Subject: | Re: Magneto Help |
<19970830.190115.15134.0.tcastella(at)juno.com>
From: | tcastella(at)juno.com (Anthony J Castellano) |
I have a low time O360-A1F6D Lycoming engine that I intend to install on
my RV-6. This engine has a single drive dual Bendix magneto which has
a history of problems, so I want to use a different type of ignition
system.
I plan to use a single Slick magneto with an impulse coupler in place of
the dual Bendix and an Electroair electronic ignition for the second set
of plugs.
I spoke to Jeff Rose of Electoair at Oshkosh who thought this was a good
way to go, and he gave me the model numbers of some magnetos that would
work for me.
These are: Bendix model LM 1209 (I0-349305-1 not sure about this )
Slick model 4370 non impulse
Slick model 4373 impulse
Jeff is not 100% sure about the slick model numbers. Can anyone tell me
if these
model numbers are OK.
Thank you,
Tony Castellano
Hopewell Junction, NY
RV-6 (fuselage now out of jig)
From: | Ken Harrill <KHarrill(at)OSA.STATE.SC.US> |
Before the final closing of my wings, I would like to mount my strobe
power packs (Aeroflash individual powerpacks). The best location seems
to be on the spar just inboard of the tip rib. Is it permissible to
drill four #19 holes in the spar at this location? Would Van's approve?
Any opinions will be greatly appreciated.
Ken Harrill
RV - 6, closing up both wings
From: | "Glen Watson" <gtwatson(at)students.wisc.edu> |
Subject: | RV-4 wing spar question |
I'm currenlty working on the main spar for my -4. The plans show a cut out
through the spar web and spar web doubler at the spar root. I find no
mention of this in the construction manual. Is this something that should
be cut right now or is it done at a later time?
Glen Watson
From: | Scott Johnson <rvgasj(at)popmail.mcs.net> |
Subject: | Is 210 Degrees Engine Oil Temp To Hot ? |
I have an RV6A with Vans baffling and a new Lycoming 0-360. This spring
when temperatures were still around 40 degrees F., my oil temp. was running
180 degrees. However, this summer, when it gets 85 degrees out, its
running about 210 degrees. I have re-checked my baffles for leaks, and my
oil cooler is mounted in the same position as a cherokee 180 with a 3" Hose
going to it from the cowl inlet. Is this in the acceptable range ? What
are you guys getting ?
Also, does anybody know where I can get those cylinder temperature stick
ons that warn if the temp. goes over 475 degrees ?
Wondering what to build next ..... ( almost started to build a sailboat, I
wish Van would make a super motorglider kit or something !!!! )
rvgasj(at)mcs.com
Scott Johnson
Chicago
Subcribe
While at Oshkosh I noticed a RV6 with a auxillary power outlet
(cigarette lighter) with a No Smoking Cover. Does anyone know where I
can get one? I don't like the lighter but I do need the power outlet
for hand held devices. Thanks for the help.
RV6A , Working on panel
Mark Malon e 85MM
Subject: | Re: Is 210 Degrees Engine Oil Temp To Hot ? |
Scott Johnson wrote:
> I have an RV6A with Vans baffling and a new Lycoming 0-360. However, this summer,
when it gets 85 degrees out, its running about 210 degrees. I have re-checked
my baffles for leaks, and my oil cooler is mounted in the same position as a cherokee
180
with a 3" Hose
I am having the same problem you are with high oil temp readings. i've seen as
high as 240
one day on a climb out. however my CHT and EGT temps are at more normal levels.
I spoke to Bill at Vans about this. He said the first thing to do was to calibrate
the oil
temp gauge by removing the sender, sticking it in a can of boiling water and then
observing
the actual reading on the gauge. He said that some of the cheaper gauges, even
the
Isspro gauges that Van's sells are notoriously inaccurate. If you boil water you
then have
an absolute 212 degree (depending on altitude) standard reading. I'll then make
a mark on
my gauge at that point and judge readings from there.
I haven't done this yet, but its definitely on the short list. I will post the
results when i
have them.
Andy Gold
>spring when temperatures were still around 40 degrees F., my oil temp.
was
>running 180 degrees. However, this summer, when it gets 85 degrees out,
its
>and my oil cooler is mounted in the same position as a cherokee 180 with
a 3"
>Hose going to it from the cowl inlet. Is this in the acceptable range ?
I'd suggest that you check your sender/gauge to make sure they are
accurate. I have a 3" hose coming off the back of the baffle to a cooler
on the firewall. I have a problem keeping my temps UP. I even installed
a remote cooler block-off plate. The only time I need it open is when
ground temps are over about 80F. When ground temps are 40 or below, I
needed to block off about 3/4 of the inlet in addition to the remote
block-off.
I usually try to keep my temps between 180-190. When I first started
flying it last winter, I was only able to get about 150 until I blocked
off most of the inlet.
Ed Bundy RV6A - first flight 11/20/96
ebundy(at)juno.com - Eagle, ID
Can anyone offer help with a vacuum installation for instruments. The
engine is a Belted Air, firewall forward Chevy V-6 package but has no
vacuum pump. The standard 211cc is typically installed on the cam of the
lycoming if I remember correctly so belt driving it off the crank would
increase the rpm significantly, I suppose. Is the pump capable of this or
is there a better method? I would hate to hang a big horn off the side of
a beautiful RV-6A to supply vacuum, so I was hoping for some great ideas
from a large group. Any information can be posted or directed to me at
flyinghi(at)worldnet.att.com. Or leave me a number to call and a time and I
will contact you.
On mains awaiting Chevy.
N609CG
Subject: | Elevator trim tab attachment |
Greetings fellow RVers,
I'm just about done with the left elevator on my -8, but...just HOW IN
THE WIDE, WIDE WORLD OF SPORTS does a guy get the piano hinge riveted to
the elevator after it's rivetted to the tab?!?! (In best Slim Pickin's
voice). The plans call for typical AN426 solid shanks here..and I just
can't see how to get a squeezer in there..or, a buck bar without
smashing the hinge pin to oblivion while setting.
So, I've boldly ventured forth..and probably screwed up in the
process..and drilled them out for CS4-4 flush head blind rivets. These
are 1/8" rivets, as you all know, and the 2d edge distance is just
barely maintained. So, is it considered acceptable to use blind rivets
in this case? They will be under shear load while in flight. My FAA
acceptable methods book says NO..do NOT use hollow shaft blind rivets in
load bearing members..but they do not mention whether going up one size
will negate the strength loss issue.
HELP!! Any thoughts? Am I doomed to redo the elevator?....if I hear a
resounding "YES, redo the whole thing"...the screams you will no doubt
hear will be mine...
Thanks folks!
Brian Denk
RV-8 #379
elevators
Get Your Private, Free Email at http://www.hotmail.com
Subject: | Typical Newbie Question |
Hello Listeners:
Just opened the box for my 6A empenage and finished with the
inventory. Having been an RC modeler for years, I can easily see that
I am going to enjoy myself very much. Just gotta get used to working
with aluminum instead of balsawood!
As I expected, I will need the help of the list. Here I haven't
even deburred a thing, and I already have a question. The kit provides
a bundle of trim sheet aluminum that measures about 12"x3" with 3 sheets
of what I will call a "thick" sheet, and 3 sheets of a "thinner" sheet
AL. How much of this is available for me to get used to
dimpling/riviting etc? I know that some of it can be used to line up
ribs with spars, and to make temporary rib supports as in the Orendorf
tapes, but I just don't want to waste any of it in case I need it later
on in the construction process.
Looking forward to getting started and to "meeting" all of you on
the list. Hopefully I will be able to return good advice to the list in
the future.
Thanks!
Jeff Orear
RV 6A Empenage inventory done
jorear(at)mari.net
<< Jeff is not 100% sure about the Slick model numbers. Can anyone tell me
if these
model numbers are OK. >>
Why not contact Unison? They make the Slick stuff and are listed in the
Yeller Pages at http://www.sound.net/~hartmann/yelrpage.htm
-GV
<< Also, does anybody know where I can get those cylinder temperature stick
ons that warn if the temp. goes over 475 degrees ? >>
Many welding supply shops sell these Tempil brand stickers.
-GV
I'm having a difficult time grasping and positioning the RV-4 flap lever.
Other than installing electric flaps, what modifications have others made
to make flap
application easier?
Lou Willig
Subject: | Re: Aux Power Cover |
<< While at Oshkosh I noticed a RV6 with a auxillary power outlet
(cigarette lighter) with a No Smoking Cover. >>
In California they are sold in Grand Auto stores in a choice of about four
different colors.
-GV
Subject: | Re: Typical Newbie Question |
Jeff, in regards to the bundle of trim sheet aluminum, just use it for
whatever you need and don't worry about using it up. If your project is
like mine you will have a lot of scrap left over (messed up parts) and
you will have ordered several sizes of sheet aluminum from Wicks or some
other supplier for building, rebuilding , etc.
You will also find that while Vans kits are very complete you will
probably be constantly ordering hardware, tools, accessories and lots of
other stuff to complete your project.
Chet Razer
crazer(at)egyptian.net
server @sac5-132.calweb.com ip 207.173.128.132 account=wcw
This is a multi-part message in MIME format.
------=_NextPart_000_01BCB644.3C494F40
Well Jeff,
Good question. If you read through all of the empenage instructions you
will little reference to needing any of it! The only places I used any of
it was connecting the Control horn on the rudder, and two strips to attach
the glass to the bottom of the rudder.
You have started out right by asking questions!! This won't be your last!
Best of luck and have a great time
Bill Wootton
RV6 wings
> From: mari.net!jorear(at)matronics.com
> Subject: RV-List: Typical Newbie Question
> Date: Sunday, August 31, 1997 6:11 PM
> Hello Listeners:
> the future.
> Thanks!
> Jeff Orear
> jorear(at)mari.net
Well Jeff,
Good question. If =
you read through all of the empenage instructions you will little =
reference to needing any of it! The only places I used any of it =
was connecting the Control horn on the rudder, and two strips to attach =
You have started out right by =
Best of luck =
Bill Wootton
RV6 =
wings<br><br>----------<br>> From: <font =
color=3D"#0000FF">mari.net!jorear(at)matronics.com
> Subject: RV-List: Typical Newbie =
Question
--> RV-List message posted by: jorear(at)mari.net
> Hello Listeners:
Just opened the box for my 6A empenage and =
finished with the
> inventory. Having been an RC modeler for =
> I am going to enjoy myself very =
> with aluminum instead =
of balsawood!
> As I =
even deburred a thing, and I already have a question. The kit =
provides
> a bundle of trim sheet aluminum that measures about =
> of what I will call a =
"thick" sheet, and 3 sheets of a "thinner" =
sheet
> AL. How much of this is available for me to get used =
to
> dimpling/riviting etc? I know that some of it can be =
used to line up
> ribs with spars, and to make temporary rib =
> tapes, but I just don't want to =
> on in the construction =
process.
> Looking =
forward to getting started and to "meeting" all of you =
on
> the list. Hopefully I will be able to return good =
> the future.
Thanks!
> Jeff =
Orear
> jorear(at)mari.net
nbsp; &n=
bsp; &nb=
sp; &nbs=
p;  =
| Visit the Matronics & RV-List Web Sites at =
http://www.matronics.com> |
nbsp; &n=
bsp; --- =
nbsp; &n=
bsp; |
color=3D"#0000FF">rv-list-request(at)matronics.com" |
> | & put the word =
"[un]subscribe" in the *body*. No other text or subject. =
nbsp; &n=
bsp; --- =
nbsp; &n=
bsp; |
| Please =
nbsp; &n=
bsp; &nb=
sp; &nbs=
p;  =
------=_NextPart_000_01BCB644.3C494F40--
Subject: | Re: Elevator trim tab attachment |
------=_NextPart_000_01BCB645.B9C93060
Pull The Pin out! Then you can use a squeezer.
now I would use -4 flush rivets (solid AL)
> From: Brian Denk <hotmail.com!akroguy(at)matronics.com>
> Subject: RV-List: Elevator trim tab attachment
> Date: Sunday, August 31, 1997 5:33 PM
> Thanks folks!
> Brian Denk
> RV-8 #379
> elevators
Pull The Pin out! Then you can =
use a squeezer.
now I would use -4 flush rivets (solid =
AL)<br><br>----------<br>> From: Brian Denk <<font =
color=3D"#0000FF">hotmail.com!akroguy(at)matronics.com>
> Subject: RV-List: Elevator trim tab =
> --> RV-List message posted by: "Brian Denk" =
<akroguy(at)hotmail.com>
> I'm just about done with the left elevator on my -8, but...just =
HOW IN
> THE WIDE, WIDE WORLD OF SPORTS does a guy get the piano =
hinge riveted to
> the elevator after it's rivetted to the =
> voice). The plans call for =
> can't see how to =
> smashing the =
> So, I've =
process..and drilled them out for CS4-4 flush head blind rivets. =
These
> are 1/8" rivets, as you all know, and the 2d =
> barely maintained. So, is it considered =
> in this case? They will be under =
> acceptable methods =
> load =
bearing members..but they do not mention whether going up one size =
> HELP!! =
resounding "YES, redo the whole thing"...the screams you will =
no doubt
> Thanks =
folks!
> Brian Denk
> RV-8 #379
elevators
> Get Your =
Private, Free Email at http://www.hotmail.com>
nbsp; &n=
bsp; &nb=
sp; &nbs=
p;  =
nbsp; &n=
bsp; --- =
nbsp; &n=
bsp; |
> | & put the word =
nbsp; &n=
bsp; --- =
nbsp; &n=
bsp; |
| Please =
nbsp; &n=
bsp; &nb=
sp; &nbs=
p;  =
------=_NextPart_000_01BCB645.B9C93060--
From: | tcraig-stearman(at)juno.com (John T. Craig-Stearman) |
'Listers,
I just came back from the hangar where I installed my wings this evening.
It went much more smoothly than I imagined it would. I can't get this
perma-grin off my face. It looks like an airplane now!
Tom Craig-Stearman
RV-4 wings mounted
Subject: | Re: RV-4 wing spar question |
Glen,
Yes, go ahead and cut out the center now. This opening allows you to
install the control column later. It is a tight fit, so don't skimp on
the dimensions. Check the "Sixteen Years of the RVator" articles on the
subject.
Tom Craig-Stearman
RV-4 Wings installed!
>cut out
>should
Anyone know John Harmon's address or phone number?
Email me off-list
Thomas Pfingsten
tompfing(at)brainerd.net
Subject: | Trim tab attachment..and my humility |
Of COURSE! Take the hinge pin out..and squeeze as usual. I outta quit
while I'm ahead..and stick to RC models....NOT! Thanks Bill! NOw, one
more silly question. What's the best way to secure the pin afterwards? A
slight crimp of the aluminum on each end? Or, should a new, longer pin
be used and then folded back somewhat? I know this question has been
posed here before..but I can't recall the answer.
If it wasn't for this forum...I would not be nearly as far along on this
project as I am now...MUCH thanks to those who have helped me...and
those who will offer sage advice in the future....
PEACEFUL skies and soft arrivals to all....
Brian Denk "red-faced but continuing on"
RV-8 #379
finishing tail components, wing kit ordered.
From: | "jacquelyn eastburn" <jimnjax(at)worldnet.att.net> |
brian, remove the pin and separate the hinges. cleco half to the elevator
and cleco the other half to the trim tab. check that the two halves "mate"
together. rivet the one half to the trim and the other half to the elevator
then reinsert the piano wire. there ya got it.. hinged trim..
Hillsboro Oregon
RV - 8 Ser. No. 80079
> voice).
Subject: | Re: Artificial Horizons |
*** sent privately ***
Brian,
I was on vacation in June, but don't remember a follow-up.
Was there a follow-up??
... thanks ... Gil Alexander
>Hi there
>A few days ago I posted a question about surplus military 28 volt electric
>A.H's for approx $200 (excl posting and local taxes). Bob N. replied that
>I should check out whether it is not an AC (as opposed to DC) instrument:
>as usual he is right. They are AC. I'm investigating appropriate power
>supplies, and have received a couple of replies from the list in this
>regard.
>I have asked the supplier to give me a couple of photo's and details of the
>A.H's for me to post to this list.
>I'm due to see a military avionics engineer this coming weekend.
>Hang in there for a couple of days, and I will post all the info as soon as
>I have it to hand.
>Kind regards
>Brian Hitchings
>South Africa
>RV6A : Wings
mailto:gila(at)flash.net
Gil Alexander,
Los Angeles, CA
Subject: | Re: Engine Vacuum |
> vacuum pump.
I've heard of smog pumps being used with good results.
From: | George McNutt <GMcNutt(at)compuserve.com> |
"I have an RV6A with Vans baffling and a new Lycoming 0-360. This spring
when temperatures were still around 40 degrees F., my oil temp. was runni=
ng
running about 210 degrees. I have re-checked my baffles for leaks, and m=
y
oil cooler is mounted in the same position as a cherokee 180 with a 3" Ho=
se
going to it from the cowl inlet."
Lycoming Operators Manual for 0-360 page 3-13 shows:
1) Ambient air temp above 80F - Oil INLET temp- desired 180F max 245F
2) " " " 30 to 90F - Oil INLET temp- desired 180F max 245F
3) Engine oil temp should not be below 140F during continuous operation.
Sounds to me like your oil temps are a little high but well within limits=
=2E
Years ago, in a Piper Owners Magazine, I read about a rare cause of high
oil temperatures that can occur on some coolers.
Depending on oil cooler inlet and outlet locations (bottom corners)
internal construction, (no standpipe to top) and how the cooler was
initially filled with oil. It is possible to trap a pocket of air in the
top half of some oil coolers so that their cooling capacity is greatly
reduced. =
George McNutt. 6A, Left elev, 0-320 staying cool in corner of garage. =
Langley, B.C. =
Subject: | Re: Trim tab attachment..and my humility |
Brian Denk wrote:
<> NOw, one
> RV-8 #379
I hate to do something that can't be easily undone or taken apart.
The advantage of going to Oshkosh every year for the last 12 or so
is that you can see how hundreds have done it.
I like either getting a longer pin and bending the inside end at an
angle then into a loop and anchoring it with a screw into a nutplate
on the inside face of the elevtor -or- carefully drilling
about a 1/32 hole thru the hinge and hinge pin and safety wiring it.
I have seen lots of planes using both methods.
Best regards,
Bill Costello
Bill Costello | bcos(at)ix.netcom.com | Building RV-6 | Reserv N97WC
Cell Tech Ind Dist SBGA 800-325-7544
>from a large group.
>N609CG
I am seriously thinking of using a small 2 inch horn mounted on the belly in
the engine outlet air. There is already turbulence there and the heat might
keep it from freezing. There was an article about an RV-4 in Sport Aviation
that had done this. I have had a vacum pump failure and am told to expect
one every 500 hours, not very reliable. The pump is heavy as well. Any
thoughts out there?
Tom Martin
RV-4
>Glen Watson
I would do it now as it is much easier before you rivet. This cutout is for
your control stick tube. There has been a revision on the cut out size make
sure you make it big enough.
Tom Martin
RV-4
Mark,
Radio Shack sell one that isn't intended to be mounted in a panel. I used
one in my six and stored it underneath the fuel selector valve with enough
wire to place the outlet on the passenger seat to power a portable CD player.
Rick McBride
rickrv6(at)aol.com
Subject: | Re: Garmin GPS 90 - info request |
I just saw a device in trade a plane that will couple a handheld gps to
an autopilot without the need for a dg. If I can find it again I will
put it on the list.
Subject: | Re: Overvoltage Protection |
<34071B0F.F1E(at)utech.net>
From: | wstucklen1(at)juno.com (Frederic w Stucklen) |
Ernesto,
Then comcept is to rewire the rotating field (ie, amature) so that
one side is grounded and the other side returns to the regulator. The
internal regulator PCB is disabled by cutting the PCB foil to achieve
this end solution, and adding a ground to the other side of the field.
This is called a "B" circuit. Your local alternator shop could probably
do the modification for you if you didn't feel comfortable about it.
The disadvantage of doing this yourself, is that you will have an
automotive quality (ie, tolerences) alternator. B & C does select parts
that have closer tolerences.
Fred Stucklen RV-6A N925RV
(Working on second RV-6A - Chevy Powered!)
Tom,
I have 967 hrs on my -6A on the original vacuum pump. I fly IFR and do
have a standby system. Now that I've said this, i should expect it to
fail!!!!
Hello Listers,
I stumbled across some 3M Magic Tape while flush riveting my wing
control surfaces. This tape works great for holding flush rivets in place
while riveting. It peels off after riveting leaving little, if any,
residue. It is far superior to even the best grade masking tape and equal
to the special purpose tape sold by Avery. It is available at Walmart and
is sold as "3M Magic Tape." It costs about a dollar per 3/4 inch roll.
Hope this helps.
Best regards,
RV-6A, skinning wings
From: | "Patrick E. Kelley" <patk(at)mail.ic.net> |
You will hate yourself when you hear the answer, but I had the same
problem and had to stare at the plans for awhile until the obvious hit
me. The hinge has been drilled to the elevator with the trim tab in
place, and clecoed. Now, remove the hinge pin and rivet the hinge half
that is still clecoed to the elevator. I used a squeezer. Reassemble
the hinge and quit beating your head on the wall. Like I said, I too
considered folding the tab back to do the riveting and came up with the
same question. Happens to us all.
PatK - RV-6A - Wings still not complete; had a small accident at Sturgis
Bike Week.
> I'm not sure if this model GPS is a handheld or not, but generally speaking,
> can handheld models talk to the autopilot system like other panel-mounted nav
> systems do? If not, do handheld owners consider this a major drawback or does
> the price savings make up for it?
A handheld's data stream can be used to drive an autopilot if a
converter is used. The Navaid devices autopilot has a
"smart coupler II" converter built in ($150 option), which takes the
GPS data stream (NMEA 0183) from my handheld Garmin 195 and converts
the signal to analog left/right signals such as are produced by a
traditional VOR.
So far, I think it's a slick system. The Navaid Devices autopilot
will track VOR, GPS course, or GPS heading. Mine is all hooked up,
except for final pushrod connection and some servo mounting screws.
Tests using the GPS in the simulator mode were successful (don't
forget to enable the GPS' data output port).
I believe the smart coupler is available from Navaid Devices as a
stand alone unit if you already have an autopilot.
Tim Lewis
N47TD (reserved) RV-6AQ #60023
San Antonio TX
timrv6a(at)earthlink.net or
timrv6a(at)iname.com
From: | Glenn & Judi <glenn(at)chocolatetruffles.com> |
Hi,
I am ready to position the airvent scoops on the skin of my RV-6 project
(New style rudder system).
The instructions are very vague about where to position these. Any
suggestions?
-Glenn Gordon
MZ
<< I just saw a device in trade a plane that will couple a handheld gps to
put it on the list. >>
Try Porcine Associates listed in the Yeller Pages.
-GV
Subject: | Other Engine Alternatives - don't bad mouth |
>This isn't new is it. Add $6000 for a core charge?
>I knew that :-)
Negative on the core charge Hal.
Rob Acker / r.acker(at)ix.netcom.com / RV-6 Quickbuild in slowbuild mode... :(
>Hello Listers,
>Hope this helps.
>Best regards,
>John
John,
... and others ... make sure you get the 3M REMOVEABLE Magic
Tape. There are two versions (the other is labelled 3M Magic Tape), and
you want the one with a less agressive sticky surface. It is a good way to
go, and seems better than the professional riveters tape. Masking tape is
a real mess after you've hit it a few times with a rivet gun ...:^)
Gil (tape those rivets) Alexander
Gil Alexander,
Los Angeles, CA
How about using manifold vacuum? The STC'd aftermarket units for
certificated planes keep the gyros alive so perhaps this approach could be
used for a primary system. I noted in a friend's Mooney that the only
effect of turning on the standby vacuum was a slight change in idle speed.
Dennis 6A fuselage in jig
> From: Tom Martin <execulink.com!fairlea(at)matronics.com>
> Subject: Re: RV-List: Engine Vacuum
> Date: Monday, September 01, 1997 5:22 AM
> >from a large group.
> >N609CG
in
might
> Tom Martin
> RV-4
Subject: | cleco substitute. |
Hi,
I am in the process of fitting the forward top skin (just forward of the
canopy frame) onto my RV-6 Tip-up project. I need to tip up the canopy
to check clearance, however the clecos on the mentioned skin are in the
way. If I rivit this skin in place, then I can't trim it down if
necessary.
Is there a low profile substitute for the clecos?
-Glenn Gordon
MZ
Subject: | Re: RV-4 Flap Lever |
Lou,
Slow down more before you put the flaps down, and only use one notch of
flaps. That will work until winter, then put in the electric flap kit.
That is my plan.
Tailwinds, N240 the pink panther
Doug Rozendaal
dougr(at)netins.net
www.petroblend.com/dougr
> From: Louis Willig <op.net!larywil(at)matronics.com>
> Subject: RV-List: RV-4 Flap Lever
> Date: Sunday, August 31, 1997 8:04 PM
> to make flap
> application easier?
> Lou Willig
From: | Michael Lott <Michael.Lott(at)ssc.nasa.gov> |
Subject: | handhelp gps autopilot coupler |
The ad I had mentioned in trade-a-plane about the handheld gps to
autopilot couplers was indeed the Porcine Associates ad mentioned by
another lister. They are located in menlo park, california. The number is
415-326-2669. It is called the GPS Smart Coupler II.
Greetings folks,
Thanks for all the great input regarding the trim tab hinge riveting
technique...I'm still kicking myself for being so oblivious to the
blatantly obvious.
Anyway, I used el cheapo electrical tape to hold the rivets in place
when back-riveting the skin stiffeners...ZERO residue and reuseable. Try
it out! Works great!
Brian Denk
RV-8 #379
tail surfaces, wing kit on order
From: | "Warren/MK Bishop" <wemkbish(at)nponline.net> |
Subject: | Re: cleco substitute. |
None that I know of. We installed the cleos from the back (under) side and
then had to leave some out.
Warren Bishop RV-6 engine area
From: Glenn & Judi <matronics.com!chocolatetruffles.com!glenn>
Subject: RV-List: cleco substitute.
Date: Monday, September 01, 1997 6:48 PM
Hi,
necessary.
-Glenn Gordon
MZ
Another useful item that is readably available without having to order is
1" wide Post-it Correction and Cover up tape available at all office suppy
stores. I got mine at office depot and did the entire backriveting jobs on
the airplane with one roll. It can be reused several times and leaves
absolutely no residue. The rolls are 1" X 700" for about 5 bucks I
believe. Just another way to beat the system.
Charles
> From: John Devlin <americus.net!jdevlin(at)matronics.com>
> Subject: RV-List: Rivet Tape
> Date: Monday, September 01, 1997 12:00 PM
> Hello Listers,
wing
place
equal
and
> Hope this helps.
> Best regards,
> John
Hi Glenn & Judi:
I don't have the tip up canopy so I'm not familiar with your particular
circumstance. However, many times I had to cleco from the inside to leave
the outside area free. Maybe that will work.
From: Glenn & Judi <chocolatetruffles.com!glenn(at)matronics.com>
Date: Monday, September 01, 1997 11:48 PM
Hi,
necessary.
-Glenn Gordon
MZ
Subject: | punch line needed |
What is considered the best way to break in a newly O/H'd engine with an
unflown airplane(owned by a low time pilot)? Seriously folks, inquiring
minds want to know. Apparently, the Wally method of tying the tail to the
hanger and running it for two hours isn't universally recognized as a great
idea. kevin 6A (220 hrs)
>suggestions?
>-Glenn Gordon
HERE ARE SOME THINGS T0 CONSIDER:
1. HEIGHT. I PUT MINE AS HIGH AS POSSIBLE. THIS IS RIGHT NEAR THE LONGERON.
YOU MUST WATCH THE TOP ANCHOR POINT FOR THE RUDDER PEDALS FOR CLEARANCE,
ALTHOUGH YOU DON'T NEED MUCH. THE BOLT MUST BE ABLE TO RISE FROM THE BLOCK
ENOUGH TO ALLOW THE PLASTIC BLOCK TO BE (RE) MOVED IF EVER NECESSARY. IF YOU
ARE GOING TO HAVE THE AIR EXIT POINTS LOW DOWN UNDER THE PANEL LIKE MOST
FOLKS, YOU MAY WANT TO LOWER THE INLET A LITTLE TO ALLOW THE WATER IT MAY
SOME DAY ACCUMULATE A WAY TO ROLL DOWN HILL AND EXIT OUTSIDE INSTEAD OF
INSIDE THE COCKPIT.
2. FORE AND AFT. I PUT MINE AS FAR FORWARD AS POSSIBLE. YOU ARE SUPPOSED TO
KEEP IT FORWARD OF THE WING TO GET HIGH PRESSURE AIR. I NOTICE THIS IS THE
SINGLE GREATEST SOURCE OF NOISE, SO IT MAY BE QUIETER A LITTLE AFT.
calibrate the oil
and then observing
even the
water you then have
I had a big argument with my wife about the reason for the term "hard boil"
used in cookbooks. I discovered using a candy thermometer that even at a
hard boil the temp. indicated only 200 degrees, since it registers the
average of the pan, not the actual boiling water molecules. If this is true
then this calibration method could be off by 12 degrees.
Subject: | Electronic Ignition? |
Hi,
I saw that Vans is offering an electronic ignition options on its new
Lycoming engines. + $1500.00
I know next to nothing about these ignition systems. Are the magnetos
eliminated from the engine? Can anyone volunteer to explain what
electronic ignition is all about?
Thank you,
Glenn Gordon
MZ
<< The instructions are very vague about where to position these. Any
suggestions? >>
With the fuselage upright, make sure the bottom of the vents are about 3/4"
minimum above the top of the rudder pedal weldment pivot blocks and that the
vent is approximately centered longitudinally between the firewall and the
vertical side skin stiffener angle. I stuck them on with proseal, but 3M
2216 Gray structural epoxy would be okay, too.
-GV
<< Watson >>
You will have to cut a hole in the spar web to permit the control column to
transit from the front to rear of the aircraft. It would be easier to cut the
hole in advance of the wing installation. Note you also installed a cutout in
F404 bulheads for the same purpose. The spar hole should be the same size.
See drawings 11 and 13 for details. Review drawing 28 for function of hole.
Tom Brown RV4 - fuselage in jig
> -Glenn Gordon
A few times when clecos were in the way I used soft alum. pop rivets
(hardware store variety).
They are easy to drill out later. Don't use more than you need to hold
the stuff together.
Bud Newhall
bud(at)softcom.net
__|__
__|__ ____(+)____
____(+)____ ' '
Subject: | Re: Holes in Spar? |
Ken:
Since the spar carries very little of the load at the tips you can
safely drill small holes out there. Just deburr carefully so you don't
leave any stress risers.
DJ
Ed:
Isn't that Vernitherm thingy set to bypass the cooler until the oil hits
about 170 or so? Seems like I remember reading that somewhere. Maybe
you've got a sticky one.
DJ
Subject: | Re: RV-List:Sheetmetal Tools |
A great source of sheetmetal tools for RV builders is Brown Aviation Tool
Supply Co. of Oklahoma City, Oklahoma. They offer a free catalog by calling
1-800-587-3883. Items available include: clecos, riveting tools,
countersinks, extension drills, air tools, and more.
Subject: | Re: punch line needed |
Kevin:
Do as little taxi testing and ground running as possible, then take it
up and run high power settings until oil consumption stabilizes. At
that point the rings will be seated and you can relax. Shouldn't take
more than a couple of hours or so depending on the kind of cylinder
surface you have (nitride, chrome, etc). The important thing is to keep
the cylinder pressure up during breakin so the rings are deflected down
to their maximum angle and the ring surface riding on the cylinder wears
in at that angle. Then after breakin you'll get good oil consumption at
high power while at lower cylinder pressures (lower power settings) the
ring will still scrape oil properly. If you do it the other way around
and seat the rings at low power, the ring won't scrape the oil off at
higher power settings than what was used for breakin and you'll use a
lot of oil.
I think the main problem with trying to break in an engine on the ground
would be cooling it. If you had some way of forcing air over the
cylinders to maintain temp limits, I don't see why you couldn't use a
test stand to break the engine in. I guess that's the way they must do
it a Lyc. My engine came already run in from the factory. Good luck.
DJ
I tried using manifold vacuum to run just a single DG and found there
isn't enough vacuum to keep it spun up at cruise. There's more than
enough at idle, but once you open the throttle, you only have an inch or
two difference between atmospheric and manifold pressure.
DJ
> suggestions? >>
>-GV
-6 Fus. builders,
... note that many folks (myself included) are putting
spacers in that raise the rudder cross tubes about 1 inch. If you want to
do this, then the air vents must be raised by a corresponding amount.
Check the archives for discussions on brake/rudder pedal height.
... Gil (check those archives) Alexander
RV6A, #20701, finishing kit
"REPLY" sends to entire RV-list
mailto:gila(at)flash.net to reply privately
Subject: | Re: Electronic Ignition? |
Glenn,
I have just had an engine delivered with the "Lasar" electronic ignition
option. It still has slick magnetos but these now have a control harness
that connects to a controller with pressure compensation. Should the
controller fail the engine reverts to a fixed advance magneto (the advance
will permit running but without the battery and controller the engine
cannot be started). What you are buying is a system that will modify the
advance according to engine RPM and ambient pressure.
I should add that no documentation came with the system except a cryptic
note on the box that it should be installed according to Slick service
bulletin #xxxxxxxxx. I am in the process of trying to obtain same. This is
a little irritating. I hope I am at the leading edge of ignition
technology. It is possible that I am a beta test site.
Leo Davies
>Hi,
>Lycoming engines. + $1500.00 =20
>Thank you,
>Glenn Gordon
>--=20
>MZ=90
charset=US-ASCII
That skin is the most Pain in the A#@. Once your canopy is on with the
struts installed, the damn frame moves forward a little from the pressure
of the struts. Your nicely fit skins now need trimming and fitting again.
That's what makes me now want the slider.
John Balbierer, RV-6
Original Text
6:48 PM:
Hi,
necessary.
Is there a low profile substitute for the clecos? =20
-Glenn Gordon
--=20
MZ=90
om" |
ct. |
charset=US-ASCII
There are no real guidlines as to where to put them. Watch out for your
rudder pedals on the inside. Look at the plans and this gives you a
general location. Tape on the template, make sure it 's level with the
longeron and cut!
Original Text
10:22 AM:
Hi,
suggestions?
-Glenn Gordon
--=20
MZ=90
om" |
ct. |
<< Before the final closing of my wings, I would like to mount my strobe
Any opinions will be greatly appreciated. >>
Ken:
I've done several set this way. I usually use only two holes, tho. More
nutplates, eh? What fun........
Check six!
Mark
<< I'm currenlty working on the main spar for my -4. The plans show a cut
out
Glen Watson >>
Do this at the same time that you're building up the #4 blkhd. It's easy
then, diffucult later.
BTW, cut the 2" hole for the heat hose at this time, too.
Check six!
Mark
Subject: | Re: Pro-Seal substitute from Spruce? |
<< Mark,
Please post the phone number for Seal-pac.
Steve Johnson
RV-8 #80121
Left wing, about ready for the dreaded fuel tank >>
316-942-6211
Have fun!
A regular caulk gun can be easily converted for use with thees tubes- reduce
the size of the plunger end so it fits inside the end of the tube. Now you
have a dispenser for 99 cents! Some styles of caulk guns will require a
rubber band or two around the gun & tube to hold things together, too.
Check six!
Mark
Glenn,
Becki and I just installed a electronic Ignition from electro air and
are very pleased with it. ItThe system directly replaces one mag leaving the
other as a backup, cost $800.00. If you would like more info give me a call
at (817)439-3280....George Orndorff
Lou: Since the handle lays tight to the floor, I cut away about 50% of
the forwardmost end next to the floor for a distance back from the end
sufficient to get my fingers around the handle except for a small spur
at the very end to reduce the chance of slipping off the handle. When
you remove the handle for this mod, make sure you remove metal from the
proper edge. You might guess why I suggest this last.
G.Comfort
RV4 N363GC
>Glenn,
>Cheers,
>Leo Davies
>>Hi,
>>Thank you,
>>Glenn Gordon
There are other options....Lightspeed, Electroair are systems I am familiar
with. They are stand alone electronics, not piggy back systems such as the
Unison. But they work fine and are significantly cheaper. I have an
Electroair on my 4 and it works great. Electroair's # 423-622-8825, Jeff
Rose is the owner. I believe he has over 800 of his systems flying.
Regards:
Rusty Gossard
N47RG RV-4 Flying since 8-94
>Ken Harrill
Ken,
I see no problem in drilling #19 holes in the spar near the tip. Keep them
close to the center of the spar (top to bottom) as this is where the stress
is the least. Deburr the holes and you should have no problems. If you are
wondering if Van would approve, just call the factory.
Hope this helps.
Scott Gesele N506RV (Taxi test complete, almost ready for FAA inspection)
From: | Charlie Kuss <charliekuss(at)sprintmail.com> |
snipped
> even the
> water you then have
No offense, but isn't it possible that the candy thermometer was not
accurate? They aren't exactly high dollar items. For that matter I
haven't seen many home oven thermostats that were accurate.
Charlie Kuss
From: | Will Cretsinger <cretsinger(at)startext.net> |
Subject: | Re: Rivet tape idea |
> I used electrical tape and had gobs of residue after a few cycles of hot
days...I have about eight rolls I'd sell cheap! Scotch Removable Magic
Tape #811 from your local office supply store is the choice for
backriveting and holding flush rivets. I never found an equivalent tape
to hold universal head rivets satisfactorily...I needed something to
hold the 3/16 spar rivets while waiting my turn at the factory rivet
squeezer. Haven't needed such a product since. Masking tape and duct
tape do leave residue to clean up...
Will Cretsinger
cretsinger(at)arlington.net
6A fuselage out of jig
Arlington, TX
You can buy an aux power outlet at any auto parts store or RadioShack. I
bought mine at the later - it was about $6.
This is absolutely not true. At standard atmospheric pressure (29.92
in.mercury),
you can get that pot to a true boil and see 210-212 deg. on any decent
thermometer. I check our shop's thermometers this way. On a day with higher
atmospheric pressure, you can get readings of 215 degrees.
Kevin, I have to believe your candy thermometer is incorrect.
Louis Willig
Subject: | Re: Air Vents and Cowl pins |
One builder in my area has used the vent as the input point for the cowl
pins. If you do this, center the vents in line with where the two halves
of the cowl meet. A hole is then drilled through the forward end of the
vent. A small length of metal tubing is prosealed in place to align the
pin with the hinges on the cowl. A large pop rivet is then placed in the
vent as the anchor point for the pin (using the center hole of the pop
rivet). This setup keeps the pin on the outside for ease of removal and
removes the possibility of the pin getting loose and messing up your prop.
Ross Mickey
rmickey@ix,netcom.com
> suggestions?
chocolatetruffles.com!glenn(at)matronics.com on 09/01/97 06:48:42 PM
Hi,
necessary.
I am having a similar problem. I suggest riveting the skin in place, and
making all of your trim adjustments on the canopy glare skin. It has more
edge distance anyway.
Alternatively - you can probably get the canopy partially open before it
contacts the clecoes (about 5%). This is about all that you need since the
interference problem occurs just as it opens.
Hi folks! I have a question about a IO320 for sale. The price is right,
2500$, but the engine has a problem. It=B4s a Dynafocal 2, 18degr. mount,
and the injector is aprox. 45 degr. backw. what kind of modification do
I need to do? The engine came from a Twin Comanche, 1800 hour.
Leif Stener, RV-6 in Sweden.
I have a Garmin 50 which is couples to a Navaid, and orks very well. I
thought it would be a big deal, but in fact there were just two wire to connect
John C GDOC 75 hours
Water boils at lower temps at higher altitudes. The boiling point goes down
about 1.2 degrees per thousand feet, so you must adjust your reading
accordingly. Also as a secondary check, you can always put a known
thermometer in the water with your oil temp sender. This way you can
compare it to the reading on the gauge as temps increase.
Andy
From: | "Louis E. Smith Jr." <lsmith(at)coastalnet.com> |
Subject: | RV-8 fuselage jig for sale |
RV-8 Fuselage Jig For Sale
Wood, Glued, & Screwed. $100.00
Louis Smith
Rocky Mount, NC
(919)937-4905
Kevin,
What altitude was the pot at when it was boiling? At standard conditions
(sea level, 760 mm Hg pressure) a thermometer immersed in a boiling
solution of water will indeed read 212 F if it is properly calibrated.
There are corrections (published in Physics tables and elsewhere) for
altitude and pressure. Either your candy thermometer is off or your
altitude/pressure were not standard at the time of the test.
> From: kevin lane <worldnet.att.net!n3773(at)matronics.com>
> Subject: Re: RV-List: Is 210 Degrees Engine Oil Temp To Hot ?
> Date: Monday, September 01, 1997 7:58 PM
If you boil
> water you then have
boil"
true
>with an unflown airplane(owned by a low time pilot)? Seriously folks,
Seriously? Don't do any more taxiing than absolutely necessary. A
couple of minutes to check the gear and brakes, make sure the panel stuff
works, shut down and check for leaks, then put the hammer to it and fly.
Running a new or newly o/h'd engine at low power is the absolute worst
thing you can do. You need to run it at 75% power for as long as the
manufacturer says. Lycoming recommends running at 75% power on a new
engine for 25-50 hours, or until the oil consumption stabilizes.
My oil consumption was stable right from the factory at about a quart
every 15 hours. Lycoming says this is common on new engines with
nitrided cylinders and to keep up the break-in period (and the straight
mineral oil) for 25 hours, with an oil/filter change at 12 hours.
I'm not sure what your 220 hours are in, but as far as the test flight is
concerned, if you have little or no time in RV's, you might want to
enlist the help of an experienced test pilot. At 190mph, and monitoring
an unproven airplane, you can get behind the curve fairly quickly.
<340B984A.3EFF@tms-usa.com>
DJ, that is more or less the idea. From what I understand however, the
vernatherm valve still lets quite a bit of oil through even when
"closed". It doesn't have near the range of an automotive thermostat.
Because RV's cool so well, the oil that keeps circulating through the
cooler is enough to keep the temps quite cool in the winter.
Lou,
I soldiered on with the manual flap handle until I installed rear seat
foot wells as shown in the RVator article. The flap handle goes right
down the middle of the left foot well. I gave up and installed the
electric motor. The installation was quite straight-forward, and will be
my first choice on my next project.
Tom Craig-Stearman
RV-4 wings mounted, hooking up the myriad little details
>lever.
>made
>to make flap
>application easier?
Subject: | Re: Just wondering out loud |
Shelby wrote:
> With at least three diesels in development, I would imagine that diesel will
> play at least a moderate role in future airplanes. I for one would love to
> have a diesel.
I think diesel's going to play a big role. No matter which way you
look, you see people doing diesel (or turbine) development for GA
aircraft. These projects all seem to be based on the belief that
avgas will become uneconomical or unavailable in the not-too-distant
future. I don't know a heck of a lot about diesels, but the duty
cycle and desirable power curve of airplane engines seems to be a
lot like what diesels are typically used for.
Tedd
Subject: | Harbor Freight HVLP Spray Gun |
I notice that everyone keeps talking about the spray guns they use such as
Binks, Croix, and others that run $300-$800 and up. I wanted to share my
experience using the Harbor Freight Central Pneumatic Brand HVLP spray gun. I
paid $59.00 for mine five years ago and have painted 3 airplanes with it,
including a Cessna Cardinal and an RV-4, plus lots of primer. The results
have been outstanding, I've had people ask where I had my paint done, so they
could get an estimate! I used to paint cars occasionally as a hobby, and my
experience is that unless you are into production spraying, etc. a gun such
as the above is more than adequate. The current catalog number of my gun is
#05726-5URA, $69.00 and free shipping. 1-800-423-2567. Just my opinion, thats
all.
RV-4 N107RV
Von Alexander
MAlexan533(at)aol.com
<< I discovered using a candy thermometer that even at a
hard boil the temp. indicated only 200 degrees, >>
Possible sources of error:
1. Water boils at 200 F at 6500 feet altitude. Are you located in
Colorado Springs?
2. Candy thermometer could be off by a couple of degrees( more probable).
Accurate thermometers are expensive.
Gene cafgef(at)aol.com
Subject: | fuel line routing |
I would like some advice on fuel line routing for the RV-6. For various
reasons I am considering a different routing from the selector valve and
the firewall than what is shown on the plans. I think what I have in
mind should work but am a little nervous about modifying this critical
item. Any help/advice would be appreciated.
The routing I am considering is this: down from the fuel selector, 90
degree left turn, 6 to 12 inches straight, then into the fuel flow
sensor, 90 degree turn out of there (bent or a fitting), forward along
one of the floor stiffeners, up to the electric boost pump, which will
be mounted at a 45 degree cant (per instructions) on the firewall,
thence up and through the firewall.
What do y'all think? The electric pump (Facet) instructions say to keep
it out of the engine compartment and away from heat. Is it too much
heat if it's mounted to the back side of the firewall? Would a bracket
that held it 3/4" back be needed/enough?
Also the plans show the line going through the firewall at what looks to
be the exact level of the fuel selector valve. Is there a specific
reason for this? Are there other high/low dimensional considerations I
need to make sure I take into account?
Randall Henderson, RV-6
randall(at)edt.com
http://www.edt.com/homewing
Subject: | Would you use better engine oil? |
Well here goes,
I have received several replies off the list about the oils I am always
talking about. I have been doing some thinking, (we all know how
dangerous that is...) If I were to formulate an metalic detergent based
engine oil based on the latest additive technology how many would be
interested in it?
This would not be something I dream up in our lab, it would be formulated
using the experience of major lubricant additive manufacters. And I don't
mean Slick 50. It would not have Teflon, and it would not allow you to run
your engine for an hour without any oil. Nothing magic or too good to be
true. Just a way to reduce the rate at which the valve train and the
cylinder walls eat themselves. We are not talking about 4000 hour TBO's
either. Just a statistically significant reduction in engine wear.
I would fund the oil and oil analysis on these engines. I could not
warranty anything, but it would further the knowledge pool. I am certain
that the majors are not going down this road because the market is just not
there. I am not promising anything at this point but if you are interested
drop me a note off-list at dougr(at)petroblend.com.
I would need to first find some high timers that were using some oil to
find out if it would plug up the valve guides. I have less concern about
the rings. But would want to watch them as well. Obviously this would be
a blind test and some of the engines would get the same oil they are
currently using.
I would put in my 200 hr IO-320 160 hp. It burns less than a quart to 20
hours. If we could get some success on the oil burners we could expand
into the lower timers.
Please include: Engine
Hrs SMOH, STOH
Oil consumption
Filter or Screen
Drain Interval
Current Oil, brand, Viscosity grade, AD or mineral
Hours flown per month
Are you currently doing oil analysis?
Also if you are happy with the oils you are using tell me that too, that is
just as important.
I have been harping on this subject for years, maybe it is time to put up
or shut up.. I am about half afraid to push send but here goes....
Doug Rozendaal
dougr(at)netins.net
PS See more about the company at www.petroblend.com
From: | "les williams" <lesliebwilliams(at)classic.msn.com> |
Leo,
Maybe the reason that no installation instructions are included is to insure
that you obtain the latest version before the final hook-up even though a lot
of the basic installation has already been done by Lycoming for the run in. A
friend of mine obtained a new engine from Van's in early 1991 and still hasn't
run it. A lot of changes could be made in that kind of time frame.
I don't think you're a beta tester as mine came the same way just three days
ago. A notice in the box also mentions a video which also might be handy to
have. Looks like it was probably in the box before Lycoming did their bit.
Would appreciate knowing what you find out. If Bill Benedict is reading this
maybe he will respond also.
Les
From: owner-rv-list(at)matronics.com on behalf of Leo Davies
Sent: Tuesday, September 02, 1997 1:20 AM
Subject: Re: RV-List: Electronic Ignition?
Leo Davies
Subject: | Re: incredible BSFC! |
<< Any idea what figure an O-360 does give? >>
The following is right out of the Lycoming Manual for O-360-A1A:
At 100% power (180 hp @ 2700 rpm) it uses 15 gph for a BSFC of .50.
At 75% power (135 hp @ 2450 rpm) it uses 10.5 gph, for a BSFC of .47.
At 65% power (117 hp @ 2350 rpm) it uses 9 gph, for a BSFC of .46.
The extra fuel above 75% power is for cooling.
-GV
Subject: | the real squeaky brake solution |
Last week I thought i had found the answer to a serious squeal from my
left brake.
When I began to look at the problem then I thought there were 3 possible
fixes. One was to find whether the brake pads (with a very high metal
content) was the culprit. To solve that problem I switched the pads
around from the left to the right sides. If the pads were bad, the
problem would have followed itself to the new side. It did not.
The next possibility was to apply a compound called "disk brake quiet" to
the contact points on the slave cylinder. I thought that was the answer
because on the next ride, everything quieted down and the problem
dissappeared.
The third "fix" I performed that day, I did not take very seriously. I thought
that since the brakes were apart anyway, I might as well lube the two pins
that allow the calipers to ride in and out of the brake assembly.
Well, a couple of flights ago the grinding and squealing came back. I applied
some more "disk brake quiet" and nothing happened. The problem was still
there. So today, I opened the brakes again and re-lubed the pins with a
powder graphite type lubricant. The problem went away.
Obviously the lubrication of the pins in their slots is the answer. However I
am still concerned on why this needs to be done. The right side works fine
without the lubricant. Is anybody here familiar with the standard Cleaveland
brake package that Van's provides? Is the need for lubrication in this area
normal? If so what kind of lubricant should be used? The graphite worked,
but only for 3-4 flights?
If this is new to everyone, does anybody have the phone numebr for the
Cleaveland Brakes Company so i can call them?
Andy Gold
I discovered quite by accident that by turning off my Loran, My electric
oil temp guage would indicate about 10 degrees cooler. Turned my radio off
and it dropped another 5 or so, turned the transponder off and the reading
dropped another 3 degrees or so.
Obviously I have a wireing "guage" glitch or some other anomoly, but you
might check it out and recieve some cheap peace of mind.
RVator
Steve
Schmitz
From: | "Gregory S. Brewsaugh" <gregbrew(at)gte.net> |
Subject: | Aerobatic Survey |
Listers,
Please respond to me personally, and I'll post the results.
Are you/did you install the "flop tube" in your fuel tanks for
aerobatics?
A simple "Yes" or "No" is adequate.
Thanks, Greg
gregbrew(at)gte.net
-6A HS and VS done Rudder 1/2 Got Wing Kit!
Subject: | Re: Oshkosh Statistics |
<19970829.180044.4807.0.GASobek(at)juno.com>
A. Sobek) writes:
>in 1986 or 1987 Kent (Rocky) Rockwell started exactly what you
>suggest. He used POLICE do NOT CROSS barricaded tape between RV's.
>Jim Ayers may have been there when this was done.
>Gary
Hi Gary and all,
Actually, I remember it being 2" wide red ribbon in 1986. He could have
used the "POLICE" tape on other years that he went.
One thing that really made a difference (even with the ribbon) was having
the canopy cover on the airplane. (As soon as Rocky would lift the cover
to get something out of his RV-3, someone would be there to get a picture
of the cockpit. Rocky received an Outstanding Workmanship award in
1986.)
There was one other deterrent. I had blisters on both feet, and was
sitting in front of, or lying under, the wing of Rocky's RV-3 most of the
time. :-)
Jim Ayers
Listers,
As I'm at least a year away from needing them, is there some as yet
hidden/secret source for the discerning buyer for good used avionics VFR
& IFR? With the time, I can pick and choose. TIA. Greg
-6A HS & VS done Rudder 1/2 Got Wing Kit!
Subject: | Tip-up VS. Sliding Canopy |
Hello Folks,
Having visited Oshkosh last month, I finally settled on an RV-6A as
apposed to an RV-6. Now I have another problem.
I'm about to order my kit and I'm at a loss as to weather or not I
should order the sliding canopy or the tip-up canopy.
The way I see it, the tip-up canopy has two downfalls.
1) Optically incorrect.
2) Exposed instrumentation.
The sliding canopy also has two issues that I'm aware of:
1) Draft eminating from the rear of the canopy (I live in a rather cold
climate - Calgary, Alberta & this would be unacceptable),
2) More difficult to install (so I'm told).
I would appreciate any feedback on this subject including work-arounds
to the various short-comings. Is there other factors I should be
considering?
Thanks for your assistance.
Anthony Wiebe
Calgary, Alberta, Canada
writes:
>Hi Ted!
>I was just as excited about the Zoche engine as you are, when I left
>Oshkosh--------- in 1990. At that time, certification was "nearly
>complete"
>and it would be available "soon".
>I'm not holding my breath.
>Good luck in your quest for an engine.
>Rob Miller
>RV8 wing #2
>Fuse OTW
Hi Rob and all,
I was just as excited when I first heard of the Zoche engine. The 25
inch diameter of the radial engine would just fit in a RV-3, even if I
had to use the 300 Hp version to get the weight and balance to come out
right.
However, I found that the Zoche was going to sell for the same price as a
Lycoming of the same horsepower. We are not talking Van's price, we're
talking retail Lycoming prices.
Maybe it's not that way now. :-)
Jim Ayers
From: | "Roger Healy" <Max_Throttle(at)classic.msn.com> |
used in cookbooks. I discovered using a candy thermometer that even at a hard
boil the temp. indicated only 200 degrees, since it registers the average of
the pan, not the actual boiling water molecules. If this is true then this
Kevin,
What altitude are you at? Water boils at 212 degrees F only at sea level and
at standard pressure. As your altitude increases, the boiling temperature
decreases. In Denver, the boiling point is approximately 195 degrees (if I
remember correctly). At a hard boil, the temperature throughout the water is
essentially uniform. The water vapor is carrying heat away from the liquid
water as the burner is adding heat so that the liquid temperature is constant
and uniform at the boiling point. Obviously, the thermometer could also be
inaccurate, as has been suggested.
Looking for RV-8 preview plans (and a certified Zoche would be nice, as well)
Roger Healy
Subject: | Re: Lycoming IO320 |
> 2500$, but the engine has a problem. Its a Dynafocal 2, 18degr. mount,
Leif:
If this is the same engine I used (IO320-B1C) in my RV-4, then there are
some mods that you will have to do. First of all, the rear mounted
injector interferes with the engine mount on the -4, I don't know about
the -6. Also the front and rear intake risers are different lengths and
staggered so that the rear risers interfered with the bottom cowling on
the -4, again I don't know about the -6 since it is wider. What I had
to do was to get a sump and intake risers from and engine with a
bottom-mounted carb or injector (they are the same mounting). Look
around for a good used sump since the price of a new one is about the
same price as the entire engine that you're getting ($2500).
The other major difference is that the mounting bosses where you bolt
the engine to the shock mounts are countersunk and have special
transition spacers which put the engine about 1" (25mm) farther forward
than the engines with flat bosses. This actually helps the c.g. a
little on the -4, but means that you will probably have to add a little
extra length to the rear of your cowling to make up for it, at least
that's what I had to do. It isn't hard, just a little more fiberglass
work.
That's really about all there is to it. What I am wondering is what is
really wrong with the engine that someone would be selling it at that
price. You can't even get the accessories for that price. Let me know
if you don't want it 'cause I'd snap it up in a Stockholm minute.
DJ
Brian,
You said you used "el cheapo electrical tape" to do your back riveting. I am
curious to know if the tape was thick enough and soft enough that you had
trouble seating the rivets flush with the skin surface. Did any of them rise
above the surface before they expanded and flattened in the hole ?????
Bob Tinnell
Salem, OR
RV-6A wings
Subject: | Canopy Paint Removal |
My RV-4 has a fine fog coat of paint on the canopy; apparently the previous
owner failed to mask adequately. Question; What chemical, if any, can be used
to clean this off? I've used scratch removal compound, but this is a very
slow process. Any better ideas? Am guessing laquer thinner would remove it,
but would probably attack the plastic too.
Unrelated Tip; For outside air temp, I used one of those $1.99 stick-on
thermometer strips that changes color. I put it right against the skin on the
inside of my RV-4, out of the direct path of vents, etc. Aluminum transfers
outside air temperature so well, that this strip, even though inside, seems
to give me a reasonably accurate idea of the outside temperature. Might not
work on those aircraft with heaters, mine doesn't have one, but for $1.99,
what the heck, right?
Happy flying
Von Alexander
N107RV
More likely your candy thermometer was made by Isspro.......
Peter Bennett
Sydney Australia
RV6 engine arrived!
> cc: (bcc: David Moore/CPSES/Texas Utilities)
> Hi,
> way.
edited....
Just a thought, as I'm only in the plans stage of an RV-4, but could you
use an appropriate size machine screw and nut to temporarily go in the
rivet holes such as a 4-40 size screw and nut?
Scott
Gotta Fly or
Gonna Die !
--Ask me about my
Aeronca Super Chief--
amended 8-29-97: Now after feeling the "Need for Speed", building an
RV-4!
No, the Super Chief is NOT for sale :)
From: | catbird(at)taylortel.com (TTC Carroll A. Bird) |
> Where can you buy an accurate one at any price?
Carroll
From: | Ken_Hitchmough(at)magic.ca (Ken Hitchmough) |
Subject: | Re: Tip-up VS. Sliding Canopy |
I suggest that you try and get a ride in both types. The slider is sexy on the
ground but who wants
to stay on the ground. ;-)
he tip up is also easier to get in and out, the negative of exposed instruments
is also a positive
when it comes to working on them.
Ken
RV6A flying (tip up)
Subject: | Aeromatic prop info |
<< You might want to contact Kent Paser. >>
I sat across from Kent on one of the OSH busses this year. I asked him about
his phone being disconnected, and he said that the Ford Motor Co had a # very
close to his, so he had his changed to something less conspicuous. I didn't
get the new #- sorry. Please post this new #, if you get it......
A local IA loaned me his Aeromatic Service book for reading once. I'm sure he
still has it, as his Bellanca has one mounted on it.....Very interseting
operational concepts..... Seems owners carried extra counterweight washers to
adjust their props while traveling from the plains to the mountains & back. I
don't remember the speed range of these units. Could be that the available
travel or blade twist isn't quite up to what we need. Email me off the list
for his #.
Check six!
Mark
From: | wstucklen1(at)juno.com (Frederic W Stucklen) |
Anthony,
What's opticaly incorrect about the tip up?? There certainly
isn't anything obstructing ones view (like the roll bar in the slider.
As far as the "exposed instruments" is concerned, I've never had
a water leak while flying (967 hrs in four years). I did put a velcroed
water proof fabric over the instruments so that water doesn't get in
when I open the canopy when it's raining. I've never had any water
related instrument failures.
It's also easier to get in/out of a tip up vs a slider... you don't
have to
step on the seats. In RV-6's, I've always stepped on the spar box. In my
-6A i step onto the landing gear bracket, never the seat......
And you're correct, the tip up seals better. It's cold in New England
in the
winter also. I don't have any problems heating the cabin in the
winter....
(Working on 2'd RV-6A - Chevy Powered!)
writes:
>Hello Folks,
>cold
>considering?
>Anthony Wiebe
Subject: | Tank Sealant mixing |
Here is an easier way to mix the tank sealant material that comes in the
caulk style tube that worked great for me. This is for the two part mix
with the part B mix in the plunger with the mixing blade inside the tube.
1. Use a drill press and slow it down to its slowest speed.
2. Push the Part B mix of the sealant into the main chamber.
3. Cut the round head off the plunger so that only the 1/4 inch shaft is
exposed. (The shaft should be connected to the mixing blade on the
inside of the tube.)
4. Insert the shaft into the drill chuck.
5. Hold onto the tube and start the drill press. As the drill in
running, you can move the tube up and down the shaft so that the Part A
and B mix are completely mixed.
I found that by using this method, the mix was very complete and could be
done in about 1-2 minutes giving you more time to apply the sealant.
Every seconds counts once part A and B mix. I did each tank in two
steps; first the inner ribs to the skins then the outer two ribs and
base plate to the skin. The key is to have at least one extra set of
hands, acetone to clean up the mess and guarantee everything, including
your tools and spares, are all laid out and ready to go. Going to the
bathroom midstream with this stuff on your hands can lead to some
embarrassing moments. Once the sealant begins to set, STOP! Its all
done and use the remaining minutes to clean up the skins. Acetone works
great and what you don't remove immeadiately will set in place forever.
I used the two hour mix from Aircraft Spruce, which gives you two hours
of working time... no more, no less.
Good luck.
Gary in NY, Project in MA
RV-6 s/n 20038 final assy - 10+ years in construction and still going
strong
From: | Shirley Hobenshield <shobenshield(at)cmsd.bc.ca> |
> I
>considering?
>Optically incorrect? Thats a new one.
>There was an excellent thread on this subject not long ago. If you cannot
>research it, contact me e-mail.
Is Calgary north of Smithers B.C?
Not to be rude Anthony, but RV-6 ( C-FXXG ) loves these ice mountians
Ed.
From: | "Jim Tennison" <jtennison.cmrl(at)veda.com> |
Subject: | No RV financing! - to Ken |
This message is for Ken. We met at the Van's tent outside with the RV-8 kit
prototype on Saturday morning. You didn't give me your email address! I
decided to take the chance of getting some listers upset by trying to locate
you on the list. (I'm also doing this from work - also not a good idea.)
I want to send you that information on the plan I have for paying off all of
your debts, including your mortgage, in 5-7 years using the money you already
make. I'll also enclose the info on the home-based business in which you can
earn between $8K and $10K per month in residual income. ("Homebuilders do it
at home!")
I know this will really make getting that RV-6QB a sounder financial
achievement especially once you've paid off your mortgage, and you won't be
paying all that interest to the finance company as well. Remember, do not
use your credit cards. Get rid of them. Cut em up!
I've also got some demo debt elimination and wealth building software that
I'll email you.
Ken, please reply to tennison(at)west.net.
If any one else is curious, you can email me too if you want.
(Sorry about this guys. Please disregard. And, I know... I'm bound to get
flames! It will not happen again.)
Jim
RV-4 - finishing up the left elevator
> 1) Optically incorrect.absolutely irrelevant; I can't imagine a situation where
even if this is so, it
would matter
> 2) Exposed instrumentation.This is a benefit not a downfall. The biggest problem
with the slider is that
it is very difficult to get to your instruments when you need to inspect or
service them
> climate - Calgary, Alberta & this would be unacceptable),There are ways to seal
the canopy, although I must say that with my tilt-up
there are no drafts what-so-ever
>More difficult to install (so I'm told).I was told this too and it is the reason
why I built mine with a tilt up. After
doing mine, and helping my neighbor with his slider, I no longer believe this to
be
true. In fact it may be just the opposite. The tilt up is no joy either.
Another benefit of the slider is to be able to open it up while taxiing on the
ground. It does get hot in there. The tilt-up has a latch to hold it open a
couple of inches when taxiing, but the full slider would be even nicer, yep,
even in Canada.
If I did it again, I would do the slider with the additional modification of a
large
removable panel in the front skin for access to the back of the panel.
Andy Gold
Winter Park, CO
elevation-9100 (just as cold as Canada)
<< The sliding canopy also has two issues that I'm aware of:
2) More difficult to install (so I'm told). >>
I would disagree that the slider is more difficult than the tip-up. The
draft issue can be dealt with.
-GV
Subject: | Re: the real squeaky brake solution |
<< If this is new to everyone, does anybody have the phone numebr for the
Cleaveland Brakes Company so i can call them? >>
Check the Yeller Pages at http://www.sound.net/~hartmann/yelrpage.htm
-GV
<< re-lubed the pins with a powder graphite type lubricant. >>
Graphite will make a battery with almost anything. The anything is
sacraficial to the graphite. In otherwords ---> graphite will cause
corrosion<----- especially with cad and zinc plating. I would advise getting
the graphite off as soon as possible.
Do not use it on anything!!. Please!!
On the other hand some stuff that looks like graphite and is almost as good a
lubricant is molybdenum disulfide. Moly will not cause corrosion. I am not
sure that I would want much lub around brakes, though.
Check with someone who knows about the proper lub for the brakes. Probably
Cleavland would know.
Gene francis cafgef(at)aol.com
The debate continues.
If the tip-up is optically incorrect, then so is the slider. They are the
same canopy, cut differently for installation. The instrumentation is only
'exposed' on the tip-up when the canopy is open or removed. Many builders
fabricate a simple lightweight shroud to offer protection when the canopy
must be opened in the rain.
Either canopy either leaks or doesn't - the responsibility for crafting an
acceptable fit is left to the builder. Reports from other builders indicate
that neither canopy is particularly difficult or easy to install.
My advice is to follow Van's advice. Choose the canopy style you like best,
or that best suits your intended use of the aircraft. In my opinion the
slider looks better on the ground, the tip-up offers less restricted vision
when in the air. Do you plan to park it, or fly it?
- Mike
hartmann(at)sound.net
From: | Mark Reisdorfer <Reisdorfer(at)compuserve.com> |
Louis,
I am interested in your jig. I left a message on your machine today. I wi=
ll
be on the road the rest of this week so e-mail may be the best way to
communicate.
What size is it and can I take it apart to transport?
Let me know if it is still available.
Thx
Mark Reisdorfer
73101.73(at)compuserve.com or reisdorfer(at)compuserve.com
812-923-5059
Subject: | Re: fuel line routing |
I will also be deviating from the plans but will be copying a builder who
will be flying way sooner than I will. The main problem with the plans is
that it leaves a loop of fuel line which can not be drained and therefore
represents a possible location for water accumulation and the problems
which come with that. This loop is between the fuel selector valve and the
firewall. I will be running my lines so they are downhill from the fuel
selector to the firewall (gasolator). This puts the low points at the fuel
drain on the tanks and the gasolator with no "dead" area in-between. I am
building a 6A so this requires routing the lines through the web of the
gear legs. I will also be mounting the boost pump almost level. I don't
know why Van calls for the 45 degree angle or why he designed this routing
with an area where water can accumulate.
Ross Mickey
My .02 on the tip-up vs slider question:
1) Optically incorrect -- how so? Whether you use the slider or the
tip-up, you start with the exact same bubble. And with the tip-up, you
don't have any roll bar in your line of sight, just unbroken sky.
2) Exposed instrumentation. This can be easily remedied by making a cover
out of some waterproof cloth or something Most people actually consider
this an advantage since you have much easier access to the back of the
panel for maintenance than with the slider.
3) Sliding canopy draft -- I haven't actually flown mine so I can't really
give advice on how to minimize or eliminate this, but I have flown many
hours in sliding canopy RV-6s, up high and in winter, and either the
builders dealt with it successfully or else it wasn't a problem to
begin with, because I never got uncomfortable (except once when the
heater failed!)
4) More difficult to install -- I only know about the slider which was no
picnic, but tip-up types also cuss about it, so who knows. I think the
slider may be more difficult but it's like hitting yourself on the head
with a hammer 10 times instead of 9.
I chose the slider, just because I like the way it works. I have flown
many cross-country hours in (other people's) RVs , both sliders and
tip-ups, and I just plain like the slider better, in spite of the
main disadvantage of having the roll bar in your field of vision.
But it really does just come down to a personal choice. A tip-up may
in fact be better in colder climes as it is probably easier to seal
against the cold and you don't care as much about keeping cool when
taxiing.
As for how best to build it -- there is lots of info in the rv-list
archives about canopy construction techniques. When you get to that point
search the archives, and feel free to email me if you do a slider and I'll
try to help out however I can.
Randall Henderson, RV-6 (about ready to buy/install the engine)
randall(at)edt.com
Subject: | Re: Canopy Paint Removal |
> to clean this off?
I used Naptha (after talking to Van's) to remove excess sealant around
the fairing, worked great. Don't know about paint though. I'm pretty sure
lacquer thinner and acetone are no-nos.
The scratch removal (e.g. Micromesh) I'd think would be a last resort.
I would worry about it removing unevenly around the different hardness
paint/plexi, and causing distortion. Belive me, you can create
distortion pretty easly with this stuff (little ripples in the surface),
just by not working perpendicular to the previous step every time. I'd
be afraid the paint might aggrivate this.
randall(at)edt.com
Subject: | Suggestions for posting messages |
It would easier to sort through the emails if everyone
would use a common syntax for the subject line: ie.
RV6: Wing skin installation question
RV6: Punch line needed
RV8: Empennage construction
GEN: Rivet tape suggestion
We could hash out a concensus on the alias as what
syntax to use?
Todd Webb
RV8-Waiting for my tail...
From: | dralle(at)matronics.com (Matt Dralle 510-606-1001) |
>> to clean this off?
I've used excessive amounts of lacquer thinner on two different canopys now
and have had no problems what-so-ever. Cleans up the overspray very nicely
(depending on what the spray is). Since there is no real 'standard' for
lacquer thinner formula, I would experiment on a test piece of plexi first...
Matt
510-606-1001 Voice | 510-606-6281 FAX | dralle(at)matronics.com Email
Subject: | Re: Harbor Freight HVLP Spray Gun |
Von:
That's good information. Thanks.
What are the air requirements. Most of us have
25 gallon tanks with 3.5 HP compressors. I
understand hose diameter may also be critical
Bob Lovering
RV-6 N7LA
Getting ready to go to the airport.
Subject: | Electronic Ignition |
Rusty Gossard or anyone,
Dave Ross and myself were discussing the installation of (one)
Electronic Ingnition module and keeping the other stock slick mag.
When you do this.
1. Does the slick mag stay at 25 degrees
2. Does the Electronic module (fire) at a different time than the
slick mag.
3. Does this hurt the engine or make it run rough at any given speed.
4. When the engine is at idle how do you get optimum smoothness when
one set of plugs are igniting the fuel at the old 25 degree setting.
5. It's not that we're dumb, we just don't know.
Jim Nolan N444JN
Subject: | Re: Fuel Tank Fabrication |
> 2. Install the stiffeners backwards so the rivets are visible.
> I will call Van's on number 2 unless there are responses on the list
> that it's a well known technique, since it does represent a deviation
> from the plans.
I did this on recommendation from a guy who builds RV wings for
a living. It was just to make it easier to rivet the stiffeners
on. I can't see any reason why it would make a difference
structurally.
randall(at)edt.com
Charles:
There must be 3 megabytes of information in the RV archives on
primers, compressors, HVLP paint systems vs conventional paint sprayers,
various paint systems and brand name recommendations. Suggest you might take
a look.
Tom Brown - RV4 fuselage in jig
Subject: | Re: Would you use better engine oil? |
Doug Rozendaal wrote:
> Well here goes,
> always
> based
> interested in it?
> formulated
> don't
> to run
> be
> TBO's
> certain
> just not
> interested
> to
> about
> would be
> currently using.
> 20
> expand
> Hrs SMOH, STOH
> Oil consumption
> Filter or Screen
> Drain Interval
> that is
> just as important.
> up
> Doug Rozendaal
> dougr(at)netins.net
Doug....
What is your findings on using Mobil 1 in Aircraft eng to date ?
Much Thanks in Advance
John McMahon
E-Mail=rv6(at)earthlink.net
Subject: | Re: No RV financing! - to Ken |
> RV-8 kit
> address! I
> locate
> idea.)
> all of
> already
> you can
> do it
> at home!")
> won't be
> not
> that
> I'll email you.
> to get
> Jim
Jim
Lets here about this plan you wrer talking about
John McMahon
>the ground but who wants
>instruments is also a positive
>Ken
>Right on Ken,
> RV-6 Flying ( tip up )
> Ed.
I hope none of this involves sending out letters that start off "Hi, my name
is Dave Rhodes" because it sure sounds like that kind of stuff.
Richard Chandler
RV-6: Garage bought and being finished, saving for tools and tail kit.
l info
Sir,
thank you for your e-mail.
So far we have accumulated over 2500 hours of bench testing, in January
1995 we began with the testing of engines assembled out of quantity
production components.
In order to develop firewall-forward solutions we are operating cowled
engines in our own windtunnel. The first fixed-wing aircraft to use our
engines will be the aerobatic competition aircraft EXTRA 300 which is
scheduled to fly the ZO 02A.
We are currently in the concurrent JAR-E (European) and FAR 33
certification program. The usual way would have been to address the
European (JAR-E) certification first before handling the US (FAR 33)
certification procedure. With both the German and US aviation authorities
having agreed upon a concurrent certification, we expect to have both Type
Certificates available during 1998 - but, as with any leading edge
technology, precise schedules are difficult to predict. It is part of our
company policy to sell certified engines only; we consider the
certification as a further proof of the design validity and production
quality. We expect to ship certified engines in two years.
Prices will be competitive to e.g. Lycoming engines of similar horsepower
output, but there is no final price list yet.
To obtain further data you might want to poll our brochure from our fax
(++49 89 342451) or visit our webpage at: http://www.zoche.de
Sincerely,
Dr. Stefan Ittner
From: | Lothar Klingmuller <lothark(at)worldnet.att.net> |
>to clean this off?
Try a very clean cotton rag with acetone.
This worked of my C175 windshield some years agoe when I had some overspray.
Lothar* Klingmuller | lothark(at)worldnet.att.net | Denver (303) 922-2329 h &
FAX ||6A: continueing w/ fuse'ge when garage is build || *(pron'd: "low-TARR")
From: | Temple Ingram <tbingram(at)huntleigh.net> |
Subject: | Other Engine Alternatives |
I am a lurker until now. I am working on the stabilizer of a 6A, so I am a
long way from needing an engine.
The October, 1997 Kitplanes has a short story on turboprop engines
"available now" from Gateway Aviation, Mike and John Sprouse for
homebuilts. They are "U.S.-manufactured industrial turbine engines" which
the Sprouses will "turn into compact, light-weight and affordable turbine
powerplants for aviation experimenters." "Factory-rated 225 shaft
horsepower, 215 pounds with starter, generator, and gearbox, 180 w/o
gearbox, $19,500 without gearbox." One downside is the minimum fuel burn
listed is 16 gallons/hour, which is a lot more than the 260 hp IO540 in my
Comanche burns. Anyway, I was wondering if anyone has any
thoughts/reactions to the article? Although I have no experience or
knowledge about turbines, I have always thought it would be nice to have a
competitively priced turboprop as an alternative to consider.
Now I'll go back to lurking.
Temple Ingram
Subject: | Oshkosh Stats(EAA Proxys) |
Although not directly RV related, this really is a terribly important topic
so I have chosen to respond both "on-list" and directly to Dick Knapinski.
I apologize in advance for the long post.
>I think one comment that said the Board really doesn't care about the
>homebuilders or other groups within EAA is mistaken. The Board is
>certainly open to ideas from any part of the membership. That's not to
>say that every idea will be adopted, but I can say that all are
>considered at a Board or administrative level.
>To that end, what programs or activities do you think would be valuable
>for homebuilders to erase the impression stated by some that the
>organization "doesn't care"?
I'm EAA, but not a chapter member so some of this may be out of line.
Anyway, here's my $0.02.
I suspect that one major reason people feel left out is that they do not
have any personal contact with EAA executives. There is really no good
forum for debate within the organization that includes the faithful on a
regular basis. The flow of information is primarily one way, with EAA
presenting the party line in Sport Aviation.
AOPA's Phil Boyer makes a substantial effort to reach members by traveling
all over the country for his Town Meetings. He seems to come by San Diego
every two years or so. Tom Poberezny needs to build a personal
relationship with his members and would be well advised to institute a
similar program. He and his VPs and possibly Board Members should consider
making visits to Chapter meetings all over the US on a regular and
continual basis. In this way can they start to meet those who cannot (or
will not) go to the annual convention. And only in this way can the masses
get the undivided attention of these men for a few hours at a time,
something which is impossible in the Oshkosh setting.
I also read another post where the author suggested grants for Chapter
homebuilding projects, YE and the like. This touches directly on the issue
of the "Big Money" being made by the convention. As far as I can see, most
if not all of this money stays in Wisconson. HQ needs to find ways to
funnel some of these profits back to the grassroots rather than just make
the convention bigger and bigger (which does _not_ help anyone not living
around Oshkosh very much).
Programs which support chapter building through targeted grants should be
seriously considered. For example, one of the strongest recruiting
elements a chapter could have is ownership of a hanger. A program to
provide a little seed or matching money to help build or purchase this
hanger could greatly strengthen a chapter. More direct support for YE
flights is not a bad idea either, although (I believe) not as effective in
chapter building. In any case, the aforementioned meeting program would
allow HQ to gather the information it needs to create effective programs.
To paraphrase other sentiments, I would rather save EAA than quit it. It
is a worthy organization, it just needs a little help in getting closer to
it's members. I'm appalled at the voting process as much as the next guy,
but that can be reformed if we can get HQ to improve communications. EAA
and AOPA are the only real influence we have on government policy and
replacing that with a new or different and just-as-effective organization
is very difficult at the least.
My two cents.
Bill Pace
wbpace(at)adnc.com
RV-6A Wings in jigs
Subject: | Re: Electronic Ignition |
> When you do this.
>slick mag.
> Jim Nolan N444JN
Jim,
I'm using Jeff Rose's electronic ignition on my O-320. I replaced the
right mag and have a Bendix mag with impulse on the left. The mag timing
stays at spec. (on my engine, 25 degrees). The electronic stays at 25
degrees at full power, take off. The advance comes in to play at reduced
manifold pressure due to either reduced throttle or higher altitude. At
idle , the electronic stays at 25 degrees and the engine runs very smoothly.
The only downside to the Rose ignition is the attachment of the automotive
type spark plug wires, a rubber grommet that squeezes down on the wire when
the nut is tightened. You can get carried away torquing the nut down and you
can break the wire. I prefer to tighten the nut down solid, which you can't
do with the auto wires/nuts. I wish he'd come up with a similar setup to
what we're all familiar with. Otherwise, I'm very satisfied with the unit
which bolts into the right mag hole (as opposed to those systems with gears
and a pick up on the front of the engine.
Bob Skinner RV-6 bskinr(at)trib.com
I use Moly on the pins on my brakes and have had no problems. Of course,
I never had any problems with any of the other airplanes that I've owned,
either. I know some mechanics spray WD40 on the pins but I don't like to do
this as it invites dust to stick and gum things up. It seems that in all of
the brake systems that I've serviced at annual (mechanics little helper, I'm
not an A&P or IA---just did the distasteful jobs for them---my winter job)
that have been sprayed with WD40 did get gummy with dirt. The spray planes
were the worst. If an airplane was flown on pavement and/or infrequently,
the pins generally stayed fairly clean.
Anyway, On my RV-6, I lightly Scotchbrited the holes and the pins,
de-greased and applied a very light coating of Moly---very light. You
really don't need to use very much. There should be no visible "gobs" of
the stuff on the pins. Just use enough so that the metal changes color. I
use Moly on all of my hinges, as well. For the horizontal cowl pins, I
polished the pins, applied Moly and slid them in and out of the hinge loops
to transfer some Moly. My pins now easily slide in and out of the cowl. I
do clean the hinge pin every once in awhile and apply a small amount of Moly.
Bob Skinner RV6 bskinr(at)trib.com
From: | "Mark D Hiatt" <OttoPilot_MSN(at)classic.msn.com> |
Subject: | RE: Gen: Suggestions for posting messages |
I like the idea, Todd, except that the airplanes each have so much in common
with one another that it's hard to say what *really* doesn't apply. There are
things about -3s that would appeal to -4, -6 and -8 builders. I'd hate to miss
out on something because someone had tagged it as being about the RV8 and I'd
been in a hurry that day only read RV6 messages.
And you're going to get posts that straddle the line. The riveting technique
portion would apply to all airplanes, but the RV8 cowling discussion would be
of little interest to the -4 builders, etc.
I think it would be easier to split the list up into an RV-General list, an
RV-8 List, RV-6 list, and so forth. And even then, I'm not sure I'd want to
give up hearing so much good stuff from so many good people (about such good
airplanes!).
I'm not even sure folks would go along with it, though--look how many requests
we still get to be removed or added to the list, and how many people still
quote whole messages, even though the new Matronics tag asks us not to.
Mark D Hiatt Visit us on MSN v2!
OttoPilot_MSN@msn.com http://Forums.msn.com/Aviation
Aviation Forum Manager, AvChat Mondays 10pm Eastern
The Microsoft Network mic://Chat.msn.com/AvChat
We could hash out a consensus on the alias as what
syntax to use?
Todd Webb
Anthony,
1. The optics would be the same as the same type canopy is used on either
one. I don't believe it is optically incorrect. The tip-up offers visibility
without the roll-bar and center support tube.
2. The exposed area behind the instrument panel on the tip-up gives better
accessability to some things, which is a plus in my opinion. It does offer
the potential of getting things wet if not opened quickly when water is
standing on the canopy unless an inner cover is installed.
3. The tip-up offers better egress than the slider, neither is bad.
4. I believe the tip-up is a little lighter, overall.
5. The tip-up is a little cheaper ($120, last I checked).
6. The slider offers a cooler look when it's open, some also say when closed.
7. The slider offers cooler occupants when open in the parked or taxi mode.
8. Air leaks are not a problem with the tip-up, but there are some with the
slider.
9. Both are considered by most to be one of the more challenging items to
build. The majority of the builders I've talked with that have done both, say
the slider is more difficult but that may be because, like me, it was a while
between planes and I seem to have forgotten a lot of the frustrations I had
with my first.
I think that about covers it (pun intended). Good luck!
Les Williams/RV-6AQ/N24LW (RES)
From: owner-rv-list(at)matronics.com on behalf of Anthony Wiebe
Sent: Tuesday, September 02, 1997 8:26 PM
Subject: RV-List: Tip-up VS. Sliding Canopy
considering?
Anthony Wiebe
From: | Ronald Vandervort <rvanderv(at)linknet.kitsap.lib.wa.us> |
Subject: | Re: Another Fuel Line Reroute.....? |
Why do we never see the fuel line to firewall along the right side?
Seems to me with the engine fuel pump inlet on the right side of pump and
outlet on the left side of pump it would be more direct to go along
the right side with boost pump and fuel line, through the
firewall on the right side, on the way to engine driven pump.
I know the blue prints show the left side, and that probably is the reason
most lines are run on the left....The side of the "Pied Piper"! Am I
missing something?
By the way, my neighbor reversed the inlet and outlet on his pump...; just
rotate the sandwitched plate 180 degrees. With that situation then the
outlet of the pump is pointing east when the carb inlet is pointing east
so still not the as straight as running line along right side .
Ron Vandervort, RV-6Q mounting engine
Subject: | Re: Suggestions for posting messages |
Another nice touch is if people use the reply feature of their
email program when replying to a posting. I have all my
RV-List messages automatically sorted to an HTML file, so I
can scan them by subject thread or author. This works great
when all the replies to a topic are true replies (that is,
have "Re:" preppended to the subject line).
Don't forget to check the address, though.
Tedd McHenry
Surrey, BC
I think the EAA is a great organization, of which we all (the
members) should be proud. The EAA has real influence on
aviation policy. Speaking without any real knowledge, I'll
bet few countries outside of the US and Canada have private
aviation organizations that have that much influence over
aviation policy, and can effectively promote sport aviation
regulations that are as progressive as ours (again, both
Canada and the US).
Work at improving it, to be sure. But also appreciate how
good it already is.
Someone mentioned that members were too isolated from the
executive. How about an email listserver for the EAA? Perhaps
it would be too big and impersonal.
Tedd McHenry
Surrey, BC
Subject: | Re: Other Engine Alternatives |
Temple Ingram writes:
> homebuilts.
I had a look at some turboprops like these at Arlington--not sure
if they were the Gateway ones or not. They are built from surplus
GPU engines, or something like that. They looked a bit cobby, but
sound (so far as my naked eye can tell, which isn't very far).
Yes, the fuel burn is a big problem. Also, I didn't see any in the
right hp range. There was one in the 100-hp range, and one in the
well-over-200-hp range, but nothing in the 150-200-hp range. With
the fuel burn, you definitely wouldn't want to use more engine than
you needed. I would think that the best approach, for a turboprop
on an RV, would be to have about 150 shp, and cruise at 90 percent
power (or 90 percent torque, depending on how it's instrumented).
Turbines a nice to fly, for sure. But the fuel burn would be a
real detractor, unless you flew long cross countries almost
exclusively. And then there's all the engineering of a unique
installation.
Tedd McHenry
Surrey, BC
> In my opinion the
I selected the slider because it can be opened for partial vision on
approach if you should ever get an oil leak which covers the
windscreen. It has happened. Before selecting I checked with
Van's that this is safe.
Below 100mph it is safe and the slider sits a few inches open quite happily.
The sex appeal comes free with the safety.
I'm just finishing mine and can attest that it is fiddly but not
really difficult.
Peter Bennett
Sydney Australia
RV6 engine arrived!
I know two RV-4s that are using a cross tube between their fuel tanks. The
one pilot never moves his fuel selector and says that the fuel is always
balanced between tanks. Now I have heard the stories about uneven fuel feed
and running one tank dry but having the other full, but this system has
worked for these pilots for years and hundreds of hours. There are also lots
stories of pilots who forget to change tanks and have problems as well!
Has any one any opions about this. As well they plumb their return fuel line
to this cross over tube.
Tom Martin
RV-4
charset=US-ASCII
LP Aero Plastics puts out a pamphlet on working with your plexi canopy.
There is a world of information in their literature. I had sticky tape
residue on my canopy. I looked for that pamphlet and found that isopropal
alcohol and kerosene were recommended.
I used kerosene. It worked fine with no harm to the plastic. I polished
it soon after with mirror glaze because the kerosene dried the plastic and
created much static. Warm water after the kerosene helps too.
John Balbierer
Original Text
used
the
transfers
Happy flying
Von Alexander
N107RV
I would like to be added to your list. What is the proceedure?
Tom Lempicke
Country Squire Airport
Squire Road and Falls Road
Rock Hill, S. C. 29730
> When you do this.
>slick mag.
> Jim Nolan N444JN
Jim:
The stock mag stays at 25 degrees.
The Electroair fires at a different time (earlier as manifold pressure dereases)
It helps the engine at all settings.
The plugs fired by the electronic side are igniting the burn at the optimum time
resulting in a more complete burn and better flame pattern in the cylinder.
Actually when you do your run up there is no drop when you shut off the mag
as the electronic side is so efficient.
I am also told the electronic has a more accurate trigger so the unit fires
+- 1/2 degree vs. +-2 degrees for the mag.
Regards:
Rusty Gossard
From: | "Glen Watson" <gtwatson(at)students.wisc.edu> |
Subject: | Re: RV-4 wing spar question |
I don't see any reference to a 2" hole for the heat hose in the plans.
Where does this hole go?
Glen
Subject: Re: RV-List: RV-4 wing spar question
Date: Tuesday, September 02, 1997 7:56 AM
Check six!
Mark
Todd - Great idea!
John Hall
From: owner-rv-list(at)matronics.com on behalf of Todd Webb
Sent: Wednesday, September 03, 1997 12:31 PM
Subject: RV-List: Suggestions for posting messages
syntax to use?
Todd Webb
>Jim
.I'm listening Jim.
. Ed.
> at home!")
Just out of curiosity---if this is so great, how come you're building an
RV instead of flying one of your warbirds?? :)
--Don
Subject: | Tip-up VS. Sliding Canopy one more 2 cents |
All of the RV options can spark a lively discussion. I think the slider
debate is second only to the tail dragger vs. 6A. It is truly a personal
choice thing. I feel all Van's canopy designs are elegant engineering
accomplishments which are unmatched by the competition.
Not bashful about my opinion, so here it is. The tip up is faster, cheaper,
easier to build, has better visibility and is lighter. I've found agreement
among all builders on these points. I would personally disagree that the
slider is harder to build, with the caveat that you read Jim Cone's hints and
use the Orndorff tape.
So I say build a slider if you like it better. None of these considerations
are huge differences. I did and I love my slider. It does not leak air in
the rear. It is not harder to get in although I thought it would be. The
lack of access to the instruments is a major pain in the back but can be
addressed by holding off on the top forward skin until everything is in place
on the panel and checked out.
If you are still torn, ask someone who has experienced both, like George
Orndorff. Would you go back to the tip up, George?
All you listers get out to Burlington and ask the builders and see for
yourself. If it's half as good as last year, it will be marvelous. RV's of
all types and lots of builders on hand to talk to. If you can't get a ride
in one, I'll eat my hat. If Jim Cone shows up you ought to be able to get
two rides. Since Burlington is practically on his extended down wind he
should be there unless he has to work for a living that weekend.
D Walsh, RV-6A 53 Hrs. Getting ready to paint someday.
Ron,
This is how I routed my fuel line and it works fine. I'll do the same
routing on my next RV. My reasoning was the same as yours, a straight shot
at the mechanical fuel pump from the gascolator on the right side of the
firewall. This eleminates a bend in a fuel line and lessens the clutter in
the engine compartment. Speaking of gascolators, I'm thinking of going to a
filter installation on the next six and eliminating the gascolator
Speaking of clutter, when you first hang the engine, there looks like
there is so much "open space" on the firewall. It's surprising how cramped
things get by the time the engine installation is completed.
<< My RV-4 has a fine fog coat of paint on the canopy; apparently the
previous
used
to clean this off? >>
Von,
Most wont agree with this but I used accetone to clean the overspray off of
mine with no negative affects. You might try it in a corner area thats
unnoticeable.
Ryan
Subject: | RV-6A Gear leg mounts |
Listers,
I'm in the process of drilling the gear legs. I need to drill for the =
bolts on
the side of the fuselage. For those who have drilled the mounts, you =
know there are 3 bolts that you can't drill from the inside.
Per the manual, the tanks have been removed which gives a clean
shot at the side of the fuselage for drilling. The problem is the amount=
of work needed to remove the tanks.
Per George Orndorff, wait until the wings come off and drill the bolts =
at
that time. The problem is, I'm afraid the mount may shift a little when =
the bolts are removed from the mount and wings.
I looked at the Justice method and got the impression he did his with
the wings off. Mine are in place. Looking at the archives was a joke. =
Getting the note ot match the title was a farce and a wast of valuable =
time.
So, listers who've gone through this, what did you do?
Jim Sears
RV-6A #22220
<< I don't see any reference to a 2" hole for the heat hose in the plans.
Glen >>
page 40. Watch the floor rib & floor support angle placements on BOTH sides
of the #4 blkhd. It's tight, but do-able.
Check six & keep warm!
Mark
>In my opinion the slider looks better on the ground, >the
tip-up offers
>less restricted vision when in the air. Do you plan to park
it, or fly it?
My reasoning for going with the slider was this: the slider offers much
better
cooling while sitting in my plane fiddling around, taxiing, etc. Once
in the air
either plane will be sufficiently cool because the vents do a decent
job. I hate
being hot. If I lived in Canada I might have gone with the tip-up. If
you can swing
it, get a ride in both styles before deciding like I did.
Mitch Faatz San Jose, CA N727MF (reserved)
RV-6AQME fitting rudder pedals / brakes and starting canopy (yikes!)
[snip!]
> I don't
Actually the 45 degree angle is per Facet's instruction sheet. They
don't explain why -- I'm going to give them a call and ask them about
it.
Regarding the low spot -- I hadn't thought of this. I suppose a quick
drain at the low spot would probably not be a bad idea either....?
Another question (in case I don't get ahold of Facet) -- does anyone
know how many amps this thing draws? The instructions say to use a
16ga wire or greater (!!!) but don't specify amperage. Bob Nuckolls
expressed surprise at this when I asked him, he seemed to think it
would only draw a couple of amps. I am at a loss as to how big a breaker
to put on it.
randall(at)edt.com
To Anyone who Is Interested In This Kind Of Come-On :
Grab your cheeks and spread wide because you are about to get the shaft.
B.Clary
From: | Denny Harjehausen <retflygtiger(at)proaxis.com> |
Subject: | Re: fuel cross tube |
Reasons to think about before making two tanks into one big tank is
a major leak in one tank or separate source in case of a remote possiblity
of contaminates in one tank. This was address in the Rvator a few years
ago. The article had other reasons also that I do not recall now.
Have a good one!
Denny,
RV-6 (R)N641DH
Fuselage-top side
Lebanon, OR
>syntax to use?
>Todd Webb
Todd, I agree. There always some blurb about the Archive, which
would be a great tool if we would follow the suggestion you made.
Have a good one!
Denny,
RV-6 (R)N641DH
Fuselage-top side
Lebanon, OR
>to put on it.
During installation, I put an ammeter on mine. It draws about 1.5A. I used
a 5 amp breaker and ran 22 gauge wire to it. During test runs and taxi
tests the breaker didn't trip.
Hope this helps.
Scott Gesele N506RV (getting close to FAA inspection :))
From: | Rob Hatwell <hatters(at)overvne.demon.co.uk> |
Subject: | Re: Is 210 Degrees Engine Oil Temp To Hot ? |
In message <970902222459_533839307(at)emout11.mail.aol.com>,
aol.com!RVator(at)matronics.com writes
>Steve Schmitz wrote.
IMHO the above are classic symtoms for wire resistance/poor
joint/earthing problems.
If you have used either the airframe or separate wires as the return
i.e. 0V path, you have either a poor joint somewhere or the wire size is
not big enough for the current and it is developing a potential
(voltage) across the resistence on this path. This also applies to the
power side, 12V.
V=IR (voltage=current*resistance)
Each time you switch a device on due to the path resistance
approximately no more current will flow and it will rob power from the
other devices which equates in lower voltage to the other devices which
shows up as a temp change on your oil temp.
I reckon Steve if you measure the supply voltage on the back of the temp
gauge it will alter as you switch each other device on or off especially
the large power items. I would suspect the biggest voltage change would
be the loran (10deg temp change)
Just a point to note: Check the volt drop per length of wire at the amps
you are going to draw for a particular piece of equipment and make sure
the volt drop is acceptable. You might have to go to a larger wire.
My 2d (tupence to the dollar lot) worth
RV8 80274
Rob Hatwell
From: | Sharlene Shipley or Bruce Knoll <snsbfk(at)mail.sage.net> |
WE ARE ALL WAITING FOR THIS FINANCIAL SOLUTION TO ALL OUR
PROBLEMS.
Please send info to the list quickley
Bruce Knoll
all of
already
you can
do it
>> at home!")
won't be
not
an
>--Don
Can we leave the Spam for the newsgroups? If you want to talk get rich
quick, do it on personal e-mail.
Jim Cimino
RV-8 sn 80039
http://www.geocities.com/MotorCity/5771
(717)842-4057
Great idea, Todd.
I hope you don't mind, I put together a possible starting point. It's
probably not a good idea to have too many categories (I think I've got too
many here ...), and adherence could be on a best individual effort basis,
rather than strictly enforced?
August 27, 1997 - September 04, 1997
RV-Archive.digest.vol-dh
