RV-Archive.digest.vol-fi
August 29, 1998 - September 04, 1998
      seems that way to me.  The sequence was a bit confusing at the front
      of the instructions due to the old cowl instructions.
      Jim Sears in KY
      RV-6A N198JS
Date: Aug 29, 1998
Subject: Re: looking for used tools
DENNIS HART wrote: > > > Listers- > > Wanted to thank all for the words of encouragement regarding building > before having pilot license. It was the final little push I needed. I am > setting up the garage and plan on ordering tail next week. > > I was wondering if there was any sort of used tool market among the > listers? > Who needs 500 clecos after the plane is built,etc.I figure the more I can > save the sooner I will fly. > Any responses off list @ dennishart(at)mindspring.com please. > > Dennis-getting spooled up Dennis, Don't be surprised if you end up spending $1500-$2000 on tools over the life of your project. There are a lot of specialty items you'll need. All of us builders think we are going to build "another one" someday and it's hard to part with tools once you've bought them. There is a little of Tim Allan in all of us! Ed Cole RV6A fuse skins ________________________________________________________________________________
Date: Aug 29, 1998
Subject: Re: IO-360 vs O-360
> >The question is will a C1E6 work on the RV ? > > >BSivori @AOL.Com >Wings Closed >N929RV ( Reserved ) I believe the "C" series engines have rear mounted injector bodies. This presents some problems - I think people have been converting them to the front"A" or "B" series setup. It is counterwieghted which some folks think is an advantage. Shelby in Nasvhille. IO-360 A1B ________________________________________________________________________________
Subject: S-type cowl and O-320 FAB
Date: Aug 29, 1998
Listers, I've fitted the VA-130C plate to the carb, fitted the filter and mounted it to the VA-130C, and now am ready to start playing with the VA-130B and VA-130A tunnel parts. I have yet to fit the scoop to the cowl. I guess these questions go out to the S-type cowl users since the cowl is marked for the scoop. The instructions are sort of sketchy, at best. 1. In my initial look, I may have to do some trimming at the front of the VA-130B to allow the scoop to fit in place. Did you? 2. Did the scoop fit inside the outlines without adjusting back and forth to meet the VA-130B? 3. I've noticed I've got the do some trimming on the VA-130B to allow for the carb sump. Did you? 4. The instructions say to put the VA-130B on the VA-130C to do the horizontal swings for the scoop line up. I found that it didn't make sense to do this without having the filter in place so I can see how it all fits as I do the fitting to the scoop. To me, the filter must sit inside the hole in the VA-130B, since it's been cut out for it. If I can't have it place while I do the fitting, the filter may not rest in place within the VA-130B and could cause air leaks. Did you do it this way to make sure the filter fits the hole during the fit up? Any help is appreciated. I found more instructions for the old cowls up front than for the newer ones. Somewhere along the way, some things appear to have been left out for those cowls after 1991. Maybe it just seems that way to me. The sequence was a bit confusing at the front of the instructions due to the old cowl instructions. Jim Sears in KY RV-6A N198JS ________________________________________________________________________________
Date: Aug 29, 1998
Shelby Smith wrote: > > > > > > >The question is will a C1E6 work on the RV ? > > > > > >BSivori @AOL.Com > >Wings Closed > >N929RV ( Reserved ) > > I believe the "C" series engines have rear mounted injector bodies. This > presents some problems - I think people have been converting them to the > front"A" or "B" series setup. It is counterwieghted which some folks think > is an advantage. > > Shelby in Nasvhille. > IO-360 A1B > The "C" series engines can be converted by machining the pad on the front of the sump to accept the injector body or repalcing the sump with an A1A type sump. Check the last RVator for Dave Barnharts conversion(although his was an IO320) Ed Cole ________________________________________________________________________________
Subject: Re: AN BOLT SIZES_CORRECTION!!
Date: Aug 29, 1998
> >> There is >>no AN3-8 bolt since that would be one inch long and then it is called >>an AN3-10 or 1" plus 0/16". > >John, I'm confused. If the scale is sixteenths, then wouldn't the -8 bolt be >1/2 inch long. Did you possibily misstate the scale? > >Joel > Damn, I looked at that email twice so I'd get it right and still messed up. You're right, first number is ?/16"s and second number is ?/8". Thanks for catching that. AN3-7 is 3/16" bolt and 7/8" long ( my fingers still wanted to make it 7/16"). John ________________________________________________________________________________
Date: Aug 29, 1998
Subject: Tubes and fittings
Looking in Aircraft Spruce and Wicks catalogs, I'm trying to figure out which polyethylene, polyurethane or nylon fittings to use for which tubes. I have figured out the NPT (pipe) threads. But, when the size says 1/4 Thread (Wicks) or 1/4T (ACS), what size tube would I use: 1/4" ID or 1/4" OD? In other words does 1/4 "Thread" go with 3/8" OD hose or 1/4" OD hose? Also, ACS catalog says to use Nylon for fuel and Polyethylene for air. Wicks saya Polyurethane for fuel and Nylon for air. What is best for fuel? I'll be using a 2.5 - 4 psi pump. Would there be any reason not to have 6D lines from tanks to pump and 4D lines from pump through filter and flow sensor to carbs? Or is it better to have smaller diameter lines in the suction lines from tanks to pump? I do not anticipate a flow above 15 GHP max. I'm also looking for oil lines for higher temps than MIL-H-6000-10 (250F), to fit the fittings I've got (MS27223-1649-1-10-10D & MS24590-1120-10). Looks like it needs a hose with 1" OD and 1/2-3/8 ID. ________________________________________________________________________________ MIL-H-83797 5/8" hose. Any suggestions? Finn ________________________________________________________________________________
Subject: Newbie semi disaster...
Date: Aug 29, 1998
Hello all - I have been monitoring this list for several months , started my RV6A emp kit in July and after a couple of goof ups (the 610 and 614) I was all set to prime everything for the HS and then set to jig. Well my kids were gone my wife was gone I had all day to prime...set the compressor in the garage final cleanup and prep of materials mix the primer( SW wash prime) and load the Dockens prime gun shoot on some cardboard adjusting the pressure looks good... away I go....Well it hits the aluminum and I can tell its a glooby mess way to much primer coming out I try to adjust the cup falls off......Well this is no good so I get out a regular spray gun more clean up time but.....well after re-cleaning the parts and ready to try again...same problem I believe, spotty very uneven coverage I believe it should be a very light see through covering correct? well its a good thing these parts are all inside and won't be seen because its ugly.....any comments or suggestions on how this is done so it doesn't look so bad or doesn't it really matter. Dreaming of the day I'll be flying.... needing to get back to work. Kevin J. Grammes Tecumseh, MI. RV6A - Emp. ________________________________________________________________________________
Date: Aug 29, 1998
Subject: Re: Exhaust System Mounting Distances
Randall, Thanks for the input. Since I still have to refit the "Scoop" to the bottom of the cowl (part of the repair process...) I should have a little flexibility as to how everything fits. Thanks everyone for the input..... Fred Stucklen RV-6A N925RV wstucklen1(at)juno.com E. Windsor, Ct. ________________________________________________________________________________
From: "Leslie B. Williams" <lesliebwilliams(at)email.msn.com>
Subject: Re: Newbie semi disaster...
Date: Aug 29, 1998
This has been discussed and is in the archives. I found that thinning it according to Van's suggestion instead of what's in the instructions works best. If you don't get it thinned enough or mixed properly, what you got is what you'll get! Yuk! Les Williams/RV-6AQ/Tacoma WA >pressure looks good... away I go....Well it hits the aluminum and I can >tell its a glooby mess way to much primer coming out I try to adjust the >cup falls off......Well this is no good so I get out a regular spray gun >more clean up time but.....well after re-cleaning the parts and ready to >try again...same problem I believe, spotty very uneven coverage I believe >it should be a very light see through covering correct? well its a good >thing these parts are all inside and won't be seen because its ugly.....any >comments or suggestions on how this is done so it doesn't look so bad or >doesn't it really matter. > > >Dreaming of the day I'll be flying.... needing to get back to work. >Kevin J. Grammes >Tecumseh, MI. >RV6A - Emp. ________________________________________________________________________________
Date: Aug 29, 1998
Subject: Engine Mount
My RV has a conical engine mount. I am looking for an engine/prop? roughness so I thought I would check the 3/8 bolts that hold the mount to the firewall. AN310 nuts are used and in checking my torque tables they show these should be torqued to 160-185 inch pounds. That is only about 15 ft/lbs. Hardly seems enough. My builders manual only said torqued to equal values, no number is specified. Does anyone know the recommended torque value for these bolts. Thanks Ken RV6 C-FKEH First flight Sept 8/93 Beautiful British Columbia ________________________________________________________________________________
Date: Aug 29, 1998
From: "Douglas G. Murray" <dgmurray(at)telusplanet.net>
> > > I was wondering if there was any sort of used tool market among the > listers? > Who needs 500 clecos after the plane is built,etc.I figure the more I can > save the sooner I will fly. > Dennis - you will find that this addiction / affliction / hobby will occur again, even after your RV is flying. For that reason you will probably find few who will willingly part with their tools. You will enjoy your own new tools and when you compare the price of the tools with the total project, the price for a life time investment for aviation tools is minor. ( Yes, I'm as poor as the next guy :-) but I love tools!!) Have fun building. DGM - RV-6 Fitting every thing on the firewall. Southern Alberta ________________________________________________________________________________
Date: Aug 29, 1998
From: Will Cretsinger <cretsinger(at)arlington.net>
Subject: Re: Gap b/t Rear Window Sides and Skin
Ross Mickey wrote: > I am concerned about a gap I have in the rear window. It fits flush with > the aft skin at the top and at the sides. In-between, (at the 8-10 o'clock > positions as you face the passenger side of the window)), there is a 12" > area (on both sides not just the passenger side) which has about a 1/2" gap > between the skin and window. I have already cut the canopy so I can't > shift front to back. I can push the window up to meet the skin. If I > drill this way, I think I will end up with small puckers between the screws > (I am not using pop rivets). Ross, I would think that 1/2" is not much and that if you start drilling and clecoing from the centerline outward on each side, that the canopy will conform satisfactorily without puckers. I feel that this would certainly be true with the backing strip on the underside but I don't know what your screw configuration might be. Good luck... Will Cretsinger, Arlington TX -6A Brake plumbing ________________________________________________________________________________
Date: Aug 29, 1998
Subject: Re: RV-6/6A Type S Cowl
Blah ba Blah wrote: > Hi, I am getting all the fuselage bulkheads ready and I don't find > mention of when to put the bend in the firewall or any measurements for > same. I am working on a RV-6A. David, I don't recall ever consciously bending the firewall. The ribs which must be flush with the top of the firewall to eventually support the upper forward skin will sort of automatically bend the firewall when they are attached to the subpanel at the rear. It seemed to impart a gentle curve to the firewall, not a "bend". Will Cretsinger, Arlington TX -6A Brake plumbing ________________________________________________________________________________
Date: Aug 29, 1998
>.Well it hits the aluminum and I can >tell its a glooby mess way to much primer coming out I try to adjust the >cup falls off.. Kevin, I see the undermixing syndrome has struck again. It took a couple of tries to cure myself of that one. Next time mix the hell out of it, take two asprins and call me in the morning. You'll be fine. Joel ________________________________________________________________________________
Subject: cabin vents
Date: Aug 29, 1998
Hi All, Has anyone out there used the cabin vents sold by Van's and Cleaveland? These are the small, round, and rather expensive little jobs that simply open out into the slipstream, then close up flush with the skin when not in use. And experiences pro or con as well as recommended locations for said vents would be appreciated. Joe Rex RV-4 Putting in all the expensive stuff ________________________________________________________________________________
Date: Aug 29, 1998
Find a builder who has recently finished his project. That is what I did, and got my tools at half price. Moe DENNIS HART wrote: > > > Listers- > > Wanted to thank all for the words of encouragement regarding building > before having pilot license. It was the final little push I needed. I am > setting up the garage and plan on ordering tail next week. > > I was wondering if there was any sort of used tool market among the > listers? > Who needs 500 clecos after the plane is built,etc.I figure the more I can > save the sooner I will fly. > Any responses off list @ dennishart(at)mindspring.com please. > > Dennis-getting spooled up > -- Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 page at: http://members.bellatlantic.net/~moejoe ________________________________________________________________________________
Date: Aug 29, 1998
Go get some Sherwin Williams 988 Self etching primer in the spray cans. It's the same stuff, but no mess or cleanup required. Coverage is even due to a special nozzle, cans dont dry up. Some auto parts stores carry the same stuff under the name "Martin Senour 7220 Self Etching primer". I pay $5.50/can. Once you try it you will never go back. No more priming sessions, just break out the can and the mask and prime parts as you go. -- Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 page at: http://members.bellatlantic.net/~moejoe Kevin J. Grammes wrote: > > > Hello all - I have been monitoring this list for several months , started > my RV6A emp kit in July and after a couple of goof ups (the 610 and 614) I > was all set to prime everything for the HS and then set to jig. > > Well my kids were gone my wife was gone I had all day to prime...set the > compressor in the garage final cleanup and prep of materials mix the > primer( SW wash prime) > and load the Dockens prime gun shoot on some cardboard adjusting the > pressure looks good... away I go....Well it hits the aluminum and I can > tell its a glooby mess way to much primer coming out I try to adjust the > cup falls off......Well this is no good so I get out a regular spray gun > more clean up time but.....well after re-cleaning the parts and ready to > try again...same problem I believe, spotty very uneven coverage I believe > it should be a very light see through covering correct? well its a good > thing these parts are all inside and won't be seen because its ugly.....any > comments or suggestions on how this is done so it doesn't look so bad or > doesn't it really matter. > > Dreaming of the day I'll be flying.... needing to get back to work. > Kevin J. Grammes > Tecumseh, MI. > RV6A - Emp. ________________________________________________________________________________
From: "Lott, Michael" <Michael.Lott(at)ssc.nasa.gov>
Subject: engine mounts
Date: Aug 29, 1998
My engine seems to be sagging slightly on the mounts, as the exhaust is now contacting the lower cowling and overheating a small spot. Is it acceptable to add large washers to the lower mounts to pick it back up, or is therer a better way? Thanks. Michael. ________________________________________________________________________________
Date: Aug 29, 1998
Subject: Tip up canopoopy front lip skin &%*$~#@%)(_(
Yup....poopy is what I got now.... Geez why do we want these darned things allways to look better than they do.. So, a while ago, while fitting the whole mess, and forward skin was cleco'd on. I opened up that darned tip up while I thought the coast was clear......NOT. The gap buckled and the canopy forward skin got whipped out of shape. In the forward most butt joint area, right at center, the skin on the canopy frame now bells/flares up, causing a nice hood scoop effect in the shut position. My canopoopy skin was high to begin with and didn't rest on the flange of that forward bulkhead to begin with. Now much worse. Probably a 20MPH drag loss, say nothing about heat loss... Then today on my friend's canopy, we found his skin does same/similar only he's way off on the co-pilot's side, like canopy frame way built 1/4" to wide and missed resting on that forward flange entirely. He thought the fit was fine before forward firewall to dash forward bulkhead top skin was all riveted on, and had the canopy off while other stuff was built. Once that forward skin was riveted and the canopy was mounted today for what was to be the last time, HOLY COW!!! Would you look at that "hood scooping type" gap.... not a fun day there.. Ideas??? I was thinking I need to shrink this skin/edge. I have HVAC double flute, flutting pliars, but it'd see-saw the front edge...probably not good. And the little shower door roller'd skin edge bending tool just made the skin stretch worse :.. ( I wonder if with the 3" head on the rivet squeezer and a Dimple die with pilot stud ground off, strategically dimpling back from the actual front line if it'd shrink it in??. Fill dimples with Aeropoxy to hid then... Certainly I'm not the first one to do this..please say I'm not the first one to do this....and you fixed it how?? or Will I just end up bondo'ng it away....... : ( See you at Oswego 9/12/98 David McManmon RV6 Cicero NY ________________________________________________________________________________
Date: Aug 29, 1998
Subject: Sam James and BAC Cowl
Guy's, I just got off the phone with Sam James and I want to correct Marks' e-mail. Sam's phone number is (941) 675-4493. (It's correct in the Yeller Pages) I really get tired of typing this but like every other RVer I have spoken too, Sam is a really NICE guy. I guess I should already EXPECT that. Sam and I discussed the cowl and it's availablility and cost. Sam has assured me that he has already paid Steve for the plugs and that Steve should be shipping them to him any day now. Unbeknownst to me Sam makes cowls for the Super Stinker and Starduster and some other homebuilts so this is just an added product. He said the price will be the same that Steve charged which I believe was somewhere around $950. Sam also sells the Plenum for this set up which for the IO-360 is $410. Well I promised Sam I would correct his phone number on the list and I have done that and I hope you find the other info at least informative. Al Col. Ohio ________________________________________________________________________________
Date: Aug 29, 1998
Subject: Re: engine m,ounts
Michael V Seager wrote: > > Ken, I put together an rv4 for a fellow last year it was a high > performance O 360 with conical mounts. The vibration was terrible. We > tried everything with no results, finally the fix was to install new > lord mount type mounts instead of the rubber doughnut type. We had the > engine strobe balanced with no help. If you would like the imformation > on these please send me your fax number or your address and I'll send > you the info. Best of luck Michael Seager ________________________________________________________________________________
Date: Aug 30, 1998
Hi, I >am getting all the fuselage bulkheads ready and I don't find mention >of when to put the bend in the firewall or any measurements for same. >I am working on a RV-6A. If I look long enough I will probably find >the answers, but I would like to hear other builders comments. >Thanks, David Ahrens David, The bend is meant to take place along the top edge of the top horizontal 1/8X3/4X3/4 angle. Unless you have a bending brake to do it ahead of time, the simplest way is wait until you are installing the fwd upper fuse. ribs and then do it by hand. You can clamp any scrap piece of alum. or steel angle across the Firewall at the bend point (a straight piece of hard wood would work also) and form the slight bend by hand. The stainless is quite soft and this does a very nice job if you work it a little at a time back and forth. Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. ________________________________________________________________________________
Subject: Re: S-type cowl and O-320 FAB
Date: Aug 30, 1998
>I've fitted the VA-130C plate to the carb, fitted the filter and >mounted it >to the VA-130C, and now am ready to start playing with the VA-130B >and VA-130A tunnel parts. I have yet to fit the scoop to the cowl. >I guess these questions go out to the S-type cowl users since the cowl > >is marked for the scoop. The instructions are sort of sketchy, at >best. > >1. In my initial look, I may have to do some trimming at the front of >the >VA-130B to allow the scoop to fit in place. Did you? The scoop is sized to fit any engine sump/carb location and allow for trimming as needed (I think this is mentioned in the instructions). Since you are building a 6A you would have to have a fwd induction sump which would require some trimming of the scoop. > >2. Did the scoop fit inside the outlines without adjusting back and >forth >to meet the VA-130B? The FAB320 generally has more than enough room. It can be a little tighter for the FAB360 be still not a problem. > >3. I've noticed I've got the do some trimming on the VA-130B to allow > >for the carb sump. Did you? This is also typical (and again I believe mentioned in the instructions) their is quite a variation in carburetors so the provided cutout is meant as a starting point and the builder then adjusts it to fit what they have. > >4. The instructions say to put the VA-130B on the VA-130C to do the >horizontal swings for the scoop line up. I found that it didn't make >sense to do this without having the filter in place so I can see how >it all >fits as I do the fitting to the scoop. As for the overall fitting with the type S cowl you should first mount the scoop to the cowl (this is the way I have always done it with the standard cowls also) and then fit the airbox to match the scoop inlet. This can be done by installing only the bottom cowl with what we refer to as the banjo (don't know part # but I think the description is obvious) loosely clamped to the plate on the carb to allow you to reach down inside and move it around. You can also use a fluting pliers in the area where the neck meets the body of the banjo to adjust the elevation at the scoop inlet. Once you think you have it close... check to see that all of the bolt holes on the mounting plate have equal distance to the edge of the big hole in the banjo so that it will fit on around the filter. When you finally have it where you want it then drill some holes, and refit the fiberglass portion, once again checking it to the cowl scoop so that you get the proper amount of opening relative to the scoop inlet. P.S. Anyone installing an FAB360 can follow pretty much the same process though in some ways it is even easier because the filter is held in by the bottom of the scoop which means that the scoop position on the plate isn't critical as long as it is somewhat centered. Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. ________________________________________________________________________________
Date: Aug 30, 1998
Subject: Re: Rudder Attachment to VS Hardware
Phil, You make three plates that have a nutplate riveted to them. They are then riveted to the forward rudder spar. That allows some adjustment if you drill the holes a bit off from where they should be. Jim ________________________________________________________________________________
Subject: Re: Tip up canopoopy front lip skin &%*$~#@%)(_(
Date: Aug 29, 1998
David, you might try borrowing/buying a shrinker/stretcher such as U. S. Industrial Tools and others sell. Practice on some scrap first and go real easy. It does leave some little bite marks but they will sand out and after painting you will not see them. I stretched a tank skin using a roller set too tight and removed it with this method. I don't think this will work to correct a 1/4" too large canopy frame, but it will help on your stretched skin. You're not the first to have this happen for sure. Mine just wasn't that bad and seamers took care of it. Good luck. Les Williams/RV-6AQ/ Tacoma WA -----Original Message----- > >Yup....poopy is what I got now.... ________________________________________________________________________________
Date: Aug 30, 1998
Subject: Re: Shipping Charges
I have found the people at Van's to be helpful at every turn. The shipping charges are not worth worrying about...The tech support is.. don't delay your project because of that. They have been great. Bob Claypool ________________________________________________________________________________
Date: Aug 30, 1998
In a message dated 8/29/98 1:45:34 Central Daylight Time, kb8pk(at)tc3net.com writes: << after re-cleaning the parts and ready to try again...same problem I believe, spotty very uneven coverage I believe it should be a very light see through covering correct? >> Correct. Thin your primer some more. Atomization is the key, and if your primer is too viscous, it won't atomize right. Regards Wendell WBWard(at)AOL.COM ________________________________________________________________________________
Date: Aug 30, 1998
Subject: Re: cabin vents
Joe Rex, Do not order the vents from (Van's whisperflow). They are flimsy and need modification with pro seal so they don't leak. Aircraft Spruce has some nice ones ________________________________________________________________________________
Date: Aug 30, 1998
From: Ronald Vandervort <rvanderv(at)linknet.kitsap.lib.wa.us>
Subject: Italian Gascolator....?
Is anyone familiar with the Marc-Ingegno Gascolator that Aircraft Spruce has in their catalog? Is it smaller than the more common ACS Gascolator, ....shorter, taller? How does it mount. AS I hope to mount a gascolator in the wing root both sides I am looking at all possible units for best fit. Thank You, Ron Vandervort, RV-6Q, Mounting wings. ________________________________________________________________________________
Subject: Voltage Regulator.
Date: Aug 30, 1998
Hi All, I have a question reguarding the Transpo M5-130A voltage regulator that I bought from Van's. It has three grouped wires (GRN,BLK,RED) with a plug and a single (YELLOW) wire with plug.Can someone tell me what these wires are defined as? Van's had zero paperwork with it.And maybe someone knows were to get the mate for these plugs.Also I bought the Alt kit that Van's sells (35 amps).Any input on this kit? Thanks, John Hughes RV-6 So Cal. Hookin things up!!Oshkosh 99!! ________________________________________________________________________________
Date: Aug 30, 1998
Kevin, I ditched the paper cup gun after a year and bought a $25 painting gun at Wal-Mart. The trigger broke the first time I tried to use it, but with all this RV experience I was able to fix it by making new parts. It shoots primer much better. It also made me feel that I can paint the outside someday, with a good gun of course. Steve Soule Huntington, Vermont RV-6A floors -----Original Message----- load the Dockens prime gun shoot on some cardboard adjusting the pressure looks good... away I go....Well it hits the aluminum and I can tell its a glooby mess way ________________________________________________________________________________
Date: Aug 30, 1998
Joe, I have to strongly disagree with you on this. Van's vents are inexpensive, light, easy to install and look good. They do leak slightly in the closed position, but this is easy to fix with a No-Hub pipe cap available from any home store. The only time you need them completely sealed is in the winter. Even without the pipe caps, the vents can be pointed towards the sidewall and presto, no cold air on the occupants. Scott Gesele N506RV - Flying > >Joe Rex, >Do not order the vents from (Van's whisperflow). They are flimsy and need >modification with pro seal so they don't leak. Aircraft Spruce has some nice >ones > > > > ________________________________________________________________________________
Date: Aug 30, 1998
Subject: Re: Wing root fairings
> the forward long > section is attached to the fuse with nutplates, c/s washers and > screws. I used a few clip nuts on the bottom section to attach > it to the fuel tank part. I used no attachment to the top of the wing. > RV4 CO. I also have the Sam James wing root fairings on my -6a. I used #6 c/s screws and washers with nutplates in the fuse and along the top of the wing, and on the bottom flange of the fuel tanks. There are no fasteners where the fairing lays along the top of the fuel tank, for they would have to be inside the tank! During my flight testing, I had a buzz that would appear at airspeeds above 140 IAS. Sounded like a C-152 stall warning. Turned out to be the right fairing section that laid across the top of the fuel tank didn't sit tight enough. I was able to use a heat gun to slightly reshape the fairing and stop the buzz. I flew to an IAS of 210, no more buzz! Mark LaBoyteaux RV-6A N106RV MLaboyteau(at)aol.com Broken Arrow, OK ________________________________________________________________________________
Date: Aug 30, 1998
Subject: Alternator bracket: 2024-T4 vs 6061-T6
In fabricating the alternator tension bracket from Van's alternator mounting kit I messed up and need to rebuild the piece. In Van's kit the bracket piece that one uses to adjust belt tension is made from 2024-T4 aluminum (no alloy specified). The plans with Van's kit simply say 3/16" or 1/4" Aluminum. I was able to get 6061- T6 in 1/4" thickness. Will this make a suitable substitute, or should I get some 2024-T4 instead? Thanks, Tim _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023 on gear, engine mounted Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ________________________________________________________________________________
Date: Aug 30, 1998
I don't believe Joe was referring to the Wisperflow but rather to the Miniture Ventilator listed in the new catalog as CA LV-3 Ventilator @ $59.00. Les Williams/RV-6AQ/Tacoma WA (Baffles & engine stuff) > >Joe Rex, >Do not order the vents from (Van's whisperflow). They are flimsy and need >modification with pro seal so they don't leak. Aircraft Spruce has some nice >ones ________________________________________________________________________________
Subject: Re: Voltage Regulator.
Date: Aug 30, 1998
The yellow wire is not used, and on mine, was clipped off at the insulator as it exits the regulator case. The instructions mentioning this was also in the box. The alternator instructions include a wiring diagram and shows the red wire going to A/C electrical buss through a 5 amp swithed circuit and the green wire to the field terminal on the alternator. Black goes to ground at the regulator by installing a ring terminal on the wire after removing and discarding the molded on plug. Butt splice on the other wires to the switch and alternator field (which comes with a plug with three wires, including a white one which is not used either). The alternator kit is pretty straight forward IMO and I found that it fit my 0-360A1A with type S cowl without interference. The only thing I had to do was size the belt so that the case didn't rub on the oil line to the prop and yet not hang so low as to hit the cowl after the engine has settled and/or I pull a few G's. Of course you can't remove the belt by just loosening the adjuster arm; you have to remove the flywheel (after removing the prop). And in order to do that, you have to remove the Sky-Tec starter (which now comes with the engine) because the ring gear will not clear the end bearing boss. Not good for belt replacement when needed. Les Williams/RV-6AQ/Tacoma WA > >Hi All, > I have a question reguarding the Transpo M5-130A voltage regulator >that I bought from Van's. It has three grouped wires (GRN,BLK,RED) with a >plug and a single (YELLOW) wire with plug.Can someone tell me what these >wires are defined as? >Van's had zero paperwork with it.And maybe someone knows were to get the >mate for these plugs.Also I bought the Alt kit that Van's sells (35 >amps).Any input on this kit? > > Thanks, John Hughes > RV-6 So Cal. Hookin things ________________________________________________________________________________
Date: Aug 30, 1998
Stephen J. Soule wrote: > > > Kevin, > > I ditched the paper cup gun after a year and bought a $25 painting gun > at Wal-Mart. The trigger broke the first time I tried to use it, but > with all this RV experience I was able to fix it by making new parts. > It shoots primer much better. It also made me feel that I can paint the > outside someday, with a good gun of course. > > Steve Soule > Huntington, Vermont > RV-6A floors > > I gave the paper cup gun away after the first use when the cup departed the gun and spilled $$$veriprime all over my shoes. Tried the $25 touch up gun with good success, but bought an $80 HVLP gun from Harbor Freight which works very well and I don't loose a lot of primer as overspary is minimal. It cleans up real fast and easy as well. Ed Cole RV6A Fuse skins... ________________________________________________________________________________
Date: Aug 30, 1998
Subject: #!@$#^ RTV
Yep, it is in the instructions.... > >I've never heard of this. Is it in the plans? > >-Larry >RV-8 VS >Email: larry(at)bowen.com >Web: http://larry.bowen.com > >[snip] >>Recently I got my rudder all closed up, stood back to admire it... and >>realized that I forgot the RTV. >[snap] > > > > > ________________________________________________________________________________
Date: Aug 30, 1998
As a caution to newbies, the HVLP gun Ed suggests requires a high output compressor (9 CFM according to the instructions). Les Williams/RV-6AQ/Tacoma WA >I gave the paper cup gun away after the first use when the cup departed >the >gun and spilled $$$veriprime all over my shoes. Tried the $25 touch up >gun >with good success, but bought an $80 HVLP gun from Harbor Freight >which works very well and I don't loose a lot of primer as overspary >is minimal. It cleans up real fast and easy as well. > >Ed Cole >RV6A Fuse skins... ________________________________________________________________________________
Subject: Re: Huntington Lift Reserve Indicator
Date: Aug 30, 1998
Look in the archives under angle of attack or stall warning for related items. I purchased the AOA from Jim Frantz of Proprietary Software Systems. You can view these at http://ourworld.compuserve.com/homepages/LFrantz/ Ross Mickey ---------- > From: John Fasching > Subject: RV-List: Huntington Lift Reserve Indicator ________________________________________________________________________________
Date: Aug 30, 1998
Subject: Re: Alternator bracket: 2024-T4 vs 6061-T6
<< In Van's kit the bracket piece that one uses to adjust (alternator) belt tension is made from 2024-T4 aluminum. The plans with Van's kit simply say 3/16" or 1/4" Aluminum (no alloy specified). I was able to get 6061- T6 in 1/4" thickness. Will this make a suitable substitute, or should I get some 2024-T4 instead? >> Tim The strength of 2024-T4 is substantially greater than that of 6061-T6. Actually, B&C uses 3/16" steel for both the mounting bracket and the tensioner, so please don't compromise on the strength of these items. If you do aerobatics, you should also fabricate a compression link between the Alternator mounting bolt and the threaded boss on the starter. This is especially true if you use the B&C 60A alternator (heavy). I have one designed in AutoCAD that I can send or post to your website. -GV ________________________________________________________________________________
Date: Aug 30, 1998
I intended to include in my reply that as an alternative to butt splicing, using insulated spade terminals or other quick disconnects would allow easier replacement of the regulator, but my brain became disengaged again. Les >removing and discarding the molded on plug. Butt splice on the other wires >to the switch and alternator field (which comes with a plug with three >wires, including a white one which is not used either). ________________________________________________________________________________
Date: Aug 30, 1998
Subject: 0320 A2A
Hi All, Just a quick double check before I plunk down the cash... 0320 A2A - to be installed in a RV-6 OK?? (for info - will it work in a -6A?) Larry Olson RV6 - Right Wing Cave Creek, AZ ________________________________________________________________________________
Date: Aug 30, 1998
Tim Lewis wrote: >I was able to get 6061- T6 in 1/4" thickness. Will this make a > suitable substitute, or should I get some 2024-T4 instead? According to the Joseph T. Ryerson's Stock List (A metal suppy house) 6061-T6 has a yield strength of 40,000 psi and an elongation of 17%. 2024-T4 has a yield strength of 47,000 psi and an elongation of 20% 2024-T4 (Alclad) has a yield strength of 62,000 psi and an elongation of 19% If you substitute 1/4" 6061-T6 for 3/16" 2024-T4 (non-alclad), the part will be stronger, but heavier. Van may have used what was laying around, ie used in other parts, or may have choosen it for it strength. 2024 specifies the alloy(4.5% copper), T4 the temper. Richard Reynolds, Norfolk,VA, RV-6A, Assembling fuselage skeleton. ________________________________________________________________________________
Subject: HVLP conversion guns
Date: Aug 31, 1998
> > As a caution to newbies, the HVLP gun Ed suggests requires a high output > compressor (9 CFM according to the instructions). > [...] > >with good success, but bought an $80 HVLP gun from Harbor Freight > >which works very well and I don't loose a lot of primer as overspary > >is minimal. It cleans up real fast and easy as well. I'm using an HVLP conversion gun (US$150, I got it on special for US$75) which sits on my 12 cfpm 2.5hp ChargeAir compressor. Imron 830 goes on like a dream, is pretty much bulletproof, and even on bad days, I get good results (and I'm a complete beginner). Minimal overspray, and the gun cleans up quickly. BUT the compressor starts up 30 seconds after I start spraying and doesn't stop until after I do. I don't think a 9 cfm would cut it for this particular gun. (what brand? Um. Lemme see. "Made In China"). For $75, I wasn't going to be too upset if it didn't work, but now I couldn't be happier with it. I'm just careful about when I spray so the neighbours don't complain about the compressor running continuously. ________________ Chris Hinch Phone: +64-3-477-2995 Systems Manager Cell: +025-228-1244 Animation Research Ltd Fax: +64-3-479-9751 442 Moray Place, Dunedin, New Zealand Email: chinch(at)arl.co.nz RV-8 Builder #80630 - http://www.arl.co.nz/chinch/rvlog/kiwi8.htm ________________________________________________________________________________
Subject: Fuel Tank Priming
Date: Aug 30, 1998
Just starting to fabricate the first fuel tank and was wondering what gets primed. The instructions mention not to prime the inside, but I was wondering if the parts get primed on the outside. In particular, how should the following parts be primed: Z-Angle Attach Brackets - Yes or No T405 Forward Attach Brackets - Yes or No Outside of tank access plate Outside (Bottom) of Tank Baffle A number of these parts are not alclad so I would think they need primed. On the other hand, there are rivets that go through these pieces into the tank. Will the primer cause problems with the proseal on these rivets. Thanks in advance. Aaron Gleixner RV8A - Wings ________________________________________________________________________________
From: "Rick & Barbara Osgood" <randbosgood(at)sprintmail.com>
Subject: Aileron spacer question
Date: Aug 30, 1998
Can someone clarify for me, if a spacer is required on the aileron hinge for the bolt that attaches to the Heim bolt? I have a spacer at the front of the hinge (where it attached to the rear spar support) but cannot determine if a rear spacer is required. Thanks Rick ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Re: Fuel Tank Priming
agleix(at)worldnet.att.net wrote: > Just starting to fabricate the first fuel tank and was wondering what gets > primed. The instructions mention not to prime the inside, but I was > wondering if the parts get primed on the outside. In particular, how > should the following parts be primed: > > Z-Angle Attach Brackets - Yes or No > T405 Forward Attach Brackets - Yes or No > Outside of tank access plate > Outside (Bottom) of Tank Baffle I've just finished my tank construction, and I'll be priming the completed tanks. I think it would be a *bad* idea to prime the individual parts before assembly; if you did that, you'd have primer between the tank sealant and the metal. Frank. ________________________________________________________________________________
Date: Aug 30, 1998
> So, a while ago, while fitting the whole mess, and forward skin was cleco'd > on. I opened up that darned tip up while I thought the coast was > clear......NOT. The gap buckled and the canopy forward skin got whipped out > of shape. This happened to me!!! Hit that row of clecos hard with the canopy skin while showing off by cool tip-up canopy to some shop guests... mine was fixable with a crescent wrench to reverse-bend the metal, but not perfectly. when closed the bulkhead sort of makes it conform flat; when open you still see the waves. Bill Boyd RV-6A 28 hrs ________________________________________________________________________________
Date: Aug 31, 1998
From: Carol Richards <crcar(at)cc.newcastle.edu.au>
Kevin and List: My 2 Cents worth on getting the painting right: Check the data sheets for your paint. They will give you the optimal mixing/thinning ratios for your application (as well as other useful data). Sometimes a 'Din' time is given, usually in seconds, which specifies how long a volume of mixed paint will take to exit through a hole in the bottom of a Din cup. The longer the din time, the thicker the paint and conversely. In the USA there may be a diffferent standard, but same principle applies. The spec sheets should also advise you of the nozzle diameter to be used in your gun. As mentioned before, thorough mixing is important. Make sure your gun is squeaky clean - at least at the fluid tip and air cap. I usually disassemble; brush the above parts with thinners; reassemble; run clean thinners through and leave 1/2" in the cup during storage. Check that you are not spraying during times of high humidity or outside the temp specs of your paint. The reps for the paint companies usually have instrucional videos for their products - esp if they are used in painting cars. You may be able to borrow one with the promise to show it at an EAA chapter meeting. I agree, preps for painting have to be the most painful part of building. As with other tasks you will experiment and find what works for you most efficiently. Moe's idea of using spray cans has a lot of appeal, especially for smaller bits and the occasional correction. I hope this helps, Sam (RV-6 skins going on wings) Newcastle Australia ________________________________________________________________________________
Date: Aug 30, 1998
Subject: Re: Sam James and BAC Cowl
<< I just got off the phone with Sam James and I want to correct Marks' e- mail. Sam's phone number is (941) 675-4493. >> Aw crap. Sorry, guys. Check six! Mark ________________________________________________________________________________
Date: Aug 30, 1998
Subject: wing skins
For -8 builders...At the forum Van held at Oshkosh the suggestion was made to hold off on closing the wings. Anyone have any other word on this? Should I rivet on the skins or not??? Bill Pagan 80555 - fuselage not shipping until 10/19:'( http://www.geocities.com/CapeCanaveral/Launchpad/9749/william.html ________________________________________________________________________________
Subject: Re: wing skins
Date: Aug 30, 1998
>For -8 builders...At the forum Van held at Oshkosh the suggestion was made >to hold off on closing the wings. Anyone have any other word on this? >Should I rivet on the skins or not??? > >Bill Pagan > Bill, Hmm...interesting. Who was it that made the suggestion to "hold off on closing the wings"? Was it a Van's representative, or suggested by a builder in attendance? For those of us with finished wings, it's too late to turn back now. The crash happened just as I was closing the last wing panel, and I also paused to think about my options. Just like the stock market these days, you just gotta have faith..and boldly forge ahead. We'll see if this was a correct plan or not, probably very soon. I wish I could offer more insight, but the jury is still out on this issue. Hang in there, Bill..the fuselage is a blast! You get to pound on stuff with a big hammer. No, I'm not kidding. :) Brian Denk RV8 #379 landing gear boxes underway. http://geocities.com/CapeCanaveral/Hangar/9656/index.html ________________________________________________________________________________
Date: Aug 30, 1998
Subject: Re: subscription to the list
Please unsubscribe me. Thanks, Travis Pat Walker wrote: > > sirs, > please unsubscribe my e-mail from the rv-list > ________________________________________________________________________________
From: "David Lundquist" <DLUNDQUIST(at)postoffice.worldnet.att.net>
Date: Aug 30, 1998
> >For -8 builders...At the forum Van held at Oshkosh the suggestion was > made > >to hold off on closing the wings. Anyone have any other word on this? > >Should I rivet on the skins or not??? > > > >Bill Pagan I was in attendance at the RV-3/4/8 seminar even though I'm building a 6. As I recall the word from Van himself was that if you hadn't closed your wings, it was recommended that you not at this point do so until this issue is relsolved to Van's satisfaction. It was stated that the entire fuse could be completed without finishing the wings. Is this what the others heard? Dave Lundquist RV-6 Wings Long Island, NY ________________________________________________________________________________
Date: Aug 30, 1998
Subject: RV-4 Crash in NC
Just read in the local paper that Richard Bibb of the RV-list experienced a forced landing on his new RV-4 at the University of North Carolina Airport on Saturday. The paper said he was on a final when the engine quite. He avoided a school with football players at practice to land in the trees. The paper said he walked away, but the plane was a total loss. Sorry to hear of the misfortune, but glad to hear that you walked away Richard. Louis Smith RV-8 N801RV 50ttsn Rocky Mount, NC ________________________________________________________________________________
Date: Aug 30, 1998
Subject: GOLDEN WEST EAA Regional Fly-In
Hi List! I'm Steve Gregory, and I have been monitoring the list for six months. What great information!! I have my RV-8 empennage kit and have been building s-l-o-o-o-w-l-y, because another project has been taking most of my time, and I think it is within the scope of this list to share it with you. On September 25, 26 and 27 the Golden West Aviation Association, Inc. (a group of EAA members/volunteers) will launch the first annual Golden West EAA Regional Fly-In at Castle Airport near Atwater, CA. Castle Airport (formerly Castle AFB) is in the central San Joaquin Valley of California. This fly-in will have all the features you would expect to see at an EAA regional fly-in. Seminars, forums, workshops, manufactures/exhibitors, RV parking, camping (tent and underwing), display planes, aircraft judging/awards, static displays and daily air shows. It is very easy to fly into Castle. The end of September in central California is great VFR weather with the temperatures hovering in the mid-80's (maybe the low 90's). Please check the NOTAM for fly-in info. Rather than take everyone's time here to discuss the event, e-mail me off-list (sgregory(at)ccnet.com)if you have any questions or would like more information. It would be great to have a bunch of RV's gathering at this event. Thanks. Steve Gregory RV8 Empennage San Ramon, CA Will be building like crazy after the fly-in! ________________________________________________________________________________
Date: Aug 30, 1998
An after thought to my previous post....to get more information about the fly-in, check out the web page at http://www.gwaafly-in.org. Thanks. Steve RV8 Empennage San Ramon, CA ________________________________________________________________________________
Date: Aug 31, 1998
I followed the instructions to add a bit of black RTV on the edge of the butterfly valve and my vents seal completely with no leakage at all. Jim Cone Repeat Offender RV-6A QB ________________________________________________________________________________
Date: Aug 30, 1998
Subject: Re: GOLDEN WEST EAA Regional Fly-In
Steve Gregory wrote: > > > An after thought to my previous post....to get more information about > the fly-in, check out the web page at http://www.gwaafly-in.org. Thanks. > > Steve > RV8 Empennage > San Ramon, CA > Steve That url does not work for me. Is it correct? -- Jerry Springer RV-6 N906GS First flight July 14, 1989 :-) Hillsboro, OR jsflyrv(at)ix.netcom.com ________________________________________________________________________________
Date: Aug 31, 1998
>Just starting to fabricate the first fuel tank and was wondering what >gets primed. The instructions mention not to prime the inside, but I >was wondering if the parts get primed on the outside. In particular, >how should the following parts be primed: > >Z-Angle Attach Brackets - Yes or No Yes >T405 Forward Attach Brackets - Yes or No Yes >Outside of tank access plate Builders choice >Outside (Bottom) of Tank Baffle Builders choice > >A number of these parts are not alclad so I would think they need >primed. On the other hand, there are rivets that go through these >pieces into the tank. Will the primer cause problems with the proseal >on these rivets. Thanks in advance. > I am not quite sure what the concern is that you have about the primer causing problems with the tank sealant on the rivets? By the time you are installing the non alclad parts (the Z brackets, and the tank support bracket) hopefully the tank has already been sealed to fuel leakage on the inside side of the tank where these parts attach. In fact the construction man. cautions about getting too much of a sealant buildup in the mating area of the Z brackets because it can space the baffle away from the ribs or the Z brackets away from the baffle, and this can effect the tank fully seating down on to the spar as it was when it was originally drilled (this is not a problem with RV-4 or 6's). Bottom line is follow the recommendations that any parts made from plate material or extrusion should be primed, anything alclad is up to the builder. Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. ________________________________________________________________________________
Subject: Re: 0320 A2A
Date: Aug 31, 1998
> >Just a quick double check before I plunk down the cash... > >0320 A2A - to be installed in a RV-6 > >OK?? > >(for info - will it work in a -6A?) > Larry, The main thing you need to check on (if you don't want to have to by other parts to modify it) is to be sure that it is a straight riser sump engine. You have to have this for a 6A so that the carb./airbox clears the nose gear leg. The way to check is see where the hole is in the bottom for the carb. mounting. If it is at the far aft of the sump then it wont work without modification. If the carb mounts at approximately the center of the sump then it will work. BTW the name straight riser comes from the shape of the induction tubes. If it is a straight riser sump then the induction tubes have just a single bend to get from the sump to the cylinder. If the engine has a rear mounted carb. then the induction tubes have numerous bends in them. Once you look at one of each the description is very clear. Mainly just look for the carb. location. Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Alternator belt replacement (was Voltage Regulator.)
> Of course you > can't remove the belt by just loosening the adjuster arm; you have > to remove the flywheel (after removing the prop). And in order to > do that, you have to remove the Sky-Tec starter (which now comes > with the engine) because the ring gear will not clear the end > bearing boss. Not good for belt replacement when needed. A good trick is to put a second belt into position but tied out of the way when you mount the alternator. Two belts should be good for what, 400 hours each? Peter Bennett RV6 firewall forward ________________________________________________________________________________
Date: Aug 30, 1998
Jerry Springer wrote: > > > Steve Gregory wrote: > > > > > > An after thought to my previous post....to get more information about > > the fly-in, check out the web page at http://www.gwaafly-in.org. Thanks. > > > > Steve > > RV8 Empennage > > San Ramon, CA > > > > Steve > That url does not work for me. Is it correct? > > -- > Jerry Springer RV-6 N906GS First flight July 14, 1989 :-) Hillsboro, OR > jsflyrv(at)ix.netcom.com > Sorry List... The real URL for the Golden West EAA Regional Fly-In '98 is http://www.gwfly-in.org. Steve Gregory RV8 Empennage San Ramon, CA ________________________________________________________________________________
Date: Aug 31, 1998
Subject: MK-319-BS Rivets
What size hole do you drill for a MK-319-BS pop rivet? They fit pretty sloppy in a #30 hole. Mike Hilger RV-6, Canopy ________________________________________________________________________________
Date: Aug 31, 1998
Does anyone have pictures of these fairings on the net? Dave Fried > I also have the Sam James wing root fairings on my -6a. I used #6 c/s screws >and washers with nutplates in the fuse and along the top of the wing, and on >the bottom flange of the fuel tanks. There are no fasteners where the fairing >lays along the top of the fuel tank, for they would have to be inside the >tank! During my flight testing, I had a buzz that would appear at airspeeds >above 140 IAS. Sounded like a C-152 stall warning. Turned out to be the right >fairing section that laid across the top of the fuel tank didn't sit tight >enough. I was able to use a heat gun to slightly reshape the fairing and stop >the buzz. I flew to an IAS of 210, no more buzz! > >Mark LaBoyteaux >RV-6A N106RV >MLaboyteau(at)aol.com >Broken Arrow, OK > > > > > ________________________________________________________________________________
Date: Aug 31, 1998
> I was in attendance at the RV-3/4/8 seminar even though I'm building a 6. > As I recall the word from Van himself was that if you hadn't closed your > wings, it was recommended that you not at this point do so until this issue > is relsolved to Van's satisfaction. It was stated that the entire fuse > could be completed without finishing the wings. > > Is this what the others heard? > > Dave Lundquist > RV-6 Wings > Long Island, NY That's what I heard at the forum. Scott -- Gotta Fly or Gonna Die ! RV-4 tailkit in hand! ________________________________________________________________________________
Date: Aug 31, 1998
Subject: [Fwd: AOA]
Here is a note I received from the man who sells the AOA lift indicators. When I get the info I will pass that along to, if any one is interested. Michael. (with Cubic Circle's cucipop (v1.21 1997/08/10) Mon Aug 31 06:51:19 1998) Date: Sun, 30 Aug 1998 17:47:32 -0400 From: "Lynda K. Frantz" <LFrantz(at)compuserve.com> Subject: AOA I'll mail you some AOA info via snail mail. Until recently full range AOA instruments were not affordable at $22,000 and up but no longer. The AOA Professional lists for $1,450. Even the= simple A/C Spruce pre stall warner which requires a switch cut into the wing "D" section wired to a horn/light is $1,200+ as a comparison. The AOA is self compensating and is the only instrument that is a true aerodynamic indicator. Just as there is an optimum AOA for all approache= s there is also an optimum AOA for initial climbs, the best L/D, Vx, Vy, an= d maximum endurance regardless of weight, altitude, fuel load, temperature,= etc. In addition any given airfoil always stalls at the same AOA regardless. The AOA Professional includes a voice warning system, gear warning system and has no protrusions or moving parts to ice up or slow y= ou down. A custom cable is also included. We have a simple web at www.lancair.net. Give me a call at (612) 474-415= 4 if you would like. Jim ________________________________________________________________________________
Date: Aug 31, 1998
%#$2(* thing happened to me with my Tip Up canopy. Stretched the leading edge with the celcos and it had been laying down beautifully flat (Sob!). Mine was so bad I got one of those metal Shrinker and that made it better, but not really satisfactory. Wish I had know before!!! Ed RV-6A N494BW SportAV8R(at)aol.com wrote: > > > > So, a while ago, while fitting the whole mess, and forward skin was cleco'd > > on. I opened up that darned tip up while I thought the coast was > > clear......NOT. The gap buckled and the canopy forward skin got whipped > out > > of shape. > > This happened to me!!! Hit that row of clecos hard with the canopy skin while > showing off by cool tip-up canopy to some shop guests... mine was fixable > with a crescent wrench to reverse-bend the metal, but not perfectly. when > closed the bulkhead sort of makes it conform flat; when open you still see the > waves. > > Bill Boyd > RV-6A 28 hrs > ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Re: RV-4 Crash in NC
Yes I did walk away - the slow stall speed of these birds saved me. Put it in the tops of some trees. Ended up vertical with the spinner on the ground. Only injuries are scratches incurred by climbing through cracked canopy. It looks like it *might* be rebuildable. Rudder, vertical stab, right elevator, ailerons hardly scratched... Fuselage intact with some damage at rear spar attach points. I was lucky - I'll have more later. These are GREAT airplanes.... > >Just read in the local paper that Richard Bibb of the RV-list experienced a >forced landing on his new RV-4 at the University of North Carolina Airport on >Saturday. The paper said he was on a final when the engine quite. He avoided >a school with football players at practice to land in the trees. The paper >said he walked away, but the plane was a total loss. Sorry to hear of the >misfortune, but glad to hear that you walked away Richard. > >Louis Smith >RV-8 N801RV >50ttsn >Rocky Mount, NC > > > > > Richard E. Bibb RV-4 N144KT Oak Hill, VA rbibb(at)fore.com ________________________________________________________________________________
Date: Aug 31, 1998
Yes, you will have to make spacers for this bolt too. Make the spacer fit so that the Heim doesn't hit the hinge pieces anywhere during the aileron's up and down travel. Steve Soule Huntington, Vermont RV-6A cockpit floors -----Original Message-----Can someone clarify for me, if a spacer is required on the aileron hinge for the bolt that attaches to the Heim bolt? I have a spacer ________________________________________________________________________________
Date: Aug 31, 1998
From: <steve.nichols(at)stoneweb.com> "Steve D Nichols"
Subject: re-4 kit
WITH ALL OF THE EXCITEMENT OF THE RV-8 AND 8A I WAS WONDERING IF ANYONE HAS OR KNOWS ANYONE WHO HAS AN RV-4 PROJECT FOR SALE ? ADVISED BY A FRIEND TO MAKE THIS POST BEFORE I ORDER THE EMP. KIT JUST TO SEE WHAT HAPPENS. PLEASE RESPOND TO ME DIRECTLY AT www.steve.nichols(at)stoneweb.com THANKS FOR THE HELP STEVE NICHOLS (READY TO ORDER -4) ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Re: MK-319-BS Rivets
michael d hilger wrote: > What size hole do you drill for a MK-319-BS pop rivet? They fit > pretty sloppy in a #30 hole. I pilot the hole with a #40. Then use a #33 for final fit. Carroll Bird, Buffalo Gap, TX RV-4 N311CB > > > ________________________________________________________________________________
Date: Aug 31, 1998
Glad to hear no significant injuries, Richard. Agree with you, the slow stall speed does a lot with making a controlled decent survivible in an RV. Also says a lot about the pilot with the skills, control, and presence of mind to be able to put it into the tree tops. Hopefully, you can repair the bird, I am more than willing to help in any way I can if you do decide to rebuild it. Have most of my tools still at the airport. Regretfully that the bird is bent, but the (only?) good news is that you are not. Ed Richard Bibb wrote: > > Yes I did walk away - the slow stall speed of these birds saved me. Put it > in the tops of some trees. Ended up vertical with the spinner on the > ground. Only injuries are scratches incurred by climbing through cracked > canopy. It looks like it *might* be rebuildable. Rudder, vertical stab, > right elevator, ailerons hardly scratched... Fuselage intact with some > damage at rear spar attach points. > > I was lucky - I'll have more later. > > These are GREAT airplanes.... > > > > >Just read in the local paper that Richard Bibb of the RV-list experienced a > >forced landing on his new RV-4 at the University of North Carolina Airport on > >Saturday. The paper said he was on a final when the engine quite. He avoided > >a school with football players at practice to land in the trees. The paper > >said he walked away, but the plane was a total loss. Sorry to hear of the > >misfortune, but glad to hear that you walked away Richard. > > > >Louis Smith > >RV-8 N801RV > >50ttsn > >Rocky Mount, NC > > > > > > > > > > > Richard E. Bibb > RV-4 N144KT > Oak Hill, VA > rbibb(at)fore.com > ________________________________________________________________________________
Date: Aug 31, 1998
I believe a 7/64ths is correct. Les Williams/RV-6AQ/Tacoma WA > > > What size hole do you drill for a MK-319-BS pop rivet? They fit >pretty sloppy in a #30 hole. > > Mike Hilger > RV-6, Canopy ________________________________________________________________________________
Subject: Re: Wing Skins
Date: Aug 31, 1998
>Who was it that made the suggestion to "hold off on closing the wings"? I was at the Oshkosh forum and Van suggested builders hold off in closing the wings. However, this was before the latest load testing of the wings (as published at the "update" section of Van's web page). I'd contact the factory and see if the "hold" is still being recommended. As you know, this is only for the 8 / 8a and not the other series of aircraft. Rick Jory Highlands Ranch, CO Potential RV-8a builder ________________________________________________________________________________
Date: Aug 31, 1998
> > What size hole do you drill for a MK-319-BS pop rivet? They >fit >pretty sloppy in a #30 hole. > > Mike Hilger RV-6, > The construction man. says to use 7/64". Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. ________________________________________________________________________________
Subject: RV4 Incident in NC
Date: Aug 31, 1998
Just saw the newspaper picture of Richard Bibb's RV4 hanging from a crane (Chapel Hill, NC). Although described as a total loss, the aircraft was completely intact, except for a wing tip, and except for some ripples in the wing, certainly didn't look like a plane that had just been in a power off landing into trees. My point is: The RV design with its monocoque aluminum construction and 50 mph landing speed is what I want to be flying if, God forbid, I ever get caught in a similar situation in an "experimental, amatuer built" airplane. John Harris Cary, NC Ordering RV8 Tail ________________________________________________________________________________
From: "Robert Acker" <robert.acker(at)ingrammicro.com>
Date: Aug 31, 1998
>If you want vents that work then buy the ones from Van's. >most builders don't seem to realize that if you want vents that work well >they need to have pretty good sized openings. >If you use the little nice looking vents that close of real well, the >amount of air they provide is barely enough to feel the air hitting you > >Scott McDaniels Or, you can use the really nice looking big aluminum vents available from Harmon. They are just a tad larger than the Whisperflows and look really nice. Rob (RV-6Q). ________________________________________________________________________________
Date: Aug 31, 1998
Subject: R.S. Jankowski Looking for
I am looking for a mailing address and phone number for this fellow. I took a couple of pictures of his plane at the take-off of the Sun 100 and thought he would like to have them. R.S. Jankowski 2612 ????????? Dr Cooper City FL ?????-???? ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Strobe P/S mounting
Listers, I'm mounting separate strobe power supplies in each wing. I can mount them, with nutplates, on the spar web, or on either side of the end ribs. What do people typically do? Regards, Chris Good, West Bend, WI. RV-6AQ, finishing up the wings. ________________________________________________________________________________
Date: Aug 31, 1998
Subject: belt sanders
> It's the file that sits in my tool chest and doesn't get any use, anymore. >since I discovered a quicker and easier method for stock removal. > First, the hand-held belt sander. I have a SandCat made by Skill. It's >the smallest and lightest that I've seen. This tool works very well on >straight runs, like smoothing down to a cut line on sheet. Use your snips >to cut outside the line and take it down to the line with the belt sander. >I also use the belt sander to smooth the rough, sheared edges of flat sheet >and ribs and bulkheads before using the "V" double edge deburring tool. The >tool seems to chatter less if smoothed before using the tool. >Bob Skinner RV-6 438 hrs. Buffalo, WY bskinr(at)trib.com Ive been looking for a light weight belt sander as Bob described and found that a small lightweight electric sander is hard to come by these days. While wandering through Harbor Freight this last weekend I found a Central Pneumatic air sander that fits the bill nicely. Uses a 3/4" X 21" belt and weighs less than 2 pounds. Cost is $89.95 (but I got their used demo for $45). I dont know if anyone else went looking for a belt sander following Bob's post, but hope this helps. Mike Wills RV-4 fuse willsm(at)manta.spawar.navy.mil ________________________________________________________________________________
From: "Anderson, John" <john.anderson(at)spcf.siemens.com>
Subject: gear leg fairing
Date: Aug 31, 1998
Does anyone know if you can buy the gear leg fairing for a rv-4...or do I have to make it myself? The fairing I am talking about is the one at the top of the gear leg that joins the fuselage. John C. Anderson Siemens Power Corporation 1040 S. 70th Street Milwaukee, WI 53214 (414) 475-4201 (414) 475-4461 - fax E-mail: john.anderson(at)spcf.siemens.com Flying RV-4 ________________________________________________________________________________
Date: Aug 31, 1998
Subject: fuel drain valve O-rings
>I have noticed that the small O-ring on the quick drain valves in the >fuel tanks have seriously deteriorated and should be replaced. Is there >anything special about these O-rings? They are a flatter ring than the standard O-ring (a great design ploy: you have to have their O-rings). I have several extra I ordered when ordering something else from Aircraft Spruce and keep them in my traveling tool kit. There are several sizes; get the seal for the CAV-110. My drains have occasionally oozed blue, but a small twist or pull puts a stop to that. Michael RV-4 N232 Suzie Q Flying (a lot) ________________________________________________________________________________
Date: Aug 31, 1998
>I have Sam James wing root fairings, but I'm not sure how they >are to be attached to the wing/fuselage. I LIKE them. It still took me several days to match them to my fuselage/wing (filling the small gap variations). I used screws and nutplates to attach. This may seem obvious but do NOT drill into your fuel tank. I put nutplates in the flange inboard of the tank with nothing on the leading edge, and on the upper wing skins further aft. I bent up little flanges to fit the fuselage under the airplane. They fit and look great. Michael RV-4 N232 Suzie Q Flying (a lot) ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Re: GPS antenna location on RV-4
>The last item is the GPS antenna which needs to go on the top of the >airplane for obvious reasons. Mine is on the top of the baggage skin under the canopy. I fashioned several mounting devices and finally just used two "U" channels under the sides (my antenna is square-ish). Works great. Only problem is the coverage is not good in a 45+ degree bank, which one must occasionally do during a long cross-country. Engine compartment idea is a good one: puts the weight up front. I wonder if vibration/heat would bother the antenna (probably not) and about yet another wire going through the firewall. Michael RV-4 N232 Suzie Q Flying (a lot) ________________________________________________________________________________
Subject: Wing root fairings
Date: Aug 31, 1998
Just ordered my finishing kit. What are the advantages of the Sam James mods? Does anyone have pictures on the net? Don Mack RV-6A http://www.flash.net/~donmack >I have Sam James wing root fairings, but I'm not sure how they >are to be attached to the wing/fuselage. I LIKE them. It still took me several days to match them to my fuselage/wing (filling the small gap variations). I used screws and nutplates to attach. This may seem obvious but do NOT drill into your fuel tank. I put nutplates in the flange inboard of the tank with nothing on the leading edge, and on the upper wing skins further aft. I bent up little flanges to fit the fuselage under the airplane. They fit and look great. Michael RV-4 N232 Suzie Q Flying (a lot) ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Re: Strobe P/S mounting
<< Listers, I'm mounting separate strobe power supplies in each wing. I can mount them, with nutplates, on the spar web, or on either side of the end ribs. What do people typically do? Regards, Chris Good, West Bend, WI. RV-6AQ, finishing up the wings. >> Chris: You have the option of making the airframe very easy to service. I usually tell folks to put the pwr supply on the front of the spar, behind the landing lite opening, so that you can easily remove the thing when all the smoke is used up. Check six! Mark ________________________________________________________________________________
Date: Aug 31, 1998
Subject: RV-4 O-320 160 HP Wooden Prop??
Date: Aug 31, 1998
Which wooden prop are you happy using on an RV-4, 0-320/160 HP?? (This a customer's plane that I'm finishing for him) As you know Van won't recommend a prop..any happy stories out there?? How about a wooden prop for an RV-4 with a 0-320/150 horse engine (A different airplane) (Mine)?? I'm using a pacesetter-200 now and find that it's not enough prop..at 10K feet the engine will go beyond 3000 RPM at 200 MPH. More pitch please!! ________________________________________________________________________________
Subject: S-type cowl and O-320 FAB revisited
Date: Aug 31, 1998
Listers, I got some information concerning the FAB to scoop fit last week that helped me get started; but, I have more questions since I'm having problems deciding what part of the first three pages of the FAB instructions are exclusive to the listed cowls or can be carried over to the other cowls. Just to be sure, more questions: 1. I assume the constant speed cowl = "S" cowl in shape. Looking at figure 3 on page 2 of my instructions, the distance from the spinner ring down to the front of the scoop of a CS cowl is 12 5/8". I have mine at about 12" right now and seem to be getting a good fit to the cowl. Is the 12 5/8" for the CS cowls, even though it's in the middle of the RV3/ RV4 instructions? 2. Figure 3 also shows the center line of the scoop 1" off center from the center line of the cowl. My scoop lines up with the FAB VA-130B fairly closely with the 1" offset. Does the 1" offset apply to all cowls? 3. Figure 4, same RV3/RV4 instructions section, shows that the FAB should be 14 3/4" long for a -6. I guessed that's a good starting point and cut mine to that length. Based upon questions 1 and 2 and this length, I have the FAB VA-130B (banjo) about 1/4" from the scoop opening. Would it be a good idea to cut some more off to give me some more breathing room for fit up? These questions are based upon the current dimensions given. This is my first trial fit and could be change, if you answers suggest it. It does seem to fit well at this position. I guess the biggest concern is the 1" offset. The scoop looks pretty good under there! :-) Jim Sears in KY RV-6A N198JS ________________________________________________________________________________
Date: Aug 31, 1998
From: "Bradley Kidder, Jr." <sparksnmagic(at)earthlink.net>
Subject: Bibb's Elquilibrium
Richard: Glad to hear you're alive and well, and that the RV might possibly fly again one day. In regard to equilibrium, you now have that much maligned state of being where your number of landings no longer equal your number of take-offs. The most simple way to resolve this is to board an airplane already in flight -- I'd recommend a -6 with a sliding canopy as the receiving aircraft. Even if you leave the numbers skewed, that's okay, as usually it's terminal when somebody messes with the balance. GLAD YOU'RE STILL ABOARD and we're all glad you're safe. // s // Bradley W. Kidder, Jr. sparksnmagic(at)earthlink.net ICQ# 11770815 RV-6A (empennage) N188FW (reserved) ________________________________________________________________________________
Date: Aug 31, 1998
Subject: gear leg fairing, and some crass commercialism
<< Does anyone know if you can buy the gear leg fairing for a rv-4...or do I have to make it myself? The fairing I am talking about is the one at the top of the gear leg that joins the fuselage. John C. Anderson >> John: I want to have these made up one day, for sale to fellow RVers. Right now you'll have to do this yourself, or hire it done. If you combine the various gear leg fairings available, with the different engine mounts, and the many wheel fairings, you will find the a one-size- fitzall fairing is not possible. As you know, a small production run of any doo-hinky is expensive. I'll probably have intersection fairings made up to fit my gear leg fairings combined with the tall gear (for the -4). The -6 is easier (only one engine mount so far), but there are many different wheelpants available for that airframe too. I can't see a winning solution here!! Now, if you want to change to 1-pc gear leg fairings at some point, the upper and lower intersection fairings you are about to make to fit the 2-pc fairings won't fit the new (larger chord) gear leg covers. So: If you think you might want to use the 1-pc GLF, do it now. Crass commercialism warning!! It just so happens I sell 'em, as does Cleaveland Tool. These units fit all models of RVs, and one fellow iseven trying one on his -6A nose strut. I hope to hear about that install soon. Are they tough enough to survive? Ask Mr Sean Tucker- he has a set on his Challenger biplane. I've been using mine (on a Rocket) for 150 hrs or so, from a sod (or dirt) field. No problems. Check six! Mark ________________________________________________________________________________
Subject: Replay on RV-4
Date: Aug 31, 1998
Hi, My husband has an RV - 4 for sale and it is about 95 to 97% done. His work phone # is (209)544-0402, Fax (209)5440429, Home (209)878-3634. He is at work right now and I happened to be reading the email and saw your request. Deb Sanborn-Jensen ---------- > From: Steve D Nichols <steve.nichols(at)stoneweb.com> > To: rv-list(at)matronics.com > Subject: RV-List: re-4 kit > Date: Monday, August 31, 1998 5:26 AM > Nichols" > > WITH ALL OF THE EXCITEMENT OF THE RV-8 AND 8A I WAS WONDERING IF ANYONE HAS > OR KNOWS ANYONE WHO HAS AN RV-4 PROJECT FOR SALE ? ADVISED BY A FRIEND TO > MAKE THIS POST BEFORE I ORDER THE EMP. KIT JUST TO SEE WHAT HAPPENS. > PLEASE RESPOND TO ME DIRECTLY AT www.steve.nichols(at)stoneweb.com > > THANKS FOR THE HELP > STEVE NICHOLS (READY TO ORDER -4) > > > ________________________________________________________________________________
Subject: Survey results are in
Date: Aug 31, 1998
I could not wait, so I compiled the results and posted the data for you to read. My apologies to those who have filled out the survey in the last 6 hours. I will include all future results in an update. Check it out at: <http://robin.getbiz.net/survey1.htm> if you have not filled out the survey please do so at: <http://robin.getbiz.net/survey.htm> please do not fill out the survey again if already had. I plan on making another survey in the near future focusing on flying and building. Let me know if you found this survey useful. Another suggestions are appreciated (I am unfortunately not a stats major!). Thanks, Robin Wessel RV-6A wing Ann Arbor, MI ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Re: HVLP conversion guns
Chris-- Do they even have complaigning nieghbors in New Zealand????? How far out do you have to get to have complete freedom????? dave--- ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Re: Replay on RV-4
waiiiittttt!!!!! sounds like my wife, don't listen to her, my plane is not for sale !!!! ( Just Kidding ) scott winging it in tampa ________________________________________________________________________________
Subject: Fwd side skins- 6A
Date: Aug 31, 1998
I am fitting the F670 fwd side skins. 1- Does the curved aft end go under the center bottom skins (676/677)? 2- do I drill the fwd hinge holes now. If I don't now , how will I deburr & demple after they are on? I am planning on back drilling the henge & spacer later. 3- Want to run a line (for wires) thru the 604,605, & 606. What type if tubing do youall recommend? Don Jordan ~ 76DJ ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Re: Canopy frame
Hi, The quality control on the weldments for the canopy seems to be weak. I read of other canopy frame mis-manufacture and of unsymmetrical roll bars. Cut, weld, bend etc. The Quick Build can be built in 500 hours but it takes 500 more to do the canopy. :-) My canopy fit just great. So I unclecoed and polished edges, now it doesn't fit well anymore!!%%##??!! I used a Nicholson plastics and laminates file which creates a smoother edge than 100 grit in much less time. I suppose a power sander would be best but I seem to enjoy filing. Weird huh? hal > Hi! I about to install the canopy frame when I discoverd that the left > rear tube > in the canopy frame is one inch longer than the right. > I have a nice curv on the right side but not on the left. > Do someone on the list have the same experience or have the measurment > for the length of the tubes between the weldments? > ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Re: Survey results are in
robin.y.wessel(at)exgate.tek.com wrote: > > > I could not wait, so I compiled the results and posted the data for you to > read. My apologies to those who have filled out the survey in the last 6 > hours. I will include all future results in an update. > > Thanks, > > Robin Wessel > RV-6A wing > Ann Arbor, MI > Nice job Robin! Ed Cole RV6A Fuse skins ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Re: Fwd side skins- 6A
donspawn(at)Juno.com wrote: > > > I am fitting the F670 fwd side skins. > > 1- Does the curved aft end go under the center bottom skins (676/677)? > > 2- do I drill the fwd hinge holes now. If I don't now , how will I deburr > & demple after they are on? I am planning on back drilling the henge & > spacer later. > > 3- Want to run a line (for wires) thru the 604,605, & 606. What type if > tubing do youall recommend? > > Don Jordan ~ 76DJ ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com > > Don, Check the Frank Justice notes if you haven't already. Ed Cole RV6A Fuse skins ________________________________________________________________________________
Date: Aug 31, 1998
Les, Bingo+ACE- I guess I have to blame my poor writing skills. You are the only one who understood my question. Let my try this one more time...the vents that I was asking about are indeed the +ACQ-59.00 units in Van's new catalogue. They are a small(?)round disk inside a circular structure. They mount flush on the skin. When ventilation is needed, they simply open up out into the slipstream. Looks to me like they would be very unlikely to leak in the closed position. My main concern was how well they vented in the open position. I'd love to hear from anybody who is using these. Sorry for any confusion on my original post. Joe Rex RV-4 sweatin' like a pig -----Original Message----- From: Leslie B. Williams +ADw-lesliebwilliams+AEA-email.msn.com+AD4- Date: Sunday, August 30, 1998 9:51 AM Subject: Re: RV-List: cabin vents +ADw-lesliebwilliams+AEA-email.msn.com+AD4- +AD4- +AD4-I don't believe Joe was referring to the Wisperflow but rather to the +AD4-Miniture Ventilator listed in the new catalog as CA LV-3 Ventilator +AEA- +AD4AJA-59.00. +AD4- +AD4-Les Williams/RV-6AQ/Tacoma WA (Baffles +ACY- engine stuff) +AD4- +AD4- +AD4APg- +AD4APg-Joe Rex, +AD4APg-Do not order the vents from (Van's whisperflow). They are flimsy and need +AD4APg-modification with pro seal so they don't leak. Aircraft Spruce has some +AD4-nice +AD4APg-ones +AD4- +AD4- +AD4- +AD4- +AD4- +AD4- +AD4- +AD4- -- +AD4- +AHw- Visit the Matronics +ACY- RV-List Web Sites at http://www.matronics.com +AHw- +AHw- +ACI-rv-list-request+AEA-matronics.com+ACI- +AHw- +AD4- +AHw- +ACY- put the word +ACIAWw-un+AF0-subscribe+ACI- in the +ACo-body+ACo-. No other text or subject. +AHw- +AHw- +AHw- +AD4- -- +AD4- ________________________________________________________________________________
Date: Aug 31, 1998
Subject: riveting near raised rib stiffening areas
I drilled the aileron bellcrank mounting angles to the 2 modified ribs this weekend. The first one I did, I marked the rivet locations on both ends of the 0.125 angles and drilled to the rib once they were located properly. After looking at what I had done, I found that I put 2 of the holes very close to the raised stiffening areas. They are close enough on these 2 holes that the rivet machine head will not lay completely flat on the rib web. One is the second hole from the main spar and the other is on the other 0.125 angle right next to the rivet attaching the .063 angle to the .125 angle. My question is, will driving a rivet so the shop or machine head is partially on the raised curve bite into the aluminum and cause a problem with stress concentration, or will the rivet deform enough to be ok? And would it be better to put the machine head or the shop head on the raised side? I took the scrap that I cut out of this rib, put 4 holes in it in the same type of position and squeezed rivets in them. 2 with the shop head forming on the curve and the other 2 the other way. Looking at these, they look fine except that the ones with the shop heads on the raised part have machine heads that hang over a little on the other side where the stiffening ring drops away from the rivet. It doesn't look like the rivets are biting into the rib where it raises. Based on this test, I am planning to just use these as is, but I'd like to know if any of you think I shouldn't do this. Thanks for your input. Chris Hand RV6A, wings CA ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Re: Bibb's Elquilibrium
landing in an open cockpit -6 wouild be a piece of cake compared to them trees... > >Richard: > >Glad to hear you're alive and well, and that the RV might possibly fly >again one day. In regard to equilibrium, you now have that much maligned >state of being where your number of landings no longer equal your number of >take-offs. The most simple way to resolve this is to board an airplane >already in flight -- I'd recommend a -6 with a sliding canopy as the >receiving aircraft. Even if you leave the numbers skewed, that's okay, as >usually it's terminal when somebody messes with the balance. GLAD YOU'RE >STILL ABOARD and we're all glad you're safe. >// s // >Bradley W. Kidder, Jr. >sparksnmagic(at)earthlink.net >ICQ# 11770815 >RV-6A (empennage) >N188FW (reserved) > > > > > Richard E. Bibb Direct: 703-245-4505 Vice President, Federal Operations Main: 703-245-4544 Fore Systems Federal, Inc. FAX: 703-245-4500 1595 Spring Hill Road Pager: 800-719-1246 5th Floor Vienna, VA 22182 We're from Pittsburgh, we make networks that last. ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Re: cabin vents
FWIW, I believe these are the ones Larry Vetterman is making. I saw them at the Minnesota Wing gathering this summer, and they are very pretty looking -- beautifully machined. Larry insists that they bring in tons of air, which seems pretty believable since they stick out an inch or more into the slipstream. Anybody got them into a plane yet? > >Les, > >Bingo+ACE- I guess I have to blame my poor writing skills. You are the only >one who understood my question. Let my try this one more time...the vents >that I was asking about are indeed the +ACQ-59.00 units in Van's new catalogue. >They are a small(?)round disk inside a circular structure. They mount flush >on the skin. When ventilation is needed, they simply open up out into the >slipstream. Looks to me like they would be very unlikely to leak in the >closed position. My main concern was how well they vented in the open >position. I'd love to hear from anybody who is using these. Sorry for any >confusion on my original post. > >Joe Rex Don Hyde Quincy, IL 6A, Building! VS done, Working on rudder. ________________________________________________________________________________
From: "Morrissey, John" <John.Morrissey(at)its.csiro.au>
Date: Sep 01, 1998
Now c'mon fella's Are you trying to tell me you never bounced on landing - In my early day's my landings always outnumbered my takeoffs!! :-) BTW any landing you can walk away from is a good one. Good luck on the recovery of your pride and joy Richard. Cheers John Morrissey -----Original Message----- From: Richard Bibb [mailto:rbibb(at)fore.com] Sent: Tuesday, September 01, 1998 10:59 AM Subject: Re: RV-List: Bibb's Elquilibrium landing in an open cockpit -6 wouild be a piece of cake compared to them trees... > >Richard: > >Glad to hear you're alive and well, and that the RV might possibly fly >again one day. In regard to equilibrium, you now have that much maligned >state of being where your number of landings no longer equal your number of >take-offs. The most simple way to resolve this is to board an airplane >already in flight -- I'd recommend a -6 with a sliding canopy as the >receiving aircraft. Even if you leave the numbers skewed, that's okay, as >usually it's terminal when somebody messes with the balance. GLAD YOU'RE >STILL ABOARD and we're all glad you're safe. >// s // >Bradley W. Kidder, Jr. >sparksnmagic(at)earthlink.net >ICQ# 11770815 >RV-6A (empennage) >N188FW (reserved) > > > > > Richard E. Bibb Direct: 703-245-4505 Vice President, Federal Operations Main: 703-245-4544 Fore Systems Federal, Inc. FAX: 703-245-4500 1595 Spring Hill Road Pager: 800-719-1246 5th Floor Vienna, VA 22182 We're from Pittsburgh, we make networks that last. ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Relay question
A question for Bob Nuckolls that may be of interest to RVers. On the 6A that I'm helping with, belonging to Charlie Tyrrel of Gillette, WY, we're going to use toggle switches for the mags as opposed to a keyed mag switch. The left toggle will be a three position: off, left mag on, spring loaded to start. The right mag will be off and right mag on, a two postion switch. I assume that the right mag switch will be off during the starting procedure. We'll be using the Laser ignition. Will this toggle switch arrangement work as described with the Laser? Also, diodes are recommended on the battery and starter relays, I think to help protect keyed, magneto switches. Van's has these for sale in the catalog and I have installed these on my six. Are these diodes required when using toggle switches for the mags? Bob, do you or any listers have a source for the three postion: off-on-spring loaded on toggle switches. We intend to use this type of switch for the left mag and also on the fuel boost pump with the spring loaded-on postion being used to open the primer relay. Thanks, Bob Skinner RV-6 438 hrs. Buffalo, WY bskinr(at)trib.com ________________________________________________________________________________
From: "Leslie B. Williams" <lesliebwilliams(at)email.msn.com>
Date: Aug 31, 1998
I put mine on the spar web. Les Williams/RV-6AQ/Tacoma WA > >Listers, > >I'm mounting separate strobe power supplies in each wing. I can mount >them, with nutplates, on the spar web, or on either side of the end ribs. >What do people typically do? > >Regards, > >Chris Good, >West Bend, WI. >RV-6AQ, finishing up the wings. ________________________________________________________________________________
Date: Sep 01, 1998
Subject: need some advice.
Hey, I know this is only an aviation list for RV builders/fliers but I REALLY need some advice on something else. (it does have to do with aviation however). Are anyone of you an opthamologist? If so would you PLEASE write me at 'das1252(at)ksu.edu' . ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Re: riveting near raised rib stiffening areas
In a message dated 8/31/98 9:09:32 Central Daylight Time, chriskelhand(at)Juno.com writes: << They are close enough on these 2 holes that the rivet machine head will not lay completely flat on the rib web. >> Check your AC 43.13 1A & 2A, to see what it says about riveting that close to a bend radius. All rivet heads should lay flat. Regards Wendell ________________________________________________________________________________
Date: Aug 31, 1998
Subject: Hand cranking a fly cutter
A little bit of trivia that might help out some day. I was cutting instrument holes with a fly cutter over the weekend and discovered that 2 of the 2.25" holes were out of reach of my little tabletop drill press. So, I clamped the panel to the workbench, drilled the 1/4" hole at the center of where I wanted the instrument hole, put the fly cutter in the hole and started turning by hand. It took about 10 minutes to cut the hole out of the .060 aluminum and the hole was actually quite clean. It wasn't fun, but it was relatively quick. Don't forget to wear gloves. The knuckle demon that lives in the fly cutter will try to get you even when there's no motor turning :-) John Allen RV-6A Installing Systems and spending money ________________________________________________________________________________
Date: Sep 01, 1998
>> I am fitting the F670 fwd side skins. >> >> 1- Does the curved aft end go under the center bottom skins >(676/677)? Most builders put them under. You want to try and have all skins lapping aft for drag reduction, clean look, etc. >> >> 2- do I drill the fwd hinge holes now. Yes, you drill and dimple but dont rivet, just leave in cleco's and you can back drill through these holes later for the hinge. BTW, don't worry if you cant dimple all of the holes on the firewall flange. The stainless is soft which will allow you to dimple the firewall flange through the dimples in the skin after removing the fuse. from the jig. >> 3- Want to run a line (for wires) thru the 604,605, & 606. What type >if >> tubing do youall recommend? I don't use tubing, I use the plastic grommets that are supplied in the kit. Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. e rivet with a gun and a bucking bar. Be sure to put the manufactured head on the rib side and form the shop head on the heavier angle material (it is better to always follow this proceedure when ever possible). Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. ________________________________________________________________________________
Subject: Cockpit / interior paint - one answer among many
Date: Aug 31, 1998
After tormenting myself for several months over what color of light gray I wanted, I finally decided to use just use Rustoleum Professional High Performance Enamel - Light Machine Gray (7581). The gray is the color I wanted, and you can't get any easier than grabbing a can and shooting something. It touches up very easily too of course. I went to my local auto paint shop this afternoon and had them color match my battery box which I had already painted with the above. The result: Dupont ChromaOne (Single stage acrylic urethane) : 7881E Dupont ChromaBase : 7881K The ChromaOne should be more durable and flows out better than the Enamel. ChromaBase is usually a two-stage product that gets a clear coat on top, but I use it on the instrument panel as is so that it stays flat for non-glare. Hope this helps someone. Mitch Faatz San Jose, CA N727MF (reserved) RV-6AQME Finishing Kit... Pres/Newsletter Editor - Bay Area RVators ________________________________________________________________________________
Date: Sep 01, 1998
Subject: My "Great" Titanium "Ti-downs", and the RV-List
Greetings RViators, I'm Randy Simpson, owner of Airtime Mfg., maker of the Titanium "Ti-downs" that many RV owners/builders already have purchased. I've been lurking on this list since April, and even though I'm not building an RV (yet), I've learned alot about what's involved in building a trick plane like the RV's and (more importantly to me at this time) is hearing about how the RV's fly, and the enjoyment the RV pilots experience (Corsair comes to mind here). First of all, ALL my dealings with my RV-List customers have been a pleasure. Since I started selling the Ti-downs via the internet in April, RV-Listers have been my only customers, as I had trouble keeping up with the RV orders alone. I've had a policy that if I had the Ti-downs in stock, I'd send them out immediately, and wait for the check to come in (at least till I got burned). Nearly all my friends and family thought I was NUTS to be so trusting. I'm happy to report that EVERY set I've shipped, the checks came in as promised. KUDOS to you! It seems that if you've got a "better mousetrap", the world will beat a path to your mailbox if you have a website also... Of all the sets of Ti-downs I've sold (havn't tallied up how many lately, but probably 50-60 sets), none have been returned because they bent, or broke. That's a good sign. I've been really testing them this summer, as I've been doing alot of air-camping, using the Ti-downs whenever I can (even if there are regular airport tie-downs already there). I've put 110 hours on my Carrera Ultralight since the last week of May of this year (it's just: work (fly), work (fly), work (fly). I'm all caught up with my backorders now, and have some sets in stock, ready for immediately delivery. My son David and I spent the WHOLE weekend in our shop "pounding out Ti-downs", despite the perfect flying weather. We're trying to earn enough money for his tuition at a private school. It's really great to be working side by side with my 14 yr old son, who will most likely fly solo for the first time at the Alvord Desert (in SE Oregon) fly-in a couple of weeks from now (weather permitting, of course). For those of you RV flyers that already have bought and used the Ti-downs, I'd like to hear from you if you have anything intresting to report about the Ti-downs (good or bad). You guys that used the Ti-downs at Oshkosh, how'd they work there? Please reply to me off list, or on list if you think other Listers could benefit from your experience. I'm gonna donate a set (or "kit") to Matt Dralle as "thanks" for giving us this excellent List. Thank you Matt, I appreciate it... Also, Sam Buchanan will have a set soon for his torture test/evaluation. Look for his report in his RV Journal soon... Thanks for your time, Randy Simpson Airtime Mfg. http://www.airtimemfg.com Current Ultralight Pilot Future RV Owner/Pilot (I'm sure) Brownsville, OR ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Torque for flare fittings ?
I have not seen any guidance on torque values for flare fittings such as those used in the fuel system of the RV. Also, I feel like I should somehow safety the flare nut which holds the flop tube to the tank fitting. Do any of you have ideas on this? Mark McGee RV4, Left Fuel Tank ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Re: RV-4 O-320 160 HP Wooden Prop??
I had very good luck with a prop from Props Inc. It ran great "right out of the box". Great performance, all around. I had to go round and round with Sterba to get a prop that would work. ________________________________________________________________________________
Date: Sep 01, 1998
The curved aft end goes OVER the center bottom skins. The rest I don't know. I left the hinge(s) undrilled thinking that I should have the cowl on hand before drilling. I hope to finesse the issue of dimpling or countersinking the holes later. Probably a mistake, but I hope not. Steve Soule RV-6A fuselage floors -----Original Message----- 1- Does the curved aft end go under the center bottom skins (676/677)? 2- do I drill the fwd hinge holes now. If I don't now , how will I deburr & demple after they are on? I am planning on back drilling the henge & spacer later. 3- Want to run a line (for wires) thru the 604,605, & 606. What type if tubing do youall recommend? ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Re: Conical engine mounts
Al Mojzisik wrote: > > Chuck, > You've got an RV-3 with an AIO-360 engine in it! Let me ask you this, do > wear a "G" suit when you fly it? And does it "take off" or do you "LAUNCH" > it? Enquiring minds want to know! Al > Al, I'd like to say yes to your "enquiring mind," but to truth of the matter lies in the fact that the conical mounts are needed for my brothers RV-4. My THREE has an "improved" IO-320 in it. I've thought about building an RV-3 with an IO-360 angle valve next, but I'll wait awhile until Van comes out with a new wing for the THREE. Life is good, so many choices and things to do!! ________________________________________________________________________________
Date: Sep 01, 1998
> > > > > >My question is, will driving a rivet so the shop or machine head is >partially on the raised curve bite into the aluminum and cause a problem >with stress concentration, or will the rivet deform enough to be ok? >And would it be better to put the machine head or the shop head on the >raised side? > >Chris- I am not a structural engineer but I have done a fair amount of sheet metal repairs at Delta following our engineers guidlines. We come across this situation of being into the radius of a bend once in a while. A fastener installed that was at all into the radius or not flat would not be acceptable. Because of the stress concentration you mentioned. We make a "radius block". A small piece of 2024 alum at least .032 thick and form a matching radius on one edge if it. Then we put sealer between the two and rivet it as normal. With the machine head on the radius block side so it will stay in place as you rivet. Hope it helps > Dennis Hart (Tail in the mail) > > > > ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Positech Oil Coolers
I need to purchase an oil cooler for my 0-360. Does anyone know anything about the Positech Oil Cooler listed in Vans new catalog @ $167.00? And how these compare to the Stewart Warner @ $241.00? Or any other suppliers you have found to be good. Thanks. Von Alexander RV-8 N41VA Installing Seats and fitting wings Oregon MAlexan533(at)aol.com ________________________________________________________________________________
Date: Sep 01, 1998
In light of Scott McD's posting, I have rethought this one. I need to go home and look at how I did my skins. I might have remembered it wrong. Don't take my advice to the bank. Steve Soule -----Original Message----- From: Stephen J. Soule Sent: Tuesday, September 01, 1998 8:24 AM To: 'rv-list(at)matronics.com' Subject: RE: RV-List: Fwd side skins- 6A The curved aft end goes OVER the center bottom skins. The rest I don't know. I left the hinge(s) undrilled thinking that I should have the cowl on hand before drilling. I hope to finesse the issue of dimpling or countersinking the holes later. Probably a mistake, but I hope not. Steve Soule RV-6A fuselage floors 1- Does the curved aft end go under the center bottom skins (676/677)? 2- do I drill the fwd hinge holes now. If I don't now , how will I deburr & demple after they are on? I am planning on back drilling the henge & spacer later. 3- Want to run a line (for wires) thru the 604,605, & 606. What type if tubing do youall recommend? ________________________________________________________________________________
Date: Sep 01, 1998
Chuck: I have 3 with a 0-320,Ellison carb.cross-over and pretty clean...Have been trying out different props...Now have Amar-Demuth 68x88..Think its a little under-pitched..Great climb!!! 2800 fpm at 2400/95mph but only 195 at 2700 level...Will go over 3000 if I let it!!! Have new prop coming thats being cut to hold 2700 full throttle...0-320 is 160...What prop are you using???? Jim Brown,Matawan,NJ ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Request for WWW links about flight testing
Listers, Now that I am on the road again, I am working on my WWW page instead of building the RV-8. I put a small section dedicated to information on flight testing on my RV Links page <http://www.cyberus.ca/~khorton/rvlinks.html>. If anyone knows about any other WWW links with information useful about flight testing amateur built aircraft, please send them direct to me, not the list. I will add them to my links page. Thanks, Kevin Horton RV-8 80427 (wings) khorton(at)cyberus.ca Engineering Test Pilot stuck in Wichita instead of home working Transport Canada on the RV :-( ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Re: Torque for flare fittings ?
<< I have not seen any guidance on torque values for flare fittings such as those used in the fuel system of the RV.>> I was always taught that standard practice is to tighten the nut until it you feel it "seat" and then tighten one more "flat" of rotation on the hex nut. << Also, I feel like I should somehow safety the flare nut which holds the flop tube to the tank fitting. >> I used Proseal on the threads. -GV ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Re: Positech Oil Coolers
<< I need to purchase an oil cooler for my 0-360. Does anyone know anything about the Positech Oil Cooler listed in Vans new catalog @ $167.00? And how these compare to the Stewart Warner @ $241.00? Or any other suppliers you have found to be good. Thanks. On the Rockets, we use a 19 row Setrab cooler bought from TMR in Orange, CA (714-771-1348- talk to Mike). I have heard that there is a supplier in the northwest also. 9, 12, and 16 row models are available, all priced around $70US. Users report success (good cooling) with these units, and no failures/leaks. Mark Goldberg's RV-8 has a 16 row unit installed on the firewall, with a 3" hose connecting the cooler to the baffling. This particular installation doesn't seem to cool as well as I had thought it would- I have a feeling that the "cone" used to attach the hose to the cooler has too steep of a divergent angle. Mark talked about changing to a 19 row, but I had asked him to change the cone angle first. Stay tuned for updates on this squawk. Check six! Mark Von Alexander RV-8 N41VA Installing Seats and fitting wings Oregon MAlexan533(at)aol.com >> ________________________________________________________________________________
Date: Aug 30, 1998
FMark40(at)aol.com wrote: > > I have not seen any guidance on torque values for flare fittings such as those > used in the fuel system of the RV. Also, I feel like I should somehow safety > the flare nut which holds the flop tube to the tank fitting. > > Do any of you have ideas on this? > > Mark McGee > RV4, Left Fuel Tank The torque values can be found in the Standard Aircraft Handbook. Best wishes, Jack Abell Los Angeles RV-6A N333JA (Reserved) 16 row models are available, all priced around $70US. Users report success (good cooling) with these units, and no failures/leaks. Mark Goldberg's RV-8 has a 16 row unit installed on the firewall, with a 3" hose connecting the cooler to the baffling. This particular installation doesn't seem to cool as well as I had thought it would- I have a feeling that the "cone" used to attach the hose to the cooler has too steep of a divergent angle. Mark talked about changing to a 19 row, but I had asked him to change the cone angle first. Stay tuned for updates on this squawk. Check six! Mark Von Alexander RV-8 N41VA Installing Seats and fitting wings Oregon MAlexan533(at)aol.com >> ________________________________________________________________________________
Date: Jun 02, 1998
Subject: Re: Cockpit / interior paint - one answer among many
Be careful with Rustoleum. I used it for some of my steel parts, and it turns out that it won't stick well to anything else but bare metal or more Rustoleum, and nothing else likes to stick to it. The Sherwin Williams guy told me that it had something to do with a type of oil in the Rustoleum. I thought he said "fish oil", but I could be wrong. Anyway, you'll want to do some tests before you spray it with any other products. Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 page at: http://members.bellatlantic.net/~moejoe Mitch Faatz wrote: > > After tormenting myself for several months over what color of light > gray I wanted, I finally decided to use just use Rustoleum Professional > High Performance Enamel - Light Machine Gray (7581). The gray is > the color I wanted, and you can't get any easier than grabbing a can and > shooting something. It touches up very easily too of course. > > I went to my local auto paint shop this afternoon and had them color > match my battery box which I had already painted with the above. The > result: > > Dupont ChromaOne (Single stage acrylic urethane) : 7881E > Dupont ChromaBase : 7881K > > The ChromaOne should be more durable and flows out better than > the Enamel. ChromaBase is usually a two-stage product that gets > a clear coat on top, but I use it on the instrument panel as is so that > it stays flat for non-glare. > > Hope this helps someone. > -- ________________________________________________________________________________
Date: Sep 01, 1998
Just had to add this to the post on landings,.Everyone knows what a good landing is, any one that you can walk away from. What a lot of people don't know is what an EXCELLENT LANDING is, one in which the aircraft can be reused ________________________________________________________________________________
Date: Sep 01, 1998
Subject: HPLV Sprayers
Anyone out there in RV land have a complete HPLV spray unit they have used and are interested in selling? If so, please contact me off line at WD_Thomas(at)Earthlink.Net. Thanks. Bill Thomas ________________________________________________________________________________
Date: Sep 01, 1998
>>> Moe Colontonio 06/02 10:48 AM >>> Be careful with Rustoleum. The Sherwin Williams guy told me that it had something to do with a type of oil in the Rustoleum. I thought he said "fish oil", Yep, it is definitely fish oil. Their corp hdqtrs in Chgo suburb has a whaling or some kind of fishing scene in the lobby. Bill Costello RV6 - still on wings ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Overlapping metal sheets
Hi Folks, For those of you who are really gung-ho about drag reduction, there was a strong case made a while back that overlapping sheets from the back toward the front of the plane actually REDUCED drag compared to the opposite. I can picture the air curling over a 'front-to-back' lap joint and then burbling into separation from the skin. I guess in the same vein, the air that bumps into a 'back-to-front' lap joint rises over the rear skin and tends to stick with it. Anybody have any wind tunnel studies? Bill Costello RV6 - on wings ________________________________________________________________________________
Subject: Bus, contactor and ground locations
Date: Sep 01, 1998
Bob Nuckolls, In a recent thread on bus location, you stated, "If designing in accessibility means longer wires, more weight, or more hours of effort to install, I think I'd opt for system efficiency over convenience." You never said where you would put the main and essential bus' in a 6A. I am designing a two battery (maybe two alternator system). I looked through the archives about contactor location. This is what I gleaned. Main battery, alternate battery and crossfeed contactors ...close to the battery on the inside of the firewall. Starter contactor...on the engine side of the firewall (any preferred distance from the battery contactor?) max. 6" from 80 amp fuse to starter contactor. Main battery ground...#2 welding cable to the ground bus located on the inside of the firewall (high up to minimize length of wire from panel instruments) then #2 cable to the engine crankcase (this is not how it is drawn in your schematics which show the battery ground going to the crankcase then to the ground bus) Alternate battery ground...you show it going to the firewall. Can I put it on the ground bus or should it be in a separate location. Waiting for Rev 8. Ross Mickey ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Re: Relay question
The purpose of the diodes across the starter and master relay coils is to "short out" the induced voltage that results from the collapse of the magnetic field when the energizing current is removed. The rate of fall is fairly high, so the induced voltage is great enough that it can cause shorts within the coils themselves. Depending upon how relay contacts are connected (or not) some protection of the contacts might also be involved.) ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Re: Request for WWW links about flight testing
Kevin, you might find this link interesting for your training/flight testing links: >>>> http://www.eurofly.co.uk/european/flyschool/3.htm <<<< AL > >Listers, > >Now that I am on the road again, I am working on my WWW page instead of >building the RV-8. > >I put a small section dedicated to information on flight testing on my RV >Links page <http://www.cyberus.ca/~khorton/rvlinks.html>. > >If anyone knows about any other WWW links with information useful about >flight testing amateur built aircraft, please send them direct to me, not >the list. I will add them to my links page. > >Thanks, > >Kevin Horton RV-8 80427 (wings) >khorton(at)cyberus.ca >Engineering Test Pilot stuck in Wichita instead of home working >Transport Canada on the RV :-( > > > > > ________________________________________________________________________________
Subject: Traveling to Washington state
Date: Sep 01, 1998
Spokane area 'Listers, I will be traveling to Fairchild AFB Washington 14 Sep to 18 Sep. I would love to look at RV projects and flying aircraft in the area. Please respond off-list. Thanks, Tom Craig-Stearman tcraigst(at)ionet.net RV-4 64ST fabricating inlet duct for forward-facing injector unit ________________________________________________________________________________
From: "William G. Knight" <wknight(at)adelphia.net>
Subject: Builder's Help Needed on Long Island, NY
Date: Sep 01, 1998
Am having an RV-6's chin scoop replaced (after an induction fire) in Easthampton, LI, NY and need builder's assistance with fabricating plenum on intake. Is there anyone on LI who'd like to make a few $$$ and help? Please reply off list to airshows1(at)msn.com Thanks, Bill Knight ________________________________________________________________________________
Date: Sep 01, 1998
<< How about a wooden prop for an RV-4 with a 0-320/150 horse engine (A different airplane) (Mine)?? I'm using a pacesetter-200 now and find that it's not enough prop..at 10K feet the engine will go beyond 3000 RPM at 200 MPH. More pitch please!! >> Try giving Aymar Demuth a call. They are listed under props in the classified section of the sport aviation magazine. He is a little more expensive, but his props are real performers and usually come out of the box right the first time. I run one of his props as well as many others in the area and I havent heard anyone complain around here. Ryan Bendure Co. ________________________________________________________________________________
Date: Sep 01, 1998
Subject: RV6A,0320-E2D,AYMAR DEMUTH PROP FOR SALE
Will sell RV6A partially finished, one wing almost done, tail feathers done, fusealage not started. Phil. Spar. 0320-E2D 538 TTSN, no finishing kit, Aymar Demuth prop. $16,000 for all, will not separate. E Mail shoffius(at)aol.com ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Archives, how to download
Hello all, I would like to download the archive and the search engine that I had before my C: drive was reformatted. How do I do that? Thanks, Mike Weller ________________________________________________________________________________
Subject: RE: Rustoleum Primer
Date: Sep 01, 1998
>I have watched the primer debates on the RV-List. I noticed you mention the >use of Rustoleum paints a couple of times and I am courious about your >feels/ results. Most people seem to stick with the aircraft or auto primers >which costs about twice as much as the Rustoleum. I am no expert on the >chemistry of paint, but all that I am looking for at this time is a >moisture / corrosion barrier for the internal structures of my RV-8. >I have found Rustoleum Clean Metal Primer at the local Home Depot >and it appears that it might work. As far as the exterior of the aircraft >I will probably go with the aircraft primer and topcoats. David, I hope you don't mind if I include the list on my response: Well, I'm using it only for the interior, and then only in places I feel aren't going to be touched too much. Top rails, seats, most of the baggage compartment, etc. are all going to be shot with Dupont ChromaOne for durability and better finish. But for small things that I just want to shoot quick and mount might get the Rustoleum. It's very handy, looks pretty good, is the "right" color gray (for me), and is relatively cheap. The quart of ChromaOne and ChromaBase were $90!! I haven't shot the ChromaOne in areas that already have some Rustoleum yet. I'll write a reminder to send another status report on this in a few months or a year after flying to report how they hold up and interact with each other. I'm using Veriprime for most of the project, the QB had the Sherwin Williams wash primer, and I sometimes use rustoleum primer or Norton's (?) on steel parts (or Veriprime if I have a batch mixed up). I suppose if I was just starting my project I might research the epoxy primer since many people think they are better if not top-coated. For the exterior, I'm having it professionally done so I'll let him use whatever he is most experienced with for primer and paint. Mitchell Faatz N727MF (reserved) RV-6AQME San Jose, CA Finishing Kit... President/Newsletter Editor Bay Area RVators ________________________________________________________________________________
Date: Sep 01, 1998
Subject: PROPS
How much do wood props cost? and what are normal lead times? The wood prop makers don't seem to have web pages and I know I could call them but I bet a lot of RVer's already know this. I'm nearing decision time on a prop and need to know if the Sensenich metal is worth the price. thanks for any info. Wayne (fumbling with the cowl) Bonesteel RV-4 O-320 150HP ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Re: [Fwd: AOA]
Hi Michael, I would appreciate receiving the information you receive on the AOA. My son talked to them at OSHKOSH. He was concerned about the reliability of the design with the rather sofisticated electronics. I talked to LRI, (Mr. Huntington's son I believe.) I have always been impressed with this unit. Would sure like to hear personal experiences on actual usage with any of these units In addiition, there is another one called the RiteAngle II. Here's a couple of web pages: http://www.liftreserve.com for the LRI http://members.aol.com/elbie/riteangle/ra2.htm for the Riteangle Catch ya later. Wally Hunt RV-4, instruments, canopy, engine and paint. ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Re: Overlapping metal sheets
This is outlined fairly well in Horner's Book "Fluid Dynamic Drag". This does not seem to meet the common sense approach to aerodynamics, but Horner did the wind tunnel testing to determine the Cd of the various types of joints. If you do overlap the rear skins you still need to bevel the rear skin to get the best drag reduction. Bob Busick RV-6 Fremont CA << Hi Folks, For those of you who are really gung-ho about drag reduction, there was a strong case made a while back that overlapping sheets from the back toward the front of the plane actually REDUCED drag compared to the opposite. I can picture the air curling over a 'front-to-back' lap joint and then burbling into separation from the skin. I guess in the same vein, the air that bumps into a 'back-to-front' lap joint rises over the rear skin and tends to stick with it. Anybody have any wind tunnel studies? Bill Costello RV6 - on wings >> ________________________________________________________________________________
Date: Sep 01, 1998
Subject: SE Oregon Alvord Fly-in/campout
Hello, all... I would like to extend an invitation to all interested to come to the Alvord Desert Fly-in / Campout. The fly-in is an annual event in the SE Oregon area, semi-sponsored by the Top Fun Flyers in Boise, ID. When: 18-21 September..... Where: Alvord Dry lake (big one! 6 by 10 miles) South East Oregon.. 42'32.08 N 118'27.18 W Why? Great people... usually about 50-60people, 20-25 airplanes. Hotsprings right on the edge of the lake bed, GREAT for soaking after a long day of relaxing... :) Majestic Steens Mountains just north, REALLY gorgeous from about 10,000! Events: Campfire gathering on Sat. night (bunch of pilots sit around and talk about flyin and such.. can you believe it!), Free breakfast (pay by donation ONLY) Sunday morning prepared by the TFF. Overall it's a really fun event for all. If any of you are interested contact me off-list and I can give you all the details. Also, bribe time.. if anyone needs extra fuel, food, or other.. I would be willing to provide for a flight or two in an RV (come on guys, its been 3 years.. please? Haha). Cheers, Nick Nafsinger n.nafsinger(at)mci2000.com RV-8, planning stages.... ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Double, double toil and trouble, bent frame and stretched bubble!
Hi all, I took my 6A QB sliding canopy bubble off to polish edges etc. Set it with care on the fuselage just ahead of the vertical stab. On top of an old but soft comforter. When I reattach it, the holes don't line up! It is just as if the bubble has gotten longer. I began by clecoing the center rail - perfect fit. Then I did the same to the rear bow. When I moved to the front, the holes all overhung the front frame bow! The stuff is alive!! My side skirts top holes - where screws go thru the plexi - are off progressively more starting from the back. I did decide that pop rivets ( I am not prejudiced against them) suck for this application. So, I drilled clear thru the center rail and the rear bow for #6 screws and nuts. The front bow, I tapped for the same. Surely the frame didn't shrink. When I force the fit at the front bow, the sides stick way out. I'm not making this up. I guess I have to re-drill the plexi at the front bow. It seemed to go so well I thought I might re-write the slider instructions but now I believe it would be a tale told by an idiot, full of sound and fury but signifying nothing. Hal Kempthorne RV-6AQ -- Fitting canopy rear skirts halk(at)sybase.com Santa Clara, CA. Debonair N6134V @ SJC ________________________________________________________________________________
Date: Sep 01, 1998
>From owner-rv-list-server(at)matronics.com Tue Sep 1 05:23:25 1998 >Received: (from daemon@localhost) (PDT) >Message-ID: <35EBE66F.E26BECAC(at)datasync.com> >Date: Tue, 01 Sep 1998 07:19:59 -0500 >From: MICHAEL <lottmc(at)datasync.com> >To: rv-list(at)matronics.com >Subject: Re: RV-List: RV-4 O-320 160 HP Wooden Prop?? >References: <19980831182609.7499.qmail(at)hotmail.com> >Sender: owner-rv-list-server(at)matronics.com >Precedence: bulk >Reply-To: rv-list(at)matronics.com > > >Thanks Michael..I'll pass this along to the owner Bob > > > > > ________________________________________________________________________________
Date: Sep 01, 1998
> >I need to purchase an oil cooler for my 0-360. Does anyone know >anything about >the Positech Oil Cooler listed in Vans new catalog @ $167.00? And how >these >compare to the Stewart Warner @ $241.00? Or any other suppliers you >have >found to be good. Thanks. > >Von Alexander > Von, I have had a look at the new cooler, but we haven't used one our selves yet. The biggest difference that I can see visually that it is heavier than the Harrison/Stewart Warner coolers are. Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. ________________________________________________________________________________
Date: Sep 01, 1998
writes: > >> >> >> >> >> >>My question is, will driving a rivet so the shop or machine head is >>partially on the raised curve bite into the aluminum and cause a >problem >>with stress concentration, or will the rivet deform enough to be ok? >>And would it be better to put the machine head or the shop head on >the >>raised side? >> >>Chris- > I am not a structural engineer but I have done a fair amount of sheet >metal repairs at Delta following our engineers guidlines. > We come across this situation of being into the radius of a bend >once in >a while. A fastener installed that was at all into the radius or not >flat >would not be acceptable. Because of the stress concentration you >mentioned. > We make a "radius block". A small piece of 2024 alum at least .032 >thick >and form a matching radius on one edge if it. Then we put sealer >between >the two and rivet it as normal. With the machine head on the radius >block >side so it will stay in place as you rivet. > > Hope it helps >> Dennis Hart (Tail in the mail) >> >> Dennis is right. This would be the proper thing to do on an inside radius of an angle, etc, but the problem that Chris encountered is different the radius bump that he was dealing with is from a stiffener bead formed in the rib (if I understood him correctly) which means their is a hollow space underneath. It would be acceptable to hammer the bead down flat or just drive a rivet on it which will pull it down flush in the process. Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. ________________________________________________________________________________
Date: Sep 01, 1998
>From owner-rv-list-server(at)matronics.com Tue Sep 1 13:52:33 1998 >Received: (from daemon@localhost) (PDT) >From: RV4131rb(at)aol.com >Message-ID: >Date: Tue, 1 Sep 1998 15:32:59 EDT >To: rv-list(at)matronics.com >Subject: Re: RV-List: RV-4 O-320 160 HP Wooden Prop?? >Sender: owner-rv-list-server(at)matronics.com >Precedence: bulk >Reply-To: rv-list(at)matronics.com > > > >< ________________________________________________________________________________
Date: Sep 01, 1998
From: "Scott A. Jordan" <SAJ_SLJ(at)compuserve.com>
>I can picture the air curling over a 'front-to-back' lap joint and then burbling into separation from the skin. I guess in the same vein, the air that bumps into a 'back-to-front' lap joint rises over the rear skin and tends to stick with it.< This is exactly correct but somehow it just doesn't look right so you hardly ever see it done. I doubt that it makes a measurable difference in our 200 MPH machines since we only have a couple joints on the fuselage. The wings are butt joints and avoid the question. Does using a single piece wing skin adversly effect low speed handling since it eliminates the "stall fence" effect of the two piece skins? Just Kidding!!! I don't want to start a long discussion about something that we can't measure. Scott A. Jordan 80331 wing skins ________________________________________________________________________________
Date: Sep 01, 1998
> How about a wooden prop for an RV-4 with a 0-320/150 horse engine Hi Bob; I just love my Sensenich wood prop. Great performance in a -4 with 150hp. John Kitz N721JK Ohio 250 hours ________________________________________________________________________________
Subject: Re: Double, double toil and trouble, bent frame and stretched
bubble!
Date: Sep 01, 1998
Hal, you didn't say how much distance the holes are off. Is the ambient temperature approximately what is was when you dirilled it up? I do know that the plexi will expand and contract quite a bit, particularly when it isn't fastened down. Did you try clecoing it up in approximately the same order in which it was drilled? The frame also may be in a different, relaxed position than when it is all clecoed up. I wouldn't get in a hurry to start redrilling until the jury from this list is in. Good luck! Les Williams/RV-6AQ/Tacoma WA >I took my 6A QB sliding canopy bubble off to polish edges etc. Set it with care on the fuselage just ahead of the vertical stab. On top of an old but soft comforter. When I reattach it, the holes don't line up! It is just as if the >bubble has gotten longer. I began by clecoing the center rail - perfect fit. >Then I did the same to the rear bow. When I moved to the front, the holes all overhung the front frame bow! The stuff is alive!! >My side skirts top holes - where screws go thru the plexi - are off >progressively more starting from the back. >I did decide that pop rivets ( I am not prejudiced against them) suck for this application. So, I drilled clear thru the center rail and the rear bow for #6 >screws and nuts. The front bow, I tapped for the same. Surely the frame didn't shrink. When I force the fit at the front bow, the sides stick way out. >I'm not making this up. >I guess I have to re-drill the plexi at the front bow. >It seemed to go so well I thought I might re-write the slider instructions but >now I believe it would be a tale told by an idiot, full of sound and fury but >signifying nothing. > > >Hal Kempthorne RV-6AQ -- Fitting canopy rear skirts >halk(at)sybase.com Santa Clara, CA. Debonair N6134V @ SJC ________________________________________________________________________________
Date: Sep 01, 1998
bubble! Hal Kempthorne wrote: > I took my 6A QB sliding canopy bubble off to polish edges etc. Set it with care > on the fuselage just ahead of the vertical stab. On top of an old but soft > comforter. When I reattach it, the holes don't line up! What was the temparature when it fit and what is it now that it doesn't fit? In the canopy section in "18 years of the RV-ator" there is an article mentioning a 3/8" difference from 10F to 90F. I think if you start from the front and work your way back you can probably make it fit. Finn ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Re: Traveling to Washington state
Tom Too bad. There are "gobs" of RV's in Western Washington. I am just south of Arlington Airport, which I believe has nearly twenty five. Good luck in Spokane. Hope you get to see some nice planes/projects. Jim Nice ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Re: Double, double toil and trouble,bent frame and stretched
bubble! Hal, Did you have any spacers somewhere that you've forgotten? (I can't imagine anyone doing that... oh, except for when I did it.) Also, I had to cleco the center rail, then cleco alternately down the front and aft bows. I could not make it work when I cleco'd the whole aft bow first. Alex Peterson Maple Grove MN > I took my 6A QB sliding canopy bubble off to polish edges etc. Set it with care > on the fuselage just ahead of the vertical stab. On top of an old but soft > comforter. When I reattach it, the holes don't line up! It is just as if the > bubble has gotten longer. ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Setrab Oil Cooler
Listers; I have access to a 16 row Setrab Oil Cooler, from TMR of Orange, Ca. Has anyone used this particular 16 row unit in the O-360 with success? Or should I try to get the 19 row? General info on this unit and your experiences with it would be appreciated. Von Alexander RV-8 N41VA MAlexan533(at)aol.com ________________________________________________________________________________
Date: Sep 01, 1998
Subject: Squeezer Yokes
Is a 4" deep squeezer yoke needed in the construction of an RV. Tony Livic RV8 tail alivic(at)wport.com ________________________________________________________________________________
Date: Sep 02, 1998
Subject: weekend fun
Hi all, I went and bought a few tool odds and ends today to complement my slowly growing set as I patiently wait for the Australia Peso to make a halfway decent effort to get back to a respectable level so I can actually rush out waving my arms like a lunatic and buy my kit. Thought i'd share with everyone the knowledge that I had the privelage of meeting a few of the folks from the RV list on the weekend and even got to sit in a real live RV-4. *thanks Sam and Carol!!* (pitty i'd have to cut 6 inches out of my back to be able to close the canopy) The experience has helped me really make a firm decision on going with the RV-8 .....or has it? Thanks to someone who shall remain Ken Glover *dobbed in* who organised a ride in a Tiger Moth for me *girlfriend now thinks I have been playing up such was the grin* I have been scratching my head as to weather the RV is really the way to go ;) Tailwinds to all, Todd ________________________________________________________________________________
Date: Sep 02, 1998
Subject: Re: Squeezer Yokes
Tony, I was told that you only need a 2 1/2 in yoke for most of the plane. It balances well and it's easy to squeeze a nice rivet. The 4" is hard to handle and you can squeeze off center because of it. So far I've found the 2 1/2 works out where you would want to squeeze and the rest are bucked. Have fun, Bob RV8 #423 Alivic(at)wport.com wrote: > > Is a 4" deep squeezer yoke needed in the construction of an RV. > > Tony Livic RV8 tail > alivic(at)wport.com > ________________________________________________________________________________
Subject: Throttle Brackett..
Date: Sep 02, 1998
Hi gang! I had a question about the throttle/mixture brackett used on the new 0-360A1A with a precision airmotive carb supplied with the new engines from Van's.I did buy the brackett that Van's sells but it doesn't look right. Anybody have a slam dunker set up? I'm sure this is not the first time this has come up..How about cable lenghts for the throttle,mixture,and prop..Any thoughts? Thanks, John Hughes RV-6 N164JH (reserved) So Cal, Hookin things up!! Oshkosh 99 or bust!! ________________________________________________________________________________
Subject: Nibbler attachment for power drill
Date: Sep 02, 1998
Speaking of the Oshkosh FlyMart, did anyone see the Austalian guy hawking a nibbler attachment for a power drill? Nice little cutting head that allows you to scroll your aluminum or steel sheet around like it was nothing. No noticeable deformation of the aluminum either. I don't recall the width of the cut though. It was ~$100 with the table clamps I think. Did anyone buy one of these? How is it? Mitch Faatz San Jose, CA N727MF (reserved) RV-6AQME Finishing Kit... Pres/Newsletter Editor - Bay Area RVators ________________________________________________________________________________
Date: Sep 02, 1998
Subject: Re: Nibbler attachment for power drill
Mitch, For $100.00 you can purchase an Jap Import Nibbler with 2 additional set's of cutting blades, and it does a great job. I looked at the drill attachment in Oshkosh, but when I got the price it just was not worth it. BSivori(at)Aol.Com N929RV ( Reserved ) Closed Wings ________________________________________________________________________________
Date: Sep 02, 1998
toni, thats the only yoke i've used since i started my 6a, emp and wings almost complete, never needed the 1 1/2 yoke yet. hope this helps good luck scott winging it in tampa ________________________________________________________________________________
Date: Sep 02, 1998
Subject: Feedback on the step into a 6A
Some 6A's have the step some don't. What is the feedback for putting steps to get into the 6A?Personally I would prefer not to put a step or two on however if it is difficult for most paople to get into the aircraft then I need to install them. Anybody care to comment? Bob Claypool, Fresno, CA RVQ6A ________________________________________________________________________________
Date: Sep 02, 1998
From: Dr Carol Richards <crcar(at)cc.newcastle.edu.au>
Subject: Re: Abrasives
I've had discussions with several people regarding suitable abrasives to be used on aluminum aircraft. I did check the archive, but did not find an extensive response to the question. How about input from listers to the following: 1. Aluminum oxide 2. Silicon carbide 3. 'wet or dry' (usually silicon carbide?) 4. 'carborundum' paper - is this silicon carbide, corundum (#9 on Moh's hardness scale; mineral for sapphire and ruby) or other? 5. Garnet paper 6. Scotchbrite - red, green, gray Sam (I hope I haven't started a primer war) Richards, RV-6 Newcastle, Australia ________________________________________________________________________________
Subject: RV-4 O-320 160 HP Wooden Prop??
Date: Sep 02, 1998
John, Which prop do you have? I have a Sensenich W68T6EM-76 wood prop that I used on a 150 HP Wittman Tailwind. I was never able to get enough RPM out of it. I'm wondering how it would do on a 160 HP RV-6. What static RPM, cruise RPM and speeds are you getting? Thanks, Bob, San Antonio RV-6; -----Original Message----- From: John Kitz [SMTP:jkitz(at)greenapple.com] Sent: Tuesday, September 01, 1998 7:44 PM To: rv-list(at)matronics.com Subject: Re: RV-List: RV-4 O-320 160 HP Wooden Prop?? > How about a wooden prop for an RV-4 with a 0-320/150 horse engine Hi Bob; I just love my Sensenich wood prop. Great performance in a -4 with 150hp. John Kitz N721JK Ohio 250 hours ________________________________________________________________________________
Date: Sep 02, 1998
From: "Bradley Kidder, Jr." <sparksnmagic(at)earthlink.net>
Subject: Re: Feedback on the step into a 6A
Bob: I was going to put steps onto my -6A (when I get to that point) but Denis Walsh changed my mind... He uses what he calls his "Zero Drag Step" -- a short, plastic (no appreciable weight) step stool that he leaves upside down in his baggage area. When he needs it, he'll get it out and use it; when he doesn't, it doesn't cost anything to ride along and doesn't sap you of drag/speed. And, as he also pointed out, using it would put you on the passenger side where you can do the gentlemanly thing (like offering your passenger a hand on/off the wing) when flying with your sig-other. That's my spin on the step. Bradley W. Kidder, Jr. sparksnmagic(at)earthlink.net ICQ# 11770815 URGENT MESSAGES: pagekidder(at)bigfoot.com ________________________________________________________________________________
Date: Sep 02, 1998
Our 6A which has been flying since May does not have steps. Did not want to have anything that might create extra drag. I am five four and manage to boost myself up onto the wing okay but some people that are not so nimble may have problems. It is an easy climb for someone much taller. BTW, we now have over 50 hours on our baby and we're loving every minute. Cathy Lamport Nepean, Ontario, Canada > > >Some 6A's have the step some don't. What is the feedback for putting steps to >get into the 6A?Personally I would prefer not to put a step or two on however >if it is difficult for most paople to get into the aircraft then I need to >install them. Anybody care to comment? Bob Claypool, Fresno, CA RVQ6A > > > > > ________________________________________________________________________________
Date: Sep 02, 1998
Subject: RV Fly-In
Just a reminder on the next RV Fly-In at Lebanon, TN (M54, 20 miles east of Nashville) October 3-4. As long as the weather holds, we should have a minimum of 35 RV's in attendance (based on our experience from the last two years), hopefully more since we are putting a blitz on the advertising. Lunch will be available both days with a dinner scheduled for Saturday night. Hotel and rental car information available on request. For those interested in some stick time with Mike Seager, I only have three slots remaining open for Friday morning: 9:00, 10:15, and 11:30. Let me know if your interested. For those who missed the opportunity to fly with Mike, you may be able to twist an arm or two for a flight with someone else. d:^) Any questions, please let me know. Dave Hudgins RV-6A Nashville ________________________________________________________________________________
Date: Sep 02, 1998
Your short legged passengers will thank you and the airplane will suffer less abuse from people trying to board. And this aging, short legged, overweight pilot has one for his side too, although I'm hedging on installing it because of the added weight, drag, etc., even if it is minimal. The archives has some more info on this. Les Williams/RV-6AQ/Tacoma WA (still baffling) >Some 6A's have the step some don't. What is the feedback for putting steps to get into the 6A?Personally I would prefer not to put a step or two on however if it is difficult for most paople to get into the aircraft then I need to install them. Anybody care to comment? Bob Claypool, Fresno, CA RVQ6A ________________________________________________________________________________
Subject: Rv 4 For Sale
Date: Sep 02, 1998
For Sale 1995 RV-4 185 TTSN , 0320 D1A 160 HP, 185TTSN , Hartzell C/S Prop 185 TTSN, K/N Air Filter, Stainless exhaust pipes with crossover . Single heater muff. Carburetor heat. Alternator cooling tube, Magneto cooling tubes, Piper oil cooler, Fuel primer. Terra 760D Com ,Terra 250D xpdr ,Apollo 360 moving map GPS ,ELT , PSII 1000 intercom, Vertical card compass, Altimeter, VSI ,Electronics International CHT EGT OAT , Oil Pressure, Fuel pressure, Amp/Volt meter, Electronic Tach, Lighting on All instruments with dimmer switch. Navigation Lights, Rear position light, Strobes on wing tips, Dual landing Lights enclosed in wing tips, Electric Flaps, Locking canopy (keyed same as ignition), Wood stick grip, Cabin heat with front and rear outlets, Two fresh air vents located on canopy skirt. Professional Paint, White with Blue stripping, Interior panels light Grey with medium Grey Leather seats Temper foam, Dark Gray Carpet , Firewall insulation ,CD player This is a very nice plane, always kept in a hanger and professionally maintained. All avionics purchased new November 1996 and installed professionally. All plans and instrument documentation. Complete Logs Cruise 187 mph @ 8.5 gph Annual due 8/98 $55,000.00 Price includes 8/98 annual (yet to be inspected) Tony Partain 314-894-0828 Saint Louis MO ________________________________________________________________________________
Date: Sep 02, 1998
Alivic(at)wport.com wrote: > > > Is a 4" deep squeezer yoke needed in the construction of an RV. > > Tony Livic RV8 tail > alivic(at)wport.com Tony, Yes it is, along with a no-hole yoke, and a longeron yoke. I have two other friends building and we've got the three between us and swap as needed. This keeps the cost of the yoke collection down. Ed Cole RV6A Fuse skins ________________________________________________________________________________
Date: Sep 02, 1998
Subject: Re: Throttle Brackett..
John Hughes wrote: > > > Hi gang! > I had a question about the throttle/mixture brackett used on > the new 0-360A1A > with a precision airmotive carb supplied with the new engines from Van's.I > did buy the brackett that Van's sells but it doesn't look right. Anybody > have a slam dunker set up? > I'm sure this is not the first time this has come up..How about cable > lenghts for the throttle,mixture,and prop..Any thoughts? > > Thanks, John Hughes > RV-6 > N164JH (reserved) > So > Cal, Hookin things up!! > > Oshkosh 99 or bust!! > > Talk to GV . I believe his dwgs. are on Sam Buchanan's web page. Ed Cole RV6A Fuse skins ________________________________________________________________________________
Date: Sep 02, 1998
A local builder, Charlie Winn, uses an empty 1 gallon can as a step for his 6A. It has a long string handle so he can place and retrieve it from the wing. Just had his plane painted and they did the can to match, complete with non-slip on the top. Cute, practical and no drag. Greg Young RV6 N6GY (reserved) finishing kit Some 6A's have the step some don't. What is the feedback for putting steps to get into the 6A?Personally I would prefer not to put a step or two on however if it is difficult for most paople to get into the aircraft then I need to install them. Anybody care to comment? Bob Claypool, Fresno, CA RVQ6A ________________________________________________________________________________
Date: Sep 02, 1998
bubble! Hal, Got no ideas on your truly wierd canopy-stretch other than to try clecoing the available holes in different sequences to try and get a fit. I got the photos and they are great. There was no return address on the envelope so please send me your address so I can sent some $. I am going to do the rear skirt in fibreglas and today will be the big day. Jim New Mexico ________________________________________________________________________________
Date: Sep 02, 1998
> What is the feedback for putting steps to > get into the 6A? I put a step on the right side, not the left. Why, because I am aware of the need to take the big step to get in and out. My passengers may not be, may forget, or may just have trouble with it. What convinced me of this was by looking at Van's 6A demonstrator a few years ago at Oshkosh. They had just put the step in their own plane, and it was apparent why. The root of the flap was in bad shape from all of the failed attempts of riders to get in and out. The RVs do not have real robust flaps. Some otherwise well meaning person stomping on it while trying to get in or out of your airplane 1000 miles from home can really ruin your trip. I view the step as cheap insurance. It does make things easier for the not-so-nimble too. Andy Gold RV-ation Bookstore http://www.rvbookstore.com ________________________________________________________________________________
Date: Sep 02, 1998
From: Joe Larson <jpl(at)showpg.mn.org.showpg.mn.org>
> > Some 6A's have the step some don't. What is the feedback for putting steps to > get into the 6A?Personally I would prefer not to put a step or two on however > if it is difficult for most paople to get into the aircraft then I need to > install them. Anybody care to comment? Bob Claypool, Fresno, CA RVQ6A Bob -- In a -6, you can get by without them, although shorter people have a bit of a problem. In a -6A, you probably need them. Because the nose isn't pointing up in the air, the trailing edge is higher off the ground and it's a pretty good step up. If you're at all tall, you might not need one on your side. But you'll want one for your passengers. If you're going to allow shorter pilots to fly your airplane, you'll want both. All this according to what the guys at Van's told me when I ordered my fuselage. -Joe ________________________________________________________________________________
Date: Sep 02, 1998
What are the +\- of using a varister instead of a diode to shunt the EMF of a contactors collapsing field? Tom De Winter ________________________________________________________________________________
Date: Sep 02, 1998
Subject: Re: Rv 4 For Sale
Tony, Cant speak for anyone else on the list, but I am certainly aware of the fact that you have an airplane for sale. I have recieved this for sale notice at least 6 times in the last 3 weeks. Apparently nobody on the list is buying at the moment. Think you could scale back to maybe once a month on the advertising? There has been some discussion in the past regarding advertising on the list (though I didnt see anything in the monthly policy statement). Perhaps Matt could address this for new listers? Mike Wills RV-4(fuse) willsm(at)manta.spawar.navy.mil > >For Sale 1995 RV-4 185 TTSN , 0320 D1A 160 HP, 185TTSN , Hartzell C/S Prop ________________________________________________________________________________
Date: Aug 30, 1998
Dr Carol Richards wrote: > > I've had discussions with several people regarding suitable abrasives to be used > on aluminum aircraft. > Sam (I hope I haven't started a primer war) Richards, RV-6 Newcastle, Australia Your question makes me worry. Any of the abrasives you mention will quickly remove the thin layer of pure aluminum from the ALCLAD skin, leaving it completely dependent on applied surface treatments for corrosion prevention. The question is, "Where do you intend to apply such an abrasive material and why?" There are a few places where you should, e.g., where you are applying Pro-Seal, and a few places where you must, e.g., where you sand a sharp edge, but, generally, it is something to be avoided. Best wishes, Jack Abell Los Angeles RV-6A N333JA (Reserved) ________________________________________________________________________________
Date: Sep 02, 1998
<< I had a question about the throttle/mixture bracket used on the new 0-360A1A with a precision airmotive carb supplied with the new engines from Van's.I did buy the bracket that Van's sells but it doesn't look right. Anybody have a slam dunker set up? I'm sure this is not the first time this has come up..How about cable lengths for the throttle,mixture,and prop. >> We've gone this route before and this entire discussion is captured in the archives for posterity. Let me know if you have trouble finding it. -GV ________________________________________________________________________________
Date: Sep 02, 1998
This makes sense to me and my wrinkled up brain. I remember how snow used to form smoothly on the upwind side of something and do all sorts of neat drifting on the downwind. hal ________________________________________________________________________________
Date: Sep 02, 1998
> Is a 4" deep squeezer yoke needed in the construction of an RV. It seems like whenever this comes up you get a number of differing opinions. I guess everyone has their own idea of what is "needed" and what is a luxury. Interestingly, Van built his first RV without the benefit of even a hand squeezer. But I digress.... here's my preference in order 1) 2 1/2" 2) thin-nose, no-hole 3) offset, or "longeron" 4) 4" The reason I like the 2 1/2" more than the 4" is that it is more likely to be helpful in tight places where it is difficult to get with a gun/bucking bar. The 4" is more likely to be useful on places where you could get a bucking bar anyway. Also the 2 1/2" one is lighter and easier to handle for everyday work. Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com ________________________________________________________________________________
Date: Sep 02, 1998
They are also a BIG job to fit. hal ________________________________________________________________________________
Date: Sep 02, 1998
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
> >What are the +\- of using a varister instead of a diode to shunt the EMF of a >contactors collapsing field? > >Tom De Winter MOVs are harder to find in low voltage ratings. I have to order our stock in from Digikey. MOVs are not polarity sensitive, it doesn't matter how your wire them in. I'm currently REPLACING the MOVs on our wiring diagrams with diodes. Easier to get, a little tougher to mount but not much, and you have to watch polarity. We'll publish, "Dealing with Those Pesky Diodes" on our website as soon as I get Rev 8 to printers (maybe tomorrow morning?). Starter contactors we stock have the diode built in so that's one less installation to make. Bob . . . AeroElectric Connection //// (o o) ==========o00o=(_)=o00o========== < If you continue to do > < What you've always done > < You will continue to be > < What you've always been. > ================================= ________________________________________________________________________________
Date: Sep 02, 1998
bubble! Hi Jim, Glad you enjoyed the photos. They are only 36 cents each - high quality finishing tho. Hal Kempthorne 2578 Elliot Ct Santa Clara, CA 95051 ero (well, the forward voltage drop of the diode which is usually around 0.7V) and a metal oxide varistor (MOV) doesn't clamp until tens or hundreds of volts since most are designed for clamping spikes on telephone lines and/or power lines. For your relays/contactors the diode is the right answer. Brian Lloyd Lucent Technologies brian(at)lcp.livingston.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6399 - voice +1.530.676.3442 - fax O- tening to this guy's pitch - he was good. Shelby in Nashville. ________________________________________________________________________________
Date: Sep 02, 1998
No doubt the specialized yokes would be "nice" to have; however, if the tool budget is a little tight, you can leave the fancy yokes at the store and get by just fine. I am nearing the finish kit phase on the RV6 and have used only the standard 3" yoke. For the price of the special yokes, you can buy an edge-former tool, a set of tank dimple dies, and several 2" ScotchBrite wheels for your diegrinder. Sam Buchanan sbuc(at)traveller.com "The RV Journal" http://www.ath.tis.net/~sbuc/rv6 Edward Cole wrote: > > > Alivic(at)wport.com wrote: > > > > > > Is a 4" deep squeezer yoke needed in the construction of an RV. > > > > Tony Livic RV8 tail > > alivic(at)wport.com > > Tony, > > Yes it is, along with a no-hole yoke, and a longeron yoke. > I have two other friends building and we've got the three between us > and swap as needed. This keeps the cost of the yoke collection down. > > Ed Cole > RV6A Fuse skins ________________________________________________________________________________
Date: Sep 02, 1998
> Some 6A's have the step some don't. What is the feedback for putting steps to > get into the 6A? After spending the week at Sun-n-fun manning the booth a couple of years ago, I would recommend anyone with an -A model get the step at least on the passenger side. Unless you are going to restrict the right seat to only a fit, well trained few, the risk of flap rash will be a lot higher without it. As for the pilot's side, you probably don't need it but I'd try it out before deciding if you haven't already. Randall ________________________________________________________________________________
Date: Sep 02, 1998
Subject: RV vs Cozy trade-offs
After chickening out of a plan to build a Long-Eze many years ago, I am once again thinking about building a plane. 2,500 hours - I must be crazy. Please tell me it helps. Anyway, my question is - RV-6A vs Cozy IV. I am sure plenty of others on this list went though a similar decision process before committing to the RV and I wonder if any of you would share some of those thoughts with me. I see the trade space defined in terms of construction complexity, kit / part cost, performance, operating / life cycle cost, reliability / safety, ease of operation / tolerance of pilot errors and lack of experience. My evaluation so far is with a + being good or better, and a - being not as good. Construction complexity RV (metal) - medium (+) Cozy (composite) - high (-) Work space needed Less for the RV, so it's a (+) Kit cost Similar (0) although you can buy the engine through Vans for a discount, so the RV may be a (+) here. Performance (speed, fuel consumption) Similar (0) Life cycle cost assuming the same engine Fuel RV a slight plus Storage /hangar RV a slight plus Engine and prop Similar (0) Reliability / safety Composites are strong Cozy (+) Corrosion susceptibility Cozy (+) Tolerance to being trapped out in bad weather RV (+) I think Potential for failure due to unseen problem (fuel seepage) RV (+) Ability to put it down in a field in an emergency with minimum damage and risk. RV (+) Ease of operation RV (+) I think # of seats Cozy (+++) So far I get about a similar score for both in terms of the really important stuff, with one big minus for the Cozy (the amount of difficulty associated with building a glass plane). I probably haven't scratched the surface on all the issues, but would like to reach a decision of this magnitude via a well reasoned process. I would appreciate any comments or suggestions. It certainly won't hurt my feelings if anyone disagrees with me. (and since this is an RV list, I am sure some will). Thanks. ________________________________________________________________________________
Date: Sep 02, 1998
Big is relative. It took about 3 hours to do both. How long will it take to build a new flap? The critical thing is to make sure it's back far enough to clear the flap. Easy to do when you mount the wings for the gear mounts, install the flap and mark it on the fuse. Don Mack RV-6A Fuselage http:\www.flash.net\~donmack They are also a BIG job to fit. hal ________________________________________________________________________________
Date: Sep 02, 1998
Subject: RV Pig Roast Fly-in
I am having an RV/Experimental/homebuilt pig roast at my hangar on sunday October 11 at 11 am. All flyins, RV or homebuilders are welcome. Im located in Sparta, IL (Hunter Field) (SAR). We'll be cooking a 200 lb hog saturday night so anyone wanting to come early and camp is welcome. Bring a lawnchair or something to sit on and side dishes are not necessary. The pig is free and soft drinks are available from the FBO. Sandwiches begin 11 am on sunday, first come first serve. RSVP direct is not necessary but would be nice. chet razer razer(at)midwest.net ________________________________________________________________________________
Date: Sep 02, 1998
Subject: Re: RV vs Cozy trade-offs
I have two friends that have built Cozys', One hardly ever fly's his (?????? Don't know why) And the other has been working on his for years and years. My point is I got to see some of the construction techniques and I came to the conclusion that I would NEVER buy a glass plane that someone else has built. There are too many ways to hide shoddy workmanship and unless you put it on a scale, you really don't know what it weighs. (Could have been overbuilt easily). I don't think I'm alone in this feeling. I would think that your resale for an RV done with reasonable craftsmanship is going to be far more valuable in the long run that putting all that time and money into something that sooner or later you will sell and take a loss on. I originally chose the RV-6 based on it's long term value and then found out all the other GREAT characteristics of the design. I'm glad I chose the way I did and I'm not even flying yet! AL > >After chickening out of a plan to build a Long-Eze many years ago, I am once >again thinking about building a plane. 2,500 hours - I must be crazy. Please >tell me it helps. Anyway, my question is - RV-6A vs Cozy IV. I am sure >plenty of others on this list went though a similar decision process before >committing to the RV and I wonder if any of you would share some of those >thoughts with me. I see the trade space defined in terms of construction >complexity, kit / part cost, performance, operating / life cycle cost, >reliability / safety, ease of operation / tolerance of pilot errors and lack >of experience. My evaluation so far is with a + being good or better, and a - >being not as good. > >Construction complexity RV (metal) - medium (+) > Cozy (composite) - >high (-) > >Work space needed Less for the RV, so it's a (+) > >Kit cost Similar (0) although >you can buy the > engine through >Vans for a discount, so > the RV may be a >(+) here. > >Performance (speed, fuel consumption) Similar (0) > >Life cycle cost assuming the same engine > Fuel RV a slight plus > Storage /hangar RV a slight plus > Engine and prop Similar (0) > >Reliability / safety > Composites are strong Cozy (+) > Corrosion susceptibility Cozy (+) > Tolerance to being trapped out > in bad weather RV (+) I think > Potential for failure due to > unseen problem (fuel seepage) RV (+) > Ability to put it down in a field in > an emergency with minimum > damage and risk. RV (+) > >Ease of operation RV (+) I think > ># of seats Cozy (+++) > >So far I get about a similar score for both in terms of the really important >stuff, with one big minus for the Cozy (the amount of difficulty associated >with building a glass plane). I probably haven't scratched the surface on all >the issues, but would like to reach a decision of this magnitude via a well >reasoned process. I would appreciate any comments or suggestions. It >certainly won't hurt my feelings if anyone disagrees with me. (and since this >is an RV list, I am sure some will). > >Thanks. > > > > > > ________________________________________________________________________________
From: "Robert Acker" <robert.acker(at)ingrammicro.com>
Date: Sep 02, 1998
>reasoned process. I would appreciate any comments or suggestions. It >certainly won't hurt my feelings if anyone disagrees with me. (and since this >is an RV list, I am sure some will). > >Thanks. The RV-6 and the Cozy are both great aircraft, but fill completely different roles: Cozy - Cruise three or four souls on long x/c's, fast and comfortable. Requires long, flat runways. Limited (if any) aerobatics. Longer buildtime, layup work affected by ambient temp's, may develop allergic reaction to resins. RV - Two people. Short, rough strips okay. Sport aerobatics. Build in all temperatures (except for canopy ), no allergic reactions. First decide what mission profile you want to satisfy, second decide what kit aircraft fullfill that role, then sweat the details (i.e. construction method, time to build, etc). My $0.02 worth...Rob (RV-6Q). ________________________________________________________________________________
Date: Sep 02, 1998
From: Mike Thompson <michaelt(at)AUSVMR.VNET.IBM.COM>
News-Software: UReply 3.1 In a previous message, it was written: > >reasoned process. I would appreciate any comments or suggestions. It >certainly won't hurt my feelings if anyone disagrees with me. (and since this >is an RV list, I am sure some will). > >Thanks. Biggest question is: How badly do you want those extra seats? When I needed the seats, I didn't have the money. Now that I have the money (sort of), I don't need the seats (one kid out of the house, other in college). A person's airplane needs change through the years - kind of like their cars. I don't need the station wagon any longer... the sports car is more attractive. Station wagons I can rent when necessary. :) all the "kids" out there are asking themselves: "What's a "station wagon"? Mike Thompson Austin, TX. -6 Emp, drilling elevators, wings on the waaayyy! ________________________________________________________________________________
Date: Sep 02, 1998
Subject: RV Hangar Party - N85
This Saturday (September 5th) is the annual RV hangar party and Alexandria Field, Pittstown, NJ. Bring your RV and tell lies to us. We provide the food and drink. Gary Corde RV-6 N211GC - NJ ________________________________________________________________________________
Subject: Fwd side skins- 6A
Date: Sep 02, 1998
I checked my fuselage last night and found that the bottom skin was over the curved portions of the side skins. Steve Soule Huntington, Vermont -----Original Message----- From: Stephen J. Soule Sent: Tuesday, September 01, 1998 8:24 AM To: 'rv-list(at)matronics.com' Subject: RE: RV-List: Fwd side skins- 6A The curved aft end goes OVER the center bottom skins. The rest I don't know. I left the hinge(s) undrilled thinking that I should have the cowl on hand before drilling. I hope to finesse the issue of dimpling or countersinking the holes later. Probably a mistake, but I hope not. Steve Soule RV-6A fuselage floors -----Original Message----- 1- Does the curved aft end go under the center bottom skins (676/677)? 2- do I drill the fwd hinge holes now. If I don't now , how will I deburr & demple after they are on? I am planning on back drilling the henge & spacer later. 3- Want to run a line (for wires) thru the 604,605, & 606. What type if tubing do youall recommend? ________________________________________________________________________________
Date: Sep 02, 1998
Some 6A's have the step some don't. What is the feedback for putting steps to >> get into the 6A? I've got a step only on the right side. I would do it again, it's a great aid for kids and those unfamiliar with RV's. The plane flies plenty fast without worring about a mile or two difference on speed. I do have a couple of suggestions, and I'm sure a lot of you guys with steps may second this. 1. Lower the flaps prior to getting in/out. Lowers the risk of stepping on them, especially when getting out. You can placard the heck out of the flap with "NO STEP" decals, but if the flap is sticking out there, eventually someone will walk on it. It's still a pretty good stretch to the step from the wing with the flap up, a little hard to see. 2. Watch the passanger weight using the step. The other day, I took a guy to breakfast who probably weighed in around 250 (before breakfast). After I jumped up on the pilots side wing standing there waiting for him to get in, he steps on the right step. Yup! You guessed it, the tail came down and hit the tie down ring, BONG! OOPS, sorry! Shouldn't have had that last piece of sausage. This is with an O-360 and C/S prop too! So watch it! Dave RV-6A Nashville ________________________________________________________________________________
Date: Sep 02, 1998
>> Ability to put it down in a field in >> an emergency with minimum >> damage and risk. RV (+) I was never "religious" in the plastic vs. metal argument BEFORE I put my RV-4 in the trees at Chapel Hill and walked away. Landing at 50mph and the energy absorbing crumple effect of the aluminum construction made me a true believer. The fact I'm writing this at all is proof enough for me... Richard E. Bibb RV-4 N144KT - in rebuild - will fly by 2000 Oak Hill, VA rbibb(at)fore.com ________________________________________________________________________________
Subject: RV6+ at Osh?
Date: Sep 02, 1998
Hi all, so, has anyone seen or ridden in, or flown the 4-place "RV-6+"? fun to fly? Horrible? just curious, as 3 friends might be more fun than 1. -Ian ________________________________________________________________________________
Date: Sep 02, 1998
On Wed, 2 Sep 1998, Mike Wills wrote: > > Tony, > Cant speak for anyone else on the list, but I am certainly aware of the > fact that you have an airplane for sale. I have recieved this for sale > notice at least 6 times in the last 3 weeks. Apparently nobody on the list > is buying at the moment. Think you could scale back to maybe once a month > on the advertising? > There has been some discussion in the past regarding advertising on the > list (though I didnt see anything in the monthly policy statement). Perhaps > Matt could address this for new listers? > > Mike Wills > RV-4(fuse) > willsm(at)manta.spawar.navy.mil > > > > >For Sale 1995 RV-4 185 TTSN , 0320 D1A 160 HP, 185TTSN , Hartzell C/S Prop Mike, Tony has lowered the price of his RV-4 since his last post. I more than welcome future posts if his trend continues. As a person debating whether to build or buy, the forsale posts are beneficial to me. Jeff Moore RV4/6A (planning and dreaming stage) jjmoore(at)tamu.edu ________________________________________________________________________________
Date: Sep 02, 1998
It sounds like "appropriate" advertising but you're right on the frequency of the ad appearing on the list. People on the list are always buying, that price is just a little too steep for most of us..... > >Tony, > Cant speak for anyone else on the list, but I am certainly aware of the >fact that you have an airplane for sale. I have recieved this for sale >notice at least 6 times in the last 3 weeks. Apparently nobody on the list >is buying at the moment. Think you could scale back to maybe once a month >on the advertising? > There has been some discussion in the past regarding advertising on the >list (though I didnt see anything in the monthly policy statement). Perhaps >Matt could address this for new listers? > >Mike Wills >RV-4(fuse) >willsm(at)manta.spawar.navy.mil > >> >>For Sale 1995 RV-4 185 TTSN , 0320 D1A 160 HP, 185TTSN , Hartzell C/S Prop > > > > > -- Scott VanArtsdalen svanarts(at)jps.net "The essence of character is doing what's right, even when nobody's looking." - J. C. Watts ________________________________________________________________________________
Date: Sep 02, 1998
Subject: RV-6A Step
One RV-6A owner told me his steps lost 5MPH for him after he put them on. I just today received a folding stool from Sporty's so my wife could more easily alight from the right wing. Looks as if it will work fine:I saved the 5MPH and only need the stool when she or a similiar non-athlete type goes with me. Try it.('tho I think the cost is about the same as a Van's step!) ________________________________________________________________________________
Date: Sep 02, 1998
>They are also a BIG job to fit. >>Big is relative. It took about 3 hours to do both. How long will it take to >>build a new flap? I work slower than Don, and it took me about seven hours. That's for all the finish work (persuading it to fit flush on all sides), bolting in, and drilling/clecoing. I think it turned out great and Dennis Persyk had calculated the reduction in speed for both steps to be 0.3 MPH at 185 MPH, so people talking about "all that extra drag" are full of hooey. I'm also going to fabricate a VS strake that comes forward more towards the back of the sliding canopy. Anything to make it look more like a Marchetti SF-260 (sorry Van!) Anybody want to make flying tip lockers or fuel tanks to complete the look? ;) ________________________________________________________________________________
Date: Sep 02, 1998
One big factor will be the fact that the construction of a composite aircraft must be done under temperature controlled conditions. An aluminum airplane is not so sensitive. Steve Soule Huntington, Vermont (often pretty cold) -----Original Message-----After chickening out of a plan to build a Long-Eze many years ago, I am once again thinking about building a plane. ________________________________________________________________________________
Date: Sep 02, 1998
> Mike, > > Tony has lowered the price of his RV-4 since his last post. I more than > welcome future posts if his trend continues. As a person debating whether > to build or buy, the forsale posts are beneficial to me. > > Jeff Moore > RV4/6A (planning and dreaming stage) > > jjmoore(at)tamu.edu Jeff, Kudo's to you Jim Nolan N444JN ________________________________________________________________________________
Date: Sep 02, 1998
I've gone through a similar analysis of the Europa, Glastar, Pulsar, Glassair, and the RV-8a and will choose the RV (I was able to fly in three of the five). One item you might want to add to your list . . . can you complete the project? It looks like RV's, in general, get finished. Quick-build RV's even more so. Recent issues of Kitplanes (I think that's where I saw it, perhaps Sport Aviation) show number of completions . . . and the RV-series get an "A+". I attended a Sportair workshop on composites, one of the attendees was a Cozy builder, and it sounded like he had quite a monster ahead of him (this was two years ago--perhaps they have more items pre-fabricated, etc.). It's hard to say. I would think either choice will give you a lot of headaches and heart burn--and a fantastic amount of fun and experiences. Your only mistake would be to want to build something--not going ahead--and then ending up with the one thing none of us want as we enter old age . . . "regrets". Rick Jory Highlands Ranch, CO Potential RV-8a builder (awaiting Dec. Sportair course on the Van's series) -----Original Message----- From: Militch(at)aol.com <Militch(at)aol.com> Date: Wednesday, September 02, 1998 12:51 PM Subject: RV-List: RV vs Cozy trade-offs > >After chickening out of a plan to build a Long-Eze many years ago, I am once >again thinking about building a plane. 2,500 hours - I must be crazy. Please >tell me it helps. Anyway, my question is - RV-6A vs Cozy IV. I am sure >plenty of others on this list went though a similar decision process before >committing to the RV and I wonder if any of you would share some of those >thoughts with me. I see the trade space defined in terms of construction >complexity, kit / part cost, performance, operating / life cycle cost, >reliability / safety, ease of operation / tolerance of pilot errors and lack >of experience. My evaluation so far is with a + being good or better, and a - >being not as good. > >Construction complexity RV (metal) - medium (+) > Cozy (composite) - >high (-) > >Work space needed Less for the RV, so it's a (+) > >Kit cost Similar (0) although >you can buy the > engine through >Vans for a discount, so > the RV may be a >(+) here. > >Performance (speed, fuel consumption) Similar (0) > >Life cycle cost assuming the same engine > Fuel RV a slight plus > Storage /hangar RV a slight plus > Engine and prop Similar (0) > >Reliability / safety > Composites are strong Cozy (+) > Corrosion susceptibility Cozy (+) > Tolerance to being trapped out > in bad weather RV (+) I think > Potential for failure due to > unseen problem (fuel seepage) RV (+) > Ability to put it down in a field in > an emergency with minimum > damage and risk. RV (+) > >Ease of operation RV (+) I think > ># of seats Cozy (+++) > >So far I get about a similar score for both in terms of the really important >stuff, with one big minus for the Cozy (the amount of difficulty associated >with building a glass plane). I probably haven't scratched the surface on all >the issues, but would like to reach a decision of this magnitude via a well >reasoned process. I would appreciate any comments or suggestions. It >certainly won't hurt my feelings if anyone disagrees with me. (and since this >is an RV list, I am sure some will). > >Thanks. > > > > > > > ________________________________________________________________________________
Subject: Re: RV6+ at Osh?
Date: Sep 02, 1998
Ian, If you get any replies, would you please forward them to me as I am also interested in the 6+ version of the RV series.....Thanks. Paul Bilodeau paul.and.ien(at)worldnet.att.net ---------- > From: Ian Kerr <ikerr(at)macromedia.com> > To: rv-list(at)matronics.com > Subject: RV-List: RV6+ at Osh? > Date: Wednesday, September 02, 1998 5:14 PM > > > Hi all, > > so, has anyone seen or ridden in, or flown the 4-place "RV-6+"? > > fun to fly? Horrible? just curious, as 3 friends might be more fun than 1. > > -Ian > > > > ________________________________________________________________________________
Date: Sep 02, 1998
Tony/listers, It appears from the consensus both on and off list that I was off base on this and that there is interest in this sort of advertisement. Apologies to all for bringing this up on list. I should have mailed my comments directly to Tony. Lets end it here and avoid another flame war. Mike Wills RV-4(fuse) willsm(at)manta.spawar.navy.mil > >For Sale 1995 RV-4 185 TTSN , 0320 D1A 160 HP, 185TTSN , Hartzell C/S Prop ________________________________________________________________________________
Date: Sep 02, 1998
Hal Kempthorne wrote: > > > They are also a BIG job to fit. Nah, If you do it while you are building, it's really not a big deal at all. It would be a big job if you decided you wanted one later. Andy would appear to be a type of construction which you enjoy enough to complete the plane. Join the EAA if you have not already and work on several different types of planes in various stages of construction. You will change your opinion of each as you learn to appreciate each material. Performance is much more than how fast a plane will go. You may want to start with a plane that flys slowly but can land almost anywhere. Your checklist is a good idea but appears to compare apples and oranges. My suggestion is to decide what type of constuction you want use, then the degree of complexity and expense. If you decide you want to build a metal aircraft you will probably decide, as have many, that the Vans Aircraft offer much in the way of buildability and performance. Joe Walker Rebuilding Wreaked RV6 Houston, Texas ________________________________________________________________________________
From: "TERRY L BENZER" <TERRYBENZER(at)prodigy.net>
Subject: RE:hs-602
Date: Sep 02, 1998
When removing the flange to create the tongue so that you can bend the forward spar, how far back do you remove the flange? R-1 on 3-PP removed the distance and now says trim to fit. Also, on the hs-814 and hs-810 do the tapers start at the edge of the remaining flange? TIA, Terry #80800 ________________________________________________________________________________
Date: Sep 02, 1998
Greg Young wrote: > > > A local builder, Charlie Winn, uses an empty 1 gallon can as a step for his > 6A. It has a long string handle so he can place and retrieve it from the > wing. Just had his plane painted and they did the can to match, complete > with non-slip on the top. Cute, practical and no drag. > > Greg Young > RV6 N6GY (reserved) finishing kit > Listers, I know that weight and drag have their penalties, but I don't think anyone will lose that much speed with a couple of steps installed. If you weigh this against someone stepping on you flap or that bucket bouncing off you $3000 paint job, you can see the practicality. If your really concerned about reaching your destination 1 -2 minutes later than planned, leave 'em off! Ed Cole RV6A Fuse skins. ________________________________________________________________________________
Date: Sep 02, 1998
My wife can hardly stand an occasional smell of primer or paint. She would have gone balistic if she had to smell resin all the time. Put a plus by 'SMELL' for the RV-6. (A rose by any other name...) Frank Smidler ________________________________________________________________________________
Date: Sep 02, 1998
Subject: Re: Relay question
AcroII(at)aol.com wrote: > > > What are the +\- of using a varister instead of a diode to shunt the EMF of a > contactors collapsing field? > > Tom De Winter > Tom, A varistor is not a diode. The diode conducts in one direction only allowing the shunting action across the relay coil as it collapses. A Varistor changes its resistance with current flow. It would also allow current flow in both directions. Not a good idea in this application. Ed Cole RV6A Fuse skins ________________________________________________________________________________
Date: Sep 02, 1998
From: "Lynda K. Frantz" <LFrantz(at)compuserve.com>
Subject: Re: Angle-of-Attack
Having had 14 RV e-mail requests this week for information on how our Angle-of-Attack instrument works with out a vane or a probe and how it is installed, I thought I should explain. First a little background. 45.3% of fatal accidents in experimentals are due to stall/spins while only 28% for GA. Why the difference? Mostly, GA is required by FARs to have stall warners and experiments generally do not. AOA is the ultimate stall warner since any given airfoil always stalls at the same AOA called the critical AOA! Here is how it works. Two tiny pressure ports (.040" dia) are located on the wing, one on top and the other on the bottom. The ports measure the local wing loading. We also look at your pitot/static differential pressure (dynamic pressure). By dividing the wing loading by the dynamic pressure the resultant coefficient of pressure is known aerodynamically to vary uniquely with AOA. The AOA is self compensating and is the only instrument that is a true aerodynamic indicator. Just as there is an optimum AOA for all approaches there is also an optimum AOA for initial climbs, the best L/D, Vx, and maximum endurance regardless of weight, altitude, fuel load, temperature, etc. The AOA Professional includes a 4 color liquid crystal display, a voice warning system and has no protrusions or moving parts to ice up or slow you down. You my have seen it in the May 98 issue of Sport Aviation Better Way to Fly page 50-53. Until recently full range AOA instruments were not affordable at $22,000 and up but no longer. The AOA Professional lists for $1,450. For comparison, the simple A/C Spruce stall warner (buzzer) is $1,200. If you want more information please check our web at www.Lancair.net or contact me directly at Jim(at)Lancair.net or (612) 474-4154. ________________________________________________________________________________
Date: Sep 02, 1998
Subject: Re: RV Hangar Party - N85
In a message dated 9/2/98 2:24:08 PM Pacific Daylight Time, RV6junkie(at)aol.com writes: << RV hangar party and Alexandria Field, Pittstown, NJ. >> MOEJOE, are you listening??? This may be near you. NOTSO ________________________________________________________________________________
Date: Sep 02, 1998
Yes, I have recently ridden in the 6+. It is a beautiful flying airplane, lots of power and performance. If you want to enjoy rv performance, plus haul more, it will do the trick. ________________________________________________________________________________
Date: Sep 02, 1998
>A person's airplane needs change through the years - kind of like their >cars. I don't need the station wagon any longer... the sports car is more >attractive. Station wagons I can rent when necessary. > > >:) all the "kids" out there are asking themselves: "What's a "station wagon"? > That's kind of like a minivan, right? ;-) I know, I know. I've owned one of each. -- Scott VanArtsdalen svanarts(at)jps.net "The essence of character is doing what's right, even when nobody's looking." - J. C. Watts ________________________________________________________________________________
Date: Sep 02, 1998
<< What is the feedback for putting steps to get into the 6A? >> I've got one on each side of my 6A. I'm tall and leggy, my fiance is short and cute. Neither of us would give up the ease of the steps for the 3-5 mph speed increase. They make it easy to get things in and out of the plane without standing on the wing and leaning over (hard on my 90 yr old back). Also, we don't race. The 185 mph TAS cruise (60% power at 10,000 ft) is more than enough. If we want to get there faster, we leave earlier. -GV ________________________________________________________________________________
Date: Sep 02, 1998
I chose to put a step on the passenger side of RV6A C-GCTZ. Glad I did. If I am alone in the aircraft then I choose to enter from the passenger side. Stepping onto the wing without a step is a little harder than I expected. Bob B -----Original Message----- From: RClayp5888(at)aol.com <RClayp5888(at)aol.com> Date: Wednesday, September 02, 1998 8:11 AM Subject: RV-List: Feedback on the step into a 6A > >Some 6A's have the step some don't. What is the feedback for putting steps to >get into the 6A?Personally I would prefer not to put a step or two on however >if it is difficult for most paople to get into the aircraft then I need to >install them. Anybody care to comment? Bob Claypool, Fresno, CA RVQ6A > > > > > > ________________________________________________________________________________
Subject: RV Resale Market
Date: Sep 02, 1998
Hello All, A recent series of messages on an RV for sale got me going on something I've been curious about again. I have seen RVs for sale in Trade-A-Plane and other places for $50-70K routinely, but I have never heard of the actual sale price. There may already be some info on this previously, but I would be happy to post a summary of actual purchase prices if individuals will e-mail me offline with the price bought or sold for and some comments on the equipment/condition. I know I am very curious what the potential value of my project is, although hopefully it won't be for sale for many years. Thanks, Marcus mcooper(at)cnetech.com RV-6 weighed, FAA comes to see it next week:)! ________________________________________________________________________________
Date: Sep 02, 1998
Subject: Re: RV-4 O-320 160 HP Wooden Prop??
Robert D. Cabe wrote: > > > John, > > Which prop do you have? I have a Sensenich W68T6EM-76 wood prop that I used > on a 150 HP Wittman Tailwind. I was never able to get enough RPM out of it. > I'm wondering how it would do on a 160 HP RV-6. What static RPM, cruise RPM > and speeds are you getting? > > Thanks, > Bob, San Antonio > RV-6; > Bob; The first Sensenich wood prop I had on my 0-320 150 hp was a W68T6EM-80 and it would end up over 2900 rpm in cruise and I could get over 200mph out of it. It had a 2200 static . After an unfortunate accident, I ordered one with 2 inches more pitch, a W68T6EM7-82. I get 192 mph at low altitude checked with a gps. Static is 2100 rpm. It is not quite as fast but I feel I get off the ground about as fast as before. Fuel consumption going to OSH at 8500 feet was 8.6 gph measured for exactly 1 hour, 2600 rpm wide open at 21 mp. I had a headwind so I do not know the speed but was very heavy on that trip. The biggest difference I notice is the reduction in noise level with 200 rpm knocked off and reduced fuel consumption.. My wife used to hear me coming miles away, but no more. John Kitz N721JK Ohio ________________________________________________________________________________
Date: Sep 02, 1998
>A varistor is not a diode. The diode conducts in one direction only >allowing the shunting action across the relay coil as it collapses. >A Varistor changes its resistance with current flow. Not quite accurate . . . varistors are rated for their ability to respond to a voltage . . . like zener diodes. Their clamping actions are not quite as sharp as a diode, zener or "transorb" (a specialized form of zener) but they are commonly used just as I've described in our published diagrams and writings. >Not a good idea in this application. I was enamored of their use because they are NOT polarity sensitive and could not accidently be wired into the system backwards. In retrospect, a minor advantange compared to hastles of acquiring the parts. ________________________________________________________________________________
Date: Sep 02, 1998
>A diode clamps the reverse voltage spike right a zero (well, the forward >voltage drop of the diode which is usually around 0.7V) and a metal oxide >varistor (MOV) doesn't clamp until tens or hundreds of volts since most are >designed for clamping spikes on telephone lines and/or power lines. When you use MOV's DESIGNED to clamp telephone line and power line spikes, the voltage at which the device begins to absorb energy is indeed on the order of 200 volts. When you buy 14-v transorbs, the clamping voltage is about 20 volts. ________________________________________________________________________________
From: "Leslie B. Williams" <lesliebwilliams(at)email.msn.com>
Date: Sep 02, 1998
Hal, I added a step to my first -6A after it was built and I didn't think that it was a "big" job, but then I quess it depends on your definition of big. It did require removing the baggage floor on that side, but I've developed quite a knack for removing rivets, both AN and pop. Otherwise it was pretty easy. On my current -6AQ, I'm not riveting the baggage floors in until I have the wings on and make a final decision on putting in one or both. If someone isn't decided at all, this would be an option. > >They are also a BIG job to fit. > >hal ________________________________________________________________________________
Date: Sep 02, 1998
Ian and Paul, I spoke to one of the builders of the 6+ at MERFI last year. I will tell you what I found out from him. First off if you look at the wings it looks like they have been lengthened. There is a solid piece 10" or 12" wide between the outboard edge of the ailerons and the wing tips. Well they were originally going to build a clipped wing six and then decided instead to build a stretched six. They had already built the ailerons and some other mods to shorten the wings but had not clipped the spars so they just put the solid spacer in to bring the wings back to there original span. There is plenty of aileron left for control. They engineered an O-540 mount for the plane and to compensate for the heavier weight up front, they lengthened the aft fuselage 14" around the aft baggage bulkhead. To add some strength to this lengthened section they used heavier skins on the aft fuselage. The aft bagged bulkhead was opened up and reinforced for the passengers legs to fit further back into the fuselage. I personally don't see enough room for two avg. sized adults but you can fit a couple of kids back there with no problem. He also told me when I ask that they do not recommend ANY aerobatics in the aircraft and that the modifications as I recall were not thoroughly gone over by an aeronautical engineer. In conclusion, the gentleman I spoke with was very straight forward with answers and the workmanship was excellent. The last I saw of the plane it was "For Sale". Maybe I'll see it again at MERFI! (Sept. 12 & 13 at Marion, Ohio) Al Columbus, Ohio > >Ian, > >If you get any replies, would you please forward them to me as I am also >interested in the 6+ version of >the RV series.....Thanks. > >Paul Bilodeau >paul.and.ien(at)worldnet.att.net ________________________________________________________________________________
Date: Sep 02, 1998
>without standing on the wing and leaning over (hard on my 90 yr old back). >-GV Gary, What it this 90 Yr. old back BS? I'll bet 750 out of 800 guys on this list believe you! Now they think your an old man......your gonna have some explaining to do when you meet them in person. ;-) Al ________________________________________________________________________________
Date: Sep 02, 1998
Don wrote: > Big is relative. It took about 3 hours to do both. How long will it take to > build a new flap? Were you both using Avery Tools' new air powered step installer? I spent three hours laying it out! hal ________________________________________________________________________________
Subject: RV-8 tank skins
Date: Sep 02, 1998
Just a note to anyone about to drill their tank skins to the ribs and rear baffle. the manual does not say anything about it, but you can not drill the holes along the baffle from the second inboard rib to the root rib with the tank clecoed to the spar.If you do you will surely drill into the spar. Remove the assemblt from the spar to drill these holes. ________________________________________________________________________________
Date: Sep 02, 1998
Robert L. Nuckolls, III wrote: > > > >A varistor is not a diode. The diode conducts in one direction only > >allowing the shunting action across the relay coil as it collapses. > >A Varistor changes its resistance with current flow. > > Not quite accurate . . . varistors are rated for their ability > to respond to a voltage . . . like zener diodes. Their clamping > actions are not quite as sharp as a diode, zener or "transorb" > (a specialized form of zener) but they are commonly used just > as I've described in our published diagrams and writings. > > >Not a good idea in this application. > > I was enamored of their use because they are NOT polarity > sensitive and could not accidently be wired into the system > backwards. In retrospect, a minor advantange compared to > hastles of acquiring the parts. > > Sorry Bob, I was thinking of a thermistor! Ed Cole ________________________________________________________________________________
Subject: MN Annual Pig Roast and Fly-In
Date: Sep 02, 1998
Fellow Listers: The MN Wing of Van's AirForce would like to announce our annual Pig Roast and Fly-In. Details below... Minnesota Wing - Annual Fall Pig Roast and Picnic Saturday September 12, 1998 1:00 pm till...... Sky Harbor Airpark, Webster MN N 44 31.7, W 93 19.5 - or 215 degree radial 9.0 nm from FGT (115.7) Join the MN Wing for our annual September Pig Roast, Family Picnic and Fly-in. Our hosts this year will be Larry Winn and Kent VanMeter and all the great folks at Sky Harbor. Naturally our own Don Flander will be handling the cooking duties slaving over a hot cooker so we can indulge in the best slow simmered pork this side of Memphis. As always, please bring a salad or dessert. Pop, lemonade, and coffee will be furnished. The kitty will be out to help cover the costs of the pork and the port-a-potty. Naturally all flying RVs on the planet are cordially invited and everything else is always welcome. Please monitor 122.9 for traffic advisories and observe our aircraft marshallers. Safety is our primary concern so please use caution in the traffic pattern and on the ground. Note also that we will be gathering on the south side of the airport this year!! Bring the wives, husbands, kids, grammas and grandpas and enjoy a great day of RV fellowship! Directions: From Minneapolis/St. Paul go south on I-35 past Lakeville to the Elko, New Market exit #76 (County Rd 2). Go east to County Rd 42. Go south to County Rd 3 and turn right (west). Cross over I-35 and turn left at Canby. Drive south to 46th St. W (the airport will be on your right). Turn right and go west to Cass Ct. The picnic will be at Kent VanMeters hangar (second house on the right). Signs will be up, but if you become disorientated call Larry Winn at 612-652-2235. If you have any questions, please call me or email. Doug, pres, MN Wing ============ Doug Weiler Hudson, WI 715-386-1239 dougweil(at)pressenter.com ________________________________________________________________________________
Date: Sep 02, 1998
Got it Jim, but I have an aerobatics lesson at Sussex that morning, and a 2.5 hr drive each way. All the club's planes were reserved, so I gotta drive. I can't wait to have my own plane. If plans change, I will be there. Thanks for the heads up, Moe JNice51355(at)aol.com wrote: > > > In a message dated 9/2/98 2:24:08 PM Pacific Daylight Time, RV6junkie(at)aol.com > writes: > > << RV hangar party and Alexandria > Field, Pittstown, NJ. >> > MOEJOE, are you listening??? This may be near you. > NOTSO > ________________________________________________________________________________
From: "Daniel H. Morris III" <Morristec(at)icdc.com>
Subject: Re: Setrab Oil Cooler
Date: Sep 02, 1998
> >Listers; I have access to a 16 row Setrab Oil Cooler, from TMR of Orange, Ca. >Has anyone used this particular 16 row unit in the O-360 with success? Or >should I try to get the 19 row? General info on this unit and your experiences >with it would be appreciated. > I have used the 13 row Setrab with the 0-320 160 hp in ambients up to 100 F without the oil temp exceeding the thermo setting of 180F. Dan Morris ________________________________________________________________________________
Date: Sep 02, 1998
Subject: Thank You all for the step feedback
A big thanks to all for your step feedback....looks like the baggage floors are coming off! Appreciate all of your feedback. Bob Claypool RVQ6A ________________________________________________________________________________
Date: Sep 02, 1998
> > > > They are also a BIG job to fit. > I spent about 12 hours total to mount mine, and I mounted them inside the skins. Part of that 12 hours was modifying the weldments so that the inboard end of the torque tube would not interfere with the belly skins. Alex Peterson Maple Grove, MN ________________________________________________________________________________
Date: Sep 02, 1998
Subject: Re: IS IT LEGAL?
IS IT LEGAL TO HAVE YOUR COCKPIT WINDOWS TINTED? ________________________________________________________________________________
Subject: Re: RV-8 tank skins
Date: Sep 02, 1998
> >Just a note to anyone about to drill their tank skins to the ribs and rear >baffle. the manual does not say anything about it, but you can not drill >the holes along the baffle from the second inboard rib to the root rib with >the tank clecoed to the spar.If you do you will surely drill into the spar. >Remove the assemblt from the spar to drill these holes. > Well....not quite. That's what drill stops are for. Adjust it so that only a very small amount of the bit is protruding so that the spar isn't marred when the bit breaks through. Ask me how I found this out..go ahead..ask. Brian Denk RV8#379 gear box assemblies underway. ________________________________________________________________________________
Date: Sep 02, 1998
>IS IT LEGAL TO HAVE YOUR COCKPIT WINDOWS TINTED? Why not? Van's offers them slightly tinted if the builder chooses. If you're referring to a very dark tint..I wouldn't recommend it from a visibility standpoint, but I don't know of any FARs that would address the issue specifically. Brian Denk RV8 fuselage ________________________________________________________________________________
Date: Sep 08, 1998
RV's have a higher re-sale value. Cozy fiberglass OOPS! are easier to fix that sheet metal OOPS! Cozy's seat three-four, RV one-two. Cozy's do not corrode. RV's? RV's more tools to buy. Cozy less tools. RV's look good. Cozy's look Hi-tech. Tough choice, Just build one of each!! Long-Ez builder with RV friend. ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Can you drill Chrome?
Listers; I am planning on chroming the grab bar and the roll bar on my RV-8. I have all the holes drilled on the rollbar, but have not drilled into it for the canopy yet. My question is, if I go ahead now and get the roll bar chromed, is it possible to drill into the chrome later when I mount the canopy? If it is possible, what procedure would be used? Von Alexander RV-8 N41VA MAlexan533(at)aol.com ________________________________________________________________________________
Date: Sep 02, 1998
Brian, I believe the RV canopies all come tinted as standard. You have to request clear. At least that is the way it was the last I heard/read. I think there was an article in the RVator or here on the list concerning ultraviolet ray exposure that explained about this. Les Williams/RV-6AQ/Tacoma WA >>IS IT LEGAL TO HAVE YOUR COCKPIT WINDOWS TINTED? > >Why not? Van's offers them slightly tinted if the builder chooses. If >you're referring to a very dark tint..I wouldn't recommend it from a >visibility standpoint, but I don't know of any FARs that would address >the issue specifically. > >Brian Denk >RV8 fuselage ________________________________________________________________________________
Date: Sep 02, 1998
In addition to what's in the archives, the length will also depend somewhat on whether you install them on a vertical (per plans) or horizontal power console. Les Williams/RV-6AQ/Tacoma WA > >Hi gang! > I had a question about the throttle/mixture brackett used on >the new 0-360A1A >with a precision airmotive carb supplied with the new engines from Van's.I >did buy the brackett that Van's sells but it doesn't look right. Anybody >have a slam dunker set up? >I'm sure this is not the first time this has come up..How about cable >lenghts for the throttle,mixture,and prop..Any thoughts? > > Thanks, John Hughes > RV-6 >N164JH (reserved) > So >Cal, Hookin things up!! > >Oshkosh 99 or bust!! > > > > > > ________________________________________________________________________________
Date: Sep 03, 1998
Gee, Mike. You take all the fun out of watching, when you give up the fight so easily. ha. (Good decision) ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Re: RV-6A power management (was fixed props)
<< Static is 2100 rpm. It is not quite as fast but I feel I get off the ground about as fast as before. >> I am new to operating a c/s prop and although all of the literature I've read says that when you make a power reduction, the throttle comes back, then the prop pitch control, then mixture. Contrary to this advice, I find that after liftoff, I prefer to: 1. Establish 120 mph cruise-climb, 2. Come back on the prop control (increase pitch) to obtain 2500 rpm, 3. Bring the throttle back to 25 inHg, 4. Add throttle as necessary to maintain 25 inHg as long as possible to cruising altitude (<75% power), 5. Bring the prop pitch back to 2300-2400 rpm. Is this a problem? It sounds like you guys with the cruise fixed pitch props only get about 2500 rpm at rotation and climb, so I feel justified in bringing the prop pitch up to get a bigger bite of the air before reducing the power to a more sedate level. Doing it the other way around seems odd to me, and I would like to know how the more experienced pilots feel about my using this technique. -GV ________________________________________________________________________________
Date: Sep 03, 1998
Subject: *** Additional Homecoming Info ***
******** If you plan on attending Van's Homecoming the weekend, please make note of the following information. This info is NEW and has not yet been posted on the rv-list. For those flying in, please pay especially close attention to what I call the "NOTAP" information (Notice to AirPersons--this is not an FAA NOTAM however). As before, I ask that you please pass this info on to those who are "Internet Challenged." ******** Aircraft Arrival Procedures: It is important to observe our special traffic pattern when arriving. First, all arrivals should monitor Hillsboro (HIO) ATIS 127.65. Contact Hillsboro Tower on 119.3 for advisories because Sunset Airpark lies just within their Class D airspace. Our traffic pattern for either runway is to the SOUTH SIDE OF THE RUNWAY, 500 AGL (700 MSL). The preferred runway is 6. Avoid flying over the town on the North side! We will have a temporary ground radio on 122.9 for landing and take off advisory during peak traffic times. Please switch to this frequency as you are released by the tower and enter Sunsets pattern. The ILS to HIO goes right over Sunset, there is an active glider strip just two miles northwest, and numerous private strips nearby. KEEP YOUR EYES OPEN. Be especially aware of traffic at Sunset that may be taking off into landing traffic. We have installed two checkerboards alongside the runway to mark the end of the landing zone. If you are not on the ground by the time you reach them, go around. Watch ground personnel for directions to parking. Departure Procedures: We have had troubles in the past with pilots blasting people and parked airplanes on start up. Please pull your airplane to an appropriate spot before starting the engine. The preferred departure is westbound. Look for traffic! Aircraft may be landing either direction. Lodging: There is no provision for camping on the airstrip. Nearby motels include: Park Dunes, Hillsboro (503) 640-4791 The Dunes, Hillsboro (503) 648-8991 Hallmark Inn, Hillsboro [across from HIO airport. Ask for rooms set aside for Vans] (503) 648-3500 Holiday Motel, Forest Grove (503) 357-7411 Travel Lodge, Forest Grove (503) 357-9700 The Courtyard, Hillsboro (503) 690-1800 Pets: Many animals are terrified or over-excited by so many people and noise. Please leave your pet at home. Picking Up Orders: Orders placed and paid for by the close of business September 3 may be picked up between 9 am and 1 pm Saturday. This is empennage kits and catalog orders onlywe will not have the staff to crate or load wing, fuselage, finish, or QB kits during the Homecoming. Have a great day, Jeremy jwb(at)europa.com Disclaimer: I have forwarded this information as a courtesy to you. However, this is not an offical posting (I suppose because of my added comments at the beginning). For an offical posting, see Van's web site Updates section. THX!) ________________________________________________________________________________
Date: Sep 03, 1998
Vanremog(at)aol.com wrote: > I am new to operating a c/s prop and although all of the literature I've read > says that when you make a power reduction, the throttle comes back, then the > prop pitch control, then mixture. > > Doing it the other way around seems odd to me, and I would like to know how > the more experienced pilots feel about my using this technique. > > -GV The oft-recommended technique of reducing power before reducing prop rpm is to prevent the combination of 'high' MP with 'low' rpm. which causes high cylinder pressures. This is said to be hard on the engine because of the high cylinder pressures that it causes. The 'other part' of this recommendation says to increase prop RPM before increasing power, for the same reason. What are the values for 'high' MP and 'low' RPM? Best source for these numbers is the engine manufacturer. If you ask enough people, you will undoubtedly hear "MP in inches should not exceed prop RPM in hundreds", or the term "oversquare" which implies the violation of this principle. That's a pretty easy rule to remember, which explains why it is so often repeated, EVEN THOUGH IT IS NOT CORRECT. I have a 172RG (Lyc 0-360) manual in front of me which shows many "oversquare" acceptable cruise settings. Here are a few: @6000 ft RPM MP %BHP 2300 24 77 2200 24 74 2100 23 67 The oversquare rule is even futher off-base for a turbo'd aircraft, Here are a few numbers from a Cessna T210L (w/Cont TSIO-520) POH: @6000 ft RPM MP %BHP 2400 27.5 74 2300 27.5 70 2200 27.5 65 Sounds like your procedure keeps the combination of MP and RPM well within the Lycoming recommendations, so I don't see a problem. Just be careful not to go to full throttle with the prop pulled way back (which could take you outside Lyc's recommended limits). Blake ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Rudder Horn - RV8
I was working on the rudder horn attachment last night and noticed when I slip the rib in place (I think this is R-404?) I noticed it doesn't clear the holes by much that I will have to drill from the doubler plate (certainly not by 2x the hole diameter). I made a notch in the rib to clear the bolt and it fits snug against the top of the 405 rudder horn, but it looks like when I drill, the holes will be close to the edge on the rib. Is this normal? Thanks Joe RV-8 Tail ________________________________________________________________________________
Date: Sep 03, 1998
From: "David S. Hamilton" <hamlton(at)mindspring.com>
Subject: Re: Can you drill Chrome?
>I am planning on chroming the grab bar and the roll bar on my RV-8. Von, The place that has powder coated all my parts offers a "chrome Look" silver baked on finish. This is a high tempature paint they use on exhaust systems in race cars. It looks like chrome but is more durable and lasts longer. It is less expensive and lighter also. Chrome will look great but could drive the back seater nuts when the sun glints off it and into his or her eyes. that is why I used regular powder coat on the roll bar but chose this "chrome" powdercoat for the tailwheel assembly. It looks great! Dave Hamilton (80001) Atlanta, GA ________________________________________________________________________________
Date: Sep 03, 1998
GV, I believe that the "rule" of reducing manifold pressure first, then rpm comes from the days of big radial engines. Those engines had a max allowable manifold pressure for each rpm, and the allowable MP went up with rpm. These engines were generally operated at the max MP for the current rpm all the time, to maximize effiency, so when making a power reduction you had to reduce MP first, or you would exceed the limiting MP as you reduced the rpm. On your aircraft, as long as Lycoming has not established a max allowable MP vs rpm curve, there should be no problem doing what you are doing. Take care, Kevin Horton RV-8 80427 (wings) khorton(at)cyberus.ca Engineering Test Pilot ex R-1820 driver Transport Canada > >I am new to operating a c/s prop and although all of the literature I've read >says that when you make a power reduction, the throttle comes back, then the >prop pitch control, then mixture. > >Contrary to this advice, I find that after liftoff, I prefer to: >1. Establish 120 mph cruise-climb, >2. Come back on the prop control (increase pitch) to obtain 2500 rpm, >3. Bring the throttle back to 25 inHg, >4. Add throttle as necessary to maintain 25 inHg as long as possible to >cruising altitude (<75% power), >5. Bring the prop pitch back to 2300-2400 rpm. > >Is this a problem? It sounds like you guys with the cruise fixed pitch props >only get about 2500 rpm at rotation and climb, so I feel justified in bringing >the prop pitch up to get a bigger bite of the air before reducing the power to >a more sedate level. > ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Re: RV Resale Market
marcus, i think we would all benifit for knowing our birds worth & resale value, if the owners don't mind posting their purchase price, they could leave their name annonomus, scott winging it in tampa ________________________________________________________________________________
From: "Rick & Barbara Osgood" <randbosgood(at)sprintmail.com>
Subject: Weeping rivets
Date: Sep 03, 1998
Despite my efforts to seal all the rivets in my 6A tank, I have three that refuse to surrender. Has anyone come up with a good way to seal these after the tank is complete? My first thought is to slosh the tank (I have not done so yet). Also, is it recommended to create a gasket between the fuel sender plate and the end rib or is this not necessary? Thanks Rick Osgood ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Re: RV-(6(A)) power management (was fixed props)
---Vanremog(at)aol.com wrote: > > > > << Static is 2100 rpm. It is not quite > as fast but I feel I get off the ground about as fast as before. >> > > I am new to operating a c/s prop and although all of the literature I've read > says that when you make a power reduction, the throttle comes back, then the > prop pitch control, then mixture. > > Contrary to this advice, I find that after liftoff, I prefer to: > 1. Establish 120 mph cruise-climb, > 2. Come back on the prop control (increase pitch) to obtain 2500 rpm, > 3. Bring the throttle back to 25 inHg, > 4. Add throttle as necessary to maintain 25 inHg as long as possible to > cruising altitude (<75% power), > 5. Bring the prop pitch back to 2300-2400 rpm. > > Is this a problem? It sounds like you guys with the cruise fixed pitch props > only get about 2500 rpm at rotation and climb, so I feel justified in bringing > the prop pitch up to get a bigger bite of the air before reducing the power to > a more sedate level. > > Doing it the other way around seems odd to me, and I would like to know how > the more experienced pilots feel about my using this technique. > > -GV When I depart, I follow a similar procedure except I never pull the throttle back. I go to 2,500 RPM full throttle @ 105 KIAS. I always try to run over square. My personal limit is not more than 3 inches MAP over RPM/100. The Lycoming chart shows (I think) 6 inches MAP over RPM above (I think) 1900 RPM. A very sweet power setting is 2,100 RPM and 22" MAP. (55% power) Fuel burn is below 6 GPH @ 135 KTAS. There is a good article on this in an old issue of "KitPlanes" and another in Key Reprints of the Lycoming Flyer. Check the Lycoming power chart in the Engine Owner's Manual for what is allowed with your engine. == Gary A. Sobek RV-6 N157GS O-320 Hartzell Flying in So. CA, USA RV6flier(at)yahoo.com ________________________________________________________________________________
Date: Sep 03, 1998
GV, the procedure you outlined is exactly what I was told to do by an experienced RV-4 driver and my sometimes CFI. Although I haven't flown much constant speed stuff either, this seemed to work for me. Les Williams/RV-6AQ/Tacoma WA >I am new to operating a c/s prop and although all of the literature I've read >says that when you make a power reduction, the throttle comes back, then the >prop pitch control, then mixture. > >Contrary to this advice, I find that after liftoff, I prefer to: >1. Establish 120 mph cruise-climb, >2. Come back on the prop control (increase pitch) to obtain 2500 rpm, >3. Bring the throttle back to 25 inHg, >4. Add throttle as necessary to maintain 25 inHg as long as possible to >cruising altitude (<75% power), >5. Bring the prop pitch back to 2300-2400 rpm. > >Is this a problem? It sounds like you guys with the cruise fixed pitch props >only get about 2500 rpm at rotation and climb, so I feel justified in bringing >the prop pitch up to get a bigger bite of the air before reducing the power to >a more sedate level. > >Doing it the other way around seems odd to me, and I would like to know how >the more experienced pilots feel about my using this technique. > >-GV ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Angle-of-Attack instruments- there is a difference
Listers: In our never-ending quest for value, here is the difference between the LRI instrument vs the AOA instrument. The LRI is mechanical... and complies with the KISS principle IMHO. It's also MUCH cheaper- about 1/2 price. We will be using an LRI instrument on the B-1, Bruce Bohannon's new climb machine. Check six! Mark This from the crew chief on Pushy Galore: << The LRI uses a probe mounted below the wing with the two sensor ports in it. It can be heated like a pitot tube for icing conditions. There are two plastic tubes that run up to the instrument panel and that is it. AOA: This fancy schmancy doo dad below has a digital processor for the LED indicator about the size of standard aircraft rack radio. Boooo hissss... Who needs all that ? ________________________________________________________________________________
Date: Sep 03, 1998
From: "Scott A. Jordan" <SAJ_SLJ(at)compuserve.com>
Message text written by INTERNET:rv-list(at)matronics.com >I was working on the rudder horn attachment last night and noticed when I slip the rib in place (I think this is R-404?) I noticed it doesn't clear the holes by much that I will have to drill from the doubler plate...., the holes will be close to the edge on the rib. Is this normal? < Yes, since the rib is sandwiched between two other parts (the 405 horn and 802 spar) the edge distance is not critical. Scott A. Jordan 80331 #$@*^ tank skins the seven rivets will go into the "z brackets". Looking at DWG 16 when I was tired, I didn't notice / realize this and evenly spaced my holes. The result was insufficient edge distance on a couple of the Z brackets. Fortunatly, Tom at Van's said it was not a structural problem and to simply add a rivet with proper clearance. Just one more potential leak. I found fitting the skin to be very difficult. I kept the straps loose while I drilled the top of the skin, reaching in to move the ribs as needed. Strapping the skin tight prooved very difficult. Though my ribs were as straight as I could make them, the flanges were not centered on the holes when the skin was tight. After many frustrating attempts, I finally opened the bottom skin enought to see inside. I reached in and lined the rib centerlines up with the holes and after several attemptsand a llittle blood I got all the ribs lined up. The skin is now strapped down tight with a nice tight fit all around, the leading edge even matches nicely at the joint. I will drill the bottom this morning. Somebody PLEASE tell me this is the hardest part of building the plane! I spent several hours in my attempts, hopefully the second one will go beter now that I have a system. Scott A. Jordan 80331 ________________________________________________________________________________
Date: Sep 03, 1998
Hi, Just wanted to review my training/reading/experiences re: using controllable pitch props. The standard procedure for using a controllable pitch prop is to keep the manifold pressure under the prop rpm......this would mean bringing the manifold pressure (throttle) back to 25" after takeoff followed by bringing the prop back to 2500 rpm. To go to climb configuration from cruise first increase prop rpm and then manifold pressure to 25" (you'll need to keep increasing manifold pressure as the plane climbs to maintain 25" - until you run out of throttle at higher altitudes unless you have a turbocharger in your plane). Hope this helps....... Paul Bilodeau ---------- > From: Leslie B. Williams <lesliebwilliams(at)email.msn.com> > To: rv-list(at)matronics.com > Subject: Re: RV-List: RV-6A power management (was fixed props) > Date: Thursday, September 03, 1998 9:28 AM > > > GV, the procedure you outlined is exactly what I was told to do by an > experienced RV-4 driver and my sometimes CFI. Although I haven't flown much > constant speed stuff either, this seemed to work for me. > > Les Williams/RV-6AQ/Tacoma WA > > > > >I am new to operating a c/s prop and although all of the literature I've > read > >says that when you make a power reduction, the throttle comes back, then > the > >prop pitch control, then mixture. > > > >Contrary to this advice, I find that after liftoff, I prefer to: > >1. Establish 120 mph cruise-climb, > >2. Come back on the prop control (increase pitch) to obtain 2500 rpm, > >3. Bring the throttle back to 25 inHg, > >4. Add throttle as necessary to maintain 25 inHg as long as possible to > >cruising altitude (<75% power), > >5. Bring the prop pitch back to 2300-2400 rpm. > > > >Is this a problem? It sounds like you guys with the cruise fixed pitch > props > >only get about 2500 rpm at rotation and climb, so I feel justified in > bringing > >the prop pitch up to get a bigger bite of the air before reducing the power > to > >a more sedate level. > > > >Doing it the other way around seems odd to me, and I would like to know how > >the more experienced pilots feel about my using this technique. > > > >-GV > > > > > > > ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Re: Thank You all for the step feedback
You will never regret adding the step. Especially when you get a little bit older (like me) it is a blessing. ________________________________________________________________________________
Date: Sep 03, 1998
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
<3.0.1.16.19980902193932.2b8f054c(at)dtc.net> > >Sorry Bob, >I was thinking of a thermistor! >Ed Cole Understand. We're just all looking out for each other here. Thanks for joining in. ________________________________________________________________________________
Date: Sep 03, 1998
> A question for Bob Nuckolls that may be of interest to RVers. > On the 6A that I'm helping with, belonging to Charlie Tyrrel of Gillette, >WY, . . . just punched Charlie into our database to get an R8 book and wondered if I'd mis-spelled his last name . . thanks for the heads up! > . . .we're going to use toggle switches for the mags as opposed to a keyed >mag switch. The left toggle will be a three position: off, left mag on, >spring loaded to start. This will work. Some builders have elected to use spring loaded, 3-position switches on both sides so that the switches reside in the same position for both OFF and ON . . . it's a consistency thing. >. . . . . The right mag will be off and right mag on, a two >postion switch. I assume that the right mag switch will be off during the >starting procedure. Yes . . in fact we use the SECOND pole of the right mag switch to disable the starter function when the switch is ON. > . . We'll be using the Laser ignition. Will this toggle >switch arrangement work as described with the Laser? Yes. Do the Laser mags switch like classic magnetos? I.e. close a switch to disable the mag? If you have to close a switch to ENABLE the mag (apply bus volts instead of opening a ground) then you'll need to use a 2 dash 50 switch ON-ON-(ON) function instead of the more common 2 dash 5 switch ON-OFF-(ON). > Also, diodes are recommended on the battery and starter relays, I think to >help protect keyed, magneto switches. Van's has these for sale in the >catalog and I have installed these on my six. Are these diodes required >when using toggle switches for the mags? Yes. The diodes catch spikes from the contactor coils . . . same problem irrespective of type of ignition system. >. . . . Bob, do you or any listers have a >source for the three postion: off-on-spring loaded on toggle switches. We >intend to use this type of switch for the left mag and also on the fuel >boost pump with the spring loaded-on postion being used to open the primer >relay. We've been supplying toggle switches over an above our catalog listings for several years. R8 to the book will have a detailed description of various toggle switch functions and how they can be use in system design. We'll be pleased to order switches we don't stock . . . The special switches like 2 dash 50 are a little breathaking ($32 last time I looked). I can get them much less expensive but I have to buy 100 at a time. Just not in a cash flow position yet to make that investment . . . ________________________________________________________________________________
Subject: IS IT LEGAL?
Date: Sep 03, 1998
There is an FAR that addresses windows. It requires 70% light transmission for front and side windows (actually it very specifically defines the field of view it covers). In effect it is very similar to the window tinting regs for autos. The big IF, like all other certification regs, is whether it applies to experimentals. I suspect it would be like strobes, i.e. depends on your inspector. Greg Young RV-6 N6GY (reserved) finishing kit : > > IS IT LEGAL TO HAVE YOUR COCKPIT WINDOWS TINTED? > > ________________________________________________________________________________
From: "Duberstein, Allen" <allen.duberstein(at)intel.com>
Date: Sep 03, 1998
Rick There is a 2 part epoxy like matyerial that I have used that will seal weeping from the outside. It seems to set when exposed to fuel. If you are interested in further info I'll get it off the package I have in the hanger. regards allen N5AD From: "Rick & Barbara Osgood" [SMTP:randbosgood(at)sprintmail.com] AT MSXGATE@CCMAIL Subject: RV-List: Weeping rivets Despite my efforts to seal all the rivets in my 6A tank, I have three that refuse to surrender. Has anyone come up with a good way to seal these after the tank is complete? My first thought is to slosh the tank (I have not done so yet). Also, is it recommended to create a gasket between the fuel sender plate and the end rib or is this not necessary? Thanks Rick Osgood ________________________________________________________________________________
From: "Robert Acker" <robert.acker(at)ingrammicro.com>
Date: Sep 03, 1998
> >Listers: >In our never-ending quest for value, here is the difference between the LRI >instrument vs the AOA instrument. The LRI is mechanical... and complies with >the KISS principle IMHO. It's also MUCH cheaper- about 1/2 price. The RiteangleII AOA indicator is cheaper than the LRI ($474 vs. $710). However, it is electromechanical vs. mechanical. Rob (RV-6Q). ________________________________________________________________________________
Subject: Burlington, Colorado Fly-In
Date: Sep 03, 1998
I missed the info on the Burlington fly-in. Would someone send it to me. Thank you Bruce Bell Lubbock, Texas email- rv4bell(at)door.net ________________________________________________________________________________
From: "Anderson, John" <john.anderson(at)spcf.siemens.com>
Subject: Insurance
Date: Sep 03, 1998
I have hull insurance on my rv-4 which does not include in motion coverage, meaning when the prop is spinning I am uninsured. The question I have is that why would an experimental cost more to insure just sitting there than any other conventional aircraft. I have this told to me by my insurance broker, but they don't give me any real concrete answer. I am currently paying $700 a year for hull insurance on a value of $40,000. Does this premium seem to be in line with what you have come across? What do others of you pay that have flying aircraft. I just can't seem to fathom that a $40,000 Cessna versus a $40,000 experiment has a lower hull rate. John C. Anderson Siemens Power Corporation 1040 S. 70th Street Milwaukee, WI 53214 (414) 475-4201 (414) 475-4461 - fax E-mail: john.anderson(at)spcf.siemens.com ________________________________________________________________________________
Date: Sep 03, 1998
I'm building a RV-6A, so maybe I don't know. I am always finding new "hardest parts" as I go along. Just this morning I tried to install my seal belt brackets into my new fuselage and found that one of the holes I drilled in the rear spar mounting brackets are partially covered by one of the seat ribs. In retrospect, it should have been obvious. Now I have to move the bracket to a new location, make sure that new holes that I am going to drill will have proper spacing from rivets and other holes previously drilled, figure out how to get my angle drill down in there to drill, wonder if I have the right stubby bit to make the 3/16 hole, and ....... We spend so much of our time trying to figure out what to do and so little time actually doing something. By the way, in reply to an earlier post about sealing leaky rivets in the tank, I once made a spit-ball sized wad of Proseal and mounded it up over the head of a poorly-sealed pop rivet in the rear baffle. It worked so far. Of course I am not flying anywhere in this thing anytime soon. Steve Soule Huntington, Vermont -----Original Message----- Somebody PLEASE tell me this is the hardest part of building the plane! ________________________________________________________________________________
Subject: Courage to fly
Date: Sep 03, 1998
I began to fly because I was afraid. Nobody else I knew of was doing it. It was costly, risky, adventurous and not approved of by my folks. Something though, was pushing me onward. I learned to love it and it gave me something back. Pride, appreciation, and self esteem to face down trepidation. A while ago, I pushed the RV out to the grass and a fellow came by, full of questions, and declared proudly that he had once flown an Ercoupe, coast to coast and back...Awesome, for I too, had flown an Ercoupe to Mexico and back when I was a kid....I had to wonder what fires kids today ? Where is the courage and adventure ?....I thought of a time when a row of 20 Mustangs were retired and parked on the grass, I got into one and sat with canopy closed and hands on stick and throttle, visualized the boys who sat here before and what they may have experienced, and wondered if I would have the kind of courage that they had. The guns were now cold and the contrails were long gone, and I sat in that row of 20 Mustangs and thought back. I read once where in the Great War, most of the aces with big scores were teen-agers, frequently dead before their 20th birthday. Now, decades later, I was to summon up courage once more to try to be at one with an airplane that was more than anything I had experienced before. With each flight, we got to know each other better and time and thoughts were allowed to enjoy more of what was outside the cockpit. Time to look at the wings, and the color of them, the fields below, and the shading of clouds along the way. I climbed to 9,000, throttled back to turn and come back home, and glided quietly and thought how beautiful it all looked and how we too, must look beautiful, ruby, burgundy, and white, up against the blue. I thought of the serenity of flight by the wonderful flying scenes in "Out of Africa" and "The English Patient" and the inspiring music of the background. This would make anyone with a soul stir his passion for pure flight. This craft slipping along the halls of air, this cathedral of the skies. It is to weep. I read too of a man, who, this month, is about to fly a 70 year old biplane from London, back to Australia. An Avro Avian, retracing the steps of those like Antoine de St. Exupery who wrote in "Wind, Sand and Stars" of crossing the cold desert at night and the furnace of the timeless plains by day, all on a compass and map (if any). The drive and the courage is still out there in some. It is a reckoning with ones self. I am a teen no more and I still need to summon up nerve sometimes, but the winning of it still thrills me and the purity of flying is ever fresh to me. The RV lets me extend myself and brings me up to where the world is broad and grand and riotous with color and sensual delights. Landing once again is a handshake of two companions who have enjoyed each others company until the next time. Thank you Van, thank you RV, and thank you all out there..... ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Re: Throttle Bracket (was Re. Throttle Brackett..)
Those of you with O-360 and MA4-5 carb wondering about using Van's throttle bracket -- you might want to hold off getting a bracket for just a little bit. I have discussed this with several people at Vans, and the bottom line is that this bracket wasn't really designed for the O-360 and there are some issues with its use on that engine/carb. They now have my carbeurator and are using it to prototype a bracket for the O-360. It will be similar to the other one but will mount between the carb and the sump. This bracket will still have the relatively short distance between the mount point and the throttle/mixture arms, so if you are getting cables from ACS for example, you will still have to get them custom sized. I will post info on cable lengths when I get this all sorted out. Randall Henderson Engineering Design Team, Inc. randall(at)edt.com ________________________________________________________________________________
Subject: RV vs Cozy trade-offs
Date: Sep 03, 1998
>>> Ability to put it down in a field in >>> an emergency with minimum >>> damage and risk. RV (+) > > >I was never "religious" in the plastic vs. metal argument BEFORE I >put my RV-4 in the trees at Chapel Hill and walked away. Landing at 50mph >and the energy absorbing crumple effect of the aluminum construction made me a true believer. > >The fact I'm writing this at all is proof enough for me... > >Richard E. Bibb >RV-4 N144KT - in rebuild - will fly by 2000 >Oak Hill, VA >rbibb(at)fore.com ===================================== Amashing the news media hadn't had anything to say about it. If you had decided to land in the only field you had, I bet we would have heard about it. Don Jordan ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com > ________________________________________________________________________________
Date: Sep 03, 1998
Subject: HVLP "systems" - reply to "HPLV Sprayers"
> Bill Thomas (wd_thomas(at)earthlink.net) asked about "a complete HPLV [HVLP] spray unit > they have used and are interested in selling" Bill, your post said HPLV but I'm responding as if you meant HVLP (hi vol, low pressure, not hi press...) I use a DeVilbiss HVLP gun bought from a PPG auto paint store for about $189 a year ago. I use it with a typical air compressor - Sears 20 gal tank. The tank runs at 100 psi, I turn the "out" pressure down to 70, then adjust the valve on bottom of gun's inlet to read 8 or 10 psi at the gage screwed in the heel (handle) of the spray gun. That "heel gage" comes with the gun. I feel it is real flim-flamery for these people to continue to show up at Oshkosh and Sun N Fun selling their big "vacuum cleaner style" air supply units, turbines, or whatever they call them. They are totally unnecessary. Just use the HVLP spray gun with the same air supply you'd use for an old fashioned "high pressure, lots of overspray" gun. I found through trial and error that the two knobs on back of my gun should be set as follows: The top knob, "pattern" lets you choose either "round pattern" or "fan" (a vertical line of paint) - "fan" gives you much better control to eliminate getting too much paint and getting runs. The next knob is "wetness". Full CW (in) is "dry" - no paint, just air. There are 6 turns until the screw comes out. I use 3/4 of a turn from full dry and 8-10psi and have to make 2 to 3 reasonably slow passes to get a 0.7 mil thick primer coat. (I started off "in the middle", i.e., 3 turns out on wetness, and REALLY got lots of runs and fisheyes. At 3/4 turn wet, you have perfect control of how much paint is going on and you can see it. Good luck. David Carter, Nederland, Texas RV-6 left elevator ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Re: Courage to fly
damn your good !!! glad you stayed with us corsair !!! scott winging it in tampa ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Re: Angle-of-Attack instruments- there is a difference
<< The RiteangleII AOA indicator is cheaper than the LRI ($474 vs. $710). However, it is electromechanical vs. mechanical. Rob (RV-6Q). >> Wait a minute- are there THREE different lift instrument manufacturers? I re- read the email from Linda Frantz- she states their cost as $1450. Gary tells me the LRI runs about half that, so $710 is in line with that. Tell me more about this $474 job! Is it simply a stall indicator, vs a lift indicator? The LRI and the AOA tells you at which angle your wing is flying: how close you are to stall, or max L/D, etc. The quest for value continues.... Check six! Mark ________________________________________________________________________________
Date: Sep 03, 1998
Subject: More on Cozy vs RV trades
I received a lot of thoughtful responses to my question on choosing the aircraft I would like building and flying. I would summarize the answers as "If you want a metal plane, its the RV, but first decide what the end application is and what construction method you like (can tolerate)" I would like a plane suited to long distance travel. I guess that mainly comes down to sound levels and comfort since both aircraft have good range and economy. Has anyone measured the typical sound levels in RVs? I took a ride in a 172 with an O-360 and constant speed prop the other day and was appalled at the noise level. How much was engine and how much prop noise - I couldn't really say, but after 45 minutes, I felt as if I had spent an evening at a rock concert. I guess anything is tolerable with enough ear plugs and headphones (the instructor used both at the same time), but noise plays a big part in fatigue, and hence safety. Has anyone on this list installed an exhaust pipe / muffler system on their RV in an attempt to get cockpit noise levels down. Is it even feasible and would it provide a measurable noise reduction if a builder had low noise as a design goal? Thanks for the advice. Peter ________________________________________________________________________________
Date: Aug 30, 1998
Jmw116(at)aol.com wrote: > > IS IT LEGAL TO HAVE YOUR COCKPIT WINDOWS TINTED? FAR Section 23.775(e): The windshield and side windows forward of the pilot's back when the pilot is seated in the normal flight position must have a luminous transmittance value of not less than 70 percent. Best wishes, Jack Abell Los Angeles RV-6A N333JA (Reserved) ________________________________________________________________________________
Date: Sep 03, 1998
>Brian, I believe the RV canopies all come tinted as standard. You have to >request clear. At least that is the way it was the last I heard/read. I >think there was an article in the RVator or here on the list concerning >ultraviolet ray exposure that explained about this. > >Les Williams/RV-6AQ/Tacoma WA > > > Les, Speaking of UV exposure, will the tint filter out enough to avoid sunburning the occupants? Being a fair skinned person, this is a concern. Arriving "poached and blistered" doesn't sound like fun. Brian Denk RV8 fuselage ________________________________________________________________________________
Date: Sep 03, 1998
> There is a 2 part epoxy like matyerial that I have used that will seal > weeping from the outside. It seems to set when exposed to fuel. If > you are interested in further info I'll get it off the package I have > in the hanger. I think it's safe to say that there are many people on this list who would be interested in this information. Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com ________________________________________________________________________________
Date: Aug 30, 1998
Corsair wrote: > > I began to fly because I was afraid. Nobody else I knew of was doing it. It . . > . >Thank you Van, thank you RV, and thank you all out there..... And thank you, "Corsair." Best wishes, Jack Abell Los Angeles RV-6A N333JA (Reserved) ________________________________________________________________________________
Subject: Re: Weeping rivets
Date: Sep 03, 1998
>Despite my efforts to seal all the rivets in my 6A tank, I have three that >refuse to surrender. Has anyone come up with a good way to seal these after >the tank is complete? My first thought is to slosh the tank (I have not done >so yet). > >Also, is it recommended to create a gasket between the fuel sender plate and >the end rib or is this not necessary? > > >Thanks >Rick Osgood Rick, Been there myself..only one rivet, however :) I drilled out the offending, weepy lil bugger, opened up the hole to #30 by drilling verrry slowly to avoid sending debris into the tank. Then, I cleaned the surrounding skin very well, scuffed it with scotchbrite pad and installed a sealed end pop rivet with a healthy dab of proseal. No more leak. This is my chosen path to leak-free tank enlightenment. Hang in there. Brian "fuselage lookin like a canoe" Denk ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Re: Insurance
<< I just can't seem to fathom that a $40,000 Cessna versus a $40,000 experiment has a lower hull rate. >> I can tell you the argument I got from the insurance company for insurance for my last project, a kit car. Their belief is - if I drive a Honda and it breaks, they can choose from an unlimited number of people who know how to fix Hondas. If I break my kit car, they have to assume that I won't be the person that repairs it, and they have to go find someone who can manufacture all the required parts from raw lumps of plastic and metal, with an arbitrary level of documentation, and no factory or dealer to call if something doesn't make sense. That cost / risk is very difficult to quantify and therefore, regardless of whether the actual cost of damage repair would be lower, higher or the same, the premium will reflect the uncertainty. If you put your Cessna down hard and broke something, they could go buy the pieces and find an A&P who knew exactly how to fix it. If you put your RV down hard, what would they do? Of course, if your RV was damaged by a storm while sitting on a field, they would face the same problems, so their approach is not entirely consistent. But, I would view that as a partial win for you, rather than an unreasonable response from them. I guess the risk is lower, and the people in the insurance company that set the odds are willing to take that bet. ________________________________________________________________________________
Date: Sep 03, 1998
> >Wait a minute- are there THREE different lift instrument manufacturers? I re- >read the email from Linda Frantz- she states their cost as $1450. Gary tells >me the LRI runs about half that, so $710 is in line with that. Tell me more >about this $474 job! Is it simply a stall indicator, vs a lift indicator? The >LRI and the AOA tells you at which angle your wing is flying: how close you >are to stall, or max L/D, etc. RiteangleII (www.riteangle.com) Good - Cheapest, $474. AOA measurement for stall, best glide, Vx, Vy, etc. The designer/owner has absolutely fantastic customer support. Bad - Senses AOA with a small vane hooked up to a potentiometer. I find the vane somewhat unpleasing to the eye, on a wingtip may get lots of "curious observer rash". Lift enhancement devices (flaps, etc) require a different calibration, accomplished via microswitch on this unit. LRI (www.riteangle.com) Good - Has a usage history (when queried for it, company response is "we don't keep that around"). Moderate pricing. Measures a combo of "AOA and Lift Reserve". Clean install via wing-mounted pitot-like sensor. Bad - I found the company pre-sales support the worst I have ever experienced...from ANY company. Rob (RV-6Q...leaning towards Riteangle...the electronic goody is just too expensive). ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Is It Legal?
I find a nice compromise to this question is to use the clear canopy and put "slap on" Wal-Mart, no glue, electrostatic adhesion, plastic on above my head. A roll costs about $12 and you can get MANY pieces, enough for several airplanes, or changes from one roll. It stays in place nicely and is very easy to apply; no water, squeegies, etc.The stuff comes in several "shades" or densities. I found a "smoke" type that shades well, yet could be seen through if need be...just my idea... ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Re: HVLP "systems" - reply to "HPLV Sprayers"
To get rid of "fish-eyes" use SMOTHIE found at professional paint stores....also wash the serfice down with correct solvent to remove oil..... David Carter wrote: > > > Bill Thomas (wd_thomas(at)earthlink.net) asked about "a complete HPLV [HVLP] spray unit > > they have used and are interested in selling" > > Bill, your post said HPLV but I'm responding as if you meant HVLP (hi > vol, low pressure, not hi press...) > > I use a DeVilbiss HVLP gun bought from a PPG auto paint store for about > $189 a year ago. I use it with a typical air compressor - Sears 20 gal > tank. The tank runs at 100 psi, I turn the "out" pressure down to 70, > then adjust the valve on bottom of gun's inlet to read 8 or 10 psi at > the gage screwed in the heel (handle) of the spray gun. That "heel > gage" comes with the gun. > > I feel it is real flim-flamery for these people to continue to show up > at Oshkosh and Sun N Fun selling their big "vacuum cleaner style" air > supply units, turbines, or whatever they call them. They are totally > unnecessary. Just use the HVLP spray gun with the same air supply you'd > use for an old fashioned "high pressure, lots of overspray" gun. > > I found through trial and error that the two knobs on back of my gun > should be set as follows: The top knob, "pattern" lets you choose > either "round pattern" or "fan" (a vertical line of paint) - "fan" gives > you much better control to eliminate getting too much paint and getting > runs. > > The next knob is "wetness". Full CW (in) is "dry" - no paint, just > air. There are 6 turns until the screw comes out. I use 3/4 of a turn > from full dry and 8-10psi and have to make 2 to 3 reasonably slow passes > to get a 0.7 mil thick primer coat. (I started off "in the middle", > i.e., 3 turns out on wetness, and REALLY got lots of runs and fisheyes. > At 3/4 turn wet, you have perfect control of how much paint is going on > and you can see it. > > Good luck. > > David Carter, Nederland, Texas > RV-6 left elevator > ________________________________________________________________________________
Date: Sep 03, 1998
Please note that homebuilts do not have to comply with FAR 23, unless some other reg calls up a specific FAR 23 requirement. I am not aware of any regulatory requirements in this area, but common sense would dictate meeting the 70% transmittance requirement if you were going to be approved to fly at night. Kevin Horton RV-8 80427 (wings) khorton(at)cyberus.ca >> >Jmw116(at)aol.com wrote: > >> >> IS IT LEGAL TO HAVE YOUR COCKPIT WINDOWS TINTED? > >FAR Section 23.775(e): The windshield and side windows forward of the pilot's >back when the pilot is seated in the normal flight position must have a luminous >transmittance value of not less than 70 percent. > >Best wishes, > >Jack Abell ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Re: Cockpit noise - was More on Cozy vs RV trades
Peter, If cockpit noise is the concern, I would strongly recommend that you try a good set of active noise reduction (ANR) headsets. I used to borrow a friends Trinidad, which was equiped with Telex ANR headsets (I can't remember which model). They made a tremendous difference. When you turned them on it was like stepping into a tomb. You could still hear the engine, but at a much, much lower volume. The ANR headsets made a huge difference in the fatigue level. As far as mufflers go, the Germans have very strigent external noise requirements. Check out the archives - I recall a German builder a while back who described a muffler system that he was happy with. Kevin Horton RV-8 80427 (wings) khorton(at)cyberus.ca > <--stuff snipped out--> >I took a ride in a 172 with an O-360 and constant speed prop the other day and >was appalled at the noise level. How much was engine and how much prop noise >- I couldn't really say, but after 45 minutes, I felt as if I had spent an >evening at a rock concert. I guess anything is tolerable with enough ear >plugs and headphones (the instructor used both at the same time), but noise >plays a big part in fatigue, and hence safety. > >Has anyone on this list installed an exhaust pipe / muffler system on their RV >in an attempt to get cockpit noise levels down. Is it even feasible and would >it provide a measurable noise reduction if a builder had low noise as a design >goal? > >Thanks for the advice. > >Peter ________________________________________________________________________________
Date: Sep 03, 1998
I am an aviation insurance broker (Aon Aviation) who specializes in aircraft product manufacturers, however I do have experience in this area. There are many factors which effect insurance premiums. Is your aircraft tied-down outside or is it hangared? How much total time do you have? How much time do you have in tail draggers? How is your loss history? What insurance company are you with? In general, Ground Risks Only (GRO) coverage is undesirable to an insurance company. You will often find that for only a small additional premium you can have full flight risks. Additionally, insurance for homebuilt aircraft IS higher than the same coverage for spam-cans. Why, because the insurance companies can charge more (there are only several companies who write such coverage so there is little competition/incentive to sell it cheep). This is even more unfair when you consider that the loss ratio for Cessnas is about the same as RVs, however we have half the seats and the cost to repair is much cheaper. Until one of the major insurance companies starts to write insurance for homebuilt aircraft the price will remain higher than the same coverage for spam-cans. I am working with the homebuilt industry and several insurance companies on a remedy to this situation. Ill keep you all posted. Gary Corde RV-6 N211GC - NJ ________________________________________________________________________________
Date: Sep 03, 1998
In a message dated 9/3/98 3:06:32 PM Eastern Daylight Time, tinckler(at)axionet.com writes: << Thank you Van, thank you RV, and thank you all out there..... >> And thank you for returning to the list. Gary Corde RV-6 N211GC - NJ ________________________________________________________________________________
Date: Sep 03, 1998
> Rob (RV-6Q...leaning towards Riteangle...the electronic goody is just too > expensive). > They are all Too Expensive if you ask me! BTW, Doesn't the LRI seem to be essentially the same setup that Dr. Powell came up with in '79? He used an old ASI for display and they use a gauge of some sort. I recently searched the archive on this subject and could not find any evidence of anyone who has FLOWN with either the Powell AOA indicator or any of the microswitch stall warning set ups. In both cases, it would seem to be very important to have accurate placement of the sensor. So, does anybody have any detailed info. on a setup that works? John ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Re: Relay question
<41116842.35ed5cc4(at)aol.com> At 07:46 PM 9/2/98, you wrote: > > >>A diode clamps the reverse voltage spike right a zero (well, the forward >>voltage drop of the diode which is usually around 0.7V) and a metal oxide >>varistor (MOV) doesn't clamp until tens or hundreds of volts since most are >>designed for clamping spikes on telephone lines and/or power lines. > > When you use MOV's DESIGNED to clamp telephone line and power line > spikes, the voltage at which the device begins to absorb energy is > indeed on the order of 200 volts. When you buy 14-v transorbs, the > clamping voltage is about 20 volts. But clamping the reverse spike at zero tends to keep that reverse voltage spike completely out of your electronics. Sure, properly designed electronics will dissipate a reverse spike on the order of 20V and of relatively short duration (low energy) but not all electronics are well designed. I like the warm feeling I get knowing that, short of the diode dying open, that reverse spike never goes more than about 1V in the wrong direction thus keeping its energy really low. Sure, MOVs are great when you are trying to clamp spikes on an AC circuit where you might not know ahead of time which direction the spike is going to go and you still have to accommodate normal voltage going in both directions (polarity) but we have the good fortune in our airplanes of being able to say, "any DC power more negative than ground is bad." Plain ol' silicon power diodes work great, are cheap, and are readily available. Brian Lloyd Lucent Technologies brian(at)lcp.livingston.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6399 - voice +1.530.676.3442 - fax O- ________________________________________________________________________________
Subject: Re: My "Great" Titanium "Ti-downs", and the RV-List
Date: Sep 03, 1998
I bought 2 sets. One for my RV6A under construction and one as a gift for a freind who lends me his 172 now and then. I got to use the ones for the 172 a couple weeks ago when we were camping up on Beaver Island in Lake Michigan. It was quite windy (you know how windy airports can be, think of a flat surface 40+ miles long for the wind to get going) and the tie downs held it fine. I was surprised at how easily they twist into the ground with the bar provided. When I gave the plane back, the owner was impressed with them too. Several times he said "Titanium, no kidding" Brian Eckstein ---------- > > > Greetings RViators, > I'm Randy Simpson, owner of Airtime Mfg., maker of the Titanium "Ti-downs" > that many RV owners/builders already have purchased. I've been lurking on > this list since April, and even though I'm not building an RV (yet), I've > learned alot about what's involved in building a trick plane like the RV's > and (more importantly to me at this time) is hearing about how the RV's fly, > and the enjoyment the RV pilots experience (Corsair comes to mind here). > > First of all, ALL my dealings with my RV-List customers have been a > pleasure. Since I started selling the Ti-downs via the internet in April, > RV-Listers have been my only customers, as I had trouble keeping up with the > RV orders alone. I've had a policy that if I had the Ti-downs in stock, I'd > send them out immediately, and wait for the check to come in (at least till > I got burned). Nearly all my friends and family thought I was NUTS to be so > trusting. I'm happy to report that EVERY set I've shipped, the checks came > in as promised. KUDOS to you! > > It seems that if you've got a "better mousetrap", the world will beat a > path to your mailbox if you have a website also... > > Of all the sets of Ti-downs I've sold (havn't tallied up how many lately, > but probably 50-60 sets), none have been returned because they bent, or > broke. That's a good sign. I've been really testing them this summer, as > I've been doing alot of air-camping, using the Ti-downs whenever I can (even > if there are regular airport tie-downs already there). I've put 110 hours on > my Carrera Ultralight since the last week of May of this year (it's just: > work (fly), work (fly), work (fly). > > I'm all caught up with my backorders now, and have some sets in stock, > ready for immediately delivery. My son David and I spent the WHOLE weekend > in our shop "pounding out Ti-downs", despite the perfect flying weather. > We're trying to earn enough money for his tuition at a private school. It's > really great to be working side by side with my 14 yr old son, who will most > likely fly solo for the first time at the Alvord Desert (in SE Oregon) > fly-in a couple of weeks from now (weather permitting, of course). > > I'd like to hear from you if you have anything intresting to report about > the Ti-downs (good or bad). You guys that used the Ti-downs at Oshkosh, > how'd they work there? Please reply to me off list, or on list if you think > other Listers could benefit from your experience. > > I'm gonna donate a set (or "kit") to Matt Dralle as "thanks" for giving us > this excellent List. Thank you Matt, I appreciate it... > > Also, Sam Buchanan will have a set soon for his torture test/evaluation. > Look for his report in his RV Journal soon... > > Thanks for your time, > > Randy Simpson > Airtime Mfg. > http://www.airtimemfg.com > Current Ultralight Pilot > Future RV Owner/Pilot (I'm sure) > Brownsville, OR > > > > > > ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Audio Panels & PS Engineering
Listers, I sent a message to PS engineering(their website asks for ideas) concerning modifying King Audio panels upgrading them with additional features and/or intercoms. There are a gazillion of those out there and I have one. I have a KMA 24 and want to use it(primarily for the marker beacon), but would like to have a stereo intercom as well. Here is their response. Shelby GREAT idea, I actually had never thought of that. But after mulling it around for a while, the problem is that there isn't any extra pins that the intercom would require. The other problem for certified aircraft is the KMA24 would no longer be TSO'd if we were to modify it anyway. Thanks a lot for your idea, keep them coming, that's how we satisfy so many customers. Sincerely, Mark PS Engineering Mark, I think there might be a pretty good market among Homebuilders, also I imagine there are lots of certified aircraft that would like to upgrade(to one of your new units). There's the rub what do you do with all the units replaced by your unit. Well, you retro them and sell them to homebuilders. I don't know about the pin situation, but that would be a minor situation for guys like you. Still thinking, Shelby in Nashville I just spoke with our VP of Marketing and he likes your idea. We'll talk with our engineers and see what they think Again, thanks for your input. Sincerely, Mark Scheuer PS Engineering ________________________________________________________________________________
Date: Sep 03, 1998
><< The LRI uses a probe mounted below the wing with the two sensor > ports in it. It can be heated like a pitot tube for icing conditions. > There are two plastic tubes that run up to the instrument panel and that is > it. > >AOA: This fancy schmancy doo dad below has a digital processor for the LED > indicator about the size of standard aircraft rack radio. Boooo hissss... > Who needs all that ? Hmm, having lived in both mechanical and microprocessor worlds for doing computation, I frankly like the microprocessor one. Much simpler and much easier to calibrate. So, does Bruce Bohannon use standard mechanical magnetos or does he use one of those fancy schmancy electronic ignition doo dads with a digital processor about the size of a standard aircraft rack radio? Brian Lloyd Lucent Technologies brian(at)lcp.livingston.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6399 - voice +1.530.676.3442 - fax O- ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Re: IS IT LEGAL?
Brian: You should call Aero Sound Shield...they have a gold film that blocks out 99% UV, but very minimal light...it is not cheap, but if that is what you are into, then it is the only way to go... Their number is 818-374-5355 Paul Besing RV-6A (197AB) Arizona Waiting on finish kit http://www.doitnow.com/~rv8er > > > > > >>Brian, I believe the RV canopies all come tinted as standard. You have >to >>request clear. At least that is the way it was the last I heard/read. >I >>think there was an article in the RVator or here on the list concerning >>ultraviolet ray exposure that explained about this. >> >>Les Williams/RV-6AQ/Tacoma WA >> >> >> > >Les, > >Speaking of UV exposure, will the tint filter out enough to avoid >sunburning the occupants? Being a fair skinned person, this is a >concern. Arriving "poached and blistered" doesn't sound like fun. > >Brian Denk >RV8 fuselage > > > > > > ________________________________________________________________________________
Date: Sep 03, 1998
Corsair your visions are wonderful.. glad you stayed with us! And yes, there are still kids out there with dreams like yours. I'm one of them. 21, planing starting an -8 in the next year. 230hours (GA), 950hours (Ultralights) Total flying time so far, not much but it's a start! Keep up the good work!!!! :) Nick Nafsinger -8 planning stages..... -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Corsair Sent: September 3, 1998 1:43 PM To: rv-list(at)matronics.com Subject: RV-List: Courage to fly I began to fly because I was afraid. Nobody else I knew of was doing it. It was costly, risky, adventurous and not approved of by my folks. Something though, was pushing me onward. I learned to love it and it gave me something back. Pride, appreciation, and self esteem to face down trepidation. A while ago, I pushed the RV out to the grass and a fellow came by, full of questions, and declared proudly that he had once flown an Ercoupe, coast to coast and back...Awesome, for I too, had flown an Ercoupe to Mexico and back when I was a kid....I had to wonder what fires kids today ? Where is the courage and adventure ?....I thought of a time when a row of 20 Mustangs were retired and parked on the grass, I got into one and sat with canopy closed and hands on stick and throttle, visualized the boys who sat here before and what they may have experienced, and wondered if I would have the kind of courage that they had. The guns were now cold and the contrails were long gone, and I sat in that row of 20 Mustangs and thought back. I read once where in the Great War, most of the aces with big scores were teen-agers, frequently dead before their 20th birthday. Now, decades later, I was to summon up courage once more to try to be at one with an airplane that was more than anything I had experienced before. With each flight, we got to know each other better and time and thoughts were allowed to enjoy more of what was outside the cockpit. Time to look at the wings, and the color of them, the fields below, and the shading of clouds along the way. I climbed to 9,000, throttled back to turn and come back home, and glided quietly and thought how beautiful it all looked and how we too, must look beautiful, ruby, burgundy, and white, up against the blue. I thought of the serenity of flight by the wonderful flying scenes in "Out of Africa" and "The English Patient" and the inspiring music of the background. This would make anyone with a soul stir his passion for pure flight. This craft slipping along the halls of air, this cathedral of the skies. It is to weep. I read too of a man, who, this month, is about to fly a 70 year old biplane from London, back to Australia. An Avro Avian, retracing the steps of those like Antoine de St. Exupery who wrote in "Wind, Sand and Stars" of crossing the cold desert at night and the furnace of the timeless plains by day, all on a compass and map (if any). The drive and the courage is still out there in some. It is a reckoning with ones self. I am a teen no more and I still need to summon up nerve sometimes, but the winning of it still thrills me and the purity of flying is ever fresh to me. The RV lets me extend myself and brings me up to where the world is broad and grand and riotous with color and sensual delights. Landing once again is a handshake of two companions who have enjoyed each others company until the next time. Thank you Van, thank you RV, and thank you all out there..... ________________________________________________________________________________
From: "Jensen, Keith (MC R&D)" <KJensen(at)simplot.com>
Subject: RV6+ at Osh?
Date: Sep 03, 1998
You wrote: > > The aft bagged bulkhead was opened up and reinforced for the > passengers legs to fit further back into the fuselage. I personally > don't see enough room for two avg. sized adults but you can fit a > couple of kids back there with no problem. > > In case some are unaware, the two rear seats face backwards. It is visible, with some difficulty, in pictures I've seen on the Internet (don't ask me where). From a CG point of view, that makes sense. Personally, I'm not sure how many adults like to ride backwards - I don't, for one. Keith Jensen #25285, 6A rudder Pocatello, Idaho ________________________________________________________________________________
Date: Sep 03, 1998
In a message dated 9/3/98 2:12:22 Central Daylight Time, tinckler(at)axionet.com writes: Austin Tinkler You never cease to amaze me!!! I won't say your talents are wasted on the RV- Listers, for I would not want to endure their wrath, nor mine. Your words are so descriptive, and so inspirational, that I would like to see you compose something for the "Young Eagles Association." I think things like this, are the very thought provoking food for thought that might swing some reluctant young individual to join in the fun of flying. Regards Your friend Wendell WBWard(at)AOL.COM ________________________________________________________________________________
Date: Sep 03, 1998
Subject: 23 months later ...
... I am strapping my 10-year-old son, Seth, into the back seat; the four-point harness and cloth helmet snug. Feet in; I lower myself down; headset on; straps tight; canopy down, the latch makes that creak as it slides home; master on accompanied by the telltale "clunk" from the firewall; annunciator lights on the panel; the buzz as the needle-ball winds up. I wait about 3 seconds savoring the lights and sounds. Mixture forward, throttle forward and back, jab at the starter, and the engine catches as the first blade goes by. A few seconds later the faint but unmistakable scent of hot metal mixed with oil comes through the ventilation system. Taxi out, runup complete, temperatures up, checklist complete. I mash down the PTT and say, "Cameron Park traffic, experimental seven eight zero golf whiskey taking off runway 13, left downwind departure, Cameron Park." Throttle full forward, tail up, lots of right rudder, and the rumble stops at about 65 kts. I increase the foward pressure on the stick as the airspeed builds to 130 kts at the end of the runway. I release the forward pressure, the nose comes up, the VSI winds around to 4,000 fpm, and, "COOOOOOL!" comes through the headphones. Or was it just inside my head? Nose down, speed 120 kts, stick left, a little pull .. crosswind. Again ... downwind. I'm not flying; I'm just thinking and the outside world does what I think. Later, the headphones say, "do a roll!" I respond with, "like this?" The stick comes back and then left simultaneously with the word "this." The headphones laugh as the horizon spins. The headphones say, "do a couple more!" The stick comes back and then right and stays there as the horizon goes around twice. The headphones are laughing, "YEAAAAHHHHH!!!!" A 172 passes going almost the opposite direction and about 500 feet below. I say, "bandit at 10 o'clock low." Left stick and rudder. At about 130 degrees of roll I start the pull. The 'G' meter moves on up to 4. "Got 'im," say the headphones. Roll out, relax the back pressure and there is the 172 ahead and above the nose. A little pull; the 172's belly and tail get bigger, and the headphones say, "Ratatatatatatata!" and, "Got him!" Stick back, 3 G's, and the airspeed winds down out of the yellow. The headphones laugh some more. Later we sit on the ramp, canopy up, listening to the tinkle and creak from the cowl and smelling that new-engine-oil smell. Behind me the headphone voice says, "Let's do it again!" It echos in my head, "... again ... again ... again ... again ..." God, I love this. P.S. Seth and the dog race to see who can get my attention first as I walk through the door after work. Seth is showing me his latest find from the school library, a biography of Amelia Earhart. He regales me with the details of her first solo Atlantic crossing. Later he continues talking about how Bob Hoover was wounded in WWII and how, if things were a little different, it might have been Bob flying the X-1 instead of Chuck. And I am thinking that, just maybe, there is hope that love of flying won't die for at least one more generation. Amelia, Bob, Chuck, and a blue RV-4 are all part of that. God Bless You Glen Whitely, wherever you are. Brian Lloyd Lucent Technologies brian(at)lcp.livingston.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6399 - voice +1.530.676.3442 - fax O- ________________________________________________________________________________
Date: Sep 03, 1998
Mlfred(at)aol.com wrote: > Wait a minute- are there THREE different lift instrument manufacturers? I re- > read the email from Linda Frantz- she states their cost as $1450. Gary tells > me the LRI runs about half that, so $710 is in line with that. Tell me more > about this $474 job! Is it simply a stall indicator, vs a lift indicator? The > LRI and the AOA tells you at which angle your wing is flying: how close you > are to stall, or max L/D, etc. And then you could probably easily make your own. I saw several at Sun'n'Fun which looked like they were simply a potentiometer with it's arm sticking out the side of the fuselage with a wedge-shaped weather vane mounted on it (actually the wedge was aft of the pot arm, with a counterweight in from of it). I'm not sure how easily fuel sender pot's turn - but that may work. You'd have to calibrate the gauge scale in degrees rather than E-1/4-1/2-F, though. Finn ________________________________________________________________________________
Date: Sep 03, 1998
> Has anyone on this list installed an exhaust pipe / muffler system on > their RV in an attempt to get cockpit noise levels down. I'd sure hate to add the drag and weight, but I have to admit the set-up that Tony B. describes in "Sportplane Builder", consisting of a long muffler pipe faired in to the underside of the plane, is intriguing. As I recall he said it was pioneered by European builders and greatly reduces db output. Haven't seen any on RVs myself. Mind you I like airplane noise as much as the next guy, but I know most "ground-lubbers" don't, and it wouldn't hurt our image any if we started taking measures to quiet our birds. I wonder if all aircraft were muffled like cars, whether we would still be banned from the Grand Canyon, fighting to keep suburban airports and backcountry strips from closing, etc. etc.? Just a thought. Not that I'm planning anything like that (not any time soon anyway!) First priority is just to get the thing flying.... Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com ________________________________________________________________________________
Date: Sep 03, 1998
> >Despite my efforts to seal all the rivets in my 6A tank, I have three that >refuse to surrender. Has anyone come up with a good way to seal these after >the tank is complete? My first thought is to slosh the tank (I have not done >so yet). Rick, While I am not a builder (yet), I have often wondered if leaks such as your's could not be sealed with the application of a low viscosity sealant over the seams and rivets in the vicinity of the leak with the simultaneous application of a mild vacuum to the tank. If nothing else worked, I would try this myself. I would be very careful to, (1) keep the vacuum mild to avoid collapsing the tank,(2) use an approved sealant, and (3) Consider using some serious prayer :-) . Louis Louis I. Willig larywil(at)home.com (610) 668-4964 Philadelphia, PA ________________________________________________________________________________
Date: Sep 03, 1998
Avemco insures all our aircraft. I recently (last weekend) took the RV-4 off "ground risk only" and put it back on flying status. Since I intend to fly it on business, my company insisted that I increase the liability coverage to $2M and name them as an additional insured. At first Avemco declined but later, after continued pressure, relented and up'ed the coverage. I also asked about adding my 16-year-old student-pilot son, Cameron, to the list of approved pilots of the RV-4. The first response was, "we don't insure student pilots in homebuilts." I pointed out that he had learned to fly in a Piper PA-16 "Clipper" and that was a whole lot more difficult to handle on the ground than an RV-4. The agent, a CFI and taildragger driver himself, agreed with me and then agreed to put Cameron on the list of approved pilots for only a-heart-stopping-sum-of-money more per year. Oh, prorated for the rest of the year, of course. :^) So, yes, some of the "big boys" do insure homebuilts. Brian Lloyd Lucent Technologies brian(at)lcp.livingston.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6399 - voice +1.530.676.3442 - fax O- ________________________________________________________________________________
From: "Leslie B. Williams" <lesliebwilliams(at)email.msn.com>
Date: Sep 03, 1998
Randall, my info on the ACS cables is that they are now being custom made for Van's to the correct mounting length (7 1/2") and effective travel, and with the threaded sleeve to fit Van's bracket. I used Van's bracket and the same custom mounting length and threaded sleeve for my prop cable except that it is longer than the 45.5" that Van's stocks, and it works well. I did move the governor control arm a little forward on the shaft to get full movement although I've been told that it really isn't necessary to get full course as you will not ever use it. Les Williams/RV-6AQ/Tacoma WA > >Those of you with O-360 and MA4-5 carb wondering about using Van's >throttle bracket -- you might want to hold off getting a bracket for >just a little bit. > >I have discussed this with several people at Vans, and the bottom line >is that this bracket wasn't really designed for the O-360 and there are >some issues with its use on that engine/carb. > >They now have my carbeurator and are using it to prototype a bracket >for the O-360. It will be similar to the other one but will mount >between the carb and the sump. > >This bracket will still have the relatively short distance between the >mount point and the throttle/mixture arms, so if you are getting cables >from ACS for example, you will still have to get them custom sized. >I will post info on cable lengths when I get this all sorted out. > >Randall Henderson >Engineering Design Team, Inc. >randall(at)edt.com ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Oversquare operation is an old wives tale.
The following was taken from the Lycoming Flyer Key Reprints with permission. (1996 edition page 65-66) --------- Start quoted document --------- A Review of Old Wives Tales Tale Number One-- "The most likely time for an engine failure to occur is at the first power reduction after takeoff." ---------- CUT --------- For the sake of safety, lets stop repeating this false tale and start promoting the idea that we should be ready to deal with power failure at any time. A second old wives tale is still being promoted by some individuals. This tale involves the constant speed propeller and goes like this: "The RPM in hundreds should not be exceeded by the manifold pressure in inches of mercury." Referred to as a "squared power setting" (i.e. 2400 RPM X 24 inches of MP), it appears that this tale may be the result of a carry-over from some models of the old radial engines which were vulnerable to bearing wear at high power settings. Changes in engine design along with improved metals and lubricants permit changes in the operation of modern flat, opposed cylinder plants. Any pilot who believes that squared power settings continue to be necessary should be urged to read and understand the information in the Pilot's Operating Handbook (POH). While there are limits to the power which should be taken from most engines, particularly those which are turbocharged, the combinations of RPM and MP listed in the power charts of the POH have been flight tested and approved by the airframe and powerplant engineers. For example, if the POH chart lists 2200 RPM and 26 inches of MP as an approved power setting, pilots should not be apprehensive about using that setting if it meets their needs. Isn't it strange that some bits of information come to be believed by large segments of a population even when they are untrue? The two issues discussed above are good examples. Will it ever be possible to get all of our fellow pilots to reject the two false ideas outline here? Lets keep trying. --------- End quoted document --------- I have scanned several pages from the Lycoming Flyer Key Reprints on engine power sequence and old wives tales regarding Over Square operation. I can forward the scanned files to anyone that would like a copy. There are 8 files totaling 1.17 Meg are all in JPG format. It most likely will take several e-mail messages to send all the files. Many mail servers will not allow attachments over 500K. File name Size Lycoming Flyer page 3 107K Lycoming Flyer page 42 180K Lycoming Flyer page 43 175K Lycoming Flyer page 44 196K Lycoming Flyer page 45 181K Lycoming Flyer page 65 192K Lycoming Flyer page 66 182K If you would like a copy, please E-MAIL ME OFF LIST And I will try to send them out Monday night. == Gary A. Sobek RV-6 N157GS O-320 Hartzell Flying in So. CA, USA RV6flier(at)yahoo.com ________________________________________________________________________________
Date: Sep 03, 1998
Subject: See you at OSWEGO NY FORUM SEPT 12
________________________________________________________________________________ Dave; Thanks for the print-out. I've taken it to work and made a bunch of copies already. Could you please post the following on the RV List? 1. Canadian RV builders are invited to the RV Forum Sept. 12, 13. 2.Customs will be on the field. 3. Discussion on engine choice. Would anyone be interested in participating? 4. Welcome cook-out on Friday night. Forums on Sat. Pancake breakfast on Sunday, featuring RV's. Thanks Bill ________________________________________________________________________________
Date: Sep 03, 1998
Subject: skysports fuel senders
I am contemplating using the Skysports capacitance fuel senders in my tanks, and would like to know 1) if you are using them and are satisfied, and 2) how you installed them? I've found a previous post on installing them on the back baffle; I'm wondering if its possible to put them on the tank cover plate (like the float senders)? I'm not planning to gauge the whole whole tank, just the area near the root end. Alan Carroll Madison, Wisconsin RV-8 #80177 (Wings) ________________________________________________________________________________
Date: Sep 03, 1998
Check the archives. There was a thread on this about 6 months ago. I think the conclusion was that this stuff also interferes with the radios or GPS or something. Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 page at: http://members.bellatlantic.net/~moejoe Paul Besing wrote: > > > Brian: You should call Aero Sound Shield...they have a gold film that > blocks out 99% UV, but very minimal light...it is not cheap, but if that is > what you are into, then it is the only way to go... > > Their number is 818-374-5355 > > Paul Besing > RV-6A (197AB) Arizona > Waiting on finish kit > http://www.doitnow.com/~rv8er > > > ________________________________________________________________________________
Date: Sep 03, 1998
Randall wrote about that long tailpipe: > I recall he said it was pioneered by European builders and greatly > reduces db output. I suppose it reduces hp output too? hal fficult. Though my ribs >were as straight as I could make them, the flanges were not centered on the >holes when the skin was tight. After many frustrating attempts, I finally >opened the bottom skin enought to see inside. I reached in and lined the >rib centerlines up with the holes and after several attemptsand a llittle >blood I got all the ribs lined up. The skin is now strapped down tight >with a nice tight fit all around, the leading edge even matches nicely at >the joint. I will drill the bottom this morning. > I found that a pick through the holes in the skin could be used to move the ribs into position, but this is not a fun part of the building experience. Steve Johnson RV-8 #80121 ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Re: Burlington, Colorado Fly-In
The third annual Burlington Rv fly in will be on 19 and 20 Sep, which is Sat and Sun. Early arivals on Fri, 18th are encouraged. There is a $15 registration fee this year which includes lunch. Tickets will be on sale for the Sat nite dinner. Departures will be on Sunday. Van's will be represented. One really good motel with special rates is : Comfort INN (719) 346-7676. Camping is allowed. Free booth space for vendors. Must be RV related. Bring Tie downs as you may have to park on the grass. Attendance is growing each year. John Sterwart at Burlington (719) 346-8741. See you there D Walsh RV-6A ________________________________________________________________________________
Date: Sep 03, 1998
Subject: gone to homecoming
I have gone to Van's homecoming to get an RV fix that I need since my RV was totaled by a severe storm. If you need to contact me, do so directly. I will re-subscribe when I get back. Jim Cone jamescone(at)aol.com Repeat Offender RV-6A QB ________________________________________________________________________________
Date: Sep 03, 1998
My two cents . . . regardless of the canopy, always use a sunscreen and lip protector--even when you're not airborne. THe other concern is the intensity of the UV at altitude. I forget the exact statistics, but here in Denver we're told 15 minutes at a ski slope is equivalent to an hour on the beach in Miami (thinner air, less protection). I may have the numbers wrong on this, but you get the idea. Rick Jory Highlands Ranch, CO -----Original Message----- From: Brian Denk <akroguy(at)hotmail.com> Date: Thursday, September 03, 1998 1:42 PM Subject: Re: RV-List: IS IT LEGAL? > > > > > >>Brian, I believe the RV canopies all come tinted as standard. You have >to >>request clear. At least that is the way it was the last I heard/read. >I >>think there was an article in the RVator or here on the list concerning >>ultraviolet ray exposure that explained about this. >> >>Les Williams/RV-6AQ/Tacoma WA >> >> >> > >Les, > >Speaking of UV exposure, will the tint filter out enough to avoid >sunburning the occupants? Being a fair skinned person, this is a >concern. Arriving "poached and blistered" doesn't sound like fun. > >Brian Denk >RV8 fuselage > > > > > > > ________________________________________________________________________________
Date: Sep 03, 1998
From: Joe Larson <jpl(at)showpg.mn.org.showpg.mn.org>
Subject: Wing leading edges
I am in one crabby mood. I just took my first tank off the wing spar for the first time after drilling the ribs to the skins. Tomorrow I'll be re-ordering two or three of the ribs. People who have been having success drilling their prepunched leading edges -- what are you doing to get everything lined up? I've had no end of trouble. I spent *days* trying to get everything lined up before drilling, and I still screwed up several ribs. Things look pretty good at the base of the ribs, and I'm okay on bottoms where I started drilling, but twist in the ribs or something is causing all sorts of weird problems for the frontmost 6 to 10 holes on the top side. The holes creep to the edges of the flange. I *thought* I could see my centerline holes in the holes I was drilling, but obviously not. Grumble. -J ________________________________________________________________________________
Subject: RV's with Mufflers
Date: Sep 03, 1998
You asked...... >Has anyone on this list installed an exhaust pipe / muffler system on their RV >in an attempt to get cockpit noise levels down. Is it even feasible and would >it provide a measurable noise reduction if a builder had low noise as a design >goal? I helped a local 6 builder with the first engine start up on his airplane the other day, and the builder has a self built exhaust system that he copied from the ones that another local builder, Gerry Wilcox, has build for I think four RV's now. (Gerry posted a message asking for interest if he decided to build them for sale.) The system is a crossover with a muffler on the right side and one large exhaust pipe that exits the bottom of the cowl. This is on sixes, I don't think it would fit under a four cowl. Anyway, I was very surprised at how much quieter this airplane is than mine with a vetterman four pipe. I like the noise that mine makes, but this six was much quieter. I think it is quiter even than Gerry's six (muffler is larger maybe???) If you are interested, get hold of Gerry (have to check the archives for his email address, I don't have it) I promiced him I would take some photo's that he could email to people, but I have to borrow the digital camera from work, should have that done early next week. (I haven't forgot Gerry) Joe Hine C-FYTQ RV-4 ________________________________________________________________________________
Date: Sep 03, 1998
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
<3.0.5.32.19980902105832.00999100(at)158.222.8.12> <41116842.35ed5cc4(at)aol.com> >But clamping the reverse spike at zero tends to keep that reverse voltage >spike completely out of your electronics. Sure, properly designed >electronics will dissipate a reverse spike on the order of 20V and of >relatively short duration (low energy) but not all electronics are well >designed. I keep hearing this . . . one guy wrote me a long letter about how he NEEDED all the pullable breakers in his C-421 because of the processors that would lock up and he had to interupt the power to get them back on line. I can only wonder why anyone pays aircraft prices for pieces of equipment that operates that way and tollerates it! > . . . I like the warm feeling I get knowing that, short of the diode >dying open, that reverse spike never goes more than about 1V in the wrong >direction thus keeping its energy really low. Contrary to popular belief, diodes and/or MOVs across contactor coils is not for the benefit of avionics . . . it's for the switch that controls the contactor (remember the AD a few years back that ACS put out a kit for adding a diode across the starter switch of their key-lock switch? The starter contactor was eating the critter alive). I quite doing the DO-160 300 volt spike test on certified avionics when I discovered that a 10uF cap on the input totally wiped out the spike. Contactor spikes are even more benign . . . lots of gizmos coming onto the market are getting protection from the indirect effects of lighting . . . a few resistors and transorbs. >Sure, MOVs are great when you are trying to clamp spikes on an AC circuit >where you might not know ahead of time which direction the spike is going >to go and you still have to accommodate normal voltage going in both >directions (polarity) but we have the good fortune in our airplanes of >being able to say, "any DC power more negative than ground is bad." Plain >ol' silicon power diodes work great, are cheap, and are readily available. True . . and in fact, Revision 8 to our power distribution diagrams is replacing the MOVs with diodes. One of the things that prompted this was the fact that our current offering of starter contactors now comes with the diode built into the contactor. The other factor was the relative difficuties of finding low voltage MOVs. Soooooo . . . we're going to be sending off an article to Sport Aviation in a few days on how to deal with those little pieces of glass with solid wire leads. The article will appear on our website too . . . ________________________________________________________________________________
Date: Sep 03, 1998
<< Speaking of UV exposure, will the tint filter out enough to avoid sunburning the occupants? Being a fair skinned person, this is a concern. Arriving "poached and blistered" doesn't sound like fun. >> Actually, very little short wave UV gets thru Plexiglas (acrylic) or Lexan (polycarbonate) to burn you anyway. IMO, comfort is more an issue of reducing the heat of the sun impinging on the occupants, not really reducing the UV. -GV ________________________________________________________________________________
Date: Sep 03, 1998
On Thu, 3 Sep 1998, Finn Lassen wrote: > > And then you could probably easily make your own. I saw several at > Sun'n'Fun which looked like they were simply a potentiometer with it's > arm sticking out the side of the fuselage with a wedge-shaped weather > vane mounted on it (actually the wedge was aft of the pot arm, with a > counterweight in from of it). Am in the design phase of something like this. In an RV, you can't put it on the fuse because of the tractor prop. Have to put it out on the wing somewhere. Currently planning on a tube attached to the outboard most ribs, sticking out 1-2ft in front of the leading edge. Rather exposed to hanger/fly-in rash, will hang a big red remove before flight flag on it. > > I'm not sure how easily fuel sender pot's turn - but that may work. > You'd have to calibrate the gauge scale in degrees rather than > E-1/4-1/2-F, though. > I'm just picking up parts at a local electronic supply store, much cheaper than an aircraft fuel sender. Not going to calibrate in deg. just mark red line for flaps down stall, yellow zone for flaps only operation, lines for best glide, aproach speed, etc. (haven't totally made up my mind on this) Planning on putting a buzzer in for a stall warning, but don't want to complicate things too much by using a flap position sensor. Anybody know the difference in stall aoa for flaps down and up? Brian Huffaker, DSWL (huffaker(at)utw.com) President and Founder Friends of P-Chan RV-8 80091 Preparing 2nd wing spar ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Re: More on Cozy vs RV trades
<< Has anyone measured the typical sound levels in RVs? >> My 6A with O-360 c/s measured 104dBA on my sound meter at full tilt boogie. And I have good sound deadening installed in the tail, on the firewall, on the cabin sides and on the floor. The straight unmuffled pipes really do a number on us. Putting a muffler on would help reduce the noise somewhat but not to the point that you could go sans headsets and suffer a cumulative hearing loss over time. Our Lightspeed 20K ANR headsets reduce this level by 44dBA, so that puts us right at 60dBA, and is quite comfortable all day. -GV emco declined but later, after continued pressure, relented and >up'ed the coverage. I also asked about adding my 16-year-old student-pilot >son, Cameron, to the list of approved pilots of the RV-4. The first >response was, "we don't insure student pilots in homebuilts." I pointed >out that he had learned to fly in a Piper PA-16 "Clipper" and that was a >whole lot more difficult to handle on the ground than an RV-4. The agent, >a CFI and taildragger driver himself, agreed with me and then agreed to put >Cameron on the list of approved pilots for only >a-heart-stopping-sum-of-money more per year. Oh, prorated for the rest of >the year, of course. :^) > >So, yes, some of the "big boys" do insure homebuilts. > > >Brian Lloyd Lucent Technologies >brian(at)lcp.livingston.com 3461 Robin Lane, Suite 1 >http://www.livingston.com Cameron Park, CA 95682 >+1.530.676.6399 - voice +1.530.676.3442 - fax O- > > > > > > > ________________________________________________________________________________
Subject: Re: Throttle Bracket (was Re. Throttle Brackett..)
Date: Sep 03, 1998
> >Those of you with O-360 and MA4-5 carb wondering about using Van's >throttle bracket -- you might want to hold off getting a bracket for >just a little bit. > >I have discussed this with several people at Vans, and the bottom line >is that this bracket wasn't really designed for the O-360 and there >are >some issues with its use on that engine/carb. > >They now have my carbeurator and are using it to prototype a bracket >for the O-360. It will be similar to the other one but will mount >between the carb and the sump. > >This bracket will still have the relatively short distance between the >mount point and the throttle/mixture arms, so if you are getting >cables >from ACS for example, you will still have to get them custom sized. >I will post info on cable lengths when I get this all sorted out. > >Randall Henderson >Engineering Design Team, Inc. >randall(at)edt.com > > Actually what appears to have happened some time in the last few years is that precision made some slight changes in how they make the MA4-5 carb. I have personally installed said bracket on said carbs in the past with no problem. As Randall mentioned, Andy is working on a new bracket right now, but builders who want to use the color and shape coded controls can buy them from Van's now, specially sized to us with the brackets. Scott McDaniels These opinions and ideas are my own and do not necessarily reflect the opinions of my employer. in a localized area which wont effect the strength of the tank at all. BTW since the tank is now closed up you need to be careful of leaving metal drillings in the tank. You should try to flush out the tank well after doing this kind of repair. One trick you can use is to put some mixed tank sealant on any drill bits or countersink cutters that you use and all the drillings/cuttings will tend to stick to the sticky stuff. Then clean off everything after you are done. heavy grease could be used also but may contaminate the hole. It is not likely that you will contaminate the hole if you use something that you are going to put there anyway. ________________________________________________________________________________
Date: Sep 03, 1998
Subject: RE: RV-8 tank Skins
>I found fitting the skin to be very difficult. I kept the straps loose >while I drilled the top of the skin, reaching in to move the ribs as >needed. Strapping the skin tight prooved very difficult. Though my ribs >were as straight as I could make them, the flanges were not centered on the >holes when the skin was tight. After many frustrating attempts, I finally >opened the bottom skin enought to see inside. I reached in and lined the >rib centerlines up with the holes and after several attemptsand a llittle >blood I got all the ribs lined up. The skin is now strapped down tight >with a nice tight fit all around, the leading edge even matches nicely at >the joint. I will drill the bottom this morning. Use threaded rod through the tooling holes (the -8 does have tooling holes, doesn't it... the -6 did) in the leading edge and tank ribs. Secure the ribs with stop nuts run up on the threaded rod. This way, you can adjust the ribs until they are "just right", and hold them in place while you drill them to match the skin. I think this was mentioned in the -6 manual. KB ________________________________________________________________________________
Subject: Re: Wing leading edges
Date: Sep 04, 1998
> >I am in one crabby mood. I just took my first tank off the wing spar >for the first time after drilling the ribs to the skins. > >Tomorrow I'll be re-ordering two or three of the ribs. > >People who have been having success drilling their prepunched leading >edges -- what are you doing to get everything lined up? I've had no >end of trouble. I spent *days* trying to get everything lined up before >drilling, and I still screwed up several ribs. Things look pretty good >at the base of the ribs, and I'm okay on bottoms where I started drilling, >but twist in the ribs or something is causing all sorts of weird problems >for the frontmost 6 to 10 holes on the top side. The holes creep to the >edges of the flange. I *thought* I could see my centerline holes in >the holes I was drilling, but obviously not. > >Grumble. > Maybe you did this but in the event you didn't let's discuss how to drill the holes so they will line up on the ribs. Use a wide felt tip marker (one that will make a mark about 1/16" wide) to mark a line down the middle of the rib flange. As you drill thru the skin stop and see if the line is centered, left of center or right of center. You can't move that hole but you CAN move the next hole. Keep 'moving' the holes as you drill and you'll be within 1/16" of the centerline all the way down the rib. Another method that works is to hold a steel nail in the middle of the flange and, using a stud finder, locate the place to drill the hole. You'll only have to do this for the first hole since the line on the rib will work for the rest of the holes. BTW, I didn't have prepunched holes in my kit so I have to guess that the prepunched holes you're referring to are in the skin. If they're in the ribs my above advice isn't worth anything. John Ammeter ________________________________________________________________________________
Date: Sep 03, 1998
Brian, since several others have already replied to this, I will only add that I have used the cling type shades with success (although if not kept perfectly clean they will scratch the canopy badly) and I will be putting a Koger shade in my new -6A. Those things, along with the usual cap or hat, with neck scarf on the back, long sleeves and a good sunscreen coating is all that I know of that will help. Fortunately (I guess), I take a good tan, even on my balding head. Les Williams/RV-6AQ/Tacoma WA >Les, > >Speaking of UV exposure, will the tint filter out enough to avoid >sunburning the occupants? Being a fair skinned person, this is a >concern. Arriving "poached and blistered" doesn't sound like fun. > >Brian Denk >RV8 fuselage ________________________________________________________________________________
Date: Sep 04, 1998
Subject: Re: Canopy Screws or Rivets
I am at that stage where it is time to attached the canopy to the frame or rollover bar on the slider RV-6. Does anyone know why in some places the plans indicated attaching with screws and in other places with rivets. Does it matter? FYI, I had to shim the front part of the slider portion of the canopy about 3/8" in places. This seems excessive, but it will work. Also at least 1/2" spacers are needed on the center canopy frame attachement. I plan on using the Jim Cone solution and use Marine Tex to fill the gaps. Tests on canopy indicated no harmfull effects on the canopy. As I understand Jim's instructions he bonds the Marine Tex to the canopy frame only and not to the plexiglass, he uses screws or rivets to attached plexiglass to Marine Tex. Any comments, suggestions or warnings? Bob Busick RV-6 Fremont CA ________________________________________________________________________________
Date: Sep 04, 1998
Subject: Re: Oversquare operation is an old wives tale.
<< A second old wives tale is still being promoted by some individuals. This tale involves the constant speed propeller and goes like this: "The RPM in hundreds should not be exceeded by the manifold pressure in inches of mercury." Referred to as a "squared power setting" (i.e. 2400 RPM X 24 inches of MP), it appears that this tale may be the result of a carry-over from some models of the old radial engines which were vulnerable to bearing wear at high power settings. Changes in engine design along with improved metals and lubricants permit changes in the operation of modern flat, opposed cylinder plants. >> I'm aware of this info. But elsewhere in the Key Reprints book (pg 42) they mention the procedure to decrease power and they state to reduce throttle first. I disagree with this in the case I mentioned, as it seems that they themselves are perpetuating the myth of oversquare. Most people who have contacted me agree that after rotation and setting up cruise-climb, reducing the prop rpm first to 2500 rpm and then reducing throttle (or not) is quite acceptable and maybe preferred. In this case it is desirable to get a bigger bite of the air with a light plane and all that power up there. Other routine power reductions should probably be handled per Lycoming's recommendations for best longevity. -GV ________________________________________________________________________________
Date: Sep 04, 1998
<> I solved this problem by having a helper with a long stick push or pull on the ribs to keep them aligned while I did the drilling. I think I also started drilling in the rib midspan rather than on the front or rear. Hope this helps, I can understand the frustration, best thing to do right now is take a few days off before you make a real mistake. I would consider this a minor mistake based upon the ones that I have made, you might not think so, but at least you are not rebuilding the spar!. I must confess, I do have a lot of extra parts and skins that did not fit right or something went wrong along the way. My top rear fuselage skin was beaten into submission by my 150 pound Great Pyreenes Dog. On the second skin I did not have the bulkhead straight when I drilled, it looked like a salomn course of rivets. Third skin was bent in shipping and finally I got the fourth one to look good, but any of the four would have worked. Trust me you are not the only one to have these problems. Most problems can be fixed or rebuilt, but just keep this all in perspective, we are suppose to be having fun! This note is posted for all of you out there thinking that everything has to be perfect and you are probably wondering why you are the only person in the RV Universe that is making these mistakes. Trust me, I don't think there are any mistakes you can make that have not already been made. The more experienced builders just know how to fix them, or hide them, or paint over them! Good luck and keep at it. Bob "I promise no more mistakes" Busick RV-6 Fremont CA ________________________________________________________________________________
Date: Sep 03, 1998
Subject: where
Where do you people go to sell and buy rv's that are unwanted...Ie already started?completed. I have been told this is not the place...thank you...jolly ________________________________________________________________________________
Date: Sep 03, 1998
Subject: Havn't
How have you and yours been? I havn't heard from you for a while...we have been having a heat wave here all in the high 80's but no rain is nice for a change....I havn't done much with the music lately, and have been thinking of selling one of the Korg I-3"s, but somehow I hope somewhere in oregon they still like my type of music, instead of twanging guitars and people in big hats and smelly boots....I guess i'm getting old, and grumpy....Ha, I've always been that way!.....I guess I've let this foot problem get me down, but I've been talking to the guy upstairs, but no answer yet.(I think he's busy with a whole lot more important things)....Did they finall let you keep a dog? The other morning I looked out the window, and someone had dumped a little kitten out of a car onto the grass in frount of the house, the poor thing was on his last legs...There MUST be some good in people who do that kind of thing, but I sure can't find any.....If I catch one, however it would sure be tempting to open one up and look....anyway, we now have a free $125.00 kitten....but he is still with us, minus a few of the nine lives, but now he has a fighting chance....Dis you get another keyboard? and how are "things" over there? any Real radical changes? Or is that a forbidden subject? go to go, and clean up the shop from unlitterbox-trained kitten........jolly ________________________________________________________________________________
Date: Sep 04, 1998
One technique I have used is to use a fine point black Sharpie to mark the centerline on the ribs, and then go over that with the regular Sharpie in red, which makes a line about 1/8" wide. It is sometimes very difficult if not impossible to keep the fine line right under the holes, but by having the red under the hole, you will know that you are within tolerance. Otherwise, if you use only the fine line, if you don't see it, you have no idea where you are. Hope you can follow this, it worked great for me, in fact I did this on the whole project. Von Alexander RV-8 N41VA MAlexan533(at)aol.com ________________________________________________________________________________
trades
Date: Sep 04, 1998
Hal Kempthorne wrote: >Randall wrote about that long tailpipe: > >> I recall he said it was pioneered by European builders and greatly >> reduces db output. > >I suppose it reduces hp output too? > Not necessarily. Recently in Britain, a Jodel was modified with a tuned exhaust, which both reduced the noise significantly (so much that the aircraft now carries a horn to scare sheep off the owners' strip) and increased power by a few hp. I believe the numbers were 4 or 5 hp improvement on a 100ish horse engine. I'd have to look it up again to get the exact figures but you get the gist ;) -- Andy A blizzard is when it snows sideways. ________________________________________________________________________________
Date: Sep 04, 1998
> >People who have been having success drilling their prepunched leading >edges -- what are you doing to get everything lined up? I've had no >end of trouble. I spent *days* trying to get everything lined up before >drilling, and I still screwed up several ribs. Things look pretty good >at the base of the ribs, and I'm okay on bottoms where I started drilling, >but twist in the ribs or something is causing all sorts of weird problems >for the frontmost 6 to 10 holes on the top side. The holes creep to the >edges of the flange. I *thought* I could see my centerline holes in >the holes I was drilling, but obviously not. Had the same problem. - As the rib centerline markings slowly started to creep away from their pre-punched holes in the skin I used a smaller drill bit (1/16") to drill an off center hole inside the larger 3/32 skin hole. Then I used a small pick (ice pick) to maneuver the rib flange back towards center. Not perfect as you have limited room to move the rib but it did the trick for me. George McNutt, Langley B.C Picking up Fusalage kit at homecoming! The rib can be dead on at bottom and top and twisted towards center of skin.
August 29, 1998 - September 04, 1998
RV-Archive.digest.vol-fi
