RV-Archive.digest.vol-ic
March 05, 2000 - March 10, 2000
      actual in flight on an aircraft test. The co. is Team-38.com. Contact Len
      Bechtold on its performance and prices, they didn't seem out of line as our
      drive units have no provision for a governor and oil through the shaft.
      Compared to a Hartzell we were quoted for a 50 Bonanza it is cheap.
      Jess Meyers
      Belted Air Power
Subject: Re: Wing wiring conduit
Date: Mar 05, 2000
> We just need to find some > really light-weight (and cheap) material to use for this conduit (I'm > wondering if we can find some cardboard tube like Estes uses for model > rocket fuselages that would fill the bill - can't imagine that you could > find the weight, and it would make running wires easy whenever we find a > need...???) I dug up this post from 1997: United States Plastics, 1-800-537-9724 sells thin walled plastic tubing perfect for wire chases in wings or fuselage. This tubing is much lighter weight than the typical thin wall PVC tubing available at hardware stores. The tubing is made from Tenite butyrate, is clear, and in the diameters of interest is available with wall thicknesses of only 1/16" or 1/32". Their stock no. 42122, for example, is 7/16" by 1/2", and is only $.23 per foot. I have it through the wings, and will put one under the floor prior to closing. Alex Peterson 6A Maple Grove, MN ________________________________________________________________________________
Subject: Follow up to HVLP, Sort of.....
Date: Mar 05, 2000
James, what number or specification did Sherwin Williams come up with to match VAN's powdercoat? Thanks. ________________________________________________________________________________
Date: Mar 05, 2000
Subject: Re: source for lugs
In a message dated 3/5/00 7:36:26 AM Pacific Standard Time, N32LC(at)worldnet.att.net writes: << I need a couple of terminals (lugs) for 2 AWG and 4 AWG wires, connecting to 1/4" and 5/16" posts. i haven't been able to find the #2 X 1/4" anywhere yet... any recommended sources? >> West Marine. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: Mar 05, 2000
Subject: Re: O rings
In a message dated 3/4/00 8:37:42 AM Pacific Standard Time, tripod(at)oneimage.com writes: << How about an address, phone #, or e-mail address for Ace Seal>> Okay, how about all three. Ace Seal 2065 Martin Av #113 Santa Clara, CA 95050 800-ACE-SEAL E-mail aceseal(at)aol.com. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Subject: is conduit necessary?
Date: Mar 05, 2000
I'm using PVC type conduit from the local home supply store. One inch holes in the ribs are needed. It's smooth and light. 98 cents per 8 foot piece. Larry Bowen, RV-8 tanks/wings Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Mar 05, 2000
Subject: Re: Paint quantity
dgmurray wrote: > > > Listers: > > The time has come to add some color to my life and my RV-6. I have chosen to > use PPG Concept paint. I need to know if any one else has used this paint as > I need to know the total quantity of unthinned paint to purchase for a one > color paint job. > > Thanks in advance > ----------------------------------------------------- > Doug Murray > Southern Alberta Check this: http://home.HiWAAY.net/~sbuc/journal/paint1.html Sam Buchanan "The RV Journal" http;//home.hiwaay.net/~sbuc/journal ________________________________________________________________________________
Date: Mar 05, 2000
Subject: Re: Follow up to HVLP, Sort of.....
"Eric M. Strandjord" wrote: > > James, what number or specification did Sherwin Williams come up with > to match VAN's powdercoat? > It's the two part acrylic (I don't remember the exact name). I left a powder-coated piece and he called me a few days later with the paint. It was a custom match and isn't perfect. ________________________________________________________________________________
Date: Mar 05, 2000
Subject: MT Propeller
With all the talk about the MT Propeller, I wondered if they had a web site. Guess what I found? http://www.mt-propeller.com/ Please report back to the list with the price when you find out how much one costs for the O-320 / O-360. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, Flying So. CA, USA ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Subject: 6A Longitudinal Cowl Hinges
Date: Mar 05, 2000
I am getting ready to drill on the longitudinal hinges on my 6A S-cowl. I plan on drilling on the lower half with the lower cowl supported by the side and bottom clecoes and the hinge halves pinned together. I have the zipper inclined per plans/RVAtor. When I put on the top cowl (all fitted), how do I back up the hinge for drilling? I can reach in through the air intake for about 1/3 to 1/2 of the way back but after that I have no means of backing up the hinge. What have others done? Thanks. Dennis Persyk 6A finishing kit Hampshire, IL C38 ________________________________________________________________________________
Subject: Re: 6A Longitudinal Cowl Hinges
Date: Mar 05, 2000
Once I got the holes that you can reach that you mentioned, I took it off and drilled one hole towards the back of the cowl. Just a random place to hold the hinge on. Then I put it back on and finished the drilling. Fill the original hole, and you are all set. Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit ________________________________________________________________________________
Date: Mar 05, 2000
Subject: RV-8 804 BULKHEAD
I HAVE 99% OF MY WIRING DONE, THE THROTTLE QUADRANT IS IN, THE MANUAL AILERON TRIM IS IN, IS IT WISE TO CLOSE UP THE 804 BULKHEAD NOW OR WAIT UNTIL A LATER DATE?? ________________________________________________________________________________
Date: Mar 05, 2000
Subject: RV-8 ENGINE INSTALLATION
I'M ABOUT TO MOUNT MY NEW AO360A1A ENGINE WITH AIR-FLOW PERFORMANCE INJECTION AND LAZAR IGNITION TO MY RV-8. IS THERE ANY THING I SHOULD MOUNT TO THE FIREWALL BEFORE I MOUNT THE ENGINE?? ________________________________________________________________________________
Date: Mar 05, 2000
Subject: RV-8 ALTERNATE AIR
HAVE ANY OF THE FINISHED RV-8'S INSTALLED AN ALTERNATE AIR SOURCE WITH FUEL INJECTION. IF THE RAM AIR SOURCE WAS PLUGGED FOR SOME STRANGE REASON, (BIRD, ICE ) WOULDN'T AN ALTERNATE AIR SOURCE BE NEEDED?? ________________________________________________________________________________
Date: Mar 05, 2000
Subject: Re: is conduit necessary?
Also, with the conduit you can slide it in from the tip after the wing is completly finished and it won't get in the way of your riviting. Dave Bristol Louis Cappucci wrote: > > listers, > > for the wiring runs in the wings (to the landing lights, strobes, pitot > heat, etc.) is it necessary to use conduits (split tubing, etc.) ? can you > just run the wire bundle through snap bushings? what is the advantage of > using conduit? > > if you do use conduit, can you just run it through the ribs, or do you > still need to use the snap bushings to protect the conduit? > > louis cappucci > rv-6a wiring > mamaroneck, ny > ________________________________________________________________________________
Date: Mar 05, 2000
Subject: Re: Looking for...
I've seen some trays in E-bay. ________________________________________________________________________________
Date: Mar 05, 2000
Subject: Re: Fuel Pickup Tube
It is quite likely I am misinterpreting what you are saying; however if you are putting electrician tape inside your gas tank, I think this is a bad idea. 100LL will turn it to goo which will be harmfull to the Lycoming. -- Denis L.(Bum) Walsh ---------- >From: HCRV6(at)aol.com >To: rv-list(at)matronics.com ('rv-list(at)matronics.com') >Subject: RV-List: Fuel Pickup Tube >Date: Sun, Mar 5, 2000, 11:48 > > >I wrapped mine with about 6 or 8 turns of electricians tape where it contacts >the anti-rotation tab. > >Harry Crosby >-6 Finish Kit > > ________________________________________________________________________________
Date: Mar 05, 2000
Subject: Terry Coles RV Photo
Lister: I just put up a photo of Terry Cole's RV on our home page. WAY TO GO TERRY...Great choice of colors! Click the blue link below if you care to see it Regards, John @ AAMR/AirCore/Mar ineCore (http://members.aol.com/aamrelectr/index.html) ________________________________________________________________________________
Date: Mar 05, 2000
Subject: Re: RV-6A performance, and other topics...
> >I haven't sent an update to the list recently on what we're learning in the >flight test program for our RV-6A/O-360/Sensenich/1080 lb "fun machine". > >Did a little climb/descent testing yesterday. One of the most interesting >results from it is that this airplane just isn't very sensitive to speed in >terms of climb performance! Testing was done at various airspeeds, trying >to hold constant speed from 6,500 ft to 9,500 ft (ground level around here >is almost 5,000 MSL, and I'm a chicken when away from the runway - don't >like to be really low with no more practice/experience than either me or the >plane has had). > >What I found: at 80 kts indicated, it took 3:03 to climb 3,000 ft. At 90 >kts, 2:57. At 100 kts, 2:56. At 110 kts, 3:10. At 120kts, 3:40. So, Vy >is probably right around 105 kts, although cyl temps run just a little >higher than preferred (but not above limits) in an extended climb at that >speed. In all cases, the first thousand feet was a little quicker than the >last thousand, but not by a big difference (maybe 8-10 sec). Thanks for the post Bill - that data sure gives a nice classic looking plot of rate of climb vs speed. The way I read the graph, the best rate of climb is a bit less than 100 kt, but as you noted, there is little performance penalty to climbing faster, and you get better cooling if you do. One comment on doing climb or descent testing: The results you get can be affected by the changing winds as you change altitudes. For example, if you are climbing into an increasing headwind, every time the wind speed increases your airspeed will increase a bit, and you will pull the nose up a bit to get back on the desired speed. This gives you a bit of extra climb every time that happens, and the apparent climb rate will be a bit higher than it would be if the wind speed was constant. The opposite thing happens if you are climbing with a tail wind that increases as you climb. In the flight test world, we account for this by doing two runs at each speed, on headings 180 degrees apart, and averaging the results. For extra points, you would do the runs at 90 degrees to the expected wind, so the changes in wind speed will have less effect on the airspeed, which makes it easier to fly the test point. Keep up the good work Bill, Kevin Horton RV-8 (dimpling fuse skins) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
Date: Mar 05, 2000
Subject: VFR panel
I am considering a panel consisting of the appropriate radios, GPS for navigation. Here is the kicker for engine instruments the Rocky Mountain Monitor and the MicroEncoder for Airspeed, VSI, Altitude, OAT. Is this asking to much from these istruments for VFR flight. I believe Vans RV-8A uses only the MicroEncoder for flight information. Your thoughts please. ________________________________________________________________________________
Subject: Re: VFR panel
Date: Mar 05, 2000
It is obviously a great unit, but I would not want to depend on it soley for those functions...one problem with it, and all your instruments are gone. I would at minimum have a back up altimeter and airspeed indicator. I would not want to be flying at night and have that go out and not have an altimeter. In fact, RMI states that it is not intended to replace those instruments. The only thing in my panel the uEncoder completely replaces is the VSI. And then I get the OAT and others to boot. Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit ----- Original Message ----- ________________________________________________________________________________
Date: Mar 05, 2000
I have the standard 6 pack of instruments with the RMI microEncoder replacing the VSI. After 510+ hours of flying this way, I would not hesitate to use the RMI microEncoder as my only pitot static instruments for a VFR only aircraft. I saw an RV-4 at Merced / Bakersfield set up this way about 6 years back. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, Flying So. CA, USA ________________________________________________________________________________
Subject: Re: RV-8 ALTERNATE AIR
Date: Mar 05, 2000
----- Original Message ----- From: <SALNED71(at)aol.com> Sent: Sunday, March 05, 2000 5:34 PM Subject: RV-List: RV-8 ALTERNATE AIR HAVE ANY OF THE FINISHED RV-8'S INSTALLED AN ALTERNATE AIR SOURCE WITH FUEL INJECTION. IF THE RAM AIR SOURCE WAS PLUGGED FOR SOME STRANGE REASON, (BIRD, ICE ) WOULDN'T AN ALTERNATE AIR SOURCE BE NEEDED?? Hi: I plan on using Mooney's alternate air system just a friend of mine has on his RV-6. Automatic and in the center of air filter bottom of Van's air box. Check it out. Dick Zander N747RZ finishing. ________________________________________________________________________________
Subject: VFR panel
Date: Mar 05, 2000
> >I am considering a panel consisting of the appropriate radios, GPS for >navigation. >Here is the kicker for engine instruments the Rocky Mountain Monitor and the >MicroEncoder for Airspeed, VSI, Altitude, OAT. Is this asking to much from >these istruments for VFR flight. I believe Vans RV-8A uses only the >MicroEncoder for flight information. >Your thoughts please. > I have been flying with a similar setup for almost three years (467 hrs): MicroEncoder (flight instruments) VM1000 (engine instruments) Garmin GPS-195 Comm and Transponder I am pleased with the instrumentation; I especially like the MicroEncoder. Some people, however, do not like a digital presentation for airspeed. (This is one of those personal preference things.) Just remember, with this setup you MUST remain VFR. I am currently considering installing an electric turn coordinator -- just to give myself a fighting chance in case I ever screw up and get in the soup. Mark Nielsen RV-6 Green Bay, WI ________________________________________________________________________________
Date: Mar 05, 2000
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: Re: NavAid Tweaking
> >Need some advise.....my NavAid is in and I thought working...wing leveler >function is good, tracks a heading OK, but now I have an oddity when >attempting to follow a GPS flight course. > >The NavAid follows a straight path to the first waypoint where I have tried >various course direction changes: a 90-degree change resulted in a VERY wide >arc with inability to get back on course. (Miles off course.) > >A 45-degree course change at the first waypoint resulted in the same. > >A 15-degree (or less) change at the first waypoint resulted in a quick turn >to the WRONG direction, immediately followed by a change and bank to the >correct direction, with approximate following of the new heading....but then >the NavAid flew the plane completely past the next waypoint and its slight >change of direction. All the while the coupler light showed GPS signals >coming in. GPS showed satellite lock on also. > >My GPS seems to lock on well. I am using NMEA 0183-2 data with RMB and RMC >sentences turned on. > >I have attempted to determine IF the NavAid course width is set too wide >(it can be from about 1.25 -as I recall - to 10nm. The instruction book >method of determining where it is set, and how to set it does not work even >remotely.....I don't know if course width is the problem or not. > >I'd sure like some help...have e-mailed NavAid but no response >yet...weekend effect likely. > >Any help out there? the NavAid is a wing leveler with a yaw rate sensor (like that found in your turn coordinator) to sense rate and direction of turning only. It has no notion of heading. The internal workings of the NavAid's electronics uses the GPS/VOR course error to put a slight bias on what it believes is a good way to steer . . . at some point on the horizon which the somewhat myopic electronic eyes believe is moving a tad. When you cross a waypoint with a coupled wing leveler, you have to uncouple the radio, get set up on a new heading toward next waypoint, it wouldn't hurt to reset the GPS receiver to make next waypoint good from present position to wash out cross track error and only then do you re-couple the radio to the wing leveler. Unlike autopilots with directional gyros, the NavAid/Radio combination cannot capture a new heading based only on turning rate and some cross-track error. I.e. it won't capture a new flight path - it will only do a nice job of holding a flight path that you've already established. Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Mar 05, 2000
> > >>From: "Louis Cappucci" <N32LC(at)worldnet.att.net> >>Reply-To: rv-list(at)matronics.com >>To: rv-list(at)matronics.com >>Subject: RV-List: source for lugs >>Date: Sun, 05 Mar 2000 09:56:43 -0500 >> >> >>listers, >> >>i need a couple of terminals (lugs) for 2 AWG and 4 AWG wires, connecting >>to >>1/4" and 5/16" posts. i haven't been able to find the #2 X 1/4" anywhere >>yet... >> >>any recommended sources? >> >>thanks, >>louis cappucci >>rv-6a wiring >>mamaroneck, ny > > >I found some copper lugs at the local automotive electrical supply store. >You need a crimping tool that you beat to death with a hammer to crimp the >lug. These aren't cheap, but maybe you could borrow one somewhere. > >Brian Denk >RV8 N94BD I stock both of these sizes an sell them as a kit with a piece of internal melting wall heatshrink to dress up the installed terminals. Bash-em crimp tools are pretty process sensitive - how calibrated is your hammer blow? Suggest you solder them on using technique described in . . . http://www.aeroelectric.com/articles/big_term.pdf The terminals are $1 each. Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Subject: source for lugs
Date: Mar 06, 2000
Louis, I got mine at a well-stocked auto parts store. It helped when I brought in a piece of the heavy cable and the battery/starter relays that I was using. When they saw what I had, they brought out a box full of terminal lugs and we found the right ones. Steve Soule Huntington, Vermont RV-6A FWF -----Original Message-----i need a couple of terminals (lugs) for 2 AWG and 4 AWG wires, connecting to 1/4" and 5/16" posts. i haven't been able to find the #2 X 1/4" anywhere yet... any recommended sources? ________________________________________________________________________________
Date: Mar 06, 2000
In a message dated 3/6/2000 11:04:12 AM Tokyo Standard Time, dpersyk(at)worldnet.att.net writes: > I am getting ready to drill on the longitudinal hinges on my 6A S-cowl. I > plan on drilling on the lower half with the lower cowl supported by the side > and bottom clecoes and the hinge halves pinned together. I have the zipper > inclined per plans/RVAtor. When I put on the top cowl (all fitted), how do > I back up the hinge for drilling? I can reach in through the air intake for > about 1/3 to 1/2 of the way back but after that I have no means of backing > up the hinge. Maybe get as far as you can, cleco what you have done, then remove the cowl half and finish? Dave Leonard ________________________________________________________________________________
Date: Mar 06, 2000
In a message dated 3/6/2000 12:43:52 PM Tokyo Standard Time, JDaniel343(at)aol.com writes: > > I am considering a panel consisting of the appropriate radios, GPS for > navigation. > Here is the kicker for engine instruments the Rocky Mountain Monitor and the > > MicroEncoder for Airspeed, VSI, Altitude, OAT. Is this asking to much from > these istruments for VFR flight. I believe Vans RV-8A uses only the > MicroEncoder for flight information. > Your thoughts please. > > I haven't flown yet, but I am installing the same thing. I dont see any reason why this wont work for VFR fligh. If you plan on being based in the mountains, or on a short strip you might want to add a backup ASI or ALT. Dave Leonard Mazda 13B RV-6 ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: Drilling Gear Leg Supports (Thanks)
Thanks for this advice. It makes me feel a lot better after a frustrating weekend trying to get my gear leg mount to line up. I too had drilled my gear mount with the bottom off. Now I can't get it too line up!!! (at this point I was wishing I had gone with the tail dragger!) --- Dennis Persyk wrote: > > > I've sent Tommy my instructions off line, which are > also found in the > archives. > Just an added note: I drilled the gear mounts before > the bottom forward skin > was riveted on. When I mounted the wings, the > mounts didn't line up! > It turns out that the bottom skin was a tight fit > where it wraps around the > longerons and it actually squeezed the sides in a > few thousandths! That was > frustrating. > Van's said this is a common problem and they > suggested using a bottle jack > to spread the sides apart. I chose instead to > hammer on the weldment flange > radii to squeeze them in a bit -- it helped. > Dennis Persyk 6A finishing kit > Hampshire, IL C38 > -----Original Message----- > From: Tommy Walker <twsurveyor(at)email.msn.com> > To: RV-List > Date: Sunday, March 05, 2000 4:13 PM > Subject: RV-List: Drilling Gear Leg Supports > > > > > > >I will begin setting up for drilling my Gear leg > supports (6A) tomorrow! > Any > >tips or "words of wisdom" from those of you who > have gone before me? > > > >Tommy Walker > >6A, Ridgetop, TN > > > > > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: Splitting wheel rims -- how?
DON'T USE A SCREWDRIVER. Try this : place in freezer overnight,,12 hrs..Then place the rim on a large heatsink of some sort (turned over large frying pan). The theory here is differiential expantion. One half will react to the warming caused by the exit of heat energy (cooling) a little bit quicker than the half not heatsunk......forcing a sharp non-serated knife into the split may force the rim apart. It worked for me. I also re-ringed a starter ring to a flywheel and did the ole heat the ring, freeze the pulley trick. When I went to place the items together I was amazed at the space the temp. delta produced. As I watched the space closed to nothing and the starter ring & pulley were one..... I would not heat your rims because you may join the paint or goop that is holding the rim........Or, on the otherhand, it might loosen up the goop and allow a knife to upen up your rims....hmmmm...Thats what beer is for (to drink -- not seperate wheel halves.) frankvdh(at)ihug.co.nz on 03/04/2000 01:04:46 AM Please respond to rv-list(at)matronics.com Subject: RV-List: Splitting wheel rims -- how? Hi, I thought I'd put my tyres and wheels together this evening, but I can't separate the rim halves. According to the Orndorff video, they should just come apart after I've removed the 3 bolts. But they are *very* firmly stuck together. I did try to use a screwdriver to force them apart, but couldn't get it into the joint between the halves. Even a knife wouldn't do it. Is there some trick to this? Or have I just not forced it hard enough? Frank. ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Fuel Injected vs Carb
I have been looking at some engines for my 6a and have found a pretty good deal on a Lycoming IO 320 B1A. My questions are, will the fuel injected model cause me considerable modifications to the cowling? Will the engine fit? What are the pros and cons of Fuel Injected vs Carberator? Thanks, Eric Newton (empennage) ________________________________________________________________________________
Date: Mar 06, 2000
> > I am considering a panel consisting of the appropriate radios, GPS > for navigation. > Here is the kicker for engine instruments the Rocky Mountain Monitor > and the > MicroEncoder for Airspeed, VSI, Altitude, OAT. Is this asking to much > from > these istruments for VFR flight. For day VFR, this would probably do fine. I intend to do the same - except night flight for which I will add a back up altimeter. If you lose the uEncoder at night, you should be able to get back on the deck using backup altitude and engine RPM as airspeed. Once you're familiar with the aircraft, you know what a particular throttle setting will get you for speeds in the pattern. YMMV. Mike Thompson Austin, TX -6 N140RV (Reserved) Wings ________________________________________________________________________________
Date: Mar 06, 2000
I have installed aluminum conduit after the wing was assembled. Not wanting to wait or pay the overpriced price I used aluimun close-line pole holder-uppers. At the hardware store for $1.98. I primed and cutoff the forkey thing and had wire conduit done in a Saturday morning. I used adel clamps to secure the (now aluminum tubing-was hardware store closeline poles) to the interior of the wing. frankvdh(at)ihug.co.nz on 03/05/2000 03:01:11 AM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: is conduit necessary? Paul Besing wrote: > If for whatever reason you need to add wire, repair or whatever, it sure > would be easier. You can see a picture of the hose I used for conduit at: Conduit isn't *necessary*, but I think it would be a good idea for the reasons outlined above. If you install conduit, it means that you don't need to actually install the wiring and other electrical stuff until much later in the construction sequence. That in turn means that you can postpone decisions on what lighting options to install (strobes, wingtip landing lights, nav lights) until later. Duckworks LE landing lights should probably be installed at construction time, although that's not *necessary* either. And therefore you can postpone purchase of these expensive items until you've got your finish kit (or even after first flight). What you're buying with your conduit is (a) time, and (b) flexibility. If you *know* what lighting you want to install, and have the money to buy it, then conduit doesn't gain you the advantages I've suggested. Frank. ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: RV-List: 6A Longitudinal Cowl Hinges >> >> I am getting ready to drill on the longitudinal hinges on my 6A S-cowl. I plan on drilling on the lower half with the lower cowl supported by the side and bottom clecoes and the hinge halves pinned together. I have the zipper inclined per plans/RVAtor. When I put on the top cowl (all fitted), how do I back up the hinge for drilling? I can reach in through the air intake for about 1/3 to 1/2 of the way back but after that I have no means of backing up the hinge. Some times the simplest chores seem the hardest. Predrill your upper hinge. Put a trouble lamp inside the cowl and you will be able to "see" the holes. Now you can drill through the fiberglass and hit the holes. Cleco the drilled holes and you will be surprised at how fast the job will be completed. Have fun building. ----------------------------------------------------- Doug Murray RV-6 Buying radios Southern Alberta ________________________________________________________________________________
Date: Mar 06, 2000
In a pinch they can be made. I used soft copper tubing squashed with a vice & some wood. You can get clever and make a squash die by drilling a med-hard wood scrap with a step drill or unibit. Cut your coned-out cored scrap in half lengthwise and use this as your squash die. Took 5 minutes in the garage. I made a bunch of lugs this way. Not so much as scrimping but EVERYTHING I need I have to wait for and pay shipping for-one thing at a time (it seems). This was a enjoyable 5 minutes in the garage so I could continue with the task at hand with my RV. AAMRELECTR(at)aol.com on 03/05/2000 12:22:29 PM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: source for lugs In a message dated 3/5/00 7:39:34 AM Pacific Standard Time, N32LC(at)worldnet.att.net writes: > I haven't been able to find the #2 X 1/4" anywhere Hi Louis: You can find Lugs on our page @ AAMR/AirCore/Lugs or http://members.aol.com/aamrelectrr/Page28.html Or AAMR/AirCore/8 GA. To 4/0 Connectors http://members.aol.com/aamrelectr/Page18.html Regards, John @ AAMR/AirCore/Mar ineCore (Chick the blue link to go there) ________________________________________________________________________________
Date: Mar 06, 2000
> > > > > the NavAid is a wing leveler with a yaw rate sensor (like that > found in your turn coordinator) to sense rate and direction > of turning only. It has no notion of heading. > > The internal workings of the NavAid's electronics uses the > GPS/VOR course error to put a slight bias on what it believes > is a good way to steer . . . at some point on the horizon > which the somewhat myopic electronic eyes believe is moving a > tad. > > When you cross a waypoint with a coupled wing leveler, you > have to uncouple the radio, get set up on a new heading toward > next waypoint, it wouldn't hurt to reset the GPS receiver to > make next waypoint good from present position to wash out > cross track error and only then do you re-couple the radio > to the wing leveler. > FWIW, My Navaid Devices autopilot does a beautiful job of turning corners when my course has a jog in it. I have never had it turn more than 30 degrees or so but on those turns it quickly and without any intervention establishes itself on the new course line. It is coupled to a UPS panel mount GPS360. > Unlike autopilots with directional gyros, the NavAid/Radio > combination cannot capture a new heading based only on > turning rate and some cross-track error. I.e. it won't > capture a new flight path - it will only do a nice job > of holding a flight path that you've already established. > Larry Pardue Carlsbad, NM RV-6 N441LP
http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: Mar 06, 2000
I drilled the hinge then put a light inside the cowl and placed the light source dead-nuts opposite the hinge hole. The light cast a shadow thru the cowl & gel coat & I drilled. Be careful of paralax error. Worked great for me . Cleko as you go. VP4SkyDoc(at)aol.com on 03/06/2000 08:17:32 AM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: 6A Longitudinal Cowl Hinges In a message dated 3/6/2000 11:04:12 AM Tokyo Standard Time, dpersyk(at)worldnet.att.net writes: > I am getting ready to drill on the longitudinal hinges on my 6A S-cowl. I > plan on drilling on the lower half with the lower cowl supported by the side > and bottom clecoes and the hinge halves pinned together. I have the zipper > inclined per plans/RVAtor. When I put on the top cowl (all fitted), how do > I back up the hinge for drilling? I can reach in through the air intake for > about 1/3 to 1/2 of the way back but after that I have no means of backing > up the hinge. Maybe get as far as you can, cleco what you have done, then remove the cowl half and finish? Dave Leonard ________________________________________________________________________________
From: "Ollie Washburn" <skybolt-aviator(at)msn.com>
Date: Mar 06, 2000
----- Original Message ----- From: John <fasching(at)amigo.net> Sent: Sunday, March 05, 2000 3:25 PM Hi John----I have the nav-aid and it tracks very well;flew from Pit to Tpa with several way points and it turned at all of them. I seem to remember that the course width of the GPS has to be set to 1.25 mile or less. > > Any help out there? > > RV-6A > Salida, CO > > ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Rocky Mountian Instruments microEncoder...
I don't know if any of you are considering this instrument to save panel space but I highly recommend it. I'm going for the glass cockpit look and decided to include the microEncoder to my spartan instrument cluster. I decided to go for the ( build it yourself ) kit and I'm glad I did. I have built my share of Heath Kits in my youth but almost with out exception have been disappointed with the end result ( always ended up spending a week trouble shooting before I could get it to work ). I decided with the microEncoder to go with the kit option and give myself a break from pounding on aluminum for a change. To make a long story short, I finished the microEncoder in 1.5 days and it works like a champ. The kit is easy. RMI puts almost all of the components into cardboard trays for easy assembly. Even the integrated circuits are stuffed in the shipping tubs in the order of assembly. If only the Heath Kits had been this well documented and easy to assemble. I give this kit two thumbs up. - Jim Andrews RV-8AQ Fuse and more fuse... N89JA ( reserved ) ________________________________________________________________________________
Subject: Flap "Oilcan"
Date: Mar 06, 2000
List Companions, One of my just completed flaps is "touch sensitive." It looks as good as the other flap, which is tight as a drum, but you can "pop" oilcan the top skin slightly into one bay so that it bulges slightly in the next bay. It pops again and returns with removal of the finger force. Should I: 1) Forget it; 2) Adhere a small light stiffener in the sensitive area; 3) Other? Any chance I've built in a little stall warning drum? Appreciate either your assurance or suggestion. Jack Blomgren, Red Wing, MN N8VZ (Reserved) -8 wings/bldg backshop ________________________________________________________________________________
Date: Mar 06, 2000
Subject: RV4 brakes
I was looking at installing the brakes this weekend and have a couple of questions. 1) The plans show the brake reservoir mounted on the engine side of the firewall with a hole bored thru the firewall for the Tee and brake lines to the master cylinders. Is there any reason (other than convenience when refilling) why the reservoir couldnt be mounted on the cockpit side of the firewall? Is it prone to leaking? 2) The manual says the brake cylinders are to be mounted with the bleed nipple pointed down. Are there distinctly different right and left cylinders? Mine are identical. Or can you remove the bleed nipple on one of the cylinders and move it to the other side of the cylinder (swap with the elbow that goes to the brake line)? Mike Wills RV4 brakes at the moment willsm(at)spawar.navy.mil ________________________________________________________________________________
Date: Mar 06, 2000
In a message dated 3/6/00 7:42:15 AM Pacific Standard Time, pcondon(at)csc.com writes: > > In a pinch they can be made. I used soft copper tubing squashed with a vice & > > some wood. You can get clever and make a squash die by drilling a med-hard > wood > scrap with a step drill or unibit. Cut your coned-out cored scrap in half > lengthwise and use this as your squash die. Took 5 minutes in the garage. I > made > a bunch of lugs this way. Not so much as scrimping but EVERYTHING I need I > have > to wait for and pay shipping for-one thing at a time (it seems). This was a > enjoyable 5 minutes in the garage so I could continue with the task at hand > with > my RV. Hi Paul: That's a really good idea. The only thing I would add it is to solder the seam in the end of the tube after you squash it and drill the hole. Doing that will stop any corrosion/moisture from wicking up into the connector and into your cable. Regards, John @ AAMR/AirCore/Mar ineCore (Chick the blue link to go there) ________________________________________________________________________________
Date: Mar 06, 2000
> >I am getting ready to drill on the longitudinal hinges on my 6A S-cowl. I >plan on drilling on the lower half with the lower cowl supported by the side >and bottom clecoes and the hinge halves pinned together. I have the zipper >inclined per plans/RVAtor. When I put on the top cowl (all fitted), how do >I back up the hinge for drilling? I can reach in through the air intake for >about 1/3 to 1/2 of the way back but after that I have no means of backing >up the hinge. >What have others done? >Thanks. >Dennis Persyk 6A finishing kit >Hampshire, IL C38 Dennis, Besides reaching through the inlets, you may be able to use a stick inserted from the lower cowl scoop exit to bear down on the hinge while someone else drills the hinge. If you're working by yourself, you could use double sided carpet tape on the back of the top hinge, stick it down with pressure from a stick inserted from below and then drill. I would not remove the top cowl to finish drilling the hinge. Too much chance for error. Also, if you drill each hole as you progress aft and insert a cleco, the hinge will deflect very little as you drill the new hole. This is probably a good place to use a new bit. Bob Skinner Buffalo, WY (1995 RV6 sold after 4 years & 470 hrs) EAA Tech Counselor # 3726 ________________________________________________________________________________
Subject: Re: Rocky Mountian Instruments microEncoder...
Date: Mar 06, 2000
Jim, I agree completely! Finished their MicroMonitor - Thanks Scott G - for the original recommendation. It wasn't hard (but I did have a lighted magnafing lamp) and it works like a champ (I'm still super impressed with all it's finctionality). Just finished the MicroEncoder Display board, last night. Both products - HIGHLY RECOMMENDED! Good Building, Chuck & Dave Rowbotham RV-8A (wiring) Niantic, CT >From: Jim_Andrews(at)tivoli.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Rocky Mountian Instruments microEncoder... >Date: Mon, 6 Mar 2000 09:35:27 -0600 > > >I don't know if any of you are considering this instrument to save panel >space >but I highly recommend it. I'm going for the glass cockpit look and >decided to >include the microEncoder to my spartan instrument cluster. I decided to go >for >the ( build it yourself ) kit and I'm glad I did. I have built my share of >Heath Kits in my youth but almost with out exception have been disappointed >with >the end result ( always ended up spending a week trouble shooting before I >could >get it to work ). I decided with the microEncoder to go with the kit >option and >give myself a break from pounding on aluminum for a change. To make a long >story short, I finished the microEncoder in 1.5 days and it works like a >champ. >The kit is easy. RMI puts almost all of the components into cardboard >trays for >easy assembly. Even the integrated circuits are stuffed in the shipping >tubs in >the order of assembly. If only the Heath Kits had been this well >documented and >easy to assemble. > >I give this kit two thumbs up. > > >- Jim Andrews >RV-8AQ Fuse and more fuse... >N89JA ( reserved ) > > ________________________________________________________________________________
Subject: Re: MT Propeller
Date: Mar 06, 2000
Alternative to the MT is a Whirl Wind prop.....made in the USA and although I did not get a prop from them I did buy a gov. Very nice people and they provided good service. Cheaper than the MT also. They have a website. C.H. ---------- > From: Gary A. Sobek <rv6flier(at)yahoo.com> > To: rv-list(at)matronics.com > Subject: RV-List: MT Propeller > Date: Sunday, March 05, 2000 6:53 PM > > > With all the talk about the MT Propeller, I wondered > if they had a web site. Guess what I found? > >
http://www.mt-propeller.com/ > > Please report back to the list with the price when you > find out how much one costs for the O-320 / O-360. > > > ==== > Gary A. Sobek > "My Sanity" RV-6 N157GS O-320 Hartzell, > Flying So. CA, USA > > > > ________________________________________________________________________________
Subject: Re: RV4 brakes
Date: Mar 06, 2000
You answered the problem your self. The inlets and outlet holes are identical and you can swap to place in the proper location. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) -----Original Message----- From: Mike Wills <willsm(at)spawar.navy.mil> Date: Monday, March 06, 2000 10:10 AM Subject: RV-List: RV4 brakes > > I was looking at installing the brakes this weekend and have a couple of >questions. > >1) The plans show the brake reservoir mounted on the engine side of the >firewall with a hole bored thru the firewall for the Tee and brake lines >to the master cylinders. Is there any reason (other than convenience when >refilling) why the reservoir couldnt be mounted on the cockpit side of the >firewall? Is it prone to leaking? > >2) The manual says the brake cylinders are to be mounted with the bleed >nipple pointed down. Are there distinctly different right and left >cylinders? Mine are identical. Or can you remove the bleed nipple on one of >the cylinders and move it to the other side of the cylinder (swap with the >elbow that goes to the brake line)? > >Mike Wills >RV4 brakes at the moment >willsm(at)spawar.navy.mil > > ________________________________________________________________________________
Date: Mar 06, 2000
From: "Scott Kuebler" <skuebler(at)cannondesign.com>
Subject: Observations on priming (long)
I have just completed priming my wing kit and would like to share my experiences with my type of primer, spraying method, weight penalty and general observations. In the past for my tail kit I used Marhyde single stage, self-etching primer in a rattle can. I loved it. It went on quickly and evenly, dried fast (two minutes), was very clean and convenient (no mixing or cleaning) and was very tough when dry. I would probably still be using this brand if it wasn't for the price, $15.00 for a 17oz can. If I remember correctly I used four cans on the tail kit. When it came time to prime the wing kit I calculated that it would probably take me fifteen cans to cover everything. $225.00 was a little more than I would like to spend on a process that many builders say is unnecessary (but we won't get into that). I knew with the Marhyde that I was paying for packaging and propellant, so I started looking into mixing my own and shooting it with a spray gun. After MUCH research into primers I decided on Deft two-part water based epoxy primer. Deft developed their primer for the military to replace zinc-chromate. The government wanted a non-chromate, corrosion inhibiting, chemical resistant primer. I think the Deft passed every test except the resistance to hydraulic fluids, but don't quote me on this. I do know for sure that this stuff is TOUGH. It mixes like this: 12.5% catalyst - 25% base - 62.5% water, by volume. I purchased the HVLP spray gun from harbor freight for $39.99. This was the first time I had ever used a spray gun before. My first spray session was almost my last, I never knew I could come up with so many four letter words! After I calmed down and before the second session I took the time to read the instructions and adjust the controls on the gun. What I found out was that all those knobs are there for a reason (and not just to make the gun look 'cool'). So I apologized to the gun for insulting it's capabilities and went on to my second, third and fourth priming sessions and everything was flawless. Well, not exactly flawless, I wish I had checked my e-mail a day earlier so that I could take advantage of Gary Zilik's advice on spaying small parts on a mesh screen to prevent blowing them all over the place. So after priming EVERY piece of the wing kit (minus the main spar and tank pieces) I went through three quarters of a gallon of mixed primer. The kit that I bought for $125.00 is able to provide four gallons of mixed primer. So I spent a total of $23.50 to prime my entire wing kit. Not bad compared to $225.00 the old way. Calculating the weight penalty is a little tricky and I have made some assumptions: 3/4 gallon of primer @ 8.34 lb/gallon = 6.25 lb 6.25 lb - 15% for overspray = 5.31 lb since the mix is 62.5% water I have assumed that most of that will evaporate while the primer cures. 5.31 - 50% = 2.66 lb So I think it is safe to say that the weight penalty is 3-5 lbs for priming everything (structure and skins) in the wing kit. In conclusion, I like the water based Deft primer. If cleaned up before drying it wipes up with water, it covers well, and after drying it is rock hard. I would also like to note that I chemically etched (alodine) some pieces and mechanically etched (scotch-brite) other pieces, but I left one rib un-etched just to test the adhesion of the Deft primer. The primer bonded to the un-etched just as well as it did to the etched areas. When I say 'bonded well' I mean 'there is nothing I can do, short of filing, to get this stuff to come off'. Scott Kuebler Buffalo, NY RV-6a (finally going to put these wings together for the last time!) ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: MT Propeller/Whirlwind Prop
Can anyone supply a URL for the other Whirlwind prop....anyone have any thoughts on it? rv6flier(at)yahoo.com on 03/05/2000 07:53:43 PM Please respond to rv-list(at)matronics.com Subject: RV-List: MT Propeller With all the talk about the MT Propeller, I wondered if they had a web site. Guess what I found? http://www.mt-propeller.com/ Please report back to the list with the price when you find out how much one costs for the O-320 / O-360. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, Flying So. CA, USA ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: Prop & Propellers
Search on "Speed Breaks" for more data on props. ( For future searching of archives) ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: [Fwd: Alert]
You would think they would have to tell you that they had a landing fee before you landed. scot > >This thread re landing fees.....it was mentioned that KPUB Pueblo, CO has a >landing fee....not so...I was was just there and there is no landing >fee...at least not for non commercial folks like us....for air carriers, >certainly. >RV6A Salida, CO > > ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: Fuel Injected vs Carb
Check with Vans. The IO320 B1A is off a twin Comanchee and has a aft induction system. Will not work on 8. Stan Mehrhoff ________________________________________________________________________________
Subject: Torquing Hartzell C/S Prop
Date: Mar 06, 2000
I am finding it difficult to get the Hartzell C/S prop torqued to the 60-70 ft-lb value. I have tried two different crow's feet and still can't get even a small-headed Snap-On torque wrench to clear the prop hub. Just to get calibrated, I set my Craftsman torque wrench to 70 ft-lbs and restrained the 1/2 drive end in a vise. The arm is 18 inches, so I need only exert 47 lbs of force to achieve the 70 ft lbs. If I tighten with a 3/4 open-end wrench with an effective 8 inch arm, I have to exert 105 lbs of force -- way more than I can muster up! So how do others torque the prop? Is there a super-long crow's foot (1/2 drive) that I don't know about? Thanks! Dennis Persyk 6A finishing kit Hampshire, IL C38 ________________________________________________________________________________
Date: Mar 06, 2000
In a message dated 3/6/2000 10:27:24 AM Central Standard Time, clhuey(at)sprynet.com writes: << Alternative to the MT is a Whirl Wind prop.....made in the USA and although I did not get a prop from them I did buy a gov. Very nice people and they provided good service. Cheaper than the MT also. They have a website. C.H. >> I am looking for a prop for my f1 rocket and when i requested info from whirlwind all i got was basically them saying its the best prop put there. No real reasons why. Mt props are similair in price. I cant remember off hand but if you buy from team rocket the price of the MT is within a few hundred dollars of the Whirlwind prop. I just wish i could afford a hartzel 3 blade composite. chris wilcox f-1 rocket ________________________________________________________________________________
Date: Mar 06, 2000
You can swap the sump & risers and get around your problem and keep the engine for your project.. Be sure to check with the exhaust vender but I don't see any problems if you convert your sump to something commonplace. I think this is a conical mount.....still I see no problems here either .. ... Phil C. RV-4 with O-320-B2C N188sm(at)cs.com on 03/06/2000 12:28:03 PM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: Fuel Injected vs Carb Check with Vans. The IO320 B1A is off a twin Comanchee and has a aft induction system. Will not work on 8. Stan Mehrhoff ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: Torquing Hartzell C/S Prop
Dennis, There are two ways that I have used. I have a "special" wrench which is two 3/4" wrenches welded together to be 1.3' in length. I put a spring scale in the end and pull the appropriate amount. For a while I was the only one on the airport that could actually torque Hartzell prop. The other method involves a Snap-On Torque wrench. There is a model that you can remove the rachet on the end and put a crows foot straight in. Last time I did it we used this method and it works easier than pulling on the spring scale, but I am sure it is more expensive. Bruce Green writes: > > > I am finding it difficult to get the Hartzell C/S prop torqued to > the 60-70 > ft-lb value. I have tried two different crow's feet and still can't > get > even a small-headed Snap-On torque wrench to clear the prop hub. > Just to > get calibrated, I set my Craftsman torque wrench to 70 ft-lbs and > restrained > the 1/2 drive end in a vise. The arm is 18 inches, so I need only > exert 47 > lbs of force to achieve the 70 ft lbs. If I tighten with a 3/4 > open-end > wrench with an effective 8 inch arm, I have to exert 105 lbs of > force -- way > more than I can muster up! > So how do others torque the prop? Is there a super-long crow's foot > (1/2 > drive) that I don't know about? > Thanks! > Dennis Persyk 6A finishing kit > Hampshire, IL C38 > > > > > ________________________________________________________________________________
Date: Mar 06, 2000
If you place an extension on the torque wrench that fits in the location that extends the length, it will be even less than the real 47# of the 18" torque wrench. I have a similar problem with my Aeromatic prop hub. I use a combination wrench that fits both on the Bolt head and can be driven with the 1/2" torque wrench drive. I re-figured the effective lever arm so I could tell how much the indication would be for my desired torque. Since I was trying for about 30 foot-pounds, I put my adapter on at right angles so the indicator was very close. If I extended it out the effective length would be much greater so the indication would be much smaller. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) -----Original Message----- From: Dennis Persyk <dpersyk(at)worldnet.att.net> Date: Monday, March 06, 2000 12:15 PM Subject: RV-List: Torquing Hartzell C/S Prop > >I am finding it difficult to get the Hartzell C/S prop torqued to the 60-70 >ft-lb value. I have tried two different crow's feet and still can't get >even a small-headed Snap-On torque wrench to clear the prop hub. Just to >get calibrated, I set my Craftsman torque wrench to 70 ft-lbs and restrained >the 1/2 drive end in a vise. The arm is 18 inches, so I need only exert 47 >lbs of force to achieve the 70 ft lbs. If I tighten with a 3/4 open-end >wrench with an effective 8 inch arm, I have to exert 105 lbs of force -- way >more than I can muster up! >So how do others torque the prop? Is there a super-long crow's foot (1/2 >drive) that I don't know about? >Thanks! >Dennis Persyk 6A finishing kit >Hampshire, IL C38 > > ________________________________________________________________________________
Date: Mar 05, 2000
Subject: Re: Turn & Bank Coordinator
A= 12volts B= grd C= not used This is from lelectric bob's diagram. Don Jordan ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com **************************************************************************** writes: > > >Lister's, > >I bought a T&B from Century Instruments of Wichita KS. The unit has a >3 pin >connector, MS3106A10S-3S. I don't have a wiring diagram. Does anyone >know >what pin is + & -. Any advise would be appreciated. > >Thanks.....Mark > >Mark Steffensen >8A Dallas, TX > ________________________________________________________________________________
Date: Mar 05, 2000
Try a leather hammer. or wood. I would not pry. Don Jordan ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com **************************************************************************** writes: > >Hi, > >I thought I'd put my tyres and wheels together this evening, but I >can't >separate the rim halves. > >According to the Orndorff video, they should just come apart after >I've >removed the 3 bolts. But they are *very* firmly stuck together. I did >try to use a screwdriver to force them apart, but couldn't get it into >the joint between the halves. Even a knife wouldn't do it. > >Is there some trick to this? Or have I just not forced it hard enough? > >Frank. > > ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: Whirl Wind Propellers URL
http://whirlwindpropellers.com/ is the URL , below is the URL for MT. rv6flier(at)yahoo.com on 03/05/2000 07:53:43 PM Please respond to rv-list(at)matronics.com Subject: RV-List: MT Propeller With all the talk about the MT Propeller, I wondered if they had a web site. Guess what I found? http://www.mt-propeller.com/ Please report back to the list with the price when you find out how much one costs for the O-320 / O-360. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, Flying So. CA, USA ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Final Post
Thank you to all that have helped me in the past. Good luck to all that I have helped. I have out-grown the need, nor do I have time, to participate on the list. Gary Corde RV-6 N211GC - NJ ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: Observations on priming (long)
Scott Kuebler wrote: > I have just completed priming my wing kit. In the past for my tail kit >I used Marhyde single stage, self-etching primer in a rattle can. I >loved it. Me too! > When it came time to prime the wing kit I calculated that it would >probably take me fifteen cans to cover everything. $225.00 was a little >more than I would like to spend on a process that many builders say is >unnecessary (but we won't get into that). I knew with the Marhyde that >I was paying for packaging and propellant(snip) I buy Marhyde in 1 qt. cans (#5112 I think) at the local auto body supply for about $18, shoot it with the same gun you're using- ain't it great?! > Scott Kuebler > Buffalo, NY > RV-6a (finally going to put these wings together for the last time!) Yeah, right! I've been saying THAT for about 3 months now!! From the PossumWorks in TN Mark -6A -gotta take skins off again to rig aileron pushrod... ________________________________________________________________________________
Date: Mar 06, 2000
Subject: RV8 Battery Cabling - Aft Mounted Battery
Van's recommendations for the battery cable routing for the aft mounted battery seems a bit clunky. Anyone come up with a better way of running the cable? Where did you go thorough the spar? -Don RV8 NJ ________________________________________________________________________________
Subject: Re: RV8-List: RV-8 ALTERNATE AIR
Date: Mar 06, 2000
Definitely, look to the Mooney 201, they have the same system to copy. I installed an IO360 with RAM and alternate air. Stephan SALNED71(at)aol.com schrieb: > --> RV8-List message posted by: SALNED71(at)aol.com > > HAVE ANY OF THE FINISHED RV-8'S INSTALLED AN ALTERNATE AIR SOURCE WITH FUEL > INJECTION. IF THE RAM AIR SOURCE WAS PLUGGED FOR SOME STRANGE REASON, > (BIRD, ICE ) WOULDN'T AN ALTERNATE AIR SOURCE BE NEEDED?? > > Stephan Servatius Untere Hauptstr. 3 85461 Bockhorn Germany ________________________________________________________________________________
Subject: Re: Final Post
Date: Mar 06, 2000
Gary, Sorry to see you go and I know about how much of a time sink reading just the articles one is interested in becomes. Good luck with your flying and hope to see you again perhaps over the summer. Thanks for your help in answering my questions and a ride in your RV. Paul Bilodeau ---------- > From: RV6junkie(at)aol.com > To: rv-list(at)matronics.com > Subject: RV-List: Final Post > Date: Monday, March 06, 2000 3:06 PM > > > Thank you to all that have helped me in the past. Good luck to all that I have helped. I have out-grown the need, nor do I have time, to participate on the list. > > Gary Corde > RV-6 N211GC - NJ > > > > ________________________________________________________________________________
Subject: Re: RV8 Battery Cabling - Aft Mounted Battery
Date: Mar 06, 2000
Don, We didn't go through the spar. We ran the cable just under the Left canopy channel and right into the Left side of the forward baggage compartment. Good Building, Chuck & Dave Rowbotham RV-8A (wiring) Niantic, CT >From: Rv8don(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv8list(at)onelist.com, rv-list(at)matronics.com >Subject: RV-List: RV8 Battery Cabling - Aft Mounted Battery >Date: Mon, 6 Mar 2000 15:53:50 EST > > >Van's recommendations for the battery cable routing for the aft mounted >battery seems a bit clunky. Anyone come up with a better way of running >the >cable? Where did you go thorough the spar? > >-Don >RV8 NJ > > ________________________________________________________________________________
Date: Mar 06, 2000
> With all the talk about the MT Propeller, I wondered > if they had a web site. Guess what I found? > > http://www.mt-propeller.com/ > > Please report back to the list with the price when you > find out how much one costs for the O-320 / O-360. Oooooo..... I like that MTV-17. No contact yet. I'll guess $4K USD. :( Mike Thompson Austin, TX -6 N140RV (Reserved) Wings ________________________________________________________________________________
Date: Mar 06, 2000
My Mooney M20-E had a spring loaded alt air door. The theory was if impact air was blocked a suction would pull open a spring loaded trap door and not let the engine air-starve. romeo.victor@t-online.de on 03/06/2000 04:08:22 PM Please respond to rv-list(at)matronics.com Subject: RV-List: Re: RV8-List: RV-8 ALTERNATE AIR Definitely, look to the Mooney 201, they have the same system to copy. I installed an IO360 with RAM and alternate air. Stephan SALNED71(at)aol.com schrieb: > --> RV8-List message posted by: SALNED71(at)aol.com > > HAVE ANY OF THE FINISHED RV-8'S INSTALLED AN ALTERNATE AIR SOURCE WITH FUEL > INJECTION. IF THE RAM AIR SOURCE WAS PLUGGED FOR SOME STRANGE REASON, > (BIRD, ICE ) WOULDN'T AN ALTERNATE AIR SOURCE BE NEEDED?? > > Stephan Servatius Untere Hauptstr. 3 85461 Bockhorn Germany ________________________________________________________________________________
Date: Mar 06, 2000
> >FWIW, > >My Navaid Devices autopilot does a beautiful job of turning corners when >my course has a jog in it. I have never had it turn more than 30 degrees >or so but on those turns it quickly and without any intervention >establishes itself on the new course line. It is coupled to a UPS panel >mount GPS360. > >> Unlike autopilots with directional gyros, the NavAid/Radio >> combination cannot capture a new heading based only on >> turning rate and some cross-track error. I.e. it won't >> capture a new flight path - it will only do a nice job >> of holding a flight path that you've already established. >> > >Larry Pardue Larry, Just out of curiousity, do you happen to know what CDI scaling the GPS was set to? Currently available, IFR capable GPS units should have three different CDI scalings: 5 nm full scale, 1 nm full scale, and 0.3 nm full scale. Generally speaking, IFR units default to the 5 nm setting for enroute, then switch to 1 nm in the terminal area (often defined as within 30 nm of the destination), and then switch to 0.3 nm approaching the Final Approach Fix (if you are doing an approach). I've bought a Navaid unit, but it looks to be at least a couple of years before I get to see how it works. Kevin Horton RV-8 (dimpling fuse skins) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
Subject: Re: Ok, now >I'VE< gone and done it
Date: Mar 06, 2000
> After all the research and dreaming, preparation and > planning, all I feel now is a sort of emptiness -- a mix of trepidation > and curiosity, of uncertainty and resolve. It is no longer a theoretical > concept. I don't know where this will lead, only that I am now committed; > I am going to build an airplane. > > -Steve > I'm right there with you brother......I know EXACTLY what you mean. Bill ________________________________________________________________________________
Date: Mar 06, 2000
Dennis Persyk wrote: > > I am finding it difficult to get the Hartzell C/S prop torqued to the 60-70 > ft-lb value. I have tried two different crow's feet and still can't get > even a small-headed Snap-On torque wrench to clear the prop hub. Just to > get calibrated, I set my Craftsman torque wrench to 70 ft-lbs and restrained > the 1/2 drive end in a vise. The arm is 18 inches, so I need only exert 47 > lbs of force to achieve the 70 ft lbs. If I tighten with a 3/4 open-end > wrench with an effective 8 inch arm, I have to exert 105 lbs of force -- way > more than I can muster up! > So how do others torque the prop? Is there a super-long crow's foot (1/2 > drive) that I don't know about? > Thanks! > Dennis Persyk 6A finishing kit > Hampshire, IL C38 > Dennis, you'll need to get the crows foot from MAC tools. They have an "extended" crows foot that works perfectly. No other source I've looked at can do the trick. Chuck Brietigam--RV-3 name="brietigam.vcf" filename="brietigam.vcf" begin:vcard n:Chuck Brietigam;Chuck tel;home:502-254-5079 adr:;;;;;; version:2.1 email;internet:brietigam(at)earthlink.net fn:Chuck Brietigam end:vcard ________________________________________________________________________________
Date: Mar 06, 2000
> > >> >>FWIW, >> >>My Navaid Devices autopilot does a beautiful job of turning corners when >>my course has a jog in it. I have never had it turn more than 30 degrees >>or so but on those turns it quickly and without any intervention >>establishes itself on the new course line. It is coupled to a UPS panel >>mount GPS360. >> >>> Unlike autopilots with directional gyros, the NavAid/Radio >>> combination cannot capture a new heading based only on >>> turning rate and some cross-track error. I.e. it won't >>> capture a new flight path - it will only do a nice job >>> of holding a flight path that you've already established. >>> >> >>Larry Pardue > >Larry, > >Just out of curiousity, do you happen to know what CDI scaling the >GPS was set to? > My GPS is set to 1 nautical mile CDI scaling. Larry Pardue Carlsbad, NM RV-6 N441LP http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: Mar 06, 2000
> When you cross a waypoint with a coupled wing leveler, you > have to uncouple the radio, get set up on a new heading toward > next waypoint, it wouldn't hurt to reset the GPS receiver to > make next waypoint good from present position to wash out > cross track error and only then do you re-couple the radio > to the wing leveler. Not true, in my experience. My Navaid handles waypoints (with heading changes) with little overshoot. It can't anticipate turns, but it follows the needle off-course signal around the corner pretty well. It's a pleasure to watch. I've also set up a course in the GPS, flown a bit off course, and let the Navaid capture the the desired course and track it dead on. Last night I tried a GPS course set up at 180 degrees from current heading. That was beyond the Navaid's capability. Navaid flew a huge circle, but since it has no internal heading reference it just kept turning in a circle. Tim ****** Tim Lewis -- Springfield VA RV-6A N47TD - First Flight 18 Dec 99 TimRV6A(at)earthlink.net http://www.geocities.com/timrv6a ________________________________________________________________________________
Date: Mar 06, 2000
Mac Tools have one that will work I'm pretty sure that is what I used. Sherman ________________________________________________________________________________
Date: Mar 06, 2000
I guess I started this NavAid thread, and appreciate ALL comments...NavAid was of no help whatever when I call them asking for help in getting my Lowarnce GPS and NavAid to track a programmed flight course. Lowrance doesn't have a controllable output for course width, and the NavAid instructions of how to determine and to set its course width are vague, and the "technical support" was non-existent when I asked them why it didn't follow the instruction book. The man said, "I just copied that from them (Porcine)" Did any of you happy owners of NavAid have difficulty in adjusting the 'SPAN' and 'Range' controls which seem to interact a lot? Mine adjusted OK for wing leveler and the thing does work in heading mode, and does track a GPS course right up until the first dog leg...then all bets are off. Also does the HEADING/COURSE switch on the coupler react as called out in the instruction book for setting course width? (That described holding the switch one way or the other, turning on the unit, counting the blinks after the start up blinking has quit) Mine is so vague and all I can get is continuous blinking of the green bulb....the NavAid "technical" person just said, "When I tried it it worked fine" boy does that help! RV6A Salida, C ________________________________________________________________________________
From: "Wilson, James Mike" <james.mike.wilson(at)intel.com>
Subject: airflow performance - purge valve
Date: Mar 06, 2000
What size is the return line and can it plumb to the tank breather (WHERE TO TIE IN). thanks, MikeW -----Original Message----- From: Eustace Bowhay [mailto:ebowhay(at)shuswap.net] Sent: Friday, February 25, 2000 6:21 PM Subject: Re: RV-List: airflow performance - purge valve I have been watching but haven't seen any replies on this subject. I have just recently installed one on my Bendix injected 0360. For those who are not completely familiar with the AFP purge valve it was designed to allow you to pump fuel with the boost pump through the entire fuel injection system excluding the flow divider on top of the engine. It is connected to the flow divider and has a lever when pulled shuts of the fuel to the flow divider and diverts all the fuel through a return line back to a tank. I use it on every start cold or hot using the following procedure. 1 Purge valve on 2 Mixture full rich 3 Throttle wide 4 Boost pump on for 15-20 seconds ( When you get used to it at this point you could close the purge valve set the throttle and start .) 5 Boost pump off 6 Mixture closed 7 Throttle closed 8 Purge valve off Then start in the normal manner. What you have done is pump a quantity of fuel through the whole system without injecting any into the cylinders.If the the aircraft has not been flown for some time you now have the system purged and full of fuel. On a hot start the system is purged of all vapor and is full of cool fuel. Have added some answers to the questions below. -----Original Message----- From: Louis Cappucci <N32LC(at)worldnet.att.net> Date: Thursday, February 10, 2000 6:42 PM Subject: RV-List: airflow performance - purge valve > >listers, > >for those of you with the airflow performance fuel injection with purge >valve, i have a series of questions: > > what kind of cable are you using to control the purge valve? where did you >put it? (i am thinking friction lock, next to a vernier mixture control...) I used a button lock control installed on my sub panel beside my heat controls. Felt the button type would prevent acidentally pulling it. The control is part # A-700 from ACS. Could also install a spring on the purge valve that will keep it off in the event of a control failure. >how did you plumb the return line from the purge valve? what size hose? (i >am thinking of using one of the vent lines...) Plumbed it back to the left hand tank using # 4 line to the firewall. >how often do you use the purge valve? is it effective on hot starts? do you >shutdown with mixture or purge? is it worth installing? You can use either one to shut down. By using the purge valve to shut down this prevents any pressure build up in the system. Eustace Bowhay Blind Bay B.C. >thanks, >louis cappucci >rv-6a qb finish kit >mamaroneck, ny > > ________________________________________________________________________________
Date: Mar 06, 2000
Subject: How to Pass 3 Cables Thru 1 Hole
Listers, I asked how to pass 3 bowden cables through one hole a couple of days ago. Thanks to the two responders (one public, one off-list)... In any case, here's how you do it (in the end, I figured it out myself): 1) Buy one of the $25 eyeball fittings from Aircraft Spruce or equivalent. These fittings come with a center hole for common cable sizes. The hole size in the one for my 3/16" OD cable was 0.188". This fitting is shown on Page 150 of the new ACS catalog. 2) Drill two additional 3/16" holes in the eyeball fitting. The holes need to be drilled in the split between the two eyeball halves, and should be parallel to the center hole. If you're carefull, you will be able to achieve a 9/32 dimension between hole centers and have both of the new holes in the flat face of the eyeball. This leaves 3/32" wall thickness between holes. It is skinny, but this isn't a structural application. The eyeball fitting allows you to angle your cables through the firewall, as opposed to traditional grommet and shield installations which "like" perpendicular penetrations. Finally, one eyeball fitting isn't much more expensive than 3 grommet shields, requires fewer holes through the firewall, and takes up less real estate. My contribution for the day... Kyle Boatright Slogging through systems installation.... ________________________________________________________________________________
Date: Mar 06, 2000
>> >> >>> >>>FWIW, >>> >>>My Navaid Devices autopilot does a beautiful job of turning corners when >>>my course has a jog in it. I have never had it turn more than 30 degrees >>>or so but on those turns it quickly and without any intervention >>>establishes itself on the new course line. It is coupled to a UPS panel > >>mount GPS360. >>> > > >>Larry Pardue >> >>Larry, >> >>Just out of curiousity, do you happen to know what CDI scaling the >>GPS was set to? >> > >My GPS is set to 1 nautical mile CDI scaling. > >Larry Pardue Larry, It might be interesting next time you are flying to try a little science experiment. Set your CDI scaling to 5 nm, and see how the Navaid turns corners at waypoints. I suspect many GPS units default to 5 nm scaling, and that may greatly affect how it does. All the Navaid sees is CDI deviation, and yaw rate. If the CDI starts to deviate, it should make an aileron input to achieve a yaw rate proportional to the amount of CDI deviation. The only feedback it gets as to how it is doing is when the CDI scaling starts to decrease again. This creates a feedback loop type control system. But, with different CDI scalings, you have greatly changed the gain in the feedback loop. So, maybe it works good at one CDI scaling, but not another. Just a thought. Kevin Horton RV-8 (dimpling fuse skins) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Subject: Compass For RV6-A
Date: Mar 06, 2000
List: I am going to mount my compass on the glare shield as the panel (IFR) will be full. My question is has anyone to date found a compass that can handle the magnetic interference inside the slider and be of operational use? Anyone tried a Mooney Compass ? As we know the canopy frame work seems to mimic the Bermuda Triangle ! Thanks Tom in Ohio ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: RV-8 804 BULKHEAD
Closing up the 804 I assume you mean pop riveting on the inside cover. I waited until the bitter end to do this part although hindsight says I could have done it once my wiring etc. was done. Just make sure you're done with everything you need to do in there. Don't forget that if you haven't riveted on the forward topskin yet that you have to get in there to buck a couple rivets. Bill Pagan RV-8A N565BW First flight 12/19/99 http://www.geocities.com/CapeCanaveral/Launchpad/9749/william.html > >I HAVE 99% OF MY WIRING DONE, THE THROTTLE QUADRANT IS IN, THE MANUAL AILERON >TRIM IS IN, IS IT WISE TO CLOSE UP THE 804 BULKHEAD NOW OR WAIT UNTIL A LATER >DATE?? > > ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: RV-8 ENGINE INSTALLATION
You should probably have a good idea of how you're going to lay things out. There is plenty of room between the engine and firewall on the 8 to be able to work in there. I did cut the hole for the cabin heat and had my battery tray mounted prior to installing the engine. Bill Pagan RV-8A N565BW First flight 12/19/99 http://www.geocities.com/CapeCanaveral/Launchpad/9749/william.html > >I'M ABOUT TO MOUNT MY NEW AO360A1A ENGINE WITH AIR-FLOW PERFORMANCE INJECTION >AND LAZAR IGNITION TO MY RV-8. IS THERE ANY THING I SHOULD MOUNT TO THE >FIREWALL BEFORE I MOUNT THE ENGINE?? > > ________________________________________________________________________________
Date: Mar 06, 2000
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: Re: NavAid Tweaking
>Larry/Kevin-- > >There must be some confusion between Navaid Instruments and its sales >force or the the way they are being wired to a directional unit (VOR, >LORAN, GPS). I called the Navaid folks, today, and they said their unit >is capable of following a waypoint direction change if coupled to a GPS. > One RV6A owner who has a Navaid unit that's maybe two years old says he >has to manually steer to each new course change and then reset the Navaid. > >Is there more than one model of Navaid? I've been getting a lot of feedback on this topic and it seems that most folk are getting satisfactory capture of a next segment course . . . I'm getting a sense that the size of cross-track error for full scale output from the radio to the NavAid steering input is a big variable. The Porcine adapter looks at raw digital data which is calculated cross-track error and puts out a proportional DC value. Some radios may have variable gains depending on distance from waypoint or whether or not you're in the approach mode. This is a case where mix-n-match of radio/autopilot and even airframe may produce unsatisfactory performance. I recall a LOT of fussing with the early Cessna wing levelers to get good VOR tracking performance. Many folk report statisfactory performance with the Nav-Aid so I have to believe that it's possible with all combinations once the proper gain is deduced and incorporated. Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: More Prop Questions
If anyone out there is still interested in an aerobatic prop I have one for sale. It's a Hartzell pn # HC-C2YK-4CF/FC7666A-2, I also have a Hartzell aerobatic governor pn# F6-3A and an all metal spinner assembly for the counterweighted prop. All have only 115 hours since new and are in like new condition. I will sell all for $6,900. Contact me off list if interested or for more detail gilthe1(at)aol.com or call 352-347-8113 ________________________________________________________________________________
Date: Mar 06, 2000
Subject: oil cooler fittings-a0360a1a
WHAT OIL COOLER FITTINGS DO I NEED FOR THIS ENGINE, SO I CAN GET THEM INSTALLED BEFORE I MOUNT THE ENGINE??? THANKS ED KOWALSKI ... #80127 ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Use of RTV impregnated fibreglas for engine baffling
Some canard builders are using RTV impregnated fibreglas to make some parts of the engine baffling. I had heard this awhile ago, but never took much notice because I couldn't figure how it could be better than plain old aluminum, and I couldn't stand the thought of that "F" word. Well, I just ran into a description and lots of photos at: http://www.geocities.com/snipyjo/pix/baffling/ Unfortunately he doesn't seem to have a web page pointing to this stuff, so this link will just get you a listing of all the files in that directory. You want the description at: http://www.geocities.com/snipyjo/pix/baffling/how_to.txt The more interesting pictures are: http://www.geocities.com/snipyjo/pix/baffling/123jm_baffling_015.jpg http://www.geocities.com/snipyjo/pix/baffling/123jm_baffling_004.jpg http://www.geocities.com/snipyjo/pix/baffling/123jm_baffling_006.jpg http://www.geocities.com/snipyjo/pix/baffling/123jm_baffling_013.jpg http://www.geocities.com/snipyjo/pix/baffling/123jm_baffling_016.jpg This looks like it would make sure that every molecule of air went through the fins, giving the best cooling for the least amount of airflow (and drag). Now I just have to figure a way to make it look like aluminum :-) I'm certainly no expert on engine baffling, since I don't even own an engine yet. So, this could all be a real stupid idea. ________________________________________________________________________________
Date: Mar 06, 2000
Dennis, I used the snap-on click type torque wrench. Worked fine but on the last one, I accidently caught the hub without knowing & broke the open end wrench part. So, as you know, be very careful not to catch the hub & the snap on will work. Rick Caldwell 29.9 hrs. -6 >From: "Dennis Persyk" <dpersyk(at)worldnet.att.net> >Reply-To: rv-list(at)matronics.com >To: "rv-list" >Subject: RV-List: Torquing Hartzell C/S Prop >Date: Mon, 6 Mar 2000 11:33:50 -0600 > > >I am finding it difficult to get the Hartzell C/S prop torqued to the 60-70 >ft-lb value. I have tried two different crow's feet and still can't get >even a small-headed Snap-On torque wrench to clear the prop hub. Just to >get calibrated, I set my Craftsman torque wrench to 70 ft-lbs and >restrained >the 1/2 drive end in a vise. The arm is 18 inches, so I need only exert 47 >lbs of force to achieve the 70 ft lbs. If I tighten with a 3/4 open-end >wrench with an effective 8 inch arm, I have to exert 105 lbs of force -- >way >more than I can muster up! >So how do others torque the prop? Is there a super-long crow's foot (1/2 >drive) that I don't know about? >Thanks! >Dennis Persyk 6A finishing kit >Hampshire, IL C38 > > ________________________________________________________________________________
Subject: Re: Compass For RV6-A
Date: Mar 06, 2000
Tom, You may want to check out the SIRS compass, available as a panel or glareshield versions. We are panel mounting ours. There was a writeup on the SIRS compass in Febuary 2000 issue of AOPAPilot. Good Building, Chuck & Dave Rowbotham RV-8A (wiring) Niantic, CT >From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Compass For RV6-A >Date: Mon, 6 Mar 2000 20:47:06 -0500 > > >List: I am going to mount my compass on the glare shield as the panel (IFR) >will be full. > My question is has anyone to date found a compass that can handle >the >magnetic interference inside the slider and be of operational use? > Anyone tried a Mooney Compass ? As we know the canopy frame work >seems to mimic the Bermuda Triangle ! > Thanks Tom in >Ohio > > ________________________________________________________________________________
Date: Mar 06, 2000
Even cheaper by the gallon. Paid $60.00/gal. for the Marhyde at the local auto paint supply. Mike Mckenna RV-8 > I buy Marhyde in 1 qt. cans (#5112 I think) at the local auto body > supply for about $18, shoot it with the same gun you're using- ain't it > great?! > > > Scott Kuebler ________________________________________________________________________________
Subject: Re: 6A Longitudinal Cowl Hinges
Date: Mar 06, 2000
Subject: Re: RV-List: 6A Longitudinal Cowl Hinges > >Once I got the holes that you can reach that you mentioned, I took it off >and drilled one hole towards the back of the cowl. Just a random place to >hold the hinge on. Then I put it back on and finished the drilling. Fill >the original hole, and you are all set. If you drill the remainder of the holes inline on the hinge , and do as Paul suggests, you can then back drill the cowl thru the hinge holes. Derek Reed 6A ________________________________________________________________________________
Date: Mar 06, 2000
Subject: nav-aid/gpd tracking
I have been using a lowrance 300/nav-aid for several years, six US crossings. My nav-aid does that little stick joggle when it crosses a way point. I haven't had the problem of loosing the course however. When I first got it installed I tried various scenerios and found that it could follow even a 90 degree intercept of the gps course, although that extreme case took several oscillations before it tracked correctly. On a typical cross-country trip you rarely have 90 degree waypoints, assuming you are trying to get somewhere in the least amount of time. I have had the autopilot loose the signal before(as indicated by a lack of the green light being lit) and it just keeps on flying level, but who knows where. When first telling the nav-aid to follow a new course I have experienced it wanting to bank off heading. I believe it takes perhaps 10-20 seconds for the gyro to settle down. Try using the wing leveler mode for 20 seconds flying along the desired course. Switch to track mode to light the green light. Then flip it from wing leveler to tracking mode mode. This should result in no stick joggle. For as many of these units that the RV'rs buy I'm surprised that the Nav-aid people have so little experience using their own equipment. But despite that I find the nav-aid the best option, along with the gps, that I have bought. It paid for itself one night when I went IMC just two miles from home(I have no other gyros). Kevin -6A ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: electric vs manual elevator trim
Check out my website. I offer an electric elevator trim system installation kit that is suitable for either a retrofit or new built electric trim system. The address to the website is www.gretzaero.com Warren Gretz Gretz Aero Leif Butler wrote: > > I am having a difficult time deciding whether to order my RV-6 tail with the > electric or manual trim and would appreciate any words of wisdom. > > Leif Butler > getting ready to begin > ________________________________________________________________________________
Date: Mar 06, 2000
-----Original Message----- From: Scott Kuebler [SMTP:skuebler(at)cannondesign.com] Sent: Monday, March 06, 2000 11:58 AM Subject: RV-List: Observations on priming (long) In the past for my tail kit I used Marhyde single stage, self-etching primer in a rattle can. I loved it. It went on quickly and evenly, dried fast (two minutes), was very clean and convenient (no mixing or cleaning) and was very tough when dry. I would probably still be using this brand if it wasn't for the price, $15.00 for a 17oz can. If I remember correctly I used four cans on the tail kit. When it came time to prime the wing kit I calculated that it would probably take me fifteen cans to cover everything. $225.00 was a little more than I would like to spend on a process that many builders say is unnecessary (but we won't get into that). I knew with the Marhyde that I was paying for packaging and propellant, so I started looking into mixing my own and shooting it with a spray gun. After MUCH research into primers I decided on Deft two-part water based epoxy primer. Marhyde can be purchased in quarts and gallons for use in spray guns if you like. Vince ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: RV-List:Forward Side Skins on 8
Listers: After fitting and drilling the bottom skin and lower longerons I started on the forward side skins tonight. But to my dismay, they didn't fit. If I line up the bottom then the opposite top doesn't fit and vice versa. Any suggestions or ideas on where I may have rigged wrong. The forward bottom skin is drilled and fits fine. Len RV-8A, fuselage North Carolina ________________________________________________________________________________
Date: Mar 06, 2000
In a message dated 3/6/00 6:09:35 PM Pacific Standard Time, tcervin(at)valkyrie.net writes: << My question is has anyone to date found a compass that can handle the magnetic interference inside the slider and be of operational use? >> My Precision Vertical Card compass is hanging from the stainless steel center tube on my 6A and works very well. Some of the builders that have had problems have had to degauss their rollover bars. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: oil cooler fittings-a0360a1a
SALNED71(at)aol.com wrote: > WHAT OIL COOLER FITTINGS DO I NEED FOR THIS ENGINE, SO I CAN GET THEM > INSTALLED BEFORE I MOUNT THE ENGINE??? Van's website use to have a small drawing showing all the fuel/oil fittings and hoses forward of the wire wall. It is a bunch and about $500! There is only one fitting for the oil pressure gage that is located on the right upper rear end of the engine right adjacent to the mount that need to be installed BEFORE you install the dynafocal mounts. All the others can be installed later, but then I do not have a vacuum pump or right mag. That sure cleans out some space. The prop governor cable bracket VA-153 must be installled and safety wired to the governor before mounting the engine to the firewall. BE WARNED that the slot in the bracket must be enlarged about 3/16 on the top side for the cable to work freely. I mounted my engine to the fuselage with temporay hardware store quality bolts. It's been off/on three times now! Richard Reynolds, Norfolk, VA, RV-6A, cowl and spinner fitted. ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Canopy latch direction
>Van's RV-4 plans have the canopy release lever move FORWARD for release >and REARWARD for latching. This seems backward to me...... I thought so too and set mine up to be FOREWARD to latch, back to unlatch. That seemed to make more sense to me. Maybe it was because every other knob is forward to go, that should be too. Just seemed more natural that way. I was up flying yesterday and happened to look at the latch knob, wondering if it would have been better the other way. I don't think so. SInce it is your airplane, you can do anything you want. I LIKE having it the "wrong" way. Michael RV-4 N232 Suzie Q ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: RV8-List: S-Tec Auto Pilot Install
Gary, I called S-tec and they sent me several drawings depicting perfered mounting locations for the roll and pitch servo's. I will mount my roll servo in the wing in the same bay as the aileron bell crank. S-Tec also will sell you just the servos up front so you don't have to shell out funds for the whole system. Also, S-Tec recommends not buying the gyro instrument until instrument panel time. It isn't good to have gyro instruments setting idle for long periods of time. Finishing the first wing #80989 At 03:23 PM 2/23/00, you wrote: >--> RV8-List message posted by: Gary Graham > >Has anyone any experience installing an S-Tec System 30 autopilot in an RV-8? >If you have let me know how and where you mounted the roll and pitch servos. > >Thanks > >Gary Graham > > ________________________________________________________________________________
Date: Mar 06, 2000
>Thank you to all that have helped me in the past. Good luck to all that I have helped. I have out-grown the need, nor do I have time, to participate on the list. > >Gary Corde >RV-6 N211GC - NJ Gary, I've enjoyed your contributions to fellow rvers through the list. You've certainly contributed a lot of helpful hints in the past and I'm sure a lot of builder's have benefitted from your experience. I understand about all of the time required to monitor the list and help other builders. It's not hard to "run out of time" and you've certainly done your fair share. Still, I sure hate to see the old timers fade away. But, the ones building and nearing completion will be tommorows experts and many will stay on the list for awhile to help out. Regards, Bob ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Old RVers fading away-long
Fellow RVers, After visiting with some fellow RVers, off list, and seeing some of the things that have been happening on the list over the past few months, I decided to post what I hope will be some useful tips, hints, insights, etc. Or, it could be just more wasted bandwidth:) When I was building a Glasair, I'd go to OSH to visit Glasair builders. Since I also intended to build a RV, I hung around the RV builders, as well. I found the RVers to be almost the exact opposite of some of the Glasair builders I met. Almost to a man, I found the RV builders to be very helpful, patient and "neighborly". This has always been one of the main drawing cards for me---the kind of people you get to associate with. There is no group like RVers. This same spirit has, for the most part, has been prevalent on the RV list for years. Yes, there are occasionally lapses of courtesy, patience or judgment but, all in all, the rv list is one of the best groups going. I've been on the list for 5 years, now. I joined after I had my six done. I wish I would have known about the list when I was building. I thoroughly enjoyed interacting with fellow RVers and passing along any helpful information that I thought might help them avoid mistakes and build a better airplane. It was interesting to visit with so many builders from all over. It's especially nice when you go to OSH or S&F and you already have "instant friends" due to participation on the list. The list is just like having an exclusive group of pen pals with the same interests and it's been a lot of fun participating. It's been kind of sad for me to see a lot of the guys I used to visit with leave the list. There are several reasons for folks leaving and I guess I can't blame them. Builders with flying airplanes do lose interest. A lot of them continue to participate for while after completing their airplanes. I imagine they have the same thoughts that I have. Sometimes, it seems like you've answered the same question over and over. It's easy to forget that there are "newbies" coming on line all of the time and they have the same questions all new builders have. There are other reasons folks drop their involvement and I'd like to pass my ideas along for what they're worth. Most of the following is from my perspective and from the thoughts of former listers that I've visited with. I think one of the primary reasons the list looses valuable members is due to the lack of courtesy and the feeling that the persons efforts in trying to help fellow RVers are not appreciated. No one likes to be flamed for their posts when all they are doing is trying to help. True, there may be, at times, inaccurate information presented. But, these can be dealt with "off list" or on list in a courteous manner. Remember, the builders who have completed and are flying their airplanes don't have much, if anything, to gain from list participation. It takes a lot of time to go through all of the messages, think about questions and try to write a helpful reply. I would encourage anyone that, when they have received a helpful reply, to write to the person directly (that's off-list) with a simple thanks. For run of the mill advice, this may not be necessary. It's your call. But, if the responder has obviously spent a lot of time and thought on helping you with a problem, it would seem a "thank you" might be appropriate. It costs nothing and goes a long way towards making a responder feel appreciated. In a lot of cases, the helpful responses have saved builders from making expensive mistakes or resulted in a quicker build, safer airplane, etc. What did the person who helped you out get out of the exchange? It does take a lot of time to monitor the list. There are several ways to "clean things up" and to speed the exchange of information along. Matt gives you a lot of these ideas when you sign up and there are periodic reminders. Try to reduce clutter as much as possible. If you have a point to make to one person and not the entire list, hit reply, erase the "to:" field and paste in the person you want to respond to. There are a lot of exchanges that are of no interest to the list and are of a personal matter. Of course, we all mis-post to the list. (I've found that, if I don't immediately erase "rv-list(at)matronics.com" from the to field that some of my posts go to the wrong place:( ) "Way to go", "I agree" and "me too's" can really clutter up the list, as well. If someone has something for sale, re-do the "to" field and respond directly. The whole list doesn't have much interest in your asking how much someone wants for his "widget". All in all, I think the list works pretty darn good. Certainly, the list is much more "flame free" than some of the newsgroups that I've seen. Probably some of the problems with the list is due to "newbies" coming on line who are used to interacting with newsgroups and have that "mind set". I'll guarantee you that that type of nasty, flame based interaction will not be tolerated on the RV-list and it's a really good way to make sure that the "old hands" won't stick around. I guess this is the main thing that has bothered me. I see so much talent leaving the list. People who have contributed so much and been so helpful. The listers are the losers when this happens. If I were a list member, I would try to make sure as many of the old timers as possible stuck around and think of ways to make this happen. I've harped to my 2 daughters since they were little kids that the "Golden Rule" is something that will benefit them their whole lives. It's something that can be put to good use here, as well. Lastly, as my building career comes to and end (and eventually my participation on the list), I'd like to say to the RVers that I've met on the list and met at fly-ins that it's been one of the highlights of my life. You are one of the greatest groups of people one could be associated with and I enjoyed it every minute. Regards, Bob Skinner Buffalo, WY (1995 RV6 sold after 4 years & 470 hrs) EAA Tech Counselor # 3726 PS For those friends who may be wondering about my ending "career". I've been building since 1980. I've owned 7 planes since 1975. I've helped several other builders with their projects. When I moved to Wyoming, I left behind a wonderful shop and don't feel like investing the money required to build another. I've also found some other fun things to do: fly fishing for trout, hiking in the mountains and traveling in the "RV substitue", my wife's silver Miata. My wife doesn't like to fly and my priorities have changed a bit. The main factor in quitting RV building is due to a problem that I've developed with fiberglass dust, even though I've been wearing a mask. Prior asthma problems along with exposure to f.g. dust have convinced me that I'm better off doing something else. I sold my RV 6 knowing that I could always build another one but that doesn't seem to be the case, now. When I get back from a visit to Nebraska, I'm going to help a friend work on his fuselage for a few days and will then inventory my tools and put them up for sale. ________________________________________________________________________________
Date: Mar 07, 2000
In a message dated 3/6/00 4:28:10 PM Pacific Standard Time, fasching(at)amigo.net writes: << Lowrance doesn't have a controllable output for course width, and the NavAid instructions of how to determine and to set its course width are vague, and the "technical support" was non-existent when I asked them why it didn't follow the instruction book. The man said, "I just copied that from them (Porcine)" >> I would recommend contacting Porcine Associates directly. I believe their website is www.porcine.com. The website states that they will make the wing leveler interface with your GPS properly; that they are not aware of any GPS units that cannot be made to work properly with their coupler except the older Magellan units (I think). I'm speaking from memory here since I haven't contacted their site in several months, but I do remember that they make a very clear committment that they will be able to assist you to get your system to work properly. Please report back to the list if you contact them and they are able to help. Good Luck, Dale Wotring RV6A ________________________________________________________________________________
Date: Mar 06, 2000
Gary, Sorry to see you go.... May your flights be beautiful and may you always enjoy a tailwind (except on final). Chuck ________________________________________________________________________________
Date: Mar 06, 2000
Subject: RV8A Quick Build Landing Gear
HELP! Is there anyone out there who has installed the landing gear weldments WD-821 L & R on a quick build fuselage? How did you do it? Specifically did you actually have to make the .040 shim called for in the drawings but there is no mention of it in the plans. It looks like you just slap the 821 in place and start drilling, yes? What about the F-895 B spacer? It looks like the F895 doubler plate is already installed. It's extremely hard to make heads or tails out of the drawings. Any help at all would be greatly appreciated. - Jim Andrews RV-8AQ Fuse N89JA (reserved) ________________________________________________________________________________
Date: Mar 06, 2000
Subject: Re: RV8-List: RV8A Quick Build Landing Gear
Hiya Jim... I drilled through the skins to gain access for drilling the spacers... To me... it looks like this spacer should have been done before the skin was installed... but wasn't... Larry N248PL RV8 quick build kit #008 Jim_Andrews(at)tivoli.com wrote: > --> RV8-List message posted by: Jim_Andrews(at)tivoli.com > > HELP! > > Is there anyone out there who has installed the landing gear weldments WD-821 L > & R on a quick build fuselage? > > How did you do it? Specifically did you actually have to make the .040 shim > called for in the drawings but there is no mention of it in the plans. It looks > like you just slap the 821 in place and start drilling, yes? What about the > F-895 B spacer? It looks like the F895 doubler plate is already installed. > It's extremely hard to make heads or tails out of the drawings. > > Any help at all would be greatly appreciated. > > - Jim Andrews > RV-8AQ Fuse > N89JA (reserved) > ________________________________________________________________________________
Date: Mar 07, 2000
Subject: Re: Old RVers fading away-long
I for one am going to miss Bob's expert advice offered to fellow RV builders. I know he has helped many builders that he has never met. I talked with him just today and he gave me advice in setting up the fuse. jig, and drilling the skins to the bulkheads. I've flown in Bob's RV-6 that he sold last summer and it was a "VERY NICE" machine. I saw Charlie Tyrells's RV-6 fuselage in the canoe stage after Charlie and Bob had worked for about 10 days. Great job (10 days!). Bob informed me today that after he helps me with my fuselage he is getting out of RV building. I feel very lucky that he is willing to help me. (By the way Bob have a safe trip and I hope you get over your cold.) I hope every one wishes Bob the best, and we should thank all the others out there who have given their time and expertise. Best of Luck to you and your wife Bob. John Danielson ________________________________________________________________________________
Date: Mar 07, 2000
Subject: Re: Aluminum "eyeball" air vents
Hi Greg, Do you still have any alum. eye ball vents? I dide-mail you after your post, but no reply. Thanks John Danielson Casper, WY ________________________________________________________________________________
Date: Mar 07, 2000
Sorry about that, was suppose to be personal. don not archive ________________________________________________________________________________
Date: Mar 07, 2000
Subject: t-407 tank re. rv-6
i asume the hole in the 403 rib is cut to the same size as the inside dia. of the 407 tank reinforcement flange. also the vent line fitting placement is not shown on the plans at the inb.403 rib.can anyone help on these subjects. tcrv6(at)aol.com left wing tank in hodge la. ________________________________________________________________________________
Subject: Re: Tools - Shear / bending brake?
Date: Mar 06, 2000
> ... I'd like to buy > a tool that would be good for making simple sheetmetal parts. One > criteria is selecting a tool that would be useful on an RV project one > day. At Harbor Freight I see several choices from a $370 > shear/press break down to a $16 bending break. Any experience > with these tools? Is a shear useful? A bending break? What is > recommended? I could have used both during my project but they're much more of a luxury than a necessity. I do think that if you don't have a "real" brake, you should at least consider getting one of those little 18" "hobbyist's" bending brakes (got mine from ATS), just because for the cost (somewhere around $25) you at least have SOME kind of brake, if not a very sophisticated one. Not worth much for larger or more complicated parts, but it beats hell out of a hand seamer for the small stuff. Be sure to get one that's made out of STEEL -- the one that Spruce sells is aluminum and really has no beef at all. Randall Henderson, RV-6 N6R (60+ hours and PAINTED!) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
Subject: D.A.R in Warsaw
Date: Mar 07, 2000
Listers, I wanted you to know that there is a DAR in Warsaw Indiana now. His name is John Blosser and he's been an A&P for years. He also owns Air Care ( a repair facility based at Warsaw Airport ). I don't know how much he's going to charge but based on my knowledge of him, he will be reasonable and also provide valuable information based on experience. John's phone number is 219-269-5081 ________________________________________________________________________________
Date: Mar 07, 2000
In a message dated 3/6/2000 3:59:05 PM Tokyo Standard Time, nuckolls(at)aeroelectric.com writes: > > > >Any help out there? > > the NavAid is a wing leveler with a yaw rate sensor (like that > found in your turn coordinator) to sense rate and direction > of turning only. It has no notion of heading. > > T Hmmm, heading(track) info is as readily available from the GPS as is cross track and bearing. I dont see why it wouldn't have been designed to take advantage of that info. Perhaps your GPS is just not refreshing fast enough for the Navaid to correlate the turns it is making with the GPS indicated track. There was a report on this list several months ago where someone was making great waypoint turns with the Navaid. I recommend checking the archives and keep trying to get a hold of Navaid. You could also try decluttering your GPS screen or using a GPS without a huge aviation database to slow it down. ________________________________________________________________________________
From: "Nancy and Walter Shipley" <wshipley(at)esper.com>
Subject: RV8A QB Landing Gear Mounts
Date: Mar 07, 2000
Jim Andrews asked about installing the WD821's: Jim, the .040 spacers are needed. If you look closely at Dwg 30A, section R-R, lower left, you'll see that the 821's rest against the F804C, except for the inboard end, where the 804C ends. You need the shim to fill the void between the 821 and the gold anodized spar carry through. As for the F895B spacer, I also have an 8A QB, and the spacer was already installed (ya gotta use a mirror to see it). I had lots of problems with the fit of the WD821R - finally had to send it back to Van's and get a new one because it was not fabricated to the correct dimensions. The new one fit perfectly! So, keep in mind this could happen in your case. Regarding the bolts that attach the 821's to the side of the fuselage (7 each side), I suggest you have the 821's snugly bolted to the spar carry through BEFORE you drill these holes, otherwise the holes in the fuselage may not be aligned w/the 821 holes. It's also very helpful to make the drift pins called for in the plans, to bring the 821's in alignment. Hope this stuff helps......... Walt Shipley RV8A QB 314TS (reserved) ________________________________________________________________________________
Subject: Wheel Landings
Date: Mar 07, 2000
Listers, During my transition training w/ Mike Seager, he said the RV's should be landed 3 point. He said the gear was too springy for wheel landings, I believe. Well, Saturday, I tried to fly up to Shady Bend RV fly in & had to turn around because of rain. The winds picked up & when I landed in Titusville for fuel, winds were gusting to 30 kts, & about 20 deg. off the runway. Seems like the situation for a wheel landing but I kept with the 3 pt. At flare, I balloned up, not once but 3 times. Finally got it down but it wasn't smooth. Have others wheel landed the -6? Is the gear that springy to not even consider it? Rick Caldwell -6 29.9 hrs Melbourne, FL ________________________________________________________________________________
Date: Mar 07, 2000
Chuck: Does the SIRS compass people have a website??? If so please forward...Thanks, Jim Brown, RV-3&4, NJ ________________________________________________________________________________
Subject: Re: RV8A Quick Build Landing Gear
Date: Mar 07, 2000
----- Original Message ----- From: <Jim_Andrews(at)tivoli.com> Sent: Monday, March 06, 2000 11:50 PM Subject: RV-List: RV8A Quick Build Landing Gear > > > HELP! > > Is there anyone out there who has installed the landing gear weldments WD-821 L > & R on a quick build fuselage? > > How did you do it? Specifically did you actually have to make the .040 shim > called for in the drawings but there is no mention of it in the plans. This is just a simple 5/8" X 3/4" piece of .040 which lies in the offset created where the gear weldment lies up against the F-804C bulkhead. An AN-13A bolt goes through the weldment and the spacer, so there is no gap between the weldment and the bulkhead. It looks > like you just slap the 821 in place and start drilling, yes? NOTHING is ever quite that simple (at least for me). My left weldment fit fine, but the right one required some "coaxing." The forward-facing arm required a slight bit of bending to rest up against the lower longeron. Van's suggested I heat the forward tube to make it bend - so I heated it with a propane torch on one side to get it to bend the other way ever so slightly. Finally, there was the slightest mismatch in the holes. You MUST NOT DRILL THROUGH THE WELDMENTS AND BULKHEAD TO GET THEM TO MATCH! (yes, I am shouting :)). Take a file and file the holes on the weldment until they will match. Put on some nice, soothing music and take your time. This is tedious. What about the > F-895 B spacer? It looks like the F895 doubler plate is already installed. > It's extremely hard to make heads or tails out of the drawings. Yep, the F-895B is already there. It's what you drill through when you make the forward wing attachment when you attach the wings. The plans are also very confusing here as this is markedly different than the RV-8 - I'll share my experiance with you there and post pictures on my website if you like. Hope this helps. Jerry Carter RV-8A Memphis, TN My RV-8A Web Site: http://www.rv8asite.homestead.com/mainpage.html ________________________________________________________________________________
Date: Mar 07, 2000
From: "Scott Kuebler" <skuebler(at)cannondesign.com>
Subject: Wing Ribs - RV-6a
I am about to temporarily install the wing ribs (tip & main) in order to fit the skins. I remember being told not to use the good AN365 Nylok nuts for the temporary assembly. Is it O.K. to re-use the AN3 bolts for both temporary and final assembly? (I think it would be alright but I just want to verify) Also- I have checked every local hardware store for 3/16" nuts and the smallest I can find is 1/4" before they switch over to numbers (#10, #8, ...). Have I overlooked something obvious or do I have to order the nuts directly from Van's or a different supplier? Thanks in advance, Scott Kuebler Buffalo, NY RV-6a (wings) ________________________________________________________________________________
Subject: Re: nav-aid/gpd tracking
Date: Mar 07, 2000
> > >I have been using a lowrance 300/nav-aid for several years, six US >crossings. My nav-aid does that little stick joggle when it crosses a way >point. I haven't had the problem of loosing the course however. When I >first got it installed I tried various scenerios and found that it could >follow even a 90 degree intercept of the gps course, although that extreme >case took several oscillations before it tracked correctly. On a typical >cross-country trip you rarely have 90 degree waypoints, assuming you are >trying to get somewhere in the least amount of time. I have had the >autopilot loose the signal before(as indicated by a lack of the green light >being lit) and it just keeps on flying level, but who knows where. When >first telling the nav-aid to follow a new course I have experienced it >wanting to bank off heading. I believe it takes perhaps 10-20 seconds for >the gyro to settle down. Try using the wing leveler mode for 20 seconds >flying along the desired course. In the Navaid Devices manual it states that one needs to wait about 30 seconds after recentering the CDI before engaging the autopilot. This has nothing to do with the gyro, it allows time for "some capacitors ... to stabilize." If you don't do this, the autopilot thinks you are still off course and will make an aggressive correction. Quite startling to passengers. How do I know? By the way, my Navaid does that stick jiggle when I first engage it, but normally quits after a short time. I think it could be tweaked out. Larry Pardue Carlsbad, NM RV-6 N441LP http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Subject: Re: Wheel Landings
Date: Mar 07, 2000
I wheel land mine about 25% of the time, just for fun. It does need to have the right tire pressure. I use 6 ply tires and 35 lbs. is just about right. As for high wind, wheel verses 3 point, it is my opinion, 3 point is the safest. Please no flames, this is the way I do it. About 1300 hours, Commercial ASEL, IFR rated and Private Glider. 800 hours in a Cessna 140 500 hours in the best airplane around, RV-6. Ken Bryan, TX http://pages.tca.net/kgray ----- Original Message ----- From: Rick Caldwell <racaldwell(at)hotmail.com> Sent: Tuesday, March 07, 2000 7:20 AM Subject: RV-List: Wheel Landings > > Listers, > > During my transition training w/ Mike Seager, he said the RV's should be > landed 3 point. He said the gear was too springy for wheel landings, I > believe. Well, Saturday, I tried to fly up to Shady Bend RV fly in & had to > turn around because of rain. The winds picked up & when I landed in > Titusville for fuel, winds were gusting to 30 kts, & about 20 deg. off the > runway. Seems like the situation for a wheel landing but I kept with the 3 > pt. At flare, I balloned up, not once but 3 times. Finally got it down but > it wasn't smooth. Have others wheel landed the -6? Is the gear that > springy to not even consider it? > > Rick Caldwell > -6 29.9 hrs > Melbourne, FL > > ________________________________________________________________________________
Subject: Re: Wing Ribs - RV-6a
Date: Mar 07, 2000
>From: "Scott Kuebler" <skuebler(at)cannondesign.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Wing Ribs - RV-6a >Date: Tue, 07 Mar 2000 10:01:55 -0500 > > >(snip) >Also- I have checked every local hardware store for 3/16" nuts and the >smallest I can find is 1/4" before they switch over to numbers (#10, #8, >...). Have I overlooked something obvious or do I have to order the nuts >directly from Van's or a different supplier? > >Thanks in advance, > Scott >Buffalo, NY >RV-6a (wings) ________________________________ Scott, The 10's are the 3/16". Just make sure you obtain the 10-32's (32 threads per inch), not the coarse threaded 10-24's. Best Regards, Jack -8 #80815 wings > > ________________________________________________________________________________
Date: Mar 07, 2000
http://www.sirsproducts.com/ Sam Buchanan A20driver(at)aol.com wrote: > > > Chuck: Does the SIRS compass people have a website??? If so please > forward...Thanks, Jim Brown, RV-3&4, NJ ________________________________________________________________________________
Date: Mar 07, 2000
> > >Listers, > >During my transition training w/ Mike Seager, he said the RV's should be >landed 3 point. He said the gear was too springy for wheel landings, I >believe. Well, Saturday, I tried to fly up to Shady Bend RV fly in & had to >turn around because of rain. The winds picked up & when I landed in >Titusville for fuel, winds were gusting to 30 kts, & about 20 deg. off the >runway. Seems like the situation for a wheel landing but I kept with the 3 >pt. At flare, I balloned up, not once but 3 times. Finally got it down but >it wasn't smooth. Have others wheel landed the -6? Is the gear that >springy to not even consider it? > I wheel land mine on occasion but don't know how it compares to other taildraggers because I haven't flown many types. My Pacer was a bear to wheel land and the six is easier than it but the gear is pretty springy and you can't have much descent rate when you touch or it will bounce. Don't Cessna 180's do that too though? I couple of months ago I posted to the list about a wheel landing I made in a very strong crosswind. It went very well. Lots of speed for excellent control and with the low ground speed, it was very easy to make a precise and under control landing. As I stated in that post I thought a taildragger wheel landing under those conditions was easier than a landing in a tri-gear plane would have been. Larry Pardue Carlsbad, NM RV-6 N441LP http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: Mar 07, 2000
Here it is: http://www.sirsproducts.com/ Eric Irwin Coral Springs, FL RV-6, empennage > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of > A20driver(at)aol.com > Sent: Tuesday, March 07, 2000 9:29 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Compass For RV6-A > > > Chuck: Does the SIRS compass people have a website??? If so please > forward...Thanks, Jim Brown, RV-3&4, NJ > > ________________________________________________________________________________
Date: Mar 07, 2000
Thanks Jack, I thought it was something simple like that. Scott >>> "Jack Blomgren" 03/07 10:26 AM >>> Scott, The 10's are the 3/16". Just make sure you obtain the 10-32's (32 threads per inch), not the coarse threaded 10-24's. Best Regards, Jack -8 #80815 wings ________________________________________________________________________________
Date: Mar 07, 2000
Subject: builders near Ft Rucker, AL (templates wing)
I was wondering if any builders in this area still have there wood templates for setting the ailerons laying around. I bought a half built project and need those for my wings. I have a RV4 and I think a 6 or 4 would work. Carey Mills ________________________________________________________________________________
Date: Mar 07, 2000
>During my transition training w/ Mike Seager, he said the RV's should be >landed 3 point. He said the gear was too springy for wheel landings.... Oh, dear. I'm afraid you've stirred the hornet's nest. This is a much debated subject and has been discussed (see archives). It seems to depend on many factors. (I look at suspect upon most statements that begin with never, except "Never say never"). Let me stir the nest a little harder: After 350+ hours in Suzie Q (a -4) I have found I am wheel landing or sort of tail low wheel landing 80% of the time, especially with someone in the back seat (-4, -8) or in cross wind situations. It is cool to squeek her on three point, but the arguement can be made that the gear is too springy to three point. If you grease it on, yeah, no bounce. If you happen to drop it in a little, the gear will chuck you back into the air, or at least bounce you around a little, with those sideways glances from your passenger (-6 types). It is easier to three point with the "new" longer gear, which the -6 already have. With the short -4 gear, it is easy to drag the tail wheel before the mains plunk on. Cross winds: I have always felt in better control carrying some speed and planting the upwind gear on first (probably from my Cub days) until losing enough speed to bring the downwind gear down, THEN, the tail. I know, "the tail has to come down sometime" but it feels better to bring it down with more weight (less lift) on the firmly planted main gear. Short field: three point. I think it depends on several things, what technique you use. What are you used to? What makes for YOUR better landings? How were you trained to do it? What is the current situation (wind, heavy back seater, etc). Do what you have to do to get it on the ground. (I once landed the Cub ACROSS a runway, on to a taxi way. In Casper Wyoming, I landed on the tiedown ramp with the winds going 35 knots and didn't roll 5 feet. That was a wheel landing.) I like to go out every once in a while when the wind is blowing and work on different techniques. It is better to find out what works and how you will react close to home and fresh, rather than at the end of a 2.5 hour cross country when your tired and have to pee really bad. Don't just fly calm days at home. Just some thoughts............. Michael RV-4 N232 Suzie Q Fly a lot; that's the bottom line. ________________________________________________________________________________
Date: Mar 07, 2000
Subject: Re: RV4 brakes
>1) The plans show the brake reservoir mounted on the engine side of the >firewall with a hole bored thru the firewall for the Tee and brake lines >to the master cylinders. Is there any reason (other than convenience when >refilling) why the reservoir couldnt be mounted on the cockpit side of the >firewall? Is it prone to leaking? If you look at the nut that plugs the fill hole, you'll see it is kind of funky looking. It is designed to allow air in to let the brake fluid move up and down. Which also means it will let the fluid out. And it does leak occasionally out the nut. Brake fluid turns into this gooey sticky mess after it "dries". The way the reservoir is made (if it is still the same as the "old days"), it is set up to be mounted on the fire wall. It would be a PITA (pain in the butt) to try to get to it to fill it if it was on the cockpit side of the fire wall. IMHO, I see no advantage to putting it in the cockpit. Except you wouldn't have to poke another hole in the fire wall. Michael ________________________________________________________________________________
Date: Mar 07, 2000
Subject: Re: VFR panel
>> MicroEncoder for Airspeed, VSI, Altitude, OAT. Is this asking to much >>from these istruments for VFR flight. >I intend to do the same - except night flight for which I will add a >back up altimeter. If you lose the uEncoder at night, you should be >able to get back on the deck using backup altitude and engine RPM as >airspeed. Once you're familiar with the aircraft, you know what a >particular throttle setting will get you for speeds in the pattern. Hmmmm. I think if I was to be redundant, I would choose, ASI. Seeing how far from the ground you are may be easier, in most situations, than trying to determine how fast/slow you are going. These airplanes we are putting together fly really fast, and really slow. It can sometimes be disorienting to come into the pattern after a fast cross country and try to determine how slow you are going without the airspeed. I think I would rather lose the altimeter than ASI I have the uEncoder and love it. I also have analog ASI and altimeter (I know: too much in the panel) and I use them all, depending on the situation. My opinion only. Michael ________________________________________________________________________________
Date: Mar 07, 2000
Subject: SIRS COMPASS
can anyone find a price scheduel for the SIRS products. They have a nice product !! erici(at)bigfoot.com on 03/07/2000 10:40:16 AM Please respond to rv-list(at)matronics.com Subject: RE: RV-List: Compass For RV6-A Here it is: http://www.sirsproducts.com/ Eric Irwin Coral Springs, FL RV-6, empennage > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of > A20driver(at)aol.com > Sent: Tuesday, March 07, 2000 9:29 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Compass For RV6-A > > > Chuck: Does the SIRS compass people have a website??? If so please > forward...Thanks, Jim Brown, RV-3&4, NJ > > ________________________________________________________________________________
From: bcbraem(at)home.com.with.ESMTP (InterMail v4.01.01.00 201-229-111)
Date: Mar 07, 2000
Tom & Cathy Ervin wrote: > > > List: I am going to mount my compass on the glare shield as the panel (IFR) > will be full. > My question is has anyone to date found a compass that can handle the > magnetic interference inside the slider and be of operational use? > Anyone tried a Mooney Compass ? As we know the canopy frame work > seems to mimic the Bermuda Triangle ! > Thanks Tom in Ohio > I have the -6 with the slider and de-gaussed the metal frame with the the Radio Shack Bulk Tape Eraser (#44-232) and my vertical card compass is hanging from front brace with very little error. Boyd RV Super6 ________________________________________________________________________________
Date: Mar 07, 2000
Aircraft Spruce sells this compass. Jeff Hays. On Tue, 7 Mar 2000 pcondon(at)csc.com wrote: > > > can anyone find a price scheduel for the SIRS products. They have a nice > product !! > > > erici(at)bigfoot.com on 03/07/2000 10:40:16 AM > > Please respond to rv-list(at)matronics.com > > To: rv-list(at)matronics.com > > Subject: RE: RV-List: Compass For RV6-A > > > > Here it is: http://www.sirsproducts.com/ > > Eric Irwin > Coral Springs, FL > RV-6, empennage > > > -----Original Message----- > > From: owner-rv-list-server(at)matronics.com > > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of > > A20driver(at)aol.com > > Sent: Tuesday, March 07, 2000 9:29 AM > > To: rv-list(at)matronics.com > > Subject: Re: RV-List: Compass For RV6-A > > > > > > > > Chuck: Does the SIRS compass people have a website??? If so please > > forward...Thanks, Jim Brown, RV-3&4, NJ > > > > > > > > > ________________________________________________________________________________
Date: Mar 06, 2000
> I am about to temporarily install the wing ribs (tip & main) in > order to fit the skins. I remember being told not to use the good > AN365 Nylok nuts for the temporary assembly. Is it O.K. to re-use > the AN3 bolts for both temporary and final assembly? (I think it > would be alright but I just want to verify) > > Also- I have checked every local hardware store for 3/16" nuts and > the smallest I can find is 1/4" before they switch over to numbers > (#10, #8, ...). Have I overlooked something obvious or do I have to > order the nuts directly from Van's or a different supplier? > Scott Kuebler> Buffalo, NY> RV-6a (wings) ***Scott: I would get hardware nuts for the 6-32,8-32, & the An3 is a 10-32. When you get finished "fitting" which takes for ever, then use the Nylocs Don Jordan ~ 6A fuselage ~ Arlington,Tx ~ donspawn(at)juno.com ************************************************************************* *** > ________________________________________________________________________________
Date: Mar 07, 2000
Get 10-32 hardware store nuts. I used brass nuts just to make sure I didn't damage the AN3 bolt threads but I don't think it is that critical. Harry Crosby -6 Finish kit ________________________________________________________________________________
Date: Mar 07, 2000
I'm looking at this same compass. Their website is http://www.sirsproducts.com What they have is pricey, but what isn't pricey? Rick Jory Highlands Ranch, CO -----Original Message----- From: A20driver(at)aol.com <A20driver(at)aol.com> Date: Tuesday, March 07, 2000 7:36 AM Subject: Re: RV-List: Compass For RV6-A > >Chuck: Does the SIRS compass people have a website??? If so please >forward...Thanks, Jim Brown, RV-3&4, NJ > > ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Date: Mar 07, 2000
No flames here. This is the way I was taught to do it. The old Cub flyers around my home base tutored me when I was flying my Champ. I asked them about wheel landings. Their *opinion* was that you want to be going as slow as you possibly can when your wheels touch down. I think you should do whatever you feel safest doing. I have yet to encounter a wind that I can't three point either landing on the centerline, on an angle to the runway (corner to corner), or that short, really wide runway. :-) -- Scott VanArtsdalen, MCSE Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Ken [SMTP:kgray(at)tca.net] Sent: Tuesday, March 07, 2000 7:20 AM To: rv-list(at)matronics.com Subject: Re: RV-List: Wheel Landings I wheel land mine about 25% of the time, just for fun. It does need to have the right tire pressure. I use 6 ply tires and 35 lbs. is just about right. As for high wind, wheel verses 3 point, it is my opinion, 3 point is the safest. Please no flames, this is the way I do it. About 1300 hours, Commercial ASEL, IFR rated and Private Glider. 800 hours in a Cessna 140 500 hours in the best airplane around, RV-6. Ken Bryan, TX http://pages.tca.net/kgray ----- Original Message ----- From: Rick Caldwell <racaldwell(at)hotmail.com> To: Sent: Tuesday, March 07, 2000 7:20 AM Subject: RV-List: Wheel Landings > > Listers, > > During my transition training w/ Mike Seager, he said the RV's should be > landed 3 point. He said the gear was too springy for wheel landings, I > believe. Well, Saturday, I tried to fly up to Shady Bend RV fly in & had to > turn around because of rain. The winds picked up & when I landed in > Titusville for fuel, winds were gusting to 30 kts, & about 20 deg. off the > runway. Seems like the situation for a wheel landing but I kept with the 3 > pt. At flare, I balloned up, not once but 3 times. Finally got it down but > it wasn't smooth. Have others wheel landed the -6? Is the gear that > springy to not even consider it? > > Rick Caldwell > -6 29.9 hrs > Melbourne, FL > > ________________________________________________________________________________
Date: Mar 07, 2000
Subject: AERO Aviation Engines
Does anyone have any information re: A.E.R.O. Aviation in Granite City, Illinois? I'm thinking of getting an engine from them but since I'm not in that area I was hoping to get some references from the list. Reply to me off-list please. Thanks, Doug Shenk RV-6A qb ________________________________________________________________________________
Subject: Re: t-407 tank re. rv-6
Date: Mar 07, 2000
Hi....Didn't catch your name... The position of the vent line in the root rib of the tank is shown on plan 18A, the right side of the sheet. There is no dimension noted, however, for its location. What I did was keep the fore/aft placement the same as the internal ribs, again this is noted on the top drawing on plans sheet 18A. Then to locate the vent line top to bottom, I measured the inside diameter of the stiffening ring stamped into the rib. Then I measured 1/4 of this distance from the inside top edge of the stiffening ring to locate the vent line exit. Seemed to work for me. As to the stiffening ring, yes, the inside diameter of the ring is the dimension that you want to cut out from the root rib. I, however, cut mine out about 1/16 inch smaller than the stiffening ring to make sure that the ring was in contact at that inside edge all the way around the ring. Probably not a big deal, but again, it worked for me. Hope all this helps you out. Regards, Jeff Orear RV6A 25171 right wing flap and aileron Peshtigo, WI -----Original Message----- From: TCRV6(at)aol.com <TCRV6(at)aol.com> Date: Tuesday, March 07, 2000 1:54 AM Subject: RV-List: t-407 tank re. rv-6 > >i asume the hole in the 403 rib is cut to the same size as the inside dia. of >the 407 tank reinforcement flange. also the vent line fitting placement is >not shown on the plans at the inb.403 rib.can anyone help on these subjects. > > >tcrv6(at)aol.com left wing tank in hodge la. > > ________________________________________________________________________________
Date: Mar 07, 2000
Subject: Re: RV-8QB Aftermarket landing gear
> I searched the archives and could not find mention of the aftermarket > aluminum landing gear by Grove Aviation and hammerhead Aviation in San > Diego. Is anybody using them and if so what are your comments? I went down > to see them and they both appear to be high quality. They claim same or > better performance as steel gear, less weight, internal brake lines, and no > need to run the fiberglass fairings because they are aerodynamically cleaner > than the steel. > > Ed Perry > edperry64(at)netzero.net > > NetZero - Defenders of the Free World > Frank Hoover used them on his RV-8, now has about 30-40 hours. He does not have gear leg fairings, and his performance is pretty much typical for a 180/CS RV-8. He likes them "fine" but really has no basis for direct comparison. Once we get some more RV8s flying in the area I think we'll get a better idea. They are definitely lighter. One thing that I worried about is the durability of these gear. I recall that Van "drop tested" the RV-8 to FAR 23 standards, which is unusual for a homebuilt. Frank doesn't think this was done with his gear. The gear have a constant cross section rather than the taper in the normal gear, and appear (to me anyway) to have much less cross sectional area at the fuselage than the steel gear. I am not, by any stretch of the imagination, an engineer. Maybe someone with more background (Kevin?) could comment James Freeman RV8QB steel gear (for now) ________________________________________________________________________________
Date: Mar 07, 2000
>Listers, > >During my transition training w/ Mike Seager, he said the RV's should be >landed 3 point. He said the gear was too springy for wheel landings, I >believe. Well, Saturday, I tried to fly up to Shady Bend RV fly in & had >to >turn around because of rain. The winds picked up & when I landed in >Titusville for fuel, winds were gusting to 30 kts, & about 20 deg. off the >runway. Seems like the situation for a wheel landing but I kept with the 3 >pt. At flare, I balloned up, not once but 3 times. Finally got it down >but >it wasn't smooth. Have others wheel landed the -6? Is the gear that >springy to not even consider it? > >Rick Caldwell >-6 29.9 hrs >Melbourne, FL For me in the -8, three pointers for calm conditions or with winds right down the runway. In stiff crosswinds, I bring it in about 5mph faster, and wheel it on. The gear structure is different between the two models, but it seems to me that tying to really slow the plane down for a three point attitude with gusty crosswinds is possibly a hazardous proposition. I've done this once or twice so far, and it got to be a real handfull in a hurry! Brian Denk RV8 N94BD 59 hours ________________________________________________________________________________
Date: Mar 07, 2000
Date: Mar 07, 2000
Subject: ProSeal
I notice in Van's catalog there is some fuel tank sealant that replaces ProSeal. The part number is MC-236-B2. Does anybody know what this stuff is called and why Van's recommends it over ProSeal? Mark Schrimmer RV-9A empennage Irvine, CA ________________________________________________________________________________
Date: Mar 07, 2000
Subject: VM1000 Fuel Flow xducer plumbing - IO-360
Anyone who's put in the VM1000 fuel flow transducer between the servo and the flow divider comment on your plumbing technique. I'm using the stock, Bendix servo. ________________________________________________________________________________
Date: Mar 07, 2000
Scott, run over to true value and go through their nuts bolts bins till you see the brass stuff. they have small brass nuts that work and they're not that much even if you use the right price........ > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Scott Kuebler > Sent: Tuesday, March 07, 2000 10:02 AM > To: rv-list(at)matronics.com > Subject: RV-List: Wing Ribs - RV-6a > > > I am about to temporarily install the wing ribs (tip & main) in > order to fit the skins. I remember being told not to use the > good AN365 Nylok nuts for the temporary assembly. Is it O.K. to > re-use the AN3 bolts for both temporary and final assembly? (I > think it would be alright but I just want to verify) > > Also- I have checked every local hardware store for 3/16" nuts > and the smallest I can find is 1/4" before they switch over to > numbers (#10, #8, ...). Have I overlooked something obvious or > do I have to order the nuts directly from Van's or a different supplier? > > Thanks in advance, > > Scott Kuebler > Buffalo, NY > RV-6a (wings) > > ________________________________________________________________________________
Date: Mar 07, 2000
Subject: wiring question
listers, i am going to use a two-bus architecture as advocated by electric bob. i have a question about the feed from the main bus to the essential bus. electric bob's diagrams show a one-way diode allowing current to flow from the main bus via short unportected wires to the essential bus under normal ops. when the "e-bus alternate feed" switch is thrown, then the e-bus gets power from the hot side of the battery, and the diode prevents the essential bus from feeding the main bus. my questions is the following. why not send both feeds through the e-bus switch? in the normal position, power could flow from the main bus via a fused feeder. in the alternate position, the e-bus would still get power from the hot side of the battery, and there would be no electrical connection between the e-bus and the main bus. then the diode would not be needed. in addition, a longer, fused feeder from the main bus would allow you to place to fuse panels further apart if necessary. am i overlooking something? any reason why this would not be just as reliable and safe, if not more so, now that we have reduced the parts count and used a protected circuit? thanks, louis cappucci rv-6a wiring (more headscratching than wiring...) mamaroneck, ny ________________________________________________________________________________
Date: Mar 07, 2000
rue Value has a knurled brass 10-32 round double thick nut that can be fingered tightened & griped easily. Buy a handfull of these and use the standard aircraft bolts. Running the brass or S/S or regural steel up & down the aircraft bolts are fine for the 100 or so times you do fit-up. at the end replace with the real nylock or steel-loc nuts.This makes fit-up easy..... capsteve(at)wzrd.com on 03/07/2000 02:32:55 AM Please respond to rv-list(at)matronics.com Subject: RE: RV-List: Wing Ribs - RV-6a Scott, run over to true value and go through their nuts bolts bins till you see the brass stuff. they have small brass nuts that work and they're not that much even if you use the right price........ > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Scott Kuebler > Sent: Tuesday, March 07, 2000 10:02 AM > To: rv-list(at)matronics.com > Subject: RV-List: Wing Ribs - RV-6a > > > I am about to temporarily install the wing ribs (tip & main) in > order to fit the skins. I remember being told not to use the > good AN365 Nylok nuts for the temporary assembly. Is it O.K. to > re-use the AN3 bolts for both temporary and final assembly? (I > think it would be alright but I just want to verify) > > Also- I have checked every local hardware store for 3/16" nuts > and the smallest I can find is 1/4" before they switch over to > numbers (#10, #8, ...). Have I overlooked something obvious or > do I have to order the nuts directly from Van's or a different supplier? > > Thanks in advance, > > Scott Kuebler > Buffalo, NY > RV-6a (wings) > > ________________________________________________________________________________
Date: Mar 07, 2000
Subject: Re: wiring question
Let's see, so what you're suggesting is essentially an essential bus feed selector switch, correct? This does create a single point of failure in the switch itself, which is also probably the most unreliable part of the scheme. Jeff. On Tue, 7 Mar 2000, Louis Cappucci wrote: > > listers, > > i am going to use a two-bus architecture as advocated by electric bob. i > have a question about the feed from the main bus to the essential bus. > > electric bob's diagrams show a one-way diode allowing current to flow from > the main bus via short unportected wires to the essential bus under normal > ops. when the "e-bus alternate feed" switch is thrown, then the e-bus gets > power from the hot side of the battery, and the diode prevents the essential > bus from feeding the main bus. > > my questions is the following. why not send both feeds through the e-bus > switch? in the normal position, power could flow from the main bus via a > fused feeder. in the alternate position, the e-bus would still get power > from the hot side of the battery, and there would be no electrical > connection between the e-bus and the main bus. > > then the diode would not be needed. in addition, a longer, fused feeder > from the main bus would allow you to place to fuse panels further apart if > necessary. > > am i overlooking something? any reason why this would not be just as > reliable and safe, if not more so, now that we have reduced the parts count > and used a protected circuit? > > thanks, > louis cappucci > rv-6a > wiring (more headscratching than wiring...) > mamaroneck, ny > > > > > ________________________________________________________________________________
Date: Mar 07, 2000
Great post Bob, I hope some people take it to heart. Best of luck on all of your endeavors, and thanks for all of your help. If you ever get out around Boise, let me know. >Subject: RV-List: Old RVers fading away-long > Fellow RVers, Ed Bundy RV6a first flight 11/20/96 ebundy(at)micron.net ________________________________________________________________________________
Subject: Re: Compass For RV6-A
Date: Mar 07, 2000
Jim, SIRS does have a web site > http://www.sirs.co.uk/ We ordered ours from Aircraft Spruce. Good Building, Chuck & Dave Rowbotham RV-8A (wiring) Niantic, CT >From: A20driver(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: Compass For RV6-A >Date: Tue, 7 Mar 2000 09:28:42 EST > > >Chuck: Does the SIRS compass people have a website??? If so please >forward...Thanks, Jim Brown, RV-3&4, NJ > > ________________________________________________________________________________
Date: Mar 07, 2000
Listers; I have about 800 landings on my -4 ( only counting the best one when there were more than one ) and an old friend how to do it. he told me to not reset the trim after you set it at power down on downwind. Keep the speed down and land on the rear of the mains, almost with the tail wheel dragging. Release the stick backpressure and let the trim setting put it in the wheel position. Works well for me. John Kitz N721JK Ohio ________________________________________________________________________________
(EMWAC SMTPRS 0.83) with SMTP id" <B0001365060@smtp-in.libertybay.com>; Tue, 07 Mar 2000 10:30:56.-0800(at)matronics.com
Date: Mar 07, 2000
Date: Mar 07, 2000
Subject: ProSeal
(EMWAC SMTPRS 0.83) with SMTP id" <B0001367388@smtp-in.libertybay.com>; Tue, 07 Mar 2000 12:16:49.-0800(at)matronics.com
Date: Mar 07, 2000
Date: Mar 07, 2000
(EMWAC SMTPRS 0.83) with SMTP id" <B0001363415@smtp-in.libertybay.com>; Tue, 07 Mar 2000 09:14:09.-0800(at)matronics.com
Date: Mar 07, 2000
Date: Mar 07, 2000
Date: Mar 07, 2000
Date: Mar 07, 2000
Date: Mar 07, 2000
Date: Mar 07, 2000
Date: Mar 07, 2000
Date: Mar 07, 2000
Date: Mar 07, 2000
Date: Mar 07, 2000
(EMWAC SMTPRS 0.83) with SMTP id" <B0001364195@smtp-in.libertybay.com>; Tue, 07 Mar 2000 09:50:09.-0800(at)matronics.com
Date: Mar 07, 2000
Date: Mar 07, 2000
Date: Mar 07, 2000
Date: Mar 07, 2000
Date: Mar 07, 2000
> > >> I searched the archives and could not find mention of the aftermarket >> aluminum landing gear by Grove Aviation and hammerhead Aviation in San >> Diego. Is anybody using them and if so what are your comments? I went down >> to see them and they both appear to be high quality. They claim same or >> better performance as steel gear, less weight, internal brake lines, and no >> need to run the fiberglass fairings because they are aerodynamically cleaner > > than the steel. >> > > >One thing that I worried about is the durability of these gear. I recall that >Van "drop tested" the RV-8 to FAR 23 standards, which is unusual for a >homebuilt. Frank doesn't think this was done with his gear. The gear have a >constant cross section rather than the taper in the normal gear, and >appear (to >me anyway) to have much less cross sectional area at the fuselage than the >steel gear. > >I am not, by any stretch of the imagination, an engineer. Maybe someone with >more background (Kevin?) could comment > Cavaet - I've got a Mechanical Engineering degree, but I've never been employed as an engineer. The following is what I've been told by guys who should know, but I've never done the calculations myself. If you want the gear to handle a certain load, steel is better than aluminum or composites, as it will be lighter. You need a much bigger piece of aluminum to handle the same load as the steel, so the aluminum gear will be heavier. The only way to make it lighter is to reduce the amount of load it has to handle. So, I suspect that the aluminum gear mentioned is weaker than Van's steel gear. This might be OK if you never do a hard landing, but I think we all do one of those every once in a while. I'm sticking with the steel gear. Now, I understand that titanium is even better than steel in this application - i.e. it would be lighter than steel for the same strength. But of course you would pay through the nose. Kevin Kevin Horton RV-8 (dimpling fuse skins) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
Date: Mar 07, 2000
Date: Mar 07, 2000
Date: Mar 07, 2000
Subject: Re: ProSeal
Date: Mar 07, 2000
Mark: Its just the stuff ya gotta use. Serioulsy, it is the same stuff that the military uses. Showed it to a guy that just got out of the AF and his first question was, "Does it smell like a sewer when you open up the can???" Of course I said "uh huh!!!" Same stuff he was familiar with. As to why Van's sells this over ProSeal, I have no idea. I will say that I had no problems with it, although you must be organized when you use it and very patient. Not bad stuff at all in my very humble opinion. Regards, Jeff Orear RV6A right wing flap and aileron. -----Original Message----- From: Mark Schrimmer <mschrimmer(at)earthlink.net> Date: Tuesday, March 07, 2000 1:37 PM Subject: RV-List: ProSeal > >I notice in Van's catalog there is some fuel tank sealant that >replaces ProSeal. The part number is MC-236-B2. Does anybody know >what this stuff is called and why Van's recommends it over ProSeal? > >Mark Schrimmer >RV-9A empennage >Irvine, CA > > ________________________________________________________________________________
Date: Mar 07, 2000
Date: Mar 07, 2000
(EMWAC SMTPRS 0.83) with SMTP id" <B0001369156@smtp-in.libertybay.com>; Tue, 07 Mar 2000 13:41:53.-0800(at)matronics.com
Date: Mar 07, 2000
Date: Mar 07, 2000
Date: Mar 07, 2000
My Airpath is mounted in the panel, on the top near the center. It was possible to swing the compass so it had no more than about 5 degrees of error, but turning on the landing light and taxi light causes 10-20 degrees of error, even though the switches and wiring runs are at the bottom of the panel. I'd certainly consider an "above the panel" location to maximize distance from the wiring runs. I believe there was a discussion of degaussing the slider roll bar within the last 3 weeks. The support rail that run forward from the center of the roll bar is stainless steel on newer RV-6's, so it shouldn't cause a problem. Tim On 6 Mar 00, at 20:47, Tom & Cathy Ervin wrote: > > List: I am going to mount my compass on the glare shield as the panel > (IFR) will be full. > My question is has anyone to date found a compass that can handle > the > magnetic interference inside the slider and be of operational use? > Anyone tried a Mooney Compass ? As we know the canopy frame work > seems to mimic the Bermuda Triangle ! > Thanks Tom in Ohio > > > > > > ****** Tim Lewis -- Springfield VA RV-6A N47TD - First Flight 18 Dec 99 TimRV6A(at)earthlink.net http://www.geocities.com/timrv6a ________________________________________________________________________________
Date: Mar 07, 2000
Subject: Navaid GPS Light
On my Navaid it is virtually impossible to see the green or yellow GPS course/heading light unless the plane is in the hanger with the door closed. Even when I cup my hand over the LED in flight, I can't tell that it is lit. Anybody else have the same problem? Tim ****** Tim Lewis -- Springfield VA RV-6A N47TD - First Flight 18 Dec 99 TimRV6A(at)earthlink.net http://www.geocities.com/timrv6a ________________________________________________________________________________
Date: Mar 07, 2000
Listers, I'm going to add my two cents on this one. I've always three pointed my RV-4. In any wind condition I use full flaps not to loose altitude but to quit flying when I get down to the runway ) and I three point land. If it's a stiff crosswind, I land on one main and the tail. I hold it there until the other main comes down. I met an old man in St. Mary's Ohio that taught flying for years and years at Ohio State. I asked him what he thought about only three pointing my RV-4 and not learning to be more proficient at wheel landings. He told me that he taught in Cessna 120's and 140's for years, and the reason why they taught wheel landings back then was because when they landed in a crosswind, they didn't have enough control over the airplane. He claimed that with an airplane like the RV-4 you had more than enough control and the idea of a safe landing was to make the airplane quit flying as soon as you could. With a three point landing you were going slower at touchdown and would be less likely to get out of shape on rollout. After 800 hrs. flying from coast to coast and in all kinds of weather, I agree with him. Jim Nolan N444JN ________________________________________________________________________________
Date: Mar 07, 2000
Subject: Bob Skinner
Hey Bob, if you're going to tour the country in your wife's Miata you should put a dependable engine in it, like a Lycoming :-) do not archive ________________________________________________________________________________
Date: Mar 07, 2000
> >Also- I have checked every local hardware store for 3/16" nuts and the smallest I can find is 1/4" before they switch over to numbers (#10, #8, ...). Have I overlooked something obvious or do I have to order the nuts directly from Van's or a different supplier? #10 is 3/16........10-32....UNF & 10-24....UNC Derek Reed ________________________________________________________________________________
Subject: Re: airflow performance - purge valve
Date: Mar 07, 2000
> > What size is the return line and can it plumb to the tank breather (WHERE TO > TIE IN). > thanks, MikeW If you haven't bought the hardware yet, you can get a copy of the recommended hook-up from Airflow Performance. The manual which comes with the system has what you need to know. The return line is -4. Don't put it to the tank vent, as you will simply pump fuel out onto the ground. Tee it into one of the lines from the tank to the selector valve. Alex Peterson ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Is anyone else getting double postings?
Today I got each posting to the list (at least) twice each. Is it my system or the list system? -- --Scott-- 1986 Corben Junior Ace N3642 RV-4 under construction (tail feathers) Gotta Fly or Gonna Die! ________________________________________________________________________________
Date: Mar 07, 2000
Subject: Re: Is anyone else getting double postings?
> >Today I got each posting to the list (at least) twice each. Is it my >system or the list system? So did I....... Have Great Day! Denny ________________________________________________________________________________
Subject: RV-4 SST Firewall cracking (240 TTAF)
Date: Mar 07, 2000
Looking for other RV-4 or RV experience with cracks in the SST firewall lower corners. On my last two annuals at (190-240 hours TTAF) I have noted vertical cracks (1.0 - 1.5" in length) in both lower corners of the SST firewall bulkhead flange, extremely hard to see!. This is the flange where the fuselage side skin and lower cowl attach hinge is. (These cracks are not in the lower corner weldments that were strenghthened some years back by Van's). The cracks appear or could have originated from the corner bend drilled relief hole in the far bottom corner of the firewall. There are also some hairline cracks appearing from the dimpled -4 rivet holes of the bottom firewall flange that gets rivetted to the fuselage belly skin. I only operate out of grass or rougher fields approx. 20% of flying time and the occasional "I have arrived flare" !!!......... When I raised the concern to Van's they commented that there is a lot of movement (side to side) at the firewall and forward fuselage area during ground operations with some airplanes showning cracking possibly in these areas and others none. I was surprised when they didn't seem concerned, and recommended sealing crack from cockpit. I recognize the firewall is essentially non structural but for future builders a local beef up may be in order. The fix to even stop drill this area is next to impossible (hidden by engine mount tube) without removing engine and engine mount!!! Any comments or experience on existing flying airplanes is most appreciated. Keith Fletcher C-FMYO (RV-4 #1219) ________________________________________________________________________________
Date: Mar 07, 2000
(EMWAC SMTPRS 0.83) with SMTP id" <B0001357597@smtp-in.libertybay.com>; Tue, 07 Mar 2000 03:40:03.-0800(at)matronics.com
Date: Mar 07, 2000
Subject: Re: NavAid Tweaking
Date: Mar 07, 2000
Date: Mar 07, 2000
Subject: Re: Old RVers fading away-short
Brian Denk wrote: >I have decided to remain on the list even though I am now one of those guys >with a flying RV. (Hallelujah!). I feel it is the least I can do to repay >all those folks who have been so patient in assisting me to achieve my dream >of RV ownership. Good for you Brian! The list lives on the contribution of others. hal ________________________________________________________________________________
Date: Mar 07, 2000
Date: Mar 07, 2000
Date: Mar 07, 2000
Subject: Old RVers fading away-short
Date: Mar 07, 2000
And my thanks also for those who provided valuable information and those who are staying around to guide us through the confusing parts .. Yes, I could just walk down to Vans, but the information provided on the list has quality and knowledge proven 100 times over. Thanks to you all. Jim Eastburn, North Plains Oregon.. ________________________________________________________________________________
Date: Mar 07, 2000
> Get 10-32 hardware store nuts. I used brass nuts just to make sure I didn't > damage the AN3 bolt threads but I don't think it is that critical. While you're at it, get a bunch of short (like 3/16" and 1/4") #6 and #8 c-sunk screws. Really handy for temporarily assembly. Saves time running screws all the way in and out, and keeps from munging up your fancy AN hardware before final assembly. Randall Henderson, RV-6 N6R (~60 hrs) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
Date: Mar 08, 2000
In a message dated 3/7/00 9:45:57 PM Pacific Standard Time, KBoatri144(at)aol.com.Tue writes: << << Today I got each posting to the list (at least) twice each. Is it my system or the list system? >> I think I got some of 'em 3 times... >> I'm getting two or three of each message also. Dale Wotring ________________________________________________________________________________
Date: Mar 07, 2000
Kevin Horton wrote: > > > > > > >> I searched the archives and could not find mention of the aftermarket > >> aluminum landing gear by Grove Aviation and hammerhead Aviation in San > >> Diego. Is anybody using them and if so what are your comments? I went down > >> to see them and they both appear to be high quality. They claim same or > >> better performance as steel gear, less weight, internal brake lines, and no > >> need to run the fiberglass fairings because they are aerodynamically cleaner > > > than the steel. > >> > > > > > >One thing that I worried about is the durability of these gear. I recall that > >Van "drop tested" the RV-8 to FAR 23 standards, which is unusual for a > >homebuilt. Frank doesn't think this was done with his gear. The gear have a > >constant cross section rather than the taper in the normal gear, and > >appear (to > >me anyway) to have much less cross sectional area at the fuselage than the > >steel gear. > > > >I am not, by any stretch of the imagination, an engineer. Maybe someone with > >more background (Kevin?) could comment > > > > Cavaet - I've got a Mechanical Engineering degree, but I've never > been employed as an engineer. The following is what I've been told > by guys who should know, but I've never done the calculations myself. > > If you want the gear to handle a certain load, steel is better than > aluminum or composites, as it will be lighter. You need a much > bigger piece of aluminum to handle the same load as the steel, so the > aluminum gear will be heavier. The only way to make it lighter is to > reduce the amount of load it has to handle. So, I suspect that the > aluminum gear mentioned is weaker than Van's steel gear. This might > be OK if you never do a hard landing, but I think we all do one of > those every once in a while. I'm sticking with the steel gear. > > Now, I understand that titanium is even better than steel in this > application - i.e. it would be lighter than steel for the same > strength. But of course you would pay through the nose. > > Kevin > Kevin Horton RV-8 (dimpling fuse skins) > Ottawa, Canada > http://members.xoom.com/kevinhorton/rv8.html > > It is my understanding that the Grove landing gear for the RV-8 (not 8A) is, in fact, a titanium gear, and thus it is supposedly just as strong as the stock steel gear while being about 12-15 lbs lighter weight. And yes, you do pay through the nose for it, about an extra $1200 or $1400 if I recall correctly. George True ________________________________________________________________________________
Date: Mar 08, 2000
I suggest those looking into titanium legs really, REALLY look into them. I intended to build my cage out of titanium in my Porsche, but after speaking to the titanium manufacturer about the properties and applications for titanium, THEY talked me out of it. It is stronger BY WEIGHT than mild steel, but in order to get the stiffness that 1.5" steel tubing offered, I needed something like 5" titanium. Also, the engineer at Titanium Industries (manufacturer) who went over my design with me said that titanium is far to springy for that sort of application. I would need bars running all over the place trying to stiffen up the design. He was quite honest with me in saying that Titanium is not suitable for that application. Now it seems to me titanium gear legs would suffer the same problems....bounce bounce bounce.......but at least fatigue shouldn't be an issue. I'm not offering engineering advice here, just passing on that which I received......so like everything else in RV's - learn about it before you buy it. Bill Rv-4 tools are here, empennage is 'in the mail' ----- Original Message ----- From: "George True" <true(at)uswest.net> Sent: Wednesday, March 08, 2000 1:34 AM Subject: Re: RV-List: RV-8QB Aftermarket landing gear > > > Kevin Horton wrote: > > > > > > > > > > > >> I searched the archives and could not find mention of the aftermarket > > >> aluminum landing gear by Grove Aviation and hammerhead Aviation in San > > >> Diego. Is anybody using them and if so what are your comments? I went down > > >> to see them and they both appear to be high quality. They claim same or > > >> better performance as steel gear, less weight, internal brake lines, and no > > >> need to run the fiberglass fairings because they are aerodynamically cleaner > > > > than the steel. > > >> > > > > > > > > >One thing that I worried about is the durability of these gear. I recall that > > >Van "drop tested" the RV-8 to FAR 23 standards, which is unusual for a > > >homebuilt. Frank doesn't think this was done with his gear. The gear have a > > >constant cross section rather than the taper in the normal gear, and > > >appear (to > > >me anyway) to have much less cross sectional area at the fuselage than the > > >steel gear. > > > > > >I am not, by any stretch of the imagination, an engineer. Maybe someone with > > >more background (Kevin?) could comment > > > > > > > Cavaet - I've got a Mechanical Engineering degree, but I've never > > been employed as an engineer. The following is what I've been told > > by guys who should know, but I've never done the calculations myself. > > > > If you want the gear to handle a certain load, steel is better than > > aluminum or composites, as it will be lighter. You need a much > > bigger piece of aluminum to handle the same load as the steel, so the > > aluminum gear will be heavier. The only way to make it lighter is to > > reduce the amount of load it has to handle. So, I suspect that the > > aluminum gear mentioned is weaker than Van's steel gear. This might > > be OK if you never do a hard landing, but I think we all do one of > > those every once in a while. I'm sticking with the steel gear. > > > > Now, I understand that titanium is even better than steel in this > > application - i.e. it would be lighter than steel for the same > > strength. But of course you would pay through the nose. > > > > Kevin > > Kevin Horton RV-8 (dimpling fuse skins) > > Ottawa, Canada > > http://members.xoom.com/kevinhorton/rv8.html > > > > > > It is my understanding that the Grove landing gear for the RV-8 (not 8A) is, in > fact, a titanium gear, and thus it is supposedly just as strong as the stock steel > gear while being about 12-15 lbs lighter weight. And yes, you do pay through the > nose for it, about an extra $1200 or $1400 if I recall correctly. > > George True > > ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Re: Compasses
>My Airpath is mounted in the panel, on the top near the center. It was >possible to swing the compass so it had no more than about 5 degrees >of error, but turning on the landing light and taxi light causes 10-20 >degrees of error...... I haven't been following this thread so delete this if it is redundant. Or if you think it's stupid. This is opinion only: I have noticed more and more, with the navigational aids we have, how little I actually use the compass while flying. If you have a DG and/or GPS, you don't really need an accurate compass. (Ouch!) (You still need a compass to be legal.) It is really for reference anyway. You establish a heading and hold that compass heading, what ever it is. Us "old guys" remember the days when that was all there was: a compass and a line on the map. It was/is your following the line on the map that had to be accurate. I still have the line, even with GPS. It's nice to know where you are. If your compass is within 5 degrees, that is close enough. You are not going to be using the compass for critical navigation when the landing/taxi light is on anyway. Mine is right upper panel (-4) and wound up pretty accurate. Your inspector is not going to ask you how accurate your compass is, only if you have one. You only have to have a compass correction card displayed to be legal; it doesn't have to be filled out (which you may not be able to do before you fly). I have seen too many compasses stuck up on the glare shield, or worse, on the canopy frame of a -4, which is a great instrument to poke your face into should you stop when you weren't planning to. Not so much a problem in a -6, but still sticking up there. In my opinion only............. Michael ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Fwd: Electric props
Gentlemen, I offer the following for those of us who were hoping for an inexpensive variable-pitch prop from the MT company: --- Eric Greindl <Eric.Greindl@mt-propeller.com> wrote: > From: "Eric Greindl" <Eric.Greindl@mt-propeller.com> > To: > Subject: Electric props > Date: Wed, 8 Mar 2000 16:44:08 +0100 > > Dear Mr. Mike Thompson, > > thank you for your e-mail dt. 07.03.2000. > > For the RV-6 with the Lyc. O-320 engine we will offer you our > electric constant speed propeler in 2-bladed version with a diameter > of 175cm (69"). > > Type: MTV-17-C/175-17d > + Spinner Assy P-470 > + Control Unit P-120-U/2700 (12VDC) > + Manifold Pressure Gauge > + Circuit Breaker > > package price US$ 9,090.00 > > Packing is included by the two blade propeller. The price for the > transportation of the prop to an Int. Airport in Texas is depending > to many things, the exchange rate, the airfreighter we use, the time > we have and the final destination. We guess that the price for > shipping and handling will be by approx. US$ 400.00 . > > You can also use our 3-bladed constant speed propeller with a > diameter of 170cm (67") > > Type: MTV-18-C/170-36a > + Spinner Assy P-469-2 > + Control Unit P-120-U/2700 (12VDC) > + Manifold Pressure Gauge > + Circuit Breaker > > package price US$ 10,970.00 > > Additional we charge you for the shipping box with US$ 200.00. The > price for the transportation is approx. US$ 500.00 to an Int. Airport > in Texas. > > The standard painting of our propellers is white with red tips or > gray with white tips, the spinner assy is painted in white. Other > colour schemes are possible but will be charged with additional US$ > 130.00. > > Prepayment and a written order is requested, our general terms of > sale apply. Prices above are valid for the next 60 days. > > Please let us know if you need any further information. > Your order is much appreciated. > > Best regards. > MT Propeller Entwicklung GmbH > > Eric Greindl > Bummer! ==== Michael E. Thompson (Grobdriver(at)yahoo.com) Austin, TX, USA RV-6 in progress, N140RV (Reserved) EX-AX1 Sub Hunter, P-3 (B/B-TACMOD/C) Orion Aircrew, PP-G,ASEL, Motorglider Driver and Unlimited Air Race Nut! ________________________________________________________________________________
Subject: Whirlwind Propellers
Date: Mar 08, 2000
I've done a "cut and paste" re: a response I received from Whirlwind concerning their three-bladed props. The response had excellent pictures, but these can't go out to the rv-list . . . so I'll just give you the verbage. Rick Jory, Highlands Ranch, CO -- Rick; Thank you for your interest in our products. I would recommend our 150 Series, in development, or our 200 Series prop. The development of the 150 Series is top priority at Whirl Wind. We are hard at work building and testing production prototypes. You can expect to see this propeller available early summer 2000. Our 150 Series is a three blade hydraulic constant speed propeller designed for the Lycoming O320 - O360 engines (150 - 200 hp). The hub assembly is CNC machined from certified aerospace aluminum alloy, shot peened and anodized. The propeller blades are similar in construction to our successful and popular 100 Series propeller which uses advanced thermoset composite materials and is equipped with a stainless steel leading edge. The 150 Series System will include: propeller, spinner, and all hardware needed for installation. Prices: TBD The 200 Series is our most popular aerobatic two-blade propeller designed for the Lycoming O360 engines (180-200 hp). This propeller delivers exceptional performance for the modern day aerobatic aircraft. The 200 Series propeller is a hydraulically controlled constant speed propeller, counter-weighted for aerobatic aircraft. The propeller is designed to go to coarse pitch in case of loss of oil pressure, decreasing the possibility of engine overspeed. Construction: The blades are constructed from compressed hardwood veneers which are then covered with a structural graphite skin. All propeller blades are equipped with a stainless steel leading edge for abrasion protection. The 200 Series is available in 76" to 78" diameters; weight is approximately 47 lbs. Pricing starts at $7500.00. Regards, Jim Rust President of Engineering Whirl Wind Propellers Corporation 1860 Joe Crosson Drive, Suite J El Cajon, CA 92020 http://whirlwindpropellers.com 1-619-562-3725 ph 1-619-562-4475 fx ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Removing plastic from sheets.
I am having much difficulty removing the white plastic that covers the wing skins. I have had these skins for several years and am now ready to finish covering the wings. Some of it is coming off slowly but lots of it is just brittle and won't peel off. I have tried heating it but no luck. (Top and Bottom). I have also heated it to melting point, scraped with wood stick and then MEK. (A mess). I am just about to the point of reordering new bottom skins. Any ideas out there? Cecil Hatfield Thousand Oaks, CA ________________________________________________________________________________
Date: Mar 08, 2000
Subject: T-34
I have been flying Cessnas and most recently a Maule. I am thinking about getting checked out in a T-34 before I fly with Mike, thinking that it might help "transition" to an RV (at least as far as handling is concerned). Opinion from those who have flown both? Chris Browne -6A finish ________________________________________________________________________________
Date: Mar 08, 2000
I am having much difficulty removing the white plastic that covers the wing skins. I have had these skins for several years and am now ready to finish covering the wings. Some of it is coming off slowly but lots of it is just brittle and won't peel off. I just went through the same scenario. What finally worked required two people. One to keep the heat gun (in this case an electric paint remover; a good hair dryer might work just as well) warming the metal just ahead of where it is being removed. The other person has to get a good grip on the edge of the plastic and pull it evenly down the skin. A little experimentation will give you the right combination of heat and muscle... Jim Wittman Mpls wings (of course) ________________________________________________________________________________
Date: Mar 08, 2000
Subject: RV-6/6A Seat Ribs
Have any other 6/6A builder's found that the F-615 (outboard) seat floor ribs are shallower by 1/8 inch than the rest of the inboard ribs? Mine are, and being anal about straightness I installed 1/8 x 1/2 x about 8 in. shims (drilled full of 3/8 holes for lightness) so that the floor panels would lay flat. Just curious. Harry Crosby -6 Finish kit ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Re: Fwd: Electric prop$
Regarding price......most manufacters quote retail pricing to protect their distribution chains.( I know, I paid about 1/2 retail for my Sensenich fixed pitch prop.) Does anyone have a relationship with a prop shop, wholesaler or distributer that would offer us or Vans a more realistic pricing structure..??? grobdriver(at)yahoo.com on 03/08/2000 11:31:42 AM Please respond to rv-list(at)matronics.com Subject: RV-List: Fwd: Electric props Gentlemen, I offer the following for those of us who were hoping for an inexpensive variable-pitch prop from the MT company: --- Eric Greindl <Eric.Greindl@mt-propeller.com> wrote: > From: "Eric Greindl" <Eric.Greindl@mt-propeller.com> > To: > Subject: Electric props > Date: Wed, 8 Mar 2000 16:44:08 +0100 > > Dear Mr. Mike Thompson, > > thank you for your e-mail dt. 07.03.2000. > > For the RV-6 with the Lyc. O-320 engine we will offer you our > electric constant speed propeler in 2-bladed version with a diameter > of 175cm (69"). > > Type: MTV-17-C/175-17d > + Spinner Assy P-470 > + Control Unit P-120-U/2700 (12VDC) > + Manifold Pressure Gauge > + Circuit Breaker > > package price US$ 9,090.00 > > Packing is included by the two blade propeller. The price for the > transportation of the prop to an Int. Airport in Texas is depending > to many things, the exchange rate, the airfreighter we use, the time > we have and the final destination. We guess that the price for > shipping and handling will be by approx. US$ 400.00 . > > You can also use our 3-bladed constant speed propeller with a > diameter of 170cm (67") > > Type: MTV-18-C/170-36a > + Spinner Assy P-469-2 > + Control Unit P-120-U/2700 (12VDC) > + Manifold Pressure Gauge > + Circuit Breaker > > package price US$ 10,970.00 > > Additional we charge you for the shipping box with US$ 200.00. The > price for the transportation is approx. US$ 500.00 to an Int. Airport > in Texas. > > The standard painting of our propellers is white with red tips or > gray with white tips, the spinner assy is painted in white. Other > colour schemes are possible but will be charged with additional US$ > 130.00. > > Prepayment and a written order is requested, our general terms of > sale apply. Prices above are valid for the next 60 days. > > Please let us know if you need any further information. > Your order is much appreciated. > > Best regards. > MT Propeller Entwicklung GmbH > > Eric Greindl > Bummer! ==== Michael E. Thompson (Grobdriver(at)yahoo.com) Austin, TX, USA RV-6 in progress, N140RV (Reserved) EX-AX1 Sub Hunter, P-3 (B/B-TACMOD/C) Orion Aircrew, PP-G,ASEL, Motorglider Driver and Unlimited Air Race Nut! ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Re: RV-6/6A Seat Ribs
HCRV6(at)aol.com wrote: >.. found that the F-615 (outboard) seat floor ribs are shallower by 1/8 inch than the rest of the inboard ribs? YES. I even bought new ones to fix the problem, but they were the same as the old ones. They seem to match the drawing dimensions. Oh well, the drawings and parts are "only for guidance" any way. Richard Reynolds, Norfolk, VA, RV-6A ________________________________________________________________________________
Date: Mar 08, 2000
Harry, This has been talked about quite a bit, and is in the archives. My solution was to split the rib horizontally and rivet a .032 x 1" patch to reassemble/extend them. Probabaly a little lighter the the 1/8 and maybe a little less work. Than again, maybe not..... Laird RV-6 22923 finishing details, details, details.... SoCal Have any other 6/6A builder's found that the F-615 (outboard) seat floor ribs are shallower by 1/8 inch than the rest of the inboard ribs? Mine are, and being anal about straightness I installed 1/8 x 1/2 x about 8 in. shims (drilled full of 3/8 holes for lightness) so that the floor panels would lay flat. Just curious. Harry Crosby -6 Finish kit ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Re: T-34
>Chris Browne wrote: > >I have been flying Cessnas and most recently a Maule. I am thinking >about getting checked out in a T-34 before I fly with Mike, thinking >that it might help "transition" to an RV ..... I probably shouldn't answer as I have never flown a T-34 but it does seem to me that it would not be much different from my Debonair. Both are straight tail Bonanza derivatives, no? I flew with Mike for 3.5 hrs in an RV6a and found it totally different from my Debonair. Easy to fly and to land but Mike had to keep after me to not flare so high. I supposed I was still flying the Deb. Maybe flying a T-34 would do more harm than good. Didn't someone suggest some time in a Grumman Tiger? If I were you, I would plan my visit to Mike to take one day but have the next day available. Spend your money on Mike and an RV6a. Hal Kempthorne - SJC RV6a N7HK at SCK Hangar K3 Debonair N6134V for sale ________________________________________________________________________________
Date: Mar 08, 2000
I had the same problem and more or less the same fix. I put the 1/8 shims only under the places where I was going to place a screw. Steve Soule Huntington, Vermont RV-6A FWF -----Original Message----- Have any other 6/6A builder's found that the F-615 (outboard) seat floor ribs are shallower by 1/8 inch than the rest of the inboard ribs? Mine are, and being anal about straightness I installed 1/8 x 1/2 x about 8 in. shims (drilled full of 3/8 holes for lightness) so that the floor panels would lay flat. Just curious. ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Re: T-34
>I have been flying Cessnas and most recently a Maule. I am thinking >about getting checked out in a T-34 before I fly with Mike, thinking >that it might help "transition" to an RV (at least as far as handling is >concerned). Opinion from those who have flown both? RV's fly better. I wouldn't, however, pass up a chance to scoot around in a -34. If you have a chance to fly the Ironhorse, the P-51, that may be more like what you are building. Someone also mentioned the F-4U Corsair. Seriously, a -34 may help give you the feel, but the RV is more responsive (not sensitive) and has better control harmony. You will drop right in to how the RV feels compaired to other mounts, no problem. Michael ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Drilling and speeds
> Steve Judd asked: > >2) As a practical matter, how important are RPMs for drilling aluminum? Someone suggested that aluminum likes high speed drills. More correctly might be to say that small bits like high speeds. The cutting edge on #30 bit is making a much slower speed over the aluminum than a 1/2 inch bit. The larger the bit the slower you need to turn it. Slow way down for the fly cutter! Generally, the harder the material, the slower the speed of the edge needs to be. Here are a few speed recommendations from an old handbook: Annealed 4340 steel 60 feet/minute Stainless 410 30 " Aluminum alloys 250 " So, aluminum likes the high speed drill. How fast does a #30 have to turn (RPMs) to achieve this 250 fpm value? Cutting too slowly is not harmful but too fast is. Slow drills only hurt productivity. Also, the recommended coolant for aluminum is water based solutions. Milk? I believe many who complain of non-round holes are feeding too fast. Feed (pushing the drill into the work) is given in inches per revolution. If one pushes a slow drill as hard as a fast one, the feed will be faster. Feed for aluminum should be 0.007 ipr and steels about one fourth that. >8) Harbor Freight sells a DeVilbiss compressor Are these the non piston super noisy screamers that drown out the jet traffic? hal ________________________________________________________________________________
Date: Mar 08, 2000
Subject: ready to buy some tools
I am about to buy the following Delta power tools: Delta Model # Bench Grinder 23-580 or 23-660 Bench top Bandsaw(10" reach) 28-160 Belt/Disc sanding station 31-280 Stand-up Drill Press 17-900 I am pretty set on using Delta because of the quality and longevity that my father and other family members have experienced with their woodworking equipment. I found a source on the web at a place called Tools Plus ( http://www.tools-plus.com/toolsplus/ ) The prices are significantly better than Home Depot special order but I was wondering if anybody knows of a cheaper source for Delta. Thanks, Scot sstambaugh(at)qualcomm.com ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Re: T-34
--- Chris Browne wrote: > > I have been flying Cessnas and most recently a Maule. I am thinking > about getting checked out in a T-34 before I fly with Mike, thinking > that it might help "transition" to an RV (at least as far as handling > is > concerned). Opinion from those who have flown both? No comparison, IMO. Any T-34 you fly as civilian has a series of bungees in the control system to limit roll rate - at least that was the way the military released them... :) I have flown both and the RV handles much better. But then we could fly the -34 with the canopy slid back. :) Save the money and put it in your airplane! Mike Thompson Austin, TX -6 N140RV (Reserved) Wings ________________________________________________________________________________
Date: Mar 08, 2000
Bill: Where did Bob get his compass and what did it cost???Jim Brown,NJ, RV-3&4 ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Re: T-34
I have owned both a Grumman Tiger (AA5-A) & a Bonanza (B-35). The ground handling of the Tiger is most like the RV due to the free castering nose wheel ( and you can turn your airplane around within its wingspan...) Control harmony & ballance would be more akin to my B-35 Bonanza. All in all I would get time in the Tiger/Cheetah/Traveler to get the most bang for the buck if cross training is in your sights. Otherwise save your cash & join up with mike Seager while he is in route somewhere & get the real thing. Sorta like virtural sex vs. real sex. kempthorne(at)earthlink.net on 03/08/2000 01:03:46 PM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: T-34 >Chris Browne wrote: > >I have been flying Cessnas and most recently a Maule. I am thinking >about getting checked out in a T-34 before I fly with Mike, thinking >that it might help "transition" to an RV ..... I probably shouldn't answer as I have never flown a T-34 but it does seem to me that it would not be much different from my Debonair. Both are straight tail Bonanza derivatives, no? I flew with Mike for 3.5 hrs in an RV6a and found it totally different from my Debonair. Easy to fly and to land but Mike had to keep after me to not flare so high. I supposed I was still flying the Deb. Maybe flying a T-34 would do more harm than good. Didn't someone suggest some time in a Grumman Tiger? If I were you, I would plan my visit to Mike to take one day but have the next day available. Spend your money on Mike and an RV6a. Hal Kempthorne - SJC RV6a N7HK at SCK Hangar K3 Debonair N6134V for sale ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Re: T-34
Chris I've got a little time in a 300hp T34. It's a great ride but it doesn't fly anything like an RV. It's fast and aerobatic but the controls are heavy compared to the RV. Like Hal said, I would get some time with Mike Seager. Also some Citabria time might be helpful. Cash Copeland RV6 wiring and systems In a message dated 3/8/00 5:16:20 PM GMT Standard Time, cebrowne(at)earthlink.net writes: << I have been flying Cessnas and most recently a Maule. I am thinking about getting checked out in a T-34 before I fly with Mike, thinking that it might help "transition" to an RV (at least as far as handling is concerned). Opinion from those who have flown both? Chris Browne -6A finish >> ________________________________________________________________________________
Subject: Re: T-34
Date: Mar 08, 2000
Chris, IMHO, if you can fly an airplane, any airplane, you can fly (and will love) an RV. *Legal disclaimer: Us mighty tail wheelers recommend any and all tricyclers stay away from transitioning to tail wheeling. It is just Too Dangerous, and requires super human skills beyond that of mere mortals. Chuck ________________________________________________________________________________
Subject: aerobatic instruments
Date: Mar 08, 2000
Can anyone out there advise on which brand of electric turn co-ordenator and A.H. instruments are best suited for aerobatics. Many thanks LLOYD BENTLEY RV6 FUSE. SOUTH AFRICA. ________________________________________________________________________________
From: "Sally and George" <aeronut58(at)hotmail.com>
Subject: Re: Removing plastic from sheets.
Date: Mar 08, 2000
CECIL: HEAT THE PLASTIC WITH A HAIR DRYER & IT'LL PEEL RIGHT OFF. GEORGE KILISHEK RIGGING CONTROLS ----- Original Message ----- From: <cecilth(at)juno.com> Sent: Wednesday, March 08, 2000 8:53 AM Subject: RV-List: Removing plastic from sheets. > > I am having much difficulty removing the white plastic that covers the > wing skins. I have had these skins for several years and am now ready to > finish covering the wings. Some of it is coming off slowly but lots of it > is just brittle and won't peel off. I have tried heating it but no luck. > (Top and Bottom). I have also heated it to melting point, scraped with > wood stick and then MEK. (A mess). I am just about to the point of > reordering new bottom skins. > Any ideas out there? > Cecil Hatfield > Thousand Oaks, CA > > > > > > ________________________________________________________________________________
Subject: Andair Fuel Valve - Installation
Date: Mar 08, 2000
Hello Fellow Builders: I'm about to install my shiny new Andair valve. Van's say they've never installed one themselves & can't offer any help! I was wondering if anyone had any tips? Did you install a doubler plate? It seems that the brace that's included in the kit for Van's brass valve won't be needed. With a bit of luck I can squeeze the Airflow performance pump into the same space... Thanks, Phil, 80691 ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Re: Whirlwind Propellers
> > >Prices: TBD >The 200 Series is our most popular aerobatic two-blade propeller designed >for the Lycoming O360 engines (180-200 hp). >This propeller delivers exceptional performance for the modern day aerobatic >aircraft. The 200 Series propeller is a hydraulically controlled constant >speed propeller, counter-weighted for aerobatic aircraft. The propeller is >designed to go to coarse pitch in case of loss of oil pressure, decreasing >the possibility of engine overspeed. > One comment for those considering a Whirlwind prop: Based on the above, it seems that the 200 series is designed as an aerobatic prop. I'm not sure what mission the other models will be designed for. Prop blades are twisted, because the angle of the relative wind hitting the prop varies with the distance from the hub (the angle being measured with respect to the plane of rotation of the prop. Any particular distribution of twist along the blade is really only the optinum at a small number of conditions. So, depending on what mission the designer has in mind, he will chose the twist to give best performance at that condition, and acceptable performance at other conditions that he cares about. An aerobatic prop is probably optimized for best performance at low speed, high rpm, and high power. This would probably make it a very good take-off and climb prop, but it may not be as efficient as some other props at high speed, medium power, medium rpm cruise conditions. So, you might spend more money, and end up losing a few knots cruise speed. I would be tempted to stick with Van's recommended Hartzells, unless someone else has already used a particular C/S prop, and you are happy with the performance that he is reporting. Kevin Horton RV-8 (dimpling fuse skins) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
Subject: Re: Andair Fuel Valve - Installation
Date: Mar 08, 2000
Phil, I installed my Andair valve in my -6 per plans. Used the same center console parts from the kit & drilled three holes in the top for #10 screws that mounts the valve. I also have the facet electric pump mounted underneath on the inside wall of the console leg. Makes for a compact installation. Rick Caldwell -6 29.9 hrs Melbourne, FL >I'm about to install my shiny new Andair valve. Van's say they've never >installed one themselves & can't offer any help! I was wondering if anyone >had any tips? Did you install a doubler plate? It seems that the brace >that's included in the kit for Van's brass valve won't be needed. With a >bit >of luck I can squeeze the Airflow performance pump into the same space... > >Thanks, > >Phil, 80691 > > ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Subject: Re: Drilling and speeds
Date: Mar 08, 2000
-----Original Message----- From: Hal Kempthorne <kempthorne(at)earthlink.net> Date: Wednesday, March 08, 2000 1:30 PM Subject: RV-List: Drilling and speeds > > >> Steve Judd asked: >> >>2) As a practical matter, how important are RPMs for drilling aluminum? > >>Here are a few speed recommendations from an old handbook: > > Annealed 4340 steel 60 feet/minute > Stainless 410 30 " > Aluminum alloys 250 " > >So, aluminum likes the high speed drill. How fast does a #30 have to turn >(RPMs) to achieve this 250 fpm value? >hal The #30 drill must turn at 7600 RPM to achieve a SFPM of 250. Dennis Persyk 6A finishing kit Hampshire, IL C38 ________________________________________________________________________________
Date: Mar 08, 2000
The problem occurs when you trim the front flange of the rib to fit it between the front and rear spars. That slides the slope forward, opening about a 1/8" gap. Since the rear flange is already bent the natural inclination is to trim the front. I did it too, made a 1/8" spacer and moved on. Regards, Greg Young - Houston (DWH) RV-6 N6GY (assigned) 90% done, 90% to go "Always do right- this will gratify some and astonish the rest." - Mark Twain (1835-1910) > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of HCRV6(at)aol.com > Sent: Wednesday, March 08, 2000 11:42 AM > To: 'rv-list(at)matronics.com' > Subject: RV-List: RV-6/6A Seat Ribs > > > Have any other 6/6A builder's found that the F-615 (outboard) > seat floor ribs > are shallower by 1/8 inch than the rest of the inboard ribs? > Mine are, and > being anal about straightness I installed 1/8 x 1/2 x about 8 in. shims > (drilled full of 3/8 holes for lightness) so that the floor > panels would lay > flat. Just curious. > > Harry Crosby > -6 Finish kit > > ________________________________________________________________________________
Date: Mar 08, 2000
Cecil, Until last week, I couldn't understand the grumbling about removing the plastic covering. Now I feel your pain. My kits all had the clear plastic and it peeled off relatively easily. That is until I tried to use some old trim stock that had that gawd awful white plastic. I managed to gingerly prod and cajole it from one side but the biggest piece I could get from the other side was 1/4" square. I wound up grinding it off with a Scotchbrite wheel. I hope someone has an aluminum-safe solvent to disolve it, otherwise I'd consider them scrap. In your case it might be an excuse to pop for 1-piece skins. Regards, Greg Young - Houston (DWH) RV-6 N6GY (assigned) 90% done, 90% to go "Always do right- this will gratify some and astonish the rest." - Mark Twain (1835-1910) > I am having much difficulty removing the white plastic that covers the > wing skins. I have had these skins for several years and am now ready to > finish covering the wings. Some of it is coming off slowly but lots of it > is just brittle and won't peel off. I have tried heating it but no luck. > (Top and Bottom). I have also heated it to melting point, scraped with > wood stick and then MEK. (A mess). I am just about to the point of > reordering new bottom skins. > Any ideas out there? > Cecil Hatfield > Thousand Oaks, CA ________________________________________________________________________________
Date: Mar 08, 2000
Subject: RV 6/6A tail and wing kit
Looking for a 6/6A project. I'm in Ohio. Joe. ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Non-threaded angle drill?
The subject line says it all. Does such a beast exist and, if so, where can I get one? The collets that Avery's sells are only for two specific size drill bits (3/32 & 1/8), but I want to use my Unibit in an angle drill. Is this possible? I can't be the first guy to want to do this... :-) Regards, Ken Balch Ashland, MA RV-8 #81125 wings, wings, wings... ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Four Freshly Overhauled O-320 Engines For Sale...
Hi Listers, I'm posting this for my friend Don. He would like to sell the following four Lycoming 0-320's which are fresh overhauls with accessories and priced right... 1. O-320 E2A 2. O-320 E3D 3. O-320 D2G (160 H.P.) 4. O-320 B1A These engines are perfect for RV's! Don is currently building my 0-320 E2D for my RV-8 and has built an 0-320 E2D for my fathers RV-6 which runs very nice. Don does excellent work. If interested please call: Don Swords A&P, IA Don's Dream Machines Griffin, Georgia Phone: 770-412-8885 ________________________________________________________________________________
Date: Mar 08, 2000
Gregory Young wrote: > > The problem occurs when you trim the front flange of the rib to fit it > between the front and rear spars. That slides the slope forward, opening > about a 1/8" gap. Since the rear flange is already bent the natural > inclination is to trim the front. I did it too, made a 1/8" spacer and moved > on. Ah, but this is not so. No matter how much you trim the front of the rib, it's placment for/aft is set by the aft flange and its position on the rear spar carry through. The real reason is that the rib needs to be curved outward just like the upper longeron and armrest rib. Most people miss this fact and put the rib in straight. The curved rib would need no shims as it becomes shorter. Gary Zilik RV-6A N99PZ - 15.7 hrs and climbing. > > > Regards, > Greg Young - Houston (DWH) > RV-6 N6GY (assigned) 90% done, 90% to go > > "Always do right- this will gratify some and astonish the rest." - Mark > Twain (1835-1910) > > ________________________________________________________________________________
Date: Mar 08, 2000
Subject: microsoft flight simulator
can some one tell me the web site that i can get the rv-6 for the flight simulator thanks Bill ________________________________________________________________________________
Date: Mar 08, 2000
Phil, I fabricated a new bracket that is wide enough to handle the Andair fuel valve. I made mine out of .040" material I think. Similar in appearance to Van's original, just wider and a bit thicker. Instead of riveting the bracket in place, I chose to make it removable with the selector valve attached to it. Makes servicing and installation easier. I fabricated and riveted a couple of tabs to where the original bracket would normally go. These tabs were made from some .063 stock. I put some #6 nutplates behind them and countersunk the holes in the bracket. Now the whole works it's fully removable and serviceable. Lastly, with service in mind, I cut the hole in the sheet metal cover plate that goes over the whole works the same size as the bezel on the Andair selector so I can just remove the screws from the sheet metal and lift it off to inspect/repair any plumbing problems. No need to remove the handle or mounting screws on the Andair valve to get the cover off. Hope this helps, -Don RV8 NJ ________________________________________________________________________________
Date: Mar 08, 2000
Subject: FACET electric fuel pump
Listers: A friend of mine, who doesn't have a PC or access to the internet and building his 8th project from scratch (a sidewinder) asked me to seek an answer to a question that has come up. He is installing a FACET electric fuel pump between the fuel selector value and carburator which he is planning to use as a boost pump for starting and during take offs and landings, etc. and has been told that when turned off will cut off fuel flow when it is shut off. If this is the case he is thinking of plumbing a by-pass for times when the boost is shut off with a back flow preventer when the boost in on. Is there anyone out there who can shed some light or advice on this that I can pass on. Many thanks for your expertise. Bud West rv-6 tail feathers ________________________________________________________________________________
Subject: Re: Torquing Hartzell C/S Prop
Date: Mar 08, 2000
Another way is to use a 3/4 inch open end wrench with the torque wrench in the other end 90 degrees to the handle of your wrench. This will torque to a value very close to the setting you have set on your torque wrench. I am uncomfortable using anything but a rigid frame click type and one that has been calibrated recently for something as critical as the prop and observe the correct pattern for tightening. Eustace Bowhay Blind Bay, B.C. -----Original Message----- From: Chuck Brietigam <brietigam(at)earthlink.net> Date: Monday, March 06, 2000 3:49 PM Subject: Re: RV-List: Torquing Hartzell C/S Prop > >Dennis Persyk wrote: > >> >> I am finding it difficult to get the Hartzell C/S prop torqued to the 60-70 >> ft-lb value. I have tried two different crow's feet and still can't get >> even a small-headed Snap-On torque wrench to clear the ________________________________________________________________________________
Subject: Re: Fuel Pressure Problem?
Date: Mar 08, 2000
Andy: A bit late on this so you may have already solved the problem. A couple more suggestions. If you can hook up a direct reading gauge this would settle the possibility of an instrument problem. Unhook your fuel line at the carb. and run a fuel flow test using your boost pump. It could easily be your engine driven pump. We have had some brand new pumps act in a similar manner lately. If it is actually putting out 9 lbs occasionally as you say the max pressure for you carb is 8 lbs and min is 1/2 lb. Normally it should run steady at somewhere between 4.5 and 5.5 on your engine driven pump. Let us know how you are making out. Eustace Bowhay Blind Bay B.C. -----Original Message----- From: Andy <winterland(at)rkymtnhi.com> Date: Saturday, March 04, 2000 2:28 PM Subject: RV-List: Fuel Pressure Problem? > >Can someone help diagnose a fuel pressure problem on a 6A with an carbureted >0-360. > >The indicated pressure has always hovered smoothly right around 9 ________________________________________________________________________________
Subject: Remote Sensing Compass (was Compass For RV6-A) long
Date: Mar 08, 2000
> > Bill: Where did Bob get his compass and what did it cost???Jim Brown,NJ, > RV-3&4 Jim and all, The compass that Bill Von Dane mentioned is a Ritchie M-2 remote sensing compass designed for marine applications. I first saw one installed in an RV on someone's web site last year and I am sorry I don't remember the man's name or URL. I got the system to replace a PAI-700 vertical card compass that I could not get to work properly where it was installed in my instrument panel. I had done some testing with the instrument panel on the work bench. It worked on the bench but not in the airplane, even with the super-duper compensating balls. My experience with remote sensing compass is limited to only three flights, so far. I am very pleased with the way it operates and its accuracy( less than 5 deg error). Although the compass is digital, the display is a DG type instrument connected by 20' of cable to a sensing unit. The display is very steady like a DG, even in moderate turbulence. The sensing unit is approx 3"wide x 4" long x 2.5" . Its internal workings are gimbaled to provide accurate readings in up to 45 deg of pitch and roll. The whole system weighs 27 ounces, if I recall correctly. I have the small display which at 2.125" inches is slightly smaller than than the 2.25" stardard small instrument hole. The smallest increment on the compass card is 5 degress. It takes 12v to operate and is internally lit. A 3.375" display is also available. Installation is simple. The sensing unit could easily fit into a wing tip or behind a baggage compartment. Mine is temporarily installed (read duct taped) in my RV-6 behind my seat, forward of the flap actuator tube. The only possble impediment I see to a "no-brainer" installation is the cable fitting that plugs into the sensing unit. The plug, 1"+ wide, will not fit through a "standard" wiring run grommet. So, there will be some head scratching to do over that. A downside to some may be that the display card is blue with white numerals. Bill says he likes the way it looks while I am still getting used to it. It is definitely not for purists. But, if you value function over form, it is worth considering. I bought mine from West Marine for $149.95 plus shipping. You can get info and pictures at www.westmarine.com and www.ritchienavigation.com The ultimate question, would I do it again? Yes, but I'm simple minded and cheap. Bob Hall RV-6, Colorado Springs (VFR, no-gyro panel except for turn coordinator) ________________________________________________________________________________
Subject: Re: FACET electric fuel pump
Date: Mar 09, 2000
> >Listers: > >A friend of mine, who doesn't have a PC or access to the internet and >building his 8th project from scratch (a sidewinder) asked me to seek an >answer to a question that has come up. He is installing a FACET electric >fuel pump between the fuel selector value and carburator which he is planning >to use as a boost pump for starting and during take offs and landings, etc. >and has been told that when turned off will cut off fuel flow when it is shut >off. If this is the case he is thinking of plumbing a by-pass for times when >the boost is shut off with a back flow preventer when the boost in on. Is >there anyone out there who can shed some light or advice on this that I can >pass on. Many thanks for your expertise. > >Bud West >rv-6 tail feathers > Not true. I had a Facet pump between the fuel selector valve and the engine pump. Only used it on take off and landings. The rest of the time it easily passed all the fuel needed. John Ammeter 1975 Jensen Healey RV-6 (sold 4/98) EAA Technical Counselor NRA Life Member ICQ#48819374 ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Re: ready to buy some tools
Scot, You might want to check out Toolcrib of the North. They seem to have the cheapest tools that I can find. I believe that they are now sold through Amazon.com. http://www.toolcribofthenorth.com Ray Murphy Scot Stambaugh wrote: > > I am about to buy the following Delta power tools: > Delta Model # > Bench Grinder 23-580 or 23-660 > Bench top Bandsaw(10" reach) 28-160 > Belt/Disc sanding station 31-280 > Stand-up Drill Press 17-900 > > I am pretty set on using Delta because of the quality and longevity that my > father and > other family members have experienced with their woodworking equipment. I > found a source > on the web at a place called Tools Plus ( > http://www.tools-plus.com/toolsplus/ ) The prices are significantly better > than Home Depot special order but I was wondering if anybody knows of a > cheaper source for Delta. > > Thanks, > > Scot > sstambaugh(at)qualcomm.com > ________________________________________________________________________________
Date: Mar 09, 2000
Subject: Re: Non-threaded angle drill?
In a message dated 3/8/00 7:00:57 PM Eastern Standard Time, Kbalch1(at)aol.com writes: << The subject line says it all. Does such a beast exist and, if so, where can I get one? The collets that Avery's sells are only for two specific size drill bits (3/32 & 1/8), but I want to use my Unibit in an angle drill. Is this possible? I can't be the first guy to want to do this... :-) Regards, Ken Balch >> YES!! I got mine last weekend at Northern Tools and Equipment for $28. It is a "3/8" Angle Drill Attachment" Item number 153890. Northern has stores in Minnesota, Iowa, Wisconsin, Florida, Texas, Tennesee, Virginia, South Carolina, North Carolina, and Georgia. The only mailing address I have is PO Box 1219, Burnsville Minnesota 55397. I don't have a URL or phone number. The 90 degree angle attachment is 3.75 inches from the tip of the chuck to the back of the assembly. It is a bit bigger than the plastic 90 degree unit I got from Avery (the one that uses the threaded bits). The unit itself looks sturdy, with a conventional chuck and all metal construction. As an aside, I don't know what it is about those threaded bits, but I broke several of them in no time. Worse, you've gotta call a specialty tool house to get more... Good luck locating a Northern outlet, Kyle Boatright ________________________________________________________________________________
Date: Mar 08, 2000
... > Not true. I had a Facet pump between the fuel selector valve and the > engine pump. Only used it on take off and landings. The rest of the > time it easily passed all the fuel needed. Well, it MIGHT be true.... he should make sure he's using the same model pump that Vans sells for use on RVs. There may be some models that do in fact have that characteristic. Randall Henderson, RV-6 N6R (~60 hrs) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
Date: Mar 09, 2000
Does the Facet fuel pump us AN fittings? I see Napa auto stores sell the Facet elec. fuel pump. Is it different than what Van sells? John Danielson ________________________________________________________________________________
Date: Mar 09, 2000
In a message dated 3/8/2000 12:40:54 PM Central Standard Time, pcondon(at)csc.com writes: << Regarding price......most manufacters quote retail pricing to protect their distribution chains.( I know, I paid about 1/2 retail for my Sensenich fixed pitch prop.) Does anyone have a relationship with a prop shop, wholesaler or distributer that would offer us or Vans a more realistic pricing structure..??? >> team rocket is a OEM for MT props. You might want to give mark fredricks a call. They the 3 bladed areobatic prop for 9000 i believe. Its on their website if anyone is interested. www.teamrocketaircraft.com chris WIlcox f-1 rocket ________________________________________________________________________________
Date: Mar 09, 2000
Subject: Re: aerobatic instruments
> Can anyone out there advise on which brand of electric turn co-ordenator and > A.H. instruments are best suited for aerobatics. > > Many thanks LLOYD BENTLEY RV6 FUSE. SOUTH AFRICA. Good question. I was planning on installing an eletric AI (AH) too. I had been thinking that if I installed a switch, I could turn in off for aeribatics and perhaps even most VFR flights to conserve its life. This may not be the best solution, though. any comments out there? Dave Leonard RV-6, Mazda 13B ________________________________________________________________________________
Date: Mar 09, 2000
Subject: Re: T-34
> The T-34B > is a dog, performance wise (if I remember right it has a 225 hp engine) > and is Heavy. I trained in the T-34C and the two aircraft are light > years apart. > I agree, the T34C is absolutely fantastic with light and crisp controls. It of course easily outperforms even lancair 360's. On the other hand, it costs 1.3mil, burns 20+ gal/hr and requires a professional crew to keep it maintained. I felt that it handled very similar (although slightly better than) the RV-8A. There are a few of the 'Charlies' that are privately owned, if you get a chance, fly one. Haven't flown the 'Bravo' yet. Dave Leonard ________________________________________________________________________________
Date: Mar 09, 2000
Subject: Re: Ok, now >I'VE< gone and done it
Appreciate the feelings of the unknown. Took the first plunge like so many others with emph delivery yesterday. May wife kept saying, c'mon to bed, you've got to go to work in the morning. Good luck. We're probably gonna need it. Bldg 81220==Skid ________________________________________________________________________________
Date: Mar 09, 2000
In a message dated 3/8/2000 7:13:30 PM Eastern Standard Time, bcbraem(at)home.com.with.ESMTP writes: > US Industrial sells a 1/4"x28 threaded cone collet/chuck that will take > your 1/4" Unibit shank. Part# TP57 $26.00 > > Boyd Thanks, that's exactly what I needed. It's ordered and on its way. Ken ________________________________________________________________________________
Date: Mar 09, 2000
In a message dated 3/9/2000 12:26:03 AM Eastern Standard Time, KBoatri144(at)aol.com writes: > YES!! I got mine last weekend at Northern Tools and Equipment for $28. It is > a "3/8" Angle Drill Attachment" Item number 153890. Northern has stores in > Minnesota, Iowa, Wisconsin, Florida, Texas, Tennesee, Virginia, South > Carolina, North Carolina, and Georgia. The only mailing address I have is > PO > Box 1219, Burnsville Minnesota 55397. I don't have a URL or phone number. > > The 90 degree angle attachment is 3.75 inches from the tip of the chuck to > the back of the assembly. It is a bit bigger than the plastic 90 degree > unit > I got from Avery (the one that uses the threaded bits). The unit itself > looks sturdy, with a conventional chuck and all metal construction. > > As an aside, I don't know what it is about those threaded bits, but I broke > several of them in no time. Worse, you've gotta call a specialty tool house > to get more... > > Good luck locating a Northern outlet, > > Kyle Boatright Thanks, Kyle. I just ordered something similar from US Tool. No delicate little threaded bits for me! :-) Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Date: Mar 09, 2000
Subject: Re: microsoft flight simulator
> can some one tell me the web site that i can get the rv-6 for the flight > simulator > thanks Bill Bill, Go to Hanger X, you can download the file from there. Go to http://home.att.net/~david2.koelzer/hangarx/index.html Charlie Kuss RV-8 ________________________________________________________________________________
Date: Mar 09, 2000
Kbalch1(at)aol.com wrote: > > The subject line says it all. Does such a beast exist and, if so, where can > I get one? The collets that Avery's sells are only for two specific size > drill bits (3/32 & 1/8), but I want to use my Unibit in an angle drill. Is > this possible? I can't be the first guy to want to do this... :-) > > Regards, > Ken Balch > Ashland, MA > RV-8 #81125 > wings, wings, wings... > Ken, Cleaveland has chuck that will accept 1/16 - 1/4 inch bits, including the smaller unibits. I use the heck out of mine - wish I had ordered it sooner. Chris Browne -6A finish Atlanta ________________________________________________________________________________
Date: Mar 09, 2000
About using Unibits and big diameter drills. I would like to suggest and alternative because the use of a Unibit in a delicate angle drill might hasten the demise of that angle drill. Unibits are unbalanced drills. they have only one cutting edge. The opposite action is curtailed by the round body of the drill in the hole. This has much friction and aluminum is very sticky. Added to this is the increased diameter leverage. I takes a lot more to rotate a 1/4" bit vs. a 1/8". I believe twice the dia. is the square of the torque. Then go to 1/2" square again. I been cheap so far. I've been using an angle grinder w/collets for 1/8" and 3/32". This sometimes has trouble turning the 1/8" when it is in the hole to start. This will never rotate a Unibit doing any work. What it does do good, it does it around 20,000rpm. What it does drill it does it fast. A suggestion, I have used a burr to make all sorts of shaped holes. Either with straight or angle drills. If you have only a few to do this might be the way. I also use a burr to trim corners and edges in assembly when it is impractical to remove the parts or just can't do it any other way. Burrs are better than stones because they don't clog but work the same only much faster. Good Luck Cheap suggestions are sometimes what they are worth. Bill Jaugilas Kbalch1(at)aol.com wrote: > > In a message dated 3/8/2000 7:13:30 PM Eastern Standard Time, > bcbraem(at)home.com.with.ESMTP writes: > > > US Industrial sells a 1/4"x28 threaded cone collet/chuck that will take > > your 1/4" Unibit shank. Part# TP57 $26.00 > > > > Boyd > > Thanks, that's exactly what I needed. It's ordered and on its way. > > Ken > ________________________________________________________________________________
Date: Mar 09, 2000
In a message dated 3/9/2000 8:44:21 AM Eastern Standard Time, jaugilas(at)allways.net writes: > About using Unibits and big diameter drills. > > I would like to suggest and alternative because the use of a Unibit in a > delicate angle drill might hasten the demise of that angle drill. > > Unibits are unbalanced drills. they have only one cutting edge. The opposite > action is curtailed by the round body of the drill in the hole. This has > much > friction and aluminum is very sticky. > > Added to this is the increased diameter leverage. I takes a lot more to > rotate a 1/4" bit vs. a 1/8". I believe twice the dia. is the square of the > torque. Then go to 1/2" square again. > > I been cheap so far. I've been using an angle grinder w/collets for 1/8" and > 3/32". This sometimes has trouble turning the 1/8" when it is in the hole to > start. This will never rotate a Unibit doing any work. What it does do good, > it does it around 20,000rpm. What it does drill it does it fast. > > A suggestion, I have used a burr to make all sorts of shaped holes. Either > with straight or angle drills. If you have only a few to do this might be > the > way. I also use a burr to trim corners and edges in assembly when it is > impractical to remove the parts or just can't do it any other way. > Burrs are better than stones because they don't clog but work the same only > much faster. > > Good Luck > Cheap suggestions are sometimes what they are worth. > > Bill Jaugilas Hi Bill, Thanks for the alternative idea. I ordered the collet chuck this morning and will see how it works out. I only need to drill a few holes with this method (angle drill w'unibit), so I'm hoping I can get away with it. Buying a few burrs is probably a good idea anyway, since I'm sure I'll use them sooner or later. Regards, Ken Balch Ashland, MA RV-8 #81125 wings ________________________________________________________________________________
Date: Mar 09, 2000
<< Kbalch1(at)aol.com >> Ken, I made an adapter to do this. Give me a call 817-439-3280.....George Orndorff ________________________________________________________________________________
Date: Mar 09, 2000
Subject: Fuselage Jig Available for 6
I'm putting the fuselage on its tires today. Have a wooden jig available to a good home. Located in Hoopeston, Illinois, 150 miles south of Chicago along the Illinois and Indiana borders. The frame will split in the middle for easier transportation. Dan DeNeal ________________________________________________________________________________
Subject: Wiring of Flasher (Wig Wag)
Date: Mar 09, 2000
Recently someone posted their wiring for the Gall's flasher unit. I can't seem to find this posting. Could you send this to me off line. Thanks in advance. Also, where did you locate (install) this unit. rickjory(at)msn.com Rick Jory ________________________________________________________________________________
Date: Mar 09, 2000
Subject: NavAid Tweaking
Can the NavAid be connected direct to a late model handheld GPS such as Lowrance or is a coupler necessary? Have a great day! Denny ________________________________________________________________________________
Subject: Morris RV Breakfast 3-5-00
Date: Mar 09, 2000
Last Sunday a bunch of RV's the Chicago/Indianapolis area showed up for breakfast at Morris, IL. We haven't heard much from the Midwest group lately since those folks in the south/southwest and Denver have been agressive in getting their planes in the air . Check out some pics of the Morris gathering here: http://mnellis.jnet.net/rv-6_page/morris.htm Mike & Beth Nellis RV6 N699BM (res), Plainfield, IL http://mnellis.jnet.net/rv-6_page name="Morris RV Breakfast 3-5-00.url" filename="Morris RV Breakfast 3-5-00.url" [DEFAULT] BASEURL=http://mnellis.jnet.net/rv-6_page/morris.htm [InternetShortcut] URL=http://mnellis.jnet.net/rv-6_page/morris.htm Modified ECF9BCD889BF01E2 ________________________________________________________________________________
Date: Mar 09, 2000
Subject: Newbe with ambitions...
Hello, list and people. Just joined today. I have a question - I'm looking for as much information as possible comparing the Zlin Aerobatic trainers with either the RV-6A or the RV-8A (even though the side-by-side sitting of the Zlin is more similar to the 6A than the 8A). Another thing - did any of you people (are you all guys, or are there some girls also among RV builders?) contemplate installing the Dynacam engine, as it became certified now? Also, what a prop will you fit to such a monster of an engine (525 ft - lbs, 200 HP @ 2000 rpm max, 650 ft - lbs, 175 HP @ 1600 rpm cruise) for simple aerobatics? Thank you all. Ronen. ________________________________________________________________________________
Subject: Re: Fuselage Jig Available for 6
Date: Mar 09, 2000
Dan, I'm located here in Plainfield, IL and I'd be very interested in your jig if it's still avaliable. Mike & Beth Nellis RV6 N699BM (res), Plainfield, IL http://mnellis.jnet.net/rv-6_page ----- Original Message ----- From: Dan DeNeal <rv6apilot(at)yahoo.com> Sent: Thursday, March 09, 2000 08:08 AM Subject: RV-List: Fuselage Jig Available for 6 > > I'm putting the fuselage on its tires today. Have a > wooden jig available to a good home. Located in > Hoopeston, Illinois, 150 miles south of Chicago along > the Illinois and Indiana borders. > > The frame will split in the middle for easier > transportation. > > Dan DeNeal > > ________________________________________________________________________________
From: "Gardner, Douglas (GA01)" <douglas.gardner(at)honeywell.com>
Subject: RV-8 Canopy Attachment
Date: Mar 09, 2000
Hello RV listers, especially -8 builders, I've been doing alot of research on the canopy attachment methods that builders have used to attach the 801 canopy, and the WD819 frame intersection. From what I hear the real problem comes from the "squeeze" stress that pulled rivets cause, which tend to fracture the plexi, especially when the 2 parts are not at an exact 90 deg fit. In Jeff Ludwigs -8 he drilled and tapped most of the attachment points which allowed him to control the setting pressure when fitted. I'm at a decision point and looking for thoughts on using 6-32 or 8-32 bolts w/ locknuts to secure the plexi and WD819 frame. That currently calls for AACQ4-4, 48 times. (I sat in the fuselage and closed the framework and could see that the extending washers and nuts would not cause interference in the cockpit) Anyone have any comments ? Thanks, Doug Gardner -8A 80717 Palm harbor Fla Canopy ________________________________________________________________________________
Subject: Right Angle Drill-Non Threaded
Date: Mar 09, 2000
Harbour Freight sells a right angle drill attachment with a standard Jacob's chuck for about $13. I use it frequently when I need to put a unibit or other sized bit that I dont have for my threaded angel attachment. Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit ________________________________________________________________________________
Date: Mar 09, 2000
Subject: Re: RV-8 Canopy Attachment
Doug, I have seen two rv-8 canopies cracked apparantly by not following the recommended directions from Van's. It appears that both of the cracks I have seen are at the left aft side of the canopy and both guys added a rivet where it says not to. I believe if you take your time and do it "as per" you shouldnt have a problem just a suggestion. Glenn Williams 8A R/H WING --- "Gardner, Douglas (GA01)" wrote: > (GA01)" > > Hello RV listers, especially -8 builders, > > I've been doing alot of research on the canopy > attachment methods that > builders have used to attach the 801 canopy, and the > WD819 frame > intersection. From what I hear the real problem > comes from the "squeeze" > stress that pulled rivets cause, which tend to > fracture the plexi, > especially when the 2 parts are not at an exact 90 > deg fit. In Jeff Ludwigs > -8 he drilled and tapped most of the attachment > points which allowed him to > control the setting pressure when fitted. > > I'm at a decision point and looking for thoughts on > using 6-32 or 8-32 bolts > w/ locknuts to secure the plexi and WD819 frame. > That currently calls for AACQ4-4, 48 times. (I sat > in the fuselage and > closed the framework and could see that the > extending washers and nuts would > not cause interference in the cockpit) > > Anyone have any comments ? > > Thanks, > Doug Gardner -8A 80717 > Palm harbor Fla > Canopy > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ________________________________________________________________________________
Subject: Insterments For Sale
Date: Mar 09, 2000
Hi Fellow RVers, Just finished rebuilding a 3. I have the following extra parts for sale. 1. cht/egt gage with probes for four cylinders and four position switch. 2.Edo-Aire 360 nav/com with built in vor,with tray. 3.combo gage/ oil pressure,oil temp,fuel pressure,oat. 4.dash mount wet compass. If interested please contact off list. Thanks Larry ________________________________________________________________________________
Date: Mar 09, 2000
I installed my RV-6A canopy with the AN equivalent of 6-32 flush screws, think washers and lock nuts. I am building the tip-up canopy and found that I could use them everywhere except into the roll bar. I agree with you that it is easier by far to control the stress that you put on the assembly when you use these threaded fasteners. It looked nice on the inside, too. Steve Soule Huntington, Vermont RV-6A FWF -----Original Message-----I've been doing alot of research on the canopy attachment methods that builders have used to attach the 801 canopy, and the WD819 frame intersection. From what I hear the real problem comes from the "squeeze" stress that pulled rivets cause, which tend to fracture the plexi, especially when the 2 parts are not at an exact 90 deg fit. In Jeff Ludwigs -8 he drilled and tapped most of the attachment points which allowed him to control the setting pressure when fitted. I'm at a decision point and looking for thoughts on using 6-32 or 8-32 bolts w/ locknuts to secure the plexi and WD819 frame. ________________________________________________________________________________
Date: Mar 09, 2000
Doug and others: I finished my RV-8 in August of 1998. For the first year my canopy was perfect. Then, the next summer, I left it outside in the HOT Texas sun for an afternoon. I believe that caused some cracking that I noticed afterward-all from rivets at the very rear of the canopy frame. This past December, while sitting in my hanger, I got about a 3" crack also from a rivet hole at the rear of my canopy/frame. I have talked with several other builder who have not had this problem, and one or two who have. I am sure it is due to the thermal contraction/expansion differences in the plexi and steel. I don't want to make everyone building an -8 scared, because the problem I encountered is NOT widespread or we would all be hearing about it. I plan on drilling out the rear-most 20 rivets or so, and replacing them with #6 screws with rubber "bushings" around them into oversize holes secured with AN364 lock nuts. For the rubber, I will use R/C model rubber fuel lines that seem about the right size. (This is how my windshield is attached). In the windshield frame I tapped it. I don't feel the canopy frame is thick enough to tap, so I will run the screws all the way through the tube.I have been waiting for the daytime temps to warm up a bit before doing this work. Hope no one else has the same problem as me. I might suggest using this technique only at the rear of the canopy/frame where the problem seems to be localized. Mark Goldberg RV-8 N982RV 90 hrs ________________________________________________________________________________
Date: Mar 09, 2000
Subject: Medical certification help
Sorry to be a little off the subject guys but I just had to pass this on... I'm an insulin dependent diabetic pilot and I had to jump through flaming hoops to get approval for my special issuance medical. At the time I applied for it there were only 19 insulin dependent diabetic pilots in the entire U.S. The Doc I used has a special talent for packaging your medical info just the way the FAA likes to see it. I received my approval in record time. In my case it was a long distance consult since I live in Texas and his practice is in California. He can be reached at his website http://www.flightsurgeon.com or email at skydoc(at)sprintmail.com if anyone else can use his services. - Jim Andrews RV-8AQ Fuse and more fuse N89JA (reserved) ________________________________________________________________________________
Date: Mar 09, 2000
Check the archives on this one. I posted a long story on how I did mine. Basically I used riv-nuts or "collared nuts" . You normally use a setting tool to pull these riv-nuts...I let them float in holes I drilled in my canopy tubing & used #6 screws thru the plexi to the collared nuts. I also oversized the plexi holes so the #6 screws would float. The Riv-nuts have a collar at the end which- -when pulled snug with the #6 screw-- snug upto the canopy tubing. I finished up with .016 angle as vanity strips inside to hide the screw/rivnut/frame attach area. The vanity pieces also were the fabric hold-down thingies--my canopy has a rat skin material running around the inside of the canopy. Exterior---- I used poly-fill and a credit card (as a applicator) ...you can flex the credit card to a "bow" shape and drag it along the seam of the plexi & aluminum to give a great looking fillet/juncture. Finish up with pipe insulation as your sand paper "shapper" or form to sand the fillet contour.....I am very pleased with the results. My hanger mate used the Vans method as outlined in the plans and his turned out very nice also. douglas.gardner(at)honeywell.com on 03/09/2000 10:18:32 AM Please respond to rv-list(at)matronics.com Subject: RV-List: RV-8 Canopy Attachment Hello RV listers, especially -8 builders, I've been doing alot of research on the canopy attachment methods that builders have used to attach the 801 canopy, and the WD819 frame intersection. From what I hear the real problem comes from the "squeeze" stress that pulled rivets cause, which tend to fracture the plexi, especially when the 2 parts are not at an exact 90 deg fit. In Jeff Ludwigs -8 he drilled and tapped most of the attachment points which allowed him to control the setting pressure when fitted. I'm at a decision point and looking for thoughts on using 6-32 or 8-32 bolts w/ locknuts to secure the plexi and WD819 frame. That currently calls for AACQ4-4, 48 times. (I sat in the fuselage and closed the framework and could see that the extending washers and nuts would not cause interference in the cockpit) Anyone have any comments ? Thanks, Doug Gardner -8A 80717 Palm harbor Fla Canopy ________________________________________________________________________________
Date: Mar 09, 2000
In a message dated 3/8/00 11:19:38 PM Central Standard Time, KBoatri144(at)aol.com writes: << YES!! I got mine last weekend at Northern Tools and Equipment for $28. It is a "3/8" Angle Drill Attachment" >> Home Depot also sells a tool like this. Not sure of the price. Dale Ensing ________________________________________________________________________________
Date: Mar 09, 2000
I should have added to my previous post that I used Tinnerman countersink washers under the heads of each of the screws and I did not tighten them to the nth degree! I wanted to leave a little room for the screws to "rock" as the assembly heated and contracted. Steve Soule ________________________________________________________________________________
Subject: RV-8 Fuselage jig available/Tampa Bay
Date: Mar 09, 2000
Listers.. I have a -8 fuselage jig available in the Tampa Bay area. It's one p.c., very straight, w/ tapcons. $85.00 Also have factory wing tips, fuel valve, assorted jigs. Doug Gardner -8A #80717 Palm Harbor Fla (727 784 2600) Canopy ________________________________________________________________________________
Date: Mar 09, 2000
Next plane I build, I will take it off immediately before it gets brittle. Cecil writes: > >Cecil, >Until last week, I couldn't understand the grumbling about removing >the >plastic covering. Now I feel your pain. My kits all had the clear >plastic >and it peeled off relatively easily. That is until I tried to use some >old >trim stock that had that gawd awful white plastic. I managed to >gingerly >prod and cajole it from one side but the biggest piece I could get >from the >other side was 1/4" square. I wound up grinding it off with a >Scotchbrite >wheel. I hope someone has an aluminum-safe solvent to disolve it, >otherwise >I'd consider them scrap. In your case it might be an excuse to pop for >1-piece skins. > >Regards, >Greg Young - Houston (DWH) >RV-6 N6GY (assigned) 90% done, 90% to go > >"Always do right- this will gratify some and astonish the rest." - >Mark >Twain (1835-1910) > >> I am having much difficulty removing the white plastic that covers >the >> wing skins. I have had these skins for several years and am now >ready to >> finish covering the wings. Some of it is coming off slowly but lots >of it >> is just brittle and won't peel off. I have tried heating it but no >luck. >> (Top and Bottom). I have also heated it to melting point, scraped >with >> wood stick and then MEK. (A mess). I am just about to the point of >> reordering new bottom skins. >> Any ideas out there? >> Cecil Hatfield >> Thousand Oaks, CA > > ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Subject: RV-4 Fuselage Jig
Date: Mar 09, 2000
RV-4 Fuselage jig available soon in Modesto, California. $100 or best offer. -- Scott VanArtsdalen, MCSE Network Administrator Union Safe Deposit Bank 209-946-5116 ________________________________________________________________________________
Subject: Re: List Perspective
Date: Mar 09, 2000
Randy, Glad to have you back!! Remember the "Delete Key" Good Building, Chuck & Dave Rowbotham RV-8A (wiring) Niantic, CT ________________________________________________________________________________
Date: Mar 09, 2000
Steve, We installed a doubler plate and it worked great. Chuck & Dave Rowbotham RV-8A (wiring) Niantic, CT ________________________________________________________________________________
From: bcbraem(at)home.com.with.ESMTP (InterMail v4.01.01.00 201-229-111)
Date: Mar 09, 2000
Subject: Re: NavAid Tweaking
Denny Harjehausen wrote: > > > Can the NavAid be connected direct to a late model handheld GPS such as > Lowrance or is a coupler necessary? > > Have a great day! > Denny > Denny-- For a hand help GPS you the 5-pin DIN (PC) cable supplied by the manufacturer. This transmits the NMEA/Argus data to a coupler, like their "Smart Coupler II" that translates for the Navaid unit. Boyd RV Super6 ________________________________________________________________________________
Subject: van's support
Date: Mar 09, 2000
anyone know if van's have changed their address or moved ,i get no answer from support any longer. ________________________________________________________________________________
Date: Mar 09, 2000
Subject: Leaving the list - but I'll be back
Due to a change in jobs. Be Back as soon as I'm settled. Ralph Capen RV6A Richardson, TX N822AR (reserved) ________________________________________________________________________________
Subject: Re: List Perspective *Hit Delete Key Now!*
Date: Mar 09, 2000
Randy, Glad to see you back! (and not just because I'm one of them "California Liberal") Chuck P.S. I refrained from entering the RV religious discussions because most who have "The Answer"... simply misunderstood the question and don't realize that their truth wasn't meant to share with others. ________________________________________________________________________________
Date: Mar 09, 2000
From: "Builder's Bookstore" <winterland(at)rkymtnhi.com>
Subject: Re: Fuel Pressure Problem solved
> > Let us know how you are making out. > Eustace Bowhay Blind Bay B.C. > Problem solved! After inspecting all the fuel lines and boost pump input (everything was clean) the low and fluctuating fuel pressure problem was narrowed down to either the engine driven pump or the gauge/sender. I placed a call to Mitchell, the maker of the instrument, who promptly told me that the indicated numbers sound like a bad sender. They asked for the sender to be returned. Less then 2 days after dropping it in the mail, Mitchell called back saying that the sender was faulty and that the way it was bad was indicative of the readings I was recieving (zero psi until around 2000 rpm, and then 3-4 lbs lower than usual) Without question and without charge Mitchell is sending me a new sender, even though the old one was over 3 years old. Kudos to Mitchell Instruments for exceptional customer service and support. Also, thank you to all those on the list who answered my queries and suggested solutions. More praise for Mitchell and Pacific Coast Avionics: To get Mitchell's phone number, I called Pacific Coast Avionics. In addition to asking for the number, I asked about the quality of the Mitchell line, and if I should be upgrading to a "better" (meaning more expensive) gauge. At that point, they probably could have easily sold me any $3-400 FP gauge they wanted. Instead, they told me that there are not any more accurate or reliable gauges to be bought, that the Mitchell products are first class, and that if needed, I could get a replacement sender from them for a paltry $28. Once again, I am impressed at their honesty and customer service. So many other companies would have seen this as nothing more than an opportunity to purge the balance of my credit limit. Once again, thanks to everyone who helped. Andy ________________________________________________________________________________
Date: Mar 09, 2000
I emailed them as recently as Tuesday and got a reply from Scott Risan. Address is support(at)vansaircraft.com It did take a day or so for them to respond. -- Scott VanArtsdalen, MCSE Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Paul Quick [SMTP:paulq(at)global.co.za] Sent: Thursday, March 09, 2000 10:47 AM To: rv-list(at)matronics.com Subject: RV-List: van's support anyone know if van's have changed their address or moved ,i get no answer from support any longer. ________________________________________________________________________________
Date: Mar 09, 2000
> >Hello RV listers, especially -8 builders, > >I've been doing alot of research on the canopy attachment methods that >builders have used to attach the 801 canopy, and the WD819 frame >intersection. From what I hear the real problem comes from the "squeeze" >stress that pulled rivets cause, which tend to fracture the plexi, >especially when the 2 parts are not at an exact 90 deg fit. In Jeff Ludwigs >-8 he drilled and tapped most of the attachment points which allowed him to >control the setting pressure when fitted. > >I'm at a decision point and looking for thoughts on using 6-32 or 8-32 >bolts >w/ locknuts to secure the plexi and WD819 frame. >That currently calls for AACQ4-4, 48 times. (I sat in the fuselage and >closed the framework and could see that the extending washers and nuts >would >not cause interference in the cockpit) > >Anyone have any comments ? > >Thanks, >Doug Gardner -8A 80717 >Palm harbor Fla >Canopy Doug, I can see why a guy would want to copy Jeff's machine to the nth degree! GORGEOUS machine. The five hours I spent with him in it showed that it flies as good as it looks. I went with the pop rivets on my canopy and have NO cracks anywhere. I have 61 hours on it now, including a couple of not-gentle canopy openings and closings. Yes, it does send the pucker factor to "10" when each rivet is pulled, but nothing at all happened. I did all of my canopy work in the heart of the summer. It was VERY hot and I would not have done it during the winter. Down in Florida, you should be fine most any time of the year. I even managed to knock the canopy off the sawhorses while I was trimming it with the cutoff disc. Thwop!! Down it went onto the floor. Ack!!! After considering putting the rivet gun to my head and ending it all, I checked the canopy. No problems. It flexed all the way closed at the front end (windshield had already been cut away) momentarily as it hit the floor. The stuff is pretty forgiving as long as it's WARM. I think that's the secret right there. Dress the edges to a very smooth finish and keep the plexi warm. You should be fine with rivets per the instructions. The screws and nuts will allow you to easily remove the entire bubble should you ever have to. That does have a lot of appeal. If you just feel better with Jeff's method, then by all means use it. This is supposed to be fun! Best of luck to you. Brian Denk RV8 N94BD 61 hours. 2.8 hours today at 200mph. ________________________________________________________________________________
Date: Mar 09, 2000
Subject: Re: SNF Meeting Place
Listers I have talked to Ed Cole about an idea of some badges for the group, maybe I can come up with a logo and put names and the email name as well, so we know who's who when we meet. I will put together something this week if I get a response or some more ideas. Steve Davis The Panel Pilot ________________________________________________________________________________
From: "Chris & Kellie Hand" <ckhand(at)earthlink.net>
Subject: Re: van's support
Date: Mar 09, 2000
I used the e-mail support link on their web page earlier this week and got a response within a day and a half. That has been the typical response time for me, pretty good considering the volume they probably get. Address is support(at)vansaircraft.com Good luck, Chris Hand RV-6A ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Subject: Constant Speed Prop
Date: Mar 09, 2000
List: After getting my complete RV6-A-QB with Vans new 0-360-A1A set up for the fixed pitch prop I have changed my mind ! The good news is I have the latest cowl and the firewall mod was ordered but I believe the spinner and backing plate will need changed. I hope Van's will give me a credit on the spinner and backing plate exchange ? Should everything else be OK ? Does anyone know how long it takes to get a prop and governor? My AP insists the Woodward Governors show up less with problems in his shop? Thanks Tom in Ohio ________________________________________________________________________________
Subject: Re: Van's Web Store
Date: Mar 09, 2000
I notice that nobody has commented on Van's new Web Store. You can now order every part you can imagine directly on the net from Van's. Go to the Van's web site, go to the "Web Store" and click on the underlined words "the list". This brings up a text file (that you can download if you want) of every part in you plane plus everything in the accessory catalog with the part number, description and price. Since nobody has mentioned it, I wondered if others knew it was there. Regards, Mel Jordan, RV6A Tucson, AZ ________________________________________________________________________________
Date: Mar 09, 2000
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
>In life, in career and most recently on the RV-List I've gotten lots of >guidance and mentoring from those who have more experience, clearer >perspective and maybe just more common sense. All the people who have >helped me never asked for anything in return although I feel compelled to >repay them. About 47 years ago, a kindly gentleman who ran a radio and TV repair shop put up with a lot of stupid questions and interruptions from a kid who dropped into his shop on the way home from school most days. He even asked the kid to have his mom drive over to the house some evening whereupon he loaded the trunk with a veritable treasure trove of electronic goodies. I distinctly recall a note I found amongst the stuff as I unpacked the box. He allowed as how there was very little he needed or could use from me but asked that I repay the debt with a sharing of my own resources with others at an appropriate time in the future. For the worse, better or indifference, we are all products of the lives who have touched us in the past. Those of us who have benefitted the most have the greatest debts to repay. Institutions like amateur built airplanes demonstrate some of the finest opportunities to make good on past promises. Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Mar 09, 2000
Subject: Embroidered RV's
I really want to thank all of you that ordered shirts from me. The response from the RV list was incredible. I have been swamped. I hope that you all liked them. I am finally finishing up the orders from my first posting, and would like to know if there are any other RVers out there that would like to have their RV paint scheme embroidered on a very nice polo shirt. I do not charge a setup fee for designs, however I have to have at least a 4 shirt order. Prices for the RV-List is only $20 per shirt plus $4 shipping. I really want to thank everyone who responded the first time I posted. You guys are really great. Paul ________________________________________________________________________________
Date: Mar 08, 2000
Subject: Re: Wheel Landings
>I've always three pointed my RV-4. In any wind condition I use full flaps > not >to loose altitude but to quit flying when I get down to the runway ) and I >three >point land. If it's a stiff crosswind, I land on one main and the tail. I >hold it there >until the other main comes down. > I met an old man in St. Mary's Ohio that taught flying for years and >years at >Ohio State. I asked him what he thought about only three pointing my RV-4 >and >not learning to be more proficient at wheel landings. He told me that he >taught in >Cessna 120's and 140's for years, and the reason why they taught wheel >landings back then was because when they landed in a crosswind, they didn't >have enough control over the airplane. He claimed that with an airplane like >the >RV-4 you had more than enough control and the idea of a safe landing was to >make the airplane quit flying as soon as you could. With a three point >landing you were going slower at touchdown and would be less likely to get >out of shape on rollout. > After 800 hrs. flying from coast to coast and in all kinds of weather, >I agree >with him. >Jim Nolan >N444JN > >Jim, What you are saying applies to me big time, as is pretty much the way I figure it. I land in private strips in the north of BC and never attempt a wheel landing as there is limited space, soft ground and a changing situation can be expected, so as you say the object is to land at the slowest speed. In my experiences with the different tail wheel aircraft I have flown, a wheel landing is reserved for the show where there is a concrete runway, lots of length and a final approch that requires somewhat less attention. WHoops! I'm sure this will get flack! But really, the piont is - when the landing really screws up, having that tail down and being at the slowest landing speed you may avoid a mishap. Ed Hobenshield - Eustace, your experiences would be gold on this topic! > Ed Hobenshield edhob(at)kermode.net Kitwanga, BC, Canada ________________________________________________________________________________
Date: Mar 09, 2000
Subject: RV-6 fuselage questions
I am in the process of clamping the bulkheads to the jig. The main longerons are bent (not fun getting those right on). Question: With the bulkheads centered and heights measured shouldn't a straight line exist from the center along the bottom of the Fuse. (top when in jig) of F-605 to F-612? I have a 1/8" or more gap at F-608. When I check the top of the Fuse. (bottom when in jig) I have a nice straight line. Question: Does F-604 sit on top of the main longerons when in the jig? I believe it does but want to check for sure. John Danielson ________________________________________________________________________________
Date: Mar 09, 2000
Subject: Book status and Groton Seminar Info
Got shipped to Charlottesville VA early this week and didn't get as much done on R9 book as I'd planned but I've got the work in the laptop and we're making good use of the 6 mile high office. Leaving again in the morning for Groton CT for our second weekend seminar of the year. If anyone not already registered chooses to attend you're welcome to just show up. We're doing something a little different this trip. We've got a suitcase full of tools that will be used for some real time demonstrations. Attendee names will be drawn for taking some of them home. >The directions to Survival Systems at the Groton, CT airport are as follows: >From the North ( Providence, RI): RT 95 South > take Exit 88 > Left onto RT >117 > follow to end > at "T" turn right onto US 1 South > (follow signs to >Groton Airport) > turn Left onto Tower Ave. > > Survival Systems is the large Blue Bldg across from the terminal. > > >>From the South (New York): RT 95 North > take Exit 88 > at the bottom of the >exit ramp take a Right > follow to end > at "T" turn right onto US 1 South > >(follow signs to Groton Airport) > turn Left onto Tower Ave. > > Survival Systems is the large Blue Bldg across from the terminal. > Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Mar 09, 2000
Subject: Re: wiring question
>> i am going to use a two-bus architecture as advocated by electric bob. i >> have a question about the feed from the main bus to the essential bus. >> >> electric bob's diagrams show a one-way diode allowing current to flow from >> the main bus via short unportected wires to the essential bus under normal >> ops. when the "e-bus alternate feed" switch is thrown, then the e-bus gets >> power from the hot side of the battery, and the diode prevents the essential >> bus from feeding the main bus. >> >> my questions is the following. why not send both feeds through the e-bus >> switch? in the normal position, power could flow from the main bus via a >> fused feeder. in the alternate position, the e-bus would still get power >> from the hot side of the battery, and there would be no electrical >> connection between the e-bus and the main bus. >> >> then the diode would not be needed. in addition, a longer, fused feeder >> from the main bus would allow you to place to fuse panels further apart if >> necessary. >> >> am i overlooking something? any reason why this would not be just as >> reliable and safe, if not more so, now that we have reduced the parts count >> and used a protected circuit? The goal is to have a dual supply path to the e-bus with nothing in common between the two. A single switch as you propose could leave you with no essential bus if the switch craps. Bob . . . -------------------------------------------- ( The only time you don't fail is the last ) ( time you try something, and it works. ) ( One fails forward toward success. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Mar 09, 2000
. I had > been thinking that if I installed a switch, I could turn in off for > aeribatics and perhaps even most VFR flights to conserve its life. This may > not be the best solution, though. any comments out there? > > Dave Leonard At OSH 98 I talked to the Sigma Tek guys about this, and their response was buy the cagable horizon (if going pneumatic, which I am) and put a valve on the air line for both the horizon and DG. Cage the horizon and shut off the air supplies (or "not" air) before starting the engine prior to an aerobatic flight. This should prevent damage to the bearings. Not to the point of ordering instruments yet, so can't confirm if this works or not. Mike Robbins RV8Q ________________________________________________________________________________
Subject: Re: Constant Speed Prop
Date: Mar 09, 2000
----- Original Message ----- From: Tom & Cathy Ervin <tcervin(at)valkyrie.net> Does anyone know how long it > takes to get a prop and governor? Tom; I talked to Bill B at Van's last Friday and he is saying four months for an engine and prop. I ordered an O-360 and Hartzell prop two days ago. Mike Robbins RV8Q ________________________________________________________________________________
Subject: Re: RV-6 fuselage questions
Date: Mar 09, 2000
Hello John, If you go to Sam Buchanan's site,<http://home.hiwaay.net/~sbuc/journal/fuse3.html> called The RV Journal. Then go to his section called Building The Fuselage, on page three down near the bottom you will find the solution to your question. I did it and I'm glad! Pictures are worth thousands of words! Thanks Sam B. Jim ----- Original Message ----- From: <JDaniel343(at)aol.com> Sent: Thursday, March 09, 2000 7:49 PM Subject: RV-List: RV-6 fuselage questions > > I am in the process of clamping the bulkheads to the jig. >on top of the main longerons when in the jig? I believe it > does but want to check for sure. > > John Danielson > =========================================================== > > ________________________________________________________________________________
Date: Mar 10, 2000
To all responding listers; Thanks so much for your feedback. I've printed all of your responses for delivery to my friend Ray. He has helped me so much, I just could refuse to help him. For all of you folks out there who are gracious enough to help, thank you and keep doing what you do best and that is giving help and assistance to we who are less knowledgeable on a subject that we all love or we wouldn't be envolved in a project that so complex or expensive. Especially since I'm just getting started and need your expertise!! I hope to reciprocate when get to the place where many of you are. Kindest regards, Bud West RV-6a tail feathers ________________________________________________________________________________
Subject: Silly question -- Rotating Tires
Date: Mar 08, 2000
Seems silly but I don't know for sure -- when rotating the tires I can just swap the wheels, and not actually take the tires off, right? Please say yes... Randall Henderson, RV-6 N6R (~60 hrs) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
Subject: Re: Silly question -- Rotating Tires
Date: Mar 10, 2000
Randall: No... You have to remove the tires from the wheels and swap ends...this way you get even wear on the inside and outside tread. This is the way to maximize tire life, by the way. Tires tend to wear on the outside because you always touch down on the outside until weight is on the wheels, so it doesn't do any good to just exchange wheels from right to left. If you do this, the outside will still be the outside. This is not difficult once you figure out a good way to break the bead on your tires...a large vice helps (and a couple of pieces of 2 x 4). Pat Hatch RV-4 N17PH @ INT RV-6 N44PH (reserved) Wing Kit ----- Original Message ----- From: Randall Henderson <randallh(at)home.com> Sent: Thursday, March 09, 2000 2:23 AM Subject: RV-List: Silly question -- Rotating Tires > > Seems silly but I don't know for sure -- when rotating the tires I can just > swap the wheels, and not actually take the tires off, right? Please say > yes... > > Randall Henderson, RV-6 N6R (~60 hrs) > Portland, OR > http://www.edt.com/homewing > > ________________________________________________________________________________
Date: Mar 11, 2000
yes ________________________________________________________________________________
Date: Mar 10, 2000
In a message dated 3/9/00 10:51:53 PM Pacific Standard Time, randallh(at)home.com writes: << Seems silly but I don't know for sure -- when rotating the tires I can just swap the wheels, and not actually take the tires off, right? >> IMO it depends on how the tires are wearing. Isn't the only point of rotating tires to get maximum life out of them? So, if the wheel swap without tire removal puts the worn spot in the same place as the wheel you just removed you haven't accomplished much. It would then require tire removal to optimize the wear pattern. I wouldn't think that rolling direction makes much difference on non-radial tires. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: Mar 09, 2000
Subject: survival skills
-thru a co-worker at my wife's new job I have been talking with Greg Davenport who teaches survival skills. He is a former air force survival instructor, has written the book "Wilderness Survival" and been featured on "48 Hours" and "BBC" during the Gulf war. He has offered to teach a class directed towards survival skills for pilots and the situations applicable to flying. His web site is www.ssurvival.com. Reply to me off-line if you would be interested in attending a class for pilots. Kevin N3773(at)mciworld.com ________________________________________________________________________________
Date: Mar 10, 2000
no -- Denis L.(Bum) Walsh ---------- >From: "Randall Henderson" <randallh(at)home.com> >To: >Subject: RV-List: Silly question -- Rotating Tires >Date: Thu, Mar 9, 2000, 0:23 > > >Seems silly but I don't know for sure -- when rotating the tires I can just >swap the wheels, and not actually take the tires off, right? Please say >yes... > >Randall Henderson, RV-6 N6R (~60 hrs) >Portland, OR >http://www.edt.com/homewing > > ________________________________________________________________________________
Subject: Re: Remote Sensing Compass (was Compass For RV6-A) long
Date: Mar 10, 2000
> > >My experience with remote sensing compass is limited to only three flights, >so far. I am very pleased with the way it operates and its accuracy( less >than 5 deg error). Although the compass is digital, the display is a DG >type instrument connected by 20' of cable to a sensing unit. The display is >very steady like a DG, even in moderate turbulence. The sensing unit is >approx 3"wide x 4" long x 2.5" . Its internal workings are gimbaled to >provide accurate readings in up to 45 deg of pitch and roll. I have not seen this unit but gimbaling, such as is used in boats, would not seem to be any help in an airplane. This makes me wonder about the accuracy in turns. Does anybody know? Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: Mar 10, 2000
Subject: Re: RV-4 Fuselage Jig
"Van Artsdalen, Scott" wrote: > > RV-4 Fuselage jig available soon in Modesto, California. > $100 or best offer. > > -- RV-4 jig available in Ailene TX. Just come and get it. Two RV's built from this jig. Carroll Bird, Buffalo Gap, TX ________________________________________________________________________________
Date: Mar 10, 2000
"Gardner, Douglas (GA01)" wrote: > > Hello RV listers, especially -8 builders, > > > I'm at a decision point and looking for thoughts on using 6-32 or 8-32 bolts > w/ locknuts to secure the plexi and WD819 frame. Doug, I am not a -8 builder but I attached my canopy on the -4 that I built with 6/32 screws and some acorn stop nuts that I found at Skybolt fastner in Florida. Looks real nice, and I know of at least three -4's that have been built this way. These stop nuts have a red plastic insert that work just like a regular stop nut except they completely cover the hole, real neat. Carroll Bird, Buffalo Gap TX RV-4 60 hours no canopy cracks yet. ________________________________________________________________________________
Date: Mar 10, 2000
Subject: Re: survival skills
In regard to the survival training, wheree would it be taught? ________________________________________________________________________________
Subject: Removal of broken bolt (long)
Date: Mar 10, 2000
I mis-read the torque for one of the bolts that hold the alternator bracket to the boss on the engine case. I read the "inch-pounds" as "foot pounds." Predictably I proceeded to break the head off the bolt. What did I think I was doing? Can't say, it seems so foolish now. The question of the day is how to use the "easy-out" to extract the bolt shank from the engine case. I have done this sort of thing only twice in my life, once after breaking off a spark plug in a cylinder head of my Dodge slant six when I was a 16 year-old and once breaking off a brake bleeder on a Datsun 240-Z. Here's how I think I should use one of these bolt and screw extractors. First, you pick the right size. Since this bolt is a 5/16 bolt, I will use my 1/8 inch extractor because it is about half the diameter of the bolt. Does this sound OK? Next you center punch the bolt shank to keep the drill from wandering. Next you select a drill bit that is about half the diameter of the bolt shank. This bolt seems to be 5/16, so I will use a 1/8 drill. Does this sound OK for the 1/8 easy out? Then you drill into the bolt for about 2/3 of the length of the threads. Then you get out a heat gun and blow hot air on the engine case until is gets too warm to touch if you can get it that hot using just hot air. You don't want to use a torch because that can cause your little annoying problem to become much worse very quickly. Then you insert the extractor into the hole in the bolt and use a wrench to turn the extractor and the bolt counterclockwise. This last part is the worst for me. Those darn easy out extractors are hard and brittle. The last thing I want to do is break one of them off! You experienced mechanics must have done this sort of thing more than once. Do you have any tips for me? Besides not being to stupid to begin with, I mean. Steve Soule Huntington, Vermont RV-6A FWF in distress ________________________________________________________________________________
Date: Mar 10, 2000
Subject: Re: T-34
Chris Browne, I fly T-34s at Texas Air Aces here in Houston am building an 8 and have flown with quite a few freinds in their 6's. Depending on your HP / prop combination you will probably get better performance out of your RV than the T-34 provides. If the T-34 is tweaked then the control forces will be similar although control movement will be greater on the T-34. All in all it should be a good transition except for having to put the wheels up and down. Do take advantage of the aerobatic qualities of the T-34 to get some training there if you have not done much of that. The RV will out-turn and out-accelerate the T-34 but it's not too far off. Of course if you are building an taildragger RV then the landings / T.O. won't be similar. Can't wait top kick some 34 butt with my 8. ________________________________________________________________________________
Date: Mar 10, 2000
John, Yes, this should be a straight line. Mine was straight in the center but not straight at the lower corners (top corner in the jig.)When I drilled the skin on, the rib (believe 608?) corner moved forward to get itself inline with the skin. I drilled from the inside out so I just followed the bulkhead when drilling. All is well, the -6 flys straight & true, and no one has ever noticed that curved rivet line on that bulkhead. I don't remember about the 604, so better check the plans. Rick Caldwell -6 29.9 hrs Melbourne, FL >With the bulkheads centered and heights measured shouldn't a straight line
March 05, 2000 - March 10, 2000
RV-Archive.digest.vol-ic
