RV-Archive.digest.vol-gh
January 26, 1999 - - - - , 20-
      >I would like to install an electric primer because it gets two more gas
      >lines out of the cabin, and also the cost of manual primers is getting right
      >up there.
      >Aircraft Spruce has an electric primer solenoid which shows an inlet and
      >outlet port, but I cannot see any wires or connectors to activate it. Is it
      >a pump ? It is recommended for Long Eze types. I called to ask my questions,
      >and guess what ?  They don't know anything about this items use. They gave
      >me a 1-800-- number to call for answers. They turn out to be a
      >distributor/supplier, not the maker, so they were even more in a fog.
      >Does anyone know how these are fitted into the system and are they what I am
      >looking for ?..How have others implemented an electric prime ?
      >Sorry for the long dissertation.............
      >Austin
      >RV-6 tanks.
      Austin,
      The solonoid is just that: when you apply a voltage it opens the valve. It
      has two wires coming out of it as well as the two fuel ports. It is NOT a
      pump. I connected the extra port on my gascolator to the solonoid and
      thence, via copper tubing, the solonoid to the primer ports. To prime the
      engine you turn on the boost pump and then open the solonoid (use a spring
      loaded switch) for long enough to prime. How long is a moot point because
      I'm not flying yet (but getting closer).
      Leo Davies
      6A bits and bobs
Subject: Do I really need a gascolator?
Date: Jan 26, 1999
I spoke with Van's and they said a gascolator is optional. Is this true? Would a filter do, as long as you are not in a moist climate where condensation would be a concern? Thanks.. Paul Besing RV-6A (197AB) Arizona http://www.doitnow.com/~rv8er Canopy ________________________________________________________________________________
Subject: Re: Do I really need a gascolator?
Date: Jan 26, 1999
How does one know that the airplane will always be in a dry climate? -----Original Message----- From: Besing, Paul <PBesing(at)pinacor.com> Date: Tuesday, January 26, 1999 5:05 PM Subject: RV-List: Do I really need a gascolator? > >I spoke with Van's and they said a gascolator is optional. Is this true? >Would a filter do, as long as you are not in a moist climate where >condensation would be a concern? > >Thanks.. > >Paul Besing >RV-6A (197AB) Arizona >http://www.doitnow.com/~rv8er >Canopy > > ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Re: electric primer Solonoid
>The solonoid is just that: when you apply a voltage it opens the valve. It >has two wires coming out of it as well as the two fuel ports. The wires come off the front, the fuel ports (in/out) come off the sides. >It is NOT a pump. No, it is not. Gets its "power" from the fuel pump. >I connected the extra port on my gascolator to the solonoid and thence, via >copper tubing, the solonoid to the primer ports. Right. How many cylinders do you prime? I did the front two and have never had a no-start situation, even in these chilly Colorado winters. This seems to be enough. I have one cylinder plugged up with the manifold pressure and another that was just a pain to get to. >To prime the engine you turn on the boost pump and then open the solonoid >(using a spring loaded [momentary-on] switch) for long enough to prime. How >long is a moot point because I'm not flying yet. Oh, about three seconds ought to do it. This is a good, simple system and gets fuel lines and (leaky, smelly ol')primer pump out of the cabin. Michael RV-4 N232 Suzie Q Year Two ________________________________________________________________________________
Date: Jan 26, 1999
Subject: elevator balance
My left elevator is underbalanced (electric trim installed) so I plan on adding some weight to the inboard side of the counterbalance arm. I'm thinking of using fishing sinkers. I'm wondering if the lead I pour in will cling to the existing weight? Do I need to remove the existing weight, add it to the pot, then pour the whole thing around the protruding bolts? I've thought about adding weight in the fiberglass tip, but I'm a bit uncomfortable with this idea. Any thoughts? Adrian Chick Nashville, TN RV-6A wings on order ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Re: forward bolts on landgear mount rv6a
Nope, you got it right. ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Re: PAINTING THE HORZ STAB
I'll be painting some parts very soon for my horizontal stab. Can someone please tell me where I can get a few cans of ZINC CHROMATE?????? Is there anything else on the market that won't kill me??? Should I etch? ANY SUGGESTIONS ? THANKS Stan Z RV-6A THEZING3(at)AOL.COM ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Re: elevator balance
>My left elevator is underbalanced (electric trim installed) so I plan on adding >some weight to the inboard side of the counterbalance arm. I'm thinking of >using fishing sinkers. I think it may be better to over balance as it is easier to take the weight off than add it on. How much do you add? Then if that is too much, you'll have to take some off anyway. >I'm wondering if the lead I pour in will cling to the existing weight? Do I >need to remove the existing weight, add it to the pot, then pour the whole >thing around the protruding bolts? Hoping it will cling to the existing lead weight is not a good option. If it falls off, it will not have good results: it could jam the elevator; it could cause the elevater to flutter as it will no longer be in balance; etc. It's a pain, but take the old weight out and melt them together. >I've thought about adding weight in the fiberglass tip, but I'm a bit >uncomfortable with this idea. Bad idea. It needs to be FIRMLY attached to the STRUCTURAL part of the elevator. The fiberglass tip is a fairing. Michael ________________________________________________________________________________
Subject: Re: RV-4 Ground location
Date: Jan 26, 1999
I used the firewall gear bolt as well and do not recommend it. I ended up having to add an additional ground strap and it made all the difference in my cranking power. So in hindsight, I would not use the gear bolt for all the reasons the listers have mentioned. I am currently building an RV8A and am enjoying taking advantage of the installation improvements from my rv6a building experience. Scott Johnson / Chicago rv6A n345RV 125TT -----Original Message----- From: mikel(at)dimensional.com <mikel(at)dimensional.com> Date: Tuesday, January 26, 1999 3:32 AM Subject: Re: RV-List: RV-4 Ground location > >>Is it poor design to attach the battery ground to the firewall on my RV-4? > >No. Mine goes from the battery to the central firewall gear bolt; then a >flexable strap goes from the other end of the bolt to the engine. > >>May I, instead, use a 3/8" brass or bronze bolt, backed up with appropriate >>washers to attach the battery to the firewall and then on the engine side >of >the F/W attach the engine ground to this same bolt? What are the >corrosion >implications? > >If you the engine mount bolt, you, of course, have to use the bolt that >holds the engine mount on and it is an AN bolt as it is stressed. Brass or >bronze will not do. The engine mount is not the ground, the bolt is. Worked >for me. > >Michael > > ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Re: Drilling Elevator Horn
> >JR wrote: > >> Drill bits do not make round holes but reamers do. > >Quibble, quibble. > Tolerance is the operative word. FOr >most stuff, a drill bit does just fine. > >We're building little airplanes here, not spacecraft. > >Opinionated in San Jose, > >hal For a middle ground compromise consider center drills. I think Avery sells them. The machinists where I work recommended them to me and they do a very nice job. Mike Wills RV-4 fuse out of the jig willsm(at)manta.spawar.navy.mil ________________________________________________________________________________
Date: Jan 26, 1999
Remember that after you add paint, the balance will change (per George > >My left elevator is underbalanced (electric trim installed) >so I plan on adding some weight to the inboard side of the >counterbalance arm. I'm thinking of using fishing sinkers. >I'm wondering if the lead I pour in will cling to the >existing weight? Do I need to remove the existing weight, >add it to the pot, then pour the whole thing around the >protruding bolts? I've thought about adding weight in the >fiberglass tip, but I'm a bit uncomfortable with this idea. >Any thoughts? > >Adrian Chick >Nashville, TN >RV-6A wings on order > > > Dan Wiesel RV6a QB starting finishing kit ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Re: RV-8 water pipe
Larry, You have the correct size pipe. All water pipe sizes are "nominal". Bill, N66WD ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Re: electric primers
Austin, To add to what others have said, you can wire your primer switch to also turn on your boost pump at the same time if you isolate it with a 1 AMP silicon diode so that turning on the boost pump will not activate the primer circuit. Regards, Bill N66WD ________________________________________________________________________________
Date: Jan 26, 1999
Can you make a lead washer and put it under the nut that holds the existing weight? I suspect new melt would freeze at the interface with the cold original so I would fasten it in some way. I used old wheel weights - oh,oh, automotive grade! I suppose now I have endangered my only life and those of everyone on the ground in California! Inside the tip seems good if firmly anchored to aluminum or lead. hal > My left elevator is underbalanced (electric trim installed) > so I plan on adding some weight to the inboard side of the > counterbalance arm. I'm thinking of using fishing sinkers. > I'm wondering if the lead I pour in will cling to the > existing weight? Do I need to remove the existing weight, > add it to the pot, then pour the whole thing around the > protruding bolts? I've thought about adding weight in the > fiberglass tip, but I'm a bit uncomfortable with this idea. ________________________________________________________________________________
Date: Jan 26, 1999
Aircraft spruce carries it. Mike. ________________________________________________________________________________
Date: Jan 26, 1999
Adrian, More lead poured on top of the old will NOT stick. Best bet is to use lead shot and pour epoxy around it to anchor it. Build a small dam to retain the mess untill it hardens. Regards, Bill N66WD ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Re: Inst Panel
Bob Glad to hear that bracing the lower instrument worked as good for you as it did for me. Gil. T. gstrv8(at)aol.com ________________________________________________________________________________
From: "Terrence C. Watson" <tcwatson(at)pstbbs.com>
Date: Jan 26, 1999
>>My left elevator is underbalanced (electric trim installed) so I plan on >adding >some weight to the inboard side of the counterbalance arm. I'm >thinking of >using fishing sinkers. Is it a good idea to balance the elevators individually? I recall reading that we should expect them to have too much counterbalance weight, and that we should expect the balance to change after painting. I am not there yet, but it would seem that trimming/adding weight would best be left till much later. Terry RV8A Wings arrive tomorrow! ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Scotch Bright brand polishing wheels
Hello Listers; I have a supply of large diameter 3M brand Scotch Bright polishing wheels for sale. They are 12 inch diameter, 3 inch thick, and have a 5 inch bore in them. I mounted mine on a 1/2 HP motor shaft. They have about 4 times the volume of the small wheels you normally find. I have two grades, 7A VFN and a few 6S VFN. They make fast work of polishing edges and forming nice radii. The price is $ 30 plus shipping. Contact me directly if interested. John Kitz ________________________________________________________________________________
Date: Jan 26, 1999
The ACS primer has 2 wires that get hooked up to a momentary switch. Most gascolators have a connection on the top. Run 1/8 alum tube to the SV, and then to the motor, at least 2 cylinders, more is better. It won't prime unless the booster pump is on. Mine needs about 3 seconds for a cold engine and then it goes on the first or second blade. Bruce Patton READY ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Test
test ________________________________________________________________________________
Subject: Re: Left side throttle quad. RV-6
Date: Jan 26, 1999
-----Original Message----- From: Tracy Saylor <tracysaylor(at)earthlink.net> Date: Monday, January 25, 1999 10:52 PM Subject: RV-List: Left side throttle quad. RV-6 > >Tracy Saylor,s throttle quadrant for RV-6 &6A is 55.00 + 5.00 S&H Ph. >805-933-8225 If you have this arrangement what controls can we put on the right side for the passenger or co-pilot who wants to fly the plane. There is also the safety factor to consider should one become incapacitated on the left side. Derek Reed 6A Fus. OR. ________________________________________________________________________________
Date: Jan 26, 1999
Subject: E-mail?
Hi, Scott, I just got your message. I'm sorry about the mix-up. I hope this will get through to you so that you can just hit "reply" to send back the contract. Dylan ________________________________________________________________________________
Date: Jan 26, 1999
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: Re: Electric Primer
Any who have read my rantings for long know of my affection for failure tolerant systems. I've been watching a thread on electric primers wondering if anyone would remember some words I wrote in Appendix Z to the 'Connection which I repeat here as follows: --------- Note 14. Consider installing an electric solenoid valve between the pressure side of your fuel system and the primer ports on your engine. Aircraft Spruce offers a suitable electrically operated valve for primer service. Further, consider using a 4 or 6 port primer system (depending on the number of cylinders on your engine). Two advantages: (1) no wet fuel lines in the cabin, (2) many an engine plagued with a plugged carburetor or broken mixture control has been kept running to an uneventful landing by a multi-port primer system. This setup will perform very nicely in such circumstances. Throttle full open. Tease the boost pump switch as required to develop considerable power and pick a landing spot well beyond your normal glide ratio! ---------- Some of my builders have gone a step further and installed a needle valve in the line downstream of the solenoid valve. With a bit of tinkering, the right combo of needle valve setting and throttle position was determined for getting 60-75% power with mixture at idle-cutoff. The also plumbed the primer valve into its own pump with a separate feed from the last-tank-to-drain in their standard flight procedures. What results is a totally independent, fuel supply system that will keep an engine running. One of my builders was able to use this feature to his advantage about 8 years ago when the mixture control on his Long-Ez became detached. He flew an additional 45 mintues to a much more desirable airport where repairs were quickly accomplished. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < If you continue to do > < What you've always done > < You will continue to be > < What you've always been. > ================================ ________________________________________________________________________________
Date: Jan 26, 1999
Paul I have 1941 hrs on my RV's with no problems at all. I run an inline filter just foreward of the fuel valve. The gascolator is a relic of the 30s & no longer needed in most cases. hope this helps. Tracy SAYLOR "Besing, Paul" wrote: > > I spoke with Van's and they said a gascolator is optional. Is this true? > Would a filter do, as long as you are not in a moist climate where > condensation would be a concern? > > Thanks.. > > Paul Besing > RV-6A (197AB) Arizona > http://www.doitnow.com/~rv8er > Canopy > ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Re: Internally regulated alternators
>Why can cars go millions of miles with never an overvoltage? Usually what >happens is that a diode fails and you start getting some AC (whine) or just low >output. One of my three Mazda RX7s is having alternator trouble - squealing >bearing. It has been going on for several months. Pretty soon I will get it >overhauled. Actually, failed diodes always result in loss of capacity from the alternator combined with increased noise on the bus. Runaway overvoltage conditions are always a failure in the guts of the regulator. Yes, millions of reliable alternator-hours are chalked up every month in automobiles . . . but the failure rate is not zero . . . it's very tiny but not zero. Since it's so very easy to accomodate that kind of failure, why not? From time to time, we get a note from or hear of a builder who was glad he did. I'd be perfectly happy if none of our ov modules ever had to slay the electronic dragon and MOST of them probably never will . . . Bob . . . //// (o o) ===========o00o=(_)=o00o======== < If you continue to do > < What you've always done > < You will continue to be > < What you've always been. > ================================ ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Re: RV Gear leg fairings RV-4, 6,6A& 8
Gil : Send your check to tracy saylor PO box 856 Santa Paula, Ca. 93061 Taxes are included in the 105.00 tracy ph. 8059338225 Gil Alexander wrote: > > Tracy ... where do I send my money?? > > Do you collect CA sales tax?? > > Gil Alexander > 4434 Stewart Av. > Los Angles, CA 90066 > > > > >Tracy Saylor's gear leg fairings are now 95.00+10.00 S& H Ph. > >805-933-8225 > > > > ------------------------------------------------------- > mailto:gila(at)flash.net > Gil Alexander, > Los Angeles, CA > ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Re: E-mail?
Thanks, contract is sent. ________________________________________________________________________________
Date: Jan 26, 1999
> All this recent talk about misdrilled elevator horns is scaring me, since > that's my next step. I have just one very quick question: the > instructions say to drill this hole "carefully," should I use a reamer, as > discussed in recent postings, or just drill with a 1/4" bit (I assume it's > a 1/4" hole). Also, any good ideas on what to use for or how to get a > "drill bushing?" Any help or past experience on this step will be > appreciated. Peter, I believe that two things are most important here: getting both elevators at neutral prior to drilling, and making sure that the hole through the two horns is parallel to the hinge line (perpendicular to the horn surfaces). Many have experienced that the two horns will not be at the same angle when the elevators are at neutral, so be careful here. Choose a hole location which will work for both horns, and drill the left one. If this hole is too far aft, the large diameter pushrod may interfere. Make a small block of maple or aluminum as thick as the gap between horns and drill a hole through it with a drill press, to insure perpendicularity. Clamp this block between the horns, with the elevators both at neutral, and drill through the existing hole in the left horn and block, making the hole in the right horn. Regarding the discussion about drills versus reamers, my experience is that if one does not try to drill thin materials with large drills in just one shot, good quality holes can be made. In other words, start with a small drill, perhaps #40, then several steps up to 1/4". Alex Peterson Maple Grove, MN 6A ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Re: Scotch Bright brand polishing wheels
John:whats the difference between a 7A and a 6S? Jim ________________________________________________________________________________
Date: Jan 26, 1999
I need a copy of that contract for my files, also. ________________________________________________________________________________
Date: Jan 26, 1999
>I'm thinking of using fishing sinkers. > I'm wondering if the lead I pour in will cling to the > existing weight? Do I need to remove the existing weight, > add it to the pot, then pour the whole thing around the > protruding bolts? I've thought about adding weight in the > fiberglass tip, but I'm a bit uncomfortable with this idea. > Any thoughts? Adrian, Could you drill and tap a hole or two through the existing lead, thread a bolt or two in, and cast additional lead around these bolts? Alex Peterson ________________________________________________________________________________
Date: Jan 26, 1999
> If you have this arrangement what controls can we put on the right side for > the passenger or co-pilot who wants to fly the plane. There is also the > safety factor to consider should one become incapacitated on the left side. > > Derek Reed 6A Fus. OR. Not a factor, IMO. When you hand off the plane to he right seat, they are not likely to be adjusting the throttle, just wiggling the stick. In case of incapacitation, the RV-6's cabin is not so wide that an average-sized person cannot reach across it to pull throttle off for emergency landing. Granted fine adjustments won't be easy, but we're not talking a P-3 flight deck here. My lefty throttle will actually go in the lower left-hand panel corner I think - I'm not near there yet but you can tell I've thought about it some, and at least one other lister has used it and likes it. Quadrants take up so much room and limit stick movement to the left unless done carefully. Mike Thompson Austin, TX -6 N140RV (Reserved) Rear Spars and ribs ________________________________________________________________________________
Date: Jan 26, 1999
Derek Its very easy for the passenger to reach across to opperate the throttle control.Try setting in the right seat & reaching over, my wife does it all the time& she's only 5' 2'' tall with arms to match her hieght. tracy Derek Reed wrote: > > -----Original Message----- > From: Tracy Saylor <tracysaylor(at)earthlink.net> > To: RV-list > Date: Monday, January 25, 1999 10:52 PM > Subject: RV-List: Left side throttle quad. RV-6 > > > > >Tracy Saylor,s throttle quadrant for RV-6 &6A is 55.00 + 5.00 S&H Ph. > >805-933-8225 > > If you have this arrangement what controls can we put on the right side for > the passenger or co-pilot who wants to fly the plane. There is also the > safety factor to consider should one become incapacitated on the left side. > > Derek Reed 6A Fus. OR. > ________________________________________________________________________________
Subject: battery cable/battery box
Date: Jan 26, 1999
Ok, I'm stumped. In my QB, the battery box is already done, and I can not find any reference in the archives or the manuals as to where to have the wires exit the battery box to go to ground and to the starter relay. Also, I am assuming that most builders put the starter relay very close to the battery inside the firewall. Correct? Paul Besing RV-6A (197AB) Arizona http://www.doitnow.com/~rv8er Canopy ________________________________________________________________________________
Date: Jan 26, 1999
From: Ronald Vandervort <rvanderv(at)linknet.kitsap.lib.wa.us>
Adrian, I shaped a small container out of aluminum to fit aft of the present weight and put a nut plate in the top and the bottom edge to allign with existing rivet holes, and poured lead into it. Ah, it was 3 sided with the edge facing forward missing. Thus I was able to drill out lead to balance and the holes did not show. I hope that is not too confusing. Any further questions give me a shout. Ron Vandervort, RV-6Q, 28 hrs and grinning! Seattle area ________________________________________________________________________________
From: "Steven B. Janicki" <sjanicki(at)us.oracle.com>
Date: Jan 27, 1999
An alternative is to engineer a system similar to the one used in the Falco. They place a throttle on the left hand side and leave another throttle, fuel, prop controls in the center console. They system is connected by a common linkage for both throttles which then goes into a single cable. A drawing can bee seen in their literature and I believe on their WWW site though it's been some time since I have looked. ----- Original Message ----- From: Mike Thompson <grobdriver(at)yahoo.com> Sent: Tuesday, January 26, 1999 8:22 PM Subject: Re: RV-List: Left side throttle quad. RV-6 > >> If you have this arrangement what controls can we put on the right >side for >> the passenger or co-pilot who wants to fly the plane. There is also >the >> safety factor to consider should one become incapacitated on the >left side. >> >> Derek Reed 6A Fus. OR. > >Not a factor, IMO. >When you hand off the plane to he right seat, they are not likely to >be adjusting the throttle, just wiggling the stick. > >In case of incapacitation, the RV-6's cabin is not so wide that an >average-sized person cannot reach across it to pull throttle off for >emergency landing. Granted fine adjustments won't be easy, but we're >not talking a P-3 flight deck here. > >My lefty throttle will actually go in the lower left-hand panel corner >I think - I'm not near there yet but you can tell I've thought about >it some, and at least one other lister has used it and likes it. >Quadrants take up so much room and limit stick movement to the left >unless done carefully. > >Mike Thompson >Austin, TX >-6 N140RV (Reserved) >Rear Spars and ribs > > ________________________________________________________________________________
Date: Jan 27, 1999
Subject: (no subject)
Is there anyone in the Poughkeepsie NY area building a RV-6 or 8 ? Or does anyone in this area have one complete? If so , could you contact me. Ken ________________________________________________________________________________
Date: Jan 27, 1999
Now that's a good idea. The idea being I guess to provide an anchor? I got impatient and went ahead and poured the lead. I really do wish I'd thought of that before I'd poured the lead. I first poured it in the outboard side, then decided it would be better in the inboard side. It took me an hour to get the lead out (no pun intended). It seems that the two 3/32 rivets that the lead formed around was more than enough to hold the lead in place. I think I might still drill a hole in the new lead and run a small flush bolt through it. Thanks. Alex Peterson wrote: > Adrian, > > Could you drill and tap a hole or two through the existing lead, thread a > bolt or two in, and cast additional lead around these bolts? > > Alex Peterson > > Matronics: http://www.matronics.com > RV-List: http://www.matronics.com/rv-list > Archive Search Engine: http://www.matronics.com/search > Archive Browsing: http://www.matronics.com/archives > Other Email Lists: http://www.matronics.com/other ________________________________________________________________________________
Date: Jan 27, 1999
Now that's a good idea. The idea being I guess to provide an anchor? I got impatient and went ahead and poured the lead. I first poured it in the outboard side, then decided it would be better in the inboard side. It took me an hour to get the lead out (no pun intended). It seems that the two 3/32 rivets that the lead formed around was more than enough to hold the lead in place. I think I might still drill a hole in the new lead and run a small flush bolt through it. Thanks. Alex Peterson wrote: > Adrian, > > Could you drill and tap a hole or two through the existing lead, thread a > bolt or two in, and cast additional lead around these bolts? > > Alex Peterson > ________________________________________________________________________________
Date: Jan 27, 1999
Subject: counterbalance cosmetics
Guys, I really appreciate all the feedback on pouring the lead. I've got one more question though. When the elevator is down, you can see the inboard counterbalance weight. I'd be curious to know whether any of you made an aluminum cover of some sort to hide this and if so, what result. Maybe one of you who've looked at lots of RV's could tell me what the "standard" practice is here. Adrian Chick Nashville, TN RV6A wings on order (and broke as hell) ________________________________________________________________________________
From: Lothar Klingmuller <lothark(at)worldnet.att.net>
Subject: 50 or 100 Watt Landing Lights ?
Date: Jan 27, 1999
BIGGER is not always better. I am working on landing lights and wonder if 100 W bulbs are really needed or if the 50 W supplied with the Duckworks landing lights are sufficient. Would appreciate input of those who made night landings with either 50 and/or 100 W lights. Thanks Lothar |||-6A; fitting wings in Lakewood/ Denver, CO ||| ________________________________________________________________________________
Date: Jan 27, 1999
Subject: Re: counterbalance cosmetics
Adrian, On my RV4 I did install alum plates over these weights. I used 1/4 in countersunk screws with c/s washers to hold the plates, and weights to the elevator horn. Stew RV4 CO. ________________________________________________________________________________
Date: Jan 27, 1999
From: "Douglas G. Murray" <dgmurray(at)telusplanet.net>
Adrian Chick wrote: > . When the elevator > is down, you can see the inboard counterbalance weight. I'd > be curious to know whether any of you made an aluminum cover > of some sort to hide this and if so, what result. Maybe one > of you who've looked at lots of RV's could tell me what the > "standard" practice is here. > > Adrian Chick Paint it - KIS --- light & easy ________________________________________________________________________________
Date: Jan 27, 1999
Subject: Re: 50 or 100 Watt Landing Lights ?
In a message dated 1/27/99 8:59:42 AM Eastern Standard Time, lothark(at)worldnet.att.net writes: > BIGGER is not always better. I am working on landing lights and wonder if > 100 W bulbs are really needed or if the 50 W supplied with the Duckworks > landing lights are sufficient. Would appreciate input of those who made > night landings with either 50 and/or 100 W lights. Thanks > > Lothar |||-6A; fitting wings in Lakewood/ Denver, CO ||| I installed a Duckworks landing light in my left wing, and experimented with both the 55 watt bulb that it comes with, and a replacement 100 watt "Baja Special" from Walmart. I felt that the 100 watt bulb was somewhat brighter, and since I only had one light at that time, that's what I went with. However, the 100 watt bulb failed after just a few hours of use. One of the leads, where they enter the bulb from the rear, broke internally. I replaced it with the same brand of bulb, and haven't had anymore problems. I guess it was just poor quality control at the Mexican factory. One more thing, if you only install one landing light, think about practicing landings in the dark with no light. Just because the light is new, doesn't mean it won't fail. Mark LaBoyteaux RV-6A N106RV Broken Arrow, Ok MLaboyteau(at)aol.com ________________________________________________________________________________
Date: Jan 27, 1999
From: Keith Williams <73623.2504(at)compuserve.com>
Subject: auto versus aircraft paint
Finally nearing paint time on my RV6. Been checking the archives and found lots of good info. But did not see this question addressed: Is there a significant difference in finished weight between auto and aircraft paint? I have been told auto paint is heavier because it contains more anti-run ingredients - a form of clay, maybe? - which increase its weight. If there really is a big difference, and does anyone know how much for a typical RV6? Is it in the priming system, paint or in the recommended paint thickness? In looking at tech data sheets for two auto paints (PPG Concept and Sikkens Autocryl) I see a RTS VOC weight of about 4.6 pounds per gallon. I'm guessing this means ready to spray volatile organic compounds. I wonder if I could use the Material Safety Data Sheets, take the total weight per gallon (about 8.5# for paints and 7.5# for reducers) and subtract the VOC weight. Then I would have to get aircraft paint data to compare. With an O360, constant speed and full panel my RV is too heavy already so I'm wondering if aircraft paint might help. Also, I have pretty much dropped the idea of trying a water based product,, based mostly on the bad reports I found in the RV list archives for System Three on aluminum. At Oshkosh I got some info on paint furnished by A.F.S. (Aircraft Finishing Systems) in Montana. Of course they say its great (sticks like crazy, light, beautiful, etc.). Does anyone on the list have experience with A.F.S. product on aluminum? I like the safety aspect but for sure don't want to get into a repainting project. Great posts the last couple of days about elevator weights - adjusting those is coming up and the comments really help! ________________________________________________________________________________
Date: Jan 27, 1999
Adrian: I put one layer of fiberglass over the lead, then sanded, and then filled and smoothed with microballoons. Looks great, and it wasn't much work, or much weight since it was only one layer of glass. Paul Besing RV-6A (197AB) Arizona http://www.doitnow.com/~rv8er Canopy > >Guys, I really appreciate all the feedback on pouring the >lead. I've got one more question though. When the elevator >is down, you can see the inboard counterbalance weight. I'd >be curious to know whether any of you made an aluminum cover >of some sort to hide this and if so, what result. Maybe one >of you who've looked at lots of RV's could tell me what the >"standard" practice is here. > >Adrian Chick >Nashville, TN >RV6A wings on order (and broke as hell) > > Paul Besing Pinacor, Inc. (800) 528-1415 ext.67697 .....Committed to being your primary distributor! ________________________________________________________________________________
Date: Jan 27, 1999
In a message dated 1/27/99 6:08:11 AM Pacific Standard Time, lothark(at)worldnet.att.net writes: << I am working on landing lights and wonder if 100 W bulbs are really needed or if the 50 W supplied with the Duckworks landing lights are sufficient. Would appreciate input of those who made night landings with either 50 and/or 100 W lights. >> All I can tell you is that the 100W GE #4595 lamps I have in the RMDs on my 6A are great and make night landings easy. -GV ________________________________________________________________________________
Subject: Re: auto versus aircraft paint
Date: Jan 27, 1999
Keith: I have painted rockets for an aerospace company, and have some experience with many different kinds of paints. IMO, paint is paint, as long is it is higher quality. My experience is, if it looks great and is durable, use it. We used Sherwin Williams Sunfire on some of our rockets, and it is also Boeing uses it as an OEM paint on their jets. It is an automotive paint, that comes in base/clear and conventional format. It shoots really nice, and is extremely durable. A local Glasair builder used Sikkens pearl white on his prize winning bird, and it is beautiful. From what I have heard, you can paint an RV with 2 gallons of paint, reduced 4:1. If you want to check out the Sherwin Williams paint, you have to go to one of their automotive shops. The stores that have the home paints do not carry it. Also IMO, use the base/clear in whatever you get. It shoots much nicer, and you can wetsand any orange peel without compromising color. Paul Besing RV-6A (197AB) Arizona http://www.doitnow.com/~rv8er Canopy (And pretty much sick of it) > >Finally nearing paint time on my RV6. Been checking the archives and found >lots of good info. But did not see this question addressed: > >Is there a significant difference in finished weight between auto and >aircraft paint? I have been told auto paint is heavier because it contains >more anti-run ingredients - a form of clay, maybe? - which increase its >weight. > >If there really is a big difference, and does anyone know how much for a >typical RV6? > >Is it in the priming system, paint or in the recommended paint thickness? > >In looking at tech data sheets for two auto paints (PPG Concept and Sikkens >Autocryl) I see a RTS VOC weight of about 4.6 pounds per gallon. I'm >guessing this means ready to spray volatile organic compounds. I wonder if >I could use the Material Safety Data Sheets, take the total weight per >gallon (about 8.5# for paints and 7.5# for reducers) and subtract the VOC >weight. Then I would have to get aircraft paint data to compare. > > With an O360, constant speed and full panel my RV is too heavy already so >I'm wondering if aircraft paint might help. > >Also, I have pretty much dropped the idea of trying a water based product,, >based mostly on the bad reports I found in the RV list archives for System >Three on aluminum. At Oshkosh I got some info on paint furnished by A.F.S. >(Aircraft Finishing Systems) in Montana. Of course they say its great >(sticks like crazy, light, beautiful, etc.). Does anyone on the list have >experience with A.F.S. product on aluminum? I like the safety aspect but >for sure don't want to get into a repainting project. > >Great posts the last couple of days about elevator weights - adjusting >those is coming up and the comments really help! > > > > Paul Besing Pinacor, Inc. (800) 528-1415 ext.67697 .....Committed to being your primary distributor! ________________________________________________________________________________
Date: Jan 27, 1999
I too forgot to put the bolts in. I called Van's, and they said ABSOLUTELY you need to put the bolts in, they will come out if you dont. I took some 1/4" hardware store bolts and drilled through the lead, then countersunk the heads on the inboard side. Once I glassed over them, you could not tell that I added bolts after the fact. Paul Besing RV-6A (197AB) Arizona http://www.doitnow.com/~rv8er Canopy (And pretty much sick of it) > >Now that's a good idea. The idea being I guess to provide an anchor? I got >impatient and went ahead and poured the lead. I first poured it in the outboard >side, then decided it would be better in the inboard side. It took me an hour >to get the lead out (no pun intended). It seems that the two 3/32 rivets that >the lead formed around was more than enough to hold the lead in place. I think >I might still drill a hole in the new lead and run a small flush bolt through >it. Thanks. > >Alex Peterson wrote: > > >> Adrian, >> >> Could you drill and tap a hole or two through the existing lead, thread a >> bolt or two in, and cast additional lead around these bolts? >> >> Alex Peterson >> > > Paul Besing Pinacor, Inc. (800) 528-1415 ext.67697 .....Committed to being your primary distributor! ________________________________________________________________________________
Subject: GPS Antenna Location
Date: Jan 27, 1999
For those of you with an RV-6 with a tip up canopy - Where are you installing your GPS antenna? Thanks, Kevin Beaton ________________________________________________________________________________
Subject: Re: GPS Antenna Location
Date: Jan 27, 1999
I plan to put my on the forward fuse skin, just forward of the subpanel. It is close to the gps, and I don't have to run more coax. Should be a no brainer, as long as you don't mind a bump in your forward skin. The location is not critical, as long as it is on the top of the airplane somewhere. Paul Besing RV-6A (197AB) Arizona http://www.doitnow.com/~rv8er Canopy > > >For those of you with an RV-6 with a tip up canopy - Where are you >installing your GPS antenna? > >Thanks, > >Kevin Beaton > > ________________________________________________________________________________
Date: Jan 27, 1999
Before I bought my Skyforce GPS, I grabbed a bargain on an antenna from Britain. The Skyforce then came with one! I used it to/from OSH last year and no problem with it sitting on the glareshield of the Debonair. At OSH, I saw a lot of GPS antennae similarly mounted. I should think that would be perfect with the tip-up. So what do I do with my cute tiny British jobbie? > For those of you with an RV-6 with a tip up canopy - Where are you > installing your GPS antenna? Hal Kempthorne RV-6AQ -- Hangar H-4 at SCK - Wings on - sorta. halk(at)sybase.com Santa Clara, CA. Debonair N6134V @ SJC ________________________________________________________________________________
Date: Jan 27, 1999
Drilling the horns was for me the most intense thing I have done so far. My advice is to measure, check, measure, check, go sleep on it, pull it apart, realign, remeasure, make sure that you get back to the same hole location if you reassemble and remeasure. Onmly then will you know if you have set it up correctly. My thought was that if I tore it down, and re-set it up, and could get back to the same spot, I was on the right trrack for drilling. All this took 4 nights of lots of measureing before I attacked it with the drill.. Use a lot of clamps and the wood block between the horns > > >> All this recent talk about misdrilled elevator horns is scaring me, since >> that's my next step. I have just one very quick question: the >> instructions say to drill this hole "carefully," should I use a reamer, >as >> discussed in recent postings, or just drill with a 1/4" bit (I assume >it's >> a 1/4" hole). Also, any good ideas on what to use for or how to get a >> "drill bushing?" Any help or past experience on this step will be >> appreciated. > > >Peter, > >I believe that two things are most important here: getting both elevators >at neutral prior to drilling, and making sure that the hole through the two >horns is parallel to the hinge line (perpendicular to the horn surfaces). >Many have experienced that the two horns will not be at the same angle when >the elevators are at neutral, so be careful here. Choose a hole location >which will work for both horns, and drill the left one. If this hole is >too far aft, the large diameter pushrod may interfere. Make a small block >of maple or aluminum as thick as the gap between horns and drill a hole >through it with a drill press, to insure perpendicularity. Clamp this >block between the horns, with the elevators both at neutral, and drill >through the existing hole in the left horn and block, making the hole in >the right horn. > >Regarding the discussion about drills versus reamers, my experience is that >if one does not try to drill thin materials with large drills in just one >shot, good quality holes can be made. In other words, start with a small >drill, perhaps #40, then several steps up to 1/4". > >Alex Peterson >Maple Grove, MN 6A > > > Dan Wiesel RV6a QB starting finishing kit ________________________________________________________________________________
Date: Jan 27, 1999
Kevin, The slickest install I've seen was under the cowling. The guy put a bracket from the firewall to just in front of the topskin to mount the antenna. This way the antenna is out of sight and can "see" through the fiberglass cowl. This fellow plane was at Camarillo, Ca and Im not sure if he has flown yet. Pat Kirkpatrick RV-6A 98% 10% to go! First engine start this weekend, with a little luck:) > > >For those of you with an RV-6 with a tip up canopy - Where are you >installing your GPS antenna? > >Thanks, > >Kevin Beaton > > More than just email--Get your FREE Netscape WebMail account today at http://home.netscape.com/netcenter/mail ________________________________________________________________________________
Date: Jan 27, 1999
> ...When the elevator > is down, you can see the inboard counterbalance weight. I'd > be curious to know whether any of you made an aluminum cover > of some sort to hide this and if so, what result. Maybe one > of you who've looked at lots of RV's could tell me what the > "standard" practice is here. "Standard" practice is to paint it and move on. Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com ________________________________________________________________________________
Date: Jan 27, 1999
Please please please take me off this list I've tried everything I've done what was asked of me. Again please take or unsubscribe rvrent(at)aol.com ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <stuckle(at)ifc.utc.com>
Date: Jan 27, 1999
Just behind the reat portion of the canopy on the Turtle deck... Fred Stucklen N925RV RV-6A E. Windsor, Ct > -----Original Message----- > From: Kevin Beaton [SMTP:kevin.beaton(at)usaa.com] > Sent: Wednesday, January 27, 1999 12:02 PM > To: rv-list(at)matronics.com > Subject: RV-List: GPS Antenna Location > > > > For those of you with an RV-6 with a tip up canopy - Where are you > installing your GPS antenna? > > Thanks, > > Kevin Beaton > > > > ----- > > ----- > http://www.matronics.com/contribution > > ----- > ________________________________________________________________________________
Subject: electric primers
Date: Jan 27, 1999
Date: Jan 27, 1999
I did---Works great---Looks proffessional. Just set a piece of 032 against the spar and drew a line around it using the elevator horn , then carefully trimmed and filed until the plate just sliped inside the horn and up against the lead. I then marked the holes from the backside through the lead weights, drilled and dimpled the plate, I believe that I had to use a dimpled washer or two for proper fit and to insure that the lead weight was snug against the inside of the elev horn. If your interrested I also built a triangular plate (foriegn object deflector) and will install it below the stab to fill the scissors type gap created when the elev is full up / balance horne down. I built these deflectors out 040 hard aluminum and preset nut plates (3) just inside the outer lip of my horizontal stab. This idea is most applicable to tail draggers operating off of grass or unimproved airstrips. This deflector plate should prevent any sticks, green weeds, bolts , etc. from jamming into the scissors gap below the stab preventing down elevator movement if needed. LKD 888LD ________________________________________________________________________________
Date: Jan 27, 1999
Subject: First Flight
A friend of mine, Jan Bussel, just flew his 6A for the first flight yesterday. He stopped by my hangar today. He got a 35NM radius to fly off his time, so can hit quite a few a irports in that circle ffrom his homebase at River Acres Airpark. Here is the note he sent to friends: "First Flight of newly constructed RV-6A N557JB completed 9:30am 1-26-99 Whoooooeeeee this baby is FUN TO FLY!!!!!!!!!!!!!!!" Jan ________________________________________________________________________________
From: cdenk(at)ix.netcom.com.by.dfw-ix3.ix.netcom.com (8.8.4/8.8.4)
Date: Jan 27, 1999
Subject: Re: COZY: Re: Electric Primer
Terry Schubert's hand primer is located on the lower aft baffle. Keat for hand propping since he doesn't have a starter. Just reach in front of the prop and give it a couple of squirts. This is a real advantage for injectors, no primer tubing in the cockpit. ________________________________________________________________________________
Date: Jan 27, 1999
Subject: HR2 Ride!! YAHOOOOOOOOOO
Hello Rocket men, Well, this past Sunday I had an opportunity to fly a Harmon Rocket II. And as many of you might, I had a pre-determined idea of what I thought it was going to be like. I have flown many RV's, a few Glasairs, alot of spam cans, and have had some training in a Pitts. I am here to tell you that it exceeded every inch of expectations that had. Not only did it exceed them, but ran past them with flying colors leaving them spinning in the background. This airplane performed like no other that I have ever flown!!!!!! The acceleration on takeoff was incredible. We saw 3800 fpm climbouts, 230 mph straffing runs down the runway. The stick response was RIGHT NOW!! And the smoothness and sturdiness of the airplane was exceptional. Aerobatics (rolls, cuban eights, 270 degree turnouts, 90 degree turns) was a breeze and very comfortable. WOW WHAT A RIDE!!!!!!!!!!!! Its been 3 days later, and the grin is still so big on my face that my ears are touching on the back of my head!! Many thanks to Mark Frederick for the real eye-opener of a ride. This exceeded my wildest of expectations. Scott ________________________________________________________________________________
Date: Jan 27, 1999
Peter Just in case you are not aware. There is Clinton Aircraft Tool and Supply down near Hartsfield Airport in downtown Atlanta. Tons of used tools. Has almost anything you could need. Including drill bushings. # 404-766-3222 Dennis Hart RV-6A, Horiz Stab > >All this recent talk about misdrilled elevator horns is scaring me, since >that's my next step. I have just one very quick question: the >instructions say to drill this hole "carefully," should I use a reamer, as >discussed in recent postings, or just drill with a 1/4" bit (I assume it's >a 1/4" hole). Also, any good ideas on what to use for or how to get a >"drill bushing?" Any help or past experience on this step will be >appreciated. > >Peter Christensen >RV-6A, left elevator >Marietta, GA > > ________________________________________________________________________________
Date: Jan 28, 1999
Subject: proseal hint.
Hi listers, A mate of mine building a Corby Starlet gave me a good hint for the use of proseal. He is a chef and he decided that proseal was about the same consistency as chocolate and cream,so obviously he used the same applicator as one would use to decorate the a cake...you know the type of thing that you squeeze the cream or chocolate through. he told me this was a great way to apply the proseal and was not messy at all.......I suppose you would have to be a chef to qualify that statement.....anyway i thought this might help someone. Regards, Peter Winter Australia RV8 wings in progress. ________________________________________________________________________________
Date: Jan 27, 1999
Subject: bendix fuel injector
I was speaking with Bart Lalonde about an IO-360-B2B which would have the Bendix fuel injector. Are there any operational drawbacks to having the injector? Is it harder to start when cold, or need lots of maintenance or something? On the plus side I assume the unit would make the engine a bit more fuel efficent and possibly run a little smoother, yes? Certainly the chance of icing is reduced. Are there any other benefits? --- Tom Sargent, sarg314(at)azstarnet.com ________________________________________________________________________________
Subject: Alberta Aircraft Overhaul
Date: Jan 27, 1999
This post is for those folks living in the Southern Alberta area (or nearby)...it's a little longwinded, too, so you may well want to hit the delete key now, and save yourself the trouble. It's not my intention to re-ignite the priming thread, but I wanted to let everybody know that I'm using Alberta Aircraft Overhaul (AAO) to do my priming, and based on the experience, there are a few other things that I intend to have them do for me as well. They have been absolutely excellent. AAO is very homebuilder friendly (see below). I bought a primer kit, which they keep on my behalf, and I can take whatever number of parts need priming, and they usually turn them around usually in one or two days. I am therefore paying for straight time. The previous place I took the parts to did a great job, but there were charging me for some minimum quantity of primer each time - it made the cost pretty outrageous. To me, though, pumping a few dollars back into the local economy was infinitely preferable to handling the miserable priming chemicals myself. Particularly neat, though, was having the fella there take a real interest in my project,. What really caught my attention is that he could identify all of the parts that I was bringing in. At first, I thought that this was a series of lucky guesses, but it turns out that his dad is currently working on his *third* RV, and he had help him build at least one of them! So they have a real appreciation of what you're up against (cost constraints, lack of experience, unfamiliarity with terminology) and make you totally comfortable with the whole thing. AAO also said that they would be able to help me out with AN hardware and other hard-to-find items that will really save them some time, and money (no shipping charges). I've also talked to them about sealing my tanks for me, which they indicated would be no problem - they do that kind of thing all the time. I'll let the list know how that goes - that should be in the next couple of weeks. Could be that with the infinitely affordable Canadian dollar, it would make sense to have stateside builders use AAO the for this ugly job - even if you factor in shipping. I intend to donate my tank jig to them once I'm done, so you wouldn't have to worry 'bout that part of it. The fellow that I deal with is Glen Tinckler (as per the anecdote above). You can also contact Teddy Juliussen. They both can be reached (403) 250-1177 or email altaair(at)telusplanet.net , and mention my name if you think that would help. I should also mention that I have no affliation with AAO (other than being a very satisfied customer). Email me off list if you want any additional info. End of plug. Terry in Calgary S/N 24414 "Wings" http://members.home.net/gannont ________________________________________________________________________________
Subject: central Missouri
Date: Jan 27, 1999
Am moving to Jefferson City in June. Have an RV-8 almost finished, cub, C-140, C-120, and twin commanche. Any RV builders close. Stan Mehrhoff ________________________________________________________________________________
Date: Jan 27, 1999
Subject: GPS Antenna Location(be careful)
I would caution anyone wanting to install a GPS antenna under the fiberglass cowl, or any other fiberglass molding. If you paint the fiberglass you will most likely keep out, or reduce the rf signal getting to the antenna. This is because most paints contain some metalic particles in them. The extreme high frequency signal from the satellite will not penetrate even a very thin layer of metal. So this makes the selection of paint, in the color you want, a great task to preform. Do you want this problem? I think not. Instead, just install your antenna in a good location on the exterior, or under the canopy where the antenna will not be blocked by metal, and in a spot where it will see almost a horizon to horizon view. I have also heard of persons wanting a gold sputtered tinted canopy for sun reduction. That works great to keep the sun out, but it also will keep out the rf signal if your GPS antenna is under the canopy. This is the same if you have a Tin Oxide coating on the canopy. Now, some good options for you. I sell a non-certified GPS antenna that is amplified by your GPS receiver (all major brands of GPS receivers are capable of this and will work well with this antenna) to boost the received signal. It is VERY small, has a VERY low profile for little drag, mounts through the skin (no magnet to goof-up the compass), works very well on the glare shield because it is finished in black, will work very well outside on the skin, and the best part is, it is only $75 delivered to you, if you are in the US. I also sell a Certified aircraft, amplified GPS antenna if those of you want that, but the cost is $250 delivered to you. It is made by the same manufacture as the non-certified antenna, and has the exact same internal antenna elements and amplifier. There are only two differences between the antennas: the Certified unit has one additional band pass filter in it to keep out an offending radio telephone frequency often used on commercial and biz jets. It does have a slightly larger foot print than the non-certified antenna, and it only comes in a white finish. I can also make up coax cables for you to any length using only the best, lowest loss coax available (that is still flexable). I also will put on the connectors for you that also are of the highest quality. You will have to contact me for what you need in coax and I will give you the price. Gretz Aero Warren Gretz 3664 East Lake Drive Littleton, Colorado 80121 303-770-3811 gretz_aero(at)h2net.net ________________________________________________________________________________
Date: Jan 27, 1999
Subject: Van's throttle and mixture cables (6A)
I searched the archives and only added more variables to my problem. What I wanted to know is when throttle and mixture controls are placed on a sub panel under the main panel, are the cables supplied by Van's at 41.5" to long, to short or just right. What I did find is that a lot of builders are using cables from Aircraft Spruce or other sources. Why? Are Van's cables bad? Gary Zilik RV-6A s/n 22993 Doing lots of things I should have done when the doing was easier. ________________________________________________________________________________
Date: Jan 27, 1999
I heard Lyle Hefel say that his experiment was quite successful. He mounted it about a half inch under the engine cowl, on a bracked mounted to the firewall. (If you don't know Lyle, he has a most excellent red and white military scheme RV-8. Same scheme as his -6 and -4). -----Original Message----- From: Kevin Beaton <kevin.beaton(at)usaa.com> Date: Wednesday, January 27, 1999 11:41 AM Subject: RV-List: GPS Antenna Location > > >For those of you with an RV-6 with a tip up canopy - Where are you >installing your GPS antenna? > >Thanks, > >Kevin Beaton > > ________________________________________________________________________________
Subject: Re: bendix fuel injector
Date: Jan 27, 1999
Advantages of fuel injection over carburetion: - more efficient fuel distribution at partial throttle settings - freedom from carburetor icing - negative G capability - ability to lean past peak EGT Tom Craig-Stearman RV-4, O-360 with Airflow Performance injection, mounting the throttle quadrant > > I was speaking with Bart Lalonde about an IO-360-B2B which would >have the Bendix fuel injector. Are there any operational drawbacks to >having the injector? Is it harder to start when cold, or need lots of >maintenance or something? > > On the plus side I assume the unit would make the engine a bit more >fuel efficent and possibly run a little smoother, yes? Certainly the >chance of icing is reduced. Are there any other benefits? ________________________________________________________________________________
Subject: Re: More RV-8 questions
Date: Jan 27, 1999
-----Original Message----- From: dipaula(at)pete.nit.disa.mil <dipaula(at)pete.nit.disa.mil> Date: Friday, January 22, 1999 11:11 AM Subject: Re: RV-List: More RV-8 questions >> >you don't seem to take the meaning of my question. allow me to give >an example. > >suppose you are in relatively straight flight, no pitch up. the wings >should basically be experiencing 1 G, right? > >now, suppose you start rolling the plane at maximum rate. i don't see >why each wing should carry greatly increased G loads as it is rising and >then greatly degreased G loads as it crosses the top and is descending. >that is, i can see how it is moving, but i don't see how it is subject >to varying loads that way when the fuselage and attach points are >also rotating at the same rate. > >if you have a flagpole sticking out from a building and put a weight on >the end, it is subject to a load similar to a wing in straight flight. >but if you hinge the flagpole so it simply moves when there is a weight >on the end, isn't that similar to a plane rolling? I'll take a stab at this despite my amateurish grasp of physics. First some rules. (1) Any object with mass, when in motion, contains kinetic energy. (2) Energy is needed to accelerate (change direction, stop or increase velocity) an object with mass. (3) Drag is a force which acts to decelerate a body in motion. (4) The creation of lift also creates additional drag. When you roll an airplane, either in level flight or turning, you impart lift to one wing and reduce lift to the other. The drag imparts a load to the wing and airframe that it is rigidly attached to. That load (acceleration in a different direction) is g force. Flight is a continual balancing act and exercise in energy management, kinetic energy vs. drag and gravity. Regards, Doug Hormann > > ________________________________________________________________________________
Date: Jan 27, 1999
Subject: Re: (no subject)
Yes, I'm building a RV-6, and Scott Jordan (Wappingers Falls) is building a RV-8. Tony Castellano tcastella(at)juno.com Hopewell Junction, NY RV-6 (fuselage on gear, working on canopy and will be working on engine installation) > >Is there anyone in the Poughkeepsie NY area building a RV-6 or 8 ? Or >does >anyone in this area have one complete? If so , could you contact me. >Ken > > > > > > > ________________________________________________________________________________
Date: Jan 27, 1999
Subject: S-TEC in an 8
Anybody installed an S-TEC System 20 autopilot in their RV-8? The S-TEC people say they only have an installation for the 6, but some 8 builders have bought the 6 kit and made the necessary parts to fit the 8. Mike Robbins RV-8Q #591 Issaquah, WA ________________________________________________________________________________
Date: Jan 27, 1999
Just thinking about this same problem on my -4. I have seen several -4/-6's that have just used bondo and have looked really nice. Bondo would be easy to do, but seems kinda heavy, what about epoxy super fil? Any Ideas on how well this stuff bonds? It seems that if it does comes lose, it is too soft/brittle to jam the elevator, or am I asking for trouble? ________________________________________________________________________________
Date: Jan 28, 1999
From: "DWAIN L. HARRIS" <102617.2606(at)compuserve.com>
Hi Guys I've been flying with my GPS under the cowling for over a year with no problems. I do have a cool vent tube blowing air on the antenna. My RV-6 is a dark metallic blue. Could'nt see putting that ugly white thing ( antenna ) on the outside stinking out like a sore thumb. Dwain N164DH RV-6 ________________________________________________________________________________
Subject: C/S prop knob mount hole
Date: Jan 27, 1999
Does anyone know the diameter of the hole to mount the Van's blue C/S prop knob? I don't have one yet, and my panel is being cut. thanks.. Paul Besing ________________________________________________________________________________
Subject: Re: S-TEC in an 8
Date: Jan 27, 1999
Mike, He's not on the list, but there's a builder in our group (Home Wing, in the Portland area), Richard Wood, who is building an 8 with I think an S-Tec System 30. E-mail me directly if you want his number. Regards, Randy Lervold -8, #80500, fuselage Home Wing - Van's Air Force -----Original Message----- From: Michael J. Robbins <kitfox(at)gte.net> Date: Wednesday, January 27, 1999 8:58 PM Subject: RV-List: S-TEC in an 8 > >Anybody installed an S-TEC System 20 autopilot in their RV-8? The S-TEC >people say they only have an installation for the 6, but some 8 builders >have bought the 6 kit and made the necessary parts to fit the 8. > >Mike Robbins >RV-8Q #591 >Issaquah, WA ________________________________________________________________________________
Date: Jan 27, 1999
> >I would caution anyone wanting to install a GPS >antenna under the cowl... >If you paint the fiberglass you will most likely keep >out, or reduce the rf signal getting to the antenna. You would think, but many people have found this to NOT be the case. Yes, the GPS antenna says "do not paint" but many people (including someone from Van's if I remember correctly) have painted them with no degradation. And several people (Tracy Saylor for example) have put their GPS antenna under the cowl with no problems whatsoever. That's what I'm planning on doing after seeing Tracy's setup and talking to him about his experiences. Now, metalic paint with silica chips is another story... Mitch Faatz San Jose, CA N727MF (reserved) RV-6AQME Finishing Kit... Pres/Newsletter Editor - Bay Area RVators http://www.skybound.com/BARV http://www.aftershock.org/rv.htm ________________________________________________________________________________
Date: Jan 28, 1999
I put a 30 in my 8. Get it with control rods on each servo, not cables. No problem. Stan Mehrhoff -----Original Message----- From: Michael J. Robbins <kitfox(at)gte.net> Date: Wednesday, January 27, 1999 10:51 PM Subject: RV-List: S-TEC in an 8 > >Anybody installed an S-TEC System 20 autopilot in their RV-8? The S-TEC >people say they only have an installation for the 6, but some 8 builders >have bought the 6 kit and made the necessary parts to fit the 8. > >Mike Robbins >RV-8Q #591 >Issaquah, WA > > ________________________________________________________________________________
Subject: rvlist--range markings
Date: Jan 28, 1999
What technique has anyone used for marking ranges on guages not already marked? How does one safely remove the glass, and has anyone used paint, such as model paint, in deference to tape? We have Westach gauges and RCAllen instruments primarily. How about a sun-resistant paint? Flat tone plastic model paint, maybe even over a white base coat to keep the color bright...? Working diligently on the panel of our half-completed RV6-AQ in Pueblo, Colorado Bill and Kathy Peck ________________________________________________________________________________
Date: Jan 28, 1999
In a message dated 1/28/99 12:18:02 AM Eastern Standard Time, kitfox(at)gte.net writes: << Anybody installed an S-TEC System 20 autopilot in their RV-8? The S-TEC people say they only have an installation for the 6, but some 8 builders have bought the 6 kit and made the necessary parts to fit the 8. >> I've basically completed installation of a System 30 in my -8. I used the -6 installation kit but had to make a few modifications. If you'd like details I can give them to you off line. Rick McBride rickrv6(at)aol.com ________________________________________________________________________________
Date: Jan 28, 1999
Subject: Re: Aircraft noise in comm radio.
>I had originally located the mic and phone jacks to the comm radio to the cage structure behind the pilot's left shoulder, using a pair of insulated adel clamps to attach the simple angle bracket.. This turned out to be a nuciance, and reminded me uncomfortably of John Denvers problem. So I decided to move the jack assembly to a more convenient position, which turned out to be at the rear of the seat back rail tab. I simply drilled a hole in the angle and used a slightly longer bolt to mount the seat rails. > >The next time I turned on the radio, planning to go flying and test a trim change, I heard the unmistakable noise of the aircraft alternator in the head set. Not only that, I discovered that there was suddenly an interaction between the strobe lights and the Apollo SL60 nav/comm, and that the nav display blinked on and off in response to the strobe flashes! > >It was apparent that I had unintentionally picked up a lot of ground currents in the shield of the headset cable, and introduced some undesirable coupling to other parts of the electrical system. Mounting the headset jack bracket on a standoff solved the problem, and my radios are once again quiet. I've reposted this item to several list-servers . . . including some of the plastic airplanes interest groups. It's important to avoid any local "grounding" of headset and microphone jacks, even to a metal instrument panel in a composite airplane. Hard paper extruded washers are available to provide insulation of the jacks from their mounting plate, or you can mount the jacks on a thin sheet of glass-epoxy like etched circuit boards. We stock the washers too @ $1 per jack, postage paid. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < A mind abhors a vacuum . . . > < When deprived of facts, > < our fantasies are generally > < much worse than reality. > ================================ ________________________________________________________________________________
Date: Jan 27, 1999
Keith; Having just finished painting my RV-8 and being very happy with the results, I would like to recommend PPG Delstar Acrylic Enamel. They claim this is what is used on 90% of new cars (except most of them use clear coat). It has a VOC of 4.2 lbs per gal. It is also one of the least expensive paints, yet with hardener is supposed to be extremely durable. If the auto paint has anti-run qualities compared to aircraft paint that is good, because unless you are a seasoned painter you need all the anti-run help you can get! I got 3 or 4 runs on mine which will be sanded and buffed out later. For my RV-8, it cost me a total of $485 for ALL the paint supplies. It took a gallon of DP-48 epoxy primer, and about 5 quarts of the main body paint, and a quart each of the trim colors. This was two full coats, you might be able to get by with one coat, but durability and longevity would drop, and it would be more difficult to get good coverage, but it can be done. In my opinion, paint is very important in how attractive the airplane is, as well as resale value. I saved weight in other areas (mostly the panel) to allow for the paint. Von Alexander N41VA(at)juno.com <73623.2504(at)compuserve.com> writes: ><73623.2504(at)compuserve.com> > >Finally nearing paint time on my RV6. Been checking the archives and >found >lots of good info. But did not see this question addressed: > >Is there a significant difference in finished weight between auto and >aircraft paint? I have been told auto paint is heavier because it >contains >more anti-run ingredients - a form of clay, maybe? - which increase >its >weight. > >If there really is a big difference, and does anyone know how much for >a >typical RV6? > >Is it in the priming system, paint or in the recommended paint >thickness? > >In looking at tech data sheets for two auto paints (PPG Concept and >Sikkens >Autocryl) I see a RTS VOC weight of about 4.6 pounds per gallon. I'm >guessing this means ready to spray volatile organic compounds. I >wonder if >I could use the Material Safety Data Sheets, take the total weight per >gallon (about 8.5# for paints and 7.5# for reducers) and subtract the >VOC >weight. Then I would have to get aircraft paint data to compare. > > With an O360, constant speed and full panel my RV is too heavy >already so >I'm wondering if aircraft paint might help. > >Also, I have pretty much dropped the idea of trying a water based >product,, >based mostly on the bad reports I found in the RV list archives for >System >Three on aluminum. At Oshkosh I got some info on paint furnished by >A.F.S. >(Aircraft Finishing Systems) in Montana. Of course they say its great >(sticks like crazy, light, beautiful, etc.). Does anyone on the list >have >experience with A.F.S. product on aluminum? I like the safety aspect >but >for sure don't want to get into a repainting project. > >Great posts the last couple of days about elevator weights - adjusting >those is coming up and the comments really help! > > > > > > > > > ________________________________________________________________________________
Date: Jan 28, 1999
> In my opinion, paint > is very important in how attractive the airplane is, as well as resale > value. I saved weight in other areas (mostly the panel) to allow for the > paint. > Good post from Von on painting. Just to relate my experiences at the local airport. I have a friend with a really well built RV-6, but he left it painted only in an ugly primer. The primer makes it look bad. Often times a transient RV-6 is tied down at the airport right next to my friends and it has a super paint job. Being an Rv-6 builder I have looked at the construction of both aircraft, the contruction of non painted RV is far superior to the painted RV. But, the crowd always goes over to the painted one, and when I mention that the aircraft right next to the painted one is an RV also, the response is which airplane? When I show it too them they say, you are kidding? These comments are from pilots who should know that a good paint job does not mean it is a quality airplane. To save weight, I am a proponent of no or minimal paint, But, If I were to sell my RV I would have the best paint job possible. Also I wonder if the non flying public (passangers) would consider a poorly painted or a non painted (not polished, ugly looking surface) aircraft as an unsafe? Bob Busick RV-6 Fremont CA ________________________________________________________________________________
Date: Jan 28, 1999
Subject: Re: rvlist--range markings
<< What technique has anyone used for marking ranges on guages not already marked? >> Bill, I wont say what I did was right or wrong, but I used the colored tape that comes in different size circles. I purchased it one year at sun'n'fun from one of the vendors. I would imagine spruce,chief or some of the instrument shops would carry this stuff. As I said before I dont know if this is for everyone but I removed the glass from my airspeed indicator and installed my own markings accordingly. My airspeed indicator is acurate and I think the markings are very profesional looking. Another option would be to send your instruments to a shop like Century instruments and have them put the markings on for you. Ryan Bendure Co. ________________________________________________________________________________
From: "Glenn Hoskins" <Imagine21_glenn(at)email.msn.com>
Subject: Re: C/S prop knob mount hole
Date: Jan 28, 1999
3/4" = .750 -----Original Message----- From: Paul Besing <rv8er(at)doitnow.com> Date: Wednesday, January 27, 1999 11:46 PM Subject: RV-List: C/S prop knob mount hole > >Does anyone know the diameter of the hole to mount the Van's blue C/S prop >knob? I don't have one yet, and my panel is being cut. > >thanks.. > >Paul Besing > > ________________________________________________________________________________
Date: Jan 28, 1999
Huh? Are we talking about the counterbalance? > Just thinking about this same problem on my -4. I have seen several -4/-6's > that have just used bondo and have looked really nice. Bondo would be easy > to do, but seems kinda heavy, what about epoxy super fil? You are worrying about covering the *LEAD* with something too heavy??? I wonder what can be done??? hal ________________________________________________________________________________
From: "Japundza, Bob" <BJapundza(at)ksmconsulting.com>
Date: Jan 28, 1999
Listers, I was wanting to get additional feedback on painting, as painting is soon approaching my project. I was wondering what the advantages/disadvantages are of basecoat-clearcoat paint jobs are. Have any of you painted your RV's this way? Are HVLP systems worth their purchase price? I also don't have the cleanest shop, either. I was thinking of fashioning a paint booth out of plastic sheeting and box fans. Can I get good results doing it this way? How important is temperature on painting? Bob Japundza RV-6 doing gear leg fairings ________________________________________________________________________________
Date: Jan 28, 1999
Subject: Re: Houston Area Builders?
"Thomas W. McCausland" wrote: > > > I'm considering building an RV-6A, and was wondering if there were > any current builders in the Houston / Missouri City area, here on the > list. The Houston area has many RVs flying and under construction. I have an RV-6 that has been flying for 18 months and I have 180+ extremely satisfying hours on it. I built it up at David Wayne Hooks airport (DWH) in northwest Houston area where we built more than 16 RVs under one roof between 1990 to present. There are currently ten flying RVs on DWH that are active weekend fly-to-eat aircraft! I know of one RV-6A project at the Sugarland airport (SGR) and I believe there are some RVs down at Houston Southwest airport (AXH) in Arcola. Come and visit EAA chapter 12 on the second Wednesday of each month at AXH airport. Several members are building RVs in that chapter. I belong to EAA chapter 774 out at Sport Flyers Field in Brookshire. They meet on the third Thursday of each month at the residential hangar of Laverne & Leonard Milholland. That chapter has over 100 members and about half of them are building a plane of some kind or other. At last count, there were 8 RVs being built. There are several flying RVs at West Houston airport (IWS) off I-10 and Hwy 6 area. I know of 4 flying RVs and at least 2 project RVs up at Montgomery Co. airport (CXO) in Conroe. There are also several RV projects southeast of Houston in LaPorte, League City, Lamarque, Texas City and down on Galveston Island. You might call Van's Aircraft and get a ZIP code sorted list of RV builders in the Houston area. You might find that your neighbor is building in his garage! I hope this gives you some insight as to the extreme popularity of this aircraft. I am up at DWH airport every weekend. You are welcome to visit us sometime. Our hangar (100' x 80') still has one RV-6A in the finishing stage and four other flying RV-4, my RV-6 and two RV-6As as hangar tenants. Once you focus on the RVs, there are no other aircraft! W ________________________________________________________________________________
Date: Jan 28, 1999
In a message dated 1/27/99 7:01:51 PM Eastern Standard Time, sarg314(at)azstarnet.com writes: > I was speaking with Bart Lalonde about an IO-360-B2B which would > have the Bendix fuel injector. Are there any operational drawbacks to > having the injector? Is it harder to start when cold, or need lots of > maintenance or something? > > On the plus side I assume the unit would make the engine a bit more > fuel efficent and possibly run a little smoother, yes? Certainly the > chance of icing is reduced. Are there any other benefits? > > --- > Tom Sargent, sarg314(at)azstarnet.com I have an IO-320-B1A on my -6A. Someone's already posted the benefits to fuel injection, so I'll go over a couple of negative's that I'm dealing with on my installation. In the summer during high temp (>90 F) operations, during a taxi-back after landing, the fuel will heat soak and the idle gets rough in short order. I haven't had any problems getting it restarted when heat soaked, but the engine runs very rough for the first few minutes after a hot start. If I'm able to do a run-up right away, it will burn off the hot fuel in the lines forward of the firewall, and then the idle is ok, as long as I don't spend much time fiddling around before takeoff. I've installed some heat sleeving on the injector lines, and this helped some, but extended taxi times lead to a rough idle. I know that Airflow Performance sells a fuel purge by-pass valve that can be installed just forward of the flow divider, that will allow the hot fuel to be purged before starting. I've also seen the same type of valve for sale in a Summit Racing catalog for $100. This problem doesn't bother me bad enough to spend the money for the purge valve setup. I'm aware of the problem, but it's embarrassing to taxi out from refueling with a rough sounding engine. I've done some research on this phenomenon, and found several periodicals and engine operating books that seem to indicate that this is a common malady on tightly cowled fuel injected engines. One good source is the Sacramento Skyranch Engineering manual. Maybe Mr. Bowhay could comment on this? Mark LaBoyteaux RV-6A N106RV Broken Arrow, Ok MLaboyteau(at)aol.com ________________________________________________________________________________
Date: Jan 28, 1999
I have an HVLP paint gun that works with 'normal' air compressors. It was $150 at Harbor Freight. Although I have never used other guns, I think it works great. Despite my total lack of spray painting experience, I was able to a good job when priming my parts. Once the gun was properly adjusted, I had absolutely no problems with runs or overspray. Sylvain Duford Bellevue, WA RV-8 #47 -----Original Message----- From: Japundza, Bob <BJapundza(at)ksmconsulting.com> Date: Thursday, January 28, 1999 10:00 AM Subject: RE: RV-List: auto versus aircraft paint > >Listers, > >I was wanting to get additional feedback on painting, as painting is soon >approaching my project. I was wondering what the advantages/disadvantages >are of basecoat-clearcoat paint jobs are. Have any of you painted your RV's >this way? Are HVLP systems worth their purchase price? I also don't have >the cleanest shop, either. I was thinking of fashioning a paint booth out >of plastic sheeting and box fans. Can I get good results doing it this way? >How important is temperature on painting? > >Bob Japundza >RV-6 doing gear leg fairings > > ________________________________________________________________________________
Date: Jan 28, 1999
Subject: Re: Van's throttle and mixture cables (6A)
> I searched the archives and only added more variables to my problem. > What I wanted to know is when throttle and mixture controls are placed > on a sub panel under the main panel, are the cables supplied by Van's > at 41.5" to long, to short or just right. > > What I did find is that a lot of builders are using cables from > Aircraft Spruce or other sources. Why? Are Van's cables bad? This is a VERY good question and one that I have planned to post something about for a while. I guess this is as good a time as any. First off, Van's sells several types of cables: bowden-style, wire end (CT-A part numbers), fat-Knob, RV-6 trim style w/ 10-32 end (CT-23 part numbers), and ACS A-750/A-800 style w/ telescoping 10-32 end (CT BLK, CT RED, CT BLUE part numbers.). I installed ACS type because I wanted the "certified" style knobs (and also I am not partial to vernier throttles). I assume that is the type you are asking about. Anyhow, the answer to your question is, NO. The 42.5" throttle and 41.5" mixture cables will be TOO SHORT unless you have a vertical center console per the plans, and even then you will have to use the most direct possible cable routing the for it to work. I discovered this when working with Vans to develop a new throttle/mixture bracket for the O-360 that would work with the ACS type cables for both the throttle and mixture. I told them how long the cables would need to be to accomodate builders who put the knobs in a horizontal subpanel or up in the panel itself, and I think they're going to change them or add longer ones to the catalog, but I don't know if they're doing so yet. This is the reason people have been ordering custom from ACS. I ended up doing that myself. Unfortunately this can be a bit tricky -- you have to know exactly the throw you need as well as the length from the panel to the bracket attach point, and from the attach point to the end of the cable, and it takes some figuring to come up with the right combination that puts the attach point in the right place. Also it costs a fair bit more for the custom lengths. Hopefully you can get the length you need from Van's, then you won't have to worry about doing a custom cable. Take it from me, it's a pain. If you do go custom, I strongly recommend starting with a h/w store lawnmower cable or similar to use to measure the length you need before ordering a custom one. You may think you have the right with a measuring tape but the way the cable twists and turns can defy accurate measurement with a tape, and it's best to have it no longer than needed. Also, when specifying throw, be sure to take into account any reduction of throw due to snaking around of the cable. You can lose up to 3/8" throw if you have a lot of bends in the cable. The ACS catalog (pg 146 & 147) has specs for these cables that include a figure for reduction in throw per 360 degrees of bend. Note that the new O-360 carb bracket (which is not yet in the catalog), will accomodate both the mixture and throttle ACS style cables (CT RED MIXTURE and CT BLK THROTTLE). The older bracket (the one that's in the catalog now) will handle the CT-BLK THROTTLE but is set up for a wire style cable for the mixture. The CT BLUE VPROP cable will work fine just about anywhere you put the knob, the only trick is where to put the hole in the firewall. Contact me on-line or off if you have other questions about this. Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com ________________________________________________________________________________
Date: Jan 28, 1999
Subject: New Sutbscriber RV-9 Wannabuilder
Hello All, Just to say hello. I'll be lurking and would like to contact RV-6 builders relatively close to Rockingham, NC. Thinking of building the six or the nine - quick build. Best Regards, Waldo Love ________________________________________________________________________________
Date: Jan 28, 1999
In a message dated 1/28/99 3:40:50 AM Pacific Standard Time, peck(at)amigo.net writes: << What technique has anyone used for marking ranges on guages not already marked? How does one safely remove the glass, and has anyone used paint, such as model paint, in deference to tape? We have Westach gauges and RCAllen instruments primarily. How about a sun-resistant paint? Flat tone plastic model paint, maybe even over a white base coat to keep the color bright...? >> If it's GAUGES you are referring to, ACS has decals for the glass listed on page 315. I don't know what a GUAGE is. -GV ________________________________________________________________________________
Date: Jan 28, 1999
> What technique has anyone used for marking ranges > on guages not already marked? [snip] > We have Westach > gauges and RCAllen instruments primarily. Westach told me they'd re-mark Westach brand gauges if I sent them to them. I don't remember the price they quoted but as I recall it was quite reasonable. Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com ________________________________________________________________________________
Date: Jan 28, 1999
Subject: High performance engine overhauls
From: "Stephen C. MacInnis" <stevemac1(at)Juno.com>
Thought I'd pass on a good experience I've had with a local overhaul shop. Jeff Harper of Tex Air Aircraft Engines in Houston and I spent about 2 weeks on and off preparing and assembling my IO-360A3B6D. All the major components had been previously overhauled and yellow tagged by specialty shops. Jeff double cut the exhaust valves, balanced all the reciprocating parts, balanced the crankshaft, flowed the cylinders, and smoothed out the ports. He painted most of the interior parts with various high-temp coatings that he's really sold on. I spent more time washing what I thought were already clean parts than I care to remember! The amount of time and care spent on the actual assembly was a pleasure to witness. Nothing was taken for granted and I have zero concern about the integrity of my engine. Anybody anywhere near Houston who needs an engine overhauled would be foolish not to talk with Jeff. Steve MacInnis RV6 mounting cowling ________________________________________________________________________________
Date: Jan 29, 1999
Subject: aussie builders RV8
To the Aussie RV8 builders. I would like to get in contact with any other Australians who are building an 8 at the moment.Please feel free to email me directly. Thanks Peter Winter Victoria Australia p.s.winter@net-tech.com.au ________________________________________________________________________________
From: "Stephen Johnson" <spjohnsn(at)ix.netcom.com>
Date: Jan 28, 1999
Mike, For what it's worth, I don't plan on closing my wings until absolutely necessary, which will be a few years at the rate I'm going, just so I can postpone the decision on an S-Tec installation. Steve Johnson RV-8 #80121 > >Anybody installed an S-TEC System 20 autopilot in their RV-8? The S-TEC >people say they only have an installation for the 6, but some 8 builders >have bought the 6 kit and made the necessary parts to fit the 8. > >Mike Robbins >RV-8Q #591 >Issaquah, WA > ________________________________________________________________________________
Date: Jan 28, 1999
In a message dated 1/28/99 8:57:42 AM Pacific Standard Time, rbusick(at)netmagic.net writes: << Also I wonder if the non flying public (passangers) would consider a poorly painted or a non painted (not polished, ugly looking surface) aircraft as an unsafe? >> I am quite sure that this is the case with "most" of the general non-aviation public. Of course, I myself have flown in commercial planes that needed a paint job and/or a good cleaning, and my thoughts were that I hoped that trimming the budget in this area allowed them to perform quality maintenance in other areas. do not archive ________________________________________________________________________________
Date: Jan 28, 1999
Von, Did you alodine the skin first or just rough it up with scotchbright? I am debating on whether to go with the epoxy primer or the 1791 wash primer which is self etching. I am leaning toward the wash primer for health reasons since I don't want to buy a forced air breathing apparatus. John Henley, 140 hrs, RV6 ---------- > From: n41va(at)Juno.com > To: rv-list(at)matronics.com > Subject: Re: RV-List: auto versus aircraft paint > Date: Wednesday, January 27, 1999 10:10 AM > > > Keith; > Having just finished painting my RV-8 and being very happy with the > results, I would like to recommend PPG Delstar Acrylic Enamel. They claim > this is what is used on 90% of new cars (except most of them use clear > coat). It has a VOC of 4.2 lbs per gal. It is also one of the least > expensive paints, yet with hardener is supposed to be extremely durable. > If the auto paint has anti-run qualities compared to aircraft paint that > is good, because unless you are a seasoned painter you need all the > anti-run help you can get! I got 3 or 4 runs on mine which will be > sanded and buffed out later. For my RV-8, it cost me a total of $485 for > ALL the paint supplies. It took a gallon of DP-48 epoxy primer, and > about 5 quarts of the main body paint, and a quart each of the trim > colors. This was two full coats, you might be able to get by with one > coat, but durability and longevity would drop, and it would be more > difficult to get good coverage, but it can be done. In my opinion, paint > is very important in how attractive the airplane is, as well as resale > value. I saved weight in other areas (mostly the panel) to allow for the > paint. > > Von Alexander > N41VA(at)juno.com > > <73623.2504(at)compuserve.com> writes: > ><73623.2504(at)compuserve.com> > > > >Finally nearing paint time on my RV6. Been checking the archives and > >found > >lots of good info. But did not see this question addressed: > > > >Is there a significant difference in finished weight between auto and > >aircraft paint? I have been told auto paint is heavier because it > >contains > >more anti-run ingredients - a form of clay, maybe? - which increase > >its > >weight. > > > >If there really is a big difference, and does anyone know how much for > >a > >typical RV6? > > > >Is it in the priming system, paint or in the recommended paint > >thickness? > > > >In looking at tech data sheets for two auto paints (PPG Concept and > >Sikkens > >Autocryl) I see a RTS VOC weight of about 4.6 pounds per gallon. I'm > >guessing this means ready to spray volatile organic compounds. I > >wonder if > >I could use the Material Safety Data Sheets, take the total weight per > >gallon (about 8.5# for paints and 7.5# for reducers) and subtract the > >VOC > >weight. Then I would have to get aircraft paint data to compare. > > > > With an O360, constant speed and full panel my RV is too heavy > >already so > >I'm wondering if aircraft paint might help. > > > >Also, I have pretty much dropped the idea of trying a water based > >product,, > >based mostly on the bad reports I found in the RV list archives for > >System > >Three on aluminum. At Oshkosh I got some info on paint furnished by > >A.F.S. > >(Aircraft Finishing Systems) in Montana. Of course they say its great > >(sticks like crazy, light, beautiful, etc.). Does anyone on the list > >have > >experience with A.F.S. product on aluminum? I like the safety aspect > >but > >for sure don't want to get into a repainting project. > > > >Great posts the last couple of days about elevator weights - adjusting > >those is coming up and the comments really help! > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Bill Knight crash
Date: Jan 28, 1999
I was reading a few articles on the Marchetti SF-260 (my real dream plane I have to admit), and the article Bill Knight wrote about his love affair with (and purchase of) a SF-260 is an awesome read. It's located at: http://www.geocities.com/Nashville/7348/bk.html. Sadly, I also saw references to his crash last year in a -6 which included a picture of the plane after it was pulled from the creek: http://www.geocities.com/Nashville/7348/knight.jpg. Does anyone know what happened to the FAA investigation of Viagra-induced problems? Mitchell Faatz N727MF (reserved) RV-6AQME San Jose, CA Engine mounted... President/Newsletter Editor Bay Area RVators http://www.skybound.com/BARV http://www.aftershock.org/rv.htm ________________________________________________________________________________
Subject: The Float Story
Date: Jan 28, 1999
Hope I am not violating the rules of the list, don't think so as this all relates to the RV's. Over the years have flown thousands of hours on floats on many different types of a/c. To name a few, DHC Beaver, DHC Beaver amphib, DHC Otter, Twin Beech D18, Grumman Goose, Fairchild 71, DGA 15 Howard, Cessna 195,C180, C185, C206, C206 amphib, SeaBee, Stinson 108 and others. Flying floats has probably given me the greatest sense of freedom with an aircraft. With the ability to land in the thousands of lakes and rivers in our country and putting your mind at ease knowing that with the number of lakes we have in a lot of the areas there was really no need to get too excited if the engine quit. When I started the RV I didn't think much about putting it on floats but guess it was tucked away in the back of my mind because I hung the O360 and constant speed up front. After flying it for awhile and seeing how it performed realized that it had some potential for floats. Decided to mention it to Van, well he just kind of looked sideways at me and am sure was wondering if I really had all my marbles. Anyway after explaining how we were going to approach the project and the engineering involved I went away without him saying no. We started out by getting a qualified engineer to do a analysis of the centre section to see if it was capable of standing the extra loads and stresses of a float operation. It came out with flying colors. From there it was fairly straight forward to build and install the floats. With it in the water and ready for the first flight, on start up taxiing and turning and all around water handleing is as good or better than any float plane I have flown. It is out of the water in no wind (glassy conditions) at standard temperature and 1100 ft elevation in 14 seconds fully loaded. Initial rate of climb at full throttle is 1000-1200 ft. per min and cruises at 145-150 mph indicated at 8-10000 ft. Flew it to Oshkosh in 1994 on the straight floats and was awarded "Best Metal Float Plane" You can see a picture of it on the cover of the July/94 Kitplanes and a write-up. Because of the good performance on the straight floats decided to go the final step and develop the amphib version. Having flown the Beaver and C206 on amphibs grew to dislike them because of the extra weight and what they did to the performance. By taking a little different approach was able to get the amphib gear into them for a total installed weight of only 101 extra pounds. The climb and cruise are affected by the extra weight and drag but can still count on 145 and 900 ft rate of climb. Have no problem getting to 10000 ft in 15 -20 minutes in climb cruise configuration. We have since as was mentioned carried out a extensive flight test program with over 400 take-offs and landings on the airport cycling the gear each time and some deliberate crosswind and hard landings. All the amphib components were removed and inspected at this point and no unusual wear was found. Flight characteristic's were also carefully exlpored at this time and nothing unusual was found. Again the entire amphib gear is engineered as close as we can get to certified standards. We feel that carefully built and maintained this is a good product. Let me tell you that the RV6 is one tough bird , with all the test work and rough water work there is not a single smoking rivet or any sign of stress. For those with any interest as I posted the other day, these floats will be available for the RV6 and 6A in either kit or competed form in the next few months with prices hopefully available in 60-90 days. Also hope to have them available for the RV8 in the near future. No modifications are required when building to accomodate the float installation with the exception of the 6A you would order the F engine mount from Van's. Eustace Bowhay Blind Bay, B.C. ________________________________________________________________________________
Subject: Elevator Push Rod Attachment
Date: Jan 28, 1999
A little slow on this one, but thought I should post it. It's a shame to cut any extra holes in these pretty birds if we don't have to and follows the "keep it light and simple policy". This has worked for me: With the inspection hole cut as per the drawings reach in with your right hand and get the rod end bearing lined up as close as you can. Then with the bolt held in a flexible mechanical finger ( say about 12inches long) push the bolt into place with the head end away from you. By moving the rod end around with your right hand this can be done easily. Leaving the mechanical finger hooked up, with your right hand reach in and install the washer and nut. Remove the mechanical finger then reach in with your right hand and put a box end wrench on the nut. While holding it with right hand with a socket on a rachet with an extension put it on the bolt and tighten. Your left hand will be outside doing this. Ten minutes should take care of it, five after a bit of practice. Eustace Bowhay Blind Bay, B.C. ________________________________________________________________________________
Date: Jan 28, 1999
Small bits of various colored vinyl tape on the glass works very well. They can be remove and re-positioned as needed. -----Original Message----- From: Vanremog(at)aol.com <Vanremog(at)aol.com> Date: Thursday, January 28, 1999 5:29 PM Subject: Re: RV-List: rvlist--range markings > >In a message dated 1/28/99 3:40:50 AM Pacific Standard Time, peck(at)amigo.net >writes: > ><< What technique has anyone used for marking ranges > on guages not already marked? How does one safely > remove the glass, and has anyone used paint, such as > model paint, in deference to tape? We have Westach > gauges and RCAllen instruments primarily. How about > a sun-resistant paint? Flat tone plastic model paint, > maybe even over a white base coat to keep the color > bright...? >> > >If it's GAUGES you are referring to, ACS has decals for the glass listed on >page 315. I don't know what a GUAGE is. > >-GV > > ________________________________________________________________________________
Date: Jan 28, 1999
Subject: Re: proseal hint.
great idea!, just like decorating a cake!! Peter Winter wrote: > > Hi listers, > > A mate of mine building a Corby Starlet gave me a good hint for the use of > proseal. > > He is a chef and he decided that proseal was about the same consistency as > chocolate and cream,so obviously he used the same applicator as one would use to > decorate the a cake...you know the type of thing that you squeeze the cream or > chocolate through. > he told me this was a great way to apply the proseal and was not messy at > all.......I suppose you would have to be a chef to qualify that > statement.....anyway i thought this might help someone. > > Regards, > > Peter Winter > Australia > > RV8 wings in progress. > > Matronics: http://www.matronics.com > RV-List: http://www.matronics.com/rv-list > Archive Search Engine: http://www.matronics.com/search > Archive Browsing: http://www.matronics.com/archives > Other Email Lists: http://www.matronics.com/other ________________________________________________________________________________
From: "Paul Riedlinger" <paulried(at)mindspring.com>
Subject: Re: New Sutbscriber RV-9 Wannabuilder
Date: Jan 28, 1999
Waldo, building a 6A in Greensboro, NC. Your welcome to come take a look...not a quick build though -----Original Message----- From: Waldo Love <waldo(at)carolina.net> Date: Thursday, January 28, 1999 5:06 PM Subject: RV-List: New Sutbscriber RV-9 Wannabuilder > >Hello All, > >Just to say hello. I'll be lurking and would like to contact RV-6 >builders relatively close to Rockingham, NC. Thinking of building the >six or the nine - quick build. > >Best Regards, > >Waldo Love > > ________________________________________________________________________________
Date: Jan 28, 1999
Subject: Re: battery cable/battery box
> Ok, I'm stumped. In my QB, the battery box is already done, and I can not > find any reference in the archives or the manuals as to where to have the > wires exit the battery box to go to ground and to the starter relay. Also, > I am assuming that most builders put the starter relay very close to the > battery inside the firewall. Correct? I haven't seen any responses to this one so I'll give it a go.... No there doesn't seem to be much in the way of guidelines for this. I've seen it done various ways, and I'm not sure there is any "standard" way people are doing it. Some people go out the top of the box, some out the side, most with grommets close to the fwd edge and often with slots from the grommet holes to the edge so you can get the box out without having to disconnect the battery. I did something a little different with a two piece deal I made out of nylon and put in the right fwd side of the box I made it out of 1/8" thick nylon. It is in two halves, one of which can be removed by taking out some screws, allowing you to remove the box without disconnecting wires. It holds the wire in place quite well and makes for a nice installation; if you want more info on how I did this, contact me off line. Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com ________________________________________________________________________________
Date: Jan 28, 1999
Subject: Re: breathing apparatus
John and listers: for a descent fresh air breathing thingy, take a cartridge respirator. Hook a small 1/4 or 3/8" hose fitting to it and feed fresh air to it. Use a DRY DIAPHRAM compressor so that you are not pumpimg oil mist to your mask. Set the pump out in the back yard, UP WIND, from your paint site and connect them with a length of soft flexible plastic hose. Tape up the cannisters so that all of your breathing air comes in through the hose from outside. One of those small 12 volt tire pump compressors might do the job. Try it and let the List know your results. Phil John Henley wrote: > > Von, > Did you alodine the skin first or just rough it up with scotchbright? > I am debating on whether to go with the epoxy primer or the 1791 wash > primer which is self etching. I am leaning toward the wash primer for > health reasons since I don't want to buy a forced air breathing apparatus. > John Henley, 140 hrs, RV6 > > ---------- > > From: n41va(at)Juno.com > > To: rv-list(at)matronics.com > > Subject: Re: RV-List: auto versus aircraft paint > > Date: Wednesday, January 27, 1999 10:10 AM > > > > > > Keith; > > Having just finished painting my RV-8 and being very happy with the > > results, I would like to recommend PPG Delstar Acrylic Enamel. They claim > > this is what is used on 90% of new cars (except most of them use clear > > coat). It has a VOC of 4.2 lbs per gal. It is also one of the least > > expensive paints, yet with hardener is supposed to be extremely durable. > > If the auto paint has anti-run qualities compared to aircraft paint that > > is good, because unless you are a seasoned painter you need all the > > anti-run help you can get! I got 3 or 4 runs on mine which will be > > sanded and buffed out later. For my RV-8, it cost me a total of $485 for > > ALL the paint supplies. It took a gallon of DP-48 epoxy primer, and > > about 5 quarts of the main body paint, and a quart each of the trim > > colors. This was two full coats, you might be able to get by with one > > coat, but durability and longevity would drop, and it would be more > > difficult to get good coverage, but it can be done. In my opinion, paint > > is very important in how attractive the airplane is, as well as resale > > value. I saved weight in other areas (mostly the panel) to allow for the > > paint. > > > > Von Alexander > > N41VA(at)juno.com > > > > <73623.2504(at)compuserve.com> writes: > > ><73623.2504(at)compuserve.com> > > > > > >Finally nearing paint time on my RV6. Been checking the archives and > > >found > > >lots of good info. But did not see this question addressed: > > > > > >Is there a significant difference in finished weight between auto and > > >aircraft paint? I have been told auto paint is heavier because it > > >contains > > >more anti-run ingredients - a form of clay, maybe? - which increase > > >its > > >weight. > > > > > >If there really is a big difference, and does anyone know how much for > > >a > > >typical RV6? > > > > > >Is it in the priming system, paint or in the recommended paint > > >thickness? > > > > > >In looking at tech data sheets for two auto paints (PPG Concept and > > >Sikkens > > >Autocryl) I see a RTS VOC weight of about 4.6 pounds per gallon. I'm > > >guessing this means ready to spray volatile organic compounds. I > > >wonder if > > >I could use the Material Safety Data Sheets, take the total weight per > > >gallon (about 8.5# for paints and 7.5# for reducers) and subtract the > > >VOC > > >weight. Then I would have to get aircraft paint data to compare. > > > > > > With an O360, constant speed and full panel my RV is too heavy > > >already so > > >I'm wondering if aircraft paint might help. > > > > > >Also, I have pretty much dropped the idea of trying a water based > > >product,, > > >based mostly on the bad reports I found in the RV list archives for > > >System > > >Three on aluminum. At Oshkosh I got some info on paint furnished by > > >A.F.S. > > >(Aircraft Finishing Systems) in Montana. Of course they say its great > > >(sticks like crazy, light, beautiful, etc.). Does anyone on the list > > >have > > >experience with A.F.S. product on aluminum? I like the safety aspect > > >but > > >for sure don't want to get into a repainting project. > > > > > >Great posts the last couple of days about elevator weights - adjusting > > >those is coming up and the comments really help! > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Matronics: http://www.matronics.com > RV-List: http://www.matronics.com/rv-list > Archive Search Engine: http://www.matronics.com/search > Archive Browsing: http://www.matronics.com/archives > Other Email Lists: http://www.matronics.com/other ________________________________________________________________________________
Date: Jan 28, 1999
Steve The roll servo will go just aft of the right foot well for the back seater. Stan -----Original Message----- From: Stephen Johnson <spjohnsn(at)ix.netcom.com> Date: Thursday, January 28, 1999 5:57 PM Subject: Re: RV-List: S-TEC in an 8 > >Mike, > >For what it's worth, I don't plan on closing my wings until absolutely >necessary, which will be a few years at the rate I'm going, just so I can >postpone the decision on an S-Tec installation. > >Steve Johnson > >RV-8 #80121 > > >> >>Anybody installed an S-TEC System 20 autopilot in their RV-8? The S-TEC >>people say they only have an installation for the 6, but some 8 builders >>have bought the 6 kit and made the necessary parts to fit the 8. >> >>Mike Robbins >>RV-8Q #591 >>Issaquah, WA >> > > ________________________________________________________________________________
Subject: Any Headsets out there needing new homes.....??
Date: Jan 28, 1999
Hi, In the past I've seen a few listings for used headsets posted by folks wanting to upgrade theirs. Two of my friends have just started taking Private Pilot training and are looking for good used headsets that are reasonably priced. Please reply to me with the information and I'll forward email to them. I appreciate any help in getting these guys a headset..... Paul Bilodeau RV-6A paul.and.ien(at)worldnet.att.net 732-721-2838 ________________________________________________________________________________
Date: Jan 28, 1999
Subject: Pitot line
Working on hooking up the pitot tube. I am going to use the flexible plastic line to hook up the pitot instead of using the aluminum line. Any ideas on the types of tubing that can be used? It would be nice to not have to order some high dollar stuff when hardware store tubing would work. Has anyone tried the plastic tubing that is used to hook up icemakers or other types of tubing? Jerry Calvert Edmond Ok -6a wings ________________________________________________________________________________
Date: Jan 28, 1999
Subject: Re: Bill Knight crash - address fix
Delete the last period (.) in the site address to make it work. > >I was reading a few articles on the Marchetti SF-260 (my real dream >plane I have to admit), and the article Bill Knight wrote about his love >affair with (and purchase of) a SF-260 is an awesome read. It's located >at: http://www.geocities.com/Nashville/7348/bk.html. Sadly, I also saw >references to his crash last year in a -6 which included a picture of >the plane after it was pulled from the creek: >http://www.geocities.com/Nashville/7348/knight.jpg. > >Does anyone know what happened to the FAA investigation of >Viagra-induced problems? > >Mitchell Faatz N727MF (reserved) RV-6AQME >San Jose, CA Engine mounted... >President/Newsletter Editor Bay Area RVators >http://www.skybound.com/BARV >http://www.aftershock.org/rv.htm > > ________________________________________________________________________________
Date: Jan 28, 1999
Subject: Re: auto versus aircraft paint
John; I used scotchbrite first, followed by the acid wash which is applied easiest with a scotchbrite. This way you a double scotchbrite effect. This was followed by DP-48 epoxy primer. The paint shop says a regular respirator will work fine for the DP-48, apparently it is not as toxic as the enamels with hardeners. Von Alexander N41VA(at)juno.com writes: > >Von, > Did you alodine the skin first or just rough it up with >scotchbright? >I am debating on whether to go with the epoxy primer or the 1791 wash >primer which is self etching. I am leaning toward the wash primer for >health reasons since I don't want to buy a forced air breathing >apparatus. > John Henley, 140 hrs, RV6 > >---------- >> From: n41va(at)Juno.com >> To: rv-list(at)matronics.com >> Subject: Re: RV-List: auto versus aircraft paint >> Date: Wednesday, January 27, 1999 10:10 AM >> >> >> Keith; >> Having just finished painting my RV-8 and being very happy with the >> results, I would like to recommend PPG Delstar Acrylic Enamel. They >claim >> this is what is used on 90% of new cars (except most of them use >clear >> coat). It has a VOC of 4.2 lbs per gal. It is also one of the least >> expensive paints, yet with hardener is supposed to be extremely >durable. >> If the auto paint has anti-run qualities compared to aircraft paint >that >> is good, because unless you are a seasoned painter you need all the >> anti-run help you can get! I got 3 or 4 runs on mine which will be >> sanded and buffed out later. For my RV-8, it cost me a total of $485 >for >> ALL the paint supplies. It took a gallon of DP-48 epoxy primer, and >> about 5 quarts of the main body paint, and a quart each of the trim >> colors. This was two full coats, you might be able to get by with >one >> coat, but durability and longevity would drop, and it would be more >> difficult to get good coverage, but it can be done. In my opinion, >paint >> is very important in how attractive the airplane is, as well as >resale >> value. I saved weight in other areas (mostly the panel) to allow >for the >> paint. >> >> Von Alexander >> N41VA(at)juno.com >> >> <73623.2504(at)compuserve.com> writes: >> ><73623.2504(at)compuserve.com> >> > >> >Finally nearing paint time on my RV6. Been checking the archives >and >> >found >> >lots of good info. But did not see this question addressed: >> > >> >Is there a significant difference in finished weight between auto >and >> >aircraft paint? I have been told auto paint is heavier because it >> >contains >> >more anti-run ingredients - a form of clay, maybe? - which increase > >> >its >> >weight. >> > >> >If there really is a big difference, and does anyone know how much >for >> >a >> >typical RV6? >> > >> >Is it in the priming system, paint or in the recommended paint >> >thickness? >> > >> >In looking at tech data sheets for two auto paints (PPG Concept and > >> >Sikkens >> >Autocryl) I see a RTS VOC weight of about 4.6 pounds per gallon. >I'm >> >guessing this means ready to spray volatile organic compounds. I >> >wonder if >> >I could use the Material Safety Data Sheets, take the total weight >per >> >gallon (about 8.5# for paints and 7.5# for reducers) and subtract >the >> >VOC >> >weight. Then I would have to get aircraft paint data to compare. >> > >> > With an O360, constant speed and full panel my RV is too heavy >> >already so >> >I'm wondering if aircraft paint might help. >> > >> >Also, I have pretty much dropped the idea of trying a water based >> >product,, >> >based mostly on the bad reports I found in the RV list archives for > >> >System >> >Three on aluminum. At Oshkosh I got some info on paint furnished >by >> >A.F.S. >> >(Aircraft Finishing Systems) in Montana. Of course they say its >great >> >(sticks like crazy, light, beautiful, etc.). Does anyone on the >list >> >have >> >experience with A.F.S. product on aluminum? I like the safety >aspect >> >but >> >for sure don't want to get into a repainting project. >> > >> >Great posts the last couple of days about elevator weights - >adjusting >> >those is coming up and the comments really help! >> > >> > >> > >> > >> > >> > >> > >> > >> > >> >> >> >> >> >> >> >> > > > > > > > ________________________________________________________________________________
Date: Jan 29, 1999
Subject: Re: The Float Story
Dear Mr. Bowhay, When I was deciding what kit airplane to build I had a tough time deciding wether to build a plane to put on floats or a high performance plane like the RV8A I am building now. I did see pictures of your RV6 on floats but I never imagined I would ever see the floats offered to the rest of us RV builders. It will be many years before I am finished my plane but putting it on floats will be the first project I undertake once it is done. With this in mind is there any special preperations I should undertake in building the airplane in foresight of water operations? Thank You, Claudio Scremin Scremm(at)aol.com RV8a #80304 Eliot, ME (Formerly of Vancouver, B.C.) ________________________________________________________________________________
Subject: Fw: S-tec 30 in a RV-8.
Date: Jan 29, 1999
Date: Thursday, January 28, 1999 8:48 PM Subject: S-tec 30 in a RV-8. >I installey a S-tec 30 in my RV-8. The pitch control servo mounts behind >the baggage conpartment and in front of the elevator horn. I connected it >with a solid rod. The roll servo mounts just aft of the right footwell for >the backseater. Watch out for the manual trim connection. The roll servo >connects with a solid rod to the control stick mount, I forgot the part >number. You don't have to buy a install kit. I have a lot of rods with a >clevis type end on they I will send you for free, you pay postage and buy me >a beer at sun and fun or osh. If you have any questions give me a call > >Stan Mehrhoff > > ________________________________________________________________________________
Date: Jan 29, 1999
I'm building an 8 in Advance (8A7). Does anyone in the Piedmont area have an interest in forming a builders group? Is there already one? -Larry larry(at)bowen.com http://larry.bowen.com RV-8 N9XS, emp. almost done. ---Paul Riedlinger wrote: > > > Waldo, building a 6A in Greensboro, NC. Your welcome to come take a > look...not a quick build though > -----Original Message----- > From: Waldo Love <waldo(at)carolina.net> > To: rv-list(at)matronics.com > Date: Thursday, January 28, 1999 5:06 PM > Subject: RV-List: New Sutbscriber RV-9 Wannabuilder > > > > > >Hello All, > > > >Just to say hello. I'll be lurking and would like to contact RV-6 > >builders relatively close to Rockingham, NC. Thinking of building the > >six or the nine - quick build. > > > >Best Regards, > > > >Waldo Love ________________________________________________________________________________
Subject: RE: Mechanical finger
Date: Jan 29, 1999
Now here is a product I could use inserting bolts into the tail cone that hold the VS on. I knew such a product had to exist. Where can I get one? Steve Soule Huntington, Vermont -----Original Message----- Then with the bolt held in a flexible mechanical finger ( say about 12inches long) push the bolt into place with the head end away from you. By moving the rod end around with your right hand this can be done easily. Leaving the mechanical finger hooked up, ________________________________________________________________________________
Date: Jan 29, 1999
Subject: Re: Fw: S-tec 30 in a RV-8.
THE CENTURY 2000 AUTO PILOT IS EASY INSTALLATION IN ALL THE RV AIRPLANES CALL MARTIN OSWALD CENTURY FLIGHT SYSTEMS 1-800-4335630 EX604 FOR INFO TOM RV8 TIO540S1AD LYC ________________________________________________________________________________
Date: Jan 29, 1999
Subject: Re: GPS Antenna Location
Seems the antenna would get too much heat under the cowl??? Is that not a problem? hilljw(at)aol.com 8a ________________________________________________________________________________
Date: Jan 28, 1999
Mike, Check w/ George Orndorff. He had an 8 in his shop that STec used as a test bed to develop the kit. I think it will be available soon. Jeff Farrar, RV8A,Got my QB!!!, Chandler, AZ -----Original Message----- From: Michael J. Robbins <kitfox(at)gte.net> Date: Wednesday, January 27, 1999 8:52 PM Subject: RV-List: S-TEC in an 8 > >Anybody installed an S-TEC System 20 autopilot in their RV-8? The S-TEC >people say they only have an installation for the 6, but some 8 builders >have bought the 6 kit and made the necessary parts to fit the 8. > >Mike Robbins >RV-8Q #591 >Issaquah, WA > > ________________________________________________________________________________
Subject: Harmon Rocket Pictures on the net?
Date: Jan 29, 1999
Does anyone know of a site that has pictures of the Harmon-Rocket? C.VonHoven Plant Process Development Engineer SSC Industries, Atlanta, GA ________________________________________________________________________________
Date: Jan 28, 1999
I just used a hair dryer set on 'cool' to feed my gas mask respirator. Worked great. Von Alexander N41VA(at)juno.com writes: > > >John and listers: >for a descent fresh air breathing thingy, take a cartridge respirator. >Hook a >small 1/4 or 3/8" hose fitting to it and feed fresh air to it. Use a >DRY >DIAPHRAM compressor so that you are not pumpimg oil mist to your mask. >Set the >pump out in the back yard, UP WIND, from your paint site and connect >them with a >length of soft flexible plastic hose. Tape up the cannisters so that >all of your >breathing air comes in through the hose from outside. One of those >small 12 >volt tire pump compressors might do the job. Try it and let the List >know your >results. Phil > >John Henley wrote: > >> >> Von, >> Did you alodine the skin first or just rough it up with >scotchbright? >> I am debating on whether to go with the epoxy primer or the 1791 >wash >> primer which is self etching. I am leaning toward the wash primer >for >> health reasons since I don't want to buy a forced air breathing >apparatus. >> John Henley, 140 hrs, RV6 >> >> ---------- >> > From: n41va(at)Juno.com >> > To: rv-list(at)matronics.com >> > Subject: Re: RV-List: auto versus aircraft paint >> > Date: Wednesday, January 27, 1999 10:10 AM >> > >> > >> > Keith; >> > Having just finished painting my RV-8 and being very happy with >the >> > results, I would like to recommend PPG Delstar Acrylic Enamel. >They claim >> > this is what is used on 90% of new cars (except most of them use >clear >> > coat). It has a VOC of 4.2 lbs per gal. It is also one of the >least >> > expensive paints, yet with hardener is supposed to be extremely >durable. >> > If the auto paint has anti-run qualities compared to aircraft >paint that >> > is good, because unless you are a seasoned painter you need all >the >> > anti-run help you can get! I got 3 or 4 runs on mine which will be >> > sanded and buffed out later. For my RV-8, it cost me a total of >$485 for >> > ALL the paint supplies. It took a gallon of DP-48 epoxy primer, >and >> > about 5 quarts of the main body paint, and a quart each of the >trim >> > colors. This was two full coats, you might be able to get by with >one >> > coat, but durability and longevity would drop, and it would be >more >> > difficult to get good coverage, but it can be done. In my opinion, >paint >> > is very important in how attractive the airplane is, as well as >resale >> > value. I saved weight in other areas (mostly the panel) to allow >for the >> > paint. >> > >> > Von Alexander >> > N41VA(at)juno.com >> > >> > <73623.2504(at)compuserve.com> writes: >> > ><73623.2504(at)compuserve.com> >> > > >> > >Finally nearing paint time on my RV6. Been checking the archives >and >> > >found >> > >lots of good info. But did not see this question addressed: >> > > >> > >Is there a significant difference in finished weight between auto >and >> > >aircraft paint? I have been told auto paint is heavier because it >> > >contains >> > >more anti-run ingredients - a form of clay, maybe? - which >increase >> > >its >> > >weight. >> > > >> > >If there really is a big difference, and does anyone know how >much for >> > >a >> > >typical RV6? >> > > >> > >Is it in the priming system, paint or in the recommended paint >> > >thickness? >> > > >> > >In looking at tech data sheets for two auto paints (PPG Concept >and >> > >Sikkens >> > >Autocryl) I see a RTS VOC weight of about 4.6 pounds per gallon. >I'm >> > >guessing this means ready to spray volatile organic compounds. I >> > >wonder if >> > >I could use the Material Safety Data Sheets, take the total >weight per >> > >gallon (about 8.5# for paints and 7.5# for reducers) and subtract >the >> > >VOC >> > >weight. Then I would have to get aircraft paint data to compare. >> > > >> > > With an O360, constant speed and full panel my RV is too heavy >> > >already so >> > >I'm wondering if aircraft paint might help. >> > > >> > >Also, I have pretty much dropped the idea of trying a water based >> > >product,, >> > >based mostly on the bad reports I found in the RV list archives >for >> > >System >> > >Three on aluminum. At Oshkosh I got some info on paint furnished >by >> > >A.F.S. >> > >(Aircraft Finishing Systems) in Montana. Of course they say its >great >> > >(sticks like crazy, light, beautiful, etc.). Does anyone on the >list >> > >have >> > >experience with A.F.S. product on aluminum? I like the safety >aspect >> > >but >> > >for sure don't want to get into a repainting project. >> > > >> > >Great posts the last couple of days about elevator weights - >adjusting >> > >those is coming up and the comments really help! >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > >> > >> > >> > >> > >> > >> > >> > >> >> Matronics: http://www.matronics.com >> RV-List: http://www.matronics.com/rv-list >> Archive Search Engine: http://www.matronics.com/search >> Archive Browsing: http://www.matronics.com/archives >> Other Email Lists: http://www.matronics.com/other > > > > > > > ________________________________________________________________________________
Date: Jan 29, 1999
Subject: Re: Any Headsets out there needing new homes.....??
IEN YOE wrote: > > > Hi, > > In the past I've seen a few listings for used headsets posted by folks > wanting to upgrade theirs. Two of my friends have just started taking > Private Pilot training and are looking for good used headsets that are > reasonably priced. > > Please reply to me with the information and I'll forward email to them. > > I appreciate any help in getting these guys a headset..... > > Paul Bilodeau > RV-6A > paul.and.ien(at)worldnet.att.net > 732-721-2838 > ________________________________________________________________________________
Date: Jan 29, 1999
Subject: Re: Pitot line
jerry calvert wrote: > > > Working on hooking up the pitot tube. I am going to use the flexible > plastic line to hook up the pitot instead of using the aluminum line. > Any ideas on the types of tubing that can be used? It would be nice to > not have to order some high dollar stuff when hardware store tubing > would work. Has anyone tried the plastic tubing that is used to hook up > icemakers or other types of tubing? > > Jerry Calvert > Edmond Ok -6a wings > ________________________________________________________________________________
Date: Jan 29, 1999
A few great pictures! http://www.maui.net/~russ/rocket/mh.html > -----Original Message----- > From: Charles P. VonHoven [SMTP:vonhoven(at)usa.net] > Sent: Friday, January 29, 1999 9:01 AM > To: RV-List > Subject: RV-List: Harmon Rocket Pictures on the net? > > > > Does anyone know of a site that has pictures of the Harmon-Rocket? > > C.VonHoven > Plant Process Development Engineer > SSC Industries, Atlanta, GA > > > > > > ----- > > ----- > http://www.matronics.com/contribution > > ----- > ________________________________________________________________________________
From: Robert Acker <robert.acker(at)IngramMicro.com>
Subject: Prop Position
Date: Jan 29, 1999
Couldn't find this in the archives... Is there a "proper" position to install the Sensenich f/p metal prop in relation to the Lycoming crank/hub/starter ring (which has an index mark on it)? Thanks, Rob Acker (RV-6Q). ________________________________________________________________________________
Date: Jan 29, 1999
Rob, Glad to see your mounting the prop! Here is our "official" word on indexing your Sensenich propeller: The proper position is to install the propeller number one blade at 11 o clock when the number one cylinder is top-dead-center (TDC). TDC can be found by turning the ring gear and crankshaft until the line on the ring gear (marked by TC #1) is aligned with a punch mark on the front edge of the starter housing. Another way, would be to remove the spark plug from the number one cylinder (facing the engine from the propeller flange, this is the 1st cylinder on the left side for Lycomings) and while turning the crankshaft put your thumb over the spark plug hole. On the compression stroke you will feel pressure build and when the mag clicks the cylinder is close to TDC. Using a flash light the exact TDC can be found. This is the best position for hand proping. It also makes the propeller stop near vertical during shutdown (or engine stoppage). There you have it! Ed Zercher ________________________________________________________________________________
Date: Jan 29, 1999
Subject: Re: Prop Position
<< This is the best position for hand proping. It also makes the propeller stop near vertical during shutdown (or engine stoppage). There you have it! Ed Zercher >> Ed: Does this method align the prop with the crank throws? Seems I heard this a while back... Check six! Mark ________________________________________________________________________________
Date: Jan 29, 1999
Subject: Looking for local builders
Hi - I am trying to decide between building an RV-6 or a Mustang II. Are any list subscribers located in or around the metro Atlanta, GA area / north GA? If you wouldn't mind sharing your experiences with building/flying this kit, please respond to me off this list. Thanks! (d_casey(at)yahoo.com) Dean Casey ________________________________________________________________________________
Subject: Re: Looking for local builders
Date: Jan 29, 1999
> >I am trying to decide between building an RV-6 or a Mustang II. > >(d_casey(at)yahoo.com) > >Dean Casey > Dean, I'd say your asking for alot of email asking that question on this list. I had the pleasure of helping a near heritic like your self make the correct decision last summer, I have a four but he was trying to decide between a six and a Mustang ll as well. I gave him the well known here, $30,000 free ride and he ultimately decided on a six. Not only a better airplane than a mustang, IMHO, but the factory support is second to none. Joe Hine C-FYTQ RV-4 ________________________________________________________________________________
Date: Jan 26, 1999
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: electric primers
>This may be a long post, so hit delete now if you like. >I would like to install an electric primer because it gets two more gas >lines out of the cabin, and also the cost of manual primers is getting right >up there. >Aircraft Spruce has an electric primer solenoid which shows an inlet and >outlet port, but I cannot see any wires or connectors to activate it. Is it >a pump ? It is recommended for Long Eze types. I called to ask my questions, >and guess what ? They don't know anything about this items use. They gave >me a 1-800-- number to call for answers. They turn out to be a >distributor/supplier, not the maker, so they were even more in a fog. >Does anyone know how these are fitted into the system and are they what I am >looking for ?..How have others implemented an electric prime ? Been trying to whip up universal in Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Jan 26, 1999
Subject: Re: Fast-on connectors and inspections
>Has anyone who chose to use the Fast-on connectors to wire their >aircraft experienced a hassle with the airworthiness inspection from a >DAR or FSDO rep? Personally, I'm planning on using the Fastons where >possible, but don't want to butt heads (buttheads?) with the inspector >when the big day comes...sometime in the next decade. *sigh* The only guy who ever jumped up in one of my forums at OSH to object to the use of Fast-Ons claimed to be an IA of many years experience. He allowed as how those were for use on washing machines and blenders and he'd be really hard on anyone who tried to use them on any airplane for which he had a say . . . I invited him to step out on the flightline and inspect ANY Cessna from about 1966 and on. I was at Cessna when the Carling rocker switches became standard and all were fitted with Fast-On terminals. Given that there were no AD's against tens of thousands of airplanes I didn't find it unusual that he would know nothing about them . . . but suggested that if he was REALLY upset about it, he sure did have his work cut out for him! Given that most of those airplanes are now pushing 30 years old, I'll suggest your concerns are quite minimal. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Jan 27, 1999
Subject: Re: 50 or 100 Watt Landing Lights ?
> I am working on landing lights and wonder if > 100 W bulbs are really needed or if the 50 W supplied with the Duckworks > landing lights are sufficient. Would appreciate input of those who made > night landings with either 50 and/or 100 W lights. >> It's interesting about the range of ideas that surround the topic of night lighting for landings. Most are aware that Part 23 doesn't even require a landing light for night flight. Some dyed-in-the-wool figher jocks speak of learning to to carrier landings at night where a light would be useless and they take visual cues from other sources. If you think about what makes a landing good or bad, it's your perception of height above the ground in the flare that allows you to hold the necessary landing posture until your energy bleeds off. I didn't figure it out until my own first attempt at no-light landing about 15 years ago. Turned out it was no big deal . . the reason being that as I settled toward the runway, I picked up the concrete in my peripheral vision every time the tip strobes flashed! Years later, I suggested to some Kitfox builders (15 amp alternator) that some little spot lights under each wing tip, pointed down and forward at about a 30 degree angle would illuminate the surface on either side and well inside your peripheral vision. A couple of builders tried it and found that very satisfactory landings were conducted with about 10 watts of light per wingtip. The other fact that begs attention is that it's not so much how many watts of light you have as it is how you use it. Case in point: Consider the 6 volt, sealed beam sporting flashlights or perhaps the popular Mag Lights. These are 5.5 volt, 0.6 amp bulbs with a grand power consumption of about 3 watts! I think if I had one of those sportsman's lanterns tied to the strut of my J-3 I could make very satisfactory night landings. The real answer to the question lies in deciding what it is that you need to see in order confidently control the airplane in that sweet zone a foot above the runway. I'll suggest that a bizillion candlepower of light pointed down the runway may be satisfying in that one may avoid the occasional cow . . . but for myself, I'd spend some time experimenting with light and evaluation of the physiology of landings to come up with a system that is small, light, low in power consumption yet adequate to the task. There are some nifty, 50 watt 12v reflector floods Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Jan 27, 1999
>Ok, I'm stumped. In my QB, the battery box is already done, and I can not >find any reference in the archives or the manuals as to where to have the >wires exit the battery box to go to ground and to the starter relay. Also, >I am assuming that most builders put the starter relay very close to the >battery inside the firewall. Correct? Please consider putting the starter contactor on the upper left corner of firewall on the engine side and putting your alternator b-lead feeder fuse right next to it. This wiring is illustrated in several drawings downloadable from http://www.aeroelectric.com/errata/z8.pdf Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Jan 29, 1999
I started to build a mustang about 6 years ago, started on the wings, got one done and then looked at Van's RV6. Well I gave away the plans, wings and whatever else I had for the Mustang away for free. The RV6 is a much nicer plane all around than the Mustang. Hope this helps, Bob Cornacchia Mooney & Rv6 ________________________________________________________________________________
Date: Jan 29, 1999
Subject: Re: RE: Mechanical finger
Steve, Here is a real simple way to install those pesky little -3 bolts in the elevator and rudder hinges. What you need is a 3/8 inch box end wrench and 3M brand blue painters masking tape. I use Sears Craftsman combination wrenches so the box end is bent about 20 degrees in relation to the handle, but any other brand of the same design will work. The 3M tape is thicker than other brands so it works the best. IMHO What you do is take a 1 inch piece of the masking tape and stick it over the hole in the box end wrench. Next push the -3 bolt head through the masking tape and into the wrench. The idea here is to get the masking tape to fold around the bolt head as it enters the wrench making the bolt head fit into the wrench a little tighter. The masking tape holds the bolt securely enough into the wrench head and gives about a 20 degree angle between the bolt and the wrench. I have installed my rudder and elevators countless times using this method. On the elevators, start by putting a long -4 bolt through the VS-411 bearing and the elevator horn. This holds the root/inboard end of the elevator so you can line up the other two bearings and install the tip/outboard -3 bolt next. On the rudder, I start with the top bolt and work down. Hope this helps Gary Zilik Pine Junction, CO RV-6A s/n 22993 - Helping another builder install wings and landing gear mounts in the morning. Stephen J. Soule wrote: > > Now here is a product I could use inserting bolts into the tail cone that > hold the VS on. I knew such a product had to exist. Where can I get one? > > Steve Soule > Huntington, Vermont > ________________________________________________________________________________
From: "Glenn Hoskins" <Imagine21_glenn(at)email.msn.com>
Date: Jan 29, 1999
I am building an RV6 quickbuild. A good friend is building Mustang II. We are at approximately the same stage of construction. Memphis, TN. -----Original Message----- From: Lamont Cranston <dean_rv(at)yahoo.com> Date: Friday, January 29, 1999 3:32 PM Subject: RV-List: Looking for local builders > >Hi - > >I am trying to decide between building an RV-6 or a Mustang II. Are >any list subscribers located in or around the metro Atlanta, GA area / >north GA? If you wouldn't mind sharing your experiences with >building/flying this kit, please respond to me off this list. Thanks! > >(d_casey(at)yahoo.com) > >Dean Casey > > ________________________________________________________________________________
Date: Jan 29, 1999
Subject: Re: Elevator Push Rod Attachment
While we are discussing drilling and attaching the elevator push rod. I've had the horizontal stab. on a table for a year while I work on the fuselage. If I align the elevator tips with the horizontal stab. would it be OK to drill the elevator horns (easy time to do it), or should I wait until it's installed on the fuselage (the access hole looks awful small). I think, if I have to do any shimming during installation that I wouldn't want to distort the hor. stab. after all the work done to make it straight during construction. Marty Sailer RV-6A Installing electric flaps ________________________________________________________________________________
Date: Jan 29, 1999
Subject: RV builders in Calgary
I'm going to be in the Calgary area on Saturday, January 30 and possibly on Sunday. I am interested in building an RV in the near future but would like to look at some projects that are being built, or at a completed aircraft. Please leave an E-mail if available this weekend. ________________________________________________________________________________
Date: Jan 30, 1999
>While we are discussing drilling and attaching the elevator push rod. >I've had the horizontal stab. on a table for a year while I work on >the >fuselage. If I align the elevator tips with the horizontal stab. >would >it be OK to drill the elevator horns (easy time to do it), or should I >wait until it's installed on the fuselage (the access hole looks awful >small). - You should do it off the airplane. Their is not enough room to to do accurate work with it mounted on the fuselage. I am not sure what you mean by this shimming/distorting stuff below though. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. - I think, if I have to do any shimming during installation that >I >wouldn't want to distort the hor. stab. after all the work done to >make >it straight during construction. > >Marty Sailer RV-6A Installing electric flaps ________________________________________________________________________________
Date: Jan 30, 1999
> >Rob, > >Glad to see your mounting the prop! Here is our "official" word on >indexing >your Sensenich propeller: > >The proper position is to install the propeller number one blade at 11 >o >clock when the number one cylinder is top-dead-center (TDC). >Ed Zercher > > If mounted this way, doesn't it locate the other blade directly in front of the timing marks on the ring gear support? This makes it a real pain to adjust the mag timing accurately. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Subject: Looking for Mesa, AZ builders
Date: Jan 29, 1999
I'm finishing the wings on my -6A and will be in the Mesa,AZ area Feb. 17-21 and would like to share mistakes with any builders in the area. If you have time for hanger wars let me know and I'll get in touch. I'm trying to make a decision on the engine and am considering a Mazda rotary. Any suggestions etc. welcome. Thanks Larry McKee Hanford, CA eschew obfuscation ________________________________________________________________________________
Subject: Re: ACS reply
Date: Jan 30, 1999
Jim Can you give me a phone number for Wicks. Stan Mehrhoff RV-8 about ready to fly, memphis area. -----Original Message----- ________________________________________________________________________________
Date: Jan 30, 1999
Stan Mehrhoff wrote: > > > Jim > Can you give me a phone number for Wicks. > Stan Mehrhoff > RV-8 about ready to fly, memphis area. (800) 221-9425 Carroll Bird ________________________________________________________________________________
Date: Jan 30, 1999
Subject: WWW links about flight testing
RV-Listers, I have collected a list of links about flight testing homebuilt aircraft. There is information there that might be useful for those preparing for their first flight, and also those who are doing performance or flight characteristics flight testing. The links are available at http://www.cyberus.ca/~khorton/rvlinks.html Please let me know if there are any other links that I should add, or if any of the ones I have are bad. Also, I am looking for someone more qualified than I to write a few notes explaining what flutter is in terms that are easily understood. Flutter is a often misunderstood phenomenon, and I would like to link to some decent info on it, either as an external link, or info on my web page. I would be more than happy to provide proper attribution to who ever is willing to write something. Take care, Kevin Horton RV-8 (fuel tanks) khorton(at)cyberus.ca (613) 821-7862 (home) Ottawa, Canada (613) 952-4319 (work) http://www.cyberus.ca/~khorton/rv8.html ________________________________________________________________________________
Subject: Re: Looking for Mesa, AZ builders
Date: Jan 30, 1999
Larry: I live in Scottsdale. I have a QB, but a new engine from Aero Sport Power (Bart Lalonde) if you want to come by and take a look. You can reach me at 473-7883 Paul Besing -----Original Message----- From: Larry McKee <lmckee(at)cnetech.com> Date: Saturday, January 30, 1999 6:11 AM Subject: RV-List: Looking for Mesa, AZ builders > >I'm finishing the wings on my -6A and will be in the Mesa,AZ area Feb. 17-21 >and would like to share mistakes with any builders in the area. If you have >time for hanger wars let me know and I'll get in touch. I'm trying to make a >decision on the engine and am considering a Mazda rotary. Any suggestions >etc. welcome. >Thanks >Larry McKee >Hanford, CA >eschew obfuscation > > ________________________________________________________________________________
Subject: Re: Harmon Rocket Pictures on the net?
Date: Jan 30, 1999
Oh man what a beautiful bird...wanna trade for a partially built -6A?? -----Original Message----- From: Lucchinetti, Marco <marcol(at)crt.com> Date: Friday, January 29, 1999 5:05 PM Subject: RE: RV-List: Harmon Rocket Pictures on the net? > > > A few great pictures! > >http://www.maui.net/~russ/rocket/mh.html > >> -----Original Message----- >> From: Charles P. VonHoven [SMTP:vonhoven(at)usa.net] >> Sent: Friday, January 29, 1999 9:01 AM >> To: RV-List >> Subject: RV-List: Harmon Rocket Pictures on the net? >> >> >> >> Does anyone know of a site that has pictures of the Harmon-Rocket? >> >> C.VonHoven >> Plant Process Development Engineer >> SSC Industries, Atlanta, GA >> >> >> >> >> >> ----- >> >> ----- >> http://www.matronics.com/contribution >> >> ----- >> > > ________________________________________________________________________________
Date: Jan 30, 1999
On Thu, 28 Jan 1999 n41va(at)Juno.com wrote: > I just used a hair dryer set on 'cool' to feed my gas mask respirator. > Worked great. Uh, You might want to check your hair dryer out first. Some of the older models were insulated with asbestos, which would not make for good breathing... Miller McPherson RV6 QB Tucson ________________________________________________________________________________
Date: Jan 30, 1999
In a message dated 1/30/99 5:56:43 AM Pacific Standard Time, acepilot(at)mwt.net writes: << he forgot the last part of their name -- "Specialty"...which makes their short reference ASS instead of just AS. >> Actually ACS is correct. -GV ________________________________________________________________________________
Date: Jan 30, 1999
Subject: Magnetic Interference
I'm looking for a way to mount the rails my radios trays will attach to. I'd like to make the rails removable, but I'm concerned that screws/nutplates may cause magnetic interference with my compass, which will be located nearby. I know you can get brass screws, but are there brass, aluminum, plastic, or some other non- magnetic female fasteners I can use for this application? Or, am I overly concerned with the impact a couple of grams of steel will have? Replies apprieciated. Kyle Boatright ________________________________________________________________________________
Date: Jan 30, 1999
Mark: Remember that one was forsale from Canada (Prince Edward Island) for 80K last year this time....I don't know who bought it..I think it went to CA...Jim Brown ________________________________________________________________________________
Date: Jan 30, 1999
Subject: nutplates
Can someone tell me if and where I can find number -4 nutplates (for mounting tail position light). AS&S only carries down to -6. Thanks. Adrian Chick Nashville, TN. rv6a wings on order ________________________________________________________________________________
Subject: Engine handleing
Date: Jan 30, 1999
Hi Louise: Not sure what your LAME means by not babying the engine. I think some people are misguided by the recommended 70-75% power setting to seat the rings during the first few hours of operation on a new or overhauled engine. This rule is also the same for a top overhaul where just the cylinders are reworked..But once the rings are seated and oil consumption has stabilized there is no further need for the 70-75% power setting on a continuous basis. The engine gets a good variety of power settings in normal use with the initial full throttle for take-off and 75% for the climb or during aerobatics. Once the engine is run-in properly I have never seen any problems develope from the 65% setting. A good example would be Jon's long distance flights and round the world flights with normal power settings of 50 -55%. These settings were used to acheive maximum range.Jon and I did a 10 day tour into the arctic with my RV6 on wheels in August and the engine subject as to fuel consumption and reliability came up frequently with our flying over the isolated areas. At that time Jon mentioned that his engine which was purchased new had some 1400 hrs on it and was running around a litre of oil every fifty hours and with all the cylinders in the high seventies over eighty. Hope this helps and feel free to contact me anytime, Regards Eustace Bowhay Do not Achive ________________________________________________________________________________
Date: Jan 30, 1999
Subject: Re: Magnetic Interference
> >I'm looking for a way to mount the rails my radios trays will attach to. I'd >like to make the rails removable, but I'm concerned that screws/nutplates may >cause magnetic interference with my compass, which will be located nearby. I >know you can get brass screws, but are there brass, aluminum, plastic, or some >other non- magnetic female fasteners I can use for this application? Stainless steel is reasonably nonmagnetic. Do they even make stainless nutplates and the like? >Or, am I overly concerned with the impact a couple of grams of steel will >have? No, you aren't being overly concerned. I was very careful to make sure there was nothing magnetic near the compass and everything was working fine until later when I forgot and installed a couple of miniature toggle switches in the panel too near the compass. I now have *serious* deviation errors that I haven't been able to eliminate yet. Brian Lloyd 3420 Sudbury Road brian(at)lloyd.com Cameron Park, CA 95682 http://www.lloyd.com +1.530.676.1113 ________________________________________________________________________________
Date: Jan 30, 1999
Miller; A good warning if you are using an old hair dryer; I bought mine new and checked for this. Von Alexander N41VA(at)juno.com ________________________________________________________________________________
Date: Jan 30, 1999
Subject: Looking for Parachute
For the first 25 hours or so, I am planning to wear a parachute for my RV-8 test period. Would like to just buy one; does anyone have one they would like to sell? Need a seat pack type, weight 170lbs. Or recommendations on where to find one for a reasonable price? Thanks. Von Alexander N41VA(at)juno.com ________________________________________________________________________________
Date: Jan 30, 1999
Subject: Re: nutplates
In a message dated 1/30/99 3:52:39 PM Eastern Standard Time, adrianchick(at)home.com writes: << Can someone tell me if and where I can find number -4 nutplates (for mounting tail position light). AS&S only carries down to -6. Thanks. >> Cleaveland sells them as part of their wing tip mounting kit. They'd probably sell you some individually. Rick McBride rickrv6(at)aol.com ________________________________________________________________________________
Subject: Gascolator in RV-4 Wingroot
Date: Jan 30, 1999
People have put gascolators in RV-6 wingroots, but I read in an earlier post that there was not enough space in the RV-4 wingroot. The idea of having it there seems sensible to me so I'd like to explore this a bit more. 1) Is anyone in a position to actually measure the amount of spanwise space in an RV-4 wingroot between the fuselage side and the fuel tank rib web? My gascolator would require about 2-1/2 inches to fit. 2) Does anyone know of a slimmer gascolator? In Canada we need gascolators not filters. Thanks Ron Taborek RV-4 Installing O-320 Toronto ________________________________________________________________________________
Date: Jan 30, 1999
In a message dated 1/30/99 12:23:10 PM Eastern Standard Time, rv8er(at)doitnow.com writes: << Oh man what a beautiful bird...wanna trade for a partially built -6A?? >> If anyone else wants some pics of a beautiful Harmon Rocket II, let me know, I have a few that I took this past weekend when I got a ride with Mark Frederick. What a ride!!! Pics turned out nice too. Scott ________________________________________________________________________________
Date: Jan 30, 1999
Subject: Special buy on D-Sub crimp tool . . .
We've just received a limited qty of "star crimp" tools for machined pins to fit D-Sub connectors and many others. Take a peek at: http://www.aeroelectric.com/consign.html The D-Sub connector is found on many of the small, modern avionics products. It's also common to most of our "black boxes". . . . ________________________________________________________________________________
Date: Jan 30, 1999
Subject: Re: Special buy on D-Sub crimp tool . . .
> > > We've just received a limited qty of "star crimp" tools > for machined pins to fit D-Sub connectors and many others. > Take a peek at: > http://www.aeroelectric.com/consign.html > > The D-Sub connector is found on many of the small, modern > avionics products. It's also common to most of our "black > boxes". . . . > Bob, I'm interested in buying one of these D-Sub crimp tools, if I will need one later on. I must admit that I know next to nothing about installing electrics and avionics though. Other than some avionics boxes, where would I need this tool? I may eventually purchase the pre-built wiring kit that Van is putting together, if I get good feedback on quality, completeness and ease of installation. In this case, would I need this tool? Thanks, Kevin Horton RV-8 (fuel tanks) khorton(at)cyberus.ca (613) 821-7862 (home) Ottawa, Canada (613) 952-4319 (work) http://www.cyberus.ca/~khorton/rv8.html ________________________________________________________________________________
Date: Jan 30, 1999
From: "howard.kidwell" <howard.kidwell(at)cwix.com>
Subject: Fw: Want to 'see' the sound barrier?
Greetings: This was passed on to me by a fellow retired fighter pilot. Enjoy. Howard Kidwell Subject: Fwd: Want to 'see' the sound barrier? > > >Take a look at this and "see" an F-4 breaking the sound barrier: > >http://www.MilAir.net/Temp/MilAirScan-F-4J_01.jpg > > 1900 [192.161.36.5]) by rly-yc04.mx.aol.com (8.8.8/8.8.5/AOL-4.0.0) with ESMTP id PAA26782; (5.5.2407.0) From: "Stevens, Mark C" <Mark.Stevens3(at)PSS.Boeing.com> Subject: Want to 'see' the sound barrier? Date: Wed, 9 Dec 1998 12:18:52 -0800 > Take a look at this F-4 breaking the sound barrier: > > http://www.MilAir.net/Temp/MilAirScan-F-4J_01.jpg > > > > > > ________________________________________________________________________________
Subject: Re: Building and waiting
Date: Jan 30, 1999
Buster, Thanks again, Chuck Rowbotham RV-8 > Progressing ________________________________________________________________________________
Subject: Re: Lyc..0340
Date: Jan 30, 1999
> >Help >Has anyone ever used a 0340 in a RV-6.. >>________________________________________________________ I know of two RV6's that have been flying with 0-340 for about seven years. One in Oregon, the other in East Texas. These engines work just fine but they are old, make sure you can get all the parts you need at a reasonable price or they might not be such a bargain. Martin Sutter N868CM 1,300hrs ________________________________________________________________________________
Date: Jan 31, 1999
Subject: Template Trap
I just drilled the last 6 holes in my panel. They were the ones to mount my new PS Engineering intercom. Unfortunately, the drilling template supplied in the installation kit didn't come close to matching the actual holes in the faceplate for the intercom. Try and imagine the happy moment ($!!&*%!) when I went to mount the thing. My suggestion: Check those templates before you drill. Kyle Boatright RV-6 with oblong holes where the intercom mounts. ________________________________________________________________________________
Date: Jan 30, 1999
KBoatri144(at)aol.com wrote: > > > I'm looking for a way to mount the rails my radios trays will attach to. I'd > like to make the rails removable, but I'm concerned that screws/nutplates may > cause magnetic interference with my compass, which will be located nearby. I > know you can get brass screws, but are there brass, aluminum, plastic, or some > other non- magnetic female fasteners I can use for this application? > > Or, am I overly concerned with the impact a couple of grams of steel will > have? > Kyle Boatright Suggest you set your compass on the kitchen table (away from any magnetic influence). Then take your screw/nutplate assembly and see how close to the compass it must come to cause any deflection or compass swing. Double that distance is probably safe. My guess is that the nutplate & screw would have to be within 3 inches to have any influence. Electrical circuits and other instruments will probably cause you greater problems. My Cessna has the compass mounted on the windshield, a magnet is used to hold the glove box door closed about two feet away from the compass. George McNutt, Langley B.C. 6A - starting fusalage. --------------------------------------------------------------------- ________________________________________________________________________________
Date: Jan 31, 1999
Subject: Re: Jack point measurment
In a message dated 1/27/99 6:55:52 AM Pacific Standard Time, borgny(at)rconnect.com writes: << Could someone with a completed RV-6A measure the distance between the wing tie-down and the ground. I want to build some wing jacks. Contact me off list. >> 28.5" from underside of wing to the ground at the threaded tie down hole. -GV ________________________________________________________________________________
Date: Jan 31, 1999
In a message dated 1/30/99 12:52:39 PM Pacific Standard Time, adrianchick(at)home.com writes: << Can someone tell me if and where I can find number -4 nutplates (for mounting tail position light). AS&S only carries down to -6. >> I've got hundreds of them. How many do you want? -GV ________________________________________________________________________________
Date: Jan 30, 1999
Subject: How to "swing" a compass?
Hi all, Does anybody have a step by step procedure one would use to swing a compass? Hopefully, posted on a web site somewhere? Thanks! Don Gates PS -- Paul Rosales and I flew down to visit Gary Sobek today, just to offer encouragement and support. It's going to be a while, but I sure hope to see him and his plane in the air again! We were there more than seven minutes so he put us to work! ________________________________________________________________________________
Subject: Re: Template Trap
Date: Jan 31, 1999
>>I just drilled the last 6 holes in my panel. They were the ones to mount my new PS Engineering intercom. Unfortunately, the drilling template supplied in the installation kit didn't come close to matching the actual holes in the faceplate for the intercom. Try and imagine the happy moment ($!!&*%!) when I went to mount the thing. My suggestion: Check those templates before you drill. Kyle Boatright<< Kyle is right! I just went through this process and found that they don't quite fit, either. One tool that I really liked was the little drilling guide for instruments from Wag Aero. You may be able to get it from other souces. However, the holes didn't quite line up with the instruments. There is a standard; but, everyone is a bit off. I had to do a bit of tweaking on each one. I must admit that the template did save time. On the other templates, I double checked for accuracy and found some errors. For some things, I made my own drilling templates and got a little closer. Hey, I'm not perfect and am not building the perfect airplane! :-) Jim Sears in KY RV-6A N198JS (Wiring done. Engine controls and plumbing next.) ________________________________________________________________________________
From: "Gardner, Douglas (GA44)" <Douglas.Gardner(at)IAC.honeywell.com>
Date: Jan 30, 1999
Hey Scott... Send me those pic's please.. Got alot of attention among other RV builders on that custom trim tab you built for me... Thanks Doug Gardner RV-8A -----Original Message----- From: FLARV8N(at)aol.com [mailto:FLARV8N(at)aol.com] Sent: Saturday, January 30, 1999 5:30 PM Subject: Re: RV-List: Harmon Rocket Pictures on the net? In a message dated 1/30/99 12:23:10 PM Eastern Standard Time, rv8er(at)doitnow.com writes: << Oh man what a beautiful bird...wanna trade for a partially built -6A?? >> If anyone else wants some pics of a beautiful Harmon Rocket II, let me know, I have a few that I took this past weekend when I got a ride with Mark Frederick. What a ride!!! Pics turned out nice too. Scott ________________________________________________________________________________
Date: Jan 31, 1999
Might make the jacks shorter than than to take care of flat tires. -----Original Message----- From: Vanremog(at)aol.com <Vanremog(at)aol.com> Date: Sunday, January 31, 1999 12:57 AM Subject: Re: RV-List: Jack point measurment > >In a message dated 1/27/99 6:55:52 AM Pacific Standard Time, >borgny(at)rconnect.com writes: > ><< Could someone with a completed RV-6A measure the distance between the wing > tie-down and the ground. I want to build some wing jacks. Contact me off > list. >> > >28.5" from underside of wing to the ground at the threaded tie down hole. > >-GV > > ________________________________________________________________________________
Date: Jan 31, 1999
Subject: Re: How to "swing" a compass?
In a message dated 1/30/99 11:50:44 PM Pacific Standard Time, dgates(at)adnc.com writes: << Does anybody have a step by step procedure one would use to swing a compass? >> 1. Use a nonmagnetic screwdriver for all adjustments and have the engine/instuments powered up and running. 2. Place the adjuster/compensators in their neutral positions (there should be marks/dots) 3. Face the aircraft north. 4. Use the N-S adjuster to remove all deviation so that the compass reads N. 5. Face the aircraft east. 6. Use the E-W adjuster to remove all deviation so that the compass reads E. 7. Face the aircraft south. 8. Note the error and use the N-S adjuster to remove half of the error. 9. Face the aircraft west. 10. Note the error and use the E-W adjuster to remove half of the error. 11. Face the aircraft north. 12. Note the error and use the N-S adjuster to remove half of the error. 13. Face the aircraft east. 14. Note the error and use the E-W adjuster to remove half of the error. 15. Face the aircraft south. 16. Note the error and use the N-S adjuster to remove half of the error. 17. Face the aircraft west. 18. Note the error and use the E-W adjuster to remove half of the error. 19. Face the aircraft in the directions indicated on the compass correction card and make the required entries for each of these headings. If you can't get a good correlation then you need to remove magnetic materials from the compass's sphere of influence or degauss magnetized items. -GV ________________________________________________________________________________
Subject: flap brace rivets and QB
Date: Jan 31, 1999
'The new quick builds here .... the new quick builds here .... I'm somebody now+ACE-' to paraphrase Steve Martin. Anyway, what have you other -8 QB'rs done on riveting the flap brace to the rear spar? The call-out is for AN470 AD4-4 rivets but w/ the QB wing skins on, there isn't any way to buck them. Is there a blind fastener substitute for an AD4 rivet ? Thanks, Jeff Farrar, RV8A, Chandler, AZ ________________________________________________________________________________
Date: Jan 31, 1999
Subject: Re: nutplates and compasses
There was a posting yesterday about steel nutplates and their effect on the mag compass. I put my compass on the workbench and held a single #8 nutplate 1 inch from the compass and got 5 deg of movement. I then placed my radio rack which contains 10 #8 stell nutplates (maybe a little overbuilt) next to and even touching the compass (even the nutplates touching the compass) with no movement. I'm thinking that the compass reacts to the ratio of magnetic vs nonmagnetic material. Thats the theory I'm sticking to until I hear a better one. Any other theorys? Dave Beizer Moreno Valley Ca RV-6A Inst Panel ________________________________________________________________________________
Date: Jan 31, 1999
Subject: Misc. Building Tips, hopefully helpful to some
I wanted to share several building tips with the group - some of these I "borrowed" from others, and some are originals. I'm sure that some of these have already been on this list. 1. Tube level. This can be used to get the wing spar mounted level on the jigs, and later to level the fuselage in pitch. Get a 1/4" or so diameter clear PVC tube around 12 feet long. Boiling an ounce or two of water a few minutes, cool, and adding a drop or two liquid soap will help eliminate gas bubbles and allow the water to "wet" the tube. Fill the tube about 80% full of this water, and duct tape one end of the tube to the end of the jig or whatever you want level, and then move the other end up and down until the water level is where it is most useful. Do not use too small a tube for this, as bubbles which are as big as the ID of the tube will make it inaccurate. 2. $85 engine hoist. The base is a rectangle consisting of two 60" and two 49" 2x4's, bolted together with two 1/4" carriage bolts in each corner. Under each 60" board are bolted two castering wheels (200# capacity each), 14" in from each end (32" from wheel to wheel). The vertical portion consists of four 84" long 3/4" rigid galvanized pipes, fashioned into a pyramid. At the bottom, each of the pipes lines up directly over one of the casters, with a little counterbore into the wood to keep it in place. At the top, I cut four pipe couplings (the above dimensions work this out to be 18 degrees) and welded them to a 4" square by 1/8" thick plate. In the middle of this plate is a hole for an eye bolt. I really like the fact that when I'm not using it, it can be disassembled for storage. The base is sized to straddle the engine pallet. This size lift will easily put the top of the engine at about 48" above the floor with a typical come-along, so size it as necessary for your application. 3. Wing incidence jigs. When setting the wing incidence angle, I found it difficult to make adjustments and then verify, as the rear spar didn't stay in place. Using scrap aluminum angle and threaded rod, I built jigs which clamped to both the fuselage and the aft end of a wing rib, connected by a length of threaded rod. Instead of simply moving the rear spar up and down, this allows the rear spar to be moved small amounts with adjustment of the nuts on the threaded rod. 4. The slider rear hold down blocks can be made adjustable by shimming under the U-channel, and then removing shims as necessary. Lateral adjustment can be made by making the plastic block narrower than the U-channel, and shimming as necessary to move the blocks left and right. 5. The holes through the bulkheads for the forward elevator pushrod in the 6/6A need to be off center to accommodate mounting the elevator bellcrank off center (spacers are not equal length, see dwg 40, middle of sheet). Maybe newer drawings show this, but if your drawings show these holes through bulkheads 605 and 606 to be on center, they are wrong. 6. A very simple balance for measuring pro-seal or epoxy can be made with coat hanger type wire. Make the lengths of the arms proportional to the weight ratio of the two part stuff you want to measure. For example, if the proportions of some epoxy are 5:1 by weight, make one arm of the balance 2" long, and the other arm 10" long (or 3" and 15"). I made little hooks to hold the small plastic cups ("Dixie" style), which are then hung on the ends of the balance. With these cups empty, weights will need to be added to the short end of the balance, as it is important that the system be in balance before adding material to the cups. 7. Cut a small notch in the interior edge of the bottom web of F607 for removal of the forward elevator pushrod. Alex Peterson Maple Grove, MN ________________________________________________________________________________
Date: Jan 31, 1999
On Sat, 30 Jan 1999, dgates wrote: > > Hi all, > > Does anybody have a step by step procedure one would use to swing a compass? This isn't on a web site but here is how I have done it in the past. 1. Carefully align the aircraft with magnetic north. The accuracy with which you perform this step will determine the accuracy of the rest of the process. Use a good compass rose painted on the ground with plumb bobs from nose and tail or use a really good hand-bearing compass sighting along the plumb lines at nose and tail. 2. Set both the N/S and E/W adjustment screws in the compass to their neutral position.. 3. Start the aircraft. 4. Turn on the lights and radios. 5. Get the DG up-to-speed and set it for N. 6. Using a nonmagnetic screwdriver, adjust the N/S adjustment screw to eliminate any error. 7. Using the DG as a reference, turn the aircraft to a heading of 180. 8. Adjust the N/S adjustment screw to eliminate 1/2 (that's right, half) the error. 9. Turn to a heading of 270. 10. Adjust the E/W adjustment screw to eliminate any error. 11. Turn the aircraft to a heading of 090. 12. Adjust the E/W adjustment screw to eliminate 1/2 the error. 13. Turn to a heading of 000 and write down the error on your compass correction card. Do this for each 30 degrees. It is a good idea to plan this whole thing out ahead of time so you can run through the steps quickly. Remember, you are dependent on the accuracy of the DG during this procedure so you want it to precess as little as possible. If you have a helper and a compass rose you can do this without using the DG but it is a lot more difficult. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane (916) 676-6399 - voice Suite 1 (916) 676-3442 - fax Cameron Park, CA 95682 ________________________________________________________________________________
Date: Jan 31, 1999
On Sun, 31 Jan 1999 PLTDBEEZER(at)aol.com wrote: > I'm thinking that the compass reacts to the ratio of magnetic vs > nonmagnetic material. Thats the theory I'm sticking to until I hear a better > one. Any other theorys? It is reacting to whether or not the nutplate is magnetized. It turns out that, if a piece of iron or steel experiences a sudden shock such as from being dropped on concrete, the metal will acquire a magnetic "charge" from the earth's magnetic field. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane (916) 676-6399 - voice Suite 1 (916) 676-3442 - fax Cameron Park, CA 95682 ________________________________________________________________________________
Date: Jan 31, 1999
On Sun, 31 Jan 1999 KBoatri144(at)aol.com wrote: > new PS Engineering intercom. Unfortunately, the drilling template supplied > in the installation kit didn't come close to matching the actual holes in the > faceplate for the intercom. Try and imagine the happy moment ($!!&*%!) when I > went to mount the thing. The paper templates that many companies supply aren't dimensionally stable. I used the actual faceplate from the intercom as a template and then drilled the holes slightly undersized. I then used a very small rat-tail file to open up the holes and ensure that they are in exactly the right place. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane (916) 676-6399 - voice Suite 1 (916) 676-3442 - fax Cameron Park, CA 95682 ________________________________________________________________________________
Subject: Re: flap brace rivets and QB
Date: Jan 31, 1999
Anyway, what have you other -8 QB'rs done on riveting the flap brace to the rear spar? The call-out is for AN470 AD4-4 rivets but w/ the QB wing skins on, there isn't any way to buck them. Is there a blind fastener substitute for an AD4 rivet ? Thanks, Jeff Farrar, RV8A, Chandler, AZ Jeff, You can buck them, just reach in through the inspection plate holes while standing on a stool (assuming you have them jigged). Also, you can get at some of them from the sides assuming you haven't riveted the outer bottom skin on yet. I just bucked them on a friends 8QB so I know it can be done. You can do it! Randy Lervold -8, #80500, fuselage Home Wing ________________________________________________________________________________
Subject: Re: Used engines
Date: Jan 31, 1999
---------- > From: N13eer(at)aol.com > To: ebowhay(at)shuswap.net > Subject: Re: Used engines > Date: Thursday, January 14, 1999 6:05 PM > > In a message dated 1/13/99 9:31:20 PM Central Standard Time, > ebowhay(at)shuswap.net writes: > > << If you like contact me of the list and give me a bit more detail on what > you are looking for. > > Eustace, > What I am thinking about is an O-360 with a fixed pitch prop. I would also > like to add one of the electronic ignetions if not right away down the road. > I have been told that Lycoming made an engine with a single mag hole and solid > crank that are priced less on the used market. Is this correct? I am also > looking to keep the cost down so if I could find something with between 500 > and 1000 hours that I could fly for a while before it needed to be pulled > down. > I have also been looking at O-320s but I would prefer the 360. So far I have > come up with the follwing questions: > Total time. > TSMO > Type of mounts > Carb location > Crank type (solid) > does it have a fuel pump > for 320 high or low compresion > has there been a prop strike. > > What else do I need to know? > Thanks > Alan Kritzman Hi Alan: Sorry to take so long to get back to you on this but here are the guide lines I use on finding a engine. In order to cut the length of this post if you go into the archives and under engines find Match #43 Message #2363 Subject FWD>RV engines (From Van's Aircraft) there is an excellent message from Van's that covers the models of Lycomings suitable for the RV's. Use these guide lines to locate the engine. Because of the number of a/c being built today the chances of picking up a good used engine are not good and this is all the more reason to be extra cautious. Using the recommended 2000 hrs as the life before overhaul if I found one with time remaining the first question would be "why was it removed". Unless it was to upgrade or it came from a damaged a/c I would be on my guard. Is it a first run ? Time since new or o/h? Are the logs and records complete? How old is it? When was it last run? If overhauled who did it and are there good records of this? Type of mount? While a dyno-1 is probably preferrable type dyno-2 and conical are also acceptable. Is it constant speed capable? While not a consideration with a fixed pitch prop it does add some value to it. If it is a H2D don't let this scare you away. This engine is like the one you refer to with dual mags mounted on a single drive.They had some cam and lifter problems due to lack of use but by using the proper oil and flying them regularily will easily go to recommended o/h. Just be aware they are fixed pitch only and will require a minor rework on the cowl due to the front mounted fuel pump.They have been available at a more resonable price. If you are still interested the next step would be a detailed inspection of the engine and logs and records.If good logs and records are not available I would treat it as a time exed engine.If the seller is the original owner a lot can be learned in a face to face visit. Most of us are not qualified to do a proper inspection before purchase so if you are getting serious about buying it get a qualified person to do the final inspection for such items as bent crank flange internal corrossion and general condition. If you are still satisfied ask the seller if he would be willing to have it run at a overhaul shop at your expence. In the case of a time exed engine that you would have overhauled will he guarantee the crankshaft. This usually sorts the thieves from the honest ones. A run at a o/h facility can be done for say 250.00. It is not possible to be absolutely sure of the crankshaft without a tear down making a run in a test stand the next best thing. Also if it is a engine that has had a previous o/h the crank may already be at limits adding around 4000 to the next o/h. You can calculate the value of the engine using these rough figures. The current value of a good first run core is between 5000 and 7000 depending on the model. If it is a overhauled engine this would probaly be say 3500 -5500. If it is a part time engine the time remaining is worth say 4.00 per hour. I follow these rules closely otherwise one stands the chance of winding up with a very expensive boat anchor. A high time engine with a bad crank is worth "zero". If you are lucky enough to find a good engine but it has the wrong sump, carb, or accessory case talk to Bart before you give up on it. A new engine comes with inter-cylinder baffles, carb or fuel injection and a fuel pump. Anything else found on a used engine would be a plus. Eustace Bowhay Blind Bay, B.C. ________________________________________________________________________________
Date: Feb 01, 1999
Subject: IO 540 in RV8?
Hi listers , Has anybody out there fitted an I0 540 into an RV8 or is in the process of doing so, I would like to get your comments or views as I am a bit of a petrol head and love high performance aircraft. Peter Winter Wings....RV8 p.s.winter@net-tech.com.au ________________________________________________________________________________
Date: Jan 31, 1999
I used a H2AD engine with Ed Sterna 68/76 prop. in my "6." I find it to be a nice combination and I'm happy with the performance and cost. The fuel pump is mounted up front and modification will have to be made to the upper cowling, but it also happens to be probably the coolest place in the engine compartment, lessens the chance of vapor lock. I don't think that Van's offers a baffle kit for it, so unless you can find a use one you'll have to build one from scratch, I did. Gil T. ________________________________________________________________________________
Date: Jan 31, 1999
Subject: lexan
I,m making the landing light leading edge lenses from lexan. Has anyone successfully made their lenses out of lexan? I heated it in the oven to 300 degrees for 10 minutes and it barely bent. Any ideas on how much heat and for how long? Jerry Calvert Edmond Ok -6a wings ________________________________________________________________________________
Subject: Re: lexan
Date: Jan 31, 1999
> >I,m making the landing light leading edge lenses from lexan. Has anyone >successfully made their lenses out of lexan? I heated it in the oven to >300 degrees for 10 minutes and it barely bent. Any ideas on how much >heat and for how long? > >Jerry Calvert >Edmond Ok -6a wings > This is from memory but I recall that you first heat it to about 200 degrees for at least 45 minutes to an hour to drive the moisture from the Lexan. Lexan has a moisture content that will cause steam bubbles if you heat it to past the boiling point without first 'drying' it out. After the moisture is gone then increase the heat to 250 to 300 until the Lexan begins to 'droop'. Upon removing it from the oven immediately ( in seconds!!) place it on your form. Cover the form with a soft cloth like flannel so you don't scratch the Lexan. I don't understand why yours didn't bend; maybe not enuf time in the oven, maybe too thick. It only needs to be about 1/16" or so thick. Lexan won't break like plexiglass will so you can get away with much thinner stock. John Ammeter Seattle WA USA 1975 JH-5 RV-6 (sold 4/98) ________________________________________________________________________________
Subject: Re: Looking for Parachute
Date: Jan 31, 1999
Dear Von, I have a WW2 era seatpack in good condition that I will sell. It does need to be repacked. I bought it years ago as new surplus , however I did not like sitting on it and bought a back pack. Make offer. Dick Martin RV8 80124 ---------- > From: n41va(at)Juno.com > To: rv-list(at)matronics.com > Subject: RV-List: Looking for Parachute > Date: Saturday, January 30, 1999 3:26 PM > > > For the first 25 hours or so, I am planning to wear a parachute for my > RV-8 test period. Would like to just buy one; does anyone have one they > would like to sell? Need a seat pack type, weight 170lbs. Or > recommendations on where to find one for a reasonable price? Thanks. > Von Alexander > N41VA(at)juno.com > > > > > > > > ________________________________________________________________________________
Date: Jan 31, 1999
Dear Jerry, I am building an RV8, however I own a TruValue hardware store and am very familiar with the plastic tubing that I sell and also that of Home Depot,Walmart etc. I would not use this tube for my airplane,b ecause I do not believe that it is good enough quality. I think that it will deteriorate after a few years of exposure to the elements. I researched the tube and have used polyurethane tubing (appears to look like the economy stuff) however, it will last forever and is much more stable under all conditions. Yes , it costs more than 10cents a foot, (approx 25cents) but I think it is a good investment. I used the "Legris" brand available at industrial supply houses that specialize in hydraulic hose and liquid transmission equiipment. Legris also has a line \of beautiful compact fittings to go with this tube in every conceivable configuration. They also supply larger sizes like 3/8 an 1/2 that I used for my vacuum system. The fittings interchange with Nylon, Polyurethane, and Polyethlene tube. Good luck. Dick Martin RV8 80124 ---------- > From: jerry calvert <calverjl(at)flash.net> > To: rv-list(at)matronics.com > Subject: RV-List: Pitot line > Date: Thursday, January 28, 1999 10:41 PM > > > Working on hooking up the pitot tube. I am going to use the flexible > plastic line to hook up the pitot instead of using the aluminum line. > Any ideas on the types of tubing that can be used? It would be nice to > not have to order some high dollar stuff when hardware store tubing > would work. Has anyone tried the plastic tubing that is used to hook up > icemakers or other types of tubing? > > Jerry Calvert > Edmond Ok -6a wings > > > > > > > ________________________________________________________________________________
From: "Moe Colontonio" <moejoe(at)bellatlantic.net>
Subject: elevator horn misalignment
Date: Jan 31, 1999
Hi all. Today I mounted my left elevator to the HS, and I used a drill bit through the center bearing to make a small mark on the horn, then rotated the elevator through it's full range of motion. Well, the mark does not stay centered. It drifts maybe 1/8" or less. Adjusting the rod end bearings didn't help, so I'm guessing the misalignment is in the vertical plane. Any ideas on fixing this? Should I fix it? I don't want to chance the elevators binding. Thanks in advance! BTW, my workshop was broken into, and my bandsaw, sander, and grinder were stolen. Had to buy all new tools today. So much for my electric DG. If you don't build at home, consider an alarm system. :( Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 Page at: http://tabshred.com/moe ________________________________________________________________________________
Date: Jan 31, 1999
I have the sliding canopy with the stainless steel support bar and would like to mount my compass on it. Does anyone know of a compass with the mounting bracket on top, dont believe I want to mount a box bracket around the compass seems it would be quite large and curtail visibility. TU ahead RV6A finish kit planejoe(at)flnet.com ________________________________________________________________________________
Subject: Re: elevator horn misalignment
Date: Feb 01, 1999
> > >BTW, my workshop was broken into, and my bandsaw, sander, and grinder were >stolen. Had to buy all new tools today. So much for my electric DG. If you >don't build at home, consider an alarm system. > >:( > Really sorry to hear that!! Hope they didn't damage your airplane. John Ammeter Seattle WA USA 1975 JH-5 RV-6 (sold 4/98) ________________________________________________________________________________
Date: Jan 31, 1999
Subject: Break-in--thiefs
Moe, you might want to check your Homeowners Insurance. You might be covered--just guessing--mine covers my tools at work. I wonder if there is renters insurance and maybe liability for such things and to cover your backside. I have been told by my agent my tools are also covered in the hanger I rent but not the airplane of course or such things as that. Just a thought. Sorry about what happened but you can still get an e-gyro just not Now maybe. Good luck. JR ________________________________________________________________________________
Date: Jan 31, 1999
-----Original Message----- From: Moe Colontonio <moejoe(at)bellatlantic.net> Date: Sunday, January 31, 1999 4:28 PM Subject: RV-List: elevator horn misalignment > >Hi all. Today I mounted my left elevator to the HS, and I used a drill bit >through the center bearing to make a small mark on the horn, then rotated >the elevator through it's full range of motion. Well, the mark does not stay >centered. > Mo, I think this means that the hinge fittings on the stabilizer are not in line. That is to say, the elevator is rotating around the line formed by the outboard two hinge fittings and if the center bearing hole is not sitting still relative to the elevator then it must not be on that line. Perhaps if you put a pencil or some other marker in the center bearing and let it mark on the bellcrank as you swing through the travel it will show you the magnitude of the error. My next step would be to do a string check on the stabilizer fittings to see if you get the same dimension. I don't have a clue as to what the maximum amount of allowable misalignment might be. This is relatively flexible structure so a fair amount of misalignment should be tolerable, but 1/8 of an inch seems to be pretty high to me. Anybody out there have any experience with this? Jack Noble RV-8 80719 ________________________________________________________________________________
Date: Jan 31, 1999
Subject: Re: electric primers
Dear Robert The Primer Solenoid in the Aircraft Spruce Cat. indeed has wires. Simply connect a l/8 in. tube from the top of the gascolator to a 4 port manifold (also available from AC Spruce, page l05, new catalogue) and prime three cylinders. The fuel pump will be ON during this exercise. I find that a 5 second prime on a cold day is adequate. This will vary. The solenoid in question has two ports, numbered l and 2. I had to phone the manufacturer to find out which was "in" and "out". At this moment I cannot remember. Stay tuned while I check the A/C. I also connected this solenoid in parallel with a tradional manual primer in the event of a battery failure (read dead). Rob Griesdale, Cayley, Alberta, RV-6A, C-GWPC. ---------- > > > > >This may be a long post, so hit delete now if you like. > >I would like to install an electric primer because it gets two more gas > >lines out of the cabin, and also the cost of manual primers is getting right > >up there. > >Aircraft Spruce has an electric primer solenoid which shows an inlet and > >outlet port, but I cannot see any wires or connectors to activate it. Is it > >a pump ? It is recommended for Long Eze types. I called to ask my questions, > >and guess what ? They don't know anything about this items use. They gave > >me a 1-800-- number to call for answers. They turn out to be a > >distributor/supplier, not the maker, so they were even more in a fog. > >Does anyone know how these are fitted into the system and are they what I am > >looking for ?..How have others implemented an electric prime ? > > Been trying to whip up universal in > > Bob . . . > //// > (o o) > ===========o00o=(_)=o00o======== > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ================================ > > ________________________________________________________________________________
Date: Jan 31, 1999
Dear Robert (Part 2, electric primer solenoid). I forgot to mention that the l/8 line from the gascolator goes directly to the solenoid THEN to the manifold. On the panel I use a momentary SPST switch (spring return). To further complicate this already simple and reliable priming system a little light on the panel tells me that the primer circuit is closed and operating. I hope this helps. I'll get back to you on the ports. Rob Griesdale, Cayley, Alberta---------- > > > Dear Robert > The Primer Solenoid in the Aircraft Spruce Cat. indeed has wires. Simply > connect a l/8 in. tube from the top of the gascolator to a 4 port manifold > (also available from AC Spruce, page l05, new catalogue) and prime three > cylinders. The fuel pump will be ON during this exercise. I find that a 5 > second prime on a cold day is adequate. This will vary. The solenoid in > question has two ports, numbered l and 2. I had to phone the manufacturer to > find out which was "in" and "out". At this moment I cannot remember. Stay > tuned while I check the A/C. I also connected this solenoid in parallel with > a tradional manual primer in the event of a battery failure (read dead). > Rob Griesdale, Cayley, Alberta, RV-6A, C-GWPC. > > > ---------- > > > > > > > > >This may be a long post, so hit delete now if you like. > > >I would like to install an electric primer because it gets two more gas > > >lines out of the cabin, and also the cost of manual primers is getting > right > > >up there. > > >Aircraft Spruce has an electric primer solenoid which shows an inlet and > > >outlet port, but I cannot see any wires or connectors to activate it. Is it > > >a pump ? It is recommended for Long Eze types. I called to ask my > questions, > > >and guess what ? They don't know anything about this items use. They gave > > >me a 1-800-- number to call for answers. They turn out to be a > > >distributor/supplier, not the maker, so they were even more in a fog. > > >Does anyone know how these are fitted into the system and are they what I > am > > >looking for ?..How have others implemented an electric prime ? > > > > Been trying to whip up universal in > > > > Bob . . . > > //// > > (o o) > > ===========o00o=(_)=o00o======== > > < Go ahead, make my day . . . > > > < show me where I'm wrong. > > > ================================ > > > > > > ________________________________________________________________________________
Date: Jan 31, 1999
Subject: Re: lexan
Try using a flat face shield for a motorcycle helmet. More than likely, no heating will be required. Sam Buchanan (RV6 engine baffling, panel, and wiring) "The RV Journal" http://www.ath.tis.net/~sbuc/rv6 jerry calvert wrote: > > > I,m making the landing light leading edge lenses from lexan. Has anyone > successfully made their lenses out of lexan? I heated it in the oven to > 300 degrees for 10 minutes and it barely bent. Any ideas on how much > heat and for how long? > > Jerry Calvert > Edmond Ok -6a wings ________________________________________________________________________________
Date: Jan 31, 1999
>If you can't get a good correlation then you need to remove magnetic materials >from the compass's sphere of influence or degauss magnetized items. > >-GV George Should all of these instructions be carried out with the engine running and all electrical equipment turned on? Derek Reed OR. 6A Fus. ________________________________________________________________________________
Date: Feb 01, 1999
> > >>If you can't get a good correlation then you need to remove magnetic >materials >>from the compass's sphere of influence or degauss magnetized items. >> >>-GV > > >George > >Should all of these instructions be carried out with the engine running and >all electrical equipment turned on? > > >Derek Reed OR. 6A Fus. > Absolutely, anything that can affect the compass must be operating as it would in flight. John Ammeter Seattle WA USA 1975 JH-5 RV-6 (sold 4/98) ________________________________________________________________________________
Date: Jan 31, 1999
Dick; Thanks for the offer; a local parachute shop says to avoid anything over 20 years old, they and apparently most shops will not repack anything over that age. Thanks anyway, and enjoy the RV-8! Von Alexander N41VA(at)juno.com > >Dear Von, >I have a WW2 era seatpack in good condition that I will sell. It does >need >to be repacked. I bought it years ago as new surplus , however I did >not >like sitting on it and bought a back pack. Make offer. >Dick Martin >RV8 80124 > >---------- >> From: n41va(at)Juno.com >> To: rv-list(at)matronics.com >> Subject: RV-List: Looking for Parachute >> Date: Saturday, January 30, 1999 3:26 PM >> >> >> For the first 25 hours or so, I am planning to wear a parachute for >my >> RV-8 test period. Would like to just buy one; does anyone have one >they >> would like to sell? Need a seat pack type, weight 170lbs. Or >> recommendations on where to find one for a reasonable price? Thanks. >> Von Alexander >> N41VA(at)juno.com >> >> >> >> >> >> >> >> > > > > > > > ________________________________________________________________________________
Date: Jan 31, 1999
Subject: Need Advice on Parachute
Listers; I have located (among others) a Security #160 emergency parachute that is designed for sailplanes and aerobatic test flying. It is 2" thick, and is a seat and back pack style. It is limited to use below 150 mph, which I assume is not a problem, since in a free fall a human doesn't exceed this, right? This unit has a conventional canopy, and is from the 70's or 80's and has not been re- packed for 10 years, but has been kept inside the house in a closet during this time. The price seems right. I would like to know if this would be a good unit to use for my RV-8? Any skydivers out there? Also, since I have never gone skydiving, and don't plan to unless I have to, can I get some advice on exiting techniques, how long to free fall before activating the chute, etc. etc. Just some tips would be appreciated. Vans says there has never been a known bail out in an RV, but the peace of mind from having that option is worth it to me. Thanks in advance. Von Alexander N41VA(at)juno.com (RV-8 goes to the airport tomorrow, weather willing) ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: Need Advice on Parachute
I've done a lot of military static line and free- fall parachuting and would recommend the advice of the one of our 'chute shop supervisors, Al Silver- one of the authorities on all aspects of parachuting. His E-mail is silver(at)pia.com. Phone 510-785-7070. Brian Trubee RV-4 fuselage ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re:
In a message dated 1/31/99 5:30:05 PM Pacific Standard Time, planejoe(at)flnet.com writes: << I have the sliding canopy with the stainless steel support bar and would like to mount my compass on it. Does anyone know of a compass with the mounting bracket on top >> I have the Precision Vertical Card Compass. I modified a bracket that came with it but I was later told that they have a special bracket that they sell for the RV series. Precision is in Houston, TX and can be reached at 713-644-7383. -GV ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: Compass mounting
> > I have the sliding canopy with the stainless steel support bar and > would like to mount my compass on it. Does anyone know of a compass > with the mounting bracket on top, dont believe I want to mount a box > bracket around the compass seems it would be quite large and curtail > visibility. TU ahead Try the Airpath C2400-L4VT. It has an angled overhead mount. Not quite the right angle for the rollover brace, but easy to adapt unobtrusively. Peter ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: Break-in--thiefs
Moe, Last year I had the Seneca parked on the ramp at Linden Airport ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: lexan
That dosen't suprise me. The melt temp for polycarbonate plastics to be injected is around 575degrees F. Forming temp would not be that high but would not be far away. Lexan is a brand name. Polycarbonate is the generic name. Bill Jaugilas jerry calvert wrote: > > > I,m making the landing light leading edge lenses from lexan. Has anyone > successfully made their lenses out of lexan? I heated it in the oven to > 300 degrees for 10 minutes and it barely bent. Any ideas on how much > heat and for how long? > > Jerry Calvert > Edmond Ok -6a wings ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: IO 540 in RV8?
Hi my name is john bunn and i am building an 8 in indianapolis in.. John Marshell 317-862-2389 is building two 8's with io-540. give hime a call. one of them will fly in a mth or to, i think it is in the paint shop. John ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Misdrilled elevator horns - update
After discussing the issue with lots o' folks, I decided to go the reweld route. I also made another decision - drilling the elevators on the plane is an unecessary pain in the a**. I have a local race car/engine builder who I trust to weld. I had him weld two 0.090" plates about 1.5" wide and trimmed to fit inside the elevator horns (away from the flange). It turned out quite well since it completely filled the gap between the horns and the rod end bearing, so no more washers are needed (yup, I measured it first). I was determined not to make the same mistake again, so I jigged the elevators up back into the empennage jig since I didn't have a flat table big enough. I am using an extra set of V-block jigs to align the elevators in trail while holding the horns together with the 1/4" center bearing bolt. The two outboard jig blocks are elevated so that the main spars align. With the two horns clamped together with no gap in between, drilling the bolt hole is a now a no-brainer and worth the extra effort to guarantee the elevators align. Now that they are jigged, the misalignment of the old holes is very apparent and is almost half a diameter!. I drilled a new hole with a #13 bit using a drill guide and reamed it to 3/16". Something else worth noting. I heeded the warnings I got about welding 4130 (chrom-moly). My welding guy confirmed that the stuff hardens when welded and turns brittle if welded to hot. This is another reason I chose not to simply fill the old hole with weld material and redrill it. If you have anyone weld 4130 for you, make sure he keeps the heat down to the minimum necessary to do the job. My welder kept dialing it down during the job. Chris Browne -6A Atlanta ________________________________________________________________________________
Date: Feb 01, 1999
Alex, Is there a drawing or photo of that engine hoist available on the web? Steve Soule Huntington, Vermont -----Original Message-----I wanted to share several building tips with the group - some of these I "borrowed" from others, and some are originals. I'm sure that some of these have already been on this list. 2. $85 engine hoist. The base is a rectangle consisting of two 60" and two 49" 2x4's, bolted together with two 1/4" carriage bolts in each corner. Under each 60" board are bolted two castering wheels (200# capacity each), 14" in from each end (32" from wheel to wheel). The vertical portion consists of four 84" long 3/4" rigid galvanized pipes, fashioned into a pyramid. At the bottom, ________________________________________________________________________________
Date: Feb 01, 1999
Hi Von, I think I can offer some input here. I've been skydiving for 15 years, and have been a static-line and tandem instructor for 7years. I have owned around a dozen different parachutes and worked on countless numbers of them. For an emergency aircraft parachute you certainly don't need anything fancy (some main skydiving units cost almost $2000 just for the main canopy) but you do want something safe, and you want to make sure that the canopy is the right size for your weight. There are a dizzying number of parachute sizes, and if you get one that is too small you'll find the landing will make you wish you had stayed with the aircraft. Personally, I'd be a little concerned with a canopy that is that old. You will definitely need to check out its history. There have been "AD-like" bulletins on a few parachutes over the years primarily due to problems with certain types of material and some parachutes have been permanently grounded. You don't want one of these... You don't want to spend a fortune on something you hope you'll never use, but you don't want to buy something useless either. There are a lot of worthless canopies out there that some unscrupulous (or unknowing) seller will try to get rid of "real cheap". My advise is to find a licensed Master Rigger that preferably has been doing it awhile and knows the background of these older rigs and have him thoroughly check it out before handing over any money to the seller. You can usually find one of these folks at your local drop zone (look under parachuting, or skydiving in the yellow pages). If you can't find one I'll be happy to look up the closest one to you or anyone else that's interested in my "DZ guide" (it travels in the RV along with my parachute wherever I go) The rigger may also be able to find you a better canopy locally. Pilots of jump aircraft are required to wear the same thing you're looking for, and this is a good place to look for one. You also might try www.paragear.com for some general info and new pricing. Most canopies are limited to 150mph by their TSO, I wouldn't worry about that. A human body falls at 120mph in a *stable* position (belly to earth, flat, not spinning), but anyone without skydiving training won't be stable. Unstable you can fall as fast as 200mph - so don't do any skydiving if you bail out. Get clear of the airplane, look at the handle, grab the handle with both hands, pull the handle to full arm extension, and throw the handle away in one motion. BTW, don't eliminate the idea of trying a jump. I've taken a few local aerobatic pilots up on a tandem jump and they said the experience was not only a blast, but very educational. It made them a lot less apprehensive about getting out if necessary. It will also teach you a lot about exit, body position, opening, and general parachute operation. There is more info on tandem jumping on my website. Let me know if I can be of any help. Ed Bundy - Eagle, ID RV6A - First flight 11/20/96 ebundy(at)mci2000.com http://home.mci2000.com/~ebundy@mci2000.com/ -----Original Message----- From: n41va(at)Juno.com <n41va(at)Juno.com> Date: Sunday, January 31, 1999 10:52 PM Subject: RV-List: Need Advice on Parachute > >Listers; >I have located (among others) a Security #160 emergency parachute that is >designed for sailplanes and aerobatic test flying. It is 2" thick, and is >a seat and back pack style. It is limited to use below 150 mph, which I >assume is not a problem, since in a free fall a human doesn't exceed >this, right? This unit has a conventional canopy, and is from the 70's or >80's and has not been re- packed for 10 years, but has been kept inside >the house in a closet during this time. The price seems right. I would >like to know if this would be a good unit to use for my RV-8? Any >skydivers out there? Also, since I have never gone skydiving, and don't >plan to unless I have to, can I get some advice on exiting techniques, >how long to free fall before activating the chute, etc. etc. Just some >tips would be appreciated. Vans says there has never been a known bail >out in an RV, but the peace of mind from having that option is worth it >to me. Thanks in advance. > >Von Alexander >N41VA(at)juno.com >(RV-8 goes to the airport tomorrow, >weather willing) > > ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Subject: Re: Misdrilled elevator horns - update
Date: Feb 01, 1999
When I mounted my elevators I found I could either have them aligned "in trail" or I could have the balance weight arms aligned so that they were both flush with the horizontal stab ends -- but I couldn't have it both ways! My elevators are not twisted (anymore). On the plane, it was difficult to establish "in trail" due to the taper in the elevators. I finally split the difference with a little more bias towards having the balance weight arms symmetrical as I was concerned about cosmetics. Just something else to consider. Dennis Persyk 6A panel Hampshire, IL -----Original Message----- From: Chris Browne <cebrowne(at)earthlink.net> Date: Monday, February 01, 1999 8:37 AM Subject: RV-List: Misdrilled elevator horns - update > Some text deleted for brevity: >I jigged the elevators up back into the >empennage jig since I didn't have a flat table big enough. I am using >an extra set of V-block jigs to align the elevators in trail while >holding the horns together with the 1/4" center bearing bolt. The two >outboard jig blocks are elevated so that the main spars align. With the >two horns clamped together with no gap in between, drilling the bolt >hole is a now a no-brainer and worth the extra effort to guarantee the >elevators align. Now that they are jigged, the misalignment of the old >holes is very apparent and is almost half a diameter!. I drilled a new >hole with a #13 bit using a drill guide and reamed it to 3/16". > >Chris Browne >-6A Atlanta ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: control mount angle stock,RV8
Hi folks This ever happen to you? It seems someone came into my shop and sawed up the piece of "scrap" angle to be used for the control mount which sits in front of the main bulkhead and bolts to a seat belt attach point. My question is can I substitute the scrap of 2x2 1/2 for the sawed up 2x1 1/2. It is 1/16 inch thicker. Or is that piece waiting to be used somewhere else? Heeeellllp. Thanks Dennis Clay #80473 fuselage a comin ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Baffle Advice Needed
Am starting to rig the baffles on my 6A/0360CS and this trimming-to-cowling business looks really problematic and time-consuming... Anybody out there got a shortcut? Or better yet, some trim line distances for the CS? The trim info on the drawings is marginally useful at best. Don't wanna re-invent the wheel if I don't have to... Jim 6A New Mexico ________________________________________________________________________________
Date: Feb 01, 1999
Hi Dennis, I thought of that, too, but settled on aligning the trailing edges and dealing with the slight mismatch of the elevator horns, if any. I figure that it is alot easier to deal with any cosmetic mismatch at the tips with fiberglass than to have the elevators imparting a moment about the roll axis which would have to be countered by aileron trim. Even more drag results from misaligned elevators in slip stream. To be sure, it's not a big deal either way. My elevators were misdrilled about 1/8"so I had both problems! Chris Browne -6A Atlanta Dennis Persyk wrote: > > When I mounted my elevators I found I could either have them aligned "in > trail" or I could have the balance weight arms aligned so that they were > both flush with the horizontal stab ends -- but I couldn't have it both > ways! My elevators are not twisted (anymore). On the plane, it was > difficult to establish "in trail" due to the taper in the elevators. I > finally split the difference with a little more bias towards having the > balance weight arms symmetrical as I was concerned about cosmetics. Just > something else to consider. > > Dennis Persyk 6A panel > Hampshire, IL > > -----Original Message----- > From: Chris Browne <cebrowne(at)earthlink.net> > To: rv-list(at)matronics.com > Date: Monday, February 01, 1999 8:37 AM > Subject: RV-List: Misdrilled elevator horns - update > > > Some text deleted for brevity: > >I jigged the elevators up back into the > >empennage jig since I didn't have a flat table big enough. I am using > >an extra set of V-block jigs to align the elevators in trail while > >holding the horns together with the 1/4" center bearing bolt. The two > >outboard jig blocks are elevated so that the main spars align. With the > >two horns clamped together with no gap in between, drilling the bolt > >hole is a now a no-brainer and worth the extra effort to guarantee the > >elevators align. Now that they are jigged, the misalignment of the old > >holes is very apparent and is almost half a diameter!. I drilled a new > >hole with a #13 bit using a drill guide and reamed it to 3/16". > > > >Chris Browne > >-6A Atlanta > ________________________________________________________________________________
Date: Feb 01, 1999
Subject: mounting compass
> I have the sliding canopy with the stainless steel support bar and would > like to mount my compass on it. Does anyone know of a compass with the > mounting bracket on top, dont believe I want to mount a box bracket around > the compass seems it would be quite large and curtail visibility. There's no reason (except maybe cosmetic) to have any kind of "box" that encloses the whole compass. If you start with a standard panel mount compass, you can make a bracket pretty easily that will be virtually no more restricting to visibility than the compass alone. Just cut out of .040 or .063 AL, a flat piece with a hole for the faceplate in it and mounting screw holes. Trim it off square just outside the mounting holes. Leave a tab on the top to bend down and clamp or screw to the center bar. This is the way it's done on a lot of cert. airplanes. Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com ________________________________________________________________________________
Date: Feb 01, 1999
> I just drilled the last 6 holes in my panel. They were the ones to mount my > new PS Engineering intercom. Unfortunately, the drilling template supplied > in the installation kit didn't come close to matching the actual holes in the > faceplate for the intercom. Try and imagine the happy moment ($!!&*%!) when I > went to mount the thing. > > My suggestion: Check those templates before you drill. > > Kyle Boatright > > RV-6 with oblong holes where the intercom mounts. Kyle (and everyone else): Since the PS engineering intercom has a faceplate, you probably won't care that much about the oblong holes in this case, but for mis-drilled holes here or anywhere else on the panel, JB Weld is the thing. Of course I never would make this kind of mistake, but I - ah -- have a friend who used JB weld to fill several mis-drilled holes in his panel. After sanding them smooth and painting you can't tell the difference. Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: Baffle Advice Needed
> Am starting to rig the baffles on my 6A/0360CS and this > trimming-to-cowling business looks really problematic and > time-consuming... Boy you said it buster > Anybody out there got a shortcut? Or better yet, some trim line > distances for the CS? The trim info on the drawings is marginally > useful at best. Why should you get this when I had to do it the hard way? :-) But seriously, this is a good idea. I might be able to do this. I'll try to remember to trace my baffles tonight, perhaps I can do that and scan them in to a GIF file, to put on the web. Or just mail them. Of course every installation will have differences so you'd want to be careful about using any other person's templates. But a ballpark would help a lot nonetheless. I know, I made several of my baffle pieces over after over-trimming the originals. Not difficult since I had the originals as templates and plenty of extra .032, but still a PITA. Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com ________________________________________________________________________________
Subject: Re: RV4 forward skins
Date: Feb 01, 1999
Hi listers . A fellow builder has asked me to put this out to the list . Can the F420 skins be drilled to the flange of the firewall once the fuselage has been removed from the jig , will the fuselage be stable enough in this area to permit this ? Many thanks .LLOYD BENTLEY RV 6 WINGS RSA ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: Houston Area Builders?
Marshall, you didn't mention the inspiration and motivation that you guys have given to many overseas visitors, including myself from Aberdeen in Scotland. During the past seven years or so that I have been completing my own RV6a, I have enjoyed many visits up to the hanger at Hooks, often topped off with a flight in the spare seat of a '6 or '6a. Seeing those aircraft coming together and being part of the enjoyment that followed was all the incentive I needed. By the way, did you ever find time for a paint-job ? Regards to all, John G-RVEE ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: mounting compass
>There's no reason (except maybe cosmetic) to have any kind of "box" that >encloses the whole compass. > >This is the way it's done on a lot of cert. airplanes. > >Randall Henderson, RV-6 (engine/finish) >Portland, OR >http://www.edt.com/homewing >randall(at)edt.com Randall/All, All this talk about compass mounting has me re-thinking my plans. Many that I talked to this past summer at various fly-ins recommended mounting a handheld GPS centered and as high as possible in the panel. They then recommended mounting the compass in the panel off center. I didnt actually talk to anyone who had done this, just to a lot who wished they had. All said that they hardly used the compass and so were really not concerned about any accuracy issues as they were relying on GPS for nav. If I gotta carry a compass in the panel I'd like it to be as accurate as I can make it. How far away from other electronic gizmos does the compass need to be for it to be accurate? If I move it to the left side of the panel it ends up beside my planned location for a micro-encoder and above the comm and transponder (less than 1" from the micro encoder; 3" above the xpndr). Is this a problem? If mounted to the other side it ends up beside my AV8 engine monitor. It also ends up grouped with my engine instruments, not my flight instruments which is not what I want. If I mount it out of the panel on the forward canopy frame (RV-4) its directly above the GPS. Is this a problem? Ive just cut out the panel this past weekend. You dont really realize what a tiny thing it is until you start trying to put stuff in it! Mike Wills RV-4 forward fuse details willsm(at)manta.spawar.navy.mil ________________________________________________________________________________
Date: Feb 01, 1999
I don't think so. The firewall area provides a great deal of stability. I think he would risk introducing twist into the fuselage if he did not drill this on the jig. He can leave them clecoed until he his ready to drill the cowl mount hinges. Regards, Tom Craig-Stearman RV-4 64ST mounting the throttle quadrant > >Hi listers . A fellow builder has asked me to put this out to the list . >Can the F420 skins be drilled to the flange of the firewall once the >fuselage has been removed from the jig , will the fuselage be stable enough >in this area to permit this ? ________________________________________________________________________________
Subject: New builder question
Date: Feb 01, 1999
I received my rv-6 tailkit a week ago, and I'm still trying to get my shop up to spec so that I can begin building. I live in Orem, Utah, and I was wondering if there is anyone else within a hundred or so miles of me who is building right now, and if you would mind letting me observe your building technique/tools owned so that I might get a better idea of how to go about getting started. Thanks, Carl Nation ________________________________________________________________________________
Date: Feb 01, 1999
Subject: RV-bookstore - 4 new items
Here are 4 new items at RV-ation bookstore and a few sale items of older versions of a few items NEW ITEMS: 1] Aircraft Fuel Metering Systems (carburetors) 2] Best of AMJ Maintenance Tips 3] 43.13B Acceptable Methods [THE NEW EDITION] 4] T-34 Association's Formation Flight Manual (by your request) AIRCRAFT FUEL METERING SYSTEMS (carburetors/fuel injection) A comprehensive guide to the workings and maintenance of aircraft fuel metering systems including theory of operation, parts breakdown, schematics, testing, overhaul, and troubleshooting. 71 pages $12.45 BEST OF AMJ MAINTENANCE TIPS 160 unique shop tools and procedures to make the most frustrating jobs easy. Here is a fully illustrated guide of how to make them or do them, from 15 years of shared experience from AMJ magazine. Why re-invent the wheel? Useful, and fun stuff! 176 pages $13.50 T-34 ASSOCIATION FORMATION FLYING MANUAL Applicable to any aircraft with full visibility from the cockpit. This is a short but well done manual describing military technique of formation procedure and technique. Would you want the guy on your left to be without it? We found this book via the recommendations of several people on the RV list. Thank you. 35 pages $10.95 43.13-1B ACCEPTABLE METHODS OF AIRCRAFT REPAIR The NEW edition is due from the printers in about 1 week. The price is unchanged at $18.95 Discounts on older versions FAR-AIM 1998 - $10.00 (1 left) 43.13 Acceptable Methods; the last edition - $10.00 (2 left) 14 Years of the RV-ator; 1980-1993 - $10.00 (8 left) 16 Years of the RV-ator; 1980-1995 - $12.00 (1 left) please order sale items by phone or e-mail to ensure they are still available - 970-887-2207 Thanks, Andy Gold RV-ation Bookstore 970 887-2207 970 887-2197 fax http://www.rvbookstore.com ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re:
The phone air flow is 864 5764512 i use his fuel injection for mny yars Claudio Purple pasion ________________________________________________________________________________
Subject: Distance Calculator: Really Cool!
Date: Feb 01, 1999
I found a site that is very useful while dreaming how long it will take you to get somewhere in your RV, without getting the charts out.. http://www.indo.com/distance/ It will give you the lattitude/longitude and distance in miles (not statute, but as the crow flies) /nautical miles Check it out.. Paul Besing ________________________________________________________________________________
Date: Feb 01, 1999
In a message dated 1/31/99 11:36:06 PM Central Standard Time, n41va(at)Juno.com writes: << Any skydivers out there? Also, since I have never gone skydiving, and don't plan to unless I have to, can I get some advice on exiting techniques, how long to free fall before activating the chute, etc. etc. >> Von, Get out any way you can, avoid any spinning (prop) or loose parts (the wing that let go at 18G). Arch your back, look for the rip cord (it's probably not where you thought you left it), pull the rip cord, count to five and look over you shoulder you should a big unbrela over your head. There are some rules to remember. 1: pull before the trees start to look big(500 ft if you want any chance) . 2: Buy the man who saved your life (the guy who packed the parachute) a bottle of any thing he wants. Alan Kritzman 300 jumps, wife says I have to stay in the plane now. RV8 ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Ameri-King caveat emptor
I won't bore the list with the bizarre details of my personal tale of woe, but I do feel I should warn anyone considering the purchase of an Ameri-King AK-450 ELT to be certain you get one that never needs warranty repair. The unit, when it works properly, seems to have lots of attractive features. However, their customer service is so poor it almost defies belief. As I write this, I am still pausing to slap my head and exclaim, "Duh!" reflecting on the series of calls and faxes to the service department which ended only minutes ago but has been dragging on for a month. It turns out they are NOT going to charge me $120 to repair a $189 device that is 9 months into a two year warranty period and has been returned twice with the same problem. Isn't that NICE of them. That's not to say they weren't going to try to charge me. Looking back, I am resentful that I let a two-bit piece of electronics ground a forty thousand dollar airplane for six weeks. I am such a tight-wad. Well, perhaps I did make a few local flights without the ELT, and maybe once or twice I thought so hard about carrying a passenger that I may have actually done it. If pressed, I'll use the Clinton defense. If I have any more run-arounds with this company, I shall have to take it up with Aircraft Spruce, from whom I bought the thing in the first place. Now THAT should be interesting... the battle of the customer service departments: who will be the best of the worst?! This is one purchase I would definitely put on a credit card so as to have one more recourse against the manufacturer in the event of a lemon. You have been warned. Now have a good day and get back to driving rivets. -Bill B RV-6A ________________________________________________________________________________
Subject: Web-based RV chat
Date: Feb 01, 1999
In case anyone had poor luck using my web-based RV chat previously, we made several fixes in the Java code which now works with Netscape without problems, Mac or PC. It should be more responsive as well. How about setting up some "common" times to try to meet? http://www.aftershock.org/chat/rv_chat.htm Mitchell Faatz N727MF (reserved) RV-6AQME San Jose, CA Engine mounted... President/Newsletter Editor Bay Area RVators http://www.skybound.com/BARV http://www.aftershock.org/rv.htm ________________________________________________________________________________
Date: Feb 01, 1999
> >Am starting to rig the baffles on my 6A/0360CS and this >trimming-to-cowling business looks really problematic and >time-consuming... > >Anybody out there got a shortcut? I positioned the top cowl 11 5/8 above the bottom cowl and then reached in with a plumb bob attached to a stick and marked the baffles 12 inches down from the bottom of the top cowl. This worked very well. It was easier than expected to locate the top cowl precisely above the bottom cowl and engine baffles. I bent 4 hinge pins with 11 5/8 distance between two stubs 1/2 inch long and bent 90 degrees to form a U shape with a very long (11 and 5/8 ) base. These 4 hinge pins were used as vertical risers by inserting the stubs into top and bottom cowling hinge hoops at each corner. Plumb bobs were hung on each corner of the top cowl. The top cowl was then positioned directly above the bottom half using a long hinge pin that was inserted in a forward hoop of the top cowl and then clamped to the lower cowl hinge near the aft end. This formed a diagonal brace between the bottom and top side hinges. The top cowl was aligned fore and aft using the plumb bobs by lengthening or shortening this diagonal with the clamp. A similar diagonal brace was used at the firewall hinge to aligned the top cowl left and right. I dropped a plumb bob down 12 inches from the bottom of the top cowl and marked every few inches along the baffles. Connecting the dots and trimming to this line gave a 3/8 gap between the baffle and the top cowl. Note, I have the S cowl which is quite light. This may have contributed to the ease of suspending the top cowl on 4 hinge sections above the bottom cowl. Bob Bob Haan bhaan(at)easystreet.com Portland, OR RV6A 24461 Working on Baffles ________________________________________________________________________________
Date: Feb 01, 1999
> Randall/All, > All this talk about compass mounting has me re-thinking my plans. Many > that I talked to this past summer at various fly-ins recommended mounting a > handheld GPS centered and as high as possible in the panel. They then > recommended mounting the compass in the panel off center. I didnt actually > talk to anyone who had done this, just to a lot who wished they had. [snip] I really don't think I'd worry too much about the compass if I were building a VFR only/GPS equipped plane. In that case I would stick it wherever it fits, try to minimize the magnetic interference but not get too carried away with it, and not worry about whether it's close to the middle of my field of view. For IFR, it's another matter. In that case it's still probably going to be what you use to tune your DG and for partial panel work (real or simulated). So in that case I'd still want to make it as accurate and as close to the center of my field of vision as I can make it. Keep in mind you can compensate for a fair amount of error when you swing the compass. It is also possible to de-magnetize steel parts -- Sacramanto Sky Ranch (http://www.sierra.net/skyranch) rents a device to do this. There has been discussion before on this list about using one of those new electronic compasses, with the sensing unit installed remotely, for a kind of high-tech/low-cost remote compass solution. Has anyone come up with a slam-dunk-er for this yet? Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: Misc. Building Tips, hopefully helpful to some
> Alex, > > Is there a drawing or photo of that engine hoist available on the web? > > Steve Soule > Huntington, Vermont Steve, Sorry, no. I do have photos that I could scan at work, and email them to someone who could post them, though. Alex ________________________________________________________________________________
Date: Feb 01, 1999
> << Any > skydivers out there? Also, since I have never gone skydiving, and don't > plan to unless I have to, can I get some advice on exiting techniques, > how long to free fall before activating the chute, etc. etc. >> > Von, I am certainly no expert - I have no sky diving training, so I offer the following as food for thought. I would appreciate comments from those with more experience. I spent a year in France - one of the funnest aircraft I was flying was the CAP 10. The CAP 10 is sort of like a wooden slider RV-6 - very popular in France as an aerobatic trainer. A wonderful aircraft. It handled a lot like an RV, but was much slower. We always flew with a helmet and chute, and the chute had a static line that you clipped to a ring on the shoulder harness. The line was a piece of nylon cord about 50 ft long (as I remember). It was held by an elastic band in such a way that it was kept captive, but would pull out without tangling. The theory was that if you hit your head on the aircraft, the chute would still open even if you were knocked unconscious. I guess the trick is to make sure the static line is long enough so you are well clear of the aircraft when the chute opens, and to have the line arranged so that it does not get tangled and pull the chute prematurely. You do have to remember to unclip the static line from the shoulder harness when getting out after your flight. I had visions of spilling the chute all over the ramp. I don't know how many people actually get knocked unconscious when exiting the aircraft, so this might be too small a risk to worry about. Take care, Kevin Horton RV-8 (fuel tanks) khorton(at)cyberus.ca (613) 821-7862 (home) Ottawa, Canada (613) 952-4319 (work) http://www.cyberus.ca/~khorton/rv8.html ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: Rocket Email List and Website Online!
http://www.matronics.com/subscribe http://www.matronics.com/rocket-list Hey there Rocket men!! Team Rocket now has a Rocket-List, similar to the RV-List, for answering builder questions and for builder support. Thanks to Matt Dralle, also creator of the RV-List, we are now up and going. Thanks Matt!! Pass the word to other Rocket Builders. YOUR TURN IS COMING.... Scott Brown Mark Frederick Team Rocket, LP ________________________________________________________________________________
Subject: Interstates / Runways
Date: Feb 01, 1999
'Listers - although only peripherally related to RVs, I ran into a fella over the weekend that mentioned what sounds like an interesting factoid (CNN-lingo)...he said that when the Interstates were originally designed, every *fifth* mile had to be straight and level enough to land military aircraft. It has a certain Cold War ring of truth, so I was just wondering if this was true, and if so, is it still the case today, when building new interstates? I'm not sure that a crowded interstate would be a good place to land even if it is straight and level, but that's another matter for another day, I guess. Terry in Calgary RV-6 S/N 24414 "Wings, Ailerons, Flaps" http://members.home.net/gannont ________________________________________________________________________________
Subject: Re: Distance Calculator: Really Cool!
Date: Feb 01, 1999
Here another site that will figure distances, plus find airports in between with a max legs with the fuel type you want. http://www.airnav.com/plan/fuel/short.html -----Original Message----- From: Besing, Paul <PBesing(at)pinacor.com> Date: Monday, February 01, 1999 6:01 PM Subject: RV-List: Distance Calculator: Really Cool! > >I found a site that is very useful while dreaming how long it will take you >to get somewhere in your RV, without getting the charts out.. > >http://www.indo.com/distance/ > >It will give you the lattitude/longitude and distance in miles (not statute, >but as the crow flies) /nautical miles > >Check it out.. > >Paul Besing > > ________________________________________________________________________________
Date: Feb 01, 1999
Subject: RV4 wing wanted
Hey Rocket Men and RVers, I am looking for an RV4 wing for sale. If anyone has one or knows of one available, please let me know. Thanks!! Scott ________________________________________________________________________________
From: "Japundza, Bob" <BJapundza(at)ksmconsulting.com>
Subject: baffling advice
Date: Feb 01, 1999
Jim, Having just done the baffles a couple of weeks ago, I do agree that trim lines would save you a little bit of time. I was actually surprised how much material is removed from the baffles. Seems to me Van's makes them extra long. The best way to trim is to have a little perseverance, a pen taped to a stick, and your snips. I think it took me about two hours to do the trimming the conventional way. Bob Japundza RV-6 N244BJ, working on gear leg stiffeners ________________________________________________________________________________
Date: Feb 01, 1999
Paul, Yuo are right - It's Cool. Have added to my bookmarks. Thanks, Chuck Rowbotham RV-8a >From: "Besing, Paul" <PBesing(at)pinacor.com> >To: "'rv-list(at)matronics.com'" >Subject: RV-List: Distance Calculator: Really Cool! >Date: Mon, 1 Feb 1999 16:28:50 -0700 >Reply-To: rv-list(at)matronics.com > > >I found a site that is very useful while dreaming how long it will take you >to get somewhere in your RV, without getting the charts out.. > >http://www.indo.com/distance/ > >It will give you the lattitude/longitude and distance in miles (not statute, >but as the crow flies) /nautical miles > >Check it out.. > >Paul Besing > > > > http://www.matronics.com/contribution > > > ________________________________________________________________________________
Date: Feb 01, 1999
> How far away from other electronic gizmos does the compass need to be for > it to be accurate? That's a tough question. When I hold my compass close to just about any electronic device in my panel, it seems to me about 6-8 inches is what it takes to eliminate _noticable_ error. But all this stuff adds up so you'd have to go further than that to really minimize the errors. Unfortunately, this makes it virtually impossible in my RV-6, with the avionics right in the middle, to get my compass out of range short of putting it way up on the roll bar which also puts it way aft and virtually in my face, and also close to the 4130 steel roll bar. Not to mention blocking the view more than I'd like. Oh and don't forget nut-plates and steel screws holding the panel in (6 slider). The net of it is that there's NO WAY I can get the compass far enough from everything that it is unaffected. I will be flying IFR in my plane so I do care about this, but frankly after trying all possible alternatives, I saw no way short of moving all my avionics and electrical instruments to the bottom of the panel, to keep from getting significant interference from them. So I just punted and put my compass on a pedestal on the glareshield. I'm hoping I can swing the compass to compensate for all this stuff, unless I can find an electronic remote compass solution for a resonable cost. Randall Henderson, RV-6 (engine/finish) Portland, OR http://www.edt.com/homewing randall(at)edt.com > beside my planned location for a micro-encoder and above the comm and > transponder (less than 1" from the micro encoder; 3" above the xpndr). Is > this a problem? If mounted to the other side it ends up beside my AV8 > engine monitor. It also ends up grouped with my engine instruments, not my > flight instruments which is not what I want. If I mount it out of the panel > on the forward canopy frame (RV-4) its directly above the GPS. Is this a > problem? > Ive just cut out the panel this past weekend. You dont really realize what > a tiny thing it is until you start trying to put stuff in it! > > Mike Wills > RV-4 forward fuse details > willsm(at)manta.spawar.navy.mil > > > > > ________________________________________________________________________________
Date: Feb 01, 1999
Mike, On my RV-4, I mounted the compass above the panel, on the canopy frame. It's the perfect place for it, not really in your vision but right there when you want to read it. I used a piece of .063-pop rivited to the underside of the square tube canopy frame with 5 LP4-3's as a shelf. The .063 has to be formed slightly to conform. the compass is a pedastal mount type. I stuck an adhesive backed rubber bumper to the back of the case that bears on the canopy plexi and steadys the whole thing. On a 4,panel space is too precious to waste on a compass. It is unaffected by the electronics just below on the panel. Best regards, Bill, N66WD ________________________________________________________________________________
Date: Feb 01, 1999
-----Original Message----- From: n41va(at)Juno.com <n41va(at)Juno.com> Date: Sunday, January 31, 1999 9:31 PM Subject: RV-List: Need Advice on Parachute > >Listers; >I have located (among others) a Security #160 emergency parachute that is >designed for sailplanes and aerobatic test flying. It is 2" thick, and is >a seat and back pack style. It is limited to use below 150 mph, which I >assume is not a problem, since in a free fall a human doesn't exceed >this, right? This unit has a conventional canopy, and is from the 70's or >80's and has not been re- packed for 10 years, but has been kept inside >the house in a closet during this time. Von, As on old sailplane pilot who spent more than a decade flying around with a Security 150 on my backside, I can tell you that this parachute passes the most important test; comfort. As crazy as it sounds, if the chute is uncomfortable, then wearing it becomes 'a bother' and the chute is home in the closet just when it is needed. Parachutes are like airplanes and engines however. Don't ever buy one without making sure that all AD's have been complied with. There have been some instances where certain chemicals used as Anti-fungal agents used to coat the fibers have been found to reduce the strength of the fabric after extended periods. Just insist that the seller get the chute packed by a certified rigger and any potential problems will surface before you write the check. Jack Noble Seattle RV-8 ________________________________________________________________________________
From: "Daniel H. Morris III" <Morristec(at)icdc.com>
Subject: Re: Interstates / Runways
Date: Feb 01, 1999
I don't know if it's still true but there are sections of certain roads in strategic locations built with this in mind. I have spotted a few. Most notably, no poles or other obstructions, tree lines cut way back, flat, and straight. BTW this is common in western European countries. They close the road and conduct military ops. usually on weekends, just like we have Natl. Guard activities. Dan Morris -----Original Message----- From: Gannon, Terry <Gannont(at)Fracmaster.com> Date: Monday, February 01, 1999 5:07 PM Subject: RV-List: Interstates / Runways > >'Listers - although only peripherally related to RVs, I ran into a fella >over the weekend that mentioned what sounds like an interesting factoid >(CNN-lingo)...he said that when the Interstates were originally designed, >every *fifth* mile had to be straight and level enough to land military >aircraft. > >It has a certain Cold War ring of truth, so I was just wondering if this was >true, and if so, is it still the case today, when building new interstates? >I'm not sure that a crowded interstate would be a good place to land even if >it is straight and level, but that's another matter for another day, I >guess. > >Terry in Calgary >RV-6 S/N 24414 >"Wings, Ailerons, Flaps" >http://members.home.net/gannont > > ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: Used engines
I used a H2AD engine with Ed Sterba 68/76 prop. in my "6." I find it to be a nice combination and I'm happy with the performance and cost. The fuel pump is mounted up front and modification will have to be made to the upper cowling, but it also happens to be probably the coolest place in the engine compartment, lessens the chance of vapor lock. I don't think that Van's offers a baffle kit for it, so unless you can find a use one you'll have to build one from scratch, I did. Gil T. ________________________________________________________________________________
Subject: Self Etching Primers
Date: Feb 01, 1999
In need of an answer about how self etching primers should work. I primed several parts of the 8 horiz stabilizer with Marhyde which had several areas of orange peel,I removed it with lacquer thinner and the alclad was as bright as before. Shouldn't it have etched the alclad,or is this how they are supposed to work? I'm thinking about using the vari-prime or SW. Any thought's Chris Santschi #80881 Festus MO. ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: New 6 Cowling
Hi , Does anyone have weight and balance for a RV-6A with a light 0-320 and wood prop.? I am asking the question because I am ready to order my finishing kit and understand the extra price lighter cowling may lighten the front of the plane too much. No reason to pay more if it is going to put my CG aft of ideal. Thanks, David Ahrens ________________________________________________________________________________
Subject: Attn: RV clubs/pilots
Date: Feb 01, 1999
Contact: John McLaughlin, KCCI-TV, 515-247-8888 johnmc49(at)ecity.net For Immediate Release: Des Moines Media Team Up to Promote Major Aviation Event! The dominant commercial television and FM radio station in Des Moines, Iowa, have joined forces to present the first annual "Wings, Wheels and Water Festival" slated for a specially-built exposition park near the northern Des Moines suburb of Ankeny, Iowa (IKV). KCCI-TV8 and KSTZ-Star 102.5 FM radio have pledged more than $75,000 in promotional announcements and live broadcasts from the event, to be held September 25-26, 1999. KCCI-TV meteorologist John McLaughlin, an instrument-rated pilot and RV-6A builder is developing the aviation aspect of the show. McLaughlin says, "we are going to take every advantage of this unique media partnership to bring new faces into aviation." "Whether people come to attend the concerts provided by the radio station, or see racing and boating exhibits, they are going to be exposed to aviation in ways they have never seen before," notes McLaughlin. The show has booked several jet airshow acts, along with a display of historic aircraft like the EAA Spirit of St. Louis replica. Experimental and ultralight aviation is also being prominently displayed on the 79-acre site. Local fixed base operators are supporting the Wings, Wheels and Water Festival by cooperating in a Learn to Fly Center. Each operator has donated 10 discovery flights and will have computer-based training simulators along with new Cessna and Piper aircraft on display. Aviation journalist and aircraft insurance agent Scott "Sky" Smith is co-organizing the two-day festival. Smith points out that this is a family event, with a carnival, disk golf, hayrack rides and many other activities packaged with a professional airshow, racing cars, motorcycles, boats and other unique vehicles. "If general aviation is to have any future, we have to get young people invigorated about airplanes and flight training through events like this," says Smith. Between the television and radio station, the message will be broadcast to more than 1.2 million people in Iowa with an intense promotional schedule consisting of nearly 1,000 broadcast announcements. McLaughlin and Smith expect the show will attract more than 70,000 people to the site. Those interested in participating in the Wings, Wheels and Water Festival can contact McLaughlin or Smith through www.wingswheelswater.com, or call 515-289-1439. Vendor packages are available for profit and non-profit organizations. Special ticket discounts are available to aircraft clubs and organizations wishing to attend the festival. ________________________________________________________________________________
Date: Feb 01, 1999
Re: Kevin Horton's comments on parachute STATIC LINE. When I was instructing in the turboprop T-34C down at Pensacola, (a non ejection seat aircraft) our parachutes had a static line, which was attached to a stud on the seat frame. As previously discussed, once you are clear of the aircraft in a bailout situation, the chute is opened automatically once your static line is pulled out to full extension, thereby pulling the ripcord. I thought it to be an excellent idea. Besides the "knocked unconscious" scenario, it also made sense, having inexperienced students (read passengers) in the aircraft; in the heat of the battle the D-ring can be hard to find (even for experienced aircrew); you may have injuries (in-flight fire, midair collision, etc) preventing your pulling the handle, etc. Why not make things as simple/foolproof as possible? I once addressed this issue with a dealer of sailplane(primairly) emergency 'chutes who basically poo-pooed the idea, but I suspect it was a case of "not invented here" or it just wasn't available in his product line. But until someone can give me a good reason not to so, I plan on having a static line setup in my -4 (BOTH seats). Doug Seward -4, wings, Seattle area ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: Ameri-King caveat emptor
yes I'll agree, be very careful with Ameri-King. there should be others out there who will honor their 2 year warantees as they are suppose to. As for me , Never again with them.... Phil SportAV8R(at)aol.com wrote: > > I won't bore the list with the bizarre details of my personal tale of woe, but > I do feel I should warn anyone considering the purchase of an Ameri-King > AK-450 ELT to be certain you get one that never needs warranty repair. The > unit, when it works properly, seems to have lots of attractive features. > However, their customer service is so poor it almost defies belief. As I > write this, I am still pausing to slap my head and exclaim, "Duh!" reflecting > on the series of calls and faxes to the service department which ended only > minutes ago but has been dragging on for a month. It turns out they are NOT > going to charge me $120 to repair a $189 device that is 9 months into a two > year warranty period and has been returned twice with the same problem. Isn't > that NICE of them. That's not to say they weren't going to try to charge me. > > Looking back, I am resentful that I let a two-bit piece of electronics ground > a forty thousand dollar airplane for six weeks. I am such a tight-wad. Well, > perhaps I did make a few local flights without the ELT, and maybe once or > twice I thought so hard about carrying a passenger that I may have actually > done it. If pressed, I'll use the Clinton defense. > > If I have any more run-arounds with this company, I shall have to take it up > with Aircraft Spruce, from whom I bought the thing in the first place. Now > THAT should be interesting... the battle of the customer service departments: > who will be the best of the worst?! > > This is one purchase I would definitely put on a credit card so as to have one > more recourse against the manufacturer in the event of a lemon. You have been > warned. Now have a good day and get back to driving rivets. > > -Bill B RV-6A > > Matronics: http://www.matronics.com > RV-List: http://www.matronics.com/rv-list > Archive Search Engine: http://www.matronics.com/search > Archive Browsing: http://www.matronics.com/archives > Other Email Lists: http://www.matronics.com/other ________________________________________________________________________________
Date: Feb 01, 1999
wat is the big deal about charts ask claudio about atrip to sao paulo brazil in a RV4 without any good charts tanks the aopa in1988 ________________________________________________________________________________
Date: Feb 01, 1999
In a message dated 2/1/99 2:41:08 PM Pacific Standard Time, willsm(at)manta.spawar.navy.mil writes: << andall/All, All this talk about compass mounting has me re-thinking my plans. >> ------- Mike, Before installing the compass in my -4, I placed my micro encoder and engine monitor on the bench, put the mag compass between them and powered them up. There was no deviation. These things draw verry little power. Fred LaForge RV-4 35 hrs logged ________________________________________________________________________________
Date: Feb 01, 1999
>Hi folks >This ever happen to you? It seems someone came into my shop and sawed >up the >piece of "scrap" angle to be used for the control mount which sits in >front of >the main bulkhead and bolts to a seat belt attach point. My question >is can I >substitute the scrap of 2x2 1/2 for the sawed up 2x1 1/2. It is 1/16 >inch >thicker. Or is that piece waiting to be used somewhere else? >Heeeellllp. >Thanks >Dennis Clay >#80473 >fuselage a comin > > If the 2 X 2 1/2 is the left over from making the fuel tank fwd support brackets... the remainder that you have shouldn't be needed for anything else, and could be used to make the bracket that you mentioned. The rod end that installs on it should have more than enough adjustment range to allow for the thicker bracket. Your problem will be that the long AN3 bolts that attach the bracket to the F-804 bulkhead assy. will likely be too short. Has your fuse kit shipped yet? If not, then call the office and have them throw a small piece in the box for you. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Date: Feb 01, 1999
>Hi listers . A fellow builder has asked me to put this out to the list >. >Can the F420 skins be drilled to the flange of the firewall once the >fuselage has been removed from the jig , will the fuselage be stable >enough >in this area to permit this ? Many thanks .LLOYD BENTLEY RV 6 WINGS > >RSA > > I think he could do this if he wanted too but I don't recommend it because he will not be able to do a nice job dimpling the skin and firewall flange at the same time. It will also be difficult to do a good job of deburring and getting all of the chips out from between the skin and firewall. He probably wants to do this because the jig is in the way so I will suggest he do the same as is recommended in the RV-8(A) manual. It recommends that the builder drill all of the holes, debur while the skin is off, and dimple the holes in the skin. After the skin is riveted on and the fuse is removed from the jig he can redimple all of the firewall flange holes (now that the jig is out of the way) by dimpling trough the skin holes that are already dimpled. This works very well because the firewall material is so soft. Dimpling the skin and the firewall flange together does not work nearly as well. After the holes are all dimpled the hinges for the cowl attachment can be back drilled through them. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Date: Feb 01, 1999
Subject: Re: Self Etching Primers
When using Marhyde, I still scuff the aluminum with a grey scotch-brite pad. The majority of my project is done with a two-part epoxy. I either use the scotch-brite pad, or acid etch. I don't bother with the alodine. Acid etching is a real easy way to do many parts fast. Unfortunately, I have to wait for summer for the garden hose & the sun. L.Adamson RV6A --- just completed bottom half of fusalage ________________________________________________________________________________
Date: Feb 01, 1999
>Looking back, I am resentful that I let a two-bit piece of electronics >ground >a forty thousand dollar airplane for six weeks. I am such a >tight-wad. Well, >perhaps I did make a few local flights without the ELT, and maybe once >or >twice I thought so hard about carrying a passenger that I may have >actually >done it. If pressed, I'll use the Clinton defense. > > I don't remember the specifics of the FAR's but I am certain that you can legally fly without the ELT. If I remember correctly, you can fly within a 50 mile radius if you have removed the ELT for repairs if the aircraft has been placarded on the panel "ELT removed for repair" Note: You can only do this if the ELT is removed for repair. Taking it out because it doesn't work (without sending it off to be repaired) or the batteries are expired doesn't count. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Date: Feb 01, 1999
Jim; What worked well for me was to mount ONE baffle at a time and then mount the upper cowling, mark and cut a little at a time til it fits right. Von Alexander N41VA(at)juno.com writes: > >Am starting to rig the baffles on my 6A/0360CS and this >trimming-to-cowling business looks really problematic and >time-consuming... > >Anybody out there got a shortcut? Or better yet, some trim line >distances for the CS? The trim info on the drawings is marginally >useful at best. > >Don't wanna re-invent the wheel if I don't have to... > >Jim 6A New Mexico > > > > > > > ________________________________________________________________________________
Date: Feb 01, 1999
As a military pilot for twenty years, I never heard of any USA highways setup to be used as runways. However, in Germany and some other European counties, there are emergency runways to be used in war time (Cold into Hot). There were maybe five to ten in the whole country. It takes a lot more effort to turn a road into a runway which can handle military aircraft than you would think. It is my understanding that the foundation and thickness of the concrete on runways is several TIMES that of normal roads. It was always interesting to drive on one base in Germany as the road into the base was just one example. Besides the normal road markings, there were runway markings too. There were also housings for the emergency barriers used to land aircraft with problems. I did see several others during my time stationed over there. Just because I never heard of it don't make it false, I just don't believe it. Tom Thomas Gummo USAF, Major, Retired Pilot F-4G Wild Weasel mounting tail surfaces on N563FS (for 563rd Fighter Squadron) reserved ________________________________________________________________________________
by phnxpop2.phnx.uswest.net with SMTP; 2 Feb 1999 10":07:45.-0000(at)matronics.com
Date: Feb 03, 1999
Subject: Parachutes
Listers, I have been following this thread with interest, as I have done some skydiving (50 jumps) and know that parachutes will be standard equipment in my RV. There have already been several excellent posts by a few skydivers who are far more experienced than I. The thoughts that I would add are as follows: 1) I would strongly urge every builder who is contemplating parachutes as standard equipment for their aircraft to go to a USPA approved dropzone and take a first jump course. There is nothing that will prepare you better than actually making a parachute jump. IMHO, there are too many aspects involved in making a safe and survivable bailout to be left to chance. One of the other listers has already talked about the importance of achieving a stable body position before opening to reduce the chances of a canopy malfunction. Also knowing how to fly the canopy could make the difference between landing in a clearing or a boulder field. Finally, if you don't know how to land you can be seriously injured or even killed. 2) Most of the emergency parachutes commonly available are round canopies. They are steerable, and have a little bit of forward drive, but NOT MUCH. You also land very hard. I know this from personal experience. The reason most of the emergency chutes have round canopies is because the manufacturers assume (correctly) that your typical pilot has never jumped before and knows nothing about parachutes, and he is less likely to kill himself landing the wrong way under a round canopy. I firmly believe that a modern ram-air square canopy of the type that every skydiver uses is the way to go for an emergency chute, but ONLY if you know how to fly it. These canopies fly 30 mph, you fly a landing pattern just like in an airplane. You can "put the brakes on" at the last moment for a landing that is like stepping off a curb, but again, only if you know how. You can fly a great distance horizontally with a square canopy, giving you a lot more options on where to land. Take the course and learn how to fly it. If there is someone who will be flying with you often (like your spouse) have her take the first jump course too, and talk to her ahead of time about how to get out of the aircraft. In the event of a catastrophic occurrence such as a mid-air or a structural failure, you won't have a chance to discuss it. If you are to have a chance at survival, you and your passenger will just have to know what to do, and be able to do it immediately and automatically. 3) I have given a lot of thought to just how you would safely bail out of an RV. A few years ago at the Phoenix Air Races, one of the racers had to bail out of his burning Sea Fury. He survived, but sustained severe injuries as a result of impacting the horizontal stabilizer as he exited the aircraft. Exiting an RV would appear to present the same hazard. I've thought about how you could prevent this, and frankly I just don't know the answer. I remember reading that Spitfire pilots and ME-109 pilots in WWII would roll the aircraft inverted, pop their seatbelt and simply fall out. Does anybody with some real knowledge about this have an opinion they could offer? George True, Phoenix, AZ RV-8, hopefully starting very soon... ________________________________________________________________________________
Date: Feb 02, 1999
>>If I have any more run-arounds with this company, I shall have to take it up with Aircraft Spruce, from whom I bought the thing in the first place. Now THAT should be interesting... the battle of the customer service departments: who will be the best of the worst?!<< You got that right! I've ended up sending stuff back to ASS because it was junk. I personally believe that ASS is a junk distributor. I don't believe them when they talk about how good their products are and how few problems they've had. I buy very little there, anymore. >>This is one purchase I would definitely put on a credit card so as to have one more recourse against the manufacturer in the event of a lemon. You have been warned. Now have a good day and get back to driving rivets. << Thanks for the warning. Yes, the credit card is our main line of defense. It works for me. Although I haven't had to use it on my project, I have used the charge back feature against another who thought they could get away with things. Personally, I'd box that little ELT right up, call ASS and ask for a RA number, send it back. Use the credit against a better ELT. Fortunately, it looks like I bought a better one because I got the warning on the one you have early enough. Jim Sears in KY RV-6A N198JS (Doing engine controls. Wiring done) ________________________________________________________________________________
Date: Feb 02, 1999
Subject: Re: fuel flow performance
In a message dated 2/1/99 5:18:28 PM Eastern Standard Time, planejoe(at)flnet.com writes: << Does anyone know the phone # of a company called fuel flow performance. Thanks in adv >> Are you sure you don't mean Airflow Performance ? Their number is 864-576-4512 ________________________________________________________________________________
Date: Feb 02, 1999
Ah, but Claudio, remember you were "returning home". Your nose guided you to the best food, your ears to the best music; you didn't need no steenkin' charts. :-) For those who don't know Claudio, his workshop is filled with classical music, even while bucking rivets. As for the food, well, he *is* Brazilian. Claudio, glad to see you posting on the list. Mike Pilla former hangar mate CTonnini(at)aol.com wrote: > > > wat is the big deal about charts ask claudio about atrip to sao paulo brazil > in a RV4 without any good charts tanks the aopa in1988 > ________________________________________________________________________________
Date: Feb 02, 1999
Subject: Re:Parachutes, opening the canopy in flight
Does anyone know if you can get the canopy open in flight? I remember hearing somewhere that there is a high pressure area behind the 8 canopy that keeps it slammed shut. I think at the very least, getting the rear seater out would be impossible. Before I mount my canopy, hopefully sometime before Star Wars episode 10, I intend to take a good hard look at some sort of jettison mechanism. Anyone know how those Nigerian Air Beetles do it? I think getting the canopy free and clear is the first step to a safe departure. I saw a good idea in the Stewart S51. It has a crank that opens and closes the canopy with a chain drive. I think this is a good alternative to a jettison mechanism. It takes longer, but you don't have to worry about holding the thing open while you try to exit. For some first hand accounts of bailouts, look in the NTSB accident reports. Do a search for accidents invoving Pitts or Decathlons or some other aerobatic aircraft. Some of the reports contain first hand accounts written by the pilots. true(at)uswest.net, , , , by, phnxpop2.phnx.uswest.net, with, SMTP;, 2, Feb, 1999, 10:07:45.-0000(at)matronics.com wrote: > > Listers, > I have been following this thread with interest, as I have done > some skydiving (50 jumps) and know that parachutes will be standard > equipment in my RV. There have already been several excellent posts by > a few skydivers who are far more experienced than I. The thoughts that > I would add are as follows: > > 1) I would strongly urge every builder who is contemplating parachutes > as standard equipment for their aircraft to go to a USPA approved > dropzone and take a first jump course. There is nothing that will > prepare you better than actually making a parachute jump. IMHO, there > are too many aspects involved in making a safe and survivable bailout to > be left to chance. One of the other listers has already talked about > the importance of achieving a stable body position before opening to > reduce the chances of a canopy malfunction. Also knowing how to fly the > canopy could make the difference between landing in a clearing or a > boulder field. Finally, if you don't know how to land you can be > seriously injured or even killed. > > 2) Most of the emergency parachutes commonly available are round > canopies. They are steerable, and have a little bit of forward drive, > but NOT MUCH. You also land very hard. I know this from personal > experience. The reason most of the emergency chutes have round canopies > is because the manufacturers assume (correctly) that your typical pilot > has never jumped before and knows nothing about parachutes, and he is > less likely to kill himself landing the wrong way under a round canopy. > I firmly believe that a modern ram-air square canopy of the type that > every skydiver uses is the way to go for an emergency chute, but ONLY if > you know how to fly it. These canopies fly 30 mph, you fly a landing > pattern just like in an airplane. You can "put the brakes on" at the > last moment for a landing that is like stepping off a curb, but again, > only if you know how. You can fly a great distance horizontally with a > square canopy, giving you a lot more options on where to land. Take the > course and learn how to fly it. If there is someone who will be flying > with you often (like your spouse) have her take the first jump course > too, and talk to her ahead of time about how to get out of the > aircraft. In the event of a catastrophic occurrence such as a mid-air > or a structural failure, you won't have a chance to discuss it. If you > are to have a chance at survival, you and your passenger will just have > to know what to do, and be able to do it immediately and automatically. > > 3) I have given a lot of thought to just how you would safely bail out > of an RV. A few years ago at the Phoenix Air Races, one of the racers > had to bail out of his burning Sea Fury. He survived, but sustained > severe injuries as a result of impacting the horizontal stabilizer as he > exited the aircraft. Exiting an RV would appear to present the same > hazard. I've thought about how you could prevent this, and frankly I > just don't know the answer. I remember reading that Spitfire pilots and > ME-109 pilots in WWII would roll the aircraft inverted, pop their > seatbelt and simply fall out. Does anybody with some real knowledge > about this have an opinion they could offer? > > George True, Phoenix, AZ > RV-8, hopefully starting very soon... > -- Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 page at: http://tabshred.com/moe ________________________________________________________________________________
Date: Feb 02, 1999
The Eisenhower Interstate system requires that one mile in every five must be straight. These straight sections are usable as airstrips during wartime emergencies. Paul Besing > >As a military pilot for twenty years, I never heard of any USA highways >setup to be used as runways. However, in Germany and some other European >counties, there are emergency runways to be used in war time (Cold into >Hot). There were maybe five to ten in the whole country. It takes a lot >more effort to turn a road into a runway which can handle military aircraft >than you would think. It is my understanding that the foundation and >thickness of the concrete on runways is several TIMES that of normal roads. >It was always interesting to drive on one base in Germany as the road into >the base was just one example. Besides the normal road markings, there were >runway markings too. There were also housings for the emergency barriers >used to land aircraft with problems. I did see several others during my >time stationed over there. > >Just because I never heard of it don't make it false, I just don't believe >it. > >Tom >Thomas Gummo >USAF, Major, Retired >Pilot F-4G Wild Weasel > >mounting tail surfaces on N563FS (for 563rd Fighter Squadron) reserved > > ________________________________________________________________________________
Date: Feb 02, 1999
> > > In need of an answer about how self etching primers should work. I >primed several parts of the 8 horiz stabilizer with Marhyde which had >several areas of orange peel,I removed it with lacquer thinner and the >alclad was as bright as before. Shouldn't it have etched the alclad,or >is this how they are supposed to work? I'm thinking about using the >vari-prime or SW. Any thought's > >Chris Santschi #80881 >Festus MO. Chris, I primed the entire fuselage on my -8 with Marhyde..with excellent results. I scuffed every part with scotchbrite pad, and then cleaned with acetone. I had no problems with orange-peel. Maybe a more thorough cleaning/scuffing would help? Brian Denk RV8 #379 wiring stuff. ________________________________________________________________________________
Date: Feb 02, 1999
-----Original Message----- From: Blah ba Blah <daviddla(at)juno.com> Date: Tuesday, February 02, 1999 2:30 AM Subject: RV-List: Re: New 6 Cowling > >Hi , Does anyone have weight and balance for a RV-6A with a light 0-320 >and wood prop.? _______ My 6 has a 0-360 and a wood prop and weighs 1050lbs. The CG is within the envelope but the aircraft is tail heavy, especially with low fuel and baggage. I have the heavy starter too. Recently I switched to a Sensenich metal prop resulting in 35lbs added to the nose and a great improvement in pitch stability at low speed. Save the money and use the standard cowling. Martin Sutter N868CM 1,300hrs ________________________________________________________________________________
Date: Feb 02, 1999
Subject: Re: Parachutes
George; Thanks for the excellent advice; I asked my wife if she would consider taking a begining skydiving course; She says she's doing good just to fly with me in the plane, let alone jump out of a perfectly good one! I likewise do not intend to take any actual skydiving courses, but figure that it is better to at least have the option....... I am interested in the static line idea; although there is probably a down side to that. I think it makes sense to just learn as much about it as you can; have a good safe parachute that is properly packed and maintained; and rehearse in your mind exactly what procedure to follow for egress, and teach all this to your flying spouse, etc. Von Alexander N41VA(at)juno.com RV-8(made it to the airport!) phnxpop2.phnx.uswest.net with SMTP; 2 Feb 1999 10":07:45.-0000(at)matronics.com writes: > >Listers, > I have been following this thread with interest, as I have done >some skydiving (50 jumps) and know that parachutes will be standard >equipment in my RV. There have already been several excellent posts >by >a few skydivers who are far more experienced than I. The thoughts >that >I would add are as follows: > >1) I would strongly urge every builder who is contemplating >parachutes >as standard equipment for their aircraft to go to a USPA approved >dropzone and take a first jump course. There is nothing that will >prepare you better than actually making a parachute jump. IMHO, there >are too many aspects involved in making a safe and survivable bailout >to >be left to chance. One of the other listers has already talked about >the importance of achieving a stable body position before opening to >reduce the chances of a canopy malfunction. Also knowing how to fly >the >canopy could make the difference between landing in a clearing or a >boulder field. Finally, if you don't know how to land you can be >seriously injured or even killed. > >2) Most of the emergency parachutes commonly available are round >canopies. They are steerable, and have a little bit of forward drive, >but NOT MUCH. You also land very hard. I know this from personal >experience. The reason most of the emergency chutes have round >canopies >is because the manufacturers assume (correctly) that your typical >pilot >has never jumped before and knows nothing about parachutes, and he is >less likely to kill himself landing the wrong way under a round >canopy. >I firmly believe that a modern ram-air square canopy of the type that >every skydiver uses is the way to go for an emergency chute, but ONLY >if >you know how to fly it. These canopies fly 30 mph, you fly a landing >pattern just like in an airplane. You can "put the brakes on" at the >last moment for a landing that is like stepping off a curb, but again, >only if you know how. You can fly a great distance horizontally with >a >square canopy, giving you a lot more options on where to land. Take >the >course and learn how to fly it. If there is someone who will be >flying >with you often (like your spouse) have her take the first jump course >too, and talk to her ahead of time about how to get out of the >aircraft. In the event of a catastrophic occurrence such as a mid-air >or a structural failure, you won't have a chance to discuss it. If >you >are to have a chance at survival, you and your passenger will just >have >to know what to do, and be able to do it immediately and >automatically. > >3) I have given a lot of thought to just how you would safely bail >out >of an RV. A few years ago at the Phoenix Air Races, one of the racers >had to bail out of his burning Sea Fury. He survived, but sustained >severe injuries as a result of impacting the horizontal stabilizer as >he >exited the aircraft. Exiting an RV would appear to present the same >h ________________________________________________________________________________
Date: Feb 02, 1999
Subject: Re: Parachutes, opening the canopy in flight
Moe; After getting an idea and checking with Scott McDaniels, I will pass this on; For you RV-8 drivers only; use a pair of the 3/16" cotterless hitch pins(instead of the called for AN-3 bolts) in the front of the canopy where the frame attaches to the rollers. These hitch pins have rings on them; face the rings back towards the pilot. In an emergency, undo the latch, pull both pins, and give the canopy a good shove upward into the slipstream. At this point only the small nylon slider block is holding the canopy in the back, and will break off as the canopy (hopefully) goes up and back over the tail. Von Alexander N41VA(at)juno.com writes: > > >Does anyone know if you can get the canopy open in flight? I remember >hearing somewhere that there is a high pressure >area behind the 8 canopy that keeps it slammed shut. I think at the >very least, getting the rear seater out would be >impossible. Before I mount my canopy, hopefully sometime before Star >Wars episode 10, I intend to take a good hard >look at some sort of jettison mechanism. Anyone know how those >Nigerian Air Beetles do it? I think getting the canopy >free and clear is the first step to a safe departure. I saw a good >idea in the Stewart S51. It has a crank that opens >and closes the canopy with a chain drive. I think this is a good >alternative to a jettison mechanism. It takes >longer, but you don't have to worry about holding the thing open while >you try to exit. For some first hand accounts >of bailouts, look in the NTSB accident reports. Do a search for >accidents invoving Pitts or Decathlons or some other >aerobatic aircraft. Some of the reports contain first hand accounts >written by the pilots. > >true(at)uswest.net, , , , by, phnxpop2.phnx.uswest.net, with, SMTP;, 2, >Feb, 1999, 10:07:45.-0000(at)matronics.com wrote: > >> >> Listers, >> I have been following this thread with interest, as I have done >> some skydiving (50 jumps) and know that parachutes will be standard >> equipment in my RV. There have already been several excellent posts >by >> a few skydivers who are far more experienced than I. The thoughts >that >> I would add are as follows: >> >> 1) I would strongly urge every builder who is contemplating >parachutes >> as standard equipment for their aircraft to go to a USPA approved >> dropzone and take a first jump course. There is nothing that will >> prepare you better than actually making a parachute jump. IMHO, >there >> are too many aspects involved in making a safe and survivable >bailout to >> be left to chance. One of the other listers has already talked >about >> the importance of achieving a stable body position before opening to >> reduce the chances of a canopy malfunction. Also knowing how to fly >the >> canopy could make the difference between landing in a clearing or a >> boulder field. Finally, if you don't know how to land you can be >> seriously injured or even killed. >> >> 2) Most of the emergency parachutes commonly available are round >> canopies. They are steerable, and have a little bit of forward >drive, >> but NOT MUCH. You also land very hard. I know this from personal >> experience. The reason most of the emergency chutes have round >canopies >> is because the manufacturers assume (correctly) that your typical >pilot >> has never jumped before and knows nothing about parachutes, and he >is >> less likely to kill himself landing the wrong way under a round >canopy. >> I firmly believe that a modern ram-air square canopy of the type >that >> every skydiver uses is the way to go for an emergency chute, but >ONLY if >> you know how to fly it. These canopies fly 30 mph, you fly a >landing >> pattern just like in an airplane. You can "put the brakes on" at >the >> last moment for a landing that is like stepping off a curb, but >again, >> only if you know how. You can fly a great distance horizontally >with a >> square canopy, giving you a lot more options on where to land. Take >the >> course and learn how to fly it. If there is someone who will be >flying >> with you often (like your spouse) have her take the first jump >course >> too, and talk to her ahead of time about how to get out of the >> aircraft. In the event of a catastrophic occurrence such as a >mid-air >> or a structural failure, you won't have a chance to discuss it. If >you >> are to have a chance at survival, you and your passenger will just >have >> to know what to do, and be able to do it immediately and >automatically. >> >> 3) I have given a lot of thought to just how you would safely bail >out >> of an RV. A few years ago at the Phoenix Air Races, one of the >racers >> had to bail out of his burning Sea Fury. He survived, but sustained >> severe injuries as a result of impacting the horizontal stabilizer >as he >> exited the aircraft. Exiting an RV would appear to present the same >> hazard. I've thought about how you could prevent this, and frankly >I >> just don't know the answer. I remember reading that Spitfire pilots >and >> ME-109 pilots in WWII would roll the aircraft inverted, pop their >> seatbelt and simply fall out. Does anybody with some real knowledge >> about this have an opinion they could offer? >> >> George True, Phoenix, AZ >> RV-8, hopefully starting very soon... >> > > >-- >Moe Colontonio >moejoe(at)bellatlantic.net >Check out my RV-8 page at: >http://tabshred.com/moe > > > > > > > azard. I've thought about how you could prevent this, and frankly I >just don't know the answer. I remember reading that Spitfire pilots >and >ME-109 pilots in WWII would roll the aircraft inverted, pop their >seatbelt and simply fall out. Does anybody with some real knowledge >about this have an opinion they could offer? > >George True, Phoenix, AZ >RV-8, hopefully starting very soon... > > > > > > > ________________________________________________________________________________
Date: Feb 02, 1999
Brian Denk wrote: > I primed the entire fuselage on my -8 with Marhyde..with excellent > results. I scuffed every part with scotchbrite pad, and then cleaned > with acetone. I had no problems with orange-peel. Maybe a more thorough > cleaning/scuffing would help? > > Brian Denk > RV8 #379 > wiring stuff. I had much the same results. Marhyde seems to adhere well if the part is cleaned. I got lazy towards the end of my project because I didn't have any peeling at all. I didn't clean and prep the rear canopy frame/bow on my tip up and sprayed it in Marhyde. You guessed it, I get flecks of grey paint settling on myself and passengers hair. Matches my grey hair perfectly and is virtually invisible. Doesn't look as good on my wife or the airplane. The only fix is to carefully strip clean and repaint trying to avoid the plexi:( -- Terry Jantzi Kitchener ON RV-6 C-GZRV <http://netrover.com/~tjantzi/terry/> ________________________________________________________________________________
Date: Feb 02, 1999
Subject: Re: Baffle Advice Needed
I just finished trimming the baffles on my RV6 last night. The process is very simple: 1) Set the top cowl into place. 2) Crawl around on floor of shop and see where baffles interfere with cowl. 3) Mark offending areas with Sharpie. 4) Remove cowl. 5) Trim baffles about 1/8" with snips. 6) Repeat steps 1-5 at least thirty times. The whole process only took about two hours. You can also reach under the cowl to feel where the baffles and cowl are touching. It is somewhat tedious, but nothing an RV builder can't handle! Sam Buchanan "The RV Journal" http://www.ath.tis.net/~sbuc/rv6 n41va(at)Juno.com wrote: > > > Jim; > What worked well for me was to mount ONE baffle at a time and then mount > the upper cowling, mark and cut a little at a time til it fits right. > Von Alexander > N41VA(at)juno.com > > writes: > > > >Am starting to rig the baffles on my 6A/0360CS and this > >trimming-to-cowling business looks really problematic and > >time-consuming... > > > >Anybody out there got a shortcut? Or better yet, some trim line > >distances for the CS? The trim info on the drawings is marginally > >useful at best. > > > >Don't wanna re-invent the wheel if I don't have to... > > > >Jim 6A New Mexico ________________________________________________________________________________
Date: Feb 02, 1999
<< For you RV-8 drivers only; use a pair of the 3/16" cotterless hitch pins(instead of the called for AN-3 bolts) in the front of the canopy where the frame attaches to the rollers. These hitch pins have rings on them; face the rings back towards the pilot. In an emergency, undo the latch, pull both pins, and give the canopy a good shove upward into the slipstream. At this point only the small nylon slider block is holding the canopy in the back, and will break off as the canopy (hopefully) goes up and back over the tail. >> A very good suggestion! This will apply to the Rocket, also, as the canopy works in a very similiar manner. I would also suggest slicing the slide block from the upper edge thru to the holes drilled for the attach bolt This will not affect the canopy in its normal operation (the rear pin will hold the thing closed in flight - no strain on the block in normal operations) but it will allow the canopy to tear away without taking any other parts with it (spine track). I suppose it is possible that the thing would stay attached for a few seconds before it breaks free - I don't think I'd like this... Be sure to tell the GIB to duck before you pull those pins! Check six! Mark ________________________________________________________________________________
Date: Feb 02, 1999
Subject: Firewall FWD hose drawing
RV-listers, I have placed a 'zipped' copy of Bill Benedict's FWF Hoses/fittings drawing (in AutoCAD .dwg format) on my web site at: http//www.flash.net/~gila/ ...it is hiding behind the green RV-6A icon. This drawing (published in a previous RVator) is useful for hose and fitting planning purposes as well as for documentation. Just modify the generic layout to fit your specific plane. Thank you Bill for the drawing. Gil (a good way to plan hoses) Alexander RV-6A, #20701 .... tip up canopy latch ------------------------------------------------------- mailto:gila(at)flash.net Gil Alexander, Los Angeles, CA ________________________________________________________________________________
Subject: Re: RV-bookstore - 4 new items
Date: Feb 02, 1999
-----Original Message----- From: winterland(at)rkymtnhi.com <winterland(at)rkymtnhi.com> Date: Monday, February 01, 1999 1:39 PM Subject: RV-List: RV-bookstore - 4 new items > >Here are 4 new items at RV-ation bookstore >and a few sale items of older versions of a few items > >NEW ITEMS: >1] Aircraft Fuel Metering Systems (carburetors) >2] Best of AMJ Maintenance Tips >3] 43.13B Acceptable Methods [THE NEW EDITION] >4] T-34 Association's Formation Flight Manual (by your request) > Andy- I would like to order the first three on this list. I tried earlier to email you, but maybe you did not get the order. Please use my previous VISA card if you still have the record for it. If not, let me know how to get it to you via phone or a secure method on the net. Gar Pessel, Fairbanks, AK ________________________________________________________________________________
Date: Feb 02, 1999
Subject: Prop gov oil line
Hello all, I just mounted my 0-360 last night (way too cool) and have a couple questions I didn't find in the archives. I'll be using a FP prop and know about the removal (and replacement) of the front plug to pierce the aft plug for oil drainback. Eventually I'll want to upgrade to a CS prop, so.... 1. Why does one have to remove the steel line from the gov pad to the front of the engine? Does it really flow a lot of oil without the gov, and since there is a drainback hole, does it matter? Can it stay in place? 2. When I want to upgrade, how do you replace that little plug that I just put a hole in? Enquiring minds want to know. Thanks in Advance, Laird #22923 SoCal (after the canopy, how bad can those baffles be?) ________________________________________________________________________________
Date: Feb 02, 1999
> >I found a site that is very useful while dreaming how long it will take you >to get somewhere in your RV, without getting the charts out.. > >http://www.indo.com/distance/ > >It will give you the lattitude/longitude and distance in miles (not statute, >but as the crow flies) /nautical miles But it won't accept airport identifiers. GTE DUATS (telnet:duats.gtefsd.com) has a free flight planning mode that will calculate fuel burn, affect of winds aloft, etc. You get to specify type of routing; e.g. airway, VOR direct, great circle GPS/LORAN, great circle RNAV, etc. Not only that, once it calculates your path it will then automatically use the info to file a flight plan and give you a weather brief. Good stuff. If you want to calculate your own great circle routes the formulae are pretty straightforward. I have them in BASIC, Excel spreadsheet, and paper form for entry into programmable calculators. If there is interest I will post the formulae. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6399 - voice +1.530.676.3442 - fax O- ________________________________________________________________________________
Date: Feb 02, 1999
Subject: Re: Various Compass notes
>On my RV-4, I mounted the compass above the panel, on the canopy frame..... In designing my panel, I wanted everything in the panel. I worry about having something (an instrument) sticking up in a place where my face could poke into it in the event of the "unexpected". I have, however, seen a lot of -4s with the compass in the 'gunsight' position. My compass is in the panel, right upper corner and is accurate. I have seen wild variations between compasses and wonder how much they vary from instrument to instrument. I have one in the Cub that I have never touched to adjust and is pretty much right on regardless of what direction it is flying. Unusual. It is above the panel, gunsight position but is a LONG way from face. With the other instruments we have access to (GPS) I find I don't refer to the compass as much anyway. I have always used it as a relative reference. I establish my course with the GPS, confirm it by the map on my knee and look to see what the compass is showing and just hold that compass heading, whatever it might be. I mostly refer to the map and the GPS now. I have never done a cross-country using ONLY the compass for reference, just striking out on a heading; it is always in conjunction with a map (the good old days) or a map and GPS. I don't think we use the compass as a true direction finder, but it should still be as accurate as we can get it. (When was the last time I looked at the compass correction card and adjusted a heading using that information?) However, when ATC asks us to fly a certain heading, it is nice to head in sort of the right direction. I do use it for that, but still finetune with the GPS. I don't have a DG (weight, complexity). How to swing a compass in 'in flight' conditions (this is easy 'out west'): go up on a no-wind day and fly the section lines, adjusting your compass as described in the other posts. They are north/south east/west like nothing else and everything is working like it would be in normal flight (!). Problem is finding a no-wind day. You can also adjust it according to your GPS readout, which may be even easier. These Chinook winds are driving me nuts. I want to get out and FLY! Just some thoughts... Michael RV-4 N232 Suzie Q Year Two, off to a slow start..... ________________________________________________________________________________
Date: Feb 02, 1999
Subject: Prestolite alternator wiring
Hi all! Got a question for you been there done that group. I have a prestolite alternator or generator or whatever. It was out of a cherokee and I assume it is 60/65 amps. I need to wire this to the adjustable voltage regulator that Vans sells but he only shows the drawing for his alternator. There are 3 terminals on the back of the alternator. The mail battery feed is obvious (12 oclock position)). I think the small terminal is the field (3 oclock position). Whats the bottom one for located at the 6 o'clock position??? I think it was labled "aux" but I dont have the alternator here at work. This is the last task I need to finish before N97WK will become a living breathing creature and would hate to smoke its chances at a good life. Thanks in advance! Pat Kirkpatrick More than just email--Get your FREE Netscape WebMail account today at http://home.netscape.com/netcenter/mail ________________________________________________________________________________
Date: Feb 02, 1999
Subject: RV6 tail kit needed
If there is anyone out there that has an RV6 tailkit for sale, please email me. Prefer one that is not built, however partially built is ok. Scott ________________________________________________________________________________
Subject: Re: RV6 tail kit needed
Date: Feb 02, 1999
---------- > From: FLARV8N(at)aol.com > To: rv-list(at)matronics.com > Subject: RV-List: RV6 tail kit needed > Date: Tuesday, February 02, 1999 2:25 PM > > > If there is anyone out there that has an RV6 tailkit for sale, please email > me. Prefer one that is not built, however partially built is ok. > > Scott Scott, I have an RV-6 tail kit ( undrilled ) I put up the jig, built the horizontal spar ( 2nd time builder ) and quit. I have the elect. trim option to go with it. $900.00 firm JimNolan(at)kconline.com ________________________________________________________________________________
Subject: Etching For Paint
Date: Feb 02, 1999
You shouldnt scuff the aluminum as it is coated to prevent corroson the etch of the acid in the prep is enough to make the paint stick Boeing doesnt scuff the parts that are painted. Most of the problem with paint sticking is with the prep and not touching the surface with your hand as it has oil that will transfer to the surface and the paint will not stick. I painted airplanes for a living and never scuffed them to make the paint stick. If you think about factory AC they are sometimes stripped and buffed to a high shine you will not do this after scuffing as the alclad of the surface has been damaged by scuffing. ________________________________________________________________________________
Date: Feb 02, 1999
Subject: Re: Etching For Paint
> I >painted airplanes for a living and never scuffed them to make the paint >stick. Boyd, For spraying the exterior of my RV, I had planned on roughing the surfaces as stated in the paint manufacturers instructions. As I recall this was not merely a recommendation. The wording in the data sheet was something like, " When applying to aluminum the surface MUST be sanded (I think it said 220 grit), etched, alodined and primed for proper adhesion." This is for PPG DP48 epoxy primer and Concept finish coat. So can you explain in detail the steps you recommend for proper prep in a home shop environment? And what paint systems do you use? The last thing I want to do is to spend huge $ on paint supplies, ignore the manufacturers instructions and end up with my paint peeling off the airplane a couple of years after painting it. Mike Wills RV-4 fuse out of the jig willsm(at)manta.spawar.navy.mil ________________________________________________________________________________
Subject: Metal dings & repair
Date: Feb 02, 1999
Dropped a bucking bar on your nice aileron or elevator ? I had a fuel tank all finished except for the rear baffle when I stood it on end to slather some rivet tails, when it fell over onto a concrete floor like a tree in the forest. Bang. I nearly S*** my drawers. Can you imagine building up a new tank and matching all the holes in the spar etc.. ? There was a dent in the leading edge right at the cusp. What I did was, get a piece of 2x4, round the nose of it (flat side top and bottom) and reach into the tank with it and press and roll the metal back. You can't have any edges or corners or it will transfer these to the damage you already have. If space is too restricted, try a piece of hardwood, rounded, and work the dent the same way. you may try the handle of a hammer (rounded) or whatever works. If you gently rub the area with a piece of steel (gently), this will cause the area to shine that you may see it better when you want to hold a rounded piece of steel, such as the nose bucking bar that Avery sells, against the dent, and then use a plastic hammer to gently tap, tap the damage on the outside. It wont be perfect, but it will be much better than before and you can fill with Bondo or whatever filler you want. My dent is now so faint, (before any filling), that I have to look for the ding that was there. Remember that you can only tap metal against metal so much and you will begin to stretch it ...could end up with an oil canning spot especially in the very thin skins. Try it, it worked for me. ________________________________________________________________________________
Subject: Re: Prop gov oil line
Date: Feb 02, 1999
I upgraded to a constant speed prop. Its very hard to get that plug out, and you can easily damage your engine. I paid an AP to get my plug out, and he had a very hard time, and could have easily damaged the engine. You need to take a punch with a hook on the end of it and pull the plug out ( which is next to impossible ), or deform the plug enough in the middle with a punch, that it can be pulled out easier. Anyway you look at it, you can get metal particles in the crank that you won't be able to get to, or you can damage the spray bar in front of the plug. Good luck ... Scott Johnson -----Original Message----- From: Owens <owens(at)Aerovironment.com> Date: Tuesday, February 02, 1999 7:01 PM Subject: RV-List: Prop gov oil line > >Hello all, >I just mounted my 0-360 last night (way too cool) and have a couple questions I didn't find in the archives. I'll be using a FP prop and know about the removal (and replacement) of the front plug to pierce the aft plug for oil drainback. Eventually I'll want to upgrade to a CS prop, so.... > >1. Why does one have to remove the steel line from the gov pad to the front of the engine? Does it really flow a lot of oil without the gov, and since there is a drainback hole, does it matter? Can it stay in place? > >2. When I want to upgrade, how do you replace that little plug that I just put a hole in? > >Enquiring minds want to know. > >Thanks in Advance, >Laird #22923 >SoCal (after the canopy, how bad can those baffles be?) > > ________________________________________________________________________________
Date: Feb 02, 1999
Subject: Firewall FWD hose drawing - CORRECTED
SORRY - missing colon in address - should be http://www.flash.net/~gila/ RV-listers, I have placed a 'zipped' copy of Bill Benedict's FWF Hoses/fittings drawing (in AutoCAD .dwg format) on my web site at: http//www.flash.net/~gila/ ...it is hiding behind the green RV-6A icon. This drawing (published in a previous RVator) is useful for hose and fitting planning purposes as well as for documentation. Just modify the generic layout to fit your specific plane. Thank you Bill for the drawing. Gil (a good way to plan hoses) Alexander RV-6A, #20701 .... tip up canopy latch ------------------------------------------------------- mailto:gila(at)flash.net Gil Alexander, Los Angeles, CA ------------------------------------------------------- mailto:gila(at)flash.net Gil Alexander, Los Angeles, CA ________________________________________________________________________________
Subject: Stabilized compasses
Date: Feb 02, 1999
Several people have expressed an interest in a stabilized compass system @ reasonable cost (whatever that is). I'd like to conduct a survey about compasses. The technology is available at now lowering prices, and with a digital display I could produce a system for about $1200. This is down from previous cost over $2500. My gut feeling that this is still expensive for most of us. It would replace the Mag. compass and a DG. The capability would also be there to output pitch and roll as well, but a display might be another thing. The unit would be self contained and panel mounted in a 2-1/4" hole. What do you think? Would you buy it for this price ($1200)? If not, what is a reasonable price? Is a digital display (numeric) adequate for your use? LED or LCD display? PLEASE REPLY OFF THE LIST! I'll summarize the results if anyone responds. Thanks, Dan Morris Morris Technologies, Inc. RV-6 ________________________________________________________________________________
Date: Feb 02, 1999
Subject: Aeroquip 701 hose
Fellow builders, What is the difference in Aeroquip 701 and Aeroquip 601 hose? Vans sells the 701 and Wicks has fittings for the 701 but only lists the 601 in the cataloge. Are these hoses the same? Gary Zilik RV-6A s/n 22993 ________________________________________________________________________________
Date: Feb 03, 1999
Subject: Emergency Radio Jacks
My flightcom intercom shows an extra set of jacks that hook up directly to the radio in the event of intercom failure. I don't remember ever seeing these on other RV,s. Has anyone had an intercom failure that made it impossible to xmit/receive on the radio? Does this seem like a reasonable precaution or overkill? Dave Beizer RV6A panel ________________________________________________________________________________
Date: Feb 03, 1999
And all these years, all this time, I've been led to believe that the interstates are built straight as much as possible because it's cheaper that way (and quicker to travel). Little did I know that, but for an act of Congress, the highways would have been built in zig zaggs. Good thing Congress stepped in and forced them to make them straight. If you were to ask me, I'd say you're all a bunch of goof balls. > I've heard the same thing regarding using every fifth mile for runway > purposes. The system was patterned off the German Autobon (sp?). Here in > the midwest, you could do better than that. Don't know if that is still > the practice or not. > > Using the crowded hiway for a rundway would not be a good idea on a > normal day, in my opinion. However, in the event of a national > emergency, rest assured that the army would close down the interstate > hiway system, while rounding up all the registered guns. > > martin shorman > ________________________________________________________________________________
Date: Feb 03, 1999
Subject: Wd-609
I'm about to mount mount my Wd-609 tail wheel assembly bracket between F611A and F612 and was wondering about priming and painting the inside of the bracket where U-602 the tail wheel arm inserts. For that matter should the end of U-602 be primed and painted also. This looks like a closely machined surface that just fits into the Wd-609 bracket. What have others done?....Thanks Fran Malczynski Olcott, NY RV6 (fuselage) ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <stuckle(at)ifc.utc.com>
Date: Feb 03, 1999
Daniel, YES.... Especially if it had pitch and roll data available that could be used in the design of a three axis autopilot! Fred Stucklen N925RV RV-6A E. Windsor, Ct > -----Original Message----- > From: Daniel H. Morris III [SMTP:Morristec(at)icdc.com] > Sent: Wednesday, February 03, 1999 2:05 AM > To: RV-List(at)matronics.com > Subject: RV-List: Stabilized compasses > > > Several people have expressed an interest in a stabilized compass system @ > reasonable cost (whatever that is). I'd like to conduct a survey about > compasses. The technology is available at now lowering prices, and with a > digital display I could produce a system for about $1200. This is down > from > previous cost over $2500. My gut feeling that this is still expensive for > most of us. It would replace the Mag. compass and a DG. The capability > would also be there to output pitch and roll as well, but a display might > be > another thing. The unit would be self contained and panel mounted in a > 2-1/4" hole. > > What do you think? > > Would you buy it for this price ($1200)? > > If not, what is a reasonable price? > > Is a digital display (numeric) adequate for your use? > > LED or LCD display? > > PLEASE REPLY OFF THE LIST! I'll summarize the results if anyone responds. > > Thanks, > > Dan Morris > Morris Technologies, Inc. > RV-6 > > > > > > - > > - > > - > ________________________________________________________________________________
Date: Feb 03, 1999
Subject: Fwd: elev horn misalignment
The only way this can happen is if your hinge brackets and center bearing are not perfectly aligned. Even if you had an elevator that was warped or twisted the point on the elevator horn that corresponds to the hole in the center bearing would be stationary when the elevator is swung (as long as the hinge points are all aligned). The fact that one of your horn assemblies is higher than the other should also have no effect (a single fixed point should still be stationary for the bolt hole to be drilled into). It may not be as bad as you think. The elevator does have some weight to it which will cause it to sag when only supported by the 2 outer bearings. This alone can cause it to move around some when the elevator is rotated on the hinge axis. If you push up and down lightly on the root end of the elevator you will see that you can move it up and down quite a bit. I would first double double check the hinge line with a string to be sure nothing is grossly out of alignment. If it is pretty close then go ahead and drill the hole for the center bearing (try and support the elevator very lightly when you do so to be sure it is not hanging slightly). Then remount the elevator with a bolt at the inner and the outer bearings. If you are then able to get a bolt in the center bearing with only slight pressure on the elevator to get the holes aligned, you don't have a problem (you may need to adjust the center bearing slightly if the alignment is off for. and aft.). If it requires more than just slight pressure, but you can still get the bolt in, you should still be ok. It is unlikely that you would ever feel any extra friction in the elevator control, but what can happen is that the bearing can have very accelerated wear because of the sid load induced on it. For this same reason you should bend/adjust the hinge brackets as required so that the elevator bearings slip nicely between them, to prevent any lateral side loads also. In fact you should choose spacer washers and bushing lengths carefully on the aileron bearings to prevent loading them laterally for the same reason. Hope this helps (feel free to post this back to the list if you think it would be of interest) Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. >Hi Scott. Today I mounted my left elevator to the HS, and I used a >drill bit >through the center bearing to make a small mark on the horn, then >rotated >the elevator through it's full range of motion. Well, the mark does >not stay >centered. -- Moe Colontonio moejoe(at)bellatlantic.net Check out my RV-8 page at: http://tabshred.com/moe From: smcdaniels(at)juno.com Subject: Re: elev horn misalignment Date: Mon, 01 Feb 1999 23:00:43 EST >Hi Scott. Today I mounted my left elevator to the HS, and I used a >drill bit >through the center bearing to make a small mark on the horn, then >rotated >the elevator through it's full range of motion. Well, the mark does >not stay >centered. It drifts maybe 1/8" or less. Adjusting the rod end bearings >didn't help, so I'm guessing the misalignment is in the vertical >plane. Any >ideas on fixing this? Should I fix it? I don't want to chance the >elevators >binding. If you look at both elevators mounted together, the left horn >is >obviously higher then the right horn. > The only way this can happen is if your hinge brackets and center bearing are not perfectly aligned. Even if you had an elevator that was warped or twisted the point on the elevator horn that corresponds to the hole in the center bearing would be stationary when the elevator is swung (as long as the hinge points are all aligned). The fact that one of your horn assemblies is higher than the other should also have no effect (a single fixed point should still be stationary for the bolt hole to be drilled into). It may not be as bad as you think. The elevator does have some weight to it which will cause it to sag when only supported by the 2 outer bearings. This alone can cause it to move around some when the elevator is rotated on the hinge axis. If you push up and down lightly on the root end of the elevator you will see that you can move it up and down quite a bit. I would first double double check the hinge line with a string to be sure nothing is grossly out of alignment. If it is pretty close then go ahead and drill the hole for the center bearing (try and support the elevator very lightly when you do so to be sure it is not hanging slightly). Then remount the elevator with a bolt at the inner and the outer bearings. If you are then able to get a bolt in the center bearing with only slight pressure on the elevator to get the holes aligned, you don't have a problem (you may need to adjust the center bearing slightly if the alignment is off for. and aft.). If it requires more than just slight pressure, but you can still get the bolt in, you should still be ok. It is unlikely that you would ever feel any extra friction in the elevator control, but what can happen is that the bearing can have very accelerated wear because of the sid load induced on it. For this same reason you should bend/adjust the hinge brackets as required so that the elevator bearings slip nicely between them, to prevent any lateral side loads also. In fact you should choose spacer washers and bushing lengths carefully on the aileron bearings to prevent loading them laterally for the same reason. Hope this helps (feel free to post this back to the list if you think it would be of interest) Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Date: Feb 03, 1999
Subject: Re: Interstates / Runways
---Adrian Chick wrote: > > And all these years, all this time, I've been led to believe that the interstates are built > straight as much as possible because it's cheaper that way (and quicker to travel). Little did > I know that, but for an act of Congress, the highways would have been built in zig zaggs. Good > thing Congress stepped in and forced them to make them straight. If you were to ask me, I'd say > you're all a bunch of goof balls. Smile when you say that, fella! :) Mike Thompson Austin, TX -6 N140RV (Reserved) Hangin' wing ribs ________________________________________________________________________________
Date: Feb 03, 1999
Building highways deliberately so that they can double as airstrips is common practice around the world. They are usually very easy to see from the air(in other countries at least). The highway is usually wider and there might be support facilities around. I doubt that 1 out every 5 miles of american highway serves as an emergency airstrip. I do not find it hard to belive that the Air Force has identified certain areas of highway that could be quickly be converted to makeshift airfields in case their primary bases get destroyed. ________________________________________________________________________________
From: "Glenn Hoskins" <Imagine21_glenn(at)email.msn.com>
Subject: Re: Aeroquip 701 hose
Date: Feb 03, 1999
I had the same question when I ordered 701 hose and 816 fittings. They are the correct combination. -----Original Message----- From: Gary Zilik <zilik(at)bewellnet.com> Date: Tuesday, February 02, 1999 10:38 PM Subject: RV-List: Aeroquip 701 hose > >Fellow builders, > >What is the difference in Aeroquip 701 and Aeroquip 601 hose? Vans >sells the 701 and Wicks has fittings for the 701 but only lists the >601 in the cataloge. Are these hoses the same? > >Gary Zilik >RV-6A s/n 22993 > > ________________________________________________________________________________
Date: Feb 03, 1999
Subject: Re: RV4 wing wanted
>I am looking for an RV4 wing for sale. If anyone has one or knows of one >available, please let me know. Thanks!! > >Scott Scott, My friend, Art Chard, has two RV4 wings for sale, right and left. Art worked at Van's for several years and is a master craftsman. I don't imagine he'd want to sell just one but your post jogged my memory and I thought maybe someone on the list might be able to speed up their progress by buying Art's wings. Anyone interested can contact Art at: 406-777-0941 (Montana number) Bob Skinner RV-6 460 hrs. Buffalo, WY bskinr(at)trib.com ________________________________________________________________________________
Subject: Swinging a compass
Date: Feb 03, 1999
This may generate some disagreement, but when I wanted to "calibrate" my whiskey compass (to get data for the "correction card") I used my GPS. I flew on 360-degrees magnetic and got stable. Noted whiskey compass: difference is compass error. I did this every 30-degrees around the full circle. Was lucky in that no error exceeded the allowable whiskey error. Comments? RV-6A flying Salida, CO ________________________________________________________________________________
Date: Feb 03, 1999
Subject: Re: Wd-609
About painting the tail wheel assembly. I stuffed a rag into the weldment and masked the contact surface of the shaft. I did paint the end of the shaft but when the time comes, a healthy coat of a lube may be all that is needed. Tom Barnes -6 fuse. -----Original Message----- From: Fran Malczynski <fmalczy(at)ibm.net> Date: Wednesday, February 03, 1999 6:50 AM Subject: RV-List: Wd-609 > >I'm about to mount mount my Wd-609 tail wheel assembly bracket between >F611A and F612 and was wondering about priming and painting the inside >of the bracket where U-602 the tail wheel arm inserts. For that matter >should the end of U-602 be primed and painted also. This looks like a >closely machined surface that just fits into the Wd-609 bracket. > >What have others done?....Thanks > >Fran Malczynski >Olcott, NY >RV6 (fuselage) > > ________________________________________________________________________________
Date: Feb 03, 1999
Subject: Re: Distance Calculator: Really Cool!
GTE duats is nice, but you have to either telnet or dial in with a modem. I have neither option from work, but can access web pages; at one time I know GTE was working on creating a duats web site, but I'm not sure if it was ever implemented. Instead I currently use http://www.airnav.com/ It accepts airport identifiers, gives airport information (gas, obstacles, FBO numbers, etc.), will find fuel stops (you enter a range), and some other goodies. Of course I still have to call the briefer to file. PS - I always double check the information gathered from airnav; it has always been right on, a really valuable flight planning tool IMHO. Chris Hill RV-8 Finishing up left elevator ________________________________________________________________________________
From: Lothar Klingmuller <lothark(at)worldnet.att.net>
Subject: Fireextinguisher
Date: Feb 03, 1999
We never hope to have an AC fire, but being prpared is part of flying sefely. A friend's airplane does not have a fireextinguisher so I thought I buy one to be used later in my RV-6A. What type and size is appropriate? Lothar |||-6A; drilling gear mounts in Lakewood/ Denver, CO ||| ________________________________________________________________________________
Subject: Denver Area - Fuselage Jig
Date: Feb 03, 1999
A jig will become available in a couple weeks. This is an straight, excellent wood jig build by a follow ROCKY MOUNTAIN RVator using laminated beam material for the main frame member. With the jig comes an attached power strip (very handy) and an 2 x 2 iron angle needed to alligning the gear legs. We would like to keep the jig in the Denver area and the next builder can make a donation to the ROCKY MOUNTAIN RVator builder/flyer group. Lothar |||-6A; drilling gear mounts in Lakewood/ Denver, CO ||| ________________________________________________________________________________
Date: Feb 03, 1999
Subject: Re: Swinging a compass
> >This may generate some disagreement, but when I wanted to "calibrate" my >whiskey compass (to get data for the "correction card") I used my GPS. I >flew on 360-degrees magnetic and got stable. Noted whiskey compass: >difference is compass error. I did this every 30-degrees around the full >circle. Was lucky in that no error exceeded the allowable whiskey error. >Comments? >RV-6A flying Salida, CO > > The GPS measures the ground track you are flying. The compass measures heading. They are only the same if there is no wind, and you have no sideslip. There is almost always some wind at altitude even if it is calm on the ground. A 10 knot crosswind with a TAS of 150 knots will give you about 4 degrees of drift. Winds at altitude are often much more than 10 kts. Propellor driven aircraft (except those with contra-rotating props) almost always have a small amount of sideslip due to prop wash, even if the slip indicator shows no side force. Now I will attempt to short circuit the protests about whether or not my claim about sideslip is true. Picture an RV flying with no sideslip. The prop wash curls around the aircraft and hits the vertical stab on the left side. This imparts a small amount of sideforce on the aircraft, which we will detect because the ball is out to the left. So, we put in left rudder as required to center the ball. Now we are happy, but we actually have a small amount of right sideslip (I think it would be less than one degree, except at high power and low speed, so it is not a big deal in the context of compass swinging). Take care, Kevin Horton RV-8 (fuel tanks) khorton(at)cyberus.ca (613) 821-7862 (home) Ottawa, Canada (613) 952-4319 (work) http://www.cyberus.ca/~khorton/rv8.html ________________________________________________________________________________
Subject: Electronic Remote Compass
Date: Feb 03, 1999
I have a kit built digital electronic compass with a remotely mounted sensor installed in my RV-4. I bought it for $229US years ago from a Company called Rusty Circuits in Angelton Texas, owned, I think, by a fellow called Russel Cowles. The design was based on work done by a NASA Researcher called Doug Garner. Doug published information on this and other instruments in the November and December 1981 issues of Sport Aviation. He also gave detailed plans at Oshkosh Forums in 1987 and other years. I spent some time trying to understand these circuits when someone told me that vacuum tubes weren't used much anymore. The only tricky bits were the magnetic windings and a programmed computer chip. The rest were pretty standard electronic things. Parts lists are in the material. Both the windings and the 8748 programmed chip could be bought from third parties. I have most of the literature referred to above plus a spare set of windings and a chip. I'd be pleased to make them available to some one who would put them to good use. Contact me off list if you have any further questions. Ron Taborek Toronto RV-4 In Basement Heading 347 degM. ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Date: Feb 03, 1999
John, You were flying track angles of thirty degree increments instead of heading angles, as countless others will doubless point out. Unless there was no wind (or less than about 10 knots at 160 KTAS), the corrections will show a bias introduced by the wind correction angle. On a day when the winds were truly "light and variable" at altitude this would be a good check. Dennis Persyk 6A finishing kit Hampshire, IL -----Original Message----- From: John Fasching <fasching(at)amigo.net> Date: Wednesday, February 03, 1999 10:24 AM Subject: RV-List: Swinging a compass > >This may generate some disagreement, but when I wanted to "calibrate" my >whiskey compass (to get data for the "correction card") I used my GPS. I >flew on 360-degrees magnetic and got stable. Noted whiskey compass: >difference is compass error. I did this every 30-degrees around the full >circle. Was lucky in that no error exceeded the allowable whiskey error. >Comments? >RV-6A flying Salida, CO ________________________________________________________________________________
Date: Feb 03, 1999
Chris Hill wrote: > > > GTE duats is nice, but you have to either telnet or dial in with a modem. I > have neither option from work, but can access web pages; at one time I know > GTE was working on creating a duats web site, but I'm not sure if it was > ever implemented. > > Instead I currently use http://www.airnav.com/ > Try http://www.duats.com - they were giving out hats at Oshkosh '98 with their web site printed on it. Marshall Dues, Katy, TX RV-6 N243MD 185 hrs based DWH airport ________________________________________________________________________________
Date: Feb 03, 1999
Date: Feb 03, 1999
Date: Feb 03, 1999
Subject: Re: New Sutbscriber RV-9 Wannabuilder
Larry(at)bowen.com: I am building an 8 and just got started. I live in NW Greensboro off Pleasant Ridge Road and work in High Point. I would love to get together with you and any other builders. Please give me a call as soon as possible. I would love to talk about the 8 empennage kit I have just gotten started on! Len Leggette 605-4762 Home 434-2124 Work ________________________________________________________________________________
Date: Feb 03, 1999
Subject: Re: Fireextinguisher
January 26, 1999 - - - - , 20-
RV-Archive.digest.vol-gh
