RV-Archive.digest.vol-eu
June 01, 1998 - June 08, 1998
      >Vancouver, WA
      >Home Wing - Van's Air Force
      I used Dow Corning 737 Neutral Cure sealant.  I did not bend my rudder TE
      radius enough on the first attempt and the sealant did not interfere with
      altering the radius on the second attempt.  It had cured for several months
      by then and had reached terminal durometer (hardness).  It is not a problem.
      Dennis Persyk 6A canopy
      Barrington, IL
Date: Jun 01, 1998
Subject: flap question
Today on short final I applied 40 degrees of flaps. On landing I went to retract the flaps and no go! Back to the hangar where I found a blown fuse. Has anyone else had this problem! It was quite gusty and my indicated speeds were under 100mph, perhaps the motor kicked out on a gust? After replacing the fuse the system cycled normally, I am looking for some suggestions of things to look for. I am using the suggested 5 amp fuse. Tom Martin ________________________________________________________________________________
Subject: Re: -4 &-8 underwing air inlet
Date: Jun 01, 1998
>Mike, and others: > >The underwing inlet using the SV-kit was my idea. I showed this to >Bill >Benedict at Copperstate '93- I had it on my -4. Lo and behold, it >shows up on >the -8! (except on the right side) The scoop is mounted outside the >wingwalk >ribs, centered in that bay. I haven't found exhaust to be a problem. >Mine is >in the left wing, where I figure the most pressure is while on the >ground. The >front edge of the cut out is 7 3/4" from the fwd edge of the main skin >on the >-8 (I use a 4" measurement). The factory engineers report no doubler >is >necessary, altho I use one in my installations. > >I'll tell ya, this thing blows a LOT of air for the backseater. > >It can be installed as a retro-fit easily. > >See the recent RVator for a cap for the eyeball vent. > >Check six! >Mark > > > Mark, It was a great idea you had; except I was the one who talked engineering into letting me try it because I had seen it on some other RV's before Bill saw yours at Copper State. I don't think he was even in the loop on this one. Not that any of this really matters though. I really posted to your message to point out that Van's aircraft has a wealth of engineer/research going on all over the world and we do take note of a lot of the good ideas that you builders come up with. And sometimes they even get incorporated into kit improvements/enhancements. It has happened many times over the years. Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. ________________________________________________________________________________
Subject: Michigan Wing Fly-in 6/7
Date: Jun 01, 1998
All listers and others interested in Van's aircraft are invited to attend the next meeting of the Michigan Wing of Van's Air Force which will be held at 12 noon on Sunday June 7th at the Experimental Aircraft Association facility at Dalton Airfield (3DA) Flushing Michigan. This very attractive field is located approximately 6 miles NNW of the main Flint Mi airport and has a 2500' paved 18-36 runway in addition to an 1800' 9-27 grass strip. About 10 RV's and a number of other aircraft (including a helicopter) generally attend if the weather is good. Pot luck meal usually starts after everybody has arrived and the first round of hanger flying has died down so you might want to bring a dish to pass. Feel free to ask if you need more information. Jack & Katy Haviland jgh(at)iavbbs.com ________________________________________________________________________________
Date: Jun 01, 1998
Subject: Re: flap question
Tom Martin wrote: > > Today on short final I applied 40 degrees of flaps. On landing > I > went to retract the flaps and no go! Back to the hangar where I found > a > blown fuse. Has anyone else had this problem! It was quite gusty and > my > indicated speeds were under 100mph, perhaps the motor kicked out on a > gust? > After replacing the fuse the system cycled normally, I am > looking > for some suggestions of things to look for. I am using the suggested 5 > amp fuse. > > Tom Martin > > I guess this would be a vote in favor of circuit breakers vs. fuses. ( I hate to bring up an old thread)Ed Cole Cupertino, CA RV6A Fuselage...ready to skin! ________________________________________________________________________________
Date: Jun 01, 1998
Make sure you have no binding in the flaps or linkage. I had to remedy things like dragging nylon actuator guide block and tight out of line torque tube bearings while constructing my RV4. I have had no problems what so ever. RV273sb CO. ________________________________________________________________________________
Date: Jun 01, 1998
Subject: Re: AVGAS IN GENERAL & floating wood? sinking feeling!
<> None chosen yet. Probably Lyc. O-320. May burn some mogas on one side. And I am (attempting to) following development of rotary conversions. ( Very impressed with turbo RX-7 I once had) Hope everyone's up for the occasional humor. I know I enjoy it. Happy building! Joel McLaughlin -6 Wings N.C. ________________________________________________________________________________
From: "TOMMY E. WALKER" <twsurveyor(at)email.msn.com>
Subject: TITE SEAL
Date: Jun 01, 1998
Has anyone had anyone had experience using "Tite Seal" compound on the fuel tank inspection plates and the sender mount plate? How well does it work? Tommy Finishing 6-A Wings Ridgetop, Tennessee ________________________________________________________________________________
Subject: HS608 rivetting problem
Date: Jun 01, 1998
I have the exact problem with my HS606 this past Sunday. I don't have a feeler gauge, but could see light between the two surfaces that were perfectly flush before I squeezed the rivets. I am still debating on what to do about it, and have stopped riveting ribs for the time being. I haven't seen a reply to this post yet. Anyone have any input? Larry larry(at)bowen.com RV-8 emp. Advance, NC -----Original Message----- From: owner-rv-list-server(at)matronics.com Sent: Sunday, May 31, 1998 7:43 PM Subject: RV-List: HS608 rivetting problem This should be easy, but I seem to be able to make anything complicated. I'm riveting the HS ribs to the rear spar. My problem is that when I squeeze the rivet it seems to lift the flange of the rib slightly so that it's no longer flush with the spar. There's only 2 holes in the flange and I had the other one clecoed. I also had a C-clamp holding the flange against the spar in the center and an elastic cord pressing the top of the hs608 down onto the spar. The flange looked flush. After the rivet was squeezed, the flange has sort of "flared" up, I guess from the rivet expanding into the hole. I have squeezed 3 rivets so far in the two hs608s. Two of them show this very obvious gap which I can get a .012 or .013 feeler gauge into all the way to the rivet. The third rivet "looks OK" but using the feeler gauge shows it has a .003 or .004 gap also. Is this acceptable? (Sure doesn't sound like it.) Should I drill these out & try again? I can't think what I could do to better hold the flange in contact with the rear spar, though. Would using the rivet gun instead of the squeezer reduce this effect? The bucking bar needs a lot of room around the rivet and I'd have to remove the C-clamp to fit it in there, so it might just make it worse. --- Tom Sargent, sarg314(at)azstarnet.com ________________________________________________________________________________
From: Lothar Klingmuller <lothark(at)worldnet.att.net>
Subject: Re: things look different here
Date: Jun 02, 1998
> Sometimes we get too focused on tail tie downs or calibrated air speeds >and forget what a beautiful country we live in. An hour flight from my >house I can pass some of the most beautiful mountains, a river gorge, and >land in the midst of it without even a landing fee. Kavin, thanks for sharing. Yes we live in the MOST beautiful country!! Stories like yours gives us earth bound rivet pounders new enthusiasm. I will be back in the Oregan skies one of these years. PS Dump question of the week: What do you'll do along the coastal areas in those gloomy winter months? Lothar ||-6A|| Denver, CO || Ready to jig fuselage|| ________________________________________________________________________________
Date: Jun 01, 1998
Subject: Re:BFL Fly-In (info needed)
Can someone post any info on the RV Fly-In this weekend Thanks Dan Helm -4 finishing kit ________________________________________________________________________________
Date: Jun 01, 1998
Subject: Re: HS608 rivetting problem
I had the same problems, and brought the parts to a builder who was almost done with his 6. He gave me a funn look and asked me what the "extra" flange did to hold the rib on. I didn't have an answer, and neither did he. He told me it was nothing to worry about. In an application like that where you are smashing rivets into such a narrow strip in a straight line, you are bound to have this effect. BTW, just another reminder, Jon Johanson's seat pics and ordering info are on my web page. They are really nice looking seats, and I'm kinda glad I'm not at that point yet on my project because I'd be breaking out the credit card that's already glowing red from overuse. Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 page at: http://members.bellatlantic.net/~moejoe Larry Bowen wrote: > > > I have the exact problem with my HS606 this past Sunday. I don't have a > feeler gauge, but could see light between the two surfaces that were > perfectly flush before I squeezed the rivets. I am still debating on what > to do about it, and have stopped riveting ribs for the time being. > > I haven't seen a reply to this post yet. Anyone have any input? > > Larry > larry(at)bowen.com > RV-8 emp. > Advance, NC > > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > Sent: Sunday, May 31, 1998 7:43 PM > To: rv-list(at)matronics.com > Subject: RV-List: HS608 rivetting problem > > > This should be easy, but I seem to be able to make anything > complicated. I'm riveting the HS ribs to the rear spar. My problem is that > when I squeeze the rivet it seems to lift the flange of the rib slightly so > that it's no longer flush with the spar. > > There's only 2 holes in the flange and I had the other one clecoed. > I also had a C-clamp holding the flange against the spar in the center and > an elastic cord pressing the top of the hs608 down onto the spar. The > flange looked flush. After the rivet was squeezed, the flange has sort of > "flared" up, I guess from the rivet expanding into the hole. I have > squeezed 3 rivets so far in the two hs608s. Two of them show this very > obvious gap which I can get a .012 or .013 feeler gauge into all the way to > the rivet. The third rivet "looks OK" but using the feeler gauge shows it > has a .003 or .004 gap also. > > Is this acceptable? (Sure doesn't sound like it.) Should I drill > these out & try again? I can't think what I could do to better hold the > flange in contact with the rear spar, though. > > Would using the rivet gun instead of the squeezer reduce this > effect? The bucking bar needs a lot of room around the rivet and I'd have > to remove the C-clamp to fit it in there, so it might just make it worse. > > --- > Tom Sargent, sarg314(at)azstarnet.com > -- ________________________________________________________________________________
Date: Jun 01, 1998
Hmm, never could understand all that beautiful scenery crap. Here in scenic NJ, I spend more time making sure I don't get hit by a 747 into Philly Int or a C130 out of Mcguire. Who's got time to look at the scenery? Maybe it would be a little easier if it wasn't so smoggy all the time, but that helps hide all those ugly factorys on the ground anyway. -- Moe Colontonio (wishing I lived in Nevada) moejoe(at)bellatlantic.net Check out my RV-8 page at: http://members.bellatlantic.net/~moejoe Lothar Klingmuller wrote: > > > > Sometimes we get too focused on tail tie downs or calibrated air speeds > >and forget what a beautiful country we live in. An hour flight from my > >house I can pass some of the most beautiful mountains, a river gorge, and > >land in the midst of it without even a landing fee. > > Kavin, thanks for sharing. Yes we live in the MOST beautiful country!! > Stories like yours gives us earth bound rivet pounders new enthusiasm. I > will be back in the Oregan skies one of these years. > > PS Dump question of the week: What do you'll do along the coastal areas in > those gloomy winter months? > > Lothar ||-6A|| Denver, CO || Ready to jig fuselage|| ________________________________________________________________________________
Date: Jun 01, 1998
Larry, I ran into a similar problem riveting the wing ribs to the rear spar, when squeezing the rivet caused the rib to bulge away from the spar. Tried putting the rivet through the rib and then the spar, so the bucktail on the rivet would be on the larger spar surface, and the manufactured head on the rivet would be against the thinner rib flange. Seemed to take care of the problem. Maybe you could try the same method on the elevator. Carl RV6 working on the fuselage Pinckney MI ________________________________________________________________________________
Date: Jun 01, 1998
Install a slow blow circuit breaker. I have PB switch CB's and regular CB's for everything that has a switch on the unit itself. This works very well. Jim Cone RV-6A Flying Great! ________________________________________________________________________________
Date: Jun 01, 1998
kevin lane wrote: > > > so shoot me down, this is material of questionable appropriateness (sp?) > > 11 am Sunday, gas up and blast out of Troutdale airport with my buddy > Brian. The sky is finally clear after weeks of rain. We head................ > Kevin... Thanks for "reminding me" why we really fly these things called airplanes! Ron Butcher Turlock, Calif ________________________________________________________________________________
Date: Jun 01, 1998
Subject: 6/6A Fuselage Jig for Sale: $50
Friend just pulled his fuselage out of jig this week and wants to sell it. He's moving fast--jig was built just two months ago. It's regular lumber, built per plans. Location: right on I-25 halfway between El Paso and Albuquerque. $50 call Pete 505/894-6701 Truth or Consequences, NM ________________________________________________________________________________
Date: Jun 01, 1998
Subject: RV-6A Tailskid
Jon Elford wrote: "Perhaps all 6A's should be fitted with -6 tail wheels in addition to the nosewheel.... :-)" Now, I have to admit, I considered a similar post myself - I'm only surprised it took so long. All kidding aside, I was looking at a Fouga Magister (European military jet trainer) and noticed that it incorporates a small wheel into the ventral strake under the aft fuselage. Something like this: -------O------- (excuse my poor computer "art") I would think that a relatively small wheel, say, the size of the wheels on office chair casters, would suffice to avoid those embarassing scraping noises if you drag the tail. Just a thought from a not-yet builder. Tim Pittsburgh RV-8 starts this fall I'll eat Grape Nuts, but I draw the line at boiling wood! ________________________________________________________________________________
Date: Jun 01, 1998
Subject: Re: Aileron Stiffners
<< One of the major reasons NOT to put RTV in the airlerons is that you will no longer be able to squeeze/un-squeeze the trailing edge radius to effect trimming out for a heavy wing condition. >> I hate to disagree with Les, but......IME the amount that you must squeeze the TE is so small and the RTV is so soft that this really isn't much of a concern. -GV ________________________________________________________________________________
Date: Jun 01, 1998
<< After replacing the fuse the system cycled normally, I am looking for some suggestions of things to look for. I am using the suggested 5 amp fuse. >> Try a slow-blow fuse next time. -GV ________________________________________________________________________________
Date: Jun 01, 1998
Lothar Klingmuller wrote: > > > > Sometimes we get too focused on tail tie downs or calibrated air speeds > >and forget what a beautiful country we live in. An hour flight from my > >house I can pass some of the most beautiful mountains, a river gorge, and > >land in the midst of it without even a landing fee. > > Kavin, thanks for sharing. Yes we live in the MOST beautiful country!! > Stories like yours gives us earth bound rivet pounders new enthusiasm. I > will be back in the Oregan skies one of these years. > > PS Dump question of the week: What do you'll do along the coastal areas in > those gloomy winter months? > Get a motel on the beach and what the storm waters crash upon the rocks. > Lothar ||-6A|| Denver, CO || Ready to jig fuselage|| > ________________________________________________________________________________
Subject: Re: TITE SEAL
Date: Jun 01, 1998
-----Original Message----- From: TOMMY E. WALKER <twsurveyor(at)email.msn.com> Date: Monday, June 01, 1998 8:55 PM Subject: RV-List: TITE SEAL > >Has anyone had anyone had experience using "Tite Seal" compound on the fuel >tank inspection plates and the sender mount plate? How well does it work? > >Tommy >Finishing 6-A Wings >Ridgetop, Tennessee > >I used a thin coat of "medium" Tite Seal on the gaskets of both of them and have had no leaks in 500hrs. I also used noncork gasket material. Ivan RV-4 > > > > > > > ________________________________________________________________________________
Subject: Lowrance/Nav-Aid coupling
Date: Jun 01, 1998
ok, I give up. The Nav-aid guys actually have never tried using the Lowrance Airmap 300 to run their autopilot. Does anyone out there have this arrangement working? Starting from the rounded side of the Lowrance plug I grounded pin 1 and used pin 3 as the output which I fed into pin 8 of the nav-aid.(which contains the $150 board to handle hand-helds). On the lowrance I turned on the NMEA version 2.0 output option and turned off the Starlink DGPS and Magnavox stuff. I turned the RMC/RMB sentences on and all the other sentences off. When I flip the autopilot switch to the left (TK maybe?) nothing seems to happen. Flipped to the right in wingleveler mode it works fine. The course/track switch doesn't seem to make any difference either. The nav-aid guy told me the thing was transmitting codes so a volt meter wouldn't work for checking. So now what? Free rides. Fix this and I'll give you a free ride. Hopefully a west coaster will solve this. kevin 6A ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: Rotary engines in RVs
<< If the rotor is rotating at 2000 rpm the eccentric shaft is rotating at 6000 rpm. If the rotor is rotating at 1500 rpm the eccentric shaft is rotating at 4500 rpm, etc. >> Still no answer to the original question. And the question is......... I'm tooling down the road in my RX7 at 4000 rpm.... What's the tachometer reading; the rotors or the shaft? ________________________________________________________________________________
Date: Jun 01, 1998
Subject: seats...
Okay, several people have expressed an interest in Jon's seats. If ya'll are ready to order, let me know. I will see how many people actually want to order and we can start getting the show on the road. My idea was to have them sent to me (I live in the new Orleans area), then repackage them and send them out to the individual buyers via UPS. I don't believe UPS will cost too much. My labor is cheap, too. (I had better say my labor is free before too many ask.) I will see what kind of payment Jon can handle. My visa loves to be exercised, if that is what he requires. If he needs a money order, I may have to get the money from everyone first. (That should tell you what one and a half rv-4's are doing to my bank account!) If anyone has a different or better idea, let us know, via the list. Thanks. Michael. ________________________________________________________________________________
Date: Jun 02, 1998
> >I have the exact problem with my HS606 this past Sunday. I don't have >a >feeler gauge, but could see light between the two surfaces that were >perfectly flush before I squeezed the rivets. I am still debating on >what >to do about it, and have stopped riveting ribs for the time being. > >I haven't seen a reply to this post yet. Anyone have any input? > > >Larry >larry(at)bowen.com >RV-8 emp. >Advance, NC > > Larry ( & Tom), What you are describing is something that happens (to a varying degree depending on the situation) some times when you squeeze rivets. It will tend to pucker the material under the shop head of the rivet. As long as the parts were tight together when you began squeezing the rivet, and the rivet is proper formed, you have nothing to worry about. Because of the problem you describe, The preferred orientation is always to put the manufactured head on the thinner material. Unless there is a particular reason for a different orientation (which there some times is). In many cases the materials are the same thickness, then it wont matter which way you put it. You are probably riveting ribs to the rear horizontal stab. spar which because it looks nicer the manufactured heads have traditionally been put on the back (out side) side of the spar. Feel free to turn them around the other way if you want. You will probably be happier with the results you get and know one will ever notice the difference. For some reason if you use a gun and a bucking bar you see much less of this happening. So that would be another option also. Final note, when we are talking about 2 or so rivets at each end of the ribs in a structure like the stabilizers, a major function of them is to hold the framework together while you get the skin put on it. Most of the strength in these structures is from the 2 spars and the skin itself. (This is not license to be sloppy with these rivets, It just means minor gaps and such wont have any negative effect on the final strength of the structure in this case) If the rivets them self look good, just keep on riveting! Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. ________________________________________________________________________________
Date: Jun 02, 1998
Subject: jon's seats
I e-mailed jon again. I asked him what method of payment he requires, are the seats attached to the fuselage in any way, do you lose any legroom with them, exactly how many seats could go in one box, and when could we expect them once they are ordered. I will post his reply to the list. Thank you. Michael ________________________________________________________________________________
Date: Jun 01, 1998
Subject: Re: flap question (blown fuse)
My C-150 will do that sometimes when on short final I drop the last 10 (from 30 to 40) and the rpm is back to idle. It uses a slo-blo style fuse. The last 10 degrees is probably when the old motor is working hardest and at idle I probably don't have full system voltage which also ups the current draw. > > Today on short final I applied 40 degrees of flaps. On landing I >went to retract the flaps and no go! Back to the hangar where I found a >blown fuse. Mike McGee N6358G Vancouver, WA jmpcrftr(at)teleport.com ________________________________________________________________________________
Date: Jun 02, 1998
Bob, Sounds plausible when you are sitting on the ground engine off or idling, but why should the fuel decide to boil in the heat sleaved lines which are no where near the exhaust system when the fuel is under pressure in them and at maximum flow rate. ie. 50 feet into the climb. The carby temp can read very high on a hot day especially with a cross over exhaust so close to it and no heat shield between them and the pressure is reduced. This aircraft has a fuel pressure gauge and as he had had some power loss on the previous flight then had it checked by an A&P then done extensive runups, I would expect he would have been watching the instruments like a hawk. I think the best bet if you can arrange it is to use avgas in the circuit and mogas in cruise. In Australia the main incentive to use mogas in Lycomings has been removed as avgas is only about 5% dearer than mogas now. Safe flying, Brian. > > I would suggest that the fuel boiling in the fuel lines raises the pressure > high enough to force the float off its seat. This rush of fuel over fills > the float bowl and slops out into the intake. I have seen the fuel > pressure gauge pegged when making a quick turn around using autofuel. My > answer has always been to run the engine long enogh to return the FP to > normal before taking off. This can often be accomplished by taxiing out to > the run up pad. > > Bob Steward, A&P IA > AA-1B N8978L > AA-5A N1976L ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: RV-8 Crash snippet from Avweb
<< builders tell us they are apprehensive. >> Well what a bunch of B.S. that is. I am not in the least bit apprehensive. Where did that come from? For those who said something like this, I have a question. How much do you want for your kit? Make it worth my while. Regards Wendell WBWard(at)AOL.COM ________________________________________________________________________________
Subject: Propellors
Date: Jun 02, 1998
I would like to hear from anyone with any knowledge of propellors as advertised by MARGIE Warnke in "Sport Aviation" We have been very impressed with the props made by Bernie Warnke, and as these are no longer available we are wondering what to use instead. Bernies props seemed to outperform the other props we have seen both on climb and cruise, with good RPM on climb and yet low Rpm for high cruise speed. I am sure the home builders will feel the loss of Bernie. Use my home Email address if you feel it prudent. Thanks in advance. Brian. ________________________________________________________________________________
Date: Jun 02, 1998
>Still no answer to the original question. And the question is......... > >I'm tooling down the road in my RX7 at 4000 rpm.... > >What's the tachometer reading; the rotors or the shaft? The shaft. Rusty ________________________________________________________________________________
From: "Lewis, Timothy, MAJ, AF/XOIWO" <lewisth(at)af.pentagon.mil>
Subject: AN470AD3 rivets in Filtered Air Box
Date: Jun 02, 1998
Listers, The FAB box kit supplies AN470AD3 rivets (small, round head) to rivet the fiberglass FAB housing to the aluminum top plate. I have the die for an AN470AD4 rivet, but not for an AN470AD3 rivet. I'm thinking of just using the flat dies that I use for AN426 rivets, rather than buying an AN470AD3 die for a dozen little round head rivets. What have others done? Tim Lewis RV-6AQ N47TD (reserved) ________________________________________________________________________________
Date: Jun 02, 1998
types="text/plain,text/html"; --=====================_2220123==_.ALT > > ><< If the rotor is rotating at 2000 rpm the eccentric shaft > is rotating at 6000 rpm. If the rotor is rotating at 1500 rpm the eccentric >shaft > is rotating at 4500 rpm, etc. >> > >Still no answer to the original question. And the question is......... > >I'm tooling down the road in my RX7 at 4000 rpm.... > >What's the tachometer reading; the rotors or the shaft? > It is reading the shaft. Louis I. Willig larywil(at)home.com (610) 668-4964 Philadelphia, PA --=====================_2220123==_.ALT It is reading the shaft. --=====================_2220123==_.ALT-- ________________________________________________________________________________
Date: Jun 02, 1998
<< << builders tell us they are apprehensive. >> Well what a bunch of B.S. that is. I am not in the least bit apprehensive. Where did that come from? For those who said something like this, I have a question. How much do you want for your kit? Make it worth my while. Regards Wendell WBWard(at)AOL.COM >> Interesting. As an AVWEB subscriber, I took notice that the "builders tell us they are apprehensive." comment was not included in the original AVFLASH news piece. It would appear that someone has edited the original news blurb. As for the comments regarding the point of failure on the RV-8 wing, a "usually reliable source" would not remain anonymous, but rather be willing to come forward. Besides, if we look at the RV-8 wing, where else would we expect it to break? Would we all feel better if it broke at the spar attach? I am fairly certain that this is the point of failure of the wings that were factory tested to ultimate limits. It has to break somewhere, and the real question is how many G's did N58RV experience prior to the accident? Jon Ross 80094 skinning fuselage ________________________________________________________________________________
Date: Jun 02, 1998
WBWard(at)aol.com wrote: > > > << builders tell us they are apprehensive. >> > > Well what a bunch of B.S. that is. I am not in the least bit apprehensive. > In all fairness to AVWeb there was nothing in the report that I received about "builders being apprehensive". Carroll Bird, Buffalo Gap TX. RV-4 day, June 02, 1998 6:55 AM To: 'rv-list(at)matronics.com' Subject: RV-List: AN470AD3 rivets in Filtered Air Box Listers, The FAB box kit supplies AN470AD3 rivets (small, round head) to rivet the ________________________________________________________________________________
Date: Jun 02, 1998
<< builders tell us they are apprehensive. >> FWIW, in my "copy" of AVflash, the above statement was not included. My guess is that it was somebody's conjecture which was not immediately caught by the editors. I'll bet they were unable to find any "apprehensive" builders. Tim Pittsburgh Non-apprehensive future RV-8 builder ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Flap Blown Fuse...WHY?
We all seem to be brainwashed to think that when a fuse blows that we should just replace it and continue on. Or we here, "Darn...I should have used a circuit breaker so I could reset it right away". The first question to ask it "why did this fuse blow?" I'd suggest considering the following: 1. Put an ammeter in the circuit and see if the motor is drawing more current than it should while cycling the flaps (on the ground!). Apply some resistive force to the flaps while they are running to see how quickly the current approaches the 5 amp rating of your fuse. You might have something binding or misaligned which would cause the motor to draw more current than it should. 2. Check the wiring. Maybe you have a frayed wire that is shorting to ground or you stipped a few extra strands of the wires when stripping off the insulation. 3. Determine the weakest link in the flap system and size the fuse to protect that part. Maybe 5 amps is too small. The fuse is meant to blow and protect the loop before some other part of the loop burns up. 4. Finally, don't kick youself for not using a circuit breaker. So what if you couldn't retract your flaps. You could have still done a go-around if needed and you can still taxi to your tie down without damage. No big deal! Gary RV-6 finishing 20038 between Long Island and MA. ________________________________________________________________________________
Date: Jun 02, 1998
>PS Dump question of the week: What do you'll do along the coastal areas in >those gloomy winter months? > Well, I live on Long Island. That has to count as a costal area, right? Last winter, I packed the skis into my -6A (internal ski rack) and constantly flew up to Maine to ski for the day. Take a look at http://villagenet.com/~scottg/inflight2.html , taken on one of these flight. This sure doesn't look all that gloomy, does it? When the weather is bad, we who live in these "gloomy" area take the opportunity to get away from the wives, go to the hanger and work on the planes. Scott Gesele N506RV - Flying ________________________________________________________________________________
Subject: G Limits
Date: Jun 02, 1998
The number is not the only thing that is important. I find that most sport aviation enthusiasts I talk to do not understand the G-Limit restrictions put on aircraft. The published G-Limits on most aircraft that we build are the symmetric G-Limits for the airframe. This insures that no wing will see more G than it can handle. It is actually pretty easy to over G an aircraft if it is out of rig or you do not do a symmetric (i.e. straight back or forward) pull on the stick with no rudder. If you think you have not over G'ed the airframe because your $200 G-Meter shows 6 Gs, in reality you could have put 9 to 12 or more Gs on one of your wings, if a symmetric pull was not accomplished. The amazing thing is that most folks think that $200 G meter protects them from over G (look I only pulled 6 Gs!!!). It got so bad in the Air Force that a special equipment is now onboard all real airplanes (fighters) that the pilot cannot reset from the cockpit. It is a natural tendency in a center stick aircraft as the G load increases for the stick to move to one side or the other depending on the hand that is on the control stick. Just my .02 cents! Gary Fesenbek ________________________________________________________________________________
Date: Jun 02, 1998
Subject: subscribe
rmccalli(at)runet.edu ________________________________________________________________________________
Date: Jun 02, 1998
<< Mark, It was a great idea you had; except I was the one who talked engineering into letting me try it because I had seen it on some other RV's before Bill saw yours at Copper State. I don't think he was even in the loop on this one. >> Scott: Jeez- the ONE TIME I decide to tell the world I had an idea,...it turns out somebody else had it first. Aaargh. My mom told me that there would be days like this! My apologies, sir. I had thought I had come up with a nifty application because after viewing the -8 at one of its early airshows, I chided Bill about having put the scoop on the 'wrong' side. He said that he told the shop guys to just put the thing in, without specifying left or right. When the gen mgr of Van's, Inc. tells me something, I tend to believe him. Heck, his desk is right over there- go ask him (as if at this point he doesn't have anything else on his mind...:-( ). But, if what you write is correct, I'd say that more than one of us figured out that the high pressure air is on the bottom! That Bernoulli guy was right! Check six! Mark keep the flow divider and lines cool, but during taxi and engine idling, the reduced cooling air and reduced fuel flow through the system gang up to overheat the fuel. My engine is an IO-320-B1A. the fuel from the servo runs aft, up through the accessory area, through the baffle slightly left of center, and to the flow divider. All fuel lines are firesleeved, except for the injector lines that go from the flow divider to the injectors. I'm running 100LL, and the fuel pressure at the outlet of the mechanical pump is staying constant at 26 psi. The reason I suspect the flow divider is that I can remove the top cowl, and the flow divider will be too hot to touch. After running the engine for a few minutes with the top cowl removed, the idle smooths out. After shutting down the engine, the flow divider is much cooler, and can be touched without causing permanent damage to my fingers. Today, I'm going to fabricate a piece of 1/8" phenolic to install between the flow divider and it's mounting bracket that's attached to the crankcase, to try and prevent heat transfer from the crankcase to the flow divider. Has anyone else had a similar problem? If so, how did you correct it? Mark LaBoyteaux RV-6A N106RV MLaboyteau(at)aol.com Broken Arrow, Ok ________________________________________________________________________________
Date: Jun 02, 1998
I'm not apprehensive either. I am really interisted in what they find out about this crash before I spend my hard earned cash. I feel for the pilot and his family. I flew in this very airplane. I've been in a crash with an RV4. I wouldnt use the word apprehensive. just looking after my butt. Johnnie989 ________________________________________________________________________________
Date: Jun 02, 1998
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: Re: Flap Blown Fuse...WHY?
>We all seem to be brainwashed to think that when a fuse blows >that we should just replace it and continue on. Or we here, >"Darn...I should have used a circuit breaker so I could reset >it right away". If you'd used a breaker, you might have fallen victim to the idea that it's somehow normal or at least okay to experience a nuisance trip . . . all our brothers flying certified iron think so . . . cause there's nothing they can do about it. Keep in mind that the response time for a fuse is 10-50 times faster than a breaker. When I spec fuses into motor circuits, I'll often go to a larger gage wire and appropriate larger fuse to filter out nuisance trips. I strongly suspect that if your flap motor called for 5A circuit protection, the designer was thinking circuit breakers. Consider going to 7-amp/20AWG or 10-amp/18AWG for flap system wiring. Bob . . . //// (o o) ===========o00o=(_)=o00o========= < If you continue to do > < What you've always done > < You will continue to be > < What you've always been. > ================================= <http://www.aeroelectric.com> ________________________________________________________________________________
Subject: Faster RVs Part 3 - Correction
Date: Jun 02, 1998
A few months ago I put three posts on the list entitled Faster RVs Parts 1, 2 and 3, suggesting how to accurately measure, calculate and compare cruise speeds at comparable power, weights and atmospheric conditions.. Wouldn't you know it, but I found an error in Part 3 where Fox's formula is used, so I thought I should post a correction. That is: - delete the words "and divide the result by two" in item 1 e) so it now reads "1 e) add a) + b) + c) +d)" - add the words " and divide the results by two" in item 1 f) so it now reads "1 f) take the square root of e) and divide the result by two. This is your TAS during the test." You can find the earlier stuff in the archives by searching for the keyword Framus. Sorry about that! Ron Taborek RV-4 Installing O-320 Toronto ht). It sounds like you're getting close- there sure are a lot of little things to do at this point...right? A condensed version of your 'amazing expanding list of things to do' posted to this list would be good information. You know- "I finished one doo-hickey and found three other chingaderas, one framus, and a photoratistat that had to be installed. Why is my list getting longer instead of shorter? AARGH!" Check six! Mark ________________________________________________________________________________
From: "Jensen, Keith (MC R&D)" <KJensen(at)simplot.com>
Subject: RV-8 Crash snippet from Avweb
Date: Jun 02, 1998
> > He said: > "...and builders tell us they are apprehensive." > As has been noted, this statement did not actually appear in the AvWeb article (I'm on their service too). I did note the government/military address from whence this mis-quote originated. Keith Jensen 25285 -6A HS done, into VS ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: G Limits
In a message dated 6/2/98 10:27:36 AM Eastern Daylight Time, gfesenbek(at)Meridium.com writes: > It got so bad in the Air > Force that a special equipment is now onboard all real airplanes > (fighters) that the pilot cannot reset from the cockpit Last I checked my RV-6 was a real airplane. It can take-off, land and even kill me just like the real thing. Gary Corde RV-6 N211GC - NJ ________________________________________________________________________________
Date: Jun 02, 1998
Carroll: If you look at the AVWEB web page, the "newswire" version of the story does contain the satement mentioned. The email version does not. I'm sure the original snippet was taken from the web version. > > > >WBWard(at)aol.com wrote: > >> >> >> << builders tell us they are apprehensive. >> >> >> Well what a bunch of B.S. that is. I am not in the least bit apprehensive. >> > > In all fairness to AVWeb there was nothing in the report that I received about >"builders being apprehensive". > > Carroll Bird, Buffalo Gap TX. RV-4 > > > > > > ________________________________________________________________________________
Date: Jun 02, 1998
SCOTT R MCDANIELS wrote: > > > > > >I have the exact problem with my HS606 this past Sunday. I don't have > >a > >feeler gauge, but could see light between the two surfaces that were > >perfectly flush before I squeezed the rivets. I am still debating on > >what > >to do about it, and have stopped riveting ribs for the time being. > > > >I haven't seen a reply to this post yet. Anyone have any input? > > > > > >Larry > >larry(at)bowen.com > >RV-8 emp. > >Advance, NC > > > > > Larry ( & Tom), > > What you are describing is something that happens (to a varying degree > depending on the situation) some times when you squeeze rivets. It will > tend to pucker the material under the shop head of the rivet. As long as > the parts were tight together when you began squeezing the rivet, and the > rivet is proper formed, you have nothing to worry about. > > Because of the problem you describe, The preferred orientation is always > to put the manufactured head on the thinner material. Unless there is a > particular reason for a different orientation (which there some times > is). In many cases the materials are the same thickness, then it wont > matter which way you put it. You are probably riveting ribs to the rear > horizontal stab. spar which because it looks nicer the manufactured heads > have traditionally been put on the back (out side) side of the spar. > Feel free to turn them around the other way if you want. You will > probably be happier with the results you get and know one will ever > notice the difference. > For some reason if you use a gun and a bucking bar you see much less of > this happening. So that would be another option also. > Final note, when we are talking about 2 or so rivets at each end of the > ribs in a structure like the stabilizers, a major function of them is to > hold the framework together while you get the skin put on it. > Most of the strength in these structures is from the 2 spars and the skin > itself. > (This is not license to be sloppy with these rivets, It just means minor > gaps and such wont have any negative effect on the final strength of the > structure in this case) > If the rivets them self look good, just keep on riveting! > > Scott McDaniels > These opinions and ideas are my own > and do not necessarily reflect the opinions > of my employer. > One other tibit is if you take a piece of rubber about a quarter of a inch thick and maybe one inch square and drill a hole in it you then can partially squeeze the rivet with the rubber over the shop head and the rubber will tend to draw the two pieces of material together. The other thing you can do to minumize the pucker is be careful not to use to long of rivet. Mike ________________________________________________________________________________
Date: Jun 01, 1998
Subject: Re: AN470AD3 rivets in Filtered Air Box
> > ><< The FAB box kit supplies AN470AD3 rivets (small, round head) to rivet the > fiberglass FAB housing to the aluminum top plate. I have the die for an > AN470AD4 rivet, but not for an AN470AD3 rivet. I'm thinking of just using > the flat dies that I use for AN426 rivets, rather than buying an AN470AD3 > die for a dozen little round head rivets. What have others done? > > Tim Lewis > RV-6AQ N47TD (reserved) > >> > >I can't comment about other builders, but I have seen flat sets used on many >universal head-3 rivets on production a/c- possibly during some sort of repair >situation. None appear to be loose, so I'd say go ahead. This approach will >leave more $$$ for adult beverages in your wallet (the ones consumed after >that first incredible flight). Even the MIL Spec says this use of flat sets is OK http://www.flash.net/~gila/ Gil (use the $$$ for those adult beverages) Alexander > >It sounds like you're getting close- there sure are a lot of little things to >do at this point...right? A condensed version of your 'amazing expanding list >of things to do' posted to this list would be good information. You know- "I >finished one doo-hickey and found three other chingaderas, one framus, and a >photoratistat that had to be installed. Why is my list getting longer instead >of shorter? AARGH!" > >Check six! >Mark Gil Alexander, Los Angeles, CA ________________________________________________________________________________
Date: Jun 02, 1998
Lewis, Timothy, MAJ, AF/XOIWO wrote: > > > Listers, > > The FAB box kit supplies AN470AD3 rivets (small, round head) to rivet the > fiberglass FAB housing to the aluminum top plate. I have the die for an > AN470AD4 rivet, but not for an AN470AD3 rivet. I'm thinking of just using > the flat dies that I use for AN426 rivets, rather than buying an AN470AD3 > die for a dozen little round head rivets. What have others done? > > Tim Lewis > RV-6AQ N47TD (reserved) > Tim I'll answer your question with a question. How did you get this far without having a AN470-3 die? Craig Hiers My planes at the airport- and I'm not :( ________________________________________________________________________________
Date: Jun 02, 1998
Subject: RV-8 crash
Please forgive my ignorance, but I tuned in too late. Was anybody injured or killed in the RV-8 crash? Mike Graves ________________________________________________________________________________
Date: Jun 02, 1998
Assuming a standard RX-7 tachometer hook-up, the 4000 RPM represents the RPM of the eccentric (crank) shaft, the rotors in this case would be rotating at 1333.333 RPM or eccentric shaft speed (tach speed) divided by 3. If the rotors were turning at 4000 RPM the tach would indicated 12000 (that is if the engine and tach survived to reach 12000). I undertand that full race prepared rotary engines can approach 12000 rpm. Hope this clarifies the RPM question. Ed QmaxLLC(at)aol.com wrote: > > > I'm tooling down the road in my RX7 at 4000 rpm.... > > What's the tachometer reading; the rotors or the shaft? > ________________________________________________________________________________
Date: Jun 02, 1998
... >factory tested to ultimate limits. It has to break somewhere, and the real >question is how many G's did N58RV experience prior to the accident? > Yes, this *is* the real question, along with the fact that this was a prototype. How was it different from the kits, if at all? How was it treated during it's life? All this may take some time, so I suspect we'll have to be patient before we find out what has to be done to avoid another such tragedy. -Ian lurking ________________________________________________________________________________
Date: Jun 02, 1998
I am >fairly certain that this is the point of failure of the wings that were >factory tested to ultimate limits. It has to break somewhere, and the real >question is how many G's did N58RV experience prior to the accident? > >Jon Ross 80094 skinning fuselage > >Listers: regarding the recent RV8 crash; I for one will not feel free to comment further on, or respond to remarks regarding this subject untill the appropriate official reports are made public. There are lots of real questions still begging answers. In spite of any and all good intentions it is still best to wait in silence while real information is still being studied. Rumors often arise out of innocent postulations and gain ever stronger validity each time they are responded or referred to. Lets all wait for word from appropriate sources (NTSB, Vans', FAA, etc.), then we can question and answer the string to its eventual end. Jon and all others please note, Do not take offence, There is no criticism intended in this statement. jim RV6-eh wing rivets and tanks to do. Kelowna, B.C., Canada > > * When dreams come true the sky's the limit * jjewell(at)okanagan.net ________________________________________________________________________________
From: "Moe Colontonio" <moejoe(at)bellatlantic.net>
Date: Jun 02, 1998
I used my flat die just the other day on a line of 470 rivets that were too close to a flange to get the cupped set on. I used a Pnuematic squeezer, and it left a little flat spot on the rivet head, but it set them just fine. Moe Colontonio >I'm thinking of just using >the flat dies that I use for AN426 rivets, rather than buying an >AN470AD3 >die for a dozen little round head rivets. What have others done? > >Tim Lewis ________________________________________________________________________________
Date: Jun 02, 1998
> Anybody up for a game of telephone? You know the one where people start a phrase and whisper it in someone's ear, pass it along, and see how distorted it can become? I think we should all cease any and all speculation out of respect to Van's, John Morgan, and his family. I am sure that we will have our answers in due time Paul Besing ________________________________________________________________________________
Subject: G Limits
Date: Jun 02, 1998
I thought going from RC models to a kitplane put me in a REAL airplane. I guess I was mistaken. I'll start saving my money for a $20 million fighter so I can have a real plane... Bryan Jones, Pearland, TX RV-8 80313, attaching empenage to fuselage > > It got so bad in the Air Force that a special equipment is now > onboard all real airplanes > (fighters) that the pilot cannot reset from the cockpit. > > It is a natural tendency in a center stick aircraft as the G > load increases for the stick to move to one side or the other > depending > on the hand that is on the control stick. > > Just my .02 cents! > > Gary Fesenbek ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: RV-8 confidence
Yesterday at our builders-group-pot-luck-rv-fly-in the guest of honor was Bill Benedict from Vans flying the 8A. He gave demo rides to our wives and children. Do you suppose Van would have permitted this, in view of recent developments and in todays litigatory(word?) climate, if he was not certain of the testing and resulting strength data of the RV-8? I for one will continue riveting with renued vigor. What a fantastic flying machine. Respectfully Dennis Clay #80473 left wing ready for rivets ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: Fuel Tank RV6
Help After pro sealing the rear baffels I installed the fuel tanks onto the wings - Now when I tried to take them off - They wont move - any suggestions on how to get them free BSivori(at)aol.com Frustrated ________________________________________________________________________________
Subject: G Limits
Date: Jun 02, 1998
> It got so bad in the Air > Force that a special equipment is now onboard all real airplanes > (fighters) that the pilot cannot reset from the cockpit Oops, should have read that before I put that out. I meant real Air Force airplanes. Fighters as opposed to the tankers, bombers and such who really earn their paycheck. Hey I'm building a 6A so obviously it is real enough for me. ************************************************* * Gary Fesenbek * * Meridium Inc. * * (540) 344-9205 x112 * * gfesenbek(at)meridium.com * * http://www.meridium.com * ************************************************* > -----Original Message----- > From: RV6junkie(at)aol.com [SMTP:RV6junkie(at)aol.com] > Sent: Tuesday, June 02, 1998 10:56 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: G Limits > > > In a message dated 6/2/98 10:27:36 AM Eastern Daylight Time, > gfesenbek(at)Meridium.com writes: > > > It got so bad in the Air > > Force that a special equipment is now onboard all real airplanes > > (fighters) that the pilot cannot reset from the cockpit > > Last I checked my RV-6 was a real airplane. It can take-off, land and > even > kill me just like the real thing. > > Gary Corde > RV-6 N211GC - NJ > > > ________________________________________________________________________________
Date: Jun 02, 1998
Hey Tim, I'd just use the AN470AD4 dies to set the AD3's. I think you'll get at better manufactured head than with a flat set. Laird, SoCal RV-6 fuse (damn, there's a lot of platenuts in the cabin area!) From: rv-list(at)matronics.com on Tue, Jun 2, 1998 6:37 AM Subject: RV-List: AN470AD3 rivets in Filtered Air Box Listers, The FAB box kit supplies AN470AD3 rivets (small, round head) to rivet the fiberglass FAB housing to the aluminum top plate. I have the die for an AN470AD4 rivet, but not for an AN470AD3 rivet. I'm thinking of just using the flat dies that I use for AN426 rivets, rather than buying an AN470AD3 die for a dozen little round head rivets. What have others done? Tim Lewis RV-6AQ N47TD (reserved) ________________________________________________________________________________
Subject: reality vs the plans-HS assembly
Date: Jun 02, 1998
Just when I thought I might know more than just how to drill a hole... I'm in the process of drilling skins and ribs on the HS and have run into a conflict between how I read the plans and what I'm actually seeing on the HS. In the rib attach dwg. for the 404&405, it shows that there are 4 rivets,one thru 404,610,602&405 / one thru 404,614,602&405. Where I'm running into confusion is how the 2 center rivets, that join the flanges of the 404&405,with the 602 sandwiched in between , fit because there is a (+/- ) 1/8 inch gap between the 404 flange and the 602.?! This is because the 404 bridges across the 610&614. I must be missing something, because this does not look the way it is shown in the plans and I'm at a stand still because I don't know what to do with it!!! I did trim the 404 to fit around the 614, am I supposed to trim somewhere else? Thanks for any help. Marc Hanson RV-6A HS in progress? paintbox(at)rconnect.com ________________________________________________________________________________
Date: Jun 02, 1998
<< I'll answer your question with a question. How did you get this far without having a AN470-3 die? >> Tim- I still don't have a 3/32 universal die and my plane is long done. I spent the savings on fuel. BTW, I see that you've recently been promoted. Congrats! -GV ________________________________________________________________________________
Date: Jun 02, 1998
I would suggest finding the problem, friction and or binding before a bandade fix like a slow blow fuse. If there is no problem then try the fuse. RV4273sb CO. ________________________________________________________________________________
Date: Jun 02, 1998
That will work fine on the -3 rivets, in that application. They might flatten a tad but will still be much stronger than the fiberglass. RV4273sb CO. ________________________________________________________________________________
Date: Jun 02, 1998
Outside snap? Don Help After pro sealing the rear baffels I installed the fuel tanks onto the wings - Now when I tried to take them off - They wont move - any suggestions on how to get them free BSivori(at)aol.com Frustrated ________________________________________________________________________________
Subject: plans vs reality,HS
Date: Jun 02, 1998
Before all of you kind and generous RV'ers out there pass your wisdom on to me, I have solved my problem! Actually, I just looked at the plans REAL hard this time and saw that I indeed was supposed to trim the flange of the 404 rib so that it would sit against the 602 in between the 610&614. Sometimes it just helps to have someone to talk to!!! Marc Hanson Back on track ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: Glad I built 'em
From: Department of Flying Builders Re: Things I'm Glad I Put On My Airplane, etc. I was up flying today, just had to go up. Crystal-clear typical Colorado morning, enjoying the airplane. Had a chance to look around inside and liked what I saw. My airplane took a little longer than usual to build, but I'm glad I took the time to build it straight (apparently) and JUST the way I wanted it. Take time to plan well and you will have a happy place to fly. Here are some random thoughts: The Warnke prop: MAN, I like it. I feel fortunate I had mine carved up before Bernie started doing angel wings (I wonder if he's still using the beautiful laminate he used on the props). Mine was perfect right out of the box. I hope he shared his magic secrets with those who are doing them now. The Landow Harmonic Balancer: Never flown the RV without it but the engine is becoming smoother with time. I think that is part breaking in of the new engine and the breaking in of the balancer. Puts the weight forward and gives the prop some inertia. I like it. Maybe those expensive Dynafocal mounts help, too. Throttle shelf: I built in a little side wall shelf that my whole arm and hand rests on to run the go lever; throttle, mixture and trim sticking through it, angled slightly for comfort. At the time I thought it may have been extra weight I didn't need but it is really great to have an area to rest your arm. No movement with The Bumps and very east to fine-tune the throttle/mixture/trim with my arm steady on the shelf. Manual trim: Never had the electric but I like the m i n u t e adjustments I can make with the manual trim. Mounted just lateral to the throttle. The Short Gear. Three point almost always drags the tailwheel first unless I'm carrying a little power. Longer gear would help that but the short gear is ON THERE and I can't even find the time to quit flying long enough to paint the ol' dear, let alone change gear. Probably won't ever change it. The Rocky Mountain mEncoder: I like it and use almost all of its many functions. I still have the analog AIS, VSI, ALT and use them all. The mEnconder is a good primary/backup system. I use different instruments at different times. I mounted the VSI upper right corner of the Flight Cluster for mountain flying: since the horizon isn't always definite, it is nice to know if you are going up or down. Airspeed Indicator: analog in the upper left corner of the Flight Cluster which is where it seems to belong. Why? Most of your turns low and slow in the pattern are to the left and that makes it a short scan distance to refer to it when most needed: slow and looking to the left in the pattern. I refer to the analog guage when in the pattern, mostly from 'where the needle should be' perspective. Take lots of time to plan your panel. You are going to have to look at it a lot and for a long time. Look at other panels and note what you like and don't about them. Then "fly" your panel a lot before you do the Hard Copy. Infinity Stick Grip: really like it. Has a great feel and just the right size for my hand. Someone asked me one time if the stick flys OK lefthanded when needed and it does, although it is, of course a right handed stick. A well thought-out design, based on F-16 design. My jet is just a little smaller, and almost as fast. Try it out at Oshkosh, excuse me, AirVenture at their booth. Manual Flaps: I can see the advantages of both, but I like the manual. I can IMMEDIATELY dump flaps on landing which PLANTS the airplane on when needed. It takes a little muscle to yank off full flaps on go-around, but we are supposed to be in shape anyway, right? This is like the tailwheel/nose wheel debate. You like what you like. The Bugs Know: In cleaning the bugs off the airplane, it is easy to see that this is a very well designed airplane. How? Where the Bugs Are. Their little smudges hug the top of the wing quite a ways back from the leading edge. Good airflow adhearance. They smudge RIGHT AT the forward canopy fairing/fuselage intersection; again, good airflow. Wingroot fairings gets bugs: good airflow. Tail fairing, for crying out loud, where the flow should be all over the place: bugs. That is why this airplane slips through the air so fast. VERY unscientific method of airflow analysis, but I can also see places I need to improve on the coweling from the bug hits (as if I needed them to know that), and the blister I made for the alternator bracked aligns exactly with bug bodies. Thanks for the help, bugs. RV-4: MAN, do I love this airplane. I am EXTREAMLY biased and like the whole RV series, but I still think the RV-4 is the best looking. You like what you like. I am very at home in the front office and the airplane just FITS me like a glove. An old soft familiar glove. Some days when I can't fly, I just go out to the hanger and LOOK at the airplane and marvel. Keep building. You are going to LOVE your NEW airplane. Michael RV-4 N232 Suzie Q Introspection ________________________________________________________________________________
Subject: Re: TAS Formula
Date: Jun 02, 1998
> >Using GPS or Loran, fly straight and level flight on any track (not >heading), record the ground speed, call it V1. Turn left or right to a >track 90 degrees from the first, record the second ground speed and call it >V2. >Turn another 90 degrees in the same direction to a third track 180 degrees >from the first, and record V3. > >For engineers, calculate TAS = ( sqrt ( V1^2 + V2^2 + V3^2 + ( >V1^2*V3^2/V2^2)))/2 > >For human beings :-) > >a) calculate V1 squared >b) calculate V2 squared >c) calculate V3 squared >d) calculate V1 squared times V3 squared divided by V2 squared >e) add a) + b) + c) + d) >f) take the square root of e) and divide by two. That is TAS. > >The wind component in the direction of your first track is W1 = (V1 - >V3)/2 > >The wind component in the direction of your second track is W2 = (V2 - >(V1*V3/V2))/2 > >Ron Taborek RV-4 Installing O-320 Toronto Well, I've said this before, but I am mistified as to why anyone would want to use such complicated methods (flying ground tracks, and doing all that math) to find TAS. --Turn on your GPS --Make a slowww turn back and forth till the GPS shows the lowest ground speed --Read the number on the GPS --Turn to a HEADING 180 degrees from the first heading --Read the number on the GPS --Add the two groundspeed numbers and divide by 2. This is your true airspeed. --You are done (Try it at a different speed now. The other guys are still trying to fly a ground track and program their calculators) :) Larry Pardue Carlsbad, NM Pacer N8025D RV-6QME N441LP Reserved Installing Radios ________________________________________________________________________________
Date: Jun 02, 1998
I think he meant real Air Force aircraft, ie: fighters, not bombers that don't pull big g's...not implying RV's aren't real, simply that the B-1 isn't. ;-) ---------- > From: RV6junkie(at)aol.com > To: rv-list(at)matronics.com > Subject: Re: RV-List: G Limits > Date: Tuesday, June 02, 1998 9:56 AM > > > In a message dated 6/2/98 10:27:36 AM Eastern Daylight Time, > gfesenbek(at)Meridium.com writes: > > > It got so bad in the Air > > Force that a special equipment is now onboard all real airplanes > > (fighters) that the pilot cannot reset from the cockpit > > Last I checked my RV-6 was a real airplane. It can take-off, land and even > kill me just like the real thing. > > Gary Corde > RV-6 N211GC - NJ > > > ________________________________________________________________________________
Date: Jun 02, 1998
When Bill gave official word of the RV-8 accident to the list last week he respectfully requested that all speculation regarding the events surrounding the accident be kept off-list until Vans and the NTSB completed their investigation. Make no mistake, when a cause is determined we will be made aware before anyone else. As such, lets stop pondering publicly as to the cause of this tragedy. This is how rumors get started. The RV series of aircraft have a proven track record. Dick is a respected designer, engineer and businessman. Lets make sure that we (individually and collectively) are not the cause of any negative impact on Vans business. Even if you have seen the wreckage, any theory or story you might have regarding the aircraft is pure speculation as to the cause of the accident. As builders, owners and flyers of Vans designs we have the right to know the facts and he Bill has told us we will be first to know any official developments. Gary Corde RV-6 N211GC - NJ ________________________________________________________________________________
From: "Terrence C. Watson" <tcwatson(at)pstbbs.com>
Date: Jun 02, 1998
>> >> >I did note the government/military address from whence this mis-quote >originated. > >Keith Jensen >25285 >-6A HS done, into VS > I think an apology is due to Major Tim Lewis. The implication that his timely and apparently accurate information about what was published on a subject of vital importance to many of us was somehow self-serving is totally inappropriate. Terry Watson RV8 #729 Seattle > > > > > ________________________________________________________________________________
Subject: RV List: HS608 rivetting problem
Date: Jun 03, 1998
Larry & Tom, Here is a little tip that I picked from Jim Gentry (Retired Production Manager Bell Helicopters Fort Worth) and it works just great. Get a piece of fairly dense rubber about 3/4 inch diameter, thickness to be a little longer than the rivet tail,drill a hole in it the size of the rivet, position the rubber over the tail of the rivet. Compress the rivet lightly with squeeser or gun, this will then pull the two surfaces together. This will, in nearly all cases, get rid of the pucker. Remove rubber, and finish driving rivet. Ken Glover Newcastle - OZ from Jim Gentry (Retired Production Manager Bell Helicopters Fort Worth) and it works just great. Get a piece of fairly dense rubber about 3/4 inch diameter, thickness to be a little longer than the rivet tail,drill a hole in it the size of the rivet, position the rubber over the tail of the rivet. Compress the rivet lightly with squeeser or gun, this will then pull the two surfaces together. This will, in nearly all cases, get rid of the pucker. Remove rubber, and finish ________________________________________________________________________________
Date: Jun 02, 1998
> > The published G-Limits on most aircraft that we build are the >symmetric G-Limits for the airframe. This insures that no wing will see >more G than it can handle. It is actually pretty easy to over G an >aircraft if it is out of rig or you do not do a symmetric (i.e. straight >back or forward) pull on the stick with no rudder. > Excellent Post Gary, Gary is absolutely right here. The situation he describes is called a "rolling pull." The loads a wing will tolerate when it is preloaded in torsion are considerably less. This is extremely critical in the North American Mustang and Douglas A-26. I personally watched an A-26 break the rear spar cap when the pilot spotted another airplane (the one I was in) and pulled back on the yoke with the ailerons near full deflection. Miraculously the pilot unloaded the wing after hearing a loud band and landed safely. This is a real concern when doing acro at speeds far above Va. What if you are 3/4 of the way around a roll at 180 mph and full aileron deflection when you see a Canada Goose headed for the canopy? Easily, you could instinctively pull too hard.... Even if you are at or below Va, if the wing is torsionally loaded by full deflection of the ailerons, maneuvering speed may not be enough protection. Editorial starts here: Let me preface these remarks by saying, I am not suggesting or accusing any particular person of doing anything to contribute to the unfortunate set of circumstances that occurred. My only purpose in discussing this event is to must make us ponder how we fly and how something similar could happen to us. Otherwise this terrible loss would be in vain. The story goes that Lloyd Stearman offered $10,000 to anyone who could break a Stearman in flight. That would be huge amount today, and no one ever collected. This was because the Stearman is so draggy that even at full power straight down it will not achieve enough speed to break it. What's the point of this? As far as I know nearly any other airplane can be broken by the pilot. (This includes the unlimited aerobatic types) An RV is no exception. It is stronger than most, but not indestructible. Apparently the weakest link was tested. Prudence dictates that a full investigation be made, and if flaws are found they be fixed. If the weakest link is what is found, then what we know is the weakest link. The fact remains that in nearly ALL airplanes you hold in your hand the power to break the airplane. In a car, when you meet an 80,000# semi on a two lane road you hold that same power. Food for thought....... Tailwinds, Doug Rozendaal dougr(at)petroblend.com http://www.petroblend.com/dougr ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: G Limits (Humor)
<< I thought going from RC models to a kitplane put me in a REAL airplane. I guess I was mistaken. I'll start saving my money for a $20 million fighter so I can have a real plane... >> In the world of mathmatics there are real numbers and imaginary numbers. If we transfer this logic to aviation there are real airplanes and imaginary airplanes. I guess that the RVs are imaginary airplanes, which is ok by me, as I consider myself for the most part to be an imaginary pilot (at least while I am in the building stage). Some of you guys need to lighten up, this is suppose to be fun, add a little humor to your life! Bob Busick Imaginary RV-6 Fremont CA ________________________________________________________________________________
Date: Jun 02, 1998
VERY unscientific method of airflow analysis, but I can also see places I need to improve on the coweling from the bug hits (as if I needed them to know that), and the blister I made for the alternator bracked aligns exactly with bug bodies.>>> Don't count yourself out, Michael. Forensic science uses maggots and flies to determine time of death! I can't wait to clean off the bugs on my bird! Paul Besing RV-6A (197AB) Mounting Empennage ________________________________________________________________________________
Date: Jun 02, 1998
<< Yesterday at our builders-group-pot-luck-rv-fly-in the guest of honor was Bill Benedict from Vans flying the 8A. He gave demo rides to our wives and children.>> I'm sorry, but I have to rain on your parade. Marketing is marketing and Science is Science. I like to look at the brightest side too, but I'm a realist. We can kid ourselves only so far. Pretending that there is no problem when the analysis is not complete is unwise. << Do you suppose Van would have permitted this, in view of recent developments and in todays litigatory(word?) climate, if he was not certain of the testing and resulting strength data of the RV-8? >> Great rhetorical question and this was quite possibly an irresponsible activity if the structures between this a/c and the prototype are identical, IMO. I realize that the proto had many more hours on it (but controlled hours by factory pilots) so I may be a little over the top here. A more prudent action might have been to tone down the marketing push a little until the analysis on the failed prototype is complete (I'm assuming here that it isn't), but then I'm not a businessman. If the structures of the two planes are equivalent and we believe no gross pilot error in the crash of the prototype, you can bet that I wouldn't be condoning the taking of women and children up until I knew EXACTLY what happened. Now maybe there is a major difference (between the two a/c) that only Van's staff is privy to. I'm not building an 8/8A, but, if I was, you can bet that "apprehension" would be my new middle name. A healthy dose of apprehension might be good for all until the truth is revealed. Just one little man's opinion. I'll be happy to receive flames if put to me directly (not to the list). -GV ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: reality vs the plans-HS assembly
m.hanson wrote: > > > Just when I thought I might know more than just how to drill a hole... > I'm in the process of drilling skins and ribs on the HS and have run into a > conflict between how I read the plans and what I'm actually seeing on the > HS. > In the rib attach dwg. for the 404&405, it shows that there are 4 > rivets,one thru 404,610,602&405 / one thru 404,614,602&405. Where I'm > running into confusion is how the 2 center rivets, that join the flanges > of the 404&405,with the 602 sandwiched in between , fit because there is a > (+/- ) 1/8 inch gap between the 404 flange and the 602.?! This is because > the 404 bridges across the 610&614. I must be missing something, because > this does not look the way it is shown in the plans and I'm at a stand > still because I don't know what to do with it!!! I did trim the 404 to fit > around the 614, am I supposed to trim somewhere else? Thanks for any help. > Hi Marc, The 404 is trimmed to fit over the 610 & 614. The 404 is held to the 602 and 405 with the center two rivets only. It's hard to picture, but drawing 3pp shows(about in the middle of the sheet) how the 404 is trimmed to fit over the 610 & 614. Jerry Calvert Edmond Ok -6a ________________________________________________________________________________
Date: Jun 02, 1998
-----Original Message----- From: TOMMY E. WALKER <twsurveyor(at)email.msn.com> Date: Monday, June 01, 1998 11:40 PM Subject: RV-List: TITE SEAL > >Has anyone had anyone had experience using "Tite Seal" compound on the fuel >tank inspection plates and the sender mount plate? How well does it work? > >Tommy >Finishing 6-A Wings >Ridgetop, Tennessee > > > > > > > > > Tommy I don't know any thing about the tite seal. I just saw your adress in Ridgetop Tenn, which is fairly close to me, I live in Benton Kentucky. Sounds like you are just ahead of me, I have a left wing in the jig with the skins drilled. Have started on the tanks. Just wanted to get aquainted. Sam RV-6 ________________________________________________________________________________
Date: Jun 03, 1998
><< builders tell us they are apprehensive. >> >Well what a bunch of B.S. that is. I am not in the least bit apprehensive. >Where did that come from? >For those who said something like this, I have a question. How much do you >want for your kit? Make it worth my while. Wendell, I love the RV-8 that the bunch of bits in a box in my workshop will one day become. I have no intent of giving up on my dream, or offering you a great deal. But, if you ask me if I am apprehensive about the fact that an extremely experienced pilot was lost in an superb aircraft build by Van's experienced team, whereas I have only over 100 hours PIC and am an inexperienced builder building my own plane eight thousand miles away from the factory? Come on, I'd have to be an idiot to say I wasn't. The loss of John Morgan, his passenger and N58RV is a tragedy. Yes, I am concerned, as we all are when a fellow pilot is lost. Yes, I am apprehensive, which is not necessarily an unhealthy thing. Most importantly though, I am certain that Van understands these concerns all too well, and that he and his team will let us know as soon as there are concrete facts and logical conclusions available. Oh, by the way, did I mention I love my plane? Even if she is 'just' an semi assembled emp kit? Chris ____ Chris Hinch Phone: +64-3-477-2995 Animation Research Ltd Fax: +64-3-479-9751 Systems Manager e-mail: chinch(at)arl.co.nz 442 Moray Place, PO Box 5580, Dunedin, New Zealand RV-8 Builder #80630 - http://www.arl.co.nz/chinch/rvlog/kiwi8.htm ________________________________________________________________________________
Date: Jun 02, 1998
On 2 Jun 98, at 15:32, RV6junkie(at)aol.com wrote: > When Bill gave official word of the RV-8 accident to the list last week he > respectfully requested that all speculation regarding the events > surrounding the accident be kept off-list until Vans and the NTSB > completed their investigation. Actually Bill said, "We would like to keep the rumors to a minimum and intend to inform this group of any findings as soon as available. We would appreciate people not speculating as to the cause of the accident." He also said "Although the NTSB may take weeks or months to reach a conclusion, Van should be able to provide some details by the end of the week." (posted 5/25) I don't believe we've heard anything more from Van's since that post. We learned the initial diagnosis of "in flight breakup" from a lister's 5/30 post from the preliminary accident report. I'm grateful to that lister for posting what he learned, and to anybody else on the list who has access to facts and posts them for all of us to see. The loss of John and the -8 has been on my mind every day since it went down. I believe the best way to reduce speculation is to provide information, not to exhort silence. All of us who build and fly RVs have a legitimate interest in knowing the facts. I'm also interested in hearing what other folks think about the accident, based on the facts that we know. I think the discussion of asymmetric G loads, for example, is important and timely. Even if it turns out to be irrelevant to the loss of the -8 it is a good topic to discuss, and one that was not covered when I went thru civilian ground school in '85. Tim Lewis Riveting the FAB tonight with flush sets _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023 on gear, engine mounted Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ________________________________________________________________________________
Date: Jun 02, 1998
You asked: > > In the rib attach dwg. for the 404&405, it shows that there are 4 > rivets,one thru 404,610,602&405 / one thru 404,614,602&405. Where I'm > running into confusion is how the 2 center rivets, that join the > flanges > of the 404&405,with the 602 sandwiched in between , fit because there > is a > (+/- ) 1/8 inch gap between the 404 flange and the 602.?! This is > because > the 404 bridges across the 610&614. > Marc: If you look at Drawing 3, about the center of the page, you will see a detail which shows that the edges of 404 are removed so that the rib does NOT sit up on 610/614, but snuggles right down between, and flush. Yes, I didn't catch it at first either, and couldn't figure out for the longest time how those pieces were supposed to slip in without bending things. Keith Jensen -6A HS just done > ________________________________________________________________________________
Date: Jun 02, 1998
> ---------- > From: Terrence C. Watson[SMTP:tcwatson(at)pstbbs.com] > Sent: Tuesday, June 02, 1998 2:37 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: RV-8 Crash snippet from Avweb > > > > > I think an apology is due to Major Tim Lewis. > Terry Watson > RV8 #729 > Seattle > Terry, Tim, et al: I agree - I sent this to Tim privately earlier, but in light of Terry's comment, I see it needs to be published as broadly as my mistake. My apology to the entire list. Keith Jensen > ---------- > From: Jensen, Keith (MC R&D) > Sent: Tuesday, June 02, 1998 5:01 PM > To: 'lewisth(at)af.pentagon.mil' > Subject: apology > > > Tim: > I posted an email concerning the avweb notice of the > RV-8 crash you posted, in which I implied something really stupid. I > apologize for the innuendo. I'll be kicking myself a while for that > one. If you feel this needs to be posted to the list in order to make > good the apology, by all means do so. > > Keith Jensen > ________________________________________________________________________________
Date: Jun 02, 1998
> Some of you guys need to lighten up, this is suppose to be fun, add a little > humor to your life! > > Bob Busick > Imaginary RV-6 > Fremont CA Bob, I've been down a month waiting on parts for my overhaul. Ha ha, boy am I having fun now. I can tell you haven't got yours built yet. Jim Nolan N444JN ________________________________________________________________________________
Date: Jun 02, 1998
Subject: [Fwd: RV seats]
Here is more mail from Jon's group. Another question brought up is import duties. Does anyone know if this would apply to a seat order from Jon in Australia? (with Cubic Circle's cucipop (v1.21 1997/08/10) Tue Jun 2 18:33:46 1998) Date: Wed, 03 Jun 1998 00:31:47 +1000 From: Bruce Johansen <bjjoey(at)writeme.com> Subject: Re: RV seats <3.0.5.32.19980529214527.00796660(at)mail.netconnect.com.au> Good morning Michael. In answer to your questions:- >What method of payment do you require. Master card or Visa card can be arranged or else a bank draft sent to me will work. >how many seats can you fit to one box? How big a box would you like? :) We will make the box to suit the order but more than four per box could be stretching things a bit. >are the seats attached in any way to the fuselage. In NOJ no, there is no need in the front but in the back it would be easy to fix them to a solid pivot on the floor. This is what I will be doing when I can but it is not really necessary. >do you lose any leg room with them? In the front no. For the passenger yes, a little. There is still plenty of room for a passengers feet and legs but they will need to move their left leg when it is time to use the manual flaps. The biggest complaint I have from passengers is that the forward visibility is reduced when it comes to them looking at the instrument panel and directly forward - a valid complaint. >One more thing, when can we expect to receive them after >they are ordered? Seats should be ready for shipping in 10 working days from receiving the order. Shipping is usually 7 - 10 days to the USA. Till next time all the best, Jon Johanson ________________________________________________________________________________
Date: Jun 02, 1998
The 404 flange must be trimmed to fit between the 810 & 814. The outboard rivets do not go through the flange of the 404 rib, as the flange there must be trimmed away. There is a picture of this on the Horizontal Stab section of my web page. -- Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 page at: http://members.bellatlantic.net/~moejoe m.hanson wrote: > > > Just when I thought I might know more than just how to drill a hole... > I'm in the process of drilling skins and ribs on the HS and have run into a > conflict between how I read the plans and what I'm actually seeing on the > HS. > In the rib attach dwg. for the 404&405, it shows that there are 4 > rivets,one thru 404,610,602&405 / one thru 404,614,602&405. Where I'm > running into confusion is how the 2 center rivets, that join the flanges > of the 404&405,with the 602 sandwiched in between , fit because there is a > (+/- ) 1/8 inch gap between the 404 flange and the 602.?! This is because > the 404 bridges across the 610&614. I must be missing something, because > this does not look the way it is shown in the plans and I'm at a stand > still because I don't know what to do with it!!! I did trim the 404 to fit > around the 614, am I supposed to trim somewhere else? Thanks for any help. > > Marc Hanson > RV-6A HS in progress? > paintbox(at)rconnect.com > ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: Rotary engines in RVs
<< Still no answer to the original question. And the question is......... > >I'm tooling down the road in my RX7 at 4000 rpm.... > >What's the tachometer reading; the rotors or the shaft? The shaft. >> Great!!! That means the shaft, a hunk of metal maybe an inch and a half in diameter is doing a piddling 4000 rpm of pure rotation while the rotors are doing 1/3 of that and rotating as well. That's a very low stress condition and definately not comparable to a recip engine's 4000 rpm. I like a rotary even more, now. Thanks!! Bob ________________________________________________________________________________
Date: Jun 02, 1998
<< It has to break somewhere, and the real question is how many G's did N58RV experience prior to the accident? >> Nope....the real question is - what happend? Answer that first, then go on to the diagnosis. beware assumptions and newsflashes. bob Fritz ________________________________________________________________________________
Date: Jun 02, 1998
You are not apprehensive??? How can a wing break, cause a terrible tragedy, and you not be apprehensive. My wing kit will stay in the box until some answers appear. You bet I am apprehensive. hilljw(at)aol.com ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Trim Tab tabs
Hi Fellow Rivet Rammers: I am about to go where this man has never gone before, and bend the tabs for the ends of the trim tab and the outboard side of the cutout for the trim tab in the left elevator. I am in a quandry as to where to make the bend for the tabs in the elevator. I see on the plans where the fold line should be for the trim tab, but not for the elevator. I want to make these bends so that the gap at the outboard edge of the trimtab and the elevator is even along its length. How did the group do this? I am thinking that the best way would be to do the bends in the trimtab, set the trim tab in place in the cutout in the elevator, and then transfer the angle the outboard end of the trim tab has to the tabs on the elevator. Sound like a plan, or is there an easier way? This is all assuming that I don't mess up these bends and end up making little ribs anyway! Thought I would at least give it a college try. Thanks for the advice, group. Regards, Jeff Orear RV6A 25171 left elevator and scary tab bends. Peshtigo, WI ________________________________________________________________________________
Date: Jun 02, 1998
<< VERY unscientific method of airflow analysis, but I can also see places I need to improve on the coweling from the bug hits (as if I needed them to know that), and the blister I made for the alternator bracked aligns exactly with bug bodies.>>> ---------- Don't count yourself out, Michael. Forensic science uses maggots and flies to determine time of death! >> ---------- Anybody know the whole story of the RAF gluing split peas to the wings of the Splitfire (oops!) Something to do with airflow analysis as I remember...they kept gluing them on to check airflow patterns. Maybe they should have used Michael's BAFALED. (Bug Airflow Forensic Analysis and Laminar Evaluation Determinator) :-) Bob Fritz ________________________________________________________________________________
Date: Jun 02, 1998
A real live picture is worth a thousand words. Moe's got a good one illustrating the 404 on http://members.bellatlantic.net/~moejoe/HS.htm under the "Drilling the skin to the skeleton" section. Larry larry(at)bowen.com RV-8 emp. -----Original Message----- From: owner-rv-list-server(at)matronics.com Sent: Tuesday, June 02, 1998 6:27 PM Subject: Re: RV-List: reality vs the plans-HS assembly m.hanson wrote: > > > Just when I thought I might know more than just how to drill a hole... > I'm in the process of drilling skins and ribs on the HS and have run into a > conflict between how I read the plans and what I'm actually seeing on the > HS. > In the rib attach dwg. for the 404&405, it shows that there are 4 > rivets,one thru 404,610,602&405 / one thru 404,614,602&405. Where I'm > running into confusion is how the 2 center rivets, that join the flanges > of the 404&405,with the 602 sandwiched in between , fit because there is a > (+/- ) 1/8 inch gap between the 404 flange and the 602.?! This is because > the 404 bridges across the 610&614. I must be missing something, because > this does not look the way it is shown in the plans and I'm at a stand > still because I don't know what to do with it!!! I did trim the 404 to fit > around the 614, am I supposed to trim somewhere else? Thanks for any help. > Hi Marc, The 404 is trimmed to fit over the 610 & 614. The 404 is held to the 602 and 405 with the center two rivets only. It's hard to picture, but drawing 3pp shows(about in the middle of the sheet) how the 404 is trimmed to fit over the 610 & 614. Jerry Calvert Edmond Ok -6a ________________________________________________________________________________
Date: Jun 02, 1998
Subject: HVLP via Binks gun
I just bought a new Binks gun and it is great!!! I'm totally unexperienced with spray guns but this thing makes me look like I know what I'm doing....so far. It's non-turbo so it doesn't suck in the dried paint that floats around the shop and it doesn't get warm with use like I was told a turbo gun would. (any corroboration to that out there?) I shot the barbeque and then a couple of picture frames and they came out really great. Beginner's luck maybe, so I'd like to hear from others before diving into the sheet metal of my a/c. Anybody got some tips re: technique, pressures, paint thinning? $400 is kind of 'spensive for a paint gun (especially if all I do is the barbeque!) but a whole lot of fun and whole lot cheaper than paying somebody to do it. Besides, what's the re-sale value when I'm done? Makes it a bunch cheaper. Come to think of it, that's less than a decent turbo rig so that's a wash. Grinning over my just received 6QB kit. Bob Fritz ________________________________________________________________________________
Date: Jun 02, 1998
I heard that a Bonanza crashed the other day. Seems it came apart in the air. There were no witnesses, so structural failure was blamed. All Bonanza owners are apprehensive. It may just be a rumor. ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: HS608 rivetting problem
John Walsh emailed me yesterday with the suggestion to put the mfr head on the rib flange AND use the gun instead of the squeezer. As Scott McDaniels' post indicated, when one piece is a lot heavier material than the other, this produces better results. I tried it last night and it worked well. I used an offset rivet set so as to minimize the bending of the rib (you have to push it aside to get the rivet gun lined up). The rivet gun is a little harder for me to get good results with, but I'm getting better. A few hundred more rivets and I'll be a pro. --- Tom Sargent, sarg314(at)azstarnet.com ________________________________________________________________________________
Date: Jun 03, 1998
>I have the exact problem with my HS606 this past Sunday. I don't have >>a >>feeler gauge, but could see light between the two surfaces that were >>perfectly flush before I squeezed the rivets. I am still debating on >>what >>to do about it, and have stopped riveting ribs for the time being. >> >Larry ( & Tom), > >What you are describing is something that happens (to a varying degree >depending on the situation) some times when you squeeze rivets. It will >tend to pucker the material under the shop head of the rivet. As long as >the parts were tight together when you began squeezing the rivet, and the >rivet is proper formed, you have nothing to worry about. > >Because of the problem you describe, The preferred orientation is always >to put the manufactured head on the thinner material. Unless there is a >particular reason for a different orientation (which there some times >is). In many cases the materials are the same thickness, then it wont >matter which way you put it. You are probably riveting ribs to the rear >horizontal stab. spar which because it looks nicer the manufactured heads >have traditionally been put on the back (out side) side of the spar. >Feel free to turn them around the other way if you want. You will >probably be happier with the results you get and know one will ever >notice the difference. > For some reason if you use a gun and a bucking bar you see much less of >this happening. So that would be another option also. >Final note, when we are talking about 2 or so rivets at each end of the >ribs in a structure like the stabilizers, a major function of them is to >hold the framework together while you get the skin put on it. >Most of the strength in these structures is from the 2 spars and the skin >itself. >(This is not license to be sloppy with these rivets, It just means minor >gaps and such wont have any negative effect on the final strength of the >structure in this case) >If the rivets them self look good, just keep on riveting! > > >Scott McDaniels Scott, This is a great reply. I remember going through the same period of worry myself back in horizontal stab days. This would be worth adding to the preamble in the manual - it causes heart burn for every first time builder. Leo Davies ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: O-360 for sale
Subject: Lyc O-360 A1D Date: From: Roger Mellema mail.halcyon.com Newsgroups: rec.aviation.marketplace Lycoming O-360 A1D engine. From 1968 Mooney damaged in hurricane - logbooks lost. The following are included: mags redone, carb redone (also have Ellison for $1500), Woodward prop governor, Pesco wet vacuum pump, flywheel modified for Light Speed ignition, good alternator, starter, oil filter adapter. Engine was recently run for a couple of hours. Hot oil pressure is top of the green, compression is 76 / 80. Everything worked perfectly including the prop governor. Engine is extremely clean inside and out, rubber is still soft. My guess is that the total time is less than 1000 hours. Also Hartzell constant speed prop (compact hub) freshly overhauled. It is 72 inches long. HC-C2YK1-A with 7666 blades. Package ~ $12,000, or best offer. Will sell separate. Reply via email. rmellema(at)who.net -- Roger D. Mellema Editor: BD-4 Builder's Newsletter BD-4 with Ford 3.8 L V-6 2/3 P-51 with 351 Ford V-8 Rotordyne tandem Gyroplane with Lyc O-290 rmellema(at)who.net http://www.halcyon.com/www2/rmellema/BDindex.html ________________________________________________________________________________
Date: Jun 02, 1998
From: Charlie and Tupper England <cengland(at)netdoor.com>
> I'm tooling down the road in my RX7 at 4000 rpm.... > > What's the tachometer reading; the rotors or the shaft? > the shaft ________________________________________________________________________________
Date: Jun 02, 1998
Subject: FAA and NTSB listings.
Some one asked. accident and incident reports are found here: The following provides the most timely info I have found, with most postings occurring the next day: http://www.faa.gov/avr/aai/iirform.htm More complete synopses of accident reports can be found on the following, but about 12 to 18 months later: http://www.canard.com/ntsb/months.htm Ken Smith. kpsmith(at)ais.net Dusty RV6 HS in the jig. ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re:BFL Fly-In (info needed)
I've attended the fly-in the last seven years,( this will be the first one I've flown to in my RV!). We usually see around 50 - 75 RV's fly-in. Attandance is usually around 300 people for the BBQ. The BBQ starts around 3-4pm. Lots of RV's, lots of nice people, and lots of great food! Walt. RV-6A 79WH ________________________________________________________________________________
Date: Jun 02, 1998
Oh yeah, I forgot: The chapter welcomes ALL aircraft, not Just RV's! ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: RV-8 Crash snippet from Avweb
<< You are not apprehensive??? How can a wing break, cause a terrible tragedy, and you not be apprehensive. My wing kit will stay in the box until some answers appear. You bet I am apprehensive. hilljw(at)aol.com >> I strongly recommend that WE STOP this "thread" right here... until the official results come out. PLEASE. ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Bill Benedict is right. RV-8 info on the web.
Info was posted to their web site on 6/1/98. http://www.vansaircraft.com/sections/n58rv.htm It takes a lot of patience to build an airplane. Waiting for answers is part of the trait necessary to see a project through to completion. I will be flying my RV to Bakersfield with its new paint for the RV BBQ. See you there. Good luck with your building. == Gary A. Sobek RV-6 N157GS O-320 Hartzell So. CA, USA RV6flier(at)yahoo.com ________________________________________________________________________________
Date: Jun 02, 1998
Subject: -8 ACCIDENT
Folks Please try to have patience in this RV8 Accident issue. This has probably been a pretty tough week for Van and his staff. Also, this is a sensitive issue, too. Who or what do we blame for this accident? I am quite sure that there will be more destructive testing of RV8 parts, but this, of course, takes time. Just my two cents worth. Jim Nice RV6A WA State ________________________________________________________________________________
Date: Jun 02, 1998
Subject: trim tab tab
Hi group, its me again: Was just doing some head-scratching about where to put the bend lines for the tabs at the outboard end of the trimtab cutout in the left elevator, when I had a revelation, no, a darn right vision! (At least for me!) Is this bend perpendicular to the trim tab hinge line?? Could it be that easy? Say it's so! Hoping I answered my own question. I gotta stop talking to myself like this! Regards, Jeff Orear RV6A 25171 Left elevator and trim tab Peshtigo, WI ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: -4 &-8 underwing air inlet
>> >>The underwing inlet using the SV-kit What did you use to attatch the vent to the wingskin.....proseal or rivets.? Marc DeGirolamo mdee(at)dlcwest.com can..oh!....p--- ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: [Fwd: RV seats]
Hi Michael, I'm ready to order. Just let me know what the next step is. Thanks, Wally Hunt RV4WGH(at)aol.com 815/332-4708 Rockford, IL ________________________________________________________________________________
Date: Jun 03, 1998
>Scott: >Jeez- the ONE TIME I decide to tell the world I had an idea,...it >turns out >somebody else had it first. Aaargh. My mom told me that there would be >days >like this! My apologies, sir. > None necessary... like I said it wasn't my idea either. It was my idea to try and develop it into a standard kit item. Some of the early RV-8 wing kit builders probably wondered why their kit had no info about installing the vent. That is because when those first wing kits went out we hadn't yet flown N58RV to allow doing any testing. After we had verified that it worked fine (almost too good) it was added into the kit. I can't remember for sure, but I think we even prepunch the opening in the bottom skin now. >I had thought I had come up with a nifty application because after >viewing the >-8 at one of its early airshows, I chided Bill about having put the >scoop on >the 'wrong' side. I decided we should put it on the right side just as a safety precaution for exhaust fumes. The prop wash spiral tends to be going around towards the left side as it curls under the belly. This turned out to be no factor though as we found out from the blue RV-8 prototype when it had a airshow smoke system installed for a while. When flying tight formation on it with the smoke on the exhaust stream wasn't even 18 in. in diam as it passed the tail wheel. He said that he told the shop guys to just put the >thing in, >without specifying left or right. When the gen mgr of Van's, Inc. >tells me >something, I tend to believe him. Heck, his desk is right over there- >go ask >him Actually its about 1 1/2 miles from the engineering/prototype shop. (as if at this point he doesn't have anything else on his >mind...:-( ). > >But, if what you write is correct, I'd say that more than one of us >figured >out that the high pressure air is on the bottom! That Bernoulli guy >was right! Yup, which also helps prove how great an idea you had! Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Re: HVLP via Binks gun
I have a wagner cap spray hvlp that I used to paint my RV4. I"ve also used a regular spray gun. I swear by the hvlp!! You never run out of air. It is extremely portable. IT uses much less paint and gives a professional job with little experience. As for resale value, I was going to sell it after I painted my first a/c. It has now painted 2 aircraft and I wouldn"t think of selling it!!!! RV273sb Co. ________________________________________________________________________________
Date: Jun 03, 1998
QmaxLLC(at)aol.com wrote: > That [4000 rpm on a rotary] is a very low stress condition > and definately not comparable to a recip engine's 4000 rpm. That's not a fair comparison. You should be comparing 6000 rpm on the rotary to 2900 rpm on a Lycont. You won't be running a rotary at 4000 rpm. It won't generate enough power. (What engine *does* deliver *enough* power?) You'll need to run the engine at 5000-6000 rpm, then reduce the shaft speed via a gearbox (PSRU) to produce 2400-2900 rpm at the prop. Not that that means a rotary isn't better than a Lycont -- just that you should be using the right comparison to demonstrate it. Frank. ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Cleaning of Instrument Glass
Listers; I have a couple of instruments, a VSI and a Turn and Bank, that have a sort of cloudy look to them. Upon close examination I see that this cloudiness is actually a film on the inside of the glass. Can these instruments be disassembled and the glass cleaned and reassembled by us? Or are they vacuum sealed? Or do they have to be sent to an Instrument shop? It looks like about 5 tiny screws that hold the front portion of the instrument together including the glass. Any tips? Thanks. Von Alexander RV-8 #544 Skinning the fuse ________________________________________________________________________________
Date: Jun 03, 1998
<< I heard that a Bonanza crashed the other day. Seems it came apart in the air. There were no witnesses, so structural failure was blamed. All Bonanza owners are apprehensive. It may just be a rumor. >> Was it the prototype? -GV ________________________________________________________________________________
Subject: Van's website
Date: Jun 02, 1998
In case anyone didn't know, Van's website is keeping a dedicated "button" (link) to a site regarding details of the -8 accident. They'll probably post there before any other list, I'd imagine. As of 6/2 they can't of course say what happened, but acknowledge that it appears to be an inflight airframe failure, though the subsequent impact damage makes it difficult for Van to determine what went wrong. If anybody doesn't know, their address is >> vansaircraft.com << Keep the faith, and keep on building. John -4 wings No. Calif ________________________________________________________________________________
From: "Nigel Marshall" <Nigel_Marshall(at)meritorauto.com>
Date: Jun 03, 1998
They did it on the prototype to determine for production which areas needed to be flush-rivetted, and which could be rivetted with 470 type rivets without reducing the top speed; the full story is in the autobiography of the test pilot, Jeffery Quill. Nigel Marshall Chevreuse, France RV-4 (# 4062) Starting second wing marshan(at)meritorauto.com QmaxLLC(at)aol.com on 02/06/98 21:12:21 Please respond to rv-list(at)matronics.com Subject: Re: RV-List: Glad I built 'em << VERY unscientific method of airflow analysis, but I can also see places I need to improve on the coweling from the bug hits (as if I needed them to know that), and the blister I made for the alternator bracked aligns exactly with bug bodies.>>> ---------- Don't count yourself out, Michael. Forensic science uses maggots and flies to determine time of death! >> ---------- Anybody know the whole story of the RAF gluing split peas to the wings of the Splitfire (oops!) Something to do with airflow analysis as I remember...they kept gluing them on to check airflow patterns. Maybe they should have used Michael's BAFALED. (Bug Airflow Forensic Analysis and Laminar Evaluation Determinator) :-) Bob Fritz ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Re: Cleaning of Instrument Glass
If you are careful you can do this but there is a chance you may tear the gasket for the glass depending on how old they are. Good Luck! Dave Funk Workin on elevators! ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Hitching a ride to Bakersfield from San Diego
Is anyone flying to the Bakersfield Fly-In this weekend from the San Diego area who needs some company on the trip? I haven't been in a light plane in ages (years) while I've been building and it's too far to drive. OK, so I'm begging, but I can't make it to OSH this year (or last year for that matter) and I need my RV fix! Replies to wbpace(at)adnc.com or calls to my machine at 619-549-8796 will receive a warm welcome. :-) ----- Bill Pace San Diego, CA wbpace(at)adnc.com RV-6A Skinning left wing ________________________________________________________________________________
Date: Jun 03, 1998
With all due respect to David Fox and his very excellent formula, consider that it is not necessary to fly these tracks at 90 degrees etc etc in order to compute TAS. All that is necessary is to record the ground speed and track for ANY three legs. This is sufficient to resolve wind speed and TAS. I have written up a description of the calculation (with spreadsheet formulae) required and Bob Nuckolls has been kind enough agree to put a PDF version on his website. I expect Bob will drop a note on the 'list when it is available. Doug Gray RV-6 LH elevator. Sydney, OZ > David Fox's GPS TAS formula, so here is > a summary of his Feb 1995 Kitplanes article. > > Using GPS or Loran, fly straight and level flight on any track (not > heading), record the ground speed, call it V1. Turn left or right to a > track 90 degrees from the first, record the second ground speed and call it > V2. > Turn another 90 degrees in the same direction to a third track 180 degrees ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Primer over Sealer
I'm about ready to mount my gas tanks and wanted to prime the metal to metal areas of the tank. Does anyone see any problem with some primer overspray ending up on the tank sealer (Thiokol MC 236 B-2) on the tank baffles or tank end ribs? I'll be using either NAPA #7220 or Vari-Prime. Thanks Fran Malczynski Olcott, NY RV6 (Wings) ________________________________________________________________________________
Date: Jun 03, 1998
In a message dated 6/3/98 2:53:23 AM Eastern Daylight Time, frankv(at)pec.co.nz writes: << That's not a fair comparison. You should be comparing 6000 rpm on the rotary to 2900 rpm on a Lycont. >> I think everyone is getting all wrapped up in RPM as an indication of stress, and you can only do that if you are comparing reciprocating to reciprocating. Rotary engines do not have the severe acceleration/deceleration forces of a reciprocating engine, therefore by the laws of physics, the stresses are not necessarily the same. Rotary engines can (and do) see RPM's in the 15,000 range in race applications, but you better not try that with a piston engine. If you want a fair comparison, you need to examine aspects of the dynamic process that are common to both engines. Regards Merle (more opinions than I can put in print) Miller ________________________________________________________________________________
Date: Jun 03, 1998
John L. Switzer wrote: > Carroll: > > If you look at the AVWEB web page, the "newswire" version of the story does > contain the satement mentioned. The email version does not. John: I stand corrected, however I don't know where or how to receive the newswire. This brings a few questions to my mind though. How does AvWeb know how to get hold of RV-8 builders? How many of them did they poll? Of those polled how many answered that they were apprehensive? It seems to me that this is one of the ways those damned lies get started. Regards --- Carroll ________________________________________________________________________________
Date: Jun 03, 1998
Request >Actually Bill said, "We would like to keep the rumors to a minimum and intend to >inform this group of any findings as soon as available. We would appreciate people not >speculating as to the cause of the accident." He also said "Although the NTSB may >take weeks or months to reach a conclusion, Van should be able to provide some details >by the end of the week." (posted 5/25) I don't believe we've heard anything more from >Van's since that post. Besides starting an accident investigation, Vans and his employees had to deal with the funeral of a colleague last week. What ya say we cut them some slack? Scott Gesele (Flying my 6A and wouldn't hesitate to jump into an 8) ________________________________________________________________________________
Subject: Titanium Tailwheel Strut
Date: Jun 03, 1998
I have a couple of titanium (grade 2) tailwheel struts. The titanium struts are dimensionally the same as my RV-8 tailwheel strut (I assume they are all the same size). I am not going into production with these things (takes too much of my time to make these cost effectively). However, I will take offers for the struts directly at jonesb(at)geon.com. The weight savings is aproximately 1-lb 3-oz. Could be a real bonus for a tailheavy plane! BTW, one of the struts is drilled and the other is not. Bryan Jones, Pearland, TX RV-8 80313, attaching empenage to fuselage ________________________________________________________________________________
Subject: Re: RV-8 confidence
Date: Jun 03, 1998
Cute, Very Cute, You say marketing is marketing and proceed to use slanderous innuendo against Van's, then admit your not a business man. I'd suggest your not much of a scientist either. You say "IF" the structure, twice and" MAYBE" once, and then proceed to be an authority by telling people to avoid allowing their friends and relatives to fly in the machines. Well ,from the scientific standpoint, you don't know anything about it. Just if's and maybe's, just like the rest of us. And from the business standpoint you have just done a great job of trying to destroy the company that builds our kits. Then you just spew this stuff out to one thousand people and then have the gall to say you'll receive flames privately. Well, this is a list of people who are sharing information on how to build Van's kits and here you are posturing yourself and at the same time destroying the very company we need. So I'd like to say this. Shut up. If I here any more of this innuendo from you I'll be on the phone to Matte Dralle asking if he can find you a different list list for you to expound your "realism" on Larry Mac Donald lm4(at)juno.com << Yesterday at our builders-group-pot-luck-rv-fly-in the guest of honor was Bill Benedict from Vans flying the 8A. He gave demo rides to Marketing is marketing and Science is Science. Great rhetorical question and this was quite possibly an irresponsible activity if the structures between this a/c and the prototype are identical, >condoning the taking of women and children up until I knew EXACTLY what happened. maybe there is a major difference (between the two a/c)that I'll be happy to receive flames if put to me directly (not to the list). >-GV ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Please Read
Gentleman, There is so much useless non-technical, non-RV spam coming from this list it diminishes the value of subscribing. Please reread the RV list policies and abide to make it a better list. ________________________________________________________________________________
Date: Jun 03, 1998
Subject: bondo and prepping
What does one use to blend the fiberglass tips to the edges of the skins? I seem to remember seeing something like Bondo...also, what is used to prep the surface before adding primer? I currently use a cleaner from sherwin williams for all my priming needs...is there anything to know about adding primer on top of Bondo? (or the aircraft equivalant) Thanks in advance.. Paul Besing RV-6A (197AB) Arizona Mounting empennage ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Re: Trim Tab tabs
jorear(at)mari.net wrote: > > Hi Fellow Rivet Rammers: > > I am about to go where this man has never gone before, and bend > the > tabs for the ends of the trim tab and the outboard side of the cutout > for the trim tab in the left elevator. I am in a quandry as to where > to > make the bend for the tabs in the elevator. I see on the plans where > the fold line should be for the trim tab, but not for the elevator. I > > want to make these bends so that the gap at the outboard edge of the > trimtab and the elevator is even along its length. > > How did the group do this? I am thinking that the best way would > > be to do the bends in the trimtab, set the trim tab in place in the > cutout in the elevator, and then transfer the angle the outboard end > of the trim tab has to the tabs on the elevator. Sound like a plan, > is there an easier way? > > This is all assuming that I don't mess up these bends and end up > making little ribs anyway! Thought I would at least give it a college > > try. Thanks for the advice, group. > > Regards, > Jeff Orear > RV6A 25171 left elevator and scary tab bends. > Peshtigo, WI > > Jeff, You might think about making some small ribs vs. bending. I did that with mine and it came out very clean. There should be posts in the archives concerning this. Ed Cole RV6A Fuselage ready to skin Cupertino, CA ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Split a mag kit?
I am looking for someone that wants to split a Slick mag kit (2 new mags plus a harness for each). The kits come with one impulse mag and one non-impulse mag. I am using Jeff Rose's electronic ignition, so I only need one, but you get the best buy if you buy a kit. If you are thinking of doing the same, then this could save us both a few hundred dollars on a new mag purchase, especially if you don't have a core. I spoke with Jeff about this last weekend and his mag can easily be used to start the engine and can go in either the left or right side. The slight advantage of having the impulse mag is that starting would be easier with it should the electronic unit quit. Other than that, it's just a matter of being sure you have the mag that's correct for your engine. If you are interested, please e-mail me privately. -eric ________________________________________________________________________________
Date: Jun 03, 1998
Larry Mac Donald wrote: > > Cute, Very Cute, > You say marketing is marketing and proceed to use slanderous > innuendo against Van's, then admit your not a business man. > I'd suggest your not much of a scientist either. You say "IF" the > structure, twice and" MAYBE" once, and then proceed to be an authority > by > telling people to avoid allowing their friends and relatives to fly in > > the machines. Well ,from the scientific standpoint, you don't know > anything about it. Just if's and maybe's, just like the rest of us. > And > from the business standpoint you have just done a great job of trying > to > destroy the company that builds our kits. Then you just spew this > stuff > out to one thousand people and then have the gall to say you'll > receive > flames privately. Well, this is a list of people who are sharing > information on how to build Van's kits and here you are posturing > yourself and at the same time destroying the very company we need. So > I'd > like to say this. Shut up. If I here any more of this innuendo from > you > I'll be on the phone to Matte Dralle asking if he can find you a > different list list for you to expound your "realism" on > Larry Mac Donald lm4(at)juno.com > Easy Larry, easy! If you take the time to read what Gary said, and read it objectively without emotion , he makes some good points. We all respect Van and what he has created. I think we all want rush to defend Van's and his products. It's almost like someone said something bad about your Dad! I suspect if you owned a car that had a potential serious defect, you would demand information and expect the manufacturer to investigate and possibly suspend production on his product. I know Gary, although not that well, but I have come to respect his style and ideas. He is one of the more conscientious builders I know and his aircraft reflects this. If you have been on this list for some time you'll find that Gary seldom replies unless he has something beneficial to input.( Besides this, he is a good friend of Matt Dalle and they are located at the same airport. So good luck getting him off of the list) Let's all lighten up about this until the facts are in. This has been a tough week for all of us with the RV8 crash, the Papa 51 crash, and the Warrior II I flew last a week ago Tues. crashed Friday and killed all 4 on board. Ed Cole ________________________________________________________________________________
Subject: Prop question
Date: Jun 03, 1998
Does anyone on the list know if a c/s Hartzell prop from a 1967 Mooney M20C will work on an RV - 6? I have noticed that Van sells a compact hub prop. What's the significance of this and is the Mooney prop a compact hub. Do some c/s props have G load restrictions. Any help will be appreciated. Ken Harrill RV - 6, fuselage ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Re: trim tab tab
Hello, I took a small carpenters square, rested it on the edge of the skin where the trim tab hinge goes and marked a line to center of the notch at the tip of the tab to be bent. My skin had a note telling me that the semi-circular notch at the corner was not at required depth. My line showed this to be true. Thus I deepened the notch and did the bend. Frankly I had more trouble with the actual bending of the tab than with marking it. I have just finished the Left Elevator + trim tab and my alignment worked out according to plans... notice I didn't say perfect :) Vince Himsl RV8 Wings Moscow, Idaho > >Hi group, its me again: > > Was just doing some head-scratching about where to put the bend >lines for the tabs at the outboard end of the trimtab cutout in the left >elevator, when I had a revelation, no, a darn right vision! (At least >for me!) Is this bend perpendicular to the trim tab hinge line?? Could >it be that easy? Say it's so! > > >Hoping I answered my own question. I gotta stop talking to myself like >this! > > >Regards, >Jeff Orear >RV6A 25171 Left elevator and trim tab >Peshtigo, WI > > > > > > > ________________________________________________________________________________
Date: Jun 03, 1998
From: Thomas Nguyen <TNGUYEN(at)oss.oceaneering.com>
Subject: Re: Lets Respect Bill Benedict*s_ Request -Reply
Listers, I am whole heartly agreed with Scott Gesele. Let's try to keep the rumors and speculations to the minimum. I am sure that we will be informed when the facts are available. I have lots of respect for Van, Bill and their organization and I would not hesitate to take a demo ride in an 8. T.Nguyen, PE Analysis Engineering Manager Fuselage in jig. >>> Scott Gesele 06/03/98 08:07am >>> >Actually Bill said, "We would like to keep the rumors to a minimum and intend to >inform this group of any findings as soon as available. We would appreciate people not >speculating as to the cause of the accident." He also said "Although the NTSB may >take weeks or months to reach a conclusion, Van should be able to provide some details >by the end of the week." (posted 5/25) I don't believe we've heard anything more from >Van's since that post. Besides starting an accident investigation, Vans and his employees had to deal with the funeral of a colleague last week. What ya say we cut them some slack? Scott Gesele (Flying my 6A and wouldn't hesitate to jump into an 8) ________________________________________________________________________________
Date: Jun 03, 1998
I agree with the quote from Merle below, except that some race piston engines do see around 16,000rpm, if I remember correctly. F1 engines. The valve springs were the limiting factor and now they use air pressure instead. >reciprocating engine, therefore by the laws of physics, the stresses are not >necessarily the same. Rotary engines can (and do) see RPM's in the 15,000 >range in race applications, but you better not try that with a piston engine. >If you want a fair comparison, you need to examine aspects of the dynamic >process that are common to both engines. > -Ian ________________________________________________________________________________
From: "Moe Colontonio" <moejoe(at)bellatlantic.net>
Date: Jun 03, 1998
Sorry, but I've got to agree with GV on this one. If one of two prototype aircraft broke up in flight for no apparent reason, you bet your ass the Air Force would ground the other until the reason is found. If Van landed in the street in front of my office right now, I wouldn't hesistate to jump in and take a ride, but I would not allow my girlfriend or sister to get in the plane. On the other hand, I know that Van has no bad intentions here. If there is a problem, it will be resolved. Van may also know something that we do not. Maybe the airframe wasn't the problem. We will probably not get any hard info until the next RVator. Flame me all you want, on or off list. Moe Colontonio http://members.bellatlantic.net/~moejoe > >Cute, Very Cute, > You say marketing is marketing and proceed to use slanderous >innuendo against Van's, then admit your not a business man. >I'd suggest your not much of a scientist either. You say "IF" the >structure, twice and" MAYBE" once, and then proceed to be an authority by >telling people to avoid allowing their friends and relatives to fly in >the machines. Well ,from the scientific standpoint, you don't know >anything about it. Just if's and maybe's, just like the rest of us. And >from the business standpoint you have just done a great job of trying to >destroy the company that builds our kits. Then you just spew this stuff >out to one thousand people and then have the gall to say you'll receive >flames privately. Well, this is a list of people who are sharing >information on how to build Van's kits and here you are posturing >yourself and at the same time destroying the very company we need. So I'd >like to say this. Shut up. If I here any more of this innuendo from you >I'll be on the phone to Matte Dralle asking if he can find you a >different list list for you to expound your "realism" on >Larry Mac Donald lm4(at)juno.com > ><< Yesterday at our builders-group-pot-luck-rv-fly-in the guest of >honor was Bill Benedict from Vans flying the 8A. He gave demo rides to > > Marketing is marketing and Science is Science. > >Great rhetorical question and this was quite possibly an irresponsible >activity if the structures between this a/c and the prototype are >identical, > >>condoning the taking of women and children up until I knew EXACTLY >what happened. > maybe there is a major difference (between the two a/c)that > > > I'll be happy to receive flames if put to me directly (not to the >list). >>-GV > ________________________________________________________________________________
Subject: Titanium tie-downs
Date: Jun 03, 1998
Anybody know where Randy Simpson is ? Trying to reach him about those neat tie-downs. Please reply if you have info.................Thanks......Austin. ________________________________________________________________________________
Date: Jun 03, 1998
Or maybe you are just kidding??? All Bonanza owners with the V tail are apprehensive and have been for years. They have had tails fall off - on rare occasion. There is a 'fix' but then when overstressed the wings come off. Hal Kempthorne RV-6AQ -- Looking for an airport halk(at)sybase.com Santa Clara, CA. Debonair N6134V @ SJC > I heard that a Bonanza crashed the other day. Seems it came > apart in the air. There were no witnesses, so structural failure > was blamed. All Bonanza owners are apprehensive. It may just > be a rumor. ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Re: Fuel Injection Heat Problems---Help!
I've also have a bit of a heat problem with my injected RV-6. When going to near idle to slow down enough to lower the flaps, the engine sometimes cuts out a little. Add some throttle and it smooths out. However, it does get my attention. I turn on the fuel pump when I start to slow down and leave it on until I shut down at the hanger. No trouble restarting after being heat-soaked, but I have a purge valve just ahead of the flow divider on top of the engine. I can recirculate cool fuel through the fuel lines and fuel controller before starting. Runs a little rough taxing out to take off, but after a runup it has always been smooth on takeoff. I have a forward pointing fuel controller with the intake horn just below the prop. I also have a crossover exhaust above the fuel contoller. I made a shield and wrapped the pipes to help control the heat. I probably should have used 4-into-1 exhaust. I still can try enclosing the mechanical fuel pump and cooling with a blast tube and rerouting the fuel line from the pump to the fuel controller. I hadn't thought of the fuel boiling in the little tubes to the injectors on top of the engine. If you insulate these somehow, let us know how it worked. Dick Steffens, RV-6, flying, North Carolina ________________________________________________________________________________
Subject: Canopy fit.
Date: Jun 03, 1998
Listers, I've been wrestling with the canopy for a couple of days. Here are some parameters I'm working with. Tell me if I'm close enough for cutting the bottom edges and prepping for the cut at the roll bar. 1. Total length is 65.5". It's resting with the front about 1" behind the front edge of the canopy skin and about 1" inside the F674 skin. I've read that 1" is OK at the front. I've allowed a bit more skin at the rear so that I could have a nice fit where it meets the sides. Also some warm fuzzy room, if needed. I had more before I cut some skin to make the canopy fit better. 2. There is a gap of about .25" at the center of the canopy on the cabin frame. It seems easy enough to push down and appears to be just the way the canopy is formed. It's round where the frame is flat. The sides are fitting right in when pushed in. It fits nicely around the curved parts, too. 3. Because cutting at the front was not making any difference at the back, we tried wedging the center of the rear edge of the canopy up against the skin. It looked great and didn't seem to make any difference at the cabin frame. We weren't sure it was OK to do that; but, it sure made better sense than cutting when not needed. 4. Sides were pushed in to be sure front fit was OK. Still need to trim around the front corners to blend into the side rails. Other than that, it seems to be lying flat enough with the sides pushed in. 5. Based upon the fit above, a line was drawn on each side's bottom for the final fit cuts. That line sort of runs uphill toward the rear. The difference is about .5" from front to rear. OK, does it sound like I'm on the right track? Because of earlier discussions on the list, I know I can do the cut at the cabin frame for a better fit. I may opt to do that. What about the angle between the canopy (front to rear) and the cabin frame? We noticed there is quite a gap at the front edge of the cabin frame when we pressed down the canopy to the canopy frame. The frame angle is right on, too. Is this normal? We couldn't see any way to get the angle much better without dropping the cabin frame back at the top and doing a lot of cutting up front. Neither idea seemed good. What do you do about the gap above when you rivet the rear window to the cabin frame? I realize the rivet line is further back on the cabin frame; but, I have about a 1/16" gap at the front edge of the rear window if I leave it that way. I read where someone cut his a bit further back on the cabin frame. How much space is there between the front canopy and the rear window along the cut line? This might help some of the above in my thinking process. I haven't seen any comments about how far to space the two sections from each other. I know a strip of glass is placed over the top to form a seal, sort of. Jim Sears in KY RV-6A N198JS ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Re: Prop question
> Ken, I took the prop and engine out of a 62 mooney and istalled it in the rv6 it will work fine. It has a 74 inch prop which is 2 inches longer than what van sells but you will still have plenty of prop clearance. Mike ________________________________________________________________________________
Date: Jun 03, 1998
Subject: electrical noise
I have noticed the development of a ticking sound in my headsets, particularly at higher power settings that seems to match a slight fluctuation in my volt meter. Any ideas on what this is and how it can be corrected? Thanks in advance, Andy ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Hi
Subject: Request for quotation From: bol(at)theboll.com Att. Sales / Export Department Re: Request for quotation A "RFQ" for products which, to the best of our knowledge are similar to those offered by you, was placed with us by one of our clients. We are a world wide sourcing firm and we are paid by our clients to find them suitable suppliers . To you ,our service is totally free of charge !!! The information we will get from you will not only be immediately sent to this particular client but also to all other clients looking for similar products. To define and advise us the products you are interested to export and/or to get more information about us and our FREE SERVICE , please use our Internet interface at: http://www.thebol.com Best Regards BOL sourcing international Ltd Purchasing department ________________________________________________________________________________
Date: Jun 03, 1998
jorear(at)mari.net wrote: > > > Hi Fellow Rivet Rammers: > > I am about to go where this man has never gone before, and bend the > tabs for the ends of the trim tab and the outboard side of the cutout > for the trim tab in the left elevator. I am in a quandry as to where to > make the bend for the tabs in the elevator. I see on the plans where > the fold line should be for the trim tab, but not for the elevator. I > want to make these bends so that the gap at the outboard edge of the > trimtab and the elevator is even along its length. > > How did the group do this? I am thinking that the best way would > be to do the bends in the trimtab, set the trim tab in place in the > cutout in the elevator, and then transfer the angle the outboard end > of the trim tab has to the tabs on the elevator. Sound like a plan, or > is there an easier way? > > This is all assuming that I don't mess up these bends and end up > making little ribs anyway! Thought I would at least give it a college > try. Thanks for the advice, group. > The elevator tabs are bent perpendicular the the hingeline and so is the corresponding ;eft tabs on the trim tab. I bent the elevator tabs first, then the mating trim tab tabs. Positioned the trim tab in place(at least 1/8" gap) and then lined up a ruler with the right side elevator skin and continued it on the right side of the trim tab and drew a reference line on the trim tab for bending. Tab came out lined up real nice. I used the bending method described in 18 years of RVator. Jerry Calvert Edmond Ok -6a ________________________________________________________________________________
Date: Jun 03, 1998
<< How many of them did they poll? >> I have NEVER been polled on anything, but I always hear the results. What a joke. ________________________________________________________________________________
Date: Jun 04, 1998
Subject: Re: Canopy fit.
22> <3.0.1.16.19980602084835.0a0fbcea(at)dtc.net> > >Listers, I've been wrestling with the canopy for a couple of days. Here >are some parameters I'm working with. Tell me if I'm close enough for >cutting the bottom edges and prepping for the cut at the roll bar. Jim, I am not sure which aircraft you are building but if it is a slider 6 where I have some experience then the best tip I got came from Scott McDaniels (I think). This tip was to get under the canopy and frame out on the front lawn and jiggle the two around until they mate. All the canopies I have seen have been able to achieve this (no one has had to cut the top bar). The mounting of the frame is fairly flexible (you can jack up the front with washers and the rear has the skins to cover a fairly wide tolerance range). You can put masking tape on all the bars to help see where contact is occurring. The next good tip is to not get obsessive about anything until you cut off the windscreen. The junction of the canopy and screen will have a fairing over it so that small angulations will not be apparent. The shape of the main canopy relaxes considerably when the front comes off! The last good tip (Gil Alexander I think) is to cut little bits at a time. Accept the fact that you will spend a weekend with your cut off wheel. My daughter turned 459 quarter inch strips of plexi into a nice mobile for her art class. As the pressure comes off and the plexi relaxes it can be difficult to predict where relationships will change (just like real life really). Hope the above helps, Leo Davies 6A antennae (where does everyone else run those coaxs?) ________________________________________________________________________________
Date: Jun 03, 1998
I hope people who are posting on this RV-8 crash thread realize that this stuff goes to hundreds of people, any one of whom could end up being a reporter, attorney, investigator or what have you, who might be inclined to use our bickering or speculation in or out of context for their own purposes. If this happened it could very well be damaging to Van's Aircraft, RV builders, experimental aircraft builders in general, or GA overall. Case in point: I'm afraid to see what AVWEB might have to say about RV builders' apprehensions NEXT week. I'm not trying to tell anyone not to talk about it, although personally I prefer to wait till the people investigating it have had time to give us some results. I just think people should be more careful about what they say on a public list like this. Randall Henderson, RV-6 randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Jun 03, 1998
<< I'll be happy to receive flames if put to me directly (not to the list). >> I do not believe that GV left an E-mail address. Also, I must add that I "know" that Van's and his staff are not getting filthy rich from their hard work, and I can say (no maybe or if in this statement) that they absolutely care about the safety of those who build from Van's kits. Jim Nice RV6A WA State ________________________________________________________________________________
Date: Jun 03, 1998
Wendell--- Will take $50,000 for my kit. Please send money as soon as possible as I think all Rv's are doomed unless we get a response from headquarters! Don't you think intelligent people want to arrange their own destiny????? Hope this isn't to strong! Dave--- ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Re: Lowrance/Nav-Aid coupling
Kevin, I have been using a Lowrance GPS coupled to a Nav-Aid with great success for about a year now. My system uses a Smart Coupler II and not the built in unit which I assume that you are using. The II has a Green LED that lights when it is receiving valid info from the GPS. I don't know if the built -in unit has this. My Lowrance is set up for NMEA ver.2.0 on, all DGPS outputs off, and all sentences on. Only 2 wires are used on the NEMA output cable from the GPS. The white wire is data output and goes to pin 2 (On the Smart Coupler II), The shield is ground and goes to pin 3. Hope this helps. If it solves your problem, give the ride to a "Young Eagle"----I live in Florida. Regards, Bill, RV4, N66WD ________________________________________________________________________________
Subject: RV-8 confidence
Date: Jun 03, 1998
I attended our RV builders group meeting at the Creswell Airport, OR Monday. I stood out near the runway and watched airplanes arrive and depart, and was astonished to see N58VA approach and land. Mr. Benedict flew that airplane down to give us demo rides. I figured if Bill flew that RV8A down to see us dispite the events of last week, then I would have no problem taking a ride. That is one great plane. I was amazed at the performance and stability of this plane. On one part of the ride I was looking straight down at the ground. I still cannot stop thinking about it. Build on you Rv-8 guy as I think Van's still has a lot of confidence in this airplane. Craig Nelson RV-6 serial # 25101 cgn(at)pond.net Eugene, OR wings finished! Installing ailerons and flaps ________________________________________________________________________________
Subject: RV-8 CONFIDENCE
Date: Jun 03, 1998
Listers, I've been reading the thread on the list about the 8 crash, it's possible causes, and implications that Van may have marketed a product for monitory considerations before it was ready for production. Well here's my 2 cents. Don't want no atta-boys, don't want no flames, just my 2 cents. When I first started building my 4 (1988) I remember if you weighed over 170 lbs., Van called you fat and told you to buy someone else's airplane. When we wanted electric flaps he said we didn't need them because the only motors available weighed too much for HIS airplane. When we wanted constant speed propellers he said we didn't need those either. Most of the changes I've seen in the last ten years have come because WE wanted them, not Van. This includes the RV-8 ( fat man's RV-4 ). In all my dealings with the man I can't say I ever thought for a minute that he would sell anything he didn't believe in. Although I don't know him that well I've staked my life on his reputation and airplane for 6 yrs. To think he would market something only for money's sake is unrealistic and has no credibility. We'll find out eventually what happened to the RV-8. It may be design error, it may be the pilot or it may be both. God knows, it's happened a thousand times before and it'll happen a thousand times again. If we all folded tent each time an airplane went down or a famous pilot got killed we'd never get in an airplane. If a mistake has been made ( RV-3 wing spars, RV-4 engine mount pads too thin) it will be corrected. It's a shame these things happen but we all know it will. I just can't think of anyone other than Van that has met the challenges, which for the most part was put on him by US, the consumer of a great product. Jim Nolan N444JN ________________________________________________________________________________
Date: Jun 03, 1998
On 3 Jun 98, at 9:17, Larry Mac Donald wrote: > You ... use slanderous innuendo against Van's, ... 7F00,0000,0000> I'd suggest your not much of a scientist either. ... >Well ,from the scientific standpoint, you don't know anything7F00,0000,0000 about it. .. > 7F00,0000,0000you have just done a great job of trying to destroy the company that builds our kits. ... 7F00,0000,0000> So I'd like to say this. Shut up. If I here any more of this innuendo from you I'll be on the phone > to Matte Dralle asking if he can find you a different list list for you to > expound your "realism" on Larry Mac Donald lm4(at)juno.com Larry, In stark contrast to your venomous, hysterical post, Gary has a long history of reasoned, insightful contributions to the list. I would describe Gary's recent post as a series of reasonable questions and observations framed in a responsible context. I posit that such a post will not elicit an ad hominem attack from responsible adults who aren't afraid of honest inquiry into the truth. Tim Lewis _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023 on gear, engine mounted Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ________________________________________________________________________________
Date: Jun 03, 1998
STOP!!!!!! Wait until the report comes out!!!!!! ________________________________________________________________________________
Date: Jun 03, 1998
Dick, Sounds like you have the airflow performance system. I have it on my RV4 and have had no problems with it quitting in the pattern like you describe. I have blast air cooling on the boost pump assbly (mounted on eng mt x tubes) and engine boost pump. I also wraped the nozzle lines and the line from the purge valve to the flow divider with silicone gyline tape. this tape bonds to it self likeyou wouldn"t believe. I have found that after rollout I have to lean to smooth and I ALWAYS USE THE BOOST PUMP FOR TAKEOFF AND LANDING. I have operated from 7000 ft to sea level with out ever adjusting anything. RV4 273sb CO. ________________________________________________________________________________
Subject: what a beast!
Date: Jun 02, 1998
dropping in to Scappoose the other day to buy some more of that great $1.69/gal 100 LL I noticed that Giles had a new project out on the ramp. What a beast, literally. Three fat paddles driven by a turbine and best of all was the modified rudder. It had this extra sort of claw on it, like maybe a bat might have on it's wing. Very Flash Gordon looking, very cool, even though it was still all carbon fiber black color. Definitely looks like aero mag material. Hopefully it will do better than the Thunder Mustang. I know I'm having lots of fun in my $30k airplane but that one, well, we couldn't even afford the prop now could we? kevin 6A ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Re: G Limits
I'm sending this after giving careful thought. 1st of all, Good article Gary.. And also read doug Rozendaal's post.... The group I hang around with thinks of this very subject quite often. The thing in your hands that can break any airplane is the "wing removal lever". About the Stearman, I don't think Lloyd Stearman ever paid the money but there have been many Stearmans break in flight from over "G"...Most that I am familiar with Precessional loads as a result of high G loading that ripped the engine or propellers off with catastrophic end results. (death) Having been in the competition circuit for about 8 years, I got a good chance to see a common direct effect of constant High G loadings. This is the rapid wear out of airplanes. The more you work them the more care and repair they require. Not to forget that Aluminum does not "forget" when you over stress it either. It can only bend so many times until it breaks. If we are lucky, we will simply find a little broken place that needs repaired. But, maybe we won't find the little broken place until it combines with another break to produce catastrophic results. I recently talked with a person who had an RV3 that he didn't build. I asked if the wings were modified and he said he wasn't sure, but didn't think they were. I told him to please don't do any Acro in it until he could verify it or not. He replied that he only done an occassional loop or a roll. HMmmm... As I become familiar with my RV6 project and study the plans, I am getting very confident in it as a well designed airplane. It is strong and if well built, it should last a long time. As for aerobatics, I would reserve that one for the imagination. Can I do the sportsman or intermediate sequence in it, probably after I become familiar with it. Will I? No. I have about a thousand hours inverted time and about five years of real concentrated Acro flying. I really don't think it is the right kind of plane for that type of flying even tho' the feel is good. Keep in mind that many of these airplanes are being built by very crafty people who haven't yet learned how to fly. "Soon" (4 or 5 years down the road) the little jewel is done and the builder has gotten his license and is happily flying his little honey on a Sunday afternoon. One day he thinks it is time to teach himself aerobatics. The response is so good, the roll was flawless, let's do it again... Nothing to it. And so it goes.. Sorry for the soapbox, but I want everyone to enjoy this great airplane. Phil Sisson '84 IAC & US National Sportsman champion '85 IAC & US National Intermediate champion '89 L. Paul Soucy award... and then I quit. Not patting myself on the back, just trying to keep some planes together... Gary wrote: > > > The number is not the only thing that is important. I find > that > most sport aviation enthusiasts I talk to do not understand the > G-Limit > restrictions put on aircraft. > > The published G-Limits on most aircraft that we build are the > symmetric G-Limits for the airframe. This insures that no wing will > see > more G than it can handle. It is actually pretty easy to over G an > aircraft if it is out of rig or you do not do a symmetric (i.e. > straight > back or forward) pull on the stick with no rudder. > > If you think you have not over G'ed the airframe because your > $200 G-Meter shows 6 Gs, in reality you could have put 9 to 12 or more > > Gs on one of your wings, if a symmetric pull was not accomplished. > The > amazing thing is that most folks think that $200 G meter protects them > > from over G (look I only pulled 6 Gs!!!). It got so bad in the Air > Force that a special equipment is now onboard all real airplanes > (fighters) that the pilot cannot reset from the cockpit. > > It is a natural tendency in a center stick aircraft as the G > load increases for the stick to move to one side or the other > depending > on the hand that is on the control stick. > > Just my .02 cents! > > Gary Fesenbek > ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Engines strength & RPMs (was: Rotary engines in RVs
Hi all, The reliability of an engine is related to many more things than the RPMs it operates at, as most of you probably know. I didn't realize how many till I got to studying engines for my 6A. Modern metals and lubricants have greatly extended the strength of engines. Modern methods of precision measurement and production improve the ability to take higher stresses and last longer while doing it. In one of my auto conversion books, there is a picture of a racing Chevy V6 that produces over 500 hp. I could put one of them in my RV and probably win lotsa time to climb races! At this rate, the Lycoming 360 would be putting out over 700 hp! It can't hold up under the loads, even if bags of money were spent on it to convert it to racing status. However, the Lyc has a good chance of chugging along reliably for 2000 hours. The 500 hp racing V6 had a TBO of ten hours! Still, ten hours could win a lot of time to climbs. Each engine has its own virtues and vices - each is designed to meet a certain need. The rotary RX7 engines have a pair of rotors in sorta rounded triangle shapes that do the four cycle thing - the suck, squeeze, bang, ptuii. They are rolling around in a triangular chamber while turning the crankshaft which is slightly eccentric. Someone has a web page with a running cut-away rotary engine. Another web page has a stationary diesel that is redlined at 140 rpm. That's one hundred forty! It has a bore of about three feet as I remember. If the durability of my RV V6 is only 500 hours, I'll be happy as parts of very high quality are quite cheap. You can get a new set of high quality pistons with pins and rings for the price of a Lycoming exhaust valve! If the engine turns out to be much less reliable than it is in millions of road vehicles, I'll be pulling it out. Likewise if I can't beat the socks off any four cylinder Lycoming RV! :-) At 7500 feet, a 240 hp engine puts out 180 hp max. A 180 puts out 135. Will this double the climb ability at this altitude? How does one determine how much power is required for level flight? Hal Kempthorne RV-6AQ -- Looking for an airport halk(at)sybase.com Santa Clara, CA. Debonair N6134V @ SJC ________________________________________________________________________________
Subject: Flap Blown Fuse...WHY?
Date: Jun 02, 1998
One explanation for blown fuses for the flaps - I put some clear tape on the forward edge of the flap, so it would not get scratched. At some stage past full flaps, the edge of the tape goes past the upper skin of the wing, and then the flap cannot be lifted. In my case it is not a problem, as the flap is never lowered that far, unless I am removing it, but I am sure the fuse would blow if the flaps were being retracted. Incidentally I recommend using the clear tape, rather than the stainless steel tape, which itself becomes scratched. John Cocker RV6A 150 hours Newmarket Ontario a turbine and best of all was the modified rudder. It had this extra sort of claw on it, like maybe a bat might have on it's wing. Very Flash Gordon looking, very cool, even though it was still all carbon fiber black color. Definitely looks like aero mag material. Hopefully it will do better than the Thunder Mustang. I know I'm having lots of fun in my $30k airplane but that one, well, we couldn't even afford the prop now could we? kevin 6A ________________________________________________________________________________
Date: Jun 03, 1998
From: Sylvan Adamson <sadamson(at)cyberhighway.net>
Subject: RV-8 crash
When the RV-8 factory plane crashed and Bill Benedict posted that Van's would inform us of what they find I had a signed and noterized licence agreement and order for an RV-8 on my desk with a check. It made it as far as the dash of my truck and I decided to wait and see what they had to say. Since that time I've been checking posts on the list to see if there was any usefull information and waiting to hear from Van's as promised. Not pushing Van's. The only thing I can say is. Don't most of you people posting on this subject have anything to do? Don't you have planes to build? While this list provides some great information, trying to sort it out sometimes can give a person a case of the drizzles. To me it's become not worth it. SA ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Countersink cutter for RV-8 wing spar
RV-Listers, I am sitting here in Wichita trying to figure out if I have all the tools I need to start my RV-8 wings whenever I make it back home. I am staring at the preview plans, but I can't look at any hardware because it is back in Ottawa. Will I need the special countersink cutter that Avery's sells for cutting clearance in the wing spar for the dimpled tank skins? This cutter is 1/2 inch diameter, and has a #30 pilot. I already have a 3/8 diameter cutter with a #30 pilot. Thanks for your advice, Kevin Horton RV-8 80427 (getting ready to start wings) khorton(at)cyberus.ca ________________________________________________________________________________
Date: Jun 03, 1998
Subject: SK-37
Getting ready to work on the spars and I noticed a reference on the plans to SK-37. What is it and where is it???? ________________________________________________________________________________
Subject: Re: electrical noise
Date: Jun 04, 1998
Andy, I had the same problem. Tried changing to electronic alternator voltage regulator, shifted intercom and all plugs and sockets and controls to behind the seat. Took supply off isolating solenoid on battery which is behind the seat. Then noticed that when the engine revs were below 2000, the noise disappeared completly. So as my alt. puts out far more amps than I could ever use I put a larger pulley on the alternator (about 3.75 inches). Have not had a problem since. I notice Van's sell a larger pulley, I suspect that would fix your problem . Good luck, Brian ---------- > From: winterland(at)rkymtnhi.com > To: rv-list(at)matronics.com > Subject: RV-List: electrical noise > Date: Thursday, June 04, 1998 4:19 AM > > > I have noticed the development of a ticking sound in my headsets, > particularly at higher power settings that seems to match a slight > fluctuation in my volt meter. > > Any ideas on what this is and how it can be corrected? > > Thanks in advance, > Andy > > > ________________________________________________________________________________
Date: Jun 03, 1998
From: David and Beth Hudgins <davidrv6a(at)mindspring.com>
>I have noticed the development of a ticking sound in my headsets, >particularly at higher power settings that seems to match a slight >fluctuation in my volt meter. > >Any ideas on what this is and how it can be corrected? > >Thanks in advance, >Andy > I get a little "tick" in the intercom from the transponder, especially when the altitude encoder is on. I also get a fluctuation in the amp meter when the strobes are on, but that's it. There is a high grade of coax available that may fix the problem, it is mentioned in the "Aeroelectric Connection" book by Bob Nuckells (sp?). Dave, RV-6A ________________________________________________________________________________
Subject: Re: RV-8 crash
Date: Jun 03, 1998
I am determined the RV-8 is an aircraft suitable for building, for AT LEAST one reason. The RV aircraft are beautifully designed aircraft. It takes a AI or AP degree of excellence (or someone dedicated to PROPER construction) to construct this bird. I am and WILL build the RV-8A because RV represents the best in Customer response and with this web site also represents the best in user experience. I do not have ANY problem with Van's designs -- but it must be constructed according to proper plans. I have ordered pre-plans for the the RV-8A, yet not have received the plans--I am not critical, as the resolution of the auger is far more important than me salivating. Once Van has determined the cause of the 'incident', I have no problem with the plans being delivered. Van, you and your staff, take your time. The RV aircraft are a beautiful sight to see while cutting through the atmosphere!!!! With Best Regards, Lane Sherrill NEW RV-8A builder and damned sure of my choice! -----Original Message----- From: Sylvan Adamson <sadamson(at)cyberhighway.net> Date: Wednesday, 3 June 1998 22:59 Subject: RV-List: RV-8 crash > >When the RV-8 factory plane crashed and Bill Benedict posted that Van's >would inform us of what they find I had a signed and noterized licence >agreement and order for an RV-8 on my desk with a check. It made it as far >as the dash of my truck and I decided to wait and see what they had to say. >Since that time I've been checking posts on the list to see if there was >any usefull information and waiting to hear from Van's as promised. Not >pushing Van's. The only thing I can say is. Don't most of you people >posting on this subject have anything to do? Don't you have planes to >build? While this list provides some great information, trying to sort it >out sometimes can give a person a case of the drizzles. To me it's become >not worth it. SA > > > > > > ________________________________________________________________________________
Date: Jun 03, 1998
Subject: aileron torq tube hole
How close is too close concerning the top of the aileron torq tube hole in the rear spar of the RV-8. ? ________________________________________________________________________________
Date: Jun 03, 1998
From: Unistar Computers <unistar(at)mindspring.com>
>Listers; I have a couple of instruments, a VSI and a Turn and Bank, that have >a sort of cloudy look to them. Upon close examination I see that this >cloudiness is actually a film on the inside of the glass. Can these >instruments be disassembled and the glass cleaned and reassembled by us? Or >are they vacuum sealed? Or do they have to be sent to an Instrument shop? It >looks like about 5 tiny screws that hold the front portion of the instrument >together including the glass. Any tips? Thanks. >Von Alexander >RV-8 #544 Skinning the fuse If your aircraft is IFR certified then you *MUST* have the instrument tested and re-certified by an instrument shop. If it is VFR then you are probably "home free" with the FEDs since you are "experimenting". The static system also runs the encoder for the Mode C, and if you booger up the seal on the VSI you may get odd readings from the altitude readout. Bob Steward, A&P IA AA-1B N8978L AA-5A N1976L ________________________________________________________________________________
Date: Jun 03, 1998
Subject: Re: Titanium tie-downs
Corsair wrote: > > > Anybody know where Randy Simpson is ? Trying to reach him about those neat > tie-downs. Please reply if you have > info.................Thanks......Austin. > Hi Austin, Randy sent me an email last week , stating he was sorry for the delay in shipping me the tie-downs I ordered. He is on the MOAT (mother of all trips) that he speaks about on his web page. Try him again in a week or so. Gene Angell RV6 N242GA (reserved) fuselage construction just begun in St.Louie ________________________________________________________________________________
Date: Jun 03, 1998
> I have been using a Lowrance GPS coupled to a Nav-Aid with great success > for about a year now. My system uses a Smart Coupler II and not the built > in unit which I assume that you are using. The II has a Green LED that > lights when it is receiving valid info from the GPS. I don't know if the > built -in unit has this. My Lowrance is set up for NMEA ver.2.0 on, all > DGPS outputs off, and all sentences on. Only 2 wires are used on the NEMA > output cable from the GPS. The white wire is data output and goes to pin > 2 (On the Smart Coupler II), The shield is ground and goes to pin 3. > Hope this helps. If it solves your problem, give the ride to a "Young > Eagle"----I live in Florida. > conversation today with nav-aid revealed that I need a set of jumper wires which are output from the interpreter board to the regular panel mount input pins, since no internal connections exist. I'll check that out next trip out, although I don't remember putting them in. He told me to turn the sentences off, so I don't know if that will make any difference. My Lowrance is the 300 which I believe just came out. Thanks for the reply. I've given several rides and finally had my first "chucker". 10 seconds from touchdown, he puked right thru the mic which now isn't working too well! kevin > > Regards, Bill, RV4, N66WD > > > > ________________________________________________________________________________
Date: Jun 03, 1998
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
> >I have noticed the development of a ticking sound in my headsets, >particularly at higher power settings that seems to match a slight >fluctuation in my volt meter. > >Any ideas on what this is and how it can be corrected? > Is the noise synchronous with the strobe flashes? Does the noise go away with the turning off of any single accessory? Does the noise go away if you're operating battery only . . . alternator off? >>Andy, I had the same problem. Tried changing to electronic alternator >>voltage regulator, shifted intercom and all plugs and sockets and controls >>to behind the seat. Took supply off isolating solenoid on battery which is >>behind the seat. Then noticed that when the engine revs were below 2000, >>the noise disappeared completly. So as my alt. puts out far more amps than >>I could ever use I put a larger pulley on the alternator (about 3.75 >>inches). Have not had a problem since. I notice Van's sell a larger pulley, >>I suspect that would fix your problem . Good luck, Brian Slowing the alternator down increases field current (more heat) and slows down the fan (less cooling) and shouldn't be necessary. If the noise IS coming from the alternator itself, changing the regulator is an inexpensive thing to try. What regulator are you using currently? When you said 'development' do I undestand that this is a new condition that didn't exist previously? How old is the battery in the airplane? What size and technology (flooded, RG?) Bob . . . //// (o o) ===========o00o=(_)=o00o========= < If you continue to do > < What you've always done > < You will continue to be > < What you've always been. > ================================= <http://www.aeroelectric.com> ________________________________________________________________________________
Date: Jun 04, 1998
Subject: Canopy and silicone?
Refresh my memory, please. Is it safe to use silicone caulk near/on plexiglas? I'm thinking of using a thin layer on the skin/canopy intersection, to keep water out. Finn ________________________________________________________________________________
Date: Jun 04, 1998
Subject: SK-37
Getting ready to work on the spars and I noticed a reference on the plans to SK-37. What is it and where is it???? Hi Jerry The SK- diagrams (does the SK mean sketch?) are in the pre-build plans book and they are not necessarily in numerical order. It appears to be a older numbering system for the diagrams and not all the references in the instructions have been updated to the numbers used with the plans figures. For example Figure 7-2 in my RV-6 plans is the same diagram as SK-37 is in the pre-build plans, unfortunately the instructions sometimes refer to the SK number instead of the Figure number. All this head scratching can be legally counted as building time and I am going for the "high time award". George McNutt, Langley B.C. 6-A completing fuel tanks. ________________________________________________________________________________
Subject: Garmin 55
Date: Jun 04, 1998
Hi listeners I have a Garmin model 55 AVD hand held GPS. I have been using it for some time now in a cradle with power supplied from the aircraft system. I have just tried to use it with it's own batteries with no go. I have checked the output of the batteries, all OK at 6.03 volts also cleaned the contacts all looks OK. Now have connected by to aircraft power and it works still I would like to use this with a data logger in a glider. Any help would be great. Trevor Mills. ________________________________________________________________________________
Subject: SK-37
Date: Jun 04, 1998
The "SK" drawings are sketches in the construction manual. Steve Soule Huntington, Vermont -----Original Message----- Getting ready to work on the spars and I noticed a reference on the plans to SK-37. What is it and where is it???? ________________________________________________________________________________
Date: Jun 04, 1998
Thank you for all the replies on the list regarding my flap fuse problem. Yesterday when I flew I checked the amperage draw on the flap circuit. On the ground, no load, the system drew a constant one amp, up and down. In the air at 100 mph, it increased to almost 5 amps at full flaps. Bob Nuckolls suggested using a 7 amp fuse and I will try that for now. The RV bunch are a great group of guys, Terry Jantzi flew hi RV6 in last night to give me a 5 amp circuit breaker, no charge! I will wait for a while to install it as I am still interested in solving this fuse problem. I am using the automotive blade type fuses and according to my supplier there is no slow blow version of this type of fuse? Tom Martin ________________________________________________________________________________
Date: May 03, 1998
G'day Andy, Those "clicks" you speak of , in my opinion, may be caused by any number of things, check out the list below. 1. System voltage may be set too high, check the sys voltage, ideally it should be around 13.8V, the theoretically maximum voltage from a 6 cell lead acid battery, this includes gell cell (12V) battery, at 1000 and at 1500 r.pm, I'm assuming that you are running an alternator, there should be little or no increase in voltage. 2. Is your buss wiring to the battery sufficently heavy, 8# min. 3. Is the grnd connection to the battery good enough, I generally use 1" braid. 4. Check the electrolyte level in the battery, if this is decreasing, then your charge rate, i.e system voltage, is too high. In order to have a quiet electical system the internal resistance of the battery must be very low, as must the buss and gnd, a battery that is low on electrolyte has a higher than usual internal resistance, and is less able to bypass transients in the system, some times alt whine or noise is indicative of this condition. 5. You may try running the wire to the alt regulator from the alt switch away from the avionics loom, I find that shielding the alt output wire to the buss is of little use. Generally the problem is a high resistance connection some where is the sys. 6. Avoid sharp bends in the transponder coax, as the high frequencies used, may radiate into the aircraft at a sharp bend, if the intercom clicks in sync with the interogator light this may be the problem. Regards, Peter O'Brien Currently building with R.Hill 60084 an RV6, hoping to fly in August. ________________________________________________________________________________
From: "Rolf Hankers" <ROLF(at)Benjamin.iff.ing.tu-bs.de>
Date: Jun 04, 1998
Confirmation of reading: your message - Date: 3 May 98 16:43 To: rv-list(at)matronics.com Subject: Re: RV-List: electrical noise Was read at 15:13, 4 Jun 98. ________________________________________________________________________________
Date: Jun 04, 1998
> > Thank you for all the replies on the list regarding my flap fuse problem. >Yesterday when I flew I checked the amperage draw on the flap circuit. On >the ground, no load, the system drew a constant one amp, up and down. In the >air at 100 mph, it increased to almost 5 amps at full flaps. Bob Nuckolls >suggested using a 7 amp fuse and I will try that for now. I presume your flap circuit is wired with at least 20AWG wire or heavier . . . the fuse is to protect the wire . . . fuse sizes can and should be upsized to eliminate nuisance tripping but the wire has to go up in capacity along with the fuse. > The RV bunch are a great group of guys, Terry Jantzi flew hi RV6 in >last night to give me a 5 amp circuit breaker, no charge! I will wait for a >while to install it as I am still interested in solving this fuse problem. I >am using the automotive blade type fuses and according to my supplier there >is no slow blow version of this type of fuse? If a 7A fuse and 20AWG fixes it, why would you want a slo-blo fuse? There are no slow versions of the ATO/ATC series fuses used in our power distribution panels and most automobiles. Bob . . . //// (o o) ===========o00o=(_)=o00o========= < If you continue to do > < What you've always done > < You will continue to be > < What you've always been. > ================================= <http://www.aeroelectric.com> ________________________________________________________________________________
Subject: N58RV THis is all anyone knows
Date: Jun 04, 1998
Until the testing is finished this is all anyone knows! The check for the tail kit is still going out on Monday , but the wing kit will wait until there is a resolution NTSB Identification: LAX98FA171 Accident occurred MAY-24-98 at RIPLEY, CA Aircraft: Van's Aircraft, Inc. RV-8, registration: N58RV Injuries: 2 Fatal. On May 24, 1998, at 0630 hours Pacific daylight time, an experimental RV-8, N58RV, experienced an in-flight structural separation and crashed 1 mile south of Ripley, California. The aircraft was destroyed and the pilot and pilot-rated passenger sustained fatal injuries. The aircraft was being operated by Van's Aircraft, Inc., as a business flight when the accident occurred. The flight originated from a private agricultural strip in Blythe, California, at 0620. Visual flight conditions prevailed at the time and no flight plan had been filed. A relative of the passenger reported that on departure the pilot was seated in the front seat, while the passenger was in the back. The aircraft is equipped with dual controls, however, the throttle can only be operated from the front seat. An eyewitness, about 1.5 miles northwest of the crash site, reported that he heard the sound of an engine surging and looked to see where the sound was originating. He saw a yellow aircraft flying straight and level, about 1,000 feet agl. The aircraft was on a southbound heading, about 1 mile east of his location. He estimated that he watched the flight for over a minute when he saw something fall from the aircraft. This was followed almost immediately by a loud boom that he described as sounding like a "shotgun." The aircraft's nose suddenly pitched up about 45 degrees, then abruptly nosed over as it began to roll. The aircraft entered a nose-down spin and continued in a vertical descent until impact. A postaccident inspection of the aircraft by the Safety Board found an outboard section of the left wing about 0.2 miles northeast of the main wreckage. The main spar of the left wing was fractured at a point inboard of the aileron and outboard of the flap. The main spar of the right wing was also fractured about the same location, but remained attached by the wing's outer skin. According to the kit designer, the wing design had previously been statically tested to failure, which had required in excess of 9 G's. P.S. I found this at www.ntsb.gov. I gotta say, reading accident reports is both very educational and VERY sobering. Marco Lucchinetti marcol(at)crt.com ________________________________________________________________________________
Date: Jun 04, 1998
Subject: Re: 180hp Sensenich prop feedback.
Comrades, Is anyone flying with a Sensenich metal prop on a 180 hp RV-6 yet? I am planning on purchasing one and am leaning toward the one with the higher pitch for better range. They also offer a metal spinner (not spinner kit) that is ready to "bolt on". If anyone has this setup a short product review would be greatly appreciated. N1150S has a Sterba prop on a Woofter 7-inch diameter extension. This combination is light, smooth, inexpensive and offers great T.O. and climb performance but with two big souls on board the baggage is limited to approximately 45 lbs due to aft cg limits. The Sterba/extension has 80 hours on it and is for sale available as soon as the ich arrives.. Make offer, it is a great setup for the flight test phase since it gets you off and climbing fast, is inexpensive, and wont ruin your engine if you prang it on the ground. I read a hard-to-believe statistic that 10% of experimentals have a prop strike before the test time is over. Not RVs I hope. Rick. ________________________________________________________________________________
Date: Jun 04, 1998
Subject: Re: Countersink cutter for RV-8 wing spar
On Wed, 3 Jun 1998, Kevin Horton wrote: > > RV-Listers, > > Will I need the special countersink cutter that Avery's sells for cutting > clearance in the wing spar for the dimpled tank skins? This cutter is 1/2 > inch diameter, and has a #30 pilot. I already have a 3/8 diameter cutter > with a #30 pilot. > Did all my countersinking with the 3/8" one, no problem. Brian Huffaker, DSWL (huffaker(at)utw.com) President and Founder Friends of P-Chan RV-8 80091 Fiddling with fuel tank ________________________________________________________________________________
Date: Jun 04, 1998
Subject: Elevator construction methods
Would any RVer who has built elevators using both constructions methods, i.e. The old way of shims under the spars and the new way of using the jig blocks, please contact me off-list at: Bskinr(at)trib.com ? Thanks, Bob Skinner RV-6 415 hrs. Buffalo, WY bskinr(at)trib.com ________________________________________________________________________________
Subject: SK-37
Date: Jun 04, 1998
>Getting ready to work on the spars and I noticed a reference on the >plans to SK-37. What is it and where is it???? Jerry: If you are building a 6/6A & you are talking about the main spar, I think your statement came from page 7-4 & the sk is above sk-40 just in front of the pictures. All the if's are because I got a Barnard kit & didn't go through that part. I hope this helps. I was going to visit your project the last time I went by Edmond but didn't have time. One of this days though. Don Jordan ~ 76DJ ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com ________________________________________________________________________________
Date: Jun 04, 1998
Subject: RV-8 crash
This counts as speculation, and I thought carefully before sending it. But in light of some other postings, here goes... The account of the crash as released by those in charge is quite consistant with other crashes (not RV's) in which the engine/prop separated from the airframe during flight (loss of a prop blade and the subsequent EXTREME vibration caused sometimes leads to this). The violent pitch up due to the balance change would load the spar WELL into the 2 digit g range. Obviously this is just a guess, but if this proves true it would eliminate both John Morgan's flying and Van's airframe design as having anything to do with it, which despite the extremely unfortunate and sad event would serve to make us all feel at least a little better. And it makes sense. John was by all accounts a truly great pilot and Van has a history of designing sound planes. I really don't think all of you guys who have money invested in an RV-8 kit need to worry -that is unless you also worry about asteroids hitting you as you climb out of bed. I guess I'm saying don't blame anyone yet... I hold Van and his employees in the highest esteem. I have no reason not to. The opinions/guesses above are completely my own. I am an authority of nothing. Time will tell... In the meantime flame away if you desire. I'm just very sorry the whole thing happened and like everyone, am trying to make sense of it the best I can. Scott Spencer -IN still trying to get my -4 flying again & looking forward to seeing other RV'ers at Mike Wonder's fly-in at Shawnee this weekend. ________________________________________________________________________________
Date: Jun 04, 1998
> > > >Comrades, >Is anyone flying with a Sensenich metal prop on a 180 hp RV-6 yet? The Sensenich props for O-360's are not being delivered yet. According to their web-site (www.sensenich.com) and a card they sent out to customers, they had problems with the forgings from an outside vendor. According to the web page, replacement forgings were released for shipment May 22nd and shipping dates will be announced shortly. I believe I will receive one of the first props shipped, as I ordered well before availability was announced. I will post to the group when I receive mine. Larry Pardue Carlsbad, NM Pacer N8025D RV-6QME N441LP Reserved Installing Radios ________________________________________________________________________________
Date: Jun 04, 1998
Subject: Electrical Noise
Most extraneous electrical noise, rather from strobes, or alternator/generator outputs, etc, can be effectively eliminated with what is called a "feed-through" capacitor. You can get them at Radio Shack for about $5. They mount in the firewall, for example, and provide a direct through connection, but the body of the device effectively "shorts" noise (and other high frequency junk) to ground. Sprauge used to make them but I have not seen their feed through capacitors on the market for some time. You can buy this kind of product in the aviation catalogs for $25-35, but the Radio shack ones work just as well. They are rated about 0.1ufd and have a currect carring capacity of more amperes than most of your generators/alternators can put out. Hope this helps. ________________________________________________________________________________
Subject: FYI: Superior Air Parts introduces its own engine
Date: Jun 04, 1998
Hello, Looking at the cost of a 6A QB, Engine, and food, teasers like the following always interest me: In AOPA's News section ( http://www.aopa.org/members/ ) there was a posting today that Superior Air Parts has introduced its own engine for experimental aircraft. Based on the Lycoming 320/360 series engines, the non-certified XP 360 is a horizontally-opposed, air-cooled design offering horsepower choices in the 180 to 200 range. Price for the new engine has not been firmed but, according to Superior, is expected to be significantly below a comparable Lycoming engine. For more information contact the engine's exclusive distributor A.E.R.O. Aviation 618/797-6630 Brent BAllen(at)uci.edu RV-6A Tail Irvine, CA ________________________________________________________________________________
Date: Jun 04, 1998
Subject: Re: Canopy and silicone?
> Is it safe to use silicone caulk near/on plexiglas? It's safe but you'll have trouble getting paint to stick anywhere near where you use silicone. I investigated and ended up using Lexel, available at Ace Hardware stores. Seems to have worked fine although I haven't flown yet. Others recommend proseal. There are some postings about both in the archives -- search for "lexel" and also "proseal AND canopy". Randall Henderson, RV-6 (engine/finish) Portland, OR randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Jun 04, 1998
Subject: Re: FYI: Superior Air Parts introduces its own engine
u> > > Price for the new >engine has not been firmed but, according to Superior, is expected to be >significantly below a comparable Lycoming engine. Yes, but compared to what? If they are comparing it to Lycoming's _list_ price (around $35K isn't it?) then it probably won't be any better than what Van charges for the certified engine at the near OEM price he pays for it. Now if Van can get OEM pricing direct from Superior then we're talking about something here. However I doubt he will be able to carry engines from Superior without jeopardizing his relationship with Lycoming. Of course he might be able to use the competition to get Lycoming to lower prices further, but I wouldn't hold my breath. But like the rest of you, I hope for the best. :-) ----- Bill Pace San Diego, CA wbpace(at)adnc.com RV-6A Skinning left wing ________________________________________________________________________________
Date: Jun 04, 1998
Subject: Re: Electrical Noise
>Most extraneous electrical noise, rather from strobes, or >alternator/generator outputs, etc, can be effectively eliminated with >what is called a "feed-through" capacitor. You can get them at Radio >Shack for about $5. They mount in the firewall, for example, and provide >a direct through connection, but the body of the device effectively >"shorts" noise (and other high frequency junk) to ground. Sprauge used >to make them but I have not seen their feed through capacitors on the >market for some time. You can buy this kind of product in the aviation >catalogs for $25-35, but the Radio shack ones work just as well. They >are rated about 0.1ufd and have a currect carring capacity of more >amperes than most of your generators/alternators can put out. Hope this >helps. This type of filter is useful only for reducing radio frequency noises effects on lower frequency radios like ADF and Loran. They have no effect on audio rate conducted noises on the bus (typical of alternator whine and some forms of alternator instability). If the noise you're trying to filter is coming in through the antenna (i.e. turning the volume control up and down on the victimized radio affects level of noise) the low capacity feedthru device mounted right on the alternator may help. If the noise is not coming in through the antenna, you'll need to deduce the propogation path or better yet, if this is a NEW noise, see if components of the offending system can be upgraded to put the snake back in the sack. Until we understand where the noise is being generated and why, one can spend a lot of time "trying" things with little or no probability of success. Bob . . . AeroElectric Connection //// (o o) ==========o00o=(_)=o00o========== < If you continue to do > < What you've always done > < You will continue to be > < What you've always been. > ================================= <http://www.aeroelectric.com> ________________________________________________________________________________
Date: Jun 04, 1998
Subject: Re: Rotary engines in RVs
Hmmmm, lessee. If a rotary is turning 6000 RPM then that's 6K at the shaft and 2000K on the rotors. The shaft is only about 1.5 inches in diameter (compared to about 12 inches for the perimeter of a Lyc crankshaft) Never mind the reciprocating mass in a Lyc. It's significant, of course, but the rotary has nothing to compare it to so we won't. And I have to PSRU that little shaft from a measley 6K down to about 2200 rpm. And the gears are typically from a Ford truck which gets thrown in reverse, stopped, restarted and mis-clutched a couple of hundred times a day (not counting the number of times your son decided to see how much rubber it would lay down) You're right, it's a lousy comparison :-) ________________________________________________________________________________
Date: Jun 04, 1998
Subject: RE: Wagner HVLP
<< I"ve also used a regular spray gun. I swear by the hvlp!! You never run out of air. It is extremely portable. IT uses much less paint and gives a professional job with little experience. As for resale value, I was going to sell it after I painted my first a/c. It has now painted 2 aircraft and I wouldn"t think of selling it!!!! >> ------- Is that a turbine type? and what model? I probably don't want to know this but was it one of the relatively cheap setups from Home Depot? If it works that nice please fill us in......yeah, all of us...even those of us you are gonna really annoy by telling us what a good deal you got AFTER we bought something expensive. Thanks a lot pal :-) :-) Bob :-) ________________________________________________________________________________
Date: Jun 04, 1998
Subject: aileron torque tube hole RV-8
A better description: The rear spar of the RV-8 has a hole in it for the aileron to bellcrank tube. It is a cut and fit operaton with the hole progressing towards the tp of the rear spar and getting very close to the flange. There are no dimensons or notes in the Vans info or drawings as to the minimum distance required on the web portion. The quickbuild comes with a hole already cut, but it is not high enough to allow the tube to pass thru. Is a half inch of web area enough ? ________________________________________________________________________________
Date: Jun 04, 1998
Allen, Brent wrote: > > In AOPA's News section ( http://www.aopa.org/members/ ) there was a > posting today that Superior Air Parts has introduced its own engine for experimental aircraft. Based on the Lycoming 320/360 series engines, After talking with Superior at S 'n F I called the engineer in charge of the project in Dallas, Tx. This engine will use dynafocal 1 mount. In Fl. they told me they were first going to build up a 200 hp engine to test but could give no specifics. It will be a parallel valve, 200 hp with 10-1 pistons and no fuel injection. He expected it to be on the market in 3 to 5 months. For planning only. Marty RV-6AQ Erwinna, Pa. ________________________________________________________________________________
Date: Jun 04, 1998
Ken-- my RV6A has a firewall forward engine and CS prop from a 1957 Mooney M20. The engine is an 0-320 and the CS prop is Hartzell. It works very well .. A small bump was required on the cowling to assure adequate clearance for the alternator. However be careful to check the CS prop which probably is subject to the recent AD by Hartzell. My old prop did not pass ( and the 40 year hub design is also quite dated compared to the new models) so I recently replaced it with a new Hartzell CS purchased thru Van's using the one-time discount price. J. E. Rehler RV6A flying, Corpus Christi, Texas, W5KNZ ________________________________________________________________________________
Date: Jun 04, 1998
<< However I doubt he will be able to carry engines from Superior without jeopardizing his relationship with Lycoming. >> Would someone refresh me on this? What type of engine is Superior building, and are they flying yet? Jim Nice RV6A WA State ________________________________________________________________________________
Subject: N58RV Information
Date: Jun 04, 1998
Don't know if this is news to y'all, but it's the first time I saw it: http://www.ntsb.gov/aviation/LAX/98A171.htm Larry larry(at)bowen.com RV-8 emp Advance, NC size=3D3>Don't know if this is news to y'all, but it's the first time I saw size=3D3>RV-8 color=3D#000000 ________________________________________________________________________________
Date: Jun 04, 1998
Subject: Re: RE: Wagner HVLP
BOB, THE WAGNER CAPSPRAY IS A TURBINE. AND I WOULDN'T SAY IT WAS CHEAP. BELIEVE I GAVE AROUND $550 FOR IT TWO YEARS AGO. DON'T RECALL THE MODEL THOUGH. IT HAS A REAL NICE 5 ADJ GUN. I COULD PUT ONE COAT OF WHITE ON MY rv4 FUSE WITH 1AND1/2 QTS. RV4 273SB CO. ________________________________________________________________________________
Subject: Re: TITE SEAL
Date: Jun 02, 1998
Dear Tommy, I have been using Tite Seal for over 25 years and I still haven't found anything better as a sealant on airplane engines and fuel tank fittings etc. I usually use the lite, however I have also used the medium with equal success. The medium is better is better on old loose threads etc. On new stuff, I think the lite is better. I used Tite Seal lite on all of the tank fittings on my RV8. Dick Martin RV8 N233M 80124 installing innards, airframe essentially complete ---------- > From: TOMMY E. WALKER <twsurveyor(at)email.msn.com> > To: rv-list(at)matronics.com > Subject: RV-List: TITE SEAL > Date: Monday, June 01, 1998 8:36 PM > > > Has anyone had anyone had experience using "Tite Seal" compound on the fuel > tank inspection plates and the sender mount plate? How well does it work? > > Tommy > Finishing 6-A Wings > Ridgetop, Tennessee > > > > > > ________________________________________________________________________________
Date: Jun 04, 1998
Listers, Yesterday, I sent a note to the RV-list to hopefully get some feedback concerning my canopy installation. I was stopped cold because I didn't have the slightest idea if I was about where I needed to be. I got two responses. One helped a little. The other wished me luck. Both were appreciated; but, the lack of response from those of you who have travelled this road before me was very disappointing. I guess the RV-8 crash discussion has tied up your minds so much that you've forgotten that there are some of us out here who are trying to get where you are. In the end, I called Van's and got the warm fuzzies I needed. Therefor, here a slightly edited list of the items again with some more info in hopes that maybe some of you behind me can use it. >>1. Total length is 65.5". It's resting with the front about 1" behind the front edge of the canopy frame skin and about 1" inside the F674 skin at the rear. I've read that 1" is OK at the front. I've allowed a bit more skin at the rear so that I could have a nice fit where it meets the sides. Also some warm fuzzy room, if needed. I had more before I cut some skin to make the canopy fit better.<< Per my conversation with Tom Green at Van's, that's just right. The closer to the front edge of the canopy skin I can make it up front, the better the transition to the canopy. That makes for a nice slope back in appearance. The 1" allows a bit for the glass work. >>2. There is a gap of about .25" at the center of the canopy on the cabin frame (roll bar). It seems easy enough to push down and appears to be just the way the canopy is formed. It's round where the frame is flat. The sides are fitting right in when pushed in. It fits nicely around the curved parts, too. << No problem there, either. Tom says it can have as much as a half inch in the center and still be just fine. When the cut is made over the cabin frame, the parts will fall into place very nicely. >>3. Because cutting at the front was not making any difference at the back, we tried wedging the center of the rear edge of the canopy up against the skin. It looked great and didn't seem to make any difference at the cabin frame (roll bar). We weren't sure it was OK to do that; but, it sure made better sense than cutting when not needed. << Tom said we did the right thing. By wedging it up, we found that it made no difference at the roll bar and prevented our making cuts we didn't need up front. I guess I could trim off a little more up front; but, I don't think I will unless I see that the cuts to make the transition curves to the sides are going to make it necessary. I should need very tiny cuts, at most. >>4. Sides were pushed in to be sure front fit was OK. Still need to trim around the front corners to blend into the side rails. Other than that, it seems to be lying flat enough with the sides pushed in.<< I give credit to Will Cretsinger's notes for that hint. It sure made a difference up front. With the sides loose, the front edge laid flat. When we pressed in on the sides, the center of the front edge would bulge up. We cut accordingly. Now, the front edge lies flat when the sides are pushed in. Remember, the canopy sides with be held in when you put it on. You don't want the front center sticking way up. Not good! >>5. Based upon the fit above, a line was drawn on each side's bottom for the final fit cuts. That line sort of runs uphill toward the rear. The difference is about .5" from front to rear. << This may change a little when I do some final trimming; but, that's just how it may turn out when it's done. I'll hold off a bit before I start this cut; but, I think it will still be very close on mine. Your canopy may not fit this way at all. Mine is a bit high up front because I cut very little off the front of the canopy. I did cut a little off the rear. I'm not sure if that's correct; but, it worked for me. Gee, I may have a lot of head room for my taller passengers, now. >>What about the angle between the canopy (front to rear) and the cabin frame? We noticed there is quite a gap at the front edge of the cabin frame when we pressed down the canopy to the canopy frame. The frame angle is right on, too. Is this normal? We couldn't see any way to get the angle much better without dropping the cabin frame back at the top and doing a lot of cutting up front. Neither idea seemed good.<< This must be normal. >>What do you do about the gap above when you rivet the rear window to the cabin frame? I realize the rivet line is further back on the cabin frame; but, I have about a 1/16" gap at the front edge of the rear window if I leave it that way. I read where someone cut his a bit further back on the cabin frame. << If I cut my canopy at the 3/8" mark behind the front face of the roll bar, I will have a gap under the leading edge of the rear window due to the curvature of the canopy vs the angle of the roll bar. However, I can cut it further back on the roll bar and eliminate a lot of the gap. In fact, Tom suggested that I cut it further back so I can use the small channel that's formed between the front and back of the roll bar as a drip channel for when it rains. That's what I'll probably do and eliminate that gap caused by the canopy curvature angle. I have to rivet it on the rear part of the roll bar, anyway. >>How much space is there between the front canopy and the rear window along the cut line? This might help some of the above in my thinking process. I haven't seen any comments about how far to space the two sections from each other. I know a strip of glass is placed over the top to form a seal, sort of. << The glass strip appears to be optional to cover up any bad stuff or keep out water. On the other hand, it may not be needed if there is a good seal and the cut is near perfect. The space is about 1/8". That's about the width of the cutting wheel. Make that cut nice and neat. :-) Be aware that I didn't even think about working on the canopy's plexi until the temps were about 80 degrees. Yeah, I did do some of it in the upper seventies after I got started ; but, most of it has been done above 80 degrees. Today, because it was very cool, I left it alone. I'm also sanding after each cut. I'm using a sanding disk on my air drill and running it at a slower speed. I then go down the edges with a sanding block to make a slight bevel to get rid of sharp edges. It's working, so far. Also, cover up any sharp edges in skins and such so that you don't get scratches on the canopy. I hope this helps some of you. Jim Sears in KY RV-6A N198JS (Struggling with the canopy) AA-5A N26276 ________________________________________________________________________________
Date: Jun 04, 1998
><< However I doubt he will be able to carry engines from Superior without >jeopardizing his relationship with Lycoming. >> >Would someone refresh me on this? What type of engine is Superior building, >and are they flying yet? >Jim Nice They are "reverse engineering" a Lycoming O-360 (and later an O-320) with cases they have developed in house. Right now they are talking experimental only, but they had the rough cases at SNF and said that they plan on PMA'd cases eventually. When you consider that nearly every part for the Lycoming O-320/O-360 series is available aftermarket right now except the case and the data plate, it doesn't take much to get to a complete "Lycoming" engine that has never been to Williamsport! A little competition is what we've been needing in the engine market for 20 years. Lycoming is going to have to wake up and deal with this issue. Bob Steward, A&P IA AA-1B N8978L AA-5A N1976L ________________________________________________________________________________
Date: Jun 04, 1998
Subject: Re: Cleaning of Instrument Glass
> > >Listers; I have a couple of instruments, a VSI and a Turn and Bank, that > >have a sort of cloudy look to them. Upon close examination I see that > >this cloudiness is actually a film on the inside of the glass. Can these > >instruments be disassembled and the glass cleaned and reassembled by us? > If your aircraft is IFR certified then you *MUST* have the instrument > tested and re-certified by an instrument shop. If it is VFR then you are > probably "home free" with the FEDs since you are "experimenting". The > static system also runs the encoder for the Mode C, and if you booger up > the seal on the VSI you may get odd readings from the altitude readout. > > Bob Steward, A&P IA > AA-1B N8978L > AA-5A N1976L Bob, Can you point out which FAR paragraph levies this requirement on Part 91 IFR ops? I don't recall reading this requirement (but I've been building rather than flying for a couple of years, so my memory is stale). Thanks, Tim Lewis FAB complete, baffling complete, now gotta mount exhaust hangers so I can finish the lower cowling cutout so I can fiberglass on the air scoop. Everything's related to everything else... _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023 on gear, engine mounted Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ________________________________________________________________________________
Subject: Indiana RV Fly in
Date: Jun 04, 1998
Once again, Mike Wonder is holding his pot-luck lunch and RV fly-in schmooze session, at the Shawnee airport, 30 mi SW of Bloomington, Indiana (1I3). The festivities will begin around noon Saturday. There will be an estimated 5-10 RV's coming, as well as many builders like myself who kick themselves for not having their airplanes done to be able to fly in with. It is a good opportunity to have your cake and eat it too; stuff your face and talk RV's with people who like to do the same. Low pass mandatory. Thanks, Bob Japundza Network Consultant, MCSE ImageMax, Inc. Carmel, IN bjapundza@iis-intellect.com RV-6, just mounted O-360 ________________________________________________________________________________
Date: Jun 04, 1998
Subject: Projects in the Denver Area
I will be in the Denver area from Jun 9th to Jun 23rd and would be interested in seeing projects or flying planes while there. I am planning on an RV-8 but am interested in all RVs. Please reply privately, not on the list. Thanks Rod Smith ________________________________________________________________________________
Date: Jun 05, 1998
Subject: Re: [Fwd: RV seats]
Wally, Tell me what color you want, and type (fiberglass, kevlar), and when I find out for sure what the others want , I'll get back with you before I order to confirm you still want it. Thanks. Michael. (Hopefully by Friday or Saturday.) hole being 5" wide and 5.5" long, it is roughly 4.75" x 5.25". The worst implication of this is that the lense would be a little difficult to get in and out of the hole. Appearance will be all but indistinguishable. What to do if you have bought one of our kits in the last 5 months: 1 - Measure the width of the opening on the Wing Cut-out Template. a - If it is 5", you're set. b - If it is 4.75", go to 2. 2 - If your template is undersize, you can: a - Adjust it to fix the discrepancies, or, b - Email Duckworks and request a new template. 3 - If '2' and you've already cut the hole: a - Try to fit the lense in, if it is a little tight, take a little off of the lower edge of the lense. b - If you just can't get it to fit widen the hole slightly (this should not be necessary) If you do request a new template, be sure to include your mailing address. Since most kits are sold thru Van's I do not have a record of who got them. Sorry for the inconvenience, Don Wentz, Duckworks Exp Aircraft Parts ________________________________________________________________________________
Date: Jun 05, 1998
Subject: Re: Rotary engines in RVs - powersport
The rotary design was always attractive to me because it's so much simpler (no valve stems or rocker arms, no connecting rods, no cam, etc.., In principal it should be possible to make a rotary more reliable than a piston engine. Don't know if the Mazda 13b actually is very reliable, of course. It might be. In any case, I was real interested in the Powersport Rotary. It seemed that they'd worked it out well and were going to offer a ready to mount package. Then Everet Hatch died. Does anybody know what happened to Powersport? Are they still going to sell engines? --- Tom Sargent, sarg314(at)azstarnet.com ________________________________________________________________________________
Date: Jun 05, 1998
Subject: Re: Flap Quesion,
I had the local DAR in yesterday to look at the wings of my RV6 prior to closing, he found one item that I was going to re-do. Where the Piano Hinge for the flap meets the flap brace & the skin, I dont have enough edge distance on the skin. Has anyone else runinto this - Is the larger Piano Hinge Van's offers the correct fix? Other than that I have a green light to close both wings - The DAR spent aboiut 1 1/2 hours going over the Wings & was impressed with the quality of Van's Kit. BSivori(at)AOL.COM Getting ready to close Wings N929RV ( Reseved ) ________________________________________________________________________________
Date: Jun 05, 1998
Subject: Sealed nut plates and screws
Where can I get the sealed nut plates (NAS1473 ?) that are used for fuel tanks. No luck in the ACS catalog. Also, I found some 8-32 stainless steel screws with integral rubber seals rated for 500 psi. They can be purchased from McMaster Carr. About 43 dollars per hundred. I would consider them if they had a groove under the head. Have any of you seen such screws as these? Mark McGee RV4 Fuel Tanks (and overhauling my Colt's O235 in the same garage) ________________________________________________________________________________
Subject: RVs and HAM RADIO
Date: Jun 05, 1998
I think I have seen a few HAM radio callsigns appearing on the list.Any HAMS out there interested in using this medium to get in touch with other builders and discuss matters and exchange experiences? Or is there already a net setup??? PLease let me know. Regards Karl Ahamer VK2GKA ________________________________________________________________________________
Date: Jun 05, 1998
<< Where the Piano Hinge for the flap meets the flap brace & the skin, I dont have enough edge distance on the skin. Has anyone else run into this - Is the larger Piano Hinge Van's offers the correct fix? >> Now, do you lack ED on the skin, or the hinge? I have used P4 or P5 as required on the wing to get the TE of the flap to line up with the TE of the ail, with good results. If you're too close (ED) on the skin, I'm afraid I can't thelp much there... Please report your results! Check six! Mark ________________________________________________________________________________
From: "Luker, Michael G." <luker.michael(at)mayo.edu>
Subject: Oshkosh area RV Builders.
Date: Jun 05, 1998
I'm wondering if there are any RV list members or readers from the Oshkosh/Fond du Lac area? Looking for a hanger to store my airplane on occasion. If so could you contact me off line. At pluker(at)ibm.net or luker.michael(at)mayo.edu Thanks. ________________________________________________________________________________
Date: Jun 05, 1998
Subject: Engine bolt attachment for exhaust support
Listers, One of Larry Vetterman's suggested methods for supporting the aft (behind the ball joint) portion of his exhaust pipes is to use a rubber isolated strap going from the exhaust pipe up to a bolt on the oil pan of the engine. If I do that the existing Lycoming bolt (STD 1414, 1/4-20 x 1 1/8) needs to be replaced with something just a bit longer. I can either try to find a longer Lycoming bolt (STD 1204, 1/4-20 x 1 5/16 should work) or use a standard AN4 bolt (much easier to find). When I called them Lycoming couldn't recommend the AN4 bolt because they don't have insight into the relative strength of AN4 bolts and the Lycoming bolts. I got the feeling they didn't really see a problem, but they were unwilling to endorse any change to an engine with a data plate without the proper paperwork. Any insight into the impacts of replacing the coarse pitch lycoming bolt with a fine pitch AN4 bolt? Thanks, Tim Lewis Sweating the details _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023 on gear, engine mounted Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ________________________________________________________________________________
Subject: Buick V-8 installation, WARP Drive Props and System 3 Paint
Date: Jun 05, 1998
I am currently finishing up the installlation of a Buick 215 CID V-8 in an RV-6A. Are there any others out there doing the same? I would like to discuss details with anyone who is interested. Using a Belted Air Power Drive. The engine runs great!! I fit a 3-bladed WARP Drive prop to the aircraft. I had to mill a special adapter plate to fit the spinner frontplate to the prop. I have drawings if anyone is interested. I am also using System 3 paints. I think the paint is wonderful, is quite inexpensive, but it has a few quirks. If anyone is interested in discussing this paint, contact me here or directly. Roger E. Bocox In Des Moines, IA RV-6A N872RF ________________________________________________________________________________
Date: Jun 05, 1998
Mark, My problem is the ED on the skin, however I went to the hangar at 6AM this morning because it was driving me nuts, I noticed that the measurements for the hinge on to the flap were not correct, the plan calls for 1/8 inch from the center of the hinge to the skin, I,m a bit heavy. I also measured the hinge full open its 1 1/4 which is a P3 - the P4 is 1/1/2 and the P5 is a full 2 inches. Since I only did this to the right wing, I'll try the left wing over the weekend and see what happens, Any suggestions would be helpfull. Thanks Bill ________________________________________________________________________________
Subject: Re: Canopy fit.
Date: Jun 05, 1998
> > >Listers, > >Yesterday, I sent a note to the RV-list to hopefully get some >feedback concerning my canopy installation. I was stopped cold >because I didn't have the slightest idea if I was about where I >needed to be. I got two responses. One helped a little. The other >wished me luck. Both were appreciated; but, the lack of response >from those of you who have travelled this road before me was very >disappointing. > Jim, Please remember we are also building airplanes and it is time consuming. I considered responding to your post but did not for two reasons. --I could not determine for sure if you have a tip-up or slider. The procedures are very different for the two designs and I'm not sure someone who has done one style can have much of intelligence to say about the other. If it said anywhere in your post what you are building I could not find it. --You asked many questions in one post. Personally I just am not willing to spend the time necessary to answer so many questions at once. I know the feelings about canopy fitting. I built a tip-up (as I believe you are) and had the similar experience of cutting and cutting at the front but the back never came up near the skin. Finally, when I was about to run out of canopy at the front I just made the lateral cut and then cut a thin wedge to make things line up at the roll-bar. Many times I thought the whole mess was hopeless but in the end it turned out reasonably well. With all my problems I felt grateful for the bits of advice I got from the list and I got some good ones through direct e-mail. I never felt like anyone on the list owed me anything, and I think having to figure some of it out myself contributed to the education and recreation stuff we are supposed to be doing. Larry Pardue Carlsbad, NM Pacer N8025D RV-6QME N441LP Reserved Installing Radios ________________________________________________________________________________
Date: Jun 05, 1998
Subject: Re: Engine bolt attachment for exhaust support
Look in the engine parts book. the sump bolts are different lengths. Seeif you can find one that will work even if you have to use a few washers. The an4 bolt will only work if it is a thru bolt as it has fine thread. The tapped holes are course. Stew RV4273sb ________________________________________________________________________________
Subject: Re: N58RV THis is all anyone knows
Date: Jun 05, 1998
> > Until the testing is finished this is all anyone knows! The >check for the tail kit is still going out on Monday , but the wing kit >will wait until there is a resolution > We all want to "know" what happened. I have some bad news. It is perfectly reasonable and likely that we may never "know" what happened. Those of you who have been on this list for a long while remember when my friend Kosta Asselanis perished in his -4 in Minnesota. We still don't "know" what happened. I am fairly sure that even Kosta never knew what was wrong. I just finished my condition inspection the pink panther. While I was twisting screws and lubeing linkages, I spent allot of time thinking about Kosta and wondering what happened. Neither the FAA or the NTSB "know" why TWA 800 blew up either. For those of you who like to live with absolute certainty, this aviation business is a bad one. One thing that I "know" absolutely is that as long as we fly airplanes we will crash them. We should continue to strive for no crashes, but it will never happen. As for the discussion of this tragedy on this list, I think the way we resolve these issues in our minds is by talking about them rationally with like minded individuals whom we respect and trust. Discussing the passing of a friend in an experimental airplane with my attorney friends is not going to get me any closer to understanding what happened or dealing with the uncertainty of this business. We should be able to find more like minded friends here than anywhere and I think a rational and polite discussion here is healthy. Having said that, all need to be extremely careful in how we choose our words in these discussions, and understanding that sometimes things don't read the way we meant them. When this is all done we will all fly our RV-4, RV-8, Bonanza, or 747, with the knowledge that sometimes they crash for reasons we will never understand. Tailwinds, Doug Rozendaal dougr(at)petroblend.com http://www.petroblend.com/dougr ________________________________________________________________________________
Date: Jun 05, 1998
Subject: Re: Sealed nut plates and screws
Mark: Try Genuine Aircraft Hardware in Paso Robles, CA at 805-239-3169. They will have everything that you need (including NAS 1473 sealed nutplates) at reasonable prices with excellent service. Nice people too. Hope this helps, Jon Ross RV-80094 ________________________________________________________________________________
Date: Jun 05, 1998
I can't see any problem with using an AN bolt, but I'm not a structural engineer either. I wrestled with that same issue then decided to go a different direction. I found some small rubber hangars at an exhaust place that look like oval "doughnuts" that are about 3"x2" with a hole in each end. One end bolts to the nosegear support with an Adel clamp, the other end to the pipe with a hose clamp. Then there is a piece of small steel tube attaching both pipes to each other. Works very well, and puts a little movement in the slip joints to keep them free. Ed Bundy RV6A - Eagle, ID - first flight 11/20/96 ebundy@bigskytel.com - http://www.bigskytel.com/~ebundy/ > that the existing Lycoming bolt (STD 1414, 1/4-20 x 1 1/8) needs to be > replaced with something just a bit longer. I can either try to find a longer > Lycoming bolt (STD 1204, 1/4-20 x 1 5/16 should work) or use a standard > AN4 bolt (much easier to find). When I called them Lycoming couldn't > recommend the AN4 bolt because they don't have insight into the relative > strength of AN4 bolts and the Lycoming bolts. ________________________________________________________________________________
Date: Jun 05, 1998
<< Any insight into the impacts of replacing the coarse pitch lycoming bolt with a fine pitch AN4 bolt? >> On advice of the A&P who did my overhaul, I replaced the Lycoming bolt with a longer Grade 5 hardware store bolt of the same pitch, to keep the same thread engagement up in the engine case. All I can say is I still have my data plate (that's a long story in itself) and after a whopping 3.5 hours it hasn't fallen out of the sky. Bill Boyd RV-6A Virginia ________________________________________________________________________________
Date: Jun 05, 1998
> > >Listers, > >One of Larry Vetterman's suggested methods for supporting the aft (behind >the ball joint) portion of his exhaust pipes is to use a rubber isolated >strap >going from the exhaust pipe up to a bolt on the oil pan of the engine. Tim, This is interesting to me. I got my Vetterman system about a month ago and that method of attachment is not mentioned. I got a rather vague sheet showing the supports being attached to the engine mount. The actual recommended geometry is not clear from the sheet. I am not crazy about attaching to the engine mount because of the relative movement between it and the engine even though there is a little isolation through the use of rubber hose in the middle of the attach tubes. I wonder if anyone has had good or bad experiences with these two different attach methods and I wonder why your method isn't mentioned in my documentation? Larry Pardue Carlsbad, NM Pacer N8025D RV-6QME N441LP Reserved Installing Radios ________________________________________________________________________________
Date: Jun 05, 1998
Subject: Looking to see RV6A/6 in Dallas area
Folks, In my research to find a suitable plane to build - I'd like to see an RV6A/6 in the Dallas area. I'm looking at things like XC comfort, storage area, layout, and maybe a $30k free ride. The Dallas area includes about 1.5 in a C-152 - so I can fly in to visit if necessary. Please respond directly - I don't think we need to choke up bandwidth on the server for this. Thanks, Ralph Capen Ralph.E.Capen(at)mci.com ________________________________________________________________________________
Date: Jun 05, 1998
<< Where can I get the sealed nut plates (NAS1473 ?) that are used for fuel tanks.>> Try Olander. << Also, I found some 8-32 stainless steel screws with integral rubber seals rated for 500 psi. They can be purchased from McMaster Carr. About 43 dollars per hundred. I would consider them if they had a groove under the head. Have any of you seen such screws as these? >> Try Olander again. These are made for APM Hexseal. Both are listed in the Yeller Pages. -GV ________________________________________________________________________________
Date: Jun 05, 1998
<< One of Larry Vetterman's suggested methods for supporting the aft (behind the ball joint) portion of his exhaust pipes is to use a rubber isolated strap going from the exhaust pipe up to a bolt on the oil pan of the engine. If I do that the existing Lycoming bolt (STD 1414, 1/4-20 x 1 1/8) needs to be replaced with something just a bit longer. >> Tim- These are coarse thread bolts because they're going into tapped aluminum sans helicoils. Fine threads would need helicoils for strength in the soft AL. IMO just use the existing bolts if your strap is 1/8" thk. If you're sure that you want to change the length, get some Grade 8 coarse bolts from the hardware store. -GV ________________________________________________________________________________
From: "Weichert, Wolfgang" <Wolfgang.Weichert(at)nrc.ca>
Date: Jun 05, 1998
I think this has nothing to do with the strength of the bolt. If you tighten a course thread to a specific torque, and you do the same with a fine thread bolt (same torque) you have different clamping pressure between head and nut. So what you want to know is how much clamping pressure the specified torque for the coarse thread would exert, and then find the torque for the fine thread causing the same clamping pressure. Use that torque for the finer thread. I don't know if there is much difference in the real world. I believe torque figures are stated to ensure minimum clamping pressure without stripping the thread. ====================================== * Wolfgang Weichert System Support Unit * Phone (613) 993-9589 Fax (613) 941-0175 * e-mail wolfgang.weichert(at)nrc.ca ====================================== -----Original Message----- From: Tim Lewis [SMTP:timrv6a(at)earthlink.net] Sent: Friday, June 05, 1998 9:32 AM To: rv-list(at)matronics.com Subject: RV-List: Engine bolt attachment for exhaust support Listers, One of Larry Vetterman's suggested methods for supporting the aft (behind the ball joint) portion of his exhaust pipes is to use a rubber isolated strap going from the exhaust pipe up to a bolt on the oil pan of the engine. If I do that the existing Lycoming bolt (STD 1414, 1/4-20 x 1 1/8) needs to be replaced with something just a bit longer. I can either try to find a longer Lycoming bolt (STD 1204, 1/4-20 x 1 5/16 should work) or use a standard AN4 bolt (much easier to find). When I called them Lycoming couldn't recommend the AN4 bolt because they don't have insight into the relative strength of AN4 bolts and the Lycoming bolts. I got the feeling they didn't really see a problem, but they were unwilling to endorse any change to an engine with a data plate without the proper paperwork. Any insight into the impacts of replacing the coarse pitch lycoming bolt with a fine pitch AN4 bolt? Thanks, Tim Lewis Sweating the details _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023 on gear, engine mounted Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ________________________________________________________________________________
Date: Jun 05, 1998
>One of Larry Vetterman's suggested methods for supporting the aft (behind >the ball joint) portion of his exhaust pipes is to use a rubber isolated strap >going from the exhaust pipe up to a bolt on the oil pan of the engine. >Tim Lewis Tim, Another method of support would be to attach some rubber belting to a plate that attaches at the carb that you attach your throttle & mixture cable to. I did this on my 150 hp RV-6 and it has worked well for 400+ hours. I didn't use Van's plate because I used a different throttle cable (highly recommended---simple push pull with friction lock as opposed to the vernier, especially the vernier supplied by Van's). I bent a flange down on the aft end of the "carb plate", drilled some holes in it and bolted on some rubber belting. To the bottom of the belting, I attached the pipe hangers. My carb plate does have a support of 4130 tubing that is attached at one end to a bolt on the prop governor pad. I can't say if this additional support is necessary but it seemed like a good idea at the time. Between the tube support and where it attaches to the top of the "carb plate" is where I attached my ground strap. I cleaned the steel so there would be good contact and then coated the connection with "Liquid Electrical tape". Again, no problem in 3 years and 400+ hours. A side note: I started out with the Vetterman mild steel, 4 pipe and switched over to the S.S. cross-over. I initially used stainless steel hose clamps to clamp the pipes to the support. I had a heck of a time keeping clamps on the plane. They broke on a regular basis. I'm now using regular muffler clamps. I know, they're heavey and ugly but they haven't let me down, yet. If anyone elects to stay with the S.S. hose clamps, I'd recommend carrying a few spares in the plane and checking security on the pipes before every flight. Bob Skinner RV-6 415 hrs. Buffalo, WY bskinr(at)trib.com ________________________________________________________________________________
Date: Jun 05, 1998
Subject: Phoenix, Arizona
I'm looking for some contacts and info of Phoenix, Arizona area RV'ers for hanger space or sharing if possible. I understand the Arizona area is quite RV active. Please respond outside the list for discussion at fletke(at)pwc.com K. Fletcher RV-4, C-FMYO ________________________________________________________________________________
Date: Jun 05, 1998
Subject: Re: Buick V-8 installation, WARP Drive Props and System 3 Paint
Exciting, keep us posted on your flight test results. Bernie Kerr, 6A fuselage, about to order Lycosarus, SE Fla. ________________________________________________________________________________
Date: Jun 05, 1998
> Any insight into the impacts of replacing the coarse pitch lycoming bolt with a > fine pitch AN4 bolt? Tim, As was previously mentioned by Gary V. stick with the coarse thread. Standard engineering practice is to alway use coarse thread in aluminium. The depth of fine (AN hardware) threads is not as deep as coarse thread. Due to the reduced (compared to steel) strength of aluminium, coarse threads are needed to prevent the aluminium threads from stripping out. It is the aluminium case castings that require that coarse bolts be used here. Rule of thumb.... Coarse threaded fasteners are stronger. Fine thread fasteners resist loosening from vibration better. Charlie Kuss RV-8 prepping wing ribs Boca Raton, Fl. ________________________________________________________________________________
Subject: Electrical wiring seminar at OSHKOSH
Date: Jun 05, 1998
I will be putting on a seminar at OSHKOSH on Friday July 31, in tent #4 at 8:30 AM. This seminar is for anyone who needs basic information on wiring you homebuilt aircraft. Things covered will be simple schematics, wire numbering, wiring diagrams, wires, connectors, wiring methods, determining wire gauges needed, why the AC-43 wants you to do things in a certain way, etc. This is not going to be a detailed indepth discussion aimed at electrical engineers and PHDs. It is basics for electrical dummies. (not really). If you or anyone you know would benefit from such a program, have them stop by. Roger E. Bocox,EE RV-6A N872RF ________________________________________________________________________________
Date: Jun 05, 1998
<< I think this has nothing to do with the strength of the bolt. If you tighten a course thread to a specific torque, and you do the same with a fine thread bolt (same torque) you have different clamping pressure between head and nut. >> ________________________________________________________________________________
Date: Jun 05, 1998
From: Terry Mortimore <terry.mortimore(at)sympatico.ca>
Roger Bocox wrote: > > I am currently finishing up the installlation of a Buick 215 CID V-8 in an > RV-6A. Are there any others out there doing the same? I would like to discuss > details with anyone who is interested. Using a Belted Air Power Drive. The > engine runs great!! > I fit a 3-bladed WARP Drive prop to the aircraft. I had to mill a special > adapter plate to fit the spinner frontplate to the prop. I have drawings if > anyone is interested. I am also using System 3 paints. I think the paint is > wonderful, is quite inexpensive, but it has a few quirks. Hi Roger, keep us posted. Couple of questions, where are you planning to mount the rad and what rad are you planning to use? I'm leaning toward a P-51 style belly scoop. tailwinds, terry Terry Mortimore 2.7L Subaru RV-6A 38 Cartier St. Sault Ste Marie terry.mortimore(at)sympatico.ca Ontario Canada P6B-3K2 RAA #4061 EAA #229708 ________________________________________________________________________________
Subject: System Three Paint system
Date: Jun 05, 1998
I have had quite a few requests to post my experiences with the paint. Here goes. 1. Primer. I am using the yellow-green anti-corrosion primer. This stuff is very full of solids, and it must be mixed with an electric mixer each time it is used. It must be thinned to about 10% to get it to spray properly. If the surface metal is prepared well, the primer sticks like iron and is as hard as concrete. I think it will be on there forever. You cannot hardly scratch it off without gouging the metal underneath. It must be applied pretty wet to get it to smooth out. If dry at all, it will make the surface like sandpaper. It fills well, and would probably hide all rivets in a couple of coats. IT sands well. Sand dry with 220 to 320 grit first, and then touch up by wet sanding with 400 before finish coats. I like the primer, although I don't know how you would ever get it off if you had to. 2. Paint system The system is a linear polyurethane which thins with distilled water. The best part is that you don't have to spend tons of money on thinner. The system is a base coat-clearcoat system. I am doing a somewhat complicated paint scheme and so I am only putting one coat of paint on in each area. I am not painting the entire plane white first. Inm this way, I can get the paint surface levels more even and have a smooth top coat when I put the clear over it. 2A. Base coats. The paint is mixed up with a crosslinker first. You put in 8 drops per fluid ounce of paint. Note: you must let this sit for 20 minutes before using the paint. The trick with the base and top coats is to thin the paint very little. I have found that about 5% thinning is all that is needed. Apply a somewhat dry coat first, then recoat with a medium wet coat every 20-30 minutes until the desired results are obtained. The paint is very vsicous and heavy, and will run easily on vertical surfaces if put on too heavy. The only problem I am having with the paint is that it does not allow the 3-M Fine-line tape to come off very well. The paint will not stick well to the masking tape, and wants to lift off the tape when you peel it off. You have to either have to pull the tape off when the paint is still quite wet, or wait until the paint is just about dry. When it is dry, you need to run and X-Acto knife along the edge to score the paint. This works quite well, and makes a nice clean edg 2B Final Clear Coat Before applying the clear coat, wet sand the paint, smoothing down the paint seam edges with maybe 400 sandpaper, and then top it off with 600 grit. Be careful with the 400 as you can cut too deep and have to recoat! Just be sure to knock the shine off the paint with the 600 grit. I used dry transfer lettering to put on the "NO STEP" and the fuel filler information. The top coat is applied just like the base coats. Wipe the entire surface with Isopropyl alcohol and let dry. Do not use alcohol on the lettering, or it will come off! Wipe with a tack rag,and go at it. The clear coat can be sanded, if desired, with 600 up to 2000 grit paper, and then use rubbing compound/polishing compound, before waxing. Conclusions So far, I like the system. It is a little different , and it takes a little to get used to it. The advantage of a base coat/clear coat system is that dings in the paint will ding, usually, the clear coat,and the plane will still look good. Let me know if anyone else has any other experiences/ comments aboutthe paint. Roger Bocox RV-6A N872RF ________________________________________________________________________________
Date: Jun 05, 1998
From: Thomas Nguyen <TNGUYEN(at)oss.oceaneering.com>
Subject: Engine bolt attachment for exhaust support -Reply
If I read your message right, I believe that there is a misconception about the preload (clamp load) on the bolt with different type of threads (coarse vs. fine thread). The preload on the bolt is determined by the applied torque, joint stiffness, bolt diameter and the theads lubrication. There is insignificant difference on the bolt preload between the coarse and fine thread if the same torque is applied. However, with the same bolt diameter, the minimum tensile area on the coarse thread bolt is smaller than the minimum tensile area on the fine thread. Therefore, in general practice, fine thread bolt has higher torque limit than the coarse thread bolt. For example: Nominal diamete Minium Tensile Area #10 -24 (UNC) 0.190" 0.0175 In^2 #10-32 (UNF) 0.190" 0.020 In^2 For tension application, the failure mode on the bolt is normally at the minimum diameter (in the threaded section) or at the fillet radius under the bolt head. Hope this helps. T.Nguyen, P.E Analysis Engineering Manager Fuselage in Jig >>> "Weichert, Wolfgang" 06/05/98 11:02am >>> I think this has nothing to do with the strength of the bolt. If you tighten a course thread to a specific torque, and you do the same with a fine thread bolt (same torque) you have different clamping pressure between head and nut. So what you want to know is how much clamping pressure the specified torque for the coarse thread would exert, and then find the torque for the fine thread causing the same clamping pressure. Use that torque for the finer thread. I don't know if there is much difference in the real world. I believe torque figures are stated to ensure minimum clamping pressure without stripping the thread. ________________________________________________________________________________
Date: Jun 05, 1998
> >One of Larry Vetterman's suggested methods for supporting the aft (behind > >the ball joint) portion of his exhaust pipes is to use a rubber isolated > >strap > >going from the exhaust pipe up to a bolt on the oil pan of the engine. > This is interesting to me. I got my Vetterman system about a month ago > and that method of attachment is not mentioned. I got a rather vague > sheet showing the supports being attached to the engine mount. I have the same sheet. The alternative method was on the reverse side. Did you look on the back side of the sheet? As I recall it just shows two straps of 4120 (.063 or thinwall tube I think) coming down from appropriate sump bolts, with rubber heater hose used as shock straps, and a cross piece between them. I talked to Larry about the pros and cons of each method. He didn't seem to have a preference for which way was better. Hanging from the engine mount is probably easier, and he said that as long as you have some sort of rubber shock strap it's not a problem. I know several people who have done it this way. He also said going from the sump seems to work fine as well but you still need the isolation straps, and also a crosspiece. You might want to give Larry a call (he's in the yeller pages). He was happy to talk to me about it. Randall Henderson, RV-6 (engine/finish) Portland, OR randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Jun 05, 1998
> Where can I get the sealed nut plates (NAS1473 ?) that are used for fuel > tanks. No luck in the ACS catalog. > > Also, I found some 8-32 stainless steel screws with integral rubber seals > rated for 500 psi. They can be purchased from McMaster Carr. About 43 > dollars per hundred. I would consider them if they had a groove under the > head. Have any of you seen such screws as these? Mark, Evidently you are going down the much travelled path of wanting to make your tank plates removable and not pro-sealed on. Hopefully this won't start another debate about the pros and cons of that idea -- I won't get into that, there's plenty of it in the archives already! But I do think that the self-sealing screws would be a better solution than the sealed nut-plates. If you think about the way the nutplates work they are only sealing the hole through the bulkhead, anything that might seep around the gasket next to the screw could potentiallyt get out the hole in the coverplate. For this reason I think the self-sealing screws would be a better solution. I have seen these in a few catalogs and all the ones I've seen do have a groove on the underside of the bolt head with an o-ring in it. One place I've seen these is at Long-Lok Fasteners Corp., at www.longlok.com. Randall Henderson, RV-6 (engine/finish) Portland, OR randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
Date: Jun 05, 1998
Subject: Fuselage
To who ever's been there. I plan on running my elect elev trim wire to up front (no other electrical this area). Should I just drill holes in the bulk heads. Also bulkhead F604 is it acceptable to drill holes in this bulkhead for electrical and static tube????? Thanks for any help. RV6A joe/fuselage ________________________________________________________________________________
Date: Jun 05, 1998
Thanks for all the feedback, guys. After I posted my question I spent 4-6 hours making different mock up brackets and examining options for attaching the supports to the plane. On the -6A I found that the engine mount tubing running down to the nose wheel attachment makes it quite challenging to run a strap from the sump to the exhaust while missing the Robbins heat muffs. I was also concerned that such a configuration might not keep the exhaust pipes from moving side to side enough to hit the engine mount. I finally stumbled on to a configuration that seems to work... For each exhaust pipe (I have the crossover Vetterman system) I fabricated a support out of 1/16" steel that is (mostly) 1" wide and about 8" long. The support starts at the 3/8" bolt that holds the nost gear portion of the engine mount to the firewall. The support has a 3/8" hole in it, and goes between the engine mount and the nut. The support then goes up and forward, parallel to the engine mount tube that leads to the nose gear. Then the support is bent down about 300 degrees so that it points down at the exhaust pipe and aft. Then I bolted a couple of layers of old car tire sidewall (1" wide, 4" long) extending down and aft from the support. ________________________________________________________________________________ steel (clamped to the exhaust pipe) that almost reaches the support described above. The "hook" is also bolted to the tire sidewalls. (To stabilitze the first support I use an adel clamp attached to the engine mount. It is bolted to a little tab that protrudes from the side of the support.) The effect of this system is similar to that shown in one of Mr Vetterman's options, but I like my modification because it doesn't require a cross over support joining the two exhaust pipes, and the support I fashioned seems firm enough to prevent the exhaust pipe from hitting the nose gear portion of the engine mount, or the cowling. I'll post a picture to my web site if I ever get access to a scanner. Thanks for all the ideas, gang! Tim _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023 on gear, engine mounted Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ________________________________________________________________________________
Date: Jun 05, 1998
Subject: RV-8 N801RV FLIES!!!
Today is the day I've been waiting on for 22 months. She left the earth for the first time!!!! The first flight lasted 1.4 hours. I returned to the ground only to fill 'er up and off I went again. Boy, does that IO-360 drink fuel. This is the third RV that I have had the honor and fortune of flying on the initial flight and it doesn't get any less exciting. It's dark now. I can hardly wait for the sun to come up tomorrow. Keep building guys. There is a light at the end of the tunnel and boy is it bright. Regards, Louis Smith RV-8 N801RV SN:80126 3 hours TTSN ________________________________________________________________________________
Date: Jun 05, 1998
Subject: Re: Wagner HVLP
<< THE WAGNER CAPSPRAY IS A TURBINE. AND I WOULDN'T SAY IT WAS CHEAP. BELIEVE I GAVE AROUND $550 FOR IT TWO YEARS AGO. DON'T RECALL THE MODEL THOUGH. IT HAS A REAL NICE 5 ADJ GUN. I COULD PUT ONE COAT OF WHITE ON MY rv4 FUSE WITH 1AND1/2 QTS. >> I have a little experiance with the Wagner HVLP systems, (worked in their quality department) They make severial diffrent models, from the basic "Home Depot" model with a plastic spray gun, up to a high end comertial unit with electro static charge to increase transfer percentage. I am currently using the low end unit that I got as a "field test" before I left. It is basicly a shop vac with a hose on the out put, it works good for primer but I would not use it for a final coat on my plane. The higher end units have much higher spray pressure and will give a very good result. Wagner also makes the same higher end HVLP units in diffrent color for sherwin williams. Shop around for the best price. Hope this helps Alan kritzman RV-8 waiting for Fus. ________________________________________________________________________________
Date: Jun 05, 1998
Subject: uphostery
would anyone on the list be able to direct me to a first class uphostery shop? I would like a professional job. thanx in advance. Randy, RV-6 time to start the finishing kit ________________________________________________________________________________
Date: Jun 05, 1998
> All I can say is I still have my data plate (that's a long story in itself) > and after a whopping 3.5 hours it hasn't fallen out of the sky. > > Bill Boyd > RV-6A Virginia > Speaking of engine data plate there is a good article in Kitplanes in the letters section this month (July 1998) on this very subject. It says you do not turn your data plate into anyone just remove and keep it if you do something to the engine to make it uncertified. -- Jerry Springer RV-6 N906GS First flight July 14, 1989 :-) Hillsboro, OR jsflyrv(at)ix.netcom.com ________________________________________________________________________________
Date: Jun 05, 1998
Subject: Re: uphostery
<< would anyone on the list be able to direct me to a first class uphostery shop? I would like a professional job. thanx in advance. Randy, RV-6 time to start the finishing kit >> Randy, I would suggest D.J.Lauritsen of Cleveland Aircraft Tool. She did the leather seats in my RV8 and I have received a lot of compliments on them. Regards, Louis Smith RV-8 N801RV ________________________________________________________________________________
Date: Jun 04, 1998
Subject: Re: RV-8
The following was copied from Vans Web site. I'm posting it here for those who do not have net access. No comments or speculation. 6/5/98 NTSB Identification: LAX98FA171 Accident occurred MAY-24-98 at RIPLEY, CA Aircraft: Van's Aircraft, Inc. RV-8, registration: N58RV Injuries: 2 Fatal. On May 24, 1998, at 0630 hours Pacific daylight time, an experimental RV-8, N58RV, experienced an in-flight structural separation and crashed 1 mile south of Ripley, California. The aircraft was destroyed and the pilot and pilot-rated passenger sustained fatal injuries. The aircraft was being operated by Van's Aircraft, Inc., as a business flight when the accident occurred. The flight originated from a private agricultural strip in Blythe, California, at 0620. Visual flight conditions prevailed at the time and no flight plan had been filed. A relative of the passenger reported that on departure the pilot was seated in the front seat, while the passenger was in the back. The aircraft is equipped with dual controls, however, the throttle can only be operated from the front seat. An eyewitness, about 1.5 miles northwest of the crash site, reported that he heard the sound of an engine surging and looked to see where the sound was originating. He saw a yellow aircraft flying straight and level, about 1,000 feet agl. The aircraft was on a southbound heading, about 1 mile east of his location. He estimated that he watched the flight for over a minute when he saw something fall from the aircraft. This was followed almost immediately by a loud boom that he described as sounding like a "shotgun." The aircraft's nose suddenly pitched up about 45 degrees, then abruptly nosed over as it began to roll. The aircraft entered a nose-down spin and continued in a vertical descent until impact. A postaccident inspection of the aircraft by the Safety Board found an outboard section of the left wing about 0.2 miles northeast of the main wreckage. The main spar of the left wing was fractured at a point inboard of the aileron and outboard of the flap. The main spar of the right wing was also fractured about the same location, but remained attached by the wing's outer skin. According to the kit designer, the wing design had previously been statically tested to failure, which had required in excess of 9 G's. ________________________________________________________________________________
Date: Jun 05, 1998
Subject: Re: System Three Paint system
Roger and others considering using System 3 paint; I painted my Kitfox with System Three about three years ago. The following is my experience. Roger, you might want to be sitting down when you read this. The good news is, which unfortunately doesn't apply to us tin airplane builders, is it sticks great to fabric, and seems to stick OK to fiberglass. BUT, after about two years, it started peeling off in sheets on all my aluminum parts. Primer and all. The first of this year and I removed all the larger aluminum parts, stripped them down to bare aluminum, and re-primed them with epoxy primer and DuPont Centari enamel. The other neat thing that is happening is that blisters are developing until the clear coat on both the fabric and plastic surfaces. And you have to clear coat it to get a gloss. A knowledgable person said it was mildew, which he said is fairly common with clear coats and water based paints. I made serveral attempts to explain my problems to System Three, but they offered little help. They did admit that it didn't stick well to aluminum. (One of the owners has built . .yes . . a plastic Glasair.) Now maybe they have improved their paint. I hope so. It hadn't been out long when I used it. But I'll never use it again. Mike Robbins RV-8Q #591 HS finally finsihed Issaquah, WA ________________________________________________________________________________
Date: Jun 06, 1998
<< I started out with the Vetterman mild steel, 4 pipe and switched over to the S.S. cross-over. I initially used stainless steel hose clamps to clamp the pipes to the support. I had a heck of a time keeping clamps on the plane. They broke on a regular basis. I'm now using regular muffler clamps. I know, they're heavey and ugly but they haven't let me down, yet. If anyone elects to stay with the S.S. hose clamps, I'd recommend carrying a few spares in the plane and checking security on the pipes before every flight. >> A clamp that I have been very pleased with for attaching pipes to their hangers is available from McMaster-Carr and is called a T-bolt Clamp. It is p/n 5312K11. I replaced the fiber locknut with an all metal 1/4-20 (coarse thread) nut and cut off some of the t-bolt length to fit. It is very robust. These are often used by OEM motorcycle companies for attaching mufflers to pipes. -GV -GV ________________________________________________________________________________
Date: Jun 06, 1998
<< would anyone on the list be able to direct me to a first class uphostery shop? I would like a professional job. >> DJ Lauritsen at Cleaveland tool is the class act. -GV ____________________________________________
