RV-Archive.digest.vol-hc
October 11, 1999 - October 15, 1999
      4.  As you get farther away from critical AoA, how does the calibration of
      the LRI hold up?
      >Our business is priamarily one of saving lives.  Do you have a problem with
      >that, Mr. Lloyd?
      Oh, get off your high horse.  Your business is one of making money or it
      isn't a business.  Yes you have what appears to be a good product.  Yes it
      seems to work.  No, it isn't magic.  It has flaws that are dictated by cost
      and physics.  Trying to claim that the flaws are features is poppycock.
      Trying to claim that the LRI is perfect is equally poppycock.
      Every day people fly with an airspeed indicator.  They know that the stall
      speed is dictated by aircraft loading and that they must accommodate that
      when operating near stall speed.  They understand about instrument
      installation errors and the difference between indicated and calibrated
      airspeeds.  They have been taught the effects of temperature and pressure
      on the instrument and are therefore able to accommodate its limitations.
      All I am asking you to do is to provide the same information about the LRI.
      You know, one of the nice things about microprocessor-based equipment is
      that you can program in corrections for variations in the system.  You can
      calibrate out the errors.  That is much more difficult to do with purely
      mechanical systems.  I do notice that you have come out with a version of
      the LRI with a digital display.  Are you going to use a microprocessor to
      calibrate out the system errors?  That would be nice.  And while you are at
      it, you can use an input from the flap system to recalibrate the instrument
      so that it gives spot-on information when the flaps are deployed.  About
      the simplest and most reliable method is a microswitch that lets the unit
      know when the flaps are deployed.
      >Let me know when the Propriatary Software system will fly on a certified
      >aircraft.
      I cannot say firsthand because I haven't seen it but I have been informed
      that it is indeed flying on a certified aircraft.  You will have to talk
      with PSS about that.  I am not going to make any claims that I have not
      verified.
      >No reports of bugging or fouling with the LRI, not as yet (20 some odd
      >years).
      Maybe you are lucky.  Maybe no one felt that it was necessary to tell you
      that a big old grasshopper impacted the probe and fouled it.  So the pilot
      had to get out and dig the pieces out of the probe just as he would have
      for his pitot tube.  I betcha that it never occurred to them to tell you
      about it.  But just because you have never had a *report* doesn't mean it
      didn't happen.  To me, your probe appears to be just as vulnerable to
      impact fouling as is a pitot tube.  If I am wrong, please correct me.
      Please back up your correction with a technical explanation of why I am wrong.
      >We do have reports of getting pilots out of difficult situations
      >when their airspeed indicators went down for those very reasons.
      I don't doubt that.  I never doubted that.  And a second airspeed
      instrument might have served them just as well as might a PSS AoA
      instrument or a vane-type AoA sensor.  This sort of added safety does not
      seem to be the unique domain of the LRI.
      >Heat is a factor with de-icing equipment and in morning frost, etc.
      Are you trying to tell me that your LRI is accurate when the airframe is
      iced up?  That it is accurate after ice has distorted the airfoil?  In that
      case, it is magic.  I was under the impression that the LRI probe had to be
      adjusted to the particular airfoil to which it is attached.  If that
      airfoil changes without a corresponding change to the calibration of the
      LRI then the LRI's information is suspect.
      OK, so your LRI probe is deiced and it is working normally.  The
      information it is giving is still suspect if the wing has ice or frost on
      it.  On the other hand, it is still providing relative information as is
      the ASI or other AoA equipment.  You just have to find where the new
      critical AoA is so you can mentally adjust for the instrument readings
      (read, you have to play test pilot with your iced up airplane).  What I
      won't buy is that the LRI is going to reliably let the pilot know where the
      critical AoA is on the first take-off of the day with a frosted up wing.
      Relying on the airspeed or AoA instrument in that case is plain foolish.
      >Mr. Franz goes after us very often.  Perhaps you were not aware of that?
      No, I was not aware of that.  I have never seen any negative stuff from
      him.  I have seen negative stuff from you.  If he uses negative
      marketing/advertising then shame on him.  It is sad that people feel a need
      to attack their competitors and their competitors' products.  I would much
      rather have factual information so I can make a reasoned decision about
      which product I want to purchase.  Sometimes it is very difficult to do
      because the manufacturers are generating lots of heat and very little
      light.  I am asking you to shed more light on the subject of *your* product.
      >Our mission is to help general aviation overcome a bad habit - airspeed.
      >We are battling that 'bad habit' every day.
      Your mission is to sell a product and that is as it should be.  I agree
      that AoA is better information than AS but I sure as heck wouldn't call
      using the ASI a "bad habit" given that every airplane is equipped with an
      ASI.  You just need to know the limitations of the instrument just as you
      need to know the limitations of the LRI or other AoA instrument.  No
      instrument is perfect and an understanding of its limitations is very
      important so that the pilot may make safe decisions.
      >We tell pilots who call us, who come by our booth at various airshows, or
      >in any way contact us, that it doesn't matter to us what system they use,
      >but fly AOA.
      No argument there.
      >If you are going to attempt a comparison of systems in public, Mr. Llyod,
      >please try to make that attempt an accurate.
      I beg your pardon?  That is what I am attempting to do.  I *KNOW* what the
      PSS AoA unit does because I have many hours using it under many different
      conditions.  I have put it to every test I can devise and it has accurately
      reported the two data points I can easily reproduce; i.e. zero lift/AoA and
      critical AoA; at all types of G and aircraft loading and at many different
      density altitudes.  It is always spot on.  How that is achieved is less
      important than the final result.  It sounds like you are implying that the
      PSS AoA does not work or is somehow incorrect in its presentation to the
      pilot.  I can attest that it does work and that it does so very well.
      >All articles that I am aware
      >of comparing the various systems that have appeared in the aviation press
      >have been written by Mr. Franz.  We invite comparisons.  We invite
      >discussion.  We do not feel compelled to attack Proprietary Software.  But
      >please make the debate honest, make the evaluations impartial, get all the
      >facts, understand all the issues, get familiar with all the applications.
      Seems to me that is what I am doing.  Frankly, I discount manufacturers'
      claims.  They have a vested interest in making their product look better
      than their competitors' products.  I certainly discount both yours and Mr.
      Frantz' claims.  What I am saying is that I was sufficiently convinced by
      Mr. Frantz that I was willing to bet money on what to my mind was an
      unproven system.  What I am saying here is that the Proprietary Software
      Systems AoA instrument, as installed in my aircraft, works precisely as
      claimed by Proprietary Software Systems.  I understand the physics behind
      its operation and I have seen for myself that it is accurate.  In fact I go
      back periodically and recheck the calibration just to make sure it hasn't
      drifted.  So far so good.
      On the other hand, I have never had the physics of the LRI explained to me.
       I have had to infer how it operates from looking at the unit and its
      probe.  I can see where it probably has potential for installation error
      and instrument errors.  You have done nothing to answer my questions or
      dispel my concerns other than act hurt and point to tests by other
      organizations.  Yes, I have read the "Engineering Discussion" section of
      your web page but some of the questions that I and others have asked remain
      unanswered.
      >Again, I ask you, in what way have we harmed or offended you, Mr. Lloyd,
      >and what are you doing to promote general aviation safety, to save lives
      >and to raise awareness so that the level of GA accident statistics declines?
      You haven't harmed me in any way.  You haven't offended me other than you
      haven't provided me with solid test information so I can see how the
      indications on the LRI really map to the real world.
      And your latter comment implies that you are doing something to improve the
      safety of GA and I am not.  This discussion isn't about me, it is about
      your product.  Please stick to the facts and provide factual information
      about your product.
      As I understand it, I believe the following statements to be true:
      1.  you are in business to sell the LRI and you want to make it as
      attractive as possible;
      2.  the LRI provides useful information about AoA especially near critical
      AoA where it is most needed;
      3.  the LRI suffers from errors but these errors are probably not
      sufficiently great so as to provide the pilot with a false sense of security.
      If I am wrong, *PLEASE* correct me, and do so with hard, factual
      information.  I would especially love to see a calibration chart showing
      the relationship between the LRI indications and actual AoA under varying
      conditions.  I know my PSS AoA is accurate over a wide operating range
      because I have personally tested my own unit in my aircraft.  Maybe my
      airplane is an anomally and the PSS AoA instrument's good performance is a
      fluke.  Somehow I doubt that since the PSS AoA instrument was designed and
      tested on Lancair aircraft and my Nanchang CJ-6A Chinese military trainer
      designed in 1957 is pretty far from that Lancair but I cannot an will not
      make any claim other than the PSS AoA instrument works properly on *MY*
      aircraft.  Your milage may vary.
      And as for how I am trying to make GA safe, I am a flight instructor.  I
      try to make GA safer one pilot at a time.  I have a reasonable grasp of
      aerodynamics but I make no claim to be an aeronautical engineer.  I use the
      tools at hand and try to impart enough knowledge so that, when I am not
      around, my students will make safe, conservative decisions.  Hopefully they
      will have learned enough to do that with or without an AoA indicator in the
      cockpit.
      >Jim Huntington
      Brian Lloyd
      brian(at)lloyd.com
      +1.530.676.6513
Subject: Re: LIVING with aircraft batteries
Date: Oct 11, 1999
----- Original Message ----- From: Robert L. Nuckolls, III <nuckolls(at)aeroelectric.com> > One company in particular > has gone the extra mile in optimizing cranking > performance in VERY small cells (1.2 a.h.). > > See http://199.239.60.165/ > > These tiny cells combined with two alternators make > it now possible to remove the pigs found on most > aircraft engines for starters and alternators and > to forego the classic 24 a.h. battery in favor of > light weight alternators, starter, and itty-bitty > batteries for a DUAL electrical system who's TOTAL > weight is about equal to the original 24 a.h. battery! Bob, I looked at this website and could only find their SecureStart product. How would you propose using this in the architecture you describe above? Also, would you have zero battery backup for electric instruments because of the dual alternators? Ross Mickey 6A Finishing kit ________________________________________________________________________________
Subject: LRI Discussion
Date: Oct 11, 1999
I have over 100 hours in my RV-6A using the LRI now. All I can say is that it works! It does what I want and the obscure technical nuances don't really mean that much in real life. FWIW I wouldn't be without it. RV-6A Flying Salida, CO ________________________________________________________________________________
Date: Oct 11, 1999
Subject: Wingtip VOR antenna
I have decided to use Bob Archer's in-the-fiberglass-wingtip VOR antenna. (Yes, I'm retro enough to want a VOR.) The antenna apparently has 2 versions: one mounts at the bottom inside of the wingtip and the other at the top. I assume that since the RV-6A wingtip is flatter on the top than on the bottom, that one would want the version that mounts at the top. Could some one out there who has used this antenna confirm this for me? Thanks, --- Tom Sargent, sarg314(at)azstarnet.com ________________________________________________________________________________
Subject: Re: Instrument Panel Planning
Date: Oct 11, 1999
> > > Agreed, Gary. The .063 is just a tad bit flimsy IMO...FWIW, I have a .090 > panel..much more rigid..I like it much more than the .063 that Van's sells. > I'm assuming it's sold thinner primarily for weight (and maybe cost?). Anyone know how the various panel types/thicknesses stack up on weight? -- Randy Howard (jrh(at)mustang.us.dell.com) ________________________________________________________________________________
Date: Oct 11, 1999
I didn't weigh my .090 and .063 panels, but my guess is that the .090 was about 2 pounds heavier..not a big deal, really..the cost was about $40 for the sheet. Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit -----Original Message----- From: Randy Howard <jrh(at)mustang.us.dell.com> Date: Monday, October 11, 1999 6:53 PM Subject: Re: RV-List: Instrument Panel Planning > >> >> >> Agreed, Gary. The .063 is just a tad bit flimsy IMO...FWIW, I have a .090 >> panel..much more rigid..I like it much more than the .063 that Van's sells. >> > >I'm assuming it's sold thinner primarily for weight (and maybe cost?). >Anyone know how the various panel types/thicknesses stack up on weight? > >-- >Randy Howard (jrh(at)mustang.us.dell.com) > > ________________________________________________________________________________
Subject: Wayne Handley
Date: Oct 11, 1999
EAA Chapter 62 is close to Wayne Handley so I thought I'd forward this message to the list for anyone who was interested..... From Judy Stout, Secretary Chapter 62 San Jose, CA Just an update on Wayne Handley. I got a card and we all signed it at the meeting on Thursday. Nick (my grandson) was part of Wayne's crew the day this happened and has been at the hospital every chance he can including the day of the accident. He has been directly in contact with Karen Handley and gave her the signed card from Chapter 62. Since he is so well known all of the cards are being held and all flowers are being photographed and sent to others in the hospital, otherwise there would not be room for Wayne. Nick went to the hospital after Young Eagles on Saturday and was not able to see Wayne yet but spoke with Karen. Wayne is eating and sitting up and spirits are good. The operation was a complete success and there is no reason to doubt a complete recovery. Wayne should be released from the hospital later this week. Ed Cole RV6A Finish Kit EAA Chapter 62 Board ________________________________________________________________________________
Date: Oct 11, 1999
Subject: Re: Paint Spray Guns
In a message dated 10/11/99 3:41:22 PM Eastern Daylight Time, emrath(at)home.com writes: << I am trying to decide upon a HVLP spray gun for primer painting. There are several on the HarborFreight WWW site. Has anyone any experience with the Central Pneumatic spay guns and what I should consider? >> Marty, I'm currently using the HF model 38308-1RDH HVLP gravity feed (was on sale for 39.99). It's worked great for me and would recommend it to anyone for priming (not finishing). I know the catalog references another gun which looks the same; however the box information on the model I received (ie jet info., etc.) was identical to the more expensive model. Rich Greener RV-8 (still waiting on wing kit) ________________________________________________________________________________
Date: Oct 11, 1999
In a message dated 10/11/99 3:41:22 PM Eastern Daylight Time, emrath(at)home.com writes: << I am trying to decide upon a HVLP spray gun for primer painting. There are several on the HarborFreight WWW site. Has anyone any experience with the Central Pneumatic spay guns and what I should consider? >> Marty, re. my previous post. Harbor Freight #38308-2VGA HVLP gravity feed 39.99 (still on sale - just checked). Sorry for the wrong part number post. Rich Greener ________________________________________________________________________________
Subject: Paint Spray Guns
Date: Oct 11, 1999
You might start a big thread, but the general opinions that I have noticed is that the Harbor Freight guns are fine for priming, but spend a little more on a better gun for painting...not that the Harbor Freight gun doesn't paint well, just not as well as a DeVilbiss or Binks. I purchased many tools from Harbor Freight, and for the most part, they are fine...painting>is too important to me to save a few bucks on, so I would spend the extra money on a higher quality gun. As far as gravity fed is concerned, it is personal preference. I have always used a siphon gun, but some others swear by the gravity fed guns.. Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit ________________________________________________________________________________
Subject: Re: Wayne Handley
Date: Oct 11, 1999
Wayne is eating and sitting up and spirits are good. The operation was a complete success and there is no reason to doubt a complete recovery. Wayne should be released from the hospital later this week. > >Ed Cole >RV6A Finish Kit >EAA Chapter 62 Board > thanks for the update. do not archive Don Jordan ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com> ________________________________________________________________________________
Date: Oct 11, 1999
Subject: Prepping skins without removing alclad
Before I prime the inside of the empennage, how do I prepare the skins without damaging the thin alclad coating? Do you just rub the skins very lightly with a gray scotchbrite pad? If so, what do you do with a deep scratch? Just prime over the scratch without removing it? If the alclad is so thin, would you be better off to skip the scotchbrite pads altogether and just etch, alodine and prime the parts? Perhaps I've just stumbled onto the reason the inside skins on many spam cans aren't primed at all. Thanks for the help. I spent a couple of hours in the archives but couldn't find the answer to these questions. Mark Schrimmer Irvine, CA Waiting for RV-9 tail kit ________________________________________________________________________________
Date: Oct 12, 1999
Subject: (no subject)
Well, The building is done.... let the issues continue VH-LDX has an unswingable compass. I have it mounted on the stainless steel windscreen support bar but the problem is clearly the windscreen rollover bar. Where have people mounted their compasses? Does anyone have a successful installation on the windscreen brace? Dash mount? (please tell me I don't have to make a hole in my nice panel) Cheers, Leo Davies LDX (flying) RV6A ________________________________________________________________________________
Date: Oct 11, 1999
> I didn't weigh my .090 and .063 panels, but my guess is that the .090 was about 2 pounds heavier..not a big deal, really..the cost was about $40 for the sheet. Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit< Seems to me that a few light angle stiffners riveted in the right places would provide the necessary stiffness at less weight. FWIW, Andy Johnson -8 wing skinning ________________________________________________________________________________
Subject: Re: Pneumatic tailwheel
Date: Oct 11, 1999
Van's should have them in soon. > I've looked unsuccessfully on the Web for where to buy a 6" Andair > pneumatic tailwheel someone reported buying at Oshkosh...er, AirVenture. > The Andair website doesn't give a clue... it only lists fuel-related stuff > and I can't make their e-mail button work. > > Can anybody steer me? Thanks. ________________________________________________________________________________
Date: Oct 11, 1999
Subject: Re: RV6 for sale
Good luck Jerry, Send propective buyers this way if they need some good words. Received your R50 today. I'll let you know once I have a chance to try it. Anh > >I reluctantly have decided to sell my 6. Its the third of five homebuilts, >(a Starduster Too, 3 RV6s and an RV8. Finished in august 94 TT 175hrs >O-320E Lyc 160hp, Colin Walker wood prop. Has tilt up canopy, gyro panel, >760Val, R50 loran, King 76a with encoder, nav lts, belly strobe and good >cabin heat. Paint is a military scheme blue top white bottom invasion >stripes and probably the only sharks mouth on a 6. I received builders >choice at the 97 Oswego NY fly in and appeared on front cover of COPAs >Canadian Flight monthly paper november 97. Asking low 50s US$. For more info >and or pictures contact off list or at 506 472 0503. My 1st and 3rd RV6s are >currently flying in the US. Photos can be seen at ( >http://personal.nbnet.nb.ca/nielsdaj/Weyman/weyman.htm ) Will deliver for >expenses. >Regards Jerry Wilcox >jawilcox(at)nb.sympatico.ca > > ________________________________________________________________________________
Date: Oct 11, 1999
Subject: Re: Wingtip VOR antenna
> sarg314(at)azstarnet.com (tom sargent) > > > > I have decided to use Bob Archer's > in-the-fiberglass-wingtip VOR > > antenna. (Yes, I'm retro enough to want a VOR.) > The antenna apparently > has > > 2 versions: one mounts at the bottom inside of the > wingtip and the other > at > > the top. I assume that since the RV-6A wingtip is > flatter on the top than > > on the bottom, that one would want the version > that mounts at the top. > > Could some one out there who has used this antenna > confirm this for me? > > > > Thanks, > > > > --- > > Tom Sargent, sarg314(at)azstarnet.com Tom: I have Bob's VOR antenna mounted in the TOP of each wing tip. ONE is used for the VOR and the other is used for the FM radio entertainment system. I have the same ones that are used on the T-18s years before there were RV-6. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, So. CA, USA Bid and sell for free at http://auctions.yahoo.com ________________________________________________________________________________
Date: Oct 11, 1999
Subject: HS608 edge distance
Listers, While riveting the HS608 rib to the rear spar in my -6 horiz. stab, I had to drill out a rivet, and buggered the hole in the rib. On the advice of many, I have cut off the flange, riveted a new one on and redrilled it to the spar. The problem is, I outsmarted myself and put the new flange inside the rib (same side as the flanges) and consequently, one of the new holes in the flange has only 3/16 edge distance from the radius of the bend. Does the 1/4 edge distance for AD4 rivets apply to a radius? If not, would it be acceptable to put one or two AD4 rivets attaching the 608 to the spar in the middle of the spar (between the flange strips) to strengthen it and make up for the 3/16 edge? Or, should I bite the bullet and order a new rib, and throw the old one on the scrap pile with my first HS610? Jeff Point jpoint(at)execpc.com -6 tail Milwaukee, WI the learning curve steepens... ________________________________________________________________________________
Subject: wing incidence
Date: Oct 11, 1999
OK ..... I'll try again. By changing the 20 3/16" dimension mentioned, and keeping the bottom of the spar carry through constant; you change the wing angle of incidence .... not the location of the wing fore and aft. Another way to say it would be adjusting the 3.03" difference in main to rear wing spar height (with top longeron level) will change the wing incidence angle. I chose to specify the incidence angle as determined by the spar carry through in an effort to preclude pre-stressing this part of the fuselage by forcing the rear spar to fuselage interface as a means of establishing incidence. (The archives discuss this to a small extent) My questions are: does anyone have experience measuring the levelness(?) of the top longeron during flight ?? and, has anyone adjusted their wing incidence or made it purposefully different from stock and found any performance differences ??? Thanks A Bunch, Larry >I would be very careful moving the wing fore or aft, you are doing a lot >more here than simply flying the fuselage a very small angle difference from >"spec"! >Bernie Kerr, 6A finishing, SE Fla >>Bernie Kerr brings up a very interesting subject - the variance in wing >>incidence. I visited a fellow builder earlier this week (with much more >>experience than I) who mentioned changing the 20 3/16" fuselage dimension >>(RV-4; firewall datum to forward top of main spar carry-through) to >>something slightly greater. >>Larry James >>>One possible solution is to drop the trailing edge down the 3/16 inch to make >>>it flush with the fuselage skin. This will change the incidence angle on the >>>wing. You will have to account for this on the horizontal stab incidence so >>>that they keep the same relative angle to each other or you will change the >>>pitch stability. When you are ready to set the stab incidence, pitch the >>>airplane until you get the 3.03 inch difference between the top of the wing >>>at the butt joint over the main spar and the top of the wing over the rear >>>spar as shown on the plans. Now your top longeron will not be level, ignore >>>this and set the horizontal stab at zero angle to horizontal. This means that >>>your fuselage will fly at slightly less angle of attack than a nominal RV, >>>but I was told by Van's technical staff that it might be faster or slower >>>because it has never been optimized for best angle. I would check with Van's >>>to make sure they have not changed their position, but this is the way my >>>plane is but it not flying yet. >>>Bernie Kerr, 6A finishing, SE Fla ________________________________________________________________________________
Date: Oct 11, 1999
GARY DO YOU HAVE STROBES ON YOUR WING TIPS TOM RV8 ________________________________________________________________________________
Date: Oct 11, 1999
Subject: Re: RV-List Digest: FireWall Punches
Several days ago, someone mentioned that Harbor Freight had some punches that were suitable for punching holes in the firewall. Does anyone have the catalog number for these punches? I have been unable to locate any in their catalog. Thanks Wally Hunt RV4WGH(at)aol.com Finishing Kit ________________________________________________________________________________
Date: Oct 11, 1999
--- WFACT01(at)aol.com wrote: > > GARY DO YOU HAVE STROBES ON YOUR WING TIPS TOM > RV8 YES. RMD landing lights, A650-PG/PR wingtip strobe/position lights, and A490A power supplies in each tip. (Van's Catalog System 2 Option A.) Strobes are set up master / slave so are in sync when they flash. There is also a single strobe on the vertical with another A490A power supply in the tail. The VOR radio is a KX-125 and picks up signals quite a way out. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, So. CA, USA Bid and sell for free at http://auctions.yahoo.com ________________________________________________________________________________
Date: Oct 11, 1999
Subject: Re: vertical fin offset
In a message dated 10/11/99 9:09:23, kempthorne(at)earthlink.net writes: Stan, I know nothing about the need or not for rudder tabs but I do know that engineering is not best done by "looks wrong" or by being always in symmetry. Space the bolt holes in a round part in a non-symmetrical pattern to ensure that the mechanic puts it on correctly for example. The tail on straight tail Bonanzas and Debonairs (still for sale) are offset from the centerline and one flap must be up slightly more than the other. The natural human urge for symmetry is just one more thing engineers need to get over. Hal Kempthorne, PE >Technologies SMTPRS 2.0.15) with SMTP id > for > >I am also troubled by the percentage of rudder tabs I have seen. Just my >opinion, but an offset rudder just looks "WRONG". I am a nut for symmetry, >> ________________________________________________________________________________
Date: Oct 10, 1999
From: "David A. Barnhart" <dave(at)davebarnhart.com>
Subject: Re: Painting Info
>Started painting tonight. Control Surfaces, wing tips, cowl >Cleaned, dusted, swept.......Cleaned, dusted and swept again. >If you think your shop is dust free, guess what....Your're wrong. >Oh well, I guess my amatuer built will have an amateur paint job ;' ) Take heart. I felt the same way. For the life of me, I could not make my paint booth dust-free. No matter how hard I tried, I still ended up with dust in the painted surface. The reality though, is that once the airplane is together and flying, no one will notice. My RV-6 was at Copperstate today, and got lots of compliments. Nobody saw the few slight imperfections. (In fact, I doubt that *I* could find all the dust specks I was originally so upset about.) Best Regards, Dave Barnhart RV-6 N601DB Flying ________________________________________________________________________________
From: "Mark D. Dickens" <mddickens(at)mindspring.com>
Subject: Re: HS608 edge distance
Date: Oct 11, 1999
Jeff, I think you're ok...Gil Alexander has a copy of the mil spec for this at http://www.flash.net/~gila/rivet_spec/rivet_a.htm Go to the bottom of the document (I printed it and keep it in the shop) and it addresses this...basically it says: "Provide a minimum of .03" between the edge of non-flush rivet heads (Nos. 1 or 2) and bend radius tangent point. Otherwise, maintain the normal edge distances, both visible and invisible." There's a picture in the document as well. Funny, I just had to cut off a flange myself yesterday and just by luck put it on the right side...didn't even think about the consequences of putting it inside the flanges... Mark Dickens Germantown, TN RV-8 Empennage, skins drilled to skeleton and ready to rivet! ----- Original Message ----- From: Jeff Point <jpoint(at)execpc.com> Sent: Monday, October 11, 1999 6:56 PM Subject: RV-List: HS608 edge distance > > Listers, > > While riveting the HS608 rib to the rear spar in my -6 horiz. stab, I > had to drill out a rivet, and buggered the hole in the rib. On the > advice of many, I have cut off the flange, riveted a new one on and > redrilled it to the spar. The problem is, I outsmarted myself and put > the new flange inside the rib (same side as the flanges) and > consequently, one of the new holes in the flange has only 3/16 edge > distance from the radius of the bend. Does the 1/4 edge distance for > AD4 rivets apply to a radius? If not, would it be acceptable to put one > or two AD4 rivets attaching the 608 to the spar in the middle of the > spar (between the flange strips) to strengthen it and make up for the > 3/16 edge? Or, should I bite the bullet and order a new rib, and throw > the old one on the scrap pile with my first HS610? > > Jeff Point > jpoint(at)execpc.com > -6 tail > Milwaukee, WI > > the learning curve steepens... > > --- > --- http://www.matronics.com/contribution > --- > > ________________________________________________________________________________
Date: Oct 11, 1999
Subject: EAA Petition
EAA Action Item - We need your support! On October 7, 1999, the Federal Aviation Administration (FAA) published the EAA Exemption request that seeks to allow owners of special airworthiness (experimental) category aircraft to be compensated for allowing his/her aircraft to be used for transition training and flight reviews under FAR Part 61, by authorized flight instructors. This request in a major step forward in allowing experimental aircraft owners to be compensated for allowing their aircraft to be used in a training environment. This is a major step forward because, if this exemption is approved, EAA members will be finally able to receive flight training in similar aircraft to the one they are building, buying, or flying. We are all aware that amateur-built, experimental aircraft are the fastest growing segment of general aviation (GA) and currently comprises more than 20% of the active single-engine GA fleet of aircraft. These aircraft have handling and performance characteristics that are different than comparable standard airworthiness aircraft. Some of these new aircraft are quite sophisticated, are pressurized, have highly unusual planforms, operate at higher airspeeds, are more maneuverable, and are capable of operating at high altitudes. Two years ago, the National Transportation Safety Board (NTSB) identified the cause of many special airworthiness category aircraft accidents - Safety Recommendation #A97-55 stated the inability of a pilot to receive training in his/her specialized aircraft prior to their first flight was the leading cause of many aircraft accidents, especially those that occurred when the pilot had less than 10 hours of total flight time in the particular type of airframe. In response to both our members requests and the NTSB finding, EAA petitioned the FAA to allow the builders/owners of these experimental aircraft the opportunity to receive flight training in flight tested, proven, aircraft similar to theirs before they conduct initial flight tests in their own, newly-built aircraft. EAA also petitioned the FAA that this training requirement also extends to those owners who acquire experimental aircraft in the secondary marketplace and those who seek to meet the flight review requirements of CFR 14 Part 61. In this exemption request, EAA illustrated that the level of safety will be greatly improved for the pilots of these special category aircraft and consequently, the public. With the approval of this exemption, EAA, the National Association of Flight Instructors (NAFI), and the Small Aircraft Manufacturers Association (SAMA) fully expect the overall accident rate of this category of aircraft will be significantly reduced. In order to ensure this critical piece of aviation safety policy gets approved EAA, NAFI, and SAMA NEED YOUR HELP !! Please write in support of this exemption request to : The Federal Aviation Administration Office of the Chief Counsel ATTN: Rule Docket (AGC-200) Petition Docket Number 29661 800 Independence Avenue, SW Washington, DC 20591 You may also e-mail your comments to: 9-NPRM-cmts(at)faa.gov. The subject of your e-mail should be: Comments to Docket No. 29661. The deadline for the FAA to receive comments is 10/26/99 This is a critical piece of rule making and your comments will help EAA, NAFI, SAMA, and our members to create truly safer skies and pilots. EAA requests you e-mail copies of your comments to: govt(at)eaa.org. Also, for a copy of the Transition Exemption and the Transition Training Change contact Randy Hansen at rhansen(at)eaa.org or 920-426-6103 Cy Galley - Editor, B-C Contact! Visit our web site at... http://www.bellanca-championclub.com ________________________________________________________________________________
Date: Oct 11, 1999
In a message dated 10/11/1999 12:20:29 PM Pacific Daylight Time, sarg314(at)azstarnet.com writes: > > I have decided to use Bob Archer's in-the-fiberglass-wingtip VOR > antenna. (Yes, I'm retro enough to want a VOR.) The antenna apparently has > 2 versions: one mounts at the bottom inside of the wingtip and the other at > the top. I assume that since the RV-6A wingtip is flatter on the top than > on the bottom, that one would want the version that mounts at the top. > Could some one out there who has used this antenna confirm this for me? > > Thanks, > > --- > Tom Sargent, sarg314(at)azstarnet.com Hello Tom, The VOR antenna mounts along the top of the wingtip. The antenna should be mounted as far forward as you can install it. Any strobe and/or NAV light wires have to be routed along the front edge of the antenna through the cables clamps provided on the antenna. Jim Ayers Thousand Oaks, CA N47RV Maroon Marauder P.S. The COM antenna is mounted along the bottom of the tip rib, and angled up to the top of the wingtip to get some vertical polarity. ________________________________________________________________________________
Date: Oct 11, 1999
Subject: AOA/LRI - Brian Lloyd
Dear Brian, ( I feel like I know you well enough now to call you by your first name.) First, please allow me to apologize to the RV-List for airing this discussion here. I hope at least a few find it interesting and the rest who don't just delete these posts. If anyone looks at the previous headings they will note that I have tried to keep this between Brian and myself. It is not that I am trying to hide anything, but I feel that most if not all of this discussion has been gone over sufficiently on the RV-List so I have tried to avoid offending anyone by continuing to go over the same material too often. I have decided to post this directly to the list (my first post to the list on this current issue) in order to defend myself and my company from what I feel are unwarranted attacks. I monitor the RV-List from time to time because I find many of the discussions interesting and informative. I must admit I don't know an F696 something from a WD822 part. I am not building an RV. Shame on me! However,there are threads that come up about flying or safety that I find stimulating. I also like to follow the various discussions that people start about angle of attack and then inevitably someone brings up the LRI. I have noticed in these discussions that there is invariably some detractor, someone who HAS NEVER ACTUALLY FLOWN with an LRI but nevertheless feeling knowledgeable enough to feel free to trash the product. On most occasions, I believe that I have not stepped in to make any claims unless someone has asked me to respond. Imagine my shock when I read your first post yesterday, Brian, tearing apart my company and making accusations about me, posting a PRIVATE e-mail to your list with various responses to it. Well it did get me a bit upset, I must admit, and I attempted to respond to you in private once again to discover what I could have done to cause you to resort to such tactics. Once again, to my shock, I find that you publicly posted that PRIVATE response to you along with your comments to the entire RV-List. Proprietary Software makes a fine instrument. Certainly. On occasion I have been asked to spell out the differences between the LRI and PSS. I don't believe that I have ever publicly attacked their product, but it has become a running gag amongst us folks to learn how 'ugly' we are. This discovery was pleasantly pointed out to us by the PSS literature. What this has to do with aviation safety, I am at a loss. Now to the list of our physical deformities must be added "snake oil" and "magic". Thank you. There are differences between the instruments regardless of all this and that information should be available, all of it, for everyone to evaluate in the best way they can. In this pursuit, yes I have made comments about holes in wings, and plugged pitots', piggy-backed pitot-static systems, etc. Concerning your comment about riding 'high horses', please be assured that when I read of aviation accidents such as two this summer that claimed 15 jumpers and two pilots, or when a pilot slips behind the power curve due to density altitude or any other cause and loses himself and his airplane, my first thought has nothing at all to do with lost sales. I am torn apart wondering what I can do to get word out about our instrument because these accidents do not have to happen! The fact is, Brian, our mission really is to promote aviation safety. So if any of this flaming mess goes to that end, good! Please, until you have flown with the LRI and really become familiar with it, try to refrain from trashing me or my company. The LRI has an astonishingly high acceptance rate by those who have installed and flown with it. As much as that may sound like 'snake oil', the statement is true. If I fail as a spokesman for it, that is another matter altogether. Again, I am at a loss as to understan why you have chosen to make this unprovoked attack on me and my company especially in a public forum. As I mentioned above, I monitor this list and I have always felt that your contributions were among the best. If the members of this list would like more information about the LRI and what it does or how it works I will be glad to provide what I know, but not in such a way that I feel I am defending myself from attacks and at the same time trying the patience of this list. Jim Huntington jimrhunt(at)wco.com ________________________________________________________________________________
Date: Oct 11, 1999
Subject: Thank You - Copperstate Fly-in
Listers, A very large part of what makes a successful Fly-in is the attendance and enthusiasm of the people that attend. Team Rocket would like to extend a sincere "Thank You" to all that visited us at the Copperstate Fly-in. The show was very successful for us, and beyond that, it was a real pleasure meeting those of you that came by. Thank you for taking the time to introduce yourself and chatting for a few. I look forward to seeing you all again at the next fly-in. Thanks Again!! Scott Team Rocket, Inc. ________________________________________________________________________________
Date: Oct 11, 1999
>Started painting tonight. Control Surfaces, wing tips, cowl >Cleaned, dusted, swept.......Cleaned, dusted and swept again. >If you think your shop is dust free, guess what....Your're wrong. >Oh well, I guess my amatuer built will have an amateur paint job ;' ) Just a FWIW tip, get a large capacity pesticide/herbicide sprayer, 4-5 gallons, and keep the floor wetted down as much as possible. I realize that this may create other problems if you're painting in your basement, but it will make a big difference in the amount of dust. Another thought is to wear freshly laundered clothes, or better still with the dangerous paints now used, is aTyvek paint suit with hood. Andy Johnson, 8 wings. BTW the paint experience is from numerous large scale RC models, I'm not really looking forward to painting something as large as an RV. ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Southwest Regional fly-in
Those of you that are planning on attending the Southwest Regional Fly-in located in Abilene, Texas, please come by the Team Rocket booth to say hi and introduce yourselves. Weather pending, I will be there Thursday thru Sunday, leaving Sunday Morning to head back to Fla. See you there!! Scott Team Rocket, Inc. ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Pop rivets
GV wrote "Back when I started my kit, I did this shear testing and I think the data is in the archives. IIRC the MK-319-BS was only slightly poorer in shear than the AD426-3. It does however require a 7/64" hole. I used them only where I couldn't buck the real ones and they are fine." Gary: Thanks. This is just the what I was looking for. Wish I still had access to some of that neat testing equipment. Harry Crosby ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: wing incidence
There has been several messages posted on the Glasair listserver that suggest that the greater the difference between the Horz. Stab. incidence and the main wing incidence (decallage ?sp), the slower and more stable the airplane. The fastest Glasairs have the lowest decallage angle, but are a little more "squirly". Bruce Glasair III builder Larry E James wrote: > > OK ..... I'll try again. By changing the 20 3/16" dimension mentioned, and > keeping the bottom of the spar carry through constant; you change the wing > angle of incidence .... not the location of the wing fore and aft. Another > way to say it would be adjusting the 3.03" difference in main to rear wing > spar height (with top longeron level) will change the wing incidence angle. > I chose to specify the incidence angle as determined by the spar carry > through in an effort to preclude pre-stressing this part of the fuselage by > forcing the rear spar to fuselage interface as a means of establishing > incidence. (The archives discuss this to a small extent) > > My questions are: does anyone have experience measuring the levelness(?) of > the top longeron during flight ?? and, has anyone adjusted their wing > incidence or made it purposefully different from stock and found any > performance differences ??? > Thanks A Bunch, > Larry ________________________________________________________________________________
Date: Oct 11, 1999
Since I painted my RV-6 just a few weeks ago (and survived the process), I would like to weigh in on the dust issue. I originally had big plans for an elaborate paint booth, and while a booth was constructed, it was much simpler than originally planned. Here is the bottom line.......you are not going to be able to eliminate dust in a home paint booth. Even the guys at the body shops with the $60,000 up-draft booths have fits with dust. Guess what happens the first time the spray gun happens to be aimed in the direction of a fender well? Yep, dust.... I was amazed at the amount of stuff that found its way into the air that originated from the interior spaces of the airframe. In spite of vigorous vacuuming and blowing, there was still dust and particles that were dislodged by the spray gun. However, I soon discovered that it really didn't matter because there is something available to every painter that will take care of dust specks..............1500 grit sand paper. I used to think the flawless paint finishes were the result of immaculate gun technique. And while I highly respect the painters that are true masters with a spray gun, any, and I repeat, any of us can get a great finish if we are willing to spend some time sanding and buffing dust and other defects. Yes, the less dust in the paint to begin with the better, but there is no reason to obsess over surface defects whether it is due to dust or suicidal bugs. There are almost no paint flaws that can't be sanded out with 1500 paper and buffing compound. If you use a single stage paint, then get the paint on the best you can and resolve to perfect the finish after the fact. Same goes for base coat/clear coat, you just may have to do the job twice. Some of the best paint I laid down was on the components I painted out in the yard on saw horses. Maybe there was enough of a breeze to blow dust away from the paint. I decided to stop spending a great deal of time figuring out why dust sometimes appeared and other times it didn't, and just fix the blems later. A friend of mine flew his new RV-8 today for the first time. He painted the plane in the driveway, and while there are numerous problem areas to fix, he will fly now and spend the winter sanding and buffing. By spring, he will have a beautifully finished plane. Painting, as are all aspects of RV construction, is difficult for the exceptionally anal builders :-) Relax, get the paint as nice as you can, confident that you can get the showplane finish later if you wish to expend the necessary elbow grease. Sam Buchanan (RV-6, nicely buffed.........except the bottom of the wings.....maybe later.....maybe not....) "The RV Journal" http://home.hiwaay.net/~sbuc/journal ----------------------- RV8DRIVER(at)aol.com wrote: > > > > >Started painting tonight. Control Surfaces, wing tips, cowl > >Cleaned, dusted, swept.......Cleaned, dusted and swept again. > >If you think your shop is dust free, guess what....Your're wrong. > >Oh well, I guess my amatuer built will have an amateur paint job ;' ) > > Just a FWIW tip, get a large capacity pesticide/herbicide sprayer, 4-5 > gallons, and keep the floor wetted down as much as possible. I realize that > this may create other problems if you're painting in your basement, but it > will make a big difference in the amount of dust. Another thought is to wear > freshly laundered clothes, or better still with the dangerous paints now > used, is aTyvek paint suit with hood. Andy Johnson, 8 wings. BTW the paint > experience is from numerous large scale RC models, I'm not really looking > forward to painting something as large as an RV. ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: Unswingable Compass and first flight
In a message dated 10/11/99 5:07:33 PM Pacific Daylight Time, leo(at)icn.usyd.edu.au writes: << The building is done.... let the issues continue>> Well done, Leo! Does my sleek canopy skirt cap give you a few more kph? << VH-LDX has an unswingable compass. I have it mounted on the stainless steel windscreen support bar but the problem is clearly the windscreen rollover bar.>> Have you thought of degaussing the surrounding steel? I would think that something somewhere has become magnetized perhaps from beating on the bar to make it fit ; ). << Where have people mounted their compasses? Does anyone have a successful installation on the windscreen brace?>> My Precision vertical card compass works great about half way up the bar on the slider. I would think that a dash mount would be worse. -GV ________________________________________________________________________________
Date: Oct 12, 1999
LARRY I DID JUST THAT REDUCED THE ANGLE ON MY RV4 BOUNTY HUNTER. BEST TIME SUN 100 227.25 WITH 180HP TOM RV8 LYCIO540 ________________________________________________________________________________
Date: Oct 12, 1999
Harbor Freight Fall 1999 Catalog, middle of page 12, 6-piece punch set (3/16,1/4,5/16,3/8,7/16,1/2) item #02580-1RDH $3.99 9-piece punch set (3/32,1/8,5/32,3/16,1/4,5/16,3/8,7/16,1/2) item #03838-1RDH $5.99 phone number: 800-423-2567 website: www.harborfreight.com They say they are good "for light gauge sheet metal", I have not tried them on stainless steel... No I don't work for them, just happened to be looking at the catalog! Stefan King Sanford, FL RV-6 plans and workshop stuff... RV4WGH(at)aol.com wrote: > > Several days ago, someone mentioned that Harbor Freight had some punches that > were suitable for punching holes in the firewall. Does anyone have the > catalog number for these punches? I have been unable to locate any in their > catalog. > > Thanks > > Wally Hunt > RV4WGH(at)aol.com > Finishing Kit ________________________________________________________________________________
Date: Oct 12, 1999
Subject: RV-4 Tail
My project was purchased with the tail components nearly completed several years ago. I recently completed the fuse tothe point where I needed to pull the tail parts out of the shop rafters and fit them to my work. Good news and bad: The hor and vir stabs fit perfectly to the fuse -- The vir stad has a signeficant twist in it that doesn't look as if it can be repaired, the hor stab and the elevators don't match very well and the overall construction is not great. I have shown this mess to several people including Bill Benedict from the factory ________________________________________________________________________________
Subject: Airbox Clearance to Scoop
Date: Oct 12, 1999
The airbox on my 360 Airflow Performance 6A is about 3/8" from the left side of the scoop. Engine torque should increase this distance, but is it too close? Also, how far should the alternator be from the cowl? Lord mounts. Alex Peterson Maple Grove, MN ________________________________________________________________________________
Date: Oct 12, 1999
Subject: RV-4 Tail
My project was purchased with the tail components nearly completed several years ago. I recently completed the fuse to the point where I needed to pull the tail parts out of the shop rafters and fit them to my work. Good news and bad: The hor and vir stabs fit perfectly to the fuse -- The vir stab has a significant twist in it that doesn't look as if it can be repaired, the hor stab and the elevators don't match very well and the overall construction is not great. I have shown this mess to several people, including Bill Benedict from the factory. Bottom line: build a new tail group. Yesterday a friend building an 8 tried his vir stab on my fuse and it fit perfectly. Question for the experts: Has anyone fitted an RV-8 tail to a 4? I know this has been done on a Rocket I saw, but the contact at Van's did not know of anyone doing this to a 4. I would like the simplicity of using the pre-punched parts available with the 8, I expect it would weight a bit more ( about 4 inches larger), but perhaps the extra control surfaces wouldn't hurt. Any ideas or comments? Thanks for the help. Sorry for the partial msg, hit the send button by mistake. Ray Grenier -- Back to step one ________________________________________________________________________________
Date: Oct 12, 1999
<< pneumatic tailwheel someone reported buying at Oshkosh...er, AirVenture. > The Andair website doesn't give a clue... it only lists fuel-related stuff > and I can't make their e-mail button work. > > Can anybody steer me? Thanks.>>> Johnny and others. Below is a reply to an e-mail I sent to Andair, which should answer most questions. Hope it helps. Dear Ken, Thanks for your note. We make two types of pneumatic tail wheel. The 6" and the 7". The 6" will fit on the Vans supplied tail fork whereas the 7" will fit on the Aviation products tail fork. (This is an optional extra and is in the catalogue) The weight for the 6" is 1Lb 4.5Oz (half the weight of the solid rubber wheel) and the 7" weighs 1Lb 11.25 Oz. The 6" on runs at $65.00 + $10.00 shipping and the 7" one is $77.00 + $12.00 shipping. They are currently only available direct from Andair so if you would like one of these wheels send a cheque for the correct amount to the address below (payable to Andair Ltd) and when receive the cheque I will send it out. However, in saying that, we are just about to supply Vans the first shipment of some 6" wheels. He may have not sold all of them. Both of the types have a 6 ply construction which makes them rugged enough to take the pounding of a bumpy strip. We recommend pressure setting of between 40 - 60 PSI. However this is a setting that you will have to "play with" so that you get the feel that you require, but even at the maximum rated 90 PSI it will still take out a good deal of shock that is normally transmitted by the solid type. Thanks again, hope to hear from you soon. Yours Sincerely Owen Phillips. andair(at)andair.co.uk --- www.andair.co.uk Andair Ltd. Unit 3 25c Brockhampton Lane, Havant Hampshire PO9 1JT England Fax +44 1705 473946 --- Tel +44 1705 473945 Cheers and take care, Ken Glover Newcastle Oz RV4 VH-MKW ________________________________________________________________________________
Date: Oct 12, 1999
In a message dated 10/12/99 1:38:51 AM Eastern Daylight Time, brucegray(at)earthlink.net writes: << There has been several messages posted on the Glasair listserver that suggest that the greater the difference between the Horz. Stab. incidence and the main wing incidence (decallage ?sp), the slower and more stable the airplane. The fastest Glasairs have the lowest decallage angle, but are a little more "squirly". Bruce >> This is textbook aero 101. If you make more downforce with the horizontal then the wing has to make up the lift(more induced drag) because the net force of the two has to overcome the weight. The penalty in induced drag to do this is minute when you are going the cruise speed with the light wing loading of an RV type machine. You will pay in pitch stability which is not the same as pitch sensitivity. Stability is if something like a gust or bumping the stick upsets the airplane, does it comeback to level flight or does it diverge to larger pitch angles. If the airplane is unstable, it can not be flown hands off in a trimmed condition. The Voyager was designed purposely this way for the around the world flight to make the ultimate fuel mileage. Not what you want in a recreational aircraft for day to day flying. I would not reduce the stability of my RV for a pitance more speed !!! Bernie Kerr, 6A finishing, SE Fla ________________________________________________________________________________
Subject: RV-4 Tail
Date: Oct 12, 1999
The only problem I can forsee you might have is this. The tail in essence provides a downward lift factor. With a bigger (than designed specs) HS and no recalibration you will have a plane that will tend to raise its nose (due to the extra reverse lift). I assume if you take in to account for this you should be alright. John > -----Original Message----- > From: GRENIER(at)aol.com [SMTP:GRENIER(at)aol.com] > Sent: Tuesday, October 12, 1999 5:37 AM > To: rv-list(at)matronics.com > Subject: RV-List: RV-4 Tail > > > My project was purchased with the tail components nearly completed several > > years ago. I recently completed the fuse to the point where I needed to > pull > the tail parts out of the shop rafters and fit them to my work. Good news > > and bad: The hor and vir stabs fit perfectly to the fuse -- The vir stab > has > a significant twist in it that doesn't look as if it can be repaired, the > > hor stab and the elevators don't match very well and the overall > construction > is not great. I have shown this mess to several people, including Bill > Benedict from the factory. Bottom line: build a new tail group. > Yesterday > a friend building an 8 tried his vir stab on my fuse and it fit perfectly. > > Question for the experts: Has anyone fitted an RV-8 tail to a 4? I know > this has been done on a Rocket I saw, but the contact at Van's did not > know > of anyone doing this to a 4. I would like the simplicity of using the > pre-punched parts available with the 8, I expect it would weight a bit > more > ( about 4 inches larger), but perhaps the extra control surfaces wouldn't > > hurt. Any ideas or comments? Thanks for the help. Sorry for the partial > > msg, hit the send button by mistake. > > Ray Grenier -- Back to step one > > > > - > > - > > - ________________________________________________________________________________
Date: Oct 12, 1999
> I have noticed in these discussions that there is >invariably some detractor, someone who HAS NEVER ACTUALLY >FLOWN with an LRI but >nevertheless feeling knowledgeable enough to feel free to >trash the product. Tried to stay out of the current LRI thread, but it too closely duplicates my experience with the folks at LRI (also my private and rv-list exchanges with them). I remember being told that I don't have to know how it works, it just works and if you don't believe it its your loss. They were also unable to provide product literature. I tried to arrange a demo even after this poor service...which they were unable to provide. In short, the product may indeed work and work well, but I have ZERO confidence in the company behind it. Oh...and if you check the NTSB archives, you will find that one pilot had too much confidence in it and rotated before enough lift was available. Rob Acker (RV-6Q, FWF stuff). ________________________________________________________________________________
Subject: rudder tabs and flap joggles
Date: Oct 12, 1999
I can add a few comments on the rudder tab issue and also on the wing incidence/flap joggle discussion. My comments are based on a FLYING RV-4, not on what looks good, etc. Way back, before e-mail and before the RV-6, 8, or the 9, when I built my 4 I noticed that many, many 4's had an unsightly flap joggle where the flap meets the belly. Someone at Van's said there were errors on the plans, or at least misleading information, which caused the problems. I was told to take some careful measurements off my wings (That's one reason to build the wings before the fuselage) and adjust the F404 bulkhead so that the belly skin/wing interface would be smooth. I did and had no flap joggle. I don't recall making any changes to the HS incidence, but I did double check the incidence relationship against the wing. The plane flew with the elevators perfectly aligned. Again way back, before e-mail and before the RV-6, 8, or the 9, when I built my 4 I also noticed that virtually all 4's had a 6" rudder tab. I built mine per the plans anyway because Van's advised me that all the other 4's probably had built in errors which caused them to need the tab. Guess what I added to mine after the first flight - YOU GUESSED RIGHT! - a 6" rudder tab. Later my 4 was slightly damaged and I built a new VS and offset the leading edge about 1/4 - 3/8" to the left when installed on te fuselage. VOILA! NO MORE TAB NECESSARY! All you skeptics need to go look at some GA airplanes. Many have an offset fin. A good example is a 300 hp Bellanca that lives at a nearby field. It must be offset 1 and 1/2" or more. My current RV project will be getting a 1/4" minimum offset. 'Nuf said. My 4 goes 196 mph with no speed mods behind a tired 150 h.p. and wood prop. I guess the above techniques must have worked OK. FWIW, I plan to install some sort of angle of attack sensing device on my current project. All competitors feel free to send product literature to the address below. Thank you, Vince Frazier 3965 Caborn Road Mount Vernon, IN 47620 812-985-7309 home 812-464-1839 office ________________________________________________________________________________
Date: Oct 12, 1999
I think those punches are for gasket material not stainless firewalls...Jim Brown,NJ,3&4 flying.. ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: ELT antenna location
I used a aviation handheld "rubber duckie" antenna & in my limited tests it works great. The signal reception of any antenna of this type....... in theory...... has less signal capturing ability but according to my signal strength meter & SWR meter ( I am a HAM amatuer radio geek...in a prior life) I am showing less than 3.5% loss difference between the 1/4 wave diapole cut exactly for 121.5 MHZ ( as close as one can come with a file & SWR meter) and the rather cool looking shapely rubber duckie antenna that came with my ICOM A-22.....My biggest fear was poking the standard 2 foot antenns in my eye because the rv-4 is rather close to the ground and the traditional location is on the turtle deck location on the rv-4 allways produced a nurvious twitch in my eye when I came near it....Now my rubber ducky antenna is located there (about 2 feet ahead of the vert. stab on centerline)...........cheers ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Subject: Lycoming 0320-A1A For Sale
Date: Oct 12, 1999
Will he take $10,000 ? -----Original Message----- From: Larry Olson [mailto:lolson(at)doitnow.com] Sent: Thursday, October 07, 1999 3:02 PM Subject: RV-List: Lycoming 0320-A1A For Sale OK, let's try again. Friend will take offer... ------------------------------------------ Posting for a friend: For Sale Lycoming 0320-A1A Complete 0 SMOH New Slick Mags & Harnesses New Carb New Prop Governor New Vacuum Pump or Hyd Pump Alternator Starter Fuel Pump All logs since new Rebuild by local reputable shop $ 12,500 FOB Phoenix, AZ Plug N Play... You can reply to me and I'll forward. Larry Olson Cave Creek, AZ RV6 - Fuselage ________________________________________________________________________________
Date: Oct 12, 1999
In a message dated 10/11/99 23:22:48, Vanremog(at)aol.com writes: In a message dated 10/11/99 5:07:33 PM Pacific Daylight Time, leo(at)icn.usyd.edu.au writes: << The building is done.... let the issues continue>> Well done, Leo! Does my sleek canopy skirt cap give you a few more kph? << VH-LDX has an unswingable compass. I have it mounted on the stainless steel windscreen support bar but the problem is clearly the windscreen rollover bar.>> Have you thought of degaussing the surrounding steel? >> That's what I did with mine( the rollover bar) and it worked like a charm. Tip and degausing was courtesy of Don Permattei. Must be something he learned in Veterinary medicne. He used a big hog of a device which plugged into AC current and hummed mightily. Be sure and remove the compass when you do it! Mine is down on hte glare shield by the way, but the roll bar was still interfering. D Walsh ________________________________________________________________________________
Subject: RV-4 Tail
Date: Oct 12, 1999
The only problem I could forsee is that RV-4's are notoriously tail-heavy anyway. I would worry about adding any extra weight on the tail. How much does an 8 tail weigh as opposed to a 4? Although, I'm not an engineer... -----Original Message----- From: GRENIER(at)aol.com [mailto:GRENIER(at)aol.com] Sent: Tuesday, October 12, 1999 5:37 AM Subject: RV-List: RV-4 Tail My project was purchased with the tail components nearly completed several years ago. I recently completed the fuse to the point where I needed to pull the tail parts out of the shop rafters and fit them to my work. Good news and bad: The hor and vir stabs fit perfectly to the fuse -- The vir stab has a significant twist in it that doesn't look as if it can be repaired, the hor stab and the elevators don't match very well and the overall construction is not great. I have shown this mess to several people, including Bill Benedict from the factory. Bottom line: build a new tail group. Yesterday a friend building an 8 tried his vir stab on my fuse and it fit perfectly. Question for the experts: Has anyone fitted an RV-8 tail to a 4? I know this has been done on a Rocket I saw, but the contact at Van's did not know of anyone doing this to a 4. I would like the simplicity of using the pre-punched parts available with the 8, I expect it would weight a bit more ( about 4 inches larger), but perhaps the extra control surfaces wouldn't hurt. Any ideas or comments? Thanks for the help. Sorry for the partial msg, hit the send button by mistake. Ray Grenier -- Back to step one ________________________________________________________________________________
Subject: RV-4 Tail
Date: Oct 12, 1999
Subject: RE: RV-4 Tail
Date: Oct 12, 1999
Subject: RV Fusalage
Date: Oct 12, 1999
We are currently working on the Fusalage. I am a bit confused as to the orientation of the components between the fire wall ( F-6101, F-602, F-684, F-655) and the " spar" bulkhead (F-604). Does the F6101 go inboard of the F-604 flange? Does the F-685 go outbord of all of the other components, ect.....I find the plans are not to clear in this area. If anyone has some detailed directions and/or pictures of this area, please send them to me. They would be apritiated. John Vanderzyde ________________________________________________________________________________
Subject: Cowl Attach
Date: Oct 12, 1999
Listers, I looked at Tyler Feldman's checkerboard RV-6 at Copperstate. It's a different world ain't it. My primary concern, after multiple cowl attach failures, is to just keep the cowling from flapping in the breeze like Levis on the line in west Texas. His concerns, apparently are that his tail fairing, attached with 4 small screws, does not have a hairs breadth gap anywhwere and that the mirror finish of the INSIDE of the cowling does not have any smudges or pinholes. And how is it that the spinner stays on with NO screws? Let's see; my record in 100 hours. Bottom cowl to fuselage attach hinges started breaking at about 5 hours. Replaced with .063 aluminum and plate nuts. No further problems. Side of bottom cowl to fuselage hinge attach on left side only replaced once for about the top five eyes. Broken again now. Considering steel or extruded aluminum hinge this time. Behind spinner originally installed .063 aluminum and nut plates. Broke on both sides this weekend. Planning 4130 steel. The performance of this airplane is fantastic. I was able to easily make it to Copperstate earlier from my home 500 miles away than from the motel in Mesa on the shuttle bus. But this is if you don't consider all the time for cowling attach repairs. Unless the plane gets more reliable I really don't feel good about flying long distances in it; a pity. I am baffled as to why I am having so much trouble. Some may be vibration. There is not a propeller shop nearby, but I need to look for one for a balancing job, although subjectively the plane seems smoother than the majority of planes I have flown. Some may be a lack of building technique although my cowl seems to have a nice relaxed fit and when I read about the experiences of people like Mike Seager and Martin Sutter I know this is not the whole story. I think that if I built another RV I would first inventory all the aluminum hinge. Then I would set aside the amount needed for the seatbacks. The remaining hinge I would bundle up with duct tape and then would run at top speed to the nearest dumpster. Larry Pardue Carlsbad, NM RV-6 N441LP 100 hours ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: RV-Lis Compass swing
See Elect. Bob for some Mueu Metal ( I know that is spelled wrong !) & wrap it around your compass. This is a somewhat common aviation fix...... p.s. keep your subject line informative for all users of the archive service......cheers Dr Leo Davies on 10/11/99 07:38:59 PM Please respond to rv-list(at)matronics.com Subject: RV-List: (no subject) Well, The building is done.... let the issues continue VH-LDX has an unswingable compass. I have it mounted on the stainless steel windscreen support bar but the problem is clearly the windscreen rollover bar. Where have people mounted their compasses? Does anyone have a successful installation on the windscreen brace? Dash mount? (please tell me I don't have to make a hole in my nice panel) Cheers, Leo Davies LDX (flying) RV6A ________________________________________________________________________________
Date: Oct 12, 1999
From: Keith Williams <73623.2504(at)compuserve.com>
Listers - Tom Glover's question on the Andair tailwheel prompted me to try the list with this question. I have tried to contact Andair twice via the Email part of their website with no reply - and don't see this covered in the archives.. I purchased the 6" model at Oshkosh and installed it on my recently completed RV6. It fit perfectly and looked good ( after an air to air photo session the guys told me it spins like mad in flight - I hope it is spinning in the right direction). After three or four flights it went flat while taxiing back to the hanger. So now the old reliable solid wheel is back on the airplane. On the Andair wheel the tire casing seems OK but the tube will no longer hold air. Its like the tube got torn inside without a blowout. My problem is that I have not been able to get it to come apart (split). I have removed the bolts and clamped the tire - trying to pry the wheel apart with a wooden lever. I also tried inflating it to 90psi with the bolts loosened. I can't tell for sure, but I think I see some dried adhesive that has oozed out between the halves. At any rate, no luck so far in opening it up. My next step would be to attack the parting seam with a chisel of some kind. But Its such a nice part that I hate to mar it. Has anyone had one apart or have any suggestions? Is it keyed in some way, requiring that part be turned before splitting? Any ideas appreciated. Also, any ideas about replacement inner tube sources this side of the U.K.?. I have a suggestion to try the medical supply places where they use wheelchair wheels of a similar size.........no TSO, though. Keith Williams - Moline, IL RV6 - 30 hours and learning. ________________________________________________________________________________
Date: Oct 12, 1999
Subject: LRI/ Rob Acker / NTSB Reports
Rob and Listers, It has been brought to my attention by someone kind enough to forward Rob's posting to me concerning the LRI and an NTSB report. This is a very serious matter, and one of which I am totally unaware. Rob, would you please post the report number and the location to access the report. Please post this information, if you will, here on the list for all those who might have an interest to read the report for themselves. I subscribe to the digest version of this list so it may not be possible to follow up on this matter until tomorrow. Thanks Rob, Jim Huntington jimrhunt(at)wco.com ________________________________________________________________________________
Date: Oct 12, 1999
In a message dated 10/12/99 11:17:18 AM Central Daylight Time, 73623.2504(at)compuserve.com writes: << My problem is that I have not been able to get it to come apart (split) >> I also purchased the 6" at OshKosh but have expeirenced no problems to date in operating from both grass and hard surface with my "4". Concerning splitting the wheel to replace tire / tube as is done with a "normal" aircraft wheel, is this neccessary with the Andair considering the considerably smaller dimensions, or was it designed to roll on/off as an auto tire? Or am I missing something? Steve Schmitz ________________________________________________________________________________
Subject: AoA
Date: Oct 12, 1999
Jim, I have read the thread on the RV-List on LRI / PSS / Other / AoA with great interest. I have found Brian Lloyd's discussion rational and very non-discriminating. I have not read any distortion, negative or otherwise biasing statements or intentions on his part. I have seen his attempt to keep the discussion technically centered and technically accurate. I don't really care how Jim or anyone else "feels" about these issues .... I am concerned with the physics, technical accuracy, and user interface involved with an AoA. I am not concerned with Jim's rationalization of saving lives or how hurt he feels by these perceived attacks. Indeed, I have not seen anyone attack him. I have seen strong technical discussion where LRI's product (nothing to do with Jim, unless he personalizes this) leaves some seemingly obvious gaps. These gaps may be technically meaningful or not meaningful (first order vrs. second order effects) or technically inaccurate. The technical questions posed have not been met with technical answers. I was convinced by two local pilots, one currently building and the other getting ready to build (both ex-military fighter drivers / navigators) that AoA is important and useful ... and I have decided to include it in my airplane. Thank you Brian and Jim and Al for the discussion !!!!! Cheers, Larry E James Bellevue, WA larryj(at)oz.net ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: Instrument Panel Planning
> >If you are really looking for absolute min distance the only way to get it >is to do a mock-up panel using the real instruments. There is definitely >some variation between different "standard" sized instruments. > >I crammed a lot of instruments close together, and used a piece of scrap >.032 AL to make a mock-up before cutting the real thing, and am glad I did. >Masonite or thin plywood can also be used. > > >Randall Henderson, RV-6 N6R (21 hrs) >Portland, OR >http://www.edt.com/homewing Ive mentioned this before but... If you want to get some good quality panel work done and particularly if you want/need a check panel to verify placement, try Steve Davis. He provides a clear acrylic check panel as part of his process. Check the archives for more info. Mike Wills RV4 canopy willsm(at)manta.spawar.navy.mil ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: Prepping skins without removing alclad
Mark and all, My 1965 Beech Debonair is not primed on the inside and not corroded at all tho the magnesium elevators were and so replaced a few years ago. I believe there are three reasons not to prime some areas: 1: Not needed 2: Cost 3: Weight hal >If the alclad is so thin, would you be better off to skip the scotchbrite >pads altogether and just etch, alodine and prime the parts? Perhaps I've >just stumbled onto the reason the inside skins on many spam cans aren't >primed at all. ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: Cowl Attach
>Larry wrote: >I am baffled as to why I am having so much trouble. Some may be >vibration. Do we have any sources for vibration analysis? For industrial machinery there are vibration signature analyzers. I suspect some RVs have more trouble than others due to the quantity and quality of vibration they are generating. I suppose this would be especially true with modified engines. hal ________________________________________________________________________________
Date: Oct 12, 1999
Subject: trying to find Mark LaBoyteaux
Does anyone know the email address of Mark LaBoyteaux? His old one at AOL seems to be stale. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Compass swing)
> > >See Elect. Bob for some Mueu Metal ( I know that is spelled wrong !) & wrap it >around your compass. This is a somewhat common aviation fix...... > p.s. keep your subject line informative for all users of the archive >service......cheers It is called mu-metal (mu is the greek letter generally used to indicate the magnetic coercivity of a substance). Magnetic lines of force are attracted to and "stick" to a material with high magnetic coercivity thus making this material a good magnetic "shield". The problem is, your compass still needs to "receive" the earth's magnetic field so if you put a mu-metal shield around the compass, the compass will no longer work. If the source of magnetic interference is localized, you can reduce the effects by putting a mu-metal shield around the offending source or as close to the source as possible. The closer the shield is to your compass, the more the shield will distort the earth's field and introduce compass errors. Also remember that plain old steel has fairly high coercivity and will act as a shield or a conduit for a magnetic field. It may be that the post in question was dropped and became permanently magnetized (one way to magnetize steel is to align it with the earth's magnetic field and then beat on it). If you can wrap a coil of wire around the steel post, you can subject it to a decaying AC field and demagnetize it. That might reduce its effect enough so that you can swing the compass. If people need to do magnetic shielding (I needed to shield my needle/ball) you can get mu-metal shielding material from Magnetic Shield Corporation (http://www.magnetic-shield.com/). They make varying thicknesses from plate down to foil. I used the thicker foil to make a shield for my T&B. It is solderable so you can easily fabricate a can for any localized magnetic source. They also make braid that you can slip over a wire and reduce its magnetic effect. Very cool stuff. > > >Dr Leo Davies on 10/11/99 07:38:59 PM > >Please respond to rv-list(at)matronics.com > >To: rv-list(at)matronics.com > >Subject: RV-List: (no subject) > > >Well, > >The building is done.... let the issues continue > >VH-LDX has an unswingable compass. I have it mounted on the stainless >steel windscreen support bar but the problem is clearly the windscreen >rollover bar. > >Where have people mounted their compasses? Does anyone have a successful >installation on the windscreen brace? Dash mount? > >(please tell me I don't have to make a hole in my nice panel) > >Cheers, > >Leo Davies > >LDX (flying) >RV6A > > Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax ________________________________________________________________________________
Subject: Re: Trade for RV6(a) Kits?
Date: Oct 12, 1999
Date: Oct 12, 1999
> However, I soon discovered that it really didn't matter because there is > something available to every painter that will take care of dust > specks..............1500 grit sand paper. > > There are almost no paint flaws that can't be sanded out with 1500 paper > and buffing compound. If you use a single stage paint, then get the > paint on the best you can and resolve to perfect the finish after the > fact. CAUTION - Most single stage metallic paints cannot be sanded at all without exposing the metallic flakes as little silver spots. Looks terrible. If you must have a metallic, basecoat clearcoat is easier to apply. You can wetsand the clearcoat for a perfect finish. There are differences between the many different brands of paints though. The original post refers to solid colors and is very good information on that topic. Check out his webpage to see the fine paintjob he now has. Single stage metallic paints require good booths. Wet down the walls and floor just before pushing in your project. Never wet down the roof, just blow it off with high pressure air before the wetdown. Paint the wings one at a time. Build racks for them with wheels on the bottom. The new HVLP sprayers do much nicer work because they have a much higher percentage of the paint applying to the surface than the old styles of spray guns. It is the overspray that is the dust problem. The old guns make tons of it. HVLP sprayers use less paint as a result. They are more efficient. You will not need as much paint. If you invest in a good name brand system you should be able to sell it when you are done for at least half of what you paid for it. Norman Hunger RV6A Delta,BC ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Re: RV Fusalage
John Vanderzyde wrote: > We are currently working on the Fusalage. I am a bit confused as to the orientation of the components between the fire wall ( F-6101, F-602, F-684, F-655) and the " spar" bulkhead (F-604). You're building an RV-6A, right? I'm building a -6, but have some photos and notes that might still be useful. Go to <http://members.xoom.com/frankv/bunny.htm> and follow the link to Fuselage -- In the Jig. In the "Firewall to F-604 Longerons" section there's a link to a photo. > Does the F6101 go inboard of the F-604 flange? Does the F-685 go outbord of all of the other components, ect.....I find the plans are not to clear in this area. I think the F6101 goes inboard. What's the F-685? I can't recall. Or do you mean F655? > If anyone has some detailed directions and/or pictures of this area, please send them to me. > They would be apritiated. Feel free to email me with questions. Frank. -- frankv(at)ee.cit.ac.nz Frank van der Hulst My home page is http://homepages.ihug.co.nz/~frankvdh ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: AoA
> >I was convinced by two local pilots, one currently building and the other >getting ready to build (both ex-military fighter drivers / navigators) that >AoA is important and useful ... and I have decided to include it in my >airplane. Thank you Brian and Jim and Al for the discussion !!!!! > >Cheers, >Larry E James >Bellevue, WA >larryj(at)oz.net I also have been convinced that AoA is a valuable instrument to have and Im going to get one. When asked, LRI produced testimonials from unbiased third parties attesting to the quality and usefulness of the instrument. I'm gonna buy the LRI because it better fits my budget, it does what I need it to do, and when I spoke to the company reps I walked away with a good feeling that they were straight shooters. I didnt get the same feeling from the PSS guy I talked to who spent a fair amount of time knocking the LRI rather than telling me about the virtues of his own instrument. While it would be nice to see these questions regarding how the instrument works answered, its not critical in my decision to buy the instrument. For me it is enough to know that it DOES work. OTOH my track record on judging companies/products isnt all that great recently since I'm one of the guys who has apparently been screwed by the disappearance of Audio Flight Avionics. Mike Wills RV-4 canopy willsm(at)manta.spawar.navy.mil ________________________________________________________________________________
Date: Oct 12, 1999
The 684's go up front on both the 6 & 6A, the 6 gets a 654 & 655 to the rear. the 6101's go on the rear of the 6A only & don't get any 654's or 655's. ref drwg 31. Be sure to tell us what airframe you are asking about. The 685 is the backrest support on manuel flaps. Take some time laying out the revits around the 6101, you will need to hide one in each courner to hold things together until the visable rivet are defined. I think they wanted more structure around the geear legs brackets on the 6A to carry more load. The gear on the 6 is taken out in the engine mount. Don Jordan ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com =========================================== writes: > >We are currently working on the Fusalage. I am a bit confused as to >the orientation of the components between the fire wall ( F-6101, >F-602, F-684, F-655) and the " spar" bulkhead (F-604). > >Does the F6101 go inboard of the F-604 flange? Does the F-685 go >outbord of all of the other components, > >John Vanderzyde ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: RV Fuselage
John, There are two web sites that I found to be very helpful in this area. Sam Buchanan's at http://home.HiWAAY.net/~sbuc/journal/ and M & M Aerosport at http://www.flash.net/~donmack/rv6a/index.html Hope it helps... Larry Olson Cave Creek, AZ RV6 - Sitting in Fuse making airplane noises!!! > >We are currently working on the Fusalage. I am a bit confused as to the orientation of the components between the fire wall ( F-6101, F-602, F-684, F-655) and the " spar" bulkhead (F-604). > >Does the F6101 go inboard of the F-604 flange? Does the F-685 go outbord of all of the other components, ect.....I find the plans are not to clear in this area. > >If anyone has some detailed directions and/or pictures of this area, please send them to me. They would be apritiated. > > >John Vanderzyde > ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: AoA
Well Larry, since you mentioned me by name I guess I'll comment on your post. I think your post is very reasoned and well stated. I think what Jim was refering to (and I'm not trying to speak for Jim here) is that his private E-mails were posted to the RV-List with comments without even the courtesy of a heads-up. I don't blame him for those "feelings". Frankly I was surprised at Brian because I didn't think he would do something like that. I have a lot of respect for Brian, but the tone of his posts just seemed accusatory to me. Maybe it's just the way I'm reading it. But beyond that, I don't blame Jim for his defense because of the last time this got dragged accross the RV -List about a year ago. It's all in the archives and people were getting pretty outspoken about their distaste for further discussion in this forum. For Brian to bring it up in such a context without giving Jim the courtesy of some private dialog puts Jim at a distinct disadvantage in the discussion because as soon as he participates he is, in some listers views, misuseing the RV-List. He's darned if he does and darned if he doesn't. My interest in this is that I have run several RV-List special price sales on the instrument. I e-mailed Jim over a year ago and asked him if he could give us a special quantity buy for RV-List members and he graciously agreed to do that. Since that time I have run that special twice and haven't heard any complaints from anyone who has participated. In fact I know one is flying and CB told me he likes it but is getting more experience with it and learning what it will do. I have since met Bill and Jim at Oshkosh and believe them to be honorable men. For one thing, their instrument has a life time guarantee. Something goes bad and they will make it right. No questions asked. I realize that this still hasn't answered your question about just how does it work. Well I have an idea but it's one that I have formed myself through reasoning things out in my own mind. AS FAR AS I AM CONCERNED,the fact is, it does work. In all the feedback I have from people who have flown with it, they say it works. Maybe Jim can give us more sources of information. I don't know. And frankly I don't even care. What I care about is what people who are using the device have to say about it's usefullness and accuracy. When Rob Acker points us to that NTSB report to back up his claim, maybe I can read something negative about the LRI. Until that happens I haven't heard or seen anything negative about the instrument. What I have seen is some people call it everything, including usefull, but I still come away thinking that they still believe there is something wrong with it because they don't understand it. Sometimes simplicity can be confusing. I certainly hope I haven't offended you. AL > >Jim, >I have read the thread on the RV-List on LRI / PSS / Other / AoA with great >interest. I have found Brian Lloyd's discussion rational and very >non-discriminating. I have not read any distortion, negative or otherwise >biasing statements or intentions on his part. I have seen his attempt to >keep the discussion technically centered and technically accurate. > >I don't really care how Jim or anyone else "feels" about these issues .... I >am concerned with the physics, technical accuracy, and user interface >involved with an AoA. I am not concerned with Jim's rationalization of >saving lives or how hurt he feels by these perceived attacks. Indeed, I >have not seen anyone attack him. I have seen strong technical discussion >where LRI's product (nothing to do with Jim, unless he personalizes this) >leaves some seemingly obvious gaps. These gaps may be technically >meaningful or not meaningful (first order vrs. second order effects) or >technically inaccurate. The technical questions posed have not been met >with technical answers. > >I was convinced by two local pilots, one currently building and the other >getting ready to build (both ex-military fighter drivers / navigators) that >AoA is important and useful ... and I have decided to include it in my >airplane. Thank you Brian and Jim and Al for the discussion !!!!! > >Cheers, >Larry E James >Bellevue, WA >larryj(at)oz.net > > ________________________________________________________________________________
Date: Oct 12, 1999
Subject: RV -6/6A wing & tail kit for sale
Hello listers, Although I have been lurking for some time, this is not the type of first message to the list I had anticipated sending. However, in the interest of family harmony, here goes: My RV-6/6A wing & tail kits are for sale. Included are: HS, VS, rudder, and elevators complete (except fiberglass work) trim tab 99% complete (set up for manual trim, easily changed to electric trim) Phlogiston spar wings are in jigs with main skins and outboard leading edges drilled on. no work has been done on the ailerons, flaps, fuel tanks. aileron bellcrank drilled, but not riveted, no work on rest of controls. variprime on tailkit, PPG DP-50 epoxy primer used on wings. 2 Van's landing light kits. My tools will be offered first to who ever buys the wing kit. Located in Jupiter, FL, near West Palm Beach. For sale at my cost - $6350 Thanks, Alan ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: Pneumatic tailwheel
Keith, I had the same problem, although I got a few more flights (<20) before the tire went flat. I used a knife blade with edge placed at the parting seam to split the wheel. A light tap with a small hammer made the two halves come apart. The parts are not keyed. There is a reinforcement patch where the valve is attached to the tube. The inner tube was torn right at the edge of this patch. Seems like a quality problem to me. Rubber resembles cheap ($3) Chinese bicycle tubes. Tyre seems ok. I have emailed my findings to Andair, but have seen no response. Pity, because it's a beautiful wheel and taxiing is much smoother. I also need the weight saving as my -6 is tail heavy. Anyone else having had problems with this product? If you find a replacement tube, please tell us. Ernst Totland SE-XOI RV6 200h > >snip > After three or four flights it went flat >while taxiing back to the hanger. So now the old reliable solid wheel is >back on the airplane. On the Andair wheel the tire casing seems OK but the >tube will no longer hold air. Its like the tube got torn inside without a >blowout. > >My problem is that I have not been able to get it to come apart (split). I >have removed the bolts and clamped the tire - trying to pry the wheel apart >with a wooden lever. I also tried inflating it to 90psi with the bolts >loosened. I can't tell for sure, but I think I see some dried adhesive >that has oozed out between the halves. At any rate, no luck so far in >opening it up. My next step would be to attack the parting seam with a >chisel of some kind. But Its such a nice part that I hate to mar it. > >Has anyone had one apart or have any suggestions? Is it keyed in some way, >requiring that part be turned before splitting? Any ideas appreciated. > >Also, any ideas about replacement inner tube sources this side of the >U.K.?. I have a suggestion to try the medical supply places where they use >wheelchair wheels of a similar size.........no TSO, though. > >Keith Williams - Moline, IL >RV6 - 30 hours and learning. > >snip ________________________________________________________________________________
Date: Oct 12, 1999
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: Re: Instrument Panel Weight (Was lighting)
>I didn't weigh my .090 and .063 panels, but my guess is that the .090 was >about 2 pounds heavier..not a big deal, really..the cost was about $40 for >the sheet. > >Paul Besing >RV-6A (197AB) Arizona >http://members.home.net/rv8er >Finish Kit< > >Seems to me that a few light angle stiffners riveted in the right places >would provide the necessary stiffness at less weight. FWIW, Andy Johnson -8 >wing skinning Aluminum weighs right at 0.1 pound per cubic inch. A sheet of aluminum 12 x 36 x .090 thick would weigh 3.88 pounds while .063 thick would drop to 2.72 pounds for a decrease of about 1.1 pounds. I suspect our 12 x 36 inch panel is a bit big so the expected weight savings would be less than a pound. The trick now is to offset the loss of stiffness with less than one pound of braces and rivets. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Independence Kansas: the > < Jurassic Park of aviation. > < Your source for brand new > < 40 year old airplanes. > ================================ http://www.aeroelectric.com ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: AoA
Date: Oct 12, 1999
Subject: Re: AoA
Date: Oct 12, 1999
Where do you get all of your data, Bob? That is great stuff...glad to have you on the list! Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit > Aluminum weighs right at 0.1 pound per cubic inch. A sheet of aluminum > 12 x 36 x .090 thick would weigh 3.88 pounds while .063 thick would > drop to 2.72 pounds for a decrease of about 1.1 pounds. I suspect > our 12 x 36 inch panel is a bit big so the expected weight > savings would be less than a pound. The trick now is to offset > the loss of stiffness with less than one pound of braces and > rivets. > > > Bob . . . > > //// > (o o) > ===========o00o=(_)=o00o======== > < Independence Kansas: the > > < Jurassic Park of aviation. > > < Your source for brand new > > < 40 year old airplanes. > > ================================ > http://www.aeroelectric.com > > ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Heavier Instument Panel Aluminum
Paul: Where did you get your 0.090 aluminum for the panel? I checked A/C Spruce and the smallest piece they offer is 2' x 4' for about twice what you say you paid. Harry Crosby (HCRV6(at)aol.com) Fuselage skinning (still) ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: LIVING with aircraft batteries
>Bob, > >I looked at this website and could only find their SecureStart product. Hmmm . . . they've rearranged their website again. Try this: http://199.239.60.165/tech/tmf.asp This points to the description of the individual cells . . . >How >would you propose using this in the architecture you describe above? Also, >would you have zero battery backup for electric instruments because of the >dual alternators? you betcha! no need to carry lots of lead around if you have two engine driven power sources. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Independence Kansas: the > < Jurassic Park of aviation. > < Your source for brand new > < 40 year old airplanes. > ================================ http://www.aeroelectric.com ________________________________________________________________________________
Subject: Re: Heavier Instument Panel Aluminum
Date: Oct 12, 1999
Steve Davis got it when he cut my panel. He got it from a local supplier in Memphis. You may want to give him a call...here is his website. http://members.aol.com/panelcut Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit -----Original Message----- From: HCRV6(at)aol.com <HCRV6(at)aol.com> Date: Tuesday, October 12, 1999 9:49 PM Subject: RV-List: Heavier Instument Panel Aluminum > >Paul: Where did you get your 0.090 aluminum for the panel? I checked A/C >Spruce and the smallest piece they offer is 2' x 4' for about twice what you >say you paid. > >Harry Crosby (HCRV6(at)aol.com) >Fuselage skinning (still) > > ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Painting
Listers: I can't resist asking what is probably a really dumb painting question. For you guys who are finished painting, when in the building process did you finish paint the interior of the cabin (RV-6/6A), before riveting the skins on or after the fuse is out of the jig? Harry Crosby HCRV6(at)aol.com ________________________________________________________________________________
Subject: Re: Painting
Date: Oct 12, 1999
Sorry I don't qualify for the sequence, as I have a quickbuild, but I can tell you that it was no big deal to paint it after the skins were on. You may want to wait until you have done the canopy and such, to avoid scratching the paint, if you don't use a very tough paint. I painted mine too early..if I were to do it again, it would be one of the last things I did before putting in wiring, canopy, and interior. Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit -----Original Message----- From: HCRV6(at)aol.com <HCRV6(at)aol.com> Date: Tuesday, October 12, 1999 10:12 PM Subject: RV-List: Painting > >Listers: I can't resist asking what is probably a really dumb painting >question. For you guys who are finished painting, when in the building >process did you finish paint the interior of the cabin (RV-6/6A), before >riveting the skins on or after the fuse is out of the jig? > >Harry Crosby >HCRV6(at)aol.com > > ________________________________________________________________________________
Subject: .090 panel/MicroEncoder
Date: Oct 12, 1999
Oh yeah, a word of caution using the .090. If you are installing a MicroEncoder in a .090 panel, it will not sit flush on the front of the panel, as it's front edge is only deep enough to sit flush on an .063 panel. Mine sits back a little..not a big deal, but for aesthetic reasons, I wish it was flush. Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit -----Original Message----- From: HCRV6(at)aol.com <HCRV6(at)aol.com> Date: Tuesday, October 12, 1999 9:49 PM Subject: RV-List: Heavier Instument Panel Aluminum > >Paul: Where did you get your 0.090 aluminum for the panel? I checked A/C >Spruce and the smallest piece they offer is 2' x 4' for about twice what you >say you paid. > >Harry Crosby (HCRV6(at)aol.com) >Fuselage skinning (still) > > ________________________________________________________________________________
Date: Oct 12, 1999
> >Listers: I can't resist asking what is probably a really dumb >painting >question. For you guys who are finished painting, when in the >building >process did you finish paint the interior of the cabin (RV-6/6A), >before >riveting the skins on or after the fuse is out of the jig? > >Harry Crosby >HCRV6(at)aol.com I am waiting on the finish kit. 6A w/tip up. I have 1/2 the instruments in & the elec flaps. I am still at cleco stage. I painted the interior w/ Centari. Will wait to rivet any thing until I get the canopy finished. Seems like everthing needs to come back out for the 50th time, so I am to scared to rivet yet. The brakes can be installed backwards. I did get them in right side up though. I shot every thing that you won't be able to see on the bench. I left the 672 forward bottom skin off, then I shot the interior. I still have to do the 631 roll bar, the top of the 605 & the 621's on the side. Don Jordan ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com ________________________________________________________________________________
Subject: AoA
Date: Oct 12, 1999
> >...AS FAR AS I AM CONCERNED,the fact is, it does work. >In all the feedback I have from people who have flown with >it, they say it works. Yikes, this has certainly gone from what I thought was a good technical discussion to a personal thang. Jim of LRI, I didn't perceive Brian's emails as "attacking" you, but more of a request for less hand waving and more technical data. You replied with more hand waving and complaining. And yet again, failed to provide some technical data or background. And I think Brian is justified in trying to figure out just where the LRI might be less accurate, since people are partially "betting their bacon" on it. Yes, everybody who has an LRI might be fat dumb and happy with it's performance, but are there times in the flight regime that they are flying closer to the raggest edge than they know? We're talking about the LRI not knowing that the airfoil has changed shape due to flap deployment. Last time I checked this happens at a pretty critical time, in the pattern and on final. If the LRI is possibly less accurate during the most critical time, you bet people are interested in finding out just how and to what degree it is off. It's that simple. Not a personal attack, just a request for information on the product. Mitch Faatz San Jose, CA N727MF (reserved) RV-6AQME Finishing Kit... Pres/Newsletter Editor - Bay Area RVators http://www.skybound.com/BARV http://www.aftershock.org/rv.htm ________________________________________________________________________________
Date: Oct 11, 1999
Subject: Re: EGT & Fuel Flow Question
writes: > >I have just purchased an RV-6A with a Lycoming 160 and Hartzell >constant >speed prop. Total time on the airframe, engine and prop is now 120 >hours. >I have flown it for the last 14 of those hours including a trip from >GA to >NH to bring it home. > Frank, Your numbers seem reasonable to me. EGT readings are relative and have a whole lot to do with how far down the exhaust pipes the thermocouples are installed. My own EGT's run in the 1380 to 1420 range when leaned to peak at 65 % power. Regards, Bill N66WD ________________________________________________________________________________
Date: Oct 12, 1999
Subject: LRI and AoA (long)
> >Well Larry, since you mentioned me by name I guess I'll comment on your >post. I think your post is very reasoned and well stated. I think what Jim >was refering to (and I'm not trying to speak for Jim here) is that his >private E-mails were posted to the RV-List with comments without even the >courtesy of a heads-up. I don't blame him for those "feelings". Frankly I >was surprised at Brian because I didn't think he would do something like >that. It was a mistake. I had taken myself off the RV-list temporarily and thought that the message had come to me and been posted to the RV-list so I replied accordingly. >I have a lot of respect for Brian, but the tone of his posts just >seemed accusatory to me. Maybe it's just the way I'm reading it. Not accusatory but certainly frustrated. I have people asking me how the LRI works and is it a valid source of AoA information? I want to understand it so I can give reasonable answers. All I can do is look at the instrument, look at the patent (look up US patent number 4559822 at http://www.patents.ibm.com), and try to divine the information myself. The patent is very illuminating and creates more questions in my mind. >But >beyond that, I don't blame Jim for his defense because of the last time >this got dragged accross the RV -List about a year ago. It's all in the >archives and people were getting pretty outspoken about their distaste for >further discussion in this forum. For Brian to bring it up in such a >context without giving Jim the courtesy of some private dialog puts Jim at >a distinct disadvantage in the discussion because as soon as he >participates he is, in some listers views, misuseing the RV-List. He's >darned if he does and darned if he doesn't. I was under the impression that people wanted this information. I got the feeling that there were a lot of people considering some sort of AoA device, the two most prominent being the LRI and the PSS AoA from Jim Frantz. I thought that, since the discussion originated here (my mistake -- it had originated on another list the and reply from Jim was a private one forwarded to me privately), my response should go back here. It just goes to show that even someone who has taught others to look carefully at the headers before posting, can make a mistake. >My interest in this is that I >have run several RV-List special price sales on the instrument. I e-mailed >Jim over a year ago and asked him if he could give us a special quantity >buy for RV-List members and he graciously agreed to do that. Since that >time I have run that special twice and haven't heard any complaints from >anyone who has participated. In fact I know one is flying and CB told me he >likes it but is getting more experience with it and learning what it will >do. I have since met Bill and Jim at Oshkosh and believe them to be >honorable men. For one thing, their instrument has a life time guarantee. >Something goes bad and they will make it right. No questions asked. This certainly sounds like good business practice and good support for their customers. >I realize that this still hasn't answered your question about just how does >it work. Well I have an idea but it's one that I have formed myself through >reasoning things out in my own mind. AS FAR AS I AM CONCERNED,the fact is, >it does work. In all the feedback I have from people who have flown with >it, they say it works. Maybe Jim can give us more sources of information. I >don't know. And frankly I don't even care. What I care about is what people >who are using the device have to say about it's usefullness and accuracy. Ahh, now you get to my major concern -- accuracy. Is the LRI an accurate portrayal of angle of attack? Will it keep you out of trouble? The more I look at it the more it appears that it is NOT an angle of attack indicator. From what I have been able to determine, it is only correct at one angle of attack, the AoA which corresponds to the zero indication on the instrument. If it is calibrated at the critical angle of attack (stall) then it will reliably indicate critical AoA and only that one AoA. If you use it to indicate how far you are from critical AoA the faster you are going and the more your airplane is loaded (pulling Gs), the more it will indicate you are "safe" when in fact you are actually quite close to stall. Unlike true angle of attack instruments, airspeed has a significant effect on the LRI indication over and above the actual AoA. In fact, the LRI displays a combination of airspeed and AoA in one guage. If you are going fast and pulling hard, you just might hit an accelerated stall before the LRI has a chance to tell you that you are near the edge. >When Rob Acker points us to that NTSB report to back up his claim, maybe I >can read something negative about the LRI. Until that happens I haven't >heard or seen anything negative about the instrument. What I have seen is >some people call it everything, including usefull, but I still come away >thinking that they still believe there is something wrong with it because >they don't understand it. Sometimes simplicity can be confusing. And sometimes too much simplicity can make something less than useful. The LRI has red and green areas on the instrument, apparently there to indicate safe and unsafe operating range. If you are flying in a narrow range of airspeed, such as during landing approach, this is probably valid. If you have the airplane loaded up and pulling Gs, the LRI indications are magnified such that the needle might be in the green range when in fact it would be in the red range if the aircraft were on a 1G approach to the airport. Now this is not in and of itself a bad thing IF THE PILOT KNOWS THIS IS HAPPENING! I suspected that this is the case but I didn't know for sure so I asked Jim the questions. The LRI will definitely tell you is if you are approaching a stall if: 1. it was calibrated to indicate zero right at stall; 2. the airplane is configured exactly the same way it was (gear, flaps, slats) when it was calibrated. Beyond that I am not sure what it will tell you. Maybe it is really useful and the combination of AoA and AS in the same instrument turns out to be really useful, I don't know. What I think I may safely say now is that the LRI is not a pure AoA instrument and people using it to guage their AoA are not necessarily getting the information that they think they are getting. How far it is in error, I don't know. It may be that the errors are not significant enough to matter. The errors may matter very much. I simply don't know and I would like to find out. It would be really easy to get better information if someone with a LRI would go out and do some tests. I would like to know how the LRI indicates margin above stall at higher G loadings (accelerated stall). Start by finding the airspeed that corresponds to the top of the red on the LRI and identify what percentage above stall speed the top of the red represents. Now lets repeat the test at 2 Gs (60 degree bank level turn) and 3 Gs (70 degree bank level turn). If the margin above stall remains the same or if the amount above stall speed remains the same then it is clear that the LRI is useful at higher G loading. My suspicion is that the stall margin indicated by the LRI will be greater than the actual stall margin remaining. Even if there are errors in the LRI, if people who own them know what the errors are they can mentally compensate thus making the LRI more useful. If I owned an LRI I would certainly be doing this kind of test so that I could fully understand my instrument. So I apologize to everyone for taking up too much bandwidth here. I have gotten a little carried away. Hopefully someone will perform the tests I suggested above and then send the information to me so I will know. In any case I will shut up now because, without experimental information, anything more would be just beating a dead horse. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax ________________________________________________________________________________
Date: Oct 12, 1999
> >> >>If you are really looking for absolute min distance the only way to get it >>is to do a mock-up panel using the real instruments. There is definitely >>some variation between different "standard" sized instruments. >> >>I crammed a lot of instruments close together, and used a piece of scrap >>.032 AL to make a mock-up before cutting the real thing, and am glad I did. >>Masonite or thin plywood can also be used. I used my calipers to measure each instrument separately and then created a template for each instrument in my CAD program. This works well also and prevents nasty surprises. Of course this presumes you already have the instrument in hand to measure. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Copperstate time-to-climb attempt
Hey, Paul or other Copperstate attendees. I'd like to hear how Bruce Bohannon and the Flyin' Tiger did on their 6000m record attempt. I live near his home base and hang out there a lot turning screwdrivers when needed and bumming rides in his RV-4. He had the Tiger running really well before he left Texas and felt good about the attempt. I hope it went well. Troy Black -8 VS ________________________________________________________________________________
Subject: Bolder Tech Batteries was "LIVING with aircraft batteries"
Date: Oct 12, 1999
Bob, I looked through my files and found Bolders information on the TMF Rebel batteries. I just emailed them to see if they still sell them. Their 12 volt, 1 amp, 6 cell battery puts out 150 cold peak starting amps and >1200 peak short circuit current amps and weighs 1.6 lbs. The 12 cell has twice the output and weighs 2.9 lbs. These would be great if they still make them and the have a reasonable price and longevity. Would you use two in series or just have one? Ross Mickey ----- Original Message ----- From: Robert L. Nuckolls, III <nuckolls(at)aeroelectric.com> > Hmmm . . . they've rearranged their website again. Try this: > > http://199.239.60.165/tech/tmf.asp > > This points to the description of the individual cells . . . > > >How > >would you propose using this in the architecture you describe above? Also, > >would you have zero battery backup for electric instruments because of the > >dual alternators? > > you betcha! no need to carry lots of lead around if you have > two engine driven power sources. ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: Painting Info
Yes indeed, Norman, these are good points. I failed to mention that I used solid colors in my paint scheme. However, I wonder if the truly novice painter has any business using metallic paints. A local RV'er used metallic single stage paint and it was very difficult to keep the metallic application uniform. He did sand some orange peel out of his finish and it sanded and buffed well (PPG Concept, a most forgiving paint). Sam Buchanan ---------------- Norman Hunger wrote: > > > > However, I soon discovered that it really didn't matter because there is > > something available to every painter that will take care of dust > > specks..............1500 grit sand paper. > > > > > There are almost no paint flaws that can't be sanded out with 1500 paper > > and buffing compound. If you use a single stage paint, then get the > > paint on the best you can and resolve to perfect the finish after the > > fact. > > CAUTION - Most single stage metallic paints cannot be sanded at all without > exposing the metallic flakes as little silver spots. Looks terrible. If you > must have a metallic, basecoat clearcoat is easier to apply. You can wetsand > the clearcoat for a perfect finish. There are differences between the many > different brands of paints though. > > The original post refers to solid colors and is very good information on > that topic. Check out his webpage to see the fine paintjob he now has. > > Single stage metallic paints require good booths. Wet down the walls and > floor just before pushing in your project. Never wet down the roof, just > blow it off with high pressure air before the wetdown. Paint the wings one > at a time. Build racks for them with wheels on the bottom. > > The new HVLP sprayers do much nicer work because they have a much higher > percentage of the paint applying to the surface than the old styles of spray > guns. It is the overspray that is the dust problem. The old guns make tons > of it. HVLP sprayers use less paint as a result. They are more efficient. > You will not need as much paint. If you invest in a good name brand system > you should be able to sell it when you are done for at least half of what > you paid for it. > > Norman Hunger > RV6A Delta,BC > ________________________________________________________________________________
Date: Oct 12, 1999
> Rob, > would you please post the report number and the location to access the > report. Please post this information, if you will, here on the list for > all those who might have an interest to read the report for themselves. Jim, Here's what I found: http://www.ntsb.gov/aviation/lax/93a170.htm Of course, the LRI may have been incorrectly adjusted and/or faulty at the time of the incident. Rob Acker (RV-6Q, FWF stuff). ________________________________________________________________________________
Date: Oct 12, 1999
Anyone else having had problems with this product? (Andair Pneumatic Tailwheel) I got about a half dozen landings out of mine before it went flat. It sure is a nice tailwheel but if I have to carry my old tailwheel for insurance, I'll bolt it back on the tail of the plane and leave the pretty Andair wheel in the hangar. Here's hoping they come up with a better tube. Steve Hamer RV-4 Bought it, didn't build it RV-6 Left wing almost done ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: LRI and AoA (long)
Now this is the Brian Lloyed I thought I knew and admired. Brian I completely agree with you and your questions are well put and I hope to find a way to get as many of them as possible answered. Thank you. You have not let me down. AL > >> >>Well Larry, since you mentioned me by name I guess I'll comment on your >>post. I think your post is very reasoned and well stated. I think what Jim >>was refering to (and I'm not trying to speak for Jim here) is that his >>private E-mails were posted to the RV-List with comments without even the >>courtesy of a heads-up. I don't blame him for those "feelings". Frankly I >>was surprised at Brian because I didn't think he would do something like >>that. > >It was a mistake. I had taken myself off the RV-list temporarily and >thought that the message had come to me and been posted to the RV-list so I >replied accordingly. > >>I have a lot of respect for Brian, but the tone of his posts just >>seemed accusatory to me. Maybe it's just the way I'm reading it. > >Not accusatory but certainly frustrated. I have people asking me how the >LRI works and is it a valid source of AoA information? I want to >understand it so I can give reasonable answers. All I can do is look at >the instrument, look at the patent (look up US patent number 4559822 at >http://www.patents.ibm.com), and try to divine the information myself. The >patent is very illuminating and creates more questions in my mind. > >>But >>beyond that, I don't blame Jim for his defense because of the last time >>this got dragged accross the RV -List about a year ago. It's all in the >>archives and people were getting pretty outspoken about their distaste for >>further discussion in this forum. For Brian to bring it up in such a >>context without giving Jim the courtesy of some private dialog puts Jim at >>a distinct disadvantage in the discussion because as soon as he >>participates he is, in some listers views, misuseing the RV-List. He's >>darned if he does and darned if he doesn't. > >I was under the impression that people wanted this information. I got the >feeling that there were a lot of people considering some sort of AoA >device, the two most prominent being the LRI and the PSS AoA from Jim >Frantz. I thought that, since the discussion originated here (my mistake >-- it had originated on another list the and reply from Jim was a private >one forwarded to me privately), my response should go back here. It just >goes to show that even someone who has taught others to look carefully at >the headers before posting, can make a mistake. > >>My interest in this is that I >>have run several RV-List special price sales on the instrument. I e-mailed >>Jim over a year ago and asked him if he could give us a special quantity >>buy for RV-List members and he graciously agreed to do that. Since that >>time I have run that special twice and haven't heard any complaints from >>anyone who has participated. In fact I know one is flying and CB told me he >>likes it but is getting more experience with it and learning what it will >>do. I have since met Bill and Jim at Oshkosh and believe them to be >>honorable men. For one thing, their instrument has a life time guarantee. >>Something goes bad and they will make it right. No questions asked. > >This certainly sounds like good business practice and good support for >their customers. > >>I realize that this still hasn't answered your question about just how does >>it work. Well I have an idea but it's one that I have formed myself through >>reasoning things out in my own mind. AS FAR AS I AM CONCERNED,the fact is, >>it does work. In all the feedback I have from people who have flown with >>it, they say it works. Maybe Jim can give us more sources of information. I >>don't know. And frankly I don't even care. What I care about is what people >>who are using the device have to say about it's usefullness and accuracy. > >Ahh, now you get to my major concern -- accuracy. Is the LRI an accurate >portrayal of angle of attack? Will it keep you out of trouble? The more I >look at it the more it appears that it is NOT an angle of attack indicator. > From what I have been able to determine, it is only correct at one angle >of attack, the AoA which corresponds to the zero indication on the >instrument. If it is calibrated at the critical angle of attack (stall) >then it will reliably indicate critical AoA and only that one AoA. If you >use it to indicate how far you are from critical AoA the faster you are >going and the more your airplane is loaded (pulling Gs), the more it will >indicate you are "safe" when in fact you are actually quite close to stall. > Unlike true angle of attack instruments, airspeed has a significant effect >on the LRI indication over and above the actual AoA. In fact, the LRI >displays a combination of airspeed and AoA in one guage. If you are going >fast and pulling hard, you just might hit an accelerated stall before the >LRI has a chance to tell you that you are near the edge. > >>When Rob Acker points us to that NTSB report to back up his claim, maybe I >>can read something negative about the LRI. Until that happens I haven't >>heard or seen anything negative about the instrument. What I have seen is >>some people call it everything, including usefull, but I still come away >>thinking that they still believe there is something wrong with it because >>they don't understand it. Sometimes simplicity can be confusing. > >And sometimes too much simplicity can make something less than useful. The >LRI has red and green areas on the instrument, apparently there to indicate >safe and unsafe operating range. If you are flying in a narrow range of >airspeed, such as during landing approach, this is probably valid. If you >have the airplane loaded up and pulling Gs, the LRI indications are >magnified such that the needle might be in the green range when in fact it >would be in the red range if the aircraft were on a 1G approach to the >airport. > >Now this is not in and of itself a bad thing IF THE PILOT KNOWS THIS IS >HAPPENING! I suspected that this is the case but I didn't know for sure so >I asked Jim the questions. The LRI will definitely tell you is if you are >approaching a stall if: > >1. it was calibrated to indicate zero right at stall; >2. the airplane is configured exactly the same way it was (gear, flaps, >slats) when it was calibrated. > >Beyond that I am not sure what it will tell you. Maybe it is really useful >and the combination of AoA and AS in the same instrument turns out to be >really useful, I don't know. What I think I may safely say now is that the >LRI is not a pure AoA instrument and people using it to guage their AoA are >not necessarily getting the information that they think they are getting. > >How far it is in error, I don't know. It may be that the errors are not >significant enough to matter. The errors may matter very much. I simply >don't know and I would like to find out. > >It would be really easy to get better information if someone with a LRI >would go out and do some tests. I would like to know how the LRI indicates >margin above stall at higher G loadings (accelerated stall). Start by >finding the airspeed that corresponds to the top of the red on the LRI and >identify what percentage above stall speed the top of the red represents. >Now lets repeat the test at 2 Gs (60 degree bank level turn) and 3 Gs (70 >degree bank level turn). If the margin above stall remains the same or if >the amount above stall speed remains the same then it is clear that the LRI >is useful at higher G loading. My suspicion is that the stall margin >indicated by the LRI will be greater than the actual stall margin remaining. > >Even if there are errors in the LRI, if people who own them know what the >errors are they can mentally compensate thus making the LRI more useful. >If I owned an LRI I would certainly be doing this kind of test so that I >could fully understand my instrument. > >So I apologize to everyone for taking up too much bandwidth here. I have >gotten a little carried away. Hopefully someone will perform the tests I >suggested above and then send the information to me so I will know. In any >case I will shut up now because, without experimental information, anything >more would be just beating a dead horse. > > >Brian Lloyd Lucent Technologies >brian(at)lloyd.com 3461 Robin Lane, Suite 1 >http://www.livingston.com Cameron Park, CA 95682 >+1.530.676.6513 - voice +1.530.676.3442 - fax > > ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: Cowl Attach-Vibration
I know of two RV-6's ; one had the senior vibration enginer & staff from a fortune 100 company come to the airport and did analysis of anything thet moved,spun,rotated,flapped,or moved in any way & added weights to smooth out the airplane----result 160 hrs. latter hinge eye cracks........... the other rv-6 had NOTHING ballanced about it ( as a matter of fact I know he dosen't even ballance his check book !) and a 200 hours nothing cracked....go figure kempthorne(at)earthlink.net on 10/12/99 01:26:27 PM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: Cowl Attach >Larry wrote: >I am baffled as to why I am having so much trouble. Some may be >vibration. Do we have any sources for vibration analysis? For industrial machinery there are vibration signature analyzers. I suspect some RVs have more trouble than others due to the quantity and quality of vibration they are generating. I suppose this would be especially true with modified engines. hal ________________________________________________________________________________
Date: Oct 12, 1999
> > > >Listers: I can't resist asking what is probably a really dumb > >painting question. For you guys who are finished painting, when in the > >building process did you finish paint the interior of the cabin > >(RV-6/6A), before riveting the skins on or after the fuse is out of the I painted the interior after the plane was on gear, all instruments and lines fitted (but removed for painting). Pictures are on my web site. Worked pretty good for me. Took some time to mask off what I didn't want to paint, but worth the effort. Tim ****** Tim Lewis timrv6a(at)iname.com N47TD RV-6A, painting Springfield VA http://home.earthlink.net/~timrv6a http://home.earthlink.net/~timrv6a/jpi.html - No JPI stuff in my airplane ________________________________________________________________________________
Date: Oct 12, 1999
It was mentioned to me Saturday morning at Copperstate that his Nitrous Oxide system malfunctioned and the attempt was aborted. Rob Reece RV-3 SN45 Socorro, NM > Subject: RV-List: Copperstate time-to-climb attempt > > Hey, Paul or other Copperstate attendees. I'd like to hear how Bruce > Bohannon and the Flyin' Tiger did on their 6000m record attempt. ________________________________________________________________________________
Date: Oct 12, 1999
Thanks much Ernst. I went right out and tried your suggestion. The wheel was cemented together but the rap at the parting seam split it. My tube has exactly the failure you described. A small hole about 3/8 inch from the valve stem, right at the edge of the reinforcing gusset. I'll start looking for a replacement tube and let you know what I find. Then - Ernst Totland wrote: I used a knife blade with edge placed at the parting seam to split the wheel. A light tap with a small hammer made the two halves come apart. The parts are not keyed. There is a reinforcement patch where the valve is attached to the tube. The inner tube was torn right at the edge of this patch. Seems like a quality problem to me. Rubber resembles cheap ($3) Chinese bicycle tubes. Tyre seems ok. I have emailed my findings to Andair, but have seen no response. Pity, because it's a beautiful wheel and taxiing is much smoother. 1st - Keith Williams wrote: My problem is that I have not been able to get it to come apart (split). I >have removed the bolts and clamped the tire - trying to pry the wheel apart >with a wooden lever......no luck so far in >opening it up. > >Has anyone had one apart or have any suggestions? Is it keyed in some way, >requiring that part be turned before splitting? Any ideas appreciated. > >Also, any ideas about replacement inner tube sources this side of the >U.K.?. I have a suggestion to try the medical supply places where they use >wheelchair wheels of a similar size.........no TSO, though. ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: AOA/LRI - Brian Lloyd
On 11 Oct 99, at 20:48, Jim Huntington wrote: > Imagine my shock when I read your first post yesterday, Brian, tearing > apart my company and making accusations about me Nonsense. Brian raised technical concerns and asked you for data, and once again you evaded. I've received off-list emails indicating at least one other list member has had similar experiences with you, and numerous others have commented on this behavior on-list. The issues can't be resolved by emotion, Mr Huntington, but they can be resolved by ANSWERS and DATA. I publicly challenge you to answer Brian's questions, and to back up your answers with credible data: 1. What effect do gear and flap deployment have on the accuracy of the LRI? 2. If there is an effect, how great it is and in what direction? 3. Are the LRI indications accurate and consistent at G loadings significantly greater than 1 G? 4. As you get farther away from critical AoA, how does the calibration of the LRI hold up? Question 3 is especially important, as it has a direct bearing on safety. As Peter Bennett pointed out a year ago (see attached email text from the RV list), it appears that at heavy G loading and/or weight, the LRI will indicate that you have more "lift reserve" than you really have. That would be dangerous. We need DATA to understand the limitations of the LRI, and the risks inherent in using the LRI. Data means credible flight test numbers showing LRI indication vs airspeed (and preferably angle of attack) for a variety of flight conditions - stall, Vx, Vy, - at various G loading and A/C gross weight. Do you have data Mr Huntington? Will you supply it for all to see here on the RV-list? Sincerely, Tim Lewis RV-6A Painting (base color done, two stripes to go) On 25 Nov 98, at 22:10, pbennett(at)zip.com.au wrote: > > This is a longish post involving some math. Delete now if you find it > tiresome already. > > > I can understand that the LRI/AOA thread may be getting tiresome to > > some. But to me it is getting more interesting all the time. > > I was going to keep quiet on this but George's comment encourages me to > say why I believe the LRI suffers much the same problems as an ASI and may > lull into a false sense of security those who use it as an AOA. I would > welcome correction by those with more fluid dynamics, aerodynamics and > math ability than me. > > As I understand it, the LRI has two pitot style ports at different > angles to the airstream. It measures differential ram air pressure and > displays it on a gauge. The bottom line is that such a setup will > indicate zero lift margin (ie a stall) at different positions on the > panel indicator depending on aircraft weight. > > For a normal pitot, > Ram air pressure = (d . V*2)/2 > where d = air density > v = airspeed > > If the ports are inclined to the airstream at angles a and b > respectively for ports 1 and 2, then > > Port 1 pressure p1 =( d . (Vcos a)*2)/2 > Port 2 pressure p2 = (d . (Vcos b)*2)/2 > > The differential pressure which is indicated is > > p1 - p2 = (d.V*2((cos a)*2 - (cos b)*2)/2 > > If we consider only the stall condition, this will always happen at the > same angle of attack, regardless of weight. Therfore a and b are > constant at the stall for all aircraft weights, as of course is air > density d. Therefore differential pressure at the stall is a function > of only velocity squared. > > However the velocity at stall is a function of G loading or weight, > whichever you prefer. Therefore the differential pressure at stall is a > function of weight, which means that "zero lift reserve" will shift on > the dial depending on fuel, pax and baggage. > > How significant is the shift? Single pilot stall is typically around 45 > mph, and gross weight stall 55 mph, a 22% increase. Because of the square > law relationship, the indication at stall will increase by 10.5% over > the same weight range. > > If you always dogfight at the same weight, the LRI will do what you > want, but if you then load up the wife and baggage and fly into short > strips, take care. > > Peter > > ****** Tim Lewis timrv6a(at)iname.com N47TD RV-6A, painting Springfield VA http://home.earthlink.net/~timrv6a http://home.earthlink.net/~timrv6a/jpi.html - No JPI stuff in my airplane ________________________________________________________________________________
Subject: Cowl Attach-Vibration
Date: Oct 12, 1999
> > I know of two RV-6's ; one had the senior vibration enginer & > staff from a > fortune 100 company come to the airport and did analysis of > anything thet > moved,spun,rotated,flapped,or moved in any way & added weights > to smooth out the > airplane----result 160 hrs. latter hinge eye cracks........... > the other rv-6 > had NOTHING ballanced about it ( as a matter of fact I know he > dosen't even > ballance his check book !) and a 200 hours nothing cracked....go figure > After hearing about all of the broken hinges, I checked mine very carefully at the last oil change. All of the hinge eyes were intact. I did find two broken rivets on the lower cowl hinge. The innermost rivet (3/32 dia.) on each side of the exhaust was broken through the shank. I drilled out the remnants of the rivets and replaced them with screws and nuts. I installed cowl hinges was shown on the drawings except for behind the spinner where I installed two screws on each side. I have a O-320, 160 hp with a Sensenich metal prop. Nothing was dynamically balanced. Am I lucky, or did I do something right by mistake? Mark Nielsen RV-6, 445 hrs Green Bay, WI ________________________________________________________________________________
Date: Oct 12, 1999
Subject: Re: vertical fin offset
My philosophy on offsetting the rudder goes along with offsetting the engine. It's best to find out what's causing the ball to be off center. Van's intructions says that a slightly off-aligned gear fairing can cause the ball to be off by half a ball and reduce speed by a few knots. Sure, offsetting the rudder may fix the obvious problem but it may cost you a few more knots yet. The question is: is that a big deal to you? If not, why be anal and go ahead with the offset rudder. Sometimes we don't like to fly a barn door eventhough it will fly. RV-6/N985VU > > >In a message dated 10/11/99 9:09:23, kempthorne(at)earthlink.net writes: > > >Stan, > >I know nothing about the need or not for rudder tabs but I do know that >engineering is not best done by "looks wrong" or by being always in >symmetry. Space the bolt holes in a round part in a non-symmetrical >pattern to ensure that the mechanic puts it on correctly for example. > >The tail on straight tail Bonanzas and Debonairs (still for sale) are >offset from the centerline and one flap must be up slightly more than the >other. > >The natural human urge for symmetry is just one more thing engineers need >to get over. > >Hal Kempthorne, PE > >>Technologies SMTPRS 2.0.15) with SMTP id >> for >> >>I am also troubled by the percentage of rudder tabs I have seen. Just my >>opinion, but an offset rudder just looks "WRONG". I am a nut for symmetry, >> > > ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Source for Aluminum for panel
Panel: Lost your message thanks to good old aol dropping off line on me before I could reply. I did get the information so thanks. HCRV6(at)aol.com ________________________________________________________________________________
Date: Oct 13, 1999
Subject: test flying: RV6A
Many thanks to all those who congratulated me on the first flight of LDX Early test flying issues: The heavy left wing completely dissapeared with squeezing the right aileron. I was very gentl and assumed it would need several iterations.... not so. Interestingly the control pressures are distinctly higher after this exercise, not unpleasant but noticeable, especially at high speeds. I was getting annoyed with myself for offsetting the vertical stab: so many people had spoken against it I was convinced I would have a tab even after re-building the tail intersection fairing to make this mod. The aviation gods must be with me because LDX hums along at 160 knots with the ball perfectly centered. For what it is worth the leading edge of the VS is offset 1/4" to the left. The idea came from Dean Hall. The starter motor solonoid is sticky. I mounted it sideways because of discussion about high G forces activating it. I think it is probably better in its design position (straight up and down). This is irritating because I put plate nuts on the firewall to make it easy to get it on and off. I may have to build a bracket to suit the plate nuts. Several people have reported success with de-gaussing the roll bar so I will do this and let the list know how it goes. My electronics international tach is reading engine RPM perfectly but is recording tach time at half the real rate????. A question for customer support I guess. I have a firewall mounted oil cooler (Vans) with 3" scat to the right rear baffle and on a 21 degree (72 F) day I am getting CHTs of 355 (back right) and Oil temps (after 30 minutes at 75% at 1000 feet) of 180 to 185. More to come, Cheers, Leo Davies ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Interior Painting Sequence
Listers: Thanks to all who responded. Guess the right answer is whatever seems right (I may be anal enough to paint before riveting, we'll see). HCRV6(at)aol.com ________________________________________________________________________________
Date: Oct 12, 1999
Subject: fuel tank inboard rib tooling hole
Hi all, Van's manual says not to worry about prosealing the access hole reinforcement ring when riveting it to the rib because it will be sealed when the gasket and cover are installed. I've seen the posts regarding do I or don't I proseal the cork gasket and I intend to use the sealant on both sides of the cork gasket. Will the sealant and gasket be enough to also seal the aft tooling hole on that rib if I don't use sealant when riveting the reinforcement ring to the rib? I've only got about 1/8 inch or so clearance from the tooling hole to the outside edge of the cover plate. I'm considering using sealant on the ring to rib job. Anybody tried that and been able to keep the sealant out of the nutplate threads? Thanks for your input, Chris Hand RV-6A, working on wings ________________________________________________________________________________
Date: Oct 12, 1999
Harry, FWIW I painted mine after finishing the canopy and before installing any systems. Actually I had run the brake lines but these were easy to remove before interior paint. The reason I painted first was that any paint job will come out better if all items that need masking are removed before painting. So I weighed the pro's and con's of installing and removal vs painting and installing. I liked the idea of paint first, then install. The downside is you have to be careful during system installation so as not to scratch/chip your wonderful new paint. I used Dupont Centari which is not known for it chip/scratch resistance. Other paints such as Sherwin William's Sunfire are nearly bomb proof. Also make sure that you are ready for paint. If something is not riveted before painting the unpainted rivet looks real bad and is hard to touch up. Gary Zilik RV-6A - Laying up a new impinge fairing - removed wings today. Pine Junction, CO > > Listers: I can't resist asking what is probably a really dumb painting > question. For you guys who are finished painting, when in the building > process did you finish paint the interior of the cabin (RV-6/6A), before > riveting the skins on or after the fuse is out of the jig? > > Harry Crosby > HCRV6(at)aol.com > > ________________________________________________________________________________
Subject: Starter
Date: Oct 12, 1999
I have a buddy who's not on the list who ran into a problem with his starter. His engine is a new O-360, and came with a Prestolite starter that he swapped out for a SkyTek from Van's. He got this engine around the same time I did so the engines are nearly identical. But mine came with the SkyTek starter. The other day he tried cranking with the starter for the first time and got a horrible grinding noise. He stopped immediately and looked at the ring gear and saw that the teeth, especially on the back side, are kind of chewed up. We compared starter part numbers and they're the same. We also counted the teeth on the ring gear and they're the same. But the evidence is that the starter gear or ring gear on his airplane has a different pitch or something. The only thing we haven't done is to actually measure the teeth on the starter. Anybody have a clue what might be going on here? The only thing I can think of is that the starter somehow got mis-labeled and is actually a different pitch. Randall Henderson, RV-6 N6R (30 hours) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
Subject: Re: test flying: RV6A
Date: Oct 13, 1999
Leo,your temps look pretty good I have a new starter relais (ex van's) which I bought as a spare... You can try it before making any changes to the mountings of it. Don't think the position would make any difference at all (at least not under no additional G-force) Have still a bit of a heavy left wing,your success may encourage me to start fixing this little problem... cheers Karl KARL AHAMER NSW AUSTRALIA ASCOT(at)HINET.NET.AU ________________________________________________________________________________
Subject: Metalic Paint
Date: Oct 13, 1999
Here's a few more points on the recent thread of metallic paints. It is difficult to get an even "look" to finished metallic paint. It will vary with pressure so make sure that your compressor can keep up. More pressure will give a lighter finish. This is more obvious on a dark color. The distance the gun is from the surface will change the finished look as well. The painter must be very disciplined as he/she works along the target. Novice painters should do the wings first while they are held in vertical racks. Practice the movements before applying paint. Decide how wide the strokes will be before spraying paint. The wings are the easiest pieces so do them first to gain experience. I made separate racks for each of my flaps and ailerons so that they could be done by themselves. If your compressor doesn't have a large storage tank it will have to make air to supply the gun. This will cause the air to become warmer as you go along. Now an expensive air dryer becomes critical to a good finish. Not that important if you have 60-80 gallons of storage tank but you still need at least a simple air/water separator. This is even less important if you have an HVLP gun as they use much less air than a standard gun. Many HVLP systems don't connect to your air system but instead have are designed to run off a pump that is part of the system. Solid colors are easier to apply than metallic. Lighter colors are easier to apply than dark colors. White is the easiest color to paint. White hides little flaws like dings, warps, and scratches better than dark colors. When my wings were finished I thought it would be best to paint them right away so that the paint could have a couple of years to really harden up. I built a booth and then decided that I would try practicing on a car first to learn how it is done. I bought exactly the same paint as I was going to use on my RV and went to work. I learnt that I should pay a professional to do my painting for me. Very shortly after I landed a really cool job working with cars. Over the next year I took many lessons from a professional painter on our staff. I learned lots about booths too. Now I am confident that I can paint my fuselage with the tail installed (to get the striping right). I will build a new booth on the side of my garage that will become a carport when I am finished. I know it won't be the show room finish of a professional job but it will be good enough for me. I have been using Sherwin Williams Sunfire. It has a very shiny gloss and appears to be very tough. It is their top single stage paint. Many people have recommended it to me. It is very expensive but with paint that is a good thing. Norman Hunger RV6A Delta, BC, Canada ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Experimental AOA?
I too am convinced that I 'need' some sort of AOA indicator. However, the cost of these things seems a little high ($780 something for the LRI) for an instrument that is only about as complex as an ASI. In fact, I have been wondering if it might be possible to fabricate one out of an ASI. It would be easy to make a probe like the one used by the LRI. The lower port on the probe would be plumbed to the static side of an ASI while the upper port would plumb to the pitot side. As AOA increases pressure in the 'static' side increases relative the upper port and the ASI indication declines. With proper adjusting of the probe it should be possible to reproduce a stalling AOA that is at some positive (and fixed) indication on the ASI. Then simply replace the markings on the ASI to indicate where stall occurs. It should also be possible make a similar set-up with the lower drag ports on an in-wing AOA indicator, only the upper/lower -- pitot/static orientation would be reversed. I would be glad to test my theories, but my plane wont be flying for several years... Any thoughts? Dave Leonard 6QB >>>>>I also have been convinced that AoA is a valuable instrument to have and Im going to get one. When asked, LRI produced testimonials from unbiased third parties attesting to the quality and usefulness of the instrument.<<<< ________________________________________________________________________________
Date: Oct 13, 1999
Uh oh. I cant believe that Im doing this, but I think I can point out the flaw in your thinking. Please keep in mind that I have no experience, credentials, or for that matter a connection to the LRI... but > How significant is the shift? Single pilot stall is typically around 45 > mph, and gross weight stall 55 mph, a 22% increase. Because of the square > law relationship, the indication at stall will increase by 10.5% over > the same weight range. Well, we know that your argument is flawed somewhat because so many pilots will testify that the LRI is at least very close. It may have an error, but testimony shows that it is no where near 10.5% for reasonable weight shifts. > Port 1 pressure p1 =( d . (Vcos a)*2)/2 > Port 2 pressure p2 = (d . (Vcos b)*2)/2 > > The differential pressure which is indicated is > > p1 - p2 = (d.V*2((cos a)*2 - (cos b)*2)/2 > > If we consider only the stall condition, this will always happen at the > same angle of attack, regardless of weight. Therfore a and b are > constant at the stall for all aircraft weights, as of course is air Ok, but lets suppose that we calibrate our LRI so that stall occurs when p1 is the same as p2. Then we get: d(VCos a) 2 /2 = d(VCos b) 2 /2 and everything nicely drops out except: Cos a = Cos b and the LRI at our calibrated stall is independent of V, d, weitght etc... because of the angled faces of the probe, a and b are moving in different directions with increasing AOA so it will always be able to be so colibrated. You do seem to be correct with regard to dependance on airspeed at any AOA other than stall may change the indicated 'closeness to stall'. But what exactly do we mean by "closeness to stall?" Is it a percent of airspeed away from stall? At markedly higher airspeeds this has a different meaning for me than at low airspeeds. At a high airspeed "close to stall" seems to mean 'dont pull much harder' while at low airspeeds it means - 'lookout, you really are very close to stalling!' I suspect that the LRI is very effective and reliable. I suspect that this deviation with airspeed would be intuitive. It would be nice to know the numbers though. Best Regards Dave Leonard 6QB ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Re: Source for Aluminum for panel
For aluminum, try Volgoson at Dillsburg Aero in Dillsburg PA. Nice folks and they have lots of parts and material. Dillsburg Aero (717) 432-4589 david faile, fairfield, ct mcfii/a&p faa aviation safety counselor eaa technical counselor/flight advisor christen eagle ii since '82 (n13bf) rv6 (n44df) started ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <stuckle(at)ifc.utc.com>
Date: Oct 13, 1999
Listers, I now have 1425 hrs on my RV and still have the original hinges. Only three eyelets have broken out in that time frame. The rest are getting rather worn out, and I am now considering replacing them with CamLocks.... By the way, use of a lot of grease helps cut down on the wear..... Fred Stucklen N925RV RV-6A E. Windsor, Ct ____ From: pcondon(at)csc.com Subject: Re: RV-List: Cowl Attach-Vibration I know of two RV-6's ; one had the senior vibration enginer & staff from a fortune 100 company come to the airport and did analysis of anything thet moved,spun,rotated,flapped,or moved in any way & added weights to smooth out the airplane----result 160 hrs. latter hinge eye cracks........... the other rv-6 had NOTHING ballanced about it ( as a matter of fact I know he dosen't even ballance his check book !) and a 200 hours nothing cracked....go figure kempthorne(at)earthlink.net on 10/12/99 01:26:27 PM ________________________________________________________________________________
(Content Technologies SMTPRS 2.0.15) with SMTP id for" ; Wed, 13 Oct 1999 08:32:44.-0400(at)matronics.com
Date: Oct 13, 1999
Subject: Re: Metalic Paint
"Norman Hunger" on 10/13/99 04:26:42 AM Please respond to rv-list(at)matronics.com Subject: RV-List: Metalic Paint Hey Norman, what is Sunfire (Poly, Enamel)? I have always been a PPG guy but the Sherwin Williams guys really impressed me at Sun N Fun.I didn't get anything on Sunfire. Great info material available on Acry-Glo and Jet-Glow. If any of you are new to the paint world it would be beneficial to call SW and get an info packet on Jet-Glow. Takes you step by step through the paint process. I learned from PPG by screwing it up, stripping it and doing it again. >>>I have been using Sherwin Williams Sunfire. It has a very shiny gloss and appears to be very tough. It is their top single stage paint. Many people have recommended it to me. It is very expensive but with paint that is a good thing. Norman Hunger RV6A Delta, BC, Canada ________________________________________________________________________________
Subject: proseal and wax
Date: Oct 13, 1999
A tech counselor visited recently and when I asked his advice about sealing the tank access plate, he suggested something I've never heard of, but he said he's known people for whom it has worked. He suggested putting wax on the the access plate and the rib, and then using proseal with no gasket. He says that the wax keeps the proseal from gluing the access plate on permanently. I'd be interested to know if anyone has tried this and what the results were. Adrian Chick Nashville, TN RV-6A second wing ________________________________________________________________________________
(Content Technologies SMTPRS 2.0.15) with SMTP id for" ; Wed, 13 Oct 1999 08:51:48.-0400(at)matronics.com
Date: Oct 13, 1999
Sam Buchanan on 10/12/99 08:00:55 PM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: Painting Info Sounds like mottling (dark color stripes in the spray pattern near the center of the pattern). Not enough pressure or too cold a temp. for the paint reducer. I fought a hell of a battle with this with PPG Delstar (Acry Enamel). Finally found that if you choke down your guns needle somewhere between a fog/tack coat and a light coat and drop your normal pattern to only 1/3 your normal pass, you can eliminate this problem. Takes some trial and error. Helps to hold a strong light with your other hand so you can see the moment the paint flows, since it takes a few passes for this to happen. I don't know why, but this leave no orange peel. I thought it was a neat trick that might help someone out in the future. Eric Henson Installing Tail Wheel Mount However, I wonder if the truly novice painter has any business using metallic paints. A local RV'er used metallic single stage paint and it was very difficult to keep the metallic application uniform. Sam Buchanan ---------------- Norman Hunger wrote: > > > > However, I soon discovered that it really didn't matter because there is > > something available to every painter that will take care of dust > > specks..............1500 grit sand paper. > > > > > There are almost no paint flaws that can't be sanded out with 1500 paper > > and buffing compound. If you use a single stage paint, then get the > > paint on the best you can and resolve to perfect the finish after the > > fact. > > CAUTION - Most single stage metallic paints cannot be sanded at all without > exposing the metallic flakes as little silver spots. Looks terrible. If you > must have a metallic, basecoat clearcoat is easier to apply. You can wetsand > the clearcoat for a perfect finish. There are differences between the many > different brands of paints though. > > The original post refers to solid colors and is very good information on > that topic. Check out his webpage to see the fine paintjob he now has. > > Single stage metallic paints require good booths. Wet down the walls and > floor just before pushing in your project. Never wet down the roof, just > blow it off with high pressure air before the wetdown. Paint the wings one > at a time. Build racks for them with wheels on the bottom. > > The new HVLP sprayers do much nicer work because they have a much higher > percentage of the paint applying to the surface than the old styles of spray > guns. It is the overspray that is the dust problem. The old guns make tons > of it. HVLP sprayers use less paint as a result. They are more efficient. > You will not need as much paint. If you invest in a good name brand system > you should be able to sell it when you are done for at least half of what > you paid for it. > > Norman Hunger > RV6A Delta,BC > ________________________________________________________________________________
Date: Oct 13, 1999
Subject: LRI NTSB Report
Thanks Rob for bringing this to my attention. I am enclosing the entire text for anyone who is interested to read and to make their own determination of the cause for this aircraft's premature rotation. I do not read this report as an indictment of the LRI. It appears that either the instrument was out of calibration, not checked as part of pre-flight, or something of the kind. The comment about the pilot's "overconfidence in his piloting skills" indicates a problem judgement and probably proceedures. Jim NTSB Identification: LAX93LA170 For details, refer to NTSB microfiche number 48340A Accident occurred APR-11-93 at TORRANCE, CA Aircraft: CESSNA 182G, registration: N460JA Injuries: 1 Minor, 1 Uninjured. THE PILOT STATED THAT DURING THE TAKEOFF ROLL HE GLANCED AT THE LIFT RESERVE INDICATOR WHICH INDICATED THAT HE HAD ENOUGH LIFT TO FLY. THE AIRPLANE IS MODIFIED WITH A WREN 460 STOL KIT. THE AIRSPEED OF THE AIRPLANE WAS APPROXIMATELY 35-40 KNOTS. SHORTLY AFTER TAKEOFF, THE AIRPLANE BEGAN A LEFT ROLLING MOTION. THE AIRPLANE DID NOT RESPOND TO ANY CORRECTIVE ACTION INITIATED BY THE PILOT. THE AIRPLANE STRUCK THE GROUND, LEFT WING TIP FIRST AND CAME TO REST BETWEEN THE TWO RUNWAYS. IN AN INTERVIEW WITH FAA INSPECTORS, THE PILOT STATED THAT THE "STALL WARNING HORN WAS GOING OFF AS USUAL," BUT HE CHOSE TO "IGNORE IT AS USUAL." ACCORDING TO THE WREN OPERATIONS MANUAL FOR THE AIRCRAFT, THE NORMAL TAKEOFF SPEED IS 60 MPH, AND A CLIMB SPEED OF 90 MPH. Probable Cause FAILURE OF THE PILOT TO ATTAIN SUFFICIENT LIFT OFF AIRSPEED. FACTORS IN THIS ACCIDENT WERE THE PILOT'S OVERCONFIDENCE IN HIS PILOTING SKILLS, AND THE INADVERTENT STALL OF THE AIRPLANE. Index for Apr 1993 | Index of Months ________________________________________________________________________________
Date: Oct 13, 1999
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: Re: Starter
> >I have a buddy who's not on the list who ran into a problem with his >starter. His engine is a new O-360, and came with a Prestolite starter that >he swapped out for a SkyTek from Van's. He got this engine around the same >time I did so the engines are nearly identical. But mine came with the >SkyTek starter. > >The other day he tried cranking with the starter for the first time and got >a horrible grinding noise. He stopped immediately and looked at the ring >gear and saw that the teeth, especially on the back side, are kind of chewed >up. > >We compared starter part numbers and they're the same. We also counted the >teeth on the ring gear and they're the same. But the evidence is that the >starter gear or ring gear on his airplane has a different pitch or >something. The only thing we haven't done is to actually measure the teeth >on the starter. > >Anybody have a clue what might be going on here? The only thing I can think >of is that the starter somehow got mis-labeled and is actually a different >pitch. > >Randall Henderson, RV-6 N6R (30 hours) >Portland, OR >http://www.edt.com/homewing Sounds like you have the pinion gear designed to mate with a 122 tooth ring gear. It's a tad larger in diameter than the pinion for the 149 tooth gear. Being larger, it wouldn't engage and turn the engine, just chew up the back side of the ring gear. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Independence Kansas: the > < Jurassic Park of aviation. > < Your source for brand new > < 40 year old airplanes. > ================================ http://www.aeroelectric.com ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Re: Bolder Tech Batteries was "LIVING with aircraft
batteries" > >Bob, >I looked through my files and found Bolders information on the TMF Rebel >batteries. I just emailed them to see if they still sell them. Their 12 >volt, 1 amp, 6 cell battery puts out 150 cold peak starting amps and >1200 >peak short circuit current amps and weighs 1.6 lbs. The 12 cell has twice >the output and weighs 2.9 lbs. These would be great if they still make them >and the have a reasonable price and longevity. Would you use two in series >or just have one? I'd use one of the 12-cell batteries. Let me know what you find out from them. Which second alternator are you considering? Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Independence Kansas: the > < Jurassic Park of aviation. > < Your source for brand new > < 40 year old airplanes. > ================================ http://www.aeroelectric.com ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Re: Instrument Panel Weight (Was lighting)
> >Where do you get all of your data, Bob? That is great stuff...glad to have >you on the list! From my physics book. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Independence Kansas: the > < Jurassic Park of aviation. > < Your source for brand new > < 40 year old airplanes. > ================================ http://www.aeroelectric.com ________________________________________________________________________________
Date: Oct 13, 1999
With all this talk about offsetting the VS to prevent an unsightly trim tab on the rudder, has anyone attempted to solve an out of rig condition by changing the alignment of the gear leg fairing? The biggest benefit of this is that one could wait until after the airplane is flying and experiment to determine how much offset is needed. FWIW, I got lucky with my -6A. No tab was needed on the rudder and the VS is centered. I would have been quite ticked off if I had offset the VS and then needed a rudder trim tab to bring the ball back into center. Scott Gesele N506RV - Flying ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Re: fuel tank inboard rib tooling hole
Chris, I ended up sealing the ring to the rib and used sealed nutplates instead of the ones van's provided. To keep the pro-seal out of the nutplate treads I cut q-tips in half and screwed the cotton end into the nutplate before installing them. Not only did that keep the stuff out of the threads but when you pull the q-tips out after prosealing it cleans the hole out. Greg Puckett Elizabeth, CO RV-8 80081 chriskelhand(at)juno.com wrote: > > > Will the sealant and gasket be enough to also seal the aft tooling hole > on that rib if I don't use sealant when riveting the reinforcement ring > to the rib? I've only got about 1/8 inch or so clearance from the > tooling hole to the outside edge of the cover plate. > I'm considering using sealant on the ring to rib job. Anybody tried that > and been able to keep the sealant out of the nutplate threads? > > Thanks for your input, > Chris Hand > RV-6A, working on wings > > ________________________________________________________________________________
Date: Oct 13, 1999
In a message dated 10/12/99 10:10:39 PM Pacific Daylight Time, leo(at)icn.usyd.edu.au writes: << The starter motor solenoid is sticky. I mounted it sideways because of discussion about high G forces activating it. I think it is probably better in its design position (straight up and down). This is irritating because I put plate nuts on the firewall to make it easy to get it on and off. I may have to build a bracket to suit the plate nuts. >> Are you sure you are not just experiencing PM starter run-on? This was discussed in the RVator a few issues back and Bob Nuckolls has a fix on his site. -GV ________________________________________________________________________________
Subject: Hobby Air Respirator
Date: Oct 13, 1999
Brand new Hobby Air Respirator in box never used. Paint 2 part paint and not worry about the bad stuff. $300 Howard Kidwell dobes(at)prodigy.net 512-288-0518 ________________________________________________________________________________
Subject: Re: proseal and wax
Date: Oct 13, 1999
Hi Adrian: My solution was to make sure the area was good and clean then install the cover as per Van's instructions with the cork gasket dry. Then put a small bead of proseal around the edge of the cover making sure that I had complete coverage between the cover and the rib and also a small bead around each screw. Had to remove the cover a couple of years later to service the fuel guage and it was easy to scrape and remove the proseal around the cover. The gasket was undamaged and could have been used over again. The screws can just be turned out breaking the proseal and cleaned up before reinstalling. The covers have been on for eight years now without a leak. On the tooling hole if my memory serves me right I put a small patch over it trimmed so as not to interfere with the cover and then prosealed it at the same time as I put the covers on. Eustace Bowhay ---------- > From: Adrian Chick <adrianchick(at)home.com> > To: rv-list(at)matronics.com > Subject: RV-List: proseal and wax > Date: Wednesday, October 13, 1999 5:54 AM > > > A tech counselor visited recently and when I asked his advice about sealing > the tank access plate, he suggested something I've never heard of, but he > said he's known people for whom it has worked. He suggested putting wax on > the the access plate and the rib, and then using proseal with no gasket. He > says that the wax keeps the proseal from gluing the access plate on > permanently. I'd be interested to know if anyone has tried this and what > the results were. > > Adrian Chick > Nashville, TN > RV-6A second wing > > > > > > > ________________________________________________________________________________
Date: Oct 13, 1999
scott gesele wrote: > > > With all this talk about offsetting the VS to prevent an unsightly trim tab on > the rudder, has anyone attempted to solve an out of rig condition by changing > the alignment of the gear leg fairing? The biggest benefit of this is that > one could wait until after the airplane is flying and experiment to determine > how much offset is needed. Scott, You have just exposed me and my dirty little secret. I needed a trim tab on the rudder until I changed to Tracy Saylor's gear leg fairings just before painting my RV-6. I played around with the alignment until the need for a tab disappeared. I built new cuffs and the misalignment is very difficult to detect. There has been little impact on speed. In fact I am slightly faster than another RV-6 with same engine and prop, the only difference being my wheel pants (Van's pressure recovery) and the already mentioned gearleg fairings. The speed came up slightly after painting and I adjusted the trim with a slightly shorter spring on the right rudder pedal. I have return springs on both. My VS is mounted as per plans. Terry Jantzi RV-6 C-GZRV Kitchener, Ontario -- http://www.netrover.com/~tjantzi/terry/ ________________________________________________________________________________
Date: Oct 13, 1999
Subject: LRI/PSS - Brian Lloyd
Brian and Listers, I very much appreciate the questions - not so much the accusations and such - but certainly the questions. If I appear defensive, it is in part a reaction to being attacked but also a hesitation to saying anything less than completely accurate. I want to state that is my intention to respond in the best way that I am able to most if not all questions which have been raised concerning the LRI, but it will take some time. This is in part due to the fact that our technical material is currently tied up in the STC process. It is also in part due to the fact that I am not an engineer, and I want to make certain that whatever information that I put out here is as accurate as possible. That being said, I must admit certain questions arise for me concerning PSS and the discussions over the past few days. Why are they not being called to answer these same questions and others that might arise? What testing has been performed by what institutions and disinterested parties on that system. I have raised certain questions concerning the PSS system that have been dismissed more or less out of hand. Where is the science in that? Is PSS a pure AOA system? Not as I understand it. It is a presure differential system (much like the LRI, but getting its inputs from the wing surfaces rather than a probe) and transducing those inputs to a display. A pure AOA system, again as I understand it, is a vane system that indicates an aircraft's position to the relative wind, as can be seen on commercial aircraft - hard to accomplish on single engine propeller driven aircraft. Brian, it is not possible for me to answer all of your questions all at once, but here are a few comments: 1) The LRI is not a pure angle of attack indicator. 2) The LRI does NOT calibrate, as the PSS system does, at the critical angle of attack. It calibrates at ZERO LIFT RESERVE. Zero Lift Reserve can described in various ways - the point of minimum controlable airspeed; that point where if the angle of attack is increased the aircraft will drop or if the airspeed is decrease the aircraft will drop; that point where all available lift being generated by the airfoil is being used to sustain level flight - no excess lift being generated. Another way of describing this is, if one is familiar with the curve for lift as it proceeds upward and then curves over to the stall break - zero lift reserve is at the top of the curve. That point, as I understand it, is Vx, also minimum sink and absolute ceiling, and the point past which the aircraft falls behind the power curve. So, in effect, the LRI allows a pilot to see where 'behind the power curve' is for his aircraft for existing weight and conditions. I will respond further responding to your concerns about errors in LRI indications, but not in this post. This is a matter of time, space, consideration to others on this list and desire to get everything as accurate as possible for you. Two further items, Brian: - My partner, Bill Geipel, is very willing to take you up with the LRI in his aircraft - unfortunately in Wisconson, not California - for you to explore the entire range of the instrument. 1 (888) 310-4574. - Did I understand you to say that your aircraft were used as the test platforms for the PSS system, and therefore, you have a hand in the development of that system? I will do my best to work my way through the full range of your questions and concerns. Allow a bit of time for this, but please continue with your questions and concerns. Jim Huntington jimrhunt(at)wco.com ________________________________________________________________________________
Date: Oct 13, 1999
---------- > From: Robert L. Nuckolls, III <nuckolls(at)aeroelectric.com> > To: rv-list(at)matronics.com > Subject: Re: RV-List: Starter > Date: Wednesday, October 13, 1999 7:33 AM > > > > > >I have a buddy who's not on the list who ran into a problem with his Occasionally these starters need to be shimmed out and shims are available but this happens very rarely. My guess is that the problem is one of the items already mentioned. Eustace Bowhay ________________________________________________________________________________
Date: Oct 13, 1999
Subject: LRI - user reports (lengthy)
Listers, Among other things that have arisen over the past few days, there have been requests for reports from pilots flying with the LRI. I am enclosing three such reports. If there is a request for more material such as the ones below, others can be posted as well. I have refrained from posting this kind of material because it did not seem altogether appropriate to this list, but here goes: The Lift Reserve Indicator By Howard J. Fried Not long ago I wrote a column for Avweb in which I pointed out that air carrier aircraft, corporate jets, and military aircraft all have Angle of Attack Indicators, and I forcefully stated that all aircraft, particularly General Aviation light planes should also have them. When that column appeared on Avweb I was contacted by one of the partners who produce the LRI or Lift Reserve Indicator. He informed me that their product was an angle of attack indicator, but not only that but much more and I was invited to try a LRI and report on its effectiveness. After having the unit installed and calibrated I went out yesterday to check out its performance and see if it does everything the manufacturer claims. I would say that it does more than claimed, but that's impossible because the claims indicate that it does so much. It does, however, do everything it is supposed to do, and it does it very well. It is extremely user friendly, a necessity for a dummy like me. No fancy interpretation required, one just glances at the indicator and learns whatever he is seeking to know about the flight situation of his flyin' machine. As for what it does, the name says it all. It tells you just how much lift is being generated by the attitude and power of one's aircraft at any given moment, and by that I mean to say that its response is immediate. The LRI differs from the ordinary angle of attack indicator in that it becomes effective as soon as the take-off roll is started. Thus it provides precise information as to when the pilot should lift off for the best angle of climb. Therefore, by using an LRI for your source of information, you can get into the very tightest field your aircraft is capable of (and get out as well). I have repeatedly pointed out that the objective in landing an airplane is to be going just as slowly as you possibly can at the moment of touchdown. Well, the LRI enables you to do just that safely with complete confidence. A glance at the LRI lets the pilot know exactly where he stands with respect to the critical (stall) angle of attack. Thus, he can safely operate in the very slowest of slow flight regimes. The critical angle is a fixed number of degrees, and it never changes. However, that specific number is reached at a variety of airspeeds depending on a number of external conditions, including weight, center of gravity location, gustiness, flap position, landing gear position, and others. The Lift Reserve Indicator is unaffected by these conditions Whereas the airspeed indicator has a built-in lag in its response, the response of the LRI is instantaneous. In my column on Avweb, I pointed out that an angle of attack indicator is cheap. An ordinary angle of attack indicator is a rather primitive instrument, and operates much like the stall warning device on our airplanes. The stall warning device consists of a vane protruding forward into the relative wind, aligned with the longitudinal axis of the airplane. As the airplane pitches up, or banks, this vane moves upward until it finally causes a contact, closing an electric circuit and sounding a buzzer or flashing a light, advising the pilot that a stall is imminent. Somewhat more sophisticated is the conventional angle of attack indicator, but it works on the same principle, the difference being that the angle of attack indicator powers an instrument, which gives the pilot a read-out telling him just where he stands with respect to the critical angle of attack. Unlike these devices which are electric-mechanical, the Lift Reserve Indicator gets its information from the pneumatic differential between two sources of air, the relative wind and still, undisturbed air. The only electricity it uses is on the model that has a heated probe. Therefore, it comes alive as soon as the take-off roll starts and it keeps giving useful information as long as the aircraft is in motion. It tells the pilot just how much lift is being generated at any given time, and more importantly, just how much lift he has in the bank (the amount of his lift reserve). When it gets to the point of zero lift reserve, the aircraft will no longer be able to maintain altitude. We all know that what keeps us up there in the sky is the excess of lift over gravity. When we have either slowed down thus increasing the angle of attack or increased the angle of attack with pitch to the point of zero lift, the airplane will sink, perhaps imperceptibly, but increase the angle of attack a bit more, and a stall will result. The LRI informs the pilot at exactly what point he has "zero lift reserve." And it works under all conditions of weight, center of gravity, flap position, density of the air, angle of bank, and turbulence. Thus in wind shear conditions it instantaneously advises the pilot of loss of lift and the immanence of a stall condition and, most important, it tells the pilot what he must do to recover. An aircraft owner's investment in this life-saving device is $750.00, and the heated probe model is $100.00 more. Installation time is something in excess of four hours, plus approximately a half-hour flight for calibration. The LRI is manufactured by the Lift Reserve Indicator Company, Box 643 Occidental, CA 95465 and it can be ordered by phone, 1 888 310 4574. Or by E-mail:jimrhunt(at)wco.com. Or through their web site: www.liftreserve.com. I intend to equip my entire school fleet with them, and I urge every aircraft owner to do likewise, or at the very least have some sort of angle of attack indicator installed on his airplane. ************************************************************************ Date: Tue, 10 Aug 1999 15:55:11 EDT Subject: Received and had instrument installed Dear Mr. Huntington, We had met at the Oshkosh convention and I had handed you my old LRI gauge which had faithfully served in my plane for almost 17 years. On the spot you had promised that you would send me a replacement instrument. I was happy to receive it three days later and had it meanwhile installed.(I did not use the metal bracket which came with the unit due to the location of the instrument within 6 inches of the compass, on the top of the glare shield). To my opinion, the new instrument appears of nicer quality than the old one. Regardless of looks, though, it felt good to have the device up and working again. My Cherokee 140 is a notoriously slow climber and the LRI helps to squeeze out every bit of climb performance. I also use the LRI to determine the power setting at cruise speed by indicating minimum lift necessary vs. rpm to obtain best range (first quarter of green arc). The third and most important reason I do not want to miss the LRI on my panel is the fact, that it serves as a valuable backup for the ASI. A few years ago on a flight through heavy rain, water clogged the pitot and the speed indicator went south. The LRI saved the day as I was in IMC and was able to deviate to a safe landing because the LRI display took the anxiety factor out of the whole situation - it told me the margin above stall. I would like to thank you for sending me the new unit. I appreciate that you stand behind your product even though it was sold so many years earlier. You can trust me that I will advocate this instrument wherever I can. Sincerely, Michael Schupp ************************************************************************ The LRI was installed on our R/STOL equipped Piper Aztec and its performance evaluated at a number of short fields throughout the Caribbean area over the last sixty days. Special emphasis was placed on the notorious and restricted airport of St. Barthelemy, which has one of the world's most difficult and dangerous approaches, and for which I am the designated check airman for the local authority. Without exaggeration, I consider the LRI both astonishing and essential. In my opinion, it is a must for any short field operation - so much so, I would not like to be without it now that I have used such an invaluable instrument. Of course, the LRI should be monitored, along with the Airspeed Indicator, as part of a continuous panel scan. Both instruments actually compliment each other, each with a vital function. But it was consistently evident that the LRI was far more sensitive - and instantly responsive - during the critical stages of any STOL approach and landing. This was especially true at St. Barths, where a minimum, yet safe approach speed must be maintained at an unusually steep angle in order to control the aircraft in ever-present wind shear conditions, clear a hill just before touchdown, and to minimize the chances for an often fatal missed approach situation. The same was true for approaches into theisland of Saba, which, I am told can lay claim to the world's shortest commercially-used airstrip. In conclusion, I consider the Lift Reserve Indicator essential for any pilot, irrespective of experience level, who truly wishes to experience the pleasures of safely flying any small aircraft to it maximum precision. E.M.L. St. Barthelemy ________________________________________________________________________________
Subject: Re: Heavy left wing
Date: Oct 13, 1999
> > >Does Every one have a Heavy left wing???? I tryed squeezing aileron , didn't >work! Need more advice. > > Thanks Tom B. > The next step after squeezing the right wing as much as you dare is to judiciously blunt the trailing edge of the left wing. I had to do this. Larry Pardue Carlsbad, NM RV-6 N441LP 100 Hours ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Instrument Panel Planning
<<>>> I second this idea Mike. I was able to visit Steve's shop in Memphis and was impressed with the process, especially the acrylic panel that he supplies to check the fit. He also uses .090 materail when making the actual panel with the CNC machine. Makes for a stiffer panel (very slight weight penalty). The backside engraved overlay looks great when attached to the panel. Gary Palinkas Parma, Ohio RV6 QB control systems N198RV reserved ________________________________________________________________________________
Date: Oct 13, 1999
> >Ok, but lets suppose that we calibrate our LRI so that stall occurs when p1 is the same as p2. Then we get: > >d(VCos a) 2 /2 = d(VCos b) 2 /2 > >and everything nicely drops out except: > >Cos a = Cos b > >and the LRI at our calibrated stall is independent of V, d, weitght etc... > >because of the angled faces of the probe, a and b are moving in different directions with increasing AOA so it will always be able to be so colibrated. Yes, that is the point I made. If it is calibrated at critical AoA, when the needle reaches zero, the wing will stall. That is why I *think* that the LRI is probably a useful instrument. >You do seem to be correct with regard to dependance on airspeed at any AOA other than stall may change the indicated 'closeness to stall'. But what exactly do we mean by "closeness to stall?" Is it a percent of airspeed away from stall? At markedly higher airspeeds this has a different meaning for me than at low airspeeds. At a high airspeed "close to stall" seems to mean 'dont pull much harder' while at low airspeeds it means - 'lookout, you really are very close to stalling!' > >I suspect that the LRI is very effective and reliable. I suspect that this deviation with airspeed would be intuitive. It would be nice to know the numbers though. That is the whole point. And I would like to ask the rest of you to stop beating up on Jim Huntington. He may not have answered me because he may not know the answers. I want to treat this like an engineering question, i.e. unemotionally, and find out what the LRI is really telling us in flight. A lot of people fly with it and swear that it works really well. I just want to quantify how well it works. I can pick up a number of books that will tell me how to interpret the airspeed indicator. We all accept that the ASI lies to us about stall speed except at one gross weight and one CG. Even so we accept the ASI as a valid instrument and fly with it readily. I just want to be able to do the same with the LRI. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Re: Experimental AOA?
> >In fact, I have been wondering if it might be possible to fabricate one out of >an ASI. It would be easy to make a probe like the one used by the LRI. The >lower port on the probe would be plumbed to the static side of an ASI while >the upper port would plumb to the pitot side. As AOA increases pressure in >the 'static' side increases relative the upper port and the ASI indication >declines. With proper adjusting of the probe it should be possible to >reproduce a stalling AOA that is at some positive (and fixed) indication on >the ASI. Then simply replace the markings on the ASI to indicate where stall >occurs. That is precisely how the LRI works. But remember that the LRI is patented and to make an instrument that duplicates the LRI would surely be a patent infringement unless you received permission from the holders of the patent. >It should also be possible make a similar set-up with the lower drag ports on >an in-wing AOA indicator, only the upper/lower -- pitot/static orientation >would be reversed. If you did that you would probably be infringing on both the LRI patent and on Jim Frantz' patent application (I don't know if his patent has been granted yet). Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax ________________________________________________________________________________
(Content Technologies SMTPRS 2.0.15) with SMTP id for" ; Wed, 13 Oct 1999 14:05:28.-0400(at)matronics.com
Date: Oct 13, 1999
scott gesele on 10/13/99 10:48:47 AM Please respond to rv-list(at)matronics.com Subject: Gearleg fairings was: vertical fin offset My hangar mate eyeballed the first set of fairings he got from Tracy Saylor. Turns out he had one gear leg leading edge down a full inch from the other. This one inch gave him a HUGE amount of yaw. He said he had a boot-full of rudder the whole way in. He parked the plane cut em off and called Tracy again. So you are definitely right on this, Scott. Eric Henson has anyone attempted to solve an out of rig condition by changing the alignment of the gear leg fairing? The biggest benefit of this is that one could wait until after the airplane is flying and experiment to determine how much offset is needed. Scott Gesele N506RV - Flying ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Re: Painting Info
For everyone's information, orangepeel is caused by too thick paint. You can see it in the air with a test spray. Sometimes little dots of paint mean you need to thin it more. Even lmron needs thinning even tho the label says none is necessary for good flowout. Jim RV6A N160JH 28hr on 3rd RV ________________________________________________________________________________
Date: Oct 13, 1999
You might want to check and see if the flywheel is spaced properly so the starter teeth can engage properly. Jim RV6A 28hr ________________________________________________________________________________
Date: Oct 13, 1999
If the aileron squeezing doesn't work, try making a wedge about 6" long made out of foam, 3/8" thick on the trailing edge and sharp on the leading edge. Then, tape it onto the bottom of the aileron you want to raise. You can't see it from above, but it sure works good. I even had to reduce the size of mine because it was too efficient. It was a temporary fix on my RV4, but it lasted the 8 years I had the -4. Jim RV6A N160JH 28hr. ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Sensenich 72FM8S16 Prop RV-6A
There are three pitches available for this prop. 81, 83, and 85. Van's Catalog implies that the 81 pitch is the best choice for a 180 HP -6A. Is anyone running the 83 pitch. If so, is it a good cruise prop? Chris Browne -6A Finish Atlanta ________________________________________________________________________________
Date: Oct 13, 1999
Check one of the prior posting on the link to the patent page...the patent has expired on Jims' dads' device;. The Attorney in my office stated that experimental development for educational or design variance, for non commercial development is NOT patent infringement....nor is debating the relative merits of one design over another..nor merging one or more patents to make a hybrid product(s). Commercial development of a existing patented device with knowledge & intent is most certainly not kosher.................Experiment away guys........ ________________________________________________________________________________
Date: Oct 13, 1999
Chris, The Van's catalog is incorrect. They published the original propeller that was tested as a 72FM8S( )-0-81 which was a 72 inch diameter with an 81 pitch. There was a resonance slightly above 2700 RPM. We shortened the propeller to 71 inches to stiffen it and raise the resonance well above any potential RPM problem. The propeller was also a little underpitched to begin with. Therefore the final corrected propeller model is a 72FM8S( )-1-83 for a standard RV-6/6A. The -1- signifies 1 inch diameter reduced and can be reduced to 69 inches for reparability. The propeller can be pitched anywhere between 80 and 87 inches of pitch. We have a few 85's and an 86 on RV-8's. Ed Zercher ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Re: Sensenich 72FM8S16 Prop RV-6A
Running 83 pitch. Static 2150 RPM. Climb reasonable, at gross, 110 to 120 mph indicated 1500 fpm. Unloads real fast at level off. Have run it as high as 2750, but backed off due to vibration, runs great at 2700, although, I don't push it past 2450 cruise. George RV6A 140 hrs. ________________________________________________________________________________
Subject: Relocating from NY to Atlanta
Date: Oct 13, 1999
Listers, I just accepted a job in Atlanta and will be transferring there from upstate New York in January. I will have to move my RV4 which consists of the completed tail section, completed wings and fuselage and finishing kits still in pieces. My major concern is moving the wings 1000 miles by truck. Has anyone on the list done this? What is the best way to move the wings, flat or nose down supported by the spar? Mark McGee ________________________________________________________________________________
Date: Oct 13, 1999
BTW Bob, concerning your comments in the previous post relating the increase in weight for a 0.090" panel to be 1.1lbs, I weighed a foot long piece of 5/8"x 0.032" angle (Van's home-rolled varitey) and found the weight to be approximtely 3/4 0z. on my wife's cheapo diet scale. (reads to 1lb) At that weight, I could use 22.8 feet of light angle stiffner (not counting rivet weight) and be at the same weight as an 0.090" panel. I seriously doubt that I'd use more than 5ft, so it seems to me that there is a weight saving available with this approach. Not much, of course, but it all adds up, both positive and negative. Andy Johnson, -8 wings ________________________________________________________________________________
Date: Oct 13, 1999
You know, I am looking at an old EAA magazine, which has an article just exactly what you proposed. A airspeed indicator and a mast under the wing. So how can this be patented (asi and mast) when the idea has around way back in the 80's Gert ________________________________________________________________________________
Date: Oct 14, 1999
I have a heavy right wing,only when I am the only POB in the left seat. When there are 2 POB its fine. I fixed this with minor adjustment of my aileron trim to the left with 1 POB. I wonder if this may be due to the slight unequal spring tension of the aileron trim?I havent bothered to take the floor of the seats off,too many screws! regards albert rv6 44hrs tasmania oz ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Re: LRI/PSS - Brian Lloyd
> >That being said, I must admit certain questions arise for me concerning PSS >and the discussions over the past few days. Why are they not being called >to answer these same questions and others that might arise? What testing >has been performed by what institutions and disinterested parties on that >system. I guess I am a disintrested third party in that I have no connection with PSS other than I bought one of their instruments. It is up to you whether you accept me as a valid third-party testing agency. And the reason they are not being called upon to answer is that I was asking the questions and I had already performed the tests on the PSS AoA to my satisfaction. I don't need answers from PSS. I performed the tests and I am satisfied that the results support PSS's assertation that their instrument indeed indicates AoA. I need to devise other tests to verify whether or not it truely identifies best L/D as they say it does so I will not support their claim until I prove it to myself. >I have raised certain questions concerning the PSS system that >have been dismissed more or less out of hand. Where is the science in >that? Absolutely not true. I am the person who started this recent thread. (Yes boys and girls, this is the Thread That Wouldn't Die! ) and I have already raised the same questions you had. The difference is that I have performed testing and have satisfied myself enough to, for myself, dismiss your questions. >Is PSS a pure AOA system? Not as I understand it. It is a presure >differential system (much like the LRI, but getting its inputs from the >wing surfaces rather than a probe) and transducing those inputs to a >display. A pure AOA system, again as I understand it, is a vane system >that indicates an aircraft's position to the relative wind, as can be seen >on commercial aircraft - hard to accomplish on single engine propeller >driven aircraft. You are correct in stating that the vane type AoA indicator is the simplest and you are correct in your assertion that a vane-type AoA sensor on the fuselage of a tractor-type propellor driven aircraft will produce incorrect results. On the other hand, there are some very interesting AoA systems based on differential pressure being developed today that have no moving parts yet they still indicate AoA very accurately. NASA has come up with some very interesting systems based on multiport differential pressure systems. They needed that for testing aircraft at very large displacements of relative wind from the centerline of the aircraft, i.e. big yaw and pitch (alpha) displacements. The science seems very valid to me after reading the white papers. (Shoot. I just went back to search for the docs and now I can't find 'em. That'll teach me not to bookmark things when I first find them.) The bottom line is, yes, the PSS AoA system appears to be a true AoA indicator. The only question is how accurate is it? My independent testing shows that it is very accurate at zero lift and from Vs to 1.15*Vs. I don't have a good way to measure at other speeds and angles. >Brian, it is not possible for me to answer all of your questions all at >once, but here are a few comments: > >1) The LRI is not a pure angle of attack indicator. > >2) The LRI does NOT calibrate, as the PSS system does, at the critical >angle of attack. It calibrates at ZERO LIFT RESERVE. Zero Lift Reserve can >described in various ways - the point of minimum controlable airspeed; that >point where if the angle of attack is increased the aircraft will drop or >if the airspeed is decrease the aircraft will drop; that point where all >available lift being generated by the airfoil is being used to sustain >level flight - no excess lift being generated. This information just feels funny. How do you determine where excess lift is being generated? If the airplane is accelerating upward, it has excess lift. If it is accelerating downward, there is insufficient lift. If the airplane is not accelerating, the lift is equal to the downward force (gravity plus, for want of a better word, centrifugal force). As you increase AoA and the airspeed remains the same, the lift increases. If I increase AoA and decrease AS proportionally, my lift remains the same. Aha! This is where your AoA + airspeed begins to make sense. So your instrument is some sort of lift indicator. The problem with that is that you need more lift as you increase loading to maintain level flight. This would also support my contention that, at higher loading the indicator would still indicate lots of "lift reserve" even tho I may be a gnat's whisker from stall. I am generating lots of lift, high airspeed plus high AoA, but since AoA is very high, I am really close to a stall and the LRI won't warn me of that. If true, this makes the LRI less useful in determining the safe flight points if you are at anything other than unaccelerated flight. This means that the LRI has errors caused by loading but not as much as the airspeed indicator. OK, I'll buy that. >Another way of describing this is, if one is familiar with the curve for >lift as it proceeds upward and then curves over to the stall break - zero >lift reserve is at the top of the curve. Since I am not 100% sure of my next statement, I invite correction. That said, I was under the impression that the "curve" at the top of the lift graph is a function of the washout in the wing that produces progressive stall spanwise on the wing and that a wing with no washout would not have that curve, just a sharp disconinuity in lift right at critical AoA. A wing produces lift until it stalls. As you increase AoA up to critical AoA the lift of the wing increases. Induced drag also increases and you need additional thrust to overcome the induced drag if you want to maintain level flight. These forces are orthogonal and may be dealt with separately. Thrust directly opposes drag but my lift control, pitch, which has a direct effect on AoA, affects both lift and drag at the same time (more lift and more drag). >That point, as I understand it, >is Vx, also minimum sink and absolute ceiling, and the point past which the >aircraft falls behind the power curve. Vx is the speed at which best angle of climb occurs. Miminum sink is at best L/D. It turns out that Vx and best L/D occur at the same speed at the absolute ceiling of the airplane but you can spread them apart again just by increasing thrust. Clearly there is a thrust (engine power) issue here and your instrument does not take thrust into account since it doesn't have an input to measure thrust. Here is another statement where I may be in error and invite correction. I am under the impression that best L/D for the airframe always occurs at the same AoA. I am also under the impression that best rate of climb (Vy) does not occur at best L/D because the thrust vector is not normal to the direction of flight and because of airflow redirection over the wing (the wing in in the propwash). Again we have an effect from the thrust that does not figure into the indications of the LRI. >So, in effect, the LRI allows a >pilot to see where 'behind the power curve' is for his aircraft for >existing weight and conditions. Being behind the power curve is also a function of excess thrust available. If you have more thrust available, the effect of increased drag has very little effect on your flight and the onset of reversed authority, i.e. where pulling back increases rate of descent instead of decreasing rate of descent, is delayed. >I will respond further responding to your concerns about errors in LRI >indications, but not in this post. This is a matter of time, space, >consideration to others on this list and desire to get everything as >accurate as possible for you. > >Two further items, Brian: - My partner, Bill Geipel, is very willing to >take you up with the LRI in his aircraft - unfortunately in Wisconson, not >California - for you to explore the entire range of the instrument. >1 (888) 310-4574. Well, I am out in California so this doesn't help too much. Surely there is someone out here with a LRI who would like to do some data collection with their airplane. >- Did I understand you to say that your aircraft were used as the test >platforms for the PSS system, and therefore, you have a hand in the >development of that system? Absolutely not. I have no connection with Jim Frantz or PSS other than I am a customer. What I did say is that I performed my own tests to determine whether or not the PSS AoA instrument was doing what it was advertised to do. So far, all the tests I have been able to devise have supported PSS's claims. The unit does appear to truely indicate AoA within my ability to measure it. The things I have not been able to verify are: 1. Is the PSS AoA indication linear with actual AoA? 2. Is the PSS indication of best L/D accurate for all aircraft and all wing airfoil shapes when calibrated according to PSS's instructions? >I will do my best to work my way through the full range of your questions >and concerns. Allow a bit of time for this, but please continue with your >questions and concerns. Thanks Jim. I know that this has been a pain in your side but I am really interested in understanding your instrument. The LRI is a simple and interesting instrument and I really like things that are both simple and useful. >Jim Huntington >jimrhunt(at)wco.com Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax ________________________________________________________________________________
Date: Oct 13, 1999
> > >There are three pitches available for this prop. 81, 83, and 85. Van's >Catalog implies that the 81 pitch is the best choice for a 180 HP -6A. >Is anyone running the 83 pitch. If so, is it a good cruise prop? > >Chris Browne >-6A Finish >Atlanta > Chris, I have posted quite a bit about my experiences with this prop in the past but quite a bit or all of it is not archived. Briefly, with the 83 inch pitch on my O-360 6 I am underpitched but I like that pitch and plan to keep it. With the old style wheel pants I had an RPM limited top cruise speed of about 171 knots at most altitudes. My testing was done at density altitudes of around 8,000 and above. I cannot use full throttle without redlining the engine till around 14,000 feet. I can, of course, use full throttle in the climb and the underpitch should give me a better climb capability. I think it is a good compromise. In my airplane I think the 81 inch would be annoyingly underpitched. For someone willing to run over the 2700 rpm redline it may be a different story. I am in the process of installing the two-piece wheel pants. These pants should make my prop even more underpitched. Larry Pardue Carlsbad, NM RV-6 N441LP 100 Hours ________________________________________________________________________________
Date: Oct 13, 1999
I moved my project 1500 miles in a rack we made from 2x4's and carpet strips. If you're interested, contact me off list and I will send a sketch. I turned the wings on the leading edges supported by the suspended carpet strips that were located on ribs. The wings were then softly clamped together with a cross 2x4 on top. From Fargo, ND to Albuquerque, NM, not a single scratch or dent in a 12 ft u-haul trailer (with the aft fuselage sticking 18" out the back!). I have since made a very sturdy wing rack with the same principle that has locking castors, the works, it would works even better. Rob Reece RV-3 SN 45 Socorro, NM 505-835-3644 ________________________________________________________________________________
Date: Oct 13, 1999
In a message dated 10/13/1999 3:30:08 PM Eastern Daylight Time, cebrowne(at)earthlink.net writes: << There are three pitches available for this prop. 81, 83, and 85. Van's Catalog implies that the 81 pitch is the best choice for a 180 HP -6A. Is anyone running the 83 pitch. If so, is it a good cruise prop? >> I just talked with Ed Zercher at Sensenich. He tells me that the 72FM8S9-1-83 is the prop you are going to use for the O 360 A1A Lycoming. It is actually 71" and 83 inches pitch. This is a change from what you will see in Van's catalog. The propeller can be repitched after flying it. The suggestion from Ed is to fly at 5000' full throttle (standard day) and see if you exceed 2700 RPM. Ed was absolutely easy to talk to and very informative. I ordered my prop from Van's and a spinner from Sensenich. david faile, fairfield, ct mcfii/a&p faa aviation safety counselor eaa technical counselor/flight advisor christen eagle ii since '82 (n13bf) rv6 (n44df) started ________________________________________________________________________________
Date: Oct 13, 1999
> > >Check one of the prior posting on the link to the patent page...the patent has >expired on Jims' dads' device;. The Attorney in my office stated that >experimental development for educational or design variance, for non commercial >development is NOT patent infringement....nor is debating the relative merits of >one design over another..nor merging one or more patents to make a hybrid >product(s). Commercial development of a existing patented device with knowledge >& intent is most certainly not kosher.................Experiment away >guys........ Thank you. I stand corrected. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Re: Prepping skins without removing alclad
Mark, There are two trains of thought here. It has been a ongoing discussion here on the list. There are several items in the archives for your further indulgance. The way a lot of us (me included) is to prime the interior with a self-etching primer. There are several out there but I used the Sherwin Williams one. it does a good job of sticking. If you want to go the long route then etch, alodine, and prime. When you apply the etch you use a light scotch-brite pad then so don't get carried away prior to then. For interior facing parts don't get carried away with scratches in the alclad as these will be filled in with primer. On the outside it is a different matter as that could show thru on the paint. You will have to blend that out. Mike Robertson RV-8A QB still installing interior In a message dated Mon, 11 Oct 1999 7:05:58 PM Eastern Daylight Time, Mark Schrimmer writes: > > Before I prime the inside of the empennage, how do I prepare the skins > without damaging the thin alclad coating? Do you just rub the skins very > lightly with a gray scotchbrite pad? If so, what do you do with a deep > scratch? Just prime over the scratch without removing it? > > If the alclad is so thin, would you be better off to skip the scotchbrite > pads altogether and just etch, alodine and prime the parts? Perhaps I've > just stumbled onto the reason the inside skins on many spam cans aren't > primed at all. > > Thanks for the help. I spent a couple of hours in the archives but couldn't > find the answer to these questions. > > Mark Schrimmer > Irvine, CA > > Waiting for RV-9 tail kit > > ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Re: Relocating from NY to Atlanta
to Mark Magee When i picked up my 6A QB at Van's with a U-Haul truck to drive it back to Chicago, Van's shipping people loaded it and tie it down for me. They placed the wings on the leading edges, padded of course, and tied each wing to the side of the truck. They did fine on the 1,000+ miles from Oregon to Chicago. ________________________________________________________________________________
Date: Oct 13, 1999
Subject: RV6 - Cut down seat backs
Has anyone heard of cutting down the seat back height on a RV6? Got a local -6 pilot that swears if I don't do it now, I will later. I'm building a slider. Any thoughts? Larry Olson Cave Creek, AZ RV6 - Fuse out of the jig ________________________________________________________________________________
Subject: Need crates
Date: Oct 13, 1999
Listers, I need crates for shipping my fuselage and finishing kits from NY to Atlanta. If anyone still has their crates in good condition, I would like to have them, depending on how far away they are. Mark McGee ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Re: RV6 - Cut down seat backs
> >Has anyone heard of cutting down the seat back height on a RV6? > >Got a local -6 pilot that swears if I don't do it now, I >will later. > >I'm building a slider. > >Any thoughts? **I did that! I rebuilt the backs because I found them to low. I would wait until you have an opportunity sit in it. Have a great Day! Denny Harjehausen Lebanon, OR RV-6 ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Re: Cowl Attach-Vibration
"Stucklen, Frederic IFC" wrote: > > Listers, > > I now have 1425 hrs on my RV and still have the original hinges. Only > three eyelets have broken out in that time frame. The rest are getting > rather worn out, and I am now considering replacing them with CamLocks.... > By the way, use of a lot of grease helps cut down on the wear..... > > Fred Stucklen Fred, You must fly that thing everyday! What lubricant have you been using on the pins? I was worried that grease would ooze down the cowl? Cheers, Leo 6A (flying and loving it) ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Prepping skins without removing alclad
I've been using the Sherwin-Williams GBP988 since the beginning of my project. In general, it's worked great. However, when I dimpled some of the wing ribs, the primer began to flake off where the dimple die made contact. Has this happened to anyone else? Any idea why? Larry Bowen RV-8 wings Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > MRobert569(at)aol.com > Sent: Wednesday, October 13, 1999 6:33 PM > Subject: Re: RV-List: Prepping skins without removing alclad > > Mark, > > There are two trains of thought here. It has been a ongoing > discussion here on the list. There are several items in the > archives for your further indulgance. > > The way a lot of us (me included) is to prime the interior with a > self-etching primer. There are several out there but I used the > Sherwin Williams one. it does a good job of sticking. > [snip] ________________________________________________________________________________
Date: Oct 13, 1999
Mark, We moved a plane from Maryland to Texas - about 1500 miles. We put the wings in the back of the pickup with 2" of foam rubber under each wing (wings were stacked flat). The control surfaces and empennage parts were wrapped in blankets and other soft things and layed on top of the wings. The spars were tied to each side of the bumper to make sure they didn't bounce out. The truck had a cap on it so nothing could bounce out the top. The house plants also went with this load - not that they added anything to the packing. We also had a mostly finished fuselage that we wrapped in plastic and tied the wheels to a flatbed trailer. Boy did I get some looks driving all this down the road. Becki Orndorff ________________________________________________________________________________
Subject: vertical fin offset
Date: Oct 14, 1999
With all the talk about Vertical fin offset I must ask, What would cause more drag, a horrible looking tab or a offset fin that most people wouldn't even see. (I have a 6 inch rudder tab on my RV6 bent at 30 to 40 degrees) Thank you. Trevor Mills RV 6 flying RV 8 left wing getting dusty. ________________________________________________________________________________
Date: Oct 13, 1999
--- Larry Olson wrote: > > > Has anyone heard of cutting down the seat back > height on a RV6? > > Got a local -6 pilot that swears if I don't do it > now, I > will later. > > I'm building a slider. > > Any thoughts? > > Larry Olson > Cave Creek, AZ > RV6 - Fuse out of the jig Larry: I have 430+ hours on my -6 with slider and the STANDARD height seat backs . I have one friend that tried to talk me into doing this (cutting down the back height) on mine and did not. I have flown in one with the seat backs cut down and did not like it. Some like the sliding canopy, some like the tilt up. Same goes with the seat backs. I know DJ makes "Drop in" seats for the standard back. I think George & Becky do also. If you cut them down, how much more will it cost for custom cushions? ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, So. CA, USA Bid and sell for free at http://auctions.yahoo.com ________________________________________________________________________________
Date: Oct 13, 1999
Listers, Lets make this a little more confusing. I was looking through the yeller pages for links to paint suppliers and ran across the E.M. Aviation website. Their product is a vane type AOA. Anyone on the list have any eperience with the product or company? Charlie Oglesby Preview Plans and Buying Tools Winter Haven, FL ________________________________________________________________________________
Date: Oct 13, 1999
> > There are three pitches available for this prop. 81, 83, and 85. Van's > Catalog implies that the 81 pitch is the best choice for a 180 HP -6A. > Is anyone running the 83 pitch. If so, is it a good cruise prop? > > Chris Browne > -6A Finish > Atlanta > Chris, I am running an 83 pitch 72FM8S on my fairly light (1,045lbs) RV6 and find it to be just right. Take-off is not too brisk but cruise climb is excellent (the guys with constant speeds are telling me to slow down). Cruise at 8500' is 170kts @ 9gph. I should add that my wife and I are quite small and weigh 270lbs combined. Martin Sutter RV6 N868CM 1500hrs ________________________________________________________________________________
Date: Oct 13, 1999
Fred, out of curiosity, did you happen to radius the factory sharp corners which are built into the hinges? I don't know what the result will be as I'm not flying yet, but I took an 1/8" diameter file to each corner in the hinge, obliterating the original sharp corner left from the stamping. These hinges are poster parts for stress risers leading to fatigue in their supplied condition. Additionally, I will be experimenting with covering the .090" steel pins used on the top hinges with heat shrink tubing, to bring the outside diameter up to about .125", to eliminate a lot of the slop without increasing stiffness much (can't take credit for the idea). I'll report as I learn... Alex Peterson Maple Grove, MN ---------- > From: Stucklen, Frederic IFC <stuckle(at)ifc.utc.com> > To: 'RV-List' > Subject: RV-List: Cowl Attach-Vibration > Date: Wednesday, October 13, 1999 7:12 AM > > > Listers, > > I now have 1425 hrs on my RV and still have the original hinges. Only > three eyelets have broken out in that time frame. The rest are getting > rather worn out, and I am now considering replacing them with CamLocks.... > By the way, use of a lot of grease helps cut down on the wear..... > > Fred Stucklen > N925RV RV-6A > E. Windsor, Ct > ________________________________________________________________________________
Date: Oct 13, 1999
Subject: Re: vertical fin offset
> >With all the talk about Vertical fin offset I must ask, >What would cause more drag, a horrible looking tab or a offset fin that most >people wouldn't even see. >(I have a 6 inch rudder tab on my RV6 bent at 30 to 40 degrees) > >Thank you. > >Trevor Mills The rudder tab should cause slightly more drag than the VS offset, but the difference would be so small that it should make no measurable difference in performance. Having an offset VS is a more elegant solution, but there is no way to predict how much (if any) offset you will need until you fly. As others have said, I would be really cranky if I put in a VS offset, and then needed a rudder tab to cancel some of the offset out. That would give even more drag than either case you described. So, I'll go without any VS offset, and put some in after flying if needed, and if I feel up to redoing the tail fairing. Kevin Horton RV-8 (wings 85% done) Ottawa, Canada http://www.cyberus.ca/~khorton/rv8.html http://www.cyberus.ca/~khorton/nojpi.html - No JPI stuff in my aircraft! ________________________________________________________________________________
Date: Oct 13, 1999
> > > > > > Has anyone heard of cutting down the seat back > > height on a RV6? > > > > Got a local -6 pilot that swears if I don't do it > > now, I will later. > > > > I'm building a slider. > > > > Any thoughts? So.... would the reason to do this be easier access to the baggage area? Can't imagine how it would make a seat more comfortable... Mike Thompson Austin, TX -6 N140RV (Reserved) Wings Bid and sell for free at http://auctions.yahoo.com ________________________________________________________________________________
Date: Oct 13, 1999
-----Original Message----- From: Charlie Oglesby <coglesby(at)ithink.net> Date: Wednesday, October 13, 1999 6:03 PM Subject: Re: RV-List: LRI/PSS - Brian Lloyd > >Listers, > >Lets make this a little more confusing. I was looking through the yeller >pages for links to paint suppliers and ran across the E.M. Aviation website. >Their product is a vane type AOA. Anyone on the list have any eperience >with the product or company? > >Charlie Oglesby >Preview Plans and Buying Tools >Winter Haven, FL Brian: I'm in Vancouver WA EAA Chap 782 past Pres. and Sec for several years also during this time Elbie M was a member of the Chapter. I am building an RV-6A, started in spring of '94 but halted all work during '98 and early '99 as my wife had ovarion cancer and was on hospice begining the end of January til August and I was primary. I have an early version of RiteAngle but remember as this is electronic, changes in this area are rapidly improving so also with RiteAngle. The accuracy of the flying wing driving RiteAngle is extremely accurate. It is another tool to help you stay out trouble, once you are familiar with the unit. Contact EM Aviation on the webpage: www.riteangle.com Dick Zander N747RZ EAA-782 Insturment Panel to Prop Spinner Panel by Steve Davis ________________________________________________________________________________
Subject: EAA Hall of Fame
Date: Oct 13, 1999
The following annoucement was in the latest issue of the COPA Flight news. CONGRATULATIONS Congratulations to Chris Heintz of Zenair in Midland, Ontario, who will be inducted into EAA's Hall of Fame during a special ceremony at Oshkosh in October, Richard Van Grunsven will also be inducted during the ceremony,Henri Mignet, the third nominee, will be inducted into the EAA Hall of Fame posthumously. More details will be presented in a future issue of Sport Aviation. While there have been many others who have also made contributiions to keep general aviation and sport aviation in particular, alive and well during the down turn of the past fifteen years, in thinking back over the past sixty years I am hard pressed to think of anyone with the possible exception of Mr. Piper that has done more for sport aviation than Van and Chris, and in that order. As I have said so many times since my first flight in my RV 6 "THANKS VAN FOR A WONDERFUL AIRCRAFT" and congratulations from a fellow RVer. My hat is of to you, Eustace Bowhay RV 6 serial 20383 ________________________________________________________________________________
Date: Oct 13, 1999
NO... > >Listers, > >Lets make this a little more confusing. I was looking through the yeller >pages for links to paint suppliers and ran across the E.M. Aviation website. >Their product is a vane type AOA. Anyone on the list have any eperience >with the product or company? > >Charlie Oglesby >Preview Plans and Buying Tools >Winter Haven, FL > ________________________________________________________________________________
Date: Oct 13, 1999
> > > >Vx is the speed at which best angle of climb occurs. >Miminum sink is at best L/D. >It turns out that Vx and best L/D occur at the same speed at the absolute >ceiling of the airplane but you can spread them apart again just by >increasing thrust. Clearly there is a thrust (engine power) issue here and >your instrument does not take thrust into account since it doesn't have an >input to measure thrust. > Brian, Most of this thread is over my head, but I can make one small correction. As any glider pilot knows, minimum sink occurs at a slower speed than best L/D speed which is the best glide angle speed. I don't know if it always has to be that way, but in all gliders I have flown minimum sink speed is quite close to stall speed and best L/D is at a higher speed. Larry Pardue Carlsbad, NM RV-6 N441LP 100 Hours/Gliders about 900 Hours ________________________________________________________________________________
Date: Oct 13, 1999
> > Has anyone heard of cutting down the seat back height on a RV6? > > Got a local -6 pilot that swears if I don't do it now, I > will later. > > Any thoughts? > My seat backs are full height, and I like them fine. The only reason that I have heard for cutting them down is to make it easier to reach things in the baggage compartment during flight. I have found that instead of trying to reach over the seat backs, it is much easier to reach between the seat backs. It is surprising how much of the baggage compartment I can reach this way. I use the space between the seat back and the flap torque tube to store items that I need during flight (water bottles, lunch, AOPA airport directory, etc.). I can reach this area behind either seat with ease, without any of the twisting and turning (and resulting aerobatics) that is required to reach over the seat back. Of course, this option is not available if you have electric flaps, since the flap drive mechanism blocks the space between the seat backs. Also, larger pilots with "Popeye" sized forearms may find this more difficult. Mark Nielsen RV-6, 445 hours Green Bay, WI ________________________________________________________________________________
Date: Oct 14, 1999
In a message dated 10/13/99 5:39:21 PM Pacific Daylight Time, lolson(at)doitnow.com writes: << Has anyone heard of cutting down the seat back height on a RV6? Got a local -6 pilot that swears if I don't do it now, I will later. >> I don't agree. He must be a short s**t ; ). IMO only the vertically challenged would be able to tolerate shorter than stock seat backs. -GV ________________________________________________________________________________
Subject: Re: test flying: RV6A
Date: Oct 14, 1999
Be aware that the timer only records time spent above 1300rpm, (at least this is how the R-1 works) so it won't be recording ground time. Ed Bundy - Eagle, ID - RV6-A First flight 11/20/96 ebundy@access1.net http://home.cwix.com/~ebundy@cwix.com/ > My electronics international tach is reading engine RPM perfectly but is > recording tach time at half the real rate????. A question for customer > support I guess. ________________________________________________________________________________
Date: Oct 13, 1999
>>Vx is the speed at which best angle of climb occurs. >>Miminum sink is at best L/D. >>It turns out that Vx and best L/D occur at the same speed at the absolute >>ceiling of the airplane but you can spread them apart again just by >>increasing thrust. Clearly there is a thrust (engine power) issue here and >>your instrument does not take thrust into account since it doesn't have an >>input to measure thrust. > >Most of this thread is over my head, but I can make one small correction. >As any glider pilot knows, minimum sink occurs at a slower speed than best >L/D speed which is the best glide angle speed. I don't know if it always >has to be that way, but in all gliders I have flown minimum sink speed is >quite close to stall speed and best L/D is at a higher speed. Ouch! You are right. That is what I get for spending too much time flying powered planes. Time for a refresher. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax ________________________________________________________________________________
Date: Oct 13, 1999
From: Thomas McIntyre <bogeybrother(at)earthlink.net>
Sorry, I've been trying to stay out of this discussion but I cant. I offset my vertical 3/8" off center and my Rv flys feet off at 190 indicated. Cool eh? there's more, any speed below or above requires a little rudder input to center the ball. Conclusion: any adjustment you make will be accurate only for a small range of airspeeds. Good luck. Tom Kevin Horton wrote: > > > > >With all the talk about Vertical fin offset I must ask, > >What would cause more drag, a horrible looking tab or a offset fin that most > >people wouldn't even see. > >(I have a 6 inch rudder tab on my RV6 bent at 30 to 40 degrees) > > > >Thank you. > > > >Trevor Mills > > The rudder tab should cause slightly more drag than the VS offset, > but the difference would be so small that it should make no > measurable difference in performance. > > Having an offset VS is a more elegant solution, but there is no way > to predict how much (if any) offset you will need until you fly. As > others have said, I would be really cranky if I put in a VS offset, > and then needed a rudder tab to cancel some of the offset out. That > would give even more drag than either case you described. > > So, I'll go without any VS offset, and put some in after flying if > needed, and if I feel up to redoing the tail fairing. > > Kevin Horton RV-8 (wings 85% done) > Ottawa, Canada > http://www.cyberus.ca/~khorton/rv8.html > http://www.cyberus.ca/~khorton/nojpi.html - No JPI stuff in my aircraft! > ________________________________________________________________________________
Date: Oct 14, 1999
> >There are three pitches available for this prop. 81, 83, and 85. Van's >Catalog implies that the 81 pitch is the best choice for a 180 HP -6A. >Is anyone running the 83 pitch. If so, is it a good cruise prop? > >Chris Browne >-6A Finish >Atlanta > Chris: When I ordered my prop (I have the short cowl, so ordered the FM8S9) I ordered the 81" pitch because that was in van's catalog. Sensenich then called me to ask if that was what I REALLY wanted. They said the very first such prop they experimented with was 81" pitch, but they recommend 83" as a better compromise. They wish Van would change his catalog to show the 83" prop instead. I changed my order to the 83". I haven't flown with it yet, though. It's gonna be a while.... --- Tom Sargent, sarg314(at)azstarnet.com ________________________________________________________________________________
Date: Oct 14, 1999
In a message dated 10/14/1999 7:40:59 AM Tokyo Standard Time, gert@exec > You know, I am looking at an old EAA magazine, which has an article just > exactly what you proposed. > > A airspeed indicator and a mast under the wing. So how can this be > patented (asi and mast) when the idea has around way back in the 80's > > Gert Well, I guess I should just let it die, but this is fun. Thanks Gert. Which issue is that? More importantly, did it work? After thinking about it, with an ASI used with an LRI type mast, this critical calibrated angle (either stall or 'zero lift reserve' - which ever you calibrate it for) will occur when the ASI drops to zero (ie both ports are at equal pressure). Since ASI's are not very accurate less than 35-50 kts I am starting to wonder if this is the best Idea. Besides, I didn't really like the idea of something sticking out in the wind. But I do like the flush port PSS type system and I think it will work even better with an ASI. The lower wing port plumbs to the pitot side of the ASI, the upper wing to the 'static' connection. As speed increases, low pressure on the upper surface and higher pressure on the lower skin cause a positive reading on the ASI. As AOA increases, so does the differiental pressure and the ASI reading. At stall, back pressure floods the upper surface and the AOA-come-lately drops down and becomes erratic, but by now you already know your wing is stalling. Because of the success of the PSS I would bet that the ASI can be read in 'units' of AOA and stall would be predictable and independent (mostly) of density, weight, and g-load. The ASI should also be solidly into the positive territory at stall. I'm not sure about the internal structure of an ASI. It may be necessary to remove any flow restrictors so the AOA reading will be more instantaneous. Anyone think it might work? As far as patent infringement, its not for commercial use. However, I would like to patronize those who go the effort and investment of producing new products for GA. Then again, charging $750 to $2000 for something I can make from off the shelf stuff for less than $200 is going too far. Its kind of like buying a Mooney, or putting together your own RV. :-) Dave Leonard 6QB ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Need fly-in info
Does anyone know of a fly-in near Nashville this month? Not the one at Lebanon, went to that. ________________________________________________________________________________
Date: Oct 14, 1999
Tom, Ed at Sensenich E-mailed about that, too. Van's also has the "-0-" wrong in the part number, it should be a "-1". So, I currently have the wrong prop on order. sigh ... Chris tom sargent wrote: > > > > >There are three pitches available for this prop. 81, 83, and 85. Van's > >Catalog implies that the 81 pitch is the best choice for a 180 HP -6A. > >Is anyone running the 83 pitch. If so, is it a good cruise prop? > > > >Chris Browne > >-6A Finish > >Atlanta > > > > Chris: > When I ordered my prop (I have the short cowl, so ordered the > FM8S9) I ordered the 81" pitch because that was in van's catalog. Sensenich > then called me to ask if that was what I REALLY wanted. They said the > very first such prop they experimented with was 81" pitch, but they > recommend 83" as a better compromise. They wish Van would change his > catalog to show the 83" prop instead. I changed my order to the 83". I > haven't flown with it yet, though. It's gonna be a while.... > > --- > Tom Sargent, sarg314(at)azstarnet.com > ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <stuckle(at)ifc.utc.com>
Date: Oct 14, 1999
Leo, I fly in excess of 200 Hr's per year. (1425 TT / 6 yrs = 237.5/Yr.....) I put regular axle grease on the pins when I insert them. The only time I see anything ooze out is after flying into rain, usually in IFR conditions. That usually leaves the traditional "gray" streaks running down the side of the fuselage. When flying in sunny weather, nothing oozes out...... Fred Stucklen N925RV RV-6A E. Windsor, Ct ____ From: Dr Leo Davies <leo(at)icn.usyd.edu.au> Subject: Re: RV-List: Cowl Attach-Vibration Fred, You must fly that thing everyday! What lubricant have you been using on the pins? I was worried that grease would ooze down the cowl? Cheers, Leo 6A (flying and loving it) ________________________________________________________________________________
Date: Oct 14, 1999
I have been following the recent thread regarding cowl attach vibration and considering alternate methods of attachment. In a recent conversation with Ken Scott from Van's, he informed me that one of the factory RV-6 aircraft has over 2200 hours time in service with no broken hinge loops. This is the highest time RV I have been able to find without hinge loop problems, Fred Stucklen is the second. After talking to many builders and taking a hard look at the problem it would seem that there are several contributing factors; such as vibration, strain on hinges due to quality of installation, air pressure at speed, aerodynamic loads and forces on the cowl due to engine air baffle seals. One other factor that may need consideration is that of exit air turbulence. My own original intent was to use the hinges with a plenum, thereby removing the engine baffle seal stress factor, along with a Chadwick prop balance. This still leaves aerodynamic loads as well as cowl air pressure at speed to contend with. I am also not so sure that the engine/prop vibration can be sufficiently reduced to a level that is conducive to the long life of the hinges. With these thoughts on the above listed fixes in mind I felt that the problem would only be partially solved. For my own RV-8, I will attempt to attach the cowl with 1/4 turn flush DZUS fasteners. I do not want to use nutplates and screws, (with the exception of those at the air inlet) and the other fasteners on the market all sit proud of the cowl surface. It will be necessary to build up the lip of the cowl with epoxy lay-ups in order to obtain the thickness required to machine countersink the cowl for the DZUS fastener. The lay-ups will also help keep the cowl stiff in this area to reduce the "inflation" forces on the cowl due to air pressure at speed. Also, proper spacing of the fasteners may be critical for the same reason. The difficulties of this type of installation are as follows: 1) More work 2) More weight 3) Will have to procure/make a special large machine countersink tool 4) More cost 5) Unknown long term effects of countersinking the fiberglass -- will cracks appear? 6) Not as pretty as the look of no fasteners while using the hinge method If it works out, it will be a a solution to the cowling hinge loop problem, and cowling removal and replacement will be easy and still look good. I am willing to take on all of these problems and attempt to provide a good alternative to the hinges, but am interested in input from other builders with similar thoughts and or experiences before I begin. Jon Ross RV-80094 Finish kit ________________________________________________________________________________
From: "Lewis, Timothy H., ,SAF/AQII" <TimothyH.Lewis(at)pentagon.af.mil>
Subject: Paint Spray Guns
Date: Oct 14, 1999
On 11 Oct 99, at 13:58, Emrath wrote: > Also, there is a Devilbess Gravity Spray gun number 34775-1VGA for > $169.99 > that says will spay upside down and has a 1 year warranty. Has anyone > used a gravity feed gun and what their opinion is of such a gun? > I've about finishing painting my plane this wee. I have the Finish Line (Conventional) Gravity Feed. Yes, you can spray with it upside down. Be sure to buy an extra box of cup liners, as they are what allow it to reliably paint upside down. I'd recommend the HVLP vs the Conventional. I have the Conventional, and I went thru a lot of Imron. I think the HVLP would have paid for itself in the savings in paint. Tim ****** Tim Lewis timrv6a(at)iname.com N47TD RV-6A, painting Springfield VA http://home.earthlink.net/~timrv6a http://home.earthlink.net/~timrv6a/jpi.html <http://home.earthlink.net/~timrv6a/jpi.html> - No JPI stuff in my airplane ________________________________________________________________________________
Date: Oct 14, 1999
Alex, Can't say that I remember doing anything special with the stock hinges prior to riveting them into place. At the time, the prospect of cracks forming in the sharp radius corners wasn't high on the priority list, or even considered a problem. I would think that it wouldn't hurt to radius these areas, but from my own personal experience, I'm not sure that it would have help prevent what little breakage I've had. Most of my breakage has occurred at the ends of the pin travel..... Putting shrink tubing onto the top cowl .090" steel pins may work OK initially, but I suspect that after very little use, the surface of the shrink tubing will deform. This would result in a hard to remove pin, and almost impossible to insert pin. The original promise of an undersized pin was to enable the pin to form to both the straight run hinge sections as well as the curved areas. I suspect that the increased diameter pin would be very difficult to insert. Fred Stucklen N925RV RV-6A E. Windsor, Ct ____ From: "Alex Peterson" <alexpeterson(at)usjet.net> Subject: Re: RV-List: Cowl Attach-Vibration Fred, out of curiosity, did you happen to radius the factory sharp corners which are built into the hinges? I don't know what the result will be as I'm not flying yet, but I took an 1/8" diameter file to each corner in the hinge, obliterating the original sharp corner left from the stamping. These hinges are poster parts for stress risers leading to fatigue in their supplied condition. Additionally, I will be experimenting with covering the .090" steel pins used on the top hinges with heat shrink tubing, to bring the outside diameter up to about .125", to eliminate a lot of the slop without increasing stiffness much (can't take credit for the idea). I'll report as I learn... Alex Peterson Maple Grove, MN ________________________________________________________________________________
Date: Oct 14, 1999
In a message dated 10/13/99 23:58:21, bogeybrother(at)earthlink.net writes: Sorry, I've been trying to stay out of this discussion but I cant. I offset my vertical 3/8" off center and my Rv flys feet off at 190 indicated. Cool eh? there's more, any speed below or above requires a little rudder input to center the ball. Conclusion: any adjustment you make will be accurate only for a small range of airspeeds. Good luck. Tom >> Shucks I have been trying to stay out too. But I have another question for the aerodynamiologists. It seems to me the offset would indeed only be good for one speed ( as would a bias spring). On the other hand the tab would be seeing more air at a greater speed and put in more rudder etc, so maybe would have a larger range of effectiveness. If so it would be another plus for the tab.(ugly, one ea.) My intuitive stabs are sometimes woefully wrong so let's hear from those less aero challenged. D Walsh ________________________________________________________________________________
Date: Oct 14, 1999
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: Re: Use (of Nightsun lites) with an alternator power source
I checked out this product on several websits . . . please don't spend a lot of bux purchasing these things for adaptation to airplanes. The bulbs used in their fixtures are plain vanilla halogen spot/flood devices not unlike the one you'll see at http://www.aeroelectric.com/exh.jpg These bulbs have built in reflectors and come in a wide variety of wattages and beam spreads. The 12V rated lamps are used by the thousands in product displays in stores and are quite inexpensive. One might also consider using a common automotive headlamp like the one I show at http://www.aeroelectric.com/4352.jpg This lamp is 55w, very compact, the right shape for leading edge incorporation and a whold lot less expensive than the Nightsun products. The respondant's concerns about "regulation of the vehicle" shows lack of knowledge of how things are supposed to work. It's true that a bulb's life varies strongly with voltage. For example, running a bulb a 95% of its rated value doubles the life, 105% of rated value halves the life. HOWEVER, given that these bulbs are designed for thousands of hours service in high duty cycle service like storefronts should mitigate the builder's concerns for service life . . . especially since the 4509 lamp used in tens of thousands of certified ships has a service life on the order of 10-20 hours! Check out the light bulbs I've suggested above and do some poking around on your own in the lighting sections of hardware stores and automotive suppliers . . . > FYI > With regard to the recent post about the Nitesun biking lighting......I >asked them if these type of lights could be used with an alternator as a >power source. Their response is below. > >--------- Forwarded message ---------- >From: "Nightsun" <night-sun(at)mail.wman.com> >To: Dana Hill >Date: Sun, 10 Oct 1999 09:24:09 +0000 >Subject: Re: Use on a car? >Message-ID: <199910101625.JAA07838(at)home.wman.com> > >Might work ok, but what wories me is the voltage regulation of the >vehicle. Some alternators / voltage regulators but out upto 16 vdc, >way too much for our bulbs. Upto about 14 will work, but the lamp >life will be shortened, over 14 and the lamp life would be very >short. Most airplanes are 28 volt. > In any event we do not sell headlights without batteries. > > >Regards, > > >Nightsun > >To: info@night-sun.com >Subject: Use on a car? >From: Dana Hill <dhill36(at)juno.com> > >Hi Night-Sun, > I would like to know if your lighting system could be hardwired into > a >14 Volt DC charging system, such as a car/airplane? Would this sort >of mod be difficult? Any info in this regard would be appreciated. > >Thanks, >Dana Hill > >Customer Service, Monday to Friday, 9 a.m. to 5 p.m., Pacific time >626-799-5074 > Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Independence Kansas: the > < Jurassic Park of aviation. > < Your source for brand new > < 40 year old airplanes. > ================================ http://www.aeroelectric.com ________________________________________________________________________________
Subject: Cowl Attach-Vibration
Date: Oct 14, 1999
Seems like a lot of effort to avoid a very slight protrusion with no net aerodynamic gain. Countersunk washers are only .016" thick and flush Camlocs can't protrude much more than that. Not much thicker than bug splatters... at least here in Texas:-) Regards, Greg Young RV-6 N6GY (reserved) finishing kit > > For my own RV-8, I will attempt to attach the cowl with 1/4 turn > flush DZUS > fasteners. I do not want to use nutplates and screws, (with the > exception of > those at the air inlet) and the other fasteners on the market all > sit proud > of the cowl surface. It will be necessary to build up the lip of the cowl > with epoxy lay-ups in order to obtain the thickness required to machine > countersink the cowl for the DZUS fastener. The lay-ups will also > help keep > the cowl stiff in this area to reduce the "inflation" forces on > the cowl due > to air pressure at speed. Also, proper spacing of the fasteners may be > critical for the same reason. The difficulties of this type of > installation > are as follows: > > 1) More work > 2) More weight > 3) Will have to procure/make a special large machine countersink tool > 4) More cost > 5) Unknown long term effects of countersinking the fiberglass -- > will cracks > appear? > 6) Not as pretty as the look of no fasteners while using the hinge method > ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Re: Bulky, unreadable files
>Hi netters. > >I hate to be a whiner, but I got two files in the Vol 01, Number 509 >Glastarnet that flat filled up my bit bucket. I had to stop and empty it >before the computer would work again. I could name names, but I won't. One >was a WINMAIL.DAT file, and the other was MIME. Please, please look at what >you are putting out to avoid this problem. I know, I know. I had trouble >passing "Works and plays well with others" too. > >Bobbi & Ric Lasher >#5648 BN954BR >Cocoa, Fl. I subscribe to about a dozen list-servers so it takes quite a bit of time to download ordinary message traffic. If a couple of folks attach a few hundred K-bytes of "information" it really slows things down and increases the risk of problems like Rich describes. There is an EASY way to avoid this for most folks. If you have a real internet access account with server hardrive space, you can upload large files to your server and then give people pointers on how to find them. For example, click on this: http://www.aeroelectric.com/exh.jpg You need an FTP program and little instruction which your ISP provider should be able to provide. You'll gain a new skill, a new tool for effective communications and avoid forcing our friends to download data which may be of no interest. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Independence Kansas: the > < Jurassic Park of aviation. > < Your source for brand new > < 40 year old airplanes. > ================================ http://www.aeroelectric.com ________________________________________________________________________________
Date: Oct 14, 1999
> > > >It seems to me the offset would indeed only be good for one speed ( as would >a bias spring). On the other hand the tab would be seeing more air at a >greater speed and put in more rudder etc, so maybe would have a larger range >of effectiveness. If so it would be another plus for the tab.(ugly, one >ea.) > >My intuitive stabs are sometimes woefully wrong so let's hear from those >less >aero challenged. > >D Walsh > > I have a rudder tab. It is only good for one speed but maybe it is close over a wider speed range? Larry Pardue Carlsbad, NM RV-6 N441LP ________________________________________________________________________________
Subject: Angle-of-Attack
Date: Oct 14, 1999
Maybe things have changed since I was in the Navy (Vietnam) but we only used AOA for landing, never take off. Use airspeed for take off. It helps to be as slow as you can be coming aboard the "boat",but what is the point, under normal circumstances, of lifting off as soon as you possible can off a runway that is adequate for your airplane? After all most of the time we fly out of runways long enough to get up to take off speed plus a little for the grandkids. AOA is great but airplanes have flown a long time with airspeed indicators just fine. If you really want to be that close to the ragged edge don't give me a ride. Additionally, if you are using the AOA to hold max rate of climb, to look cool for the guys, think about what happens when the engine quits at 150 feet with your nose pitched up at 40 degrees. You can't recover!!! Next time you see a Rocket guy getting 5000 FPM rate of climb off the deck, think about it. If the engine quits before he gets high enough to recover you can get a good deal on aluminum scrap and maybe a used "Lift Gauge". Go up to 5000 feet and try it. Rich Crosley Palmdale, CA RV-8 wings, gas tanks ________________________________________________________________________________
Subject: Matronics List Idea
Date: Oct 14, 1999
Hey Matt Can we get another list created for AOA? : ) Gary Fesenbek RV6A Dallas ________________________________________________________________________________
Subject: Re: Instrument Panel Weight (Was lighting)
Date: Oct 14, 1999
There actually is a lot less difference in the weight of the standard Van's panel and a .090 or .125 panel than the 1.1 pounds mentioned. When you make all the cutouts you actually have a lot less material than when you started especially for IFR birds like mine. Gary Fesenbek RV6A Dallas, TX ________________________________________________________________________________
Date: Oct 14, 1999
Subject: LRI
Listers, Of course during the last four days my digest version of the day's RV traffic twice would not open. That never happened before, but I believe that I have been able to follow the LRI conversation adequately enough using the search engine. We have not been challenged quite like this previously, to produce the technical work underlaying the LRI. We will do our best to make everything we have available to you. One idea is to send copies of flight test data to Brian Lloyd rather than to weigh down the list with lengthy documents. I hope to respond here to many of the questions that have been directed our way, but give me a couple of days and then maybe we can have another go at it. To the question of high wing loading and accelerated stalls, I can only reply that in fact the LRI does give true readings - the best explanation that I can give for that at the present time is, in one word - magic. Jim Huntington jimrhunt(at)wco.com 1 (888) 310-4574 ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Re: Angle-of-Attack( Non recoverable corner)
In a message dated 10/14/99 11:27:02 AM Eastern Daylight Time, dirtrider(at)qnet.com writes: << Additionally, if you are using the AOA to hold max rate of climb, to look cool for the guys, think about what happens when the engine quits at 150 feet with your nose pitched up at 40 degrees. You can't recover!!! Next time you see a Rocket guy getting 5000 FPM rate of climb off the deck, think about it. If the engine quits before he gets high enough to recover you can get a good deal on aluminum scrap and maybe a used "Lift Gauge". Go up to 5000 feet and try it. >> Been there done that except in an UL. I have preached to my students not to climb out on the prop of high horsepower to weight vehicles and a 54HP Kolb Firestar certainly falls in that category.( Don't laugh, It grosses at less than 400 pounds with a lightweight pilot) and it has absolutely no momentum and very high drag. I was demonstrating how you have to push over very hard and hold it nose down to the very last minute to have enough velocity to flare. Ops started just a wee bit early and there was not a darn thing I could do when I pushed over I realised it was not going to get enough speed before running out of that precious commodity called altitude. I did not feel that going to power was a solution and rode it down till the last minute and hauled back. It almost got the rate of decent slowed but not quite. It wiped the gear legs off and I was not hurt, but was very embarassed. It was an expensive $ demo to prove my point that there is a corner with no escape. AOA is good, but useless in this situation. Bernie Kerr 6A finishing SE Fla ________________________________________________________________________________
Date: Oct 14, 1999
>time you see a Rocket guy getting 5000 FPM rate of climb off the deck, think >about it. If the engine quits before he gets high enough to recover you can >get a good deal on aluminum scrap and maybe a used "Lift Gauge". Go up to >5000 feet and try it. I did try it in my Tiger when I was trying to determine whether it was possible to turn back to the runway after an engine failure. I was climbing at Vx and I had to push *right now* and push hard (zero G at least) to avoid a stall. Something like a rocket with that big prop providing lots of drag might be a bit dicey even if you were at Vy. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax ________________________________________________________________________________
Date: Oct 14, 1999
Flaking of the primer can be the result of too much dry film thichness. This type of primer should be only 3 or 4 mils thick. Not more than 5 or 6 mils. (or 1/2 of a thousandth of a inch.) DaleEnsing 6A FWF ________________________________________________________________________________
Date: Oct 14, 1999
In a message dated 10/13/99 8:30:31 PM Eastern Daylight Time, lolson(at)doitnow.com writes: << Has anyone heard of cutting down the seat back height on a RV6? Got a local -6 pilot that swears if I don't do it now, I will later. I'm building a slider. Any thoughts? >> Your friend is right. I cut mine after a few hours. Makes access to baggage compartment much easier and doesn't detract from seat comfort. Phil Rogerson 6A flying Fernandina Beach, FL ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Matronics List Idea)
> >Hey Matt > >Can we get another list created for AOA? : ) This is actually a good idea. There is a list dedicated to avionics that our late Don Corbitt started. That is probably the place to discuss aircraft instrumentation. We were all kibutzing with Don about his super-duper engine monitor and talking about how to do glass cockpits for GA aircraft when he met his untimely end. We have kept the list alive and there is all sorts of avionics discussions there. Recent discussions have been about AoA, including a very interesting mathematical analysis of the LRI vs. the PSS AoA, and rewiring old spam cans, just to give you an idea of the range of topics. If anyone wants to subscribe over there I believe you send email to majordomo(at)awpi.com and place the words "subscribe avionics" in the BODY of the message. It isn't as nice and fancy as Matt's mail server but it works. Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Cornering speed (was: Non recoverable corner)
> > ... Ops started just a wee bit early and there was not a darn thing I >could do when I pushed over I realised it was not going to get enough speed >before running out of that precious commodity called altitude. I did not feel >that going to power was a solution and rode it down till the last minute and >hauled back. It almost got the rate of decent slowed but not quite. As strange as it may seem, sometimes adding power at low altitude when pointed at the ground is the correct thing to do. You want to get the airplane as quickly as possible to "cornering speed," that speed which will produce the smallest radius turn or pullout. BTW, it is a good idea to know what cornering speed is *BEFORE* you get into this situation. >It wiped >the gear legs off and I was not hurt, but was very embarassed. It was an >expensive $ demo to prove my point that there is a corner with no escape. AOA >is good, but useless in this situation. It is certainly possible that you did put yourself into that unrecoverable corner but it is also possible that a shot of power might have made the difference. Now that I have opened my mouth, does anyone know how to calculate cornering speed without having to go out and try several turns/pull-ups to determine the speed experimentally? Brian Lloyd Lucent Technologies brian(at)lloyd.com 3461 Robin Lane, Suite 1 http://www.livingston.com Cameron Park, CA 95682 +1.530.676.6513 - voice +1.530.676.3442 - fax ________________________________________________________________________________
Subject: Re: Metalic Paint
Date: Oct 14, 1999
> > > Hey Norman, what is Sunfire (Poly, Enamel)? I have always been a PPG guy but the > Sherwin Williams guys really impressed me at Sun N Fun.I didn't get anything on > Sunfire. Great info material available on Acry-Glo and Jet-Glow. If any of you > are new to the paint world it would be beneficial to call SW and get an info > packet on Jet-Glow. Takes you step by step through the paint process. I learned > from PPG by screwing it up, stripping it and doing it again. Sherwin Williams Sunfire is an acrylic urethane. This is a single stage paint which will give one of the lightest weight applications. In solid colors it is very easy to wetsand for the perfect mirror finish. Metalics are a what you see is what you get situation. A pro in a real spray booth can make it look first class with two coats. They have quite a selection of colors. I am using a pure bright white on all of mt metal parts and my wings/fuselage while I am considering a metalic dark blue for trim and lower fuselage. They let me play with their paint code system and design my own color. I had them mix small quantities of it to take home and try out. On the third try I did my car. I am very happy. Soon my plane will probably match it. Regards, Norman Hunger RV6A Delta, BC. ________________________________________________________________________________
Subject: Static System Ports
Date: Oct 14, 1999
I have the static system kit from Van. How do the rivit ports mount? Do I just glue them in or do I pop the rivit? Also, I am intending an alternate static source that is just a 1/4 inch fuel on/off valve. I will "T" it into the system so that alternate cabin air is on when it is opened. I have heard that the instrument calibration guys love to have a place to tap in their instruments when they calibrate the altimeter. What size and type of fitting should I install to make these guys happy? If I did this at the low point of the system would then my alternate static source also be a drain point for the system? Is this a good way to do this? Is my fuel valve a good idea? Thanks, Norman Hunger ________________________________________________________________________________
Subject: Re: Static System Ports
Date: Oct 14, 1999
>Is my fuel valve a good idea? > >Thanks, >Norman Hunger Norman, I also put in an alternate static source that will be easy for the technician to connect to. I used a plastic tube as the static line, tee off at the low end behind the panel, and the end of the tube is pinched shut with a plastic tube clamp. This is a nylon (?) clamp that pinches the tube shut. It is held closed with serrations gripping the pawl. Very cheap and weighs nothing. Available at plastics stores, believe I bought mine from AIN Plastics, years ago. I have many left and will mail you one, if so desires. I am not yet flying so I can't give a flight report. Rick Caldwell RV-6 #24187 wings on, fitting flap control rods Melbourne, FL ________________________________________________________________________________
Subject: Sunfire Paint
Date: Oct 14, 1999
I second Norman's advice on Sunfire paint...It is virtually bulletproof, looks and sprays excellent. It is also available as a base/clear application as well. You can get any color mixed that you like, based on automotive formulas. They don't market it to aviation, but it is their strongest paint that they make, and IMHO, should be marketed as their aviation paint. Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit -----Original Message----- From: Norman Hunger <nhunger(at)sprint.ca> Date: Thursday, October 14, 1999 8:23 PM Subject: Re: RV-List: Metalic Paint > >> >> >> Hey Norman, what is Sunfire (Poly, Enamel)? I have always been a PPG guy >but the >> Sherwin Williams guys really impressed me at Sun N Fun.I didn't get >anything on >> Sunfire. Great info material available on Acry-Glo and Jet-Glow. If any of >you >> are new to the paint world it would be beneficial to call SW and get an >info >> packet on Jet-Glow. Takes you step by step through the paint process. I >learned >> from PPG by screwing it up, stripping it and doing it again. > > >Sherwin Williams Sunfire is an acrylic urethane. This is a single stage >paint which will give one of the lightest weight applications. In solid >colors it is very easy to wetsand for the perfect mirror finish. Metalics >are a what you see is what you get situation. A pro in a real spray booth >can make it look first class with two coats. > >They have quite a selection of colors. I am using a pure bright white on all >of mt metal parts and my wings/fuselage while I am considering a metalic >dark blue for trim and lower fuselage. They let me play with their paint >code system and design my own color. I had them mix small quantities of it >to take home and try out. On the third try I did my car. I am very happy. >Soon my plane will probably match it. > >Regards, >Norman Hunger >RV6A Delta, BC. > > ________________________________________________________________________________
Date: Oct 14, 1999
> > Norman, I also put in an alternate static source that will be easy for the > technician to connect to. I used a plastic tube as the static line, tee off > at the low end behind the panel, and the end of the tube is pinched shut > with a plastic tube clamp. This is a nylon (?) clamp that pinches the tube > shut. It is held closed with serrations gripping the pawl. Very cheap and > weighs nothing. Available at plastics stores, believe I bought mine from > AIN Plastics, years ago. I have many left and will mail you one, if so > desires. I am not yet flying so I can't give a flight report. I'm planing on using the fuel valve because it has a nice handle. That way it can be mounted and placarded properly and used in flight as an aletrnate static source. I am quite sure (but not positive) that all of this is required by Transport Canada for IFR flight. The valve must be visible, functional, and placarded to be legal for IFR. It is one of numerous examples of how our country demands stiff standards for homebuilts. If the valve is "T'd" off the low point in the system, with the valve pointing down, then it should serve as a drain during pre-flight. If the aircraft is ever parked outside in the rain with the wind hitting the side is there a possiblity of rain entering the port on the upwind side? It rains alot here on the West Coast. Regards, Norman PS - Rick, thanks for the offer anyway. ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Re: Experimental AOA?
The 'offending' issue is January 1979, page 43. article is Craftman's Corner by Ron 'Scotty' Scott. And that refers back to a publication of the chapter 124. In essence, it mounts, rather cleverly I think, a piece horizontally to a pitot tube. The tube is horizontally divided in half. Gert VP4SkyDoc(at)aol.com wrote: > > > In a message dated 10/14/1999 7:40:59 AM Tokyo Standard Time, gert@exec > > You know, I am looking at an old EAA magazine, which has an article just > > exactly what you proposed. > > > > A airspeed indicator and a mast under the wing. So how can this be > > patented (asi and mast) when the idea has around way back in the 80's > > > > Gert > > Well, I guess I should just let it die, but this is fun. Thanks Gert. Which > issue is that? More importantly, did it work? After thinking about it, with > an ASI used with an LRI type mast, this critical calibrated angle (either > stall or 'zero lift reserve' - which ever you calibrate it for) will occur > when the ASI drops to zero (ie both ports are at equal pressure). Since > ASI's are not very accurate less than 35-50 kts I am starting to wonder if > this is the best Idea. Besides, I didn't really like the idea of something > sticking out in the wind. > ------------------------------------------------------------------------ Pursuant to US Code, Title 47, Chapter 5, Subchapter II, '227, any and all nonsolicited commercial E-mail sent to this address is subject to a download and archival fee in the amount of $500 US. E-mailing denotes acceptance of these terms. ------------------------------------------------------------------------ ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Re: Cornering speed (was: Non recoverable corner)
> >Now that I have opened my mouth, does anyone know how to calculate >cornering speed without having to go out and try several turns/pull-ups to >determine the speed experimentally? > >Brian Lloyd Lucent Technologies Simple answer - Multiply the one g stall speed by the square root of the max allowable g loading. Complicated answer - You really need to be dealing with calibrated airspeed, not indicated airspeed. And it varies with weight too. CS=VS*sqrt(n*W/(max W)) CS = corner speed at a given weight, in calibrated airspeed VS = stall speed at gross weight, in calibrated airspeed n = load factor W = weight Bring that CJ-6 up here and we'll do a flight test program :-) Kevin Horton RV-8 (wings 85% done) Ottawa, Canada http://www.cyberus.ca/~khorton/rv8.html http://www.cyberus.ca/~khorton/nojpi.html - No JPI stuff in my aircraft! ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Re: Sunfire Paint
> >I second Norman's advice on Sunfire paint...It is virtually bulletproof, >looks and sprays excellent. It is also available as a base/clear >application as well. You can get any color mixed that you like, based on >automotive formulas. They don't market it to aviation, but it is their >strongest paint that they make, and IMHO, should be marketed as their >aviation paint. > >Paul Besing >RV-6A (197AB) Arizona >http://members.home.net/rv8er >Finish Kit I assume that Sunfire is comparable to PPG Concept? Are there any painters on the list who have sprayed both and can compare the two? Ive sprayed some Concept and found it relatively easy to deal with. However as a novice painter I'm willing to accept any crutch that I can. If there is an advantage to using the Sunfire in the ease of use or recovery from error department I would switch. Mike Wills RV-4 canopy willsm(at)manta.spawar.navy.mil ________________________________________________________________________________
Subject: Sunfire paint
Date: Oct 14, 1999
Sherwin Williams also makes Acry Glo anybody with experience with it. Almost sounds the same as the Sunfire. Chris ________________________________________________________________________________
Date: Oct 14, 1999
Subject: [Fwd: Tail wheels]
Received the following from Owen at Andair regarding the tailwheel problem. Steve Hamer MBOX-Line: From andair.co.uk!andair Thu Oct 14 17:20:26 1999 remote from mail via smail with P:smtp/R:bind_hosts/T:smtp-filter (sender: ) (Smail-3.2.0.105 1999-Mar-3 #3 built 1999-Mar-26) From: "andair" <andair(at)andair.co.uk> Subject: Re: Tail wheels Date: Thu, 14 Oct 1999 17:21:21 +0100 Dear Steve, I am sorry to hear you have had a problem with your tail wheel. We have approx.., 60 wheels in the field now. We want to offer a solution. We are prepared to do what it takes to help customers that have had problems with the tailwheels. Could you please post this on the RV-List and we will respond as quickly as possible to any further problems. Below is a brief description of our testing/conclusions to date. On the test aeroplanes here in the UK (we have 4 aeroplanes that are carrying the pneumatic tyre tailwheel 2, with 7in and 2 with 6 in.. Sometimes all run with 6 in for a certain experiment) so far we have logged about 20 hours on each. My own aeroplane has almost 100 hours now on various pneumatic tailwheels. Now the problems we have had: The tyre first used was only 4 ply and this was found to be unsuitable,it was too light in construction, Tyre manufacturers were consulted and a 6 ply tyre was produced. The static loading on the tyre was tested to over 200 lbs. and the working pressure was raised to between 60 and 90 psi on the test aeroplanes. The difference between to two pressure is preference to 'ride'. We have had several failures on the test aeroplanes, all have been investigated and I list them below for you to see. 1. RV6 (7in) rolled off the rim ( rim design changed) 2. RV6 (6in) 3 flights all the tread pattern destroyed down to the canvass but this did not deflate. The cause was, the tailwheel assembly was (out of line) and caused the tailwheel to shimmy, this seems to be a common problem, to produce a tailwheel assembly where the pivot pin is truly vertical, and carries the wheel assembly at 90 deg. to the ground. This is very important because it offers the wheel to the ground at the correct angle to prevent shimmy and makes turning easy. If the tail spring has been accidentally bent in a possible firm landing and is not returned to its former angles then a completely new set of rules take over, this is not generally noticed when the solid tyre is in use. 3. RV4 ( 6in) the aeroplane was pushed at speed over a steel channel at the entrance to the hanger, the tail pitched up and landed back down on the rib of the other channel. It was found to have pinched the tyre between the cover and the rim. This tyre was inflated to approx.. 40 psi 4 (RV6) (7in and 6in) I have destroyed two 7in and one 6in tyres in tests on my own RV and the conclusions, drawn from my experiences and all of the test aircraft pilots are as follows: The tailwheel assembly has to be in good condition, by that I mean it has to be at the correct angle (90 deg.) to the ground. If free castoring then the detent for the forward lock needs to be working correctly i.e. to put the wheel in the centre position and hold it there during takeoff and landing. The same applies to tailwheel assy with rudder springs the wheel must not be allow to scoot or shimmy' (apply an increase loading to the nut, to stiffen the resistance to turning of the wheel) Finally the inflation of the tyre. The most failures of the pneumatic tyre seem to be the pressure that was in the tyre prior to destruction. My own conclusions are on the tyres I was running, as the pressure was reduced ( to decrease the bumps, to smooth out the taxi ride) from 60 psi or 80 psi down to 30 psi there became a point when the side walls could no longer sustain the weight of sudden changes in loading. >From our tests (and they are continuous, we are all running pneumatic tyres) the most important point is to maintain a pressure at approx. 60 to 80 psi This we feel is close to the optimum pressure. With the conclusions that we have drawn from the above, if the tyre is inflated to a pressure below 60 PSI there is a strong risk of failure. We see no reason that the rubber tyres have been made to an unsatisfactory standard as our tests here in England have been VERY brutal (i.e. hard landing on all sorts of different surfaces). The total hours on As to the failures that have happened if the field, we will supply all parts ie tyres and tubes and also wheel hubs where they have been damaged due to punctures, free of charge. We would like to see the damaged wheels returned to us, for us to take what ever action is needed for the future. It has been brought to our attention that there are 4-5 failures out in the field. Yours Sincerely Owen Phillips. andair(at)andair.co.uk --- www.andair.co.uk Andair Ltd. Unit 3 25c Brockhampton Lane, Havant Hampshire PO9 1JT England Fax +44 1705 473946 --- Tel +44 1705 473945 -----Original Message----- From: Steve Hamer <shamer(at)mscomm.com> Date: 13 October 1999 05:33 Subject: Tail wheels >Owen, > >I recently purchased your tail wheel for my RV-4. It's a very nice >product both in looks and performance. The quiet ride is nice. >However, after a half dozen flights it went flat and will not hold >air. I don't know if you moniter the RV list, but there are three or >four others who have had the same experience with bad tubes. >I thought you would want to be aware of this so you could respond before >your tail wheel gets a bad reputation. If you aren't on the RV list, I >would be happy to post your response to the masses. >Are you aware of other tube failures and if so, do you have a fix in the >works? Will you provide new tubes to those of us who have had short >term failures? >I hope to hear from you soon. > >Sincerely, > >Steve Hamer >shamer(at)mscomm.com > > ________________________________________________________________________________
Subject: Re: Painting Info
Date: Oct 14, 1999
The mottling effect when shooting metalic paints is caused by the paint not being mixed throughly. If you put a couple of marbles in the gun and give it a little shake at the end of every couple of passes the paint will stay pretty well mixed. Some professional guns have a mixing arm built in to take care of this problem. Dave Bristol, RV6 finishing paint and upholstry, Los Angeles area -----Original Message----- From: Eric.J.Henson(at)chase.com(Content Technologies SMTPRS 2.0.15) with SMTP ; 13 Oct 1999 08:51:48.-0400(at)matronics.com <13 Oct 1999 08:51:48.-0400(at)matronics.com> Date: Wednesday, October 13, 1999 5:54 AM Subject: Re: RV-List: Painting Info Technologies SMTPRS 2.0.15) with SMTP id for ; > > >Sam Buchanan on 10/12/99 08:00:55 PM > >Please respond to rv-list(at)matronics.com > > >To: rv-list(at)matronics.com >Subject: Re: RV-List: Painting Info > > >Sounds like mottling (dark color stripes in the spray pattern near the center of >the pattern). Not enough pressure or too cold a temp. for the paint reducer. I >fought a hell of a battle with this with PPG Delstar (Acry Enamel). Finally >found that if you choke down your guns needle somewhere between a fog/tack coat >and a light coat and drop your normal pattern to only 1/3 your normal pass, you >can eliminate this problem. Takes some trial and error. Helps to hold a strong >light with your other hand so you can see the moment the paint flows, since it >takes a few passes for this to happen. I don't know why, but this leave no >orange peel. I thought it was a neat trick that might help someone out in the >future. > >Eric Henson >Installing Tail Wheel Mount > > > However, I wonder if the truly >novice painter has any business using metallic paints. A local RV'er >used metallic single stage paint and it was very difficult to keep the >metallic application uniform. > >Sam Buchanan > >---------------- > >Norman Hunger wrote: >> >> >> > However, I soon discovered that it really didn't matter because there is >> > something available to every painter that will take care of dust >> > specks..............1500 grit sand paper. >> > >> >> > There are almost no paint flaws that can't be sanded out with 1500 paper >> > and buffing compound. If you use a single stage paint, then get the >> > paint on the best you can and resolve to perfect the finish after the >> > fact. >> >> CAUTION - Most single stage metallic paints cannot be sanded at all without >> exposing the metallic flakes as little silver spots. Looks terrible. If you >> must have a metallic, basecoat clearcoat is easier to apply. You can wetsand >> the clearcoat for a perfect finish. There are differences between the many >> different brands of paints though. >> >> The original post refers to solid colors and is very good information on >> that topic. Check out his webpage to see the fine paintjob he now has. >> >> Single stage metallic paints require good booths. Wet down the walls and >> floor just before pushing in your project. Never wet down the roof, just >> blow it off with high pressure air before the wetdown. Paint the wings one >> at a time. Build racks for them with wheels on the bottom. >> >> The new HVLP sprayers do much nicer work because they have a much higher >> percentage of the paint applying to the surface than the old styles of spray >> guns. It is the overspray that is the dust problem. The old guns make tons >> of it. HVLP sprayers use less paint as a result. They are more efficient. >> You will not need as much paint. If you invest in a good name brand system >> you should be able to sell it when you are done for at least half of what >> you paid for it. >> >> Norman Hunger >> RV6A Delta,BC >> > > ________________________________________________________________________________
Date: Oct 14, 1999
D. Walsh: I had a 1/4" offset in my last RV-6, which I liked very much. But as you said it is only good for one speed. Mine worked very well for about 65% to 70%. I am at a dilemma as too offset my present project or not. I might just offset 1/8" for experimental purposes. Harvey Sigmon - RV-6AQB- Vertical Stab install. ----- Original Message ----- From: <BumFlyer(at)aol.com> Sent: Thursday, October 14, 1999 9:42 AM Subject: Re: RV-List: vertical fin offset > > > In a message dated 10/13/99 23:58:21, bogeybrother(at)earthlink.net writes: > > > Sorry, I've been trying to stay out of this discussion but I cant. I offset my > vertical 3/8" off center and my Rv flys feet off at 190 indicated. Cool eh? > there's more, any speed below or above requires a little rudder input to > center > the ball. Conclusion: any adjustment you make will be accurate only for a > small > range of airspeeds. Good luck. > Tom >> > > Shucks I have been trying to stay out too. But I have another question for > the aerodynamiologists. > > It seems to me the offset would indeed only be good for one speed ( as would > a bias spring). On the other hand the tab would be seeing more air at a > greater speed and put in more rudder etc, so maybe would have a larger range > of effectiveness. If so it would be another plus for the tab.(ugly, one ea.) > > My intuitive stabs are sometimes woefully wrong so let's hear from those less > aero challenged. > > D Walsh > > ________________________________________________________________________________
Date: Oct 14, 1999
In a message dated 10/14/99 3:48:25 PM Eastern Daylight Time, brian(at)lloyd.com writes: << It is certainly possible that you did put yourself into that unrecoverable corner but it is also possible that a shot of power might have made the difference. >> Maybe soo!!! But have you ever flown an UL, try this at altitude and see how steep the attitude is. UL's of this nature will not even lose altitude at full throttle and the stick full aft. They will stall and recover on the prop with positive attitude so I preach power out of bad situations and it might have been the proper thing but my gonads were not that large at the time. Bernie Kerr, 6A finishing details, SE Fla ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Re: Sensenich 72FM8S16 Prop
When the Van's catalog was published, it DID contain the most current information on props; the info changed after 10,000 copies were printed. D'oh! A new edition, now well underway, will contain the correct information from Sensenich. BTW: The new catalog is only 1 (one) of 3 (three) things that are "Coming to the Web...it's what you've been waiting for," only it looks like they've been pushed back to Nov 15 instead of the 1st. Sorry :-( Have a great day, ~Jeremy jwb(at)europa.com Disclaimer: I speak for myself only, not my clients. "D'oh!" as said by Homer Simpson, is probably trademarked, copyrighted, and patented by Fox. :-) >> They said the >> very first such prop they experimented with was 81" pitch, but they >> recommend 83" as a better compromise. They wish Van would change his >> catalog to show the 83" prop instead. ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Re: Prepping skins without removing alclad
In a message dated 10/13/99 7:57:42 PM Central Daylight Time, Larry(at)bowenaero.com writes: << I've been using the Sherwin-Williams GBP988 since the beginning of my project. In general, it's worked great. However, when I dimpled some of the wing ribs, the primer began to flake off where the dimple die made contact. Has this happened to anyone else? Any idea why? >> You didn't say if you where using Scotch Brite to treat the skin. Always use the Scotch Brite and use lacquer thinner to clean the oil (from your hands) off. ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Re: Rear Pins on Sliding Canopy
In a message dated 10/5/99 7:12:12, smcdaniels(at)juno.com writes: << I always listen very carefully to what Tom says, but, I do enlarge these holes slightly. One of the problems with machining/drilling UHMW plastic is that it can creap/distort. Drilling a hole with a 1/4 " drill doesn't usually leave you with a 1/4 " hole (try and slip the drill bit in to the hole after drilling it and you will see what I mean). I use a drill index of number and letter indexed drill bits to go up slightly in size to get a slip fit as required. I then use a tapered reamer or a counter sink cutter and counter bore the outer portion of the hole to give the pins something bigger to aim at (the canopy can move around quite a bit when it is opened because of prop blast / gusty winds / etc.)when it is being closed. You will still have a close fit on the pin in the lower portion of the hole (still meeting Tom's recommendation). Scott McDaniels >> P. P. S. 1. Always listen to what Tom says. 2. Always do what Scott McD says. D. Walsh ________________________________________________________________________________
Date: Oct 14, 1999
Subject: fly-in
all flyers-please try to come to the fly-in at pineville la.municipal on oct.23.for more info call terry myers at 318-448-3934. ________________________________________________________________________________
Subject: Re:
Date: Oct 14, 1999
Thanks, Fred. You are probably right, but I have been humbled before by things I didn't think would work that did. What I really don't like about the .090" pins is that the hinges have a LOT of slop, and hence the stress is distributed mostly at the ends. I have FEP heat shrink, which is almost as slippery as teflon, and fairly abrasion resistant. Ask me in a few years... Alex ---------- > From: Stucklen, Frederic IFC <stuckle(at)ifc.utc.com> > To: 'RV-List' > Subject: > Date: Thursday, October 14, 1999 8:06 AM > > > Alex, > > Can't say that I remember doing anything special with the stock hinges > prior to riveting them into place. At the time, the prospect of cracks > forming in the sharp radius corners wasn't high on the priority list, or > even considered a problem. I would think that it wouldn't hurt to radius > these areas, but from my own personal experience, I'm not sure that it would > have help prevent what little breakage I've had. Most of my breakage has > occurred at the ends of the pin travel..... > > Putting shrink tubing onto the top cowl .090" steel pins may work OK > initially, but I suspect that after very little use, the surface of the > shrink tubing will deform. This would result in a hard to remove pin, and > almost impossible to insert pin. The original promise of an undersized pin > was to enable the pin to form to both the straight run hinge sections as > well as the curved areas. I suspect that the increased diameter pin would be > very difficult to insert. > > Fred Stucklen > N925RV RV-6A > E. Windsor, Ct > > > > ____ > From: "Alex Peterson" <alexpeterson(at)usjet.net> > Subject: Re: RV-List: Cowl Attach-Vibration > > > > Fred, out of curiosity, did you happen to radius the factory sharp > corners > which are built into the hinges? > > I don't know what the result will be as I'm not flying yet, but I > took an > 1/8" diameter file to each corner in the hinge, obliterating the > original > sharp corner left from the stamping. These hinges are poster parts > for > stress risers leading to fatigue in their supplied condition. > > Additionally, I will be experimenting with covering the .090" steel > pins > used on the top hinges with heat shrink tubing, to bring the outside > diameter up to about .125", to eliminate a lot of the slop without > increasing stiffness much (can't take credit for the idea). I'll > report as > I learn... > > Alex Peterson > Maple Grove, MN > > > > > > > > ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Re: RV8-List Digest: 10/13/99
i'm just starting to think and plan my elec. sys. for the rv-8. right now it seems to be overwhelming. is there a step by step process of where to put this or that and whatever. i want to start with the battery and the ground bloc, but are they going to be in the way of something else later on? is there a simple plan? i've always believed in the kiss plan and i just don't see it yet. thanks for your help!!!!!!!!!!!!!!!!.............ed 80127 ________________________________________________________________________________
Date: Oct 14, 1999
Subject: plumb line holes in wing spars-help-
rv-6 i understand the crosswise measurements for the holes.could someone explain the lengthwise measurements.are the holes drilled thru the main spar web and the tank mount web also? how do you end up with equal lengthwise holes on both spars? tcrv6(at)aol.com ________________________________________________________________________________
Date: Oct 14, 1999
Subject: fly-in-please read
all flyers please try to come to the fly in at the pineville la. municapal airport on oct. 23.for more info call terry myers at 318-448-3934. ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Re: RV8-List: Re: RV8-List Digest: 10/13/99
Ed, I felt the same way when I was at that point. I first concentrated on my instrument panel. If you have vacuum instruments, this will take up alot of room with hoses and regulators and such. Wiring can be planned around these items. I have the battery in the forward location as per Van's plans. Van's has a wiring schematic for the RV-8 but they don't advertise it. It comes with the wiring kit they sell. The wiring schematic shows many wire runs and answers questions like where to cut a hole in the F-806 web. It helped me. Joe Czachorowski #80125 SALNED2131(at)cs.com wrote: > --> RV8-List message posted by: SALNED2131(at)cs.com > > i'm just starting to think and plan my elec. sys. for the rv-8. right now it > seems to be overwhelming. is there a step by step process of where to put > this or that and whatever. i want to start with the battery and the ground > bloc, but are they going to be in the way of something else later on? is > there a simple plan? i've always believed in the kiss plan and i just don't > see it yet. > > thanks for your help!!!!!!!!!!!!!!!!.............ed 80127 > ________________________________________________________________________________
Date: Oct 14, 1999
Sherwin Williams Sunfire is also "almost" bullet proof. I did my engine mount in a light gray. It goes on easy (as easy as it can when doing tubing) and has a great looking finish. You have to buy Sunfire from the Sherwin Williams Automotive stores. The local SW home paint stores don't carry it. I also used their acid etch two part primer (I think it is also on my QB6) and an adhesion promoter (UltraFil II). The primer and promoter went on with 30 minutes dry time each and then I shot the Sunfire. I was also considering it for the entire aircraft. I know Norman Hunger will get his done first and I hope he posts the results. Gary Palinkas QB6 control systems (wanted to paint a few things before winter in Ohio sets in) Parma, Ohio In a message dated 10/14/99 3:29:59 PM, nhunger(at)sprint.ca writes: <<> > Hey Norman, what is Sunfire (Poly, Enamel)? I have always been a PPG guy but the > Sherwin Williams guys really impressed me at Sun N Fun.I didn't get anything on > Sunfire. Great info material available on Acry-Glo and Jet-Glow. If any of you > are new to the paint world it would be beneficial to call SW and get an info > packet on Jet-Glow. Takes you step by step through the paint process. I learned > from PPG by screwing it up, stripping it and doing it again. Sherwin Williams Sunfire is an acrylic urethane. This is a single stage paint which will give one of the lightest weight applications. In solid colors it is very easy to wetsand for the perfect mirror finish. Metalics are a what you see is what you get situation. A pro in a real spray booth can make it look first class with two coats. They have quite a selection of colors. I am using a pure bright white on all of mt metal parts and my wings/fuselage while I am considering a metalic dark blue for trim and lower fuselage. They let me play with their paint code system and design my own color. I had them mix small quantities of it to take home and try out. On the third try I did my car. I am very happy. Soon my plane will probably match it. Regards, Norman Hunger RV6A Delta, BC. >> ________________________________________________________________________________
Date: Oct 14, 1999
By definition cornering speed is the speed at which you generate the highest turn rate, which happens to be the lowest speed at which you can generate the limit load your airplane can take. So for an RV, the stall speed at 6 G's is ~2.4 times clean stall or about 135 mph. It is hard to generalize about the best tactic for low airspeed, low altitude recoveries except don't get yourself into that fix. Back in my youth I flew airplanes and maneuvers where it was important to not rush raising the nose, sometimes using afterburner to maintain speed even going straight down. But other than not pulling into an accelerated stall on the backside a loop, it is hard to imagine getting myself into that kind of a hole the way I fly now. BTW, a local pilot, young and very talented, killed himself doing a loop in a Midget Mustang about 8 years ago by stalling on the backside of a loop begun at about 100 feet. Maybe I am just getting old, but large pitch attitudes and low altitudes just don't go together anymore. Jim Van Laak RV6 N1KJ ________________________________________________________________________________
Date: Oct 14, 1999
I second Norman's advice on Sunfire paint...It is virtually bulletproof, looks and sprays excellent. It is also available as a base/clear application as well. You can get any color mixed that you like, based on automotive formulas. They don't market it to aviation, but it is their strongest paint that they make, and IMHO, should be marketed as their aviation paint. Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit ________________________________________________________________________________
Date: Oct 14, 1999
Subject: SW products (was: Prepping skins without removing alclad)
I usually don't scotchbrite, as I take "self-etching" to mean just that. Am I assuming too much? Also, I clean thoroughly with the SW product recommended on the primer can - I don't recall it's name off the top of my head. I was in the SW store this afternoon and posed this question to the help there. He said it sounded like inadequate cleaning. Next time I'll more diligent and change the cloth more often; we'll see if that helps. They did have a new cleaning product in the store. It was a package of presoaked cloths sort of like baby-wipes. Just wipe and toss. I decided against them for the time being. They were $18 for a pkg of 50 cloths. I also asked about Sunfire. He reiterated all that has been said here recently, except there is an even stronger, newer product called Genesis, I think, that is even better. I didn't get the details. Cheers, Larry Bowen RV-8 wings Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of > MRawls3896(at)aol.com > Sent: Thursday, October 14, 1999 8:15 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Prepping skins without removing alclad > > > In a message dated 10/13/99 7:57:42 PM Central Daylight Time, > Larry(at)bowenaero.com writes: > > << > I've been using the Sherwin-Williams GBP988 since the beginning of my > project. In general, it's worked great. However, when I dimpled some of > the wing ribs, the primer began to flake off where the dimple die made > contact. Has this happened to anyone else? Any idea why? > >> > You didn't say if you where using Scotch Brite to treat the > skin. Always > use the Scotch Brite and use lacquer thinner to clean the oil (from your > hands) off. > ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Re: MAC Trim Phone Not Working
> How are builders running the wires back to the tail? Do I need to > use a run of that black conduit or can I strap the bundle to a J stringer > every five inches? Because the only wire I had to run aft was to the Mac trim servo, I used the 6-conductor cable I got from Van's (p.32 in the catalog) and no black conduit. I used small plastic grommets to go through the bulkheads and plastic adhesive clips attached to the side skin above the J-channel to hold the cable in place. I'll see how the adhesive is holding up when I do my condition inspection in a few weeks. Bob Hall, RV-6, Colorado Springs ________________________________________________________________________________
Date: Oct 14, 1999
Subject: Re: plumb line holes in wing spars-help-
TCRV6(at)aol.com wrote: > > > rv-6 i understand the crosswise measurements for the holes.could someone > explain the lengthwise measurements.are the holes drilled thru the main spar > web and the tank mount web also? how do you end up with equal lengthwise > holes on both spars? tcrv6(at)aol.com > > The hole goes through the both spar webs in the root end. I drilled through the main and rear spar with a 3/64" bit at both ends. On the rear spar I made a cross-hair "+" on both holes. Each line of the "+" was 1/2" long. Then I drilled the rear spar holes to 3/16". I was more concerned with jigging the twist out of the wing using the "+" marks and then using a carpenter square to make sure the ribs were perpendicular to both spars. Also the skins help jig the wing lengthwise. If the skin is perfect on the 1" spar line and you can see the rib centers through the skins, the wing should be fairly jigged lengthwise. I used thread with a tiny washer tied to it on the top spar and a heavier washer on the bottom of the thread. Place the plumb weights in glasses of water and they won't swing in the breeze and drive you nuts! Jerry Calvert Edmond Ok -6 (leaving for SW regional "Big Country" fly-in Friday morn) ________________________________________________________________________________
Date: Oct 14, 1999
In a message dated 10/14/99 7:04:51 PM Pacific Daylight Time, SALNED2131(at)cs.com writes: << i'm just starting to think and plan my elec. sys. for the rv-8. right now it seems to be overwhelming. is there a step by step process of where to put this or that and whatever. i want to start with the battery and the ground bloc, but are they going to be in the way of something else later on? is there a simple plan? i've always believed in the kiss plan and i just don't see it yet. >> I've got an AutoCAD file that's got everything in my loaded 6A. It is easier to delete things that you don't need than add things. Let me know if you want it. -GV ________________________________________________________________________________
Subject: Re: RV6 - Cut down seat backs
Date: Oct 14, 1999
I saw an RV6A in Nashville TN this summer where the builder had located the electric flap mechanism over to the right side (passenger side) of the plane. He said you can do this, but only on the right side. I do not remember this gentleman's name, but if he on this list, maybe he can comment and tell us how he did it. Thanks. -----Original Message----- From: Mark Nielsen <Mark.Nielsen@fiedler-lp.com> Date: Thursday, October 14, 1999 1:14 AM Subject: RE: RV-List: RV6 - Cut down seat backs > >> >> Has anyone heard of cutting down the seat back height on a RV6? >> >> Got a local -6 pilot that swears if I don't do it now, I >> will later. >> >> Any thoughts? >> > >My seat backs are full height, and I like them fine. > >The only reason that I have heard for cutting them down is to make it >easier to reach things in the baggage compartment during flight. I have >found that instead of trying to reach over the seat backs, it is much >easier to reach between the seat backs. It is surprising how much of the >baggage compartment I can reach this way. I use the space between the >seat back and the flap torque tube to store items that I need during >flight (water bottles, lunch, AOPA airport directory, etc.). I can reach >this area behind either seat with ease, without any of the twisting and >turning (and resulting aerobatics) that is required to reach over the seat >back. Of course, this option is not available if you have electric flaps, >since the flap drive mechanism blocks the space between the seat backs. >Also, larger pilots with "Popeye" sized forearms may find this more >difficult. > >Mark Nielsen >RV-6, 445 hours >Green Bay, WI > > ________________________________________________________________________________
Date: Oct 14, 1999
And silly me, I was thinking of putting in head restraints in my RV6! Marty in Brentwood TN -----Original Message----- From: PhilipR920(at)aol.com <PhilipR920(at)aol.com> Date: Thursday, October 14, 1999 12:59 PM Subject: Re: RV-List: RV6 - Cut down seat backs > >In a message dated 10/13/99 8:30:31 PM Eastern Daylight Time, >lolson(at)doitnow.com writes: > ><< Has anyone heard of cutting down the seat back height on a RV6? > > Got a local -6 pilot that swears if I don't do it now, I > will later. > > I'm building a slider. > > Any thoughts? > >> >Your friend is right. I cut mine after a few hours. Makes access to baggage >compartment much easier and doesn't detract from seat comfort. > >Phil Rogerson >6A flying >Fernandina Beach, FL > > ________________________________________________________________________________
Date: Oct 14, 1999
For what its worth, I made a drill jig out of typical construction angle long enough to be able to span the rear spar length. That way I know the holes in the main and rear spar are exactly the same distance lengthwise. I then drilled some more holes in this measuring jig based upon the wing skin holes and use that to line up all my ribs. The main spar plumb bob holes were drilled with a #60 drill and lower holes drilled #30. I hot glued the thread in the main spar holes and also used the "cross hairs" approach on the rear spar (drill the rear spar #60 and put the cross hairs on before opening up the hole to #30). I like the idea of using large nuts for plumb bobs in cans of water. I work in an enclosed garage but the breeze does blow, even in TN once in a while. Marty in Brentwood TN, RV6 wings -----Original Message----- From: TCRV6(at)aol.com <TCRV6(at)aol.com> Date: Thursday, October 14, 1999 8:13 PM Subject: RV-List: plumb line holes in wing spars-help- > >rv-6 i understand the crosswise measurements for the holes.could someone >explain the lengthwise measurements.are the holes drilled thru the main spar >web and the tank mount web also? how do you end up with equal lengthwise >holes on both spars? tcrv6(at)aol.com > > ________________________________________________________________________________
Subject: Re: Sensenich 72FM8S16 Prop RV-6A
Date: Oct 14, 1999
My understanding is your prop will be full length at 72". The -1- means that the length is one inch less than the full prop diameter. If I am correct, maybe you will have the right prop afterall - Yipee. One can always cut the prop down, but I'm not sure of the limit for this prop. Sensenich can tell you. -----Original Message----- From: Chris Browne <cebrowne(at)earthlink.net> Date: Thursday, October 14, 1999 7:28 AM Subject: Re: RV-List: Sensenich 72FM8S16 Prop RV-6A > >Tom, > >Ed at Sensenich E-mailed about that, too. Van's also has the "-0-" wrong in the >part number, it should be a "-1". So, I currently have the wrong prop on >order. sigh ... > >Chris > >tom sargent wrote: > >> >> > >> >There are three pitches available for this prop. 81, 83, and 85. Van's >> >Catalog implies that the 81 pitch is the best choice for a 180 HP -6A. >> >Is anyone running the 83 pitch. If so, is it a good cruise prop? >> > >> >Chris Browne >> >-6A Finish >> >Atlanta >> > >> >> Chris: >> When I ordered my prop (I have the short cowl, so ordered the >> FM8S9) I ordered the 81" pitch because that was in van's catalog. Sensenich >> then called me to ask if that was what I REALLY wanted. They said the >> very first such prop they experimented with was 81" pitch, but they >> recommend 83" as a better compromise. They wish Van would change his >> catalog to show the 83" prop instead. I changed my order to the 83". I >> haven't flown with it yet, though. It's gonna be a while.... >> >> --- >> Tom Sargent, sarg314(at)azstarnet.com >> > > ________________________________________________________________________________
Subject: Tank leak testing
Date: Oct 14, 1999
I haven't seen this one on the list. In attempting to seal the fuel cap from leaking during your test, unscrew the bottom nut on the cap and then heat the cap to about 120 degrees - used my wife's hair dryer. Put lots of axle grease on the bolt under the nut and let sit. When cooled to room temp., tighten the nut. Make a filet of grease around the nut at the joint with the plate and around the threads to nut joint. Grease the "O" ring really well and insert in full neck. Lock down, and tape over. I was not able to get 3" tape and the 2" kept leaking, but final taping was by using a but joint with the first two with a third over the top on the butt joint. The heating allows the grease to flow and seal/stick better. Good Luck, your mileage may vary. For Me, NO LEAKS in one tank so far, Yippee!!! ________________________________________________________________________________
Date: Oct 14, 1999
Subject: LRI - a bit of back ground with more to come
"The Lift Reserve Indicator is designed so that: DP = q[Sin F - Sin B], where DP is the differential signal pressure, q is the dynamic presure of the relative wind, Sin F is the natural sine of the wind's impingement angle against the probe's vented plane surface 'F'. Sin B is the natural sine of the wind's angular incidence against the probe's vented surface 'B'. The angular input function is [Sin F - Sin B], which is arithmetically identical to DP/q." F is the forward face of the probe. B is the bottom surface of the probe. If I understand correctly what has gone on in previous discussions, this much has already been covered. "I think it is relatively easy to use and it is based upon sound engineering. It's a little different from an angle of attack indicator because what it does is indicate the proximity to the depletion of kinetic energy." I" found that I was able to land pretty precisely with it." Fenelon Taylor, Chief of Aerodynamics and Performance, Mooney Aircraft Corporation Jim Huntington jimrhunt(at)wco.com 1(888) 310-4574 ________________________________________________________________________________
Subject: RV6 - Cut down seat backs
Date: Oct 15, 1999
> > > ><< Has anyone heard of cutting down the seat back height on a RV6? > The reason not to cut the seat back down in the RV6 RV9 series is that it lowers the height of the shoulder straps. Canadian builders doing this will fail their final inspection if they have a sharp inspector who knows these airplanes. Can't speak for any one else but I have done alot of research on this topic as I have made changes to my luggage compartment that forced me to. The result of lower shoulder straps on an average height pilot is that in a collision involving deceleration the occupants vertebrae will get a compression force down because the shoulder straps are anchored on the longeron. This point is actually low for an ideal situation but those longerons are simply the strongest point in the rear fuselage. Van has engineered the solution by having the seat back at a certain height. This protects the occupants to a certain point. Tony talks about this in one of his books. Some one mentioned it on this list just a few months ago. Norman Hunger RV6A ________________________________________________________________________________
Date: Oct 15, 1999
> I saw an RV6A in Nashville TN this summer where the builder had located the > electric flap mechanism over to the right side (passenger side) of the > plane. He said you can do this, but only on the right side. I do not > remember this gentleman's name, but if he on this list, maybe he can comment > and tell us how he did it. Thanks. Second the notion. This sounds like a worthy idea. Norman ________________________________________________________________________________
Date: Oct 15, 1999
Subject: Re: AOA/LRI - Brian Lloyd
> > Nice try Dave, but in fact all you have proved is that for equal > pressure at the ports (p1=p2) the two ports are at the same angle > to the relative airstream (cos a = cos b). As this is one of our > starting assumptions anyway one would hope it would prove so! > > Please keep trying. We need to find out why this thing seems to > work at least a lot of the time. > Well, right, I wasn't fooling myself. The point is that if we accept the assumption that the pressure in the ports varies proportional to that ports incident angle (an assumption that we have not proven but everyone accepts), then there will be a particular AOA where p1 and p2 are equal regardless of airspeed. I suppose this is obvious but it had been neglected in the discussion I was responding to. > The $39 solution is available from http://www.dwyer-inst.com . The > Minihelic II Differential Pressure Gages (model 2-5002 or 2-5003) > should do the trick. Tim, thanks for the info! I will be glad to do some testing - but it will take a couple of years :-) > The 'offending' issue is January 1979, page 43. > article is Craftman's Corner by Ron 'Scotty' Scott. And that refers back > to a publication of the chapter 124. And thank you too, Gert. Is anyone going to comment on the PSS style of flush wing installation so we can get that probe out of the wind? :-) Dave Leonard 6QB ________________________________________________________________________________
(Content Technologies SMTPRS 2.0.15) with SMTP id for" ; Fri, 15 Oct 1999 08:11:09.-0400(at)matronics.com
Date: Oct 15, 1999
Subject: LRI & Landings
Something I was wondering about flying with the LRI. If someone has a "sweetspot" on the guage, lets call it the approach to flare mark, wouldn't your landings become more consistant since you are carrying the same amount of lift into the flare each time. Seems reasonable to me. Although long, this has been a very interesting thread, and good publicity. Of course being featured on the cover of the August Sport Aviation doesn't hurt either. Eric Henson ________________________________________________________________________________
Date: Oct 15, 1999
Well this isn't exactly correct. It is my understanding that the "-1" means you can shorten the prop *up to* one inch from the as delivered (new) length. That means if you ding the tips and everything else about the prop is okay, you can cut up to 1" off to correct the problem. What is not clear, is the 1" in total from both tips or from each tip making the total from the prop 2"? I would think it's in total but I don't know. ( ie: Shorten the prop 1" Vs. shorten each blade 1".) Anyone know? AL > >My understanding is your prop will be full length at 72". The -1- means >that the length is one inch less than the full prop diameter. If I am >correct, maybe you will have the right prop afterall - Yipee. One can >always cut the prop down, but I'm not sure of the limit for this prop. >Sensenich can tell you. > ________________________________________________________________________________
Date: Oct 15, 1999
Subject: Re: Tank leak testing
Emrath wrote: > > > I haven't seen this one on the list. In attempting to seal the fuel cap from > leaking during your test, unscrew the bottom nut on the cap and then heat > the cap to about 120 degrees - used my wife's hair dryer. Put lots of axle > grease on the bolt under the nut and let sit. When cooled to room temp., > tighten the nut. Make a filet of grease around the nut at the joint with > the plate and around the threads to nut joint. Grease the "O" ring really > well and insert in full neck. Lock down, and tape over. > > I was not able to get 3" tape and the 2" kept leaking, but final taping was > by using a but joint with the first two with a third over the top on the > butt joint. The heating allows the grease to flow and seal/stick better. > Good Luck, your mileage may vary. For Me, NO LEAKS in one tank so far, > Yippee!!! > The trick I used was to take one of the rubber gloves and cut a piece out of it large enough to tightly stretch over the part of the cap that has the o-ring in it. Sealed it right up! Jerry Calvert Edmond Ok -6 "head'n to SW Regional Fly-in this morning!" ________________________________________________________________________________
Subject: Sensenich 72FM8S16 Prop RV-6A
Date: Oct 15, 1999
Al and all, The 72FM8S( )-1 means the diameter is 71 inches when you receive it. If you have a tip strike, the propeller can be reduced a full 2 inches (who else can give you that in an aluminum prop?) to a 69 inch diameter and is still safe to fly. If a propeller shop were to reduce the diameter to 69 inches they should restamp the propeller as a 72FM8S( )-3- much the same way if they changed the pitch. Ed Zercher ________________________________________________________________________________
Date: Oct 15, 1999
From: "Silverstein, Chuck" <chuck.silverstein(at)lmco.com>
Check the length of the spars. When I built my wings, the rear spar was about 3/16 longer than the plans call for. Had some alignment problems and it took some head scratching to figure out what was wrong. Chuck S. RV6 fuse -----Original Message----- From: Emrath [mailto:emrath(at)home.com] Sent: Thursday, October 14, 1999 11:34 PM Subject: Re: RV-List: plumb line holes in wing spars-help- For what its worth, I made a drill jig out of typical construction angle long enough to be able to span the rear spar length. That way I know the holes in the main and rear spar are exactly the same distance lengthwise. I then drilled some more holes in this measuring jig based upon the wing skin holes and use that to line up all my ribs. The main spar plumb bob holes were drilled with a #60 drill and lower holes drilled #30. I hot glued the thread in the main spar holes and also used the "cross hairs" approach on the rear spar (drill the rear spar #60 and put the cross hairs on before opening up the hole to #30). I like the idea of using large nuts for plumb bobs in cans of water. I work in an enclosed garage but the breeze does blow, even in TN once in a while. Marty in Brentwood TN, RV6 wings -----Original Message----- From: TCRV6(at)aol.com <TCRV6(at)aol.com> Date: Thursday, October 14, 1999 8:13 PM Subject: RV-List: plumb line holes in wing spars-help- > >rv-6 i understand the crosswise measurements for the holes.could someone >explain the lengthwise measurements.are the holes drilled thru the main spar >web and the tank mount web also? how do you end up with equal lengthwise >holes on both spars? tcrv6(at)aol.com > > ________________________________________________________________________________
Date: Oct 15, 1999
Corner speed is Va. Read Vans recent article showing the V-G (velocity - G's) envelope. Restated; Va is the speed where the maximum design G is available. You are getting maximum turn only if you are pulling maximum G. Speeds below Va you stall before attaining max design G. Speeds above Va you exceed max design G before stalling. ________________________________________________________________________________
Date: Oct 15, 1999
>The reason not to cut the seat back down in the RV6 RV9 series is that it >lowers the height of the shoulder straps. Canadian builders doing this will >fail their final inspection if they have a sharp inspector who knows these >airplanes. Can't speak for any one else but I have done alot of research on >this topic as I have made changes to my luggage compartment that forced me >to. > >The result of lower shoulder straps on an average height pilot is that in a >collision involving deceleration the occupants vertebrae will get a >compression force down because the shoulder straps are anchored on the >longeron. This point is actually low for an ideal situation but those >longerons are simply the strongest point in the rear fuselage. Van has >engineered the solution by having the seat back at a certain height. This >protects the occupants to a certain point. Norman, When you sit in an RV-6(A) your shoulders are above the seat back. The height of the seat will have no effect on the angle that you reference. I'd be curious to find out what changes you made to the baggage compartment and why they were needed. There are alot of RVs flying in Canada. Take care, Scott Gesele N506RV -Flying ________________________________________________________________________________
Date: Oct 15, 1999
Eric, That is exactly how the gauge is supposed to work. You calibrate it so that when the needle meets the red/white juncture, you want your wheels to be about touching the runway. Here is what the calibration instructions say: "The WHITE arc is the area where most takeoff, pattern and landing flying is done. We have heard the term, "Behind The Power Curve." The RED arc is that infamous place where the pilot doesn't want to be caught. The RED area is behind the power curve. No matter how much power you have, if you are in the RED, the airplane is sinking. Stay out of the RED. One of the most important locations on the gauge is called the RED/WHITE juncture. You will notice that there is a white line at the RED/WHITE juncture. This is calle "ZERO LIFT RESERVE." What that indicates to the pilot is that everything the wing is producing is being used to maintain level flight. If flying on the white line, any increase in pitch results in a decent, any decrease in power results in a descent. If you keep the needle in the WHITE arc you will have excess lift available. Excess lift is good to have during turbulence, down drafts, and wind-shear......" Technologies SMTPRS 2.0.15) with SMTP id for > > >Something I was wondering about flying with the LRI. If someone has a >"sweetspot" on the guage, lets call it the approach to flare mark, wouldn't your >landings become more consistant since you are carrying the same amount of lift >into the flare each time. Seems reasonable to me. > >Although long, this has been a very interesting thread, and good publicity. Of >course being featured on the cover of the August Sport Aviation doesn't hurt >either. > >Eric Henson > > ________________________________________________________________________________
Date: Oct 15, 1999
Subject: AOA
_______ From: "Rich Crosley" <dirtrider(at)qnet.com> Subject: RV-List: Angle-of-Attack "Maybe things have changed since I was in the Navy (Vietnam) but we only used AOA for landing, never take off. Use airspeed for take off. It helps to be as slow as you can be coming aboard the "boat",but what is the point, under normal circumstances, of lifting off as soon as you possible can off a runway that is adequate for your airplane? After all most of the time we fly out of runways long enough to get up to take off speed plus a little for the grandkids." Airspeed for take off - true enough, except for short fields, grass strips, bush flying. Then sufficient lift for rotation and take off is useful information. Check this week's AVweb: "Short- and Soft-Field Takeoffs, FAA vs. Reality" by John Deakin for some interesting comments on this. Granted, these are not the kinds of conditions that are typical for RVs. Also, the airspeed indicator will not provide readouts that are density altitude correct during take off or at any time. Jim Huntington jimrhunt(at)wco.com 1(888)310-4574 ________________________________________________________________________________
Subject: Re: vertical fin offset
Date: Oct 15, 1999
>Sorry, I've been trying to stay out of this discussion but I cant. Tom >Shucks I have been trying to stay out too. But I have another question for >the aerodynamiologists. >D Walsh I think I may have found a solution to this, if one can see it as a problem. The tab is not so unsightly to me but it will be good for one speed. Well, that's not so big a problem,but, maybe I want more. So I've been fooling around and gluing cardboard and trying things and have come up with this. The .016X 2 1/2 X 4 1/4 sheet will lie flush in the hole cut in the rudder. The .050 ( slightly smaller) will nest nicely into the .050 backing/mounting plate. A special hinge I picked up at my local carpenter supply store will lift the plates outward while pivoting it into the wind. This lash up will be driven by a Mac servo. And there you go. A variable pitch precision damper. Larry Mac Donald lm4(at)juno.com ________________________________________________________________________________
Date: Oct 15, 1999
Subject: Re: LRI & Landings
Subject: RV-List: LRI & Landings > >Something I was wondering about flying with the LRI. If someone has a >"sweetspot" on the guage, lets call it the approach to flare mark, wouldn't your >landings become more consistant since you are carrying the same amount of lift into the flare each time. Seems reasonable to me. >Eric Henson This thread is great information but I just have to ask --Who is staring at a guage while flaring? Don't most of your inputs at that point in the flight come from outside the cockpit? It seems to me that the only point that the instrument would be of any assistance is when you set up on final - the part far before the fence. Then to I am not sure who would want to fly at that accute angle of attack knowing that winds can change abruptly and leave you without enough airspeed to make changes quick enough to land safely. ________________________________________________________________________________
Date: Oct 15, 1999
Subject: Commanche sump
Listers, Does anybody have a Commanche sump(or equivalent) that they are interested in selling? Thanks. -- Todd tmrv6(at)webcombo.net RV-6 N92TM Flying in Southern MD ________________________________________________________________________________
Subject: Re: Cornering speed (was: Non recoverable corner) 12:00:16
-0700
Date: Oct 15, 1999
I have sat on my fingers as long as I can! Joe is on the mark here, but fails to go far enough. Does anybody realize what a Max performance turn is????? I want all the flyers on this list who have the guts to do a maximum performance turn to step up here. I won't be in that line! When was the last time anybody did a 6 G turn at the buffet? How long do you think the 160 hp lyc will maintain 135 mph (or what ever cornering velocity is) at 6 Gs??? When was the last time ANYONE on this list did an accelerated stall at 6 G's??? We are talking about FAR OUT flying. I would doubt that there are many, if any, of us who have the training or the guts, to fly our airplane that close to the edge. That is a GOOD thing. None of us should ever allow ourselves anywhere near a situation that requires a Maximum performance turn to save our tail feathers! These are good discussions to provoke thought and understanding of aeronautical concepts, but lets not get that confused with our everyday flying. Experienced pilots use superior judgment to avoid situations requiring superior skill. Tailwinds, Doug Rozendaal dougr(at)petroblend.com www.petroblend.com/dougr > > Corner speed is Va. Read Vans recent article showing the V-G (velocity > - G's) envelope. > > Restated; Va is the speed where the maximum design G is available. You > are getting maximum turn only if you are pulling maximum G. > > Speeds below Va you stall before attaining max design G. > Speeds above Va you exceed max design G before stalling. > ________________________________________________________________________________
From: "Consultant3, Cmtsd" <cmtsd.consultant3(at)cmtsd.mea.com>
Subject: MAC Trim Phone Not Working
Date: Oct 15, 1999
Norman, They changed the area code in that part of San Diego county a few years ago. Their phone number is now (760) 598-0592. Ken Brown -----Original Message----- From: Norman Hunger [mailto:nhunger(at)sprint.ca] Sent: Thursday, October 14, 1999 3:19 PM Subject: RV-List: MAC Trim Phone Not Working The phone number (619-598-0592) listed in the Yeller Pages and on MAC's brochure is not working. The website doesn't list an email address. Any one got any new info on how to talk to these guys? ________________________________________________________________________________
Date: Oct 15, 1999
- > And silly me, I was thinking of putting in head restraints in my RV6! > > Marty in Brentwood TN :) for all those times you get rear-ended? :) - mike ==== Michael E. Thompson (Grobdriver(at)yahoo.com) Austin, TX, USA RV-6 in progress, N140RV (Reserved) EX-AX1 Sub Hunter, P-3 (B/B-TACMOD/C) Orion Aircrew, PP-G,ASEL, Motorglider Driver and Unlimited Air Race Nut! Bid and sell for free at http://auctions.yahoo.com ________________________________________________________________________________
Date: Oct 15, 1999
Subject: Re: Power failure in max performance climb and,
yes... AoA > >Yes, I am an AoA fan (probably hard to tell...). Other fans, peek at this >for a vane-driven AoA which, incidentally, is less expensive than any we've >been talking about here lately: > >http://www.riteangle.com > >Johnny Johnson >49MM -3A The guys who complain about the aesthetics of the LRI probe are gonna have a field day with this! This system looks like it would be far more susceptible to damage and wear than the LRI or PSS systems that dont rely on moving parts. That vane looks like an ideal toy for a kid on a fly-in flight line and its at his altitude too. Maybe this explains the 1 year warranty as opposed to the LRI lifetime warranty. Not meant to be a flame but something to consider. To answer the question about who is gonna be staring at a gauge during final approach that was posed by another lister. I plan to mount mine on the glare shield so it should be in my field of view during final approach. And of course all of the systems discussed have some form of audio warning to wake you up if you get into trouble. Mike Wills RV-4 canopy skirts ruined; new ones on order willsm(at)manta.spawar.navy.mil ________________________________________________________________________________
Date: Oct 15, 1999
Go down to your local hardware store and by a "Test Plug" for about 3 bucks. You can find the appropriate diameter for the fuel tank filler opening. Seals perfect for testing. Doug Hudson, WI > > > > I haven't seen this one on the list. In attempting to seal the fuel cap from > > leaking during your test, unscrew the bottom nut on the cap and then heat > > the cap to about 120 degrees - used my wife's hair dryer. Put lots of axle > > grease on the bolt under the nut and let sit. When cooled to room temp., > > tighten the nut. Make a filet of grease around the nut at the joint with > > the plate and around the threads to nut joint. Grease the "O" ring really > > well and insert in full neck. Lock down, and tape over. > > > > I was not able to get 3" tape and the 2" kept leaking, but final taping was > > by using a but joint with the first two with a third over the top on the > > butt joint. The heating allows the grease to flow and seal/stick better. > > Good Luck, your mileage may vary. For Me, NO LEAKS in one tank so far, > > Yippee!!! > > > > The trick I used was to take one of the rubber gloves and cut a piece > out of it large enough to tightly stretch over the part of the cap that > has the o-ring in it. Sealed it right up! ________________________________________________________________________________
Date: Oct 15, 1999
----- Original Message ----- From: scott gesele <sgesele(at)usa.net> Sent: Friday, October 15, 1999 6:26 AM Subject: Re: RV-List: RV6 - Cut down seat backs > > >The reason not to cut the seat back down in the RV6 RV9 series is that it > >lowers the height of the shoulder straps. Canadian builders doing this will > >fail their final inspection if they have a sharp inspector who knows these > >airplanes. Can't speak for any one else but I have done alot of research on > >this topic as I have made changes to my luggage compartment that forced me > >to. > > > >The result of lower shoulder straps on an average height pilot is that in a > >collision involving deceleration the occupants vertebrae will get a > >compression force down because the shoulder straps are anchored on the > >longeron. This point is actually low for an ideal situation but those > >longerons are simply the strongest point in the rear fuselage. Van has > >engineered the solution by having the seat back at a certain height. This > >protects the occupants to a certain point. > > Norman, > > When you sit in an RV-6(A) your shoulders are above the seat back. The height > of the seat will have no effect on the angle that you reference. Yes the angle will remain the same in normal flight but in an accident the standard height of seatback will prevent the shoulder straps from travelling down as the occupant is thrown forward. The cut down seatback allows the occupant to be thrown forward further while at the same time compressing the occupant's spine down. This is the reason not to cut the seatback. I'd be > curious to find out what changes you made to the baggage compartment and why > they were needed. I've been working out a way of carrying skis, snowboards, or golf bags without protruding into the pasenger compartment. My current thinking has this cargo being hauled above the longerons as they are the strongest area to work from. This would also be the easiest to load/unload. The problem I had to overcome was that the shoulder harness cable passes throught the rear baggage compartment bulkhead at a point slightly higher than the longerons. This would put the cable in the middle of my cargo. Once I did some research on the topic I learned that it would be a very bad idea to change this relationship. So now I plan on building a pedistal for the cable that holds it up where it needs to be and provides a strong point for tyeing down skis. The skis will have to sit on either side of the pedistal. The lower part will have a slot in it that will allow me to use one of those funky small ratcheting straps from the auto parts store to secure my cargo. The weight penalty is very small for all that I plan on adding. The benifit is all of the mountians that I will be able to hit within one day of travel. Jackson Hole, Vail, Mammoth, Aspen....... Regards, Norman Hunger Delta, BC Whistler two hours by road, snows coming soon! ________________________________________________________________________________
Date: Oct 15, 1999
Also- BEFORE you scuff with Scotchbrite, wipe parts (I use naphtha on paper towels) to remove oils- It took me a while to figure out those spots the pads just skimmed over had my thumbprints in 'em! And priming it the last thing I do before the rivets go in... (not that I'm doin' it right of course!) ; ) From the PossumWorks in TN Mark Phillips -6A wings MRawls3896(at)aol.com wrote: > > > In a message dated 10/13/99 7:57:42 PM Central Daylight Time, > Larry(at)bowenaero.com writes: > > << > I've been using the Sherwin-Williams GBP988 since the beginning of my > project. In general, it's worked great. However, when I dimpled some of > the wing ribs, the primer began to flake off where the dimple die made > contact. Has this happened to anyone else? Any idea why? > >> > You didn't say if you where using Scotch Brite to treat the skin. Always > use the Scotch Brite and use lacquer thinner to clean the oil (from your > hands) off. ________________________________________________________________________________
Date: Oct 15, 1999
> > As strange as it may seem, sometimes adding power at low altitude when > pointed at the ground is the correct thing to do. You want to get the > airplane as quickly as possible to "cornering speed," that speed which will > produce the smallest radius turn or pullout. SOP for some jets (F-5, F-104) is to go full burner in a nose-low unusual attitude. Tedd McHenry Surrey, BC ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Date: Oct 15, 1999
-----Original Message----- From: Norman Hunger <nhunger(at)sprint.ca> Date: Friday, October 15, 1999 2:24 AM Subject: RV-List: RV6 - Cut down seat backs > >> > >> ><< Has anyone heard of cutting down the seat back height on a RV6? >> > >The reason not to cut the seat back down in the RV6 RV9 series is that it >lowers the height of the shoulder straps. Canadian builders doing this will >fail their final inspection if they have a sharp inspector who knows these >airplanes. Can't speak for any one else but I have done alot of research on >this topic as I have made changes to my luggage compartment that forced me >to. > >The result of lower shoulder straps on an average height pilot is that in a >collision involving deceleration the occupants vertebrae will get a >compression force down because the shoulder straps are anchored on the >longeron. This point is actually low for an ideal situation but those >longerons are simply the strongest point in the rear fuselage. Van has >engineered the solution by having the seat back at a certain height. This >protects the occupants to a certain point. > >Tony talks about this in one of his books. Some one mentioned it on this >list just a few months ago. > >Norman Hunger RV6A > Norman, You certainly raise a valid point. I thought I had worked this out when I decided to cut down my seats. I am 5'9" and when I sit in 6As with normal height seat backs ( three that I can remember) the shoulder belts bear on my shoulders anyway, so cutting down the seat backs did not seem to be a safety issue. Do other pilots have the belts bearing on the seat backs when they are strapped in? Some feedback, please! In David B. Thurston's book, "Design for Safety" (ISBN 0-07-064554-x), p88, he says the angle between the thrust line and the shoulder belt tangency when resting upon the pilot's shoulder should be zero to ten degrees up. That is indeed impossible in a 6 or 6A. I calculate an angle (my seats are removed at the moment, so this is an approximation) of approximately 5.6 degrees (7 inches rise over 72 inches horizontally), so the compressional force is about 10% -- that's 400 pounds for a 40g crash and 100 lb upper torso. You guys with stock seat height and seats adjusted for padding height: Where does the shoulder belt rest -- seat back or you shoulder? Dennis Persyk 6A finishing kit Hampshire, IL C38 ________________________________________________________________________________
Date: Oct 15, 1999
-----Original Message----- From: Larry Olson <lolson(at)doitnow.com> Date: Wednesday, October 13, 1999 6:43 PM Subject: RV-List: RV6 - Cut down seat backs > >Has anyone heard of cutting down the seat back height on a RV6? > >Got a local -6 pilot that swears if I don't do it now, I >will later. > >I'm building a slider. > >Any thoughts? > >Larry Olson >Cave Creek, AZ >RV6 - Fuse out of the jig > It is commonly done on 6es and 6As to allow easier reaching into the baggage area to get things while in flight or just seated in position. Seats cut nearly flush with horizontal channel (allowing for tilt adjustment) offer nearly the same support as full length seats. Dennis Persyk 6A finishing kit Hampshire, IL C38 ________________________________________________________________________________
Date: Oct 15, 1999
From: Charlie and Tupper England <cengland(at)netdoor.com>
Subject: Re: LIVING with aircraft batteries
> > >How > >would you propose using this in the architecture you describe above? Also, > >would you have zero battery backup for electric instruments because of the > >dual alternators? > > you betcha! no need to carry lots of lead around if you have > two engine driven power sources. > > Bob . . . > of course, in the case of engine failure, it would be nice if the flight instruments operated long enough to get out of the clouds..... Charlie ________________________________________________________________________________
Date: Oct 15, 1999
I'm sure the battery will last long enough to get you safely to the ground in the event of an engine malfunction, even with full IFR stuff humming along. Mike RV6 - 699BM (reserved) From: Charlie and Tupper England@cengland on 10/15/99 12:51 PM To: rv-list(at)rv-list@matronics.com@SMTP@McGate cc: Subject: Re: RV-List: Re: LIVING with aircraft batteries > > >How > >would you propose using this in the architecture you describe above? Also, > >would you have zero battery backup for electric instruments because of the > >dual alternators? > > you betcha! no need to carry lots of lead around if you have > two engine driven power sources. > > Bob . . . > of course, in the case of engine failure, it would be nice if the flight instruments operated long enough to get out of the clouds..... Charlie http://www.matronics.com/subscribe http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 15, 1999
Subject: [Fwd: Tail wheels]
Here's the latest response from Owen at Andair regarding the tailwheel situation. He's obviously going to stand behind his product which is really no surprise. MBOX-Line: From andair.co.uk!andair Fri Oct 15 08:47:18 1999 remote from mail via smail with P:smtp/R:bind_hosts/T:smtp-filter (sender: ) (Smail-3.2.0.105 1999-Mar-3 #3 built 1999-Mar-26) From: "andair" <andair(at)andair.co.uk> Subject: Re: Tail wheels Date: Fri, 15 Oct 1999 08:43:47 +0100 Dear Steve, Thanks for doing that for us. I'll get the tube shipped out today. As for splitting the hubs, the first batch of 50 that we sold had white silicon to prevent water or any other dirt getting between the rims and into the tyre. However we found that to be unnecessary as the fit between the two rims was good enough to prevent this anyway. So assuming that yours has been bonded with the silicon I have found that the best way is to take all three bolts out lent insert a strong bar of diameter of about 5/32" (4.00mm) and apply a force to the bar so that is shears the two halves. It may take some 'wiggling' to separate them but i have found that it works in the end. You can then carefully clean the silicon off with a knife or just peel it off. I hope this info helps Steve and if there's any more I can help you with please don't hesitate to contact me. Best Regards Owen Phillips. andair(at)andair.co.uk --- www.andair.co.uk Andair Ltd. Unit 3 25c Brockhampton Lane, Havant Hampshire PO9 1JT
October 11, 1999 - October 15, 1999
RV-Archive.digest.vol-hc
