RV-Archive.digest.vol-et
May 26, 1998 - June 01, 1998
From: "Moentenich, Brian L NWP" <Brian.L.Moentenich(at)nwp01.usace.army.mil>
Subject: Canopy modification
Date: May 26, 1998
At least one builder (Kevin Lane - N3773) made his seats a couple of inches lower. -----Original Message----- From: dougm@physio-control.com [SMTP:dougm@physio-control.com] Sent: Tuesday, May 26, 1998 12:05 PM To: rv-list(at)matronics.com Subject: RV-List: Canopy modification Medema) Listers: I am just starting my sliding canopy and am very interested in any modifications that will make it taller over the seating area. In talking with various people, including Van, I have been told that you can push the currently supplied canopy back from it's normal position and thus gain an extra inch or so of height over the seating area. I would like to do this but have some questions: 1) Has anyone on the list done this? If so, please contact me directly via email. I would really appreciate being able to communicate directly with you. 2) Does anyone have any knowledge of the modifications required? I believe the roll-over structure (Wd-643) stays the same as well as the front member of the sliding frame. Do I have to replace/rebend the center bar of the sliding frame? How about the rear cross-member? Or do you raise the whole frame up somehow? Since the slope of the canopy over the fixed roll-bar remains the same, I don't see how raising the whole frame would work, but maybe there is something I'm not seeing. Any leads on how to make this modification would be appreciated. Thanks! Doug Medema RV-6A #21140, working on sliding canopy. ________________________________________________________________________________
Date: May 27, 1998
Subject: Re: RFI: Avery close quarter 8-32 screw dimpler
wbpace(at)adnc.com wrote: > Could someone who has used the Avery "Close Quarter 8-32 Screw > Dimpler Kit" please share their opinion of it with me? I bought it recently and have been using it on my wings (tank attach nutplates). It works fine. It does seem expensive to me for what you get -- a male die with a hole through it, 3 or 4 hex-head #8 screws, and an Allen key to match. > Does it produce results which are substantially superior to just > dimpling with an AN 509 screw and K1100 nutplate? Dunno -- didn't try that. > Given about 20 odd holes over two wings, the cost per hole > is over 50 cents - pretty pricy unless I eventually find other > uses for it to help amortize the cost. I believe there's many more nutplates to go yet, although I dunno how many are recessed or how many of those will need the close-quarters tool. Frank. ________________________________________________________________________________
Date: May 27, 1998
Subject: Re: Getting started
Hi Steve, > I am an instrument-rated pilot with no building experience other > than once rebuilding the engine in my car. The bad news is that neither your instrument rating, flying experience, nor your car engine rebuild experience won't help you much towards building an RV. The good news is that you don't actually need any experience. > One: Is it really possible to construct > the major components of this airplane in my single-car garage? I hope so... that's what I'm doing! More seriously, yes. Except (obviously) for fitting wings to fuselage. I'm most of the way through building my wings, all work done so far in my spare room (empennage) and single garage. I'm sure that building the fuselage can be done in my garage too. As someone else said, you will need to find somewhere to store your completed components. > And two: What preparation should I as a builder put myself > through before I attempt this insane task? 1) Stop calling it insane. It's not insane -- just a big challenge. Over 1800 people have shown that it *is* possible. 2) Join your local EAA chapter 3) Help out (or just watch) someone else building 4) Go to one of the Alexander Aeroplane/Aircraft Spruce sheet metal workshops. 5) Acquire catalogs from tool suppliers like Avery Tools and Aircraft Spruce. FWIW, I've collected my RV building experiences into "The Bunny's Guide to RV Building". My thoughts on the build/no-build decision are available at <http://www.geocities.com/CapeCanaveral/Launchpad/4808/bunny0a.htm> Frank. ________________________________________________________________________________
Date: May 26, 1998
Subject: Re: Auto Fuel in "High" compression RVs?
<< Dumb questions from a guy who has never flown anything but club aircraft fueled with 100LL. 1) How do you get auto gas to the airport and into your plane safely? I use 5 gal containers, and pour in thru a funnel w/ a screen. 2) Where do you buy auto gas to ensure that you are getting gasoline and not some blend (alcohol or??) which may or may not work properly? Check w/ the local suppliers- they will tell you the ingredients. BTW- keep an eye on the RVP of the fuel you choose- locally, the "winter mix" stops 1 May. Will the thing run on 87 octane? That depends! BMEP has a lot to do with it, but a "dirty" cyl will tend to pre-ignite also. To figure BMEP, Pratt & Whitney supplies the following: BMEP=2200 (for the O-360)X BHP divided by RPM. Use your power chart to figure BHP. Bottom line: Part throttle operations should be OK on reg mogas. Check the BMEP at the power setting you plan to use. A chart by Chuck Berthe (Kitplanes- Sept 1995) shows the following BMEP for the O-360: 28"/2700 RPM/147PSI (ok by most standards) 29"/2400 RPM/158 PSI (I'd use 100LL for this one- this is the highest allowed by Lyc) 28"/2200RPM/155 PSI (t/o for most f/p equipped a/c- probably the highest you will see) 28"/2500 RPM/150 PSI (c/s at initial climb) 24"/2100 RPM/131PSI (lower than I'd thought- probably OK w/ 87 octane) 24"/2500 RPM/126 PSI Read Chuck's article- he has researched this stuff much more than I. I have mogas in one tank in my Rocket. It works fine in the air, but it won't do too well on the ground- vapor lock, you know. Check six! Mark >> ________________________________________________________________________________
Date: May 27, 1998
> The FAA has approved the use of varying grades of autofuel > for the engines most are likely to use in their RVs. Yes. > RVs don't need the STC since they are not "certified". Yes. > This means that we are not "experimenting" when it comes to > Auto Fuel use in *MOST* RVs. No! What it means is that you won't be experimenting with the *engine* if you run auto fuel. You would still be experimenting with the fuel delivery system -- for example, someone mentioned vapour lock problems in Mooneys running autofuel. The fact that it works just fine on your Cheetah doesn't mean it'll necessarily work OK in another aircraft model. Here in NZ, we've got rid of our leaded auto fuels. We now have unleaded 91 and 96 octane fuels. At the changeover, there were also quite a number of problems with fuel hoses... the high aromatic (benzene) content of the new fuel caused O-rings to expand and leak. This was first noticed on an aircraft running mogas under an STC. What effect does the aromatics in unleaded auto fuel have on Proseal? How about on the various O-rings and other seals? Note that I'm not saying "Don't try this". What I *am* saying is that if you do try it, do it with your eyes open. Frank. ________________________________________________________________________________
Date: May 26, 1998
Doug, In a few months I, too, will be working on the sliding canopy and will be modifying for headroom. Please post any useful information sent directly to you. Thanks. Ken Harrill RV - 6, fuselage -----Original Message----- From: dougm@physio-control.com [SMTP:dougm@physio-control.com] Sent: Tuesday, May 26, 1998 3:05 PM To: rv-list(at)matronics.com Subject: RV-List: Canopy modification Medema) Listers: I am just starting my sliding canopy and am very interested in any modifications that will make it taller over the seating area. In talking with various people, including Van, I have been told that you can push the currently supplied canopy back from it's normal position and thus gain an extra inch or so of height over the seating area. I would like to do this but have some questions: 1) Has anyone on the list done this? If so, please contact me directly via email. I would really appreciate being able to communicate directly with you. 2) Does anyone have any knowledge of the modifications required? I believe the roll-over structure (Wd-643) stays the same as well as the front member of the sliding frame. Do I have to replace/rebend the center bar of the sliding frame? How about the rear cross-member? Or do you raise the whole frame up somehow? Since the slope of the canopy over the fixed roll-bar remains the same, I don't see how raising the whole frame would work, but maybe there is something I'm not seeing. Any leads on how to make this modification would be appreciated. Thanks! Doug Medema RV-6A #21140, working on sliding canopy. ________________________________________________________________________________
Subject: No hole set
Date: May 27, 1998
Hello I have a Tatco hand squeezer with the one and three inch yokes. I would like a no hole set for the tight spots, however the special yoke in the Avery catalog does not look very thin (or not as thin as the Avery thin nose yokes) My question Does anyone out have the tatco special yoke, is it a useful tool or is there a better alternative. Thank you. Trevor Mills 80605 Brisbane OZ. Finishing left elevator Waiting on wings ________________________________________________________________________________
Date: May 26, 1998
One: Is it really possible to construct the major components of this airplane in my single-car garage? Yes, I'm doing just that. My garage is 16*20 exterior dimension. Tight but do-able. And two: What preparation should I as a builder put myself through before I attempt this insane task? Oh, rebuild the motor in your car, OR build the empenage. Brian Eckstein 6A Fuselage ________________________________________________________________________________
From: "Charles Golden" <Flyinghi(at)worldnet.att.net>
Subject: Newark Catalog
Date: May 26, 1998
I received a Newark Electronics Catalog earlier this year to order some neat electronics out of. Before I discard it, does anyone have a need for it? Send me an address and I will forward it. This is the 1998 edition #116. Seems a waste to toss it. Respond off the list. Regards, Charles Golden RV-6A N609CG Finishing up and so close Chevy V-6 SE Texas ________________________________________________________________________________
Date: May 26, 1998
Subject: Re: Primer
Bob, I have been using Mar-Hyde on my RV-8 project and really like it. It dries fast and is tough as nails once dried. -Jeff Hawkins RV-8 #563 Working on the wings Suwanee, GA > >Has anyone checked out the Mar-Hyde Self Etching Primer for use instead >of Zinc Chromate or Zinc-Oxide? Can any one offer yeah or nay on this? > >Bob Binzer >RV-6A tailfeathers >Madison, Indiana > > > > > ________________________________________________________________________________
Date: May 26, 1998
SWasher1 wrote: > > > To the members of this list: > > I am an instrument-rated pilot with no building experience other than once > rebuilding the engine in my car. Yet I have been captivated by the beauty and > elegance of the RV-6A, not to mention the sheer volume and quality of the > communication on this list. I would like to ask for your expert opinions on 2 > matters that are of concern to me. One: Is it really possible to construct > the major components of this airplane in my single-car garage? And two: What > preparation should I as a builder put myself through before I attempt this > insane task? > Steve, If you have the desire and patience, you can build an RV. I'm building in a two-car garage w/o any problem(so far). I have seen a builder on the list who did it in a one-car. With good planning, you shouldn't have any problem, but you will need places to store completed components. As for preparation, I took the Sport Air sheet metal class, bought the Orendorff(sp?) videos, studied the manual, and read the list. If you can rebuild a car engine, you can probably build an RV. Good Luck. Jerry Calvert Edmond Ok -6a ________________________________________________________________________________
Date: May 26, 1998
Subject: Fuel Cap Engraving
Guys, Want your fuel caps professionally deep CNC engraved with: a) fuel quantity b) fuel grade c) the word "FUEL" There is a dandy engraver in Fargo ND who will charge $20 to engrave both caps and paint the letters black or white, your choice. High quality. I am very satisfied. I disassembled my caps, took the main body of the gas cap to the business, and in a day it was done. Very high quality CNC machine engraving. They kept the template used for mine and asked me to tell my friends that they will be pleased to assist others. Call Linda at 1-701-237-6560. The business address is: ENGRAPHICS, 1335 2nd Ave N, Fargo, ND, 58102 Frank Zeck RV4, June 98 :) ________________________________________________________________________________
Date: May 26, 1998
Subject: Re: No hole set
Tatco makes a no hole yoke. I believe Avery and Cleveland sell them. I have one, and I use it alot. -- Moe Colontonio moejoe(at)bellatlantic.net http://members.bellatlantic.net/~moejoe Trevor Mills wrote: > > > Hello > I have a Tatco hand squeezer with the one and three inch yokes. I would like a no hole set > for the tight spots, however the special yoke in the Avery catalog does not look very thin > (or not as thin as the Avery thin nose yokes) > My question Does anyone out have the tatco special yoke, is it a useful tool > or is there a better alternative. > Thank you. > > Trevor Mills 80605 Brisbane OZ. > Finishing left elevator > Waiting on wings > ________________________________________________________________________________
From: "TOMMY E. WALKER" <twsurveyor(at)email.msn.com>
Subject: Getting Started
Date: May 26, 1998
I tell people who ask "How's the plane comming?", that building an RV (or any plane for that matter) is like "Eating an Elephant". You have to take that first bite if you want to eat him. Soon after that first bite you'll know if you have a taste for elephant or not! A few bites of him every day is the key! If you only have elephant every week or two it'll take one hell of a long time to finish him. Also, too much elephant at one sitting is hard to digest, and you'll find yourself saying "Oh no not elephant again". Most folks call it "Burn Out"! After 800+ hours of elephant diet I find myself enjoying the taste more and more! My advise is go ahead and order that first hind leg (Tail Kit) and see if you have a taste for an RV Elephant. Tommy (6-A in single car garage) Ridgetop, TN ________________________________________________________________________________
Date: May 26, 1998
Subject: HS-411 bearing - Prime?
HI Guys and Gals - you can tell from the subject that I've just gotten started. My first two questions aren't specifically addressed in the archives, although one got side-swiped. The rivets called out in the plan sheet to sandwich the bearing in HS-411 are 4-5s. I drove the first one and went to check it with the guage - something's not right. I think the rivet is too short. It's good that this stopped me, though, as I started wondering: Should that bearing be primed along with the brackets? I didn't do it because it seemed like the primer would get into the bearing and cause problems. What? Sealed bearing you say? Guess I have to drill out that rivet and replace with a -6, and while I have it apart again... prime the bearing? Thanks all Mike Thompson Austin, TX RV-6 25368 Emp. ________________________________________________________________________________
Date: May 26, 1998
Subject: Elevator Bearings
Hi Paul: I feel your pain! First of all, make sure that your bolts will pass through the brackets on your HS. I had to pass a drill bit through mine by hand a couple of times to make enough room. Then, I used an old surgical forcept to hold the bolt in the hole of the bracket while I positioned the rod end so that the bolt would pass through. These surgical forcepts are slender enough to allow you to hold the bolts through the rod end cutouts in the elevator skins. I immagine that you can use similar forcepts that are sold in sporting goods stores for removing fish hooks. Since I don't catch much fish, I use mine on my RV! ;^) Hope this helps you out One last note, my condolences to the RV family on the loss of the RV8 and its pilots. We all share in their loss. Regards, Jeff Orear RV6A 25171 elevators Peshtigo, WI ________________________________________________________________________________
Date: May 26, 1998
Subject: Re: Rotary engines in RVs
Anyone out there comtemplating putting a Mazda 13B into an RV? I'm certainly leaning that way. I'm pretty well along on the wings for my RV-4. Any input is welcome, even negative, so fire away. Brian, Redmond, Wa ________________________________________________________________________________
Date: May 26, 1998
Subject: Re: X-country flying
I do not think that all of the instruments have to be TSO'd to be legal. That is what I was told by my FSDO during my inspection for certification. I would consider using just a turn coordinator in IFR conditions an emergency and would advise ATC of my condition. The Navaid devices does have a turn coordinator and a ball race for trimming for coordinated flight. Just my opinion. Jim Cone ________________________________________________________________________________
Date: May 26, 1998
Subject: Time to get started
To the generous RV netizens, This was me this morning.... To the members of this list: I am an instrument-rated pilot with no building experience other than once rebuilding the engine in my car. Yet I have been captivated by the beauty and elegance of the RV-6A, not to mention the sheer volume and quality of the communication on this list. I would like to ask for your expert opinions on 2 matters that are of concern to me. One: Is it really possible to construct the major components of this airplane in my single-car garage? And two: What preparation should I as a builder put myself through before I attempt this insane task? Thank you for your responses. Steve Washer Windsor, CT This is me at the end of the day... A little overwhelmed by the sheer quantity and quality of the responses I received both on-line and off-line from you folks. Can't thank you enough! I've been on lists before but nothing approaches the good feeling I get from you all and your passion for this purpose. Thank you for the time you took out of your projects to counsel this "newbie". Your advice was considered, thoughtful, and hopeful, especially in the light of some very sad news which appeared on the list today. Joe Waltz, you made me feel like I knew your friend. Hope to see you all back here very soon and for some time to come. A building project is a long-term commitment, so I hear... Steve (calling the factory) Washer SWasher1(at)aol.com ________________________________________________________________________________
Date: May 26, 1998
Subject: Re: Primer
>> >> Has anyone checked out the Mar-Hyde Self Etching Primer for use >> instead of Zinc Chromate or Zinc-Oxide? Can any one offer yeah >> or nay on this? > I have been using Mar-Hyde on my RV-8 project and really > like it. It dries fast and is tough as nails once dried. > > -Jeff Hawkins Bernie and I have been using mostly Deft (two-part epoxy primer), but we tried Marhyde, too. Deft is easier to clean up (with water), and "hard as nails" doesn't even begin to describe it. I found it easier to apply than Marhyde. We're using an HVLP gun. Marhyde will wash off with solvents, Deft won't. -- -------- Rob Rimbold, RV6A Fuselage, Florida rimbold(at)ntr.net ________________________________________________________________________________
Date: May 26, 1998
Subject: Re: HS-411 bearing - Prime?
No need to prime bearings. At least it is not standard practice. Depending on what the seals are made of, thinner could seep in and ruin the bearing. Most are corrosion resistant material. RV4 233sb ________________________________________________________________________________
Date: May 26, 1998
Make sure you always check rivet lengths, don't just trust what you see in the plans. There are many occasions where you need to use longer rivets. One short rivet is not going to be a problem, but if you feel you can drill it out without any trouble, go ahead. If you really want to prime the bearing, just put tape over the rubber part and spray away. Take a look at my web page, there's alot of tips for beginners. -- Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 page at: http://members.bellatlantic.net/~moejoe GROBDRIVER wrote: > > > HI Guys and Gals - you can tell from the subject that I've just gotten > started. My first two questions aren't specifically addressed in the > archives, although one got side-swiped. > > The rivets called out in the plan sheet to sandwich the bearing in HS-411 are > 4-5s. I drove the first one and went to check it with the guage - something's > not right. I think the rivet is too short. > > It's good that this stopped me, though, as I started wondering: Should that > bearing be primed along with the brackets? I didn't do it because it seemed > like the primer would get into the bearing and cause problems. What? Sealed > bearing you say? > > Guess I have to drill out that rivet and replace with a -6, and while I have > it apart again... prime the bearing? > > Thanks all > > Mike Thompson > Austin, TX > RV-6 25368 Emp. > ________________________________________________________________________________
Date: May 26, 1998
Steve- To be short and sweet: 1. Yes 2. Just get started. 2a. Attend one of the weekend sheetmetal classes if practicable, or just have one of the guys from your Eaa chapter spend about an hour and a half showing you how all of your tools work, and practice messing up some rivets. 3. Just get started. Joel McLaughlin -6 Wings N.C. ________________________________________________________________________________
From: "Douglas G. Murray" <dgmurray(at)telusplanet.net>
SWasher1 wrote: To the members of this list: > I am an instrument-rated pilot with no building experience other than once > rebuilding the engine in my car. Yet I have been captivated by the beauty and > elegance of the RV-6A, not to mention the sheer volume and quality of the > communication on this list. I would like to ask for your expert opinions on 2 > matters that are of concern to me. One: Is it really possible to construct > the major components of this airplane in my single-car garage? And two: What > preparation should I as a builder put myself through before I attempt this > insane task? > > Thank you for your responses. > > Steve Washer > Windsor, CT > SWasher1(at)aol.com > Steve - answer to first question - YES!! I am building in a 12 x 24 foot area. You will need a bit more area when you attach the wings, but not to worry about now. Second concern - Join an EAA Chapter. Those guys are a real asset to your building project - both in information needed and encouragement to keep going. It is a big project to build an aircraft but REALLY WORTH THE EFFORT !! BTW the best tool you can find for your RV project will be a builder who is slightly ahead of you in his/her project :)) GO FOR IT ! and have fun too. Doug Murray - RV-6 Engine - Southern Alberta ________________________________________________________________________________
Date: May 26, 1998
>Anyone out there comtemplating putting a Mazda 13B into an RV? I'm certainly >leaning that way. I'm pretty well along on the wings for my RV-4. Any input is >welcome, even negative, so fire away. Brian, Redmond, Wa Check out my website at http://www.aftershock.org/rv.htm There are pictures of a Mazda 13B installed in an RV-6A. Mitch Faatz San Jose, CA N727MF (reserved) RV-6AQME mounting the empennage & control rods ________________________________________________________________________________
Subject: Re: Elevator Bearings bolts
Date: May 27, 1998
To install the bolts, wrap a piece of fairly heavy copper or aluminium wire (about .063 to .080 electrical single strand cable is ideal) around the shank of the bolt and the up over the head to stop it slipping out. Then install the bolt and when in place,simply pull hard on the wire and it will straighten out and come away. Insulated wire is fine. Works a treat. Brian. ---------- ________________________________________________________________________________
Date: May 27, 1998
G'day, my advice is buy it. It has much more power and does a much better job. Worth every dollar, and our dollar only buys 62 cent US! Brian. ________________________________________________________________________________
Date: May 27, 1998
Subject: Re: RV-8 (N58RV)
My family's thoghts and prayers go out to the famillies of these folks. Will say a prayer with my daughters for them tonight. ________________________________________________________________________________
Date: May 27, 1998
<< any O-320 powered and *MOST* O-360 powered RVs can safely run the correct octane autofuel. >> I think the keyword here is "correct." Regards Wendell WBWard(at)AOL.COM ________________________________________________________________________________
Subject: For Sale
Date: May 26, 1998
1. I have been building my rv-8 project in a 20X20X10 shelter. This hangar/shelter/tent has galvenized steel frames that supports the material covering it which is made out of polyethyline. It has zippered doors in front which roll up through a pully system. The frame can be bolted to the ground as mine is. I am remodeling the house and building a garage so i don't need the hangar any more. The unit was purchased last October @ $1300.00 I have shop lights hanging from the top which will go with it. No reasonable offer will be refused. 2. I also have a steel jig for the wing and the empenage made out of 3/8" thick square tubing with 5/16" thick base plates. It is solid. It was made last year also @ $380.00 I will sell it for $290.00 Please contact me off list if you are interested. Tony Moradian Empenage #80398 N100TM reserved tmoradia(at)ix.netcom.com ________________________________________________________________________________
Date: May 26, 1998
Subject: Salmon Arm Fathers Day Fly in
The Salmon Arm ,( British Columbia) Flying Club Annual Fathers Day Fly in will be held Sunday June 21. Pancake breakfast starting at 7:30 am. Giant flea market for the ladies. Static displays, fly bys, ultra lights,demo's and of course RV's. We hope to have 12 to 16 Rv's attend. Anyone arriving Sat. June 20 is invited to a free spaghetti dinner in the clubhouse. Any RVer's arriving Saturday and desiring complimentary accomodation (builders homes) please advise and we will do our best to look after you. Salmon Arm is approx. 100 miles north of the U.S. border on the beautiful Okanagan Valley and approx. half way between Vancouver and Calgary. For more info contact me direct. Regards Ken Hoshowski C-FKEH RV6 160 HP/C/S First flight Sept 8/93 ________________________________________________________________________________
Date: May 27, 1998
Shaftela(at)aol.com wrote: > Anyone out there comtemplating putting a Mazda 13B into an RV? I am. I've collected together what information I can find at <http://www.geocities.com/CapeCanaveral/LaunchPad/4808/mazda13b.htm>. Actually, I was wondering how Ed Anderson is getting on with his. He should be flying by now. Frank. ________________________________________________________________________________
Date: May 27, 1998
Subject: Vetterman Exhaust Leak- Fixed
I had noticed an exhaust leak on the slip joint just below the #3 cylinder on my Vetterman Exhaust system, and a few other listers wanted me to report if I was able to fix it. So here's what I did: I went down to AutoZone, and purchased a 1 3/4" U shaped muffler clamp. I removed the attaching bracket that holds the upper tube to the lower crossover tube under the #3 cylinder, and used the muffler clamp to slightly compress the outer tube in order to reduce the clearance between it and the inner tube. It took 3 or 4 tries to get it where I wanted it. I then removed the muffler clamp and re-installed the attaching bracket, and Presto! problem solved without having to remove the exhaust system. This was the only joint that showed significant leakage. All other joints seem to be sealing up ok. One thing I notice, on approach to landing, like on crosswind and final, the exhaust pops some. At first I thought maybe the idle mixture was too rich, but while I was flying the red 6A at Van's, it did it too. I've had a couple of the old coots at the field ask me about it, and I'm not sure how to reply. Their convinced that something must be wrong with my engine. Could this be related to the fact that there is no muffler on the exhaust? That would explain why their Wichita Spam cans don't do it and mine does. Mark LaBoyteaux RV-6A N106RV Flying!!!!! MLaboyteau(at)aol.com Broken Arrow, Ok ________________________________________________________________________________
Date: May 26, 1998
Subject: Farewell John Morgan...
I didn't much feel like building tonight after hearing the news of John Morgan's passing. Not because I am suddenly fearful of flying or of the aircraft I have chosen to build, but because having met John and flown with him, my heart was very heavy. It was because of John's flying and his pleasant demeanor that my garage is now filled with parts to the greatest kit aircraft available. It was late August, 1997 on a beautiful VFR day that John introduced me to the world of RV's with a demo flight that I cherish to this very day. After flying with me for a half-hour or so and executing a flawless landing at Van's home strip, he proceeded to take my nervous wife (she is not yet comfortable in an airplane) on a scenic flight over our new house which was being built at the time. On our drive home she mentioned that he "really seemed to know what he was doing". I couldn't agree more. John was an excellent pilot. In addition to flying with him once, I had the privelege of being a fellow member of the Home Wing Builder's Group with John. He always seemed to have a smile for everyone and something good to say. Our prevously mentioned new house is located about 5 miles from North Plains and I have the privilege of watching the prototype aircraft giving demo flights and doing testing on a regular basis. One of my most-used tools when building on nice VFR days is my Bushnell binoculars. When an RV flies over I run out like an idiot with my binoculars and watch until they disappear from sight. Then, motivated, I run in and squash some more rivets. I will miss N58RV and John over my house and at the fly-ins. My sincere condolences go out to John's family as well as the family of his passenger. My family's thoughts and, more importantly, our prayers go out for John's widow, family and the entire family at Van's Aircraft. Farewell, John Morgan. You will certainly be missed.... Regards, Jon Elford RV6 #25201 Drilling wing ribs to spars... ________________________________________________________________________________
Date: May 25, 1998
>Anyone out there comtemplating putting a Mazda 13B into an RV? input is >welcome, even negative, so fire away. Brian, Redmond, Wa > Put a water pipe in your aileron, Put an automotive light in the wing leading edge, Use an automotive type fuse block for your electrical system, Sit on a boat cushion, Use any primer you like,......or none at all, but, DO NOT PUT AN AUTO ENGINE IN YOUR AIRPLANE Mike Adams/-4/#2316 ________________________________________________________________________________
Date: May 27, 1998
Subject: Re: Priming Nutplate
<< I just got done priming a bunch of nutplates for my rv-4 wing. This is what I did- got a block of wood, drilled a about 40 3/8" holes in it, set the nutplates in the holes, and sprayed the mating surface of them with 2 or 3 coats of primer. I then turned them over and placed the now primed flat surface of the nutplates down on a clean surface(don't put them on a primered surface, they will stick) and sprayed the other side of them. I takes longer to write about it than to do it. >> I know this has come up in the past, but. The nut plates provided with the kit are cad plated. In short they are already coated with a protectant that will keep them from rusting or causing dissimilar metal corrosion. If one is not comfortable with that then the extra work and effort to prime the nut plates is fine but not necessary. Ryan Bendure Co. ________________________________________________________________________________
Date: May 27, 1998
At some of the airports I fly at/to, the problem is how do you get AVGAS? These only have auto gas. My home airport, 9B3, has only auto gas, for example. We have a conventional pump, but the auto gas is the only thing that comes out of it. Steve Soule Huntington, Vermont -----Original Message-----How do you get auto gas to the airport and into your plane safely? ________________________________________________________________________________
Subject: Re: Vetterman Exhaust Leak- Fixed
Date: May 27, 1998
Hi Mark, I have a T18 that does have a muffler and it often pops once on final approach, so the muffler does'nt fix the popping. Niether does changing the idle mixture. Like to know the answer as it can lead to cracks in the muffler. Carby was recently overhauled, new main jet etc. but did'nt fix anything. Engine was fully overhauled at same time. Cheers, Brian ________________________________________________________________________________
Date: May 27, 1998
> > Get a pair or needle nose pliars and file (I ground on bench > grinder) a samll V groove in the jaws near the tip. This enables > one to hold a round bolt by the shaft easier. .......and put a rubber band around the nose of the pliers inboard of the bolt. This holds the bolt in. You have to squeeze to drop it. Peter Bennett Sydney Australia RV6 tailwheel on, main gear happening ________________________________________________________________________________
Date: May 27, 1998
Subject: Re: Getting Started
> > > I tell people who ask "How's the plane comming?", that building an > RV (or any plane for that matter) is like "Eating an Elephant". You > have to take that first bite if you want to eat him. Right. Start with a small tusk, master it and............. Peter Bennett Sydney Australia RV6 tailwheel on, main gear happening ________________________________________________________________________________
Date: May 27, 1998
mike a adams wrote: > > >Anyone out there comtemplating putting a Mazda 13B into an RV? > input is > >welcome, even negative, so fire away. Brian, Redmond, Wa > > > Hi Brian, I have an RV-6A with a Mazda 13B as the powerplant just about ready for inspection. Power estimation is 170HP based on static rpm of 2300 with an 68X72 Propeller. Working an auto conversion is not for everyone. Strong liking for working out engineering problems, willingness to extend the time to get into the air, and willingness to accept the additional risk is required. Also, do not expect to save a lot of $$. Unless you are aquiring a FWF installation, you are actually engaged in your own mini- R&D program and typical of such - it costs more than you planned and takes longer than you think. However, if you are the type that enjoys this type of challenge and are interested in the 13B, I recommend Tracy Crook's conversion manual. You may also want to look at some photos of my 13B installation at www.flash.net/~donmack. At some point in time, there may be a reasonably priced alternatives to the very limited options today, however, they are years away. As far as automobile alternative engine projects- like any project, you need to be realistic about the time you want to expend, money you want to invest, and risk you are willing to take. Best Regards Ed RV-6A N494BW Vienna VA > DO NOT PUT AN AUTO ENGINE IN YOUR AIRPLANE > > Mike Adams/-4/#2316 > ________________________________________________________________________________
Date: May 27, 1998
Hi Frank, Saw your mention of my project. No, sorry to inform you, but not yet in the air. I sprung a leak in the coolant system, that took about 3 months, 3 welders, and four trips to the junk yard for evaporator cores to finally get a new set of radiators welded up. I know have them reinstalled on the airframe and am building new air ducts for them. So I am about where I was 3 months ago. Will be taking several weeks vacation in June, so it will probably be late july or August before I get into the air. I will certainly announce it when that day occurs. Ed Anderson RV-6A N494BW -13B Mazda Powered Frank van der Hulst wrote: > > Actually, I was wondering how Ed Anderson is getting on with his. He > should be flying by now. > > Frank. > ________________________________________________________________________________
Date: May 27, 1998
MLaboyteau wrote: > > One thing I notice, on approach to landing, like on crosswind and final, > the exhaust pops some. At first I thought maybe the idle mixture was too rich, > but while I was flying the red 6A at Van's, it did it too. I've had a couple > of the old coots at the field ask me about it, and I'm not sure how to reply. > Their convinced that something must be wrong with my engine. Could this be > related to the fact that there is no muffler on the exhaust? That would > explain why their Wichita Spam cans don't do it and mine does. > > Mark LaBoyteaux > RV-6A N106RV Flying!!!!! > MLaboyteau(at)aol.com > Broken Arrow, Ok > Mark Spam cans also pop under certain circumstances, usually what cause that is somewhere in the exhaust system is a leak. When you close the throttle cold air mixes with hot exhaust air and causes the pop. -- Jerry Springer RV-6 N906GS First flight July 14, 1989 :-) Hillsboro, OR jsflyrv(at)ix.netcom.com ________________________________________________________________________________
Date: May 27, 1998
After all the hi-tech advice, here's another from the low-tech side. By the way, I liked Brian H's technique. Mine was similar; I cut a 12" length of hanger wire and bent it in the center around a bolt. I bent it until it was in the shape of a 'U' with the wire ends spread about 4". In use, I just dropped a bolt into the U and brought the ends together, clamping it. When the bolt was in place, I slipped the wire over the head and finished tightening the bolt. Not sophisticated, but it didn't cost me anything. PatK - RV-6A - Right fuel tank done; frantically finishing wing before I move Paul Besing wrote: > > Has anyone come up with a way to put the bolts through the bearings when > attaching the elevators to the HS? I had to stop after an hour of trying > to do one of them...it's pretty frustrating! ________________________________________________________________________________
Date: May 27, 1998
As for space considerations, check out my website at http://ic.net/~patk/rv-6a.htm and see what it takes to build in an apartment w/o a nice, spacious 1-car garage. As for the skills, you have already demonstrated the first one - asking questions. Contact Vans for a builders list in your area and visit some projects if you can. Also locate the fly-ins (many are announced here) and visit them to get inspiration and advice. If you fall short in a skill area, often another builder can help or can teach you. I was taught riveting on my empennage by an A&P at the company where I worked, for example. Speaking of announcing fly-ins, I have not seen a posting about the Michigan Wing of Vans Air Force, but I got a flyer that says that it will be at 12 noon on June 7 at Dalton Airport (near Flint, MI). The usual format is to informally look at the planes that make an appearance and hangar fly until the pot-luck is served. Then the meeting goes more formal as introductions are made all around and any special presentations are done. Good people, good food (if I do say so myself), and great topic. Hope I can take time out from Judi's graduation to be there this time. PatK - RV-6A - Moving the project to Chicago in a couple of weeks. > One: Is it really possible to construct > the major components of this airplane in my single-car garage? And two: What > preparation should I as a builder put myself through before I attempt this > insane task? ________________________________________________________________________________
Date: May 27, 1998
From: Terry Mortimore <terry.mortimore(at)sympatico.ca>
Brian wrote: > >Anyone out there comtemplating putting a Mazda 13B into an RV? Hi Brian, Tracy Cook has put a Mazda engine in his RV-4, I believe he has written a book or paper on it. Let me know if your interested and I can find out more information on it. I believe he's on the Airsoob mailing list. tailwinds, terry Terry Mortimore 2.7L Subaru RV-6A 38 Cartier St. Sault Ste Marie terry.mortimore(at)sympatico.ca Ontario Canada P6B-3K2 RAA #4061 EAA #229708 ________________________________________________________________________________
MLaboyteau wrote: > > > One thing I notice, on approach to landing, like on crosswind and final, > the exhaust pops some. At first I thought maybe the idle mixture was too rich, > but while I was flying the red 6A at Van's, it did it too. Could this be > related to the fact that there is no muffler on the exhaust? That would > explain why their Wichita Spam cans don't do it and mine does. > Mark - this backfire is quite common on short pipe - no muffler engines and engines that have excessive leakage in the exhaust system. It is caused by the unburned fuel that is leaving the engine meeting with oxygen in the air and due to the elevated temperature of the resulting gas there is an 'explosion' and you hear it as a popping in the pipes. I have seen it do damage to exhaust valves if the condition persists or is really bad. Remember that the exhaust valve is still partially open when this burning is taking place. A loss of back pressure not only will cause the popping, and possible burned exhaust valves, but can also result in a higher fuel consumption as an engine needs some back pressure to 'hold' the incoming fuel/air mixture in the cylinder. On the certified aircraft the muffler does the double duty of quieting the engine and providing back pressure. I have heard the exhaust popping on a 172 while retarding the throttle after entering a spin so I feel all engines can and are affected by this. I would like to see someone come up with a muffler for the RV series aircraft. Hope this helps Doug Murray - RV-6 - engine Southern Alberta ________________________________________________________________________________
Date: May 27, 1998
> 2) Where do you buy auto gas to ensure that you are getting gasoline and > not some blend (alcohol or??) which may or may not work properly? EAA HQ has an excellent info packet on auto fuel use in aircraft that will answer this. It's free for the asking and I highly recommend it for anyone contemplating using auto fuel. -- Bob Reiff Reiff Preheat Systems http://www.execpc.com/reiff ________________________________________________________________________________
Date: May 27, 1998
Ed Anderson is putting one in his RV-6A. You can find pictures and description of the installation at: http://www.flash.net/~donmack/mazda/index.html Don Mack RV-6A Fuselage -----Original Message----- From: owner-rv-list-server(at)matronics.com Sent: Tuesday, May 26, 1998 8:52 PM Subject: RV-List: Re: Rotary engines in RVs Anyone out there comtemplating putting a Mazda 13B into an RV? I'm certainly leaning that way. I'm pretty well along on the wings for my RV-4. Any input is welcome, even negative, so fire away. Brian, Redmond, Wa ________________________________________________________________________________
Date: May 27, 1998
Subject: New Bearing Question!
Thank you all for all of your innovative ideas...I have now installed the bearings (using the notched needle nose method) There is one small problem....how the heck do you tighten them???? I normally do not have to ask step by step questions, but this one has just got me........ Thanks in advance, Paul Besing RV-6A (197AB) Arizona Mounting Empennage ________________________________________________________________________________
Date: May 27, 1998
Subject: Mufflers
I know this may seem like heresy in the land of maximum performance, etc. but what about a muffler for RVs? Has anyone installed one? I love performance but quieting my bird would make the spousal unit more inclined to join me in longer aerial forays. I currently run the Vetterman 4 pipe unit on my -4 and it does nice job but the cockpit is loud!!! I'd sacrifice a few precious hp for some db attenuation on the noise. Richard E. Bibb RV-4 N144KT Oak Hill, VA rbibb(at)fore.com ________________________________________________________________________________
Date: May 27, 1998
Subject: John Morgan
I'd like to send my condolences and prayers to the family and friends of John Morgan and his passengers family and friends for their sudden loss recently. I didn't know John personally, but talked with him a couple of times on a problem I had with the baffles on my gas tanks. He gave me a fix and the fix worked and the tanks have been holding air for over four days. John, if your monitoring the list, Thanks..... Fran Malczynski Olcott, NY RV6 (Wings almost done, fuselage parts in the garage) ________________________________________________________________________________
Date: May 27, 1998
Subject: Re: Michigan Fly-in
Patrick Kelley wrote: > Speaking of announcing fly-ins, I have not seen a posting about the > Michigan Wing of Vans Air Force, but I got a flyer that says that it > will be at 12 noon on June 7 at Dalton Airport (near Flint, MI). The > usual format is to informally look at the planes that make an appearance > and hangar fly until the pot-luck is served. Then the meeting goes more > formal as introductions are made all around and any special > presentations are done. Good people, good food (if I do say so myself), > and great topic. Hope I can take time out from Judi's graduation to be > there this time. Info contacts are listed in the announcement on "The RV Journal" front page: http://www.ath.tis.net/~sbuc/rv6 Sam Buchanan (jigging fuse, RV6, Athens, AL, USA) sbuc(at)traveller.com ________________________________________________________________________________
From: "Nigel Marshall" <Nigel_Marshall(at)meritorauto.com>
Date: May 27, 1998
Subject: Wing weight
Thanks to all those who replied to my question last week about removing the first wing from the jig. Two of us did it on Saturday and it was, as you all said, much lighter and easier than I had anticipated. Now I have got to start all over again.......... Nigel Marshall Chevreuse, France RV-4 (# 4062) Starting second wing marshan(at)meritorauto.com ________________________________________________________________________________
Date: May 27, 1998
Subject: Re: New Bearing Question!
Tightening them is a slow, tedious 1/8 turn at a time affair.... don't do it until final install and/or use non lock nuts for interim fittings.... > >There is one small problem....how the heck do you tighten them???? I >normally do not have to ask step by step questions, but this one has just >got me........ Richard E. Bibb RV-4 N144KT Oak Hill, VA rbibb(at)fore.com ________________________________________________________________________________
Date: May 27, 1998
> > Tracy Cook has put a Mazda engine in his RV-4, I believe he has written Yes, Tracy Crook has written an extensive manual on installation, systems, and performance specs for a Mazda 13B Rotary conversion in an RV-4. The book is available from RV-ation Bookstore. Call us at 970 887-2207 or see our web page at: http://www.rvbookstore.com Andy Gold RV-ation Bookstore ________________________________________________________________________________
Date: May 27, 1998
Subject: Re: Rotary engines in RVs (Tracy Crook)
<< Anyone out there comtemplating putting a Mazda 13B into an RV? I'm certainly leaning that way. I'm pretty well along on the wings for my RV-4. Any input is welcome, even negative, so fire away. Brian, Redmond, Wa >> Hard to imagine all those post and Tracy Crook was only mentioned as a maybe once. Tracy has been written up by the RVator, has over 600 hours on his rotary powered 4 . published a neat book on how to do it, sells electonic ignition, publishes a newspaper on alternate power, and is a great guy. I am going to give you his email address w/o his permission and know he will say it's OK. Tracy Crook's email, 71175.606(at)compuserve.com Bernie Kerr, 6A fuselage, SE Fla ________________________________________________________________________________
Subject: Van's Air Force Northwest RV Fly-in '98 - Jun 20
Date: May 27, 1998
I hadn't seen this posted yet so I have taken it upon myself to invite all you RV-er's out there to the 7th Annual Northwest RV Fly-in sponsored by the Home Wing of Van's Air Force. The following was brazenly plagiarized from the Home-Wing Home-Page which can be found at: http://www.edt.com/homewing/flyin98.html "This is the premier RV event of the Northwest (all right, Van's homecoming is pretty good too....) with good food, souvenir t-shirts, and lots of great RV camaraderie. Last year we had... well, it was pretty much a rain-out. But the year before that we had over 60 RVs. So come join the fun! " This is an opportunity not to miss. Date: Sat. Jun. 20th Time: 8:00AM to Whenever Place: Scappose, OR Airport (1S4) For Detailed Airport Info see: http://www.airnav.com/cgi-bin/airport-info?1S4 For more information, or if you want to volunteer to help out, call, or write, to Don Wentz: don.wentz(at)intel.com (503)543-2298 ________________________________________________________________________________
Date: May 27, 1998
Subject: Re: Mufflers
Richard, Have you tried putting the mufflers on your ears instead of your engine? If you havent tried them already, I suggest you test some active noise cancelling headsets. I love my Lightspeed 20K and would imagine that it would work as well in the RV as it does in the spam I fly. Of course I would be happy to do some flying in your RV with you and confirm this! Mike Wills RV-4 fuse willsm(at)manta.nosc.mil >I'd sacrifice a few precious hp for some db attenuation on the noise. > >Richard E. Bibb >RV-4 N144KT >Oak Hill, VA >rbibb(at)fore.com ________________________________________________________________________________
Date: May 27, 1998
Richard, Try a set of Lightspeed active noise cancelling headsets. Much lighter, quieter, and less hassle (Probably less $$) than a muffler installation! Sam Buchanan sbuc(at)traveller.com "The RV Journal" htt://www.ath.tis.net/~sbuc/rv6 Richard Bibb wrote: > > > I know this may seem like heresy in the land of maximum performance, etc. > but what about a muffler for RVs? Has anyone installed one? I love > performance but quieting my bird would make the spousal unit more inclined > to join me in longer aerial forays. > > I currently run the Vetterman 4 pipe unit on my -4 and it does nice job but > the cockpit is loud!!! > > I'd sacrifice a few precious hp for some db attenuation on the noise. > > Richard E. Bibb > RV-4 N144KT > Oak Hill, VA > rbibb(at)fore.com ________________________________________________________________________________
Date: May 27, 1998
I just used a couple of box wrenches and a few choice words. Just snug them until you are ready to finalize the assembly, then tighten to final torque with a small torque wrench or with a pull scale on the nut's wrench (you can figure out the pull with the moment times force algebra). PatK - RV-6A Paul Besing wrote: > > There is one small problem....how the heck do you tighten them???? I > normally do not have to ask step by step questions, but this one has just > got me........ ________________________________________________________________________________
Date: May 27, 1998
Regarding the June 20 Northwest RV Fly-In in Scappoose, OR, I would like to make a clarification. The fly-in starts at 10:00am, not 8:00am as previously stated. We will be setting up between 8:00 and 10:00. People are welcome to show up before 10:00, but should be prepared to be pressed into service! Randall Henderson, RV-6 (engine/finish) Portland, OR randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: May 27, 1998
Thanks everyone who pointed out that I can't spell my own web address in the morning. It should be http://ic.net/~patk/rv6a.htm PatK Patrick Kelley wrote: > > As for space considerations, check out my website at > http://ic.net/~patk/rv-6a.htm and see what it takes to build in an > apartment w/o a nice, spacious 1-car garage. ________________________________________________________________________________
Date: May 28, 1998
chaskuss(at)miami.gdi.net (and others) wrote: > I tried to follow the link above. I received a message saying > that the page did not exist. Did you possibly make a typo? Oops, my mistake -- GeoCities is case-sensitive... the 'P' in Launchpad' should be lower case. Try this... http://www.geocities.com/CapeCanaveral/Launchpad/4808/mazda13b.htm Frank. ________________________________________________________________________________
Date: May 27, 1998
Subject: IO-360 '6s (&'4s)
Dear Listers Many thanks to all those who replied to my request for info on 200hp angle valve IO-360/C/S prop powered RV-4s and 6s. It may help to know of anyone who is building such a machine as well as flying examples. Hopefully I can then baffle our Popular Flying Association with huge numbers of like-minded sane people. Contact name and address, rv/engine/prop type etc would be a great help. My building oppo has been to see Steve Barnard last year and will contact him again direct, also I'm sure Van's will help with whatever knowledge they have on their database. Steve's splendid cowls are deigned for an extended hub prop which we can't use on our motor, so it's out with the hack saw and rubber gloves for us! The PFA doesn't mind the weight and balance aspect of this combo - we have worked out that the CofG stays in limits at all times (we have the battery in the baggage compartment). Their worry is the extra weight hanging on the front of the aircraft and whether or not the structure will cope. Being lightweight limeys the useful load loss is not really a problem. Most people seem to think RVs come out with an aft CofG if anything anyway which the heavy combo should help. By the way our motor is an AEIO-360 A1A without the inverted system (at the moment.....) and the prop is a Hartzell HC-C2YK 4CF/FC7666A-2. Both were bought because of the price and availability. The prop was brand new, still in its box and being disposed off by British Aerospace. It was originally for the Scottish Aviation Bulldog RAF basic trainer which was powered by an AEIO-360 A1B6D, I think. The price - about US$1800...! Thanks once again to all who helped - hopefully I can help some others at some stage. Trouble is I look after Cessnas and Pipers as a day job - no use to man nor beast, really. Jerry Parr RV-6 G-RVVI Up to my armpits in rudder pedals Peterborough England PS If anyone still wants to know, the article on prop comparison in the Sport Aviation was the Jan 91 issue. PPS I would ditch bog standard mags for electronic ignition anyday - let's go modern! ________________________________________________________________________________
Date: May 27, 1998
Subject: Re: John Morgan
Listers-- I called Van's today to find out where to send cards, flowers or whatever for John, and was given the following address where his widow, Sally, will be for a while. If you feel the desire to send a card, I'm sure she would appreciate hearing from John's extended RV family. Sally Morgan 760 Ocotillo Road Blythe, CA 92225 --Don McNamara N8RV ________________________________________________________________________________
Date: May 27, 1998
<< it often pops once on final approach, >> Does this "pop" happen when you first pull power? Does it seem to happen less on a "hot" day? When flying C-150 with an 0-200, I almost always got the "pop", and was told by my instructor that it was cooler air hitting the valves due to a temporary lack of back pressure. I never let it worry me. Any thoughts on this?? Jim Nice RV6A WA State ________________________________________________________________________________
Date: May 27, 1998
Subject: Solder?
I am wiring my electric trim, and would like to know what kind of solder to use when connecting the cable to the servo....anyone have some advice? Paul Besing RV-6A (197AB) Arizona Mounting Empennage ________________________________________________________________________________
Date: May 27, 1998
> >There is one small problem....how the heck do you tighten them???? I > >normally do not have to ask step by step questions, but this one has just > >got me........ Tightening them is a slow, tedious 1/8 turn at a time affair.... don't do it > until final install and/or use non lock nuts for interim fittings.... I used a small set of ignition wrenches from sears. I had them for my autos...someone around you should have a few to borrow. They were handy for other jobs in tight areas as well. A good tool is a joy forever. Mark Graf RV-6 N71CG 150 hp Arvada CO > ________________________________________________________________________________
Date: May 27, 1998
From: Charlie and Tupper England <cengland(at)netdoor.com>
> DO NOT PUT AN AUTO ENGINE IN YOUR AIRPLANE > > Mike Adams/-4/#2316 > P.S. Be sure to retain the farm tractor ignition systems & carb, and the 60+ year old metalurgy, and the overall unreliable (yes, UNRELIABLE) nature of your antique engine on your brand new plane. Seriously, opinions are like that well known & hopefully unseen part of the anatomy; everybody's got one. Mine is: better to warn of the many pitfalls of EXPERIMENTING with the power plant in addition to EXPERIMENTING with the airframe. If you are serious, contact Tracy Crook (email 71175.606(at)compuserve.com). He has over 600 hours on a 13b powered RV-4 and is very candid about both the advantages and problems involved. He publishes an excellent newsletter on the subject. To the rest of us: it doesn't seem reasonable to me to express such unwavering, dogmatic opinions without reasoned evidence to back it up. I'll bet we all have friends who consider us crazy for building our on a/c in the first place (but who know nothing at all about the subject). I've owned 4 planes (2 factory, 2 homebuilt), all with a/c engines, none of which inspired as much confidence in reliability as my various car engines. I had a friend who died in a Ford V-6 powered Mustang II. I feel that I've seen it from both sides. I currently fly a Lyc powered RV-4. I hope that the plane I build will be auto powered, but I'm doing all I can to learn about the "gotcha's" before I start. We pilots seem to be almost as superstitious as baseball players, and as susceptable to propaganda as communists or John Birchers. (please, no political threads) Bottom line: Question everything. Including your powerplant. Charlie England Slobovia Outernational, Jackson, MS visitors welcome (you can halp build the house so I can start on the plane) ________________________________________________________________________________
Date: May 28, 1998
> >Make sure you always check rivet lengths, don't just trust what you see >in the plans. My understanding is that rivet lengths are not ordinarily called out on plans for aircraft structures. It is intended that you calculate the length required based on the structure call outs. Van is just being nice to tyros Leo Davies leo(at)icn.su.oz.au ________________________________________________________________________________
From: "Wilson, James Mike" <james.mike.wilson(at)intel.com>
Subject: Solder?
Date: May 27, 1998
Personally, I would use crimp connectors. Solder makes the end of the wire brittle such that fatigue can break it after some time. If you solder, mechanical strain relief the flying leads. Any hardware store should carry electrical rosin flux solder. Don't use acid flux! mikewilson RV4 in the finishing 80% left to go stage. I am wiring my electric trim, and would like to know what kind of solder to use when connecting the cable to the servo....anyone have some advice? Paul Besing RV-6A (197AB) Arizona Mounting Empennage ________________________________________________________________________________
Subject: Re: Solder?
Date: May 28, 1998
Yes. DO NOT USE SOLDER..... unless unavoidable. Unless the cable is very well supported it leads to the wire breaking where the solder ends. Use good crimp lugs or joiners where possible. If you must use solder use good heatshrink tube over it to support the joint. Cheers, Brian ---------- > From: Paul Besing <rv8er(at)doitnow.com> > To: rv-list(at)matronics.com > Subject: RV-List: Solder? > Date: Wednesday, May 27, 1998 11:41 PM > > > I am wiring my electric trim, and would like to know what kind of solder to > use when connecting the cable to the servo....anyone have some advice? > > > Paul Besing > RV-6A (197AB) Arizona > Mounting Empennage > > > > > > ________________________________________________________________________________
Date: May 27, 1998
My advice would be to use 63/37 flux core eutectic solder, if you can find it. This solder has no plastic state. It is either liquid or it is solid. This helps to eliminate fractures, should you not be real steady with your work. Jim Nice RV6A WA State ________________________________________________________________________________
Date: May 27, 1998
It makes it easier to tighten them if you use 12point nuts instead of 6 point nuts Stew RV4 273sb ________________________________________________________________________________
Date: May 27, 1998
<< Solder makes the end of the wire brittle such that fatigue can break it after some time. >> If you are sure you wish to solder this item, you may use a potting compound that will absorb the shock, also act as a seal to moisture, and keep the solder from experiencing fatigue. Jim Nice RV6A WA State ________________________________________________________________________________
Date: May 27, 1998
Only one to use.. Rosin core!! You might consider a disconnect connector however.. RV4 273sb Co. ________________________________________________________________________________
Date: May 27, 1998
Subject: Sally Morgan's Address
All: I inadvertently deleated the message containing Sally Morgan's address. Would someone be kind enough to email it to me? Best Regards, dave Barnhart barnhart(at)a.crl.com RV-6 sn 23744 N601DB Flying on't know why other than air is being ramme through the hole and slowing the air coming down through the cyls. David Malott ________________________________________________________________________________
Date: May 27, 1998
>Anyone out there comtemplating putting a Mazda 13B into an RV? I'm certainly >leaning that way. I'm pretty well along on the wings for my RV-4. Any input is >welcome, even negative, so fire away. Brian, Redmond, Wa I'm building an RV-8A, and the engine will either be Mazda or Lycoming. It's really too soon to decide, but I have all Tracy Crook's info, and plan to go visit him one of these days. I'm even planning to pick up a junk engine just to take it apart for the experience. There are many factors to consider. The easy and practical thing to do is bolt up a Lycoming and go. In the long run, it might even be the cheapest, but this violates my sense of individuality in a big way. IMO, the rotary engine is the best design there is, and I wouldn't have the slightest hesitation to fly behind one. The downside to any conversion is extra building time, frustration, extra risk, and potentially poor resale value. "DO NOT PUT AN AUTO ENGINE IN YOUR AIRPLANE" "You're crazy if you fly something built in a garage" is another one of my favorite quotes :-) All my life, I've gone out of my way to do what others say you shouldn't, and I've rarely been disappointed by the results. I'll take this statement as a vote for Mazda :-) Rusty Navarre, FL Kolb SlingShot (flying) RV-8A (waiting for wing kit) ________________________________________________________________________________
Date: May 27, 1998
Paul, Use rosin core solder only! Fred ________________________________________________________________________________
Subject: washer identification
Date: May 27, 1998
Could someone help me identify some washer callout numbers? On plan sheet number 19a there is a washer 5702-95-30. Plan calls for two of these washers to set next to the VA-146 bearing on the bellcrank. I have the book Standard Aircraft Handbook to identify parts and it is not listed. Also there are two washers 5702-75-60 that are placed between the hiem bearing on the bellcrank that I can not identify. If someone could describe the size of these washers I would be gratefull. Thank you in advance. Craig Craig Nelson RV-6 serial # 25101 cgn(at)pond.net Eugene, OR wings finished! Installing ailerons and flaps! __I__ ______O______ o/ \o ________________________________________________________________________________
Date: May 27, 1998
At 03:41 PM 5/27/98, Paul Besing wrote: > >I am wiring my electric trim, and would like to know what kind of solder to >use when connecting the cable to the servo....anyone have some advice? > SNIP For anything resembling electronics, the only thing to use is 60/40 rosin multicore (or 63/37 eutectic alloy if it's available). Thin is good -- I usually like 22ga. The other essential thing is to have a good thermostatically-controlled soldering iron, and ALWAYS clean the tip immediately before soldering to remove the oxidized solder layer that forms on the iron tip within a few seconds. The tip should be shiny. I just looked in the Digi-Key catalog, and they have an iron from Easy Braid Co. that looks like it might be OK and the fancy model is only $20 (p443). I've never seen that one, though, so I can't say whether it's actually any good. For years, I have used a Weller WTCP60, which Digi-Key doesn't carry, but I think Newark still does. Not to look too much like an ad, but Digi-Key is a good place to get electronic stuff, and easy to order from (almost like RV suppliers). They are at 1-800-344-4539 or http://www.digikey.com . Radio Shack is not a good supplier. Their irons are junk and their solder is huge and whatever alloy it is, it is not shiny like the real stuff. I learned soldering from NASA techs at Marshall Space Flight Center when I was a coop student. At the time they were testing the Saturn V rockets that were going to carry Apollo astronauts (spam in the can to us rocket guys). Those guys were just along for the ride -- it was our computers that were driving... Back to soldering -- the idea is to get the joint hot so that the solder flows all over it. Clean the iron tip (usually with a sponge, but a damp rag will work), melt a little "pillow" of solder on the iron, then touch the pillow to the joint so that the little blob of molten solder makes a good thermal connection. Wait a few seconds, then touch the solder to the joint. If it melts and flows readily, flow on enough to fill in the spaces but not drip. If it's not hot enough, wait some more. One reason for using that expensive Tyvek insulated wire is that the insulation won't melt and burn when you solder, so you can apply enough heat to get a really good joint. That's one reason I wouldn't want to use automotive wire in my airplane. ________________________________________________________________________________
Date: May 27, 1998
Subject: Re: Sally Morgan's Address
It is Sally Morgan 760 Ocotillo Rd. Blythe, Ca. 92225 Stew RV4 273sb ________________________________________________________________________________
Date: May 27, 1998
>Seriously, opinions are like that well known & hopefully unseen part of the >anatomy; everybody's got one. >Bottom line: Question everything. Including your powerplant. > >Charlie England >Slobovia Outernational, Jackson, MS >visitors welcome (you can halp build the house so I can start on the plane) > Correction: Opinions unlike a------s quite commonly come more than one per person> > jim - wing tanks next. ( B.C. Canada.)> > * When dreams come true the sky's the limit * jjewell(at)okanagan.net ________________________________________________________________________________
Date: May 28, 1998
Subject: tank skin rivets
RV-8 builders, When drilling the top of the tank skin to the baffle, the last 15 or 20 holes are so close to the spar reinforcement bar that the drill bit hits it. Not a problem in itself however I am concerned that the shop set on the rivits will hit the re-bar. Anyone had this situation occur and was it a problem? Thanks IA Dennis Clay wings happening Eugene OR ________________________________________________________________________________
Date: May 28, 1998
Shaftela wrote: Sure! I am. I'm trying to duplicate Tracy Crook's installation, although I made a simpler engine mount (using the cheaper lord mounts - $21 for 8 at Wag Aero). Also moved the muffler over to the left side - less space in my RV-3 cowling. By the way, Tracy now has an fuel-injection system, replacing his three bike carburators. Finn (RV-3, just about done with the *&^&^%^&$# canopy!) > > Anyone out there comtemplating putting a Mazda 13B into an RV? ________________________________________________________________________________
Subject: Rv 6A- bend in .063 angle
Date: May 28, 1998
I broke my .063 angle that runs parallel to the upper & lower longerons between the 601 & 604 bulkheads. Does anyone have any suggestions on a technique to bend it. All I did was run a four cycle fatigue test. I drilled a hole & removed the metal with a saw & filed. Looks like I need to start the bend before it gets to the 604 & then bend back I guess an opposite 45% angle. If i bend the first radius then how can I hold it to bend back the other way? Does the front end line up with the SS firewall and is held there with the little "L" shape angle? I watched George's vedio again & just like the other night, his when together with no problems as usual. Don Jordan ~ N76DJ ~ 6A-fuselage donspawn(at)juno.com ~ Arlington, Tx ________________________________________________________________________________
Date: May 27, 1998
> "DO NOT PUT AN AUTO ENGINE IN YOUR AIRPLANE" My understanding is that auto engines are designed for mostly low power output punctuated by occasional spurts of high power. And that aircraft engines typically run at or near full throttle most of the time, yet retain a high degree of reliability. Auto racing engines on the other hand are also used mostly at or near full throttle. Nevertheless they are rebuilt often, sometimes after each race. Would someone in-the-know care to comment about the expected reliability of non-racing auto engines used mostly at or near full throttle? Mark Mason Portland/Hillboro Oregon Pondering an RV-6A ________________________________________________________________________________
Date: May 28, 1998
<< y understanding is that auto engines are designed for mostly low power output punctuated by occasional spurts of high power. And that aircraft engines typically run at or near full throttle most of the time, yet retain a high degree of reliability. Auto racing engines on the other hand are also used mostly at or near full throttle. Nevertheless they are rebuilt often, sometimes after each race. >> Mark, Your comment about reciprocating racing car engines is true but does not apply to rotarys. A friend of mine used to race a rotary and he would go to Daytona and race for 24 hours at 10000+ RPM. He would not tear the engine down, but take it to a race in Miami next weekend. The rotor was basically a stock rotor. I worked at Pratt Whitney as a turbine engineer for 33 years and for the life of me can not believe that NASCAR folks are able to hold a reciprocating piston engine together at 9000 rpm for 500 miles. If the auto industry had put as much effort in developing the almost bullet proof rotary in our cars. 500000 mile car engines would be standard fare IMHO. I am building a 6A and will put a New Ly. in it because I am 61 years old and wish to be flying rather than working on installing and developing an alternate engine. I may start another project with a rotary powerplant when this one is flying. Bernie Kerr, 6A fuse., SE Fla ________________________________________________________________________________
Date: May 28, 1998
From: "Scott A. Jordan" <SAJ_SLJ(at)compuserve.com>
Subject: DAL area RV's
I will be in the DAL area all next week. I would love to see some RV's, flying or under construction. I am especially interested in wings under construction or -8 fuselages. If you would like a set of hands to help out or some gas money please E-mail me direct. Thanks Scott A. Jordan -8 #331 flaps & ailerons ________________________________________________________________________________
Subject: Re: Primer
Date: May 28, 1998
"Robert D. Binzer" robinzer(at)seidata.com Has anyone checked out the Mar-Hyde Self Etching Primer for use instead of Zinc Chromate or Zinc-Oxide? Can any one offer yeah or nay on this? Bob Binzer RV-6A tailfeathers Madison, Indiana Bob, Several people have told me that Mar-Hyde is the best. Strong, scratch resistant, and seals unlike Veriprime so you can put it on and you don't have to cover it in a couple of days. Just what I want for at least the inside of the bird. I bought a can at the local paint store for $14.00, then someone mentioned that you can buy the same under the name Martin Seniour self etching primer 7220 at your local NAPA store so I bought three cans of that at $5.00/can. HTH Larry Mac Donald lm4(at)juno.com ________________________________________________________________________________
Date: May 28, 1998
Subject: Re: tank skin rivets
Dennis, This is not a problem. Just drill these last few holes with the tank off the spar and on the bench. There is just enough clearance for the shop head of the rivets so don't worry about it. It will fit just fine. Jeff Hawkins RV-8 #563 Suwanee, GA Left wing almost done. > >RV-8 builders, > >When drilling the top of the tank skin to the baffle, the last 15 or 20 holes >are so close to the spar reinforcement bar that the drill bit hits it. Not a >problem in itself however I am concerned that the shop set on the rivits will >hit the re-bar. > >Anyone had this situation occur and was it a problem? > >Thanks IA > >Dennis Clay >wings happening >Eugene OR > > > > > ________________________________________________________________________________
Date: May 28, 1998
Hi Paul, Tony B's yellow book has a whole chapter on this kind of stuff. If you do not have his books I highly recommend you get them. They are great reading when your not building. Jeff Hawkins RV-8 #563 Suwanee, GA Finishing left wing > >I am wiring my electric trim, and would like to know what kind of solder to >use when connecting the cable to the servo....anyone have some advice? > > >Paul Besing >RV-6A (197AB) Arizona >Mounting Empennage > > > > > > > ________________________________________________________________________________
Date: May 28, 1998
Subject: Connectors
Regarding the reccommendations of using connectors instead of solder to join the wires for my trim, can someone reccommend a type/model/manufacturer for these wires...If you are not familiar with them, there is about six wires, and they are about 26 ga wire.... Thanks... Paul Besing RV-6A (197AB) Arizona Mounting empennage ________________________________________________________________________________
Date: May 27, 1998
Subject: Re: Connectors
>Regarding the reccommendations of using connectors instead of solder to >join the wires for my trim, can someone reccommend a >type/model/manufacturer for these wires...If you are not familiar with >them, there is about six wires, and they are about 26 ga wire.... > > >Thanks... > >Paul Besing >RV-6A (197AB) Arizona >Mounting empennage Paul .. this is in the archives. Search for "trim' AND "connector" ... Of course ... I like this 'hit' the best...:^) I have since bought these connectors, and they are exactly as advertised. ... Gil (it's in the archives) Alexander *** from the RV-List archives at http://www.matronics.com/rv-list/search.htm *** ############################################################ # "trim" AND "connector" - Match #9 at Msg #6523 (18.5%) # ############################################################ ___ Date: Wed, 13 Dec 1995 16:47:13 -0800 From: gil(at)rassp.hac.com (Gil Alexander) Subject: Re: RV-List: Suitable CONNECTORs for electric TRIM >If you are not looking for a waterproof CONNECTOR, it's hard to beat the >old square, white Molex CONNECTOR. I've used them in aircraft for >years. They are cheap and reliable (they are NOT reliable if they are >constantly being connected and disconnected though.) I would recommend >the style that uses the .092-diameter pins instead of the smaller >.063-diameter pins. > >If you are looking for something waterproof, the only thing I've found >are those mil-spec Cannon plugs, but they are heavy. Cannon makes a >lighter plastic variety, but they are not waterproof. RV-guys..... Just checked my Newark catalog. Mil-spec CONNECTORs are $100+ .. WOW!! But .... They Newark sells "Conxall" brand weathertight 'Mini-Con-X Cable End CONNECTORs' that are designed for outdoor use. Mated, the plug/socket combo. is about 2.7 inches long by 0.7 inch diameter, but it's made of high-impact molded material, so should not be heavy. The length dimension includes the "weathertight rubber grommet/seal" and strain relief. They have gold-plated solder cup connections, so no special crimping tools are needed, just solder the wire to the CONNECTOR. For the Pacific Northwet, I believe these CONNECTORs would be better than the Molex ones, and more weatherproof than the plastic DIN CONNECTORs supplied by MAC. For 6 contacts, the part numbers are: stock# Conxall part# description price ($) 89F4115 6282-6SG-3XX 6 contact cable end socket conn. 6.69 93F7231 8282-6PG-3XX 6 contact cable-cable pin conn. 3.42 A panel mount version is also made: 8F4135 7282-6PG-300 6 contact panel mount socket conn. 5.80 They are a normal stock item (200+ at the local warehouse). Newark is a supplier of electronic components, etc., and has distributors all over the US, and has a good, 2+ inch thick catalog. Call and get their catalog since they have a $25 minimum charge :^) Catalog requests go to 1-800-298-3133 ext 48, and the catalog lists all of the regional offices. ... hope this helps ..... Gil Alexander gil(at)rassp.hac.com RV6A, #20701 PS .. I haven't bought these CONNECTORs, but after finding them in the catalog, I think I will use them for all of my electric TRIM cable hook-ups. The micro version of the above CONNECTOR at 0.540 inch diam. (2 or 3 contacts) should make a good CONNECTOR for the PTT switch in the removeable passengers control stick. RV6A, #20701, finishing kit "REPLY" sends to entire RV-list Newsletter Editors: Permission given to re-print if credit is given and a courtesy copy is sent to me. ________________________________________________________________________________
Date: May 28, 1998
Subject: Re: Rv 6A- bend in .063 angle
>I broke my .063 angle that runs parallel to the upper & lower longerons >between the 601 & 604 bulkheads. Does anyone have any suggestions on a >technique to bend it. All I did was run a four cycle fatigue test. I >drilled a hole & removed the metal with a saw & filed. Looks like I need >to start the bend before it gets to the 604 & then bend back I guess an >opposite 45% angle. If i bend the first radius then how can I hold it to >bend back the other way? > >Does the front end line up with the SS firewall and is held there with >the little "L" shape angle? I watched George's vedio again & just like >the other night, his when together with no problems as usual. > >Don Jordan ~ N76DJ ~ 6A-fuselage >donspawn(at)juno.com ~ Arlington, Tx Don, You can possibly salvage the angle, if you wish. Just cut another short piece of .063 angle, 2-3 inches long and rivet it where the long angle attaches to the 604. In other words, the short piece will be riveted to the longer angle and to the 604. I've done this on my RV-6 and on the one we're building in Gillette. I felt that this is a faster method and in doing it this way it is easier to get a smooth transition in this area so there is no bulge in the skin. You are correct about the attachment of the front part of this angle to the firewall. A small angle is used attached to the angle on the firewall and the angle from 604 to the firewall is attached to this angle. Bob Skinner RV-6 415 hrs. Buffalo, WY bskinr(at)trib.com ________________________________________________________________________________
Date: May 28, 1998
Mark, While its true that most auto engines are operated as you describe, I dont think its necessarily true that all are designed with that goal in mind. Thus, I dont think its fair to write off all auto engines as hopeless for use in aircraft. In chosing an engine consider the original application, maintenance history,etc.. If the engine has experienced any success in racing applications, boating applications, and especially aircraft applications I think that would be a real good sign. The Mazda 13B has proven to be nearly bulletproof in racing applications and boat usage, and has been flown successfully in a number of aircraft. The 2 aircraft examples that come to mind are Tracy Crook's RV, and Jim Mayfield's autogyro. Jim's gyro is used in a training environment and sees regular operation at 7000 RPM. His first engine was overhauled at approx 1100 hours for excessive oil consumption. Theory is that the engine's premature failure was due to some cooling problems/overheating experienced during development of the installation(the aircraft is based in Arizona). Overhaul involved replacement of internal oil seals at a cost of less than $1000. Last I heard the engine was running strong at over 1500 hours since the overhaul when the gyro was sold. Auto racing can provide a good indicator of an engine type's durability and an engine that is popular with racers usually generates a healthy supply of heavy duty aftermarket parts. Again, I feel it is unfair to write off engine reliability based on racing history because most race engines are highly stressed and frequent rebuilds are one of the costs of racing competitively. An engine type which demonstrates good reliability in this environment should do well in a less stressful aircraft application. What do you think the reliability history of a Lyc O-320 would be if it was required to deliver 400hp @ 5500 rpm continuously? Keep in mind that many of the previous failures of auto conversions have been due to application, poor installation, support system failures, etc... and not failure of the basic engine. All the above obviously is just opinion and I'm sure there will be those who will dispute them. Mike Wills RV-4 fuse willsm(at)manta.nosc.mil > > >> "DO NOT PUT AN AUTO ENGINE IN YOUR AIRPLANE" > >My understanding is that auto engines are designed for mostly >low power output punctuated by occasional spurts of high power. >And that aircraft engines typically run at or near full throttle >most of the time, yet retain a high degree of reliability. > >Auto racing engines on the other hand are also used mostly at >or near full throttle. Nevertheless they are rebuilt often, sometimes >after each race. > >Would someone in-the-know care to comment about the expected reliability >of non-racing auto engines used mostly at or near full throttle? > >Mark Mason >Portland/Hillboro Oregon >Pondering an RV-6A ________________________________________________________________________________
Date: May 28, 1998
From: Unistar Computers <unistar(at)mindspring.com>
Subject: Re: OH NO! Auto engines in RVs
If the auto >industry had put as much effort in developing the almost bullet proof rotary >in our cars. 500000 mile car engines would be standard fare IMHO. >Bernie Kerr, 6A fuse., SE Fla Will all the list members who have owned a Mazda powered by a rotary engine please give us *YOUR* experiences? I've seen several Mazda conversions, and haven't seen anyone demonstrate superior engine life to the Lyconental. More power for given size, yes. Less vibration, yes, at least at the low frequencies which we are used to in the Lyconental. Better fuel consumption? Hmmmm, a qualified *MAYBE*. I take issue with the "500000 mile [rotary] car engine". Mazda sells just one rotary powered vehicle anymore, the RX-7. This car has an engine life expectancy of less than 60,000 in "normal service". Mazda has an excetional warranty policy over the years which has disguised this short life. They will replace the engine under warranty (50,000 published, more if the customer asks). Essentially you buy the RX-7 plus your replacement engine at the time of purchase. They install it when the first engine begins to fail, and then by the time the second engine bites the dust the original owner has sold the car and the subsequent owners don't expect that a 120,000 + mile car should have the engine last forever. This is not an indictment of auto engines in general or even Mazda engines in particular when used in aircraft. There have after all be certified auto engines in production aircraft! (Go look it up if you are a true believer in the sacred Lyconental engine.) Modern auto engines need a PSRU to drop their RPM to acceptable prop RPMs. This is often the most difficult portion of the conversion. Numerous failures have occurred when very minor parts have failed on conversions. An oil leak from a cheap brass fitting used instead of steel or aluminum AN type fittings, water leaks from hoses, cracks occurring in components because of undamped vibrations, failed cotter pins or safety wire, etc. The point is that few of the failures are from the "engine" itself. It is mostly accessory failure which has caused auto engine failures in aircraft. Did you follow the extensive work of PowerSport in their rotary conversions? I have had extensive experience with a successful auto engine conversion. The airplane has operated hundreds of hours with a Honda Civic engine in it. Almost every difficulty has been systems failures. The crank, rods, pistons, block, head, valves and cam have all performed well. This is a turbo charged setup with 42" MP as METO and 45" Max. The RPM at cruise is 4000-4500. This engine is too small for even most RV-3s with only 120-125 HP. It was very light though @ #170! Maybe someone would like to look into the 2L or 2.2L Accord engine. The blanket statement that auto engines are unsuitable for A/C has been repeatedly proven wrong by those that went the distance. 1 issue that still dogs the auto engine is that there is essentially no "standard" conversion. Everyone engineers enough of it in their basement to destroy any chance of statistical models. If all Lycoming and Continental engines were only available with no accessories, they would also have similar failures (in addition to the well known problems they currently continue to have). Imagine if every homebuilder had to fabricate their own carburation, fuel pump, ignition system, oil cooling, etc. with *NO FACTORY COMPONENTS*. Would these engines run any more or less reliable than the FAA certified versions? In most every case the answer would be *LESS* reliable. If you go auto conversion because it is "cheaper", you will likely find it is not. If you do it because you want something different and don't mind the longer building time and the more extensive testing that comes with 2 experiments at once (airframe and powerplant), then go for it. Or if as I did you use the auto conversion because there is no aircraft engine which fits or is light enough or produces enough power for the weight. Then you are willing to "pay the price" of doing the conversion. Bob Steward, A&P IA AA-1B N8978L AA-5A N1976L ________________________________________________________________________________
Subject: For Sale
Date: May 28, 1998
I forgot to mention in my intial email that I am located in Los Angeles, CA if any one is interested. Tony Moradian Empenage #80398 N100TM reserved tmoradia(at)ix.netcom.com -----Original Message----- From: J.C. Hassall <jhassall(at)ipass.net> Date: Wednesday, May 27, 1998 5:32 PM Subject: Re: RV-List: For Sale >> >>1. I have been building my rv-8 project in a 20X20X10 shelter. This >>hangar/shelter/tent has galvenized steel frames that supports the material >>covering it which is made out of polyethyline. It has zippered doors in >>front which roll up through a pully system. The frame can be bolted to the >>ground as mine is. I am remodeling the house and building a garage so i >>don't need the hangar any more. The unit was purchased last October @ >>$1300.00 I have shop lights hanging from the top which will go with it. No >>reasonable offer will be refused. >> >>2. I also have a steel jig for the wing and the empenage made out of 3/8" >>thick square tubing with 5/16" thick base plates. It is solid. It was made >>last year also @ $380.00 I will sell it for $290.00 Please contact me off >>list if you are interested. > >Where are you located? Is the hangar shaped like a box or a quonset hut? > >TIA > > > >J.C. Hassall >RV-6 Builder Wannabe ________________________________________________________________________________
Date: May 28, 1998
Mark Mason wrote: > My understanding is that auto engines are designed for mostly > low power output punctuated by occasional spurts of high power. > And that aircraft engines typically run at or near full throttle > most of the time, yet retain a high degree of reliability. > Partly right and partly wrong. Truck engines and marine derivatives of auto engines are often operated for long extended periods at or near full power at sea level. I don't know anyone who operates his aircraft engine at 100% for more than a few minutes. I always back off my Debonair's Continental at or below 1000 feet agl. Within a few minutes I am at an altitude where the most power I can get is 75% at full throttle. For long flights and after a longer time I'm well below that, maybe down to 50% or less. Full throttle does not yield 100% power unless the engine is at sea level and rated RPM. > > Would someone in-the-know care to comment about the expected reliability > of non-racing auto engines used mostly at or near full throttle? > The real issue is the reliability of auto engine derivatives (most installed in aircraft are modified). I don't think the answers really exist yet. Durability is less important, at least to me. I'd rather have an engine I can rely on for 500 hours but is then worn out and cheaply overhauled than one that lasts 2000 hours but that I worry about all the time. This statement is about me though, not engines! The other big issue is weight but as fuel economy pressures continue, weight is rapidly coming down. The overwhelming virtue of auto engines is mass production. There are zillions of them and they are dirt cheap. They are cheap because they are made in huge quantities. Many don't understand just how big an effect on price high volume production has. Get a factory tour - any mass product factory. It really can be enlightening. Using an auto engine can suck up as much time as it takes to build the airframe and be exceedingly frustrating. I'm sure it is not for everyone. Hal Kempthorne RV-6AQ -- Looking for an airport halk(at)sybase.com Santa Clara, CA. Debonair N6134V @ SJC ________________________________________________________________________________
Date: May 28, 1998
What about the Everett Hatch rotary conversion? The last distributed info was that the remaining company director was planning to go forward with the manufacture of the plane jane versionof the engine expected to sell for about 15K. ________________________________________________________________________________
From: "Christopher E Browne" <cebrowne@duke-energy.com>
Date: May 28, 1998
Subject: Rotary Engines in Aircraft
Because I am anxious to fly, I will probably install a Lyc because of the engineering and extra work involved, but I am a big fan of alternative engine research that will help rock the avaition power plant boat. I found this on the internet at http://www.monito.com/wankel/aircraft.html and I thought this would be interesting: [quote]The first application of the rotary to an aircraft that this writer is aware of was a 1968 or 1969 Lockheed experimental Q-Star powered sailplane, a civilian version of the US Army's QT-2 reconnaissance plane, basically a Schweizer, two seater. It was powered by a 185 HP Curtiss-Wright RC2-60 Wankel rotary engine, complete with an automobile radiator.[unquote] It seems to me that rotaries do have an aviation history and that these guys may be on to something. Chris Browne Atlanta -6 Trim Tab ________________________________________________________________________________
Date: May 28, 1998
Subject: Maryland
Will any one who lives a reasonable distance from Hagerstown or Frederick, Maryland please contact me personally at emcole(at)ix.netcom.com Thanks, Ed Cole RV6A Fuselage.. ________________________________________________________________________________
Date: May 28, 1998
>RV-8 builders, > >When drilling the top of the tank skin to the baffle, the last 15 or 20 holes >are so close to the spar reinforcement bar that the drill bit hits it. Not a >problem in itself however I am concerned that the shop set on the rivits will >hit the re-bar. > >Anyone had this situation occur and was it a problem? > >Thanks IA > >Dennis Clay >wings happening >Eugene OR > Dennis, Yes, happened on my left wing. On my right wing, I slid the drill stop up on the bit so the bit would juuust barely penetrate through the baffle..and not contact the spar underneath. Oh well, live and learn. On the small gouges made on the left spar, I dressed them down with a jewelers file (round) and polished with scothbrite pad. I'm not concerned at all about it. Press on! Brian Denk -8 #379 wings almost done! > > > > ________________________________________________________________________________
Subject: bend in .063 angle
Date: May 28, 1998
> You can possibly salvage the angle, if you wish. Just cut another >short piece of .063 angle, 2-3 inches long and rivet it where the long angle >attaches to the 604. In other words, the short piece will be riveted >to the longer angle and to the 604. >Bob Skinner RV-6 415 hrs. Buffalo, WY bskinr(at)trib.com Thanks Bob: I may go that way. I was trying to visulise what it would look like when out of the fixture. If that will work I think I will do it to both sides & hope you don't tell any one. Don Jordan ~ 76DJ ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com ________________________________________________________________________________
Date: May 28, 1998
I hate to mention it, BUT !!! I think for the last few months over at Lycoming they had their office staff building engines while the real experts were on strike. Makes me kidda nervous buying new from Lycoming right Now. imagine ( file clerk: what spec did they call for on those main rod end bearings? janitor:: spec? I just cleaned it, it better not have no spec on it !!! ) scary !!! scott reviere winging it in Tampa ________________________________________________________________________________
Date: May 28, 1998
Subject: Nav Aid Wing Leveler Installation
Seriously considering retrofitting a NAV AID wing leveler into my RV-6A - flying. Can this unit be fitted under the seats and connected to the aileron push tubes, or must it be installed internally in the wing? The later would be very impractical in a completed plane, but just might be possible under the seats. Any experience out there? ________________________________________________________________________________
Date: May 28, 1998
There was a brief comment in a recent Sport Aviation that Steve Beckham was looking for a buyer for the company. Mike Wills RV-4 fuse willsm(at)manta.nosc.mil > > >What about the Everett Hatch rotary conversion? ________________________________________________________________________________
From: "Terrence C. Watson" <tcwatson(at)pstbbs.com>
Date: May 28, 1998
Regarding Mazda RX7 rotary engine reliability in automobiles: I would take emphatic exception with the idea that they were (are?) only good for about 60,000 miles. This is what the Nissan dealer told me when I bought my Mazda RX7 new in '82. I drove it for about 180,000 miles with no basic engine problems at all. (By "basic", I am excluding the accessories. I had minor ignition problems that were solved by replacing a computer component.) When I sold it after driving it about 15 years, it had developed an oil leak in the o ring between the sections that house each rotor. It's still running -- and still leaking -- somewhere in Texas. My biggest hesitation in replacing it with a Miata was that I would have to give up the rotary engine. After enjoying this little 4 banger for a couple of years though, I wouldn't go back -- in a car. The biggest annoyance I experienced with the rotary was what happens when you flood it. It was explained to me that too much raw gas softened the rotor tip seals, destroying the compression until they dried out. The technique for starting a flooded rotary was to pour a quart of oil down the carb and crank it until it started, and hope the cloud of smoke didn't bring the fire department, or worse yet, the EPA. >Will all the list members who have owned a Mazda powered by a rotary engine >please give us *YOUR* experiences? > snipped >I take issue with the "500000 mile [rotary] car engine". Mazda sells just >one rotary powered vehicle anymore, the RX-7. This car has an engine life >expectancy of less than 60,000 in "normal service". Mazda has an >excetional warranty policy over the years which has disguised this short >life. They will replace the engine under warranty (50,000 published, more >if the customer asks). Essentially you buy the RX-7 plus your replacement >engine at the time of purchase. They install it when the first engine >begins to fail, and then by the time the second engine bites the dust the >original owner has sold the car and the subsequent owners don't expect that >a 120,000 + mile car should have the engine last forever. > Terry Watson RV-8 #729 Seattle ________________________________________________________________________________
Date: May 28, 1998
<< I think for the last few months over at Lycoming they had their office staff building engines while the real experts were on strike. >> DITTO Did the labor dispute ever get settled? I don't believe it did. It would be nice if we could "rock their world" a little bit, "not that they'd care". Jim Nice RV6A WA State ________________________________________________________________________________
Date: May 28, 1998
Bob Steward wrote: >This car (the Mazda RX7) has an engine life > expectancy of less than 60,000 in "normal service". . > I must be lucky. Each of my three (3) RX7s have over 125,000 miles on them with no problems. These *ARE* original engines. I believe the RX7 is now discontinued entirely. The main drawback to these engines in autos is that the piston engines have gotten to be much better at fuel economy. My wife loves them and our three are all a hoot to drive and the latest ones are really works of art. Owners say the new Corvette is just a copy. hal ________________________________________________________________________________
Date: May 28, 1998
<< BUT !!! I think for the last few months over at Lycoming they had their office staff building engines while the real experts were on strike. Makes me kidda nervous buying new from Lycoming right Now. imagine ( file clerk: what spec did they call for on those main rod end bearings? janitor:: spec? I just cleaned it, it better not have no spec on it !!! ) scary !!! >> I've heard that Lycosaur has most/all of the components built overseas (lower labor costs?). So...we've got the lowest-wage people building the parts and the office staff slapping (slopping?) them together. This is a prescription for relilability?!?!? Question for Mazda experts. When we talk of a Mazda doing 6000 rpm, just what is doing 6000 rpm? The rotors or the output shaft? The rotor turns once for each turn of the output shaft so which is it? Might make a difference in the attitude of the openminded (nothing's going to affect the rest of 'em). And as to reliability, if the engine quits you've got a glider...if the airframe quits you've got a rock. Seems to me that if you want to err on the side of conservatism you'd put a Chevy in a Cessna. A Chessna? Of course if you're that worried what the heck are you doing reading this? You're supposed to be on a 737 (one that's had all the latest repairs of course.) Tails done and 6QB kit is in the world's narrowest hanger. (One car garage) Bob Fritz ________________________________________________________________________________
Date: May 28, 1998
Subject: Vacumm Instruments
I am ready to order my directional gyro and my artifical horizon. Do I need to special order these to account for the tilt of the instrument panel? Or can I use the standard ones? It doesn't seem that 6 to 8 degrees would be that big of a deal, but I'm no expert on the subject. I'm interested in hearing from the flying members of the list as to their experiences. Thanks. Randy Pflanzer RV-6 N417G "Special Angel" Wiring and Stuff ________________________________________________________________________________
Date: May 28, 1998
Bob Fritz, Don't know why you are knocking Boeing 737's. One of the safest aircraft ever developed. Think about it!! How many accident free miles do you think the 737's have??? A staggering amount!! You should be one of the people who realizes Airplanes are Mechanical . They can and do fail or break! Stew RV4273sb ________________________________________________________________________________
Date: May 28, 1998
From: David and Beth Hudgins <davidrv6a(at)mindspring.com>
Subject: Re: Vacumm Instruments
>Do I need to special order these to account for the tilt of the >instrument panel? Or can I use the standard ones? It doesn't >seem that 6 to 8 degrees would be that big of a deal Randy, I ordered mine with a 8 degree tilt for a -6A. This was recommended by a friend of mine in our local chapter who is an IA & AP. I also discussed this with Bill Benedict at Van's during Sun 'n Fun (3 yrs ago), he dragged out the prints and confirmed that 8 degree's would be right. I ended up ordering rebuilt from Century Instruments at the show that year. Haven't had any trouble in 200 hours of flight, although they do act a little "goofy" after aerobatics, I know I'm not doing them any good, but can't help it! Tom Green suggested to me at the time to install a vacuum shut off valve to disable the gyros during "the fun stuff". Never got around to it, but it may be worth considering. Also, there are different lengths of gyro's. I ordered the shorter version so I wouldn't have to cut through the sub-panel. Good Luck, Dave -6A, (down for annual)(but not for long!) ________________________________________________________________________________
Date: May 28, 1998
<< When we talk of a Mazda doing 6000 rpm, just what is doing 6000 rpm? The rotors or the output shaft? The rotor turns once for each turn of the output shaft so which is it? >> The rotor turns at 1/3 the output shaft. Bernie Kerr, 6A fuselage, SE Fla ________________________________________________________________________________
Date: May 28, 1998
Subject: RV8 Crash
Listers, Anyone heard any details of the RV8 crash? I am curious to know why a pilot with nearly 10,000 hours suddenly gets killed on a routine flight.... Jon Elford RV6 #25201 Banks, OR Wing skeletons.... Almost ready to jig. member that these engines are 2 strokes, which contributes to high emissions, but they also must burn a small amount of crankcase oil to lubricate the rotors. This oil is purposely injected into the intake tract by a small pump controlled by the throttle and driven by the eccentric shaft (rotary equivalent to a crankshaft). This oil burning is a fact of life with a rotary as well as being a pollution issue. Just my $.02.... Jon Elford RV6 #25201 Banks, OR Wing skeletons.... Almost ready to jig. ________________________________________________________________________________
Date: May 28, 1998
Mazda rotary engines used to wear out rotor seals at around 60,000 miles. They fixed this in the early '80s. Mark Mason Portland/Hillboro RV-6 maybe ________________________________________________________________________________
Date: May 28, 1998
I spoke to the folks from MAC at S & F. I noticed a plug they had installed on a trim motor (5 conductor--just what we need). It was Radio Shack part nos. 274-003A, 274-006A. The only thing they changed (and so will I) was to remove the pigtail extending from the plug and used shrink wrap instead. Marty RV-6AQ Erwinna, Pa. Installing RMD Lights in tips ________________________________________________________________________________
Date: May 28, 1998
(apologies in advance to those who will consider this off topic) >Will all the list members who have owned a Mazda powered by a rotary engine >please give us *YOUR* experiences? I've seen several Mazda conversions, I owned an 85 RX-7 and consider the rotary engine to have been the best engine I've ever owned, though it wasn't powerful enough in those days. I ran the car VERY hard including some SCCA solo events. However, I should note that I sold the car at about 50,000 miles to buy something faster. >I take issue with the "500000 mile [rotary] car engine". Mazda sells just >one rotary powered vehicle anymore, the RX-7. This car has an engine life >expectancy of less than 60,000 in "normal service". Mazda has an First off, Mazda sold many cars and trucks in Japan with rotary engines. This includes the 3 rotor engine that would be quite nice in my RV-8A. The engine got (and deserved) a bad reputation during the early 70's when it was originally introduced here, because of the problems they had with seals. THOSE engines were good for about 50,000 before rebuild. Once the RX-7 was introduced in '79, the 12A engine had been perfected, and no further problems existed. I've known many people that had RX-7's with well over 100,000 miles and no engine problems. IMO, you are certainly mistaken about the 60,000 "normal service" figure. There are a couple of things that will trash a rotary though. They aren't tolerant of overheating, and you should keep the oil clean because it's injected in a small quantity to lubricate the apex seals. Ideally, the engine should have a supply of 2-cycle injection oil that burns cleaner than regular motor oil, but Mazda knew that most people would eventually let the reservoir run out and trash the engine, so they just use oil from the pan. >Essentially you buy the RX-7 plus your replacement >engine at the time of purchase. Damn, I guess Mazda still owes me an engine. Who do I call to claim it :-) Rusty (don't talk bad about my rotary) Duffy ________________________________________________________________________________
Date: May 28, 1998
Subject: Re: bend in .063 angle
>Thanks Bob: >I may go that way. I was trying to visulise what it would look like when >out of the fixture. If that will work I think I will do it to both sides >& hope you don't tell any one. >Don Jordan ~ 76DJ ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com Gosh, Don, I don't think it's anything to be embarassed about:) I didn't do the assembly this way because of an "uh oh" but because it seemed more precise. Bending the altered .063 angle is kind of hit and miss as to whether you will achive the "lines" that you want. Drilling, bending and fitting as per plans also takes more time and if it doesn't fit flush with 604, you have to try again. No such problem with fitting a second (short) piece of .063 and lapping over the long angle and the 604. But---I won't tell anyone, either way. Regards, Bob Skinner RV-6 415 hrs. Buffalo, WY bskinr(at)trib.com ________________________________________________________________________________
Date: May 28, 1998
Subject: Re: Vacuum Instruments
<< I am ready to order my directional gyro and my artifical horizon. Do I need to special order these to account for the tilt of the instrument panel? Or can I use the standard ones? It doesn't seem that 6 to 8 degrees would be that big of a deal, but I'm no expert on the subject. >> Only the AG needs the 8 tilt. The DG is standard. -GV ________________________________________________________________________________
Date: May 28, 1998
Randy J. Pflanzer wrote: > > > I am ready to order my directional gyro and my artifical horizon. > Do I need to special order these to account for the tilt of the > instrument panel? Or can I use the standard ones? It doesn't > seem that 6 to 8 degrees would be that big of a deal, but I'm > no expert on the subject. > > I'm interested in hearing from the flying members of the list > as to their experiences. Thanks. > > Randy Pflanzer RV-6 > N417G "Special Angel" Wiring and Stuff > Randy The AH works just fine without the tilt, mine is not tilted but I wish it was. The problem is where the horizon line is in level flight, I have to have the little adjustable airplane all the way to the top of the adjustment to be even with the horizon line in level flight. -- Jerry Springer RV-6 N906GS First flight July 14, 1989 :-) Hillsboro, OR jsflyrv(at)ix.netcom.com ________________________________________________________________________________
Subject: Re: Rotary engines in RVs
Date: May 28, 1998
>Question for Mazda experts. When we talk of a Mazda doing 6000 rpm, just what >is doing 6000 rpm? The rotors or the output shaft? The rotor turns once for >each turn of the output shaft so which is it? Might make a difference in the >attitude of the openminded (nothing's going to affect the rest of 'em). (Disclaimer- not a Mazda "expert") Each rotor housing fires once for every revolution of the eccentric shaft. Therefore it takes 3 revolutions of the shaft to fire all sides of the rotors once. This is one of the reasons that the rotary isn't stressed as much by rpm's- the rotors are only turning 1/3 of the speed of the eccentric shaft. It also makes the topic of "displacement" interesting :-) Rusty ________________________________________________________________________________
Date: May 29, 1998
Mark C. Mason wrote: > Auto racing engines on the other hand are also used mostly at > or near full throttle. Nevertheless they are rebuilt often, sometimes > after each race. Except for the rotary, which apparently often goes a whole season without being opened. As far as I'm concerned, the only thing to be worried about are the systems attached to the engine (reduction gear, fuel, ignition, cooling, oil, exhaust, etc.). You certainly don't have to worry about it throwing a piston or valve! Worst case a seal might start leaking, loosing a bit of power, plenty of warning. Finn than making them in Williamsport. There was an auction scheduled last fall to sell off the Lycoming production tooling. I heard that a Federal Judge stopped them from selling (as this would have made the outsourcing a moot point if they no longer owned the equipment needed to make engine parts. There aren't likely to be *ANY* engines sitting around which were assembled by the engineering and management staff. The market was so desperate for engines that there was a 12-16 week wait for them to *LOOK* at warranty claims. New engines were available on an AOG basis and each one was built just for that particular order. Bob Steward, A&P IA AA-1B N8978L AA-5A N1976L ________________________________________________________________________________
Date: May 29, 1998
Subject: Re: RV8 Crash
<< Anyone heard any details of the RV8 crash? I am curious to know why a pilot with nearly 10,000 hours suddenly gets killed on a routine flight.... >> Jon: We are all naturally curious about the RV-8 crash... and I mean no flame be directed at you, Jon, by my following comments. The fact that the pilot had 10,000 hours may have little or no bearing upon the reason for the accident... John Morgan was not alone in that airplane. Van's has asked all of us here on the RV-List to make an effort to curb rumors, and I hope we can all do just that. Bill Benedict informed me this evening that Van arrived late today (Thursday) back in North Plains from his trip to examine the wreckage after it was moved to Phoenix. They (Van's) have not yet decided what was the actual cause of the accident, although much discussion is taking place. I know from my own investigation that the Official FAA report states "In flight break-up." This fact was not withheld by Van's. I feel certain that Van will direct that a statement be issued very soon, and that it will be truthful and factual no matter what the consequences may be. So I will resist the temptation to speculate and await what the designer has to say. Perhaps this is not so much to ask of us by the designer, after all, has he not always acted responsibly? Just my .02, getting off the soapbox now. Jon Ross RV-80094 N207RV Skinning fuselage ________________________________________________________________________________
Date: May 29, 1998
Subject: N106RV----Checking in!
I thought that I'd check in with the list, an update of sorts on how my testing is going. I've put 8.3 hours on it to date. I managed to fly 2 hours, today. It seems that the crimping I did on the number 3 exhaust leak, worked. I also noticed that the afterfiring on base and final approach is almost gone. I did some climb performance testing today. I did 3 full power climbs from 1500' to 10,500', at 105, 100, & 95 mph indicated. My initial weight was 1470 lbs. At 105 mph, the initial climb rate at 2500' was1600 fpm. For 100 & 95 mph at 2500' it was 1846 fpm. The average climb rates from 1500' to 10,500' were 105 mph = 963 fpm, 100 mph = 1001 fpm, and 95 mph = 1056 fpm. Using 95 mph, at 12,500' I was still climbing at 650 fpm. I leveled off at 12,500' and set up a cruise configuration of MAP 18.6", prop 2300. I was indicating 125 mph, 155 TAS when corrected for temp and pressure. Using the formula for the GPS on three different headings, I calculated that my calibrated airspeed was actually 168 mph, with a fuel burn of 6.9 GPH. This should've been about 55% power. I've done some other cruise airspeed calibration checks, and I'm always reading about 10 mph slower than what I compute using the GPS three headings 90 degrees apart formula from Kitplane magazine. I haven't done any slow speed calibration runs yet, so I don't know if the error is across the whole range, or just at the high end. I'm having some problems getting my engine to idle well after it gets heat soaked. I suspect I may have a problem with the diaghram in the flow divider. I'm thinking about pulling the injection system off and having it worked over. Just when I think I have the idle mixture set just right, the next time I run it, it changes. I know the idle mixture setting knob isn't moving, I marked it and it's staying put. I wonder if it might just be a piece of crap stuck under the seat. I wonder if I could disassemble the flow divider myself and inspect if for foreign objects? Man I love this airplane!!!!!!!!! Let the testing continue............. Mark LaBoyteaux RV-6A N106RV IO-320-B1A MLaboyteau(at)aol.com Broken Arrow, Ok ________________________________________________________________________________
Date: May 29, 1998
<< Do I need to special order these to account for the tilt of the instrument panel? Or can I use the standard ones? It doesn't seem that 6 to 8 degrees would be that big of a deal, but I'm no expert on the subject. >> When I ordered mine, I forgot to request the 8 degree tilt. I called the shop I bought the A/H from after I realized it, and they said to go ahead and try it out, and if I felt it needed to be adjusted, they would take care of it. It's a Sigma-Tek, and the horizon bar is adjustable. Well, it can be adjusted to level the bar with the horizon on the indicator in flight, but the horizon line on the indicator isn't in line with the lines on the outer frame. But I'm having too much fun to pull it out and send it back in. I really don't find it all that objectionable, but do wish I had remembered to specify the tilt when I ordered it. Mark LaBoyteaux RV-6A N106RV MLaboyteau(at)aol.com Broken Arrow, Ok ________________________________________________________________________________
Date: May 29, 1998
<< Anyone heard any details of the RV8 crash? I am curious to know why a pilot with nearly 10,000 hours suddenly gets killed on a routine flight.... Jon Elford >> Jon, Either im drunk or I cant help but think you have lost your mind!!! What kind of question is this? Its kind of like asking why did Phil Hartman shoot himself ? Who the hell knows!! We have no information. I also cant believe your ridding the auto conversions because of emisions. Lets face it no matter how you look at it we are turning a liquid (gasoline) into a gas. None of it is good for our enviroment. It doesent matter if its a Lycoming or a Mazda. Ryan Bendure Co ________________________________________________________________________________
Date: May 29, 1998
<< Of course if you're that worried what the heck are you doing reading this? You're supposed to be on a 737 (one that's had all the latest repairs of course.) Tails done and 6QB kit is in the world's narrowest hanger. (One car garage) Bob Fritz >> Sorry Bob but you sound like another person who is believing what the media is telling you (you should know better by now). The 737 is one of the most reliable jetliners ever built. I cant say where all the BS came from about the frayed wiring within the conduit in the fuel tanks because it just wasnt true. Sorry I was there but we all must believe what we need to believe. Ryan Bendure Co ________________________________________________________________________________
Date: May 29, 1998
In a message dated 5/28/98 3:28:56 AM Eastern Daylight Time, mark(at)edt.com writes: << Would someone in-the-know care to comment about the expected reliability of non-racing auto engines used mostly at or near full throttle? >> You HAD to ask didn't you. Auto engines are not designed to run at full rated power for long periods of time. The operative word in that sentence is rated. If an aircraft engine is rated at 150 HP at 2700 RPM that means it will develop that HP at that RPM. If an auto engine were rated accordingly,(at 2700 RPM), it would produce that power level as long or longer than an aircraft engine. the problem is that the auto engine power would probably be less than the equivalent aircraft engine. Likewise, if you tried to operate an aircraft engine at 4,000 RPM it wouldn't live very long either. The key to this whole very controversial subject is not to expect unreasonable amounts of power for ANY engine, and expect it to live very long. I expect to run my V-6 Chevy, for the most part, under 4,000 RPM and as such I expect to have a very acceptable TBO. There are a lot of auto engines with more than 1,000 hours on them with no problems, but they are not junkyard engines that were just thrwon together and stuck in an airplane. You must assemble the engine with your mission profile in mind, and then it will be just fine. I have read NO negative comments from anyone who has actually flown behind an auto engine, only from people who haven't tried it because "it won't work". This ought to open the flame wars again, huh ?? Regards, Merle (Yes Virginia, auto engines can, and do, fly) Miller ________________________________________________________________________________
Date: May 29, 1998
> more precise. Bending the altered .063 angle is kind of hit and > miss as to whether you will achive the "lines" that you want. > Drilling, bending and fitting as per plans also takes more time and > if it doesn't fit flush with 604, you have to try again. Actually Bob, it's quite precise if you joggle it by putting packing of the appropriate thickness on both sides and squeezing it up in a big vice. As always, practice on a piece of scrap. Peter Bennett Sydney Australia RV6 tailwheel on, main gear happening ________________________________________________________________________________
Date: May 29, 1998
Randy, I don't know about the AH or DG but some of the Turn Coordinators do not like being inclined in the panel. I have a combined vacuum and electric TC and it would slowly turn to one side when it was mounted on an angle in my T18. The instrument shop said that was normal though I could'nt understand why it would not do the same in a vertical panel in a sustained dive or climb. The TC may be the odd one out as it has it's gyro mounted at a 45 degree angle while a Turn and Bank Indicator and the others have the shaft horizontal or vertical. Regards, Brian. Albany. West Aussie Land. ________________________________________________________________________________
Subject: Re: Primer
Date: May 29, 1998
$14.00, then someone mentioned that you can buy the same under the name Martin Seniour self etching primer 7220 at your local NAPA store so I bought three cans of that at $5.00/can. HTH Larry Mac Donald lm4(at)juno.com > Larry, It's my understanding that the NAPA 7220 primer is supposed to be Sherwin Williams primer, not Marhyde. Rusty Well, I guess I screwed that up pretty good. I apologize to all. Larry Mac Donald lm4(at)juno.com ________________________________________________________________________________
Date: May 29, 1998
><< Anyone heard any details of the RV8 crash? I am curious to know why a >pilot > with nearly 10,000 hours suddenly gets killed on a routine flight.... > Jon Elford >> > >Jon, > Either im drunk or I cant help but think you have lost your mind!!! >What kind of question is this? Its kind of like asking why did Phil Hartman >shoot himself ? Who the hell knows!! We have no information. I think you're being a little harsh on Jon. It's a reasonable question that probably a few hundred of us on this list have not been able to get out of our minds since we heard the news. No one is speculating on anything, and the question is clearly no reflection on John's well-known excellent airmanship and instructing abilities. It's precisely because John was such a highly regarded pilot that many of us have been given pause to reflect. In other words, whatever did happen in this horrible tragedy could just as easily taken any one of us on the list because few I suspect there are very of us here who, regardless of how good we may be, would ever claim to be a "better" pilot than John. Please rethink your analogy.....few of us are worried about us accidently (or intentionally) shooting ourselves or being shot by a loved one. ALL of us ARE concerned about making every flight a safe, successful one. ________________________________________________________________________________
Date: May 29, 1998
In a message dated 5/28/98 2:57:57 PM Eastern Daylight Time, halk(at)sybase.com writes: << Using an auto engine can suck up as much time as it takes to build the airframe and be exceedingly frustrating. I'm sure it is not for everyone. >> How right you are !! I'm into my 8th month of installing my Chevy and I've only got the engine mounted with no plumbing or wiring done yet. Most people look at auto conversions for the wrong reasons (cheap) It IS less expensive, but in order to have it succeed the most important parts are the systems (fuel, ignition, cooling etc.) the darn engines are pretty much bulletproof, but the failure modes are usually attributed to faulty systems outside the actual engine. I am doing this as an engineering exercise, and because I've heard it won't work, and any engineer loves to hear that ! I wouldn't reccommend it to everyone, but if you have the inclination, and can take some frustrations (read engineering problems) go for it ! Regards, Merle ________________________________________________________________________________
Date: May 29, 1998
In a message dated 5/29/98 3:34:13 AM Eastern Daylight Time, JRoss10612(at)aol.com writes: << So I will resist the temptation to speculate and await what the designer has to say. Perhaps this is not so much to ask of us by the designer, after all, has he not always acted responsibly? >> I think we MUST NOT speculate or add fuel to any fire, but rather wait and see what Van has to say. I'm sure he will come out with a statement as soon as practicable. And, I might add there is nobody in the kitplane business IMHO with more integrity than Van. Regards, Merle (RV-4 Chevy) Miller ________________________________________________________________________________
Subject: Brake line locations
Date: May 29, 1998
Can someone tell me where the AN fitting goes for the brakeline as it exits the cockpit and goes out to the main gear. This is for a 6A. I see the routing on the drawing but there is no measurement there on the drawing. Also, I have the dual brake option and don't feel too comforatable putting those plastic tube fittings in on the passenger side. Anyone have any thoughts on this one or even better actual field test feedback? Gary Fesenbek Roanoke, VA ________________________________________________________________________________
Date: May 29, 1998
Subject: Re: RV-6/6A OAT probe location
At Van's, we have at least one aircraft with the probe in the NACA inlet and it works great on the ground. However, with cabin heat you can change the OAT reading by up to 10 degrees F. I have been told that insulating the end of the probe on the inside with some spray insulating foam in a paper cup will thermally isolate the probe and allow accurate measurements. Regards, Bill >>Will-- >>I stuck my probe in the NACA vent on the right side! I drilled up from the >>bottom about an inch back from the opening so you couldn't see it. I made the >>hole a few thousandths undersized and added a tad of RTV when I inserted it, >>seems very secure. Haven't tested it yet so can't give you any final details. >>Dave--- >>RV6 hoping for Sept. >> >I have mine in the same location, but on the left side of the fuse. It is >extremely accurate when the airplane is parked in the hanger. In flight, it >is useless, it always reads high. If I had to do it over again, I'd >probably mount it in the wing root fairing or out on the wing tip. One item >on my "to do" list is to move this probe. > >Scott Gesele N506RV - Flying > Bill RV-4-180 flying. N894RV with over 400 hours behind a O-320, Over 1000 RV flying hours. These opinions are mine and do not necessarily represent the opinions or position of my employer. ________________________________________________________________________________
Date: May 29, 1998
Exactly, spend some time at a race track. When the mazdas blow, there are not parts all over the track, it just blows smoke and starts losing power and comes to the pits on the next lap or so. Lots of warning and still some power. ________________________________________________________________________________
Date: May 29, 1998
>><< Anyone heard any details of the RV8 crash? I am curious to know why a >>pilot >> with nearly 10,000 hours suddenly gets killed on a routine flight.... >> Jon Elford >> >> >>Jon, >> Either im drunk or I cant help but think you have lost your mind!!! >>What kind of question is this? There is nothing wrong with asking a question about an accident or an incident. The answers often produces constructive, useful information to do a better job of building and piloting. Even if 99.9% of the answers are speculation, this includes hundreds of "offical report" speculating officially on accidents and incidents. Van has an excellent product, without question. Van and his staff make a sincere and responsive effort, to the best of my knowledge, at all times to make the products as "fool" proof as posible. That is why I bought the kit. The rest is the resposibility of the builder and pilot. It is, for education and it is experimental! My limited conversations with John lead me to believe that he was a educated, sincere, and competent pilot. He was alway diligent in his answers to me when I ask for advise. No one is above mistakes...that should not take anything away from the pilot or the product in thinking men's minds. But the knowledge derived from the mistakes can help us. I know many of the thought provoking (most speculative) answers helped me through 50+ years of general and professional flying. ________________________________________________________________________________
Date: May 29, 1998
Subject: RV-8 Fuse Jig- Oregon
Listers; I will have my fuse out of the jig shortly, and would like to make the jig available to others. I have reciepts for 130.00 for materials, and two days labor to build it. Would like the standard (around here) $100 for it. It is built straight and true out of dry high quality lumber. It is made to come apart into two pieces for hauling with a pickup truck. Located in Independence, Oregon, which is 10 miles from Salem, Oregon. Von Alexander RV-8#544 MAlexan533(at)aol.com ________________________________________________________________________________
Subject: Cherry Rivet application
Date: May 29, 1998
I have made my first big opps! Building the elevator last night, I forgot to rivet the control arm first and will be forced to use structural blind rivets. Question: The archives mention that CherryMax "Structural" rivets will be an acceptable substitute for driven rivets. Do you need the $200 plus Cherry brand Hydra Pullers or can I use my $15 Sears model to install 12 rivets. Vans online catalog lists 5/32 Cherry "N" rivets as structural, but Cherry lists them as non-structural. Is this the case were a 5/32 "N" rivet would substitute for 1/8 rivet in a structural application? Robin Wessel RV-6A Ann Arbor, MI ________________________________________________________________________________
Date: May 29, 1998
Subject: Digi-Key Connectors
Just a follow up on the connectors for the electric trim wires...I spoke with the folks at Digi-Key yesterday, and they were extremely helpful...the tech guys talked with me for about 20 minutes on all the possible options that I had, the benifits, drawbacks, etc...I placed an order for some Molex connectors, crimpers, etc...I'm sure I will be ordering more electrical supplies from them in the future.... Paul Besing RV-6A (197AB) Arizona Mounting Empennage ________________________________________________________________________________
Date: May 29, 1998
<< At Van's, we have at least one aircraft with the probe in the NACA inlet and it works great on the ground. However, with cabin heat you can change the OAT reading by up to 10 degrees F. I have been told that insulating the end of the probe on the inside with some spray insulating foam in a paper cup will thermally isolate the probe and allow accurate measurements. Regards, Bill >> I am considering mounting the OAT probe in the NACA fresh air inlet on the lower wing skin on my RV-8, this should eliminate cabin/engine heat induced errors. The wires will have to be made longer, but RMI says no problem. Jon Ross RV-80094 Skinning fuselage ________________________________________________________________________________
Date: May 29, 1998
> >Randy, I don't know about the AH or DG but some of the Turn Coordinators do >not like being inclined in the panel. I have a combined vacuum and Is this 8 degree setting an adjustment or are the instruments manufactured this way. The reason I am wondering is I already have mine and don't know what they are set for. Thanks Shelby in Nashville. ________________________________________________________________________________
Date: May 29, 1998
Well put Loren. I think this has sent a shudder throughout our community and it is perfectly understandable to seek understanding and some sort of resolution as to the cause. Shelby in Nashville. ________________________________________________________________________________
Date: May 29, 1998
Subject: jon's seats
I received another e-mail from Jon concerning his seats. He said they are already upholstered. I asked for pictures of the seats and the colors so we could better determine which color would better match our planes or existing upholstery. I will pass it on when I hear back form him. There are 2 others besides myself who are interested in these seats. Jon said they could ship 4 to a box to cut down on the shipping (~350.00). Is anyone else interested. Michael. ________________________________________________________________________________
From: "Moe Colontonio" <moejoe(at)bellatlantic.net>
Subject: Re: Cherry Rivet application
Date: May 29, 1998
Check the archives. Someone else made this mistake not too long ago. I believe they were told not to use "pop" rivets here, and it turned out they only had to drill out a few solid rivets to get in there and buck the horn. Moe > >I have made my first big opps! Building the elevator last night, I forgot to >rivet the control arm first and will be forced to use structural blind >rivets. > >Question: The archives mention that CherryMax "Structural" rivets will be an >acceptable substitute for driven rivets. Do you need the $200 plus Cherry >brand Hydra Pullers or can I use my $15 Sears model to install 12 rivets. > >Vans online catalog lists 5/32 Cherry "N" rivets as structural, but Cherry >lists them as non-structural. Is this the case were a 5/32 "N" rivet would >substitute for 1/8 rivet in a structural application? > > >Robin Wessel >RV-6A Ann Arbor, MI > > > > > ________________________________________________________________________________
Date: May 29, 1998
I think the internet has caused us all to expect instant feedback on everything. I know that I am a little more then frustrated that I can't find a shred of info on this accident anywhere. The NTSB still has no report (that I could find). I wouldn't expect Van to put anything about it on the webpage. After all, the page is really just an advertisement, and this is not the type of thing you want to advertise about your product. Keep in mind that if it wasn't for the internet, most of us wouldn't even know about this until the next RV-ater came out. I think we should all be patient, Van is a straight shooter, and I'm sure we will all be satisfied with his report. Moe Colontonio RV-8Q #00485 Check out my RV-8 page at: http://members.bellatlantic.net/~moejoe >Well put Loren. I think this has sent a shudder throughout our community >and it is perfectly understandable to seek understanding and some sort of >resolution as to the cause. > >Shelby in Nashville. > ________________________________________________________________________________
From: "Jensen, Keith (MC R&D)" <KJensen(at)simplot.com>
Subject: General Question: Autogas in Lyc
Date: May 29, 1998
This is an open question to the list: I was in Edmonton, Canada (Villeneuve) last week, and got a chance to fly a rental (C-172) with an instructor in the local area. When checking the sumps, lo and behold the gas was yellow! When I asked, he said they run on Autogas mostly. He indicated that they will run three or four tanks of Autogas, and then fill it up with a tank of 100LL, the idea being that the engine is o.k. when fed only an occasional dose of leaded fuel to keep the valves and stuff happy. I'd like to hear some opinions on that. I'd also like to hear some opinions as to what happens to rated HP when running with the lower octane number - does it drop noticeably? That is my guess. Keith Jensen Pocatello, Idaho -6A HS done - trying to figure out how to store it so I can get going on the VS ________________________________________________________________________________
Date: May 29, 1998
><< At Van's, we have at least one aircraft with the probe in the NACA inlet > and it works great on the ground. However, with cabin heat you can change > the OAT reading by up to 10 degrees F. For RV-6, where is a good place for RMI OAT probe? I would thing in a dead air area to minimize temp rise from friction. I know at our speeds it is not much of a factor, but it would amount a small amount. A Good Day to you! Denny harje(at)proaxis.com Lebanon, OR ________________________________________________________________________________
Date: May 29, 1998
Subject: Re: Brake line locations
<< Can someone tell me where the AN fitting goes for the brakeline as it exits the cockpit and goes out to the main gear. This is for a 6A. I see the routing on the drawing but there is no measurement there on the drawing.>> I'll take a measurement today for you. All of the wing related tubing obviously needs to be contained by the wing root fairing so put your airfoil template up against the side of the fuse and outline it. I used the 1/4" right angle bulkhead fittings. Mine are in the reinforced area ahead of the spar (6A). You drill a hole thru both sheets and then chase the outside hole to a diameter sufficient to tighten the nut. << Also, I have the dual brake option and don't feel too comforatable putting those plastic tube fittings in on the passenger side. Anyone have any thoughts on this one or even better actual field test feedback? >> I used a one into four manifold from ACS and ran the plastic lines from that into the top of each master cyl (I have shuttle valves so this is required) using Parker Hannifin brass fittings for plastic tubing. -GV ________________________________________________________________________________
Date: May 29, 1998
If you use the 1/8" Cherrymax rivets you can pull them with a good hand puller. They have a small washer around the stem that sets the lockring and enables you to use the standard pulling head. Make SURE you use the correct Grip Length!!! Stew RV4273sb Co. ________________________________________________________________________________
Date: May 29, 1998
Jim they all went back to work unhappily as i read in sport aviation. still i scares me to purchase a new lyc built by pissed off employees still scarry scott winging it in Tampa ________________________________________________________________________________
Date: May 29, 1998
Jon, the NSTB, stated that it was an in flight break up, but i'm still waiting to see what Mr. VAN has to say about it. I'm sure he will do a complete investigation of his own. I would expect as soon as it settles down over there he will inform us sadly missing Mr. Morgan scott reviere ________________________________________________________________________________
Subject: Prop wanted
Date: May 29, 1998
Looking for good/new condition Sensenich fixed metal, or Hartzell c/s prop for O-320 (7/16" bolt holes) RV-6. Please send all leads privately to my e-mail address. Thanks, Rob (RV-6Q, waiting for warm canopy working weather and engine delivery). ________________________________________________________________________________
Date: May 29, 1998
Jon, Curious as to where on the lower wing skin you are mounting this inlet? Any possibility you might pick up engine exhaust through this "fresh air duct", or is it located far enough out on the wing to avoid exhaust flow? Mike Wills RV-4 fuse willsm(at)manta.nosc.mil >I am considering mounting the OAT probe in the NACA fresh air inlet on the >lower wing skin on my RV-8, this should eliminate cabin/engine heat induced >errors. The wires will have to be made longer, but RMI says no problem. > >Jon Ross RV-80094 Skinning fuselage ________________________________________________________________________________
Date: May 29, 1998
Moe, & other listers the NSTB can be found at ( faa.gov/avr/aai/iirform.htm ) if any one has address to other sites let me know scott reviere winging it in Tampa ________________________________________________________________________________
Date: May 29, 1998
Gary, I replaced all the brake lines inside the cockpit with stainless steel braided brake hose from Earl's Performance Products. I did this after having one of the plastic/nylon lines pull lose from a fitting - I may have installed it poorly, but decided that the reliability of stainless steel line was worth the cost and weight. I mean its one thing if you can't get started, its quite another if you can't get stopped. Ed Andeson RV-6A anderson_ed(at)bah.com Fesenbek, Gary wrote: > > Also, I have the dual brake option and don't feel too comforatable > putting those plastic tube fittings in on the passenger side. Anyone > have any thoughts on this one or even better actual field test feedback? > > Gary Fesenbek > Roanoke, VA > ________________________________________________________________________________
Date: May 29, 1998
<< Is this 8 degree setting an adjustment or are the instruments manufactured this way. The reason I am wondering is I already have mine and don't know what they are set for. >> The instrument must be disassembled to make the change. The manufacturer should be consulted or a good gyro shop should be able to do the mod. -GV ________________________________________________________________________________
Date: May 29, 1998
<< have made my first big opps! Building the elevator last night, I forgot to rivet the control arm first and will be forced to use structural blind rivets. >> Did the same thing - Called Vans and they could not advise using the Cherrymax in its place, the reason was they never did it, therefor could not reccomend it. I ran it by several A&P and they all agreed that the Cherrymax would work fine. So I used #4 Cherrymax - I purchased the Air Pop Rivet Tool from Avery the Cherry Max Gauge and it was fixed in about 15 minutes. Will it work ? I'm sure it will, however keep in mind a failure on this horn can be rather fatal, I have since rebuilt both elevators, the one with the Trim Tab did not come out the way I would have liked it too, so I built the other for the hell of it. The great part about building the RV is that if you screw up a part, its cheap enough to buy the parts and do it again, the second time you are armed to the teeth with the knowledge you gained the first time , lets face it most of us never did this type of work and its a learning experience. Good Luck BSivori(at)AOL.COM N929RV (Reserved) Closing the Wings @LAST ________________________________________________________________________________
Date: May 29, 1998
There is a difference between a Cherry N rivet and a CherryMax rivet. The CherryMax are supposed to be stronger and resist vibration better. Cherry-Textron describes the Cherry N as a "Non-structural blind breakstem rivet designed for a wide range of applications. Available in a variety of materials and combinations with low profile, large flange or countersunk head styles." I understand that the CherryMax is a structural rivet. Check the website at www.advelcherrytextron.com. much to my surprise, they no longer describe the CherryMax at that site (or at least I couldn't find it!) Steve Soule Huntington Vermont -----Original Message----- Sent: Friday, May 29, 1998 12:00 PM To: rv-list(at)matronics.com Subject: Re: RV-List: Cherry Rivet application Check the archives. Someone else made this mistake not too long ago. I believe they were told not to use "pop" rivets here, and it turned out they only had to drill out a few solid rivets to get in there and buck the horn. Moe robin.y.wessel(at)exgate.tek.com > >I have made my first big opps! Building the elevator last night, I forgot to >rivet the control arm first and will be forced to use structural blind >rivets. > >Question: The archives mention that CherryMax "Structural" rivets will be an >acceptable substitute for driven rivets. Do you need the $200 plus Cherry >brand Hydra Pullers or can I use my $15 Sears model to install 12 rivets. > >Vans online catalog lists 5/32 Cherry "N" rivets as structural, but Cherry >lists them as non-structural. Is this the case were a 5/32 "N" rivet would >substitute for 1/8 rivet in a structural application? > > >Robin Wessel >RV-6A Ann Arbor, MI > > > > > ________________________________________________________________________________
Date: May 29, 1998
I generally consider myself a moderate when it comes to use of pop rivets and alternate fastners in building one of these things, but I don't believe I would care to fly in one having pop rivets (Cherry, structural or otherwise) in the elevator horn attachment. I would try and open up the elevator skin and attach as designed. Just my opinion... Good luck. Bryan Jones RV-8 80313, attaching empenage Pearland, TX > > I have made my first big opps! Building the elevator last night, I > forgot to > rivet the control arm first and will be forced to use structural blind > rivets. > > ________________________________________________________________________________
Date: May 29, 1998
Subject: Re: Nav Aid Wing Leveler Installation
> >Seriously considering retrofitting a NAV AID wing leveler into my RV-6A >- flying. Can this unit be fitted under the seats and connected to the >aileron push tubes, or must it be installed internally in the wing? The >later would be very impractical in a completed plane, but just might be >possible under the seats. Any experience out there? John, I think it might be easier to retro fit the Navaid servo under the passenger seat as opposed to a wing installation, especially if the plane is painted. The original material that I got with my Navaid showed an under the passenger seat installation. The push rod from the servo, which is mounted to the belly, attached to the co-pilot stick. An idea that I like better that was done by a fellow lister (GV?) was to use a longer push rod and attach to the pilots control stick. This lessens the operating range or arc that the push rod has to operate in thus making the location of the servo less exacting. When using the short push rod, positioning of the servo is critical. I had to make some cone shapped (tiny) spacers for each side of the two push rod rod end bearings so I could get maximum travel. Otherwise, at extreme positions, the rod ends would bottom out putting stress on the tiny rod ends. The downside to mounting in the fuselage is that you will have some new rivets on the belly. I would recommend that the servo be mounted on a doubler of some kind to lessen flex as opposed to just being mounted on the .032" belly skin. Bob Skinner RV-6 415 hrs. Buffalo, WY bskinr(at)trib.com ________________________________________________________________________________
Subject: RV8 Crash
Date: May 29, 1998
a more direct address is ntsb.gov g. fesenbek braking in Roanoke > -----Original Message----- > From: ABAYMAN(at)aol.com [SMTP:ABAYMAN(at)aol.com] > Sent: Friday, May 29, 1998 1:31 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: RV8 Crash > > > Moe, & other listers > the NSTB can be found at ( faa.gov/avr/aai/iirform.htm ) > if any one has address to other sites let me know > scott reviere > winging it in Tampa > > > ________________________________________________________________________________
Date: May 29, 1998
Subject: Re: General Question: Autogas in Lyc
> Keith, All other things being equal, reduced octane number does not effect power output of an engine provided the engine doesnt detonate on the lower octane fuel. Higher octane fuel is insurance against detonation. Mike Wills RV-4 fuse willsm(at)manta.nosc.mil > I'd like to hear some opinions on that. I'd also like to hear >some opinions as to what happens to rated HP when running with the lower >octane number - does it drop noticeably? That is my guess. > > Keith Jensen > Pocatello, Idaho ________________________________________________________________________________
From: "David Shumway" <dshumway(at)casewaretech.com>
Subject: Re: jon's seats
Date: May 29, 1998
Thanks for the update. I met with my Australian distributor who said he gets items sent from Australia to Utah for $80 via Fed. Ex. Though he did not know what the size restraints were. He also said that we could get items shipped at a small fraction of the cost if we were to have them sent via boat. (approx. 4-6 weeks) I am in no hurry even though I am already flying. If the cost difference were worthwhile, I wouldn't mind the wait. I will be very interested in the photos. David Shumway -----Original Message----- From: MICHAEL <lottmc(at)datasync.com> Date: Friday, May 29, 1998 9:46 AM Subject: RV-List: jon's seats > >I received another e-mail from Jon concerning his seats. He >said they are already upholstered. I asked for pictures of the >seats and the colors so we could better determine which color >would better match our planes or existing upholstery. I will >pass it on when I hear back form him. There are 2 others besides >myself who are interested in these seats. Jon said they could >ship 4 to a box to cut down on the shipping (~350.00). Is anyone >else interested. Michael. > > > > > > ________________________________________________________________________________
Date: May 29, 1998
>I am ready to order my directional gyro and my artifical horizon. >Do I need to special order these to account for the tilt of the >instrument panel? Or can I use the standard ones? It doesn't >seem that 6 to 8 degrees would be that big of a deal, but I'm >no expert on the subject. > >I'm interested in hearing from the flying members of the list >as to their experiences. Thanks. > >Randy Pflanzer RV-6 > Randy, The 8 deg tilt on the artificial horizon works perfectly in my RV-6A. When trimmed in cruise, all lines line up as they should. It was well worth the added two week wait to get the special order "8-deg" tilt in the gyro. BTW, RC-Allen did not charge extra for this. The D.G. does not need the tilt. Hope this helps. Scott Gesele N506RV -Flying (120 hrs since Sept and "Climbing") ________________________________________________________________________________
Date: May 29, 1998
>Actually Bob, it's quite precise if you joggle it by putting packing >of the appropriate thickness on both sides and squeezing it up in a >big vice. As always, practice on a piece of scrap. > >Peter Bennett >Sydney Australia > Peter: I was the one wilh .063 bending problem. After Bob's post I am planing on the shim & splice method. Could you explain to me the technique your usinf to bend it? the 2 f604 pcs are .063 each. So do I need two .125 pieces in the vise to joggle the angle? If I contour the two scrap pieces with a .250 radius, are your saying I will end up with a .125 offset in the joggle? Thanks: Don Jordan ~ 76DJ ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com ________________________________________________________________________________
Date: May 29, 1998
robin.y.wessel(at)exgate.tek.com wrote: > > > I have made my first big opps! Building the elevator last night, I forgot to > rivet the control arm first and will be forced to use structural blind > rivets. > Robin, Don't feel bad, that's one of the many easy-to-make mistakes. I think it's great that you have gone this far w/o a major mistake. Personally, I would drill out the skin rivets around the horn and either reach in with the squeezer or hand-buck them. If you have a deep squeezer yoke, you may be able to do all riveting by just drilling out one side of the elevator. I may be wrong, but to me, this is an area that I would want all the strength I could get! It's hard to drill out perfectly good rivets, but the peace of mind definately justifies it IMHO :^) Good Luck Jerry Calvert Edmond Ok -6a ________________________________________________________________________________
Date: May 29, 1998
<< I cant say where all the BS came from about the frayed wiring within the conduit in the fuel tanks >> ANSWER - - POLITICS ________________________________________________________________________________
Date: May 29, 1998
Bob Skinner wrote: > Thank you for taking the trouble to give me some much appreciated advise re the > NAVAID; it's a lot easier to stay out of trouble than to GET out of trouble! > thank you. John > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: May 29, 1998
In a message dated 5/29/98 10:22:05 AM Eastern Daylight Time, billb(at)atheria.europa.com writes: << is >> Bill-- How do you spray insulating foam in a cup? Do you put the foam around the probe leaving what part exposed, or do you insulate the NACA vent betwen the fusalage and vent? Dave--- Please except our condolences from Akron, NY on John Morgan's unfortunate accident. Our thoughts will be with him and his wife Salley and his passenger! ________________________________________________________________________________
Date: May 29, 1998
> All other things being equal, reduced octane number does not effect power > output of an engine provided the engine doesnt detonate on the lower octane > fuel. Higher octane fuel is insurance against detonation. In the early 70s there were water injection systems to prevent detonation in high compression engines when high octane fuel was not available. A side effect was steam-cleaned combustion chambers and valves. Given the added complexity, is this a viable alternative to high-octane fuel in aircraft engines? Mark Mason Portland/Hillsboro RV-6 maybe ________________________________________________________________________________
Date: May 29, 1998
RV4131rb(at)aol.com wrote: > .........The 737 is one of the most > reliable jetliners ever built...... Ryan Bendure Co > Does anyone remember the 737 that broke up over Hawaii (sp?) a few years ago? The skins and structure pealed away behind the cockpit for several feet, yet the plane kept flying and landed safely even though a passenger or two were sucked out the top. Television footage showed the plane coming in and the passengers were sitting there with the wind in their faces. My impression at the time was that Boeing had designed a pretty good airplane. My $0.025 worth :) martin shorman Lawton, IA ________________________________________________________________________________
Date: May 29, 1998
Something to bear in mind -- if a vacuum instrument just sits for 90 days, the warranty is no longer valid. Apparently the lubrication drains away. Therefore, do not order the vacuum instruments until you are ready to use them. John RV6A Flying, 150 hours Newmarket Ontario ________________________________________________________________________________
Date: May 29, 1998
>I am curious to know why a pilot >with nearly 10,000 hours suddenly gets killed on a routine flight.... >Jon Elford Jon, An Excellent Question! Unfortunately we don't know the short answer. What I do know is, the more we ask ourselves that question, the less likely it is to happen....... I met John recently at the Redwing Flyin. He seemed like a very professional and thoughtful aviator. My thoughts are with his family and his friends. Tailwinds, Doug Rozendaal dougr(at)petroblend.com www.petroblend.com/dougr ________________________________________________________________________________
Date: May 29, 1998
>In the early 70s there were water injection systems to prevent >detonation in high compression engines when high octane fuel >was not available. A side effect was steam-cleaned combustion >chambers and valves. > In the late 40's on big round engines Water/Methonal Injection systems were introduced on hi-output radials. This involved spraying large amouts of water/methonal, called ADI fluid in the Intake system. This allowed running much higher manifold pressures without detonation. If the ADI was not available or not used then a reduced Manifold pressure setting would have to be used for takeoff resulting in much less power available. In an RV it would be much easier to use a lower power setting for take off, than fool with the ADI fluid. Tailwinds, Doug Rozendaal dougr(at)petroblend.com (my old netins.net is no longer valid) www.petroblend.com/dougr ________________________________________________________________________________
Date: May 29, 1998
<< An idea that I like better that was done by a fellow lister (GV?) was to use a longer push rod and attach to the pilots control stick.>> Sorry, Bob. It wasn't me. I did it the standard way, attached to the co- pilot's stick and it works well. <> I agree. These small rod ends will break if you look at them cross-eyed (I broke both during installation and they sent me new ones). I sure would like an alternative to these little guys. If the rod end attached to the servo arm breaks in flight, the loose push rod could hang up on the seat ribs and foul the stick. I need to give this failure mode some thought. -GV ________________________________________________________________________________
Date: May 29, 1998
<< Something to bear in mind -- if a vacuum instrument just sits for 90 days, the warranty is no longer valid. Apparently the lubrication drains away. Therefore, do not order the vacuum instruments until you are ready to use them. >> Just what we need, another thing to worry about. -GV (running gyros that sat in the box for 2 yrs) ________________________________________________________________________________
Date: May 29, 1998
Subject: Re:RV4 slider
John, I am forwarding your request to the RV mail-list. No doubt you will get some responses. Listers, please send CC's of your replies directly to John: jholtphx(at)syspac.com I don't think he is on the list. Thanks, Sam Buchanan sbuc(at)traveller.com "The RV Journal" http://www.ath.tis.net/~sbuc/rv6 John Holt wrote: > > I'm looking for a kit or set of plans, for a sliding canopy for > an rv-4. John Haehn has offered one in the past, but I can't > seem to track him down. Any ideas? > > Blue Skies, > > John Holt ________________________________________________________________________________
Subject: Re: AVGAS IN GENERAL
Date: May 30, 1998
With all this talk about octane ratings, water injection etc. I hope no one is being misled into thinking that the danger with mogas is the octane rating and effects on engine lifeand performance. The danger with mogas is in the engine stopping or losing power when you want it most. The biggest problem is the reduced Ried's Vapour Pressure or more simply (correct me if I'm wrong) Boiling temperature of mogas. Their seems to be an almost universal misconception that the only problem at high temperatures is "vapour lock".This being interpreted to mean the fuel boils in the lines due to the reduced pressure caused by the pump, thereby leading to fuel starvation ie.,an engine failure due to SHORTAGE of fuel . It then seems to follow that a gravity feed system won't have problems due to the higher volatility because it does'nt suck the fuel. I'm sure this thinking has led to many accidents. I know of at least two. The problem that I have never seen in print, is the engine failure due to EXCESS fuel caused by the use of mogas. The temperatures in the engine compartment can get very high and the carburator is not isolated from this. Normally the fuel coming through is cool enough that it cools the carby and there is no problem. However if the airplane sits in the sun all day, the fuel gets nice and hot, you do a few circuits, taxi in, change passengers and take off !!!! Maximum power, reduced pressure in the carby bowl, bowl in hot engine compartment, reduced boiling point due to mogas. What's next? Fuel BOILS IN THE CARBY, carby float is now heavier than the bubbling fuel and sinks to the bottom. Unrestricted fuel flows to the engine through the bowl vent which is in the carby throat the engine now losses power due to EXCESS fuel. You would need to be a brave and quick thinking person to pull the mixture and or restrict the fuel flow with the shut off valve, but that is what is required, and fast ! I have seen a Cessna on a very hot day, which would run fine below 3500 feet, but could'nt climb above that due to the mogas boiling. And another which could not climb after takeoff. ( black smoke puffing from exhaust ) All your training now tells you to "richen mixture,fuel pump on" which only makes the problem worse Try putting a block of wood ( which just floats ) in water and watch what happens when the water boils. I have used quite a lot of mogas, and in winter it may be fine, but be very wary if you intend to use it for take off and landing in summer or it might work out more expensive than avggas. This is longer than intended but if it saves someone some angst it is worth it. Happy flying, Brian ________________________________________________________________________________
Date: May 29, 1998
Subject: 6A tail tie down
Can someone tell me which drawing has the info on mounting the tail tie down weldment for the 6A? I couldn't find anything on mounting or positioning in Charlie's plans. I assume that it is installed with nutplates so it can be easliy replaced if damaged due to over rotation, etc. Thanks, Bob Skinner RV-6 415 hrs. Buffalo, WY bskinr(at)trib.com ________________________________________________________________________________
Date: May 30, 1998
<< For RV-6, where is a good place for RMI OAT probe? I would thing in a dead air area to minimize temp rise from friction. I know at our speeds it is not much of a factor, but it would amount a small amount. A Good Day to you! Denny harje(at)proaxis.com Lebanon, OR >> Hi Denny, I have the RMI micromonitor in my -6A, and I installed the OAT sensor in the right naca inlet, just like a lot of other people. It reads accurate on the ground, but in flight, it reads high, just like a lot of other people's! I tried making a seal at the aft edge of the top cowl with clear RTV, but I suspect the cowl is flexing out a little in flight, allowing hot air to leak out, and it's getting sucked in the naca vent. Even at 12,500' when the OAT should be around 8-10 degrees C, it will still read 23 - 25C. And on mine, the air coming in the right vent is warmer than the air coming in the left vent. I'm going to relocate my probe down to the aft end of the lower wing root fairing. I'm just not sure when! I'm having too much fun flying! Mark LaBoyteaux RV-6A N106RV MLaboyteau(at)aol.com Broken Arrow, Ok ________________________________________________________________________________
Date: May 29, 1998
Subject: RV8 Crash
Listers, I publicly apologize for any offense generated by my inquiry into the RV8 crash. I know this is a difficult and trying time, but was only curious if anyone had heard anything. I deeply respect Van's integrity and truthfulness and have no doubts as to whether we will be told the bottom-line as far as this issue goes. Please, if I offended you, I'm sorry. Regards, Jon Elford RV6 #25201 Banks, OR Wing skeletons.... Almost ready to jig. ________________________________________________________________________________
Date: May 30, 1998
From: Unistar Computers <unistar(at)mindspring.com>
> > I was in Edmonton, Canada (Villeneuve) last week, and got a >chance to fly a rental (C-172) with an instructor in the local area. >When checking the sumps, lo and behold the gas was yellow! When I >asked, he said they run on Autogas mostly. He indicated that they will >run three or four tanks of Autogas, and then fill it up with a tank of >100LL, the idea being that the engine is o.k. when fed only an >occasional dose of leaded fuel to keep the valves and stuff happy. > > I'd like to hear some opinions on that. I'd also like to hear >some opinions as to what happens to rated HP when running with the lower >octane number - does it drop noticeably? That is my guess. > Keith Jensen Does the power go *UP* as you increase your fuel's octane with no other changes? NO. The octane is the measure of resistance to ignition from heat and pressure. If the engine (C-172, must have been O-300 Cont. on a really old one, or a O-320 Lycoming on a newer one) was designed to use "80/87" Octane avgas then 87+ Octane auto fuel has been shown to be adequate. (The O-320 H2AD is a high compression engine and needs more than "80 Octane" fuel to run correctly.) Since we used to have "91-96 Octane" avgas back 30+ years ago there are quite a few engines which can run 91-93 Octane car gas with no ill effects. Some have speculated that auto fuel may have more heat energy / gallon than Avgas, and so might provide more HP. I can't confirm this, but the true issue of "rated horsepower" is purely a function of the energy of the fuel and its resistance to detonation. Thus if you use "premium" in your car which was designed for 87 octane you can't see any performance increase. (Much to the chargrin of the high school crowd who buy "hi-test" with the idea of gettting a few more ponies out of the old man's Chevy.) The only way to liberate more power from higher octane fuel is to increase the compression ratio (actually the BMEP for you purists) and this can not be done without taking wrenches to the engine. Thus as long as the fuel used has adequate resistance to detonation, no power is lost (or gained) by just changing the octane of the fuel. The occasional use of 100LL with mostly unleaded car gas will certainly not hurt the engine. Most who have the autofuel STC and do any serious X-C work in their planes find that usually you have autofuel at home and 100LL on the road. There are a few places which have (and advertise) autofuel, but the 100LL only FBOs out number those who will sell autofuel many times over. I have felt that until we have materials which are intended from the factory to use unleaded, that the odd dose of 100LL probably *HELPS* provide some lubrication to the valve seats and stems. Bob Steward, A&P IA AA-1B N8978L AA-5A N1976L ________________________________________________________________________________
Date: May 28, 1998
<< Seriously considering retrofitting a NAV AID wing leveler into my RV-6A - flying. Can this unit be fitted under the seats and connected to the aileron push tubes, or must it be installed internally in the wing? The later would be very impractical in a completed plane, but just might be possible under the seats. Any experience out there? >> Lots. It fits fine under the pax seat. The RV-6 instructions they provided worked swell, no axis cross coupling at all. I wouldn't be without it on a long x-country. GPS tracking is great. -GV ________________________________________________________________________________
Subject: Re: 6A tail tie down
Date: May 30, 1998
It needs to be if you are going to do any short field flapless landings, stalling it on is almost certain to touch the tie down ring before the mains and the ring won't like it ! Brian ---------- > From: Bob Skinner <bskinr(at)trib.com> > To: rv-list(at)matronics.com > Subject: RV-List: 6A tail tie down > Date: Saturday, May 30, 1998 12:42 PM > > > Can someone tell me which drawing has the info on mounting the tail tie > down weldment for the 6A? I couldn't find anything on mounting or > positioning in Charlie's plans. I assume that it is installed with > nutplates so it can be easliy replaced if damaged due to over rotation, etc. > Thanks, > > Bob Skinner RV-6 415 hrs. Buffalo, WY bskinr(at)trib.com > > > > ________________________________________________________________________________
Date: May 30, 1998
I designed my own tie down, that can not be bent over or hook onto anything. Its simple. Cecil Hatfield Thousand Oaks, California > >It needs to be if you are going to do any short field flapless >landings, >stalling it on is almost certain to touch the tie down ring before the >mains and the ring won't like it ! Brian > >---------- >> From: Bob Skinner <bskinr(at)trib.com> >> To: rv-list(at)matronics.com >> Subject: RV-List: 6A tail tie down >> Date: Saturday, May 30, 1998 12:42 PM >> >> >> Can someone tell me which drawing has the info on mounting the >tail tie >> down weldment for the 6A? I couldn't find anything on mounting or >> positioning in Charlie's plans. I assume that it is installed with >> nutplates so it can be easliy replaced if damaged due to over >rotation, >etc. >> Thanks, >> >> Bob Skinner RV-6 415 hrs. Buffalo, WY bskinr(at)trib.com ________________________________________________________________________________
Date: May 30, 1998
Jon I really don't think you have offended anyone. We are all waiting to get word about what happened. In the mean time we want to here something. I really suspect the airplane may have got a workout more than what it was capable of. I wouldn't say that publicly on the list because I may be 180 degrees out. I'll just have to wait and see like every one else. Best wishes, Phil Sisson at Litchfield, Ill. RV6 getting ready to start jigging the fuselage. Jon Elford wrote: > > Listers, > > I publicly apologize for any offense generated by my inquiry into the > RV8 > crash. I know this is a difficult and trying time, but was only > curious if > anyone had heard anything. I deeply respect Van's integrity and > truthfulness and have no doubts as to whether we will be told the > bottom-line as far as this issue goes. Please, if I offended you, I'm > sorry. > > Regards, > Jon Elford > RV6 #25201 > Banks, OR > Wing skeletons.... > Almost ready to jig. > ________________________________________________________________________________
Date: May 30, 1998
I made the same mistake on one of the elevators for my RV8 and I just drilled out the rivets (about 12-15) so that I could get the hand squeezer in there to squeeze the rivets on the horn. It is not that difficult and the result looks great. I feel a lot more confident about the structural integrity this way than using cherry rivets on such an important component. Gary RV8 80352, tail complete awaiting QB kit Carlsbad, CA -----Original Message----- From: Moe Colontonio <moejoe(at)bellatlantic.net> Date: Friday, May 29, 1998 9:18 AM Subject: Re: RV-List: Cherry Rivet application > >Check the archives. Someone else made this mistake not too long ago. I >believe they were told not to use "pop" rivets here, and it turned out they >only had to drill out a few solid rivets to get in there and buck the horn. > >Moe > > >> >>I have made my first big opps! Building the elevator last night, I forgot >to >>rivet the control arm first and will be forced to use structural blind >>rivets. >> ________________________________________________________________________________
Date: May 30, 1998
Subject: RV-8 N801RV Photos
If interested, I have added photos of my completed RV-8 to my web site. FAA inspection is scheduled for this week. http://members.aol.com/lousmith/rv.html Louis Smith RV-8 N801RV 80126 Rocky Mount, NC ________________________________________________________________________________
From: "Ronald Blum" <fly-in-home(at)worldnet.att.net>
Date: May 30, 1998
When using auto fuel in aircraft, remember the octane rating of auto and aviation fuels are calculated by different methods. The auto fuel rating must be lowered by approximately 4-6 to arrive at the aviation fuel rating (ie 86 octane auto fuel is about equivalent in octane to 80 octane aviation fuel. As a little background, I worked for the EAA Aviation Foundation at the Kermit Weeks Flight Research Center (Oshkosh) on the auto fuel program. The EAA auto fuel STC and information should explain this difference in octane ratings and provides a quick and easy method to test for alcohol in the fuel. FLY-IN-HOME(at)worldnet.att.net Ron -----Original Message----- From: Unistar Computers <unistar(at)mindspring.com> Date: Saturday, May 30, 1998 3:42 AM Subject: Re: RV-List: General Question: Autogas in Lyc > >> I was in Edmonton, Canada (Villeneuve) last week, and got a >>chance to fly a rental (C-172) with an instructor in the local area. >>When checking the sumps, lo and behold the gas was yellow! When I >>asked, he said they run on Autogas mostly. He indicated that they will >>run three or four tanks of Autogas, and then fill it up with a tank of >>100LL, the idea being that the engine is o.k. when fed only an >>occasional dose of leaded fuel to keep the valves and stuff happy. >> >> I'd like to hear some opinions on that. I'd also like to hear >>some opinions as to what happens to rated HP when running with the lower >>octane number - does it drop noticeably? That is my guess. >> Keith Jensen > >Does the power go *UP* as you increase your fuel's octane with no other >changes? > >NO. The octane is the measure of resistance to ignition from heat and >pressure. If the engine (C-172, must have been O-300 Cont. on a really old >one, or a O-320 Lycoming on a newer one) was designed to use "80/87" Octane >avgas then 87+ Octane auto fuel has been shown to be adequate. (The O-320 >H2AD is a high compression engine and needs more than "80 Octane" fuel to >run correctly.) Since we used to have "91-96 Octane" avgas back 30+ years >ago there are quite a few engines which can run 91-93 Octane car gas with >no ill effects. > >Some have speculated that auto fuel may have more heat energy / gallon than >Avgas, and so might provide more HP. I can't confirm this, but the true >issue of "rated horsepower" is purely a function of the energy of the fuel >and its resistance to detonation. Thus if you use "premium" in your car >which was designed for 87 octane you can't see any performance increase. >(Much to the chargrin of the high school crowd who buy "hi-test" with the >idea of gettting a few more ponies out of the old man's Chevy.) > >The only way to liberate more power from higher octane fuel is to increase >the compression ratio (actually the BMEP for you purists) and this can not >be done without taking wrenches to the engine. Thus as long as the fuel >used has adequate resistance to detonation, no power is lost (or gained) by >just changing the octane of the fuel. > >The occasional use of 100LL with mostly unleaded car gas will certainly not >hurt the engine. Most who have the autofuel STC and do any serious X-C >work in their planes find that usually you have autofuel at home and 100LL >on the road. There are a few places which have (and advertise) autofuel, >but the 100LL only FBOs out number those who will sell autofuel many times >over. > >I have felt that until we have materials which are intended from the >factory to use unleaded, that the odd dose of 100LL probably *HELPS* >provide some lubrication to the valve seats and stems. > > >Bob Steward, A&P IA >AA-1B N8978L >AA-5A N1976L > > > > > ________________________________________________________________________________
Date: May 30, 1998
> The danger with mogas is in the engine stopping or losing power when you >want it most. The biggest problem is the >reduced Ried's Vapour Pressure or more simply (correct me if I'm wrong) >Boiling temperature of mogas. Brian, I think you have this backwards. The lower the vapor pressure or RVP the less vapors or emissions it will give off. Autogas normally has a higher or increased RVP than Avgas. Regards, Tom Velvick Phoenix, AZ rv-6a psyching myself to prime both fuel tanks ________________________________________________________________________________
Date: May 30, 1998
Subject: RV-8 In-flight Breakup
Folks: I was brousing and stumbled on this. Using search engines, I could find nothing more. I have not been on the list for some time and am waiting for Majordomo to kick back in, so would appreciate a direct copy of any replies. Thanks. Ken Smith, Jr. kpsmith(at)ais.net **** 05/27/98 Preliminary Accident/Incident Data Record RECORD 1 **** A. Type: Accident Mid Air:N Missing:N Entry date: 05/26/98 From: WESTERN PACIFIC REGION OPERATIONS CENTER B. Reg.No.: 58RV M/M: EXP Desc: EXP: VANS RV-8 Activity: Pleasure Phase: Unknown GA-A/C: General Aviation Descr: ACFT CRASHED DUE TO IN-FLIGHT BREAK UP, THE 2 POB SUFFERED FATAL INJURIES, THE ACFT WAS DESTROYED, RIPLEY, CA. WX: METAR KBLH 241350Z 00000KT 40SM SKC 20/09 A2988 Damage: Destroyed C2. Injury Data: # Crew: 1 Fat: 1 Ser: 0 Min: 0 Unk: # Pass: 1 Fat: 1 Ser: 0 Min: 0 Unk: # Grnd: Fat: 0 Ser: 0 Min: 0 UNK: D. Location City: RIPLEY State: CA E. Occ Date: 05/24/98 Time: 14:00 F. Invest Coverage. IIC: KAPPA Reg/DO: WP21 DO CTY: RIVERSIDE DO State: CA Others: NTSB (CRISPIN) G. Flt Handling. Dep Pt: UNKN Dep Date: / / Time: Dest: UNKN Last Radio Cont: UNKN Flt Plan: UNK Last Clearance: UNKN WX Briefing: Other: AAI IIC: ________________________________________________________________________________
Date: May 30, 1998
It seems to me that on a 6A, that the rudder hits before the ring. Does anyone have experience hitting A's on hard surfaces and skinning the FG tip? Bernie Kerr, 6A fuselage, SE Fla. ________________________________________________________________________________
Date: May 30, 1998
Subject: Re: Flying
From: Department of Encouragement Re: She is going to LOVE your new airplane There are several reasons we build. No, wait. There MANY reasons we build. Every construction crew has it's own many and varied reasons. Some of mine were to have a REALLY cool looking airplane that went fast and went slow, that you could go up of a Tuesday morning and feel a tight G turn pull on your face, land at an unimproved strip in Idaho without much worry, attract a crowd at the pumps. And one you could travel in. Travel in. We went on our first RV cross-country last week and had a BLAST! We had some friends that were going to Arizona and wanted us to meet them there. They would be going in the conventional way, for the week, and, as we only had three days off, the only way we could be there was to fly. In the RV. (YES!!!!) And it was all Kelli's idea. OK, now, I must admit, I was a little apprehensive: this would be our first RV cross-country and from Denver, there are some hills to climb before desert appears in the canopy. I was thinking, maybe we should go somewhere not so far away for a first trip, maybe. Flatter, maybe, just as a test. But this trip would be a great one and to a place we had never been. And why not? What an opportunity. We packed light and were ready to go Sunday night. This would be the biggest load the airplane had carried. And over a few hills, did I mention? Monday was good weather but with 35+ knot winds in the mountains. Driving a Model T over a plowed field would not be a good introduction to cross-country. The wind was above my personal limits for mountain winds anyway. We stayed home. I worked on the airplane. (What? You mean it isn't done yet?) Tuesday was Weather Fantastic and we had an early morning departure. The airplane flew like it ever did, even with the weight (WELL within the weight and balance limits). Trim was not much more forward than passenger-usual. Climbed a little slower, but have you seen the Cessnas climb, loaded for vacation? The first pass through the Rocky Mountains was less than an hour from home: the first real test, real soon. Now, I am a talker. I like to talk my passenger through anything that may not be familiar and slipping through a mountain pass with snow-covered 14,000+ foot peaks on either side needed a little chat. "OK, we will get a little up air here.....well, here, ah, there it is. Now we will get in a little downdraft here and, now, maybe a little bump about here. We are going at this pass at a 45 degree angle so we have a way out if we hit some down air. We would turn off to the left, over there. See the other side of the pass? No problem with this one. Might be a little bit of a ride through here." The view of the Rocky Mountains from the lofty perch of the -4 was out of this world. We slipped through at 13,500 (for a brief period) without a hitch. Wasn't even that bumpy and the up/down did exactly what we expected. And what an airplane: there we were at 13,500 feet, near but not at gross and still had a bunch of climb left. The next pass was lower, but by then we were old hands at slipping through mountain passes. I have a lot of mountain time in the Cub; this airplane is going to be different. I still give The Rocks a lot of respect. Did I mention the view? OK, I don't care for towers. I mean airport control towers. No reason, really, just cuz. They make me nervous, like a cop car following you. Most of the cross-country I do in the Cub is done without their "permission to land". Farmington, New Mexico has a tower. "Farmingtown tower, 232 Suzie Q, five miles east with Juliet, landing Farmington." Nothing. Talking to other folks, not me. "....232 Suzie Q four miles east..." Nothing. Oh, great. Could they not hear me? I've never had problems before. Maybe....oh, OK, I can play. "...232 Serria Quebec, four east..." Now they hear me. First time I have had problems with using Suzie Q as a call sign. Sticks-in-the-mud. Maybe they were just busy. Maybe. I hope. Didn't sound like it. They had no problem with me outbound, Sierra Quebec-ing all the way. Don't like towers. I am not supposed to tell where we landed in Arizona because Kelli wants it to be a secret. I will tell you the scenery is beyond description and you have to land on an aircraft carrier. Sort of. Our friends were waiting for us at the airport and just couldn't get over the fact we had left Denver at 6 am and were in Arizona at 9 in the morning (time change). It had taken them two days to get there. They were also pretty excited about us dropping out of the sky in the airplane we built ourselves ("You looked SO COOL coming in!!"). Lots of great photos. I need to tell a story on Kelli. She was in the back seat absolutely enthralled with it all, taking photos like Ansel Adams' niece and amazed with the visiblity and where we were. We were getting into some light rain and flying below an arch in the clouds, bumping along and I'm watching, throttling back to protect the prop, looking at the clouds, getting kind of dark and !!FLASH!!OHMANLIGHTNING!WASTHATLIGHTNING?WHEREWASTHAT?I DID'T SEE ANY BEFORE THAT and I hear over the intercom michael that was the flash the flash on the camera went off and I'm sorry I did't think it would I'm sorry. Hey, I'll take the flash any day! No problem. Flash, yes; lightening, no. REALLY looked like lightning. MAN, was there a lot of smoke/smog from the Mexican fires on the way back. Visibility was about 10 miles max. Pretty unusual for this part of the country. This airplane has such grand visibility, it was disappointing not be able to use it. Going: just under four hours, about 140-160 knots, GPS. Coming back: just over three hours about 180-210 knots. Love those westerly winds, going with them. We left Tuesday, came back the next day and it was like being gone a week. What an airplane. Goes fast, goes slow, travels. Travels well. And Kelli had a ball. She is a great Back Seat Girl. (PIB: Princess In Back). When we got back to town, she hit the bookstore and bought a sack full of travel books. We are making a list. Did I mention what a great PIB I have? Did I mention you are going to love this airplane? Did I mention SHE is going to love this airplane? Michael RV-4 N232 Suzie Q (except in Farmington) Greatly Expanding the Boundaries ________________________________________________________________________________
Date: May 29, 1998
Yes ... I helped repair a RV6A that suffered this. The tie down ring did bend upwards, but could be essentially straightened. Since it's stainless, it deforms fairly easily. It was adifferent story at the rudder FG lower fairing though. The fairing was scraped and damaged, but it ends up the the FG fairing is stronger than the 0.016 alum. skin of the rudder. This caused the upward loads of impact to buckle the aft edge of the rudder a few inches above the lower fairing. Structurally, the damage was not bad, and the plane flew for a while like that, however the fix was to construct a new rudder. Someone else built the rudder, I just got the upper fairing glass work to match the exising vert. stab. (added about 3/16 to the top), painted it and fitted it. The old tie down ring was re-used. On the other thread... I fabricated a 0.032 plate that sits on the inside of the rear most bulkhead. All of the bolts that pass through this bulkhead to hold on the vert. stab. spar and tie down fit into floating nutplates. This _will_ make final installation of the vert. stab. _much_ easier. If you don't do this, then you have to work through the small side access hole to tighten these bolts. this plate can be installed through the 5 inch hole in the F-614 and passed aft to the rear bulkhead loaction. ... hope this helps ... Gil (I helped fix one) Alexander > >It seems to me that on a 6A, that the rudder hits before the ring. Does anyone >have experience hitting A's on hard surfaces and skinning the FG tip? > >Bernie Kerr, 6A fuselage, SE Fla. RV6A, #20701, finishing kit "REPLY" sends to entire RV-list Newsletter Editors: Permission given to re-print if credit is given and a courtesy copy is sent to me. ________________________________________________________________________________
Date: May 30, 1998
Subject: Re: RV8 Crash
Ditto X 10 Dave Funk Building elevators RV-6 ________________________________________________________________________________
Subject: pressure carb
Date: May 29, 1998
I have had problems from the start with my normally aspirated O-320 quitting when the G load dropped below 1. At SNF I bought a Stromberg pressure carb. It appears to have the rebuilt red diaphram. Does anyone have experience in testing and installing one of these? They originally fit the O-360 and some continental 470's I believe. kevin 6A 160 hrs! ________________________________________________________________________________
Subject: Glide Ratio
Date: May 30, 1998
With all the talk about aircraft vs auto engines (and fuel) reliability etc, I have an somewhat related (I hope) question... How well does an RV glide?? Tim Friendshuh St Paul MN (considering an RV8) ________________________________________________________________________________
Date: May 30, 1998
info on mounting the tail tie down weldment for the 6A? > >Bob Skinner RV-6 415 hrs. Buffalo, WY bskinr(at)trib.com > Bob: My "old" instructions have numbers in SK 62 & ref Drg 34. Drwg 34 shows only a 6. My new plans are at home. You splice on the .063 angle worked great.!!! Don Jordan ~ 76DJ ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com ________________________________________________________________________________
From: "Leslie B. Williams" <lesliebwilliams(at)email.msn.com>
Date: May 30, 1998
My experience is that the tie down ring will hit first. Les Williams/RV-6AQ/Tacoma WA > >It seems to me that on a 6A, that the rudder hits before the ring. Does anyone >have experience hitting A's on hard surfaces and skinning the FG tip? > >Bernie Kerr, 6A fuselage, SE Fla. ________________________________________________________________________________
Date: May 30, 1998
> I touched the tail of Van's red RV-6B and bent it a bit, and also did the same > once on my RV-6A. The ring bent a bit, and I replaced it. I would not use nut > plates; not strong enough. Use bolts per plans. You need a long wrench and some > choice words to reach the nuts (remove the fairing) but it can be done. An > inspection mirror and flashlight help. The best solution I found was just to learn to land the darn thing properly! (It took a while for me!) ________________________________________________________________________________
Date: May 30, 1998
Subject: Re: Glide Ratio
<> I believe that Van has shown it to be 10 to 1. Joel Mclaughlin -6 Wings NC ________________________________________________________________________________
Date: May 30, 1998
wankers ________________________________________________________________________________
Date: May 30, 1998
Subject: Re: RV-6/6A OAT probe location
youll never fly friction man ________________________________________________________________________________
Date: May 30, 1998
The best thing about mogas is the excellent quality control, no go fly that night xc. ________________________________________________________________________________
Date: May 30, 1998
Subject: Re: Vacuum Instruments
rvs are really comfortable in instrument conditions ________________________________________________________________________________
Date: May 30, 1998
lets add more systems to something simple ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Date: May 30, 1998
-----Original Message----- From: Kerrjb(at)aol.com <Kerrjb(at)aol.com> Date: Saturday, May 30, 1998 10:54 AM Subject: Re: RV-List: 6A tail tie down > >It seems to me that on a 6A, that the rudder hits before the ring. Does anyone >have experience hitting A's on hard surfaces and skinning the FG tip? > >Bernie Kerr, 6A fuselage, SE Fla. > There is a 6A from Kansas that is at OSH every year with triangular gusseted plate on the tail for a combination tiedown and tail skid. It is about a foot long and looks like a 30/60 triangle with perpendicular short leg of about 6 inches. The builder put it on after an over rotation episode. I have been seriously considering such a modification since it is clear that the 6 has excessive elevator authority in take off and landing. After 2200 hours of yoke-in-lap landings in my C-172 ( I do not fly it on!) I'm concerned I'm going to prang my 6A! Dennis Persyk 6A canopy Barrington, IL ________________________________________________________________________________
From: "Luker, Michael G." <luker.michael(at)mayo.edu>
Subject: Aileron Flutter
Date: May 30, 1998
Has anyone experienced aileron flutter while doing a roll in an RV6A. Is Aileron flutter in the 6A during rolls common? ________________________________________________________________________________
Subject: Avgas in General
Date: May 31, 1998
Hello I have a friend who runs mogas in his Tailwind, he recently had quite a scare when his little 100 horse monster just stopped at 50ft AGL on take off. After draining the tank and lines he made it safely home with samples of the offending fuel in the baggage. He asked me to have look at the fuel as he had not seen anything like it before, When we poured the fuel into a small bucket it looked a bit cloudy however when we blew on top of the sample it became very cloudy. After some more technical testing was completed we found that the gentleman at the local gas stop had more than a little bit of water in one of his tanks, so he just put some alcohol in to get rid of it. My point is, There are many reasons why I worry about the use of mogas in aircraft, most have been discussed already R.V.P. (F.V.I. index) would be the main one. However nobody has said anything about quality control, this is one of the reason why avgas is more expensive than mogas, the guy at the local pump mite not have tampered with the fuel he was selling if he knew where it was going. (And understood the gravity of it) Yes, I know lots of aircraft run on mogas very well, But just beware! you really do get what you pay for. Trevor Mills RV 80605 ________________________________________________________________________________
Date: May 30, 1998
<< I publicly apologize for any offense generated by my inquiry into the RV8 crash. I know this is a difficult and trying time, but was only curious if anyone had heard anything. I deeply respect Van's integrity and truthfulness and have no doubts as to whether we will be told the bottom-line as far as this issue goes. Please, if I offended you, I'm sorry. Regards, Jon Elford RV6 #25201 Banks, OR Wing skeletons.... Almost ready to jig. >> Jon, I think this time its not you who owes the public appology but me. My attack on you wasnt nice or fair. I met John Morgan last year at the Burlington Co. flyin and we all sat around a room one night having a few beers and swapping flying stories. I thought he was a top notch guy. I have lost several friends in RVs for one reason or another and I cant help but get angry when people speculate what happened with no solid information to work with. My comment about Phil Hartman was a good example of what happens when people specutlate or believe rummors. At the time I wrote the post they had said he shot himself. The next morning it changed to his wife doing the killing. But who really knows at this point. At any rate Jon you have my personal appology. Ryan Bendure Co. ________________________________________________________________________________
Date: May 30, 1998
<< Jon, Curious as to where on the lower wing skin you are mounting this inlet? Any possibility you might pick up engine exhaust through this "fresh air duct", or is it located far enough out on the wing to avoid exhaust flow? Mike Wills RV-4 fuse willsm(at)manta.nosc.mil >> Mike: The RV-8 drawings now show the rear seat fresh air NACA inlet installed in the lower right wing just ouside the wingwalk area doubler ... that is, the next bay out. Most builders are simply using pro-seal to attach the inlet to the skin. It's a bit more difficult to do if your wing is complete, but it can be done. I'm quite sure that this will avoid exaust flow and engine cooling exit air, offering accurate OAT readings. Jon Ross RV-80094 - Skinning fuselage ________________________________________________________________________________
Date: May 30, 1998
cecilth(at)Juno.com wrote: > > > I designed my own tie down, that can not be bent over or hook onto > anything. Its simple. > > Cecil Hatfield > Thousand Oaks, California > Hey Cecil ole buddy ole pal, would you share your design with us???? Jerry Calvert Edmond Ok -6a ________________________________________________________________________________
Date: May 30, 1998
Gee, why is it that I get the idea that the RV-6A bangs it's tail a lot? Is this true or am I detecting some bad landings caused by some overzealous handling (showing off)? Since I've never banged the tail of my airplanes during landings, I'm wondering if there is something about the -6A that makes this an easier happening. Showing off does not count, fellas. :-) I have installed the Orndorff tie down ring. I hope this will tie down the airplane OK. I'm hoping I can keep the tail off the ground during my landings, even if I do show off a bit. Jim Sears in KY RV-6A N198JS (Working on canopy) AA-5A N26276 ________________________________________________________________________________
Date: May 30, 1998
<< Fuel BOILS IN THE CARBY, carby float is now heavier than the bubbling fuel and sinks to the bottom. >> Elimination of the CARBY seems to be the logical way to handle this situation. Jim Nice RV6A WA State ________________________________________________________________________________
Date: May 30, 1998
Dennis Persyk wrote: > > > -----Original Message----- > From: Kerrjb(at)aol.com <Kerrjb(at)aol.com> > To: rv-list(at)matronics.com > Date: Saturday, May 30, 1998 10:54 AM > Subject: Re: RV-List: 6A tail tie down > > > > >It seems to me that on a 6A, that the rudder hits before the ring. Does > anyone > >have experience hitting A's on hard surfaces and skinning the FG tip? > > > >Bernie Kerr, 6A fuselage, SE Fla. > > > There is a 6A from Kansas that is at OSH every year with triangular gusseted > plate on the tail for a combination tiedown and tail skid. It is about a > foot long and looks like a 30/60 triangle with perpendicular short leg of > about 6 inches. The builder put it on after an over rotation episode. > I have been seriously considering such a modification since it is clear that > the 6 has excessive elevator authority in take off and landing. After 2200 > hours of yoke-in-lap landings in my C-172 ( I do not fly it on!) I'm > concerned I'm going to prang my 6A! > > Dennis Persyk 6A canopy > Barrington, IL > Dennis, We commonly do very full stall landings in the RV6A and there is really no reason to drag the tail. This is normally caused by over controlling which is very easy to avoid.The same goes for soft field type takeoffs. Many students drug the tail in cessna 150s too but that certainly is not neccesary. Michael Seager CFI I do the pilot check out in the RV6 and RV6A For Vans rv6cfi(at)vernonia.com 503 429 5103 ________________________________________________________________________________
Subject: Inspection Protocol
Date: May 30, 1998
Listers, The pink panther is due for her annual physical. My A&P wondered if anyone had an inspection protocol for a -4. Send it directly to me at the address below if you wish to save bandwidth. Thanks in advance. Tailwinds, Doug Rozendaal dougr(at)petroblend.com (my old netins.net is no longer valid) www.petroblend.com/dougr ________________________________________________________________________________
Subject: Re: Aileron Flutter
Date: May 30, 1998
> >Has anyone experienced aileron flutter while doing a roll in an RV6A. >Is Aileron flutter in the 6A during rolls common? > Michael, What you are experiencing is not flutter. If it was, most likely you wouldn't be telling about it. What is however, common in RV's, is a little buffet in the ailerons at full deflection. This is caused by some stalling of the aileron. It should only occur at full or nearly full deflection and at fairly high speeds. If this is what you are experiencing, worry not, it is normal. If you find this annoying there is a solution, The Extra 300L for about $300,000 does not do that at all...... or just back off on the aileron deflection slightly. Tailwinds, Doug Rozendaal dougr(at)petroblend.com www.petroblend.com/dougr ________________________________________________________________________________
Date: May 30, 1998
>How well does an RV glide?? > > >Tim Friendshuh >St Paul MN >(considering an RV8) Tim, The short answer is better than almost anything that was built in wichita or florida. The long answer would depend on your airplane. If you search the archives you will find a thread about glide ratio vs propellor type. The point is the glide ratio of the RV depends greatly on the type and pitch of propellor installed. I apoligize that I don't have the exact name of the thread it was some time ago and I don't have the name of it. Tailwinds from MCW, Doug Rozendaal, -4 the pink panther dougr(at)petroblend.com www.petroblend.com/dougr ________________________________________________________________________________
Date: May 30, 1998
Subject: RV Upholstery Products/Seats
RV Builders I have been in the upholstery business for 26 years and have been making upholstery products for kitplanes for 14 years. I have interior kits available for RV-4, RV-6, RV-6a, and RV-8. I also have cabin covers and other items. I am the supplier of upholstery products for several kitplane manufacturers. A list of other kitplane interior products available upon request. For more information, call Knight Aircraft Interiors, Inc., at (208) 342-2602 or e-mail me at cknight(at)rmci.net. Photos available upon request. Sincerely, KNIGHT AIRCRAFT INTERIORS, INC. "Fly by Knight" Upholstery Products Sam Knight ________________________________________________________________________________
Date: May 30, 1998
> Can someone tell me which drawing has the info on mounting the tail tie > down weldment for the 6A? I couldn't find anything on mounting or > positioning in Charlie's plans. I assume that it is installed with > nutplates so it can be easliy replaced if damaged due to over rotation, etc. If I remember correctly, it doesn't show anywhere on the plans. There is a small detail sheet on one of the "SK" drawings in the construction manual. Ed Bundy RV6A - Eagle, ID - first flight 11/20/96 ebundy@bigskytel.com - http://bigskytel.com/~ebundy/ ________________________________________________________________________________
Date: May 30, 1998
Subject: Re: Flying
>I am not supposed to tell where we landed in Arizona because Kelli wants it >to be a secret. I will tell you the scenery is beyond description and you >have to land on an aircraft carrier. Sort of. Ah, that's easy. You landed on the USS Sedona ;-) Best Regards, Dave Barnhart rv-6 sn 23744 N601DB Flying ________________________________________________________________________________
Date: May 30, 1998
Subject: Re: N30YD flies
Fellow listers: Wednesday, after an all-day inspection with no squawks (except that my whiskey compass deflects a bit as the joystick is swung around - got to degauss that thing!), the FAA man said N30YD was an airplane. Two days later, after high speed taxi tests, brakes groaning on one side (perhaps another case of bogus springs? I haven't looked yet...) and with my friend flying parallel to the 7000 ft runway in his Maule, I opened the throttle and off we (the plane and I) went. No unexpected moves, no bad manners. She flew like she had been waiting 4 years for this moment, and indeed she had. Well, 3 yrs, 11 months and 29 days, but who's counting?! Sometime during the 45 minute first flight, which included the traditional climbs, descents, slow flight, stalls, and gentle turns, but nothing over 135 mph indicated,my nemesis in the Maule said, "Hey, I'm keeping up with you!" "Enjoy it!" was my reply, as I realized that for the first time, the RV grin was about to overspread my face. "Yeah," he radioed back. "Guess it won't last long..." Well, enough of that. I just want to add my voice of encouragement to those who are still banging rivets as I was just a few weeks ago. They are all correct when "they" say, "Keep building, it's worth it!" Remember, the usual congratulatory messages should be sent to me, not to the list. The archives are already too full of that sort of thing... Thanks. Bill Boyd RV-6A Clifton Forge, VA SportAV8R(at)aol.com ________________________________________________________________________________
Date: May 30, 1998
Jim, To the best of my knowledge, I never caused the tie down ring to hit by over- controlling during flight. What did happen was that I taxied a little too fast over a bump at the edge of the tarmac when parking at a fly-in. The nose bounced up causing the tail to come down hard enough to bend the tie down ring back and also bend the tail cone skin a bit where it extended beyond the F-612 flange. I would say that you would have to be intentionally hot-dogging quite a bit or else be pretty heavy handed to accidentally over-rotate enough to drag the tail. I've seen it done more than once by some pilots that I would put in the latter category. Having a light engine/prop combination up front like I did could contribute to this being easier to do, but an average pilot such as myself should not have any difficulty with this IMO. Les Williams/RV-6AQ/Tacoma WA > >Gee, why is it that I get the idea that the RV-6A bangs it's tail a lot? Is >this true or am I detecting some bad landings caused by some >overzealous handling (showing off)? Since I've never banged the tail >of my airplanes during landings, I'm wondering if there is something >about the -6A that makes this an easier happening. Showing off does >not count, fellas. :-) > >I have installed the Orndorff tie down ring. I hope this will tie down the >airplane OK. I'm hoping I can keep the tail off the ground during my >landings, even if I do show off a bit. > >Jim Sears in KY >RV-6A N198JS (Working on canopy) >AA-5A N26276 ________________________________________________________________________________
Date: May 30, 1998
Subject: 6 Slider Tip
A week or so ago, someone was commenting on how many of the little aft hold down blocks they went through, trying to get them drilled properly. I suspect the lack of adjustability has something to do with it. If one shims below the U shaped aluminum cradle before drilling the hole for the canopy pins, then adding/subtracting the shims will allow for vertical adjustment. Similarly, if one makes the plastic block narrower than the aluminum, the lateral position can be shimmed by moving the plastic within the U. Alex Peterson Maple Grove, MN 6A ________________________________________________________________________________
Date: May 29, 1998
> Seriously considering retrofitting a NAV AID wing leveler into my RV-6A > - flying. Can this unit be fitted under the seats and connected to the > aileron push tubes, or must it be installed internally in the wing? mine just barely fit under the seat. by bending the push tube I was able to get the free play needed at all stick positions. Cut the sides off the cover so that you can remove the cover without removing the entire unit. kevin 6A 160hrs since Oct! ________________________________________________________________________________
Date: May 30, 1998
<< It seems to me that on a 6A, that the rudder hits before the ring. Does anyone have experience hitting A's on hard surfaces and skinning the FG tip? >> The ring hits first. -GV ________________________________________________________________________________
Date: May 30, 1998
Fellow RVers, I didn't mean to open a can of worms (or start a thread similar to primer). I don't know how easy it is to hit the tail tie down on a RV6A. I have seen several with bent rings which started me thinking on ways to deal with the problem before it occurs. If the tie down ring is attached with nutplate, removing the rudder would enable one to easily replace Van's weldment. I would hope that the ring would protect the rudder bottom but I'm not sure that this is the case. I've been thinking along the lines of a tie down/skid similar to the Cherokees, a streamlined skid with a hole in it for tie down rope. A piece of 1/4" plate could be sandwiched between two angles so if the plate were damaged it could be easily replaced. The curvature of the tail cone makes mounting the angles a little tricky but I think it can be done. I was thinking of riveting to the skin and spanning the two bulkheads and tying into them, as well. I know the guy that I'm helping, "Gillette Charlie", is going to fly with Mike Seager. In fact, I think he may have already flown with Mike at a Longmont fly in a year or two ago. I know Charlie hit the skid when he rotated for take off and whoever he was flying with indicated that tail-hits happen sometimes. I imagine that by the time Mike gets done with Charlie that his tail bump days will be over so maybe there is not much to worry about. However, if a guy can come up with an idea that protects the rudder and can be easily replaced if damaged, it seems like a good idea. Of course, I have the ideal tail skid/protector. It's called a tailwheel:) Bob Skinner RV-6 415 hrs. Buffalo, WY bskinr(at)trib.com ________________________________________________________________________________
Subject: TAS formula
Date: May 30, 1998
I have a question regarding the 3-leg gps formula. Let's say the wind is directly out of the West (270). Now if you fly one leg at 0, and one leg at 180 your ground speed for both of those legs will be the same. So wouldn't your third leg (and the result of the formula) be radically different depending on whether you flew it at 270 or 90? I'm sure I'm missing something ridiculously simple here, but I can't see it. Thanks, Ed Bundy RV6A - Eagle, ID - first flight 11/20/96 ebundy@bigskytel.com - http://bigskytel.com/~ebundy/ ________________________________________________________________________________
Date: May 31, 1998
I wont argue Tom as I think your right, the important thing is autogas BOILS at a lower temperature or higher pressure for a given temperature. So next time you hear of a loss of power on take off, and some one says it can't have been due to autogas because it was pouring black smoke out, and it should have been lean not rich if it was vapour lock due to autogas. At least you will know it could have been the autogas. Tried the block of wood yet? Regards, Brian ---------- > From: Thomas Velvick <rver(at)caljet.com> > To: rv-list(at)matronics.com > Subject: Re: RV-List: AVGAS IN GENERAL > Date: Saturday, May 30, 1998 11:13 PM > > > > > The danger with mogas is in the engine stopping or losing power when you > >want it most. The biggest problem is the > >reduced Ried's Vapour Pressure or more simply (correct me if I'm wrong) > >Boiling temperature of mogas. > > Brian, I think you have this backwards. The lower the vapor pressure or > RVP the less vapors or emissions it will give off. Autogas normally has a > higher or increased RVP than Avgas. > > Regards, > Tom Velvick > Phoenix, AZ > rv-6a psyching myself to prime both fuel tanks > > > he rear most bulkhead. All of the bolts that pass through this > bulkhead to hold on the vert. stab. spar and tie down fit into floating > nutplates. This _will_ make final installation of the vert. stab. _much_ > easier. If you don't do this, then you have to work through the small side > access hole to tighten these bolts. this plate can be installed through > the 5 inch hole in the F-614 and passed aft to the rear bulkhead loaction. > > > ... hope this helps ... Gil (I helped fix one) Alexander > > > > > >It seems to me that on a 6A, that the rudder hits before the ring. Does > anyone > >have experience hitting A's on hard surfaces and skinning the FG tip? > > > >Bernie Kerr, 6A fuselage, SE Fla. > > RV6A, #20701, finishing kit > "REPLY" sends to entire RV-list > Newsletter Editors: Permission given to re-print if > credit is given and a courtesy copy is sent to me. > > > ________________________________________________________________________________
Date: May 30, 1998
> If you find this annoying there is a solution, The Extra 300L for about > $300,000 does not do that at all...... or just back off on the aileron > deflection slightly. while you're at it limit the elevator travel and maybe they'll think it's a $300,000 Ercoupe! > ________________________________________________________________________________
Date: May 31, 1998
Eliminate the autogas is cheaper and easier, Jim, after all fuel injection systems like bubbles from vapour lock even less than carbs. Brian ---------- > From: JNice51355(at)aol.com > To: rv-list(at)matronics.com > Subject: Re: RV-List: AVGAS IN GENERAL > Date: Sunday, May 31, 1998 6:24 AM > > > > << Fuel BOILS IN THE CARBY, > carby float is now heavier than the bubbling fuel and sinks to the bottom. >> > Elimination of the CARBY seems to be the logical way to handle this situation. > Jim Nice > RV6A > WA State > > > ________________________________________________________________________________
Date: May 31, 1998
Subject: Re: Flying
I must have been standing too close to my painter when he primed the latest set of parts; I'm now a shade of green. Oh, well, back to the project. PatK - RV-6A Kelli Lewis wrote: > *** Long, gloating post :) snipped *** ________________________________________________________________________________
Subject: Re: Avgas in General
Date: May 31, 1998
>After some more technical testing was completed we found that the >gentleman at the local gas stop had more than a little bit of water in >one of his tanks, so he just put some alcohol in to get rid of it. I've been reading some of this stuff with interest and have made a few comments along the way in the defense of auto gas. As a user of auto gas in my automobiles for many years (about 35), I have yet to have any problems with it, no matter where I got the stuff. At no time have I ever had an auto stop due to poor gas. The fuel filters rarely get dirty enough to change out during the entire time I own the autos, even with over one hundred thousand miles on them. Any time I've ever opened up a carb, the bowl has been clean. I have been using auto gas in my airplanes for twelve years. Again, other than a vapor lock on the ground after quick turn arounds, there have been no problems with the stuff. When I first started using auto gas, I even got the gas from some unusual places when on XC trips. Most of the time, I was using the same gas as that was used in the airports' tractors. I no longer do that; but, I never had the first problem while I was doing it. I figured that gas was pretty fresh. My Cheetah has a tight cowled setup like the RV. I've learned that I must be careful when I do a quick turnaround anywhere. It is more important as the temps start warming up after winter cold. Even then, it's just a minor inconvenience to run the engine up to full power once before takeoff to be sure the gas is flowing. I've read that I should not use autogas above 10K'. Heck, I'm a low level pilot who hates being at 10K'; so, that presents no problems for me. Never do I have lead fouled plugs except when I use a little 100LL on XC trips. All I'm trying to say is that you must to listen to both sides before you decide not to use auto gas. Some who speak against the use of auto gas have never used it in an airplane. Some have only listened to others who've listened to others. I didn't buy a Grumman for several years because I listened to my friends who had nasty tales about them. Well, I'm flying that Grumman today and am enjoying the heck out of it. If the Feds have approved auto gas in aircraft, the insurance companies have given their approvals, airports are now getting in the act, and future avgas will be a blend of autogas, I'm having a problem understanding what the problem is with it. I'd just suggest that you be careful where you buy it, just as you should do for your car. If you do that, you should have few, if any, problems with it. As for comments like not flying XC at night with auto gas, keep in mind that the air temps are cooler then, which is much better for auto gas. That's the kind of false information that I'm talking about that should not be here since it has no facts to back it up. I've flown many an hour at night using pure auto gas for power. I worry about where to land if the engine quits due to mechanical failure more than I think about the gas I'm using. As for the comment above that stemmed from some guy using alcohol to pick up water in his tanks, I still remember some friends of mine who bought some 100LL that looked like it had syrup in it. They almost didn't make it back to the airport on that stuff. How about those times we've read about Jet A being put in the 100LL tanks? Just be careful about where you buy your gas. I get my auto gas around the corner from our airport where I know it has a high volume of sales. It's always clean and fresh. One thing that's seldom mentioned is that cost of auto gas vs the cost of avgas. I save enough money on fuel to pay for my insurance and some of the tie down. Around here, the savings is about $1.12 per gallon. That makes it substantial enough to at least think about it if you fly very much. Jim Sears in KY RV-6A N198JS (Working on the canopy) AA-5A N26276 ________________________________________________________________________________ Delivered-To: fixup-rv-list(at)matronics.com@fixme
Date: May 31, 1998
Subject: RV6A Elevator Travel
I've got my 6A painted and nearly completed. While checking control surfaces travel, I found that I don't have the full prescribed down elevator travel (25 degrees). I only have 18 degrees. The forward flange of the elevator control horn is resting against the control stop in the full down position. Is 18 degrees OK? Is there anything else I can do to increase the down travel. BTW, I do get the full 30 degress up travel. Thanks for your help. Ron Caldwell rlcaldwell(at)uswest.net ________________________________________________________________________________ Delivered-To: fixup-rv-list(at)matronics.com@fixme
Date: May 31, 1998
Subject: Control Stiffness
Just finished hooking up my Control sticks to my airlerons and elevators on my RV6A. Moving the sticks side to side for the airlerons seems rather stiff. I tried my friends 6a controls and they flow much more smoothly and easily. Have I tightened things down to much? Any ideas appreciated? Ron Caldwell rlcaldwell(at)uswest.net ________________________________________________________________________________
<35707275.CEB(at)flash.net>
Date: May 31, 1998
writes: > >cecilth(at)Juno.com wrote: >> Hi Jerry, Sure, Send me info off list as to where to send it. I have photos somewhere I could send. If others want this, I can copy photos. Cecil Hatfield cecilth(at)juno.com Thousand Oaks, CA >> I designed my own tie down, that can not be bent over or hook onto >> anything. Its simple >> Cecil Hatfield >> Thousand Oaks, California >> >Hey Cecil ole buddy ole pal, would you share your design with us???? >Jerry Calvert >Edmond Ok -6a ________________________________________________________________________________
Date: May 31, 1998
From: "Scott A. Jordan" <SAJ_SLJ(at)compuserve.com>
Subject: Aileron Stiffners
RV-8 Short list , RV Tech Support I am completing my -8 aileron and wonder if I should put a dab of RTV at the end of the stiffners as is done on the rudder and elevators. It seems logical that this should be done since it is similar construction & material size, though the controls on the -8 at .020 are heavier than other models and probably less prone to cracking. I can't find anything specifically saying to do or not do this on the ailerons but I am reluctant to change the weight and or balance of a control surface without specifically being told it is OK. Thanks, Scott A. Jordan -8 #331 N733JJ (res) ________________________________________________________________________________
Date: May 31, 1998
Brian Holman wrote: > > >(snip)............... Tried the block of wood > yet? Regards, Brian > Brian: Being the naturally curious sort I am, I would like to try this block of wood in boiling gasoline experiment. Can you tell me how to boil the gas without blowing myself up? I don't think I want to put the gasoline in a pan and boil on my natural gas powered kitchen stove above an open flame :) Also, what type of wood, how big, how much gasoline, etc., etc.? Has anyone else tried this yet? martin shorman ________________________________________________________________________________
Date: May 30, 1998
Jim Sears wrote: > > Gee, why is it that I get the idea that the RV-6A bangs it's tail a lot? Certainly not in my one year experience. > Is > this true or am I detecting some bad landings caused by some > overzealous handling (showing off)? Since I've never banged the tail > of my airplanes during landings, I'm wondering if there is something > about the -6A that makes this an easier happening. Showing off does > not count, fellas. :-) > > I have installed the Orndorff tie down ring. I hope this will tie down the > airplane OK. I'm hoping I can keep the tail off the ground during my > landings, even if I do show off a bit. > I show off a lot but that's another story. My 6A has not hit the tail yet, although I did have a slight scrape during a half flap crosswind landing in about 30K component, when I had about 50 hours experience. This was caused by a too late decision to go around and my inexperience with the pitch angle for landing. That scrape took off the paint but spared the metal, and certainly didn't get near the rudder even though I mounted my rudder/verical stab about an inch lower than plans. At present I have logged about 320 landings in 228 hours and am a lot more consistent. All landings are marvelous. Your ability to hit the tie down ring on landing is controlled by the c of g, the flap setting and the speed at touchdown. On my nose heavy (O 360 with C/S prop) airplane, it is very tough when solo to scrape the tail at any speed or flap setting, but with a heavy passenger it is much easier to wind up with the nose too high in flaring--until you get a good sight picture of what to hold. With mine I would deem that you would have to be brain dead to hit the ring on take off. In any event the ring has to fail first to allow the rudder to strike. My guess is you would need a significant sink rate as well as a high pitch angle to do that. In that case you better look at the main gear too. I would give some very careful thought before adding something stronger as a skid as this may cause the tail cone, or aft fuselage skin to crumple instead of the rudder which could be a far bigger repair job. In conclusion I will repeat again that this is the easiest airplane to land I have ever flown. All of the above is just one man's opinion ________________________________________________________________________________
Date: May 31, 1998
Subject: jon's seat
I have a pic of Jon's seat, now. I don't have a way to post it to a website for everyone to look at, so I have been mailing it out to individuals. If someone can volunteer some website space, I will gladly mail it to you to post, so everyone can see it. Thanks. Michael C. Lott ________________________________________________________________________________
Date: May 31, 1998
If your worried about fuel cost try hang gliding. Want me to quote facts: TCM Aircraft Engine Technical Bulletin #T93-5 ASTM D910 ASTM D-439 ________________________________________________________________________________
Date: May 31, 1998
Subject: Tank attach angle & tank rib.
Working on fuel tank parts, have cut out the T-405, and noticed that the T-shaped "dent" on the T-803 end rib prevents it laying flat against the web. Should I hammer it flat on my anvil, thus warping the rib (already drilled to tank skin), or just try to rivit around it. Also, the ring is interfering with the access plate. Should it just be cut away entirely? Brian Huffaker, DSWL (huffaker(at)utw.com) President and Founder Friends of P-Chan RV-8 80091 Fiddling with fuel tank. ________________________________________________________________________________
Subject: Navaid in RV-8?
Date: May 31, 1998
Listers: Anyone know if the Navaid servo can be installed under the seat in an RV-8, or must the servo be mounted in the wing (probably the right wing). I'm closing my wings up soon and need to know! Retrofitting to a closed wing doesn't sound like fun. Regards, Randy Lervold -8, #80500, wings Vancouver, WA Home Wing - Van's Air Force ________________________________________________________________________________
Date: May 31, 1998
>After some more technical testing was completed we found that the gentleman at the local gas stop had more than a little bit of water in one of his tanks, so he just put some alcohol in to get rid of it. >Trevor Mills >RV 80605 With such extensive test equipment as a mason jar and a magic marker one can test for alcohol in *EVERY* load of fuel. Place a mark on the outside of a mason jar a inch from the bottom. Fill jar to the mark with water from sink in FBO restroom. Add auto fuel to jar, install lid and shake. Allow to seetle for a few minutes, "read" the line. If alcohol is present the fuel and water line will have moved from the mark. If not, then the line will match the fuel/water separation exactly. Relative amounts of alcohol can be measured with a graduated cylinder from any chemistry set if you are interested in the *percentage* of alcohol instead of the yes/no indication. Now, can we get back to RVs? Bob Steward, A&P IA AA-1B N8978L AA-5A N1976L ________________________________________________________________________________
Date: May 30, 1998
Maybe ... but ground loop damage is usually more severe...:^) > >Best fix of all, is put the nose wheel where it belongs......on the >tail....oooh, who said that ? > >---------- >> From: Gil Alexander <gila(at)flash.net> >> To: rv-list(at)matronics.com >> Subject: Re: RV-List: 6A tail tie down >> Date: Saturday, May 30, 1998 12:45 PM >> >> >> Yes ... I helped repair a RV6A that suffered this. >> >> The tie down ring did bend upwards, but could be essentially >> straightened. Since it's stainless, it deforms fairly easily. >> >> It was adifferent story at the rudder FG lower fairing though. The >> fairing was scraped and damaged, but it ends up the the FG fairing is >> stronger than the 0.016 alum. skin of the rudder. This caused the upward >> loads of impact to buckle the aft edge of the rudder a few inches above >the >> lower fairing. >> >> Structurally, the damage was not bad, and the plane flew for a while >> like that, however the fix was to construct a new rudder. Someone else >> built the rudder, I just got the upper fairing glass work to match the >> exising vert. stab. (added about 3/16 to the top), painted it and fitted >> it. The old tie down ring was re-used. >> >> >> On the other thread... I fabricated a 0.032 plate that sits on the >> inside of the rear most bulkhead. All of the bolts that pass through >this >> bulkhead to hold on the vert. stab. spar and tie down fit into floating >> nutplates. This _will_ make final installation of the vert. stab. _much_ >> easier. If you don't do this, then you have to work through the small >side >> access hole to tighten these bolts. this plate can be installed through >> the 5 inch hole in the F-614 and passed aft to the rear bulkhead >loaction. >> >> >> ... hope this helps ... Gil (I helped fix one) Alexander >> >> >> > >> >It seems to me that on a 6A, that the rudder hits before the ring. Does >> anyone >> >have experience hitting A's on hard surfaces and skinning the FG tip? >> > >> >Bernie Kerr, 6A fuselage, SE Fla. >> >> RV6A, #20701, finishing kit >> "REPLY" sends to entire RV-list >> Newsletter Editors: Permission given to re-print if >> credit is given and a courtesy copy is sent to me. >> >> >> > > > > > > Gil Alexander, Los Angeles, CA ________________________________________________________________________________
Subject: Fast RV s
Date: May 31, 1998
I try to fly as much as circumstance will allow, and I still look up from the lawnmower when I hear an engine overhead. I will run a bit when I hear a homebuilt exhaust. My wife and I go and sit at the airport to listen and watch as the avians come home to settle in the twilight. Damn, it is so pretty. Tower says, "Make it quick, homebuilt turning final 2 miles out" Got to be an RV, On the radio, I always say RV, never just homebuilt. Here he comes, a black silhouette against a red-gold sky, swoops to a text book landing the kind of which I never can do.....................But....I can still fly a bit of combat.......... 2 nights ago, I went for a blast up the valley....old folks need to do this.... at 2000' feet, things were comfy without a jacket on and vents open. I went to 6000 to see how much snow was on the peaks and to see into the canyons and valleys lying many miles away. I notice it is much colder up here, so I begin to let down at 1800 rpm when lo ! , a bandit I see heading West and fast and well lighted against the bronze splash of reflected sun on the serpentine river below. Well, poor me, here it comes again, that feeling which is automatic and I cannot control (I remember similar when spying pretty chick in my youth) beyond my control...you know what is coming, I must go down to engage him. But from my height and speed quickly up to 185 indicated, I am right on him, but foolishly overshoot. He now sees me, and picks up the game and swoops and arcs behind me. Can't have this ! The straps keep this old bod from twisting around to look, so I crank RV around and once again I get behind. Clever fellow, he breaks off and I lose him in the dark of the mountain range. Just as well, I rather he not see my numbers, not everyone has a sense of humor...I run to home base, land quickly and look at bird. No holes..it is quiet now, just the resident hawk and a few cows nearby. I drive out the gate and two Canada geese give me a dirty look. Guess I didn't land as nice as they do. Back home, old fart puts feet up and wife asks, "have a nice time"? "Want to watch wheel of Fortune"?..No thanks....too much excitement like that for and old warrior like yours truly.....Besides, phone rings and friend says " I saw you blast over my house tonight " Me ? Blast ? I was throttled way back to go home " That is the way of the RV though, it isn't just me that runs to the window when the sound of those pipes go by !..........What a nice placid way for old folks to spend an evening. I can't help but smile a bit when the Safeway boy asks, " Can I help you out with your bags to your car Sir ?..........Jeez.......... ________________________________________________________________________________
Subject: Re: RV6A Elevator Travel
Date: May 31, 1998
> I've got my 6A painted and nearly completed. While checking control > surfaces travel, I found that I don't have the full prescribed down > elevator travel (25 degrees). I only have 18 degrees. The forward > flange of the elevator control horn is resting against the control stop > in the full down position. Is 18 degrees OK? Is there anything else I > can do to increase the down travel. BTW, I do get the full 30 degress > up travel. Thanks for your help. Did you relieve the flanges on the HS rear spar? That is pretty much universally necessary in order to get full down travel. Ed Bundy RV6A - Eagle, ID - first flight 11/20/96 ebundy@bigskytel.com - http://bigskytel.com/~ebundy/ ________________________________________________________________________________
Date: May 31, 1998
Subject: Re: AVGAS IN GENERAL & floating wood?
> >>(snip)...... Tried the block of wood yet? Regards, Brian >Being the naturally curious sort I am, I would like to try this block of >wood in boiling gasoline experiment. Can you tell me how to boil the gas >without blowing myself up? I don't think I want to put the gasoline in a >pan and boil on my natural gas powered kitchen stove above an open flame >:) >Also, what type of wood, how big, how much gasoline, etc., etc.? >Has anyone else tried this yet? >martin shorman Martin (and anyone else wanting to try this...) Brian said in his lengthy post: "Try putting a block of wood (which just floats) in water and watch what happens when the water boils." With all the chatter about avgas vs mogas I guess it was understandable that the leap would be made to floating the wood in gas, but that isn't what he suggested. Brian's implication is that the wood will sink when the water boils. (Haven't tried this myself, but may this afternoon.) If the wood did float in any kind of gasoline, which with the reduced specific gravity of gas compared to water suggests that it would not, then any open flame or extreme heat source near the gas would be unreasonably dangerous. Once we have all boiled our blocks of wood, where will we use them in the construction of our RVs? Bob Steward, A&P IA AA-1B N8978L AA-5A N1976L ________________________________________________________________________________
Date: May 10, 1998
Subject: Re: 6A tail tie down
Michael V Seager wrote: > > Dennis, We commonly do very full stall landings in the RV6A and there is > really no reason to drag the tail. This is normally caused by over > controlling which is very easy to avoid.The same goes for soft field > type takeoffs. Many students drug the tail in cessna 150s too but that > certainly is not neccesary. > Michael Seager CFI I do the pilot check out in the RV6 and RV6A For Vans > rv6cfi(at)vernonia.com > 503 429 5103 > Hi Mike, Last summer I flew round trip from Los Angeles to Oshkosh in another pilot's RV-6A. My first attempted landing on this trip resulted in the damage described by Gil Alexander. The landing occurred at Milford, UT, as I recall. As I flared for landing, the aircraft began to float, with the nose surprisingly high, and as the airspeed bled off, the owner (and PIC) took control of the aircraft and landed it, damaging the rudder and tie-down ring in the process of recovering from the nose-high attitude. Ultimately, I paid for a new rudder, and Gil wound up helping with the repair, but that's another story. The incident was, for me, an awkward embarrassment that led to some serious introspection. After the trip, and after a flight shooting landings with an instructor that was probably unnecessary, I reflected thoughtfully on this incident and came to the conclusion that the problem was not induced by improper technique, or a full stall approach, or an attempt to drag the aircraft in, but, rather, a center of gravity that was too far aft, and for which I was unprepared. The airplane was loaded to the gills, so to speak, with baggage, tool box, oxygen, towbar, charts, approach plates, equipment, etc., and was low on fuel. The PIC made no weight and balance check before flight, although he might have had some intuition about where the C.G. was from past experience. My own intuition suggests that, without some systematic way to estimate the C.G., pilots of such shortly coupled aircraft as the RVs may be unknowing victims of C.G.s that are out of limits. I was wondering if you have some comments on the aft C.G. problem and how it affects the attitude of the RV-6/6A in slow flight and in the flare. Thanks. Jack Abell Los Angeles RV-6A N333JA (Reserved) ________________________________________________________________________________
Date: May 31, 1998
> >I wont argue Tom as I think your right, the important thing is autogas >BOILS at a lower temperature or higher pressure for a given temperature. So >next time you hear of a loss of power on take off, and some one says it >can't have been due to autogas because it was pouring black smoke out, and >it should have been lean not rich if it was vapour lock due to autogas. At >least you will know it could have been the autogas. I am real interested in this subject, Brian as I have a Petersen Autogas STC for my Cessna and am thinking about starting to use mogas in it. I looked up the distillation curves for avgas and for unleaded gasolines. They show the initial boiling points for both fuels start at 75 degrees. So it looks like they will both start to boil at the same temperature, but I guess it is a matter on how much each evaporates. Avgas's RVP is from 3 to 5 and mogas runs 7-9 in summer and 11 or higher in winter, so mogas is definately more volatile. It seems that there are potential problems either way you go. If you use 100LL in a plane designed for 80/87 Avgas, then you may have fouled plugs or sticky valves from the excessive lead in the fuel (2 grams versus .5 grams in 80/87). If you use mogas, you may have vapor lock problems and you have to run some 100LL every so often to add some lead. My Petersen STC says you can use mogas and every 75 hours burn a tank of 100 LL to add lead to the engine or you can blend mogas 3 to 1 with 100LL to get the correct lead ratio for the engine. There are a couple of kits out there to check the RVP of gasoline and whether it has any ethanol in it. The Following copied from the Petersen STC web site Thanks to Dr. Ray Hodges of Australia, a simple fail-safe portable tester is available. The Hodges Fuel Volatility Tester is small enough to be carried in the airplane and will tell you at a glance whether or not the fuel has any serious vapor lock potential, given the current outside air temperature. It immediately tells you if the fuel could cause vapor lock, regardless of contributing factors such as, temperature, altitude, seasonal blend, weathering history, or blends with avgas or ethanol. The operation of the tester is fail safe since air leaks cause low ("unsafe") readings. This tester has become standard equipment for many people who use auto fuel and desire a preflight safety check of the fuel. Operating the tester is quick and simple. A sample of fuel is drawn into the syringe; the syringe is then coupled to the gage and the plunger is drawn down. This creates a vacuum in the syringe, the fuel boils, evaporates, and a reading is obtained on the gage which indicates whether the fuel is "safe or unsafe". Complete instructions are, of course, included with the tester. The Hodges Volatility Tester gives an on-the-spot answer to the question - "could the fuel cause vapor lock?" - and unlike all other standard tests it does not give an answer that needs further interpretation. If the fuel has weathered to a lower Reid Vapor Pressure (RVP) than normal, the equipment automatically accounts for the current vapor pressure, and registers a "safe or unsafe" result dependent only on the current value. This capacity to read current value gives the pilot the option of blending fuels until a safe reading is obtained, or of delaying the flight until a cooler part of the day when a "safe" reading can be obtained. Please note that the volatility tester does not give octane ratings, nor does it specifically give you RVP. However, a chart is available at your request that can be used to extrapolate RVP to within 1 psi. RVP by itself means nothing. The tester is designed to give a "go-no go" indication which is really the most useful way to evaluate the fuel for vapor lock potential. Furthermore, samples for testing must be fresh, since any sample collected in an open jar or blends tested that are not properly mixed won't give a true result. Highly recommended for any low wing pump fed airplane, and for all homebuilts, the Hodges Volatility Tester sells for $52.00 shipping included. ALCOHOL TESTER We include a description of how to test for alcohol along with each STC. It is a simple test and you can easily make your own tester. However, we also offer a reusable alcohol tester for $10.00. >Tried the block of wood >yet? Regards, Brian No, the next time I boil eggs I will throw in a chunk of wood for flavor. I am going to put a equal amount of mogas and avgas out at different temperatures and see how long it takes each to evaporate. I have been reading that you can not burn autogas in the 160 hp O-320's because of the higher compressions. I have found out that Petersen has an STC for 160 hp O-320's. You have to use 91 Octane minimum Premium auto gas instead of 87 Octane unlead. Still a lot cheaper than Avgas. Regards, Tom don't want to talk about fuel tanks Velvick Phoenix, AZ rv-6a ________________________________________________________________________________
Subject: Rear tie down hook.
Date: May 31, 1998
Regarding rear tie down hooks, I'm glad others are bringing it up. I've had 2 rear tie down incidents in the last year with my RV6A. Both were at short grass strips. I'll explain, both strips were shorter than 1200 feet, getting on the ground was not a problem, the length of the runway was not a problem. It was while rolling out that I had the problem. In both instances I was rolling out with plenty of runway left when my nose wheel hit a GOPHER Mound(Minnesota #$@& creatures), nose goes up and tail hits ground. In both instances the tie down ring was driven backwards, forcing the stainless steal edge into the rudder forward fiberglass bottom fairing, as a result I was unable to move my rudder after impact, fortunately in either case I didn't have to do a go around!! I removed the rear tie down ring. I did inform Vans of the situation, because I feel theres a little bit of a safety issue. I think An aerodynamic skid plate maybe the solution. Or a stainless steal bracket similar to what we have in the wing's where we have the option to remove the ring might be the best answer. To answer the what hits first question, It's the tie down hook! ________________________________________________________________________________
Subject: FW: Elevator trim
Date: May 31, 1998
-----Original Message----- From: Noel E Drew [SMTP:noeldrew(at)iafrica.com] Sent: Saturday, May 30, 1998 9:28 PM To: 'rv-list(at)matronics.com' Subject: Elevator trim My challenge is to get a few more knots out of my RV6 as I intend participating in the annual South African State President's Air race. In my search for drag that could easily be reduced I noticed that my trim at top speed left the elevator slightly low with the counterweight sitting above the top surface of the horizontal stabiliser by about 3/8th of an inch. My conclusion was that I had either an error in the alignment of my elevator (or wing) or a C. of G. which was too far back. A weight and balance check eliminated the C of G possibility and I experimented with a .040" shim on the front bolt down which lifted the leading edge of the horizontal stab. The next test resulted in a lesser deflection of only about 1/8th inch. This has had a positive effect on speed of at least 1 knot and no noticable effect on stability. Slow speed flight is well in trimmable range. The next step seems to be a shim of .063" but I thought I would put this out for comment from the list before proceeding. I have not seen any discussion on the subject before but has anyone else gone through a similar trimming process? Noel Drew Durban South Africa RV6 ZU-APF 160hrs ________________________________________________________________________________
Date: May 31, 1998
Subject: Re: Elevator tip ribs
Greetings, The plans do not specifically say at what point to attach the 603, & 604 tip ribs to each other. I think they should be attached together early - before attaching to the spar. Is this correct? - or did I miss something? Also, the 605 El. Horn seems to have a slightly different angle than that made by the rib, spar, & skin at that corner. I have not attached those elements together yet - Maybe (hopefully) that will not be the case. Any solutions to that? Thanks David Wentzell, Racine, WI (RV6) ________________________________________________________________________________
Date: May 31, 1998
Subject: Re: Fuel Tank Tabs
I would like to but fuel tank tabs similar to those in a Piper Warrior in my RV6A tanks. I tried the archives but promptly got overcome by the deluge of info. If anyone else has completed this, what length were your tabs, for what quantity of fuel and exactly where did you mount them? Thanks, in advance! George Stanley Desert Center, CA. RV-6A, Fuel Tanks ________________________________________________________________________________
From: "Stephen Johnson" <spjohnsn(at)ix.netcom.com>
Subject: Re: Tank attach angle & tank rib.
Date: May 31, 1998
-----Original Message----- From: Brian Huffaker <huffaker(at)utw.com> Date: Sunday, May 31, 1998 11:06 AM Subject: RV-List: Tank attach angle & tank rib. > > > Working on fuel tank parts, have cut out the T-405, and noticed that the >T-shaped "dent" on the T-803 end rib prevents it laying flat against the >web. Should I hammer it flat on my anvil, thus warping the rib (already >drilled to tank skin), or just try to rivit around it. Also, the ring is >interfering with the access plate. Should it just be cut away entirely? > Hi Brian, I have some bad news for you. It looks like you are working with an 804 rib instead of an 803. The 803 has no T shaped dent. Good luck, Steve Johnson RV-8 #80121 ________________________________________________________________________________
Date: May 31, 1998
Subject: Re: jon's seat
Michael; If you send your snail mail address, I'll send a SASE for a jons' seat picture. steve schmitz ________________________________________________________________________________
Date: May 31, 1998
George The best fuel gauge is a small wooden stick that you can mark the No of usable gallons on it. Use this to dip the tanks and it will be small enough to keep in the cockpit. We have one in the Luscombe and we had one in the Turbulent & my RV8 will have one. When we rebuilt the Luscombe we also put the aircraft into flying attitude and gradually added fuel. From this we were able to make a placard to show how much fuel was remaining in gallons instead of 1/4, 1/2 full etc. as marked on the gauges. This has been very usefull on long cross countries. In message <13dbbc8a.3571a39b(at)aol.com>, Wndwlkr711(at)aol.com writes > >I would like to but fuel tank tabs similar to those in a Piper Warrior in my >RV6A tanks. Thanks, in advance! > >George Stanley >Desert Center, CA. >RV-6A, Fuel Tanks > RV8 80274 -- Rob Hatwell ________________________________________________________________________________
Date: May 31, 1998
Subject: Re: Aileron Stiffners
Hi Scott I faced the same problem as you and I decided to go ahead and do it. I figured a little dab of RTV in the ailerons wouldnt hurt anything. Rob Miller 80153 Skinning Fuselage ________________________________________________________________________________
Date: May 31, 1998
Guys and Gals: Just put a vapor return line in as described in the RVator a fews years back. It works good on Ellison TB or carb engines. Dennis Trusty dtrusty(at)iname.com Granbury,TX RV-6 ________________________________________________________________________________
Date: May 31, 1998
Subject: Re: AVGAS IN GENERAL & floating wood test
Unistar Computers wrote: > > > Brian said in his lengthy post: > > "Try putting a block of wood (which just floats) in water and watch what > happens when the water boils." >(snip).............. > > Once we have all boiled our blocks of wood, where will we use them in the > construction of our RVs? > > Bob Steward, A&P IA Bob: I have to admit to being a bit red faced after reading your posting. I should have gone back and tried to find Brian's original posting regarding the liquid to use in the float test. I had an accident as a youngster trying to recreate an experiment with gasoline, and I wanted to verify the proper procedures. At any rate let me tell you the results of the wood block test I just got finished with. Room Temperature 73f Stainless steel Revereware pan 5.75" dia x 2.75" deep approx 3 cups tap water 1 - 2x4x 1.25" long The wood 2x4 scrap was placed in pan after water and the gas flame turned on (no gasoline added to water :) ) As the water started to boil, approx 4 minutes later, the wood began to move around due to the boiling water. After 7 minutes of boiling, the wood remained floating. I then removed the 2x4 scrap and placed a scrap of clear pine which measured 1.5"x11/16"x4.75" in the boiling water. After an additional 6 minutes of boiling, the scrap continued to float. I shut the heat off, removed the wood scrap and washed out the pan. Approximately one cup of water had boiled off in the 17 minutes of heat. Did I do something wrong here? Was the block actually supposed to sink? Has anybody else tried this? martin shorman, lawton, ia wood block floats in boiling water ________________________________________________________________________________
Date: May 31, 1998
Subject: Re: Thunder Mustang Crash
This is not an RV, but yet a very high profile experimental airplane. The entire source is listed. Can any one verify this? Subject: Thunder Mustang Crash Date: 31 May 1998 20:15:20 GMT From: "sven" Micron Internet Services Newsgroups: rec.aviation.homebuilt, rec.aviation.marketplace, rec.aviation.products, rec.aviation.restoration Apparently yesterday afternoon (Saturday). Papa 51's Thunder Mustang crashed 25 miles or so southwest of Boise, Idaho. Both Pilots were killed on impact. Not Much is known of the accident as of yet, some reports lead to a stall spin scenario..... I will try to keep the group informed as information becomes available.... ________________________________________________________________________________
Date: May 31, 1998
<< Working on fuel tank parts, have cut out the T-405, and noticed that the T-shaped "dent" on the T-803 end rib prevents it laying flat against the web. Should I hammer it flat on my anvil, thus warping the rib (already drilled to tank skin), or just try to rivit around it. Also, the ring is interfering with the access plate. Should it just be cut away entirely? Brian Huffaker, DSWL (huffaker(at)utw.com) President and Founder Friends of P-Chan RV-8 80091 Fiddling with fuel tank. >> Brian: Van's tooled up and made a new root rib for the RV-8 wing tank. The stiffener ring on the original rib got in the way of the tank cover doubler attach ring. This, in combination with the tooling hole, made it difficult to place the stiffener ring on the rib without fear of leaks later on. The T shaped stiffener bead was, I believe, omitted on the new rib. When I called and politely inquired, they sent me the new rib, free of charge. But I had to ask for it... If you have not riveted your tank yet, I suggest that you consider obtaining/installing this new root rib. By your serial #, I'd guess that you have the old rib style, I did, and I'm 3 serial numbers later than you. I'd also suggest that you consider (I said consider here guys) using sealed nutplates (NAS1473) inside the tank where the sender and cover attach doubler plates are secured. They are expensive, however you will have less fuel leak worries later on. On the other hand, many, many RV's have been built without sealed nutplates which have had no leaks (yet?). But then, I did read about a few builders that did have fuel leaks past the screw threads.... Van's is simply trying to save us builders a few bucks here, it's one of those trade- offs I guess. Hope you like pro-seal... Hope this helps, Jon Ross 80094 Skinning fuselage ________________________________________________________________________________
Date: May 31, 1998
Subject: Re: Control Stiffness
>Just finished hooking up my Control sticks to my airlerons and elevators >on my RV6A. Moving the sticks side to side for the airlerons seems >rather stiff. I tried my friends 6a controls and they flow much more >smoothly and easily. Have I tightened things down to much? Any ideas >appreciated? > >Ron Caldwell >rlcaldwell(at)uswest.net > Ron, Go through your control system piece by piece to find out what is binding. The ailerons should be smooth as silk. When rigging my -6A, I found that if I tightened the long bolts (AN4-25?) that go through the bottom of the control sticks( these are the ones that go through the brass bushing, that the ailerons were very stiff. In my case, the solution was to file a bit off of the steel weldment that rides on the brass bushing. If that isn't where yours binds, check each bellcrank and try to isolate the problem. I also found that control stick boots made out of naugahyde will stiffen the controls somewhat. I didn't consider this to be a problem as the control system itself was very smooth. Hope this helps ________________________________________________________________________________
Date: May 31, 1998
Hi Dave: I riveted my tip ribs together prior to riveting the assembly to the elevator spar. As you noted, the plans do not specify when to to this, but it seemed to work out fine for me. It was just easier working with two small parts, as opposed to messing with it with the spar flopping around the whole time. As to the elevator horn not in synch with the elevator skins et al, I had no problem with either elevator, in fact I just got done riveting my left control horn on. So I can't help you there. Just make sure that the control horn is bent at the prescribed 68 degrees and you should be OK. Regards, Jeff Orear RV6A 25171 Left Elevator Peshtigo, WI ________________________________________________________________________________
Date: May 31, 1998
<< Best fix of all, is put the nose wheel where it belongs......on the tail....oooh, who said that ? >> Why would I want to raise my insurance and lower my resale value? -GV ________________________________________________________________________________
Date: May 31, 1998
>Just finished hooking up my Control sticks to my airlerons and elevators >on my RV6A. Moving the sticks side to side for the airlerons seems >rather stiff. I tried my friends 6a controls and they flow much more >smoothly and easily. Have I tightened things down to much? Any ideas >appreciated? Aileron control movement should be very free and smooth due to the use of ball-bearing rod-ends at every point of movement/rotation. You should proceed to isolate the point of stiffness or binding by disconnecting one component at a time, starting at the ailerons and working inboard. For example, if you disconnect the pushrod from the right aileron and the stiffness disappears, then you know that your problem is with the movement of the aileron itself. Best Regards, Dave Barnhart rv-6 sn 23744 N601DB Flying ________________________________________________________________________________
Date: May 31, 1998
> >This is not an RV, but yet a very high profile experimental airplane. >The entire source is listed. Can any one verify this? > >Subject: > Thunder Mustang Crash Yes, I can verify it. A friend of mine lives in Caldwell, Idaho (the home of the first customer flying RV-8). The Thunder Mustang is built in Napa, Idaho, about 10 miles south of Caldwell, He knows Dan Denney and the Thunder Mustang project. He said an eye witness said there was a "pop", it nosed over and went straight into the ground. Nothing left except a few chunks of the engine and a black hole 50' in diameter. Dan was in his Glasair at the time. Mike Robbins Issaquah, WA RV-8Q #591 ________________________________________________________________________________
Date: May 31, 1998
<< Once we have all boiled our blocks of wood, where will we use them in the construction of our RVs? >> There you go. You can make a tail skid out of them. ________________________________________________________________________________
Date: May 31, 1998
<< Why would I want to raise my insurance and lower my resale value? >> Here we go again!!! ________________________________________________________________________________
Date: May 31, 1998
Subject: HS608 rivetting problem
This should be easy, but I seem to be able to make anything complicated. I'm riveting the HS ribs to the rear spar. My problem is that when I squeeze the rivet it seems to lift the flange of the rib slightly so that it's no longer flush with the spar. There's only 2 holes in the flange and I had the other one clecoed. I also had a C-clamp holding the flange against the spar in the center and an elastic cord pressing the top of the hs608 down onto the spar. The flange looked flush. After the rivet was squeezed, the flange has sort of "flared" up, I guess from the rivet expanding into the hole. I have squeezed 3 rivets so far in the two hs608s. Two of them show this very obvious gap which I can get a .012 or .013 feeler gauge into all the way to the rivet. The third rivet "looks OK" but using the feeler gauge shows it has a .003 or .004 gap also. Is this acceptable? (Sure doesn't sound like it.) Should I drill these out & try again? I can't think what I could do to better hold the flange in contact with the rear spar, though. Would using the rivet gun instead of the squeezer reduce this effect? The bucking bar needs a lot of room around the rivet and I'd have to remove the C-clamp to fit it in there, so it might just make it worse. --- Tom Sargent, sarg314(at)azstarnet.com ________________________________________________________________________________
Subject: Re: TAS formula
Date: May 31, 1998
Ed Bundy You wrote "I have a question regarding the 3-leg gps formula. Let's say the wind is directly out of the West (270). Now if you fly one leg at 0, and one leg at 180 your ground speed for both of those legs will be the same. So wouldn't your third leg (and the result of the formula) be radically different depending on whether you flew it at 270 or 90? " This is one of my favorite formulas, described by David Fox in Kitplanes of Feb 1995, page 49, so I thought I'd try to answer your question. The formula works when you change from one track to another by 90 degrees. So in the case you describe V1 is tracking 0, V2 is tracking either 90 or 270 degrees depending on whether you make left or right turns and V3 is tracking 180. I worked out both cases using the formula, where the second leg was either upwind or downwind as you described. This gives different numbers for V2 in the formula. You still get the same answer however. That is because V2 appears twice in the formula, once in the numerator of a term and once in the denominator of a term. It is the combined effects of these two terms that results in the formula working. To refresh people's minds, the formula allows quick and accurate determination of TAS, wind speed and direction using GPS by flying three successive tracks (not headings) 90 degrees to each other, noting the ground speed and then making a calculation. People on the list quote performance many different ways, IAS, CAS, TAS etc., often using uncalibrated ASIs. As a result comparisons are almost impossible to make. Performance comparisons would be a lot more useful if people quoted TAS obtained this way. Ron Taborek RV-4 Installing O-320 Toronto ________________________________________________________________________________
Date: May 31, 1998
Subject: AVGAS IN GENERAL
>>Tried the block of wood >>yet? Regards, Brian I got a wild hair and tried the block of wood. Despite untold looks of curiosity from my wife, I boiled a piece of Douglas fir and a piece of oak. The fir stayed afloat, but the oak sank like a brick when it started to boil heavily. FWIW..... Regards, Jon Elford RV6 #25201 Banks, OR Wings rib, spar, & skin at that corner. I have not attached >those elements together yet - Maybe (hopefully) that will not be the case. >Any solutions to that? > Thanks > David Wentzell, Racine, WI (RV6) > David, I attached the ribs together before attaching them to the spar. I think you could do it the other way if you wanted to. It's your choice. As for the angle of the elevator horn at the spar/root rib junction, the skin is ultimately going to determine the angle here. First, make sure that the root end of the spar is not extending out and contacting the radius at the bottom of the "V" in the Wd 605. If it does, file it down so that it clears. After you are satisfied here, cleco the skin to the skeleton and check for proper fit of the horn. It should fit fairly close, but I think a slight amount of spreading or "pinching" of the "V" should be OK. If it's just way off, contact Van's about possibly sending it back and getting one that fits better. Note: Check, double check and triple check that you get the correct horn drilled to each elevator. Fitting them upside down would be hard to correct without buying some new parts. Keep at it.... > > > > Jon Elford RV6 #25201 Banks, OR Wings ________________________________________________________________________________
Date: May 31, 1998
Subject: RV Fly-in at Creswell, Oregon
I heard there is an RV flyin at the Creswell Oregon Airport tomorrow evening(monday) . Does anyone have the specifics on this? Von Alexander RV-4 #544 skinning fuse MAlexan533(at)aol.com ________________________________________________________________________________
Date: May 31, 1998
Subject: Dipstick-Oil type
Lycoming gurus, I have a Lyc. 0-360-A4M (used) mounted to a RV-6 that I just filled with 8 quarts oil using the slow process of "pre-oiling". However, my dipstick is only showing 7quarts. Could I have the wrong dipstick for that engine? Would the oil filter and engine cavities hold a quart of oil? How much difference does in make on the dipstick whether the aircraft is on all 3 wheels or flight level? Thanks in advance. Warren Bishop N876TB North Platte, NE getting tangled up in my wiring. ________________________________________________________________________________
Date: May 31, 1998
Subject: Re: Cherry Rivet application
I did the same thing on my left elevator. At our builders group meeting here in the Minneapolis area, one of our advisors said to just use aviation grade nuts and bolts. ________________________________________________________________________________
Date: May 31, 1998
Hi All, The method I've found to keep one from inadvertanly hitting the tail on landing is to mount an antenna (wire wipe type, not plastic...) on the belly of the plane such that it's tip end will come in contact with the runway prior to the tail tiedown. This has saved me a** many times.... It's not a cure all... You can still over rotate and slap the tail, but it clearly demonstrates the maximum rotation angle when landing.... Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com E. Windsor, Ct ________________________________________________________________________________
Date: May 31, 1998
Because it's the morally right thing to do. :) -- Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 page at: http://members.bellatlantic.net/~moejoe Vanremog(at)aol.com wrote: > > << Best fix of all, is put the nose wheel where it belongs......on the > tail....oooh, who said that ? >> > > Why would I want to raise my insurance and lower my resale value? > > -GV ________________________________________________________________________________
Date: May 31, 1998
Subject: Re: Rotary engines in RVs
Go look up "irony" in the dictionary! ________________________________________________________________________________
Date: May 31, 1998
<< I have read NO negative comments from anyone who has actually flown behind an auto engine, only from people who haven't tried it because "it won't work". >> THAT says it all. Bob-gonna-use-a-rotary-but-not-in-a-737-Fritz ________________________________________________________________________________
Date: May 31, 1998
Date: May 31, 1998
Subject: Airline humor
--part0_896665353_boundary --part0_896665353_boundary From: Patches1(at)aol.com Subject: Airline Bashing Date: Sat, 30 May 1998 11:36:02 EDT Here are some actual humorous statements by airline flights crews. As the plane landed and was coming to a stop at Washington National, a lone voice comes over the loudspeaker: "Whoa, big fella...WHOA..!" "As we prepare for takeoff, please make sure your tray tables and seat backs are fully upright in their most uncomfortable position." "There may be 50 ways to leave your lover, but there are only 4 ways out of this airplane..." "Your seat cushions can be used for flotation, and in the event of an emergency water landing, please take them with our compliments." "We do feature a smoking section on this flight; if you must smoke, contact a member of the flight crew and we will escort you to the wing of the airplane." "Smoking in the lavatories is prohibited. Any person caught smoking in the lavatories will be asked to leave the plane immediately." "Good morning. As we leave Dallas, it's warm, the sun is shining, and the birds are singing. We are going to Charlotte, where it's dark, windy and raining. Why in the world y'all wanna go there I really don't know." Pilot : "Folks, we have reached our cruising altitude now, so I am going to switch the seat belt sign off. Feel free to move about as you wish, but please stay inside the plane till we land... it's a bit cold outside, and if you walk on the wings it affects the flight pattern." Pilot: "Folks, if you were with us last week, we never got around to mentioning that it was National Procrastination day. If you get a chance this week, please try to celebrate it. If you can't get to it, then maybe try to do it at the weekend, but no big rush. Have a nice day." And, after landing: "Thank you for flying Delta Business Express. We hope you enjoyed giving us the business as much as we enjoyed taking you for a ride." As we waited just off the runway for another airliner to cross in front of us, some of the passengers were beginning to retrieve luggage from the overhead bins. The head steward announced on the intercom, "This aircraft is equipped with a video surveillance system that monitors the cabin during taxiing. Any passengers not remaining in their seats until the aircraft comes to a full and complete stop at the gate will be strip-searched as they leave the aircraft. Here are a few heard from Northwest: "Should the cabin lose pressure, oxygen masks will drop from the overhead area. Please place the bag over your own mouth and nose before assisting children or adults acting like children." "As you exit the plane, please make sure to gather all of your belongings. Anything left behind will be distributed evenly among the flight attendants. Please do not leave children or spouses." And from the pilot during his welcome message: "We are pleased to have some of the best flight attendants in the industry... Unfortunately none of them are on this flight...! --part0_896665353_boundary-- ________________________________________________________________________________
Date: May 31, 1998
Subject: Re: Aileron Flutter
Mike, Aileron stall, which you are probably confusing for flutter, is common if the roll is performed at or above the minimum maneuvering speed..... Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com E. Windsor, Ct. ________________________________________________________________________________
Date: May 31, 1998
<< << When we talk of a Mazda doing 6000 rpm, just what is doing 6000 rpm? The rotors or the output shaft? The rotor turns once for each turn of the output shaft so which is it? >> The rotor turns at 1/3 the output shaft. Bernie Kerr, 6A fuselage, SE Fla >> Duhh, Sorry, typo. Thas what I meant. That's why the question. So what's the answer? ________________________________________________________________________________
Date: May 31, 1998
<< Bob Fritz, Don't know why you are knocking Boeing 737's. One of the safest aircraft ever developed. Think about it!! How many accident free miles do you think the 737's have??? A staggering amount!! You should be one of the people who realizes Airplanes are Mechanical . They can and do fail or break! Stew RV4273sb >> I tell ya', some folks are: 1. too slow to get the joke 2. don't understand irony 3. have a personal ax to grind 4. miss the point altogether and nit pick on the irrelevant. Consider yourself flamed back! And in case you hadn't noticed, the entire 737 fleet was grounded while they did a retrofit to some part that "only" lasted a bazillion flight hours! That was my point!!! Sheesh, I'm gonna go climb back into the fuselage....... Bob ________________________________________________________________________________
Date: May 31, 1998
Just a little bit of info on the Thunder Mustang, best glide speed is (or was) 158kts :( Last I heard they were putting a turboprop in the thing. Wonder if this had anything to do with it? (Yes, 158, it's not a typo!) -- Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 page at: http://members.bellatlantic.net/~moejoe Michael J. Robbins wrote: > > > > > >This is not an RV, but yet a very high profile experimental airplane. > >The entire source is listed. Can any one verify this? > > > >Subject: > > Thunder Mustang Crash > > Yes, I can verify it. A friend of mine lives in Caldwell, Idaho (the home > of the first customer flying RV-8). The Thunder Mustang is built in Napa, > Idaho, about 10 miles south of Caldwell, He knows Dan Denney and the > Thunder Mustang project. He said an eye witness said there was a "pop", it > nosed over and went straight into the ground. Nothing left except a few > chunks of the engine and a black hole 50' in diameter. Dan was in his > Glasair at the time. > > Mike Robbins > Issaquah, WA > RV-8Q #591 > ________________________________________________________________________________
Date: May 31, 1998
Subject: Prince P-Tip Prop
From: carowbotham(at)Juno.com (Charles A Rowbotham)
I'd appreciate any ones' experiences/comments regarding Prince P-Tip Props, in particular their composite props. I plan on installing an O-360. Also any comments about lead edge strips. As a new subscriber and previous lurker, I greatly appreciate the discussions on the RV-List. I also appreciate the excellent job done by the Web Master and Matronics' support. Thanks, Chuck Rowbotham RV8A-QB ________________________________________________________________________________
Date: May 31, 1998
I have sent a picture of jon's seat to a man on the list who has graciously offered to put it on his web page for everyone to see. He will let the list know as soon as it is viewable. Thanks. Michael ________________________________________________________________________________
Date: May 31, 1998
Brian: The ribs shipped with early kits had this problem. If you call Vans they will replace them free (but only if you ask). You can use the ones you have...flatten the indentations with a rubber mallet and use lots of pro-seal underneath the access plate. -----Original Message----- From: Brian > > Working on fuel tank parts, have cut out the T-405, and noticed that the >T-shaped "dent" on the T-803 end rib prevents it laying flat against the >web--... ________________________________________________________________________________
Date: May 31, 1998
Subject: Re: AVGAS IN GENERAL & floating wood? sinking feeling!
> > ><< Once we have all boiled our blocks of wood, where will we use them in the > construction of our RVs? >> >There you go. You can make a tail skid out of them. > Hmmmm!---- Let's see: After all you blockheads have boiled your wood......? No, no, thats not it, How about? --- After all you wooden heads have boiled your blocks.......? I just know there's the makings of a great cheap shot in here somewhere. Now if I said------ after all you------------.........* A big smiley Sorrey about the bandwidth folks > >jim > * When dreams come true the sky's the limit * jjewell(at)okanagan.net ________________________________________________________________________________
Date: May 31, 1998
Steve, I wasn't thinking on that last post. Some people don't have access to the web to view websites. If you can't view websites, let me know. I don't mind sending you a printout of jon's seat. Michael. ________________________________________________________________________________
Subject: Re: RV Fly-in at Creswell, Oregon
Date: May 31, 1998
There will be a Eugene RV Builders Group Fly-In monday June 1st at the Creswell Airport at 6:00 PM. As far as I know, anyone is invited. Ross Mickey is the head of the builders group and he will have a couple of bar-b-que grills working. It is bring your own grill items and pot luck style dinner. RV motivational rides is the theme. Van's was to send down the RV8A for us to see. But........ Craig Nelson RV-6 serial # 25101 cgn(at)pond.net Eugene, OR wings finished! Installing ailerons and flaps __I__ _____O______ o/ \o ________________________________________________________________________________
Date: May 31, 1998
Subject: Re: FW: Elevator trim
<< In my search for drag that could easily be reduced I noticed that my trim at top speed left the elevator slightly low with the counterweight sitting above the top surface of the horizontal stabiliser by about 3/8th of an inch... A weight and balance check eliminated the C of G possibility and I experimented with a .040" shim on the front bolt down which lifted the leading edge of the horizontal stab. The next test resulted in a lesser deflection of only about 1/8th inch...The next step seems to be a shim of .063" but I thought I would put this out for comment from the list before proceeding. I have not seen any discussion on the subject before but has anyone else gone through a similar trimming process? >> Noel- With just me and no baggage my 6A and the cg in the 22% MAC position, mine also did this. I replaced the 1/8" thick blocks under the HS LE with 3/16" blocks and now the tab is in trail during cruise. A change of .063" in these blocks is about 0.4 on the HS. Good luck with the race. Be sure and tell us how you did. -GV ________________________________________________________________________________
Date: May 31, 1998
David M Wentzell wrote: > > > Greetings, > The plans do not specifically say at what point to attach the 603, & 604 > tip ribs to each other. I think they should be attached together early - > before attaching to the spar. Is this correct? - or did I miss something? > Also, the 605 El. Horn seems to have a slightly different angle than > that made by the rib, spar, & skin at that corner. I have not attached > those elements together yet - Maybe (hopefully) that will not be the case. > Any solutions to that? > Thanks > David Wentzell, Racine, WI (RV6) David, Assembly of the 603's and 604's was one of the first tasks I completed when building the elevators. I built both sets at once. The 603's were trimmed to fit the spars and then the rivet holes were marked(remember, the counter weights need to clear the rivets) and drilled the 603 to the 604. Orndorff videos show the drilling procedure. Primed and assembled them. Regarding the elevator horn, I put the skeleton in the skin(jigged in v-blocks) and side gripped the 609(609 wasn't riveted to spar yet) to the skin. I adjusted the 609 until it snugged up to the horn(horn just sitting on spar and centered, not drilled yet) and also had the proper edge distances on the skin rivets. Took the horn off and marked the 609 as to where it contacts spar. Drilled 609 to spar. Reassembled skeleton and put skin and skeleton back in jig and drilled horn to spar first and then to 609. Both elevators were done this way and worked well for me. There's probably an easier way, but everything lined up real nice :-) Just make sure all the edge distances are there. Good Luck Jerry Calvert Edmond Ok -6a ________________________________________________________________________________
Subject: things look different here
Date: May 31, 1998
so shoot me down, this is material of questionable appropriateness (sp?) 11 am Sunday, gas up and blast out of Troutdale airport with my buddy Brian. The sky is finally clear after weeks of rain. We head up the Columbia Gorge as flight of two climbing to 8,000 feet. We pass Mt. Hood in all her majesty. Mt Jefferson and clear down to Mt Shasta in CA is visible. At 8,500' the GPS is indicating 195mph, the airspeed indicator 155. Thirteen minutes puts us abreast Mt Jefferson, also gleaming in white splendor. Brian is at my 9 o'clock several hundred feet away. The unpainted aluminum either glows or completely disappears into the background. Three Fingered Jack, I've climbed that, Black Butte, that one too, then the Three Sisters and Bachelor. Whoa, only 25 miles to Sun River and I'm 5,000' too high. GPS says 205 now, yes! One, two we plunk down into Sun River in the middle of Oregon's high desert just south of Bend. A nice walk to stretch the legs, although it's been but an hour, and it's fresh fish for lunch. Sometimes we get too focused on tail tie downs or calibrated air speeds and forget what a beautiful country we live in. An hour flight from my house I can pass some of the most beautiful mountains, a river gorge, and land in the midst of it without even a landing fee. I hope that by sharing this with you it might last a bit longer in my memory. Just get them flying, you'll be working on them anyways. I have been to the airport almost every day since last October's maiden flight, leg fairings, nav-aid, map box, you name it, they're works in progress. I'm rambling, sorry, it was a damn fine day. kevin 6A 160 hrs. ________________________________________________________________________________
Date: May 31, 1998
Subject: Jon's Seats
OK everyone, pictures and ordering information for Jon Johanson's RV seats can be found on my web page at: http://members.bellatlantic.net/~moejoe Please keep in mind that I am only hosting Jon's pictures, and am not selling the seats myself. The email that Jon sent me with ordering information is on the page as well. -- Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 page at: http://members.bellatlantic.net/~moejoe ________________________________________________________________________________
Date: Jun 01, 1998
Subject: Re: Dipstick-Oil type
<< I have a Lyc. 0-360-A4M (used) mounted to a RV-6 that I just filled with 8 quarts oil using the slow process of "pre-oiling". However, my dipstick is only showing 7quarts. Could I have the wrong dipstick for that engine? Would the oil filter and engine cavities hold a quart of oil? How much difference does in make on the dipstick whether the aircraft is on all 3 wheels or flight level? >> Between the oil filter, oil cooler and lines you have 1 qt semi-trapped. -GV ________________________________________________________________________________
Subject: Re: washer identification
Date: Jun 01, 1998
>Could someone help me identify some washer callout numbers? >On plan sheet number 19a there is a washer 5702-95-30. Plan calls >for two of these washers to set next to the VA-146 bearing on the >bellcrank. I have the book Standard Aircraft Handbook to identify >parts and it is not listed. > >Also there are two washers 5702-75-60 that are placed between the >hiem bearing on the bellcrank that I can not identify. > >If someone could describe the size of these washers I would be >gratefull. > >Thank you in advance. Craig > Craig, I don't recall see a reply to you from anyone else so I'll try and help. These are thin silver colored washers about the diameter of a quarter that are used as a safety precaution to be sure that bell cranks or rod end bearings stay in there relative positions should the bearing portion fail. Thus preventing the likely hood of a control system function being jammed. Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. t to adjust than the elevators. Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. ________________________________________________________________________________
Date: Jun 01, 1998
< > and < < Hmmmm!---- Let's see: After all you blockheads have boiled your wood......? No, no, thats not it, How about? --- After all you wooden heads have boiled your blocks.......?>> Sorry, but I just can't resist: Let's get those wooden-block- skidded, over-rotating, aft-cg'ed, non-tail-draggin', mogas-burnin', rotary-powered, 737s outta here. :^) Joel McLaughlin -6 Wings ________________________________________________________________________________
Date: May 31, 1998
> I have a Lyc. 0-360-A4M (used) mounted to a RV-6 that I just filled with > 8 quarts oil using the slow process of "pre-oiling". However, my > dipstick is only showing 7quarts. Could I have the wrong dipstick for > that engine? Would the oil filter and engine cavities hold a quart of > oil? I wouldn't lose sleep over it. I don't think the dipstick measurement is perfectly precise on total volume. When I change the oil in my 0320 I put in 7 qts. This shows up as about 6.5 after it has had a chance to drain into the sump but before engine start. After engine start it is just slightly below that. (maybe 6.4 qts - the oil filter doesn't hold much due to it's sideways orientation) My engine uses very little oil, and I've found that anything over 7 gets blown out in short order, so I keep it between 6 and 6.75 qts. >How much difference does in make on the dipstick whether the > aircraft is on all 3 wheels or flight level? That I couldn't tell you, because my airplane IS in level flight on all 3 wheels... :-) Ed Bundy RV6A - Eagle, ID - first flight 11/20/96 ebundy@bigskytel.com - http://www.bigskytel.com/~ebundy/ ________________________________________________________________________________
Date: May 31, 1998
Perhaps all 6A's should be fitted with -6 tail wheels in addition to the nosewheel.... :-) Jon Elford RV6 #25201 Banks, OR Wings ________________________________________________________________________________
Date: Jun 01, 1998
<< Joel McLaughlin-6 Wings >> So what engine have you chosen, and what kind of fuel have you deciided to burn? Regards Wendell WBWard(at)AOL.COM ________________________________________________________________________________
Date: May 31, 1998
> < Best fix of all, is put the nose wheel where it belongs......on the > tail....oooh, who said that ? > Want the final word on where that third wheel should go? Ask the tail-wheel itself. Given the opportunity, it's always trying to put itself out front. It wants to become a tricycle sooo bad... ;-) Gary (who counts many tail wheels amoung his friends) ________________________________________________________________________________
Subject: Re: Navaid in RV-8?
Date: Jun 01, 1998
Yes it can be installed under seat. Stan -----Original Message----- From: Randy Lervold <RandyLervold(at)csi.com> Date: Sunday, May 31, 1998 10:13 AM Subject: RV-List: Navaid in RV-8? > >Listers: > >Anyone know if the Navaid servo can be installed under the seat in an RV-8, >or must the servo be mounted in the wing (probably the right wing). I'm >closing my wings up soon and need to know! Retrofitting to a closed wing >doesn't sound like fun. > >Regards, >Randy Lervold >-8, #80500, wings >Vancouver, WA >Home Wing - Van's Air Force > > > > > > > > > > ________________________________________________________________________________
Date: Jun 01, 1998
Thanks, Jon, I thought someone would eventually read what I actually said. Perhaps it's my Aussie accent which confuses. From my experience, carby floats only just float. So fir will probably not duplicate the result. The chap who brought to my attention that mogas could cause an engine to cut through richness was once the chief engineer for General Motors out here and also in charge of the Government aircraft factory at one time, so I thought he just might know more than some others on the subject. His explanation was, bubbles are lighter than petrol or carby floats, so when the fuel boils rapidly, its density drops dramatically and the float sinks. The reason I asked him was that the T18 which I now own had had an engine failure on take using mogas and as witnesses said it was pouring black smoke they claimed it could not be the mogas that caused it as vapour lock should cause leaness ie. no smoke. As you can see the engineer disagreed with them. As the engine had been rough on the previous take off, the pilot did extensive run ups to check it but that probably just compounded the problem. By the way the accident which followed was very serious and had there not been help available immediately it would certainly have been fatal. Regards, Brian. > I got a wild hair and tried the block of wood. Despite untold looks of > curiosity from my wife, I boiled a piece of Douglas fir and a piece of oak. > The fir stayed afloat, but the oak sank like a brick when it started to boil > heavily. FWIW..... > > Regards, > Jon Elford ker(at)utw.com) > President and Founder Friends of P-Chan > RV-8 80091 Fiddling with fuel tank. >> > > Brian: > > Van's tooled up and made a new root rib for the RV-8 wing tank. The stiffener > ring on the original rib got in the way of the tank cover doubler attach ring. > This, in combination with the tooling hole, made it difficult to place the > stiffener ring on the rib without fear of leaks later on. The T shaped > stiffener bead was, I believe, omitted on the new rib. When I called and > politely inquired, they sent me the new rib, free of charge. But I had to ask > for it... If you have not riveted your tank yet, I suggest that you consider > obtaining/installing this new root rib. By your serial #, I'd guess that you > have the old rib style, I did, and I'm 3 serial numbers later than you. > > I'd also suggest that you consider (I said consider here guys) using sealed > nutplates (NAS1473) inside the tank where the sender and cover attach doubler > plates are secured. They are expensive, however you will have less fuel leak > worries later on. On the other hand, many, many RV's have been built without > sealed nutplates which have had no leaks (yet?). But then, I did read about a > few builders that did have fuel leaks past the screw threads.... Van's is > simply trying to save us builders a few bucks here, it's one of those trade- > offs I guess. > > Hope you like pro-seal... > > Hope this helps, > Jon Ross 80094 Skinning fuselage > > > ________________________________________________________________________________
Date: Jun 01, 1998
I live about three miles from Merrymeeting field (the home patch) and was sitting on the porch sipping an ice tea after mowing the dooryard when one of the C-150 trainers went overhead. It coughed, I looked up, it coughed some more, then it started sounding really bad. I got my private ticket in the same plane and the same thing happened to me, a valve stuck - and a valve has stuck in that aircraft every year since. We only have mogas at Merrymeeting - You have to go to the big city to get real gas. It's good training I suppose, but I run 100LL exclusively in my '46 Chief to avoid just that problem, and do. Now I'm no expert, but we here in Maine have and additive called MTBE inserted into our mogas which may cause this problem. We have MTBE to offset the pollutants that waft up from NH, NY and Mass. Personally, I think it'd just be easier to turn 'em away at the entrance to the Maine turnpike. My personal moral to the story: Auto fuel is for autos, aviation fuel is for airplanes, and flatlanders should stay home in the summer. These opinions are my own Any offense taken is entirely intentional Nick Knobil #80549 Wings on Wait Merrymeeting Field Bowdoinham, Maine ________________________________________________________________________________
Date: Jun 01, 1998
Subject: RV-6 Instruction by CFI in a Factory RV-6
The 1998 Northeast RV Forum Planning Committee will arrange for this instruction if there is enough interest. 1. Mike Segar is amenable to instruction October 6, 7, 8, 1998 at Oswego County Airport(FZY) just north of Syracuse, NY. We must have at least ten pilots signed up but there is room approximately 18, one hour sessions. 2. The 4th Annual Northeast RV Forum itself is September 12th followed by a Fly in Breakfast on the 13th. We expect to share short pleasure rides again at the Forum (55 last year) - but these, of course, can't compare with instruction by an experienced instructor specializing in builders and pilots of RV's - bring your log book. 3. Mike is FAA approved for the factory RV-6. He has helped Van at Sun' n' Fun and Oshkosh for a number of years and he makes a somewhat brief "road show" trip around to instruct. Note: this is not his "day time job" and he has limited time for it. He will be coming to Oswego from three days of instruction in Tennessee. 4. Other "high performance" builders would be eligible for this instruction too. 5. This will be a first come, first served opportunity. 6. Since our RV Forum Flyer should be going in the mail soon, if you want to take a lesson, e-mail (drmotorhd(at)aol.com), telephone (315:469-3763), or write immediately to: Bill Hodge, 1998 RV Forum Chairman 110 Orchard Avenue Nedrow, New York 13120 7. If there is sufficient interest to "launch", we may then ask for a Deposit of say $50 in order to raise our level of assurance. We, The Committee, and Mike have time and money at risk if we attempt this venture. 8. Dates to remember for RV interest at Oswego County Airport: 12 & 13 Sept 98- 4th Annual RV Forum. 6, 7, & 8 October 98(middle of the week days): Instruction with Mike Segar and the factory RV-6. ________________________________________________________________________________
Date: Jun 01, 1998
Subject: -4 &-8 underwing air inlet
<< Jon, Curious as to where on the lower wing skin you are mounting this inlet? Any possibility you might pick up engine exhaust through this "fresh air duct", or is it located far enough out on the wing to avoid exhaust flow? Mike Wills RV-4 fuse willsm(at)manta.nosc.mil >> Mike, and others: The underwing inlet using the SV-kit was my idea. I showed this to Bill Benedict at Copperstate '93- I had it on my -4. Lo and behold, it shows up on the -8! (except on the right side) The scoop is mounted outside the wingwalk ribs, centered in that bay. I haven't found exhaust to be a problem. Mine is in the left wing, where I figure the most pressure is while on the ground. The front edge of the cut out is 7 3/4" from the fwd edge of the main skin on the -8 (I use a 4" measurement). The factory engineers report no doubler is necessary, altho I use one in my installations. I'll tell ya, this thing blows a LOT of air for the backseater. It can be installed as a retro-fit easily. See the recent RVator for a cap for the eyeball vent. Check six! Mark ________________________________________________________________________________
Subject: RE: New bucking tool
Date: Jun 01, 1998
I always prided myself on having a fairly complete assortment of tools to build the RV6 with. Not much fancy stuff but pretty much all the essentials. This weekend I needed to buck a few rivets inside the canopy rail and just did not have a bucking bar that would fit in there. I decided to try my 4" no hole yoke for my avery hand tool and must report that that thing works absolutely great as a bucking bar especially for -3 rivets. It can fit almost anywhere you can get your fingers into, is easily aligned and held and does not make a mess with the surrounding skin. Of course as bucking bars go, it's a bit on the pricey side. Just wanted to past on some tool experimentation to yall! Gary Fesenbek RV6A, Ronaoke, VA Canopy ________________________________________________________________________________
Date: Jun 01, 1998
The rotors of a Mazda rotory move around the eccentric shaft (crankshaft) on a set of gears such that the eccentric shaft rotates 3 times for each 360 degree rotation of the rotor. If the rotor is rotating at 2000 rpm the eccentric shaft is rotating at 6000 rpm. If the rotor is rotating at 1500 rpm the eccentric shaft is rotating at 4500 rpm, etc. Ed Anderson RV-6A with a Mazda 13B installed anderson_ed(at)bah.com QmaxLLC(at)aol.com wrote: > > > The rotor turns at 1/3 the output shaft. > > Bernie Kerr, 6A fuselage, SE Fla > >> > Duhh, > > Sorry, typo. Thas what I meant. That's why the question. > > So what's the answer? > ________________________________________________________________________________
Date: Jun 01, 1998
<< To refresh people's minds, the formula allows quick and accurate determination of TAS, wind speed and direction using GPS by flying three successive tracks (not headings) 90 degrees to each other, noting the ground speed and then making a calculation. People on the list quote performance many different ways, IAS, CAS, TAS etc., often using uncalibrated ASIs. As a result comparisons are almost impossible to make. Performance comparisons would be a lot more useful if people quoted TAS obtained this way. Ron Taborek RV-4 Installing O-320 Toronto >> I used this formula last week doing speed calibration checks on my system. I wondered about using "Tracks" or "Headings". Every post I could find in the archives related to using aircraft heading. Every check I did at cruise speeds came out 10 mph faster than what my airspeed indicator showed when corrected for pressure altitude and OAT. I wonder how much difference it makes? I'm going to go out and try running them again, but this time using aircraft track 90 degrees apart instead of aircraft heading. I took the liberty of highlighting the words "tracks, not headings" from Rons original post. Ron, I hope you don't mind. Mark LaBoyteaux RV-6A N106RV Starting max gross wght, and aft CG tests! MLaboyteau(at)aol.com Broken Arrow, OK ________________________________________________________________________________
Subject: Cherry Rivet application
Date: Jun 01, 1998
Thanks for all of your suggestions about rivets It only took me a few minutes to drill out a dozen rivets from the elevator so I could get my longeron yoke in to squeeze the control arm on with some std 1/8 rivets thanks Robin Wessel RV-6A Ann Arbor, MI ________________________________________________________________________________
Date: Jun 01, 1998
From: Unistar Computers <unistar(at)mindspring.com>
>> The fir stayed afloat, but the oak sank like a brick when it started to >>boil heavily. >> Jon Elford >His explanation was, bubbles are lighter than petrol or carby floats, so when >the fuel boils rapidly, its density drops dramatically and the float sinks. >The reason I asked him was that the T18 which I now own had had an engine >failure on take using mogas and as witnesses said it was pouring black >smoke they claimed it could not be the mogas that caused it as vapour lock >should cause leaness ie. no smoke. >Brian. I would suggest that the fuel boiling in the fuel lines raises the pressure high enough to force the float off its seat. This rush of fuel over fills the float bowl and slops out into the intake. I have seen the fuel pressure gauge pegged when making a quick turn around using autofuel. My answer has always been to run the engine long enogh to return the FP to normal before taking off. This can often be accomplished by taxiing out to the run up pad. The best procedure is to avoid this entirely by opening the oil door on the cowl after landing and leave it open until preflight oil level check just prior to engine start. This removes heat from the accessory area of the cowl and pulls cooler air in the bottom of the cowl by thermal siphon as the hot air escapes out the top. Works for me.... Bob Steward, A&P IA AA-1B N8978L AA-5A N1976L ________________________________________________________________________________
Date: Jun 01, 1998
Subject: Re: RV-6 Instruction by CFI in a Factory RV-6
> Mike is FAA approved for the factory RV-6. He Makes a somewhat brief >"road show" trip around to instruct. Note: this is not his "day time >job" and he has limited time for it. He will be coming to Oswego from >three days of instruction in Tennessee. Yes, Mike will be in the Nashville, TN area on October 2 - 4 (Fri-Sun) for our annual fly-in. We have more or less turned this event into an RV fly-in, since we have as many RV's show up as everything else combined (35 last two years). We will post another note closer to show time, however, if anyone is interested in some stick time with Mike, E-Mail me off list. We will have 18 one hour slots available starting at 9 AM each day. Last I heard, Mike was charging $65 an hour total. Fly-in will be at the Lebanon, TN. airport (M54), twenty miles due east of Nashville. Transportation, lodging, and meals will be available. As always, weather permitting. So, if the weather turns to crap during your turn to fly, you will more than likely loose your time unless Mike can reschedule you. Just be prepared for this possibility. Any questions, drop me a line. Dave Hudgins davidrv6a(at)mindspring.com ________________________________________________________________________________
Subject: Aileron Stiffners
Date: Jun 01, 1998
I put the RTV in all of my control surfaces just because I could not find a good reason to not put it there. I could understand the fatigue issue which prompted use of the RTV in the elevators. Balance is a concern (just don't go crazy with the RTV usage) but I was more concerned with a cracked control surface. Just my opinion. Bryan Jones, Pearland, Texas RV-8 80313, attaching empenage to fuselage > -----Original Message----- > From: Scott A. Jordan [SMTP:SAJ_SLJ(at)compuserve.com] > Sent: Sunday, May 31, 1998 9:20 AM > To: RV List; RV-8 Short list; RV Tech Support > Subject: RV-List: Aileron Stiffners > > > > I am completing my -8 aileron and wonder if I should put a dab of RTV > at > the end of the stiffners as is done on the rudder and elevators. It > seems > logical that this should be done since it is similar construction & > material size, though the controls on the -8 at .020 are heavier than > other models and probably less prone to cracking. > > I can't find anything specifically saying to do or not do this on the > ailerons but I am reluctant to change the weight and or balance of a > control surface without specifically being told it is OK. > > Thanks, > Scott A. Jordan > -8 #331 > N733JJ (res) > > > ________________________________________________________________________________
Date: Jun 01, 1998
From: "John M. Denman" <mikedenman(at)earthlink.net>
Subject: Boeimg Surplus Warehouse
Does anyone know the exact address of the Boeing Surplus Warehouse in Seattle or Renton. I would like to go there on Wednesday. Do you need to have a car to get there from the nearest airport? Mike Denman "Sweat the small shit, pay attention to the details! RV6 ________________________________________________________________________________
Date: Jun 01, 1998
Subject: Re: RV-6/6A OAT probe location
Thanks Jon, I'll consider trying that though as you say it may be hard to implement since the wings are already done. Mike > > ><< Jon, > Curious as to where on the lower wing skin you are mounting this inlet? > Any possibility you might pick up engine exhaust through this "fresh air > duct", or is it located far enough out on the wing to avoid exhaust flow? > > Mike Wills > RV-4 fuse > willsm(at)manta.nosc.mil >> > >Mike: > >The RV-8 drawings now show the rear seat fresh air NACA inlet installed in the >lower right wing just ouside the wingwalk area doubler ... that is, the next >bay out. Most builders are simply using pro-seal to attach the inlet to the >skin. It's a bit more difficult to do if your wing is complete, but it can be >done. I'm quite sure that this will avoid exaust flow and engine cooling exit >air, offering accurate OAT readings. > >Jon Ross RV-80094 - Skinning fuselage > > > > > ________________________________________________________________________________
Date: Jun 01, 1998
Subject: Re: RV-8 Crash
I don't wish to start any rumors, but I heard from a usually reliable source that the RV-8 wing spar failed at the outboard fuel tank joint. Beyond this I will not speculate. Hoping that Van's will post info soon, -GV ________________________________________________________________________________
From: "Noble, Jack S" <Jack.Noble(at)PSS.Boeing.com>
Date: Jun 01, 1998
Boeing Surplus is roughly 6 miles south of Renton at 20651 84th Ave. Kent, WA Take East Valley Highway south out of Renton; take 212th St exit; go west to 84th Ave; go north 4 blocks and you're there. Jack Noble 767-400 Wing Structures Boeing Commercial Airplanes Phone 425-342-5596 FAX 425-342-7251 email: jack.s.noble(at)boeing.com ________________________________________________________________________________
Date: Jun 01, 1998
________________________________________________________________________________ the method of adjusting a "wing heavy" condition is to tweak the radius on the trailing edge of the ailerons. If you put much RTV in there I would think this would interfere with this process. Plus Scott McDaniels indicates in his post that since the chord is shorter than that of the elevators or rudder it is not needed. I put it in my elevators and rudder but for these reasons will not put it in my ailerons. FWIW, Randy Lervold -8, #80500, wings Vancouver, WA Home Wing - Van's Air Force > >I put the RTV in all of my control surfaces just because I could not >find a good reason to not put it there. I could understand the fatigue >issue which prompted use of the RTV in the elevators. Balance is a >concern (just don't go crazy with the RTV usage) but I was more >concerned with a cracked control surface. > >Just my opinion. > >Bryan Jones, Pearland, Texas >RV-8 80313, attaching empenage to fuselage > >> -----Original Message----- >> From: Scott A. Jordan [SMTP:SAJ_SLJ(at)compuserve.com] >> Sent: Sunday, May 31, 1998 9:20 AM >> To: RV List; RV-8 Short list; RV Tech Support >> Subject: RV-List: Aileron Stiffners >> >> >> >> I am completing my -8 aileron and wonder if I should put a dab of RTV >> at >> the end of the stiffners as is done on the rudder and elevators. It >> seems >> logical that this should be done since it is similar construction & >> material size, though the controls on the -8 at .020 are heavier than >> other models and probably less prone to cracking. >> >> I can't find anything specifically saying to do or not do this on the >> ailerons but I am reluctant to change the weight and or balance of a >> control surface without specifically being told it is OK. >> >> Thanks, >> Scott A. Jordan >> -8 #331 >> N733JJ (res) ________________________________________________________________________________
Subject: Re: Boeimg Surplus Warehouse
Date: Jun 01, 1998
>Does anyone know the exact address of the Boeing Surplus Warehouse in >Seattle or Renton. I would like to go there on Wednesday. Do you need >to have a car to get there from the nearest airport? >Mike Denman >"Sweat the small shit, pay attention to the details! >RV6 Yes, you'll need a car, it's about a ten minute drive. You can get complete directions at www.boeing.com/assocproducts/surplus/map.html Randy Lervold -8, #80500, wings Vancouver, WA Home Wing - Van's Air Force ________________________________________________________________________________
Date: Jun 01, 1998
Noble, Jack S wrote: > > > Boeing Surplus is roughly 6 miles south of Renton at 20651 84th Ave. > Kent, WA > Take East Valley Highway south out of Renton; take 212th St exit; go > west to 84th Ave; go north 4 blocks and you're there. > > Jack Noble > 767-400 Wing Structures > Boeing Commercial Airplanes > Phone 425-342-5596 > FAX 425-342-7251 > email: jack.s.noble(at)boeing.com > Thanks for the timely input. Mike Denman RV6 ________________________________________________________________________________
From: "Leslie B. Williams" <lesliebwilliams(at)email.msn.com>
Date: Jun 01, 1998
One of the major reasons NOT to put RTV in the airlerons is that you will no longer be able to squeeze/un-squeeze the trailing edge radius to effect trimming out for a heavy wing condition. This is a common thing to do and is very effective. This has been discussed and recommended by Van's. Also, If you end up with a bulbous trailing edge on your aileron with RTV in it, you are in for some trouble. A result of this is commonly described as "aileron snatch" and has gotten the attention of more than one experienced RV pilot. Before making any changes/additions to any structure or procedure it would probably be a good idea to thoroughly research it. This is just one example. Les Williams/RV-6AQ/Tacoma WA > >I put the RTV in all of my control surfaces just because I could not >find a good reason to not put it there. I could understand the fatigue >issue which prompted use of the RTV in the elevators. Balance is a >concern (just don't go crazy with the RTV usage) but I was more >concerned with a cracked control surface. > >Just my opinion. > >Bryan Jones, Pearland, Texas >RV-8 80313, attaching empenage to fuselage > >> -----Original Message----- >> From: Scott A. Jordan [SMTP:SAJ_SLJ(at)compuserve.com] >> Sent: Sunday, May 31, 1998 9:20 AM >> To: RV List; RV-8 Short list; RV Tech Support >> Subject: RV-List: Aileron Stiffners >> >> >> >> I am completing my -8 aileron and wonder if I should put a dab of RTV >> at >> the end of the stiffners as is done on the rudder and elevators. It >> seems >> logical that this should be done since it is similar construction & >> material size, though the controls on the -8 at .020 are heavier than >> other models and probably less prone to cracking. >> >> I can't find anything specifically saying to do or not do this on the >> ailerons but I am reluctant to change the weight and or balance of a >> control surface without specifically being told it is OK. >> >> Thanks, >> Scott A. Jordan >> -8 #331 >> N733JJ (res) ________________________________________________________________________________
Subject: Fast RV s
Date: Jun 01, 1998
> > to a text book > > landing the kind of which I never can do.....................But....I can > > still fly a bit of combat > > where do you live? I wanna shot at you too! Haven't found anyone around > here to have fun with. kevin 6A 160 hrs. > Come, come ye warriors to us old dogs who are but ghosts of the time of air combat as it was so long ago. We are old now and the lines in the faces are not just from the oxygen masks. Gracing the face of one of our number is the crease mark of a .50 caliber, courtesy of a young B17 tail-gunner, but that is for another day. Some of us are from the Luftwaffe and although of late we flew ME108, not 109s, we are now mounted on RVs. We are in the Coast and Cascade range, North of Seattle, North of the border. We also have the retractable 4, fast and fair of face. You will need drop tanks to come this far to engage the "Abbeville Kids" and when you cross the border, radar will pick you up, so you must fly low, there, down low over the river that we may spot you from where we wait. Come up, ...up to meet us where we wait among the peaks and high sun and cumulus. We'll be glad to see you...and fear not..we do not shoot to kill, as we never liked to kill a fellow flier, just down his craft that he may fly again. " I am bloodied but unbeaten, I am weary and will lie me down to rest awhile, and when the day shall dawn anew, I will rise and fight again". ________________________________________________________________________________
From: "Lewis, Timothy, MAJ, AF/XOIWO" <lewisth(at)af.pentagon.mil>
Subject: RV-8 Crash snippet from Avweb
Date: Jun 01, 1998
________________________________________________________________________________ "RV-8 Prototype Crashes The prototype Vans RV-8 experimental reportedly crashed last Sunday during a demonstration flight near Ripley, California. According to a preliminary FAA report, the single suffered an in-flight structural failure and broke up, killing both aboard. Early information indicates a factory representative and a prospective purchaser -- neither of whom were identified -- were aboard for a demonstration flight. There are reports of approximately 1,000 RV-8 kits in various stages of construction and builders tell us they are apprehensive." ________________________________________________________________________________
Date: Jun 01, 1998
Subject: Re: Avgas in General
I believe there is also a test for JET-A in avgas. (remember when???) hal > > With such extensive test equipment as a mason jar and a magic marker one > can test for alcohol in *EVERY* load of fuel. > ________________________________________________________________________________
Date: Jun 01, 1998
Subject: Re: Boeing Surplus Warehouse
writes: > > >Does anyone know the exact address of the Boeing Surplus Warehouse in >Seattle or Renton. I would like to go there on Wednesday. Do you >need >to have a car to get there from the nearest airport? >Mike Denman Boeing Surplus is located at S 208th and 84th S in Kent. Their hours are 10 to 5 Tues thru Fri and Sat 9 to 4. Their phone # is 425-393-4060. They are about 5 miles north of the Auburn airport, 8 miles south of Renton airport and about 10 miles east, southeast of SEA. Boeing employees and retirees get a discount with id. As I remember they put new stuff out early in the week so it's best to go Tues or Weds. Mike Talley Arlington WA RV-6 about to seal the tanks. ________________________________________________________________________________
Subject: RV-8 Crash
Date: Jun 01, 1998
That sounds consistent with where the prototype wing failed during destructive load testing. -----Original Message----- Sent: Monday, June 01, 1998 9:08 AM Subject: Re: RV-List: RV-8 Crash I don't wish to start any rumors, but I heard from a usually reliable source that the RV-8 wing spar failed at the outboard fuel tank joint. Beyond this I will not speculate. Hoping that Van's will post info soon, -GV ________________________________________________________________________________
Date: Jun 01, 1998
Subject: Re: Aileron Stiffners, and more
<< One of the major reasons NOT to put RTV in the airlerons is that you will no longer be able to squeeze/un-squeeze the trailing edge radius to effect trimming out for a heavy wing condition. This is a common thing to do and is very effective. This has been discussed and recommended by Van's. Also, If you end up with a bulbous trailing edge on your aileron with RTV in it, you are in for some trouble. A result of this is commonly described as "aileron snatch" and has gotten the attention of more than one experienced RV pilot. Before making any changes/additions to any structure or procedure it would probably be a good idea to thoroughly research it. This is just one example. Les Williams/RV-6AQ/Tacoma WA >> No snips, as it is all relevant. I *assume* (uh-oh!) the builder in question put RTV only at the ends of the stiffeners, as opposed to filling the entire trailing edge. I see no potential problem (or gain, for that matter) with this, as the stiffeners usually hold the TE radius to the correct (or very nearly so) radius. The bulging occurs *between* the stiffeners, where I wouldn't expect to find any RTV. The ol' squeezing trick should work OK- just go easy- a little bit at a time. A sidenote: I adjusted a customer's h stab (Rocket). He didn't have enough down trim to go past 200 MPH with a pax, or 225 solo. After the h stab was adjusted to the proper angle (the Rocket uses a 3/16" shim under the fwd spar of the h stab), the trim was more correct, and he picked up 12 KTS!! There seems to be no small benefit from having the airframe tuned correctly. Alas, all was still not well in Rocketland. He now had a stick shake passing thru 250 MPH. Not good, Mav. I could see a bit of bulging in the elev trailing edge (I had seen this on previous visits as well). I felt that we had gotten the incidence angle correct, but another Rocketeer suggested the trim tab might be causing some of this shake. The tab was tight- no play. I commented on the unsightly TE bulging, and recommended fixing that first (easy, fast, cheap). POOF! No more shake- the a/c behaved normally up to 275 MPH indicated. BTW- this empennage has no RTV at the stiffeners. Moral of the story? Watch what the heck you (and others) are doing or have done! Don't ignore those trailing edges (like I did- it was a slight bulge), or any other recommended control sfc profiles for that matter. I'd say that if the elev had this sort of effect, maybe the -6 drivers might pay v close attention the their rudder profiles, as these birds seem to like to wag their tails (yes- I know- they're happy!). Do any of you (-6 drivers) have comments on the rudder profile? Has anyone else had the elev shake I described? Check six! Mark ________________________________________________________________________________
Subject: RV8 Crash
Date: May 29, 1998
http://www.ntsb.gov/aviation/9805.htm Don Mack RV-6A -----Original Message----- Moe, & other listers the NSTB can be found at ( faa.gov/avr/aai/iirform.htm ) if any one has address to other sites let me know scott reviere winging it in Tampa ________________________________________________________________________________
Date: Jun 01, 1998
. I'd say that if >the elev had this sort of effect, maybe the -6 drivers might pay v close >attention the their rudder profiles, as these birds seem to like to wag their >tails (yes- I know- they're happy!). Do any of you (-6 drivers) have comments >on the rudder profile? Has anyone else had the elev shake I described? > >Check six! >Mark Mark Under some conditions, I am getting a little tail wagging the dog syndrome. Before the next flight I intend on squeezing the trailing edge of the rudder slightly, I will report any differences. Tom martin ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Date: Jun 01, 1998
-----Original Message----- From: Randy Lervold <RandyLervold(at)csi.com> Date: Monday, June 01, 1998 12:02 PM Subject: Re: RV-List: Aileron Stiffners > > > >From what I understand once we're flying our planes (won't THAT be great!) >the method of adjusting a "wing heavy" condition is to tweak the radius on >the trailing edge of the ailerons. If you put much RTV in there I would >think this would interfere with this process. Plus Scott McDaniels indicates >in his post that since the chord is shorter than that of the elevators or >rudder it is not needed. > >I put it in my elevators and rudder but for these reasons will not put it in >my ailerons. > >FWIW, >Randy Lervold >-8, #80500, wings
May 26, 1998 - June 01, 1998
RV-Archive.digest.vol-et
