib odes not have fluting marks extending the length as > other > ribs do. Is it acceptable to carry the marks to the end to flatten? Check where the rivets go. Flute midway between rivets. Are you sure you need to flute to the end? Since the edge of the web isn't curved, the web shouldn't have bowed much in the forming process. > 2.) Elevator directions in manual call for drilling th e spar to the > skin. A few paragraphs later this is done while parts are in the "v" > blocks which is correct? I don't recall, but it can't have been a problem because I didn't note anything about it in my Bunny's Guide page <<a target="otherpages" href="http://www.pec.co.nz/~frankv/bunny1.htm">http://www.pec.co.nz/~frankv/bunny1.htm</a>> -- check that out for other stuff about the elevator and rest of the emp. > 3.) Speaking of elevator jig---- center measured from otside edges of > wood or perpendicular to center of the v itself. Should be the same, I think, if everything is square (assuming I've understood the question correctly). Actually, Van's measurements as shown on the plans were a bit far apart for me. I'm sure you could move them in or out an inch or more; the important thing is to hold everything straight and square to the chord line. Frank. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"James E. Clark" <James.E.Clark(at)worldnet.att.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Pitot Heat Resistance</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "James E. Clark" <James.E.Clark(at)worldnet.att.net> Is it a "Cessna Tube Type" or a "Piper Blade Type"?? I think my Piper consumes over 5 amps. I can check it if thats the type. James RV6AQ ... Trying to complete the S-TEC installation in the wings ---------- > From: Mark LaBoyteaux <ix.netcom.com!tailspin(at)matronics.com> > To: rv-list(at)matronics.com > Subject: RV-List: Pitot Heat Resistance > Date: Monday, June 23, 1997 1:24 PM > > --> RV-List message posted by: Mark LaBoyteaux <tailspin(at)ix.netcom.com> > > I've purchased a used heated pitot head, and checked the resistance of > the heater to make sure it was serviceable. With a digital meter, I read > 9 ohms resistance. So, for 12 volt supply, it will draw about 1.3 amps. > This translates into about 16 watts of power. This sounds a little low > to me, I was under the impression that the pitot heat would draw around > 5 amps. Does anyone know what the resistance for the heater should be? > > Mark LaBoyteaux > RV-6A N106RV > tailspin(at)ix.netcom.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"James E. Clark" <James.E.Clark(at)worldnet.att.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wire Runs</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "James E. Clark" <James.E.Clark(at)worldnet.att.net> ---------- > From: aol.com!KBoatri144(at)matronics.com > To: rv-list(at)matronics.com > Subject: RV-List: Wire Runs > Date: Monday, June 23, 1997 12:06 AM > > --> RV-List message posted by: KBoatri144(at)aol.com > > Help me avoid a mistake on wire runs in the wings, as I'm about to drill the > ribs for conduit runs, but I want to make sure I use an appropriately sized > conduit. I too have the Whelen strobes and am using 1/2" PVC conduit. On my wingtips I will have Nav, Strobe, Landing/Taxi lights. This seems to be big enough for that. Keep in mind though that you **may** want to run wiring for pitot heat and autopilot. In my case each of these is planned so I may have to have a *second* 1/2" PVC. Before anyone goes "huh"???, the reason is that on the QB, the holes that are drilled by Vans and plugged with the little plastic grommets are too small *and* they are close enough to the top of the rib that you don't want to drill much bigger than that. Drilling a second hole in a wing with some of the skins already on takes much bravery. (I chickened out). My (potential) second one (assuming the wires really don't fit as I desire) will be run through the lightening holes and clamped. > > I expect to use the Whelen strobe system with the single power supply. Am I > correct in assuming that in addition to the shielded wire for the strobes, > I'll need to install a separate run of wire to the wingtips for the postion > lights? I seem to recall that the Whelen I have (single power supply) has a single (sizeable) shielded cable with all necessary wiring for strobes and position lights. I may be wrong though. Will still need wire for landing/taxi. James RV6AQ ... working S-TEC installation (wings) > > Replies appreciated. > > Kyle Boatright > RV-6 > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Doug Rozendaal" <dougr(at)netins.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re:Wheel Landings</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>May 18, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "Doug Rozendaal" <dougr(at)netins.net> I certainly did not mean to start a discussion about which is better, I am wiser than to wander down that road.... The only point that I was trying to make is that a wheel landing is a very acceptable method of landing in when the trees are leaning. It can be done on any runway long enough that an RV should be routinely operated from. And yes the three-point is shorter. I know of no DC-3 or BE-18 operators that advocate or allow the airplanes to be three pointed. If you want to discuss the reasons why I could go on and on and won't. (I will if you want too, but it has nothing to do with RV's, write me directly) The B-17 (I am told, I intend to find out for myself someday) three-points nicely I see it done regularly as well. Three-pointing is a great way to land an RV. So is on the wheels. There really is not a bad way to land an RV. Right side up is good ;-) Doug Rozendaal ATP CFI MEI B-25 PBY, RV-4 N240 1000 hrs nite frieght BE-18 and a couple hundred right seat in a -3 dougr(at)netins.net www.petroblend.com/dougr ---------- > From: Boris <digital.net!smbr(at)matronics.com> > To: rv-list(at)matronics.com > Subject: Re: RV-List: Re:Wheel Landings > Doug, > > A few years back I was having lunch with three local old pilots who were telling stories about their > flying days and we got on the subject of full stall (three point) vs wheel landings. These guys all > started flying during the thirties. Dick Spalding, a retired airline pilot, and Bob Lloyd, also an old > airline (and just about everything else) pilot, both said that, originally, all the landings were > typically full stall, especially in strong winds. At some point the airlines mandated that they make wheel > landings unless absolutely necessary. Bob said that in some of the small fields in South America he could > only do full stall (flying the DC-3). Wheelies were done because it was easier on the passengers, and in a > competitive market, better makes more money. Check out the really old clips on 'Weekday Wings' and, in > fact, most of the old shots, even B-17's, were three-point. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table> Date-Warning: Date header was inserted by InfoAve.Net <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>GIBBONSR.FTC-I.NET(at)InfoAve.Net (RB Gibbons)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV 8 center section</u></b></i></font></td></tr></table> --> RV-List message posted by: GIBBONSR.FTC-I.NET(at)InfoAve.Net (RB Gibbons) Tail done. Left wing done. Ribs on right spar. Center section done. Yes indeed, the hole will almost cut it two, but not quite. Mine worked out fine. > >Has anyone completed their center section? I am confused with the placement >and hole size in F-804-J . Dimensions on Drawing 11, dated 9/26/96 shows top >of F-804 J 2 and 29/32 below top of center section. If this dimension is >held, the holes will not fall in the center of the angle. > >Drawing 18 original shows F-804 J with 8 1/8" holes. Revision # 1 of sheet >18 shows 6 1/8" holes and 1 3/16" hole. Revision # 1 and 2 to sheet # 11 >show 3/16" hole enlarged to 5/8" for rudder cable. F 804 J is 3/4 by 3/4 by >1/16" . A 5.8" hole will essentially cut it in two. > > > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Frank van der Hulst <frankv(at)pec.co.nz></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV-8 Rudder</u></b></i></font></td></tr></table> --> RV-List message posted by: Frank van der Hulst <frankv(at)pec.co.nz> ziplink.net!jbc1(at)matronics.com wrote: > I am getting ready to close up the rudder and Van's instructions calls > for > placing a dab of RTV at the trailing edge of each stiffener to provide > > additional support. Question: won't this block the flow of any water > (rain, condensation) which gets in the rudder? I guess. However: 1. How is water going to get to your trailing edge? Conceivably a little could leak in round the top fairing, then run down the inside of the skin to the first stiffener, then down the stiffener to the TE. 2. Since the rudder is vertical (more or less), not much will collect there (a mm or so?) before overflowing down to the next stiffener and so on down to the bottom fairing. I'm planning on putting a wee (pun intended) hole here. That'll allow egress of water that comes in via the hinge gaps in the rudder LE. 3. A few bounces over the grass and flicks to and from of the rudder (full & free pre-flight check) will knock the remnants loose. In short, I don't think it's a significant problem. 4. The elevator (and trim tab?) TEs may be more of a concern. Anyone with a flying RV had any problems with this? Frank. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"John B. Abell" <jbabell(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Pitot Heat Resistance</u></b></i></font></td></tr></table> --> RV-List message posted by: "John B. Abell" <jbabell(at)ix.netcom.com> Mark, As a point of comparison, the AN5812 12 volt pitot heater draws 10 amps. The 12 volt AN5814, which has both a pitot and static heater, draws 20 amps. Yours seems pretty weak in comparison. Jack Abell RV-6A N333JA (Reserved) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Charlie & Tupper England <england(at)vicksburg.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: cabin air</u></b></i></font></td></tr></table> --> RV-List message posted by: Charlie & Tupper England <england(at)vicksburg.com> >RV-List, I took an extra altimeter with me in my RV-4 several years ago >that was just vented to the cockpit. When my speed was indicating about >160, the altimeter vented in the cockpit was indicating 300 feet higher >than the aircraft system altimeter. >The canopy is raised because it has lift, not because of the positive >pressure inside. The altimeter experiment proved to me that the cockpit of >the -4 is at a slight vacuum and the amount of vacuum is proportional to >airspeed. >>I first noticed this on the way to Oshkosh in 1980 while flying a >>Mustang II in a rain. We kept getting wet - the rainwater would run >>down the canopy and tuck under at the back where the canopy had >>raised off the fuselage due to pressure inside and lifting force on >>the outside - the canopy is shaped like an airfoil, is it not. The >>airflow then would "throw" the rain forward and hit us in the back of >>the head and neck. Talk about drag - I'd like for an aeronautical >>engineer to calculate that! >>Joe Colquitt >>Flying - well ventilated - RV-3, but a Spitfire it ain't. >Bill <billb(at)europa.com> I think that it would be enlightening to place the extra altimeter's port outside the back of the canopy. If you look at a sampling of T-18's, the most common fresh air port is: (pause for effect) the trailing edge of the canopy. It is NOT an exit point. I'll bet the canopy trailing edge is at a relatively high pressure. Bill, has Van's measured this? Charlie (england(at)vicksburg.com) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"John B. Abell" <jbabell(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: engine failure</u></b></i></font></td></tr></table> --> RV-List message posted by: "John B. Abell" <jbabell(at)ix.netcom.com> Tom, Something like 95 percent of in-flight power losses are the result of fuel starvation. You got nailed with one of the five percent and managed to walk away from it. Nice work. Jack Abell RV-6A N333JA (Reserved) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Paul Osterman III" <PineRanch(at)msn.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>engine failure</u></b></i></font></td></tr></table> --> RV-List message posted by: "Paul Osterman III" <PineRanch(at)msn.com> Tom, Sorry to hear about your trouble. You didn't say what engine you've got in your RV-4. Paul OstermanIII RV6A Wings only a few rivets away from completion Anderson, Ca ---------- From: owner-rv-list(at)matronics.com on behalf of Tom Martin Sent: Monday, June 23, 1997 7:26 PM Subject: RV-List: engine failure --> RV-List message posted by: Tom Martin <fairlea(at)execulink.com> Tonight while flying home from a local flight the engine in my RV-4 quit. >> I love this plane, I have however lost a lot of respect for this engine! Tom Martin RV-4 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Jerry Springer <jsflyrv(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: engine failure</u></b></i></font></td></tr></table> --> RV-List message posted by: Jerry Springer <jsflyrv(at)ix.netcom.com> Tom Martin wrote: > -***Snip*** > I am sorry that this is such a long post but I had to write it down > and I > thought that it would interest the readers of this list. > I love this plane, I have however lost a lot of respect for this > engine! > > Tom Martin > RV-4 Tom Congratulations on a job well done. Sorry about the engine but glad no one was hurt. -- Jerry Springer RV-6 N906GS First flight July 14, 1989 :-) Hillsboro, OR jsflyrv(at)ix.netcom.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Leo Davies <leo(at)icn.su.OZ.AU></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: engine failure</u></b></i></font></td></tr></table> --> RV-List message posted by: Leo Davies <leo(at)icn.su.OZ.AU> >--> RV-List message posted by: Tom Martin <fairlea(at)execulink.com> > Tonight while flying home from a local flight the engine in my RV-4 quit. All of a sudden not such a perfect flying night. We were coming down in a quiet glide and cleared hydro wires with room to spare. The plane settled quickly, bounced slightly, and rolled to a stop. I dragged the plane backwards out of the field and up the laneway. There is absolutely no damage to the airframe. Tom Martin >RV-4 > Tom, Bloody well done. You turned a disaster into an adventure. And you still have a plane. Hope I do as well when my turn comes. My new engine from Van's is looking less expensive all the time. Well done again Leo Davies leo(at)icn.su.oz.au ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>unsubscribe</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>ab6a(at)juno.com (ALLAN E POMEROY)</i></b></font></td></tr></table> --> RV-List message posted by: ab6a(at)juno.com (ALLAN E POMEROY) Matt, Please unsubscribe me. This will only be temporary. I will be back once my email is straightened out. Thanks. Allan Pomeroy AB6A(at)juno.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Tom Martin <fairlea(at)execulink.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>engine failure</u></b></i></font></td></tr></table> --> RV-List message posted by: Tom Martin <fairlea(at)execulink.com> At 05:19 24/06/97 UT, you wrote: >--> RV-List message posted by: "Paul Osterman III" <PineRanch(at)msn.com> > >Tom, > Sorry to hear about your trouble. You didn't say what engine you've got in >your RV-4. > >Paul OstermanIII >RV6A Wings only a few rivets away from completion I have a 180hp I0-360 with a bendix injector, everything stock. Tom Martin (not sleeping well!) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>bennett(at)zip.com.au</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: cabin air</u></b></i></font></td></tr></table> --> RV-List message posted by: bennett(at)zip.com.au > > >RV-List, I took an extra altimeter with me in my RV-4 several years ago > >that was just vented to the cockpit. When my speed was indicating about > >160, the altimeter vented in the cockpit was indicating 300 feet higher > >than the aircraft system altimeter. > > >The canopy is raised because it has lift, not because of the positive > >pressure inside. The altimeter experiment proved to me that the cockpit of > >the -4 is at a slight vacuum and the amount of vacuum is proportional to > >airspeed. > > >>I first noticed this on the way to Oshkosh in 1980 while flying a > >>Mustang II in a rain. We kept getting wet - the rainwater would run > >>down the canopy and tuck under at the back where the canopy had > >>raised off the fuselage due to pressure inside and lifting force on > >>the outside - the canopy is shaped like an airfoil, is it not. The > >>airflow then would "throw" the rain forward and hit us in the back of > >>the head and neck. Talk about drag - I'd like for an aeronautical > >>engineer to calculate that! > > >>Joe Colquitt > >>Flying - well ventilated - RV-3, but a Spitfire it ain't. > >Bill <billb(at)europa.com> > > I think that it would be enlightening to place the extra altimeter's port > outside the back of the canopy. If you look at a sampling of T-18's, the most > common fresh air port is: (pause for effect) the trailing edge of the canopy. > It is NOT an exit point. > I'll bet the canopy trailing edge is at a relatively high pressure. > Bill, has Van's measured this? > > Charlie (england(at)vicksburg.com) > Bill's experiment was most enlightening. My guess would be that the air is exiting from the canopy into the low pressure area that extends along the top of the wings and over the canopy. The canopy probably bulges at the sides to vent the air. Behind the canopy would be relatively high pressure as the fuselage cross section has reduced at this point. The flow would be in the back and out the sides. Peter Bennett<bennett(at)zip.com.au> Sydney Australia RV6 building sliding canopy ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Antenna Corrosion</u></b></i></font></td></tr></table> 41,43,45-51 <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>wstucklen1(at)juno.com (Frederic W Stucklen)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table> --> RV-List message posted by: wstucklen1(at)juno.com (Frederic W Stucklen) Rick, First try and replace the fitting with one made from a different material. You may have a simple case of dissimilar material electrolysis. Next start looking for a possible ground current loop through the shield of the coax. This could be caused by a poor ground on the radio itself. Another possibility could be contamination in the rug covering the fitting. Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com writes: >--> RV-List message posted by: RICKRV6(at)aol.com > >I hope someone can solve this problem. I have a Dorne and Margolin com >antenna mounted on my RV6 floorboard directly behind the battery box. I have >and RG58 cable run underneath the battery box floor which attaches to >a 90 degree BNC connector which then connects to the antenna. This arrangement >has worked well for the last five years. A few months ago however, corrosion >began to collect on the 90 degree BNC connector where it attaches to the > antenna and to the antenna connector. The corrosion is a thick white >powder. The corrosion does not collect on the BNC connector of the RG58 >cable. I have removed the antenna, cleaned the corrosion and replaced the 90 >degree fitting. Most of the plating on the antenna connector is now gone. I >checked yesterday and the corrosion is back. > >I'm certain the corrosion is not battery related. The white powder doesn't >have the same smell as battery corrosion plus the carpet which covers the >antenna is in contact with the corrosion is not effected. The battery is a >gell cell and is not leaking. I can only assume there is an incompatability >problem and the antenna may need to be replaced. Help. > >Rick McBride >RICKRV6(at)aol.com > > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: First Flight C-GDOC</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>wstucklen1(at)juno.com (Frederic W Stucklen)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table> --> RV-List message posted by: wstucklen1(at)juno.com (Frederic W Stucklen) John, Congradulations on your first flight. Now the fun REALLY begins! Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com <medhumor.com!jcocker(at)matronics.com> writes: >--> RV-List message posted by: Dr John Cocker <jcocker(at)medhumor.com> > >I have been looking forward to send this message for a long time. >C-GDOC final made it into the air yesterday, following three years of >building, with many helpers. The final inspection was a month ago, and there >was then a very frustrating wait for the paperwork to be completed. > >Larry Weeks was the test pilot, and there were no hitches, unless you would >count a slighly heavy right wind, and a complete radio failure caused by the >radio sliding out of its tray. Larry also did the first flight on Ken >Hitchmoughs similar RV 6A one year ago. > >The heavy wing was cured instantly by squeezing the trailing edge of the >aileron on the light side. It is hard to believe that such a small squeeze >can make such a big difference. > >The final inspection revealed two snags. The word "Canadian" was not on the >ident plate, and I had not fitted the strut from the starter to the >alternator bracket (- I didn't know there was one.) > >I will post further information when I am on the ground long enough, but >thanks to the rv-list for a lot of useful advice (and entertainment( > >John. > > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>William Costello <bcos(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Unsubscribe - the true story</u></b></i></font></td></tr></table> --> RV-List message posted by: William Costello <bcos(at)ix.netcom.com> To UNSUBSCRIBE from the RV list, just send an email to RV-list-request(at)matronics.com with nothing (blank) in the Subject and one word in the body: UNSUBSCRIBE Note that the message is to RV-list-REQUEST(at)matronics.com and NOT to RV-list It would probably be good for us to read the 'Rules of the road' that Matt Dralle sends out about once a month. But I suppose many of us independent folks only read directions if ALL else fails. Best regards, Bill Costello -- Bill Costello | bcos(at)ix.netcom.com | Building RV-6 | Reserv N97WC Want an extra hour and a half of energy per day with Super Blue Green products? Email for info or call 800-325-7544 Chicago ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>OrndorffG(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Prop Governors</u></b></i></font></td></tr></table> --> RV-List message posted by: OrndorffG(at)aol.com Ron, If you can give me the number off the governor I can tell you if it can be used. I have a list of governors that will work or can be made to work....George Orndorff ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>OrndorffG(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wanted to buy: RV-4/rv 4 for sale</u></b></i></font></td></tr></table> --> RV-List message posted by: OrndorffG(at)aol.com call jim hyde (817) 326-4131 he has a RV4 for sale ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Patrick Kelley <patk(at)mail.ic.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV-8 Rudder</u></b></i></font></td></tr></table> --> RV-List message posted by: Patrick Kelley <patk(at)mail.ic.net> Frank van der Hulst wrote: > 1. How is water going to get to your trailing edge? Conceivably a little > could leak in round the top fairing, then run down the inside of the > skin to the first stiffener, then down the stiffener to the TE. I'd still worry about condensation. Quite a lot of water could condense on the inner surfaces without running down. However, due to the orientation of the surface, I don't think much, if any would be trapped by the stiffeners. Be sure to drill the drain hole in the bottom fairing, though. PatK - RV-6A ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>JRoss10612(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV-8 Rudder</u></b></i></font></td></tr></table> --> RV-List message posted by: JRoss10612(at)aol.com Joe: Vans does call for a dab of RTV at the trailing edge by each stiffener as an additional safeguard to prevent vibration and susequent cracking. With the rudder mounted vertically, I doubt water would could become trapped. What I did to prevent water entrapment on my elevators was to cut a 3/4" long small section of a plastic drinking straw and push this into the trailing edge by each stiffener before applying the RTV. When you look down the training edge lengthwise, you can see light, yet there is a large enough glob of RTV present around each piece of plastic straw to prevent vibration. As I say, I doubt this precaution would be necessary on a vertically mounted rudder, however it is a homebuilt airplane and you can do what you like in this area. Hope this helps. Jon Ross RV-80094 - Finishing wings, fuselage kit should be here any day... ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Peter Hanna <peterh(at)rdmcorp.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: engine failure</u></b></i></font></td></tr></table> --> RV-List message posted by: Peter Hanna <peterh(at)rdmcorp.com> >--> RV-List message posted by: Tom Martin <fairlea(at)execulink.com> > >Tonight while flying home from a local flight the engine in my RV-4 quit. Tom: Great job on the forced landing. Looking foward to hearing what went wrong, and any further advice on best engine out speeds, impressions, etc., for RVs. What speed did you use for best glide prior to final appraoch? Is 110 mph about right? Peter Hanna, RDM Corp, 4-608 Weber St. North, Waterloo, Canada, N2V1K4. B: 519-746-8483 X224, 1-800-567-6227 X224, Fax: 519-746-3317. Email: peterh(at)rdmcorp.com. -6 Fuselage. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Denny Harjehausen <retflygtiger(at)proaxis.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: First Flight C-GDOC</u></b></i></font></td></tr></table> --> RV-List message posted by: Denny Harjehausen <retflygtiger(at)proaxis.com> >--> RV-List message posted by: Dr John Cocker <jcocker(at)medhumor.com> > >I have been looking forward to send this message for a long time. >C-GDOC final made it into the air yesterday, following three years of >building, with many helpers. The final inspection was a month ago, and there >was then a very frustrating wait for the paperwork to be completed. (Snip) Hey that is Great! Have fun flying it! Have a Great Day! Denny RV-6 (R)N641DH Fuselage top side Lebanon, OR ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Charlie Kuss <charliekuss(at)sprintmail.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Locking Fuel Caps</u></b></i></font></td></tr></table> --> RV-List message posted by: Charlie Kuss <charliekuss(at)sprintmail.com> Henson, Eric wrote: snipped > I am currently talking with Wicks about ordering a limited quantity of these > caps with undrilled flanges, this would make it a no brainer (I need that > sometimes) to install into you uncompleted kits. If anyone is interested the > cost is $92.00 per cap, all the info I have is what's in the ACS catalogue > and what I saw at Sun N Fun. I need to give an estimate of how many is > needed this week. > > If interested please e-mail me privately, PLEASE don't reply to the list. Eric, I'll be interested in about 6 months. Obviously you don't want to tie your money up for that length of time. I'm still buying tools so I'm not in a position to buy that far ahead. Let Wicks know I'll buy in 6 months. Charlie Kuss Rv-8 H.S. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Dr John Cocker <jcocker(at)medhumor.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: engine failure</u></b></i></font></td></tr></table> --> RV-List message posted by: Dr John Cocker <jcocker(at)medhumor.com> Thanks for the email John. Sorry I can't recall the shipping costs, I block out all these painful memories, I think it is called "Repressed memory syndrome." I now have five uneventful hours of flying time on C-GDOC, and I am having a ball. I will look up the shipping costs, and if are down this way, the aircraft is at Buttonville, call me on 905 853 1884 or home at 905 836 7067 John ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Dennis Jaynes <dljaynes(at)ipa.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>UNSUSCRIBE</u></b></i></font></td></tr></table> --> RV-List message posted by: Dennis Jaynes <dljaynes(at)ipa.net> Please unsubscribe me. I will be back once my email is straightened out. Thanks. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Graham Armour <grahama(at)cmw.ca></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Blast tube</u></b></i></font></td></tr></table> --> RV-List message posted by: Graham Armour <grahama(at)cmw.ca> chester razer wrote: > > --> RV-List message posted by: chester razer <crazer(at)egyptian.net> > > Has anyone used the plastic lightweight wiring conduit Vans supplies in Chester, We have used this plastic conduit to cool mags, gascolator and alternator. All air is picked up from the rear engine baffle. We have had no problems in over 150 hrs. since first flight last September. Graham Armour RV-6 C-FVMH ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Don McNamara <mcnamara(at)sbt.infi.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV-8 Rudder</u></b></i></font></td></tr></table> --> RV-List message posted by: Don McNamara <mcnamara(at)sbt.infi.net> John B. Ciolino wrote: > I am getting ready to close up the rudder and Van's instructions calls for > placing a dab of RTV at the trailing edge of each stiffener to provide > additional support. Question: won't this block the flow of any water > (rain, condensation) which gets in the rudder? John-- I remembered to add my RTV to my rudder stiffeners just as I was putting in the last of the pop rivets to close the leading edge! I contemplated making a new rudder, but then was advised that RTV probably isn't even necessary if your stiffeners are close enough (<1") to the trailing edge. So, I guess I'll take my chances. I can always make a new rudder. --Don McNamara ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Robert Acker <r.acker(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Pitot Heat Resistance</u></b></i></font></td></tr></table> --> RV-List message posted by: Robert Acker <r.acker(at)ix.netcom.com> >--> RV-List message posted by: "John B. Abell" <jbabell(at)ix.netcom.com> >Mark, >As a point of comparison, the AN5812 12 volt pitot heater draws 10 amps. >The 12 volt AN5814, which has both a pitot and static heater, draws 20 >amps. Yours seems pretty weak in comparison. > >Jack Abell >RV-6A N333JA (Reserved) The spec sheet for the 12-volt AN5812 I installed this weekend claims 4.5 amps. So, should I size up the wire & breaker for 5 or 10 amps? Rob Acker / r.acker(at)ix.netcom.com / RV-6Q ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Denny Harjehausen <retflygtiger(at)proaxis.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>engine failure</u></b></i></font></td></tr></table> --> RV-List message posted by: Denny Harjehausen <retflygtiger(at)proaxis.com> (Snip) >I have a 180hp I0-360 with a bendix injector, everything stock. > >Tom Martin >(not sleeping well!) That was one gripping story there, Tom! I experienced something similar in that won't land off airport well,but happily they started at a lower altitude. That is a terrible sinking ;^) feeling! It is great your skill was up to the challege. It seems like most of the power out/off airport landings end up on their back. I have often wondered if there is much instruction and practice on dead stick landings done these days. As I notice that most light aircraft I observe locally seem to drag in with power. I assume you have a C/S prop...If so was it set for that high of RPM? The reason I ask is a fellow with lots of experience in engine experimentation told me that I could run my O-320 up higher than 2700 recommended with out any ill affects. He gave me the reasons which I have since forgotten. Have great Day! Denny RV-6 (R)N641DH Fuselage top side Lebanon, OR ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>BARNES_ERIC(at)tandem.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>h-s questions</u></b></i></font></td></tr></table> --> RV-List message posted by: BARNES_ERIC(at)tandem.com Hi Wayne, If I understand your questions correctly: 1) This is confusing. I don't think the skins fit into the "V" well until the stiffners are in and the trailing edge bent. But they say to drill to the spar before the stiffners go in, right? (Maybe that was just on the rudder). In anycase, on my PP Kit, I don't think there was any room for adjustment anyway. Of course, maybe that's why more people with the PP emp. are ending up with oil-canning... Safest seems to be to do the stiffners, bend, and then drill the spar to the skins in the jig. Can't see how it wouldn't be straight that way. 2) I measured the center of the "V" at the large end of the wedge. If the "V" is not in the center of the block, using the outside edges of the block will throw it off. The idea is to have the "V"s straight up, and directly across from one another. I used a plumb line down each wedge and shimmed the block until the center line was verticle, drew a line on the bench between the centerlines at the bottom of each block, and squared the blocks up to that line. If I have misunderstood your question - sorry! EB #80131 ------------ ORIGINAL ATTACHMENT -------- SENT 06-23-97 FROM SMTPGATE (wayneaf(at)inwave.com) --> RV-List message posted by: WAF <wayneaf(at)inwave.com> 1.) E-603 rib odes not have fluting marks extending the length as other ribs do. Is it acceptable to carry the marks to the end to flatten? 2.) Elevator directions in manual call for drilling th e spar to the skin. A few paragraphs later this is done while parts are in the "v" blocks . which is correct? 3.) Speaking of elevator jig---- center measured from otside edges of wood or perpendicular to center of the v itself. Wayne Feggestad H-S ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Bob Skinner <BSkinner(at)navix.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Blast tube</u></b></i></font></td></tr></table> --> RV-List message posted by: Bob Skinner <BSkinner(at)navix.net> >Has anyone used the plastic lightweight wiring conduit Vans supplies in >their wiring kits as blast tube to cool mags, fuel pump, gascolator, >etc. The catalog states it is suitable for use in the engine >compartment as long as it remains 4-6" from exhaust pipes. >-- >Chet Razer Chet, I've used the conduit for blast tubes to the mags, alternator and gascolator and the tubing is holding up well. I use 2" scat tube for cooling the mechanical fuel pump as this is the size required for the fuel pump shroud that I'm using. Bob Skinner RV-6 BSkinner(at)navix.net ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"D. F. Cimperman, Jr." <Cimperman(at)tusco.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: engine failure</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "D. F. Cimperman, Jr." <Cimperman(at)tusco.net> I could care less if the post is long, if I want to know the information, I will read, if not, I pass it up. I was interested in reading, It can only help us to know about problems like this, it may save our life some day. Thanks Dave ---------- > From: Tom Martin <execulink.com!fairlea(at)matronics.com> > To: rv-list(at)matronics.com > Subject: RV-List: engine failure > Date: Monday, June 23, 1997 7:26 PM > > --> RV-List message posted by: Tom Martin <fairlea(at)execulink.com> > > Tonight while flying home from a local flight the engine in my RV-4 quit. I > was with a friend, John, also my mechanic, at 3000 ft descending to circuit > height. We had just done a high rpm run of 2900 rpm for about four or five > minutes. The engine was running beautifully and we were both enjoying the > sound of a well behaved engine on a perfect flying night. > I slowly reduced power and at 2500 rpm it started to run rough, some slight > shaking. "What's that". All of a sudden not such a perfect flying night. I > reduced power further and it was clear that we had a major problem, Both > mags on, fuel on, boost pump on, switch tanks, no difference. For a fleeting > moment I was convinced that we still had partial power, but it was just the > noise of the engine windmilling. As our speed decreased it got too quiet. > The airport was three miles ahead and I thought that I could make it, but > not for long! We were going down and quick. As luck would have it our farm > was coming up and I planned a descent to a recently planted soybean field. I > called our unicom and did a mayday call three times. Local planes in the air > and the airport staff both replied and I gave my position. > I had been watching my airspeed closely but was getting distracted as the > radio got busy, During this John was very calm and offered suggestions > about different things to try. We were getting close to the ground and John > suggested that I turn off the fuel. I did this and then told him politely to > let me fly the plane. > We were descending faster then I thought we would and my airspeed had > dropped to 65 mph. I was not happy with this as my target was 75 mph at this > point. We were coming down in a quiet glide and cleared hydro wires with > room to spare. The plane settled quickly, bounced slightly, and rolled to a > stop. Somewhere along the way I had put on 20 degrees of flaps. Always the > farmer I remember wondering if we were rolling on the rows of soybeans. > I radioed the airport and told them that we were safe and on the ground. I > dragged the plane backwards out of the field and up the laneway. > What happened. All I know at this point is that when you turn the prop there > is only compression on two cylinders. It sounds expensive. There is > absolutely no damage to the airframe. It was a good landing in a soft field. > This is my second dead stick landing in this aircraft, the first due to a > faulty fuel controller. This engine was rebuild 260 hours ago by someone who > is supposed to know what he is doing. > I am sorry that this is such a long post but I had to write it down and I > thought that it would interest the readers of this list. > I love this plane, I have however lost a lot of respect for this engine! > > Tom Martin > RV-4 > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>mauser(at)claris.com (Richard Chandler)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Unsubscribe - the true story</u></b></i></font></td></tr></table> --> RV-List message posted by: mauser(at)claris.com (Richard Chandler) > with nothing (blank) in the Subject > and one word in the body: UNSUBSCRIBE > Note that the message is to RV-list-REQUEST(at)matronics.com One list I'm on puts this info in a two line .sig appended to every message. -- "Wait a minute, you expect us innocent children to climb up dangerous scaffolding and paint naked people all over a church? We'll do it!!" -- Yakko Warner, Animaniacs "Yeah, I've got ADD, you wanna make something of.... oooh, cool. Look!" ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>halk(at)sybase.com (Hal Kempthorne)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Current topics - my two bits...</u></b></i></font></td></tr></table> --> RV-List message posted by: halk(at)sybase.com (Hal Kempthorne) Hi all, You'll be gald to know I don't have time to gab at length! I do have a few words of - well, whatever: Re: Inlet air vents - my Debonair has a cabin air inlet on top the cabin, aft the passengers and outlet underneath. Re: Wire looms - my Debonair has landing gear wiring which is exposed to weather etc in a plastic tube. The dirt, water, bugs etc that had accumulated there are now coming back out as the tubing disintegrates. The wiring is in fine condition. There is little or no loom or conduit inside the aircraft and the wiring is pretty good after 32 years of service. They do wrap it and attach it frequently. My feelings: generally inside the airplane the loom has weight, costs time and money and adds nothing. Re: Water in the rudder - I flew a rental Cherokee once in which the rudder froze up solid once I reached altitude. Don't give it a chance to accumulate. Re: Blast tubing, ducts etc - the auto makers use a corrugated aluminum tube - sometimes with paper lining. Super light, cheap and locally available. No where near as indestructable as SCAT though. Re: Antenna corrosion. Corrosion-X or similar is good. Wet carpet is bad as is battery acid, of course. Re: Painting with HVLP - I painted an occasional motorcycle years ago and got a big kick out of it. Even bad results swelled me with pride. I am one of those "Good enough is good enough" people though. I didn't like the clouds of paint, spattering or the clean up. I think HVLP would be great fun. Hal Kempthorne RV-6AQ -- On main gear - panel fitted halk(at)sybase.com Santa Clara, CA. Debonair N6134V @ SJC ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RICKRV6(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>antenna Corrosion</u></b></i></font></td></tr></table> --> RV-List message posted by: RICKRV6(at)aol.com I hope someone can solve this problem. I have a Dorne and Margolin com antenna mounted on my RV6 floorboard directly behind the battery box. I have an RG58 cable run underneath the battery box floor which attaches to a 90 degree BNC connector which then connects to the antenna. This arrangement has worked well for the last five years. A few months ago however, corrosion began to collect on the 90 degree BNC connector where it attaches to the antenna connector. The corrosion is a thick white powder. The corrosion does not collect on the BNC connector of the RG58 cable. I have removed the antenna, cleaned the corrosion and replaced the 90 degree fitting. Most of the plating on the antenna connector is now gone. I checked yesterday and the corrosion is back. I'm certain the corrosion is not battery related. The white powder doesn't have the same smell as battery corrosion plus the carpet which covers the antenna and is in contact with the corrosion is not effected. The battery is a gell cell and is not leaking. I can only assume there is an incompatability problem and the antenna may need to be replaced. Help. Rick McBride RICKRV6(at)aol.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Larry D. Hoatson" <lhoatson(at)e2.empirenet.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Pitot Heat Resistance</u></b></i></font></td></tr></table> --> RV-List message posted by: "Larry D. Hoatson" <lhoatson(at)e2.empirenet.com> > The spec sheet for the 12-volt AN5812 I installed this weekend claims 4.5 > amps. So, should I size up the wire & breaker for 5 or 10 amps? > > Rob Acker / r.acker(at)ix.netcom.com / RV-6Q Hello Rob, Do you have a copy of AC 43.13? It has the wire size information for a given load and length of run - then I usually go 1 size larger. How's the bird coming? Was Bakersfield worth the trip? Sorry we missed you. Larry -- Larry D. Hoatson Yucaipa, CA Redlands (L12) Airport lhoatson(at)empirenet.com KC6WYF via packet at: KC6WYF(at)W6JBT.SOCAL.CA.USA.NOAM Restoring 1950 Cessna 170A N9948A... Looking forward to RV-6 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Grant E. Young" <gyoung(at)crl.nmsu.edu></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>gps/com</u></b></i></font></td></tr></table> --> RV-List message posted by: "Grant E. Young" <gyoung(at)crl.nmsu.edu> If anybody has any opinions on the King vs. Garmin GPS/COMs I would be interested in hearing them, Thanks, Grant- RV-6 (finishing wiring and engine hookup) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Denny Harjehausen <retflygtiger(at)proaxis.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: antenna Corrosion</u></b></i></font></td></tr></table> --> RV-List message posted by: Denny Harjehausen <retflygtiger(at)proaxis.com> (Snip) >I'm certain the corrosion is not battery related. The white powder doesn't >have the same smell as battery corrosion plus the carpet which covers the >antenna and is in contact with the corrosion is not effected. The battery is >a gell cell and is not leaking. I can only assume there is an >incompatability problem and the antenna may need to be replaced. Help. (Snip) First off my qualifications on this subject is nil, I am repeating (again) what I was told about one of the production aircraft changing over to a ground return wire to eliminate using the A/C as a grounding source. They were having joint corrosion problems. Bob Knuckols posted sometime ago that he didn't see that as much of a problem. Could that be the reason? I have seen one or two connections with corrosion while none of the other have any... It was suggested to me to use "Dielectric Grease on all connections"......would that help your situation? Have a Good Day! Denny RV-6 (R)N641DH Fuselage top side Lebanon, OR ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Mark LaBoyteaux <tailspin(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Pitot Heat continued.....</u></b></i></font></td></tr></table> --> RV-List message posted by: Mark LaBoyteaux <tailspin(at)ix.netcom.com> The pitot tube I have is a Cessna type. The battery indicator has been showing for some time on my voltmeter,so after running down to WalMart for a new one and making sure the meter was properly zeroed, the heater element now measures about 2.6 ohms. I decided to do a little experimenting, and put the tube in my freezer for a couple of hours. The resistance now checked at 2.5 ohms. So I took my jumper cables and connected it to the battery in my truck. It pulled 4.9 amps. After about 15 seconds, all of the frost melted. The phone rang. It was some salesman wanting to clean my ductwork, I said no thanks. I went back to check on the pitot tube which has now been heating for a few minutes, and grabed hold of it to see how warm it was. YEEEOOOWW! That sucker was hot! Now it was pulling about 4.5 amps. I disconnected it, and now it measured 2.9 ohms. Ops check ok. Now off to WalMart to get some salve for my fingers..... Mark "Smokin' Fingers" LaBoyteaux RV-6A N106RV tailspin(at)ix.netcom.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>scott.fink(at)Microchip.COM (Scott Fink)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: scott.fink(at)Microchip.COM (Scott Fink) --IMA.Boundary.046591768 I would suggest that you drill for the conduit on the leading edge side of the spar, thus reducing the number of wires that will have to pass through the spar. This will also reduce the chance of interference with the control sticks. Gary Corde RV-6 N211GC - NJ Doesn't this interfere with the fuel tanks? Scott Fink RV-6 working on wings --IMA.Boundary.046591768 SMTP -0700 (<a href="mailto:firewall-user@prometheus-gate.Microchip.COM">firewall-user@prometheus-gate.Microchip.COM</a> [198.175.253.129]) by titan.Microchip.COM (8.6.12/8.6.12) with SMTP id SAA24447 for smap (3.2) From: aol.com!RV6junkie(at)matronics.com Date: Mon, 23 Jun 1997 15:13:12 -0400 (EDT) Subject: Re: RV-List: Wire Runs --IMA.Boundary.046591768-- ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"John B. Abell" <jbabell(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>More on Instrument Panel Tilt and Gyros</u></b></i></font></td></tr></table> --> RV-List message posted by: "John B. Abell" <jbabell(at)ix.netcom.com> I had lunch at the Santa Maria airport today with Tom Rogers, a Ph.D. physicist who owns Avionics West, the source of my S-Tec System 50 autopilot and a couple of Bose headsets. I went to visit Tom for two reasons: (a) to return a turn coordinator to him for modification for panel tilt correction and (b) to ask him to illuminate the panel tilt issues we've been discussing recently. I felt the modification was necessary because the turn coordinator supplied with my system for installation in a -6A had a sticker on it that said that it was to be installed only in a vertical instrument panel. The installtion booklet that came with the system reflected the fact that there was another part number turn coordinator available with eight degrees of tilt correction. Thus, I inferred that I had been supplied with the wrong turn coordinator. I learned the following. Tom thought that the only advantage in correcting a turn coordinator for eight degrees of tilt would be the correction of a very slight error in the indication of rate of turn and that there was no reliability issue involved. However, he added that eight degrees of panel tilt would be very troublesome indeed for an attitude gyro and it should be corrected for in the instrument. Again, he believed that there was no reliability issue involved. He added that S-Tec was the only company he knew of that corrected for panel tilt in turn coordinators. After lunch he called S-Tec to verify what he was telling me. He learned that S-Tec would be pleased to make the correction for tilt in my turn coordinator, but that they recently discontinued making turn coordinators with tilt correction because, as Tom had surmised, the error was slight. When I asked him what he would do in my shoes, Tom suggested going ahead with the correction since I had flown up there to deliver the turn coordinator in the first place and didn't need it urgently. This is all I know, boys and girls, except that Leo Davies verified Bill Benedict's assertion of eight degrees of panel tilt by actual measurement. BTW, for those interested in getting some help with their instrument panels and avionics installations, I would heartily recommend Avionics West. Tom Rogers knows what he's up to. He can be reached at: Avionics West, Inc.; 3203 Lightning, Suite 124; Santa Maria, CA 93455. Phone (805) 928-3601. Fax (805) 928-3603. e-mail avionics(at)avweb.com. Don't worry; I'm not getting any commission. Good luck to all. Jack Abell RV-6A N333JA (Reserved) For Leo Davies: Tom wondered which part number turn coordinator you received. He remembered who referred you. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"John B. Abell" <jbabell(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Pitot Heat Resistance</u></b></i></font></td></tr></table> --> RV-List message posted by: "John B. Abell" <jbabell(at)ix.netcom.com> Interesting. I was quoting from the Aircraft Spruce catalog, p. 268, which specifies the 10 and 20 amps. Determine what wire size you will use and size the breaker or fuse accordingly. Jack Abell RV-6A N333JA (Reserved) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>lottmc(at)datastar.net (Michael C. Lott)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>balance</u></b></i></font></td></tr></table> --> RV-List message posted by: lottmc(at)datastar.net (Michael C. Lott) While we are on the subject of balancing control surfaces, (I thought I slid into that rather smoothly), what is the best way to do it, how close does it have to be, what are the ramifications of not doing it properly, and since it will be balanced mainly fore and aft, does it matter if the balancing weight is added only to a side, and not in the center of the plane being balanced? All answers appreciated. Thanks, Michael ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>GHLX34A(at)prodigy.com (MR GEORGE T KILISHEK)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: GHLX34A(at)prodigy.com (MR GEORGE T KILISHEK) Frank van der Hulst wrote: "I'm doing the same," (PVC conduit through wings) " except I'll put my PVC pipe in front of the main spar. I'll make up a couple of little brackets to hold it between the spar and tank. This was recommended to me by Bill Benedict. It apparently helps solve some wire routing issues in the cockpit." I'm really dumb, I'll concede, but I can't visualize this. On my wing, the "Z" brackets which mount the tank preclude any conduit between the tank and the spar, and there doesn't appear to be room between the tank and the spar stiffeners for a 7/8" D. PVC pipe. What am I missing? George RV-8 #80006 wings. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>John Darby <<a href="mailto:johnd@our-town.com">johnd@our-town.com</a>></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: First Flight C-GDOC</u></b></i></font></td></tr></table> --> RV-List message posted by: John Darby <<a href="mailto:johnd@our-town.com">johnd@our-town.com</a>> >--> RV-List message posted by: Dr John Cocker <jcocker(at)medhumor.com> Congratulations. John Darby RV6 sold Stephenville TX <a href="mailto:johnd@our-town.com">johnd@our-town.com</a> ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>John Darby <<a href="mailto:johnd@our-town.com">johnd@our-town.com</a>></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: engine failure</u></b></i></font></td></tr></table> --> RV-List message posted by: John Darby <<a href="mailto:johnd@our-town.com">johnd@our-town.com</a>> >--> RV-List message posted by: Tom Martin <fairlea(at)execulink.com> > I was convinced that we still had partial power, but it was just the >noise of the engine windmilling. >This is my second dead stick landing in this aircraft, Tom; are you trying to proved that practice makes perfect?:-) Congratulations on a well done. >From what I remember, the force required to drag one over grass, when you dragged it over the plowed field, the adrenalin must have still been pumping strong!! John Darby RV6 sold Stephenville TX <a href="mailto:johnd@our-town.com">johnd@our-town.com</a> ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Dave Barnhart <barnhart(at)A.crl.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Prop Governors</u></b></i></font></td></tr></table> --> RV-List message posted by: Dave Barnhart <barnhart(at)A.crl.com> Ron: >I have a Prop Governor which came off a Twin Commanche which had Lyc. 0-320 >150 fuel injected engines. I would like to install it on my 0-320 D3G 160 >hp. Any ideas on how I could go about finding out if it will work on my >engine? Should I call Lycoming or Hartzell or someone else. Appreciate >any ideas. Thanks. That prop governor is a full-feathering governor. You don't want to use it on your RV. I know because *my* engine is an IO320-B1A from a Twin Comanche, and I worked that problem about a year ago. Best Regards, Dave Barnhart rv-6 sn 23744 electrical & avionics installed engine assembly starts next week ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 23, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Jim Phillips <jimphil(at)earthlink.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: engine failure</u></b></i></font></td></tr></table> --> RV-List message posted by: Jim Phillips <jimphil(at)earthlink.net> Tom Martin wrote: > > --> RV-List message posted by: Tom Martin <fairlea(at)execulink.com> > > Tonight while flying home from a local flight the engine in my RV-4 quit. > I love this plane, I have however lost a lot of respect for this engine! > I have a 180hp I0-360 with a bendix injector, everything stock. > Tom Martin > RV-4 Good job on saving yourselves & the plane. Intresting note, the July issue of Light Plane Maintenance just arrived & there is a notice about Lycoming IO-360 piston pins failing. The pins (LW-14077) were from Textron Lycoming and were shipped between December 15, 1995 and September 17, 1996. According to the article, Lycoming changed vendor suppliers for 1000 pins. To date, only 385 have been returned for warranty replacement. In the same issue there is concern that the Superior Air Parts, Inc. pin (SL-13444-1) is also failing. Failing may be too kind, the picture in the article shows the pin broken and in two pieces. The editor of Light Plane Maintenance can be reached at 970-663-9379 or lpmed(at)frii.com Jim ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Vanremog(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV6 Panel mod.</u></b></i></font></td></tr></table> --> RV-List message posted by: Vanremog(at)aol.com << I too have some questions about dimensions for a throttle/mixture/prop sub-panel. Specifically, I am wondering what's a reasonable center to center distance between the controls. >> Randall- I used 3" centers and my subpanel is 7.5"W x 1.5"H. It seems like a good feel to me, plenty of room for large hands, yet close enough to get to them all when you need to. -GV ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Ian Dadd <gidadd(at)tpgi.com.au></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RTV in control surfaces</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table> --> RV-List message posted by: Ian Dadd <gidadd(at)tpgi.com.au> Hi John, Had a similar problem with my RV-6 elevators. Paul O'Connor gave me an invaluable tip. Use short lengths (25mm or 1 inch in old money) of plastic drinking straw in the trailing edge radius behind the stiffeners. RTV over the lot. Leave the open ends free of course. Water can't get trapped though I doubt any will be in the rudder, the elevators are a different matter. I think someone else has already replied about this. If you have a bit of trouble getting into the confined space down there use some plastic tubing - maybe another long straw taped onto the nozzle of the RTV cartridge to apply the sticky stuff into the trailing edge. Mineral turpentine for clean-up. Cheers Ian - RV-6 Empennage almost completed ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Mark LaBoyteaux <tailspin(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Alternator modifications</u></b></i></font></td></tr></table> --> RV-List message posted by: Mark LaBoyteaux <tailspin(at)ix.netcom.com> Tim Lewis wrote: snip > Alternator: I need a big alternator (60 A) to run my night/IFR > electrical load. I have the mounting kit from Van's, which suggests > a Mazda 323 alternator (65 amps). That's fine, except it has an > internal regulator. Does anybody have any experience to share on > either disabling internal regulators or finding automotive > alternators without internal regualtors? > > Thanks, > > Tim > --------------------- > Tim Lewis > RV-6AQ #60023 > San Antonio TX > timrv6a(at)earthlink.net or > timrv6a(at)iname.com > ----------------------- Tim & Listers, I had talked to a local alternator repair shop about modifying my alternator off of a Mazda 323 to use an external regulator in order to incorporate overvoltage protection. On the phone the guy said "No problem". After disassembling the alternator, he said "No way". Apparently, the brushes are manufactured in assembly with the solid state regulator, and there was no way to seperate them. Mark LaBoyteaux RV-6A fitting cowling & C/S spinner tailspin(at)ix.netcom.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>JamesCone(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Blast tube</u></b></i></font></td></tr></table> --> RV-List message posted by: JamesCone(at)aol.com I have used it to cool my alternator, mags, and fuel pump. It works great. Jim Cone jamescone(at)aol.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>mauser(at)claris.com (Richard Chandler)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Dead Stick</u></b></i></font></td></tr></table> --> RV-List message posted by: mauser(at)claris.com (Richard Chandler) > I have often wondered if there is much instruction and practice on > dead stick landings done these days. My checkride involved a dead stick landing on a little barely marked grass strip in a valley which I had only seen once before. Did a pretty good job of it too. And it came at a perfect time. I was able to get out of the plane and use the portapotty (Man did I need it!). Take-off was tricky, had to split the difference between short field and soft field techniques. I then proceeded to really screw up my s-turns over the road, and I would have failed if I hadn't done an absolutely perfect constant speed constant altitude 360 degree standard turn (Best one I ever did, the needles could have been painted on). -- Richard Chandler <mauser(at)claris.com> RV-6: Garage bought and being finished, saving for tools and tail kit. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Mark LaBoyteaux <tailspin(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: balance</u></b></i></font></td></tr></table> --> RV-List message posted by: Mark LaBoyteaux <tailspin(at)ix.netcom.com> For my elevators, I bought the pre-cast weights from Van's. They fit well, and were easy to install. On my left elevator half with the trim tab, the weight was just slightly more than required, and I'm leaving it that way untill I'm finished with the exterior painting. On the right elevator half, I wound up using a suicide countersink to remove quite a bit of excess lead in order to get it to balance the same as the left one. Mark LaBoyteaux RV-6A N106RV fitting cowl & C/S spinner tailspin(at)ix.netcom.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"W. Tom Glover" <tglovebox(at)bc.sympatico.ca></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Grounding questions</u></b></i></font></td></tr></table> --> RV-List message posted by: "W. Tom Glover" <tglovebox(at)bc.sympatico.ca> Dave Barnhart wrote: > > --> RV-List message posted by: Dave Barnhart <barnhart(at)A.crl.com> > > Bob: > > >Just found your original about the ground block and > >solder sleeves. Did we get all your questions answered? > > Except one: > Back to those terminal blocks... > I have a couple of spots, though, where I could use *something* like that: > >....etc...... Greetings, Dave. You were looking for studded terminal blocks for multiple connections? Well, if you get to your local aircraft parts supplier you will find them listed as MS27212(ASG) Terminal Board, Assembly, Molded-in Stud, Electric. They are available with stud sizes of #6, #8, #10, 1/4", 5/16", and 3/8". These things have a single row of studs with insulating pylons. There is another style of terminal block, which I have two of, that are used on some Cessnas that have 6 - 3/16" male spades under one rivet in a fan pattern. _\!.!/_ kinda like that. They aren't in my 182 parts books so I'll have to get out to the local Cessna emporium (real soon now) and see if I can find the part number again. Good luck on the project. Ain't wiring grand? Cheers, Tom Glover ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Frank van der Hulst <frankv(at)pec.co.nz></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: Frank van der Hulst <frankv(at)pec.co.nz> prodigy.com!GHLX34A(at)matronics.com wrote: > > --> RV-List message posted by: GHLX34A(at)prodigy.com (MR GEORGE T KILISHEK) > > Frank van der Hulst wrote: "I'm doing the same," (PVC conduit through > wings) " except I'll put my PVC pipe in front of the main > spar. I'll make up a couple of little brackets to hold it between > the > spar and tank. This was recommended to me by Bill Benedict. It > apparently helps solve some wire routing issues in the cockpit." > > I'm really dumb, I'll concede, but I can't visualize this. On my > wing, the "Z" brackets which mount the tank preclude any conduit > between the tank and the spar, and there doesn't appear to be room > between the tank and the spar stiffeners for a 7/8" D. PVC pipe. > > What am I missing? I guess the -8 must have a different tank-mount from the -6. I understand the -4 is also different from the -6. The -6 has a C-channel doubler on the front of the main spar, so there's a flange top and bottom facing forward. The tank's rear wall is also a C-channel, with flanges top and bottom facing backwards. Thus, there's a gap an inch wide or so through which the conduit can be put. (At least, I hope there is!) Frank. RV-6 #24692, Wings. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Alternator modifications</u></b></i></font></td></tr></table> <33B0B80A.1D05(at)ix.netcom.com> <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>wstucklen1(at)juno.com (Frederic W Stucklen)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table> --> RV-List message posted by: wstucklen1(at)juno.com (Frederic W Stucklen) Tim & listers, Try modifying a Nippon Alternator. It's a very simple process.... Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com <ix.netcom.com!tailspin(at)matronics.com> writes: >Tim & Listers, > I had talked to a local alternator repair shop about modifying my >alternator off of a Mazda 323 to use an external regulator in order to >incorporate overvoltage protection. On the phone the guy said "No >problem". After disassembling the alternator, he said "No way". >Apparently, the brushes are manufactured in assembly with the solid >state regulator, and there was no way to seperate them. > >Mark LaBoyteaux >RV-6A fitting cowling & C/S spinner >tailspin(at)ix.netcom.com > > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Stephen J. Soule" <SSoule(at)pfclaw.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>balance</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "Stephen J. Soule" <SSoule(at)pfclaw.com> And on the same subject ... I know that my RV-6 ailerons have a heavy water pipe in the nose to balance them. I don't know how to make sure that the pipe alone is heavy enough or too heavy. Does anyone in RV land have any advise on how to check the aileron balance? Steve Huntington, Vermont ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Louis E. Smith Jr." <lsmith(at)coastalnet.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wire Runs</u></b></i></font></td></tr></table> --> RV-List message posted by: "Louis E. Smith Jr." <lsmith(at)coastalnet.com> >--> RV-List message posted by: GHLX34A(at)prodigy.com (MR GEORGE T KILISHEK) > >Frank van der Hulst wrote: "I'm doing the same," (PVC conduit through >wings) " except I'll put my PVC pipe in front of the main >spar. I'll make up a couple of little brackets to hold it between >the >spar and tank. This was recommended to me by Bill Benedict. It >apparently helps solve some wire routing issues in the cockpit." > >I'm really dumb, I'll concede, but I can't visualize this. On my >wing, the "Z" brackets which mount the tank preclude any conduit >between the tank and the spar, and there doesn't appear to be room >between the tank and the spar stiffeners for a 7/8" D. PVC pipe. > >What am I missing? > >George >RV-8 #80006 wings. > George, The tanks on the RV-4 and RV-6 don't have the "Z" brackets on the rear baffel. They are connected to the wing just by the screws around the edge of the tank. Regards, Louis Smith lsmith(at)coastalnet.com Rocky Mount, NC RV-8 #80126 N801RV reserved RV-4 #2844 N102LS sold (919)937-4905 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 24, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RodWoodard <rodwoodard(at)mcione.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: gps/com</u></b></i></font></td></tr></table> --> RV-List message posted by: RodWoodard <rodwoodard(at)mcione.com> > --> RV-List message posted by: "Grant E. Young" <gyoung(at)crl.nmsu.edu> > > If anybody has any opinions on the King vs. Garmin GPS/COMs I would be > interested in hearing them, > > Thanks, Grant- Please post responses to the list on this one. I'm interested too! Rod Woodard RV-8, #80033 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Pitot Heat continued.....</u></b></i></font></td></tr></table> <33B07232.6A38(at)ix.netcom.com> <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>wstucklen1(at)juno.com (Frederic W Stucklen)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table> --> RV-List message posted by: wstucklen1(at)juno.com (Frederic W Stucklen) Mark, Your story reminds me of a CFII, whom, while instructing his student (on the ground) on the need to check the pitot heat, burned his fingers demonstrating that it was indeed working! Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com <ix.netcom.com!tailspin(at)matronics.com> writes: >--> RV-List message posted by: Mark LaBoyteaux ><tailspin(at)ix.netcom.com> > >The pitot tube I have is a Cessna type. The battery indicator has been >showing for some time on my voltmeter,so after running down to WalMart >for a new one and making sure the meter was properly zeroed, the heater >element now measures about 2.6 ohms. I decided to do a little >experimenting, and put the tube in my freezer for a couple of hours. The >resistance now checked at 2.5 ohms. So I took my jumper cables and >connected it to the battery in my truck. It pulled 4.9 amps. After about >15 seconds, all of the frost melted. The phone rang. It was some >salesman wanting to clean my ductwork, I said no thanks. I went back to >check on the pitot tube which has now been heating for a few minutes, >and grabed hold of it to see how warm it was. YEEEOOOWW! That sucker was >hot! Now it was pulling about 4.5 amps. I disconnected it, and now it >measured 2.9 ohms. Ops check ok. > Now off to WalMart to get some salve for my fingers..... > >Mark "Smokin' Fingers" LaBoyteaux >RV-6A N106RV >tailspin(at)ix.netcom.com > > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Denny Harjehausen <retflygtiger(at)proaxis.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Panel tilt and gyros</u></b></i></font></td></tr></table> --> RV-List message posted by: Denny Harjehausen <retflygtiger(at)proaxis.com> As I have been reading about this tilt I have been wondering how long the average RV panel would be in the eight degree position. It seems to me that it couldn't make much difference. Maybe in something very stable such as a 747 or something of that type. But wouldn't the RVs be moving around to much to make any difference at all? Have a Good Day! Denny RV-6 (R)N641DH Fuselage top side Lebanon, OR ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Mlfred(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: balance</u></b></i></font></td></tr></table> --> RV-List message posted by: Mlfred(at)aol.com << On the right elevator half, I wound up using a suicide countersink to remove quite a bit of excess lead in order to get it to balance the same as the left one. >> DOH! For those who may not have "balanced" this assembly, I would suggest doing this balance procedure AFTER painting. Mark, I hope your parts are painted........ Check six! Mark ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Craig Hiers <<a href="mailto:CRAIG-RV-4.@worldnet.att.net">CRAIG-RV-4.@worldnet.att.net</a>></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Lycoming</u></b></i></font></td></tr></table> --> RV-List message posted by: Craig Hiers <<a href="mailto:CRAIG-RV-4.@worldnet.att.net">CRAIG-RV-4.@worldnet.att.net</a>> I need to make a decision reguarding my 0320. I recevied the motor about three months ago from Eustace Bowhay, my plans were to get the engine on the plane and get it runing ASAP. As usual my best laid plans have been shot to hell agian. Now it will be at least three more months before the motor can be started. I was told that the motor has preservative oil in it, however if it does it has very little ( it does not show on the dip stick ). What should I do, if anything to make sure there is no internal pitting, rusting, or whatever. The humidity here in Florida is very high right now and I feel I should do something. Any ideas would be of great help. Craig Hiers RV-4 N143CH ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Boris <smbr(at)digital.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: balance</u></b></i></font></td></tr></table> --> RV-List message posted by: Boris <smbr(at)digital.net> If the surface dose not twist it should not matter that the balance weight is not in the center. As a note, the purpose of balancing is to avoid control surface flutter. I was recently told that when flutter occurs, say on an aileron, the wing is twisting and with a non-balanced surface, the tendancy is for the surface to accentuate the twist, or flutter, due to inertia. So, it is better for the aileron to be nose heavy so that any oscillation will have a dampening effect. Michael C. Lott wrote: > > --> RV-List message posted by: lottmc(at)datastar.net (Michael C. Lott) > > While we are on the subject of balancing control surfaces, (I thought I > slid into that rather smoothly), what is the best way to do it, how > close does it have to be, what are the ramifications of not doing it > properly, and since it will be balanced mainly fore and aft, does it > matter if the balancing weight is added only to a side, and not in the > center of the plane being balanced? All answers appreciated. Thanks, > Michael ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Robert Acker <r.acker(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: gps/com</u></b></i></font></td></tr></table> --> RV-List message posted by: Robert Acker <r.acker(at)ix.netcom.com> >--> RV-List message posted by: "Grant E. Young" <gyoung(at)crl.nmsu.edu> > >If anybody has any opinions on the King vs. Garmin GPS/COMs I would be >interested in hearing them, > >Thanks, Grant- Grant, panel-mount or handheld gps/com's? I've been researching panel mounts, and the Garmin GNC250XL has a *much* richer feature set and screen in comparison to the King KLN-135A, at about the same price. However, Garmin's database updates cost twice those of King's :( . Rob Acker / r.acker(at)ix.netcom.com / RV-6Q ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Robert Acker <r.acker(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Pitot Heat Resistance</u></b></i></font></td></tr></table> --> RV-List message posted by: Robert Acker <r.acker(at)ix.netcom.com> >--> RV-List message posted by: "Larry D. Hoatson" <lhoatson(at)e2.empirenet.com> > >> The spec sheet for the 12-volt AN5812 I installed this weekend claims 4.5 >> amps. So, should I size up the wire & breaker for 5 or 10 amps? >> Rob Acker / r.acker(at)ix.netcom.com / RV-6Q > >Hello Rob, >Do you have a copy of AC 43.13? It has the wire size information for a >given load and length of run - then I usually go 1 size larger. Larry, Sorry, I don't think I made my point clear. Everything I have read about the 12-volt AN5812 in the archives and current discussion indicates it requires 10 amps. The documentation that I received with my AN5812 indicates 4.5 amps. Which one is right? Which load do I size the wire/breaker for? >How's the bird coming? Was Bakersfield worth the trip? Sorry we missed you. >Larry To all listers I heartily recommend the Bakersfield fly-in. I learned more there about what I want to do, and what I don't want to do, with my RV during construction than two visits to sun'n'fun! I also got to meet a few listers face to face! Great bunch, very helpful and knowledgeable, and willing to share it. Rob Acker / r.acker(at)ix.netcom.com / RV-6Q ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: balance</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>less_drag(at)juno.com (JAMES E AYERS)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table> --> RV-List message posted by: less_drag(at)juno.com (JAMES E AYERS) <pfclaw.com!SSoule(at)matronics.com> writes: >--> RV-List message posted by: "Stephen J. Soule" <SSoule(at)pfclaw.com> (Snip) >Does anyone in RV land have any advise on >how to check the aileron balance? > >Steve >Huntington, Vermont Hello Steve and all, Hang the PAINTED aileron upside down by the two hinges. The trailing edge should be higher than the leading edge in this position. BTW, the assembled aileron will fall over from almost any position you try to set, or stand, it, so find a place to store them for there own protection. Jim Ayers Less_Drag(at)juno.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Robert Acker <r.acker(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Pitot Heat continued.....</u></b></i></font></td></tr></table> --> RV-List message posted by: Robert Acker <r.acker(at)ix.netcom.com> >--> RV-List message posted by: Mark LaBoyteaux <tailspin(at)ix.netcom.com> > >The pitot tube I have is a Cessna type...YEEEOOOWW! That sucker was >hot! Now it was pulling about 4.5 amps. I disconnected it, and now it >measured 2.9 ohms. Ops check ok. > Now off to WalMart to get some salve for my fingers..... >Mark "Smokin' Fingers" LaBoyteaux Mark, I guess that answers my question regarding the load of a 12-volt AN5812, 4.5 amps. Thanks for saving *my* fingers <g>. Rob Acker / r.acker(at)ix.netcom.com / RV-6Q ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>steve(at)barnardaircraft.com (barnardaircraft)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>BAC RV-6A, Rocky Mtn. Fly-In</u></b></i></font></td></tr></table> --> RV-List message posted by: steve(at)barnardaircraft.com (barnardaircraft) For those of you interested, Barnard Aircraft's RV-6A, N157ST with numerous speed mods, which include the "Holy Cowl", for 200 Hp installations, cooling plenum, wing tips, root fairings, new gear leg fairings and new wheel pants will be at the Rocky Mountain Fly-In at Longmont, Colorado on June 28, 1997 which is a Saturday. I will be spending sometime at the airplane for those of you have questions about RV clean up for speed and efficiency. Note: It's easier to install speed mods as you build the airplane, compared to working on a completed airplane. I will be arriving at Longmont Airport on Friday evening and will put the airplane in Mike Willis's hangar. See you there. Respectfully, Steve Barnard Barnard Aircraft Components RV-6A N157ST 1000 hrs flying steve(at)barnardaircraft.com <a target="otherpages" href="http://www.barnardaircraft.com">http://www.barnardaircraft.com</a> ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"John B. Abell" <jbabell(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Panel tilt and gyros</u></b></i></font></td></tr></table> --> RV-List message posted by: "John B. Abell" <jbabell(at)ix.netcom.com> I think it does matter with the attitude gyro if you ever reach up to center the little "airplane" on your artificial horizon. The question is whether you want the artificial horizon in the center of the window when you're straight and level, right? Jack Abell RV-6A N333JA (Reserved) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Jerry Springer <jsflyrv(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Panel tilt and gyros</u></b></i></font></td></tr></table> --> RV-List message posted by: Jerry Springer <jsflyrv(at)ix.netcom.com> This has been said before but I will say it again as there still seems to be allot of questions on this topic. The ONLY reason you need the eight degree tilt is so the little adjustable airplane that moves up and down can be lined up with the horizon line. When you fly in level flight and the instrument is tilted this moves your horizon indicator line up. Jerry Springer RV-6 N906GS First flight July 14, 1989 :-) Hillsboro, OR jsflyrv(at)ix.netcom.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>RodWoodard <rodwoodard(at)mcione.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Help near SFO</u></b></i></font></td></tr></table> --> RV-List message posted by: RodWoodard <rodwoodard(at)mcione.com> Hello all: I'm considering the purchase of a Smith Miniplane that's located in Hayward, California (near San Francisco). The price seems reasonable and I need to hook up with somebody who's qualified to do a pre-buy inspection. I'm hoping to find somebody who's experienced with experimentals and fabric covered airplanes. I'll of course be willing to compensate this person for his time. On the off-chance that anyone might be familiar with the airplane, I'd love to hear from you. It belongs to Bob Taylor and it's painted in a US Navy pattern. It's a basic VFR bi-plane about the size of a Pitts S-1. I apologize if this non-rv-related post offends anyone. This is just such an incredible nationwide resource that I can't think of any other means which would be more effective in my search. Please reply to me via direct e-mail to save any additional clutter to the list. My address is rodwoodard(at)mcione.com Thanks in advance! Rod Woodard RV-8, #80033 [Maybe a Smith Miniplane in the meantime] Loveland, Colorado ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>randall(at)edt.com (Randall Henderson)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Pitot Heat Resistance</u></b></i></font></td></tr></table> --> RV-List message posted by: randall(at)edt.com (Randall Henderson) > Everything I have read about the 12-volt AN5812 in the archives and current > discussion indicates it requires 10 amps. The documentation that I received > with my AN5812 indicates 4.5 amps. > > Which one is right? Which load do I size the wire/breaker for? My documentation for the same pitot says 6.4 to 8A. I will probably use a 10A breaker and 16 ga wire. I got the wire size not from any fancy calculations but instead from looking at Nuckolls' diagrams, which show 16 ga wire on a 10A breaker for a position light circuit. Randall Henderson, RV-6 randall(at)edt.com <a target="otherpages" href="http://www.edt.com/homewing">http://www.edt.com/homewing</a> ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Jerry Prado (Excell Data)" <v-jerryp(at)microsoft.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>gps/com</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "Jerry Prado (Excell Data)" <v-jerryp(at)microsoft.com> Another thing to consider is that you can not update the King 135 via an internet connection like you can with their 90 series. You are forced to use a floppy or send the cartridge in (they send you one first). Talk to people that have used the floppy method. It's touchy. I think that Trimble has the best software in terms of useability. However, Trimble has fallen behind in display technology. Even their approach certified offerrings rely on a two line LED display. Additionally, they don't offer a GPS/COM. I've used a KLN90 extensively and one of the things I did not like about it is that it REQUIRES altitude input before doing anything. It did not have a 3d mode. I don't know if the 135 shares this requirement but I would hate to loose my GPS if my encoder fails. Jerry Prado > -----Original Message----- > From: Robert Acker [SMTP:ix.netcom.com!r.acker(at)matronics.com] > Sent: Wednesday, June 25, 1997 8:41 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: gps/com > > --> RV-List message posted by: Robert Acker <r.acker(at)ix.netcom.com> > > >--> RV-List message posted by: "Grant E. Young" <gyoung(at)crl.nmsu.edu> > > > >If anybody has any opinions on the King vs. Garmin GPS/COMs I would > be > >interested in hearing them, > > > >Thanks, Grant- > > Grant, panel-mount or handheld gps/com's? > > I've been researching panel mounts, and the Garmin GNC250XL has a > *much* > richer feature set and screen in comparison to the King KLN-135A, at > about > the same price. However, Garmin's database updates cost twice those > of > King's :( . > > Rob Acker / r.acker(at)ix.netcom.com / RV-6Q ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Keith Warfield <KeithW(at)ncgwpc.syntellect.com></i></b></font></td></tr></table> <rv-list-request(at)matronics.com> <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>subscribe</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table> --> RV-List message posted by: Keith Warfield <KeithW(at)ncgwpc.syntellect.com> ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>JDaniel343(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>re:rivet squeezer</u></b></i></font></td></tr></table> --> RV-List message posted by: JDaniel343(at)aol.com The phone number for Bill Williams Tool Co., Fort Worth, TX is 1-817-838-2601. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Denny Harjehausen <retflygtiger(at)proaxis.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Lycoming</u></b></i></font></td></tr></table> --> RV-List message posted by: Denny Harjehausen <retflygtiger(at)proaxis.com> >I was told that the motor has preservative oil in it, however if it >does it has very little ( it does not show on the dip stick ). >What should I do, if anything to make sure there is no internal >pitting, rusting, or whatever. >The humidity here in Florida is very high right now and I feel I >should do something. >Any ideas would be of great help. > >Craig Hiers >RV-4 N143CH > I was told to fill it up completely, the man said completely, and turn the whole engine over once a month.... Have a Good Day! Denny RV-6 (R)N641DH Fuselage top side Lebanon, OR ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Grant E. Young" <gyoung(at)crl.nmsu.edu></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: gps/com</u></b></i></font></td></tr></table> --> RV-List message posted by: "Grant E. Young" <gyoung(at)crl.nmsu.edu> oooops, I was talking about hand-held GPS/Coms....sorry about that. grant- ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Bob Skinner <BSkinner(at)navix.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Lycoming</u></b></i></font></td></tr></table> --> RV-List message posted by: Bob Skinner <BSkinner(at)navix.net> >I was told that the motor has preservative oil in it, however if it >does it has very little ( it does not show on the dip stick ). >What should I do, if anything to make sure there is no internal >pitting, rusting, or whatever. >The humidity here in Florida is very high right now and I feel I >should do something. >Any ideas would be of great help. > >Craig Hiers >RV-4 N143CH Craig, I had a local welder build me an engine stand before I overhauled my engine. After overhaul, I left the engine bolted to the stand and put dehydrator (?) plugs in a spark plug hole in each cylinder. I went to the local pharmacists and obtained a bunch of packets of silica gel and taped them to the engine and then put two clear, plastic bags over the engine and secured the bags at the prop flange with duct tape. I did this in the winter when it was dry and I think I ended up drying the plugs and packets of silica gel a couple of times. If I were to do it over again, I would hook a shop vac up to the bag and suck as much air out as I could. When I bolted the engine on, it stayed in my air-conditioned shop in which I also ran a de-humidifer and I ended up drying the plugs six or seven times over a 1 1/2 years, or so. Bob Skinner ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Denny Harjehausen <retflygtiger(at)proaxis.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Panel tilt and gyros</u></b></i></font></td></tr></table> --> RV-List message posted by: Denny Harjehausen <retflygtiger(at)proaxis.com> The ONLY reason you need >the eight degree tilt is so the little adjustable airplane that moves up >and down can be lined up with the horizon line. When you fly in >level flight and the instrument is tilted this moves your horizon >indicator line up. > Ah Ha...I see what you all have been talking about...I was thinking reliablity here. Looking in ACS Sigma Tek shows a choice at a much higher price...RC Allen doesn't mention a choice. Has anyone purchased any other Horizon with this 8 degree choice. Have a Good Day! Denny RV-6 (R)N641DH Fuselage top side Lebanon, OR ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: balance</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>lm4(at)juno.com (Larry Mac Donald)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table> --> RV-List message posted by: lm4(at)juno.com (Larry Mac Donald) On Tue, 24 Jun 1997 19:19:36 (Michael C. Lott) writes: While we are on the subject of balancing control surfaces, (I thought I slid into that rather smoothly), what is the best way to do it? I can't tell you. I only have plans for a 6. how close does it have to be? IMO--Close. what are the ramifications of not doing it properly? Death. In the several texts that I have read, the designers mention that you cannot have an imbalance of the control surfaces or you will have flutter. Then they go into pilot talk about flutter will bring about some destruction of parts or a poor flying envelope. I think that may mean ( Re: Molt Taylor ) that the aileron will destroy itself and rip the wing off along with it. and since it will be balanced mainly fore and aft, does it matter if the balancing weight is added only to a side, and not in the center of the plane being balanced? I don't know. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>JMJN01(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Wanted to buy: RV-4/rv 4 for sale</u></b></i></font></td></tr></table> --> RV-List message posted by: JMJN01(at)aol.com Thank you. I saw his add in Trade-a-plane last month. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Stephen J. Soule" <SSoule(at)pfclaw.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>balance</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "Stephen J. Soule" <SSoule(at)pfclaw.com> The trailing edge is level with the nose on both of my unpainted ailerons. Should I add lead to the water pipe? Steve Huntington, Vermont ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Stephen J. Soule" <SSoule(at)pfclaw.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>aileron balance</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table> --> RV-List message posted by: "Stephen J. Soule" <SSoule(at)pfclaw.com> The trailing edge is level with the nose on both of my unpainted ailerons. Should I add lead to the water pipe? Steve Huntington, Vermont PS, I hang the ailerons from the ceiling when I'm not using them 'cuz they do fall easily! ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Glenn & Judi <<a href="mailto:flyers@anet-chi.com">flyers@anet-chi.com</a>></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RV6 VFR or IFR</u></b></i></font></td></tr></table> --> RV-List message posted by: Glenn & Judi <<a href="mailto:flyers@anet-chi.com">flyers@anet-chi.com</a>> I am in the panel planning stages of my RV-6 project. I would like to set the aircraft up for LIGHT IFR. IFR GPS, Loc/GS, Marker Beacon etc. I have flown in an RV-6, but not on instruments. How does the RV-6 handle on instruments? As far as the panel goes, IFR vs. VFR, should I or shouldn't I? Any thoughts on the matter are appreciated. How much does it cost per year to keep the typical IFR GPR updated? Thanks in advance, Glenn Gordon ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>AlexMSl(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: first flight</u></b></i></font></td></tr></table> --> RV-List message posted by: AlexMSl(at)aol.com To Les Vaughan RV-6 C-FYQD Congratulations of the first flight. I know the feeling. I've had it twice and watched two others land with the RV GRIN. Alex Sloan RV-6 N626BA 130 Hours. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Jeremy William Benedict <jbenedic(at)uofport.edu></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Part numbers)</u></b></i></font></td></tr></table> --> RV-List message posted by: Jeremy William Benedict <jbenedic(at)uofport.edu> > --> RV-List message posted by: dougm(at)mailhost.physio-control.com (Doug Medema) > P.S. Sure would be nice if VANS would get the whole > parts catalog on their web page. Hint, Hint! Yeah, it sure would be nice. ;-) I just happen to be working on a few "minor" additions to the Van's web site and am looking for a few people to help out. Basically, I just would like a few more eyes to look over some of the additions to help proof them out. If you would like to help out, and have a spare hour or two in the next couple of days, please send me an e-mail to: jbenedic(at)uofport.edu Just, whatever you do, DON'T hit the reply key, and PLEASE DO NOT reply to the rv-list if you would like to preview, just send it to my address...... Thanks! Jeremy :-) :-) ----------------------------------------------------------------------- | name://Jeremy Benedict | PP-ASEL (1994) [R/E: TD,HP] | |email://jbenedic(at)uofport.edu | Logged: RV-4,-6,-6A,-6B,-6T | | <a target="otherpages" href="http://wally.uofport.edu/~jbenedic|">http://wally.uofport.edu/~jbenedic|</a> Cessna 150, 182 | |voice://503.514.3100 pager/vmail | TT: 303.6 hrs TT-RV: 164.6 hrs | ----------------------------------------------------------------------- ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>dralle(at)matronics.com (Matt Dralle 510-606-1001)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Test...</u></b></i></font></td></tr></table> --> RV-List message posted by: dralle(at)matronics.com (Matt Dralle 510-606-1001) This is a test message. Matt -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 510-606-1001 Voice | 510-606-6281 FAX | dralle(at)matronics.com Email <a target="otherpages" href="http://www.matronics.com/">http://www.matronics.com/</a> W.W.W. | Featuring Products For Aircraft +----------------------------------------------------------------------------+ | --- The RV-List is sponsored by Matronics --- | | Featuring a line of affordable Aircraft Fuel Managment Instrumentation | | Visit the Matronics & RV-List Web Site at <a target="otherpages" href="http://www.matronics.com!">http://www.matronics.com!</a> | | --- | | To [un]subscribe to the RV-List, email "rv-list-request(at)matronics.com" and | | put the word "[un]subscribe" in the *body*. No other text or subject. | +----------------------------------------------------------------------------+ ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>dralle(at)matronics.com (Matt Dralle 510-606-1001)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Test</u></b></i></font></td></tr></table> Matt is testing. Matt Dralle -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 510-606-1001 Voice | 510-606-6281 FAX | dralle(at)matronics.com Email <a target="otherpages" href="http://www.matronics.com/">http://www.matronics.com/</a> W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>dralle(at)matronics.com (Matt Dralle 510-606-1001)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>ANR - Headsets Inc...</u></b></i></font></td></tr></table> Builders, I sent the following message to Headset Inc., but never received a reply. Headsets Inc. make what appears to be a very slick modification for most aviation headsets adding some active noise reduction. Their web page is at: <a target="otherpages" href="http://members.aol.com/anrsets.">http://members.aol.com/anrsets.</a> Email: anrsets@aol.com Has anybody tried these units out? Seems like a neat idea, but I am concerned about the fidelity of the DPS. See message below. Thanks, Matt > > Dear Headsets Inc., > > I read with interest your informational web page on the ANR headset > modifications. I have 2 sets of DC-40 headsets that I have modified > with Sony V6 Pro headphone speaker elements. The V6 elements are > exactly the same size as the DC-40 units and the retaining ring can be > reused. It makes for a very slick installation/retrofit. The best part > is that the fidelity of the headset when used with the PM2000 stereo > intercom is unbelieveable. I have also modified the PM2000 somewhat by > removing the low-pass filtering that attenuates most of the bass. > > I was wondering if your ANR systems could be adapted to my setup? > Obviously I would want to continue to use the Sony elements but I am > concerned about performance of the TI DSP and the possible negative > impact on the over all frequency response available. The ANR would > obviously be an excellent addition to my current system if good response > and low distortion were available. > > Thank you for your time, > > Matt Dralle > RV-4 N442RV > -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 510-606-1001 Voice | 510-606-6281 FAX | dralle(at)matronics.com Email <a target="otherpages" href="http://www.matronics.com/">http://www.matronics.com/</a> W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>TOMRV4(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Blast tube</u></b></i></font></td></tr></table> << Has anyone used the plastic lightweight wiring conduit Vans supplies in their wiring kits as blast tube to cool mags, fuel pump, gascolator, etc. The catalog states it is suitable for use in the engine compartment as long as it remains 4-6" from exhaust pipes. -- >> I have an RV-4 that I use the conduit to cool the mags and fuel pump. I flew the plane for about 200 hours, then installed the conduit, and now have about 640 hours total time and have had no problems with it...except...The first time I flew the plane after installing them I had a very annnoying "whistle" coming from the engine compartment. It was audible both on the ground and in the air! Apparently the air moving across the ribs in the conduit caused the whistling. I was ready to yank out the stuff, when I decided to do a little testing, and found by adding some subltle "bends" to the conduit and tie wrapping them off to the engine mount the whistling was eliminated. I was able to verify this by simply blowing thru the conduit. (Yes just put your lips on it and blow!) Tom Chapman RV-4 N153TK Working on RV-8 tail kit- 80025 TOMRV4(at)aol.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>dralle(at)matronics.com (Matt Dralle 510-606-1001)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>test</u></b></i></font></td></tr></table> This is a test. Matt -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 510-606-1001 Voice | 510-606-6281 FAX | dralle(at)matronics.com Email <a target="otherpages" href="http://www.matronics.com/">http://www.matronics.com/</a> W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>dralle(at)matronics.com (Matt Dralle 510-606-1001)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>test</u></b></i></font></td></tr></table> This is a test. Matt -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 510-606-1001 Voice | 510-606-6281 FAX | dralle(at)matronics.com Email <a target="otherpages" href="http://www.matronics.com/">http://www.matronics.com/</a> W.W.W. | Featuring Products For Aircraft .| .| .| .| ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>dralle (Matt G. Dralle 510-606-1001)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>test</u></b></i></font></td></tr></table> test test Matt .| .| .| .| ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>dralle (Matt G. Dralle 510-606-1001)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>test</u></b></i></font></td></tr></table> test test Matt ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>jperri(at)interserv.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Off Field Landing</u></b></i></font></td></tr></table> Well you can't have a perfect flight every day. Last Thursday at 7:30 PM local time, two creatures of flight tried to occupy the same airspace. I took a direct hit on the pilot side of the canopy on my RV-6. They say that in critical situations, time slows down. I was able to see the bird clear enough to remark later, that he came through feet or rear end first. This was later verified when the rescue crew and FAA located the bird in my downed craft. While moving far enough left to avoid a direct bird hit to the forehead, I did take on a large chunk of the canopy in the head... Hurt and blood followed. My sun glasses were covered with bird remains on the right and me on the left. I cut power and looked for an on field landing but speed and altitude, told me I might over run and the chances of survival at that end of the runway (fence, 6 ft. ditch, road, fence and another ditch ) then a house and old oil refining stuff slim. Bad choice ! I attempted a go around but got extreme vibration with an added power. Bird two ( his/her mate) got the prop. More blood and an ever increasingly difficult aircraft to fly stated to limit my choices. In the past I have selected several emergency spots to land at my local field and selected what I thought would be a no damage field. Everything went well over the ditch ,hump and barb wire fence. Touch down ... when did that alfalfa get so tall ? Held the tail on the ground and maintained stability. As I was rolling to a safe stop my world went inverted, along with the plane. One of the wheel paints filled with muck allowing the front half to roll under the tire and ..over we went . Almost convinced it not to at the top but as I went over I leaned into the passenger seat as far as possible. Good choice since my neck would have been three inches to long. I tried to get out the pilot side but this was at ground level. I kicked out (what little remained of the canopy on the passenger side) pushed up and got the He## out of there. Well a few stitches later I am in the process of fixing the damage. Still pondering the hole made by the bird( pidgin -- thought it would bounce off and only leave cracks). As a CFII I always teach my students to pick a spot where survival is a guaranteed outcome and forget about aircraft damage. Much easier if it's not your first love. So once again (Skin - Tin - Ticket) Think I saved all three. RV will fly again soon. Hope the birds don't. JMP RV-6 N345JE 500 hrs. and holding ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Tom Martin <fairlea(at)execulink.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>failure update</u></b></i></font></td></tr></table> I now have a little more information on why the engine on my RV-4 quit Monday evening. As I said in an earlier post I found that I had compression in only two cylinders. One bad jug I could understand but two at the same time seemed hard to believe. After removing the number 4 cylinder and the intake and exhaust pipe on the failed # 1 cylinder I have discovered the problem. The intake valve failed in the #4 jug. The valve fell into the cylinder and bashed the top of the piston and destroyed the head. It did not put a hole in the piston or score the walls or rings. A good size junk of the valve travelled through the induction pipes into the #1 pot. It got stuck in the intake valve and caused it to lose compression. The mechanics that I have spoken to say that intake valves rarely fail and the odds of sucking up such a large junk are very low. In their opinion it was a case of metal fatigue and could only be explained as such. I wondered why #2 and #4 did not fire but they felt that the engine would not run on two cylinders. It would however, have run on three and allowed me to get to an airport. There was no metal in the oil intake screen and a very few flakes in the main oil screen. At this point the camshaft appears ok At this stage I am looking for advise. I am going to remove all jugs to inspect/repair/replace as necessary The sump and induction system will be taken apart and cleaned. There are some valve pieces unaccounted for. They may have gone out the exhaust but I am not counting on it. Is there anything else we should do. Is it possible to test the valve pieces to determine the cause of the failure. Can the remaining valves be tested for serviceability? I would like to thank the list for their concern and sincerely hope that none of you have to experience what I have on not one but two occasions. Tom Martin RV-4 sleeping better! Even thinking of Oshkosh ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Dave Barnhart <barnhart(at)A.crl.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: gps/com</u></b></i></font></td></tr></table> "Grant E. Young" <gyoung(at)crl.nmsu.edu> wrote: > >If anybody has any opinions on the King vs. Garmin GPS/COMs I would be >interested in hearing them, Yes, I have an opinion. I have just completed the installation of a King KLX135A in my panel. fine unit. absolutely no problems whatsoever. About a month after I purchased my KLX135A, Garmin announced the GNC250XL with the moving map. Had they done soe a month earlier, I would have considered it for two reasons: 1. I thinkk Garmin's display is much larger and easier to read. The Day/Night modes look impressive. 2. The Garmin has a serial RS232 air data input while the King does not. My RMI uEncoder has an *air data output*. This means that with the Garmin, I could provide it with altitude information *corrected for the current altimeter setting*. With the KLX135A, the best I can do is provide it with pressure altitude via the Mode C. (The ONLY place this matters is SUA alerts, by the way.) On the other hand, there is one thing about the King I DEFINITELY like better: The King has seperate left and right knobs. The left knobs are used only for the COM. The right knobs are used only for the GPS. The Garmin, on the other hand, has a single set of knobs for both 'sides'. I have not played with the Garmin, but I suspect that my feeble mind would cause me to continually be changing the wrong thing on the Garmin. Best Regards, Dave Barnhart rv-6 sn 23744 N601DB avionics & electrical installed engine assembly starts next week ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>jperri(at)interserv.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: gps/com</u></b></i></font></td></tr></table> Send me your questions directly about the garmin vs. King. I have both JMP ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>jperri(at)interserv.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV6 VFR or IFR</u></b></i></font></td></tr></table> I have an RV-6 . IFR equipped .. Send me your questions direct and I'll see if I can help. JMP ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>mlcarr(at)qdot.qld.gov.au (Martin Carr)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RV-Propellers</u></b></i></font></td></tr></table> I am trying to track down the correct details for a person who builds wooden propellers for RVs, the details I have are as follows: Aymar DeMuth 8213 Elbera Drive State - unknown Country - unknown Postcode - unknown phone number: 410 461 4329 (I am not sure if this is correct) fax: unknown email: unknown If anybody can help fill the gaps, it would be most helpful. I know of one person in Australia who has had a prop built for his RV-4 and is very satisfied. I would be interested in hearing from anybody else who may had a prop built from Aymar. Martin Carr (RV-6A builder) mlcarr(at)qdot.qld.gov.au Australia ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"John B. Abell" <jbabell(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Panel tilt and gyros</u></b></i></font></td></tr></table> Although the Aircraft Spruce catalog doesn't mention it, R. C. Allen vacuum-driven attitude gyros are available on special order with tilt correction, internal lighting, and failure warning flag. I've ordered one for myself. The price was $545.00. Jack Abell RV-6A N333JA (Reserved) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Mark LaBoyteaux <tailspin(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: balance</u></b></i></font></td></tr></table> aol.com!Mlfred(at)matronics.com wrote: > > > > << On the right > elevator half, I wound up using a suicide countersink to remove quite a > bit of excess lead in order to get it to balance the same as the left > one. >> > > DOH! > For those who may not have "balanced" this assembly, I would suggest doing > this balance procedure AFTER painting. > > Mark, I hope your parts are painted........ > > Check six! > Mark You are correct, Mark. It was going to involve the removal of quite a bit of lead for the right elevator. So I decided to go ahead and remove some of it from the outboard weight before I installed the elevator tip. Both of my elevators are still overbalanced and waiting on the finish paint before I put the precision balance on 'em. See 'ya! Mark LaBoyteaux tailspin(at)ix.netcom.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"John B. Abell" <jbabell(at)ix.netcom.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: gps/com</u></b></i></font></td></tr></table> Grant, There's an article on p. 48 of the July issue of Kitplanes magazine that compares the Bendix King and Garmin GPS/Comms. The author explains his reasons for preferring the Garmin. Jack Abell RV-6A N333JA (Reserved) ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Ernesto Sanchez <40106(at)utech.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Off Field Landing</u></b></i></font></td></tr></table> interserv.com!jperri(at)matronics.com wrote: >I took a direct > hit on the pilot side of the canopy on my RV-6. Can I ask what canopy you used?? ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"les williams" <lesliebwilliams(at)msn.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Panel tilt and gyros</u></b></i></font></td></tr></table> Denny, In the 350 hrs I flew my first RV-6A, along with several flights in other RVs, I was impressed with it's stability compared to other general aviation type aircraft that I've flown (mostly Piper and Cessna single engine). The RVs have good penetration, but do thud and ride a little rough in turbulent air. However, I've had some commercial rides that weren't much better. It sure doesn't bounce around like a leaf. And in smooth air, it rides like a dream. In either case, when properly trimmed out, it maintains the trim very well. At least mine did. So I would say that if one's panel is tilting that much, they are either in a severe weather system that they had better get out of, or they are experiencing the effects of PIO (pilot induced oscillation). Les Williams/RV-6AQ ---------- From: owner-rv-list(at)matronics.com on behalf of Denny Harjehausen Sent: Wednesday, June 25, 1997 6:08 AM Subject: RV-List: Panel tilt and gyros As I have been reading about this tilt I have been wondering how long the average RV panel would be in the eight degree position. It seems to me that it couldn't make much difference. Maybe in something very stable such as a 747 or something of that type. But wouldn't the RVs be moving around to much to make any difference at all? Have a Good Day! Denny RV-6 (R)N641DH Fuselage top side Lebanon, OR ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Elon <elon.o(at)worldnet.att.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RV6 VFR or IFR</u></b></i></font></td></tr></table> Glenn & Judi wrote: > > How much does it cost per year to keep the typical IFR GPR updated? ---------------------------- I just bought my once-a-year (obviously VFR) GPS Dbase update from IIMorrow for $119. The same Dbase on a 28 day IFR cycle would be $470 per year. -Elon ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>kevin lane <n3773(at)worldnet.att.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>final checklist</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table> has anyone created a comprehensive initial pre-flight checklist, or do I just do the "knee bone connected to the leg bone" thing? In light of stories like pop rivets missing from push tube end I thought a check off list might be handy. kevin 6A-on main gear ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Leo Davies <leo(at)icn.su.OZ.AU></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: failure update</u></b></i></font></td></tr></table> > >I now have a little more information on why the engine on my RV-4 quit >Monday evening. >At this stage I am looking for advise. >I am going to remove all jugs to inspect/repair/replace as necessary >The sump and induction system will be taken apart and cleaned. There are >some valve pieces unaccounted for. They may have gone out the exhaust but I >am not counting on it. >Is there anything else we should do. Is it possible to test the valve pieces >to determine the cause of the failure. Can the remaining valves be tested >for serviceability? >Tom Martin RV-4 >sleeping better! Even thinking of Oshkosh > > Tom, I strongly suggest buying a copy of The Skyranch Engineering Manual by John Schwanner. You can buy a copy through AvWeb. Provides the (expensive) answers to the questions you are asking. Leo Leo Davies 6A My engine is on its way!!!!! ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"W. Tom Glover" <tglovebox(at)bc.sympatico.ca></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: ANR - Headsets Inc...</u></b></i></font></td></tr></table> Matt Dralle 510-606-1001 wrote: > > > Builders, > > I sent the following message to Headset Inc., but never received a reply. >....etc.... Matt, I have installed several of the Headsets, Inc. adapters in various headsets for my friends. I have found them to be an excellent bang for the buck when it comes to attenuating the low-frequency component of the engine's noise. Earlier ones (the ones I installed) apparently had a "thinner" sound than those available now. I have had no trouble with that, as I think that it enhances communication. Mine are installed in an older set of Telex EBM-1400's and I don't go flying without them! Haven't played with the newer adapters though. If you look at the adapter, you will see that there are two speaker elements in each earcup, and I doubt that you could adapt your Sony elements. I believe that, because of the way all these headsets operate, they aren't going to allow low-frequency audio stuff to exist in the earcup; the lower frequencies are gonna suffer. Perhaps the higher-end headset manufacturers ( Bose, Sennheiser, et al) have figured out how to preserve the low-end audio, but that's what one pays the BIIIIG bux for. 73, Tom Glover ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>John Top <jjtop(at)cts.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RE: Lex-aire HVLP spray gun</u></b></i></font></td></tr></table> > >Eric, > I'm the one who started that thread about 6 months ago and I still havent >bought a gun. Mike/Eric. My Binks M-1/Gravity feed HVLP works great with the tiny compressors most of us have. There should be a message in the archives some where (it possibly could have a direct reply) from an RVer who had purchased one based on the last thread and had tried it on his engine mount and loved it. Used about 1/2 the paint he expected to use. Mike You are welcome to come try mine anytime if you are getting antsy or you can wait until I am ready to prime some parts and come over then. John Top Phone: (619) 549-3556 ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Patrick E. Kelley" <patk(at)mail.ic.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Off Field Landing</u></b></i></font></td></tr></table> interserv.com!jperri(at)matronics.com wrote: > *** harrowing story snipped; couldn't bear to read it again! *** Yikes! Glad you kept your head (in all senses) and made it back! Congrats on the fine landing (any one you can walk away from...) and hope you get it back in the air real soon. Thanks for sharing. PatK - RV-6A ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>bennett(at)zip.com.au</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: ANR - Headsets Inc...</u></b></i></font></td></tr></table> > I believe that, because of the way all these headsets operate, they > aren't going to allow low-frequency audio stuff to exist in the earcup; > the lower frequencies are gonna suffer. Perhaps the higher-end headset > manufacturers ( Bose, Sennheiser, et al) have figured out how to preserve > the low-end audio, but that's what one pays the BIIIIG bux for. > > 73, > Tom Glover If my understanding of how ANR operates is correct, you will not suffer bass attenuation. It compares the actual sound in the earcup with what the signal on the lead says ought to be in the earcup, and applies an out of phase (ie cancelling) signal equal to the difference.. If you want whompa whompa from the stereo, without the sound of your Lycoming's exhaust, that's what you'll get. Peter Bennett<bennett(at)zip.com.au> Sydney Australia RV6 building sliding canopy ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Todd <tmrv6(at)pop.erols.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV-Propellers</u></b></i></font></td></tr></table> Martin, Aymur Demuth props P.O. Box 853 Ellicott City, MD 21041 Phone 410-461-4329 I am flying with their prop and love it. No problems after 177 hours. Check the archives. -- Todd tmrv6(at)erols.com RV-6 N92TM Flying Martin Carr wrote: > > > I am trying to track down the correct details for a person who builds wooden > propellers for RVs, the details I have are as follows: > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV6 VFR or IFR</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>wstucklen1(at)juno.com (Frederic W Stucklen)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table> Glenn, You should check the archive for past discussions on this topic. In short, the RV-6 is NOT a Bonanza or C-182 stability-wise. You definitely have to "fly" the plane all the time. Most people find that a wing leveler is a "must have" in an RV-6 for IFR operation. After over 150 Hrs of actual in my -6A, (with a wing leveler), I find that I need to be doing at least 3 Hrs each MONTH (either actual or under a hood) just to keep my proficiency at a point I feel comfortable with. Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com <anet-chi.com!flyers(at)matronics.com> writes: > >I am in the panel planning stages of my RV-6 project. I would like to >set the aircraft up for LIGHT IFR. IFR GPS, Loc/GS, Marker Beacon etc. >I have flown in an RV-6, but not on instruments. How does the RV-6 >handle on instruments? As far as the panel goes, IFR vs. VFR, should I >or shouldn't I? Any thoughts on the matter are appreciated. > >How much does it cost per year to keep the typical IFR GPR updated? > >Thanks in advance, >Glenn Gordon > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: failure update</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>wstucklen1(at)juno.com (Frederic W Stucklen)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table> Tom, With all your luck with that engine, why even consider re-using the same valves. Just the piece of mind of new ones makes up for the cost..... Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com <execulink.com!fairlea(at)matronics.com> writes: >At this stage I am looking for advise. >I am going to remove all jugs to inspect/repair/replace as necessary >The sump and induction system will be taken apart and cleaned. There are >some valve pieces unaccounted for. They may have gone out the exhaust but I >am not counting on it. >Is there anything else we should do. Is it possible to test the valve pieces >to determine the cause of the failure. Can the remaining valves be tested >for serviceability? > >I would like to thank the list for their concern and sincerely hope that >none of you have to experience what I have on not one but two >occasions. > >Tom Martin RV-4 >sleeping better! Even thinking of Oshkosh > > > > > > > >+---------------------------------------------------------------------------+ > | --- The RV-List is sponsored by the Matronics Company --- > | > | Featuring a line of affordable Aircraft Fuel Management >Instrumentation | > | Visit the Matronics & RV-List Web Site at ><a target="otherpages" href="http://www.matronics.com!">http://www.matronics.com!</a> | > | --- > | > | To [un]subscribe to the RV-List, email >"rv-list-request(at)matronics.com" & | > | put the word "[un]subscribe" in the *body*. No other text or >subject. | > >+---------------------------------------------------------------------------+ > ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Charlie Kuss <charliekuss(at)sprintmail.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: failure update</u></b></i></font></td></tr></table> Tom Martin wrote: SNIPPED I now have a little more information on why the engine on my RV-4 quit Monday evening. The intake valve failed in the #4 jug. The valve fell into the cylinder and bashed the top of the piston and destroyed the head. It did not put a hole in the piston or score the walls or rings. A good size junk of the valve travelled through the induction pipes into the #1 pot. It got stuck in the intake valve and caused it to lose compression. I wondered why #2 and #4 (I think you meant #3) did not fire but they felt that the engine would not run on two cylinders. Tom, With the #1 & #4 intake valves permanently open ( #4 due to breakage & #1 being wedged open by parts of #4) vacuum in the intake plenum is distrupted. As #1 & #4 piston rose on their exhaust strokes, they pushed the exhaust gases back into the intake plenum as well as out their respective exhaust ports. This destroyed the vacuum in the plenum and #2 & #3 intake runners, preventing proper introduction of the fuel/air mixture into the remaining cylinders. If the exhaust valves had failed instead of the intakes, the engine "may" have continued to run at reduced power (and greatly increased vibration). Check the #4 intake valve seat for indentations. This could indicate ingestion of a foreign object, which could have been caught between the valve and seat, causing breakage. Good luck Charlie Kuss RV-8 H.S. charliekuss(at)sprintmail.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>catbird(at)taylortel.com (TTC Carroll A. Bird)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Brake Wheel Cylinders</u></b></i></font></td></tr></table> This is probably a silly question but my Cleveland wheel cylinders has a little red plug on the bottom side. What do I put in this hole? I think there are fittings which you can use to fill the brake system from the bottom up to the top, which purges the air as it fills. If this is true, where do I get them, and what are they called. Thanks in advance for any info. Carroll, RV-4 on gear. Hanging engine soon. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Blast tube</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>ebundy(at)juno.com (Ed Bundy)</i></b></font></td></tr></table> >Has anyone used the plastic lightweight wiring conduit Vans supplies >in their wiring kits as blast tube to cool mags, fuel pump, gascolator, >etc. The catalog states it is suitable for use in the engine compartment >as long as it remains 4-6" from exhaust pipes. Hi Chet. I used the same stuff (I got it from Home Depot, I think) and it works well. It does have a slit running the length of it to facilitate wires running in and out, and when you bend it, it tends to split somewhat. This dumps some of the cooling properties, but it doesn't seem to be a problem. I recently bought some similar ribbed bilge tubing that is somewhat thicker, and doesn't have the slit in it. I plan to install that soon. Ed Bundy RV6A - first flight 11/20/96 ebundy(at)juno.com - Eagle, ID ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>n5lp(at)carlsbad.net (Larry Pardue)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Panel tilt and gyros</u></b></i></font></td></tr></table> > > >This has been said before but I will say it again as there still seems >to be allot of questions on this topic. The ONLY reason you need >the eight degree tilt is so the little adjustable airplane that moves up >and down can be lined up with the horizon line. When you fly in >level flight and the instrument is tilted this moves your horizon >indicator line up. > I'm getting more and more confused on this topic. Does anyone have an authoritative source? I had always heard tilt was only needed in taildraggers. My Pacer has an eight degree tilted artificial horizon that works fine. Is the important thing the angle between the panel and the horizon in level flight or is it the difference on the ground (for erection purposes)? Usually there is a real expert on any topic brought up on the list but I'm not getting that impression on this one. If someone knows, please explain. I don't readily accept unsupported assertions. Larry Pardue Carlsbad, NM Pacer N8025D RV-6QME N441LP Fuselage Skins ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: aileron balance</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>less_drag(at)juno.com (JAMES E AYERS)</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table> Hello Steve and all, My RV-3 ailerons (built to the plans and painted) were overbalanced, i.e. heavy at the leading edge when hung by the hinge points. I can't speak for the other RV's. Hopefully Bill B. will jump in on this one. Jim Ayers Less_Drag(at)juno.com <pfclaw.com!SSoule(at)matronics.com> writes: >The trailing edge is level with the nose on both of my unpainted >ailerons. Should I add lead to the water pipe? > >Steve >Huntington, Vermont > >PS, I hang the ailerons from the ceiling when I'm not using them 'cuz >they do fall easily! ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Collins/S-TEC TDR-950 Transponder</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>robjhall(at)juno.com (Robert J. Hall)</i></b></font></td></tr></table> Does anyone have any experience with this transponder? Please respond privately and I will summarize for the list. Thanks in advance. Bob Hall, Filling out the panel. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Scott A. Jordan" <71341.3505(at)CompuServe.COM></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>RV-8 Rudder Skeleton</u></b></i></font></td></tr></table> The instructions for building the rudder skeleton says to bolt the R-405PD rudder horn in place and slide the R-803 rib in place. The rib does not have a slot cut to allow it past the bolt. Simply drilling a hole will be very close to the edge so I assume I need to cut a slot. Any suggestions or limitations I should know about before I cut this slot? Thanks Scott A. Jordan 80331 N733JJ ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Cafgef(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Blast tube</u></b></i></font></td></tr></table> << Apparently the air moving across the ribs in the conduit caused the whistling. I was ready to yank out the stuff, when I decided to do a little testing, and found by adding some subltle "bends" to the conduit and tie wrapping them off to the engine mount the whistling was eliminated. I was able to verify this by simply blowing thru the conduit. (Yes just put your lips on it and blow!) >> Here in Colorado ( and I imagine elsewhere), we have a design for an elk caller that looks amazingly like a blast tube. It makes a squeel that can be heard for miles. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Doug Rozendaal" <dougr(at)netins.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: ANR - Headsets Inc...</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 25, 1997</i></b></font></td></tr></table> charset="us-ascii" >If my understanding of how ANR operates is correct, you will not >suffer bass attenuation. It compares the actual sound in the earcup >with what the signal on the lead says ought to be in the earcup, and >applies an out of phase (ie cancelling) signal equal to the >difference.. If you want whompa whompa from the stereo, without the >sound of your Lycoming's exhaust, that's what you'll get. > >Peter Bennett<bennett(at)zip.com.au> >Sydney Australia >RV6 building sliding canopy The Bose does compare the input stream so as to not block it out, The ANR kit from Headsets Inc. does not, That is what you get for your addition $850.00. That was from the owner of Headsets Inc. I have the Headsets inc kit in my DC and it worked great in a B-25 until it quit, In a 400 series Cessna it was stunning, I would rrecommend it and will replace it, but that takes time you know... Tailwinds, Doug Rozendaal RV-4 N240 dougr(at)netins.net <a target="otherpages" href="http://www.petroblend.com/dougr">http://www.petroblend.com/dougr</a> ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>mikel(at)dimensional.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: balance</u></b></i></font></td></tr></table> >Both of my elevators are still overbalanced and waiting on the finish >paint before I put the precision balance on 'em.... This was tossed around a while back and I can't get into the archives (Matt?) to find out what the final word was but as I remember, the ailerons are dynamically (?) balanced and need no further attention. But, as Mark's original question asked: what do you do with the ELEVATORS? I have never seen any description on how the elevators are balanced. Instructions are to "balance them". It seems hard to get the left to balance accurately with the trim cable in there. Those who will fly before painting will have to rebalance their elevators after painting.....but how is it done?? I believe that is your question, right Mark? I hung them on the horizontal and played with the weights until they were......well......balanced, staying put when moved, neither up nor down. That left one was the hardest as the resistance of the cable made it more difficult. I also "over balanced" them forward, waiting until paint to fine tune them. Michael ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>mikel(at)dimensional.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: old valves</u></b></i></font></td></tr></table> >Is it possible to test the valve pieces to determine the cause of the failure. >Can the remaining valves be tested for serviceability? As we all know, Lycoming engines are VERY reliable ("bullet-proof"). The failures I know of are from swallowed valves, usually exhaust as they take the most abuse. What caused the failure of yours? Metal fatigue. I would guess, the overhaul shop reused all your old valves, except perhaps the exhaust. You have a new airplane, how about as near-new an engine as possible. Can this happen with brand new valves? You bet. But less likely to. My $0.02 Michael ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>Shelby1138(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: Prop Governors recess</u></b></i></font></td></tr></table> A friend here in Nashville installed the Hartzell, but had problems with the Hartzell governor fitting the firewall recess. He ended up enlarging the recess a the bottom. Since I have a Hartzell also, I am wondering if anyone else has had the same problem? Shelby in Nashville. ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>JamesCone(at)aol.com</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: ANR - Headsets Inc...</u></b></i></font></td></tr></table> Only Bose, Sennheiser, and Lightspeed offer integration circuitry to playback good quality stereo sound. The kit does not have this circuit and they advised me that I would not like the result when playing my stereo throught the headset with the ANR on. I just bought the Lightspeed ANR 20K and really like it. I have published a review of it in the July issue of my newsletter which is at the printers now. Jim Cone jamescone(at)aol.com ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Robert Hughes" <hawk(at)digisys.net></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: failure update</u></b></i></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table> For Tom Martin: Were the valves replaced with new items at the time of overhaul ("rebuild 260 hrs ago.."? Chuck Berthe had to put his beautiful RV-3 into a field a few years ago because of catastrophic valve failure. In an article (that I can't lay my hands on right now... but I think it was in Kitplanes or Sport Aviation) he described the hazards involved in re-using valves at the time of major. The valve that failed on him had apparently been re-used on the basis of miking/inspection. It will be interesting to see whether fatigue or FOD is found to be the most probable failure mode of your valve. Congratulations on getting it down safely. Regards, Hawkeye ________________________________________________________________________________ <table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">Date: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#8f0000"><b><i>Jun 26, 1997</i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><b><font size=3 face="times new roman, times" color="#000000">From: </td><td width="85%" align="left"></font><font size=3 face="times new roman, times" color="#007000"><b><i>"Thomas L. Velvick" <tvelvick(at)caljet.com></i></b></font></td></tr></table><table border="0" cellpadding="0" cellspacing="0" width="100%"><tr><td width="15%" align="left"><font size=3 face="times new roman, times" color="#000000"><b>Subject: </b></td><td width="85%" align="left"><font size=3 face="times new roman, times" color="#707000"><i><b><u>Re: RV-8 Rudder Skeleton</u></b></i></font></td></tr></table> Scott, my slot turned out to be almost the depth of the bolt deep. You don't want to cut it too wide because of the holes for the nut plate. I usee a dremel tool a little at a time to size it until the rib was fully against the rudder horn. I also had to cut a little slot in the .032 spacer that goes on the bottom of the rudder horn. Tom Velvick tvelvick(at)caljet.com RV-6a elevators >The instructions for building the rudder skeleton says to bolt the R-405PD >rudder horn in place and slide the R-803 rib in place. The rib does not have a >slot cut to allow it past the bolt. Simply drilling a hole will be very close >to the edge so I assume I need to cut a slot. Any suggestions or limitations I >should know about before I cut this slot? > >Thanks > >Scott A. Jordan >80331 >N733JJ > > > > > +-- --+ > | Visit the Matronics & RV-List Web Sites at <a target="otherpages" href="http://www.matronics.com!">http://www.matronics.com!</a> | > | --- | > | To [un]subscribe from the RV-List, email "rv-list-request(at)matronics.com" | > | & put the word "[un]subscribe" in the *body*. No other text or subject. | </pre> <center> <hr size=1> <br> <text><font color="#800000">June 18, 1997 - June 26, 1997</font><br> <h1><i><font color="#000080">RV-Archive.digest.vol-da</font></i></h1> <a href="/archives/archive-get.cgi?RV-Archive.digest.vol-cz"> <img align=center src=/archives/vparchive.jpg></img></a> <a target="SearchEngine" href="http://www.matronics.com/search"> <img align=center src=/archives/vnarchivesearch.jpg></img></a> <a href="/archives/archive-get.cgi?RV-Archive.digest.vol-db"> <img align=center src=/archives/vnarchive.jpg></img></a> <p> </center> <hr size=4> </blockquote> </html>
