RV-Archive.digest.vol-hv
January 25, 2000 - January 30, 2000
      >      I need some advice about matching a IImorrow (UPS Aviation
      >Technologies)
      >SL-60 GPS/Com with a Skyforce Tracker  moving map.  I like the features of
      >the SL-60 GPS/Com, especially nominating com frequencies on your route, but
      >the Apollo 360 Map display from IImorrow is primitive compared to the
      >detail
      >available with the Skyforce Tracker moving map.  Skyforce promotional
      >material says that the Tracker maps are designed to interface with existing
      >Loran and GPS receivers.
      >      I need to finalize my panel now.  Anyone know if this will work well
      >or
      >if it will be a mistake because the two units won't speak the same language
      >well enough to cooperate with each other?  I'm ignorant of whether their
      >are
      >industry standards which make this as simple and viable as using a brand A
      >stereo receiver with brand B speakers or not.  I don't want to tackle
      >making
      >this work if it won't be a nice setup in the end.
      >      I'm pretty good at following directions and hooking wires up but I
      >don't
      >understand much about how these things work.  I really hope this can work.
      >Is this a doable idea that will work properly or an experiment that will
      >likely not work very well?
      >      All responses appreciated.
      >Thanks,
      >Dale Wotring
      >RV-6A working on panel (and still don't have a final equipment list)
      >Vancouver, WA
Date: Jan 25, 2000
Subject: Re: common radio freq.
>In this area (Southeast), on 1st call to Approach or Tower the >controller will ask for 'class' of experimental. The class tells the >controller the cruise speed range of the a/c, with rv's being class B. >Controllers are not very consistent with this, but a friend who's a >controller has told me it's 'official.' Is this not a national >practice? Your friend is correct, it is 'official'. Asking the 'class' of experimental is not national practice, but then nothing is in the FAA. The various regions within the FAA work from the same basic rulebook, but each region likes validate its uniqueness by making up local supplements. I suspect the sum of the local supplements from all the regions probably accounts for more paper than the national orders they supplement. Even when the same basic order is used, each region develops a local interpretation of how that order should be applied. You've probably heard of the different experiences homebuilders have had getting their aircraft certified from region to region. It works the same way in air traffic. We are just barely one FAA; we are not standardized. In any case, when calling for VFR flight following you can call your type whatever you like to call it. If the controller is unfamiliar with the performance characteristics of that type, he may ask your cruise speed or for other details, or may ask the speed class (HXA, HXB, HXC). When filing IFR, use the correct identifier, which will be HXB for any of the RVs (100 to 200 kts cruise). You can put experimental, or RV-(whatever), or both in remarks if you like. I know using the HXA/B/C for the type doesn't sit well with a lot of homebuilders, but the fact is that there isn't enough room in the book for each of us to have a unique type identifier. You can't have a Vans RV unless you bought one they built at Vans - and at least for now even then it would be an experimental (HXB). Regardless of where you bought the parts, you are the manufacturer of your aircraft and it is one of a kind - and experimental. As a controller, HXB as a type and RV-3/4/6/8/9 in remarks tells me everything I could ever need to know to work your flight. I might ask for more details though, if I'm not busy, just 'cause I'm nosey. - Mike RV-6A(to fuselage)/Grumpy old controller ________________________________________________________________________________
Date: Jan 25, 2000
Subject: Garmin e-map
Here is some info on the emap: http://www.garmin.com/eMap.html -Bill Von Dane - Colorado Springs, CO RV-8A N912V res., wink kit maybe this week? http://vondane.tripod.com -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Doug Rozendaal Sent: January 24, 2000 9:42 PM Subject: RV-List: Garmin e-map I went to the MSP boat show Sunday. The boat gadget peddlers were selling Garmin's latest and greatest, the "e-map"....... ________________________________________________________________________________
Date: Jan 25, 2000
Subject: Re: Source for fuse blocks that take auto fuses
Brian Denk, Saw your post on the fuse block install. Talk me through your ideas on the location as to accessibility while in flight. I have heard "elec. Bob's" ideas and am still deciding on my location for the two blocks I got from B&C. Am leaning toward building a swing down panel mounted vertically below the right console (F-865). ________________________________________________________________________________
Date: Jan 25, 2000
Joe Waltz wrote: > > > Brian Denk, > > Saw your post on the fuse block install. Talk me through your ideas on > the location as to accessibility while in flight. I have heard "elec. > Bob's" ideas and am still deciding on my location for the two blocks I > got from B&C. Am leaning toward building a swing down panel mounted > vertically below the right console (F-865). Okay, I'm going to play the part of troll here. Why do the fuses have to be accessible in flight? Sam Buchanan (RV-6, fuses tucked behind panel) "The RV Journal" http://home.hiwaay.net/~sbuc/journal ________________________________________________________________________________
Date: Jan 25, 2000
>Brian Denk, > >Saw your post on the fuse block install. Talk me through your ideas on >the location as to accessibility while in flight. I have heard "elec. >Bob's" ideas and am still deciding on my location for the two blocks I >got from B&C. Am leaning toward building a swing down panel mounted >vertically below the right console (F-865). > Joe, My fuse blocks are not accessible during flight, nor are they meant to be. The time for troubleshooting an electrical problem is while ON THE GROUND, not while flying the airplane. I do not operate my airplane in any conditions where an electrical problem, up to and including total failure, will compromise safety of flight. (Day VFR) Placing the fuse blocks by the 865 sounds like a great location, if they will fit there. I wanted to keep the wiring to the panel stuff as short as practical, so that's why I put the blocks where I did. Like anything of this nature, if it's buried away out of reach, it will fail. On the other hand, if it's made to be easily accessed, you'll never have a problem with it. Such is life! Have fun with your decision. Place them where they best suit your needs. Brian Denk RV8 N94BD ________________________________________________________________________________
Subject: Source for fuse blocks that take auto fuses
Date: Jan 25, 2000
Ever have a fuse blow at night? I have...and it was the fuse to the panel lights in a Cherokee 235... Bob Japundza -----Original Message----- From: Sam Buchanan [mailto:sbuc(at)hiwaay.net] Sent: Tuesday, January 25, 2000 10:36 AM Subject: Re: RV-List: Source for fuse blocks that take auto fuses Okay, I'm going to play the part of troll here. Why do the fuses have to be accessible in flight? Sam Buchanan (RV-6, fuses tucked behind panel) "The RV Journal" http://home.hiwaay.net/~sbuc/journal ________________________________________________________________________________
Date: Jan 25, 2000
Subject: Re: GPS and Map Compatibility
Dale, No answers here, just options. How about the MX20 from UPS? More pricey (~$5,000) than the Syforce but totally compatable with some neat features not found on the Skyforce, especially if linked with the SL 70 transponder. Check out the UPS website: www.upsat.com How about a dual GPS setup? Use the SL60 by itself and the Skyforce version with the built in GPS. Again more pricey but compatability insured plus redundancy. Talked with the UPS folks regaurding IFR capabilities and WAAS the other day. Today, if you want a legal IFR panel you need VOR's. After WAAS you won't. When will WAAS be up and running? The FAA has had a hard time getting it fully functional but our present adminstrator has recently promised 09/00. In order to be IFR after that (GPS only) you will need a WAAS compatable IFR GPS that is TSO'd for GPS approaches (C129 A1A). The good news? With a WAAS compat. GPS and peripherals (CDI/GS) you will have Cat 1 ILS type capability wherever the feds construct an approach; potentially everywhere. Of course this takes time to certify all the possible approaches. My desires: GPS only IFR capability. My solution: UPS GX65 now. This unit isn't C129A1A now (it's C129A2 for enroute and terminal IFR ops) so VFR only. UPS is developing their new WAAS GPS engine and should be able to upgrade all of the GX series GPS's but not the SL line. When able, I'll return the GX65 for the upgrade and get IFR capability. UPS said that the upgrade for the GX60 & GX65 will not be much different in cost so since I don't have panel mounted VOR's (not IFR capable) the GX60 (approach certified) would be wasted money since it will need the upgrade too. I'm leaving room for the required CDI but will hold off till needed. Another plus for UPS. They deal with Van so you can purchase through him. Van's doesn't stock so lead time could be awhile. Garmin won't deal with Van. ________________________________________________________________________________
Date: Jan 25, 2000
Subject: Re: Proseal measuring balance
Here is a simplistic way. Get a stick between 12 and 20 inches long. Tape, nail or glue a 3 inch pad on each end. Get eleven bolts or nuts or some such of that weigh the same. Put ten on one pad and the last one on the other pad. Now balance the stick on something so that it sits level with the world. Many ways to do this. Now take the bolts or nuts off the pads. Replace the one bolt with the black stuff and the ten bolts with the white stuff. 10:1 Me??? I use a very accurate balance beam at the office that I mix ink on. Cecil Hatfield Thousand Oaks, CA >>Can someone tell me where I can find a picture of the 10:1 balance to >>weigh out the proseal? >> >>Doug Gray ________________________________________________________________________________
Subject: fuse blocks
Date: Jan 25, 2000
Listers, Since we're on the topic, are there any manufacturers producing fuseblocks similar to what Electric Bob sells that use the newer "mini" fuses, which are about half the size of the regular blade-type fuses? I Bob Japundza ________________________________________________________________________________
Date: Jan 25, 2000
Subject: Re: RV-List Digest: 01/24/00
Please remove my name from ALL lists. ________________________________________________________________________________
Date: Jan 25, 2000
Subject: team rocket
Does anyone have team rocket web or e-mail address. Thanks Stan Mehrhoff, N188sm RV-8, mounting engine, missouri ________________________________________________________________________________
Date: Jan 25, 2000
Subject: RE: Strobe Power Supplies...
I found this Able power supply for $149... What do you all think? http://store.yahoo.com/swps/abshowme21st.html -Bill Von Dane - Colorado Springs, CO RV-8A N912V res., waiting for wings, getting the shakes... http://vondane.tripod.com -----Original Message----- From: Bill VonDane [mailto:bvondane(at)atmel.com] Sent: January 25, 2000 9:15 AM Subject: Strobe Power Supplies... Has anyone found a single power supply to power two Whelen wingtip strobes that doesn't cost $350? I have been looking, and for aviation strobes, the PS's are rated with joules, and the automotive are rated in watts... What's the correlation? can I use an automotive PS? Thanks for the help... -Bill Von Dane - Colorado Springs, CO RV-8A N912V res., wing kit maybe this week? I'm having withdrawals... http://vondane.tripod.com ________________________________________________________________________________
Date: Jan 25, 2000
Date: Jan 25, 2000
Bob asked: >Ever have a fuse blow at night? In an airplane, no. A few times in cars but the maintenance was pathetic in each case. Were you able to change yours in flight without rolling inverted? hal :-) ________________________________________________________________________________
Date: Jan 25, 2000
I still don't see why people don't choose the solidstate protection devices over fuses and circuit breakers for most of their circuits. Greg -----Original Message----- From: Joe Waltz <TRAASHMAN(at)webtv.net> Date: Tuesday, January 25, 2000 8:47 AM Subject: Re: RV-List: Source for fuse blocks that take auto fuses > >Brian Denk, > >Saw your post on the fuse block install. Talk me through your ideas on >the location as to accessibility while in flight. I have heard "elec. >Bob's" ideas and am still deciding on my location for the two blocks I >got from B&C. Am leaning toward building a swing down panel mounted >vertically below the right console (F-865). > > ________________________________________________________________________________
Date: Jan 25, 2000
Subject: Re: team rocket
In a message dated 1/25/2000 10:14:20 AM Central Standard Time, N188sm(at)cs.com writes: << Does anyone have team rocket web or e-mail address. Thanks Stan Mehrhoff, N188sm RV-8, mounting engine, missouri >> www.teamrocketaircraft.com mark Fredricks mlfred(at)aol.com Scott Brown F1rocket(at)aol.com I would be glad to answer questions from a builders point of few as i bought their first kit. Chris WIlcox F-1 Rocket ________________________________________________________________________________
Date: Jan 25, 2000
Sam - This is easy - After the shorted circuit in the stereo blows the correct sized fuse in flight. You can replace it with the next, and then next higher rated fuses. The subsequent fire keeps you occupied so you no longer worry about the lack of music... Circuit Breakers come with this feature as a built-in. Jeff. On Tue, 25 Jan 2000, Sam Buchanan wrote: > Why do the fuses have to be accessible in flight? > > Sam Buchanan (RV-6, fuses tucked behind panel) > "The RV Journal" http://home.hiwaay.net/~sbuc/journal > > > > > ________________________________________________________________________________
Date: Jan 25, 2000
Jim: Goto www.aeroelectric.com. I would buy the $35.00 book, then I think Bob sells everthing you will need. Don Jordan ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com ****************************************************************************** > > >Anyone know of a good place to pick up a fuse block that will take >auto fuses ( >the knife variety ). > >I have decided to forgo the circuit breaker idea and just put in auto >fuses. > >Thanks, > >- Jim Andrews >RV-8A QB ( wings ) >N89JA ( reserved ) ________________________________________________________________________________
Date: Jan 25, 2000
So that is why there is mandatory flash light for night flying. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) -----Original Message----- From: Japundza, Bob <bjapundza(at)dowagro.com> Date: Tuesday, January 25, 2000 10:48 AM Subject: RE: RV-List: Source for fuse blocks that take auto fuses > >Ever have a fuse blow at night? I have...and it was the fuse to the panel >lights in a Cherokee 235... > >Bob Japundza > >-----Original Message----- >From: Sam Buchanan [mailto:sbuc(at)hiwaay.net] >Sent: Tuesday, January 25, 2000 10:36 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Source for fuse blocks that take auto fuses > > >Okay, I'm going to play the part of troll here. > >Why do the fuses have to be accessible in flight? > >Sam Buchanan (RV-6, fuses tucked behind panel) >"The RV Journal" http://home.hiwaay.net/~sbuc/journal > > ________________________________________________________________________________
Date: Jan 25, 2000
Buchanan a troll? Sam, your question is te thread I want to run. ________________________________________________________________________________
Date: Jan 25, 2000
Subject: parker 37 degree rolo-flair question
my new flairing tool from Avery does the same thing mentioned by russ nichols, though maybe not as severe. would any of you owning this tool look through the hole formed by the tool dies that hold the tubing in place (with the tool closed), up at the flairing point and see if you notice a significant offset of the center of the tip of the flairing point? mine has a noticable offset that seems to be causing the flair to be out-of round. Is this normal? Thanks, Jim ________________________________________________________________________________
Date: Jan 25, 2000
I had smoke from the panel dimmer and had to shut off the panel lights and use a flash light as a student. I was also cleared to land and then the controller made me do a 360 on final for spacing because an airliner got to the field before me. If I had a circuit breaker on that old 63 Skyhawk, it would have popped again with more smoke. Some thing I didn't need, more smoke! As Bob Nuckols says, fly the plane, trouble shoot on the ground. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) -----Original Message----- From: Japundza, Bob <bjapundza(at)dowagro.com> Date: Tuesday, January 25, 2000 10:48 AM Subject: RE: RV-List: Source for fuse blocks that take auto fuses > >Ever have a fuse blow at night? I have...and it was the fuse to the panel >lights in a Cherokee 235... > >Bob Japundza > >-----Original Message----- >From: Sam Buchanan [mailto:sbuc(at)hiwaay.net] >Sent: Tuesday, January 25, 2000 10:36 AM >To: rv-list(at)matronics.com >Subject: Re: RV-List: Source for fuse blocks that take auto fuses > > >Okay, I'm going to play the part of troll here. > >Why do the fuses have to be accessible in flight? > >Sam Buchanan (RV-6, fuses tucked behind panel) >"The RV Journal" http://home.hiwaay.net/~sbuc/journal > > ________________________________________________________________________________
Date: Jan 25, 2000
Subject: New web site...
I just found this site today: http://www.kestrobes.com/ They sell strobes, power supplies, and a thingy called a Hot Box (a complete electrical system intended for use with an electric starter equipped engine). -Bill Von Dane - Colorado Springs, CO RV-8A N912V res., waiting for wings http://vondane.tripod.com ________________________________________________________________________________
Date: Jan 25, 2000
In a message dated 1/25/00 11:51:25 AM Eastern Standard Time, N188sm(at)cs.com writes: << Does anyone have team rocket web or e-mail address. Thanks Stan Mehrhoff, N188sm RV-8, mounting engine, missouri >> Website is www.teamrocketaircraft.com or you can email me at F1Rocket(at)aol.com. Scott ________________________________________________________________________________
Date: Jan 25, 2000
Good point Hal... >>Ever have a fuse blow at night? >In an airplane, no. A few times in cars but the maintenance was pathetic >in each case. >Were you able to change yours in flight without rolling inverted? Ever have a fire in the cockpit? The last two RV's I got to see up close had NO fire extinguishers!!! I have redundancy on all my key instruments planned. I also have a back up battery planned for all critical systems. Best way to avoid a disaster is to plan on having one :-) - Jim RV-8A QB ( wings ) N89JA ( reserved ) ________________________________________________________________________________
Date: Jan 25, 2000
This is another advantage of the solidstate protection devices. They won't reset unless the short is removed so you don't have to worry about welded contacts(circuit breaker) or inflight fires from putting in a fuse that is over rated by accident. Removing the short and cycle the power(switch off) is all you have to do. So, if a filement on a lamp momentarily burnes out and goes into a high enough current to blow the fuse and then opens, the solidstate device can be reset by turning the panel lights switch off then back on and it's reset. You don't have to fumble in the dark for a circuit breaker or try to find a fuse.... Greg -----Original Message----- From: Jeff Hays <jshays(at)interaccess.com> Date: Tuesday, January 25, 2000 11:04 AM Subject: Re: RV-List: Source for fuse blocks that take auto fuses > > >Sam - > >This is easy - After the shorted circuit in the stereo blows the >correct sized fuse in flight. You can replace it with the next, and then >next higher rated fuses. The subsequent fire keeps you occupied so >you no longer worry about the lack of music... > >Circuit Breakers come with this feature as a built-in. > >Jeff. > >On Tue, 25 Jan 2000, Sam Buchanan wrote: > >> Why do the fuses have to be accessible in flight? >> >> Sam Buchanan (RV-6, fuses tucked behind panel) >> "The RV Journal" http://home.hiwaay.net/~sbuc/journal >> >> >> >> >> > > ________________________________________________________________________________
Subject: Wiring Wig-Wag
Date: Jan 25, 2000
I have the Gall's Wig-Wag flasher for my two wing tip lights. I need help in wiring. The schematic shows one wire to each light. OK. The power and Grd wire. OK. Then there are two wires that go to the "wiring harness" of the auto this thing is supposed to be installed in. Do I need these two wires connected, and if so, where do they go? Thanks, Rick Caldwell RV-6 N136RC 2.3 hrs Melbourne, FL ________________________________________________________________________________
Date: Jan 25, 2000
Subject: Re: wing walk doubler-help-rv6
It butts up to the aft spar flange in my installation. Seemed to work that way. ________________________________________________________________________________
Subject: Re: parker 37 degree rolo-flair question
Date: Jan 25, 2000
It is designed that way to wipe a flare as it rotates instead of pushing straight down. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) -----Original Message----- From: Jim Lane <jlane(at)CROSSCOUNTYBANK.COM> Date: Tuesday, January 25, 2000 12:09 PM Subject: RV-List: parker 37 degree rolo-flair question > >my new flairing tool from Avery does the same thing mentioned by russ nichols, though maybe not as severe. would any of you owning this tool look through the hole formed by the tool dies that hold the tubing in place (with the tool closed), up at the flairing point and see if you notice a significant offset of the center of the tip of the flairing point? mine has a noticable offset that seems to be causing the flair to be out-of round. Is this normal? Thanks, Jim > > ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Date: Jan 25, 2000
My flairing tool from Avery also displays the offset. I have always assumed it was part of the design. The tool produces excellent flairs, limited only by my abilities. Dennis Persyk 6A finishing kit Hampshire, IL C38 -----Original Message----- From: Jim Lane <jlane(at)CROSSCOUNTYBANK.COM> Date: Tuesday, January 25, 2000 11:00 AM Subject: RV-List: parker 37 degree rolo-flair question > >my new flairing tool from Avery does the same thing mentioned by russ nichols, though maybe not as severe. would any of you owning this tool look through the hole formed by the tool dies that hold the tubing in place (with the tool closed), up at the flairing point and see if you notice a significant offset of the center of the tip of the flairing point? mine has a noticable offset that seems to be causing the flair to be out-of round. Is this normal? Thanks, Jim > > ________________________________________________________________________________
Date: Jan 25, 2000
Subject: Looking for RV-8 under construction
I have a friend who is itching to build an 8A. If there is anyone in the Chicagoland area who is building an 8/8a and wouldn't mind a visit, please contact me directly, so I can push him over the edge. Don Mack RV-6A Finishing(Canopy) donmack(at)flash.net http://www.flash.net/~donmack ________________________________________________________________________________
From: "Michael Robertson" <mrobert569(at)hotmail.com>
Date: Jan 25, 2000
Jim, On the roto-flair the point is supposed to float somewhat in order to find the center of the tube as it tightens. It sounds like yours may be bound up. Mike Robertson RV-8A QB Panel is DONE!!! Finally >From: "Jim Lane" <jlane(at)CROSSCOUNTYBANK.COM> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: parker 37 degree rolo-flair question >Date: Tue, 25 Jan 2000 10:59:04 -0600 > > >my new flairing tool from Avery does the same thing mentioned by russ >nichols, though maybe not as severe. would any of you owning this tool look >through the hole formed by the tool dies that hold the tubing in place >(with the tool closed), up at the flairing point and see if you notice a >significant offset of the center of the tip of the flairing point? mine has >a noticable offset that seems to be causing the flair to be out-of round. >Is this normal? Thanks, Jim > > ________________________________________________________________________________
Date: Jan 25, 2000
I used a wiring kit for a kit car last year from a company called Painless Wiring. It had an ATC type fuse box with all connections in the box pre wired for automotive applications. You may be able to get the box from them and make your own connections. I found a race car switch/fuse panel that I considered using in my Kitfox but decided on a Hot Box that I got from Skystar instead. I have seen it in Aircraft Spruce or Lockwood's catalog. It also uses automotive (ATC) fuses but may not have the capabilities for the more complex RV electrical system. It works fine in my Night/VFR Kitfox. Even thought I can reach it while flying I don't think I would attempt to change one in flight. Larry Gagnon Kitfox Model IV/912 N102LG RV-6 Wings N6LG (reserved) ________________________________________________________________________________
Subject: Re: New web site..(strobes)
Date: Jan 25, 2000
Good tip Bill...thx I sent an e-mail to this company and asked for some technical info regarding output in joules or watts. I got a reply within a very short time so I am pasting it here for all to view. Rob Baxter Sarnia Ont. RV-8 wing waiting =================snip============= In a message dated 1/25/00 1:40:23 PM Eastern Standard Time, robbax(at)sympatico.ca writes: << I'd like to compare apples to apples (ie: whelan and or aeroflash). Your prices are certainly very good. >> Hi Rob, Thanks for the inquiry. When comparing the strobes you mentioned there are of course different models but generally our drivers produce a flash that is as bright as the GA strobes. I have an Aeroflash dual unit that I purchased so that I could compare. Our Dual drivers weigh 10 ounces, draw 2 Amps of power @ 14 volts, and flash at about 14 Joules. This Aeroflash driver weighs 21.5 ounces, draws 4 Amps of power, and has an energy of 11.6 Joules. Having said that, I still think the best way to see if you like a product is to try it. That is why I offer a satisfaction or your money back policy. You buy it and if you aren't satisfied send it back and we will refund your money. If you checked out our website you can see we do not offer Red & Green Nav lights, but our drivers will fire the strobe bulbs on all other brands of strobe heads. I hope this answers your questions, if not please feel free to contact me. Dick Kuntzleman, President Kuntzleman Electronics, Inc www.KEstrobes.com ============================unsnip============================ ----- Original Message ----- From: "Bill VonDane" <bvondane(at)atmel.com> Sent: Tuesday, January 25, 2000 11:49 AM Subject: RV-List: New web site... > > I just found this site today: http://www.kestrobes.com/ > > They sell strobes, power supplies, and a thingy called a Hot Box (a complete > electrical system intended for use with an electric starter equipped > engine). > > -Bill Von Dane - Colorado Springs, CO > RV-8A N912V res., waiting for wings > http://vondane.tripod.com > > ________________________________________________________________________________
Date: Jan 25, 2000
Subject: radio freq/flight plans/call signs
I have been having an off-list discussion with David Faile( mcfii, tech counselor, us flight instr. of the year...). He strongly recommends we NOT use designated a/c mfg freqs. for air to air conversations. 122.75 is set aside for this and 122.85 for private airports. He also pointed out that "experimental" is only required on initial contact with the tower and can be dropped afterwards for the last three (if you have enough) digits/letters of your call sign. At non-towered airports he suggests using a/c description(experimental,low wing, white) rather than call signs. Flight plans use a/c codes: These are the homebuilt types. When ATC asks what type? These are the designations for homebuilts HXA Speed 100 Knots or less HXB Speed over 100 Knots but less than 200 Knots HXC Speed 200 knots and higher Most RV's would be Hotel Xray Bravo. equipment codes follow, such as /U ( x/p mode C, no DME or VOR). I thought listers might have forgotten some of this as I have. Kevin do not archive ________________________________________________________________________________
Subject: elevator horns bolt
Date: Jan 25, 2000
If you're willing to pay up front, I'd suggest getting the bulk assortments of bolts, nuts and washers from your favorite mail order house. I used A/C Spruce but I'm sure a dozen folks will tell you a dozen different places that are absolutely the cheapest. Every year at SnF & Osh I'd pick up small packs of hardware, but still always seemed to be missing something. Oh yeah, it gets worse as you progress. This is one place where you can buy peace of mind. YMMV. Regards, Greg Young - Houston (DWH) RV-6 N6GY (reserved) 90%done, 90% to go "Always do right- this will gratify some and astonish the rest." - Mark Twain (1835-1910) > > Listers > The 1/4" AN4-12A bolt that ties both elevator horns through the bearing is > too short. Looks like I will require an AN4-14A to get the required thread > clearances. Not a huge deal except I don't have one and must order one and > wait 3 or 4 days. > Just wondering if others encountered this. Is this similar to all the > callouts that suggests an AD426 3 rivet when 3.5's seem to be the > standard. > The plans allow for up to 3 AN960-416 washers per side to fill any gap. > Looks like I will need to use 2 per side (one is also called for > on the nut > end of the bolt). My "bag of surprises" hardware kit from Van > gave me only 2 > AN960-416 (1/4" washers). I would pay more money to have all the required > hardware in my kit. I have to order AN hardware by phone or > e-mail as I have > no local supply and then wait for "widgets". > I'm waiting for wings (shipping Jan 31) and I'm just about out of > things to > do so I'm sniveling. I think I'll go fly the Aerobat because it will > actually climb at 500 fpm in the dead of winter. ________________________________________________________________________________
Subject: Baffle trim
Date: Jan 24, 2000
Thanks to whomever it was who suggested a few days ago on the list to use blobs of clay to determine where to make the final 1/2" trim on the baffles - it worked well. Alex Peterson Maple Grove, MN 6A ________________________________________________________________________________
Date: Jan 25, 2000
-------------original message------------ I have the Gall's Wig-Wag flasher for my two wing tip lights. I need help in wiring. The schematic shows one wire to each light. OK. The power and Grd wire. OK. Then there are two wires that go to the "wiring harness" of the auto this thing is supposed to be installed in. Do I need these two wires connected, and if so, where do they go? ---------------snipped--------------- If you have the FS-025, the wiring diagram indicates that the unit goes between the headlight power switch and the headlights. Just connect those 2 wires to power and it will wig and wag the power between the 2 lights. I removed the circuit board from the box it came in that includes a fuse and switch, since I have my own fuse and switch on the inst. panel. Dave Biddle RV6A - finishing canopy, instrument panel stuff Phoenix AZ. ________________________________________________________________________________
Date: Jan 25, 2000
>>Can someone tell me where I can find a picture of the 10:1 balance to > >>weigh out the proseal? > >> > >>Doug Gray HI Doug Just my two cents worth on the subject. Here is what I did but don't tell every one Ha!ha! I mixed the whole content of both cans of pro seal, removed what I needed and put the rest in the ''freezer''. You can keep it there for about 4 weeks and it will not set on you. Just take what you need at a time out of the can and let it sit where it's warm for 3 to 4 minutes and use as per normal. Hope this helps. Alain Nantel(at)hotmail.com RV-6 Still installing systems. ________________________________________________________________________________
Subject: BAFFLE TEMPLATES
Date: Jan 25, 2000
Does anyone have a template available for the cutouts around the valve covers for a 200hp IO-360 angle valve engine? I have a fiberglass plenum chamber from Sam James that I only want to cut once! Ed Cole RV6A ________________________________________________________________________________
Date: Jan 25, 2000
Subject: YOU ARE MY FRIEND AND I AM HONORED!
I guess this is RV related as you ....................... YOU ARE MY FRIEND AND I AM HONORED! What a great way to teach a lesson! Make sure everyone reads to the bottom. For my friends ... There once was a little boy who had a bad temper. His father gave him a bag of nails and told him that every time he lost his temper, he must hammer a nail into the back of the fence. The first day the boy had driven 37 nails into the fence. Over the next few weeks, as he learned to control his anger, the number of nails hammered daily gradually dwindled down. He discovered it was easier to hold his temper than to drive those nails into the fence.... Finally the day came when the boy didn't lose his temper at all. He told his father about it and the father suggested that the boy now pull out one nail for each day that he was able to hold his temper. The days passed and the young boy was finally able to tell his father that all the nails were gone. The father took his son by the hand and led him to the fence. He said, "You have done well, my son, but look at the holes in the fence. The fence will never be the same. When you say things in anger, they leave a scar just like this one. You can put a knife in a man and draw it out. It won't matter how many times you say I'm sorry, the wound is still there." A verbal wound is as bad as a physical one. Friends are a very rare jewel indeed. They make you smile and encourage you to succeed. They lend an ear, they share words of praise and they always want to open their hearts to us. It's National Friendship Week. Show your friends how much you care. Send this to everyone you consider a FRIEND, even if it means sending it back to the person who sent it to you. If it comes back to you, then you'll know you have a circle of friends. YOU ARE MY FRIEND AND I AM HONORED! Now send this to every friend you have!! And to your family. This was sent to me by a friend, and is now passed on to YOU Please forgive me if I have ever left a hole in your fence. -- Pursuant to US Code, Title 47, Chapter 5, Subchapter II, '227, any and all nonsolicited commercial E-mail sent to this address is subject to a download and archival fee in the amount of $500 US. E-mailing denotes acceptance of these terms. ________________________________________________________________________________
Date: Jan 25, 2000
blow at night, wrote: > >It was an enlightening experience...I had to rob the pitot heat fuse to >replace the panel lights fuse. Luckily, no night aerobatics for me that >time, but it got my heart rate up for a brief moment while I figured out >what was happening. But, if the fuses were under the panel, I would have >had to finish the flight with a flashlight in my mouth. A swing-out fuse >panel is OK as long as you can see it/reach it during flight. > >Bob Japundza > The way I look at the world you are drawing the wrong lesson from this experience. What if you had a real short that took out the panel lights? Having the fuse accessible in flight wouldn't help at all. All it would do is let you make some more smoke. If panel lights is a required system, you need a backup. I plan on having panel lights on one fuse, and little flood lights (LEDs actually), on a separate fuse, powered from the emergency bus. If the panel lights die, I'll turn on the flood lights, and sort it out after I land. The same thing goes for any critical system (a system that is required for safe flight and landing). Landing and taxi lights on separate fuses, etc. If the failure will affect your ability to safely complete the flight, have a backup plan. Hoping you can change a fuse and bring a system back on line is not a great back up plan. Just my two cents worth. Kevin Horton RV-8 (working on landing gear boxes) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
Date: Jan 25, 2000
From: Charlie and Tupper England <cengland(at)netdoor.com>
Cy Galley wrote: > > > I had smoke from the panel dimmer and had to shut off the panel lights and > use a flash light as a student. I was also cleared to land and then the > controller made me do a 360 on final for spacing because an airliner got to > the field before me. > snip One of the first things my instructor taught me is that the controller works for me. With smoke in my cockpit, the airliner would have waited. What say you, feds? Charlie flying -4 ________________________________________________________________________________
Date: Jan 25, 2000
Subject: Voltage Regulator
Per a call-out in Electric Bob's book, I went to the local auto parts store today and bought a VR166 voltage regulator. This model isn't adjustable, but at $9.50, it was $25+ less expensive than the ones sold through aviation parts houses.. Thought somebody might wanna save a few $... As an aside, I got into an interesting discussion with the parts manager at the store. When I mentioned that the regulator was for an airplane he said that he didn't understand how the electronics on an airplane worked because they are not grounded. I explained that all of he electrical stuff is grounded to a central point, so grounding isn't a problem. He said, yeah, but when you're up in the air, nothing touches the ground, so you're not grounded... I tried to explain that that isn't how it works, but to no avail. I even tried to point out that cars are electrically isolated, because those tire things are pretty good insulators. He didn't buy that either... Kyle Boatright RV-6 - Reducing the parts count. ________________________________________________________________________________
Date: Jan 25, 2000
Subject: Re: Prop Balancing/Hinge Breakage
pcondon(at)csc.com wrote: > > > Relative to this thread....... is there any data to support more or less hinge > damage on the rv-4 vs. the rv6 ?? The only reason I suggest this is the RV-4 > cowl has tighter radius and less expance and hence less movement then the rv-6 ( > theory at this point). For the same fiberglass thickness my rv-4 cowl seems to > behave differently than my hanger mates' rv-6 cowl in terms of vibration & > hinge breakage....Any real world testimonials?? > I think this is in the archives, but here goes: (purchased) -4, wood prop, static balance only, Landoll solid steel flywheel weight. No probs until @ ~300hrs the snubber under the starter which holds the cowling 'chin' down in flight broke. Both spinner hinges followed, along with the first couple of eyelets of the side hinges and 1 or 2 at the top of the firewall. Also minor problem with fiberglas cracking around the inlets & rivets in spinner hinge. Reinforced inlets with formed al & upped rivet size in spinner hinges to 1/8", no further probs. Charlie ________________________________________________________________________________
Subject: Looking for RV-8 builder in Chicago area
Date: Jan 25, 2000
I am in Chicago area and have a friend who is leaning hard towards starting an RV-8A. If you are in Chicagoland, working on an 8, and don't mind a visitor, please reply directly to me. Maybe you can help push him over the edge. Don Mack RV-6A finishing kit donmack(at)flash.net http://www.flash.net/~donmack ________________________________________________________________________________
Date: Jan 25, 2000
Subject: RV-8 Canopy Mounting
Guys, Thought I would pass along a potential problem when mounting your RV-8 canopy. Well, not really the canopy, but the front windscreen. I mounted the front windscreen according to the instructions, glassed it up, and came back the next morning to check my work. As I looked at it much closer, I found that the front windscreen did not aerodynamically fair into the canopy near the bottom edges of the canopy/windscreen bow. It had a cavity too large to fill with microballons. It just didn't look right. It seemed to me that the front windscreen needed shims between the windscreen and the roll-over bar near the bottom to make a clean aerodynamic shape. I stripped the fiberglass off and redid the front windscreen over with shims. Much better now! I just wish I caught this the first time. Hope this helps someone. Joe RV-8 # 80125 ________________________________________________________________________________
Date: Jan 25, 2000
Subject: Smoke in cockpit - was: Source for fuse blocks that take auto
fuses > >With smoke in my cockpit, the airliner would have waited. Right on, Charlie! When I saw the first email on this thread I thought of one of my instructors. He said that when I have an emergency I should shout "Mayday". For me, smoke would constitute an emergency. I have seen it written in some printed form that we pilots are much too shy about declaring emergencies. It makes sense since we are usually culpable when one occurs. If a worn wire shorts, we are dinged for poor inspection or maintenance. It is as tho the poor old pilot is solely responsible for the safety of the flight! One airliner went around at SJC due to beverage cart out of control. I saw another go around a few weeks ago so they can do it. hal ________________________________________________________________________________
Subject: Empenage Kit
Date: Jan 25, 2000
Posting this for a friend in the Arlington, Wash. area. Has a completed empenage kit for a RV6, good workmanship and a full set of plans for the RV6 all for $500.00. Please send any reply direct to my address. Eustace Bowhay -- Blind Bay, B.C. Do not achieve. ________________________________________________________________________________
Date: Jan 25, 2000
Subject: Re: radio freq/flight plans/call signs
When I come into San Jose Intl, Bay Approach hands me off to a second approach controller. Sometimes it is nearly impossible to get a word in edgewise so I usually switch frequencies and say just "34V level 3000". No one has ever complained. I can't see how I can say, "Experimental RV6a, Hotel Xray Bravo, November seven hotel kilo" on first contact! What do real people say? hal >I have been having an off-list discussion with David Faile( mcfii, tech >counselor, us flight instr. of the year...). He strongly recommends we NOT >use designated a/c mfg freqs. for air to air conversations. 122.75 is set >aside for this and 122.85 for private airports. He also pointed out that >"experimental" is only required on initial contact with the tower and can >be dropped afterwards for the last three (if you have enough) >digits/letters of your call sign. At non-towered airports he suggests >using a/c description(experimental,low wing, white) rather than call signs. > Flight plans use a/c codes: >These are the homebuilt types. When ATC asks what type? >These are the designations for homebuilts >HXA Speed 100 Knots or less >HXB Speed over 100 Knots but less than 200 Knots >HXC Speed 200 knots and higher >Most RV's would be Hotel Xray Bravo. >equipment codes follow, such as /U ( x/p mode C, no DME or VOR). > >I thought listers might have forgotten some of this as I have. Kevin do >not archive > > ________________________________________________________________________________
Date: Jan 25, 2000
Subject: Checker Auto parts has automotive fuse blocks
Checker auto parts has automotive fuse blocks. Any auto parts store such as National Aircraft Parts Association (NAPA) that sell Buss fuses will carry or can order the fuse blocks Gary Zilik - Off to fly with Mike Seagar in the morning RV-6A N99PZ Pine, Colorado ________________________________________________________________________________
Date: Jan 25, 2000
Subject: WIREING HARNESS
NEED SOME GOOD INFO FOR WIRING RV 8. ANY GOOD BOOKS? ANY GOOD PRE FAB. WIRING HARNESS? THANKS FOR ANY INFO. MIKE ELROD RV8AQB GETTING TO MOUNT WINGS ________________________________________________________________________________
Date: Jan 25, 2000
Hal, When you get passed on to a busy freq, that is just what you have to do. Make sure you use the entire N number, though. On a handoff like that, the controller is expecting your call, even though he may not be giving you much time to talk. I am based in Cleveland and the Approach Controllers here have started their own little procedure during the handoffs from one App freq to another. They tell you to "monitor" the next freq, which means just that. The controller will call you when he is ready for you to do something. FYI. Gary Baker B-737 Driver RV-6 (Working on wings) N4GB (Reserved) Medina, OH > > When I come into San Jose Intl, Bay Approach hands me off to a second > approach controller. Sometimes it is nearly impossible to get a word in > edgewise so I usually switch frequencies and say just "34V level 3000". No > one has ever complained. I can't see how I can say, "Experimental RV6a, > Hotel Xray Bravo, November seven hotel kilo" on first contact! > > What do real people say? > > hal ________________________________________________________________________________
Date: Jan 25, 2000
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: Re: Voltage Regulator
>As an aside, I got into an interesting discussion with the parts manager at >the store. When I mentioned that the regulator was for an airplane he said >that he didn't understand how the electronics on an airplane worked because >they are not grounded. I explained that all of he electrical stuff is >grounded to a central point, so grounding isn't a problem. He said, yeah, >but when you're up in the air, nothing touches the ground, so you're not >grounded... I tried to explain that that isn't how it works, but to no avail. > I even tried to point out that cars are electrically isolated, because those >tire things are pretty good insulators. He didn't buy that either... Seems a quote from my hero is called for here: "There is a great difference between knowing a thing and understanding it. You can know a lot and not really understand anything." Charles F. Kettering Bob . . . http://www.aeroelectric.com ________________________________________________________________________________
Date: Jan 25, 2000
Subject: RE: Source for fuse blocks that take auto fuses
>The way I look at the world you are drawing the wrong lesson from >this experience. What if you had a real short that took out the >panel lights? Having the fuse accessible in flight wouldn't help at >all. All it would do is let you make some more smoke. > >If panel lights is a required system, you need a backup. I plan on >having panel lights on one fuse, and little flood lights (LEDs >actually), on a separate fuse, powered from the emergency bus. If >the panel lights die, I'll turn on the flood lights, and sort it out >after I land. The same thing goes for any critical system (a system >that is required for safe flight and landing). Landing and taxi >lights on separate fuses, etc. If the failure will affect your >ability to safely complete the flight, have a backup plan. Hoping >you can change a fuse and bring a system back on line is not a great >back up plan. You got an A+ on that exam! Bob . . . http://www.aeroelectric.com ________________________________________________________________________________
Date: Jan 25, 2000
Subject: Pressure Sensors
Listers, Do fuel and oil pressure remote sensors have a preferred orientation? I always see them installed with the pressure port down, but is this just for ease of installation, or is there something else at work here? Thanks, Kyle Boatright ________________________________________________________________________________
Date: Jan 25, 2000
>This is another advantage of the solidstate protection devices. They won't >reset unless the short is removed so you don't have to worry about welded >contacts(circuit breaker) or inflight fires from putting in a fuse that is >over rated by accident. . . . hazards that are more fiction than fact . . . > Removing the short and cycle the power(switch off) >is all you have to do. So, if a filement on a lamp momentarily burnes out >and goes into a high enough current to blow the fuse and then opens, When bulbs burn out, their current goes to ZERO . . . not higher. Transient shorts in a system are no more acceptable for continued flight than a solid short . . . why accomodate them with a self reseting breaker? >the solidstate device can be reset by turning the panel lights switch off then >back on and it's reset. You don't have to fumble in the dark for a circuit >breaker or try to find a fuse.... Certified aircraft systems are designed to "leave you fumbling in the dark" but modern, amateur built airplanes should be totally free of such posibilities by design. It's not hard to do. Bob . . . http://www.aeroelectric.com ________________________________________________________________________________
Date: Jan 25, 2000
> >So that is why there is mandatory flash light for night flying. > Because everybody knows that certified airplanes frequently go dark. If they didn't, the flying magazines would loose an important source of hair-raising tales to publish in the interest of "safety and education" . . . It just wouldn't do to design systems that always put you back on the ground without breaking a sweat. Bob . . . http://www.aeroelectric.com ________________________________________________________________________________
Date: Jan 26, 2000
>It was an enlightening experience...I had to rob the pitot heat fuse to >replace the panel lights fuse. Luckily, no night aerobatics for me that >time, but it got my heart rate up for a brief moment while I figured out >what was happening. But, if the fuses were under the panel, I would have >had to finish the flight with a flashlight in my mouth. A swing-out fuse >panel is OK as long as you can see it/reach it during flight. Pitot heater = 10A Panel lights = 5A or perhaps 3A? I recall an uncle that put a penny into the socket under an old threaded plug fuse in grandma's house and damned near set the house on fire. How about a gooseneck map light (optional in many Grummans for years and found on our website) - a single bulb wired to the e-bus. In normal ops it hovers right over the map in your lap. When main panel lighting goes down, it swivels to become a panel flood that you don't have to hold in your teeth. Bob . . . http://www.aeroelectric.com ________________________________________________________________________________
Date: Jan 26, 2000
Subject: Re: fuse blocks
> >Listers, > >Since we're on the topic, are there any manufacturers producing fuseblocks >similar to what Electric Bob sells that use the newer "mini" fuses, which >are about half the size of the regular blade-type fuses? I The mini-blade fuses are found in OEM fuseblock assemblies with harnesses fabricated right into the fuseholders. I've not seen any suited for individual, customized point to point wiring in airplanes. Bob . . . http://www.aeroelectric.com ________________________________________________________________________________
Date: Jan 26, 2000
In a message dated 1/25/00 6:03:10 PM Pacific Standard Time, KBoatri144(at)aol.com writes: << I even tried to point out that cars are electrically isolated, because those tire things are pretty good insulators. He didn't buy that either. >> They may be now, but I would have to measure them. They are certainly not low impedance paths to ground. I heard that tire compounds used to be heavily loaded with carbon black so that they would in fact conduct a charge to ground. Volume resistivity in ESD control measures x<1X10 5 ohms/sq as conductive, 1X10 5From: "J. Rion Bourgeois" <rion(at)worldnet.att.net>
Subject: RV-4 canopy latch
Date: Jan 25, 2000
I am at the decision point for my RV-4 canopy latch mechanism. I would like to use the standard latch mechanism in the plans, but it does not provide for a partially open position for ground operations. I have heard a rumor about a builder in the Seattle area who has designed a safety latch that allows use of the standard canopy latch and has a partially open position. Does anyone have his address and phone number or any suggested solutions? Thanx, Rion ________________________________________________________________________________
Date: Jan 26, 2000
Subject: Re: Looking for RV-8 builder in Chicago area
TO DON MACK Don i'm not in the chicago , but if you are in the indianapolis aera you are welcom to drop by. You can contact me at 317-862-2389 John marshall ________________________________________________________________________________
Date: Jan 26, 2000
Subject: Re: RV-8 Canopy Mounting
It seemed to me that the front windscreen needed shims between the windscreen and the roll-over bar near the > bottom to make a clean aerodynamic shape. Joe, I found the same thing while I was fitting the frame and van's said to use up to 1/2 inch shims, but they had never heard of this problem. Alan Kritzman hanging engine ________________________________________________________________________________
Subject: How many cylinders to connect to the primer?
Date: Jan 26, 2000
I am now turning my titanic intellect to the question of how to install a primer to the cylinders of my carburetor-equipped O-320. My present plan is to run the primer line from the primer port on my gascolator to an electric solenoid and then to the engine. I will turn on the electric fuel pump to pressurize the system and open the solenoid to let gas down the primer line(s). My problem: I don't have a clear idea of where to run the primer line(s) to. Tony B appears to state that it is common to run a primer line to just one cylinder. I would think that it would be better to squirt the gas into more than one. The first question is, therefore, is one cylinder enough? The second question is, if I should run that primer line to more than one cylinder, how do I split the 1/8 inch line into two or more separate lines? The third question is whether the copper priming line that Van's sells is OK for this use. Some of the experts around here tell me that I should use only aluminum line. The fourth question is whether the little primer lines should be covered with some sort of extra small diameter firesleeve, or it this just to cover the flexible lines? Steve Soule Huntington, Vermont RV-6A Snow at last! ________________________________________________________________________________
Date: Jan 26, 2000
-----Original Message----- From: Robert L. Nuckolls, III <nuckolls(at)aeroelectric.com> Date: Wednesday, January 26, 2000 12:36 AM Subject: Re: RV-List: Source for fuse blocks that take auto fuses > > >>This is another advantage of the solidstate protection devices. They won't >>reset unless the short is removed so you don't have to worry about welded >>contacts(circuit breaker) or inflight fires from putting in a fuse that is >>over rated by accident. > > . . . hazards that are more fiction than fact . . . what part are you saying is fiction? > >> Removing the short and cycle the power(switch off) >>is all you have to do. So, if a filement on a lamp momentarily burnes out >>and goes into a high enough current to blow the fuse and then opens, > > When bulbs burn out, their current goes to ZERO . . . not higher. > Transient shorts in a system are no more acceptable for continued > flight than a solid short . . . why accomodate them with a self > reseting breaker? Then why have I had a headlamp fuse blow in a car when the headlamp burned out? The answer is the filiment fell into the supports and conducted at a much higher current for a split second and took the fuse out, while also vaperizing itself AND THEN GOING TO ZERO. Also had this happen recently in the home when a floodlamp on a track light burned out and flipped the breaker. Reset the breaker and all but one lamp came on. Checked the lamp and sure enough you couldn't find ANY of the filiment in the lamp. Where did it go? Into vapor.... As the filiment fell against the conductive supports at a much lower resistance. And the solidstate devices I'm talking about don't AUTORESET, the circuit must manually be turned off by the pilot. I would never recommend having an 'autorest' circuit in any aircraft. Greg ________________________________________________________________________________
Date: Jan 26, 2000
What's an example of these 'solidstate devices' you keep refering to? Where can I see one? Who sells them? Who's using them? Larry Bowen RV-8 Tanks Larry(at)BowenAero.com http://BowenAero.com > And the solidstate devices I'm talking about don't AUTORESET, the circuit > must manually be turned off by the pilot. I would never > recommend having an > 'autorest' circuit in any aircraft. > > Greg ________________________________________________________________________________
Date: Jan 26, 2000
Here you go Larry... There are at least two RV's at my airport with these installed... http://www.controlvision.com/frame.cfm?link=avionics.htm -Bill Von Dane - Colorado Springs, CO RV-8A N912V res., waiting for wings http://vondane.tripod.com -----Original Message----- What's an example of these 'solidstate devices' you keep refering to? Where can I see one? Who sells them? Who's using them? Larry Bowen RV-8 Tanks Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Jan 26, 2000
Hi Kevin, I have no problem with you or some of your points, but my point with the failure experience is that if you make your fusepanel inaccessible in flight, you lose the option to do some immediate troubleshooting. Something in my case was drawing more current than the fuse was rated for, and I replaced the fuse in flight and everything worked fine afterwards. This may have been an anomaly, but the worst thing I thought would happen was the other fuse would blow. If I remember correctly, in that Cherokee the panel lights were on the same circuit as the nav lights, so the fuse I replaced was of the same value as the pitot heat. I made sure the values were the same. You are right about redundancy in your systems, and I have many electrical items on their own circuits. My fuseblocks are attached to the right side of the cockpit below and behind the panel where they are easily reachable, and I like them there so I can at least try to fix something in-flight within reason to continue on safely. Bob Japundza The way I look at the world you are drawing the wrong lesson from this experience. What if you had a real short that took out the panel lights? Having the fuse accessible in flight wouldn't help at all. All it would do is let you make some more smoke. If panel lights is a required system, you need a backup. I plan on having panel lights on one fuse, and little flood lights (LEDs actually), on a separate fuse, powered from the emergency bus. If the panel lights die, I'll turn on the flood lights, and sort it out after I land. The same thing goes for any critical system (a system that is required for safe flight and landing). Landing and taxi lights on separate fuses, etc. If the failure will affect your ability to safely complete the flight, have a backup plan. Hoping you can change a fuse and bring a system back on line is not a great back up plan. Just my two cents worth. Kevin Horton RV-8 (working on landing gear boxes) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
Date: Jan 26, 2000
Subject: Re: How many cylinders to connect to the primer?
> >I am now turning my titanic intellect to the question of how to install a >primer to the cylinders of my carburetor-equipped O-320. My present plan is >to run the primer line from the primer port on my gascolator to an electric >solenoid and then to the engine. I will turn on the electric fuel pump to >pressurize the system and open the solenoid to let gas down the primer >line(s). > >My problem: I don't have a clear idea of where to run the primer line(s) to. >Tony B appears to state that it is common to run a primer line to just one >cylinder. I would think that it would be better to squirt the gas into more >than one. Especially if you'd like to consider the primer system as a backup fuel delivery system. Break a mixure control, plug a float valve and the primer system (if calibrated for a 50-60% power fuel flow) can be energized and throttle adjusted for smoothest running engine. You get to select a landing spot on your terms, not the terms dictated by energy stored in your lifeless airframe. Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Jan 26, 2000
Subject: Re: RV-4 canopy latch
I think I have the gentleman's address. I met him at OSH this past year. By latching mechanism I assume you mean the pins (3/8's inch heavy wall tubing) that latch into the dash & rear seat bulkhead ??? Are you looking for a safety (additional ) latch ??. The west coast RV-4 person I ran into has a very clever safety latch and uses the traditional latching pin ( Vans) method. Contact me & I can get the address to you. I am using the traditional latching pin(s) and trying to decide on a safety latch system.....where are your thoughts on this issue..... rion(at)worldnet.att.net on 01/26/2000 02:49:03 AM Please respond to rv-list(at)matronics.com Subject: RV-List: RV-4 canopy latch I am at the decision point for my RV-4 canopy latch mechanism. I would like to use the standard latch mechanism in the plans, but it does not provide for a partially open position for ground operations. I have heard a rumor about a builder in the Seattle area who has designed a safety latch that allows use of the standard canopy latch and has a partially open position. Does anyone have his address and phone number or any suggested solutions? Thanx, Rion ________________________________________________________________________________
Date: Jan 26, 2000
Subject: Re: Voltage Regulator/Voltage meters
The VR166 solution worked for me two weeks ago. Being annal retentative & took my regulator & alternator (35 amp Mark Landrol with 4 inch pulley) home , clamped the alt. to the table saw , ran the belt around alt. & lit the whole mess up. Worked 100%. What was interesting was the variance in digital voltage meters I saw. I ended up borrowing 6 meters from work & the 4 from home & only two of the 10 meters showed the same voltage.... I am talking about up to 2.8 volts variance in digital readouts ......... The cheepie units were the worst offernders ( dah) The Fluke & H/P meters were the most accurate ( calabrated and verivied by my oscilloscope ). The matter was important because I was trying to see the cut in / cut out voltage of the cheepie regulator... and the steady state voltage of the battery & if the setup was (would) overcharge my aircraft system. Tell your parts counter man that aircraft nuts & bolts are left hand threads and hence vibrate tighter rather than become looser. Point to the fact that regular right hand nuts & bolts vibrate loose......see if he buys that....... KBoatri144(at)aol.com on 01/25/2000 08:13:31 PM Please respond to rv-list(at)matronics.com Subject: RV-List: Voltage Regulator Per a call-out in Electric Bob's book, I went to the local auto parts store today and bought a VR166 voltage regulator. This model isn't adjustable, but at $9.50, it was $25+ less expensive than the ones sold through aviation parts houses.. Thought somebody might wanna save a few $... As an aside, I got into an interesting discussion with the parts manager at the store. When I mentioned that the regulator was for an airplane he said that he didn't understand how the electronics on an airplane worked because they are not grounded. I explained that all of he electrical stuff is grounded to a central point, so grounding isn't a problem. He said, yeah, but when you're up in the air, nothing touches the ground, so you're not grounded... I tried to explain that that isn't how it works, but to no avail. I even tried to point out that cars are electrically isolated, because those tire things are pretty good insulators. He didn't buy that either... Kyle Boatright RV-6 - Reducing the parts count. ________________________________________________________________________________
Date: Jan 26, 2000
Subject: Wiring VS
Allright listers... In the instructions for the Empennage kit, all that it says is "be sure to provide for the necessary wiring runs and access details". The intent here is to accomodate the coaxial cable for a Comant CI182 GS/LOC/VOR antenna. My lights are going to be on the wings only so the same theories should apply when I get to that step. So here's my (and most novice builders) quandry: What do you use (grommet / tube / both) to go through the VS404, VS406, and VS407, or do you go forward of the VS402 with some adel clamps (every how many inches?) and a teflon tube through the VS406 forward of the VS402 to the aft of the VS405? I think that I confused myself with that question. So, how about some part numbers/suppliers from all of the builders that have finished this successfully already! Thanks, Ralph Capen RV6A Richardson, TX N822AR (reserved) QB ordered while I work on EMP (HS and VS Rear Spars ready to Prime)! ________________________________________________________________________________
Date: Jan 26, 2000
Steve, You will probably get a whole array of answers to your questions, so you'll be faced with selecting the answers that you think fit your situation and moving on from there. As with many questions, there is no one right answer. I'll tell you what I did. > >The first question is, therefore, is one cylinder enough? I copied the primer system from my Piper. I ran it to all four cylinders. I'm in a cold weather climate like you and I thought this would provide me with the maximum benefit from a priming system. No scientific facts to prove four is better than three, or one. That's why I just copied it from Mr. Piper. >The second question is, if I should run that primer line to more than one >cylinder, how do I split the 1/8 inch line into two or more separate lines? I used three steel 1/8" flared tee fittings that are cushioned clamped to the sump. >The third question is whether the copper priming line that Van's sells is OK >for this use. Some of the experts around here tell me that I should use >only aluminum line. I bought both the aluminum and the copper. After researching the issue in Tony's book and after looking at production aircraft, I chose the copper. I was concerned that the aluminim flares would pull out of the nut over time. >The fourth question is whether the little primer lines should be covered >with some sort of extra small diameter firesleeve, or it this just to cover >the flexible lines? I don't think the firesleeve is necessary. When your primer pump is closed, no fuel is flowing through the lines. If a fire would break out, or if a line would break, you would only burn the fuel remaining in the 1/8" line. Not much there to worry about. Now I did run a flexible line from an end coupling in the primer line to the middle of my firewall (which runs to my primer pump) and this line is firesleeved, although it is probably not necessary. Randy Pflanzer N417G RV-6 "Painting" ________________________________________________________________________________
Date: Jan 26, 2000
> >I am now turning my titanic intellect to the question of how to install a >primer to the cylinders of my carburetor-equipped O-320. My present plan >is >to run the primer line from the primer port on my gascolator to an electric >solenoid and then to the engine. I will turn on the electric fuel pump to >pressurize the system and open the solenoid to let gas down the primer >line(s). > >My problem: I don't have a clear idea of where to run the primer line(s) >to. >Tony B appears to state that it is common to run a primer line to just one >cylinder. I would think that it would be better to squirt the gas into >more >than one. > >The first question is, therefore, is one cylinder enough? >The second question is, if I should run that primer line to more than one >cylinder, how do I split the 1/8 inch line into two or more separate lines? > >The third question is whether the copper priming line that Van's sells is >OK >for this use. Some of the experts around here tell me that I should use >only aluminum line. >The fourth question is whether the little primer lines should be covered >with some sort of extra small diameter firesleeve, or it this just to cover >the flexible lines? > >Steve Soule Steve, Here's how I did it. I used copper tubing for all the hookups to THREE cylinders, since the fourth cylinder primer port is hooked up to the manifold pressure gauge. I used a manual primer pump, which pulls fuel out of the top of the gascolator. A bulkhead "T" fitting is mounted on the firewall to send one line to the side of the engine with just one primed cylinder, and the other side of the T goes to yes, yet another T fitting. It is positioned between the other two cylinders near the intercylinder baffle and short tubes go from there to each cylinder above it. I did not sleeve the lines with anything. I momentarily energize the fuel pump to pressurize the system, then give the primer about four or five strokes for a cold start. It fires up in two or three blades. Brian Denk RV8 N94BD flying ________________________________________________________________________________
Subject: Re: Chatter/RV Speed Hints
Date: Jan 26, 2000
> >Another secret is to not paint the airplane. Bare aluminum and >unfinished fiberglass does just not get 'em out of their seats. A >drawback to this strategy is blindness due to sun reflections off >unpainted wings. HAH! Yeah right! When Pat K. and I parked our UNPAINTED airplanes at Moriarty last Saturday, we must have had at least ten guys hovering around them for at least 45 minutes. So, then after we paint them, it gets worse? (better?) I fully agree that when flight planning to go from A to B, an RV driver must calculate in the question and answer session, preflight, then more questions, then maybe a ride around the patch, then go pee, then more questions... All things considered, I'm enjoying every minute of it. :) Brian in Albuquerque with a sorta balanced prop. RV8 N94BD ________________________________________________________________________________
Date: Jan 26, 2000
Hi Randy and thanks for the reply. I like your approach and will probably adopt it. I have a CHT sender in my #3 cylinder right now, if I want to prime all four where do I put that CHT sender? I know next to nothing about these engines. Steve -----Original Message----- From: Randy J. Pflanzer [mailto:rpflanze(at)iquest.net] Sent: Wednesday, January 26, 2000 11:07 AM To: rv-list(at)matronics.com Subject: Re: RV-List: How many cylinders to connect to the primer? Steve, You will probably get a whole array of answers to your questions, so you'll be faced with selecting the answers that you think fit your situation and moving on from there. As with many questions, there is no one right answer. I'll tell you what I did. > >The first question is, therefore, is one cylinder enough? I copied the primer system from my Piper. I ran it to all four cylinders. I'm in a cold weather climate like you and I thought this would provide me with the maximum benefit from a priming system. No scientific facts to prove four is better than three, or one. That's why I just copied it from Mr. Piper. >The second question is, if I should run that primer line to more than one >cylinder, how do I split the 1/8 inch line into two or more separate lines? I used three steel 1/8" flared tee fittings that are cushioned clamped to the sump. >The third question is whether the copper priming line that Van's sells is OK >for this use. Some of the experts around here tell me that I should use >only aluminum line. I bought both the aluminum and the copper. After researching the issue in Tony's book and after looking at production aircraft, I chose the copper. I was concerned that the aluminim flares would pull out of the nut over time. >The fourth question is whether the little primer lines should be covered >with some sort of extra small diameter firesleeve, or it this just to cover >the flexible lines? I don't think the firesleeve is necessary. When your primer pump is closed, no fuel is flowing through the lines. If a fire would break out, or if a line would break, you would only burn the fuel remaining in the 1/8" line. Not much there to worry about. Now I did run a flexible line from an end coupling in the primer line to the middle of my firewall (which runs to my primer pump) and this line is firesleeved, although it is probably not necessary. Randy Pflanzer N417G RV-6 "Painting" ________________________________________________________________________________
From: bcbraem(at)home.com.with.ESMTP (InterMail v4.01.01.00 201-229-111)
Date: Jan 26, 2000
Subject: Re: EXPERIMENTAL call signs to ATC
Fellow Listers & Esp. the ATC guys, including "Grumpy" Thanks for clearing up the grey area of identifying yourself to Approach and Tower. However, I am unfamiliar with HXA, HXB..., etc. and in Florida, no controller has ever asked my "class". I had been taught to tell controllers your "approach category" when they ask for speed (ie, Class A = less than 91 KIAS thru Class E = 166 KIAS or more--based on 1.3 Vso at gross weight). Since my modified RV-6 (IO-540) cruises at 180 - 240 mph, what "class" do I tell the controllers--I guess it's HXC?--can't find it in AIM/FAR. "Sarasota Approach, RV6 600 Sierra Sierra Experimantal Class Hotel XRay Charlie, from the South at twenty, level at two thousand"? Also, a note to my fellow RV'ers that come into Approach and airport range at full speed to get a testosterone boost by making a Mooney "get out of the way"--can be dangerous--use an approach speed that you feel fits into the speed range of the planes already in the pattern or that you hear are coming in--but then, again, you may need to peg it if Tower says there's a Lear on your tail,"please expedite". As an ex-Navy Flight Surgeon, I have photographed too many bodies that have used their airplanes as a penis extender. Oh, and by the way, MY IO-540 is NOT a penis extender--it's an aerodynamic experiment to expand basic aeronautical knowledge for the betterment of mankind, yeah--that's the ticket. Boyd. Michael Hartmann wrote: > > > >In this area (Southeast), on 1st call to Approach or Tower the > >controller will ask for 'class' of experimental. The class tells the > >controller the cruise speed range of the a/c, with rv's being class B. > >Controllers are not very consistent with this, but a friend who's a > >controller has told me it's 'official.' Is this not a national > >practice? > > ________________________________________________________________________________
Date: Jan 26, 2000
Subject: PR Wheel Pants-ground clearance
To all, I mounted up the pressure recovery 2 piece wheel pants last night on my -6. (Having the airplane up on stands in level attitude is nerve wracking out here in earthquake land). When I lowered it off of the stands and put weight on the wheels, I became a little concerned about the clearance of the wheel pants and the ground just aft of the wheel. Mine looks to be about one inch. Tire pressure is about 30psi and I set it up with 1-3/8" of tire clearance from the top of the wheel to the top of the pant. Every thing else is per the plans. To those who have been flying with these pants in a taildragger, what is your clearance and is one inch (no jokes please :-) ) enough? TIA, Laird RV-6 22923 SoCal ________________________________________________________________________________
Date: Jan 26, 2000
Steve: the CHT is under the spark plug or is just screwed to the jug for Temp. Each jug has a hole ( like the injector types) that is plumbed to the innards of the cylinder. Most people have to use one for the MP. So you can use the other three. Don Jordan ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com ****************************************************************************** writes: > >Hi Randy and thanks for the reply. I like your approach and will >probably >adopt it. I have a CHT sender in my #3 cylinder right now, if I want >to >prime all four where do I put that CHT sender? I know next to nothing >about >these engines. > >Steve > > -----Original Message----- > From: Randy J. Pflanzer >[mailto:rpflanze(at)iquest.net] > Sent: Wednesday, January 26, 2000 11:07 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: How many cylinders to >connect >to the primer? > > > > Steve, > > You will probably get a whole array of answers to your >questions, so you'll > be faced with selecting the answers that you think fit >your >situation and > moving on from there. As with many questions, there >is no >one right answer. > > I'll tell you what I did. > > > >The first question is, therefore, is one cylinder >enough? > > I copied the primer system from my Piper. I ran it to >all >four cylinders. > I'm in a cold weather climate like you and I thought >this >would provide me > with the maximum benefit from a priming system. No >scientific facts to > prove four is better than three, or one. That's why I >just >copied it from > Mr. Piper. > > >The second question is, if I should run that primer >line to >more than one > >cylinder, how do I split the 1/8 inch line into two >or more >separate lines? > > I used three steel 1/8" flared tee fittings that are >cushioned clamped to > the sump. > > >The third question is whether the copper priming line >that >Van's sells is > OK > >for this use. Some of the experts around here tell >me that >I should use > >only aluminum line. > > I bought both the aluminum and the copper. After >researching the issue in > Tony's book and after looking at production aircraft, >I >chose the copper. I > was concerned that the aluminim flares would pull out >of the >nut over time. > > >The fourth question is whether the little primer >lines >should be covered > >with some sort of extra small diameter firesleeve, or >it >this just to cover > >the flexible lines? > > I don't think the firesleeve is necessary. When your >primer >pump is closed, > no fuel is flowing through the lines. If a fire would >break >out, or if a > line would break, you would only burn the fuel >remaining in >the 1/8" line. > Not much there to worry about. Now I did run a >flexible >line from an end > coupling in the primer line to the middle of my >firewall >(which runs to my > primer pump) and this line is firesleeved, although it >is >probably not > necessary. > > Randy Pflanzer N417G RV-6 > "Painting" > > > > > > > > > > ________________________________________________________________________________
Date: Jan 26, 2000
Steve, The CHT sender goes into a well in the bottom, center of the cylinder. This is not where the primer line goes. The primer goes into a 1/4" npt port to the left, bottom of the valve cover. This is an open port right into the cylinder head. It usually has a allen head plug in it. This is also where manifold pressure can be taken. On my engine, one of my cylinders had an additional port on top of the cylinder from which I took my manifold pressure. Of you don't have this extra port (and not all cylinders do), then you can only prime three of the cylinders. I made frequent visits to my FBO and I wandered around the birds that were in the maintenance hangar to see how the spam cans did it. Most of the time, the mechanics would gladly answer my questions for me. Hang in there. Randy -----Original Message----- From: Stephen J. Soule <SSoule(at)pfclaw.com> Date: Wednesday, January 26, 2000 1:09 PM Subject: RE: RV-List: How many cylinders to connect to the primer? > >Hi Randy and thanks for the reply. I like your approach and will probably >adopt it. I have a CHT sender in my #3 cylinder right now, if I want to >prime all four where do I put that CHT sender? I know next to nothing about >these engines. > >Steve > > -----Original Message----- > From: Randy J. Pflanzer [mailto:rpflanze(at)iquest.net] > Sent: Wednesday, January 26, 2000 11:07 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: How many cylinders to connect >to the primer? > > > > Steve, > > You will probably get a whole array of answers to your >questions, so you'll > be faced with selecting the answers that you think fit your >situation and > moving on from there. As with many questions, there is no >one right answer. > > I'll tell you what I did. > > > >The first question is, therefore, is one cylinder enough? > > I copied the primer system from my Piper. I ran it to all >four cylinders. > I'm in a cold weather climate like you and I thought this >would provide me > with the maximum benefit from a priming system. No >scientific facts to > prove four is better than three, or one. That's why I just >copied it from > Mr. Piper. > > >The second question is, if I should run that primer line to >more than one > >cylinder, how do I split the 1/8 inch line into two or more >separate lines? > > I used three steel 1/8" flared tee fittings that are >cushioned clamped to > the sump. > > >The third question is whether the copper priming line that >Van's sells is > OK > >for this use. Some of the experts around here tell me that >I should use > >only aluminum line. > > I bought both the aluminum and the copper. After >researching the issue in > Tony's book and after looking at production aircraft, I >chose the copper. I > was concerned that the aluminim flares would pull out of the >nut over time. > > >The fourth question is whether the little primer lines >should be covered > >with some sort of extra small diameter firesleeve, or it >this just to cover > >the flexible lines? > > I don't think the firesleeve is necessary. When your primer >pump is closed, > no fuel is flowing through the lines. If a fire would break >out, or if a > line would break, you would only burn the fuel remaining in >the 1/8" line. > Not much there to worry about. Now I did run a flexible >line from an end > coupling in the primer line to the middle of my firewall >(which runs to my > primer pump) and this line is firesleeved, although it is >probably not > necessary. > > Randy Pflanzer N417G RV-6 > "Painting" > > ________________________________________________________________________________
Subject: Re: Emergencie and ATC (was Source for fuse blocks)
Date: Jan 26, 2000
Works for me!!! When there is an unusual situations/emergency, the stress level goes right out the roof. At that point the pilot becomes a hazard to everyone around him, not just himself and his pax. By all means lets get him of the ground where everyone is safe. Now of course if he /she gets macho and does not let ATC know then ATC can't help him out. Even if you don't declare an emergency let ATC know what is going on and keep them advised. They will give you a higher level of priority and handling to help you get on the ground as soon as possible. Back in the late fifties and early sixties over 75% of accident were caused by mechanical failure as the primary cause. Today the trend has reversed. Between 90 and 95% of ALL accidents are primarily caused by the pilot. We are going in depth into the human factors of accident investigation now. And one of the primary causes of pilot induced accidents is PILOT EGO. We are building better/smarter aircraft today. That includes all categories...heavy metal, home builts, Cessna, helicopters, etc. As pilot's we need to put our egos on hold when we fly and use common sense. I don't know about you but I would much rather fill out a little paper work explaining an incident than having my soul try to comfort my friends and relatives because I was stupid and won't ask for help. Sorry I got carried away. I will get off the soap box. Mike Robertson RV-8A QB Panel is DONE!! "Das Fed" >From: Charlie and Tupper England <cengland(at)netdoor.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Source for fuse blocks that take auto fuses >Date: Tue, 25 Jan 2000 18:52:39 -0600 > > > > >Cy Galley wrote: > > > > > > I had smoke from the panel dimmer and had to shut off the panel lights >and > > use a flash light as a student. I was also cleared to land and then the > > controller made me do a 360 on final for spacing because an airliner got >to > > the field before me. > > snip > >One of the first things my instructor taught me is that the controller >works for me. With smoke in my cockpit, the airliner would have waited. > >What say you, feds? > >Charlie > >flying -4 > > ________________________________________________________________________________
Date: Jan 26, 2000
Paul: Please send me his address and phone number. I do indeed want to use the 3/8's inch tubing latching mechanism per the plans where the latch tube runs through the canopy frame bows, but the safety latch that Van's provides doesn't have an intermediate stop: you are fully open or fully closed. Some builders put two holes in the instrument panel and rear seat bullkhead, but this requires riveting or welding an extension inboard on the canopy frame bows to run the latch tubing through. I had heard that the builder in the Seattle area had come up with a solution that allowed you to run the latch tube through the canopy frame bows as per the plans. Please send me his e-mail address and phone number. Thanx, Rion ----- Original Message ----- From: <pcondon(at)csc.com> Sent: Wednesday, January 26, 2000 7:40 AM Subject: Re: RV-List: RV-4 canopy latch > > > I think I have the gentleman's address. I met him at OSH this past year. By > latching mechanism I assume you mean the pins (3/8's inch heavy wall tubing) > that latch into the dash & rear seat bulkhead ??? Are you looking for a safety > (additional ) latch ??. The west coast RV-4 person I ran into has a very clever > safety latch and uses the traditional latching pin ( Vans) method. Contact me & > I can get the address to you. I am using the traditional latching pin(s) and > trying to decide on a safety latch system.....where are your thoughts on this > issue..... > > > rion(at)worldnet.att.net on 01/26/2000 02:49:03 AM > > Please respond to rv-list(at)matronics.com > > To: rv-list(at)matronics.com > > Subject: RV-List: RV-4 canopy latch > > > I am at the decision point for my RV-4 canopy latch mechanism. I would like > to use the standard latch mechanism in the plans, but it does not provide > for a partially open position for ground operations. I have heard a rumor > about a builder in the Seattle area who has designed a safety latch that > allows use of the standard canopy latch and has a partially open position. > Does anyone have his address and phone number or any suggested solutions? > Thanx, Rion > > ________________________________________________________________________________
Date: Jan 26, 2000
Subject: less expensive strobes
I have been running school bus strobes from ISSPRO (the company that now supplies Van's custom gauges). The power pack I believe was $179, runs four, 30 joules, quad flash, hi/lo power, strobe bulbs which cost $40 a piece. I used shielded wire and have no radio interference. I mounted the bulbs inside the wingtip lens and had to add an air vent hole to cool them. The unit seems very well built. They sell smaller units, 20 joules, single bulb for as low as $112(?). I would guess that you could buy the whelen lens if you wanted a wingtip mount. I realize now that this is a much better location because even though the bulb is shielded from the cockpit the plex lens flashes bright and is annoying when it is very dark. kevin ________________________________________________________________________________
From: "Michael Robertson" <mrobert569(at)hotmail.com>
Subject: Re: WIREING HARNESS
Date: Jan 26, 2000
Just now putting finishing touches on my panel. I would recommend starting out with Van's elelctrical kit and going from there. The ONLY part of their kit I would change out, after having already finished, is using a series of regular terminal bloks purchased form Acft. Spr. or Radio Shack instead of the homemade nylon blocks and screws in the kit. After that you are on your own pretty much. Bob Nuckoll's book AeroElectric Connection is an excellent book with many different schematic ideas to use. Mike Robertson RV-8A QB >From: Elrod3794(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: WIREING HARNESS >Date: Tue, 25 Jan 2000 22:26:14 EST > > >NEED SOME GOOD INFO FOR WIRING RV 8. ANY GOOD BOOKS? >ANY GOOD PRE FAB. WIRING HARNESS? >THANKS FOR ANY INFO. >MIKE ELROD RV8AQB >GETTING TO MOUNT WINGS > > ________________________________________________________________________________
Subject: Re: Wiring VS
Date: Jan 26, 2000
Ralph, There was an article in RVator #4(?) this last year covering exactly that. May want to try that first. >From: "Ralph E.Capen" <Ralph.E.Capen(at)wcom.com> >Reply-To: rv-list(at)matronics.com >To: RV-List >Subject: RV-List: Wiring VS >Date: Wed, 26 Jan 2000 09:39 -0500 (EST) > > >Allright listers... > >In the instructions for the Empennage kit, all that it says is >"be sure to provide for the necessary wiring runs and access details". > >The intent here is to accomodate the coaxial cable for a Comant CI182 >GS/LOC/VOR antenna. My lights are going to be on the wings only so >the same theories should apply when I get to that step. > >So here's my (and most novice builders) quandry: > >What do you use (grommet / tube / both) to go through the VS404, VS406, >and VS407, or do you go forward of the VS402 with some adel clamps >(every how many inches?) and a teflon tube through the VS406 forward of >the VS402 to the aft of the VS405? > >I think that I confused myself with that question. So, how about some >part numbers/suppliers from all of the builders that have finished >this successfully already! > >Thanks, >Ralph Capen >RV6A Richardson, TX N822AR (reserved) >QB ordered while I work on EMP (HS and VS Rear Spars ready to Prime)! > > ________________________________________________________________________________
Date: Jan 26, 2000
pcondon(at)csc.com wrote: > > > The VR166 solution worked for me two weeks ago. Being annal retentative & took > my regulator & alternator (35 amp Mark Landrol with 4 inch pulley) home , > clamped the alt. to the table saw , ran the belt around alt. & lit the whole > mess up. Worked 100%. > > What was interesting was the variance in digital voltage meters I saw. I ended > up borrowing 6 meters from work & the 4 from home & only two of the 10 meters > showed the same voltage.... I am talking about up to 2.8 volts variance in > digital readouts ......... What kind of battery did you have on the alt.? With minimal filtering by the battery it's not surprising to see that, but if you had a full sized battery on line even the 'cheapies' should be more accurate than that. Charlie ________________________________________________________________________________
Date: Jan 26, 2000
Subject: IO-360 Engine Control Cables Installation
Anyone who's put or is putting a front induction, IO360 in their -8(A) find that the throttle and mixture cables come pretty close to the exhaust pipes? I made my own cable support brackets out of .063", 4130 stock, and attached them to the bosses on the sump. Just looks like there isn't much clearance from the exhaust pipes when the cables are set up at the proper position relative to the throttle and mixture control arms. Van's recommendation on the mixture cable length (55") seem too short as well. Additionally, on Van's governor bracket, I bent over the cable attach tab 180 degrees. Sure did make everything line up a lot better. Comments on the mixture and throttle clearance issues/cable length? -Don RV-8 NJ ________________________________________________________________________________
Date: Jan 26, 2000
Subject: Re: PR Wheel Pants-ground clearance
--- Owens wrote: > > > To all, > > I mounted up the pressure recovery 2 piece wheel > pants last night on my -6. (Having the airplane up > on stands in level attitude is nerve wracking out > here in earthquake land). When I lowered it off of > the stands and put weight on the wheels, I became a > little concerned about the clearance of the wheel > pants and the ground just aft of the wheel. > > Mine looks to be about one inch. Tire pressure is > about 30psi and I set it up with 1-3/8" of tire > clearance from the top of the wheel to the top of > the pant. Every thing else is per the plans. > > To those who have been flying with these pants in a > taildragger, what is your clearance and is one inch > (no jokes please :-) ) enough? > > TIA, > Laird RV-6 22923 > SoCal Laird: Yes this is about the same as my-6. I over-inflate the tires to 40 psi. I use a 1" X 2" (firing stirp)in the hangar for wheel chocks. Actaul thickness of a firing strip is 3/4". When I cannot place the firing strip behind the tires with out rubbing the wheel pant, it is time to add air. I will also scrap the door track when I put the airplane away or take it out. Air pressure at this condition is 25 psi. It takes about 3 months to go from 40 to 25. Hope this helps. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, Flying So. CA, USA Talk to your friends online with Yahoo! Messenger. http://im.yahoo.com ________________________________________________________________________________
Date: Jan 26, 2000
Rion, I think I know the device you are talking about. Saw one on a -4 with a military paint scheme at Copperstate last year (the airplane was on the cover of the RVator a couple of issues ago). Since I was working on this area at the time I asked the owner about it. The thing was machined from Titanium and very pricey. It apparently is in high demand as the guy told me there was a backlog at the time. He waited many months to get his. So I didnt persue any further. For my -4 I drilled a hole throught the roll bar longitudinally about 4" above the cockpit rail. I bushed the hole with brass tube and installed a pin that engages a UHMW block attached to the canopy frame (the stamped sheet metal brace that goes across the airplane directly behind the roll bar). The UHMW has 2 holes, 1 for propping the canopy open for taxi and 1 for a safety in the closed position. A bellcrank pivoted on a bolt mounted in the rollbar gusset drives the pin from 1 arm of the bell crank, the other arm of the bell crank has a pushrod going forward so you dont have to reach over your shoulder to actuate the thing. It works well, the only problems are that propping the canopy in taxi position is a 2 hand job and it takes some practice to find the hole until you get used to it. I would do it this way again. For the canopy stay I did something I havent seen on any other -4. A piece of 1/8 X 1/2 X about 18" piece of bar stock is attached to the canopy frame via a pivot bolt at one end. The attachment point is again on that cross piece of the frame about 6" inches from the right edge. The bar is slotted and a bolt is passed thru the slot and bolted to the rollbar. So when the canopy is opened the bar slides along the bolt until it reaches the end of the slot and can then open no further. The geometry is such that in the closed position the bar sits behind the right upright of the rollbar so it doesnt impede the rear seat view. Another advantage is that you can notch the slot so that it provides a positive stop. The canopy cant be closed until the bar is lifted up out of the notch. If talked to several -4 owners who have had their canopies ruined when the wind blew them closed. Hope this makes sense. There seems to be as many methods of doing props and stays as there are RV4s. If you want more info contact me off-list. Maybe I can borrow a digital camera and email some pictures. Mike Wills RV-4 engine installation (Mazda 13B) willsm(at)spawar.navy.mil > >I am at the decision point for my RV-4 canopy latch mechanism. I would like >to use the standard latch mechanism in the plans, but it does not provide >for a partially open position for ground operations. I have heard a rumor >about a builder in the Seattle area who has designed a safety latch that >allows use of the standard canopy latch and has a partially open position. >Does anyone have his address and phone number or any suggested solutions? >Thanx, Rion > > ________________________________________________________________________________
Date: Jan 26, 2000
>Mine looks to be about one inch. Tire pressure is about 30psi and I set it up with 1-3/8" of tire clearance from the top of the wheel to the top of the pant. Every thing else is per the plans. > >To those who have been flying with these pants in a taildragger, what is your clearance and is one inch (no jokes please :-) ) enough? Mine are mounted at about that same clearance. They are ok on flat cement. But they have scraped a couple of times on bumps. And I am going to have to redo them....I don't think they will do well on grass or any other rough surface. As I was told at Van's they have had a few of them roll right around the wheel and depart! Have a great day! Denny, RV-6 N641DH (Flying) ________________________________________________________________________________
Date: Jan 26, 2000
Subject: Re: RV4-List: RV-4 canopy latch
Hi J; I used a pin from the nautilus weight room that holds the weights in the stack. I drilled a hole in my roll bar through the canopy bulkhead at a point on the entry side that left the canopy about 3 inches "above the rim" with the pin in. I used plastic bushings in the hole in the roll bar just like the ones for the rudder cables and drilled the pin so I could put a small cotter key and washer 2 inches from the end. Now I simply slide it into the hole in the canopy bulkhead on the ground and pull it back when I shut the canopy. It slides about 3 inches stop to stop. The cool part is when the canopy is down, the pin slides backwards OVER the top of the bulkhead preventing opening if the canopy lock should fail. See ya. Rob Ray smokyray(at)yahoo.com --- "J. Rion Bourgeois" wrote: > --> RV4-List message posted by: "J. Rion Bourgeois" > > > I am at the decision point for my RV-4 canopy latch > mechanism. I would like > to use the standard latch mechanism in the plans, > but it does not provide > for a partially open position for ground operations. > I have heard a rumor > about a builder in the Seattle area who has designed > a safety latch that > allows use of the standard canopy latch and has a > partially open position. > Does anyone have his address and phone number or any > suggested solutions? > Thanx, Rion > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > Talk to your friends online with Yahoo! Messenger. http://im.yahoo.com ________________________________________________________________________________
Subject: RV9 Rudder
Date: Jan 26, 2000
Any RV9 Builders should note there is an error on Drawing 7. (verified by Ken at Vans on the phone). To wit: The counterbalance skin goes between the ribs and main rudder skin. John Harris Cary, NC RV9A, N901RV(reserved) DIgging out of 18 inches of snow and about to finish rudder riveting. ________________________________________________________________________________
Date: Jan 26, 2000
Sounds neat and simple. However, if the pin slides backwards over the canopy bulkhead, how do rescuers open the canopy to get you out? Got pictures? Rion ----- Original Message ----- From: rob ray <smokyray(at)yahoo.com> Sent: Wednesday, January 26, 2000 3:45 PM Subject: Re: RV4-List: RV-4 canopy latch > --> RV4-List message posted by: rob ray > > > Hi J; > > I used a pin from the nautilus weight room that > holds the weights in the stack. I drilled a hole in my > roll bar through the canopy bulkhead at a point on the > entry side that left the canopy about 3 inches "above > the rim" with the pin in. I used plastic bushings in > the hole in the roll bar just like the ones for the > rudder cables and drilled the pin so I could put a > small cotter key and washer 2 inches from the end. Now > I simply slide it into the hole in the canopy bulkhead > on the ground and pull it back when I shut the canopy. > It slides about 3 inches stop to stop. The cool part > is when the canopy is down, the pin slides backwards > OVER the top of the bulkhead preventing opening if the > canopy lock should fail. See ya. > > Rob Ray > smokyray(at)yahoo.com > --- "J. Rion Bourgeois" wrote: > > --> RV4-List message posted by: "J. Rion Bourgeois" > > > > > > I am at the decision point for my RV-4 canopy latch > > mechanism. I would like > > to use the standard latch mechanism in the plans, > > but it does not provide > > for a partially open position for ground operations. > > I have heard a rumor > > about a builder in the Seattle area who has designed > > a safety latch that > > allows use of the standard canopy latch and has a > > partially open position. > > Does anyone have his address and phone number or any > > suggested solutions? > > Thanx, Rion > > > > > > > > through > > > > http://www.matronics.com/archives > > http://www.matronics.com/emaillists > > > > Matronics! > > > > > > > > > > > Talk to your friends online with Yahoo! Messenger. > http://im.yahoo.com > > ________________________________________________________________________________
Date: Jan 26, 2000
Hi Steve This is how I ran the primer lines on my 4. Gascolator to a machanical primer (solenoid wasn't available...I would use one now) to three cylinders. the fourth cylinder primer port is used for a manifold pressure guage. I split the 1/8th copper line with a 1/8th An "T" fitting at the rear of the engine and again on the left side. These fittings are available from most compaines who sell fittings. I used an aircraft flaring tool that was capable of flaring the small tube. It is difficult to get good flares on the small copper tube, but I managed to get them all done with no leaks. The system seems to work fine. I also have seen flaring systems that use auto store brass fittings to accomplish the splitting of the lines, in fact the engine in my 4 came out of a Piper and had these fittings on it. Find a way to immoblise the fittings, so they don't vibrate and break the copper lines, as well as the lines themselves. There are two other RV's at our field here in Canada that have essentially the same system. A good primer system is a necessity here if we want to fly in the cooler part of the year. Hope this helps. Joe Hine RV4 C-FYTQ > >I am now turning my titanic intellect to the question of how to install a >primer to the cylinders of my carburetor-equipped O-320. My present plan is >to run the primer line from the primer port on my gascolator to an electric >solenoid and then to the engine. I will turn on the electric fuel pump to >pressurize the system and open the solenoid to let gas down the primer >line(s). > >My problem: I don't have a clear idea of where to run the primer line(s) to. >Tony B appears to state that it is common to run a primer line to just one >cylinder. I would think that it would be better to squirt the gas into more >than one. > >The first question is, therefore, is one cylinder enough? >The second question is, if I should run that primer line to more than one >cylinder, how do I split the 1/8 inch line into two or more separate lines? > >The third question is whether the copper priming line that Van's sells is OK >for this use. Some of the experts around here tell me that I should use >only aluminum line. >The fourth question is whether the little primer lines should be covered >with some sort of extra small diameter firesleeve, or it this just to cover >the flexible lines? > >Steve Soule >Huntington, Vermont >RV-6A >Snow at last! > > ________________________________________________________________________________
Date: Jan 26, 2000
Subject: In-flight troubleshooting, was: Source for fuse blocks that
take auto fuses Hi Bob, I think we are going to have to agree to disagree, but no hard feelings. I understand your desire to keep your options open. The trick is to not get so caught up with troubleshooting the system that you get distracted and screw something else up, or do something stupid when troubleshooting, like replace a fuse with a bigger one, and start an electrical fire. Let's not forget the airliner (1011?) that went down in the Everglades one night many years ago because all three crew members were focused on troubleshooting a burned out gear down-and-locked green light, and no one was flying the aircraft. I got a bit too focused on trying to sort out a an engine with a compressor stall years ago. The engine in the single-engine jet was still producing thrust, but not quite enough to maintain level flight. I was trying to coax it to give me just a bit more thrust to break my 300 ft/min descent, so I could get to the airport 10 miles away. I got focused on trying different things with the engine, and lost track of my altitude. I snapped out of it at about 500 ft, and prepared to eject, only to see a big electrical sub-station just ahead, with gazillion volt power lines going in every direction - not a good place to come down in a parachute. I had to wait until the other side of the power station before ejecting, and the altitude was a lot lower than I would have liked. Bottom line - I got focused on doing in-flight troubleshooting, and it almost cost me my life. Be careful out there, Kevin > >Hi Kevin, > >I have no problem with you or some of your points, but my point with the >failure experience is that if you make your fusepanel inaccessible in >flight, you lose the option to do some immediate troubleshooting. Something >in my case was drawing more current than the fuse was rated for, and I >replaced the fuse in flight and everything worked fine afterwards. This may >have been an anomaly, but the worst thing I thought would happen was the >other fuse would blow. If I remember correctly, in that Cherokee the panel >lights were on the same circuit as the nav lights, so the fuse I replaced >was of the same value as the pitot heat. I made sure the values were the >same. You are right about redundancy in your systems, and I have many >electrical items on their own circuits. My fuseblocks are attached to the >right side of the cockpit below and behind the panel where they are easily >reachable, and I like them there so I can at least try to fix something >in-flight within reason to continue on safely. > >Bob Japundza > > >The way I look at the world you are drawing the wrong lesson from >this experience. What if you had a real short that took out the >panel lights? Having the fuse accessible in flight wouldn't help at >all. All it would do is let you make some more smoke. > >If panel lights is a required system, you need a backup. I plan on >having panel lights on one fuse, and little flood lights (LEDs >actually), on a separate fuse, powered from the emergency bus. If >the panel lights die, I'll turn on the flood lights, and sort it out >after I land. The same thing goes for any critical system (a system >that is required for safe flight and landing). Landing and taxi >lights on separate fuses, etc. If the failure will affect your >ability to safely complete the flight, have a backup plan. Hoping >you can change a fuse and bring a system back on line is not a great >back up plan. > >Just my two cents worth. >Kevin Horton RV-8 (working on landing gear boxes) >Ottawa, Canada >http://members.xoom.com/kevinhorton/rv8.html > > Kevin Horton RV-8 (working on landing gear boxes) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
Date: Jan 26, 2000
I purchased Van's wiring harness, but can't comment on it because it is still sitting in the box. However, for $2.50 or so Van's will sell you the wiring drawing and instructions. This is dirt cheap for the amount of information you get from this (which gage wire to use, where to cut holes for the wiring to pass through, etc. etc. etc.). That's my 2 cents. Rick Jory, Highlands Ranch, CO RV8A quickbuild -----Original Message----- From: Elrod3794(at)aol.com <Elrod3794(at)aol.com> Date: Tuesday, January 25, 2000 8:34 PM Subject: RV-List: WIREING HARNESS > >NEED SOME GOOD INFO FOR WIRING RV 8. ANY GOOD BOOKS? >ANY GOOD PRE FAB. WIRING HARNESS? >THANKS FOR ANY INFO. >MIKE ELROD RV8AQB >GETTING TO MOUNT WINGS > > ________________________________________________________________________________
Date: Jan 26, 2000
If you placed a small battery or no battery to load and filter the current coming from alt it will be very noisy which tricks the 'cheap' meters into false DC reading. Switch over to AC and see if you get a reading, if so then there is lots of noise. Better yet look at it with the oscilloscope in the 250ms setting and look for noise. You would be surprise and the noise that comes from alternators. Greg ________________________________________________________________________________
Date: Jan 26, 2000
From: "Shelby Smith" <shelbyrv6a(at)mindspring.com>
You know that would be something they could post on their website(PDF file) Shelby Smith shelbysmith(at)mac.com ---------- >From: "Rick Jory" <rickjory(at)email.msn.com> >To: >Subject: Re: RV-List: WIREING HARNESS >Date: Wed, Jan 26, 2000, 6:59 PM > > > I purchased Van's wiring harness, but can't comment on it because it is > still sitting in the box. However, for $2.50 or so Van's will sell you the > wiring drawing and instructions. This is dirt cheap for the amount of > information you get from this (which gage wire to use, where to cut holes > for the wiring to pass through, etc. etc. etc.). That's my 2 cents. > Rick Jory, Highlands Ranch, CO RV8A quickbuild > > -----Original Message----- > From: Elrod3794(at)aol.com <Elrod3794(at)aol.com> > To: rv-list(at)matronics.com > Date: Tuesday, January 25, 2000 8:34 PM > Subject: RV-List: WIREING HARNESS > > >> >>NEED SOME GOOD INFO FOR WIRING RV 8. ANY GOOD BOOKS? >>ANY GOOD PRE FAB. WIRING HARNESS? >>THANKS FOR ANY INFO. >>MIKE ELROD RV8AQB >>GETTING TO MOUNT WINGS >> >> > > > ________________________________________________________________________________
Date: Jan 26, 2000
Subject: RV-3 Firewall aft project
My project is for sale. RV-3 firewall aft project. If you're tired of building and would like to be flying sooner, this project may be what you're looking for. Wing leading edge skins, one flap skin, one wing tip, need replacing, lower cowl needs fiberglass repair. Have gear legs, wheels, tires, brakes, seat pads, upper cowl, fuel tank, and other parts. Aircraft has flown 265.7 hrs. Will be sold as parts. ($4700.00 or reasonable offer takes it all) for details Call 520-680-6902 or e-mail Jerry at (vicki(at)ctaz.com) ________________________________________________________________________________
Date: Jan 26, 2000
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
> >If you placed a small battery or no battery to load and filter the current >coming from alt it will be very noisy which tricks the 'cheap' meters into >false DC reading. Switch over to AC and see if you get a reading, if so >then there is lots of noise. Better yet look at it with the oscilloscope in >the 250ms setting and look for noise. You would be surprise and the noise >that comes from alternators. the ripple voltage left on a 3-phase alternator's rectified output is about 5% of the average DC . . . for a 14v alternator this is on the order of 700 mV peak to peak. Normally, this isn't a problem for avionics or other accessories designed to run in vehicles of any kind having an alternator/battery power system. It's true that some digital meters are sensitive to this kind of noise and will benefit from some filtering. The DC meter modules I use the most have a 10 to 100 Megohm input impedance so adding 10K of series resistance in the meter's sense lead doesn't upset the calibration much . . less than 0.1%. After the resistor is added, you put a capacitor across the meter's input terminals, anything 0.1 uF up to 10 uF is fine . . . 1.0 uF and larger tend to be electrolytics so observe polarity. This simple R/C filter will calm the little fellers down so that their readings are accurate. Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Subject: Lyc 0-320 (160 hp) parallel valve parts for sale
Date: Jan 26, 2000
To all, I thought that this might be an opportunity for someone building up their own engine, so please excuse the Ad. I have a short list of Lycoming engine parts that are for sale. They came out of my engine after a valve spring failure turned up other problems with the reconditioned cylinders. I would like to sell the whole lot at one time, but may consider other offers. The parts are all cleaned up (glass bead blasted and solvent cleaned), and are in the listed condition. Qty Description Condition 4 ea. Pistons (standard size) 40 hours, within new limits (almost new) 4 ea. Intake valves 40 hours, within new limits (almost new) 2 ea. Exhaust valves 40 hours, within service limits 4 ea. Rocker shafts hours unknown, within service limits 2 ea. Pushrods P/N 73413 hours unknown, within service limits 1 lot Valve springs 3 cylinder sets 40 hours (for angle valve cylinders) within service limits 1 lot Spring caps and seats hours unknown, within service limits Price: $150.00 takes all you pay shipping. For sale separately: 4 0-320 nitrided cylinders beyond service limits, need chrome, 2 with cracked heads, rocker bushings worn on all. Good for cores only. All 4 for $60 you pay shipping. Dan Morris RV-6 ________________________________________________________________________________
Date: Jan 26, 2000
Subject: Tank attach platenuts
After a couple of sessions of deburring & fluting, my right wing ribs (I'm doing one wing at a time, starting with the right) are ready to go. The manual says to install the tank attach platenuts on the top flange of the main spar before drilling the ribs on. So far, so good. The question is: how & when are the platenuts on the bottom flange located? They're not pre-punched, so do I back drill them through the holes in the tank skin once it's cinched down to the spar with the plastic strapping? That's not supposed to happen until after the ribs are drilled on. Maybe install the top platenuts now, drill & cleco the ribs on, cinch the tank skin down, back drill the holes for the bottom platenuts, take everything apart and install the bottom platenuts before riveting it all together. Does that make sense? Maybe I've just been doing too much fluting today... Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Date: Jan 26, 2000
Subject: Re: In-flight troubleshooting
> >Hi Bob, > >I think we are going to have to agree to disagree, but no hard >feelings. I understand your desire to keep your options open. The >trick is to not get so caught up with troubleshooting the system that >you get distracted and screw something else up, or do something >stupid when troubleshooting, like replace a fuse with a bigger one, >and start an electrical fire. Let's not forget the airliner (1011?) >that went down in the Everglades one night many years ago because all >three crew members were focused on troubleshooting a burned out gear >down-and-locked green light, and no one was flying the aircraft. My all time favorite example of the greatest aviation snafu . . . >I got a bit too focused on trying to sort out a an engine with a >compressor stall years ago. The engine in the single-engine jet was >still producing thrust, but not quite enough to maintain level >flight. I was trying to coax it to give me just a bit more thrust to >break my 300 ft/min descent, so I could get to the airport 10 miles >away. I got focused on trying different things with the engine, and >lost track of my altitude. I snapped out of it at about 500 ft, and >prepared to eject, only to see a big electrical sub-station just >ahead, with gazillion volt power lines going in every direction - not >a good place to come down in a parachute. I had to wait until the >other side of the power station before ejecting, and the altitude was >a lot lower than I would have liked. Bottom line - I got focused on >doing in-flight troubleshooting, and it almost cost me my life. There's a difference between troubleshooting things that you only have one-of (engines, controls, etc.) and trouble shooting things that you SHOULD have two-of. The vast majority of failures in goodies like turn coordinator, panel lights, primary nav radios, and transponders are NOT trouble-shootable . . . so why launch into the blue with any mindset that suggests doing so MIGHT be a good idea? The butt-saving capabilities of these devices need backups . . . meaning these fall into the category of having TWO. Everything else is handy to have but has little to contribute to a no-sweat flight. Even your own example of systems diagnostics distractions could have ended differently. When the low volts light comes on, flipping two switches is all it takes to get into the get-me-home-comfortably mode . . . you don't even have to take your eyes down from the horizon. If anything else craps, you should either not need it or it's backed up. Again, not a scenario for a hair-raising tale to be immortalized on the pages of Flying magazine. I'll judge that with a little advance planning and considered preventative maintenance, 99% of all electrical failures tales in those magazines need not have been written. Not something the spam-can driver is encouraged or even allowed to do. Now the guys building RVs ???? It's a much different matter. Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Jan 26, 2000
Subject: Re: Tank attach platenuts
> >After a couple of sessions of deburring & fluting, my right wing ribs (I'm >doing one wing at a time, starting with the right) are ready to go. The >manual says to install the tank attach platenuts on the top flange of the >main spar before drilling the ribs on. So far, so good. The question is: >how & when are the platenuts on the bottom flange located? They're not >pre-punched, so do I back drill them through the holes in the tank skin once >it's cinched down to the spar with the plastic strapping? That's not >supposed to happen until after the ribs are drilled on. Maybe install the >top platenuts now, drill & cleco the ribs on, cinch the tank skin down, back >drill the holes for the bottom platenuts, take everything apart and install >the bottom platenuts before riveting it all together. Does that make sense? >Maybe I've just been doing too much fluting today... > >Regards, >Ken Balch Ken, You don't want to cinch the tank skins on now, as the skeleton is not strong enough to take the loads. It gets a lot stiffer once the skins are clecoed on. So, rivet the ribs, drill and cleco the skins, drill and cleco the O/B leading edge, drill and cleco the tanks, then drill the lower platenut holes. I drilled them to #30, and did the final drilling after the tank was all finished. It was not too hard to rivet the lower platenuts on at the end. I was careful to get the inner few at a good angle to facilitate riveting. In some cases it seemed to make sense to use a different angle than that shown on the drawings. Just think about riveting access when you drill the rivet holes, thats all. Take care, Kevin Kevin Horton RV-8 (working on landing gear boxes) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
Date: Jan 26, 2000
Subject: Re: Source for fuse blocks that take auto fuses
>>This is another advantage of the solidstate protection devices. They won't >>>reset unless the short is removed so you don't have to worry about welded >>>contacts(circuit breaker) or inflight fires from putting in a fuse that is >>>over rated by accident. >> >> . . . hazards that are more fiction than fact . . . > > what part are you saying is fiction? > Circuit breaker contacts don't weld. Fuses that are not fiddled with in flight don't suffer mis-sizing accidents. Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Jan 26, 2000
Subject: rv-list:GPS and Map Compatability
Listers, Thanks to everyone who gave input about my GPS and Map question. Yesterday I went to Pacific Coast Avionics and posed my questions to them. Here is what I found. 1 The IImorrow SL-60 will work fine with the Allied Signal Skyforce Tracker or even the Skyforce GPS/Map. You can turn the GPS function of the Skyforce unit off and use the SL-60 GPS engine or turn it on and use it's own GPS engine. 2 The Skymaps have been selling like hotcakes lately since they reduced the price to $1995, $1795 for the Tracker version without GPS(was $2295). This is the Skymap IIIc with color map. That's right, the GPS engine adds only $200 to the cost. I played with it a bit in the shop and was impressed with it's capability and intuitive operation. Although I've never used a GPS before (so maybe I'm easily impressed) I found it easy to use and also that it had comparable functions to the SL-60 GPS features although I couldn't tell that from the advertisements I had seen....IImorrow seems to do a better job of listing the features in their ads. 3 As one of you posted earlier, going with the SL-40 Com radio and a GPS/Map is cheaper and offers the flexibility of a portable GPS/Map. Its at least a thousand dollars cheaper even if I pay asking price on both units. 4 It appears that the SL-40 Comm radio will interface with the Skyforce GPS to nominate frequencies along my route. Not fully confirmed yet, but a possibility. This was one of the things I liked about the SL-60 GPS/Com unit. Didn't think that would be possible unless I went with a GPS/Com unit. I could go with the Garmin 295 color GPS/Map too for less money but I like the Skyforce system for mounting in the panel on a rack... and still being fully portable in 30 seconds. Bottom line I think it looks better in my panel configuration. Maps a little bigger too. Haven't spent any money yet but I'm pretty drawn to the SL-40 plus Skymap IIIc combination. My flying will be VFR with no plan for IFR later so this seems like a relatively inexpensive and elegant solution for me. Thanks to all whose input helped me sort though this far. Regards, Dale Wotring RV6A (panel and finish stuff) Vancouver, WA ________________________________________________________________________________
Subject: Re: RE: Source for fuse blocks that take auto fuses
Date: Jan 26, 2000
> >The way I look at the world you are drawing the wrong lesson from > >this experience. What if you had a real short that took out the > >panel lights? Having the fuse accessible in flight wouldn't help > > at all. All it would do is let you make some more smoke. [snip] And Aero-Bob said: > > You got an A+ on that exam! > Uh-oh, I guess I get a D.... I had the panel rheostat smoke once, during the day. Funny smell, a little smoke, but was definitely freaked out for a second before I looked at the breakers and SAW that the panel dimmer breaker was popped. Made me feel much better seeing the popped breaker which told me A) that it wasn't anything I needed at the moment (it was daylight) and B) that the reason for the smoke had been more or less "corrected" by the breaker popping. It could be argued that I should have landed anyway but the smoke and smell cleared rapidly so I didn't, and either way I feel that the breaker prevented a possible panic situation. Randall Henderson, RV-6 N6R (in the paint shop) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
Date: Jan 27, 2000
In a message dated 1/26/00 11:00:25 AM Pacific Standard Time, bcbraem(at)home.com.with.ESMTP writes: << Thanks for clearing up the gray area of identifying yourself to Approach and Tower. However, I am unfamiliar with HXA, HXB..., etc. and in Florida, no controller has ever asked my "class". I had been taught to tell controllers your "approach category" when they ask for speed (ie, Class A = less than 91 KIAS thru Class E = 166 KIAS or more--based on 1.3 Vso at gross weight) >> Actually all this HXB stuff is just so much baloney now that the official contractions manual lists most Van's aircraft by their own designations RV3, RV4, RV6. RV-6As are RV6s as far as the FAA is concerned (they don't care where the training wheel is--we're all butt draggers to them). -GV RV6/U ________________________________________________________________________________
Date: Jan 26, 2000
Subject: Re: RV-List:fuselage support
Listers: My thinking cells are going into overload with this one. (maybe it's old age catching up). I am ready to start installing the gear leg fairings and wheel pants. In order to do this I need to lift the fuselage off the ground so the legs are unloaded. I have the engine installed and so the fuselage is getting heavy. I want to lift the fuselage just under the main spar hole but realise that the tail will be too light to balance out the weight. I think that a couple sand bags will do the trick but would appreciate some input from those of you who have been there and done that. Does any one have pictures of the jig that will hold a mostly completed airframe less wings off the ground? I sure would like to get this part done. I'm getting close enough to seeing the project completed now. Thanks in advance, Doug Murray RV-6 Southern Alberta ________________________________________________________________________________
Subject: Re: Prop Balancing
Date: Jan 26, 2000
: Re: RV-List: Prop Balancing > > . If indeed the rubbers are shot >you could tell by the sag...at any rate the rubbers are very cheap (wag aero >among others) for the conical motor. Please don't use the cheap rubber mounts!! I have a set I will give you free ( you pay postage) I went through 4 years of engine roughness, damn near tore the engine apart, changed carbs, had the prop. checked and they couldn't improve on it ( done at 2500 RPM). The roughness showed up below 2500 rpm and also very noticeable on final when power was being reduced to maintain 85-90 mph. In Oct. 98 Mark Todd and Mike Seager helped me (through this list) pin down my problem. DON'T USE THE CHEAP ENGINE MOUNTS WITH THE CONICAL ENGINE MOUNT! Bite the bullet and buy the Lord 6230-1 mounts ( my engine is a 0 320 B3B ) with the Hartzell C/S. I cannot speak for other conical mount lycoming models or if this problem would not occur with a wooden prop. but if you are using my combination save yourself a lot of grief and get the correct mounts. You wouldn't believe you were flying in the same airplane. An aside, the only cowling hinge pin that broke was the pilot side cowl cheek hinge. All top, side,and bottom pins still okay after 300 hours. Fly Safely Ken Hoshowski RV6 C-FKEH Salmon Arm B.C. Temp. 32 , 15" of snow on the lawn ________________________________________________________________________________
Date: Jan 27, 2000
Subject: RV-8 Aileron deflection angles
Bob, The aileron bellcrank is designed to give a differential action to the ailerons. For the same amount of movement of the pushrod from the stick, you get a lot more aileron up travel than you get down travel on the other side. In the final assembly stage, you may have to fine tune the differential action by adjusting the length of the various pushrods, which changes the neutral position of the bellcrank, which changes how much differential action you get. This will make a lot more sense once you can play with some hardware. Kevin Horton RV-8 (working on landing gear boxes) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html > > >Dave, > > I got 30 degrees without any opening of the hole. I wonder how you limit >the travel down to anything less than 30 since the ailerons link through the >stick. Maybe there's some geometry >there that I'm missing. I haven't started on the fuselage yet so I don't >know how the linkage >works there. > > Bob >RV8 #423 working on right wing. > > >-----Original Message----- > >RV-8 guys, > >While enlarging the hole in rear spar for the aileron pushrod, I needed to >determine the correct amount of aileron deflection. Bill at Vans gave a >design limit of 32 degrees up and 17 degrees down and a minimum acceptable >limit of 25 degrees up and 15 degrees down. > >My aileron only deflects a maximum of 28 degrees up without and kind of >aileron stop installed (bolt on the aileron bracket hitting the aileron >hinge, absolute maximum travel). I am afraid that with the aileron stops >installed that I am only going to get between 25 to 27 degrees of up aileron >travel. > >How much travel are other RV-8 guys getting? > >Thanks >David Grover Kevin Horton RV-8 (working on landing gear boxes) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
Date: Jan 27, 2000
Subject: Re: Proseal measuring balance
Excellent suggestion. I think I would prefer to hang something from single points on the balance arms to be certain that the ratio is unaffected by the position of the goop. The 11 'calibrated' bolts idea is perfect. Thanks, Doug > > > Here is a simplistic way. > Get a stick between 12 and 20 inches long. Tape, nail or glue a 3 inch > pad on each end. Get eleven bolts or nuts or some such of that weigh the > same. Put ten on one pad and the last one on the other pad. Now balance > the stick on something so that it sits level with the world. Many ways to > do this. > Now take the bolts or nuts off the pads. Replace the one bolt with the > black stuff and the ten bolts with the white stuff. 10:1 > Me??? I use a very accurate balance beam at the office that I mix ink on. > Cecil Hatfield > Thousand Oaks, CA > > >>Can someone tell me where I can find a picture of the 10:1 balance to > >>weigh out the proseal? > >> > >>Doug Gray > ________________________________________________________________________________
Date: Jan 27, 2000
Subject: Primer lines/manifold press.
Would it not be possible to connect the manifold pressure guage somewhere else, such as into one of the intake tubes, allowing all four primer lines to be used? Seems a small fitting could be tig-welded near the cyl head for this. One of my favorite stories from "Great American Fighter Pilots of WWII" I read as a kid was about a P-51 pilot that got his fuel pump shot up over Europe, and literally wore his hand down to the bone using the manual primer to return to England. Using all four primer lines and a manual primer might make a useable backup in the event of fuel pump and electrical failure (however unlikely). I'm a long way from having to do this, but this thread's got me thinking...(oh no!) From the PossumWorks Mark ________________________________________________________________________________
Subject: WIREING HARNESS
Date: Jan 27, 2000
I'm wiring right now. FWIW, I would buy the wiring kit. I decided to save money and buy the wire and fittings, etc. I can't tell you how many times I have discovered that I don't have the right length of the right size wire. This means that I have to stop what I'm doing and place yet another order to Wick's for the right wire or whatever. Steve Soule Huntington, Vermont -----Original Message-----However, for $2.50 or so Van's will sell you the wiring drawing and instructions. This is dirt cheap for the amount of information you get from this (which gage wire to use, where to cut holes for the wiring to pass through, etc. etc. etc.). ________________________________________________________________________________
Date: Jan 27, 2000
Subject: Dunno....
GV says: <<<< Volume resistivity in ESD control measures x<1X10 5 ohms/sq as conductive, 1X10 5>>> Gee, I'd always wondered about that.... :=)) Johnny Johnson 49MM -3A flying (well.. not much lately, it's been 20 below..) ________________________________________________________________________________
Date: Jan 27, 2000
Subject: Re: Chatter/RV Speed Hints
Yes Larry that's true, but: ain't it GREAT . FAA inspection done flying soon N468TC ________________________________________________________________________________
Date: Jan 27, 2000
Subject: Re: RV-4 canopy latch
I will get the data from my builders folder tonight. stay tuned......... ________________________________________________________________________________
Date: Jan 27, 2000
Subject: Re: Voltage Regulator/Voltage meters
I was very surprised on the qualitity of the digital meters. I borrowed a whole lot of cheepie $20.00 to 60.00$ meters from folks at work ant my cheepies & good Fluke brand meter. Hooked up to the terminals of a battery... all 10 meters cooking..... the variance in the voltage was close to three volts on a battery with reading of 12.4 volts. I tried the mower battery, motercycle battery & a spare car battery all with the same results. What was really surprising the old Simpson & Lafayette analog meters (needle swing)..when I got real close to the meter face & could read a voltage to about .5 volt which about half of the cheepie digitals gave me worse (in accuracy) readings. All this was found by accident. I wanted to see that the regulator would regulate. I hooked up a digiatal meter and the voltage was rock solid on the test alternator rig I made up. What got me to experimenting was the concord battery the Vans sells. I wanted to be sure I was charging at the rate that Elect. Bob told me was the correct voltage for that kind of battery......this lead me to the digital voltage test sequence. This is why my aircraft is taking so long to build...what little time after work I get I start playing around with diversions like this one & then the night dissapears..... cengland(at)netdoor.com on 01/26/2000 03:47:10 PM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: Voltage Regulator/Voltage meters pcondon(at)csc.com wrote: > > > The VR166 solution worked for me two weeks ago. Being annal retentative & took > my regulator & alternator (35 amp Mark Landrol with 4 inch pulley) home , > clamped the alt. to the table saw , ran the belt around alt. & lit the whole > mess up. Worked 100%. > > What was interesting was the variance in digital voltage meters I saw. I ended > up borrowing 6 meters from work & the 4 from home & only two of the 10 meters > showed the same voltage.... I am talking about up to 2.8 volts variance in > digital readouts ......... What kind of battery did you have on the alt.? With minimal filtering by the battery it's not surprising to see that, but if you had a full sized battery on line even the 'cheapies' should be more accurate than that. Charlie ________________________________________________________________________________
Date: Jan 27, 2000
God forbid if you ever crash landed, your pin (as described) would prevent help personnel from extracting you from you aircraft. They could beat their way to you but that would take time & your head is just 2 inches from the canopy. smokyray(at)yahoo.com on 01/26/2000 06:45:53 PM Please respond to rv-list(at)matronics.com Subject: RV-List: Re: RV4-List: RV-4 canopy latch Hi J; I used a pin from the nautilus weight room that holds the weights in the stack. I drilled a hole in my roll bar through the canopy bulkhead at a point on the entry side that left the canopy about 3 inches "above the rim" with the pin in. I used plastic bushings in the hole in the roll bar just like the ones for the rudder cables and drilled the pin so I could put a small cotter key and washer 2 inches from the end. Now I simply slide it into the hole in the canopy bulkhead on the ground and pull it back when I shut the canopy. It slides about 3 inches stop to stop. The cool part is when the canopy is down, the pin slides backwards OVER the top of the bulkhead preventing opening if the canopy lock should fail. See ya. Rob Ray smokyray(at)yahoo.com --- "J. Rion Bourgeois" wrote: > --> RV4-List message posted by: "J. Rion Bourgeois" > > > I am at the decision point for my RV-4 canopy latch > mechanism. I would like > to use the standard latch mechanism in the plans, > but it does not provide > for a partially open position for ground operations. > I have heard a rumor > about a builder in the Seattle area who has designed > a safety latch that > allows use of the standard canopy latch and has a > partially open position. > Does anyone have his address and phone number or any > suggested solutions? > Thanx, Rion > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > Talk to your friends online with Yahoo! Messenger. http://im.yahoo.com ________________________________________________________________________________
Date: Jan 27, 2000
Greg, your right. The Scope showed noise and that triggers the cheap meters to indicate false readings. I used a big old car battery as my "filter capacitor" and the noise in was abaited. gyachts(at)kans.com on 01/26/2000 07:55:48 PM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: Voltage Regulator/Voltage meters If you placed a small battery or no battery to load and filter the current coming from alt it will be very noisy which tricks the 'cheap' meters into false DC reading. Switch over to AC and see if you get a reading, if so then there is lots of noise. Better yet look at it with the oscilloscope in the 250ms setting and look for noise. You would be surprise and the noise that comes from alternators. Greg ________________________________________________________________________________
Subject: Re: Primer lines/manifold press.
Date: Jan 27, 2000
Mark Most recent Lycoming cylinders do have 2 ports in them. I also am planning a 4 port primer system for the very reason you mention so I just removed the other blanking plug (#1102) from my #3 cylinder to add a manifold pressure pick up. It should not be necessary to do any welding. email me direct if you need any more info. Regards Ian RV6 G-RVIB Fitting Canopy http://www.belmorerentals.com ----- Original Message ----- From: Mark Phillips <ripsteel(at)edge.net> Sent: Thursday, January 27, 2000 2:11 PM Subject: RV-List: Primer lines/manifold press. > > Would it not be possible to connect the manifold pressure guage > somewhere else, such as into one of the intake tubes, allowing all four > primer lines to be used? Seems a small fitting could be tig-welded near > the cyl head for this. One of my favorite stories from "Great American > Fighter Pilots of WWII" I read as a kid was about a P-51 pilot that got > his fuel pump shot up over Europe, and literally wore his hand down to > the bone using the manual primer to return to England. Using all four > primer lines and a manual primer might make a useable backup in the > event of fuel pump and electrical failure (however unlikely). I'm a > long way from having to do this, but this thread's got me thinking...(oh > no!) > > From the PossumWorks > Mark > > ________________________________________________________________________________
Date: Jan 27, 2000
Subject: Re: Prop Balancing/Conical Mounts
Re-posted for future search/hits ve7fp(at)jetstream.net on 01/26/2000 11:36:13 PM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: Prop Balancing : Re: RV-List: Prop Balancing > > . If indeed the rubbers are shot >you could tell by the sag...at any rate the rubbers are very cheap (wag aero >among others) for the conical motor. Please don't use the cheap rubber mounts!! I have a set I will give you free ( you pay postage) I went through 4 years of engine roughness, damn near tore the engine apart, changed carbs, had the prop. checked and they couldn't improve on it ( done at 2500 RPM). The roughness showed up below 2500 rpm and also very noticeable on final when power was being reduced to maintain 85-90 mph. In Oct. 98 Mark Todd and Mike Seager helped me (through this list) pin down my problem. DON'T USE THE CHEAP ENGINE MOUNTS WITH THE CONICAL ENGINE MOUNT! Bite the bullet and buy the Lord 6230-1 mounts ( my engine is a 0 320 B3B ) with the Hartzell C/S. I cannot speak for other conical mount lycoming models or if this problem would not occur with a wooden prop. but if you are using my combination save yourself a lot of grief and get the correct mounts. You wouldn't believe you were flying in the same airplane. An aside, the only cowling hinge pin that broke was the pilot side cowl cheek hinge. All top, side,and bottom pins still okay after 300 hours. Fly Safely Ken Hoshowski RV6 C-FKEH Salmon Arm B.C. Temp. 32 , 15" of snow on the lawn ________________________________________________________________________________
Date: Jan 27, 2000
In a message dated 1/26/2000 10:27:00 PM Eastern Standard Time, khorton(at)cyberus.ca writes: > Ken, > > You don't want to cinch the tank skins on now, as the skeleton is not > strong enough to take the loads. It gets a lot stiffer once the > skins are clecoed on. > > So, rivet the ribs, drill and cleco the skins, drill and cleco the > O/B leading edge, drill and cleco the tanks, then drill the lower > platenut holes. I drilled them to #30, and did the final drilling > after the tank was all finished. It was not too hard to rivet the > lower platenuts on at the end. I was careful to get the inner few at > a good angle to facilitate riveting. In some cases it seemed to make > sense to use a different angle than that shown on the drawings. Just > think about riveting access when you drill the rivet holes, thats all. > > Take care, > > Kevin Sounds like a plan. The steps are pretty much in the order I imagined, with the exception of drilling and clecoing on the skins to provide the skeleton with necessary stiffness. I wish I'd thought about it a little longer before clogging bandwidth. It should have been obvious. Oh, well -- it probably won't be the last time. :-) Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Subject: The fuel primer system that almost was.
Date: Jan 27, 2000
I bought one of those cool primer solenoids from ACS, plus all the fittings and tubing to make a three-cylinder primer system. I installed the pushbutton switch in the cockpit and ran the lines into the engine compartment. I then spoke with one of my friends with an opinion on everything and the credentials to back it up (10,000 hr. ATP, A&P, IA, CFII, Completed RV-6, etc.) His advice was to leave the primer system out of the plane. Since the carburetor on my O-320 has a built in pump to spray fuel into the intake manifold, it was likely I would have no starting troubles except in the coldest conditions. Therefore the addition of a bunch of copper tubing in the engine compartment filled with AVGAS was unnecessary. I have about 500 hours in Cessna 172 airplanes and can't remember the last time I needed a primer to start the engine (here in Southern California). I also thought about the Electric Bob argument of using the primer system to keep the engine running. Although Bob is the author of my electric system (God Bless him) I determined that the incident he refers too was one of those 10 -9 events. So, I left the wiring in, removed the switch and put a hole plug in the panel, removed the solenoid, put plugs in the cylinder primer holes, and we'll see if I need a primer system. If I do then all the under-the-panel work is done and I can install it later. -- John Allen Moving to the airport for final assembly fliier(at)onebox.com - email Sign Up Now! http://www.onebox.com ________________________________________________________________________________
Date: Jan 27, 2000
If the wings are off like you indicated then run a piece of wood laminated to the proper thickness thru the spar plate area of the fuse. Get some metal saw horses & suspend the fuse from the wood outriggers. Use the spar bolts to secure to the fuse. dgmurray(at)telusplanet.net on 01/27/2000 12:45:35 AM Please respond to rv-list(at)matronics.com Subject: Re: RV-List:fuselage support Listers: My thinking cells are going into overload with this one. (maybe it's old age catching up). I am ready to start installing the gear leg fairings and wheel pants. In order to do this I need to lift the fuselage off the ground so the legs are unloaded. I have the engine installed and so the fuselage is getting heavy. I want to lift the fuselage just under the main spar hole but realise that the tail will be too light to balance out the weight. I think that a couple sand bags will do the trick but would appreciate some input from those of you who have been there and done that. Does any one have pictures of the jig that will hold a mostly completed airframe less wings off the ground? I sure would like to get this part done. I'm getting close enough to seeing the project completed now. Thanks in advance, Doug Murray RV-6 Southern Alberta ________________________________________________________________________________
Date: Jan 27, 2000
Subject: Re: Conical engine Lord mounts (was: Prop Balancing)
Ken Hoshowski wrote: "... DON'T USE THE CHEAP ENGINE MOUNTS WITH THE CONICAL ENGINE MOUNT! Bite the bullet and buy the Lord 6230-1 mounts ( my engine is a 0 320 B3B ) with the Hartzell C/S. I cannot speak for other conical mount lycoming models or if this problem would not occur with a wooden prop. but if you are using my combination save yourself a lot of grief and get the correct mounts. You wouldn't believe you were flying in the same airplane...." Just a quick follow-up report on the Lord 6230-1 mounts in my RV4 (160 HP Hartzell CS much like Ken's). I now have 250+ hours on these mounts (lots of +5/-1G acro) and haven't felt any loss of the vastly superior dampening qualities so far. I'm encouraged that they will last a reasonable amount of time. Obviously, dynamic prop balancing comes first, but even with my prop/ engine balanced to 0.14 ips, the benefit of the Lord mounts was dramatic. Personally, I will never go back to the "cheap" conical bushings. Not so cheap when you consider I was replacing them every 150-200 hrs! Mark RV4 owner KAWO ________________________________________________________________________________
Subject: Re: The fuel primer system that almost was.
Date: Jan 27, 2000
All I'll add is there's a big difference starting an airplane in Southern California than in the frozen tundra of the Midwest. I've never been able to get one started in the winter without a primer of some sort. I'm sure it can be done, but it's a whole lot easier with a primer. Using the accelerator pump on the carb is another matter completely. This is not a very good substitute for a primer. It may work in cooler weather, but it doesn't put the fuel where it needs to be (in the cylinders). It also opens up the possibility of backfiring and pooling of fuel in the intake. Again, it can be done, is done, and all without problems. But with some risk. As with all decisions on our birds, follow those that make sense for your particular application and discard those that don't . Randy Pflanzer N417G RV-6 "Painting" > >snip > >I then spoke with one of my friends with an opinion on everything and >the credentials to back it up (10,000 hr. ATP, A&P, IA, CFII, Completed >RV-6, etc.) His advice was to leave the primer system out of the plane. >Since the carburetor on my O-320 has a built in pump to spray fuel into >the intake manifold, it was likely I would have no starting troubles >except in the coldest conditions. Therefore the addition of a bunch >of copper tubing in the engine compartment filled with AVGAS was unnecessary. > >snip >-- >John Allen >Moving to the airport for final assembly >fliier(at)onebox.com - email > ________________________________________________________________________________
Subject: SourceRV Content
Date: Jan 27, 2000
To all the sourceRV subscribers out there. sourceRV has made a special "6th Issue" of the RVator avaliable that will not be avaliable to regular subscribers until after February. Thought I'd pass it along. Mike Nellis (N699BM) reserved http://mnellis.jnet.net/rv-6_page Plainfield, IL ________________________________________________________________________________
Date: Jan 27, 2000
Subject: DFW seminar date set . . .
Program date for George and Becky's hangar in Ft. Worth has been set for June 3/4 See http://www.aeroelectric.com/seminars.html Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
From: "Ollie Washburn" <skybolt-aviator(at)msn.com>
Date: Jan 27, 2000
Hi One word of caution;if you over pump the throttle and get a bunch of fuel in the induction system and the eng. backfires you can get one H--- of a carb. fire.Not likely but possible. Ollie-RV6-A Flying Tampa ----- Original Message ----- From: John Allen <fliier(at)onebox.com> Sent: Thursday, January 27, 2000 11:21 AM Subject: RV-List: The fuel primer system that almost was. > > I bought one of those cool primer solenoids from ACS, plus all the fittings > and tubing to make a three-cylinder primer system. I installed the pushbutton > switch in the cockpit and ran the lines into the engine compartment. > > I then spoke with one of my friends with an opinion on everything and > the credentials to back it up (10,000 hr. ATP, A&P, IA, CFII, Completed > RV-6, etc.) His advice was to leave the primer system out of the plane. > Since the carburetor on my O-320 has a built in pump to spray fuel into > the intake manifold, it was likely I would have no starting troubles > except in the coldest conditions. Therefore the addition of a bunch > of copper tubing in the engine compartment filled with AVGAS was unnecessary. > > > I have about 500 hours in Cessna 172 airplanes and can't remember the > last time I needed a primer to start the engine (here in Southern California). > > I also thought about the Electric Bob argument of using the primer system > to keep the engine running. Although Bob is the author of my electric > system (God Bless him) I determined that the incident he refers too was > one of those 10 -9 events. > > So, I left the wiring in, removed the switch and put a hole plug in the > panel, removed the solenoid, put plugs in the cylinder primer holes, > and we'll see if I need a primer system. If I do then all the under-the-panel > work is done and I can install it later. > > -- > John Allen > Moving to the airport for final assembly > fliier(at)onebox.com - email > > > Sign Up Now! http://www.onebox.com > > ________________________________________________________________________________
Subject: skin priming for unpainted RV
Date: Jan 27, 2000
I have searched the archives but couldn't find an answer to this question. I would like to keep the option of not using a colored top coat on the exterior of my RV although I would probably use a clear coating like an Airstream trailer to keep polishing to a minimum. I am about to start my first priming session on the H.S. parts using the 3 step etch/alodine/epoxy primer system. I will use the tinted alodine on the skeleton and I was planning on using clear alodine on the inside of the skins so that if any dripped through the dimpled holes, it would not stain the exterior. Should I etch and clear alodine both sides of the skin or try to keep everything off the exterior as much as possible? If I get any epoxy primer overspray on the exterior, will I be able to remove it without destroying the alclad surface? I am using a MIL-P-23377F Type I Class 1 yellow primer applied with a Sharpe Cobalt HVLP gun. Chris Heitman RV-9A Just finished building paint booth ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Subject: FW: Engine monitor
Date: Jan 27, 2000
Just in case anyone else might be interested I am forwarding the Engine Monitor information I received from Rob Hickman. I liked the looks of his engine monitor and requested info. The monitor may be viewed here: http://hometown.aol.com/robhickman/index.html <http://hometown.aol.com/robhickman/index.html> Here's the info: -----Original Message----- From: RobHickman(at)aol.com <mailto:RobHickman(at)aol.com> [SMTP:RobHickman(at)aol.com] Sent: Wednesday, January 26, 2000 6:57 PM Subject: Re: Engine monitor ACS 2000 Aircraft Monitoring System The ACS 2000 is a complete aircraft monitoring and data acquisition system designed for aircraft with a 4 or 6 cylinder engine. The system continuously monitors and displays all of the aircraft engine data on a 4.7" DMTM active matrix LCD display. The system is constantly checking the current engine readings against user adjustable set points. If any of the engine readings are out of the limits a bright yellow or red LED will start blinking indicating a Caution or Warning fault and the affected gauge will flash. The display is completely sunlight readable and has an adjustable backlight for night operations. Unlike most LCD displays the screen is viewable from almost any angle in the aircraft. Unlike other systems, the display can be customized to the user's preference. Any of the standard instruments can be eliminated or added to the screen. The system also supports two different instrument configurations: analog and digital or digital only. Also unique to the ACS 2000 is the user check lists and parameters that can be adjusted using the supplied PC software and PC to ACS 2000 communication cable. Engine Functions Range Manifold Pressure 0 to 31.0 inhg RPM 0 to 3500 rpm Fuel PSI 0 to 50 psi GPH 0 to 30 gph Oil PSI 0 to 100 psi Oil Temperature 20 to 250 F Volts 8 to 30 V Amps 0 to 100 amps Outside Air Temp -50 F to 125 F Exhaust Gas Temperature 200 to 1800 F Cylinder Head Temperature 100 to 600 F % Power 0 to 100 % Carburetor Temperature 20 to 40 F Tachometer Time Hobbs Time Fuel Tank Functions The fuel tank levels are calibrated on installation in 2 gallon increments to correct for sender position. The fuel gauges store two calibration tables, one for plane level and one for tail down. Unlike other instruments the fuel gauges will read correct for a tail wheel airplane when it is on the ground as well as in level flight. Tank Left Level Tank Right Level Gallons Used Gallons Left Aircraft Functions Flap Position Elevator Trim Position Aileron Position 4 user inputs Canopy Latched User 2 User 3 User 4 Flight Time Local Time GMT Time 4 User Check Lists with 10 items each Features Separate data processing module for easy wiring 1" Deep remote screen unit EGT/CHT Bar Chart or Digital Display Price Estimated price is approximately $3000 including sensors Current Status The first system has been flying for over 25 hours in our RV-4 with great success. I am currently installing a second system in an RV-6A for further testing. We are currently working on adding the % power function to the first system for further testing. We are also currently working on solid needles for the instruments. Delivery July 2000 Rob Hickman Advanced Control Systems Inc. ________________________________________________________________________________
Date: Jan 27, 2000
Ken, You are not clogging anything. I am finishing up my spar and getting ready to do the same thing you are doing. The response that Kevin Horton gave will in all likelihood save me a great deal of time as he outlined the process. If nothing else, it will offer me a good feeling of security that I had the sequence right. Most of us "novice" builders have a lot of the same questions. Your question to the list may have saved me one later. Thanks, Keith Hughes RV-6 wings Parker (snow covered!), CO Kbalch1(at)aol.com wrote: > Sounds like a plan. The steps are pretty much in the order I imagined, with > the exception of drilling and clecoing on the skins to provide the skeleton > with necessary stiffness. I wish I'd thought about it a little longer before > clogging bandwidth. It should have been obvious. Oh, well -- it probably > won't be the last time. :-) > > Regards, > Ken Balch > Ashland, MA > RV-8 #81125 > wings ________________________________________________________________________________
Date: Jan 27, 2000
> > > Ken Hoshowski wrote: > "... > DON'T USE THE CHEAP ENGINE MOUNTS WITH THE CONICAL > ENGINE MOUNT! > Bite the bullet and buy the Lord 6230-1 mounts ( my > engine is a > 0 320 B3B ) with the Hartzell C/S. I cannot speak > for other conical > mount lycoming models or if this problem would not > occur with a wooden > prop. but if you are using my combination save > yourself a lot of grief > and get the correct mounts. You wouldn't believe > you were flying in the > same airplane...." > > Just a quick follow-up report on the Lord 6230-1 > mounts in my RV4 (160 > HP Hartzell CS much like Ken's). I now have 250+ > hours on these mounts > (lots of +5/-1G acro) and haven't felt any loss of > the vastly superior > dampening qualities so far. I'm encouraged that > they will last a > reasonable amount of time. > > Obviously, dynamic prop balancing comes first, but > even with my prop/ > engine balanced to 0.14 ips, the benefit of the Lord > mounts was > dramatic. > > Personally, I will never go back to the "cheap" > conical bushings. Not > so cheap when you consider I was replacing them > every 150-200 hrs! > > Mark > RV4 owner > KAWO > I am using the CHEAP Lycoming part number conical mounts O-320 B2B and I am having NO problem. Hartzell Prop was balanced after 180 hours. I do not have any sagging or vibration problem. Where were you getting these cheap non-Lycoming conical mount bushings? My Lycoming part number bushings came from Wag-Aero as they had the BEST price (~$25 for the set). Where are you purchasing the Lord part number and how much? This is the first I have hear of someone getting imitation Lycoming bushings. Everyone that I know that have used the Lycoming part number bushings have not had these problems. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, Flying So. CA, USA Talk to your friends online with Yahoo! Messenger. http://im.yahoo.com ________________________________________________________________________________
From: "Gordon or Marge Comfort" <gcomfo(at)tc3net.com>
Date: Jan 27, 2000
From: John Allen <fliier(at)onebox.com> : Thursday, January 27, 2000 4:46 PM The fuel primer system that almost was. >I bought one of those cool primer solenoids from ACS, plus all the fittings >and tubing to make a three-cylinder primer system. >So, I left the wiring in, removed the switch and put a hole plug in the >>John Allen John: If you ever go anywhere that a primer is needed, please do not depend on the accelerator pump to start the engine. A friend of mine attempted a cool weather start on a 150hp Lyc that way and set fire to the engine (Mustang II). Fortunately he recognized what was happening, was able to exit the aircraft, run for a fire extinguisher and put out the fire. The cowl needed repair. Fortunately the engine and other mechanicals did not. If you have ever watched one of those carbs squirt you can see that some of the fuel comes straight back down into the airbox. Cranking while you pump might help but the risk is not insignificant. Additionally, I found that 3 cylinder priming with the solenoid and Facet fuel pump to work better than 4. Don't know why but suspect that in my system, with 1/8th inch lines from the valve, the nozzle pressure is too low when 4 lines are being fed. Gordon Comfort N363GC ________________________________________________________________________________
Date: Jan 27, 2000
Subject: Fuel Cap Update
Listers I have received alot of caps. I had planned on getting started on them monday but I have had a death in the family so want be able to start until after this weekend. Sorry if this causes any problems but couldn't be helped. Thanks to all who sent them in. Thanks Steve ________________________________________________________________________________
Date: Jan 27, 2000
I placed my fuse blocks on the rear wall of the baggage compartment (front) and it will have a clear plexi cover. Obviously can't get to it in flight. To resolve the problem below, the panel lights are off the main buss and then I used the Aeroelectric map lights from an independent source - the essential buss. Third backup is a flashlight. Jeff Farrar, RV8A N4ZF reserved, Chandler, AZ jfarrar1(at)home.com Wings done, fuselage almost, fuselage interior and wiring ----- Original Message ----- From: Japundza, Bob <bjapundza(at)dowagro.com> > Ever have a fuse blow at night? I have...and it was the fuse to the panel > lights in a Cherokee 235... > From: Sam Buchanan [mailto:sbuc(at)hiwaay.net] > Sent: Tuesday, January 25, 2000 10:36 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Source for fuse blocks that take auto fuses > Okay, I'm going to play the part of troll here. > > Why do the fuses have to be accessible in flight? > > Sam Buchanan (RV-6, fuses tucked behind panel) > "The RV Journal" http://home.hiwaay.net/~sbuc/journal ________________________________________________________________________________
Date: Jan 27, 2000
Subject: Re: Empenage Kit
Eustace, Yesterday you posted the RV 6 empennage for sale by Bob Spencer. I answered that I would take it because you vouched for the workmanship. I am sure that I had to be the first email you got because I answered almost immediately.Your respnse with Bob's number came a bit later. I called Bob today and he told me I was 3 on the list. I am sure that I contacted you first but maybe when you gave him the list of those who emailed he got mixed up. If possible, could you check the date and times of the emails you received because I delayed calling until tonight because I thought we had a deal. Sorry for the inconvenience but fair is fair. I am leaving for vacation to Fla in the morning and will check my email tromorrow night or if Bob agrees he can call me and I will pay for the call. Thanks, Gary Palinkas GLPalinkas(at)aol.com Parma, Ohio RV 6 QB 216 496 0805 ________________________________________________________________________________
Subject: Re: Wiring Wig-Wag
Date: Jan 27, 2000
Rick, I have the FS020 and I think the two wires you refer to are the red and black. Safe off the black, you don't need it. It is used to override the wig wag function in nitetime use. The red wire is the trigger circuit that enables the wig wag action. Hope this helps. Jeff Farrar, RV8A N4ZF reserved, Chandler, AZ jfarrar1(at)home.com Wings done, fuselage almost, fuselage interior and wiring. ----- Original Message ----- From: Rick Caldwell <racaldwell(at)hotmail.com> Sent: Tuesday, January 25, 2000 10:25 AM Subject: RV-List: Wiring Wig-Wag . Then there are two wires that go to the "wiring harness" of > the auto this thing is supposed to be installed in. Do I need these two > wires connected, and if so, where do they go? > > Thanks, > Rick Caldwell > RV-6 N136RC 2.3 hrs > Melbourne, FL ________________________________________________________________________________
Subject: Two speed prop
Date: Jan 27, 2000
Does anyone on the list have any info on an electrically controlled two speed prop? John Harris RV9A N901RV (reserved) ________________________________________________________________________________
Date: Jan 27, 2000
Subject: winter updates
Winter is here and I have made some updates in 399SB. They include the following: 1) Reiff Hotpadd oil sump heater 2) Aileron pushrod boots 3) Stuffed the Muff Oldtimers will have seen these items before, but if you are still building (or this is your RV's first winter) you may want to check out this page: http://home.HiWAAY.net/~sbuc/journal/cold.html Man, its cold out there! Sam Buchanan "The RV Journal" http://home.hiwaay.net/~sbuc/journal ________________________________________________________________________________
Date: Jan 27, 2000
Hi Gary: I posted Bob's kit on the 25 th at 7:26 PM, the first reply was at 8:55 another at 9:29 then one at 7:35 AM on the 26 th and the last one yours at 12:02 PM . Know this won't make you feel any better but these are the actual times. Eustace Bowhay Do not achieve ---------- > From: GLPalinkas(at)aol.com > To: rv-list(at)matronics.com > Subject: Re: RV-List: Empenage Kit > Date: Thursday, January 27, 2000 6:30 PM > > > Eustace, > > Yesterday you posted the RV 6 empennage for sale by Bob Spencer. I answered > that I would take it because you vouched for the workmanship. I am sure that > I had to be the first email you got because I answered almost > immediately.Your respnse with Bob's number came a bit later. I called Bob > today and he told me I was 3 on the list. I am sure that I contacted you > first but maybe when you gave him the list of those who emailed he got mixed > up. If possible, could you check the date and times of the emails you > received because I delayed calling until tonight because I thought we had a > deal. Sorry for the inconvenience but fair is fair. > > I am leaving for vacation to Fla in the morning and will check my email > tromorrow night or if Bob agrees he can call me and I will pay for the call. > > Thanks, > > Gary Palinkas > GLPalinkas(at)aol.com > Parma, Ohio > RV 6 QB > 216 496 0805 > > > ________________________________________________________________________________
Date: Jan 27, 2000
Subject: Carb problems need help
I recently did the annual on RV6 (flying 4 years) and found that the carburetor bowl was loose. I pulled it off smeared some fuel valve lube on the gasket to seal it and tightened every thing up. Prior to this it ran fine. Now it runs too lean. nearly 1400 deg. at cruise power settings, mixture full rich. This represents 100 deg. or more increase. Anyone have any ideas on this? Bud ________________________________________________________________________________
Date: Jan 27, 2000
Date: Jan 27, 2000
I just took a 20"x3/4"x3/4" angle and hung it in the middle. Used a pinch type clothes pin to balance the bar by moving it as needed. Then put 10 large nuts in a cup and a cup of Sealant A in the other end, adding and removing material as required to balance the beam. Then put one more large nut in the cup and added Accelerator type B to the other cup and balanced as needed. If you carefully add the Sealant B material you can remove some if needed. I also improvised a bit and came up with 10 small nuts that equal one large nut in weight. Thus if I weighed in Seal Type A of only 6 nuts worth of weight, putting in 6 small nuts in the cup and adding Sealant B material to the other cup gave me flexibility to mix whatever quantity needed. Maybe my mix wasn't all that accurate, but in the end, it all hardened up and so far my tanks have passed the leak test. I used plastic spoons to dip into the can to get sealant material and a plastic knife to spread on surfaces. The serrated knife worked very well to smear thin coats on the tank baffle as Scott McDaniel so advised and I'm happy with the way it turned out. For cups, I cut down plastic Yogurt cups until only 1" deep. small, but enough for my slow building. Just my 10 cents. Marty in Brentwood. Wings almost, fuselage kit due in any day. ----- Original Message ----- From: Doug Gray <doug.gray(at)hlos.com.au> Sent: Thursday, January 27, 2000 10:51 PM Subject: Re: RV-List: Proseal measuring balance > > Excellent suggestion. I think I would prefer to hang something from > single points on the balance arms to be certain that the ratio is > unaffected by the position of the goop. The 11 'calibrated' bolts idea > is perfect. > Thanks, > Doug > > > > > > Here is a simplistic way. > > Get a stick between 12 and 20 inches long. Tape, nail or glue a 3 inch > > pad on each end. Get eleven bolts or nuts or some such of that weigh the > > same. Put ten on one pad and the last one on the other pad. Now balance > > the stick on something so that it sits level with the world. Many ways to > > do this. > > Now take the bolts or nuts off the pads. Replace the one bolt with the > > black stuff and the ten bolts with the white stuff. 10:1 > > Me??? I use a very accurate balance beam at the office that I mix ink on. > > Cecil Hatfield > > Thousand Oaks, CA > > > > >>Can someone tell me where I can find a picture of the 10:1 balance to > > >>weigh out the proseal? > > >> > > >>Doug Gray > > > > ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Re: e-mail change
Sam, Just in case you want to get in touch as you approach the AZ. trip. My new e-mail; ronvandervort(at)aol.com is now in place. I won't know my new phone # for a few days yet. Ron V ________________________________________________________________________________
Subject: Lamb tires
Date: Jan 27, 2000
Anyone using Cheng-Shin (Also known as "Lamb" tires) for the mains on a RV-3,4,8..etc? I would like to know what kind of wear to expect from them, and if they are worth the extra pounds saved over standard 500x5's. THX Chris ________________________________________________________________________________
Subject: Routing of wires in RV-8\8A
Date: Jan 28, 2000
Having chosen to use the Nuckolls approach to wiring my 8A using fuses, 2 alternators and one battery, I'm deliberating where to locate certain things and would appreciate opinions and suggestions. 1. Firewall ground block. Next to the battery tray? Middle of the firewall between the rudder pedals? 2. Routing of the 4AWG wire from the battery contactor to the main power distribution bus, specifically with regard to where it penetrates the firewall. 3. Should both main power and essential buses be located on that little shelf on the aft side of the forward baggage compartment? Thanks, Jerry Carter 8A QB Planning Wiring ________________________________________________________________________________
From: "J. Rion Bourgeois" <rion(at)worldnet.att.net>
Subject: canopy latch
Date: Jan 27, 2000
Mike: Wow! I'm impressed! Very elegant solution! Your workmanship looks great too. Let me know if you kit it. Is the hole for the pin for the roll bar exactly perpendicular to the bar, or is there any angle? I assume the slot in the pin end of the bellcrank is to compensate for any angle problems. What is the prop pin made of? Is that safety wire at the end? Thanx for all your trouble. Rion ________________________________________________________________________________
(Content Technologies SMTPRS 2.0.15) with SMTP id for" ; Fri, 28 Jan 2000 08:03:02.-0500(at)matronics.com
Date: Jan 28, 2000
If someone wants an empenage or an empenage and set of wings (RV-6) built by a third time offender there is one for sale in Florida. The workmanship is as good as it gets, both wings and tail are DONE. Will sell for the price of the kit, he built them to alieviate boredom. What a deal! Phlogiston will charge you ten grand for a set of completed wings. These are built for free. Contact off list, Tom Benton @ TMB1564(at)aol.com "Eustace Bowhay" on 01/27/2000 11:09:38 PM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: Empenage Kit Hi Gary: I posted Bob's kit on the 25 th at 7:26 PM, the first reply was at 8:55 another at 9:29 then one at 7:35 AM on the 26 th and the last one yours at 12:02 PM . Know this won't make you feel any better but these are the actual times. Eustace Bowhay Do not achieve ---------- > From: GLPalinkas(at)aol.com > To: rv-list(at)matronics.com > Subject: Re: RV-List: Empenage Kit > Date: Thursday, January 27, 2000 6:30 PM > > > Eustace, > > Yesterday you posted the RV 6 empennage for sale by Bob Spencer. I answered > that I would take it because you vouched for the workmanship. I am sure that > I had to be the first email you got because I answered almost > immediately.Your respnse with Bob's number came a bit later. I called Bob > today and he told me I was 3 on the list. I am sure that I contacted you > first but maybe when you gave him the list of those who emailed he got mixed > up. If possible, could you check the date and times of the emails you > received because I delayed calling until tonight because I thought we had a > deal. Sorry for the inconvenience but fair is fair. > > I am leaving for vacation to Fla in the morning and will check my email > tromorrow night or if Bob agrees he can call me and I will pay for the call. > > Thanks, > > Gary Palinkas > GLPalinkas(at)aol.com > Parma, Ohio > RV 6 QB > 216 496 0805 > > ________________________________________________________________________________
Date: Jan 28, 2000
Hi Eustace, I appreciate the effort. I thought maybe there was a pdt/mdt/edt problem because us east coasters usually suffer from that. (I'm sleeping/your'e not+visa-versa) Bob also told me a builder he knows who has a partially completed kit but is not active with it. He will check to see if he would be willing to part with the empennage. Thanks again for the try. Had to check my email before I left for Fla.....wife is staring at me suspiciously now. Gary Palinkas GLPalinkas(at)aol.com Parma, Ohio RV 6 QB 216 496 0805 ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Re: Two speed prop
--- John Harris wrote: > > Does anyone on the list have any info on an electrically controlled > two > speed prop? John, I posted a similar question some months ago, got little to no response. I fly a Grob motorglider with a manual (lanyard) two speed prop - seemed (and seems) like a great compromise between constant speed and fixed for the RV. The Ivanho props have quite the poor reputation - I don't know how much is deserved (currently) and how much is history... I guess no one wants to risk their plane and butt to find out. Seems the natural, inexpensive two-speed prop is not to be had for our class of machine. Mike Thompson Austin, TX -6 N140RV (Reserved) Wings Talk to your friends online with Yahoo! Messenger. http://im.yahoo.com ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Standardized List Sales
In light of recent posts and my own experience I am wondering if anyone else would be interested in me writing up a set of rules governing sales on the RV-List. I would not presume to dictate what is being sold only the method of responding to the offer. I think too often sellers just sell to the nearest guy to make shipping easier. If that is their policy then they need to state that in their original post. Otherwise it should be first respondent to accept the offer. We can have acceptances timed and dated directly to the list so we all know who it was and others don't have to respond knowing that three or four already have. They can add "do not archive" to there messages to save the space. I usually keep 2 or 3 months of messages in my trash bin so I could most likely retrieve one in case of a dispute. I would post the suggested rules for review of any of you who care to respond and give input then ask Matt to add it to the FAQ and put it in the rotation of list policy notices. Any interest? AL Matt do you think this would be a good idea? ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <stuckle(at)IFC.UTC.COM>
Subject: Aileron Boots
Date: Jan 28, 2000
Sam, Glad to see that the aileron boots worked out for you too. They sure do make a difference, don't they.... I tried the stainless scrubby in the heat muff trick too and I agree with your results - not so good. They seem to have slowed the airflow down too much. What came out was warm, but there just wasn't enough of it in cold weather. What I did do that worked much better was to make a spring out of the .020" stainless tie wire by winding it up onto a 1/4" dowel driven by a drill. With the Robin William heat muff ends in place on the exhaust pipe, the spring was wrapped around the exhaust pipe, with its ends attached to the heat muff ends. The heat muff cover was then installed. Some areas of the spring had to be crushed a bit to due to the offset center muff design. This system now allows much more air, all of it very warm, into the cockpit. I've flown in -10*F temps lately, and didn't need a jacket (while flying).... Of coarse, any heater is only as good as the canopy seal and lack of other air leaks...... Fred Stucklen N925RV RV-6A E. Windsor, Ct ____ From: Sam Buchanan <sbuc(at)hiwaay.net> Subject: RV-List: winter updates Winter is here and I have made some updates in 399SB. They include the following: 1) Reiff Hotpadd oil sump heater 2) Aileron pushrod boots 3) Stuffed the Muff Oldtimers will have seen these items before, but if you are still building (or this is your RV's first winter) you may want to check out this page: http://home.HiWAAY.net/~sbuc/journal/cold.html Man, its cold out there! Sam Buchanan "The RV Journal" http://home.hiwaay.net/~sbuc/journal ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Date: Fri, 28 Jan 2000 09:15:25 -0600
I am ready to start installing the gear leg fairings and wheel pants. In order to do this I need to lift the fuselage off the ground I put my gear, pants and everything else on while the fuselage was still upside down in the jig. Worked great...much easier that jacking up the whole mess and crawling around on the floor. Not much help if you're already past that point though... Vince ________________________________________________________________________________
Date: Jan 28, 2000
I had the pleasure of meeting Ron out at my airport the other day. (DVT) Saw his RV6 pull up and had to go say hi. Real nice guy and a beautiful RV!!! Welcome to the neighborhood. Larry Olson > >Sam, > >Just in case you want to get in touch as you approach the AZ. trip. My new >e-mail; ronvandervort(at)aol.com is now in place. > >I won't know my new phone # for a few days yet. > >Ron V ________________________________________________________________________________
Subject: Electric Flap Retrofit to RV-4
Date: Jan 28, 2000
Hi all, I have been lurking pretty much for the last 6 months. I am a student pilot who made the mistake of going for a ride in an RV-4. Once I got the ride I HAD to have one. While I did take the easy way out (bought instead of built) I have been faithfully reading the list every day while going through the plane with a fine toothed comb. I owned the plane for 3 months before ever going flying in it. Durring that time I installed the rear rudder pedal kit, and rear throttle. I checked for compliance with Vans service bullitins. (Carb airbox safety wire bolt SB was not done) Spent many hours trying to remove the spinner screws so I could retorque the prop, only to learn that I don't have to remove the spinner. Spent countless hours trying to figure out what an "A N What???" was. Replaced marginal rubber hoses running to the oil cooler with fancy stainless braided aeroquip hoses. (don't start a thread on stainless braided hoses. I used them for years on race bikes and vintage race cars and never had a problem) I am currently taking tailwheel/transition instruction with Joe Gauthier and we have made the necessary mods for instruction. (rear rudder pedals and rear throttle) I like simple mechanical things. I have no interest in electric aleron or elevator trim, and I thought the manual flaps would be fine also. That was until Joe and I actually tried to use them. Cant get them fully extended until well below 80mph without fiddling around with them. Like I said, I am still a student (50 hrs, checkride in C152 within the next month or so)but even I know that when I'm 400ft AGL with the power off, I shouldn't be farting around with a lever that flexes and twists in my hand. (can you say "stall/spin") I have come to the conclusion that I want to put in the electric flaps. I would like input on the following items: 1) Are my flaps representative of RV-4s in general. Are most of them a pain? In the near term, I am putting a big handle on it to help a bit. 2) How much trouble is the electric flap retrofit kit. I am very mechanical and feel totally comfortable tearing an engine appart, but can not read plans to save my life. I am sure I will spend many hours looking at the plane and figuring how to do it, as well as getting up the nerve to actually start. I do have the help of RV builders Dave and Ed Peters. (The nicest RV-4 I have ever seen) That's it. This list has been both HORRIBLE and Fantastic. Horrible because it confirmed what I knew when I went for a ride in an RV and therefore FORCED me to buy one of these machines. And fantastic for all the tips that I have picked up over the last 6 months. Best regards, Don Mei RV-4 N92CT (Builder Mark Taylor) Essex, CT ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Re: Carb problems need help
In a message dated 1/27/0 22:08:30, bud(at)softcom.net writes: I recently did the annual on RV6 (flying 4 years) and found that the carburetor bowl was loose. I pulled it off smeared some fuel valve lube on the gasket to seal it and tightened every thing up. Prior to this it ran fine. Now it runs too lean. nearly 1400 deg. at cruise power settings, mixture full rich. This represents 100 deg. or more increase. Anyone have any ideas on this? Bud >> You might check the archives, there has been a lot of chatter on this over the years. I would start by determining how your carb float chamber is vented. There are some models which are vented in the carb throat which have a devil of a time in the RV, with the symtoms you describe. Any way start by making sure it is probperly vented Good luck D Walsh ________________________________________________________________________________
Subject: canopy prop open device
Date: Jan 28, 2000
I made a very simple device to prop the canopy partly open on my RV-4. It worked very well and is completely gust proof. It could be used from either inside the cockpit while taxiing or outside for ventilation while parked. The device consisted of a 6" piece of 1/16" thick, 3/4" x 3/4" aluminum angle, a 3/16" bolt, 1 camloc with "mickey mouse ears", 2 camloc receptacles, misc. washers and rivets. Align the angle with the left side cockpit rail with the angle almost touching the instrument panel. The rear of the angle and the cockpit rail are drilled for the bolt, which is used as the pivot point. The bolt should be a loose fit so that the angle can move easily. Put the camloc on the front of the angle. Put one receptacle in the cockpit rail and the other in a suitable spot on the canopy frame ( you will need some sort of bracket to hold the receptacle to the canopy frame). The angle is either held to the cockpit rail when not in use or is swung vertically to hold the canopy open. Like I said it is dirt simple, cheap, and works just fine. Feel free to call if this doesn't explain it well enough. Sorry I don't have a photo handy. Vince Frazier 3965 Caborn Road Mount Vernon, IN 47620 812-985-7309 University of Southern Indiana 812-464-1839 ________________________________________________________________________________
Date: Jan 28, 2000
> > the ripple voltage left on a 3-phase alternator's rectified output > is about 5% of the average DC . . . for a 14v alternator this is > on the order of 700 mV peak to peak. Normally, this isn't a problem > for avionics or other accessories designed to run in vehicles > of any kind having an alternator/battery power system. Is that 5% with a battery in the circuit? Or just a small DC source for field excitation? I went and checked the alternator in my Mazda (car) and it had at least 1.8 V peak to peak according to the scope. > > It's true that some digital meters are sensitive to this kind of > noise and will benefit from some filtering. The DC meter modules > I use the most have a 10 to 100 Megohm input impedance so adding > 10K of series resistance in the meter's sense lead doesn't upset > the calibration much . . less than 0.1%. After the resistor > is added, you put a capacitor across the meter's input terminals, > anything 0.1 uF up to 10 uF is fine . . . 1.0 uF and larger tend > to be electrolytics so observe polarity. > > This simple R/C filter will calm the little fellers down so that > their readings are accurate. The R/C filter is a good recommendation. I should have said that also. I have mine in a small plastic box with lead jacks for my meter. I used a 22K in series with the positive lead and a 10uF tantilum capacitor and a 0.1uF ceramic. It had been so long I had to open the box to remember. Greg ________________________________________________________________________________
Subject: Re: Source for fuse blocks that take auto fuses
Date: Jan 28, 2000
> Circuit breaker contacts don't weld. Fuses that are not fiddled > with in flight don't suffer mis-sizing accidents. > > > Bob . . . > I need to try to find the failed ON circuit breaker I have then and tear it appart. It failed ON and I just took the appinion of the A&P that is what happened. I'll see if I can find it still and cut it apart and see what failed. The A&P said the contacts had welded but I never checked. He said he had seen it before but it was rare. It came from an alternator circuit and a shorted battery. A friend of mine who was in the aircraft at the time reset the breaker twice when it failed 'on' and then ate the alternator. Luckly he was on the skirt when it happened and just shut down and got towed back to the hanger. Greg ________________________________________________________________________________
Subject: Re: Standardized List Sales
Date: Jan 28, 2000
Al, Some of the problems withs this are..... * email does not arrive to all immediately after it is posted * we are working through several time zones * email is not read immediately by all * it is a free market econonmy and most sellers don't care who buys it, as long as it gets sold I typically see responses to questions many days after the thread has been "put to bed" by most listers so it is obvious not everyone is on top of the list daily. If this was to be "fair", the only way to do it would be to post the item, wait several days for responses and then pick a name out of a hat. I doubt most listers would want to go through the hassle. We used to have a popular classified newspaper distributed in our County that was distrubuted to different parts of the county on different days. As you might guess, the folks who got the paper first jumped on all the bargins before the people who got the paper days later. Ed Cole ----- Original Message ----- From: Al Mojzisik <prober(at)iwaynet.net> Sent: Friday, January 28, 2000 9:55 AM Subject: RV-List: Standardized List Sales In light of recent posts and my own experience I am wondering if anyone else would be interested in me writing up a set of rules governing sales on the RV-List. I would not presume to dictate what is being sold only the method of responding to the offer. I think too often sellers just sell to the nearest guy to make shipping easier. If that is their policy then they need to state that in their original post. Otherwise it should be first respondent to accept the offer. We can have acceptances timed and dated directly to the list so we all know who it was and others don't have to respond knowing that three or four already have. They can add "do not archive" to there messages to save the space. I usually keep 2 or 3 months of messages in my trash bin so I could most likely retrieve one in case of a dispute. I would post the suggested rules for review of any of you who care to respond and give input then ask Matt to add it to the FAQ and put it in the rotation of list policy notices. Any interest? AL Matt do you think this would be a good idea? ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Re: ELT
> >Dumb question - Is an ELT required on an experimental airplane? Yes Have a great day! Denny, RV-6 N641DH (Flying) ________________________________________________________________________________
From: "Michael Robertson" <mrobert569(at)hotmail.com>
Subject: Re: Routing of wires in RV-8\8A
Date: Jan 28, 2000
Jerry, I did not use a grounding block but (I think) placed grounding studs at several strategic spots in order to save long wire runs for grounding. But if you are going to use one make sure it is in a spot where it can't get wet. On running the wire from the Master to the main bus, I have the Van's kit and their suggestion is on the left side a little lower and outboard from the brake reservoir. For me this location has worked out good so far. Van's drawing also uses that very shelf you are talking about. The only thing I would suggest is changing the homemade terminal block to ones available from Radio Shack or Acft Spruce. The other thing that I noticed on mine (full IFR) is the radio installation comes back quite far and could make it tough if the radios were located directly in front of the Bus on that shelf. Luckily I had already decided to put the radios on the right side of the panel or I would have had to re-locate the bus. Good luck with the wiring. I think I would rather work with fiberglass than spend any more time wiring. To install a full IFR panel and two of the Infinity grips has been a nightmare. Mike Robertson RV-8A QB >From: "Jerry Carter" <rv8abuild(at)mindspring.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Routing of wires in RV-8\8A >Date: Fri, 28 Jan 2000 00:42:22 -0600 > > >Having chosen to use the Nuckolls approach to wiring my 8A using fuses, 2 >alternators and one battery, I'm deliberating where to locate certain >things and would appreciate opinions and suggestions. > >1. Firewall ground block. Next to the battery tray? Middle of the >firewall between the rudder pedals? > >2. Routing of the 4AWG wire from the battery contactor to the main power >distribution bus, specifically with regard to where it penetrates the >firewall. > >3. Should both main power and essential buses be located on that little >shelf on the aft side of the forward baggage compartment? > >Thanks, > >Jerry Carter >8A QB >Planning Wiring > > ________________________________________________________________________________
Date: Jan 28, 2000
From: Thomas McIntyre <bogeybrother(at)earthlink.net>
Subject: Re: Lamb tires
Christopher I've ot them on my 3. Wear is little better but the really good thing about them is that they don't leak air. They are lighter. I'd do it again, Tom christopher huey wrote: > > Anyone using Cheng-Shin (Also known as "Lamb" tires) for the mains on a > RV-3,4,8..etc? I would like to know what kind of wear to expect from them, > and if they are worth the extra pounds saved over standard 500x5's. > > THX > > Chris > ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Re: ELT
Not if your have a single place airplane. Tom Denny Harjehausen wrote: > > > > >Dumb question - Is an ELT required on an experimental airplane? > > Yes > > Have a great day! > Denny, RV-6 N641DH (Flying) > ________________________________________________________________________________
Date: Jan 28, 2000
I've looked at this message a couple of times. I think what has happened is you used a liberal amount of Valve Lube and it got squeezed out into the bowl. This stuff is NOT fuel soluble. It probably has partially plugged some thing; jet, vent, etc. If I were you I would take the entire carb back off and blow out all passages. reassemble being careful if I used Parker fuel or valve lube to use it very sparing if at all. Some times in our efforts to improve things, to make them perfect, the opposite happens. It is somewhat the same thing that happens with silicone rubber gasket sealer. The amount that you wipe off the outside has also been squeezed out on the inside. A lump or two that breaks or falls into what you are sealing can cause problems. For this reason, I do not use silicone rubber gasket sealer especially around fuel and oil. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) -----Original Message----- From: BumFlyer(at)aol.com <BumFlyer(at)aol.com> Date: Friday, January 28, 2000 10:27 AM Subject: Re: RV-List: Carb problems need help > > >In a message dated 1/27/0 22:08:30, bud(at)softcom.net writes: > > >I recently did the annual on RV6 (flying 4 years) and found that the >carburetor >bowl was loose. >I pulled it off smeared some fuel valve lube on the gasket to seal it >and >tightened every thing up. >Prior to this it ran fine. Now it runs too lean. nearly 1400 deg. at >cruise power >settings, mixture full rich. This represents 100 deg. or more increase. >Anyone have any ideas on this? > >Bud > > >> > >You might check the archives, there has been a lot of chatter on this over >the years. > >I would start by determining how your carb float chamber is vented. There >are some models which are vented in the carb throat which have a devil of a >time in the RV, with the symtoms you describe. Any way start by making sure >it is probperly vented > >Good luck > >D Walsh > > ________________________________________________________________________________
Subject: Air-Oil Separator
Date: Jan 28, 2000
I want to add an oil separator to my engine breather outlet. I am considering the "Homebuilders Oil Breather/Separator" sold by Aircraft Spruce (p. 233, 99/00 catalog). I would appreciate any comments on how well this separator works. Questions: 1. Where does the oil return line attach to the engine? I have a carburated O-320 D2J (160 hp) with Slick mags, no constant speed, no vacuum pump. 2. What is the diameter of the oil return line? (I may try to fabricate my own separator.) Mark Nielsen RV-6, 463 hrs ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Re: RV4-List: RV-4 canopy latch
Rion;' I'll try to take a photo for you. First, several egress considerations from a canopy aircraft are presented in the RV4. I have been flying the F-16 for 12 years now and it's canopy is exactly like the -4 except it weighs 390 pounds! It hinges at the rear and is electrically raised and lowered. It is explosively jettisonable with the pull of a T handle, or automatically during ejection. Our owners manual recommends ejection over "riding out" an off runway excursion. One pilot 15 years ago had a main gear failure and flipped over, trapping him for three hours until a fireman used a chainsaw to cut open the THREE inch thick (400 knot birdproof) plexiglass and free him. A fire would have made a different ending to the story. As RV's go, I have personally rescued one wary RV3 pilot after his -3's engine quit on takeoff putting him in a soft corfield on his back. He had a sliding canopy and we couldn't move it until we righted the airplane. He was so humbled by the experience that he redesigned his canopy to be jettisonable, installed a BRS and vowed never to land in a cornfield again. With 500 safe hours on my -4 now I can safely say that if anything requiring an off pavement, highway or otherwise non-prepared surface landing comes up, I am jettisoning my canopy prior to landing. With the locking pin, you simply reach over your left shoulder, pull the pin forward 2 inches and open the canopy. In normal circumstances in hot weather, you simply pull the pin, raise the canopy about 6 inches and slide the pin aft into the taxi position hole. I have a tear away canopy "restraint" that is made of steel with aluminum bolts. 80 knots should rip it off if I need to get rid of it. Thats why I like the pin, when it's shut, it won't blow open. Rob --- RION BOURGEOIS wrote: > --> RV4-List message posted by: "RION BOURGEOIS" > > > Sounds neat and simple. However, if the pin slides > backwards over the > canopy bulkhead, how do rescuers open the canopy to > get you out? Got > pictures? Rion > ----- Original Message ----- > From: rob ray <smokyray(at)yahoo.com> > To: > Sent: Wednesday, January 26, 2000 3:45 PM > Subject: Re: RV4-List: RV-4 canopy latch > > > > --> RV4-List message posted by: rob ray > > > > > > > Hi J; > > > > I used a pin from the nautilus weight room that > > holds the weights in the stack. I drilled a hole > in my > > roll bar through the canopy bulkhead at a point on > the > > entry side that left the canopy about 3 inches > "above > > the rim" with the pin in. I used plastic bushings > in > > the hole in the roll bar just like the ones for > the > > rudder cables and drilled the pin so I could put a > > small cotter key and washer 2 inches from the end. > Now > > I simply slide it into the hole in the canopy > bulkhead > > on the ground and pull it back when I shut the > canopy. > > It slides about 3 inches stop to stop. The cool > part > > is when the canopy is down, the pin slides > backwards > > OVER the top of the bulkhead preventing opening if > the > > canopy lock should fail. See ya. > > > > Rob Ray > > smokyray(at)yahoo.com > > --- "J. Rion Bourgeois" > wrote: > > > --> RV4-List message posted by: "J. Rion > Bourgeois" > > > > > > > > > I am at the decision point for my RV-4 canopy > latch > > > mechanism. I would like > > > to use the standard latch mechanism in the > plans, > > > but it does not provide > > > for a partially open position for ground > operations. > > > I have heard a rumor > > > about a builder in the Seattle area who has > designed > > > a safety latch that > > > allows use of the standard canopy latch and has > a > > > partially open position. > > > Does anyone have his address and phone number or > any > > > suggested solutions? > > > Thanx, Rion > > > > > > > > > > > > through > > > > > > http://www.matronics.com/archives > > > http://www.matronics.com/emaillists > > > > > > Matronics! > > > > > > > > > > > > > > > > > Talk to your friends online with Yahoo! Messenger. > > http://im.yahoo.com > > > > > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > Talk to your friends online with Yahoo! Messenger. http://im.yahoo.com ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Re: RV-4 canopy latch
I guess the RV-4 is somewhat different from the RV-3, but I think that you can't have the latch rod (tube) go through the canopy frame. The original design called for additional rods, however, I simply pop rivited triangular pieces of .125 alu to the frame. The grommets are placed in holes in these pieces, rather than in the frame. This allows for the closed and taxi holes to still be drilled close to instrument and bulkhead edges. Taxi holes are not much more than an inch above the closed holes, and is drilled as close as possible to the outside edge of the bulkheads. I doubt you'll need much more than a one inch crack when the prop is running. The center of the rods runs maybe 3/4" in from the center of the frame. Finn Rob Reece wrote: > > I > > would like > > to use the standard latch mechanism in the plans, but it does not provide > > for a partially open position for ground operations. I have heard a rumor > > about a builder in the Seattle area who has designed a safety latch that > > allows use of the standard canopy latch and has a partially open position. > > The RV-4 that I have flown in just has a second hole installed about 4-6 > inches above the existing hole that latches/locks the canopy partially open > for ventilation and ground ops as you have described. Appears to be just a > second hole in the bulkhead with a thick doubler riveted on like original > (don't have the plans. . .could be wrong about original hole). > NetZero - Defenders of the Free World ________________________________________________________________________________
From: "Johnson, James, Maj, AF/XOOT" <James.Johnson(at)pentagon.af.mil>
Subject: RE: RV4-List: RV-4 canopy latch
Date: Jan 28, 2000
Rob, Another question one could ask is what happens to the structural integrity of the roll bar with a rather large hole drilled through it supporting the pin? Of course, as my old instructor used to say, "At this point your luck has been quite miserable. What makes you think it's about to change. S--- happens!" Jj -----Original Message----- From: rob ray [mailto:smokyray(at)yahoo.com] Sent: Friday, January 28, 2000 2:16 PM Subject: Re: RV4-List: RV-4 canopy latch --> RV4-List message posted by: rob ray Rion;' I'll try to take a photo for you. First, several egress considerations from a canopy aircraft are presented in the RV4. I have been flying the F-16 for 12 years now and it's canopy is exactly like the -4 except it weighs 390 pounds! It hinges at the rear and is electrically raised and lowered. It is explosively jettisonable with the pull of a T handle, or automatically during ejection. Our owners manual recommends ejection over "riding out" an off runway excursion. One pilot 15 years ago had a main gear failure and flipped over, trapping him for three hours until a fireman used a chainsaw to cut open the THREE inch thick (400 knot birdproof) plexiglass and free him. A fire would have made a different ending to the story. As RV's go, I have personally rescued one wary RV3 pilot after his -3's engine quit on takeoff putting him in a soft corfield on his back. He had a sliding canopy and we couldn't move it until we righted the airplane. He was so humbled by the experience that he redesigned his canopy to be jettisonable, installed a BRS and vowed never to land in a cornfield again. With 500 safe hours on my -4 now I can safely say that if anything requiring an off pavement, highway or otherwise non-prepared surface landing comes up, I am jettisoning my canopy prior to landing. With the locking pin, you simply reach over your left shoulder, pull the pin forward 2 inches and open the canopy. In normal circumstances in hot weather, you simply pull the pin, raise the canopy about 6 inches and slide the pin aft into the taxi position hole. I have a tear away canopy "restraint" that is made of steel with aluminum bolts. 80 knots should rip it off if I need to get rid of it. Thats why I like the pin, when it's shut, it won't blow open. Rob --- RION BOURGEOIS wrote: > --> RV4-List message posted by: "RION BOURGEOIS" > > > Sounds neat and simple. However, if the pin slides > backwards over the > canopy bulkhead, how do rescuers open the canopy to > get you out? Got > pictures? Rion > ----- Original Message ----- > From: rob ray <smokyray(at)yahoo.com> > To: > Sent: Wednesday, January 26, 2000 3:45 PM > Subject: Re: RV4-List: RV-4 canopy latch > > > > --> RV4-List message posted by: rob ray > > > > > > > Hi J; > > > > I used a pin from the nautilus weight room that > > holds the weights in the stack. I drilled a hole > in my > > roll bar through the canopy bulkhead at a point on > the > > entry side that left the canopy about 3 inches > "above > > the rim" with the pin in. I used plastic bushings > in > > the hole in the roll bar just like the ones for > the > > rudder cables and drilled the pin so I could put a > > small cotter key and washer 2 inches from the end. > Now > > I simply slide it into the hole in the canopy > bulkhead > > on the ground and pull it back when I shut the > canopy. > > It slides about 3 inches stop to stop. The cool > part > > is when the canopy is down, the pin slides > backwards > > OVER the top of the bulkhead preventing opening if > the > > canopy lock should fail. See ya. > > > > Rob Ray > > smokyray(at)yahoo.com > > --- "J. Rion Bourgeois" > wrote: > > > --> RV4-List message posted by: "J. Rion > Bourgeois" > > > > > > > > > I am at the decision point for my RV-4 canopy > latch > > > mechanism. I would like > > > to use the standard latch mechanism in the > plans, > > > but it does not provide > > > for a partially open position for ground > operations. > > > I have heard a rumor > > > about a builder in the Seattle area who has > designed > > > a safety latch that > > > allows use of the standard canopy latch and has > a > > > partially open position. > > > Does anyone have his address and phone number or > any > > > suggested solutions? > > > Thanx, Rion > > > > > > > > > > > > through > > > > > > http://www.matronics.com/archives > > > http://www.matronics.com/emaillists > > > > > > Matronics! > > > > > > > > > > > > > > > > > Talk to your friends online with Yahoo! Messenger. > > http://im.yahoo.com > > > > > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > Talk to your friends online with Yahoo! Messenger. http://im.yahoo.com ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Re: Air-Oil Separator
The latest edition of AOPA Pilot has just what your looking for if you can find an edition. Mike Nellis http://mnellis.jnet.net/rv-6_page From: Mark Nielsen <Mark.Nielsen@fiedler-lp.com> on 01/28/2000 01:01 PM cc: Subject: RV-List: Air-Oil Separator I want to add an oil separator to my engine breather outlet. I am considering the "Homebuilders Oil Breather/Separator" sold by Aircraft Spruce (p. 233, 99/00 catalog). I would appreciate any comments on how well this separator works. Questions: 1. Where does the oil return line attach to the engine? I have a carburated O-320 D2J (160 hp) with Slick mags, no constant speed, no vacuum pump. 2. What is the diameter of the oil return line? (I may try to fabricate my own separator.) Mark Nielsen RV-6, 463 hrs ________________________________________________________________________________
Date: Jan 28, 2000
Okay Ed, I thought of most of that but I figured most e-mail gets time stamped when it's sent. Thought later that this can be messed with by changeling the time on your computer. So how about requiring a phone number so anyone can respond by phone immediately and follow up with a confirmation over the list. It would be nice to have something less arbitrary than it currently is. It's a real bummer when you know you bought something only to find your e-mail being ignored because a better or easier deal came in later. Oh well I guess we'll just have to plod on. AL > >Al, >Some of the problems withs this are..... > >* email does not arrive to all immediately after it is posted > >* we are working through several time zones > >* email is not read immediately by all > >* it is a free market economy and most sellers don't care who buys it, as >long as it gets sold > ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Tire Mounting
When mounting tires, does the red dot on the tire line up with the valve stem or does it go opposite of the valve stem??? Bruce Green ________________________________________________________________________________
Date: Jan 28, 2000
> > >I want to add an oil separator to my engine breather outlet. I am >considering the "Homebuilders Oil Breather/Separator" sold by Aircraft >Spruce (p. 233, 99/00 catalog). I would appreciate any comments on >how well this separator works. > >Questions: > >1. Where does the oil return line attach to the engine? I have a >carburated >O-320 D2J (160 hp) with Slick mags, no constant speed, no vacuum pump. It attaches to the oil filler tube so it goes right back where it came from. > >2. What is the diameter of the oil return line? (I may try to >fabricate my own separator.) Tony Bingelis has a neat cross setional cutaway drawing of a home made separator in his "firewall forward" book. I thought about making one myself, but since the belly of the plane is staying very clean so far, I don't see much need for it. If you plan to do some occasional (momentary) negative G stuff, or like to run your oil level rather high, then it would be a nice device to install. Brian Denk RV8 N94BD ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Re: Aileron Boots
I missed the post on aileron boots.What was used??????? Ken Harrell RV6 400 Hrs. (BWG) Ky. ________________________________________________________________________________
Date: Jan 28, 2000
Al, I've missed a few bargins do to late notification, so I know what a bummer it can be! I have had luck with Avweb autions however, even though you must constantly monitor the bidding. How's that project going?? As slow as mine? I'm still finishing the fuselage and have it on gear, motor mount is on, seats, flap motor, and interior sheetmetal is done. Just need to put on the top skins, and start the panel and canopy. Some day.... Ed Cole ----- Original Message ----- From: Al Mojzisik <prober(at)iwaynet.net> Sent: Friday, January 28, 2000 4:41 PM Subject: Re: RV-List: Standardized List Sales Okay Ed, I thought of most of that but I figured most e-mail gets time stamped when it's sent. Thought later that this can be messed with by changeling the time on your computer. So how about requiring a phone number so anyone can respond by phone immediately and follow up with a confirmation over the list. It would be nice to have something less arbitrary than it currently is. It's a real bummer when you know you bought something only to find your e-mail being ignored because a better or easier deal came in later. Oh well I guess we'll just have to plod on. AL > >Al, >Some of the problems withs this are..... > >* email does not arrive to all immediately after it is posted > >* we are working through several time zones > >* email is not read immediately by all > >* it is a free market economy and most sellers don't care who buys it, as >long as it gets sold > ________________________________________________________________________________
Date: Jan 28, 2000
The red dot is the light spot on the tire. It should be lined up with the yellow strip on the tube. If there is no yellow line on the tube then it should be lined up with the valve stem. ***Bryan E. Files*** A&P, IA, FAA Safety Counselor Fat City Aircraft Palmer, Alaska mailto:BFiles(at)corecom.net When mounting tires, does the red dot on the tire line up with the valve stem or does it go opposite of the valve stem??? Bruce Green ________________________________________________________________________________
Subject: Carburetor problems with loose bowl.
Date: Jan 28, 2000
People usually do not know this but there is a service letter to check the bowl screws for being tight every 50 hours. What happens when the bowl gets loose is two things: The bowl and upper end of the carburetor wear differently and or a booger gets in the flange area so when you tighten the bowl back up there is usually a little gap somewhere between the venturi and the float bowl that is allowing the ventrui to put a vacuum on the float bowl which in turn doesn't allow the right amount of fuel to travel thru the main jet on the carb which causes a lean mixture. I suggest that you pull the carb off and disassemble and mate the surfaces by laying a piece of 400 grit sandpaper on a flat surface and true up the bowl and top half of the carb. When you assemble again use just a slight amount of fuel lube on the parting gasket. Hope this helps. ***Bryan E. Files*** A&P, IA, FAA Safety Counselor Fat City Aircraft Palmer, Alaska mailto:BFiles(at)corecom.net I recently did the annual on RV6 (flying 4 years) and found that the carburetor bowl was loose. I pulled it off smeared some fuel valve lube on the gasket to seal it and tightened every thing up. Prior to this it ran fine. Now it runs too lean. nearly 1400 deg. at cruise power settings, mixture full rich. This represents 100 deg. or more increase. Anyone have any ideas on this? ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Re: J Stringer Add-ons - RV6
Greetings I have heard that some builders have added two J Stringers to the bottom of the fuse between bulkheads 606 & 608 , and then one centered between the 608 & 610. Has anyone done this? and / or, would recomend it?? I can certainly see that it would be real easy to get carried away with this sort of thing and I am constantly holding myself back from doing exactly that. So ... comments?? David Wentzell RV6 Fuse (starting to take shape) Racine Wisconsin ________________________________________________________________________________
Subject: O320H2Ad for Sale
Date: Jan 28, 2000
about 3 weeks ago I posted this engine for sale and had some interested replys. However I had to leave town and lost the interested party's list. (One was from England). The engine has 0 time and is a rebuilt by Aero Sport Power with installation of oil spray nozzles. do not archieve planejoe(at)ewol.com 941 474 0615 ________________________________________________________________________________
Subject: ELT mount
Date: Jan 28, 2000
Need some opinions. I am looking for a mounting location for an ACK EL-01 elt, the one that is portable and uses d-cell batteries. It needs to be accessible for portable use. The only place I can see to mount it is in the rear baggage compartment in my -8A. On the hat shelf with a .025 doubler for added stiffness. Does anyone see a problem with this. Is the hat shelf sufficiently stiff for this use? I don't want it tearing out in a crash. Thanks, Jeff Farrar, RV8A N4ZF reserved, Chandler, AZ jfarrar1(at)home.com Wings done, fuselage almost, fuselage interior and wiring. ________________________________________________________________________________
Date: Jan 28, 2000
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
> >> Circuit breaker contacts don't weld. Fuses that are not fiddled >> with in flight don't suffer mis-sizing accidents. >> >> >> Bob . . . >> >I need to try to find the failed ON circuit breaker I have then and tear it >appart. It failed ON and I just took the appinion of the A&P that is what >happened. I'll see if I can find it still and cut it apart and see what >failed. The A&P said the contacts had welded but I never checked. He said >he had seen it before but it was rare. > >It came from an alternator circuit and a shorted battery. A friend of mine >who was in the aircraft at the time reset the breaker twice when it failed >'on' and then ate the alternator. Luckly he was on the skirt when it >happened and just shut down and got towed back to the hanger. Aha! It is true that contacts on switches weld only when the switch closes and burn mostly when switches opne. When the breaker tripped the first time, it was trying to say something . . . that circuit was OVERLOADED. It might be slightly overloaded such that the breaker takes awhile to warm up and trip or it could be a hard fault . . . with modern batteries, short fat wires hooking things up, it's conceivable that a dead short fault current in an arplane could be many hundreds of amps. Trying to reset the breaker without knowing the exact nature of the fault is an invitation to welding. I guess I should have said that breakers operating in their intended function (opening a faulted circuit where the breaker is already closed) don't weld. Breakers used as SWITCHED to restore power to heavily faulted circuits may indeed suffer a weldment. Do you REALLY want to punch that breaker back in? Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Subject: Re: ELT
Date: Jan 28, 2000
Please site your reference Mike Robertson RV-8A "Das Fed" >From: Thomas McIntyre <bogeybrother(at)earthlink.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: ELT >Date: Fri, 28 Jan 2000 09:57:00 -0800 > > >Not if your have a single place airplane. >Tom > >Denny Harjehausen wrote: > > > > > > > > >Dumb question - Is an ELT required on an experimental airplane? > > > > Yes > > > > Have a great day! > > Denny, RV-6 N641DH (Flying) > > > > ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Flight Test Basics School
To all, I just came across this notice for a weekend class for learning the basics of flight tests and performance estimation. I thought it might be of interest to some on the list who would like to know more about their RV's performance. Since I'll be flying in the next couple of months (I hope) this class is of real interest to me. I called up Ed to see if there is still space available. Good news is there is still space, bad news is it looks like there might be enough interest to do the class. What a shame. He has 12 confimed, and need to get close to 20 to make the break even point. This is to be the first of several that he hoped to put on. If something like this might be of interest, please give Ed a call real soon. (He was going to make a decision this weekend). I have a personal interest in seeing the course happen, as I want to attend! Thanks, Laird RV-6 22923 SoCal The announcement from Kitplanes is at: http://www.kitplanes.com/what's%20new/whatsnew.htm#Highlights I included the text in case people don't have web access. "Homebuilders whose flying skills may have become rusty during the building process often look for a well qualified pilot to make initial test flights, and we encourage that. Other builders, however, opt for the excitement and experience of testing their own. If you are considering joining the second group, Ed Kolano's weekend course on flight test basics set for February 26 and 27 in San Diego may be for you. Kolano is a nationally recognized professional test pilot who was an instructor at Navy Test Pilot School. His two-day course teaches how to measure data and use it to determine specifications including takeoff, climb, range, endurance, descent, engine-out and landing performance. Also in the curriculum: handling qualities and stability and control as they relate to piloting tasks. On completion, you will be able to produce the performance section of an operator's manual for your own aircraft. Cosponsored by KITPLANES magazine and the San Diego Aerospace Museum--which will host the event--the course will be related to some of the aircraft on display in the museum. The course will accommodate a maximum class of 25 pilots. Register now by sending a check for $300 made to Ed Kolano at P.O. Box 163941, Fort Worth, TX 76161. Extensive materials are included in the cost. Checks will be voided and returned promptly once the class is full or if minimum class size is not achieved. The San Diego Aerospace Museum is one of 11 museums in San Diego's Balboa Park, which also houses the world famous San Diego Zoo. Bring the family and they will find plenty to do while you learn about flight testing. Questions? Call Ed Kolano evenings at 817/421-0555." ________________________________________________________________________________
Date: Jan 28, 2000
From: Charlie and Tupper England <cengland(at)netdoor.com>
Subject: Re: ELT
Denny Harjehausen wrote: > > > > > >Dumb question - Is an ELT required on an experimental airplane? > > Yes > > Have a great day! > Denny, RV-6 N641DH (Flying) If it has more than 1 seat & you stray more than 50 mi from home. I think. ce ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Off list Comm.
Ed, Mine is still stalled also. Have a few other things on the front burner, not to mention it's about -5 degrees right now out in the shop. Hey did you ever get that e-mail when I offered to fax you the parts list for your engine that I had made up. You asked for somethign about that as I recall and I offered and never heard back and I think I forgot about it. Did you ever get that other engine rebuilt? I have been so busy It's hard to get to the projuect. Thanks for asking though.....AL > >Al, >I've missed a few bargins do to late notification, so I know what a bummer >it can be! >I have had luck with Avweb autions however, even though you must constantly >monitor >the bidding. >How's that project going?? As slow as mine? I'm still finishing the fuselage >and have it on gear, >motor mount is on, seats, flap motor, and interior sheetmetal is done. Just >need to put >on the top skins, and start the panel and canopy. >Some day.... > >Ed Cole ________________________________________________________________________________
Subject: Re: Tire Mounting
Date: Jan 28, 2000
It lines up just under the valve stem. ________________________________________________________________________________
Subject: Re: Carburetor problems with loose bowl.
Date: Jan 28, 2000
Interesting Bryan. I thought he said that he reassembled with Parker valve lube so it would not have any gaps. I was not aware of the service letter. Thanks for the info. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) -----Original Message----- From: Bryan E. Files <bfiles(at)corecom.net> Date: Friday, January 28, 2000 6:35 PM Subject: RV-List: Carburetor problems with loose bowl. >747. >People usually do not know this but there is a service letter to check the >bowl screws for being tight every 50 hours. >What happens when the bowl gets loose is two things: The bowl and upper end >of the carburetor wear differently and or a booger gets in the flange area >so when you tighten the bowl back up there is usually a little gap somewhere >between the venturi and the float bowl that is allowing the ventrui to put a >vacuum on the float bowl which in turn doesn't allow the right amount of >fuel to travel thru the main jet on the carb which causes a lean mixture. >I suggest that you pull the carb off and disassemble and mate the surfaces >by laying a piece of 400 grit sandpaper on a flat surface and true up the >bowl and top half of the carb. When you assemble again use just a slight >amount of fuel lube on the parting gasket. >Hope this helps. >***Bryan E. Files*** >A&P, IA, FAA Safety Counselor >Fat City Aircraft >Palmer, Alaska >mailto:BFiles(at)corecom.net > > >I recently did the annual on RV6 (flying 4 years) and found that the >carburetor >bowl was loose. >I pulled it off smeared some fuel valve lube on the gasket to seal it >and >tightened every thing up. >Prior to this it ran fine. Now it runs too lean. nearly 1400 deg. at >cruise power >settings, mixture full rich. This represents 100 deg. or more increase. >Anyone have any ideas on this? > > ________________________________________________________________________________
Date: Jan 28, 2000
Subject: Engine Component Safetying
I've got 3 things to safety wire, but can only find two places to tie off the safety wire... Items to safety: 1) Oil filter (on a spin-on adapter). It looks like this safety's through a hole near the top of the spin on adapter. 2) Vernatherm. Looks like this safety's through a hole near the bottom of the spin on adapter. 3) Oil temperature sensor. Could safety through the same hole as the oil filter, but I doubt it... What gives?? Thanks, Kyle Boatright ________________________________________________________________________________
Subject: rivet identification
Date: Jan 29, 2000
I keep bumping into the same delema everytime I find a different rivet spec on the drawings. I never had the original packing list from my kit and had to guess at the rivets ID's using aircraft spruce catalog photos and descriptions . Is there a web site that might happen to have all the different rivit types and thier various designations along with an image? This could really help us less informed builders. I wish Vans just wrote the actual ID on the bag instead of (or along with) a number. Pat Perry Dallas, PA RV-4 canopy soaking in the tub to help release the #$@#!!@ protective coating! ________________________________________________________________________________
Date: Jan 28, 2000
(I've been TDY for a few days, so I missed this thread while it was ongoing.) > Why do the fuses have to be accessible in flight? Four experiences that support accessible fuses or breakers: Gruman AA1C (mine): intermittent short in panel light cirucit while night IFR. Replaced fuse, flew to destination (IFR) w/o flashlight in mouth. I'm glad that fuse was accessible. I fixed the intermittent short later. RV-6A (mine): First flight, stall horn was on all the time (stall tab needed to be moved). Pulled breaker, completed first flight without distracting noise. RV-6A (mine): I have a weird interaction between my Garmin 195 and my Navaid autopilot that I've not resolved yet. During the interim, I like to be able to power down the Navaid until the Garmin 195 is on. The accessible Navaid breaker makes that possible. RV-6A (mine): My engine monitor sometimes locks if I start the engine with the monitor on. You can bitch and moan all you want about how it shouldn't do that, but the bottom line is it's the best monitor on the market, and I'm going to use it. When I forget to turn the avionics master off while cranking the engine, I can easily cycle the avionics master or the engine monitor breaker without interrupting power to my electronic ignition (which is on the main bus, not the avionics bus). People will make arguments about a "proper" design eliminating the need for an accessible fuse/breaker in any given situation. They'll make these arguments AFTER knowing all the circumstances that made the accessible breaker/fuse useful. But it is not possible to anticipate every fault/problem/circumstance that may occur, so I say give the pilot in command maximum control over his aircraft's electrical system. The decision to reset a circuit belongs with the PIC. The decision to power down a circuit belongs with the PIC. I will not hide my breakers/fuses and rob myself of the option of turning off or resetting a circuit in flight, based on my needs and my judgment during the flight. Tim Lewis B.S. Electrical Engineering M.S. Electrical Engineering RV-6A Flying ****** Tim Lewis -- Springfield VA RV-6A N47TD - First Flight 18 Dec 99 TimRV6A(at)earthlink.net http://www.geocities.com/timrv6a ________________________________________________________________________________
Date: Jan 28, 2000
Subject: PLEASE STOP!!
Please remove me from your list. Thanks!!!! ________________________________________________________________________________
From: bcbraem(at)home.com.with.ESMTP (InterMail v4.01.01.00 201-229-111)
Date: Jan 28, 2000
Subject: Re: ELT
Also-- Not if you're flying exclusively within 50 miles of your airport or are using our RV for Agwagon spraying. bcb. Thomas McIntyre wrote: > > > Not if your have a single place airplane. > Tom > > Denny Harjehausen wrote: > > > > > > > > >Dumb question - Is an ELT required on an experimental airplane? > > > > Yes > > > > Have a great day! > > Denny, RV-6 N641DH (Flying) > > > ________________________________________________________________________________
Date: Jan 28, 2000
>I want to add an oil separator to my engine breather outlet. I am >considering the "Homebuilders Oil Breather/Separator" sold by Aircraft >Spruce (p. 233, 99/00 catalog). I would appreciate any comments on >how well this separator works. > >Questions: > >1. Where does the oil return line attach to the engine? I have a >carburated >O-320 D2J (160 hp) with Slick mags, no constant speed, no vacuum pump. > >2. What is the diameter of the oil return line? (I may try to >fabricate my own separator.) > >Mark Nielsen >RV-6, 463 hrs Mark, When I had mine installed, I plumbed the drain back from the separator to a 90 degree nylon fitting (pipe thread on one end, barbed fitting on the other) that was screwed (and sealed) into the lower portion of the plastic, dipstick tube. I used 1/4" id tubing and clamped the ends on the barbed (and bulbed fitting on the bottom of the separator). I removed the separator at about 200 hours, or so, because I needed the location to mount the electronic module for Jeff Rose's electronic ignition. This is when I found that I had not gained anything with the addition of the separator. The belly of the airplane was just as clean with as without. Bob Skinner Buffalo, WY (1995 RV6 sold after 4 years & 470 hrs) EAA Tech Counselor # 3726 ________________________________________________________________________________
Subject: Re: PLEASE STOP!!
Date: Jan 29, 2000
Greg, Go to the subscription site listed below and delete your subscription. The list is not the place to do this. Thanks. Gary Baker RV-6 (Working on wings) N4GB (Reserved) Medina, OH > > Please remove me from your list. Thanks!!!! > > ________________________________________________________________________________
Date: Jan 29, 2000
Subject: Re: Engine Component Safetying
Kyle-- If you have a firewall mounted spin-on filter adapter there should be a hole in the adapter frame on the right-hand side--begin the safety wire in a hole in the bottom of the filter under the frame hole, connect to the next counterclockwise hole and then up and around 180 to the adapter hole. This prevents the wire from sliding on the filter, esp. if you use a "long" (CH48109) filter. I don't know what the Vernatherm is--sounds like something we wouldn't use in FL and I don't know the distance from your oil sensor to the next bolt or screwhead. I may be preaching to the choir but there are some good examples of possibilities in AC 43.13-1B/2A (Acceptable Methods, Techniques and Practices...") in Section 7 on safetying technique. bcb KBoatri144(at)aol.com wrote: > > > I've got 3 things to safety wire, but can only find two places to tie off the > safety wire... > > Items to safety: > > 1) Oil filter (on a spin-on adapter). It looks like this safety's through a > hole near the top of the spin on adapter. > > 2) Vernatherm. Looks like this safety's through a hole near the bottom of > the spin on adapter. > > 3) Oil temperature sensor. Could safety through the same hole as the oil > filter, but I doubt it... What gives?? > > Thanks, > > Kyle Boatright > ________________________________________________________________________________
Date: Jan 29, 2000
In a message dated 1/28/00 11:58:05 AM Pacific Standard Time, Mark.Nielsen@fiedler-lp.com writes: << I want to add an oil separator to my engine breather outlet. I am considering the "Homebuilders Oil Breather/Separator" sold by Aircraft Spruce (p. 233, 99/00 catalog). I would appreciate any comments on how well this separator works.>> These represent a good value and can be made to work quite well if you are willing to modify them as described in the archives. <> IMO the best answer is that it doesn't. Oil and moisture are extracted so you probably are going to get some sulfuric acid in it. I certainly wouldn't return it to the engine. Plumb the drain to collect the condensate in some sort of bottle (I used a Matco brake fluid reservoir with a curtis valve) and then drain it every 50 hrs or so. <> 3/8" ID on the drain line. This breather is sold in two versions, the original I used was for the O-200 and is equipped with nipples to fit 5/8" ID hose. I changed the fitting on my O-360 engine to use the AN840-10D hose nipple (same as most Continentals) so that I could use the same 5/8" ID hose for everything (vacuum pump, etc.). Wicks also has another version (pg 242) equipped with nipples to fit 3/4" ID hose. So you have a choice. -GV ________________________________________________________________________________
Date: Jan 29, 2000
I would think a switch would do just fine in 3 out of your 4 examples!!!! Fuses or CB being accessible or not have nothing to do with every problem in your 6A! Read it again. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) -----Original Message----- From: Tim Lewis <timrv6a(at)earthlink.net> Date: Friday, January 28, 2000 10:51 PM Subject: Re: RV-List: Source for fuse blocks that take auto fuses > >(I've been TDY for a few days, so I missed this thread while it was >ongoing.) > >> Why do the fuses have to be accessible in flight? > >Four experiences that support accessible fuses or breakers: > >Gruman AA1C (mine): intermittent short in panel light cirucit while >night IFR. Replaced fuse, flew to destination (IFR) w/o flashlight in >mouth. I'm glad that fuse was accessible. I fixed the intermittent short >later. > >RV-6A (mine): First flight, stall horn was on all the time (stall tab >needed to be moved). Pulled breaker, completed first flight without >distracting noise. > >RV-6A (mine): I have a weird interaction between my Garmin 195 and >my Navaid autopilot that I've not resolved yet. During the interim, I >like to be able to power down the Navaid until the Garmin 195 is on. >The accessible Navaid breaker makes that possible. > >RV-6A (mine): My engine monitor sometimes locks if I start the >engine with the monitor on. You can bitch and moan all you want >about how it shouldn't do that, but the bottom line is it's the best >monitor on the market, and I'm going to use it. When I forget to turn >the avionics master off while cranking the engine, I can easily cycle >the avionics master or the engine monitor breaker without interrupting >power to my electronic ignition (which is on the main bus, not the >avionics bus). > >People will make arguments about a "proper" design eliminating the >need for an accessible fuse/breaker in any given situation. They'll >make these arguments AFTER knowing all the circumstances that >made the accessible breaker/fuse useful. But it is not possible to >anticipate every fault/problem/circumstance that may occur, so I say >give the pilot in command maximum control over his aircraft's electrical >system. The decision to reset a circuit belongs with the PIC. The >decision to power down a circuit belongs with the PIC. I will not hide >my breakers/fuses and rob myself of the option of turning off or >resetting a circuit in flight, based on my needs and my judgment >during the flight. > >Tim Lewis >B.S. Electrical Engineering >M.S. Electrical Engineering >RV-6A Flying > > >****** >Tim Lewis -- Springfield VA >RV-6A N47TD - First Flight 18 Dec 99 >TimRV6A(at)earthlink.net >http://www.geocities.com/timrv6a > > ________________________________________________________________________________
Date: Jan 29, 2000
Subject: Stop 2 Request
Please take me off your list AZAP!! TNX ________________________________________________________________________________
Date: Jan 29, 2000
aerome(at)onramp.net
Subject: [Fwd: RV Homebuilt Aircraft Data Plates......FOR SALE]
Hey Gang! I picked up one of these data plates from Ted and it really is neat. Considering what we spend an all the play things we buy for our toys, this is a neat little deal. Check it out! Al -6 From: brokenspar(at)aol.comstopspam (BrokenSpar) Subject: RV Homebuilt Aircraft Data Plates......FOR SALE NNTP-Posting-Host: ladder07.news.aol.com Date: 28 Jan 2000 06:54:31 GMT Xref: iad-artgen.news.verio.net rec.aviation.marketplace:8939 I am selling acid etched stainless steel RV homebuilt data plates with the Van's Air Force logo...see the following for photos: http://members.aol.com/brokenspar/RVplate.jpg http://members.aol.com/brokenspar/rv.jpg I am selling them for $12. each which includes shipping within the U.S.A. Also have Corben.....Baby Ace....Acro Sport.....Gee Bee email if you have an interest. THANK YOU!! remove "stopspam" to email me remove "stopspam" to email me ________________________________________________________________________________
Subject: Time to get an Engine?
Date: Jan 29, 2000
Hi Folks: As I am moving along quite nicely on the second wing (that learning curve is a wonderful thing), I am looking forward a bit to construction of the fuse. Being the planner that I am, I am wondering at what point is having the engine in house necessary? Can this hefty purchase wait until the finish kit, or do I need it during construction of the fuse? Also, are there any problems/hints that I should know as to installing the 0320 160hp that Vans sells in a 6A.....like what accessories will fit in regards to the nosewheel strut? Just trying to do some hopefully not too long-range planning here. Thanks in advance Regards, Jeff Orear RV6A 25171 second wing...priming all sorts of parts Peshtigo, WI ________________________________________________________________________________
Subject: Re: rivet identification
Date: Jan 29, 2000
I can see how not having the original packing list is a bummer, maybe you can get a copy from another local builder or send me your fax number off list and I'll send you a copy. I used the packing list and put the bagged parts into one of those multiple tray storage units sold by Home Depot and others. Maybe the new SOURCERV has this or can post it. By the way, how about a comment on the SOURCERV from subscribed users for other list readers. I see that the formal introduction/start of this has been delayed until March 1. Marty in Brentwood TN. ----- Original Message ----- From: Pat Perry <pperryrv(at)hotmail.com> Sent: Friday, January 28, 2000 9:09 PM Subject: RV-List: rivet identification > > I keep bumping into the same delema everytime I find a different rivet spec > on the drawings. I never had the original packing list from my kit and had > to guess at the rivets ID's using aircraft spruce catalog photos and > descriptions . > > Is there a web site that might happen to have all the different rivit types > and thier various designations along with an image? > > This could really help us less informed builders. > > I wish Vans just wrote the actual ID on the bag instead of (or along with) a > number. > > > Pat Perry > Dallas, PA > RV-4 canopy soaking in the tub > to help release the #$@#!!@ protective coating! > > ________________________________________________________________________________
Date: Jan 29, 2000
Subject: Selling RV related items.
Just a thought but possibly we (the list) should contact an online auction house such as ebay, ubid, or boxlot. We could have them setup a catagory for RV related stuff. This would provide a method of selling items that would not anger anyone. This would provide a simple way to list things and a single place to look to buy things also. The only bad point I see is that the auction house would skim 1 or 2 % from us. Dustin ________________________________________________________________________________
Date: Jan 29, 2000
Subject: Re: Time to get an Engine?
In a message dated 1/29/00 10:51:29 AM Eastern Standard Time, jorear(at)mari.net writes: << Hi Folks: As I am moving along quite nicely on the second wing (that learning curve is a wonderful thing), I am looking forward a bit to construction of the fuse. Being the planner that I am, I am wondering at what point is having the engine in house necessary? Can this hefty purchase wait until the finish kit, or do I need it during construction of the fuse? >> If you know which engine you're going to use (easy if you're buying new from Van's), there is no need to purchase it until after the finish kit arrives. Kyle Boatright ________________________________________________________________________________
Subject: Lean Mixture
Date: Jan 29, 2000
Hi Bud: Just a couple of ideas. When you are set up at cruise power say 2400 RPM and 22 inches manifold pressure is your EGT's at peak or can you still get a rise when you attempt to lean. If you can get a rise , how much? If it is running too lean when you try leaning further the EGT's should drop. To me the actual EGT readings are only a reference. These readings can vary a lot depending on the location of the probes. Also I have found that there is a wide variation in the mixture to each cylinder on a carburated Lycoming. In my case changing to fuel injection cured this, now all four EGT's are exactly the same. The other thing I might mention is if when your had your carb. apart if for whatever reason the float level was changed this could also affect the mixture. Eustace Bowhay - Blind Bay, B.C. 6A ready to come out of jig. ________________________________________________________________________________
Subject: Re: ELT mount
Date: Jan 29, 2000
Jeff, I made the floor of the baggage compartment come out (6 nut plates). Of course, I have to remember to carry the proper screw driver to be able to remove the floor. Then I mounted the ELT under the floor. The ant. comes out through the floor of the fuselage too. Theory, if I land upright I shouldn't need the ELT, however, if I turn upside down, the ELT ant. will be pointed up. If the crash is bad enought that I don't survive, I don't care which way the ant. is pointed. Tom Gummo 90% done with 90% to go ----- Original Message ----- From: J. Farrar <jfarrar1(at)home.com> Sent: Friday, January 28, 2000 4:38 PM Subject: RV-List: ELT mount > > Need some opinions. I am looking for a mounting location for an ACK EL-01 > elt, the one that is portable and uses d-cell batteries. It needs to be > accessible for portable use. The only place I can see to mount it is in the > rear baggage compartment in my -8A. On the hat shelf with a .025 doubler > for added stiffness. Does anyone see a problem with this. Is the hat shelf > sufficiently stiff for this use? I don't want it tearing out in a crash. > Thanks, Jeff Farrar, RV8A N4ZF reserved, Chandler, AZ jfarrar1(at)home.com > Wings done, fuselage almost, fuselage interior and wiring. > > ________________________________________________________________________________
From: Lothar Klingmuller <lothark(at)worldnet.att.net>
Subject: Help on TWO In-line Fuel Filters
Date: Jan 29, 2000
Here is my question, concern, and thinking: Has anybody thought of installing or flying with two (yes 2 !) in-line fuel filters.?? The filters would be loccated on each tank line prior to reaching the fuel selector. That means a total of 4 in-line filters! The reason I want to use two filters is screening, e. g. the first is coarse (in the 60 mesh = 250 um) and the second fine ( in the 200 mesh = 60-80 um range). The method of reducing screen sizes is currently used in most AC (see also below). The fine filters are commonly used in racing cars. I am afraid to use the fine filter only because of rapid plugging in case there is crudd in the fuel. I have not been able to locate a coarse e. g. 60 mesh in-line filter. Does anybody know of a source a for coarse in-line see-through fuel filter?? For background information: In-line filters are used in VariEze, Quicki etc ( according to Aircraft Spruce) and by some local (Denver area) flying RVs. The great references of Toni Bingelis (on Engines, mostly RV !) shows a schematics of fuel system filters (Fig. 2, p. 161). His screen sizes are 1]16 (=1.24mm) mesh in the fuel tank, 2] 60 (=250 um) mesh in the cascolator, 3] 200 (=80 um) mesh in the carburator. However, Bingelis has the electric fuel pump located AFTER the gascolator in the engine compartment. Vans shows no fuel filters prior to the FACET electric fuel pump located inside the cockpit. The FACET pump states to keep it in a cool place (<140F). That means NOT in the fire-wall foreward location. I do not want to re-invent the wheel but are concerned that there is a filter (NOT a fine only) prior to the electric fuel pump. The FACET pump should be in the cockpit. Lothar |||-6A tip up; fuel and brake lines before starting canopy ||| Lakewood/ Denver, CO ________________________________________________________________________________
Date: Jan 29, 2000
In a message dated 1/29/2000 12:11:44 PM Eastern Standard Time, KBoatri144(at)aol.com writes: > If you know which engine you're going to use (easy if you're buying new from > Van's), there is no need to purchase it until after the finish kit arrives. > > > Kyle Boatright FWIW, Aero Sport is currently running 5 to 6 months out, at least on the IO-360 I had quoted. I'm currently working on my first wing and am planning to place engine and fuselage orders when I start on the second wing. Also, I understand that Van's is running a good six months out on new Hartzell props. I'll probably order the prop when I start on the fuselage. YMMV, of course. Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Date: Jan 29, 2000
>>People will make arguments about a "proper" design eliminating the >>need for an accessible fuse/breaker in any given situation. They'll >>make these arguments AFTER knowing all the circumstances that >>made the accessible breaker/fuse useful. But it is not possible to >>anticipate every fault/problem/circumstance that may occur, so I say >>give the pilot in command maximum control over his aircraft's electrical >>system. The decision to reset a circuit belongs with the PIC. The >>decision to power down a circuit belongs with the PIC. I will not hide >>my breakers/fuses and rob myself of the option of turning off or >>resetting a circuit in flight, based on my needs and my judgment >>during the flight. Suppose you're flying a Cessna or Piper with push-to-reset only breakers? Do you refuse to rent such a machine because it lacks important controls? Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Jan 29, 2000
Subject: Re: breaker welding
>It came from an alternator circuit and a shorted battery. A friend of mine >who was in the aircraft at the time reset the breaker twice when it failed >'on' and then ate the alternator. Luckly he was on the skirt when it >happened and just shut down and got towed back to the hanger. On further reflection, I'm thinking perhaps the alternator was already bad . . . shorted diodes. The breaker popped because of a very high backfeed fault into the alternator while the battery was providing the energy necessary to weld things. Appreciate your additional data on this phenomenon. I'm going to include some discussion on it in Rev 9 of the book . . . Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Jan 29, 2000
Subject: Re: Voltage Regulator/Voltage meters
> >> >> the ripple voltage left on a 3-phase alternator's rectified output >> is about 5% of the average DC . . . for a 14v alternator this is >> on the order of 700 mV peak to peak. Normally, this isn't a problem >> for avionics or other accessories designed to run in vehicles >> of any kind having an alternator/battery power system. > > >Is that 5% with a battery in the circuit? Or just a small DC source for >field excitation? I went and checked the alternator in my Mazda (car) and >it had at least 1.8 V peak to peak according to the scope. No, that's the theoretical value of ripple when you rectify 3-phase ac into a purely resistive load. You can overlap three sine-waves displaced 120 degrees from each other, take only the waveform above the overlapped envelope of the three waveforms and you get the 5% value. In an alernator, you'll get some additional little spikey noises due to ringing of the alternator windings as the diodes switch into and out of conduction. Depending on alternator loads, switching speed of diodes, inductance of widings, these lower energy components may well exceed the basic AC ripple left over for rectified 3-phase. Given that they are lower energy and short duration (higher frequency) these are the components that benefit from filtering at the rear of the alternator (Fat capacitor). Local filtering is suggested when you have an ADF or Loran that fusses about alternator noise. The lower frequency component (true ripple from rectification of AC) is VERY difficult to filter and is generally mitigated >> >> It's true that some digital meters are sensitive to this kind of >> noise and will benefit from some filtering. The DC meter modules >> I use the most have a 10 to 100 Megohm input impedance so adding >> 10K of series resistance in the meter's sense lead doesn't upset >> the calibration much . . less than 0.1%. After the resistor >> is added, you put a capacitor across the meter's input terminals, >> anything 0.1 uF up to 10 uF is fine . . . 1.0 uF and larger tend >> to be electrolytics so observe polarity. >> >> This simple R/C filter will calm the little fellers down so that >> their readings are accurate. > > >The R/C filter is a good recommendation. I should have said that also. I >have mine in a small plastic box with lead jacks for my meter. I used a 22K >in series with the positive lead and a 10uF tantilum capacitor and a 0.1uF >ceramic. It had been so long I had to open the box to remember. That would do it . . Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Subject: Re: Help on TWO In-line Fuel Filters
Date: Jan 29, 2000
The reason that in-line filters were used in VariEzes was Burt lived in the desert and didn't have moisture problems. If I remember right this was quickly changed to a gascolator as water can be a big problem. With the composite planes, there was an awful lot of junk that washed out of the tank in the first couple hours. This would quickly plug the fine mesh of an inline. Since yours is metal airplane, you should have the problem, but why not go with the proven Gascolator system? If you filter what goes in the tank, then there should not be a problem. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) -----Original Message----- From: Lothar Klingmuller <lothark(at)worldnet.att.net> Date: Saturday, January 29, 2000 2:10 PM Subject: RV-List: Help on TWO In-line Fuel Filters > >Here is my question, concern, and thinking: >Has anybody thought of installing or flying with two (yes 2 !) in-line >fuel filters.?? The filters would be loccated on each tank line prior to >reaching the fuel selector. That means a total of 4 in-line filters! >The reason I want to use two filters is screening, e. g. the first is coarse >(in the 60 mesh = 250 um) and the second fine ( in the 200 mesh = 60-80 um >range). The method of reducing screen sizes is currently used in most AC >(see also below). The fine filters are commonly used in racing cars. >I am afraid to use the fine filter only because of rapid plugging in case >there is crudd in the fuel. I have not been able to locate a coarse e. g. >60 mesh in-line filter. Does anybody know of a source a for coarse in-line >see-through fuel filter?? > >For background information: >In-line filters are used in VariEze, Quicki etc ( according to Aircraft >Spruce) and by some local (Denver area) flying RVs. > >The great references of Toni Bingelis (on Engines, mostly RV !) shows a >schematics of fuel system filters (Fig. 2, p. 161). His screen sizes are >1]16 (=1.24mm) mesh in the fuel tank, >2] 60 (=250 um) mesh in the cascolator, >3] 200 (=80 um) mesh in the carburator. >However, Bingelis has the electric fuel pump located AFTER the gascolator in >the engine compartment. Vans shows no fuel filters prior to the FACET >electric fuel pump located inside the cockpit. The FACET pump states to keep >it in a cool place (<140F). That means NOT in the fire-wall foreward location. > >I do not want to re-invent the wheel but are concerned that there is a >filter (NOT a fine only) prior to the electric fuel pump. The FACET pump >should be in the cockpit. > > > Lothar |||-6A tip up; fuel and brake lines before starting canopy ||| >Lakewood/ Denver, CO > > ________________________________________________________________________________
From: "Charles Zaloom" <czaloom(at)worldnet.att.net>
Date: Jan 29, 2000
Curious, has anyone seen in-line filters on any certified aircraft? I'm very leery of them -- they'll protect the engine to the point of starving it. That's fine for a car or boat, but they don't separate large quantities of junk at high flow rates the way a gascolator does, nor is there a drain or reasonable inspection access. It may be just as well to let anything small enough to get through Bingelis' 3 screens to go through the engine. It'll probably be an infrequent event and I guess I'd accept status quo (imperfect filtration/shorter engine life) over stoppage and a forced landing. It may be significant that TB doesn't mention in-lines... -Z ----- Original Message ----- From: "Lothar Klingmuller" <lothark(at)worldnet.att.net> Sent: Saturday, January 29, 2000 2:28 PM Subject: RV-List: Help on TWO In-line Fuel Filters > > Here is my question, concern, and thinking: > Has anybody thought of installing or flying with two (yes 2 !) in-line > fuel filters.?? The filters would be loccated on each tank line prior to > reaching the fuel selector. That means a total of 4 in-line filters! > The reason I want to use two filters is screening, e. g. the first is coarse > (in the 60 mesh = 250 um) and the second fine ( in the 200 mesh = 60-80 um > range). The method of reducing screen sizes is currently used in most AC > (see also below). The fine filters are commonly used in racing cars. > I am afraid to use the fine filter only because of rapid plugging in case > there is crudd in the fuel. I have not been able to locate a coarse e. g. > 60 mesh in-line filter. Does anybody know of a source a for coarse in-line > see-through fuel filter?? > > For background information: > In-line filters are used in VariEze, Quicki etc ( according to Aircraft > Spruce) and by some local (Denver area) flying RVs. > > The great references of Toni Bingelis (on Engines, mostly RV !) shows a > schematics of fuel system filters (Fig. 2, p. 161). His screen sizes are > 1]16 (=1.24mm) mesh in the fuel tank, > 2] 60 (=250 um) mesh in the cascolator, > 3] 200 (=80 um) mesh in the carburator. > However, Bingelis has the electric fuel pump located AFTER the gascolator in > the engine compartment. Vans shows no fuel filters prior to the FACET > electric fuel pump located inside the cockpit. The FACET pump states to keep > it in a cool place (<140F). That means NOT in the fire-wall foreward location. > > I do not want to re-invent the wheel but are concerned that there is a > filter (NOT a fine only) prior to the electric fuel pump. The FACET pump > should be in the cockpit. > > > Lothar |||-6A tip up; fuel and brake lines before starting canopy ||| > Lakewood/ Denver, CO > > ________________________________________________________________________________
Date: Jan 29, 2000
Jeff, Dave & I placed our ACK ELT behind the baggage compartment,as follows: We placed the rear battery shelf per plans and attached two pieces of angle (cross wise) to the battery tray. The battery tray is bolted to the floor lonerons (pre plans and the cross members' end to the side lonerons. Looking aft our Powersonic 19 amp battery is secured to the battery tray. The ELT mount is bolted to scrap of .125 AL (that is riveted to the two pieces of angle) on the right of the battery. We mounted our Whelen power supply to the left of the battery, by bolting it directly to the angles. Good Building, Chuck & Dave Rowbotham RV-8A ( will be riveting the canopy tomorrow) Niantic, CT >From: "J. Farrar" <jfarrar1(at)home.com> >Reply-To: rv-list(at)matronics.com >To: , "RV List" >Subject: RV-List: ELT mount >Date: Fri, 28 Jan 2000 17:38:56 -0700 > > >Need some opinions. I am looking for a mounting location for an ACK EL-01 >elt, the one that is portable and uses d-cell batteries. It needs to be >accessible for portable use. The only place I can see to mount it is in >the >rear baggage compartment in my -8A. On the hat shelf with a .025 doubler >for added stiffness. Does anyone see a problem with this. Is the hat >shelf >sufficiently stiff for this use? I don't want it tearing out in a crash. >Thanks, Jeff Farrar, RV8A N4ZF reserved, Chandler, AZ jfarrar1(at)home.com >Wings done, fuselage almost, fuselage interior and wiring. > > ________________________________________________________________________________
Date: Jan 29, 2000
Subject: Re: Standardized List Sales/apology
Charlie, Thanks for the consideration. I must admit that I was surprised by that post. I have always considered your posts very relevant to the issue and well stated. We all have a flyer once in a while. ;-) I know I do. Thanks for responding so positively, now let's let it die. Al >Al (and the rest of the list), > >My apologies. > >Charlie ________________________________________________________________________________
Date: Jan 29, 2000
It should have said NOT have the problem with metal tanks. By the way, There aren't any inline filters in the gas supply of certified airplanes. FAA won't certify it any other way. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) -----Original Message----- From: Cy Galley <cgalley(at)accessus.net> Date: Saturday, January 29, 2000 4:02 PM Subject: Re: RV-List: Help on TWO In-line Fuel Filters > >The reason that in-line filters were used in VariEzes was Burt lived in the >desert and didn't have moisture problems. If I remember right this was >quickly changed to a gascolator as water can be a big problem. With the >composite planes, there was an awful lot of junk that washed out of the >tank in the first couple hours. This would quickly plug the fine mesh of an >inline. Since yours is metal airplane, you should have the problem, but why >not go with the proven Gascolator system? If you filter what goes in the >tank, then there should not be a problem. > >Cy Galley - Editor, B-C Contact! >(Click here to visit our Club site at http://www.bellanca-championclub.com) > > >-----Original Message----- >From: Lothar Klingmuller <lothark(at)worldnet.att.net> >To: rv-list(at)matronics.com >Date: Saturday, January 29, 2000 2:10 PM >Subject: RV-List: Help on TWO In-line Fuel Filters > > > >> >>Here is my question, concern, and thinking: >>Has anybody thought of installing or flying with two (yes 2 !) in-line >>fuel filters.?? The filters would be loccated on each tank line prior to >>reaching the fuel selector. That means a total of 4 in-line filters! >>The reason I want to use two filters is screening, e. g. the first is >coarse >>(in the 60 mesh = 250 um) and the second fine ( in the 200 mesh = 60-80 um >>range). The method of reducing screen sizes is currently used in most AC >>(see also below). The fine filters are commonly used in racing cars. >>I am afraid to use the fine filter only because of rapid plugging in case >>there is crudd in the fuel. I have not been able to locate a coarse e. g. >>60 mesh in-line filter. Does anybody know of a source a for coarse in-line >>see-through fuel filter?? >> >>For background information: >>In-line filters are used in VariEze, Quicki etc ( according to Aircraft >>Spruce) and by some local (Denver area) flying RVs. >> >>The great references of Toni Bingelis (on Engines, mostly RV !) shows a >>schematics of fuel system filters (Fig. 2, p. 161). His screen sizes are >>1]16 (=1.24mm) mesh in the fuel tank, >>2] 60 (=250 um) mesh in the cascolator, >>3] 200 (=80 um) mesh in the carburator. >>However, Bingelis has the electric fuel pump located AFTER the gascolator >in >>the engine compartment. Vans shows no fuel filters prior to the FACET >>electric fuel pump located inside the cockpit. The FACET pump states to >keep >>it in a cool place (<140F). That means NOT in the fire-wall foreward >location. >> >>I do not want to re-invent the wheel but are concerned that there is a >>filter (NOT a fine only) prior to the electric fuel pump. The FACET pump >>should be in the cockpit. >> >> >> Lothar |||-6A tip up; fuel and brake lines before starting canopy ||| >>Lakewood/ Denver, CO >> >> > > ________________________________________________________________________________
Subject: 639 & 640 forward seat skins
Date: Jan 29, 2000
After fitting the 639 & 640 forward seat skins the 639 does not overlap the 640 enough to have the screws that hold them have enough room without being to close to the edge of 639. The 640 is ok. I did not remove any more material than was necessary to fit them to the side of the fuselage and the ribs are straight. Has anybody got an answer as to why this is? Thanks ________________________________________________________________________________
Date: Jan 29, 2000
Subject: Re: Electric Flap Retrofit to RV-4
Don, By all means, retrofit to electric flaps. The stock flap arangement on the RV-4 is the only miserable part on a terrific airplane. I retrofitted my original RV-4 and installed electric from the get go on the new one. The manual flaps can be made to work by "pre-twisting" the flap lever so that the twist that is imparted by pulling the flaps on is cancelled out, but it still requires a lot of muscle. Regards, Bill N66WD ________________________________________________________________________________
Subject: Fw: RV-6 Kit Forsale
Date: Jan 29, 2000
----- Original Message ----- RV-6 Empenage and Wing kit for sale. The empenage kit is 95% complete. The wing kit which has the Phlogiston spar has been uncrated but not touched since. Both kits are before the pre-punched era. Does not have electric trim or any other options. I am located in east central Alabama, 120 miles southwest of Atlanta. Will sell both kits for $4900.00. Bought a Stearman. If you need more info, e-mail or call me. Joe Edmondson 256-825-8929 tazman(at)lakemartin.net ________________________________________________________________________________
Date: Jan 29, 2000
>From: KBoatri144(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Engine Component Safetying >Date: Fri, 28 Jan 2000 21:22:10 EST > > >I've got 3 things to safety wire, but can only find two places to tie off >the >safety wire... > >Items to safety: > >1) Oil filter (on a spin-on adapter). It looks like this safety's through >a >hole near the top of the spin on adapter. > >2) Vernatherm. Looks like this safety's through a hole near the bottom of >the spin on adapter. > >3) Oil temperature sensor. Could safety through the same hole as the oil >filter, but I doubt it... What gives?? > >Thanks, > >Kyle Boatright Kyle, It just so happens that I'm doing the same thing today. I'm changing out the oil screen housing for a spin on adapter. Safety the temp sensor to the little hole right where it screws into the housing. Safety the filter and the vernatherm to the lower hole. It really doesn't matter where you wire the stuff, as long as the parts absolutely cannot loosen. It doesn't have to be pretty, just effective. Brian Denk RV8 N94BD More mountain flying today. Can you say...tur..bu lence?? ________________________________________________________________________________
Subject: More flight comments, RV8 N94BD
Date: Jan 29, 2000
Greetings all, After 27 hours of RV grins, I thought I'd share a few more flight testing comments. First of all, I'm really not doing any serious, scientific data acquisition, but just getting a good feel for what this planes likes and does not like. 1. Landing: 75mph indicated (in my plane, your mph may vary) at solo weight on final works well. The time spent in the flare is just about right so you don't burn up a lot of runway. I was using 80mph for quite a while and just kept sailing down the runway waiting for it to quit flying. Amazing what 5mph can do. Still, start out at 80 in your plane and see how it feels. If you put it on straight, it will roll straight. Put it on in a crab, and you'll be fighting it down the runway. So, kick that nose straight...not sorta straight....but STRAIGHT! Nuff said. 2. Spins. Whoa...be careful here. I tried spins to the left today. I went waaaay up to 10,000' and did the usual clearing turns with a couple G's on it to kill off speed. Then, power back to idle, nose up, hold it, feel the shudder....then full left rudder....ok...I'm waiting...there it goes! It felt more like a wingover entry and the nose was much too low, or at least it looked that way. I didn't let if fully develop because I had a feeling in my gut that I was entering a spiral and the wing wasn't fully stalled. So, after about one and a half turns, stick forward and opposite rudder followed by a GENTLE pullout registering 3G on the meter had me back in the realm of straight and level flight. The speed never got critical, but certainly could have if I spent more time with the nose pointed straight down..as in a competition spin exit downline. To future new RV pilots: When thy nose is pointed earthward, you shall approach warp drive speed in a hurry! Something that REALLY got my attention was a loud bang type of noise during the spin rotation...I mean an oil canning type of noise. I think it was that flimsy feeling belly skin between the 808 and 809 bulkheads. All checks of the tail structure after the flight were normal. That belly skin does pop and flex a lot though. I might proseal a stiffener angle down there. The -8 really makes a racket when it's stalling, or spinning. So, rest assured, you will KNOW when it's ready to quit flying! The whole plane shakes, shudders and rattles. Not having this type of experience in other RV's, I cannot say if it's solely an RV8 behaviour or not. Oh and YES, I was wearing my parachute, and YES I've done spins before. I was also within gliding distance of a runway in case the Lycosaur decided to take a nap. 3. Cross country ground speeds at my typical cruise altitudes of nine to eleven thousand feet at full throttle (2650rpm is all I can get) have averaged 190mph. Fastest groundspeed to date: 235mph. Yes, it does get windy here. I still don't have the wheel pants on. OK OK! I'll get to it...someday. 4. Climb rates with the Sensenich -83" pitch on the O-360 180hp have been about 1200fpm with a moderate deck angle so I can (hopefully) see traffic ahead before we swap paint....er, well I get paint on my UNPAINTED plane from another plane. You get my meaning. I haven't nailed down the climb speeds exactly. 100mph indicated gives me this rate and steeper climb angles push temps up rather quickly. When my CHT is pushing 500 degrees, it's time to lower the nose. Simple as that. The engine seems happier with 100mph or more showing, and really lugs down at slower climb speeds. 5. Rolls: Easy! At full throttle, pitch up well above the horizon, lock that pitch angle, then full aileron. It's not on par with a Pitt's, but is over in a couple of seconds. As long as the pitchup is sufficient and no elevator is added during the roll, the nose will end up right on the horizon. With an inverted oil and fuel system, you could clean up the roll and keep the nose on the horizon throughout the maneuver....as long as the pilot does his job. I did notice the stick pulsing at full aileron deflection. It's not alarming at all, just a subtle vibration felt in the stick and you really have to put it against the stops to feel it. 6. Mechanical trims: The vernier elevator trim cable works GREAT. It's very smooth and you soon get a feel for it. Placing it per plans on the left panel, it's just a short reach from the throttle so pitch and power adjustments are easily accomplished. I put the flap switch right under the trim knob so all three can be manipulated without reaching. The aileron trim works well, but is rather stiff and has a lot of preload on the cable. The springs that attach to the control column could be a bit stiffer to give a more solid feel. As it is, I have to fiddle with it a bit to get the desired tension on the column. It just feels "soft". Those springs are a bear to get attached, and stiffer ones would be even more work, but I think it would be a better system in the end. 7. Fun factor: It just gets better every flight! These airplanes show you things that you may never have experienced before: Climb rates that take you up and over things right NOW, and not after a long, labored climb from miles away. Speed that gets you there TODAY, refreshed and in comfort. Maneuverability that just begs to be explored. No more twisting and heaving on a yoke and stomping on the pedals to turn...you just think of where you want to go, and the plane goes there. It's truly being "in tune" with the airplane. If there aren't any RV's at your airport, you will soon become a celebrity. Everyone wants to see it, and you might have to lock the hangar doors to get any work done. Press on, build it right and do quality work. The end result will be more than you ever imagined. Brian Denk RV8 N94BD RV grins 'o plenty ________________________________________________________________________________
Date: Jan 30, 2000
> >Here is my question, concern, and thinking: >Has anybody thought of installing or flying with two (yes 2 !) in-line >fuel filters.?? The filters would be loccated on each tank line prior to >reaching the fuel selector. That means a total of 4 in-line filters! I tried something similar in my 'other RV', that is to say, my motorhome, and would NOT do anything of the kind in an aircraft. I think it is a reasonable test bed for this installation since it burns 8 to 10 Gallons per hour under load. Other similarities are dual fuel tanks, selected independently, a single, inline electric fuel pump, and a single engine-driven fuel pump. I got carried away with fuel filters because the documentation for the electric boost pump I installed required filters prior to the pump. I'd had a problem with the electrically controlled tank selection valve being full of rust and decided that a filter needed to be inline prior to the valve as well. Long story short, you can have too many filters in a line. If you do try the filter to filter setup, be very sure you do good flow testing before you fly. I had problems with fuel starvation after sustained full-throttle operation (climbing long grades) and frequent partial vapor-locks. Really not worth the trouble. Even if the flow had been acceptable, there were other problems to consider. I tried several different kinds of filters. Some, notably the translucent filters with what appears to be paper elements from NAPA would not pass water. That is, when even a small amount of water in the system reached the filter it would partially block the filter and significantly reduce the flow rate. The clear glass filters with replaceable fine mesh plastic elements were more tolerant of water, but needed to be changed very freqently. The documentation suggests they be replaced every 5000 miles when used in an automobile. In a motorhome that translates to about every 1000 miles - probably about every 10 hours in an airplane. Really not worth the trouble. I haven't finalized my plans for the fuel system in my RV-6A, but I am sure that if it doesn't look exactly like the one designed by Van it will look exactly like one in a Cherokee. Without any automotive style inline fuel filters (or marine filters, although they might be more suitable). Did I mention I take a bath in gas every time I have to change those filters? - Mike ________________________________________________________________________________
Date: Jan 30, 2000
Subject: Pro-Seal substitute?
Can anyone offer a reason why I shouldn't use Aircraft Spruce's Pro-Seal 'type' tank sealant? It comes in cartridges (to be dispensed by either hand or air powered guns) and seems to be a simpler, neater means of attacking this necessary evil than dixie cups and popsicle sticks with goo everywhere. The listed Milspec is: MIL-S-8802E, Type II, Class B-2 Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Date: Jan 30, 2000
Subject: W-423?
George O. shows, in his -8 wing video, a part number W-423 which attachs to the inboard leading edge rib to serve as a mounting point for the tank attach platenuts. I haven't been able to find this part in my kit, plans or manual. Am I crazy or was it deleted from the kit since the video was made? What, if anything, took its place? FWIW, I may very well be crazy, anyway. :-) Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Subject: Re: Pro-Seal substitute?
Date: Jan 30, 2000
> Can anyone offer a reason why I shouldn't use Aircraft Spruce's Pro-Seal > 'type' tank sealant? It comes in cartridges (to be dispensed by either hand > or air powered guns) and seems to be a simpler, neater means of attacking > this necessary evil than dixie cups and popsicle sticks with goo everywhere. > The listed Milspec is: MIL-S-8802E, Type II, Class B-2 > > Regards, > Ken Balch > Ashland, MA > RV-8 #81125 Ken, I used it, works fine. And a lot let messier. I'm told it is exactly the same stuff. The only problem is that the dispenser is kind of expensive. Randy Lervold RV-8, #80500, panel, canopy skirt www.pacifier.com/~randyl ________________________________________________________________________________
Date: Jan 30, 2000
The applicator gun for the ProSeal works great...hhhmmmm..wondering what life would be like with out one>> ***Bryan E. Files*** A&P, IA, FAA Safety Counselor Fat City Aircraft Palmer, Alaska mailto:BFiles(at)corecom.net -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Kbalch1(at)aol.com Sent: Sunday, January 30, 2000 6:19 AM Subject: RV-List: Pro-Seal substitute? Can anyone offer a reason why I shouldn't use Aircraft Spruce's Pro-Seal 'type' tank sealant? It comes in cartridges (to be dispensed by either hand or air powered guns) and seems to be a simpler, neater means of attacking this necessary evil than dixie cups and popsicle sticks with goo everywhere. The listed Milspec is: MIL-S-8802E, Type II, Class B-2 Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Date: Jan 30, 2000
In a message dated 1/30/2000 11:08:45 AM Eastern Standard Time, randyl(at)pacifier.com writes: > Ken, > I used it, works fine. And a lot let messier. I'm told it is exactly the > same stuff. The only problem is that the dispenser is kind of expensive. > > Randy Lervold > RV-8, #80500, panel, canopy skirt > www.pacifier.com/~randyl Hi Randy, Sounds good to me! For myself, I prefer the expense to the mess. I'm pretty sure that it's similar, if not the same. The Milspecs listed in Van's catalog & Aicraft Spruce's are different. That aside, I'm going to go ahead with it. The order goes in tomorrow morning. Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Date: Jan 30, 2000
In a message dated 1/30/2000 11:58:33 AM Eastern Standard Time, bfiles(at)corecom.net writes: > The applicator gun for the ProSeal works great...hhhmmmm..wondering what > life would be like with out one>> > ***Bryan E. Files*** > A&P, IA, FAA Safety Counselor > Fat City Aircraft > Palmer, Alaska > mailto:BFiles(at)corecom.net Hi Bryan, Are you using the hand or air powered gun? I'm inclined toward the air powered... Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Date: Jan 30, 2000
Subject: Cleveland Wheels
Are "standard" Cleveland wheels made of magnesium or aluminum. In the ACS catalog, they list conversion kits as magnesium for general use and aluminum for "Ag" use. If they are magnesium, do they need to be etched and alodined before paining? Bruce Green ________________________________________________________________________________
From: "Mark D. Dickens" <mddickens(at)mindspring.com>
Subject: Re: W-423?
Date: Jan 30, 2000
The W-423 is shown on the packing list as the two strips of aluminum which are 36.5" long (they are not shown as W-423 except in the explanation). Look for them under the "AS032...36 1/2" part number... ----- Original Message ----- From: <Kbalch1(at)aol.com> Sent: Sunday, January 30, 2000 9:19 AM Subject: RV-List: W-423? > > George O. shows, in his -8 wing video, a part number W-423 which attachs to > the inboard leading edge rib to serve as a mounting point for the tank attach > platenuts. I haven't been able to find this part in my kit, plans or manual. > Am I crazy or was it deleted from the kit since the video was made? What, > if anything, took its place? FWIW, I may very well be crazy, anyway. :-) > > Regards, > Ken Balch > Ashland, MA > RV-8 #81125 > wings > > ________________________________________________________________________________
Date: Jan 30, 2000
Subject: Re: W-423?
Ken, the w-423 is a 2" wide by 36" (approx) strip that is buried in the bottom of your wing kit box along with some very similar strips that are included as practice materials as in the empennage kit. I had a hard time finding these and other parts on the bottom of the box as I did not inventory the full wing kit due to a lack of storage space. the W-423 is definitely needed to connect the fuel tank with the leading edge section. Andy Johnson, -8, left wing done, started right. ________________________________________________________________________________
Subject: Re: Cleveland Wheels
Date: Jan 30, 2000
Are you not going to use wheel pants? You can't see the wheels with pants on, so why paint them? Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit ----- Original Message ----- From: "b green" <rvinfo(at)juno.com> Sent: Sunday, January 30, 2000 1:13 PM Subject: RV-List: Cleveland Wheels > > Are "standard" Cleveland wheels made of magnesium or aluminum. In the > ACS catalog, they list conversion kits as magnesium for general use and > aluminum for "Ag" use. > > If they are magnesium, do they need to be etched and alodined before > paining? > > Bruce Green > > ________________________________________________________________________________
Date: Jan 30, 2000
-> > > >Can anyone offer a reason why I shouldn't use Aircraft Spruce's Pro-Seal >'type' tank sealant? It comes in cartridges (to be dispensed by either >hand >or air powered guns) and seems to be a simpler, neater means of attacking >this necessary evil than dixie cups and popsicle sticks with goo >everywhere. >The listed Milspec is: MIL-S-8802E, Type II, Class B-2 > >Regards, >Ken Balch >Ashland, MA >RV-8 #81125 >wings > Ken, I used one of these to do the stiffeners on the bottom of both tanks. I worked well and seemed to be exactly the same stuff as you get in the cans from Van's. For what it's worth, the only leaks I've had have been on those stiffeners. I really don't think it was the sealant, but the guy using it! Just wanted to offer my experiences with it. If I had to do it all over again...(Ack!!)..I'd just use the kit from Van's. It's really not that bad once you get used to it. I used paper plates and large craft sticks. I never got a drop on me anywhere. I used a small postal scale found at Walmart to meter out the white goo with the black goo. Place the paper plate on the scale, zero the scale, then glop the goo on the plate. Mix well, smear on toast, enjoy. :) Brian Denk RV8 N94BD flyin' n smilin' ________________________________________________________________________________
Date: Jan 30, 2000
Subject: Hood-type respirator system
Listers--Does anyone know where I can get one of those hood-type respirator systems that fit over your head and down to your shoulders? Does anyone have experience with such a type? Have been through my catalogs and don't see it. Looks like it might do a better job of keeping paint out of hair and eyes, plus I would like to compare price with Hobbyair. Thanks. --LeRoy Johnston, Columbus, OH, RV-6 empennage. ________________________________________________________________________________
Date: Jan 31, 2000
Jeff Orear wrote: > Being the planner that I am, I am wondering at what point is having the > engine in house necessary? Can this hefty purchase wait until the finish > kit, or do I need it during construction of the fuse? Jeff, You don't need the engine at all for fuselage construction. You can even go some way into the finish kit without an engine. However... if you don't know what engine you're going to use, you can't buy your engine mount. And the gear legs are match-drilled to the mount, so you can't get those either. Also, the airscoop is specific to O320 or O360. Frank. (No engine decision made yet, fuselage about complete, starting canopy work) RV-6 #24692, Marton, NZ) ________________________________________________________________________________
Date: Jan 30, 2000
Subject: Re: Hood-type respirator system
> >Listers--Does anyone know where I can get one of those hood-type respirator >systems that fit over your head and down to your shoulders? Check the archives as there have been some emails about *MUCH* cheaper alternatives to the Hobby Aire. Things like simply made hoods and shop vacs to provide fresh air etc. Try searching with 'hood' and 'safety' hal ________________________________________________________________________________
Date: Jan 30, 2000
> >Jeff Orear wrote: > > Being the planner that I am, I am wondering at what point is having the > > engine in house necessary? Can this hefty purchase wait until the finish > > kit, or do I need it during construction of the fuse? I was just thinking about this the other day. I have had this new O360A for a year now. Had I had the cash in Janus Mercury fund all that time my engine would have been almost free! You must have the engine to do cowl, baffles, filtered air box, and connections - a few weeks. My problem is that poor planning (trying to make it look as complete as possible) left me with much to do behind the firewall. Next time I will do everything - **EVERYTHING** possible firewall back before getting the engine. Notice "getting" not ordering as they can have a long lead time. Actually, I might get avionics last since they are so much like lettuce. hal ________________________________________________________________________________
Date: Jan 30, 2000
Subject: Re: W-423?
Ken It is shown on drawing 17 ( top left quarter ) at the tank/leading edge intersection next to filler cap and is riveted between the inboard leading edge rib and leading edge skin. It is also show on the same drawing (17) in detail section E-E'. Hope this helps. Gert 8 wings too Kbalch1(at)aol.com wrote: > > > George O. shows, in his -8 wing video, a part number W-423 which attachs to > the inboard leading edge rib to serve as a mounting point for the tank attach > platenuts. I haven't been able to find this part in my kit, plans or manual. > Am I crazy or was it deleted from the kit since the video was made? What, > if anything, took its place? FWIW, I may very well be crazy, anyway. :-) > > Regards, > Ken Balch > Ashland, MA > RV-8 #81125 > wings > -- Pursuant to US Code, Title 47, Chapter 5, Subchapter II, '227, any and all nonsolicited commercial E-mail sent to this address is subject to a download and archival fee in the amount of $500 US. E-mailing denotes acceptance of these terms. ________________________________________________________________________________
Date: Jan 30, 2000
Subject: A short lecture on precision - was: Voltage meters
>I was very surprised on the qualitity of the digital meters. This remark prompts me to give a little lecture. Two things to learn in today's sermon: 1. Many measurement products are of *VERY* poor quality. 2. Digital instruments are usually not any more accurate than non-digital. Here is an enlightening little lab experiment. Go to the hardware store and check out the wall thermometers. See if you can find two that read the same. This is most dramatic with the best known brand, Taylor - all their stuff is awful. I've never check to see if the ones that are close at the store temp are also same at some other temp. I've never checked them to see if they are accurate either. They might be the same and off 5 degrees, huh? I wonder how the oil temp gauge does with the sender in boiling water? I just measured one of those little plastic "air aids" you get each year from AOPA. It is 5 31/32 inches from the 1 to the 6 !!! I haven't double checked my steel rule, however. Most electronic digital measurers get an analog value and convert it to digital. In many of these, the ADC (analog to digital conversion circuit) is probably pretty cheap but even the most accurate is just reading the analog indication and converting it. If the analog value is wrong, the digitization will not improve it. I recently dismantled a nice little Skyway Precision Tools quarter inch torque wrench of the click type. It has a little bar -- that is, inside it is just like the cheap torque wrenches with one heavy bar and one light one. We are told not to use them on airplanes because they are inaccurate. Actually, they are quite accurate but very hard to read in many positions. They get out of whack easily but are easily put back into whack. The dial type use a dial indicator to measure the bend of the little bar. You already know about the effects of grease and extreme cold. Some digital things actually measure a digital type of thing - a discrete event. For example, a tachometer *MIGHT* be a counter counting the flashes of light from a tiny bulb that passes by a photocell but most are analog converted to digital. Class dismissed! hal ________________________________________________________________________________
Date: Jan 30, 2000
> Listers--Does anyone know where I can get one of those hood-type respirator > systems that fit over your head and down to your shoulders? Does anyone have > experience with such a type? Have been through my catalogs and don't see it. > Looks like it might do a better job of keeping paint out of hair and eyes, > plus I would like to compare price with Hobbyair. I used a borrowed Hobbyair and got my own hood from a local safety supply store (Sanderson's Safety Supply in Portland OR.) Worked well, cost was $65. I was going to get a hose there too to go from the hood to the Hobbyair but they wanted $80 for that plus they didn't have the fittings, so I ended up going to a local hose supply place just a few blocks over (Associated Hose) and had them put some fittings on the ends of some "food grade" vinyl hose (that clear stuff with reinforcing webbing underneath, like you see in soda machines) which cost less than half that. As I said I used a Hobbyair but there are lots of posts in the archives about homemade air supply systems. Randall Henderson, RV-6 N6R (in the paint shop) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
Date: Jan 30, 2000
One thing about buying the engine early on, or first, you will get it cheaper as the cost increase each year for new at least is more than you can get for your money at the bank. Who knows where the next lawyer will strike, increasing the cost of all new engines?? Had a friend that bought an O-360 for his Eagle. Sent it back to the factory for not one but two AD repairs while he was building. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) -----Original Message----- From: Frank and Dorothy <frankvdh(at)ihug.co.nz> Date: Sunday, January 30, 2000 12:56 PM Subject: Re: RV-List: Time to get an Engine? > >Jeff Orear wrote: >> Being the planner that I am, I am wondering at what point is having the >> engine in house necessary? Can this hefty purchase wait until the finish >> kit, or do I need it during construction of the fuse? > >Jeff, > >You don't need the engine at all for fuselage construction. > >You can even go some way into the finish kit without an engine. >However... if you don't know what engine you're going to use, you can't >buy your engine mount. And the gear legs are match-drilled to the mount, >so you can't get those either. Also, the airscoop is specific to O320 or >O360. > >Frank. >(No engine decision made yet, fuselage about complete, starting canopy >work) >RV-6 #24692, Marton, NZ) > > ________________________________________________________________________________
Date: Jan 30, 2000
> You must have the engine to do cowl, baffles, filtered air box, and > connections - a few weeks. A few weeks?!? Hal, you must be a full timer - we non-retired guys aren't so fast. I think it took a week just to get the cowl trimmed, and a few more to get it drilled in. Alex Peterson Maple Grove, MN 6A ________________________________________________________________________________
Date: Jan 31, 2000
Subject: Airshow downunder
Hi, Just a note to let interested parties (who may happen to be in New Zealand in a fortnight's time) know that the annual airshow (for sport fliers!) is to be held February 11-13 with the main show day being the Saturday 12. L.Coats RV6 ZK-RVL 357.5hr ________________________________________________________________________________
Date: Jan 30, 2000
Subject: Re: J Stringer Add-ons - RV6
Dave, I just finished riveting the bottom fuselage skins on my 6A. The bottom aft fuse skin came out tight with no tendancy to oil can. I can't see any reason to add J stringers between the 606 and 608 bulkheads. Also, I have not heard of any builders doing this. Steve Allison Fitting the gear. San Jose, CA David Wentzell wrote: > > > Greetings > I have heard that some builders have added two J Stringers to the > bottom of the fuse between bulkheads 606 & 608 , and then one centered > between the > 608 & 610. > Has anyone done this? and / or, would recomend it?? > I can certainly see that it would be real easy to get carried away with > this sort of thing and I am constantly holding myself back from doing exactly > that. > > So ... comments?? > > David Wentzell > RV6 Fuse (starting to take shape) > Racine Wisconsin > ________________________________________________________________________________
Date: Jan 30, 2000
Subject: pitot tube rourting
for rv-8 builders. where have you found to be the best route for the pitot tube from the wing to the instrument panel? forward through the spar box, or up to the top longeron and then forward with the static line? Comments on this appreciated, because unlike the 3 or 6, the pitot tube runs behind aft of the wing spar. J Lane ________________________________________________________________________________
Date: Jan 30, 2000
Subject: Re: W-423?
In a message dated 1/30/2000 12:34:05 PM Eastern Standard Time, RV8DRIVER(at)aol.com writes: > Ken, the w-423 is a 2" wide by 36" (approx) strip that is buried in the > bottom of your wing kit box along with some very similar strips that are > included as practice materials as in the empennage kit. I had a hard time > finding these and other parts on the bottom of the box as I did not > inventory > the full wing kit due to a lack of storage space. the W-423 is definitely > needed to connect the fuel tank with the leading edge section. Andy Johnson, > > -8, left wing done, started right. OK, I'm an idiot. I'd even looked through those parts on the bottom of the box when I inventoried the kit, then promptly forgot about them. They're down there, alright. Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Date: Jan 30, 2000
Subject: Re: W-423?
In a message dated 1/30/2000 1:58:23 PM Eastern Standard Time, gert(at)execpc.com writes: > Ken > > It is shown on drawing 17 ( top left quarter ) at the tank/leading edge > intersection next to filler cap and is riveted between the inboard > leading edge rib and leading edge skin. It is also show on the same > drawing (17) in detail section E-E'. > > Hope this helps. > > Gert > > 8 wings too It sure is shown on Drawing 17 right where you say it is. I jumped the gun and my 'thorough' look through the plans, the manual & the kit was anything but. Consider it a lesson learned... :-) Thanks for pointing me in the right direction. Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Date: Jan 30, 2000
Subject: Re: W-423?
In a message dated 1/30/2000 12:28:36 PM Eastern Standard Time, mddickens(at)mindspring.com writes: > The W-423 is shown on the packing list as the two strips of aluminum > which are 36.5" long (they are not shown as W-423 except in the > explanation). Look for them under the "AS032...36 1/2" part number... Found 'em. Thanks for the hint. Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Date: Jan 30, 2000
In a message dated 1/30/2000 12:41:25 PM Eastern Standard Time, akroguy(at)hotmail.com writes: > Ken, > > I used one of these to do the stiffeners on the bottom of both tanks. I > worked well and seemed to be exactly the same stuff as you get in the cans > from Van's. For what it's worth, the only leaks I've had have been on those > stiffeners. I really don't think it was the sealant, but the guy using it! > Just wanted to offer my experiences with it. If I had to do it all over > again...(Ack!!)..I'd just use the kit from Van's. It's really not that bad > once you get used to it. I used paper plates and large craft sticks. I > never got a drop on me anywhere. I used a small postal scale found at > Walmart to meter out the white goo with the black goo. Place the paper > plate on the scale, zero the scale, then glop the goo on the plate. Mix > well, smear on toast, enjoy. :) > > Brian Denk > RV8 N94BD > flyin' n smilin' Hi Brian, Just curious, but why would you use Van's sealant kit if you had to do it over? Even if the measuring, mixing & glopping is not too stressful, why bother with it at all if the cartridges make it unnecessary? Assuming that your leaks were really the fault of the applicator, not the applicant, as it were... :-) Am I missing something? Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Date: Jan 30, 2000
> >Hi Brian, > >Just curious, but why would you use Van's sealant kit if you had to do it >over? Even if the measuring, mixing & glopping is not too stressful, why >bother with it at all if the cartridges make it unnecessary? Assuming that >your leaks were really the fault of the applicator, not the applicant, as >it >were... :-) Am I missing something? > >Regards, >Ken Balch >Ashland, MA >RV-8 #81125 >wings The main reason I abandoned the cartridges was due to cost, and the stuff is so thick that it pretty much destroyed the caulking gun I was using. Using a super heavy duty gun would be the way to go for sure. Or, isn't there a pneumatic applicator? Even better yet, but I didn't want to spend more money to do something that I can do myself with a couple dollar's worth of paper plates and mixing sticks. By using the "black death in a can", you can also custom mix exactly the amount you need. Once you charge the cartridge and get it all mixed up, you'd better use it up because the clock is running. I found two hours to be the maximum working time during the summer. If you use the cartridges, you will save yourself the weighing of the two parts and get a very accurate mix every time. You will still have to smear the goo around where you need it on your tank parts. So, you will still get your hands, riveting tools and clecos messy. The cartridges don't save you from this....only the sheer grace of God and living a clean life devoid of frivolous fun and debauchery will save you from this. OK, maybe not. Either way, you'll get it done and have a flying airplane. Believe it or not, I developed a fondness for the sealant. I actually started to ENJOY playing with it! Yes, I'm not well. Not well at all. *twitch* Brian Denk RV8 N94BD at work but wanna fly! Superbowl?? Who cares when you have an RV? ________________________________________________________________________________
Date: Jan 30, 2000
I have a friend in the Air Nat Guard that gave me some Sealant they used on C-130 that came from Lockheed. It is MIL-S-8802, type II, Class B2. Looks just like proseal after mixing. It comes with a Dasher Rod that does the mixing in the cartridge. I mixed it and used latex gloves and popsicle sticks to apply. It was made by Piedmont Adhesive & Sealant Systems, Inc. , 84 Patterson Road, Lawrenceville, Ga. 30244. 404-563-3653. Could be the same stuff Aircraft Spruce is selling. Earl, RV-4 finish kit Kbalch1(at)aol.com wrote: > > > Can anyone offer a reason why I shouldn't use Aircraft Spruce's Pro-Seal > 'type' tank sealant? It comes in cartridges (to be dispensed by either hand > or air powered guns) and seems to be a simpler, neater means of attacking > this necessary evil than dixie cups and popsicle sticks with goo everywhere. > The listed Milspec is: MIL-S-8802E, Type II, Class B-2 > > Regards, > Ken Balch > Ashland, MA > RV-8 #81125 > wings > ________________________________________________________________________________
Date: Jan 30, 2000
Subject: RV 6A
INTERESTED IN PURCHASING QUALITY BUILT RV6A WITHOUT ENGINE Tremsc(at)aol.com ________________________________________________________________________________
Date: Jan 30, 2000
Subject: 0320 Engine for sale
FOR SALE - 0320 E2D ENGINE TT - 2000 -0- - SMOH including millinium cylinders CERTIFIED INCLUDING LOGS $12500.00 Tremsc(at)aol.com ________________________________________________________________________________
Date: Jan 30, 2000
Yes, I did that on the two RV-6 aircraft I'm building because every RV 6 I flew in formation with had severe oil can deflection in that area. This can only lead to premature cracking and this way the problem can be fixed before a crack can begin. We are not talking about much weight at all and it is a simple addition during the construction process. Greg Schmidt RV6S N250GS Canopy and wiring Phoenix DVT ________________________________________________________________________________
Subject: Another RV Grin
Date: Jan 30, 2000
Couldn't stand another day of Bill's grin. So, with 2 hours on the old tack-o-meter, N110KB and I consummated our relationship in .8 hour south of Pueblo airport in the practice area. After all, I did help build her, and I didn't want her to get too used to only Bill's touch in the air. We were compatible from the taxi all the way through the final flare. What an experience! Now Bill and I have matching RV grins, and a lot of thanks to everyone on the list for support. Kathy Peck N110KB FLYING!!! ________________________________________________________________________________
Date: Jan 30, 2000
Subject: RV-6 Wanted
Looking for RV-6 project. Good workmanship a must. Without engine, instruments, or interior is OK. Chuck ________________________________________________________________________________
Date: Jan 30, 2000
From: Thomas McIntyre <bogeybrother(at)earthlink.net>
Subject: Re: RV3-List: RV3 Performance Enhancements
The two easiest and possibly most effective performance enhancements you should do is get a set of two piece wheel fairings and fit them them with minimal clearance to the tires. Next is try to eliminate trim drag. Be careful in aligning your wheel pants and gearleg fairings. Are your elevators in perfect trail at your normal high speed cruise speed? If not re-shim the horizontal. If you've got a BUTT (big ugly trim tab) on your rudder, reposition your vertical stabilizer for 'feet off' at your cruise speed. I don't think the fancy wing to fuselage fairings do much for you except in high angle of attack situations. At least that's my experience. Now that you've got a straight airframe you can start to spend $ on engine enhancements. It'll never end. Good Luck Tom RV3 978TM Linzel G . Civ - 43CES/CECP wrote: > --> RV3-List message posted by: "Linzel G . Civ - 43CES/CECP" > > Has anyone made any minor airframe modifications to a stock RV3 like > additional fairings, gap seals, etc. (unless they are keeping them secret) > and noticed performance improvements. > > My RV3 flies as advertised which is great. However, I see nifty wing root > fairings on some planes and Mooneys have nice tight aileron and elevator > seals. If anyone has tried a mod and found it of questionable benefit or > that it came with some undesirable side effect I'll know not to try it. > > Gray > ________________________________________________________________________________
Date: Jan 30, 2000
In a message dated 01/30/2000 7:36:04 AM Pacific Standard Time, Kbalch1(at)aol.com writes: > Can anyone offer a reason why I shouldn't use Aircraft Spruce's Pro-Seal > 'type' tank sealant? It comes in cartridges (to be dispensed by either > hand > or air powered guns) and seems to be a simpler, neater means of attacking > this necessary evil than dixie cups and popsicle sticks with goo everywhere. > > The listed Milspec is: MIL-S-8802E, Type II, Class B-2 Ken, I have used this with good results. The one disadvantage is that you have to use the whole cartridge at once. Cant mix up just a little bit. Dale Wotring RV6A Vancouver, WA ________________________________________________________________________________
Date: Jan 30, 2000
Hi Ken, I use the pneumatic gun. Spendy buy you will be happy. When you get finished with it and want to sell it give me a call I can always use another. ***Bryan E. Files*** A&P, IA, FAA Safety Counselor Fat City Aircraft Palmer, Alaska mailto:BFiles(at)corecom.net -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Kbalch1(at)aol.com Sent: Sunday, January 30, 2000 8:12 AM Subject: Re: RV-List: Pro-Seal substitute? In a message dated 1/30/2000 11:58:33 AM Eastern Standard Time, bfiles(at)corecom.net writes: > The applicator gun for the ProSeal works great...hhhmmmm..wondering what > life would be like with out one>> > ***Bryan E. Files*** > A&P, IA, FAA Safety Counselor > Fat City Aircraft > Palmer, Alaska > mailto:BFiles(at)corecom.net Hi Bryan, Are you using the hand or air powered gun? I'm inclined toward the air powered... Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Date: Jan 30, 2000
From: "Derrick L. Aubuchon" <n184da(at)pacbell.net>
Subject: Weight and Balance Numbers
Greetings everyone,,
January 25, 2000 - January 30, 2000
RV-Archive.digest.vol-hv
