RV-Archive.digest.vol-gr
April 01, 1999 - April 08, 1999
rudder during cruise flight. Don't know whether this is just a
coincidence or what. Another opinion; this is definitely a more difficult
airplane to land smoothly than my RV-4 was. The higher stance of the
nose, the more sensitive rudder, and the stiffer gear probably has
something to do with it, as well as my inexperience. I am slowly getting
used to it though, and that is just my '10 hour' observation, ask me
again in another 40 hours what I think! It appears that this airplane
begs to be wheel landed every time and not 3-pointed. I had only
3-pointed the RV-4, so will have to practice, practice. Stay
tuned.........
Von Alexander
N41VA(at)juno.com
Subject: | Cherry Q rivets on RV-8 Tank Baffle |
I was getting ready to finish my RV-8 tanks last weekend and when I was
arranging all the tools and parts I needed I noticed that the rivets in my
bag of AD-41H and my bag of AD-42H's are exactly the same. They look way to
short to go through the Z-angle portion so I'm guessing I have all AD-41H's.
I called Van's and they are going to send me some 42H's but I wanted these
$%%#$ tanks done so I also had ASC fed-ex me some BSPQ-42's (pg. 100-101 in
98-99 cat)that they say are the same as USM AD42H's. They look completely
different than the Van's supplied ones as they are not Soldered on the ends.
Has anyone used the Cherry Q rivets (BSPQ-42's) for anything that needs to
be sealed? Do you think they will seal as well as the USM rivets?
Greg Puckett (Inventorying fuselage)
Elizabeth, CO
rv8er(at)concentric.net
Subject: | New AD for ALL RV'S! |
I'm hearing of a new AD coming out of Van's that
applies to all RV's that have ever been built as well
as those under construction.
It appears that all rivits must be replaced. Due to
excessive performance, Van has decided that flush
rivits produce too little drag, thereby threatening
the pilot community with "too much fun".
There are two complience methods offered:
1. All external skin rivits must be replaced with
CherryMax non-flush head rivits of equivilant
diameter to those replaced -- a detailed replacement
schedule will be forthcoming.
2. Placarding the MP or RPM instrument so that max
power is limited to no more than 125 HP, calculated
in accordance with the arcane formula published on
the "RV-List".
"These procedures will help eliminate these pesky
trips to the bank I have to keep making from the
brisk sales of kits" Van was quoted to say. "People
were building the planes and having so much fun they
were building second and third planes. I was
threatened with liability suits for grin removal
therapy. This AD should effectivly put a stop to
this!"
Happy April Fools!
Subject: | RV-8;Observations/Landing |
I too gave-up doing 3-pointers in my RV-6 do to the limited forward
visibility. After talking with one of the local RV experts at my airport, I
have found that the best way to wheel land is to touchdown nose high (as if
doing a "tail-high" 3-pointer) and move the stick forward which kills most of
the remaining lift. I found that when I tried to land in a level attitude the
stiff gear would bounce the aircraft.
Gary Corde
RV-6 N211GC - NJ
<< It appears that this airplane
3-pointed the RV-4, so will have to practice, practice >>
Subject: | Re: Light Speed Engineering Electronic Ignition |
Kerrjb(at)aol.com writes:
> I don't think the air or airplane know or care what the ignition system is. At
> a given RPM with a fixed airplane and prop, you will get the exact performance
> IMHO.
If by performance you mean speed, yes. If by performance you mean
fuel consumption, no. Improved ignition can result in more complete
and efficient combustion, which can result in producing the same
power at lower fuel flow. With a fixed-pitch prop, this would be
indicated by lower manifold pressure at the same RPM and airspeed
(though the difference will likely be very small). With a constant
speed prop, it would be indicated by higher speed at the same RPM
and manifold pressure.
Tedd McHenry
Surrey, BC
(-6 tail)
From: | Norman Stingent Polevaulter <reah_right(at)europa.com> |
Subject: | JPI Instruments Sues JPI |
AP April 1, 1999
JPI Instruments announced today that they have filed a trademark
infringement lawsuit against JPI (Jumbo Penis Inserts Ltd.), a San
Francisco based company which markets a product called PENISCAN(TM), a
semen totalizer, exhaust gas analyzer, and CHT probe.
JPI says that it could cause confusion with their product IQSCAN which
is an aviation industry board of directors IQ totalizer. Unfortunatly
JPI has never been able to fully test their product as they do not have
enough combined IQ to even move the needle off of zero.
Subject: | Re: Remote fuel selector |
>I for one will always put my grubby paws on the fuel selector directly and
>feel it into the proper on left or right position so as not to allow this
>possible problem.
Suzie Q (a -4) has a fuel selector valve down front per plans. I canted it
so the handle is pointing in the direction of the tank I am using. I built
up a little platform with a solid stop for the right tank, and a
spring-loaded one for the left tank. This spring-loaded stop has to be
pushed down to get the handle to OFF. This way, I have the detents and the
stops to assure the valve is were it is supposed to be.
I understand the desire to keep fuel lines out of the cabin, but I am not
sure the concerns are valid. If it is to prevent a possible fuel leak in the
cabin, those will probably start out small and be very noticable and will
reslult in a precautionary landing to fix the problem. Since they are on the
floor area the fuel will not be dripping on crew. If the concern is
rupturing a fuel line in an 'uncheduled landing', if you land hard enough
you are tearing up interior fuel lines, you will also be having many other
problems.
As we know, too many unscheduled landings in experimental aircraft are from
problems with the fuel system. The system as designed by Van is well tested
and works well in many different now flying aircraft. The temtation to
change a good thing should be carefully considered.
Just some thoughts.....
Michael
RV-4 N232 Suzie Q
Expanding the relationship.......
Subject: | RV-8 Fuselage Jig in CO needed |
Does anyone around Colorado have a fuselage jig that they will be done with
in the next month or so????
Greg Puckett
Flight Simulator Staff Specialist
United Airlines Flight Center,
7401 East Martin Luther King Blvd.
Denver, CO 80207 USA
PH (303)780-5916 FAX (303) 780-5861
puckett(at)ualfltctr.com
From: | "Molinos Cabodi Hnos SA - JMFC" <cabodijmfc(at)datasys.com.ar> |
Subject: | Aligning horizontal stabilizer |
I just finished the forward spar of my RV-8 empennage. Now, I am preparing
the jig to assembly the skeleton of the horizontal stabilizer, but it is
made from wood, so it has some little deviations from the ideal. Are there
safe margins in measurements when you aligning the HS or you have to do this
perfect?
PABLO
RV-8
Argentina
Subject: | Re: RV-8;Observations/Landing |
Gary; That sounds like it would work great, I will try it!
Von Alexander
N41VA(at)juno.com
>airport, I
>(as if
>most of
>attitude the
>Gary Corde
>RV-6 N211GC - NJ
Subject: | Re: Aligning horizontal stabilizer |
> perfect?
I suppose it must be perfect since there are no tolerances on anything in the
kit. But, perfect is hard to come by. As one approaches perfection in these
tolerances - in quality control - the costs rise exponentially. Practically, I
would guess that if you can measure the error with the tool you usually do the
measurement with, the error is too much. So, if you measure the distance
between rivets with a six inch steel rule where you can see a 32nd or even less,
that is the allowable +- amount. With a caliper you could measure error you
would not know about with the rule but that doesn't mean you need to use the
caliper on everything.
You would think that a 1% total tolerance ( +- 1/2%) would be adequate. That is
only +- 0.010 inches when measuring between rivets at 2 inch spacing which
seems to me quite adequate, even excessive. The 1/32 inches mentioned above is
3%. However, 1% means you could be off a whole inch in 100 inches, which is a
lot. If you measure the 100 inch dimension with a tape measure you could "see"
1/4 inch error pretty easily if you are careful to avoid sag and stretch.
Why doesn't some of us take a few minutes and establish some tolerances for our
little gems? This needn't cover everything but a start is a start. Something
like:
MEASUREMENT TOLERANCE inches
fuselage 3/32 rivets +- 1/8
fuselage floor rivets +- 1/4
most drilled holes + .005 -.000
3/8 main spar holes + .001 -.000
wing sweep +0 - 1/2 Note: no forward sweep allowed!
rivet heads per standard handbook
fiberglass fairings no standards
etc.
You would be amazed how many real factories don't have good tolerance
specifications so that they are really unable to control quality except by
frequent meetings, threatening workers, exceeding the real needs etc.
With software it is no problem as we do not have quality. :-)
Hal Kempthorne RV-6AQ -- Hangar H-4 at SCK - Fitting cowl, controls
halk(at)sybase.com Santa Clara, CA. Debonair N6134V @ SJC
From: | "Doyon, Richard" <Richard.Doyon(at)PSS.Boeing.com> |
Subject: | Don't shoot me: primer/paint question! |
Hi!
Just spoke with a paint manufacturer rep, and he had some disturbing news
concerning my priming plan for my RV... so I first hit the archive (ghee...
talk about a beating a dead horse: 1800+ returns!) but I didn't find the answer
to my question.
Due to my set up (I only have a small compressor (2 HP, 6 Gal, 3.4CFM @
50PSI, 115V/11A) big enough for riveting - I live in an apartment complex where
I have a one car garage only, so the electrical outlet is quite low in power),
I wanted to use spray cans of Zinc Chromate (Zinc Oxide nowadays) for the
interiors parts, and get the larger surface like the skins done at a friend's
place 'cause he has the right set up for two part epoxy primer.
The rep strongly urged me NOT to used it on the exterior parts since he
said that most of today's paint won't stick to it, but that for inside work,
Zc-Cr will be quite sufficient. He'd rather see me use the 2 parts epoxy primer
on the exterior. He also said that before applying the epoxy primer, an acid
etch will have to be done on the exterior, and that if by any means some of it
found its way inside (and I guess it will!) it will 'eat' up the Zinc Chromate
on the interior parts, thus defeating its purpose of being there in the first
place. What's your take on that? By the way, I won't prime the whole thing
obviously, but still, like on the wing tips, canopy frame, some rivet lines and
such, I'll need to apply some I guess.
The reason why I want to use the Zc-Cr on the inside, it's because it does
not require a spray gun since it's available in aerosol cans, and, it only
requires a light scuffing and cleaning (that's what the guy said, even if Zc-Cr
is not self etching, a light scuffing + good cleaner like solvent will do just
fine: it's not exposed to 200MPH airflow and rain and such), instead of the
acid etch/alodine/cleaning and then mixing the two parts + cleaning the tools
after. That's a biggie for me. I don't want too much to do with chemicals such
as acid and then alodine process (plus, there's the time to do all that + added
weight issues). I've got a pretty nice homemade paint booth that'll handle
nicely the fumes from a spray can. But, I don't have running water in my "shop",
and there's no way I'll do that inside my place nor will I transfer bucket
loads of water. But, I might have to do it nonetheless in light of what the
rep told me. If it's true that most paint won't hold to it, I!
might have to change my priming plans.
Has any one of you folks even ran into that problem? I know there's a lot
of builders that use the Zc-Cr spray cans if I'm to believe the archive, so
this must have happen to somebody before. BTW, I'll either use the Tempo or Randolph
cans.
Rich
'shop' almost completed, -6A tail will be ordered 'soon'
98208
***My comments/questions do not represent my employers in any ways***
>perfect?
>PABLO
>RV-8
>Argentina
Hi Pablo,
The jig itself does not have to be perfectly straight, as it only
holds the parts. You must ensure the parts are properly aligned by
other means (plumb bobs, etc) and adjust the fit in the jig with
shims, etc to get the parts aligned.
You want to get things aligned as well as possible for two reasons:
the remaining parts will fit poorly if you don't get things aligned
now, and the aircraft will fly better if it is built straight. Small
errors in the alignment of the HS will probably not produce
noticeable changes in the aircraft's handling qualities, but the drag
will be increased a bit.
So, do it as accurately as you reasonably can, and then don't worry
about it further, other than to check periodically that things are
still in alignment. Wooden jigs can warp with time, and parts could
move in the clamps.
Have fun riveting the HS together. It really feels good when you
finally have the first thing that looks like an aircraft part :-)
Kevin Horton RV-8 (fuel tanks & fuselage bulkheads)
khorton(at)cyberus.ca (613) 821-7862 (home)
Ottawa, Canada (613) 952-4319 (work)
http://www.cyberus.ca/~khorton/rv8.html
Subject: | Re: Don't shoot me: primer/paint question! |
You may want to check into using "Mar-Hyde" self etching primer. It's light
grey, comes in 19oz. spray cans & dries very fast. I just lightly scuff the
alum. surface with the grey scotch brite pads before spraying. Both the
Mar-hyde & grey scotch pads can be purchased at many automotive paint
suppliers. This product is good for steel, aluminum, & stainless steel.
L.Adamson RV6A fuselage
Reading many of the posts lately, it has become apparent that a great many
of you fly high. What type of oxygen setups are you using? How and where
do you mount the bottle? Do you use canulas or are there other options?
Are your systems permanently plumbed in with valves for pilot and passenger
or do you just run exposed air hose?
Vince
RV-8A
Saving for wings
Subject: | Re: Lycoming O-360-A1A (0 TT) for sale |
Hal,
From the comments you may start to find that you may be talking to a
crowd of airplane engine users only! And they may sound that way with good
reason. You see, auto engine conversions are only for the true
experimenter. They require a very high level of commitment of time, energy,
talent, testing and refining,safety consideration, often much more money
than ever could imagine!
As for me I always am looking for the right alternative engine and
thinking what can be done. I would be interested in hearing how you come
out, purchase price of the engine ect.
As you probably know, with the added weight of gear reduction drive,
coolant and radiator plus other accessories you'll be adding more weight.
Also, you can move the engine as for forward as possible even to modifying
the cowling. The goal is "The Lighter The Better"
Brad Bundy Flying Chard Built RV6 N48AC
You wrote
>The new mini-Corvette is supposed to have an all aluminum V-8 just as the
full >sized one does but it should weigh about 220 pounds and put out one hp
per >pound at 4400 rpm!
>So, I am selling my new Lycoming O-360-A1A and getting one of these.
>Since it is actually too light, I will have to add some weight up front.
Any
>suggestions as to how to do that appreciated.
Richard,
You can't believe everything you hear, not even from us! The epoxy
eating the zinc-chromate is new to me and doesn't make a lot of sense.
I live in a harsh enviroment (for aluminum, that is) and, after trying a
lot of stuff including 2-part epoxy, have been using the Sherwin
Williams 980 self etching 2-part zinc-chromate primer. you can top-coat
with most paints and it has good scratch resistance during building. It
also comes in spray cans!! Call a sherwin williams auto paint store.
The 980 primer has been discussed in the archives.
there's a lot of builders that use the Zc-Cr spray cans if I'm to
believe the archive, so this must have happen to somebody before. BTW,
I'll either use the Tempo or Randolph cans.
I use a small system from Mountain High. I use nasal cannulas with
adjustable continuous flow since my flying is below 18,000'. I have a
portable system since I use three different airplanes that fly high enough
to make O2 use necessary.
On my last trip in the RV-4 I just strapped it into the back seat since I
didn't have a passenger with me. I haven't decided how to mount it in the
case where I might have a passenger but I am leaning toward strapping it to
the back of the pilot's seat.
Brian Lloyd Lucent Technologies
brian(at)lloyd.com 3461 Robin Lane, Suite 1
http://www.livingston.com Cameron Park, CA 95682
+1.530.676.6513 - voice +1.530.676.3442 - fax O-
>Hal,
>Any
Hal,
You caught one.
John Ammeter
Seattle WA
USA
1975 Jensen Healey
RV-6 (sold 4/98)
EAA Technical Counselor
NRA Life Member
Dear Pablo,
Take the extra time that it takes to make your jig perfectly straight and
also perfectly plumb vertically. The airplane will fly if the stabilizer
is not straight etc, however it will fly much better if the stabilizer is
perfect, or as near perfect as possible. Also you will find later when you
are assembling the airplane that if these parts are crooked, twisted etc.
you will have difficulty assembling. I installed a plumb bob from a line
above the jig that allowed me to check the allignment of the stabilizer
through the various phases of construction. The plumb bob is suspended
from a taut line above and parallel to the center line of the stabilizer
when it is installed on the jig. This way the plumb bob can be slid back
and forth from one side to the other to check the alignment of the
stabilizer throughout construction.
Good luck. se veja bien.
Dick Martin
RV8 almost ready to fly
> From: Molinos Cabodi Hnos SA - JMFC <cabodijmfc(at)datasys.com.ar>
> To: RV-List Digest Server
> Subject: RV-List: Aligning horizontal stabilizer
> Date: Thursday, April 01, 1999 1:15 PM
preparing
there
this
> perfect?
> PABLO
> RV-8
> Argentina
Subject: | No direct RV Content |
This may not be a realistic idea but maybe, just maybe, it might make
a difference.
Sorry for 'spamming' the List with this request I felt it important to
pass on.
>Subject: Not a joke but something to think about.
> Let's hear it for a GAS OUT.
> I didn't write this, but am passing it on.....
> THE GREAT "GAS OUT"
> It's time we did something about the price
> of gasoline in America! We are all sick and
> tired of high prices when there are literally
> millions of gallons in storage.
> Know what I found out? If there was just
> ONE day when no one purchased any
> gasoline, prices would drop drastically.
> The so-called oil cartel has decided to
> slow production by some 2 million barrels
> per day to drive up the price. I have decided
> to see how many Americans we can get
> to NOT BUY ANY GASOLINE on one
> particular day!
> Let's have a GAS OUT! Do not buy any
> gasoline on APRIL 30, 1999!!!!!
> Buy on Thursday before, or Saturday after.
> Do not buy any gasoline on FRIDAY,
> APRIL 30, 1999.
> Wanna help? Send this message to
> everyone you know. Ask them to do the same.
> All we need is a few million to participate in
> order to make a difference.
> WE CAN MAKE A DIFFERENCE!
John Ammeter
Seattle WA
USA
1975 Jensen Healey
RV-6 (sold 4/98)
NRA Life Member
Subject: | My Website Has Moved! |
Listers: I have a new provider, so my website has moved..you can access it
at:
http://members.home.net/rv8er
Paul Besing
RV-6A (197AB) Arizona
Setting up new shop for Finish Kit!
Subject: | LSE Plasma CDI System |
Does anyone out there in cyber-land have any experience with Klaus
Savier's newest Plasma CDI system? I was just browsing their web-site
and was quite impressed with the specs and design of the system. As
someone who spends 9 hours a day working with the cutting edge
automotive systems on today's newest cars, I was glad to see such an
advanced system addressing this sadly-lacking area of aviation - the
ignition system.
Any thoughts or experiences? I'm quite a ways away from engine work on
my plane at this point, but I just really liked what I saw.
Jon Elford
RV6 #25201
Ailerons/Flaps....Preparing for fuselage
In a message dated 4/1/99 3:58:53 PM Pacific Standard Time,
vwelch(at)knownet.net writes:
<< What type of oxygen setups are you using? How and where
do you mount the bottle? Do you use cannulas or are there other options?
or do you just run exposed air hose? >>
We've got the 13 ft Aerox system hard mounted to the rear upright of the 6A
electric flap center pedestal. The regulator sticks up thru a hole in the
baggage cover and, when we need it, we just break out the exposed hose and
the cannel and plug them in. It takes about a minute to get the whole
enchilada setup and donned.
-GV
Subject: | Re: My Website Has Moved! |
> at:
> Paul Besing
Paul
Nicely done page. I really can't contribute a whole lot to
building technique anymore because the kit has changed so much
since I started my RV-6 in 1987. But to help give a little inspiration
to you guys not flying I have put a few pictures of my RV on a web page
with little history and some pictures of some of the other airplanes
I have had the pleasure of building and flying.
Web publishing is something I am slowly learning so please be kind
with any comments:)
http://www.teleport.com/~jsflyrv/
Jerry Springer|RV-6 first flight 1989|Hillsboro,Or|jsflyrv(at)teleport.com
From: | "Patrick E. Kelley" <patk(at)megsinet.com> |
If you've been reading the recent posts about helium and such, you'd realize
that most of them use no oxygen at all. :-)
PatK - RV-6A
Subject: | Compression tester |
A while back I got the urge to build a compression tester and went out to
Home Depot and purchsed lots of goodies. Later, having talked with a
friend, I found there may be something more to it than just valves, guages
and hoses. Maybe an orfice in the picture?
Could someone explain how to put a compression tester together?
Thanks, Tom Barnes -6 canopy
Subject: | RV-8; Observations |
I had said that I would post what I learned from Jerry VanGrunsven about
squeezing the ailerons to correct a wing heavy tendency. First, make sure
your fuel load is somewhat balanced on both sides, and any aileron trim
is centered. It would seem(to me) that you would need a person or weight
in the right seat, if flying an RV-6 or 6-A. Fly and take note of which
wing is heavy. On the ground, take a 12" ruler and lay it on top of the
LIGHT wings aileron, going from the skin seam on top of the aileron to
the trailing edge of the aileron. This should be straight. Jerry says
most people tend to UNDERBEND the last 3/4" or so, (past the ribs). If
the ruler shows even a 1/32nd gap at the trailing edge, this side should
be gently sqeezed either by fingers or with seaming pliers lined with
duct tape. Check BOTH sides first before you do anything so you can see
where you are at. IMPORTANT! Squeeze only very lightly! You will only be
able to tell if it has closed up any by using the ruler again. If you
oversqeeze, you run the risk of cracking the paint, or worse yet, the
skin itself by exceeding the acceptable bend radius. Once you get it
straight, go fly. If it is still a problem, and you have the light wing
aileron straight (top and bottom), then move to the other side (the heavy
wing). Chances are it may be OVERSQEEZED. Use the ruler again to find
out. If it is, you have a challenge. You will need to take a small 12"
long 2x2 or 2x4 and using a light weight hammer(yes, a hammer), gently
tap along the length of the trailing edge, checking constantly with the
ruler again. Do a little, go fly, do a little go fly. If you have a
problem after all this, you will probably need to resort to a permanent
trim tab on the bottom of the light wing aileron. The main thing is; DONT
OVERDO IT! A MICRO-AMOUNT OF BEND GOES A LOOOONG WAY! Hopefully this is
understandable for you, and will help some of you. If you know someone
who has done this before, by all means have them do it for you (like I
did). And for those of you building the ailerons, you can see that it is
better to slightly undersqeeze than to oversqeeze, although perfectly
straight is preferred!
Von Alexander
N41VA(at)juno.com
RV-8 Flying
Von Alexander
N41VA(at)juno.com
Subject: | RV-8;Observations |
Forgot to mention again that Jerry VanGrunsven is not connected with Vans
Aircraft and the advice on aileron sqeezing is only what I have learned
from Jerry and others. Use at your own risk.
Von Alexander
N41VA(at)juno.com
Subject: | Re: Compression tester |
It is all set up in AC 43-13-1b with diagrams
Cy Galley - Editor BC Contact!
Click here to visit our Club site at http://www.bellanca-championclub.com
-----Original Message-----
Date: Friday, April 02, 1999 9:45 AM
Subject: RV-List: Compression tester
Just been a "lurker" on the list, but something has come up that concerns
me, and I thought I would share. AOPA Pilot has an editorial on page 4 of
the April '99 issue concerning H.R. 111 about "user fees" for general
aviation.(translation - more taxes for the little guys) Suggest that you
read the article and contact your Senators and House members supporting this
effort if you feel moved. For help, try "Contacting the Congress" at
http://www.visi.com/juan/congress/
While on the soapbox, how would like for your private ticket to cost an
additional $150 every year or two? Read the thread on page 24 about the
"photo I.D." type pilot ticket. My old raggedy cardboard one issued in 1957
looks just fine to me.
Tailwinds
Carl (IO360 and RV8 plans owner)
Subject: | Re: the price of gas |
>Adjusted for inflation, gas is at an all time low.
Not in AZ - $ 1.55/gl for Prem
Subject: | Re: LSE Plasma CDI System |
Well, sort of. Lycoming rep told me that *ANY* alteration of the ignition
system on a new engine would probably void the warrantly for many kinds of upper
end problems!
You can understand their position but it does help maintain the ancient farm
tractor system now in place. (Sorry, *EARLY* farm tractors)
hal
Subject: | Sky-tec vs B & C starters |
Has anyone directly compared Sky-tec vs B & C starters??? Jim Brown,
Matawan,NJ RV-3, O-320
From: | "Charles P. Kuss" <chaskuss(at)miami.gdi.net> |
Richard,
I submit that you can spray epoxy primer in your garage. I do. Make
sure you get a decent paint mask. On the recommendation of many listers,
I purchased one of the $69.95 HVLP spray guns from Harbor Freight. I
love it! It's easy to use, wastes less paint, & most importantly for
you, uses less air.
You definitely will remove a considerable amount of the Zinc Chromate
primer when you prep your exterior. Why do double work? (priming inside
& outside separately) It's easier to prime inside and out at one time.
More important, the epoxy primers supply the best corrosion protection
(and scratch protection as well) .
The AlumiPrep and Alodining takes minimal time if done with a little
forethought. Dipping tanks can range from plastic ice chests to a
child's wading pool. I'd be happy to email anyone interested, photos of
how I've accomplished Alodining various pieces of my empennage & wings.
I'd be happy to explain in detail if you wish to call.
Charlie Kuss
RV-8 fuel tanks
Boca Raton, Fl.
(561)338-9373
snipped
@ 50PSI, 115V/11A) big enough for riveting - I live in an apartment complex where
From: | "Scott Kuebler" <skuebler(at)CANNONdesign.com> |
Subject: | RV-6a Side Steps |
As I flip to the month of April on my AOPA Air Safety calender I sit and admire
the great photography. Looking over the nice silhouette of the twin engine my
eye immediately goes to the big ugly step hanging off of the side of the plane.
This reminds me of a question I thought up a while ago, but never got around
to asking:
Is there a way to make the optional side steps on the -6a removable? I was thinking
of a simple slip-in pipe fitting with a quarter turn to lock them in place.
When the step is removed for flight a plastic snap-in cap could be placed
over the hole.
I don't have drawings that show how they are mounted, so I don't know how the structure
is set up for them. I do know I will definitely have to put these steps
on my RV do to the size of my wife (4'-10"). Has anybody else thought of
this and tried or rejected the idea?
Thanks in advance,
Scott Kuebler
Buffalo, NY
RV-6a (wings)
Subject: | oops, RV-8 tanks sender |
Well, I knew I would forget something. I riveted my rear baffle on my
non inverted left tank yesterday and forgot to bend and set-up my SW
sender 1st. It would have been much easier to make sure I got the bends
right with the baffle removed.
How has the 3" x 3" 90deg bend as depicted in the plans worked out for
everyone else using the PP tank cover plate?
Also, come to think of it. What bend arrangement has everyone been
using on their inverted tanks? I believe I ordered a left and right SW
sender from vans? With the sender mounted in the center of the second
bay has anyone else used the "right" SW sender on their inv. tank?
Greg Puckett
Elizabeth, CO
RV-8 80081
Well, I beg to differ with you, at least in CA. In the past three weeks my
price for regular (87 octane) auto fuel has jumped from $0.98 to $1.60 and
I know the that wholesalers have bumped the price yet again since my
regular distributor has informed me that, with his last batch, the price to
me jumped to $1.80. My price for 80/87 avgas on the field is $1.83.
The reason that this is germane to aviation is that I put a 100 gal tank
and pump in my pickup truck so that I could fuel my aircraft that have
mogas STCs. Needless to say, at these prices it is going to take me one
heck of a long time to finally break even, if ever.
>guages and hoses. Maybe an orfice in the picture?
Try page 460 of Airframe & powerplant Machanics powerplant handbook.
need a .040 inch hole below I think 1000 in cube & .060 for over.
Don Jordan ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com
From: | Richard Reynolds <RVReynolds(at)macs.net> |
Subject: | Re: RV-6a Side Steps |
Scott Kuebler wrote:
"to make the optional side steps on the -6a removable?"
Buy a little plastic step from K-Mart. Its cheaper. The pax can not get
in or out until you place the step and help them. No bent flaps.
I just finished install my steps in the RV-6A fuselage, lots of fitting
and $160 for two steps. PS, use Van's plans as a guide. The weldment was
a little off and the location of the hole in the side skin was way off
(1.0 inches) in the vertical direction.
Richard Reynolds, Norfolk, VA, RV-6A, ALMOST finished skinning the
fuselage.
Subject: | Re: Sky-tec vs B & C starters |
Many, many, many times . . . you can check our website
for excerpts from the various discussions. The bottom line
is that B&C starters are the only all ball bearing and
all metal starters currently being offered as light-weights.
All of the lightweights perform well with some indiosyncrocies
so it's mostly a matter of deciding if the extra dollars are
worth it for the extra effort B&C spent on the design of
their product.
(o o)
===========o00o=(_)=o00o========
< Independence Kansas: the >
< Jurasic Park of aviation. >
< Your source for brand new >
< 40 year old airplanes. >
http://www.aeroelectric.com
upper
>end problems!
Ask the "rep" for this condition in writing on Lycoming documents.
There are a bunch of ol' salts out there who grew up with and embrace
antique technology on modern products. Whether it's Lycoming or
any other supplier of aviation proudcts, get their warranty
statements in writing. If upgrades of their products are discouraged
by threatening withdrawing warranty coverage, everyone in the
consumer-grade aviation industry needs to know who those vendors
are along with the basis (if any) for their actions.
(o o)
Subject: | Re: oops, RV-8 tanks sender |
Hello Greg,
I am doing my tank now. If you follow the instructions that come with the
sender from Van's, you will probably adjust it too high. It will bang the
top skin. At least that is what happened to me. The plans say that some
tweaking may be necessary after install so you can conclude the given
dimensions are not gospel.
If I had to install it blind, I would first bend it according to
instructions, then tie a marker and weight to the float, install with
clecoes, rotate tank, remove sender and look at the arc made on the inside
baffle skin. Bend again, erase previous mark and then repeat the process
until the arc is centered on the baffle. A tube type flouerescent light
and telescoping mirror will help you see the arc.
After I adjusted the sender, I had to adjust the bend so that the float
center line was parallel to the skin.
Another idea is to cut a crude piece of plexiglass using the cover plate as
a template. Then you could mount the sender and look inside (hopefully)
well enough to gage the correct position.
I am not far enough along to know for sure but I suspect the real accuracy
comes when you fill/calibrate the tanks prior to the first flight.
Don't feel too bad, I had a 'nice' time post installing the fuel line vent
clip! Fortunately I caught it before installing the baffle, but still,
what a pain!
Hope this helps!
Vince Himsl
RV8 Left wing tank (still)
>Greg Puckett
>Elizabeth, CO
>RV-8 80081
In a message dated 4/2/99 12:43:37 PM Pacific Standard Time,
skuebler(at)CANNONdesign.com writes:
<< Has anybody else thought of this and tried or rejected the idea? >>
Scott
IMHO, I think I have an idea that will save money, weight, and aggravation.
How about using a plastic bin like what is used in some communities to
recycle trash,
and also used to carry milk jugs? You could glue onto the edges some
styrofoam
pipe insulation, and install a lightweight lanyard. Both parties could enter
the aircraft from the same side. Last person in retrieves the step stool.
Once in the plane, any
items going into the baggage compartment could be placed in the stool. This
would weigh less than the metal side-steps, and involve less work. Also,
keep one question in mind. Unless you have a step design that allows you to
"retract" the step from the inside, I would think that it would be a pain to
"remove before flight" unless you had someone on your "ground crew" remove it
for you and hand it to you.
Your airplane would not suffer the "maybe one mile an hour" that Van's
claims. Has
anyone else used some other ideas instead of installing these "steps"?
Jim Nice
RV6A
WA State
I have seen your plane in many pictures, but still have yet to see it in
person. Maybe Oshkosh this year? Mine won't quite be ready, but I may go
for a weekend. It looks like you have a nice piece of work, and your posts
describe the work you have done. Thanks for all of your help, and your
inspiration...time to get back to setting up my shop...It has been two long
months since I have touched N197AB, so I can't wait to get going again. See
you at a fly-in, I am sure of it.
Paul
P.s...Don't worry about quality of webpages. The information is there, and
that is what counts. My page is really pretty simple, except for the
graphics, which I stole from other sites. Any RV builder will be more than
motivated by seeing your page..fyi, if you want an easy program to publish
your pages with, get Frontpage 98. Works great..
Date: Friday, April 02, 1999 8:34 AM
Subject: Re: RV-List: My Website Has Moved!
it
>> at:
>> Paul Besing
>Paul
>with any comments:)
The way I look at it , assuming the twin you were looking at had retracts,
the steps would look out of place & detract from the looks.. The 6A has
three sets of gear hanging out in the wind, that will never look as sleek as
a retractable. Therefor in my opinion, the steps are not that noticeable. I
installed both steps on my 6A last month.
L.Adamson RV6A - panel tomorrow
and how much price increases are due to exploding refineries?
hal
> Gary Corde
> RV-6 N211GC - NJ
Gary;
I had trouble wheel landing my -4 until an experienced pilot told me to land on
the rear of the wheels. He also said don't trim the elevator after the initial
power cut trim and as soon as the rear side of the mains touch down, release all
back pressure on the stick. It works for me now unless the speed it too high.
John Kitz
N721JK
Ohio
From: | George McNutt <gmcnutt(at)intergate.bc.ca> |
Hi Tom
EA-AC 43.13 - 1A & 2A page 273 has a good diagram. Engines up to 1,000
cubic inch displacement have a restrictor orifice .040 diameter, .250
inch long with a 60 degree approach angle.
I made one several years ago that works well.
George McNutt, Langley B.C.
6A skinning fusealage.
>bends
Even with the bend instructions followed perfectly, it usually takes some
minor adjustments to get it exactly right.
An easy way for you to do this now is measure the tank depth at the point
where the float will contact top and bottom.
Then measure where the sender centers vertically between these 2 points.
Now make a drawing on a cardboard box, table top, etc., that will allow
you to hold/clamp the sender in the proper location between your
"simulated" top and bottom skins.
Keep making small adjustments to the float arm until it swings through
the entire space and stops just as it reaches your simulated skin line at
each end of the travel.
It will now be very close to matching the tank exactly.
Scott McDaniels
These opinions and ideas are mine alone and do not necessarily
reflect the opinions and ideas of my employer.
Subject: | Re: RV-3 Wing Mods |
>I'll retract my earlier posting regarding using a file to move the
>1/8" holes in
>the lower spar cap before drilling to 3/16 rivits, to ensure proper
>edge
>clearance. Not needed, as the upper (inner) part of the lower spar cap
>is in
>compressing during positive G loads.
>I don't believe that CN-2 promises full -6 G's.
>Finn
Finn,
I believe you would be correct in assuming that, since the RV-3 with all
of the recommended mods is not approved for - 6 G's.
The airplane is approved for +6 / -3 G's.
For the wing structure to be capable of + and - 6 G's, the mod. that is
done on the top spar stiffeners (for compression loads) would also have
to be done on the bottom ( for the compression loads during - G loading).
As for the seeming counter diction in terms of cautioning against
enlarging holes because of strength loss but then instructing
builders/modifiers to enlarge holes... I can understand the confusion.
What I believe Van was meaning to say is that a builder should not be
"indiscriminately" enlarging holes for a bigger fastener because of the
strength loss that it could cause.
The holes that are being enlarged when doing the wing mods are holes that
were enlarged on test wings that were used to qualify the modification
itself. I.E., If you modify your wings as instructed, and they were
built per the plans previous to that (no messed up/enlarged holes, etc.)
then you have a set of wings that should be the equivalent to what was
load tested in the shop at Van's and held the load at 9 G's as required
by FAR 23.
In the course of developing the modifications we probably built 1/2 dozen
RV-3 wings in the shop and then tested them. The final version is the
same as what a builder should have if no construction errors exist and
the recommended mods are correctly installed.
Scott McDaniels
In a message dated 4/2/99 4:29:58 PM Pacific Standard Time,
JNice51355(at)aol.com writes:
<< Has
anyone else used some other ideas instead of installing these "steps"? >>
I don't know Jim, has anyone used some other ideas instead of installing a
windscreen?
-GV
From: | "James E. Clark" <jclark(at)conterra.com> |
Subject: | Mike Seageer Schedule ??? Please help |
Anyone out there know if Mike Seager is in NC this weekend giving RV
training?
I am in SC and if he is there and there is an open slot, I'd like to get
it.
SO if he is there and you know where, please email letting me know.
James (803-603-8702 ... call collect if you have the info)
RV6A-QB ... canopy
Subject: | Not exclusively RV, but flying related ... sobering |
Per the Cirrus Homepage, there was a recent crash of the Cirrus SR20,
killing the test pilot.
Every crash and particular every death is tough to bear but this one caused
me to really stop and think ...
Within a short period, most of the "experimental, amateur built" planes that
I admired have had SERIOS crashes. To wit:
Thunder Mustang
RV-8
Lancair Columbia 300
Cirrus SR20
There **must** be some take-away for us all in this. These all appear to be
GREAT planes being flown by what seemingly everyone says was a GREAT pilot.
The plane I am building is of a great design but I suspect it will be of
average build. I am definitely not a GREAT pilot. Makes ya think ...
Let's all fly safe.
James
RV6AQ ... canopy
Subject: | Re:Check fuel tanks |
At a recent annual, it was discovered that the slosh and seal that the
builder had put in the fuel tanks on my RV4 was peeling off. Both tanks were
removed and disassembled and manually scrapped and all the s&s and proseal
was removed. A very expensive and difficult procedure. Please check in your
tanks as we found pieces of this stuff in the pick-up tube and could lead to
fuel starvation, a very serious situation. I have used car gas only a few
times and will now use 100 LL exclusively.
Subject: | Epoxy priming inside of fuel tanks |
Listers,
A fellow RV builder (not on the list) who is also an A&P has suggested
that I epoxy prime all my fuel tank parts, inside and out. He says that
the fuel tanks of nearly all the certified aircraft are epoxy primed
internally. Has anyone on the list done this with their tanks? Comments
please.
Charlie Kuss
RV-8 fuel tanks
Boca Raton, Fl.
Scott,
We have flown the same plane with and without the steps on it and
have noticed no performance difference. The installation pictures feature
our first RV-6A as we installed the first step outside of Van's planes. The
safety for passengers and pilot entering and exiting the plane as well as the
safety to your flaps is well worth any asthetic detraction in the airplane
lines. Please give us a call if you need more information.
George and Becki Orndorff
From: | "John W. Fasching" <fasching(at)amigo.net> |
George, I noticed your comment that you saw no performance difference with
or without the side steps on RV-6s. I have talked to other RV-6A owners who
say they lost about 5 MPH after putting on the steps. What's your secret?
Justin,
Do these steps for the RV6a go on both sides?or is it just for one side?
Justin Wallace,Don Mckelson
RV6a tail section(waiting for tools to arrive)
Justin & Don,
We have just bought the tools to get us threw the tail section of our RV6a!
These tools were bought from Avery and the total was $860.00 worth of tools.
It sould arrive Wes.
Justin & Don
RV6a(waiting for tools for tail section to arrive)
From: | "H. Martin Sutter" <hmsutter(at)flash.net> |
Subject: | Re: Epoxy priming inside of fuel tanks |
>Listers,
>that I epoxy prime all my fuel tank parts, inside and out>
No Way! Any coating you put inside the tank will be exposed to a plethora
of chemicals for years to come. So far "Pro Seal" is the only thing we know
that will hold up for sure. Several years ago the instructions suggested
that the tanks be sloshed with sloshing compound. Those of us who did so
are living to regret that since the slosh is gradually coming loose on the
older airplanes. Further more there is no way of knowing what the future
chemical content of aviation gasoline will be. Leave well enough alone and
stay with Van's instructions.
Martin Sutter N868CM 1,350hrs>
Subject: | Tank Reinforcing Ring - RV6 |
Does any one remember how they handled the reinforcing
ring in regards to the tooling hole on the tank root rib?
The plate nut rivet hole on the reinforcing ring and the
tooling hole misaligned. The tooling hole is too big to use
as a rivet hole (and not lined up) and not far enough away
to be able to put a separate universal rivet as a filler.
Let me know if I'm missing something simple...
Larry Olson
Cave Creek, AZ
RV6 - Tanks
Hi Folks,
Two comments on recent posts regarding steps on the RV-6A:
1) The Twin on the AOPA calendar is a Cessna 310. The step retracts and
extends with the gear.
2) If you choose to go with the plastic stool or milk carton option, I
would recommend adding some type of rubber or other non-skid material to
the bottom of the stool. I have had these things slide away when I stepped
on them from a hotel courtesy van. Some people have had bad falls for the
same reason. I step over them now, directly to the ground, even from a
tall vehicle, because I do not trust them not to slide out from under me.
I think this could easily happen on a concrete or asphalt ramp.
Of course, if you would just build a taildragger....Ow! Just kidding! ;)
Tim - Pittsburgh
Listers,
I am about to close my tanks and the sender floats are about 3/4 inch from
the top and bottom skins when the sender range of motion goes to either
extreme. I plan to bend the float to almost touching the top skin so as to
reflect "full" when the tank is nearest to full (dihedral makes this
measurement inaccurate), and when it registers "empty" on the guage it will
have a bit of fuel left. When I fill an empty tank later I will record
amounts of fuel that correspond to reference marks on the guage, expecially
the 1/2 mark.
Anyone armed with better information or ideas please shoot holes in this plan
before I can no longer make changes easily.
Dennis Clay #80473
I am posting this on behalf of a friend, John Jensen.
For Sale RV-6, Completed January 1996
Fully IFR and Certified
120 hrs TTSN.
180 HP Lycoming A1A and Hartzell Constant Speed Prop, new when installed.
Terra stack, VOR, ADF, GPS, Mode C and Audio.
ELT, Intercom, Engine Analyzer
Fully upholstered
Wingtip Strobes, Navigation and Landing Lights
Inmont Paint System
Annual Inspection Completed January 1999
Price $70,000 US
Location Burlington Ontario, (near Toronto).
Contact:
John Jensen
139 Secord Lane
Burlington, Ontario
L7L 2H6
905-632-7824
I happen to know this aircraft was built in large part by a very experienced
builder, who had previously completed eight homebuilts of various types.
Ron Taborek RV-4 Installing O-320 Toronto
Subject: | Re: Thanks for the info |
writes:
>Thanks Don, I have this book. I just quickly scanned the article and
>didn't see the size of the metering orifice. You've supplied a
>valuable
>missing link.
>Thanks, Tom Barnes
I am sorry Tom:
I found the articale in Ac 43.13-1a/3 para 692, page 273 or 337 I don't
understand the page numbering they do.
from
as to
will
expecially
>the 1/2 mark.
Hi Dennis,
I was happy with the range of my float movement, but I did have to pick
either full or empty to be the best end of the travel. I chose to make
the empty side more accurate. As you say, the full side will never be
quite right due to dihedral, but the empty side can be reasonably
accurate. Doing it your way will make both sides inaccurate.
Keep in mind, this opinion is different, not "better". Either way, I
would never really trust the fuel gauges. They're just a double-check
of the fuel level that I expect to have. Probably, the most important
thing is to understand and expect the inaccuracies of the method you
choose.
Now go install them and move on :-)
Russell Duffy
Navarre, FL
RV-8, sn-587, N174KT (beginning fuselage skins)
Subject: | Re: Tank Reinforcing Ring - RV6 |
>Larry Olson
>Cave Creek, AZ
>RV6 - Tanks
Patch on the inside. Use flush rivets to attach.
John Ammeter
Seattle WA
USA
1975 Jensen Healey
RV-6 (sold 4/98)
NRA Life Member
I just made a small plate and rivited it ove the hole.
Brian Trubee
I replaced both my senders with newer style senders after
the tanks were closed up. This was quite a while ago, but as
I recall I just stuck the senders in there and turned the tanks
over and progressively adjusted them so they wouldn't quite
"bonk" the top/bottom of the tank when turned over.
Somewhat tedious checking, taking them out, re-bending and
trying again, but it's one way to do it.
Randall Henderson, RV-6 (instruments/finish)
Portland, OR
http://www.edt.com/homewing
>Larry Olson
>Cave Creek, AZ
>RV6 - Tanks
I guess the simple answer is that, it doesn't matter if you don't fill
the tooling hole with a rivet. The access cover that will be screwed on
over the opening will cover the tooling hole. Not by a lot, but it does
cover it more than enough to seal it when the cover is screwed on.
Scott McDaniels
Subject: | Re: Not exclusively RV, but flying related ... sobering |
that
>Thunder Mustang
>RV-8
>Cirrus SR20
Jim,
More sobriety follows. Your list includes one certified airplane, the
Cirrus. I will add another interesting read about an Extra 300S that was,
fortunately, if not unbelieveably, not fatal!
http://www.ntsb.gov/aviation/CHI/99A120.htm
I have flown the Extra. it is impossible for me to imagine breaking that
airplane! The airplane is the pinnacle of quality design and construction.
(IMHO) If I read this report correctly it was not the plastic that broke
either! It looks to me like it was the water pipe that give way!!! We all
have faith in that, right???
As a point of interest, these airplanes have nitrogen pressure in the tubing
with a gauge in the cockpit that will indicate a loss of pressure should a
crack develop anywhere. One would hope the pilot noticed a drop in pressure
rather than a loud bang when the tubing broke. The latter might result in
soiling one's trousers!
At the risk of being redundant, the point of this is, the stick between your
legs is called the "wing removal lever." Handle it accordingly.
Tailwinds,
Doug Rozendaal
www.petroblend.com/dougr
PS After you have read the NTSB report, remember all those threads about
Aircraft G-stresses with the ailerons deflected? Anybody wanna bet a cool
frosty that there is a correlation? I know a pilot with this group, I will
try to learn more and report here.
In a message dated 4/3/99 12:49:08 AM Pacific Standard Time,
jclark(at)conterra.com writes:
<< Within a short period, most of the "experimental, amateur built" planes
that
I admired have had SERIOUS crashes. To wit:
Thunder Mustang>>
Definitely pilot error.
<< RV-8>>
Probable pilot/copilot error with possible limited design safety margin (my
opinion only, not fact-only time will tell).
<< Lancair Columbia 300>>
<< Cirrus SR20 >>
Cause TBD.
Also was the late Vern Dallman's fire in the Rocket (fuel system
dysfunction), John Denver's loss of control in the Long-Ez (pilot error with
construction issue), the Wheeler Express several years ago (pilot error with
possible tail design issues-unproven) and too many others.
We should remember the old adage that "flying is terribly unforgiving of any
carelessness, incapacity or neglect".
Let's be careful out there, but have fun,
-GV
From: | "Robert D. Binzer" <robinzer(at)seidata.com> |
Hi lister,
We are getting great information about the accidents and they are
sobering. The advise is all good, remember this:
Today I just learned about the death of a local aviation pioneer. When
I inquired about how it happened I found that it was a routine pulling
of a stump in the shallow steam on his farm. The tractor it seems did a
loop he wasn't prepared for. Caution and a cool head works everywhere!
Bob Binzer, 6a wings, Madison, IN
Just installed a Cessna (60amp) alternator today to my O-320 on my
RV6.However the lower cowl hits the cooling fan. I raised the alternator
as high as possible but only managed a 1/8" clearance, obviously the
wrong alternator for this aircraft. Interested to know what brands of
alternators others are using on their RV6's ?
Regards Peter (Toronto Canada)
What works best as a sandable filler for smoothing up roughness in aluminum?
hilljw(at)aol.com
rv8a
Greg: I just ordered the General Aircraft Hardware catalog...Sound like a
fantastic reference book...Cost $25 with a refund coupon good for 90 days
when used with a $75 order...From my past experience, $75 is easily spent on
acft hardware...Best Regards, Jim Brown-RV-3,Matawan,NJ
Peter,
I had the same probem with a 70 amp unit that came with my engine. A lot of
overkill on the alternator but with the O320 and wood prop, I needed the nose
weight. My alternator pully also had a fan attached which further decreased
the cowl clearance. I lengthened the mounting slot in the alternator
mounting arm and pulled the alternator up as close as possible to the engine.
I had to use a slightly shorter belt but it worked fine and never had a
problem with cowl clearance.
Rick McBride
RV6 N523JC
RV8 80027
I use the one from Dick Waters He is located in Fl. and his number is
1-800-366-4746 They seem to be OK and come with hardware etc.
Pat RV- 8 # 80536 Starting fuse.
Subject: | Re: aluminum filler |
I used micro-balloons and epoxy from my VariEze for damaged metal on the
cowl of my Bellanca. Works great.
Date: Saturday, April 03, 1999 7:57 PM
Subject: RV-List: aluminum filler
aluminum?
>hilljw(at)aol.com
>rv8a
In a message dated 4/3/99 9:40:49 AM Pacific Standard Time, RV6aJMW(at)aol.com
writes:
<< Do these steps for the RV-6A go on both sides?or is it just for one side?
I put them on both sides of my 6A and would do it again. My passengers and I
appreciate them. If you want to be selfish just put them on your side.
-GV
In a message dated 4/3/99 9:13:44 AM Pacific Standard Time,
fasching(at)amigo.net writes:
<< I noticed your comment that you saw no performance difference with
say they lost about 5 MPH after putting on the steps. >>
I think people imagine all kinds of things. The mind can be very creative
when it has no accurate facts with which to work.
-GV
> Larry Olson
> Cave Creek, AZ
> RV6 - Tanks
Larry,
My platenut rivet hole is about 1/16" from the tooling hole, but I think
that will be ok. The ring completely covers the tooling hole so I won't
need a rivet in the hole to seal it shut.
Jerry Calvert
Edmond Ok -6
DenClay(at)aol.com wrote:
> Listers,
> the 1/2 mark.
> Thanks,
> Dennis Clay #80473
Dennis,
I think I would rather have the float bottomed out and indicating a
reliable empty reading. More fuel related accidents have happened from
"empty" conditions than "full" conditions. Therefore; a reliable empty
reading would be safer than a reliable full reading IMHO.
Jerry Calvert
Edmond Ok -6
From: | Charlie and Tupper England <cengland(at)netdoor.com> |
Subject: | Prop failure/ warning |
I lost a piece of my Bernie Warnke prop this afternoon.
This prop may have been a unique model. It has bent tips made of what
appears to be carbon fiber or some kind of high density plastic.
I recently noticed the white paint on the front of the prop cracking in
a line from leading to trailing edge, about 5" from the tip. I foolishly
assumed that it was a paint problem.
While doing the required pass down the grass strip prior to landing, I
lost the wood & front half of the bent tip from paint crack out.
Fortunately, the pass was being made at medium speed due to gusty
conditions. Normal landing was made with no obvious damage to motor
mounts, cowling, etc.
The other tip has a paint crack in the same location, & the tip feels as
if it may be broken under the fiberglas wrap.
Bernie sold this prop to me as a 'new experimental design', so it may be
the only one in existence, but if you have a Warnke prop with bent tips,
check the tips carefully.
RV-4
I just ordered the book too.
CAUTION! ... They sent my sales confirmation with my credit card AND
expiration date.
-Paul Imhof, RV-8 on gear
From: A20driver(at)aol.com [mailto:A20driver(at)aol.com]
Sent: Saturday, April 03, 1999 5:40 PM
Subject: Re: RV-List: ACS catalog
Here's the Email I wrote to them...
Sent: Saturday, April 03, 1999 8:01 PM
Subject: RE: GAHCo Book Order
Dear Genuine Aircraft Hardware Co.,
Please STOP sending your sales confirmations via SMTP (unsecured) Email with
credit card information in them. This is a very BAD thing to do.
I was very happy to see a secured ordering site but I was VERY disappointed
when my credit card number WITH expiration date was plainly displayed in my
Email. I would hope you understand the severity of this. Your company has
exposed my credit card to the Internet and to who knows what.
I will no longer order ANYTHING from your company until you confirm that all
credit card information will never be sent over Email.
Sincerely,
Paul Imhof
Subject: | Re: Prop failure/ warning |
Thanks for posting this, Charlie! I'm sure glad to hear that, other than what
I'm
sure was a healthy dose of adrenaline, that all turned out well. I'm betting that
one of your old instructors was somewhere in the back of your head while it was
all
happening whispering to ya "fly the plane".
Your post was to the point, and let us all know that this is something to watch
out
for. 'Preciate it!
THIS is why I subscribe to this list -- and why I support Matt with $$$ to keep
this
resource available to me.
Don Gates
I have a PA28-140.
Look in my tank and you can see brite shinny aluminum.
You can even see printing in some places.
Bill Jaugilas
Charles P. Kuss wrote:
> Listers,
> please.
> Charlie Kuss
> RV-8 fuel tanks
> Boca Raton, Fl.
In a message dated 4/3/99 9:54:29 PM Pacific Daylight Time,
cengland(at)netdoor.com writes:
RV-4
Charlie, A friend here in So Cal had one of those (almost constant speed)
Warnke props fail in the exact same way. Any one running one of these props
should examine the front face verry carefully! Fred LaForge RV-4 Flying
From: | EARL FORTNER <e.fortner(at)worldnet.att.net> |
Subject: | Putting wings on RV-4 |
Guess I measured twice and cut once. Just put the wings on for the first
time and discovered much to my horrow the rear spar attach (W-407D) is
1/4 inch forward of where it should be. Van's suggest I remove the
seatbelt anchors and move F-406D in front of F-406 bulkhead with spacers
and then put the seatbelt anchors back in place. Sounds OK to me but
they want step by step plan on what I do before they approve it.
What do you think about cutting F-406D off flush with the fuselage and
instead of removing the seatbelt anchors cut another F-406D in half so
that it goes to the anchors but not all the way across the fuselage and
bolt this to the F-406C, F406D and the Bulkhead assy.
I would appreciate any input on this before sending my plan to Andy
Hanna at Van's.
your gonna proseal that ring to the rib right!! the ring , rib, and plate
nuts are prosealed to the rib which in my 2 tanks cover the lower tooling
hole. on the outer side of the tank rib you put the cork gasket and cover
plate with aviation gasket sealant, the other tooling holes gets a big rivit
squeeshed in them, hope this helps, happy easter
scott
winging it in tampa
waiting on mike seager tuesday
The ONLY time a gage has be accurate for the FAA is when it is empty.
Date: Saturday, April 03, 1999 11:39 PM
Subject: Re: RV-List: oops, RV-8 tanks sender
>> Listers,
from
to
will
expecially
>> the 1/2 mark.
plan
>> Thanks,
>> Dennis Clay #80473
>Dennis,
>Jerry Calvert
>Edmond Ok -6
Subject: | prop NEEDED (was prop faliure) |
In my haste, I forgot to ask:
Does anyone have for sale, a standard Warnke 72 - 72 prop, or something
similar?
RV-4, O320 160 hp 3/8" bolts
John,
There is no secret to putting the steps on. We put them on as
described in the instructions and did not lose any speed. They are not that
big to cause that much drag.
George Orndorff
From: | "Daniel H. Morris" <morristec(at)icdc.com> |
Subject: | RV 6 Engine Saga |
Sometimes you take your chances...
I'm sending this story to the list for it's safety value and nothing else.
The story-
I was performing the Condition Inspection which was being conducted at the
end of my Phase 1 (40 hr.) flight time. I always drain the oil through a
paint strainer to show up any big stuff, and cut open the oil filter. The
drained oil looked good, so on to the filter. Upon pulling the paper
element apart, I spotted a glint of bronze. Something like a light metallic
appearance. After washing a piece of the paper element off in a jar with
clean solvent, the solvent contained very tiny (almost microscopic) bronze
particles, giving the solvent a metallic appearance. Not a good sign! At
the previous oil change just 20 hrs before there was no sign of this.
Something must be drastically changing.
Fortunately, the bronze things in the engine are easily identified, but the
ones that are there are pretty important (valve guides, con. rod bushings,
rocker bushings, and acessory drive gear bushings). The easiest thing to
check is the valve guides and rocker bushings, so off came the valve covers.
On removing one cover several loose parts were discovered. Seems that an
inner spring on an intake valve had broken. The remaining parts proceeded
to chew up the guide.
Well, I thought that while this wasn't great, but that it could be much
worse. Little did I know that this was only the beginning.
A little background. While searching for an engine for the project, I came
upon a highly recommended person who built up engines. He had an 0-320
available which he would build up to my specs. The price was good, but not
so good to make me concerned. I specified very carefully what parts were to
be replaced, what inspection criteria was to be used etc. Upon receipt of
the engine it came with a log entry matching my specifications. One of the
things that I specified was new valve springs, and standard dimension
cylinders (so that they may go a round of overhaul before being replaced).
This is a parallel valve engine. On removal of the cylinder the following
was found. The valve springs that were installed were for an angle valve
cylinder, probably contributing to the spring failure. The cylinder
dimension check showed that the cylinder bore was beyond service limits for
.010 over size cylinders (beyond limits for a nitrided cylinder). The
pistons and rings were for a standard cylinder. This left ring end gaps 3
times the allowable.
Needless to say the scope of the problem got much worse at this point. The
remainder of the cylinders were removed. All 4 cylinders had incorrect
springs, and were similarly oversized with standard pistons and rings
installed. Furthermore, several cylinder head rocker bushings were cracked
and or loose in the head, and one cylinder head was found very cracked at a
vlave seat.
There were some serious safety issues here. The valve guide was probable
only a couple of hours from total failure which would have resulted in
swallowing a valve. Any one of the conditions found could have led to
sudden stoppage of the engine, which of course will always occur at the
least convienent time. References or not, the overhauler had obviously done
shoddy work, and then was willing to sign for it. Of course there was
concern about the remainder of the engine. The accessory housing and sump
were removed. From there everything was examined and no other problems
found. In conversations with the overhauler, it appears that he got the
cylinders reconditioned by someone else, then simply took their word for it.
The facts above have all been verified by an experienced third party engine
overhauler.
The moral of the story: When you change oil check the oil and filter
carefully. Even the smallest anomoly should be considered. I feel lucky.
The airplane wasn't damaged, and no one was hurt.
Epilog- Apparently the overhauler thinks that all of this is no big deal. I
think that there are serious safety issues here. After long conversations
with the overhauler, I have no reason to beieve that this situation is
unique. If you have, or know of anyone having an engine that was overhauled
by Mr. Ed Low of Columbus, OH, ( and I know that there are RV's out there
with them) please consider that you may have a safety situation with your
engine that may be undetectable until catastrophic failure.
Dan Morris
A&P, IA
RV-6
hello everyone.
i'm in the middle of buying an rv-3a and i would appreciate any information
that anyone one has on the rv-3a such as what to look for when inspecting the
plane. the n number is n148cw it was built by charlie wilson up in spokan
washington in 1994. it has a lyoc.= 0-320-e2c and ted hendrickson wood prop.
i've only seen photo's of it so far looks very clean. will be buying it next
weekend if all works out. i'm from new york. there are a few rv out here on
long island but no 3's there is 2 6's flying one 8 being built and another 6
being built.
thank you
dan carley
e-mail = dfcpac(at)aol.com
>aluminum?
Bondo. You would be amazed at how many spam cans have bondo on them when
you strip them to repaint. But then again, maybe you wouldn't. ;
Brian Lloyd Livingston Enterprises, Inc.
(916) 676-6399 - voice (916) 676-3442 - fax O-
hello everyone.
being built.
thank you
dan carley
Bondo is HEAVY
Date: Sunday, April 04, 1999 11:26 AM
Subject: Re: RV-List: aluminum filler
>>aluminum?
I put the step on the right side of my 6A but not the left. Why? Because
as the pilot and owner of the aircraft, I am aware of the big step up
and down. A passenger may not be, or may not be as physically capable of
making it with ease.
The convincing factor was a few years ago at Oshkosh where I saw Van's
demo 6A (no step at the time) with lots of dents and damage to the flap.
Someone accidentally stepping on the flap could cause a lot of damage to
both the flap itself or the flap actuation hardware. Having this happen
1000 miles from home would not make for a good day of flying.
Regarding drag; my 6A with a step is faster than my hangarmates 4. So go
figure. There are a lot of places to pick up or lose speed on these
planes that are a lot more critical than the 1/10th of a mile per hour
that might be attributable to a Van's clean step.
Andy Gold
RV-6A N-5060
Builder's Bookstore
http://www.buildersbooks.com
> Charlie
> RV-4
Fred when you say one of those props do you mean a bent tip one like Charles
had or the standard thin blade Warnke? I have had one of the early
"almost constant speed props" on my 180hp RV-6 for about 7 years now and
have had no problems. I really like this prop and have had better service
with it than either Sensenich or Pacesetter.
Jerry Springer|RV-6 flying since 1989|Hillsboro, OR| jsflyrv(at)teleport.com
Subject: | Re: RV 6 Engine Saga |
<< A little background. While searching for an engine for the project, I came
be replaced, what inspection criteria was to be used etc. >>
Dan,
I had a similar experience with the engine I originally purchased
for my 4. I bought a hombuilt project (a cavalier 102.5) that included engine
0SMOH, instruments and several other goodies. The price was right and even
after the disaster I think I still came out ahead. My 4 was not ready to fly
but I had another freind that had his engine down for overhaul and we decided
to run the engine in on his plane and have him break it in for me while his
was down. After initial ground runs were complete everything looked ok and it
was time to fly. The engine lasted about a grand total of 2hrs before the
plugs started fowling and the carburator had oil running out of it. After
pulling the cylinders it was determined that the wrong rings were installed,
and the cylinders were out of tolerance. After this I decided I couldnt take
a chance on the rest of the engine so I disasembled sent everything out
purchased new bearings and reasembled my self. In the mean time I tried to
find the supposed A&P who overhauled this thing. Odly enough the number in
the book did not translate to any individual. I cant prove it but my theory
is that the guy I purchased the project from is the one who actually did the
overhaul ( he claims he and this A&P who doesent exist) and he penciled in an
arbotrary number in the book.
Like my Dad always used to say (and still does). Let the buyer beware, and
of course you get what you pay for!
I am currious though Dan why if your an A&P and an IA why you would pay
someone else to do it for you.
After my experience I have overhauled many engines for other people. But
only if it is done my way. And when it comes time for my next one I will be
looking for a core that is pulled off after a first time run and overhaul it
myself. I am one of the very few people I trust.
Ryan Bendure Co A&P
From: | "Tom Craig-Stearman" <tcraigst(at)ionet.net> |
Subject: | Re: Putting wings on RV-4 |
Earl,
At first blush I prefer Van's suggestion. I think you will want the aft
spar carry-through structure to be one piece straight through. The aft spar
carries wing drag loads which place the carry-through structure in
compression.
Do you have any thoughts on how the mismatch occurred? I would suspect the
F-406 bulkhead is off by 1/4", since the wing main ribs determine the
spacing between the main and aft spar.
For all of you still building your fuselages, I recommend that you measure
the distance between your main and aft spars while setting up the fuselage
on the fixture. Also measure the distance between the forward and aft
horizontal stabilizer spars. Then adjust your fuselage so that it will
match YOUR wings and tail. This will prevent similar nasty surprises. I
did this on my RV-4. As I recall, my wings were right on the plans
dimension, but my horizontal tail differed slightly.
Tom Craig-Stearman
RV-4 STILL sanding and filling the cowl
Date: Sunday, April 04, 1999 9:55 AM
Subject: RV-List: Putting wings on RV-4
>Hanna at Van's.
Subject: | Re: Another (long) Engine Saga |
>You hear these stories................. 'Course, getting a new engine is no
>guarantee; things can still happen. (My oil sure stays clean, though;
doesn't
>burn much either.)
>Michael
>RV-4 N232 Suzie Q
>Running smoothly........
Too true, Michael. My brand new O-360 from Van's had a bad exhaust valve.
I don't mean it was just a little out of round; the seat area was clearly
oval to the naked eye. Fortunately we found it while modifying the engine.
I might otherwise have had an exciting tale for the 'List.
Tom Craig-Stearman
RV-4 64ST sanding & filling & sanding & filling & sanding & filling . . .
Subject: | Re: Back riveting question |
I used the Avery spring loaded back riveting tool. The aileron skins lay
insides up on a large piece of flat polished steel plate. All the rivets are
pre-loaded & taped to the skins. Set the stiffeners over the rivets, press
down on the stiffener & rivet. This setup works well & leaves no marks on
the skins.
Does anyone know someone who likes to build wings? I need to repair/replace
both wings on my bird.
RV6 Russ,
Was there an accident?
Larry Olson
Cave Creek, Az
RV6 - Trying to get MY wings done
Date: Sunday, April 04, 1999 12:47 PM
Subject: RV-List: RV 6 Engine Saga
>The story-
Great inspection technique Dan, and good catch!
Events such as this is the reason I elected to install the ADC remote oil
filter on my O-320 RV-4. The fine screen (25 micron) element is easily
inspected and cleaned at each oil change. Additionally, it includes a
bypass indicator light to warn of contaminant build up and a magnetic chip
indicator light. As the manufacturer suggested the bypass light came on
after about 20 hours on a fresh complete overhaul. The element had trapped
a small amount of lint etc. as well
as a small amount of "normal" break-in shavings. Since then periodic
cleanings show very little contamination.
I also used a major overhaul facility (G&N) with an established record and
dyno test facility. I had a "friend" I thought qualified rebuild the carb
and then had to have the job done over again to get it done right.
150 Hours
RV4 N250DS
From: | "Anthony Dutton" <Anthony(at)dutton42.freeserve.co.uk> |
Over here in England we have to fit an audiable stall warner to the RV6.
Does anyone know of the availablility of a stall warner kit, other than the
Aircraft Spruce one which is expensive. Has anyone got any experience of
fitting a stall warner? Any comments gratefully received.
Tony Dutton.
Waiting for Wing Kit to arrive
Subject: | New Residential Airpark |
Michigan RV builders who want to live close to their planes might like to
know that a group of Northwest pilots is in the process of attempting to
purchase the Linden Mi airport (9G2) for conversion to a "residential
airpark community". If the local planning commission approves, they plan
to extend the runway to 4000', add taxiways, and offer one acre or larger
lots for homes with integral hangars. The FBO would continue to operate
and new hangar space added if and when demand warrants. They have
distributed a flyer to many Michigan pilots but apparently not everybody
got one.
If you are interested please send an email and I'll provide the name and
phone number of the person(s) to contact. To avoid cluttering the list
with repetitive and perhaps unwanted messages, please use the address
below. I'm not a member of the group but suggested this posting after
learning that one of them is building an RV-4. They indicated they are
getting a large number of calls and are keeping a list of people to
contact after the planning commission meets.
Jack Haviland
jgh(at)iavbbs.com
Where are you located.
I have friend who loves to build here in Hesperia, CA.
Tom Gummo
Date: Sunday, April 04, 1999 2:59 PM
Subject: RV-List: Rv6Awings
repair/replace
Brian,
just a little bit of tartan information.
I topped off my tanks today at 92 pence per litre over here in Aberdeen,
Scotland. That computes back to over $5 per US gallon !!
This accounts for a considerable chunk of the wet hire costs over here.
John Wheeler
10 hours on RV6a, G-RVEE and loving every moment of it.
I bought a Century 2 auto pilot. Can anyone help with the layout of the
pins?
I have the wiring & servo. Also have a black box which I think is the
interface to the tracking off the Nav radios.
Don Jordan ~ Arlington, Tx ~ RV6A fuselage ~
CY: In reference to the sender calibration, I recently replaced the senders in
the Rv-6 I owned. I used the new SW senders Van sells, I installed a New
Electronic International Fuel Indicator, which is very accurate as you calibrate
the indicator every two gallons, and the indicator has permanent memory, as you
calibrate it in steps. When it goes above about 15 gallons the last three
gallons made no difference. But the bottom end was very accurate. The beauty of
the system is that it is digital and analog. It send visual warning when it is
time to change tanks I.E. 1/4 out of balance, and on the low end at about 1/8
tank it sends a red warning. The situation that has been discussed here is
correct. It will be accurate at full or empty but not both because of dihedral
of the wing. I had a fuel injected engine and I wanted to know exactly how much
fuel that was left at the bottom end. This gage system is the best I have
seen. They make two kinds, resistive and capacative . I am building my second
RV-6 and I plan to use the same system, because it works the way a fuel system
should work. The cost of this indicator is about $350.00. I can appreciate the
system as I am a Professional Flight Engineer, and I have spent my whole life
looking at fuel indicators. No pun intended.
Harvey Sigmon - RV-6A QB- Waiting for Kit
> From: jerry calvert <calverjl(at)flash.net>
> >> Listers,
> from
> to
> will
> expecially
> >> the 1/2 mark.
> plan
> >> Thanks,
> >> Dennis Clay #80473
> >Dennis,
> >Jerry Calvert
> >Edmond Ok -6
> Matronics: http://www.matronics.com
> RV-List: http://www.matronics.com/rv-list
> Archive Search Engine: http://www.matronics.com/search
> Archive Browsing: http://www.matronics.com/archives
> Other Email Lists: http://www.matronics.com/other
Subject: | VS808 spar plate curved? |
Hello Listers
I'm wondering if anyone has experienced an unusual looking VS808 spar plate.
Mine has a gentle curve to it out of the box. It will flatten out on the
work table but "springs" back leaving about 3/4" off the table at the forked
end. Is this a concern? Could it cause some problems with the VS803 spar
alignment.
I did have some shipping damage..my rudder skin was crunched badly on the
top and I had bent flanges on R802PP and E602. The spars are in a different
container then the skin so it seems as if UPS had to work very hard to
mangle 2 well packed boxes. The box with the skins was punctured twice
through the "fragile handle with care" tape.
thx in advance for any wisdom offered
Rob Baxter RV8
finished emp. inventory
Help??
I am running the aluminum brake lines in the cockpit from the flex lines on
the firewall to the sides where they feed through. The drawings do not show
any dimensions where they feed through the sides. In fact it is VERY vague.
If I were to just eye ball it, I would say the feed through fitting is
shown between the forward wing attach and the vertical rib about 15 inches
back from the firewall. This is a tight area and the line will hit the 3/4
angle reinforcing piece on the inside that backs up the forward wing
attach. Also getting to the fitting with a wrench will be a bear. The sides
here are close to where your feet will be during flight so the lines must
be run as close to the inside wall as possible. Is it more common to put
the feed through behind the vertical rib and run the line thru it via a
grommet etc.???? Confused.... & @#$&
Larry, RV-6A finish kit stuff
Subject: | Re: Don't shoot me: primer/paint question! |
Date: Thursday, April 01, 1999 5:57 PM
Subject: Re: RV-List: Don't shoot me: primer/paint question!
>You may want to check into using "Mar-Hyde" self etching primer. It's light
>grey, comes in 19oz. spray cans & dries very fast. I just lightly scuff the
>alum. surface with the grey scotch brite pads before spraying. Both the
>Mar-hyde & grey scotch pads can be purchased at many automotive paint
>suppliers. This product is good for steel, aluminum, & stainless steel.
>L.Adamson RV6A fuselage
I would not use Marhyde on steel parts as it does not provide a vapor
barrier. I started using Marhyde on all my aluminum parts but 6 months into
my project Jim Cone, who lives 5 miles from me, had his RV-6A destroyed in a
wind storm. Jim was a big supporter on this rv-list of Marhyde and used it
on everything. After examining his damaged plane he found that all the
steel parts had corrosion on them under the Marhyde after only one year. On
his new RV-6A he is using 2 part epoxy primer for steel and aluminum after
being convinced that Marhyde is easy and tough but not a moisture barrier.
By the way Jim has not been on the RV-list since he got his new quickbuild
kit last fall. He is building at a furious pace and will fly this summer.
I wish I was an airline pilot and had all that time to build!
Phil Lehrke
RV-6A
St Louis
Marhyde is not to be used on steel. You must use a different primer on
steel. When I prime around the steel parts, I always tape them off before
spraying with Marhyde
Don Mack
RV-6A Fuselage
Ercoupe N2051H
donmack(at)flash.net
http://www.flash.net/~donmack
light
the
into
a
it
On
> Phil Lehrke
> RV-6A
> St Louis
Date: Saturday, April 03, 1999 12:52 PM
Subject: RV-List: Tank Reinforcing Ring - RV6
>Larry Olson
>Cave Creek, AZ
>RV6 - Tanks
Larry, I riveted on all but three of the nut plates on the reinforcement
ring first. The three I left off are located at noon, four and eight
o'clock position. These three are riveted "through" the ring and the rib.
Thus I have only 6 rivets holding the reinforcement ring on going through
the ears of three nut plates. My ring is prosealed on, and all rivet tails
covered with ProSeal. The access cover screws will hold the access cover
plate on, and the 6 "through" rivets only hold the ring on until the proseal
sets up. The screws should later hold everything together. This way you
can locate the "through" rivets so that there is no rivet hole anywhere near
the tooling hole. Fill the tooling hole with proseal when you put the ring
on. Don't know if others have done this or if it will leak as I am still
working on my first wing.
Marty RV6_ in Nashville.
Another option may be to topcoat the primer with something. At least that is
what I'm doing with my Sherwin Williams 980 spray can. Yea, spray twice, but
it is quick, drys fast.
Date: Sunday, April 04, 1999 8:41 PM
>From: RVHI(at)aol.com <RVHI(at)aol.com>
light
the
into
a
On
>Phil Lehrke
>RV-6A
>St Louis
Subject: | Re: VS808 spar plate curved? |
>Hello Listers
>alignment.
>Rob Baxter RV8
Hi Rob,
Your VS808 sounds it is curved exactly the same way mine was. I
suspect they are all that way. Some kind of artifact of the way they
are made.
It didn't take too much force to flatten it out, but it would spring
back. But, once you get everything all riveted together, that VS is
very stiff, and there is no way that the VS808 is going to give you
any problem in my humble opinion. Mind you, my VS is still hanging
on the wall, so this opinion is worth every cent you paid for it :=)
Take care,
Kevin Horton RV-8 (fuel tanks & fuselage bulkheads)
khorton(at)cyberus.ca (613) 821-7862 (home)
Ottawa, Canada (613) 952-4319 (work)
http://www.cyberus.ca/~khorton/rv8.html
avery sells a nice set that has a plastic skirt that is spring loaded, don't
leave home without it
scott
winging it in tampa
Subject: | Re: Century 2 help |
In a message dated 4/4/99 6:40:35 PM Pacific Daylight Time, donspawn(at)Juno.com
writes:
<< I bought a Century 2 auto pilot. Can anyone help with the layout of the
pins?
interface to the tracking off the Nav radios. >>
Contact Century at 800-433-5630 <http://www.centuryflight.com>. They
contacted me to get included in the next rev of the Yeller Pages. Tell them
you got the word here. The Yellers are getting famous as I get a new vendor
of something or other every few weeks contacting me.
-GV
Larry,
I ran mine a couple of weeks ago and placed the 90 deg. bulkhead fitting 5.125
in front of the forward face of the main wing spar and 1.25" above the
centerline of the 1.25" angle. This places the fitting up and forward enough to
clear the main gear mount and still leaves enough room for the aux. fuel pump.
The line then drops down and runs parallel to the 1.25 angle and is clamped
using two adel clamps attached to the angle. The other side is the same except
that it has to run up and over the battery box. As the line runs up and over the
battery box I again used adel clamps attached at the battery box base top AN3
bolts with a couple of AN960-10 washers to space the line out far enough to
clear the big angle pieces on the bottom of the firewall. Nylon clamps were used
to secure the line at the bottom of the battery box. I drilled and tapped the
big angle pieces for a number 8 screws to hold the nylon clamps.
Where the 90 deg. bulkhead fittings pass through the fuselage you will need a
.063" washer (made from scrap lightening holes) so that there is enough material
to tighten the nut. There is also a .165" gap between the .063" gusset plate and
the outside skin so the skin has to have a larger hole to allow the nut to sit
against the gusset plate. I found a 1 inch hole in the skin was just enough room
for the nut. To make the two sizes of holes, drill a pilot hole first. Then
using a hole saw, rota broach (sp.) or forstner bit, make the hole in the
outside skin. once this hole is made a unibit will drill a clean hole in the
gusset plate. As I recall, the inside hole is 7/16".
So there you have it. Hope this helps
Gary Zilik
RV-6A s/n 22993 - engine stuff, instrument stuff, flap stuff, and general all
around finishing stuff.
Larry Rush wrote:
> Help??
>plate
>tooling
>cover
Because the outer cover plate covers everything it is redundant work to
put proseal on the re-enforcing ring, but I guess their is nothing wrong
with doing so since we all look forward to the parts that "we get" to
install with proseal. :-)
Scott McDaniels
>senders in
>New
>calibrate
>memory, as you
>calibrate it in steps. The situation that has been discussed
>here is
>dihedral
>of the wing. This gage system is the best I
>have
>my second
>fuel system
>appreciate the
>whole life
Anyone willing to to pay the price for the Electronics International
fuel instrument can now have total fuel gage accuracy from zero fuel all
the way up to full tanks and have a visual reading of the fuel in the
tank (even the amount normally above the fuel level sender because of
dihedral).
This can be done by using the capacitive version of the gage and a
capacitive sensor kit available (soon) from Van's at a very reasonable
cost.
See more info in the latest RVator (Soon coming to mail boxes near you).
Scott McDaniels
As far as steel & Marhyde are concerned, the can states right on the side
--- adheres to steel / aluminum/ stainless steel. Use under all primer
surfaces. Furthur down in the directions, it states---- make sure that steel
is free from rust.
Personally I use Marhyde for quick spot priming of aluminum parts which are
all interior. The majority of my RV6A is primed with PPG two part epoxy. The
steel parts are coated with Rust-Oleum primer & paint.
L.Adamson ---- RV6A fusalage top side
Subject: | Oil Cooler fire wall mount |
Has any one mounted their oil cooler on the fire wall ? an if so what
should the stand off distance be, what size scat tube, should it be a
controled flow ,any info on this application shall be greatly appreciated.
RV8 getting very close
Gary,
Thanks very much for the detailed info on running the brake lines. I
appreciate it. Too bad the drawings do not at least suggest this possible
installation.
Larry, RV-6A finishing stuff in fuselage
...........................BK.....................................
>Larry,
5.125"
enough to
pump.
except
over the
were used
material
plate and
sit
enough room
>Gary Zilik
>plate.
>the
>forked
>spar
>alignment.
>the
>different
>Rob Baxter RV8
This is quite normal on parts that have been CNC machine punched out of
material as thick as the 0.125 VS-808. As long as their doesn't appear
to be localized damage (nicks, bends in a localized area, etc. the part
should be fine to use.
Scott McDaniels
>hello everyone.
>information
>inspecting the
>spokan
>prop.
>it next
>here on
>another 6
>being built.
>thank you
>dan carley
This question has been asked before, and there is a lot of stuff in the
archives about what to do (and what not to do).
The short version is that (particularly with an RV-3) no one should
purchase an RV without having an experienced (have completed a nice
example themself) builder look at it for them. With it being an RV-3 I
highly recommend that you have someone who is very familiar with RV-3's
do the inspection for you.
Scott McDaniels
Dan-
I'm no expert, and I know more about the pre-1984 RV-3's, but I could give
you some advice as to what to look for. You can call me at the below
numbers if you like, or I'm attaching an email sent to the list on 3/18/99
addressing someone asking some of the same questions. I know of one builder
I've talked to named Bill Saindon who is building a post-1984 RV-3 that is
just installing his engine and will most likely be flying by summer, and
would probably answer your questions or give you some advice as to what to
look for in the newer type-II RV-3's. Bill is at for more information.
Blue Skies!
Rob Reece
RV-3 SN45
Socorro, NM
505-835-3644
RE: Message on 3/18/99 to RV-List
Steve-
Make sure you know the Serial Number and/or at least the type of spar flange
strips it has and try to get a building "start" date (the completion date
should be on the data plate). This is crucial in knowing what mods are
required and also what to look for as far as "fixes" that have been
called-out over the years in the newsletters/RV-ator, etc (i.e., the fix to
the engine mount for cracks in the mount/gear tubes from wheel shimmy, the
change in the trim tab from the original design, etc.).
The mods that are required (mainly CN-1 & CN-2) are not complicated and
should not discourage you from purchasing a great aircraft. But, you REALLY
need to do what Scott McDaniels suggested and take someone along that at
least knows RV's, and preferably knows the -3's.
I have a friend who just recently traded a '56-58(?) C-172 for a RV-3 and a
pre-war Taylorcraft. When he got the -3 (which is what he really wanted out
of the deal), he knew it was rough around the edges (needed paint, needed FG
work, needed a new canopy, needed gearleg fairing, etc.), but it was what he
didn't know that kinda bit him.
When I looked at the plane, I found that the right inboard aileron attach
mounting has been bent from what looked like compression stress which would
indicate an overspeed or an overstress. This means that the wings need to
be opened and examined at the bellcrank and bellcrank rib, and the torque
tubes checked for bends, etc. Then, when I looked at the spar flanges (from
what I could see of them from the gap b/t the wing and fuselage), it
appeared that the builder had ground down the flanges to "fit" into the
fuselage. Yikes! Also, there were small stall gates on the leading edge of
the wings at the mid-wing point. They were only sticking out about a 1/2",
but closer examination (it really was an optical illusion!) showed that the
wing fuel tanks stuck out 1/4" past the outer skin/d-section, and the stall
gate was used to "hide" this screw up, perhaps after wet wings were
retro-fitted at one point or another?
In addition, the -3 had flown about 40 hours with it's previous owner (and
God knows how many hours prior to that?) without the bolt holding the
elevators together. . .there was still untouched primer in the hole! The
elevators were held on by the bearings, and moved/held together by only the
torque tube/bellcrank attach bolt!
Moral of the story: The -3 is an awesome airplane, that even Van himself
says flies better than any of the other RV's (here we go, commence flaming),
but since it was the first design it has more things to be conscious about
than say a -4 or -6. Take a knowledgeable RV'er with you, preferably a -3er
and look it over good, only AFTER doing your homework on what to look for.
If it looks good, a good going price for a -3 is probably anywhere from
about $9-25K, with a mean at about $12.5 - 16.5 for one with a O-320/160hp
that needs some TLC, IMHO.
Give me a call or send me an email off list if you have any specifics. I am
still doing my mods to my -3, and can give you names of about 5-10 or so
owners that have done the mods that you can talk to. I am also getting
together info on interested builder/flyers/owners of the -3 and have an
email group listing of all their emails/addresses/numbers that I am
preparing to circulate.
Blue skies!
Rob Reece
RV-3 SN45
Socorro, NM
505-835-3644
Subject: | RV-4 Main Gear Nut |
Hi gang,
Boy, have I had a time giving my -4 its Conditional Inspection! My RV-4 was
purchased from the builder with about 160 hrs. TTAF, and I have put on
about 40 hrs in the past three months. It is due for it's annual so I put
the electric screwdriver in reverse and dismantled it. My mechanic and I
have found a zillion things to repair and modify, besides the standard
replacement items.
This is my first experience working on an aircraft, and I am finding it
almost as rewarding as flying. I guess the trick is to have the right
tools, the right know how, and the determination to set and complete each
task to be done, one-by-one. The initial inspection was a shocker to me
when my mechanic showed me a very long list of problems. He is short on
free time after his daily 10 hr. day at the FBO, so he asked me to do most
of the repairs myself (with his help and approval as I progressed). I was
annoyed at this suggestion at first. I thought he would do all of the
repairs. But after a week of working 10 hr. days on the A/C, I am starting
to feel comfortable with this close tolerance work. Before we close her up
again, I will actually install electric flaps myself. I know all you
builders are laughing at me, but I really never thought I'd get into this
so deeply. Last night, after a rough, but rewarding 14 hr. day on the A/C,
I realized that I might be ready someday soon to build myself.
Boy have I gotten off of the original subject. How do you determine the
torque on the main gear axle nuts? Am I doing something wrong? I used a
homemade jack to lift the axle after removal of the nut, slid the wheel off
of the main axle and onto the shaft of the jack. Then I set the axle down
on a block.When the bearings and brake service was completed, I reversed
the steps. Now, I have a wheel on the axle and lowered to the ground. When
I screw the nut in, I am also squeezing in the wheel and its bearings with
the weight of the A/C on these surfaces. I am afraid to take a wrench to
this set up. Do I just use elbow grease until I run out of elbow? Help!!
Louis
Louis I. Willig, RV-4 - N8ZZ
larywil(at)home.com
(610) 668-4964
Philadelphia, PA
Subject: | Re: Private airstrip beaurocratic boondoggle |
SportAV8R(at)aol.com wrote:
>(snip long post) has a runway that straddles two counties
Wow, what an interesting question. I would think you are not breaking
the law unless you actually land or takeoff on the dirt of the offended
county. I think the non-approving county can regulate the dirt but not
the airspace.
I'd tell them to get screwed and be careful for the first year or two
not to be seen rolling on the bad end of the runway. After that, I
don't think anybody would care.
--Kent "not a lawyer but play one on TV" Ashton
From: | "Charles P. Kuss" <chaskuss(at)miami.gdi.net> |
Subject: | Re: Don't shoot me: primer/paint |
question!
Dialupnet wrote:
Moe,
Chromate based primers are intended for use on aluminium. They are NOT
recommended for ferrous (iron/steel) metals. Zinc Phosphate is for use
on ferrous metals.
Zinc Chromate = aluminium
Zinc Phosphate = steel/iron
Read the information on the can.
Charlie Kuss
RV8 fuel tanks
Boca Raton, Fl.
> Rustoleum works well on steel parts, and will protect them very well. I
> don't know wbout topcoating it with anything though. If you plan on
> topcoating it with something, like exterior steel parts, then use Zinc
> Chromate.
> Moe Colontonio
> moejoe(at)dialupnet.com
> Check out my RV-8 Page at:
> http://tabshred.com/moe
> >light
> >the
Subject: | Re: Oil Cooler fire wall mount |
Mike:
This subject has been discussed in great detail in the past. There are many
different variables to consider. For the most part, the concensous (sp?) is
don't do it. I wanted to, and had overwhealming response from others saying
not to. Check out Mark LaBoyteaux's site. His has his orginal
installation, and then the second. I believe Mark Fredrick (Check Six!) did
the same thing. I guess it depends where you live. I live in the desert,
so I have decided to put in on the baffle. Also, see Sam Buchanan's site.
His has a nice installation. We will all be awaiting his test figures to
see what his temps are like.
The archives have alot of information on this subject. Good luck!
Paul Besing
RV-6A (197AB) Arizona
http://members.home.net/rv8er
Finish Kit
-----Original Message-----
Date: Monday, April 05, 1999 3:12 AM
Subject: RV-List: Oil Cooler fire wall mount
>Mike
Subject: | Re: RV-4 Main Gear Nut |
Although it is a large nut, it does not get much torque. What you are
looking for is a slight Pre-load. The wheel should be jacked up free to
rotate. Snug it up until it just becomes harder to turn and then back it
off until you can line up the cotter key hole. The wheel should be easy to
turn at this point with no bearing looseness. Do not over tighten as you
will damage the bearings. It is an adjustment not a fastener type nut.
Cy Galley - Editor BC Contact!
Click here to visit our Club site at http://www.bellanca-championclub.com
Date: Sunday, April 04, 1999 10:58 PM
Subject: RV-List: RV-4 Main Gear Nut
>Hi gang,
>replacement items.
>Louis
>larywil(at)home.com
>(610) 668-4964
>Philadelphia, PA
Avery sells a back rivet set Part No. 1048 for $16.75 that I have used with
great results.I Purchased my back riveting plate from a steel vendor and
finished it my self. The total cost for the plate was $2.75.
Good Luck
Rollie
RV6A Fuslage on the way
T
Mike; I mounted my Setrab oil cooler horizontally on the firewall about
6" above where the exhaust pipes exit. I made a simple shroud out of
aluminum that fits tightly over the top of the cooler in the shape of a
tent with two 2" scat tubes going into the 'tent', one from each rear
baffle. These scat tubes enter the 'tent' at a 45 degree angle. This unit
is close enough to the bottom of the cowling air exit that I should have
a 'suction' effect(due to the slipstream) that pulls the cooling air
through the oil cooler, increasing air flow. With 10 hours on my RV-8, I
am seeing 175 degree oil temps at OAT's of around 55-60 degrees. This
should be about right, and will allow a generous margin for hotter
outside temps and the resulting increase in oil temps. The redline is 245
degrees. I have no way to control the inflow of air, although if you
wanted LESS air, you could simply attach a round disk over one of the
scat inlets on the rear baffle. This aluminum disk could be pop riveted
on one side so that you could swing it over the hole to any amount of
blockage you want. By the way, I mounted the oil cooler to the firewall
with rubber grommets for further vibration protection and longer oil
cooler life.
Von Alexander
N41VA(at)juno.com
>appreciated.
>Mike
I would consider sticking with what you have and modifying the cowl. Several
in this area, including me have had to do this even with the smaller honda,
nippondensa, mitsubishi 35 amp alt, when installed on a 180 engine. You just
add a bubble to the bottom cowl. It is not noticable and is not a tough
project if you get it done before painting. I would shoot for a half inch
clearance as a minimum, since the darn thing will come down to meet teh cowl at
least a quarter inch in flight depending on g load, landing forces and
turbrlence. TIn fact some theorists feel the cowl also comes up a bit in high
speed flight due to positive pressure.
Good luck.
D WAlsh
Subject: | Ring Gear asmbly |
I have an 0360 A1D 180 HP. The AP is installing a hertzel CSP. Here is my
problem (I think) He said the ring gear (PN 71328) has the marks for dead
center and 25 deg 180 deg out and has been remarked. Also said he dosent
think the part nr for this starter ring is for this engine. Any great
wisdom on this subject out there would be appreciated.
RV6Afinish kit 3 steps forward 53 back.
planejoe(at)flnet.com
In a message dated 4/4/99 7:28:39 PM Pacific Daylight Time, donmack(at)flash.net
writes:
<< Marhyde is not to be used on steel. >>
Not only that, folks, but you may want to check the archives and obtain
information about "conversion coatings" for steel parts. Works just like
alodine to help arrest corrosion.
Subject: | Re: Ring Gear asmbly |
It might have been changed to get a different number of teeth on the starter
ring. As they aren't balanced with the engine at the factory, if it fits you
shouldn't have any problem other than timing. Many airplanes fly without it
at all. (non-electrical)
Date: Monday, April 05, 1999 6:32 PM
Subject: RV-List: Ring Gear asmbly
When I started on the RV-4 I was using marhyde spray cans for alum
parts, ribs,etc. I later switched to zinc cromate. Now six years later I
find the marhyde flaking off numberous paces but the zinc cromate is
still ok. I did scuff and clean before priming.
> is free from rust.
I'm located in Spanish Fork, Utah - near Provo.
Subject: | Re: Sky-tec vs B & C starters |
I have been running the Skytec for about a year and a half with no
problems and outstanding performance. It really cranks the engine over
much faster. I use a gelled battery and it is at least 10 feet from the
starter. I have been told that because the Skytec is a permanent magnet
starter I wouldn't be able to use a gelled battery, but it works good so
far. I chose the Skytec because the B&C interferes with the mixture
control arm on fuel injected engines with the forward mounted injectors.
Bruce Green
>Has anyone directly compared Sky-tec vs B & C starters??? Jim Brown,
>Matawan,NJ RV-3, O-320
My RV-6 VS spar plate was also "warped" upon receipt. I straightened it out
as best I could. I think I put it on a smooth flat surface with the warp
side up (top and bottom on bottom ends on the surface) and rolled with my
wife's rolling pin when she wasn't using it to beat sense into me.
Straightened right out. :-) Sort of an poor mans version of the English
Wheel.
Date: Sunday, April 04, 1999 9:06 PM
Subject: Re: RV-List: VS808 spar plate curved?
>>Hello Listers
plate.
forked
>>alignment.
different
>>Rob Baxter RV8
>Hi Rob,
>are made.
>Take care,
Many of the North Texas RV's are using a Ford 60 amp alternator. This unit
is basically the same size as the Cessna described above (the internals are
sightly different). To make it fit we are doing the following:
Remove the fan and run a 3/4" blast tube from the front baffle to the fornt
of the alternator or induce the air by drilling a 3/4' hole in the back of
the case and attaching a fitting ot take the 3/4"tube. This cooling method
is more efficient since it brings ambient air to the alternator rather than
already quite hot under the cowling air.
Use a pulley no larger than 3"diameter and get a drive belt that allows the
alternator to be all the way up against the engine case.
Glue a hard rubber block (use Pro Seal) to the inside of the cowling
positioned so that the alternator case hits the rubber block before the
pulley chews on the cowl. High speed can push tho cowl inward a bit and ary
G-loads cause the engine to sag momentarily resulting in contact between
cowl and pulley even when you have 1/2" clearance at rest. The rubber block
will keep that from happening.
Martin Sutter N868CM 1,350 hrs>
Subject: | Re: Stall Warners |
Anthony, give us a ring on 01773 715186 about the stall warner, I should be
able to sort you out.
Neil France.
Subject: | Re: the price of gas |
In a message dated 4/4/99 3:45:26 PM Pacific Daylight Time, RVGEM(at)aol.com
writes:
<< That computes back to over $5 per US gallon !! >>
Guess that just goes to prove that it is definately not that hard to justify
the cost of fuel if it is going into a lean, mean, flying machine. do not
archive
Subject: | Check Six Comes to Fla. |
Hello there Rocketmen!!
Mark Frederick and his Rocket is down here in Florida for this week
(Wednesday and Thursday only. Friday we are heading off to Lakeland to set up
for SNF.). If there are any of you out there that are teetering on buying a
Rocket but not just yet sure, please let us know this week and we will see
about arranging a ride for you - We have a few slots left. Call 561-748-2429.
Scott Brown
Mark Frederick
Team Rocket, Inc.
In a message dated 4/4/99 9:57:42 AM Pacific Daylight Time,
jsflyrv(at)teleport.com writes:
Jerry, I talked to my friend today, he broke not one , but two of
them . He described them having a thin scimitar blade. Warnke then shipped
him a more conventional prop which held up fine. Fred LaForge RV-4--180 CS
Subject: | Re: Compression tester |
Also look in Sport Aviation, page 106, July 1996. This has a very good
description of the Diff. comp. tester. It lists all parts as well.
Phil at Litchfield, IL Pitts S1S, N1GB RV6 underway
Date: Friday, April 02, 1999 3:33 PM
Subject: RV-List: Compression tester
> Later, having talked with a
>>friend, I found there may be something more to it than just valves,
>>guages and hoses. Maybe an orfice in the picture?
>>Could someone explain how to put a compression tester together?
>>Thanks, Tom Barnes -6 canopy
>Try page 460 of Airframe & powerplant Machanics powerplant handbook.
>need a .040 inch hole below I think 1000 in cube & .060 for over.
>Don Jordan ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com
I'm planning on beginning a homebuilt project within the next few months,
and have narrowed my choice of airplanes to the RV-6a and the GlaStar -
though leaning heavily towards the RV-6a. One concern I have about the
RV-6a is the useful load, as I plan to do a great deal of cross-country with
2 people and baggage.
According to factory specs from the Van's website, the useful load with full
fuel would be a bit under 440 lbs., which would be (just barely!) adequate.
Two questions I have concerning this issue are:
1) How realistic is it to expect the completed airplane to be close to the
published empty weight of 985 lbs.? (At this point I expect I would equip
the airplane for day/night VFR, with a Lyc. O-320 with a metal prop)
2) Is it difficult to load an RV-6a to the full gross weight of 1650 lbs.
without exceeding aft CG limits?
I realize that both of these questions are highly dependent upon actual
equipment/configuration, but I would consider any real-world experiences
concerning these issues to be invaluable input towards making a decision.
Thanks!
Chris Delker
Just to update everyone-
I met with _the man_ today; he seemed cordial but determined. If I was ever
going to use my airstrip without looking over my shoulder all the time, I was
going to have to register the last 600 feet of overrun in his court house,
his way.
He didn't want to make any exceptions because he didn't want "the next guy
planning an airstrip" in his jurisdiction to say they had let me off the
hook, so why not him. And he wanted to "protect" me from the possibility
that one day someone else might hassle me about the airstrip (I really had to
bite my tongue at this point!) so he wanted all the T's crossed and all the
I's dotted so no one would be able to give me any grief. It was apparent
that he thought he was from the government and he was there to help me, but
we had to do it his way. Actually, I suspect he was on an extended power
trip; maybe even a cross-country.
On the bright side, he indicated every likelihood that my application would
be favorably received. I'm sure my money will. I discovered today that the
grass seed I just bought for the runway was not $2.63 a pound as the farmers'
co-op had quoted last month, but instead just a buck a pound. The savings on
200# of bluegrass seed will equal the fees that "County B" wants to charge me
for their rubber stamp of approval... once again, God provides!
Thanks to everyone who responded. I got many off-list replies and lots of
encouragement. I think the outcome here is about as good as one can hope for
unless one hopes to fight city hall and win. Perhaps, when all my paperwork
is safely in hand, I can mount a legal reform campaign to make the country
safe for pilots, who as property owners face discrimination from local
governments because their favorite sort of motor vehicle is capable of
flight. I look at it this way: the Feds pre-emptively regulate all aspects
of flight, and while on the ground a plane is just a motor vehicle like a
tractor or a 4-wheeler. If farmers had to get county permission to operate
those, there would be open rebellion! We have the laws we permit them to
foist upon us, and we lose the rights and privileges we let them take.
Regards to all,
-Bill B
That government governs best which governs least.
unlikely to the point of impossible. I built an RV-6 with a 150 HP
engine and wood prop. Without paint, it weighed 975 pounds. The
panel was a panel similiar to what you describe.
Your metal prop will help keep your CG forward. That figure of 1650
is 'suggested' by the factory. I have seen RV-6's and RV-6A's with an
increased gross weight. Ask Van's for info on that or check with
local builders. Personally, I flew mine with up to 1750 pounds but
you have to limit the "G's" you pull and land 'carefully'. I seem to
recall that one of the factory ships had a gross weight of 1700
pounds; I asked if it was built any different, answer was no.
>Thanks!
>Chris Delker
John Ammeter
Seattle WA
USA
1975 Jensen Healey
RV-6 (sold 4/98)
EAA Technical Counselor
NRA Life Member
Timing of a ring gear is easily marked with a punch.
Sounds like the AP is being overly critical at your potential HIGH
expense, creating a problem. ("Well, we wouldn't want to put the
WRONG gear on, of course!") I'd be very wary of any expensive advice
he'd give.
Visit our web site at http://www.soundproofing.org for soundproofing info!
From: | Judy and Graham Murphy <jgmurphy(at)xtra.co.nz> |
Subject: | Bench For C Frame Tool |
Folks
The instructions from Cleaveland for their C-Frame tool specifies a
bench 36inches deep by 48 inches wide. I am proposing to use an
existing bench 34inches deep (but plent wide). Does anybody know whether
this slightly narrower bench will matter ?
Thanks in advance
Graham M
Getting workshop ready for -6A still enroute to NZ
Chris,
There is a GlassStar in the hanger directly across from my hanger. We
have an RV4, an RV6, and an RV6A in my hangar. I could write several pages
on which one I would pick to build but I will make it short and sweet.
Opt for the RV. You will never regret it. There is no comparison in
my opinion between the two. You speak of doing a lot of cross country
flying. Look at the speeds between the two planes in question. That should
give you a good idea of what you will be getting in each plane
One more thing. The RV will carry all you can load in it and still stay
within CG.
Bill B.
N426BB
325 hrs.
Houston, TX
Subject: | Re: RV6A Gross Weight and Balance |
In a message dated 4/5/99 8:45:53 PM Pacific Daylight Time, ccd(at)flash.net
writes:
<< 1) How realistic is it to expect the completed airplane to be close to the
published empty weight of 985 lb..? (At this point I expect I would equip
the airplane for day/night VFR, with a Lyc. O-320 with a metal prop)>>
Unlikely that you will come in this low. But hope springs eternal. This is
going to be one bare assed bird. You could call it Gypsy Rose.
without exceeding aft CG limits?>>
Not at all. I loaded my 6A (1160 lb empty O-360 , c/s, w/all the bells and
whistles) during the testing phase to my published gross weight of 1900 lb
(full fuel, me at 182 lb, my buddy at 230 lb and 100 lb of sand in the
baggage area) and was still 1.200" in front of the aft limit. It stalled
just fine at 60 mph no flaps, recovered normally and landed like it didn't
know the difference. Of course no acro and it only climbed at 1500 fpm.
In this configuration, as fuel burns to nothing the cg moves aft by 0.75".
Flying with empty tanks is unlikely since I would be illegally low on fuel
but still ahead of the aft limit.
You can download my POH with all the pertinent (and even some impertinent)
info from either Tim Lewis' or Mitch Faatz' website.
-GV
Should be ok. Mine is 32 inches by 8 feet. With the narrower table top you
will need to place the C-frame at an angle instead of perpendicular to the
table. No big deal.
Stephen Soule
Huntington, Vermont
-----Original Message-----The instructions from Cleaveland
use an
know whether
Subject: | Re: Check Six Comes to Fla. |
WHERE IN FLA?
SCOTT
I decided to start my Aero Sport O-360 for the first time last night.
I don't have the wings mounted on my 6 at this time so I rigged up a plastic
tube adapted to the fuselage fuel fittings. The plastic tube was stuck in a
one gallon gas can.
When I turned on the facet fuel pump to get fuel in the system, I was very
unimpressed with how well it was sucking. It took a long time to get any
fuel in the system. The pump only wanted to suck the fuel an inch or two up
the clear tube. The gas can was at the same level as the fuselage fittings.
While I had a fresh battery I was finally able to start the engine with the
help of the engine driven fuel pump. When my plastic tube shifted around
and came out of the fuel can I lost my prime and was unable to regain it.
At this point the facet wasn't able to suck the fuel uphill even an inch.
I never did get any fuel pressure indication.
The facet banged around like crazy and loaded down for those brief moments
there was fuel in it.
Surely this isn't right. I read in the archives that these pumps are super
reliable and this is the new one that was in my kit but I can't figure out
what might be wrong except a bad pump.
Larry Pardue
Carlsbad, NM
RV-6Q N441LP Inspection scheduled April 22.
Thanks for the info all, the AP has rearanged the thought process.
Do not archieve
RV6A/finish kit
Subject: | Re: Bench For C Frame Tool |
Do not have to angle if you can let the frame hang out the back of the
table.
Date: Tuesday, April 06, 1999 4:40 AM
Subject: RE: RV-List: Bench For C Frame Tool
you
>table. No big deal.
>Stephen Soule
>Huntington, Vermont
>use an
>know whether
Subject: | Re: Facet Fuel Pump |
I think that the Facet pump is not a sucker but a pusher. It needs to be
down low compared to the fuel level.
Date: Tuesday, April 06, 1999 8:59 AM
Subject: RV-List: Facet Fuel Pump
plastic
a
>one gallon gas can.
up
fittings.
>Larry Pardue
>Carlsbad, NM
Subject: | Sun N Fun -- get together?? |
Hi everyone,
I'm planning on attending Sun N Fun, flying
commercial out there for a week. *Really* looking
forward to it!
I was wondering if there is a dinner or get together
or whatever planned for the RV-List folks that may be
coming? If so, where / when? If not, want to try and
set up a time / place to meet at least and then see
where the four winds take us?
I'd prefer it to be early in the ween, Monday or
Tuesday, as I'm heading down to visit my brother
later in the week -- ya gotta fish!
Talk to ya...
Don Gates
PS -- I'm going to hit the SNF site and see if there
is a good spot to meet. Maybe Van's tent? Hmm....
plastic
in a
>one gallon gas can.
very
any
two up
fittings.
the
around
it.
inch.
moments
super
out
>Larry Pardue
>Carlsbad, NM
Larry,
For what it's worth, I posted a question about the same pump recently.
Those things make one HELLUVA racket! I haven't run any fuel through
mine yet, so who knows what will happen. Just the mere noise it made
when dry makes me wonder if it's getting ready to grenade itself or
something. I'll be interested to see the responses to your post.
Brian in Albuquerque.
RV-8 #379
engine and finish kit on the way.
Subject: | Jeff Ludwig's RV-8 pictures |
Greetings listers,
I just posted pictures of Jeff Ludwig's shiny new RV-8 on my web page.
Another -8 takes to the skies! Check out the pics at:
http://www.geocities.com/CapeCanaveral/Hangar/9656/jeff.html
Brian Denk
RV-8 #379
finish kit here. Engine almost here!
Subject: | Re: LSE Plasma CDI System |
Jon,
I installed the CDI in my -6 O-320 160 HP last fall. I used the flywheel/sensor
type of system.
The installation of the sensors was quite involved and I used a dividing head
with my milling machine to drill the holes in the flywheel.. The drilling and
tapping of the engine wasn't too bad. I think I would recommend the magneto
mounted Hall Effect installation. The .0025 degrees of backlash in the gears :
) probably won't effect the normal flier (not racing). Now for the goodies.
I can idle my engine down to 500 RPM with a wooden prop. No more fouled plugs.
I
can lean the engine past peak EGT with no roughness(carburated engine). About
1/2 - 1 gallon per hour less fuel burn, depending on conditions (I have fuel
flow).
All in all it just runs smoother. Will it pay for itself? Maybe, but probably
not. I feel that all of the above will be enough of a return.
Hope this helps.
Jon El
Todd tmrv6(at)erols.com RV-6 N92TM Flying in Southern MD
ford wrote:
> Does anyone out there in cyber-land have any experience with Klaus
> Savier's newest Plasma CDI system? I was just browsing their web-site
> and was quite impressed with the specs and design of the system. As
> someone who spends 9 hours a day working with the cutting edge
> automotive systems on today's newest cars, I was glad to see such an
> advanced system addressing this sadly-lacking area of aviation - the
> ignition system.
> Any thoughts or experiences? I'm quite a ways away from engine work on
> my plane at this point, but I just really liked what I saw.
> Jon Elford
> RV6 #25201
> Ailerons/Flaps....Preparing for fuselage
From: | rfiler(at)glenvan.glenayre.com (Rory Filer [4438]) |
Subject: | Lawsuit Against Vans Aircraft!? |
Hi
I've carefully scanned the last four days' messages and haven't seen
a reference to this (in the subject line). So I'm posting it. Here's
a short article - excerpted verbatim - from "Aviation Trader" news
April 1999, Volume 7, Number 4. This publication is freely available
at most airports and flying schools. I picked mine up at a local FBO
here in Vancouver.
------------------------- Beginning of Article -------------------------
LAW SUIT FILED AGAINST VAN'S AIRCRAFT
A multi-million dollar lawsuit has been filed against Van's Aircraft
and owner Richard VanGrunsven by the family of John Morgan, who was
killed in the crash of the RV-8 production prototype (N58RV) in Ripley
Calif. last May 24th. The suit, filed in federal district court, claims
negligence in the design and construction of the RV-8. It was filed by
Morgan's widow and two children. They are each asking $4 million in
damages. Morgan, 53, an experience pilot employed by Van's, was
demonstrating the RV-8 to prospective kit buyer Lawrence Hull. A
witness reported hearing the engine rev. then seeing the left wing separate
and the RV-8 crash nose-first into the ground.
----------------------- End of article ---------------------------------
This is obviously relevant to this newsgroup.
I was surprised to note that it was the family of the pilot, not the
passenger, who filed the suit. According to the article, they are claiming
that there was negligence in the design and construction. Perhaps this
will save the day for Van. All the testing they've done has proven the
design to be reliable. OTOH, we're talking about lawyers here.....
Rory Filer - Glenayre R&D (My opinions, not my employer's)
Vancouver, B.C.
From: | "Steven B. Janicki" <sjanicki(at)us.oracle.com> |
Chris, If cost is not a factor and you don't mind going a bit slower the
GlaStar is a good choice. The real difference in my mind is if you want to
use floats or not. I originally opted for a Glastar as vs. a second RV.
After taking advantage of the specials Stoddard-Hamilton had to offer the
Glastar still costs a bunch of money.
In the end I did not want to loose the aerobatics capability of the RV and
did not want to spend 2 X the cost of an RV so I opted to go with an RV-4.
Much less expensive to build and the user group is the best support group
bar none. I know other aircraft builders monitor this list for tips as well.
If your careful you can build an RV-6 light enough leaving enough baggage
capacity to meet your needs.
----- Original Message -----
Sent: Monday, April 05, 1999 10:21 PM
with
full
adequate.
> Thanks!
> Chris Delker
Subject: | Search Engine Registration adv |
I saw your listing on the internet. I work
for a company that submits websites to search
engines. We can submit your website to over
350 of the worlds best search engines and
directories for a one time charge of only
$39.95. If you would like to put your
website in the fast lane and receive more
traffic call me on our toll-free number
listed below.
All work is verified!
Sincerely,
Mike Davidson
(888) 892-7537
Hello
I found a 'Zynolyte' product at the hardware store called Zinc Coat Primer,
claims to simulate galvanizing on steel and iron and contains epoxy.
I tried it on a few steel parts after the proper acid wash (dupont 5717s), it
seems to
work well. What does anyone have to say about this?
As background, I acid wash and alodine all aluminum parts. I have tried
mar-hyde on
top along with tempo zinc oxide with mixed results. I may not be alodining
properly.
Mike Barrow
Reno,Nv
EAA1073 Truckee,Cal.
Jigging fuselage
Subject: | Re: Sun N Fun -- get together?? |
A lot of us will be at Van's Banquet on Tuesday night.
Date: Tuesday, April 06, 1999 10:51 AM
Subject: RV-List: Sun N Fun -- get together??
>Hi everyone,
>forward to it!
>Talk to ya...
>Don Gates
From: | "John W. Fasching" <fasching(at)amigo.net> |
Subject: | RV-6A "New" Nose Gear |
I decided to put on the new/improved/stronger RV-6A nose gear just to be on
the safe side. (40% stronger) Today Van's notified me my turn on the
waiting list had come up. Here's something I didn't know: You have to either
drill the mounting hole yourself, or send the old nose gear leg to Van's for
duplicate drilling. In itself this is not a big deal, only I sure hate to
put the airplane out of service for a couple of weeks! Van's folks say they
will give 3-day turnaround. It's just the darn shipping delays that are
pain. Just thought others would like to know.
FWIW
RV-6A
Salida, CO
Subject: | Re: Search Engine Registration adv |
NO SPAM PLEASE
-----Ursprngliche Nachricht-----
Von: Dscott33(at)yybecker22.ca
An: websiteuser22(at)yxybecker.22.ca
Datum: Dienstag, 6. April 1999 20:38
Betreff: RV-List: Search Engine
Registration adv
work
search
over
and
only
more
|listed below.
|Sincerely,
|Mike Davidson
|(888) 892-7537
| The RV-List is sponsored by
Matronics, makers of fine Aircraft
| Avionics, and by the generous
Contributions of List members.
| Matronics:
| RV-List:
| List Subscribe/Unsubscribe:
http://www.matronics.com/subscribe
| Archive Browsing:
| Other Email Lists:
In a message dated 4/6/99 9:06:09 AM Eastern Daylight Time, ABAYMAN(at)aol.com
writes:
WHERE IN FLA?
SCOTT >>
writes:
WHERE IN FLA?
SCOTT >>
Mark is in Jupiter Fla., By Palm Beach.
Scott
writes:
WHERE IN FLA?
SCOTT >>
Scott
writes:
WHERE IN FLA?
SCOTT >>
writes:
WHERE IN FLA?
SCOTT >>
Scott
writes:
WHERE IN FLA?
SCOTT >>
> up the clear tube. The gas can was at the same level as the fuselage
> fittings.
It's been several months since I did the same experiment. As I recall,
my Facet pump was able to pull fuel from a container on the ground up
to the pump, and on to the engine. It makes a TERRIBLE noise until it
has fuel in the pump, then it quiets down nicely. My facet pump, by
itself, produced acceptable fuel pressure indication without the engine
running, as I recall.
_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_+_
Tim Lewis
N47TD (reserved) RV-6AQ #60023, engine completed and tested
Springfield VA
http://home.earthlink.net/~timrv6a
timrv6a(at)iname.com
From: | Bob Paulovich <jonkarl(at)worldnet.att.net> |
Subject: | hs 610-614 6 degree bend |
having heck of a time getting an exact 6. with protractror both look
good but by standing back and looking they just don't look even. i did
notice one bend has just a slight twist look (in sunlight) at the point
of bend. am i being too picky?? i tried and tried to find the error
but... perhaps there is not one. suggestions?? bob in arkansas
Chris,
At the risk of offending non-RV folks monitoring the list I would highly
recommend the RV6 over a Glastar, especially if you're a first time builder.
Besides being twice as expensive as a RV6 or 6A, it is a much more difficult
kit to build. In my opinion, there are a lot of things on the Glastar kit
that are not very well thought out and some things that are just not very
desirable.
If both kits were the same cost, I'd still go with the RV. I believe it
represents a much better value and the RV kit will be a lot easier for a
first time builder.
BTW, I've been involved in the construction of both kits (and a Glasair
before those.)
Bob Skinner RV-6 460 hrs. Buffalo, WY bskinr(at)trib.com
>Chris Delker
Subject: | Re: RV-6A "New" Nose Gear |
Duplicating the hole sounds like a standard machine shop setup exercise.
You should ask Van if this is true.
Tom Barnes
Date: Tuesday, April 06, 1999 2:51 PM
Subject: RV-List: RV-6A "New" Nose Gear
either
for
they
>FWIW
>RV-6A
>Salida, CO
> > fittings.
The manual with the pump says it has a lift of 18 inches. That is, self priming
up to 18 inches.
Regards Peter
Chris,
desirable.
first time builder.
before those.)
>Chris Delker
>Chris,
>highly
>builder.
>difficult
>kit
>very
>desirable.
>believe it
>a
>first time builder.
>Glasair
>before those.)
Though I realize it is not a direct apples to apples comparison (an old
Glasair/Lancair story some of you may know about), I have seen a lot of
people trying to decide between an RV-6A and a Glastar decide on the
RV-6A during demo flights at Oshkosh when the following happens...
With the constant out and back flights being done by many of the kit
manufacturers it is not uncommon to end up at the runway directly behind
another companies demo plane.
With the reduced separation that is going on during the fly-in we get
cleared for take-off only 10 to 15 seconds behind the other airplane.
I can't count the # of times that on climb out I have been 300 to 400
feet above a Glastar as I pass them with probably a 20 to 25 mph speed
advantage.
Of course it is only coincidence that I usually have to pass on the left
so that the demo flight passenger has a good view of Glastar as we go by.
Scott McDaniels
These opinions and ideas are mine alone and do not necessarily
reflect the opinions and ideas of my employer.
Rob:
3/4" sounds like a lot. I received my in the last couple of months and have
just installed it this week. It had about 1/4" bend in it. Smoothed right
out when riveted .
Len
Subject: | Re: Laser levels |
> Whew, I'm glad I'm not the only one who's wife thinks this RV project
costs
> "A LOT"
One needs to plan ahead - when I met my wife, our second date was to an
airshow, the third was to go flying if I recall correctly.... that was
thirteen years ago.
Alex Peterson
SmithBL(at)micron.net, buettner(at)ionet.net, Cetnrn(at)aol.com,
dfoster(at)k-town.de, elisaerik(at)Juno.com, brhamm(at)ionet.net,
dand(at)firstdial.com, david.foster2(at)ramstein.af.mil, Millerg(at)ionet.net,
DLemonsMEC(at)aol.com, BCMproperties(at)enid.com, dglockner(at)cpanw.com,
starmaker(at)compuserve.com, ECParr(at)Juno.com, williamspsc(at)seanet.com,
Ettestad(at)Polar.Polarcomm.com, fwarner01(at)Juno.com,
bmadhok(at)alpha.albion.edu, Dag87(at)Juno.com,
gregory.miller(at)guam.andersen.af.mil, jagolinzer(at)randolph.af.mil,
JRESTEP(at)prodigy.net, powder01(at)Juno.com, ammeterj(at)seanet.com,
kjbklb(at)aol.com, tkugel(at)enid.com, LButikofer(at)hotmail.com,
mbwerner(at)Juno.com, Shell(at)aol.com, seaok71302(at)Juno.com,
roxanne30(at)Juno.com, Tedbob5(at)aol.com, Mustbe21(at)hotmail.com,
bppcprayerline(at)Juno.com, PMAC(at)enid.com, PennyBSO(at)aol.com,
eopckent(at)aol.com, parrr(at)vncgate1.vnc.aetc.af.mil, ghandi(at)erols.com
Subject: | Fwd: Church Kids Say the Darndest Things |
>From: TEDBOB5(at)aol.com
>Date: Fri, 2 Apr 1999 20:25:28 EST
>Subject: Fwd: Church Kids Say the Darndest Things
>To: JTDEVINEY(at)enid.com, Gail1125(at)aol.com, RRPARR(at)ionet.net,
> Landers(at)kimball.com, rowem(at)intellisys.net, MSAHOB(at)aol.com,
> PCLUNE(at)webtv.com, SN1724(at)aol.com, SSLEE(at)neto.com, Srjaxson(at)aol.com,
> SGROSSOEHMIG(at)mail.datasys.net, PEBERHART(at)aol.com
>Reply-To: TEDBOB5(at)aol.com
>Return-path: Prndeb(at)aol.com
>From: Prndeb(at)aol.com
>Full-name: Prndeb
>Message-ID:
>Date: Thu, 1 Apr 1999 00:04:14 EST
>To: tbrbnvi(at)pacbell.net, sprunger(at)netusa1.net, TEDBOB5(at)aol.com,
> clcoffey(at)wcic.cioe.com, alohaemma(at)worldnet.att.net,
> oompaloompas(at)sprintmail.com, judy-jim(at)juno.com
>MIME-Version: 1.0
>X-Mailer: AOL 4.0 for Windows sub 11
>Reply-To: Prndeb(at)aol.com
>Return-path: HLSClown(at)aol.com
>From: HLSClown(at)aol.com
>Full-name: HLSClown
>Message-ID:
>Date: Sun, 21 Mar 1999 12:23:34 EST
>To: shadeanna(at)juno.com, Prndeb(at)aol.com, DHillLeom(at)aol.com, gsdeon(at)monad.net,
> JMNCSNDL(at)aol.com, JJBAUTISTA(at)aol.com, DenaLogs(at)aol.com,
> ajbement(at)rebel.ticz.com, a.l.henry(at)juno.com
>MIME-Version: 1.0
>X-Mailer: AOL 4.0 for Windows 95 sub 13
>Reply-To: HLSClown(at)aol.com
>Return-path: LGilchrest(at)aol.com
>From: LGilchrest(at)aol.com
>Full-name: LGilchrest
>Message-ID:
>Date: Sun, 21 Mar 1999 09:28:25 EST
>Subject: Church Kids Say the Darndest Things
>To: kathryn.wolcott(at)millipore.com, mjertaylor(at)msn.com, silcon(at)psouth.net,
> SShel97667(at)aol.com, JMRuiter(at)aol.com, HLSClown(at)aol.com,
> GLN36(at)webtv.net, mumjay(at)capecod.net, sgjacobs(at)webtv.net,
> hel-moe(at)juno.com, DRMCHAFFIN(at)aol.com
>MIME-Version: 1.0
>X-Mailer: AOL 4.0 for Windows 95 sub 4
>Reply-To: LGilchrest(at)aol.com
> Church Kids Say The Darndest Things
>One Sunday in a Midwest city a young child was "acting up" during the
>morning worship hour. The parents did their best to maintain some sense of
>order in the pew but were losing the battle. Finally the father picked the
>little fellow up and walked sternly up the aisle on his way out. Just before
>reaching the safety of the foyer the little one called loudly to the
>congregation, "Pray for me! Pray for me!"
>A daddy was listening to his child say his prayer "Dear Harold". At this,
>dad interrupted and said, "Wait a minute, "How come you called God,
>"Harold"? The little boy looked up and said, "That's what they call Him in
>church. You know the prayer we say, "Our Father, who art in Heaven, Harold
>be Thy name."
>And this particular four-year-old prayed: "And forgive us our trash baskets
>as we forgive those who put trash in our baskets."
>During the minister's prayer one Sunday, there was a loud whistle from one
>of the back pews. Gary's mother was horrified. She pinched him into silence,
>and after church, asked: "Gary, whatever made you do such a thing?" Gary
>answered soberly: "I asked God to teach me to whistle... And He just then
>did!"
>One night Mike's parents overheard this prayer. "Now I lay me down to rest,
>and hope to pass tomorrow's test, if I should die before I wake, that's one
>less test I have to take."
>A five-year-old said grace at family dinner one night. "Dear God, thank you
>for these pancakes." When he concluded, his parents asked him why he thanked
>God for pancakes when they were having chicken. He smiled and said, "I
>thought I'd see if He was paying attention tonight."
>A little boy's prayer. "Dear God, please take care of my daddy and my mommy
>and my sister and my brother and my doggy and me. Oh, please take care of
>yourself, God. If anything happens to you, we're gonna be in a big mess."
>A rabbi said to a precocious six-year-old boy: "So your mother says your
>prayers for you each night? Very commendable. What does she say?" The little
>boy replied, "Thank God he's in bed!"
>A woman invited some people to dinner. At the table, she turned to her
>six-year-old daughter and said, "Would you like to say the blessing?" I
>wouldn't know what to say," the little girl replied. "Just say what you hear
>Mommy say, " the mother said. The little girl bowed her head and said, "Dear
>Lord, why on earth did I invite all these people to dinner?"
>Johnny had been misbehaving and was sent to his room. After a while he
>emerged and informed his mother that he had thought it over and then said a
>prayer. "Fine," said the pleased mother. "If you ask God to help you not
>misbehave, He will help you." "Oh, I didn't ask Him to help me not
>misbehave," said Johnny. "I asked Him to help you put up with me."
>A little boy was overheard praying: "Lord, if You can't make me a better
>boy, don't worry about it. I'm having a real good time like I am!
In a message dated 4/6/99 8:35:23 AM Pacific Daylight Time,
cgalley(at)accessus.net writes:
<< It needs to be
down low compared to the fuel level. >>
Question
If this is so, does that mean that RV's all have the Facet pump lower than
the wing tanks? If not, I would think that it would cause problems being
used as a boost pump.
very
>> fittings.
>Tim
I tried it again tonight. The pump works fine when it is primed and
produces about 4 psi but it will absolutely not self-prime which gives me
pause because I can think of several situations where the pump could lose
its prime, like inverted flight or running a tank dry. It will not even
pull fuel an inch up the tube with a small gas can sitting on the floor.
There seems to by a real split of opinion as to whether it should be able to
do this and to further confuse things my engine driven pump will not do it
either with the engine running at 1200 rpm. Van's has offered to replace
the pump but I hate to do that until I am sure mine is defective.
I am leaning toward just waiting till the wings are mounted again and seeing
how it works that way. It is hard for me to see the difference though as
the vertical lift to the top of the 1 gallon gas can is about the same as
the lift to the fuel selector.
Thanks for the opinions,
Larry Pardue
Carlsbad, NM
RV-6Q Inspection scheduled 4/22
Subject: | Fwd: Homeless Man |
>Date: Fri, 2 Apr 1999 21:08:45 EST
>Subject: Fwd: Homeless Man
>To: TEng33(at)aol.com, Morrow01(at)aol.com, Gail1125(at)aol.com, JTDEVINEY(at)enid.com,
> rizer(at)uswest.net, RRPARR(at)ionet.net, Landers(at)kimball.com,
> mikeycharlie(at)prodigy.net, rowem(at)intellisys.net, MSAHOB(at)aol.com,
> WFi8189635(at)aol.com, SN1724(at)aol.com, SSLEE(at)neto.com, Srjaxson(at)aol.com,
> SGROSSOEHMIG(at)mail.datasys.net, T.KUGEL(at)enid.com
>Return-path: Gail1125(at)aol.com
>From: Gail1125(at)aol.com
>Full-name: Gail1125
>Message-ID: <3109add5.2433f5f0(at)aol.com>
>Date: Wed, 31 Mar 1999 17:04:32 EST
>Subject: Homeless Man
>To: CrawCheryl(at)aol.com, Quiltnnut(at)aol.com, TEDBOB5(at)aol.com,
> fourkids(at)frontiernet.net, scooby_doo167(at)yahoo.com,
> sue_wilson_99(at)yahoo.com
>MIME-Version: 1.0
>Reply-To: Gail1125(at)aol.com
>>>>>Homeless Man
>>>>> It was a cold winter's day that Sunday. The parking lot to the church
>>>>>was filling up quickly. I noticed as I got out of my car fellow church
>>>>>members were whispering among themselves as they walked in the church.
>>As
>>>>>I got closer I saw a man leaned up against the wall outside the church.
>>>>>He was almost laying down as if he was asleep. He had on a long trench
>>>>>coat that was almost in shreds and a hat topped his head, pulled down so
>>>>>you could not see his face. He wore shoes that looked 30 years old, too
>>>>>small for his feet, with holes all over them, his toes stuck out. I
>>>>>assumed this man was homeless, and asleep, so I walked on by through the
>>>>>doors of the church. We all had fellowship for a few minutes, and
>>someone
>>>>>brought up the man laying outside. People snickered and gossiped but no
>>>>>one bothered to ask him to come in, including me. A few moments later
>>>>>church began. We all waited for the Preacher to take his place and to
>>>>>give us the Word, when the doors to the church opened. In came the
>>>>>homeless man walking down the aisle with his head down. People gasped
>>and
>>>>>whispered and made faces. He made his way down the aisle and up onto the
>>>>>pulpit where he took off his hat and coat. My heart sank. There stood
>>>>>our preacher ... he was the "homeless man." No one said a word. The
>>>>>preacher took his Bible and laid it on his stand. "Folks, I don't think
>I
>>>>>have to tell you what I am preaching about today."
Subject: | Ques Wiring ? KT76A with ACK encoder |
I'm wiring a ACK encoder to my KT76A. I bought both used, and got a used
harness with it too. But I do not know if the 2 were used together....... I
have the wiring diagram for the King KT76A.
If someone had a wiring diagram for the ACK encoder and could fax, scan,
jpeg, bitmap and email or??? to me, that would be great.
3) Questions/Problems:
a) Wiring in the King Manual, KT76A to King encoder doesn't seem to jive with
the 25 pin connector as it is currently wired. So I need to check it out I
guess......some encoders wire different?
b) There was a wire cut free and dangling from the harness....it goes to pin
# 13 in the 25 pin connector.....if It didn't go to transponder where did it
go?
c) Ditto, there was another wire cut free and dangling from the harness....it
goes to both pins # 10 and # 22, in the 25 pin connector.....if It didn't go
to transponder where did it go?
Now about my KLX135......VFR plane here, nights limited, and I'll have dash
brow lights bathing the entire instrument panel...do I need to worry about
the lighting circuit in the radio to switch it to back light mode?
David McManmon, RV6 Cicero NY
Subject: | Intrument Panel in 6A |
Finally started trimming the instrument panel for my 6A. Question:
The plans do not show the outside bottom edges of the panel that sit under
the longeron to be trimmed at all. I assume I have to trim it otherwise
there is no way to get it past the F604 and into position.
Suggestions? I don't see trimming as a big deal other than it won't look as
nice.
Don Mack
RV-6A Fuselage
Date: Tuesday, April 06, 1999 11:15 AM
Subject: Re: RV-List: Facet Fuel Pump
>RV-8 #379
>When you hear that noise on downwind after you have throttled back, you
will discover that the engine will not respond to the throttle a few seconds
later when you need a little bit of power to extend your glide. Then you
will remember when you last heard that sound and switch tanks. Hopefully the
prop will still be windmilling. You can guess how I know this to be a fact.
Ivan RV-4 550 hrs. Yes, My plane and I survived another hard lesson.
Subject: | Re: Intrument Panel in 6A |
<< Finally started trimming the instrument panel for my 6A. Question:
nice. >>
Don,
I cut mine off directly below the rails. It drops in nicely now, but doesn't
look as good as the ones where folks were able to fiddle the thing in place.
I'm planning to install my cabin vents in the hole I left, so that'll hide
most of the opening.
You may want to look at the pictures on the Matronics site to see some panel
examples...
Kyle Boatright
From: | Frank van der Hulst <frankvdh(at)ihug.co.nz> |
Subject: | Re: hs 610-614 6 degree bend |
Moe Colontonio wrote:
> Trust me when I tell you: If mine came out ok, yours will definately
> fit.
Me too!
BTW, in my Bunny's Guide <http://members.xoom.com/frankv/bunny1a.htm> I
show how simple trigonometry (is that an oxymoron?) can eliminate the
need for a protractor in this situation. And probably give you an
unneeded improvement in the accuracy of the bend.
Frank.
>costs
>> "A LOT"
>thirteen years ago.
>Alex Peterson
But what does she think a RV project costs?
>nice.
People do it lots of ways -- cut part of it off just enough to get it in
there and slide it back in place. Or cut all of it. I cut it them all the
way back and made pieces that would screw back in there (with nutplates on
the back) and that's where I put my headphone jacks. Bottom line is yes you
have to cut it to get it in there.
Randall Henderson, RV-6 (instruments/finish)
Portland, OR
http://www.edt.com/homewing
Subject: | Re: Ques Wiring ? KT76A with ACK encoder |
Hello, David and RVators,
I am using that combination of a King KT-76A ATC transponder and an
ACK model A-30 remote altitude encoder in my RV-6. My installation
manual that came with the encoder shows the following for wiring the
two pieces of equipment together:
ACK A-30 Function KT-76A Wire Color
5 B1 E Brown
4 A4 J Blue
3 A2 K White
2 A1 M Green
13 C2 L Violet
12 C4 H Gray
11 C1 D Pink
10 B4 B Orange
9 B2 C Yellow
6 Airframe GND Brown
15 Airframe GND Black
8 +DC Input (thru 2 A fuse) Red
1 8
o o o o o o o o View of connector on encoder
o o o o o o o (looking into pins )
9 15
Note:
You mention a 25 pin connector. The ACK model A-30 has a 15 pin
D-type connector, not 25 pin. Are you sure you have an ACK encoder?
You didn't mention the specific model number of the encoder. If your
encoder unit does in fact have a 25 pin connector, then this may not
apply to your case, but others may have a use for this data.
Good luck,
Marshall Dues
RV-6, N243MD
200 hrs
DWH arpt (Houston area)
> go?
whack
From: | "Stucklen, Frederic IFC" <stuckle(at)ifc.utc.com> |
> From: McManD(at)aol.com [SMTP:McManD(at)aol.com]
> Sent: Tuesday, April 06, 1999 11:10 PM
> Subject: RV-List: Ques Wiring ? KT76A with ACK encoder
******* SNIP ******
> dash
> Thanks
Dave,
I have LCD instruments in my panel on N925RV, both radios and gauges. To
see them in the sunlight, they needed to be backlite - i.e. their internal
lights on full during daylight hours. These lights were much too bright
after dark. So what I did was to switch their power source between +12VDC
for daytime flying, and the dimmer circuit output for night time flying. A
simple relay, powered by the NAV light circuit, works fine (NAV lights are
suppose to be ON after sunset, right?). IF for some reason, the NAV light
circuit blows a fuse, then the panel lights come on full bright..... IF the
dimmer circuit blows a fuse, OR the relay fails, well, that's why we carry
flashlights after dark...... KISS.... Keep it simple stupid! should
prevail.....
Fred Stucklen
N925RV RV-6A
E. Windsor, Ct
From: | "Cappucci, Louis" <Louis.Cappucci(at)gs.com> |
larry,
if van's offered to replace it, sounds like a "fuel pump no workee" to me.
you must have convinced them that it was defective, otherwise they would
have told you what you were doing wrong, how to install, etc. (i could be
wrong: this could just be "the customer is always right" attitude from
them.)
this is a low cost, easy-to-ship part. why not exchange it? seems that would
take a lot less effort than trying to troubleshoot a system without even
knowing for sure what it should be able to do or not do.
it is good that you are posting this to the list so we can learn from it,
but i say send it back, and then let us know how the new one works out for
you. if you get the same result, this could very important info, especially
for those contemplating intentionally running a tank dry (see archives).
good luck,
louis cappucci
mamaroneck, ny
rv-6a qb
> to
> seeing
> Larry Pardue
> Carlsbad, NM
Heck, I just drew it out on a piece of cardboard and bent until it matched.
Worked fine.
RV8 #423 working on wings.
Don,
I started with a panel blank that was 1 1/2" taller than the one suppplied. I
traced the supplied panel unto it. I used the area under the rails to locate
my airvents. I did MINIMAL trimming in this area on my panel. It is a tight
fit to get it in and takes some wiggling, but it looks nice.
-Glenn Gordon
> nice.
> Don Mack
> RV-6A Fuselage
> http://www.flash.net/~donmack
From: | Lothar Klingmuller <lothark(at)worldnet.att.net> |
Subject: | Re: ADC REMOTE OIL FILTER |
>Events such as this is the reason I elected to install the ADC remote oil
>filter on my O-320 RV-4. The fine screen (25 micron) element is easily
>inspected and cleaned at each oil change. Additionally, it includes a
>bypass indicator light to warn of contaminant build up and a magnetic chip
>indicator light. As the manufacturer suggested the bypass light came on
Dick, can you tell us more about this remote oil filter like cost,
suppliers, installation etc? Thanks Lothar
Lothar |||-6A; just finisched drilling gear mounts in Lakewood/ Denver, CO |||
From: | "Christopher Heitman" <cjh(at)execpc.com> |
I suspect that there was a piece of debris stuck on the foot valve. It
probably cleared itself after running the pump with fuel. I would suggest
draining the hoses and try running it dry again to see if the self priming
feature now works.
Chris Heitman
cjh(at)execpc.com
From: | "Randy J. Pflanzer" <rpflanze(at)iquest.net> |
A quick check of the archives did not turn up an answer to the following
question:
For those folks with flying RV-6 or 6A and using hinge pins to secure the
bottom of the cowling to the fuselage, do you secure these bottom pins
somehow? I bent mine with a loop in the end so I can grab them with my
finger to pull them out. But it looks like they should be secured so they
don't work their way out in flight. What have others done? Thanks.
Randy Pflanzer N417G RV-6
"Ready to Paint"
From: | "Scott Kuebler" <skuebler(at)CANNONdesign.com> |
Subject: | Final wing skeleton questions |
I am just about ready to disassemble my wings skeletons to prime and prepare for
skinning. Before I do this I have a couple questions that I can't find answers
to in the manual :
#1. Wing rib stiffener angles - In my personal RV-list archive I have saved a
posting that states not to forget to put a 45 degree taper on the ends of the
angles, specifically on the side that rests against the ribs. I guess this is
to achieve proper clearance for future rivets and platenuts on the main spar
flange. My question is, if it is the side that rests against the ribs wouldn't
the ribs cause the same clearance problems? Is this taper necessary? No mention
of in the manual or on the plans.
#2 - Aileron Bellcrank Gussets - On the newer kits these are more like ribs than
gussets. My question- when is the proper time to install these? Now during
the skeleton assembly, or later during the skinning. I can't find in the manual
where it give a sequence for installation of these two gussets.
Thanks in advance for the help.
Looking forward to finally putting some skins on.
Scott Kuebler
Buffalo, NY
RV-6a (wings)
Randy,
If memory serves me correctly the plans call for bending the bottom
cowl hinge pins in an "L" shape with one end of the "L" to be inserted
in the hinge and the other end of the "L" to be inserted into two holes
in the cowl plate on the bottom that holes the cowl to the nose wheel
brace (on the 6A at least). However, it can be a little bit of a hassle
getting those pins in due to their shape and size of the "L". It would
appear you could secure them any number of ways.
I saw one installation where the individual secured one section of a
hinge to the end of the hinge pin, drill a hole in the hinge section and
secured it with safety wire to a hole drilled in the lower lip of the
firewall.
Ed Anderson
> question:
> "Ready to Paint"
Listers,
FYI......... I found this site on the web. Thought I'd pass it on FWIW.
I have no connection nor do I know anything about the company.
http://www.pavionics.com/
Rodney
6A emp
Subject: | Re: RV6 vs Glastar |
Out of curiosity, did you pose the same question to the Glastar Builders
group?
From: | Rv8er(at)concentric.net[1-800-745-2747.The.Concentric.Network] |
Heck, I think I just held it up to the Mech. Drawing and bent a little at
a time until it mached. Angles are angles regardless of scale.
Greg Puckett
Elizabeth, CO
rv8er(at)concentric.net
(One tank finally completed with no leaks)
From: | "H. Martin Sutter" <hmsutter(at)flash.net> |
the
> > somehow?
Many of us who have several hundreds of hours on our RV6's have found that
the bottom hinges will fail and have replaced them with a .063" plate and 5
nutplates and screws per side.
Martin Sutter N868CM 1,350hrs
From: | "Tom Craig-Stearman" <tcraigst(at)ionet.net> |
Subject: | Re: Final wing skeleton questions |
Question #1:
I'm not familiar enough with the RV-6 to comment.
Question #2:
I think my RV-4 manual stated it is necessary to have the wing skin clecoed
to properly position the gussets. But that was a couple of years ago.
Tom Craig-Stearman
RV-4 finally feather-filled the cowl scoop for final sanding
prepare for skinning. Before I do this I have a couple questions that I
can't find answers to in the manual :
saved a posting that states not to forget to put a 45 degree taper on the
ends of the angles, specifically on the side that rests against the ribs. I
guess this is to achieve proper clearance for future rivets and platenuts on
the main spar flange. My question is, if it is the side that rests against
the ribs wouldn't the ribs cause the same clearance problems? Is this taper
necessary? No mention of in the manual or on the plans.
than gussets. My question- when is the proper time to install these? Now
during the skeleton assembly, or later during the skinning. I can't find in
the manual where it give a sequence for installation of these two gussets.
Scott,
If you are referring to the angles that get bolted and riveted to the spar
and riveted to the rib, I rounded the corners. Did not 45.
I did mine in the skeleton stage. Easier to rivet the gusset to the rib. Be
sure to simulate skin between ribs so you don't get a bulge or bow right
there. Also on the bottom, mine became an intrigal part of the inspection
plate reinforcement ring. (pre-predrilled, and in this case pre-joggled)
Good luck...
Larry Olson
Cave Creek, AZ
RV6 - Tanks
Martin,
I can see why. My lower hinges are already pre-loaded as they hold up the
cowling. I've harbored a concern that they may crack in time. I may just
replace them now with a plate. I'd rather do this before paint and in the
comfort of my garage rather than at the airport. I'm already using screws
to hold the two cowling halves together (new S-cowl). Thanks.
"Ready to Paint"
Date: Wednesday, April 07, 1999 10:28 AM
Subject: Re: RV-List: Cowl Pins
>the
>> > somehow?
________________
Hello,
I used a protractor and didn't use the sun and time to amplify minor
inaccuracies. If you only notice a problem by rotating the piece in the
sunlight and staring at it, then you are probably ok.
My main problem when I started was that I considered the dimensions on the
plans more important that the holes in the pre punched skins. With the pre
punched holes, the skins actually become the final authority as to rib/spar
alignment. It is a subtle distinction, but an important one as now, when
faced with your problem, I would wait to see how everything lines up with
the skins before becoming overly concerned about a minor bend error, real
or imagined.
A Builders Law: The seriousness of an error, real or imagined, is directly
proportional to the time spent staring at it!
Hope this helps!
Vince Himsl
RV8 Wings
Subject: | Engine Mounts for Aerobatics |
I've searched the archives and didn't find anything definitive.
What are the advantages/disadvantages to having a stiffer aerobatic engine
mount? What am I giving up besides smooth ride and extra $$. What am I
gaining with aerobatic mounts? I called VANS and they have only sold a
couple aerobatic mounts for the RV-8 and really recommend the standard
mounts. I plan on medium aerobatics (if there's an amount). I don't plan on
doing competition aerobatics. I will be installing an IO-360A1B6 engine... I
would be very interested in your comments.
Paul Imhof
RV-8, on gear, tail installed, engine on the way.
From: | Dan Wiesel <dan(at)interlinkrecruiting.com> |
Be careful on the trimming to make sure that you don get too excited trying
to get it into position only to find out that you shouldn't have cut off
that little piece you thought dint count.
suggestion: this is a tough fit, so why not cut out some cardboard and fit
that first. I have found that using a cardboard template/ tryout has been
very useful for a lot of parts before I cut into the aluminum.
But the truth is, you'll end up doing the panel twice anyway, I am, and I
know that some others were not happy after a while and also decided to cut
it again for a final fit.
Also, Vans plans calls for a lot of rivets on the panel to attach the back
angle. All you need is 3 holes for screws on top of the panel for the
attachment to the "ribs". (reason #2 for my second panel)At 10:29 PM 4/6/99
>nice.
>Don Mack
>RV-6A Fuselage
Dan
Dan Wiesel
Interlink Recruiting
408-551-6554
Martin:
I haven't yet looked at the cowl installation yet, but it is up soon. Could
you better describe what you did to replace this hinge? I'm sure a lot of
>the
>> > somehow?
Dan
Dan Wiesel
408-551-6554
> that I can't find answers to in the manual :
I'm ready to start skinning this puppy myself (-6) and here are my
thoughts:
> have saved a posting that states not to forget to put a 45 degree
> taper on the ends of the angles, specifically on the side that rests
> against the ribs. I guess this is to achieve proper clearance for
> future rivets and platenuts on the main spar flange. My question is,
> if it is the side that rests against the ribs wouldn't the ribs cause
> the same clearance problems? Is this taper necessary? No mention of
I have not seen the post to which you refer. They may have been
confusing the main spar angles with the rib attachment angles. 45 the
spar angles, but as you say, what's to be gained by putting a 45 on the
rib attach angles?
> like ribs than gussets. My question- when is the proper time to
> install these? Now during the skeleton assembly, or later during the
> skinning. I can't find in the manual where it give a sequence for
This thought rattled around in my head too.
I decided better to drill and cleco the skin (either side top/bottom)
and then locate and drill the gusset/ribs. This will let you get the
gusset/rib up against the skin, then you can drill the skin to it as
well. Pull that skin and drill/cleco the other side, mount gusset/rib.
My plan, anyway. YMMV.
Jeez, me too. How many times do I have to assemble and disassemble
these things (doing both wings, double jig) before I can set a rivet?
Good luck!
Mike Thompson
Austin, TX
-6 N140RV (Reserved)
Wings (still)
> Martin:
Could
The hinge was replaced by drilling out the rivets along the fire wall and
using the same holes to attach a .063" plate in the hinges place. The plate
was cut 1 3/4" wide and the same lenght as the hinge it replaced.
Five #8 countersunk screws with washers and nut plates per side are used to
hold the cowl to the plate. This set-up has held up well over the last
950hrs while the hinges failed after 400hrs (the ears broke off).
Subject: | Instrument Panel (was) Intrument Panel |
Dan Wiesel wrote:
"Also, Vans plans calls for a lot of rivets on the panel to attach the back
attachment to the "ribs"."
Dan,
I think the reason Van calls out "a lot or rivets" on the instrument panel is that
it is a structural member of the fuselage, and not just holding the panel
in place. It helps transfer a torsional load in the fuselage to the skin. By
only holding the panel with 3 screws you've eliminated that bulkhead from the
picture as far as being able to transfer these loads.
Try taking a paper towel cardboard tube and twisting it. Now try cutting a big
hole in the middle with sharp corners (like a cut out for the pilot/baggage compartment)
and see how resistant it is to the same torsional load. The aft baggage
bulkhead and the instrument panel are there to help take and spread out
that load.
I used screws to put my panel in, but I'm using the 2.5" spacing that's called
out in the plans.
Just my opinion....(everybody has one you know....just like a**holes ;-))
Laird
SoCal RV-6 #22923 firewall forward
Randy,
I put loops at the center ends and tie wrap them to an rubber exhaust
cross over shock mount that's in that area. Works well ..
As an after thought, I would never again use hinge pins on any part of
the cowl. They might be simple, but are more trouble than there're worth.
And when the hinges wear out or break, the replacement process ruins your
paint job. Next time it's CamLocks......
Fred Stucklen
N925RV RV-6A
E. Windsor, Ct
> From: Randy J. Pflanzer [SMTP:rpflanze(at)iquest.net]
> Sent: Wednesday, April 07, 1999 10:39 AM
> Subject: RV-List: Cowl Pins
> question:
> "Ready to Paint"
Did this recently. Trimmed mine to get past the post. leave enough to get a screw
in under the deck to firm up the panel.
Brian Eckstein
> nice.
> Don Mack
> RV-6A Fuselage
Martin,
Did you leave the original hinge material on the cowl? Or did you remove
it?
Fred Stucklen
N925RV RV-6A
E. Windsor, Ct
> From: H. Martin Sutter [SMTP:hmsutter(at)flash.net]
> Sent: Wednesday, April 07, 1999 2:20 PM
> plate
> to
I can't address the RV-6 but my RV-4 uses the same attach mechanism and I
can comment on what 12 years and almost 700 hours have done.
My hinge pins are not secured but they have never shown any signs of
wanting to move on their own. The hinge itself was directly riveted to the
fiberglas lower cowling. The loads near the top caused the top two rivets
to eventually pull through. I ended up putting an aluminum plate on the
outside of the cowl through which I drove new rivets. This spreads the
load over a larger area. I don't see any evidence of the new rivets
working at all so I am happy with the solution.
On the other hand, these plates are probably knocking at least 5 kts off my
speed. ;
Brian Lloyd Lucent Technologies
brian(at)lloyd.com 3461 Robin Lane, Suite 1
http://www.livingston.com Cameron Park, CA 95682
+1.530.676.6513 - voice +1.530.676.3442 - fax
From: Stucklen, Frederic IFC <stuckle(at)ifc.utc.com>
> Martin,
> it?
The remnants of the hinge have to be removed. Riveting on the plate is a
little tricky on a 6 tail dragger because the bottom cross tube of the
engine mount is very close. I used the squeezer and a no-hole yoke, that
worked fine.
Subject: | Re: Instrument Panel (was) Intrument Panel |
Laird:
Great info, thanks. Its got me thinking.
But, would it be possible to rivet the back angle we are talking about to
the skin(glareshield) with the 2.5"spacing, and then only use the three
screws for the panel attachment. Would that give us back our engineering
calcs? Am I missing something here?(i dont have the plans at the office)At
>Dan,
is that it is a structural member of the fuselage, and not just holding the
panel in place. It helps transfer a torsional load in the fuselage to the
skin. By only holding the panel with 3 screws you've eliminated that
bulkhead from the picture as far as being able to transfer these loads.
a big hole in the middle with sharp corners (like a cut out for the
pilot/baggage compartment) and see how resistant it is to the same
torsional load. The aft baggage bulkhead and the instrument panel are
there to help take and spread out that load.
called out in the plans.
>Laird
Dan
Dan Wiesel
408-551-6554
Date: Wednesday, April 07, 1999 3:58 PM
Subject: RV-List: Instrument Panel (was) Intrument Panel
>Dan,
called out in the plans : . INSERT: ???????? see
below
>>Laird
What plane/canopy are you referring to?
In my 6/6A drawings, I find
Dwg 35 R6 2 screws, one in each end tab
Dwg 32 R8 4 screws, two in each F603 flange. I count six screws
(structural -- 125,000 PSI) holding the instrument panel.
If I were doing it over, I'd use 0.090 sheet for the panel as instrument
shops advise -- the .062 doesn't have much strength left after you mount
lots of gyros and goodies.
Dennis Persyk 6A finishing kit
Hampshire, IL
>question:
>"Ready to Paint"
Randy,
I did some head scratching on this. I heated the pins and bent a small loop
at the end as you have done. I then drilled a 1/16 hole in the flange/hinge
at the base of the firewall adjacent to the exhaust pipes. I secure the
pins with safety wire through the loops and the holes.
Leo Davies
RV6-A (LDX) almost ready to paint
Date: Wednesday, April 07, 1999 4:41 PM
Subject: RE: RV-List: Cowl Pins
>Randy,
>Fred Stucklen
>N925RV RV-6A
>E. Windsor, Ct
I'd like to hear from those who have successfully used CamLocs, and what
part numbers they used. I've talked to many owners who have problems with
them. The male CamLocs protrude from the cowl section and the cowl must be
flexed to allow them to drop into their sockets. With the stiff cowl,
especially the S-cowl, the cowl cannot be spread/flexed sufficiently to get
it over the CamLoc sockets.
I am leaning towards screws (maybe even round head!) and carrying my
electric screwdriver with me.
Hampshire, IL
under
as
> nice.
I trimmed mine non symmetrically - one side is essentially full width, and
the other is short enough to clear 604. The short one is not much shorter
than the other.
Alex Peterson
Maple Grove, MN 6A slider
attachment to the "ribs".<
Laird Owens wrote:
>I think the reason Van calls out "a lot of rivets" on the instrument panel
bulkhead from the picture as far as being able to transfer these loads<
(structural -- 125,000 PSI) holding the instrument panel.<
That last question got me thinking. I was talking about the -6 "slider", as that's
what I'm building. I went back and looked at my plans and studied the -6
"tip up". It has a shorter deck skin, with a slightly different sub structure,
that terminates at the sub panel. Since this was the first design for the
-6, I'm assuming that Van did a stress analysis of this design, and that the short
deck was deemed acceptable in the torsional mode.
The "slider" has a longer deck skin coming back to the instrument panel. I said
that I thought that taking the instrument panel out of the picture, by not attaching
it using all the screws called out, would weaken the ability of the fuselage
to take torsional loads.
So I'll back pedal a little and say that I still think that it would weaken the
fuse in that mode, but since the "tip up" does exactly that, and that's ok by
Van, it would probably be fine in the "slider".
So, I attaching the panel with 3 screws may be ok when looking at torsional stiffness.
Dan wrote back:
Dan,
That's what I thought you were talking about, i.e., riveting the angle to the
skin, then screwing the panel to the angle. I still think 3 screws is too few.
I would at least add one more in each corner of the panel at the F-621A/longeron.
I would not want to support the panel from just 3 screws in tension from the upper
skin.
By putting all of the screws in as shown in the plans, you would be getting the
additional stiffness that the "slider" affords.
Sincerely,
Laird
SoCal
From: | greynoldsn98(at)mailhost.ind.ameritech.net.with.SMTP (InterMail v03.02.07 118 |
124)
> FWIW
> RV-6A
> Salida, CO
John,
The rest of the story is you get to pay shipping both ways. It was
closer to 3 weeks off old gear on to new one. And..WD631 axle flange
must be drilled 90 degrees to the old gear bolt hole.
Gary
Subject: | Re: empenage kit for sale |
Three (3) month old empenage kit for sale. Price includes elevator electric
trim
$900 Firm.
Stan Z
THEZING3(at)AOL.COM
From: | "William R. Davis Jr" <rvpilot(at)Juno.com> |
Larry Pardue,
Hi Larry,
Have been following this thread and noted that no one has commented about
you running the engine with the wings off. This is not a good Idea. I
know of at least one builder that wrecked on of his elevators doing this
. His name is Pat Carr (woodsboat(at)aol.com) You might check with him
before running it this way again. I believe that Van's cautions against
this too.
About the pump--Facet specifies that it be mounted at a 45 Deg. angle
with the inlet lower than the outlet, is this the case in your
installation?
Regards, Bill N66WD
Subject: | Re:clecoes/avery rivet squeezer for sale |
I have 325 pcs 3/32 NEW clecoes and 125 pcs NEW 1/8 clecoes for sale
.20 each Avery hand rivet squeezer -3 months old with 3 sets of dies $100.00
Stan Z
THEZING3(at)AOL.COM
Subject: | Ques Wiring ? KT76A with "NARCO 850" encoder |
Well I blew that!~~~
Great help from you guys.... for those who know what they are asking for!
Thanks Marshall Dues for the great details....but
It was late and all those tiny numbers sorry listers...here goes again;
I'm wiring a Narco AR 850 encoder to my KT76A. I bought both used, and got a
used harness with it too. But I do not know if the 2 were used
together....... I have the wiring diagram for the King KT76A.
If someone had a wiring diagram for the Narco AR850 encoder and could fax,
scan, jpeg, bitmap and email or??? to me, that would be great.
guess......some encoders wire different? (Yes I found that our cause the ACK
encoder has a different pin plug compared to the NARCO..duh as I later was
advised...)
go?
From: | "Marian Rendall & Scott Sawby" <mkr(at)netw.com> |
Subject: | Gyros, long sad story |
I'm hoping someone on the list knows enough about gyros to shed some light
on my problem, I'm at my wits end.
I installed IFR brand gyros in my RV-6A. I know from the archives that
other prople have been less than thrilled with this brand and they are now
out of business, which may say something. Nevertheless, they were not
cheap gyros, I could have had either of the other major brands for the same
price. I bought them because they were a little shorter and I thought they
would be easier to get in and out with the sub panel.
Anyway, I got my plane flying and neither my DG or Attitude worked. This
was probably my fault, it was over a year from the time I bought them to
the time I got flying. Gyros don't like to sit around inactive.
I had them rebuilt at about $200 ea. They still didn't work. Sent them
back a second time and had them rebuilt. They still didn't work, only $100
this time. I had them rebuilt a third time and this time the DG worked and
still does, but not the attitude, it has been several months. IFR was out
of business, but they were sending them to some instrument repair place in
Wichita. These people are telling me that the bearings are trashed and I
am "abusing them". In discussing this with them they sound convinced that
I am dropping them.
Anyway I decided I wasn't going to spend any more money on this IFR
Attitude gyro, so I bit the bullet and ordered an R C Allen. I Installed it
a week or so ago, it worked fair for a couple of hours (did what it was
supposed to but not particularly accurately). Yesterday it tumbled after I
turned the engine off and it was winding down. It did the same thing this
AM and by this afternoon it had gone tits up. The display either spins or
stabilizes at some weird attitude.
Tomorrow I am going to have my local mechanic put a gauge on my vacuum
system and see if I am getting the vacuum that my gauge says I am, but I'm
not hopeful that is my problem. The DG seems to be doing fine and I have a
new regulator in the line.
I am wondering if RV's just kill them through vibration. I don't think my
plane vibrates excessively, in fact people have told me it runs pretty
smooth. Yet I don't have the gyros on any sort of rubber mounted sub
panel. Has anyone on the list had success with gyros just mounted in the
main panel?
My other theory is maybe you just can't ship these things. They come
packed in a lot of foam, but I've seen they way the UPS people handle
packages.
I would really appreciate it if anyone has any information that may be of
use to me.
Scott Sawby N341SS 130 hrs.
Subject: | Re: Engine Mounts for Aerobatics |
In a message dated 4/7/99 1:20:54 PM Eastern Daylight Time,
Paul_Imhof(at)Dell.com writes:
Paul Imhof
RV-8, on gear, tail installed, engine on the way. >>
Paul,
I have the stiffer mounts on my RV-8 with an IO-360-A1B6. I ordered the
standard ones from Van's, but was shipped and charged for the stiffer ones.
I decided to keep them anyway. I have now been flying my RV-8 for about ten
months. So far, my engine has not sagged at all. The spinner is still in
the same relation to the cowling as day one. I have a McCauley CS prop on my
RV-8 that has a yellow range from 1450 to 1950 rpms. When slowing down to
land, I can feel the vibration when going through this range. I often wonder
if I would feel this if I had the softer mounts. I am helping a friend build
a RV-4 now and am tempted to try his softer mounts since he is not ready for
them yet.
Louis Smith
RV-8 N801RV
85 hours ttsn
Leaving for Sun-N-Fun Saturday Morning!!!!!
Randy,
i found the simplest way (always my desire) was to bend the inboard ends of
the pin into an L with a half hook at the end. Then the half hook can be
sprung in and rotated up to latch onto the engine mount brace. To remove,
reach into the exhaust opening, unhook the pin and pull to the center of the
a/c. Just the reverse to install and hook. No drilling, no extra stuff,
and it is hooked under tension and stays in place.
You'll work it out.
John Darby
>> question:
they
>> "Ready to Paint"
Subject: | Re: Gyros, long sad story |
In a message dated 4/7/99 10:04:23 PM Eastern Daylight Time, mkr(at)netw.com
writes:
main panel?
Scott,
I have a RC Allen horizon and a Sigma-Tek DG mounted in my panel. Both of
these are mounted in the panel without any type of rubber mounts. So far, so
good. They have about 10 months and 85 hours on them.
Louis Smith
RV-8 N801RV
From: Lothar Klingmuller <lothark(at)worldnet.att.net>
Date: Wednesday, April 07, 1999 11:11 AM
Subject: Re: RV-List: ADC REMOTE OIL FILTER
Lothar: The ADC oil filter I spoke of is advertised on page 226 of the
current Spruce Catalog. The manufacturer is Aviation Development Corp,
phone numbers on yellar page and they usually run ads in most of the gen
aviation tabloids.
A casting replaces the stock oil filter, hoses run from this to the remote
mounted filter. I put mine on the outer right engine mount tubes.
Installation instructions and manuf. support very good. (Sent me a free
extra screen when I damaged one.)
The design is often referred to as an "Oberg" type filter and I believe is
common on Nascar racers, ag planes
and other applications
Pluses in my view: early contamination warning, ease of cleaning and
inspection of any debris, no filter to replace.
Minuses: Approx 5lb net weight gain, cost, ($485) added complexity of
additional fittings and plumbing.
Overriding factor for me was the early warning of something coming apart in
the engine via the chip and bypass lights.
Dick Sipp
RV-4 N250DS 145 HOURS
> main panel?
> packages.
> use to me.
I've had RC Allens in my RV-6 for about 6 years and love them. I have done
aerobatics and have had no problems with them. What dose your Vacuum gauge
show for vacuum?
Jerry Springer|RV-6 First flight 7/14/89|Hillsboro, OR|jsflyrv(at)teleport.com
Gee, and I thought I was the only person who had problems with gyros. I
bought all brand new vacuum equipment and Sigma Tek gyros. The attitude
indicator was internally lighted, and very expensive. To make a long story
short I went through the same process you did. After 3 times being rebuilt,
they could not figure out what the problem was ( at this point I had 1,000
dollars into that stupid gyro ). So I bought the same model new again, and
never had a problem with it ( go figure ). Since I do fly it IFR, I was not
going to risk it. In fact, I also have an electric attitude indicator for
redundancy ( It has not been modified for the RV6A panel tilt, so it is not
precise in how it reacts, but it is adequate for backup purposes. ) Make
sure you get the gyros modified for panel tilt if you are using them in real
IFR conditions.
RV6A 125 TT
Scott Johnson scottj(at)ais.net
From: Marian Rendall & Scott Sawby <mkr(at)netw.com>
Date: Thursday, April 08, 1999 3:38 AM
Subject: RV-List: Gyros, long sad story
>I am dropping them.
>main panel?
>packages.
>use to me.
Randy In 200 hours I have had no problem with cracks, broken hinges etc. on
my RV6. I did rivit on a small plate and put one screw on the inboard side
of each hinge ( closest to the exhaust pipes). The hinge itself is bent to
form an "L" with the short end about 2 inches, just enough to give you
something to pull on. I do not have anything to hold the pins in. They
have never moved. All hinges on my cowl were installed with a very light
coat of proseal between the cowl and hinge. Has worked great so far. >
When painting your cowls be sure to mask of the hinges. I got paint
overspray into mine and had an awful time getting my long cowl pins in.
Ken Hoshowski RV6 C-FKEH
Salmon Arm B.C.
>Larry Pardue,
>Hi Larry,
>this too.
>installation?
Bill,
I have not heard of this caution before and do not believe I have read it in
any material from Van's. I got the idea from watching George's videotape.
How was the elevator damaged? I can't think of any reason not to do this.
In any case I am not planning to run it again until the wings are mounted
for the final time.
My pump is mounted exactly per plans and I have spent enough time with it
now to know it pumps fuel fine but will not self prime even after having
been full of fuel. I still am not sure if this is a defective pump on not.
I think I have met you. I looked at a beautiful 4 with a prince prop at Sun
and Fun several years ago. It was owned by Bill Davis. I even inquired
about buying it.
Larry Pardue
Carlsbad, NM
RV-6Q N441LP Madly sanding filler to get ready for inspection 4/22
Subject: | Canopy Installation sequence |
I an finishing the last wing for my RV6A and should have the fuselage kit
here by the end of this month, but I have a question for a friend of mine who
is near installation of his engine and he would like to delay the
installation of the sliding canopy until he has finished cutting the firewall
and completed other connections before he installs the canopy. He has
completed the alignment of the canopy frame and feels that he can get around
inside the forward part of the fuselage by not having the canopy and wind
shield in the way. He also thinks that he can better protect the canopy by
completing most of the inside work before installation. He ask me to quize
the RV list to see what you RV builders think about his plan.
Thanks for your help.
Rollie RV6A Fuselage on the way
RQuinn1(at)aol.com
Subject: | Re: Snow flying (rebroadcast) |
Buster, remove the "do-not-archive" from your vocabulary. I enjoy the fact
that I can find your thoughts in the archive when I need inspiring. Not many
can articulate themselves
as you. this rebroadcast is for posterity.
We now return you to your regularly scheduled program.........
Want me to tell you what I have been up to with flinging the old RV around
the peaks ?
RAIN and lots of it for 40 days and 40 nights and then some, made for dark
days and no flying except for all the Bravo Sierra in the coffee shop.
Then, the dawn broke clear and bright one day in this land of the Northern
Lights, and that was the signal we were waiting for to roll open the doors,
roll out the RV and have at it with a vengeance.
What comes to mind is the hitching up of the dogs, as you truck out the
harness and they know they are in for adventure....they can't wait..and the
lead chews out the next guy and so on down the line until all are in place
and ready...and off we go.
But, in our case, there is no blood unless it is from catching the finger on
the fuel strain,
we climb in, hit the starter, run that prop up so that the blast is almost
seminal and get ourselves out on the button to blast off. BTW, did I
mention that we are also Rocket country here ?...Yes we are, but I am flying
a mere RV.
I head North, climbing at full bore and soon am at the alpine
meadows, 15 minutes from the city, but a world away from civilization, and
find myself "out back" where at 6,000 plus, I see the scars of ski trails
in the virgin snow and it is mighty cold.
If I went down here, I could be lost for 40 years, and that is a fact.
But the RV is a marvelous steed the like of which you will likely not
encounter anywhere else in the realm of airplanes.
This is no place for me, though the beauty draws me like a magnet, I am
uncomfortable close to the peaks, and nobody knows I am here.
With a deft suggestion of right aileron, we reverse course and the land
falls away and we have loads of altitude. I am "high" and very happy.. what
a magic carpet I have...it gets warmer and I feel good and in the glow, I
drop the nose, bring back the stick just a hint, and we go up and over..the
horizon is at the top of my head and the green comes back as I see barns and
cows and fields assume their proper place and we are showing 190 plus..it
feels so grand, I must repeat it. Am I entitled to feel such glory at my
sedate and responsible age ??
I think to reason this question, I must try a most exquisite and slow barrel
roll that takes me 2 miles to complete. What else can I tell you about
myself and my "oneness" with this wonderful RV ??
I am blessed, and make of that what you will, but Van has opened a vista to
all of us RVer's that is not likely to come our way again, anytime soon.
What a feeling of self and what we do !!!!
Now, out of reach of controllers, where the free spirit runs unchecked, I
point the nose downhill and listen to the wind around the windscreen and
watch the clock climb upward, and how can you suppress the smile ? even when
you are alone ??
Down, down, flashing over the beach like no Cessna ever could, nor want
to,..I see a tanker, probably laden with fuel for the enemy, and I strike
out after it and beat it up, climbing away , engine running hard, climbing
in a "g" laden arc, that lets me look back at the wake of the tanker I have
just shot up, and I swear the wide, white, wake looks just like the smoke
streaming from a stricken foe as I turn a 180, seeing I can do no more, and
head back where good fellows wait.
Landing, carrier approach as always, no long 5 mile gaggling drag in as a
172 does, I am filled with the thrill of speed and abrupt maneuver and it
doesn't go away that fast nor that easily....I am pumped, and I must land a
fighter like a fighter should be landed.
With panache, pride of ridership and some skill...
I see the prop now, ..could not before, we are fast, but not unduly so...
the strip lays before me, black, not so wide, not so long, but straight and
familiar..
I chop the throttle..round out very slightly, keep the spinner just where I
have told you many times before..and we touch ....just like that...and only
that...open the canopy, slide it back..listen to the exhaust bark as the
prop slows..we slow.. and turn off...
Could you ask for a better day ??? .. feel grand ??? time doesn't mean
anything..we are consumed in the moment...what else matters ??
All that remains is to debrief..(lie a lot), to the hangar rats,..my dear
friends all, put the steed to bed...wet, and rode hard...listen to the
"ticks" of the cooling ..love it..and close the doors.
I will take you with me next time if you like...this is too good not to
share....
.......Buster,...bent,...bleeding..but not broken...
>>I took a look at the fuel sender. Holy cow, the resistance element for
>>the sender is completely exposed to the fuel! I hope someone
>>can explain why the fuel doesn't blow up once the fuel level goes below
>>the sender. I assume there is very little current going through it, but
>>still, it looks really dangerous. Is this normal?
>Yes. As far as I know, this is common in virtually all light aircraft that
>do not use corks (at the low end) or capacitance guages (at the high end)
> Stuart Spindel A&P IA
As long as there is liquid fuel in a tank, the atmosphere above
the liquid is saturated far beyond stoichiometric (explosive) ratios
and cannot be ignited. Further, materials chosen and electrical
energies applied to the senders are chosen to be spark free and/or
of such low magnitude that it cannot ignite a stoichiometric mixture.
This type of 'sender' has been around for over 50 years in automobiles.
(o o)
===========o00o=(_)=o00o========
< Independence Kansas: the >
< Jurasic Park of aviation. >
< Your source for brand new >
< 40 year old airplanes. >
http://www.aeroelectric.com
>Many of the North Texas RV's are using a Ford 60 amp alternator. This unit
>is basically the same size as the Cessna described above (the internals are
>sightly different). To make it fit we are doing the following:
>Remove the fan and run a 3/4" blast tube from the front baffle to the fornt
>of the alternator or induce the air by drilling a 3/4' hole in the back of
>the case and attaching a fitting ot take the 3/4"tube. This cooling method
>is more efficient since it brings ambient air to the alternator rather than
>already quite hot under the cowling air.
>Use a pulley no larger than 3"diameter and get a drive belt that allows the
>alternator to be all the way up against the engine case.
>Glue a hard rubber block (use Pro Seal) to the inside of the cowling
>positioned so that the alternator case hits the rubber block before the
>pulley chews on the cowl. High speed can push tho cowl inward a bit and ary
>G-loads cause the engine to sag momentarily resulting in contact between
>cowl and pulley even when you have 1/2" clearance at rest. The rubber block
>will keep that from happening.
Whew!!! why not run a stock Nipon-Dienso 60 amp machine that's about
3 pounds lighter, doesn't need an external fan or blast tube, is smaller
in diameter and available from salvage yards for 25-50 dollars?
(o o)
In a message dated 4/7/99 7:10:21 PM Pacific Daylight Time, mkr(at)netw.com
writes:
<< I installed IFR brand gyros in my RV-6A. I know from the archives that
out of business, which may say something.>>
Possibly. My gyro maintenance buddy (Jeff Chambliss) said that they were not
his first choice (or words to that effect), but I have the same IFR Gyros and
they have worked swell since day one. It can't just be my good or your bad
Karma.
<< I am wondering if RV's just kill them through vibration. I don't think my
smooth.>>
I don't think that's it either, but dynamic balancing does a world of good
for reducing wear on your airframe in general and I would think it money well
spent, particularly if it's an O-360 with c/s.
<< Yet I don't have the gyros on any sort of rubber mounted sub
main panel? >>
That's where mine are (hard mounted to the main panel of my 6A) and I've got
200 hrs on them including normal (not overly strenuous) acro. Maybe you got
a lemon.
-GV
In a message dated 4/7/99 7:16:18 AM Pacific Daylight Time,
lothark(at)worldnet.att.net writes:
<< Dick, can you tell us more about this remote oil filter like cost,
suppliers, installation etc? >>
I wouldn't get too excited about the Oberg (ADC) filter. They have been
extensively tested and found to be inferior to the standard spin on type in
terms of particulate removal. LPM, TBO Advisor and Howard Fenton have the
info.
-GV
In a message dated 4/7/99 8:55:28 AM Pacific Daylight Time,
hmsutter(at)flash.net writes:
<< Many of us who have several hundreds of hours on our RV6's have found that
nutplates and screws per side. >>
I would second this opinion. I have 200 hrs on my 6A and have lost the first
two innermost hinge eyes on the cowling right side. I expect to convert
these to plates, nutplates and screws in the not too distant future.
-GV
Subject: | Re: Canopy Installation sequence |
I see no problem with your buddies plan except he may install something that
could interfere with the forward skin and windscreen. I built my canopy and
windscreen and it now sits in a dark corner of the basement collecting dust.
After finishing engine and instrument stuff I will finally permanently install
the windscreen forward skin.
Gary Zilik
Subject: | Damage running engine without wings; was Facet Fuel Pump |
In my builders manual (6A) ,or some where in all my rvators, Van's cautions
against running the engine without the complete and finished airframe. States
that structural damage could occur. I am not in my shop at the moment and will
research this a little more and post my findings.
Gary Zilik
> >. I have not heard of this caution before and do not believe I have read it
> in
> for the final time.
firewall
I built the fuselage including the canopy (slider) but left the top forward
skin un-riveted, and cut and fitted the windscreen but didn't permanently
install it. Then I removed the all of it including the roll bar while I did
all my firewall forward work and instrument panel. Just last week I finally
went back and riveted on the topskin and final installed the roll bar and
windscreen, and am right now doing the windscreen fairing. I'm glad I did it
this way, it really would have been in the way if I'd left it on.
Some people rivet on the front topskin but leave the bottom front skin off
and work from . I think others leave BOTH of them off. Don't know which is
better but it worked ok for me this way.
Randall Henderson, RV-6 (fairings/finish)
Portland, OR
Subject: | Re: Ques Wiring ? KT76A with "NARCO 850" encoder |
Let's see, now...Narco AR-850...ah, yes, here 'tis:
AR-850
Encoder Wire KT-76A
connector Function connector Notes:
13 +DC Input (Thru a 2 amp fuse or CB)
10 Airframe GND DC ground
22 Enable Connect to a GND
19 A1 P1-M
17 B1 P1-E
21 C1 P1-D
20 A2 P1-K
16 B2 P1-C Altitude data bit lines
14 C2 P1-L
18 A4 P1-J
15 B4 P1-B
24 C4 P1-H
4 Oven jumper Connect pin 4 to pin 9
9 Oven jumper to enable the oven
This data was copied from Narco AR-850 Altitude Reporter Installation/
Operation Manual part number 03753-0620 dated July 1988.
Hope this is useful for anyone installing these radios.
Marshall Dues
RV-6, N243MD 200 hrs
Louis,
Is there a problem on long term engine alignment with regular mounts?
The spinner is still in the same relation to the
cowling as day one.
From: | Stuart Summers <stuartrv(at)powerup.com.au> |
Subject: | RV6 Aileron and Flap position |
I am requesting information on behalf of another RV6 builder who is a
non internet user.
Has anyone mounted the flaps and ailerons closer in an upwards direction
to the top skin. Closer is about 3/8" in an effort to increase
performance.????
Please reply to: bactech(at)bigpond.com.au
In a message dated 4/8/99 5:25:41 AM Eastern Daylight Time,
Louis,
cowling as day one.
Paul,
I have only read post here on the RV-list cautioning that most installations
seem to sag about 1/8 to 1/4 inch after a short while. I don't have first
hand experience with this, so some others on the list would be better
qualified to comment on this subject.
Louis Smith
Sorry to hear about your gyro problems, Scott. I also purchased IFR
gyros because they were shorter and fit behind my tilt up canopy
instrument panel. The AI never worked from day one and I replaced it
with an RC Allen which works fine thus far. My IFR DG appeared to work
for a while but now has taken to spinning on engine shut down, so that
bodes ill for its continued functionality. Scary to think of flying IMC
with the quality of gyos we see.
Ed Anderson
RV-6A N494BW 32 hours
Vienna, VA
> I am dropping them.
> main panel?
> packages.
> use to me.
Louis & Paul,
After 1300 Hrs on my O-320D1A with regular Lord mounts, my engine has
sagged about 5/16". I'm now seriously considering replacing them......
Fred Stucklen
N925RV RV-6A
E. Windsor, Ct
> -----Original Message-----
> From: Lousmith(at)aol.com [SMTP:Lousmith(at)aol.com]
> Sent: Thursday, April 08, 1999 6:40 AM
> Subject: Re: RV-List: Engine Mounts for Aerobatics
> cowling as day one.
> Paul,
> installations
> Louis Smith
Ed,
I replaced my IFR Gyro after numerous problems. It had about 1100 Hrs on
it with three overhauls. The RC Allen so far has held up with about 200
hours on it....
Fred Stucklen
N925RV RV-6A
E. Windsor, Ct
> From: Anderson Ed [SMTP:anderson_ed(at)bah.com]
> Sent: Thursday, April 08, 1999 7:15 AM
> Subject: Re: RV-List: Gyros, long sad story
> Ed Anderson
> Vienna, VA
Fred,
I did not even get 1 hour out of my AI and the IFR DG looks like it is
headed south after approx 30 hours. I sort of had a bad feeling about
the IFR gyros when I noticed that a number of the gyro overhaul places
would not accept IFRs as a core. They have a nice face and are compact,
but clearly have reliability/durability problems. Does not surprise me
they are no longer in business. Hopefully, my RC AI lasts longer.
Ed Anderson
N494BW RV-6A
Vienna, VA
Stucklen, Frederic IFC wrote:
> Ed,
> hours on it....
> Fred Stucklen
> N925RV RV-6A
> E. Windsor, Ct
> > Ed Anderson
> > Vienna, VA
In a message dated 4/8/99 8:51:27 AM Eastern Daylight Time,
stuckle(at)ifc.utc.com writes:
Louis & Paul,
Fred Stucklen
N925RV RV-6A
E. Windsor, Ct
Fred,
I have heard of some people shimming the bottom mounts with an extra washer
or two to bring the engine back in line. Are you going down to SNF this
year? If so and passing through eastern NC on the way, I can provide hanger
or tiedown on Friday night. I also can top you off with 100LL REALLY cheap!
I will be leaving early Sat. morning for SNF.
Louis Smith
RV-8 N801RV
Subject: | Engine Mounts - Fixing a Sagging Engine |
> installations
> have first
I have 328 hours on my RV-6 in two years. The engine (O-320 D2J,
Sensenich metal prop) has sagged about 1/4". I used standard engine
mounts, which I purchased from Van's. Unfortunately, I didn't learn about
setting the engine high (or rather the cowling low) until after I was
flying.
To correct the problem, I am considering installing shims between the
engine mount and the firewall at the four lower attach points. Does
anyone have any comments on the advisability of this? Is there another
fix that would work better?
Mark Nielsen
Green Bay, WI
Subject: | Re: Wing tips and lights |
> Need lots of good input and opinions on mounting
> position lights and strobe light.
Opinions abound. Just wait. Here's my own.
> Question is...what do you think looks best ?
Ahhh... you abdicate your responsibility as an RV builder (repeat
offender no less!) to make it the way _you_ think it looks best.
> Mounting position lights and strobe on an angle,..
> e.g. flush with underside of wingtip or forming
> up a fibreglass mount that sits the whole works
> vertical like ??
But since you ask, you really should push the lights out there rather
than flush on the bottom dside of the tip. I don't think you will have
full coverage of your position lights otherwise. I intend to do this
with mine - either from Van's parts or roll my own; will have to see
how I like working fiberglass.
> I was going to make the tip removable and decided
> to hell with it for two reasons.
> One was not enough #6 plate nuts ( I need at least
> 72)... Two, was, ..how many times are you going to
> want to remove the damn tip anyway ??
> I am leaning strongly to mounting on an
> angle,..cutting out a square
> access hole about 5" square to get at the strobe
> power pack if I need to and let it go at that...
> Think that looks OK ??? what would you do ???
You have mentioned the only reason I can think of to make them
removeable, and that's only if you mount the power supply on the tip
rib. If you put it on the main spar in the same bay as your landing
light (assuming you have a leading edge light) you'll be able to access
it through the light hole.
Good luck!
Mike Thompson
Austin, TX
Wings
Subject: | Re: Engine Mounts - Fixing a Sagging Engine |
Subject: RV-List: Engine Mounts - Fixing a Sagging Engine
> > installations
> > seem to sag about 1/8 to 1/4 inch after a short while........
Mark: You do not have to place shims under the engine mount at the fire
wall. The easier fix is to add one large washer each between the lower
rubber mounts and the engine. This is permissible as long as the engine
mount bolts still are long enough for nut and cotter pin (you might be able
to eliminate a washer from the front side if you have more than one there).
One washer brings the enigine up about 1/4". As far as mounting the cowl
1/4" low in the beginnig that may not always be the answer either. I
mounted my cowl to fit the spinner and after 1,350hrs and eight years
everything is still in the same place - no sag. I used Barry Controls
mounts from Van's. However I have seen may installations where sag did
occur, usually very shortly after the first flight. That makes me wonder if
the mounts were not seated properly at the time of engine istallation. When
I install an engine I raise and lower it several times with the hoist after
all four bolts are in and the nuts are snug but not fully torqued. This
allows the mounts to align and seat themselves. So far none of the engines
I helped install this way have sagged.
Louis,
I'm leaving early Sat Morning myself, but will stay with my parents on
the East cost of Florida (Sabastian) and fly over daily. I plan on
leaving for home again (CT) on Tue morning. Plan is to stop at Duplin
Co A/P, winds permitting. Otherwise, it's Suffic Co Virginia and
probably Ocalla Florida.
Where are you based? Maybe on the return, or some other time....
Fred Stucklen
N925RV RV-6A
E. Windsor, Ct
> Sent: Thursday, April 08, 1999 10:18 AM
> Louis & Paul,
> has
> them......
> Fred Stucklen
> N925RV RV-6A
> E. Windsor, Ct
> Fred,
> washer
> this
> hanger
> cheap!
> Louis Smith
> RV-8 N801RV
> http://www.matronics.com/contribution
From all the problems listed, there must be a reason that certified planes
have shock mounted panels.
Date: Thursday, April 08, 1999 8:21 AM
>Fred,
>Ed Anderson
>N494BW RV-6A
>Vienna, VA
>> Ed,
on
>> hours on it....
>> Fred Stucklen
>> N925RV RV-6A
>> E. Windsor, Ct
IMC
>> > Ed Anderson
>> > Vienna, VA
Subject: | Re: Fwd: Church Kids Say the Darndest Things |
Those things are no more silly than what adults pray for, and the prayer are
just as effective.
Brian Trubee
<< To correct the problem, I am considering installing shims between the
Mark & List,
Its pretty much a common occurance for the engine to sag
about a quarter of an inch if your using the new mounts supplied by Vans. I
dont know of any one who I fly with who hasnt experienced this. There are two
ways to correct for this problem.
#1. When installing the cowl assembly set it up so that the rear top edge of
the spinner is about a quarter inch above the cowl. After 100hrs or so
(probably less) the engine will settle into place.
#2, Simply install one of the large washers like the kind suplied with the
mounts between the mount pad on the engine and the mount its self. This can
be done by loosening one of the lower mounts and pulling the bolt back some
on the other. Then have a friend lift on the front of the engine, at the same
time slip in the washer. Repeat the process for the other side. This will
lift the engine up about a quarter inch.
I had to do step 2 on my engine, and after the initial shimming it has not
moved since.
Ryan Bendure Co.
Subject: | transponder altitude encoder general info |
The recent questions about wiring an altitude encoder prompted me to
reexamine some of my paperwork and make a few comments.
The original altitude encoders were mechanical things. They were
essentially a standard altimeter with an optical encoder in place of the
hands in the mechanism. In fact, this type of encoder even looks like an
altimeter without a face (same shape and size generally). This type of
encoder is relatively expensive ($500 or so) and expensive to overhaul
($200 or so). It does have the advantage that, as soon as you apply power,
it puts out a good signal.
A couple of years back someone discovered that the electronics industry had
come up with a small pressure transducer that was essentially built into a
chip. These pressure transducers are cheap (on the order of $10)
especially when you compare them to the older electromechanical encoders.
This made the current crop of small, relatively inexpensive ($150-$300)
solid-state encoders possible.
But these little pressure transducers have a characteristic that the
electromechanical encoders don't have; they are *very* temperature
sensitive. Unless you can keep them always at exactly the same temperature
they can not meet accuracy specs. So the manufacturers build in an "oven",
a heater that heats up the pressure transducer to a temperature that is
higher than ambient and then keeps it there. The units are calibrated at
this higher temperature. What this means to you is that, somehow, these
boxes need extra power to power the oven heater. Also, most of these units
will not generate a signal to the transponder until the oven heats up to
operating temperature. This is why the instructions say that the encoder
will not produce a signal until some 5-10 minutes after power is applied
(worst case if the unit is sub freezing when you turn it on).
Where I got burned by the oven (pun intended) is with my Terra transponder.
I wired my encoder as I have in other aircraft ... where I used a common
transponder like a King KT-76A or a Narco AT-150. These transponders have
a standby position on the power switch (off-standby-on-altitude). When I
start the airplane and turn on the avionics, I turn the transponder to
standby. By the time I taxi out and am ready to take off, enough time has
passed and the encoder is warmed up and working. Not so with the Terra.
As I was doing my installation I noticed that Terra had provided a second
power input to their encoder for the heater. Clever me thought, "I don't
need that since the heater will also run off the power from the
transponder." What I didn't pay attention to is the fact that the Terra
transponder doesn't have a standby position on the selector switch. It
just has off-on-alt. You see, unlike most transponders, the Terra unit has
no vacuum tubes (the KT-76A and the AT-150 still have tubes that need to
warm up) so it will start working just as soon as you apply power. Not so
the encoder.
So now when I taxi out I have to turn my transponder to "on" so that the
encoder will warm up. When I get out to the runway and do my run up, I
turn it to "alt" just before take-off. This won't matter most places but I
expect someday when I am at a big airport that has the radar at the airport
to hear the tower tell me to turn off my transponder until I taxi into
position for take-off. That means that, for a couple of minutes after I
take off I am going to have to listen to ATC complain about not receiving
my mode-C reply.
Oh well ...
From: | Donald Farrand <dotndon(at)worldnet.att.net> |
Subject: | Re: RV-List Digest: 04/07/99 |
Larry n51p(at)carsbad.net
I had an experience with the electric fuel pump that wouldn't self prime
and learned it was a loose fitting upstream so that the pump wouldn't
prime, but after I found that fitting loose and snugged it up, things
started working ok. I flew an rv4 for over 5 years and just started
flying the rv 6 last month...14 hours and going...but I noticed it takes
longer for the '6 to get that "full" sound that I always listen for
before turning the ignition switch.
Don RV6 N164DF What fun!
Laird,
Yes, I forgot that there are 2 screws each side that go into an angle with
the angle attached to the logeron/deck to secure it in addition to the 3
as that's what I'm building. I went back and looked at my plans and
studied the -6 "tip up". It has a shorter deck skin, with a slightly
different sub structure, that terminates at the sub panel. Since this was
the first design for the -6, I'm assuming that Van did a stress analysis of
this design, and that the short deck was deemed acceptable in the torsional
mode.
I said that I thought that taking the instrument panel out of the picture,
by not attaching it using all the screws called out, would weaken the
ability of the fuselage to take torsional loads.
weaken the fuse in that mode, but since the "tip up" does exactly that, and
that's ok by Van, it would probably be fine in the "slider".
>Dan wrote back:
>Dan,
the skin, then screwing the panel to the angle. I still think 3 screws is
too few. I would at least add one more in each corner of the panel at the
F-621A/longeron.
the upper skin.
getting the additional stiffness that the "slider" affords.
>Sincerely,
>Laird
>SoCal
Dan
Dan Wiesel
408-551-6554
Re: 6A ... look at the plans.
Builders
Point 1 If you add a shim at the firewall you need to add less, to raise
the front of the engine up the 1/4 inch because you are working with a
longer arm length.
Point 2 You are changing your thrust line less adding it at the firewall
for the same reason. If you change it at the back of the engine you have
to angle the engine (thrust line) more degrees to get the same amount of
rise in the spinner. (think about it)......
Hope this helps
Tom Overton
Top Gun, Calif.
This is NOT correct. The sag is not in the mount. If the mount was welded
up correctly, the sag is in the Rubber and that is where it should be
corrected. It is was right when built, steel tube mounts do NOT sag.
Date: Thursday, April 08, 1999 4:24 PM
Subject: Re: RV-List: Engine Mounts - Fixing a Sagging Engine
>Builders
>longer arm length.
>Hope this helps
>Tom Overton
>Top Gun, Calif.
From: | "Gar & Jan Pessel" <pessel(at)ptialaska.net> |
----- Original Message -----
Sent: Wednesday, April 07, 1999 3:50 PM
Subject: RV-List: Wing tips and lights
> Need lots of good input and opinions on mounting position lights and
strobe
> light.
I can only relate my experience using the RMD faired light system. Get
Orndorff's video if you want to see what it looks like. This is a beautiful
system, well built, etc. etc., looks gorgeous. However, fiberglass
anythings never fit perfecfly, and the system proved to be enormously time
consuming to install. Beware of watching the video when George says
something
like "you have to be careful in trimming this and I have done this and this
is what it looks like" 30 seconds later. This is often hours. Lots of tiny
little adjustments to get both the
bulkhead insert and particularly the lens to fit correctly. The process is
straightforward unless you try to hurry. The use of filler will be
necessary in some places, particularly to get a smooth curve from the wing
leading edge to the lens leading edge. It took me a couple of days for each
tip (okay, I am very slow). At times I yearned for having chosen the "drill
one hole in the tip and put the position-strobe-tail light in place. Could
have done that in minutes. It probably will get me .2mph speed increase at
cruise, at least 10mph increase when tied down. :-) Gar Pessel Fairbanks,
AK rv6 qb electric flaps and controls
From: | Bob Paulovich <jonkarl(at)worldnet.att.net> |
the plans say to leave radius yet cut to have a flat tongue. bunny said
leave and flatten in order to get the 3.25 inch distance between the 610
and 614. i get that distance without radius flatten. any suggestions???
btw, thanx for the advise guys on the 6 degree bends. oh yeah, have fun
at sun see u all perhaps next yr or at osh this summer. drivin of
course. bob in arkansas
From: | L & M Rowles <lmrowles(at)netspace.net.au> |
Subject: | Re: Laser levels |
I have told my sons what ever happens after I'm gone don't let my wife sell
anything for what she believes I paid for it.
Les Rowles
Po Box 1895
Traralgon
Australia 3844
Subject: | Re: Facet Fuel Pump |
Larry Pardue wrote:
> ****snip***
>***snip
> Larry Pardue
> Carlsbad, NM
I had this problem on a gas powered golf cart. Turned out to be a
very..very...very small crack in the fuel line and it allowed just
enough air in the line that it wouldn't draw the fuel.
Jerry Calvert
Edmond Ok -6 wings
Subject: | Vans new video is here |
Vans new RV video is done, in stock, and ready to ship.
Its longer than the first and very well done with lots of straight &
level and aerobatic flying, RV history, and even some building
instruction. The new tape has extensive coverage of the RV-8 and 8A,
various quickbuild kits and even some on the new RV-9.
Watch it when you can't look at another rivet or if you find its been
too long since you've looked at one last; or to help a friend or
relative understand your new obsession; or to help obsess yourself if
you're still just considering making the commitment.
Bargain price at $10.
Order through our secure on-line catalog.
(from the front page, click on Vans RV specific)
Andy Gold
RV-6A N-5060 (flying)
Builder's Bookstore
http://www.buildersbooks.com
From: | EARL FORTNER <e.fortner(at)worldnet.att.net> |
Give me a fax number or call me at (704) 361-3163 I have a wireing
diagram.
> 3) Questions/Problems:
> a) Wiring in the King Manual, KT76A to King encoder doesn't seem to jive with
> the 25 pin connector as it is currently wired. So I need to check it out I
> advised...)
> b) There was a wire cut free and dangling from the harness....it goes to pin
> # 13 in the 25 pin connector.....if It didn't go to transponder where did it
> go?
> c) Ditto, there was another wire cut free and dangling from the harness....it
> goes to both pins # 10 and # 22, in the 25 pin connector.....if It didn't go
> to transponder where did it go?
> Thanks
> David McManmon, RV6 Cicero NY
From: | "Daniel H. Morris" <morristec(at)icdc.com> |
Scott,
I would be very suspicious of the vacuum plumbing and connections. It is
interesting that the gyros will sort of work if plumbed backwards, just not
very well. BTW I have IFR gyros that sat for 3 yrs before use and they work
very well for about 50 hrs. now.
Dan Morris
RV6A
>From: "William R. Davis Jr" <rvpilot(at)Juno.com>
>To: rv-list(at)matronics.com
>Subject: Re: RV-List: Facet Fuel Pump
>Date: Wed, Apr 7, 1999, 7:42 PM
> Larry Pardue,
> Hi Larry,
> this too.
I know of one other one--Bill Kowalewski had the same thing happen to his
RV-4. he says his second set of elveators look better anyway
James Freeman
Believe it or not, my wife is encouraging me to build the 6. Some lucky guy
huh.
Mike Rawls, enpenage on order
Subject: | Interested Builder in California |
RVer's,
I am considering building/buying an RV-4/8 and will be hosting the Harrier
static display at the March AFB airshow this weekend in Riverside, CA.
Would love to show you my airplane and talk with you about building an RV.
Hope to see some of you out there.
Sorry, no Harrier demo at this airshow.
Dale Willey
toverton wrote:
> Builders
> longer arm length.
> Hope this helps
> Tom Overton
> Top Gun, Calif.
Tom
If you shim at the engine you are just putting it back to its original
position. If you shim under the mount at the firewall you change the
geometry of the engine.
Jerry (had to shim) Springer
Subject: | Re: RV-6A "New" Nose Gear |
I'm sorry, I can't resist....
For Christ's sakes, quit yer bitchin'........ Van's charged me $80 plus
shipping for the new nose gear. For a grand total of $100 I sleep better at
night knowing that a new, better nose gear is on my aircraft. Van's turned
it around within 72 hours of receiving my old nose gear. That time included
custom drilling a part off of their shelf to match my existing nose gear.
Anybody out there think Cessna or Piper would have that turn around time and
that cost for a "certified" part.
According to Van's the reason the WD631 axle flange must be drilled 90
degrees to the old gear bolt hole is that it may make the nose gear last
longer. Can you believe it, a manufacturer making a design change AFTER
receiving test data that the change may improve the product. It took me a
grand total of five minutes to drill the WD631 to accept the new nose gear.
This was less time than it took to write this e-mail.
It's all part of being an AIRCRAFT OWNER :)
Off my soapbox,
Scott Gesele N506RV - Flying
(InterMail v03.02.07 118 124) with SMTP
>> I decided to put on the new/improved/stronger RV-6A nose gear just to be on
>> the safe side. (40% stronger) Today Van's notified me my turn on the
>> waiting list had come up. Here's something I didn't know: You have to either
>> drill the mounting hole yourself, or send the old nose gear leg to Van's for
>> duplicate drilling. In itself this is not a big deal, only I sure hate to
>> put the airplane out of service for a couple of weeks! Van's folks say they
>> will give 3-day turnaround. It's just the darn shipping delays that are
>> pain. Just thought others would like to know.
>> FWIW
>> RV-6A
>> Salida, CO
>John,
>Gary
April 01, 1999 - April 08, 1999
RV-Archive.digest.vol-gr
