RV-Archive.digest.vol-ik
April 28, 2000 - May 04, 2000
      Gary Fesenbek
      RV6A
      Dallas, TX
Subject: Re: Using a Laser Level to Align the Horizontal Stabilizer...
Date: Apr 28, 2000
Date: Apr 28, 2000
Subject: Re: SOURCE-RV
Excellent point - in essence a living memorial. > > I also had subscribed to source-rv and of course i want my > subsc. money > to go to the memorial,----------but wouldn't it be wonderful if > instead of > ending Jeremys fine effort, it could be finished and maintained. All > of us > would benefit from it and what a great tribute to his idea. Is it > possible > for us [as a group] each contributing a small amount of time and > effort to > do such a thing? any comments???? Mike > McGowan RV-4 > > > > > Lawrence J. Greeno - greenrv(at)juno.com 24 Gilead Hill Road, N.Chili, NY 14514 716-594-0883 ________________________________________________________________________________
Date: Apr 28, 2000
Subject: Re: acro & gyros
Most GA gyros are not affected by roll. Think about it. The heading doesn't change much so the DG doesn't have to move and the face of the AI just rolls, never having to swap ends. Conversly the AI face only has one side so if you go over the top (or bottom) the card has to do a flip-flop. Consequently they usually put stops at +-80 deg. So when doing a loop, split S, etc. the AI will follow you up to 80 deg up, stop, roll 180 deg when you are pure vertical and then start tracking pitch again when you get to 80 deg nose up on the other side (i.e. its against the stops for 20 deg of nose movement). It repeats this when pure vertical nose down. Also at this pure vertical point the heading changes 180 deg so the DG has some catching up to do also. The difference is that the DG is is gymballed in only 2 axis vs. 3 for the AI. The T&B is similar to the DG and is the least effected of all the gyros. Try doing acro on the gages with a safety pilot onboard. You'll see some wierd stuff and all those demon unusual attitudes will become usual after awhile. mailsorter-101-12.iap.bryant.webtv.net (8.8.8-wtv-f/ms.dwm.v7+dul2) From: "Brian Denk" <akroguy(at)hotmail.com> Subject: Re: RV-List: acro & gyros Date: Thu, 27 Apr 2000 21:54:38 PDT >From: Glenn & Judi <foxinsocks(at)mediaone.net> >Reply-To: rv-list(at)matronics.com >To: rv list >Subject: RV-List: acro & gyros >Date: Thu, 27 Apr 2000 21:06:42 -0500 > > >Hi, > >I found a lot of info in the archives on this topic, but not this exact >question. >How long does it take for a non-cageable gyro to recover from a basic >loop or roll? > >Thanks, >Glenn Gordon My AI gets pretty scrambled after a loop but comes back online within about two minutes. A roll doesn't seem to disturb it at all, but I'm sure it won't put up with it indefinitely. The DG tumbles during a steep turn but rides out a full roll pretty well. Maybe it's just the fast rate of heading change and G loading during a steep turn (like around 60 degrees bank or more) that upsets it. A loop doesn't disturb it. Brian Denk RV8 N94BD wishing I had made that quick disconnect tray for the gyros ________________________________________________________________________________
Date: Apr 28, 2000
Subject: The panel evolves
Just completed another big step in the process. The panel is complete. As I previously reported, I used Steve Davis, the "Panel Pilot" to help me out, thanks to this list. I've really been thinking about the layout for about 15 years as I've dreamt about brewing my own craft. Of course as soon as the fuselage was able to hold me I sat in it to dream about what it would be like. I started the paper-doll instrument routine about a year ago and have fiddled around with it off and on. End result was about 5 times saying "Hey, this is it." I finally decided on "the panel" and drew it all out to scale and then went to Memphis to visit Steve. We (Steve doing the work, me lurking over his shoulder) drew it out on Autocad and cut the clear plastic "practice" panel. (See his website at www.panelcut(at)aol.com for a description of the process) We needed a few mods to make it work but basically it fit great. Also added a lot of graphics to switch positions, limitations and other panel type stuff. I looked at a bunch of Douglas/Boeing/Lockheed and bizjet manufacturers for guidance. They spend thousands on human factor design, why not copy it. Well anyway, it was really fun watching all of that planning and plotting come together as the CNC machine whirled away and cut out the panel and overlay. The total actual cut time on the main panel was 45 min. as the spindle made 5 passes at incrementally deeper levels to cut all the way through the new .090 panel. As with all parts of this project there is much more to it than it appears at first blush and Steve put in a good 2 days total to get the end product. His time will obviously vary depending on the complexity of the project and the amount of work done before the piece shows up so if you use Steve you may pay more or less than another builder. He does his work via UPS but I found it much easier to be there at the right hand of the "King". That's Steve and Elvis since I was in Memphis. Of course, being amateur-built friendly, Steve wants to take you to the airport to see the local herd of planes. We only had time to ride in a friends C-210 that has a Davis panel in it. He really made me jealous by telling me about his ride in a local RV-8 that is on his website. I think that when he completes his C-120 restoration that we may get him to join our group. His first RV ride swayed him from the abyss of "the other guys". Thanks for your time. It's hard to stop rambling when a plan comes together and I just wanted to let you know who helped me with that plan. Joe "Traash" Waltz RV-8 the "Traashcan" N877TC ________________________________________________________________________________
Date: Apr 28, 2000
Subject: Re: The panel evolves
>>Just completed another big step in the process. The panel is complete. Pictures man! Let's see some pictures. If you have given this a year's worth of thought we would LOVE to see what that has produced. I'm just like you, I like to ride along on someone else's coat tails to take the benefit of their knowledge and experience. Why reinvent the wheel, right? Thx, - Jim Andrews RV-8AQ ( just about to cut the panel ) N89JA (reserved) ________________________________________________________________________________
From: "Gardner, Douglas (GA01)" <douglas.gardner(at)honeywell.com>
Subject: RV Source
Date: Apr 28, 2000
Right on Scott.. I have hundreds of pic's of completed RV's that I would contribute, mostly -8's but something for everyone. I also have printed out many tips through the years of the RV list that I have to contribute. Doug Gardner -8A Palm Harbor Fla -----Original Message----- From: ABAYMAN(at)aol.com [mailto:ABAYMAN(at)aol.com] Sent: Friday, April 28, 2000 7:45 AM Subject: Re: RV-List: RV Source john i for one hate to see the RV source web site just disappear, Jeremy worked to hard on that web site. there are a lot of computer talented rvers on this list that should pick up the ball and run with it, hint hint Sam b. its not a matter of the 20 bucks, Jeremy was on to something grand, we should not let it go. i wouldn't know where to start, but to ask any on the list who has the talent and the time to fully carry out Jeremy's dream and finish the website, whatcha think guys look at what Jeremy gave us, vans website, the best on the Internet. just my thoughts Scott Tampa 6a tipsy ________________________________________________________________________________
Subject: N66WD for sale
Date: Apr 28, 2000
OH, Yea... I'll second Eric's comments, This is one perfect -4, like he say's, you can look at this plane all day long. Bill is a very patient person, and a great inspiration. I can't wait to see his -8 also, I'd like to have him look at my -8A for suggestions. Doug Gardner -----Original Message----- From: michael.snook(at)honeywell.com [mailto:michael.snook(at)honeywell.com] Sent: Friday, April 28, 2000 8:06 AM Subject: Re: RV-List: N66WD for sale SMTPRS 2.0.15) with SMTP id Hey John, I'll throw in my .02 worth here. ________________________________________________________________________________
Date: Apr 28, 2000
Subject: Date: Fri, 28 Apr 2000 10:08:51 -0500
......experimenting with "rolls on a point" with my -4... while inverted .... Each time I distinctly smell avgas. ...Can I can prevent it? ...... he attributed the fuel odor to gas tank venting with the gas running down the line between the wing and fuselage and the vapors coming in thru the flap actuator holes. Can you prevent it? Not the way the RV's are currently designed. Sure you can prevent it! Extend the hopelessly short vent lines to be 2 or 3 inches below the fuselage. That will prevent most of the problems. Yeah, yeah, I hear you "but it's more drag and more weight." Yes. A little. If that bothers you, don't change it. As for me the combination of acro and strong gas fumes made me ill. Works for RV-4's. Should work equally well on the other RV's too. Or you can give up the negative g stuff. That also will work. Fly safe! Vince in Indiana RV-4 HRII under construction ________________________________________________________________________________
Subject: teflon tape
Date: Apr 28, 2000
Any problem teflon taping the threads on the fittings that go into the brake cylinders? Fran, As an EAA tech counselor, instrument tech, and former Hughes Aircraft QC inspector I have opinions about such things. Heck, who doesn't! :-) I have strong opinions about teflon tape. You won't find a single piece of it on my plane. It's much too easy to get bits of it where it doesn't belong. Especially when you disassemble parts....then you get to pick all the little bits out of the fittings so they don't head downstream later. On a similar note: No silicone RTV on my gaskets either. It's for hurry-up car repairs, not airplanes. When gaskets are set in place, the RTV can ooze out inside the engine (or whatever) and later break loose and clog oil passages, etc. It can even break things if it gets between gear teeth, etc... where there's tight clearance.... something has to give. NEVER use it around fuel as it will soften and eventually fall off or leak. Use proseal on your airbox and most other places FWF, if you need a sealant. What do I trust????? I prefer the old fashion "Aviation Form- a -gasket" that you brush on for general work. Many fittings need only to be lubed with hyd. fluid, oil, or whatever passes through the fitting when installed. Whatever you choose, the important thing is to use it sparingly and not let anything go where it doesn't belong. Build safe, fly safe. Vince RV-4 HRII under construction ________________________________________________________________________________
Date: Apr 28, 2000
> > > >>Just completed another big step in the process. The panel is complete. > >Pictures man! Let's see some pictures. > >If you have given this a year's worth of thought we would LOVE to see what >that >has produced. I'm just like you, I like to ride along on someone else's coat >tails to take the benefit of their knowledge and experience. Why reinvent the >wheel, right? > >Thx, > >- Jim Andrews >RV-8AQ ( just about to cut the panel ) >N89JA (reserved) Jim, I can tell you this, whether you are doing a really simple day VFR panel like mine or a much more involved panel (see Paul Besing's website) the quality of workmanship that comes out of Steve Davis' shop cant be beat. Using paper cutouts, or printed output from Panel Planner doesnt compare to bolting all of your instruments into a plexi check panel, bolting the panel into your airplane, and sitting in the pilots seat making airplane noises. I changed my layout twice after installing the check panels in my -4 before commiting to cutting metal. As for the finished product, if you havent seen a reverse engraved panel overlay you just cant appreciate what a finished professional look this gives to your "homebuilt" airplane. Looks far better than any factory iron. Before you commit to cutting any metal talk to Steve and look at the work he does. Its worth every penny you'll pay for it. If you'd like to see a picture or 2 of my basic day VFR panel done by Steve Davis, contact me off list and I'll send it to you (I dont have a website to post it to). Mike Wills RV4 engine installation (Mazda 13B) willsm(at)spawar.navy.mil ________________________________________________________________________________
Subject: Lycoming O-235-N2C for sale
Date: Apr 28, 2000
Steve Steckler (not on the list) has an RV-9 engine for sale. He changed projects and is building the RV-8. Details: Lycoming O-235-N2C, 1690 SMOH by Mattituck, 2400 TBO, good compressions, all accesories included. $6000. Steve also has a new, never used, stainless steel exhaust system for the Lycoming O-320-H2AD engine. Fits Cessna 172's. $400 Hope this can help someone. For more details contact Steve directly at (812)867-6072 ________________________________________________________________________________
Subject: source-rv (long and technical)
Date: Apr 28, 2000
Listers, I have been toying with the idea for the past few weeks since Jeremy's untimely departure that it would be great to see the website go on and have all funds contributed to the scholarship fund. By trade I am a Windows software developer and have three projects going on right now, two of which are web-based. Sometimes the last thing I want to do when I come home is write more code after 8-10 hours, but I do it anyway out of love of doing it when changing diapers and finishing my -6 don't take precedence. Late last year I exchanged a few emails with Jeremy and we discussed some of the technical things he was doing with his website, and he was definitely on the right track. The gist of what he was doing was to create a website that allowed him to manage the site effectively without doing much of the laborious work of continually editing HTML and formatting images. A common solution to managing content is to put images and descriptions into a database, and have the web server dynamically create HTML "on the fly" using a scripting language and database queries (SQL). For those of you out there that are knowledgeable in this sort of thing know that the initial work is lengthy but well worth the result. Jeremy was more familiar with a UNIX environment (specifically, Sun Solaris), Apache, Perl, and CGI from his work at Intel, not the most intuitive environment (IMO) to work with, but he was doing a good job with it nevertheless. That might indicate to those of you who have wondered why the site was coming along relatively slowly...Jeremy was learning quite a bit as he went along. For someone to take over where he left off, their knowledge of this environment would be necessary for them to even begin, and there are a few obstacles. First of off, I have no idea of what sort of arrangement Jeremy had with the ISP who's hosting the site, and how that was being paid for. I'm sure Van's could answer that question, because I'm thinking that both sites are virtual roots off the same box. The SourceRV.com domain name contact information would have to be changed over to whomever becomes the new maintainer of the site. Given that Jeremy was running the service as a business, I'm sure there are some legal complications that would have to be resolved. Here's my take on getting SourceRV going again... First, it would have to be a community effort. I think the site could have huge potential for builders if it was "open sourced", that is, the RV community allowed to contribute to the site. Membership fees would still apply, but all of it would go to the scholarship fund. The problem with this approach is that in the case of SourceRV, you could have a real mess of a website if you had many people working on it at the same time. Everyone's got different style, egos to deal with, and that would be apparent. But there would have to be only a few people actually maintaining it...maybe 3-4 people. Even then you still might run into problems...the "plumbers" (like me) don't make very good artists sometimes, and the look-and-feel suffers. My solution to this sort of problem on one of the projects I'm working on right now was to create an app that allows non-technical people to update the site via a program on their desktop...it works like this: pick existing categories or create a new one, add a description, open the digital camera image via a dialog box that automatically formats the picture into the right format, shape, and size, boom the user is done. The website and all links are automatically updated, style is no longer an issue since nobody is actually touching the website. This is something I am actively working on right now which I have written in Visual Basic/SQL Server/ASP and I could easily bring it over to SourceRV, once its done. Which should be in the next two months or so. But there's a catch, if we went this route: the webserver would have to be switched over to Windows2000 to accomodate this, and Win2K doesn't run on the Sparc which is was Jeremy was using...so we'd have to run it on a different server possibly at a different site where someone could get physical access to it. Obviously there is a significant cost in purchasing the software but if InfoAv was made into a non-for-profit corporation Microsoft WILL (believe it or not!) donate the software for free. We could maybe have a group of people (10-15 perhaps?) from various parts of the country doing this, going to flyins, visiting builders, taking pictures, etc. and updating the site via a tool like the one I'm working on, and a small committee managing the technical portion of the site. These are just some ideas of mine, but I certainly don't want go it alone or see only just a select few involved. It sure would be a nice tribute to Jeremy and his dad and a great information tool. I'm certainly open for ideas--maybe some of us technical types can put our heads together and collectively get it going. I propose that we get some people together via a email list and start throwing some ideas around, get Van in the loop, and start where Jeremy left off. Bob Japundza RV-6 flying soon ________________________________________________________________________________
Date: Apr 28, 2000
Subject: Re: RV Source
In a message dated 4/27/00 8:15:19 PM Pacific Daylight Time, dougweil(at)pressenter.com writes: << Wouldn't that be a nice tribute if everyone elected to donate their subscription. >> YES! Harry Crosby ________________________________________________________________________________
Date: Apr 28, 2000
Subject: Sender: owner-rv-list-server
I just tried to get into the Matronics website and it appears to be in accessible accept for a memo type letter say the site will be down for upgrade on 4/4 and 4/5. Is this the wrong address? http://www.matronics.com ________________________________________________________________________________
Date: Apr 28, 2000
> My $.02. Keeping Jeremy's dream alive makes a lot of sense. Lots of web-site > talent among the listers - Sam B., Paul B. and a whole lot more. If I had the The real value of such a site comes from both general content ( panel pictures and such ) and from Vans. Although I would really enjoy a common point of contact and think that there would be tremendous value in having ( perhaps ) a copy of the building instructions on line that the entire community could annotate, we also need the input from Vans own draftsmen in the form of plan revisions. I was gladly willing to pay $25 and more a year just to get to that. It makes me crazy to think that every time I start a major assembly I may be building a flaw into my project. All this because I'm not informed of changes that may make for fewer cracks down the road and perhaps a faster ( safer ) plane in the long run. I too am in the web business. Java code is my life. But I'm wise enough to see that this must be a business and not a community project. There is just to much technical that goes into constructing and maintaining something as complex as this. If this was such a good idea ( and I think it was a GREAT idea ), then perhaps someone else who wants to make a buck will pickup the ball. - Jim Andrews RV-8A (fuse) N89JA (reserved) ________________________________________________________________________________
Date: Apr 28, 2000
Subject: RV-8 baggage door
Ok all you 8 builders out there, what's the trick? I'm in the process of doing final tweaking to the front baggage door and I'm having a heck of a time getting it to curl so it looks like it fits. What technique did you use to put that last little roll in the starboard side to make it look like the rest of the skin? Thx, - Jim Andrews RV-8AQ ( Fuse ) N89JA (reserved) ________________________________________________________________________________
Date: Apr 28, 2000
Subject: Re: SOURCE-RV annual dues
<< Yet when Jeremy announced the site there were lots of complaints about the $24.95 per year. >> randy no disrespect here, but wasnt there 700 members that had subscribed to rv souce.com out of 850 listers? i think the majority is willing to pay for the site. scott tampa ________________________________________________________________________________
Date: Apr 28, 2000
Subject: Re: Tilt up canopy jettison question
In a message dated 4/27/00 2:26:33 PM Eastern Daylight Time, RV6captain(at)aol.com writes: << am in the process of installing my tilt up canopy. I need some info about weather or not to install the jettison mechanism. I am installing the lift struts in the sides of the canopy frame so wouldn't this defeat the purpose of the jettison mechanism by still having the struts attached. Would appreciate any input I could get. Thanks, Eli Lewis Venice, FL RV-6 >> You can also buy special rivets designed to shear (shear rivets) for the aft mount of the gas strut. It might help in flight but it wont help much on the ground if you flip over. (if the plane flips over on the ground I think it would be fairly hard to jettison the canopy anyway. The plexi glass would probably be cracked or missing all together. I just finished my canopy, and decided not to mount the jettison handle in the instrument panel. I installed the canopy with bolts and nut plates, if it needs to be removed for maint. Tom Powers RV6 N5UA ________________________________________________________________________________
Date: Apr 28, 2000
Subject: Re: SourceRV
How about Larry Bowen. He works on websites, computers, etc. for a living. You can visit his site at www.bowenaero.com Come on Larry !! Len Leggette, RV-8A North Carolina (N901LL res) Fuselage ________________________________________________________________________________
Subject: Re: teflon tape
Date: Apr 28, 2000
I'll second that. If you need a sealant on pipe type threads, use a pipe dope. Most have powdered Teflon in them but the powder is so small it will go through the orifices of you fuel or brake system. Flakes of tape on the other hand when they get into the system and they will sooner or later, plug these small holes, and keep valves from sealing. What kind of valves? Carb float valves, quick drain valves, master cylinder brake valves. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) ----- Original Message ----- From: "Frazier, Vincent A" <VFrazier(at)usi.edu> Sent: Friday, April 28, 2000 10:47 AM Subject: RV-List: teflon tape > > Any problem teflon taping the threads on the fittings that go into the > brake > cylinders? > > Fran, > > As an EAA tech counselor, instrument tech, and former Hughes Aircraft QC > inspector I have opinions about such things. Heck, who doesn't! :-) > > I have strong opinions about teflon tape. You won't find a single piece of > it on my plane. It's much too easy to get bits of it where it doesn't > belong. Especially when you disassemble parts....then you get to pick all > the little bits out of the fittings so they don't head downstream later. > > On a similar note: No silicone RTV on my gaskets either. It's for hurry-up > car repairs, not airplanes. When gaskets are set in place, the RTV can ooze > out inside the engine (or whatever) and later break loose and clog oil > passages, etc. It can even break things if it gets between gear teeth, > etc... where there's tight clearance.... something has to give. > > NEVER use it around fuel as it will soften and eventually fall off or leak. > Use proseal on your airbox and most other places FWF, if you need a sealant. > > What do I trust????? I prefer the old fashion "Aviation Form- a -gasket" > that you brush on for general work. Many fittings need only to be lubed > with hyd. fluid, oil, or whatever passes through the fitting when installed. > Whatever you choose, the important thing is to use it sparingly and not let > anything go where it doesn't belong. > > Build safe, fly safe. > > Vince > RV-4 > HRII under construction > > ________________________________________________________________________________
Date: Apr 28, 2000
Subject: Re: Allegro (was: egt & cht)
I have the Allegro units in my RV6A ________________________________________________________________________________
Subject: Flaring tool
Date: Apr 28, 2000
I have one of the genuine 37 degree flaring tool from Avery and have trouble getting an even flare. Using the 1/4" tubing in the wing kit, I set the jaws for 1/4" and slide in until the tubing is at the pointer. Then clamp it shut and crank it down to generate the flare. The instructions say crank it down until you feel pressure. If I do that, no flare is generated. If I go further, then a flare is generated but it is off center. I have tried loosening the clamp, rotating the tubing 180 and then flaring it again. This actually works and the joint doesn't leak, but I feel sure that this is not the correct approach. If there is a technique to this, I'd sure like to hear it. There is no adjustment for centering this tool that I can see. Thanks, Bill Christie, RV8A Wings ________________________________________________________________________________
From: bcbraem(at)home.com.with.ESMTP (InterMail vM.4.01.02.00 201-229-116)
Date: Apr 28, 2000
Subject: Night Vision Lighting--Medical Physiology(long)
All-- Several recent posts have dealt with dimmable, night lighting arrangements. For years, the doctrine has been to avoid bright, white lights at least 30' before a night flight and close one eye if unexpectedly exposed to that light. That's generally still pretty good advice. We were also told to use red lighting in our cockpits to avoid "night blindness" (drum beat of Doom). 1. A bright, sunny day at the beach (afternoon) can last much longer than 30' on night vision adaptation (think in terms of hours, here). 1A. dark sunglasses that block both UV-A & UV-B are a help, in this case (also, for future cataract formation). 2. The two major problems with red light is that it 1: distorts map colors and 2: is on the longer wavelength side of our visual spectrum making it harder to focus, esp. for mid-age and older pilots and for those on long/extended flights (commercial/military) and can cause significant eye strain even over a relatively short period of time. Also, in more sophisticated tests, dim red light was really no more protective of night vision than "dim" light of other colors. 3. The next big paradigm shift was to blue light. The theory being that at a shorter wavelength, it was easier to focus and, therefore, it caused much less eye strain and apparently a little less color distortion in map reading. 4. Well, in all the confusion, some people tried DIM white light for initial map reading followed by a little brighter blue light to help with map detail. Fine and dandy. 5. A lot(?--I don't have the numbers) of commercial carriers currently just go with dim white lights. And for CAT III, II and I approaches, who can argue?--the outside marker lights are brighter than anything inside the cabin. 6. The most stringent requirement that I can find in the 2000 FAR is 135.159.par.f(2) "Instrument lights to make all instruments, switches and gauges easily readable, the direct rays of which are shielded from the pilot's eyes...". 7. If you will be doing extensive night flying it would be wise to consume beta carotene, 25,000 U/day for several days prior to flying as the body will turn beta carotene into Vitamin A (which is required for good night vision) on as an as needed basis rather than stocking up on Vitamin A, itself, which can build up to toxic levels, if overdone. 7A. Subacute myopia (short sightedness) can also cause visual acuity (clarity) to decrease in dim light, so a visit to the eye doctor may be a good investment if you notice that problem. (You should also notice a problem reading road signs while driving at night) 8. This is also done to prevent current and future builders from spending a lot money on fancy "night lighting" that may not be necessary. 9. Also bear in mind that some contemporary textbooks still use vision data from the Navy and Air Force that was collected during '40's, '50's and'60's. The bulk of our current info on hypothermia and duration of life (still quoted in current medical texts) was gathered by Nazi doctors using Jewish and Gypsy(Romano) prisoners in the concentration camps of WWII. Boyd RV S6 Life is a Cabaret (M.D.) contact off-line if you want more specifics but remember that I can only give general guidelines without physically examining a patient--unlike Ann Landers ________________________________________________________________________________
Date: Apr 28, 2000
Hey Jim... You bring up a timely topic. I'm at that stage also, quite happy w/ my results but of the 15 or so -8's Ive' seen this is one very noticeable metal working feat. like the book says, drill the door from the inside and hope the curve matches. Mine does if you push down hard when you activate the lock, but I'm waiting till the engine is hung until I drill the UHMA blocks to the bulkheads. Some builders add shims to the bulkheads to account for the irregularly, others add a fill material to match a joint. Most I've seen have a mismatch at the rear curve, not as bad as the front mismatch which would question the lift up possibility. I'd love to hear what the experts say, cause there's many of us coming that way. Regards Doug Gardner -8A -----Original Message----- From: Jim_Andrews(at)tivoli.com [mailto:Jim_Andrews(at)tivoli.com] Sent: Friday, April 28, 2000 2:43 PM Subject: RV-List: RV-8 baggage door Ok all you 8 builders out there, what's the trick? I'm in the process of doing final tweaking to the front baggage door and I'm having a heck of a time getting it to curl so it looks like it fits. What technique did you use to put that last little roll in the starboard side to make it look like the rest of the skin? Thx, - Jim Andrews RV-8AQ ( Fuse ) N89JA (reserved) ________________________________________________________________________________
Date: Apr 28, 2000
>Ok all you 8 builders out there, what's the trick? > >I'm in the process of doing final tweaking to the front baggage door and >I'm >having a heck of a time getting it to curl so it looks like it fits. What >technique did you use to put that last little roll in the starboard side to >make >it look like the rest of the skin? > >Thx, > >- Jim Andrews >RV-8AQ ( Fuse ) >N89JA (reserved) I used the edge rolling tool to dress down all three sides of the door skin to so that at least it doesn't stick up into the airstream on the front edge. I managed to get this edge to sit down pretty well, but the rear just didn't want to cooperate no matter how I approached it. the radius just isn't the same as the bulkhead it sits on. It really doesn't look bad unless you OBSESS over it (not a good idea if you want to fly the thing someday!). So, curl those edges a bit, make sure the locking pins work and secure the door properly, then move on. You can always build another one someday. Ack! the horror. Brian Denk RV8 N94BD watched three Grumman warbirds land today. Oooh! gimmee.... ________________________________________________________________________________
Date: Apr 28, 2000
I second that Jim Streit 9A- Emp ABAYMAN(at)aol.com wrote: > > john > i for one hate to see the RV source web site just disappear, Jeremy worked > to hard on that web site. there are a lot of computer talented rvers on this > list that should pick up the ball and run with it, hint hint Sam b. its not > a matter of the 20 bucks, Jeremy was on to something grand, we should not let > it go. i wouldn't know where to start, but to ask any on the list who has the > talent and the time to fully carry out Jeremy's dream and finish the website, > whatcha think guys > look at what Jeremy gave us, vans website, the best on the Internet. > > just my thoughts > > Scott > Tampa > 6a tipsy > ________________________________________________________________________________
Subject: Re: ACK Encoder
Date: Apr 28, 2000
I have pin outs for AT150, same as 50. If you get pin outs for ACK, you just match them. -----Original Message----- From: flyhars(at)ibm.net <flyhars(at)ibm.net> Date: Thursday, April 27, 2000 7:31 PM Subject: RV-List: ACK Encoder > >Can someone help with the wiring output from an ACK-30 encoder to an >Narco-AT50A Transponder. > >Thanks in Advance: Harvey Sigmon RV-6AQB Wiring DNA > > ________________________________________________________________________________
Subject: Re: replacing Van's wing t ips with Rocket wing tips
Date: Apr 28, 2000
hello, do you have a photo of what they look like installed? thanks, lucky >From: pdsmith <pdsmith(at)pacbell.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: replacing Van's wing t ips with Rocket wing tips >Date: Sat, 22 Apr 2000 21:41:08 -0700 > > >I have them on my -8. Also see the October picture on Van's 2000 >calendar.They fit better than Van's originals, are sturdier & you can tell >that they are just better made all the way around. If you buy them from Dan >Potter & Oliver Brennan (see Yeller Pages) they have a lighting kit (which >I >haven't entirely figured out how to install yet). You could also check with >Team Rocket as they were making their own sheared tips with nav/strobe >bulkhead already molded in. When I checked with them some months ago, there >was no room for a landing light in this set-up. you had to use the >Duckworths in the wing leading edge. > >Phil 80691 > > > snip > > Someone suggested to me that the Rocket wing tips would be better than >Van's > > wing tips for a few reasons IF they would fit. They thought that 1) the > > wing tips are already modified for night and taxi lights, 2) they were > > lighter as they were made differently and better and 3) they have a >"cooler" > > shape. > > ________________________________________________________________________________
Date: Apr 28, 2000
Thanks all for your help on the wiring of the ACK encoder. I recieved a lot of info, thanks Harv ----- Original Message ----- From: Bill Noel <bnoel(at)ausa.net> Sent: Friday, April 28, 2000 9:23 PM Subject: Re: RV-List: ACK Encoder > > I have pin outs for AT150, same as 50. If you get pin outs for ACK, you just > match them. > -----Original Message----- > From: flyhars(at)ibm.net <flyhars(at)ibm.net> > To: RV6-list(at)matronics.com > Date: Thursday, April 27, 2000 7:31 PM > Subject: RV-List: ACK Encoder > > > > > >Can someone help with the wiring output from an ACK-30 encoder to an > >Narco-AT50A Transponder. > > > >Thanks in Advance: Harvey Sigmon RV-6AQB Wiring DNA > > > > > > ________________________________________________________________________________
From: "Mark Steffensen" <steffco1(at)email.msn.com>
Subject: Re: RV-8 baggage door
Date: Apr 28, 2000
Lister's A bit of advise, based on my experience. 1. Don't cut out the baggage door original stock until the top skin is drilled. 2. Follow the instructions & file to fit the door to your airframe. I used a few shims & filed to fit the door & the fit is good. I am not going to have to use any body filler. I found thus far, the baggage door to be the most challenging metal working aspect of the project. Take your time, think it through & it will look great. Mark Stefensen RV8A N783MS Airport Bound soon......... ----- Original Message ----- From: Brian Denk <akroguy(at)hotmail.com> Sent: Friday, April 28, 2000 7:35 PM Subject: RE: RV-List: RV-8 baggage door > > > >Ok all you 8 builders out there, what's the trick? > > > >I'm in the process of doing final tweaking to the front baggage door and > >I'm > >having a heck of a time getting it to curl so it looks like it fits. What > >technique did you use to put that last little roll in the starboard side to > >make > >it look like the rest of the skin? > > > >Thx, > > > >- Jim Andrews > >RV-8AQ ( Fuse ) > >N89JA (reserved) > > I used the edge rolling tool to dress down all three sides of the door skin > to so that at least it doesn't stick up into the airstream on the front > edge. I managed to get this edge to sit down pretty well, but the rear just > didn't want to cooperate no matter how I approached it. the radius just > isn't the same as the bulkhead it sits on. It really doesn't look bad > unless you OBSESS over it (not a good idea if you want to fly the thing > someday!). So, curl those edges a bit, make sure the locking pins work and > secure the door properly, then move on. You can always build another one > someday. Ack! the horror. > > Brian Denk > RV8 N94BD > watched three Grumman warbirds land today. Oooh! gimmee.... > > ________________________________________________________________________________
Date: Apr 28, 2000
Subject: SOURCE-RV
Ok--------if it would be too much work to continue Jeremys site, is all the work that he did complete [ plans revisions-builder tips-safety notes-etc ] going to be gone to all those future builders? I am a computer dummy so i don't know how things work but could this information and future panel/plane pictures, building tips, safety notes, etc. be placed on a site where it could be accessed by all of us. ?????????? Mike McGowan RV-4 ________________________________________________________________________________
Subject: Re: Flaring tool
Date: Apr 28, 2000
Bill, are you putting oil on the cone shaped flaring mandrel? Makes all the difference in the world. If you are already using oil, maybe your tool is not aligned, and should be sent back. Alex Peterson Maple Grove, MN 6A > > I have one of the genuine 37 degree flaring tool from Avery and have trouble > getting an even flare. Using the 1/4" tubing in the wing kit, I set the jaws > for 1/4" and slide in until the tubing is at the pointer. Then clamp it shut > and crank it down to generate the flare. The instructions say crank it down > until you feel pressure. If I do that, no flare is generated. If I go > further, then a flare is generated but it is off center. I have tried > loosening the clamp, rotating the tubing 180 and then flaring it again. This > actually works and the joint doesn't leak, but I feel sure that this is not > the correct approach. > > If there is a technique to this, I'd sure like to hear it. There is no > adjustment for centering this tool that I can see. ________________________________________________________________________________
Date: Apr 28, 2000
Bill, Are you using the Rolo Flair (red handle, does down to 1/8" tubing) or the other style? Since you indicated a pointer, I assume you are using the Rolo Flair. Make sure the tubing is square and deburred both inside and outside. Use oil. The cone on the R.F. should float a bit and is self centering. I like to polish the O.D. of the tube on a fine Scotch Brite wheel and slide a sleeve on, backwards. I use this, slid up to the end, to gauge squareness when I dress up the end of the tube on the S.B. wheel. You tighten the cone until increased resistance is felt after the flare is mostly formed. Bob Skinner Buffalo, WY (1995 RV6 sold after 4 years & 470 hrs) EAA Tech Counselor # 3726 >I have one of the genuine 37 degree flaring tool from Avery and have trouble >getting an even flare. Using the 1/4" tubing in the wing kit, I set the jaws >for 1/4" and slide in until the tubing is at the pointer. Then clamp it shut >and crank it down to generate the flare. The instructions say crank it down >until you feel pressure. If I do that, no flare is generated. If I go >further, then a flare is generated but it is off center. I have tried >loosening the clamp, rotating the tubing 180 and then flaring it again. This >actually works and the joint doesn't leak, but I feel sure that this is not >the correct approach. > >If there is a technique to this, I'd sure like to hear it. There is no >adjustment for centering this tool that I can see. > >Thanks, > >Bill Christie, RV8A Wings ________________________________________________________________________________
Date: Apr 29, 2000
Jim, I found myself in the same situation what I ended up doing was curling it by hand around a cylinder, it took a few revolutions of bend/curl and fit close. You will find it really will come together when it is taped down and held by someone from the outside while you back drill the inside skin from underneath. Also a side note for the best fit ensure that you pop rivet the inside skin on while it is on the plane and taped flat with someone holding the contour from the outside, even though you drilled it in place the natural untwisting of the door when it is colecoed on the bench will change the dimensions and you will not get a good fit if done off the plane. Just my experience and I had to drill out my first set of rivets before I put the door on and riveted it. Dave Rowbotham Connecticut rv-8aq wiring instrument panel and starting cowling >>> 04/28/00 02:43PM >>> Ok all you 8 builders out there, what's the trick? I'm in the process of doing final tweaking to the front baggage door and I'm having a heck of a time getting it to curl so it looks like it fits. What technique did you use to put that last little roll in the starboard side to make it look like the rest of the skin? Thx, - Jim Andrews RV-8AQ ( Fuse ) N89JA (reserved) ________________________________________________________________________________
Subject: Re: Instrument Lighting
Date: Apr 28, 2000
Just to throw more fuel on the fire, check out http://www.edt.com:80/homewing/rhproject/#cabinlts Randall Henderson, RV-6 N6R (~75 hrs) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
Subject: Re: Tire Wear
Date: Apr 28, 2000
You guys, counting how many landings you get on your tires... sheesh! I mean, if I were that obsessive, I'd probably know that I got 177 landings, hard surface, mostly "normal" landings and just a few wheel landings, on my Aero Trainers, and wore the outsides almost bald, and just reversed them. Sire glad I'm not that obsessive.... ;-) Randall Henderson, RV-6 N6R (~75 hrs) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
Date: Apr 29, 2000
Subject: pholgiston or not??
i have ordered wings and was wondering if the pholgiston is worth it. i have plenty of time here and vans said it's mostly clean up work. the only thing that scares me is setting the larger rivets. some guys said they used c frame and 3 lb sledge. vans said they pass around via ups a pneumatic... to set the big ones. i don't mind the clean up and the acid etch, alodine, poxy, but the rivets, well, i have drilled out many in the empenage and not want to do much of that with wing spars. thoughts guys????? thanx, bob in arkansas ________________________________________________________________________________
Subject: Re: pholgiston or not??
Date: Apr 28, 2000
> i have ordered wings and was wondering if the pholgiston is worth it. i have > plenty of time here and vans said it's mostly clean up work. the only thing > that scares me is setting the larger rivets. some guys said they used c frame > and 3 lb sledge. vans said they pass around via ups a pneumatic... to set the > big ones. i don't mind the clean up and the acid etch, alodine, poxy, but > the rivets, well, i have drilled out many in the empenage and not want to do > much of that with wing spars. thoughts guys????? thanx, bob in arkansas This question comes up every now and then which is why it's in the FAQ -- go to http://www.matronics.com/ftp/Archives/RV-List.FAQ.html#wingspar. Bottom line is it looks a lot scarier than it is. Yes people have apparently had good luck with a 3 lb sledge, but I used a 5 pounder -- would feel better about that cuz fewer blows so less chance of work-hardening the rivets. Randall Henderson, RV-6 N6 (~75 hrs) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
Date: Apr 29, 2000
Bob, I just finished setting the 3/16 rivets in my left main spar yesterday. I was as psyched out as anyone about this, but using the C frame tool method (described very well in the Orndorf wing video and the plans) and a 4 lb hammer resulted in a spar full of nearly perfect rivets. I too drilled out many in the emp, but honestly, setting the 3/16 with a C frame tool is probably easier to contol than trying to buck 1/8 riverts by yourself. Just make sure the spar is level and supported at both ends, and the rivet head is firmly in the cupped set, and you'll have no problems. I also found it helps a lot to clamp the spar pieces together with c clamps and wood blocks just ahead of the rivet being set, it prevents any gap from being formed between the flange strips and web. PS After looking proudly at my new spar, I look even more fondly at the $900 still in my checkbook, and I know I made the right decision! Jeff Point -6 wings Milwaukee, WI ________________________________________________________________________________
Date: Apr 29, 2000
At sun and fun there was a booth displaying a light strip that put out a really cool greenish blue light. It apparently attaches to the visor and looked really good with my head under that blanket they were demonstrating with. Lightweight, and looked simple to install. Bill ________________________________________________________________________________
Date: Apr 29, 2000
Subject: RV-8 Baggage Door
From: "Gardner, Douglas (GA01)" <douglas.gardner(at)honeywell.com> Subject: RE: RV-List: RV-8 baggage door Date: Fri, 28 Apr 2000 17:03:39 -0700 Hey Jim... You bring up a timely topic. I'm at that stage also, quite happy w/ my results but of the 15 or so -8's Ive' seen this is one very noticeable metal working feat. like the book says, drill the door from the inside and hope the curve matches. Mine does if you push down hard when you activate the lock, but I'm waiting till the engine is hung until I drill the UHMA blocks to the bulkheads. Some builders add shims to the bulkheads to account for the irregularly, others add a fill material to match a joint. Most I've seen have a mismatch at the rear curve, not as bad as the front mismatch which would question the lift up possibility. I'd love to hear what the experts say, cause there's many of us coming that way. Regards Doug Gardner -8A Doug and RV-8 ers, I used a different technique that works really well. I did not even crawl inside to back drill! First, procure some 3M two part epoxy (2216). Drill and clecoe your baggage door parts and tweak the baggage door from the outside while it is just clecoed (no rivets yet).You may have to take it off and on about ten times until you get it to were you want it. A straight vixen file is excellent to match up the edges with the cutout in the fuselage. I used a "slip roll" for the bottom edge to get a nice curl but in lieu of that you could probably do a real nice job with a edge rolling tool (Cleaveland tools sells a nice one that is made from a vice grips). After everything is drilled, debarred and dimpled, install the door with clecoes and check your fit once again (btw, don't install the inner door cover, yet!) If your happy, remove the top door skin and mix a small batch of epoxy. Epoxy the door to the door ribs and hold it with clecoes ONLY! After a day of curing, remove the clecoes (they remove easily) and lightly clean the holes with a hand held deburr tool. Rivet the top and bottom doors on the ribs and install on to the fuselage. Your done. The neat thing about the epoxy is that it holds the door skin to the ribs without shifting. You get a real nice fit that way. Joe Czachorowski #80125 (almost finished) ________________________________________________________________________________
Date: Apr 29, 2000
Subject: David Clark Headset ANR Kit.
Hi, Is anyone familiar with a kit that will upgrade a set of David Clark headsets to noise cancelling types? I heard that a kit exists, but I haven't seen it anywhere. Does anyone know anything about these kits? Whether or not they work well? How much they cost? Where to get them? I would love to buy the real ANR headsets, but somehow all of my money is getting sucked into the RV project. Thanks -Glenn Gordon ________________________________________________________________________________
Date: Apr 29, 2000
"Vans said they pass around via ups a pneumatic... to set the big ones". Thats what I used two years ago and it worked very well. perfect rivits. Vans, at that time charged $10 for the week and they paid shipping to me and I paid to get it back to them. I had everything ready to go when it got here and it took two evenings to do by myself. Cecil Hatfield > >i have ordered wings and was wondering if the pholgiston is worth it. >i have >plenty of time here and vans said it's mostly clean up work. the only >thing >that scares me is setting the larger rivets. some guys said they used >c frame >and 3 lb sledge. vans said they pass around via ups a pneumatic... to >set the >big ones. i don't mind the clean up and the acid etch, alodine, poxy, >but >the rivets, well, i have drilled out many in the empenage and not >want to do >much of that with wing spars. thoughts guys????? thanx, bob in >arkansas > > ________________________________________________________________________________
Date: Apr 29, 2000
Bob, I used the pneumatic squeezer that Vans ships via UPS as a rental. ($15?) It took two of us about 6 hours to set all rivets on two sets of spars. Piece of cake! I recommend you save the money you don't spend on Phlogiston for other goodies. George Stanley RV-6A Wings ________________________________________________________________________________
Date: Apr 29, 2000
-----Original Message----- From: Bobpaulo(at)aol.com <Bobpaulo(at)aol.com> Date: Saturday, April 29, 2000 1:08 AM Subject: RV-List: pholgiston or not?? > >i have ordered wings and was wondering if the pholgiston is worth it the only thing >that scares me is setting the larger rivets. Bob, Don't worry about it The bark is much worse than the bite! I set mine with a 3X gun and a big bucking bar. Worked Just fine! Tommy in Ridgetop > > ________________________________________________________________________________
Date: Apr 29, 2000
Subject: Re: RV8-List: RV-8 Baggage Door
Greets... Our baggage door fits good without gaps but I want it to fit better... To get to this level of good fit I did this... 1 Rolled outer and inner door skins to match rib shape... 2 I articulated door rods so they poke the plastic bearing is a straight line... 3 I machined bearing blocks out of slippery Delrin... note... I built door completely from the outside without drilling from the inside... To go to the next level of fit... I might drill holes in ribs to relieve pressure and have door conform better... I can send pic of door rods to anyone interested... Larry The Busy Little Shop N248PL Joe Czachorowski wrote: > --> RV8-List message posted by: Joe Czachorowski > > From: "Gardner, Douglas (GA01)" <douglas.gardner(at)honeywell.com> > Subject: RE: RV-List: RV-8 baggage door > Date: Fri, 28 Apr 2000 17:03:39 -0700 > > Hey Jim... You bring up a timely topic. I'm at that stage also, quite > happy > w/ my results but of the 15 or so -8's Ive' seen this is one very > noticeable > metal working feat. like the book says, drill the door from the inside > and > hope the curve matches. Mine does if you push down hard when you activate > > the lock, but I'm waiting till the engine is hung until I drill the UHMA > blocks to the bulkheads. Some builders add shims to the bulkheads to > account > for the irregularly, others add a fill material to match a joint. Most > I've > seen have a mismatch at the rear curve, not as bad as the front mismatch > which would question the lift up possibility. > I'd love to hear what the experts say, cause there's many of us coming > that > way. > > Regards > Doug Gardner -8A > > Doug and RV-8 ers, > > I used a different technique that works > really well. I did not even crawl inside to back drill! First, procure > some 3M two part epoxy (2216). Drill and clecoe your baggage door parts > and tweak the baggage door from the outside while it is just clecoed (no > rivets yet).You may have to take it off and on about ten times until you > get it to were you want it. A straight vixen file is excellent to match > up the edges with the cutout in the fuselage. I used a "slip roll" for > the bottom edge to get a nice curl but in lieu of that you could probably > do a real nice job with a edge rolling tool (Cleaveland tools sells a > nice one that is made from a vice grips). > > After everything is drilled, debarred and dimpled, install the > door with clecoes and check your fit once again (btw, don't install the > inner door cover, yet!) If your happy, remove the top door skin and mix > a small batch of epoxy. Epoxy the door to the door ribs and hold it with > clecoes ONLY! After a day of curing, remove the clecoes (they remove > easily) and lightly clean the holes with a hand held deburr tool. Rivet > the top and bottom doors on the ribs and install on to the fuselage. > Your done. The neat thing about the epoxy is that it holds the door skin > to the ribs without shifting. You get a real nice fit that way. > > Joe Czachorowski > #80125 (almost finished) > ________________________________________________________________________________
Date: Apr 29, 2000
I used the Avery C-Frame tool and a 5x rivet gun to set the rivets. Avery provides a ram with a .401 machined end to fit a rivet gun. worked perfect. Took about 2 to 3 seconds on each rivet. I took me approx. 50 minutes to rivet each spar. John Danielson Fuselage ________________________________________________________________________________
Date: Apr 29, 2000
Subject: Re: David Clark Headset ANR Kit.
Glenn: Look in the latest issue of Aviation Consumer...Jim Brown,RV-3&4, NJ ________________________________________________________________________________
Subject: Aluminum windshield fairing
Date: Apr 29, 2000
Hi all, I rent half of a 50 x 40 hangar. The other half was empty till a few weeks ago when Jim, a retired United Airlines sheetmetal mechanic, moved in. He has a bread truck converted to a shop with tools I have never seen in any catalog! He is very helpful. Yesterday, I learned how to use a shrinker as well as how to buck, properly and where and when to use a porkchop.. He offered to help me make an aluminum windshield fairing. My first homework is to figure out the shape of the initial piece of flat stock. I like to learn by copying others and I recall seeing somewhere an article about someone doing an aluminum fairing on an RV - I believe. Can anyone remember seeing anything such? Or, can anyone suggest how to lay out the flat stock? hal RV6A N7HK N6134V is a 1965 Beech Debonair still for sale. ________________________________________________________________________________
Subject: Re: Aluminum windshield fairing
Date: Apr 29, 2000
> I recall seeing somewhere an article > about someone doing an aluminum fairing on an RV - I believe. Can anyone > remember seeing anything such? Or, can anyone suggest how to lay out the > flat stock? > > hal > RV6A N7HK Hal, Not sure if this is the one you're referring to, but Phil Arter has done his windscreen fairing in aluminum on his RV-8. It can be seen at... http://shell.rmi.net/~arter/windshield.html Randy Lervold RV-8, #80500, mangling Aeroquip fuel line today www.pacifier.com/~randyl Home Wing VAF ________________________________________________________________________________
Date: Apr 29, 2000
Glenn, By an amazing coincidence I just finished reading about this in "Aviation Consumer" May 2000 edition. It is made by Headsets, Inc. of Amarillo, Tx and lists for $169. It is a kit and requires soldering skills. According to the reviewer, it performs well enough, but they had their unit fail twice. You can have the company assemble it for you for $50 extra. The instructions are excellent and the service is good. Contact: 800-876-3374, www.headsetsinc.com. I don't have one, but am going to order one next month (credit card needs to cool off)! Bill Christie, RV8A Wings, Phoenix ----- Original Message ----- From: Glenn & Judi <foxinsocks(at)mediaone.net> Sent: Saturday, April 29, 2000 8:05 AM Subject: RV-List: David Clark Headset ANR Kit. > > Hi, > Is anyone familiar with a kit that will upgrade a set of David Clark > headsets to noise cancelling types? > > I heard that a kit exists, but I haven't seen it anywhere. Does anyone > know anything about these kits? Whether or not they work well? How > much they cost? Where to get them? > > I would love to buy the real ANR headsets, but somehow all of my money > is getting sucked into the RV project. > > Thanks > -Glenn Gordon > > ________________________________________________________________________________
Date: Apr 29, 2000
Hi Bob I thought you are building an -8. If you are, don't worry about phlogiston....the -8 wings are done by phlogiston. Rob Baxter Sarnia Ontario RV-8 fuel tanks ----- Original Message ----- From: <Bobpaulo(at)aol.com> Sent: Saturday, April 29, 2000 2:04 AM Subject: RV-List: pholgiston or not?? > > i have ordered wings and was wondering if the pholgiston is worth it. i have > plenty of time here and vans said it's mostly clean up work. the only thing > that scares me is setting the larger rivets. some guys said they used c frame > and 3 lb sledge. vans said they pass around via ups a pneumatic... to set the > big ones. i don't mind the clean up and the acid etch, alodine, poxy, but > the rivets, well, i have drilled out many in the empenage and not want to do > much of that with wing spars. thoughts guys????? thanx, bob in arkansas > > ________________________________________________________________________________
Date: Apr 29, 2000
> Just to throw more fuel on the fire, check out > http://www.edt.com:80/homewing/rhproject/#cabinlts Wups! That should be http://www.edt.com/homewing/rhproject/index.html#cabinlts Sorry! Randall Henderson, RV-6 N6R (~75 hrs) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
Date: Apr 29, 2000
Subject: Fuel Pumps
Do engine driven fuel pumps often go bad or need overhaul or are they typically an install and forget type component? Mine has less than 100 hours. Also, if they are a higher maintenance item, when they do go bad, do they typically cause a blockage or partial blockage in the flow that would show as very low fuel pressure? Still having a fuel pressure problem. I just installed a new FP sender after fluctuating to zero indicated pressure. After installing it, with only the boost pump on, pressure went immediately to a steady 4 lbs. With engine running it went to 8-9 lbs steady. Thought the problem was solved. Then about 10 minutes into a flight it started coming down slowly, all the way to zero. The boost pump would kick it up to less than 1/2 lb. The engine sputtered a little at low rpm. After shut down the boost pump by itself did nothing. Thought there might be a leak but everything is dry and no odor. Fuel from the tanks and gascolator is also clean. I checked all the lines prior to installing the new sender. They were also clean. Andy ________________________________________________________________________________
Date: Apr 29, 2000
>i have ordered wings and was wondering if the pholgiston is worth it. i have >plenty of time here and vans said it's mostly clean up work. the only thing >that scares me is setting the larger rivets. some guys said they used c frame >and 3 lb sledge. vans said they pass around via ups a pneumatic... to set the >big ones. i don't mind the clean up and the acid etch, alodine, poxy, but >the rivets, well, i have drilled out many in the empenage and not want to do >much of that with wing spars. thoughts guys????? thanx, bob in arkansas Bob, You've received some good advice already. I always figured I had more time than money so built 2 sets of spars. The Phlogiston spars are a thing of beauty and are worth the extra money if you have a high paying job and would rather work at the job instead of on the airplane. I elected to save the money and build them myself. The first set of spars, I rented Van's giant squeezer. At the time, I had "tennis elbow" and couldn't lift a hammer let alone swing one. The squeezer worked fine but is slower than setting the rivets with the "C" frame tool. The set on the squeezer must be re-adjusted for each strech of rivet lengths and then the spar inverted and the whole procedure done again. This is where the extra time comes in. It sure is quiet, though. I used bolts in the open holes and some "C" clamps to keep the stack of strips together. You have to work around these when using the squeezer which slows building down. The second set of spars (no, I didn't mess up. They were for the second airplane.) I built with the "C" tool and a 3 lb. "mini" sledge hammer. 4 or 5 lbs. might have worked even better. About 3 wacks with the 3 lb. set the rivet. I bolted the "open" holes with hardware store bolts to keep the flange stack together. Another trick you might try is to use is to slide the "C" tool set with the hole in the end over the end of the rivet and give the set a light tap to make sure the stack of flange strips is compressed. Then insert the flush set in the long set and set the rivet. I like what John Danielson did the best. Use the "C" frame tool with a 5X gun. That would be a bit faster and less tiring than using a hammer. Maybe a 4X would work for this. It's hard to believe that you could set 3/16" rivets with a 3X gun without work hardening but one responder said he got along fine. My 3X wouldn't have been able to do the job, though. Bob Skinner Buffalo, WY (1995 RV6 sold after 4 years & 470 hrs) EAA Tech Counselor # 3726 ________________________________________________________________________________
Date: Apr 30, 2000
kempthornes wrote: > He offered to help me make an aluminum windshield fairing. My first > homework is to figure out the shape of the initial piece of flat stock. I > like to learn by copying others and I recall seeing somewhere an article > about someone doing an aluminum fairing on an RV - I believe. Can anyone > remember seeing anything such? Or, can anyone suggest how to lay out the > flat stock? "18 years of the RV-Ator" pg 106 (from the 6/97 RV-Ator). I don't know who wrote the article, but it talks about Tracy Saylor's RV-6 with sliding canopy and an all aluminum windscreen fairing. It includes 3 pages of how-to, half-a-dozen photos, and a diagram. Frank. RV-6, Building tip-up canopy frame ________________________________________________________________________________
Date: Apr 29, 2000
Bob, I had the time so I used the "C" frame from Avery's and a 4 lb. Ctraftsman sledge from Sears. Worked great. I kept both ends of the spar leveled with the die in the "C' frame using 2 x 4 and 1 x 4 pieces and used 3 firm whacks with the sledge on the "C" frame and the rivets set just fine. Fran Malczynski RV6 (finish kit) Olcott, NY >From: Bobpaulo(at)aol.com >Subject: RV-List: pholgiston or not?? > >I have ordered wings and was wondering if the pholgiston is worth it. i have >plenty of time here and vans said it's mostly clean up work. the only thing >that scares me is setting the larger rivets. some guys said they used c >frame >and 3 lb sledge. vans said they pass around via ups a pneumatic... to set >the >big ones. i don't mind the clean up and the acid etch, alodine, poxy, but >the rivets, well, i have drilled out many in the empenage and not want to >do >much of that with wing spars. thoughts guys????? thanx, bob in arkansas<< ________________________________________________________________________________
From: "Craig Hiers" <craig-rv4(at)worldnet.att.net>
Subject: Re: Fitting Wheel Fairings
Date: Apr 29, 2000
Norman If you use Sam's wheel pants and operate off a grass strip do not install them as low as his instructions show. I have trashed both wheel pants on grass strips and I'm tired of fixing them. I'm going to glass over all the mounting holes and move the pants up about 1 inch. I might lose 1 knot of speed but you have to draw a line somewhere. Craig Hiers Tallahassee,FL. RV-4 N143CH > I ordered my finishing kit without the main wheel pants (and cowl) as I plan > to try the ones made by Sam James. Is there more room in these? > > It would also seem that aircraft using grass runways are subject to very low > wear and tear. It is possible that the stock tires are just fine for these > aircraft? Can anyone flying mostly on grass comment? > > > Norman Hunger > RV6A Delta, BC > ________________________________________________________________________________
Date: Apr 29, 2000
Disposition-Notification-To: "Richard" Larry Very interesting procedure on fitting the baggage door. I have use of a roller and was going to roll the inner and outer skins to match the curve of the ribs too. I would like very much to see the photographs you have fitting the baggage door. Dick Johnson Willits, Ca RV8A putting the pieces together ________________________________________________________________________________
Date: Apr 29, 2000
To me getting everything cleaned and primed was more work then the revits. I did it by myself and took me two evenings. I had to replace two bad revits but this was because I didn't have the spar level on those two ocassions. I used a one 25 lb. buck shot bag to weight things down and used the C frame method. I was very proud of the way it came out and would recomend this method to anyone building there on spars. Also work off the concrete floor, there is not much bounce when hitting the revits. And take the fellow up on his offer to help. Mike (getting ready to skin) ________________________________________________________________________________
Date: Apr 30, 2000
Subject: Manual flap handle mechanism
Hi all, A few notes regarding the flap handle mechanism in the RV-6. I suspect that the comments possibly also apply to other models. The F660A dimensions aren't critical. It would be a good idea to increase the outer 3/4" measurement a little to give better spacing to the LP4-3 rivets. However, it is *very* important that the distance from the folded end to the 3/16" hole be *at* *least* 1/2" -- more is better. I discovered this (fortunately) whilst still building the flap handle... the end of the F660A jammed solidly in the end of the bottom slot in the handle. It took about 30 minutes of vigorous work to get everything apart again. This would have been impossible in the air, and would have meant flying round with the flaps stuck at some awkward angle :-(. The width of the strip is also important at the fold-over point since the spring pushes directly on the folded-over end of the F660 at just the outer edges. Pilot drill the pop-rivet holes #40 before doing the 180 degree bend. Also strip the plastic (and prime) before doing that bend. I bent my F660A in a vise, round a 1/8" bit. That seemed to work well, although the space between the two sides seemed to close up -- maybe I got the angles a little wrong. After the above wee problem, I've decided to rebuild the F660A a little differently. I'll put some spacers (about .150" or so) at either end of the slot that the anchor goes through -- one up close to the pushrod, the other aft of the AN-3 bolt (or maybe if I can find a bit of 3/16" ID tube, I'll put it at the bolt. Perhaps also put some UHMW tape on the inside of the slot to avoid scraping paint off the anchor. The back end will be about 1" from the bolt. Probably all this will be built from .063" aluminium -- the .040" used by Vans seems a bit flimsy to me. I may also cut down the wooden dowel a little if the spring tension is too great. I also wonder about the way the spring pushes directly on the folded-over end of the F660 at just the outer edges -- I think that it would be better if the dowel was above the spring in the handle. Or perhaps one dowel above the spring and one below it. Any comments on the above ideas? Anyone had problems with the flap mechanism? Frank. RV-6, Marton, NZ ________________________________________________________________________________
Date: Apr 29, 2000
Hal, The article you are looking for is in the June 97 RVator page 6. I followed the directions and fabricated a pretty good looking fairing. To bond and seal the plexi and aluminum I used Dow Corning Trade Mate Silicone Sealant/Adhesive along with pop rivets. This sealant/adhesive was recommended by TAP plastics. It is used in industrial applications to seal and bond plastics. I was very careful to mask the plexi and aluminum so that the squeeze out could be peeled away when the tape was removed. And to prevent problems with painting the tape keeps the silicone off the aluminum. You are very fortunate to have Jim Barker in your hanger. He has been a great help to me whenever I have a problem. Cash Copeland RV-6Q N46FC #60075 Wire---Wire--- Everywhere In a message dated 4/29/00 7:05:48 PM GMT Daylight Time, kempthornes(at)home.com writes: << Hi all, I rent half of a 50 x 40 hangar. The other half was empty till a few weeks ago when Jim, a retired United Airlines sheetmetal mechanic, moved in. He has a bread truck converted to a shop with tools I have never seen in any catalog! He is very helpful. Yesterday, I learned how to use a shrinker as well as how to buck, properly and where and when to use a porkchop.. He offered to help me make an aluminum windshield fairing. My first homework is to figure out the shape of the initial piece of flat stock. I like to learn by copying others and I recall seeing somewhere an article about someone doing an aluminum fairing on an RV - I believe. Can anyone remember seeing anything such? Or, can anyone suggest how to lay out the flat stock? hal RV6A N7HK N6134V is a 1965 Beech Debonair still for sale. >> ________________________________________________________________________________
Date: Apr 29, 2000
Date: Apr 29, 2000
Subject: Dick Martin contact info?
Does anyone have an email address and/or phone number for Dick Martin? I'd like to talk to him about a few details on his -8. Regards, Ken Balch Ashland, MA RV-8 #81125 fuselage bulkheads ________________________________________________________________________________
Date: Apr 29, 2000
>From: "Norman Hunger" <nhunger(at)sprint.ca> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Fitting Wheel Fairings >Date: Sat, 29 Apr 2000 08:40:23 -0700 > > >I was following the recent thread on tire wear and was wondering if there >are some basic recommendations here for all RV builders. > >For instance, it seems that most listers that are flying feel that the >tires >supplied in the kits aren't the greatest. One suggested ordering finish >kits >without the tires and buy high quality ones later in construction. How do >the experienced guys feel about this? Sounds like a good idea to me but I >already have them in my finish kit. > >It was also mentioned that some of the better tires don't fit into the >wheel >pants the same as the stock ones. There are various clearance problems. >Could we please nail these down so that builders who haven't fitted these >yet can build them to fit later in life? It could be something real simple >like "install wheel pants with three silver dollars taped to the top of the >tire and X amount of clearance around the sides of the tire". I have yet to >fit mine and would really appreciate the opportunity to be flexible down >the >road. > >And how many different main wheel pants are there? Van has tried a few over >the years. All replies should try to mention which pant they have. > >I ordered my finishing kit without the main wheel pants (and cowl) as I >plan >to try the ones made by Sam James. Is there more room in these? > >It would also seem that aircraft using grass runways are subject to very >low >wear and tear. It is possible that the stock tires are just fine for these >aircraft? Can anyone flying mostly on grass comment? > > >Norman Hunger >RV6A Delta, BC Norman, My -8 has the Aerotrainer tires as supplied in the kit. I have the two-piece, pressure recovery type wheel pants installed per plans. I have no complaints except that they are NOT fun to install. Tire wear at 86 hours and LOTS of landings is uniform and about what I would expect. With the -8, you have to get those gear legs on STRAIGHT and the tires will wear evenly and probably give well over 100 hours of flight time off of hard surfaced runways. When I do replace them, I would not hesitate to replace them with the same type. They work fine as long as the guy in the driver's seat doesn't abuse them. Brian Denk RV8 N94BD sat in an F6F Hellcat today. Grrrrr.... ________________________________________________________________________________
Date: Apr 29, 2000
Subject: Interior priming?
I've been using the Tempo spraycan zinc chromate primer with good results so far. I'd like to paint the cockpit interior to match the powder coated parts. I know that Cardinal #230 will be a match for this. My question is: should I leave the cockpit area bare aluminum until I paint it all gray, or should I prime as I've been doing elsewhere and apply the gray interior paint over the chromate? Regards, Ken Balch Ashland, MA RV-8 #81125 fuselage bulkheads ________________________________________________________________________________
Date: Apr 29, 2000
I have been carefully following the discussions on tire wear since I am observing similar wear patterns on the tires of my clipped-wing RV-9. Hopefully I have discovered some landing techniques that will enhance the wear characteristics of the Aero-Trainers on my plane. I have observed that the best way to quickly wear out tires is to make smooth landings. If you 'grease" the plane onto the runway, the total amount of time required to "spin-up" the tires to landing speed is much greater than if you slam the tires onto the pavement. When the tires are hammered into the asphalt, such as is apt to happen when you try to flare from twenty feet above the runway, the tires INSTANTANEOUSLY come up to speed with very little resulting tread wear. You may have to contend with asphalt rash on the bottom of the wheelpants, however, but this is a minor inconvenience compared to replacing worn-out tires. When the plane touches down during the following bounces, the tires will already be spinning rapidly (unless you are clumsy enough to land with the brakes applied) and no wear will occur. An advanced technique is to concentrate all the tread wear on one tire. This is accomplished by slamming only one tire onto the pavement (usually can be accomplished by employing reversed cross-wind technique) then letting the plane slow to stall speed while it is still three feet in the air. The resulting "arrival" will be at very low ground speed, and the remaining tires will suffer very little wear. The trick to making this work well is to alternately bounce wheels on subsequent landings so the tires wear equally a small amount. 6-A and 8-A drivers can preserve tire tread on the main tires by always touching down first on the nosegear. This is desireable since a couple of listers have stated that the nosegear tire seems to last "forever". If the nose wheel is plonked down hard enough, the resulting bounce will allow you to stall the plane several feet above the runway and the main wheels will barely be turning as you complete the arrival. I am sure there are other ways to preserve tire tread, but these are some techniques that I have used or have observed other wear conscious pilots using. Tire rubber is a resource that responsible pilots try to conserve at all times, and these techniques are certainly worth mastering. Sam Buchanan ------------------------------------- Ed Hobenshield wrote: > > > >--> > >> > >Have done a lot of interviews and fact straining on this subject with many > >variables. IMHO, you are right on the norm; however It is unusual that you > >are counting landings. It is a very good sign that you are wearing same on > >both sides and that the outside is going first. Mine is a 180 HP 6A which > >weighs a little over 1100 lbs. I got 250 landings on the original tires, > >reversed at about 125 landings. I replaced with Condors, and got 450 > >landings (they have about twice as much tread). I am on the third set and > >am trying for 500. I just rotated at 250 landings. All my ops are on paved > >surface; however I strive to be very gentle with my undercarriage and its > >shoes. > > > >The good news is the nose tire lasts forever. I changed mine out at 900 but > >it still had a bit of tread left. > > -- > > Man, > What s going on? 250 landings and the tires wore out? I have 250+ landings > on my 6a and have very little wear. However, it lookes like the Condors are > a great tire and would be a great tire for replacement. > I am still amazed that the origional tires are getting such poor life. > Perhaps the 1000 ft grass runway helps as less taxi time and only using the > 500 max take-off and landing? > Ed. > > Ed Hobenshield edhob(at)kermode.net > Kitwanga, BC, Canada ________________________________________________________________________________
Date: Apr 29, 2000
> > If you use Sam's wheel pants and operate off a grass strip do not install > them > as low as his instructions show. I have trashed both wheel pants on grass > strips and I'm tired of fixing them. > I'm going to glass over all the mounting holes and move the pants up about > 1 inch. I might lose 1 knot of speed but you have to draw a line somewhere. Craig, did your wheel pants get trashed by wearing against the tires or by wearing against grass? Thanks for replying, Norman ________________________________________________________________________________
Subject: Re: Dick Martin contact info?
Date: Apr 29, 2000
The following is Dicks Email address. I seem to remember he posted his phone number in one of his messages. A search of the archives on "Dick Martin phone number" might yield some results. martin(at)gbonline.com Mike Nellis RV-6 Wings - Plainfield, IL http://mnellis.jnet.net/rv-6_page ----- Original Message ----- From: <Kbalch1(at)aol.com> Sent: Saturday, April 29, 2000 7:33 PM Subject: RV-List: Dick Martin contact info? > > Does anyone have an email address and/or phone number for Dick Martin? I'd > like to talk to him about a few details on his -8. > > Regards, > Ken Balch > Ashland, MA > RV-8 #81125 > fuselage bulkheads > > ________________________________________________________________________________
Date: Apr 29, 2000
Try this link, it might be what you're looking for. http://mnellis.jnet.net/RV-6_Page/images/RV8Tips.JPG Mike Nellis RV-6 Wings - Plainfield, IL http://mnellis.jnet.net/rv-6_page ----- Original Message ----- From: "lucky macy" <luckymacy(at)hotmail.com> Sent: Friday, April 28, 2000 10:29 PM Subject: Re: RV-List: replacing Van's wing t ips with Rocket wing tips > > hello, > do you have a photo of what they look like installed? > > thanks, > lucky > > > >From: pdsmith <pdsmith(at)pacbell.net> > >Reply-To: rv-list(at)matronics.com > >To: rv-list(at)matronics.com > >Subject: Re: RV-List: replacing Van's wing t ips with Rocket wing tips > >Date: Sat, 22 Apr 2000 21:41:08 -0700 > > > > > >I have them on my -8. Also see the October picture on Van's 2000 > >calendar.They fit better than Van's originals, are sturdier & you can tell > >that they are just better made all the way around. If you buy them from Dan > >Potter & Oliver Brennan (see Yeller Pages) they have a lighting kit (which > >I > >haven't entirely figured out how to install yet). You could also check with > >Team Rocket as they were making their own sheared tips with nav/strobe > >bulkhead already molded in. When I checked with them some months ago, there > >was no room for a landing light in this set-up. you had to use the > >Duckworths in the wing leading edge. > > > >Phil 80691 > > > > > snip > > > Someone suggested to me that the Rocket wing tips would be better than > >Van's > > > wing tips for a few reasons IF they would fit. They thought that 1) the > > > wing tips are already modified for night and taxi lights, 2) they were > > > lighter as they were made differently and better and 3) they have a > >"cooler" > > > shape. > > > > > > ________________________________________________________________________________
Date: Apr 29, 2000
From: Charlie and Tupper England <cengland(at)netdoor.com>
Subject: tailwheel choices
It's time for a new t/w for my -4. Bad bearings & really rough spots on the tire. I've been basically happy with the original, pivot-on-the-bent-tailspring, solid tire wheel. The plane is 8 yrs old & has around 500 hrs. Searched the archives about pneumatic t/w's & didn't get anything more recent than Oct, with no follow-up info from the guys who had probs with the original 4 ply Andairs. What say you? I wouldn't mind saving a pound or 2 at the rear, but is it really worth 3 times the money & the risk of a flat away from home (or at home for that matter)? 'Smoother' really isn't that big an issue to me. Thanks, Charlie ________________________________________________________________________________
Date: Apr 29, 2000
In a message dated 4/29/00 9:09:14 AM Pacific Daylight Time, nhunger(at)sprint.ca writes: << it seems that most listers that are flying feel that the tires supplied in the kits aren't the greatest. One suggested ordering finish kits without the tires and buy high quality ones later in construction. How do the experienced guys feel about this? Sounds like a good idea to me but I already have them in my finish kit.>> When you first start flying your plane you will probably be wearing tires faster than normal until you get the approach speed nailed. The McCreary Aerotrainers are a very soft compound. <> You should consider that most of the other tire brands are more of a square profile so ensure that you have a good finger's worth of pant clearance all around the tire opening along with a few RCHs more clearance in the corner area (at periphery of tread). I think the Condor tire is a very good value and has a much more robust compound for use on tarmac. Turf is far more forgiving and your tires (whatever the brand) will probably last much longer.>> -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: Apr 29, 2000
Subject: Re: Interior priming?
Ken: Depends what kind of top coat you're using on the interior. I met some of the paint vendors at OSH last year & asked them similar questions. They asked if I was using zinc chromate because they said it can cause some of the newer urethane paints to bubble & blister. (Perhaps others more knowledgeable than myself could comment). I've been using the SW P60G2 primer that Van uses & that seems to be OK with some of the paints you might use on the interior. Paul Besing said it worked fine with Sherwin-Williams Sunfire. But, since I'm using Cardinal paint to match the Cardinal powder coat, I switched to the Cardinal wash primer when I ran out of the SW. The two products seem very similar by appearance & usage & seem to have similar chemical components if you read the MSDS. No compatibility problems so far. Phil, 80691 ________________________________________________________________________________
Date: Apr 29, 2000
In a message dated 4/29/00 8:36:08 AM Pacific Daylight Time, foxinsocks(at)mediaone.net writes: << Hi, Is anyone familiar with a kit that will upgrade a set of David Clark headsets to noise cancelling types? I heard that a kit exists, but I haven't seen it anywhere. Does anyone know anything about these kits? Whether or not they work well? How much they cost? Where to get them? I would love to buy the real ANR headsets, but somehow all of my money is getting sucked into the RV project. Thanks -Glenn Gordon >> Glen, Check out < http://2.eos.net/morrism/ > I don`t know anything good or bad, just that they`re out there. Fred LaForge RV-4 Flying ________________________________________________________________________________
Date: Apr 29, 2000
Subject: Re: Manual flap handle mechanism
Frank and Dorothy wrote: > > Hi all, > > A few notes regarding the flap handle mechanism in the RV-6. I suspect > that the comments possibly also apply to other models. > > The F660A dimensions aren't critical. It would be a good idea to > increase the outer 3/4" measurement a little to give better spacing to > the LP4-3 rivets. However, it is *very* important that the distance from > the folded end to the 3/16" hole be *at* *least* 1/2" -- more is better. > It also helps if the slot in the flap handle is no larger than necessary. > Perhaps also put some UHMW tape on the > inside of the slot to avoid scraping paint off the anchor. The back end > will be about 1" from the bolt. I left my "Anchor" unpainted since I knew the paint would get scraped off. > > > I also wonder about the way the spring pushes directly on the > folded-over end of the F660 at just the outer edges -- I think that it > would be better if the dowel was above the spring in the handle. Or > perhaps one dowel above the spring and one below it. > I put the dowel above the spring in the handle. The mechanism seems to work a little smoother with this arrangement. Gary Zilik ________________________________________________________________________________
Date: Apr 29, 2000
Hal, I made my own aluminim windshield fairings and they came out much nicer than any glass fairings I've seen. They are much thinner than fiberglass and took me about a day from start to finish. The material I used was, I believe 1100 grade, .032. It,s soft and works almost like putty after a little practice. I didn't do any shrinking and did not use any special tools. I used a piece of 2X4 in the vice and used my rivit gun (at a very low pressure) and a flush set as a planishing hammer. As you work one side the metal will start to curve and you'll find that you can form it to almost any shape you want. I started with a piece of construction paper for the starting shape then gave up and just guessed at what it should look like. I only scrapped one piece and ended up with what I think are pretty nice fairings. What the heck you don't have anything to lose but a little bit of sheet metal! Dave kempthornes wrote: > > Hi all, > > I rent half of a 50 x 40 hangar. The other half was empty till a few weeks > ago when Jim,.... offered to help me make an aluminum windshield fairing. My > first.... > > hal > RV6A N7HK > N6134V is a 1965 Beech Debonair still for sale. > ________________________________________________________________________________
Date: Apr 29, 2000
Subject: Re: Fuel Pumps
If you are using the electric pressure gauge be aware the senders are often the cause of pressure problems. In the last 5 years I've had to open and repair/calibrate 4 of them (some fuel and some oil pressure). The sending unit should be your first suspect. Dave Andy wrote: > > Do engine driven fuel pumps often go bad or need overhaul or are they typically > an install and forget type component? Mine has less than 100 hours. > > Also, if they are a higher maintenance item, when they do go bad, do they > typically cause a blockage or partial blockage in the flow that would show as > very low fuel pressure? > > Still having a fuel pressure problem. I just installed a new FP sender after > fluctuating to zero indicated pressure. After installing it, with only the boost > pump on, pressure went immediately to a steady 4 lbs. With engine running it went > to 8-9 lbs steady. Thought the problem was solved. Then about 10 minutes into a > flight it started coming down slowly, all the way to zero. The boost pump would > kick it up to less than 1/2 lb. The engine sputtered a little at low rpm. After > shut down the boost pump by itself did nothing. Thought there might be a leak but > everything is dry and no odor. Fuel from the tanks and gascolator is also clean. > I checked all the lines prior to installing the new sender. They were also clean. > > Andy > ________________________________________________________________________________
Date: Apr 29, 2000
Frank and Dorothy wrote: > > > Hi all, > > A few notes regarding the flap handle mechanism in the RV-6. I suspect > that the comments possibly also apply to other models. > I also wonder about the way the spring pushes directly on the > folded-over end of the F660 at just the outer edges -- I think that it > would be better if the dowel was above the spring in the handle. Or > perhaps one dowel above the spring and one below it. Precisely what I did with my flap handle installation. I cut the wood dowel into two pieces and put the spring between them as shown on this page: http://home.HiWAAY.net/~sbuc/journal/fuse7.html The flap handle was also shortened 4". The installation works very nicely. Sam Buchanan (RV-6, 140 hrs; engine to be dismantled next week....check the website for blow-by-blow details...) "The RV Journal" http://home.hiwaay.net/~sbuc/journal ________________________________________________________________________________
Date: Apr 29, 2000
they are made my headsets inc. in amarillo texas. ive had one for years and they work great. installed it in my 10-60. cost me 169.00 at snf a couple of years ago. R. Burns rv-4 s/n 3524 N82RB > ________________________________________________________________________________
Date: Apr 29, 2000
Subject: Re: an515-8r8 torque value
Hello, Checked archives and AC43.13 for torque values for an an515-8r8 screw, specifically the gas tank access plate ones. Does anyone know the correct value(s) Also, is there a special screwdriver point for this screw as I keep with little effort messing up the heads. Thanks, Vince Himsl Moscow, ID USA ________________________________________________________________________________
Date: Apr 30, 2000
> > It's time for a new t/w for my -4. Bad bearings & really > rough spots on > the tire. I've been basically happy with the original, > pivot-on-the-bent-tailspring, solid tire wheel. The plane > is 8 yrs old & > has around 500 hrs. > During my annual inspection last week, I replaced my original RV-6 tailwheel with a new one from Van's. Today as I was pulling the airplane out, I heard a thump, thump, thump. Upon inspection, I found the tail wheel had a flat spot on it. (It wasn't that way when I flew on Thursday.) I haven't a clue as to why. The wheel had accumulated a total of 8 landings. Out with new, in with the old. I hope Van's will replace it. Mark Nielsen RV-6; 471 hrs. Green Bay, WI ________________________________________________________________________________
Date: Apr 30, 2000
Subject: Aileron Stops
Howdy! In checking my aileron travel (installing top skin tonight!) per the specs in section 15, when almost full "up" the pushrod heim joint bolt contacts the W-413 mounting bracket (look at dwg. 16, left middle detail where "+" shows bolt center next to mounting bkt. just under end of pushrod), and when almost full "down" the bellcrank contacts the vertical .063 angle that ties the rear of the 1/8" angles together. It doesn't seem like these interferences would make very good aileron stops- certainly not per plan. (bellcrank is mounted right way 'round!) It is possible I am not measuring these angles correctly or ? Has anyone "run into" this problem, and if so, suggest an explanation or cure? Sure wanna keep that roll rate up to max! yeee-haaaaaaaaaa!!!!!! From the PossumWorks in TN Mark - -6A, 1st wing nearing completion (I hope!) ________________________________________________________________________________
Subject: Navid aid device
Date: Apr 30, 2000
I'm thinking about purchasing a navaid device (wing levler) the type that can be coupled to a GPS. My question is has anyone installed this particular wing leveler in the wing tip? If so was it practical, did it work ok, any prints or info?? thanks ahead. RV6A 100 hrs still grinin planejoe(at)ewol.com do not archieve ________________________________________________________________________________
"RV List"
Subject: Fuel filter
Date: Apr 30, 2000
Hello, I was starting to work on my fuel system and wanted a fuel filter for my IO engine. Aircraft Spruce and Van's have filters which state "NOT FOR FUEL INJECTION SYSTEMS." Spruce has one for with number 6 fittings but costs 89 dollars. It had a name of Flow Ezy so I did a web search and found they had a site. http://www.freeyellow.com/members3/flowezy/ Look under Racing Filters. It look like just what I want and at half the price of ACS. Filter 43.xx Replacement screens 3.90 New O-Ring 3.00 It also has replacable or cleanable screens. The model I looked at had a 2 gpm (120 gallons per hours) hope my fuel flow never gets that high. Good to 250 psi, my pump is rated at 25 or 35, I wil have to look that up but seems to be plenty. Anybody, tried one of these? Or any word on the Flow Ezy company? Thanks, Tom Gummo ________________________________________________________________________________
Date: Apr 30, 2000
Subject: PLEASE READ: Network Problems To Matronics...
Dear Listers, My ISP is upgrading their network today 4/30 and tomorrow 5/1. I noticed that Nameservice (DNS) went down last night around 3am which causes all sorts of problems. If your message post was rejected between about 3am 4/30 and 1pm 4/30, please repost as it was rejected do to the DNS being down. I've redirected my systems to a different DNS server in the mean time and things seem to be working right now. In any case, be aware that there may be continuing issues over the next couple of days both posting email messages and accessing the web server. My ISP *promises* that things are going to be so much better after the upgrade! We'll see... ;-) Best regards, Matt Dralle Matronics Email List Admin. -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft Great minds discuss ideas, Average minds discuss events, Small minds discuss people... ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Date: Apr 30, 2000
Cleaveland Aircraft Tools, part no. SBZ-2, Zephyr ACR Phillips Bit #2, ribbed bit for anti-camout -- $.90. Snap-On offers anti-camout bits but you have to get an insertion bit and a removal bit if you go that route. Dennis Persyk 6A finishing kit Hampshire, IL C38 -----Original Message----- From: Vince Himsl <vhimsl(at)turbonet.com> Date: Sunday, April 30, 2000 12:05 AM Subject: RV-List: Re: an515-8r8 torque value > >Hello, > >Checked archives and AC43.13 for torque values for an an515-8r8 screw, >specifically the gas tank access plate ones. Does anyone know the correct >value(s) > >Also, is there a special screwdriver point for this screw as I keep with >little effort messing up the heads. > >Thanks, >Vince Himsl >Moscow, ID USA > > ________________________________________________________________________________
Date: Apr 30, 2000
In a message dated 4/29/00 10:34:25 PM Pacific Daylight Time, vhimsl(at)turbonet.com writes: << Checked archives and AC43.13 for torque values for an an515-8r8 screw, specifically the gas tank access plate ones. Does anyone know the correct value(s)>> I have a torque table from Ford Aerospace (which became Loral which became Lockheed Martin) that has suggested general purpose torques for light duty fastenings. It's at work so I will check it on Monday. My recollection is that 8-32 steel screws into steel free running nuts is somewhere in the 12-15 lb-in range. To this value one must add the prevailing torque value created by the locking thread to result in the actual recommended torque value. Another thing you should consider is that "de-virgining" #8 nutplates takes a bit of effort as you can imagine, but can be both productive and satisfying. Just use some Boelube or anti-sieze (molydisulfide) compound on the first few threads of each screw. <> The best tool for this job IMO is a replaceable tip screwdriver. They are available at many hardware and auto stores and are characterized by a hexagonal driver end that accepts a number of different hardened steel or titanium nitrided steel tips. These tips stay good and sharp to grab the cross recessed (Phillips) driving recesses. Use a #2 or #3 tip and, if necessary, get some valve lapping compound to put in the recess. This improves the torque coupling of driver to screw. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: Apr 30, 2000
Subject: Re: Florida RV builders breakfast
can you put me on you email list stan RV-6A ________________________________________________________________________________
Date: Apr 30, 2000
>Checked archives and AC43.13 for torque values for an an515-8r8 screw, >specifically the gas tank access plate ones. Does anyone know the correct >value(s) > >Also, is there a special screwdriver point for this screw as I keep with >little effort messing up the heads. > >Thanks, >Vince Himsl >Moscow, ID USA Vince, Van's kits used to come with a large amount of kind of pot metal looking #8 screws. These didn't have very good "+" slots in them. You received good advice on bits. I like "Snap On's" ribbed bits for taking out pesky screws. I feel the S.O. is a little bit better than the bits that I got from Cleavland. When I was down helping John Danielson, we looked for these screws in his parts assorment. He didn't remember getting any screws like I described. He did have a lot of cad plated #8 truss head screws. Possibly Van's has replaced these. I didn't use the supplied screws and replaced them with stainless steel #8 truss head screws for in the cockpit and the cad plated screws for other places. Bob Skinner Buffalo, WY (1995 RV6 sold after 4 years & 470 hrs) EAA Tech Counselor # 3726 ________________________________________________________________________________
Subject: Re: tailwheel choices
Date: Apr 30, 2000
There were some poorly vulcanized tailwheels according to an AD. I think it was for Maule. But this might be the case for your new Tail wheel. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) ----- Original Message ----- From: "Mark Nielsen" <Mark.Nielsen@fiedler-lp.com> Sent: Sunday, April 30, 2000 12:19 AM Subject: RE: RV-List: tailwheel choices <Mark.Nielsen@fiedler-lp.com> > > > > > It's time for a new t/w for my -4. Bad bearings & really > > rough spots on > > the tire. I've been basically happy with the original, > > pivot-on-the-bent-tailspring, solid tire wheel. The plane > > is 8 yrs old & > > has around 500 hrs. > > > > During my annual inspection last week, I replaced my original RV-6 > tailwheel with a new one from Van's. Today as I was pulling the > airplane out, I heard a thump, thump, thump. Upon inspection, I found > the tail wheel had a flat spot on it. (It wasn't that way when I flew > on Thursday.) I haven't a clue as to why. The wheel had accumulated > a total of 8 landings. > > Out with new, in with the old. I hope Van's will replace it. > > Mark Nielsen > RV-6; 471 hrs. > Green Bay, WI > > ________________________________________________________________________________
Date: Apr 30, 2000
Subject: Oil door latch alternatives?
Hi, I have seen several ideas on the list for a substitue to camlocks and piano hinge for the oil door. I am going to try the concealed hinges out of the Mc Master Catalog. But as far as the actual latching mechanism goes; has anyone tried the following? 1. "Push to Open" magnetic catch. Typical of the type you would see on a stereo cabinet. 2. Push To Open cabinet catch. Operates like the magnetic type, however it is mechanical and non-magnetic. (obviously the biggest issue with #1 & #2 is that the door needs to be supported on a flange which would prevent the door fron being pushed in to open it.) 3. A spring loaded hinged inward access button (such as the type AC Spruce sells for valve stem access on a wheel pant'd wheel) into which you can put your finger to pull the oil door open from a tension catch. I did like the idea of using the piano hinge/pull pin as a hidden method of latching, however I didn't like the idea of having the oil door latch hinge on the top of the door. I of course am still trying to figure out a clean way of hinge latching the bottom of the oil door without getting to carried away with a mechanism for it. I am trying to get the hingepin to follow an arc, so I can have its pull point inside the engine air inlet. Please share your thoughts on this. I spent enough time on this cowling (polyester resin type) and would really like to get it finished already. Thanks, Glenn Gordon ________________________________________________________________________________
Subject: Re: Aileron Stops
Date: Apr 30, 2000
s anyone "run into" this problem, and if so, suggest an explanation or >cure? Sure wanna keep that roll rate up to max! yeee-haaaaaaaaaa!!!!!! > >From the PossumWorks in TN >Mark - -6A, 1st wing nearing completion (I hope!) Mark, I don't remember about the installation (plans at hangar & memory shot) but my -6 was done per plans & had no interference. Speaking of max roll rate, seems the aileron design is not favoring quick, full aileron travel. When I do this, the aileron stalls & there is very noticable pulsing of the stick. So I move about 80% of the travel and the roll is just fine & the stick is still. Rick Caldwell -6 1st flight 1/3/00 & 50.4 grin generating hrs. Melbourne, FL ________________________________________________________________________________
From: Bob DiMeo - Oracle <dimeob(at)powertel.com.au>
Date: May 01, 2000
I used light machine oil (sewing machine oil) on the screw threads and used a power screwdriver (Sears or Black & Decker type). the torque is about right and the screws didn't gall. The biggest problem is that people tend to over torque small hardware. Bob RV8 #423 > ---------- > From: Vanremog(at)aol.com > Sent: Sunday, April 30, 2000 05:26 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Re: an515-8r8 torque value > > > In a message dated 4/29/00 10:34:25 PM Pacific Daylight Time, > vhimsl(at)turbonet.com writes: > > << Checked archives and AC43.13 for torque values for an an515-8r8 screw, > specifically the gas tank access plate ones. Does anyone know the > correct > value(s)>> > > I have a torque table from Ford Aerospace (which became Loral which became > > Lockheed Martin) that has suggested general purpose torques for light duty > > fastenings. It's at work so I will check it on Monday. My recollection > is > that 8-32 steel screws into steel free running nuts is somewhere in the > 12-15 > lb-in range. To this value one must add the prevailing torque value > created > by the locking thread to result in the actual recommended torque value. > Another thing you should consider is that "de-virgining" #8 nutplates > takes a > bit of effort as you can imagine, but can be both productive and > satisfying. > Just use some Boelube or anti-sieze (molydisulfide) compound on the first > few > threads of each screw. > > < with > little effort messing up the heads. >> > > The best tool for this job IMO is a replaceable tip screwdriver. They are > > available at many hardware and auto stores and are characterized by a > hexagonal driver end that accepts a number of different hardened steel or > titanium nitrided steel tips. These tips stay good and sharp to grab the > cross recessed (Phillips) driving recesses. Use a #2 or #3 tip and, if > necessary, get some valve lapping compound to put in the recess. This > improves the torque coupling of driver to screw. > > -GV (RV-6A N1GV) > vanremog(at)aol.com > > > > > ________________________________________________________________________________
Subject: Argus MFD displays
Date: Apr 30, 2000
Richard Weaver from Aero Sport Inc. sent me great photos from the 3 Extra 300 cockpits. I noticed one of them (fully IFR equipped) had an Argus 5000CE display that looked real interesting. After a search, I found that this is an Eventide product. The price seems to be competetive (starting at ~2500) and I like the small size and many functions - particularly the ability to use it with an ADF as well as flightplanning stormscope, HSI, GPS's, etc. Has anyone tried the Argus MFD's? If so, I would like to hear what you think. I couldn't find any info in the RV archieve about this when searching for Argus and Eventide. Here's a link to the Eventide site with more info. http://www.eventide.com/argus/argpage.htm Regards, Are Barstad ________________________________________________________________________________
Subject: engine questions
Date: Apr 30, 2000
Hi all, I've got a couple engine questions if you don't mind. These refer to a new O-360-A1A purchased through Van's. - The engine was test run at the factory, and came with long term storage. The engine included a new oil filter in the box. Am I supposed to install the new filter before I run the engine, or save it for the first oil change? The filter on the engine would only have an hour and ten minutes of running time, but I guess it might also be full of preserving oil. - Since I'm using a fixed pitch prop, I removed the prop governor adapter and oil line. Now I have to plug up the hole where the governor adapter was, and I've been unable to find a cover at any of the local FBO hangouts. As it turns out, I have a perfect aluminum plate to go over the hole, but it has about a 3/8 hole right in the middle. I also plan to use an air oil separator, and need a place to run the drain oil back to the engine. Would there be any problem with tapping the governor plate hole for 1/4" NPT, and installing a hose fitting for the return oil? I'm assuming there's just crankcase pressure under the plate. Is that right? Thanks for any advice. Russell Duffy Navarre, FL RV-8, sn-587, N174KT (moving to the hanger next weekend) ________________________________________________________________________________
Date: Apr 30, 2000
Subject: Re: Navid aid device
Joe Wiza wrote: > > > I'm thinking about purchasing a navaid device (wing levler) the type that > can be coupled to a GPS. My question is has anyone installed this > particular wing leveler in the wing tip? If so was it practical, did it work > ok, any prints or info?? > thanks ahead. Well........now that you asked....... Here is the info you are looking for: http://home.HiWAAY.net/~sbuc/journal/navaid.html The installation detailed in the article now has a large diameter servo pushrod. Anyone interested in the necessary adapters to fabricate the pushrod, let me know and I will see if I can get our local machinist guru to make up a few. Sam Buchanan "The RV Journal" http://home.hiwaay.net/~sbuc/journal ---------------------------- ________________________________________________________________________________
Subject: Re: Oil door latch alternatives?
Date: Apr 30, 2000
I believe there is a lot of air pressure inside the cowl during flight. I know an RV-6 where the cowl bulges out just behind the oil door about a 1/16". There is a 3" gap in the hinges that fasten the cowl to the boot cowl at that point and the cowl flexes out. due to the internal pressure of about 180 mph. When you design your revised oil door you should take this into consideration. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) ----- Original Message ----- From: "Glenn & Judi" <foxinsocks(at)mediaone.net> Sent: Sunday, April 30, 2000 6:12 PM Subject: RV-List: Oil door latch alternatives? > > > Hi, > I have seen several ideas on the list for a substitue to camlocks and > piano hinge for the oil door. > > I am going to try the concealed hinges out of the Mc Master Catalog. > But as far as the actual latching mechanism goes; has anyone tried the > following? > > 1. "Push to Open" magnetic catch. Typical of the type you would see > on a stereo cabinet. > > 2. Push To Open cabinet catch. Operates like the magnetic type, > however it is mechanical and non-magnetic. > > (obviously the biggest issue with #1 & #2 is that the door needs to be > supported on a flange which would prevent the door fron being pushed in > to open it.) > > 3. A spring loaded hinged inward access button (such as the type AC > Spruce sells for valve stem access on a wheel pant'd wheel) into which > you can put your finger to pull the oil door open from a tension catch. > > I did like the idea of using the piano hinge/pull pin as a hidden method > > of latching, however I didn't like the idea of having the oil door latch > > hinge on the top of the door. I of course am still trying to figure out > > a clean way of hinge latching the bottom of the oil door without > getting to carried away with a mechanism for it. I am trying to get the > > hingepin to follow an arc, so I can have its pull point inside the > engine air inlet. > > Please share your thoughts on this. I spent enough time on this cowling > > (polyester resin type) and would really like to get it finished already. > > Thanks, > Glenn Gordon > > ________________________________________________________________________________
Date: Apr 30, 2000
> The installation detailed in the article now has a large diameter > servo pushrod. Hey Sam, What prompted replacement with a larger rod? I have the 1/4 inch on mine (wingtip mount) - course the wings are stored now while fuselage works goes on. Was there some bending and robbing the servo of travel? Mike Thompson Austin, TX -6 N140RV (Reserved) Fuselage ________________________________________________________________________________
Date: Apr 30, 2000
Mark: Just got done doing this myself. I didn't get the interference you mention, mine was the lower bolt on A-406 touching W-414, which is fairly common, I think. The interference you mention sounds like you can avoid by adjusting the width of the spacers on A-407. I believe you can move the rod-end slightly outboard, I believe this will solve your problem. Once you can get the full 30 degrees up, then you can install the stop slightly before any other interference comes into play. By the way, I had to relieve the W-414 aileron mount assembly slightly for the bolt interference I mentioned previously. You might run into this once you fix your other problem. On the bellcrank interference, I think if you start with the 1 3/16" neutral position (measurement as shown on plan 19a), you shouldn't have the interference you mention. Just a shot in the dark. Hope this helps. Pat Hatch RV-4, N17PH @ INT RV-6, Fuse on the way. ----- Original Message ----- From: Mark Phillips <ripsteel(at)edge.net> Sent: Sunday, April 30, 2000 6:01 PM Subject: RV-List: Aileron Stops > > Howdy! > > In checking my aileron travel (installing top skin tonight!) per the > specs in section 15, when almost full "up" the pushrod heim joint bolt > contacts the W-413 mounting bracket (look at dwg. 16, left middle detail > where "+" shows bolt center next to mounting bkt. just under end of > pushrod), and when almost full "down" the bellcrank contacts the > vertical .063 angle that ties the rear of the 1/8" angles together. It > doesn't seem like these interferences would make very good aileron > stops- certainly not per plan. (bellcrank is mounted right way > 'round!) It is possible I am not measuring these angles correctly or ? > Has anyone "run into" this problem, and if so, suggest an explanation or > cure? Sure wanna keep that roll rate up to max! yeee-haaaaaaaaaa!!!!!! > > From the PossumWorks in TN > Mark - -6A, 1st wing nearing completion (I hope!) > > ________________________________________________________________________________
Date: Apr 30, 2000
Subject: Proseal life
Has anyone had any experience using Proseal that is out of date. I am ready to seal my tanks and have a quart of Proseal from Van's that has never been opened but the date on the can says it is 6 months out of shelf life. What happens when the Proseal get old? Should I just can this and buy a new batch? Tom Clark 80525 ________________________________________________________________________________
Date: Apr 30, 2000
Subject: rudder stiffner question
i am confused as to the angles of the stiffeners i understand the tapered part, length and the sort. however in vans drawings there is a discrepancy as to the angle direction and i have seen pix that are also 180 degrees different. does it matter which direction the angles are as long as dimensions are correct????? ________________________________________________________________________________
Subject: Re: Proseal life
Date: Apr 30, 2000
ive uses stuff that was years out of date. if it can still be mixed it works. R. Burns RV-4 N82RB s/n 3524 ----- Original Message ----- From: <Ski2001a(at)aol.com> Sent: Sunday, April 30, 2000 9:25 PM Subject: RV-List: Proseal life > > Has anyone had any experience using Proseal that is out of date. I am ready > to seal my tanks and have a quart of Proseal from Van's that has never been > opened but the date on the can says it is 6 months out of shelf life. What > happens when the Proseal get old? Should I just can this and buy a new batch? > > > Tom Clark 80525 > > ________________________________________________________________________________
Date: Apr 30, 2000
Subject: Re: rudder stiffner question
In a message dated 4/30/00 10:59:45 PM Eastern Daylight Time, Bobpaulo(at)aol.com writes: << i am confused as to the angles of the stiffeners i understand the tapered part, length and the sort. however in vans drawings there is a discrepancy as to the angle direction and i have seen pix that are also 180 degrees different. does it matter which direction the angles are as long as dimensions are correct????? >> The angles have a 180 degree different orientation to stagger their webs. IF you don't install them with this difference, the webs can hit each other (primarily near the trailing edge), and will prevent you from forming the trailing edge bend and closing the rudder. The same thing applies to the elevators. KB ________________________________________________________________________________
Date: Apr 30, 2000
Subject: Electric Trim Clearance
OK, I just finished the part I've been putting off, installing the electric elevator trim servo in left elevator. Proud as a peacock about the installation, I hooked it up to a battery and ran it stop to stop. My problem is, when I run it all the way out, the arm where the rod screws in makes contact with the reinforcement plate. Any suggestions? I can't see mounting it any further back as that would interfere with the spar. Any help would be appreciated. Thanks, Eric Newton Long Beach, MS RV-6A (empennage almost done - waiting for wing kit to arrive) ________________________________________________________________________________
Date: Apr 30, 2000
Mike Thompson wrote: > > > > The installation detailed in the article now has a large diameter > > servo pushrod. > > Hey Sam, > What prompted replacement with a larger rod? I have the 1/4 inch on > mine (wingtip mount) - course the wings are stored now while fuselage > works goes on. Mike, the wingtip installation is working perfectly, but Bob upgraded the pushrod at my insistence. I just feel better having a stiff pushrod in the aileron circuit that is far less likely to induce some sort of weird resonance. > > Was there some bending and robbing the servo of travel? Absolutely no problems whatsoever. The smaller pushrod probably will be just fine, but I feel a lot better about the installation with the larger pushrod. This is just an area where I had rather be conservative in design. By the way, the 3/4", thinwall pushrod weighs about the same as the smaller, heavier unit, but is MUCH stiffer. Sam Buchanan "The RV Journal" http://home.hiwaay.net/~sbuc/journal ________________________________________________________________________________
Date: Apr 30, 2000
Subject: Re: engine questions
The 3 new Lycomings at FTG called lycoming and got the governor cover plate for free. Gary Zilik > > - Since I'm using a fixed pitch prop, I removed the prop governor adapter and oil line. Now I have > to plug up the hole where the governor adapter was, and I've been unable to find a cover at any of > the local FBO hangouts. ________________________________________________________________________________
Date: May 01, 2000
Subject: Re: Electric Trim Clearance
Just completed the same part myself & was wondering also. Ended up notching the mount/cover about 15/16" back from the edge. The same width as the original notch, only not tapered. Looks good & works. L.Adamson RV6A finish ________________________________________________________________________________
Subject: Airflow performance
Date: Apr 30, 2000
Listers, I have 2 questions: - I've completed the fuel lines from the wing root bulkheads thru the valve, filter and Airflow performance fuel pump to the firewall bulkhead. I want to run an air pressure leak check on the system, thought about 10psi. since it's on the low pressure side of the pump. Does anyone know if the Airflow performance pump can take air pressure? Any diaphragm, bellows or such that might rupture? - Can anyone explain if the Andair gascolator is worth more than double the price of the other one Van's sells? I've never looked at the two types side by side and can't tell from the catalog. Thanks, Jeff Farrar, RV8A N4ZJ reserved, Chandler, AZ jfarrar1(at)home.com Wings done, fuselage almost, fuselage interior and wiring, building RMI units. ________________________________________________________________________________
Date: May 01, 2000
>Any suggestions? I can't see mounting it any further back as that would >interfere with the spar. Any help would be appreciated. Eric, Just grab a round rat tail file and notch that bad boy out. The key here is to not file past the doubler plate. I had to notch mine back about 3/4 of an inch before it would reliably run back and forth without making contact. - Jim Andrews RV-8AQ ( My engine is finally here!!! Yippee! ) N89JA (reserved) ________________________________________________________________________________
Date: May 01, 2000
In a message dated 4/30/00 7:11:15 PM Pacific Daylight Time, rv8(at)ispchannel.com writes: << I also plan to use an air oil separator, and need a place to run the drain oil back to the engine. Would there be any problem with tapping the governor plate hole for 1/4" NPT, and installing a hose fitting for the return oil? I'm assuming there's just crankcase pressure under the plate. Is that right? >> I would recommend not running oil return back to the engine. I have used a Matco brake fluid reservoir to collect the condensate. Various attempts by local builders to return fluids to the pressurized crankcase in this area have not been successful. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: May 01, 2000
Proseal seems to work fine for quite a while after it's expiration date, but if it were me, I wouldn't risk it on the tanks. You want every advantage you can get when sealing them because a leak can be a major headache. I'd buy some fresh stuff, and you can use the older stuff on a myriad of other things that aren't as critical as tank sealing. Windscreen fairings, firewall sealing, etc. I have some that I used recently that's over 3 years old, and it's starting to get really thick and sticky, but it does work for general sealing chores. Ed Bundy - Eagle, ID RV6A - First flight 11/20/96 ebundy(at)micron.net > Has anyone had any experience using Proseal that is out of date. I am ready > to seal my tanks and have a quart of Proseal from Van's that has never been > opened but the date on the can says it is 6 months out of shelf life. What > happens when the Proseal get old? Should I just can this and buy a new batch? ________________________________________________________________________________
Subject: RV-8 QB Landing Gear
Date: May 01, 2000
Anyone know of any "tricks" for drilling the outboard landing gear wear plate holes on the RV-8 QB? Seems impossible to me without drilling holes in the F-850/F-851 fuselage skins. John Hall RV-8QB ________________________________________________________________________________
Date: May 01, 2000
You want to overlap opposing angles slightly. When you "finish bend" the control surface opposing angles might hit each other. No overlap could result in the angles creasing the thin flight control skin while finish bending. John Sheppard RV8 (sealing second tank) -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bobpaulo(at)aol.com Sent: Sunday, April 30, 2000 9:29 PM Subject: RV-List: rudder stiffner question i am confused as to the angles of the stiffeners i understand the tapered part, length and the sort. however in vans drawings there is a discrepancy as to the angle direction and i have seen pix that are also 180 degrees different. does it matter which direction the angles are as long as dimensions are correct????? ________________________________________________________________________________
Date: May 01, 2000
I just finished using some pro-seal that had an manufacture date of 8/97 on it to attach the NACA scoops to the inside of my fuselage. It's been on for three days now and is setting up just fine. Seems that when I did my fuel tanks the pro-seal was already six or more months past the manufacture date and they mantained pressure for more then a week using the ballon test. Your results may vary. Fran Malczynski RV6 (finish kit) Olcott, NY -----Original Message----- From: Ski2001a(at)aol.com <Ski2001a(at)aol.com> Date: Sunday, April 30, 2000 10:39 PM Subject: RV-List: Proseal life > >Has anyone had any experience using Proseal that is out of date. I am ready >to seal my tanks and have a quart of Proseal from Van's that has never been >opened but the date on the can says it is 6 months out of shelf life. What >happens when the Proseal get old? Should I just can this and buy a new batch? > > >Tom Clark 80525 > > ________________________________________________________________________________
Date: May 01, 2000
Subject: Re: Argus MFD displays
> >Richard Weaver from Aero Sport Inc. sent me great photos from the 3 Extra >300 cockpits. I noticed one of them (fully IFR equipped) had an Argus 5000CE >display that looked real interesting. After a search, I found that this is >an Eventide product. The price seems to be competetive (starting at ~2500) >and I like the small size and many functions - particularly the ability to >use it with an ADF as well as flightplanning stormscope, HSI, GPS's, etc. > >Has anyone tried the Argus MFD's? If so, I would like to hear what you >think. I couldn't find any info in the RV archieve about this when searching >for Argus and Eventide. > >Here's a link to the Eventide site with more info. > >http://www.eventide.com/argus/argpage.htm > >Regards, >Are Barstad > > I've flown with an Argus 5000 (monochrome) for several long cross countries. It was a fairly busy, but useful display. You can select which types of data to show (airports, long range VORs, short range VORs, airspace boundaries, airways, etc) to control how busy the display gets. My only complaint is the convoluted series of multiple button presses you need to use to get to various functions. There are only four buttons on the right side, which access the main functions, but you also have to know which combinations of two or three buttons you can press simulataneously to access various secondary functions. This is OK if you fly with the unit regularly, but it would be a trick to remember all this stuff in the heat of battle if you only used it occasionaly. You need some sort of GPS to tell the Argus where it is. If I was going to have a GPS and a moving map, I would be tempted to get a Garmin GNS 430. Kevin Horton RV-8 (cockpit floor) khorton(at)cyberus.ca (613) 821-7862 (home) Ottawa, Canada (613) 952-4319 (work) http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
Subject: Fw: Lightening holes
Date: May 01, 2000
First, I asked the list...and someone suggested I ask van's...so I did...Here's their response. Now I gotta figure out what they mean...I think they're talking about 2xrivetdia etc... -----Original Message----- From: Scott Risan <support(at)vansaircraft.com> Date: Monday, May 01, 2000 2:22 PM Subject: Re: Lightening holes small lightening holes in the spacer should pose no problems so long as you maintain adequate pitch distance from the fastener holes. van's From: "Ralph E. Capen" <recapen(at)earthlink.net> Subject: Lightening holes > First, concerning the spacer that we have to build for the Rudder Spar? SNIP ________________________________________________________________________________
Date: May 01, 2000
Subject: Sliding Canopy Rear Track
Listers: I'm fitting the sliding canopy frame on my RV-6 and have a question about fitting the nylon (or whatever) rear track slider block to the canopy frame. It's obvious that the slider block has to rotate as it travels up and aft on the track, but the plans (SC-1) shows the block snuggled up close to the square bottom of the weldment that it fits on. If that is done there is no way it can rotate. On the other hand if I move it down far enough so that it can rotate around the square bottom of the weldment there is very little edge distance left for the mounting bolt. The solution appears to be to grind the forward side of the weldment in an arc so that the block can rotate around it, but there is no mention of doing that on the plans, in Van's manual or in the Justice notes. What am I missing here? Harry Crosby -6 finish kit stuff ________________________________________________________________________________
Date: May 01, 2000
Date: May 01, 2000
Date: May 01, 2000
Date: May 01, 2000
Subject: RE: RV8-List: engine questions
Date: May 01, 2000
Rv8'rs: I went through these same issues too, same configuration. As for the filter I had to remove the old one just to get at the #$%@# oil cooler line fitting, so the new one went on. On the governer, Bengilis suggests fabrictating a 1/4" alum plate cover for it. I used a double layer of 1/8" plates because that's what I had available. Our local EAA tech consuler thought that ok. On the air-oil sep, I ran a drain line into the base of the plastic oil fill tube, which I driled and tapped for 1/4" NPT. Again our EAA tech consuler said that was fine, though another member who is an A&P would only comment that the FAA would not accept it. Greg Miller RV8 QB N89GM, finally ready for prop (24 mo. 2200 hrs) -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Russell Duffy Sent: Sunday, April 30, 2000 7:03 PM Subject: RV8-List: engine questions --> RV8-List message posted by: "Russell Duffy" Hi all, I've got a couple engine questions if you don't mind. These refer to a new O-360-A1A purchased through Van's. - The engine was test run at the factory, and came with long term storage. The engine included a new oil filter in the box. Am I supposed to install the new filter before I run the engine, or save it for the first oil change? The filter on the engine would only have an hour and ten minutes of running time, but I guess it might also be full of preserving oil. - Since I'm using a fixed pitch prop, I removed the prop governor adapter and oil line. Now I have to plug up the hole where the governor adapter was, and I've been unable to find a cover at any of the local FBO hangouts. As it turns out, I have a perfect aluminum plate to go over the hole, but it has about a 3/8 hole right in the middle. I also plan to use an air oil separator, and need a place to run the drain oil back to the engine. Would there be any problem with tapping the governor plate hole for 1/4" NPT, and installing a hose fitting for the return oil? I'm assuming there's just crankcase pressure under the plate. Is that right? Thanks for any advice. Russell Duffy Navarre, FL RV-8, sn-587, N174KT (moving to the hanger next weekend) ________________________________________________________________________________
From: "Jones, Bryan D." <bryan.jones@lyondell-citgo.com>
Subject: Sky-Tec Starters
Date: May 01, 2000
Anyone have any experience with the Sky-Tec starters on Lycoming engines? How about other "after-market" starters? Thanks Bryan Jones Pearland, Texas ________________________________________________________________________________
Date: May 01, 2000
Subject: oil cooler placement on baffling
I would like to place my oil cooler on the left rear baffle, there's not that much room on the firewall of the 4. Does anyone know where I could get plans are some pictures of the cooler done this way. Carey Mills N286RV ________________________________________________________________________________
Date: Apr 30, 2000
Subject: routing the mix & throttle cable(help)
I have a 4 and put vans throttle quad between the 402 and 403 bulkhead. I wanted to get some idea's from other builders before I started drilling holes in my firewall. I have the bendix injector and I was thinking of working from there and going straight back into the firewall and then try to figure out how I'm gonna get it to the quad. What do you guys think? I would love to hear form someone who's done this before. Carey Mills N286RV ________________________________________________________________________________
Date: May 01, 2000
In a message dated 4/30/00 10:51:03 PM Eastern Daylight Time, cgalley(at)qcbc.org writes: << > Please share your thoughts on this. I spent enough time on this cowling > > (polyester resin type) and would really like to get it finished already. >> Glenn, Cy is right in that there is a higher pressure inside the cowl. Rich Jankowski opens his door "in" rather than out and I am doing it to mine also. You build a flange on the underside of the door, your hinge is concealed and the pressure makes the door seal tighter. Bernie Kerr, 6A N60WM ,inspection tomorrow, flying soon!!, SE Fla ________________________________________________________________________________
Date: Apr 30, 2000
Subject: rudder cracks, caulk, etc.
Has anyone found the ideal solution (short of a new rudder) to stopping cracks in the rudder at the stiffeners on existing a/c which did not have caulk applied during assy? Stop-drilling has proven to be only a stop-gap solution. I suppose I can gently pry the cracks open & get some caulk in, but that makes me uncomfortable. Has anyone tried something like 'GREAT STUFF' spray foam insulation? If there aren't any corrosion issues, I think it will be a lot easier to get into the rudder, lighter, & it sticks like nothing I've ever seen. Thanks Charlie flying -4 ________________________________________________________________________________
Date: Apr 30, 2000
Subject: Re: Tire Wear
Sam Buchanan wrote: > > I have been carefully following the discussions on tire wear since I am > observing similar wear patterns on the tires of my clipped-wing RV-9. > Hopefully I have discovered some landing techniques that will enhance > the wear characteristics of the Aero-Trainers on my plane. > > Great report Sam, your particular twist on this subject has once again proven the > usefulness of the "List", and changed my perspective, on my many tire saving > arrivals. Thanks, Garry/RV6 still finishing and finishing, like the pink drum pounding bunny. ________________________________________________________________________________
Date: Apr 30, 2000
Subject: oil door latch idea
Date: May 01, 2000
I have a 4 and put vans throttle quad between the 402 and 403 bulkhead. I wanted to get some idea's from other builders before I started drilling holes in my firewall. I have the bendix injector and I was thinking of working from there and going straight back into the firewall and then try to figure out how I'm gonna get it to the quad. What do you guys think? I would love to hear form someone who's done this before. Carey Mills N286RV From: Rvmils(at)aol.com Full-name: Rvmils Date: Sun, 30 Apr 2000 09:40:38 EDT Subject: routing the mix & throttle cable(help) I have a 4 and put vans throttle quad between the 402 and 403 bulkhead. I wanted to get some idea's from other builders before I started drilling holes in my firewall. I have the bendix injector and I was thinking of working from there and going straight back into the firewall and then try to figure out how I'm gonna get it to the quad. What do you guys think? I would love to hear form someone who's done this before. Carey Mills N286RV ________________________________________________________________________________
Date: Apr 30, 2000
Subject: Tip-up canopy questions
Hi All, Dwg 51 is sparse on details... 1. The C603 canopy side skin. Will Cretsinger says in his notes that the aft end of the C603 should be positioned 3/8" aft of the front face of the cabin frame. That would make it extend 5/8" aft of the F631A of the canopy frame. That sounds kindof odd to me. What's the reason? Will the canopy plexiglass extend back that far too? Perhaps someone could point me to a photo of this part of a completed canopy? 2. How is the F631A canopy bow attached to the Wd625B canopy side frame? According to the plans, there are 2 bolts that hold on the Wd622 canopy latch. But that doesn't seem like enough to me. Surely there must also be some rivets holding the canopy frame together? 3. What is the relative position of the instrument panel and the Wd616D canopy frame tube when the canopy is closed? I haven't trimmed my panel to shape yet, so I'm just not sure whether the tube should be forward or aft of the panel top when the canopy is closed. Frank. RV-6, Marton, NZ ________________________________________________________________________________
Date: Apr 30, 2000
Andy Check your fuel vent lines. The symptoms you describe sound like a restriction in the vent system. Charlie Kuss RV-8 wings smashing rivets Boca Raton, Fl. > snipped > > Still having a fuel pressure problem. I just installed a new FP sender after > fluctuating to zero indicated pressure. After installing it, with only the boost > pump on, pressure went immediately to a steady 4 lbs. With engine running it went > to 8-9 lbs steady. Thought the problem was solved. Then about 10 minutes into a > flight it started coming down slowly, all the way to zero. The boost pump would > kick it up to less than 1/2 lb. The engine sputtered a little at low rpm. After > shut down the boost pump by itself did nothing. Thought there might be a leak but > everything is dry and no odor. Fuel from the tanks and gascolator is also clean. > I checked all the lines prior to installing the new sender. They were also clean. ________________________________________________________________________________
From: "Gardner, Douglas (GA01)" <douglas.gardner(at)honeywell.com>
Subject: Instrument Lighting
Date: Apr 30, 2000
That company was Aero Enhancements, I believe they have a link via Van's site, but that light was very expensive like $220.00, but it has a 9V battery backup. I know Jeff Ludwig from Jax Fla really likes it though. Doug Gardner -----Original Message----- From: Bill Shook [mailto:billshook(at)mindspring.com] Sent: Saturday, April 29, 2000 8:22 AM Subject: Re: RV-List: Instrument Lighting At sun and fun there was a booth displaying a light strip that put out a really cool greenish blue light. It apparently attaches to the visor and looked really good with my head under that blanket they were demonstrating with. Lightweight, and looked simple to install. Bill ________________________________________________________________________________
Date: May 01, 2000
Date: May 01, 2000
Subject: Pitot tube mounting location
Does anyone know what the closest location to the fuselage that you can mount your pitot tube is? I'm thinking of experimenting with a pitot + static tube off of a piece of scientific equipment ( good for readings down to about 28 knots ) but I need to mount it in the middle access cover which is about 42 inches from the fuse. I'm just wandering if this will put me in the prop wash. Van's normally has you locate it about a foot farther out. - Jim Andrews RV-8AQ ( fuse ) N89JA (reserved) ________________________________________________________________________________
From: "William M. Costello" <wmcent(at)enteract.com>
Subject: ANR upgrade kit for David Clark and others
Date: Apr 30, 2000
Hi Glenn, The company is called Headsets, Inc. I bought a kit at Oshkosh from a rep for the company: Morris Morgan Authorized Representative ANR Headsets 2955 Fawn Drive Burllington, KY 41005 606-466-6022 check out his site: http://www.anr-headsets.com I moved shortly after Osh and haven't completed the installation, which I hope to do so soon. I recall a number of people saying they work great. The installation is not falling-off-a-log easy. You have to drill a hole in the plastic earcup. You should have a volt-ohmmeter and know how to figure electrical circuits somewhat. Soldering is also required. I have built a few amatuer radio pieces, so have some experience. Don't get me wrong, it is not rocket science! And, if all else fails you can send the whole thing to them and they will do it for a price. Speaking of price, I can't remember, but I think it was $150 to $200. Best regards, Bill Costello WMCEnt(at)enteract.com ________________________________________________________________________________
Subject: Re: Instrument Lighting
Date: May 01, 2000
I have that system in my airplane. Aero Enhancements power supply is running the panel lights and the glareshield lights that they offer. Stay tuned for a much cheaper version to come out in the near future. I am working with a company to provide the same system for much less. Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit ----- Original Message ----- From: "Gardner, Douglas (GA01)" <douglas.gardner(at)honeywell.com> Sent: Sunday, April 30, 2000 6:16 AM Subject: RE: RV-List: Instrument Lighting > > That company was Aero Enhancements, I believe they have a link via Van's > site, but that light was very expensive like $220.00, but it has a 9V > battery backup. I know Jeff Ludwig > from Jax Fla really likes it though. > > Doug Gardner > > -----Original Message----- > From: Bill Shook [mailto:billshook(at)mindspring.com] > Sent: Saturday, April 29, 2000 8:22 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Instrument Lighting > > > At sun and fun there was a booth displaying a light strip that put out a > really cool greenish blue light. It apparently attaches to the visor and > looked really good with my head under that blanket they were demonstrating > with. Lightweight, and looked simple to install. > > Bill > > ________________________________________________________________________________
Date: May 01, 2000
> I would recommend not running oil return back to the engine. I have used a > Matco brake fluid reservoir to collect the condensate. Various attempts by > local builders to return fluids to the pressurized crankcase in this area > have not been successful. > > -GV (RV-6A N1GV) > vanremog(at)aol.com This is good advice. In fact, Lycoming told me to forget about the air oil separator because it would allow some water to be drained back to the engine rather than dumped overboard. I've gotta admit, I never thought of that. I can't see a problem with using a dedicated reservoir for the waste liquid though. I'll try it the old fashion way first, and if the belly gets too dirty, maybe I'll use the separator with it's own reservoir. I was able to order a cover for the governor adapter hole in the case through a local FBO. For the sake of the archives, the part number is 69106 for the cover, and 69551 for the gasket. These should fit an O-360-A1A. Thanks, Russell Duffy Navarre, FL RV-8, sn-587, N174KT (Moving to the hanger this weekend- won't be long now) ________________________________________________________________________________
Subject: Re: RV-8 QB Landing Gear
Date: May 01, 2000
John... You got it right. That is the only way I have heard of, so far. Not a problem tho.. later you are gonna cover it with a fairing anyway. Dick White RV-8QB systems Newport OR ----- Original Message ----- From: AV8R <jhth(at)email.msn.com> Sent: Monday, May 01, 2000 4:20 PM Subject: RV-List: RV-8 QB Landing Gear > > Anyone know of any "tricks" for drilling the outboard landing gear wear > plate holes on the RV-8 QB? Seems impossible to me without drilling holes > in the F-850/F-851 fuselage skins. > > John Hall > RV-8QB > > ________________________________________________________________________________
Date: May 01, 2000
Subject: Re: Sliding Canopy Rear Track
In a message dated 5/1/00 11:03:18 PM Eastern Daylight Time, HCRV6(at)aol.com writes: << Listers: I'm fitting the sliding canopy frame on my RV-6 and have a question about fitting the nylon (or whatever) rear track slider block to the canopy frame. It's obvious that the slider block has to rotate as it travels up and aft on the track, but the plans (SC-1) shows the block snuggled up close to the square bottom of the weldment that it fits on. If that is done there is no way it can rotate. On the other hand if I move it down far enough so that it can rotate around the square bottom of the weldment there is very little edge distance left for the mounting bolt. The solution appears to be to grind the forward side of the weldment in an arc so that the block can rotate around it, but there is no mention of doing that on the plans, in Van's manual or in the Justice notes. What am I missing here? Harry Crosby -6 finish kit stuff >> Harry, I just looked at my slider (Its in the dining room - is there any wonder why I can't keep a girlfriend?). I have just under 3/16 edge distance on the hole through the weldment. Also, I filed the forward portion of the weldment slightly so the block would rotate. KB ________________________________________________________________________________
Subject: Re: Tip-up canopy questions
Date: May 01, 2000
1. Just trim it to match the cut line of the plexiglass. Make sure that the rear skin butts up against it at the same angle. 2. It is attached with rivets. The bolts are to attach the canopy latch catches. I don't have my drawings in front of me, but there is a place that shows the rivet pattern. 3. The tube is aft of the panel when the canopy is closed. Be sure you trim the panel just lower than the method described, or you might have some contact with the frame. Paul Besing RV-6A (197AB) Arizona http://members.home.net/rv8er Finish Kit ----- Original Message ----- From: "Frank and Dorothy" <frankvdh(at)ihug.co.nz> Sent: Sunday, April 30, 2000 2:35 AM Subject: RV-List: Tip-up canopy questions > > Hi All, > > Dwg 51 is sparse on details... > > 1. The C603 canopy side skin. Will Cretsinger says in his notes that the > aft end of the C603 should be positioned 3/8" aft of the front face of > the cabin frame. That would make it extend 5/8" aft of the F631A of the > canopy frame. That sounds kindof odd to me. What's the reason? Will the > canopy plexiglass extend back that far too? Perhaps someone could point > me to a photo of this part of a completed canopy? > > 2. How is the F631A canopy bow attached to the Wd625B canopy side frame? > According to the plans, there are 2 bolts that hold on the Wd622 canopy > latch. But that doesn't seem like enough to me. Surely there must also > be some rivets holding the canopy frame together? > > 3. What is the relative position of the instrument panel and the Wd616D > canopy frame tube when the canopy is closed? I haven't trimmed my panel > to shape yet, so I'm just not sure whether the tube should be forward or > aft of the panel top when the canopy is closed. > > Frank. > RV-6, Marton, NZ > > ________________________________________________________________________________
Subject: Re: RE: RV8-List: engine questions
Date: May 01, 2000
-----Original Message----- From: Greg Miller <gvm(at)srv.net> Date: Monday, May 01, 2000 9:47 PM Subject: RV-List: RE: RV8-List: engine questions > >Rv8'rs: > >On the air-oil sep, I ran a drain line into the base of the plastic oil fill >tube, which I driled and tapped for 1/4" NPT. Again our EAA tech consuler >said that was fine, though another member who is an A&P would only comment >that the FAA would not accept it. > >I used to do the same until someone convinced me to run it into a container of some sort and take a look at what collects there. My engine had a fair amount of blow-by at that time and was I ever surprised to see what I was collecting. It looked like a bunch of water with a little bit of oil in it. Not something I would want to recirculate in my engine. I'm sure a new engine would not have as much water, but we are trying to turn them into used engines, aren't we? >Ivan Haecker > > ________________________________________________________________________________
Date: May 01, 2000
For the aerodynamic sealing, out of date sealant will be fine but for fuel tanks it is better to be safe than sorry. We use proseal quite a lot in our hangar on our jets. To be "legal" we have to reject any "prc" as we call it, due to the FAA PRC is not that expensive so just buy a new quart and your worries will be gone. They also come in tubes to be used with a sealant gun, I think the sizes are 8oz or 4oz. One thing that is important is to mix the sealant lots to get a good mix and so that the sealant hardens. Lots of people say that temp is a major factor in set up time, my experience is that any temp above 65 it does not need a heat source. If you are shooting the stuff at a lower temp understand it will take longer to set up. That has been my experience with the B-half sealant. Hope this helps. RV-8 Tail on order Mike A&P ________________________________________________________________________________
Date: May 01, 2000
If you have access to 'Tony Bingelis on Engines', see Pg. 109 for a picture of Dave Anders' RV-4 installation to get an idea of what it could look like. Paul ------Original Message------ From: Rvmils(at)aol.com Sent: May 1, 2000 11:57:46 AM GMT Subject: RV-List: oil cooler placement on baffling I would like to place my oil cooler on the left rear baffle, there's not that much room on the firewall of the 4. Does anyone know where I could get plans are some pictures of the cooler done this way. Carey Mills N286RV ________________________________________________________________________________
Subject: Re: ANR upgrade kit for David Clark and others
Date: May 01, 2000
I have had the Headsets,Inc. kit in my Peltor 7004 for two years. I think I lost a little attenuation of the higher frequencies but the elimination of the low end rumble is truly amazing. I never fly without them. I found the installation instructions to be clear and easy to follow. Minor soldering required. I had a problem with strange noises in the left earcup 6 months ago and gave them a call which resulted in my sending them the headset for repair (mic went bad). For $5.00 they repaired it and upgraded the battery box and it's plug even though the unit was out of warranty. In my opinion, if you are happy with your headset now, this is a good way to get ANR for less money. Ivan Haecker ________________________________________________________________________________
From: "Howard RV-6A N55HW" <der_Jagdflieger(at)prodigy.net>
Subject: Re: IFR
Date: May 01, 2000
My RV-6A is used regularily in IMC. However, I strongly believe that anyone indulging in single- pilot IFR needs at least a wing-leveler A/P to ease the workload. I installed a S-TEC System 30 with Altitude Hold. It takes all of the work out of cross country and when things get busy, it's a life-saver in anything as twitchy (also know as very responsive to control inputs) as an RV. The System 30 can be coupled to either the Nav/LOC receiver or the GPS and its worth it. I looked at the Navaid unit but it has no altitude hold capabililty and the way they mount the roll servo (under the seat instead of out in the wing) induces pitch changes with heading corrections. No thanks. Howard RV-6A N55HW Flying 165 hours ----- Original Message ----- From: "Micah Froese" <mfroese(at)hotmail.com> Sent: Thursday, April 20, 2000 3:22 PM Subject: RV-List: IFR > > I'm new to this list and have a question for those already flying. Is the > RV 6 or 8 stable enough for instrument flight? I would not consider an > aircraft that is as fast as an RV without being able to go IMC as the need > arises. Is anyone out there flying IFR on a regular basis? Can it be done > without an autopilot? > > Micha Froese > > ________________________________________________________________________________
Date: May 02, 2000
My cousin had done this to his David Clarks a year or two ago and gave such a good review that I decided to jump in also. I have just completed mine a few weeks ago. I do not have a David Clark headset. I have a Flightcom 4DX. They have a kit that can fit many different existing sets. With their set you basically replace the entire guts. You only use the mike and the volume control. Bill Costello is right you have to be comfortable with wiring and soldering to complete this easily. If not, as with a lot of skills in homebuilding, can be learned with a little time. It took me a little over an hour to do once I understood what I needed to do. My Flightcoms needed the ground reversed from the volume control to one common ground. That is a slight basic difference in wiring just like a negative ground in a car opposed to a positive ground. David Clarks are straight forward with no changes. They also strongly suggest to install gel ear seals. Besides being much more comfortable, they seal your ear better to reduce the noise even before the ANR takes effect thus greatly improving the overall performance. I work in a high tech machine control industry. I see and do many new things. But sometimes you run into a simple device that just tickles your fancy. This was one for me. When you flip the switch to activate the ANR, the low frequency noise simply goes away. I kinda, sorta, smile and giggle with amazement. I guess there is still a little kid inside me. Price was $169.00 if I remember correctly. I had to wait a couple weeks for delivery because they were out of stock at the time. This was before Sun n Fun. I can now tease my cousin that I have a black pair of David Clarks that say Flightcom on them. Bill Jaugilas "William M. Costello" wrote: > > Hi Glenn, > > The company is called Headsets, Inc. I bought a kit at > Oshkosh > from a rep for the company: > Morris Morgan > Authorized Representative > ANR Headsets > 2955 Fawn Drive > Burllington, KY 41005 > 606-466-6022 > check out his site: > http://www.anr-headsets.com > > I moved shortly after Osh and haven't completed the > installation, > which I hope to do so soon. > > I recall a number of people saying they work great. > The installation is not falling-off-a-log easy. You have > to drill a > hole in the plastic earcup. You should have a > volt-ohmmeter and > know how to figure electrical circuits somewhat. Soldering > is also > required. > > I have built a few amatuer radio pieces, so have some > experience. > Don't get me wrong, it is not rocket science! And, if all > else fails > you can send the whole thing to them and they will do it > for a price. > > Speaking of price, I can't remember, but I think it was > $150 to > $200. > > Best regards, > > Bill Costello > WMCEnt(at)enteract.com > ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: Sky-Tec Starters
Bryan, I have the Sky-Tec Starter on my 160 HP -6. About 4 years on it and wouldn't leave home without it. Todd tmrv6(at)webcombo.net RV-6 Flying in Southern MD "Jones, Bryan D." wrote: > > Anyone have any experience with the Sky-Tec starters on Lycoming engines? > How about other "after-market" starters? > > Thanks > > Bryan Jones > Pearland, Texas ________________________________________________________________________________
Date: May 02, 2000
frank << 2. How is the F631A canopy bow attached to the Wd625B canopy side frame? According to the plans, there are 2 bolts that hold on the Wd622 canopy latch. But that doesn't seem like enough to me. Surely there must also be some rivets holding the canopy frame together? i used 4 rivits plus the 2 bolts on each side 3. What is the relative position of the instrument panel and the Wd616D canopy frame tube when the canopy is closed? I haven't trimmed my panel to shape yet, so I'm just not sure whether the tube should be forward or aft of the panel top when the canopy is closed. >> the rear tube will sit about 1" aft of the panel hope this helps, just did this last weekend know i'm fiberglassing the canopy weldment for stiffening scott tampa 6a tipper gooey, sticky, icky, fingers ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: FOR SALE: RV-6A WIng and Empennage Kits
Bob, Thanks for getting back to me. Please let me know ASAP if the deal falls through. I am presently negotiating a purchase of another rv6 kit. Thanks and good luck. Rick Gray 740-678-8031 (Ohio) ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: engine gurus please read
dear listers, i think i found an engine for my 6a, i know absoultly nothing about this engine other than what the seller is telling me, see below. please read his statements and give me your thoughts, that kind of money i would like an informed opionion. thanks, please remember this is going into a 6a , hopefully a constant speed prop. thanks, see below scott tampa 6a tipper Dear Scott, Yes, I still have the engine in my hangar. Some basic Background on this engine: The first question asked could be, what is the total time on the engine. That cannot be answered because the crankshaft and cases came from a Mooney engine whose cylinders I did not want to use (standard O-360 parallel valve). The Crankshaft is a Constant Speed and the drive lugs are set for a Hartzell. The lugs can be replaced to fit either a fixed pitch prop or a constant speed prop of different manufacturer. I went with the thicker barrel O-540 cylinders (same mounting and fit as O-360-essentially the same except the heavier barrel) because I wanted a heavier duty cylinder and because I had recently had standard O-360 cylinders crack on our PA-28-180 Cherokee. All overhaul parts are either Lycoming or Superior and are new, FAA certified. All the yellow tags are available. The O-540 Cylinders are Standard steel, but two cylinders are bored oversized .10 and are set opposite to each other for balance purposes. The rods are of course a matched set that came with the crank. The pistons are new; the standard 8.5-1 compression. The cam shaft is a reground which only says that the hardness existed to FAA specs, but was resurfaced by Superior Airparts. The Cases were resurfaced by ECI in Texas. What that means is that when an engine runs, the cases actually "move" opposite to each other and "fret". Fretting is not a cause for rejection, but you can't get a good seal (and thus oil leaks) if the fret marks are allowed to stay at overhaul and thus ECI puts them on there machine and they remove .001 of the material on each mating half so you get a clean and precise fit. The FAA Overhaul Engine shop that overhauled the engine is Gills Engines, located at Stead Airport (4SD), owned by Milton Gill. His phone number is (775) 972-0909. By the way, the oil pump is aluminum, not the sintered steel. The shotgun AD the FAA put out recently on the aluminum oil pump affected the O-235 to the O-360, but the FAA left the O-540 out to stay with the Aluminum. I left it up to Gill- and he went with Aluminum because in his experience, the Aluminum lasts longer and the O-235's to O-360's have been running with them for 35 years with no problems. If this upsets you, a change out is no big thing, but you need to know. What else can I answer? There are no accessories for this engine because I was going to buy ALL NEW. I have a set of Bendix mags and harness you can use for the SLICK magneto exchange program (worth $150.00 on a dual mag purchase). The Starter ring gear is for a HOT prop. Meaning: IF you wanted to heat the prop for icing, the ring gear has provision for that. If you are going to have a aircraft for day-VFR, I would exchange the ring gear for a lighter weight one. The rear accessory housing is the same standard housing you will find on the 235's through the O-360's. There is a provision for the Vacuum pump-that special gear pad is there as well as the housing for the constant speed prop governor and dual magnetos. The bottom Sump housing has the Carb/injector attach at the bottom versus either side or back feed which the RV-6 cowl requires. Here in Reno, The Flight Service Station is very picky on Experimental aircraft employing FAA certificated and name plated engines and then putting on non-STC'd parts for that engine. This is why the Lycoming data plate has been omitted from the sump. IF you want to put on a Slick mag that will work on your engine, but the O-360 data plate indicates a Bendix mag was used, the FAA inspector will flag the discrepancy and you will not be flying until you get that specific Bendix mag and install it; with all ADs complied with as well. This is ridiculous because the New Slicks are not only better than Bendix but far cheaper and lighter. What about that great Airflow Performance Fuel injection system you can get for an O-360. Don't install it on a "name-plated" O-360 because although the kit from Airflow performance is simply fantastic, it IS NOT FAA certificated. This situation got so bad on my Long Ez, that on the Lancair 235 I recently finished, I simply removed the data plate and had another one made up by a local engraver that stated the engine was built by my Grandfather! No Ad's from Grandpa! All nonstandard accessories APPROVED for flight and stated in the Engine log book and everything was NEW-New Slicks/harness, Carb, Starter and Alternator, Fuel pump! Let's go! Well, let me know if this thing would work for you or if you have other questions. The engine is in my humidity free hangar and no running time on it at all. The rocker covers and intake tubes are newly cad plated and the engine is painted Lycoming Grey. Sincerely, ________________________________________________________________________________
Date: May 02, 2000
I have run mine to the oil return line on the left rear cyl. It works great. This is a gravity return. I took the breather line and ran it just above one of the exhaust pipes so that it burns any residue so that it doesn't end up on the belly. Karl RV-8 Indy -----Original Message----- From: Vanremog(at)aol.com [SMTP:Vanremog(at)aol.com] Sent: Monday, May 01, 2000 04:27 Subject: Re: RV-List: engine questions ________________________________________________________________________________
Date: May 02, 2000
Yes you must drill the skins. This is a problem with the Q B -----Original Message----- From: AV8R [SMTP:jhth(at)email.msn.com] Sent: Monday, May 01, 2000 06:21 Subject: RV-List: RV-8 QB Landing Gear ________________________________________________________________________________
Date: May 02, 2000
Is the clearance there for a door to swing in AND be big enough for a big hand to reach the oil stick while griping it ? ( This reminds me of a coconut monkey trap....an coconut is chained to a tree with a hole large enough for the monkeys hand only, a few rocks are placed in the coconut and when the monkey grasps a rock he can't get his hand out). Also with all the plumbing for my air-oil sep. and cooling tubes for mags and skat tubing running all over the place....I would have liked to do this option but could'nt because of the junk under/around my door. Rv660wm(at)aol.com on 05/01/2000 07:06:30 AM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: Oil door latch alternatives? In a message dated 4/30/00 10:51:03 PM Eastern Daylight Time, cgalley(at)qcbc.org writes: << > Please share your thoughts on this. I spent enough time on this cowling > > (polyester resin type) and would really like to get it finished already. >> Glenn, Cy is right in that there is a higher pressure inside the cowl. Rich Jankowski opens his door "in" rather than out and I am doing it to mine also. You build a flange on the underside of the door, your hinge is concealed and the pressure makes the door seal tighter. Bernie Kerr, 6A N60WM ,inspection tomorrow, flying soon!!, SE Fla ________________________________________________________________________________
Subject: For sale - King Private Pilot Written Exam Videos
Date: May 02, 2000
Fellow listers: If any of you are working on the private exam, my videos are for sale for $75 and I will pay shipping. Respond off-list if interested. thanks Jack Rowell ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: oil cooler placement on baffling
I put mine there.Fabricated a plate with a angle aluimun joggle to bolt to engine case.This plate also acted as the rear baffle. I installed my cooler skinny side up. I went to all the bother to do this and the engine temps are within the green with the thing not connected. I removed the cooler and now have a plate that I could lift my engine with........RV-4's - I remember reading - do run cool anyway. Check the archives. I also figured I saved weight by removing the cooler, have less #8 hose running in a tight cowl and less chance of a oil line blowout. (I guess anything can be rationalized away ) Rvmils(at)aol.com on 05/01/2000 07:57:46 AM Please respond to rv-list(at)matronics.com Subject: RV-List: oil cooler placement on baffling I would like to place my oil cooler on the left rear baffle, there's not that much room on the firewall of the 4. Does anyone know where I could get plans are some pictures of the cooler done this way. Carey Mills N286RV ________________________________________________________________________________
Date: May 02, 2000
><bryan.jones@lyondell-citgo.com> > >Anyone have any experience with the Sky-Tec starters on Lycoming engines? >How about other "after-market" starters? > >Thanks > >Bryan Jones >Pearland, Texas I just put a Skytec on my O-360 and LOVE it. Spins like mad and a LOT lighter than the boat anchor Prestolite. I asked Skytec directly if they sell remanufactured starters, in hopes of saving a few bucks, but their email response said they don't normally carry them. I know they are out there in other channels. Brian Denk RV8 N94BD ________________________________________________________________________________
Subject: Re: Pitot tube mounting location
Date: May 02, 2000
> > >Does anyone know what the closest location to the fuselage that you can mount >your pitot tube is? I'm thinking of experimenting with a pitot + static tube >off of a piece of scientific equipment ( good for readings down to about 28 >knots ) but I need to mount it in the middle access cover which is about 42 >inches from the fuse. I'm just wandering if this will put me in the prop >wash. >Van's normally has you locate it about a foot farther out. > I mounted my heated pitot inboard from the access cover to avoid tiedown interference problems. That I may have mounted it too far inboard worried me for many months. In MY airplane the location has worked out fine. As far as I can tell my airspeed reads entirely normally. Larry Pardue Carlsbad, NM RV-6 N441LP http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Subject: oil separators
Date: May 02, 2000
I agree that you don't really need to put the oil back into the engine. As was stated, the stuff that collects is often 90% water and 10% oil. The water is likely somewhat acidic too. Throw it all out. On my 4 I tried to get away with just a breather tube. What a mess on the belly. Then I made a very simple can, about the size of a soft drink can, that attached to the breather line. Another line exited the cowl near the exhaust pipes...just like it did before. I loosely filled the can with a large piece of scrotchbrite pad. Screen, steel wool or other material would also work. It gives the vapors something to condense on, i.e. more surface area. Be sure to make your can easy to empty, although you really don't need to empty much very often. Acro will burp more oil though. No more oil on the belly. Obviously both lines are on top of the can...you don't want the stuff that condenses to drain out 'til you empty it. Be sure to put a "whistle slot" in your breather tube near the engine. That will prevent the previously mentioned water vapors from freezing the vent line shut and causing internal engine pressure to blow out your front seal. That would be bad... messy at best...possibly fatal if you lose all your oil over rough terrain. For those who don't know: a whistle slot (no, it doesn't really whistle) is a one inch slit, lengthwise not crosswise, cut in the breather line near the engine, i.e. where the engine heat keeps it warm. You can tape a paper towel over it loosely if it slobbers oil... however if you cut it with a razor it will seal itself unless pressure builds up. Then it will open and vent....just like it's supposed to. Vince in Indiana RV-4 HRII underway ________________________________________________________________________________
Date: May 02, 2000
Subject: Fuel Filter
http://www.moroso.com/catalog/CategoryDisplay.asp?CatCode=32041 Is the URL to Moroso performance parts. I used the filter with the finger screen & a Earls #8 to #6 AN adapter. Great product. There are three (at least) Rv's in the north east and mine that are running these filters. ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: RV4-List: Official Usage Guideline [Please Read] [Monthly
Posting] ________________________________________________________________________________
Date: May 02, 2000
In a message dated 5/2/00 10:22:55 AM Eastern Daylight Time, pcondon(at)csc.com writes: << Is the clearance there for a door to swing in AND be big enough for a big hand to reach the oil stick while griping it ? >> Well I doubt if you hand is as large as mine. On the hand bubba scale I must be a 8 or 9. I can palm a regulation basketball with ease.I have removed the oil stick with door in place without any difficulty. Bernie Kerr, 6A N60WM is now legal to fly as of this am, SE FLA ________________________________________________________________________________
Subject: Re: oil separators
Date: May 02, 2000
> For those who don't know: a whistle slot (no, it doesn't really whistle) is > a one inch slit, lengthwise not crosswise, cut in the breather line near the > engine, i.e. where the engine heat keeps it warm. You can tape a paper > towel over it loosely if it slobbers oil... however if you cut it with a > razor it will seal itself unless pressure builds up. Then it will open and > vent....just like it's supposed to. > > Vince in Indiana Excellent idea, and very timely. It was mentioned on the list recently, but Lycoming also made a point of telling me to fill the engine only to 6 quarts to prevent unnecessary oil loss. They said the 8 quart limit was to satisfy an FAA requirement for duration of flight with the most worn out engine imaginable. In his words, "the engine is happiest at 6 quarts". Russell Duffy Navarre, FL RV-8, sn-587, N174KT (I was hoping it really whistled) ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: Fwd: Re: New rumor
FYI. Our avionics should get quite a bit more accurate now. scot >>> May 1, 2000 >>> >>> STATEMENT BY THE PRESIDENT REGARDING THE UNITED STATES? DECISION TO STOP >>> DEGRADING GLOBAL POSITIONING SYSTEM ACCURACY >>> >>> THE WHITE HOUSE >>> >>> Office of the Press Secretary >>> >>> _______________________________________________________ >>> For Immediate Release May 1, 2000 >>> >>> STATEMENT BY THE PRESIDENT REGARDING >>> THE UNITED STATES? DECISION TO STOP DEGRADING >>> GLOBAL POSITIONING SYSTEM ACCURACY >>> >>> Today, I am pleased to announce that the United States will stop the >>> intentional degradation of the Global Positioning System (GPS) signals >>> available to the public beginning at midnight tonight. We call this >>> degradation feature Selective Availability (SA). This will mean that >>> civilian users of GPS will be able to pinpoint locations up to ten times >>> more accurately than they do now. GPS is a dual-use, satellite-based >>> system that provides accurate location and timing data to users worldwide. >>> My March 1996 Presidential Decision Directive included in the goals for >>> GPS >>> to: ?encourage acceptance and integration of GPS into peaceful civil, >>> commercial and scientific applications worldwide; and to encourage private >>> sector investment in and use of U.S. GPS technologies and services.? To >>> meet these goals, I committed the U.S. to discontinuing the use of SA by >>> 2006 with an annual assessment of its continued use beginning this year. >>> >>> The decision to discontinue SA is the latest measure in an on-going effort >>> to make GPS more responsive to civil and commercial users worldwide. Last >>> year, Vice President Gore announced our plans to modernize GPS by adding >>> two new civilian signals to enhance the civil and commercial service. >>> This >>> initiative is on-track and the budget further advances modernization by >>> incorporating some of the new features on up to 18 additional satellites >>> that are already awaiting launch or are in production. We will continue >>> to >>> provide all of these capabilities to worldwide users free of charge. >>> >>> My decision to discontinue SA was based upon a recommendation by the >>> Secretary of Defense in coordination with the Departments of State, >>> Transportation, Commerce, the Director of Central Intelligence, and other >>> Executive Branch Departments and Agencies. They realized that worldwide >>> transportation safety, scientific, and commercial interests could best be >>> served by discontinuation of SA. Along with our commitment to enhance GPS >>> for peaceful applications, my administration is committed to preserving >>> fully the military utility of GPS. The decision to discontinue SA is >>> coupled with our continuing efforts to upgrade the military utility of our >>> systems that use GPS, and is supported by threat assessments which >>> conclude >>> that setting SA to zero at this time would have minimal impact on national >>> security. Additionally, we have demonstrated the capability to >>> selectively >>> deny GPS signals on a regional basis when our national security is >>> threatened. This regional approach to denying navigation services is >>> consistent with the 1996 plan to discontinue the degradation of civil and >>> commercial GPS service globally through the SA technique. >>> >>> Originally developed by the Department of Defense as a military system, >>> GPS >>> has become a global utility. It benefits users around the world in many >>> different applications, including air, road, marine, and rail navigation, >>> telecommunications, emergency response, oil exploration, mining, and many >>> more. Civilian users will realize a dramatic improvement in GPS accuracy >>> with the discontinuation of SA. For example, emergency teams responding >>> to >>> a cry for help can now determine what side of the highway they must >>> respond >>> to, thereby saving precious minutes. This increase in accuracy will allow >>> new GPS applications to emerge and continue to enhance the lives of people >>> around the world. >>> > > ________________________________________________________________________________
Date: May 03, 2000
> Dwg 51 is sparse on details... >> > Frank. > RV-6, Marton, NZ > 1. The C603 canopy side skin. Will Cretsinger says in his notes that > the aft end of the C603 should be positioned 3/8" aft of the front face > of the cabin frame. That would make it extend 5/8" aft of the F631A of > the canopy frame. That sounds kindof odd to me. What's the reason? Will > the canopy plexiglass extend back that far too? Perhaps someone could > point me to a photo of this part of a completed canopy? Your side skin will need to stop at the front of the roll bar, so the 2 screws WILL go in the feet. I used #8 forward & #10's aft (under the skin). I did own #8 dimple dies. Will & the factory uses that term "canopy frame" wrong, I think. Drwg 51 shows the canopy glass cut aft of the forward face of the "roll bar". If you follow the drwg down you can see plexi has to be aft of the 603 side skin. that is what I did. Now Will talks about a targa strip that will cover the crack. I plane on getting wet & did without the strip so my glass goes past the side skin a little. > 2. How is the F631A canopy bow attached to the Wd625B canopy side > frame?> According to the plans, there are 2 bolts that hold on the Wd622 > canopy latch. But that doesn't seem like enough to me. Surely there must > also be some rivets holding the canopy frame together? I used 4 rivets , 2 on each side of the hold down gizmos. > 3. What is the relative position of the instrument panel and the > Wd616D canopy frame tube when the canopy is closed? I haven't trimmed my > panel to shape yet, so I'm just not sure whether the tube should be > forward or aft of the panel top when the canopy is closed. Your panel will be 1/4 below the extended line from the 601/668 subpanel & just forward of the tube. I think the best way to fit the frame is: BOW TO ROLL BAR clamp the bow its 1/4 inch from the roll bar that is bolted down & supported by the 632 brace. Make sure it lines up the roll bar . The plexi needs to fit both the bow & the roll bar. final fit with the splice plate at the top. SIDE FRAMES Bend the 625 sides to fit the longeron curves. attach the 1/8 shims to keep the frame above the longerons. Now attach the 625's to the bow. Leave room in the center for the 2 bolts on each side for the hooks. WELDMENT Clamp at least 3 extended angles from the 601 over the 668 past the tube on the weldment. The weldment needs to be clamped 5/8's from the 668. Fit the width of the weldment for the center splice plate. Now you can fit the 2 side splices for the side frames. Don Jordan -- 6a finish -- Arlington, Tx -- dons6a(at)juno.com ********************************************** ________________________________________________________________________________
Date: May 02, 2000
Subject: Gas Tank Test Tips
Hello, For a cheap and very effective leak detector, pick up a pint or two of "Mr. Bubble"...yep, the kids bubble toy. I had the official "SNOOP" so I could make a comparison. Snoop dries clean but considering the price savings, a quick rinse with the hose is no problem. Use the leak test to calibrate your gas caps. I turned the adjustment nut 1/4 turn past the point of no leaking. Once adjusted you may want to put some sealant along the base of the adjustment nut to keep leaks from coming up through the center. Regards, Vince Himsl Moscow, ID USA ________________________________________________________________________________
Subject: G Meter for sale
Date: May 02, 2000
Fellow Listers: I have a new 2 1/4" G meter that I decided not to install (just ran out of room on the panel). The first $175 gets it (shipping included). Contact me off list. Doug Weiler RV-4 =========== Doug Weiler Hudson, WI 715-386-1239 dougweil(at)pressenter.com ________________________________________________________________________________
From: Scott.Fink(at)Microchip.com.Tue, 02 May 2000 10:43:11.-0700(at)matronics.com
Subject: Re-Post of David Clark Headset ANR kit
Date: May 02, 2000
05/02/2000 10:50:04 AM This is a repost as it bounced yesterday. > > > headsetsinc.com is the manufacturer, the same ones can be ordered through a > distributer a little cheaper at: http://www.anr-headsets.com/ > The service at anr-headsets is great and the web site is now secure. I > ordered one set some time last year and skeptically tried it out, it is > WONDERFULL! I since ordered a second set and have just (this past weekend) > converted over my other David-Clark H10-20 set and installed power supplies > in the plane so I have no need to use batteries. I highly recommend them. > I do have an awful lot of electronics experience (I am an EE), but one of > the software engineers (bit head) who hardly knows not to grab the hot end > of a soldering iron converted his headset successfully as well, so I think > that most people should be able to do the conversion. > > Scott Fink > > > The instructions are > excellent and the service is good. Contact: 800-876-3374, > www.headsetsinc.com. I don't have one, but am going to order one next month > (credit card needs to cool off)! > > Bill Christie, RV8A Wings, Phoenix > > > Hi, > > Is anyone familiar with a kit that will upgrade a set of David Clark > > headsets to noise cancelling types? > > -Glenn Gordon > > >------------------- ________________________________________________________________________________
Subject: Re: Instruments
Date: May 02, 2000
> 5-2-00 > > HI'' > I enjoyed meeting many of you fellows, with your beautifull RV's..; It > was nice to meet > Sam Buchanan, thanks for the tips you gave me on connecting the > Nav-aid.. > Have a question, on Instruments for my pannel; oon the primary > Insutrments, should > I buy the Ligthted ones? Vacumm or Electric...there is a big > difference in prices.. Bert, I vote for all electric - keeps you from having to plumb lines for vacuum system. One thing I have learned is that EVERYTHING you add to this project adds time - often more than you think and in ways you don't expect. There's something to be said for keeping it simple. As far as lighting, I declined internal lighting where possible and assured that all instrument lighting etc. was connected to a dimmer. I have heard that reflection of lights off the canopy can be a problem. Good luck, Jerry Carter My RV-8A Web Site: http://www.rv8asite.homestead.com/mainpage.html ________________________________________________________________________________
Date: May 02, 2000
From: "Builder's Bookstore" <winterland(at)rkymtnhi.com>
Subject: Occum's Razor and fuel pressure
The is a mathmatical postulate called Occum's Razor (I think that's what it's called) that says: For any problem, start with the simplest possible solution and then work towards the most complex. These are good words, and not just for mathematicians, but for the rest of us as well. Over the past 2 months I've been plagued by a fuel pressure problem, that even with a lot of help from right here on this list, I just couldn't figure out. The indicated pressure would slowly fluctuate all over the scale but finally end up at zero by the end of each flight. (Or in other words, when it got too close to zero, I made it the end of the flight.) I looked for blocked vents and lines, removing and inspecting every one of them, and the boost pump and gascolator too. Everything was clean. I replaced the FP sender (at no charge) which Mitchell said was a bit off. I tested each fuel port for flow and pressure using a manual FP guage. Everything was absolutely clean and worked, except that zero FP indication 15 minutes into each flight. All that was left was the guage itself and the engine driven pump. I really hesitated to pull the mechanical pump. It was new when I installed it and has less than 100 hours. It would have also been the most expensive and difficult part to deal with. I decided to pull both the sender and guage and send them once again back to Mitchell, this time as a set for inspection and calibration. On removing it, I discovered that the power lead into it was loose at the oil pressure gauge, the place from where the FP power comes. The nut on the guage was half unwound on the oil pressure guage terminal. My oil pressure gauge always gave consistent and proper readouts. I was leary that this was the culprit since the intermittency during ground testing came with just hose removal and reinstallation, without getting anywhere near the gauge or causing any shaking or vibration that would have altered the contact of the lead to the gauge. But, anyway, I tightened the lead nut, this time with a lock washer, and retested the system. A steady 4 lbs with the boost pump, up to a steady 9 lbs with the engine on. Closed the fuel valve; down to 1 lb. Open the fuel valve; back to 9 lbs. Same on the other tank. Closed up the cowl and decided to stay real close to the airport. During almost an hour's flight it stayed at 9 lbs as solid as a rock. Switching tanks, prolonged steep banks, 3-4 Gs; everything seems OK. (For good this time, I hope) A lot of brain power from a lot of people went into trying to figure out this problem. The answer turned out to be the simplest solution there could possibly be. So simple that not a single person including myself ever thought about it. It is true that even the most complex problem have the simplest solutions. Thanks to everyone for your help. Andy Builder's Bookstore http://www.buildersbooks.com RV-6A N-5060 flying (again, finally) RV-X (waiting to do it again) ________________________________________________________________________________
Date: May 02, 2000
Subject: 6/6A QB deliveries
After reading a recent post about a conversation someone had with Van at SNF regarding the long lead times for 6/6A QB kits, and Van's response that he wasn't aware of the problem, I was fairly stunned to get a letter from Van today admitting the problem and his lack of awareness of it. AND - that they were speeding up production on these kits and that the kit destined for me would now be shipped sometime between 5/15 and 5/24. It was originally scheduled to be shipped "June/July" Apparently my garage is going to be full of large airplane parts a lot sooner than I thought. I guess it's time to finish that empennage! Robert Dickson -6A emp (accelerated) ________________________________________________________________________________
From: bcbraem(at)home.com.with.ESMTP (InterMail vM.4.01.02.00 201-229-116)
Date: May 02, 2000
pcondon(at)csc.com wrote: > > > I put mine there.Fabricated a plate with a angle aluimun joggle to bolt to > engine case.This plate also acted as the rear baffle. I installed my cooler > skinny side up. I went to all the bother to do this and the engine temps are > within the green with the thing not connected. I removed the cooler and now have > a plate that I could lift my engine with........RV-4's - I remember reading - > do run cool anyway. Check the archives. I also figured I saved weight by > removing the cooler, have less #8 hose running in a tight cowl and less chance > of a oil line blowout. (I guess anything can be rationalized away ) > > Mr. Condon may have a good point in that with engines that have a good supply of cooling air, an oil cooler may not be needed. As most of the regular list readers already know, I run an IO-540-EXP at 322 HP with a sealed plenum intake/exhaust system. I have to place a "baffle" over the "radiator" section of the oil cooler that blocks somewhere between 1/3 - 1/2 of the airflow (I don't have the dimensions here at home, they're at the hangar) thru the cooler to get oil temps. in the normal range, even during a prolonged climb--tho none of my climbs are really "prolonged"--10,000' in 3-4 min. This summer, I plan to disconnect the oil cooler and put the engine thru her paces and see what the oil temps turn out to be. I might be running an add for a used oil cooler and plumbing at very good price--It'll fit a -360. Boyd RV S6 Osprey, FL demonstrated aileron rolls, today, for some visitors--they may never go back to Disney, again! ________________________________________________________________________________
Date: May 02, 2000
jack, contact me off list. interested in exam materials!!!!! ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: rudder cracks, caulk, etc.
Charlie and Tupper England wrote: > > > Has anyone found the ideal solution (short of a new rudder) to stopping > cracks in the rudder at the stiffeners on existing a/c which did not > have caulk applied during assy? > > Stop-drilling has proven to be only a stop-gap solution. > > I suppose I can gently pry the cracks open & get some caulk in, but that > makes me uncomfortable. > > Has anyone tried something like 'GREAT STUFF' spray foam insulation? If > there aren't any corrosion issues, I think it will be a lot easier to > get into the rudder, lighter, & it sticks like nothing I've ever seen. > > Thanks > > Charlie > > flying -4 > > Charlie-- Tho I have the -6 with the big engine, I got cracks on the left side of the rudder and the upper left elevator at the LEADING edge rivets at the last (first forward) position of the stiffeners. They occurred at about 75 hrs--stop drilled with a 1/16" drill and no further problems at 190 hrs. I called Van's in a panic and then just said "stop drill 'em". I have seen them -4's and other -6's and it seems to be an accepted but not important problem with the original design. The plane has been to 250 mph and done Sportsman aerobatics with no problems. Of course, by now, everyone should know to put a glop of RTV under the leading and trailing edges of the rudder and elevator stiffeners. Boyd RV S6 ________________________________________________________________________________
Subject: RV6A for sale
Date: May 02, 2000
I posted this yesterday but never saw it show up on the list! OK, one more time. Pat Kirkpatrick is offering his RV6A for sale: 1999 RV6A 113 TT airframe 1723 SMOH O-320E3D, 150hp, 130 STOH Props Inc. wood prop Full panel w/ gyros Collins microline nav/com (no indicator) loran King KT78 digital xponder dual landing lights with wig/wag flasher circuit intercom gray/charcoal interior airframe not painted elec flaps, elevator and rudder trim 5/2000 condition inspection underway $60k OBO aircraft located at AEG, Albuquerque, NM Contact Pat Kirkpatrick at pat.w.kirkpatrick(at)intel.com (505)892-4929 home (505)893-1990 work (505)321-5410 cell ________________________________________________________________________________
Subject: RV-4 Accident NM
Date: May 02, 2000
Listers: Doug Reeves alerted me to an RV-4 accident that occurred Friday at the Los Alamos, NM airport. The NTSB report at http://www.faa.gov/avr/aai/s_0501_y.txt indicates the pilot was injured. Rumor is that it was a loss of directional control type accident. Lister Steve Judd, who lives in Los Alamos sent the following comments to me: >Los Alamos airport is on a mesa, much like the "USS Sedona" if you read >Sam Buchanan's travelogue, except there's a big mountain at one end and a >big restricted area immediately adjacent. The airport is one-way and the >winds can be tricky on normal days, but spring winds here can be quite >strong and gusty, and Friday was no exception. Steve has put a newspaper photo of the wreckage up on his website at http://www.ffd2.com/rv/rv4crash.jpg In the photo, it appears most of the damage was to the landing gear, and firewall forward. They identify the pilot as Marilyn Hughes of Pagosa Springs, CO. Larry Pardue Carlsbad, NM RV-6 N441LP http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: RV-4 Accident NM
> Los Alamos, NM airport. The NTSB report at > http://www.faa.gov/avr/aai/s_0501_y.txt indicates the pilot was I saw the report and am glad Marilyn is OK. But one thing really struck me. There were seven (7) accidents involving experimental aircraft listed under May 2nd, some serious; some like Marilyn's, not so serious. Is this typical? 7 accidents? .....on a Tuesday? I've been around flying experimentals for a long time but never imagined this kind of record. Be carefull out there guys. Andy ________________________________________________________________________________
Date: May 02, 2000
Larry Pardue wrote: > > > Listers: > > Doug Reeves alerted me to an RV-4 accident that occurred Friday at the > Los Alamos, NM airport. The NTSB report at > http://www.faa.gov/avr/aai/s_0501_y.txt indicates the pilot was injured. > Rumor is that it was a loss of directional control type accident. > > Lister Steve Judd, who lives in Los Alamos sent the following comments to > me: > > >Los Alamos airport is on a mesa, much like the "USS Sedona" if you read > >Sam Buchanan's travelogue, except there's a big mountain at one end and a > >big restricted area immediately adjacent. The airport is one-way and the > >winds can be tricky on normal days, but spring winds here can be quite > >strong and gusty, and Friday was no exception. > > Steve has put a newspaper photo of the wreckage up on his website at > > http://www.ffd2.com/rv/rv4crash.jpg > > In the photo, it appears most of the damage was to the landing gear, and > firewall forward. They identify the pilot as Marilyn Hughes of Pagosa > Springs, CO. Is that guy in the photo STOMPIN' on the poor RV-4???? Talk about kickin' a good plane when it is down..... Sam Buchanan ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: engine questions
> In a message dated 4/30/00 7:11:15 PM Pacific > Daylight Time, > rv8(at)ispchannel.com writes: > > << I also plan to use an air oil separator, and > need a > place to run the drain oil back to the engine. > Would there be any problem > with tapping the governor > plate hole for 1/4" NPT, and installing a hose > fitting for the return oil? > I'm assuming there's > just crankcase pressure under the plate. Is that > right? >> My engine came out of a TriPacer. The Oil Separator on the TriPacer did exactly as you say. It had a tapped hole in the cover on the hole for where the governor drive mounts. I still have the plate somewhere as I converted to Constant Speed. I have my oil separator running back to the engine into a tapped hole that Lycoming had in the case. Works great after 540+ hours of flying. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, Flying So. CA, USA http://SoCAL_WVAF.tripod.com Send instant messages & get email alerts with Yahoo! Messenger. ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: IFR
Howard RV-6A N55HW wrote: > > > My RV-6A is used regularily in IMC. However, > I strongly believe that anyone indulging in single- > pilot IFR needs at least a wing-leveler A/P to ease > the workload. > > I installed a S-TEC System 30 with Altitude Hold. > It takes all of the work out of cross country and > when things get busy, it's a life-saver in anything > as twitchy (also know as very responsive to control > inputs) as an RV. > > The System 30 can be coupled to either the Nav/LOC > receiver or the GPS and its worth it. I looked at the > Navaid unit but it has no altitude hold capabililty and > the way they mount the roll servo (under the seat instead > of out in the wing) induces pitch changes with heading > corrections. No thanks. Well.......not necessarily. It is very possible to mount the servo under the seat with a careful installation and not have any pitch coupling. There are, however, several other servo mounting options. Mine is mounted midwing in the inspection bay, and the slickest installation I have seen is on a wingtip rib: http://home.HiWAAY.net/~sbuc/journal/navaid.html The S-Tec is a nice system, but the Navaid works very well at 1/3 the price, and couples beautifully with a handheld GPS or panel mounted radio. Sam Buchanan (RV-6 withdrawal in progress....engine apart for overhaul....details on the web site) "The RV Journal" http://home.hiwaay.net/~sbuc/journal ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: IFR
Howard RV-6A N55HW wrote: > The System 30 can be coupled to either the Nav/LOC > receiver or the GPS and its worth it. I looked at the > Navaid unit but it has no altitude hold capabililty and > the way they mount the roll servo (under the seat instead > of out in the wing) induces pitch changes with heading > corrections. No thanks. > > Howard RV-6A N55HW Flying 165 hours Have to totally disagree with you Howard the Navaid works great under the seat. ________________________________________________________________________________
Subject: Re: G Meter for sale
Date: May 02, 2000
> > I have a new 2 1/4" G meter that I decided not to install (just ran out of > room on the panel). The first $175 gets it (shipping included). > > Contact me off list. > > Doug Weiler Sold it. ________________________________________________________________________________
Subject: Los Alamos Correction
Date: May 02, 2000
Listers: Regarding my post on the Los Alamos RV-4 accident. Contrary to what I said, the NTSB report says NO injuries. I was thrown off by the format where it kind of says injuries: Pilot 1, but then it is a government form. I am sorry for the error. The photo certainly did not look like there would have been any injuries. Larry Pardue Carlsbad, NM ________________________________________________________________________________
Date: May 02, 2000
Subject: Bill Of Sale Questions
I got my bill of sale from Vans yesterday and I'm not sure how to finish filling it out. I assume I have to put the price of the kit and N number in, but under the purchaser block its got a block that says and to executers, administraters, and assigns to have and to hold singularly the said aircraft forever, and warrents the title therof. (It sounds like they want me to marry the plane) Does anything go in this blank and does it have to be notarized. I took it to a Notary and he coudn';t figure out where to put the seal. Do I need to sign it anywhere. Better yet, could someone scan a Bill of sale that the FAA has accepted. Thanks. Dave Beizer RV6A Final Assembly ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: an515-8r8 torque value
In a message dated 4/29/00 10:34:25 PM Pacific Daylight Time, vhimsl(at)turbonet.com writes: << Checked archives and AC43.13 for torque values for an an515-8r8 screw, specifically the gas tank access plate ones. Does anyone know the correct value(s) >> Here are the torque values (+00%/-20% tol) we used at my last company for light duty fastenings using steel (or stainless steel) screws into steel threads. If you are going into aluminum threads multiply by .75 (75%). If going into a thread form having a prevailing torque feature, add the prevailing torque to the tightening torque in the table to get the final torque. thread lb-in 0-80 1.0 2-56 2.0 4-40 5.5 6-32 10.0 8-32 20.0 10-32 28.0 -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: Bill Of Sale Questions
PLTDBEEZER(at)aol.com wrote: > > I got my bill of sale from Vans yesterday and I'm not sure how to finish > filling it out. I assume I have to put the price of the kit and N number in, > but under the purchaser block its got a block that says I just put my N number in and left the price blank. > > > and to executers, administraters, and assigns to > have and to hold singularly the said aircraft forever, and warrents the title > therof. > > (It sounds like they want me to marry the plane) Does anything go in this > blank and does it have to be notarized. I took it to a Notary and he > coudn';t figure out where to put the seal. Do I need to sign it anywhere. > Better yet, could someone scan a Bill of sale that the FAA has accepted. > Thanks. Mine was signed by Van, no other signature required. Gary Zilik RV-6A N99PZ_ ________________________________________________________________________________
Date: May 02, 2000
The word "his" or "hers" goes in that spot. Mine was not signed, because it came from my lender...but the FAA took whatever they submitted, and gave me my N-number. Paul Besing RV-6A (197AB) Arizona http://www.lacodeworks.com/besing/ Finish Kit ----- Original Message ----- From: <PLTDBEEZER(at)aol.com> Sent: Tuesday, May 02, 2000 7:25 PM Subject: RV-List: Bill Of Sale Questions > > I got my bill of sale from Vans yesterday and I'm not sure how to finish > filling it out. I assume I have to put the price of the kit and N number in, > but under the purchaser block its got a block that says > > and to executers, administraters, and assigns to > have and to hold singularly the said aircraft forever, and warrents the title > therof. > > (It sounds like they want me to marry the plane) Does anything go in this > blank and does it have to be notarized. I took it to a Notary and he > coudn';t figure out where to put the seal. Do I need to sign it anywhere. > Better yet, could someone scan a Bill of sale that the FAA has accepted. > Thanks. > > Dave Beizer > RV6A Final Assembly > > ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: Thanks!
Listers: RV4 builder Jefferey Sharman at Nutree airport was good enough to ask me to fly with him in his beautiful and very airworthy RV4. He has made some real utilitarian changes to his bird, many make it more comfortable and also safer. Just had to say THANKS JEFF! I am building a 4 and sometimes you just get run down due to the never ending list of things to accomplish along the construction path. After a couple of hours in this airplane and the fine instructions and insight from Jeff, I AM WORKING HARD AT THE PROJECT AGAIN. First RV ride, first Roll in an aircraft .......WOW. I recommend all you guys and gals building a project. Go out now and find someone who will give you a ride. It will kick your A## like nothing other. You will be energized and ready to work even harder at that project. I was impressed at the ease of flight, the light yet very responsive controls. It feels like a heavier airplane, not troubled by a little turbulence, holds true once it is trimmed up. What a fantastic feeling and to think that soon I will be flying one too!! David Aronson RV4 N504RV ________________________________________________________________________________
Date: May 02, 2000
Subject: Re: Odyssey Battery
Listers: Has anyone used the small format Odyssey battery that Van's sells. I am looking at a smaller battery to help make room for my Airflow Performance booster pump. At 7 3/16 X 3 1/8 X6 5/8 this is the smallest with 600 cranking amps. A bit expensive too. Would appreciate anyone who has past experience with this battery to respond. David Aronson RV4 N504RV ________________________________________________________________________________
Date: May 03, 2000
Hi Dave, Just got my 'official' Registration yesterday...You can send it in 'as-is' from Van's, Notary not required, and other than Van's, no other signatures are required either. If you have a reserved N number, you can fill that in. If the bill of sale is in your name only, and you'd like to add a co-owner, just add the name to the "Purchaser" block. I failed to do this as I wanted my wife as co-owner (I did ask the FAA to 'add' her when I sent the paperwork), and they sent me back the original Kit Bill of Sale. They asked me to add my wife's name to the purchaser block (they couldn't do it even though I asked). I did just that, returned it and got my registration here 2 weeks later. Paul > > I got my bill of sale from Vans yesterday and I'm not sure how to >finish >filling it out. I assume I have to put the price of the kit and N >number in, >but under the purchaser block its got a block that says > >and to executers, administraters, and >assigns to >have and to hold singularly the said aircraft forever, and warrents >the title >therof. > >(It sounds like they want me to marry the plane) Does anything go in >this >blank and does it have to be notarized. I took it to a Notary and he >coudn';t figure out where to put the seal. Do I need to sign it >anywhere. >Better yet, could someone scan a Bill of sale that the FAA has >accepted. >Thanks. > >Dave Beizer >RV6A Final Assembly > > ________________________________________________________________________________
Date: May 03, 2000
Subject: Re: Navaid RV6 Seat Instal Again
> What exactly could a guy do to install the Navaid Servo under the seat of > an RV6 to have the least impact on the pitch travel of the stick? Mount the servo as far forward as possible (but don't let the servo mechanism hit/rub the push rod). Mine is mounted under the pax seat pretty much per the Navaid plans, works fine, no observed pitch coupling. Tim ****** Tim Lewis -- Springfield VA RV-6A N47TD - First Flight 18 Dec 99 TimRV6A(at)earthlink.net http://www.geocities.com/timrv6a ________________________________________________________________________________
Date: May 03, 2000
Subject: Re: Proseal life
to all who use out of date proseal: this is Glenn again responding to your "out of date proseal" question. I say this with reservation but here goes anyway. When I worked for K.C.Aviation in Dallas we routinely had "proseal parties" where in all out of date proseal was mixed and after hardening you can simply throw it away in the trash can because it is no longer a hazard to the environment. We had proseal that was two years old that would set up. However that said, let me say that as a preface to your question any proseal that takes more than 24 to 48 hours to set up is probably not going to set up. As a test take a little white and some black and mix on a piece of scrap aluminum. If it sets up in 24 hours I would use it on my tanks. If it does not set up you may get it to "set" by using heated air on it. You heat it up for about 5 minutes and then check on it later in about 4 hours. If this has taken a "set" I might use it on aerodynamic fairings, but in all honesty I would throw that can of sealant out. Another word of caution. Upon opening the black can mix it thouroghly by itself as it is like oil and water, and if you do not mix thix your proseal will not set up even if it new. Glenn archive this one --- Ski2001a(at)aol.com wrote: > > Has anyone had any experience using Proseal that is > out of date. I am ready > to seal my tanks and have a quart of Proseal from > Van's that has never been > opened but the date on the can says it is 6 months > out of shelf life. What > happens when the Proseal get old? Should I just can > this and buy a new batch? > > > Tom Clark 80525 > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > Send instant messages & get email alerts with Yahoo! Messenger. ________________________________________________________________________________
From: "Fesenbek, Gary" <Gary.Fesenbek(at)marykay.com>
Subject: 2000 - The worse safety year in RV history?
Date: May 03, 2000
1996 - 12 incidents, 9 fatalities 1997 - 19 incidents, 3 fatalities 1998 - 12 incidents, 8 fatalities 1999 - 22 incidents, 4 fatalities As of the end of April... 2000 - 7 incidents, 4 fatalities In past years the RV accidents start happening in April and are heaviest during the summer so we have only just barely begun to be in prime accident period. Gary Fesenbek RV6A Dallas, TX ________________________________________________________________________________
Date: May 03, 2000
> What exactly could a guy do to install the Navaid Servo under the > seat of an > RV6 to have the least impact on the pitch travel of the stick? > > I have seen this mentioned a few times. Is there some thing in > particular to > look out for when chosing the final location of the servo? > > Norman Hunger Norm, Check this out: http://home.HiWAAY.net/~sbuc/journal/navaid.html I changed my plans to do an under-the-seat mount to Sam's wingtip mount. Installation went smoothly - I can't imagine an easier way in either flying or building stages. _Only_ down side is no in-flight adjustments. :) Mike Thompson Austin, TX -6 N140RV (Reserved) Fuselage Send instant messages & get email alerts with Yahoo! Messenger. ________________________________________________________________________________
Date: May 03, 2000
> What exactly could a guy do to install the Navaid Servo under the seat of an > RV6 to have the least impact on the pitch travel of the stick? > > I have seen this mentioned a few times. Is there some thing in particular to > look out for when chosing the final location of the servo? Just instal it per the plans. I'm not sure what problem other people might be having, but everyone around here that has installed one (myself included) have absolutely ZERO pitch input problems. In fact, I even installed mine one rib closer to the center than shown (brain fart on my part, I had cut out half of the rib before I realized it was the wrong one) and the arm pushes even more fwd/aft than stock and there is STILL no pitch input. So instal as shown, cut the *correct* rib, insure a straight run with no binding, and enjoy. Ed Bundy - Eagle, ID RV6A - First flight 11/20/96 ebundy(at)micron.net ________________________________________________________________________________
Date: May 03, 2000
glenn williams wrote: > > to all who use out of date proseal: > > this is Glenn again responding to your "out of date > proseal" question. I say this with reservation but > here goes anyway. When I worked for K.C.Aviation in > Dallas we routinely had "proseal parties" where in all > out of date proseal was mixed and after hardening you > can simply throw it away in the trash can because it > is no longer a hazard to the environment. We had > proseal that was two years old that would set up. > However that said, let me say that as a preface to > your question any proseal that takes more than 24 to > 48 hours to set up is probably not going to set up. As > a test take a little white and some black and mix on a > piece of scrap aluminum. If it sets up in 24 hours I > would use it on my tanks. If it does not set up you > may get it to "set" by using heated air on it. You > heat it up for about 5 minutes and then check on it > later in about 4 hours. If this has taken a "set" I > might use it on aerodynamic fairings, but in all > honesty I would throw that can of sealant out. Another > word of caution. Upon opening the black can mix it > thouroghly by itself as it is like oil and water, and > if you do not mix thix your proseal will not set up > even if it new. > > Glenn > > archive this one > > --- Ski2001a(at)aol.com wrote: > > > > Has anyone had any experience using Proseal that is > > out of date. I am ready > > to seal my tanks and have a quart of Proseal from > > Van's that has never been > > opened but the date on the can says it is 6 months > > out of shelf life. What > > happens when the Proseal get old? Should I just can > > this and buy a new batch? > > > > > > Tom Clark 80525 > > > > > > > > through > > > > http://www.matronics.com/archives > > http://www.matronics.com/emaillists > > > > Matronics! > > > > > > > > > > > > Send instant messages & get email alerts with Yahoo! Messenger. > ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Subject: Thanks!
Date: May 03, 2000
Hey Dave, I expect a ride from you when *you're* done! -- Scott VanArtsdalen, MCSE (fuselage finally out of the jig!!!) Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: David Aronson [mailto:daronson(at)cwnet.com] Sent: Tuesday, May 02, 2000 9:19 PM To: rv-list(at)matronics.com Subject: Re: RV-List: Thanks! RV4 builder Jefferey Sharman at Nutree airport was good enough to ask me to fly with him in his beautiful and very airworthy RV4. He has made some real utilitarian changes to his bird, many make it more comfortable and also safer. Just had to say THANKS JEFF! I am building a 4 and sometimes you just get run down due to the never ending list of things to accomplish along the construction path. After a couple of hours in this airplane and the fine instructions and insight from Jeff, I AM WORKING HARD AT THE PROJECT AGAIN. First RV ride, first Roll in an aircraft .......WOW. I recommend all you guys and gals building a project. Go out now and find someone who will give you a ride. It will kick your A## like nothing other. You will be energized and ready to work even harder at that project. I was impressed at the ease of flight, the light yet very responsive controls. It feels like a heavier airplane, not troubled by a little turbulence, holds true once it is trimmed up. What a fantastic feeling and to think that soon I will be flying one too!! David Aronson RV4 N504RV ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Subject: Re: IFR
Date: May 03, 2000
-----Original Message----- From: Jerry Springer <jsflyrv(at)teleport.com> Date: Tuesday, May 02, 2000 7:55 PM Subject: Re: RV-List: IFR > >Howard RV-6A N55HW wrote: > >> The System 30 can be coupled to either the Nav/LOC >> receiver or the GPS and its worth it. I looked at the >> Navaid unit but it has no altitude hold capabililty and >> the way they mount the roll servo (under the seat instead >> of out in the wing) induces pitch changes with heading >> corrections. No thanks. >> >> Howard RV-6A N55HW Flying 165 hours > > >Have to totally disagree with you Howard the Navaid works >great under the seat. > And the reason it works great under the seat is that in tracking or wing-leveling mode the corrective input displacements are very small. If you run the servo arm over its entire range you will see that there is indeed a small component of displacement in the direction of the pitch axis. However, in real life, the servo arm is making very small inputs -- way, way too small to cause you to bust your +/- 200 feet allowance in assigned altitude. To achieve minimum pitch coupling the NavAid autopilot servo coupling rod should lie as close as possible to parallel to the aileron push-pull tubes. Note that any single-axis autopilot will loose a little altitude in a commanded turn. I believe that maintaining altitude in an RV is just as difficult as maintaining heading, so in time I may upgrade my NavAid Devices A/P to a two-axis A/P. Dennis Persyk 6A finishing kit Hampshire, IL C38 ________________________________________________________________________________
Date: May 03, 2000
Subject: Re: 2000 - The worse safety year in RV history?
How do the RV' accident profiles compair to other aircraft. We have about 2400 flying aircraft in the RV group. This has to be the highest in terms of fininshed homebuilt types. Are these accident numbers hi or low in terms of the overall number of aircraft completed and the number of actual flying hours........ Gary.Fesenbek(at)marykay.com on 05/03/2000 08:08:21 AM Please respond to rv-list(at)matronics.com Subject: RV-List: 2000 - The worse safety year in RV history? 1996 - 12 incidents, 9 fatalities 1997 - 19 incidents, 3 fatalities 1998 - 12 incidents, 8 fatalities 1999 - 22 incidents, 4 fatalities As of the end of April... 2000 - 7 incidents, 4 fatalities In past years the RV accidents start happening in April and are heaviest during the summer so we have only just barely begun to be in prime accident period. Gary Fesenbek RV6A Dallas, TX ________________________________________________________________________________
Date: May 03, 2000
Subject: rudder cracks, caulk, etc.
Several recent posts deal with cracking of the rudder/elevator trailing edges. The recommendation to prevent this is to add RTV during assembly to help brace the transition point between the stiffeners and the skin at the trailing edge. I built my rudder and, like many others, I remembered the RTV only after I riveted the skeleton to the rudder. Now that I'm done with beating my head against the wall, I've been trying to find a way to add the RTV to a completed rudder. I have an idea that I want to run by the list. I'm thinking of taking a piece of 1/8 ID plastic tubing and taping it to a small-diameter welding rod so that I can position the tubing. I would then squirt RTV about 2-3 inches into the end of the tube, run the rod/tube through the rod-end-bearing nutplate holes (3/8 inch?) in the rudder spar, position the tubing end at the trailing edge at each stiffener, and then use compressed air to blow the RTV out of the tubing end into the gap. I'll try it this weekend and let the list know the results. It sure would have been easier to do it right the first time. I'll remember it on the elevators ;-) Bob RV-8AQ Elevators ________________________________________________________________________________
Date: May 03, 2000
Subject: Drilling the firewall
After struggling with drilling the firewall and watching some other folks go nuts with the holes for the larger pass throughs like the cabin heat box, I found a good tool for this. Starret makes a series of sheet metal hole saws which I bought to drill odd sized holes my instrument panel, and I found that they do a burr free job on stainless. The arbor is fairly expensive, about $12, as are the larger saws, but it is far cheaper than trying to buy the large Unibits or Carbide hole cutters. I get them fom J&L Industrial Supply. Chris Browne -6A firewall forward Atlanta ________________________________________________________________________________
Date: May 03, 2000
Subject: -6A antennas
I know from the archives that many have put a variety of antennae under the forward cockpit floor. I want to mount the transponder or comm antenna near the battery box, but was wondering if the engine exhaust is hard on the plastic parts of the anenna. Chris Browne -6A Atlanta ________________________________________________________________________________
Subject: Spin-on oil filter question
Date: May 03, 2000
I am about to order my engine from Aero Sport Power. I am trying to decide what options I should order. I'm going to buy an O320-D2A from him and I'd like to get the spin-on oil filter. Will it fit in an RV-4 that does not have the cut-out on the firewall for the prop governer? Thanks in advance! -- Scott VanArtsdalen, MCSE Network Administrator Union Safe Deposit Bank 209-946-5116 ________________________________________________________________________________
Date: May 03, 2000
> > > How do the RV' accident profiles compair to other aircraft. We have about 2400 > flying aircraft in the RV group. This has to be the highest in terms of > fininshed homebuilt types. > Are these accident numbers hi or low in terms of the overall number of > aircraft completed and the number of actual flying hours........ > I guess we can do a lot of playing with statistics. I also own a Citabria. The current number of flying RVs and Citabrias are very similar (around 2300-2400). According to the NTSBs web site, Citabrias had the following accident rate: 1998: 12 total, 3 fatals 1999: 25 total, 4 fatals 2000: 6 total so far These numbers are very similar to the quoted rate on RV aircraft. I would dare say that RVs are typically flown many more hours per year than the average Citabria. Keep in mind that a new RV flies nearly every day (lets say at least 300 per year). American Champion built 91 airplanes in 1999. Just food for thought. Doug Weiler MN Wing RV-4 finishing ________________________________________________________________________________
Date: May 03, 2000
Subject: Re: Spin-on oil filter question
Yes. I used the smaller spin-on too for a little bit more room. svanarts(at)unionsafe.com on 05/03/2000 01:13:10 PM Please respond to rv-list(at)matronics.com Subject: RV-List: Spin-on oil filter question I am about to order my engine from Aero Sport Power. I am trying to decide what options I should order. I'm going to buy an O320-D2A from him and I'd like to get the spin-on oil filter. Will it fit in an RV-4 that does not have the cut-out on the firewall for the prop governer? Thanks in advance! -- Scott VanArtsdalen, MCSE Network Administrator Union Safe Deposit Bank 209-946-5116 ________________________________________________________________________________
Date: May 03, 2000
> I'm going to buy an O320-D2A from him and I'd like to get the spin-on oil > filter. Will it fit in an RV-4 that does not have the cut-out on the firewall > for the prop governer? Not a specific answer, but maybe this might help. I have an 0-360 A4M in my 6A. The spin on filter barely fits without a firewall cutout with a couple modifications. First, I have to cut off the tacked on nut type fitting on the filter. I leave the tabs for safety wire on Then to remove or tighten it I had to modify a filter wrench so the strap comes off on one end, then gets wrapped around the filter from the top and then re-attached with a clevis pin. It probably adds about 10 minutes to the time it takes to do a filter change. Andy ________________________________________________________________________________
Subject: Filtered air box
Date: May 03, 2000
I'm getting ready to order the finish kit for my RV-4. I was wondering, why would I want a filtered air box? Thanks again for your help! -- Scott VanArtsdalen, MCSE Network Administrator Union Safe Deposit Bank 209-946-5116 ________________________________________________________________________________
Date: May 03, 2000
Subject: Navaid altitude hold
Norman Hunger wrote: > > > > I believe that maintaining altitude in an RV is just as difficult as > > maintaining heading, so in time I may upgrade my NavAid Devices A/P to a > > two-axis A/P. > > You might want to wait and see what Navaid comes up with later in the year. > They are working on an altitude hold system that will be a separate > installation. It sounds like completed aircraft will be able to add it. > > I have lots of faith that it will be the lowest cost two axis autopilot > around as again they will not try for certification. Don't hold your breathe waiting for the altitude hold from Navaid. When I first approached Navaid three years ago about my project, the altitude hold option was "to be available later this year"......... There is an altitude hold device that you might want to check out: http://members.aol.com/_ht_a/ccady/eztrim.htm I have no experience with this unit, but apparently an RV-4 is using it with good results. Sam Buchanan "The RV Journal" http://home.hiwaay.net/~sbuc/journal ________________________________________________________________________________
Date: May 03, 2000
From: General Equipment Company <general(at)generalequip.com>
Subject: Re: remove from mailing list
ABAYMAN(at)aol.com wrote: > > frank > > << 2. How is the F631A canopy bow attached to the Wd625B canopy side frame? > According to the plans, there are 2 bolts that hold on the Wd622 canopy > latch. But that doesn't seem like enough to me. Surely there must also > be some rivets holding the canopy frame together? > > i used 4 rivits plus the 2 bolts on each side > > 3. What is the relative position of the instrument panel and the Wd616D > canopy frame tube when the canopy is closed? I haven't trimmed my panel > to shape yet, so I'm just not sure whether the tube should be forward or > aft of the panel top when the canopy is closed. >> > > the rear tube will sit about 1" aft of the panel > > hope this helps, just did this last weekend > know i'm fiberglassing the canopy weldment for stiffening > > scott > tampa > 6a tipper gooey, sticky, icky, fingers > ________________________________________________________________________________
Date: May 03, 2000
I put the NavAid servo under the passenger seat of my RV6A and did find pitch changes. I changed the activating rod (got a longer one) and connected it to the bottom of the pilot's stick. No more pitch changes. The only very minor problem was that the longer rod touched the end of the manual aileron trim lever...I merely shortened that a small amount to gain the clearance needed and I can now rotate the NavAid's trim control so that the ailerons go stop to stop with absolutely no elevator movement either on the ground or in flight. RV6A Flying Salida,CO ________________________________________________________________________________
Date: May 02, 2000
Subject: Philosophy: Occum's Razor
Almost. As far as I know, Occam's Razor is a philosophical postulate, that says - Of all the valid arguments, that are based on true assumptions - and therefor represent a truth - the real truthful one is the simplest argument. Ronen. -----Original Message----- From: Builder's Bookstore <winterland(at)rkymtnhi.com> Date: Tuesday, May 02, 2000 9:42 PM Subject: RV-List: Occum's Razor and fuel pressure | |The is a mathmatical postulate called Occum's Razor (I think that's what it's |called) that says: For any problem, start with the simplest possible solution |and then work towards the most complex. | |These are good words, and not just for mathematicians, but for the rest of us |as well. | |Over the past 2 months I've been plagued by a fuel pressure problem, that even |with a lot of help from right here on this list, I just couldn't figure out. |The indicated pressure would slowly fluctuate all over the scale but finally |end up at zero by the end of each flight. (Or in other words, when it got too |close to zero, I made it the end of the flight.) | |I looked for blocked vents and lines, removing and inspecting every one of |them, and the boost pump and gascolator too. Everything was clean. I replaced |the FP sender (at no charge) which Mitchell said was a bit off. I tested each |fuel port for flow and pressure using a manual FP guage. Everything was |absolutely clean and worked, except that zero FP indication 15 minutes into |each flight. All that was left was the guage itself and the engine driven |pump. I really hesitated to pull the mechanical pump. It was new when I |installed it and has less than 100 hours. It would have also been the most |expensive and difficult part to deal with. I decided to pull both the sender |and guage and send them once again back to Mitchell, this time as a set for |inspection and calibration. | |On removing it, I discovered that the power lead into it was loose at the oil |pressure gauge, the place from where the FP power comes. The nut on the guage |was half unwound on the oil pressure guage terminal. My oil pressure gauge |always gave consistent and proper readouts. I was leary that this was the |culprit since the intermittency during ground testing came with just hose |removal and reinstallation, without getting anywhere near the gauge or causing |any shaking or vibration that would have altered the contact of the lead to |the gauge. | |But, anyway, I tightened the lead nut, this time with a lock washer, and |retested the system. A steady 4 lbs with the boost pump, up to a steady 9 lbs |with the engine on. Closed the fuel valve; down to 1 lb. Open the fuel valve; |back to 9 lbs. Same on the other tank. Closed up the cowl and decided to stay |real close to the airport. During almost an hour's flight it stayed at 9 lbs |as solid as a rock. Switching tanks, prolonged steep banks, 3-4 Gs; everything |seems OK. (For good this time, I hope) | |A lot of brain power from a lot of people went into trying to figure out this |problem. The answer turned out to be the simplest solution there could |possibly be. So simple that not a single person including myself ever thought |about it. | |It is true that even the most complex problem have the simplest solutions. | |Thanks to everyone for your help. | |Andy |Builder's Bookstore |http://www.buildersbooks.com | |RV-6A N-5060 flying (again, finally) |RV-X (waiting to do it again) | | | | | ________________________________________________________________________________
Date: May 03, 2000
Subject: Re: Filtered air box
"Van Artsdalen, Scott" wrote: > > > I'm getting ready to order the finish kit for my RV-4. I was wondering, why > would I want a filtered air box? Thanks again for your help! > > Scott-- Look at the leading edges/surfaces of cowls/wings/stabilizers of airplanes that have been flown and visualize the poor lives of all those insects and pieces of dirt. Without a filter, you are betting that none of that inhuman detritus gets into your carb or injector body and causes your engine to crash quicker than a MicroSoft program. In return, you get increased airflow and performance. With a filter, you are sacrificing a bit of performance for a bit more safety. The other choice is to have have two routes of air: (1) filtered induction air while on the ground; and (2) a closeable ram air door that can be opened in flight for increased performance when supposedly safe from the the fuel induction system destroyers. You, Scott, are charged with this holy quest to determine the ultimate rulers of far flung galaxies: filter foam or insects. Boyd. RV S6 ________________________________________________________________________________
Date: May 03, 2000
Subject: trim tab gap
Fellow builders, I'm finishing up my trim tab and was wondering how much of a gap you ended up with between the trim tab inboard end and elevator. The plans call for 1/8" min, mine is more like 1/4". Gary Gunn, AZ RV-6 (empennage almost done) ________________________________________________________________________________
From: "Sally and George" <aeronut58(at)hotmail.com>
Subject: Re: RV-8 QB Landing Gear
Date: May 03, 2000
Don't know about quick builds. On the Rv-8 kit, these holes must be drilled before any of the forward bottom skins are put in place. George #80006 Waiting for finish kit ----- Original Message ----- From: AV8R <jhth(at)email.msn.com> Sent: Monday, May 01, 2000 6:20 PM Subject: RV-List: RV-8 QB Landing Gear > > Anyone know of any "tricks" for drilling the outboard landing gear wear > plate holes on the RV-8 QB? Seems impossible to me without drilling holes > in the F-850/F-851 fuselage skins. > > John Hall > RV-8QB > > ________________________________________________________________________________
From: "Jones, Bryan D." <bryan.jones@lyondell-citgo.com>
Date: May 03, 2000
I once read about an RV that ingested a bird in the carb air intake. The FAB was what kept the bird out of the carb and the RV flying... Low probability, but another thing to consider. Bryan Jones -8, N765BJ Pearland, Texas -----Original Message----- From: bcbraem(at)home.com.with.ESMTP [mailto:bcbraem(at)home.com.with.ESMTP] Sent: Wednesday, May 03, 2000 4:16 PM Subject: Re: RV-List: Filtered air box 201-229-116) with ESMTP "Van Artsdalen, Scott" wrote: > > > I'm getting ready to order the finish kit for my RV-4. I was wondering, why > would I want a filtered air box? Thanks again for your help! > > Scott-- Look at the leading edges/surfaces of cowls/wings/stabilizers of airplanes that have been flown and visualize the poor lives of all those insects and pieces of dirt. Without a filter, you are betting that none of that inhuman detritus gets into your carb or injector body and causes your engine to crash quicker than a MicroSoft program. In return, you get increased airflow and performance. With a filter, you are sacrificing a bit of performance for a bit more safety. The other choice is to have have two routes of air: (1) filtered induction air while on the ground; and (2) a closeable ram air door that can be opened in flight for increased performance when supposedly safe from the the fuel induction system destroyers. You, Scott, are charged with this holy quest to determine the ultimate rulers of far flung galaxies: filter foam or insects. Boyd. RV S6 ________________________________________________________________________________
Date: May 03, 2000
Subject: Re: Wire dimension
In a message dated 5/3/00 5:51:14 PM Eastern Daylight Time, foxinsocks(at)mediaone.net writes: << Hi, I need to size some holes/grommets/firewall sheilds for some electric wire runs through the firewall. Since I haven't purchased the wire yet, can someone please tell me the outside diameters of #2 and #4 Mil spec wire? Please reply off list. Thanks, Glenn Gordon >> I think this one's listworthy... The #2 wire I used had an outside diameter (OD) of 3/8" The #4 wire had an OD of 5/16". KB ________________________________________________________________________________
Subject: Filtered air box (rephrased)
Date: May 03, 2000
Okay, I think I phrased my original question wrong. Let me clarify. I know the carb needs an air filter. No offense intended to everyone but I do know that air to the carb needs to be filtered. I may be dumb but I'm not stupid! :-) My question is: why the FAB? It's an option on the finish kit order form. Since it's an option I figured that there are other options. My question really is, why would I want a FAB rather than the squarish filter I used to have on my Champ? I've seen both types on RV's. -- Scott VanArtsdalen, MCSE Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: bcbraem(at)home.com.with.ESMTP [mailto:bcbraem(at)home.com.with.ESMTP] Sent: Wednesday, May 03, 2000 2:16 PM To: rv-list(at)matronics.com Subject: Re: RV-List: Filtered air box vM.4.01.02.00 201-229-116) with ESMTP "Van Artsdalen, Scott" wrote: > > > I'm getting ready to order the finish kit for my RV-4. I was wondering, why > would I want a filtered air box? Thanks again for your help! > > Scott-- Look at the leading edges/surfaces of cowls/wings/stabilizers of airplanes that have been flown and visualize the poor lives of all those insects and pieces of dirt. Without a filter, you are betting that none of that inhuman detritus gets into your carb or injector body and causes your engine to crash quicker than a MicroSoft program. In return, you get increased airflow and performance. With a filter, you are sacrificing a bit of performance for a bit more safety. The other choice is to have have two routes of air: (1) filtered induction air while on the ground; and (2) a closeable ram air door that can be opened in flight for increased performance when supposedly safe from the the fuel induction system destroyers. You, Scott, are charged with this holy quest to determine the ultimate rulers of far flung galaxies: filter foam or insects. Boyd. RV S6 ________________________________________________________________________________
Date: May 03, 2000
Subject: Re: trim tab gap
I cut the tabs off & installed small rib ends. Ended up with 5/32" gap L.Adamson RV6A finish ________________________________________________________________________________
Date: May 03, 2000
> I'm getting ready to order the finish kit for my > RV-4. I was wondering, why > would I want a filtered air box? Thanks again for > your help! > -- > Scott VanArtsdalen, MCSE I am sure that there are many reasons more than I am going to list. 1. Keep dirt out of the engine. (Make the engine last longer.) 2. Increased manifold pressure. The FAB that Van's sells is a "Divergent duct" design. It works the OPPOSITE of a venturi. Instead of speeding the air up and decreasing pressure like a venturi, it Slows air down and INCREASES pressure. This will allow greater manifold pressure and more power. Tests that I have run at 10,000 feet indicate that there is a 0.5" increase in manifold pressure at cruise speed. The method that I used was to slow the aircraft to near stall speed. With the prop in high RPM, I advanced the throttle to full open and read the digital manifold pressure. The airplane accelerated to cruise speed and I read the manifold pressure again. The manifold pressure was now 1/2" higher. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, Flying So. CA, USA http://SoCAL_WVAF.tripod.com Send instant messages & get email alerts with Yahoo! Messenger. ________________________________________________________________________________
Date: May 03, 2000
Subject: Adell clamps
I am getting ready to start wiring soon and was wondering what the most common size adell clamps to buy for our purposes? Also how many approx. of each size should I buy? Thanks John Danielson Fuselage ________________________________________________________________________________
Date: May 03, 2000
David Aronson wrote: > > Listers: > > Has anyone used the small format Odyssey battery that Van's sells. I am looking at > a smaller battery to help make room for my Airflow Performance booster pump. At 7 > 3/16 X 3 1/8 X6 5/8 this is the smallest with 600 cranking amps. A bit expensive > too. > > Would appreciate anyone who has past experience with this battery to respond. > > David Aronson > RV4 N504RV David, I've been flying behind one for the past seven months. (actually, it's mounted behind me in the luggage compartment.) I've not had any problems with it. Not only did it save 10 pounds over the RG-25XC, it has a few more cranking amp available. I'm very satisfied!! Chuck Brietigam, RV-3's forever!! ________________________________________________________________________________
Subject: Re: Filtered air box (rephrased)
Date: May 03, 2000
> >Okay, I think I phrased my original question wrong. Let me clarify. I know >the carb needs an air filter. No offense intended to everyone but I do know >that air to the carb needs to be filtered. I may be dumb but I'm not >stupid! :-) My question is: why the FAB? It's an option on the finish kit >order form. Since it's an option I figured that there are other options. >My question really is, why would I want a FAB rather than the squarish >filter I used to have on my Champ? I've seen both types on RV's. > Well first, many RV-4's do not have any air filter at all. If you agree, as I do, that filtering is a very good idea, the reason to go with the FAB is that it is a very efficient filter system. The very large filter area, as compared to the squarish filter you refer to, as well as the "decelerate the air" induction design makes for minimal if any MP loss. I believe the rule of thumb is that induction systems with a filter will cause about a 1" MP loss. Van's design should do much better. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: May 03, 2000
Yes, the oil filter is above the cut-out (at least in my Aero-Sport 0-360). There is 1" clearance from the back of a regular oil filter to the firewall. Doug Weiler ________________________________________________________________________________
Date: May 03, 2000
Scott The RV4 has plenty of room to get a spin on filter on and off, with no interferance with the firewall. It is a fairly messy job thought. I think someone on this list had a good tip a while ago, when you are ready to change a filter, use a punch or screwdriver to make a small hole in the filter in the top rear, loosen the filter a half turn, allow the oil to run into some sort of container and then put a plastic bag over the filer and remove it. I tried this this spring and ALOT less mess Joe Hine RV4 C-FYTQ Subject: RV-List: Spin-on oil filter question > > I am about to order my engine from Aero Sport Power. I am trying to decide > what options I should order. I'm going to buy an O320-D2A from him and I'd > like to get the spin-on oil filter. Will it fit in an RV-4 that does not > have the cut-out on the firewall for the prop governer? Thanks in advance! > > -- > Scott VanArtsdalen, MCSE > Network Administrator > Union Safe Deposit Bank > 209-946-5116 > > ________________________________________________________________________________
Date: May 03, 2000
Subject: VFR/IFR Experimental Certification
Hi, Since I can't afford the IFR panel I would like to put in my RV-6, I am opting for a more economical VFR panel with room for expansion to IFR when funding permits. When it comes time to certify the airplane, will I have to certify it VFR? How do I later change it to IFR certification? Is it possible to certify it as IFR even though I don't yet have the appropriate Navaids on board? Even the most basic no gyro paneled Cessna 150's have day/night VFR/IFR on their placards even though they don't have the equipment on board to actually fly IFR. Can I do the same thing? Thanks, Glenn Gordon ________________________________________________________________________________
Date: May 03, 2000
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
>David Aronson wrote: > >> >> Listers: >> >> Has anyone used the small format Odyssey battery that Van's sells. I am looking at >> a smaller battery to help make room for my Airflow Performance booster pump. At 7 >> 3/16 X 3 1/8 X6 5/8 this is the smallest with 600 cranking amps. A bit expensive >> too. >> >> Would appreciate anyone who has past experience with this battery to respond. >> >> David Aronson >> RV4 N504RV There are a variety of 17 a.h. recombinant gas batteries which can be found on the following links. These batteries can be purchased from a variety of battery specialty shops. We have some little convenience store sized Battery Patrols around Wichita that handle these batteries for $60-70 each. Powersonic: PS-12180 http://www.power-sonic.com/12180.html Hawker: Check out the first 6 batteries on this page . . . http://www.hepi.com/products/genesis/genprod.htm Panasonic: particularly the LCRD1271P http://www.panasonic.com/industrial_oem/battery/battery_oem/images/pdf/lc-rd 1217p.pdf http://www.panasonic.com/industrial_oem/battery/battery_oem/chem/seal/seal.htm Yuasa-Exide: Check out the NP18-12B at this site . . . http://www.yuasa-exide.com/np-prod.html Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( still understand knothing. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: May 03, 2000
> > interferance with the firewall. It is a fairly messy job thought. > > I think someone on this list had a good tip a while ago, > when you are ready > to change a filter, use a punch or screwdriver to make a > small hole in the > filter in the top rear, loosen the filter a half turn, > allow the oil to run > into some sort of container and then put a plastic bag over > the filer and > remove it. I tried this this spring and ALOT less mess > When I change my filter, I use a one-gallon plastic milk jug with the bottom cut out. I get the open bottom up under the filter so I can "catch" both the filter and the oil. The milk jug has a handle to hang on to and is flexible enough to bend around hoses and other interferences. If I am careful, I can change the filter without spilling a drop. Mark Nielsen RV-6; 477 hours ________________________________________________________________________________
Subject: Re: Adell clamps
Date: May 03, 2000
> I am getting ready to start wiring soon and was wondering what the most > common size adell clamps to buy for our purposes? Also how many approx. of > each size should I buy? What a great question, the only problem is that there is no way to answer it precisely. Every builder will wire his/her airplane differently and use different materials. Personally, I used the Van's Accessory Catalog and ordered about 10 of each size before I started. There are certain sizes that I needed more of (and i'm not done yet), but I had enough to get started on any task I might encounter so as to keep my work flowing. So my advice is to get maybe 6 of each then buy more as you need them. Another less costly tactic would be to buy a half dozen of every other size, then at least you're close on any needs. Lastly, don't forget the plastic verson... they are useful for some of the smaller wiring applications. You can obtain these from AAMR ( http://hometown.aol.com/aamrelectr/index.html) or any common electronics supply outlet. Have fun, Randy Lervold RV-8, #80500, fwf stuff www.pacifier.com/~randyl Home Wing VAF ________________________________________________________________________________
Date: May 03, 2000
Subject: Re: Navaid altitude hold
In a message dated 5/3/00 12:30:09 PM Pacific Daylight Time, sbuc(at)hiwaay.net writes: << Don't hold your breathe waiting for the altitude hold from Navaid. When I first approached Navaid three years ago about my project, the altitude hold option was "to be available later this year". >> Jim Ham from Porcine Associates is a member of our chapter (663 in Livermore, CA) and he is the guy designing the future Navaid altitude hold device. It will work by driving the elevator trim servo (only the most recent vintage MACs) and he is on the Prototype Rev 4 unit at the moment. The unit was/is being tested in Roger Hansen's "Dragon Master" RV-6 and still needs some tweaking. I'm holding out for it, but probably not this year. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: May 03, 2000
Subject: Re: Oil door latch alternatives?
At Sun & Fun I picked up the pround push botton lock exactly lke the Cessna uses on the oil door on their front cowl for $20. My griedn has already installed his and it is great, very clean, firm and much smaller than the larger toggle type locks or the wing cam locks. Great Choice. Gary Gembala Still working on tail feathers ________________________________________________________________________________
Date: May 04, 2000
Subject: Re: Adel clamps
In a message dated 5/3/00 6:44:48 PM Pacific Daylight Time, JDaniel343(at)aol.com writes: << I am getting ready to start wiring soon and was wondering what the most common size Adel clamps to buy for our purposes? Also how many approx. of each size should I buy? >> You'll need half a dozen of each from -2 thru -5. A dozen from -6 thru -7. Probably two dozen of the -8 and a smattering of the others. I'd just buy a dozen of each size to start ; ) -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: May 03, 2000
Robert, You have any suggestions for the Rocket with the IO-540? Are the ones below as good for the extra cylinders? Tom G. > Powersonic: PS-12180 > http://www.power-sonic.com/12180.html > > Hawker: Check out the first 6 batteries on this page . . . > http://www.hepi.com/products/genesis/genprod.htm > > Panasonic: particularly the LCRD1271P > > http://www.panasonic.com/industrial_oem/battery/battery_oem/images/pdf/lc-rd > 1217p.pdf > > http://www.panasonic.com/industrial_oem/battery/battery_oem/chem/seal/seal.h tm > > Yuasa-Exide: Check out the NP18-12B at this site . . . > http://www.yuasa-exide.com/np-prod.html ________________________________________________________________________________
From: bcbraem(at)home.com.with.ESMTP (InterMail vM.4.01.02.00 201-229-116)
Date: May 04, 2000
Subject: Re: VFR/IFR Experimental Certification
Glenn & Judi wrote: > > > Hi, > > Since I can't afford the IFR panel I would like to put in my RV-6, I am > opting for a more economical VFR panel with room for expansion to IFR > when funding permits. > > When it comes time to certify the airplane, will I have to certify it > VFR? How do I later change it to IFR certification? Is it possible to > certify it as IFR even though I don't yet have the appropriate Navaids > on board? Even the most basic no gyro paneled Cessna 150's have > day/night VFR/IFR on their placards even though they don't have the > equipment on board to actually fly IFR. Can I do the same thing? > > Thanks, > Glenn Gordon > > Glenn- You do not have to "certify" anything other than to list your IFR equipment on your flight plan (/G, /A, /R--filed VFR with 50 hrs of XC (cross-country) time and 10 hrs XC in a IFR "equipped" airplane, or other ways before you begin IFR instruction. See FAR 61.65. Your instructor will verify your equipment and experience. After passing your IFR flight test, you can fly IFR anytime, anywhere, unless a specific type-rating is required for the airplane. A lot of pilots get their IFR ticket so they can fly up, thru the clouds to be "on top" and then get back down again. RV's, because of their wing loading, tend to be a bit bumpy in IFR minor turbulence. You do need gyros (AI, DG, Turn Coorinator/AutoPilot) plus VOR/GS/MB(/GPS an additional flavor, but non-precision, for now) to have an IFR airplane along with a few other sundry items like an analog CDI "needle" display, altho this is currently under review and digital displays may be equivalent, altho this is not universally allowed, depending on your local FSDO (is that a sentence, or what). Read FAR 61.65. Boyd. RV S6 ________________________________________________________________________________
Date: May 04, 2000
Subject: Re: engine HELP please read
dear listers, i think i found an engine for my 6a, i know absoultly nothing about this engine other than what the seller is telling me, see below. please read his statements and give me your thoughts, that kind of money i would like an informed opionion. thanks, please remember this is going into a 6a , hopefully a constant speed prop. thanks, see below scott tampa 6a tipper Dear Scott, Yes, I still have the engine in my hangar. Some basic Background on this engine: The first question asked could be, what is the total time on the engine. That cannot be answered because the crankshaft and cases came from a Mooney engine whose cylinders I did not want to use (standard O-360 parallel valve). The Crankshaft is a Constant Speed and the drive lugs are set for a Hartzell. The lugs can be replaced to fit either a fixed pitch prop or a constant speed prop of different manufacturer. I went with the thicker barrel O-540 cylinders (same mounting and fit as O-360-essentially the same except the heavier barrel) because I wanted a heavier duty cylinder and because I had recently had standard O-360 cylinders crack on our PA-28-180 Cherokee. All overhaul parts are either Lycoming or Superior and are new, FAA certified. All the yellow tags are available. The O-540 Cylinders are Standard steel, but two cylinders are bored oversized .10 and are set opposite to each other for balance purposes. The rods are of course a matched set that came with the crank. The pistons are new; the standard 8.5-1 compression. The cam shaft is a reground which only says that the hardness existed to FAA specs, but was resurfaced by Superior Airparts. The Cases were resurfaced by ECI in Texas. What that means is that when an engine runs, the cases actually "move" opposite to each other and "fret". Fretting is not a cause for rejection, but you can't get a good seal (and thus oil leaks) if the fret marks are allowed to stay at overhaul and thus ECI puts them on there machine and they remove .001 of the material on each mating half so you get a clean and precise fit. The FAA Overhaul Engine shop that overhauled the engine is Gills Engines, located at Stead Airport (4SD), owned by Milton Gill. His phone number is (775) 972-0909. By the way, the oil pump is aluminum, not the sintered steel. The shotgun AD the FAA put out recently on the aluminum oil pump affected the O-235 to the O-360, but the FAA left the O-540 out to stay with the Aluminum. I left it up to Gill- and he went with Aluminum because in his experience, the Aluminum lasts longer and the O-235's to O-360's have been running with them for 35 years with no problems. If this upsets you, a change out is no big thing, but you need to know. What else can I answer? There are no accessories for this engine because I was going to buy ALL NEW. I have a set of Bendix mags and harness you can use for the SLICK magneto exchange program (worth $150.00 on a dual mag purchase). The Starter ring gear is for a HOT prop. Meaning: IF you wanted to heat the prop for icing, the ring gear has provision for that. If you are going to have a aircraft for day-VFR, I would exchange the ring gear for a lighter weight one. The rear accessory housing is the same standard housing you will find on the 235's through the O-360's. There is a provision for the Vacuum pump-that special gear pad is there as well as the housing for the constant speed prop governor and dual magnetos. The bottom Sump housing has the Carb/injector attach at the bottom versus either side or back feed which the RV-6 cowl requires. Here in Reno, The Flight Service Station is very picky on Experimental aircraft employing FAA certificated and name plated engines and then putting on non-STC'd parts for that engine. This is why the Lycoming data plate has been omitted from the sump. IF you want to put on a Slick mag that will work on your engine, but the O-360 data plate indicates a Bendix mag was used, the FAA inspector will flag the discrepancy and you will not be flying until you get that specific Bendix mag and install it; with all ADs complied with as well. This is ridiculous because the New Slicks are not only better than Bendix but far cheaper and lighter. What about that great Airflow Performance Fuel injection system you can get for an O-360. Don't install it on a "name-plated" O-360 because although the kit from Airflow performance is simply fantastic, it IS NOT FAA certificated. This situation got so bad on my Long Ez, that on the Lancair 235 I recently finished, I simply removed the data plate and had another one made up by a local engraver that stated the engine was built by my Grandfather! No Ad's from Grandpa! All nonstandard accessories APPROVED for flight and stated in the Engine log book and everything was NEW-New Slicks/harness, Carb, Starter and Alternator, Fuel pump! Let's go! Well, let me know if this thing would work for you or if you have other questions. The engine is in my humidity free hangar and no running time on it at all. The rocker covers and intake tubes are newly cad plated and the engine is painted Lycoming Grey. Sincerely, ________________________________________________________________________________
Date: May 04, 2000
Subject: hartwell latch
Hi, Are builders generally using one or two of the hartwell latches to secure down the oil door on the cowl? Thanks, Glenn Gordon ________________________________________________________________________________
Date: May 04, 2000
Subject: Re: RV8-List Digest: 0 Msgs - 05/03/00
I'm just getting started and came up with an idea i think will be helpful to other newbies. To get proper alignment of the HS-810 and HS-814 I used a clear plastic laminating sheet (contact paper would probably work also but is stretchier) and carefully laid out the edge dimensions (3.25") and vertical and horizontal centerlines. After quadruple checking my measurements I removed the paper backing and set the HS-810 and HS-814 onto the adhesive side. I transferred the whole setup to the HS-602s (already properly clamped to my work surface) and lined up the vert. and horiz. centerlines. After multiple checks I taped the assembly in place and proceeded to drill the appropriate holes. This process worked extremely well and I am well pleased with the results. Tim Nell RV-8 19.5 whole hours (about 1%) ________________________________________________________________________________
Date: May 04, 2000
Subject: Re: hartwell latch
I used one hartwell latch on mine. Terry E. Cole N468TC ________________________________________________________________________________
Date: May 04, 2000
The answer to this is the same as the answer to the question "How much wire do I need?" The answer is "just a little more than you have on hand!" I used about a dozen of the -3, -4, -5, and -6. Another popular size was -8, -10, -12, and -16. These fit the tubes of the engine mount. Then there was a sprinkling of the other sizes. Take you best estimate and order some. It won't matter in the end anyway. You'll always need just one more of a size that you don't have. Make friends with the FBO so you can purchase a few here and there. Randy Pflanzer N417G RV-6 "Weight and Balance this weekend, Fed inspection next week" ----- Original Message ----- From: <JDaniel343(at)aol.com> Sent: Wednesday, May 03, 2000 8:17 PM Subject: RV-List: Adell clamps > > I am getting ready to start wiring soon and was wondering what the most > common size adell clamps to buy for our purposes? Also how many approx. of > each size should I buy? > > Thanks > John Danielson > Fuselage > > ________________________________________________________________________________
Subject: Odyssey Battery - Voltage Regulator
Date: May 04, 2000
Isn't the Odyssey a dry cell type battery? If so, what type voltage regulator does it require? Same as for lead-acid battery? Bryan Jones -8 N765BJ Pearland, Texas -----Original Message----- From: Chuck Brietigam [mailto:brietigam(at)earthlink.net] Sent: Wednesday, May 03, 2000 8:43 PM Subject: Re: RV-List: Odyssey Battery David Aronson wrote: > > Listers: > > Has anyone used the small format Odyssey battery that Van's sells. I am looking at > a smaller battery to help make room for my Airflow Performance booster pump. At 7 > 3/16 X 3 1/8 X6 5/8 this is the smallest with 600 cranking amps. A bit expensive > too. > > Would appreciate anyone who has past experience with this battery to respond. > > David Aronson > RV4 N504RV David, I've been flying behind one for the past seven months. (actually, it's mounted behind me in the luggage compartment.) I've not had any problems with it. Not only did it save 10 pounds over the RG-25XC, it has a few more cranking amp available. I'm very satisfied!! Chuck Brietigam, RV-3's forever!! ________________________________________________________________________________
Date: May 04, 2000
Vans went a lot of trouble designing a pressure recovery air box. There was lots of talk on it a few years ago in the RVator . At the speeds the RV's fly, the air burbles, bending the air input stream 90 degrees and the general air fluid dynamics around the carburator suggest a need for a constant velocity, pressure recovery vessle (air box). You need a duct (air box) to route the input air to the carb that won't disturb the air stream. You need to mate your lower cowl to the snoot of the air box. If you allow pressure to exist in the lower cowl area ( i.e. no air box) you effect the draft for you cooling and the exit air. This exit air requires a pressure differential from the air inlet on the top cowl......... There are a few more engineering reasons to run with it but this is my first cup of coffee..... svanarts(at)unionsafe.com on 05/03/2000 02:45:35 PM Please respond to rv-list(at)matronics.com Subject: RV-List: Filtered air box I'm getting ready to order the finish kit for my RV-4. I was wondering, why would I want a filtered air box? Thanks again for your help! -- Scott VanArtsdalen, MCSE Network Administrator Union Safe Deposit Bank 209-946-5116 ________________________________________________________________________________
Date: May 04, 2000
John, I had the same issue on my QB fuselage. Yes, you have to drill two holes through the skin in order to get the mounting holes for the wear plates drilled. Don't worry, you gear-leg intersection fairing will eventually cover these holes. While you at it, check you landing gear weldments, WD822-L & R to make sure that the angle, WD-822B is installed. See dwg 35 top right hand corner and read the note for Rev 1. Some of the early QB kits, (mine for example) did not have these. Regards, -Don RV8 NJ ________________________________________________________________________________
Date: May 04, 2000
Subject: Long Term Engine Storage
I just came across an excellent deal on a runout (2200 hrs) O-320 H2AD with good logs and no prop strike. It has had the T-mod done and has had the additive put in every 50 hours with oil change since new. It's still flying in a C-172 and comes with the Carb and Mags for $2,400. It runs and flys great and is run almost daily by a flight school. My plan is to use it in my RV-6A and hopefully squeeze a few hundred hours out of it while I'm getting out of financial shock from builing my plane, then I'll go with an overhaul. My question is this: What is the best way to prepare the engine for long term storage (probably 2 years)? I will probably keep it in my air conditioned garage. Thanks in advance for any suggestions. Eric Newton Long Beach, MS (Wings were shipped by Vans yesterday :-)) ________________________________________________________________________________
Date: May 04, 2000
Gary, Thanks for the info. Does Jim Ham's altitude-hold installation (as it is now) require that the NavAid servo be installed in the under-the-seat position, or will it work with the nerved servo installed in the wing? I am currently finishing an installation very similar to Sam B.'s, except that I am installing the servo to main rib #13, one inboard of the end rib. My thinking is that this position will still allow easy access and shortens the length of the rod to the bellcrank. Gary Baker RV-6 (Working on wings) N927MG (Reserved) Medina, OH > > In a message dated 5/3/00 12:30:09 PM Pacific Daylight Time, sbuc(at)hiwaay.net > writes: > > << Don't hold your breathe waiting for the altitude hold from Navaid. When > I first approached Navaid three years ago about my project, the altitude > hold option was "to be available later this year". >> > > Jim Ham from Porcine Associates is a member of our chapter (663 in Livermore, > CA) and he is the guy designing the future Navaid altitude hold device. It > will work by driving the elevator trim servo (only the most recent vintage > MACs) and he is on the Prototype Rev 4 unit at the moment. The unit was/is > being tested in Roger Hansen's "Dragon Master" RV-6 and still needs some > tweaking. I'm holding out for it, but probably not this year. ________________________________________________________________________________
Date: May 04, 2000
> > >Hi, > >Since I can't afford the IFR panel I would like to put in my RV-6, I am >opting for a more economical VFR panel with room for expansion to IFR >when funding permits. > >When it comes time to certify the airplane, will I have to certify it >VFR? How do I later change it to IFR certification? Is it possible to >certify it as IFR even though I don't yet have the appropriate Navaids >on board? Even the most basic no gyro paneled Cessna 150's have >day/night VFR/IFR on their placards even though they don't have the >equipment on board to actually fly IFR. Can I do the same thing? > Glenn, I don't have the exact wording, because it is in my airplane, but my limitations say something to the effect that IFR flight is not permitted unless the airplane is suitably equipped. That seems to pretty well cover it. My airplane was IFR equipped at the time of the inspection. Larry Pardue Carlsbad, NM RV-6 N441LP http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: May 04, 2000
Subject: Vision - not RV related
All, First I apologize for using this forum for this questions, but I'm sure I will get good input so here goes: I just got back from a visit to the eye doctor and the pain of selecting new glasses and options. One of the options was a coating for anti-reflective lenses - the specific product was Crizal. I wondered if eye care professionals that fly had an opinion on this. The glossy brochure has photos showing a great reduction around lights, but I wonder if this is a good thing when I may be looking for the bright light of something that may smite me from the sky. Thanks in advance. Becki Orndorff ________________________________________________________________________________
Date: May 04, 2000
Subject: Re: Long Term Engine Storage
Simplest way store is to locate a large ( 2 foot by 3 foot ) cookie sheet, position the engine upside down (carb up) on a large car tire and tighten all orfaces (oil dip stick, accessory area, ect) and start filling the case up with oil. You need'nt fill the sump all the way up ( when inverted). Make a mini-dip stick (popcicle stick) and stick your sump from the drain. Run a handle across the prop flange drive lugs and rotate the crank a few tens of turns. You want to fill the backbone of the engine up with oil ..this is the cam and tappets area.... drown it with oil. The oil also will drown the crank and piston skirts (and rods) too when the oil is added. Took me 9 qts of oil. A bit messy but after you rotate the crank there is a sweet spot where everything alligns and oil stops weeping. With everything bathed in mineral aviation oil you will not have any worries. This is a old-timers trick. There are many exotic ways to prepair a engine for storage but This is 100% workable. ( If I could find a 50 gallon drum, I would do long term storage that way-filled up with oil ) Great price. I did that also. The H2AD engine is a good price performer. Be sure to order the H2AD engine mount also. ENewton57(at)aol.com on 05/04/2000 09:55:51 AM Please respond to rv-list(at)matronics.com Subject: RV-List: Long Term Engine Storage I just came across an excellent deal on a runout (2200 hrs) O-320 H2AD with good logs and no prop strike. It has had the T-mod done and has had the additive put in every 50 hours with oil change since new. It's still flying in a C-172 and comes with the Carb and Mags for $2,400. It runs and flys great and is run almost daily by a flight school. My plan is to use it in my RV-6A and hopefully squeeze a few hundred hours out of it while I'm getting out of financial shock from builing my plane, then I'll go with an overhaul. My question is this: What is the best way to prepare the engine for long term storage (probably 2 years)? I will probably keep it in my air conditioned garage. Thanks in advance for any suggestions. Eric Newton Long Beach, MS (Wings were shipped by Vans yesterday :-)) ________________________________________________________________________________
Date: May 04, 2000
Subject: Re: Odyssey Battery - Voltage Regulator
<bryan.jones@lyondell-citgo.com> > >Isn't the Odyssey a dry cell type battery? If so, what type voltage >regulator does it require? Same as for lead-acid battery? The Odyssey is not a dry cell, it has liquid water and sulphuric acid in it. It's also a lead-acid battery. It requires no special attention in terms of voltage regulation. see http://www.aeroelectric.com/articles/rg_bat.html The majority of my builders are using a 17 a.h. recombinant gas batteries which which can be found on hte following links. These batteries can be purchased from a variety of battery specialty shops. We have some little convenience store sized Battery Patrols around Wichita that handle these batteries for $60-70 each. Powersonic: PS-12180 http://www.power-sonic.com/12180.html Hawker: Check out the first 6 batteries on this page . . . http://www.hepi.com/products/genesis/genprod.htm Panasonic: particularly the LCRD1271P http://www.panasonic.com/industrial_oem/battery/battery_oem/images/pdf/lc-rd 1217p.pdf http://www.panasonic.com/industrial_oem/battery/battery_oem/chem/seal/seal.htm Yuasa-Exide: Check out the NP18-12B at this site . . . http://www.yuasa-exide.com/np-prod.html Handle these like any other lead-acid battery. Bus volts no less than 13.8 - 14.2 is about ideal - no more than 14.6 Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( still understand knothing. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: May 04, 2000
Eric, fist this is WAY too expensive for this engine, please give me his phone number so I can buy it instead and keep you from making this grave error... Seriously, I have to wonder why they're unloading this engine so cheap. The H2AD's had a bad rap IMO, and with the mods they are very good engines. That said however, *personally* (for all you flame-meisters out there) I would be very reluctant to try to significantly bust TBO with this engine. All Lycomings are time-limited primarily by the exhaust valves. The H2AD also has a slightly finicky valve train. I would postulate that since the school has already gone well past TBO that they don't have a problem with the engine's total time and there is something that makes them WANT to swap that engine out. I think that the best way to store an engine is to completely fill it to overflowing with oil, and turn and top it off regularly. Be aware however, that the likelihood of taking a past-TBO engine, storing it for two years, and getting another few hundred reliable hours out of it are very slim. Again, IMHO. If it were me, I would store it, then have it overhauled just before flying. I have, however, been accused of being too anal in the past. Good luck. Ed Bundy - Eagle, ID RV6A - First flight 11/20/96 ebundy(at)micron.net > I just came across an excellent deal on a runout (2200 hrs) O-320 H2AD with > good logs and no prop strike. It has had the T-mod done and has had the > additive put in every 50 hours with oil change since new. It's still flying > in a C-172 and comes with the Carb and Mags for $2,400. It runs and flys > My question is this: What is the best way to prepare the engine for long > term storage (probably 2 years)? I will probably keep it in my air > conditioned garage. ________________________________________________________________________________
Date: May 04, 2000
> >Robert, > >You have any suggestions for the Rocket with the IO-540? > >Are the ones below as good for the extra cylinders? > >Tom G. Yep, they'll do just fine as long as you have something other than the Prestoheavy starter on it. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( still understand knothing. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________ User-Agent: Microsoft-Outlook-Express-Macintosh-Edition/5.02.2022
Date: May 04, 2000
on 5/4/00 8:30, Larry Pardue at n5lp(at)carlsbad.net wrote: > > >> >> >> Hi, >> >> Since I can't afford the IFR panel I would like to put in my RV-6, I am >> opting for a more economical VFR panel with room for expansion to IFR >> when funding permits. >> >> When it comes time to certify the airplane, will I have to certify it >> VFR? How do I later change it to IFR certification? Is it possible to >> certify it as IFR even though I don't yet have the appropriate Navaids >> on board? Even the most basic no gyro paneled Cessna 150's have >> day/night VFR/IFR on their placards even though they don't have the >> equipment on board to actually fly IFR. Can I do the same thing? >> > > Glenn, > > I don't have the exact wording, because it is in my airplane, but my > limitations say something to the effect that IFR flight is not permitted > unless the airplane is suitably equipped. That seems to pretty well > cover it. > > My airplane was IFR equipped at the time of the inspection. > > > Larry Pardue > Carlsbad, NM > > RV-6 N441LP > http://www.carlsbadnm.com/n5lp/index.htm > Mine was VFR equipped and had the same sentence in it. I think the sentence in mine may have also added the same thing about night flight. At any rate the phase I of your flight limitations will restrict you to daylight VFR, within your assigned test area, until completion of your flight test period . Perhaps it would clear up the confusion if you thought of the Airworthiness inspection as the name implys. Have heard of no cases (even by FAA inspectors ) where they were checking the static system cert, the transponder cert, or the altimeter cal. The most detail I have heard of is wanting to see a compass deviation card. Even then I don't think it had to be filled in. -- Denis L.(Bum) Walsh ________________________________________________________________________________ User-Agent: Microsoft-Outlook-Express-Macintosh-Edition/5.02.2022
Date: May 04, 2000
on 5/4/00 6:11, Glenn & Judi at foxinsocks(at)mediaone.net wrote: > > Hi, > Are builders generally using one or two of the hartwell latches to > secure down the oil door on the cowl? > > Thanks, > Glenn Gordon > > > > > > I used one and it is doing well. I like it. -- Denis L.(Bum) Walsh ________________________________________________________________________________
Date: May 04, 2000
I called Lycoming & they told me to fill my engine up completely through the breather port with new auto engine oil. Then take out the top plugs and fill the cylinders completely full of oil. The exhaust ports and intake ports have to be sealed off to do this. Either remove the pushrods or fab a small plate to fit over the ports. Others thinking of buying a new engine from Van's: Save your $200 & perserve the engine as desribed above. That way, you can mount the engine & still have it perserved. You can't mount the engine with prepurchased Long Term Storage becasue its sealed in plastic. Rick Caldwell RV-6 1st flight 1/16/2000 Melbourne, FL >From: ENewton57(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Long Term Engine Storage >Date: Thu, 4 May 2000 09:55:51 EDT > > >I just came across an excellent deal on a runout (2200 hrs) O-320 H2AD with >good logs and no prop strike. It has had the T-mod done and has had the >additive put in every 50 hours with oil change since new. It's still >flying >in a C-172 and comes with the Carb and Mags for $2,400. It runs and flys >great and is run almost daily by a flight school. My plan is to use it in >my >RV-6A and hopefully squeeze a few hundred hours out of it while I'm getting >out of financial shock from builing my plane, then I'll go with an >overhaul. >My question is this: What is the best way to prepare the engine for long >term storage (probably 2 years)? I will probably keep it in my air >conditioned garage. > >Thanks in advance for any suggestions. > >Eric Newton Long Beach, MS >(Wings were shipped by Vans yesterday :-)) > > ________________________________________________________________________________
Date: May 04, 2000
Scott, The way he states it makes it sound good but I have some reservations here. When he states the total time can't be determined he is in error. Total time in an engine is the total time for that serial number since new or factory reman. Also when he says that he has to remove the data plate due to non-TSO'd accessories I get a big question mark in my mind (or what's left of it after all the fiberglass work on the canopy and cowling). While indeed the Type Certificate lists the acceptable appliances, most FAA offices know that once the engine goes on an experimental aircraft those applicances can be changed and they do not affect the data plate. I can't guarantee that as some offices get funny ideas but it sounds fishy. Also the AD for the Aluminum oil gears was for a very good reason. There was a higher than normal occassion of galling which reduced the oil pressure and flow. It may not have happened to that mechanic but just because it did not happen to him is it worth taking a chance with someones life for the few extra dollars it costs (relative to overall engine cost). Overall just by the way he makes his case I do not get a warm fuzzy here. If he can't furnish a set of logs and a data plate I think I would have to recommend staying away from it. But on the other hand there are some excellent independent engine rebuilders out there and this could be one. I would suggest calling the Reno FSDO and ask one of the Airworthiness Inspectors about this gut and about the guy that overhauled the engine. They know what kind of work he does. Mike Robertson RV-8A Sick of Fiberglass >From: ABAYMAN(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: engine HELP please read >Date: Thu, 4 May 2000 08:11:26 EDT > > >dear listers, >i think i found an engine for my 6a, i know absoultly nothing about this >engine other than what the seller is telling me, see below. please read his >statements and give me your thoughts, that kind of money i would like an >informed opionion. >thanks, please remember this is going into a 6a , hopefully a constant >speed >prop. >thanks, see below >scott >tampa >6a tipper > >Dear Scott, > Yes, I still have the engine in my hangar. Some basic Background on >this >engine: > > The first question asked could be, what is the total time on the >engine. > That cannot be answered because the crankshaft and cases came from a >Mooney engine whose >cylinders I did not want to use (standard O-360 parallel valve). The >Crankshaft is a Constant >Speed and the drive lugs are set for a Hartzell. The lugs can be replaced >to >fit either a fixed pitch prop or a constant speed prop of different >manufacturer. I went with the thicker barrel O-540 cylinders (same mounting >and fit as O-360-essentially the same except the heavier barrel) because I >wanted a heavier duty cylinder and because I had recently had standard >O-360 >cylinders crack on our PA-28-180 Cherokee. > All overhaul parts are either Lycoming or Superior and are new, FAA >certified. All >the yellow tags are available. The O-540 Cylinders are Standard steel, but >two cylinders are bored oversized .10 and are set opposite to each other >for >balance purposes. The rods are of course a matched set that came with the >crank. The pistons are new; the standard 8.5-1 compression. The cam shaft >is >a reground which only says that the hardness existed to FAA specs, but was >resurfaced by Superior Airparts. The Cases were resurfaced by ECI in Texas. >What that means is that when an engine runs, the cases actually "move" >opposite to each other and "fret". Fretting is not a cause for rejection, >but >you can't get a good seal (and thus oil leaks) if the fret marks are >allowed >to stay at overhaul and thus ECI puts them on there machine and they remove >.001 of the material on each mating half so you get a clean and precise >fit. > The FAA Overhaul Engine shop that overhauled the engine is Gills >Engines, located at Stead Airport >(4SD), owned by Milton Gill. His phone number is (775) 972-0909. By the >way, >the oil pump is aluminum, not the sintered steel. The shotgun AD the FAA >put >out recently on the aluminum oil pump affected the O-235 to the O-360, but >the FAA left the O-540 out to stay with the Aluminum. I left it up to Gill- >and he went with Aluminum because in his experience, the Aluminum lasts >longer and the O-235's to O-360's have been running with them for 35 years >with no problems. If this upsets you, a change out is no big thing, but you >need to know. > What else can I answer? There are no accessories for this engine >because >I was going to buy ALL NEW. I have a set of Bendix mags and harness you can >use for the SLICK magneto exchange program (worth $150.00 on a dual mag >purchase). The Starter ring gear is for a HOT prop. Meaning: IF you wanted >to >heat the prop for icing, the ring gear has provision for that. If you are >going to have a aircraft for day-VFR, I would exchange the ring gear for a >lighter >weight one. > The rear accessory housing is the same standard housing you will find >on >the 235's >through the O-360's. There is a provision for the Vacuum pump-that special >gear pad is there as well as the housing for the constant speed prop >governor and dual magnetos. The bottom Sump housing has the Carb/injector >attach at the bottom >versus either side or back feed which the RV-6 cowl requires. > Here in Reno, The Flight Service Station is very picky on Experimental >aircraft employing FAA certificated and name plated engines and then >putting >on non-STC'd parts for that engine. This is why the Lycoming data plate has >been omitted from the sump. IF you want to put on a Slick mag that will >work >on your engine, but the O-360 data plate indicates a Bendix mag was used, >the >FAA inspector will flag the discrepancy and you will not be flying until >you >get that specific Bendix mag and install it; with all ADs complied with as >well. This is ridiculous because the New Slicks are not only better than >Bendix but far cheaper and lighter. What about that great Airflow >Performance >Fuel injection system you can get for an O-360. Don't install it on a >"name-plated" O-360 because although the kit from Airflow performance is >simply fantastic, it IS NOT FAA certificated. This situation got so bad on >my >Long Ez, that on the Lancair 235 I recently finished, I simply removed the >data plate and had another one made up by a local engraver that stated the >engine was built by my Grandfather! No Ad's from Grandpa! All nonstandard >accessories APPROVED for flight and stated in the Engine log book and >everything was NEW-New Slicks/harness, Carb, Starter and Alternator, Fuel >pump! Let's go! > >Well, let me know if this thing would work for you or if you have other >questions. The engine is in my humidity free hangar and no running time on >it >at all. The rocker covers and intake tubes are newly cad plated and the >engine is painted Lycoming Grey. >Sincerely, > > ________________________________________________________________________________
Date: May 04, 2000
Subject: Re: ANR upgrade kit or NEW ANR's
http://www.jetstreamcat.com/lightspeedheadset.html.....CHeck out this site for ANR's. New Lightspeed 15K for 295.00. Thats compaired to the 160.00 retro-fit kit. The retro-fit kit is nice but for the exrta 120.00 I will get the new 15K's. The retrofits have a unsightly wire that is taped to your existing wire (or you can spring for a special cabel for 40.00 I will save my existing headsets and not retrofit-use them as spares. For me the exrta 120$ buys a Lightspeed 15X.... ________________________________________________________________________________
Date: May 04, 2000
Glenn, What Larry and the others have said is right. The Operating Limitations that are issued with your airworthiness certificate state that the aircraft will be flown day VFR unless otherwise equipped. Once you upgrade your panel and meet the requirements of FAR 91.205(d) then the aircraft can be flown IFR once you get the transpnader and pitot-static system checked and logbook entries made. Although I would suggest, only suggest, that you call this a Major Alteration, limit the aircraft to a five hour test flight and conduct practice IFR approaches and enroute work during that time. With standard cat aircraft upgrading a panel from VFR to IFR is a major alteration and needs a 337 submitted to the local FSDO. But under the new Operating LImitations that are now being issued it states that it is your determination of whether or not it is a major. But ot be on the safe side with your local FSDO folks I would highly recommend gong that way. Mike Robertson RV-8A cough....cough...da** dusty fiberglass@$%*&!!! >From: Glenn & Judi <foxinsocks(at)mediaone.net> >Reply-To: rv-list(at)matronics.com >To: rv-list >Subject: RV-List: VFR/IFR Experimental Certification >Date: Wed, 03 May 2000 21:57:32 -0500 > > >Hi, > >Since I can't afford the IFR panel I would like to put in my RV-6, I am >opting for a more economical VFR panel with room for expansion to IFR >when funding permits. > >When it comes time to certify the airplane, will I have to certify it >VFR? How do I later change it to IFR certification? Is it possible to >certify it as IFR even though I don't yet have the appropriate Navaids >on board? Even the most basic no gyro paneled Cessna 150's have >day/night VFR/IFR on their placards even though they don't have the >equipment on board to actually fly IFR. Can I do the same thing? > >Thanks, >Glenn Gordon > > ________________________________________________________________________________
Date: May 04, 2000
Date: May 04, 2000
Subject: Two O-320s for Sale 0 SMOH
Don Sords who built my motor has two *experimental* O-320s for sale: One O-320 D2A and one O-320 E2A 0 SMOH All accessories included except vacuum pump (i.e., LW starter, alternator, carb, mags & harness) 160 HP (or more if you want : } - call Don) Call Don for a price. Don Swords Don's Dream Machines 770-412-8885 donsdream(at)aol.com Chris Browne -6A FWF Atlanta ________________________________________________________________________________
Date: May 04, 2000
I talked to a fellow at the airshow at Half Moon Bay, Ca this past weekend. He said the inspector would not inspect his airplane until he had a pitot, static, transponder certification. Once he had the certification he said the inspection went fine. I suppose this is a requirement because of the huge SFO Class B airspace we fly under here in the bay area. Cash Copeland RV-6Q N46FC Oakland, Ca In a message dated 5/4/00 5:10:26 PM GMT Daylight Time, deniswalsh(at)earthlink.net writes: << Mine was VFR equipped and had the same sentence in it. I think the sentence in mine may have also added the same thing about night flight. At any rate the phase I of your flight limitations will restrict you to daylight VFR, within your assigned test area, until completion of your flight test period . Perhaps it would clear up the confusion if you thought of the Airworthiness inspection as the name implys. Have heard of no cases (even by FAA inspectors ) where they were checking the static system cert, the transponder cert, or the altimeter cal. The most detail I have heard of is wanting to see a compass deviation card. Even then I don't think it had to be filled in. Denis L.(Bum) Walsh >> on 5/4/00 8:30, Larry Pardue at n5lp(at)carlsbad.net wrote: > > >> >> >> Hi, >> >> Since I can't afford the IFR panel I would like to put in my RV-6, I am >> opting for a more economical VFR panel with room for expansion to IFR >> when funding permits. >> >> When it comes time to certify the airplane, will I have to certify it >> VFR? How do I later change it to IFR certification? Is it possible to >> certify it as IFR even though I don't yet have the appropriate Navaids >> on board? Even the most basic no gyro paneled Cessna 150's have >> day/night VFR/IFR on their placards even though they don't have the >> equipment on board to actually fly IFR. Can I do the same thing? >> > > Glenn, > > I don't have the exact wording, because it is in my airplane, but my > limitations say something to the effect that IFR flight is not permitted > unless the airplane is suitably equipped. That seems to pretty well > cover it. > > My airplane was IFR equipped at the time of the inspection. > > > Larry Pardue > Carlsbad, NM > > RV-6 N441LP > http://www.carlsbadnm.com/n5lp/index.htm > ________________________________________________________________________________
Date: May 04, 2000
Subject: Hartwell latches
Hi, Can someone tell me the grip thickness for the Hartwell latches that Aircraft Spruce sells. I would like to use them on the oil door rather than the kit supplies camlocks. Thanks, Glenn Gordon ________________________________________________________________________________
Date: May 04, 2000
It looks like the upcoming Navaid Altitude Hold will be easy to add to any aircraft that has the electric trim option. It would seem to be simular to the system at http://members.aol.com/_ht_a/ccady/eztrim.htm This is a great way to go as it will be the easiest to retro fit and should be low dough. Maybe Roger Hansen can comment for us. Norman > > Thanks for the info. Does Jim Ham's altitude-hold installation (as it is > now) require that the NavAid servo be installed in the under-the-seat > position, or will it work with the nerved servo installed in the wing? Jim Ham from Porcine Associates is a member of our chapter (663 in > Livermore, > > CA) and he is the guy designing the future Navaid altitude hold device. > It > > will work by driving the elevator trim servo (only the most recent vintage > > MACs) and he is on the Prototype Rev 4 unit at the moment. The unit > was/is > > being tested in Roger Hansen's "Dragon Master" RV-6 and still needs some > > tweaking. I'm holding out for it, but probably not this year. ________________________________________________________________________________
Date: May 04, 2000
Unless I had a complete inventory of P/N & S/N of every item in that dash-nothing, data plate removed engine, and had log to back it up..... I would stay well clear of it. It Could be a well done engine but how are you to know? If you had to bail from your project in 6 months how many folks would buy that engine from you ??? . Priced realistically you could tear it down and inventory & reassemble to a (-something) engine but that data plate is hard to come by. Some folks scrap build engines from various sources and this accounts for the data plate missing. Consider your time and the rebuilders time and your buy-in money for a real dollar cost of this engine. This may be the case on this -nothing engine (determining total time) If it were scraped assembled then he may be quite accurate in that he can't determine the TT. There is nothing inherently wrong with a scrap built engine but you need to be exrta dilligent for many, many reasons. mrobert569(at)hotmail.com on 05/04/2000 01:26:41 PM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: engine HELP please read Scott, The way he states it makes it sound good but I have some reservations here. When he states the total time can't be determined he is in error. Total time in an engine is the total time for that serial number since new or factory reman. Also when he says that he has to remove the data plate due to non-TSO'd accessories I get a big question mark in my mind (or what's left of it after all the fiberglass work on the canopy and cowling). While indeed the Type Certificate lists the acceptable appliances, most FAA offices know that once the engine goes on an experimental aircraft those applicances can be changed and they do not affect the data plate. I can't guarantee that as some offices get funny ideas but it sounds fishy. Also the AD for the Aluminum oil gears was for a very good reason. There was a higher than normal occassion of galling which reduced the oil pressure and flow. It may not have happened to that mechanic but just because it did not happen to him is it worth taking a chance with someones life for the few extra dollars it costs (relative to overall engine cost). Overall just by the way he makes his case I do not get a warm fuzzy here. If he can't furnish a set of logs and a data plate I think I would have to recommend staying away from it. But on the other hand there are some excellent independent engine rebuilders out there and this could be one. I would suggest calling the Reno FSDO and ask one of the Airworthiness Inspectors about this gut and about the guy that overhauled the engine. They know what kind of work he does. Mike Robertson RV-8A Sick of Fiberglass >From: ABAYMAN(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: engine HELP please read >Date: Thu, 4 May 2000 08:11:26 EDT > > >dear listers, >i think i found an engine for my 6a, i know absoultly nothing about this >engine other than what the seller is telling me, see below. please read his >statements and give me your thoughts, that kind of money i would like an >informed opionion. >thanks, please remember this is going into a 6a , hopefully a constant >speed >prop. >thanks, see below >scott >tampa >6a tipper > >Dear Scott, > Yes, I still have the engine in my hangar. Some basic Background on >this >engine: > > The first question asked could be, what is the total time on the >engine. > That cannot be answered because the crankshaft and cases came from a >Mooney engine whose >cylinders I did not want to use (standard O-360 parallel valve). The >Crankshaft is a Constant >Speed and the drive lugs are set for a Hartzell. The lugs can be replaced >to >fit either a fixed pitch prop or a constant speed prop of different >manufacturer. I went with the thicker barrel O-540 cylinders (same mounting >and fit as O-360-essentially the same except the heavier barrel) because I >wanted a heavier duty cylinder and because I had recently had standard >O-360 >cylinders crack on our PA-28-180 Cherokee. > All overhaul parts are either Lycoming or Superior and are new, FAA >certified. All >the yellow tags are available. The O-540 Cylinders are Standard steel, but >two cylinders are bored oversized .10 and are set opposite to each other >for >balance purposes. The rods are of course a matched set that came with the >crank. The pistons are new; the standard 8.5-1 compression. The cam shaft >is >a reground which only says that the hardness existed to FAA specs, but was >resurfaced by Superior Airparts. The Cases were resurfaced by ECI in Texas. >What that means is that when an engine runs, the cases actually "move" >opposite to each other and "fret". Fretting is not a cause for rejection, >but >you can't get a good seal (and thus oil leaks) if the fret marks are >allowed >to stay at overhaul and thus ECI puts them on there machine and they remove >.001 of the material on each mating half so you get a clean and precise >fit. > The FAA Overhaul Engine shop that overhauled the engine is Gills >Engines, located at Stead Airport >(4SD), owned by Milton Gill. His phone number is (775) 972-0909. By the >way, >the oil pump is aluminum, not the sintered steel. The shotgun AD the FAA >put >out recently on the aluminum oil pump affected the O-235 to the O-360, but >the FAA left the O-540 out to stay with the Aluminum. I left it up to Gill- >and he went with Aluminum because in his experience, the Aluminum lasts >longer and the O-235's to O-360's have been running with them for 35 years >with no problems. If this upsets you, a change out is no big thing, but you >need to know. > What else can I answer? There are no accessories for this engine >because >I was going to buy ALL NEW. I have a set of Bendix mags and harness you can >use for the SLICK magneto exchange program (worth $150.00 on a dual mag >purchase). The Starter ring gear is for a HOT prop. Meaning: IF you wanted >to >heat the prop for icing, the ring gear has provision for that. If you are >going to have a aircraft for day-VFR, I would exchange the ring gear for a >lighter >weight one. > The rear accessory housing is the same standard housing you will find >on >the 235's >through the O-360's. There is a provision for the Vacuum pump-that special >gear pad is there as well as the housing for the constant speed prop >governor and dual magnetos. The bottom Sump housing has the Carb/injector >attach at the bottom >versus either side or back feed which the RV-6 cowl requires. > Here in Reno, The Flight Service Station is very picky on Experimental >aircraft employing FAA certificated and name plated engines and then >putting >on non-STC'd parts for that engine. This is why the Lycoming data plate has >been omitted from the sump. IF you want to put on a Slick mag that will >work >on your engine, but the O-360 data plate indicates a Bendix mag was used, >the >FAA inspector will flag the discrepancy and you will not be flying until >you >get that specific Bendix mag and install it; with all ADs complied with as >well. This is ridiculous because the New Slicks are not only better than >Bendix but far cheaper and lighter. What about that great Airflow >Performance >Fuel injection system you can get for an O-360. Don't install it on a >"name-plated" O-360 because although the kit from Airflow performance is >simply fantastic, it IS NOT FAA certificated. This situation got so bad on >my >Long Ez, that on the Lancair 235 I recently finished, I simply removed the >data plate and had another one made up by a local engraver that stated the >engine was built by my Grandfather! No Ad's from Grandpa! All nonstandard >accessories APPROVED for flight and stated in the Engine log book and >everything was NEW-New Slicks/harness, Carb, Starter and Alternator, Fuel >pump! Let's go! > >Well, let me know if this thing would work for you or if you have other >questions. The engine is in my humidity free hangar and no running time on >it >at all. The rocker covers and intake tubes are newly cad plated and the >engine is painted Lycoming Grey. >Sincerely, > > ________________________________________________________________________________
Subject: Re: Navaid RV6 Seat Instal Again
Date: May 03, 2000
As an RV6A builder, I have put the angles in the wing per Sam's original installation with the intention of mounting the servo in the wing. But I agree it will be very difficult to get the servo in and out of the access hole and screws in the holddown nut plates without making up some special tool. It appears there may be many times to get it out and make adjustments as discussed in the installation manual. Putting it out on the wingtip will help the in-out series as it appears easier, assuming one mounts the tips with screws. Mounting under the pax seat appears to work for many including one local flyer I know - no know pitch coupling. Another builder is putting the servo under the pax seat and running the push rod to the pilots stick. Anyone done this or care to comment? These are for RV6's. Different for tandem models. If I were doing it over, and I may, I'd go for the wing tip installation. Put in on the wing without the heavy flop tube to help the balance. Just my 2 cents. Marty in Brentwood, gotta get those fuselage Longeron's bent tonight. ----- Original Message ----- From: "Mike Thompson" <grobdriver(at)yahoo.com> Sent: Wednesday, May 03, 2000 8:40 AM Subject: Re: RV-List: Navaid RV6 Seat Instal Again > > > > What exactly could a guy do to install the Navaid Servo under the > > seat of an > > RV6 to have the least impact on the pitch travel of the stick? > > > > I have seen this mentioned a few times. Is there some thing in > > particular to > > look out for when chosing the final location of the servo? > > > > Norman Hunger > > > Norm, > > Check this out: > http://home.HiWAAY.net/~sbuc/journal/navaid.html > I changed my plans to do an under-the-seat mount to Sam's wingtip > mount. > Installation went smoothly - I can't imagine an easier way in either > flying or building stages. > > _Only_ down side is no in-flight adjustments. > :) > > > Mike Thompson > Austin, TX > -6 N140RV (Reserved) > Fuselage > > > Send instant messages & get email alerts with Yahoo! Messenger. > > ________________________________________________________________________________
Date: May 04, 2000
Subject: Re: Vision - not RV related
OrndorffG(at)aol.com wrote: > > > All, > First I apologize for using this forum for this questions, but I'm sure I > will get good input so here goes: > I just got back from a visit to the eye doctor and the pain of selecting > new glasses and options. One of the options was a coating for > anti-reflective lenses - the specific product was Crizal. I wondered if eye > care professionals that fly had an opinion on this. The glossy brochure has > photos showing a great reduction around lights, but I wonder if this is a > good thing when I may be looking for the bright light of something that may > smite me from the sky. Thanks in advance. > > Becki Orndorff > > Becki-- I talked with a couple optometrists who have used Crizal and they are quite impressed. As Steve Judd mentioned it's an anti-reflective coating but does not decrease the amount of light seen, in fact, it may help resolve the definition of two points of light that are close together, that would otherwise be perceived as one light from a distance. It is also said to be more wear resistant and color-neutral than other anti-reflective coatings. But, as of today, it seems to be the best anti-reflective coating available and will NOT affect perceived brightness. Personally, I'd go with laser surgery LASIK and throw my glasses away. I did that a year ago and went from 20/400 with astigmatism to 20/20 without astigmatism and I'm smiling almost as much as a RV grin. Boyd RV S6 M.D. ________________________________________________________________________________
Date: May 04, 2000
Subject: Re: Strobe question
In a message dated 5/4/00 4:22:29 AM Pacific Daylight Time, wirraway(at)bravo.net.au writes: << A recent inquiry to a sales person, resulted in a statement, that a single flash from the power supply is much stronger (CP) than the double flash. My aging eyes tell me, they are about the same........ Also, is the (CP) output the same for Whelen and Aeroflash ?. I like the pricing on Aeroflash compared to Whelen. I realise that Aeroflash is not TSO'd which is OK for experimental aircraft. >> Lots of info on this subject in the archives. Each power pack is rated for a certain output and simultaneous flashing I believe robs power vs alternating flashes which doesn't. Check the literature carefully from Whelen and they explain exactly how much power (in Joules) gets to each head with the different power supplies. The bulbs themselves have a effect on the light output. The ones with more volume and surface area result in a brighter flash for a given input. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: May 04, 2000
In a message dated 5/4/00 5:51:57 AM Pacific Daylight Time, foxinsocks(at)mediaone.net writes: << Are builders generally using one or two of the hartwell latches to secure down the oil door on the cowl? >> I used two of the pushbutton Camloc (ala Cessna) latches. I don't like the Hartwells, as they can whack your fingers if you are not careful. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: May 04, 2000
Subject: Filtered air box
John Kitz wrote: > pcondon(at)csc.com wrote: > >> >> Vans went a lot of trouble designing a pressure recovery air box. >> There was lots >> of talk on it a few years ago in the RVator . At the speeds the >> RV's fly, the >> air burbles, bending the air input stream 90 degrees and the general >> air fluid >> dynamics around the carburator suggest a need for a constant >> velocity, pressure >> recovery vessle (air box). You need a duct (air box) to route the >> input air to >> the carb that won't disturb the air stream. You need to mate your >> lower cowl to >> the snoot of the air box. If you allow pressure to exist in the >> lower cowl area >> ( i.e. no air box) you effect the draft for you cooling and the exit >> air. This >> exit air requires a pressure differential from the air inlet on the >> top >> cowl......... There are a few more engineering reasons to run with >> it but this >> is my first cup of coffee..... >> > > I think it is > > Pt= Pv + Ps > > or the total pressure always remains the same within reason. As air > is decelerated from 200 mph to near 0, Pv, or velocity pressure > drops, the static pressure Ps goes up and helps force the air into > the carb. > That was that way 40 years ago. So many things have changed though. > John Kitz > N721JK > Ohio ________________________________________________________________________________
Date: May 04, 2000
Who sells them? I've gone through the market at OSH and can only find a similar latch that has two discs. One is pushed to open the latch and the other is pushed to close it. I'd like to find one just like cessna sells. Brian Eckstein ________________________________________________________________________________
Date: May 04, 2000
Subject: Re: Duckworks landing light
I lost the template sheet for my Duckworks Landing light hole. Could someone please e-mail or fax me a copy. Thanks Bruce Voutas BVOUTAS @ AOL fax (860)355-4740 RV8-A still on the wings! ________________________________________________________________________________
Date: May 04, 2000
Subject: Re: Filtered air box (rephrased)
In a message dated 5/3/00 4:51:48 PM Pacific Daylight Time, svanarts(at)unionsafe.com writes: << Okay, I think I phrased my original question wrong. Let me clarify. I know the carb needs an air filter. No offense intended to everyone but I do know that air to the carb needs to be filtered. I may be dumb but I'm not stupid! :-) My question is: why the FAB? It's an option on the finish kit order form. Since it's an option I figured that there are other options. My question really is, why would I want a FAB rather than the squarish filter I used to have on my Champ? I've seen both types on RV's. -- >> Got one on my -4, It works real GOOD, almost 2 in. of ram air pressure increase, It is very efficient. Fred LaForge So Cal ________________________________________________________________________________
Date: May 05, 2000
>I talked with a couple optometrists who have used Crizal and they are >quite impressed. As Steve Judd mentioned it's an anti-reflective >coating but does not decrease the amount of light seen, in fact, it may >help resolve the definition of two points of light that are close >together, that would otherwise be perceived as one light from a >distance. It is also said to be more wear resistant and color-neutral >than other anti-reflective coatings. But, as of today, it seems to be >the best anti-reflective coating available and will NOT affect perceived brightness. > >Personally, I'd go with laser surgery LASIK and throw my glasses away. >I did that a year ago and went from 20/400 with astigmatism to 20/20 >without astigmatism and I'm smiling almost as much as a RV grin. > >Boyd >RV S6 >M.D. > > Boyd, I've thought about that surgery, too. One question/concern I've got is that my eyesight seems to be changing more now that I'm in my early 50's. Will the surgery be a 'permanent' fix or will I have to have more surgical corrections later? I know I'll have to wear reading glasses after the surgery. That will be a new thing for me as, being nearsighted, I can easily read now without glasses. My eyesight now is roughly 20/60 or 20/70 without glasses (and astigmatism, too). Your thoughts?? John Ammeter 1975 Jensen Healey RV-6 (sold 4/98) EAA Technical Counselor NRA Life Member ICQ#48819374 ________________________________________________________________________________
Date: May 04, 2000
From: Thomas McIntyre <bogeybrother(at)earthlink.net>
Increase over what? and at what speed? Ferdfly(at)aol.com wrote: > > In a message dated 5/3/00 4:51:48 PM Pacific Daylight Time, > svanarts(at)unionsafe.com writes: > > << > Okay, I think I phrased my original question wrong. Let me clarify. I know > the carb needs an air filter. No offense intended to everyone but I do know > that air to the carb needs to be filtered. I may be dumb but I'm not > stupid! :-) My question is: why the FAB? It's an option on the finish kit > order form. Since it's an option I figured that there are other options. > My question really is, why would I want a FAB rather than the squarish > filter I used to have on my Champ? I've seen both types on RV's. > > -- >> > Got one on my -4, It works real GOOD, almost 2 in. of ram air > pressure increase, It is very efficient. Fred LaForge So Cal > ________________________________________________________________________________
Date: May 04, 2000
Subject: Elevator Horn Question
I finished both elevators on my RV-6A and diring the trial fit, I noticed that the gap between the elevator horns and the center Bearing of the Horizontal Stab (where a bolt goes through conecting the Elev horn to the HS) is 3/16" on one side and 1/8" on the other. I this right? Looking at the plans it calls for a 960-416 washer and a 5702-95-30 washer on each side. I'm not sure what the 5702-95-30 washer is, but if it is the silver colored ones it's not thick enough to fill the gaps. Am i missing something? I rechecked all my measurments and since the spar and hinges were all predrilled, I can't see how it could be that far off. Any advise would be appreciated. Thanks, Eric Newton Long Beach, MS RV-6A (wings soon) ________________________________________________________________________________
Date: May 04, 2000
Subject: Re: Elevator Horn Question
I ended up with about the same dimensions. Approx. 1/16" on the right & 3/16" on the left. I couldn't find the specs for the 5702-95-30 in my Aircraft Spruce catalog. They may be larger outside diameter washer to capture the bearing should it fail. I'm not sure. Will have to find out myself, since I'm getting to the point of making this permanent. L.Adamson RV6A finish ________________________________________________________________________________
Subject: Mk12D/R Pinouts
Date: May 04, 2000
Sorry to bother the list with this. I have a buddy who bought a radio from e-bay that was represented as a Narco Mark 12D/R. This is a special version of the Mark 12D that is supposed to be a slide in replacement for a Mark 12A. When he slid in the radio and hooked it up it smoked. Now we are trying to figure out if it is truly a Mark 12D/R or a Mark 12D and are also trying to check the pinouts. This is one reason I don't shop on e-bay. Does anyone have the relevent pin-outs or other knowledge on this radio, like how to tell if it is a /R. There are no markings that would make it obvious. Larry Pardue Carlsbad, NM RV-6 N441LP Flying
April 28, 2000 - May 04, 2000
RV-Archive.digest.vol-ik
