RV-Archive.digest.vol-ef
February 08, 1998 - February 14, 1998
Date: Feb 08, 1998
Subject: Rolling tank trailing edges?
It seems that many RV's tank skins have a scalloping between the screws on the trailing edge, can this not be prevented be rolling the trailing edge down slightly with a dowel (broomstick) so that the skin conforms to the slope of the airfoil? Bernie Kerr RV6A SE FLA working on fuselage ( but tanks are not finished) ________________________________________________________________________________
Date: Feb 08, 1998
Subject: RV IFR
Sam, I would agree that you should make your RV IFR capable. I have flown IFR in my RV-6 many times and could publish another horror story for your Web Page but I'll just give you a few words of caution. I originally tested the RV in IFR during some of the frequent inversions we get in the Salt Lake Valley in the winters. This is not much risk due to the thin layer of the inversion generally 500 to 1000 ft. thick, then severe clear. The other feature is the lack of air movement. This proved fun and gave me a chance to use all that fancy stuff on the panel. Then once I came into SLC International in a real rain storm with low visibility. Not much problem except that with the low wing loading the RV was not as good of IFR Platform as I would have hoped. Later that same month I encountered a situation which caused the canopy to frost over. This was not horribly critical since I could go lower and warm up to defrost. It did however give me cause to think about adding a heated pitot and defrost for that big bubble. Add all the equipment you can afford both in dollars and weight. Enjoy flying and be careful out there. JMP ________________________________________________________________________________
From: "Rick and Barbara Osgood" <randbosgood(at)sprintmail.com>
Subject: Re: Wing skin edge rolling
Date: Feb 08, 1998
>Hi folks, Do I need to roll the edges of the wing skins where they butt >up to each other to prevent the edge from lifing? Thanks, Dave >RV-6A wings Hi Dave... I would recommend rolling them. They will lay flater and have a much cleaner joint between skins. Rick RV6A (working on wings) ________________________________________________________________________________
Subject: RV6A longerons
Date: Feb 08, 1998
boundary="----=_NextPart_000_0043_01BD3470.6B2043A0" This is a multi-part message in MIME format. ------=_NextPart_000_0043_01BD3470.6B2043A0 Can anyone clear up a question for me??? I bought a RV6/6A wing kit and in it was the fuselage longerons of = course. My question is: a) How many total pieces of fuselage longeron or similar pieces should = be in that spar box? b) How long are those pieces? I have: a) 2 14 foot longerons b) 6 12 foot longerons c) 2 10 foot longerons Thanks Rick=20 ------=_NextPart_000_0043_01BD3470.6B2043A0 http-equiv=3DContent-Type>
Can anyone clear up a question for=20 me???
I bought a RV6/6A wing kit and in it = was the=20 fuselage longerons of course. My question is:
a) How many total pieces of fuselage = longeron or=20 similar pieces should be in that spar box?
b) How long are those = pieces?
I have:
a)  2   14 foot=20 longerons
b)  6   12 foot=20 longerons
c)  2   10 foot=20 longerons
Rick
------=_NextPart_000_0043_01BD3470.6B2043A0-- ________________________________________________________________________________
From: "robert dziewiontkoski" <dzflyer(at)email.msn.com>
Subject: Vortex Generators
Date: Feb 08, 1998
I just read a very interesting article RE: Vortex Generators at AVweb.com. Was wondering if any RV builders are using them. If they truly are such a great thing, why aren't they included in EVERY design? Bob ________________________________________________________________________________
Date: Feb 08, 1998
Subject: Pitot-Static System
Is a 24 month re-cert. of the pitot static system required if the aircraft (RV) is VFR only. And is the holder of a repairmans certificate able to do the 24 month or initial certification providing it is for the aircraft he built? -- Abby Razer Barbara Razer Molly the Dog and Chet Razer razer(at)midwest.net http://scribers.midwest.net/razer/ ________________________________________________________________________________
Date: Feb 08, 1998
Subject: Re: IFR RVs
> [extensively trimmed comments regarding planned VFR, with IFR contingency] I just finished my instrument rating in December. Obviously, I'm not an expert, but at least my training is current. Also, I had a talk with a guy last week who related a *very* scary incident regarding a VFR flight into IMC. Neither he nor his aircraft are IFR enabled. My RV *will* be IFR enabled, and I intend to fly it in the same sorts of situations where I would be willing to fly a C-172. That is, my skills are sufficient to climb through a layer or shoot an approach, possibly to minimums (depending on the situation -- minimums at night on an NDB are a lot different for me than day on a glideslope). I'll have a Navaid wing level, the basic IFR instruments, a VOR w/ glideslope and an IFR GPS. I might not have all of them from flight 1, but they'll show up during the first two years. Now, my 2 cents for those who are not planning a full IFR panel: 1. Make sure you have enough instruments that you can keep the wheels pointed to the ground in IMC. You don't need an AI and a DG. 2. Make sure you have enough skill to fly YOUR PLANE with YOUR INSTRUMENTS in IMC. This will require recurrent training if you don't frequently fly IFR. What does this really mean? Well, you don't really *need* the 4 extra instruments -- DG, AI, VSI and turn coordinator. But you better be able to fly in the clouds with what you do install. And you'll need at least an AI or a turn coordinator, and I would take the latter. If you have the navaid wing leveler, you have enough, provided it's reliable and you know how to use it. Get training. Get training. Get some training. My 2 cents... -Joe ________________________________________________________________________________
From: "Steven Spruell" <sspruell(at)idexsystems.com>
Date: Feb 08, 1998
boundary="----=_NextPart_000_000B_01BD3489.814CCD60" Importance: Normal This is a multi-part message in MIME format. ------=_NextPart_000_000B_01BD3489.814CCD60 Rick, The 2 14' pieces are the longerons. Don't cut those. Everything else is reinforcement angle for the spars, ribs and tanks. Steven Spruell RV-6A N316RV (Fuselage) Houston Bay Area RVators http://www.iwl.net/customer/markr/hbar -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Rick and Barbara Osgood Sent: Sunday, February 08, 1998 9:03 AM To: RV-list Subject: RV-List: RV6A longerons Can anyone clear up a question for me??? I bought a RV6/6A wing kit and in it was the fuselage longerons of course. My question is: a) How many total pieces of fuselage longeron or similar pieces should be in that spar box? b) How long are those pieces? I have: a) 2 14 foot longerons b) 6 12 foot longerons c) 2 10 foot longerons Thanks Rick ------=_NextPart_000_000B_01BD3489.814CCD60 http-equiv=3DContent-Type>
Rick,
The 2 14' pieces are the = longerons. =20 Don't cut those.  Everything else is reinforcement angle for the = spars,=20 ribs and tanks.
Steven = Spruell
RV-6A N316RV = (Fuselage)
http://www.iwl.net/custom= er/markr/hbar
-----Original=20 Message-----
From: owner-rv-list-server(at)matronics.com=20 [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Rick = and=20 Barbara Osgood
Sent: Sunday, February 08, 1998 9:03=20 AM
To: RV-list
Subject: RV-List: RV6A=20 longerons
Can anyone clear up a question = for=20 me???
I bought a RV6/6A wing kit and = in it was the=20 fuselage longerons of course. My question is:
a) How many total pieces of = fuselage=20 longeron or similar pieces should be in that spar box?
I have:
Rick
------=_NextPart_000_000B_01BD3489.814CCD60-- ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: RV6A longerons
randbosgood(at)sprintmail.com wrote: > Can anyone clear up a question for me??? > > I bought a RV6/6A wing kit and in it was the fuselage longerons of course. > My question is: > > a) How many total pieces of fuselage longeron or similar pieces should be > in that spar box? > b) How long are those pieces? > > I have: > a) 2 14 foot longerons > b) 6 12 foot longerons > c) 2 10 foot longerons ________________________________________________________________________________ <http://www.geocities.com/CapeCanaveral/Hangar/4809/bunny2a.htm>: The 14'2" pieces of .125" (1/8") angle are the longerons, and are clearly labelled as such. The 10'10" pieces are spare offcuts (25' - 14'2" = 10'10"); despite the label on them, they're not used for the firewall, which is now all precut according to Vans. Cut the bellcrank support angles from one of them. IIRC, the 12' pieces are .063" (1/16") angle, not .125", and used for making spar spreader angles and rib reinforcing angles. Frank. ________________________________________________________________________________
Date: Feb 08, 1998
Subject: used lyc value
Listers, There is an old Piper Apache at the local airport. The owner is considering parting it out rather than selling it outright. He is in the middle of a messy divorce and his wife who is listed on the title refuses to sign off on a sale of the complete aircraft out of spite, but he does have permission from the court to sell it in parts. The airplane has not flown since Oct 97. When annualed at this time it was found to need an AD on the carbs, and possibly on the oil pumps, and props as well. The owner hasnt done this and the plane has sat un-cowled since. The engines are 150hp O-320's carbureted and with conical mount (not sure of exact model as the engines were wrapped in a tarp). Engines are complete with accessories and Hartzell HC-82VL-2C constant speed props. Another twist to this. The original logs were lost in a bankruptcy sale of the aircraft in 1990, so it has new logs that were started as of that time, with a sworn affadavit added to attest to time since overhaul and compliance with AD's. The current owner claims 1185 hours since overhaul based on this affadavit. This also explains the confusion about whether or not all AD's have really been complied with. My questions are, will the prop work on my RV, and what should this engine prop combo be worth? The owner has no idea what price to put on this stuff and frankly neither do I. If I can get further info I will post it here, and of course if others are interested, I will only be needing one of these so perhaps the other one could help someone else on the list if the deal is right. Mike Wills RV-4(fuse on order) willsm(at)manta.nosc.mil ________________________________________________________________________________
Date: Feb 08, 1998
Subject: Re: Certification (Flying)
Forgive my ignorance but this thread brings up a question. I expect that when my RV is completed that it will be far more capable as an airplane than I am as a pilot. Part of the reason for my choice of an RV was to have an airplane I can grow with. I'm not sure that I will be capable/confident in my abilities as a pilot to test all the capabilities of the airplane during the test phase. Does this mean that if, at some point after my test period is complete and my skills grow, that I cant do these more advanced manuevers, and that there is no way to revise the operating limitations of the airplane? Mike Wills RV-4 (fuse on order) willsm(at)manta.nosc.mil > >If you are finished with your test flight hours but want to, say, test it >further doing spins because those weren't done in the initial test period, >you are restricted once again to your test area for that flight testing. >Michael >RV-4 N232 Suzie Q >Flying (expanding the envelope) ________________________________________________________________________________
Date: Feb 08, 1998
Subject: Re: IFR RVs and Gyros
On Sun, 8 Feb 1998, Joe Larson wrote: [much snippage] > > Now, my 2 cents for those who are not planning a full IFR panel: > > 1. Make sure you have enough instruments that you can keep the wheels pointed > to the ground in IMC. You don't need an AI and a DG. > > 2. Make sure you have enough skill to fly YOUR PLANE with YOUR INSTRUMENTS > in IMC. This will require recurrent training if you don't frequently > fly IFR. > > What does this really mean? Well, you don't really *need* the 4 extra > instruments -- DG, AI, VSI and turn coordinator. But you better be able > to fly in the clouds with what you do install. And you'll need at least > an AI or a turn coordinator, and I would take the latter. I'm a strictly VFR pilot, occasionally night, so had been planing to maybe put in only one gyro for "just in case". Because of statements like this, and others (more resistant to acro, cheaper, no vacum system) was thinking to have a turn cordinator. However, had an experience the other day that caused me to rethink a little. Was in a 172, in medium to severe turbulance (downwind of mountains). The turn cordinator was bouncing stop to stop, would never have been able to stay right side up by reference to it, but the AI was solid as a rock, only moving when the actual attitude changed. Is this typical? Maybe some of you guys who fly IFR could comment. Maybe this plane (a rental) just has a bad gyro? Brian Huffaker, DSWL (huffaker(at)utw.com) President and Founder Friends of P-Chan RV-8 80091 Mounting 1st aileron to wing. ________________________________________________________________________________
Date: Feb 08, 1998
The 14 footers - put them in a safe place - you will not use them on the wing. BSivori(at)AOL.COM N929RV ( Reserved ) Wing/Tanks ________________________________________________________________________________
Date: Feb 08, 1998
BIG Snip, all of which I agree with whole heartedly >What does this really mean? Well, you don't really *need* the 4 extra >instruments -- DG, AI, VSI and turn coordinator. But you better be able >to fly in the clouds with what you do install. And you'll need at least >an AI or a turn coordinator, and I would take the latter. > >If you have the navaid wing leveler, you have enough, provided it's >reliable and you know how to use it. > >Get training. Get training. Get some training. > >My 2 cents... > >-Joe Dear Joe, Your comments are very well said and I would strongly second all of them. The turn coodinator is the one and the training to use it is essential. Your .02 is worth millions. May you have many years of fun flying in your RV, even that time in the clouds. Tailwinds, Doug Rozendaal dougr(at)petroblend.com (my old netins.net is no longer valid) www.petroblend.com/dougr ________________________________________________________________________________
Date: Feb 08, 1998
Mike, Your RV will take you from a Student Pilot right through your single engine commercial, however you will need show the Examiner tha you can fly a retractable gear plane with a Constant Speed Propeller. It amounted to two circuits in the pattern with 2 spot landings, I think it was .4 Hours on the hobbs. So have no fear about the airplane your building, I just flew Fred Stucklens RV6A yesterday for the 2nd time in about a month, I own a Seneca but if you want to have fun - The RV is the way to go. It also give you a great shot in the arm as far as the building goes, you just seem to get back into it all over again. Best of Luck BSivori(at)AOL.COM N929RV ( Reserved ) Wings & Tanks Going Strong ________________________________________________________________________________
Date: Feb 08, 1998
Subject: Re: Prop job.
snip >Even though you are "experimenting" with your RV, prudence (and the FAA) >require you to comply with ADs. The one in question in this scenario is: >AD91-14-22. > >This AD deals with any "sudden stoppage", and requires the bolt at the back >of the crank and the pin that drives the accessory gears be replaced after >any "sudden stoppage". snip Putting prudence aside for a moment to clarify a technical point: I was under the impression that you only have to comply with ADs if you want to keep the certified status of the engine intact. Otherwise, it was my understanding that you can remove the lycoming data plate, sacrifice the certified status of the engine, and do whatever you wish with it - including all your own maintenance. Of course, this means that you won't ever be able to sell it to someone for their Cherokee, which is not a big concern of mine. If you decide to keep the lycoming data plate installed, then you are limited to the maintenance items specified in the FARs - which is the same stuff you can do on your production Bugsmasher. I agree with your point though that prudence, common sense, and the desire to live a long and happy life would dictate complying with the ADs... Bruce Stobbe RV-6 control linkages ________________________________________________________________________________
Date: Feb 08, 1998
Subject: Instrument panel design & spacing
Is there a standard or recommended or minimum instrument spacing. Does anyone have full size diagrams of instruments available via the internet for downloading and printing in order to layout and plan the instrument panel design? Bob Haan bobh(at)cdac.com Portland, OR RV6A 24461 Fuse out of jig, working on forward deck ________________________________________________________________________________
Date: Feb 08, 1998
Subject: RV-Chat
Did the RV Chat spot go away or change? Went there on the new page and could not find it ... Thanks JMP ________________________________________________________________________________
Date: Feb 08, 1998
Subject: Re: tank dies
dear listers, what are your opinions on the Cleveland tank dies, is this a must for fuel tanks? or is it just a waste of money? thanks in advance chris marion right wing RV-6a cinci oh ________________________________________________________________________________
Subject: Re: Pitot-Static System
Date: Feb 08, 1998
Chet - Only the certification of the transponder is required every 24 calendar months for VFR. I believe that an altimeter check is included with the transponder work. However, for peace of mind you might want to get your pitot static system checked as well. I don't believe it's that expensive. As a repairman, I don't believe your authorized to certify your transponder. It requires an FAA licensed technician with extremely expensive equipment to do that job. It's not a job that an A&P or IA is allowed to do either unless they have specific authorization. I can't quote the appropriate FAR's off hand. If you have a current copy of FAR-AIM or Part 43.13, you might be able to find it in there. Bill Shaw ________________________________________________________________________________
Date: Feb 08, 1998
From: "Garrett V. Smith" <GARRETTSMITH(at)compuserve.com>
Hi Brian: Regarding your question, Was in a 172, in medium to severe turbulance (downwind of mountains). The turn cordinator was bouncing stop to stop, would never have been able to stay right side up by reference to it, but the AI was solid as a rock, only moving when the actual attitude changed. Is this typical? Maybe Yup, it is typical. The turn coordinator measures the rate of yaw, you can, and should , check this on the ground while you are taxiing out prior to an instrument or night flight. Just ensure that the T.C. is going in the same direction as you are taxiing in, right turn, needle right, left turn, needle left. Turn coordinators generally indicate a rate 1 turn, which is 3 degrees /second, that is when you have the needle or little airplane at the hache mark. The turn coordinator was reacting to the presence of yaw in the above situation, as a result of the turbulence. The attitude indicator shows the aircraft attitude with reference to the horizon and does not indicate yaw, but will show bank angle (obviously). Test this when you are flying by side slipping, along a road for reference, the A.I. will indicate the wing and nose low (watch your airspeed) but the T.C. will not indicate a turn if you side slip without changing direction. Hope this answers your question. Have a good one, Garrett Smith Calgary,Canada ________________________________________________________________________________
Date: Feb 08, 1998
<19980207.172350.3726.0.DavidDLA(at)juno.com>
Dave, Yes, but very lightly so it is barely discernable when the light hits it at the right angle. It is also wise to leave a slight gap between the skin edges ( on the order of .005 ) If the edges are butted tightly together they often bulge upward when rivited, having no place else to go when a slight amount of expansion occurs from riviting close to the edge. Regards, Bill, N66WD _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 08, 1998
Subject: Re: used lyc value
Hi Mike, Those engines are most likely 0-320 dash nothing but equivelant to 0-320A The propellor can be made to work but it is very heavy, much heavier than the Hartzell that Van sells. Another point- it would not fit in the stock RV spinner due to the counterweights, the Apache spinner would have to be used. IMO, this is ugly on an RV. The prop would probably fall under the latest AD out on steel hub Hartzells. Personally, I wouldn't touch it with a fork. The engines are probably OK if you don't mind accepting conical mounts instead of dynafocal. They can be converted to 160HP. I would not pay more than 5K and try to get them for 4K. Hope this helps. Regards, Bill RV4 N66WD _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 08, 1998
Subject: IFR RVs and the FARs
Thanks to all who responded to my inquiry concerning equipping our RVs for IFR flight. After consulting the FARs, here is what I have been able to determine. This is not conclusive, as I still have some questions about how Experimental registered aircraft fit into the overall scheme of things. FAA Advisory Circular 20-27D, Certification and operation of Amateur-Built Aircraft, section 14, A, 5: "Depending on the intended operation under FAR Part 91, the following FAR sections may be applicable: c. FAR section 91.205, Instrument Flight Rules." Notice the word "may". What does this mean in the real world? FAR 91.205, Powered civil aircraft with standard category U.S. airworthiness certificates: Instrument and equipment requirements. d) Instrument flight rules. For IFR flight, the following instruments and equipment are required: 1) (paraphrasing) all instruments required for day and night VFR flight. 2) Two-way radio communication and navigation equipment appropriate to the ground facilities to be used. 3) gyroscopic rate-of-turn 4) slip-skid indicator 5) sensitive altimeter 6) Clock 7) artificial horizon 8) directional gyro I have paraphrased some of the above lines for brevity. This leaves the following for additional consideration by the individual pilot: 1) How many com and nav radios are sufficient for redundancy? 2) DME (required only for flight above 24,000' (leaves me out!) 3) Does the Navaid control unit satisfy FARs for a "gyroscopic rate-of-turn indicator? 4) Heated pitot tube 5) Which nav system to install; GPS, VOR, Loran, ADF... 6) Certain equipment must be operational to fly ILS approaches to the lowest minimums. Oh well, this shows what the VFR-only guys DON'T have to worry about! Sam Buchanan (still pndering) sbuc(at)traveller.com "The RV Journal" http://www.ath.tis.net/~sbuc/rv6 ________________________________________________________________________________
Date: Feb 08, 1998
Subject: RV-6 Seat Rib Question
To all that have gone before me. Disclaimer: I have searched the Archives and while the problem is mentioned there was no definitive answer. Today I got to the point that it was time to install the seat ribs between bulkheads f-604 and f-605. When installing the f-616, 617,618,619 seat ribs I noticed that the forward flange is not at the correct angle and wants to impart a twist to the f-604 web. I have again verified the tilt in the f-604 bulkhead and found no problems. The heights of the bulkheads from the longhorn are also correct. In Frank J's supplement he mentions modifying the forward flange of the seat ribs so that the f-604 will not twist. Why do I have this Problem? If I modify the forward flange, can I flatten the flange out and rebend it? Or, should I cut it off and rivet a new flange on? I like the new flange option. One more question. View F-F` on dwg 33 shows how the f-619 rib is spit in half. It also shows a huge notch in the bottom of the rib to clear the spice plate. My ribs came with a smaller notch already in them. Do I need to enlarge the notch or is the factory notch enough? Thanks in advance. Gary Zilik RV-6A S/N 22993 Pondering over fuselage problems. ________________________________________________________________________________
Date: Feb 08, 1998
writes: (Snip) >The turn coordinator was bouncing stop to stop, would never have been able >to stay right side up by reference to it, but the AI was solid as a rock, >only moving when the actual attitude changed. Is this typical? Maybe >some of you guys who fly IFR could comment. Maybe this plane (a rental) >just has a bad gyro? > > Brian Huffaker, DSWL (huffaker(at)utw.com) > President and Founder Friends of P-Chan > RV-8 80091 Mounting 1st aileron to wing. Hi All, Kent Rockwell (IFR rated) had a turn coordinator in his RV-3, and replaced it with a Turn & Bank Indicator. The little airplane on the Turn coordinator is coupled in yaw and roll axis, the needle on the T&B just "sees" the yaw axis. Just my .02 Jim Ayers Less_Drag(at)juno.com _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 08, 1998
chris marion wrote: > > > dear listers, > what are your opinions on the Cleveland tank dies, is this a must for > fuel tanks? or is it just a waste of money? > thanks in advance > chris marion > right wing RV-6a > cinci oh > Chris If I had to do it over agian, I would get the dies....They do make a difference. Craig Hiers RV-4 N143CH Tallahassee,FL. ________________________________________________________________________________
Date: Feb 08, 1998
From: Unistar Computers <unistar(at)mindspring.com>
<3.0.5.32.19980208182202.0079e760(at)mail.weblabs.com> >My A+P told me you only have to check the crank runout with a >dial indicator, not pull the engine apart and send it off, unless >it shows the crank to be out of tolerance after the strike. >Several people I have talked to that have certified engines on >their planes, who have had prop strikes with wood props said >their engines showed no damage at all (after use of dial >indicator) and never were torn apart. So, is someone telling me >I have to tear the engine apart and send the crank off to keep it >certified, even if the dial indicator shows no out of true >condition? Does anyone know the accepted tolerance? I would >like to know myself so when the mechanic does it I'll know what >he is telling me, too. Thanks. >Michael Michael, I advised that the AD 91-14-22 was applicable in your situation. It does NOT require removal of the crank, nor is it about bent flanges. It is about damage to the accessory gear drive which runs your magnetos and oil pump. It is applicable to all O-320s and O-360s except the "76" series engines line O-320H2AD... Quoting from the AD: Compliance: Required at each engine overhaul, after a prop strike, sudden stoppage, or whenever gear train repair is required. A propeller strike for the purpose of this AD, is defined as a sudden engine stoppage, or loss of a propeller tip. To prevent loosening or failure of the crankshaft gear retaining bolt, which may cause sudden engine failure, accomplish the following: ----------End Quote------------- So if you have a data plate on your engine, then you *MUST* comply with this AD. If you have removed your data plate, and surrendered it and the official Lycoming log book to the FSDO, then you may feel free to not bother with this inspection. Please don't fly over my house if the latter condition is true. If your A&P doesn't know about this AD, then he must be pretty green. Go to an IA, and get a copy of the AD, read it for yourself. Bob Steward, A&P IA AA-1B N8978L AA-5A N1976L ________________________________________________________________________________
Subject: Re: Rolling tank trailing edges?
<19980208.210655.10686.1.rvpilot(at)juno.com>
Date: Feb 08, 1998
> >Bernie, Those skins seem to lay down better if the # 8 dimples are >set rather >firmly with the avery "C" tool rather than using a hand squeezer. Any >final waviness can be cured by bending down between the screw holes. >Regards, Bill N66WD Thanks Bill, That was the other thing I ment to mention in my post but forgot. Give it a couple of good hammer wacks to get a cleanly formed dimple on the .032 Scott McDaniels RV-6A N64SD 560+ Hrs. These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 08, 1998
> My questions are, will the prop work on my RV, and what should this >engine >prop combo be worth? I know of at least one RV-4 that used an apache engine and prop. I believe the prop can't use the standard spinner. It had a very unusual look with that apache spinner mounted up front (my opinion). Scott McDaniels RV-6A N64SD 560+ Hrs. These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 08, 1998
if you dont use them youll have to grind down to tops of the rivets a few thousandths. -- Abby Razer Barbara Razer Molly the Dog and Chet Razer razer(at)midwest.net http://scribers.midwest.net/razer/ ________________________________________________________________________________
Date: Feb 07, 1998
Subject: Re: Flying
I do not wish to enter a urining contest regarding FARs; however would like to offer some two cents worth on flight testing, which I feel is much misunderstood. In the case of van's RV series I personally think it is an excellent idea to test under high g loads fairly early in the test period, after making sure you are under the "aerobatic weight" as I did. I did not do this because I thought the FAA required it or because I enjoy doing high G manuevers. Far from it. My hemmorhoids got all the Gs they needed thirty years ago, and I am not looking to wear out my beautiful airplane early. Here is why I think it is a good idea: This is not to check to see if the wings come apart! I have no doubts whatsover about the primary structure of the plane which has been shown to be good if built to plans. What is not covered in the plans or in Van's tests, is the individual mounting of many components in your custom installation, such as radios, instruments, firewall items, etc., etc. If you have not properly designed or installed anything this is the time to discover if it is going to come loose, or otherwise fail. Even if you don't intend to ever exceed two Gs, the plane is capable of easily generating 6Gs at any speed about 134MPH, and someday you may need it. I have come within a whisker of 4 Gs while dodging student entries in the traffic pattern. This is my opinion and why I hold it. I have no claim to FAA knowledge or experience with which to try to match any one else. D Walsh RV-6A ________________________________________________________________________________
Date: Feb 08, 1998
> >It seems that many RV's tank skins have a scalloping between the >screws on the >trailing edge, can this not be prevented be rolling the trailing edge >down >slightly with a dowel (broomstick) so that the skin conforms to the >slope of >the airfoil? > >Bernie Kerr RV6A SE FLA working on fuselage ( but tanks are not >finished) > > > Most of the scalloping is caused by the deformations that result from making such large dimples (#8 screws) in the .032 tank skins. What I prefer to do is wait until the tank is completed with all the screw hole dimpling done. Then using your thumbs and fingers put a small curve in the skin between each screw hole. You are trying to make the skin have a scalloped condition that is the reverse of what you described so that when the screws pull the dimples down tight. there is a preload on the portion of the skin that is between the holes which then holds it down tight. You can work on the tank and then install it with clecos to check it. Remove and do some more where necessary. The area on RV-6/6A and RV-4 tanks near the root that has no screws along the edge you can also work a gentle curve into the skin with your hands to give it a preload and make it lay down tight. Scott McDaniels RV-6A N64SD 560+ Hrs. These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 08, 1998
Subject: Re: RV-6 Seat Rib Question
> Today I got to the point that it was time to install the seat ribs > between bulkheads f-604 and f-605. When installing the f-616, > 617,618,619 seat ribs I noticed that the forward flange is not at the > correct angle and wants to impart a twist to the f-604 web. I have again > verified the tilt in the f-604 bulkhead and found no problems. The > heights of the bulkheads from the longhorn are also correct. In Frank > J's supplement he mentions modifying the forward flange of the seat ribs > so that the f-604 will not twist. Gary, Use caution here - be sure to quadruple check the angle of the bulkhead. Use alternate methods such as a plumb line and trigonometry to verify the correct bulkhead angle. Maybe I got lucky, but my seat ribs exactly matched the proper angle. The baggage ribs were too long, but that is another story... > If I modify the forward flange, can I flatten the flange out and rebend > it? Or, should I cut it off and rivet a new flange on? I like the new > flange option. I agree that new flanges are better than modifying old ones. I've used 063 angle for this. Alex Peterson 6A slider canopy slowed down for basement project... Maple Grove, MN ________________________________________________________________________________
Date: Feb 08, 1998
Michael, your A&P can only advise you, he cannot force you to tear your engine down. I would be careful about entering prop strike info in your logbooks also. If after he dials it out he wants to pull the engine down I would get some more opinions first. Frankly, If I understand the situation, I would dial the engine and if it is within limits I might want to forget the whole sorry incident. If something is entered in the books I would put it as incidental to other maintenence that the crank was dialed and found to be witin limits and no more. You are the Repairman for your aircraft so it is you that has the final say. However, I believe to maintain your engines certified status all work above preventive main. must be done by and signed by an A&P. JR A&P, plain and simple works best. ________________________________________________________________________________
Date: Feb 08, 1998
>Hi Brian: > >Regarding your question, > >Was in a 172, in medium to severe turbulance (downwind of mountains). >The turn cordinator was bouncing stop to stop, would never have been >able >to stay right side up by reference to it, but the AI was solid as a >rock, >only moving when the actual attitude changed. Is this typical? Maybe > >Yup, it is typical. >The turn coordinator measures the rate of yaw, you can, and should , >check >this on the ground while you are taxiing out prior to an instrument or >night flight. Just ensure that the T.C. is going in the same direction >as >you are taxiing in, right turn, needle >right, left turn, needle left. Turn coordinators generally indicate a >rate >1 turn, which is 3 degrees /second, that is when you have the needle >or >little airplane at the hache mark. The turn coordinator was reacting >to the >presence of yaw in the above situation, as a result of the turbulence. > >The attitude indicator shows the aircraft attitude with reference to >the >horizon and does not indicate yaw, but will show bank angle >(obviously). Test this when you are flying by side slipping, along a >road >for reference, the A.I. will indicate the wing and nose low >(watch your airspeed) but the T.C. will not indicate a turn if you >side >slip without changing direction. > >Hope this answers your question. > >Have a good one, > >Garrett Smith >Calgary,Canada > > > >From my understanding everything you said is correct except implying the instrument having a needle that swings left or right. I believe this would be what is referred to as a turn and bank which is not the same as a turn coordinator. I think a turn and bank shows indication of movement in roll. Compared to the T.C which indicates movement in Yaw and I believe a certain amount of roll factored in. Can anyone comment further? Scott McDaniels RV-6A N64SD 560+ Hrs. These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
<34DE63F6.ABB6E1CC(at)datastar.net>
Date: Feb 08, 1998
writes: > >My A+P told me you only have to check the crank runout with a >dial indicator, not pull the engine apart and send it off, unless >it shows the crank to be out of tolerance after the strike. >Several people I have talked to that have certified engines on >their planes, who have had prop strikes with wood props said >their engines showed no damage at all (after use of dial >indicator) and never were torn apart. So, is someone telling me >I have to tear the engine apart and send the crank off to keep it >certified, even if the dial indicator shows no out of true >condition? Does anyone know the accepted tolerance? I would >like to know myself so when the mechanic does it I'll know what >he is telling me, too. Thanks. >Michael > > > > A common misconception is that the only damage that a crank shaft occurs from a prop. strike is a bent crankshaft flange. The possible hidden damage is what often is over looked. When an engine is running fast and the prop suddenly stops, the inertia of the crank shaft, and the accessories that are being driven by it, attempt to keep the crank shaft turning. This puts a major twisting load on the crank which can cause internal stress fractures. Not to mention the loads it puts on the accessory gears and such, on the back of the engine when everything comes banging to an instant stop. It is for this reason that a tear down and full crank inspection is required for a sudden stop. There have been instances of crank failures even though the crank flange dialed perfectly (Lycoming cranks are pretty tough). I think it is doubtful that you got the type of sudden stoppage with the wooden prop that is a factor in this type of scenario. IMO with the wood prop. I think it is a lot more likely that you caused some internal damage (or to magnetos, etc.) than it is that you bent the crankshaft flange. If you only got 4 inches or so of each blade, and the engine kept running My gut feeling is that you are probably ok, BUT if you follow the recommendations of Lycoming this incident would probably warrant a tear down. _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 09, 1998
<> I just spent the last couple of days installing my seat ribs & the forward flanges line up perfectly with the 604. Even the 606 bulkhead came out level when installing the baggage compartment floor ribs. I can't think of anything unless your top to bottom 606 measurements are reversed. I also looked at the notches in the 619's & determined, but not positive, these were for clearance for nuts. Will modify later if needed. Larry A. --- RV6A 180 HP CS prop ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: Vortex Generators
<< If they truly are such a great thing, why aren't they included in EVERY design? >> -GV ________________________________________________________________________________
Date: Feb 09, 1998
Subject: RV-6A Tow Bars
About time to get our build a tow bar for the -6A. Before I tackle this job, designing, buying material and fabricating at least three of them, any advice? Is there a Cessna bar that adapts with only minor mods? Any thing out there, in the Hardware store that provides a good head start? Any reasonable priced bars for sale among the builders? Folding handle, plug in handle, aluminum, steel ?? Bruce Patton (Just finished sanding all the fiberglass parts, ready for paint. Need to move things around so I can get the Glider in the shop for its annual two weeks, and then start building the Spray Booth!) ________________________________________________________________________________
Date: Feb 08, 1998
robert dziewiontkoski wrote: > > > I just read a very interesting article RE: Vortex Generators at AVweb.com. > Bob There is a person with an RV6 that is testing the "Vortec Generators" as we speak. He is compyling data to determine if they make any significant peformance inprovements to the Rv. I spoke to him last week and it looks good so far. I plan to use them if it turns out they warrant the cost I'll let you know soon. Don ________________________________________________________________________________
Date: Feb 08, 1998
--------------0F1CAD71F478A05F929BE54B Rick and Barbara Osgood wrote: > Can anyone clear up a question for me??? I bought a RV6/6A wing kit > and in it was the fuselage longerons of course. My question is: a) How > many total pieces of fuselage longeron or similar pieces should be in > that spar box?b) How long are those pieces? I have:a) 2 14 foot > longeronsb) 6 12 foot longeronsc) 2 10 foot longerons ThanksRick I asked 'Vans support 'this identical question this week[phone] they told me they didn't have any idea of what was needed as there were several different ways the kit was configured over the years.They said just don't use the .125 angle as that was needed for the Fuselage.Also just go ahead and use what was needed of the .060 angle for the wing construction and that there was nothing of the .060 angle over 3 ft pieces needed in the fuselage! Guess this doesn't answer your question ,neither did it answer mine! Derek Reed OR RV6A --------------0F1CAD71F478A05F929BE54B Rick and Barbara Osgood wrote:
 Can anyone clear up a question for me??? I bought a RV6/6A wing kit and in it was the fuselage longerons of course. My question is: a) How many total pieces of fuselage longeron or similar pieces should be in that spar box?b) How long are those pieces? I have:a)  2   14 foot longeronsb)  6   12 foot longeronsc)  2   10 foot longerons ThanksRick
Derek Reed OR  RV6A --------------0F1CAD71F478A05F929BE54B-- ________________________________________________________________________________
Date: Feb 08, 1998
Craig Hiers wrote: > > > > > what are your opinions on the Cleveland tank dies, is this a must > for > > fuel tanks? or is it just a waste of money? What are 'Tank Dies',what do they do? Derek Reed OR RV6A ________________________________________________________________________________
Date: Feb 09, 1998
From: jharmstrong(at)attmail.com (Jack H Armstrong)
Phone: 540-338-7715
Subject: Willing to help (want to learn)
Folks, As a new pilot, new member to the list and an RV wannabe, I would like to offer my help in exchange for some experience with RV's. I will be in San Fran/Livermore area on business from Feb 9-20, and most of my free time will be on the weekend. From looking at some of the postings, it appears that there is an active contingent of RV builders in the SF/Livermore area and I would love to use the weekend "learning RV". Please reply to: jharmstrong(at)mail.att.net Thanks in advance, Jack Jack Armstrong N3005X Hamilton, Virginia ________________________________________________________________________________
Date: Feb 09, 1998
I ordered a set of Tank Dimple diew from Avery - What I think I got was another set of 3/32 Dimple Dies. Bill ________________________________________________________________________________
Date: Feb 09, 1998
<< I noticed that the forward flange is not at the correct angle and wants to impart a twist to the f-604 web. I have again verified the tilt in the f-604 bulkhead and found no problems >> I to am just installing the seat ribs. There is not a problem with the angle on the ends of the ribs on our kit, so would be very suspicious that something is not yet in the correct position. If the the 605 is vertical and the heights from the jig face are correct, it must be the angle. Check that the firewall is vertical and redo the measurements to 604. If that doesn't work get another pair of eyes to look at it. Often that works for me ,because I am assuming something that should'nt be assumed,etc. A mistake I just made is when lining up the seat ribs for drilling to the 605 BH, I clamped the both the horizontal flanges to the flange on 605 and the ribs end up not really faired for the bottom skin because of the steep angle of the cockpit floor. Should have just clamped the rib so that the bottom skin was faired when drilling. Sorry for the long winded post Bernie Kerr ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Left elevator skeleton rivets
My RV-8 prints seem vague on the type, size and number of rivets to be used to attach the E-605 inner elevator rib to the E-606 sub spar. I would ASSume that 2 AN470AD4-4 rivets should be used. Is this correct? Does anyone have suggestions regarding drilling these 2 parts together? I wish to avoid introducing a twist in the elevator and/or trim tab alignment to the elevator. Charlie Kuss RV-8 getting off my dead as*, the wings should be here soon. :-) Boca Raton, Fl. ________________________________________________________________________________
Date: Feb 09, 1998
Michael; My Lyc. Direct drive overhaul manual on page 1-3, Service table of limits, Part 1 Direct drive engines, Section 1 Crankcase, Crankshaft, Camshaft. Ref. new 508, ref. old, 607. Chart -All, Nomenclature -Crankshaft Prop. Flange Run-out. Clearances Mfg. Min& Max.-.002. Serv. Max.- .005 I would take it that on a runout dial, your max limit is .005. Good luck on the reading. John C Darby Jr. RV6 N61764 sold Stephenville TX -----Original Message----- From: Michael C. Lott <lottmc(at)datastar.net> Date: Sunday, February 08, 1998 22:01 Subject: Re: RV-List: Prop job. >condition? Does anyone know the accepted tolerance? I would >like to know myself so when the mechanic does it I'll know what >he is telling me, too. Thanks. >Michael ________________________________________________________________________________
Subject: Re: Flying
Date: Feb 09, 1998
Jerry, Good answer. How would you test the negative G limit??? Bob ---------- > From: Jerry Springer <jsflyrv(at)ix.netcom.com> > Well Gil normally I have alot of respect for what you say, but your > are putting your own interpretation on this one. > They don't say fly the airplane to the design g limits. ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: Instrument panel design & spacing
Check out www.panelplanner.com They have a panel planning software that is EXCELLENT! It has a very large database (virtually any kind of instrument you can imaging) of equipment that you can place on templates for panels. (including RV's) It will calculate weight, price, amps, and even allow you to export the file to autocad, so that you can have a computerized machine shop cut your panel. Highly reccommended for about $100 > >Is there a standard or recommended or minimum instrument spacing. > >Does anyone have full size diagrams of instruments available via the >internet for downloading and printing in order to layout and plan the >instrument panel design? > >Bob Haan >bobh(at)cdac.com >Portland, OR >RV6A 24461 Fuse out of jig, working on forward deck > > > > > ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: Veriprime
Why don't you guys using Variprime just call DuPont and ask??? DuPont - Customer Services - 800-338-7668 -Jeff RV-8 #80563 Suwanee, GA > >>The label has the following statement: >> >>615S Variprime Self-Etching Primer, Variprime is a two component, fast >drying, >>self-etching enamel primer with excellent corrosion resistance for >refinishing >>passenger cars or commercial vehicles with any topcoats. To be used only >with >>616S variprime converter. > > >I just looked at my brand new can of Veriprime, and this statement is >absolutely, positively, NOT on it. Perhaps it's on some sort of additional >data sheet that you may have obtained, or they have more than one version of >the label. Of course it does say "Not for sale or use by the general >public". I guess that means I didn't really buy it, and I certainly can't >use it :-) > >Rusty > > > > > > > ________________________________________________________________________________
Subject: RV6 Longerons
Date: Feb 09, 1998
boundary="----=_NextPart_000_001F_01BD3533.E0D372C0" This is a multi-part message in MIME format. ------=_NextPart_000_001F_01BD3533.E0D372C0 Thanks to all who answered my (extra lengths) of longerons. As I sum it = up, I only need the 2 14' pieces and the rest are up for whatever I need. As I calculate = this out... I have about 65 feet of angle I dont need.... Maybe a garage sale is in order 8>) Thanks Rick ------=_NextPart_000_001F_01BD3533.E0D372C0 http-equiv=3DContent-Type>
Thanks to all who answered my (extra = lengths) of=20 longerons. As I sum it up, I only need the
2 14' pieces and the rest are up for = whatever I=20 need. As I calculate this out... I have about 65 feet
of angle I dont need.... Maybe a = garage sale is=20 in order 8>)
Rick
------=_NextPart_000_001F_01BD3533.E0D372C0-- ________________________________________________________________________________
Date: Feb 09, 1998
I used three AN470AD4-4s. I used a 12 inch #30 drill to drill the holes while the horizontal stabilizer was in the jig. You will still go in a bit at an angle, but with a 12inch drill the angle will be very slight. I put three in mostly to be able to cleco the center hole and rivet the two sides. I just decided to put a rivet in that center hole rather than leave it for ventilation?? Gary -----Original Message----- From: Charlie Kuss [SMTP:chaskuss(at)miami.gdi.net] Sent: Monday, February 09, 1998 8:23 AM To: smcdaniels(at)Juno.com Cc: rv-list(at)matronics.com Subject: RV-List: Left elevator skeleton rivets My RV-8 prints seem vague on the type, size and number of rivets to be used to attach the E-605 inner elevator rib to the E-606 sub spar. I would ASSume that 2 AN470AD4-4 rivets should be used. Is this correct? Does anyone have suggestions regarding drilling these 2 parts together? I wish to avoid introducing a twist in the elevator and/or trim tab alignment to the elevator. Charlie Kuss RV-8 getting off my dead as*, the wings should be here soon. :-) Boca Raton, Fl. ________________________________________________________________________________
Subject: Re: IFR RVs and the FARs
Date: Feb 09, 1998
RV-List message posted by: Sam Buchanan After consulting the FARs, here is what I have been able to determine. This is not conclusive, as I still have some questions about how Experimental registered aircraft fit into the overall scheme of things. FAA Advisory Circular 20-27D, Certification and operation of Amateur-Built Aircraft, section 14, A, 5: "Depending on the intended operation under FAR Part 91, the following FAR sections may be applicable: c. FAR section 91.205, Instrument Flight Rules." Notice the word "may". What does this mean in the real world? - Depends on what IFR facilities you plan to use. In any evernt, you know the FAA, they LOVE AMBIGUITY!!! It in polite terms is called, CTA (covering their ass!!!) FAR 91.205, Powered civil aircraft with standard category U.S. airworthiness certificates: Instrument and equipment requirements. d) Instrument flight rules. For IFR flight, the following instruments and equipment are required: 1) (paraphrasing) all instruments required for day and night VFR flight. 2) Two-way radio communication and navigation equipment appropriate to the ground facilities to be used. 3) gyroscopic rate-of-turn 4) slip-skid indicator 5) sensitive altimeter 6) Clock 7) artificial horizon 8) directional gyro I have paraphrased some of the above lines for brevity. This leaves the following for additional consideration by the individual pilot: 1) How many com and nav radios are sufficient for redundancy? Only required to have one-two are nice! particularly if you're on an ILS approach and the glideslope goes belly up-but then, you could make a Localizer approach. 2) DME (required only for flight above 24,000' (leaves me out!) These are required on VOR-A approaches, which only get you to the airport vicinity and it's visual from there or a missed approach 3) Does the Navaid control unit satisfy FARs for a "gyroscopic rate-of-turn indicator? If memory serves, I believe it replaces the Turn Coordinator 4) Heated pitot tube - Nice in clouds in near freezing temps 5) Which nav system to install; GPS, VOR, Loran, ADF... You may want to consider installing more than one e.g., VOR and glideslope combination is available in one indicator, IFRcert GPS is nice but expensive, ADF is still functioning but is in the process of being phased out and is more difficult to fly in a crosswind situation, the Loran is kind of up-in-the-air at the moment, it may or may not survive the current flap about so-called outdated systems. In addition, many marine interests have depended upon Loran for navigation but there going to GPS as well. I think I would hang on to the ILS for precision approaches for the forseeable future until the problems with GPS get sorted out. 6) Certain equipment must be operational to fly ILS approaches to the lowest minimums. - Excluding Category I and Cat II approaches which require that both aircraft and pilot be certified for these approaches, you need glideslope receiver, marker beacon receiver, and a two-way radio, of course. Oh well, this shows what the VFR-only guys DON'T have to worry about! Sam Buchanan (still pndering) sbuc(at)traveller.com I can't remember if you said you were IFR rated or not. In any event, I hope this doesn't come over as speaking down to you! Secondly, this may not be an all-inclusive listing as I am a low-time instrument pilot myself! Hope this helps Bill Shaw "The RV Journal" http://www.ath.tis.net/~sbuc/rv6 ________________________________________________________________________________ rv-list
Subject: F683 console assembly
Date: Feb 09, 1998
I've been looking at and prepping for installing the console in my -6A. Per the manual, the F683A attaches to the seat floors and seems to do it via an overlap of the F683A over the seat floor skins. Then, the F683Bs attach to the F683A to most likely give it plenty of strength. 1. Are the F683Bs riveted to the F683A? Per the drawings, I'm led to believe they are. 2. If #1 is true, how in the world do you get the floors out when you need to to an inspection? The seat floors have wide flanges that would get in the way of things and pretty much require lifting them straight up when initially removing them from the floor. If the F683 is in the way, there is no way to lift them up without having all kinds of problems, if it can be done. Unfortunately, the plans leave this area much to one's imagination. Any help is greatly appreciated. I did find one picture from my "14 Years of the RVator" book that helped some; but, it only gave a clue to the placement. George Orndorff used an angle on the front of his instead of using the overlap. In fact, he may not have used the F683Bs since he used the angles. Not sure on that point. Jim Sears RV-6A #22220 ( Puzzled!) ________________________________________________________________________________
Date: Feb 09, 1998
From: "VanArtsdalen, Scott" <scott.vanartsdalen(at)lmco.com>
Subject: Re: Wiring Tip
Absolutely, this is almost exactly what I was taught in the wire-wrap and crimp class at Lockheed. That blunt stick would be an orange wood stick if you can find them but if you can't a shishkabob skewr should do. ---------- From: Robert L. Nuckolls, III[SMTP:nuckolls(at)aeroelectric.com] Reply To: rv-list(at)matronics.com Sent: Thursday, February 05, 1998 4:31 AM To: rv-list(at)matronics.com Subject: RV-List: Re: Wiring Tip > >I just thought I'd pass this information along to those of you who are >beginning to wire your birds and using shielded cable. I have had three >wiring glitches the last of which was a dead right mag and all three >were attributed to the same problem. > >During initial wiring, after removing the outer jacket from the ends of >shielded cable I simply pulled braided shielding back and installed my >crimp connectors on the conductor wire and shielding. After time, >vibration caused the shielding to "creep" back toward and inside the >crimp connector of the conductor and grounded it (not good). As I >mentioned the last instance grounded my right mag and it bacame non >functional, fortunately it was found during a ground run-up. Try this for keeping all the braided shield wires out of harming ways . . . (1) Put 1" piece of 3/16" heatshrink over end of wire to be terminated. (2) Remove outer insulation to expose shield braid approx 1" from end of wire. (3) Push shield braid back slightly so as to "bunch" it up a bit right at the end of the outer insulation jacket. (4) Bend braid and internal conductors over right at the end of the outer jacket to make a "J" shape on end of wire. (5) Use blunted pick to tease an opening into the side of the shield braid exposing the wires within. (6) Use the pick to get under the wires and pull them out through the opening. (7) Pull the shield braid back out straight and twist the ends just slightly to take care of the "fuzzies" at the end. (8) Put piece of 3/16" heatshrink over shield braid leaving approx 3/16" exposed. Shrink down. Install PIDG or similar terminal on end of braid. (8) Install PIDG or similar terminal on center conductor(s). (9) Slide heat shrink from step (1) so that 1/3 of it's length is past end of shielded wire's outer jacket and shrink in place. This technique prevents damage to center conductor insulation since only standard strip-and-terminate operations are carried out. "Fuzzies" from stray shield braid are corraled because there's no attempt to "unbraid" or comb out the strands in an effort to make the center conductor accesable. ALL conductors are ultimately covered with insulation exposing only the portion of the terminals necessary for connection. Bob . . . AeroElectric Connection //// (o o) ==========o00o=(_)=o00o========== < If you do, > < What you've always done, > < You will be, > < What you've always been. > ================================= <http://www.aeroelectric.com> ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: RV8/rudder/K-1000-6
>> >>Hello, >>Is it permissible to enlarge the holes in the K-1000-6 plate nut to >>accept >>a -5 rivet instead of the -4? >> >>This particular plate nut is at the bottom of the spar at the >>intersection >>of R410, R405PD and spar. >> >>Regards, >>Vince Himsl >>RV8 rudder >> >> >> >I think it should be ok. The main strength of the rod end (hinge) >bearing to the spar is the fact that the spar is trapped between the nut >plate and the jamb nut. The rivets just hold the plate nut (and >partially the rib) in place. >Why do you need to do this? > > >Scott McDaniels RV-6A N64SD 560+ Hrs. >These opinions and ideas are my own >and do not necessarily reflect the opinions >of my employer. > >Why do you need to do this? ANS: I Riveted the rib to the spar before attaching the R410 brace. Upon removal of rivets to get at the R410 the hole to K-1000-6 plate nut become enlarged such that I couldn't meet min diameter spec on the shop head of the -4 rivet. My choices are either to go with out of spec -4 in enlarged hole or move up to a -5 rivet. I am tempted to go with the -4 in this case as it is non critical...I think. Regards, Vince Himsl RV8 rudder ________________________________________________________________________________
Date: Feb 09, 1998
The old paint and body guys in the room are chuckling, if only it was that easy. >> This is a very clear statement that Variprime is a primer to be used with any topcoat. What part of that statement is un-clear to you? <<< >> Most of us try to post accurate information to the RV-List to help other builders,......... Curtis Hinkley RV8 ________________________________________________________________________________
Date: Feb 09, 1998
Subject: RV-8 Tank Skins
Hi Von, I had the same problem on my 6 tanks. A combination of moving the ratchet straps to the bottom side so that it was pulling the skin toward the bottom, and starting to ratchet the skins toward the bottom with the skins sitting with about a 1/2 inch bias toward the bottom seemed to help. >>Listers; I am installing the left tank skin and am having a heck of a time getting the skins to meet up with the lower main skin on the other side. << on the wings as Vans has already done for us. I do not think that G testing is a reqired manuever such as stalls or turns.There is no performance range here only whether the wings stay on or fall off. No new manuevers would be allowed by doing this. Most people would be unsafe pulling 6g. Lets be safe while doing uor flight testing. ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Rolling tank trailing edges?
Hi Bernie, I rolled mine exactly as you describe. It does lat flat along the spar, however it still has that "puffy" look around the dimpled screws. The c/s ones look fine and that alone drives me nuts. BTW I used the Cleveland edge tool to ensure the edge lays down. It does make the edge lay down uniformly. Sounds like you are on the right track. Eric Henson >>It seems that many RV's tank skins have a scalloping between the screws on the trailing edge, can this not be prevented be rolling the trailing edge down slightly with a dowel (broomstick) so that the skin conforms to the slope of the airfoil?<< ________________________________________________________________________________
Date: Feb 09, 1998
<< Does anyone have full size diagrams of instruments available via the internet for downloading and printing in order to layout and plan the instrument panel design? >> I think it's 3/8" of an inch. Before you start cutting metal, I would suggest that you have your instruments in hand so you can besure that all will fit. Also keep in mind that some instruments will sit very deep in your panel. Before I did my panel I created "standard" instrument icons and did a full size drawing (using Freelance Graphics) and printout of the panel to see if I would like it. It did change several times before the final version but the end product is a panel that I love. Gary Corde RV-6 N211GC - NJ ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: RV-6A Tow Bars
<< About time to get our build a tow bar for the -6A. Before I tackle this job, designing, buying material and fabricating at least three of them, any advice? Is there a Cessna bar that adapts with only minor mods? Any thing out there, in the Hardware store that provides a good head start? Any reasonable priced bars for sale among the builders? Folding handle, plug in handle, aluminum, steel ?? >> Why don't you just buy the one that Ken Barto sells for the RV-6A. He actually has three models of essentially the same design and uses the three bears marketing approach. I believe the papa bear is .065" wall, the mama bear is .058" wall and the baby bear (for lightest carry on) is .049" wall. One of these is just right for you. Ken's number can be had by printing out the RV Builders' Yeller Pages at http://www.sound.net/~hartmann/yelrpage.htm -GV ________________________________________________________________________________ rv-list
Subject: F83 console puzzle continues....
Date: Feb 09, 1998
I went back out to the shop after my first questions pertaining to the F683 assembly and set up my blocks of wood to simulate the spar. I put the bolts through them and the splice plates to get a good feel for the fit. I then marked the center line on the floor skin. When I looked down from the top of the F683A, it became immediately apparent that someone has changed the design of the F683 and didn't change the DWGs to reflect it! Per my drawings, the F683Bs should bolt up to the spar at the third bolts from the center, top and bottom. The flanges should also be pointing to the center. Now, there is no way that can happen. It appears that the flange on the F683A is bent so that the F683Bs will be attached at the top using the third bolt out and at the bottom using the fourth bolt out. The flanges on the F683Bs will now be pointed to the outside. So, just how does it fit? Do I bend the flanges on the F683A some more so that I only use the third bolts out? It appears that I can't use the flanges pointed inwards because of the F683A's width and the fact the F683As are labeled accordingly. Why is it that such a simple thing has to be made so difficult? I've wasted a good deal of time on this one, today. I had hoped for some good progress after losing out on some time last week because I had to shovel out! The snow got pretty deep here in KY :-( Jim Sears RV-6A #22220 (Still puzzled.) ________________________________________________________________________________
Date: Feb 09, 1998
Subject: rv-8 elevator trim
What is the world's wisdom concerning the electric trim versus manual for rv-8 elevators? I've heard that the rv-4 is very sensitive to the manual elev. trim. Is the 8 trim the same setup? I would prefer (for simplicty) to go with the manual trim, but would appreciate hearing from those who have "been there" Thanks. HILLJW(at)AOL.COM RV-8 TAIL KIT ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: Willing to help (want to learn)
<< Folks, As a new pilot, new member to the list and an RV wannabe, I would like to offer my help in exchange for some experience with RV's. I will be in San Fran/Livermore area on business from Feb 9-20, and most of my free time will be on the weekend. From looking at some of the postings, it appears that there is an active contingent of RV builders in the SF/Livermore area and I would love to use the weekend "learning RV". Please reply to: jharmstrong(at)mail.att.net Thanks in advance, Jack Jack Armstrong N3005X Hamilton, Virginia >> Jack, I have a very good freind finishing a 6A in Livermore. If you give him a call I am sure he wouldnt mind showing off his project. He is not currently on the internet so give him a call. His name is John McCallister (510)-606-0421. Tell him Ryan sent you. Ryan Bendure Thornton Co. RV4131RB(at)aol.com ________________________________________________________________________________
Date: Feb 09, 1998
>About time to get our build a tow bar for the -6A. Before I tackle >this job, designing, buying material and fabricating at least three of them, any >advice? Yep. Get one of the cheapie Cessna "Y" tow bars. My friendly IA gave me one that they didn't need any longer and it works great. The holes in the end are just the rights size for the bolt in the nose gear axle. If I remember correctly, I needed to pull the two legs apart slightly wider than stock. Make sure you get one with a telescoping handle so it will fit in the baggage compartment. Even if you have to buy one new I think they are only around $30 or so. BTW, if anyone is interested I have a new web page up that shows some of my RV construction, skydiving stuff, and other info. Ed Bundy RV6A - Eagle, ID - first flight 11/20/96 ebundy@juno.com - http://members.aol.com/rv67em/ - _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Subject: Oil Cooler
Date: Feb 09, 1998
I'm struggling with the oil cooler location. For those of you that have installed yours already: 1. Which location do you prefer, left rear baffle or fire wall?? 2. Advantages/disadvantages of the two alternatives?? Thanks, Bob RV-6; O-320 --- "The opinions expressed herein are solely the author's and are not necessarily the opinions of USAA." ________________________________________________________________________________
Date: Feb 09, 1998
I got most of mine from www.gulf-coast-avionics.com <http://www.gulf-coast-avionics.com> . They have full size pictures of most of the stuff. If you are a little computer literate you can cut and past these into a program that will allow you to scale them to the dimensions that you require. Have fun! Gary Fesenbek RV6AQ Roanoke, VA -----Original Message----- From: RV6junkie(at)aol.com [SMTP:RV6junkie(at)aol.com] Sent: Monday, February 09, 1998 12:33 PM To: rv-list(at)matronics.com Subject: Re: RV-List: Instrument panel design & spacing << Does anyone have full size diagrams of instruments available via the internet for downloading and printing in order to layout and plan the instrument panel design? >> I think it's 3/8" of an inch. Before you start cutting metal, I would suggest that you have your instruments in hand so you can besure that all will fit. Also keep in mind that some instruments will sit very deep in your panel. Before I did my panel I created "standard" instrument icons and did a full size drawing (using Freelance Graphics) and printout of the panel to see if I would like it. It did change several times before the final version but the end product is a panel that I love. Gary Corde RV-6 N211GC - NJ ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: Flying/G load testing/chatter
Listers: Not all kitplanes are of the same caliber as the fine products fron Van's. Some specify G testing during the flight test phase- for example, the Pulsar. A friend (engineer, very careful) had completed his Pulsar, and asked me to do the G test on the thing. I had watched his building process, and he had been doing a fine job. The "test" was to be to 4G's, and I did not consider this to be excessive for the a/c. We loades the a/c to gross, set up the calibrated G meter, and away I went. Of course, I was wearing a 'chute! This little bird had almost no inertia, so I had to dive for enough speed to GET 4 G's from the thing (in a slightly climbing turn), before it got too slow. Well, everything went fine (I thought), and the landing was uneventful. Post-flight inspection revealed a 18"crack and de-lamination in the bottom skin, about where we would have the seam between the tank skin and the main skin, just outboard of the fuse. Oh boy. The fix was fairly easy, and the result was a factory "AD" for existing a/c, and those under construction. The a/c was supposed to much stronger than it actually turned out to be. Believe me, this flight didn't make me feel superhuman, or anything of the sort. Just lucky. Looking back, I can't say that the failure would have been "soft", had it occured. Fiberglass doesn't bend with an overstress, it breaks. How about our birds? I think the opposite is true- these a/c seem to turn out stronger than one would think. The wonder of aluminum, eh? I don't think the "G" test is necessary on these RV's- they will take most of what we mortals can dish out, except abrupt turning pull-ups at Vne (take it easy on those pull-ups following those low approaches, fellas), and maybe some of our landings. ;-) Check six! Mark ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: rv-8 elevator trim- man or elec?
<< What is the world's wisdom concerning the electric trim versus manual for rv-8 elevators? I've been considering this one (iIve flown with both types): I would suggest that the elec system is lighter, and maybe a bit easier to install. In the event of an elec system meltdown, you will be without trim, but that's a very small thing to worry about. The difference between cruise trim and pattern trim is very slight. I *have* found that the elec system is diffucult to get just right for cruise, but this might be something I'm just not used to. If I put one on my next bird (mine has man trim), I'll use one of the Matronics speed controls. I've heard that the rv-4 is very sensitive to the manual elev. trim. Is the 8 trim the same setup? I would prefer (for simplicty) to go with the manual trim, but would appreciate hearing from those who have "been there" Yes, it is sensitive. But, so is the rest of the a/c! It's easy to get used to. I guess it's sort of like comparing elec windows to manual- which do you prefer? Check six! Mark ________________________________________________________________________________
Date: Feb 09, 1998
> > ><< Does anyone have full size diagrams of instruments available via the > internet for downloading and printing in order to layout and plan the > instrument panel design? >> > >I think it's 3/8" of an inch. The bible vol. II (aka, Bingelis, T., "Sportplane Construction Techniques") quotes an absolute minimum of 3.375 inches center to center instrument spacing (for 3 1/8 instruments), but reccommends 3.5 inches for a stiffer panel. Some local RV builders have used the closer spacing and puchased thicker aluminum for their instrument panels, but the 3.5 inch dimension gives a little better access for easier installation. These three books by Tony Bingelis should be on every kitbuilders bookcase, there is a great wealth of knowledge in them. Gil (get the Bingelis books) Alexander ... tip-up latch mechanism *** snip *** >Gary Corde >RV-6 N211GC - NJ ------------------------------------ RV6A, #20701, finishing kit "REPLY" sends to entire RV-list mailto:gila(at)flash.net to reply privately ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Subject: Re: Prop job.
Date: Feb 09, 1998
-----Original Message----- From: Michael C. Lott <lottmc(at)datastar.net> Date: Sunday, February 08, 1998 8:22 PM Subject: Re: RV-List: Prop job. > >My A+P told me you only have to check the crank runout with a >dial indicator, not pull the engine apart and send it off, unless >it shows the crank to be out of tolerance after the strike. [Much editing] >>Michael > Michael, May I suggest that you refer the problem to your insurance company. They will tell you whether they will pay for a dial gauge run-out check or a teardown. Dennis Persyk 6A fuselage Barrington, IL ________________________________________________________________________________
Date: Feb 09, 1998
-----Original Message----- From: Gary Zilik <zilik(at)bewellnet.com> Date: Sunday, February 08, 1998 9:11 PM Subject: RV-List: RV-6 Seat Rib Question > . When installing the f-616, >617,618,619 seat ribs I noticed that the forward flange is not at the >correct angle and wants to impart a twist to the f-604 web. I have again >verified the tilt in the f-604 bulkhead and found no problems. The >heights of the bulkheads from the longhorn are also correct. In Frank >J's supplement he mentions modifying the forward flange of the seat ribs >so that the f-604 will not twist. > >Why do I have this Problem? ANS: Because the ribs do not fit as supplied. I rebent my flanges to fit, but making new flanges is also acceptable. >One more question. View F-F` on dwg 33 shows how the f-619 rib is spit >in half. It also shows a huge notch in the bottom of the rib to clear >the spice plate. My ribs came with a smaller notch already in them. Do I >need to enlarge the notch or is the factory notch enough? ANS: The drawing incorrectly depicts the ribs as currently supplied. The degree of additional cutout will be determined after you have mounted the control assembly. You should ideally wait until the wings are in so you can carve out the minimum metal to achieve full measured control surface deflection -- I carved earlier. I would also suggest following FJK's advice on providing two removeable ribs. I find it much harder to remove the control assembly with only one rib removed. Finally, consider using AN3 bolts (with appropriate nut plates) instead of screws as called out because it is much easier to get a socket wrench on a bolt head in the narrow confines of the ribs than to get in with a stubby screwdriver. Dennis Persyk 6A fuselage (about 200 building hours ahead of you) Barrington, IL ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: tank dies
<< what are your opinions on the Cleveland tank dies, is this a must for fuel tanks? or is it just a waste of money? >> A must? No way. I didn't use them on my first RV and it flew okay. But I did shave those tank rivets. Waste of money? I don't thinks so. The tank rivets on my second RV now fit much nicer than without these dies. I've also used these dies on the substructure of the other skins and I believe the skins lay better as a result. It's all asthetics. How important is splitting that hair? Rick McBride ________________________________________________________________________________
Date: Feb 09, 1998
The old paint and body guys in the room are chuckling, if only it was that easy. Eric, I used to be one of those guys chuckling. The old paint and body guys learned that Variprime did not provide any protection against moisture the first time they painted a car fender then rolled it out of the shop for the night before they applied a sealer. When they came in the next day the dew or rain had caused the unprotected steel to rust right through the Variprime which they then had to fix on their own time. I realized that I was chuckling at the thought of people that were smart enough to learn how to build an RV and yet would not take the time to research how to properly use Variprime. I also realized that while the RV-List has be very helpful to me in building my RV8 I should not let misinformation on Variprime continue. This thread has gone on for years and every time it comes up the old timers on the list with allot of RV building experience we all look up to who are not sealing there Variprime take cheep shots at those of us that are trying to educate new builders on the proper use of Variprime. The facts are easy, DuPont recommends that Variprime be sealed with a topcoat to provide moisture/corrosion protection. The only reason we are painting the inside of our RV's is to provide a little more corrosion protection, if you do not seal Variprime then you have not done that. This thread should only be put to rest when there is no confusion about the need to seal Variprime. Is it bed time yet? Curtis Hinkley RV8 ________________________________________________________________________________
Date: Feb 09, 1998
> 2) DME (required only for flight above 24,000' (leaves me out!) These are >required on VOR-A approaches, which only get you to the airport >vicinity and it's visual from there or a missed approach A VOR-DME approach requires DME. A VOR-A approach is a typical VOR approach that is not aligned with a runway. While it only gets you to vicinity of an airport, it does not automatically require DME. Hope this helps. Scott Gesele N506RV ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: F83 console puzzle continues....
> I went back out to the shop after my first questions pertaining to the > F683 assembly and set up my blocks of wood to simulate the spar. [big snip] > Why is it that such a simple thing has to be made so difficult? I've > wasted a good deal of time on this one, today. I had hoped for some [snip] Actually Jim, the correct way to do it is in the plans, if you just know where to look. And also which drawing is right as opposed to the one that is wrong. And also the right one isn't quite right, and is too vague anyway.... Got it? Seriously though, I went through the same thing and ended up having to make new parts. Oh well, I had plenty of mat'l, and it helped make me feel I was justified in purchasing that hobbyist's bending brake. Without having my plane here at work I can't say for sure which holes were used, but if you do what I did it'll become obvious. All you need to know is this: At the top, the width is fixed by the F-683A. At the bottom, the side pieces (f683Bs?) go right on the inside of the floor stiffening angles, and although it isn't shown on the plans, I believe they are supposed to be attached to the stiffening angles with two AN-3 bolts w/self locking nuts on each side, similar to how two gusset plates on the outer stiffening angles are attached (section E-E', dwg. 46 -- you didn't miss that did you?) I won't do this until the spar is on, since I can't be exactly sure about the thickness of the spar even with the fake wood spar. Once you poition them that way, it should be clear which holes in the spar are used. Does that clear it up? It bears mentioning that I have seen a number of variations on various planes, which I suspect is just a result of this area being so "open to interpretation". But this one seems to me to make the most sense to me. Randall Henderson, RV-6 randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Feb 09, 1998
Subject: avionics For Sale (?)
As I near completion of my 6A I am actually considering removal of some avionics to clean up and simplify the layout and maybe shed a few needless pounds... I installed an audio panel/intercom and a 760 nav/comm with G/S althought I am not IFR certified and neither will the plane be. The trade would net me a comm-only radio and perhaps an upgrade to a _stereo_ intercom. If I'm going to do this, I want to do it soon so my project is not needlessly delayed. Despite building my panel with a dozen Molex connectors to make it readily detatchable for upgrades/repairs, I still dread making any major changes after the fwd skin is riveted on and all that access to the rear of the panel is lost for good! So here's a trial balloon to see if the upgrade is economically feasible. I'm NOT doing this if the removed equipment will end up on my shelf! FOR SALE: TERRA TXN 960 Nav/Comm/ECDI (Tri-Nav-C) with triplexer for taking the Nav and G/S signals from one antenna and of course the tray and manual included// removed in working condition and tests okay//no tags. RST Engineering Audio Panel and intercom, currently at the factory for alignment after expert construction by yours truly. Prices on Request off-list. Can't sell one without also selling the other (Not necessarily to the same party). Some restrictions apply. Void where prohibited. Actual mileage may vary. See store for details. Member FDIC. Bill Boyd getting close/getting giddy ________________________________________________________________________________
Date: Feb 09, 1998
At >Why is it that such a simple thing has to be made so difficult? I've >wasted a good deal of time on this one, today. I had hoped for some >good progress after losing out on some time last week because I had >to shovel out! The snow got pretty deep here in KY :-( > >Jim Sears >RV-6A #22220 (Still puzzled.) Jim, you are just in time for two of us here in Oregon as we are both just now getting ready to work on that area. We are both modifing that area. But keep us posted on how you come out with. Have a Great Day! denny-->> RV-6 harje(at)proaxis.com ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: Baffles
Robert Cabe wrote: > > Suggestions please. > > 1. I'm using Van's oil cooler and baffle kit on an RV-6 with an O-320. > > 2. How do you install the oil cooler on the back of the left side of the > baffle? I used four AN3-41 bolts with alum. tubing between the flanges of the cooler. This is to prevent the flanges from bending when tightenting the bolts. Two bolts thru the angle at the left rear corner and the other 2 where they the cooler leaves them. I did add a .040" plate where the other two bolts come thru and extended it to the right with a bend to rivet to the jog in the rear of the baffle. > > > 3. The plans that come with the baffle kit say on page 7 that Part 4 > requires that you must increase the angel of the flange from 90 to 115 > degrees. Why??? I was puzzled at this too. As I recall, I left every thing at 90. > > > 4. How do you attach the oil cooler to the that flange?? > > 5. How do you reinforce the baffle so that both sides of the oil cooler > can be attached to the baffle? > > Please provide any other helpful hints you may have. I have added a ball valve to the top oil line to the oil cooler with a choke cable to the cockpit for temp. control of the oil. It is a tight fit, but it can be done. Good luck. Warren Bishop RV-6 installing systems > > > Thanks, > Bob > San Antonio ________________________________________________________________________________
Date: Feb 09, 1998
Subject: RV-6(a) Fuse Jig avail.
Hi All, My "hell for stout" aluminum fuse jig is looking for it's next fuselage to keep it company. I need to keep ownership of it for a couple of reasons, like, ah, I got the material from the scrap bin at work with the permission of my boss, as long as I let him use when he's ready. That could be a while. So in the mean time, I'm willing to loan (with no charge) it out to someone who is ready to build their fuselage, and who will take good care of it. They will also need to pick it up, and deliver it back in good condition when there finished, so the next fuse in line can be built. So, if your ready to build, it's located in the San Fernando Valley just north of Los Angles, CA. E-mail back to "owens(at)aerovironment.com", not to the list. Laird Owens RV-6 #22923 making airplane noises in the seat ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: avionics For Sale (?)
<< I still dread making any major changes after the fwd skin is riveted on and all that access to the rear of the panel is lost for good! >> Not to bust your bubble, but many folks I have visited at your stage of the project have opted to allow access by installing nutplates and countersunk screws instead of rivets in the area you describe. It's not too late to make a small change in the plans. Jim Nice RV6A ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: Tank dies
Tank dies from Cleaveland...questions. Are these for dimpling the tank mounting screw holes? Are they usable elsewhere in the building project? What rivets need 'shaving' if these dies are not used? These questions may be answered on Friday when I pick up my wing kit, but I would like to know now so I can order them if needed. Thanks Dennis Clay RV-8 #80473 ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Pitot tube mount by Gretz Aero
I will admit it right away, I am a klutz when it comes to computers!! I was ready to respont to an e-mail I just got when I managed to erase it. It was not on the RV-List. I now do not have the address to the person that had asked me a question about my pitot tube mounting bracket kits! If the person who sent it to me reads this, I am sorry! The question to me was; Can a person install my pitot tube mounting bracket kit to a finished RV? The answer; Yes, one can install the mounting bracket to a finished RV, but it is harder to do. If this person has further questions about my products, please contact me. I will attempt to not get too close to the delete key this time. Warren Gretz, (Gretz Aero) 3664 East Lake Drive Littleton, CO 80121 (303) 770-3811 gretz-aero(at)juno.com _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 09, 1998
Subject: How do I use the 3 inch panel punch?
Hi all, I can use my FBO's panel punch but I don't really know how to use it. I will drill 5/8 inch holes at center of each instrument - 3.5 inches on centers thanks to today's mail. Should I take my 3/8 inch air ratchet and sockets(?) or do I use a hand wrench or what? Hal Kempthorne RV-6AQ -- Looking for an airport & sweating canopy halk(at)sybase.com Santa Clara, CA. Debonair N6134V @ SJC ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: Oil Cooler
Robert Cabe wrote: > > I'm struggling with the oil cooler location. > > For those of you that have installed yours already: > > 1. Which location do you prefer, left rear baffle or fire wall?? > 2. Advantages/disadvantages of the two alternatives?? > > Thanks, > Bob > RV-6; O-320 I chose the left rear baffle because of shorter oil lines and easier mounting (I thought). It will rob a little air from the #4 cyl., but apparantly that isn't a problem. The problem with mounting it on the firewall (at least in my case) is that I have enough stuff on the firewall or coming through it. Also, you have to run a 3" min. (4" is better) SCAT tube to it. I havn't flown yet, but am satisifed with my decision so far. Warren Bishop ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Oh-no! Veriprime
Curtis, Of course it has to be topcoated, the point was, it probably won't adhere to veriprime. Your comment was: >> This is a very clear statement that Variprime is a primer to be used with any topcoat. What part of that statement is un-clear to you? <<< Go drop $500.00 + for a nice gallon of durethane and top coat over the VP. Most top coats now days are designed for their own primers, VP is pretty wimpy, most finish coats are going to either eat it or fail to chemically bond. It's a pretty mute point, if you convert the metal and seal it with anything, it should outlast you and I. >>This thread should only be put to rest when there is no confusion about the need to seal Variprime. Is it bed time yet?<<< Nope, I sense non-believers in the congregation, put on the coffee. Ahhhhhhh, I'm in a primer debate. I'm sending Matt the $5.00 fine. Curtis Hinkley RV8 ________________________________________________________________________________
Date: Feb 09, 1998
Subject: starter F/S
Another item for sale as I draweth near to completion: Electro Systems starter- 12 v - 149 tooth p/n 2064 removed working condition from C-172 and rebuilt by A&P 12/96 as part of my O-320 engine overhaul. First installed 7/88. TT in service to date: 510 hrs. Will sell for essentially core value; now have metal prop and don't need the fwd ballast! (I'll go with a lightweight aftermarket starter.) Reply off list to SportAV8R(at)AOL.com Bill Boyd ________________________________________________________________________________
Date: Feb 09, 1998
Subject: RV x Lancair
I am about to make a decision and your opinion is important. After days of research I am in doubt between the Lancair MKII 320/360 and RV 6/8. I researched about Velocities, Cozys, Glasairs, Pulsars, 1/4 share Cesna 182, and even BD-5s..yeah I thought about it, deadly fun huh! The reasons why I picked the RV and Lancair is because of the fact they are fast for Xcountry and can aerobatic. Well folks, gulp....here it goes Why should I get and RV instead of a Lancair? am I wrong to think that the only difference in cost is the kit it self ? It seems that other then the kit everything else will cost the same. I am planing to get an OH IO-320, fix prop and Minimum VFR setup(planing to fly only in good weather). In this configuration, I figured that a Lancair 320 will run about $ 50,000 and the RV6A about 40,000.00. I hope I can start by having your friendly support :) thank you Martin 8X -Otus- 8X VF-17 "The Jolly Rogers" "We're the Jolly Rogers, Who the hell are you?" ________________________________________________________________________________
Date: Feb 10, 1998
Subject: Re: RV x Lancair
Martin Quartim wrote: > > > I am about to make a decision and your opinion is important. After days of > research I am in doubt between the Lancair MKII 320/360 and RV 6/8. I > researched about Velocities, Cozys, Glasairs, Pulsars, 1/4 share Cesna 182, > and even BD-5s..yeah I thought about it, deadly fun huh! > > The reasons why I picked the RV and Lancair is because of the fact they are > fast for Xcountry and can aerobatic. > > Well folks, gulp....here it goes > > Why should I get and RV instead of a Lancair? > > am I wrong to think that the only difference in cost is the kit it self ? > It seems that other then the kit everything else will cost the same. I am > planing to get an OH IO-320, fix prop and Minimum VFR setup(planing to fly > only in good weather). In this configuration, I figured that a Lancair 320 > will run about $ 50,000 and the RV6A about 40,000.00. > > I hope I can start by having your friendly support :) > > thank you > > Martin > > 8X -Otus- 8X VF-17 "The Jolly Rogers" > "We're the Jolly Rogers, Who the hell are you?" > I'm from the 103Fis F-86H 1959 Ok now I'll try to give you my opinion as to why I picked the RV over the Lancair. I know this is going to become a great list because I'm sure there are some strong feelings here. Personally I don't like to work with fiberglass or composites. I learned that early on building radio control models in the 1/4 scale class. But that wasn't the only reason, All i've ever flown have been either aluminium or fabric covered aircraft and the track record is very good on durability with proper care. Proper care may be the key; but I'm still uneasy about that since most plastic airplanes are painted white to prevent ultraviolet light from breaking down the composites.We don't have worry about that with metal. Though we have to be concerned about corrosion. We also don't have to wear masks all the time so we don't breath in the fibers while sanding and drilling. We don't have to worry about the mixture of the resins even though they have the proper pumps to help you. The problem is in the mixing, is it mixed enough or not? If its not you wont know it it for a while then "bang". Was the temperature right at the time cureing. Rivets are easier and more forgiving since if you screwed up just drill it out and try again. The fact is you can see the screw up you can't when you mix epoxy. Finally, I had a diving board out at the pool. It was painted white and put away and covered in the winter. It was 2in. thick and was made of fiberglass and many layers. This summer after 12yrs of service it broke in half when some active boys jumped on it. Is that what will happen to a wing in 12yrs? I don't know that and I don't want to find out. I may go 25-50-75mph slower than a Lancair but I think My Rv will be here for a long time. We still have Ford Tri-Motors, DC-3, DC6 and many other metal planes around that are still airworthy. I won't be around long enough to see if the plastics are in as good shape in the same time frame. I just don't want to be one of the test pilots. MY OPINION ONLY Don Call sign "MONGO" ________________________________________________________________________________
Date: Feb 10, 1998
Vanremog(at)aol.com wrote: > > > > << If they truly are such a great thing, why aren't they included in EVERY > design? >> > > -GV > GV, They do have them for many types out there from Aeroncas, Pipers Cessnas and many twin's. They have just started testing with a few selected homebuilts and they should have results soon. For the aircraft mentioned the performance enhancements have been very impressive. It remains to be seen if the better designs of the homebuilts will produce the same. Will let you know DON ________________________________________________________________________________
Date: Feb 10, 1998
RV6junkie(at)aol.com wrote: > > > > << Does anyone have full size diagrams of instruments available via the > internet for downloading and printing in order to layout and plan the > instrument panel design? >> > > I can direct you to a a piece of software that I purchased at Sun&Fun last year that called "Panel Planner" it a great program that consists of about all the hardware,avionics and controls used in an airplane. He also has many templates of instrument panel for RV's. you can creat a fuull size panel in color with all your equipment and alos create a demensional template for cutting. I used it and it was a piece of cake. You can try out different senarios before settling on a final panel. The cost is $99.00 for the basic program to $199.00 for the Pro copy. They also have a web page WWW.panplnr.com DON ________________________________________________________________________________
Date: Feb 09, 1998
Subject: Re: Certification (Flying)
> I'm not sure that I will be capable/confident in > my abilities as a pilot to test all the capabilities of the airplane during > the test phase. Does this mean that if, at some point after my test period > is complete and my skills grow, that I cant do these more advanced > manuevers, and that there is no way to revise the operating limitations of > the airplane? This came up about a year ago. According to the conversation at that point, you have two choices: 1. Buddy up with a more experience pilot to test the more advanced manuevers during the initial testing period. 2. If you want to add more testing down the road, the procedure is as follows (roughly, anyways): A. Land the airplane at the airport listed as your original break-in airport -- where ever you do your first flight. B. Make an entry in the aircraft log book stating you are returning the airplane to testing. C. Do your testing under the same guidelines as the initial testing -- same airspace restrictions, no passengers, etc. D. When done, land, make another entry in your aircraft log returning to normal service. Thus, yes, you can go and do additional manuevers, but you have to do them in the same place as your original testing. -Joe ________________________________________________________________________________
Date: Feb 09, 1998
> > Thanks to all who responded to my inquiry concerning equipping our RVs > for IFR flight. > > [snip] > > I have paraphrased some of the above lines for brevity. This leaves the > following for additional consideration by the individual pilot: > > [snip list of avionics] Here's what I'm tentatively planning: 1. All the required items -- clock, AI, DG, etc. These are listed in the FARs, so I won't repeat. Note: clock has sweep second hand and is near top center of panel, highly visible without craning my neck 2. *At least* one NAV/COM with VOR and glideslope. This radio will have flip-flop frequencies so I can switch easily. I *might* have two, but I'm not sure. The second doesn't require glideslope. 3. IFR GPS. I'll explain why shortly. 4. *Maybe* DME. If I have an IFR GPS, I don't *need* it. However, a DME is *easy* to use, and a GPS requires a bunch of button pushing. I'm thinking in a tight situation, I just won't want to dink around with the GPS. I recently tried to fly an underequipped airplane to an airport whose only instrument approach was an NDB. If you page through a set of approach plates, it turns out that NDB approaches are a lot more common than one would like. Thus, if I want to be able to fly to all these airports, I better have an ADF. Well, of course the FAA is replacing all these approaches with GPS overlays. So that means I need an IFR GPS instead. Luckily, at the rate I'm building, they'll be pretty reasonably-priced by the time I need one :-) -Joe ________________________________________________________________________________
Date: Feb 10, 1998
Isn't a Lancair kit over $25,000? If so, this is twice as much as an RV. I think that the REAL question is which type of material YOU are most comfortable working with, metal or composite? Walt RV-6A ________________________________________________________________________________
Date: Feb 10, 1998
I've thought about your question some more, so here goes: You must throughly analyze as much info on each aircraft as you can get your hands on, talk to as many builders and flyers as you can find, look at as many planes of each type as you can find, and eventually you will come to realize which one is the right one for YOU. It will be very clear. I wouldn't commit to one or the other until it is. Walt (again) RV-6A ________________________________________________________________________________
Date: Feb 10, 1998
I have an RV-4 with over a thousand hours on it, and the manual elevator trim is simple, light, cheap and effective, and dependable. Not sensitive at all in my opinion. Why complicate matters unecessarily with electric trim? Now electric flaps is a must have in the RV-4 because of being in the way of the passengers foot, and other minor problems. That is partially why the RV-8 is electric flaps standard. Just an opinion. Von Alexander RV-4 N107RV RV-8 #544 ________________________________________________________________________________
Date: Feb 10, 1998
> >Isn't a Lancair kit over $25,000? If so, this is twice as much as an RV. > >I think that the REAL question is which type of material YOU are most >comfortable working with, metal or composite? > > Walt RV-6A > Standard kit $23,900.00 Fast Built $28,900.00 Carbon Fiber FB $34,400.00 I have no experience working with metal or composite. Martin ________________________________________________________________________________
Date: Feb 10, 1998
> >I've thought about your question some more, so here goes: > >You must throughly analyze as much info on each aircraft as you can get your >hands on, talk to as many builders and flyers as you can find, look at as many >planes of each type as you can find, and eventually you will come to realize >which one is the right one for YOU. It will be very clear. I wouldn't commit >to one or the other until it is. > > Walt (again) RV-6A That is exactly I am doing now :) So far I am finding a lot more help from RV builders then Lancair. Thank you, Martin ________________________________________________________________________________
Date: Feb 10, 1998
eventually you will come to realize >>which one is the right one for YOU. It will be very clear. I wouldn't commit >>to one or the other until it is. >> >> Walt (again) RV-6A > >That is exactly I am doing now :) > >So far I am finding a lot more help from RV builders then Lancair. > >Thank you, > >Martin Martin, You've already seen just how motivated, friendly, and energetic the RV building club is! We are proud of Van's designs and I, personally, just LOVE to see new faces here. It's a family affair, and through the sharing of our techniques and building experiences, we create better aircraft than we could do on our own. I spent over a year going over various aircraft kit designs, biplanes, metal, composite, fabric, the whole spectrum..and nothing that I found offered more performance for the dollar spent than the RV. My objectives are primarily sportsman aerobatics, and fair-weather VFR cross country with flexible schedules to stay out of nasty wx. The composite aircraft sure are sexy to look at..but all that sanding, filling and resin mixing...not to my liking. A recent death of a local aerobatic pilot in a brand new Sukhoi Su-31 due to wing delamination failure (or something like that) also greatly influenced my decision to avoid composite structures. I just don't feel comfortable with the subtle nuances of multi-layer layups, cure times, mixing ratios, etc. So, enough bandwidth for me. Just search your heart for what you REALLY feel will make you smile when you're airborne...that's what it's all about..because we're CERTAINLY not in this for the money! Best of luck to you Brian Denk RV-8 #379 wings underway ______________________________________________________ Get Your Private, Free Email at http://www.hotmail.com ________________________________________________________________________________
Date: Feb 10, 1998
Subject: RV 6A - Cowl fixture
A question for thoes that have mounted the lower cowl without hinges on the bottom of the firwall. Did you use screws and nutplates? ... What size? Did you use camlocs? ...... What type (4002, 2600 2700 etc) and size?? I have put two strips of 0.63 al. on the firewall. Has anyone put extra 'glass' on the lower cowl near the air outlet?? Thanks Royce Craven RV6A - cowling Melbourne Oz ________________________________________________________________________________
Date: Feb 10, 1998
OK, what you said made sense. No, I didn't spot the part on DWG 46. I was concentrating on the ones around DWG 32 and 49. I did look in that area and must have overlooked it. Now, how did you handle the conection to the floor, itself. Did you use a tab that overlapped the top of the floor; or, did you use the Orndorff method and use some angle stock and just butt up to the floor? I think I'll use the angle; but, that could cause a problem too because one can't get to the screws on the underside or will have the same problems with the top in that it will be in the way. I want to be able to get the floor off for inspections. That's my biggest rub, right now. ________________________________________________________________________________
Date: Feb 10, 1998
Subject: Re: How do I use the 3 inch panel punch?
Hi Hal, Some of the punches & dies work with a ratchet or open end wrench - this is the dark ages, The new sets or the more expensive ones have a Hydrolic Punch. You cut your 1/2 or 5/8 KO out of the middle put in your die & punch, turn the valve and 6 or 7 pumps on the handle & it pops it out. I am an electrical contractor and have both the Hydrolic & Dark Age method, there are several styles of Hydrloic units out there - some designed for real close quarter work. If they have the old style, it not that bad you just need to apply some strength. Good Luck BSivori(at)AOL.COM N929RV ( Reserved ) Wings ________________________________________________________________________________
Subject: IFR RVs and the FARs
Date: Feb 10, 1998
Snip>> However, a DME is *easy* to use, and a GPS requires a bunch of button pushing. I'm thinking in a tight situation, I just won't want to dink around with the GPS. Snip<< Not only that my DME does not require software updates every month like my IFR GPS does. Gary Fesenbek RV6AQ Roanoke, VA ________________________________________________________________________________
Date: Feb 10, 1998
Bill, They look identical, but the tank dies are just a pubic hair deeper... Fred > >I ordered a set of Tank Dimple diew from Avery - What I think I got >was >another set of 3/32 Dimple Dies. > >Bill > > > > _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
From: "Douglas G. Murray" <dgmurray(at)telusplanet.net>
Martin Quartim wrote: > > > > The reasons why I picked the RV and Lancair is because of the fact they are > fast for Xcountry and can aerobatic. > > Well folks, gulp....here it goes > > Why should I get and RV instead of a Lancair? >Martin, Why would you want a piece of tupperware made of compost that needs only white paint and an expensive hangar when you could have a great all metal durable aircraft that doesn't need to be babied all day to stay in one piece? :-) Those prices you quote are about correct for an RV but miss the mark quite a bit for the Lancair. Those plastic craft usually come in at $80,000 to $120,000 + to complete and only fly faster by 30 knots. My question is - Should 30k cost an extra $50,000? I also would really like to see a Lancair follow an RV into some of the short strips we like to frequent. But, you know what they say, build what your heart desires cause you got to live with it when your done! The most important thing is to HAVE FUN FLYING!!! :-)) Doug - RV-6 canopy frame now primed & waiting for rivets. > am I wrong to think that the only difference in cost is the kit it self ? > It seems that other then the kit everything else will cost the same. I am > planing to get an OH IO-320, fix prop and Minimum VFR setup(planing to fly > only in good weather). In this configuration, I figured that a Lancair 320 > will run about $ 50,000 and the RV6A about 40,000.00. > > ________________________________________________________________________________
Date: Feb 10, 1998
> > >So far I am finding a lot more help from RV builders then Lancair. > >Thank you, > >Martin > I don't know where you live but here in New England some of the best places to fly to are around 2,000 ft long. Many types claim they can get into fields this small but an RV can get you in and out even when you're tired and not break a sweat. That's why I'm building a -4, which is known by all to be the best RV model there is. You may hear from a few who are still unwilling to admit this so just ignore them. The Lancair will be a bit faster. I honestly can't think of any other advantage they have. Good luck with your decision and take your time making it. John ________________________________________________________________________________
Date: Feb 10, 1998
Listers, please excuse the message I sent earlier (see below). It had some misleading statements because I actually meant to send it to an individual lister. However, I've done some more looking. I looked at DWG 46, per a suggestion. It refers to the F699s only. I've got those in place already. DWG 32 does not show bolting the bottoms of the F683Bs to the angle stock in the fuselage floor to tie them together; but, I have to agree that it's meant to be since mine seem to fall into alignment, sort of, with the angles. This is all goodness since it does answer some questions that the manual completely ignored. However, the rub is still there. DWG 49 shows a 3/4" tab on the back of the F683A that must get screwed to the top of the seat floors to tie things together. If I do that, I will not be able to get the seat floors out since I have the manual aileron trim shaft that prevents that from happening unless I lift the floor straight up at the front of the floor. One thing I think I should do is trim one of the floor flanges at the front so that the floors are flush at the flange. That would make for a better fit of the F683A and would allow me to use a piece of angle. The rub with using the angle is that there is very little room for a screw inside the F683A because of the plumbing if I want to hide the angle. Of course, I can extend tabs out from the angle to give me some meat to drill through for the screws. That would also make things easier to get to at annual time. With that said, 1. Cut one of the flanges on the seat floors to make it flush along the front. 2. Cut a piece of angle that will have tabs long enough past the F683A so that easier screw mounting can be done. Only two screws due to the plumbing under the F683A. 3. Trim the angle under the F683A where the valve overlaps the angle somewhat. Also trim the tab back until it's flush with the edge of the angle. 4. Fit the F683A and angle to the seat floor and drill for screws. 5. Drill for the spar bolts so that the F683Bs will contact the angles on the fuselage bottom. I plan to mark them and drill in the drill press. 6. Drill the F683Bs to the F683A. 7. Drill pilot holes for the bolts in the F683Bs and angles like the F699s. To be finished later when the spars are in place again 8. Finish the console assembly. That sure is a lot more to do than the plans show, huh? What do you think? >OK, what you said made sense. No, I didn't spot the part on DWG >46. I was concentrating on the ones around DWG 32 and 49. I did >look in that area and must have overlooked it. Now, how did you >handle the conection to the floor, itself. Did you use a tab that >overlapped the top of the floor; or, did you use the Orndorff method >and use some angle stock and just butt up to the floor? I think I'll >use the angle; but, that could cause a problem too because one >can't get to the screws on the underside or will have the same >problems with the top in that it will be in the way. I want to be able >to get the floor off for inspections. That's my biggest rub, right now. Jim Sears RV-6A #22220 ________________________________________________________________________________
Date: Feb 10, 1998
Martin, Take note of one fact....RV builders DO NOT have to defend one aspect of the airplane they have chosen to build. i.e.: Materials used in construction Construction technique Design configuration Performance (As published by kit Mfger.) Engine (As suggested by kit Mfger.) And I'm probably overlooking a few. One other consideration. Just try to find an unhappy RV builder who has completed his mission! (Just my opinion) Al > >I am about to make a decision and your opinion is important. ________________________________________________________________________________
Date: Feb 10, 1998
<< The most important thing is to HAVE FUN FLYING!!! :-)) >> I might point out that the above is the focus of the discussion- agreed? Next step: Get a ride! Get your mitts on the stick of both, and measure the "fun factor" of each. Compare with your expected mission profile, and there you have it. $$$ doesn't enter into the equation- you WILL find a way to pay for the desired toy. Check six! Mark ________________________________________________________________________________
Date: Feb 10, 1998
> Why should I get and RV instead of a Lancair? Go fly both. That will help. More importantly, land both. You will find the Lancair is a HOT little airplane both in the air and on the ground. Lands FAST. Which is something you will not want to be doing after a flameout. I once read a pilot report on the Lancair in which the demonstrating pilot would not let the reporting pilot land the airplane. (!) What do you want your airplane for? Just cross country? Back country strip landings? Aerobatics? Compare what airplane is used for what activities. Simplicity of design. Lancairs have folding gear: more complex, more maintainance, higher insurance, the chance of landing with them folded. RV's have GREAT performance with the gear fixed. Hang with the pilots who fly both. Who would you rather hang/fly with? How many of each design are flying? Van wins there. Tells you what a lot of other pilots decided, thinking of the same questions you are. I once was trying to decide between the -4 and the Glasair. I made the right choice, NO doubt. Love my -4. Michael RV-4 N 232 Suzie Q Flying (gently expanding the envelope) ;>/ ________________________________________________________________________________
From: "TOMMY E. WALKER" <twsurveyor(at)email.msn.com>
Date: Feb 10, 1998
-----Original Message----- From: Martin Quartim <martinq(at)cris.com> Date: Monday, February 09, 1998 10:24 PM Subject: RV-List: RV x Lancair > > >I am about to make a decision and your opinion is important. After days of >research I am in doubt between the Lancair MKII 320/360 and RV 6/8. I >researched about Velocities, Cozys, Glasairs, Pulsars, 1/4 share Cesna 182, >and even BD-5s..yeah I thought about it, deadly fun huh! > >. > >Why should I get and RV instead of a Lancair? > >I hope I can start by having your friendly support :) > Martin, Two Years ago I was faced With this same question "Plastic Or Metal" After 6 months of much thought and "tire kicking" I ordered my 6-A Tail Kit form Van. After 18 months of being an RV builder, much more thought and "tire kicking", I KNOW I made the right decision! > GOOD LUCK, Tommy Walker 6-A Wings Ridgetop, Tennessee (GO VOLS) > > > > > > > ________________________________________________________________________________
Date: Feb 10, 1998
Martin, Havent seen my reasoning in print yet so will give you my $.02. Two primary reasons for my choice: 1) The RV's were the highest performing aircraft I could find with fixed gear. I didnt want to deal with the added cost, complexity, extra insurance, etc.. that comes with owning a retract. Didnt want to have to worry about an accidental gear up landing either. 2) The RV's (particularly the tandem seat airplanes) scream sport plane/fighter plane to me. The plastic stuff says pretty but boring go fast transportation. I wanted a fighter plane! Of course these arent my only reasons, there are lots of others. Builder support, factory support, lots of flying aircraft, etc... But even without the extra reasons, 1 & 2 above were enough for me. Mike Wills RV-4(fuse on order) willsm(at)manta.nosc.mil >Why should I get and RV instead of a Lancair? >thank you > >Martin > >8X -Otus- 8X VF-17 "The Jolly Rogers" >"We're the Jolly Rogers, Who the hell are you?" ________________________________________________________________________________
Date: Feb 10, 1998
<< >So far I am finding a lot more help from RV builders then Lancair. > >> The above statement is single most important reason for my decision to build an RV. When I started, I was living in a small town in NM (about 40,000) and there was only 5 RV's under construction, about 80% of all the airplanes in my EAA chapter. If you need or want help, the RV is the way to go. If you have built many airplanes and live close to the Lancair factory, then go with the lancair. Just understand, even a simple airplane is a very daunting undertaking. Also consider the amount of time to build, you can easily build an RV under 2500 hours, but most Lancairs I see completed in Kitplanes Magazine take 4000+ and one was over 9000 hours! Even at 2500 hours of building, do you think in your wildest dreams you will be able to fly your plane 2500 hours before you die! The ratio gets worse with a more complex airplane. Bob Busick RV-6 (Almost as good as an RV-4) Fremont CA ________________________________________________________________________________
Date: Feb 10, 1998
Subject: lancair vs. rv
Martin: I don't know a lot about some of the issues on the rv net, but do believe I could respond to your dilemma, because I have and fly a two seat lancair, and I am buildidng a rv-8. IMHO, both are wonderful airplanes. The lancair is a fun, responsive, beautiful airplane. I dread having to part with mine, but I have built a fairly short grass strip on my farm, and the lancair is definitely not made for that kind of use. It is a great paved runway type plane, but as others on the net have told you, the rv is much better adapted to short and/or grass strip use: therefore I'm going through the whole process again. My lancair has an O-320 lycoming with a three blade, wood, fixed prop. If you decide to build a lancair, you might want to spend the extra $ and put a constant speed prop: I believe it would up the performance. Also, if acrobatics is a major interest to you, I believe the rv might be more appropriate, although I am not an expert on this subject. I just know that the lancair is so slick that I am afraid to point it downhill for very long. Others may tell you more on that. I do think the lancair will give you more fuel efficiency ie speed for horsepower. Building concerns? What material do you prefer to work with? Its a lot of work either way. Good luck. HILLJW(at)AOL.COM ________________________________________________________________________________
Date: Feb 10, 1998
From: "David L. Macintire" <dave_mac(at)bellsouth.net>
Martin Quartim wrote: > > > I am about to make a decision and your opinion is important. After days of > research I am in doubt between the Lancair MKII 320/360 and RV 6/8. I > researched about Velocities, Cozys, Glasairs, Pulsars, 1/4 share Cesna 182, > and even BD-5s..yeah I thought about it, deadly fun huh! > > The reasons why I picked the RV and Lancair is because of the fact they are > fast for Xcountry and can aerobatic. > > Well folks, gulp....here it goes > > Why should I get and RV instead of a Lancair? > > am I wrong to think that the only difference in cost is the kit it self ? > It seems that other then the kit everything else will cost the same. I am > planing to get an OH IO-320, fix prop and Minimum VFR setup(planing to fly > only in good weather). In this configuration, I figured that a Lancair 320 > will run about $ 50,000 and the RV6A about 40,000.00. > > I hope I can start by having your friendly support :) > > thank you > > Martin > > 8X -Otus- 8X VF-17 "The Jolly Rogers" > "We're the Jolly Rogers, Who the hell are you?" > Mark, Why not build a Glasair? It is a great fibreglass airplane, fast and sexy. For that matter, how can you resist the sleekness and sex appeal of the GP4? It is a beautiful wooden airplane that is a work of art! The point is, it took me over two years to decide which airplane I was going to build. I was convinced, after seeing a Merritt Island chapter member's Lanceair that that was the plane for me. One day, I was re-reading some old AOPA Pilot magazines and I ran across George and Becky's article about the Van's RV-6A with the accompanying article by the staff of the magazine about Van and all his planes. The articles and the idea that I would be building a metal airplane just the way airplanes have always been built fascinated me. Significant contributing factors include the high ratio of top speed to stall speed (4:1 in most cases), reasonably priced kits, build time estimates and roominess helped my decision. All the planes are great. If you have a lot of money and the talent, build a Lanceair IV. Learn to fly it IFR. However, the reality for me is that the RV-6 maximizes the fun factor while minimizing the cost. Dave Macintire RV-6 LE Orlando, FL ________________________________________________________________________________
Date: Feb 10, 1998
> >Why should I get and RV instead of a Lancair? > >thank you > >Martin Hello Martin, The Lancair is a fine airplane, but I chose the RV8 because of three items. 1. I work out of garage attached to house. Significant dust and chemical smells were out of the question. Sanding and painting require a patience level well beyond mine. So all composite type aircraft were out. 2. I can purchase the RV8 incrementally. The completion rate on homebuilts is roughly 25-30% (don't recall source, EAA Magazine I think). With the RV8 I could find out with a 'relatively' minor investment of $3200.00 (Tail kit + tools + minor garage fix up) my chances of being in the completion group. The Lancair was a pretty much an all or nothing affair, at least at the time I was deciding. The tools and garage fix up, except for rivet stuff, I could use on other things to offset the cost. 3. Cost! I believe the Lancair is significantly more expensive. Even though I am really happy with my decision, I still like to pull out the Lancair video pack from time to time. One nice airplane! Good luck on your decision. I would be thrilled to fly, let alone own, either one. Regards, Vince Himsl RV8 rudder ________________________________________________________________________________
From: "Jensen, Keith (MC R&D)" <KJensen(at)simplot.com>
Date: Feb 10, 1998
You commented: > > Martin, > > Take note of one fact....RV builders DO NOT have to defend one aspect > of > the airplane they have chosen to build. > i.e.: Materials used in construction > Construction technique > Design configuration > Performance (As published by kit Mfger.) > Engine (As suggested by kit Mfger.) > One exception: to topcoat or not topcoat primer ! ;-) kj ________________________________________________________________________________
Date: Feb 10, 1998
For those listers who seem interested in my problems with the console because they have yet to do it: >1. Cut one of the flanges on the seat floors to make it flush along >the front. Done. In fact, I'd suggest that this be done when the floors are installed. I didn't; but, it looks OK. I may need to shim just a tad on the left side if it doesn't pull up correctly. >2. Cut a piece of angle that will have tabs long enough past the >F683A so that easier screw mounting can be done. Only two >screws due to the plumbing under the F683A. Done. I made mine about 1" past the F683. Now that may be too much; but, it will work. Why too much? I'll explain shortly. >3. Trim the angle under the F683A where the valve overlaps the >angle somewhat. Also trim the tab back until it's flush with the edge >of the angle. Done. I did leave a little extra where the F683A is butted up to the left seat floor. If your seat's floors are flush at the front, this will not be needed. Only for appearance and may be overkill. >4. Fit the F683A and angle to the seat floor and drill for screws. Done. I clamped a 1/8" shim on the F683A and made that flush to the floor tops so I could drop the F683A just below the bend curves of the floors. I actually drilled out too far because now I'm going to have to bend the flanges of the F683A to allow more clearance for the F683Bs. I could have moved the screws in a bit closer, had I known that. See item 5. >5. Drill for the spar bolts so that the F683Bs will contact the angles >on the fuselage bottom. I plan to mark them and drill in the drill >press. Bingo! More problems. When I looked down on the bolts stuck through the spar holes, I discovered the bolts aren't centered One side will not fit, at all. Now, to make the F683Bs work as braces for the F683A, I'm going to have to bend the F683A flanges a bit to allow them to clear the top bolts in the spar. That means I can no longer use the F683Bs as supports for the fuselage floor angles. What next? :-( Are you guys sure about using the F683Bs like the F699s? It makes sense to; but, the angles are all wrong on my parts vs the locations of the angles in the fuselage floor. At first, I thought they'd be OK; but, now I don't. Boy, I sure dread running those fuel lines through there. :-) >6. Drill the F683Bs to the F683A. >7. Drill pilot holes for the bolts in the F683Bs and angles like the >F699s. To be finished later when the spars are in place again >8. Finish the console assembly. Jim Sears in Ky RV-6A #22220 (Scratching my head again!) ________________________________________________________________________________
Date: Feb 10, 1998
Subject: Lancair or RV
In terms of bang for the buck, the RV,s are the top dog when comparing cost to build and resale value. There is also a trend in the insurance industry that requires owners of high performance homebuilts (right now Glassair III and Lancair IV) to have their aircraft inspected by an "approved" facility and also undergo "approved training before they are insurable. I have a friend who owns and built a Glassair III, also a professional pilot, whose insurance was cancelled until he met the above qualifications. He had to fly his UNINSURED airplane to Louisiana from CT. just to have the inspection performed. If this trend continues, the next batch of planes to require this may very well include the smaller Lancairs, primarilly due to their high wing loading and above average pilot ability required. The RV's on the other hand are a very docile and forgiving aircraft. Good Luck Bill Mahoney Sherman, CT RV-6 N747W ________________________________________________________________________________
Date: Feb 10, 1998
I can't wait for your answers. I haven't ordered my kit yet but... my reasons for RV: *Proven construction methods. *New engines/props avail @ good price through Van. *Lots of local builders (Houston, TX) and lots of builders elsewhere. *Good support through Van and sites such as this. *Tandem seating (RV8) is great for aero/formation. *Resale (look @ Trade-A-Plane) *Quick build looks great *Conservative design with superior results. *Good short field capability for that time the engine doesn't want to run anymore (i.e. good survivability) *Easier to repair *More expertise available for metal vs. plastic. *More of em @ airshows. call sign "TRAASH" ________________________________________________________________________________
Date: Feb 10, 1998
<< I have an RV-4 with over a thousand hours on it, and the manual elevator trim is simple, light, cheap and effective, and dependable. Not sensitive at all in my opinion. Why complicate matters unecessarily with electric trim? Now electric flaps is a must have in the RV-4 because of being in the way of the passengers foot, and other minor problems. That is partially why the RV-8 is electric flaps standard. Just an opinion. Von Alexander >> I have an RV4 with over 450hrs on it, and the electric elevator trim is simple, light, a little more expensive and also dependable. It is not to sensitive, as some people claim ( usually those who dont have it or havent given it a chance). This subject is a 50 50 toss up! Both systems work equally as well. The reason I went with the electric over the manual is one less large lever in that small space your sitting in. The electric trim IMHO is not that difficult to install either. However does require a little more time to install and a little more attention to detail than the manual. Ryan Bendure ________________________________________________________________________________
Date: Feb 10, 1998
<< That's why I'm building a -4, which is known by all to be the best RV model there is. You may hear from a few who are still unwilling to admit this so just ignore them. >> I agree John. Ryan ________________________________________________________________________________
From: "Ernest Kells" <ernest.kells(at)sympatico.ca>
Date: Feb 10, 1998
Martin: The comments by Al Mojzisik and others were right on!!! I took a structured approach, since it is very easy to get taken up with a shiny airplane. I love them all, sleek, fast, aerobatic, etc. I started a checklist to help me. In it I defined my flying objectives, including ALL of the criteria that affected these objectives. I listed this in detail. The following list by Al is great, but only a start. Although not necessary, I determined a weight factor for each factor. Then I measured each available kit and added it up. I definitely did not start out with an RV-6A in mind. The Vans didn't win any category. It was just "close to best" in an overwhelming number of factors. For instance, cross country cruising with my wife is important. It's nice to be fast - Vans a/c are near the top, but take a look at anything faster. Some of them can't carry diddly squat. The RV is a flying station wagon. I didn't have one factor where the Van's performed poorly. I went to Oshkosh last year with the sole purpose of researching my checklist. I attended workshops on each construction type, talked to many builders, vendors, etc., etc. For my needs (my type of building skill, time requirement, cost, type of flying etc.), Vans was definitely the overall winner - wasn't that close. You will have to have your own criteria based upon your own needs. By the way, go out to the airport and look at the military, commercial and general aviation aircraft sitting around - DC-3 (early 30's) to the new stuff. The construction techniques will look pretty familiar to any RV builder. There is a message there. Happy Building (it will probably be an RV)!!! >Take note of one fact....RV builders DO NOT have to defend one aspect of >the airplane they have chosen to build. >i.e.: Materials used in construction > Construction technique > Design configuration > Performance (As published by kit Mfger.) > Engine (As suggested by kit Mfger.) > >And I'm probably overlooking a few. One other consideration. Just try to >find an unhappy RV builder who has completed his mission! (Just my >opinion) Al ________________________________________________________________________________
Date: Feb 10, 1998
[snip!] > However, the rub is still there. DWG 49 shows > a 3/4" tab on the back of the F683A that must get screwed to the > top of the seat floors to tie things together. [big snip] I just screwed it to the top of the seat floors; I don't have the manual trim down there so I can just remove the screws that hold the fuel valve down and the side screws on the F-683B to take the plate off. As far as your proposed solution, you look like you've thought this through pretty well, and what you propose should work, but I'd like to suggest a few solutions that may be simpler and/or cleaner. A) Cut off the seat floor flange in the area of the F-683B and install F-683B with the tab underneath the seat floor. I have seen a few that look like they were done this way -- at least the tab went under the seat floor, I don't know if they slotted the seat floor or cut the flange all the way off. B) Bend the back tab of the F-683B down 90 deg. and screw it to the floor flange (nutplates on the back side of the floor flange). This assumes you could find two places to drill holes that are clear of the plumbing. C) Rivet some small pieces of .063 angle to the outside edges of the F-683B and screw those to the front of the seat floor flange. Just a few ideas. Sounds like you have a handle on it now however. Randall Henderson, RV-6 randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Feb 10, 1998
I have a Sterba 68 X 68 performance prop for sale, $350., that I used on my -4 with an O-320 E2D. Worked great but can't use anymore since I'm installing an O-360. ________________________________________________________________________________
From: "Mark S. Jennings" <markjenn(at)chinook.halcyon.com>
Date: Feb 10, 1998
You've already gotten alot of good feedback but I'll weigh in. For the better part of two-years I've been looking at an RV-8 vs. a Lancair Super ES. (These are not really comparable, I know, but I was also trying to decide whether I wanted a do-everything bird that could replace my Bonanza or just get a sport bird for fun flying.) I decided that I would be happy flying either. What I needed to concentrate on was which one I was going to be happier with during the construction phase. So I built an epoxy canoe over last winter and helped a friend with some riveting work. Both constructions resulted in good results, but I had much, much more fun riveting than I had doing lay-ups and sanding. I also hated my garage becoming a toxic waste dump every few days and stuffing my garbage can full of disposable plastic, brushes, sandpaper, cups, etc. It really offended my sensibilities about the environment and waste. Wearing a respirator is no fun either. Some people enjoy working with composites, I didn't. You should try it and decide for yourself. Another key factor for me was deciding which one I was more likely to be successful in completing. Even proven designs like the RV and the Lancair still have very low completion rates. I wanted to bump my personal percentage as high as possible. Here again, I felt like the RV was the better choice. If you get into trouble on the RV, you have tons of people to turn to: your local A&P who knows sheet metal, all the local RV builders, this list, Van's etc. This list is a HUGE consideration. There is nothing comparable in the Lancair world. They have a lame web site discussion forum which gets about three messages a month and has little if any participation from builders. Their other resource is the newsletter which is skimpy. Then there is rec.avation.hombuilding (may not be exactly right) which is one step down from CB radio. This list, flawed as it is, gives you a virtual sense of community as you raise your young bird. In anything, feeling like you are not alone and working in a team can make a huge difference in your ability to carry through adversity. Another consideration are the initial barriers to entry. I wanted to QB, so with the RV-8, I only have to pony up $2K or so for a tail kit and some starting tools. Worst comes to worst, I'm out $2K and walk away with a great experience. With the Lancair, I was looking at ponying up $55K or so. I'm also concerned about Lancair's stated policy to try and pursue the certified and kit markets simultaneously. I wonder if they can do this. It seems to me that the business models are drastically different. I will predict right here and now that if the Columbia does well, that they will drop or sell off the kit market. Conversely, if the Columbia does poorly, I predict they will go bankrupt. Either doesn't bode well for a builder with a half-completed 320 4-years from now. I have still not pulled the trigger to order my tail kit, but this has to do with my time availability, not the RV. I'm waiting to see what the RV8A looks like and to go fly one this spring at Van's. I'd like to see that the QB's are flowing in the pipeline and get some early feedback on quality. But if/when I do pull the trigger it will be an RV (unless something else comes along). Again, if I had to give you one thought, I'd say to concentrate on what you would enjoy building, not flying. A completed RV-8 will be worth 1,000 times more to you than a better flying bird that didn't get done because you got sick (maybe literally) of pumping nasty smelling toxins into disposable cups. Good luck, - Mark -----Original Message----- From: Martin Quartim <martinq(at)cris.com> Date: Monday, February 09, 1998 10:46 PM Subject: RV-List: RV x Lancair > > >I am about to make a decision and your opinion is important. After days of >research I am in doubt between the Lancair MKII 320/360 and RV 6/8. I >researched about Velocities, Cozys, Glasairs, Pulsars, 1/4 share Cesna 182, >and even BD-5s..yeah I thought about it, deadly fun huh! > >The reasons why I picked the RV and Lancair is because of the fact they are >fast for Xcountry and can aerobatic. > >Well folks, gulp....here it goes > >Why should I get and RV instead of a Lancair? > >am I wrong to think that the only difference in cost is the kit it self ? >It seems that other then the kit everything else will cost the same. I am >planing to get an OH IO-320, fix prop and Minimum VFR setup(planing to fly >only in good weather). In this configuration, I figured that a Lancair 320 >will run about $ 50,000 and the RV6A about 40,000.00. > >I hope I can start by having your friendly support :) > >thank you > >Martin > >8X -Otus- 8X VF-17 "The Jolly Rogers" >"We're the Jolly Rogers, Who the hell are you?" > > > > > > ________________________________________________________________________________
Date: Feb 10, 1998
Anybody that asks this crowd about an Lancair vs. RV must have their mind made up and just want validation... :) Of course the RVs are the best value, etc. Just plop your money down and get started! Richard E. Bibb RV-4 N144KT Oak Hill, VA rbibb(at)fore.com ________________________________________________________________________________
Date: Feb 10, 1998
<< Tank dies from Cleaveland...questions. Are these for dimpling the tank mounting screw holes? Are they usable elsewhere in the building project? What rivets need 'shaving' if these dies are not used? >> Dennis, The dies of for the -3 (3/32") rivets. When you rivet the tanks the pro-seal tends to lift the rivets up off the skin slightly. Some builders will shave these rivets down but there is really no need to do this unless you're looking for perfection. The tank dies dimple a bit deeper and allow the rivets to fit closer to flush. They indeed make a difference. Some builders have used these dies on substructure which must be dimpled (wing ribs & fuselage bulkheads). The skins seem to lay a little tighter. Although it's hard to really tell a difference. Rick McBride RV-6 N523JC sold RV-8 80027 wings ________________________________________________________________________________
Date: Feb 10, 1998
<< I hope I can start by having your friendly support :) >> SUPPORT is the "key" word, my friend. There are lots more RV's being built and flown. I have my doubts about the Lancair completing for only $10,000 more than a similar RV. Method of construction is quite different. Your main choice will be composite versus conventional construction. Tool cost does not count, since tools maintain their value, and there is "always" someone looking for good aircraft tools. GOOD LUCK on your choice! ________________________________________________________________________________
Date: Feb 10, 1998
In a message dated 2/10/98 3:03:31 PM, you wrote: <> Not me. I want both. ________________________________________________________________________________
Date: Feb 10, 1998
Subject: Re: RV x Lancair (toxic dump)
<< I also hated my garage becoming a toxic waste dump every few days and stuffing my garbage can full of disposable plastic, brushes, sandpaper, cups, etc. It really offended my sensibilities about the environment and waste. Wearing a respirator is no fun either. Some people enjoy working with composites, I didn't >> Mark makes a point which I have been meaning to comment on. I worked with the early epoxies (safety-poxie) and built a composite fuselage. My sensitivity got so bad that I can not get within a mile of the stuff. Once you start a composite airplane, the market is very slim to buy a half built kit because you can not really inspect the quality of workmanship. I would never buy a non flying composite for that reason. This is not true with metal aircraft. It is very inspectable. Bernie ________________________________________________________________________________
Date: Feb 10, 1998
Subject: Calculated perf difference for step changes my mind!
The previous thread of discussion for installing steps got me to thinking about the step again. So I dug out Mr. Hoerner's fluid-dynamic drag book and cranked out some numbers. Assumed two steps and a 160knot cruise at 6000 ft. The Reynold's number is about 200 thousand which is right where the drag coeficient make's the adjustment between separated and attached flow. I assumed the worst case of separated flow with a drag coef.=.10. The drag calculates out to 1.3 pounds or .7 horsepower. If we had two exactly equal airplanes ,except for two steps, at exactly the same power, the one with out the steps would be less than 10 seconds behind the clean one in one hour! Think I will go ahead and install one step! Has anyone else done this and got any significant result? Bernie Kerr 6A fuselage SE Fla ________________________________________________________________________________
Date: Feb 10, 1998
Subject: Dimpling made easier
This is a repost because my server was down and I don't know if it went through the first time. To make your dimpling task a little easier check out this web page for a neat attachment for your C Frame tool. http://www.softcom.net/users/bud/cframe.htm -- Bud Newhall bud(at)softcom.net __|__ __|__ ____(+)____ ____(+)____ ' ' ' ' ________________________________________________________________________________
Date: Feb 10, 1998
> ... If we had two exactly equal > airplanes ,except for two steps, at exactly the same power, the one with out > the steps would be less than 10 seconds behind the clean one in one hour! Some time ago David Fried calculated the drag for baggage pods and a tip light set, the baggage pods cost 2.8 mph and the tip light set cost 0.3 mph. Search the archive looking for "drag coefficient" to see his math. This tells me: add a set of Tracy Seylor's gear leg fairings and it will cancel out the drag from tip lights and a couple of steps! Mitch Faatz San Jose, CA N727MF (reserved) RV-6AQME working on the sliding canopy... ________________________________________________________________________________
Date: Feb 10, 1998
Subject: Re: IFR RVs and the FARs
Subject: Re: RV-List: IFR RVs and the FARs "6) Certain equipment must be operational to fly ILS approaches to the lowest minimums. - Excluding Category I and Cat II approaches which require that both aircraft and pilot be certified for these approaches, you need glideslope receiver, marker beacon receiver, and a two-way radio, of course." I don't know if this is of great interest to the RV community, but FWIW: CAT II ILS approaches DO require special aircrew and aircraft certification. CAT I ILS approaches DO NOT generally require anything special from the pilot beyond being instrument rated and current. Most CAT I ILS approaches bring you down to minimums of 200'AGL/ one-half mile visibility. There are exceptions (this is aviation, right?). If you'd like a few examples of exceptions (in which case your project must be done) e-mail me off-list. Tim - Pittsburgh - Pre-empennage garage prep phase ________________________________________________________________________________
Date: Feb 10, 1998
OK, here is an answer from a non-RV builder--but I may yet build one! I work in non-destructive testing at the Oregon Air Guard. F-15's have a lot of composite parts as well as aluminum and titanium. Because these planes are flown to the edge of the envelope and beyond, we check them regularly for cracks, delaminations and water entrapment in composite structures. Metal is easy. You can see a crack. Use a pencil eraser on the rivets & wiggle it to check for tight rivets (not an official Air Force procedure, but one I learned along the way). If you see a line you suspect might be a crack, press on the metal alternately on opposite sides of the line. Or use a hand lens for a better view. Composites are another problem. We X-ray composites for water entrapment and other problems. Got an x-ray unit handy? We also do ultrasonic testing. You do have an ultrasonic unit in your garage, don't you? No? Then I guess you are stuck with the tap test. Use a quarter and tap all over the surface, covering every half inch or so, listening for any change in sound that might indicate delamination. Yes, all over the structure. A recent crash of a D4 Fasination that was written up in Western Flyer also sheds some light. Apparently, someone had sat or fallen against the leading edge of the wing and broken some nose ribs, made out of composite. This damage was not apparent from the outside--but damage metal and you see a dent or crack. Anyway, the ribs reportedly broke away after several flights following the damage. It happened just after takeoff with 2 aboard and the plane began rolling as it dove into the ground. Not the way I want to go. Flying is not very forgiving. I want to know the condition of my flying machine as well as possible before I take off. That's a lot harder with a composite structure. Go for the RV! Dick Scott Interstate Cadet NC37301 ________________________________________________________________________________
Subject: AKZO primer solvent
Date: Feb 10, 1998
Greetings folks, I recall seeing a post in here saying that Akzo primer is difficult to clean out of the gun with acetone...which I've been using to clean up Variprime. I'm thinking of buying some Akzo...the cost savings and quality of the product seems exceptional. But, is the stuff a mess to clean up? That would negate the savings, in my opinion. The Aircraft Spruce catalog doesn't show any special reducer/solvent or mention the need for it. Thanks! Brian Denk -8 #379 5 year wedding anniversary this weekend...shall we spend it riveting wing skins? NOT!!! ______________________________________________________ Get Your Private, Free Email at http://www.hotmail.com ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Subject: Re: Calculated perf difference for step changes my mind!
Date: Feb 10, 1998
-----Original Message----- From: Kerrjb(at)aol.com <Kerrjb(at)aol.com> Date: Tuesday, February 10, 1998 6:54 PM Subject: RV-List: Calculated perf difference for step changes my mind! > >The previous thread of discussion for installing steps got me to thinking >about the step again. So I dug out Mr. Hoerner's fluid-dynamic drag book and >cranked out some numbers. Assumed two steps and a 160knot cruise at 6000 ft. >The Reynold's number is about 200 thousand which is right where the drag >coeficient make's the adjustment between separated and attached flow. I >assumed the worst case of separated flow with a drag coef.=.10. The drag >calculates out to 1.3 pounds or .7 horsepower. If we had two exactly equal >airplanes ,except for two steps, at exactly the same power, the one with out >the steps would be less than 10 seconds behind the clean one in one hour! > >Bernie Kerr 6A fuselage SE Fla > Let me quantify the 10 seconds in an hour to plain ol' MPH: 0.7/160 = 0.0044, the fractional horsepower change, so dividing by 1/3 we get 0.0015, the fractional MPH change. Then 0.0015 x 185 MPH = 0.3 MPH. That's it guys, the drag penalty for two steps at 185 MPH. If I put 240 steps on my 6A it would still be as fast as my Skyhawk! Dennis Persyk 6A fuselage Barrington, IL ________________________________________________________________________________
Subject: Lineart RV Wanted
Date: Feb 10, 1998
I'm looking for a line-art drawing of an RV, to grace the cover of the Western Canada RVator. Anyone know where I can get one? I have a GIF photograph that I've tried to convert using Adobe Streamline, but the results haven't been satisfactory. Tedd McHenry Surrey, BC [-6 tail] ________________________________________________________________________________
Date: Feb 10, 1998
Subject: Re: tank dies
<< the tank dies are just a pubic hair deeper. >> Now for the big question. An RCH or a BCH? -GV ________________________________________________________________________________
Date: Feb 10, 1998
Subject: Re: AKZO primer solvent
Brian, ... I've been using acetone for the Dexter (nee AKZO) primer for years now (way to many years ...:^) and had no problems. It's pot life is in the order of 4-8 hours, so you don't have to rush too quickly after painting. Another advantage of this primer is that you can use acetone to clean up Sharpie pen writing, grease stains (from the rudder cables) etc. off the painted surface after it's cured. Try that with Variprime...:^) ... Gil (use acetone to clean it all) Alexander ... just starting the fuel valve console ... need to re-dimension due to the use of the Andair fuel valve (makes Vans part look like it came of a tractor). > >Greetings folks, > >I recall seeing a post in here saying that Akzo primer is difficult to >clean out of the gun with acetone...which I've been using to clean up >Variprime. I'm thinking of buying some Akzo...the cost savings and >quality of the product seems exceptional. But, is the stuff a mess to >clean up? That would negate the savings, in my opinion. The Aircraft >Spruce catalog doesn't show any special reducer/solvent or mention the >need for it. > >Thanks! > >Brian Denk ------------------------------------ RV6A, #20701, finishing kit "REPLY" sends to entire RV-list mailto:gila(at)flash.net to reply privately ________________________________________________________________________________
Date: Feb 10, 1998
Martin - As one who recently went through the same process your are I would like to make the following suggestions as a minimum: 1) Find several local builders of both RV's and Lancair's and spend at least one afternoon/evening with them working on their project. You need to get a feel for the rivet vs layup/sanding debate to see which construction method you dislike the least. 2) You must fly each airplane you are interested in at least once. Going to an air show like Sun 'n Fun or Oshkosh is a great place to meet lots of builders and get factory demo rides. 3) If money is an issue, re- check your kit cost figures. Unless you are planing on purchasing an RV Quickbuild Kit a Lancair is substantially more expensive. 4) While looking into both the Lancair and RV you might as well take a closer look at a Glasair - they put out a great kit. Regards, Mike Kiess (GIII on the way!) ________________________________________________________________________________
Date: Feb 10, 1998
Subject: Re: Instrument panel design & spacing
> The cost is $99.00 for the basic program to $199.00 for the Pro copy. >They also have a web page WWW.panplnr.com > On my browser the actual sute URL is www.panelplanner.com ________________________________________________________________________________
Date: Feb 10, 1998
Subject: Re: Dimpling made easier
> > To make your dimpling task a little easier check out this web page for > a neat attachment for your C Frame tool. > > http://www.softcom.net/users/bud/cframe.htm > Looks like someone went to a lot of trouble to make the dimple c-frame tool more time consuming to use. A simple spring works just great and there is no need to set you hammer (I prefer a plastic mallet) down when moving the aluminum piece you are dimpling. ________________________________________________________________________________
Date: Feb 11, 1998
I built a composite plane and became very sensitive to the epoxy. The stuff stinks and is very messy. I logged over 1000 hours of sanding!. You can't stop in the middle of a part or it will be ruined. I spent many evenings up past 2:00 AM because I started something that I thought would not take too much time and found out otherwise. You get dust everwhere. Fuel tanks are difficult to seal and be sure that they won't leak. My RV was much easier to build and not nearly as messy. No bad smells, very little sanding, almost no dust. You can stop at any time and come back later to pick up where you left off. I have flown both the Lancair and my RV. The RV is much more fun to fly. At a recent Young Eagles Rally, a Lancair 320 could not keep up with me when climbing out to the practice area. It was only after I leveled off that he was able to catch up with me. On a short 40 mile cross county to another airport, I took off behind him and and landed as he was turning off of the runway. He beat me by less than two minutes. The RV will easily handle a grass strip, no way will my friend land his Lancair on grass. I have done aerobatics in both planes. The RV wins hands down. Insurance for a retractable gear plane is much higher than the RV. Building time for composite vs metal is much higher. Cost of Lancair vs RV is nearly double at best. The Lancair is a great plane. The RV is better. Jim Cone RV-6A Flying ________________________________________________________________________________
Date: Feb 10, 1998
> > >I am about to make a decision and your opinion is important. After days of >research I am in doubt between the Lancair MKII 320/360 and RV 6/8. I >researched about Velocities, Cozys, Glasairs, Pulsars, 1/4 share Cesna 182, >and even BD-5s..yeah I thought about it, deadly fun huh! > >The reasons why I picked the RV and Lancair is because of the fact they are >fast for Xcountry and can aerobatic. > >Well folks, gulp....here it goes > >Why should I get and RV instead of a Lancair? > >am I wrong to think that the only difference in cost is the kit it self ? >It seems that other then the kit everything else will cost the same. I am >planing to get an OH IO-320, fix prop and Minimum VFR setup(planing to fly >only in good weather). In this configuration, I figured that a Lancair 320 >will run about $ 50,000 and the RV6A about 40,000.00. > >I hope I can start by having your friendly support :) > >thank you > >Martin > >8X -Otus- 8X VF-17 "The Jolly Rogers" >"We're the Jolly Rogers, Who the hell are you?" > Martin, I think that it would be hard to beat the "bang for the buck" of an RV. You have an extremely reliable aircraft when you're done that is built by tried and true methods. Yeah, it's fast and maneuverable, but it's also quite strong and of extremely sound design. As far as construction goes, this bird is designed to be built in a garage - literally. Aside from the purchase of about $1000 of specialized aircraft tools, the rest of the equipment in my garage has been bought at Fred Meyer or built out of hardware store parts. Very basic in construction. Most of my head-scratching comes not from "how do I do this", but "how can I do this BEST". But the real kicker for me is the overwhelming support from the multitudes of RV builders out there. It's almost cult-like. If I have a real head-scratcher, I post my problem on this list and nearly need to buy a bigger hard-drive to handle all the responses. It's all "been-there-done-that" advice, too. Now stop analyzing and speculating, pick up the phone, call Van's and order the best kit plane in the world - the RV6!! Sorry, you -4 guys.... :-) > > > Jon Elford RV6 #25201 Elevators - Wings ordered!! ________________________________________________________________________________
Date: Feb 11, 1998
I started a Composite Aircraft over a year and a half ago, about 6 months into the project - Jerry Stallings the designer of the Air Master - was killed in a plane crash with the prototype, We took a Sawzall to the Tail Feathers and the lower half of the main fuselage $6000.00 later The support and the amount of people involved with the RV was enough to sell me, but then I made the fatal mistake of flying one. Its one great airplane. BSivori.@AOL.COM N929RV (Reserved) Wings & Tanks ________________________________________________________________________________
Date: Feb 11, 1998
Subject: RV's vs Composite
From: bob.char.reeves(at)juno.com (Robert L Reeves)
My $.02 worth, I saw the D4 Facination after the crash. I doubt if I will ever even sit in a Composite plane again. The D section of the wing, that I understand is built by a professional company, came apart like it had been assembled with waxed paper laid between the layers of material. I thought the stuff was suppose to bond together and form a single unit. I have never felt good about composite construction, mainly because of the inability to inspect the material after its made. Now I'm even more convinced that for amateur builders its not the way to go. I had flown in the D4 just a couple weeks previous to the crash. It was a neat flying airplane and the owner was a really great guy. Bob Reeves Building Bearhawk, Flying RV-4 Hidden River Airport, Sarasota, Florida _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 11, 1998
> >Greetings folks, > >I recall seeing a post in here saying that Akzo primer is difficult to >clean out of the gun with acetone...which I've been using to clean up >Variprime. Brian, you are just determined to cause trouble around here aren't you? The Azko/Dexter is not hard to clean up, you just have to make damn sure you do. If allowed to harden, all of the acetone in the world won't help. I see two big advantages to this stuff. 1. Nobody will argue about the corrosion protection it offers. 2. It is almost scratch proof. I have been able to cut, sand, polish, assemble, disassemble parts primed with this stuff and it is bulletproof. The downside is that it is toxic. I always spray it outside. If I can't stand upwind of it, I wear a homemade fresh air supply. If there is a little breeze, I'll just use a respirator. Overall, I find it well worth the trouble. Good luck John ________________________________________________________________________________
Date: Feb 11, 1998
From: "robert l. wadsworth" <rv6_wads(at)compuserve.com>
Subject: Cleveland Tools
Does anyone have the phone number/email address for Cleveland Tools? I am having difficulty finding one. Thanks Robert- Athens, GA ________________________________________________________________________________
Date: Feb 11, 1998
Subject: Re: Oil Cooler
<< With the baffle kit from Van, there was a piece of aluminum. It is about .040 and about 8"X11". What is it to be used for? I spoke to one guy who riveted a doubler that was the same size as the rear baffle to the left rear baffle. Is that appropriate? Needed? >> Such a doubler is necessary if you are going to mount the cooler to the baffle system. Keep the coolers from TMR in mind- about $70, for the size to fit the 320's and 360's (with AN fittings). Check six! Mark HR II 206 hrs At that rate, my engine should last 20 yrs! ________________________________________________________________________________
From: "robert dziewiontkoski" <dzflyer(at)email.msn.com>
Subject: Re: Cleveland Tools
Date: Feb 11, 1998
Cleaveland Tools: www.cleavelandtool.com -----Original Message----- From: robert l. wadsworth <rv6_wads(at)compuserve.com> Date: Wednesday, February 11, 1998 8:24 AM Subject: RV-List: Cleveland Tools > >Does anyone have the phone number/email address for Cleveland Tools? I am >having difficulty finding one. >Thanks > >Robert- Athens, GA > > > > > > ________________________________________________________________________________
Date: Feb 11, 1998
---------- Mark, Thanks for the reply. Too late on the recommendation for the alternate oil cooler. I bit the bullet and ordered from Van ($220). Ouch!! What's your opinion. Baffle mount or fire wall mount??? I enjoy reading your list notes. Thanks, Bob San Antonio ________________________________________________________________________________
Subject: Cutting large circles in Aluminum
Date: Feb 11, 1998
Have a tip that may be worthwhile: To cut large circles in aluminum (ie: panel, ect.) I use a laminate trimmer with a carbide router bit. For those that don;t know, a laminate trimmer is basically a small router that can be easily helf in one hand. You will need to make a simple circle cutting jig for your router - I use Lexan for my router jigs, but any good quality plywood would work fine. 1. Locate the center of the hole. 2. Set deisred radius on the router jig. 3. Attach jig to aluminum. 4. Cut away! If anyone wants/needs more specific instructions, E-mail me off list. I will try to come up with a sketch or photo if needed. Bob ________________________________________________________________________________
Date: Feb 11, 1998
Subject: Primers and the new builder
For those of us just starting the emmpenage, primers are not re-hashing an old subject. But they are certainly confusing! I've come to the conclusion that I'm not going to use Vari-prime because I don"t want to have to topcoat interior parts,(more weight,hours, fumes,etc..). A fellow wise old RV builder in my area has introduced me to another DUPONT product that you may want to check out. It is "CORLAR"-epoxy primer (light gray),824s and activator 826s. It is designed as a primer for use under IMRON polyurethane enamel, but as an epoxy it can be overcoated with most topcoat paints except for laquer. Any feedback or experience with/about CORLAR welcome. M.HANSON RV-6A HS STARTED,Jig is up...On my way! paintbox(at)rconnect.com ________________________________________________________________________________
Date: Feb 11, 1998
> >Does anyone have the phone number/email address for Cleveland Tools? Try 1-800-368-1822 or 1-515-432-6794 Tim Houle RV6 emp *************************** Tim Houle email: eprth(at)kneehill.com *************************** ________________________________________________________________________________
Date: Feb 11, 1998
You wrote: > > > ><< the tank dies are just a pubic hair deeper. >> > >Now for the big question. An RCH or a BCH? > >-GV > Gary, I always use an RCH as they are much finer :^) Ed Cole ________________________________________________________________________________
Date: Feb 11, 1998
Cleaveland Tools 1-800-368-1822 -Jeff RV-8 #80563 Suwanee, GA Working on Rudder > >Does anyone have the phone number/email address for Cleveland Tools? I am >having difficulty finding one. >Thanks > >Robert- Athens, GA > > > > > ________________________________________________________________________________
Date: Feb 11, 1998
A ><< Does anyone have full size diagrams of instruments available via the > internet for downloading and printing in order to layout and plan the > instrument panel design? >> > I made up some cardboard templates of instruments, switches, guages, etc.(obtained from ACS catalogue) , stuck some magnetic tape strips on the back of each. I then cut a full size panel out of 18ga mild steel sheet, and scribed some reference lines (1 in spaced)onto the surface. Now I can put the instuments, switches, gauges etc. onto my panel and fiddle with the arragngement till I find something that I like. This isn't as fancy as a computer generated template but it works.....! You can also hang it on your wall....makes a great conversation piece as also. Well onward and upward. Marc DeGirolamo -4 #3289 Saskatoon,SK. Canada ________________________________________________________________________________
Date: Feb 11, 1998
So did you order your RV yet? Well, what the heck are you waiting for? ________________________________________________________________________________
Date: Feb 11, 1998
> > To make your dimpling task a little easier check out this web page for > > a neat attachment for your C Frame tool. > > > > http://www.softcom.net/users/bud/cframe.htm > > > Looks like someone went to a lot of trouble to make the dimple c-frame > tool more time consuming to use. A simple spring works just great and > there is no need to set you hammer (I prefer a plastic mallet) down when > moving the aluminum piece you are dimpling. Actually I think it looks pretty good. I find I can get a much better feel for when the dimple is "done" without the spring in there. I removed the spring and used a bent piece of aluminum against the shaft to hold it in whatever position I put it, but I think his solution look even better. Another clever thing that a fellow builder did (Kevin Lane) was to clamp a laser pointer to a rafter above the work area and point it directly at the tip of the dimple die. The little red dot that was always over the die made it a lot easier to position the aluminum without "feeling" for the dimple die like you otherwise have to do. A large platform with strips of carpet on it and fits around the arbor to support the large skins at the level of the dimple die is also a REALLY big help. Randall Henderson, RV-6 randall(at)ed.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Feb 11, 1998
<< Mark, Thanks for the reply. Too late on the recommendation for the alternate oil cooler. I bit the bullet and ordered from Van ($220). Ouch!! What's your opinion. Baffle mount or fire wall mount??? Hmmmmm........probably firewall for that big sucker. You might have a bit of cooling problems (judging from what I've read on the list), but some claim it works fine. Go figure. Why don't you sell that thing, and get one of those cheeeeep ones? I enjoy reading your list notes. Thanks- I try to keep it light, but some refuse to "get it". Thanks, Bob San Antonio Hey- which PRIMER are YOU using? ;-) Mark ________________________________________________________________________________
Date: Feb 12, 1998
Subject: Re: Lineart RV Wanted
tedd(at)idacom.hp.com wrote: > I'm looking for a line-art drawing of an RV, to grace the cover > of the Western Canada RVator. There's a few gracing various Web pages... Try Van's page for 3-view drawings, or mine <http://www.pec.co.nz/~frankv/homebilt.htm> for a 3-view partly filled in. Also <http://www.flash.net/~gila/> has a nice oblique view. Frank. ________________________________________________________________________________
Date: Feb 11, 1998
UAU Guys ! the response has been tremendous! Thanks to all of you that took the time to help me getting better informed. I will do as Mike says below and not rush into any decision. I am sure I will be meeting some of you folks very soon. In the safety side, I can say that there were fatal accidents involving RVs and Lancairs. Actually in the last 5 years there were more accident with RVs then with Lancairs, probably because there are more RVs out there. May be I am wrong but I don't remember reading anything about fatal accident of either plane due to airframe problems. In most cases the accident was due to ENGINE FAILURE and pilot improper training. Many died because the engine stopped at low altitude and were not prepared to act promptly. The RV can land shorter in any farmers field. The Lancair seems to be able to glide further giving more landing fields options. Thank you all for the positive response, Check those engines twice before take off and Happy Landings:) Martin p.s. if you haven't checked http://www.ntsb.gov you better do it now > >Martin - > As one who recently went through the same process your are I would like to >make the following suggestions as a minimum: > >1) Find several local builders of both RV's and Lancair's and spend at least >one afternoon/evening with them working on their project. You need to get a >feel for the rivet vs layup/sanding debate to see which construction method >you dislike the least. > >2) You must fly each airplane you are interested in at least once. Going to >an air show like Sun 'n Fun or Oshkosh is a great place to meet lots of >builders and get factory demo rides. > >3) If money is an issue, re- check your kit cost figures. Unless you are >planing on purchasing an RV Quickbuild Kit a Lancair is substantially more >expensive. > >4) While looking into both the Lancair and RV you might as well take a closer >look at a Glasair - they put out a great kit. > >Regards, > >Mike Kiess (GIII on the way!) > > > > > > > > ________________________________________________________________________________
Date: Feb 11, 1998
Saw your mail mentioning TMR coolers. Can you tell me more about them? The Stewart Warner and Allied Signal (Harrison) models don't fit my wallet. I'm putting an IO-360 in my -4 replacing an O-320 w/Van's auto type cooler, which didn't quite handle the job. Pete ________________________________________________________________________________
Date: Feb 11, 1998
In a message dated 2/10/98 9:00:25 PM, you wrote: <>... I was turned on to a Sherman Williams product through the list, and although they didn't have the one suggested, they did have something called Reducer #54. It works exceptionally well and cost roughly $16.00 for a gallon. Get some Alumiprep, Akzo primer, Sherman Williams Reducer #54 and a Harbor Freight Air Brush (currently on sale for $5.97)... be sure to get the $.99 adapter to tie it into your compressor... and you'll be in priming heaven. Jeff Carpenter RV-6 Altadena CA wstcttprss(at)aol.com ________________________________________________________________________________
Date: Feb 11, 1998
Subject: RV-6 Empenage for sale
Listers, There is an RV-6 Empenage kit for sale in Columbus, Ohio. The person to contact regarding details of this empanage is: Trace at (614) 890-4328 I have not seen it yet but it is supposed to be completed except for the left elevator and trim tab and tips. All parts are there. The asking price is $850. This price also includes the full Orendorf video set. If you have any more serious questions you can e-mail me and I will forward them to Trace or better yet, call him direct. Al ________________________________________________________________________________
Date: Feb 11, 1998
I too used the "traditional" method of designing my panel -- made a template out of scrap (.032 al in this case) and taped pictures of the instruments on there. Up till now I would tell anyone who asked that there is no reason to buy a fancy computer program to do this. I work at a computer all day, and would rather spend my evenings in the shop! But I just got a chance to try out the Panel Planner, and I'm hooked! This is a really handy program. Maybe a little weak on the user interface, but not enough to really degrade its usefulness. It took me about 15 minutes to lay out a nice approximation of my panel, and I'm sure that if I had had it in the first place it would have saved me a lot of time puzzling over just what should go where. Randall Henderson, RV-6 randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Feb 11, 1998
Subject: Re: One exception
Keith, You my have missed the point on the Variprime thread. The point of the Variprime thread is to educate users of this product that DuPont intends it to be topcoated to provide a barrier against moisture. No one on the RV-List that uses Variprime needs to defend how they use the product. They can use it anyway they want to, just like they can build their RV's any way they want to. However, since you brought up the thread again I can only assume that you have some unanswered questions about some parts you have used Variprime on and have not topcoated. I would offer the following thoughts, and let me state right up front that these are my own, based on common sense and the fact that Variprime provides no moisture protection. ALUMINUM PARTS 1. If you have an Alclad part primed with Variprime and have not topcoated it, you still have the Alclad working for you and like one lister stated Variprime looks cool. Alclad is all most Censa's and Pipers have going for them, and you can always treat your RV with something like ACF-50. 2. If you have a NON-Alclad part primed with Variprime and have not topcoated it, I would suggest that you do. I believe NON-Alclad parts need to be protected from moisture. STEEL PARTS 1. If you have steel parts primed with Variprime and have not topcoated them, I would suggest that you do. I am not sure which of our RV steel parts are mild steel and which are 4130 (chromally), however the 4130 is highly resistant to rust and corrosion as compared to mild steel. I have chromally in my shop that is over 10 years old and has not been treated with anything and it is showing no signs of rust or corrosion. This is why most people that have Variprimed steel parts are not seeing any rust and corrosion, its not the Variprime, it's the 4130. Curtis Hinkley RV8 You commented: > > Martin, > > Take note of one fact....RV builders DO NOT have to defend one aspect > of > the airplane they have chosen to build. > i.e.: Materials used in construction > Construction technique > Design configuration > Performance (As published by kit Mfger.) > Engine (As suggested by kit Mfger.) > One exception: to topcoat or not topcoat primer ! ;-) ________________________________________________________________________________
Date: Feb 11, 1998
<< I will do as Mike says below and not rush into any decision. I am sure I will be meeting some of you folks very soon. >> I'll bet I know what your final decision will be!! ________________________________________________________________________________
Date: Feb 11, 1998
Subject: Arbor press/building wing spar
I have found a 1-ton arbor press that looks the right size for building wing spars. Looks just like the one Harbor Sales carries but less expensive. I think the one at Harbor is 1 1/2 tons. Anyone used a 1-ton with success? Jerry Calvert Edmond Ok -6a emmpenage ________________________________________________________________________________
Date: Feb 11, 1998
Subject: PARTIALLY COMPLETED -6A AVAILABLE
Completed; empennage, 1 wing and fuselage up to jigged bulkheads. My partner moving out of state and I'm starting a -8. We're willing to turn project over to a new builder..no charge for our labor. Maybe some tools too. Stan ..Yorktown, VA 757-867-7244 ________________________________________________________________________________
Subject: D4 Facination
Date: Feb 11, 1998
What was a D4 Facination and what part of the country was it at? ---------- > > I saw the D4 Facination after the crash. ________________________________________________________________________________
Date: Feb 11, 1998
Gary's Yellow pages say: clevtool@tdsi.net http://www.cleavelandtool.com 800-368-1822 515-432-6794 Don Jordan~6A wings~Arlington,Tx donspawn(at)juno.com _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 11, 1998
Martin: Many people have stated the same thoughts I have about your question, so I'll be brief. I chose the RV-6 over anything else because (1) I flew one, and it gave exactly the feel I wanted. Handling and TO/L qualities are more important for my mission than cruise speed (the RVs are plenty fast enough). (2) Another pilot, whose views I respect greatly, has flown the RV-6, the Lancair, and the Glassair. He advised me to avoid the Lancair because the lack of tail authority would disappoint me. I guess this is hearsay, but I respect his opinion. (3) I prefer working with metal to working with composites. (4) I found the tail-dragger appealing. (5) Builder support. Tedd McHenry Surrey, BC -6 tail ________________________________________________________________________________
Subject: Finishing Kit 6A Delivery Time
Date: Feb 11, 1998
boundary="----=_NextPart_000_0022_01BD3731.F6B7AE80" This is a multi-part message in MIME format. ------=_NextPart_000_0022_01BD3731.F6B7AE80 I received my 6A finishing kit Tuesday, 20 weeks after placing the order = on Sept 22, 1997. It arrived 8 weeks beyond the order verification = form's promised ship date. Many major items needed to continue are still = backordered: Engine mount, F631A canopy channels, nose gear, to name a = few. Have other builders incurred similar delays and omissions? Dennis Persyk 6A fuselage Barrington, IL ------=_NextPart_000_0022_01BD3731.F6B7AE80 http-equiv=3DContent-Type>
I received my 6A finishing kit Tuesday, 20 weeks after placing the = order on=20 Sept 22, 1997. It arrived 8 weeks beyond the order verification form's = promised=20 ship date. Many major items needed to continue are still backordered: = Engine=20 mount, F631A canopy channels, nose gear, to name a few.
Barrington, IL
------=_NextPart_000_0022_01BD3731.F6B7AE80-- ________________________________________________________________________________
Date: Feb 11, 1998
Subject: Primer Alternative
Yes, another comment on primers. I just read an article in the November issue of the Aviation Consumer on BOESHIELD T-9. It's sort of like the ACF-50 that Chris mentioned, but isn't as messy, and lasts longer. They rated it quite high as a moisture barrier. It dries to a waxy finish and lasts about 3 years before it should be recoated. I happen to have a can of it that I sprayed on the steel parts in my tail kit because I didn't want to prime them yet. No sign of rust in my damp garage. Because I am considering getting the RV-8 quick build kit when it becomes available, I will not be able to prime the inside of the wings and fuselage with the epoxy primer (Dextor/Crown Metro/Akzo) I will use on the interior of the tail section and airplane exterior. Van's does prime the interior of their quick builds with a Sherwin-Williams wash primer, but I don't think it's moisture barrier. So I think that the best alternative for those of us that want maxium protection is to spray the inside with something like T-9. I'll be happy to fax the article to anyone who wants it. And, to give credit where it is due, John Morgan at Van's also suggested using BOESHIELD when I was there. Mike Robbins RV-8 tail kit still in the box kitfox(at)gte.net, or for a quicker response, michael.j.robbins(at)boeing.com ________________________________________________________________________________
From: "Leslie B. Williams" <lesliebwilliams(at)email.msn.com>
Subject: Re: Camlocs...?
Date: Feb 11, 1998
Hi, Ron. Strange you should ask about that. I just the other day received 25 of the MS245-2 Receptacle, Floating, from Skybolt. Was not too happy. Price quoted was $2.79 each; billed for $3.07 each. Asked about mounting hole size before I ordered and was assured they were 3/32"; they are 1/8". Asked for a catalog which they said they would be happy to send; no catalog. Package was under 1# and I can put the parts in one hand; shipping charges by regular Fedex from Florida was $10.73. Total bill was $87.13 for just those. They are about twice as large ( 7/8" X 1 3/8" ) as the normal receptacles. They are made mostly of machined aluminum of unknown type so I don't know what corrosion problems will follow. I believe they will fit either type 2700 or 4000 Camlocs as the pin slot is 9/16" wide and that's what the sales person told me. But right now I wouldn't believe anything he said including that he would adjust the price, send me a catalog, check into the freight charges or honor the Return Authorization number that he gave me by phone when I called to query about this stuff. So to answer your question. I quess I'm still out to lunch on this. I have the new epoxy type cowl with the overlapping sides and intended to use the adjustable receptacles and camloc fasteners, both across the top and on the sides, instead of the hinges. I also intended to use soft 3/32 AN rivets to mount them on the sides because of the thin fiberglass and wanted the ability to adjust the holding tension. Until I try riveting a scrap of the cowl with an NAS cheater rivet to see how it holds up to the squeeze, I don't know if I will use them on the sides. The top will be okay because they mount on .040 aluminum. I could mount the receptacles on aluminum strips and then rivet the strips to the sides with the soft rivets which would keep the 1/8" rivet squeezing from crunching the fiberglass. I am finishing up some other things right now but will figure this out this weekend, I hope. I don't know if this helps or not. If you're not in a big hurry, I may have some extra receptacles for sale and I won't gouge you like Skybolt or Aircraft Spruce does without telling you first. Les Williams/RV-6AQ/Tacoma WA -----Original Message----- From: Ronald Vandervort <rvanderv(at)linknet.kitsap.lib.wa.us> Date: Wednesday, February 11, 1998 1:23 PM Subject: Camlocs...? >Hello Les, > How is your research going on the Camloc question? > > I just talked with a sales type at Skybolt, and he recommended >going with the 4000 series as it would hold up better in the long run. >i.e. less chance of holes wallowing out. > I note that Gary Vanremog suggested on a posting that 27S3 Series >are the ones to use. I shot him a note also questioning his views. > > By the way on the riveting of the top nose skin on my aircraft >along the right side where I had the rivet line running too close to the >edge; I put rivets in the "runout" holes then drilled out the quickbuild >rivets, and will use those holes to do the nose skin, thus requireing no >additional holes. > >Hope you are making good progress on that machine.. > >Ron Vandervort ________________________________________________________________________________
Date: Feb 11, 1998
Subject: ACS Catalog
If you need a new Aircraft Spruce catalog you can get one FREE! by ordering it oline at http://www.aircraft-spruce.com/spruce/order.cgi/01-38400?,catalog_order I got mine today. It cost them $4.00 just to mail it to me. -- Bud Newhall bud(at)softcom.net __|__ __|__ ____(+)____ ____(+)____ ' ' ' ' ________________________________________________________________________________
Date: Feb 11, 1998
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: Power system reliability
Last November, there was a lenthy post from a list-subscriber commenting on paralleled batteries. I didn't have time to do a proper response until now and the resulting document was quite lengthy . . . Individuals with an interest in the subject are invited to check out, "What's all This Battery Paralleling Stuff Anyhow?" at <http://www.aeroelectric.com/parallel.html> Bob . . . //// (o o) ===========o00o=(_)=o00o========= < If you do, > < What you've always done, > < You will be, > < What you've always been. > ================================= <http://www.aeroelectric.com> ________________________________________________________________________________
Subject: Left Elevator RV6A
Date: Feb 11, 1998
I have come to point of bending the tabs over in the area of the trim tab. According to instruction & video you are to install elevator in V-block then insert cut out wedge to bend tabs over. George in Video mentions drawing a line from edge of elevator skin and level to skin what distance though? Can someone shed some light for me appreciate it. Thanks again---- Mike Comeaux mcomeaux(at)cmc.net ________________________________________________________________________________
Date: Feb 11, 1998
>STEEL PARTS > *** snip *** >1. If you have steel parts primed with Variprime and have not topcoated >them, I would suggest that you do. I am not sure which of our RV steel >parts are mild steel and which are 4130 (chromally), however the 4130 is No parts are mild steel, all 4130, with some being heat-treated, which leaves a nice oxide finish on them. >highly resistant to rust and corrosion as compared to mild steel. I have >chromally in my shop that is over 10 years old and has not been treated >with anything and it is showing no signs of rust or corrosion. This is why See below .... >most people that have Variprimed steel parts are not seeing any rust and >corrosion, its not the Variprime, it's the 4130. Curtis, .... last year I was working on my tail tips (tail built circa 1991) and I noticed some brown spots on the horizontal hinge brackets. A little Scotchbrite and they prooved to be corrosion on the 4130 steel. These parts were solvent washed and Variprimed before assembly, and the tail has always been indoors in my garage. I live in a fairly dry area (Los Angeles - except for the past two weeks) and I bet my garage is drier than most hangars. This was done before I was told about the Dexter (then AKZO) primer by Steve Barnard, who was using it in his job at MacDonald Douglas (now Boeing). This epoxy is a much better seal than the Variprime, and based on my personal experience I would rate Variprime (with no top coat) as unacceptable for 4130 steel in RV external locations (mainly tail and aileron hinges). I now cadmium plate my steel parts, and will also epoxy prime all of those that are 'external' on my plane. ... Gil (very disappointed with Variprime) Alexander ... .. will probably make new brakets and CherryMax rivet them on ... after cadmium plating and epoxy priming. I really should build faster though ...:^) > > >Curtis Hinkley >RV8 ------------------------------------------------------- mailto:gila(at)flash.net Gil Alexander, Los Angeles, CA ________________________________________________________________________________
Date: Feb 12, 1998
Subject: Re: Primers and the new builder
<< A fellow wise old RV builder in my area has introduced me to another DUPONT product that you may want to check out. It is "CORLAR"-epoxy primer (light gray),824s and activator 826s. It is designed as a primer for use under IMRON polyurethane enamel, but as an epoxy it can be overcoated with most topcoat paints except for laquer. Any feedback or experience with/about CORLAR welcome. >> I used Corlar on the FRP for two Kitfoxes I built a while back. It's tough as nails but doesn't have any sacrificial qualities as a corrosion resistant primer. For that, nothing beats a strontium chromate epoxy primer, especially on steel. And then there's always that other duPont product, which shall remain nameless, that works fine on aluminium (sic). -GV -GV ________________________________________________________________________________
Subject: short story
Date: Feb 11, 1998
I had this on my computer because it had sent ot our RV Home wing news letter editors so I thought I would post it here in case anyone else was interested... Scott It "looked" like it should work! I was relating this story at one of our builders meetings recently, and thought I would share it with everyone. It is a good reminder for us to think about what we are doing, and to realize that things may not always work out as we would expect them to. This story happened quite a few years ago (well OK not too many years ago) so I may not remember all the details exactly. It begins with me doing my usual parking and greeting airplanes at the Copper State Regional Fly-In in Arizona. A couple of RV-6's were taxiing in, and being an RV builder myself I made sure that I got them parked in a good spot and said hello. The gentleman that got out of one of the airplanes immediately got on the ground and began looking into his cowling from the air outlet in the bottom. He then began laughing and jumped up and began teasing his friend about how slow his RV was. After things settled down I asked him to explain... He said that ever since completing his airplane his friend's had always been faster. Even though they were nearly identical in the way they were equipped. While flying in formation at altitude on the way to the fly-in; he heard a loud noise up front. While he was looking into what the problem was his wingman buddy noticed that his partner flying lead was suddenly pulling away "And Climbing". He called him on the radio and asked what the heck happened. Said it looked like he had just kicked in a turbocharger. Well, it turns out that while this person was building his RV he decided to design his own induction airbox with filter (I don't know whether the factory one was available then or not). What happened in route was that the whole thing fell of his carb. into the bottom of the cowling. It turns out that it was so inefficient that he had more power from the engine with the carb. just open to the bottom cowling area than he had with his home designed induction system that utilized ram air from the outside. Moral of the story? If you are going to deviate from the designers design. Be prepared to test and evaluate what ever you do so that you know what the real life effect is. Otherwise it is anybodies guess. It may "look" good, but until you prove it you really don't know. --------- End forwarded message ---------- _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 11, 1998
>>> I wear a homemade fresh air supply. John: I have a air pump off a medical unit to home make a freash air hood. Do you have any suggestions on builting or converting a hood to hook to it. Don Jordan~6A wings~Arlington,Tx donspawn(at)juno.com _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 12, 1998
Subject: Web page for Painting
* * * * The views expressed in this EMail are my own and do not represent the policy or position * * * * * * * * of the Farm Credit Administration. * * * * GV, You would not believe all of the responses and questions I have received off line of the RV-List on the Variprime thread. I have responded to all that have written weather they just wanted advice about painting or if they just wanted to tell me to stick this thread where the sun don?t shine. What this means to me is that we need to get this information out to the RV builders and since you have a very good (OK, GREAT!) Web page, I was hopping that you would consider adding a section that would have information on different painting systems. I could send you documentation from DuPont and PPG that you could verify before you place it on you Web page to make sure it?s accurate. I?m sure someone else could provide the same info on SW and other systems. This would provide the RV-List with another great resource like you?re yellow pages. Then the next time a paint or primer question comes up we could just point them at "GV's- Painting Systems for Your RV" or I?m sure you can come up with a more creative name. I relize this would be more work for you, but the RV-list is worth it. Curtis Hinkley Sterling, VA RV-8 N815RV reserved CHink11769 @ aol.com hinkleyc(at)fca.gov ________________________________________________________________________________
Date: Feb 12, 1998
Subject: Re: D4 Facination
The D4 was based in Venice Fla. It was a side by side 2 place low wing retractable with a 80 hp Rotax engine. The wing was a fiberglass spar and leading edge with a fabric covered rear section. The crash occured in Florida, but I forget the name of the airport. They were not doing aerobatics when it occured. The accident occured on downwind in the pattern. Bob Reeves Building Bearhawk, Flying RV-4 Hidden River Airport, Sarasota, Florida _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 12, 1998
I can't believe no one has suggested straight laq thinner!!!! I buy the cheapest stuff that the local paint supplier carries (5 gal pail, about $22), and use it for cleaning up almost all painting messes, INCLUDING epoxy resin, and epoxy primers. I don't think that you will need that $16/gal stuff for cleaning up.... K.I.S.S. ! Check six! Mark ________________________________________________________________________________
Date: Feb 12, 1998
Subject: Re: Veriprime
> >I used to be one of those guys chuckling. The old paint and body guys >learned that Variprime did not provide any protection against moisture the >first time they painted a car fender then rolled it out of the shop for the >night before they applied a sealer. When they came in the next day the dew >or rain had caused the unprotected steel to rust right through the >Variprime which they then had to fix on their own time. > I can't concur with this. Back in the summer of 1993, I started my RV-6A. There was a spot on my Ford van that was dented and the paint and primer chipped off. This area had a good amount of rust on it. I used a Scotch-Brite wheel to get the rust off and down to the bare metal. This area was primed with Vari-Prime and never topcoated. There is currently no sign of corrosion after almost 5 years. This van is always parked outside, on Long Island, NY and the driveway is about 75 feet from a salt water canal. Is it possible that the formula for Vari-Prime has changed over the years? From my experience, Vari-Prime alone should be more than adequate for corrosion proofing the inside of an RV. Just my $.02 Scott Gesele N506RV- Flying (68 hr since October) ________________________________________________________________________________
Date: Feb 12, 1998
> > >>>> I wear a homemade fresh air supply. > >John: > >I have a air pump off a medical unit to home make a freash air hood. Do >you have any suggestions on builting or converting a hood to hook to it. > >Don Jordan~6A wings~Arlington,Tx >donspawn(at)juno.com OK Don, you asked for it. I bought some chemical splash shields at the local hardware store. They are just a big plastic face shield with a head strap( about $2). I then took a plastic trash bag and cut a hole in it. I duct taped the face shield into the bag and just tuck the bag into my shirt. I run the air nozzle right over the top of my head and it blows down on my face and the shield. It always stays clear and gives you a big field of view. I bought a small shop-vac for the air supply and run about 50' of hose from it. The only drawback is dragging the damned hoses around. Otherwise it works very well. Good luck John ________________________________________________________________________________
Date: Feb 12, 1998
From: "VanArtsdalen, Scott" <scott.vanartsdalen(at)lmco.com>
I second this! Many of you guys have been around on the list for a while but there are some new guys out here that could use the info. To squash the primer thread just because *you* have been through it before isn't really fair to the newer guys. Yes I know about the archives, but they aren't as helpful as current, live information. -- Scott RV-4, wings ---------- From: HinkleyC(at)fca.gov[SMTP:HinkleyC(at)fca.gov] Reply To: rv-list(at)matronics.com Sent: Thursday, February 12, 1998 3:56 AM To: rv-list(at)matronics.com Subject: RV-List: Web page for Painting * * * * The views expressed in this EMail are my own and do not represent the policy or position * * * * * * * * of the Farm Credit Administration. * * * * GV, You would not believe all of the responses and questions I have received off line of the RV-List on the Variprime thread. I have responded to all that have written weather they just wanted advice about painting or if they just wanted to tell me to stick this thread where the sun don?t shine. What this means to me is that we need to get this information out to the RV builders and since you have a very good (OK, GREAT!) Web page, I was hopping that you would consider adding a section that would have information on different painting systems. I could send you documentation from DuPont and PPG that you could verify before you place it on you Web page to make sure it?s accurate. I?m sure someone else could provide the same info on SW and other systems. This would provide the RV-List with another great resource like you?re yellow pages. Then the next time a paint or primer question comes up we could just point them at "GV's- Painting Systems for Your RV" or I?m sure you can come up with a more creative name. I relize this would be more work for you, but the RV-list is worth it. Curtis Hinkley Sterling, VA RV-8 N815RV reserved CHink11769 @ aol.com hinkleyc(at)fca.gov ________________________________________________________________________________
Date: Feb 12, 1998
Subject: Re: Web page for Painting
<< . To squash the primer thread just because *you* have been through it before isn't really fair to the newer guys. Yes I know about the archives, but they aren't as helpful as current, live information. -- >> Priming aluminum is not rocket science, I think we all are making too much out of this. The airplane for the most part does not need to be primed, so priming with any type of primer has got to provide increased protection over bare aluminum. I'm glad the list is trashing Variprime and not my primer, but in the past every primer I know of, has been trashed on the list. It would lead one to believe that it is impossible to prime aluminum. You know, I think that K- Mart Rust-Olem would be about as good as any other primer, it certainly can not be any worse than bare aluminum! After having read all the debate on primers for almost 4 years, I find the best advice and information on primer is located in Van's instruction manual. Simple and to the point. Advice for new builders: Pick any primer, follow the manufacturers directions, and get back to building the airplane. Do not get into the "Macho" debate of "My primer is better than yours." Bob Busick RV-6 Fremont CA ________________________________________________________________________________
Subject: Baffle Kit
Date: Feb 12, 1998
Sirs, I recently received the baffle kit for an RV-6, O-320. Going together fairly well. Couple of questions: 1. I have to trim a good bit off the front side pieces. I assume the kit is for the fixed pitch cowling. Right? 2. A piece of aluminum was delivered with the instructions. It's about 8"x11". What's it for?? I intend to install the oil cooler (from Van) on the left baffle. Is this piece of aluminum supposed to be used as a doubler on the left rear baffle to reinforce that area for the oil cooler?? Thanks, Bob Cabe San Antonio --- "The opinions expressed herein are solely the author's and are not necessarily the opinions of USAA." ________________________________________________________________________________
Date: Feb 12, 1998
> > << the tank dies are just a pubic hair deeper. >> > > Now for the big question. An RCH or a BCH? > > -GV Judi won't let me do any comparison testing, but working with the materials at hand, I'd have to say 'RCH'. This also concurs with analysis done in my bachelor days (if my memory serves me). PatK - RV-6A ________________________________________________________________________________
Date: Feb 12, 1998
Subject: Re: Vortex Generators
>If they truly are such a great thing, why aren't they included in EVERY >design? Hmmmm. I know they are out for the J-3. I never considered them because, gad, what would you do with a 28mph stall as opposed to a 35mhp stall. I'm not sure, unless you were in short landing competition, they would help. What about the RV series? I am sure they would help an already great performing aircraft. But to what end? I don't think I would be able to go anywhere I wouldn't go without them. Besides, they stick up and are hard to clean/wax around. I would like to see someone try them and report results, though. It would be interesting to compare them to the perf tape on wings..... Just some thoughts....... Michael ________________________________________________________________________________
Date: Feb 12, 1998
Robert, when I flew F3B models (specialized RC gliders) one of the USA team's aircraft had a failure once. These aircraft were Kevlar bodies and s-glass wings designed to handle over 10g for tight turns on a speed course. The failure was in the elevator linkage and the aircraft headed straight for the ground. The battery and receiver were retrieved from about 1.5 feet below the surface of a hard-packed football field; the fuselage was pretty much shards of glass. The interesting things were the wings: while they looked whole at first glance, picking them up revealed that they were limp. The impact had not only delaminated the glass, it had returned the laminations to a cloth-like state. Prior to the accident, I had seen this plane fly many times in practice. Personally, I am not fearful of composite structures; I just hate the mess. But that V2 jet looks so sexy, I'm thinking I might have to change my tune someday. Meanwhile, I'm gonna enjoy my RV. PatK - RV-6A Robert L Reeves wrote: > > The D4 was based in Venice Fla. It was a side by side 2 place low wing > retractable with a 80 hp Rotax engine. The wing was a fiberglass spar > and leading edge with a fabric covered rear section. The crash occured > in Florida, but I forget the name of the airport. They were not doing > aerobatics when it occured. The accident occured on downwind in the > pattern. ________________________________________________________________________________
Date: Feb 12, 1998
Subject: Backriveting the Wings
Just thought I would pass on my experience in attempting to back rivet the top skins on the wings of my RV-8. I have the special tool from Avery for this. We found that the rivets do not set as far in and as flush as with the regular method (bucking from the inside). When you stop and think about it, you are pushing the rivet out, not pushing it in, so no matter how big or flat or convex the bucking bar is, the rivet is just simply not set in the dimple as well. Just our observation and experience. Von Alexander RV-8 #544 I think the Sherman Williams Reducer #54 at $16.00 per gallon will last throughout the project and will save more than its cost in replacement air-brushes... the airbrush pays for itself 50 times over in saved primer!!! Jeff Carpenter RV-6 wstcttprss(at)aol.com ________________________________________________________________________________
Subject: MN Saturday Breakfast
Date: Feb 12, 1998
Fellow Listers: Just a quick note to the local Twin Cities RV folks advising of the MN Wing's Bi-Monthly Saturday breakfast on 2/14. We'll meet at 9:00 am at the Hideaway Cafe at the St. Paul airport. Fly-in or drive. Come hungry!! Doug Weiler, pres, MN Wing ******************************************* Doug Weiler, Hudson, WI 715-386-1239 email: dougweil(at)mail.pressenter.com ________________________________________________________________________________
Date: Feb 12, 1998
>Bob Busisk, RBusick505(at)aol.com wrote: Priming aluminum is not rocket science, I >think we all are making too much out of this. The airplane for the most part does not need >to be primed, so priming with any type of primer has got to provide increased protection over > bare aluminum. After having read all the debate on primers for almost 4 years, I >find the best advice and information on primer is located in Van's instruction manual. >Simple and to the point. Do not get into the "Macho" debate of "My primer is better >than yours." Bob Busick RV-6 Fremont CA Those new builders who feel it prudent to study and inquire about what or how much of the interior to coat for corrosion resistance are not the ones worried about "rocket science" or "making too much of this" or involved in "the Macho debate of My primer is better than yours". For what it is worth to new builders learning about corrosion control, it is obvious that Bob Busisk has determined for his own application that "The airplane for the most part [which part is that?] does not need to be primed"; that "any type of primer" is better than . . .". He also is unable to or unwilling to recognize or acknowledge that all three primers listed by Van's in the Jan 1997 RV-6 Builders Manual were inadequate and inappropriate and should not have been listed at all. Yes, the real issue is accurate information so new builders can "get up to speed" and make their decisions, based on - - - accurate information. Van's should have simply cited a reputable source of info for the new builder to go to, rather than put out bad info. Cessna chose not to apply any interior corrosion preventative in some 1980s C-172s - and the wings of 4 aircraft in Florida had to be replaced 4 years later. I was in a repair facility last month and was shown serious corrosion in an older Cessan being rebuilt. Sure, some planes seem never to have corroded. But, because the owner believes that is the case with his, he is not going to dismantle the airplane and find the serious corrosion that would not visible through normal access panels. One primer may be as good as another (for corrosion prevention) but anyone can divide cost by square feet covered and calculate "$ per sq ft". Are they all "one as good as another"? Not on your life. New guys, study your primer choices and compare - and do the same with opinions and "information" on the rv-list. signed David Carter, RV-6 horizontal stab (drilling & dimpling skins today), Nederland, Tex ________________________________________________________________________________
Date: Feb 12, 1998
* * * * The views expressed in this EMail are my own and do not represent the policy or position * * * * * * * * of the Farm Credit Administration. * * * * Bob, I hope no one thinks we are trashing Variprime or that this is a "Macho" debate of "My primer is better than yours". Variprime is one of the best self-etching primers money can buy. What has not been stressed or presented during the almost 4 year debate is it's proper use according to DuPont. The idea of a Web page for painting would be to provide an information source for the manufactures recommended use for their products. As always Van's advice is right on target, " Pick any primer, follow the manufacturers directions". The problem is that allot of people that start building RV's have never painted anything or used a real spray gun. It's a good bet that they have never been into a DuPont or PPG or SW store to purchase the type of paint used to paint aircraft or cars. So how are they going to pick a paint system? The reason this RV-list is here is because Van's plans and instructions are very simple and to the point. They leave allot of unanswered questions for the first time builders, so we turn to the RV-List for help and guidance. This is why the primer questions keep coming up. Every one is trying to build the best RV they can and they want that extra protection that paint will provide. Curtis Hinkley Sterling, VA RV-8 N815RV reserved CHink11769 @ aol.com hinkleyc(at)fca.gov << . To squash the primer thread just because *you* have been through it before isn't really fair to the newer guys. Yes I know about the archives, but they aren't as helpful as current, live information. -- >> Priming aluminum is not rocket science, I think we all are making too much out of this. The airplane for the most part does not need to be primed, so priming with any type of primer has got to provide increased protection over bare aluminum. I'm glad the list is trashing Variprime and not my primer, but in the past every primer I know of, has been trashed on the list. It would lead one to believe that it is impossible to prime aluminum. You know, I think that K- Mart Rust-Olem would be about as good as any other primer, it certainly can not be any worse than bare aluminum! After having read all the debate on primers for almost 4 years, I find the best advice and information on primer is located in Van's instruction manual. Simple and to the point. Advice for new builders: Pick any primer, follow the manufacturers directions, and get back to building the airplane. Do not get into the "Macho" debate of "My primer is better than yours." Bob Busick RV-6 Fremont CA ________________________________________________________________________________
Date: Feb 13, 1998
Subject: Re: Left Elevator RV6A
mcomeaux(at)cmc.net wrote: > I have come to point of bending the tabs over in the area of the trim tab. > According to instruction & video you are to install elevator in V-block > then insert cut out wedge to bend tabs over. George in Video mentions > drawing > a line from edge of elevator skin and level to skin what distance though? > Can someone shed some light for me appreciate it. Thanks again---- I have some comment and photos, etc on my Bunny's Guide page http://www.geocities.com/CapeCanaveral/Hangar/4809/bunny1b.htm which may help. Incidentally, last weekend I looked over several RVs at SportAvex 98, NZ's national homebuilt fly-in. One builder had cut off the tabs and made some little ribs -- that looked nicer than the bent-over tabs on other RVs. Frank. ________________________________________________________________________________
Date: Feb 12, 1998
www.dupont.com imagine what you can find on the web. -----Original Message----- From: HinkleyC(at)fca.gov <HinkleyC(at)fca.gov> Date: Thursday, February 12, 1998 12:50 PM Subject: Re: RV-List: Web page for Painting > > > > > > * * * * The views expressed in this EMail are my own and do not represent > the policy or position * * * * > * * * * of the Farm Credit Administration. * * * * > > >Bob, > >I hope no one thinks we are trashing Variprime or that this is a "Macho" >debate of "My primer is better than yours". > > Variprime is one of the best self-etching primers money can buy. What has >not been stressed or presented during the almost 4 year debate is it's >proper use according to DuPont. The idea of a Web page for painting would >be to provide an information source for the manufactures recommended use >for their products. > >As always Van's advice is right on target, " Pick any primer, follow the >manufacturers directions". The problem is that allot of people that start >building RV's have never painted anything or used a real spray gun. It's a >good bet that they have never been into a DuPont or PPG or SW store to >purchase the type of paint used to paint aircraft or cars. So how are they >going to pick a paint system? > >The reason this RV-list is here is because Van's plans and instructions are >very simple and to the point. They leave allot of unanswered questions for >the first time builders, so we turn to the RV-List for help and guidance. >This is why the primer questions keep coming up. Every one is trying to >build the best RV they can and they want that extra protection that paint >will provide. > > >Curtis Hinkley >Sterling, VA >RV-8 N815RV reserved >CHink11769 @ aol.com >hinkleyc(at)fca.gov > > > > ><< >. To > squash the primer thread just because *you* have been through it before > isn't really fair to the newer guys. Yes I know about the archives, but > they aren't as helpful as current, live information. > -- >> > >Priming aluminum is not rocket science, I think we all are making too much >out of this. The airplane for the most part does not need to be primed, so >priming with any type of primer has got to provide increased protection >over bare aluminum. > >I'm glad the list is trashing Variprime and not my primer, but in the past >every primer I know of, has been trashed on the list. It would lead one to >believe that it is impossible to prime aluminum. You know, I think that K- >Mart Rust-Olem would be about as good as any other primer, it certainly >can not be any worse than bare aluminum! > >After having read all the debate on primers for almost 4 years, I find the >best advice and information on primer is located in Van's instruction >manual. Simple and to the point. > >Advice for new builders: Pick any primer, follow the manufacturers >directions, and get back to building the airplane. Do not get into the >"Macho" debate of "My primer is better than yours." > >Bob Busick >RV-6 >Fremont CA > > > > > > > > > > ________________________________________________________________________________
Subject: Fuel And Vent Lines
Date: Feb 12, 1998
Rather than running aluminum fuel and vent lines through the fuselage side walls (with plastic bushings) to the tanks, is there a problem(s) with using bulkhead fittings at the side wall and then flexible hose and fittings to the tanks? I assume that if you can't use flexible hoses, that you should wait until your wings are installed on the fuse to know exactly where to run these lines. Is this a correct assumption? Thanks in advance for your comments. Ron Caldwell rlcaldwell@utah-inter.net RV6A - Finish Stage . ________________________________________________________________________________
Date: Feb 12, 1998
Subject: Re: Backriveting the Wings
<< When you stop and think about it, you are pushing the rivet out, not pushing it in, so no matter how big or flat or convex the bucking bar is, the rivet is just simply not set in the dimple as well. Just our observation and experience. Von Alexander RV-8 #544 >> Hmmmm.......Von, I sure hope you're wearing your asbestos underware for this one. Many wings have been built with exactly the system you mention. Let's look at this from a different angle- did the rivet heads pop out when you did your elev's & rudder? If they did (doubtful), then I would agree with you about the bucking bar letting the rivets back out. Normally, I'd say that you could be simply pushing with the gun too hard. I know that what you are describing happens while "front riveting" with an over- enthusiastic bucker. What size gun are you using? Remember, that long set soaks up a lot of energy. If you are using a 3X, you may need to raise your pressure about 5-10 lbs over what you would normally use when "front riveting". Sneak up on this higher pressure, so to speak. We use a 4X for everything here, and we adjust the press down to about 30 lbs to do stiffeners, etc., up to 90 PSI for spars. We can certainly tell the difference when we get that big set onto the gun- it takes more hits, or (preferred) more air pressure with the same hits. We have a 6 lb bar, called the Big *ss Bar, for back riveting. I don't think the round bar from Avery is quite big enough, but that's my taste. Keep trying! Check six! Mark ________________________________________________________________________________
Subject: Rocky Mountain Engine Monitor
Date: Feb 12, 1998
The instructions indicate using shielded, twisted pair wire for the wiring application. What has everyone been using for this application? Two days of searching has left me without any wire and I'm hoping it can't be this hard. Has anyone used standard shielded wire or does anyone know where I can get the twisted pair wire. Charles Golden N609CG 6A Chevy Vortec test run Completing panel and cowl SE Texas ________________________________________________________________________________
Date: Feb 12, 1998
Subject: factory rv flight training
Anyone wanting RV-6 flight training the in Grandhaven Michigan area. I will be there April 8-10. My original message give the wrong phone numbers the contacts should be Scott DeGaynor 616 776 0840 or John Gill at 616 940-3017 hope this clears up the confusion Michael Seager 503-429-5103 rv6cfi(at)Vernonia.com ________________________________________________________________________________
Date: Feb 13, 1998
Subject: Wing Tip
To All Aussie Listers, This morning when I went into my paddocks I found a fiber glass wing tip. It is definitely not an RV, but if some one should here about a lost iridescent green wing tip complete with NV light (red) could you send them in my direction. It was picked up 10nm east of Traralgon in Gippsland Victoria. Regards Les Rowles Po Box 1895 Traralgon Australia 3844 lmrowles(at)netspace.net.au ________________________________________________________________________________
Date: Feb 12, 1998
Robert, The reason I had not posted the www.dupont.com to the RV-List was because after searching all over it, I could not find any information on their painting systems or how to use them. It would give you a nice list of repair shops in you state that use DuPont products. Curtis Hinkley RV8 << www.dupont.com imagine what you can find on the web. >> ________________________________________________________________________________
Date: Feb 12, 1998
Curtis The DuPont web page also has a direct e-mail to technical support. If someone wanted specific directions or questions answered by the manufacturer, that would be the place to go. Bob -----Original Message----- From: CHink11769(at)aol.com <CHink11769(at)aol.com> Date: Thursday, February 12, 1998 7:11 PM Subject: Re: RV-List: Web page for Painting > >Robert, > >The reason I had not posted the www.dupont.com to the RV-List was because >after searching all over it, I could not find any information on their >painting systems or how to use them. It would give you a nice list of repair >shops in you state that use DuPont products. > >Curtis Hinkley >RV8 > > ><< > > > www.dupont.com > > imagine what you can find on the web. > >> > > > > > > ________________________________________________________________________________
Date: Feb 12, 1998
Subject: Re: Rocky Mountain Engine Monitor
Hi Charles, All, Twisted pair is all around us! But where can you get good quality stuff locally? I get it down the street. Computer networks use either twisted pair (4 pairs in the cable?) for local area networks. Less commonly they use coax RG58AU. If you can't find any let me know needs. Hal Kempthorne RV-6AQ -- Looking for an airport & sweating canopy halk(at)sybase.com Santa Clara, CA. Debonair N6134V @ SJC ________________________________________________________________________________
Date: Feb 12, 1998
Subject: EXTERIOR LIGHTING
The time has come to write a check to VANS. I am still undecided wether I need to order the Empennage with or without the provision for the position light in the bottom of the rudder. It seams "most" folks are using the three- light system on the wing tips. Does anyone have any good feedback about this matter? Jim Nice RV6A ________________________________________________________________________________
Date: Feb 12, 1998
chief aircraft 18004473408 has all the stuff you need. It's real airplane stuff. 22 gauge 2 and 3 conductor twisted conductor shielded Flyinghi(at)worldnet.att.net wrote: > > The instructions indicate using shielded, twisted pair wire for the > wiring > application. What has everyone been using for this application? Two > days > of searching has left me without any wire and I'm hoping it can't be > this > hard. Has anyone used standard shielded wire or does anyone know > where I > can get the twisted pair wire. > > Charles Golden > N609CG 6A > Chevy Vortec test run > Completing panel and cowl > SE Texas > -- Abby Razer Barbara Razer Molly the Dog and Chet Razer razer(at)midwest.net http://scribers.midwest.net/razer/ ________________________________________________________________________________
Subject: Re: tank dies (Clean one)
Date: Feb 12, 1998
There is another guy in the area who is also building an rv6a and he is a bit ahead of me in his project. He is a retired guy who has no interest in crazy things like internet e-mail lists. He had never heard of tank dimple dies and his tank rivets ended up a bit proud. I saw this and thought that I, being so very aware of everything would avoid this by buying the tank specific dies. Well, many of mine stick out too. Maybe not as much, but they do. I think the problem is that the proseal didn't have enough time to squeeze out during the riveting. I know that I used more proseal than I needed to because I made a long range tank modification and I wanted to ensure no leaks, that could have something to do with it. But, if I had it to do over again I would work each rivet rather lightly first completing the tank to skin rivets and then go back and give them another hit after the proseal has had a chance to move. Brian Eckstein Fuselage on order ________________________________________________________________________________
Date: Feb 12, 1998
Bob, That's just what I did a little while ago. Lets' see what happens. I gave them both my e-mail and snail mail address so this may take a while. Al > >Curtis > >The DuPont web page also has a direct e-mail to technical support. If >someone wanted specific directions or questions answered by the >manufacturer, that would be the place to go. > >Bob ________________________________________________________________________________
Date: Feb 12, 1998
RBusick505(at)aol.com wrote: > > > Advice for new builders: Pick any primer, follow the manufacturers > directions, and get back to building the airplane. Do not get into the > "Macho" debate of "My primer is better than yours." > > Bob Busick > RV-6 > Fremont CA Well said Robert, it is going on eleven years since I started my Rv-6 and I have been flying it since '89. when I started building my airplane I ask Art Chard who was working for Van's at the time what I should use for a primer he suggested Vari-Prime so that was good enough for me. Living in Oregon as I do my hanger is damp inside the biggest part of the winter, so far I see no signs of corrosion. This airplane will outlast me I am sure. YOU ARE RIGHT PICK A PRIMER AND USE IT, We need to remember that there are over 7000 kits out there and only about 800 people on the list so the non list people must be doing fine picking the primer of their choice and using it with out the reams of discussion that goes on here. If I were to build again I would not prime anything except non alclad and steel parts. -- Jerry Springer RV-6 N906GS First flight July 14, 1989 :-) Hillsboro, OR jsflyrv(at)ix.netcom.com ________________________________________________________________________________
Date: Feb 12, 1998
Subject: Re: Fuel And Vent Lines
Hi Ron, The only problem with using bulkhead fittings & flexable hose is weight and$$. You can make a poster board template of your root nose rib and transfer the fuel outlet positions to the fuse. Use Rubber grommets, not plastic bushings. The grommets are in the kit. The feed thru hole need not be perfectly exact, minor bends can be made in the 3/8 alum. tubing to make it match up.. Keep it light for performance. Regards, Bill, RV4, N66WD _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 12, 1998
> >Rather than running aluminum fuel and vent lines through the fuselage side >walls (with plastic bushings) to the tanks, is there a problem(s) with >using bulkhead fittings at the side wall and then flexible hose and >fittings to the tanks? I assume that if you can't use flexible hoses, that >you should wait until your wings are installed on the fuse to know exactly >where to run these lines. Is this a correct assumption? Thanks in advance >for your comments. Just pondering this, especially since some re-design is needed to use the Andair fuel valve ... Why not just run the flexible hose straight from the tank to the fuel valve?? ... it would save several joints in the whole system ... Gil (using flex hoses?) Alexander > >Ron Caldwell >rlcaldwell@utah-inter.net >RV6A - Finish Stage ------------------------------------------------------- mailto:gila(at)flash.net Gil Alexander, Los Angeles, CA ________________________________________________________________________________
Date: Feb 12, 1998
Subject: Re: Primer Alternative
Hi Mike, Please don't be too quick to dismiss Sherwin Williams Vinyl wash primer as Vans uses. I have been following the primer thread for some time and though I almost hate to jump in, I feel that someone has to defend this product. Instead of theorys, let me give you some hard facts. I used this product on my first RV4. It is now 10 yrs old. It resides here on Florida's west coast. There is no sign of internal corrosion on this airplane. The aluminum was not treated with metal prep or alodine before priming, such is not necessary, it was just wiped clean with laquer thinner( The SW product is metal etching). A few other advantages: it is lighter (properly applied, thickness is about .0005"), it is cheaper than Variprime, but most of all, it contains zinc chromate,this is the stuff that fights corrosion. I certainly don't wish to pan Variprime because DuPont pays my Pension but I have to say that I think SW vinyl wash primer is a better choice for our purposes. It's hard to beat success. Best regards, Bill RV4 N66WD _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 12, 1998
>Rather than running aluminum fuel and vent lines through the fuselage side >walls (with plastic bushings) to the tanks, is there a problem(s) with >using bulkhead fittings at the side wall and then flexible hose and >fittings to the tanks? I assume that if you can't use flexible hoses, that >you should wait until your wings are installed on the fuse to know exactly >where to run these lines. Is this a correct assumption? Thanks in advance >for your comments. > >Ron Caldwell Ron, I used bulkhead fittings on all fuselage penetrations (fuel, vent, pitot). This resulted in a very professional looking installation. Aeroquip hoses would probably work just fine. I used aluminum as they are slightly lighter (every gram counts). My lines were run with the wings on the fuselage. That way, there is no doubt as to how it will all fit together. Hope this helps. Scott Gesele N506RV- Flying (All those long hours were well worth it !!!!!) ________________________________________________________________________________
Date: Feb 12, 1998
>>I need to order the Empennage with or without the provision for the >>position light in the bottom of the rudder. Hi Jim Order the Empennage kit and ask Vans to delete the bottom rudder fairing (about $26 credit I think) and then when you make up your mind you can order the correct fairing. I purchased my bottom rudder fairing when I ordered the wing kit. George McNutt, Langley B.C. 6A - Wings. ________________________________________________________________________________
Date: Feb 12, 1998
>The instructions indicate using shielded, twisted pair wire for the wiring >application. What has everyone been using for this application? Two days >of searching has left me without any wire and I'm hoping it can't be this >hard. Has anyone used standard shielded wire or does anyone know where I >can get the twisted pair wire. > Mouser Electronics is an excellent source for this along with Amp terminals, heat shrink, etc. They can be reached at 800-346-6873 or www.mouser.com. I believe that what I used was Mouser stock # 602-2401c-100. This a 100 foot spool of two conductor shielded wire. Please verify with Mouser that this stock number is twisted pair. When I ordered mine, the catalog didn't say that it was twisted pair, but a call to them confirmed that it was. The 100' spool isn't overkill. I only have about 10' left over. Hope this helps. Scott Gesele N506RV - Flying ________________________________________________________________________________
Date: Feb 13, 1998
> >Computer networks use either twisted pair (4 pairs in the cable?) for local area >networks. Less commonly they use coax RG58AU. Didn't the original poster specify *shielded* twisted pair? Computer networks use UTP (unshielded twisted pair) for 10baseT networks. If shielding is important to the equation, UTP probably shouldn't be used. Chris ____ Chris Hinch Phone: +64-3-477-2995 Animation Research Ltd Fax: +64-3-479-9751 Systems Manager e-mail: chinch(at)arl.co.nz Level 2, 450 Moray Place, PO Box 5580, Dunedin, New Zealand ________________________________________________________________________________
Date: Feb 12, 1998
Subject: Re: Baffle Kit
<< 1. I have to trim a good bit off the front side pieces. I assume the kit is for the fixed pitch cowling. Right?>> The kit will work for both but the front floor and side baffles need to be trimmed according to fixed pitch or c/s. I think all cowlings for the past two or so years are c/s. 2. A piece of aluminum was delivered with the instructions. It's about 8"x11". What's it for?? >> Reinforcing the attach points using doubler patches as shown in the instructions. -GV ________________________________________________________________________________
Date: Feb 12, 1998
<< Rather than running aluminum fuel and vent lines through the fuselage side walls (with plastic bushings) to the tanks, is there a problem(s) with using bulkhead fittings at the side wall and then flexible hose and fittings to the tanks? >> Only more opportunities for leaking. -GV ________________________________________________________________________________
Date: Feb 12, 1998
Subject: Re: EXTERIOR LIGHTING
>The time has come to write a check to VANS. I am still undecided >wether I need to order the Empennage with or without the provision for the >position light in the bottom of the rudder. It seams "most" folks are using >the three-light system on the wing tips. Does anyone have any good feedback Jim, FWIW, I ordered the rudder bottom with the hole for the light. I later decided that I would use the 3 light wingtip system to save the weight of the light and wire that far aft of the CG, and the hassle of running the wire. Plus you get an extra light pointing rearward. It isn't a big deal to re-glass the rudder bottom, but I would just order the smooth one if I were doing it over again. Ed Bundy RV6A - Eagle, ID - first flight 11/20/96 ebundy@juno.com - http://members.aol.com/rv67em/ - _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Subject: backrivetting
Date: Feb 12, 1998
Can someone tell me what I am doing wrong? I was practicing back rivetting with some scrap pieces. My working pressure was around 40 psi. The rivets came out terrible. They were all bent. The gun was moving all over the place. I am sure it's something obvious this novice hasn't seen yet. Go ahead let me know what i am doing wrong. Thanks, Tony Moradian Empenage #80398 N100TM reserved tmoradia(at)ix.netcom.com ________________________________________________________________________________
Date: Feb 12, 1998
I have the three light system on my Kitfox and am going to use it on my RV-8. No wires running to the back. I'm happy with it (in use four years now). Mike Robbins RV-8 ________________________________________________________________________________
Date: Feb 12, 1998
<< The instructions indicate using shielded, twisted pair wire for the wiring application. What has everyone been using for this application? Two days of searching has left me without any wire and I'm hoping it can't be this hard. Has anyone used standard shielded wire or does anyone know where I can get the twisted pair wire. >> How much do you want? I've got a 500 ft spool of W.L. Gore 24 AWG teflon FEP shielded twisted pair. Just for you I'll send gratis, you pay shipping when you get it. Agreed? -GV ________________________________________________________________________________
Date: Feb 12, 1998
Hi Mark, I've built two trim tabs and two L. elevators. The first one I bent the tabs. It came out looking like a wet bag-o deer horns. The next one I made my cuts 90 degrees to the spar lines and built little ribs. My elev. and TT look like they were machined out of an aluminum block. The trailing edge is absolutely straight and the gap is a very square 1/8 inch. The point is you can cut a lot straighter than you can bend, especially at the trailing edge. Another bonus, if you screw up, you just rebuild the tabs, not the whole elevator as I had to do. Let me know if I can help. Eric Henson eric.henson(at)cendantmobility.com ---------- From: mcomeaux Subject: RV-List: Left Elevator RV6A Date: Wednesday, February 11, 1998 10:21PM I have come to point of bending the tabs over in the area of the trim tab. According to instruction & video you are to install elevator in V-block then insert cut out wedge to bend tabs over. George in Video mentions drawing a line from edge of elevator skin and level to skin what distance though? Can someone shed some light for me appreciate it. Thanks again---- Mike Comeaux mcomeaux(at)cmc.net ________________________________________________________________________________
Subject: Flutter testing
Date: Feb 12, 1998
I'd be interested in hearing anyone's experience in flutter testing their RV, whether done rigorously or not. Seems like there are quite a few RVs capable of exceeding Van's 212mph Vne in level flight and I hope to be able to as well when mine is done. I fully intend to do flutter testing to establish my own Vne, but I'd like to know what to expect. Has anyone had problems attributable to building differences, or conversely, found Van's numbers to be conservative? If there were any problems, can you recommend any changes to incorporate before testing? I would hope the Harmon Rocket folks tested much higher, but I don't know what, if anything, they changed in the control system or structure. A related question: any ideas on in-flight egress from a -6 slider? I've heard that you can't open the canopy above ~130 mph because of backpressure. It's not much good wearing a chute for either flight testing or aerobatics if you can't get out to use it. I thought about using quick release pins to attach the rollers to the canopy frame, with a handle built-in to pry the canopy back far enough to clear the molding. How much force would it take to slide the canopy back 2 inches? My thought is you could then push it up and have the slipstream "remove" it for you. Seems like this would take alot of time and coordinated actions... all at the wrong time. Has anyone solved this or have any suggestions? Explosive bolts? Light weight ejection seats? Thanks, Greg Young RV-6 N6GY (reserved) fuselage out of jig ________________________________________________________________________________
Date: Feb 13, 1998
Charles, You can get the wire from Aircraft Spruce. They're not one of my favorite companys to deal with, but they stock all of the types of wire you'll need. Here's a tip, wire your monitor just exactly like the manual shows. I tried to save some money because I had a lot of mil spec single conductor and twisted pair shielded wire laying around and figured that I could use the single conductor in place of the twisted pair shielded, and the twisted pair in place of the three conductor that's specified on some of the sensors in the manual. If you notice on the oil press, fuel press, manifold press, and current transducer use the signal ground as one of the internal conductors while the shield is grounded to main ground. On the circuit board, this "signal" ground is common to the main ground. Hey they're the same, right? So I figured that I could just use the shield for the common return and the shield. Well, I spent two weeks chasing all sorts of gremlins in my system. Mainly that when I transmitted, most of my indications went nuts. I wound up having to re-wire all of those sensors just like the installation manual showed. Also, keep the pigtails of the shields at the micromonitor as short as possible. Sometimes I have to teach myself important lessons the hard way! Good luck. Mark LaBoyteaux RV-6A N106RV MLaboyteau(at)aol.com ________________________________________________________________________________
Date: Feb 12, 1998
> > The time has come to write a check to VANS. I am still > undecided wether I > need to order the Empennage with or without the provision > for the position > light in the bottom of the rudder. It seams "most" folks > are using the three- > light system on the wing tips. Does anyone have any good > feedback about this > matter? I like the idea of a position and strobe combo in the rudder even though it means running add'l wires to the tail. I'll also have strobes in the tips which will be recessed under a lens with the position lights. The 3 light system cannot be recessed in the wingtip , it has to be external. Those external mounts are more subject to hangar rash and the lenses are expensive. But my major reason is purely emotional, I don't want the same nav lights on my sleek new RV that I had on my 1946 T-Craft. Greg Young RV-6 N6GY (reserved) fuselage out of jig ________________________________________________________________________________
Date: Feb 13, 1998
Here is the way I figure it; correct me if I'm wrong. The three-light model strobes by whelen, with aft facing white position light and power supplies starts at around $600. The Aeroflash set, which has all the same stuff except the aft facing position light is around $280. Now you will need the tail light at around $50.00, for a total of around $330, or almost half-price. The only penalty, the weight of the tail light plus wire and time to install. Does this make sense to you? I had the Aeroflash system in my 172 I used to have, it worked great and was reliable. Just an observation. Von Alexander RV-8 #544 finishing wings ________________________________________________________________________________
Date: Feb 13, 1998
Subject: RV-3 stick length & travel
With the stick straight up/down it's faily close to the instrument panel. What is you full travel fore/aft at the tip of the stick (and how log is it from the hinge bolt)? Does it pass forward under the instrument panel? I'm considering a 6-8" subpanel from the bottom of the instrument panel down to the wing spar. Finn ________________________________________________________________________________
Subject: Ivoprop
Date: Feb 12, 1998
If several messages come from me, I apologize. I am not sure that my messages are getting out. I have a RV6 prototype that I have completely refurbished. Built by Art Chard and certified in 1980 S/N 002. Powered by a Continental IO-346 modified with TISO-520 cylinders with high compression piston takes this engine from 165 to estimated 190HP. New paint, new interior and 0 timed engine makes this a fun airplane. The old wood prop (Wranke) not able to take the extra HP began to show cracks after 20hrs of flight. I've installed the Ivo magnum electric. I've been having problems with the electric motor that controls the pitch. Has anyone had experience with or info about this prop. Also looking for spare prop. 68x70 S.A.E. #2 Brad Bundy Chard 6 N48AC bundyb(at)inofowest.com ________________________________________________________________________________
Date: Feb 13, 1998
>Rather than running aluminum fuel and vent lines through the fuselage >side >walls (with plastic bushings) to the tanks, is there a problem(s) with >using bulkhead fittings at the side wall and then flexible hose and >fittings to the tanks? No problem. The main drawbacks are that it costs a lot more and its heavier. I assume that if you can't use flexible hoses, >that >you should wait until your wings are installed on the fuse to know >exactly >where to run these lines. Is this a correct assumption? That depends. You could do part of what you have suggested and run hard lines to bulkhead fittings, and then later at final assy. you can make up short alum lines for the final connection. The only real negative to this is that you have an extra potential leak point, and a small extra cost but much less than the cost of using flex hoses. This is the standard installation for the RV-8 kit. It made the kit cost a little more but makes the installation much simpler. Scott McDaniels RV-6A N64SD 560+ Hrs. These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
<34E33151.84E(at)datarecall.net> 84-85,87-89,92-93,97-98,101-107
Date: Feb 13, 1998
>For what it is worth to new builders learning about corrosion control, >it is obvious that Bob Busisk has determined for his own application >that "The airplane for the most part [which part is that?] Any part that is made of Alclad Aluminum (including but not limited to Skins, bulkheads, ribs, stiffeners, etc.) does not need >to be primed"; that "any type of primer" is better than . . .". He >also >is unable to or unwilling to recognize or acknowledge that all three >primers listed by Van's in the Jan 1997 RV-6 Builders Manual were >inadequate and inappropriate and should not have been listed at all. As with anything else on this list you are entitled to your own opinion, and that's what that is; your opinion. > >Yes, the real issue is accurate information so new builders can "get >up >to speed" and make their decisions, based on - - - accurate >information. > >Van's should have simply cited a reputable source of info for the new >builder to go to, rather than put out bad info. Cessna chose not to >apply any interior corrosion preventative in some 1980s C-172s - and all of the 1970's and 60's and 50's.(unless you paid big bucks for a seaplane option which sometimes still got you a primer job done after the structure was together, go figure) Go look at a few so that you have "accurate" information to provide to new builders. and >the >wings of 4 aircraft in Florida had to be replaced 4 years later. I >was >in a repair facility last month and was shown serious corrosion in an >older Cessan being rebuilt. Sure, some planes seem never to have >corroded. But, because the owner believes that is the case with his, >he >is not going to dismantle the airplane and find the serious corrosion >that would not visible through normal access panels. > >One primer may be as good as another (for corrosion prevention) but >anyone can divide cost by square feet covered and calculate "$ per sq >ft". Are they all "one as good as another"? Not on your life. > >New guys, study your primer choices and compare - and do the same with >opinions and "information" on the rv-list. I second that statement and now add my personal feelings. I intend to not get involved in this debate so no response to me is necessary. This post is primarily directed to the lurkers on the list that may be new builders or seriously thinking about an RV as a project. Some people do put far to much emphasis on which primer to use. I would like to offer (as others have) that you consider one of the reasons that a lot of builders profess to choosing an RV to build over some other designs... because it is a tried an proven material and process for building airplanes. We are talking about the 10's of thousands of airplanes that were built this way, and could it be true "A large percentage of them were built with no internal priming for corrosion protection ( The crowd gasps). And no the majority of them haven't been thrown away by now because of corrosion. Just the opposite. If you are going to research what the best primer for corrosion protection is then you should also be researching what causes most of the corrosion in general aviation airplanes. Working as a mechanic I have crawled through my share of airplanes and I can tell you that from my opinion there is a lot more to whether you are likely to get corrosion than what state you have the plane based in. >From what I have seen most RV's and custom built airplanes in general get treated much differently that your typical FBO rental line airplane. They are usually hangared. Flown regularly, and well maintained. As an airplane gets older it usually starts to accumulate what I call Lube crud. When a mechanic (one that doesn't care that he is working on your "Baby") lubes interior parts that need to be, he ends up spraying it all over the place. Over time this mixes with the dust and dirt that accumulates where it accumulates, and then you have lube crud that does a very good job of trapping moisture and plugging drain holes. Can any other mechanics out there comment on there experiences with the causes of corrosion. Without going into this in any more detail (I'm sure you get the idea) I will end this by saying "think about how you will take care of your airplane". How you will store it? Will you be fussy about keeping it clean on the interior, etc.? Then you decide what's right for you. Most of this debate is whether people are foolish for not making there 50 year useful life (and I only use 50 because that is about as old of an unprimed airplane as you will find to use as a bench mark) into a 100 year useful life. I get the feeling that there are builders out there that are going to be completed and flying while some others will be still trying to make sure their airplane wont have corrosion by the time they get it flying :-) Scott McDaniels RV-6A N64SD 560+ Hrs. These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 12, 1998
> >The time has come to write a check to VANS. I am still undecided wether I >need to order the Empennage with or without the provision for the position >light in the bottom of the rudder. It seams "most" folks are using the three- >light system on the wing tips. Does anyone have any good feedback about this >matter? >Jim Nice >RV6A > Jim, I personally like the separation between the wingtip nav lights and the tail nav light. This makes it easier for me to see the relative direction another aircraft is headed in flight. If all the lights are bunched up on the wingtips, with a strobe flashing in there to boot, it is more difficult for me to tell how the aircraft is oriented and thus it's heading relative to mine. Certainly not impossible, but more difficult at a glance. I am all for doing anything to improve my night visibility. I personally am planning on fitting nav/strobe assemblies to the wingtips and a single aft white position light to the rudder bottom on my -6. While you've got your checkbook out, can you pay off the balance on my wing kit? :-) > > Jon Elford RV6 #25201 Elevators - Wings ordered!! ________________________________________________________________________________
Date: Feb 13, 1998
> I have really wanted to stay out of this discussion but must put my $0.02 in. If you read the "ingredients" on the back of the Variprime can, you will find all sorts of stuff including zinc chromate. As I recall the military primed with zinc chromate for years and this has no vapor barrier at all, just the sacrificial zinc, and this doesn't last forever. Just ask any salt water boater. > Variprime did not provide any protection against moisture the > >first time they painted a car fender then rolled it out of the shop for the > >night before they applied a sealer. When they came in the next day the dew > >or rain had caused the unprotected steel to rust right through the > >Variprime which they then had to fix on their own time. > This > area was primed with Vari-Prime and never topcoated. There is currently no > sign of corrosion after almost 5 years. This van is always parked outside, > on Long Island, NY and the driveway is about 75 feet from a salt water > canal. ________________________________________________________________________________
Date: Feb 13, 1998
Subject: Re: backrivetting
Hi Tony, A few of the local builders gave me some advice on the Gun Pressure 28 to 30 lbs and it seemed to work out real fine big improvement in my rivetting, The back rivett set should keep the head from slipping off & a good bottom steel plate should work out fine. 1/4 inch to 1/2 on the back plate I use the 1/2 Hope it helps BSivori(at)AOL.COM Wings N929RV Reserved ________________________________________________________________________________
Date: Feb 13, 1998
<< Those new builders who feel it prudent to study and inquire about what or how much of the interior to coat for corrosion resistance are not the ones worried about "rocket science" or "making too much of this" or involved in "the Macho debate of My primer is better than yours". For what it is worth to new builders learning about corrosion control, it is obvious that Bob Busisk has determined for his own application that "The airplane for the most part [which part is that?] does not need to be primed"; that "any type of primer" is better than . . .". He also is unable to or unwilling to recognize or acknowledge that all three primers listed by Van's in the Jan 1997 RV-6 Builders Manual were inadequate and inappropriate and should not have been listed at all. >> I have to agree with Dick Carter. I am a newbie, and doing my own research with the primer / paint suppliers. Dupont tech reps have told me applying Veriprime without a topcoat could be considered detrimental. The reason you are suggested to apply a topcoat within 16 hours of applying Veriprime is because of the moisture absorbed during that time. After 16 hours your are advised to reapply the primer after scuffing if a topcoat is to be applied. I also have come to the same conclusion that the reccommendations made in the Builders Manual are misleading. Not throwing stones, only adding to the discourse. Tony Philpin RV-8 empennage ________________________________________________________________________________
Date: Feb 13, 1998
Subject: Re: Flutter testing
<< I'd be interested in hearing anyone's experience in flutter testing their RV, whether done rigorously or not. Seems like there are quite a few RVs capable of exceeding Van's 212mph Vne in level flight and I hope to be able to as well when mine is done. I fully intend to do flutter testing to establish my own Vne, but I'd like to know what to expect. Has anyone had problems attributable to building differences, or conversely, found Van's numbers to be conservative? If there were any problems, can you recommend any changes to incorporate before testing? I would hope the Harmon Rocket folks tested much higher, but I don't know what, if anything, they changed in the control system or structure. >> Well,..... I've seen 280 MPH in mine. I know of others that have been to 330MPH. Some fellas regularly descend at 300 indicated. That's really smokin'! No problems, and the control system is RV style all the way. I did make the elev trim tab a bit larger than is called out, but I can't comment about any effects this might bring about, except that I can trim for approach speeds while solo. I will also say hat John did a 5 MPH incriment flutter test, up to 300 indicated. The structure is exactly the same, except it's all different. (same style, different stations, and the cockpit area is 040 vs 032. Wings are a bit shorter.). I'd say that flutter testing isn't really necessary, if the a/c is built to plans specifications. I recall hearing this statement before. Check six! Mark ________________________________________________________________________________
Date: Feb 13, 1998
Subject: Re: Ivoprop
I would lose that prop asap if I were you. Although I do not have any personal experience with tis prop, I did do some extensive research for my first plane. I have heard nothing but nightmares about the Ivoprop, including some fatalities...... Spend the extra money on a Hartzell Paul > >If several messages come from me, I apologize. I am not sure that my >messages are getting out. >I have a RV6 prototype that I have completely refurbished. >Built by Art Chard and certified in 1980 S/N 002. >Powered by a Continental IO-346 modified with TISO-520 cylinders with high >compression piston takes this engine from 165 to estimated 190HP. New >paint, new interior and 0 timed engine makes this a fun airplane. >The old wood prop (Wranke) not able to take the extra HP began to show >cracks after 20hrs of flight. >I've installed the Ivo magnum electric. I've been having problems with the >electric motor that controls the pitch. >Has anyone had experience with or info about this prop. >Also looking for spare prop. 68x70 S.A.E. #2 > >Brad Bundy Chard 6 N48AC >bundyb(at)inofowest.com > > > > > ________________________________________________________________________________
Date: Feb 13, 1998
>I've installed the Ivo magnum electric. I've been having problems with >the >electric motor that controls the pitch. >Has anyone had experience with or info about this prop. >Also looking for spare prop. 68x70 S.A.E. #2 > >Brad Bundy Chard 6 N48AC >bundyb(at)inofowest.com Brad, There was a fatal recently, involving a large lycoming a plastic prop, a prop motor failure and a fool pretending to be a pilot/mechanic. I believe Garfield might still have the details and you might want to know what they are. You can contact him at > garfield(at)pilgrimhouse.com <. Larry Mac Donald lm4(at)juno.com _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 13, 1998
Here is the way I figure it; correct me if I'm wrong. The three-light model strobes by whelen, with aft facing white position light and power supplies starts at around $600. The Aeroflash set, which has all the same stuff except the aft facing position light is around $280. Now you will need the tail light at around $50.00, for a total of around $330, or almost half-price. The only penalty, the weight of the tail light plus wire and time to install. snip Von Alexander RV-8 #544 finishing wings >> I'd say you are right. You can substitute the tail nav/strobe from Van's for $110, and an extra Aeroflash power supply for $82, and have a three strobe system, with nav lights, for around $500. My company, and also Cleaveland Tool, sell the Aeroflash three light systems for $420, with double flash power supplies. This is a v easy system to install, and light. This system seems to be the preferance of the -6 builders. BTW- The nav/strobe systems (double flash) run $295, or $280 for single flash. Geez- I'm busy today! Check six! Mark ________________________________________________________________________________
Date: Feb 13, 1998
Scott Gesele wrote: > > > >The instructions indicate using shielded, twisted pair wire for the wiring > >application. What has everyone been using for this application? Two days > >of searching has left me without any wire and I'm hoping it can't be this > >hard. Has anyone used standard shielded wire or does anyone know where I > >can get the twisted pair wire. > > > > Mouser Electronics is an excellent source for this along with Amp terminals, > heat shrink, etc. They can be reached at 800-346-6873 or www.mouser.com. I ________________________________________________________________________________
Date: Feb 13, 1998
<< Dupont tech reps have told me applying Veriprime without a topcoat could be considered detrimental. The reason you are suggested to apply a topcoat within 16 hours of applying Veriprime is because of the moisture absorbed during that time. >> IMO, you true believers have really gone "over the top" on this primer thread. It would probably be a good thing not to get too emotionally invested in this issue, as Scott is quite right. Was the duPont rep made aware that you are applying the Variprime to aluminum and not to steel? They corrode differently you know. In contrast to oxides of steel (rust), aluminum oxide is actually protective (harder than the parent aluminum) and protects against further corrosion. What alodine does is to grow a nice looking protective oxide layer that if not mechanically beaten off (it's more brittle too) will do the job of a primer just fine on alclad surfaces. The other alloy parts (6061-T6, 6063 etc.) may need a little (the operative word) additional protection to reduce the potential for intergranular corrosion due to the alloying ingredients in the presence of an electrolyte (water and surface salts). The chromate ions are there to reduce the filiform corrosion problem with aluminum. Any zinc chromate source will do. The presence of moisture alone wicking thru the porous primer has little bearing on your actual corrosion. Like I said before, try the testing yourself. It's good to be skeptical. Then you know what's what and aren't just parroting dogma. All the great sounding pronouncements won't change the facts that you needn't be so wrapped around the axle on this one. -GV ________________________________________________________________________________
Date: Feb 13, 1998
From: Unistar Computers <unistar(at)mindspring.com>
>I'd be interested in hearing anyone's experience in flutter >testing their RV, whether done rigorously or not. Seems >like there are quite a few RVs capable of exceeding Van's >212mph Vne in level flight and I hope to be able to as well >when mine is done. I fully intend to do flutter testing to >establish my own Vne, but I'd like to know what to expect. > Has anyone had problems attributable to building >differences, or conversely, found Van's numbers to be >conservative? If there were any problems, can you >recommend any changes to incorporate before testing? I >would hope the Harmon Rocket folks tested much higher, but >I don't know what, if anything, they changed in the control >system or structure. The FAA's idea of how to set the VNE is to dive test the airplane to 110% of the VNE. In other words, for a 200 mph VNE, one must demonstrate 220 mph dive. This is just one part of the margin of safety built into the design certification process. As to Van's numbers being conservative... I think he's been very forthright and honest with us on *ALL* the numbers for the RV series. Many have met and exceeded his proto-type performance numbers and some have managed to come in at less weight than the proto-type, so why should we doubt that he has tested the design to the FAA standard for VNE? If you wish to test to a higher speed, be sure that as you excite the controls (usually done by "slapping" the stick) you are actually pointed slightly nose up, so as to be slowing down. If flutter begins to occur, one is already slowing which helps damp the offending motion. There are some good source materials on inflight testing available from the Government Printing Office and from EAA and in several books by various authors, get them and understand the causes and cures for flutter *BEFORE* you try to establish your own VNE. Bob Steward, A&P IA AA-1B N8978L AA-5A N1976L ________________________________________________________________________________
Date: Feb 13, 1998
Subject: Canopy open in flight?
>A related question: any ideas on in-flight egress from a -6 >slider? I've heard that you can't open the canopy above >~130 mph because of backpressure. It's not much good >wearing a chute for either flight testing or aerobatics if >you can't get out to use it. I thought about using quick >release pins to attach the rollers to the canopy frame, >with a handle built-in to pry the canopy back far enough to >clear the molding. How much force would it take to slide >the canopy back 2 inches? My thought is you could then >push it up and have the slipstream "remove" it for you. > Seems like this would take alot of time and coordinated >actions... all at the wrong time. Has anyone solved this >or have any suggestions? Explosive bolts? Light weight >ejection seats? >Thanks, >Greg Young >RV-6 N6GY (reserved) fuselage out of jig I own 2 Grummans with sliding canopies. The design and shape are very similar to Van's RV-6/A slider. The Grumman canopy can (and should!) be opened on warm days in flight. There are limits to how far back one is supposed to open the canopy (about 13") and it is only supposed to be open at speeds of 130 mph or below. It is not hard to open the canopy, infact it will open itself a few inches if the latch is undone. The further back it is pushed, the harder it gets, it acts as though the air flowing over the opening creates a suction which pulls the canopy back to the closed position. It is possible to open the canopy fully in flight, and those who have done it report that the drag increase slows them considerably, but that other than some reports of low frequency vibration of the aft canopy edge, there have been no other ill effects. There is a story of Grumman pilot using his plane to drop a skydiver. Supposedly, they slowed the plane, opened the canopy, and after unbuckling the seat belt of the skydiver, rolled inverted and dropped him out the open canopy. This may be "urban legend" but was printed in a flying magazine as a true story. Since this is all related to Grummans, it should be noted that RVs may react considerably differently. Whose got a slider that they have tested in the open position? Bob Steward, A&P IA AA-1B N8978L AA-5A N1976L ________________________________________________________________________________
Date: Feb 13, 1998
>Just thought I would pass on my experience in attempting to back rivet the top >skins on the wings of my RV-8. I have the special tool from Avery for this. We >found that the rivets do not set as far in and as flush as with the regular >method (bucking from the inside). When you stop and think about it, you are >pushing the rivet out, not pushing it in, so no matter how big or flat or >convex the bucking bar is, the rivet is just simply not set in the dimple as >well. Just our observation and experience. >Von Alexander >RV-8 #544 Has anyone "front" riveted their wing skins using Avery's swivel set? I was quite impressed by the job it did on the horizontal stab (no dings at all, despite my lack of experience). Is it really neccessary to backrivet the wings, or can you do an qually nice job with the swivel set? Alan Carroll RV-8 #80177 (Wings) ________________________________________________________________________________
Date: Feb 13, 1998
I found no problem with two inches when I inadvertantly left it open on take off! Did not have the inclination to try for more however. Sorry. hope this helps ________________________________________________________________________________
Date: Feb 13, 1998
One person I encounterd had this same awful result. He did not realize he needed to push the gun against the rivet and maintain pressure before pulling the trigger. :-( It was an easy fix. Hope this helps. ________________________________________________________________________________
Date: Feb 13, 1998
<< The instructions indicate using shielded, twisted pair wire for the wiring application. What has everyone been using for this application? Two days of searching has left me without any wire and I'm hoping it can't be this hard. >> Rocky Mountain will sell you all you want. ________________________________________________________________________________
Date: Feb 13, 1998
>> I'd be interested in hearing anyone's experience in flutter >> testing their RV, whether done rigorously or not. > >I'd say that flutter testing isn't really necessary, if the a/c is built to >plans specifications. 10% above Vne is sufficient for testing in a standard RV. I believe Van issued a statement in one of the RVators (can't remember which one) that standard slap-the-stick flutter testing should not be done. You are the factory for your airplane. You need to determine what YOUR Vne is and test fly your airplane to 10% above that. Keep in mind, the Vne Van publishes is the design Vne; i.e., the airplane was designed for that Vne, which the designer would recommend not to be exceeded. Michael RV-4 N232 Suzie Q Flying (Vne 210, been to 230) ________________________________________________________________________________
Date: Feb 13, 1998
>Remember, you are going to need some three conductor shielded wire >for the manifold press, and fuel sending unit if you are using it. > >Craig Hiers > > Craig, Talk to Ron Mower from RMI. According to him the three conductor wiring isn't needed when installing the unit in an RV. The main reason the three conductor wire is used is when installing these sensors in a plastic aircraft. I used the two conductor throughout my -6A and had no problems. Hope this helps. Scott Gesele N506RV - Flying ________________________________________________________________________________
Date: Feb 13, 1998
Subject: Re: Web page for Painting
><< Dupont tech reps have told me applying > Veriprime without a topcoat could be considered detrimental. The reason you > are suggested to apply a topcoat within 16 hours of applying Veriprime is > because of the moisture absorbed during that time. >> > Let's here from just one person whose RV started to corrode under a layer of VariPrime. Scott Gesele N506RV - Flying ________________________________________________________________________________
Date: Feb 13, 1998
> >Sirs, > >I recently received the baffle kit for an RV-6, O-320. Going together >fairly well. > >Couple of questions: > 1. I have to trim a good bit off the front side pieces. I assume the kit >is for the fixed pitch cowling. Right? A: The kit will fit either cowling. Trim it to fit yours. > > 2. A piece of aluminum was delivered with the instructions. It's about >8"x11". What's it for?? A: Can't tell from this description > >I intend to install the oil cooler (from Van) on the left baffle. > >Is this piece of aluminum supposed to be used as a doubler on the left rear >baffle to reinforce that area for the oil cooler?? A: Sounds likely. Details should be shown on the baffle plans. > >Thanks, >Bob Cabe >San Antonio > >--- > "The opinions expressed herein are solely the author's > and are not necessarily the opinions of USAA." > > > > > > > Bill Benedict G.M., or Tom Green, or John Morgan, or Ken Scott or the office staff @ ls ________________________________________________________________________________
Date: Feb 13, 1998
Subject: Re: not Backriveting the Wings
On Fri, 13 Feb 1998, Alan Carroll wrote: > > Has anyone "front" riveted their wing skins using Avery's swivel set? I > was quite impressed by the job it did on the horizontal stab (no dings at > all, despite my lack of experience). Is it really neccessary to backrivet > the wings, or can you do an qually nice job with the swivel set? > did just that last month. Looks fine except for one dent from the bucking bar hitting the skin. Back riviting is not nesscary, even on control surfaces. Front rivited the stiffners to the aileron skin, no dents, looks fine, is as strong as any other method. Brian Huffaker, DSWL (huffaker(at)utw.com) President and Founder Friends of P-Chan RV-8 80091 Attaching 1st Aileron to wing. ________________________________________________________________________________
Date: Feb 13, 1998
Subject: Re: RV-List:Flying
From: Department of Encouragement Re: Keep Building: Your gonna LOVE this airplane More notes from the test flying. Up this morning doing climbing times, solo, full fuel. Have to start at 6K cuz the ground is at 5.5K. Goes up like a scalded cat. Three speeds: 100, 110, 120, from 6-11K. Don't have all the data yet compiled and I will need to repeat these tests but Best: 110 1350-890fpm. Wow. (This is an O-320, Warnke prop.) While I was up at 11K, did a bunch of stalls. Straight ahead and departure stalls, various flaps; accelerated stalls. What a sweet airplane! Suzie Q tends to drop the left wing slightly in all configurations but is a gentle staller. Not a whole lot of buffett but enought to tell you, along with attitude and control feel, things are going to let go. NO bad habits; no whipping the wing down. Slips at a hellish rate, too, without feeling like you are about to break off in a spin. You can also hold her in a stall, wings level, coming down stalled, wings kept level with rudder OR ailerons (they are effective all the way throught the stall) and instant recovery with neutral stick. Man, what an airplane. More later. Keep Building! Michael RV-4 N232 Suzie Q Flying, expanding the envelope ________________________________________________________________________________
Date: Feb 13, 1998
Tony Moradian wrote: > > > Can someone tell me what I am doing wrong? > > Thanks, > > Tony Moradian > Empenage #80398 > N100TM reserved > tmoradia(at)ix.netcom.com Tony, Were you using a back rivet set? Jack Abell Los Angeles RV-6A N333JA (Reserved) ________________________________________________________________________________
Date: Feb 13, 1998
<< Let's here from just one person whose RV started to corrode under a layer of VariPrime. Scott Gesele N506RV - Flying >> Scott, Do you really think such statements and solicitations fosters an educated discussion of the benefits of using this or any other products???? I believe members of the list have already stated parts and or assemblies have shown signs of corrosion while others have not. Not very credible evidence one way or the other. I beginning to believe many have been using products based on unsound information, spending their money and wasting their time. Do you remember when burns were treated with butter???? How about the cautions about the dangers of the downwind turn????? Rethinking has dismissed these things that were once considered the norm. Having no stake in any product or process. Merely sharing research from credible souces in the interest of enlightenment. Others need not pay any heed. Tony Philpin RV - 8 Empennage ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Subject: Stick Angular Displacement 6A
Date: Feb 13, 1998
boundary="----=_NextPart_000_001A_01BD389B.0B650CA0" This is a multi-part message in MIME format. ------=_NextPart_000_001A_01BD389B.0B650CA0 I would appreciate it if someone with controls installed and adjusted to = full elevator movement would measure the stick angular displacement from = full up to full down. I have the F689 forward elevator pushrod installed = so far. Its forward (down) travel is limited by the rear ball end = bearing fouling on the F635 bellcrank. The rear (up travel) is limited = by forward ball end bearing fouling on the fork of the Wd610 weldment.=20 I can obtain only 29 degrees of movement, as measured with a Smart Level = with the zero set in the full up position. This seems inadequate since I = am a long ways from being limited by the spar in full down position. = I=92d like to get a calibration of stick movement so I know what I=92m = up against now that I=92m starting to mount the tail. Thanks. Dennis Persyk 6A tail mounting Barrington, IL=20 ------=_NextPart_000_001A_01BD389B.0B650CA0 http-equiv=3DContent-Type>
I would appreciate it if someone with controls installed and adjusted = to full=20 elevator movement would measure the stick angular displacement from full = up to=20 full down. I have the F689 forward elevator pushrod installed so far. = Its=20 forward (down) travel is limited by the rear ball end bearing fouling on = the=20 F635 bellcrank. The rear (up travel) is limited by forward ball end = bearing=20 fouling on the fork of the Wd610 weldment.
I can obtain only 29 degrees of movement, as measured with a Smart = Level with=20 the zero set in the full up position. This seems inadequate since I am a = long=20 ways from being limited by the spar in full down position. I’d = like to get=20 a calibration of stick movement so I know what I’m up against now = that=20 I’m starting to mount the tail.
Thanks.
Barrington, IL
------=_NextPart_000_001A_01BD389B.0B650CA0-- ________________________________________________________________________________
From: "Steven Spruell" <sspruell(at)idexsystems.com>
Subject: Backriveting the Wings
Date: Feb 13, 1998
Importance: Normal > Has anyone "front" riveted their wing skins using Avery's swivel set? I > was quite impressed by the job it did on the horizontal stab (no dings at > all, despite my lack of experience). Is it really neccessary to backrivet > the wings, or can you do an qually nice job with the swivel set? > > > Alan Carroll > RV-8 #80177 (Wings) Yes, I did. I was VERY pleased with the results. The secret is just using your thumb and forefinger on the rubber boot of the rivet set to hold the set firmly in place. I used Avery's 3x gun at about 40-42 psi. I orignially tried to back rivet the top skins, but gave up after about 6 rivets because the 12" angle rivet set was to difficult to use (couldn't get a satisfactory shop head). Steven Spruell RV-6A N316RV (fuselage) Houston Bay Area RVators http://www.iwl.net/customers/markr/hbar ________________________________________________________________________________
Subject: not Backriveting the Wings
Date: Feb 13, 1998
> > did just that last month. Looks fine except for one dent from the > >bucking bar hitting the skin. Back riviting is not nesscary, even > on > >control surfaces. Front rivited the stiffners to the aileron skin, > no > >dents, looks fine, is as strong as any other method. > > Just wondering - why didn't you back rivet your ailerons? With > thinner > skins like those, backriveting seems like it would be *far* easier, > faster, and no chance of dinging a skin. > > Just curious - don't take offense! > > Mitch Faatz San Jose, CA N727MF (reserved) > RV-6AQME finishing up sliding canopy... > > ________________________________________________________________________________
Date: Feb 13, 1998
Subject: EXT. LIGHTING
Thanks from all who gave their input about Nav,Strobe, and Position light placement. Jim Nice RV6S ________________________________________________________________________________
Date: Feb 13, 1998
Hi Charles, SOmeone mentioned that nets use unshielded cable - not sure, everything around here seems to be terminated already and boss would probably not like to see it opened up. Whatever it takes, use what is spec'd!.. One cable here is "CAT 5" - the top grade and the terminator is clear plastic and it does not appear to be shielded. Sorry if I troubled you with my incorrect info about network cable. Ideally, you ought to get something pre-terminated as they are tricky todo. hal ________________________________________________________________________________
Date: Feb 13, 1998
Subject: Re: Backriveting the Wings
This week I had the opportunity to see another builder's aircraft, the day after I "front riveted" my HS. He back riveted his wings, and there definitely is a difference. I used the swivel set on my HS, and I got a very nice, ding free finish, but the back riveted wing skins still looked smoother. I always thought back riveting was done against a metal plate set on a bench top or similar flat surface, but he used a 3"x5"x1.75" steel plate held like a bucking bar. Looking at the plate, it looked way too light to be used for this purpose, but the proof is in his finish. He is a first time builder too. He also countersunk all his HS rivets instead of dimpling as per the plans. He said the thicker skins were plenty good (.032?). Can anyone comment on this? (I'm sure plenty will!) His tail is glass smooth, and looks great, but is it safe? Aerobatics don't interest him, so he won't be intentionally pulling any G's. Moe Colontonio RV-8 HS almost done Cherry Hill, NJ > > Has anyone "front" riveted their wing skins using Avery's swivel set? I > was quite impressed by the job it did on the horizontal stab (no dings at > all, despite my lack of experience). Is it really neccessary to backrivet > the wings, or can you do an qually nice job with the swivel set? > > Alan Carroll > RV-8 #80177 (Wings) > ________________________________________________________________________________
Date: Feb 13, 1998
On Fri, 13 Feb 1998, Mitch Faatz wrote: > > > >control surfaces. Front rivited the stiffners to the aileron skin, > > no > > >dents, looks fine, is as strong as any other method. > > > > Just wondering - why didn't you back rivet your ailerons? With > > thinner > > skins like those, backriveting seems like it would be *far* easier, > > faster, and no chance of dinging a skin. > > > > Just curious - don't take offense! Found it easier to get the bucking bar inside the bends than to hold the skin back and get the whole gun in there. The innermost are tough either way tho. Brian Huffaker, DSWL (huffaker(at)utw.com) President and Founder Friends of P-Chan RV-8 80091 Installing 1st aileron ________________________________________________________________________________
Subject: Pressure mask for painting
Date: Feb 13, 1998
Thanks John. Thats what I had it mind. Don Jordan~6A wings~Arlington,Tx donspawn(at)juno.com _____________________________________________________________________ You don't need to buy Internet access to use free Internet e-mail. Get completely free e-mail from Juno at http://www.juno.com Or call Juno at (800) 654-JUNO [654-5866] ________________________________________________________________________________
Date: Feb 13, 1998
Sorry, his plate is 3"x5"x.75". A 1.75" plate would be very heavy. >I always thought back riveting was done against a metal > plate set on a bench top or similar flat surface, but he used a > 3"x5"x1.75" steel plate held like a bucking bar. Moe Colontonio ________________________________________________________________________________
Subject: Re: Stick Angular Displacement 6A
Date: Feb 13, 1998
Dennis, you and I are neck and neck! Actually, I guess you're a bit ahead of me. I'm just thinking about running the push tubes. Well, I have to make them first. I did get the rudder cables through the rear skins today. Tomorrow, I'll be putting the engine back together with my A&P buddy. Have you checked the manual for the movement degrees? If I remember, it may be toward the back of the manual. Maybe in the flight preparation section? I know it's in the archives if you can find it. There's been much discussion of it over the past year. >I can obtain only 29 degrees of movement, as measured with a >Smart Level with the zero set in the full up position. This seems >inadequate since I am a long ways from being limited by the spar in >full down position. Id like to get a calibration of stick movement so I >know what Im up against now that Im starting to mount the tail. Jim Sears in KY RV-6A #22220 ________________________________________________________________________________
Date: Feb 13, 1998
Subject: drilling thin tubing (spacers & bearing)
Anyone have any hints for drilling the spacers & brass bearing for the aileron mounts? They just spin in every clamp I can devise, getting rather deeply _scored_ (not scratched) in the process. Brian Huffaker, DSWL (huffaker(at)utw.com) President and Founder Friends of P-Chan RV-8 80091 Mounting 1st Aileron ________________________________________________________________________________
Date: Feb 13, 1998
From: "David L. Macintire" <dave_mac(at)bellsouth.net>
>HinkleyC(at)fca.gov wrote: >Variprime is one of the best self-etching primers money can buy. I agree although I have not tried any of the others. >What has not been stressed or presented during the almost 4 year >debate is it's proper use according to DuPont. . . . be to provide an >information source for the manufactures recommended use for their >products. Could it be that we Americans are becoming cynical? Many of us refuse to believe what the manufacturers say. For example, the label clearly states that this product should not be used by the general public, only by professional painters. That's a ridiculous statement. We all know that DuPont and most of the other large chemical companies have had problems with their products. In this age of over litiginess, the lawyers now run DuPont. They force the company to put absurd statements on their products, and they probably force the company to occupy an overly conservative position in regards to their product's application. It is much worse when the word "airplane" or "aviation" is involved in their product applications. > As always Van's advice is right on target, " Pick any primer, follow >the manufacturers directions". This is very true. > . . .good bet that they have never been into a DuPont or PPG or SW >store to purchase the type of paint used to paint aircraft or cars. So >how are they going to pick a paint system? Listen to the people who have had experience with the product. Don't always believe everything the manufacturer claims. > The reason this RV-list is here is because Van's plans and >instructions are very simple and to the point. Sorry, I disagree somewhat, but this is a different subject. > They leave allot of unanswered questions for > the first time builders, so we turn to the RV-List for help and >guidance. I have found the list somewhat helpful, but I am not that far enough along building my RV-6 to stand by that completely. > This is why the primer questions keep coming up. Every one is trying >to build the best RV they can and they want that extra protection that >paint will provide. Cannot argue with that. Dave Macintire RV-6 Left Elevator Orlando, FL ________________________________________________________________________________
Date: Feb 13, 1998
Tony Moradian wrote: > > > Can someone tell me what I am doing wrong? I was practicing back rivetting > with some scrap pieces. My working pressure was around 40 psi. The rivets > came out terrible. They were all bent. The gun was moving all over the > place. I am sure it's something obvious this novice hasn't seen yet. Go > ahead let me know what i am doing wrong. Tony; It's been a while since I back rivited my top skins, but I used the long tool from Avery. I ground some of the bottom shoulder off so I would not have any contact with the ribs. I held the tool with one hand to guide it and had my Son hold a large bucking bar. Prior to riviting, I had also taken a turn or two with the cutter as Orndorf suggests, and the rivits came out looking excellent. The turn or two with the counter sink tool as Orndorf suggests will also eliminate the need for the tank dimple dies that people have been discussing. You will not have to shave the rivit heads either. John Kitz N721JK Ohio ________________________________________________________________________________
Date: Feb 13, 1998
Gregory Young wrote: > > > I'd be interested in hearing anyone's experience in flutter > testing their RV, whether done rigorously or not. Seems > like there are quite a few RVs capable of exceeding Van's > 212mph Vne in level flight and I hope to be able to as well > when mine is done. I fully intend to do flutter testing to > establish my own Vne, but I'd like to know what to expect. > Has anyone had problems attributable to building > differences, or conversely, found Van's numbers to be > conservative? If there were any problems, can you > recommend any changes to incorporate before testing? I > would hope the Harmon Rocket folks tested much higher, but > I don't know what, if anything, they changed in the control > system or structure. > > A related question: any ideas on in-flight egress from a -6 > slider? I've heard that you can't open the canopy above > ~130 mph because of backpressure. It's not much good > wearing a chute for either flight testing or aerobatics if > you can't get out to use it. I thought about using quick > release pins to attach the rollers to the canopy frame, > with a handle built-in to pry the canopy back far enough to > clear the molding. How much force would it take to slide > the canopy back 2 inches? My thought is you could then > push it up and have the slipstream "remove" it for you. > Seems like this would take alot of time and coordinated > actions... all at the wrong time. Has anyone solved this > or have any suggestions? Explosive bolts? Light weight > ejection seats? > > Thanks, > > Greg Young > RV-6 N6GY (reserved) fuselage out of jig > > Sounds to me like you bought the wrong airplane. Since your not to happy with the design and performance. It's homebuilt! You can do whatever you want to do with it. I just hope I don't recognize your name in NTSB accident reports. GOOD LUCK!!! Don ________________________________________________________________________________
Date: Feb 13, 1998
> Has anyone "front" riveted their wing skins using Avery's swivel set? I > was quite impressed by the job it did on the horizontal stab (no dings at > all, despite my lack of experience). Is it really neccessary to backrivet > the wings, or can you do an qually nice job with the swivel set? Alan and listers, My experience and observations tell me that the cosmetics of the skins are mostly dependent on how well the underlying structure is prepared. The swivel set worked well for me with standard riveting, but do trim off some of the red rubber if it is too long. Consider this also - the impact of the set in "front" riveting forces the layers together just as the bucking bar sets the rivet. Back riveting does not do this, and relies on the crushing rivet to bring the layers into contact. Drawing this out on paper and stepping through the inertia effects helped me understand the dynamics of back riveting. I'm not saying back riveting is a problem, I just don't like its lack of clamping force prior to setting the rivet. The spring on some of the back riveting sets helps, but pales in comparison to the inertial forces. Alex Peterson 6A canopy, Maple Grove, MN ________________________________________________________________________________
Date: Feb 14, 1998
Subject: Workmanship Concerns (CHATTER)
Dear listers, I had an opportunity to take a close look at a brand new Mooney Encore this evening. Mooney's Western Region Sales Manager stopped through our local airport this evening on his way back to Colorado Springs. I couldn't believe the workmanship on the Mooney's wings. Comparing the Mooney riveting job to my HS (my first and worst efforts), my HS was 10x better. You could tell that the flanges on the Mooney didn't lay flat, the bucking bar wasn't flush, etc., etc. If I didn't know better, I'd think that the wing skin was .020" with all the waves and ripples. Heck my ailerons looked better than the Mooney's wings! I guess what I'm trying to say is that we all (me too) have a tendency to be overly critical of our own work. We all get caught up in things like priming and back versus standard riveting, etc. Obviously the Mooney was airworthy and I doubt the its structural integrity suffered any, but wow, the workmanship on my -8 will be much better than the Mooney, and I'm just a desk-jockey by day. What really made me grin was when the sales manager proudly told me that if you got the thing up to 25,000 feet, it could cruise at 190kts burning _only_ 13.5 gallons per hour! Sorta makes me want to find a Mooney at 10,000ft and slide up beside it at 180kts while INVERTED with my landing gear hanging out in the wind and while burning 10.5 gph! arghh, arghh, arghh... He even told me that it would climb at better than 1300fpm! Wow, really?!? Is that at FULL power? Miscellaneous ramblings, I know, but somehow it really inspired me to get building! Best to all, Rod Woodard RV-8, #80033 [working on ailerons--yes, STILL] Loveland, Colorado ________________________________________________________________________________
Date: Feb 13, 1998
> I would appreciate it if someone with controls installed and adjusted >to full elevator movement would measure the stick angular displacement >from full up to full down. I have the F689 forward elevator pushrod >installed so far. Its forward (down) travel is limited by the rear ball >end bearing fouling on the F635 bellcrank. The rear (up travel) is limited >by forward ball end bearing fouling on the fork of the Wd610 weldment. I >can obtain only 29 degrees of movement, as measured with a Smart Level with > the zero set in the full up position. This seems inadequate since I am a >long ways from being limited by the spar in full down position. I'd >like to get a calibration of stick movement so I know what I'm up >against now that I'm starting to mount the tail. Thanks. 6A tail >mounting Dennis, ... I just had a similar problem and had to buy a new VA-115 end fitting to shorten my forward elevator pushrod. I believe that the 47.5 inch length shown on the plans for this pushrod tube is in error, and this displaces the neutral position of the F635 bellcrank top end forward. This leads to the rear ball end bearing fouling you described above. Check your neutral position .... reading the drawings, I assume that when the small lower arm of the Wd-610 weldment is vertical, then the F635 bellcrank should also be vertical. I think this should also be the 15 degree slope forward on the control stick that the instructions call neutral elevator. Is your forward pushrod cut to 47.5 inches tube length?? The forward fouling against the Wd-610 weldment is a seperate problem that others have reported, and is fixed with a little grinding. My new VA-115 arrived this week, so I'll try this out this weekend and let you know what angles I come up with. ... Gil (shouldn't have believed the plans dimensions) Alexander .. control tube cutting ... ------------------------------------ RV6A, #20701, finishing kit "REPLY" sends to entire RV-list mailto:gila(at)flash.net to reply privately ________________________________________________________________________________
Date: Feb 13, 1998
> >><< Dupont tech reps have told me applying >> Veriprime without a topcoat could be considered detrimental. The reason you >> are suggested to apply a topcoat within 16 hours of applying Veriprime is >> because of the moisture absorbed during that time. >> >> > >Let's here from just one person whose RV started to corrode under a layer of >VariPrime. Scott, ... as per my previous post, my horizontal tail steel hinge brackets corroded while the assy. was still in my garage. The corrosion showed up as brown, dirt-like spots. .... Gil (use epoxy) Alexander > >Scott Gesele N506RV - Flying ------------------------------------------------------- mailto:gila(at)flash.net Gil Alexander, Los Angeles, CA ________________________________________________________________________________
Date: Feb 14, 1998
> This seems inadequate since I am a long ways from being limited by > the spar in full down position. I’d like to get a calibration of > stick movement so I know what I’m up against now that I’m > starting to mount the tail. What exactly does I’m mean Gary Zilik ________________________________________________________________________________
Date: Feb 14, 1998
Subject: Re: Priming
<< Priming aluminum is not rocket science, I think we all are making too much out of this. The airplane for the most part does not need to be primed, so priming with any type of primer has got to provide increased protection over bare aluminum. >> Those 40-50-year old Aercoupes, Cessnas, etc. were not primed at all, and they have been holding out fairly well. Don't spend a career worying about the darn stuff, it's not worth the time. I have used the spray can primer (metal etching) on various hot rods over the years and it holds up fine. You're not going to be flying the airplane through a salt water bath. I'm not trying to be negative or trivialize it or anything but priming the airplane need not be a choice that causes ulcers. As always, My $.02 worth - for what it's worth Merle (Chevy's DO fly) Miller ________________________________________________________________________________
Subject: Re: Workmanship Concerns (CHATTER)
Date: Feb 14, 1998
>I couldn't believe the workmanship on the Mooney's wings. >Comparing the Mooney riveting job to my HS (my first and worst >efforts), my HS was 10x better. You could tell that the flanges on >the Mooney didn't lay flat, the bucking bar wasn't flush, etc., etc. If I >didn't know better, I'd think that the wing skin was .020" with all the >waves and ripples. Heck my ailerons looked better than the >Mooney's wings! Whenever I get a feeling I'm not doing well with my riveting, I go look at commercially built airplanes. Of course, I can't do that with my Cheetah since it's glued together; but, I can look at the quality of the assembly. In every case, it's lacking a bunch. I'm not building a show plane; but, I think my -6A will look better than a commercially built one. Take a look at one of the new Cessna 172s. :-) When I get hung up on all of those rivets we have to do, I like to go down to Middlesboro, KY to look at the P-38 restoration project. After looking at all of the rivets in that baby, I come back with a renewed appreciation for how few we have in the RVs! One thing a friend told me was that our worst rivet is proably 90% as strong as a perfect one. Since he's a design engineer with the Cessna jet folks, and has talked a lot with the manufacturing folks, I guess he knows a bit more than I do about things like that. Well, I still try to drill out my worst ones; but, I don't drill out every rivet I mess up a little. I'm more afraid of making a weakened hole or a deeper depression in the skin if I redo the ones that are not quite perfect. As for the tiny depressions I may make in the skins from riveting, I'm building a metal airplane that isn't a show plane. Remember? Critics had better beware when they look at it (after I start flying it, of course. It's fair game right now. ) :-) Jim Sears in KY RV-6A #22220 (Will be assembling the engine today) ________________________________________________________________________________
Date: Feb 14, 1998
> From: Gary Zilik > > This seems inadequate since I am a long ways from being limited by > > the spar in full down position. I’d like to get a calibration of > > stick movement so I know what I’m up against now that I’m > > starting to mount the tail. > > What exactly does I’m mean I would suspect that it means " ' ", as in "I'm" and "I'd". :-) Bob Moore ________________________________________________________________________________
Date: Feb 14, 1998
Hi Guys, I am building my RV6 in my T Hangar at Republic Airport, Farmingdale New York. I have my Seneca 1 in the T Hangar also, and every time I get upset over workmanship, I just go over and look at the Rivet Work on the Seneca. I feel better at once. No way did they take the time and effort we do. So keep on working, Bill ________________________________________________________________________________
Date: Feb 14, 1998
Subject: Re: Rocky Mountain Engine Monitor
Craig Hiers wrote: > Remember, you are going to need some three conductor shielded wire > for the manifold press, and fuel sending unit if you are using it. > > Craig Hiers > Craig: I talked to Ron Mower about this. He told me that on an all metal airplane you could use the shield for the signal ground. He should know. Regards ---- Carroll Bird RV-4 ________________________________________________________________________________
Date: Feb 14, 1998
Gary, ’ means apostrophy Just substitute a ' each time you see that and you'll get the meaning. Some guys like to type the long version. :-) Al > >> This seems inadequate since I am a long ways from being limited by >> the spar in full down position. I’d like to get a calibration of >> stick movement so I know what I’m up against now that I’m >> starting to mount the tail. > >What exactly does I’m mean > >Gary Zilik > > > > > > > ________________________________________________________________________________
Date: Feb 14, 1998
Mike, I think those speeds were achived with Harmon Rockets and we all know they are not RV's. We just let Mark hang around on this list to humor him. We all know he would like to build a real RV but can't help himself. He's addicted to speed! :-) Al >I would like to comment on what I feel is a very dangerous situation. >The RV series airplanes were never meant to be flown at 300 mph, you >should seek another design if you want to go that fast. By reading this >list you might get the idea that its quite common for our planes to be >flown past 300 mph. I do not believe this to be so. For those thinking >about it I would say do some studying and find out what happens when an >airplane flutters, not very many people come back to tell about. I >beleive anyone flying our airplanes like that is flirting with disaster. >I would also question the possibilities of bailing out after a >catastrophic failure. Lets fly our airplanes safe and within the >envelope as established by the manufacture. > >Michael Seager >rv6cfi(at)vernonia.com >1500hrs daul given in RV6 ________________________________________________________________________________
Date: Feb 14, 1998
Subject: subscribe
Please start my subscription. Thank you. schw(at)epix.net ________________________________________________________________________________
Date: Feb 14, 1998
Subject: Panel Planning Software
Hello Friends on the RV List Last week there were a couple of threads asking where to obtain help with planning the instrument panel for our aircraft projects. Mentioned was something called Panel Planner, located at http://www.panelplanner.com/ which turns out to be quite a nifty package. I ordered the program, received it in two days via snail mail, installed it in 20 minutes, and within two hours had produced several iterations of my thoughts on the design of an RV4 panel. Templates are provided for all of Van's products. Click and drag instruments, guages, switches, indicators, etc, from an extensive collection provided with the program to your panel template. Then you can very easily rearrange, align, shift, wish for more space and more dollars, etc. Very easy to use. And with a color printer, the results are terrific. Eventually, when satisfied, you can print out a cutting template. Frank Zeck, North Dakota, RV4 soon to fly. ________________________________________________________________________________
Date: Feb 14, 1998
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: re: cell phones in aircraft
> >I will be getting a copy of the FCC rules from him in the mail. If you >want a copy, e-mail me, and I will e-mail back with it attached. > >I said I WAS going to install it, no longer, and the fine is $10000. Cell phone frequencies are indeed allocated to land-mobile service only and it's an FCC issue, not an FAA one. Therefore, it's a vilolation of a regulation to use one from an airborne aircraft. Now, could you use one while on taxi from active to the ramp to call home, call for fuel, etc? Certainly. Just can't have daylight under the wheels. Would it be prudent to carry a hand held or have an installed cell phone for situations where it's use might mitigate lost of property, or worse yet, loss of life? Certainly. The FCC is like any other branch of government with inforcement responsabilities. The LIKELYHOOD that any single transgression of the rules will be (1) noticed, (2) complained about, (3) acted upon by an enforcer who already has too much on his plate is extremely small. Use of a cellphone in blatant, obvious and noticed disregard for the rules is inviting the wrath of government. Responsable use within the rules with occasional "transgressions" when warranted are most unlikely to bring you grief. Given the capabilities and growing coverage of cell phones and their technology, I'd not go flying without it (if I owned one). It's an issue similar to the ELT's that were once sold to hikers and backpackers . . . obviously not for the original intended purpose but if used only for the most obvious emergency situations, it's unlikely to get the user in hot water. Now, the REAL crime is the fact that a back-packer laying at the bottom of a drop with a broken leg thinks the calvary is going to come riding over the hill as soon as the switch is flipped on his little yellow box. I believe a recent AOPA article told us that ELTs yield their intended usefulness in less than 10% of aircraft accidents where an ELT is installed. But that's another problem . . . My best recommendation, trash your ELT and buy a cell phone. Now, if you wanted to INSTALL a cell phone in your certified ship, the FAA would have you drawn, sawed and quartered for not installing a TSO'ed model . . . it matters not how many lives might be saved. So use only HAND HELD devices in your certified iron, and don't plug it into the cigar lighter. In some FAA jurisdictions this is tantamount to an "installation". Bob . . . //// (o o) ===========o00o=(_)=o00o========= < If you do, > < What you've always done, > < You will be, > < What you've always been. > ================================= <http://www.aeroelectric.com> ________________________________________________________________________________
Date: Feb 14, 1998
boundary="----=_NextPart_000_0031_01BD393B.1E849120" This is a multi-part message in MIME format. ------=_NextPart_000_0031_01BD393B.1E849120 There are two main choices for riveting the wing skins: A) Avery swivel tool [P/N 1047] and a good collection of bucking bars. = Here the RIVETER needs very little skill but the BUCKER needs = considerable skill to avoid dings in the skin from the bucking bar being = cocked everso slightly. B) Avery extra long backriveting set [P/N 4580] and Avery backriveting = bucking bar [P/N 635]. Here the RIVETER needs considerably more skill = than the BUCKER. The BUCKER needs very little skill at all because the = bucking bar angular positioning is automatic with the broad contact = base. The danger is not so much in dinging the skin as in forming bad = shop heads when the rivet set is not held at the right angle. It takes = some practice to get the hang of it, as the geometry and motions = required for driving are not intuitional. My wife and I practiced driving about 20 rivets into a floppy 0.016 = dimpled piece to get the feel of the Avery backriveting set. I found = that I got best results with only 22 PSI at the supply end (25 feet of = 1/4 hose further dropping the pressure). With higher pressures the set = would "dance" on the stem and the set would tend to rotate. The 22 = PSI-driven rivets were not work hardened. Bear in mind that you will wind up using method A) when you put on your = last skins because you have no choice! We put on our top skins first = using method B) but now that we are done I can't see any difference = between A) and B). =20 Dennis Persyk 6A finishing kit Barrington, IL ------=_NextPart_000_0031_01BD393B.1E849120 http-equiv=3DContent-Type>
There are two main choices for = riveting the wing=20 skins:
A) Avery swivel tool  [P/N = 1047] and a good=20 collection of bucking bars.  Here the RIVETER needs very little = skill but=20 the BUCKER needs considerable skill to avoid dings in the skin from the = bucking=20 bar being cocked everso slightly.
B) Avery extra long backriveting set = [P/N=20 4580]  and Avery backriveting bucking bar [P/N 635]. Here the = RIVETER needs=20 considerably more skill than the BUCKER.  The BUCKER needs very = little=20 skill at all because the bucking bar angular positioning is automatic = with the=20 broad contact base. The danger is not so much in dinging the skin as in = forming=20 bad shop heads when the rivet set is not held at the right angle.  = It takes=20 some practice to get the hang of it, as the geometry and motions = required for=20 driving are not intuitional.
My wife and I practiced driving = about 20 rivets=20 into a floppy 0.016 dimpled piece to get the feel of the Avery = backriveting=20 set.  I found that I got best results with only 22 PSI at the = supply end=20 (25 feet of 1/4  hose further dropping the pressure).  With = higher=20 pressures the set would "dance" on the stem and the set would = tend to=20 rotate.  The 22 PSI-driven rivets were not work = hardened.
Bear in mind that you will wind up = using method=20 A) when you put on your last skins because you have no choice!  We = put on=20 our top skins first using  method B) but now that we are done I = can't see=20 any difference between A) and B).
Barrington, IL
------=_NextPart_000_0031_01BD393B.1E849120-- ________________________________________________________________________________
Date: Feb 14, 1998
Alan: My RV-8 wings were riveted with the Avery flush swivel set with excellent results. With care and proper air pressure (28-30 lbs) it was an easy job. It seems everyone is going towards the back riveting of wing skins. Then there is the heat the skins issue... (anyone want to buy a wing skin heating pad, never used?) I think that it is fairly easy to obtain wing skins that look like they have been back riveted as long as it is approached with the same care that you would apply to other areas of your RV construction. I did have the help of an experienced RV builder to hold the bucking bar for me, and also planned rivet sessions that were 2-3 hours maximum duration. Again, the key is a well coordinated team with some prior experience, as well as taking your time. As for the quality of the riveting on my RV-8 wings, you may wish to ask those list subscribers that have seen them, Scott Gesele, Dave Lundquist, Bill Sivori and maybe a few other builders that have been by my shop. Just my .02. Hope this helps, Jon Ross RV-80094 fuselage ________________________________________________________________________________
Date: Feb 14, 1998
Subject: Re: drilling thin tubing (spacers & bearing)
<< Anyone have any hints for drilling the spacers & brass bearing for the aileron mounts? They just spin in every clamp I can devise, getting rather deeply _scored_ (not scratched) in the process. >> Have you tried freezing them into a block of water ice? Sounds goofy but it's a dandy way to hold irregular shapes with easily scratched surfaces. Use the minimum amount of water necessary to barely cover the part and a container through which you don't mind drilling a hole after the bit passes through the part. (The container can be reused by putting some duct tape over the hole.) Let us know it works with this particular part. I've done this on other items but never tried it on a circular part that might spin within the ice. Have fun, Bob ________________________________________________________________________________
Date: Feb 14, 1998
<< Whenever I get a feeling I'm not doing well with my riveting, I go look at commercially built airplanes. Of course, I can't do that with my Cheetah since it's glued together; but, I can look at the quality of the assembly. In every case, it's lacking a bunch. >> This may be all good and well that we certainly take more care in our work than a typical assembly line worker, but before we get to euphoric, I think we should not forget they do have an expert (we hope) quality person over looking their work to make sure the gliches are only cosmetic and not a safety issue. You are the only set of eyes to keep your airplane safe, so let's not dilute ourselves by looking at their gliches and passing our hacks off to lightly. Bernie ________________________________________________________________________________
Date: Feb 14, 1998
Subject: Re: RV-6 Seat Rib Question
> Today I got to the point that it was time to install the seat ribs > between bulkheads f-604 and f-605. When installing the f-616, > 617,618,619 seat ribs I noticed that the forward flange is not at the > correct angle and wants to impart a twist to the f-604 web. I have again > verified the tilt in the f-604 bulkhead and found no problems. Make sure that your F604 bulkhead is straight by Bracing the forward surface with something that id "dead true." I had the same problem initially and discovered that the bulkhead was warped. I clamped a heavey bar to the forward surface of the bulkhead and the ribs began to match much better. The rear tabs on the ribs are horribly bent to all sizes. had to shim several varing from 0.040 to 0.100. one was so bad it was replaced. Jerry Walker ________________________________________________________________________________
Date: Feb 14, 1998
Alan, Of course its not necessary, as many here have already said. But other than having to invest in the long rivet set, I found no negatives in
February 08, 1998 - February 14, 1998
RV-Archive.digest.vol-ef
