RV-Archive.digest.vol-he
October 23, 1999 - October 29, 1999
Empty weight without paint 1019 lbs. Aymar-Demuth 68x74 wood prop.
Regards Peter Burrowes (Toronto Canada)
Subject: | ANR -- what's all the fuss? |
I just tried on a pair of Lightspeed 25x headsets (borrowed from a friend)
in my RV-6, and I can't help but wonder, what am I missing here? I flew for
about 40 minutes with them and yes, the ANR does eliminate the low frequency
noise. But it seems to do very little with the high frequency noise. There
was a faint but constant hissing, and the audio was tinny and hurt my ears.
Not only that, but something about the ANR seemed to mess with my inner ear
and made me queasy. I finally turned off the ANR.
Has anyone else experienced this? I suppose the headset could be defective
or need tuning, or maybe its just not tuned for a plane that has a lot of
high frequency sound. Which my plane does, I think from the propwash hitting
the windscreen as well as air leaks around the canopy skirts. But with my
Peltors I've never noticed it, and in fact I never was bothered by the
amount of low freqency sound -- the abscence of it in fact was disconcerting
with the ANRs, as I felt I couldn't sense what my engine was doing as well
as I wanted to.
If this is really what the ANRs are like, I'll stick with my trusty Peltors,
which, frankly, I've been very happy with anyway. In fact my wife never
complains when she has the Peltors on, and she has very sensitive ears.
I hope this doesn't start a flame war, I know there are a lot of people who
swear by their ANRs. I just thought that with all the hype, maybe a vote for
the "old standard" might be in order.
Randall Henderson, RV-6 N6R (35 hours)
Portland, OR
http://www.edt.com/homewing
Subject: | Re: First FLight |
Peter,
Good show.
Jim.
-----Original Message-----
Date: Saturday, October 23, 1999 11:39 PM
Subject: RV-List: First FLight
>RV6 24049 Registration C-GFLG based at Brampton Ontario made a
>successful first flight today.
>Four years two months from starting the tail kit.
>No trim changes required, 180mph indicated 2000 feet @ 2500 rpm (No leg
>or wheel fairings yet). Engine was obtained from the local flying club
>with 2350 hours time on it.( 160 hp 320-D2J)
>Only thing I noticed was the flaps (trailing edge) appeared to be
>slightly higher than the ailerons as if they may be pushed up by the
>airflow, on the ground they do line up. All the linkages are tight,
>possibly the flap twists slightly to raise the outboard end. Comments?
>Needs a little nose down trim for level flight, I guess the stabilizers
>angle of attach may need increasing.
Subject: | New RV-8 Rudder on a RV-4 |
All,
I noticed that the new RV-8's will be shipping with a larger rudder for "added
stabilility". I would like to do this to my RV-4 also. Would Van's have a
problem with me putting an RV-8 Rudder on my 4?
JB
Kevin Horton wrote:
> I didn't know that Van's was planning on addressing this sort of
> issue. I'll wait and see what the Van's website update looks like,
> then decide whether there is a need for any additional info. I
> certainly don't want to duplicate anything that Vans does.
> Kevin
> >Good idea, but in a way, you're sort of replicating in part a major effort
> >that's expected to be available Nov 15 on the web.
> >For starters, you'll be able to update all of your plans with all revisions
> >(published or not), search for any articles written on any particlar
> >problem, or search Van's tech support to see if it's been answered before...
> >~Jeremy
> >jwb(at)europa.com
> >SD: In this message, I don't speak for my employer, clients, the US
> >Goverment, or anyone else.
> >>RV-8/8A builders,
> >>I just moved my web page to a new server, and supposedly have no
> >>limit on how much space I use, unlike the old one where I had to
> >>remove old material to make room for new stuff.
> >>So, now that I have all this space to play with, I am considering
> >>putting together a list of known issues with the plans, instructions
> > >or parts for the RV-8 or 8A.
> Matronics: http://www.matronics.com
> RV-List: http://www.matronics.com/rv-list
> Archive Search Engine: http://www.matronics.com/search
> Archive Browsing: http://www.matronics.com/archives
> Other Email Lists: http://www.matronics.com/other
Oh controller, who sits in tower,
Hallowed be thy sector.
Thy traffic come, thy instructions be done,
On the ground as in the air.
Give us this day our radar vectors,
And forgive us our incursions,
As we forgive those who restrict our speed on final.
And lead us not into adverse weather,
But deliver us our clearances.
Roger (Amen)
Subject: | Re: ANR -- what's all the fuss? |
The low frequency range noise is all it is designed for. That is the noise
that most effects our ears, and can physically wear down a pilot. I have
flown wtih Bose headsets, and can honestly say that I would purchase a pair
in a heartbeat if I didn't have other $1000 items to buy. I plan on the
lightspeed, but have not yet tried them. Maybe you had a bad pair, but most
seem to swear that the lightspeeds are far superior to any non ANR headset.
Your milage may vary.
Paul Besing
RV-6A (197AB) Arizona
http://members.home.net/rv8er
Finish Kit
Date: Sunday, October 24, 1999 3:55 AM
Subject: RV-List: ANR -- what's all the fuss?
frequency
hitting
disconcerting
>as I wanted to.
Peltors,
for
>Portland, OR
Subject: | Re: Log entries? |
Denton,
Put exactly what you have done to the engine and prop. State that they have been
overhauled and then what the mods are that you have installed. Also it is
highly advisable that you state that the prop and engine are to be used in experimental
aircraft only unless and new overhaul is conducted. Your local FAA
Rep should by that off. The only other thing you have to do is remove the data
plate from the engine. Keep it with the logbook for future overhauls.
Mike Robertson
RV-8A QB Just installed wings
In a message dated Sat, 23 Oct 1999 8:40:20 AM Eastern Daylight Time, Denton Harjehausen
writes:
> Anyone out there give me an idea of log entries for an overhauled engine
> that is not certified because of mods and a C/S that was reconditioned by
> an prop overhaul shop employee?
> I am about to call for inspection and need to get all the Ts crossed
and
> the dots in the right places.
> Have a great Day!
> Denny Harjehausen
> Lebanon, OR
> RV-6
Subject: | wood stiffeners in the RV-6A main gear legs |
I recall about a year ago that Tim Lewis and maybe several others were
communicating on the List about omitting the wood stiffeners in their
RV-6As. I have my RV-6A on gear and I would like to try the plane (if it
ever moves under its own power) without the wood stiffeners. Is anyone
flying the RV-6A without the wood in the main gear? If so, how do you like
it? Would you put the wood in if you had the time to do it over again?
Steve Soule
Huntington, Vermont
RV-6A main gear fairings
Subject: | Re: New RV-8 Rudder on a RV-4 |
I think you are the guy who would have the problem, because I doubt
that it would fit. Van increased the height of the VS on the RV-8
slightly (I think), and put a mass balance on the rudder (like on the
elevators). I just measured the height on my rudder. It is 51 3/16
from the bottom of the rudder to the bottom of the mass balance.
Van had to make these changes because of the increased side area of
the RV-8 canopy, and it is designed to take a bit more power. Your
RV-4 should be just fine with the rudder you've got, unless you put
an RV-8 canopy on your RV-4, and stuff in a 200 hp IO-360, in which
case you might want the RV-8 rudder.
Take care,
Kevin Horton RV-8 (wings 95% done)
Ottawa, Canada
http://members.xoom.com/kevinhorton/rv8.html
http://members.xoom.com/kevinhorton/nojpi.html - No JPI stuff in my aircraft!
Subject: | Re: Beware AC$ Stencils |
>>I have heard that planes at Oshkosh are ineligible for awards if the
>>paint job uses any vinyl graphics --
>If you are after awards, then yes, go with the paint....I obviously
>can't speak for others, but I am after a fun, flying airplane! To be
>honest, I could care less if I ever receive an award.... a simple,
>"Nice looking airplane you got there" will mean much more to me
>than a panel of judges going over my airplane with a fine tooth
>come.
Now, you're cooking, Paul. What so many of us forget is that we're
building something for our own pleasure. To heck with what others
think. I can remember when I first started that I was going to build
something as perfectly as I could. That idea disappeared when I
drilled my first set of rivet holes. :-) Today, as I complete my RV-6A
that's taken over 7 elapsed years to build, I can look at my airplane
and be proud of what I've accomplished in the boonies of KY. It's
not perfect and would never win an award at Oshkosh; but, it sure
does look nice to me. Others have told me same; so, maybe my
ideas of what nice is isn't way off in left field. Maybe I did build it as
perfectly as I could with the talents I have and have achieved my
goal. I'm certainly satisfied with that idea and don't feel it necessary
to get any judge's approval.
Yesterday, I was driving home from the airport and saw this neat set
of graphics on the side of a pickup. Boy, would I like to have those
on the side of my RV! I guess that makes me less than perfect to
the judges at Oshkosh. Since the folks up there will never see my
RV, it doesn't matter. Now, if I could just remember what kind of
pickup that was. :-)
Jim Sears in KY
RV-6A N198JS (Hope to fly in December. No paint, yet.)
AA-5A N26276
Ive flown with a set of 20k's for a couple of years now and I just
recently traded them in for a set of 25k's. Yes the audio is a little
more "tinney" and they fit a little tighter on my head. They do however
make the cockpit quieter, the microphone boom is stiffer and the mic
stays in place better and I think lightspeed improved the mic over my 2
year old 20k's. They now instruct you in proper microphone placement
and orientation. Also, I can hear my CD player a little better. They
work in conjunction with my passenger set of 20k's better than anything
else Ive tried to date. If you have a new set of 20k's I'd just keep
them, however if your 20k's are a couple of years old they would
definately be worth upgrading to 25k's
I only wish lightspeed would have put a strip of sheepskin on top of the
head band.
Chet Razer and Miss Chiquita 215 hrs now
Will someone post a URL for a site that has a good graphical "winds
aloft" pict for 5k and 10k altitudes. A site other that the weather
channel or duats.
chet
I too was a little dissapointed by the high freq noise getting through my Telex
4100 ANR. But I have never heard of anyone getting dizzy from them. The sound
reproduction is so excellent in mine that I got a second pair. I think that
maybe the David Clarks do a better job yet with the high freq sound.
I suggest trying a different pair or a different brand. However, a good pasive
pair with 'foamies' underneath works just as good IMHO, but is just a litle less
comfortable on long trips.
Dave Leonard
6QB
complains when she has the Peltors on, and she has very sensitive ears.<<<<<
Try intellicast.com
Pat
Chet:
Although not graphical, this is the best winds aloft site that I have found.
Check it out: http://www.aviationweather.com/
Pat Hatch
RV-4 N-17PH @ INT
RV-6 Wing Kit
----- Original Message -----
Sent: Sunday, October 24, 1999 9:30 AM
Subject: RV-List: Winds Aloft
> channel or duats.
> chet
In a message dated 10/23/99 21:55:03, randallh(at)home.com writes:
Portland, OR
Randall I have had similar experiences. When I heve compared the ANR with my
Peltors, the first thing I notice is how much better the Peltor seals off the
high freq noise, while the ANRs don't seem to seal nearly as well, and
definitely don't do nearly as good a job until you turn the magic on. I have
even had the evil thought they are made that way just so you can notice the
stark comparison between "on' vs "off" !
Therefore I am still happy with my lightweight Peltors and good head
clearance from the canopy. However Iam thinking I would like to try
Peltor's ANR??
Perhaps they have retained the characteristics of the old sets and just added
ANR. They are awfully proud of them though.
D Walsh
Subject: | Re: wood stiffeners in the RV-6A main gear legs |
In a message dated 10/24/99 4:53:03, SSoule(at)pfclaw.com writes:
RV-6As. I have my RV-6As on gear and I would like to try the plane (if it
Steve Soule
Huntington, Vermont
RV-6A main gear fairings >>
When I was building I called Geo Orndorff and asked him. His quote was "You
don't need them". So I gave it a try without stiffeners on the main gear.
At first I was bothered because I wasn't sure whether I was getting main gear
shake or nose gear shimmy. In fact they are quite different, and easily
differentiated
I have been flying for 540 hours that way, and offer the following: I do get
gear shake at 23 to 30 MPH when taxiing either during acceleration or on slow
down after landing. For reasons I can not explain, it does not happen on
take off acceleration. At the other times it does not happen all the time
but around 80 to 90 percent. It depends on tire pressure, balance wear
pattern, gross weight, etc.
I have got used to it and therefore don't taxi above 23 unless I need to. I
kind of like it on landing because I can tell when I am going slow enough to
turn off with out looking at the indicator. It lasts from two to three or
four seconds on landing, depending on whether you are on the brakes or not.
I am not going to add them and would not do it next time either. I really
like the idea of being able to easily inspect the legs and lines.
P S I have noticed no difference in the way the nose gear behaves. (The new
one has no stiffener.) It wants to shimmy above 70 and does nothing below.
D Walsh
I've found two new sites: www.rap.ucar.edu that will also lead to
www.adds.awc-kc.noaa.gov .
Rick Jory
Highlands Ranch, Co
Date: Sunday, October 24, 1999 8:25 AM
Subject: Re: RV-List: Winds Aloft
>Chet:
found.
>Pat Hatch
>RV-4 N-17PH @ INT
>RV-6 Wing Kit
>From: chester razer <razer(at)midwest.net>
>To:
>> channel or duats.
>> chet
You do NOT have to remove the data plate.
(Click here to visit our Club site at http://www.bellanca-championclub.com)
From: MRobert569(at)aol.com <MRobert569(at)aol.com>
Date: Sunday, October 24, 1999 3:24 AM
Subject: Re: RV-List: Log entries?
>Denton,
have been overhauled and then what the mods are that you have installed.
Also it is highly advisable that you state that the prop and engine are to
be used in experimental aircraft only unless and new overhaul is conducted.
Your local FAA Rep should by that off. The only other thing you have to do
is remove the data plate from the engine. Keep it with the logbook for
future overhauls.
>Mike Robertson
Denton Harjehausen writes:
engine
crossed and
>> Have a great Day!
>> Denny Harjehausen
>> Lebanon, OR
>> RV-6
From: | Hal Kempthorne <kempthorne(at)earthlink.net> |
Subject: | Re: RV4 flat plate drag area |
In "The Illustrated Guide to Aerodynamics" by H.C. 'Skip' Smith page 75 is
a list of ten gen av planes with equivalent flat plate areas. Piper
Traumahawk at 6.64, Bonanza at 3.47 and Mooney 201 at 2.81. I recall P51
Mustang as better than any of these but can't find reference.
hal
>In a message dated 10/21/99 3:49:42 PM Pacific Daylight Time,
>willsm(at)manta.spawar.navy.mil writes:
><< Does anyone have a number for the effective flat plate area for the RV-4?
> An article or ??? that may have produced such a number? Its a matter of
> curiosity for someone Ive been having a bench flying session with. >>
Gary Vanremogel answered:
>FWIW, in the RV6A CAFE article presented in the 09/93 Sport Aviation, they
>listed the flat plate area as 2.32 ft
2.
Subject: | List of RV-8/8A plans/instructions/partsproblems |
Kevin... I agree but how does one know what Van's has planned. Maybe a few
subtle hints from Jeremy would go a long way toward keeping us from
re-inventing the wheel.
What about it Jeremy......not to let any cats out of the bag but it is about
time we knew what to expect from Van's. I have been waiting to get the new
catalog for 6 months so I could fill my panel (amonst other things). Nothing
yet. I really hate to spend my money somewhere else because I really would
like to support Van's if I can. However, time is getting short.
Gary Palinkas
Parma, Ohio
RV6 QB
>that's expected to be available Nov 15 on the web.>>>>
From: | "John B. Abell" <jbabell(at)mediaone.net> |
Hi Chet,
I subscribe to a service that you can peruse at:
http://www.weatherconcepts.com
This site has excellent graphical representation of winds aloft at 5000, 10000,
and 18000 ft. as well as many other informative displays.
Best wishes,
Jack Abell
Los Angeles
RV-6A N333JA Finishing
> channel or duats.
> chet
Subject: | Re: Stainless screws in fuel tank |
Being as you admit being borderline anal, aren't you concerned about specs
being for "dry torque"?
Did you do this for instrument screws too?
hal :-)
>Anytime any screw of anytype goes into any threaded receiver......(not during
>assembly/fitup with the many ins & outs of screws....) but during the
>last ( HA
>) securing of the screw I grab a pipe cleaner, dunk in some thick oil and
>push
>in the threaded receiver ( nutplate.......) During annuals & maintenance I do
>the same thing....border- line anal retentive but helpful nonetheless...
Subject: | RV-6A QB end wing rib |
I finished the first section of the QB manual - the fuselage - and
turned to the wings. I have 2 questions.
First, the manual says I have to build the end wing rib, but a
factory built one is obviously already clecoed into the wing. What's going
on there?
Second, what's the best way to rivet those end ribs to the front
spar? My rivet gun, even with the offset rivet set doesn't look like it
can get in to a good position. The 1/8" rivets are close enough to the web
that the gun will at best be held at an significant angle to the rivet
which is very likely to make the rivet cleat.
Tom Sargent, sarg314(at)azstarnet.com
I think that the abscence of low frequency noise makes the high frequency
noise more apparent to the wearer. There is also a slight boosting of some
high frequencies due to the physics of the analog system. I like my 20K's a
lot and find I am not tired and my ears suffer no numbing after using them
all day. As to getting dizzy--?????? I have not an idea. As to not being able
to hear the engine--I can actually hear the engine better without all the low
frequency drumming that many mistake for engine sounds. No need for a flame
war--each to their own. JR
If you are an AOPA member, they have a flight plan option on their
website..you put in your airplane's specs one time, then just configure
flights with winds aloft info. It will tell you how your airplane will
perform on each leg, groundspeeds, magnetic heading, etc..
Paul Besing
Finish Kit
Date: Sunday, October 24, 1999 12:30 PM
>channel or duats.
>chet
Congratulations, Peter
Good to see another RV lift into the air.
Ed Anderson
RV-6A N494BW Rotary Powered
do not archieve
In a message dated 10/24/99 7:58:49 AM Eastern Daylight Time,
khorton(at)cyberus.ca writes:
<< I noticed that the new RV-8's will be shipping with a larger rudder for
"added
Jason,
Your RV-8 rudder will work well on your "-4" as long as you intend to use the
RV-8 vert as well, which I think is what you meant.
Scott
Subject: | Re: RV-6A QB end wing rib |
Tom:
I believe you can just push the rib out of the way a little. It will
spring back.
Pat Hatch
RV-4 N17PH @ INT
RV-6 Wing
Sent: Sunday, October 24, 1999 12:39 PM
Subject: RV-List: RV-6A QB end wing rib
going
> on there?
web
Subject: | RV Builders Sites |
We've put up a new feature on our Home Page. It will list an RV builder's
site.
The first site we are featuring is Bob Haan's of Oregon. He's building an
RV-6A. His site has a panoramic view from the seat of the plane which allows
the viewer to turn 360 degrees.
You can find the link near the top of our Home page @ AAMR/AirCore/MarineCore or http://members.aol.com/aamrelectr/index.html
Also if you have other builder sites you'd care to submit to be featured,
please do so.
Sq.John @AAMR/AirCore
Hi !!!
I think this kind of idea and question is a good one, and would think that
this list would be a good place to kick it around. "Half the rivets might
equate to half the strength" is just the point ..... *might* is the key
word. Incorporating a joggle here does not necessarily force a single row
of rivets; one could joggle the main skin and give it three rows of rivets.
As far as changing the airfoil, my wing doesn't even come close to the
template supplied in the shipping crate .... giving rise to question the
ultimate utility of adhering to the theoretical airfoil (and I used all
Van's parts: spars, ribs and skins !!). I believe there are aircraft out
there that do use a joggle and single row of rivets here .... anyone know
what the underlying structure is ?? I know that this main wing skin /
leading edge skin butt joint is my worst skin joint so far; and would love
to figure out a better way to do it.
It seems to me that, as good as the RV family of aircraft are, there is
still room for improvement. I could understand Van not wanting to
participate in these variations given our propensity for litigation. But I
also recall that Van's first RV-? was a modified something else .....
telling me that this is a natural design progression. Yes, we have to be
careful in our decisions, and build to our own comfort and competence level.
I think this list could use a bit more tolerance for builders not quite
falling into the "insert tab A into hole A" category. I consider these
Experimental Aircraft, and as such, we have the opportunity to embark on
changes from "standard". It seems to me that persons at both extremes of
this continuum have a place in and value to the List. End of soap box.
Larry E James
Bellevue, WA
larryj(at)oz.net
> This kind of idea should be put into writing/drawing and sent to Van. It
is
> an engineering change. Half the amount of rivets might equate to half the
> strength. Please document these types of changes in your construction log
so
> that future buyers of the airplane will be aware that the wing is not the
> same as the thousands of other RV wings out there. Resale value of an
> airplane modified like this is likely to be substantially lower than
market.
> > I would like to know if anyone has used a joggle to mate the rear wing
> > skin to the leading edge skin. The reason being to make it possible to
> > use only one row of rivets into the spar flange instead of the butt
joint
> > using two rows of rivets. It might require some thought and planning in
> > the fuel tank area.
Yeah, I built mine and found out that Van's was kind enough to include the
rib...wasted some good aluminum!
My gun with the offset set worked fine on the rivets against the spar. The
spring on the gun penetrated into the lightening hole, as opposed to the gun
sitting inboard with the offset rivet set.
BTW, if you have not pounded out the other ribs and bulkheads in the manual,
don't. Buy them from Vans..you will be much happier with your end results.
Lets just say that I will be building another rudder, because I made my own
ribs.
Paul Besing
Finish Kit
Date: Sunday, October 24, 1999 4:41 PM
>on there?
From: | "Howard Walrath" <H_D_Walrath.HVIL(at)prodigy.net> |
Subject: | Documenting Registration Number Change for RV-6A |
Listers, I am looking for some advice from someone
(particularily our members of the Friendly Aviation
Administration) regarding what needs to be done
to effect a change to a special registration number
in a flying RV-6A (2 years, 140 hours). I paid the fee,
reserved the Special Registration Number, received
the Confirmation of Reservation (AC Form 8050-110).
I have submitted a letter requesting permission to affix
the Special Registration Number to my RV-6A and
attached copies of the Confirmation and my Certificate
Of Registration. It is being processed at OKC and I
expect to receive back AC Form 8050-64 (Assignment
of Special Registration Numbers) authorizing the new
numbers to be placed on the airplane.
My questions are related to what else I need to do with
the other FAA documentation???
Specifically:
I presume that when I return the form stating that the new
numbers have been affixed to the aircraft, the FAA will
send me a new CERTIFICATE OF AIRCRAFT REGISTRATION
AC Form 8050-3(8/97) with the new "N" number on it, without
me having to submit anything. Correct ????
Since the SPECIAL AIRWORTHINESS CERTIFICATE
(FAA form 8130-7) shows the old "N" number in section D,
I presume it must be changed too. Is this done by the local
FSDO office, Oklahoma City, or how? By mail or does it
have to be in person?
Finally, the SPECIAL OPERATING LIMITATIONS document
issued by the original DAR for Phase I and Phase II (issued in
1997 and long since complied with) contains the old "N" number
as well as Make, Model and Serial Number. Does it need to
be reissued or is it still valid if the documents authorizing the
registration number are attached and carried in the aircraft?
If it needs to be revised to show the new REG. NO.:, must that
be the originating DAR (a thousand miles from here) or can
another DAR here locally make me a new one with REG. NO.:
the only revision?
Guys and gals, I would sincerely appreciate any information &
personal knowledge you may have. Thanks in advance
Howard Walrath
940-321-5758 or 940-321-5014 (Fax)
RV-6A Flying 140 hours
I'm considering about forty different panel designs but have a question to
ask about one of them. This one has three sections. The radio stack would be
right down the center with separate removable sections on either side for
everything else. The left section would be the primary flight instruments
and I was wondering how much lower than a stock panel would this section be
if it had a triple stack tall of 3 1/8 gauges. Does any one care to take a
guess?
Thank-you,
Norman Hunger
RV6A Delta, BC
Do not remove the data tag off your engine!!!!!!
What you want to do is a entry like this:
NXXXRV 10-24-1999 Total Time: 000.00 TSMOH: 0000.00 Explain what work
has been accomplished on the engine i.e. installed new bearings, crank
ground.... Now explain the mods to the engine i.e. installed lycon 400hp
pistons P/N 222222...
John Doe Pilot # 23456778
Sign name
> for awards if the
Where did you hear this info?
I have worked aircraft Judging at a local fly-in for
the last 10 years. We use the Aircraft Judging
Guidelines published by EAA HQ Oshkosh that were
published a few years back. They have no reference to
vinyl graphics or registration numbers that are not
painted being ineligible nor are points deducted for
using them.
I know that Werner Berry, to name one person who has
won an award at Oshkosh, has a VINYL overlay on his
Instrument panel.
Gary A. Sobek
So. CA, USA
Subject: | Electrical Wiring? Tach problems |
Initial run of 0320H2AD with the big single drive mag.
I have the P lead on RH mag terminal...connected to the 2 1/4 inch tach Van's
sells. (sorry I can't find any of the info for model # here at home...)
As they are close to one another....I connected in the dash area to the Key
switch screw down lug for the P lead to mag and to the wire input to gage.
ACS OFF/RH/LH/BOTH/Start .....Key switch wiring diagram looks to have all
connections Normally open in running mode? So single inpules/input from mag
should be OK?
But it looks to be reading double? While cranking on B&C starter, no plugs
in to pre lube it read 1000 ish.
During running it looked to be double.
I don't remember the other wires exactly but I think it had 3..so 1 was
ground and other?? I'm gonna have to dig into and refresh memory..been a
while...
Any ideas as I attempt to tear the gage out of the dash and trace wiring?
Thanks David McManmon Cicero, NY
Shooting for NOV...First flight!!
Subject: | Suction problems, VAC pump? Regulator setting? |
Initial start of used engine with used suction pump and vac regulator.
I got on suction reading at idle. I did get the 4-5 vac reading while
running up 1300+ rpm.
I will go under dash and play with regulator ....
But theory please:
If regulator regulates an inch set point, then if idle doesn''t pull right
amount..if I get it to pull right amount at idle won't it be way off at high
rpm...?
So is pump bad?
I guess I need some trouble shooting advise here too..
David McManmon, Cicero NY
Listers,
Searched the archives on this but couldn't find it...
I'm having trouble figuring out how to seal the rear baffle using the
airseal material, specifically the two 90 deg. bends behind cylinder #4.
The instructions are vague and state this may be a difficult area, and
experimentation is advised. I've cut out quite a few paper patterns
experimenting, just not the right one .
Any ideas most welcome, drawings/photos especially. Maybe we can get this
up on somebody's web site?
Thanks, Rob Acker (RV-6Q, FWF stuff...)
Subject: | Re: Baffle Airseal |
>From: "Rob Acker" <racker(at)cyberhighway.net>
>To:
>Subject: RV-List: Baffle Airseal
>Date: Sun, 24 Oct 1999 17:01:30 -0700
>Listers,
Rob,
I solved the problem in that area by making the corners of the seals extend
out, or, towards each other, at 45 degrees. If you can imagine the shape of
Gumby's head, then that's about it! When the pieces are folded forward when
the cowl is on, they overlap each other and seal the corner. This applies
only to the "outside" type corner at the baffle corner just above the #4
cylinder head to barrel junction. Egads, this is hard to explain! The pics
on my webpage were taken too far away from the engine to be of much use, I'm
afraid.
All the other "inside" corners aren't a problem, just cut the baffle corners
at 90 degrees and they will overlap nicely with the cowl down tight.
Hang in there, you'll figure it out.
Brian Denk
RV8 N94BD
Rob
I made a rextangular rib to fit into that little joggle at the left side of
the rear baffle. Now the baffle material can extend in a straight line from
side to side.
Dave Fried
One way to minimize the possibility of the stencil bleeding is to blow a
light coat of the base color around the edges (i.e. white) before painting
the final color coat. The base color coat might bleed but seals the stencil.
It is less noticable than the color since it matches the base. This was
passed along by an RV4 builder at Oshkosh this year. He may be lurking out
there.
Tom Brown RV4 fiberglass
RV4brown(at)aol.com
Subject: | Re: Oops! Securing Vetterman's exhaust |
I have 0-360A1A at 180 hrs and have had two adel type clamps fail and one SS
elbow fail, which is part of the spreader bar, on the Vetterman's mount.
If this continues I will be changing something.
Ron Vandervort, RV-6 N84N Seattle area...on round the USA flight...reporting
in from Myrtle Beach S.C.
The spring on the gun penetrated into the lightening hole, as opposed to
the gun sitting inboard with the offset rivet set.
Mark Phillips adds:
I removed the spring from the gun and wrapped 3-4 layers of duct tape to
hold the offset rivet set in the nose of the gun- you get a much better
angle, worked great for me, Y.M.M.V. but I got 7 good rivets like this
(don't ask me to show the ones I did before I thought of this!)
From the PossumWorks
Mark... "duct tape: one side's light and the other side's dark; it's
the force that holds the universe together!"
- > -----Original Message-----
> From: tom sargent <sarg314(at)azstarnet.com>
> >on there?
FAR43 is clear on logbook entries: a complete discription of work performed.
Even though part 43 is not our realm it is a good guide. I would make a
entry similar to the following-
Overhauled engine IAW manufacturers manual ( list it) with the following
deviations. (list ALL deviations).
(Then list all parts used and P/N S/N as well as new or the limits they
had.)
The engine may not be certified now but if you list all the mods it can
make it possible to return the engine or parts of it to it's original
condition. This is important if you sell it. About the prop, I am not clear
if you mean the engine was not designed for it or that the prop was not
legally rebuilt. Either way I would make another entry showing this prop
installed and the condition and status of it as well. This will protect you
since it is not illegal to run mods on experimental acft but we need to
document the fact or risk questions later.
RV4 flying, A&P-IA, FAA safety counselor
Date: Saturday, October 23, 1999 7:19 AM
Subject: RV-List: Log entries?
engine
crossed and
>Have a great Day!
>Denny Harjehausen
>Lebanon, OR
>RV-6
Subject: | Re: Documenting Registration Number Change for RV-6A |
The easiest way to be sure is contact your local FAA FSDO. You will have a
few forms to fill to complete youre process but it's no big deal. A call to
EAA or AOPA can help as well. We do N# changes in my office alot so if you
have problems contact me direct here or at work at bnoel(at)omniflight.com and
I will try to help.
From: Howard Walrath <H_D_Walrath.HVIL(at)prodigy.net>
Date: Sunday, October 24, 1999 3:16 PM
Subject: RV-List: Documenting Registration Number Change for RV-6A
>Specifically:
>the only revision?
>Howard Walrath
The AOPA Memebers Section has excellent weather graphics (DTN), I use it
almost daily.
Bob Dz
RV-6A Tail kit
Date: Sunday, October 24, 1999 7:31 AM
>channel or duats.
>chet
Subject: | Pop Rivet problems |
Listers, I'm trying to set MK319-BS monel pop rivets in the trailing edge of
my rudder stiffeners. The stems keep breaking off so that they rattle around
inside the rivet or come out the backside altogether leaving a hole in the
middle. I'm using a pneumatic pop rivet puller. Have tried various air
pressure settings. Surely, it isn't normal for these rivets to have loose
stems like this. Should I shelf the pneumatic puller and buy a hand operated
unit? Thanks.
Troy Black
-8 @#$% rudder stiffeners
Subject: | Enroute Assistance........yeilded quick drain leak. |
Eureka....!!
With the help of Harvey in Delaware my enroute oil leak has been stopped.
A noteworthy bit to pass on to all "quickdrainers";
We found the quick drain to be the culprit. It did not leak during three
ground runups but would leak a quart in a two hr. flight. The o-seal did not
look like it should be contributing to a leak. I have suspicions that it
might have been related to o-seal deteriation with high temp exposure near
exhaust muff over time, as the leak increased as time went on. Reinserting
the crankcase plug solved the problem.
Ron Vandervort, RV-6 180 hrs Seattle area...reporting in from Myrtle Beach
S.C.
Subject: | Re: Pop Rivet problems |
> unit? Thanks.
> Troy Black
It's a little early for that kind of language, unless you're practicing for the
gear boxes :-)
As for the MK319-BS rivets, it sounds about normal actually. I'm not quite sure
what you mean about
"rattle around inside the rivet". Sometimes the end of the stem stays in the rivet,
and sometimes
it doesn't. I'm often tempted to punch out the stem just to keep it from coming
out later, but I
don't. I doubt the pneumatic rivet puller has anything to do with it. My experience
with a Kolb
SlingShot I build was that the pneumatic puller does a superior job to the hand
version. However,
you'll run across rivets that you won't be able to reach with the pneumatic puller
(like the Z
brackets on the fuel tank baffles) so you might as well buy a manual one anyway.
You can try a few
rivets to see if it improves your situation, but I doubt it will.
Good luck,
Russell Duffy
Navarre, FL
RV-8, sn-587, N174KT (front baggage door)
web
Tom, try grinding a flat area on the side of the rivet set to allow it to sit
squarely on the shop head. These are sold by Avery and others, but you can
modify yours. Andy Johnson, -8 wings
Rob Acker wrote:
> Listers,
Rob,
I just put a little bridge of aluminum across the offending section. Gives you
a
nice straight run with the rear baffle seal to the side and looks neat. Seal the
gaps with a little red RTV.
Leo Davies
RV6A 6 hours and growing.
Subject: | Re: Panel Design |
Norman,
On my 6A slider I would need 1.25" more room to get 3 high. My instruments have
1/2" between hole edges. This would leave no room under the bottom instrument
and has 3/4" above the artificial horizon.
Gary Zilik
> guess?
Anyone interested in buying my RV6A Project give me a call at
318-221-3503 or E-Mail me at jerrydd(at)earthlink.net. Wings,
Empennage,Fuselage and most of Finishing Kit is complete. 0 SMOH 0-360
A1A Lycoming Engine and 0 SMOH McCauley Constant Speed Prop. New
Vetterman Exhaust, Overhauled Govenor, Rocky Mountain Micro-Monitor, New
vacuum pump, New Skytech starter, New Instruments, Vans Wiring Kit, New
Fuel Pumps Mechanical and Electric, Carb and Mags, ETC...
Subject: | RV-4 Eng.-Mount Bolt Hole Fix |
I have just finished drilling my engine mount to the firewall on my
RV-4. I had previously drilled 3/16 dia. undersize holes to attach it to
the jig. When I first fit the engine mount I could see the holes did not
line up perfectly with the mount, but it appeared that they would clean up
if I used the mount as my drill guide. After finishing the drilling and
removing the mount, much to my dismay I found that one of the holes did not
clean up fully. About 1/8 of the 3/16 dia. hole is left. The offending
hole is on the bottom right side of the fuselage.
Anybody else have this problem? Any ideas on how to fix this? Is it
really a problem?
I have thought about trying to weld a reinforcing doubler to the steel
weldment and redrilling, but it would be very difficult to weld down there.
I thought about cutting off the 3/8 ID tube on the mount, welding in a 7/16
but I don't know how these bolts are loaded.
What really makes me mad is that this is the first mistake I've made in
5 years of building (if you believe that I've got a BD-5 kit I'd like to
sell you).
Thanks in advance,
Ted
>In a message dated 10/22/99 4:29:44 PM Pacific Daylight Time,
>grobdriver(at)yahoo.com writes:
><< I doubt I'm the only one with this follow-up question...
> Why is an avionics master switch outdated? >>
>IMO Bob should have prefaced that comment with "IMO", because it is by no
>means a certainty. I know that Bob has what he considers to be good and
>valid reasons for believing that the Avionics Master is outdated, but even
>smart people of good conscience don't always draw the same conclusions from
>what they perceive the facts to be.
>-GV
Given what I know about why the avionics master switch
was perceived to be a good thing to do (I was an electrical/
avionics tech writer at the Cessna single engine facility
from 1964 to 1969 where we birthed the thing); and having
been involved in the certification of dozens of products
that attach to aircraft electrical supply busses; and
having observered the evolution of electronics systems
capabilities over the past 30 years, I think the statement
is a tad stronger than an singular opinion. Neither I
nor any of my collegues has ever designed a product for
use in ANY airplane that requires pilot intervention to
hold the wiley electro dragons at bay in the defense of
our products. I'm talking some pretty sensitive, microprocessor
based hardware here too . . . We hook 'em up and they
play.
The avionics master switch was conceived in good faith
but like the carburetor, points in the distributor,
relays in the regulators and vacuum tubes in the radios,
the avionics master switch no longer provides a
useful function while driving parts count up and reliability
down.
Of course, the alternate feed path mitigates the reliability
factor for an avionics master so by all means, if you have
the panel space and want to have one, it's not an issue
with respect to probable outcome of any given flight.
(o o)
===========o00o=(_)=o00o========
< Independence Kansas: the >
< Jurassic Park of aviation. >
< Your source for brand new >
< 40 year old airplanes. >
http://www.aeroelectric.com
Subject: | Re: Aviation Trust Fund Support |
Details of bill AIR-21 (Aviation Investment and Reform Act for the 21st
Century) that unlocks the Aviation Trust fund can be found at
http://www.aopa.org/whatsnew/newsitems/1999/991021trust.html. Billions
of dollars that we pay in as fuel taxes and passenger ticket taxes sit
unused in the fund. The bill comes up for discussion in the Senate on
Monday, October 25th. Call or fax your Senator TODAY and tell them to
support AIR-21!
Senate Switchboard: 202-224-3121
Senator Fax numbers: http://www.aopa.org/whatsnew/faxnos.html
Comprehensive history of AIR-21:
http://www.aopa.org/whatsnew/caphill.html
>Congress has made great strides in getting the Aviation Trust Fund
>legislation passed. The Senate now has to act and that action is
>expected this week, with many conferences going on between the Congress
and the
>Senate.......
From: | Thomas McIntyre <bogeybrother(at)earthlink.net> |
I'm looking for a new or slightly used MA4SPA carburetor.
Please contact me off-list.
Tom
I was feeling guilty about those croos country trips where my wife got
stuck with the $80 Flightcom headsets and recently bought a Lightspeed 25X
set. I had been impressed with them at SNF, testing them in their demo
"egg" booth. When I flew with the in my -6A however they seemed overly
sensitive, the speakers distorted at about half volume, and they had a
constant hiss to them. Lightspeed, here in Portland, gladly refunded my
money and let me try the 20K's. These seem to work well, the mic volume
better matches the headset volume. I have to admit though the $155
upgrade-your-existing-Dave-Clark ANR that I installed in my headset 2 years
ago are just about as good. I do think ANR's are the way to go rather than
attempting to soundproof the cabin. kevin -6A 450+ hrs
I just cut the sides longer so that it overlapped the other side, and folded
one over the other, and secured with a pop rivet and washer. On the oil
cooler side,. I cut the baffle seal from the top of the seal down to the
baffle, bent them in, and had to put a small piece of material inside the
folds to make a good seal. This probably doesn't make much sense, but it
was just a head scratching trial and error job that took the better part of
one evening.
I have been uploading a few baffle images, I'll try to get them finished up
in a couple of days. In the meantime, check out:
http://members.home.net/rv8er/engine.htm
It has one picture of one corner...I am waiting to repaint a screw up on the
other side, when I paint it in the next couple of days, I will re install
the baffle material and post pics of that.
Paul Besing
Finish Kit
Date: Sunday, October 24, 1999 11:08 PM
>Listers,
> > > --> grobdriver(at)yahoo.com writes:
> >by no
> >and
> >but even smart people of good conscience don't always draw the same
> >conclusions from what they perceive the facts to be.
> down.
Let's cut to the chase, here, gentlemen. We sound like a bunch of
politicians! A lot of of words, no information!
1) Why was the avonics master "conceived in good faith?"
2) Does or can engine start cause voltage spikes on a power bus?
3) Do modern (1980's, 1990's) avionics provide sufficient power input
filtering to trap (caps) or shunt such spikes?
Inquiring minds have an idea, but still want to know!
Mike Thompson
Austin, TX
-6 N140RV (Reserved)
Wings
> > unit? Thanks.
> > Troy Black
>However,
>pneumatic puller (like the Z
>one anyway. You can try a few
One thing to keep in mind if you do buy a manual pop rivet puller now
- it will need to be able to reach rivets very close to a corner to
do the Z-brackets. My pop rivet puller wouldn't reach, and I was
ready to pull my hair out when I found a small pop rivet puller in my
wife's pile of tools. Even then I had to grind it down some to get
it to fit. If you do grind one down, you might want to wear safety
glasses when using it. My wife's eventually exploded on me, and I
had to do an emergency battle damage repair on it.
Ottawa, Canada
>> down.
>Mike Thompson
Mike,
Surf over to the Bob's list of articles and info at
http://home.kscable.com/aeroelectric/articles.html and read the one
on avionics master switches. It should answer your questions.
Ottawa, Canada
From: | "Lemen, Ted Ce" <ted.ce.lemen(at)lmco.com> |
Larry, the stress on the rivets is the same as if you had two rows. The main
difference is that the two skins are pulling or pushing against each other
and what ever is left over goes into the spar, wheras with the two rows, all
loads go into the spar and and the tension or compression that is left over
transfers from one skin to the other through the spar. Draw a cross section
of the single row rivet and I think it becomes more clear.
Ted Lemen Denver
(Content Technologies SMTPRS 2.0.15) with SMTP id
for" ;
Mon,
25 Oct 1999 08:42:35.-0400(at)matronics.com
Hi Kyle,
If you have a dual action sander (harbor freight $30) you can get a sponge
attachment at your local paint store that does a great job. What I have always
done is wet sand with 1500 grit until you get a uniform chalky appearance then
use the sponge buffer and LOTS of 3M finessing compound. I soup it on then buff
till completely gone. I think the sponge is a little more forgiving than a
polishing bonnet.
If it looks like what you are doing is always going to yield a little orange
peel, then plan for an additional light coat so you don't get light spots. At
least this is what I learned from beating my head against the paint wall.
Eric Henson
Fuse Stuff
KBoatri144(at)aol.com on 10/23/99 02:13:19 PM
Subject: RV-List: Buffers
I'm into the painting process, and it turns out that I've got some defective
paint - it has orange peel in it! (Or maybe it was the oaf running the spray
gun...?) Anyway, I'm looking for a buffer. Anyone have experience with the
$50 units sold at auto parts stores, home improvement stores, etc? Will this
type unit be OK for some moderate buffing? If not, please provide some
suggestions for a reasonably priced unit which would work.
And, yeah, I could probably borrow one, but this is a great excuse to buy
another tool.
Kyle Boatright
Cause every once in awhile, when a hoard of pilots arrived
on the field at Cessna to take delivery of a gaggle of new
airplanes, the piece of crap batteries we were able to buy
back then were dying or dead. Radios of the time contained
the earliest examples of solid state technologies . . .
GERMANIUM transistors with 30 volt not to exceed ratings
and "second breakdown" (a merit of vulnerability under
certain operating conditions) characteristics that would
poof a transistor in a few microseconds.
RTCA (Radio Technical Commission on Aeronautics) barely
knew what transistors were much less how they might be at-risk
in a piece of avionics. Vacuum tubes were king.
Yes.
YES! Over the past 20 years, an RTCA specification (DO-160) has
been through 4 major revisions. The document outlines about
27 environmental stresses to which a wouldbe producer of
electronics for aircraft should design for if they expect
their products to survive in the real world. Building firewalls
for electrical stresses (the kind that the Avionics Master
can deal with) is child's play. It adds a very few dollars worth
of components to the design. Heat and moisture are the biggest
killers of electro-goodies to this day.
I visited Electro-Mech a few days ago . . . used to work there
20 years ago. Picked up a product I'd designed for the Learjets
back about 1982 . . . pitch trim controller. I asked the
technicians what kinds of failures they were finding on returned
units. Of the three guys I talked to, not one had replaced a
popped semiconductor . . . virtually all failures were mechanical.
Corrosion, insulation displacement connectors that had become
intermittant, fasteners that were loose and a handfull of random
failures in components unrelated to any environmental stress.
This device, an many of it's cousins of the time, are tied right
to the bus during engine cranking (1000 amp inrush starters)
and bus bumps during generator initialization (2 generators
of 600 amps each side) and lots of contactors going on and
off . . . scarry compared to our single engine boogity-
boogities. I'm working on three new, bus powered products
for single engine airplanes including the AGATE program.
Bus gremlins are so far down on the list of things to worry
about, they aren't even on the radar screen. I've not had a
product fail in certification testing from bus induced stresses
since I learned how to do it 20 years ago.
My personal experience with rentals of dozens of airplanes
recalls many instances where the avionics master switch was
left on during shutdown . . . I have to presume that like all
checklist items on airplanes not regularly flown by a multiplicity
of pilots, some things get missed from time to time. I've
never had a radio come up dead after engine start. As a further
reinforcement to the "what, me worry?" attitude, consider all
the electro goodies on the modern automobile . . . these aren't
even high-tech, supper qualified products certified for
aircraft . . . they get hit with whatever the bus throws at
them severals times each day . . . far greater service cycles
than any airplane. Drivers are not asked to "protect" any of those
things from things that go spark in the night . . .
Have the switch if you desire the convenience but back it
up with the alternate feed path that allows you to shed
main bus loads -AND- the battery contactor.
(o o)
>unit? Thanks.
>Troy Black
What size hole are you drilling? I think I recall they call for a
7/64" bit.
John Ammeter
Seattle WA
USA
http://members.home.net/ammeterj/
1975 Jensen Healey
RV-6 (sold 4/98)
EAA Technical Counselor
NRA Life Member
ICQ#48819374
Subject: | Aerobatic Propeller |
I have a like new Aerobatic Counterweight Propeller for sale. If interested,
please contact me @ "gilthe1(at)aol.com".
Gil. 80628 almost ready for paint
From: | "Chris Browne" <cebrowne(at)earthlink.net> |
Subject: | Re: RV-4 Eng.-Mount Bolt Hole Fix |
Ted,
I went through this with my -6A. Tom at Vans explained that the firewall
bolts are compression joints, meaning the size of the hole is not critical.
Check the archives on this. He used the example of changing engine mounts,
in which you would likely have to open the holes up to get a new mount to
align. Tom said just to line it up as best you can and drill away. He
specifically said that no repair plates are necessary.
Chris Browne
-6A finish
Atlanta
Date: Monday, October 25, 1999 12:14 AM
Subject: RV-List: RV-4 Eng.-Mount Bolt Hole Fix
>really a problem?
>sell you).
>Thanks in advance,
>Ted
Ron,
Whose quickdrain was it that leaked? There are several manufacturers out
there. Has anyone else on the list had a similar problem? I have a
quickdrain from Van's that has not leaked so far (just put it on 50 hours
ago).
Take care,
Scott Gesele N506RV - Flying
From: | "Fesenbek, Gary" <fesenbek(at)marykay.com> |
Well this is going to be a shocker for you. I bought a used KX155 w KI209
with no manual/harness. I was rolling my own so I contacted Bendix-King for
a manual and they sent me one "FREE". Quite nice folks in these days of $10
shipping and handling on a $2 order.
Gary Fesenbek
RV6A, final touches
Dallas, TX
Very well put Larry!
Bryan Files
Ever Fly MAintenance
Palmer, Alaska
-4 tail
Sent: Sunday, October 24, 1999 11:39 AM
Subject: RV-List: wing skins
> Hi !!!
rivets.
I
level.
> Larry E James
> Bellevue, WA
> larryj(at)oz.net
> is
the
log
> so
the
> market.
> joint
in
> > > the fuel tank area.
Kyle asked:
Kyle,
When I was doing custom paint, I used a buffer that was sold at Sears. It was
a 2 speed unit. I don't remember the cost off hand, but I think it was around
$75. One of the keys of buffing out paint is to use a slow wheel speed, somewhere
less that 1500 RPM. If its going much faster than that you stand a REAL
good chance of burning the paint, which will make it look worse than the orange
peel. The lack of a slower speed is one the drawbacks to some of the cheaper
units on the market. The best polishers will have a variable adjustment.
A little practice you'll be slinging compound with the best of em.
Good luck
Laird
SoCal RV-6 working instrument panel stuff
My Grand Rapids engine monitor will occasionally display "digital gibberish"
if left on during engine start. The Avionics Master is the only on/off switch
for this unit (besides the battery contactor/master switch.) Granted, I
could reset the monitor CPU (and the gyros, and the radios, and the GPS,
etc...) with the master switch, but the Avionics Master, properly used,
avoids this hassle every time.
The digital boxes in my plane have yet to fail outright from a voltage spike,
but they can and do get their little brains addled from time to time if
subjected to bus voltage during cranking; something to think about, and it
works for me.
-BB
Subject: | S-TEC altitude hold |
I'd like comments from anyone who has installed or has experience with the
S-TEC System 30 in a 6 or 6A. Information related to installation and/or
performance would be appreciated.
I have the System 20 in my 6A and am considering adding the altitude hold
feature because of difficulty in achieving pitch trim for constant altitude.
Phil Rogerson
Fernandina Beach, FL
Does anyone know where I can find the phone number for the company that
produces the RC Allen instruments???
Brian
I had my first experience with installing firesleeve this weekend and I know
there has got to be a better way to tighten the clamps. These are the
store-bought band style that I thought would look better than safety wire.
My Rube Goldberg approach with vise grips to pull the free end and a
big-assed screwdriver to push the band seems destined to impale the
screwdriver in my hangar wall or otherwise injure me. I got away with 2 but
I don't want to tempt fate. I'm sure there's some spiffy, polished titanium
tool to do it, but I just need a manual way for the dozen or so clamps I'll
have. What's the secret?
Greg Young
RV-6 N6GY (reserved) finishing kit
"Always do right- this will gratify some and astonish the rest." - Mark
Twain (1835-1910)
Subject: | "One Small Step For Man..." |
CHANGE OF SEASONS BRINGS ANNUAL "NO" VOTE
It is a battle always fought in Washington as the leaves begin to fall,
and 1999 has proven to be no exception. A body that rarely supports any
issue with unanimity voted last week 419 to 0 against H.R. 3085, a bill
that would have enacted $1.5 billion in aviation user fees. H.R. 3085
was actually introduced to allow Congress to take a very public stand
against new taxes disguised as user fees, and the Clinton White House's
annual attempt to enact them.
Subject: | Re: lightspeed 25X |
I purchased a pair of 25XLs for my wife to use (I normally wear a helmet)
and I was looking for something comfortable for her. I tried them one
day in my RV-4 and found them to be nothing short of amazing. The only
strangeness is that everything sounds unbalanced due to the lack of bass
frequencies. It affects the radio reception but it actually has the
effect of making radio communications more readable/unstandable at the
cost of making voices sound unnatural.
Bottom line: if I didn't have a helmet, I would be wearing a Lightspeed 25XL.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
Cy,
My apologies but I respectfully disagree. If the engine is modified and no longer
meets the type design for that model engine then the Data plate is no longer
valid until the engine is returned to the original configuration. Obviously
nobody will probably know if one does not remove the DAta plate unless something
happens but technically the data plate is supposed to be removed.
Mike Robertson
RV-8A QB
"Das Fed"
In a message dated Sun, 24 Oct 1999 12:00:16 PM Eastern Daylight Time, "Cy Galley"
writes:
> >Denton,
> future overhauls.
> >Mike Robertson
> engine
> crossed and
> >> Have a great Day!
> >> Denny Harjehausen
> >> Lebanon, OR
> >> RV-6
Subject: | RV-6 Videos wanted |
I'm looking to purchase some of the construction videos for the RV-6. Made
my Mr Orndoff? Ed Kowalski posted a email a few weeks ago but I'm not able
to get a hold of him. If Ed is out there or anyone else has the videos
please let me know.
Future builder and RV admirer.
Steve Hurlbut
Comox, BC, Canada
shurlbut(at)island.net
Subject: | Re: Question Answered, was Re: Question |
> input
> YES!
I'm going to have to read that book...
Thanks, Bob.
Mike Thompson
Austin, TX
Wings
> Brian
You're in luck, because I just hung up the phone with them. Apparently, RC Allen
has been Kelly
Manufacturing for some time now, but I'm always the last to know :-) Anyway,
call 800-722-4976 if
you're in the US, and if not, let me know and I'll call them to get a toll number
for you.
On the subject of RC Allen ELECTRIC (didn't ask about vacuum) gyros, I just asked
a few questions.
First: What fuse do they need- 2 amps.
Second: How do you adjust it for panel tilt. Answer- you don't, they do it for
$200 unless you
were smart enough to order the instrument that way in the first place. BTW- this
only applies to
the AI, and not the DG.
Third: Do aerobatics hurt them. Answer is that they're very durable in aerobatic
use. I asked if
it was better to have them running or shut down, and they said it was really a
toss up, but maybe
slightly better to have them off. They said there are no stops to run into, as
long as you don't
engage the caging function (AI only) during aerobatics.
Russell Duffy
Navarre, FL
RV-8, sn-587, N174KT (just found out it's going to cost me $200 to get my AI adjusted
for panel
tilt- rats!!!)
Howard,
AS you have stated there is some question in my mind of what you want to do so
I will take a stab at all of it. It is ironic that you should ask this as I just
finished finding out some of this for another group (Police Dept.) that wanted
to change their reg. number while waiting for the hard copy of their new
registartion to arrive.
First if all you are trying to do is change the number on you plane and you have
already requested the change then you need to wait for the new permenant registration
to arrive then apply the new numbers, and take the special airworhtiness
certificate and operating limitations to your local FSDO to have them amended.
DO NOT FLY The aircraft until that is completed. More than likely they
will change those while you wait. Once that is done go enjoy flying.
If, on the other hand, you are trying to change the special registration number
that you have already requested to be applied then you have to wait until the
hard copy registration arrives and then go thru the process of changing it again.
If I have got this correct then go for it, but if I haven't then please feel free
to email me directly off-line and I will be glad to help.
Mike Robertson
RV-8A QB
"Das Fed"
In a message dated Sun, 24 Oct 1999 4:45:27 PM Eastern Daylight Time, "Howard
Walrath" writes:
> Specifically:
> the only revision?
> Howard Walrath
Does the slight tilt in the -6(A) panel enough to justify a corrected gyro?
Paul Besing
Finish Kit
> Paul Besing
Paul,
The RV-8 panel is tilted forward 8 degrees relative to the top longerons, and according
to RC Allen,
it absolutely has to be corrected. I'm guessing the RV-6 is similar, and either
you can measure it,
or someone will let you know what the tilt is. Fortunately, my gyro is still new
and unopened, so
Aircraft Spruce just gave me an RMA to exchange it at no charge for the 8 degree
tilted model. That
just saved me about $180 :-)
Russell Duffy
Navarre, FL
RV-8, sn-587, N174KT (canopy done, starting panel and electrical)
it for $200 unless you
BTW- this only applies to
I got them to do it for $100. I told them that I bought their instruments
not knowing that they were not universal. That was the truth. I admit if
I would have thought a bit I would have known better, but...
So give it a try!
Denny Harjehausen
FTL-Capt/SO/Nav/Mech(Ret.)
FTL Ret.
Lebanon, OR
There is a tool. I was lucky, a friend had one.
Denny Harjehausen
FTL Ret.
Lebanon, OR
Any tilt will show up, as I discovered running my instuments with plane
leveled. I believe it is * degrees for all the -6s, A or not.
Have a good one!
Denny Harjehausen
Lebanon, OR
Paul,
It sure does - mine is 8 degrees built per plans, just like the standard tilt
Sigmatek.
Chris Browne
-6A finish
atlanta
> Paul Besing
> Finish Kit
Does anyone have the original number for the Lord Mts. used on the Van's
Con. mount for an IO 360 ? Gettin droopy and alternator is wearing
through.
thanks
JMP
> Paul Besing
> Finish Kit
YES. Gone through 3 attitude gyros in 400 hours
without the tilt. When my spare gets back from the
repair shop, it will have the 8 degree tilt retrofited
in. This lesson has cost me the purchase of TWO new
gyros. The first one failed at 125 hours and was
overhauled for $300. The 2nd new one failed at 13
months 220 additional flying hours and was repaired
under warranty. The overhauled one ran 75 hours and
is not being repaired under warranty and should come
back with the 8 degree tilt I measured in my panel.
This has been an EXPENSIVE lesson for me. The most
expensive lesson on the airplane that was caused by my
engineering / construction in 445 flying hours.
Gary A. Sobek
So. CA, USA
You are correct, I do not believe I disagreed.
Date: Monday, October 25, 1999 3:32 PM
>Cy,
longer meets the type design for that model engine then the Data plate is no
longer valid until the engine is returned to the original configuration.
Obviously nobody will probably know if one does not remove the DAta plate
unless something happens but technically the data plate is supposed to be
removed.
>Mike Robertson
>RV-8A QB
>"Das Fed"
Galley" writes:
>> >Denton,
to
conducted.
do
>> future overhauls.
>> >Mike Robertson
overhauled
>> engine
by
>> crossed and
>> >> Have a great Day!
>> >> Denny Harjehausen
>> >> Lebanon, OR
>> >> RV-6
In a message dated 10/25/1999 7:02:33 PM Eastern Daylight Time,
rv8er(at)home.com writes:
The answer to that is yes and no (for the AI gyro)!
With a tilted panel and a non-corrected gyro, the attitude gyro horizon line
in level flight will not line up with the horizon tic marks on the sides of
the gyro case.
I think it is nice to have them look correct and plan to make sure that I
have a corrected AI gyro. I also plan to fly IFR! If you plan to level your
RV and measure the panel angle, level the longerons from the correct place
(not just aft of the panel).
I just discussed this with several gyro manufacturers this past weekend at
AOPA Expo. None of them indicated any other problems other than the off case
horizon indication!
david faile, fairfield, ct
mcfii/a&p faa aviation safety counselor
eaa technical counselor/flight advisor
christen eagle ii since '82 (n13bf)
rv6 (n44df) started
Hi,
Since the book Lycoming supplies with the engine isn't all that detailed
for such things, can someone please identify the following threaded
holes on the cylinder:
1. On the top surface side of the cylinder, just left of each upper
spark plug is a tapped hole (1/8 NPT?) that has an allen head screw in
it on all four jugs.
2. On the bottom surface of the cylinder, just inboard of each spark
plug is a tapped hole (1/8 NPT?) that has nothing in it.
Logic tells me #1 is for the primer lines, and #2 is for CHT probes.
But I don't want to find out the hard way.
-Glenn Gordon
I disagree Mike. I know that you are a Fed but..... If you have a Lycoming
O-320 and make modifications to it you still have an O-320. It is a
modified O-320 but never the less it is still an O-320. If he sells the
aircraft the new owner must have the aircraft annualed every year by a
licenced mechanic because the new owner did not build the aircraft.... As a
licenced mechanic you can not sign off an annual inspection on any aircraft
or any engine that does not have a data tag. If you can point me to an FAR
that states something different I would be glad to take a look at it.
How is your 8QB comming or is it finished?
Bryan Files A&P IA FAA Safety Counsler
Ever Fly Maintenance
Palmer, Alaska
-4 tail
Sent: Monday, October 25, 1999 12:03 PM
> Cy,
no longer meets the type design for that model engine then the Data plate is
no longer valid until the engine is returned to the original configuration.
removed.
> Mike Robertson
> RV-8A QB
> "Das Fed"
Galley" writes:
> > >Denton,
to
conducted.
do
> > future overhauls.
> > >Mike Robertson
overhauled
> > engine
reconditioned by
> > crossed and
> > >> Have a great Day!
> > >> Denny Harjehausen
> > >> Lebanon, OR
> > >> RV-6
Installing the pitch servo is easier than installing the roll servo for the
system 20 - plenty of space behind the luggage compartment and good parts
and directions.
The rest of the parts are
- an altitude transducer mounted behind the luggage compartment up top
- a climb rate box, I installed it behind the panel
- and a button on the panel to activate the altitude hold.
I like it.
Rick Solana, N804RS, 40 hours
Richmond, VA
> PhilipR920(at)aol.com
> Sent: Monday, October 25, 1999 1:45 PM
> To: rvlist(at)matronics.com
> Subject: RV-List: S-TEC altitude hold
> with the
> constant altitude.
> Phil Rogerson
Subject: | Re: Log entries? |
Bryan,
Hey, thanks for the comment. This is good.
The FARs address this in a round about way. FAR 21.31 talks about the type design.
An o-320 may still be an o-320 but it goes further than that. One has to
also look at the extended configuration, i.e. A1A. When one gets into the specific
design and components called out in the design for that engine then we
get down to it. Yes for experimental aircraft we don't worry about that for
the yearly condition inspction but in order to return that engine for use in a
"standard" category aircraft it must be returned to its original condition.
The data plate calls out the extended configuration so therefore if the engine
is altered in any way from its design then the data plate is "technically" invalid
and is supposed to be removed.
But the bottom line is that neither I nor any other inspector is going to tear
an engine apart to find out unless somebody tells us about a specific engine or
if there is an accident and the engine is suspect.
I am not even going to go to the reason why anybody does not want to remove the
data plate (25 verses 40, hint...hint).
My -8A is coming along fine. I received the fuselage and wings in August and am
shooting for a Xmas first flight. It is going to be close because a few important
parts are on back order with expected delivery dates of December 1st.
We'll see.
Mike Robertson
RV-8A QB
"Das Fed"
In a message dated Mon, 25 Oct 1999 9:31:20 PM Eastern Daylight Time, "Bryan E.
Files" writes:
> Palmer, Alaska
> -4 tail
> From: <MRobert569(at)aol.com>
> To:
> > Cy,
> removed.
> > Mike Robertson
> > RV-8A QB
> > "Das Fed"
> Galley" writes:
> > > >Denton,
> > > >Put exactly what you have done to the engine and prop. State that they
> to
> conducted.
> do
> > > future overhauls.
> > > >Mike Robertson
> > > >RV-8A QB Just installed wings
> > > >In a message dated Sat, 23 Oct 1999 8:40:20 AM Eastern Daylight Time,
> > > >> Anyone out there give me an idea of log entries for an
> overhauled
> > > engine
> > > >> that is not certified because of mods and a C/S that was
> reconditioned by
> > > >> an prop overhaul shop employee?
> > > >> I am about to call for inspection and need to get all the Ts
> > > crossed and
> > > >> the dots in the right places.
> > > >> Have a great Day!
> > > >> Denny Harjehausen
> > > >> Lebanon, OR
> > > >> RV-6
Subject: | RV8 Fuse Jig - Free to good home |
Listers, I have an RV8 Fuse jig, very well constructed. Free to good home.
Palm Beach, FL
561-748-2429
Scott
From: | Frank van der Hulst <frankv(at)ee.cit.ac.nz> |
> without the tilt.
I don't understand *why* the angle of the panel should affect the life
of the gyro. Could someone explain it to me please?
To my simple mind, if the panel is tilted 8 degrees, the gyro will just
think you're flying along at an 8 degree nose-down (or is it nose-up?)
attitude most of the time. Why should this affect the gyro? If you do a
lot of descents at 8 degrees nose-down, will this somehow shorten the
life of the gyro (assuming you remember to always stop descending AGL)?
How about gyros in taildraggers? Most of the gyro's life will be spent
in an 'unusual' attitude. A significant part of its active life
(taxiing, run-ups, take-off, landing rolls) is done in this ??? degree
nose-up attitude.
Frank.
(feeling like I'm not getting the picture here)
frankv(at)ee.cit.ac.nz Frank van der Hulst
My home page is http://homepages.ihug.co.nz/~frankvdh
Subject: | RV6 how to drill center tube on sliding frame? |
Hi listers,
I have the canopy split, drilled and cleco'd to rollover bar and forward bar
of the sliding frame. The lower edge is also trimmed above the outer
horizontal bars. I believe the only way to drill the center bar (at the top
of the canopy) is to remove the canopy from the fuselage and drill it on the
bench where I can lean over it - or - stand it vertically on the forward
bar.
Am I on the right track or is there a reason to do it on the plane?
Thanks in advance for your suggestions.
Tom Barnes -6 canopy
Buffalo Grove, IL
From: | "Bert F. Murillo" <bertrv(at)intellistar.net> |
Subject: | Diameter rivets.. |
10/25/99
Bert Murillo
:bertrv(at)intellistar.net
This might be a first? when I was riveting the flap brace & hinge, i
discovered
fortunately, after I have set a couple rivets, as the first ones, I thought
I had the
wrong size.....after looking carefuylly, I did have rivets called for in the
plans
426-3.4 rivets... but what happened is that the rivets are too "thin" they
would
fit perfectly in the gage no. 41 hole.. but on the no. 40, ofcourse they
are too
loose...and the shop head does not set properly, actually gos thru the
hole....
The rivets I am using, are the ones that came with the kit, from Vans...
altough I had some that came with the empenage kit, they were fine...
This is really a puzzle for me... can any one solve the mistery... or really
are rivets as AD426-3 for no. 41 drill????
Please E-mail suggestions...
Bert
was finishing falps.....
Dimpling was correct, with the Avery dimpple set...for no. 3 rivets..
In a message dated 10/25/99 7:46:27, fesenbek(at)marykay.com writes:
Gary Fesenbek
RV6A, final touches
Dallas, TX >>
I had a similar nice experience when I called and confessed I never got
around to sending for my free update on the GPS two or three years ago and
they sent me one free ! Very nice folks.
Subject: | RV-6A for sale - pictures |
Sorry to take up list space again but several people contacted me about my
RV for sale and wanted to see pictures. I bought a digital camera and took
pictures but have lost the e-mail address of those interested. It you are
interested, please contact me directly and I will send pictures and/or
information.
Thankyou, Rick Fogerson
Just to pass on a note...I originally painted my interior with a
conventional DeVilbess siphon gun, and got paint EVERYWHERE. It wasted an
enormous amount of paint, and since it was high in pressure, runs were very
hard to control. I was having trouble with it recently, and decided to go
buy an HVLP gun. Let me tell you, the difference was too much to describe.
The paint was idiot proof and looks excellent. Not to mention, there is NO
overspray anywhere, and I used ALOT less paint.
For those who desire to purchase one, I bought a Sharpe Cobalt for about
$150. This came from the recommendation of my local Sherwin Williams
dealer, and he assured me that the quality of the job will equal that of a
$400 HVLP gun...he was right...Go check it out at:
http://www.sharpe1.com
Paul Besing
RV-6A (197AB) Arizona
Finish Kit
switch
A clasic example of poor craftsmanship in the design and
fabrication of a modern aircraft instrument. If I tried to
sell something like that to my pilots at Raytheon, they'd
cut off my supply of atta-boys.
spike,
>works for me.
Have you complained to Grand Rapids about this? It takes a
50-cent jelly-bean part to do an orderly reset of the internal
processor in case of brown-out. Unless you guys complain about
poor performace quirks in these products, the manufacturer
sails along fat, dumb and sassy thinking that they're doing a
good job. They won't get better unless you expect them do
do better and let them know about it.
(o o)
From: | "Stephen D. Metzger" <smetzger(at)ma.ultranet.com> |
Subject: | Re: S-TEC altitude hold |
Phil,
I don't have any experience with the STEC-30 in an RV, but I just had one
installed in my Cessna Cardinal RG. I plan on installing one on my RV-8A,
assuming I ever finish it. I watched closely and stopped by every day as my
avionics shop was installing it.
It appears to be a high quality unit and the guys at the shop unanimously
agreed that out of all the APs they have installed, the STEC was the best
documented and most thorough in terms of the hardware supplied by the
factory, and instant support when needed.
It works great, and is dog simple to use. It will warn you with a faint
beep and LED indicators when the plane needs either up or down trim, though
the beep can be distracting to passengers if wired so they can hear it,
especially when the bumps build up. For enroute operations it works fine,
and tracks well. I don't see the altitude vary at all in smooth air and in
reasonable turbulence I have only see it vary about 50ft. up or down worst
case. I usually disengage it for all phases of an instrument approach since
it tends to "hunt" a bit from the course line and the smoothness which is
nice for enroute corrections is not "quick" enough to correct when on
approach if there is any turbulence at all, even on the high-sensitivity
setting.
Though the panel space it takes up is minimal (installed in place of a turn
coordinator), it does require a fairly large pitch trim computer box as
well, and a completely independent static system if installed in the rear of
the plane.
All in all I am quite satisfied and still plan on putting one in the RV. It
is light years ahead of the Cessna 300A Nav-o-matic that it replaced.
-Steve Metzger
RV-8A Horizontal Stab.
From: PhilipR920(at)aol.com <PhilipR920(at)aol.com>
Date: Monday, October 25, 1999 3:07 PM
altitude.
>Phil Rogerson
Subject: | Re: O-360 Parts ID |
>Hi,
>Thanks
>-Glenn Gordon
As you surmised, #2 is for CHT, but I believe that the #1 ports are used
for fuel injection & remain plugged if you have a carb. You should find
additional plugged 1/8 NPT ports on the aft, outside, lower corner of each
cylinder. These are normally used as primer ports, with maybe cylinder #3
having a manifold pressure connection instead of primer.
Chris Good, http://www.slinger.net/rv-6a/
West Bend, WI
RV6A-QB N-86CG, O-360 installation
West Bend, WI
In a message dated 10/25/99 6:31:56 PM Pacific Daylight Time,
glenng(at)megsinet.net writes:
<< Since the book Lycoming supplies with the engine isn't all that detailed
it on all four jugs.>>
This is for fuel injection tubing.
plug is a tapped hole (1/8 NPT?) that has nothing in it.>>
This is the thermo-well for the CHT probes.
The hole on the lower part of the cylinder just to the left of the spark plug
hole is for primer or manifold pressure take off.
-GV
Subject: | Re: Diameter rivets.. |
<< i
discovered
I had the
plans
would
are too
hole.... >>
Bert,
I, too noticed "skinny" rivets from time to time. Properly set, skinny
rivets will fill the hole just fine. If the shop heads are forming too
small (or inside the hole), you need to go to a longer rivet.
Kyle Boatright
Gary, and others, where is the best place to get them overhauled??? I can
buy a new one for what they want to overhaul one in Canada. I have a
artifical horizon that needs O/H.
Ken Hoshowski RV6 C-FKEH
Salmon Arm B.C. First flight sept. 8,1993
Date: Monday, October 25, 1999 5:42 PM
Subject: Re: RV-List: Panel Tilt
>> Paul Besing
>> Finish Kit
>Gary A. Sobek
>So. CA, USA
Glen you are correct.
#2 is not NPT just a strait thread.
Also there is another 1/8 NPT on the lower side which also could be used for
primer.
Bryan Files
Ever Fly Maintenace
Palmer, Alaska
-4 tail
----- Original Message -----
Sent: Monday, October 25, 1999 4:34 PM
Subject: RV-List: O-360 Parts ID
> Hi,
> Thanks
> -Glenn Gordon
From: | "Dean Pichon" <pichon.dean(at)adlittle.com> |
Subject: | Aft (Top) Skin on RV-4 |
I'm about to "commit" to riveting the aft top skin on my -4 fuselage. I'm
concerned that I might be riveting this skin too early in the building process.
I've installed the empenage and associated control surfaces, and will soon start
the canopy installation process. My question is the following? Have any
builders found it beneficial to postpone final riveting of this skin until much
later in the building process (e.g., after fitting the canopy, installing gear,
etc.)? Thanks in advance for the help.
**** This message is from Arthur D. Little, Inc. and may contain
confidential business information. It is intended for the addressee
only and may not be copied without our permission. If you are not
the intended recipient please contact the sender as soon as possible.****
for" ;
Tue,
26 Oct 1999 08:13:37.-0400(at)matronics.com
Subject: | Re: RV6 how to drill center tube on sliding frame? |
My friend just did this, he used the strap duplicator from Avery, he said it was
a no-brainer and he hit every hole dead center.
Eric Henson
Tom Barnes on 10/25/99 10:02:50 PM
Subject: RV-List: RV6 how to drill center tube on sliding frame?
Buffalo Grove, IL<<<<<
My major goof...Working on too many planes at once. My 6 has a Dynafocal mount.
JMP
> through.
> thanks
> JMP
Subject: | Re: HVLP painting |
Paul, it sounds like a good deal and a good job,
can you tell us where you bought this gun.
Gil, 80628 almost ready to paint.
Subject: | Re: Enroute Assistance........yeilded quick drain leak. |
My quickdrain was purchased from an engine shop. It is brass. I"ll have to
look at the name on it , if any. It will take me a few days to get that for
you, as I still am enroute.
Ron Vandervort
From: | Keith Warfield <kpwarfield(at)worldnet.att.net> |
Well my RV-6 kit is for sale again. The person that wanted it did not
have the money. I need to sell this ASAP. ALso available is an I-Com 760
comm radio ($800) and Auto Meter engine guages ($225). Also, you may
call me @ 623.561.2527 (H) or 602.789.2779 (Working til EOM).
Lost my job, must sell completed tail and partially completed wing kits.
Need $4,500 in order to pay bills for next couple months. Some tools
included. Have strobes, electric elevator trim, and fuel
senders.Willing to complete wings for $$. Consider trade for 200+hp
turbo shaft engine (I know someone that will buy it from me). Reply to:
Greg,
Last time I did it, I borrowed the fancy tool from the FBO. Next time I
will just use a Ty-Wrap. They are acceptable according to AeroQuip and I
think they will leave a neater appearance when finished. You also don't
have to borrow a tool to install them.
Bruce Green
writes:
>I know
>wire.
>2 but
>titanium
>I'll
>Thanks,
>Greg Young
>Mark
>Twain (1835-1910)
From: | "Randy J. Pflanzer" <rpflanze(at)iquest.net> |
Can you not also pull manifold pressure off one of the top holes? I do not
have fuel injection but I do have a four cylinder primer system. I plumbed
manifold pressure off of one of these top fittings. I hope this is okay.
Anyone know for sure? Thanks.
Randy Pflanzer N417G RV-6
"Painting"
Date: Monday, October 25, 1999 11:16 PM
Subject: Re: RV-List: O-360 Parts ID
plug
>-GV
Subject: | Firewall forward kit |
Hey Scott!
When are you guys going to start taking orders for the firewall forward kit?
Gary
Sounds like a Curtis Valve.
Bryan Files
Palmer, Alaska
-4 tail
Sent: Tuesday, October 26, 1999 4:50 AM
Subject: Re: RV-List: Enroute Assistance........yeilded quick drain leak.
to
for
> Ron Vandervort
I forwarded everything on this data plate problem to my friend, Earl
Lawrence of the EAA. He is a A&P but more over, he is the liaison person
that can straighten out problems between builders and restorers and the FAA.
As you can tell, it is a gray area, even when Earl goes to the top.
Note the requirement for A PLATE.
Cy Galley - Chair, Emergency Aircraft Repair, Oshkosh
Volunteer from Chapter 75 for 28 continuous years
Date: Tuesday, October 26, 1999 8:36 AM
Subject: RE: RV-List: Log entries?
>Cy:
>FAA HQ, (not the field folks) can not come to a definite answer on this
>subject. Basically NTSB, and all the accident investigation type want the
>data plates left alone, and all the hard core inspectors want the data
plate
>changed. EAA and at least one FAA HQ manager has suggested that an X be
>stamped on the data plate at the end of the part number when ever any part
>with a data plate is used on an experimental aircraft. If the part is then
>inspected for conformity then a "c" would be stamped after the x and a log
>book entry would be made.
>This all is really just an academic exercise though because no one is
>actually going to take action against someone for not changing a data plate
>or for changing a data plate. Eventually EAA and FAA will work this one
out
>but until then I would not get very excited about this issue it is just not
>on the FAA's radar screen. That is not to say a local FAA inspector may
not
>have a hard line opinion on this, but FAA HQ does not consider it of such
>importance that they need to take any action to develop policy on this, at
>this time.
>One thing that builders of experimental amateur-built and experimental
>kit-built aircraft must do though is have a data plate on the engine and
the
>airframe as per FAR 45.11. So if you take off the engine data plate you
>must put one of your own on the engine as required per FAR 45.11 and 45.13.
>For an amateur-built engine the data plate would have the builders name, a
>model designation, serial number, and a power rating.
>Earl
>> From: Cy Galley [SMTP:cgalley(at)accessus.net]
>> Sent: Monday, October 25, 1999 4:35 PM
>> To: Earl Lawrence
>> Subject: Fw: RV-List: Log entries?
>> What is your opinion on the data plate?
>> Cy Galley - Editor, B-C Contact!
>> (Click here to visit our Club site at
>> http://www.bellanca-championclub.com)
>> From: MRobert569(at)aol.com <MRobert569(at)aol.com>
>> Date: Monday, October 25, 1999 3:35 PM
>> Subject: Re: RV-List: Log entries?
>> >Cy,
>> no
>> no
>> removed.
>> >Mike Robertson
>> >RV-8A QB
>> >"Das Fed"
>> "Cy
>> Galley" writes:
>> >> You do NOT have to remove the data plate.
>> >> Date: Sunday, October 24, 1999 3:24 AM
>> >> >Denton,
>> they
>> >> have been overhauled and then what the mods are that you have
>> installed.
>> >> Also it is highly advisable that you state that the prop and engine
are
>> to
>> >> be used in experimental aircraft only unless and new overhaul is
>> conducted.
>> >> Your local FAA Rep should by that off. The only other thing you have
>> to
>> do
>> >> is remove the data plate from the engine. Keep it with the logbook
for
>> >> future overhauls.
>> >> >Mike Robertson
Time,
>> >> Denton Harjehausen writes:
>> overhauled
>> >> engine
>> reconditioned
>> by
Ts
>> >> crossed and
>> >> >> Have a great Day!
>> >> >> Denny Harjehausen
>> >> >> Lebanon, OR
>> >> >> RV-6
Subject: | Re: Aft (Top) Skin on RV-4 |
Good Morning Dean,
In my opinion, I would wait until the very end to rivet the turtle deck
on. While I don't think it is an absolute necessity, it will provide easy
access for later work such as running any wires or antenna cables aft, is
your battery going to be mounted in the rear baggage compartment, working on
the canopy attach point at the rear bulkhead is easier. Have you installed
the baggage compartment sheet metal yet? Have you performed the initial
rigging of the elevator linkage? installed the pitot static vents? Run the
rudder cables? All of these things can be done after the deck has been
installed but are easier with it off.
I have not found any disadvantage in leaving the riveting of the turtle
deck until the end.
Tom Brown RV4 Fiberglass
RV4Brown(at)aol.com
Last night I updated my "Tips, Tricks and Ideas" section to include RV List
member Dick Martin's RV8 and RV List Member Dennis Persyk's RV-6. There are
3 or 4 pics for each along with some descriptions. I've guoted Dick on some
performance figures for his -8 and they are pretty impressive. There is
also an interesting Rudder Gust Lock Idea and a small pictorial and a couple
of pictures of Lyle Heffel's -8 that I took at a local flyin in late
September.
Hidden in there somewhere is a picture of the RV Webring gurus, (Don Mack)
Ercoupe. Hope you like.
http://www.mindspring.com/rv6_log
Subject: | Re: Web Site Update |
>From: "Nellis, Mike" <mike.nellis(at)mcd.com>
>Subject: RV-List: Web Site Update
>Date: Tue, 26 Oct 1999 09:34:48 -0500
>are
>some
>couple
>September.
>Mike
Mike,
I couldn't get the URL to work. Please check it, I wanna see those RV8
numbers!
Brian Denk
RV8 N94BD
wings on, tail on, money gone.
Randy,
It is OK to pull MP off the top holes.
Bryan Files
Palmer, Alaska
-4 tail
Sent: Tuesday, October 26, 1999 5:49 AM
not
plumbed
> "Painting"
> From: Vanremog(at)aol.com <Vanremog(at)aol.com>
detailed
> plug
> >-GV
From: | John Chalker <john.chalker(at)infoseek.com> |
too bat the URL returns a 404 error :o(
> From: Nellis, Mike [SMTP:mike.nellis(at)mcd.com]
> Sent: Tuesday, October 26, 1999 7:35 AM
> List
> are
> some
> couple
> September.
> Mike
Subject: | Web Site Correction |
Oops, I made a mistake on the website URL. Sorry,
http://www.mindspring.com/~mnellis1/rv6_log/
Mike Nellis
In a message dated 10/25/99 10:01:51 PM Central Daylight Time, rv8er(at)home.com
writes:
<< I bought a Sharpe Cobalt >>
Paul, could you share with us the specs on the compressor you used with the
Sharpe gun and is it a gravity feed gun?
From: | jrh(at)mustang.us.dell.com (Randy Howard) |
Subject: | Re: Van's Construction Manuals |
> Builder's Bookstore has been authorized by Van's to distribute Construction
> Manuals for RV-4, RV-6/6A, and RV-8/8A aircraft. These are the actual manuals
> that you will otherwise need to buy when you start your project.
I am wondering if you will be doing any proofreading on these before
reselling them? :-)
I have the RV-8 doc. from Van's, and it is clear they do not use a
spell checker or grammar checker to produce these.
Apart from that, they look good.
Randy Howard (jrh(at)mustang.us.dell.com)
Dean,
Do you have wiring and static lines in yet???
Stew RVer 273sb
From: | "John B. Abell" <jbabell(at)mediaone.net> |
For a 3/32" rivet, drill with a #41 bit, then deburr and dimple. The dimpling
will enlarge the hole slightly, making a perfect fit for the rivet.
Best wishes,
Jack Abell
"Bert F. Murillo" wrote:
> 10/25/99
> Bert Murillo
> discovered
> I had the
> plans
> would
> are too
> hole....
> Thanks
> Bert
Doesn't look like much chance of getting an A&P to sign off on the engine or
prop. Does it have the new oil pump and housing? New exh valves? And
guides? Is the crankshaft airworthy? An IA (at annual or sign off time) is
supposed to verify "even to the point of disassembly" that all the required
things are done to certify an engine. Same goes with the prop. You can
still use it, but it won't be certified.
Jim (A&P-IA)
In my experience, I believe it would be easier to sand off all the paint or
use some stripper (nasty job). Then, be sure you thin the paint enough to
flow out good.
Jim RV6A flying
I continue to use the Gyro House in Auburn, CA. They overhaul
instruments of all types and they have a good selection of used,
overhauled, yellow-tagged instruments in stock. They will custom mark
any instrument they sell. They do not sell any "low-cost" instruments
that are not repairable. They also repair/overhaul autopilot components.
I have been generally pleased with their service and those times things
have not been to my liking, they made them right, no questions asked. In
fact, even when I discovered a problem with an instrument that was well
past their 90 day warrantee (it took me a lot longer to build the panel
in my RV-4 than I had anticipated), they took my word for it that the
instrument hadn't been used and they repaired it free of charge.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
Subject: | Re: wood stiffeners in the RV-6A main gear legs |
Yep, I am flying an RV6A without the wooden stiffners. Works fine.
Sometimes, if I land a little fast, the "chirp " might turn into 3 or 4
chirps. Otherwise, no problems.
Jim RV6A flying
Cy,
I stand corrected. FAR 45.11 does indeed state that the engine and prop must be
identified with a fireproof plate. And like the gentlemen says, neither I nor
anybody else that I know of is going to get wrapped around the axle about this.
All I am stating is that "technically" the data plate no longer is valid
and, god forbid, if something should happen then you are leaving yourself out
to dry. This is especially true if while the altered engine is on an aircraft,
you sell it, and something goes wrong. Now you are really in the s--t can
because with our legal system you are going to get nailed because you did not
follow the regulations exactly. I do not want to see that happen to anyone.
Mike Robertson
RV-8A QB
"Das Fed"
Cy,
I can not resist one last pot shot here. Sorry, but you know how us "Feds" get.
FAR 45.11 only applies to aircraft covered by Part 21.182 and to manufactures
of products. Experimental aircraft are not covered by 21.182 as stated in
paragraph (b) of that part. And even though we may alter the engine we are not
the manufacturer so that also does not apply. Therefore 45.11 does not apply.
Mike Robertson
RV-8A QB
"Das Fed"
In a message dated Tue, 26 Oct 1999 11:17:33 AM Eastern Daylight Time, "Cy Galley"
writes:
> From: Earl Lawrence <elawrence(at)eaa.org>
> To: 'Cy Galley'
> >Cy:
> plate
> out
> not
> >this time.
> the
> >Earl
> >> To: Earl Lawrence
> >> To: rv-list(at)matronics.com
> >> >Cy,
> >> no
> >> no
> >> removed.
> >> >Mike Robertson
> >> >RV-8A QB
> >> >"Das Fed"
> >> "Cy
> >> Galley" writes:
> >> >> >Denton,
> >> they
> >> installed.
> are
> >> to
> >> conducted.
> >> to
> >> do
> for
> >> >> future overhauls.
> >> >> >Mike Robertson
> Time,
> >> overhauled
> >> >> engine
> >> reconditioned
> >> by
> Ts
> >> >> crossed and
> >> >> >> Have a great Day!
> >> >> >> Denny Harjehausen
> >> >> >> Lebanon, OR
> >> >> >> RV-6
Paul-
What paint are you using with it?
Ray
You're right. Primer lines on top, CHT on bottom of cylinders. Also, top
ones can be used for manifold psi.
Jim RV6A flying
From: | "Ian Belmore" <ian(at)ibelmore.demon.co.uk> |
Russell
Do you need to specify which way the tilt is ??
Ian Belmore
RV6
G-RVIB
Doing Seats & Rudder Pedals
Sent: 25 October 1999 23:05
gyro?
> > Paul Besing
> Paul,
and according to RC Allen,
either you can measure it,
still new and unopened, so
degree tilted model. That
> Russell Duffy
> Navarre, FL
> Russell
> Ian Belmore
> RV6
> G-RVIB
Ian, I think they would assume it to be a forward tilt, but I wouldn't take that
chance. I told
them it was.
Russell Duffy
Navarre, FL
RV-8, sn-587, N174KT (goofy baggage door)
> Mike Thompson
> Austin, TX
> Wings
This is a silly question I suppose, but how do you go
about reserving a number like you have?
FYI...I just purchased my attitude indicator, and purchased the tilt
option...it was $20 more.....not a bad price for the insurance..
Paul Besing
Finish Kit
Subject: | Quick Build Primer |
Hello listers
I am at the point of painting my RV6QB interior. I would like to know if I
should seal the factory self etching primer or can I paint over it. I
thought I might use RustOleum until I read the post on Sherwin Williams
Sunfire paint. Are there any other paints that QB builders have had good
luck with?
Cash Copeland
Oakland, Ca.
RV6QB 60075, Canopy done ready to paint interior
Subject: | Re: N Number Reservation |
>how do you go about reserving a number like you have?
Randy,
Check out the Landings site: http://www.landings.com/
Then go to Databases, look for N numbers and reserved N numbers. Make up a
list of about 5 numbers that you would like to reserve. See if they are in
use.
Come up with a good list of 5 unused N numbers and send a request to the
FAA. The following is a copy of my original request for a reserved number.
The reservation is good for one year and costs $10/year to maintain the
reservation. Let me know if you need anything else.
"Federal Aviation Administration
Mike Monroney Aeronautical Center
P.O. Box 25504
Oklahoma City, OK 73125
Re: Reservation of N Number
Dear Sir/Madam,
I would like to request that one of the following N numbers be reserved in
my name. I am in the process of building an airplane, an RV-6. The numbers
are listed in the order of preference:
N2GB
N4GB
N3GB
N5GB
N24BD
I have enclosed a check in the amount of $10 to cover this reservation for
this year."
Another option that a friend of mine has done is actually register the
aircraft with the FAA prior to completion. He or someone else could possibly
tell you how to go that route.
Gary Baker
RV-6 (Working on wings)
N4GB (Reserved)
Medina, OH
Subject: | Re: Quick Build Primer |
> I should seal the factory self etching primer or can I paint over it. I
> luck with?
I scuffed the SW primer with scotch brite (red), then primed and
painted with Rustoleum. I did this because I didn't know how to use a
spray gun, and didn't want to learn in the cockpit area. IMO that was
a bad idea. It worked OK, but I think I'd recommend painting the
interior with a good quality paint, using an HVLP gun (DeVilbiss
makes a good HVLP unit, Finish Line, for $170.).
The Rustoleum is OK, but it chips a whole lot easier than my good
quality paint (Imron) exterior.
Tim Lewis
timrv6a(at)iname.com
N47TD RV-6A, painting
Springfield VA
http://home.earthlink.net/~timrv6a
http://home.earthlink.net/~timrv6a/jpi.html - No JPI stuff in my airplane
In a message dated 10/25/99 10:27:45 PM Eastern Daylight Time,
skytop(at)megsinet.net writes:
top
the
> bar.
???? I had no trouble on a small step stool drilling it in place. Tape the
center bar to highlight the area where the plexiglass touches and drill
straight through. Use a dupe strap for the aluminum strip afterwards, using
the center bar as a guide. You may want to drill it front to back using the
latch hole as the place from which the plexi can expand and contract. The
plexi probably doesn't touch the bar all the way back until you drill and
cleko anyway.
Good luck
Brian Eckstein
6A finishing
Have any of you heard anything about an experimental plane crash at Corpus
Christi Texas that killed two people a couple of days ago,or what type of
airplane?
Jim Callender
Hitchcock, Tex.
RV-6 Fuselage
Subject: | oil cooler hookup |
Hi,
RE: RV-6 O360-A1A, LEFT FIREWALL MOUNT, POSITECH
I am starting to figure out which oil line routing from the engine to
the oil cooler will work out best.
Questions....
1. Am I correct that the 45 degree bend type is the only AN fitting
that will work in the "Oil to Cooler" port on the engine? And that the
straight type AN fitting is the only one that will work in the "Oil from
Cooler"?
2. Am I better off with a short run and a long run to and from the
cooler, or am I better off with 2 medium length runs. Does it matter?
3. It seems that many different combos of hoses and fitting will work
in this situation. What have other builders using this configuration
used?
Thank you,
Glenn Gordon
Subject: | OT: homebuilt Piper Comanche? |
Here is a question, a little of topic. Found two Piper airplanes register
as "amateur built." Is this just a bookkeeping error on the part of the FAA?
Or any they really homebuilts to be maintained that way???
N-Number 7659P
Amateur-Built? Yes
Aircraft Make Piper
Aircraft Model PA-24-180
Serial Number 24-2872
Year Manufactured 1961
Aircraft Type Land
Engine Type
Engine Make Lycoming
Engine Model O&VO-360 SER
Horsepower 180
Airworthiness Class Standard
Approved Operations
Seats 4
Type of Ownership Individual
Owner Name Langebro Hakan C
Street 101 W Olympic Pl Apt 310
City Seattle, WA 98119-4714
FAA Region Northwest-Mountain
Country US
Registration Date 22-Apr-1998
Last Activity Date 22-Apr-1998
P.S. they were both 180 model 24
(Click here to visit our Club site at http://www.bellanca-championclub.com)
Subject: | List of...(cat's out of the bag) |
OK, I guess I will start letting out a bit more...keep in mind this is
unofficial, so I'm not really saying anything. If anyone asks, we'll just
say you have ESP. :-)
There are three things that are supposed to be ready on November 15, in
order from least to most significant:
1. Van's New Accessories Catalog - Not much to say here, except that it
will have some new products and updated prices (some increased, some
decreased). Available for Acrobat download or non-Acrobat on-line browsing.
On-line shopping/ordering allows you to place orders 24/7. The catalog, of
course, will also be available in print.
2. Van's New Web Site - A revived version of what's currently available, in
a new site design. New information on the RV-8A, RV-9, 8/8A QuickBuilds,
builders groups, insurance/financing, flight training, cost to complete an
RV, kit options, shipping information, etc. Plus most everything that is
currently available on-line. And the RV of the Week will continue, but will
be updated every week, at the same time--to the second (no more "RV of the
Season"). On-line ordering will be available for accessory items and parts.
3. SourceRV - This is produced by an independent company in cooperation
with Van's Aircraft. This is the main part of what I was referring to in my
messages. I don't know the best way to describe it other than say it is the
ultimate Internet-based resource for RV enthusiasts, builders, and pilots...
It will be a central place for information of all kinds. Plans revisions,
RVator archives, photographs, builder's tips, gotchas, workarounds, fixes,
additional help, Van's tech support archives, service bulletins, safety
discussions, maintenance articles, cg calculator...the list goes on.
Being independent from Van's, yet associated, is really the best of both
worlds. The content will really be what YOU want, and will not be dictated
(nor will it have to be approved) by Van's. It will also allow more timely
distribution, because it is put up direct. However, the cooperation with
Van's means that the site still will contain "Van's Official" information
along with independently developed and user contributed material.
I'm involved in this project, and I can tell you that it has been a while
in the making. In the end, factoring planning, design, development, and
dynamic maintenance, I will have put thousands of hours into the project.
Because SourceRV is not financially supported by Van's, there will have to
be a small subscription fee (about two bucks a month). I'm confident that
you will find this to be a value for what's available.
If this site were officially announced, I'd tell you that more information
is available at:
http://www.infoav.com/rv/
but I'd better not tell you that... ;-)
Hope this answer some questions,
~Jeremy (I didn't tell you) Benedict
jwb(at)europa.com
>Kevin... I agree but how does one know what Van's has planned. Maybe a few
>subtle hints from Jeremy would go a long way toward keeping us from
>re-inventing the wheel.
>What about it Jeremy......not to let any cats out of the bag but it is about
>time we knew what to expect from Van's. I have been waiting to get the new
>catalog for 6 months so I could fill my panel (amonst other things). Nothing
>yet. I really hate to spend my money somewhere else because I really would
>like to support Van's if I can. However, time is getting short.
>Gary Palinkas
>Parma, Ohio
>RV6 QB
><<<issue. I'll wait and see what the Van's website update looks like,
>then decide whether there is a need for any additional info. I
>certainly don't want to duplicate anything that Vans does.
>Kevin
>>Good idea, but in a way, you're sort of replicating in part a major effort
>>that's expected to be available Nov 15 on the web.>>>>
From: | "Scott A. Jordan" <SAJ_SLJ(at)compuserve.com> |
Message text written by Cash Copeland
>I would like to know if I should seal the factory self etching primer or
Sunfire paint.<
Sunfire is a acrylic Urethane that I believe requires a compatible primer
and sealer first. I'll pass this on to my next door neighbor / SW rep and
get the definative answer to you this weekend. I've been using Sw Vynly
Etch (similar to the wash primer) and he told me I would need to prime /
seal before using the sunfire. I am not priming parts that will eventually
get painted.
Scott A. Jordan
80331
seat backs
Sunfire does not require a sealer...maybe compatible, but not a sealer...I
used Sherwin Williams 988 with no sealer, and the Sunfire went on
perfectly..it also paints well over the QB primer...I even painted over my
baffles, which were originally done with BBQ grill paint (bad idea) and it
even stuck to that...the stuff is about idiot and bullet proof....for the
exterior, I will first use acid etch, then a product called Corrosion Seal,
and then a sealer, then the sunfire...just to make sure that moisture does
not get in there...
Paul Besing
Finish Kit
>and sealer first.
Subject: | R.A.C.E race at Mesquite Nv |
Hey Racers
R.A.C.E. is having a race this weekend at Mesquite. Lots of fun,
two laps around for a total of 102 nm. Come on out and challange
those plastic airplanes. Might even beat a few of them. Should
be a good RV showing with 5 or 6 (or more) participating.
Contact me off-list for info.
Tom
RV3
> It's Bob's standard answer when the subject comes up. From an idealistic
>point of view it makes sense, if a piece of hardware needs the protection
>of an avionics master its a defective design and you shouldnt buy it. In my
>opinion that viewpoint doesnt jive with reality.
No, I'm saying that every manufacturer of avionics I've worked
with for the past two decades subscribe to the tenants of good
design signs up to testing their products against DO-160 . . .
check the installation manual. If they're TSO'd, then DO-160 is
an automatic part of the qualification to get TSO. If they're not
TSO'd then somewhere in their book they'll call out qualification
to DO-160.
The gripe cited (processor resets during browout) earlier in the
conversation is a functional design defect, not a shortcoming that
puts the product at risk of damage. These things are often tolerated
of Learjet that pilots have to pull and reset with some frequency.
Seems the VLF Omega nav system needs a cold-boot reset from time to
time. Let's be sure we're talking about performance quirks versus
damage to the product from stimuli that is present in every airplane
and considered NORMAL.
> If I understand Bob's position correctly I should refuse to purchase any
>device which suffers an occasional glitch at engine start until the
>manufacturer corrects whatever deficiency causes this to happen. Should
>this be the sole basis for making a decision to purchase a device that
>otherwise does exactly what I want it to do? Particularly when I can
>overcome this minor deficiency by installing and using an avionics master
>switch in my panel to overcome this single intermittant discrepancy?
Not at all. I'm talking about being a good consumer and applying
pressure to the industry to shape up. Ask every supplier of goodies
if they REQUIRE or even suggest pilot intervention (turn off or have
avionics master) to prevent damage to their product. If they say
"yes", then politely tell them you'll look for a more appropriate
product elsewhere. Now, if you REALLY want their gizmo and you're
willing to subject yourself to their ADMITTED shortcomings, call
back in a week and order the thing. They won't remember your
earlier call but they might have told the engineering manager that
"we just lost another sale because we can't measure up."
Nothing draconian nor restrictive of your fondest dreams . . . but
I object to aviation's mindset that everything is fragile, expensive
and needs government intervention to keep from hurting us. Further
everything has to be installed by people with magic diplomas saying
they're qualified to protect us from ourselves and from things too
technical for us simple folk to understand. Airplanes, like other
expensive hobbies tend to stay that way until we stop bending over
to take it in the shorts. You guys are building the finest airplanes
ever flown. You've taken on a task that only one person in 200,000
will ever accomplish. If your RV had a quirky stall characteristic,
you'd be all over Van about it. If your engine craps a jug every
100 hrs for no good reason, you be camping on your supplier's
doorstep. Why are you so willing to give the electro-wienies a
bye on rudimentary electronics design defaults?
> Bob is correct in that his is not a singular point of view. Nor is GV's.
>Bob has a lot of good ideas when it comes to electrical system design. I
>intend to use a number of them. But he doesnt have the market cornered.
> Bob, I'm quite impressed that in all of your years in this field you've
>NEVER designed a piece of hardware requiring pilot intervention (read
>avionics master). Nor have any of your collegues? If so then who invented
>the avionics master and for what purpose? SOMEBODY designed those boxes
>that fizzled on engine start. :-)
We (Cessna) did . . . and the problems were showing up in OUR
own radios (Cessna owned ARC) when the first transistors were
designed in . . . .
. . . . 35 years ago. When transistors were germanium, 30 volt devices
that would head south if you yelled at them; 10 years before
DO-160; 10 years before 100+ volt silicon devices; and 15 years before
the industry really began to understand how to do it right in the
lab and be competitive in a real world with easily survivable
hazards.
Actually, it was probably low voltage (brownout) that was killing
radios back then but now it matters not. Avionics master switches are
dinosaurs. . . . common guys, are we going to wear our 1960's
security blankies into the 21st century? Electrically induced
failures in avionics nowadays are caused by runaway alternators.
Systems with a battery flogged far beyond its practical service
life. Systems with no or slow over voltage protection . . .
yes, there are hazards out there that will cook radios . . .
NONE of which are mitigated by an avionics master switch.
(o o)
===========o00o=(_)=o00o========
< Independence Kansas: the >
< Jurassic Park of aviation. >
< Your source for brand new >
< 40 year old airplanes. >
http://www.aeroelectric.com
Subject: | Out of Baffle Material |
Does anyone have any leftover baffle material? I need about a 12" X 3 12"
piece....I promise I'll buy you a beer at Oshkosh next year!
Paul Besing
http://members.home.net/rv8er
Finish Kit
From: | "Mark D. Dickens" <mddickens(at)mindspring.com> |
Subject: | RV-8 Empennage Options |
OK, I've finally riveted the HS together and am cleaning up the job
while I plan the VS. Thinking ahead to lighting and antenna
installations has me wondering what options I have and what cool things
have been done to simplify or improve the kit. I'd like to get ideas
from the crowd on:
1. Has anyone mounted a strobe or beacon on top of the VS? This would
require a custom fiberglass fairing at least...the fairing I have has a
place for a light on the bottom...I like the look of the bottom
location, but wonder about visibility down there
2. I really like the idea of mounting the GPS antenna under the VS top
fairing although the feedline length is an issue. Has anyone done this
and have results they'd like to post?
3. I am considering Warren Gretz's kit for relocating the electric
elevator trim...any experience with this?
Any other options I should consider?
Thanks!
Mark Dickens
Germantown, TN
RV-8 Emp, HS more or less finished, eyeing the VS
Amen! - neither does 43
-----Original Message-----
Date: Tuesday, October 26, 1999 12:32 PM
Subject: Re: Fw: RV-List: Log entries?
>Cy,
get. FAR 45.11 only applies to aircraft covered by Part 21.182 and to
manufactures of products. Experimental aircraft are not covered by 21.182
as stated in paragraph (b) of that part. And even though we may alter the
engine we are not the manufacturer so that also does not apply. Therefore
>Mike Robertson
>RV-8A QB
>"Das Fed"
Galley" writes:
FAA.
>> To: 'Cy Galley'
>> >Cy:
the
>> plate
part
then
log
plate
>> out
not
>> not
such
at
>> >this time.
>> the
45.13.
a
>> >Earl
>> >> To: Earl Lawrence
>> >> >Cy,
and
>> >> no
is
>> >> no
configuration.
plate
be
>> >> removed.
>> >> >Mike Robertson
>> >> >RV-8A QB
>> >> >"Das Fed"
Time,
>> >> "Cy
>> >> Galley" writes:
>> >> >> >Denton,
>> >> they
>> >> installed.
>> are
>> >> to
>> >> conducted.
have
>> >> to
>> >> do
>> for
>> >> >> future overhauls.
>> >> >> >Mike Robertson
>> Time,
>> >> overhauled
>> >> >> engine
>> >> reconditioned
>> >> by
the
>> Ts
>> >> >> crossed and
>> >> >> >> Have a great Day!
>> >> >> >> Denny Harjehausen
>> >> >> >> Lebanon, OR
>> >> >> >> RV-6
Not so. Look up certification:airworthiness certificates. A experimental
airworthiness registered aircraft has a yearly CONDITION inspection to it,
the engine, prop etc IAW the scope and detail of appendix of part 43. ( even
though part 43 does not apply, it is the guide required- gotta love the
feds). The manufacturer or a A&P may perform this inspection, IA not
required. I would gladly give you the references but my FAR's are at work.
A&P,IA,FAA safety counselor, Chief Inspector.
Date: Monday, October 25, 1999 8:01 PM
Lycoming
>Palmer, Alaska
>-4 tail
>To:
>> Cy,
is
>removed.
>> Mike Robertson
>> RV-8A QB
>> "Das Fed"
"Cy
>Galley" writes:
>> > >Denton,
they
installed.
>> > Also it is highly advisable that you state that the prop and engine are
>to
>conducted.
to
>do
>> > is remove the data plate from the engine. Keep it with the logbook for
>> > future overhauls.
>> > >Mike Robertson
>overhauled
>> > engine
>reconditioned by
>> > crossed and
>> > >> Have a great Day!
>> > >> Denny Harjehausen
>> > >> Lebanon, OR
>> > >> RV-6
Subject: | Re: Michigan Fly-In |
Thanks to any who considered coming up or down to Cadillac last weekend. The
weather did not allow any planes in, but we did have around 30 or so of our
chapter members, and some builders in from Howell and the Sault Canada area.
We had good stories and great Chili. Here's to better weekends of weather in
the future
D Bell
8QB
PPG Concept is a good paint that covers well and is easy to shoot.
Bryan Files
Palmer, Alaska
-4 tail
Sent: Tuesday, October 26, 1999 1:57 PM
Subject: RV-List: Quick Build Primer
> Hello listers
I
> luck with?
> Cash Copeland
> Oakland, Ca.
Subject: | Re: RV-8 Empennage Options |
Mark:
Check with Warren, but it appears that his alternative trim mounting kit
won't work very well for the RV8. I considered it but decided against it and
fitted the trim motor per the plans. Since the plans are a little vague (at
least to my befuddled mind) I found some of the photos on folks web sites
helpful. I believe Moe's site at http://tabshred.com/moe/ has a photo of the
trim installation.
Phil Smith
Fairfax, CA 80691
Subject: | Pop Rivet Question |
I'm having some concerns with my common sense conflicting with my plans for
my RV-3, and was wondering if some of you other experienced RV dash-number
builders may be able to give me some advice/feedback.
My ailerons skins on my -3 are .020 instead of the .016 depicted in the
plans. Where the overlapping single joint meets on the bottom of the
aileron there is a total thickness of .080 (.020 top skin, .020 bottom skin,
and .040 for spar = .080). Both my 1973 plans, and my post-1984 preview
plans depict 1/8" pop rivets, 1973 set= MD-424-BS (now equivalent to ?????),
and post 1984 set= CS4-4. Both rivet references appear to be to 1/8"
countersunk, with a grip of .188-.250 (for the CS4-4's anyway). I tested
some .188-.250 total grip self plugging pop rivets that were in the aileron
previously. Some seemed to grip/clamp tight, while some seemed to allow
some movement in the test pieces.
Any recommendations besides just trying a 1/8" -2 countersunk rivet (hard to
find that are self plugging)? Only ones that seem readily available are the
MSP-42 that are 120 degrees vs. the 100 degrees and are not self plugging.
I'm willing to try anything that is 100 degrees countersunk with the right
grip (.063-.125 I guess), and self plugging. . . .any suggestions that I am
ignorant to are very much appreciated.
Rob Reece
RV-3 SN45
Socorro, NM
505-835-3644
> airplane?
> Jim Callender
> Hitchcock, Tex.
> RV-6 Fuselage
Hello Yall
We were at the Reklaw fly-in this weekend and talked to a man and women
whom we met last year at the same fly-in. In the conversation the
gentleman talked about a new plane he recently acquired, a Spezio. While
watching the news last night my heart sank when the newscaster announced
that the plane was a Spezio. They then aired the pictures of the couple
from Reklaw.
Talking to him it was obvious he had a great amount of experience and
appeared to be cautious pilot. He was a flight instructor and
volunteered to help me transition to the more complicated and faster RV.
I barely knew him, but feel a great loss.
There is an news paper clip on the net.
http://www.caller.com/1999/october/26/today/local_ne/20.html
George Meketa
Cessna 140\RV8-QB wings
As promised, the corners of the baffle material pictures are up at:
http://members.home.net/rv8er/enginep.htm
Paul Besing
Finish Kit
Subject: | Re: MAP port (wasO-360 Parts ID) |
I am installing a RMI uMonitor. The instructions warn that, despite
software integration of the MAP readings, if the takeoff is too close
to the inlet valve, the fluctuating pressure will cause variations in
the readings. Without having seen the layout of the induction path
in the head, I'm surmising that the lower ports will have less violent
perturbations than the upper. This may not affect your MAP
sensor/display but I am probably going to need a restrictor fitting
even in the lower port.
Peter Bennett
RV6 Sydney
> not have fuel injection but I do have a four cylinder primer system. I
> plumbed manifold pressure off of one of these top fittings. I hope this
> is okay. Anyone know for sure? Thanks.
> "Painting"
> >detailed
> plug
> >-GV
> Browsing: http://www.matronics.com/archives List Support
> Contributions: http://www.matronics.com/contribution Other Email
Is this information good for the O-320 too?
Steve Soule
Huntington, Vermont
ports are used
should find
corner of each
maybe cylinder #3
Subject: | Re: List of...(cat's out of the bag) |
Jeremy,
That all sounds great! Has there been any thought to putting the RVator on
the web site as well in a PDF format. I would think it would save Van's the
time & cost of printing & postage. I for one would welcome it. If it is
added to the SourceRV site that would be great as well.
Thanks for the improvements.
Mark Steffensen
8A Firewall Forward
Sent: Tuesday, October 26, 1999 8:02 PM
Subject: RV-List: List of...(cat's out of the bag)
Subject: | UH-OH EVERYONE PLEASE READ THIS! |
Well fellow listers it's almost Halloween and you know what that means.
November is just one weekend away and our annual RV-List fund raiser is
about to kick off! This year all of these pitiful pleas for participation
will be going to three additional lists as well. The Rocket, Zenith, and
Kolb Lists will also be exposed to my shameless appeals on Matt's behalf.
For those of you who have never been through this before, what I do is try
to get you to VOLUNTARILY contribute a donation to Matt to help keep all
these homebuilt aircraft computer lists financed and in state-of-the-art
working order. I have been so impressed that Matt has never REQUIRED us to
pay any user fees that I have volunteered to be the list "Tax Man". I will
be posting from three to four e-mails a week with pleas in various forms
(mostly humorous, all intended to be) to try to make you want to
contribute. Either by shamming you into it, peer pressure, or anything else
that I think will work. Feel free to send me any skeletons of other list
members that I can use to accomplish these goals ;-) ).
The point is, these lists take a lot of Matt's time and money to run for
our convenience. Everyone who subscribes to them gets some form of benefit
from them. This benefit has to have a monetary value to you and YOU get to
decide what that is. (At least a magazine subscription price I hope!)
From the response I got privately last year everyone really enjoyed last
years fund raiser and made it a point to read the posts. My subjects will
always be in capital letters and from me so you will know before you open
it what it's going to be about. I would like to encourage anyone who wishes
to give testimony on how the list helps them to feel free to do so, but
please let's not start until next week. November is Turkey month here in
the USA so just kind of look at me as your List Turkey and make that
donation early to get it over with! I will post one of last years favorites
later today so you can kind of get a feel for what is going to be coming.
I hope you all enjoy it and are as generous this year as you were last
year. Al Mojzisik IRS agent............Internet
Revenue Service
PS.....Matt do you have anything you can tell us about how last years
donations were spent and plans for the future ????
You can make on-line secure credit card donations at:
http://www.matronics.com/contribution.html
Or if you wish, you can send your opinions and a generous check too:
PO Box 347
Livermore, CA 94550
Yes
Sent: Wednesday, October 27, 1999 3:45 AM
Subject: RE: RV-List: O-360 Parts ID
> Steve Soule
> Huntington, Vermont
> ports are used
You
> should find
lower
> corner of each
> maybe cylinder #3
Does anyone know of a Lyc. 0360 A1A run out for sale ?
Please replay
RV-6 N7470U Flying (BWG) KY.
On Wed, 27 Oct 1999, Hal Kempthorne wrote:
> Let's hope that panel tilt not being built in was, in fact, the cause of
> your troubles!
Whether or not panel tilt has been programmed in should have absolutely
no effect on gyro life. I would be looking elsewhere for the problem.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
10/26/99
John:
Thank for the good suggestion; would be for the future though, since
now
the holes are already dimpled....
Godd luck too
Bert
Subject: | -6 Canted instrument panel |
Hi all,
Thanks for the kind words, Gary. I had unsubscribed while I was on vacation and
didn't see this thread until I was bumming around the archives a couple of days
ago.
I've been working on a Glassair style panel for my -6. I've got the prototype
installed in my fuse and have some pictures up on a friends web page (thanks Paul).
You can check them out at:
http://www.planes-wings-things.com/rv-6_panel.htm
The page is still needs some work but the pictures are there.
I haven't had time to investigate bringing this to market yet (gotta work on getting
mine flying first :-), but I would appreciate any feedback from any potential
customers. It has room for 8 - 3 1/8" primary instruments, a full stack
of radios, and engine instruments. The layout shown is for a simple VFR airplane
(what mine will be), but I think there is room for everything needed for a
light IFR panel. It is 1-1/4" lower than a stock panel.
I think the real advantage to this panel over a Glassair panel from Stoddard-Hamilton
is that it will install in a very similar manor as the stock RV panel with
no major hacking of the forward structure. You can see by the pictures that
the stock forward skin is retained as well as all the stock substructure.
I did modify the F-6107 panel supports, but in the end I don't think it was necessary.
A little local trimming around the instruments is all that's required.
I'll put more info on the web page about some of the other features and some other
specific stuff when I get the time.
Price would "probably" be around $300-$325. I'll know more when I price out the
materials and refine the manufacturing processes. I still need to do the documentation
as well. So it could be awhile before I could get them out. At least
I've got the molds done.
Let me know what you all think.
Laird Owens
owens(at)aerovironment.com
RV-6 starting to wire stuff
Subject: | Re: 10% for Matronics & a challenge |
In a message dated 10/27/99 9:34:22 AM Pacific Daylight Time,
winterland(at)rkymtnhi.com writes:
> From now through the end of November 10% from any purchase from Builder's
> Bookstore can be set aside as a donation to Matronics (the folks who
provide
> this mailing list) to help keep the RV list operating throughout next year.
This is an excellent idea. We at AAMR/Aircore thank Matt for all he as done
to make these lists work.
We will do the same as Builder Book Store. Please note in the comments
section of the order form that you are an RV LIST or any of Matt's other
Lists members and we'll donate 10% of your purchase price to Matt.
Also please consider this to be a challenge to the rest of the businesses
that are users this list...Let's support Matt!
e or http://members.aol.com/aamrelectr/index.html
Best regards,
John & Robin Caldwell @AAMR/AirCore
Subject: | Re: FAA BANS RV-LIST |
>FAA administrator, Jane Garvey, announced today in Washington that the
>RV-List operated by Matt Dralle (On the left coast!) was to be shut down.
>Citing the 51% rule as the reason for the shut down Garvey explained that
>with the advent of Vans Quick Build Kits the RV-List offered so much
>additional assistance to the builders that they no longer met the 51%
>criteria! "These builders are really pushing the envelope!" Garvey was
>quoted as saying. "They get all there builder questions answered by one
>simple E-Mail to this list! They no longer have to spend hours trying to
>figure out the plans and the manuals supplied by the kit builder. This
>significantly reduces build time and they make far fewer mistakes. It has
>taken most of the fun out of being the Administrator and besides, that
>Dralle guy has nicer hair than me!" She also noted. Rumor has it that
>Vans also supports the ban because they have noticed that their sales
>of replacement parts has significantly decreased since people get advice on
>how to do it the right way the first time from "one quick question" to the
>List. We were not able to confirm this rumor however.
>It was suggested by Moe Colontonio that builders supply their serial numbers
>to the list administrator and if they cross check to a Quick Build serial
>number then they would not be allowed on the list. Moe also asked that if
>anyone had a spare empennage and NON-Quickbuild serial number he would be
>interested in purchasing it.
>Doug Rozendaal asked the administrator if it wasn't possible that she was
>just jealous because Matt Dralle calls himself an administrator too? (The
>List Administrator) To which Garvey replied, "Absolutely not! I can care
>less what he calls himself! Don't you fly that pink airplane I saw at
>Oshkosh? We'll have to have a closer look at that machine!" After which
>Rozendaal withdrew his question.
>Chet Razer and some others at this point in the meeting asked Ms. Garvey if
>there was any more beer since they were done flying for the day anyway. To
>which Ms. Garvey responded that that "was an inappropriate question at
>such a meeting! " After which Ms. Garvey was bombarded with questions
>about bolt torque, Extra storage space in RV's, numerous engine questions,
>and finally some misguided newbie asked her about PRIMER!
>After tearing her hair out (no wonder Matt's looks better) Ms. Garvey
>suggested that maybe she better have another look at the RV-List ban and
>reassess her position. She said she is open to more public input if you
>don't mention PRIMER!
>You can contact the Administrator at:
> Please have your Credit Card ready!
> Matt Dralle
> PO Box 347
> Livermore, CA 94550
> If you even smiled once, won't you contribute? AL
> | Visit the Matronics & RV-List Web Sites at http://www.matronics.com
> | To [un]subscribe from the RV-List, email
"rv-list-request(at)matronics.com" |
> | & put the word "[un]subscribe" in the *body*. No other text or
subject. |
> | Please aggressively edit quoted text on a followup posting!
Subject: | Re: Question Answered, was Re: Question |
To reserve an "n" number go to your local FSDO with a list of the numbers you would
like. They will check the computer list to see if any of them are already
in use. When you have three - very important - write to the aircraft registry
in Oklahoma City, along with $10, requesting to reserve the number. Put the
numbers in order of which one you really want on down. The reason for three is
just in case the first one you want has been reserved ahead of you then they
will go to the second then to the third. You will get a letter back from the
registry letting you know that your number is reserved. That reservation is
good for one year. If you are not ready to activate the number after a year then
you will need to send another ten dollars to keep it reserved. When you are
ready to put the number on you plane then send the reserved card along with
yet another letter requesting them to actually activate it.
Mike Robertson
RV-8A wings and wheels on
"Das Fed"
In a message dated Tue, 26 Oct 1999 5:38:51 PM Eastern Daylight Time, jrh(at)mustang.us.dell.com
(Randy Howard) writes:
> > Mike Thompson
> > Austin, TX
> > -6 N140RV (Reserved)
> > Wings
Subject: | Compressor Warning; was HVLP painting |
Listers,
Last week I painted the interior of a local builders RV-6A. I was using a HVLP
gun (develbliss) and things were going quite well. We primed a bunch of airframe
parts and then the interior. While shooting the color top coat I started having
a harder and harder time getting good coverage. That is when I noticed the
compressor's silence and lack of air pressure. The compressor had tripped it's
thermal shutdown. The compressor is a Sears's 5 hp oil less with a 20 gallon
tank. It is located in a sound proofed box outside the garage. Since there was
inadequate ventilation for the compressor the beast got so hot that the plastic
guards melted down over the compressor. What a sight. The tank was too hot to
touch. After setting a fan blowing on the compressor it finally reset itself and
came back to life. The compressor has a listed duty cycle of 50% which we
exceeded greatly. Contributing factor was the insufficient cooling for the
compressor.
When painting think about your compressors health. I have a two stage 5 hp 60
gallon compressor at home so the thought never crossed my mind that I was taxing
the compressor. The little guys need a rest every once in a while
Gary Zilik
RV-6A - almost ready to paint.
Hi Hal,
I just went through the same experience and I have talked to several spray gun
manufacturers and paint shop professionals. Here's what I was told and what I
bought.
The two factors to consider in HVLP painting is SCFM rate and storage tank
size.
Typically your inexpensive HVLP gun will have a large compressor rating. Like
the Sharpe Cobalt which needs 13.9 SCFM at 50 PSI. Your compressor will be rated
somewhere in the manual or on the side of the tank. Mine, a single stage
220v/6HP vertical with a 60 gal tank, was rated at 12.5 SCFM at 40 PSI or 10.2
SCFM at 90 PSI.
This made it marginal for the new Sharpe Cobalt gun I just bought. The only
saving 'grace' was my tank size. With the Cobalt gun and a 60 gal tank,
according to Sharpe, I would be able to spray for 2-3 minutes and then I would
have to stop and wait for the compressor to catch up.
The other factor to consider is cup size. Unless we're just painting small
parts, the cups on these guns are just too small. If you're laying on primer
over the whole fuselage or wing, typically 100-150 sq/ft each, then something in
a bigger cup size is needed if you want to maintain a wet edge.
Last, unless you have the fixtures to rotate your fuselage, you're going to have
a difficult time painting the bottom of the fuselage with a gravity feed HVLP
gun.
All things considered, I took the Cobalt back and exchanged it for a Sharpe
Pressure Pot System 5675. This is made up of 988HVLP Pressure feed gun, 2 liter
remote pressure pot, and a pair of 6 foot connecting hoses. It was a bit pricey
at $400 bucks, but it will spray anything without changing nozzles, in any
position - including upside-down, only requires 7.5 SCFM at 50 PSI, and will
paint my entire wing or fuselage without a refill. I bought a cheap mini HVLP
for the small stuff.
I figure I can pass this professional equipment on to another builder for a
significant percentage of my cost when I'm done.
Hope this helps,
Bruce
Glasair III builder
> >dealer .....
> Just curious here...how do you know when a sales person is giving good
> advice? I asked about a Sharpe spray gun at a dealer and the guy told me
> my five HP compressor was much too small to paint an airplane with using
> any gun.
> I don't think he is right.
> hal
From: | "john schmidt" <jeschmidt(at)hotmail.com> |
Subject: | Re: RV-List Digest: 10/26/99 |
>From: jrh(at)mustang.us.dell.com (Randy Howard)
>Subject: Re: RV-List: Question Answered, was Re: Question
> > Mike Thompson
> > Austin, TX
> > Wings
Wed October 27, 1999 347pm CT
Greetings:
You mentioned getting an N number on the RV list
I have two numbers on reserve, 218PJ and 4622T (personal reasons for having
these two, don't want to get into it now. Hope to build two entirely
different projects, RV6 and Something Else.)
I would highly recommend calling Aero Records, a private title, escrow and
registration company in Oklahoma City, Oklahoma. I've dealt with them much;
they are incredibly knowledgeable, hard-working, and competent. They have
access to all available N-number combinations, and can secure one much
faster and more conveniently than dealing directly with the sloth FAA(and in
some cases, it's not the FAA's fault; I've seen their operation in Oklahoma
City, and it's underfunded and technologically backward).
Aero Records 800 654 7202 I think, or look it up in directory assistance.
They charged me (i think) $75. After that, it costs $10 per year to the FAA,
from the anniversary date of issuance, to keep the registration number
reserved in your name for your bird. Every year they (the FAA) send you a
postcard, asking for another $10, per N number (my bill this year was $20).
If I can be of any further help, please contact me.
John Schmidt
EAA 250021
RV6 N218PJ (reserved) slider, on the gear, progress SLOW.
serial 23721
12985 N. 2nd Ave.
Lindstrom MN 55045
651 257 8765
Subject: | 14V to 28V conversion |
Surfing the web I have noticed some good avionics deals on the various
auction sites. There seems to be an abundance of 28V models going for pretty
fair prices. I have not bid on any of them yet, but there could be a few
deals that I may want to take advantage of out there.
Is there an inexpensive and reliable way to convert 14V aircraft voltage into
28V? ACS only lists 28V to 14V DC-DC converters.
thanks,
Robin Wessel
RV-6A fuse
Tigard, OR
Subject: | Date: Wed, 27 Oct 1999 14:25:11 -0500 |
Jake L. Wegman (jake(at)ultrex.com) reminded me of the location on Vans site
for the detailed information I was referring to.
Check out
http://www.vansaircraft.com/sections/n58rv.htm for all the information you
need on RV8 wings and spar integerty.
http://www.mindspring.com/~mnellis/rv6_log
From: | Mike Wills <willsm(at)manta.spawar.navy.mil> |
to have
>gun.
One good piece of advice I got from my dealer was to buy a small easily
manuevered cup for the small stuff and the interior. The gun that I bought
(Accuspray, also pretty pricey) is easily converted to use a pressure pot.
The gun dealer recommended I purchase a cheap pressure pot from Harbor
Freight (which he said would work just fine with the Accuspray) when I get
to the exterior painting.
Mike Wills
RV-4 canopy
>Greetings:
>John Schmidt
>EAA 250021
>serial 23721
>12985 N. 2nd Ave.
>Lindstrom MN 55045
>651 257 8765
I used the approach recommended previously, search using Landings for
available numbers and then drop a note with a check for $10 in the mail.
After all the negatives Ive heard about the FAA imagine my shock when I
received confirmation of reservation of my first choice 1 week after I sent
my check!
Mike Wills
RV-4 canopy; N144MW (reserved)
As I started to build my RV-8 ailerons I discovered that I had been
shipped two right aileron spars, although they were identified as left and
right. I requested a replacement left spar and Van's sent it. When it
arrived it was identified as left spar, but was the same as the other two I
already have. I now have three right spars. I am returning two of them and
requesting a mirror image part which should be the left spar. The problem,
I believe is, RV-8, drawing 13, Aileron (left). The drawing in the upper
right hand corner of the spar is incorrect. It is identified as "AILERON
SPAR REAR VIEW, FULL SCALE". It is not a view of the rear of the spar
looking forward, it is a view of the front of the spar looking aft. (i.e.
A-407 & A-406 bracket position, hidden lines defining edges of flanges)
With that being the case, the left end view of the spar is backwards. (spar
flanges should be pointing toward the left, not the right) If a person can
read a blueprint, believes this is a rear spar view looking forward as
titled, discounts the A-406 & A-407 positions and believes the left end view
to be correct, they will misidentify right hand spars as left and you may
have been shipped one too.
If you haven't built your RV-8 ailerons yet take a look and see if
you have one spar of each kind. This may also apply to other RV designs
too.
Rich Crosley
Palmdale, CA
RV-8 Wings
From: | Charlie and Tupper England <cengland(at)netdoor.com> |
Subject: | Re: 14V to 28V conversion |
post the question to:
avionics(at)awpi.com
> thanks,
> Robin Wessel
> RV-6A fuse
> Tigard, OR
Okay, so how about a separate gravity feed pot (3-4 feet of line from
the pot to the gun), kinda like those I.V. drip things at the hospital?
You could make a stand on wheels as you move around the workpiece and
could even make the pot big enough for the whole shoot session. Anybody
tried this?
just another hare-braind idea...
from the PossumWorks
Mark Phillips
> to have
> >gun.
> Mike Wills
> RV-4 canopy
Subject: | Re: Aileron Spars |
The aileron spars on the 6's are identical. The only difference being which end
you designate at the root end.
Gary Zilik
> right.
"Re: RV-List: 10% for Matronics & a challenge" (Oct 27, 11:36am)
Dear John and Robin,
This is wonderful! Thank you for your support! I really appreciate it.
Best regards,
List Admin.
>provide
>Best regards,
>I believe the only way to drill the center bar (at the top
>of the canopy) is to remove the canopy from the fuselage and drill it on
the
>bench where I can lean over it - or - stand it vertically on the forward
>bar.
>Am I on the right track or is there a reason to do it on the plane?
I did it on the plane. It might be ok to do it on the bench, however even
after its all riveted together it still has some flex, so you could be
running the risk of building in some preload unless its set exactly how it
will be on the plane.
On the other hand... I know that at least a couple of people have left these
rivets out altogether. This is of course a design change and I know nothing
about what it does to the strength. But it might be worth looking into -- I
think they look nicer without that top strip on there. Has anyone on the
list done that?
Randall Henderson, RV-6 N6R (40 hours)
Portland, OR
http://www.edt.com/homewing
From: | "Fesenbek, Gary" <fesenbek(at)marykay.com> |
Subject: | Getting an N number |
I've read the posts about getting an N-Number and wanted to relate my
experience.
I called the "Sloth" FAA office in Oklahoma and told them I wanted a three
digit number that stared with 1. About 2 minutes later the very nice FAA
lady came back to me saying that I could have my pick from the following
three choices.
Hmm, Experimental 152 has a nice ring to it. So I took that one. Geez, I
think anybody giving the FAA a bad rap about getting an N-Number should at
least call them first. Oh... and they didn't charge me $75 for the service
either. It was free (At least as long as Al Gore doesn't become president).
cheers!
Gary Fesenbek
RV6A
Dallas, TX
Registered N152
Subject: | Re: HVLP Painting and compressor ratings |
Hal (& others):
One little item that can creep up as a "gotcha" on compressor power ratings
is the old magic advertising hype.
I have a Campbell & Hausfeld (spelling?) compressor set (from Wal-Mart,
believe it or not) that has "5 HP" stickers on it. It also runs on 120V
power, with a 15A max rating. The MOTOR nameplate (not the compressor) has
"SPECIAL" entered in the horsepower rating block. My own calculations show
that this motor is not likely to be more than 2 HP at most (15A X 120V X .85
power factor X 90% eff X 1HP/746W). The COMPRESSOR may be able to handle 5
HP input, but the MOTOR isn't providing that much.
Bruce Gray and Bryan Files have both mentioned CFM ratings (and duty factor,
for that matter) as being the real keys for evaluating whether a specific
compressor will be likely to get the job done for you or not - they're
right! The power rating can be deceiving...
Bill & Kathy Peck - RV-6A(Q) - moved to the airport last weekend! (Still
fitting the cooling baffles, though - if I ever find the Lycoming guy that
claims to have designed the O-360 case, I'm going to beat him senseless for
not making better provisions for baffle mounting!)
Subject: | Re: Getting an N number( good FAA experience) |
In a message dated 10/28/99 8:53:32 AM Eastern Daylight Time,
fesenbek(at)marykay.com writes:
experience.
three choices.
I just received my reserved number. First did the Landings thing and searched
to make sure the numbers were not in use. All five kicked back. Called the
FAA and a very nice lady told me you can not always depend on the list, so
she gave me the only 2 digit number followed by the to letters that I
requested.
Bernie Kerr, 6A, 60WM reserved, SE FLA
>Why don't you want an automotive alternator with a built in voltage
regulator?
>There are many homebuilts that fly with these. I have one myself-bought it
for
>$100- its out of a Chevy Spectrum- 60 amp and very small. I have 2 1/2 years
>and 300 hrs on it now with no problems.
I'm pleased that your experience with built in regulators has
been positive. However I'll ask that you please review:
http://home.kscable.com/aeroelectric/articles/bltinreg.pdf
http://home.kscable.com/aeroelectric/articles/failtoll.pdf
http://home.kscable.com/aeroelectric/articles/crowbar.pdf
http://home.kscable.com/aeroelectric/articles/bleadov.pdf
Fly comfortable . . .
(o o)
Bill Peck wrote:
"I have a Campbell & Hausfeld (spelling?) compressor set (from Wal-Mart,
right! The power rating can be deceiving..."
I have the Campbell-Hausfeld "6 hp" - 60 gallon model which is rated at 10.2
cfm @ 90 psi. The motor label also has "special" in the motor block space for
hp. However, lower down on the right side of the plate is an "output" label
which is listed, in this case, at 2.98kw. Dividing 2.98kw by 0.746kw/hp =
3.99hp, which is reasonable for the cfm of the unit. It is also listed as a
"continous duty" motor which is something the small airless, ie; Sears,
machines are not. So it pays to read the labels closely when buying a
compressor. You will generally get what you pay for. The Campbell Hausfeld
unit is by no means as good as an Ingersoll-Rand or other industrial unit,
but it only cost $388 at Home Depot, and if it lasts the life of this
project, it will have been cost effective. It is also a hell of a lot quieter
than my Sears 3.5 hp airless that it replaced. Andy Johnson, wings.
Performance results todate:
RV6 with 160 hp and Aymar-Demuth 68 x 74 prop, no wheel fairings or
pants.
Test weight 1450 lb.
TAS at 7000 feet , 2400 rpm - 175 mph / 2500 rpm - 185 mph
TAS at 5000 feet, full throttle 2680 rpm - 198 mph
ASI was tested against a calibrated unit in a chase plane
Looking good so far.
Regards Peter
Subject: | Re: Strobes:Mini Xenon Strobe |
>Heads-up, J C Whitney has a mini xenon strobe rated at 1,000,000 cp,
>12V,
>1/2 amp. 60 fpm, lexan lens, weatherproof housing, 1000 hr. life.
>I think this would qualify for aircraft use if above is true.
>$64.95. interesting?
Conventional wisdom suggests that we avoid hassles and just go
buy the TSO/PMA/STC item . . . HOWEVER, it just may be that
your local bearer of government holy water would consent to
the needed sprinkle if:
Borrow a photo flash light meter from a friendly photographer.
My personal favorite is the Gossen Luna Pro. Set up to measure
flash output in the direct radiation mode (little white plastic
window closed).
Find a few airplanes with high-dollar, already blessed
strobes on them and make some measurements using the hand held
flash meter. Use a yardstick to hold uniform distance from the
strobe head and make 8 measurments on the cardinal compass points
in the horizontal plane. Repeat for 30 and sixty degrees above
and below horizontal.
Get some data on several installed, certified systems.
Do the same thing with your proposed bootleg strobe. The lightmeter
readings should be equal to or greater than those for the certified
installations.
Gross calibration of the lightmeter is not an issue . . . you're
using it to compare one product with several others . . . we're
looking only for readings equal-to-or-greater.
When it comes time to sell your proposal to the cognizant
authority, you'll have DATA to justify your proposition that the
substitute strobe meets the spirit and intent of the rules
and is therefore suited for use on an amateur built airplane.
Yes, some of you may be anticipating some questions that could
require some additional effort but give this a try for the
first pass. If push comes to shove, I'll help with more detailed
and tighter controls on the tests . . . but if your inspector
is the least bit inclinded to favor good logic, this first pass
I've suggeseted may be enough . . .
(o o)
> experience.
>three
> three choices.
>I
>at
>service
>president)
>searched
>requested.
I had the very same experience. I went the snail mail route and submitted
five requests. None of them were available, yet the Landings webpage
database showed them to be available. I called a different guy at the FAA,
and he had already picked out every number with "BD" on the end for me. Now
THAT is what I call SERVICE. I simply chose one, and it was a done deal.
Brian Denk
RV8 N94BD
rigging controls then off for Transition training with Jeff Ludwig!
Subject: | Vendor web sites |
Listers,
I came across this list of general aviation vendors exhibiting at the AOPA
convention.
It lists web address for most of the companies and might be a great
reference
to go along with the "yellar pages"
Check it out at the following address:
http://data.aopa2.org/expo/exhibitors.cfm
Ed Cole
RV6A Finishing Kit
From: | Hal Kempthorne <kempthorne(at)earthlink.net> |
Electric Bob suggested:
I'm messing with some very bright halogens and thinking of this
demonstration which is just short of being there and seeing it. (you can
observe a lot just by looking!)
I will photograph several aircraft with strobes going and mine with my
lights going. Will take some trial and error and I'll publish findings.
Isn't it everyone's favorite?
hal
John:
As I recently posted, the Lord p/n is J-9613-49. This is a direct
replacement for the Barry 94011-20.
Doug Weiler
> My major goof...Working on too many planes at once. My 6 has a Dynafocal
mount.
> Thanks
> JMP
> John Perri wrote:
> > Does anyone have the original number for the Lord Mts. used on the Van's
> > Con. mount for an IO 360 ? Gettin droopy and alternator is wearing
> > through.
Someone posted a few days back that they were looking for a MA4SPA
carburetor.....I have two.
The carburetors are disasebmlbed at this time but when you get one it will
be togeather and look like a brand new carb that has just been overhauled
with yellow tag. The part # is 10-3678-32.
$1050.00 + shipping --- outright
$650.00 + shipping with your old core
Bryan E. Files
Ever Fly Maintenance
Palmer, Alaska
-4 tail
The integration time of the eye is not the same as integration time for
film. When you are comparing steady-state lights like the halogens with
flashing strobes, what your eye perceives and what the film perceives
might be quite different. Frankly I would go with testimonials from
people estimating the relative brightness rather than trying to
photograph it.
OTOH I would bet that the film would favor the halogens over the strobes
so if you are trying to "prove" that the halogens are better maybe
photos would work well for you.
Brian Lloyd
Lucent Technologies
brian(at)lloyd.com
+1.530.676.6513
Subject: | Sensenich Prop on 160 HP RV6/6A |
Hi
Looking for any feedback on using the metal fixed pitch metal prop on a
0-320 160 hp engine. Particulatly interested in:
1) how restrictive is the 2600 rpm limit. It would seem that 100 rpm is a
lot to give up.
2) performance differences between wood and sensenich props from those who
have experienced flying with both on the same aircraft.
John Crate
RV-6A
Fuselage out of jig next week
Subject: | buying used tools |
I just PCS to Ft. Rucker and lost the shop I was sharing at Bragg, I'm
looking for good deals on most used tools needed to build an RV.
Carey Mills
RV4 fuse
From: | "Eustace Bowhay" <ebowhay(at)shuswap.net> |
Subject: | Jon Johanson Award |
Thursday 28 October 99
MEDIA RELEASE
URGENT- for immediate release
ADELAIDE PILOT JON JOHANSON RECIEVES PRESTIGIOUS INTERNATIONAL AWARD AT
LONDON BANQUET.
Adelaide's record breaking pilot JON JOHANSON received the pretigious
JOHNSTON MEMORIAL TROPHY FOR 1998 FROM THE GUILD OF AIR PILOTS AND AIR
NAVIGATORS at an awards banquet at Guildhall in London just a few hours
ago.
Jon has been nominated for this award in recognition of his outstanding
combination of self-confidence, persistence, determination and
piloting/navigational skills in a series of world record breaking solo long
distance flights in an aircraft built by himself.
Jon built his RV-4 single engine, two seat, sport aircraft VH-NOJ and flew
it twice around the world, once heading east and once heading west. Jon
presently holds 43 world aviation records and numerous world firsts
including the first pilot to solo the world's four major oceans.
The Johnston Memorial Topy is international recognition for Jon's
achievements. The trophy was first awarded by the Guild of Air Pilots and
Air Navigators in 1931 to Sir Francis Chichester. Some other recipients
include Bert Hinkler, Jean Batten an P G Taylor. The Terms of Reference for
the award are:AWARDED IN MEMORY OF SQUADRON LEADER ERNEST JOHNSTON, FIRST
DEPUTY MASTER OF THE GUILD AND NAVIGATOR OF THE R101, TO A PERSON OR
PERSONS FOR THE MOST OUSTANDING PERFORMANCE OF AIR NAVIGATION,OR FOR THE
AIRBORNE DEVELOPMENT OF NEW NAVIGATION TECHNIQUES AND EQUIPMENT, OR FOR THE
GROUND DEVELOPMENT OF NAVIGATION TECHNIQUES AND EQUIPMENT.
In acknowledging this prestigious award to an Australian pilot, Quantas
ensured that Jon was able to be in London to receive the trophy in person.
"Thought this would qualify for the RV-List, what a guy what an aircraft."
Eustace Bowhay
John,
First of all I want to thank you for contacting me!
The big compromise with the 2600 RPM restriction is in climb performance. We
pitch the propeller (79 for 160 HP) so that you will hit 2600 RPM full
throttle level flight at altitude...around 7000 to 8000 feet. What this does
is give you about 2100 RPM static, and about 2250 on climb. This should
yield a climb rate of 1200 FPM. On the cruise side, this propeller is
extremely efficient and I feel safe in saying that RPM's being equal, is the
most efficient cruise prop available! I think that is why we have sold over
350 to date.
One person comes to mind when you ask for someone who has flown both the
wood and the 70CM metal prop. His name is Gordon Comfort and I can assure
you that he will give you an honest opinion, and I'm not even sure what that
opinion will be. He will find that statement amusing I'm sure!
He can be emailed at gcomfo(at)tc3net.com
You may wish to get his phone number and discuss live, because he has a lot
of data.
Let me know if I can be of any assistance to you on your propeller
selection. I realize that this is a lot of money your spending and I want to
make sure that if we get it, you are happy!
Ed Zercher
Subject: | Re: Pop Rivet Question |
I'll see if I can't take a crack at this. I hope I don't confuse the issue more.
"Pop" style rivets are fickle creatures. They do not always work the way we envision.
Which is to say that they do not always pull up tight and fully plug the
hole. The only recorse is to pop out the stem and drill out the rivet. But
then we have the aggravation the the little Ba----ds want to spin in the hole
so be ready with a pair of dikes to hold on to them.
My choice for the critical areas such as you are speaking is to go the expensive
route and get Cherry-Lok or Cherry-Max rivets. Yes they are expensive (about
$.65 ea) but generally have a much higher percentage of setting correctly and
are considered structural rivets with high shear loads.
In either case make sure that the layers you are riveting together are tight before
"pulling" the rivet. Otherwise you will almost always have a loose set.
Good luck and good building
Mike Robertson
RV-8A QB Painting the interior
In a message dated Wed, 27 Oct 1999 1:33:05 AM Eastern Daylight Time, "Rob Reece"
writes:
> Rob Reece
> RV-3 SN45
> Socorro, NM
> 505-835-3644
Date: Thursday, October 28, 1999 12:42 PM
Subject: Re: RV-List: Re: Strobes:Mini Xenon Strobe
can
>photograph it.
>Brian Lloyd
>Lucent Technologies
>brian(at)lloyd.com
>+1.530.676.6513
The visual perception process of the eye is quite different than any
integrating or peak-reading instrument, and way different than film. An
example of clever engineering to take advantage of the eye's properties is
the Whelen "Comet Flash". The Comet Flash principle takes advantage of the
eye's integration time such that the eye/brain system automatically
"connects the dots". The three brief duration, intense flashes appear to
the eye as a continuous steak of light. When you observe one of these
systems in marginal visibility along with a conventional system you begin to
appreciate the safety edge afforded by the better engineered systems. Note
that most of these advantages are not apparent by simple comparison of
specs.
Dennis Persyk 6A finishing kit
Hampshire, IL C38
Subject: | Re: Sensenich Prop on 160 HP RV6/6A |
I've got 230 hrs on my 6A with the 160hp and Sensenich prop...
I am very happy with this setup.. I get a good climb out rate as well as fast
cruise speeds, (190mph TAS) Cruising up high at full throttle usually gets
around 2500rpm,
so you do not have to worry about the 2600 rpm limitation much until you
start descending.
Walt
From: | Peter Laurence <plaurenc(at)bellsouth.net> |
> > experience.
> >three
> > three choices.
> >I
> >at
> >service
> >president)
> >searched
> >requested.
The same happened to me. They were efficient!
Peter Laurence
Peter Laurence
RV6-A Wings
Sunfire paint.<
I just checked with my SW rep. He said the Sunfire is not compatible with
the was primer that Vans uses and that you must prime with a Urethane
primer over the wash primer.
For those of you using the 988 (SW spray can) he said you do not have to
prime or seal first. It is OK to scuff with 600 paper and spray the
Sunfire. He did say that it is not as durable without a urethane primer or
sealer and that the 988 is very absorbant and would not be as glossy as if
it were sealed first.
Scott A. Jordan
80331
seat backs
Subject: | Re: RV6 for sale |
wvu(at)mail.ameritel.net wrote:
> Good luck Jerry,
> Send propective buyers this way if they need some good words. Received your
> R50 today. I'll let you know once I have a chance to try it.
> Anh
> >I reluctantly have decided to sell my 6. Its the third of five homebuilts,
> >(a Starduster Too, 3 RV6s and an RV8. Finished in august 94 TT 175hrs
> >O-320E Lyc 160hp, Colin Walker wood prop. Has tilt up canopy, gyro panel,
> >760Val, R50 loran, King 76a with encoder, nav lts, belly strobe and good
> >cabin heat. Paint is a military scheme blue top white bottom invasion
> >stripes and probably the only sharks mouth on a 6. I received builders
> >choice at the 97 Oswego NY fly in and appeared on front cover of COPAs
> >Canadian Flight monthly paper november 97. Asking low 50s US$. For more info
> >and or pictures contact off list or at 506 472 0503. My 1st and 3rd RV6s are
> >currently flying in the US. Photos can be seen at (
> >http://personal.nbnet.nb.ca/nielsdaj/Weyman/weyman.htm ) Will deliver for
> >expenses.
> >Regards Jerry Wilcox
> >jawilcox(at)nb.sympatico.ca
So do you still have your RV-6 for sale dl
I sprayed the 988 and did not seal it...then I sanded with 600, then shot
Sunfire...with a slight buff, you can shave in it...not a shine problem at
all.
Paul Besing
RV-6A (197AB) Arizona
Finish Kit
Date: Thursday, October 28, 1999 11:27 PM
>thought I might use RustOleum until I read the post on Sherwin Williams
>Sunfire paint.<
>Scott A. Jordan
>80331
>seat backs
I know this has been discussed before but I couldn't find it in the
archievs. I am about to but a freshly overhauled O-360 for my RV-8. I
don't expect to get the engine installed and running for the better part of
two years. What should be done before removing the engine from its current
airframe? How should it be stored?
Scott A. Jordan
80331
fuselage
Subject: | IA/A&P in the SoCal area |
Not RV related. Some potential partners and myself are looking to buy a
cheap taildragger to build time on. We've got a line on a C140 based in
Hemet that sounds promising. All we know is that it needs some work. Hope
to have further info late tomorrow. We will be able to go up and take a
look but since none of us are real familiar with what to look out for we
wondered if there was an A&P or IA who would be willing to meet us there
and help us out with a pre-buy inspection. Possibly as soon as this
weekend. Anyone out there willing or anyone that you can recommend?
Mike Wills
RV-4 canopy(still!)
Subject: | Re: Getting an N number |
What number did you call the one I have is always bussy?
--- Ed Zercher wrote:
> John,
> hit 2600 RPM full
> climb. This should
> this propeller is
> 350 to date.
> I'm sure!
> of data.
> your propeller
> Ed Zercher
John:
I have a Constant Speed prop on my 160 HP RV-6. I fly
with Walt Hastings (Rvator97(at)aol.com) N79WH that uses
a 160 HP Sensenich on his RV-6A. His RV with the
Sensenich prop, is the best fix pitched RV that I have
flown with. This includes 180 HP RVs with fix pitched
wood props.
We (The 6 Pack,
http://home.HiWAAY.net/~sbuc/journal/album_2.html)
flew as a flight from Southern California to Oshkosh.
At any given airspeed, I was turning 40 RPM more than
he was for the same airspeed. We both have digital
tachs. In fact, I was usually asking him to slow down
as I did not want to turn that high of an RPM and burn
that much fuel. My RV-6 is not slow. If you check
this years Copperstate Dash results, you will see that
I was faster than one RV-6 that had a 180 HP. All the
speeds are low as we had headwinds all the way. My
airspeed during the Dash never dropped below 172 KTAS.
Headwinds made the ground speed much lower.
http://www.copperstate.org/Winners/Speed_Dash.htm
The biggest advantage to the constant speed is that I
can slow down, decend, and not go over REDLINE on the
engine. Yes, Vx and Vy are better with the constant
speed but you do not notice it unless you are flying
in formation.
Gary A. Sobek
So. CA, USA
From: | "Frank & Kit Zwart" <zwart(at)kalamazoo.net> |
> Sent: Wednesday, October 27, 1999 10:25 AM
> Subject: Re: RV-List: O-360 Parts ID
> Yes
> ----- Original Message -----
> From: Stephen J. Soule <SSoule(at)pfclaw.com>
> To:
> > Steve Soule
> > Huntington, Vermont
> > As you surmised, #2 is for CHT, but I believe
> that the #1
> > ports are used
> > for fuel injection & remain plugged if you have a carb.
> You
> > should find
> > additional plugged 1/8 NPT ports on the aft, outside,
> lower
> > corner of each
> > cylinder. These are normally used as primer ports, with
> > maybe cylinder #3
> > having a manifold pressure connection instead of primer.
> >I will be using the upper ports for each cylinder cht probes which are
installed with a bayonet base, unless someone more knowledgeable than me has
a reason not to. I would like to know.
Subject: | Re: Beware AC$ Stencils |
Or, call your nearest sign making company and get him to computer cut your
stencils from low tack vinyl. It won't cost all that much and you'll be pleased
with the results.
Dave Hrycauk
RV-8 Left Elev (Wings Here)
Bonnyville, Alberta Canada
http://www.incenter.net/dhrycauk/index.htm
Tim Lewis wrote:
> Listers,
> A warning to those doing their own painting:
> I bought a two sets of 3" N number stencils from Aircraft Spruce (Part
> number 9-3280x). ACS sent 9 stencils that are essentially poor quality
> masking tape with the letter/number precut. ACS sent one stencil (the
> letter "T") that was a high quality vinly stencil.
> Despite the fact that I followed AC$'s directions to the letter, the poor
> quality stencils were a disaster. The paint seeped under the edges of
> the stencil, leaving a nasty, blotched edge. The single good quality
> "T" stencil worked great... crisp, sharp edges.
> Recommendation: If you order your stencils from AC$ DEMAND the
> high quality vinyl (white) stencils rather than the poor quality (light
> brown) stencils.
> Tim
> Tim Lewis
> timrv6a(at)iname.com
> N47TD RV-6A, painting
> Springfield VA
> http://home.earthlink.net/~timrv6a
> http://home.earthlink.net/~timrv6a/jpi.html - No JPI stuff in my airplane
Aircraft Registry in OKC is (405) 954-3116. There is only one number so it is
often busy and when you do get through please be prepared to wait a few minutes
on hold.
In a message dated Thu, 28 Oct 1999 9:14:54 PM Eastern Daylight Time, TColeE(at)aol.com
writes:
Also keep in mind that many vinyl stencils are not compatible with
solvent based paints unless the paint is sprayed on in very light coats.
It is beetter to ask for frisket masks to be cut. Frisket is a special
material and resists paints far better, is thinner, and easier to
remove.
I do this kind of thing for a living and there is just no substitute.
Why not just use the vinyl lettering anyway? If properly applied to a
wax free surface the high quality vinyl is good for 5-7 years. In my
experience they last longer than that. You must ask for High Performance
vinyl (3M is best). It should not lift or loosen. I don't recommend
spraying any clearcoats over it either as they will likely not bond that
well and might chalk.
Subject: | Re: Quick Build Primer |
Scott
Thanks for the info. After pricing the primer and Sunfire top coat I think
this might be overkill for my airplane as I intend to upholster the sidewalls
and carpet the floor.
Would you check with your source and find out if the Sherwin Williams Acrylyd
acrylic enamel will go over the quick build primer.
Cash Copeland
Rv6QB
in a message dated 10/29/99 12:57:24 AM GMT Daylight Time,
SAJ_SLJ(at)compuserve.com writes:
Scott A. Jordan
80331
seat backs
Paul
Did you spray the 988 over the QB wash primer, or just on the parts that you
fabricated?
Cash Copeland
RV6QB
n a message dated 10/29/99 1:22:22 AM GMT Daylight Time, rv8er(at)home.com
writes:
all.
Paul Besing
Finish Kit
Listers:
Just made my next big STUPID mistake. While dimpling the VS skin on the
avery c frame tool, I pounded one dimple without the die centered in the
hole. As a result, I have a 3/32 hole punched out by the die which is
just barely but not quite touching the original hole. I caught myself
before pounding enough to form the full dimple. It appears that the two
holes are far enough apart to preclude drilling a #30 hole between them
and using an Oops rivet (or even an AD4 flush rivet.) FWIW, the hole
in question is on the front spar, 4 holes from the tip rib. Is there an
Oops rivet with a 5/32 head and 3/32 or 1/8 shank? Or something similar
which might save my skin?
Any suggestions, short of a new VS skin?
Jeff Point
jpoint(at)execpc.com
-6 tail
Milwaukee, WI
And the VS was going flawlessly, after the fits and starts on the HS.
sigh........
Subject: | Re: Jon Johanson Award |
Fellow Listers:
Just a short comment on Jon's award. In August, my family and I traveled to
Australia to spend some time with a very dear friend and RV-6A builder Ross
Rebgetz. While visiting Ross in Townsville, QLD, Jon just happened to fly
in for a visit in his RV-4. The next day we had morning tea with Jon and
some of the other local homebuilders. We had a great morning and Jon was
the life of the gathering, relating his many adventures of world-wide RV
travel. I continue to marvel at his courage. He is most deserving of this
award.
Doug Weiler,
Hudson, WI
> LONDON BANQUET.
> ago.
Look on my web page in the tips section, there is a little paragraph in
there on filling holes in sheet metal that works fairly well.
http://www.tabshred.com/moe/tips.htm
Moe Colontonio
moejoe3(at)home.com
just barely but not quite touching the original hole. Is there an
Subject: | Re: Engine storage |
Aeroshell makes a preservitive oil that works well....
1) Drain out engine oil.
2) Put in 7-8 qts of Aeroshell preserve oil.
3) Run engine for about 5-7 min on ground.
4) Drain preserve oil out.
5) DO NOT MOVE PROPELLER OR TURN OVER ENGINE UNTIL YOU ARE READY TO GO!
Sent: Thursday, October 28, 1999 4:02 PM
Subject: RV-List: Engine storage
of
current
> Thanks
> Scott A. Jordan
> 80331
> fuselage
Subject: | Re: Date, RV8 spar/fuel tank interaction |
Greetings All,
Concerning previous thread on RV8 spar/ fuel tank interaction leading to
failure.
I saw this thread started a couple days ago about the interaction between
the RV8
wing spar and the fuel tanks. Thought I would lurk around and wait for
someone
with some knowledge in this area to reply, but things ended here with
reference to
VANS official report.
I have read the report, and checked the archives. The report says the
metalurgist
concluded no cracking or fatigue, but cause was G induced failure. Not
much
on this in the archives. How accurate is the analysis by the metalurgist??
I know a bit about engineering, as i am an electrical engineer, and have
been designing
telecom equipment for some 10 years. You simulate/calculate and then test,
test, test.
The gotchas are usally things like unexpected sub-system interaction or
things you would
never expect.
I have absolutely NO practical knowledge in this area, although i have dealt
with metalurgist
before. I do have the tail kit which I bought after reading VANS RV8 test
report, and am gathering
tools and learning. ok, also almost done with PPL.
Would someone with some experise in this area please comment. I will be
inspecting my spars (what i can) at about 400 hr or sooner, even with all
the data.
Eric Tauch
Sent: Wednesday, October 27, 1999 4:52 PM
Subject: RE: RV-List: Date: Wed, 27 Oct 1999 14:25:11 -0500
> Check out
you
> Mike
Subject: | Re: RV-4 Eng.-Mount Bolt Hole Fix |
Chris,
Thanks for the information. I did talk to Vans and as you predicted
they said not to worry about it. I am still a bit concerned about it
though. I guess the first loop I do in my plane I'll have my heart in my
throat! But, that would probably be the case anyway.
Thanks again for the help.
Ted
Date: Monday, October 25, 1999 6:44 AM
Subject: Re: RV-List: RV-4 Eng.-Mount Bolt Hole Fix
>Ted,
>I went through this with my -6A. Tom at Vans explained that the firewall
>bolts are compression joints, meaning the size of the hole is not critical.
>Check the archives on this. He used the example of changing engine mounts,
>in which you would likely have to open the holes up to get a new mount to
>align. Tom said just to line it up as best you can and drill away. He
>specifically said that no repair plates are necessary.
>Chris Browne
>-6A finish
>Atlanta
>From: Ted Lumpkin <tlump(at)mediaone.net>
>Date: Monday, October 25, 1999 12:14 AM
>Subject: RV-List: RV-4 Eng.-Mount Bolt Hole Fix
>> I have just finished drilling my engine mount to the firewall on my
>>RV-4. I had previously drilled 3/16 dia. undersize holes to attach it to
>>the jig. When I first fit the engine mount I could see the holes did not
>>line up perfectly with the mount, but it appeared that they would clean up
>>if I used the mount as my drill guide. After finishing the drilling and
>>removing the mount, much to my dismay I found that one of the holes did
not
>>clean up fully. About 1/8 of the 3/16 dia. hole is left. The offending
>>hole is on the bottom right side of the fuselage.
>> Anybody else have this problem? Any ideas on how to fix this? Is it
>>really a problem?
>> I have thought about trying to weld a reinforcing doubler to the steel
>>weldment and redrilling, but it would be very difficult to weld down
there.
>>I thought about cutting off the 3/8 ID tube on the mount, welding in a
7/16
>>but I don't know how these bolts are loaded.
>> What really makes me mad is that this is the first mistake I've made
in
>>5 years of building (if you believe that I've got a BD-5 kit I'd like to
>>sell you).
>>Thanks in advance,
>>Ted
Ed,
Thanks for the info but can you also address the recommended prop for the
O-360 A1A. The recommended cruise pitch prop was 83 last year and now I have
some information that an 85 pitch is being recommended. Can you clarify this
for me (and I am sure other RV6 builders with O-360 installations)
Gary Palinkas
Parma, Ohio
RV6QB pluggin' away on control systems
From: | David Roseblade <davidagr(at)emirates.net.ae> |
Subject: | Stabiliser skin finish around dimples (RV-6) |
I have just finished riveting the skins on to my stabiliser, no big
problems - I actually used solids throughout. A couple of observations which
might assist other builders.
When riveting the spars etc where it is necessary to bend back the skin for
bucking bar access, try and get additional help to support and keep the skin
flat under the rivet snap, I didn't and I have a few minor crease's (bottom
skin so not too concerned). I used a C-frame tool to dimple the skin, again
get some help to support the skin, where you have to bend it back to gain
access, this will keep the dimples really even, alternatively it is possible
to use limited access dimples tools but it will not look the same. After
riveting the skins these dimples looked superb.
Also use the C-frame tool on all skin dimples, I used a pneumatic squeezer
for the dimples at skin edges and after riveting you can notice that the
dimples are in slight hollows (Anyone have any ideas on how to get these
out, is this usual ?? my first thought is to use a rivet block on the skin
and tap gently from underneath) I don't want to use filler.
RV-6 Empennage
David Roseblade
UAE Persian Gulf
Subject: | RV-6 aircraft in Seattle area |
I am travelling to Seattle next week from the Persian Gulf to collect a Big
Bird (Boeing). Are their any listers in the area who would be willing to let
me have a look at their machines. I have just completed my stabiliser and as
yet I have never seen a RV-6 in the flesh.
Here's hoping !
RV-6 Empennage
David Roseblade
UAE Persian Gulf
Subject: | Quick Build Primer |
> coat I think
My SW dealer claims that Westhane is the same stuff as Sunfire, only
marketed differently as a "econo" line (the SW web page does seem to
indicate they have the same properties).
He said one of his clients paints Coast Gaurd Sikorsky's with it, and the
paint even lasts in a seawater environment.
Can whomover posted that they have a knowledgeable SW rep confirm?
Rob Acker (RV-6Q, FWF stuff...)
Gary,
The 83 pitch is still the preferred standard pitch for the RV-6/6A. Last
year we did all of our testing on a 6 and a 6A and pretty well nailed that
one down. Where the 85 pitch is coming into play is the RV-4's and RV-8's.
We have several of each flying now and those aircraft with the 180 really
seem to unload the prop a little more than the 6's. We have had very few
customers change their 83 pitch on the RV-6/6A series. As you know, every
aircraft and engine is a little different so a pitch tweak is always a
possibility down the road; but those are few.
Looking forward to working with you,
Ed Zercher
Subject: | Re: Flight Results |
Do you happen to have Manifold Pressure readings as well. RPM only tells half
of the power story. A-D makes great props and it looks like you got a good
one. Expect to see 5 to 8 more mph with the wheel pants installed.
Gary Corde
RV-6 N211GC - NJ
Anyone have the Oklahoma office number?
-Bill
Subject: | ?Westach EGT Senders installation |
I bought a Westach EGT/CHT off of a friend, but don't have the installation
instructions. He can't remember the recommended distance from the exhaust
port to drill for the EGT senders.
Can someone email me a copy of the installation manual for the Westach dual
EGT/CHT guage.
If someone just knows the correct distance to drill for the EGT probes, I'd
be happy.
Thanks in advance!
I am building an RV6A, working on the fusalage skeleton. Do the flanges of the
F-611 bulkhead face forward or aft? I have seen information both ways.
John Vanderzyde
jvanderzyde(at)gtn.net
Subject: | Re: ?Westach EGT Senders installation |
In a message dated 10/29/99 8:21:08, Metalplane(at)aol.com writes:
EGT/CHT guage.
be happy.
Thanks in advance!
I don't remember the distance but was unable to achieve it with the crossover
system anyway. Go as far from the engine as you can before the first bend on
the shortest one, then match that distance on the others. This will give you
as good as you can get with relative readings, and maximize probe life.
One man's technique (acquired from those who went before me)
D Walsh
Subject: | Re: Bulk head F611 |
-----Original Message-----
Date: Friday, October 29, 1999 9:39 AM
Subject: RV-List: Bulk head F611
the F-611 bulkhead face forward or aft? I have seen information both ways.
>John Vanderzyde
John,
I suspect you mean the aft-most F612; F611 has a pair of back-to-back
bulkheads.
I installed my flanges aft per the George O tape so I could squeeze the
rivets. I also wrapped the fuse skin around the bottom per the video.
Others who have done it per plans and have seen mine prefer my (George's)
way.
Hampshire, IL C38
(Content Technologies SMTPRS 2.0.15) with SMTP id
for" ;
Fri,
29 Oct 1999 11:37:55.-0400(at)matronics.com
"Dennis Persyk" on 10/29/99 11:00:15 AM
Subject: Re: RV-List: Bulk head F611
Hi Dennis,
I have not seen the video, can you elaborate on what you are talking about. Do
you mean bringing the side skins lower on the tailcone piece?
Thanks in advance
Eric Henson
Starting to skin
way.<<<
Hampshire, IL C38
Scott:
Searce for "engine inhibiting".
I pluged all the holes & build 2-( 2bys) stands. one for right side up &
one for unside down. Put 12 qts of auto oil in it & 4 deicator plugs. I
store it up side down & roll it every 2 monts.
The quick drain was replaced with a plug & the filler up tube was pluged
with a rubber free plugs. STC'ed of course.
Don Jordan ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com
writes:
>I
>part of
>current
>Thanks
>Scott A. Jordan
>80331
>fuselage
I have seen them both ways. On mine I followed the plans and faced the flanges
forward. I suggest to new builders the alternative of placing flanges
rearward. Sure makes riveting the tailcone easier
Gary Zilik
> John Vanderzyde
Subject: | Re: O-360 Parts ID |
All 4 cylinders are alike. Both ports (top & bottom) open into the intake
port, so you can use either of them for priming or m.p. Engines are
pretty easy to get along with.
It is usually about 3 inches down.
Bryan Files
Palmer, Alaska
-4 tail
Sent: Friday, October 29, 1999 6:44 AM
Subject: Re: RV-List: ?Westach EGT Senders installation
installation
dual
> EGT/CHT guage.
I'd
> be happy.
> Thanks in advance!
crossover
on
you
> D Walsh
> be happy.
It isn't that critical but each probe should be the same distance from
its respective exhaust port if possible (2" to 10" is probably OK) since
the exhaust gasses are cooling as they travel down the exhaust pipe and
you probably want consistent EGT readings from cylinder to cylinder.
Brian Lloyd
Lucent Technologies
brian(at)lloyd.com
+1.530.676.6513
JOHN
the flanges face forward, plans 34 top left section
good luck
scott
fuse
tampa
From: | "John Sheppard" <jtshepp(at)lvnworth.com> |
Dave,
My experience with "fixing" cosmetic flaws in dimples by using the female
half of a dimple set have all been bad! I recommend you chose one method of
dimpling and stick with it throughout the project. As for existing dimples -
I'd keep building - bigger hurdles lay ahead. I use my rivet gun with a
pivoting male die and female die, block combination for all skin dimples
with excellent results (pretty slow though).
John Sheppard (RV8 tanks)
Sent: Friday, October 29, 1999 7:17 AM
Subject: RV-List: Stabiliser skin finish around dimples (RV-6)
RV-6 Empennage
David Roseblade
UAE Persian Gulf
Subject: | Re: OK phone # Getting an N number( good FAA experience) |
In a message dated 10/29/99 10:46:25 AM Eastern Daylight Time,
vondanes(at)email.msn.com writes:
<< Anyone have the Oklahoma office number? >>
405-954-3116
Bernie Kerr, 6A on wheels and engine mounted, 60WM reserved, SE Fla
Subject: | List Server Humour - NOT RV-related - delete as appropriate..... |
Came across this t'other day..... With all the goings on recently I just
had to post it.......
Smile ........ and send your donations to the contribution fund.......
Graham Jones
Kilmore
Aust...
Q: How many list subscribers does it take to change a light bulb?
A: 1,331:
1 to change the light bulb and to post to the list that the light bulb has
been changed.
14 to share similar experiences of changing light bulbs and how the light
bulb could have been changed differently.
7 to caution about the dangers of changing light bulbs.
27 to point out spelling/grammar errors in posts about changing light bulbs.
53 to flame the spell checkers
156 to write to the list administrator complaining about the light bulb
discussion and its inappropriateness to this mail list.
41 to correct spelling in the spelling/grammar flames.
109 to post that this list is not about light bulbs and to please take this
email exchange to alt.lite.bulb
203 to demand that cross posting to alt.grammar, alt.spelling and
alt.punctuation about changing light bulbs be stopped.
111 to defend the posting to this list saying that we all use light bulbs
and therefore the posts **are** relevant to this mail list.
306 to debate which method of changing light bulbs is superior, where to buy
the best light bulbs, what brand of light bulbs work best for this
technique, and what brands are faulty.
27 to post URLs where one can see examples of different light bulbs
14 to post that the URLs were posted incorrectly, and to post corrected
URLs.
3 to post about links they found from the URLs that are relevant to this
list which makes light bulbs relevant to this list.
33 to summarize all posts to date, then quote them including all headers and
footers, and then add "Me Too."
12 to post to the list that they are unsubscribing because they cannot
handle the light bulb controversy.
19 to quote the "Me Too's" to say, "Me Three."
4 to suggest that posters request the light bulb FAQ.
1 to propose new alt.change.lite.bulb newsgroup.
47 to say this is just what alt.physic.cold_fusion was meant for, leave it
here.
143 votes for alt.lite.bulb.
They forgot a few:
27 to post in HTML because they are using the IE or Netscape that had it
turned on by default and are too clueless to look
48 to complain about the HTML posts
27 to post 'sorry I didn't realize it was on' -- in HTML
96 to complain about more HTML and post detailed instructions on how to
change the setting
58 to mumble something about using a web browser to read mail
12 MIME posts with useless colors and bolds saying thanks for the help with
the HTML mail
1 to post a GIF/JPG of the lightbulb hanging too close to their digital
camera.
1 complaint from the guy using /usr/ucb/Mail who wants to know what the
*@&(%$!@ has been going on
58 to complain about the binary post
74 to say they liked the binary and didn't mind it
1 post about how you can MAKE MONEY FAST!!!!! by selling lightbulbs and this
report available for only $5.
1328 to reply to the list with the full spam attached and then put 'remove'
at the end
3 to flame the other morons for replying to the spammer and CCing the list
1 from the list admin notifying that the list is looking for a bigger server
to handle the load
There have now been several followups:
"How did I get on this list?"
"How do I get off this list?"
"REMOVE"
"REMOVE
UNSUB
SIGNOFF
REMOVE
TAKE ME OFF THIS LIST"
"unsubribe" [sic]
"Morons, you have to send it to the majordomo address"
"How am I supposed to know that?"
If it wasn't so pitiful, it would be funny.
A friend of mine who is not on the list is offering his beautiful RV-6A for
sale. The workmanship on the aircraft is outstanding.
TTAF-187
150 HP
Metal Sensenich Prop
Terra com, Transp-mode-C
Trimble GPS
VFR panel w/shock-mounted gyros
Imron blue over white
Owner can be contacted for particulars at:
ajsrv6a(at)juno.com
or (303) 412-6913
Ray Parker
Will the person looking for used tools please respond again. I lost his
e-mail address.
Subject: | Re: RV-6 aircraft in Seattle area |
>Here's hoping !
>RV-6 Empennage
>David Roseblade
>UAE Persian Gulf
If you have the time visit Van's Aircraft in Oregon. It's about 180
miles south of Seattle.
Or, visit the Arlington Airfield north of Seattle about 40 miles.
There are at least 15 RV's on the field, -3,-4,-6,-6A and I think an
-8. Just drive around the hangars and see what you can find.
John Ammeter
Seattle WA
USA
http://members.home.net/ammeterj/
1975 Jensen Healey
RV-6 (sold 4/98)
EAA Technical Counselor
NRA Life Member
ICQ#48819374
Subject: | Propane Engine Preheater |
From everything I've read, it's best to preheat a Lycoming below 30*F.
I'd like something I can use regardless of whether my hanger (or tie
down) has electricity, and that I can use while traveling. So far the
$288 Red Dragon MH-300 looks like the best bet (
http://www.flameeng.com/Red_Dragon_Heaters.html ). The 49,000
BTU heater runs off propane and 12 v to run fan. According to the
company, it takes 10-15 minutes to preheat an engine from 0*F, with
minimal drain to the battery. I can apprently use a Barbeque-size LP
gas container at home, and those little 14oz propane tanks (using an
adapter) while flying around the country.
Does anybody know of a better solution?
Tim Lewis
Springfield VA
I'm not the one you talked to before but i am an A&P who is working on
getting a RV-6 project started soon, and i"m always interested in tools of
the trade so if you don't get a response give me a e-mail at ITZSTEVEJ(at)AOL.COM
Subject: | Re: Stabiliser skin finish around dimples (RV-6) |
Guys here is a good idea to ease your mind when you
accidently punch a hole in the stab skins with the
c-frame. go ahead and deburr the hole first and
install the skins rivet them on as you normally would
you will still have a hole where you messed up no big
deal just mix up some proseal and seal the hole with
it and use a squegee to get aerodynamically smooth or
a popsicle stick and then use mek or coleman fuel
acetone whatever to clean up the mess from around the
hole and whalaa you have a clean skin for paint
Glenn Williams 8a wings and a&p mechanic hope this
helps
> stabiliser, no big
> can notice that the
> on how to get these
> filler.
> RV-6 Empennage
> David Roseblade
> UAE Persian Gulf
> Avionics, and by the generous Contributions of
> List members.
> Matronics:
> RV-List:
> Archive Search Engine:
> http://www.matronics.com/search
> Archive Browsing:
> http://www.matronics.com/other
David; Tapping gently is the key word, otherwise you may (will) stretch
the skin, resulting in localized oil canning and a much more difficult fix.
I, of course, have no first hand knowledge of this phenomenon.
HCRV6
Subject: | Re: RV-List:Hartzell propeller numbers |
Hello fellow RV 'ers, I am working on the fuselage of a RV-6A and I have
not yet purchased a propeller for my 0-320 engine. I am leaning toward
the fixed pitch metal Sensenich , but of course I would love to find a
C/S for a good price. The problem that I could use some help with is the
interpreting of Hartzells model numbers. For example, HC-C3YR-2UF with a
serial number of CK3482 and Blades numbered FC7451. Any help in
explaining Hartzells I.D. system would be appreicated. David Ahrens
It would be me, Carey Mills in Daleville, AL.
Here's a new one for the list.
Anyone have a problem in their hangers with mice? If yes, how do you deal
with them? Several people at my airport have had problems and I'm trying
to figure a way to keep the little rodents out of my airplane.
Any suggestions?
Bill Pagan
N565BW
"The original RV-8A builders page on the web"
http://www.geocities.com/CapeCanaveral/Launchpad/9749/william.html
In a message dated 10/29/99 8:55:15 AM Pacific Daylight Time,
jvanderzyde(at)gtn.net writes:
<< I am building an RV6A, working on the fuselage skeleton. Do the flanges
of the F-611 bulkhead face forward or aft? I have seen information both ways.
On mine the F-611A flanges face forward and the F-611B flanges face aft.
-GV
Subject: | Re: Propane Engine Preheater |
I'm a proponent of electric oil pan or Tanis-type heaters. I live in
northern Wisconsin and it gets seriously cold. I have an Easy-Heat system
in my Citabria. When it gets below 30 degrees, I wrap up the cowling in a
big moving blanket and leave it plugged in all the time (in the hangar). I
have measured the free air temp above the cylinders at 50 degrees when the
OAT has been near zero. Cheap and works great.
Doug Weiler
Hudson, WI
Thanks!
I forgot to mention that the trophy was presented to Jon by Prince Philip
the Queens husband.
Eustace Bowhay
>................................................ but of course I would
>love to find a
Forget it. I hunted for a good used CS prop to no avail. Finally, I asked
a used prop dealer what would work for a RV6 and he said the market for
them is so strong that a new one from Van's is a much better deal.
(No one goes there any more, it is too crowded.)
hal
Hello John Vanderzyde,
If I read your question correctly:
The fuse bulkhead "f-611" you refer to is made up of two parts called out as
f-611/A and f-611/B on the top center of DWG 28. the resulting assembled
bulkhead has flanges facing forward and aft.
the F-611/A (The larger of the two) Faces forward in my RV6A fuse. It took a
bit of finessing to get the flanges to fit so that the skins fit smoothly
over them.
This area sure is fun to rivet!
happy fitting.
jim - Kelowna BC. fiting fuse top skins.
flanges forward. I suggest to new builders the alternative of placing flanges
>Gary Zilik
>> John Vanderzyde
In a message dated 10/29/99 7:26:05 PM Pacific Daylight Time,
daviddla(at)juno.com writes:
<< The problem that I could use some help with is the
serial number of CK3482 and Blades numbered FC7451. >>
HC is Hartzell Controllable, C is standard hub, 3 is three blades, Y is the
blade shank, R is 4.75" bolt circle of six 1/2" bolts for Lyc, 2 is
feathering oil pressure to lower pitch, U is the spring assy in the cylinder
and F is large pitch change fork, knob.
This is from pages 216 thru 218 in the Hartzell Manual 115N Dated 01/99.
-GV
From: | "Rohan Lloyd" <rlloyd(at)northnet.com.au> |
Lister's, with all this talk of HVLP, could some one give me a site or quick
explanation as too what are the mechanical differences between the 2 sorts
of guns??
RV-6
Half Winged (OZ)
Rohan
October 23, 1999 - October 29, 1999
RV-Archive.digest.vol-he
