RV-Archive.digest.vol-gq
March 25, 1999 - April 01, 1999
       1/2 inch from the position given in the plans to make this problem go away.
       Of course, I've already drilled the weldment in place, so now I gotta figure
      a
       way to fix it.
       Anyone else have this problem?  Got a solution?
      Hey Kevin:
      Does the cable bind at BOTH ends of its travel? If not, you can heat and bend
      the angle at which the nut is welded to the tab to move some of the free-play
      from one side to the other. It sounds like a case of using the correct sized
      hammer...
      The current method in favor with those forward-thinking boys at Bakersfield is
      to have the cable run parallel to the elev root rib, instead of thru the spar
      and the h stab. A small fitting holds the cable to the flange of the root rib,
      and it is also tied to the elev horn (or in some cases , run thru the horn!)
      You must modify the act. arm on the tab to do this, but it is a very EZ mod,
      and makes installing and adjusting that cable a much simpler task.
      Check six!
      Mark
Subject: Re: Val vs ICOM
Date: Mar 25, 1999
> >Some time ago there was some discussion about the Val Com (599)radio >versus the ICOM radio(899). I have installed the Val radio in my RV-8, >and with 10 hours am very happy with it. I feel the switch setup for >frequency changes works very well, and have had no problem changing >frequencies even in turbulence. Another thing; today I got to see an >installed and working ICOM in another RV-8, and I noticed that the >frequency readout(numbers) are only about 1/4" high, versus the 1/2" >high of the ValCom. Also the ICOM uses the type of LCD(?) readout that is >difficult to see in direct sun. No such problem with the ValCom, as I got >to try that the other day when we had some of that rarely seen(here in >the Northwest) bright thing in the sky. No I do not work for ValCom, just >a very satisfied user. Just my opinion and my observation. >Von Alexander >N41VA(at)juno.com I'll second Von's views on the VAL COM here. I haven't actually used mine yet since the plane isn't ready to defy gravity at this time. (But that time grows nearer by the minute!) I have installed it, and I like it's rugged design. The large LEDS do show up nicely and VAL's customer support is excellent. I was missing a few molex pins for the wiring harness in the hardware kit. I called them up, and they sent plenty of them priority mail. For you -8 folks, bear in mind this radio is almost 12" deep..but it WILL fit. Brian Denk RV8 #379 N-number applied for, engine on the way. ________________________________________________________________________________
Subject: Trim Cable Installation
Date: Mar 25, 1999
I can't picture this. Have mercy, I am visualizationally challenged. Can you direct me to a photo on the web? Or perhaps a re-explanation using different words? Steve Soule Gave up (temporarily) trying to fish that cable through the HS and other hollow places and did something else instead. -----Original Message----- The current method in favor with those forward-thinking boys at Bakersfield is to have the cable run parallel to the elev root rib, instead of thru the spar and the h stab. A small fitting holds the cable to the flange of the root rib, and it is also tied to the elev horn (or in some cases , run thru the horn!) You must modify the act. arm on the tab to do this, but it is a very EZ mod, and makes installing and adjusting that cable a much simpler task. ________________________________________________________________________________
Date: Mar 25, 1999
Subject: Re: E-mail contact for Vans Aircraft
I have faxed and e-mailed Vans several times over the last couple of months and received an answer usually the same day?? Len ________________________________________________________________________________
Date: Mar 25, 1999
I have a VAL and have a couple complaints, #1 It has no live memory. You can buy an optional memory feature, but I read about it and was not impressed. #2 you can not preselect on freq with out switching away from the current one. I wish you could flip freqs and it would flash or something until you hit an enter or activate command. #3 if you are on approach at 135.xx and want to go to tower at 118.xx you can not go around the top. You have to scroll back all the way to 118. My Val talks out really well, I have some recieve troubles but I finally figured out that my tray is set too deep in the panel and the connector is not totally seated. Another project...... In my last airplane I had a KY97. Nothing wrong with that radio either! It is in the same price range and has features like the ICOM. Tailwinds, Doug Rozendaal dougr(at)petroblend.com www.petroblend.com/dougr ________________________________________________________________________________
Date: Mar 25, 1999
Subject: Payback (was: Unison Industries LASAR ignition)
> > > >> >> >> They're neat systems with some advances in technologies >> to offer but the payback is VERY elusive . . . > >Let's not even go down the path of cost justification with the hobby we all >enjoy. I was not trying to justify the cost of the aircraft or the hobby. The thought of that strikes me as good fodder for a comedian. But I do look at the costs of components. If I spend money I want it to DO something. That something should make the aircraft fly faster, climb better, help me navigate, reduce my workload, whatever. I am a gadget nut but I like my gadgets to do something. The LASAR ignition doesn't do anything for me in the performance catagory where I do most of my flying down low. It does buy me something when I am doing long cross country flying up high (lower fuel burn, marginal performance improvement). It decreases system reliability because now I don't just have the reliability of the mags to deal with, I also have the reliability of the electronics box. So it is a trade off. Since it doesn't add anything else to the airplane, is it worth it for the gadget factor? If I knew that, over the life of the engine and its ignition it wouldn't cost me any more than the stock mags, I would probably still do it so I can point to it and have another conversation factor. But if it can't even break even ... BTW, I think it would break even if I lived in a coutry where fuel was costing a lot more so it could be justified that way. OTOH, the Lightspeed ignition system gives you the advantages of the LASAR system at a significantly lower price AND it is a completely separate system from the mags giving better redundancy IMHO. Certified airplane: buy LASAR Experimental airplane: buy Lightspeed Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax O- ________________________________________________________________________________
Subject: Re: Engine inhibiting and Pre-Oilers
Date: Mar 25, 1999
Eustace, I have been considering installing a Pre-Oiler and am now wondering if this could be used as a 'longer term storage" aid for installed engines. I have a Pegasus catalog ( http://www.execpc.com/~pegasus/ ) which shows a Heavy-Duty Electric Solenoid Activated Accusump in one, two and three quart capacity for $230, $275 and $275. I see that they work by storing pressure during engine operation. This might make it unsuitable for preserving an installed engine unless it could be charged with an air compressor. Do you or anyone else know about this system? Ross Mickey 6A - Finishing kit -----Original Message----- From: Eustace Bowhay <ebowhay(at)shuswap.net> >It has been suggested that preoiling can be done through the steel fitting >that your oil pressure line connects to but in a lot of installations this >fitting can not be removed after the engine is installed and because it has >a restriction in it makes it almost impossable to get any voume of oil >through it. ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Re: Capacitance fuel sender
"Doyon, Richard" wrote: > I looked up the archive and got 69 hits on the subject. There's an article by Jim Weir on DIY electronic capacitance fuel senders at <http://www.rst-engr.com/rst/magazine/kp-89sep.zip>. Combine that with the DIY sender described by Dick Martin in a post to the RV-list, and I think you'd have a very cheap and very effective system. See my page <http://members.xoom.com/frankv/bunny2c.htm> for information that I found out about capacitance senders. Frank. -- frankv(at)ee.cit.ac.nz Frank van der Hulst This is my work account. Weekend email should be sent to me at frankvdh(at)ihug.co.nz. My home page is http://homepages.ihug.co.nz/~frankvdh ________________________________________________________________________________
Date: Mar 25, 1999
Subject: Re: Flaps
joseph.wiza wrote: " My problem is the right flap edge, the part that fits under the fuselage had to be bent down about 1/4" while the left flap had to be bent up about 1/8" just less then half an inch between the two." I am building a RV-6A (fuselage kit delivered in 3/97). While in the process of skinning the fuselage this month, I decided to check the fit of the wings before installing the bottom skins F676 and F677. I set the incidence angle as shown in SK-59, 3.03" at the aft spar. The bottom skin on both wings at the aft spar was .25 above the F676-F677 skins. I rechecked and all the dimensions were "per plan". I keep hearing the fiberglass gods saying "I told you not to fool with metal!". I will just add a joggeled piece to each flap. Richard Reynolds, Norfolk, VA, RV-6A, skinning the fuselage, still, still,.......... ________________________________________________________________________________
Subject: Re: Flaps
Date: Mar 25, 1999
Relative to aileron which was pinned neutral ---------- > From: Alex Peterson <alexpeterson(at)cwix.com> > To: rv-list(at)matronics.com > Subject: Re: RV-List: Flaps > Date: Wednesday, March 24, 1999 10:29 PM > > > > About a month ago I fitted the wings on pinned the alerons in nuetraland > > installed the electric flaps. > > How did you determine flap neutral position? > > Alex Peterson > Maple Grove, MN 6A finishing, finishing, finishing..... > > > > > > > ________________________________________________________________________________
Subject: Alt Belt
Date: Mar 25, 1999
RV6A O360 180. Has anyone tied a spare alternator belt to the baffling and have it servive for any period of time. (beats taking off a CS prop to put a new one on) thanks in advance. RV6A/finish kit ________________________________________________________________________________
Date: Mar 25, 1999
Subject: Re: Misc.
> > > 3)Have all control surfaces and empenage in Variprime, nothing on fuselage > and wings,Dupont says to seal coat Variprimewith something like Prime-n-Seal > before topcoating with Chromabase/Chromaclear or Centari--is this absolutely > necessary and what happens if I don't Prime-n-Seal(due to not wanting any > extra weight)? Or is Dupont just trying to sell me more paint? > John, I just painted my interior with Centari enamel. I had previously primed all parts when building with Variprime. Before shooting the Centari top coat, I wiped down the inside with Naphtha and sanded with green Scotch Brite. After sanding I then wiped down with enamel reducer and shot a thin coat of Dupont Velva-Seal over the variprime followed almost immediately (so minutes) with the top coat of Centari enamel with hardener. So far it seems to be a hard durable surface. Old primer, variprime included, will not form the proper chemical bond with the paint. The primer must be roughed up, cleaned and reprimed or removed totally and reprimed before final top coat if you want the paint to stick at 200 mph. The Velva-Seal I used comes premixed ready to shoot and is a neutral gray color that will not change the color of the top coat. Gary Zilik 6A s/n 22993 - fitting rigid fluid lines. ________________________________________________________________________________
From: "Steven B. Janicki" <sjanicki(at)us.oracle.com>
Subject: Re: Alt Belt
Date: Mar 25, 1999
Robinson does this on their helicopters as you would have to remove the squirrel cage to replace an alternator belt. Similar to removing a propeller. ----- Original Message ----- From: joseph.wiza <planejoe(at)flnet.com> Sent: Thursday, March 25, 1999 2:41 PM Subject: RV-List: Alt Belt > > RV6A O360 180. Has anyone tied a spare alternator belt to the baffling and > have it servive for any period of time. (beats taking off a CS prop to put > a new one on) thanks in advance. > > RV6A/finish kit > > ________________________________________________________________________________
Date: Mar 25, 1999
I have used Accusumps on several race car engines. They tend to store their charge indefinitely as long as the valve (either manual or solenoid) does not leak. However, you can also charge them manually by filling them with oil prior precharging with air. Before doing this, the piston which separates the oil from the air should be pushed back with a wooden dowel. Do not overfill the oil. You then install the oil valve and precharge the air side of the piston through the tire valve stem. I think that the air pressure should equal your highest normal oil pressure at normal operating temperature (if my memory is intact - if not, this is specified in the instructions). Any excess air on the oil side should then be "burped" and then the air charge checked once more. Not only is an Accusump good for pre-oiling before starting, but it also provides oil pressure for short durations when the oil pickup becomes uncovered such as during high cornering or braking in a race car or during brief periods of negative G's in an airplane. Chris Heitman cjh(at)execpc.com -----Original Message----- >I have been considering installing a Pre-Oiler and am now wondering if this >could be used as a 'longer term storage" aid for installed engines. I have >a Pegasus catalog ( http://www.execpc.com/~pegasus/ ) which shows a >Heavy-Duty Electric Solenoid Activated Accusump in one, two and three quart >capacity for $230, $275 and $275. I see that they work by storing pressure >during engine operation. This might make it unsuitable for preserving an >installed engine unless it could be charged with an air compressor. Do you >or anyone else know about this system? > >Ross Mickey >6A - Finishing kit ________________________________________________________________________________
Subject: O-360 AIA For sale
Date: Mar 25, 1999
I have a O-360 AIA for sale, Approx. 1900 hrs SMOH It was taken off of a Beech Twin in November that was flown pretty much every day. Starter, mags, carb, ect is all there. Compression is in the 70s First $ 6,000.00 Cash Takes it home. Please do not reply to the list. Ken Crabtree Bakersfield, Ca ODCBFL(at)LIGHTSPEED.NET ________________________________________________________________________________
Date: Mar 25, 1999
Subject: Re: Trim Cable Installation
Kyle, Just bend that little weldment until the tension is gone when the trim tab is in neutral. Regards, Bill N66WD ________________________________________________________________________________
Date: Mar 25, 1999
Subject: drill press/bandsaw question
i got a few bucks to blow on tools and need advise on drill press and bandsaw. looking at 8 inch-1/3 hp. 5 speed craftsman drill press with fence about $120 and a variable speed craftsman band around $200. any suggestions?????????????????? thanx bob doin tail in arkansas ________________________________________________________________________________
Date: Mar 25, 1999
From: "Douglas G. Murray" <dgmurray(at)telusplanet.net>
> << I''m installing my elevator trim cable and am finding that the geometry is > causing a large preload on the trim tab. I think a preload is going to > guarantee a cracked trim tab someday. > > It looks like the little weldment with the nut on it needs to move back about > 1/2 inch from the position given in the plans to make this problem go away. > Of course, I've already drilled the weldment in place, so now I gotta figure > a way to fix it. > > Anyone else have this problem? Got a solution? > >> > Hey Kevin: > > Does the cable bind at BOTH ends of its travel? If not, you can heat and bend > the angle at which the nut is welded to the tab to move some of the free-play > from one side to the other. It sounds like a case of using the correct sized > hammer... > > The current method in favor with those forward-thinking boys at Bakersfield is > to have the cable run parallel to the elev root rib, instead of thru the spar > and the h stab. A small fitting holds the cable to the flange of the root rib, > and it is also tied to the elev horn (or in some cases , run thru the horn!) > You must modify the act. arm on the tab to do this, but it is a very EZ mod, > and makes installing and adjusting that cable a much simpler task. > > Check six! > Mark Mark Does any one have a picture of this modification? I kind of get your drift but a picture is worth a thousand words. DGM RV-6 Southern Alberta ________________________________________________________________________________
Date: Mar 25, 1999
This is commonly done so one can quickly replace a broken belt away from home to return. You then can replace it with a new belt at a more convenient time. The spare belt will deteriorate from solvent cleanings and heat, but probably not any more than the belt in use. However if you replace promptly after main belt failure, it is cheap and convenient. Cy Galley - Editor BC Contact! Click here to visit our Club site at http://www.bellanca-championclub.com -----Original Message----- From: joseph.wiza <planejoe(at)flnet.com> Date: Thursday, March 25, 1999 5:32 PM Subject: RV-List: Alt Belt > >RV6A O360 180. Has anyone tied a spare alternator belt to the baffling and >have it servive for any period of time. (beats taking off a CS prop to put >a new one on) thanks in advance. > >RV6A/finish kit > > ________________________________________________________________________________
Subject: Re: Aileron Trim-RV-8
Date: Mar 25, 1999
>I have a slight left banking tendency on my RV-8 that I need to take >care >of. As I understand it, there are basically three methods of fixing >this >problem; 1. Install a small wedge shaped tab to the bottom of the >right >aileron. 2. Use the 'bang the trailing edge of the aileron >technique'. >3. Adjust the left flap slightly downward. As of now, I think I >prefer >the flap adjustment method. Has anyone had good success with this? >What >has worked for you? Thanks. >Von Alexander >N41VA(at)juno.com > > Von, I don't know if you ever got any response to this one so here is some input. Most builders tend to always come up just slightly short of bending the trailing edge closed enough, so squeezing the trailing edge closed a little more on the "light" wing is usually better than hammering on the trailing edge of the heavy one. This of course should not be done until you have verified that the flaps are adjusted exactly where they ,should be when fully retracted. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Subject: Re: What paint do you all use?
Date: Mar 25, 1999
> >Here in Arizona, I plan to use "Dash Mat" material. >Basically, real short pile carpet. > >Larry Olson >Cave Creek, AZ >RV6-Fuse N606RV > > Larry, Take a look at the velour type of material that Dash Mat has. It is very nice for this. I used a color other than black to do the entire interior side panels of my airplane. It is very light but has a 1/8 " foam insulation on the back which insulates you from the (sometimes) cold skin surface very well and seems to have a little bit of sound deadening ability. Because it is meant for dash mats it is also very sun/fade resistant. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Subject: Re: Brakes to right side
Date: Mar 25, 1999
On Wed, 24 Mar 1999 18:15:13 +-1000 Trevor Mills writes: > >Well today I have crawled in and out of our aeroplane so many times I >lost count. I have just fitted the brakes to the right hand side, with >no luck so far. >As I don't have the drawings for this aeroplane and I have only >reached the wing stage on my 8, I tried to fit the brakes using common >sense ( what a mistake ) >What I have done is fitted the pedals and plumbed the new pedals with >tee's at the firewall, so now what happens is when I pump the brakes >on one side, the brake fluid runs through the other side and back to >the bottle at the firewall, if I get someone to hold there feet on the >brakes next to me all is fine. Have I plumbed it all wrong or do I >just need one way valves at each master cylinder ? > >I would be very pleased if you could cc to my home address below as I >really would like to sort this out soon. > >Thank You >Trevor Mills 80605 >( my back is killing me) > > I didn't see whether you got a reply to your question, but the answer is a definite "no you didn't do it correctly" In fact it sounds as thought you caused yourself more work than you would have had if done correctly. With right side brakes the out put of the right master cylinders (bottom ports) get plumbed to the input ports of the left seat master cylinders (top ports). the reservoir then gets plumbed to the 2 top ports of the right hand master cylinders. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Date: Mar 25, 1999
Subject: Re: drill press/bandsaw question
Bob, Be careful that your drill press turns slow enough for use of your flycutter. I believe that 250rpm is what you should shoot for. The smaller(less expensive) ones only will slow down to about 500rpm which can be very exciting. In terms of a band saw I know that Sears is changing model lines and replacing the 10inch vari. with a 11 inch model. Therefore, if you watch, the 10 inch can be purchased at a good price. And if you join the Craftsman club( it's free)..you can get a bigger discount. Good LucK Mark (6a tail) ________________________________________________________________________________
Subject: Re: RV-8 A: wheel size?
Date: Mar 25, 1999
> >I like to use the RV wheel pants on another plane. Can anyone tell me >what >size wheels (front and rear) the RV "A"'s use? > >Thank you, >Ernesto Sanchez >es12043(at)utech.net > > The mains wheels use a standard 5" wheel with 5.00 X 5 aircraft tires. The nose wheel is a standard 5" aircraft nose wheel with a lamb tire. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Date: Mar 25, 1999
Chris, Can you share how you installed the Accusump system in your RV? I am ordering an Accusump for my RV-4 though I must admit that I am uncertain as to the best hookup. -----Original Message----- From: Christopher Heitman <cjh(at)execpc.com> Date: Thursday, March 25, 1999 5:02 PM Subject: Re: RV-List: Engine inhibiting and Pre-Oilers > >I have used Accusumps on several race car engines. They tend to store their >charge indefinitely as long as the valve (either manual or solenoid) does >not leak. However, you can also charge them manually by filling them with >oil prior precharging with air. Before doing this, the piston which >separates the oil from the air should be pushed back with a wooden dowel. Do >not overfill the oil. You then install the oil valve and precharge the air >side of the piston through the tire valve stem. I think that the air >pressure should equal your highest normal oil pressure at normal operating >temperature (if my memory is intact - if not, this is specified in the >instructions). Any excess air on the oil side should then be "burped" and >then the air charge checked once more. > >Not only is an Accusump good for pre-oiling before starting, but it also >provides oil pressure for short durations when the oil pickup becomes >uncovered such as during high cornering or braking in a race car or during >brief periods of negative G's in an airplane. > >Chris Heitman >cjh(at)execpc.com > >-----Original Message----- >>I have been considering installing a Pre-Oiler and am now wondering if this >>could be used as a 'longer term storage" aid for installed engines. I have >>a Pegasus catalog ( http://www.execpc.com/~pegasus/ ) which shows a >>Heavy-Duty Electric Solenoid Activated Accusump in one, two and three quart >>capacity for $230, $275 and $275. I see that they work by storing pressure >>during engine operation. This might make it unsuitable for preserving an >>installed engine unless it could be charged with an air compressor. Do you >>or anyone else know about this system? >> >>Ross Mickey >>6A - Finishing kit > > name="Steven B Janicki.vcf" filename="Steven B Janicki.vcf" BEGIN:VCARD VERSION:2.1 N:Janicki;Steven;B;Mr. FN:Steven B Janicki ORG:Oracle Corporation;Data Center TITLE:Sr. Director TEL;WORK;VOICE:650-506-2740 TEL;WORK;FAX:650-633-2165 ADR;WORK:;4op4;500 Oracle Pkwy;Redwood Shores;CA;94065;USA Pkwy=3D0D=3D0ARedwood Shores, CA 94065=3D0D=3D0AUSA URL:http://www.oracle.com URL:http://www.oracle.com EMAIL;PREF;INTERNET:sjanicki(at)us.oracle.com EMAIL;INTERNET:sjanicki(at)us.oracle.com REV:19990326T024852Z END:VCARD ________________________________________________________________________________
Subject: Fw: A Word on Milspecs
Date: Mar 25, 1999
-----Original Message----- From: Laura Greig <lgreig(at)home.com> Date: Thursday, March 25, 1999 1:29 PM Subject: A Word on Milspecs >Here's a good one! > >~ L. (InterMail v4.00.03 201-229-104) with ESMTP for ; From: "D.A. Chipman" <ortona(at)portal.ca> "Mike Chessnoe" , "John Gorkowski" , "John Guthrie" , "Don Ethell" , "Steve Richards" , "Larry Tolton" , "Rob Chipman" , "Neil Corbett" , "Mike Peters" , "Dan McFaull" , "Tim McNeil" , "Laura Greig" , "Adam Dymitrtuk" Subject: A Word on Milspecs Date: Wed, 24 Mar 1999 09:00:30 -0800 From: Conrad Metcalfe The US standard railroad gauge (the distance between the rails) is 4 feet, 8.5 inches. That's an exceedingly odd number. Why was that gauge used? Because that's the way they built them in England, and the US railroads were built by English expatriates. Why did the English people build them like that? Because the first rail lines were built by the same people who built the pre-railroad tramways, and that's the gauge they used. Why did "they" use that gauge? Because the people who built the tramways used the same jigs and tools that they used for building wagons, which used that wheel spacing. Okay! Why did the wagons use that odd wheel spacing? Well, if they tried to use any other spacing, the wagons would break wheels and axles on some of the old long distance roads, because that's the spacing of the old wheel ruts. So who built the old rutted roads that way? The first long distance roads in Europe were built by Imperial Rome for the benefit of their legions. The roads have been used ever since. And the ruts? The initial ruts, which everyone else had to match for fear of destroying their wagons, were first made by Roman war chariots. Since the chariots were made for or by Imperial Rome, they were all alike in the matter of wheel spacing. Thus, we have the answer to the original questions. The United States standard railroad gauge of 4 feet, 8.5 inches derives from the original specification (Military Spec) for an Imperial Roman war chariot. So, the next time you are handed a specification and wonder what horse's ass came up with it, you may be exactly right. Because the Imperial Roman chariots were made to be just wide enough to accommodate the back ends of two war horses. ________________________________________________________________________________
Date: Mar 25, 1999
Very strongly suggest you do it. My belt rubbed the cowl on the first flight slightly, and I am looking at taking the prop off after the test period. Don't want to start the great adventure with a damaged belt and I did not put a second one on.. Be sure you have at least 3/8" clearance between the cowl and alternator pulley. I added a bump, a pain since my ship was completely painted before it left the shop. Second belt probably will be in bad shape from heat and age before you need to use it, but stuck in Podunk Airport, it sure beats removing the prop. Bruce Patton RV-6A 8.6 hours, still with noisy brakes (which we hope are solved this weekend. Vans has been great) ________________________________________________________________________________
Subject: Re: fuel tank leak
Date: Mar 25, 1999
-----Original Message----- From: flyhars(at)ibm.net <flyhars(at)ibm.net> Date: Tuesday, March 23, 1999 9:14 PM Subject: Re: RV-List: fuel tank leak What is really needed is fuel proof nut plates that have built >in "O" >rings to seal when the screw is tightened. They are expensive I am sure, >but I >am sure they would stop the leaks. Pegasus,Auto Racing Supplies. 1-800- 688- 6946 Alum. washers with molded Buna-N inner seals...#8...# 3245-#8....$0.79 Would probably work under Button Head Socket Cap Screws. They also have same for # 10 screws. Derek Reed Grants Pass OR. 6A waiting to P/U finish kit April. ________________________________________________________________________________
Date: Mar 25, 1999
Subject: Re: paint or powder coating for RV-8 landing gear
Kevin Horton wrote: > > > Hi there, > > I searched the archives on this, but didn't find anything useful. > > I am wondering about what to put on my RV-8 landing gear legs for > corrosion protection. Will they flex enough to cause problems with > any types of paint or powder coating? > > I assume that I need something pretty tough, or it will wear off the > LG leg at the wear plates. Or, will anything I put on wear there, > and I just need to put some grease in that area to protect from rust? > > Does anyone have some thoughts on this? > > Take care, > Kevin Horton RV-8 (fuel tanks & fuselage bulkheads) Hi Kevin I just had the steel parts for the fusalage, (gear mounts, rudder pedal assembly, engine mount etc, etc) powder coated. Not sure if I would spend the money to do it again. The powder coat surface is harder and thicker than paint but does not adhere to the metal any better than a good paint. Also there are different qualities of powder, the cheap stuff comes from China. As with other finishes the preparation and workmanship probably make the difference, unfortunately I think an apprentice did my job. I epoxy primed my gear legs. George McNutt, Langley, B.C. 6-A, starting to skin fuse. ________________________________________________________________________________
Date: Mar 26, 1999
In a message dated 3/25/99 5:23:43 PM Central Standard Time, planejoe(at)flnet.com writes: << . Has anyone tied a spare alternator belt to the baffling and have it servive for any period of time. >> That is an old crop-duster trick to save time during the busy season, I was told. I fly a friends Glasair and it has two belts tied to the engine hoist point on top of the engine. I know they were there for the last 300 or so hours with no problem. Tim Presley N64TX RV-4, sold, RV-8 QB underway ________________________________________________________________________________
Date: Mar 25, 1999
Subject: Re: CSP climb rate (was Newbie RV-6 questions)
Kevin, Actually, I was asking about the extra climb rate of the constant speed prop over the fixed pitch, assuming an O-360 in both cases. However, your method can apply to this, as well. Searching the archives, I see that the Sensenich prop turns about 2350 rpm at full throttle while climbing. The CSP would allow 2700 rpm. 350 over 2700 times 180 is about 23 extra hp available. This would imply another 350 fpm climb, based on your calculation. Also, I just got my RV-6/6A preview plans, and it claims about 10-15% increase in climb rate for a CSP. This would be about 180-250 fpm more. So I guess the answer is somewhere around 200-300 fpm greater climb rate. Tom Kevin Horton wrote: > > > > 3. I read plenty in the archives on O-360's and constant speed props. > > But I couldn't really find too many quantitative answers. What is the > > typical increase in initial climb rate over Van's specs for the 180 hp > > RV-6? > Tom, > > Kyle answered your other questions, so I'll step in on the rate of climb. > > If everything else is the same, it is easy to estimate the change in > rate of climb with change in power. At the same weight, and speed, > the drag is the same, so any extra power increases the climb rate. > > Lets assume a propeller efficiency of 75%, so we only get to use 15 > of the extra 20 hp (assuming that the 160 hp with constant speed is > the baseline). > > Power = rate of doing work. 1 Horsepower = 33,000 ft-lb/min. > > We are lifting a 1650 lb aircraft. > > Extra rate of climb = 20 X 0.75 X 33,000/1650 = 300 ft/min. > > Actual results will vary due to prop efficiency being a bit different > from the assumed value, variations in power output of engines and > variations between aircraft that affect drag. > > Take care, > Kevin Horton RV-8 (fuel tanks & fuselage bulkheads) > khorton(at)cyberus.ca (613) 821-7862 (home) > Ottawa, Canada (613) 952-4319 (work) > http://www.cyberus.ca/~khorton/rv8.html > ________________________________________________________________________________
Date: Mar 25, 1999
I have the Craftsman variable speed bandsaw with a non-ferrous metal cutting blade and it works well on the aluminum speed setting. Wear eye protection of course, as it occasionally flings a chip skyward. The Sears drill press looks OK but also check Harbor Freight (see archives) as their $59 (on sale sometimes) inch drill press has served me well on the empennage. Good luck! Phil Smith ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Lamb tire
The nose wheel is a standard 5" aircraft nose wheel with a lamb tire. What makes the nose wheel a lamb tire? What is a lamb tire? Inquiring minds want to know. Gary Zilik ________________________________________________________________________________
Date: Mar 26, 1999
<< The powder coat surface is harder and thicker than paint but does not adhere to the metal any better than a good paint. >> George, You must have gotten a shoddy job. Usually this stuff is tuff as nails and will take alot more of a beating then any paint Ive seen. I had all of my steel parts powder coated with the exception of the flap actuator bar ( I missed it some how while gathering everything to take to the powder coaters). Any way I epoxy painted the actuator bar. After almost 5 years of service the only steel part that shows any wear is the flap bar. It has chips knocked out of it everywhere. My roll bar however is still in new condition and anyone who flys a 4 knows that takes a beating over time. That says alot for the powder coating in my book. Ryan Bendure Co. ________________________________________________________________________________
Subject: Re: Lamb tire
Date: Mar 26, 1999
> >The nose wheel is a standard 5" aircraft nose wheel with a lamb tire. > >What makes the nose wheel a lamb tire? What is a lamb tire? > >Inquiring minds want to know. > >Gary Zilik > > The lamb tire is actually a Lamb tire, just a brand of tire. The tire is named for a friend of mine, Mike Lamb, founder/former owner of the Lamb brand of tires. His company made ten of thousands of tires (Van's bought a bunch), and he subsequently sold the company to Japanese investors. Since last November, Mike has been tearing up the skies over Southern California in his recently completed Harmon Rocket II Paul Rosales RV-6A N628PV Firewall Forward ________________________________________________________________________________
Date: Mar 26, 1999
Check out http://www.grizzleyindustrial.com/main.html I made the error of purchasing a bandsaw from Harbor Freight. I also purchased a drill press. The quality is not great but it works. The band saw has a poor blade center/retainer mechanism. -----Original Message----- From: pdsmith <pdsmith(at)pacbell.net> Date: Thursday, March 25, 1999 11:23 PM Subject: Re: RV-List: drill press/bandsaw question > >I have the Craftsman variable speed bandsaw with a non-ferrous metal cutting >blade and it works well on the aluminum speed setting. Wear eye protection >of course, as it occasionally flings a chip skyward. The Sears drill press >looks OK but also check Harbor Freight (see archives) as their $59 (on sale >sometimes) inch drill press has served me well on the empennage. > >Good luck! > >Phil Smith > > name="Steven B Janicki.vcf" filename="Steven B Janicki.vcf" BEGIN:VCARD VERSION:2.1 N:Janicki;Steven;B;Mr. FN:Steven B Janicki ORG:Oracle Corporation;Data Center TITLE:Sr. Director TEL;WORK;VOICE:650-506-2740 TEL;WORK;FAX:650-633-2165 ADR;WORK:;4op4;500 Oracle Pkwy;Redwood Shores;CA;94065;USA Pkwy=3D0D=3D0ARedwood Shores, CA 94065=3D0D=3D0AUSA URL:http://www.oracle.com URL:http://www.oracle.com EMAIL;PREF;INTERNET:sjanicki(at)us.oracle.com EMAIL;INTERNET:sjanicki(at)us.oracle.com REV:19990326T081906Z END:VCARD ________________________________________________________________________________
Date: Mar 26, 1999
Location/phone number/web site????? for Dash Mat Ed Anderson smcdaniels(at)Juno.com wrote: > > > > > >Here in Arizona, I plan to use "Dash Mat" material. > >Basically, real short pile carpet. > > > >Larry Olson > >Cave Creek, AZ > >RV6-Fuse N606RV > > > > > Larry, > Take a look at the velour type of material that Dash Mat has. It is very > nice for this. I used a color other than black to do the entire interior > side panels of my airplane. It is very light but has a 1/8 " foam > insulation on the back which insulates you from the (sometimes) cold skin > surface very well and seems to have a little bit of sound deadening > ability. > Because it is meant for dash mats it is also very sun/fade resistant. > > Scott McDaniels > These opinions and ideas are mine alone and do not necessarily > reflect the opinions and ideas of my employer. > ________________________________________________________________________________
Date: Mar 26, 1999
<< The current method in favor with those forward-thinking boys at Bakersfield is > to have the cable run parallel to the elev root rib, instead of thru the spar > and the h stab. A small fitting holds the cable to the flange of the root rib, > and it is also tied to the elev horn (or in some cases , run thru the horn!) > You must modify the act. arm on the tab to do this, but it is a very EZ mod, > and makes installing and adjusting that cable a much simpler task. > > Check six! > Mark Mark Does any one have a picture of this modification? I kind of get your drift but a picture is worth a thousand words. DGM RV-6 Southern Alberta >> Boy, I should have expected this -- it seems a LOT of you want to know about this mod. My apologies for having no pictures, but here's a (possibly) better explanation: Referring to plans page 30 (RV-4): Picture the cable running OVER the elev horn with about 1" clearance. The cable must then turn to parallel the root rib on the left elevator. The cable must also attach to the rib area somehow -- I drilled out a rivet, and used an adel clamp secured by a #8 AN525 screw and nut to stabilize the cable housing ( a more hefty attach might be a better idea). The actuator arm on the trim tab was per the plans, but it was left more or less flat (not bent) so the it would remain parallel to the angle of the root rib, and also the angle of the cable. We also installed a larger adel on the top of the h stab spar as a slip guide for the cable, as it moves with the elev a bit. This is as installed on Bruce Bohannon's ship, which will more than likely be the subject of many photos while on display at SnF -- maybe Sam can snap one of this area, and post it to his web site. You'll do the same as I did when I first saw one done this way -- SLAP on the forehead -- Why didn't I think of that??! Check six! Mark ________________________________________________________________________________
Date: Mar 26, 1999
From: "Scott A. Jordan" <SAJ_SLJ(at)compuserve.com>
Subject: Roadway
You may remember about a month ago I sent Roadway a letter complaining of poor service in the two shipments they have made for me, loosing part of the shipment in both cases. I received a response that in effect, said too bad. Following are a few excerpts. On the wing shipment last year: "In researching your complaint, I was unable to find a shipment to you on or around May 1998." I didn't give them a tracking number so I guess thier records don't include customer names. Concerning the February fuselage shipment: "There are two possible reasons for misrouted freight. First, it could be a misload by Roadway personnel. The second reason could be the shipper gave Roadway bad information." In both cases, the crates were clearly marked, Vans ships enough orders to know how to do this properly. Futher: "Too much time has passed for me to discern why this happened to either of your shipments." My letter to customer support was in the mail the day following the eventual delivery of the misplaced crate. Apparently, four or five days after delivery everyone involved had forgotten all about it! "However, I am forwarding your letter and my reply to the origin and destination terminal managers so that they can take preventative measures to prevent a recurrence of this problem." I will take my own preventative measures, I will not ship with Roadway in the future. Scott A. Jordan 80331 waiting for a warm day to prime bulkheads & floor parts ________________________________________________________________________________
Subject: Vintage Airways/Airlines
Date: Mar 26, 1999
Not directly RV related, folks, sorry, but I was looking to track down anyone who knows anything about Vintage Airway/sAirlines - or maybe knows someone who does. This was the Branson/Virgin venture in Florida that was running a couple of DC-3s between Miami and Key West, I believe. I also understand that they are now defunct. Please contact me off list at gannont(at)home.com . Thanx... Terry in Calgary RV-6 S/N 22414 "Wings" ________________________________________________________________________________
Date: Mar 26, 1999
Scot... Where do you get Dash Mat?? Chat ----Original Message----- From: smcdaniels(at)Juno.com <smcdaniels(at)Juno.com> Date: Thursday, March 25, 1999 9:47 PM Subject: Re: RV-List: What paint do you all use? > > >> >>Here in Arizona, I plan to use "Dash Mat" material. >>Basically, real short pile carpet. >> >>Larry Olson >>Cave Creek, AZ >>RV6-Fuse N606RV >> >> >Larry, >Take a look at the velour type of material that Dash Mat has. It is very >nice for this. I used a color other than black to do the entire interior >side panels of my airplane. It is very light but has a 1/8 " foam >insulation on the back which insulates you from the (sometimes) cold skin >surface very well and seems to have a little bit of sound deadening >ability. >Because it is meant for dash mats it is also very sun/fade resistant. > > >Scott McDaniels >These opinions and ideas are mine alone and do not necessarily >reflect the opinions and ideas of my employer. > > ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Re: RV-List:"Dash Matt''
Where can we find dash matt material ??? Ken Harrell Bowling Green , Ky. RV6 N7470U Flying RV6 Q/B in shop ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Re: RV6 /8 engine
I'm just curious. What makes this engine "for experimental only"? ________________________________________________________________________________
Date: Mar 26, 1999
So far I have only installed them in race cars. On wet sump engines this was done by adding a tee in the return line from the oil cooler. The oil cooler was plumbed to a sandwich plate between the block and spin-on oil filter. I am not sure of the best way to add to a Lycoming. Chris Heitman cjh(at)execpc.com considering RV9 when available -----Original Message----- >Chris, Can you share how you installed the Accusump system in your RV? I am >ordering an Accusump for my RV-4 though I must admit that I am uncertain as >to the best hookup. ________________________________________________________________________________
Date: Mar 26, 1999
In a message dated 3/25/99 11:32:52 PM Pacific Standard Time, zilik(at)bewellnet.com writes: << The nose wheel is a standard 5" aircraft nose wheel with a lamb tire. What makes the nose wheel a lamb tire? What is a lamb tire? >> It is a tube type tire made by Lamb common to light aircraft. Although it fits on a 5" wheel, it is narrower and smaller in OD than a 5x5. It's also used on more than a few ultralights as mains when mounted on Azusalite plastic wheels. Check the ACS catalog. -GV ________________________________________________________________________________
Date: Mar 26, 1999
Bob Paulovich wrote: > > i got a few bucks to blow on tools and need advise on drill press and > bandsaw. looking at 8 inch-1/3 hp. 5 speed craftsman drill press with > fence about $120 and a variable speed craftsman band around $200. any > suggestions?????????????????? thanx bob doin tail in arkansas Bob, I would buy a larger drill press for sure. I bought the 8" drill press and it is too small to even fit my fly cutter in! Go with something with a little larger throat. I also do wood working and the 1/3 horse bogs down way to easy. Joe #25491 Working on Horizontal stab ________________________________________________________________________________
Date: Mar 26, 1999
They are sold thru a car wash chain here in Phoenix. My thought was to contact the manufacturer to see if I could just buy a yard or so. Will post if successful. Larry Olson RV6 - Fuse > >Where can we find dash matt material ??? >Ken Harrell >Bowling Green , Ky. >RV6 N7470U Flying >RV6 Q/B in shop ________________________________________________________________________________
Date: Mar 26, 1999
I purchased to Sears non adjustable speed bandsaw and it works great. I bought the adjustable speed bandsaw a couple of years later to cut steel tubing for my Pitts. It's a piece of junk! Doesn't even cut aluminum well. I'd be glad to sell it if anyone is interested! -Gene Gottschalk RV6A, N700RV Frederick, Maryland > >I have the Craftsman variable speed bandsaw with a non-ferrous metal cutting >blade and it works well on the aluminum speed setting. Wear eye protection >of course, as it occasionally flings a chip skyward. The Sears drill press >looks OK but also check Harbor Freight (see archives) as their $59 (on sale >sometimes) inch drill press has served me well on the empennage. > >Good luck! > >Phil Smith ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Rear seat vent bracket
RV Tech Support The plans for F-814J, rear seat vent bracket say to make it from AA3 063 3/4x3/4. I can't find any of this angle, nor can I find it listed in my fuselage inventory. Should it actually be made from an AA3 angle or scrap from an earlier part? If it is to be made from scrap, how can I tell T3 from T6 material? Thanks Scott A. Jordan 80331 ________________________________________________________________________________
Date: Mar 26, 1999
A lamb tire is 11.4 in diameter instead of the the standard 15" of a 5:00x5. -----Original Message----- From: Gary Zilik <zilik(at)bewellnet.com> Date: Friday, March 26, 1999 1:38 AM Subject: RV-List: Lamb tire > >The nose wheel is a standard 5" aircraft nose wheel with a lamb tire. > >What makes the nose wheel a lamb tire? What is a lamb tire? > >Inquiring minds want to know. > >Gary Zilik > > ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Re: RV-List : JPI's BIG Mistake
Listers In talking with an avionics shop the other day, as I often do working and cutting panels. I mentioned JPI's Mistake to him and my mind begin to work. You the builders buy from these guys, here's another way to get to JPI's managment. Start calling your suppliers tell them about Matt's misfortune. Maybe they can help get the point across that this industry will not support a bully. Somebody mentiond as I did that we were going to post this on there web site. I would like to here from those people so we can group together, when someone surf's in, we have links to all pages standing together in this cause. Steve Davis The Panel Pilot panelcut(at)aol.com ________________________________________________________________________________
Date: Mar 26, 1999
When the Data Plate is removed due to modification of fuel systems, ignition system, pistons, etc. Any part not originally certified for that engine by the FAA. -----Original Message----- From: MICHAEL <lottmc(at)datasync.com> Date: Friday, March 26, 1999 6:06 AM Subject: Re: RV-List: RV6 /8 engine > >I'm just curious. What makes this engine "for experimental >only"? > > name="Steven B Janicki.vcf" filename="Steven B Janicki.vcf" BEGIN:VCARD VERSION:2.1 N:Janicki;Steven;B;Mr. FN:Steven B Janicki ORG:Oracle Corporation;Data Center TITLE:Sr. Director TEL;WORK;VOICE:650-506-2740 TEL;WORK;FAX:650-633-2165 ADR;WORK:;4op4;500 Oracle Pkwy;Redwood Shores;CA;94065;USA Pkwy=3D0D=3D0ARedwood Shores, CA 94065=3D0D=3D0AUSA URL:http://www.oracle.com URL:http://www.oracle.com EMAIL;PREF;INTERNET:sjanicki(at)us.oracle.com EMAIL;INTERNET:sjanicki(at)us.oracle.com REV:19990326T163412Z END:VCARD ________________________________________________________________________________
Date: Mar 26, 1999
From: rfiler(at)glenvan.glenayre.com (Rory Filer [4438])
Hi Sears has one of its tool sales on in my area. Last night I went to look at the bandsaws (not on sale :( and drillpresses. The salesman said that the bandsaws weren't very good for cutting metal because the filings just trash the plastic coating on the wheels used to transport the blade 'round. All the bandsaws I've seen in the lower price ranges seem to have this plastic coating on the drive wheels. Has shredded plastic on the drive wheels been a problem for anyone out there? He also said that Sears didn't sell any blades for metal cutting. Do most of you use the stock blade, or do you buy metal cutting blades somewhere else? Rory Filer - RV-6A (Stocking the shop) > > > I purchased to Sears non adjustable speed bandsaw and it works great. I > bought the adjustable speed bandsaw a couple of years later to cut steel > tubing for my Pitts. It's a piece of junk! Doesn't even cut aluminum well. > I'd be glad to sell it if anyone is interested! > > -Gene Gottschalk > RV6A, N700RV > Frederick, Maryland > > > > >I have the Craftsman variable speed bandsaw with a non-ferrous metal cutting > >blade and it works well on the aluminum speed setting. Wear eye protection > >of course, as it occasionally flings a chip skyward. The Sears drill press > >looks OK but also check Harbor Freight (see archives) as their $59 (on sale > >sometimes) inch drill press has served me well on the empennage. > > > >Good luck! > > > >Phil Smith > > ________________________________________________________________________________
Subject: Re: Boycott JPI logo
Date: Mar 26, 1999
Moe: The logo's URL is http://home.earthlink.net/~timrv6a/nojpi.jpg You can add this logo to your web page by putting the following string at the appropriate place. http://home.earthlink.net/~timrv6a/nojpi.jpg"> That'll save you from having to copy the image file, and also save you disc space on your web site. This is Tim Lewis's web page http://home.earthlink.net/~timrv6a/ which has a lot of information about the boycott and the JPI/Matronics issue. Tedd McHenry Surrey, BC ________________________________________________________________________________
Date: Mar 26, 1999
I have a 10" Sears bandsaw. It is the compact kind with three wheels. The wheels are plastic with rubber "tires" that are replaceable. Sears sells the blades, and a metal cutting blade is available. In fact I bought one last month. I haven't had any trouble with the metal filings clogging up the works or harming the wheels. The saw cuts Al very well, but it is noisy compared to cutting wood. I vacuum out the insides every now and then and check the condition of the blade and other wearable parts. I replaced the rubber "tires" once about four years ago. Sears is the only source for the blades that fit my bandsaw. The blades are three quarters of an inch longer than the standard size for bandsaws of this type. I have never had any trouble getting blades from Sears, though. I have several different kinds on hand so I can use the right blade for the material I am cutting. I have had the bandsaw for about ten years. It is good for light cutting. Most of its use in my shop has been for building things out of wood. You know, wood. I built my kitchen out of the stuff. I built my shop out of wood. Projects that had a beginning, a middle and an end. That's what I used to do for fun before I started the never-ending project of building this RV-6A. Steve Soule Huntington, Vermont RV-6A fuselage waiting for the finish kit (four years and still earth bound) -----Original Message-----The salesman said that the bandsaws weren't very good for cutting metal because the filings just trash the plastic coating on the wheels used to transport the blade 'round. All the bandsaws I've seen in the lower price ranges seem to have this plastic coating on the drive wheels. Has shredded plastic on the drive wheels been a problem for anyone out there? He also said that Sears didn't sell any blades for metal cutting. Do most of you use the stock blade, or do you buy metal cutting blades somewhere else? ________________________________________________________________________________
Date: Mar 26, 1999
From: "Scott Kuebler" <skuebler(at)CANNONdesign.com>
I use a Craftsman 12" bandsaw with a 80" blade. Mine is about six years old an I can't recall if it has the plastic wheels or the metal wheels, but it is a Sears model and I haven't had any problems with it cutting aluminum. As for blades, I know Craftsman has a wide variety of blades, and several are specifically for ferrous metals, I would try to find a more knowledgeable salesperson. I have personally found that the blade designed for steel works well on aluminum and lasts a long time. I have also found that if you use it for what it is designed for, steel, it will become dull after a few passes and will no longer work on steel or even the aluminum. Therefore, I keep one blade that is only used for aluminum and one blade for other metals. A few people on the list have said that a medium wood blade works well for cutting the bar stock aluminum, but I have never tried it. Hope this helps, Scott Kuebler Buffalo, NY RV-6a (wings) >>> Rory Filer [4438] 03/26 11:59 AM >>> Hi Sears has one of its tool sales on in my area. Last night I went to look at the bandsaws (not on sale :( and drillpresses. The salesman said that the bandsaws weren't very good for cutting metal because the filings just trash the plastic coating on the wheels used to transport the blade 'round. All the bandsaws I've seen in the lower price ranges seem to have this plastic coating on the drive wheels. Has shredded plastic on the drive wheels been a problem for anyone out there? He also said that Sears didn't sell any blades for metal cutting. Do most of you use the stock blade, or do you buy metal cutting blades somewhere else? Rory Filer - RV-6A (Stocking the shop) ________________________________________________________________________________
Date: Mar 26, 1999
Should we be boycotting Electronics International too? Didn't they start this whole thing by sueing JPI in the first place? Bruce Green >You the builders buy from these guys, here's another way to get to >JPI's >managment. Start calling your suppliers tell them about Matt's >misfortune. >Maybe they can help get the point across that this industry will not >support a >bully. ________________________________________________________________________________
Subject: Retractable RV8?
Date: Mar 26, 1999
The post http://www.matronics.com/ftp/Scans/RV/896rtk-1.jpg is an RV-4 retract. I had an engineer make up some drawings for me a while back. His name was Pat Falley. He was working on a tapered wing/retract on his RV-4. He had over 1000 extra hours in his left wing alone. The RV-8 modification he drew up for me looks fairly straight forward. He moved the fuel tanks outboard toward the tips. I decided against it as it would only provide MAYBE 5 knots and add 600+ hours and $15,000+ to the project. If you are interested in a DWG file (exterior), I've got a copy. Email me directly. Paul Imhof RV-8 #80024 - QB On gear, working on rear seat and floor Here's an Email I dug up when I was considering it for my RV-8: -----Original Message----- From: Pat Falley Sent: Friday, February 21, 1997 1:43 PM Subject: RE: RV-8 Paul, A couple of comments. The landing loads on the wing will be lower than flight loads with the exception of in torsion, hence the need to beef up the portion of the rib that extends to the aft spar. This gives about a 20 inch arm to balance the moment generated by the wheels. Some local strengthening of the aft spar is required as well as a suitable method to carry the load through the main spar (I used AN4 and AN5 bolts on my wing to do this). The leading edge extensions at the root actually improve both low and high speed characteristics. To what degree I can't say for sure, but a lot of Glass-air builders are adding similar extensions and report a 5 kt increase at top end and 2 - 3 knots lower stall speed. The key is that the leading edge extensions have the camber line of the airfoil cranked down about 5 degrees, forming a "cuff". The theory works something like this: At high speed, the airflow at the wing root has a localized increase in angle of attack due to the wing/fuselage intersection (in RVs, this is an area of very dirty airflow because of the sharp corner made where the side of the fuselage meets the bottom ). By bending the leading edge down to meet the airflow, the interference drag is reduced. At low speed, the increased camber increases max cl, lowering stall speed. Although increasing cl at the root degrades stall characteristics, the extensions are small enough compared to the overall wing this will not be noticable. Actually, on my wing, the wheels fit within the wing. I am sitting on the fence as to the advantages/disadvantages of inboard doors to cover the wheels when they are retracted. regards, Pat Falley -----Original Message----- From: Scott Johnson [mailto:scottj(at)ais.net] Hi Mark, I happened to see a set of full size plans for an RV8 retractable drawn up by a well known aeronautical engineer. An individual has already started construction on the gear itself. I would like to be able to tell you more, but it was the persons wishes not to divulge the specifics at this time. I felt privileged being able to see the plans. Scott Johnson scottj(at)ais.net -----Original Message----- From: Mark S. Jennings <markjenn(at)halcyon.com> > >I know this cuts against the grain of the KISS/cheap philosophy the Van >exposes, but are there any rumors of a retract RV8? Has anyone looked into >what would be required? Is there room in the wing? > >The 8 has a nice mini-T28 look about it, a retract option would really >complete the picture. > >- Mark > > ________________________________________________________________________________
Date: Mar 26, 1999
Rory Filer [4438] wrote: > > > Hi > > Sears has one of its tool sales on in my area. Last night I went to > look at the bandsaws (not on sale :( and drillpresses. The salesman > said that the bandsaws weren't very good for cutting metal because > the filings just trash the plastic coating on the wheels used to > transport the blade 'round. > > All the bandsaws I've seen in the lower price ranges seem to have this > plastic coating on the drive wheels. Has shredded plastic on the drive > wheels been a problem for anyone out there? > > He also said that Sears didn't sell any blades for metal cutting. Do > most of you use the stock blade, or do you buy metal cutting blades > somewhere else? Rory - I bought the small three wheel bandsaw from Sears and have not had any problems cutting metal with the wood blades. I use 1/8" x 12 teeth and get a smooth cut. I have found no damage to the wheels and the only maintenance needed it to vacuum out the interior of the saw monthly and wipe off the wheels. I have built my entire RV-6 with it and have only used three blades. Don't use the blades on fiberglass - you get a really dull blade that won't touch metal real quick. ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Re: Electric gyros - AI & DG
>Do they generally last longer than vacuums or less long?? My information is that they last about the same length of time. If you are religious about taking care of your filter in the pneumatic system, vacuum gyros last a long time. OTOH, vacuum pumps fail much more often so I would guess that from a system point of view, i.e. taking all the components into consideration, an electric gyro system will suffer fewer failures. >Other than cost, are there any other disadvantages? I can't think of any. I have an all electric gyro panel in my RV-4. I am happy with it. Backup electrical power is easier to come by than backup pneumatic power IMHO. >I figure the same but vacuum and with a vacuum system would cost about >$1500 and be more work and less weight. It would be easier with electrics >to have a removable section. That is true. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax O- ________________________________________________________________________________
Subject: Finding a GOOD Engine - Parts 1 & 2
Date: Mar 26, 1999
In an effort to repay the RV-List for all the help provided, in building our dream. We are providing a history of our search for a good used O-360 Lycoming engine and it's performance. I hope this helps others. Chuck & Dave Rowbotham RV-8A - awaiting QB Part 1 - The Education As a first time builder (building a RV-8A), I have lost sleep over many things. However, engine selection ranks far and away as the leader. I had accepted Van's recommendation of a Lycoming engine, early on, and originally planned on buying a new engine from Van's. When my partner (my son David) and I decided to go with the Quick Build kit, the budget said no way. I began my research and the more I investigated the greater the stress level rose. Almost everyone had a horror story about buying used engines and most overhaulers. I became convinced that unless you were in the "Business" forever, you can only hope to be very lucky. I contacted all the Salvage yards, talked to anyone remotely connected with aviation, called almost every overhauler in Trade-A-Plane and felt less comfortable with each additional contact. I was also pleasantly surprised at how much time and advice was provided by almost everyone I talked to. My problem was that I wanted the confidence that a new engine provided, but had a tight budget (still do) that said I could afford a mid-time engine. I talked to Aero Sport and while they are well respected, the budget still said mid-time engine. In late December, I contacted Fred Strucklen, and requested one of his famous flights. Fred very generously obliged and we flew with him in his beautiful RV-6A in January. After the flight, I asked him about his engine. He described how he had an engine builder in Florida build an engine for him, from the specifications he provided. Fred also said that, following his nose gear collapse, how the builder tore down the engine, checked it out, reassembled it and sent it back to him for approximately $1500. When asked for the builder's name he said Dick Waters of Air-Tec. Fred also spent considerable time with me identifying many items that should be included/confirmed prior to buying an engine. - Thanks Fred for everything - I called Dick Waters a couple of days later and discussed what I was looking for. He had a three of engines available, but they were either the wrong size or too expensive. Dick and I spent a considerable amount of time discussing what I was looking for and his business philosophy, including warranty. By this time, I knew the major questions to ask and could talk the basic terminology. Part 2 - The Engine Dick Waters called me in early February and said he was getting an engine in that might meet my requirements. It was an IO-360 C1E6 (200hp) from a Seneca. The engine had been overhauled, by Air-Tec, following a prop strike and now had 1038 hours. Dick said he was going to tear the engine down, check it out and if it was good would give me a call. I said that I might be interested, but I'd need the engine converted to an IO-360 A1B6 configuration. He said that he would do the conversion and estimated that the total cost to be around $13,500. The engine would come with a two year warranty on the crank and case and a one year warranty on the cylinders - all beginning from the first flight. In addition, the engine comes with a vacuum pump and prop governor. Dick called back on March 3rd and said the crank and flange had checked out and was yellow tagged. He will be installing full sets of rings, bearings (3 over) rod & main. I asked him about installing a light weight alternator and starter. He agreed to replace both for an additional $449. Dick also said that he was sending out the Bendix fuel injection servo to be checked out and yellow tagged and estimated the additional cost to be around $100. When I informed the RV-List that I thought I had found an engine I received a few responses that suggested that I should be careful in dealing with Mr. Waters. While no one could identify anyone who had a problem with Mr. Waters they seemed to remember hearing that someone did. A few responders also said that they knew someone who had bought one of Mr.Water's engines and had no problems. I called or wrote to a number of people mentioned and confirmed that they had heard something but couldn't remember who had the problem. I started to have second thoughts, but realized that anyone who has been in business for a number of years and sold thousands of engines was bound to have a few problems. This was confirmed in the latest Aviation Consumer's article on engine overhaulers. The issue really comes down to this: do I trust Dick Waters. One of things I remembered from a couple of responses was this statement: "Dick had been in the business for a long time and wasn't going to disappear tomorrow". Based on all this information and a gut feeling, I have concluded that Dick Waters is who he claims to be, an honest business man of the old school, who is willing to sign his name to what he builds/sells and will stand behind his work. I will update this history with Part 3 - The Purchase, when we finalize the deal, hopefully within the next two weeks. Chuck & Dave Rowbotham RV-8A ________________________________________________________________________________
Date: Mar 26, 1999
Paul said of retractable gear: >I decided against it as it would only provide > MAYBE 5 knots and add 600+ hours and $15,000+ to the project. These costs are just a start. You have to maintain it and it is *MUCH* more expensve to maintain than fixed gear. I had to have 34V's gear overhauled a few years ago and I repressed the memory of the costs. Beech knows how to turn base metals into gold! Your insurance will probably be significantly more expensive to cover your inevitable wheels up landing. They say that there are those who have landed wheels up and those who will. I hope I can get Valentine in the air and the Debonair sold before I do it. There is one other advantage other than speed and that is that when emergency landing on water or mush, doing it wheels up may save flipping. Hal Kempthorne RV-6AQ -- Hangar H-4 at SCK - Fitting cowl, controls halk(at)sybase.com Santa Clara, CA. Debonair N6134V @ SJC ________________________________________________________________________________
Date: Mar 26, 1999
Hi Doug Thanks for taking the time to send some information. It's all new stuff to me, but I'm finding the RV-list a great help. Looking forward to getting started! Regards Rory Filer > Rory - I bought the small three wheel bandsaw from Sears and have not had any > problems cutting metal with the wood blades. I use 1/8" x 12 teeth and get a smooth > cut. I have found no damage to the wheels and the only maintenance needed it to > vacuum out the interior of the saw monthly and wipe off the wheels. I have built my > entire RV-6 with it and have only used three blades. Don't use the blades on > fiberglass - you get a really dull blade that won't touch metal real quick. > > > > > ________________________________________________________________________________
Subject: strange blank mails
Date: Mar 26, 1999
Hi, for several days I receive attached blank mail from the RV list server. Yesterday alone five of them. Does anyone have an idea what is going on there? loef -----Ursprngliche Nachricht----- Von: owner-rv-list-server(at)matronics.com Datum: Donnerstag, 25. Mrz 1999 20:08 | | +--------------------------------------- ----------------------------------- | The RV-List is sponsored by Matronics, makers of fine Aircraft | Avionics, and by the generous Contributions of List members. | +--------------------------------------- ----------------------------------- | Matronics: http://www.matronics.com | RV-List: http://www.matronics.com/rv-list | List Subscribe/Unsubscribe: http://www.matronics.com/subscribe | Archive Search Engine: http://www.matronics.com/search | Archive Browsing: http://www.matronics.com/archives http://www.matronics.com/contribution | Other Email Lists: http://www.matronics.com/other | +--------------------------------------- ----------------------------------- | | | ________________________________________________________________________________
Subject: Re: Rear seat vent bracket
Date: Mar 26, 1999
> >The plans for F-814J, rear seat vent bracket say to make it from AA3 063 >3/4x3/4. I can't find any of this angle, nor can I find it listed in my >fuselage inventory. Should it actually be made from an AA3 angle or scrap >from an earlier part? If it is to be made from scrap, how can I tell T3 >from T6 material? > >Thanks >Scott A. Jordan >80331 Scott, There should be enough of the AA3 stock in the kit. I ran short right at the end of the fuselage kit, and had to borrow 13.5" for the front seat back assembly. The vent bracket isn't a critical airframe component, so most any suitable stock...T3, T6 or whatever should work out. I wouldn't use the bent, .032" angle, it would be rather flimsy. I know the "phantom parts" list on the inventory sheet can be quite hard to figure out...it gave me fits too. Don't let it waste too much of your time though. Just find some 3/4x3/4 angle, cut the three inch piece, and get on with it. Extra bits of angle and sheet stock will likely need to be purchased later anyway. Just my experience. Your mileage may vary. Brian Denk RV8 #379 engine ships monday. ________________________________________________________________________________
Subject: RV3 vs Midget
Date: Mar 27, 1999
Brad- I purchased the plans for the M-1, and after talking with some people about flight characteristics, cockpit room, etc., and seeing both the M-1 and RV-3, I went with the RV-3. Some of my reasoning behind going with the -3: - If I remember correctly, the M-1 has about a 20-21" wide cockpit vs. the RV-3's 24" wide cockpit. it mad a big difference for me being about 215 and broad shouldered. - The M-1 has a laminar flow airfoil that if not true to it's shape or you have inconsistencies in the bend of the leading edge, you can get some "wild rides" and different flying characteristics between bird-to-bird. I know of a M-2 owner that has some slight inconsistencies in his leading edge (same airfoil as the M-1 I believe) and has some straight-ass nasty stall tendencies in the thing. The pilot who flew the thing back for the owner from the east coast was turning base-to-final and had the aircraft start to go into a spin on him! Needless to say, he doesn't care for the craft at all?!? I think that you will find the -3 an easier airplane to fly and especially land! There are some advantages to the M-1 though, that include: higher cruise speeds on less HP, no bad history of wing departures, smaller airframes for smaller engines=less fuel, etc., etc. Rob Reece RV-3 SN45 Socorro, NM 505-835-3644 ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Re: Finding a GOOD Engine - Parts 1 & 2
> > In an effort to repay the RV-List for all the help provided, in >building our dream. We are providing a history of our search for a good >used O-360 Lycoming engine and it's performance. I hope this helps >others. If you are building an RV and are thinking about your engine options, consider buying a run-out core and doing your own rebuild. You can end up with a champagne engine on a beer budget. I did and I am very happy with the result. I have an O-320-D2J in my RV-4. A local A&P looked over my shoulder and signed off the logbook so I ended up with a zero-time-SMOH engine. The price was, IMHO, reasonable for what I ended up with (my overhaul ended up costing me about $9000). For that I ended up with a zero-time engine with reworked cylinders, new mags, overhauled carb, overhauled fuel pump, but with the old starter and alternator. The flat-four engines from Lycoming are simplicity incarnate. Of all the components, the following are the ones you need to be good: crank cases gears connecting rods If you are lucky you may get to reuse the camshaft. I was lucky and we only had to resurface the cam (less than 0.002" removed anywhere). When I started the engine was already in the RV-4. It had 2600 hrs SNEW. At about 2000 hrs it was removed from a C-172 and installed in the RV-4. It flew another 600 hrs in the RV-4 before I decided to overhaul it. When we tore it down everything seemed to be in pretty good shape. I removed all external components; e.g. alternator, generator, mags, carb, fuel pump, etc.; and the cylinders. The cylinders went to Lycon where they were reworked; e.g. bored +0.010, minor head cracks welded, ported, polished, etc.; and built up with new valves, guides, springs, pistons, rings, wrist pins, and plugs. The bottom end went to Nickson Machine where they tore down the bottom end, inspected everything, and returned the pieces. Good stuff was reworked and yellow tagged. I was lucky and the cam came back yellow tagged (don't count on this happening to you). They also pressed new bushings in the cases where appropriate. The build-up was rather anticlimatic. It took about a month to get all the new parts (small bolts, rod-end bolts, bearings, gaskets, seals, lifter bodies, lifters, etc.). It took two weekends to actually assemble the engine. I am sure that an experienced shop could do this much more rapidly but I have the pleasure of knowing the status of every component in the engine. I know that every bolt had its torque checked three times. Not only that but I know exactly how an O-320 goes together. I would have no qualms about doing major repairs to this engine in the future. I have put over 60 hours on the engine including the recent trip to Minneapolis and Rocky Mountain crossing. The engine has settled down to using about 1 quart of oil every 20 hours (it used only 1 quart on my trip to Minneapolis and back). I am statisfied that this engine is as good as anything I could get from any rebuilder or from Lycoming. If you consider that this engine has a core value of $3,500 then my engine ended up costing me about $12,500. That seems pretty reasonable to me. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax O- ________________________________________________________________________________
From: "Steven B. Janicki" <sjanicki(at)us.oracle.com>
Subject: Re: Engine inhibiting and Pre-Oilers
Date: Mar 26, 1999
Thanks! I am also investigating a connection between the sump and the oil pressure sensor outlet. ----- Original Message ----- From: Christopher Heitman <cjh(at)execpc.com> Sent: Friday, March 26, 1999 6:11 AM Subject: Re: RV-List: Engine inhibiting and Pre-Oilers > > So far I have only installed them in race cars. On wet sump engines this was > done by adding a tee in the return line from the oil cooler. The oil cooler > was plumbed to a sandwich plate between the block and spin-on oil filter. I > am not sure of the best way to add to a Lycoming. > > Chris Heitman > cjh(at)execpc.com > considering RV9 when available > > -----Original Message----- > >Chris, Can you share how you installed the Accusump system in your RV? I am > >ordering an Accusump for my RV-4 though I must admit that I am uncertain as > >to the best hookup. > > ________________________________________________________________________________
Subject: Re: More engine experiences (long)
Date: Mar 26, 1999
> > In an effort to repay the RV-List for all the help provided, in >building our dream. We are providing a history of our search for a good >used O-360 Lycoming engine and it's performance. I hope this helps >others. > > Chuck & Dave Rowbotham Chuck and Dave, Your experiences in your engine search practically parallel mine. I, too lost sleep, and even got downright grouchy at times from the sheer mental angst over such a large purchase for a rather simple piece of machinery. Russell Duffy and I exchanged numerous emails over this topic...from buying new, to buying very old, to something in the middle..and never coming up with a really warm fuzzy feeling inside with either of these options. It truly is a compromise. The recent experiences with brand new Lycomings in factory fresh Skyhawks at Embry Riddle added some clarity to the picture: NEW doesn't necessarily mean GOOD. Still, there is a warranty to cover it. This IS a valuable asset. I chatted at length with Mr. Waters several months ago, and also felt comfortable with our discussion. He had several O-360's coming in from Europe, most with high time, but that's since factory new. Still, that would likely present the need for at least a top overhaul within a year or so. This didn't quite appeal to me. I think you'll do fine with him, and you have learned how and what to ask at the right time. An educated consumer seldom gets taken advantage of. My next idea was to call various rebuilders around the country. I've lost track of how many. All were in the $15k price range, and all told of vast experience and seemed honest and patient with me. One didn't return my calls, and was eliminated. I then contacted Bart Lalonde. I placed a "request" for him to build up an O-360 with a used crankshaft. Well, these buggers seem to be a true rarity. So, three months later, no crankshaft, and I'm still financially unable to afford the "full meal deal". If the funds were available, I would not hesitate an instant to write a check to Bart. A more skilled and talented engine builder would be hard to find. So, now it's nearing the end of March, I've sprouted a few gray hairs over this dilemma, and I have an airplane that needs an engine. NOW! During this time, I read everything I could find, from Lycoming, Tony Bingelis, John Schwaner, etc. This, and discussions at length with my trusted A&P/IA friend, (where would I be without ya, Mike?) at least left me able to ask the right questions. I called Central Air Parts, since they obviously have been around for a long time. I believe this would not be the case were they to have shoddy ethics or lack of customer relations skills. Jerry at CAP was very easy to talk with, and not once did I feel a "get on with it buddy, do ya want it or not?" attitude. Every question was answered, if he couldn't offer an answer, he pulled the logbooks, and read verbatim what they said. He offered the name of the aircraft owner in Florida, where the engine came from as well. I double checked the N number registry, it all was exactly as Jerry said it was. Jerry offered to run the engine on the test stand for me...while I watch. Too bad it's 1000 miles away! I decided to go ahead with it. I made an offer (less than the stated price in Trade a Plane, by the way), they accepted, and thus I now own an engine. It's not HERE yet...so it ain't over! It should be here late next week...with a few extra goodies thrown in...FREE OF CHARGE. These items would cost me over $400 if purchased elsewhere. I'll update the list of any discrepancies I find with the engine. We plan to dye penetrant check various areas, dial the flange, and check compressions right out of the crate. It's an O-360A4J, with the sump changed out to a standard, "A" or "M" configuration. It has 300 hrs. SMOH from Certified Engines in Florida. It has no damage history, and the aircraft it came out of was totalled when a neighboring, parked aircraft ran into it during a storm while they were (at least in theory) tied down. The gear never collapsed, thus the prop did not touch the ground. Okay, time to go wire something. I hope I've helped out somewhat. Brian Denk ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Re: strange blank mails
In a message dated 3/26/99 1:38:50 PM Pacific Standard Time, irlgmbh(at)okay.net writes: << Does anyone have an idea what is going on there? >> Not a clue on this, but I have had the same, and deleted the same. do not archive ________________________________________________________________________________
Date: Mar 26, 1999
> >Listers, > >Does any one have a list or where I can find a list of "What must be included >in an overhauled engine" The local FSDO claimed that its any part that is >necessary to make the engine run. Case, Cam, Crank, Cylinders, Spark Plugs, >Mags, Harness, >Carb or Fuel Injector, Starter. I don't believe that it includes accessories. That means that you can overhaul but technically use the same starter, alternator, mags, carb, etc. >If any of the above are left out - What do you have. ? A Repaired >Engine.....This is not an overhaul but a repair. I don't think you are quite correct about that. >Is the Oil Pump part of the overhaul.... Yes, it is. All of the different oil pump ADs require you to change the oil pump any time you open up the accessory housing so you must change it to the approved config at overhaul time anyway. >I could use all the imput you have since I paid for a Overhauled IO360 C1E6 >and I did not get 2 Overhauled Mags, Starter, Spark Plugs, and I am being >charged an additional 377.00 for the Oil Pump. In short he wants more money >than a factory new, zero time would have cost me. When you get an engine from Lycoming, sometimes it does not come with starter and/or alternator and, surprisingly, sometimes it does. No, I have not been able to figure out how to know if you are or aren't going to get these things. Not too long ago my father bought a factory overhauled O-540 for our Comanche and it came with new Slick retard-breaker (shower-of-sparks) mags, alternator, and lightweight starter. Go figure. If your engine was overhauled before the most recent oil pump AD, you might have the steel/aluminum gear combination. I would have to go back and check the AD but, as I recall, you have until TBO (2000 hrs) or something like the year 2001 to change it out. I can't imagine that it was overhauled that long ago tho'. The AD on the oil pump came out a couple years ago. If they didn't do the new oil pump gears and housing at that time, the engine is not airworthy. It is for reasons like this that I chose to overhaul my engine myself. I knew *exactly* what I was getting. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax O- ________________________________________________________________________________
From: dralle(at)matronics.com (Matt Dralle 925-606-1001)
Date: Mar 26, 1999
"Re: RV-List: strange blank mails" (Mar 26, 5:00pm)
>-------------- ><< Does > anyone have an idea what is going on > there? >> > >Not a clue on this, but I have had the same, and deleted the same. > >-------------- Every once in a while the Matronics email computers system crashes (a possible harddisk problem I'm looking into). Depending on how many outgoing messages are in the queue at the time of the crash, a few of these blank messages get sent out for some reason. Best thing to do is just hit the delete key... Matt -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Vent bracket
>There should be enough of the AA3 stock in the kit.< Actually, there isn't any. This caught my attention because the plans say to use T3 063 3/4x3/4 and I didn't have any. Vans answered and said that all 063 3/4x3/4 angle they ship is T6, not what the plans call for. Knowing it can't be too critical, I grabbed a piece of "scrap" angle and made the piece. Don't know why they don't just say to make it from any 3/4x3/4 angle. Now, if it would only warm up I could get a lot of priming done and jig the bulkheads. Scott A. Jordan 80331 ________________________________________________________________________________
Date: Mar 26, 1999
>Should we be boycotting Electronics International too? Didn't they >start >this whole thing by sueing JPI in the first place? > >Bruce Green > I think you accidently got it backwards. E.I. was sued by JPI for the use of scanner in there Smart Scanner, and Ultimate Scanner products. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Date: Mar 26, 1999
>I am wondering about what to put on my RV-8 landing gear legs for >corrosion protection. Will they flex enough to cause problems with >any types of paint or powder coating? > >I assume that I need something pretty tough, or it will wear off the >LG leg at the wear plates. Or, will anything I put on wear there, >and I just need to put some grease in that area to protect from rust? - A very small coating of grease is not a bad idea because most any coating that is on these surfaces will wear through. Pay particular attention to the note in the construction man. about re-torquing intervals for the gear attach bolts. If you have a heavy buildup of powder coat or paint that may be wearing away over time, then the intervals should maybe be reduced. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Re: drill press/bandsaw question
Rory Filer [4438] wrote: > > > Hi > > Sears has one of its tool sales on in my area. Last night I went to > look at the bandsaws (not on sale :( and drillpresses. The salesman > said that the bandsaws weren't very good for cutting metal because > the filings just trash the plastic coating on the wheels used to > transport the blade 'round. > > All the bandsaws I've seen in the lower price ranges seem to have this > plastic coating on the drive wheels. Has shredded plastic on the drive > wheels been a problem for anyone out there? > I use a Tradesman 10 inch bandsaw(ACE hardware) and the plastic wheels have replaceable rubber bands around them that the blade rides on. This saves the plastic wheel. I have replaced them once in two years. > He also said that Sears didn't sell any blades for metal cutting. Do > most of you use the stock blade, or do you buy metal cutting blades > somewhere else? Wrong, that's were I buy mine. Part #926655 14 tpi metal cutting blade for non-ferrous metal. Don't even think about trying to cut steel with it. Will ruin the blade in one revolution(don't ask how I know)!! > Rory Filer - RV-6A (Stocking the shop) > Jerry Calvert Edmond Ok -6 wings ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Engine And Prop For Sale
I have an 0-360A1A engine 0 since major overhaul and 0 since overhaul McCauley constant speed propeller for sale $18,000 for both. Contact me off list at jerrydd(at)earthlink.net or 1-800-221-3418 Jerry Doyal ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Re: RV3 vs Midget
Rob: I found your discussion very interesting comparing the M1 to the RV-3. My first Home built was a MII, It was very hard to get the leading edges uniform, as at that time we was using 1/8" rivets. I had some tricky stall characteristics. I was doing some stall strip test on the wing because it gave no warning when it would stall, It was very docile at the very first break of the stall, but if you continued to hold it in a stall condition it would break to the right and have a tendency to roll over on it's back and just fall like a leaf until the speed built up, and the nose would drop and then it would start flying again about 1,000ft later. To say the least it would scare the hell out of you. My second home built was a RV- 6, a real honest airplane. I sold it in Oct. after flying it for 6 years, I was OK for about 2 month before I had to have another RV, This time I am Building a RV-6AQB. I should receive my kit in may, I can't hardly wait to get started. My only worry now is finding an 0-360 engine. I hope this was not to boring as I have flown both airplanes and there is no comparison. Harv- waiting Do not arcive Rob Reece wrote: > > Brad- > > I purchased the plans for the M-1, and after talking with some people about > flight characteristics, cockpit room, etc., and seeing both the M-1 and > RV-3, I went with the RV-3. > > Some of my reasoning behind going with the -3: > - If I remember correctly, the M-1 has about a 20-21" wide cockpit vs. the > RV-3's 24" wide cockpit. it mad a big difference for me being about 215 and > broad shouldered. > > - The M-1 has a laminar flow airfoil that if not true to it's shape or you > have inconsistencies in the bend of the leading edge, you can get some "wild > rides" and different flying characteristics between bird-to-bird. I know of > a M-2 owner that has some slight inconsistencies in his leading edge (same > airfoil as the M-1 I believe) and has some straight-ass nasty stall > tendencies in the thing. The pilot who flew the thing back for the owner > from the east coast was turning base-to-final and had the aircraft start to > go into a spin on him! Needless to say, he doesn't care for the craft at > all?!? I think that you will find the -3 an easier airplane to fly and > especially land! > > There are some advantages to the M-1 though, that include: higher cruise > speeds on less HP, no bad history of wing departures, smaller airframes for > smaller engines=less fuel, etc., etc. > > Rob Reece > RV-3 SN45 > Socorro, NM > 505-835-3644 > > Matronics: http://www.matronics.com > RV-List: http://www.matronics.com/rv-list > Archive Search Engine: http://www.matronics.com/search > Archive Browsing: http://www.matronics.com/archives > Other Email Lists: http://www.matronics.com/other ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Sun and Fun?
I was off the list for several weeks. Has there been any talk of Van's banquet? Bernie Kerr, 6A engine and panel, SE Fla ________________________________________________________________________________
Date: Mar 26, 1999
>><< Does >> anyone have an idea what is going on >> there? >> >> >>Not a clue on this, but I have had the same, and deleted the same. >> >>-------------- I figured it was someone like me. Didn't have anything interesting to say and didn't want to get flamed for not saying it. John D ________________________________________________________________________________
Date: Mar 26, 1999
In a message dated 3/26/99 9:10:04 AM Pacific Standard Time, rfiler(at)glenvan.glenayre.com writes: << Hi Sears has one of its tool sales on in my area. Last night I went to look at the bandsaws (not on sale :( and drillpresses. The salesman said that the bandsaws weren't very good for cutting metal because the filings just trash the plastic coating on the wheels used to transport the blade 'round. All the bandsaws I've seen in the lower price ranges seem to have this plastic coating on the drive wheels. Has shredded plastic on the drive wheels been a problem for anyone out there? He also said that Sears didn't sell any blades for metal cutting. Do most of you use the stock blade, or do you buy metal cutting blades somewhere else? Rory Filer - RV-6A (Stocking the shop) >> It has been my experience that I get more band saw or drill press for my money at Harbor Freight than I do at Sears.. Fred LaForge RV-4 50 hrs & Flying great ________________________________________________________________________________
Date: Mar 26, 1999
Subject: Re: RV-List : JPI's LAST MISTAKE
In a message dated 3/26/99 5:48:35 PM Pacific Standard Time, smcdaniels(at)Juno.com writes: << E.I. was sued by JPI for the use of scanner in there Smart Scanner, and Ultimate Scanner products. >> If this is so, IMO it is our solemn duty to bring JPI down hard. This crap must stop!! I realize that this is so reminiscent of the little Chihuahua chanting Viva Gorditas in the Taco Bell spots, but are you with me? Let's say it all together... NO JPI! NO JPI! Viva Matronics! Viva FuelScan! All of you need to talk this up at your Chapter meetings and everyone attending SnF needs to express our collective disapproval of JPI to them in no uncertain terms. They should emerge from SnF bruised, battered (not necessarily in that order) and with empty order books. Definitely feeling my Gorditas and possibly even my huevos rancheros, -GV ________________________________________________________________________________
Date: Mar 27, 1999
From: "Charles P. Kuss" <chaskuss(at)miami.gdi.net>
Subject: Re: Sun and Fun?
Bernie & listers, I had to call Van's today. I goofed and had to order some new leading edge ribs. I wasn't happy with the way my left leading edge skin fit. I ordered a ticket to the banquet while I had my sorely overworked credit card out! :-( The banquet is Tuesday the 13th, at 6:30pm. Tickets are $18 for the chicken and $25 for the steak. I almost lost out on the banquet last year because I waited till noon, the day of the banquet last year, to buy a ticket. They had all been sold. I lucked out because while I was at Van's tent, a gentleman with a family emergency came in. He had bought 2 tickets and wanted to return them. I got 1 of them. :-) Don't wait, get yours now. Charlie Kuss RV-8 moving on to the fuel tanks while I await new ribs. Boca Raton, Fl. > I was off the list for several weeks. Has there been any talk of Van's > banquet? > > Bernie Kerr, 6A engine and panel, SE Fla ________________________________________________________________________________
Date: Mar 26, 1999
Hi Bernie, As I seem to recall, you sent a message to Van's (that passed by me) last week asking about the banquet. Did they ever respond to you? Just trying to do some customer service QC here... Have a great day, ~Jeremy **Jeremy W. Benedict * jwb(at)europa.com * (503) 514-3100 vm/pager** **Intel-Hawthorne * RV-x Pilot** SD: I maintain the official Van's web site, but I am not an employee of Van's Aircraft, Inc., so this e-mail is not an official response. > >I was off the list for several weeks. Has there been any talk of Van's >banquet? > >Bernie Kerr, 6A engine and panel, SE Fla > > ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Re: Sun'nFun, Crate Sizes, RVator, Mountains
Geez, looks like I can't even practice what I preach with making sure to use correct e-mail header info and such... :-) Oh well. But since I'm out here in public rv-list land, I may as well add something useful for everyone. Pertaining to a recent discussion on e-mail/crate sizes/shipping, etc., if you ever need to know the size of the RV kit crates, they are available on-line. Just surf over to the Van's web site (www.vansaircraft.com), click on "Aircraft Kits", then click on either "Standard" or "QuickBuild"; the respective info is near the bottom of each page. Also, for those who salivate upon hearing the mailperson arrive, don't despair about not seeing an RVator in the box--it shouldn't be long before it's there... Finally, if you will allow me to comment on the recent mountain flying discussion: when cross-country flying "across the mountains", I am not "mountain flying." Two different things. For someone just trying to get from one side of the country to the other, this can be an important distinction. Of course, I am not saying that flying "across the mountains" requires absolutely no training, preparation, or special awareness...it does. Just different. BTW: Where I live, we have many 3000'-8000' "hills", and a couple "mountains." Have a great day out there in RV-land everyone, Jeremy jwb(at)europa.com Usual disclaimer applies... > >Hi Bernie, > >As I seem to recall, you sent a message to Van's (that passed by me) last >week asking about the banquet. Did they ever respond to you? Just trying >to do some customer service QC here... > >Have a great day, >~Jeremy >**Jeremy W. Benedict * jwb(at)europa.com * (503) 514-3100 vm/pager** >**Intel-Hawthorne * RV-x Pilot** > >SD: I maintain the official Van's web site, but I am not an employee of >Van's Aircraft, Inc., so this e-mail is not an official response. > > >> >>I was off the list for several weeks. Has there been any talk of Van's >>banquet? >> >>Bernie Kerr, 6A engine and panel, SE Fla >> >> > > ________________________________________________________________________________
Subject: Lycoming, LPE and Ceramic coatings
Date: Mar 27, 1999
Just purchased an IO-360A1B6D from MOD Works and I'm now looking to have this "Mid" time (1300 SMO) engine overhauled. I was wonder if any of the RV-List listeners have (or are going to have) Darus Zehrbach from Light Power Engine (LPE) Corp. ceramic coat their engine's exhaust stack and valve faces? I'm also considering electronic ignition and electronic fuel injection from LPE. I don't know a thing about him or his company. Very curious: If someone has some first-hand experiences please pass them on. Also, Darus (LPE) uses T.W. Smith as their overhaul shop. Any good/bad experiences with T.W.? Thanks Paul Imhof RV-8 #80024 - QB On gear, tail on, working on rear seat and floor. ________________________________________________________________________________
Date: Mar 27, 1999
In a message dated 3/27/99 3:15:38 AM Eastern Standard Time, jwb(at)europa.com writes: << Hi Bernie, As I seem to recall, you sent a message to Van's (that passed by me) last week asking about the banquet. Did they ever respond to you? Just trying to do some customer service QC here... Have a great day, ~Jeremy ** >> Hi Jeremy, Yes and no. Scott wrote back and said he would check on it and get back, but he never did. Bernie ________________________________________________________________________________
Date: Mar 27, 1999
Subject: RV towbars
From the "for what it's worth department," I was told by my brother ( an RV-4 builder) that the Deluxe Cessna Towbar (A/C Spruce p/n 13-01540---$36.00) would fit perfectly over the 9/16th bolts on Van's tailwheels. So I bought one. He was absolutely right!!! It sure has taken the work out of moving my Three around in the hangar. My back is also very happy!! Fits fine and I suspect it will out last me! Enjoy, Chuck Brietigam, RV-3's forever!! ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Eletric Gyros
> Other than cost, are there any other disadvantages? Yes. You want to have two independent sets of gyros, each with its own power source, so that a single failure won't wipe 'em all out. That's why conventional arrangements have an electric turn coordinator and the other gyros are vacuum. You can lose either system and still have enough information to control the airplane. Note that electric pitot heat is part of that design, too -- lose electrics, you lose the turn coordinator and possibly the airspeed. Lose vacuum, and you can still fly partial panel. I would not (and did not) go all electric. Ed Wischmeyer RV-4 for sale http://www.ath.tis.net/~sbuc/rv6/forsale.html ________________________________________________________________________________
Subject: Noise cancelling headsets
Date: Mar 27, 1999
Some time ago I purchased a Headsets, Inc. noise cancelling kit for my Peltors. Works great, but I am getting tired of replacing 9 volt batteries (I'm not always so good at remembering to turn it off ) and that little battery box is forever getting in the way. The company told me it would be toast if connected directly to my electrical system due to fluctuations of some sort and that I should purchase a devise from them which would prevent this. However, this devise costs an additional $75 which makes the total investment more than I wish to spend on my old headsets. I'm hoping that such a devise is really quite simple and inexpensive to build myself. Any words of wisdom from the list? Ivan Haecker rv-4 550hrs. p.s. noise cancelling is heaven on earth! ________________________________________________________________________________
Date: Mar 27, 1999
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: Re: Eletric Gyros
> >> Other than cost, are there any other disadvantages? > >Yes. You want to have two independent sets of gyros, each with its own power >source, so that a single failure won't wipe 'em all out. That's why >conventional arrangements have an electric turn coordinator and the other >gyros are vacuum. You can lose either system and still have enough information >to control the airplane. Note that electric pitot heat is part of that design, >too -- lose electrics, you lose the turn coordinator and possibly the >airspeed. Lose vacuum, and you can still fly partial panel. > >I would not (and did not) go all electric. > Given the dismal history of certified aircraft electrical systems, pilots are justified in their distrust of airplanes all-electric. As designers and builders of the best aircraft ever, we're free to look into modern alternatives for hardware and architecture of electrical systems. It's now possible to install alternators with exemplarly track records in real airplanes. Further, it's also possible to install dual alternators and dual batteries with a lower total system weight than most of our certified brothers are lugging around. Flight system reliabilty far exceeding the capabilites of a brand new Cessna's alternator/battery/vacuum pump combination is a piece of cake . . . Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Independence Kansas: the > < jurasic park of aviation. > < The source for brand new > < 40 year old airplanes. > ================================ ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Re: Alt Belt
><< . Has anyone tied a spare alternator belt to the baffling and > have it servive for any period of time. >> >That is an old crop-duster trick to save time during the busy season, I was >told. I fly a friends Glasair and it has two belts tied to the engine hoist >point on top of the engine. I know they were there for the last 300 or so >hours with no problem. Why store a loose belt UNDER the cowl? I think the "spare belt trick" was to have a second belt over the prop shaft and behind the propeller secured in a way that would keep it out of the way of moving parts. If the main belt broke, one could "replace" it without having to pull the prop. Use Gates belts and replace at first sign of fuzzies or cracking. Like batteries, tires, cylinder rings, etc the key to reliable operation is to monitor performance and replace BEFORE failure. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Independence Kansas: the > < jurasic park of aviation. > < The source for brand new > < 40 year old airplanes. > ================================ ________________________________________________________________________________
Date: Mar 27, 1999
Subject: IFR Garmin installation
I wrote Garmin a note regarding installation and was not real happy with their answer. Has anyone worked with a dealer and if so, how much did they charge? ---------------------------------------------------------------- Subj: GNS 430 Question Date: 3/26/99 9:58:37 PM Eastern Standard Time From: Kerrjb I have heard a rumor that I can not do the installation of this unit in RV6 experimental airplane. Is this true. TIA Bernie Kerr kerrjb(at)aol.com ----------------------------------------------- Date: 3/27/99 11:59:56 AM Eastern Standard Time From: Mike.Franke(at)garmin.com (Franke, Mike) Bernie, In the interest of safety and reliability all Garmin IFR equipment must be purchased and installed by a qualified Garmin avionics dealer. Most of the dealers will be willing to work with you so that you can stay personally involved with the installation. Our avionics product support group will answer any questions about the installation you may have but the installation will have to be performed by the dealer. Thank you and best Regards, Mike Franke Aviation Support Specialist GARMIN International 1200 E. 151st Street Olathe, KS 66062 USA http://www.garmin.com/ ________________________________________________________________________________
Date: Mar 27, 1999
Subject: FUEL TANK LEAK
Derek McMaster-Carr Hardware has stainless steel pan head screws machined with silicone o-rings under the head: 8-32 x 1/2 #90825a816 10-32 x 1/2 #90825a916 phone# 562-692-5911 Wayne Bonesteel Derek Reed wrote: > > What is really needed is fuel proof nut plates that have built > >in "O" > >rings to seal when the screw is tightened. They are expensive I am sure, > >but I > >am sure they would stop the leaks. ________________________________________________________________________________
Date: Mar 27, 1999
I have a sears direct drive bandsaw I have used to saw most parts. I have also bought a metal cutting bandssaw from Northern Hydraulics for cutting angle and tubing. It was a cheep one but has been the best investment so far. For the sears bandsaw you need a metal cutting blade. There are many suppliers that will make a blade while you wait. Check the yellow pages for people who sharpen blades. If you can't find one check with a machine shop to see where they get their blades. Hope this helps. Working on canopy and ready to mount wings on RV-4. "Roy Filer [4438]" wrote: > > > Hi > > Sears has one of its tool sales on in my area. Last night I went to > look at the bandsaws (not on sale :( and drillpresses. The salesman > said that the bandsaws weren't very good for cutting metal because > the filings just trash the plastic coating on the wheels used to > transport the blade 'round. > > All the bandsaws I've seen in the lower price ranges seem to have this > plastic coating on the drive wheels. Has shredded plastic on the drive > wheels been a problem for anyone out there? > > He also said that Sears didn't sell any blades for metal cutting. Do > most of you use the stock blade, or do you buy metal cutting blades > somewhere else? > > Rory Filer - RV-6A (Stocking the shop) > > > > > > > I purchased to Sears non adjustable speed bandsaw and it works great. I > > bought the adjustable speed bandsaw a couple of years later to cut steel > > tubing for my Pitts. It's a piece of junk! Doesn't even cut aluminum well. > > I'd be glad to sell it if anyone is interested! > > > > -Gene Gottschalk > > RV6A, N700RV > > Frederick, Maryland > > > > > > > >I have the Craftsman variable speed bandsaw with a non-ferrous metal cutting > > >blade and it works well on the aluminum speed setting. Wear eye protection > > >of course, as it occasionally flings a chip skyward. The Sears drill press > > >looks OK but also check Harbor Freight (see archives) as their $59 (on sale > > >sometimes) inch drill press has served me well on the empennage. > > > > > >Good luck! > > > > > >Phil Smith > > > > > ________________________________________________________________________________
Date: Mar 27, 1999
Hi Ross: Some of my thoughts and ideas on installed inhibiting and pre oilers. Assumeing the engine was properly inhibited and was stored upside down with the cylinders well oiled before hanging, all I would do is keep the dehydrator plugs in good shape and avoid turning the crankshaft until ready to start it. Then just before starting it preoil it. Remember preoiling does not lubricate the cam lobes and lifters so cranking should be kept to a minumum. With clean dry plugs and properly primed it should start in the first three or four blades. As soon as there is an indication of oil pressure go to 1000-1100 RPM to supply some sprayed oil to the cam lobes and lifters as well as the wrist pins and cylinders. A simple and inexpensive way to preoil is to install a suitable steel fitting where the plug is above the left mag in the area of the oil cooler fitting. Then with a new one or two gallon size clean garden type pump up spray can connect to the fitting in the engine and run at least a quart of warm oil into the engine then cap and safety wire and start the engine. This fitting will now be available to preoil anytime in the future and will require nothing more than the removal of the top cowling and connecting the spray can. It will take a bit of innovating to rig up the proper connections for the pump up can and be sure to use a steel fitting in the back of the engine and the proper one to accept a cap. A tip on rigging up the spray can, either replace the hose from the can with another hose if you want to save the spray nozzle then useing another piece of hose insert a piece of aluminum tubing in the end with a flaired end and the correct nut to fit your engine fitting. By saving the hose and spray nozzle you can use the spray can to wash the engine down with varsol. Ideally preoiling should be done anytime the engine has been idle for more than thirty days . Eustace Bowhay Blind Bay, B.C. Skinning fueselage on the 6A ---------- > From: Ross Mickey <rmickey(at)ix.netcom.com> > To: rv-list(at)matronics.com > Subject: Re: RV-List: Engine inhibiting and Pre-Oilers > Date: Thursday, March 25, 1999 2:17 PM > > > Eustace, > > I have been considering installing a Pre-Oiler and am now wondering if this > could be used as a 'longer term storage" aid for installed engines. I have > a Pegasus catalog ( http://www.execpc.com/~pegasus/ ) which shows a > Heavy-Duty Electric Solenoid Activated Accusump in one, two and three quart > capacity for $230, $275 and $275. I see that they work by storing pressure > during engine operation. This might make it unsuitable for preserving an > installed engine unless it could be charged with an air compressor. Do you > or anyone else know about this system? > > Ross Mickey > 6A - Finishing kit > > -----Original Message----- > From: Eustace Bowhay <ebowhay(at)shuswap.net> > > >It has been suggested that preoiling can be done through the steel fitting > >that your oil pressure line connects to but in a lot of installations this > >fitting can not be removed after the engine is installed and because it has > >a restriction in it makes it almost impossable to get any voume of oil > >through it. > > > > > > > ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Storing engine
I plan on getting an engine around 1 1/2 to 2 years in advance so the tips that Eustace has been posting on engine storage have really been of interest to me. I was pondering the thought of placing the engine on a tire and rotating occassionally to circulate the oil and had an idea. I am considering modifying a car engine stand to hold the lycoming. Possibly mounting the lyc on the engine mount and mounting the engine mount to a flat steel plate that would be attached to the engine stand. This would make rotating the engine very simple and lessen the possiblity of damaging the engine. Has anyone built something like this?? A big thanks to Eustace Bowhay for his tips!!! Jerry Calvert Edmond Ok -6 wings ________________________________________________________________________________
Date: Mar 27, 1999
From: Charlie and Tupper England <cengland(at)netdoor.com>
Subject: Re: Noise cancelling headsets
baremetl wrote: > > > Some time ago I purchased a Headsets, Inc. noise cancelling kit for my > Peltors. Works great, but I am getting tired of replacing 9 volt batteries > (I'm not always so good at remembering to turn it off ) and that little > battery box is forever getting in the way. The company told me it would be > toast if connected directly to my electrical system due to fluctuations of > some sort and that I should purchase a devise from them which would prevent > this. However, this devise costs an additional $75 which makes the total > investment more than I wish to spend on my old headsets. I'm hoping that > such a devise is really quite simple and inexpensive to build myself. Any > words of wisdom from the list? > Ivan Haecker rv-4 550hrs. p.s. noise cancelling is heaven on earth! piece of cake. LM7809 3-terminal positive regulator or equivilant from any electronics supply house. Input (12 V bus in plane), ground, and 9 volt output (the 09 in 7809) to the head set. Ask for the to220 package. It's a plastic square about 3/8"X3/8"X1/8" thick with a metal tab for mounting & heat sinking. Mount in the smallest aluminum box you're comfortable working in & this will supply the heat sink. The box should cost more than the regulator. Charlie ________________________________________________________________________________
Date: Mar 26, 1999
Subject: ARROW
Please forgive me for asking such an elementary question, but I can't remember how to decipher the mnemonic ARROW, which is intended to remind us what documentation must be aboard an aircraft during flight. I got this far, but I'm guessing at the O: Airworthiness certificate Registration R ??? Operating handbook (?) Weight and balance records FAR Part 91.302 only prescribes the first two of these documents. Would someone kindly help out a brain-dead old man with the missing elements? Many thanks and best wishes, Jack Abell ________________________________________________________________________________
Date: Mar 27, 1999
In a message dated 3/27/99 4:16:25 PM Eastern Standard Time, ebowhay(at)shuswap.net writes: << It will take a bit of innovating to rig up the proper connections for the pump up can and be sure to use a steel fitting in the back of the engine and the proper one to accept a cap. >> Eustace, Why do you say use a steel fitting here? My brand new Lycoming has aluminum AN fitting on the engine. Van's told me they were going to retract their statement to only use steel fittings on the engine. TIA, Bernie Kerr, 6A engne and panel, SE Fla ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Re: ARROW
"John B. Abell" wrote: > > > Please forgive me for asking such an elementary question, but I can't > remember how to decipher the mnemonic ARROW, which is intended to remind > us what documentation must be aboard an aircraft during flight. I got > this far, but I'm guessing at the O: > > Airworthiness certificate > Registration > R ??? > Operating handbook (?) > Weight and balance records > > FAR Part 91.302 only prescribes the first two of these documents. Would > someone kindly help out a brain-dead old man with the missing elements? > > Many thanks and best wishes, > > Jack Abell > > Used to be Radio station license but they are not needed anymore. ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Re: Storing engine
jerry calvert wrote: > > > I plan on getting an engine around 1 1/2 to 2 years in advance so the > tips that Eustace has been posting on engine storage have really been of > interest to me. I was pondering the thought of placing the engine on a > tire and rotating occassionally to circulate the oil and had an idea. I > am considering modifying a car engine stand to hold the lycoming. > Possibly mounting the lyc on the engine mount and mounting the engine > mount to a flat steel plate that would be attached to the engine stand. > This would make rotating the engine very simple and lessen the > possiblity of damaging the engine. > > Has anyone built something like this?? > > A big thanks to Eustace Bowhay for his tips!!! > > Jerry Calvert > Edmond Ok -6 wings How about a plywood disc, diameter slightly larger than engine width, bolted to the prop flange & one bolted to the motor mount. Think lazy; it makes you efficient. ________________________________________________________________________________
Date: Mar 27, 1999
Subject: New RV-6 Panel (Best Yet) Web page support for matt
Listers I have updated my page in support of Matt, I now sport the NO JPI Logo, and it will stay until this is resolved. I have a new RV6 Panel on my page that everyone needs to see. It's the best one yet.I have a new page dedicated to RV's I have done, It's under the photos page Check it out!!!. The Panel Pilot. Steve Davis The Panel Pilot panelcut(at)aol.com ________________________________________________________________________________
Subject: Re: ARROW
Date: Mar 27, 1999
Jack It used to be Radio Station License, but that is no longer required. ---------- From: John B. Abell <jbabell(at)mediaone.net> Subject: RV-List: ARROW Date: Friday, March 26, 1999 1:25 AM Please forgive me for asking such an elementary question, but I can't remember how to decipher the mnemonic ARROW, which is intended to remind us what documentation must be aboard an aircraft during flight. I got this far, but I'm guessing at the O: Airworthiness certificate Registration R ??? Operating handbook (?) Weight and balance records FAR Part 91.302 only prescribes the first two of these documents. Would someone kindly help out a brain-dead old man with the missing elements? Many thanks and best wishes, Jack Abell ________________________________________________________________________________
Date: Mar 27, 1999
From: "Shelby Smith" <shelbyrv6a(at)mindspring.com>
Subject: Re: fuel tank leak
Date: Mar 27, 1999
Hi Andy: This is what I did when I built my RV6. Carefully cleaned the area on the tank that the cork gasket rests on and the cover plate. I like to use Alumaprep and submerge the cover for cleaning. I used the cork gasket dry as supplied and installed with the screws as called out in the drawings. Then layed a narrow bead of proseal around the edge say 3/8 wide half on the cover and half on the tank and small amount around each screw. That was in 1991 and haven't had leak. The other thing I liked it didn't cost anything. By keeping the bead around the cover narrow it is not to hard to remove and the same on the screws if one ever has to take the covers of. Eustace Bowhay Blind Bay, B.C. ---------- > From: winterland(at)rkymtnhi.com > To: rv-list(at)matronics.com > Subject: RV-List: fuel tank leak > Date: Monday, March 22, 1999 6:46 AM > > > I have a fuel odor in my cockpit which I've traced to a leak on the > access door at the root of the left tank. > > The tank is now sealed with a cork gasket which certainly needs to be > replaced. Is this method still considered the recomended way to do this? > Is there another material that may be superior? Are there different > grades of cork used for this application? > > Thnaks for any help you can give. > > Andy > > > > > ________________________________________________________________________________
Date: Mar 27, 1999
In a message dated 3/27/99 12:36:33 PM Pacific Standard Time, ebowhay(at)shuswap.net writes: << Ideally preoiling should be done anytime the engine has been idle for more than thirty days . Eustace Bowhay Blind Bay, B.C. Skinning fueselage on the 6A ---------- >> Somebody suggested that I use an air blow gun with a 18 in copper tube extention. Put it down the dipstick tube into the oil, give it a shot of air. You could probably blow lots of oil up on the cam and followers...... and perhaps up the dipstick tube too, so use a rag to shield yourself. F LaForge RV-4 So Cal. ________________________________________________________________________________
by mailhost.ind.ameritech.net (InterMail v03.02.07 118 124) with SMTP id" <
19990327225629.BVLR19793@oemcomputer>
Date: Mar 27, 1999
jerry calvert wrote: > > > I plan on getting an engine around 1 1/2 to 2 years in advance so the > tips that Eustace has been posting on engine storage have really been of > interest to me. I was pondering the thought of placing the engine on a > tire and rotating occassionally to circulate the oil and had an idea. I > am considering modifying a car engine stand to hold the lycoming. > Possibly mounting the lyc on the engine mount and mounting the engine > mount to a flat steel plate that would be attached to the engine stand. > This would make rotating the engine very simple and lessen the > possiblity of damaging the engine. > > Has anyone built something like this?? > > A big thanks to Eustace Bowhay for his tips!!! > > Jerry Calvert > Edmond Ok -6 wings > Jerry, I modified an auto engine stand by using flat stock extenders to fit a Cessna engine mount. Mine didn't rotate because I braced the bottom support to the stand base. However it would have been easy to do so. Keep in mind my stand was home built and was larger than stands I see for sale, so watch the cg. I turned the engine upside down before mounting it and removed it a couple of times during the four years it was stored. This was a suggestion from the A&P that built it for my Cessna, also filling the cylinders with oil followed by draining from the bottom plug. Gary Reynolds RV6A, wiring,plumbing ________________________________________________________________________________
Date: Mar 27, 1999
Hi Berry: For the preoiler fitting I am sure that an aluminum fitting would be fine because there is nothing hooked to it during flight. But over the years I have seen some problems, maybe the aluminum fittings are stronger now I don't know. I am sure the steel fittings are stronger and that is what I have used and gives me the peice of mind. On the other hand even steel will fail under the right circumstances. Had a friend once install a sending unit directly into the back of the engine instead of coming off with flex hose and then to the sending unit. The weight of the sending unit plus the weight of the hose attached to it coupled with the viberation broke it of in flight over 10000 foot mountains pumped all the oil out resulting in a forced landing in a swamp totaling the aircraft. Fortunetly he was able to walk away from it. Eustace ---------- > From: Kerrjb(at)aol.com > To: rv-list(at)matronics.com > Subject: Re: RV-List: Engine inhibiting and Pre-Oilers > Date: Saturday, March 27, 1999 1:48 PM > > > In a message dated 3/27/99 4:16:25 PM Eastern Standard Time, > ebowhay(at)shuswap.net writes: > > << It will take a bit of innovating to rig up the proper connections for the > pump up can and be sure to use a steel fitting in the back of the engine > and the proper one to accept a cap. >> > > > Eustace, > > Why do you say use a steel fitting here? My brand new Lycoming has aluminum AN > fitting on the engine. Van's told me they were going to retract their > statement to only use steel fittings on the engine. > > TIA, > Bernie Kerr, 6A engne and panel, SE Fla > > > > > ________________________________________________________________________________
Date: Mar 27, 1999
Hi Jerry: Just an excellent idea. Safe and very handy for us lazy guys who say "You know I should rotate that engine tomorrow" and it does't get done till next fall. The big plus it would get rotated on a regular basis. Eustace ---------- > From: jerry calvert <calverjl(at)flash.net> > To: rv-list(at)matronics.com > Subject: RV-List: Storing engine > Date: Saturday, March 27, 1999 1:16 PM > > > I plan on getting an engine around 1 1/2 to 2 years in advance so the > tips that Eustace has been posting on engine storage have really been of > interest to me. I was pondering the thought of placing the engine on a > tire and rotating occassionally to circulate the oil and had an idea. I > am considering modifying a car engine stand to hold the lycoming. > Possibly mounting the lyc on the engine mount and mounting the engine > mount to a flat steel plate that would be attached to the engine stand. > This would make rotating the engine very simple and lessen the > possiblity of damaging the engine. > > Has anyone built something like this?? > > A big thanks to Eustace Bowhay for his tips!!! > > Jerry Calvert > Edmond Ok -6 wings > > > > > ________________________________________________________________________________
Subject: Storing Lycoming's way
Date: Mar 27, 1999
Hello List, There has been much discussion lately on preserving engines. I have posted this before but it has not been mentioned in the latest round of discussion. I called Lycoming last November about perserving my new O-320. Tech help told me to fill the engine completely full with new, clean automotive motor oil. Fill from the breater fitting. Then seal the exhaust ports with homemade plates and fill the cylinders through the top plugs. I have hung my engine on my RV-6 so I can fit everything to it. This makes rotating the engine upsidedown impractical. What I did was lift the tailwheel to the garage ceiling so the nose was pointed way down. Then filled the engine full of oil. Lots of oil. The cam has to be submerged because the rear of the engine was the high point. The only problem I have is #1 cyl is on the intake and that intake is not sealed. I will spray oil into the cyclinder through the bottom plug but have not done it yet. It is near TDC so I don't think my procrastination is too detremental. Eustace Bowhay said not to use automotive oil in case you forget its in there. After filling the engine with so much oil, I couldn't forget that experience if I wanted to. Of course Lycoming said the oil is drained thoruoghly and then filled with aircraft oil before running. P.S. DO NOT order long term storage with the engine if you plan on hanging the engine. Rick Caldwell RV-6 coming together in central FL. ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Re: Storing Lycoming's way
Listers, I like Rick's idea for long term engine storage the best. I used to do exactly what he has proposed many times with auto and motorcycle engines. It isn't hard to eliminate problems of oil not being retained in one or more cylinders with an open valve. Remove the valve cover of the cylinder(s) with open valves. Rotate the engine so that the open valve(s) are now closed. Remove the rocker arm for that valve(s). Rotate the engine back to it's original position. Reinstall the valve cover(s). All the engine's valves are now closed. Fill the engine completely with oil. This has the added bonus of minimizing the chance of valve spring "sacking" while stored. (The weakening of a valve spring's tension). Be sure to install a red tag on the appropriate cylinder(s).This is to remind yourself to drain the oil and reinstall the removed rocker arm(s) before use. I also like to install plastic ( a baggie) secured with rubber bands to the carb inlet and all exhaust pipes ( if installed). This helps keep moisture out of the intake and exhaust tracts. Some people use tennis balls in the exhaust pipes. I've lived in humid regions my whole life. In Buffalo, N.Y. you can only use your motorcycle about 5 months a year. I learned really quick what works and what doesn't. Charlie Kuss RV8 working on fuel tank skeletons Boca Raton, Fl. If more is better, too much is just enough! :-) snipped > I called Lycoming last November about perserving my new O-320. Tech > help told me to fill the engine completely full with new, clean > automotive motor oil. Fill from the breater fitting. Then seal the > exhaust ports with homemade plates and fill the cylinders through the > top plugs. > > I have hung my engine on my RV-6 so I can fit everything to it. This > makes rotating the engine upsidedown impractical. What I did was lift > the tailwheel to the garage ceiling so the nose was pointed way down. > Then filled the engine full of oil. Lots of oil. The cam has to be > submerged because the rear of the engine was the high point. > > The only problem I have is #1 cyl is on the intake and that intake is > not sealed. I will spray oil into the cyclinder through the bottom plug > but have not done it yet. It is near TDC so I don't think my > procrastination is too detremental. > Rick Caldwell > RV-6 coming together in central FL. ________________________________________________________________________________
Date: Mar 27, 1999
Subject: JPI issue
As an RV-List subscriber, I have watched with interest as the recent JPI issue has taken its course. I support the RV-List, and Matt Dralle has my respect and thanks for providing builders like me with a ready source of information. Seeing the completion in sight for my own RV-8, it was time for me to make some decisions on avionics. After some thought, On March 11, 1999, I decided to write JPI a letter on my own corporate letterhead, reflecting my views. The letter, a copy of which is attached below, was sent via US Mail on March 11th. The result of my letter was March 13th fax to me from JPI, which in fact was a copy of my own letter with JPI's hand written comments on the bottom. (repeated below in quotes) "Dear Mr. Ross: You Loose, by not having the best equipment in your plane - our country is one of laws, not pub opinion!" Original letter: <> A final thought: Now I will admit that my letter was somewhat less than nice, but I was quite surprised by the arrogance of the hard nosed reply that I received. My only conclusion must be: To hell with JPI. Jon Ross RV-80094 ________________________________________________________________________________
Date: Mar 27, 1999
I believe a lot of the issues with Stalling the MI/MII Mustangs were centered around plans built aircraft. Mustang Aeronautics the latest company to hold the rights to the MI/MII provides full kits with preformed leading edges. This is why RV's are so popular. They are consistent in behavior for the most part because much of the compact bending has been handled at the factory. If you have an MI/MII in kit form you are going to have a more predictable stall Vs. a plans built model. Although you cant do much about the width of the MI you can opt for a bubble canopy which will give you better visibility and a bit more head room. -----Original Message----- From: Rob Reece <reece(at)rt66.com> Date: Friday, March 26, 1999 1:40 PM Subject: RE: RV-List: RV3 vs Midget > >Brad- > >I purchased the plans for the M-1, and after talking with some people about >flight characteristics, cockpit room, etc., and seeing both the M-1 and >RV-3, I went with the RV-3. > >Some of my reasoning behind going with the -3: >- If I remember correctly, the M-1 has about a 20-21" wide cockpit vs. the >RV-3's 24" wide cockpit. it mad a big difference for me being about 215 and >broad shouldered. > >- The M-1 has a laminar flow airfoil that if not true to it's shape or you >have inconsistencies in the bend of the leading edge, you can get some "wild >rides" and different flying characteristics between bird-to-bird. I know of >a M-2 owner that has some slight inconsistencies in his leading edge (same >airfoil as the M-1 I believe) and has some straight-ass nasty stall >tendencies in the thing. The pilot who flew the thing back for the owner >from the east coast was turning base-to-final and had the aircraft start to >go into a spin on him! Needless to say, he doesn't care for the craft at >all?!? I think that you will find the -3 an easier airplane to fly and >especially land! > >There are some advantages to the M-1 though, that include: higher cruise >speeds on less HP, no bad history of wing departures, smaller airframes for >smaller engines=less fuel, etc., etc. > >Rob Reece >RV-3 SN45 >Socorro, NM >505-835-3644 > > name="Steven B Janicki.vcf" filename="Steven B Janicki.vcf" BEGIN:VCARD VERSION:2.1 N:Janicki;Steven;B;Mr. FN:Steven B Janicki ORG:Oracle Corporation;Data Center TITLE:Sr. Director TEL;WORK;VOICE:650-506-2740 TEL;WORK;FAX:650-633-2165 ADR;WORK:;4op4;500 Oracle Pkwy;Redwood Shores;CA;94065;USA Pkwy=3D0D=3D0ARedwood Shores, CA 94065=3D0D=3D0AUSA URL:http://www.oracle.com URL:http://www.oracle.com EMAIL;PREF;INTERNET:sjanicki(at)us.oracle.com EMAIL;INTERNET:sjanicki(at)us.oracle.com REV:19990328T015142Z END:VCARD ________________________________________________________________________________
Subject: Re: JPI issue
Date: Mar 27, 1999
Jon, Thank you for posting JPI's response to your letter. I am still awaiting their response to my (2) letters, FAX and email. While I expected a somewhat negative response, their response to your very professional letter is INCREDIBLE! This response should be made available to aviation media. Chuck Rowbotham RV-8A ________________________________________________________________________________
From: "David Lundquist" <DLUNDQUIST(at)postoffice.worldnet.att.net>
Date: Mar 27, 1999
-----Original Message----- From: JRoss10612(at)aol.com <JRoss10612(at)aol.com> Date: Saturday, March 27, 1999 8:45 PM Subject: RV-List: JPI issue Incredible! They seem to be digging themselves a VERY deep hole. Any reasonable business person would either respond in an apologetic business like tone, or not respond at all. What could they possibly gain by responding in that manner? I must admit that I had earlier felt that some of the posts regarding the JPI situation were a bit heavy handed. Apparently not so. It is clear now that their intention was to intimidate Matt into withdrawing his use of the FuelScan name. This seems to have backfired on a scale which they could not have imagined, and has obviously done irreparable harm to their business. Good. David Lundquist dlundquist(at)worldnet.att.net RV-6 Wings, Long Island NY ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Re: IFR Garmin installation
We did not have the Garmin Installed but the Apollo GX50 and it was a shock when we got the estimate. 1 King Nav Com & the Apollo $5500.00 - becasue it was IFR certified - And the best - Only non precision approaches - Hope it helped BSivori(at)Aol.Com N929RV (Reserved ) N15035 Seneca 1 Wing's Closed. ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Re: ARROW
RADIO LIC - NOT REQUIRED ANY MORE ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Updated "Boycott JPI" page
Listers, I just got back from a business trip (ah, Florida in the spingtime), and discovered JPI's latest pronouncements on their web site. I've updated my web site to expose the nonsense in this latest bit of JPI cranial rectalitis. It's at http://home.earthlink.net/~timrv6a/jpi.html . I welcome your ideas for improving the page. Don't forget, downloadable flyers are at the bottom of the page. I passed out 40 at this week's EAA meeting. ---------- text of new section on my web site: ----------------------- Update 27 March 1999 JPI apparently realized their web page was a transparent pack of lies, and they removed it from their server. Around 24 March they posted a new web page attacking Matronics. (If they move or remove this page like they did their earlier one, click here for a copy I kept.) I must say that this second web page is a much better public relations product. The lies are much more subtle, the "JPI is the injured party" tone is much reduced, and they even included some sections that are true (although irrelevant). JPI's tools in this new web page are: 1. Lies (that's their favorite tool from the last page) 2. Unfounded assertions 3. True (but irrelevant) statements/paragraphs (intended, no doubt, to convince the reader that JPI's position regarding Matronics is legitimate). 4. Blaming the victim 5. Blaming others for JPI's own choice/actions 6. Playing the victim (when JPI is in fact the aggressor) What follows is text from JPI's web page, with analysis and comments. "Dear Mr. Dralle," "I am disappointed that you chose to publicize our letter to you of February 5, 1999. It changes a situation from one that could have been easily resolved by the parties to a public dispute in which personal egos can be perceived to be at stake. We hope that such a situation can be avoided." (Later, JPI continues this theme) "...Our letter of February 5, 1999 was just a letter, not a formal pleading initiating a lawsuit. As stated in the letter, legal action was not going to be sought until February 19, 1999. Our letter offered to answer any questions that you had about our letter and asked you to respect our client's intellectual property rights. You chose instead to make the matter public on the Internet." This is tactic number 4, "Blame The Victim." JPI threatens a baseless law suit, then gets upset when their threats are made public. Note that Matronics has not posted any attacks against JPI. Matronics has not made any assertions about JPI. Matronics simply made JPI's threats public (via email, not a web post), and let the aviation community act as each individual thought appropriate. "I have received several emails and faxes from individuals that have been misinformed regarding the nature of our letter and the trademark rights of J.P. Instruments for SCANNER, SMART SCANNER and DIGISCAN. Since you have chosen not to respond to my to my recent telephone calls, I will assume that you harbor the same misconceptions and will respond accordingly." No, they weren't "misinformed." They saw that JPI's position was baseless, JPI's threats were anti-aviation, and JPI's lies (on the earlier web page) were blatant and transparent. People sent JPI emails and faxes to let JPI know they had been found out. JPI is employing tactic #6, "Playing the Victim." "Since you have chosen not to respond to our telephone calls, we have now filed suit against you and Matronics for trademark infringement and false designation of origin." Tactic 5 "Blaming others for one's own actions." "...However J.P. Instruments can and will prevent other manufacturers from using SCANNER, SMART SCANNER, DIGISCAN or any other confusingly similar mark, such as FUELSCAN, as a trademark for their aircraft parts." It's preposterous to call FuelScan "confusingly similar" to Scanner, Smart Scanner, or Digiscan. FuelScan is a fuel monitor system, while Scanner, Smart Scanner, and Digiscan are all registered trademarks for engine temperature measurement systems. (See http://trademarks.uspto.gov/access/search-mark.html for a description of each of JPI's trademarks.) Here JPI employs tactic #2, "Baseless Assertion" "An appropriate analogy is that people are free to use the word "shell" when referring to seafood and "apple" when referring to fruit. However, a manufacturer or retailer cannot use SHELL for its brand of gasoline or APPLE for its brand of computers because these trademarks are obviously previously established by Shell Oil and Apple Computers, Inc. A search of federal and state trademark databases shows that no other aircraft parts manufacturer has registered SCANNER or any derivative of SCAN as a trademark for its goods." JPI owns the right to the word SCANNER for engine temperature measurement, and nobody disputes that. Matronics is not using the word SCANNER. Matronics is using the word FuelScan, and JPI doesn't own the rights to it. Neither does JPI own rights to the word SCAN. Tactic #3, "True (but irrelevant) paragraph." "J.P. Instruments has spent considerable time and money building goodwill in the SCANNER family of marks including winning a trademark opposition proceeding before the Trademark Trail and Appeal Board ("TTAB") against Electronics International, Inc. Electronics International, Inc. had originally filed an application for the trademark SMART SCANNER. The U.S. Patent and Trademark Office rejected the application. Electronics International, Inc. then filed an opposition to J.P. Instruments' application for SCANNER. Electronics International, Inc. alleged that SCANNER was a generic term that was not protectable as a trademark. Several members of the aviation industry testified on behalf of J.P. Instruments and its trademark rights, including competitors. The TTAB ruled that SCANNER is not a generic term for engine temperature indicators and that the SCANNER trademark had acquired distinctiveness and goodwill amongst consumers such that consumers identify products with the SCANNER mark with a single source, J.P. Instruments. Electronics International, Inc.'s suit was dismissed and it stopped using the trademarks "ULTIMATE SCANNER" and " SMART SCANNER " shortly thereafter." Probably true, but irrelevant. Tactic #3 again. "Another common mistake among faxes and emails that we have received is that J.P. Instrument's product just indicates engine temperature and that your product indicates fuel flow and consumption. J.P. Instruments produces products under the SCANNER family of marks that provide engine temperature, fuel flow and fuel consumption data. Thus, J.P. Instruments and Matronics produce identical products that are identified by trademarks that have "SCAN" as the dominant feature. This makes confusion likely, if not inevitable." JPI's products are NOT identical to Matronics' products. Tactic #1, "Lies." Furthermore, it is absurd to claim that any pilot would somehow "confuse" JPI's cost-a-fortune, EGT/CHT-graphs-galore systems, or their cost-a-fortune does-nothing-but-measure-temps system with Matronic's fuel management system. (I suspect any pilot who would "confuse" JPI's product for Matronics' product would also "confuse" the ground with the sky, and eliminate himself from the marketplace in short order.) "Your public campaign against J.P. Instruments has not helped to alleviate this very real problem. For several days, our phone lines, fax machines and email were bombarded by prank calls, obscene and distasteful letters, and generally confused individuals who are unaware of the valuable trademark rights at stake." JPI seems to believe that anyone who disagrees with JPI's position is "generally confused." I'm certainly not confused enough to believe their lies, nor are hundreds of people who are now boycotting JPI. "In total, J.P. Instruments' sales and operations were disrupted for a number of days thereby forcing us to file suit against you and your company." Oh look, there's our old friend, Tactic #5, "Blaming Others for Your Choices." JPI is just absurd. Just a few paragraphs ago JPI said they filed suit because Matt didn't call them back. Now they say they're filing suit because people expressed their opinions to JPI. It sounds to me like Joe Polizzotto (JPI's owner) needs to grow up and take responsibility for his own behavior. A good therapist could assist in this endeavor. One positive note: we now know that our messages to JPI were received loud and clear. "J.P. Instruments would like sport aviation consumers to know that J.P. Instruments is committed to supplying them with the best quality products and giving the best service we can offer. To do this, our reputation, goodwill and trademark rights must be protected through the vigorous enforcement of our rights. Our action against you and Matronics is in conformity with this policy and the protection of the products and rights we worked so hard to develop and bring to the marketplace." Rubbish. JPI is destroying their reputation and goodwill by vigorously lying in front of an audience of thousands (especially obvious in thier previous web page), and by attacking Matt Dralle, a strong, generous supporter of sport aviaiton. _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ Tim Lewis N47TD (reserved) RV-6AQ #60023, engine completed and tested Springfield VA http://home.earthlink.net/~timrv6a timrv6a(at)iname.com ---------------------------------------------------------------- ________________________________________________________________________________
Date: Mar 27, 1999
Steve, I appreciate your response to the concerns of mine in regards to the M1 and RV3. I am considering trading my Chard RV 6 for a 3 or M1 plus cash to make up the difference. I have two people interested, each with one or the other. Your welcome to look at my webpage were my 6 is . http://www.infowest.com/personal/b/bundyb/ thanks for your help Brad Bundy Flying Chard Built RV6 N48AC -----Original Message----- From: Steven B. Janicki <sjanicki(at)us.oracle.com> Date: Saturday, March 27, 1999 8:06 PM Subject: Re: RV-List: RV3 vs Midget > > >I believe a lot of the issues with Stalling the MI/MII Mustangs were >centered around plans built aircraft. Mustang Aeronautics the latest company >to hold the rights to the MI/MII provides full kits with preformed leading >edges. This is why RV's are so popular. They are consistent in behavior for >the most part because much of the compact bending has been handled at the >factory. If you have an MI/MII in kit form you are going to have a more >predictable stall Vs. a plans built model. > >Although you cant do much about the width of the MI you can opt for a bubble >canopy which will give you better visibility and a bit more head room. > >-----Original Message----- >From: Rob Reece <reece(at)rt66.com> >To: rv-list(at)matronics.com >Date: Friday, March 26, 1999 1:40 PM >Subject: RE: RV-List: RV3 vs Midget > > >> >>Brad- >> >>I purchased the plans for the M-1, and after talking with some people about >>flight characteristics, cockpit room, etc., and seeing both the M-1 and >>RV-3, I went with the RV-3. >> >>Some of my reasoning behind going with the -3: >>- If I remember correctly, the M-1 has about a 20-21" wide cockpit vs. the >>RV-3's 24" wide cockpit. it mad a big difference for me being about 215 >and >>broad shouldered. >> >>- The M-1 has a laminar flow airfoil that if not true to it's shape or you >>have inconsistencies in the bend of the leading edge, you can get some >"wild >>rides" and different flying characteristics between bird-to-bird. I know >of >>a M-2 owner that has some slight inconsistencies in his leading edge (same >>airfoil as the M-1 I believe) and has some straight-ass nasty stall >>tendencies in the thing. The pilot who flew the thing back for the owner >>from the east coast was turning base-to-final and had the aircraft start to >>go into a spin on him! Needless to say, he doesn't care for the craft at >>all?!? I think that you will find the -3 an easier airplane to fly and >>especially land! >> >>There are some advantages to the M-1 though, that include: higher cruise >>speeds on less HP, no bad history of wing departures, smaller airframes for >>smaller engines=less fuel, etc., etc. >> >>Rob Reece >>RV-3 SN45 >>Socorro, NM >>505-835-3644 >> >> > > name="Steven B Janicki.vcf" > filename="Steven B Janicki.vcf" > >BEGIN:VCARD >VERSION:2.1 >N:Janicki;Steven;B;Mr. >FN:Steven B Janicki >ORG:Oracle Corporation;Data Center >TITLE:Sr. Director >TEL;WORK;VOICE:650-506-2740 >TEL;WORK;FAX:650-633-2165 >ADR;WORK:;4op4;500 Oracle Pkwy;Redwood Shores;CA;94065;USA >Pkwy=3D0D=3D0ARedwood Shores, CA 94065=3D0D=3D0AUSA >URL:http://www.oracle.com >URL:http://www.oracle.com >EMAIL;PREF;INTERNET:sjanicki(at)us.oracle.com >EMAIL;INTERNET:sjanicki(at)us.oracle.com >REV:19990328T015142Z >END:VCARD > > ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Re: ARROW
In a message dated 03/27/1999 4:53:39 PM Eastern Standard Time, jsflyrv(at)teleport.com writes: << Airworthiness certificate > Registration > R ??? > Operating handbook (?) > Weight and balance records > > FAR Part 91.302 only prescribes the first two of these documents. Would > someone kindly help out a brain-dead old man with the missing elements? > > Many thanks and best wishes, > > Jack Abell > > Used to be Radio station license but they are not needed anymore. >> Actually, a Radio Station License and a Radio Operators License are required if you are going out of the country. but right, not in the USA. david faile, fairfield, ct mcfii/a&p faa aviation safety counselor eaa technical counselor/flight advisor christen eagle ii since '82 (n13bf) rv6 n44df started ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Air Compressor
I know the subject has been debated at length according to the archive, but I just want to know if some of you have used the following: Central Pneumatic, 2HP, 6.5 Gal, Oil lubricated (quieter?), 3 SCFM @ 90PSI, 3.4 @70. Freight Harbor has it for 129$ this week. The only purpose for which I'll use it will be for riveting (I think I'll pick up a 3X gun, I have the Orndorff's video, and they use a 2X. It has a rapid fire machinegun sound that I don't like too much. At work, the folks use 3X, and it's a bit slower to the ear, which I like better... which one eats more air???) The priming will be done with cans (preloaded), and for the tooling I got most of it electrical and/or cordless. The main reason I tend toward it, it's because it's the smallest oil lubricated compressor I've found. All the others that were 'small' were oil less, thus very noisy. For my current situation, less noise is strongly desirable. Thanks. Rich, -6A Empennage 'soon to be ordered' currently building the 'factory' 98208 ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Re: Air Compressor
In reality, your rivet guns will not use much air. You can drive a lot of rivets between compressor cycles. Air drills & grinders are what keeps the compressor running. L.Adamson ________________________________________________________________________________
Date: Mar 27, 1999
>P.S. DO NOT order long term storage with the engine if you plan on >hanging the engine. Does anyone know exactly what you get when you pay the $200 for long term storage? Russell Duffy Navarre, FL RV-8, sn-587, N174KT (jigging fuselage) ________________________________________________________________________________
Date: Mar 28, 1999
Subject: Re: ARROW
> >Please forgive me for asking such an elementary question, but I can't >remember how to decipher the mnemonic ARROW, which is intended to remind >us what documentation must be aboard an aircraft during flight. I got >this far, but I'm guessing at the O: > > Airworthiness certificate > Registration > R ??? > Operating handbook (?) > Weight and balance records I learned the second R as Radio station license, no longer required for US domestic flights. The O is for Operating limitations, which may include placards, the operations manual, or a combination of both, depending on what was specified at the time of certification. A more lively discussion is likely to erupt by asking about the mnemonic CIGARTIPS. Ask ten pilots, get eleven answers. - Mike hartmann(at)sound.net ________________________________________________________________________________
From: "Steven B. Janicki" <sjanicki(at)us.oracle.com>
Subject: Re: RV3 vs Midget
Date: Mar 27, 1999
Brad, I have seen your RV-6 and can appreciate your situation. I think the decision is not too difficult. If you like your RV-6 then chances are the RV-3 will make you feel at home as it is part of the RV family and thus shares similar flight characteristics. You will need to make certain the wing mod has been completed or compensated for $ allowing you to handle the mod. On the other hand if you want something different then you could opt for the MI. However, if the M1 is plans built then you have to be careful about the quality of the construction and the date it was built, mods, etc. Both have support so you can obtain pre formed parts for repairs, updates, etc. However, there is only 1 RV-List with the best builder support available! I had a -6 which I had to sell for financial reasons. I miss the plane. I am building a -4 as I am comfortable with the RV family but want the inline seating configuration Vs. the -6 side by side. Similar to the Pitts I have been flying. Good luck with your decision. I have been there and I am certain others have as well. -----Original Message----- From: Brad Bundy <bundyb(at)infowest.com> Date: Saturday, March 27, 1999 7:27 PM Subject: Re: RV-List: RV3 vs Midget > >Steve, >I appreciate your response to the concerns of mine in regards to the M1 and >RV3. I am considering trading my Chard RV 6 for a 3 or M1 plus cash to make >up the difference. I have two people interested, each with one or the >other. >Your welcome to look at my webpage were my 6 is . >http://www.infowest.com/personal/b/bundyb/ >thanks for your help >Brad Bundy Flying Chard Built RV6 N48AC >-----Original Message----- >From: Steven B. Janicki <sjanicki(at)us.oracle.com> >To: rv-list(at)matronics.com >Date: Saturday, March 27, 1999 8:06 PM >Subject: Re: RV-List: RV3 vs Midget > > >> >> >>I believe a lot of the issues with Stalling the MI/MII Mustangs were >>centered around plans built aircraft. Mustang Aeronautics the latest >company >>to hold the rights to the MI/MII provides full kits with preformed leading >>edges. This is why RV's are so popular. They are consistent in behavior for >>the most part because much of the compact bending has been handled at the >>factory. If you have an MI/MII in kit form you are going to have a more >>predictable stall Vs. a plans built model. >> >>Although you cant do much about the width of the MI you can opt for a >bubble >>canopy which will give you better visibility and a bit more head room. >> >>-----Original Message----- >>From: Rob Reece <reece(at)rt66.com> >>To: rv-list(at)matronics.com >>Date: Friday, March 26, 1999 1:40 PM >>Subject: RE: RV-List: RV3 vs Midget >> >> >>> >>>Brad- >>> >>>I purchased the plans for the M-1, and after talking with some people >about >>>flight characteristics, cockpit room, etc., and seeing both the M-1 and >>>RV-3, I went with the RV-3. >>> >>>Some of my reasoning behind going with the -3: >>>- If I remember correctly, the M-1 has about a 20-21" wide cockpit vs. the >>>RV-3's 24" wide cockpit. it mad a big difference for me being about 215 >>and >>>broad shouldered. >>> >>>- The M-1 has a laminar flow airfoil that if not true to it's shape or you >>>have inconsistencies in the bend of the leading edge, you can get some >>"wild >>>rides" and different flying characteristics between bird-to-bird. I know >>of >>>a M-2 owner that has some slight inconsistencies in his leading edge (same >>>airfoil as the M-1 I believe) and has some straight-ass nasty stall >>>tendencies in the thing. The pilot who flew the thing back for the owner >>>from the east coast was turning base-to-final and had the aircraft start >to >>>go into a spin on him! Needless to say, he doesn't care for the craft at >>>all?!? I think that you will find the -3 an easier airplane to fly and >>>especially land! >>> >>>There are some advantages to the M-1 though, that include: higher cruise >>>speeds on less HP, no bad history of wing departures, smaller airframes >for >>>smaller engines=less fuel, etc., etc. >>> >>>Rob Reece >>>RV-3 SN45 >>>Socorro, NM >>>505-835-3644 >>> >>> >> >> name="Steven B Janicki.vcf" >> filename="Steven B Janicki.vcf" >> >>BEGIN:VCARD >>VERSION:2.1 >>N:Janicki;Steven;B;Mr. >>FN:Steven B Janicki >>ORG:Oracle Corporation;Data Center >>TITLE:Sr. Director >>TEL;WORK;VOICE:650-506-2740 >>TEL;WORK;FAX:650-633-2165 >>ADR;WORK:;4op4;500 Oracle Pkwy;Redwood Shores;CA;94065;USA >>Pkwy=3D0D=3D0ARedwood Shores, CA 94065=3D0D=3D0AUSA >>URL:http://www.oracle.com >>URL:http://www.oracle.com >>EMAIL;PREF;INTERNET:sjanicki(at)us.oracle.com >>EMAIL;INTERNET:sjanicki(at)us.oracle.com >>REV:19990328T015142Z >>END:VCARD >> >> > > name="Steven B Janicki.vcf" filename="Steven B Janicki.vcf" BEGIN:VCARD VERSION:2.1 N:Janicki;Steven;B;Mr. FN:Steven B Janicki ORG:Oracle Corporation;Data Center TITLE:Sr. Director TEL;WORK;VOICE:650-506-2740 TEL;WORK;FAX:650-633-2165 ADR;WORK:;4op4;500 Oracle Pkwy;Redwood Shores;CA;94065;USA Pkwy=3D0D=3D0ARedwood Shores, CA 94065=3D0D=3D0AUSA URL:http://www.oracle.com URL:http://www.oracle.com EMAIL;PREF;INTERNET:sjanicki(at)us.oracle.com EMAIL;INTERNET:sjanicki(at)us.oracle.com REV:19990328T070858Z END:VCARD ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Re: Throttle/Prop Controls on Panel
Listers: I am on my final version of the panel layout for an RV4. After looking at many RV4s I have found none that have mounted the throttle, prop and or mixture controls directly on the panel. I intend to do this using Cessna style friction controls and vernier controls for the prop rpm. Would appreciate hearing from anyone that has done this instead of the throttle quadrants typically used. Also would like to hear from anyone who has a strong objection or reasoning for keeping the quadrant style controls. Rear seat controls is the only logical reason for positioning quadrant controls on the side of the cockpit. Thanks for replies. Dave Aronson, RV4 finish ________________________________________________________________________________
Date: Mar 27, 1999
Subject: Re: ARROW
ARROW Airworthyness certificate Radio License Registration Operating limitations Weight and balance information Dave Aronson, RV4 finish ________________________________________________________________________________
Date: Mar 27, 1999
>Does anyone know exactly what you get when you pay the $200 for long >term storage? I've posted messages about this in the past in hopes of saving some people from making the mistake I did. I bought the long term storage option thinking it was for the preservative oil and dessicant plugs. NOT SO. Preservative oil is in there regardless, and they don't give you dessicant plugs with or without the long term storage option. What you do get is the engine packed in a vacum sealed bag, and expando-foam filling the space between the bag and the outside of the box. That's it. Since I immediately hung my engine when I got it, the hissing sound I heard when I made the first knife cut in the bag was $200 going out the window. Randall Henderson, RV-6 (instruments/finish) Portland, OR http://www.edt.com/homewing randallh(at)home.com ________________________________________________________________________________
Subject: Re: RV-List : JPI's LAST MISTAKE
Date: Mar 27, 1999
><< E.I. was sued by JPI for the use of scanner in there Smart Scanner, and > Ultimate Scanner products. >> > >If this is so, IMO it is our solemn duty to bring JPI down hard. From reading their "open letter", I'm not sure this is true. It looks like EI tried to get a TM on their SMART SCANNER and it was rejected. They then filed an appeal against JPI's application for the use of SCANNER. JPI in turn filed against EI and won. That's what their letter says anyway, although I now take everything JPI says with a grain of salt. But in fact, if this were what we were debating I wouldn't be writing letters about it. Both of those instruments are engine temperature monitoring gauges and they both had the word SCANNER in the name. I would agree that that's the kind of thing the trademark laws are there for. But of course we aren't talking about similar products in this case, or even two cases of the word SCANNER being used in the name. JPI seems to think that since both instruments are made to be used in airplanes, they will be somehow be confused. Makes me wonder just how dumb JPI thinks aircraft owners are! In their "open letter" they also now seem to have decided that they have a SCANNER line that includes all of their products, I guess to imply that the word SCANNER covers their their one engine temp monitoring gauge that has fuel flow as an option. That doesn't track with any of their literature that I've seen, or with their original "response" which both only mention the word SCANNER in relation to the one original engine temp. moitoring gauge. Plus their trademark record just says under "Goods and Services" ENGINE TEMPERATURE INDICATORS". Nothing about fuel. I think they're grasping at staws here, frankly. Randall Henderson, RV-6 (instruments/finish) Portland, OR http://www.edt.com/homewing randallh(at)home.com ________________________________________________________________________________
Date: Mar 28, 1999
Subject: Re: Electric gyros - AI & DG
Brian Lloyd wrote: > > >Other than cost, are there any other disadvantages? > > I can't think of any. I have an all electric gyro panel in my RV-4. I am > happy with it. Backup electrical power is easier to come by than backup > pneumatic power IMHO. > > >I figure the same but vacuum and with a vacuum system would cost about > >$1500 and be more work and less weight. It would be easier with electrics > >to have a removable section. > > That is true. > I would like to use all electric gyros, for the reasons you mention, but I would also like to put in an autopilot with HEADING SELECT, and I have not been able to locate an electric DG with an autopilot pickup without going to an electric HSI at a cost of $6K or more. Does anyone know if there is electric equivalent of the the 52d54 gyro (I think this is a relatively inexpensive vacuum gyro for use with Century autopilots). I'm actually leaning toward the lower-priced STEC models, so I would love to locate an electric DG that would work with STEC autopilots. STEC has a vacuum DG with autopilot output for about $1500. Anyone know what differences, if any exist between the autopilot outputs (from DGs) for Century and STEC? Blake Harral Blake Harral ________________________________________________________________________________
Date: Mar 28, 1999
Subject: Re: ARROW
Guys, I just mailed in for the Radio "Ship" Lic. It is not a FAA form, but an FCC form which can be obtained via Fax on demand, The fee is $85.00 and its good for 10 years. If you are going out of the country it is a must, or as per the FRG FSDO your aircraft could be impounded.<<<<<<< NO A GOOD THING >>>>>> BSivori(at)AOL.COM ________________________________________________________________________________
Subject: MOD Works
Date: Mar 28, 1999
-----Original Message----- From: B&S Eckstein [mailto:eckstein@net-link.net] Sent: Saturday, March 27, 1999 10:05 PM Paul, I am interested in doing business with Mod Works too. Were they honest to deal with? Does the engine need an overhaul at 1300 hours? Thanks Brian Eckstein eckstein@net-link.net ---------- From: Paul Imhof [mailto:paul_imhof(at)dell.com] All: MOD Works seems to be reasonable to deal with. I pushed really hard to get them to "Guarantee" the case and crank to be Serviceable. They wouldn't put "Guarantee" in their invoice. After much discussion they put: IF CASE OR CRANK IS FOUND TO BE UNREPAIRABLE, MOD WORKS WILL REPLACE WITH NEXT AVAILABLE ENGINE." This statement leaves A LOT to be interpreted: UNREPAIRABLE?... by who's standards; The FAA? AND How long would they honor UNREPAIRABLE... 2 months? 5 years? AFTER subsequent overhauls? etc. I talked with David. He said in the 6 years he's been working there he has only had to take one engine back. Even though this statement is open-end, UNREPAIRABLE means unserviceable by FAA guidelines and probably within 1 year of original sale. The first thing I'll have an overhaul shop do is check the case and crank. I thought I remember him saying they sell about 30+ engines a year. I only know of one other RVer who purchased an engine from them and they are happy too. Here's all the info on the engine I purchased: Lycoming IO-360A1B6D sn: L-17428-51A. It has no prop. strike, no engine log entry of lap or line-bore (assume it never needed it) in the past two major overhauls. Compression is very high and even on all cyl.s. Tested on Friday 3/26 as follows: cyl. #1 - 79, cyl. #2 -79, cyl. #3 - 79, cyl. #4 - 76 It has 1382 SMO and TT of 3803. It is very well maintained with detailed log entries. It came off a '77 Mooney M20-J (N201MG) from MOD Works. The plain flew in (good sign of a working engine) a few weeks ago to MOD Works and the engine is being removed on Monday 3/29/99. COST: $7500 BTW: The typical cost for this type of engine from MOD Works is $9500. They lowered the price 2k to sell it fast. Wednesday morning 3/24 I called to put on a list for an IO-360 engine. They told me of an engine that was just recently came in(last few days). They told me that they didn't have time to call the list of people and asked if I would be interested. By 5pm I had purchased this engine. I don't think I would have paid the extra 2k (normal price $9500). Lesson: Do your research up front. Know exactly what you want and what you are willing to pay. When a good thing comes a long, be prepared to act quickly. As far as does the engine need to be overhauled. NO. but if you are familiar with Lycoming engines, just because it's rated for 2000 hours doesn't mean you can expect 2000 hours out of an engine. This engine was very well maintained. There's no reason why I couldn't put it on my RV-8 right now. Heck I could even do head overhaul. I want the engine to be in tip top shape. I want to know every thing about this engine. Nothing less than a complete overhaul will do. The airframe will be, why not the engine? Thanks Paul Imhof RV-8 #80024 - QB On gear, tail on, working on rear seat and floor. > > > Just purchased an IO-360A1B6D from MOD Works and I'm now looking to have > this "Mid" time (1300 SMO) engine overhauled. > > I was wonder if any of the RV-List listeners have (or are going to have) > Darus Zehrbach from Light Power Engine (LPE) Corp. ceramic coat their > engine's exhaust stack and valve faces? I'm also considering electronic > ignition and electronic fuel injection from LPE. I don't know a thing about > him or his company. Very curious: If someone has some first-hand experiences > please pass them on. > > Also, Darus (LPE) uses T.W. Smith as their overhaul shop. Any good/bad > experiences with T.W.? > > Thanks > Paul Imhof > RV-8 #80024 - QB > On gear, tail on, working on rear seat and floor. > > ________________________________________________________________________________
Date: Mar 28, 1999
Thanks for the product review. This has been in my mind for a long time. I found info at http://www.avweb.com/sponsors/headsets/index.html Thing is though, I saw that the power adapter in their literature was $59.00. Of course it is much too much to pay for just a power adapter but others charge $75.00 for a headset to handheld adapter. I have a cousin that is an electrical and software engineer he now runs a software development department that works with GPS for autos. When he was flight testing his Challenger II we had found some problems. It came to hooking up his handheld com radio to his head set. It wasn't the lack of money but rather his field of experience that made it compulsitory to just solider the "patch cord" together. I was the ground grunt. He was making his taxiing practices. I was monitoring the radio work on a ham radio. I could tell that his signal was very weak and had much more noise in the background. When he came back, we started troubleshooting. That is my field. After the swap and switch routine, it became evident that it narrowed down to the standard plug used for the mike input. What was happening was the input jack has contacts for both leads for the input but also it has a second function. That is a contact that disconnects the mike in the main body of the handheld. What was happening was that both mikes were working. You could hear him talking at half, or so, volume and you could hear cabin noise, Challenger II has lots including air. He purchased the adapter patch cord and all was well. I have never compared the actual standard plug to the patch cord plug, but all it needed to be was a tiny bit longer to push the contact open. I'm not advocating spending the unheard of prices by any means. I really don't thing they use a non-standard plug for those. I have made mike adapters for ham radios to work with computers and those same connectors that were used. I guess with anything, we should always perform tests every time we build something. His radio for all practical purposes didn't work. I was listening on the ground where it was quiet. If I were flying, I would tune my ears to the ambient level of radio noise, give or take a little bit. His transmissions were too low to be heard in that situation. Bill Jaugilas baremetl wrote: > > > Some time ago I purchased a Headsets, Inc. noise cancelling kit for my > Peltors. Works great, but I am getting tired of replacing 9 volt batteries > (I'm not always so good at remembering to turn it off ) and that little > battery box is forever getting in the way. The company told me it would be > toast if connected directly to my electrical system due to fluctuations of > some sort and that I should purchase a devise from them which would prevent > this. However, this devise costs an additional $75 which makes the total > investment more than I wish to spend on my old headsets. I'm hoping that > such a devise is really quite simple and inexpensive to build myself. Any > words of wisdom from the list? > Ivan Haecker rv-4 550hrs. p.s. noise cancelling is heaven on earth! ________________________________________________________________________________
Date: Mar 28, 1999
Subject: Re: ARROW Radio License Form
Unless you leave US borders, ie Canada or May Hee Ko (Mexico), the radio license is not required. If you plan to fly outside US airspace, file form 404 from the FCC. It is available in pdf form from the FCC at: http://www.fcc.gov/formpage.html Scott A. Littfin BSivori(at)aol.com wrote: > > > RADIO LIC - NOT REQUIRED ANY MORE > -- --Scott-- 1986 Corben Junior Ace N3642 RV-4 under construction (tail feathers) Gotta Fly or Gonna Die! ________________________________________________________________________________
Date: Mar 28, 1999
David Aronson wrote: > > > Listers: > > I am on my final version of the panel layout for an RV4. After looking at many > RV4s I have found none that have mounted the throttle, prop and or mixture > controls directly on the panel. I intend to do this using Cessna style friction > controls and vernier controls for the prop rpm. Would appreciate hearing from > anyone that has done this instead of the throttle quadrants typically used. > Also would like to hear from anyone who has a strong objection or reasoning for > keeping the quadrant style controls. Rear seat controls is the only logical > reason for positioning quadrant controls on the side of the cockpit. > > Thanks for replies. > > Dave Aronson, RV4 finish 1. panel real estate is limited, even with a vfr panel. 2. personal preference for fighter cockpit like throttle position. 3. if you use a vernier for the throttle & do any formation flying, you will hate it. Charlie flying -4 ________________________________________________________________________________
Date: Mar 28, 1999
Subject: 9 volt regulator
************Oops!*********** baremetl wrote: > > > Some time ago I purchased a Headsets, Inc. noise cancelling kit for my > Peltors. Works great, but I am getting tired of replacing 9 volt batteries > (I'm not always so good at remembering to turn it off ) and that little > battery box is forever getting in the way. The company told me it would be > toast if connected directly to my electrical system due to fluctuations of > some sort and that I should purchase a devise from them which would prevent > this. However, this devise costs an additional $75 which makes the total > investment more than I wish to spend on my old headsets. I'm hoping that > such a devise is really quite simple and inexpensive to build myself. Any > words of wisdom from the list? > Ivan Haecker rv-4 550hrs. p.s. noise cancelling is heaven on earth! piece of cake. LM7809 3-terminal positive regulator or equivilant from any electronics supply house. Input (12 V bus in plane), ground, and 9 volt output (the 09 in 7809) to the head set. Ask for the to220 package. It's a plastic square about 3/8"X3/8"X1/8" thick with a metal tab for mounting & heat sinking. Mount in the smallest aluminum box you're comfortable working in & this will supply the heat sink. The box should cost more than the regulator. Charlie I "misspoke" myself. The # should be either 7809 or LM340-9. It's been a long time, & I got 2 different manufacturer's numbering systems mixed up. My apologies. http://www.digikey.com/B.DKS$214877175H751660 Above link will take you to one. Also, Radio Shack at one time sold a cigar lighter adaptor with selectable outputs down to around 3 volts. Charlie ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Date: Mar 28, 1999
-----Original Message----- From: Blake Harral <bharral(at)home.com> Date: Sunday, March 28, 1999 2:32 AM Subject: Re: RV-List: Electric gyros - AI & DG > >I would like to use all electric gyros, for the reasons you mention, but >I would also like to put in an autopilot with HEADING SELECT, and I have >not been able to locate an electric DG with an autopilot pickup without >going to an electric HSI at a cost of $6K or more Century Instruments can supply you with a rebuilt DG with heading bug. Several of the avionics houses quoted me a rebuilt DG with heading bug along with the S-Tec AP at much below the S-Tec price. I finally went with a Nav Aid Devices AP. Dennis Persyk 6A finishing kit Hampshire, IL ________________________________________________________________________________
Date: Mar 28, 1999
From: "Charles P. Kuss" <chaskuss(at)miami.gdi.net>
Subject: Teledyne Continental Parts Books/Price list
Listers, Does anyone know where I could obtain a Continental Parts price list and possibly parts books for their 4 & 6 cyl. piston engines? An online source would be ideal. I need to cross-reference the part numbers of engine overhaul parts I've aquired to their useage. TIA Charlie Kuss RV-8 leading edges/fuel tanks Boca Raton, Fl. ________________________________________________________________________________
Subject: Re: Updated "Boycott JPI" page
Date: Mar 28, 1999
I used to have a link to JPI on my web site. I now have a link to Tim's excellent "Boycott JPI" page instead. http://www.duford.com/aviation.htm Sylvain Duford RV-8 #80047 > > Listers, > > I just got back from a business trip (ah, Florida in the spingtime), and > discovered JPI's latest pronouncements on their web site. I've > updated my > web site to expose the nonsense in this latest bit of JPI cranial > rectalitis. It's at http://home.earthlink.net/~timrv6a/jpi.html . > > I welcome your ideas for improving the page. > > Don't forget, downloadable flyers are at the bottom of the page. I > passed out 40 at this week's EAA meeting. > > _+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_ > Tim Lewis > N47TD (reserved) RV-6AQ #60023, engine completed and tested > Springfield VA > http://home.earthlink.net/~timrv6a > timrv6a(at)iname.com > ________________________________________________________________________________
Date: Mar 28, 1999
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: Re: 9 volt regulator
>The # should be either 7809 or LM340-9. It's been a long time, & I got 2 >different manufacturer's numbering systems mixed up. My apologies. > >http://www.digikey.com/B.DKS$214877175H751660 > >Above link will take you to one. > >Also, Radio Shack at one time sold a cigar lighter adaptor with >selectable outputs down to around 3 volts. > >Charlie The 7800 series regulators used to have an 8v version but these are not obsolete parts and rapidly disappearing from catalogs and distributor shelves. The 340 series devices are only available in 5, 12, 15v parts. The LM317 is an adjustable version of the 340 series devices. It requires two resistors to set the output for the desired voltage. In the case of a 9v regulator, a 120 ohm resistor from OUT to ADJ pins and a 750 ohm resistor from ADJ to system ground will produce the desired voltage. For improvment in noise reduction and regulation dynamics, I use small bypass capacitors at the input and output terminals to ground. Our DIM5-14 dimmer can be ordered as a fixed voltage regulator. This device uses the LM317 and the appropriate combination of resistors and capacitors on an etched circuit board with 9 pin d-sub connector for wiring. You can see a picture of it on our website. Also, the article I did on solid state dimming in Sport Aviation is a good baseline for building small stepdown voltage regulators for those who would like to roll-their- own. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Independence Kansas: the > < jurasic park of aviation. > < Your source for brand new > < 40 year old airplanes. > ================================ ________________________________________________________________________________
Date: Mar 28, 1999
Subject: Thorpe T-18 VS RV flying qualities
Hi! Have any of the RV folks out there flown both a Thorpe T-18 and the RV series aircraft? I'm seeking opinions on the two aircrafts' relitive performance, and more importantly, flying qualities. I got a ride in a T-18 yesterday, what a blast! I found, admittedly based on limited time in either the T-18 OR the RV aircraft, that the flying charecteristics were quite similar, they are both a lot of fun to fly. The T-18 is slower, not a lot though. The roll rate was similar, and with two people aboard this particular T-18, with a O320 with high compression LyCon pistons (about 180hp) and a fixed pitch prop I was seeing 1500 fpm climbs and 170 mph cruise. Not bad! We did both power on and power off stall series, the T-18 stall was abrupt with little or no buffet. I understand from hanger flying that some Thorp foks put stall strips on inboard of the wings to give more stall warning though, this airplane did not have them. The stall break was straight ahead though, with little tendancy to drop a wing. Certainly NO comparison to my current (flying) plane, a Cessna 150! Don Gates Tailwheel transition training in process..... ________________________________________________________________________________
From: "Randy Compton" <rdcompton(at)mindspring.com>
Subject: Gear Leg Shimmy
Date: Mar 28, 1999
I'm getting landing gear shimmy, during taxi and during landing rollout, on pavement. The GPS shows about 18 to 20 knots during taxi, and the onset during landing rollout seems to be around 30 knots. Firm braking dampens this somewhat, with no shimmy below 18 knots. Also, during takeoff acceleration, there is no shimmy. The gear legs have the wooden/wrapped fiberglas stiffeners, as per the plans. However, after reading the archives, now I'm paranoid about corrosion. (maybe it's just me, but every time I read these postings I seem to come away with more to worry about :-( ) The tires are McCreary, with a good, even wear pattern. (Perhaps higher quality tires might help) The only suggestion I got from Vans was to try no more than 25psi. I did that, and besides the fact that the tires looked awfully flat, I got only VERY slight improvement in reducing shimmy. Any ideas, other than always avoiding pavement? All this motion can't be good for the long-term health of the airframe/plumbing/etc. Worst of all, it looks bad in front of all my fellow airport bums. :-) These RV's sure are nice to fly, but this gear leg shimmy is a bunch of crap. The designer certainly can't be proud of this quirk. Sluggo Compton RV-3A Gulf Breeze, FL ________________________________________________________________________________
Date: Mar 28, 1999
Subject: Re: Gear Leg Shimmy
Randy Compton wrote: > > > I'm getting landing gear shimmy, during taxi and during landing rollout, on > pavement. > > The GPS shows about 18 to 20 knots during taxi, and the onset during landing > rollout seems to be around 30 knots. Firm braking dampens this somewhat, > with no shimmy below 18 knots. Also, during takeoff acceleration, there is > no shimmy. > > The gear legs have the wooden/wrapped fiberglas stiffeners, as per the > plans. However, after reading the archives, now I'm paranoid about > corrosion. (maybe it's just me, but every time I read these postings I seem > to come away with more to worry about :-( ) > > The tires are McCreary, with a good, even wear pattern. (Perhaps higher > quality tires might help) > > The only suggestion I got from Vans was to try no more than 25psi. I did > that, and besides the fact that the tires looked awfully flat, I got only > VERY slight improvement in reducing shimmy. > > Any ideas, other than always avoiding pavement? All this motion can't be > good for the long-term health of the airframe/plumbing/etc. Worst of all, > it looks bad in front of all my fellow airport bums. :-) > > These RV's sure are nice to fly, but this gear leg shimmy is a bunch of > crap. The designer certainly can't be proud of this quirk. > > Sluggo Compton > RV-3A > Gulf Breeze, FL > Sometimes you guys just blow me away with your remarks. My guess when you built the airplane you put the gear on crooked. ________________________________________________________________________________
Date: Mar 28, 1999
<< Any ideas, other than always avoiding pavement? All this motion can't be good for the long-term health of the airframe/plumbing/etc. Worst of all, it looks bad in front of all my fellow airport bums. :-) >> Sluggo, Some people have had some success by balancing their wheel pants. This sounds a little strange but I have talked to a couple of people who swear it works. I believe they add lead to the front of the pant on the inside until its in balance fore and aft. You might also try several different air pressures on your tires until you find the one that works best. The other option is to try a new set of tires. If they are wearing evenly it sounds like the legs must be drilled properly. Ryan Bendure Co. ________________________________________________________________________________
Date: Mar 28, 1999
Subject: rivet squeeze (sizes) question
rookie here again. i need someone to e mail me or list with some guidelines for rivet dies. i am about to attach the hs flange bars and brackets. rivets used are 470 4's. i ordered from avery the 6 piece squeeze set and not sure what dies i use. also, do i use a flush for the un cuped side of rivet??? any and all help greatly appreciated here. thanx, bob paulovich in arkansas ________________________________________________________________________________
Subject: Re: Thorpe T-18 VS RV flying qualities
Date: Mar 28, 1999
-----Original Message----- From: dgates <dgates(at)techie.com> Date: Sunday, March 28, 1999 12:52 PM Subject: RV-List: Thorpe T-18 VS RV flying qualities > >Hi! >Have any of the RV folks out there flown both a Thorpe T-18 and the RV series aircraft? I'm seeking opinions on the two aircrafts' relitive performance, and more importantly, flying >qualities. > I did have the opportunity to fly a T18. They do fly a lot like the RV at higher air speeds and performance is pretty close with comparable engine and prop. The big difference is in slow flight and landing. The T18 has a higher stall speed and the controls become quite ineffective below 80 mph. The RV on the other hand has full control authority right down to it's 50mph (depends on model) stall. Directional control during roll out is much easier in the RV due to it's wider gear and larger rudder. The T18 is a great airplane but an older design. Martin Sutter RV6 N868CM 1,350hrs ________________________________________________________________________________
Subject: Re: rivet squeeze (sizes) question
Date: Mar 28, 1999
> >rookie here again. i need someone to e mail me or list with some >guidelines for rivet dies. i am about to attach the hs flange bars and >brackets. rivets used are 470 4's. i ordered from avery the 6 piece >squeeze set and not sure what dies i use. also, do i use a flush for the >un cuped side of rivet??? any and all help greatly appreciated here. >thanx, bob paulovich in arkansas > > If you look carefully on the side of the dies I think you'll see a size designation such as -4. You use the rounded die for the factory head and the flush or flat die for the shop head. The factory head is the rounded end and the 'shop' head is the side you form when you squeeze or drive the rivet. John Ammeter Seattle WA USA 1975 Jensen Healey RV-6 (sold 4/98) EAA Technical Counselor NRA Life Member ________________________________________________________________________________
Date: Mar 28, 1999
Bob--- The "4" refers to 4/32" or 1/8". The correct die will have 1/8 470 on the side. Same with a "3", or 3/32". Your correct, the flat die will be used for the unfinished side of the rivet. L.Adamson RV6A Fuselage out of jig (top side work) ________________________________________________________________________________
Date: Mar 28, 1999
Subject: squeezer die question
i see on each die an470 and a size, i.e., 3/32, 1/8, and so forth. what do i use for 470 4's??? thanx again, bob ________________________________________________________________________________
Subject: Re: squeezer die question
Date: Mar 28, 1999
> >i see on each die an470 and a size, i.e., 3/32, 1/8, and so forth. what >do i use for 470 4's??? thanx again, bob > The 470 4's are 4/32" rivets or 1/8". Use the 1/8 for the 470 4's John Ammeter Seattle WA USA 1975 Jensen Healey RV-6 (sold 4/98) EAA Technical Counselor NRA Life Member ________________________________________________________________________________
Date: Mar 28, 1999
In a message dated 3/28/99 2:52:48 PM Mountain Standard Time, jonkarl(at)worldnet.att.net writes: << i see on each die an470 and a size, i.e., 3/32, 1/8, and so forth. what do i use for 470 4's??? thanx again, bob >> Use the 1/8 (4/32) for a 470 4. 3/32 for a 470 3 Universal (cupped rivets) are 470's. Flush (countersunk or dimpled) rivets are the 426's. Once you memorize all of this----- keep working on the project. Quit six months like I did, & you might forget a bunch. L.Adamson ________________________________________________________________________________
Date: Mar 28, 1999
In a message dated 3/28/99 12:47:34 AM Pacific Standard Time, randallh(at)home.com writes: << But in fact, if this were what we were debating I wouldn't be writing letters about it. Both of those instruments are engine temperature monitoring gauges and they both had the word SCANNER in the name. I would agree that that's the kind of thing the trademark laws are there for. But of course we aren't talking about similar products in this case, or even two cases of the word SCANNER being used in the name. >> This is baloney! What if it were a toaster? That's what scanners do...scan. -GV ________________________________________________________________________________
Date: Mar 29, 1999
Just to add to this thread... First, practise on some scrap. The -4 rivets take a fair amount of muscle power to squeeze (mostly I prefer to drive them), and it's hard to not bend the tail end. Secondly, don't rely on Van's rivet length callouts in the plans. In many cases, they're too short. Check the length with a gauge before squeezing/driving. Frank. ________________________________________________________________________________
Date: Mar 28, 1999
Subject: Plastic Brake Lines & Bleeding Problems
I just wanted to pass along my experience from my brake system to the list. I put my brake system together as per the plans, but when I went to bleed the system it seemed to take more pressure than I expected. The rubber line I used kept blowing off the bleeder screw and before I finally got the brakes bled, I had fluid all over. After I finished, I noticed air bubbles appeared in the one of my plastic lines, so I assumed the fitting at the master cylinder was leaking...and it was slightly. I checked it and it was tight. I have worked with compression fittings before, but not on plastic lines. I knew I would need a new fitting but did not want to order them because the shipping would cost more than the fittings. I went to Home Depot and found 1/4" compression fittings for plastic lines and bought some, although the brass insert was about twice the diameter as the ones that came in my kit. I figured it was worth the chance. I took the leaking fitting off and the brass insert fell out. I put the new fitting on and the new insert (twice the diameter), which fit perfect, and re installed it. When I went to bleed the system it did not take much pressure at all and I no longer had the leak. It worked so well that I changed the one on the other line also. Now I no longer have the leaks and the pressure to bleed the system is very small. I had called Van's when I was having the problem bleeding and Tom said I must of hooked up my parking brake valve wrong. The moral of this long story is...if you are having any problems or your inserts for your lines seem too small, buy new ones with the proper inserts. Jim Cimino RV-8 sn 80039 http://www.geocities.com/MotorCity/5771 (717)842-4057 N.E. Pennsylvania ________________________________________________________________________________
Subject: Re: Plastic Brake Lines & Bleeding Problems
Date: Mar 28, 1999
-----Original Message----- From: Jim Cimino <jcimino(at)epix.net> Date: Sunday, March 28, 1999 5:54 PM Subject: RV-List: Plastic Brake Lines & Bleeding Problems > >I just wanted to pass along my experience from my brake system to the list. > I put my brake system together as per the plans, but when I went to bleed >the system it seemed to take more pressure than I expected. The rubber >line I used kept blowing off the bleeder screw and before I finally got the >brakes bled, I had fluid all over. >I went to Home Depot and found 1/4" >compression fittings for plastic lines and bought some, although the brass >insert was about twice the diameter as the ones that came in my kit. I >figured it was worth the chance. I took the leaking fitting off and the >brass insert fell out. I put the new fitting on and the new insert (twice >the diameter), which fit perfect, and re installed it. When I went to >bleed the system it did not take much pressure at all and I no longer had >the leak. It worked so well that I changed the one on the other line also. > Now I no longer have the leaks and the pressure to bleed the system is >very small. >I had called Van's when I was having the problem bleeding and Tom said I >must of hooked up my parking brake valve wrong. >The moral of this long story is...if you are having any problems or your >inserts for your lines seem too small, buy new ones with the proper inserts. > > >Jim Cimino >RV-8 sn 80039 >http://www.geocities.com/MotorCity/5771 >(717)842-4057 N.E. Pennsylvania I noted about two months ago that my brass inserts were very loose in my plastic lines and I had heard that they were very difficult to insert, requiring heating of the line to get them in. I sent a fax to Van's asking what was wrong -- I sent a second fax two days later. Called on fourth day after no response and Tom Green told me they had not had the "small insert" problem for about 5 years and that I must have a very old kit. My kit was about 12 months old. Anyway, the problem was not that the inserts were too small, but that the line supplied was the wrong kind. A couple of weeks later I got some replacement line (after two more telephone calls). The inserts were indeed a tight fit into the correct brake line. Dennis Persyk 6A finishing kit Hampshire, IL ________________________________________________________________________________
Date: Mar 28, 1999
Date-warning: Date header was inserted by TTACS.TTU.EDU
From: "Charles R. Chandler" <ylcrc(at)ttacs.ttu.edu>
Randy Compton wrote: >The GPS shows about 18 to 20 knots during taxi, and the onset during landing >rollout seems to be around 30 knots. Firm braking dampens this somewhat, >with no shimmy below 18 knots. Also, during takeoff acceleration, there is >no shimmy. My RV-3 does the exact same thing when tires are fully inflated. So I keep them underinflated and that eliminates the shimmy. When I have too much air in them, I taxi very slowly and brake when the shimmy starts upon landing. Not an ideal situation but I live with it. If anybody else has a solution, other than putting the gear on straight in the first place, I'd like to hear it. Chuck RV-3 N893FS ________________________________________________________________________________
Date: Mar 28, 1999
Subject: Team Rocket Hats
Hey there Rocket men! Team Rocket now has hats with the Team Rocket emblem embroidered on it. Be a part of the Team. Hats are $12 (plus S+H). To order, just send your request, your return address, and money to: Team Rocket, Inc. 2731 S.E. Tailwinds Rd. Jupiter, FL 33478 Thanks!! Scott Team Rocket, Inc. ________________________________________________________________________________
Date: Mar 28, 1999
Subject: Team Rocket....movie stars??
Hey Rocket men!! The Team Rocket video will begin filming in one week. This is Mark and Scott's film debut...so wish us luck!! Whats next....Hollywood?? Not!! Anyway, we expect that these videos will be completed in about a months time. They will be available in VHS and CD. Thanks! Scott Team Rocket, Inc. ________________________________________________________________________________
Date: Mar 28, 1999
Subject: Re: Team Rocket....movie stars??
Is a rocket still considered an rv hybrid, or it's own "thing"? ________________________________________________________________________________
Date: Mar 28, 1999
David Aronson wrote: After looking at many RV4s I have found none that have mounted the throttle, prop and or mixture controls....using Cessna style friction controls and vernier controls for the prop rpm... instead of the throttle quadrants typically used. Also would like to hear from anyone who has a strong objection or reasoning for keeping the quadrant style controls. I have seen some airplanes that use vernier controls for prop and mixture, while having a Quadrant-style throttle. My memory is not the greatest, but I think both the Extra 300 and Pitts S2B are so configured. This will allow precise prop & mixture control, while allowing more convenient (in my opinion) throttle operation. The quadrant-style throttle is the way to go, IMHO. If you rest your hand edge-down on the quadrant, as if you were trying to remove it from the mount with a karate chop, you can adjust the throttle with thumb and index finger by rocking your hand. Your arm is supported, reducing fatigue and allowing precise throttle movement. Works great for formation flying. I have never flown formation with a knob-style throttle, but I would think that having to move your whole arm fore and aft instead of just flexing your wrist would get real old real fast. Don't plan to fly formation? Well, never say never. With proper training and practice, it is great fun. But I degress. I would think the one of the advantages of building your own airplane is the opportunity for making it ergonomically correct, so it fits YOU, not Joe Average Pilot. Proper placement of controls has a significant effect of comfort and fatigue. Tim Pittsburgh ________________________________________________________________________________
Date: Mar 28, 1999
Subject: crossover exhaust
Hi, Can someone explain the purpose of crossing over the exhaust system on an RV-6? Thanks, Glenn Gordon ________________________________________________________________________________
Date: Mar 29, 1999
This was a common problem on the RV-3. It caused cracks in the gear/engine mount and was fixed by the newer 6-point gear, or gussets/additional tube on the mount. I talked once about this problem with Jim Ayers, and he said that the problem was easily resolvable by balancing the wheelpants with lead shot/epoxy. You may want to contact him at for more specifics on solving your problem. Rob Reece RV-3 SN45 Socorro, NM 505-835-3644 ________________________________________________________________________________
From: dralle(at)matronics.com (Matt Dralle 925-606-1001)
Date: Mar 28, 1999
Subject: Four New Email Lists Now Available!
Dear Listers, I have added four new Email Lists to the existing Lists currently sponsored by Matronics. These include Lists for the Yak, VariEZ/LongEZ, Lancair, and Glasair. Existing Lists include the RV, Zenith, Kolb, and HR Rocket Lists. The new Lists will be run in the same spirit as the existing Email Lists available on the Matronics server including the high-speed web-based archive searching and browsing capabilities as well as the respective List web site. As always, access and subscription to the new Lists is completely free of charge. Generous contributions are, however, always appreciated... ;-) To subscribe to any of the new lists, please refer to the following URL: http://www.matronics.com/subscribe For more information on any of the Lists sponsored by Matronics, please refer to the following URL, and select the particular List of interest: http://www.matronics.com/other.html Thank you for all of your generous support over the years! Best Regards, Matt Dralle Matronics Email List Administrator -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Date: Mar 28, 1999
In a message dated 3/28/99 7:20:18 PM Mountain Standard Time, IMAV8N(at)compuserve.com writes: snipped << The quadrant-style throttle is the way to go, IMHO. If you rest your hand edge-down on the quadrant, as if you were trying to remove it from the mount with a karate chop, you can adjust the throttle with thumb and index finger by rocking your hand. Your arm is supported, reducing fatigue and allowing precise throttle movement. Works great for formation flying. I have never flown formation with a knob-style throttle, but I would think that having to move your whole arm fore and aft instead of just flexing your wrist would get real old real fast. >> I'm still trying to figure out a descent way to install a Piper quadrant in my 6A. I've sat in it twice & find the quadrant could be in the way of my knees & control stick. Not enough room between the seats, & I don't want it to far forward. I'm still exploring options & will think of something. I'm just to used to Piper's & can't stand Cessna type push-pull knobs. Would still like a left hand throttle also. L.Adamson --- top side of 6A fuse. ________________________________________________________________________________
Date: Mar 28, 1999
> >I'm getting landing gear shimmy, during taxi and during landing rollout, on >pavement. > I have a -6 with factory drilled engine mount and gear with the same problem. I took someones bad advise and did not use the wood on the gear legs, and the gear does tend to shake a lot. I have checked the gear alignment and it looks good. I do agree that the gear geometry leaves a lot to be desired. Fo instance if you watch how the gear deflects with weight you will notice that weight changes change the toe in/out. If the gear is unevenly loaded (as in a bounce) it tends to steer the aircraft. One could also imagine that this would tend to cause a gear leg oscillation. Just maybe I'll balance the pants though. Dan Morris Rv6 ________________________________________________________________________________
Date: Mar 28, 1999
"Daniel H. Morris" wrote: > > > > > >I'm getting landing gear shimmy, during taxi and during landing rollout, on > >pavement. > > > > I have a -6 with factory drilled engine mount and gear with the same > problem. I took someones bad advise and did not use the wood on the gear > legs, and the gear does tend to shake a lot. I have checked the gear > alignment and it looks good. I do agree that the gear geometry leaves a lot > to be desired. Fo instance if you watch how the gear deflects with weight > you will notice that weight changes change the toe in/out. If the gear is > unevenly loaded (as in a bounce) it tends to steer the aircraft. One could > also imagine that this would tend to cause a gear leg oscillation. > > Just maybe I'll balance the pants though. > > Dan Morris Rv6 > Dan are you still not using the wood? If not I would take the time to redo them and put it on. I have been there and done that it makes a totally different airplane on the ground. ________________________________________________________________________________
Date: Mar 28, 1999
Subject: First Flight
Just wanted to notify the list that a third RV-8 on our field here at Independence, Oregon made its first flight yesterday. N88CV, built mostly by Greg Robl was flown by Jim Oveross and all went well. We have two additional RV-8's moving along (quickbuilds) here, as well as more in the planning stage. Seems like RV-8 fever is makin the rounds here! Von Alexander N41VA(at)juno.com ________________________________________________________________________________
Date: Mar 28, 1999
Charles R. Chandler wrote: > > > Randy Compton wrote: > >The GPS shows about 18 to 20 knots during taxi, and the onset during landing > >rollout seems to be around 30 knots. Firm braking dampens this somewhat, > >with no shimmy below 18 knots. Also, during takeoff acceleration, there is > >no shimmy. Hi Randy A friend of mine had a continuing wheel shimmey problem with his Cessna 182, tried everything to no avail until he discovered that the wheel itself was out of round (split rim wheel and both halves were out of round). I had my Cessna 182 wheels balanced at a motorcycle shop and that helped somewhat. George McNutt, Langley B.C 6A. Starting to skin fusealage. ________________________________________________________________________________
Date: Mar 29, 1999
From: Charlie and Tupper England <cengland(at)netdoor.com>
Subject: Re: crossover exhaust
Glenn & Judi wrote: > > > Hi, > > Can someone explain the purpose of crossing over the exhaust system on > an RV-6? > > Thanks, > Glenn Gordon It's for "tuning" the exaust to some degree. Or more like "interference reduction" between the exaust pulses. Charlie ________________________________________________________________________________
Date: Mar 28, 1999
Subject: AvWeb's "AVflash" covers JPI vs Matronics!
FLASH! Just got this weeks AvFlash email list mailing, AvWeb is covering the JPI thing. See http://www.avweb.com/newswire/news9913.html#3 for AvWeb's coverage of the JPI vs Matronics issue! I feel this is GREAT news! This will widen the awareness of JPI's predatory actions to the *entire" aviation community, or at least a large part of it. I don't know what AvWeb's circulation is, but I'm confident that it's in the 100K range. Don Gates ________________________________________________________________________________
Date: Mar 29, 1999
Recently, I noticed that it was a little hard to push my 1026 pound RV-6 across a smooth hangar floor. I checked the tire pressure and found that between 20 and 22 psi were in the tires after previous airing some time ago. To make the plane easier to push out of the hangar (and to taxi on grass runways occasionally) I put around 40 - 45 psi in the tires and went flying. Big mistake! On the landing roll out the gear legs (and wheel pants) began to vibrate so violently, the tower advised me of the condition. (Like I couldn't tell?) I applied braking to attenuate the vibrating landing gear until I was slowed to taxi speed (where the vibrating stopped). I taxied to my hangar and bled the tire pressure down to the 30 - 32 psi range and went flying again. The problem just went away! It is plain and simply a small matter of proper tire pressure! Another thing to consider is balancing the wheel pants by epoxying some B-B shot in the nose of the pants. If you pick up the pants by two fingers at the axle points, you will notice the tail end is the heavy end. Pour some B-Bs in a small sandwich bag and tape the bag to the nose end of the pants. Pick up the pants by the axle points again and check the balance. Adjust the contents of the sandwich bag until you have almost enough B-Bs to balance the pants. Thoroughly clean the inside nose area of the pants with solvent to remove that waxy stuff on the surface, and then use a course sandpaper to roughen the area for better adhesion of fibreglas resin. Now, stand the pants on their noses, mix up some epoxy resin, and paint the resin inside the nose of the pants, pour in the B-Bs and fill with resin to cover them. Let the pants stand on their nose until the epoxy hardens. Neat, huh? Now, the wheel pants are balanced. Note: The inner tubes in the tires are notoriously porous. It is important that you check (and air up) your tires at least once a month. Or, if your airplane is hard to push. Whichever comes first. Your mileage may vary. Fly to eat, eat to fly! JNice51355(at)aol.com wrote: > > > > << If anybody else has a solution, > other than putting the gear on straight in the first place, I'd like to hear > it. >> Marshall "every flight is a flying lesson" Dues RV-6 N243MD 199.4 hrs DWH airport (NW Houston area) ________________________________________________________________________________
Date: Mar 29, 1999
<< I have a -6 with factory drilled engine mount and gear with the same problem. I took someones bad advise and did not use the wood on the gear legs, and the gear does tend to shake a lot. >> I dont know if I would consider it bad advise. It takes quite a few extra hours of work to install the stiffeners. I decided that I would fly mine first without and install later if needed. I am happy with that decision as I did not need them. I do sometimes get a slight shimmy at around 15mph but thats about it. I simply avoid that speed for taxi. Ryan Bendure Co. ________________________________________________________________________________
Date: Mar 29, 1999
My -4 didn't have a shimmy problem until I put new tires on it last month. Now, as I get to a fast taxi speed and start braking, it starts shimmying. I think I put the tire on wrong. (Didn't align the balance mark up with the tube). I'll try fixing it when I would rather work on it, than fly it. ________________________________________________________________________________
Date: Mar 29, 1999
Subject: F-1/HR2 differences
<< Is a rocket still considered an rv hybrid, or it's own "thing"? >> Hmmmmmmm.....How about this: The F-1 is a stand alone kit, but the change-over kit from John will let you construct a hybrid. The F-1 has many changes from the HR2, so much so that we decided to give it a different designation. Now, it is true that the two ship will LOOK similiar, but the changes to the interior structure are significant. The F-1 is a production ship, and thus cannot have any of the fit problems usually associated with homebuilt aircraft kits. This was the focus of most modifications applied to the ship during its re- design. I hope this helps! Check six! Mark Team Rocket ________________________________________________________________________________
Date: Mar 29, 1999
Randy, I found that a difference in tire air pressure made a big difference in how the gear handled on concrete/tarmac. When my tires are pressurized to 25-30 psi, the gear interaction with the concrete is just not noticable. However, when I once pressured the tires to 55 psi the gear/runway interaction was very noticable and unpleasant. There was much more viberation transmitted to the fuselage, the main tires tended to skip when they hit uneveness - which make braking interesting - and the nose tire indicated a tendency to shimmy. Lower tire pressure tended to eliminate those adverse effects. Ed Anderson Randy Compton wrote: > > > I'm getting landing gear shimmy, during taxi and during landing rollout, on > pavement. > > The GPS shows about 18 to 20 knots during taxi, and the onset during landing > rollout seems to be around 30 knots. Firm braking dampens this somewhat, > with no shimmy below 18 knots. Also, during takeoff acceleration, there is > no shimmy. > > The gear legs have the wooden/wrapped fiberglas stiffeners, as per the > plans. However, after reading the archives, now I'm paranoid about > corrosion. (maybe it's just me, but every time I read these postings I seem > to come away with more to worry about :-( ) > > The tires are McCreary, with a good, even wear pattern. (Perhaps higher > quality tires might help) > > The only suggestion I got from Vans was to try no more than 25psi. I did > that, and besides the fact that the tires looked awfully flat, I got only > VERY slight improvement in reducing shimmy. > > Any ideas, other than always avoiding pavement? All this motion can't be > good for the long-term health of the airframe/plumbing/etc. Worst of all, > it looks bad in front of all my fellow airport bums. :-) > > These RV's sure are nice to fly, but this gear leg shimmy is a bunch of > crap. The designer certainly can't be proud of this quirk. > > Sluggo Compton > RV-3A > Gulf Breeze, FL > ________________________________________________________________________________
Date: Mar 29, 1999
In a message dated 3/28/99 2:50:59 PM Eastern Standard Time, rdcompton(at)mindspring.com writes: > Any ideas, other than always avoiding pavement? All this motion can't be > good for the long-term health of the airframe/plumbing/etc. Worst of all, > it looks bad in front of all my fellow airport bums. :-) On my -6a, the first 100 hours were shimmy free, then I removed the tires and reversed them on their respective wheels to promote even wear. Now during roll-out when I slow below about 30 mph, the right wheel shimmys a little. I've tried different air pressure's, etc. All it takes is a little brake application and it quits. It isn't bothersome, and I realize it has to do with the wear patterns on the tires, so I figure as long as it doesn't get any worse, when I replace the tires it will probably go away. Mark LaBoyteaux RV-6A N106RV Broken Arrow, Ok MLaboyteau(at)aol.com ________________________________________________________________________________
Date: Mar 29, 1999
Subject: frivolous lawsuit
Mr. Joseph Polizzotto: I have followed from the beginning your attacks on Matronics, including your recent rude and borderline illiterate responses to reasonable, courteous letters complaining about your heavy handed tactics. Be aware that neither I, nor any other pilot with an IQ above 50, could possibly confuse the name 'Fuelscan' used to describe a fuel monitoring system, with the word 'Scanner', used to describe an engine monitoring system. Trying to manipulate our legal system to expand your trademark rights for an engine monitoring instrument AFTER you decide to add fuel monitoring to it, AND trying to bully a one-man company with the excuse that he uses 4 letters of the alphabet that you use is unforgivable. I hope that the recent coverage by Avweb will result in total loss of sales of your product. I will certainly not use any of your products in the future, and will do my best to convince everyone I know through word of mouth, local EAA chapter, etc. to avoid all your products in the future. I sincerely hope that your fate can serve as an example to future potential bullies trying to abuse our legal system. Charlie England 140 Highway 49 N Jackson, MS 39209 ________________________________________________________________________________
Date: Mar 29, 1999
I've flown both. The RVs are lots roomier (this was an early Thorp, 38" wide), and the ailerons were reasonably stiff. Granted, I flew this about 10 years before I flew an RV, so this may not be totally accurate. Ed Wischmeyer ________________________________________________________________________________
Date: Mar 29, 1999
Another perspective: I own a '92 RV-4 with almost 500 hrs tt. It has (as far as I know) standard gear legs. It has no stiffeners on the legs, aluminum fairings, & 1-pc pants. I try to keep my tire pressures near 50 lbs. If I am negligent & allow pressures to fall below 30 lbs, the plane is hard to push on the ramp, the side walls rub the pants, & it handles on the ground like a '60s era land yacht. I have never had shimmy problems, except on 'corrugated' surfaces which were obviously causing the shimmy. I wish I could offer a solution, but I've never had to deal with the problem. However, I do think that lowering your tire pressure is only a way of masking the problem, instead of finding & fixing the problem. It seems to me that shimmy is just another form of resonance, similar to flutter. Warped brake rotors? The already mentioned wheel pant balance (or just remove them & see if the problem goes away or changes frequency)? Tire balance and/or out of round? At any rate Van's advice to lower tire pressure to damp out the shimmy instead of finding a fix is disappointing. charlie ________________________________________________________________________________
Subject: Re: RV-List : JPI's BIG Mistake
Date: Mar 29, 1999
AvWeb has taken up the cause. The latest newsletter calls JPI's suit "way out of hand" and provides email addresses for Matt and Joe Polizzotto. Nothing like a little publicity > -----Original Message----- > From: b green [SMTP:rvinfo(at)Juno.com] > Sent: Friday, March 26, 1999 4:11 PM > To: rv-list(at)matronics.com > Subject: RV-List: Re: RV-List : JPI's BIG Mistake > > > Should we be boycotting Electronics International too? Didn't they > start > this whole thing by sueing JPI in the first place? > > Bruce Green > > >You the builders buy from these guys, here's another way to get to > >JPI's > >managment. Start calling your suppliers tell them about Matt's > >misfortune. > >Maybe they can help get the point across that this industry will not > >support a > >bully. > > > > ----- > > ----- > http://www.matronics.com/contribution > > ----- > ________________________________________________________________________________
Date: Mar 29, 1999
In a message dated 3/28/99 9:21:57 PM Eastern Standard Time, glenng(at)megsinet.net writes: > Can someone explain the purpose of crossing over the exhaust system on > an RV-6? It has to do with power pulses and exhaust scavenging. By using a crossover exhaust you use low pressure created in one cylinder to "suck" the exhaust gases out of another cylinder while its exhaust valve is opened. Gary Corde RV-6 N211GC - NJ ________________________________________________________________________________
Date: Mar 29, 1999
Subject: Re: frivolous lawsuit
Charles Way to go!!!!, Couldn't have said it better myself. Let's show JPI that the Homebuilt Market is BIGGER than they thought. We stand up for what we think is RIGHT and we hate seeing one of OUR FAMILY walked on. Steve Davis The Panel Pilot ________________________________________________________________________________
From: "Steven B. Janicki" <sjanicki(at)us.oracle.com>
Subject: Re: Four New Email Lists Now Available!
Date: Mar 29, 1999
Matt, Your going to become the Rupert Murdock of email lists! ----- Original Message ----- From: Matt Dralle 925-606-1001 <dralle(at)matronics.com> Sent: Sunday, March 28, 1999 6:20 PM Subject: RV-List: Four New Email Lists Now Available! 925-606-1001) > > > Dear Listers, > > I have added four new Email Lists to the existing Lists currently sponsored > by Matronics. These include Lists for the Yak, VariEZ/LongEZ, Lancair, and > Glasair. Existing Lists include the RV, Zenith, Kolb, and HR Rocket Lists. > The new Lists will be run in the same spirit as the existing Email Lists > available on the Matronics server including the high-speed web-based archive > searching and browsing capabilities as well as the respective List web > site. As always, access and subscription to the new Lists is completely > free of charge. Generous contributions are, however, always appreciated... > ;-) > > To subscribe to any of the new lists, please refer to the following URL: > > http://www.matronics.com/subscribe > > For more information on any of the Lists sponsored by Matronics, please > refer to the following URL, and select the particular List of interest: > > http://www.matronics.com/other.html > > > Thank you for all of your generous support over the years! > > Best Regards, > > Matt Dralle > Matronics Email List Administrator > > > -- > > Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 > 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email > http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft > > ________________________________________________________________________________
Date: Mar 29, 1999
Everett Hatch tested my new O-360 on his dyno with both the Vetterman cross-over exhaust and the Vetterman 4-pipe exhaust. He found no significant difference in the power output between the two systems. There is, however, a difference in the exhaust note. The 4-pipe system has a harsher sound than the crossover. He chose the 4-pipe system for my airplane because it fit more easily around his custom cold-air induction. Regards, Tom Craig-Stearman RV-4 64ST doing f*berglass work. Ugh. > >In a message dated 3/28/99 9:21:57 PM Eastern Standard Time, >glenng(at)megsinet.net writes: > >> Can someone explain the purpose of crossing over the exhaust system on >> an RV-6? > >It has to do with power pulses and exhaust scavenging. By using a crossover >exhaust you use low pressure created in one cylinder to "suck" the exhaust >gases out of another cylinder while its exhaust valve is opened. > >Gary Corde >RV-6 N211GC - NJ ________________________________________________________________________________
Subject: Fiberglass tips
Date: Mar 29, 1999
Fellow builders, After having spent the last weekend with some of those nasty fiberglassing chores on the cowlings, I thought I'd share a few tips that might make the job a little easier for those that haven't worked with the stuff very much. Before the RV, I built a "glass backwards" airplane and I learned quite a few tips that make the job easier. One of the really simple things that you can do to make the job easier is to lay up the fiberglass on your workbench on a sheet of aluminum foil. Wet the cloth with epoxy and squeegee out the excess. Then cut the strips the size you need to do the job. In fact, layout your cut marks on the foil with marker before hand. You can see them through the wetted cloth. Then cut our the strips through the foil and the glass. Take the strip over to the airplane, turn it over and press it into place. Once you have it where you want it, carefully peel the foil off of the back. This keeps the edges neat and straight and makes it easy to handle. Note, it takes a sharp pair of scissors to do this. If they are dull, forget it. You'll make a big mess of it. If you cut the glass cloth on the bias (and you should always do this), then the strip tends to get distorted the more you handle it. Eventually it becomes a big mess. The foil really helps it to hold its shape. I almost never put glass onto a lay-up without first wetting it out on the bench as I've described. Using this technique also saves glass and helps to keep the layout more dry. This doesn't work all the time though. If you need to overlap joints, you may need to lay-up many single strips on the foil and apply them one at a time so that you can stagger the joints. Even so, putting them on foil first makes it a breeze. Anyway, just a few tips for those that may find it helpful. Randy Pflanzer N417G RV-6 "Getting ready for Paint" ________________________________________________________________________________
Date: Mar 29, 1999
When I first started flying Suzie Q there was no shimmy, with the exception of an occasional wiggle as roll-out slowed down. As the tires got worn (still on my first set with over 200 hours), I started to get a little more wiggle. I balanced the wheel fairings and that helped. Two days ago, I did the monthly tire pressure check, found the pressure down some and put 32 psi in each. And of course, I went out and did some stop and go landings. MAN, was there some shimmy. This morning, let the pressure back down to 27 and the shimmy went away. Hmmm. I have several layers of glass on the landing gear legs but no wood. I have a new set of tires in the hanger that are going to be put on pretty soon here. I think just having new and balanced tires will also help. Going with Condor tires this time, just to see the difference. Michael RV-4 N232 Suzie Q Having a ball, learning..... ________________________________________________________________________________
Subject: fairings
Date: Mar 29, 1999
Can anyone make a comparison between the factory fairings and the Tracy Sailor fairings hours work, looks etc. Cant find much in the archieves. RV6A/finsih kit ________________________________________________________________________________
Subject: Light Speed Engineering Electronic Ignition
Date: Mar 29, 1999
I said I would post a report after I finished installing a LSE Hall effect electronic ignition in place of my right, or non-impulse, magneto on my Lycoming-like (its not a certified engine) O-320, 160HP RV-6A. I received the unit, it was complete and appears well made. Nothing was missing. Instructions could be a tad more clear (I had no idea what a "standard" clamp was, nor a "toe clamp," terms that were used interchangeably.) I also was bit confused about high voltage cable routing, but when Claus pointed out that the photos in the section (not included) for his dual system should be used, all was clear. I installed the module on one of the ribs that connect from the aft face of the fire wall to the forward side of the sub-panel. With a completed RV that has the center console that was mechanically difficult. If open access were possible it would have been a 10-minute job. Installation of the trigger coils atop the engine was simple. Installing and setting the sensor which has been installed in place of the removed magneto was a no-brainer. Starting is VERY noticeably faster. The engine snapped to life on the first blade over! Take off seemed better, but that's very subjective. Flight might have given me a few more MPH at the same RPM, but again that's not too firm. At 1700 RPM on runup, disabling the remaining conventional magneto resulted in NO RPM DROP WHATEVER. Turning off the electronic unit and running on the mag only gave a drop of about 95RPM. I am not certain if engine smoothness is improved yet or not, I was so busy watching other things that I forgot to evaluate it. More later if anything significant develops. RV-6A Flying Salida, CO ________________________________________________________________________________
Subject: LEADING EDGE
Date: Mar 29, 1999
I'm in the process of painting my wings and was about to pain a strip along the leading edge about 4" back. I was told this ridge could effect the air flow with negative results. Any first hand experience out there. Thanks ahead RV6A/finishkit planejoe(at)flnet.com ________________________________________________________________________________
Date: Mar 29, 1999
Subject: Re: Eletric Gyros
> >> Other than cost, are there any other disadvantages? > >Yes. You want to have two independent sets of gyros, each with its own power >source, so that a single failure won't wipe 'em all out. Agreed. But that power source doesn't necessarily mean a different *types* of power, e.g. electricity vs. vacuum. If you have two sources of electrical power, you have satisfied the need for redundant power if you can easily select between the two sources of power. With an all-electric panel, if I lose one source of electrical power, i.e. my main buss with alternator, I can switch to my alternate source of electrical power and, voila', I still have all my gyros. With vacuum power, I lose my horribly unreliable vacuum pump, and my air-driven gyros are *gone* so I *MUST* fly partial panel. Sure I can fly partial panel but nowhere near as well as I can fly when I have an AI and a DG. >That's why >conventional arrangements have an electric turn coordinator and the other >gyros are vacuum. You can lose either system and still have enough information >to control the airplane. Sometimes conventional wisdom isn't all that wise. Alternators, batteries, and electrical wiring are a lot more reliable than the dry vacuum pump. Why build around an unreliable system just because it is redundant? Build the most reliable system you can, and that is 100% electrical in my book, and then add redundancy there. Bob Nuckols says it very well in his book, _The_Aeroelectric_Connection_. (I am going to paraphrase here because I don't want to go look up the exact quote.) You need to do failure analysis and then determine what the ramifications are for each possible failure. If a failure is possible AND it would threaten the safety of the flight, then you need to find a work-around solution that will allow you to safely land the aircraft. You build in the necessary redundancy or extra systems to accommodate that failure. As I said in a previous message, redundant electrical power is *VERY* easy to come by. If the primary (alternator) fails, you already have a secondary source (aircraft battery). If that fails you can even have a tertiary source, e.g. an extra battery pack made out of D-cells, etc. That is much easier to come by than a second pneumatic source. The only question then is how to accommodate a failure of the path between source; e.g. battery, alternator, etc.; and sink; e.g. radios, gyros, etc. Bob's dual-source, dual-path, no-single-point-of-failure approach to aircraft electrical buss design takes care of that very handily. >Note that electric pitot heat is part of that design, >too -- lose electrics, you lose the turn coordinator and possibly the >airspeed. Lose vacuum, and you can still fly partial panel. And I reiterate, flying partial panel ranges from no fun to downright dangerous. Why design for that sort of fallback position when you can do so much better? Just remember, vacuum pumps suck. ; ) Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax O- ________________________________________________________________________________
Date: Mar 29, 1999
Reply to message dated 03-28-99 Sluggo, Ryan Bendure Co. gave you the correct advice on wheel shimmy. Having built an RV-3A and flew it for 2-1/2 years, I experienced the same wheel shimmy at different speeds also. After I sold the plane, I found out how to correct it. Definitely balance your wheel pants. Grumman Yankee aircraft did this by putting weights in the forward section of the wheel pants. One story goes, that a fellow didn't understand what the weights were for and removed them from his Yankee wheel pants and experienced horrible wheel shimmy. After putting them back, nothing but smooth. Hope it works for you too. Tom Benton ________________________________________________________________________________
Date: Mar 29, 1999
rivets used are 470 4's. i ordered from avery the 6 piece >squeeze set and not sure what dies i use. also, do i use a flush for >the un cuped side of rivet??? any and all help greatly appreciated here. >thanx, bob paulovich in arkansas Bob: I found if you drive the #4 rivets, it a lot better than trying to squeeze them. If you have a round head you got to used a round head anvil. you of couse got to use a flat on the bucked side. Don Jordan ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com ________________________________________________________________________________
Subject: Storing Lycoming's way
Date: Mar 29, 1999
>I called Lycoming last November about perserving my new O-320. Tech >help told me to fill the engine completely full with new, clean >automotive motor oil. Fill from the breater fitting. Then seal the >exhaust ports with homemade plates and fill the cylinders through the >top plugs. >Of course Lycoming said the oil is drained thoruoghly and then filled >with aircraft oil before running. > >P.S. DO NOT order long term storage with the engine if you plan on >hanging the engine. > >Rick Caldwell >RV-6 coming together in central FL. Rick: I have my upside down with 8 qts. I plan on rotating it each month or so. How much oil did it take to fill-er-up??? one more thing. Would it be good to drain the auto oil & fill with old but clean avaition oil from the last oil change of a friend & then turn it till you get a lettle pressure & then drain for the new avaition oil. Just wondering about a small layer of auto oil mixed with the new avation oil. Don Jordan ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com ________________________________________________________________________________
Subject: Props
Date: Mar 29, 1999
I need to buy a new does anyone know which one works well on the RV 3's, 150 horse. How about the two blade ground adjustable Ivo Props or would a wood fixed pitch be a better choice? Thanks for any available help. Steve ________________________________________________________________________________
Date: Mar 29, 1999
where can one find this book? >From: Brian Lloyd <brian(at)lloyd.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Eletric Gyros >Date: Mon, 29 Mar 1999 14:55:13 -0800 > > >> >>> Other than cost, are there any other disadvantages? >> >>Yes. You want to have two independent sets of gyros, each with its own power >>source, so that a single failure won't wipe 'em all out. > >Agreed. But that power source doesn't necessarily mean a different *types* >of power, e.g. electricity vs. vacuum. If you have two sources of >electrical power, you have satisfied the need for redundant power if you >can easily select between the two sources of power. > >With an all-electric panel, if I lose one source of electrical power, i.e. >my main buss with alternator, I can switch to my alternate source of >electrical power and, voila', I still have all my gyros. With vacuum >power, I lose my horribly unreliable vacuum pump, and my air-driven gyros >are *gone* so I *MUST* fly partial panel. Sure I can fly partial panel but >nowhere near as well as I can fly when I have an AI and a DG. > >>That's why >>conventional arrangements have an electric turn coordinator and the other >>gyros are vacuum. You can lose either system and still have enough >information >>to control the airplane. > >Sometimes conventional wisdom isn't all that wise. Alternators, batteries, >and electrical wiring are a lot more reliable than the dry vacuum pump. >Why build around an unreliable system just because it is redundant? Build >the most reliable system you can, and that is 100% electrical in my book, >and then add redundancy there. > >Bob Nuckols says it very well in his book, _The_Aeroelectric_Connection_. >(I am going to paraphrase here because I don't want to go look up the exact >quote.) You need to do failure analysis and then determine what the >ramifications are for each possible failure. If a failure is possible AND >it would threaten the safety of the flight, then you need to find a >work-around solution that will allow you to safely land the aircraft. You >build in the necessary redundancy or extra systems to accommodate that >failure. > >As I said in a previous message, redundant electrical power is *VERY* easy >to come by. If the primary (alternator) fails, you already have a >secondary source (aircraft battery). If that fails you can even have a >tertiary source, e.g. an extra battery pack made out of D-cells, etc. That >is much easier to come by than a second pneumatic source. The only >question then is how to accommodate a failure of the path between source; >e.g. battery, alternator, etc.; and sink; e.g. radios, gyros, etc. Bob's >dual-source, dual-path, no-single-point-of-failure approach to aircraft >electrical buss design takes care of that very handily. > >>Note that electric pitot heat is part of that design, >>too -- lose electrics, you lose the turn coordinator and possibly the >>airspeed. Lose vacuum, and you can still fly partial panel. > >And I reiterate, flying partial panel ranges from no fun to downright >dangerous. Why design for that sort of fallback position when you can do >so much better? > >Just remember, vacuum pumps suck. ; ) > > >Brian Lloyd Lucent Technologies >brian(at)lloyd.com 3461 Robin Lane, Suite 1 >http://www.livingston.com Cameron Park, CA 95682 >+1.530.676.6513 - voice +1.530.676.3442 - fax O- > > > > http://www.matronics.com/contribution > > > ________________________________________________________________________________
Date: Mar 29, 1999
Subject: Re: Light Speed Engineering Electronic Ignition
In a message dated 3/29/99 4:28:03 PM Eastern Standard Time, fasching(at)amigo.net writes: << Flight might have given me a few more MPH at the same RPM, but again that's not too firm. >> John, I don't think the air or airplane know or care what the ignition system is. At a given RPM with a fixed airplane and prop, you will get the exact performance IMHO. Bernie Kerr, 6A cowl and panel, SE Fla. ________________________________________________________________________________
Date: Mar 29, 1999
Subject: Re: LEADING EDGE
In a message dated 3/29/99 4:35:54 PM Eastern Standard Time, planejoe(at)flnet.com writes: << I'm in the process of painting my wings and was about to pain a strip along the leading edge about 4" back. I was told this ridge could effect the air flow with negative results. Any first hand experience out there. Thanks ahead >> Hi Joe, I beleive that is an old wives tale. It is probably left over from the Q-2 early days. The first kit to fly experinced a big loss in lift when it had a LE strip painted. It was a laminar flow canard that was operating at a Reynolds Number arround 1.5 million. This canard also exhibited the same phenomena in rain or bugs. Your wing will not experience any loss of lift IMHO. It is possible that you might have a tiny increase in drag if you left a large discontinuity at the stripe edge. If you are really concerned, make a butt joint in the paint with no effects if it is smooth. Bernie Kerr, 6A cowl and panel, SE Fla ________________________________________________________________________________
Date: Mar 29, 1999
Subject: HS 610-614 question
are the outer holes drilled prior to the 6 degree bends??? thanx, bob in arkansas ________________________________________________________________________________
Date: Mar 29, 1999
Subject: Mazda power
For anyone interested in Mazda power for their RV, Tracy Crook now has his website up and running at: http://www.rotaryaviation.com Documents stats on his RV4 (including flight time of 780 hours as of 3/99) and his companies products. Mike Wills RV-4 saving for the finish kit willsm(at)manta.spawar.navy.mil ________________________________________________________________________________
Subject: Tanks screws etc.
Date: Mar 29, 1999
I was fitting the tanks on to see how well they position after all the sealing, etc. I found that a product like Boelube, (looks like a dry lubricant pasty powder) Do-all, (looks like bees wax) or best of all, a dab of Mastinox, (looks like a yellow custard) works like a charm to lube the screws very well so they drive in well and better yet, remove well, avoiding a lot of twisting and stripping of screws to seat them. Another little item from an auto parts store is little round rubber grommets all the way from 1/8" to 1/2" or more inside diameter, make for handy, cheap carry throughs for wires where you don't really want big honkin' holes for just one or two wires passing through a member or bulkhead...e.g. spar attach or whatever..just a thought...Buster. ________________________________________________________________________________
Subject: LSE on RV-6A
Date: Mar 29, 1999
Niel France - your essage did not have your e-mail address, so I have to post it to the net. No, this system is not the same as the one you saw that had blanking plates over the old mag holes. That is LSE's system where bolts are put in the rim of the flywheel and they pass pick up coils that fire the plugs (ultimately.) That system fires all plugs by the electronic system. The Hall effect system uses a sensor that is mounted in the place one mag is taken off the aircraft. That give RPM information. The intake manifold pressure is also input to the control module. Between the two they set the timing. The remaining mag runs just like it always did. You can see this system on LSE's web page; Http://www.lsecorp.com I think the system will be worthwhile as long as you do not attempt to justify it from a fuel savings standpoint. RV-6A Flying Salida, CO 7,500' ________________________________________________________________________________
Subject: RV6A Gear Mount Question
Date: Mar 29, 1999
From: Watson(at)earthlink.net, Bill <wmwatson(at)earthlink.net>
Folks, I am ready to mount the wing and start on the landing gear. Prior to mounting the wings (should I say wing?), I trial fit the gear to a get a look-see. Bottom line, it didn't seem to fit very well; I couldn't get it to snug into the corner and be approximately in alignment with the future bolt holes. Question: should it fit tight to the surfaces? Did you need to use shims or spacer plates? Did you need to gring off some material on the strut that takes the rivets? I may be jumping the gun, (I will keep going), but what's ahead? Thanks, Bill Watson RV6A Gear Mounting Next ________________________________________________________________________________
Date: Mar 29, 1999
Date: Mar 29, 1999
Date: Mar 29, 1999
Date: Mar 29, 1999
Date: Mar 29, 1999
Date: Mar 29, 1999
Subject: Remote fuel selector
Date: Mar 29, 1999
I want to put a fuel sector on the cockpit side of the firewall and be able to rotate it by a shaft connected to the selector handle. What brand selector is of excellent quality and can be modified easily? And if anyone has done this I am open for any suggestions. C.H. ________________________________________________________________________________
Date: Mar 29, 1999
I talked to a glider pilot whosaid that he had had a beautiful new paint job done to his glider with the afore mentioned leading edge accent which caused a great lift reduction. Removed the trim design on the leading edge and his problem went away. Go figure! Brad Bundy Flying Chard Built RV6 N48AC Joseph, You wrote> >I'm in the process of painting my wings and was about to pain a strip along >the leading edge about 4" back. I was told this ridge could effect the air >flow with negative results. Any first hand experience out there. Thanks >ahead ________________________________________________________________________________
Date: Mar 30, 1999
Subject: Re: Noise cancelling headsets
As I recall, to prevent the regulator from oscillating, you should also have a 0.22uF cap between the +9V pin and the ground pin. Even better is to also add at least 100uF (16V or more) electrolytic cap between the 12V and ground pin. Royce > >LM7809 3-terminal positive regulator or equivilant from any electronics >supply house. Input (12 V bus in plane), ground, and 9 volt output (the >09 in 7809) to the head set. Ask for the to220 package. It's a plastic >square about 3/8"X3/8"X1/8" thick with a metal tab for mounting & heat >sinking. Mount in the smallest aluminum box you're comfortable working >in & this will supply the heat sink. The box should cost more than the >regulator. > >Charlie > ________________________________________________________________________________
Subject: Re: Gear Leg Shimmy
Date: Mar 29, 1999
> > >Has anyone tried the new fiber glass nose gear strut? What is the shimmy >like with it? I plan on odering one pretty soon. Seems like a better >engineered setup regards corrosion than glued on wood. Question...what will >they do for damping shimmy? >Larry, RV-6A finish stuff > I have the new fiberglass fairings. I think that is what you are referring to. I am using them on the main gear of an RV-6. I like the fact they are removable but they are very light weight and I don't believe they would have any effect on shimmy. I went ahead and installed the wood under the fairings although the instructions don't say anything about what to do. Haven't flown, so don't know how my setup will work, but I like the new Van's glass fairings. Larry Pardue Carlsbad, NM RV-6 N441LP Inspection scheduled April 22 ________________________________________________________________________________
Date: Mar 29, 1999
In a message dated 3/28/99 4:55:46 PM Pacific Standard Time, ylcrc(at)ttacs.ttu.edu writes: > > Randy Compton wrote: > >The GPS shows about 18 to 20 knots during taxi, and the onset during > landing > >rollout seems to be around 30 knots. Firm braking dampens this somewhat, > >with no shimmy below 18 knots. Also, during takeoff acceleration, there is > >no shimmy. > > My RV-3 does the exact same thing when tires are fully inflated. So I keep > them underinflated and that eliminates the shimmy. When I have too much air > in them, I taxi very slowly and brake when the shimmy starts upon landing. > Not an ideal situation but I live with it. If anybody else has a solution, > other than putting the gear on straight in the first place, I'd like to hear > it. > > Chuck > RV-3 N893FS I balanced the wheel pants. My tire pressure was 18-22 psi tire pressure to control the shimmy. It doesn't shimmy at 30 psi. Of course, some things work for me that don't work for anyone else. :-) Jim Ayers RV-3 N47RV ________________________________________________________________________________
Subject: Flyin' with Mike - value as good as Van's hardware!
Date: Mar 29, 1999
Yeeeea - Haaaa! We just got back from spending some time in the North Plains area flying with Mike Seager in Van's RV-6A (N666RV). What a great deal! I absolutely believe that spending this time and money was every bit as valuable as the money spent directly on hardware from Van himself. Almost everyone reading this list agrees with me that sending money to Van's Aircraft beats any other way to spend it on airplanes, in terms of what you pay for what you get (if not, why ARE you subscribing???!!!) Specifically, Kathy and I spent parts of two days (3.9 "billable hours" in three sessions for me, 2.8 in two sessions for Kathy) with Mike getting some familiarization training in the -6A. Van and Mike have conspired (with the FAA) to make this service available to RV customers to increase thier likelihood of success in that critical early flight period (especially the first one!). If you're already flying a Thorp T-18, Lancair, Glasair, etc., you're probably already used to the type of performance that an RV provides. If, however, you're like Kathy and me and all previous experience is in spam cans like the Cherokee and 152/172, hark an ear... What we got for our money: Mike took us out and introduced us to the plane (climb, cruise, maneuvering flight, turns, stalls, etc. - classic BFR and/or transition training for any new/different plane), then we headed for the airport (Scappoose, OR in my case) to see what it's like in the pattern. We spent a major portion of our time with him in the pattern, learning how to get the plane on/off the ground safely and smoothly. At this point in time, I feel much more confident that I can handle our plane when it's ready for that first flight. The RV-6A is every bit as good an airplane to fly as is claimed. (Hearsay says this is true of the entire RV family - I believe it, just can't state it from my own experience...!) The plane is very predictable, very easy to control, and overall a total gas to fly (hence the universal RV grin from pilots!). Although sometimes you start wondering after reading some of the messages on this list, it also obeys every one of the same laws/rules/principles of physics and aerodynamics that the Cessper/Pissna's do. This is both good and bad (balance is far to the good side...). At the same time, while aerodynamics say it has to share a lot of flight characteristics with it's ancestors, there are also differences that can catch you napping, especially if you haven't "flown with Mike". Biggest difference between the RV and a Cherokee: THINGS CAN CHANGE QUICKLY! The RV whips Piper/Cessna specs in terms of dimensions, weights, power loading, roll and pitch rates, etc. That's why we've all bought (or are buying, or are considering buying) these experimental aircraft - to be able to enjoy higher performance for our dollars than we can get in the certified world. Sliding the throttle forward to start the takeoff roll (even uphill on Van's wet/soft grass strip) causes you to get squished back in the seat WAY more than a Cherokee can do. This is just a hint of what's in store through the whole flight. Speed reductions happen faster, too (partly due to the constant speed prop on N666RV, but not entirely). If you reduce power on downwind, then don't pay attention to airspeed/descent rate/power setting, you can find yourself playing with the bottom of the green/white arcs on the airspeed indicator much sooner than this could happen in a C-172. To give you an idea of how this is manifested overall, I usually figure on about 6 minutes per lap of the pattern if I'm doing touch & go practice in our Cherokee. I think the average time was closer to 4 minutes in the RV, and that includes stop & goes instead of touch & goes! Like I said - things CHANGE quickly! The same processes are used, but you don't get as much time to dawdle around noticing that you need to correct a "drift", be it attitude, position, or speed. Fortunately, though, any variance can be corrected very quickly and easily - if you pay attention, this aircraft can fly like it's on rails and under computer control. As far as Mike's personality and credentials go, he's the guy you'd pick if you did a search for flight instructors using the suggestions in articles in Plane & Pilot, Flying, etc. He's technically a good pilot, has been instructing for a lot of hours, loves flying (and is infectious about it!), is very methodical, and at least for me, HE CAN DESCRIBE WHAT HE WANTS IN WORDS THAT I UNDERSTAND! I've worked with coaches/instructors in the past (not always in aviation) that just didn't have the communication knack that is the difference between an expert and an expert instructor. He's patient, allows minor "learning experiences" (as long as they're not going to hurt us or the hardware), and is constantly positive in his outlook and critique of recent events. He also keeps after a point until you convince him that you at least know what the correct procedure is, and can demonstrate it with reasonable skill and consistency. (I had trouble getting the sight picture, timing, and control inputs correct in the landing flare - I know I was driving Mike nuts, but he kept with it. The last session, I finally pulled it together and got a couple of acceptable touchdowns. Now that I know what needs to happen, I feel pretty good about doing it alone in a few months when the time comes...) Mike doesn't consider this flight training to be his primary profession - he owns another business that is his first responsibility. I'm personally hoping that he and Van are both successful enough that he can make a choice - can he be successful and have more fun by delegating/selling the "other" job so that he can put more time into teaching us to fly RV's? I'm certainly glad that Van and Mike have seen fit to make this opportunity available to us. I really believe that having done this (especially the landings!) will make my chance of success much better on the "Big Day" for N110KB, the -6A that Kathy and I are working on. Neither one of them can be getting rich from this process - the cost was only $70/hr, which included Mike's time AND the RV-6A (with fuel). This is pretty close to what I was paying for instructor and C-172 rental during my primary training a couple years ago. There aren't many opportunities to get experience like this - while a lot of RV'ers are willing to let you take the stick for a while at altitude, even those who are CFI's are understandably reluctant to let you actually do the approach and LAND! I heartily recommend to any and all that you take advantage of this opportunity - who knows, if there's enough demand, Van might even see fit to open flight training centers around the country (Mike already takes the -6 on tour a couple times a year - I think he's in Texas this week or next, on the way to Sun & Fun). (Realistically, the logistics could be a nightmare - by using the factory prototypes, Van also has the R & D staff do the maintenance, mods, etc. on these planes - he gets pretty good use/value from them, and has a chance to keep a close eye on them. If a plane doing this job weren't based in North Plains, it would be a lot tougher to keep it in the kind of condition that these are.) In closing: Mike S., thanks again for working with us. Scott McDaniels - could you please pass on our thanks to your boss for going to the trouble to make this possible to us (with the FAA and with his equipment!). Bill & Kathy Peck - RV grins refreshed, back to working on details with enthusiasm while we wait for finish kit & engine... ________________________________________________________________________________
Subject: Request for an RV6 Maintenance Schedule
Date: Mar 30, 1999
Hi All In order for us to register RV's in our country, the Civil Aviation Authorities require a specific maintenance schedule for the aircraft. Please help. Does anyone have a basis that we can modify for use here. Kind Regards Gary F Wellock Tail Feathers Tel ++ 263-4-741816 Fax ++ 263-4-741816 Cell ++ 263-11-601340 E-Mail:garyw(at)compasst.co.zw ________________________________________________________________________________
Date: Mar 30, 1999
Subject: Re: Remote fuel selector
Chris- Read the John Denver accident report before you do this. You may change your mind. --- christopher huey wrote: > > > I want to put a fuel sector on the cockpit side of > the firewall and be able > to rotate it by a shaft connected to the selector > handle. What brand > selector is of excellent quality and can be modified > easily? And if anyone > has done this I am open for any suggestions. > > C.H. > > > > > The RV-List is sponsored by Matronics, makers of > fine Aircraft > Avionics, and by the generous Contributions of > List members. > > > Matronics: > http://www.matronics.com > RV-List: > http://www.matronics.com/rv-list > List Subscribe/Unsubscribe: > http://www.matronics.com/subscribe > Archive Search Engine: > http://www.matronics.com/search > Archive Browsing: > http://www.matronics.com/archives > http://www.matronics.com/contribution > Other Email Lists: > http://www.matronics.com/other > > > > > ________________________________________________________________________________
Date: Mar 30, 1999
Lucky, You can contact AeroElectric at WWW.aeroelectric.com Chuck Rowbotham RV-8A awaiting QB ________________________________________________________________________________
Date: Mar 30, 1999
christopher huey wrote: "I want to put a fuel sector on the cockpit side of the firewall and be able to rotate it by a shaft connected to the selector handle." Read the John Denver accident report on the FAA/NSTB web site! <http://www.ntsb.gov/default.htm> Richard Reynolds, RV-6A ________________________________________________________________________________
Date: Mar 30, 1999
> christopher huey wrote: > > "I want to put a fuel sector on the cockpit side of the firewall and be > able to rotate it by a shaft connected to the selector handle." > Christopher, Take a look at a Stearman. The fuel selector is located on the aft side of the firewall, however it might give you some ideas on how to set up the linkage. One thing you'll see is that it can be controlled from either the front of rear cockpit. Something else to note of operating safety is that the linkage uses a coupling which acts as a universal joint. This minimizes the change of the system binding due to a slight misalignment. Glenn Gordon ________________________________________________________________________________
Date: Mar 30, 1999
Bill, I found this also to be a problem last year when I mounted the wings and took my first look at the fit of the landing gear mounts. Mine also did not fit well. I called Van's. They said they had never heard of a problem fitting these to the RV-6A fuselage. I went back to the shop and pushed and clamped until they looked to be as tight in the corner of the fuselage and the F-604/wing spar as they could get. I ended up with what looked a little bit of a bad fit almost everywhere and two big problems. Problem one was that the strut that goes forward to the outside angle bracing in the fuselage did not come close to touching the fuselage. There was a gap of a quarter inch or more. Advice from this list was to heat and bend the steel strut until it fit. Other advice was to shim. Take your pick. I made shims. Problem two was that one of the bolt holes in the wing spar came very, very, very close to the big tube that houses the gear. So close that I could not get a bolt in the hole or a nut on the bolt if it put the bolt through from the rear. I ended up grinding away a small semi-circle in the weld so I could get a nut on. I read another post a few weeks or months ago that indicated that another builder with a similar problem sent the gear mount back and got a slightly re-welded one that fit better. There may be some variation in what Van's Aircraft is shipping and another gear mount might fit better. After many weeks of careful drilling and bolting, I got the wings and the landing gear mounts to line up pretty well. I was pleased and a bit surprised given how bad it looked the first time I tried to fit them. You will find it is easier to do the drilling and bolting in if you leave the bottom skins off. I have small shims on the sides of the gear mounts and at the front strut as mentioned above. That was about a year ago. I am waiting for the finish kit. With time on my hands I decided to make a nice false spar so I can (some day soon) get the machine up on its gear and more easily move it around the shop. Now I am getting some practice putting bolts in the wing spar and through the holes in the gear mounts with the floors on and the fuselage upright. Everything is lining up OK, but at least three of the bolts are pretty snug and are still giving me problems. The guys who build the RV-6 don't have to mess with landing gear mounts through the floor at all. There is a virtue in simplicity. Made me wish many times that I built the taildragger. After a tremendous number of hours (well four, but it felt longer) trying to land a Cub, I am glad that I stuck with the tri-gear. Steve Soule Huntington, Vermont -----Original Message----- I am ready to mount the wing and start on the landing gear. Prior to mounting the wings (should I say wing?), I trial fit the gear to a get a look-see. Bottom line, it didn't seem to fit very well; I couldn't get it to snug into the corner and be approximately in alignment with the future bolt holes. Question: should it fit tight to the surfaces? Did you need to use shims or spacer plates? Did you need to gring off some material on the strut that takes the rivets? ________________________________________________________________________________
Date: Mar 30, 1999
In a message dated 3/30/99 7:20:17 AM Central Standard Time, RVReynolds(at)macs.net writes: << christopher huey wrote: "I want to put a fuel sector on the cockpit side of the firewall and be able to rotate it by a shaft connected to the selector handle." Read the John Denver accident report on the FAA/NSTB web site! >> And for a more positive answer, look at any Champ. The approx 4' shaft even has a knuckle in the middle! If you want to do this, have a hard look at the failure modes, and address any issues that may come up. I see no reason to not do this, given a good design. Heck, even the handles on valves have been known to turn on the shaft, leaving the pilot with few options. Gravity always works! Check six! Mark ________________________________________________________________________________
Date: Mar 30, 1999
Perspective! The glider almost certainly has a laminar flow wing. Bugs on the leading edge would probably cause the same problem. Most of the original canard designs had this problem. The paint seam (or bugs) disrupts the laminar flow & kills the lift efficiency of the airfoil. Now note the paint on the RV-4 prototype. It's not laminar flow & isn't as sensitive to bugs, paint stripes, etc. Charlie Brad Bundy wrote: > > > I talked to a glider pilot whosaid that he had had a beautiful new paint job > done to his glider with the afore mentioned leading edge accent which caused > a great lift reduction. Removed the trim design on the leading edge and his > problem went away. Go figure! > Brad Bundy Flying Chard Built RV6 N48AC > > Joseph, You wrote> > >I'm in the process of painting my wings and was about to pain a strip along > >the leading edge about 4" back. I was told this ridge could effect the air > >flow with negative results. Any first hand experience out there. Thanks > >ahead ________________________________________________________________________________
Date: Mar 29, 1999
MLaboyteau(at)aol.com wrote: > > In a message dated 3/28/99 2:50:59 PM Eastern Standard Time, > rdcompton(at)mindspring.com writes: > > > Any ideas, other than always avoiding pavement? All this motion can't be > > good for the long-term health of the airframe/plumbing/etc. Worst of all, > > it looks bad in front of all my fellow airport bums. :-) > > On my -6a, the first 100 hours were shimmy free, then I removed the tires > and reversed them on their respective wheels to promote even wear. Now during > roll-out when I slow below about 30 mph, the right wheel shimmys a little. > I've tried different air pressure's, etc. All it takes is a little brake > application and it quits. It isn't bothersome, and I realize it has to do with > the wear patterns on the tires, so I figure as long as it doesn't get any > worse, when I replace the tires it will probably go away. > > Mark LaBoyteaux > RV-6A One more two cents worth. First of all a cheap shot at those daring to be critical of the design. Listen you guys this is one of the truly elegant design triumphs of the RV series. The weird scruffing of the tires on landing is in lieu of expensive shocks, sturdy oleo struts and all the things that go with them. It works, is cheap, reliable and simple. The down side trade off is tire wear and shimmy. Be happy. My guess is to design and manufacture a "conventional" gear would cost more than we are paying for the whole kit. These shimmy things vary according to tire pressure, speed, surface condition, tire condition (type, wear, etc), even temperature. But most of all a big variable is the type RV! The 6A has shorter legs and seems far less prone to the big shakes that you see on 43, 3s, and 6s. So be leary of applying a fix to your plane based on experience from another model. What I find most interesting is it never happens on take off, so it may well be that "unloading" weight is dampening while "loading" the gear is destabilizing. I do find that when it occurs on my trike, I can stop it instantly with brake pressure, but in a 6, it takes some slowing also. Hmmmm Finally perhaps a useful idea. If you suspect the balance the pants trick is a good idea for you, (Ryan Bendure's ideas are always good), why not just remove them and see if the problem gets better or worse? This may tell you if the pants are contributing to the problem. D Walsh ________________________________________________________________________________
Date: Mar 30, 1999
Subject: Gear Leg Prep
I was concerned about gear leg corrosion since I used foam/fiberglass fairings. I decided to prime and paint the gear legs, I then went to an electrical supply house and got 2 big peices of heat shrink tubing large enough to slip over the gear legs. A little heat from a bernz-o-matic torch and presto, two neatly wrapped gear legs. If you have ever tried to remove heat shrink you how tough the stuff is. I have had no problems going on 9 years. regards, Bill Mahoney RV-6 N747W ________________________________________________________________________________
Date: Mar 30, 1999
Subject: More JPI ...
Gentlemen, I offer you a quote from the late Col. Arthur D. "Bull" Simons, United States Army, he of V-N and the rescue for Ross Perot: "If history is any teacher ... it teaches that when you become indifferent and lose the will to fight, some other son-of-a-bitch who has the will to fight will take you over." In reviewing the JPI correspondence (after the report on AvWeb), there appears to be no rational incentive for the malicious actions of JPI. Are we missing something? The rest of the story? Clearly, JPI has no grounds for a lawsuit. Maybe the lawyers are just jerking JPI (they do that, you know, just for fun). The obvious action to be taken is a counter-suit. Is that the hope of JPI? Publicity? If one looks at business as a war, perhaps some of the tactics used, e.g., as for Serbia, can be applied. JPI can afford to crush a single competitor, perhaps to acquire him. But, can JPI stand against the whole aviation community, it's source of Being? Instead of writing letters to JPI and their attorneys, give them all the publicity they appear to be seeking. The letters of boycott should be sent to every source of advertising used by JPI, every user of JPI products, every trader of JPI stock, every source of basic parts used by JPI. If JPI wants war, and that seems to be the arrogant intent, the public that is sneered at should accommodate. The "public" makes the laws through its (our) determinations as to how society conducts itself. It is the public that chooses who shall rise, and who shall fall, as has been recently illustrated. Cut off the sources of JPI's income, and I assure you the demonstration of public disapproval will get the message across. I think a nice gesture would be for the JPI CEO, and each of his lawyers, to kiss the bare behind of Matronics' CEO on the DC mall--along with those other apologies sought. Just my opinion, of course. Fly safely, --B. ________________________________________________________________________________
Date: Mar 30, 1999
When looking for a paint scheme for my RV-8, I had one picked out which had the leading edges of the wings painted a different color. But I noticed in the manual that Vans cautions against this, as well as here on the list there were warnings against this. I figured, 'why take the chance?' There must be a gazillion paint schemes a guy can come up with; why choose one that could 'possibly' have a problem? You could avoid this by painting so that the lap joint is butted, as one lister said, but this is somewhat difficult and time consuming for the beginning painter. Von Alexander N41VA(at)juno.com RV-8 (10 hours) writes: > >I talked to a glider pilot whosaid that he had had a beautiful new >paint job >done to his glider with the afore mentioned leading edge accent which >caused >a great lift reduction. Removed the trim design on the leading edge >and his >problem went away. Go figure! >Brad Bundy Flying Chard Built RV6 N48AC > >Joseph, You wrote> >>I'm in the process of painting my wings and was about to pain a strip >along >>the leading edge about 4" back. I was told this ridge could effect >the air >>flow with negative results. Any first hand experience out there. >Thanks >>ahead > > > > > > > ________________________________________________________________________________
Subject: Re: More JPI ...
Date: Mar 30, 1999
Bud, Sounds like you're right - ON! Let's get the word out. We can make a difference. See you all at S-N-F! Chuck Rowbotham RV-8A >From: Bud Martin <budm303(at)earthlink.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: More JPI ... >Date: Tue, 30 Mar 1999 08:13:12 -0700 > > > Gentlemen, I offer you a quote from the late Col. Arthur D. "Bull" >Simons, United States Army, he of V-N and the rescue for Ross Perot: >"If history is any teacher ... it teaches that when you become >indifferent and lose the will to fight, some other son-of-a-bitch who >has the will to fight will take you over." > In reviewing the JPI correspondence (after the report on AvWeb), >there appears to be no rational incentive for the malicious actions of >JPI. Are we missing something? The rest of the story? Clearly, JPI has >no grounds for a lawsuit. Maybe the lawyers are just jerking JPI (they >do that, you know, just for fun). The obvious action to be taken is a >counter-suit. Is that the hope of JPI? Publicity? > If one looks at business as a war, perhaps some of the tactics used, >e.g., as for Serbia, can be applied. JPI can afford to crush a single >competitor, perhaps to acquire him. But, can JPI stand against the >whole aviation community, it's source of Being? > Instead of writing letters to JPI and their attorneys, give them all >the publicity they appear to be seeking. The letters of boycott should >be sent to every source of advertising used by JPI, every user of JPI >products, every trader of JPI stock, every source of basic parts used by >JPI. If JPI wants war, and that seems to be the arrogant intent, the >public that is sneered at should accommodate. The "public" makes the >laws through its (our) determinations as to how society conducts itself. >It is the public that chooses who shall rise, and who shall fall, as has >been recently illustrated. > Cut off the sources of JPI's income, and I assure you the >demonstration of public disapproval will get the message across. I >think a nice gesture would be for the JPI CEO, and each of his lawyers, >to kiss the bare behind of Matronics' CEO on the DC mall--along with >those other apologies sought. > Just my opinion, of course. > Fly safely, > --B. > > > > http://www.matronics.com/contribution > > > ________________________________________________________________________________
Date: Mar 30, 1999
> "I want to put a fuel sector on the cockpit side of the firewall and > be > able to rotate it by a shaft connected to the selector handle." > > Read the John Denver accident report on the FAA/NSTB web site! This is the second connection between Denver's accident and the question at hand. The fact that Denver had a "remote" selector did not cause his problems as much as the un-safe location of the remote selector. I intend to use an electric valve in my -6, and have caught some grief when discussing it. Departing from the original design is not _bad_ as long as failure modes and backup possibilities of the change are examined. This I have done, and I think I'll be as safe as anyone, or anyone who wants to use a remote valve - so long as they don't mount it over their left shoulder! Mike Thompson Austin, TX -6 N140RV (Reserved) Wings ________________________________________________________________________________
Date: Mar 30, 1999
Subject: Re: Flyin' with Mike - value as good as Van's hardware!
Kathy & Bill Peck wrote: > > Biggest difference between the RV and a Cherokee: THINGS CAN CHANGE > QUICKLY! The RV whips Piper/Cessna specs in terms of dimensions, weights, > power loading, roll and pitch rates, etc. That's why we've all bought (or > are buying, or are considering buying) these experimental aircraft - to be > able to enjoy higher performance for our dollars than we can get in the > certified world. Sliding the throttle forward to start the takeoff roll > (even uphill on Van's wet/soft grass strip) causes you to get squished back > in the seat WAY more than a Cherokee can do. This is just a hint of what's > in store through the whole flight. Speed reductions happen faster, too > (partly due to the constant speed prop on N666RV, but not entirely). If you > reduce power on downwind, then don't pay attention to airspeed/descent > rate/power setting, you can find yourself playing with the bottom of the > green/white arcs on the airspeed indicator much sooner than this could > happen in a C-172. Bill and Kathy That is a really excellent article you posted and you have described very well the reactions that I get when I am checking out prospective RV pilots the first time. One little thing I would like to caution you about is your statement about the fact that slowing down faster than other types of airplanes. While it is true that with a constant speed prop they will slow down in a hurry it is also true that without a CS prop they are very hard to get to slow down and you must plan you approach to landing much sooner than you would in a 150/172 etc. My RV-6 has a Warnke prop which is a narrow skinny blade and it has almost no braking ability at all so it is hard to get my RV-6 to slow down on downwind, base and final. If I am flying formation with a CS prop RV and we do say a overhead brake to land the RV with the CS prop can reduce power turn and land. If I don't plan carefully I reduce power and still fly to the next county before getting slow enough to land. Once again a very good post and description of your flying time with Mike, but please don't praise him anymore and make his head to big. I have to see him at the local Saturday morning breakfasts and have to take flight instructor refresher courses with him. If you keep this up he will be impossible to be around. :):) Jerry Springer|RV-6 first flight 1989|Hillsboro,OR|jsflyrv(at)teleport.com ________________________________________________________________________________
Date: Mar 30, 1999
Subject: Re: Mazda power
and the latest Contact! magazine has an article on Ed Anderson's installation. hal > For anyone interested in Mazda power for their RV, Tracy Crook now has his > website up and running at: > > http://www.rotaryaviation.com ________________________________________________________________________________
Date: Mar 30, 1999
Ivan, I and other Ag pilots over here have been running that headsets inc ANR. In reply to you question the $75 transformer they sold us lasted about a week and cooked itself. Our engineer then went to the equivalent of your Radio Shack and got some sort of "chip' that steps down the voltage to 9vdc and we have never looked back. We have all found that in the wear and tear of Ag work there installaion does not stand up. The biggest complaint would be the power plug which corrodes and does not like to be pulled in and out of the socket very often. I also wonder why this system is so cheap as the helmet manufacturers are selling systems at least two to four tmes dearer?? Rohan --- > ________________________________________________________________________________
Date: Mar 30, 1999
If you carefully the entire Denver accident report it appears that the problem was, in fact, caused by the extended selector not by the location. The valve seems to have been in a position where it allowed air fom the empty tank to enter one side while fuel was in the other tank. This partial opening to the dry tank allowed the engine to run out of fuel even though the selector handle was in the correct position. The extended selector had slipped due to the rivets loosening in the extension. At least thats how I read It. fwiw I for one will always put my grubby paws on the fuel selector directly and feel it into the proper on left or right position so as not to allow this possible problem. My 2 cents Steve Hughes okeanos(at)msn.com -----Original Message----- From: Mike Thompson <grobdriver(at)yahoo.com> Date: Tuesday, March 30, 1999 7:48 AM Subject: Re: RV-List: Remote fuel selector > >> "I want to put a fuel sector on the cockpit side of the firewall and >> be >> able to rotate it by a shaft connected to the selector handle." >> >> Read the John Denver accident report on the FAA/NSTB web site! > > >This is the second connection between Denver's accident and the question >at hand. > >The fact that Denver had a "remote" selector did not cause his problems >as much as the un-safe location of the remote selector. > >I intend to use an electric valve in my -6, and have caught some grief >when discussing it. Departing from the original design is not _bad_ as >long as failure modes and backup possibilities of the change are >examined. >This I have done, and I think I'll be as safe as anyone, or anyone who >wants to use a remote valve - so long as they don't mount it over their >left shoulder! > >Mike Thompson >Austin, TX >-6 N140RV (Reserved) >Wings > > ________________________________________________________________________________
Date: Mar 30, 1999
Subject: Govener accesory pad
I have an O-360-A1A and do not plan on using a constant speed prop. I have removed the oil line and plugged the holes and was wondering what to do with the governor mounting pad. Should I fabricate a blockoff plate for the where the governor would normally attach, or should I remove the governor mounting pad and associated gears and put a blockoff plate on the accessory case. Gary Zilik Pine Junction, CO RV-6A s/n 22993 ________________________________________________________________________________
Date: Mar 30, 1999
Subject: Re: crossover exhaust
In addition to scavenging the exaust, it improves the intake charge. There is a period of time (valve overlap) where both valves are open. The scavenge starts in motion the input charge. Tom Barnes -6 canopy -----Original Message----- From: RV6junkie(at)aol.com <RV6junkie(at)aol.com> Date: Monday, March 29, 1999 10:50 AM Subject: Re: RV-List: crossover exhaust > >In a message dated 3/28/99 9:21:57 PM Eastern Standard Time, >glenng(at)megsinet.net writes: > >> Can someone explain the purpose of crossing over the exhaust system on >> an RV-6? > >It has to do with power pulses and exhaust scavenging. By using a crossover >exhaust you use low pressure created in one cylinder to "suck" the exhaust >gases out of another cylinder while its exhaust valve is opened. > >Gary Corde >RV-6 N211GC - NJ > > ________________________________________________________________________________
Date: Mar 30, 1999
Subject: Slider Canopy Block Location (RV-6)
I realize that the primary consideration for locating the rear of the canopy frame is how the frame matches with the turtledeck. I *think* my frame is in the correct location, but the pins at the rear of the frame are 1/2" to 3/4" above the main longerons. Is this gonna be a problem?? Is there a "not to exceed" height for how high the pins can be (And you could shim the blocks, right?)? Suggestions appreciated. Kyle Boatright ________________________________________________________________________________
Date: Mar 30, 1999
Subject: Engine Mounts
Van's catalog shows engine vibration mounts which seem very pricey. ($68 per pair, 4 pair required) Question 1: Do mounts come in the finish kit? Question 2: What if any, are other sources? Bill Pagan N565BW(Reserved) "The original and only RV-8A builders page on the web" http://www.geocities.com/CapeCanaveral/Launchpad/9749/william.html ________________________________________________________________________________
Date: Mar 30, 1999
Subject: Re: Govener accesory pad
I removed the governor mounting pad (no sense spinning that gear needlessly & hauling around the weight) and covered it with a block off plate. The local FBO gave me an old plate out of their "old plate box" free of charge. Ed Bundy - RV6-A First flight 11/20/96 ebundy(at)cwix.com http://home.cwix.com/~ebundy@mci2000.com/ -----Original Message----- From: Gary Zilik <zilik(at)excelgeo.com> Date: Tuesday, March 30, 1999 4:50 PM Subject: RV-List: Govener accesory pad > >I have an O-360-A1A and do not plan on using a constant speed prop. I >have removed the oil line and plugged the holes and was wondering what >to do with the governor mounting pad. Should I fabricate a blockoff >plate for the where the governor would normally attach, or should I >remove the governor mounting pad and associated gears and put a >blockoff plate on the accessory case. ________________________________________________________________________________
Date: Mar 30, 1999
Subject: Re: Slider Canopy Block Location (RV-6)
Mine were about 3/4 inch above the longerons. Keeping the rear of the canopy low enough so that the rear skirts simply continue the F6112 "turtledeck" skin makes them fit nicely. hal > I realize that the primary consideration for locating the rear of the canopy > frame is how the frame matches with the turtledeck. I *think* my frame is in > the correct location, but the pins at the rear of the frame are 1/2" to 3/4" > above the main longerons. Is this gonna be a problem?? Is there a "not to > exceed" height for how high the pins can be (And you could shim the blocks, > right?)? ________________________________________________________________________________
Date: Mar 30, 1999
Subject: Re: Engine Mounts
Answers: 1 - No. 2 - ACS for example but more expensive. hal > Van's catalog shows engine vibration mounts which seem very pricey. ($68 > per pair, 4 pair required) > > Question 1: Do mounts come in the finish kit? > Question 2: What if any, are other sources? ________________________________________________________________________________
Date: Mar 30, 1999
Subject: Re: frivolous lawsuit
> > Trying to manipulate our legal system to expand your trademark rights > > for an engine monitoring instrument AFTER you decide to add fuel > > monitoring to it, AND trying to bully a one-man company with the excuse > > that he uses 4 letters of the alphabet that you use is unforgivable. For therapy against this sort of thing, I recommend taking out the local yellow pages, and tearing out all of the pages containing "attorneys". You have to try it to believe how good it feels. Alex Peterson ________________________________________________________________________________
Date: Mar 30, 1999
On Tue, 30 Mar 1999, Tom Barnes wrote: > > In addition to scavenging the exaust, it improves the intake charge. There > is a period of time (valve overlap) where both valves are open. The > scavenge starts in motion the input charge. There was a really good article on exhaust tuning and engine performance in "EAA Sport Aviation" magazine January 1997. It covered many different types of exhaust system including the "crossover" exhaust. For those of you who save your back issues of Sport Aviation, this is good reading. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane (916) 676-6399 - voice Suite 1 (916) 676-3442 - fax Cameron Park, CA 95682 ________________________________________________________________________________
Date: Mar 31, 1999
Subject: Re: Tire Mounting and Balancing
Hi Everyone, I'm at the point where I will want to mount my tires on the Cleveland wheels soon. I am beginning on the finish kit of my 6A. With the current discussion of wheel/gear shimmy problems and solutions, I have begun to wonder whether I should plan to mount the tires myself or have an aircraft maintenance facility mount and balance them for me-----or are their better options that others have used to get them properly balanced. I asked my local FBO about mounting and balancing them and got an estimate of 1.5 hours labor charge to mount and balance EACH TIRE. At $45/hr, that's a lot more than I had in mind! I'm hoping that their is a better and cheaper way that someone has found to get them properly done. I'm sure I would have no trouble mounting them myself, but I'm not sure where to get them balanced. What have you guys ahead of me done? Thanks in advance for your ideas. Dale Wotring RV-6A N244DW (finish kit) Vancouver, WA ________________________________________________________________________________
Date: Mar 30, 1999
Subject: Re: Tanks screws etc.
Buster: Where can a person bu Boelube? Thanks Gerald Buster wrote: > > I was fitting the tanks on to see how well they position after all the > sealing, etc. > I found that a product like Boelube, (looks like a dry lubricant pasty > powder) > Do-all, (looks like bees wax) or best of all, a dab of Mastinox, (looks like > a yellow custard) works like a charm to lube the screws very well so they > drive in well and better yet, remove well, avoiding a lot of twisting and > stripping of screws to seat them. > Another little item from an auto parts store is little round rubber > grommets all the way from 1/8" to 1/2" or more inside diameter, make for > handy, cheap carry throughs for wires where you don't really want big > honkin' holes for just one or two wires passing through a member or > bulkhead...e.g. spar attach or whatever..just a thought...Buster. > ________________________________________________________________________________
Date: Mar 31, 1999
I bought mine from Avery Tools. Stephen Soule Huntington, Vermont -----Original Message----- Where can a person bu Boelube? ________________________________________________________________________________
Date: Mar 31, 1999
Hi Dale, Save your money and do it yourself. The hardest part is getting the tubes in those little tiny tires. Use a little powder if you need to slick them up a little bit, and be sure to align the valve with the colored dot on the outside of the tire. That is supposed to provide the best balance. If you have a second set of hands, that will make it very easy to get the 2 wheel halves together, and start the bolts and nuts. Be careful not to pinch the tubes between the halves, before you tighten the bolts down all the way. I have never pinched one, but it looks like you will when you are stuffing all that tube in there. Good luck. ________________________________________________________________________________
Date: Mar 31, 1999
In a message dated 3/30/99 9:26:05 PM Eastern Standard Time, pagan(at)CBOSS.COM writes: << Question 1: Do mounts come in the finish kit? Question 2: What if any, are other sources? >> No, they are not in the finish kit! Other sources that I'm aware of are basically the same price. Bernie Kerr ________________________________________________________________________________
Subject: Tire Mounting and Balancing
Date: Mar 31, 1999
Does the valve stem go adjacent to the colored dot on the outside of the tire, or opposite the colored dot? Steve Soule -----Original Message----- Save your money and do it yourself. ... be sure to align the valve with the colored dot on the outside of the tire. That is supposed to provide the best balance. ________________________________________________________________________________
Date: Mar 31, 1999
From: Will Cretsinger <cretsinger(at)arlington.net>
Subject: Logging of Flight Test Data
I need some information regarding logging of flight test operational and performance data. Amateur-Built Aircraft And Ultralight Flight Testing Handbook (AC 90-89A) indicates this data should be incorporated "into the aircrafts flight manual so that the pilot can reference the data prior to each flight." Can, or should, the flight manual, pilots operating handbook, and the operational limitations (the "O" in ARROW) be one document? What entries should be made in the aircraft log regarding the test flight phase? Sample entries? It seems aircraft log entries have to do with the flight phase whereas the POH incorporates the flight test data? Later reentry into flight test phase to document aerobatic capabilities would entail two entries in the aircraft log, one for entering and one for completion? The POHs posted on the web by Gary V and Scott G seem to incorporate most of the essentials determined by flight testing. It would seem that one of these POHs can be modified with the figures for my airplane and will meet the requirements of AC 90-89A? What are some of the more important flight test data which should be included in the POH? Thank you for comments and sample entries. Will Cretsinger, Arlington, TX -6A Landing gear pants/fairings & flight test ________________________________________________________________________________
Date: Mar 31, 1999
From: "Douglas G. Murray" <dgmurray(at)telusplanet.net>
lottmc(at)datasync.com wrote: > > Hi Dale, > Save your money and do it yourself. The hardest part is getting the tubes in those little tiny tires. Use a little powder if you need to slick them up a little bit, and be sure to align the valve with the colored dot on the outside of the tire. That is supposed to provide the best balance. If you have a second set of hands, that will make it very easy to get the 2 wheel halves together, and start the bolts and nuts. Be careful not to pinch the tubes between the halves, before you tighten the bolts down all the way. I have never pinched one, but it looks like you will when you are stuffing all that tube in there. Good luck. Dale -Put a little talcum powder inside the tire first and make sure it has been brushed over all the interior of the tire. It serves to cut friction between the tube and tire. I like to partially fill the tube with air before joining the hub half's. There is less tendency for the folds in the tube to slide between the hub half's this way. When you inflate the tire after you have assembled the hubs, you may have to push the tube stem part way back into the hub the help the air on the outside of the tube escape to atmosphere. I like to completely fill the tire to 25# and then let all the air out and then refill again to 28# just to be sure that the tube gets a chance to move a little to reduce the chances of it being folded over on itself. I hope this helps. DGM RV-6 Southern Alberta ________________________________________________________________________________
Date: Mar 31, 1999
> << Question 1: Do mounts come in the finish kit? > Question 2: What if any, are other sources? >> > > No, they are not in the finish kit! > > Other sources that I'm aware of are basically the same price. > > Bernie Kerr > --- One other source is your local FBO. I was given a set of good used mounts with the silicone inserts for my installation. The price was right. I wiped then down and they look just like new. I do have one half on a lower one that has started to show surface cracking I wonder how long I ought to leave it before replacing it. Anyone have any ideas? Who Knows - maybe my aviation friend will have another mount I can get. DGM RV-6 Southern Alberta ________________________________________________________________________________
Date: Mar 31, 1999
Stephen J. Soule wrote: > -Does the valve stem go adjacent to the colored dot on the outside of the > tire, or opposite the colored dot? > > Steve Soule Steve - the dot goes right beside the valve stem. DGM RV-6 Southern Alberta ________________________________________________________________________________
Date: Mar 31, 1999
It is very helpful to inflate the tube a little bit after getting it inside of the tire before joining the rim halves. This is helpful to keep the limp tube from dangling in between the rim halves where they join. Don't inflate enough to stretch the tube, just take the slack out. After torqueing the bolts, inflate to recommended pressure, then let all the air out, then inflate back to normal pressure. This insures against pinching the tube or wrinkling it. My experience Brad Bundy Flying Chard Built RV6 N48AC ________________________________________________________________________________
Date: Mar 31, 1999
Hi, Stephen, I always put the dot right next to the stem. ________________________________________________________________________________
Date: Mar 31, 1999
-----Original Message----- From: gerric(at)agt.net <gerric(at)agt.net> >Buster: >Where can a person bu Boelube? >Thanks >Gerald This excellent product, developed by Boeing (hence the name), was bought from Aircraft Spruce.. ________________________________________________________________________________
Date: Mar 31, 1999
> >-----Original Message----- >From: gerric(at)agt.net <gerric(at)agt.net> >To: rv-list(at)matronics.com >>Buster: >>Where can a person bu Boelube? >>Thanks >>Gerald > > >This excellent product, developed by Boeing (hence the name), was bought >from Aircraft Spruce.. > > >It can also be ordered from Avery Tools> > ________________________________________________________________________________
Date: Mar 31, 1999
To prevent pinching the tube between the wheel halves, just blow a little air in the tube to make it doughnut shaped instead of lying flat while you are bolting the wheel halves together. Also, use a liquid hand soap to lubricate the bead of the tire so it will easily slip up against the rim of the wheel when you air up the tire. Over inflate the tire first, then bleed off to proper air pressure. Hope this helps. Marshall Dues RV-6 N243MD 199 hr DWH arpt (Houston) ________________________________________________________________________________
Date: Mar 31, 1999
pagan wrote: > Van's catalog shows engine vibration mounts which seem very pricey. ($68 > per pair, 4 pair required) > Question 2: What if any, are other sources? There is a non-certified version of these mounts available. Wicks Aircraft Supply (See Yeller Pages) shows part number EM100-005 at 175.00 for complete set (4 Pairs). I did not know about this when I bought my certified mounts. Otherwise, I probably would have given them a try. From the picture in the catalog, they appear to be an exact copy of the certified version (perhaps they are identical, except for paperwork?) If you try these, let us know how they work out. Blake Harral RV-4, Hope to be flying in June ________________________________________________________________________________
Subject: IO360
Date: Mar 31, 1999
Called J B ACFT engine for a part I needed and they said by the way we have an IO360 A3B6D with all ACC encluding ring gear. 1700 smoh, 3600 TT. Came off a monie no prop strikes. Dont know anything about this just passing along the info. Call 941 655 5000 RV6A/finish kit ________________________________________________________________________________
Date: Mar 31, 1999
> Question 2: What if any, are other sources? >> When I bought my engine from Central Air Parts, I asked them what they might have on hand as far as engine mounts from the many aircraft they dismantle. They are including a set of mounts in the crate. I have no idea if they'll be serviceable or not, but at least it's worth a shot. If they are deteriorated, I won't use them. If they look good, then I'll be quite pleased! You might try calling them and see what they can do for you. Brian Denk RV8 #379 engine on the way...hoping the engine AND the mounts look good! ________________________________________________________________________________
Date: Mar 31, 1999
Many Bicycle shops also have it to protect the inside of steel bikes. Cy Galley - Editor BC Contact! Click here to visit our Club site at http://www.bellanca-championclub.com -----Original Message----- From: Buster <6430(at)axion.net> Date: Wednesday, March 31, 1999 11:04 AM Subject: Re: RV-List: Tanks screws etc. > > >-----Original Message----- >From: gerric(at)agt.net <gerric(at)agt.net> >To: rv-list(at)matronics.com >>Buster: >>Where can a person bu Boelube? >>Thanks >>Gerald > > >This excellent product, developed by Boeing (hence the name), was bought >from Aircraft Spruce.. > > ________________________________________________________________________________
Date: Mar 31, 1999
In a message dated 3/31/99 5:37:56 AM Pacific Standard Time, SSoule(at)pfclaw.com writes: << Does the valve stem go adjacent to the colored dot on the outside of the tire, or opposite the colored dot? >> Stem aligns with dot. The dot indicates the lightest area of the tire and the stem is the heaviest area of the tube. However this may not completely balance the assembly so one should always check the static balance by slowly spinning the assy on the shaft and seeing if it always settles at a given point. Balance weights may be added to the top as needed. -GV ________________________________________________________________________________
Date: Mar 31, 1999
Subject: Re: Logging of Flight Test Data
> >I need some information regarding logging of flight test operational and >performance data. Amateur-Built Aircraft And Ultralight Flight Testing >Handbook (AC 90-89A) indicates this data should be incorporated "into >the aircrafts flight manual so that the pilot can reference the data >prior to each flight." > >Can, or should, the flight manual, pilots operating handbook, and the >operational limitations (the "O" in ARROW) be one document? >The POHs posted on the web by Gary V and Scott G seem to incorporate >most of the essentials determined by flight testing. It would seem that >one of these POHs can be modified with the figures for my airplane and >will meet the requirements of AC 90-89A? What are some of the more >important flight test data which should be included in the POH? > >Thank you for comments and sample entries. >Will Cretsinger, Arlington, TX Will, First, you are not required to comply with AC 90-89A, it is simply a recommendation. But, I think it is a good recommendation, so I encourage your efforts. There is no reason why the flight manual, pilot's operating handbook and the operational limitations could not be in the same document, in fact that is the best approach in my opinion. A good guide is to take a look at the pilot's operating handbook from a newer Piper or Cessna (and I assume a Beech, I mean Raytheon, but I am not familiar with those). These handbooks are done in a format developed by GAMA, and they cover all the bases. I believe that the POHs posted by GV and Scott G may be based on the same format, but I cannot confirm that as my ancient version of Word chokes on them. A good look at a GAMA format operating handbook will give you a list of limitations, normal, abnormal and emergency procedures, systems description and performance data to include. The complete list is too long to practically include, plus I don't have a handbook home to look at anyway. There is probably no need to do produce rigorous take-off and landing performance charts, unless you want to operate out of shorter strips at high airfield elevations. In that case I might be able to dig up some rough generic corrections you could apply to data from low altitude to give estimated hot and high performance. Of course, I've got to finish working on the GPS flight test notes I promised first :-) That'll be done soon, I promise, maybe this weekend. My wife will be away for a few days, so I'll have nothing to do except work in the RV, work on the computer, drink beer and fly (not in that order). Take care, Kevin Horton RV-8 (fuel tanks & fuselage bulkheads) khorton(at)cyberus.ca (613) 821-7862 (home) Ottawa, Canada (613) 952-4319 (work) http://www.cyberus.ca/~khorton/rv8.html ________________________________________________________________________________
Date: Mar 31, 1999
Subject: Kit for sale
Any one in Florida interested in an RV6-6A empennage kit 90% complete? Also, wing kit 90% complete, preview plans, plus manual. Delivered to your "cottage" in Florida. The reason for sale is that I am switching back to my RV3 project as soon as kits are available. Contact off line @ tmb1564(at)aol.com or 561/466-3536. Tom Benton ________________________________________________________________________________
Date: Mar 31, 1999
Subject: Re: Engine inhibiting and Pre-Oilers
> Then just before starting it preoil it. How about the practice of cranking the engine a few seconds with mixture full lean etc so that it doesn't start immediately?? Then, there is pulling it thru by hand first. hal ________________________________________________________________________________
Subject: Norway suing JPI and HP
Date: Mar 31, 1999
Hello fellow listers....this just in on the miswired WIRE. Norway and Sweden are suing JPI over the use of the word "SCAN". They are also suing Hewlett Packard (ScanJet) and movie producer David Cronenberg (Scanners). Jorgy Lappbelt a spokesperson for the Ministry of Ridiculous Lawsuits stated that they have been SCANdanavians for much longer than JPI has been using the word SCAN. As partial settlement the SCANdanavians will be require Mr Polizzotto to be equipped with antlers riveted to his head, covered in reindeer pheremones and locked naked in a pen full of rutting reindeers. OK it's april 1 and I had my respirator on backwards while shooting primer....but I'm not as lightheaded as Mr. Polizzotto from JPI. below is a clip from the weekly AVweb post for those listers who don't get AVweb (highly reccomended and free) Rob Baxter RV8 tail ==========snip============== GOLIATH SUES DAVID... This one's gotten way out of hand. AVweb has been watching a spat between J.P. Instruments (JPI), which makes FAA-approved engine monitoring devices for piston engines, and Matronics, a one-man company selling a low-cost, uncertified fuel totalizer system popular with builders of homebuilt aircraft. After weeks of threats, JPI has filed a lawsuit against Matronics, contending that the latter's use of the product name "FuelScan" infringes JPI's trademarked products. ...OVER USE OF THE WORD "SCANNER" JPI's president Joseph Polizzotto contends that Matronics' FuelScan is "confusingly similar" to JPI's Scanner, Smart Scanner and DigiScan products. Matronics owner Matt Dralle says that JPI is improperly trying to extend its trademark rights to all such products containing the suffix "scan." Dralle says he does not have the resources to wage a legal battle with JPI and is appealing to the homebuilder community for help. Contact Dralle at and Polizzotto at . NOTE: AVweb's Newswire includes additional details on JPI's lawsuit against Matronics. ===========snip=========== ________________________________________________________________________________
Date: Mar 31, 1999
Subject: RV-3 Wing Mods
I wonder if this was meant as humor??? Someone wrote: > I found a contradiction from the literature sent with CN-1(rear spar > attachment/rear spar carry through mod) and CN-2(main spar mod). In CN-1 it > state something like "enlarging the holes in the spar flange strips to the > next bigger size will reduce the spar strength by 2%," something to that > effect, and in CN-2, you are doing just that by drilling out the -4 rivets > and replacing with -6, and putting in the AN-3 bolts for the angle? > I suspect that engineering calculations as to structure's strength differ from physical testing actual strength by at least plus minus 5%. This is what engineers call "specious precision" if I remember right. hal ________________________________________________________________________________
Date: Mar 31, 1999
Brian Denk wrote: > > > > Question 2: What if any, are other sources? >> > > When I bought my engine from Central Air Parts, I asked them what they > might have on hand as far as engine mounts from the many aircraft they > dismantle. They are including a set of mounts in the crate. I have no > idea if they'll be serviceable or not, but at least it's worth a shot. > If they are deteriorated, I won't use them. If they look good, then > I'll be quite pleased! You might try calling them and see what they can > do for you. > One thing you need to watch for is there are many different grades of hardness to these mounts. Each part number represents a specific purpose. Get the wrong ones and you will have a lot more vibration than you will like. They also need to have a certain amount of hardness if you plan on doing aerobatics. Jerry Springer|RV-6 first flight 1989|Hillsboro, OR|jsflyrv(at)teleport.com ________________________________________________________________________________
Date: Mar 31, 1999
Subject: Re: Request for an RV6 Maintenance Schedule
>Hi All > >In order for us to register RV's in our country, the Civil Aviation >Authorities require a specific maintenance schedule for the aircraft. >Please help. Does anyone have a basis that we can modify for use here. > >Kind Regards > >Gary F Wellock >Tail Feathers Gary, Here's the one that I use. Hope it helps. Bob Skinner RV-6 460 hrs. Buffalo, WY bskinr(at)trib.com *********** INSPECTION REPORT Type of Inspection __________________ OWNER: _________________________ DATE: _________ MAKE: _________ HOURS: _________ "N" #: _________ SER. #: _________ DESCRIPTION A. PROPELLER GROUP 1.______ Inspect spinner and back plate 2.______ Inspect blades for nicks and cracks 3.______ Check for grease and oil leaks 4.______ Lubricate propeller per lubrication chart 5.______ Check spinner mounting brackets 6.______ Check propeller mounting bolts and safety 7.______ Inspect hub parts for cracks and corrosion B. ENGINE GROUP CAUTION: ground mags before working on engine 1.______ Remove engine cowl 2.______ Clean and check cowling for cracks, distortion and loose or missing fasteners 3.______ Drain oil sump 4.______ Clean suction oil strainer at oil change 5.______ Clean pressure oil strainer or change full flow oil filter element 6.______ Check oil temp. sender for leaks and security 7.______ Check oil lines and fittings for leaks, chafing, security, dents and cracks 8.______ Clean and check oil radiator cooling fins 9.______ Fill engine with oil per lubrication chart 10._____ Clean engine 11._____ Check condition of spark plugs, adjust gap to:______ clean, test, rotate 12._____ Check ignition harness and insulators 13._____ Check magneto points for proper clearance maintain at .018 +- .006 14._____ Check magneto for oil seal leaks 15._____ Check breaker felt for proper lubrication 16._____ Check distributor block for cracks, burned areas or corrosion 17._____ Check magnetos to engine timing Left______ Right _______ 18._____ Remove air filter and clean 19._____ Drain carburetor and clean inlet line fuel strainer 20._____ Check condition of carburetor heat air door and box 21._____ Check intake seal for leaks and clamps for tightness 22._____ Clean fuel screens 23._____ Clean and check gasolator 24._____ Inspect condition of fuel lines 25._____ Check fuel system for leaks 26._____ Check electric fuel pump for operation 27._____ Check engine controls throttle, carb heat, mixture, and prop 28._____ Inspect exhaust stacks, connections, gaskets 29._____ Inspect heat exchange, baffles and shrouds 30._____ Check breather tube for obstructions and security 31._____ Check crankcase for cracks, leaks, security of bolts 32._____ Check engine mounts for cracks and loose mountings 33._____ Check all engine baffles 34._____ Check firewall seals 36._____ Check condition and tension of alternator and drive belt 36._____ Check condition of starter 37._____ Check fluid in brake reservoir 38._____ Lubricate all controls 39._____ Inspect engine for general condition, loose parts, chafing, proper safties and proper installation 40._____ Check condition of alternator 41._____ Check vacuum pump and lines 42._____ Compression check #1______ #2______ #3 ______ #4 ______ #5 ______ #6 ______ 43._____ Grease starter gear with moly 44._____ Reinstall engine cowl C. CABIN GROUP 1._____ Inspect canopy and windows 2._____ Check upholstery for tear 3._____ Check seats, seat belts, shoulder straps 4._____ Check trim operation 5._____ Check rudder pedals 6._____ Check control column, systems and connection 7._____ Check landing, nav, cabin, and instrument lights 8._____ Check instrument, lines and attachments 9._____ Check gyro operation, and electric turn and bank 10.____ Check or replace gyro air filter 11.____ Clean or replace vacuum regulator filter 12.____ Check altimeter 13.____ Check operation of fuel selector valve 14.____ Check operation of engine primer 15.____ Check condition of heater controls 16.____ Check condition and operation air vents 17.____ Check flap operation 18.____ Check fuel drains 19.____ Lubricate aileron, flap and elevator controls 20.____ Check general condition uder panel for loose wires, chafing, etc. 21.____ Check brake cylinders for operation and leaks D. FUSELAGE AND EMPENNAGE GROUP 1._____ Remove inspection plates and panels 2._____ Check battery box, battery and cables 3._____ Check electronic installations 4._____ Check bulkheads and stringers for damage 5._____ Check antenna mounts and wiring 6._____ Check fuel lines and valves 7._____ Check vertical fin and rudder surfaces 8._____ Check rudder horn and attachment 9._____ Check vertical fin attachments 10.____ Check rudder bolts for wear 11.____ Check horizonal stabilizer and elevators 12.____ Check horizonal stabilizer attachment 13.____ Check elevator horn 14.____ Check elevator bolts for wear 15.____ Check elevator bell cranks and controls and trim system 16.____ Lubricate all bearings as needed 17.____ Check general condition of skin 18.____ Check doors, latches and hinges 19.____ Check wiring for damage and security 20.____ Check cables for damage, security and operation 21.____ Check cabin heater and controls 22.____ Service hydraulic brake system 23.____ Check drain holes in rudder bottom and fuselage 23.____ Reinstall inspection plates and panels E. WING GROUP 1._____ Remove inspection plates and fairings 2._____ Check surfaces and tip for damage and loose rivets and condition of walkways 3._____ Check aileron mounts and attachments 4._____ Check aileron bellcrank and control tubes 5._____ Check flaps and attachment for damages 6._____ Check all wing attachment bolts 7._____ Check fuel tanks and lines for leaks and chafing 8._____ Check fuel tank vents 9._____ Check pitot 10._____ Reinstall inspection plates F. LANDING GEAR GROUP 1._____ Check nose gear travel and damper tightness 2._____ Check main gear attachments 3._____ Check tires for cuts and wear 4._____ Remove wheel, clean, and repack bearings COTTER PINS IN AXLES? 5._____ Check wheels for cracks, corrosion and broken bolts 6._____ Check tire pressure_____ 7._____ Check brake lining and disc 8._____ Check brake lines 9._____ Check tailwheel assembly for integrity and grease tailwheel G. OPERATIONAL INSPECTION 1._____ Check fuel pump and fuel tank selector 2._____ Check fuel pressure 3._____ Check oil pressure and temperature 4._____ Check alternator output 5._____ Check manifold pressure 6._____ Check alternate air 7._____ Check vacuum gauge 8._____ Check gyros for noise and roughness 9._____ Check Cabin heat operation 10.____ Check magneto switch operation 11.____ Check magneto RPM variation Left_____ Right_____ Run up rpm_______ 12.____ Check throttle and mixture operation 13.____ Check propeller smoothness 14.____ Check electronic equipment operation: fuel gauges, tach, engine instrumensts 15.____ Check ELT for operation and battery date 16.____ Check static rpms 17.____ Check idle rpms H. GENERAL 1._____ A.D.s complied with 2._____ Manufacturers service letters complied with 3._____ Registration, Airworthiness Cerfificate, Operating Limitations Signature_________________________ Certificate No.________________________ ________________________________________________________________________________
Subject: Re: LEADING EDGE
Date: Mar 31, 1999
>Perspective! >The glider almost certainly has a laminar flow wing. Bugs on the >leading >edge would probably cause the same problem. Most of the original >canard >designs had this problem. The paint seam (or bugs) disrupts the >laminar >flow & kills the lift efficiency of the airfoil. Now note the paint on >the RV-4 prototype. It's not laminar flow & isn't as sensitive to >bugs, >paint stripes, etc. > This is true, but... If you look closely at the paint scheme on the proto RV-4 you will see that the paint color change (mask line) is still quite a ways back from the leading edge. It is correct that an RV is not using a laminar flow airfoil (it uses the 23000 series like on a cub, actually it is a 23013.5) This airfoil can have its stall characteristics effected by anything that would act as a stall strip. A paint mask line (particularly a heavy one) located at an inappropriate location (somewhere close to the leading edge)can be as active as a purposely installed stall strip. Please use caution when planning a paint scheme. Scott McDaniels These opinions and ideas are mine alone and do not necessarily reflect the opinions and ideas of my employer. ________________________________________________________________________________
Date: Mar 31, 1999
OK. I'll bite. Why do you need a certain amount of hardness for aerobatics. AND What's the limit on the aerobatics using the normal engine mounts that VAN's sell? Paul Imhof, RV-8 on gear, tail attached. -----Original Message----- From: Jerry Springer [mailto:jsflyrv(at)teleport.com] One thing you need to watch for is there are many different grades of hardness to these mounts. Each part number represents a specific purpose. Get the wrong ones and you will have a lot more vibration than you will like. They also need to have a certain amount of hardness if you plan on doing aerobatics. Jerry Springer|RV-6 first flight 1989|Hillsboro, OR|jsflyrv(at)teleport.com ________________________________________________________________________________
Date: Apr 01, 1999
Hello again. Thanks to everyone who responded to my tire mount and balance question. I feel confident to go ahead and mount the tires myself now with the directions you have given. I'll put them on the axles and see if they seem out of balance or not by spinning them. If they appear to need balancing, I think I'll see if a local tire store has equipment to balance tires and wheels that size. I'll report back to the list if I find a good cheap way to get them precision balanced. Its good to know that they don't really need to be precision balanced, but if I find a cheap way to do it I'll probably do it. Can't hurt. This list is really a great resource! Thanks. Dale Wotring RV6A (finish kit) Vancouver, WA ________________________________________________________________________________
Subject: David Clark Headset
Date: Apr 01, 1999
(2) David Clark headsets for sale Model H10-13.4 , in very good condition. They are two years old. $ 140.00 each or $250.00 for the pair. Plus shipping. Tony Partain Partain Trading Co Inc 314-894-0828 aviator(at)tseinc.com ________________________________________________________________________________
Date: Mar 31, 1999
Paul_Imhof(at)Dell.com wrote: > > > OK. I'll bite. Why do you need a certain amount of hardness for aerobatics. > AND What's the limit on the aerobatics using the normal engine mounts that > VAN's sell? > > Paul Imhof, RV-8 on gear, tail attached. > > -----Original Message----- > From: Jerry Springer [mailto:jsflyrv(at)teleport.com] > > One thing you need to watch for is there are many different grades of > hardness to these mounts. Each part number represents a specific purpose. > Get the wrong ones and you will have a lot more vibration than you will > like. They also need to have a certain amount of hardness if you plan > on doing aerobatics. > > Jerry Springer|RV-6 first flight 1989|Hillsboro, OR|jsflyrv(at)teleport.com > Well just how much do you want your engine moving around when you are doing aerobatics? Remember this is a rubber cushion, softer lets the engine shift around under g loads. Van use to to list a specific number for lord mounts that were a good combination for aerobatics and least amount of vibration. Since I built my airplane he has started selling mounts and I don't know what they are you would have to ask him. A good example was a RV-4 here locally that had a very bad vibration problem and no matter what was done it could not be fixed this included all the prop balancing methods. It was finally figured out that it had the wrong mounts. If Mike Segar reads this he could comment more as he helped with this airplane. ________________________________________________________________________________
Date: Apr 02, 1999
> I wonder if this was meant as humor??? Hal- I found no humor in this whatsoever for several reason, maybe you'll agree? I wrote this back when one RV-3 builder had elongated a hole after drilling the spar flange -4 rivet out to 3/16" and was asking about the possibilities of going to the next size larger hole, or a larger rivet/AN4 bolt. I did not have the document in front me when I wrote this, and now I do out of curiosity and to disprove any "humor" in all of this, and will quote Vans aircraft and CN-1 (February 1982): "INSPECTION POINTS: Following is a list of possible errors in the construction of an RV-3 wing which can have an appreciable effect on its strength. Presence of any one or more of these errors will result in a reduction in strength and the RV-3 will not meet 6-G limit load aerobatics requirements at a gross weight of 1050 lbs. Therefore, it should not be re-designated an RV-3A. By definition, an RV-3A is one built in strict compliance with VAN'S AIRCRAFT RV-3 plans and has been modified in accordance with VAN'S AIRCRAFT CN-1. Thus, any RV-3 with a known structural deviation, whether included in the following list or not, should not be re-designated as RV-3A:" (items 1-3 skipped.) "4. Substitution of larger than 1/8" rivets in the spar flange strip attachment will result in reduced strength. If a 3/16" bolt or rivet is substituted, a strength loss of up to 6% will result." (items 5-7 skipped.) NOW, on to the main spar mod (January 1997), called CN-2(CN-2-I for type-I early pre-1984 wings/spar, and CN-2-II for post 1984 wings/spars): "The CN-2-I modifications supplements the CN-1 modifications, but does not supersede or replace it. Both are necessary to achieve aerobatics strength. Each addresses a different part of the wing structure. If any RV-3 has not yet been modified in accordance with CN-1, this needs to be performed before or in conjunction with CN-2-I." Okay, to give the Readers Digest summary of CN-2-I: - Drill out all of the 1/8"/-4 rivets in the inner row of the staggered -4 rivet pattern on the lower spar flange strips between ribs 1-6. - Enlarge the 1/8"(#30) holes to 3/16" and replace with -6 (3/16") rivets (now, myself and several other RV-3ers have, through coordinating with VAN's for engineering approval, substituted AN3 bolts for the -6 rivets in this application). - Drill out three 1/8"/-4 rivets in the upper spar flange strips between ribs 1-6 and enlarge holes to 3/16" (with some minor differences between ribs 1-2). - Cut and fit 1x1.250x.125 6061-T6 stiffener angle between ribs and attach to the upper spar flange strips with AN3 bolts through the three enlarged holes, repeating between ribs 2-6, and also in fuselage outward of the 4130 steel splice plates (Ribs 1-2 gets 1.250x1.250.125 angle). - Cut and fit .063 and/or .040 2024 T3 sheet to cover lightning holes and pop rivet to spar web covering holes with MSP-42 pop rivets or AN470AD4-5 rivets. Okay. Can you see where the contradicting and confusing data is? CN-1 states that a 6% loss of strength can occur if you replace the 1/8"/-4 rivets with -6 rivets and/or AN3 bolts. Where CN-2-II says that you are to replace all of the lower spar flange 1/8"/-4 rivets with 3/16"/-6 and/or AN3 bolts! And in addition to that, add the three AN3 bolts between each rib to hole on the angle stiffeners! > I suspect that engineering calculations as to structure's > strength differ from > physical testing actual strength by at least plus minus 5%. This is what > engineers call "specious precision" if I remember right. I've rarely seen anything that I work with have a slosh factor of more than +/- .5-1%, with real slop being around 1.5-2%. I'll check with several close friends (one formal structural design engineer at Boeing for 777 and Bell helicopter, the other was former structures at Rockwell, Cessna, Beechcraft, and test pilot for Lear) and see what they think a 5% loss would amount to in this application. . curious. Well, maybe that's not much, but it's enough to make me want to correct for the 5% loss of strength when it's my ass strapped into the seat and nobody else's! Rob Reece RV-3 SN 45 Socorro, NM 505-835-3644 ________________________________________________________________________________
Date: Apr 01, 1999
Subject: Re: RV-3 Wing Mods
Rob Reece wrote: > > - Cut and fit 1x1.250x.125 6061-T6 stiffener angle between ribs and attach > to the upper spar flange strips with AN3 bolts through the three enlarged > holes, repeating between ribs 2-6, and also in fuselage outward of the 4130 > steel splice plates (Ribs 1-2 gets 1.250x1.250.125 angle). > > - Cut and fit .063 and/or .040 2024 T3 sheet to cover lightning holes and > pop rivet to spar web covering holes with MSP-42 pop rivets or AN470AD4-5 > rivets. > > Okay. Can you see where the contradicting and confusing data is? CN-1 > states that a 6% loss of strength can occur if you replace the 1/8"/-4 > rivets with -6 rivets and/or AN3 bolts. Where CN-2-II says that you are to > replace all of the lower spar flange 1/8"/-4 rivets with 3/16"/-6 and/or AN3 > bolts! And in addition to that, add the three AN3 bolts between each rib to > hole on the angle stiffeners! Rob, I'm not familiar with the RV-3 internal wing structure, but here is what I surmise from your posting of the excerpts from the change notices: First, Van's claims a strength reduction by using larger rivets. This makes sense for a joint loaded in tension (normal case for the lower spar flange), because the larger hole removes load bearing material. The analysis for the compression case (upper spar flange) is more complex, but I suspect the strength reduction is less. Second, Van's instructs you to use a larger fastener on both the top and bottom flange strips, but angle is added to the top flange strips. For the top flange strips, presumably this extra angle material more than makes up for the loss of strength in the flange strips due to the larger holes. In other words the _assembly_ that makes up the top spar cap is now stronger than the original, even though some the original parts were weakened. The bottom spar flange has had the holes enlarged, but no additional material has been added, so it _will_ have reduced strength per the notes in CN-1 So it appears Van has strengthened the upper spar cap, while slightly weakening the lower spar cap. The strengthening of the upper spar caps, plus the covering of the lightening holes seem to suggest that Van is trying to prevent the buckling of the upper surface of the wing, due to high positive G-loads. Why 'weaken' the lower spar cap in process? I'm not sure, but if it is necessary to disassemble the spar for these modifications, perhaps this is the best solution to the oversize/elongated holes that would probably result from such disassembly. The resulting reduction in strength may be perfectly acceptable in the lower spar cap, if the original design had 'excess' strength in this part. I'm not a structural engineer, nor am I privy to Van's calculations. I did want to point out that it entirely possible that Van's modifications are sensible, even with the apparent contradictions. Your desire for more information is understandable, I would like to know more of the details myself. Perhaps someone at Van's can address this. Blake Harral ________________________________________________________________________________
Date: Apr 01, 1999
<-- a bunch of stuff snipped--> >Okay. Can you see where the contradicting and confusing data is? CN-1 >states that a 6% loss of strength can occur if you replace the 1/8"/-4 >rivets with -6 rivets and/or AN3 bolts. Where CN-2-II says that you are to >replace all of the lower spar flange 1/8"/-4 rivets with 3/16"/-6 and/or AN3 >bolts! And in addition to that, add the three AN3 bolts between each rib to >hole on the angle stiffeners! > >> I suspect that engineering calculations as to structure's >> strength differ from >> physical testing actual strength by at least plus minus 5%. This is what >> engineers call "specious precision" if I remember right. > >I've rarely seen anything that I work with have a slosh factor of more than >+/- .5-1%, with real slop being around 1.5-2%. I'll check with several >close friends (one formal structural design engineer at Boeing for 777 and >Bell helicopter, the other was former structures at Rockwell, Cessna, >Beechcraft, and test pilot for Lear) and see what they think a 5% loss would >amount to in this application. . curious. > >Well, maybe that's not much, but it's enough to make me want to correct for >the 5% loss of strength when it's my ass strapped into the seat and nobody >else's! >Rob Reece Bob, I can certainly understand your concern to make sure this is done right. But, hasn't Van done static testing on a modded RV-3 wing that showed that the desired strength is achieved? Have there been any inflight breakups of RV-3s with CN-1 and CN-2-II? Van is the guy with the answers to your questions on inconsistencies between CN-1 and CN-2-II. Anything you get off us bozos is worth what you've paid for it ;-) Take care, Kevin Horton RV-8 (fuel tanks & fuselage bulkheads) khorton(at)cyberus.ca (613) 821-7862 (home) Ottawa, Canada (613) 952-4319 (work) http://www.cyberus.ca/~khorton/rv8.html ________________________________________________________________________________
Date: Apr 01, 1999
In a message dated 3/31/99, 3:00:21 PM, rv-list(at)matronics.com writes: Engine mounts are typically changed when an engine is removed or replaced. Although they might look serviceable, time does harden the material and they do a poorer job of isolating vibration. I would always opt for new mounts, especially on a new aircraft. Its one of those things that you don't realize that they were worn until you replace them and suddenly things are smoother. Gary Corde RV-6 N211GC - NJ <> ________________________________________________________________________________
Date: Apr 01, 1999
Hi Rob, I'll retract my earlier posting regarding using a file to move the 1/8" holes in the lower spar cap before drilling to 3/16 rivits, to ensure proper edge clearance. Not needed, as the upper (inner) part of the lower spar cap is in compressing during positive G loads. I don't believe that CN-2 promises full -6 G's. Finn Rob Reece wrote: > - Drill out all of the 1/8"/-4 rivets in the inner row of the staggered -4 > rivet pattern on the lower spar flange strips between ribs 1-6. > > - Enlarge the 1/8"(#30) holes to 3/16" and replace with -6 (3/16") rivets ________________________________________________________________________________
Date: Apr 01, 1999
Subject: RV-8;Observations
Now that I have a few more hours on my RV-8, I have a few more things to mention. As I posted before, I had a left wing heavy tendency, even with the manual trim in full right position. Jerry VanGrunsven (no connection with Vans Aircraft) came down at my request and 'sqeezed' the right aileron trailing edge slightly, until the aileron followed a ruler layed on it. While we expected to need two or three flights to get it right, I flew the airplane and lo and behold, it was now perfect! Jerry was in formation with me (with his RV-4) and when I told him he got it perfect, he didn't believe me and asked me to put my arms up to prove it! It is hard to believe that just that little bit of 'messaging' of the aileron resulted in this much change! Jerry gave me a complete 'short course' on how to do this, and how to determine whether to sqeeze, or to 'fatten' the aileron leading edge, and I will post that in a separate post soon for the benefit of all. Another observation; All three of the RV-8's built on this field have had a wing left turning tendency, as well as requiring a tab on the rudder because of having to hold slight right
March 25, 1999 - April 01, 1999
RV-Archive.digest.vol-gq
