RV-Archive.digest.vol-fp
October 10, 1998 - October 15, 1998
      Gary Zilik
      RV-6A s/n 22993 (fitting sliding canopy side skirts)
      Bob Skinner wrote:
      >   Have any 6/6A slider builders had any problems with the canopy latch
      > handle being too short?
      >   Also, was there an "AD" on the suspended rudder pedals on the 6/6A as
      > there was on the floor mounted rudder pedals?
Date: Oct 10, 1998
Subject: Re: New on list
Eustace Bowhay wrote: > > > Finally got a computer after much pressure from my RV friends. Still > trying to learn how to use it. Have been following the posts and hope I may > be able to contribute in some way. > > Eustace Bowhay C-FHAY RV6 (amphib. floats) > Blind Bay British Columbia > Eustace, Welcome to the list. By any chance, are you still a source for lycomings?? Jerry Calvert Edmond Ok -6a wings ________________________________________________________________________________
Date: Oct 10, 1998
Subject: Re: Ballistic Recovery System
> >They say the BRS can handle up to 1800lbs Gross weight, but I would think >the plane needs to be designed around the system. For instance, on an RV8, >where would you mount the thing so that you don't end up tearing the plane >apart when you have to deploy it at 225 MPH? I guess my point was that the plane would already be tearing apart when you deployed it. Say a wing seperation or some such. I most likely wouldn't deploy the chute for a simple engine failure. I don't know how much speed if any the aircraft would bleed off as it flips through the air minus one wing. I am not very confidant that if the plane was spinning wildly that I would be able to locate the deployment mechanism and operate it. I would assume that it has to >go right above, or near the CG. What would happen if it accidentally >deployed? Probably tear the plane apart just shortly before the 'chute departs the airplane. >Has anyone heard of a BRS saving the passengers in an 1800lb >airplane? Has it been installed on one? >I know they are testing it on that Cirrus, but are they actually >letting it hit the ground? You come down at something like 30FPS, and that's >still pretty fast. Yes be the idea is that the airplane absorbs much of the impact. If you get out with some scratches and broken bones that it still much better than hitting the ground sans wing. >The BRS is a viable solution for ultralights, but I don't >think they are quite ready to strap the thing to a high performance airplane >just yet, especially as a retro fit. Personally I don't think so either. I intend to wear a parachute in my RV, >and am asking around to see what I can do to make the canopy jettisonable, >as I've heard you can't get a slider open in flight. I just brought the subject up because people were thinking of BRS parachutes in terms of engine out emergencies. My point was that there are other failure modes in which a BRS deployment would make sense (as in a wing separation scenario.) I have no idea if a BRS could or even should be installed for the very reasons you give. Merely that one should think about these things. > >Moe Colontonio >moejoe(at)bellatlantic.net >Check out my RV-8 Page at: >http://members.bellatlantic.net/~moejoe > > > > >> >>> >>>Van also commented about a BRS in a recent RVator - he said, as I recall, >>>that the structural changes needed would be extensive, and he thought that >>>the weight penalty would be great - as I recall his remarks. >>> >>>We had one plane here (a Canadian ultra-like plane, a "Beaver") that had >an >>>engine out incident. Rather than deploying the BRS (it costs a lot to have >>>them repacked) the pilot elected to put it down in a fairly clear field; >>>only one tree in the area. You guessed it, he put it down into the tree >>>top. Fortunately he's OK, the plane is pretty well smashed up tho! Maybe >>>the BRS isn't too good an idea in all circumstances! >> >> >>This is probably a terribly insensative thing to say, but I never been >>known for my diplomacy. If I was building an RV-8, I would think long and >>hard about putting a BRS into my plane. At least until they find out why >>that wing came off.... >>-- >>Scott VanArtsdalen >>svanarts(at)jps.net >> >>"The essence of character is doing what's right, >>even when nobody's looking." >> - J. C. Watts >> > > > > > -- Scott VanArtsdalen svanarts(at)jps.net "The essence of character is doing what's right, even when nobody's looking." - J. C. Watts ________________________________________________________________________________
Date: Oct 10, 1998
Subject: Re: One Flight Test View on BRSs
>Again, think about the conditions in which YOU would deploy the chute. Here >are three "typical" scenarios where chutes are deployed. > >1. The airplane is in unrecoverable high speed flight (Mach tuck, poorly >performed split-S, ...). Here, a smaller chute out the back of the airplane >is the best answer - yet loads are VERY high. > >2. The airplane is in an unrecoverable stall and/or spin. Here, a chute out >the aft end of the airplane works well (known as a spin chute), but you'll >want to be able to release it later. > >3. The airplane has structural damage. If the airplane is structurally >damaged, it will most likely NOT be doing straight and level flight. Where >is the chute going to go? Will it be a good umbrella, a streamer, or put >the nose, tail or top of the aircraft toward the ground? > >If you want to save something, make it yourself, and improve YOUR odds of >survival; ditch the aluminum. If you fly acro, wear a chute (and fly high >enough). When performing hazardous tests, we carry four chutes - two on the >aft end of the airplane and one on each of us. Both chutes on the aft end >of the airplane are high speed or low speed, depending on the test. Both >shoot out the aft end of the airplane (one at a time), and both can be >released from the airplane after the event is over. They are designed to >bring the airplane back to a stable condition (not designed to save the >aircraft but rather to allow the crew to get out if recovery cannot be >accomplished from the chute deployed flight condition). > >Fly smart. Adding stuff doesn't always make the airplane safer. Excellent points. I wouldn't try to argue against them. This is the type of discussion I was trying to provoke. I said in an earlier reply that if the airplane was sans a wing and uncontrollable, I'm not so sure that I could locate and operate any kind of BRS deployment mechanism. >ps2 As for the -8 proto, I have 110% confidence in Van's design. All >airplanes will come apart when over-G occurs. The BRS would not have helped >here, either. This is the point that I really don't want to think about but I have to. It all boils down to the fact that it had to either be pilot error or a design flaw. Two scenarios that I hate to even ponder. -- Scott VanArtsdalen svanarts(at)jps.net "The essence of character is doing what's right, even when nobody's looking." - J. C. Watts ________________________________________________________________________________
Date: Oct 10, 1998
Subject: RV-6 Left Elevator Hits H. Stab Rear Spar Flange
Hung left elevator on horiz stab today and drilled elevator horn to center bearing. Noticed that elevator horn hits rear spar flange after "not much" down travel. Is this something where I'll trim the flange later on when setting limits on elevator? Or, have I somehow got the horns on backwards so the "wide" side is forward? I can't visualize (yet?) how I could have put them on with the "thin" side of horn forward to have more travel. David Carter, RV-6, starting wing (I hope - or starting two new elevators??) ________________________________________________________________________________
Date: Oct 11, 1998
Subject: Re: RV-6 Left Elevator Hits H. Stab Rear Spar Flange
David Carter wrote: > > > Hung left elevator on horiz stab today and drilled elevator horn to > center bearing. Noticed that elevator horn hits rear spar flange after > "not much" down travel. > > Is this something where I'll trim the flange later on when setting > limits on elevator? David, I don't know why Van does not include this in the manual. But the answer is Yes!, you will have to trim some of the flange away to get the proper down travel. Gary Zilik 6A 22993 fitting the frigging rear canopy skirts ________________________________________________________________________________
Date: Oct 11, 1998
Subject: Re: Registration and Taxes
And here in Wisconsin you pay sales tax (5.5%) and for Experimentals, a one time $50 registration fee that's good as long as you own it (applies to antique/classics as well). Jerry Springer wrote: > > RobHickman(at)aol.com wrote: > > > > > > I have the solution!! > > > > Move to Oregon and save the sales tax and shipping costs!! > > > > Rob Hickman > > RV-4 > > > Yup, no sales tax and it cost us $37.00 a year for state registration. > > Jerry Springer RV-6 N906GS First flight July 14, 1989 :-) Hillsboro, OR > jsflyrv(at)ix.netcom.com > -- Scott 1986 Corben Junior Ace N3642 Gotta Fly or Gonna Die ________________________________________________________________________________
Date: Oct 10, 1998
> >Hung left elevator on horiz stab today and drilled elevator horn to >center bearing. Noticed that elevator horn hits rear spar flange after >"not much" down travel. > >Is this something where I'll trim the flange later on when setting >limits on elevator? Or, have I somehow got the horns on backwards so >the "wide" side is forward? I can't visualize (yet?) how I could have >put them on with the "thin" side of horn forward to have more travel. > It is necessary to trim the flange. See archives. Larry Pardue Carlsbad, NM RV-6Q Cranked engine yesterday ________________________________________________________________________________
Date: Oct 10, 1998
Subject: Thanks for feedback on elevator travel
Thanks for putting my mind at ease. Now I won't have nightmares tonight. David Carter, RV-6, starting wings, Nederland, Texas ________________________________________________________________________________
Date: Oct 10, 1998
Subject: Nice RV-4 for sale / trade for 6/A
The RV-4 "ARSA Fighter" needs a new home. I've got a new bride who wants to share the front seat and learn to fly, I've got a new job and a new house, and those will take time that the RV-4 really needs for normal maintenance. The RV-4 has a fresh annual, 160 HP, gyros, GPS, and glideslope, and is worth $39K, other things being equal. However, it needs the new gear fairings put on, the spinner and backplate failed annual and were removed, so there's some cosmetic stuff to be done that I just don't have time for -- and all the shop tools are still in boxes, somewhere... Reasonable, genuine offers will be entertained. Low ball offers will be rejoined with puns. As part of the move, we'll have a new email address, so please phone queries to me at 425 898-9856 Ed Wischmeyer PS. Finder's fee of $250 ________________________________________________________________________________
Date: Oct 10, 1998
Dave, several of us (all that I have talked to) have had the same problem. We just notched the flange on the rear spar about 3/16-1/4 of an inch to get the necessary travel. This should not cause any structure problen, because the spar joins here and you have a butt joint anyway. Rollie RV6A Wing Kit to be shiped Octobere 12 ________________________________________________________________________________
Date: Oct 11, 1998
Re RV-8, you said "This is the point that I really don't want to think about but I have to. It all boils down to the fact that it had to either be pilot error or a design flaw. Two scenarios that I hate to even ponder". The exact cause of this and many other accidents may never be known. There are other potential causes. Something I can imagine happening involves a blockage, jamming or passenger obstruction of the flight controls that the pilot is attempting to overpower (read pulling with both hands) the blockage suddenly releases causing subsequent overstress! In my humble opinion the facts released to date boil down to nothing as to initial cause, and it is unfair to the pilot and/or designer for ameteurs to speculate publicly. George McNutt 6A wings Langley, B.C. ________________________________________________________________________________
Date: Oct 11, 1998
Subject: Re: Nice RV-4 for sale / trade for 6/A
I think I know where your plane is. Send me the 250.00 and I'll tell you. ________________________________________________________________________________
Date: Oct 11, 1998
Subject: Desiccant plugs
On 7 Oct 98, at 19:57, Joe D Wiza wrote: > It was suggested from a reliable source to fill the compression chambers > with oil turn the engine upside down and fill with approx 5 gallon's of > oil. (long term storage) any comn\ents. planejoe(at)aol.com fusleage Lycoming tech support made that same suggestion to me some time ago. If it weren't for all the work involved in removing a hooked up engine I'd do it that way. _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023 on gear, engine mounted Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ________________________________________________________________________________
Date: Oct 11, 1998
Subject: rivet substitutes- 6A
Does anybody know of a substitute for a solid rivet in a structural area? What about a cherry max? I'm referring to an occassional substitute of course. I'm having trouble with one of the rivets that joins the hs405 to the front spar. I'm working inside an acute angle here with no luck. Thanks, Adrian Chick rv6a. ________________________________________________________________________________
Date: Oct 11, 1998
> >Re RV-8, you said > >"This is the point that I really don't want to think about but I have to. >It all boils down to the fact that it had to either be pilot error or a >design flaw. Two scenarios that I hate to even ponder". > >The exact cause of this and many other accidents may never be known. There >are other potential causes. Something I can imagine happening involves a >blockage, jamming or passenger obstruction of the flight controls that the >pilot is attempting to overpower (read pulling with both hands) the >blockage suddenly releases causing subsequent overstress! >In my humble opinion the facts released to date boil down to nothing as to >initial cause, and it is unfair to the pilot and/or designer for ameteurs >to speculate publicly. But now you've just blamed the passenger and that isn't fair either. You know and I know that the NTSB is only going to chalk it up to one of two things.... But this is getting off my original point. -- Scott VanArtsdalen svanarts(at)jps.net "The essence of character is doing what's right, even when nobody's looking." - J. C. Watts ________________________________________________________________________________
Date: Oct 11, 1998
Subject: Another Gear Failure
Listers: While at Copperstate yesterday, it seems that another nose gear on a -6A has failed. I have only heard preliminary reports, but it failed on landing and beat up the prop...I will post more info if I get any more info...maybe Scott knows something about it? Paul Besing RV-6A (197AB) Arizona Finish Kit almost here! http://www.doitnow.com/~rv8er Paul Besing RV-6A (197AB) Arizona http://www.doitnow.com/~rv8er Waiting on finish kit ________________________________________________________________________________
Date: Oct 11, 1998
FWIW, my manual dated 11/17/97 didn't have the instruction but they updated it in the manual dated 4/28/98. It needs to be removed. Be careful, DO NOT cut into the HS-409PP bar. Jeff Farrar, RV8A, Empennage complete, QB due in Nov., Chandler, AZ -----Original Message----- From: Gary Zilik <zilik(at)bewellnet.com> >> >> Is this something where I'll trim the flange later on when setting >> limits on elevator? > >David, > >I don't know why Van does not include this in the manual. ________________________________________________________________________________
Date: Oct 11, 1998
Subject: RV-8 pictures updated
I have updated my web site with some new fuselage pictures, including installing the landing gear, tail, and engine. Check them out...comments welcome. Jim Cimino RV-8 sn 80039 http://www.geocities.com/MotorCity/5771 (717)842-4057 N.E. Pennsylvania ________________________________________________________________________________
Date: Oct 11, 1998
What if only Monica is looking??? >Scott VanArtsdalen >svanarts(at)jps.net > >"The essence of character is doing what's right, >even when nobody's looking." > - J. C. Watts ________________________________________________________________________________
Subject: Archives
Date: Oct 11, 1998
Am I the only one having trouble with getting messages back from the archives? I can get a good list of searches, but no response when one is selected. Have noticed this for some time now. Am I doing something stupid? ________________________________________________________________________________
Date: Oct 11, 1998
Subject: RV-8 Engine
Anybody want a LOW TIME "Dick De Mars" prepared AEIO-360 200 hp Lycoming engine and prop for $15,000.00? (Not a Wreck or a run out) Call Tom Hahn at 561-465-0003 for details. ________________________________________________________________________________
Date: Oct 11, 1998
Subject: Re: Rv-4 wing
I am just about finished with my wings and was wondering how other builders trimmed off the outboard inch of the main spar where it interfers with the instalation of the wingtips. Also, before I skin the tops of the wings, is there any reason ( such as having the FAA inspector inspect the inside of the wing) that I should leave the top skin off until later? Thanks in advance. Brian Trubee RV-4 #2366 ________________________________________________________________________________
Date: Oct 12, 1998
This was all discussed some time ago, and my comments are still in the archive. I'll give them again, briefly: 1. Most engine failures are due to running out of gas. Therefore it would be better to add 25 lbs of gas to your plane than 25 lbs of BRS. And an ounce of commonsense to your head. 2. Many other RV crashes are due to low-level acro. A BRS won't help there. 3. In a 25kt wind, you'll come down at 25kts groundspeed under your BRS. If you fly your RV to a landing, you'll also be doing about 25kts groundspeed (assuming you land directly into wind), and with less vertical speed than under the BRS, AND you'll be landing under control. lottmc(at)datasync.com wrote: > Not meaning to be sarcastic, but, I would like to see how many rv > pilots could safely put there plane down in a few hundred feet in > a pinch. So what's the ground roll going to be with a BRS? Frank. ________________________________________________________________________________
Date: Oct 11, 1998
Subject: N925RV gear leg failure
Fred, Do you know if the manufacturing process of the nose gear leg has changed since your original (failed) gear leg was made? I believe that the main gear on the -8's are now shot peened for stress relief. When you installed the new leg, how well did it line up with your original bolt hole? I wonder if Scott McDaniels knows how well a new predrilled gear leg will fit on an engine mount that was originally predrilled from the factory. With $25K invested firewall forward, it may be cheap insurance to change the nose gear leg every 300-500 hrs. I'm a little spooked now that another -6A has lost a nose gear leg on landing. Thanks for keeping us up to date on this incident. Scott Gesele N506RV - Flying and about to add "Magnaflux the nose gear leg" to the annual inspection checklist ________________________________________________________________________________
Subject: Re: 6A Slider
Date: Oct 11, 1998
I thought my handle was a little short but was able to "make it work" for a few attempts, right up until two days before my inspection when I was double checking the latching and the handle exploded under tension. Now it's a little longer and works great. Marcus RV-6, Just took it camping, what a great airplane > > Have any 6/6A slider builders had any problems with the canopy latch > handle being too short? We don't have very good edge distance for the hole > through the latch tube even when drilling the hole through the bottom of the > aluminum handle. > ________________________________________________________________________________
Subject: Re: Tank screws
Date: Oct 11, 1998
Randy; I did not use any thread sealant on the tank screws, and have never heard of any suggestion or reason to do so. Von Alexander RV-8 N41VA N41VA(at)juno.com ________________________________________________________________________________
Subject: Lycoming engines
Date: Oct 11, 1998
I am no longer a source for engines. It is getting to hard to find quality cores or any cores for that matter with good records. Looks like we homebuilders have just about used up all of the good used engines. I have been refering any inquires to Sport Aero at 1 800 667 0522. Ask for Bart LaLonde. Unfortunetly for most of us working with limited bugets I can see the day when Van's new engines will likely be the best bet. Eustace Bowhay Blind Bay, B C ________________________________________________________________________________
Subject: Fuel sender floats
Date: Oct 11, 1998
Listers: Just finished installing my fuel tank senders, the standard Stewart Warner type from Van's. Van's packs a nice drawing in there that shows the bends in the float wire, and also the orientation of everything including the assymetrical floats. When installing according to these plans the rearmost tank stiffener seems to interfere with the float. When I flip the floats around then there's no interference but it doesn't match the plans. I went with the latter. Has anyone else notice this, or am I nuts? (don't want to have guage problems down the road) Randy Lervold -8, #80500, N558RL reserved Finishing wings Camas, WA ________________________________________________________________________________
Date: Oct 11, 1998
I took a piece of scrap aluminum, slid it between the spar stub and the skin, then used a Dremel tool with a cut off wheel to cut it back. The scrap keeps the cut off wheel from going into the skin. I just trimmed it enough so that the tips cleared. Kurt -----Original Message----- From: Bktrub(at)aol.com <Bktrub(at)aol.com> Date: Sunday, October 11, 1998 9:33 PM Subject: Re: RV-List: Rv-4 wing > >I am just about finished with my wings and was wondering how other builders >trimmed off the outboard inch of the main spar where it interfers with the >instalation of the wingtips. Also, before I skin the tops of the wings, is >there any reason ( such as having the FAA inspector inspect the inside of the >wing) that I should leave the top skin off until later? Thanks in advance. >Brian Trubee RV-4 #2366 > > > > > > ________________________________________________________________________________
Date: Oct 11, 1998
I used a 3" cut-off wheel in a die grinder, then sanded flush. It is tricky, so be careful. You can close the wing any time. If you may want to run more wires, mount antennas in the tips, etc, you can wait to close the final skin. If you are comfortable you have everything installed, you can close them now. I riveted the final skins (bottom in my case) after I finished fitting the flaps and ailerons. The only FAA inspection required is before the first flight. Tom Craig-Stearman tcraigst(at)ionet.net RV-4 64ST installing baffle seal material > >I am just about finished with my wings and was wondering how other builders >trimmed off the outboard inch of the main spar where it interfers with the >instalation of the wingtips. Also, before I skin the tops of the wings, is >there any reason ( such as having the FAA inspector inspect the inside of the >wing) that I should leave the top skin off until later? Thanks in advance. ________________________________________________________________________________
Date: Oct 11, 1998
Subject: Re: Mounting Engine
>Randy; > >Was that $14,250 for an engine from Aero Sport for a 0-320, or 0-360? > > >Von Alexander >RV-8 N41VA >N41VA(at)juno.com > Von, Mine is a O-320-D2A. I think the base price was around $11,000 - $11,500. I added electronic ignition, chrome, spin on oil filter, vacuum pump, and had him drop the alternator (too small). Total price $13,975. Add $330 for shipping, Regarding the alignment pins, I'm sorry to hear that some folks have had trouble. I guess I should have said "If you have an O-320-D2A and you want to save some time........." They worked great for me. Maybe I was just lucky or maybe it was the aviation God helping me out since he gave me such fits with the sliding canopy frame? Randy Pflanzer N417G "Special Angel" RV-6 Slider working in firewall forward. ________________________________________________________________________________
Date: Oct 11, 1998
Subject: Re: Lycoming engines
Eustace Bowhay wrote: > > > I am no longer a source for engines. It is getting to hard to find quality > cores or any cores for that matter with good records. Looks like we > homebuilders have just about used up all of the good used engines. I have > been refering any inquires to Sport Aero at 1 800 667 0522. Ask for Bart > LaLonde. > > Unfortunetly for most of us working with limited bugets I can see the day > when Van's new engines will likely be the best bet. > > Eustace Bowhay > Blind Bay, B C > Eustace, Hate to hear that you are out of the engine business. I've heard good things about the quality of your work. I,m dreading having to look for an engine because of the junk that is being misrepresented out there. Thanks, Jerry Calvert Edmond Ok -6a wings ________________________________________________________________________________
Date: Oct 11, 1998
Subject: Re: Front Gear Leg Failure Summary
Bad News: Thre was another 6A front gear leg failure yesterday at Copperstate. Owner was taxiing and leg broke just inside the motor mount housing. This was all I could find out about it. I'm sure there will be more info forth coming. Walt RV-6A N79WH ________________________________________________________________________________
Date: Oct 11, 1998
Subject: Midget Mustang
I love the RV4 and yes the 6 also and my Kfox is a happy little airplane and what could be nicer than a Cub -----but----in my dreams I fly a Long Midget Mustang. JR ________________________________________________________________________________
Date: Oct 11, 1998
Subject: Re: RV-8 Engine
WHAT KIND OF PROP? ________________________________________________________________________________
Date: Oct 11, 1998
Subject: Re: Midget Mustang
JRWillJR(at)aol.com wrote: > > > I love the RV4 and yes the 6 also and my Kfox is a happy little airplane and > what could be nicer than a Cub -----but----in my dreams I fly a Long Midget > Mustang. JR > Hi JR, I once saw a lovely lady who flies a polished Midget Mustang, ....she's in my dreams! Jerry ________________________________________________________________________________
Date: Oct 11, 1998
> >You can close the wing any time. If you may want to run more wires, mount >antennas in the tips, etc, you can wait to close the final skin. If you are >comfortable you have everything installed, you can close them now. I >riveted the final skins (bottom in my case) after I finished fitting the >flaps and ailerons. > >The only FAA inspection required is before the first flight. Yes ... but if you are working with an EAA Technical Counselor, then he would probably like to see inside the wings before the final skin is installed. You are using an EAA Technical Counselor aren't you?? The nearest one is easily obtained by asking at the next EAA Chapter meeting....:^) ... Gil (EAA TC #3661) Alexander > >Tom Craig-Stearman >tcraigst(at)ionet.net >RV-4 64ST installing baffle seal material mailto:gila(at)flash.net Gil Alexander, Los Angeles, CA ________________________________________________________________________________
Subject: RV-6 wins Copperstate Custom Built
Date: Oct 12, 1998
I am happy to announce that Dwain Harris' beautiful blue RV-6 won 1st place category for Custom Metal Built at Copperstate 98! Some guy with a Glasair (a local) won grand champion. I can't remember who/what aircraft won the metal category in 1996 but I do know that RVs have won this category since I started going in 1995 with Dennis & Joy Keith's RV-6A, and 1997 Copperstate Grand Champion Rich & Karol Hansen's RV-6A. Way to go Dwain! Paul Rosales RV-6A (yea, I know Dwain, just a -6A) ________________________________________________________________________________
Subject: Re: Another Gear Failure
Date: Oct 12, 1998
>While at Copperstate yesterday, it seems that another nose gear on a >-6A has failed. I have only heard preliminary reports, but it failed on >landing and beat up the prop.. > Just returned from Copperstate tonight.....Rich Hansen and I found Marv & Maxine Horn's RV-6A (stored) nose down in the farthest reaches of the worth, we were able to reach under and 'feel' inside the gear leg tube. We could feel that the gear leg snapped about 1/4-1/2" up into the tube. I'm hoping that he only needs another wood prop and lower cowl. No opinions here, just a shared observation. Paul Rosales ________________________________________________________________________________
Date: Oct 11, 1998
Marcus, It seems like the tube on the handle is a little short. A breaking handle while away from tools could be a little frustrating. I'm surprised that I've not seen any comments on this on the list (that I can remember). We drilled the hole through the lower part of the handle but that still doesn't give much edge distance on the latch tube. Bob Skinner RV-6 450 hrs. Buffalo, WY bskinr(at)trib.com >I thought my handle was a little short but was able to "make it work" for a >few attempts, right up until two days before my inspection when I was >double checking the latching and the handle exploded under tension. Now >it's a little longer and works great. >Marcus ________________________________________________________________________________
Date: Oct 12, 1998
Subject: Aerofab Trim Wheel
Has anyone out there tried the Aerofab trim wheel? I searched the archives, but could not find an actual user. If there are any users, could we have a pirep? Thanks. Joel Mclaughlin (trying to decide how to control the trim) ________________________________________________________________________________
Subject: Re: Air sickness
Date: Oct 12, 1998
I find the eardots work very well with no drowsiness, but they are only suitable for passengers as they can effect the vision. The effect is to cause a loss of short sight. On me this made it impossible to read. Brian > > I was crewing a sailboat a few years ago from Houston to Corpus Christi (a long > trip for me) and I was concerned about seasickness. My friend gave me a small > plastic dot which you stuck to the back of your earlobe. There was no hint of > seasickness for two days but I did get "dry mouth". The other guys on the boat > said the "eardots" were the way to go and pretty much the standard of the boating > community, especially for wives. I don't know what the drug is but it is > prescription. It may be a good solution for someone who doesn't know about it. See > your doctor. > > Joe Walker ________________________________________________________________________________
Date: Oct 12, 1998
The late Neil Williams, once World Aerobatics champion, says in his book "Aerobatics", that to avoid airsickness one should eat before flying and do the seat belt up tight to stop vertical movement off the seat. It is the change in pressure on one's seat which he claims causes the sensation of one stomach moving. He say's the stomach does'nt move, and strapping down tight eliminates the sensation. Unfortunatly the RV's have their harness attach points so far aft that no matter how tight the belt is it will not stop vertical movement. The present belt angle is only about 35 degrees off horizontal. NASA recommends 45 to 55 degrees. Van suggested a crotch strap would be helpful in an issue of RVator which showed a photo of one, but has not produced a drawing for same. I note that they are standard on the 8 and consider this a step in the right direction. I find that a tight belt does help in other aircraft so perhaps the retro fit of a crotch strap would help keep your wifes breakfast down. It would also stop your head from hitting the canopy, a not uncommon occurence in turbulence in low wing loading fast aircraft such as the RV's. Brian > > can a person get acclimated to motion sickness? ________________________________________________________________________________
Date: Oct 12, 1998
<< I am just about finished with my wings and was wondering how other builders trimmed off the outboard inch of the main spar where it interferes with the installation of the wingtips.>> I believe that the plans for the 6/6A state that one should cut a 1" x 1" chamfer on the top and bottom corners. << Also, before I skin the tops of the wings, is there any reason (such as having the FAA inspector inspect the inside of the wing) that I should leave the top skin off until later? >> The FAA doesn't care. If you haven't built your fuselage and rigged the controls you should wait until this is done. If you are done with the rigging you should let the EAA Technical Counselor check things out before you rivet final skins in place IMO. -GV ________________________________________________________________________________
Subject: F-633
Date: Oct 11, 1998
Anyone have a picture of the F-633 control column bolted in fuselage on a website? Regards Mike Comeaux Thanx ________________________________________________________________________________
Subject: Pig Roast, engine baffle hint, some advice
Date: Oct 12, 1998
Listers, For those of you who were close enough and didn' t take the time to go to Chet's pig roast at Sparta, IL, you missed a good time. That's too bad because Bob Pretzsch and I really enjoyed ourselves and had a great two hour cross country flight each way from central KY. One visitor came from MD! I hope this becomes an annual event. After going to Chet's pig roast, I finally found out where all of the clam shell RVs are! Around here, all I ever get to see is sliders and feel left out! :-) That made me feel more encouraged about mine. Now, the biggy for me. I asked about the clearance for the center baffle bulkhead to inlet duct clearance the other day. As usual, I got no answer to my question from the RV-list. I got my answer there when I peeked into a couple of inlets. For those of you behind me, it's about 1/4" to 3/8" to allow for side to side vibrations. You may want to seal that somehow, since it's a gap that could let out a lot of air, as well as the gapping hole behind the bulkhead that's formed by the transition of the inlet to the top of the cowl. Another thing I got out of the trip is that we are losing listers because the info coming out of the RV-list isn't as informative as it used to be. I know we all have time shortages that may not allow us to answer questions for the ones behind us; but, some of us must take the time if we are to keep this list open to what it's supposed to be used for. I have found that I can't even get simple questions answered anymore, when I ask. However, get a discussion going about ballistic chutes, and the tread goes forever. We must redirect our discussions somewhat to help our brethren who haven't finished and want to join those of you who have. Personally, I find the discussions about broken gear legs more informative than chute discussions since I like to think that ultralights need them more than we do. Of course, that just my opinion. Anyway, if you fellas could just take a little time to answer some of our questions so that we don't lose listers, it would be appreciated. We must stick together. As for me, I hate to do it; but, I've begun to transitioned back to getting my answers from Van's if I really want an answer to a question. I can no longer depend on you guys for them. It's sad; but, we are losing too many people on the list because they don't want zillions of uninformative messages and get fed up when they can't get help. Gee, it seems I've preached this before and got flamed for it. Jim Sears in KY RV-6A N198JS (Working in the engine area) ________________________________________________________________________________
Date: Oct 12, 1998
Welcome to the list Eustace looking forward to hearing about the floats and your other ideas pertaining to the RV. Joe Wiza planejoe(at)juno.com writes: > >Finally got a computer after much pressure from my RV friends. Still >trying to learn how to use it. Have been following the posts and hope >I may >be able to contribute in some way. > >Eustace Bowhay C-FHAY RV6 (amphib. floats) >Blind Bay British Columbia > > > > ________________________________________________________________________________
Date: Oct 12, 1998
Good post, Jim. I would answer your questions, but you're way ahead of me now. Thanks for posting the answers to your own questions. I'll need them one of these days. Steve Soule Working his day job at nights and on weekends Huntington, Vermont -----Original Message----- From: Jim Sears [mailto:sears(at)searnet.com] .......... we are losing listers because the info coming out of the RV-list isn't as informative as it used to be. I know we all have time shortages that may not allow us to answer questions for the ones behind us; but, some of us must take the time if we are to keep this list open to what it's supposed to be used for. I have found that I can't even get simple questions answered anymore, when I ask. However, get a discussion going about ballistic chutes, and the tread goes forever. ________________________________________________________________________________
Date: Oct 12, 1998
From: Carroll Bird <"catbird(at)taylortel.com"(at)taylortel.com>
> Regarding the alignment pins, I'm sorry to hear that > some folks have had trouble. I used these alignment pins on an 0-360 A1A and had no problems with them. There must be some difference in individual engines. Carroll Bird Buffalo Gap, TX RV-4 Just a few more months. ________________________________________________________________________________
Date: Oct 12, 1998
Subject: engine baffle hint
<< I asked about the clearance for the center baffle bulkhead to inlet duct clearance the other day. As usual, I got no answer to my question from the RV-list. >> Well, I was at Copperstate, so I'm writing this on Mon morning. Sorry. A rule of thumb (from Tony's wonderful books) is to be able to slide your finger between the baffling and the cowl. I've seen this posted before, so it may be in the archives, or at least it will be now! As with all baffles, seal it up with some of that nifty orange rubber stuff, prefreably the type with the re-inforcing threads in it. On another note: Has anyone become disillusioned with the uneven top edge on the rear baffle, and the associated small pcs of baffle strip you must cut to seal that area? Why not make that area a straight run, to allow for a tighter sealing baffle? You would cut the rear baffle a bit shorter, and fit a new upper edge with the appropriate bends and joggles to allow for a single pc of sealing strip to run from corner to corner. Check six! Mark ________________________________________________________________________________
Date: Oct 12, 1998
From: mailhost.onramp.net(at)mailhost.onramp.net (charles young)
Subject: Of Interest?
Top Headlines from AVweb's NewsWire WHITHER TRIMBLE? AVIONICS COMPANY POISED TO ABANDON GA MARKET? The last few weeks have not been good ones at Trimble Navigation. The manufacturer of avionics and other navigation devices closed out a very poor third financial quarter, losing $36.5 million, finding yet another way for an aviation-related company to turn a large fortune into a small one. On Monday of last week, Trimble informed the Mooney Aircraft Corporation that they are getting out of the GA nav/comm market. The move came after a vote by Trimble's Board of Directors which AVweb has been told was as surprising to the employees within the division as it was to Mooney. Mooney officials tell AVweb that Trimble's board voted to cut their losses and get out of GA to concentrate on more profitable ventures, and, indeed, Trimble issued a press release saying that it was restructuring its operations and ending production of certain products at its Austin, Texas plant where its GA operations are located. However,on Friday, Trimble spokesperson Leann McNabb would say only that the company is "reviewing and considering a number of options." She told AVweb no decisions have been made and that it will be at least a week before anything is decided. ________________________________________________________________________________
Subject: The short and the long of it
Date: Oct 12, 1998
Attended the RV fly in at Lebanon Airport (Just east of Nashville). I must say it was a terrific experience. Met Robert Redmon and Bill Libby experienced some formation flying for the first time along with valuable building tips. Couldn't have felt more welcomed by the local folks, plan on attending again next year hopefully with our completed rv6a. The wife and I each had a one hour flying lesson with Mike Seager in the rv6 excellent instructor a must for anyone contemplating eventual flight in the rv. However we just experienced an unexpected problem my wife is 5'2" and I'm 6 foot. I could reach the rudder peddles easily in Mike's plane but my wife had a problem. Even with pillow under seat and on back side her legs were straight out to the rudder peddles and up against the stick. If I move the peddles back that means I'll be crammed. Has anyone had the same problem? How about forming a U in the control stick on her side??? planejoe(at)juno.com RV6A/fuselage ________________________________________________________________________________
Date: Oct 12, 1998
In a message dated 10/11/98 11:12:40 PM Eastern Daylight Time, calverjl(at)flash.net writes: << Hate to hear that you are out of the engine business. I've heard good things about the quality of your work. >> He didn't say he was out of business. He said he was no longer a source for engine cores. Gary Corde RV-6 N211GC - NJ ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <stuckle(at)ifc.utc.com>
Date: Oct 12, 1998
Listers, Does anybody know when this particular kit was purchased. It would be very interesting to find that the failure was caused by "surface conditions we are now aware of --" on an older gear leg....... Buyer beware gentlemen, buyer beware...... Maybe it's time for us to pass the word on to others....... Fred Stucklen N925RV RV-6A E. Windsor, Ct > -----Original Message----- > From: rv6a(at)juno.com [SMTP:rv6a(at)juno.com] > Sent: Monday, October 12, 1998 12:25 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Another Gear Failure > > > Just returned from Copperstate tonight.....Rich Hansen and I found > Marv & > Maxine Horn's RV-6A (stored) nose down in the farthest reaches of the > it's > worth, we were able to reach under and 'feel' inside the gear leg > tube. > We could feel that the gear leg snapped about 1/4-1/2" up into the > tube. > I'm hoping that he only needs another wood prop and lower cowl. No > opinions here, just a shared observation. Paul Rosales > ________________________________________________________________________________
Date: Oct 12, 1998
Subject: Re: ...some advice
In a message dated 10/12/98 7:28:21 AM Eastern Daylight Time, sears(at)searnet.com writes: << Now, the biggy for me. I asked about the clearance for the center baffle bulkhead to inlet duct clearance the other day. >> Jim, I saw your question last week and didn't respond to it because I didn't understand it. I still don't know what the center baffle bulkhead is so I can't relate its position to the inlet ramps. Now that I see the answer to your own question I assume that you meant the clearance between the baffle and the cowling, perhaps more specifically the REAR bulkhead. (?) When I looked at your question I didn't have the time to try and figure-out what information you were looking for. If I took two minutes to think about it I'm sure I would have figured it out, but I looked at it and went on. This IS NOT meant to be a flame and is not directed (only) at you Jim but, please make sure your questions are clear and concise. I'm sure no one responded to your request because no one knew what a center baffle bulkhead was. Gary Corde RV-6 N211GC - NJ ________________________________________________________________________________
Date: Oct 12, 1998
Subject: RV4 canopy
Listers, Got back from Copperstate yesterday. While unloading the RV4 I noticed the first 4 rivets that hold the lower hinge half to the fuselage were popped. ?? The aft ones are fine?? This is with 197hrs ac time. Of course the question is why? Has any one else experienced this?? I do remember that pop rivets are used so the canopy will tear away for egress. RV4 273sb Stew Bergner CO. ________________________________________________________________________________
Subject: RE: Van's refusal to share info
Date: Oct 12, 1998
Bruce & listers, The message I sent out originally had a few more paragraphs that I decided were not worth sending out to the whole list. In them, I had basically stated that I have taken the stance that I would not consider legal action against Van's as I felt that it was non-productive for general aviation. In fact, I have said that to Van's organization from the very start, in writing. My concerns have been and continue to be for the overall safety of flying, not for financial gain or even the replacement of the funds spent on repairs (although it would have certainly helped... I'm not that well off..). It is my hope that the more recent failure of a front gear leg at CopperState now opens everyone's eyes to a potential problem that Mr. VanGrunsven seems to be keeping quite about. This failure, which seems to have happened while taxiing, emphasizes even more the need for everyone with an older kit date, or with more than 300 Hrs on their planes, to do a through inspection on their front gear legs. This "ounce of prevention" may prove to save you many $$$$$... As a side note, Based upon my recent experience, I would strongly suggest that the gear leg not be sent to Van's for analysis. Independent tests should be made first by a reliable testing house. Only after independent testing should the gear be sent to Van's. Van seems to be taking the attitude that these are "experimental aircraft and do not conform to the normal certification standards" and therefore failures should be expected. It is up to us, as the end users, to deal with "surface conditions we are now aware of--" Let's keep the channels of communications open........ Fred Stucklen N925RV RV-6A E. Windsor, Ct > -----Original Message----- > From: Bruce Knoll [SMTP:tripod(at)vvm.com] > Sent: Friday, October 09, 1998 9:09 PM > To: Stucklen, Frederic IFC > Subject: Van's refusal to share info > > Hi Fred, > > I am disturbed that Van will not share the metallurgical information with > you, the owner of the affected plane. The first suspicion is "what is he > hiding?". At the risk of being a rabel rouser, If it were me, I would > consider legal action. It is not Vans piece of metal, but yours and you > have a sales invoice to prove it. > I would suspect that you would share the information with the RV community > for our benefit. Perhaps the NTSB could get the info for you. > > I am starting (empennage) to build a rv6a. This deliberate non information > from Vans is certainly cause for pause and concern to me, and perhaps > others. Please keep the list and / or me informed of further developments. > > Thank you and good luck, > > Bruce Knoll > tripod(at)vvm.com > 254-770-1145 > Temple, TX ________________________________________________________________________________
Date: Oct 12, 1998
Winfield Bowers' RV-4 went down with 2 aboard. N741WB Paper said 2 dead. ________________________________________________________________________________
Date: Oct 12, 1998
Scott and listers: From my understanding, the manufacturing process for the front gear leg is different now as compared to how it was done back when I built my kit (1991) but I'm not sure when it changed. On my original leg, the mount /leg were fitted together after the manufacturing process. A new leg required refitting it to the motor mount. The new method is for the leg to be dimensionally the same between legs, making them interchangeable. There are other process changes, but I can't remember what they are..... Adding "Magnaflux the nose gear leg" to the annual inspection checklist is a good idea, but maybe every other year, or after a bad shimmy problem is more reasonable..... Fred Stucklen N925RV RV-6A E. Windsor, Ct > -----Original Message----- > From: Scott Gesele [SMTP:scottg(at)icsnet.com] > Sent: Sunday, October 11, 1998 3:34 PM > To: rv-list(at)matronics.com > Subject: RV-List: N925RV gear leg failure > > > Fred, > > Do you know if the manufacturing process of the nose gear leg has changed > since your original (failed) gear leg was made? I believe that the main > gear on the -8's are now shot peened for stress relief. When you > installed > the new leg, how well did it line up with your original bolt hole? I > wonder > if Scott McDaniels knows how well a new predrilled gear leg will fit on an > engine mount that was originally predrilled from the factory. With $25K > invested firewall forward, it may be cheap insurance to change the nose > gear > leg every 300-500 hrs. > > I'm a little spooked now that another -6A has lost a nose gear leg on > landing. > > Thanks for keeping us up to date on this incident. > > Scott Gesele N506RV - Flying and about to add "Magnaflux the nose gear > leg" > to the annual inspection checklist > ________________________________________________________________________________
Date: Oct 12, 1998
Listers; Just so the new ones know, it is possible to mount the engine without any 'alignment pins'. I am a first timer, and mounted my 0-360 in about an hour. I did have my son to help me, and I followed Vans directions in the manual. Everything went together fine. Von Alexander RV-8 N41VA N41VA(at)juno.com <"catbird(at)taylortel.com"(at)taylortel.com> writes: ><"catbird(at)taylortel.com"(at)taylortel.com> > >> Regarding the alignment pins, I'm sorry to hear that >> some folks have had trouble. > > I used these alignment pins on an 0-360 A1A and had no >problems >with them. There must be some difference in individual engines. > > Carroll Bird Buffalo Gap, TX > RV-4 Just a few more months. > > > > ________________________________________________________________________________
Date: Oct 12, 1998
I bought the plans to a M-1. . . . . then compared overall top-to-bottom end performance of the M-1 and RV-3. . . . . .talked to a couple Mustang pilots about why they never fly their aircraft anymore (had something to do with leading edge inconsistencies and 1-2 survivable stall/spin entries on base-to-final). . . . . .& now I have RV-3 SN45 project! Still like the looks of the M-1, especially when I envision the in-line 140hp LOM engine that is in Jim Ayers Maroon Marauder. . . .po' man's P-51. . . . . . . .? Rob Reece RV-3 SN45 (finishing spar mod on left wing) Socorro, NM -----Original Message----- From: JRWillJR(at)aol.com <JRWillJR(at)aol.com> Date: Sunday, October 11, 1998 9:38 PM Subject: RV-List: Midget Mustang > >I love the RV4 and yes the 6 also and my Kfox is a happy little airplane and >what could be nicer than a Cub -----but----in my dreams I fly a Long Midget >Mustang. JR > > > > > > ________________________________________________________________________________
Date: Oct 12, 1998
Subject: Re: engine baffle hint, some advice
<< I asked about the clearance for the center baffle bulkhead to inlet duct clearance the other day. As usual, I got no answer to my question from the RV-list. I got my answer there when I peeked into a couple of inlets. For those of you behind me, it's about 1/4" to 3/8" to allow for side to side vibrations. >> As with life, better questions get better answers. Using part numbers helps, as that reduces confusion. After all, what is a center baffle bulkhead? Another reason is that much of this info is actually in the manual. -GV ________________________________________________________________________________
Date: Oct 12, 1998
> >Listers; >Just so the new ones know, it is possible to mount the engine without any >'alignment pins'. I am a first timer, and mounted my 0-360 in about an >hour. I did have my son to help me, and I followed Vans directions in the >manual. Everything went together fine. > I am also a first-timer that also installed my engine (O-320D2J) without alignment pins. I did it by myself in less than an hour without any instruction other than the builders manual. In fact, I did it twice, because I initially forgot to install the infamous oil pressure port fitting. Mark Nielsen RV-6; 287 hours ________________________________________________________________________________
From: "Robert Acker" <robert.acker(at)ingrammicro.com>
Subject: Re: The short and the long of it
Date: Oct 12, 1998
> > However we just experienced an unexpected problem my wife is 5'2" >and I'm 6 foot. I could reach the rudder peddles easily in Mike's plane >but my wife had a problem. Even with pillow under seat and on back side >her legs were straight out to the rudder peddles and up against the >stick. If I move the peddles back that means I'll be crammed. Has anyone >had the same problem? How about forming a U in the control stick on her >side??? Joe, Check the archives for some good info on this problem. I am 6'4, my soon-to-be wife 5'4. I have fabricated a second set of pedals, identical to the first, which mount on three 3" standoffs (tubing with a bolt through it, blind nuts of the forward side of the first set of pedals). This brings the second set of pedals 3" lower and closer. Don't know how the braking will work out yet, if it doesn't we'll have to come up with another solution then. Rob Acker (RV-6Q). ________________________________________________________________________________
From: "Kirkpatrick, Pat W" <pat.w.kirkpatrick(at)intel.com>
Subject: Warp drive props
Date: Oct 12, 1998
Does any have any experience using the Warp Drive prop on a RV6A. I am starting my search for a prop and tring to gather any info I can. Thanks, Pat Kirkpatrick Rio Rancho, NM ________________________________________________________________________________
Date: Oct 12, 1998
> no answer to my question from the RV-list. > As with life, better questions get better answers. Using part numbers helps, > as that reduces confusion. After all, what is a center baffle bulkhead? > Another reason is that much of this info is actually in the manual. I must second that motion. I have rarely responded to a technical question openly, and have instead sent a post direct to the questioner. The reason is that there are 800 listers out there and I feel that there has GOT to be somebody that will answer and knows a lot more than I do. I really am sorry when I hear that a guy got no response as that is what the list is for. I just don't want to come off as a "know it all" 'cause I sure don't. Also, early in the game, I did post the odd technical answer only to get blasted by someone who really had a strong opinion and a different view. Who needs it ? If I can relate to a particular problem, I usually reply at length telling what I found. I still make boo-boos and yes, I still drill under my fingernails, I am still learning and I hope others get the help they need..Again...my apologies..Austin. ________________________________________________________________________________
Date: Oct 12, 1998
Subject: Re: RV4 canopy
In a message dated 10/12/98 9:57:32 Central Daylight Time, RVer273sb(at)aol.com writes: << I noticed the first 4 rivets that hold the lower hinge half to the fuselage were popped. >> Have you ever noticed any dark grey or black residue (smoking) around the rivets? If so, the indication is of relative motion between the rivets and the hinge. Based on the fact that the rivets let go, indicates that they "might" have been worn in two. (Relative motion.) Shearing is also a possibility. Shearing of the rivets could be an indication that the airflow may be getting under your canopy skirt, and trying to lift it off the fuselage. I'd really have to see it. Regards Wendell WBWard(at)AOL.COM Rebuilding the "Junkyard Dog" RV-4 Kit Memphis, Tennessee ________________________________________________________________________________
Date: Oct 12, 1998
Subject: Re: RE: Van's refusal to share info
Fred: Did your gear crack in the same place and in the way as the one in Copperstate? There was a posting, I presume you read, yesterday describing the type of failure. Joe Walker RV-6 Houston Stucklen, Frederic IFC wrote: > > Bruce & listers, > > The message I sent out originally had a few more paragraphs that I > decided were not worth sending out to the whole list. In them, I had > basically stated that I have taken the stance that I would not consider > legal action against Van's as I felt that it was non-productive for general > aviation. In fact, I have said that to Van's organization from the very > start, in writing. My concerns have been and continue to be for the overall > safety of flying, not for financial gain or even the replacement of the > funds spent on repairs (although it would have certainly helped... I'm not > that well off..). > > It is my hope that the more recent failure of a front gear leg at > CopperState now opens everyone's eyes to a potential problem that Mr. > VanGrunsven seems to be keeping quite about. This failure, which seems to > have happened while taxiing, emphasizes even more the need for everyone with > an older kit date, or with more than 300 Hrs on their planes, to do a > through inspection on their front gear legs. This "ounce of prevention" may > prove to save you many $$$$$... > > As a side note, Based upon my recent experience, I would strongly suggest > that the gear leg not be sent to Van's for analysis. Independent tests > should be made first by a reliable testing house. Only after independent > testing should the gear be sent to Van's. > > Van seems to be taking the attitude that these are "experimental > aircraft and do not conform to the normal certification standards" and > therefore failures should be expected. It is up to us, as the end users, to > deal with "surface conditions we are now aware of--" Let's keep the channels > of communications open........ > > Fred Stucklen > N925RV RV-6A > E. Windsor, Ct > > > -----Original Message----- > > From: Bruce Knoll [SMTP:tripod(at)vvm.com] > > Sent: Friday, October 09, 1998 9:09 PM > > To: Stucklen, Frederic IFC > > Subject: Van's refusal to share info > > > > Hi Fred, > > > > I am disturbed that Van will not share the metallurgical information with > > you, the owner of the affected plane. The first suspicion is "what is he > > hiding?". At the risk of being a rabel rouser, If it were me, I would > > consider legal action. It is not Vans piece of metal, but yours and you > > have a sales invoice to prove it. > > I would suspect that you would share the information with the RV community > > for our benefit. Perhaps the NTSB could get the info for you. > > > > I am starting (empennage) to build a rv6a. This deliberate non information > > from Vans is certainly cause for pause and concern to me, and perhaps > > others. Please keep the list and / or me informed of further developments. > > > > Thank you and good luck, > > > > Bruce Knoll > > tripod(at)vvm.com > > 254-770-1145 > > Temple, TX > ________________________________________________________________________________
Date: Oct 12, 1998
> I am also a first-timer that also installed my engine (O-320D2J) without > alignment pins. I did it by myself in less than an hour without any > instruction other than the builders manual. In fact, I did it twice, > because I initially forgot to install the infamous oil pressure port fitting. Ditto for me. I found it useful to tweak the engine alignment by jacking the hoist ever so slightly up or down for each bolt, to get it to line up. Did it in about an hour with help the first time, about 1/2 hour by myself the 2nd. Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com ________________________________________________________________________________
Date: Oct 12, 1998
Fred and others worried about nosegear failures: I have a solution to your problem! Build an airplane with the little wheel in back where it belongs. Even if it did fail, (don't think it ever has) it would not chew the prop. Helpfully, Tom Craig-Stearman tcraigst(at)ionet.net RV-4 builder donning asbestos apron and ducking behind flame shield > It is my hope that the more recent failure of a front gear leg at >CopperState now opens everyone's eyes to a potential problem ________________________________________________________________________________
Date: Oct 12, 1998
Sorry, Fred, I couldn't resist. I do sympathize with your failure. I hope you get back in the air soon. Tailwinds, Tom Craig-Stearman > It is my hope that the more recent failure of a front gear leg at >CopperState now opens everyone's eyes to a potential problem ________________________________________________________________________________
Date: Oct 12, 1998
Atx > Got back from Copperstate yesterday. While unloading >the RV4 I noticed the first 4 rivets that hold the lower hinge >half to the fuselage were popped. ?? The aft ones are fine?? >This is with 197hrs ac time. Of course the question is why? > Has any one else experienced this?? I do remember that pop >rivets are used so the canopy will tear away for egress. >RV4 273sb Stew Bergner CO. I remember reading that last year someone had a canopy come off inflight. Van reccomended that we double the number of rivets in the first and last few inches of the hinge. Tom Martin HR2 ________________________________________________________________________________
Date: Oct 12, 1998
You might try a hand brake, like a cher, 140. jd Robert Acker wrote: > > > > > However we just experienced an unexpected problem my wife is 5'2" > >and I'm 6 foot. I could reach the rudder peddles easily in Mike's plane > >but my wife had a problem. Even with pillow under seat and on back side > >her legs were straight out to the rudder peddles and up against the > >stick. If I move the peddles back that means I'll be crammed. Has anyone > >had the same problem? How about forming a U in the control stick on her > >side??? > > Joe, > > Check the archives for some good info on this problem. I am 6'4, my > soon-to-be wife 5'4. I have fabricated a second set of pedals, identical to > the first, which mount on three 3" standoffs (tubing with a bolt through it, > blind nuts of the forward side of the first set of pedals). > > This brings the second set of pedals 3" lower and closer. Don't know how > the braking will work out yet, if it doesn't we'll have to come up with > another solution then. > > Rob Acker (RV-6Q). > ________________________________________________________________________________
Date: Oct 12, 1998
Subject: Re: Warp drive props
In a message dated 10/12/98 2:27:02 PM Eastern Daylight Time, pat.w.kirkpatrick(at)intel.com writes: << Does any have any experience using the Warp Drive prop on a RV6A. >> I don't think it is recommended to use a composite prop on a direct drive (i.e.Lycoming) installation. There are guys on the list more knowledgeable than I, but I don't think it is a good idea. ________________________________________________________________________________
Date: Oct 12, 1998
Chet, Sorry you're having trouble getting your messages answered. I agree there seems to be an escalation of general BS the list which is one reason I frequently just scan through the Subject lines and delete any that don't look like I know/care about (e.g. BRS, primer, airsickness). One thing that would help is if people would modify the subject line when the subject changes. Another is to take the advice of the FAQ to heart, and really THINK before you post. I myself have a personal policy of responding only to technical issues, and ones that I think know something about. These BS sessions can be fun but the list has gotten too big to accomodate both them and the technical issues, IMHO. So about your question... From the original post I wasn't clear which area you were talking about but in the baffle plans I remember there was a specific distance of 1/4" to 3/8" between baffle and cowl. That's what I used. Randall Henderson, RV-6 (engine/finish) Portland, OR randall(at)edt.com http://www.edt.com/homewing ________________________________________________________________________________
From: "Jensen, Keith (MC R&D)" <KJensen(at)simplot.com>
Subject: Rivets in tip of Rudder
Date: Oct 12, 1998
To the list: I am using an Avery hand squeezer. I have put off squeezing the last tip rivets in the HS and VS because a standard yoke won't fit - I suspect a no-hole yoke will, though. I am just finishing up my rudder, and although I believe the tip rib on the bottom (R-404) is close enough to the edge to be reached by a no-hole yoke (within 5/16" of the edge) for those last several rivets, I'm not so sure about the last couple rivets on the top tip rib (R-403), which is set in about 3/4" from the edge. Has anyone out there actually used the Avery hand squeezer with one of the no-hole yokes (or for that matter a Chicago-type 214 pneumatic squeezer- the yokes are interchangeable with the Avery squeezer) to reach in and get those last rivets on the R-403? Will a 1" no-hole yoke fit? How about the 2-1/2" no-hole yoke? I'm concerned that the top taper on the 1" yoke rises too quickly to allow it to fit deep enough into that narrow space. I'm not even sure the 2-1/2" yoke will go in that far without hitting up against that taper. (FYI, I'm trying to avoid using "pop-rivets" or my 2X gun - personal preference.) I have put off buying a no-hole yoke about as long as I feel I can, but with a difference of $50 between the two sizes, on top of the freight and hassle to get them back and forth if I get the wrong one . . . well, you get the picture. Thanks Keith Jensen -6A emp, 25285 ________________________________________________________________________________
Date: Oct 12, 1998
> On another note: Has anyone become disillusioned with the uneven top edge on > the rear baffle, and the associated small pcs of baffle strip you must cut to > seal that area? Why not make that area a straight run, to allow for a tighter > sealing baffle? I assume you are talking about the zig that it makes on the left rear side (RV-6/6A)? I used a tip from Ken Scott: make a u-shaped, curved filler piece to fill in the top left rear area of the baffle. Make the front of the "U" flush with the rest of the baffle. That way the baffle seal material can go straight across all the way. Don't know how clear this is, email me if you need clarification. Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com ________________________________________________________________________________
Date: Oct 12, 1998
Subject: Re: rivet substitutes- 6A
Yes cherry max rivets are a frequently used substitute for solid rivets. I'm sure I'm not the only one who has resorted to their use on occasion! Expensive though so I use them only when I have to. Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com > Does anybody know of a substitute for a solid rivet in a > structural area? What about a cherry max? I'm referring to > an occassional substitute of course. I'm having trouble > with one of the rivets that joins the hs405 to the front > spar. I'm working inside an acute angle here with no luck. > > > Thanks, Adrian Chick rv6a. > > > > ________________________________________________________________________________
Date: Oct 12, 1998
> I'm now doing the final install on my RV-8 tanks. Question; is it > wise/smart/recommended to put Loctite (blue) on the screws? Is there > typically any need to remove the tanks during later installation other than > for leaks or something major? Since the tanks are fastened using self-locking nut-plates (at least the RV-6 is, I assume the RV-8 is too?), I don't think there's much point in using loctite. Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com ________________________________________________________________________________
Date: Oct 12, 1998
Subject: Re: Pig Roast, engine baffle hint, some advice
<< Another thing I got out of the trip is that we are losing listers because the info coming out of the RV-list isn't as informative as it used to be. I know we all have time shortages that may not allow us to answer questions for the ones behind us; but, some of us must take the time if we are to keep this list open to what it's supposed to be used for. I have found that I can't even get simple questions answered anymore, when I ask. >> Jim & list, Part of the problem at least for me, is that I dont like getting blasted when I give a piece of advise. Usually any advise I offer is from first hand experience ( Im flying and have been for a long time ). I try to give the pro's and the con's. I dont expect everyone to agree with the way I do things but it is another way to look at it. When I share my input about how the airplane flys or handles I am talking about how an RV4 handles, not my related experience in a cessna 150. In other words I dont want some one with no RV time telling me that my flying procedure could be better if I would just do such and such. The second problem is that the list has gotten so big. I find myself every night running through the list of E-mail and picking out only the subject material that looks interesting. I used to read it all, but it just takes to much time now. Many of the questions that come up have come up over and over and over again. I realize that many of the people on the list are new and its a new question to them. If people would use the archives more often it would help alot. These are just a few of my observations and I think you will find that these are some of the reasons we have lost so many valuable contributors to the list and why so many others are just quietly lurking in the shadows. Ryan Bendure Co. (RV4 131RB) ________________________________________________________________________________
From: "William G. Knight" <wknight(at)adelphia.net>
Subject: Re: Aerofab Trim Wheel
Date: Oct 12, 1998
Dear Joel, I tried the trim wheel and found that the house or the geometry was too short --ie., with the trim wheel in the center of its travel, the trim tab would be full up or down (I don't remember which). Since I had hooked it to the factory-supplied trim cable from Van's, this was clearly a design arror so I sent it back to Aero Fab for modification. That was two or three months agao but I have heard nothing from them since and have been too busy to ask them for the $250 I spent to be refunded. Caveat Emptor! -----Original Message----- From: McLaughlJR(at)aol.com <McLaughlJR(at)aol.com> Date: Monday, October 12, 1998 2:18 AM Subject: RV-List: Aerofab Trim Wheel > >Has anyone out there tried the Aerofab trim wheel? I searched the archives, >but could not find an actual user. If there are any users, could we have a >pirep? Thanks. > >Joel Mclaughlin >(trying to decide how to control the trim) > > > > > ________________________________________________________________________________
Date: Oct 12, 1998
Subject: Re: Rivets in tip of Rudder
use counter sink pop rivets, get used to the idea, they are inevitable, and you can't tell once installed and polished the top with scotch brite wheel ________________________________________________________________________________
Date: Oct 12, 1998
<< I asked about the clearance for the center baffle bulkhead to inlet duct clearance the other day. As usual, I got no answer to my question from the RV-list. I got my answer there when I peeked into a couple of inlets. For those of you behind me, it's about 1/4" to 3/8" to allow for side to side vibrations. >> >As with life, better questions get better answers. Using part >numbers helps, as that reduces confusion. After all, what is a >center baffle bulkhead? Another reason is that much of this info is >actually in the manual. OK, I'll buy that; but, in the past I've tried to be very complete with my questions so that I leave nothing out and still get no answers. If I make them complete enough for folks to understand, it's too long and your time too valuable. If I leave a little bit out and make it confusing, you don't have time to ask what I mean. That's what's missing today. Last year, when I joined this list, folks were willing to ask for that clarification. Today, it's an excuse not to help out. Sure, I can understand why someone wouldn't answer a question to something they haven't seen in ages; but, if one is fairly familiar with the item, a quick answer is usually going to be appreciated. That's the one thing I enjoy with the Grumman Gang discussion group. Maybe the RV folks could learn something from us Grumman drivers. We seem to be a bit more close knit than the RVers. As for that center baffle bulkhead, it's the parts 1 and 11 that make up the front center that's attached to the two floors. It's called the bulkhead in the instructions that come with the baffle kit. As for the inlet ducts, some of the older cowls may not have them. The newer ones do. When one pushes the top of the cowl down onto the baffles, the center bulkhead comes close to the inlet ducts. I needed to know how much to allow for any side to side motion in the engine to keep from messing up the baffle bulkhead or duct. I have now finished that portion of the work and am off to something else. BTW, my note got some responses. I will answer each individually off line, as I usually do. Jim Sears in KY RV-6A N198JS (Baffles and seals completed, except for RTV.) ________________________________________________________________________________
Date: Oct 12, 1998
I have some notes and pictures about this on my web page. You definately should get a no hole yoke, but even that will not solve your problem here. It is usually possible to get one of the rivets, but the rivet on the opposite side will usually have to be a pop. Trying to get a solid rivet in there can make a mess. -- Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 page at: http://members.bellatlantic.net/~moejoe Jensen, Keith (MC R&D) wrote: > > To the list: > I am using an Avery hand squeezer. I have put off squeezing the > last tip rivets in the HS and VS because a standard yoke won't fit - I > suspect a no-hole yoke will, though. I am just finishing up my rudder, and > although I believe the tip rib on the bottom (R-404) is close enough to the > edge to be reached by a no-hole yoke (within 5/16" of the edge) for those > last several rivets, I'm not so sure about the last couple rivets on the top > tip rib (R-403), which is set in about 3/4" from the edge. > Has anyone out there actually used the Avery hand squeezer with one > of the no-hole yokes (or for that matter a Chicago-type 214 pneumatic > squeezer- the yokes are interchangeable with the Avery squeezer) to reach in > and get those last rivets on the R-403? Will a 1" no-hole yoke fit? How > about the 2-1/2" no-hole yoke? I'm concerned that the top taper on the 1" > yoke rises too quickly to allow it to fit deep enough into that narrow > space. I'm not even sure the 2-1/2" yoke will go in that far without > hitting up against that taper. (FYI, I'm trying to avoid using "pop-rivets" > or my 2X gun - personal preference.) > I have put off buying a no-hole yoke about as long as I feel I can, > but with a difference of $50 between the two sizes, on top of the freight > and hassle to get them back and forth if I get the wrong one . . . well, you > get the picture. > > Thanks > Keith Jensen > -6A emp, 25285 > ________________________________________________________________________________
Date: Oct 12, 1998
From: "Scott Kuebler" <skuebler(at)CANNONdesign.com>
Keith, I just finished up my rudders / elevators and used the 1" Tatco no-hole squeezer for my end ribs. I believe the dimensions are relatively the same for the Avery model. The 1" no hole squeezer works great! I recommend it as the primary squeezer in all flush head rivet applications where it will reach. There is no flex in the head, therefore there is no tendency for the rivet shanks to bend over. Even with my 2" yoke the rivet shop head tends to come out a little bent (oval). This is primarily on #4 rivets. Needless to say I won't even use my 3" yoke on #4 rivets, it is barely good enough to use on #3's. As for using the 1" no-hole on the end ribs of control surfaces, it will be a little tight for the last rivet on each side, but can be 'persuaded to fit' for the couple that need it, even on the R-403. I wouldn't trust a 2 1/2" no-hole because of the potential flex of such a long thin yoke, but that's my opinion, I've never tried one. Scott Kuebler RV-6 (or 6a, haven't decided yet!) working on wings > > Has anyone out there actually used the Avery hand >squeezer with one of the no-hole yokes (or for that matter a >Chicago-type 214 pneumatic squeezer- the yokes are >interchangeable with the Avery squeezer) to reach in and get >those last rivets on the R-403? Will a 1" no-hole yoke fit? How >about the 2-1/2" no-hole yoke? > >Thanks >Keith Jensen >-6A emp, 25285 ________________________________________________________________________________
Date: Oct 12, 1998
Joe, No, mine broke outside the motor mount tube. the one at Copperstate was said to have broken inside the tube. But I suspect that it was due to the same metal fatigue problem that caused mine. Fred Stucklen N925RV RV-6A E. Windsor, Ct > -----Original Message----- > From: Joe Walker [SMTP:joewalk@hal-pc.org] > Sent: Monday, October 12, 1998 3:27 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: RE: Van's refusal to share info > > > Fred: > > Did your gear crack in the same place and in the way as the one in > Copperstate? There was > a posting, I presume you read, yesterday describing the type of > failure. > > Joe Walker > RV-6 > Houston > > Stucklen, Frederic IFC wrote: > > > > > > Bruce & listers, > > > > The message I sent out originally had a few more paragraphs that > I > > decided were not worth sending out to the whole list. In them, I had > > basically stated that I have taken the stance that I would not > consider > > legal action against Van's as I felt that it was non-productive for > general > > aviation. In fact, I have said that to Van's organization from the > very > > start, in writing. My concerns have been and continue to be for the > overall > > safety of flying, not for financial gain or even the replacement of > the > > funds spent on repairs (although it would have certainly helped... > I'm not > > that well off..). > > > > It is my hope that the more recent failure of a front gear leg > at > > CopperState now opens everyone's eyes to a potential problem that > Mr. > > VanGrunsven seems to be keeping quite about. This failure, which > seems to > > have happened while taxiing, emphasizes even more the need for > everyone with > > an older kit date, or with more than 300 Hrs on their planes, to do > a > > through inspection on their front gear legs. This "ounce of > prevention" may > > prove to save you many $$$$$... > > > > As a side note, Based upon my recent experience, I would strongly > suggest > > that the gear leg not be sent to Van's for analysis. Independent > tests > > should be made first by a reliable testing house. Only after > independent > > testing should the gear be sent to Van's. > > > > Van seems to be taking the attitude that these are > "experimental > > aircraft and do not conform to the normal certification standards" > and > > therefore failures should be expected. It is up to us, as the end > users, to > > deal with "surface conditions we are now aware of--" Let's keep the > channels > > of communications open........ > > > > Fred Stucklen > > N925RV RV-6A > > E. Windsor, Ct > > > > > -----Original Message----- > > > From: Bruce Knoll [SMTP:tripod(at)vvm.com] > > > Sent: Friday, October 09, 1998 9:09 PM > > > To: Stucklen, Frederic IFC > > > Subject: Van's refusal to share info > > > > > > Hi Fred, > > > > > > I am disturbed that Van will not share the metallurgical > information with > > > you, the owner of the affected plane. The first suspicion is "what > is he > > > hiding?". At the risk of being a rabel rouser, If it were me, I > would > > > consider legal action. It is not Vans piece of metal, but yours > and you > > > have a sales invoice to prove it. > > > I would suspect that you would share the information with the RV > community > > > for our benefit. Perhaps the NTSB could get the info for you. > > > > > > I am starting (empennage) to build a rv6a. This deliberate non > information > > > from Vans is certainly cause for pause and concern to me, and > perhaps > > > others. Please keep the list and / or me informed of further > developments. > > > > > > Thank you and good luck, > > > > > > Bruce Knoll > > > tripod(at)vvm.com > > > 254-770-1145 > > > Temple, TX > > > > > > > > ________________________________________________________________________________
Date: Oct 12, 1998
Subject: RV-6 Emp ordered: Took the plunge!
Hi everyone, Took the plunge at Copperstate on Saturday, wrote the check for a -6 emp kit. There goes *all* my spare time-- not to mention the money..... Hello, Avery? Take my money, please. No, not just some, all of it. Yes, I won't be needing it any more......I'm building an airplane.... Don Gates Lancaster, CA RV-6(A) Emp on order ________________________________________________________________________________
Date: Oct 12, 1998
> >Does any have any experience using the Warp Drive prop on a RV6A. I am >starting my search for a prop and tring to gather any info I can. > I live in Clear Lake Iowa. (home of Warp Drive) I talked to Dale about a Warp Drive prop for my Lawn Dart and he would not sell it to me for a 4 Cylinder Lycoming. Several people who have done it, but he said sooner or later they all start "growing hair" around the shank of the blade. Dale said they will not catastrophically fail just slowly deteriorate at the shank. He sells more props than he can build now so he is not putting much if any effort into 4 cylinder Lycomings. He had a O-360 test stand on a trailer and some one hitched up to it and stole it. Thus endeth the Lycoming program. He tested a really wild looking scimitar prop on a Glasair from Wisconsin for a while. I guess the performance was awesome. It flexed allot and worked like a C/S but it grew hair too. I have a friend who has one on a Miget Mustang I with an O-320 and he loves it but he doesn't fly it much at all. FWIW Tailwinds, -4 N240 "the pink panther" Warnke prop Doug Rozendaal dougr(at)petroblend.com http://www.petroblend.com/dougr ________________________________________________________________________________
Date: Oct 12, 1998
VON L ALEXANDER wrote: > > > Listers; > Just so the new ones know, it is possible to mount the engine without any > 'alignment pins'. I am a first timer, and mounted my 0-360 in about an > hour. I did have my son to help me, and I followed Vans directions in the > manual. Everything went together fine. > > Von Alexander > RV-8 N41VA > N41VA(at)juno.com > Somebody posted on the list a few years ago to take the engine mount off the airframe and bolt the mount to the engine, then bolt the mount/engine back to the airframe. This is what I did, it took about 1 1/2 hours to do the whole thing. Bolting the mount to the engine was the easy part. Craig Hiers RV-4 N143CH Tallahassee, FL. ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Re: Mounting Engine
>> Regarding the alignment pins, I'm sorry to hear that >> some folks have had trouble. > > I used these alignment pins on an 0-360 A1A and had no problems >with them. There must be some difference in individual engines. > > Carroll Bird Buffalo Gap, TX Carroll, There must indeed be some difference between engines. I used the Avery pins and the technique worked fine but there was no way the shorter of the pins would go through the lower right side mount. Like someone else on the list I got it throught followed by a bolt only to find that further progress was impeded by some piece of crankcase. I had to back out the bolt and the 50 calibre slug (much bad language deleted) and grind the pin about 30% shorter than supplied. I can only think that Lycoming must have fiddled with the casting. If you have a new Van's engine just check the lengths before you start pounding on the pins. Cheers, Leo Davies PS: I put my wings on for a final pre-paint fit on the weekend and everything fitted just nice. Flaps the right length. Rear spars centered in the clevis mounts at the appropriate incidence angle. Belly skins overlay wing skin to within 10 thou. This is a very very good feeling :-) LD ________________________________________________________________________________
Date: Oct 12, 1998
We at Belted Air have used the Warp Drive only. Due to the fact we are running a belt between the engine and the propeller has led to its success. The People at Warp in my opinion are the most honest in the propeller business. We have over 240 hours at present with nary a problem. We returned the plane to service just prior to Copperstate with new metal tipping. Just a note while we were testing our first prop on the Buick and while cutting off 4 inches one at a time under the guidance of the factory, it did not work as all expected, we returned the prop and they returned the full amount, something we have never experienced before, and tried another on the Chevy powered unit. It is a complete success with great preformance at very reasonable cost. So if your not running a Lycoming we feel it is a very good prop. ________________________________________________________________________________
Date: Oct 12, 1998
In a message dated 10/12/98 8:14:29 AM Pacific Daylight Time, stuckle(at)ifc.utc.com writes: << Van seems to be taking the attitude that these are "experimental aircraft and do not conform to the normal certification standards" >> Van is correct in this, but only to a certain point. If the analysis of the gear leg shows a problem in the manufacturing process, then I feel it is "still" up to Van to work with the vendor to adjust the process and produce a more reliable gear leg. Of course, it is prudent to do the inspections carefully. More importantly, if there is a problem only with "certain" gear legs of a certain vintage, it would be really helpful to those folks to know this. Jim Nice RV6A WA State ________________________________________________________________________________
Date: Oct 12, 1998
In a message dated 10/12/98 2:58:26 PM Pacific Daylight Time, skuebler(at)CANNONdesign.com writes: << I wouldn't trust a 2 1/2" no-hole because of the potential flex of such a long thin yoke, but that's my opinion, I've never tried one. >> For the $$$ they cost, you would think that they could give us one that didn't flex. ________________________________________________________________________________
Date: Oct 12, 1998
Ryan and listers, Very good point! I totally agree. Alot of the info could be handled off the list. RV4 273SB Stew Bergner ________________________________________________________________________________
Date: Oct 12, 1998
Subject: Fluctuating Fuel Flow Computer Indications
Listers, I just made the first engine run ups on my O-360 A1A. Everything went pretty well. The lightspeed electronic ignition made it the smoothest idling engine I've ever set behind. The EIS engine computer worked well, monitoring CHTs and EGTs (2 of each at a time, switchable between the front and rear cylinders), oil temp and pressure, rpm and manifold pressure, and fuel flow (among other things). I noted some odd fluctuations in the indicated fuel flow. At idle (920 rpm) with the boost pump off the indicated fuel flow would jump to around 2.8 gph, then slowly move down to as low as .3 gph, then it would hop back up to something near 2.8, and slowly work down again. My fuel flow transducer is between the fuel selector valve and the boost pump, and is preceeded by a pretty much straight pipe run of 10- 11" to minimize turbulence into the transducer. Any ideas? Does the carbeurator float bowl system cause this sort of up-and-down flow behavior? Thanks, Tim Lewis _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023, engine completed and tested Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ________________________________________________________________________________
Subject: Lycoming Magnetos
Date: Oct 12, 1998
Listers, I am looking for a pair of new or serviceable mags for an 0-320 Lycoming (modified 0-320-E2D). Some of you guys that converted to electronic ignition may have what I'm looking for. Contact off list if you have one or both. A hot lead will would be great if you don't have the mags! Jerry Isler RV4 #1060 Donalsonville, Ga ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Re: Riveting aileron
Charlie Kuss sent me some aileron construction photos for my web pages. The following are Charlie's comments; I've just added the URLs. Each file is about 130KB in size. I've now linked the drawing of someone else's bucking bar to my Bunny's Guide page <http://members.xoom.com/frankv/bunny2d.htm>... I guess I'll eventually link these photos too (but, until then, this message is the only way you'll find them!). Frank. Charlie said: On the 1st photo <http://www.geocities.com/CapeCanaveral/Launchpad/4808/ail1.jpg> (Close up of bucking bar in aileron) you can see the special bucking bar I made. It's original purpose was to aid bucking rivets on the inner flap ribs. The point on the bar is used to reach into tight corners. It's shape by sheer coincidence, was perfect for riveting the aileron skins to the spar. The other 3 photos <http://www.geocities.com/CapeCanaveral/Launchpad/4808/ail2.jpg>, <http://www.geocities.com/CapeCanaveral/Launchpad/4808/ail3.jpg>, <http://www.geocities.com/CapeCanaveral/Launchpad/4808/ail4.jpg> show how I managed the job solo. I find that after some practice, I can shoot and buck quite well by my self, IF I can reach. I'm 6"4" , have long arms and could barely manage to shoot the center rivets alone. For more normal sized people, reaching over the top of the aileron would work better to get at the center spar to skin rivets. ________________________________________________________________________________
Date: Oct 12, 1998
Subject: "Old Mans'" V6
In a message dated 10/12/98 7:25:10 PM Eastern Daylight Time, BELTEDAIR(at)aol.com writes: << We have over 240 hours at present with nary a problem. We returned the plane to service just prior to Copperstate >> How are you guys making out with your conversion? How 'bout an update. Gary Corde RV-6 N211GC - NJ ________________________________________________________________________________
Date: Oct 12, 1998
From: Charlie and Tupper England <cengland(at)netdoor.com>
> the RV4 I noticed the first 4 rivets that hold the lower hinge > half to the fuselage were popped. ?? The aft ones are fine?? Can you tell if the hinge is stressed when you open the canopy all the way? I popped about 8 or 10 a while back by letting it go too far past vertical. I called Van's for advice (I didn't build the plane). As I remember, they said to just use "hardware store" al. pop rivets, & it's ok to add a few as mentioned in another post. Charlie ________________________________________________________________________________
Subject: Re: RV-6 Emp ordered: Took the plunge!
Date: Oct 12, 1998
Don, Welcome to the RV List! You don't know how true your words are. At least, I didn't when I started. It is good that you found the 'List so early in the game. There is a whole lot of corporate "been there, done that" experience here, so don't be afraid to speak up when you get stuck. Happy riveting, Tom Craig-Stearman tcraigst(at)ionet.net RV-4 64ST installing baffle seal material > >Hi everyone, > >Took the plunge at Copperstate on Saturday, wrote the check for a -6 emp kit. There goes >*all* my spare time-- not to mention the money..... ________________________________________________________________________________
Date: Oct 12, 1998
>Joe, > > No, mine broke outside the motor mount tube. the one at Copperstate >was said to have broken inside the tube. But I suspect that it was due >to the same metal fatigue problem that caused mine. Being a concerned 6A owner, could you tell me if these failures were with an O-360 or O-320. I've noticed a difference in how the nose gear flexes more with the 360 due to the increased weight, not to mention the addition of a C/S prop. Dave Hudgins -6A Nashville ________________________________________________________________________________
Date: Oct 12, 1998
Subject: Re: Front Gear Leg Failure Summary, witholding information
Fred, Thanks very much for informing the list of the results of your investigation. This is info we 6A builders need. > As to why the front gear leg broke, Van has not released to me > the full metallurgy report, and does not plan to in the future. .. That doesn't sound good. Did Van's provide any reason why they won't tell you the results of the tests performed on the gear leg that came from your aircraft, which you voluntarily sent to Van's for testing? > However, I am a bit more critical of Mr. VanGrunsven's decision > to not share the metallurgy results with me. While his letter indicated > that my gear leg "had some surface imperfections" that lead to "metal > fatigue", I am still at a loss as to what these "imperfections" were, and > where they came from. >If it was a leg manufacturing process issue, are there any more out there that need to > be found? (Even ONE should be too many if it's "surface conditions we are > now aware of --" ....). More importantly, if it is a manufacturing issue, > why not communicate the findings to all builders as a warning so that > POSSIBLE PROBLEMS might be found prior to another failure. (I guess that's > what I'm doing...) Thanks for the warning. Given the Copperstate nose gear breakage I'm concerned. I'd sure hate to have my 1996-purchased nose gear drop my engine and prop on the concrete. Scott McDaniels, do you have any insight into Van's plans with regard to figuring out what's up with the gear leg failures, and informing Van's customers what measures we should take to prevent falures in our aircraft? Is something forthcoming? I'd be happy to hear that Van's is working the issue, and will tell us all what happened (results of analysis, history of manufacturing changes, etc), which gears are most at risk, and what we should do to prevent future nose gear failures. I'd be disappointed if Van's isn't going to share results/recommendations with the customers who have invested in a Van's aircraft. Tim Lewis Concerned _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023, engine completed and tested Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ________________________________________________________________________________
Date: Oct 12, 1998
---------- >From: Tom Martin <fairlea(at)execulink.com> >To: rv-list(at)matronics.com >Subject: Re: RV-List: RV4 canopy >Date: Mon, Oct 12, 1998, 1:14 PM > > >Atx >> Got back from Copperstate yesterday. While unloading >>the RV4 I noticed the first 4 rivets that hold the lower hinge >>half to the fuselage were popped. ?? The aft ones are fine?? >>This is with 197hrs ac time. Of course the question is why? >> Has any one else experienced this?? I do remember that pop >>rivets are used so the canopy will tear away for egress. >>RV4 273sb Stew Bergner CO. A friend of mine had a partial separation of an RV-4 canopy while doing a slow roll--the right edge popped up about 1" but the latch held and he was able to return to the airport. The separation appeared to start from the front edge like you describe. He is a very competent ex-military (F104) and airline type who was confident he was not overstressing or overspeeding the airplane. He felt it might have been related to a piece of foam weatherstrip under the hinge which put a constant load on it while closed. This happened several months before the in-flight canopy loss in Arkansas. I would definitely add the extra rivets. James Freeman ________________________________________________________________________________
Subject: Re: Fluctuating Fuel Flow Computer Indications
Date: Oct 13, 1998
> >Listers, > >I just made the first engine run ups on my O-360 A1A. Everything >went pretty well. The lightspeed electronic ignition made it the >smoothest idling engine I've ever set behind. The EIS engine >computer worked well, monitoring CHTs and EGTs (2 of each at a time, >switchable between the front and rear cylinders), oil temp and >pressure, rpm and manifold pressure, and fuel flow (among other >things). > >I noted some odd fluctuations in the indicated fuel flow. At idle (920 >rpm) with the boost pump off the indicated fuel flow would jump to >around 2.8 gph, then slowly move down to as low as .3 gph, then it >would hop back up to something near 2.8, and slowly work down >again. > >My fuel flow transducer is between the fuel selector valve and the >boost pump, and is preceeded by a pretty much straight pipe run of 10- >11" to minimize turbulence into the transducer. > >Any ideas? Does the carbeurator float bowl system cause this sort of >up-and-down flow behavior? > >Thanks, > >Tim Lewis > >_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ >Tim Lewis >N47TD (reserved) RV-6AQ #60023, engine completed and tested >Springfield VA That would be my guess. If the float was 'sticking' in the up position until the fuel level dropped enough to unstick it you'd likely get that kind of fuel usage. I'd definately check into it since you'd be in a world of hurt should the float stay stuck closed. John Ammeter Seattle WA USA 1975 JH-5 RV-6 (sold 4/98) ________________________________________________________________________________
Date: Oct 12, 1998
Subject: Rudder TE?!
Date: Oct 12, 1998
I'm having a hard time getting the proper trailing edge formed on my RV-8 rudder. I bend it until the leading edge is touching while in the wooden brake, but at rest, there is > 7" between the sides. The archives say I can fix this with the hand-seamer - is this still the prefered method? With or without the dowel in the TE? Any other ideas? Thanks, -Larry RV-8 Rudder. Advance, NC (8A7) Email: larry(at)bowen.com Web: http://larry.bowen.com ________________________________________________________________________________
Date: Oct 12, 1998
I agree; I want to know if my $45,000 investment is in danger of being trashed by a relatively easy to replace unit. Van owes us this information!!!!!! ________________________________________________________________________________
Date: Oct 12, 1998
Good for you , Don (snicker) welcome to our little spending world! I'm broke now,(thanks Van) Paul Besing RV-6A (197AB) Arizona http://www.doitnow.com/~rv8er Finish Kit Almost Here!!! > >Hi everyone, > >Took the plunge at Copperstate on Saturday, wrote the check for a -6 emp kit. There goes >*all* my spare time-- not to mention the money..... > >Hello, Avery? Take my money, please. No, not just some, all of it. Yes, I won't be needing >it any more......I'm building an airplane.... > >Don Gates >Lancaster, CA >RV-6(A) Emp on order > > > > > > Paul Besing RV-6A (197AB) Arizona http://www.doitnow.com/~rv8er Waiting on finish kit ________________________________________________________________________________
Date: Oct 12, 1998
Tim and List, I too have the EIS with the fuel management option. I've put 150 hours on my plane (Carrera U/L with Rotax 503) since the end of May. When I sent my EIS back to Grand Rapids Tech for an up-grade for adding the Fuel flow option (last year), Greg (the owner of EIS) said there was a Cessna pilot that installed the system, and the fuel flow readout bounced around alot, so Greg took it back and dampened it electronically (to stabilize it). All the EIS units after that has that damping built into the unit. Mine works really good, and I can see it change almost instantly when I change the throttle setting, then it stabilizes out in about 5 seconds. On one of my big cross country trips this last summer, the fuel flow started changing from 1 gpm to 10 gpm. It would slowly go up, then back down (the electronic damping kept it moving slowly). Turns out, some of my baggage had caught on the transducer, and rotated it down 90 degrees (it's supposed to be level, with the top side up). I straightened it back out, and the flow rate stabilized again. I'm assuming you did mount it right, so maybe vibration is affecting it. My transducer is suspended by the fuel lines to reduce vibration on it. I doubt the float in the carb is causing the fluctuations, but I suppose it's possible Good luck with the EIS. I sure love mine! Oh yeah, be sure to add the fuel pressure sender. It's nice to be able to monitor the fuel pressure (with alarm)... Randy Simpson Carrera Ultralight flyer Future RV flyer Brownsville, OR http://www.airtimemfg.com >I noted some odd fluctuations in the indicated fuel flow. At idle (920 >rpm) with the boost pump off the indicated fuel flow would jump to >around 2.8 gph, then slowly move down to as low as .3 gph, then it >would hop back up to something near 2.8, and slowly work down >again. > >My fuel flow transducer is between the fuel selector valve and the >boost pump, and is preceeded by a pretty much straight pipe run of 10- >11" to minimize turbulence into the transducer. > >Any ideas? Does the carbeurator float bowl system cause this sort of >up-and-down flow behavior? > >Thanks, > >Tim Lewis > >_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ >Tim Lewis >N47TD (reserved) RV-6AQ #60023, engine completed and tested >Springfield VA >http://home.earthlink.net/~timrv6a >timrv6a(at)iname.com > > > > > > ________________________________________________________________________________
Date: Oct 12, 1998
Tim Lewis wrote: > > > Listers, > > I just made the first engine run ups on my O-360 A1A. Everything > went pretty well. The lightspeed electronic ignition made it the > smoothest idling engine I've ever set behind. The EIS engine > computer worked well, monitoring CHTs and EGTs (2 of each at a time, > switchable between the front and rear cylinders), oil temp and > pressure, rpm and manifold pressure, and fuel flow (among other > things). > > I noted some odd fluctuations in the indicated fuel flow. At idle (920 > rpm) with the boost pump off the indicated fuel flow would jump to > around 2.8 gph, then slowly move down to as low as .3 gph, then it > would hop back up to something near 2.8, and slowly work down > again. > > My fuel flow transducer is between the fuel selector valve and the > boost pump, and is preceeded by a pretty much straight pipe run of 10- > 11" to minimize turbulence into the transducer. > > Any ideas? Does the carbeurator float bowl system cause this sort of > up-and-down flow behavior? > > Thanks, > > Tim Lewis > Tim The instructions that came with the Rocky Mountian engine monitor said to mount the Flo Scan transducer downstream of the boost pump and gascolator. Mine is mounted just past the gascolator and is rock steady. You might want to wait and see what it does while in flight with higher fuel flow before you change anything. Craig Hiers ________________________________________________________________________________
Date: Oct 12, 1998
>>A rule of thumb (from Tony's wonderful books) is to be able to slide your finger between the baffling and the cowl. I've seen this posted before, so it may be in the archives, or at least it will be now! << Mine had that clearance except where the inlet duct goes past the center bulkhead at the front behind the flywheel. I just wanted to be sure about the clearance on that little section. I got that info at the fly-in at Chet's. Thanks, Jim in KY ________________________________________________________________________________
From: "Moe Colontonio" <moejoe(at)bellatlantic.net>
Subject: Re: Rudder TE?!
Date: Oct 12, 1998
You really gotta lay into it Larry. Watch George do it in the video, he moves the whole bench. Make sure you flip it around, and move it back and forth too. It will take several tries, you won't get it all in one shot. If you're still not happy, try taking out the dowel and carefully tweaking it. I wouldn't mess with the hand seamers here. Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 Page at: http://members.bellatlantic.net/~moejoe -----Original Message----- From: Larry Bowen <larry(at)bowen.com> Date: Monday, October 12, 1998 10:46 PM Subject: RV-List: Rudder TE?! > >I'm having a hard time getting the proper trailing edge formed on my RV-8 >rudder. I bend it until the leading edge is touching while in the wooden >brake, but at rest, there is > 7" between the sides. The archives say I can >fix this with the hand-seamer - is this still the prefered method? With or >without the dowel in the TE? Any other ideas? > >Thanks, > >-Larry >RV-8 Rudder. >Advance, NC (8A7) >Email: larry(at)bowen.com >Web: http://larry.bowen.com > > > > > > ________________________________________________________________________________
Date: Oct 13, 1998
In a message dated 10/12/98 12:37:16 PM Pacific Daylight Time, tcraigst(at)ionet.net writes: << have a solution to your problem! Build an airplane with the little wheel in back where it belongs. Even if it did fail, (don't think it ever has) it >> Oh Yeah, here it comes! I knew it wouldn't be long before the " wheel where it belongs" types would be heard from... under the current circumstances, these comments are neither funny, nor productive/helpful to the problem, and should not be aired on this forum. Walt Hastings RV-6A ________________________________________________________________________________
Date: Oct 12, 1998
> >I'm having a hard time getting the proper trailing edge formed on my RV-8 >rudder. I bend it until the leading edge is touching while in the wooden >brake, but at rest, there is > 7" between the sides. The archives say I can >fix this with the hand-seamer - is this still the prefered method? With or >without the dowel in the TE? Any other ideas? > >Thanks, > Larry I recall having the same problem on mine and I got a little more agressive using my homemade wooden brake and put some heavier pressure on it to get it to bend the trailing edge enough. I used a metal dowel in the TE during the whole process. I think it also helps to put a handle in the center of the wooden brake as well as one on each end to give a more consistent bend along the trailing edge and also reduce oil-canning. (well, that's what it said in the archives) Regards, Tom Velvick rv-6a fusilage ________________________________________________________________________________
From: dralle(at)matronics.com (Matt Dralle 925-606-1001)
Date: Oct 12, 1998
Subject: READ THIS
RV Listers, I try my best to stay out of this and let the List police itself, but there comes a time... I've gotten a few complaints in recent days about the signal-to-noise ratio on the RV-List lately and I'd probably have to agree. People, please remember that there are now *OVER* 1000 people on the RV-List. When you post a message to the List, everyone of these members gets a copy and has to deal with it - be that to delete it or read it or whatever. I really love the family atmosphere we have on the RV-List and the free discussion is a wonderful resource. But the number of messages per day is starting to choke some people and I can't really blame them. I've been asked to impliment some sort of splitting up of the List or some other method of controlling the amount of traffic. I *really* _don't_ want to do this because I feel that it will be to the detriment of the List as a whole. I have some other ideas about forcing certain keywords such as "Primer", "Wings", "Tail", etc. to be added to the Subject line of incoming posts so that some filtering can be done by members. Again, this sounds great, but I'm sure will cause more problems and add some level of confusion for new members. As the RV-List Administrator, an RV Builder, and an RV-List member for nearly 10 years, I am asking that *everyone* do their part to curb the excess chatter and discussions about topics that could easially found with the Archive Search Engine. Just this past weekend I had a question regarding something I was building and sat down to write a quick message to the List about it. Then I stopped and thought, "Hum, I wonder if the answer to this is in the Archives..." In 2 minutes, I had found over 10 messages in the archive regarding the very question I had. By the way, most of that 2 minutes was waiting for my browser to start up - the actual search took exactly 7 *seconds*. Anyway, I'll get off the soapbox now. Let's keep the List content concentrated and to the point. Edit out all that quoted text that really doesn't have anything to do with your response. Use the Archive Search Engine. The RV-List is the World's Best Resource for RV-Related information - let's keep it that way. Best Regards, Matt Dralle RV-List Administrator -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Date: Oct 13, 1998
Subject: sent to the archives
I wouldn't argue that the archives are a great resource of information. The only potential problem is that the information may occasionally be obsolete, or someone currently on the list may have a better approach than what had been previously suggested, or done in the past to resolve a particular issue. That's why, IMHO, I don't think it's such a terrible offense to post questions that may have been previously discussed - as long as the discussion wasn't just last week! Bruce Stobbe RV-6 working on fuselage ________________________________________________________________________________
Subject: Some advice
Date: Oct 13, 1998
Listers, I read the note from our provider this morning; so, I'm going to keep this as short as possible. I got several answers to my note. Here are some of them and my responses. 1. Guys hate giving advice on the list and getting blasted for it. I don't blame them. This is no place for a flame. Let the person asking the question figure out what's best for him/her. I've found that I can sometimes get a better idea by combining ideas. None of us know it all, even though some of us think we do. Answer off line, if need be. Just answer! 2. There is so much BS on the list that much of it is bypassed by the readers. I do the same. Keeping the BS off line would help a bunch. We do need to be sure that we don't lose reports like those given by Fred concerning the broken gear legs. 3. Subjects change and no change in the title. I've found this a lot and don't use the archives because of that and other reasons. Valuable info could be lost because of it, too. 4. People get tired of answering the same questions over and over. OK; but, Van's keeps selling kits. We have new people who may not be up on the archives. Remember, we had those questions when we were in their stages. Let's answer those questions off line and tell them about the archives. 5. Use the archives. Contrary to some, I've not been able to get much from the archives. I tried them several times and got very little because of the nature of the question and how my machine handles them. My responses end up as garbage after a few hundred lines of response. Maybe others run into the same problems. I've not tried the new search engine, yet. 6. You didn't explain it well enough for us to understand. Put in more detail. That's my favorite. In the past I've been flamed for that, too. When I put in enough, it's too long for your time. If I leave a little out, it's not detailed enough or is confusing. Gee, folks, I didn't know my KY drawl carried into the list. If the ones behind me can understand my answers when I find them on my own and tell the rest, why is it so hard to understand the question? Why not ask off line what we mean, rather than doing nothing? I can tell you I'd do anything to get the explanation clear enough to get that answer. I don't have RVs all around me to look at. Many of us are in the same boat. You ask for a clarification, we can give it. That's about it. Per the note I got this morning, there are over 1000 people on this. With about 25, or so, doing all of the talking, I'm wondering where the rest are. I'm sure you lurkers have some ideas and experiences of your own. We need your help just as much as we do the regulars. Answer off line if you're afraid of being embarrassed. All of us need help! You may be just the one who can do it! 'Nough said. Sorry for taking up the space. For the sake of others and me, I felt it needed saying. Jim Sears in KY RV-6A N198JS (Hanging engine parts.) ________________________________________________________________________________
Subject: attaching wire connectors for #2 or #4 wire
Date: Oct 13, 1998
Even though I just happily smashed the large connectors onto the ends of the large (#2 or #4 gauge)starter wire, it seems to me that the grip is not that good, especially given all the engine vibration. Is there a special crimping technique or tool? Also, I didn't include any insulation in the crimp, only because it didn't readily slide into the connector. Should I have? Rick Solana, RV-6a N804RS Richmond, VA ________________________________________________________________________________
Date: Oct 13, 1998
From: "David S. Hamilton" <hamlton(at)mindspring.com>
Larry, I bent the trailing edges first with the dowel and then without it. I couldn't get the bend I wanted using the dowel so I called Van's. John Morgan assured me it would be okay without the dowel and sure enough he was right. It made me nervous but I worked slowly and am very pleased with the final bends on all control surfaces. Fraternally, Dave Hamilton 80001 (N880RV) just tested fuel tanks, no leaks:) >I'm having a hard time getting the proper trailing edge formed on my RV-8 >rudder. I bend it until the leading edge is touching while in the wooden >brake, but at rest, there is > 7" between the sides. The archives say I can >fix this with the hand-seamer - is this still the prefered method? With or >without the dowel in the TE? Any other ideas? ________________________________________________________________________________
Date: Oct 13, 1998
Larry, I started building my wooden brake the same way George says to do it in the video, but I added one thing.... Instead of letting the two faces close completely, I left a 1/8" gap between the two boards. This way if the trailing edge is all the way in (touching the hinges), the edge can't overbend, but the front face of the break can close completely. This made forming the leading edge very easy, and I didn't have to worry about flattening the TE. I still used an 1/8" wooden dowel in the bend (I never trust my ideas that much!) Scott Kuebler RV-6 (or -6A) wings >>> "Larry Bowen" 10/12/98 09:22PM >>> I'm having a hard time getting the proper trailing edge formed on my RV-8 rudder. I bend it until the leading edge is touching while in the wooden brake, but at rest, there is > 7" between the sides. The archives say I can fix this with the hand-seamer - is this still the prefered method? With or without the dowel in the TE? Any other ideas? Thanks, -Larry ________________________________________________________________________________
From: "Bart Dalton" <Planenutts(at)worldnet.att.net>
Subject: Re: Woodward Prop Governor
Date: Oct 13, 1998
EMI in Tulsa ,OK is a good shop to have good quality work done for experimental accessories. Tell Justin that it is for experimentals. This is where I have all my mags,Govs and other accessories worked on. ---------- > From: VON L ALEXANDER <n41va(at)Juno.com> > To: rv-list(at)matronics.com > Subject: RV-List: Woodward Prop Governor > Date: Thursday, October 08, 1998 3:20 PM > > > Listers; > > I recently obtained a Woodward Prop Governor(used) and my question is > since I would like to have this unit checked or overhauled before I > install it on my 0-360, would this go to a prop shop? Is there an > overhaul requirement on these? Does anyone specialize in these? This > will be my first engine installation, so I have a lot of learning to do! > This is type 210080 U, Part # 21350-3. > > Thanks. > > > Von Alexander > RV-8 N41VA > N41VA(at)juno.com > > > > ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <stuckle(at)ifc.utc.com>
Date: Oct 13, 1998
Rick, Check out the archives on this subject. Seems to me I remember Bob Nickols had posted something on his web page concerning these connectors and how to deal with them... Fred Stucklen N925RV RV-6A E. Windsor, Ct > -----Original Message----- > From: MSN mail [SMTP:solanas(at)email.msn.com] > Sent: Tuesday, October 13, 1998 6:58 AM > To: RV list > Subject: RV-List: attaching wire connectors for #2 or #4 wire > > > Even though I just happily smashed the large connectors onto the ends > of the > large (#2 or #4 gauge)starter wire, it seems to me that the grip is > not that > good, especially given all the engine vibration. > > Is there a special crimping technique or tool? Also, I didn't include > any > insulation in the crimp, only because it didn't readily slide into the > connector. Should I have? > > Rick Solana, RV-6a N804RS > Richmond, VA ________________________________________________________________________________
Subject: Front Gear Leg Failure Summary, withholding information
Date: Oct 13, 1998
Listers, I've received a lot of questions on this subject. >> As to why the front gear leg broke, Van has not released to me >> the full metallurgy report, and does not plan to in the future. .. >That doesn't sound good. Did Van's provide any reason why they >won't tell you the results of the tests performed on the gear leg that >came from your aircraft, which you voluntarily sent to Van's for >testing? > Tim Lewis [timrv6a(at)earthlink.net] >Fred, have you asked for "YOUR" broken nose leg to be returned? >I think the one at Copperstate is the fifth one to fail in normal >operations. >Brian Holman [bholman(at)fullcomp.com.au] Yes, I voluntarily sent the leg to Van's, but he did replace it free (so far), as well as rework the engine mount for the new gear leg, so in essence, the old leg is his..... From conversations with Tom Green concerning Van's reasoning for not releasing the data, I get the impression that Van feels that experimental aircraft are just that, experimental, and the end user should be more responsible for his creation than the kit builder. And in today's business environment, it would not be prudent for him to be releasing information that could hurt him. And we really don't want him to go under because of legal issues from a problem that we are all now well aware of. I feel that it IS our responsibility to discipline ourselves in identifying and controlling mechanical issues with our planes. Part of that responsibility is to REACT to the know problems. How many of you flying have actually tested your gear legs? I've only had three (3) responses (all negative) to my post in August requesting test data..... I know that this incident has taught me that there is a potential problem area that needs to be periodically inspected, especially after a nose wheel shimmy. If nothing else, this incident has informed a 1000 others of a potential area of concern. So, in effect, hasn't the job of informing the owners been performed without the legal liability? Is there a better way? Who do you want in control of your flying? Van's, the FAA, or yourselves? >Being a concerned 6A owner, could you tell me if these failures were with >an O-360 or O-320. I've noticed a difference in how the nose gear flexes >more with the 360 due to the increased weight, not to mention the addition >of a C/S prop. >Dave Hudgins >-6A Nashville N925RV has an O-320-D1A engine. I HAVE NOT re-installed the wood/glass stiffener on the new gear leg and already have noticed more instability on takeoff's and landings when the nose gear is on the ground, so, IMHO, the flexing issue on a heavier O-360 engine would be even more pronounced. I plan on re-installing the stiffener for this reason... It will make inspection more difficult, but not impossible.... << Van seems to be taking the attitude that these are "experimental aircraft and do not conform to the normal certification standards" >> >Van is correct in this, but only to a certain point. If the analysis of the >gear leg shows a problem in the manufacturing process, then I feel it is >"still" up to Van to work with the vendor to adjust the process and produce a >more reliable gear leg. Of course, it is prudent to do the inspections >carefully. >More importantly, if there is a problem only with "certain" gear legs of a >certain vintage, it would be really helpful to those folks to know this. >Jim Nice >RV6A >WA State I think Van is reacting to this situation, abet quietly. It is my understanding that he is now doing more inspections on the new gear legs and the manufacturing process has been changed. All-in-all, quality should get better. It's the older units in the field that I would be concerned about.... Jim, this is the area that WE can make a difference. I too feel that it should be Van's responsibility to warn current owners of older kits that there may be a process problem on front gear legs, even if that problem does not effect ALL of the fleet. To the end user, KNOWLEDGE is the tool to preventative maintenance. In my opinion, Van does not see this whole issue as a problem yet. (But in our eyes, one failure is a problem.) We as a group can better control the issue if we were to generate data on how many gear legs do have problems. This, of course, means those flying have to have their gear legs tested. If nothing else, this disciplined approach will prevent more failures..... Hope this helps guys & gals..... Fred Stucklen N925RV RV-6A E. Windsor, Ct ________________________________________________________________________________
Subject: Re: attaching wire connectors for #2 or #4 wire
Date: Oct 13, 1998
Rick; I feel sure that there is a special tool for this crimping of battery line terminals. Since there are left handed monkey wrenches and special pieces of flight line. But like so many a/c related things, they are of very high value, and it was not economical for me to buy one for such limited use. I remembered that the telephone co. used something like that when they repaired my barb wire fences after they had cut them. I located the right guy. He was a/c interested. Came to see my a/c under construction, brought the tool, we fixed the crimp. Incidentally, he has gone on to get his private license because of the interest generated by the visit. I had tried to do it in a vice, and like you, I wasn't satisfied with the crimp that resulted. No, I didn't include insul. inside the crimp. Don't know if that was the correct thing to do or not. But didn't have any problems with it in two years with 175 hours. You may want to give the telep. line maint. guy a call and try to save some money. John C Darby Jr. RV6 sold, Cessna 210 bought Stephenville TX >Is there a special crimping technique or tool? Also, I didn't include any >insulation in the crimp, only because it didn't readily slide into the >connector. Should I have? ________________________________________________________________________________
Date: Oct 13, 1998
Rick, There is a special crimping tool, but it is very expensive. You may be able to take your cables to an electrical supply house and have them crimped there. I made a set of dies out of 1" thick aluminum and used a large vice to crimp my #2 connections. Another method to strengthen up your current crimps is to "nail" a few small pieces of copper ground wire into the front end of the connection. This will act like a wedge. After you have a good mechanical connection, it is a good idea to solder the terminal for additional security. A standard Radio Shack soldering iron has no chance of heating up a #2 terminal, so I used a torch. Be sure to put a heat sink on the wire, right behind the terminal, as you only want the solder within the terminal area and not to wick into the wire past the terminal. This would make the cable brittle. You do not want insulation in the crimp. It is imperative to get a good electrical connection here. Hope this helps. Scott Gesele N506RV - Flying ________________________________________________________________________________
Date: Oct 12, 1998
From: Shirley Hobenshield <shobenshield(at)cmsd.bc.ca>
Subject: Re: New on list
and hope I may >be able to contribute in some way. > >Eustace Bowhay C-FHAY RV6 (amphib. floats) >Blind Bay British Columbia > > >Eustace, List or no list we think of you often, your flying abilities are well rembered by us back when we started building. I still recall 2 things you told us, " These things are way stronger than a Cessna " " Just be carefull building speed in a dive, you could pull the wings off ! " We have many fun hours now in the North BC on C-FXXG. Your advice has not fell on deaf ears. Am looking foreward to reading your notes. Thanks, Ed & Shirley Hobenshield ________________________________________________________________________________
Date: Oct 13, 1998
> >Even though I just happily smashed the large connectors onto the ends of the >large (#2 or #4 gauge)starter wire, it seems to me that the grip is not that >good, especially given all the engine vibration. > >Is there a special crimping technique or tool? Also, I didn't include any >insulation in the crimp, only because it didn't readily slide into the >connector. I just did this and had good luck soldering the connectors on. I used a propane torch on the back of the connector and lots of solder. Those connectors are not designed to include any insulation in the crimp. Larry Pardue Carlsbad, NM Pacer N8025D RV-6Q N441LP Reserved Wiring & FWF ________________________________________________________________________________
Subject: Re: Some advice
Date: Oct 13, 1998
> > > >3. Subjects change and no change in the title. > >I've found this a lot and don't use the archives because of that and >other reasons. Valuable info could be lost because of it, too. > > >5. Use the archives. > >Contrary to some, I've not been able to get much from the archives. I >tried them several times and got very little because of the nature of >the question and how my machine handles them. My responses end >up as garbage after a few hundred lines of response. Maybe others >run into the same problems. I've not tried the new search engine, >yet. > I would greatly encourage anyone who has not tried the new search engine to do so. It is much, much better than the old one. I have found it to work flawlessly. Also I don't believe the subject line has any special function on the search engine. The engine searchs the entire text. Larry Pardue Carlsbad, NM Pacer N8025D RV-6Q N441LP Reserved Wiring & FWF ________________________________________________________________________________
Date: Oct 13, 1998
> >Even though I just happily smashed the large connectors onto the ends of the >large (#2 or #4 gauge)starter wire, it seems to me that the grip is not that >good, especially given all the engine vibration. **Idea that was submitted to some publication I get was to drive copper wire into the #2 or #4 after the connector put on until it is tight. Then solder the connect in the same method as sweating copper plumbing joint. I have used this method and it seem to be very solid and strong. Have a good one! Denny Harjehausen RV-6 wing fairings Lebanon, OR ________________________________________________________________________________
Date: Oct 13, 1998
From: "Michael A. Pilla" <mpilla(at)NOSPAMmitre.org>
I went to the local Marine supply house and purchased their battery cable crimping tool; I think it was a whopping $8 or something like that. This tool can crimp 0, 1, 2, 4, etc. cable onto the standard lugs. The instructions suggest hitting the end with a hammer, but I just placed the assembly in my vise and squeezed. The tool has an automatic limiting stop to prevent overcrimping. Several of the local builders have been using this tool. Michael Pilla Scott Gesele wrote: > > > Rick, > > There is a special crimping tool, but it is very expensive. You may be able > to take your cables to an electrical supply house and have them crimped > there. I made a set of dies out of 1" thick aluminum and used a large vice > to crimp my #2 connections. Another method to strengthen up your current > crimps is to "nail" a few small pieces of copper ground wire into the front > end of the connection. This will act like a wedge. After you have a good > mechanical connection, it is a good idea to solder the terminal for > additional security. A standard Radio Shack soldering iron has no chance of > heating up a #2 terminal, so I used a torch. Be sure to put a heat sink on > the wire, right behind the terminal, as you only want the solder within the > terminal area and not to wick into the wire past the terminal. This would > make the cable brittle. > > You do not want insulation in the crimp. It is imperative to get a good > electrical connection here. > > Hope this helps. > > Scott Gesele N506RV - Flying > ________________________________________________________________________________
Subject: CHT; Bayonet or Screw-in?
Date: Oct 13, 1998
Listers; In installing my AV-8 engine monitor, I have a choice of using the spark-plug type sensor for my CHT readouts, or the screw-in type. I have heard the screw-in types are more accurate so will use those. The probe is a 3/8-24 thread, is this the correct one? Do these go into the small threaded hole above each cylinder, or below, or does it matter? Besides the 4 CHTs, I also have Manifold pressure to go into one of these openings. Thanks. Von Alexander RV-8 N41VA N41VA(at)juno.com ake fluid spilling. Von Alexander RV-8 N41VA N41VA(at)juno.com ________________________________________________________________________________
Date: Oct 13, 1998
Subject: CO Monitors
I've checked the archives, because I seem to remember a discussion on CO monitors awhile back, but got no hits. So, does anyone know what is available and where? Thanks, Joel Harding RV-8 CO ________________________________________________________________________________
Date: Oct 13, 1998
>>> > > >RV-List: posted by Rijkers, Jan <robynne@harare,iafrica.com> > >posted by: "Jensen, Keith (MC R&D)" >>>> >>>> To the list: >>>I had to have a look at my VS, and it has all solid rivets in it- a non event . >>>Contrary to Avery's catalog the yokes are not hardened and could be reshaped >>>easily. I use the pneumatic squeezer for wich I made four addittional yokes. >>>Probably the best investment I made in tooling. >>> >>> >>>Good luck >>>JAN RIJKERS-(zimbabwe) ________________________________________________________________________________
Date: Oct 13, 1998
<< Even though I just happily smashed the large connectors onto the ends of the large (#2 or #4 gauge) starter wire, it seems to me that the grip is not that good, especially given all the engine vibration. Is there a special crimping technique or tool?>> Rick- For the RV (battery close to engine), 4 AWG wire is completely adequate to carry the starting current. The best termination technique I know of involves the use of a special crimping tool (similar in design to a bolt cutter or nicopress tool) that is about $240 (McMaster-Carr p/n 7333K15). IMO, every chapter should have one of these (along with filter can cutter, spark plug sand blaster, nicopress tool, Roto-flare and similar specialty tools). It has a compound head and a die nest (adjustable for AWG) that is designed to cold flow the terminal and the wire strands together for a gas tight (or nearly so) joint. Some boating supplies dealers have these and if you look around your airport maybe someone will lend you one. The large nicopress tool will also work in a pinch (someone building a wire braced design might have one of these). Some choose to solder these terminals in place. It is certainly not the preferred technique (reduces joint flexibility and stresses concentrate at the edge of the joint area), but if you have clean surfaces and a big soldering iron it can be done. Just use a mildly active rosin flux and clean off the residues following reflow using isopropyl alcohol or similar mild solvent. << Also, I didn't include any insulation in the crimp, only because it didn't readily slide into the connector. Should I have? >> This is personal preference but installing shrink sleeving is considered to be good practice. In some cases it can be installed after the termination is completed if the normally available 2:1 shrinkage material can be slipped over the end. There are some types of 3:1 shrinkage products available. -GV ________________________________________________________________________________
Subject: Engine Plumbing Shopping List
Date: Oct 13, 1998
I am finding that one of the most difficult and time consuming things is figuring out what size and type of plumbing to order for the engine. Does anyone have a shopping list already made up for an 0360-Constant Speed setup? I seem to recall that Tim Lewis had a nice one on the list a while back. Von Alexander RV-8 N41VA N41VA(at)juno.com ________________________________________________________________________________
Date: Oct 13, 1998
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
> >Even though I just happily smashed the large connectors onto the ends of the >large (#2 or #4 gauge)starter wire, it seems to me that the grip is not that >good, especially given all the engine vibration. > >Is there a special crimping technique or tool? Also, I didn't include any >insulation in the crimp, only because it didn't readily slide into the >connector. Should I have? Fat wires get along well without insulation-grip on installed terminals. It's little guys like 20 and 22AWG that shed their terminals readily under vibration if not afforded the extra support. Crimping tool design and calibration is pretty exacting science. I won't say that the low cost, screw-jack tools out there will not produce an adequate installation, without evaluating each one with specific wire and terminals, I cannot judge. However, over the past 35 years, the history on bizillions of solder joints has been exemplary. It's not hard to do and the results are not in doubt. I've posted an article I did for Kit Aircraft Builder a couple of years ago. You can download it from: <http://www.aeroelectric.com/articles/big_term.pdf> For those of you who have tried to download this one in it's former life (1.4 Meg!!!) I've learned a few things about Acrobat Distiller and the article is now down to 290K Bytes . . . although Distiller is putting little streaks in my photos . . . I'll get it right eventually. In the mean time, the piece is much easier to acquire. ________________________________________________________________________________
Date: Oct 13, 1998
You can use the clamp from a tube flaring tool. Lay the connector in the half round that fits. Turn the other bar around and use it to press a small ball bearing in to the connector. Make a neat, good swage every time. -----Original Message----- From: Stucklen, Frederic IFC <stuckle(at)ifc.utc.com> Date: Tuesday, October 13, 1998 9:20 AM Subject: RE: RV-List: attaching wire connectors for #2 or #4 wire > >Rick, > > Check out the archives on this subject. Seems to me I remember Bob >Nickols had posted something on his web page concerning these connectors >and how to deal with them... >Fred Stucklen >N925RV RV-6A >E. Windsor, Ct > > >> -----Original Message----- >> From: MSN mail [SMTP:solanas(at)email.msn.com] >> Sent: Tuesday, October 13, 1998 6:58 AM >> To: RV list >> Subject: RV-List: attaching wire connectors for #2 or #4 wire >> >> >> Even though I just happily smashed the large connectors onto the ends >> of the >> large (#2 or #4 gauge)starter wire, it seems to me that the grip is >> not that >> good, especially given all the engine vibration. >> >> Is there a special crimping technique or tool? Also, I didn't include >> any >> insulation in the crimp, only because it didn't readily slide into the >> connector. Should I have? >> >> Rick Solana, RV-6a N804RS >> Richmond, VA > > > > > > ________________________________________________________________________________
From: "David Cross" <sfo621(at)impop.bellatlantic.net>
Date: Oct 13, 1998
Subject: Opinion request
I started RV-6A empennage construction nearly four years ago, after getting the "$30,000 free ride" in North Plains. Since that time I have relocated to the East Coast, lost my "copilot" (side-by-side advocate) and stored my project until I could locate a suitable work space. I now feel that tandem seating is more appropriate for me. I would like to take advantage of the latest thinking from builders and pilots that have experience with tandem RVs. Any opinions on the relative merits of the RV-4 and RV-8 would be appreciated. I assume this subject has been discussed previously, but I have not been able to locate anything specific in the archives. Also, I have not seen many examples of the RV-4, and I have never seen an RV-8 (although I almost had a chance last Sunday at the Eastcoast Flyin). I live in Alexandria VA and I would like to visit anyone within a reasonable distance that is willing to discuss this subject with me. Flames welcome. Please respond off list. David Cross sfo621(at)bellatlantic.net ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Re: Front Gear Leg Failure Summary, withholding information
<< And we really don't want him to go under because of legal issues from a problem that we are all now well aware of. I feel that it IS our responsibility to discipline ourselves in identifying and controlling mechanical issues with our planes. Part of that responsibility is to REACT to the know problems.>> What about those that are not on the RV-List. Wouldn't a recap in the RV-ator by Van's be a thoughtful and prudent act. Is this info only for the net literati? << How many of you flying have actually tested your gear legs? I've only had three (3) responses (all negative) to my post in August requesting test data..... I know that this incident has taught me that there is a potential problem area that needs to be periodically inspected, especially after a nose wheel shimmy. If nothing else, this incident has informed a 1000 others of a potential area of concern. So, in effect, hasn't the job of informing the owners been performed without the legal liability?>> The list info is not about avoiding legal liability IMO. Neither should it be used as an informal leak of info from the factory (what are we, Ken Starr's office?). If there are issues that become apparent as the RV Fleet ages, I think that the factory has an obligation to point them out in their official publications (RV-ator, Service Bulletins, Service Letters) with the facts and the current factory position on each. What we do with the info is our responsibility as the manufacturer. The RV-List represents only a small portion of those building the RV series. Hopefully those without net access will have friends that can pass along this underground information. Their livelihood my depend on this informal network if the factory is unwilling to identify potential areas of concern as the RV fleet ages. This situation is unfortunate, but I guess I can appreciate some of the concerns Van's has with regard to our litigious society. I believe that some official avenue of notification should be pursued. << Is there a better way? >> We are open to suggestion. The Kitfox list has gentleman member who does a periodic posting of what is referred to as "Kitfoxsafe" (subject line). This compilation identifies the currently known problem areas on different models/options collected from various sources (magazine articles, anecdotal info, postings) and recommended course(s) of action. No legalities, just what is currently known. Will someone take up the "RVsafe" challenge? -GV ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Re: Lycoming Magnetos
I will have a Slick right mag for an O-320 E2D when my electronic ignition comes. If you are interested, send me an E-mail. Jim Cone jamescone(at)aol.com ________________________________________________________________________________
Date: Oct 13, 1998
<< So, in effect, hasn't the job of informing the owners been performed without the legal liability? Is there a better way? Who do you want in control of your flying? Van's, the FAA, or yourselves? >> I agree that the best way for us "experimenters" is to talk to one another and with Van's guys about the problems. I know that they are doing everything that they possibly can to identify if there is a common thread here amont the gear failures. Were they from one batch from the vendor, did they have a history of shimmy, were the failure modes the same, etc., etc.......? It is possible that the list might even be a good tool to answer some of these ?'s. If you know of a nose gear failure, can you provide as many details to the list as possible regarding the configuration and the circumstances regarding the incident. ________________________________________________________________________________ failure that had apparently been growing for some time and that it failed just below the socket, that the Copperstate failure was actually up in the socket a 1/4 to 1/2 inch, and that a third failure from a earlier scenario is recorded on video and it a hard nose first touchdown with the gear bending approximately 30 degrees to the rear before snapping off at the socket. It does not sound like there is a common thread here, but if you guys that are familiar with these incidents would submit as many facts as you could regarding the shipping date of the gear from Van's and other info, maybe we might even see a thread to share with Van to try to solve the problem. After all this is the age of information and we are on the "information highway" Bernie Kerr , RV6A fuselage, SE FLA ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Re: Bleeding of Brakes
Von, While filling the system, pump enough fluid into the first brake to purge the air out of the lines and fill the reservoir about 1/4 of the way. Fill the second side the same as the first, then top off the reservoir. You do not need to pump the brakes at all during this process. Make sure that you do not inject any air into the system while filling. The brakes should be firm when you are done. Any spongyness is an indication that air is in the system and it will need to be bled again. Hope this helps. Scott Gesele N506RV -Flying ________________________________________________________________________________
Subject: Bleeding of Brakes
Date: Oct 13, 1998
Von, I found that pumping the fluid in at the brake caliper until the it comes out of the reservoir. The firewall mount reservoir I used had a pipe tread fitting on it which I just plumbed into an overflow can. I did find that I needed a good flow rate to get all the bubbles out of the top of the tubing loops in my floor mounted rudder pedal system. Fred Stucklen N925RV RV-6A E. Windsor, Ct > -----Original Message----- > From: n41va(at)juno.com [SMTP:n41va(at)juno.com] > Sent: Tuesday, October 13, 1998 10:34 AM > To: rv-list(at)matronics.com > Subject: RV-List: Bleeding of Brakes > > > I am getting ready to fill my brake system with fluid. In using a pump > can to fill the system from the bottom-up(thru the nipple), do I need > to > keep going until brake fluid comes out the reservoir on the firewall? > Do > the brakes have to be pumped at all during this process? I thought > about > slipping a stick down into the reservoir, pump one side until there is > a > fluid level on the stick, then pump the other side till there is a > higher > fluid level. Would this work? Seems like it would save the mess on > brake > fluid spilling. > > Von Alexander > RV-8 N41VA > N41VA(at)juno.com > ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Titanium Landing Gear
I am interested in whether there has been anyone who has seriously checked into the possibility of titanium gear. I understand titanium is 56% of the weight of steel and stronger. I know the Sonex is using titanium and so are the Harmon Rockets. I talked to Sonex and they use a constant diameter bar stock from Harvey Titanium in Santa Monica. Harmon uses a tapered leg and I think someone said he had to respec his because of a failure. Anyway, if there is someone with some knowledge about this I would appreciate it. Shelby in Nashville. ________________________________________________________________________________
From: "Lewis, Timothy, MAJ, AF/XOIWO" <lewisth(at)pentagon.af.mil>
Date: Oct 13, 1998
>In installing my AV-8 engine monitor, I have a choice of using the >spark-plug type sensor for my CHT readouts, or the screw-in type. I have >heard the screw-in types are more accurate so will use those. The probe >is a 3/8-24 thread, is this the correct one? Do these go into the small >threaded hole above each cylinder, or below, or does it matter? Besides >the 4 CHTs, I also have Manifold pressure to go into one of these >openings. CHT probes go in the bottom of the cylinder, pointing up. They measure the temp of the cylinder head metal, so they don't actually protrude inside the cylinder, just into a recess machined in the cylinder for this purpose. Manifold pressure can be taken from one of the primer fitting holes. These holes are near the oil return lines coming from each cylinder head, and are probably currently plugged with pipe plugs on your engine. These holes go into the intake manifold of the engine, near the valves. Clear? I have pictures, but haven't scanned them in yet, so I hope this explanation is good enough. Tim ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Re: CHT; Bayonet or Screw-in?
> >Listers; > >In installing my AV-8 engine monitor, I have a choice of using the >spark-plug type sensor for my CHT readouts, or the screw-in type. I have >heard the screw-in types are more accurate so will use those. It doesn't seem to matter that much. I used the screw-in type for my O-320 and my AV-10. >The probe >is a 3/8-24 thread, is this the correct one? Do these go into the small >threaded hole above each cylinder, or below, or does it matter? The well for the CHT probe is on the bottom of the head below (toward the crankcase) the spark plug hole. >Besides >the 4 CHTs, I also have Manifold pressure to go into one of these >openings. I think you are mistaking the plugs in the intake for the CHT probe well. Check for the CHT well below the spark plug. I tapped for MAP for my AV-10 off the bottom intake hole where the primer usually goes. Brian Lloyd Lucent Technologies brian(at)lcp.livingston.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6399 - voice +1.530.676.3442 - fax O- ________________________________________________________________________________
Date: Oct 13, 1998
>Any ideas? Does the carbeurator float bowl system cause this sort of >up-and-down flow behavior? Yes, I see that behavior with my carb at low flow rates periodically. The problem does not manifest itself at higher flow rates in flight. BTW, watch out for flow rates that fluctuate upward in cruise. That is a hint that vapor bubbles are going through the flow sender. It could indicate incipient vapor lock or a small leak in the system. Brian Lloyd Lucent Technologies brian(at)lcp.livingston.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6399 - voice +1.530.676.3442 - fax O- ration which certainly makes sense to me. After all, a larger volume of rubber would be entrained by the metal casing than with a traditional bushing. I couldn't find anything in the archives about them. All I know is that they're relatively expensive, in the range of $350 for a set of four. I wouldn't mind having less vibration but I can certainly live with what I've got. My biggest problem with the regular conical bushing is the limited lifespan. I'm looking for advice on the following: 1. Do these fancy Lord bushings last substantially longer than traditional ones? 2. Does the engine flex more, less or about the same as with traditional ones? 3. How much does the engine get moved forward by these new Lord bushings? Thanks for any information. Please accept my apologies for using RV-List bandwith for a non-builder question, but it may have operational interest for those of us flying conical mount engines. Mark RV-4 owner WA state ________________________________________________________________________________
Date: Oct 13, 1998
Subject: RMI?
Does anyone have any experience with the Rocky Mountian Insttruments engine moniter? I am thinking about getting one with alot of the extras such as fuel flow all 4 cht & egt amp. volt ect. This is a light weight instrument and would cost just about the same as if I bought all the seperate ones. But am I putting all my eggs in one basket is this piece of gear reliable? I am not on the list so if any one has any Info please respond directly to my E-mail address donrmc(at)gte.net. thanks Don McMullen Quick build RV-6A Building. ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Re: batteries
>rh wrote: >> >> My gill battery is 4 years old and it is still perfectly healthy. Should I >> just keep using it until it gets weak or should I just get a new one? >> >> Rebecca > >Rebecca, > >If you get rid of your present battery before it gets weak, you will get >no more out of it and you will start the amortization of your new >battery at once. If you wait until your present battery gets weak, >which you can tell by slow cranking or having to bump the starter past >the first compression stroke on the first flight of the day, you will >have extracted the maximum amount from your investment in the battery. > >I got 3.5 years out of my last Concorde 25Amp lead-acid battery. . . . . and I've got a battery in my Voyager that over 4 years old . . . but I NEVER depend on the battery to take over essential duties for comfortable termination of the journey. Beat'em til they die is perfectly acceptable for day-vfr service where potential total loss of electrical system is of no concern to the pilot. As battery technology continues to improve, battery ability to crank an engine in spite of below-minimums capacity will become a strong possiblity. By all means do whatever you're comfortable ________________________________________________________________________________
Date: Oct 13, 1998
The holes on the top are blind holes or wells for the CHT. Manifold pressure sensors won't work in these holes. The Manifold pressure sensor should replace a plug in the intake system. I believe you can use on of the primer holes which is what I think you are referring to when you say "below". Using the screw in probes are better than the spark plug type as your don't disturb them when hanging plugs. Accuracy is not important, relative temperature between cylinders is what you are looking for to get your cooling baffles set. Then you do want actual temps for max temperature. But you should see overtemps earlier from the EGT to prevent damages. -----Original Message----- From: VON L ALEXANDER <n41va(at)Juno.com> Date: Tuesday, October 13, 1998 11:36 AM Subject: RV-List: CHT; Bayonet or Screw-in? > >Listers; > >In installing my AV-8 engine monitor, I have a choice of using the >spark-plug type sensor for my CHT readouts, or the screw-in type. I have >heard the screw-in types are more accurate so will use those. The probe >is a 3/8-24 thread, is this the correct one? Do these go into the small >threaded hole above each cylinder, or below, or does it matter? Besides >the 4 CHTs, I also have Manifold pressure to go into one of these >openings. > >Thanks. > >Von Alexander >RV-8 N41VA >N41VA(at)juno.com > > > > > > > ________________________________________________________________________________
Date: Oct 14, 1998
n5lp(at)carlsbad.net wrote: > >5. Use the archives. > >Contrary to some, I've not been able to get much from the archives. > > I would greatly encourage anyone who has not tried the new search engine > to do so. It is much, much better than the old one. I have found it to > work flawlessly. Also I don't believe the subject line has any special > function on the search engine. The engine searchs the entire text. For those who are new to the list (and with apologies to those who've seen me blowing this particular trumpet too often already), I'll mention "The Bunny's Guide to RV Building", available at <http://members.xoom.com/frankv/bunny.htm>. This is a compilation of what I've learnt or discovered whilst building my RV-6, including lots of information which I've gleaned from the RV-List. It also includes links to other RV-related sites. Two advantages that the Guide has over the archives are photographs (over 100 now), and organisation. The Guide has now grown to over 500KB of text, divided up into the following sections: Pre-Build Stuff <http://members.xoom.com/frankv/bunny0a.htm> The Decision to Build <http://members.xoom.com/frankv/bunny0b.htm> Construction Techniques <http://members.xoom.com/frankv/btime.htm> Time to Build <http://members.xoom.com/frankv/blinks.htm> Links and References Empennage <http://members.xoom.com/frankv/bunny1a.htm> Tailplane and Fin <http://members.xoom.com/frankv/bunny1b.htm> Rudder and Elevators <http://members.xoom.com/frankv/carter0.htm> David Carter's notes on building the VS, Rudder, and Elevators. Wings <http://members.xoom.com/frankv/bunny2a.htm> Spars and Ribs <http://members.xoom.com/frankv/bunny2b.htm> Skinning <http://members.xoom.com/frankv/bunny2c.htm> Tanks <http://members.xoom.com/frankv/bunny2d.htm> Ailerons and Flaps <http://members.xoom.com/frankv/bunny3.htm> Fuselage Avionics <http://members.xoom.com/frankv/bunny5a.htm> DIY Avionics <http://members.xoom.com/frankv/bunny5b.htm> RST-564 Audio Panel <http://members.xoom.com/frankv/bunny5c.htm> Lighting One of my aims in creating the Guide was that it would be a complement to the RV-List... providing answers to frequently asked questions before they are asked. Accesses to the Guide index now run at about 12 per day (1040 total), with most of the sections averaging 1-2 hits per day. Hopefully that's reduced RV-List traffic by 1000 or more yet-another questions. Since I can't make all the mistakes possible, I can't learn all the lessons either. Also, my interest in (e.g.) empennage construction has dropped to near zero since I finished mine, so I'm not going to spend much time on adding to those pages. Therefore I encourage people to contribute their experiences to the Guide... email them to me, and I'll add them to the Guide. Now returning you to your scheduled program... Frank. RV-6 #24692, Hanging second aileron. ________________________________________________________________________________
Date: Oct 13, 1998
<< How many of you flying have actually tested your gear legs? I've only had three (3) responses (all negative) to my post in August requesting test data.... >> Fred: I dye checked mine after your incident, and several porpoising landings on rough turf that got a bit wilder than I liked... NO CRACKS... at least not in the area not covered by the fiberglass. I will be checking this situation at least annually. Due diligence is just that: what we owe ourselves to manage the known risks. Bill Boyd RV-6A N30YD 32 hrs TT ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Titanium Landing Gear for -6A nose gear?
<< I understand titanium is 56% of the weight of steel and stronger. I know the Sonex is using titanium and so are the Harmon Rockets. The Rocket does use that expensive stuff. snip Harmon uses a tapered leg and I think someone said he had to respec his because of a failure. Correct again! We had to remove a "step" machined into the leg near the bottom of the gear socket. The failure was exactly the same as Fred's -6 nose gear, but it was BOTH legs at the same time! WHAM! Without getting too technical, that particular failure cause has not been determined- embrittlement from vibration, improper installation, over-gross operation, chemical contamination, etc. Please keep in mind that metal fails in tension, not compression. A discussion last night with a -6 driver who is VERY familiar with heat treating and other sorts of metal conditioning suggested shot-peening for any metal used like we use our gear legs. This will keep the surface in a compression state, more or less preventing cracks from starting. No cracks start, no leg breaking. It would be the same situation with titanium (tension will start a crack), so that may not be the cure-all for this particular event. With titanuim, your wallet would be MUCH lighter- we pay $850 for EACH gear leg! Anyway, if there is someone with some knowledge about this I would appreciate it. There you have what I remember from my conversation with that engineer... Check six! Mark HR2 295 hrs See y'all at Abilene this weekend! ________________________________________________________________________________
Date: Oct 13, 1998
Here's what I did on the trailing edges of my elevators and rudder. I plan to do same on the other controls, as needed. I couldn't get the bend with the dowel, either. I decided to do the squeezing without it; but, I made templates to match the plans. I then proceeded to go down each trailing edge, using the template as I went. It worked well and made me feel a lot better. I'm sure the ailerons will get the same treatment since I've already made the template. Jim Sears in KY RV-6A N198JS (Hanging parts on the engine.) ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Re: Titanium Landing Gear
Shelby: No, actually steel is much stronger than Titanium but about three times as heavy. There are many grades of steel and each may have it's strength modified by temper. ASTM A-4130 steel (usually known as "chrome moly" is the most common steel alloy used in aircraft construction and is about twice as strong as titanium. Pound for pound titanium is stronger but costs much more. If cost were not an issue (such as military aircraft) much of the aircraft would be made of titanium. For homebuilt aircraft, steel is actually a better value. A pound or two of chrome moly in a critical area such a the root of the nose gear could easily double the strength in that area. However, the cause of failure of the nose gears has not been determined (or at least not published). It may be that the failed nose gear struts had surface defects which caused stress risers. If so, the stress risers failed in fatigue, not over stress. If fatigue is found to be the problem (which appears likely) the solution could be to examine the affected gear for surface defects and correct that problem by grinding smooth any defects and/or heat treating the affected area. Another solution would be to "beef" the affected area by adding more steel to reduce the stress on the affected area which greatly increases fatigue life. A properly designed titanium nose strut with surface defects would fail in fatigue in the same way as steel. Surface defects can be caused by stray file marks, deep scratches from mishandling the material, or cracking of welds from hydrogen imbrittlement during welding. You may consider expressing your concerns directly to Van's and ask for more information. The builder is responsible for the manufacture of the aircraft. Van's is responsible for the design of the aircraft. Van should review the situation carefully and make a design recommendation if he feels one is necessary. No matter what, Van is the most qualified person to review the problem. Shelby Smith wrote: > > I am interested in whether there has been anyone who has seriously checked > into the possibility of titanium gear. I understand titanium is 56% of the > weight of steel and stronger. > > ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Re: RE: Van's refusal to share info
In a message dated 10/12/98 9:24:23 PM Pacific Daylight Time, Rvator97(at)aol.com writes: << Oh Yeah, here it comes! I knew it wouldn't be long before the " wheel where it belongs" types would be heard from.. >> So, Walt, The question is, WHEN there are more Nosedragger RV's than Taildraggers, do you think we should let them fly formation with us??? ________________________________________________________________________________
Date: Oct 13, 1998
Subject: avionics
I'm starting to window shop panel goodies and am interested in listers inputs, recommendations, warnings, regarding the following toys: Transciever. Considering Icom, Terra, II Morrow, King. Cost, performance, features, ease of use, warranty/support are all considerations more or less in that order. So far the Icom A200 looks to be the best bang for the buck ($879 from Marv Golden here in San Diego). Are there any others I should consider? Transponder. I really dont know much about these or who makes them. Was leaning toward the Terra based on size and because I like the digital display, but with the rumors regarding Trimble/Terra Im not so sure. Same cost, perf, features, etc... apply. Intercom. I know nothing other than that I would like it to be a panel mount and would like an aux stereo input. I'd like to start with new stuff although I would consider used/refurbished if it is still currently available modern equipment from a reputable source. Please respond off list and if response is good I will compile results and post to the list. Thanks, Mike Wills RV-4 fuse willsm(at)manta.spawar.navy.mil ________________________________________________________________________________
Date: Oct 13, 1998
test it ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Rudder Trim Tab???
I would like to build into my rudder a movable tab. Anyone who has sucess with this, please forward your ideas. If you wish respond directly to B747400(at)compuserve.com. thanks LKD ________________________________________________________________________________
Date: Oct 14, 1998
>>> Mastic (hot melt adhesive) lined varieties are ideal for this duty as they provide support for the cable at its highest load point and seal the joint from corrosion. This is strongly recommended for soldered joints as well as crimped. (This is just a note from someone who has made (and remade) more crimp connections than I like to think about.)<<<< This is personal preference but installing shrink sleeving is considered to be good practice. In some cases it can be installed after the termination is completed if the normally available 2:1 shrinkage material can be slipped over the end. There are some types of 3:1 shrinkage products available. -GV ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Erroneous RPM Reading on RMI Engine Monitor
My RPM reads about double what it should read until the engine speed reaches 2200RPM, then it begins reading correctly. I have checked wiring, capacitors, connections, etc and know about the setting for 1 or 2 pulses per RPM. I've even swapped RMI engine monitor boxes with a fellow RV builder and got the same indications. The engine is an O-320H2AD and runs great. Has anyone had a similar problem and, if so, what is the fix? BoB Hall, RV6 N976RH Colorado Springs Ready to Fly ________________________________________________________________________________
Date: Oct 13, 1998
In a message dated 10/13/98 11:12:28 Central Daylight Time, n41va(at)juno.com writes: << I am getting ready to fill my brake system with fluid. In using a pump can to fill the system from the bottom-up(thru the nipple), do I need to keep going until brake fluid comes out the reservoir on the firewall?>> I would have someone watch the brake reservoir until fluid that has NO bubbles in it, is seen coming up into the reservoir. After all, the purpose of bleeding/backfilling the brakes, is meant to make sure all the air is out of the system. Right? Once airless fluid is seen coming out of one side of the brake system, repeat the same steps for the other side. Sometimes, it is necessary to draw a little fluid off the system, in order to keep it from overflowing. A cooks suction bulb works real well for this, and the thing is, this "special" tool doesn't cost a lot. Once you have made sure airless fluid is coming into the reservoir from both sides, then you can get up off the floor, and top off your system by filling the reservoir up with fluid by pouring it in. Hope this helps. Regards Wendell WBWard(at)AOL.COM Do the brakes have to be pumped at all during this process? >> ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Unsubcribe
Please remove my name from the list. It was just a great experience but I have too much other things to do. Thank you Yves Boulais ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Re: Engine Plumbing Shopping List
On 13 Oct 98, at 11:03, VON L ALEXANDER wrote: > I am finding that one of the most difficult and time consuming things is > figuring out what size and type of plumbing to order for the engine. Does > anyone have a shopping list already made up for an 0360-Constant Speed > setup? I seem to recall that Tim Lewis had a nice one on the list a while > back. I posted my list on 14 and 15 Mar 98. Should be in the archives. Search for "ACS #10570" and "AN960-C916L" to find the two posts. Experience gained since then leads me to suggest: -Forget the air/oil seperator oil return line. Capture oil in Matco brake reservoir as was suggested here a couple of weeks ago (although I don't know what fixture is required for the top of the reservoir... just got mine in the mail). - Trak Auto has little $2.00, 1/8" "T" fittings to split Van's 1/8" plastic line. I used the 1/8" line for manifold pressure line (inside the cabin) between electronic ignition and engine computer. - Trak also has larger "T" fittings which come in handy in pluming the vacuume system - Order a boatload of internal star washers (various sizes from -8 up to big enough for nearly engine-mount-bolt size. - Order a small boatload of rivnuts. Avery has an inexpensive installation mandril that prevents needing a special installation tool... you can just use the pop rivet puller. - Plan everything with a marker right on the firewall. Think about hoses interfering with each other. Think about where stuff on the other side of the firewall (starter selenoid, brake valve) will go. Plan routing of heater duct. Plan engine control cables so they won't interfere with full rudder pedal throw or brake application. - Patience! It took me about 400 hrs to do cowling, baffling, engine installation, engine hookup. I am not a fast builder (!!!!) and I do have a complicated system (CS prop, dual heaters, custom made brackets to fit ACS cables, 4CHT/4EGT computer, etc). Sure feels great when you crank the engine and she fires! Tim _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023, engine completed and tested Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Re: Fluctuating Fuel Flow Computer Indications
On 13 Oct 98, at 11:12, Brian Lloyd wrote: > Yes, I see that behavior with my carb at low flow rates periodically. The > problem does not manifest itself at higher flow rates in flight. I guess I'm relieved that I'm not alone, but still puzzled. AC65-12A describes the carbeurator float on page 117. It says ..."when the engine is running and fuel is being drawn out of the float chamber, the valve assumes an intermediate position so that the valve opening is just sufficient to supply the reqired amount of fuel and keep the level constant." This doesn't sound like a system that would demand surges in fuel supply at constant RPM. Odd. Any insight from other listers? Thanks, Tim _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023, engine completed and tested Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Re: Rudder TE?!
All you guys folding your trailing edges must realize that these wooden folders are a miserable tool, akward and not consistent. What I`ve been using is a 48" sheet metal brake. Put masking tape on both sides of your T E, put T E in brake 1/4-3/8, and push down carefully with the (hold down). I think every small town has a sheet metal shop or air conditioning shop and wouldn`t charge much to let you do a 15 minute job. Fred LaForge RV-4 taxied yesterday, wt.&balance today -- 1054 lbs. ________________________________________________________________________________
Date: Oct 13, 1998
Joe Walker wrote: "Surface defects can be caused by stray file marks, deep scratches from mishandling the material, or cracking of welds from hydrogen imbrittlement during welding." I am wondering if the edges of the socket are chafing the leg? I could imagine this if the leg is able to move in the socket. Some mentioned shimmy as being possibly related. I would expect shimmy to increase the chafing. I suppose there are many RV6A's hours without the problem? hal ________________________________________________________________________________
Date: Oct 13, 1998
don't be such a baby walt, I think he's just having alittle fun w/his friend. carey mills world champion ________________________________________________________________________________
Date: Oct 13, 1998
>Oh Yeah, here it comes! I knew it wouldn't be long before the " wheel where >it belongs" types would be heard from... under the current circumstances, >these comments are neither funny, nor productive/helpful to the problem, and >should not be aired on this forum. > >Walt Hastings RV-6A Just a wee bit defensive are we? I thought it was funny (the original poster's comment, not the nosewheel failures). But then my wheel is in back where it belongs... -- Scott VanArtsdalen svanarts(at)jps.net "The essence of character is doing what's right, even when nobody's looking." - J. C. Watts narts(at)jps.net "The essence of character is doing what's right, even when nobody's looking." - J. C. Watts ________________________________________________________________________________
Date: Oct 13, 1998
Subject: aerobatics
I'm wondering about loops and the force which may be exerted on the airframe. In particular, I'm wondering about the end of the loop (the part where you're basically pulling out of a dive). I'm curious as to how many g's that part puts on the plane (for those of you who have g meters and have done the loops). I know there are several factors which will determine the exact force, but some ball park figures would be nice. Thanks RV6A- working on empenage (thinking WAY ahead).... ________________________________________________________________________________
Date: Oct 13, 1998
Vanremog(at)aol.com wrote: > I think that the factory has an obligation to point them out in their official > publications (RV-ator, Service Bulletins, Service Letters) with the facts and > the current factory position on each. In my limited experience, Van is not one to jump the gun. He does his home work well before publishing such data. The RV-3 spar investigation took more than a year but in the end he sent out *free* spar mod material to all RV-3 owners/builders! Has an RVator issue been published since Fred's front gear failure? How many RV6As flying? How many front gear failures? Finn ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Re: Erroneous RPM Reading on RMI Engine Monitor
> My RPM reads about double what it should read until the engine speed > reaches 2200RPM, then it begins reading correctly. I have the RMI monitor, but have not had any problems with the tach. My first guess would be to re-check the mag timing, to make sure both mags are timed perfectly. If your running the engine below 2200 rpm, and it's reading double, what does it do when you do a mag check? Like at 1700 rpm (3400 indication) does it indicate normal on one mag? Or does it indicate double on each mag individually? Mark LaBoyteaux RV-6A N106RV MLaboyteau(at)aol.com ________________________________________________________________________________
Subject: Looking for Governor
Date: Oct 13, 1998
I just found out the governor I have is unuseable with my 0-360-A-1-A/Hartzell CS prop combo. Does anyone have a used or rebuildable governor to fit the above combo? Or any leads? Thanks. Von Alexander RV-8 N41VA N41VA(at)juno.com ________________________________________________________________________________
Date: Oct 13, 1998
Have your ever dropped an apple into a tube a water. It bounces up and down. I think you float is doing the same thing as it might take a little to un-seat it and then it bounces. It also maybe dragging on the side of the float chamber. At a certain flow rate there might be a harmonic bounce. When it un-seats the flow goes way up, then the flow slows down, then as the float drops, it is high once again. -----Original Message----- From: Tim Lewis <timrv6a(at)earthlink.net> Date: Tuesday, October 13, 1998 8:00 PM Subject: Re: RV-List: Fluctuating Fuel Flow Computer Indications > >On 13 Oct 98, at 11:12, Brian Lloyd wrote: > >> Yes, I see that behavior with my carb at low flow rates periodically. The >> problem does not manifest itself at higher flow rates in flight. > >I guess I'm relieved that I'm not alone, but still puzzled. AC65-12A >describes the carbeurator float on page 117. It says ..."when the >engine is running and fuel is being drawn out of the float chamber, the >valve assumes an intermediate position so that the valve opening is >just sufficient to supply the reqired amount of fuel and keep the level >constant." This doesn't sound like a system that would demand >surges in fuel supply at constant RPM. Odd. > >Any insight from other listers? > >Thanks, > >Tim >_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ >Tim Lewis >N47TD (reserved) RV-6AQ #60023, engine completed and tested >Springfield VA >http://home.earthlink.net/~timrv6a >timrv6a(at)iname.com > > > > > > > ________________________________________________________________________________
Date: Oct 14, 1998
> > > > >This is personal preference but installing shrink sleeving is considered to be >good practice. In some cases it can be installed after the termination is >completed if the normally available 2:1 shrinkage material can be slipped over >the end. There are some types of 3:1 shrinkage products available. > >-GV > > If you have access to heavy duty heat shrink used at your local electric utility I'd recommend using it. The heat shrink we use at our utility has a 'sealant/glue' inside the tubing and, combined with the heavy wall of the tubing, does an excellent job of sealing that joint as well as stopping any movement. John Ammeter Seattle WA USA 1975 JH-5 RV-6 (sold 4/98) ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Metal flakes in oil inlet screen
During an oil change today, I found 5 tiny metal flakes in my oil inlet screen. They appear to have a highly polished surface on one side, like flakes of chrome plating, but my cylinders aren't chrome plated. Disassembly of the oil filter revealed a couple of very tiny pieces that were very similar. I retained an oil sample that I'm sending off to have analyzed. My worst fear is that they are from either the bearings or the lifters. My gut instinct is that it's not normal to find pieces of metal in the screen's and filter. Has anyone else ever found metal in the inlet screen that is considered normal wear and tear? Mark LaBoyteaux RV-6A N106RV MLaboyteau(at)aol.com ________________________________________________________________________________
Subject: Re: aerobatics
Date: Oct 13, 1998
You are right that you can pull as many or as few Gs as you like in any maneuver. Start out around four and experiment from there. Your G level will be highest on entry and exit. It will decrease as you slow during the pull up, then increase again as you go nose-low during the pull-out. Regards, Tom Craig-Stearman tcraigst(at)ionet.net RV-4 64ST installing baffle seal material > >I'm wondering about loops and the force which may be exerted >on the airframe. ________________________________________________________________________________
Date: Oct 13, 1998
In a message dated 10/13/98 6:00:01 PM Pacific Daylight Time, halk(at)sybase.com writes: << I am wondering if the edges of the socket are chafing the leg? I could imagine this if the leg is able to move in the socket. >> Having not even looked at an RV-6A nosegear socket yet, I am not qualified to answer this, but I can guess pretty good. Is the inside diameter of the socket tapered? Maybe it isn't tapered enough. I know a couple of people with RV-6A's(not on-line, incidentally) I had better try to get a peek and also pass on what has been happening to them. We "will" get to the bottom of this. Jim Nice RV6A WA State ________________________________________________________________________________
Date: Oct 13, 1998
Dear Jerry, I have a set of mags for sale. Call 920 432 4845 or reply off list. Dick Martin---------- > From: Jerry Isler <jlisler(at)surfsouth.com> > To: rv-list(at)matronics.com > Subject: RV-List: Lycoming Magnetos > Date: Monday, October 12, 1998 7:18 PM > > > Listers, > > I am looking for a pair of new or serviceable mags for an 0-320 Lycoming > (modified 0-320-E2D). Some of you guys that converted to electronic ignition > may have what I'm looking for. > > Contact off list if you have one or both. A hot lead will would be great if > you don't have the mags! > > Jerry Isler > RV4 #1060 > Donalsonville, Ga > > > > ________________________________________________________________________________
Date: Oct 13, 1998
Subject: Pipe Thread Compounds
Here is a post actually regarding RV building: Is the common hardware store pipe joint compound with TFE appropriate for pipe threads in A/C fuel system fittings? It says it is for fuel, but the application is rather important, so I want to be sure. A & P's? Thanks, Alex Peterson Maple Grove, MN 6A ________________________________________________________________________________
Date: Oct 13, 1998
-----Original Message----- From: MSN mail <solanas(at)email.msn.com> Date: Tuesday, October 13, 1998 7:40 AM Subject: RV-List: attaching wire connectors for #2 or #4 wire > >Even though I just happily smashed the large connectors onto the ends of the >large (#2 or #4 gauge)starter wire, it seems to me that the grip is not that >good, especially given all the engine vibration. > >Is there a special crimping technique or tool? Also, I didn't include any >insulation in the crimp, only because it didn't readily slide into the >connector. Should I have? > >Rick Solana, RV-6a N804RS >Richmond, VA > rick they do make a crimper for 4 ga and larger. It resembles a pair of boltcutters but has notches of different sizes for crimping. I've also encountered a hammer type. it was a cast body that the connector sat in then there was a hinged top that you smashed with a hammer. crude but it works. i bought mine at my local electrical contractor supply company. ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: Opinion request
talk to mark fredricks about the RV4 and its souped up companion the Harmon Rocket II. I went with a rocket do to the speed etc. Mark will be offering a quick build for it this spring and I am eagerly awaiting it so I can get started. I have sat in all of the planes etc the rocket since i live in oshkosh and eaa is like 5 mins away. The 8 is nice but I wanted more power and the rocket provided that and also the cockpit is wilder in the rocket Harmon Rocket II Homepage (unofficial) chris wilcox oshkosh, wi ________________________________________________________________________________
Subject: Wire Splices
Date: Oct 13, 1998
What is the acceptable method for splicing wires? I looked in my "Acceptable Methods...." book which says crimp connectors are preferable over soldered connections which tend to be brittle. It also said; 1:...to stagger splices in the same wire bundle so the diameter of the bundle is not enlarged more than one splice connector thick. 2:...to not have more than one splice in a wire. 3:...to not splice closer than 12" from the unit. The first I can do except where the wites comming out of the electrical unit are to short to stagger...like the Mac 8A servo. I can't do the second on this particular application because I will be hooking the servo to the Matronics governer. I can't do the third because the wites are to short. So....solder or crimp? Since I can't meet the rest of the "acceptable practices" I won't worry about them. Ross Mickey 6A Finishing Kit ________________________________________________________________________________
Date: Oct 14, 1998
<< The holes on the top are blind holes or wells for the CHT. Manifold pressure sensors won't work in these holes. The Manifold pressure sensor should replace a plug in the intake system. I believe you can use on of the primer holes which is what I think you are referring to when you say "below". Using the screw in probes are better than the spark plug type as your don't disturb them when hanging plugs. >> For the parallel valve Lycomings, CHT thermowells (F straight threads on a spot faced boss) are on the underside of the barrel pointing straight down. The primer or manifold pressure ports (1/8" FNPT) are on the lower corner of the head pointing out and just slightly down. The top ports (1/8" FNPT) are for the fuel injection lines. -GV ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: CO Monitors
<< I seem to remember a discussion on CO monitors awhile back, but got no hits. So, does anyone know what is available and where? >> There are three or so of the simple button type. Some are designed to be replaced anywhere from every month to every 18 months. Chief and ACS have them all. -GV ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: attaching wire connectors for #2 or #4 wire
>Even though I just happily smashed the large connectors onto the ends of the >large (#2 or #4 gauge)starter wire, it seems to me that the grip is not that >good, especially given all the engine vibration. > >Is there a special crimping technique or tool? Also, I didn't include any >insulation in the crimp, only because it didn't readily slide into the >connector. Should I have? >Rick Solana, RV-6a N804RS Rick, Bob Nuckolls has a very good article on attaching connectors to big gauge wires on his web site. I have used his technique and things look very robust. Leo Davies ________________________________________________________________________________
Date: Oct 14, 1998
>I am getting ready to fill my brake system with fluid. In using a pump >can to fill the system from the bottom-up(thru the nipple), do I need to >keep going until brake fluid comes out the reservoir on the firewall? Do >the brakes have to be pumped at all during this process? I thought about >slipping a stick down into the reservoir, pump one side until there is a >fluid level on the stick, then pump the other side till there is a higher >fluid level. Would this work? Seems like it would save the mess on brake >fluid spilling. Von, Get someone to look in the resevoir while you pump fluid in (you will see it rising through the clear tubing anyway. Once the fluid is above the master cylinder (visible in the clear tubing) you can give the pedal a few pumps to clear out any bubbles trapped in the master. I put in enough to just start filling the resevoir on one side and then finished filling it from the other. Its an easy and satisfying process. Leo Davies ________________________________________________________________________________
Date: Oct 13, 1998
Finn Lassen wrote: > > > Vanremog(at)aol.com wrote: > > I think that the factory has an obligation to point them out in their official > > publications (RV-ator, Service Bulletins, Service Letters) with the facts and > > the current factory position on each. > > In my limited experience, Van is not one to jump the gun. He does his > home work well before publishing such data. The RV-3 spar investigation > took more than a year but in the end he sent out *free* spar mod > material to all RV-3 owners/builders! > > Has an RVator issue been published since Fred's front gear failure? > > How many RV6As flying? How many front gear failures? > > Finn > I also think that this report should be taken into consideration. Especially the part about exiting the rwy at a high rate of speed. B. Reg.No.: 26MH M/M: EXP Desc: EXP/HOMEBUILT: VANS RV-6A Activity: Pleasure Phase: Landing GA-A/C: General Aviation Descr: ACFT LANDED ON RWY 30L AND NOSED OVER WHILE ATTEMPTING TO EXIT THE RWY AT A HIGH SPEED, MESA, AZ. -- Jerry Springer RV-6 N906GS First flight July 14, 1989 :-) Hillsboro, OR jsflyrv(at)ix.netcom.com ________________________________________________________________________________
Date: Oct 13, 1998
Loops can be done at any g-loading from about 3 up. I enter a loop at about 160mph indicated, pull 3g's up through vertical, float over the top at about 65, and pull 3gs on the way back down. This results in a very big loop, but it is very graceful, and very gentle on the airframe and the carbon life forms inside. You can make them smaller, with resulting higher g-loads. Ed Bundy - Eagle, ID RV6A - First flight 11/20/96 ebundy(at)mci2000.com http://home.mci2000.com/~ebundy@mci2000.com/ > >I'm wondering about loops and the force which may be exerted >on the airframe. In particular, I'm wondering about the end >of the loop (the part where you're basically pulling out of >a dive). I'm curious as to how many g's that part puts on >the plane (for those of you who have g meters and have done >the loops). I know there are several factors which will >determine the exact force, but some ball park figures would >be nice. Thanks ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: Pipe Thread Compounds
In a message dated 10/13/98 11:37:25 Central Daylight Time, alexpeterson(at)mci2000.com writes: << Is the common hardware store pipe joint compound with TFE appropriate for pipe threads in A/C fuel system fittings? >> I would venture to say no. Here is why. Normal pipe threads, are cut on a taper. If they are torqued properly, they should seal themselves, with no additional additives required. If you are using black iron, or galvanized pipe from the hardware store, then a sealer such as pipe joint compound might be appropriate. However, if you are using aircraft grade fittings with pipe threads, they should seal up nicely, if they are properly aligned. Regards Wendell WBWard(at)AOL.COM Rebuilding the "Junkyard Dog" RV-4 Kit Memphis, Tennessee (And an A&P for longer than I would like to admit.) ________________________________________________________________________________
Subject: Aileron Trailing edge
Date: Oct 13, 1998
There have been a few posts about rudder and aileron trailing edges in the last few days. One word of advice when squeezing the aileron trailing edge. Don't give them the final squeeze until after your first flights. I squeezed mine and the within the next week the RVator (1993) arrived with information on squeezing to rectify a heavy wing. Leave enough of a rounded trailing edge so that you have enough material to squeeze if you need to. Using a piece of wood and tapping from the back can make the trailing edge a little fatter but I am afraid it will take the paint off so have opted for a trimtab made of tapered balsa wood about 2" x 8" and 1/16 to 3/16 thick. Painted and glued to the bottom of the aileron. Works okay but wish I had done it right. This is where this list shines. Share and share alike. For those who haven't got there yet, this may help. Ken RV6 C-FKEH Beautiful British Columbia ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: Rudder Trim Tab???
<< I would like to build into my rudder a movable tab. >> Whatever for? -GV ________________________________________________________________________________
Date: Oct 14, 1998
><< Is the common hardware store pipe joint compound with TFE appropriate for >pipe threads in A/C fuel system fittings? >> > >I would venture to say no. Here is why. > >Normal pipe threads, are cut on a taper. If they are torqued properly, they >should seal themselves, with no additional additives required. > >If you are using black iron, or galvanized pipe from the hardware store, then >a sealer such as pipe joint compound might be appropriate. However, if you are >using aircraft grade fittings with pipe threads, they should seal up nicely, >if they are properly aligned. > >Regards > >Wendell WBWard(at)AOL.COM >Rebuilding the "Junkyard Dog" RV-4 Kit >Memphis, Tennessee >(And an A&P for longer than I would like to admit.) Wendell, I am not an A&P so hesitate to offer my advice over yours.....but...... I found that the AN fittings tended to gall when screwed into the master cylinders and brake units of the Parker-Hannefin manufactured components that Van supplies. My local A&P suggested using just a smear of PTFE compound on the threads..... this led to much less sweating and swearing. I suspect that this may be due to lubrication rather than any sealing properties.j Leo Davies ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: Titanium Landing Gear for -6A nose gear?
> Mark: Other than cables, which can only fail in tension, most structural failures in steel are compression. This is actually true of any metal. The compression failure is usually known as "buckling" like the wing on a plane pulling too many gees. A piece of round or square tubing will usually fail by buckling the compression face. Try a piece and see. As a general rule, bending of a solid bar will result in failure in tension, bending in a thin wall tube, sheet metal, beam, channel, or angle will result in failure by buckling of the compression face. On the other hand, fatigue failures are always in tension. The fatigue causes small cracks to grow until the tension pulls the part apart at the crack. Shot peening conditions the surface to eliminate small defects. However, it does not induce permanent compression that counteracts the tension caused by landing stresses. Normally, aircraft parts made of tubing and welds are stress relieved by heating with a torch. This method eliminates internal stresses (both tension and compression) to let the part work the best it can. It also helps prevent the cracking due to uneven cooling which can sometimes occur after welding. I am not sure exactly what information you were requesting. I hope this is of some use. How many pounds are saved by using titanium on the landing gear of the HR2? Joe Walker Deciding what gauges to add Houston > > > Please keep in mind that metal fails in tension, not compression. A discussion > last night with a -6 driver who is VERY familiar with heat treating and other > sorts of metal conditioning suggested shot-peening for any metal used like we > use our gear legs. This will keep the surface in a compression state, ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: Metal flakes in oil inlet screen
<< During an oil change today, I found 5 tiny metal flakes in my oil inlet screen. They appear to have a highly polished surface on one side, like flakes of chrome plating, but my cylinders aren't chrome plated. Disassembly of the oil filter revealed a couple of very tiny pieces that were very similar. I retained an oil sample that I'm sending off to have analyzed. My worst fear is that they are from either the bearings or the lifters. My gut instinct is that it's not normal to find pieces of metal in the screen's and filter. Has anyone else ever found metal in the inlet screen that is considered normal wear and tear? Mark LaBoyteaux >> Mark, One way to help figure out what type metal you have or where its comming from is to use a magnet on the flakes and see if theyre magnetic or not. You left out a few important details. Engine total time or time since overhaul. Its normal to have some flakes on a newer or newly overhauled engine with a couple hundred hours on it. How long its been since the last time you checked the screen. You mentioned that the cylinders you have are not chrome. Are they steel? Cermichrome? There are many variables. If you have a reputable engine shop or a good mechanic in your area they may be able to help put your mind at ease.( The oil analysis is always a good idea when in doubt. ) Ryan Bendure Co. ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: Unsubcribe
Please unsubscribe me from the list for the time being - I'm changing internet providers. thanks Stuart Hawksworth ________________________________________________________________________________
Date: Oct 14, 1998
Subject: More Mazda Powered Rv-6A Photos
For those of you interested, Don Mack has just posted some photos of the engine compartment of my Mazda Powered RV-6A on his web page www.flash.net/~donmack/. Ed Anderson RV-6A N494BW Vienna, VA ________________________________________________________________________________
Date: Oct 14, 1998
In a message dated 10/14/98 3:58:19 AM Eastern Daylight Time, leo(at)icn.su.OZ.AU writes: << Normal pipe threads, are cut on a taper. If they are torqued properly, they >should seal themselves, with no additional additives required. >> As a piping contractor I must disagree with this statement. Pipe dope is used first as a lubricant, because when threads are cut, there is a jagged surface to the cut threads, and second it also fills in the spaces, however small, between the cut threads on the pipe, and the cut threads in the fitting. Teflon is used because it is a good lubricant. Gasoline is a solvent and as such will find leaks that few other liquids will. Therefore, I would use some type of sealant/lubricant on any threaded connections, especially fuel line ones. To answer the original question, yes, PTFE containing dopes are suitable for fuel system use. ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <stuckle(at)ifc.utc.com>
Date: Oct 14, 1998
> -----Original Message----- > From: halk(at)sybase.com [SMTP:halk(at)sybase.com] > Sent: Tuesday, October 13, 1998 8:17 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Titanium Landing Gear > > > I am wondering if the edges of the socket are chafing the leg? I > could imagine > this if the leg is able to move in the socket. Some mentioned shimmy > as being > possibly related. I would expect shimmy to increase the chafing. > > I suppose there are many RV6A's hours without the problem? > > hal > Hal, The design of the motor mount tube and the gear leg shape rules out a chafing problem. The break on my gear leg was a classical fatigue break due to a crack that formed just below larger diameter area of the lower tube bearing area. The break occurred in an area where the leg diameter is significantly less than the area that mates with the tube. Fred Stucklen N925RV RV-6A E. Windsor, Ct ________________________________________________________________________________
Date: Oct 14, 1998
<< Is the common hardware store pipe joint compound with TFE appropriate for pipe threads in A/C fuel system fittings? It says it is for fuel, but the application is rather important, so I want to be sure. A & P's? >> No,no,no NEVER use thatTFE tape on your aircraft fittings! It is very likely that a small pc of the end will work its way into a fuel or oil system, with potential consequences. We use Permatex #2 here, but there are others available. Check six! Mark ________________________________________________________________________________
Date: Oct 14, 1998
Adrian... In a well performed loop, you should pull 3 to 3.5 G's. By the way, when done correctly, you should pull close to this going up and at the bottom. Do yourself a favor and get instruction before you try it. The big danger is not getting over the top or falling out at the top. Chat Daniel RV-8 678RV (reserved) ---------- > From: Adrian Chick <adrianchick(at)home.com> > To: rv-list(at)matronics.com > Subject: RV-List: aerobatics > Date: Tuesday, October 13, 1998 9:21 PM > > > I'm wondering about loops and the force which may be exerted > on the airframe. In particular, I'm wondering about the end > of the loop (the part where you're basically pulling out of > a dive). I'm curious as to how many g's that part puts on > the plane (for those of you who have g meters and have done > the loops). I know there are several factors which will > determine the exact force, but some ball park figures would > be nice. Thanks > > RV6A- working on empenage (thinking WAY ahead).... > > > > ________________________________________________________________________________
Date: Oct 14, 1998
<< I'm wondering about the end of the loop (the part where you're basically pulling out of a dive). I'm curious as to how many g's that part puts on the plane (for those of you who have g meters and have done the loops). >> Adrian- I enter loops in my 6A at 180 mph. Pull-up and recovery are 3.5g. 70 mph over the top. -GV ________________________________________________________________________________
Date: Oct 14, 1998
During transition training with Mike Seager in the RV-6, I asked him about loops. He said "sure, you just keep pullin' about two G's all the way around". We didn't do any then; matter-o-fact I've never done a loop, but that's what I recall Mike saying. Sounds like that would make a big, lazy loop compared to what everyone else is saying. -Larry Mental loops while working on RV-8 Rudder ---Chat Daniel wrote: > In a well performed loop, you should pull 3 to 3.5 G's. By the way, when > done correctly, you should pull close to this going up and at the bottom. > Do yourself a favor and get instruction before you try it. The big danger > is not getting over the top or falling out at the top. > > Chat Daniel > RV-8 678RV (reserved) > > ---------- > > From: Adrian Chick <adrianchick(at)home.com> > > > > I'm wondering about loops and the force which may be exerted > > on the airframe. In particular, I'm wondering about the end > > of the loop (the part where you're basically pulling out of > > a dive). I'm curious as to how many g's that part puts on > > the plane (for those of you who have g meters and have done > > the loops). I know there are several factors which will > > determine the exact force, but some ball park figures would > > be nice. Thanks > > > > RV6A- working on empenage (thinking WAY ahead).... > > ________________________________________________________________________________
Date: Oct 14, 1998
Alex Peterson wrote: > > > Here is a post actually regarding RV building: Is the common hardware > store pipe joint compound with TFE appropriate for pipe threads in A/C fuel > system fittings? It says it is for fuel, but the application is rather > important, so I want to be sure. A & P's? > > Thanks, > Alex Peterson > Maple Grove, MN 6A > Alex I'm not an A&P, but when I looked into this I found a product called Fuel Lube. This coincided with someone on the list selling it in film containers for 5.00$. I've had no leaks or problems. Craig Hiers RV-4 N143CH Tallahassee,FL. ________________________________________________________________________________
Date: Oct 14, 1998
<< I am not an A&P so hesitate to offer my advice over yours.....but...... I found that the AN fittings tended to gall when screwed into the master cylinders and brake units of the Parker-Hannefin manufactured components that Van supplies. My local A&P suggested using just a smear of PTFE compound on the threads..... this led to much less sweating and swearing. I suspect that this may be due to lubrication rather than any sealing properties.j >> On advice of my mechanic, I used a dollop of Permatex Aviation Form-A-Gasket black goo on the brake system threaded fittings, especially helpful on the brass elbows going into the master cylinders on the pedals, which never seemed to point in the desired direction when tightened "dry." So far, 100% satisfied. Also used this material under the gaskets for the fuel tank inspection plates and senders, on the threads for the quick-drains, etc. No leaks! Bill B RV-6A flying / western VA ________________________________________________________________________________
Date: Oct 14, 1998
Subject: VSI Indication
OK folks, I am puzzeled by the indication on my vertical velocity indicator. When I am flying straight and level (really!) the indicator is indicating approx 1000 fpm down. When I climb the indicator still indicates down (descent) (just not as much). My airspeed and altimeter are both connected to the same static source and Appear to be normal. It would appear (to one of limited knowledge about the VSI) that if the calibrated hole were plugged it should be registering zero. In fact the only way I can figure that the VSI would indicate down is if there is positive pressure in the static line. But, I would assume that would cause my airspeed and altimeter to read lower than actually and at least I do not see any indication of that. Any Ideas before I yank it out and take it to the Instrument shop??? Ed Anderson RV-6A N494BW Vienna, VA ________________________________________________________________________________
Date: Oct 14, 1998
Subject: 6A nose gear stresses 101
Listers: More from the engineer I spoke with about the -6A nose gear failure. For flames, etc, see the bottom line. Check six! Mark << Subj: Re: Fwd: RV-List: Titanium Landing Gear for -6A nose gear? Date: 98-10-14 10:46:45 EDT Mark, The comments on steel failure forwarded to me are not accurate. I can assure you that there are several different types of failure modes for steel. His response does not address fatigue failure at all. Fatigue failure is the cause of the gear failure I have seen and heard about. Fatigue failure is ALWAYS in tension. Any Metallurgy 101 book will confirm that. Shotpeening DOES create compressive stresses at the surface. The surface compressive stresses do improve the fatigue limits of normal steel members. I have seen the results of X-Ray defraction testing which actually quantified the residual COMPRESSIVE stress from shot peening processes. I am very concerned that people might ignore the potential benefits of shot peening based upon some uninformed opinions which are broadcast on the web. I'm not trying to sell shot peening - but it works. Another potential way to improve the fatigue life of gear legs is to polish them at the highly stressed areas. This eliminates the minute scratches (stress risers) and also eliminates the decarburization which is present on the surface of the 6150 heat treated steel gear legs. Decarburization is evidenced by the black oxide which is present on the gear legs as recieved from Vans. Describing why removing decarburization helps fatigue life will take a very long explanation. Thats in Metallurgy 201. Hot Rodders have not been polishing and shot peening connecting rods, cranks, etc. for the past 50 years because they had too much extra time or money. Please stick this on the web. My Email address is seibert(at)swbell.net if anybody wants to comment or flame me. Regards, Bob >> ________________________________________________________________________________
Date: Oct 14, 1998
<< To answer the original question, yes, PTFE containing dopes are suitable for fuel system use. >> I have found that for aircraft fuel systems these are the general rules: -A properly flared connection requires no sealant, however a thread lubricant may be helpful. -All NPT threaded joints need some kind of sealant/lubricant. -Sealants must be non-permanent/non-hardening. -Use all sealants sparingly and only in the thread area that will be engaged. -DO NOT use PTFE (Teflon) threadseal tape, ever! -PTFE containing dopes are acceptable, but not preferred, because they won't always prevent the galling and seizure that can occur in aluminum to aluminum or stainless to stainless applications (I have found that the Permatex/Loctite brands work best) -Fuelube/Sealube products (sold thru aviation suppliers) are best for use on aluminum to aluminum or stainless to stainless NPT threaded joints as they prevent galling and seizure. -The old standby, Permatex gasket sealer #2 (flexible), will also work well for everything. -Torque all fittings properly. -GV ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: aerobatics (loops)
> >I'm wondering about loops and the force which may be exerted >on the airframe. If you think about it, you have gravity and airspeed working against you at the bottom of the loop and helping you at the top. For a constant radius loop (read: round) your airspeed will be higher at the bottom and you will be pulling against gravity. I find that an entry pull of about 3.5 g and an entry speed of about 130 kts indicated is comfortable. If you don't pull hard enough you won't complete the first 180 degrees by the time you run out of airspeed and if you pull too hard the induced drag will burn off your energy (you run out of airspeed) before you complete the first 180 degrees (this is less of a problem with our slick airplanes). I find that I "float" over the top at about 70 kts and about 0.5 g. As you come down the backside, be sure to pull hard enough that the airplane doesn't overspeed. Our RV's are slick and accelerate like a squeezed watermelon seed when the nose is pointed down. If you think about it, you will realize that to complete a round loop, the pull and airspeed at the end of the loop will be exactly the same as the initial pull and airspeed to start the loop. As for "falling out the top," that will happen if you run out of energy before you reach the apex of the loop. The safe thing to do is to go to zero angle of attack (zero G) so the wing doesn't stall even if you get really slow. It won't be a pretty loop but you won't stall/spin either (no stall, no spin, no exceptions). Just ride it over the top and let the nose fall through naturally (the fall-through may be surprisingly quick). Once you get a bit of airspeed you may start to pull again and round out the bottom. Like others, I recommend going out and doing some aerobatics with an aerobatic instructor just to get the feel of things. I did my RV-transitional aerobatic training in a Christen Eagle and found that, with the exception of the RV's greater acceleration when pointed downhill, the two weren't all that far apart in terms of behavior (positive G maneuvers here). An RV-whatever and a Citabria/Decathalon are two completely different breed of cat so I suspect that, if you are used to what a Citabria does, you might be a bit surprised when you try to do the same things in your RV. Disclaimer: I am not you. Your milage may vary. Brian Lloyd Lucent Technologies brian(at)lcp.livingston.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6399 - voice +1.530.676.3442 - fax O- ________________________________________________________________________________
Date: Oct 14, 1998
Question?? Does the Rocket still have full aerobatic capability? What is so wild about the cockpit? hal > and the rocket provided that and also the cockpit is wilder in the rocket ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: VSI Indication
<< I am puzzled by the indication on my vertical velocity indicator. When I am flying straight and level (really!) the indicator is indicating approx 1000 fpm down. When I climb the indicator still indicates down (descent) (just not as much). My airspeed and altimeter are both connected to the same static source and Appear to be normal. It would appear (to one of limited knowledge about the VSI) that if the calibrated hole were plugged it should be registering zero. In fact the only way I can figure that the VSI would indicate down is if there is positive pressure in the static line. But, I would assume that would cause my airspeed and altimeter to read lower than actually and at least I do not see any indication of that. Any Ideas before I yank it out and take it to the Instrument shop??? >> Ed- When it's just sitting there on the ground what does the VSI read? Should be zero. When you had your Mode C system calibrated, the shop would have brought out an instrument that simulates the pressure changes that would occur at altitude. This equipment can be used to check the VSI also. It certainly sounds as your VSI has something wrong with it, if your info regarding the ASI and Altimeter is accurate. -GV ________________________________________________________________________________
Date: Oct 14, 1998
From: "Scott A. Jordan" <SAJ_SLJ(at)compuserve.com>
Message text written by INTERNET:rv-list(at)matronics.com >I am puzzeled by the indication on my vertical velocity indicator. When I am flying straight and level (really!) the indicator is indicating approx 1000 fpm down.< Does it read a descent on the ground? There is usually an adjustment screw on the face of the instrument. Typically a small screw in the bottom left of the faceplate. Scott A. Jordan 80331 riveting bottom wing skins ________________________________________________________________________________
Date: Oct 14, 1998
Hi Mark: The message from Ryan Bendure Co. pretty well covers it. From past experience would add the following. If the flakes are aluminum, engines equipped with aluminum wrist pin plugs will sometimes shed the occasional flake. If it is steel and the screen was clean on previous oil change I would find the source before running it any more. This can sometimes be done without a complete tear down such as pulling a couple of cylinders. If I can be of any help contact me at my email address. Good luck. Eustace Bowhay ________________________________________________________________________________
Date: Oct 14, 1998
> > During an oil change today, I found 5 tiny metal flakes in my oil inlet >screen. They appear to have a highly polished surface on one side, like flakes >of chrome plating, but my cylinders aren't chrome plated. Disassembly of the >oil filter revealed a couple of very tiny pieces that were very similar. I >retained an oil sample that I'm sending off to have analyzed. My worst fear is >that they are from either the bearings or the lifters. My gut instinct is that >it's not normal to find pieces of metal in the screen's and filter. Has anyone >else ever found metal in the inlet screen that is considered normal wear and >tear? Bearing material is neither hard nor shiny. If the metal is ferrous (magnetic) you are probably looking at cam/lifter/crank/oil pump gear material. Given the propensity for Lycoming engines to lunch their cams/cam followers (lifter bodies), that is the first place I would look. If you look at the top of the engine you will notice that two of the pushrod housings are lined up with each other (I think it is #2 intake and #3 exhaust but I don't have either engine or overhaul manual in front of me). Since this cam lobe drives two followers/lifters, this is the one that usually fails first. Pull one of the involved cylinders (#2 or #3) so you can inspect the cam lobes (be careful to protect the rod with a rag when you lay it against the edge of the case). I bet this is where your metal is coming from. If so, you win the $10,000 opportunity to overhaul your engine. Sorry. Brian Lloyd Lucent Technologies brian(at)lcp.livingston.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6399 - voice +1.530.676.3442 - fax O- ________________________________________________________________________________
Date: Oct 09, 1998
Larry Bowen wrote: > > During transition training with Mike Seager in the RV-6, I asked him > about loops. He said "sure, you just keep pullin' about two G's all > the way around". If you pull constant Gs in a loop, the loop obviously isn't a circle; it's more like a script "e." This maneuver has a name, but I forget it; the point is that it isn't a classical loop because you come out of the loop at a different point than where you enter it, i.e., you gain ground during the loop. One prevents a stall at the top of a well-executed loop by smoothly pulling sufficient Gs when entering it and having sufficient airspeed. I recommend some competent instruction prior to trying any aerobatic maneuvers other than, perhaps, lazy eights. You may otherwise suddenly find yourself in a position that you'll find scary at best and, at worst, dangerous. Best wishes, Jack Abell Los Angeles RV-6A N333JA (Reserved) ________________________________________________________________________________
Date: Oct 09, 1998
SportAV8R(at)aol.com wrote: > > > < compound on the threads..... > >> > > On advice of my mechanic, I used a dollop of Permatex Aviation Form-A-Gasket > black goo on the brake system threaded fittings, . . . Isn't anyone but me using Fuel Lube on threaded fittings? Have I screwed up again? Jack Abell Los Angeles RV-6A N333JA (Reserved) ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Left Elevator Rear Spar Problem
After mounting my elevators I laid a straight edge on the left to line up the trim tab and saw a huge valley in the elevator that I hadn't noticed before. The archives turned up Dave Carter's post (which I must have missed somehow) and responses indicate that the elevator rear spar is delivered too wide (which would account for my problem). A response to Dave's question indicates that this is a common problem - but I'm worried about the aerodynamic effects. Will this dip behave as a trim tab itself (deflecting airflow upwards) and have to be counteracted by trim (ergo more drag)? Am I building a slow airplane here? Does it matter? Am I being too, er.... attentive? I'm bummed! Mike Thompson Austin, TX -6 Emp details, starting wings by the end of the month! ________________________________________________________________________________
Date: Oct 14, 1998
Reads zero sitting on the ground, so still puzzled?? Ed Scott A. Jordan wrote: > > > Message text written by INTERNET:rv-list(at)matronics.com > >I am puzzeled by the indication on my vertical velocity indicator. > When I am flying straight and level (really!) the indicator is > indicating approx 1000 fpm down.< > > Does it read a descent on the ground? There is usually an adjustment screw > on the face of the instrument. Typically a small screw in the bottom left > of the faceplate. > > Scott A. Jordan > 80331 > riveting bottom wing skins > ________________________________________________________________________________
Subject: Firewall mounted oil cooler
Date: Oct 14, 1998
Listers, I'm just beginning to work on my firewall mounted oil cooler. In the instructions, it is suggested that a back plate be installed on the firewall to take up some of the vibration caused by the cooler. Since they didn't include the material in the kit, can those of you who installed the firewall version tell me what thickness you used and about how far past the cooler you went on all sides? I just want to make sure the thing is thick enough and with enough area to do the job. Besides, I think I'm going to need some ballast up front, anyway. :-) Jim Sears in KY RV-6A N198JS ________________________________________________________________________________
Date: Oct 14, 1998
What does it read on the ground? ---------- > > > OK folks, > I am puzzeled by the indication on my vertical velocity indicator. > When I am flying straight and level (really!) the indicator is > indicating approx 1000 fpm down. When I climb the indicator still > indicates down (descent) (just not as much). My airspeed and altimeter > are both connected to the same static source and Appear to be normal. > It would appear (to one of limited knowledge about the VSI) that if the > calibrated hole were plugged it should be registering zero. In fact the > only way I can figure that the VSI would indicate down is if there is > positive pressure in the static line. But, I would assume that would > cause my airspeed and altimeter to read lower than actually and at least > I do not see any indication of that. > > Any Ideas before I yank it out and take it to the Instrument shop??? > > Ed Anderson > RV-6A N494BW > Vienna, VA > > > > ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: Wheel Nut Installation- another 2 cents worth
> >Scott:& Mark > >If the parts don't work as produced, why not change the specification on one >or the other part? In the days before front wheel drive some car manufacturers on their front wheel bearings used a normal thin nut with a hardened washer between nut and bearing with a pressed steel shaped like the inside of a twelve sided socket with slots in the portion on the axel. This gave a fine adjustment. These pressing should be cheaply available from the automotive industry. This also means changing the number washers with the thin nut for each application is easy. P.S. Scott if you want a drawing email me offline, as an engineer sketches are easier than English. -- Rob Hatwell ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: 6A nose gear stresses 101
Mark: Being a practicing structural engineer with a specialty in failure analysis for over twenty years has made me pay close attention to this thread. I do not remember seeing the posting which stated that fatigue failure was not due to tension, perhaps you got it from another source.. For the record, shot peening only affects the surface and does not reduce, in any way the, bending induced tension stresses. Shot peening works by making tiny impact craters at random which act in the same way stop drilling a crack in plexiglas stops the crack from growing. The microscopic stress discontinuities which contain compressive forces directly under the impact points do not add or subtract from the bending stress in any way. There are an equal amount of tension forces added to satisfy the laws of physics. The whole purpose of shot peening is to prevent micro cracks from growing into big cracks. Polishing removes surface defects and does the same thing in a different way. Heat treatment does several things including, setting the temper, blending the grain of the metal to eliminate internal cracks, and eliminating internal stresses. However, stress cycles work harden the metal and cause the basic grain structure to change. Once this process is complete the metal has lost it's ductility and becomes brittle. At this points it will break (instead of bend) and becomes unsuitable for high stress applications no matter what type of surface treatment it has had. The standards of the FAA and all publications by the EAA are uniform about heat treating (to remove internal stresses) and polishing (to remove stress risers). It should be noted that both of these processes are normally used in the manufacture of hot rod crank shafts. Shot peening is not normally used in the manufacture of aircraft because the standards for design and construction are so high and their limits so well known, the addition of internal stresses, if only at a surface level, are unnecessary. Hot rod crankshafts, by contrast, are commonly pushed well past design limits and anything which helps delay failure is used. They will eventually fail anyway, perhaps not as quickly. There is nothing wrong with using shot peening as a surface treatment.. However, if the design and construction of the homebuilt aircraft part are correct there is also no need for it. Shot peening will add no allowable stress to the design of a member nor will it add additional cycles to failure to the published fatigue values for metals at a given temper. Hence the general absence of it in military aircraft. The cost of shot peening could go to more gas or whatever. I would appreciate you sending me the posting I missed, or whatever you sent your friend. Perhaps we can help the listers understand the processes at work and ease their concerns about the current nose gears failures. I also am concerned that the listers get good information. The best information will eventually come from Van. This whole mess may eventually work out to being caused by a few critical parts which were not properly heat treated or contained surface defects. Joe Walker P.E. President R.J. Walker & Associates, Inc. Consulting Engineers RV6 (the one without the nose gear) > Mark, > The comments on steel failure forwarded to me are not accurate. > I can assure you that there are several different types of failure modes > for steel. His response does not address fatigue failure at all. > Fatigue failure is the cause of the gear failure I have seen and heard > about. > Fatigue failure is ALWAYS in tension. Any Metallurgy 101 book will > confirm that. > Shotpeening DOES create compressive stresses at the surface. The surface > compressive stresses do improve the fatigue limits of normal steel > members. I have seen the results of X-Ray defraction testing which > actually quantified the residual COMPRESSIVE stress from shot peening > processes. > I am very concerned that people might ignore the potential benefits of > shot peening based upon some uninformed opinions which are broadcast on > the web. I'm not trying to sell shot peening - but it works. > skip > Hot Rodders have not been polishing and shot peening connecting rods, > cranks, etc. for the past 50 years because they had too much extra time > or money. > Please stick this on the web. My Email address is seibert(at)swbell.net if > anybody wants to comment or flame me. > Regards, > Bob > ________________________________________________________________________________
Date: Oct 14, 1998
While everyone has their favorite compound for pipe threads, it should be noted that the application matters too. I was taught to apply a uniform thin layer to all but the first one or two threads (the first ones to enter the joint). This keeps any pipe dope from getting in your line. Regards: Joe Walker Looking for gauges RV6 Houston > ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: One Flight Test View on BRSs
Ronald Blum wrote: > > >>Van also commented about a BRS in a recent RVator - he said, as I recall, > >>that the structural changes needed would be extensive, and he thought that > >>the weight penalty would be great - as I recall his remarks. > > Think about the conditions in which YOU would deploy the chute. As a really > rough estimate, opening loads would be in the range of > (0.5)*rho*V^2*S*1.3 -at least. That's a lot of load going into the attach > point . . . and a lot of Gs on you and the entire airframe. Van's right on > the structural beef up. Realize, however, that the S (reference area of the parachute) in your estimate is a function of time. If that big honkin' parachute opens all at once with a pop -- yeah, you're going to leave two wet spotson the inside of your sunglasses and something in the airframe or parachute is going to give. If the chute opens gradually, the S starts out small, reducing the V as S grows, so the the deceleration is less. Quote from AVweb: (http://www.avweb.com/newswire/news9828.html) Cirrus' biggest bugaboo was getting a piece called a "slider" to work the way it should. Any parachute deployed at 160 knots on a plane as heavy as the SR20 is torn to shreds. The slider does just what the name implies...it "slides" down the inside of the parachute, allowing more and more fabric to deploy as the plane slows. That slider, says Maddy, was a "hard thing to get right." The CAPS system now deploys properly and manages to slow the plane's descent to less than 30 feet per second at 5,000 feet density altitude. ) 1998 The AVweb Group. All rights reserved.No, I'm not going to try to install a ballistic parachute in my RV-8 (I'll be sitting on one for flight testing and aerobatics), but I thought this made for an interesting discussion. Final note -- I wish I could remember which type it was, but within the last few months I read about an aircraft that experienced a loss of control during flight test and deployed an aircraft parachute system, but it wrapped around the airplane and couldn't save the test pilot. > Ron > FLY-IN-HOME(at)worldnet.att.net > > ps. This message will look like crap if I haven't solved my e-mail > problems. > > ps2 As for the -8 proto, I have 110% confidence in Van's design. All > airplanes will come apart when over-G occurs. The BRS would not have helped > here, either. You don't think so? How come? Roll rate? > > > ps3 Yes, in the 75 year history of spam, we have used all three different > type of chutes we carry (personal, high speed and spin). > Todd Whelan RV-8 #554 in Atlanta twhelan(at)acs.mar.lmco.com ________________________________________________________________________________
Date: Oct 14, 1998
>Rick; > >I feel sure that there is a special tool for this crimping of battery line >terminals. Since there are left handed monkey wrenches and special pieces >of flight line If you know any electricians (especially industrial electricians) or contractors I am sure that they will have a "Hy-Press", it is used to crimp large wire connections. The Hy-Press is a hydraulic press with a hand pumped handle. The tool makes great crimp connections in large wire (usually much larger than you will find in house wiring. #6AWG all the way up through 750MCM). Perhaps if you bring the wire to them they will be happy to crimp it for you. Vince ________________________________________________________________________________
Date: Oct 14, 1998
Mike, I too had that problem. It bugged me alot but I left it alone and got on to building the wings. While I was waiting for my fuselage kit, I had a little extra time and went back and fixed it by drilling out the spar, bending it to the right shape and riveting it back in. Looks like it's supposed to now. I'm sure it wouldn't affect the handling, and alot of other things have a much greater effect on drag. I fixed it because I hated the way it looked. Laird in SoCal RV-6 22923 Canopy stuff >>I'm worried about the aerodynamic effects. Will this dip behave as a trim tab itself (deflecting airflow upwards) and have to be counteracted by trim (ergo more drag)? Am I building a slow airplane here? Does it matter? Am I being too, er.... attentive? I'm bummed! Mike Thompson Austin, TX -6 Emp details, starting wings by the end of the month!<< ________________________________________________________________________________
Date: Oct 14, 1998
In a message dated 10/14/98 12:53:47 PM Central Daylight Time, halk(at)sybase.com writes: > Does the Rocket still have full aerobatic capability? This souncs like a question for Mark Fredricks > What is so wild about the cockpit? Cockpit is wider for the front seat 36" back seat is 25" I would assume thats what the post ment instead of wilder. ________________________________________________________________________________
Date: Oct 14, 1998
---------- >From: "B&S Eckstein" <
eckstein@net-link.net> >To: "rv-list" >Subject: Re: RV-List: VSI Indication >Date: Wed, Oct 14, 1998, 7:33 PM > > >What does it read on the ground? > >---------- >> >> >> OK folks, >> I am puzzeled by the indication on my vertical velocity indicator. >> When I am flying straight and level (really!) the indicator is >> indicating approx 1000 fpm down. When I climb the indicator still >> indicates down (descent) (just not as much). My airspeed and altimeter >> are both connected to the same static source and Appear to be normal. >> It would appear (to one of limited knowledge about the VSI) that if the >> calibrated hole were plugged it should be registering zero. In fact the >> only way I can figure that the VSI would indicate down is if there is >> positive pressure in the static line. But, I would assume that would >> cause my airspeed and altimeter to read lower than actually and at least >> I do not see any indication of that. >> >> Any Ideas before I yank it out and take it to the Instrument shop??? >> >> Ed Anderson >> RV-6A N494BW >> Vienna, VA >> >> >> >> > > > > > 1000 fpm seems excessive, but there is an adjustment on the face of every VSI I've ever flown behind which can be used to set zero. It is a small flathead screw on the edge of the dial. Just set it on the ground before takeoff. I've heard rumors that a fingernail can be used to set it, although I personally would never of course do that. Of course, since it is an FAA approved device, which has been liberally sprinkled with FAA holy water,you should probably keep your "amateur" hands in your pocket and find an A&P.... ;-) James Freeman ________________________________________________________________________________
Date: Oct 14, 1998
In a message dated 10/14/98 6:19:23 PM Central Daylight Time, vwelch(at)knownet.net writes: > >I feel sure that there is a special tool for this crimping of battery line > >terminals. Since there are left handed monkey wrenches and special pieces > >of flight line > Easist place to take a 1/0, 2, 4, 6 guage wire to get crimped is your local car stereo shop. They are always dealing in 1/0 and 2 guage wire for the main power wires. I have always run 2 guage wire in my car for the stereos and they are usually younger guys working there and they will do alot of work for free specially if you offer them a ride. PS they are usually really good at wiring so if you need help, a few rides will give you a lot of help. ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Off list: Crankcase vent line
On 24 Sep 98, at 2:25, Vanremog(at)aol.com wrote: > Oil mist captured by condensing out on the s/s media sinks to the bottom > of the separator where it runs into a bottle ACS p/n 06-11225 (a clear > Matco brake fluid reservoir) equipped with a Saf-Air drain valve ACS p/n > CAV-110H4 which gets drained at oil changes. The 5/8" outlet of the > separator is dumped using more of the silicone hose with a whistle slot > and a short piece of 5/8" aluminum tubing onto the right exhaust pipe. GV, How to do you attach the fluid line from the air/oil seperator to the Matco brake reservoir. Mine has a bolt for a cap. I've been unable to find a fitting that is the same diameter as the bolt. Did you just drill thru your bolt, and attach the line to the bolt? Thanks Tim _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023, engine completed and tested Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: Wire Splices
I'd use a butt splice. One wire in one side, two in the other, then crimp away. Or if you're not afraid to solder.... If you're going to splice onto a wire that has not been cut and has one end disconnected, you can strip a bit more insulation off the end, then cut the insulation in the desired splice location (hopefully not too far from the end of the wire), then slide the insulation toward the wire end exposing bare wire in your desired splice location. Slip some heat shrink tubing on past the exposed bare wire and solder your wire splice to this bare spot. Make sure the wires are parallel to each other and not perpendicular. Then slide the heat shrink over the soldered wires and shrink it. You can modify this technique if you have to cut the wire. I just don't like soldering three wires together at once (although I've done it). When I used to work as a tech we had these inline splices. They looked like a butt splice with a wire coming out the side. Maybe someone knows of a company that sells these things. Mr. Knuckolls? > >What is the acceptable method for splicing wires? I looked in my >"Acceptable Methods...." book which says crimp connectors are preferable >over soldered connections which tend to be brittle. >It also said; >1:...to stagger splices in the same wire bundle so the diameter of the >bundle is not enlarged more than one splice connector thick. >2:...to not have more than one splice in a wire. >3:...to not splice closer than 12" from the unit. > >The first I can do except where the wites comming out of the electrical >unit are to short to stagger...like the Mac 8A servo. I can't do the >second on this particular application because I will be hooking the servo >to the Matronics governer. I can't do the third because the wites are to >short. > >So....solder or crimp? Since I can't meet the rest of the "acceptable >practices" I won't worry about them. > >Ross Mickey >6A Finishing Kit > > > > -- Scott VanArtsdalen svanarts(at)jps.net "The essence of character is doing what's right, even when nobody's looking." - J. C. Watts ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Firewall Forward
Fellow Builders, I have a few questions for everyone as I fiddle with all of the hook-ups on the engine. If you can help me out, I'd appreciate it. 1) My engine, O-320-D2A has a fitting on top of the number 1 cylinder opposite of the normal primer port. My question is "Can I use this port (the top one) to pull my manifold pressure from?" The other cylinders do not have this port on top, only the one. 2) What is the best way to connect up the fuel pressure sender? Should I plumb some fittings right off of the carb? Should I mount the sender remote? 3) Where is the best place to mount the oil pressure sender. It is fairly large and cylindrical. If you mount it to the engine mount, how did you fasten it? Did you mount it on the firewall? Again, how did you fasten it. Thanks folks. Randy Pflanzer N417G "Special Angel" RV-6 - Engine compartment ________________________________________________________________________________
Date: Oct 14, 1998
Subject: trim tab range of movement
Listers; I am happy to report that RV-6 N827GB left my shop on 10-11-98 after almost six years of work and now is at the local grass strip in my hanger awaiting final details and a sign off by the FAA. One question: in final assembly I noticed that I have almost the same range of motion of my trim tab on the elevator as the ailerons require- 15 degrees down and about 30 degrees up. Is 15 down enough? I find nothing in the assembly manual that addresses range of travel for the trim tab. Thanks. Gary Bray Carmel, Maine hoping to beat the snow to first flight! ________________________________________________________________________________
Date: Oct 14, 1998
In a message I deleted, I think that you mentioned that it reads Zero on the ground. Could it be that the Pitot is driving this instrument instead of the static? It would logically seem that this would peg the vsi at it's lowest setting, but them, I've never tried it. ---------- > > > What does it read on the ground? > > ---------- > > > > > > OK folks, > > I am puzzeled by the indication on my vertical velocity indicator. > > When I am flying straight and level (really!) the indicator is > > indicating approx 1000 fpm down. When I climb the indicator still > > indicates down (descent) (just not as much). My airspeed and altimeter > > are both connected to the same static source and Appear to be normal. > > It would appear (to one of limited knowledge about the VSI) that if the > > calibrated hole were plugged it should be registering zero. In fact the > > only way I can figure that the VSI would indicate down is if there is > > positive pressure in the static line. But, I would assume that would > > cause my airspeed and altimeter to read lower than actually and at least > > I do not see any indication of that. > > > > Any Ideas before I yank it out and take it to the Instrument shop??? > > > > Ed Anderson > > RV-6A N494BW > > Vienna, VA > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 14, 1998
> I am very concerned that people might ignore the potential benefits of > shot peening based upon some uninformed opinions which are broadcast on > the web. I'm not trying to sell shot peening - but it works. Pardon my ignorance but................................just what exactly is shot peening? Vince ________________________________________________________________________________
Subject: Wing Rear Spar Dimpling
Date: Oct 14, 1998
I am in the process of dimpling the .040 rear wing spar on my RV8, and am not sure how to dimple the holes near the root end on the top side of the wing. The W-806GPP reinforcement fork gets in the way, especially for the last 5 holes where the W807DPP reinforcement plate also gets in the way. I was thinking of machine countersinking these 25 holes in the spar and dimpling the skin to fit, but am concerned that countersinking the spar (it is only .040) will weaken the joint or cause the rivets to work loose over time. How have other builders been handling this problem? Am I missing something? Aaron Gleixner Wings - RV8A ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: Firewall Forward
<< I have a few questions for everyone as I fiddle with all of the hook-ups on the engine. If you can help me out, I'd appreciate it. 1) My engine, O-320-D2A has a fitting on top of the number 1 cylinder opposite of the normal primer port. My question is "Can I use this port (the top one) to pull my manifold pressure from?" The other cylinders do not have this port on top, only the one. It sounds like you have one cyl with this port drilled. We use the primer port on the rear right cyl, to keep the hose shortest. It really doesn't matter which port or cyl you use, but some are easier to hook up 2) What is the best way to connect up the fuel pressure sender? Should I plumb some fittings right off of the carb? Should I mount the sender remote? Remote. The sender could break at its threads if left to hang that way. Use the fuel pump fitting from Van's that has the 1/4" hole drilled in it, and run a hose to the sender (hung on the engine mount). 3) Where is the best place to mount the oil pressure sender. It is fairly large and cylindrical. If you mount it to the engine mount, how did you fasten it? Did you mount it on the firewall? Again, how did you fasten it. A correctly sized non-cushioned (grounding) adel clamp, attaching the sender to the firewall where it's easy to wire, would work fine. You could use the same approach for the fuel sender, but it really should be mounted at the same height as the port it reads from on carbureted engines (to read a fairly close to correct pressure). Neither of these lines really needs firesleeving- there is no flow, only pressure. Use the correct restrictor orfices at the pressure sources, too. Keep working- it's really worth it. Check six! Mark >> ________________________________________________________________________________
Subject: Re: Wing Rear Spar Dimpling
Date: Oct 14, 1998
Aaron, The .040 rear wing spar is more than thick enough to countersink for those last few holes. Although too late for this situation, I did not rivet the wing skeleton together until after the skins were drilled, everything deburred, dimpled and primed. Keeping things together with clecoes until everything is done (as much as possible) has allowed me to back out of problems spots more than once. Carl Froehlich RV-8A (skinning wings) Vienna, VA ________________________________________________________________________________
Date: Oct 14, 1998
Hi Aaron, I just machine countersinked (is this a word?) these on my wings. I think they even mention this in the manual. Jeff Hawkins RV-8 #563 Suwanee, Georgia Wings done... Fuselage under way... ---------- > From: Aaron Gleixner <agleix(at)worldnet.att.net> > To: rv-list(at)matronics.com > Subject: RV-List: Wing Rear Spar Dimpling > Date: Wednesday, October 14, 1998 8:47 PM > > > I am in the process of dimpling the .040 rear wing spar on my RV8, and am not sure how to dimple the holes near the root end on the top side of the wing. The W-806GPP reinforcement fork gets in the way, especially for the last 5 holes where the W807DPP reinforcement plate also gets in the way. I was thinking of machine countersinking these 25 holes in the spar and dimpling the skin to fit, but am concerned that countersinking the spar (it is only .040) will weaken the joint or cause the rivets to work loose over time. How have other builders been handling this problem? Am I missing something? > > Aaron Gleixner > Wings - RV8A > > > ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: Bleeding of Brakes
I got very good results by using a simple pressure pot consisting of a 16 oz model aircraft fuel tank filled with Hyd fluid. Connect to the brake, pressurize to a few psi to get good flow. A tube from the reservoir to catch the overflow. First trys left some air in the system. The solution was to establish some flow and then pump the brake, very slowly. I have dual brakes on the -6, and after one try, pumping both brakes on the circuit gave a completely filled system. Bruce Patton All at the airport, wings going on this weekend!! ________________________________________________________________________________
Date: Oct 14, 1998
Mark, Don't know the time on your engine. Knew a guy who found alum flakes in the oil and it turned out to be the oil pump gears. AD had not been acp. RV4 Stew Bergner CO. ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Re: Crankcase vent line
<< How to do you attach the fluid line from the air/oil separator to the Matco brake reservoir. Mine has a bolt for a cap. I've been unable to find a fitting that is the same diameter as the bolt. Did you just drill thru your bolt, and attach the line to the bolt? >> Tim- I tapped the cap hole out to 1/4" NPT, used an AN flare fitting, 3/8" alum line and a short piece of 3/8" ID fuel line to join to the drain at the separator. -GV ________________________________________________________________________________
Date: Oct 14, 1998
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
>I'd use a butt splice. One wire in one side, two in the other, then crimp >away. Agreed >Or if you're not afraid to solder.... If you're going to splice onto a >wire that has not been cut and has one end disconnected, you can strip a >bit more insulation off the end, then cut the insulation in the desired >splice location (hopefully not too far from the end of the wire), then >slide the insulation toward the wire end exposing bare wire in your desired >splice location. Slip some heat shrink tubing on past the exposed bare >wire and solder your wire splice to this bare spot. Make sure the wires >are parallel to each other and not perpendicular. Then slide the heat >shrink over the soldered wires and shrink it. You can modify this >technique if you have to cut the wire. I just don't like soldering three >wires together at once (although I've done it). > >When I used to work as a tech we had these inline splices. They looked >like a butt splice with a wire coming out the side. Maybe someone knows of >a company that sells these things. Mr. Knuckolls? Actually, a company called Raychem (and probably others) make some very specialized solder sleeves that are installed with a heat gun. They're commonly used to attach ground jumpers to the braided wires of a shielded conductor. I've seen them used to create the kind of butt joints you suggest. Your technique is better because you can see what's going on with the solder before the heatshrink is applied. By-in-large, I'll vote for the PIDG butt splice any day . . . The MAC servos do present a unique problem . . . Why doesn't EVERYBODY on this list write to MAC and suggest they upgrade to 22AWG leads. It's not hard to do and it makes their product compatable with the majority of wiring products out there. You guys are 1000+ strong . . . you can make a difference. ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Great news on the B&C Saga . . .
I just got of the phone with Bill Bainbridge who recounted the day's experiences with the FAA. Administrator Garvey called his office this morning to see if all of the promised items and followup from the FAA had been delivered to Bill's satisfaction. Bill was pleased to report that things were in order. The long sought letter of appology has been crafted and signed (Bill has an unofficial copy) and is winding its way through the maze of approval required for such weighty documents. Watch AVWeb for next Monday. Liz Swaine (lady pilot and TV news anchorperson) is doing a piece to recap the events since OSH where Ms. Garvey first became aware of how badly her staff had bashed B&C and Mr. Bainbridge. To her credit, she didn't let this issue languish nor did she forget it. Watch our website for a posting of relevant documents concerning the original issue and its resolution. It's to Bill's credit that he didn't roll over and take it in the shorts like so many folk have felt compelled to do in the past. One reason for posting the documents pertaining to this matter is to allow the aviation community to hold future administrators accountable to the standards Ms. Garvey has errected during her term of office. Further, having these documents available to the aviation public may well be the encouragement others need to bear the burdens government can heap upon citizens even when they've done nothing wrong. This has been a GOOD day . . . ________________________________________________________________________________
Subject: Re: Firewall mounted oil cooler
Date: Oct 14, 1998
Jim, I elected to go with the method shown in the last RVator. I plan to mount the oil cooler in the left cowl cheek. Rather than weld tabs to my engine mount tubes I will use cushioned clamps and aluminum brackets. I needed the limited firewall space for the Christen inverted system. Regards, Tom Craig-Stearman tcraigst(at)ionet.net RV-4 64ST soldering harness for transponder, encoder, and GPS > >I'm just beginning to work on my firewall mounted oil cooler. ________________________________________________________________________________
Date: Oct 14, 1998
>In the days before front wheel drive some car manufacturers on their >front wheel bearings used a normal thin nut with a hardened washer >between nut and bearing with a pressed steel shaped like the inside of >a >twelve sided socket with slots in the portion on the axel. This gave a >fine adjustment. >These pressing should be cheaply available from the automotive >industry. >This also means changing the number washers with the thin nut for each >application is easy. > >P.S. Scott if you want a drawing email me offline, as an engineer >sketches are easier than English. > >-- I know exactly the part you are talking about. The problem is that if I remember correctly these are used on axles that protrude through the nut with the hole for the pin on the out side of the nut. Problem is... RV's use axle nuts that are closed off on the end so these parts would be of no use. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Date: Oct 14, 1998
>During transition training with Mike Seager in the RV-6, I asked him >about loops. He said "sure, you just keep pullin' about two G's all >the way around". We didn't do any then; matter-o-fact I've never done >a loop, but that's what I recall Mike saying. Sounds like that would >make a big, lazy loop compared to what everyone else is saying. > > I used to do big loops at only 2 G's in my RV-6A. I think it is as much dependant on the particular RV you are flying as it is how you are flying it (well not entirely but it is a factor). If you are flying an RV that has a bit of a beer belly (spent all of your beer money on do-dads and wing-dings for your airplane instead of beer) you are going to suffer with having less "total performance". Your airspeed will be used up much quicker going vertical and energy management will be a little more critical. Factor in a heavy RV with a lower HP engine and it gets even worse. The best example of this I have ever seen was when Van used to do his airshow routine in his RV-4 (light weight, constant speed prop, with full inverted systems). He was very good at doing a loop in a loop (a very large loop with a very small loop done at the top of the large one). Definitely the epitome of energy management. Personal opinion comment follows.... I see so many posts on the list about doing aerobatics in RV's with detailed descriptions of how the poster thinks they should be done, but then they end with "but don't try this at home without proper dual instruction first" This seems counter productive to may and possibly dangerous. It is possible to make it sound sooooo easy that many may anyway. Now I know that this list is for passing along info and that it is good for pilots that have had some of the suggested training to be able to compare notes with others, but I am concerned that it may lead to a frightening situation for some RV pilots. I suppose the flight instruction by E-mail will never really be stopped so I will just ad (with a pleading tone in my voice) Please get some dual training in aerobatics before you try any maneuver that would be considered an aerobatic maneuver as stipulated in the FAR's. Yes, RV's are a lot of fun to do aerobatics in, and with the proper training they can do most maneuvers very well (in fact the airplanes are probably more capable than most of us will ever be), but they are high performance airplanes which means you can get into trouble very very quickly, if you have not received proper training. Please be careful, and have fun. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Subject: Re: More Mazda Powered Rv-6A Photos
Date: Oct 14, 1998
>For those of you interested, Don Mack has just posted some photos of >the engine compartment of my Mazda Powered RV-6A on his web page >www.flash.net/~donmack/. Ed, Thanks for passing along the pictures. I'll be more interested than most to hear how the testing goes along. I do have an oil question though. I noticed that you're using the engine on it's side like Ross Aero does, and I guess you're using their oil tank system as well. Do you (or anyone else that is reading this) happen to know if the rotary can have an inverted oil system for negative G aerobatics? Perhaps the Ross system is capable of this already. I just took some aerobatic training at Mudry aviation, and now I think I might want to have an inverted oil system to go along with inverted fuel pickup. Good luck, and keep us posted. Rusty ________________________________________________________________________________
Date: Oct 14, 1998
Maybe there is a leak in the case or face glass. -----Original Message----- From: Vanremog(at)aol.com <Vanremog(at)aol.com> Date: Wednesday, October 14, 1998 1:51 PM Subject: Re: RV-List: VSI Indication > > ><< I am puzzled by the indication on my vertical velocity indicator. > When I am flying straight and level (really!) the indicator is > indicating approx 1000 fpm down. When I climb the indicator still > indicates down (descent) (just not as much). My airspeed and altimeter > are both connected to the same static source and Appear to be normal. > It would appear (to one of limited knowledge about the VSI) that if the > calibrated hole were plugged it should be registering zero. In fact the > only way I can figure that the VSI would indicate down is if there is > positive pressure in the static line. But, I would assume that would > cause my airspeed and altimeter to read lower than actually and at least > I do not see any indication of that. > > Any Ideas before I yank it out and take it to the Instrument shop??? >> > >Ed- > >When it's just sitting there on the ground what does the VSI read? Should be >zero. When you had your Mode C system calibrated, the shop would have brought >out an instrument that simulates the pressure changes that would occur at >altitude. This equipment can be used to check the VSI also. It certainly >sounds as your VSI has something wrong with it, if your info regarding the ASI >and Altimeter is accurate. > >-GV > > > > > > ________________________________________________________________________________
Date: Oct 14, 1998
I was thinking of machine countersinking these >25 holes in the spar and dimpling the skin to fit, but am concerned >that countersinking the spar (it is only .040) will weaken the joint >or cause the rivets to work loose over time. How have other builders >been handling this problem? Am I missing something? > This is what is recommended. Though you should only have to machine countersink the inboard most 7 or 8 holes. The ones that are the most restricted by the (can't remember the part #) rear spar attach fitting plate. The ones that are next to the forked part of the rear spar attach plate can be dimpled. I thought it was in the plans or construction manual. I will try to remember to to check and see that it is. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Date: Oct 14, 1998
Todd Whelan wrote: > Final note -- I wish I could remember which type it was, but within the last few > months I read > about an aircraft that experienced a loss of control during flight test and > deployed an aircraft > parachute system, but it wrapped around the airplane and couldn't save the test > pilot. You may be referring to the tragic loss of Jim Collie. Jim was testing a new ultra-light motor glider of his design when a wing spar delaminated. The BRS deployed properly but became entangled in the broken wing. Jim was a very careful engineer of considerable talents. His loss reminds us that we cannot guarantee a perfect safety record regardless of flight/design skills and pre-flight preparation. The BRS is only one potential component of flight safety; It is however, not perfect and certainly should be regarded solely as a recourse of last resort. Those who advocate chute deployment for "minor" circumstances such as fuel starvation or being trapped on top of a cloud layer probably have not considered the prospects of becoming a passenger on a windblown, uncontrolled vehicle that is very rapidly headed for a violent contact with earth. An impact of 26 ft/min HURTS! Add to this the possibility of ending the journey in powerlines, upside in water, or some other unpleasant location without the pilot's (passenger's?) choosing. BRS states in their literature that they are only attempting to give the pilot a shot at a "survivable" impact (the pilot's survival...forget about the plane), certainly not a comfortable one. The BRS debate will continue for as long as folks wish. It has raged in the UL ranks for years, and the UL community has remained split on the issue even though their aircraft are much more suited for BRS installation than ours. This is a complex issue, much more complicated than just floating down effortlessly as the chute billows comfortably above you. Sam Buchanan (have flown with and without a BRS) "The RV Journal" http://www.ath.tis.net/~sbuc/rv6 ________________________________________________________________________________
Date: Oct 14, 1998
Raychem makes shield terminations and splices. They are kind of expensive though. ________________________________________________________________________________
Date: Oct 14, 1998
> 2) What is the best way to connect up the fuel > pressure sender? Should I plumb some fittings right > off of the carb? Should I mount the sender remote? I purchased an outlet fitting for my fuel pump from Van's that had an 1/8" npt thread manufactured on it, in order to plumb it to a fuel pressure transducer. I mounted the fuel pressure transducer on the firewall with a #26 clamp. I installed a restrictor, and got the clamp idea from Tony Bengelis's books on engines. > > 3) Where is the best place to mount the oil pressure > sender. It is fairly large and cylindrical. If you > mount it to the engine mount, how did you fasten it? > Did you mount it on the firewall? Again, how did you > fasten it. I mounted the oil pressure transducer the same way I mounted the fuel transducer. Mark LaBoyteaux RV-6A N106RV MLaboyteau(at)aol.com ________________________________________________________________________________
Date: Oct 14, 1998
Subject: Audio mixer
>I want to connect two radio's together so that I can switch to either for >transmit and receive, with the option to receive on both. I know audio >panels are available commercially, but they usually contain Markers ADF etc >which I do not need, not to mention the cost. >The only problem I have encountered, is feeding the two audio outputs into >one speaker at the same time. Some form of isolation circuit is required >to prevent the two radios trying to drive each other backwards, so to >speak. Are you really considering a "speaker"? Don't know many homebuilts with sufficiently low cabin noise to allow comfortable use of speakers. Here's something I've used on several simple systems (two receivers). Use a 47 ohm, 1/2 watt resistor in series with EACH radio's headset output to drive both headsets in paralle. This has the effect of cutting output voltage from each receiver by 1/2 but it's generally made up quite easily by turning up the volume. I genrally don't bother to put switches in the headset lines from each radio and choose to control each radio by setting its volume control. Use a two-pole, two position switch to flip the microphone audio and press-to-talk lines between the two transmitters. This is very easy to implement and see how it works before you go out and buy/build an isolation amplifier. Bob . . . //// (o o) ===========o00o=(_)=o00o========= < If you continue to do > < What you've always done > < You will continue to be > < What you've always been. > ================================= ________________________________________________________________________________
Date: Oct 15, 1998
> >Fellow Builders, > >I have a few questions for everyone as I fiddle with >all of the hook-ups on the engine. If you can help >me out, I'd appreciate it. > >1) My engine, O-320-D2A has a fitting on top of the >number 1 cylinder opposite of the normal primer >port. My question is "Can I use this port (the top >one) to pull my manifold pressure from?" The other >cylinders do not have this port on top, only the one. > I used one of the primer ports that didn't have a primer line for the manifold pressure. >2) What is the best way to connect up the fuel >pressure sender? Should I plumb some fittings right >off of the carb? Should I mount the sender remote? I have to say that I hooked the pressure sender directly to the carburator. I DON'T recommend this method as the vibrations from the engine can break the sender off from the carb. This WILL make a very bad day for you. What you should do is remotely mount the sender using a fuel line from the carb to the sender. > >3) Where is the best place to mount the oil pressure >sender. It is fairly large and cylindrical. If you >mount it to the engine mount, how did you fasten it? >Did you mount it on the firewall? Again, how did you >fasten it. > You can probably mount the oil press sender using adel clamps to hold the oil line. This will hold the sender easily. >Thanks folks. > > >Randy Pflanzer N417G "Special Angel" >RV-6 - Engine compartment > John Ammeter Seattle WA USA 1975 JH-5 RV-6 (sold 4/98) ________________________________________________________________________________
Subject: Re: trim tab range of movement
Date: Oct 15, 1998
> >Listers; >I am happy to report that RV-6 N827GB left my shop on 10-11-98 after almost >six years of work and now is at the local grass strip in my hanger awaiting >final details and a sign off by the FAA. >One question: in final assembly I noticed that I have almost the same range of >motion of my trim tab on the elevator as the ailerons require- 15 degrees down >and about 30 degrees up. Is 15 down enough? I find nothing in the assembly >manual that addresses range of travel for the trim tab. >Thanks. >Gary Bray >Carmel, Maine >hoping to beat the snow to first flight! > My RV-6 only needed about 1 to 5 degrees up for all flight conditions. I'd suggest you fly the plane and find out what, if any, adjustments you may need on the angle of incidence/attack of the horizontal stab. Once you have the HS dialed in you will probably find that the trim tab motion is more than you will ever need. John Ammeter Seattle WA USA 1975 JH-5 RV-6 (sold 4/98) ________________________________________________________________________________
Date: Oct 15, 1998
<< I have almost the same range of motion of my trim tab on the elevator as the ailerons require- 15 degrees down and about 30 degrees up. Is 15 down enough? >> The tab on my 6A never needs to go more than 1/4" up or down (from ref neutral) at the TE to trim for all normal conditions. -GV ________________________________________________________________________________
Date: Oct 15, 1998
Subject: 6A nose gear stresses 101
Shot peening is basicly sandblasting with round steel shot. ______________________________ Reply Separator _________________________________ Subject: Re: RV-List: 6A nose gear stresses 101 Date: 14-10-98 20:58 > I am very concerned that people might ignore the potential benefits of > shot peening based upon some uninformed opinions which are broadcast on > the web. I'm not trying to sell shot peening - but it works. Pardon my ignorance but................................just what exactly is shot peening? Vince ________________________________________________________________________________
Date: Oct 15, 1998
>>I elected to go with the method shown in the last RVator. I plan to mount the oil cooler in the left cowl cheek. Rather than weld tabs to my engine mount tubes I will use cushioned clamps and aluminum brackets. I needed the limited firewall space for the Christen inverted system.<< I gave that idea some thought. I'm just afraid of hanging heavy stuff on the tubes. Of course, that could be silly; but, I feel more comfortable not doing it. It sure looked good, though! Thanks! Jim in KY ________________________________________________________________________________
Date: Oct 15, 1998
Hi Rusty, Thanks for the comments on my project. Yes, I am using the Ross oil pan, however, I recently discovered a problem with that. It turns out that with the engine on its side the oil level with with 7 quarts (1 for cooler, one for filter and five for the pan) raises the oil level sufficiently in the pan to keep the rotors oil outlet opening continously bathed in oil. One my engine above 5000 rpm the rotors cause the oil to churn so much that it blows oil out the crankcase breather and cause oil pressure to flucuate 30 psi. There is a relative simply fix - add an extention to the oil pan to keep the oil below the block and extend the oil pick up to keep it below the new oil level. My engine would only reach 5000 rpm on the ground with teh 68x72 prop so I did not realize this was a problem (should have in hindsight) until I got up some airspeed an unloaded the prop so the engine could rev higher. So definetly keep that in mind. In the racing circuits some folks use a dry sump which the 13B adapts to quite readly, however that then means you have to come up with the mechanics to drive the sump. That would give you an inverted oil system. On the other hand, if you are just going to be doing basic level aerobatics with no prolonged inverted flight, the current system would do just fine. In intend to lower the oil level by two quarts which should drop the level below the rotors and then see what happens at higher rpm. But, this is the kind of thing you sign up for if you go the alternative engine route. Its really a mini R&D project, so be prepared for it to take longer, cost more than you had planned. If you are a "Gear Head" then its just all part of the fun and challenge, if however, you are mainly interested in getting an airplane into the air, I strongly recommend a good used lycoming. 4th flight coming up this weekend, going to take it to a local fly in and show of my baby. Ed Russell Duffy wrote: > > > >For those of you interested, Don Mack has just posted some photos of > >the engine compartment of my Mazda Powered RV-6A on his web page > >www.flash.net/~donmack/. > > Ed, > > Thanks for passing along the pictures. I'll be more interested than most to > hear how the testing goes along. > > I do have an oil question though. I noticed that you're using the engine on > it's side like Ross Aero does, and I guess you're using their oil tank > system as well. Do you (or anyone else that is reading this) happen to know > if the rotary can have an inverted oil system for negative G aerobatics? > Perhaps the Ross system is capable of this already. I just took some > aerobatic training at Mudry aviation, and now I think I might want to have > an inverted oil system to go along with inverted fuel pickup. > > Good luck, and keep us posted. > Rusty > ________________________________________________________________________________
Date: Oct 15, 1998
<< I needed the limited firewall space for the Christen inverted system.<< >> Doug Dodge makes a very high quality system also. The breather can is quite a bit smaller, and will fit these cramped engine nacelles slightly easier. His cost is lower than the FAA approved Christen system..... I found out about this after I had installed my Christen system, too. :-( Check six! Mark HR2 295 hrs ________________________________________________________________________________
Date: Oct 15, 1998
Subject: Re: Pipe Thread Compounds
In a message dated 10/14/98 1:27:17 PM Eastern Daylight Time, Vanremog(at)aol.com writes: << -The old standby, Permatex gasket sealer #2 (flexible), will also work well for everything. >> Yes, but remember that Permatex is not for use with alcohol, if you are using auto gas that may contain alcohol, DON'T use Permatex #2 ________________________________________________________________________________
From: "Ronald Blum" <fly-in-home(at)worldnet.att.net>
Date: Oct 15, 1998
IRT the chute opening time. Your statement is correct, but it is that opening, "shock load" that normally rights the airplane. We use them for drag more than anything. In other words, to get the pointy end going forward and down (normally a recoverable mode). They are NOT designed to bring the airplane safely to rest on the ground. IRT the openning time, we don't use sliders but do reef the high speed chutes (make smaller). BUT, I know of a high speed chute deployment at Vtrue > 400 knots on a 10,000# airplane. Also as a side note, we release the chute after it has done its job of righting the aircraft. >Final note -- I wish I could remember which type it was, but within the last few >months I read about an aircraft that experienced a loss of control during flight test and >deployed an aircraft parachute system, but it wrapped around the airplane and couldn't save the test >pilot. This is not an abnormal condition. If something is so wrong to deploy a chute, it's probably not travelling in straight and level flight. >IRT -8 proto accident . . . You don't think so? How come? Roll >rate? Yes, roll rate (and position) with a piece of the wing now missing and time from 1000' agl to the ground. Ron FLY-IN-HOME(at)worldnet.att.net ________________________________________________________________________________
Date: Oct 15, 1998
Subject: Homemade pressure bleeder was bleeding brakes
Listers, I was recently directed to the web site below. It shows a photo of the homemade brake pressure bleeder described below. I got this from an automotive email list for Mercedes owners. It would be a simple matter of changing the resevoir cap to adapt this idea to your RV. Charlie Kuss RV8 wings Boca Raton, Fl. > I got very good results by using a simple pressure pot consisting of a 16 oz > model aircraft fuel tank filled with Hyd fluid. Connect to the brake, > pressurize to a few psi to get good flow. A tube from the reservoir to catch > the overflow. First trys left some air in the system. The solution was to > establish some flow and then pump the brake, very slowly. I have dual brakes > on the -6, and after one try, pumping both brakes on the circuit gave a > completely filled system. Date: Mon, 5 Oct 1998 12:56:42 -0400 From: Ted Grozier <grozier(at)fas.harvard.edu> Subject: [MB] brake bleeding If y'all are lying on your backs bleeding your own brakes, you can easily make a pressure bleeder, which makes the job so easy (and, for the perverse few, even fun) that you'll do it every year. I have put some pictures on-line:
http://www.fas.harvard.edu/~grozier/bleeder.jpg and .../cap.jpg, .../top.jpg My homemade EziBleed: The main bottle is a Nalgene 32oz wide-mouth camping bottle, the white plastic kind, not the grey lexan. The lexan cracks under pressure, at least mine did. Atop the cap, to one side, sits a screw-on tire valve. On the other side, a hole is drilled for a rubber grommet into which slides 1/4 plastic tubing. The fit must be tight. Soapy water or spit helps here. The tube goes to the bottom of the bottle, like a straw. The other end of the tube (it is ~2.5 ft long) attaches with the same grommet to the brake resevoir cap. Go to the dealer and buy a new cap -- it is an upgraded part anyway. Doctor the old one: remove the small one-way diaphram on the underside of the cap. Seal the small hole with a hot screwdriver. Then drill in the center for the grommet. I think it was 17/64 but I can't remember. Best way is to use one of those drill gauges with all the holes and try for the tightest fit. With a turkey baster, suck all the fluid out of the resevoir. Fill almost to the max mark with new fluid. (a good DOT 4 like Castrol LMA) Pour about 3/4 liter new brake fluid into the bottle, tighten the lid, and attach the resevoir cap. With a bicycle pump, slowly add pressure, checking for leaks. Use a good pressure gauge and do not exceed 15psi. I used a 6" hand pump and it took about 25 strokes. Only a small amount of fluid will travel from the bottle to the resevoir since the resevoir will hold pressure. Now go to the right rear wheel and open the bleed screw, using rubber tubing to channel the fluid into a collection container. As the fluid level drops in the resevoir, new fluid will travel from the bottle to the resevoir. The level in the resevoir stays constant. Using the markings on the Nalgene bottle, let at least 100ml flush out each brake, but do not stop until the fluid coming out of the bleed screw is clean and bubble-free. Check the bottle pressure and maintain 15psi. Resist the temptation to increase the pressure beyond 15psi; each wheel only takes 3min or so and spilled brake fluid is a pain. Bleed the other brakes in this order: right rear, left rear, right front, left front; that is, working towards the MC. If you have installed a new master cylinder, bleed the MC with it's bleed screw. Also remember to only release the bottle pressure at the valve; do not unscrew either cap or you're in for a nasty surprise. You can flush hydraulic clutch circuits, too. Good luck to all and change that brake fluid! "Annually, preferably in the spring." Ted 83 240D 298K, nice firm pedal. You can get the EEZI-Bleed, by Gunson Ltd., from John Abbott, Auto Expert Products, 2574 NW 29th Drive, Boca Raton, FL 33434, (561) 483-7898. http://members.aol.com/eezibleed/, the correct number is 800-795-6958, or you can e-mail John at eezibleed(at)aol.com. ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <stuckle(at)ifc.utc.com>
Date: Oct 15, 1998
Jim & Listers, I mounted my oil cooler (a rather large C-182 heavy unit) to the right side motor mount area (in front & below the cabin air box on the firewall) using 1/8" angle alum and Adel clamps. Upper cowl air is routed from the upper rear baffle area (above & behind Cyl #3) through a 3" hose to a home made fiberglass plenum on the oil cooler. The plenum on the oil cooler was formed using builders insulation foam (from home depot) shaped to what I thought was about the right shape. The hose attachment area was formed using a spray can cover. The shaped foam was then covered with plaster, sanded and coated with mold release. I put on two layers of glass. When the glass dried, I riveted in a metal sleeve for the final hose connection as the spray can cover diameter plus glass thickness was just a little oversized for the hose. This whole process took two evenings of work. The result is an oil cooler mounted in a position that will not cause baffle breakage..... Fred Stucklen N925RV RV-6A E. Windsor, Ct > -----Original Message----- > From: Jim Sears [SMTP:sears(at)searnet.com] > Sent: Thursday, October 15, 1998 9:47 AM > To: rv-list > Subject: Re: RV-List: Firewall mounted oil cooler > > > > >>I elected to go with the method shown in the last RVator. I plan to > mount the oil cooler in the left cowl cheek. Rather than weld tabs to > my engine mount tubes I will use cushioned clamps and aluminum > brackets. I needed the limited firewall space for the Christen inverted > system.<< > > I gave that idea some thought. I'm just afraid of hanging heavy stuff > on the tubes. Of course, that could be silly; but, I feel more > comfortable not doing it. It sure looked good, though! > > Thanks! > > Jim in KY > > > > ________________________________________________________________________________
Date: Oct 15, 1998
Since oil weighs less than water and a 1 foot difference in location makes about 0.4 of a pound difference, worrying about sender location is overkill. -----Original Message----- From: Mlfred(at)aol.com <Mlfred(at)aol.com> Date: Wednesday, October 14, 1998 10:28 PM Subject: Re: RV-List: Firewall Forward > > ><< I have a few questions for everyone as I fiddle with > all of the hook-ups on the engine. If you can help > me out, I'd appreciate it. > > 1) My engine, O-320-D2A has a fitting on top of the > number 1 cylinder opposite of the normal primer > port. My question is "Can I use this port (the top > one) to pull my manifold pressure from?" The other > cylinders do not have this port on top, only the one. > >It sounds like you have one cyl with this port drilled. We use the primer port >on the rear right cyl, to keep the hose shortest. It really doesn't matter >which port or cyl you use, but some are easier to hook up > > 2) What is the best way to connect up the fuel > pressure sender? Should I plumb some fittings right > off of the carb? Should I mount the sender remote? > >Remote. The sender could break at its threads if left to hang that way. Use >the fuel pump fitting from Van's that has the 1/4" hole drilled in it, and run >a hose to the sender (hung on the engine mount). > > 3) Where is the best place to mount the oil pressure > sender. It is fairly large and cylindrical. If you > mount it to the engine mount, how did you fasten it? > Did you mount it on the firewall? Again, how did you > fasten it. > >A correctly sized non-cushioned (grounding) adel clamp, attaching the sender >to the firewall where it's easy to wire, would work fine. You could use the >same approach for the fuel sender, but it really should be mounted at the same >height as the port it reads from on carbureted engines (to read a fairly close >to correct pressure). > >Neither of these lines really needs firesleeving- there is no flow, only >pressure. Use the correct restrictor orfices at the pressure sources, too. > >Keep working- it's really worth it. > >Check six! >Mark > >> > > > > > > ________________________________________________________________________________
Date: Oct 15, 1998
From: Mike Thompson <michaelt(at)AUSVMR.VNET.IBM.COM>
News-Software: UReply 3.1 In a previous message, it was written: > >Aaron, > > The .040 rear wing spar is more than thick enough to countersink for >those last few holes. > > Although too late for this situation, I did not rivet the wing >skeleton together until after the skins were drilled, everything >deburred, dimpled and primed. Keeping things together with clecoes until >everything is done (as much as possible) has allowed me to back out of >problems spots more than once. > >Carl Froehlich >RV-8A (skinning wings) >Vienna, VA On the other hand, I learned a lesson on my elevators to _always_ rivet the skeleton before drilling he skins! The clecos allow _some_ movement and I found that after drilling the skins to a clecoed skeleton, then riveting the skeleton, the holes on the skins were off just a tad. Not much in most areas, but a tad in others (root rib) which says they didn't rivet together the same as they were clecoed despite using the technique of remove a celco, replace with rivet, all the way along. Haven't done the wings yet, but I'll be keeping the elevator fiasco in mind. Mike Thompson Austin, TX -6 emp details, waiting on wings... ________________________________________________________________________________
Date: Oct 15, 1998
Subject: Re: VSI Indication
Ed, Sounds like you have a leak in the case of the VSI, probably around the front glass. Remove the face and try reseating the gasket- a little RTV might help. Good Luck Bill Mahoney RV-6 N747W Sherman, CT ________________________________________________________________________________
Date: Oct 15, 1998
Thanks Bill, Sounds like something easy enough to do, appreciate the info. Ed RV6ator(at)aol.com wrote: > > > Ed, > > Sounds like you have a leak Remove the face and try reseating the gasket- a little RTV might help. > > ________________________________________________________________________________
Subject: aerobatics (loops)
Date: Oct 15, 1998
Most loops look more like an egg with the bigger part down. Before the start of a loop, gravity is offset by the wing pulling one G. As the loop starts, you pull three G's. One G is still required to offset the earths gavity. Therefore, the plane turns with the effect of only two G's. At the 90 degree climb point, gravity and drag work together and it no longer has any effect in the turn so all three G's are now turning the plane. As you go upside down, gravity is pulling you in the direction you want to go and adds to the three G's pulling by the wing so you effectively are turning with four G's. (Guess, why Fighter Pilots want to be above you?) At the 90 degree dive point, gravity works with thrust and the plane agains turns with three G's. So without accounting for the constantly changing airspeed, you have to fight gravity at the bottom and will have a larger turn radius and gravity helps at the top and causes a smaller turn radius. Using a constant three G loop, there will be three G's on the engine and engine mount at all times. A G is a G is a G. What you see on the G meter or feel by the seat of your pants is what the plane sees too. Tom Gummo Apple Valley, CA starting the fuselage ________________________________________________________________________________
Subject: Fuel Pressure Gauge Venting
Date: Oct 15, 1998
Listers; I have a combo Manifold Pressure and Fuel Pressure gauge, that also has a third hook-up for Vent. Where does this go? Does raw fuel ever come out of this vent? Should it just go thru the firewall and vent overboard? Thanks. Von Alexander RV-8 N41VA N41VA(at)juno.com ________________________________________________________________________________
Date: Oct 15, 1998
In a message dated 10/14/98 10:39:05 PM Pacific Daylight Time, nuckolls(at)aeroelectric.com writes: << . Why doesn't EVERYBODY on this list write to MAC and suggest they upgrade to 22AWG leads. >> This is a very good idea. There are several easy ways to make the leads work for you as is. One way is to use a Circular Area Units chart. For instance, a raychem moisture proof splice(blue-16ga) per the chart, can be crimped with one 20ga wire in one side because the CAU's of a 20ga wire fall within the limitations of the splice. Two 22ga wires can be placed on the other side. They also fall within the limitations. If you need to "take up space" to meet the CAU requirements, you can use a wire loop, or, if you need less CAU's, you can use one wire and cap it on the end. I do, however, agree that it would be pretty easy for them to use another size of wire for their pigtails. What are they using? 24?? Jim Nice RV6A WA State ________________________________________________________________________________
Subject: Nose gear legs
Date: Oct 15, 1998
I am taking this opportunity to disseminate some information about the failures to those concerned about same. Please understand that this is not official from Van's and I did not ask permission to speak for them, but it bothers me that some think the worst of Van and the staff due to the rumor mill. I spoke to the office today about another matter and then asked about the gear legs because I want to build a 6A. (They are running about 58% as opposed to 6s in demand). It was said that they are very much aware of the heat on the net and that their supplier is doing extensive tests involving changes and duty cycles, which takes a long time to study. There is a notice being drafted to be sent out to every 6A owner in the near future. Finally, yes, the failures seem to be date/batch related. One more finally, 100 hr checks will catch any potential problems before they become catastrophic since the cracks are not sudden in nature. Lots of warning. I knew Van's was a group of people with integrity and concern about their customer/fliers and it is just unfortunate that broadcast messages are not sent out quickly to update all concerns. They are not sitting idle. That phone is going all the time......Hope this helps some out there..... ________________________________________________________________________________
Subject: Pressure Bleeders
Date: Oct 15, 1998
Why go to all of the trouble to make something that you will only use once or twice? We used to use a pump oil can and a short length of clear tubing connected to the bleeder at the caliper and a rag at the master cyl to catch the vented fluid, it doesnt take much to bleed the system on a plane so not much is spilled especily if the master cylinder is empty when you start as it fills the line will be cleared of all air. ________________________________________________________________________________
Date: Oct 15, 1998
<199810140419.XAA04923@dfw-ix14.ix.netcom.com> > > >>I'd use a butt splice. One wire in one side, two in the other, then crimp >>away. > > Agreed > >>Or if you're not afraid to solder.... If you're going to splice onto a > Actually, a company called Raychem (and probably others) make some > very specialized solder sleeves that are installed with a heat gun. > They're commonly used to attach ground jumpers to the braided wires > of a shielded conductor. I've seen them used to create the kind of > butt joints you suggest. Your technique is better because you can > see what's going on with the solder before the heatshrink is applied. Raychem!! That was it! I couldn't remember the name. I kept wanting to say Raytheon. That would be for the sidewinder missiles. That comes much later in construction. If I remember correctly these little beauties have a bead of solder in the middle and some adhesive that make for a very strong bond. We used them in Trident II missles. They ought to be good enough for a homebuilt airplane. Probably pretty expensive, though. -- Scott VanArtsdalen svanarts(at)jps.net "The essence of character is doing what's right, even when nobody's looking." - J. C. Watts ________________________________________________________________________________
Subject: Vans Service
Date: Oct 15, 1998
The people who are bashing Van on the net should look in there own back yard and keep it to themselves as Corsair is right and a fix will come soon and an answer just as in the 3 and N58s case, they only have so much time and will not give out any information untill they know it is as correct as possible, not off the cuff stuff that others do. Long live Dick and his crew!!!!!!!!!!!!!!!!!!!! ________________________________________________________________________________
Date: Oct 15, 1998
Subject: silent participent
Listers; I've been monitoring all the dialog back and forth and I want to say that although it is very time consuming reading all the email, I have found the information absolutely invaluable. I can't use the information yet, but I will and I would like to thank everyone for all the great tips. (I'm stashing them in a folder and will be accessing them as I proceed) Question: I am considering doing the unthinkable (according to Van) and that is building a center console that extends back to the Electric Flap motor housing. I would like to put my throttle, mix and constant speed controls in the center a-la- piper or boeing 747 etc. Does anyone know where I can get a more "sexy" quadrant than the ones in Vans catalog or Spruce? Dan Wiesel RV6a QB - controls/empennage mounting ________________________________________________________________________________
Subject: Alternator Belt Size
Date: Oct 15, 1998
Does anyone know what size alternator belt an 0-360-A1A with a liteweight alternator takes? Could not find any belts at all in the ACS catalog. Can these be bought at the local auto store? Or must you use Lycoming belts? Von Alexander RV-8 N41VA N41VA(at)juno.com ________________________________________________________________________________
Date: Oct 15, 1998
Subject: Re: 6A nose gear stresses 101
In the old days more work was done with a ball peen hammer. Today, as then, sometimes you need to work a piece of metal by hitting it with a hammer. If you use the flat side of a ball peen hammer you are hammer forging. If you use the ball side, you are "peening". "Shot" means small round pellets, like those in a shot gun. Thus 'shot peening" is a method where you impact the surface with shot. It has an effect similar to polishing. Joe Walker Shopping for panel stuff RV6 Houston V. E. Welch wrote: > > > I am very concerned that people might ignore the potential benefits of > > shot peening based upon some uninformed opinions which are broadcast on > > the web. I'm not trying to sell shot peening - but it works. > > Pardon my ignorance but................................just what exactly is > shot peening? > > Vince > ________________________________________________________________________________
Subject: Alternator Power Cable Size
Date: Oct 15, 1998
I am confused about the cable gauge to use for the power cable going from the alternator to the bus bar. Vans says 8 gauge shielded or unshielded, other books say 10-12 ga. shielded. 8 ga. shielded is $4.60 per ft! Whereas 12 ga. shielded is .95 per ft. I have an internally regulated 40 amp alternator, and will have a light VFR load. Is 12 ga. shielded adequate? Von Alexander (Buried in the wiring maze) RV-8 N41VA N41VA(at)juno.com ________________________________________________________________________________
Date: Oct 15, 1998
Thanks for the responses to my question! There were some good ones! Because I felt uncomfortable with the mounting on the engine mount tubes, I've decided to go with the cooler mounted on the lower left side of the firewall as suggested in the instructions. I'll be using a plate of .063 sheet (as suggested in one of the notes) that will be tied into the firewall at the angle stock that makes the "X" behind the firewall and the angle at the side. That should give me a solid platform for the thing. I'll be using .063 angles to hold it, to include a couple of braces angled down. Except for the two braces, the supports will be riveted, instead of bolted, to the firewall. I don't think I'll need to take them off. Well, I hope I won't, anyway. :-) I'm also going to include a trap door so I can control the heat. I don't have a temp control valve for the oil. So far, the progress is slow; but, I'm am making progress. Again, thanks! Jim Sears in KY RV-6A N198JS ________________________________________________________________________________
Date: Oct 15, 1998
Subject: fuel smell in cabin
I've got a fuel odor in the cabin of my 6A that I just can't find the source of. All the fittings are dry. There are no tell tale blue stains. I don't start to notice it until after about 1/2 hour flying. Its not real bad, but is still unacceptable and needs to be fixed. Does anybody have any magic tricks to locate a small leak? One thought is that I do have a leaky rivit on the bottom of the left tank. There will always be a small drop or two of blue dye around it. It needs to be fixed and I was planning on doing it this winter. I'm wondering if its possible that such a small leak at the tip end of the tank can be streaming fuel into the cockpit. I certainly can't see it (or stains leading inwards). Anyway, I can't believe that such a small amount of external seepage can find its way all the way into the cockpit and still produce an odor; so I still think I need to look inside. Any suggestions on how? Andy ________________________________________________________________________________
Date: Oct 15, 1998
Subject: Rudder trim tab??
I am interrested in building a controlable trim tab into my -8 rudder. Any ideas and/or experiences would be appreciated. LKD (empenage done building rudder over new) ________________________________________________________________________________
Date: Oct 15, 1998
Subject: Re: Nose gear legs
In a message dated 10/15/98 10:30:12 AM Pacific Daylight Time, tinckler(at)axionet.com writes: << They are not sitting idle. That phone is going all the time......Hope this helps some out there..... >> I am sure that they have been quite busy answering questions about the nose- gear failures. Hopefully, these issues will be studied/resolved in the short term, so that the friendly folks at Van's can spend more time working on the RV-Series 2000(RV's for the next century). Also, they can spend more time getting replacement parts to those who goofed the first time.(Who?Me?) Jim Nice RV6A WA State ________________________________________________________________________________
Date: Oct 15, 1998
Subject: Re: Wire Splices
In a message dated 10/15/98 11:12:26 AM Pacific Daylight Time, svanarts(at)jps.net writes: << If I remember correctly these little beauties have a bead of solder in the middle and some adhesive that make for a very strong bond. We used them in Trident II missles. They ought to be good enough for a homebuilt airplane. >> Yes, they work well. Those of you contemplating using them, however, need to be aware of one thing. They are approved for low temperature areas only. I would use them anywhere but under the cowling. The same goes for the moisture proof inline splices. Jim Nice RV6A WA State ________________________________________________________________________________
Subject: RV-4 H2AD oil access door
Date: Oct 15, 1998
Fellow Listers: One of our local builders has asked me to post this question on the list... He is building an RV-4 with an 0320-H2AD. He says that the oil dipstick is directly on the top of the engine perfectly centered over where the rear engine baffle will run. This would expose the front half of the dipstick access door to high pressure forward of the rear baffle and very high air loads from inside the cowling. How have any H2AD builder's approached this problem? He saws this problem would also exist for -6 builders using this engine. Thanks, Doug ============ Doug Weiler Hudson, WI 715-386-1239 dougweil(at)pressenter.com ________________________________________________________________________________
Date: Oct 15, 1998
Subject: Re: Vans Service
In a message dated 10/15/98 11:14:26 AM Pacific Daylight Time, linbb(at)worldnet.att.net writes: << and an answer just as in the 3 and N58s case, >> This is true. We should be glad that Richard is "not" just another politician. Take comfort in knowing that he will not just "tell us what we wish to hear". Jim Nice RV6A WA State ________________________________________________________________________________
Subject: Lift Reserve Indicator, Part 1
Date: Oct 15, 1998
I took advantage of a $40 OSH discount and purchased a Lift Reserve Indicator (look it up with a search engine using that name). After a few weeks back-log, I received the unit. It was well made (the indicator housing is about 3/16" aluminum) and all fittings, and plenty of tubing were supplied. I installed the indicator on the glare shield in an RV-6A with a tip-up canopy. That necessitated trimming the meter housing to avoid interference with the canopy plexiglass. Fortunately the housing is extra long, and can be cut quite a bit. The probe was installed in the left wing using the bell-crank inspection plate for mounting. That had to be beefed up a bit: I used .050 aluminum plate. Overall the installation took me about 7 to 8 hours (I'm slow.) The calibration in flight will have to wait a few days for calm weather. Calibration will entail going to altitude, using full power, and hauling back until no altitude is being gained or lost, and VSI shows zero. If I was lucky and got the probe angle set corectly the indicator should just show that no more wing lift was available. If I am unlucky, trial and error changes will have to be made in the probe angle with flights made to check for the above results. Overall, the quality of the instrument is very good. Service was good. Price of the instrument is rather dear (normally $750 plus $35 s/h) BUT if it saves my butt once I'll consider it worthwhile, even if nobody else does! Part two with results will be posted after calibration and flight testing. ________________________________________________________________________________
Subject: Re: Alternator Belt Size
Date: Oct 15, 1998
a good Gates belt from the National Air Parts Association (NAPA) will do fine. if you use metric sized belts, there is a wider length selection (2.54 cm to the inch). So you get 2 and 1/2 times as many different lengths. -----Original Message----- From: VON L ALEXANDER <n41va(at)Juno.com> Date: Thursday, October 15, 1998 2:37 PM Subject: RV-List: Alternator Belt Size > >Does anyone know what size alternator belt an 0-360-A1A with a liteweight >alternator takes? Could not find any belts at all in the ACS catalog. Can >these be bought at the local auto store? Or must you use Lycoming belts? > >Von Alexander >RV-8 N41VA >N41VA(at)juno.com > > > > > > > ________________________________________________________________________________
Date: Oct 15, 1998
Subject: Re: Pressure Bleeders
> Why go to all of the trouble to make something that you will only use once >or twice? We used to use a pump oil can and a short length of clear tubing >connected to the bleeder at the caliper and a rag at the master cyl to catch >the vented fluid, it doesnt take much to bleed the system on a plane so not >much is spilled especily if the master cylinder is empty when you start as >it fills the line will be cleared of all air. > > I agree 100%. Another easy way to avoid the spill is to remove the vent plug on the fluid reservoir and replace it with a spare AN816 fitting. Slip a piece of plastic tubing over the other end of the fitting and direct the tube to a container to catch the overflow. The clear plastic tubing gives you the added advantage of being able to see when the air bubbles stop coming out of the overflow. Mark Nielsen Rv-6; 288 hrs. ________________________________________________________________________________
Date: Oct 15, 1998
Subject: Re: Alternator Power Cable Size
t the cable gauge to use for the power cable > going from the alternator to the bus bar. Vans says 8 gauge shielded or >unshielded, other books say 10-12 ga. shielded. 8 ga. shielded is $4.60 >per ft! Whereas 12 ga. shielded is .95 per ft. I have an internally >regulated 40 amp alternator, and will have a light VFR load. Is 12 ga. >shielded adequate? Shielding is not necessary for the alternator b-lead. Folk have been doing that since it's shown on so many Cessna wiring diagrams. I was there when they started shielding the b-leads as part of an ADF installation option . . . frankly, I don't think it did ANY measureable good and in retrospect, given the testing I witnessed, I'll suggest that shielding was added 'cause it seemed like a good idea at the time. The wire needs to be rated for the continuous output rating of the alternator and tailored for potential cooling problems under the cowl. See http://www.aeroelectric.com/articles/wiresize.pdf A 40 amp machine could probably get by with 8AWG wire . . given the short run of wire and the hot environment, 6AWG wouldn't hurt. The b-lead protection for a 40 A alternator should be no less than 50 amps with 60 even better . . . this is one device in the Cessnas DESIGNED to nuisance trip. A 40A alternator charging a dead battery on a cold day can put out 50 amps. Bob . . . //// (o o) ===========o00o=(_)=o00o========= < If you continue to do > < What you've always done > < You will continue to be > < What you've always been. > ================================= ________________________________________________________________________________
Date: Oct 15, 1998
Subject: Archives - Neat, Neat, Neat
Well, I've been on the list for three or four years and have done some searching of the archives(using a couple of the engines - with varying degrees of success), but today I had a couple of questions about my F-608 bulkhead height and alignment. Didn't figure I'd bother everyone with another post that had probably aleady been discussed. So I decided to try the new search engine. Whew, I quickly found several previous post by the familiar names and answered all of my questions. The new search engine is really neat. It allows you to scroll/tab through all the messages containing your search words. It is GREAT! EASY! FAST! even with my dinasour computer. Kudos to Matt and one more reason Van's community resources have to be the best in the homebuilt arena. Thanks everyone! Shelby in Nashville. ________________________________________________________________________________
Date: Oct 15, 1998
Based on my own personal experience: > Does anyone know what size alternator belt an 0-360-A1A with a liteweight > alternator takes? Could not find any belts at all in the ACS catalog. Can > these be bought at the local auto store? Or must you use Lycoming belts? Take the alternator or a putty imprint of the pulley groove to an auto parts store and get a Gates or Dayton belt to fit. Experimental belt, right? I put a Gates auto store belt on my Debonair as the Continental (3X$) belts were wearing out too fast. It lasted till a sharp eyed IA made me replace it. I firmly believe that Continental gets rejects from Gates or cheapos from Taiwan. You can see the difference! Millions of autos run alternators etc at higher speeds with great success. Hal Kempthorne RV-6AQ -- May have found a huge hangar! halk(at)sybase.com Santa Clara, CA. Debonair N6134V @ SJC ________________________________________________________________________________
Subject: Re: fuel smell in cabin
Date: Oct 15, 1998
> I've got a fuel odor in the cabin of my 6A that I just can't find the > source of. All the fittings are dry. There are no tell tale blue stains. See if the primer fittings are weeping. Also it could simply be the fuel selector valve that has a small weep at the stem but doesn't show. I know of 2 like this . I had the experience and since I had Mogas in one tank, it really stunk and had me worried (good thing no smokers on board). Eventually, it went away. No smell at all now. ________________________________________________________________________________
Date: Oct 15, 1998
Subject: Check that Carb... too lean?
I talked to Pete Nielson at Precision Airmotive tech support about the fluctuating fuel flow I'm seeing in my new O-360 A1A at idle. It turns out the flow fluctuations are probably no big deal (more testing to follow). During that conversation Mr Nielson told me that he believes the MA4-5 carbeurator (part number 10-3878) that came with my O-360 (from Van's) is too lean for the RVs (something about the induction system on the RV, coupled with the use of the reusable air filter). He indicated a richer carb (MA4-5 part number 10-4164-1) is what he believes should be used in the RVs. He indicated he's discussed this matter with Bill Benedict a couple of times, including recently regarding an RV-4 that's running too lean. According to Mr Nielson, one should test the engine at several power settings (every 200 rpm or so up to full power, static and in flight) and be sure that the carb is runing rich enough that you can lean the carb and produce a 75-100 rpm rise and a 150 degree (F) EGT rise. If you can't, the carb is too lean and needs to be swapped for a richer carb, or modified. Precision has a conversion kit, which lists for $240. I asked Van's about this, and got the following response: "At this writing, we have only about 1-2% of the aircraft that seem to be on the lean side and so it has not even been an issue here beyond helping those that individually have the problem to solve it" I doubt I'd have thought to make this check, so I'm passing the info on to the group. In 6 months or so I hope to be flying and checking this myself. Tim _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023, engine completed and tested Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ________________________________________________________________________________
Date: Oct 15, 1998
Subject: Re: RV-4 H2AD oil access door
Doug, I have a H2AD in my -6. Here is the way I did it. Use screws and nutplates across the top of the cowling to attach it to the fuselage. It will be impossible to insert the hinge pins. On the baffling, as it approaches the center or the engine in the rear, make some 90 degree bends in it so that it comes foreward of the dipstick. The dipstick is not in a pressurized area then. I made the access door very small--approx 21/2 inches square. I did run into a problem that I did not anticipate; because the access door must be so close to centerline (the inner edge of mine is on centerline), the structural integrity of the cowling is lost. It will sag or develop a dip at that point. I had to use a long piece of 3/4 inch angle to reinforce the cowling to eliminate the sagging. It would have been a lot easier if I had anticipated the problem when initially fitting the short piece of hinge for the door. I attached the 3/4 angle to the inside of the cowling with proseal and -3 rivets and it works fine. If your friend has any questions he can call me at 850-537 -6034 or 850-609-3175. John Henley, N6LD, 100 hrs ________________________________________________________________________________
Date: Oct 15, 1998
Andy, I would think that the fuel smell is coming from the leaking rivit. The air from the wings is drawn into the cockpit via the aileron tube opening. The only time I have ever smelled fuel in my -6 was when I had ill fitting fuel caps and a small amt of fuel ran from the cap to the main spar area. Until I discovered where the smell was coming from, I was ready to make an emergency landing. John Henley, N6LD, 100 Hrs ________________________________________________________________________________
Date: Oct 15, 1998
Re: Raychem ZAP splice > svanarts(at)jps.net writes: > > If I remember correctly these little beauties have a bead of solder in the > middle and some adhesive that make for a very strong bond. We used them in > Trident II missles. They ought to be good enough for a homebuilt airplane. I do not have a single splice in my flying RV-6. I do have a lot of AMP (Molex) connectors that join wires. A terminal block can also be used. A "homemade" ZAP splice can be made by striping apx. 3/8" of wire from each end to be joined. Tin both wires with solder. Slip CLEAR heat shrink over one wire. Place the wires together like they are one continuous wire with the tinned ends over lapping. Heat the solder ends together. When finished, you should be able to see the strands in the wire with a fillet between the two. Clean the flux from the solder joint with IPA. (Isopropyl Alcohol) An "ACID" brush works well with the IPA. Cut the bristles on the brush to 1/4". Slide the clear heat shrink over the solder joint and heat with a heat gun. The clear heat shrink is used so that you can inspect the joint at anytime. We use splices like this on test equipment but NEVER on a spacecraft. On the rare occasion that a spacecraft has splices, they are always Raychem. If you check AC 43.13A, the FAA uses something like this but they have a "hook" on each wire before fusing together. This gives a mechanical joint that does not rely on the solder for strength. The solder just insures a good electrical joint. The only bad thing about solder in airplanes is that it makes the wire hard and brittle. With vibration, this increase the possibility of a "break" (open circuit). The heat shrink helps as a strain relief to reduce the chance of breaking. If splicing wires in a bundle, remember to stagger them so that the bulge in the cable is spread out over a larger area. Hope this is understandable to the electrically challenged. Sorry for being so long winded but this is "my area of expertise". == Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell Flying in So. CA, USA RV6flier(at)yahoo.com ________________________________________________________________________________
Date: Oct 15, 1998
---VON L ALEXANDER wrote: > > > Does anyone know what size alternator belt an 0-360-A1A with a liteweight > alternator takes? Could not find any belts at all in the ACS catalog. Can > these be bought at the local auto store? Or must you use Lycoming belts? > > Von Alexander > RV-8 N41VA > N41VA(at)juno.com I took the "Starter Ring Gear" (it has the pulley on it) to Pep Boys to match up to a Dayco belt. I purchased about 4 belts that I though might work. Kept one and took the other 3 back in exchange for one spare. So far, I have 255 hours on it and no visible wear. I have also not re-tighten it since it was installed and it is still perfect. == Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell Flying in So. CA, USA RV6flier(at)yahoo.com ________________________________________________________________________________
Date: Oct 15, 1998
<< Does anyone know what size alternator belt an O-360-A1A with a lightweight alternator takes? Could not find any belts at all in the ACS catalog. Can these be bought at the local auto store? Or must you use Lycoming belts? >> ________________________________________________________________________________
Date: Oct 15, 1998
<< I am confused about the cable gauge to use for the power cable going from the alternator to the bus bar.>> It is better to run the alternator B-lead thru a 60-80A fuse/breaker/link then connect to the switched side of the master contactor (electrically the same point as the input to the starter contactor). Then take an identical AWG wire from this same point (switched side of master contactor) directly to the main bus. This is per Bob Nuckolls, and will reduce noise to your panel. If done this way, you do not need to shield either of these wire runs. << Vans says 8 gauge shielded or unshielded, other books say 10-12 ga. shielded. I have an internally regulated 40 amp alternator, and will have a light VFR load. Is 12 ga. shielded adequate? >> No. Refer to AC43.13-1A. You should use 8 AWG to have a comfortable safety band. 10 AWG would be the absolute minimum and would need to be in free air (not bundled). It sounds as though you need to get and read the AeroElectric Connection. -GV ________________________________________________________________________________
Subject: Re: silent participant
Date: Oct 15, 1998
For what it's worth, a friend of mine has a RV-6A with a throttle quadrant mounted to the center pedestal. I thought it was a pretty neat deal until I flew my -6 with the normal control knobs and was amazed at the difference in room. Several people I have flown with also made the comment it looked much bigger inside (including an owner on the -6A). Marcus > Question: > I am considering doing the unthinkable (according to Van) and that is > building a center console that extends back to the Electric Flap motor > housing. I would like to put my throttle, mix and constant speed controls > in the center a-la- piper or boeing 747 etc. > > Does anyone know where I can get a more "sexy" quadrant than the ones in > Vans catalog or Spruce? > Dan Wiesel > RV6a QB - controls/empennage mounting ________________________________________________________________________________
Date: Oct 15, 1998
In a message dated 10/15/98 6:47:57 Central Daylight Time, halk(at)sybase.com writes: << May have found a huge hangar! >> Well now, that's great news. Hope it works out for you. By the way (and this is a non-A&P thing to say) I agree with you on the alternator drive belts. Used to be a time, but those days are long gone. Regards Wendell WBWard(at)AOL.COM ________________________________________________________________________________
Subject: Re: Great news on the B&C Saga . . .
Date: Oct 15, 1998
Did those @#$%^ s ever apologize to Bob Hoover? > >I just got of the phone with Bill Bainbridge. Administrator Garvey called his office this >morning. The long sought letter of appology >has been crafted and signed (Bill has an unofficial copy). ________________________________________________________________________________
Subject: Re: silent participent
Date: Oct 15, 1998
Dan, You can build your own sexy box for Van's plain quadrant. I plan to do that on my RV-4 to include a custom throttle grip with radio flip/flop and transmit buttons. It should be a relatively simple task. Regards, Tom Craig-Stearman tcraigst(at)ionet.net RV-4 64ST installing baffle seal material > >Does anyone know where I can get a more "sexy" quadrant than the ones in >Vans catalog or Spruce? >Dan Wiesel >RV6a QB - controls/empennage mounting ________________________________________________________________________________
Date: Oct 15, 1998
writes: >>..He is building an RV-4 with an 0320-H2AD. He says that the oil dipstick is >>directly on the top of the engine perfectly centered over where the rear >>engine baffle will run. This would expose the front half of the dipstick >>access door to high pressure forward of the rear baffle and very high air >>loads from inside the cowling. How have any H2AD builder's approached this >>problem?.... Doug, I have an RV-6 with an O320-H2AD installed and about ready to fly. Also there is an RV-6A with the same installation flying out of our airport since May. The rear baffle on the engine jogs forward around the front of the dipstick. There is enough room for an adequate door that is entirely aft of the baffle. Mine is about 5" square centered over the dipstick. Remember that the rubber seal material bends forward away from the dipstick. I would recommend that the door not be cut until the baffles are installed and don't worry if the door needs to be in a curved part of the cowling. Regards, Bob Hall, RV-6 N976RH Colorado Springs ________________________________________________________________________________
Date: Oct 15, 1998
Subject: Re: Firewall Forward
> 2) What is the best way to connect up the fuel > pressure sender? Should I plumb some fittings right > off of the carb? Should I mount the sender remote? > > 3) Where is the best place to mount the oil pressure > sender. It is fairly large and cylindrical. If you > mount it to the engine mount, how did you fasten it? > Did you mount it on the firewall? Again, how did you > fasten it. I made a bracket on the FW for both out of 1-1/2 inch aluminum angle. Plumb them remotely. If you hang them straight onto a fitting they eventually break off. The fitting Van sells for the engine-driven fuel pump includes an optional 1/8 in pipe thread port that makes a convenient fuel pressure line hookup point. -BB ________________________________________________________________________________
From: "Daniel H. Morris III" <Morristec(at)icdc.com>
Date: Oct 15, 1998
>I've got a fuel odor in the cabin of my 6A that I just can't find the >source of. All the fittings are dry. There are no tell tale blue stains. >I don't start to notice it until after about 1/2 hour flying. Its not >real bad, but is still unacceptable and needs to be fixed. > >Does anybody have any magic tricks to locate a small leak? Try to wipe the lines, fittings or whatever with a white absorbent rag. I have searched long and hard visually and couldn't find a sign of a leak, but when wiping the line a trace of the fuel dye will show up very clearly. Dan Morris RV6 flying ________________________________________________________________________________
Subject: RV's invited to Des Moines area in September 99.
Date: Oct 15, 1998
Mark your 1999 calendars for a midwest airshow and gathering of RV's. We'll be organizing and RV type get together with free tickets for homebuilt arrivals. This is the press release going to the local Des
October 10, 1998 - October 15, 1998
RV-Archive.digest.vol-fp
