RV-Archive.digest.vol-im
May 10, 2000 - May 15, 2000
> > >Sam Buchanan
> > >"The RV Journal" http://home.hiwaaay.net/~sbuc/journal
> > >ORDER: 8700.1
> > >APPENDIX: 3
> > >BULLETIN TYPE: Flight Standards Handbook Bulletin for General
> > >Aviation
> > >(HBGA)
> > >BULLETIN NUMBER: HBGA 99-13
> > >BULLETIN TITLE: Operations over Densely Populated Areas,
> > >Experimental,
> > >Amateur-Built Aircraft < snip
Subject: | Re: EAA Northwest Fly-in |
Mike Robertson wrote:
> While I know this may be a bit early I am planning on going to the fly-in in
> Arlington this year and was wondering how many of you are planning on going
> and if there is a common place where everyone meets. I am going to be there
> on Friday and Saturday.
> This is going to be on my own and not on the FAA time. I am bringing my
> wife to convince her another RV would be a good investment. Although I
> think I will have to bribe...er....buy her a few things first.
> Mike Robertson
> RV-8A
> Hoping...fingers crossed....to have first flight before then
I well be there, you won't miss the RV's, there could be well
over a hundred there Friday and Sat. There is usally a shade
tent in the RV area where people hang out, or just go around
and talk to people at their airplanes.
Jerry|RV-6 N906GS|Hillsboro, OR|jsflyrv(at)teleport.com
I noticed your ad in the current issue of Sport Aviation, and carefully read
your web page information. I had earlier obtained a copy of your patent from
the Patent Office, and purchased Dimple Tape for my RV6A.
The results were extremely disappointing. I have a 160HP Lycoming driving a
wood prop (Warnke) and normally the prop limits the engine speed to 2,550RPM
(on a 'good day.') The normal cruise RPM is 2,300 and that produces 175MPH
TAS, day in and day out. Maximum speed in level flight with half fuel, at
8,000FT density altitude; best ever= 210MPH TAS.
WITH the dimple tape, engine RPM ran up to 2,800 and was willing to go
higher (red line is 2,700RPM.) At this high RPM the TAS DROPPED to 135MPH
TAS. Slower RPM settings produced proportionally lower air speeds. No
combination of altitude or engine settings resulted in anything but VERY
degraded performance.
I applied the tape precisely per your directions.
I removed it, and consider it a danger to the engine and the performance of
the airplane.
Comments? (PS I am also an attorney and electronics engineer.)
RV6A
Salida, CO
Subject: | EAA Northwest Fly-in |
Mike,
I went 2 years ago and had a blast. Lots of great people and airplanes. There were
60 or so RV's then, and probably a lot more this year. They're all in one
area so it's easy to see them all and say hi to everybody.
With any luck (and a short test period) at least one new RV-6 should be there this
year, mine :-)
Look for a white and blue (plus a few other colors) RV-6, N515L, with the funny
fiberglass panel in it. I'll be wearing one of Steve's Davis' list name badges
(with my name on it, not his) and probably sipping on a cold one in front of
the airplane. Make sure you stop by and say Hi. (No fair ramp checking anybody...)
See you all there, (I hope, I hope, I hope...)
Laird RV-6 N515L
(going to fly with Mike Seager next week...please don't rain, please don't rain)
SoCal
http://www.planes-wings-things.com/images/lorv60.jpg
for a shot of my panel
> RV6A
> Salida, CO
PS I am also an attorney? Vailed threat from a attorney? LOL
Subject: | Re: Eliminate "Greasy Belly" |
In a message dated 5/10/00 7:07:15 AM Pacific Daylight Time,
rv8(at)ispchannel.com writes:
<< Just about a week ago, I had this very conversation with Lycoming about my
new O-360, and they definitely do not like air/oil separators. The reason
given was corrosion due to water being returned to the engine. However,
since the amount of liquid that's returned is so small, I believe you can use
a small reservoir to hold it between oil changes, rather than allowing it to
go back to the engine. I just tossed my separator in a bag, and set mine up
the standard way.>>
That's throwing the baby out with the bath water. I have the collection
bottle on mine and all I ever get is straight oil (never water). The water
escapes overboard as vapor as it is far more volatile than the oil. I have a
stainless scrubber pad media inside my separator and it is always wetted by
the fine oil droplets expelled with crankcase gases at the engine breather
pipe. Water is naturally exhausted from the system.
<< Along the same subject, Lycoming told me that the engine was "happiest" at
the 6 quart oil level. They said the 8 quart level was to satisfy an FAA
requirement to be able to fly for X number of hours with a completely worn
out engine. According to Lycoming, the 7th and 8th quart will increase the
mess on the belly significantly. >>
This is absolutely correct.
-GV (RV-6A N1GV)
vanremog(at)aol.com
Subject: | Re: FAB Air box for RV-6 |
> I had the same problem with the heat muff interfering with the scoop on my
> 6A, and was debating all sorts of not-so-fun fiberglass fixes. Then I
> simply rotated the exhaust pipes in the spherical joint until the last
> little bends were aimed somewhat inward, and the clearance problem was
> eliminated. My plane might look a little bow-legged, but the heat muff
> won't beat on the cowl. The perfect fix would be to make the last little
> downward bends in the pipes angled outward from standard, maybe a muffler
> shop would have the proper tools?
I had the same clearance problems from day one. Eventually I figured out
about turning the pipes. But by this time the pipes had rubbed on the bottom
of the firewall and had worn areas on them to the point that I was worried
they'd wear through. I called Larry Vetterman and he had the perfect
solution -- pipe extensions he sells that slip over and clamp on, and also
have a smaller turndown angle allegedly to provide more exhaust thrust. I
rotated the pipes, whacked off the ends and slipped the extensions on,
covering the worn area, and readjusted the hangars and now everything clears
well and the turndowns point where I want them. Much better! Right now
they're clamped on, I'll probably have them welded eventually.
Randall Henderson, RV-6 N6R (~75 hrs)
Portland, OR
http://www.edt.com/homewing
Subject: | Re: uEncoder, Gmeter for sale |
Paul,
I'll buy the g-meter if its not already sold. I already built my u-encoder.
Dave Leonard
One suggestion (IMHO, FWIW, and its ONLY an opinion, from far,
far away, you being a lawyer and all...):
Your prop is over - pitched!
So, even regularly, you ran too high AoA on the prop, and parts
of it were stalled - that's why there was much drag, and the
rev's wouldn't go up.
Now, you applied the tape. Probably, if everything was OK at
the beginning, you would have gotten less departure on parts of
the airfoil of the prop, slightly MORE torque (funny, but - in
props - some times detached flow creates less drag than
turbulent, attached flow...).
However, since the prop is overpitched, parts of it reached full
stall - less torque, less thrust, and higher revs...
What do you think?
Ronen.
-----Original Message-----
Date: Thursday, May 11, 2000 4:36 AM
Subject: RV-List: Results (?)
carefully read
your patent from
Lycoming driving a
speed to 2,550RPM
produces 175MPH
half fuel, at
willing to go
DROPPED to 135MPH
speeds. No
but VERY
performance of
|the airplane.
|RV6A
|Salida, CO
Subject: | OV protection w/built in regulator |
After reviewing the archives and electric bob's schematics, I am little
confused on the implementation for OV protection for alternators w/built-in
regulators. I have a nipondenso alt on my Aerosport 320. Why does the OV
protection require a relay to break the "B" contact on the alternator? Does
removing the ground from the "C" contact (alt switch) not provide overvoltage
protection for built-in alternators?
thanks,
Robin Wessel
RV-6A finish kit
Tigard, OR
Subject: | Electric Gyros VS Vac gyros |
Can anyone tell me if electric gyros are fundamentally more reliable? My
assumption is that one can make a very robust fault tolerant automatic
redundant electric system for the gyros much easier and cheaper than a backup
vac system. For example, if you took 2 RC Allen Gyros, 1 electric and 1 vac
which one would have a better MTBF (mean time before failure)?
Electric Gyros
Pros
Easy to install (no plumbing)
Can easily turn off when not needed (save hours when flying in good VFR and
aerobatics)
Easy to implement amd low cost electric backup systems
Gyro reliability???
Service life??
Cons
Cost to overhaul??
Vac gyros
Pros
standard in GA planes
low cost
inherent redundancy assuming you can use a T/C in IFR
Cons
Backup systems costly or hard to implement/ease of use
system reliability???
Comments appreciated,
thanks,
Robin Wessel
RV-6A finish
Tigard, OR
From: | Richard Reynolds <RVReynolds(at)macs.net> |
Subject: | Re: Electric Gyros VS Vac gyros |
A Navy avionics technician told me the electrics were more reliable
because the "case" is sealed. The vacuums are always sucking in little
"things" (dust, oil, salt).
Richard Reynolds Norfolk, VA, RV-6A, all electric ($$$)
Subject: | Re: new category |
Randall Henderson wrote:
> > I don't think I made the point very clear . . . I wouldn't
> > suggest anything having to do with the FAA . . .
> [snip]
> > I'm thinking along lines of coining a phrase that more
> > accurately describes us and perhaps with words friendlier
> > to public perceptions.
> Yeah I guess my response was influenced by the other responses that were
> going in more of a "change the category" direction.
> Anyway I do like the idea. Okay, from now on I pledge to introduce my plane
> to people as a "custom built aircraft".
> Portland, OR
I don't know about the rest of you but I am pretty proud
of the fact that mine is a homebuilt aircraft.
Subject: | A-ctual VNE for the RV's? |
I read in the specs that 'top speed' is a certain percentage above 75%
cruise. I can't see why this would be the same as VNE. The same aircraft
with same engine but less HP (IO vs. O) has a lower top speed. I can see the
top speed being lower with less hp, but not VNE.
Do we know what it is? Has anyone (Van's?) tested the airframes in a speed
tunnel to see what max 'dive speed' would be before chances of structural
failures? Maybe it's not required for the experimental category.
Are Barstad
RV-6
Loretto, Ontario
From: | "Fesenbek, Gary" <Gary.Fesenbek(at)marykay.com> |
1) How long does it take to get a cylinder head temperature reading?
2) When I retard the throttle all the way, the engine quits. I assume that
I need to adjust the throttle stop. What RPM works best?
3) At what RPM does your engine draw full vacuum? Does it do it at idle?
1. I see 200 degrees within a few minutes. Oil temp takes quite a bit
longer. Of course this will depend on outside temp but not by that much in
my area.
2. You will need to set the idle and idle mixture. The best way to do this
is with the engine running. I left this task to the A&P shop that I go to
because you can see the idle and mixture screws are quite close to the
propeller. Make certain you do this before going to fly. You don't want to
pull back to idle in the air on base turn and have the engine quit on your
initial test landing. Make sure whether you do it yourself or have someone
else do it that you check the safety wire on the throttle linkage. I found
this was safe tied backwards on my throttle linkage. My DAR did not catch
that. Luckily I had a superb EAA tech counselor.
3. I had a Van's vac gauge that I had to replace and I also have a low vac
warning light. My light comes on at less than 3.8". When I start and run
at idle the light is on and the gauge is in the low range. I have to check
this but I think when I am up to 1800 rpm I am at 4.2". You can use a small
vacuum cleaner to test your vac gauge without starting the engine. My vac
could only pull 2 inches which was enough to ops check the system and not
damage anything. After running the engine for a while make sure you check
the vac pump seal for leaks. If there are any leaks take care of these as
soon as you can.
Hope this helps,
Gary Fesenbek
RV6A
Dallas, TX
Subject: | GLASAIR COMPANY CLOSED |
I know this isn't completely RV related, but does anyone have any info about
what is going on at Stoddard-Hamilton. Whether warranted or not, stuff like
this makes me nervous:
GLASAIR KITPLANE COMPANY CLOSED FOR REORGANIZATION: Callers yesterday to
Stoddard-Hamilton, home to Glasair and Glastar composite kitplanes since 1980,
were greeted by this recorded message: "With heartfelt regret, we are
temporarily closed for reorganization." The recording directs callers to the
company Web site for updates, but as of our deadline yesterday no news was
posted there. Stoddard-Hamilton, according to its Web site, has more than
2,000 kits in the field and some 800 aircraft flying around the world. No
further information was available at our deadline yesterday.
Subject: | Re: RV-List:Plenum for rv4/0360 |
Try a mid-60's mooney engine baffle/box from the salvage yard. With the new
round inlets or the traditional square openings this mooney "dog-house" as its
called is 95% of what your after in a pressure plenum box......
daronson(at)cwnet.com on 05/09/2000 04:32:21 PM
Subject: Re: RV-List:Plenum for rv4/0360
Listers:
Hanging the engine very soon. Looking forward to baffles and the
cowling. Does anyone have plans or patterns for a sheet metal plenum
for and 0360, constant speed prop in an RV4. I would like to modify the
inlet holes and minimize drag by installing a plenum. There is a great
picture of one in Firewall Forward that got my interests up. Any
comments?
Dave Aronson
RV4 N504RV
Firewall Forward
Subject: | Engine Temp >> Flying a Pitts |
>>>Get some dual in an RV, Citabria, Pitt's, etc. Then go have the most awe
inspiring flight of your life in your RV!
Brian Denk
RV8 N94BD
Speaking of dual in a Pitts as prep for RV test flight, I just finished my
15 takeoffs and landings per insurance company in an S2B, and it was a
blast! I now feel much more confident about testing my plane personally.
There are two primary differences, in my estimation, between the Pitts and
an RV, one - the final approach angle, and two - pattern speeds. We used
about 25 degree approach angle on final at 105 mph. The Pitts glided like a
brick when the power was pulled. I would imagine the RV will require more
effort to kill altitude and airspeed (more flat approach angle).
Bryan Jones
-8, ready for inspection
Pearland, Texas
Is this a piece of empennage your referring to ?
billshook(at)mindspring.com on 05/09/2000 06:28:10 PM
Subject: Re: RV-List: locker talk
Oh brother........anyone offended by talk as lightly sexist as this should
certainly not be hanging out with any pilot's on an airport. Besides,
though you mean to be kind (or politically correct) by rebuting men for
talking this way.....have you ever heard how women talk when you're not
around? I'll bet my newly completed empennage it would make you blush. :-)
-4
Subject: | Re: Badges for List (Shipping Info) Need to Read to get Badge |
Hi Steve,
I mailed my envelope this morning and put 33 cents on it, however I covered my
tracks and donated $5.00 to our "Exotic Island Retirement Fund". I owe you one.
Thanks for making the badges, this was the best idea yet. Color or printing is
immaterial. What you did looks great.
Marty
name="mwsailer.vcf"
filename="mwsailer.vcf"
begin:vcard
n:Sailer;Marty
adr:;;;;;;
version:2.1
email;internet:mwsailer(at)erols.com
note:Marty RV-6A- Plumbing Fuselage
fn:Marty Sailer
end:vcard
Aircraft Spruce sells one ? Anyone NOT able to recommend Spruces?
HAROLD1339(at)aol.com on 05/10/2000 07:41:20 AM
Subject: Re: RV-List: Eliminate "Greasy Belly"
I installed one on a Cessna 172-XP and it seems to be working well. The belly
is much cleaner. So far I would recommend it.
Subject: | flight over densely populated areas |
but this bulletin would seem
to preclude assembling and test flying your experimental at an airport in a
congested area, South Florida,
I had my RV6A inspected and tested at Addison Airport in Dallas, Texas. The
airport folks there boast that this is one of the busiest GA airports in the
country. It lies under the DFW class B and you can't swing a dead cat
without hitting an air park or private airstrip here. In fact there is
another airport three miles off the end of runway 35. The east side of the
airport is 30 story buildings with plenty of cranes around building new ones
while the west side is industrial parks. There is a single runway of some
7000 feet. It is controlled and has fire and a hospital about four miles
away.
I half expected my FAA and DAR inspector just to give me a ferry permit to
fly it out to Oklahoma for testing but they gave me some good guidance for
testing it there. Addison is very busy, but at certain times of the day it
is not busy at all. I would generally go fly for an hour or two before work
leaving at 6:30 in the morning when the wind was calm and there was no
traffic. The weekends have plenty of dead times too because a lot of the
traffic there is corporate. I think another consideration you want to have
in an airport just getting started is runway width. Addison has 200 feet.
That came in pretty handy to me as I was never worried too much about
directional control problems. There is an 8 guy here that is getting ready
to test off a 30' wide runway after not having flown for many years. I
guess I'm a baby because even with plenty of logged hours but only 60 hours
in my 6A I still won't land there. Some of the more experienced pilot I
work with have nicknamed him "Dead man walking". I set up my test
program(and after) similar to what is used in the military. You have
certain wind limits/ runway limits and weather mins at each stage. My
current limits after sixty hours of flying my airplane are ten knot
crosswind, min runway length 4000', min runway width 100', wx 3000/3
forecast within two hours of ETA. Setting limits like these takes some of
the guesswork out of "Should I go flying today?". I had a 40 hour test
period but I still feel the pilot is in testing. I think graduated limits
are a good idea.
Gary Fesenbek
RV6A
Dallas, TX
Subject: | Re: prop bolt's/how long |
Make a depth guage out of coat hanger wire or something...Obviously this is a
area where you DON'T want the bolts to "shoulder out'" or false tighten because
either you ran out of thread or bottomed out the bolt...... Also, if using
a
Sensenich, the factory sells a extention & bolts .....FWIW
Rvmils(at)aol.com on 05/10/2000 12:07:48 PM
Subject: RV-List: prop bolt's/how long
I have a 0360 with Mark Landoll's steel ring @ 1", Culver prop @ 41/4, and
Van's 21/4 prop extension. Just wandering if I'm missing something before I
ordered my bolts. I'm not sure how thick Van's prop ext is and how much
longer the bolts need to be in the hub.
Carey Mills
Beats me.
The 'What's New' page was last updated on February 17, 2000 and has no
information about this.
Are
RV-6
have any info about
or not, stuff like
Subject: | Badge Offer Misunderstanding |
Listers
I think there has been a misunderstanding about the badges. I did not mean
that they were for Oshkosh Only. They are offerd to the LIST, that means ALL
LIST MEMBERS are welcome. I have received many emails offering to pay for
badges because they were not going to Oshkosh this year. The Stinking Badges
are FREE!!!
I have a big batch of the badges done and waiting for mailers
Thanks (Sorry about the non RV related posts just didn't want to leave
anybody out)
Steve Davis
The Panel Pilot
http://members.aol.com/panelcut
Subject: | Re: A-ctual VNE for the RV's? |
I am not sure I completely understand the question but will give it a
stab.
Top speed refers to the maximum true airspeed attainable in level flight.
In a non-turbocharged airplane this would be full throttle at sea level.
It is a flight condition that most of us will never be in.
Maximum cruise speed is the maximum true airspeed attainable at 75%
power, and will occur at the highest altitude that 75% power is
attainable at, because that will be the minimum drag condition for that
power setting.
Top speed would normally be calculated rather than observed.
VNE has nothing to do with performance. It is a structural or flutter
related limitation. It refers to indicated airspeed (at least at lower
altitudes), not true airspeed.
It is normal and easy to be crusing at a true airspeed that would be well
in the yellow if the airspeed indicator showed true airspeed, but the
airspeed indicator will normally be showing something much less. You
could be crusing at 170 knots but showing only 130 knots or so on the
airspeed indicator, so you are well in the green arc.
Larry Pardue
Carlsbad, NM
RV-6 N441LP
Subject: | Re: Aileron Stops/Adjustable seat back |
I still like the Van's stops. I see what Akroguy is saying but I am a belts &
suspenders guy with my airplane. If a component were to fail or bend I would
want the stops. I used a piece of aluim. round stock, (about a .25 cent piece
in diameter and a fat 1/4 inch in length) & drilled if off center to make a cam.
Bolted the gizmo with a #10 bolt (as per plan location), adjusted the cam to
hit where I wanted to (the Vans method is one shot in that once riveted in place
its there to stay) and used a C/S & 8 to safety the cam. Looks sharp and is
easy to make. Also added these cams to my seat back/stop. On long flights its
nice to have a little adjustment. I can go long distances without being cramped
when I exit the RV-4 if I reach up and crank in a little angle change once every
15 minutes or so.
akroguy(at)hotmail.com on 05/10/2000 08:41:41 PM
Subject: Re: RV-List: Aileron Stops
>Anyone install adjustable aileron stops (in an -8) on the fwd side of the
>spar carry through? Other locations? What I'm thinking about is pretty
>much like other planes I've seen using an adjustable jack bolt with a flat
>head. The flat head of the bolt is what the side of the control column
>bumps against to set the aileron travel. I don't care for the suggested
>stops installed on the hinge attachment. Any comments or better ideas...
>Bryan Jones
>-8 ready for inspection -
>after aileron stops!
>Pearland, Texas
Bryan,
I have no aileron stops on my airplane. It passed inspection after the FAA
safety inspector verified the ailerons could not go "overcenter" on the
bellcrank and jam. The geometry of the pushrods are self limiting in this
regard. If your inspector insists on them, then so be it.
Brian Denk
RV8 N94BD
88 hrs.
On my Van's brand Air Speed Indicator, marked in knots for easier IFR, the
red line is at about 182 knots. The red line indicates VNE and is a point
beyond which it might be marked as on the sea maps of old, "here there be
dragons".
hal
Subject: | Public and Regulatory Image Crafting . . . |
A short time ago, I related a personal observation concerning
the value of asserting one's aspirations and then taking the posture
that the goal is already reached if not imminent. It's analagous
to the mail room runner coming to working in a suit and tie . . .
people are not going to even consider you for promotion if you
don't appear worthy of the consideration. A bit of serendipity
arrived in my e-mail box at RAC yesterday. A long time friend
and mentor at Raytheon, Dr. Leland Johnson, included the following
bit in his soliloquy about both internal and external images
. . . in this case about RACs engineering department:
>Many years ago, there was a conductor named James Robertson who not
>only led the Wichita Symphony, but also had the orchestra at WSU and
>the Senior Youth Symphony. Your guru was a minimally talented
>bassoonist who sneaked into the Youth Symphony because no other
>bassoons showed up for tryouts one year. Anyway- one Saturday morning
>the maestro stopped the orchestra during rehearsal and told us this
>story:
>"The Philadelphia Orchestra puts 'The World's Greatest Orchestra' on
>the cover of their record albums. There are many good orchestras in
>the world, and some are even great perhaps some are even better than
>the Philadelphia Orchestra. But they have the courage to put it on
>the cover of their albums!"
>Pausing to let that sink in, he next said in a very quiet voice: "The
>World's Greatest Youth Symphony."
>Dr. Robertson picked up his baton- and we went on with rehearsal.
>Raytheon Aircraft: The World's Greatest General Aviation Company.
Dr. Johnson demonstrates his own understanding and endorsement
of what I suggested a few days ago. The RV faction of light
aircraft fabricators, owners and pilots can set the tone
for some aspects of GA's future. What we chose to call
ourselves (at the risk of being labled kooks or stuffed shirts)
may have a strong influence on both regulatory and societal
fortunes yet to be.
What ever phrase catches on, I'll suggest it would be well to
make it inclusive and welcoming of all privately owned and
operated light aircraft . . . ESPECIALLY the declining fleet
of orphaned certificated aircraft current being canibalized
just to maintain its existance by devouring itself to satisfy
regulatory appetites for "certified parts".
I'd love to see the day when a warm Saturday morning in a big
hangar where owners of Tri-Pacers, Kitfoxes, RV's and
C-170's might all have their toolboxes out to accomplish what's
necessary to keep their airplanes well maintained and
flying.
There are thousands of RV's flying and many more to come. You
folk have an opportunity here.
( Knowing about a thing is different than )
( understanding it. One can know a lot )
( still understand knothing. )
( C.F. Kettering )
http://www.aeroelectric.com
Subject: | Re: Results (?) Prop tape flap |
I may have forgotten my prop 101 but isn't a overpitched prop a prop that has
to much bite for the (torque/rpm/engine health/displacement) of the engine ?
What does stalling(of the prob blade...being a airfoil) have to do with prop
overpitch ??? Is the gentleman referring to boundry layer dynamics simular to
what the VG (vortex generators) do ? If so, isn't that at the slow range of
effective use of the air foil not at the fast end of the effective use of the
airfoil. Surely the reynolds number dosen't effect the airfoil at this
dimention............
yron(at)isdn.net.il on 05/11/2000 03:14:54 AM
Subject: Re: RV-List: Results (?)
What do you think?
Ronen.
carefully read
your patent from
Lycoming driving a
speed to 2,550RPM
produces 175MPH
half fuel, at
willing to go
DROPPED to 135MPH
speeds. No
but VERY
performance of
|the airplane.
|RV6A
|Salida, CO
Jerry, No, the reference to being an attorney and an engineer is simply to
mark the coincidence that the seller/patent holder of the Dimple Tape is
also an attorney and an engineer. No threat involved.
Subject: | Re: OV protection w/built in regulator |
One of the simplest way to provide overvoltage protection is to use Mark
Landall's (spelling?) zener diode and fuse combination. Simple to install,
foolproof, and inexpensive. He has an ad usually in the ad section of Sport
Aviation.
Someone wrote:
>The gascolator is merely an inline gravity water separator
>that will shunt a small quantity of water off to the bottom
>of the bowl and allow the lighter fuel to pass thru the
>mesh filter. It can be anywhere in the fuel line and I
>don't know how this myth about it needing to be the
>lowest point in the system got started.
The practice probably got started to accomodate areas where the temp gets
below freezing.... the "slug" of water that can/will collect in the low
point of the system during warm times can freeze and slow or stop fuel flow
when it gets cold. Another thought is that the low point is where heavy
debris that may be carried along in the fuel can settle.... you gotta be
able to drain the low spot IMHO, be it via
the gascolator or a low-point drain. Since the gascolator already has a
drain, might as well use it...
Johnny Johnson
49MM -3 flying
Subject: | Re: ***uEncoder For Sale (Lowered Price)**** |
Paul:
I am interested.
Subject: | Re: Badge Offer Misunderstanding |
Glen
I need the info below and a 3x5 mailer with two 33 cent stamps and send to
address below.
Steve
Name:
email address
City, State:
Type Aircraft Building
Steve Davis
P.O. Box 510
Memphis, TN 38101
Subject: | Re: GLASSAIR OUT OF BUSINESS |
If you visit Stoddard-Hamilton's website you will see their plan for
reorganization. According to Ron Wanttaja, they were forced to declare
bankruptcy earlier this week.
Dave
RV-6 Preview Plans (ya gotta start somewhere)
Subject: | Re: RV- Flight Training | Mike Seger visit |
Vans Factory flight training person, Mike Seger, will be conducting RV type
specific flight training in the Philadelphia area this July 18, 19 & 20. ( The
long way from Washington/Oregon to Oshkosh) The Usual rules apply,
building/completing any RV-with preference toward those who are nearing
completion. Must be a pilot with reasonably current activity . The object of
Mikes' training is transition not basic flight training (most certainly it
can be the basics of what a RV can/will do or more advanced RV flight training
depending on your need). Three (3) am sessions and 3 PM sessions are planned
starting around 8 and finishing around 5 ish. There will be three days of this-
making a total possible of 18 training sessions-each lasting about 1 to 1.3
hrs....depending on what's being taught/absorbed. Cost is 75$/hr...... that
included Mikes RV and his CFI time. Bring pilots log for signatures. Contact me
for a slot. I will be arranging lodgings for Mike and his travel partner. It
looks like if each of us who get a session can contribute 10 or 12 bucks toward
the hotel then Mike is all taken care of. I will arrange travel to and from
the hotel too, in order to keep Mikes expenses minimal. Lets face it, RV type
training is difficult at best to get.....I want to keep Mikes stay as pleasant
as possible. Please e-mail if interested. As slots are taken up, alternates
will be taken so any last minute emergencies can be handled and we can use up
Mikes time accordingly. e-mail to (philc(at)voicenet.com) or post general
questions to RV-list & I can respond (pcondon(at)csc.com) or 609.654.9587 (don't
sound like a salesman or my wife gets real nasty...) phil condon
Dave and I are getting optimistic and are wondering if anyone has made up
set of Test Flight Cards. We have a couple of books, but if anyone has
already developed test routines it would really help.
Thanks in advance,
Chuck & Dave Rowbotham
RV-8A (almost done wiring)
Niantic, CT
From: | bcbraem(at)home.com.with.ESMTP (InterMail vM.4.01.02.00 201-229-116) |
> Thanks in advance,
> Niantic, CT
Chuck--
One of the best I've seen for collecting, collating and reducing flight
test data is:
Flight test Checklist
Jerry Milek
ORDER:
JaviFix
Trenton Centre
PO Box 22092
Trenton, Ontario
K8V 6S3
Canada
US $11.97+s/h$2.75=$14.72
Can $17.97+3.00=$22.44
http://www.reach.net/~javifix
Boyd.
I am overwhelmed with the number of responses. Too many to response to each
one so I am doing a blanket response. From the number and kind of responses
it is obvious this is a great group of people. And I do intend on ramping
each and every aircraft I can get to, to include notes. But that will be
private information for my learning pleasure alone. In other words I want
to get ideas for the future, not for the job.
After talking to my wife we are going to drag the camper over there and stay
at the RV camp. Hope to see everyone there.
Mike Robertson
Go over to http://www.evansville.net/~boeing/project_viking
THere is a very comprehensive test flight test plan for the KR-2. I know,
I know...but it is a good flight test plan and can be updated to the
RV's.
Click on Chapter 11, Flying the KR and then click on Article 1, KR Test
Plan.
Steve Eberhart
mailto:newtech(at)newtech.com
THE WING FLIES! - http://www.newtech.com/nlf for info on the new, flight
tested, KRnet/UIUC airfoils. Good job KRnet, you can be proud of your
contribution to Sport Aviation. Special thanks to Dr. Ashok Gopalarathnam
and Dr. Michael Selig for some great Sport Aviation airfoils.
One test is worth a thousand expert opinions but a thousand opinions are
easier to get. --plagiarized from an unknown author
All information, in any of my aircraft related correspondence, is strictly
food for thought requiring additional, qualified, engineering analysis.
> Aviation.
Oh how elegant..
What voltage did he recommend? I would be interested to know the device
number as well.
Doug Gray
From: | Glenn & Judi <foxinsocks(at)mediaone.net> |
Subject: | instrument panel labeling |
Hi,
Two instrument panel questions:
1) Where can I find out what is required labeling and verbage on the
instrument panel, i.e. breakers, switches, engine controls?
2) Does anyone know if dry transfer lettering will accept a clearcoat
spray?
3) What are some other panel labeling techniques?
Glenn Gordon
Subject: | OSH avionics specials |
Hi,
I am very soon to be needing avionics for my RV-6. Since I have never
had to shop for avionics, I was wondering if I am likely to get any
significant deals at OSH. Are they through manufacturers or
distributors?
Specifically I was looking for a Apollo GX65 GPS/Comm, SL70 Transponder,
and an altitude encoder.
Glenn Gordon
Subject: | Windshield defroster for RV-8 |
Anyone know of a good source for a windshield defroster kit for an RV-8?
I could probably cobble one together but times a wasting and I want to get this
baby in the air...
Thx,
- Jim Andrews
RV-8Aq ( Fuse - stuff )
Austin, Texas
N89JA ( reserved )
As I recall the zener is a 15-volt unit....also, it seemed that he got
around $15-20 for it...it's a very "husky" unit, probably many watts
Subject: | Re: instrument panel labeling |
A good guidline to use is FAR 23.1301. That is the guidelines that your
friendly inspector will go by at final inspection. Bottom line, everything
installed is supposed to be labeled.
For labeling I have been using a new type label maker. The tape comes in
clear, white, and some colors.
Mike Robertson
RV-8A
>From: Glenn & Judi <foxinsocks(at)mediaone.net>
>To: rv-list
>Subject: RV-List: instrument panel labeling
>Date: Thu, 11 May 2000 16:21:32 -0500
>Hi,
>spray?
>Thanks,
>Glenn Gordon
Subject: | installing wing ribs. |
I am ready to install the ribs to the spare and angles. Do I clamp the rib
flange to the spare web and hope they all line up evenly on the rear spare,
is shimming something that is normally done on the ribs? My conclusion is to
clamp them on the spare and drill the angles and the ribs should fall in
place hopefully. wondering what others have done.
Subject: | Re: OSH avionics specials |
In a message dated 5/11/00 5:45:44 PM Eastern Daylight Time,
foxinsocks(at)mediaone.net writes:
Hi,
distributors?
Glenn Gordon >>
All the big dealers offer "deals" at the big flyins.. For instance, I got my
new Lightspeed 25XL's at SNF for $495, while the catalogs showed $580 +/- at
that time. I've found Chief Avionics very competitive on price, with Van's
usually being competitive if they carried what I want..
KB
Thanks Mike,
I found that FAR online. It reads as follows:
Sec. 23.1301 Function and installation.
Each item of installed equipment must--
(a) Be of a kind and design appropriate to its intended function.
(b) Be labeled as to its identification, function, or operating
limitations, or any applicable combination of these factors;
(c) Be installed according to limitations specified for that equipment; and
(d) Function properly when installed.
[Amdt. 23-20, 42 FR 36968, July 18, 1977]
It seems rather vague in its verbage. I guess I need to take trip to the
airport and look at how certified aircraft manufacturers interpret the FAR.
Glenn Gordon
> If my RV is structurally safe up to a wing loading of 6g x gross weight,
and
> by some miracle I shave its weight down to half of gross, is it not now
able
> to take the stress of 12 g's (simplisticly assuming all the weight to be
> centered in the fuselage and none in the wings)? Same weight / force is
> experienced by the spar either way. If so, why are we told that " Va
> decreases as weight decreases." ??? Never understood this... "g" is not
a
> unit of weight, neither is 6g's... g times (aircraft weight) is a unit of
> weight, and weight, it seems, is what breaks airplanes before they stall.
Your plane is not safe up to 6g's at gross weight, only aerobatic max.
weight within weight/balance limits...
For airplanes with increasing Va with increasing weight, some structure
other than the wings is the limiting factor in that particular situation
(motor mount, tail, etc.). In other words, the lighter plane will develop
more G loading at max lift than the heavy airplane, even though the wings
are stressed the same. The motor mount only senses G loading, while the
wings don't care directly about G loading, only the angle of attack and
airspeed. You are right that the wings, for a given airspeed, develop the
same max lift just prior to stall angle of attack regardless of how heavy
the plane is.
Alex Peterson
Maple Grove, MN 6A
>Mike Robertson
>RV-8A
Mike,
What kind of label maker is that? It sounds idea for quick panel marking.
- Jim Andrews
RV-8Aq ( fuse - stuff )
Austin, Texas
N89JA ( reserved )
> Try Vans.
> Page 22 of the new catalog shows most of the Apollo stuff. At the top of the
> page they claim to be able to supply any thing from UPS Aviation
> Technologies. They list no prices, send them your query by email.
Thanks Norman,
I called Van's last week and spoke with Tom. They did have some great prices on
the avionics. He however admitted that their ability to make up wiring
harnesses went with the passing of Ken.
-Glenn Gordon
I used the dry-transfer letters and then sprayed a clear coat over them on
my Bellanca. It works very nice when you want to run the label around
instead of straight.
As Mike pointed out, there are some nice labeling machines as well. I have
a Brother P-touch and you can use various width tapes, and make various size
letters.
(Click here to visit our Club site at http://www.bellanca-championclub.com)
----- Original Message -----
Sent: Thursday, May 11, 2000 4:21 PM
> Hi,
> spray?
> Thanks,
> Glenn Gordon
Subject: | Re: Windshield defroster for RV-8 |
>this
>baby in the air...
>Thx,
>- Jim Andrews
>Austin, Texas
>N89JA ( reserved )
How 'bout a 12V powered travel hair dryer? Should keep the windshield clear
and would allow hairdo touchups before arrival.
OK, maybe not. *rimshot*
I've heard of some folks cutting a slot or two in the glareshield skin just
inside the windscreen and then mounting a small muffin fan horizontally
behind the instruments and right under the slot(s). You would simply open
up the cabin heat door and activate the fan to pull warm air up through the
fan and through the slots. Sounds like a relatively simple setup. I haven't
found any need for defrost yet, even up at 15,000' on a rather wet winter
day.
Brian Denk
RV8 N94BD
grounded due to 50mph gusts!
Bought a 12 volt fan from radio shack for a few bucks, cut a hole about 3"
in dia about 4 " from the leading edge of the windshield. Works great
provided you the the cabin heat coming in at the firewall.
RV6A 100 hrs in 6 months still ok
Sent: Thursday, May 11, 2000 5:25 PM
Subject: RV-List: Windshield defroster for RV-8
this
> baby in the air...
> Thx,
> - Jim Andrews
> Austin, Texas
> N89JA ( reserved )
Subject: | Van's new general manager |
I want to congratulate Tom Green at Vans, not part time any longer. A
full fledged General Manager of Vans Aircraft. I'm sure many of you, like
me, got advice from Tom down thru the years, when we had problems reading
the plans, etc.
Congratulations Tom
Cecil Hatfield
Subject: | Re: installing wing ribs. |
I have a prepunched kit.
I laid out the wing skins on a bench then placed the spar in the correct
position on the skins. Because of the prepunched holes I now knew where to
place each rib. I then marked the spar according to the prepunch mark.
If you think the ribs are different lengths and need to adjust the flanges
just take one rib and check its length with all the other ribs using your
bench as a false spar.
I don't think you'll have any trouble with rib lengths thou.
John Danielson
Fuselage
Ooops!
I apologize, I meant Bill. No disrespect meant.
-Glenn Gordon
> Thanks Norman,
on
> -Glenn Gordon
I bought it at Radio Shack, but th elabel tape is a generic kind that I have
been able to but at Office Depost and other places.
>From: Jim_Andrews(at)tivoli.com
>Subject: Re: RV-List: instrument panel labeling
>Date: Thu, 11 May 2000 17:48:19 -0500
> >Mike Robertson
> >RV-8A
>Mike,
>- Jim Andrews
>Austin, Texas
>N89JA ( reserved )
Glenn,
Like I said before everything has to be label as to what it is and which way
is on/off. For example, the master switch should have the word "Master"
either above, below or beside it, and "on". It is standard practice for
all switches to be up or outboard for "on" but that is by no means set in
concrete. As long as it is labeled for purposed and On/Off then that is all
that is needed.
All your gages now must be labeled with limits and common practice is for
those labels to be on the gage itself but again that is not set in concrete
for our aircraft. The limits could be...say... on a placard next to the
gage. But that may take a bit of convincing to you local inspector and you
may not want to go through the hassle. Everyone I have seen has put the
limits right on the gage with either a stick-on decal or paint. My best
advice is to get with your local Tech Counselor as he/she will know what is
required and also how your local FAA type is.
>Date: Thu, 11 May 2000 17:35:57 -0500
>everything
>Thanks Mike,
>Thanks,
>Glenn Gordon
From: | Scott Haskins <scott_haskins(at)yahoo.com> |
Subject: | Mustang II - (rv6)? |
All,
I have been watching the list for quite some time
trying to decide on a model. I thought I was ready
for a 6A till I ran across the Mustang 2
(www.mustangaero.com). It looks like a 6 and has a
slightly higher cruise speed. I also noticed that the
stall speed is a little higher. The kicker...the
mustang quickbuild is $10,795, while the 6a qb is
$21,643 (with a 6 month backlog). What am I missing?
I am not real knowledgable about either one, yet I
understand a $10000 difference on two "seemingly"
similar airplanes? Any thoughts?
Scott
> > Aviation.
>Oh how elegant..
>number as well.
>Doug Gray
I assume that electric Bob will jump in here and point out that a simple
zener diode will respond to short duration transients on the bus that are
not necessarily indicative of a regulator runaway. The design that Bob has
for OVP is relatively simple, relatively inexpensive, and is designed to
respond only to true runaway conditions and ignore transients of shorter
duration. I just read this chapter in the Aeroelectric connection last nite.
Regarding the earlier question about OVP for internal regulators, Bob is
there a relatively easy way to convert to an external regulator (in my case
the alternator I think is a Mitsubishi unit which came with the Mazda
engine I'm using)? Is this a recommended approach or would you stick to the
internal regulator/over-voltage relay depicted on your website? If
converting to an external regulator can you recommend one? I'm reliant on
electrical power for ignition and fuel injection so reliability is a major
concern.
Mike Wills
RV4 engine stuff (Mazda 13B)
willsm(at)spawar.navy.mil
Subject: | Re: Van's new general manager |
From: | "Shelby Smith" <shelbyrv6a(at)mindspring.com> |
Excellent!
I am one of many Tom has helped.
I guess everyone saw the Stoddard_Hamilton announcement. It's not an easy
deal.
Shelby Smith
RV6A - Skinning Fuselage - 200HP
N95EB - reserved
>From: cecilth(at)juno.com
>Subject: RV-List: Van's new general manager
>Date: Thu, May 11, 2000, 6:20 PM
> Congratulations Tom
From: | "Rick Caldwell" <racaldwell(at)hotmail.com> |
Subject: | Re: Mustang II - (rv6)? |
Scott, I know very little about Mustangs 1 & 2 so here it is. They were
9are0 built to be racers & they have a thin wing. The wing stalls abruptly.
For example, the Mustang 1 across the hangar from my -6 was flown for its
first loop. Just going past vertical, the plane snapped. Then a Mustang 2
was just sold here last month. The new owner was getting checked out in it
& they were doing wing overs. That plane also abruptly snapped. Guess its
the thin wing. My -6 has never given any surprises yet for this rookie
pilot.
Rick Caldwell
-6 53 hrs Melbourne, Fl
>From: Scott Haskins <scott_haskins(at)yahoo.com>
>Subject: RV-List: Mustang II - (rv6)?
>Date: Thu, 11 May 2000 17:28:43 -0700 (PDT)
>All,
>Thanks,
>Scott
> Glenn,
> that is needed.
Have any of the RMI uMonitor (and other brands, as well) users received
a hassle from the Feds about having to put redlines on the electronic
engine instruments? My plane was the first all-electronic panel my DAR
had ever seen.
Sam Buchanan
http://home.hiwaay.net/~sbuc/journal
Sorry I didn't explain my self clearly it 's not the length of the ribs that
concerns me. When you attach the ribs to the main spare will they all line up
evenly to the rear spares top or bottom of the wing. If one of the rib is off
and you pull it to line up with the rear spare, it will twist the main spare.
This might not be a problem you probably just clamp the ribs to the spare and
they line up with the rear spare.
From: | Bob DiMeo - Oracle <dimeob(at)powertel.com.au> |
Scott,
Aside for looking at thinks like who the designer is, how long has the
design been in the field, how many have been built, can you get a ride in
one before you plunk down the hard earned cash, etc, you should find out
what the completely fit up cost is. Not all "quick builds" are the same. If
I just look at the plain ol' RV kit compared to what you get from most kit
manufactures, you could call IT a quick build.
My 2 cents.
RV8 #423 (plain ol' kit!)
> From: Scott Haskins[SMTP:scott_haskins(at)yahoo.com]
> Reply To: rv-list(at)matronics.com
> Sent: Friday, 12 May 2000 10:28
> All,
> Thanks,
> Scott
Subject: | RV-8 #80620 flies |
I flew RV-8 #80620 (N624S) today for 40 minutes. Too busy learning and
scanning to write down any numbers. But..... what a trip, this is one HOT
aeroplane. Got in two landings.
Ed Storo RV-8 ( Joe Spence flew his RV-8 last sunday, has 6 hours as of
today)
From: | "Harvey Sigmon" <flyhars(at)earthlink.net> |
Listers: My first home built was a MII, with the laminar flow wing it had
a rather strange stall characteristic. It would initially stall like a RV
with a little shake. I had to install stall strips about 18" long on both
wings. I did this after it scared the hell out of me during stall test.
It was quite docile if you don't let it go into a deep stall. If you would
hold it into a deep stall it would break and wanted to roll over on its
back and fall for a while before starting to fly again. But you must
understand they were no kits like we have these days. I am on my second
RV-6, super airplanes, and there is no comparison, but that is my 2 cents
worth. and my view only. Hope this helps.
Harvey Sigmon RV-6AQB- Installing electric stuff
> [Original Message]
> From: Rick Caldwell <racaldwell(at)hotmail.com>
> To:
> Date: 5/11/00 9:11:40 PM
> Subject: Re: RV-List: Mustang II - (rv6)?
abruptly.
its
it
its
> pilot.
> Rick Caldwell
> >All,
> >Thanks,
> >Scott
--- Harvey Sigmon
--- flyhars(at)earthlink.net
--- EarthLink: It's your Internet.
In a message dated 5/11/2000 5:35:42 PM Central Daylight Time,
nhunger(at)sprint.ca writes:
<< > Specifically I was looking for a Apollo GX65 GPS/Comm, SL70 Transponder,
One thing to keep in mind is Gulf Coast will beat any price out there that
they can confirm.
From: | "Stephen Johnson" <spjohnsn(at)ix.netcom.com> |
Scott,
I considered at one time the Glassair series. There were many factors which
made me go for the RV-8, but one was the support and stability of the
company. I know that any spares built out of aluminium can be fabricated
somehow, so that makes the dependency on the company less than if the plane
were fiberglass, but I still think the solidarity of Van's has to be
considered in light of the announcement that Stoddard-Hamilton just went
bankrupt.
Steve Johnson
RV-8 #80121
Sent: Thursday, May 11, 2000 7:28 PM
> All,
> Thanks,
> Scott
Subject: | rudder rib/horn rivet question |
in drilling the bottom rudder rib to spar i have a hole(cener) to edge of
less than 2x.
instead of 8/32 i have 6/32 on all four holes. remember this rib is
sandwiched in between the rudder horn and the horn helps cover the rib
flange. order another or go ahead????????????????????? if it was not
sandwiched between the rudder horn and spar i would redo but this case is a
little different with the help of the horn.
thanx guys, bob paulovich in arkansas
i re-looked and measured. the holes in that bottom spar are already pre
drilled. there is no way it can be 2x because the rib flange is not wide
enough. i guess this is a case that the 2x rule a no go???
From: | "James Connell" <james_connell(at)bigpond.com> |
Sent: Friday, May 12, 2000 10:28 AM
> All,
> Thanks,
> Scott
From: | "Kevin Brewster" <kevin(at)synelec.com.au> |
Hi Scott,
The Mustang-II quickbuild kit is nowhere near as complete as the RV6-QB. My
understanding is that it is basically the same as the standard airframe kit,
but with all the welding & prefab spar options included and wings completed
"ready to close". The fuselage is as per the standard kit. What Mustang
Aeronautics calls the "complete airframe kit" does not include things such
as canopy, engine mount, cowling, fibreglass fairings etc. (although these
"finish kit" type items are available individually).
I believe both aircraft would cost about the same to build from "standard"
kits.
M-II kits have only been available relatively recently, and most so flying
examples have been scratch-built. The tight leading edge radius on the
Mustang's wing is apparently hard to form by hand, and there is a lot of
variation in stall-characteristics among these planes. Apparently
(according to Mustang Aero) the pre-formed leading edge skins in the kits
improve low speed performance considerably.
I think they are both great aircraft, and the decision really comes down to
personal preference. One factor which may be important to you is that the
RV6 has a lot more luggage space than the M-II. I was torn between the two
for many months until recently deciding on the Mustang. My personal reasons
are:
1. I think a well built M-II can look better than an RV6. There are a lot
of RV's down here, and they all look very good. If I built one, it would
just be another good looking RV. If I build a good Mustang, it will also
look very nice, without being just "another nice RV". (No offence)
2. The Mustang is slightly faster (Vne 200kt / 230mph), and slightly
stronger (+/- 6G). It does stall slightly faster, but I am hoping by
building light, not much. It is still capable of takeoff / landing
distances <500ft.
3. The Mustang has the potential for retractable gear.
4. Someone else in my area is also planning on building one.
5. My dad owns one, so I am familiar with the type.
In a different situation, I could easily have chosen the RV6 instead. I
hope no-one takes offence at my pro-Mustang opinion on this list. They are
similar aircraft and this list is a great learning resource for me. If it
weren't for RV's I wouldn't be anywhere near as ready to start construction
of any sort of plane!
Have fun making your own choices!
Kevin Brewster, Australia
(M-II flap kit just started)
Sent: Friday, 12 May, 2000 10:28
> All,
> Thanks,
> Scott
J.C. Whitney used to sell a 12 volt stand alone heater/blower defroster. It was
small and cheap, but could be used as an organ donor to build a sturdier metal
built in unit of some sort.
Bill Jaugilas
Northern Illinos Mountian Rescue Team
Lemont Illinois
> >this
> >baby in the air...
> >Thx,
> >- Jim Andrews
> >Austin, Texas
> >N89JA ( reserved )
> day.
> Brian Denk
> RV8 N94BD
> had ever seen.
> Sam Buchanan
I had an EIS unit on my previous plane (a Kolb SlingShot), and the DAR didn't quite
know what to do
about the markings. I explained that the limits were marked by way of the alarm
set-points, and he
accepted that. At worst, you'd have to placard the limits somewhere. In a few
weeks, I'll have the
same DAR inspecting my RV-8 with an RMI micromonitor, so we'll see how it goes
this time.
Russell Duffy
Navarre, FL
RV-8, sn-587, N174KT (wings on permanently this weekend)
PS- Congrats to Ed and Joe on their recent RV-8 flights! Sounds like there's going
to be a lot of
this in the very near future.
From: | "Nancy and Walter Shipley" <wshipley(at)esper.com> |
Scott, you may also want to consider not just the merits of the two
aircraft but the companies behind them. One of the primary reasons I chose
the RV8A was the fact that Van's has been in business 25 years and has over
2,000 of their airplanes flying.
In my view, Van's, while certainly not perfect, is still the class act in
terms of future business viability, support, readiness to make needed
changes, etc. Just my 2c worth!
Walt Shipley RV8A QB
N314TS (R) Fuselage/Finish
Regarding the discussion of aileron stops, I have found that my aileron
"up" travel is slightly over the 32 deg maximum specification in section
15(?) of the manual. Likewise, my "down" aileron travel is beyond the 17
degree maximum allowable.
Am I correct in thinking that installing stops to bring "up" travel within
specs will automatically take care of excessive "down" aileron travel? (One
lister indicated this was the case in the archives).
From: | Karl Schilling <k_schilling(at)iquest.net> |
please go look at what they call a quick build. no where close to what you get
from Van's!
From: Scott Haskins [SMTP:scott_haskins(at)yahoo.com]
Sent: Thursday, May 11, 2000 07:29
When I bought my GX-65 right after it came out in 1998, I shopped around
and then called Vans, and they had the best price by about $150. As I
remember I got it for about $2600 or 2700. Today I got the new Chief
catalog and they have it for $2900. On the back cover they talk about it
being the latest and best etc.
Cecil Hatfield
> Hi,
>never
> distributors?
>Transponder,
> Thanks,
> Glenn Gordon >>
>got my
>+/- at
>Van's
>KB
From: | "Randy J. Pflanzer" <rpflanze(at)iquest.net> |
I used decal paper and an ALPS MD-1600 printer on my personal computer and
made my own custom decals. Looks just like silk screening. Durability is
still a question which I hope to answer over the next few years.
Randy Pflanzer N417G RV-6
"FAA Inspection Next Week"
> Hi,
> spray?
> Thanks,
> Glenn Gordon
Subject: | Re: Aileron Stops |
Yes
Larry Pardue
Carlsbad, NM
RV-6 N441LP
From: | "Japundza, Bob" <bjapundza(at)dowagro.com> |
Billy,
I think what your worried about is drilling the rib reinforcing angles off
and causing misalignment at the trailing edge of the wing rib. The best way
I found (on my -6 non-prepunched kit) to ensure accuracy in this regard was
to drill the ribs to the spar, drill all the holes in the reinforcing angles
and bolt them on, but not drill them to the ribs until the wing was lined up
in the jig with the rear spar clecoed on. After everything is lined up you
can drill the angles to the ribs and have no worries about them being out of
whack. I used the same reasoning on the leading edge ribs also, not
drilling the ribs/angles together until I was positive everything was plumb
and square. By the way, I clecoed everything together during construction,
took everything apart, deburred, dimpled, primed then riveted. I did no
riveting until the very end and everything worked out great...much easier
IMO than riveting things as I went along, which I did on the first wing.
Bob Japundza
RV-6 flying in June sometime
to
Yes(sorta) , as long as all the push tubes stay in place. It depends on the
geometey of the bellcranks and the length of the push tube on the ailron. I have
stops installed as per the factory plans.
wshipley(at)esper.com on 05/12/2000 08:26:30 AM
Subject: RV-List: Aileron Stops
In a message dated 5/12/2000 9:03:06 AM Central Daylight Time,
cecilth(at)juno.com writes:
<< When I bought my GX-65 right after it came out in 1998, I shopped around
Cecil Hatfield >>
Actually they say its the best, but they also say they introduced it at EAA
in oshkosh in 1998.
How do you "rescue a mountain"???? IN Illinois, yet????
Sent: Friday, May 12, 2000 6:42 AM
Subject: Re: RV-List: Windshield defroster for RV-8
It was
metal
> Bill Jaugilas
> Lemont Illinois
RV-8?
get
> > >this
> > >baby in the air...
> > >Thx,
> > >- Jim Andrews
> > >Austin, Texas
> > >N89JA ( reserved )
clear
just
open
the
haven't
winter
> > day.
> > Brian Denk
> > RV8 N94BD
Subject: | Re: RV-8 #80620 flies |
Congratulations Ed!!!
What did it feel like?
Details PLEASE!!!... for those of us in your wake :-)
- Jim
N89JA (reserved)
Subject: | RV-8 Forced Landing |
I'm sorry to hear of the damage. Glad it wasn't worse.
Anyone know anything more specific about the gear failure (broken attachment
fasteners, ldg gear boxes pulled out of the fuselage, gear leg bent,
etc...). Knowing how robust the gear on the -8 are might help in choosing
the best surface (if possible!) in a similar landing situation. How about
the fuel smell?
NTSB Identification: SEA00LA084
Accident occurred MAY-07-00 at INDEPENDENCE, OR
Aircraft: OVEROSS VANS RV-8, registration: N998TT
Injuries: 1 Uninjured.
This is preliminary information, subject to change, and may contain errors.
Any errors in this report will be corrected when the final report has been
completed.
On May 7, 2000, approximately 0800 Pacific daylight time, a homebuilt
Oveross model Vans RV-8, N998TT, was substantially damaged when the landing
gear collapsed during a forced landing immediately after takeoff at the
Independence State airport, Independence, Oregon. The pilot was uninjured.
Visual meteorological conditions prevailed and no flight plan had been
filed. The flight, which was personal, was to have been operated under
14CFR91, and was local. The pilot reported that he took off on runway 34 and
immediately after breaking ground detected a strong odor of fuel in the
cockpit. He initiated a left turn during which the engine began to run
rough. Shortly thereafter all engine power was lost and the pilot executed a
forced landing slightly northwest of the airport. During the landing roll
the fixed main landing gear collapsed.
Subject: | Re: Trouble linking to URLs |
In a message dated 5/7/00 12:38:09 PM Pacific Daylight Time,
daronson(at)cwnet.com writes:
> Is anyone else having trouble linking up with aeroelectric or
> aamrelectric sites?
> Dave Aronson
Hello Listers:
My apologizes for not paying more attention. Our site has been down and I was
out of town dealing with a family tragedy and could not fix it from where I
was.
John @ AAMR/AirCore/Mar
ineCore
(Chick the blue link to go there)
Subject: | Website forms mailer back up . . . |
Our website is back up using a generic forms mailer that came
with the original configuration. I seem to have been swallowed
up in the policies and procedures swamp at my host's offices.
Couldn't get an expert to look at the problem until a form had
been filled out and dropped on somebody's desk; a day later expert
takes a peek and then phones me at the wrong number to leave voicemail
on quote to fix; a day later expert is out for the day; etc. etc.
Gave up and went back to square one.
In any case, the system is functioning as of this hour. I'm really
warming to the idea of having my site-server site in dedicated
hardware right in my office . . . we'll have DSL in our neighborhood
this fall so that just might be the ultimate solution.
Thanks to everyone for their patience.
( C.F. Kettering )
Subject: | Re: rudder rib/horn rivet question |
In a message dated 5/11/00 10:39:20 PM Pacific Daylight Time,
Bobpaulo(at)aol.com writes:
<< instead of 8/32 i have 6/32 on all four holes >>
A long time ago I called Van's with a similiar concern, although on a
different part. They (I've forgotten who it was) told me that as long as
there was enough edge distance so that the hole did not bulge out when the
rivet is squeezed it was ok. He added that if I was really concerned I could
add several rivets in between with adequate edge distance. I have followed
that guidance since.
Harry Crosby
-6 finish kit stuff
Subject: | Site update, new domain |
Gang,
Just wanted to let you know that I've updated my site by adding a couple of
pages and updating a few others. The FWF page is new, you might find details
of my fuel system interesting also. There have also been additions to the
Plenum/Cowl page and the Battery page for those of you interested.
Lastly, I have a new domain and url... www.rv-8.com. Very imaginative, huh?
If you would like to visit the site again you might want to remember to
change your Favorites or Bookmarks. Oh, my e-mail address has changed too to
randy@rv-8.com.
Blue skies,
Randy Lervold
RV-8, #80500, N558RL, plenum/baffling, soon to mount prop
www.rv-8.com
Home Wing VAF
Gang,
randy@rv-8.com.
Blue skies,
Randy Lervold
www.rv-8.com
Home Wing VAF
From: | Mark Schrimmer <mschrimmer(at)pacbell.net> |
Just when I thought I had every possible tool (yeah, right) for
building an RV, I learn about tank dies. Do most builders use them,
or will regular dimple dies work just fine for building your tanks?
If you start with regular dies and don't like the results, can you
re-dimple the tank skins with tank dies?
Mark Schrimmer
RV-9A
Irvine, CA
Ohhh... So many questions, so little time and space,,,
P-Condon? Is that how I should refer to you?
I'll try...
a prop that has
the engine ?
What does it mean "too much bite?"
Do engines have jaw muscles? Do engines chew?
And what's engine health got to do with that?
What is that "bite", anyway???
to do with prop
|overpitch ???
Well, prop is, after all, comprised of a set of airfoils in an
airflow. The fact that the airflow rotates, does add
complications, but does not change the basic physics... And,
airfoils in an airflow do (sometimes) stall...
|Is the gentleman
I guess that is me, right?
In fact, my Ex used to say I was TOO gentle, and I'm a "he", so
I guess that's OK by me...
everything that has any hint of an airflow around it, has a
boundary layer. Boundary layer, being a physical entity, does
have dynamics...
simular to
slow range of
|airfoil.
What VG do have no relation to airspeed.
In fact, most of the prop flies at a much lower reinolds number
than the wings...
Ronen.
full
|What do you think?
|Ronen.
|To: dimpletape(at)aol.com
||I noticed your ad in the current issue of Sport Aviation, and
|carefully read
||your web page information. I had earlier obtained a copy of
|your patent from
||the Patent Office, and purchased Dimple Tape for my RV6A.
||The results were extremely disappointing. I have a 160HP
|Lycoming driving a
||wood prop (Warnke) and normally the prop limits the engine
|speed to 2,550RPM
||(on a 'good day.') The normal cruise RPM is 2,300 and that
|produces 175MPH
||TAS, day in and day out. Maximum speed in level flight with
|half fuel, at
||8,000FT density altitude; best ever= 210MPH TAS.
||WITH the dimple tape, engine RPM ran up to 2,800 and was
|willing to go
||higher (red line is 2,700RPM.) At this high RPM the TAS
|DROPPED to 135MPH
||TAS. Slower RPM settings produced proportionally lower air
|speeds. No
||combination of altitude or engine settings resulted in
anything
|but VERY
||degraded performance.
||I applied the tape precisely per your directions.
||I removed it, and consider it a danger to the engine and the
|performance of
||the airplane.
||Comments? (PS I am also an attorney and electronics engineer.)
||RV6A
||Salida, CO
Subject: | Re: Randolph 912 slosh |
My rv6 had slosh, as per Van's instructions. Rebuilt right tank(new), so
only left tank has slosh. The slosh, when covered with fuel, can be seen
swaying back and forth like seaweed. I don't recommend using it. An
alternative, if you've already used it, is to put an inline filter in that
tank's fuel line, and always use the other tank for takeoff & landing. Good
luck.
Subject: | Re: Question re: conduit for the vertical stabilizer |
John: I left out any wiring in the tail. Whelen makes excellent strobe/fwd
facing position/aft facing position lights. Keep the tail as LIGHT as poss.
You'll be glad you did. Doug
Glenn: On my 6, I put the fuel vents about 3 in inboard of the side of the
fuse, works fine. Good luck. Doug
Subject: | KT-78A Transponder |
Can anyone tell me the difference between a KT-76A and KT-78A transponder.
John Hall
RV-8QB - Avionics
Subject: | navaid ap for sale |
Got a new navaid on Jan 15th which is now for sale cause my wife made me buy
the s-tec system thirty with alt hold. The unit is complete never mounted,
never powered up or otherwise manhandled. First 1200 takes I'll ship....if
not maybe I'll put it in my experimental Cherokee...hmmmmm.
Also I have a sigma tek directional gyro new as of may 1 that I could sell
if someone needs one right away. Its from gulf -coast avionics never
installed. I bought a gyro with heading bug so I no longer need it for this
rv. I'll sell for what I paid on invoice.(I'll have to look) If no one is in
need I'll just end up putting it in my other plane...
716.570.2933 Right coast
Steven DiNieri
capsteve(at)wzrd.com
Subject: | Re: KT-78A Transponder |
John,
The KT-78A is no longer produced. It puts out 113 watts vice 200 watts for
the KT-76A. Also, the -78A is only good up to 15,000, whereas the -76A goes
to 35,000. Other than that, not much.
Chris Browne
-6A FWF
Atlanta
> Thanks,
> John Hall
> RV-8QB - Avionics
From: | "Bill Shook" <billshook(at)mindspring.com> |
Subject: | Jack Kane in Amboy Washington |
Well, now I'm a bit frustrated (Ok, I'm furious). Jack Kane advertised a
wing kit, engine mount and gear legs and a steel stand for sale on
barnstormers. I answered that add, agreed to buy his parts, agreed to a
price, cancelled my ready to ship wing kit at Van's, had a cashiers check
drawn for the amount agreed upon and overnighted the check to him.....all
per HIS instructions. Now that he has my check in hand, he disappears for
two days (no response to calls or email). Today I get him on the phone to
see if all was OK and he informs me he sold the kit Wednesday evening (after
speaking to me Wednesday morning when I told him the check went out next day
air). So, I've sent this 'gentleman' $4K in certified funds and he does
business like this. He says he'll be returning my money.....
Just thought it should be known that he does business in this
way......should anyone else wish to deal with him in the future. My
cancelled order with Van's for the wing kit now puts me BACK IN THE BACK OF
THE LINE TO GET ONE. My empennage is finished, I had a wing kit ready to
ship to me, I cancelled it because of this dickhead and now I have to wait 2
1/2 months to get back to building. Dammit, I am pissed. Sorry for the
language, but I can't understand people who do things this way.......if he
were not on the other side of the country there would be one ticked off
marine standing on his doorstep right now. Actually, it's not that far by
airline.
Bill Shook
-4 stalled
From: | "Ernest Kells" <ernest.kells(at)sympatico.ca> |
Mark:
I would beg or borrow a set of tank dies - or share the cost with a couple
of other builders. You only need them for a very short time. It is my
weak-minded understanding that tank dies are not mated tightly, therefore a
little Proseal is squeezed through each rivet hole. It probably reduces
significantly the chance for leaks. I don't think that you can try this
approach when or if you don't like the regular solution. You would still be
in a serious rework project second only to screwing up a canopy. Too much
pain!
Ernest Kells
RV-9A - Wings in the Mail EAA: #430137
Sault Ste. Marie, Ontario Email: ernest.kells(at)sympatico.ca
___ I___
______( 0 )______
the KT-76-A is 250 watt KT-78-A is is 150 watt as certificated if cavaty
has been replaced most likely to be 250 watts anyway.
Pat
IMHO tank dies are not needed. The popularity in the tank dies is that if
you get proseal under the rivet in a normal dimple the rivit will sit a
little high after setting. The tank dies create a slightly deeper dimple
to lessen this effect. If you prep each dimple with a couple of twists
of your deburring tool the effect is the same. For that matter prep all
12000 holes in the skin with the deburing tool after dimpling and all
your rivets will look even better.
Gary Zilik
From: | "Eustace Bowhay" <ebowhay(at)jetstream.net> |
Subject: | Jon Johanson's number three trip around the world. |
Thought all you RVer's would be interested to know that Jon is departing
Australia on Monday in his RV 4 and should arrive in a couple of weeks. The
following is the message I received yesterday from his manager.
Hello,
Just to let you know that the website for Jon's flight is being launched
tomorrow morning here in Adelaide. The address is www.jonjohanson.on.net
The media release is attached (word doc). Also attached is the latest
itinerary (exel).
Jon is hoping to attend airshows in :
Norway, Sweden, Denmark,Ireland, England
He will be back for Oshkosh.
Sue Ball
Manager for Jon Johanson
Subject: | Re: Jack Kane in Amboy Washington |
Go for it Bill!
>..if he
airline.
Bill Shook
-4 stalled<
Ed & Joe,
CONGRATULATIONS & WELL DONE !!!!
To Both of You
RV-8A (wiring)
Niantic, CT
>From: ERSF2B(at)aol.com
>Subject: RV-List: RV-8 #80620 flies
>Date: Thu, 11 May 2000 22:15:52 EDT
>of
>today)
anybody have any pictures on-line on how they routed the prop cable on a
O-360 RV-4? Im looking for a idea or two before drilling holes in the
firewall.
R. Burns
RV-4 s/n 3524 N82RB
www.flash.net/~hsierra
some time this summer i hope..........
Bill Shook,
I work for an airline. Do you want a free pass to go kick ass?
Chuck - RV6 (50%)
In a message dated 5/11/00 7:00:31 PM Pacific Daylight Time, BillyRV6(at)aol.com
writes:
<< When you attach the ribs to the main spare will they all line up
off
spare.
and
they line up with the rear spare. >>
Billy,
This is one of those things where your thinking and concern is logical
but, in actual practice, the parts are accurate and line up well enough that
it is not issue. Just clamp the ribs to the main spar and rear spar. As
long as the main and rear spar are correctly aligned relative to each other
in your jig all will be well.
Dale Wotring
RV6A Working on wireing
don,t use tank dies on wing skins and ribs, they make the holes too big for
clecos to hold
Sent: Friday, May 12, 2000 2:00 PM
Subject: RV-List: Tank dies
> Mark Schrimmer
> RV-9A
> Irvine, CA
Yes they did. I saw it there and bought it in August, Bill B. gave it to
me at the homecomming at the factory in Sept .
Cecil
>around
>it
> Cecil Hatfield >>
>at EAA
>in oshkosh in 1998.
Sloshed my tanks before putting any fuel in them , they were clean in my
opinion, prepped with Aluma-Prep before riveting. Three years later it
started coming loose.
I cut inspection holes in the back in each bay and removed all the slosh
with MEK, it would almost have been easier to build new tanks. No slosh ever
again for me.
In my case it all had to be removed as it was coming loose in large pieces
and could easily block the pick up tubes.
Eustace Bowhay Blind Bay, B.C. Floor skins in the 6A
Sue him for breach of contract. His action is a breach and you have lost
something as a result.
hal
Sent: Friday, May 12, 2000 3:32 PM
Subject: RV-List: Jack Kane in Amboy Washington
(after
day
OF
> airline.
> Bill Shook
> -4 stalled
From: | Charlie and Tupper England <cengland(at)netdoor.com> |
> > > Aviation.
> >Oh how elegant..
> >number as well.
> >Doug Gray
> concern.
> Mike Wills
Mike,
(private post due to history of flame wars on this subject)
My experience has been that most of the hardware old enough to use an
external regulator is also less reliable. Note that I said 'my
experience' and 'most.' I went through 4 externally regulated
alternators & at least that many regulators in about 4 months before
switching to an internally regulated alt. almost 5 years ago, with not a
single glitch since. None of the above failures were of the o/v nature &
none damaged any avionics.
I don't use o/v protection, but if I did, it would probably be the very
simple zener/fuse arrangement. I'm sure Bob's solid state system is more
sophisticated & works better, but as the guy used to write in BYTE
Magazine, 'Better is the enemy of good enough.'
My personal feeling about external regulators & o/v protection is this:
Once I reach a certain (hard to define) comfort level about the
reliability of a system, I'd rather not add failure modes. Over-voltage
type failures in self-regulated alternators seem to be so rare that you
hear about every one. Generator/regulator & alt/regulator failures are
so common that they are treated like dry vac pump failures, you know
they are going to happen sometime in the near future.
I hope the above will be worth at least a little more than its cost. :-)
I'm looking forward to another Mazda taking to the air. As soon as I
finish my (literal) homebuilding project, I hope to start on a rotary
project myself.
flying -4 (Lyc)
Slobovia Outernational Airport
Hi Jim:
I also am somewhat familiar with Glassair/Glasstars operation.
For several years we were Stoddard Hamilton's/Glassair's electrical connector
supplier...Until they could not pay their bills, would not pay their bills
and got real unpleasant when asked to pay up.
They had got to the point of not making most of their parts. Almost
everything was farmed out and they slowly dumped most of the original staff
that actually did the work. The staff that made them successful in the first
place.
I am sorry that a bunch of folks lost their jobs, but you are absolutely
right about a group of "Non Value Added personnel."
They made a great kit plane and were at one time a pleasure to work with. I
am sorry that the old company is gone...But in my opinion you reap what you
sow.
So if any of you are building Glassairs or Glasstars and need your your
electrical bits and pieces, we got them.
ineCore
Subject: | Re: Vacume and fuel |
With a "both" setting on your fuel selector, you will be feeding from both
tanks at once. However, you'll never start with exactly the same amount of
gas in both tanks. Also, because of fuel line routing, vent installation, and
other variables, one tank will probably feed easier than the other.
Therefore, one tank will run out first. (Note, because of the well head
pressure generated at the carb with high wing mounted fuel tanks, this
situation isn't important for high wing aircraft.).
When that first tank runs out, the air from that tank is going to get sucked
to your fuel pump more easily than the fuel from your other tank (Remember,
gravity isn't helping fuel flow with our low wing RV's.) So, when the first
tank runs out, the prop's gonna stop.
Depending on your altitude at flameout and a whole bunch of other factors,
you may be able to get a restart before you tie the record for low altitude
flight.
There is much discussion of this in the archives.
KB
From: | "Larry Helming" <rhelming(at)evansville.net> |
What are the test flight cards?
Sent: Thursday, May 11, 2000 3:44 PM
Subject: Re: RV-List: TEST Cards
up
> RV's.
> Plan.
> Steve Eberhart
>clecos to hold
>> Mark Schrimmer
>> RV-9A
>> Irvine, CA
I used tank dies for my tank skins. They let the rivet sit flush
even though there was some proseal between the rivet head and the
skin. I would use them again. They are also useful to dimple the
underlying structure on the rest of the aircraft, so the dimple in
the skins from the regular dimple dies sits nicer.
I find it better to use a #41 drill for all holes that will be
dimpled, rather than the usual #40. The hole gets bigger when you
dimple it, and rivets (and clecos) fit pretty loosely if you use a
#40.
Kevin Horton RV-8 (cockpit floors)
Ottawa, Canada
http://members.xoom.com/kevinhorton/rv8.html
This is RV building related because if a large, established kitplane company
can close it's doors with no notice, then this public forum should be free
to discuss the reasons why. I couldn't imagine how I would feel if I was
building a Glassair right now.
There seems to be two reasons so far.
First their website claims slow sales. This would support the "high on the
hog" theory. Companies with a large managerial staff need large revenue to
survive. However, a well established company (without a big lawsuit on the
horizon) would still have the potential to be sold and continue operations
with a new owner.
Second is the speculation from an earlier post that they are being sued out
of existence. This would mean that they are lying on their website. I find
it interesting to note that the son of the deceased pilot quotes the
"Purchase / Release Agreement" that indicates to me that Stoddard Hamilton
doesn't have to take any responsibility for pretty much any thing. I guess
the main reason I have written this post is to ask if there are any American
lawyers on this list that can comment on this. Can a release agreement like
this be thrown out in a court of law? See the son's website for the details
of the agreement and accident.
http://hometown.aol.com/glastarcrash/myhomepage/index.html
It is all very sad,
Norman Hunger
> This is just out of couristy but why cant you run on both tanks at the same
> time instead of switch tanks every 15 mim, if you plan your flight low fuel
> should not be a problem. and second question is why do you need a vacuum
> pump, why not put a vacuum resovore in and regulate the vacuum to or from
> the gages.
> Just curious
Hello Yall
There have been plenty of replies to the fuel tank question. I will
attempt to answer the vacuum question. I am not an IFR pilot, but
know how the system works. If any one on the list has experience with an
manifold pressure vacuum backup system and the limitations of it I am
sure all on the list would like hear about it.
The vacuum system requires a constant flow of vacuum, not just vacuum
being held in reserve. When full throttle is used, as in 75%
power\8,500 ft. altitude cruise or full throttle go around, you have no
engine vacuum to drive the gyros. The vacuum reservoir reserve would be
quickly depleted. To get 4 inches of gyro vacuum from the intake
pressure port one would have to fly with manifold pressure 4 inches less
than the full throttle manifold pressure reading. Using intake pressure
for the gyros would only be practicle as a backup system for reduced
power flight or decents. A go around in IMC would likely be without
Gyros. Better get it right the first time.
If I am wrong here feel free to correct me. Constructively please.
George Meketa
RV-8 fuselage
#80984
Subject: | OV protection w/built in regulator |
Agreed . . . and MOST of the externally regulated alternator
hardware out there is specific to aircraft and designed/certified
20-30 years ago. Check the service difficulty reports using keyword
"alternator" and then filter for single engine aircraft . . .
Everything that might be deduced in the way of alternator failures
happens every month in a TC aircraft . . . "casting broke, thru-bolts
stripped, brushes worn out, windings burned, bearings siezed, diodes
shorted, etc. etc." FBO's love 'em . . . regulated job security well
into the new century.
On the other hand, when you take a brand new, Nipon-Dienso, 40 or
60 amp alternator, disassemble for modification to run external
regulation, balance the rotor to about 10x tighter specs than
they come out of the factory and re-assemble with due care, you
end up with an alternator that runs well for a very long time.
I have first hand knowledge of 2,000+ such alternators sold over
the last 8 years . . . not one has returned for wear-out or
repair. It's the difference between a 1990's product and a
1960's product.
The zener fuse combo was certified onto early American and subsequently
Grumman-American aircraft. It's a sort of poor-man's crowbar ov
protection scheme. When I first heard of it, I was skeptical.
It has been about 15 years since I brass-boarded this system onto
an alternator-battery system in the lab. Here's what I found.
Proper operation of the system depended heavily on two things.
(1) A fuse (fast acting) had to be used upstream of the zener
and (2) the zener had to be a 1W glass encapsulated device -
p/n 1N4745.
It works like this: In an ov condition, the zener tries its
best to keep the bus voltage from rising above 16 volts. In so
doing, internal disipation rises well above the diode's 1W
rating and it commits electronic suicide by becoming a dead
short. The resulting short opens the fuse and corrals the runaway
alternator.
Over the years, folk who did not understand the "balance of
power" implicit the this design made well meaning-changes to
this scheme with the unintended consequences of degrading
performance or even making the system ineffectual. Common
errors include:
(1) Replace pesky fuse with a real circuit breaker: Opening
times for breakers vs. fuses is 10x to 50x longer. The slow
response of the breaker stresses the zener to explosive
destruction. The altenrator runaway continues unabated.
(2) Substituted any ol zener with the number "1N4745"
printed on it: Plastic parts were unable to withstand
the rapid onset of heat dissipation and explosive
destruction of the zener results. The runaway continues
unabated.
(3) Substitute a really husky 16 volt zener for the itty-
bitty 1W device. This change was often combined with
a change from fuse to circuit breaker. The general idea
was to make the protection scheme "reusable" . . . no
fuses -or- zeners to replace: The general effect of this
modification was to push the time-constant for tripping
OV protection out by hundreds of milliseconds to perhaps
several seconds. Contemporary OV protection is designed
to react to a step from 14-20 volts on the bus in 50
milliseconds or less.
No argument about comfort levels . . . I'll suggest that
the greatest body of experience with aircraft alternators
comes from the world of certified aircraft. My best
recommendation is to see what's happening with true
state-of-the art designs and fabrication techniques.
There's a mistaken perception that the certified aircraft
world is benefiting from the advance of technologies
in all respects . . . I'll suggest it happens only in
area of things you bolt into holes on the instrument
panel. Stuff under the cowl has evolved very slowly if
at all in 50 years or so that have passed since
the first generator was bolted to a single engine
airplane. If you want to know what a modern alternator
can really do for you, you'll have to limit your
observations to the real leading edge of aviation
technologies . . . check out the flight line at
OSH.
( C.F. Kettering )
From: | "Builder's Bookstore" <winterland(at)rkymtnhi.com> |
Subject: | Re: Glassair Closed |
> can close it's doors with no notice, then this public forum should be free to
> discuss the reasons why. I couldn't imagine how I would feel if I was building
We can only hope (and I tend to think it's true) that Van is a better
businessman than the folks at Stoddard Hamilton.
There is also comfort in the sheer numbers of RVs flying and being built. If for
some reason Van did have to close his doors, the market is probably big enough
to entice someone else to quickly come in and fill the vacuum. The simplicity of
RV parts compared to Glasair parts would also help to make that a quick and
fluid transition.
On the other hand, this is a precarious business with none of the companies
involved having tremendous amounts of reserve capital. I think with Van's we are
in the best situation that we could possibly be, but this is still a risk we
have to take.
Andy
To answer the why question if I may: You see most of
the guys who build rv's come from the cessna
community high wings and don't bother with switching
that often unless you go with the "big" cessnas so you
just simply put the selector in both mode and forget
about it. That said, People who don't regularly fly a
plane in witch you switch tanks get a little
aggravated about it so they ask the question why. You
guys have done a splendid job in explaining the why to
them, now they know
Glenn
> > the gages.
> > Just curious
> Hello Yall
> question. I will
> IFR pilot, but
> as in 75%
> around, you have no
> from the intake
> system for reduced
> likely be without
> George Meketa
> RV-8 fuselage
> #80984
> through
> Matronics!
Glenn Williams
8A
A&P
Send instant messages & get email alerts with Yahoo! Messenger.
The release agreement can be applied to the pilot. It cannot however be held
against his relatives or his estate. The passenger (a CFI giving the builder a
BFR), his estate, and his relatives, are free to sue all in sight including the
builder and Stoddard-Hamilton.
Bruce
Glasair III
> with a new owner.
> It is all very sad,
> Norman Hunger
Subject: | Re: RV-List Digest: 77 Msgs - 05/09/00 |
From my friend Earl Lawrence at EAA. He is willing to go to bat for you when
your local FSDO reads and makes their own determination as to what the Regs
say.
Sent: Saturday, May 13, 2000 9:14 AM
Subject: RE: RV-List: Re: RV-List Digest: 77 Msgs - 05/09/00
> Dennis:
> From the EAA web site, members only section - government- hombuilt you can
> find the following:
> Flight Over Congested Areas
> Since the issuance (05-28-98) of FAA Bulletin # HBAW 98-11 and HBGA 98-05
> (http://www.faa.gov/avr/afs/hbaw/hbaw9811.txt), we have been seeking FAA
> clarification of flight over congested areas for AB experimental aircraft.
> On 07-14-99 FAA Bulletin # HBGA 99-13
> (http://www.faa.gov/avr/afs/hbga/hbga9913.doc) was issued - stating AB
> experimental aircraft are allowed to fly over congested areas. The
07/31/99
> meeting with the FAA (see above) highlighted the need for all FAA
> MIDO/FSDO/DAR inspectors to comply with this bulletin.
> Also for new homebuilts the FAA has revised the operating limitations for
> these aircraft also on EAA's web site at
> http://members.eaa.org/home/govt/homebuilt.html the following can be
found.
> FAA Order 8130.2D Certification requirements for homebuilt
> Sport Aviation Article about FAA Order 8130.2D
> FAQ's on FAA Order 8130.2D
> FAA Order 8130.2D Sections 6 and 7 - Homebuilt (zipped .doc file)
> FAA Order 8130.2D Sections 6 and 8 - Exhibition (zipped .doc file)
> FAA Order 8130.2D sections 6 & 9 - Kit-built aircraft
> Required forms: For your copy of the 280 page order in its entirety send
> $20.00 (includes shipping and handling) to:
> EAA
> Attn: Government & Industry Relations
> P.O. Box 3086
> Oshkosh, WI 54903
> I hope this answers your questions if you have any more after reviewing
this
> information feel free to contact me. Also anytime you may have a
regulatory
> question for EAA you can email us at govt(at)eaa.org and one of my staff will
> answer your question.
> Earl Lawrence
> -----Original Message-----
> From: Dennis Persyk [mailto:dpersyk(at)worldnet.att.net]
> Sent: Wednesday, May 10, 2000 6:20 PM
> To: elawrence(at)eaa.org
> Subject: Fw: RV-List: Re: RV-List Digest: 77 Msgs - 05/09/00
> Earl,
> Could you please comment on this letter of understanding and if I can
indeed
> fly my homebuilt, after fly-off period, anywhere I can fly my certificated
> Cessna and with the same restrictions.
> Thank you.
> Best regards,
> Dennis Persyk
> EAA 170614 Chapter 790
> From: Cy Galley <cgalley(at)accessus.net>
> Date: Wednesday, May 10, 2000 5:34 PM
> Subject: Re: RV-List: Re: RV-List Digest: 77 Msgs - 05/09/00
> >It is amazing how many read the regs and then quote hook, line and verse
> and
> >they are wrong. Yes, it does say that, BUT there is a letter of
> >understanding between the FAA and the EAA that once you fly off your test
> >flying, you can fly anywhere that a certified plane can fly with the same
> >restrictions. If you or your 90 wonder need additional material or
> >explanation, contact Earl Lawrence, in Government Relations at EAA...
> >From: "Larry Rush" <krush(at)iquest.net>
> >To:
> >Sent: Wednesday, May 10, 2000 10:24 AM
> >Subject: RV-List: Re: RV-List Digest: 77 Msgs - 05/09/00
> >> I talked to a DAR friend of mine who is just starting as a FAA EXP A/C
> >DAR,
> >> and he mentioned a Part 91 reg stating that AFTER we get our
> Airworthiness
> >> Cert we are still not legal to fly over heavily populated areas. Is
this
> >> true??? Surely not!
> >> Larry, RV-6A final/finish stuff,3SY Avon.In.
Subject: | Fw: [c-a] Propeller change and the FAA |
Another good reason to join the EAA. Be sure to get your paper work updated
so the FSDO can't hassle you.
Sent: Saturday, May 13, 2000 9:25 AM
Subject: RE: [c-a] Propeller change and the FAA
Anyone who is making a "major change" to their homebuilt should ask their
local FAA office to update their operating limitations to the new ones
outlined in FAA ORDER 8130.2D. This was issued in September 1999 and can be
downloaded from the EAA members only web site at,
http://members.eaa.org/home/govt/homebuilt.html. The new operating
limitation dealing with major changes states the following:
(17) After incorporating a major change as described in
21.93, the aircraft owner is required to re-establish compliance with
91.319(b). All operations will be conducted day VFR in a sparsely populated
area. The aircraft must remain in flight test for a minimum of 5 hours.
Persons non-essential to the flight shall not be carried. The aircraft
owner shall make a detailed log book entry describing the change prior to
the test flight. Following satisfactory completion of the required number
of flight hours in the flight test area, the pilot shall certify in the
records that the aircraft has been shown to comply with 91.319(b).
Compliance with 91.319(b) shall be recorded in the aircraft records with
the following or a similarly worded statement: "I certify that the
prescribed flight test hours have been completed and the aircraft is
controllable throughout its normal range of speeds and throughout all
maneuvers to be executed, has no hazardous operating characteristics or
design features, and is safe for operation. The following aircraft
operating data has been demonstrated during the flight testing: speeds
Vso______, Vx______, and Vy______, and the weight______, and CG
location______ at which they were obtained."
Earl Lawrence
Sent: Wednesday, May 10, 2000 9:06 PM
Subject: Fw: [c-a] Propeller change and the FAA
WOW look at requirement #2. If it was a one of a kind plane, he would be
screwed. I have a feeling that his FSDO doesn't really have a clue and are
making local interpretations.
Sent: Wednesday, May 10, 2000 5:51 PM
Subject: [c-a] Propeller change and the FAA
> [The Canard Aviators's Mailing list]
> Dear Canardians,
> I could use your help.
> I am switching my LongEZ from a Great American Propeller to a Margie
Warnke "Air Claw" propeller. I
> have been in contact with the FAA FSDO in Scottsdale, AZ about the
paperwork I need to process. I
> have gotten a different answer each time I called them from Tucson. Last
week I drove to Scottsdale
> (Phoenix suburb) and sat down with an examiner with all my papers and log
books and this is what I
> was advised to do. You will see at the end of this note where I need some
help here.
> FAA Examiners instructions:
> 1) In spite of some of the earlier, conflicting instructions, I will not
have to have a new
> airworthiness certificate issued.
> 2) I will have to send a letter to the examiner stating my intent to
change props and provide (this
> is the important part) data on the prop and any information I can dig up
showing that the same type
> has been used on a LongEZ before. Data regarding hours in service and
registration numbers of the
> aircraft using the prop type will be important. (see info at end of note)
> 3) I will have to state the number of hours (5 to 10) I plan to employ in
testing the new
> configuration in a restricted flight area away from populated regions (I
guess they don't like to
> have planes falling on houses and people - but I know that).
> OK. Here is where I am asking for help.
> I have contacted Margie Warnke and she will provide me with the data from
three LongEZ customers. I
> could use more. She says that there are hundreds of satisfied customers
and many LongEZ drivers.
> If you are a LongEZ driver flying a Warnke Propeller, I would appreciate
your sending me the
> following data (no need to clog the canard-aviators line with private
communications - just reply
> directly to me. If you are interested in passing the information on, I
will be glad to summarize
> the data for the group):
> Aircraft type:
> Registration Number:
> Prop description: e.g. pitch and diameter, manufacturer
> Engine type: manufacturer and HP
> Cruise speed:
> Cruise rpm:
> Hours in service:
> Satisfaction:
> Comments:
> And anything else that might be pertinent.
> Thanks,
> Marc Borom
> Tucson, AZ
> -For details on sponsors of this list, copyrights, and how to remove
> -yourself from this list, please visit:
> http://www.canard.com/canard-aviator-sponsors.html
> (c) 1997,1998, 1999 Canard Aviators. support(at)canard.com
From: | Glenn & Judi <foxinsocks(at)mediaone.net> |
Hi,
Can someone pleas suggest some good anchoring locations for the #2 & #4
wires going to the starter and alternator. My starter solenoid is on
the firewall, but I am not sure where to anchor it inbetween the
firewall and the starter itself. Same goes for the alternator.
Glenn Gordon
Subject: | Battery Dimensions Needed |
Hi,
I have the basic case dimensions for the Concorde RG-25 battery as
supplied by Van's. Since they differ from the dimensions listed in the
archives, can someone verify them as correct?
5"W x 7.5"L x 6.625"H
I was also hoping someone could provide me with the following
information related to the position of the terminals?
1. Center to center distance of the terminals.
2. Center to edge distance of the terminals (both X and Y axis)
3. Which terminal is + and which is -
Glenn Gordon
Subject: | Re: wire routing |
In a message dated 5/13/00 3:00:32 PM Eastern Daylight Time,
<< Hi,
Glenn Gordon >>
I'm not sure there are any *good* ones. Mine, and most others I see run the
big wires along the engine mount (using adel clamps and/or zip ties) and then
along the sump/engine case seam (using adels attached to the sump bolts).
KB
From: | "Craig Hiers" <craig-rv4(at)worldnet.att.net> |
You don't want to waste all that time going through a law suit, not to
mention
the aggravation.
Besides, think how much better you would feel after hearing a few bones
breaking.
Craig Hiers
RV-4 N143CH
Just crossed the 100 hour mark
> hal
> From: Bill Shook <billshook(at)mindspring.com>
> To:
a
check
him.....all
for
to
> (after
> day
> OF
to
wait
> 2
he
by
> > airline.
> > Bill Shook
> > -4 stalled
Subject: | Re: Battery Dimensions Needed |
In a message dated 5/13/00 3:29:30 PM Eastern Daylight Time,
<< Hi,
Glenn Gordon >>
I've got the RG-25XC. I expect the dimensions are the same as the plain 'ol
-25. It is 5 1/8 wide, 7 5/8 long, and 6 3/4 tall. I think the extra 1/8" in
length and width directions is because the top of the battery is slightly
larger than the rectangular plastic body of the unit, which is probably where
they got their lenght and width measurements.
The terminals are located on one of the "long sides" of the battery. They
are 5/8" from the long side, and 1" from the end of the battery. These
measurements are to the centers of the terminals. This puts the terminals 5
5/8" apart, though I didn't measure this (although it would be a neat way to
short the terminals together)...
If you are standing over the battery with the terminals on the left side, the
positive terminal will be at the bottom left corner.
I'd suggest you get your battery first, then finish your battery box. I had
to modify mine from plans once the battery arrived. The bad part was I'd
already painted the box and was out of that paint...
KB
I've published a flight model of an RV-3 in the X-Plane registry. If any of
you have the time to download the Free Demo Version of X-Plane
www.x-plane.com and the RV-3 design I've created, I would appreciate any
feedback. And yes, it even exhibits the same poor yaw dampening from too
little vertical stab.
Bruce Meacham
Subject: | Re: OV protection w/built in regulator |
Charlie and Tupper England wrote:
> Mike Wills wrote:
> > > > One of the simplest way to provide overvoltage protection is to use Mark
> > > > Landall's (spelling?) zener diode and fuse combination. Simple to install,
> > > > foolproof, and inexpensive. He has an ad usually in the ad section of Sport
> > > > Aviation.
> > >Oh how elegant..
> > >What voltage did he recommend? I would be interested to know the device
> > >number as well.
> > >Doug Gray
> > concern.
> > Mike Wills
> Mike,
> project myself.
> Charlie
> flying -4 (Lyc)
Oh oh must have missed the privacy button:) Any way Charles
I agree with you 100% the internal regulators nowadays are as
reliable as anything out there. Yes there is always the
possibility of something going wrong but there is that chance
and possibility in any thing we hook up to our airplanes.
Subject: | Re: Flight Model |
I hit send way too soon. Installation assumes you understand how to unzip,
this will work on either Mac or Win OS. To install:
1. Follow the instruction for installing X-Plane. I recomend you install
the classic version as it is almost garenteed to work regardless of graphics
cards and drivers, etc.
2. Then unzip this file: www.seanet.com/~bruceme/rv3.zip in the x-plane
expiremental aircraft folder.
3. Boot X-Plane, from the file menu select open. And locate rv3.acf at the
prompt.
There you are on the runway in an RV-3!
Some known issues: The power, handling and stability all seem about right,
but I was unable to factor out adverse yaw the way that Dick did so many
years ago with the very effective Frez(sp) aelarons. So there's a heavty
amount of adverse yaw. I hope I can remidy this at some point. Also
matter what. This is a known issue with the Sim.
Please Enjoy!
Bruce Meacham
RV-3 3456B
www.seanet.com/~bruceme/ShotGun.htm
Sent: Saturday, May 13, 2000 2:02 PM
Subject: Flight Model
of
> Bruce Meacham
Subject: | RV-6/6A Elevator control tube length |
-6/6A builders
I could not find anything in the archive on this so here goes. For the
forward elevator control tube, the one that is 3/4 in. diameter that goes
from the control column to the bellcrank, sheet 40 of the plans shows a
length of 47 1/2 inches. Assuming that this refers to the tube length
without rod ends, the overall length between bolt hole centers with the rod
ends set to the middle of their allowable travel would be 51 1/2 inches
(center to center of the bolt holes). But, when I set the control column at
about mid fore and aft travel and the bellcrank vertical as shown on the
plans, it looks like an overall push rod length of 50 5/8 inches is required
(or 46 5/8 for the tube without the rod ends). This 7/8 in. difference is
more than the available adjustment in the rod ends. Can anyone remember
what they did here. I'd sure hate to have to make this part over (I'm hoping
there will be at least one part on this airplane that I only make once).
Harry Crosby
-6 finish kit (stumped again)
Subject: | Re: RV-6/6A Elevator control tube length |
Harry,
I'm sure a 6 builder will step in and confirm this but what I had to do on my 8
for the push rod that goes from the bell crank to the elevator was "measure the
distance first" and then cut the tube length. I was saved the expense of having
to do it twice by a builder in San Antonio that informed me that the plans were
WRONG! Imagine that? I ask Ken about this at Van's and he said that the
recommended practice is to ALWAYS measure the distance first and then cut the
tube. He said that there are so many variables that go into making a fuselage
that some are longer and shorter than others.
Maybe someone will see this in the archives and not have to make a push rod more
than once.
- Jim Andrews
RV-8Aq ( fuse and finish )
N89JA (reserved)
Subject: | Re: GLASSAIR OUT OF BUSINESS |
---- Original Message -----
Sent: Saturday, May 13, 2000 9:07 AM
Subject: Re: RV-List: Re: GLASSAIR OUT OF BUSINESS
> In a message dated 05/11/2000 12:14:00 PM Pacific Daylight Time,
> dpetri(at)uswest.net writes:
> << they were forced to declare
> bankruptcy earlier this week. >>
> Simply a matter of opinion, I feel that it is a simple case of living too
> high on the hog.
Not my opinion, Jim. Ron Wanttaja wrote that he stopped by and found a sign
on the door saying they were in bankruptcy. So maybe a matter of rumor, eh?
Dave
RV-6 Preview Plans (the credit card keeps calling, "use me, use me...")
Flight cards should be used on your test flights. They help you keep track
of what you are going to do before you go flying, what you are doing once
you are in the air, and what you did and didn't do once you get back on the
ground.
I used them and wouldn't test fly without them. I had a set series that
went over all the things I needed to accomplish to complete my test
flights. (Early on, they helped me to dream of what I would be doing once
the ol' girl was flying.) They changed from my initial set as my goals for
each flight changed, and sometimes I would take two or three flight cards
up in case I needed to do extra things or if I wasn't able to do what I set
out to do (ceilings low for time to climb tests, for example.)
Do you have to have them? No, of course not. But, especially on that first
flight, there is so much going through your head and things you want to do,
it is nice to look down at your card and remind yourself that grinning and
looking around in amazement were not the only things you went up to do today.
I might be able to summon mine up and post them if anyone is interested.
Notice I said might. I can at least bring up the first ten or so to give
ideas.
Michael
N232 Suzie Q
tested and mighty glad for it.....................
Subject: | Switching fuel tanks |
>People who don't regularly fly a plane in witch you switch tanks get a little
>aggravated about it so they ask the question why....
Switching tanks in flight: I switch mine every half hour. It keeps the
airplane in better balance and keeps me up on what is going on a little
more. I am on the right tank from 0 to 30 minutes, left tank from 30 to 60
minutes. That way: right tank, right side of the clock, left tank, left
side. I also make it a habit of looking at the guages to take a purposeful
survey of the engine, fuel, airspeed, etc. I keep track on my travel log
when cross country and just take mental notes when out "going up". ("Cha'
fly this morning? Where'd you go?" 'Up.') I like switching tanks.
Michael
Same experience here. Ended up cutting the rod about 5/8 -7/8" shorter as I
remember. You can get a new threaded end piece, or spend hours saving &
drilling out the old one like I did. It was a real pain to get the existing
rivit holes to line up with no slop. Easier to get new end piece.
L.Adamson RV6A finish
Here is a question for you allready flying.
What predominant flap settings do you use. like...
0, 1/2, and full
0, 1/3, 2/3, full
or do you go in degrees, like...
10 for shortfield/heavy t.o., 20 on base, 40 on final, 10 to slow down.
Just wondering what the prefered flap settings are out there
Gert
Pursuant to US Code, Title 47, Chapter 5, Subchapter II, '227,
any and all nonsolicited commercial E-mail sent to this address
US. E-mailing denotes acceptance of these terms.
Subject: | Re: Flight cards |
> ideas.
> Michael
> N232 Suzie Q
Michael,
YES, please post them. In fact I'd be willing to put them on my web site for
download if folks like them. What file format are they?
Randy Lervold
RV-8, #80500, not flying
www.rv-8.com
Flaps are cool.
Take off: one notch: 20 degrees
Landing: two notches: 40 degrees.
I've noticed the flap lever allows the flaps to come up some in flight so
it is more like 35 degrees landing. I know some pilots that use no flaps on
take off as the RV series takes off so soon anyway; but to me, the sooner
the better. I like the way the airplane performs on final with two notches
better than none or one notch.
Part of your flight testing, and later once you get the airplane figured
out, is to go out and shoot a ton of landings, using no flaps, one notch,
two notch and see what YOU like, not what I like. What do slips feel like?
How slow can you come down the final ramp? What is it like to have one
notch on final and plunk on two? Or to have two, then take one off? What
about emergency landings? (I find with emergency landings, I use my flaps
to help regulate where I am trying to get to: putting on flaps, taking them
off and on again, then full flaps on short final. Yes, I am watching speed
and have already tried this at altitude.)
Every landing I do, I am seeing a carrier deck, and trying to be "on the
ball" on every landing: centerline, speed, landing right
here. EERrrrk, trap third wire.
(Not full throttle at the trap, though.)
Fly a lot, learn what your airplane has to teach you.
Flaps are cool.
Michael
RV4 N232 Suzie Q
From: | "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> |
Subject: | Alternator 0-360-A1A |
List: I have the alternator bracket kit from Vans and was wondering if
anyone has a recommendation as to what alternator in the 50 or 60 Amp range
is a good fit with this bracket kit?
I was thinking a Honda Unit with internal regulator and Crowbar over
voltage protection as available from "The AeroElectric Connection."
(RV-6-QB installing Navaid on the right wing tip)
Tom
in Ohio (362CT)
> -6/6A builders
rod
at
required
hoping
I don't remember the actual length vs drawing, but I believe the best
sequence is this: 1) mount the elevators, 2) relieve the elevator spar
flange as necessary for down travel, 2.5) build and mount the down travel
stop, 3) relieve the elevator horns if necessary to get the required up
travel (don't forget a stop plate on the front side of the last bulkhead),
4) neutralize the elevators and aft bellcrank, which will determine the
length of the aft pushrod, 4.5) mount the aft pushrod, 5) starting with the
front pushrod on the lengthy side, tape the pushrod ends in, install it and
see if you get full elevator travel. With the elevators full up against
their stop, the yoke on the stick weldment should be 1/8" aft of F604, if I
recall correctly. This is ultimately what will determine neutral stick
position. Also, most have to grind a bit of the yoke which holds the
forward end of the forward pushrod to get full up elevator.
Alex Peterson
Maple Grove, MN 6A
Under the cylinders, above the induction tubes. Anchor to adel clamps bolted
to the engine case. Alternately run them inside a firesleeve and wire tie
the firesleeve to the induction tube coupler hoses. The firesleeve provides
heat protection from the exhaust pipes but more importantly protects from
chafing since they're sitting on top of the induction tube hose clamps. Plus
they're still not that far from the oil line, so its good protection either
way.
If you have a C/S prop do NOT adel clamp them to that...! Keep the high
voltage lines away from fluid lines.
Randall Henderson, RV-6 N6R (
75 hrs)
Portland, OR
http://www.edt.com/homewing
Listers,
In light of Glasair going out of business I'd like to tell you a story
about Van.
A friend of mine went to Oregon to see Van's factory sometime around 1990.
When he got there he asked to speak to Van. He was directed to an old school
bus. There he found Van in a pair of old coveralls gutting the inside of the
bus to convert it into a camper. My friend said the pitiful part about it
was that he wouldn't have drug the damn thing across the road if Van had
gave it to him.
Now that's wanting to save money awful bad.
Every year I go to Sun-N-Fun and see the displays. Lancair's and Glasairs
have the best tents with all the trimmings. Then there's Van, same old tent
( he's had to have had the same tent for the last ten years ) I've often
wondered why Van doesn't spruce up his advertisement, after all he sells
more kits than all of the rest put together ( assumption ).
I guess now we know why he doesn't, and I've got a new attitude about
advertisement dollars.
Jim Nolan
N444JN
Hi all,
Just made a major oops in the wing spar. I drilled the tie down bracket in
place, (including the top bolt hole that passes through the spar web and two
flange strips) and was getting ready to drill the hole where the tie down
ring passes through the spar flange when to my horror I realized that I had
just put the tie down bracket with the threaded end facing the top of the
spar. No problem to turn it around but now I have an extra hole in my flange
strips (where the top bolt goes through the tie down bracket, spar web and
through two flange strips. I also have an extra hole in the spar web as
well.
Now what?
Thanks for any advise. I'll probably call Van's on Monday as well but would
like some input from the group.
Eric Newton Long Beach, MS
RV-6A N57ME (reserved)
(Working on Wing Spars)
Eric's RV-6A
Construction Page
> High wing planes don't have this problem since the gravity feed head
pressure will insure even flow. >
Hey, Joe:
The high wing planes don't really avoid the fuel flow problem. Based upon
my student days it's my impression that a some high wing planes on any long
flight may develop a slightly wing low condition. Since this could favour
the fuel flow TO/FROM the low wing that wing could get heavier and you end
up chasing the trim. I think that Van has the best "fuel management
system" - based upon simple discipline and postive control by the pilot.
Physical check before flight and switch tanks on the half hour (buzzer
alert??), use the gages to verify your procedure only. The "Both" option
will eventually cause you a fuel starvation problem. Check the frequency of
this in accident reports. Reliance on electronic instruments for fuel
management makes it easy to get out of the "positive control" mode (Hey,
Bubba, this expesive instrumment means I don't even have to think about that
routine stuff). We all know that fuel starvation is pretty common. It's a
"Duh!" situation like wheels up landings. IMHO
Hey Micheal
Of course, you are right. What ever makes it tick for me.
I was just wondering on what kind of indication to use and what the
major tick marks would be. i.e. count 4 secs on base, another 4 on
final.....paint so stripes on the aileron to compare flap angle..., use
some indicator lights for 10, 20, 30, 40 degree flap pos....
Gert
> Flaps are cool.
> Flaps are cool.
> Michael
> RV4 N232 Suzie Q
From: | "The Stribling's" <bbattery(at)teleport.com> |
Thanks to all who respond I am just learning to fly so this is all new to
me. I will get in to the habit of switching tanks and I think the trick with
the clock is great.
Back to priming
Thanks for the info Ken
Hi Jeff:
Just wanted to let you know in case you have not made a decision on your
engine that I was able to pick up a premium first run core this week and
will be having it overhauled by Aero Sport Power and it will be available in
about a month. It is a O360 A3A and is constant speed capable. This is the
wide deck engine with heavy cylinders and is rated at 180 HP.
Depending what we find on the tear down the price will be right at $14750.00
US. This will also carry the standard Aero Sport warranty.
If you have no interest maybe some of your friends could use it. These
premium first run cores are getting scare. It was removed from a wind
damaged aircraft with no damage to the engine or the prop.
Eustace Bowhay
250 675 4428
-----Origina
l Message-----
Date: Monday, May 08, 2000 7:35 PM
Subject: RV-List: Engine info
>Greetings:
>This is a question for the engine gurus amongst us. I have an opportunity
>to purchase an engine and I am not sure if it is applicable to the RV6A
that
>I am building.
>The engine is a HO-360-E1AD of 180 hp with a solid core crank....therefore
>fixed pitch. Yes, the "H" indicates that it is a Horizontal Helicopter
>engine. It is apparently fuel injected per information from the seller.
>The history of this engine is an over-rev at initial run-ups after
>installation in a new helicopter. The engine will be completely overhauled
>with all the appropriate new parts. As of now, no firm price has been
>mentioned, but if it is attractive, I need to know if I should make a move
>on it.
>My question is if this is an engine that will fit in a 6A. As there is no
>carb, I assume that this is not a factor regarding the nosewheel strut.
Any
>red flags about this engine? I am confident that it will be a sound engine
>after OH, so that is not a concern. I just don't want to be faced with a
>multitude of mods to "make" it work.
>As always, Thanks in advance folks
>Regards,
>Jeff Orear
>RV6A
>Peshtigo, WI
>Sealing second tank
Subject: | Re: Alternator 0-360-A1A |
> range is a good fit with this bracket kit?
The low cost end of the market includes the $40 junkyard Mitsubishi
alternator plus $50 for new bearings and brushes, modified to use an
external regulator such as the one that Van sells (compatible with the
crowbar overvoltage unit Bob sells). Details on the conversion are at
http://www.geocities.com/timrv6a , then click on the alternator link.
I have about 60 hours on mine, with good luck so far.
Tim Lewis -- Springfield VA
RV-6A N47TD - First Flight 18 Dec 99
TimRV6A(at)earthlink.net
I know it has probably been addressed, but how much is Vans conversion to
electric flaps and how hard is it? Also, how do you get to the archives?
Admitting my ignorance. Would love to not have to do the butt shuffle
pattern dance to Oshkosh this tear.
One day in the phase one of the flight testing I did 96 touch and goes,
having so much fun couldn't stop, flaps are something you will have to adjust
to your own comfort level. I did a little on down wind a little more on base
and a little more on final as I felt I needed them. You will figure it out
and enjoy the experience of coming in high and floating down, long and slow
on final, and some times come in almost perfect. Terry E. Cole N468TC
Subject: | Re: Electric flaps |
Bill -
I just changed over to electrics and I found the job very straight forward.
I cut and welded the flap cross shaft myself and made all the 'housing'
pieces myself. AlI I purchased from Vans was the flap motor. The entire
modification took under ten hours. The only negative is the loss of space
between the seats. There is a fellow on the list that made a flap change
over to electric and installed the flap motor over against the right baggage
wall. The article is in the archives.
Hope this helps
Doug Murray RV-6 C-GRPA
Southern Alberta
----- Original Message -----
Sent: Saturday, May 13, 2000 8:58 PM
Subject: RV-List: Electric flaps
Archives search :
http://www.matronics.com/searching/search.html
Subject: | Re: Wing Spar ooops |
You will most likely find that there is no problem at all. The rivet spacing
is already 1 & 1/2" with the hole for the tiedown in the middle. 3/4" spacing
is more than plenty for a 3/16" hole. As long as there is more than adequate
edge distance & spacing between the holes, I see no problem at all. I'd just
leave the hole, or I suppose you could put a flush rivet in it.
Subject: | instrument panel labeling |
> I used decal paper and an ALPS MD-1600 printer on my
> personal computer and
> made my own custom decals. Looks just like silk screening.
> Durability is
> still a question which I hope to answer over the next few years.
I printed my own placards on Avery clear laser labels. (I have a very
light gray panel.) I also used these labels on the exterior for "No
Step" placards on the flaps and for fuel type and quantity on the fuel
tanks. All of the labels still look like new after three years,
except for those on the fuel tanks. After about a year, they start to
become discolored (because of spilled fuel). When they start to look
ratty, I just pull them off an stick on new ones.
When I had my FAA inspection, most of the squawks were for placards.
It was a cinch to change them.
Mark Nielsen
RV-6; 487 hrs.
Green Bay, WI
Subject: | Re: Zenith-List: Alum polishing compound recommendation? |
In a message dated 5/13/00 8:11:33 PM Pacific Daylight Time, elrond(at)xprt.net
writes:
> Anyone got a recommendation for a brand of aluminum polishing compound?
> Any tricks to speed up the process?
Hi Bruce: Below please find two links. One is for a company in Canada. They
give a lot of info on polishing and their US counter parts.
The other is a company I am going to use to buy supplies to polish my
Airstream(s). Great info. Their site is under reconstruction this weekend, So
book mark them and look them over next week.
Aircraft Exterior Polish, Aircraft
Polishing products
Lake Country Manufacturing
I hope this helps.
ineCore
Subject: | It LOOKS like an empennage... |
Let's see...five months, one SportAir workshop, one HS-610, two HS-614s, one HS-411PP,
and 102 hours of work (not including workbench/jig construction and several hours
of
head-scratching and mindless ranting and raving as I learned how to read plans
and think
ahead), I finished the empennage to my RV-6!!!!!! *jumping up and down*
Just had to tell someone. :-)
Mucho gracias to Van's for their patient hand-holding on the several occasions
I called
them with crayon-level questions; the company is a class act and I appreciate
the
efforts they've put into making the tail kit as easy to build as possible. Thanks
to
those members of this list who responded to my queries, and a BIG thanks to those
builders who are thoughtful enough to put photos and descriptions of their projects
on
the World Wide Web; I would not have even thought of starting this project without
the
on-line information that's available, especially the construction notes that folks
have
posted. And a grateful tip of the hat to James Clark and the RV-6 factory crew
with EAA
242 in Columbia, SC, for the inspiration they've given me. I'll be back up there
soon
for another look at your projects and a trip to the Lizard's Thicket!
Semper Fi
John Lawson
RV-6...already started on the VS...waiting for the wing kit to arrive
Having only owned airplanes with no flaps at all, I'm wondering if a
notch of flaps really does shorten the takeoff roll? In the flight
manuals for Cessna 150's, flaps are reserved for SOFT field takeoffs.
The manual states zero degrees for SHORT filed takeoffs. I would think
that if anything, albeite probably unoticeable to most pilots, taking
off with say 10 degrees flaps may slightly increase the roll due to
added drag? I know most would probably say you get more lift with a n
otch of flaps on and thus get off the ground sooner. Seems you would be
getting more lift only on the part of the wings where the flaps are
located. Why not use the whole wing and start the takeoff roll with the
stick all the way back and ease it forward as speed builds. In other
words, a soft field takeoff without the flaps. If your whole goal is to
break ground the soonest, seems this would be the best way...now to
clear that dreaded 50 foot obstacle, that's a DIFFERENT story.
These are just the ramblings of a "rookie" with a bit over 500 hours and
about 400 of those getting in to or out of my dad's strip which is 1500
long and trees at both ends. Haven't tried it with an RV yet ;)
Scott RV4 Tailkit
> Flaps are cool.
> Flaps are cool.
> Michael
> RV4 N232 Suzie Q
--Scott--
1986 Corben Junior Ace N3642
RV-4 under construction (tail feathers)
Gotta Fly or Gonna Die!
I agree.
Doug Gray
Yes I had the same problem but considering what it is sandwiched between
(.125 +.032) and that the primary consideration for the edge distance is
tear away I'd press on.
Doug Gray
RV6 Wings, Sydney Oz
> in drilling the bottom rudder rib to spar i have a hole(cener) to edge of
> less than 2x.
> instead of 8/32 i have 6/32 on all four holes. remember this rib is
> sandwiched in between the rudder horn and the horn helps cover the rib
> flange. order another or go ahead????????????????????? if it was not
> sandwiched between the rudder horn and spar i would redo but this case is a
> little different with the help of the horn.
Subject: | Re: fuel inj vs. carb |
dear listers
i'm still looking for an engine, here are a few questions.
if i go with fuel injection, do i still need,
1. the scoop on the cowel
2. carb heat
3. mixture control
what are the benifits of both, and disadvantages of both.
thanks
scott
tampa
rv6a cut canopy yesterday for tipper, piece of cake !!!!
Tom,
I'm in the process of doing this same thing and will pass along a couple
discoveries. I went to the junkyard without my list of choices and asked
for the wrong model. The (wrong choice) alternator was $105 so knowing I
must have made a mistake, asked for a mid '90's Honda. They found one for a
'93 Civic (Nippon-D...) and charged $75 plus tax. They couldn't tell me how
much output capacity (in Amps) but I figure it being a modern auto has to be
worth a gamble. The pulley is of serpentine type and will have to be
swapped. The measurement of the mount is 2.230".
I'm curious as to the inside dimensions of Van's mount. Will you post this
please?
Sent: Saturday, May 13, 2000 8:02 PM
Subject: RV-List: Alternator 0-360-A1A
range
> Tom
> in Ohio (362CT)
Thanks Eustace but I already have my 0-320 installed. Your engine is a
perfect deal though so I'll spread the word. Later, JT
Sent: Saturday, May 13, 2000 7:35 PM
Subject: Re: RV-List: Engine info
> Hi Jeff:
in
$14750.00
> Regards
> Eustace Bowhay
> 250 675 4428
> -----Origina
> l Message-----
> From: Jeff Orear <jorear(at)mari.net>
> >Greetings:
opportunity
> that
> >I am building.
crank....therefore
overhauled
move
> >on it.
no
> Any
engine
> >Regards,
> >Jeff Orear
> >RV6A
> >Peshtigo, WI
> >Sealing second tank
In a message dated 5/13/00 4:27:13 PM Pacific Daylight Time, RVHI(at)aol.com
writes:
From the git-go I didn`t like those rivets, I had my tube ends welded on.
Fred LaForge RV-4 flying
Subject: | RV CFI's near Pensacola FL? |
Hi all,
I'm trying to find an instructor with an RV near Pensacola, FL for an insurance
checkout. I've been
trying to contact a local RV-6 owner/CFI, but haven't had any luck. He's retired,
and could be
anywhere in his plane now. Anyway, in case I can't get in touch with the local
guy in time, I need
to line up an alternate plan. Jeff Ludwig in Jacksonville, FL is the only other
CFI that I've
heard of, but that's still a 6 hour drive. Anyone else?
Russell Duffy
Navarre, FL
RV-8, sn-587, N174KT (inspection soon)
From: | Stefan King <stefanking_1999(at)yahoo.com> |
Sorry to hear about this, Bill... unfortunately there
are 'unscrupulous' folks out there, even in the RV
community.
What goes around comes around. He'll be at a fly-in
someday and we'll all know his reputation.
BTW, I'm still having fun up there in the skies over
Sanford, just got back from another dual session with
the instructor. Would have gone out for an hour of
solo, but he wouldn't recommend it due to low clouds
forming over the airport and out in the practice area.
Did I tell you my instructor has taken a job in
Pennsylvania and will be moving in about 6 weeks???
I'm not happy about this, as I thought I'd be with him
until the end (I projected Sept. timeframe), but I'm
working on a deal where I could take off a month from
work and just go flying every day with him until I get
my license. So things may happen quickly...
I'll keep you posted.
Good luck with the wing kit fiasco.
Stefan
> stand for sale on
From: | Warren Gretz <warrengretz(at)gretzaero.com> |
list-aviation ,
list-avionics ,
list-ez ,
list-glasair ,
list-homebuilt ,
list-lancair ,
list-rocket ,
list-zenith
Subject: | Gretz Aero Products |
Hello listers,
I have been told lately that a few builders have been trying to get in
touch with me. Several months ago my e-mail address changed when I got
my website up. My current e-mail address is info(at)gretzaero.com
My website address is www.gretzaero.com
You should take a look at the products I make and sell for builders at
this website. The most popular item is the heated pitot tube mounting
bracket. I also sell heated pitot tubes at a great price. There are
several other items there I am sure you will be interested in also.
Please contact me by e-mail, or the phone if you have questions.
Warren Gretz
Gretz Aero
303-770-3811 evenings and weekends or leave a message on the recorder
Gert: After 450 hrs on RV6 N894CD, I believe Van had it right from the
start. With my manual flaps built as per plans, you have 0, 20 (first
notch), and 40 (second and last notch). With 160 hp, and constant speed,
here in Longmont, CO, I can take off and land with any flap setting. This is
a wide open airport with 5000 ft runway. Almost always, I takeoff at 20, and
land at 40. 40 helps keep the speed down, and gives the best (though not all
that great) visibility over the nose. 20 for gusty conditions. Very little
stall speed change betw. 20 and 40. About 4 kts between 0 and 20. Good
luck. Doug Sykes
Tom & Cathy: I have 160 hp, and bought a B & C 40 amp alternator, with
crowbar OV protection. Both have worked without flaw. The ov protection
worked so well when my original Ford regulator went off the high end that I
never saw the high voltage indication on my ov/uv light, also bought from
Nuckolls or B&C. I have dual GPS (not very much current), VMI 1000 engine
inst., and elec gyro. Two big landing lights. 40 amps has been plenty,
though you could exceed that draw with absolutely everything turned on.
Lndg/taxi lights are 90/130 watts each. Good luck. Doug Sykes
Subject: | Re: Cheap Dutchman |
(Snip)
>Jim Nolan
>N444JN
(Snip)
So true! Same thing at Arlington Living this close to the factory I get up
there often.
I have said many times the nice thing about dealing with Van is that he
doesn't want to
spend his money and he does everything he can afford to do to keep me from
spending mine.
I have wished many times I would have taken his and some of his employees
advise...
build it light! Thereby building it cheap! Next time for sure!
I almost fell off chair when I saw those full page adds on the RV-9A.
There has
to be a plan to spend that kind of money.
Denny
Thanks. Lots of data here. It will take many hours to test a plane even if
all goes right from the get go.
Subject: | Re: Still undecided |
Oh NO??? How about the guy that cracked when his improperly constructed
winglet broke???
(Click here to visit our Club site at http://www.bellanca-championclub.com)
From: "Shelby Smith" <shelbyrv6a(at)mindspring.com>
Sent: Saturday, May 06, 2000 6:11 PM
Subject: Re: RV-List: Still undecided
> You know our chapter met at a members home last month to view his highly
> modified Varieze design. In the course detailing his ideas he made the
> statement that no Variezes have had wings fall off like RVs. Well,
needless
> to say that caused several throats to need clearing in the crowd. But,
sadly
> this guy didn't realize how even ill informed statements like that hurt us
> all. Clearly, he didn't know what he was talking about, but I am still
> chapped that anyone would, even in jest, make a statement like that.
> Glad to see you back Jerry.
> Shelby Smith
> RV6A - Skinning Fuselage - 200HP
> N95EB - reserved
> >From: Jerry Springer <jsflyrv(at)teleport.com>
> >Date: Sat, May 6, 2000, 2:19 PM
> > You should also be fair and tell the newcomers about how
> > much testing and re-examining of the spar was done after
> > the accident. Don't just tell one side without giving all
> > the facts. BTW tell me about the average engineer saying
> > hmmmmm. Where they there when testing was being done?
> > Were they doing any analysis of the spar? are they aircraft engineers?
> > You may not be starting a war but you did say newcomers should be given
> > ALL the information available then you proceed to leave the other half
> > out.
> > That makes me go hmmmmm.
Subject: | Re: Randolph 912 slosh |
From: | "Robert Hall" <robjhall(at)earthlink.net> |
snip
Those are the basic base and final numbers I use. I would probably use 20
for soft/short field takeoff. There is is very little apparent increase in
drag for up to 20 degrees of flaps. You won't slow down much with 10 or
even 20. Anyway, in an RV you are already slow before you can put the flaps
down.
Bob Hall,
RV-6, Colorado Springs
150+ hrs and in the paint shop
Here's what I'm doing right now. First I cut a 5 inch hole in each bay with
a fly cutter. I had a piece of 3"x1/12x 3/16 aluminum with 2 #30 holes
drilled on each side of a 1/4 hole. I would pop rivet this temp plate to the
bay and use it as a guide for the fly cutter. After cutting all 8 holes I
than used shears to cut my covers from .040. I than drilled the covers to
each bay and scribe a number on the cover and bay so I would know which cover
went to each bay. I may be able to use standard rivets by starting outboard
and working in, if not I have already ordered the fuel tank pop rivets from
Van's. Next I went and bought a cheap respirator and started cleaning with
MEK and course scotch bright pads. I also use sponges to keep the tanks nice
and wet with MEEK. Prior to doing this I tested MEK on Pro Seal and the 912
in a coffee can for 1 hour, the MEK had no effect on the Pro Seal and the 912
just wipe off. I know this sounds like a pain and it is, but the whole job
took 3 days to clean. I'm just waiting on the pop rivets and Pro Seal to
come in from Van's. I will put a layer of Pro seal in each fuel tank prior
to closing. I recommend doing this, flying at night, on take off or anytime
you don't want to worry about your fuel system clogging.
Blue Skies,
Carry Mills
334 598-6226
Clarification: I meant to say "If you have a C/S prop do NOT adel clamp the
wires to the C/S oil line, which runs under the cylinders on the right side
of the engine."
75 hrs)
Portland, OR
>Nuckolls or B&C.
I'm confused. What kind of light did you have installed in
conjuction with your "Ford" regulator . . . was it the OV/LV
light from B&C? If so, this product flashes if and only if
bus voltage exceeds 16.0 volts and illuminates steady if
but voltage drops below 13.0. If you have ov protection
installed, one would EXPECT to never see the OV light
"flash" due to an OV condition . . . it's all over in 20-50
milliseconds. After the alternator shuts down, the light should
come on steady showing that the bus voltage is low since
the alternator is now off line.
With everything on, you should still be well under 40A although
depending on pulley ratios, you may not have full output available
from the alternator when throttled back for decent. This is why
we like to keep the small pulley on the B&C alternator as it
comes from the factory.
( Knowing about a thing is different than )
( understanding it. One can know a lot )
( still understand knothing. )
( C.F. Kettering )
http://www.aeroelectric.com
A friend is looking for a 4, 6, 8 or Rocket. I guess he isn't too
picky. He has previously owned a 4 and wants a flying copy.
Send any responses to:
TRAASHMAN(at)webtv.net
Joe Waltz
8 @ DWH
Hi Listers,
Just out of curiosity, do all/any of you switch the fuel
selector to OFF at the end of the day's flying ??
Just wondering about wear that's all......
Lyle
In a message dated 5/13/00 3:56:09 PM Pacific Daylight Time,
mikel(at)dimensional.com writes:
<< I might be able to summon mine up and post them if anyone is interested. >>
Michael: I would definitely be interested. Seems like they would also
be a valuable addition to the archives.
Harry Crosby
-6 Finish kit stuff (Hoping to fly someday)
Scott,
Some answers are below
>From: ABAYMAN(at)aol.com
>Subject: Re: RV-List: fuel inj vs. carb
>Date: Sun, 14 May 2000 09:38:34 EDT
>dear listers
NO
>2. carb heat
NO
>3. mixture control
YES
Fuel Injection does not need Carb heat and generally produces more power.
But fuel injection costs more initially and can't be overhauled/fixed on
your bench. Special instruments are needed for testing.
>thanks
>scott
>tampa
In regards to the 9 is it light enough that you can fly it under the proposed
sport pilot license. If it is that will make the 9 be the biggest seller of
them all if the sport pilot license passes. And it sounds like if will from
what I heard from some EAA people this weekend.
Subject: | Re: Fuel selector |
WHY???? Especially with the low wing configuration where in all fuel has to
be pumped up.
Sent: Sunday, May 14, 2000 2:48 PM
Subject: RV-List: Fuel selector
> Hi Listers,
> Thanks,
> Lyle
Subject: | Re: Our Dutchman |
George True wrote:
> The 9A offers this "typical" pilot a lot of RV-like performance, but with a lot
> more of the stability and docile landing speeds that your lower-end spam-cans
> have.
I was not a high time pilot when I first flew my 6A. I had a lot of ultralight
time,
but my "real" plane time could not have been more than 10 hours per year during
the
previous 7-8 years.
Still, I immediately (and somewhat surprisingly), found the RV-6 to be the most
simple, straight forward, and easy plane to fly as I have ever flown. It has no
bad
habits and at no time did I ever feel that the plane was getting ahead of me.
I can't imagine how the 9 could be significantly "easier". Surely not "easier"
enough to justify the loss of the upper end of the curve.
I was a little dissappointed when Van chose to commit his resources to the 9. But
now that he has, I sure hope I was wrong.
Andy
El Lobo wrote:
> Hi Listers,
> Thanks,
> Lyle
Don't think mine has been in the off position in 11 years.
At 1:30 pm Sunday, May 14, an RV-4, N45DR, lost power and crashed on takeoff
from Cox Aerodrome, a private residential air park, in Apex, NC.
The owner and pilot, of Raleigh, NC and his young nephew perished.
The engine quit as the plane departed the runway and the aircraft impacted
into a yard about two hundred feet to the left of the end of the runway.
There was no fire and the canopy was not damaged in the crash. Pilot and
passenger died shortly after being taken to hospital by EMT.
Witnesses on the airport heard the engine sputter and then quit, saw the
plane go down and were on the scene almost immediately.
The pilot had owned the aircraft about three months and was an airline
pilot. I have purposely omitted the pilot's name at this time. If you
recognize the N number, please note that Denny had sold this plane earlier
this year.
With sadness
John Harris
Cary, NC
RV9A N922JH (Reserved)
From: | "Bill Shook" <billshook(at)mindspring.com> |
Subject: | Re: kickbutt Bill |
Chuck,
Is that possible? He isn't returning my phone calls or emails (prior to
sending the money I would get a return nearly immediately).
Sent: Saturday, May 13, 2000 1:24 AM
Subject: RV-List: kickbutt Bill
> Bill Shook,
> I work for an airline. Do you want a free pass to go kick ass?
> Chuck - RV6 (50%)
Sent: Sunday, May 14, 2000 10:42 AM
Subject: Re: RV-List: Alternator 0-360-A1A
this
> please?
> From: Tom & Cathy Ervin <tcervin(at)valkyrie.net>
> To:
> range
over
Tom
> > in Ohio (362CT)
Tom: Vans bracket is 2.50 inches. I believe the instructions say shim to
fit.
Tom in Ohio
this
> please?
> To:
> range
over
Tom
> > in Ohio (362CT)
Dammit, I hate this reply to one answer and it goes to the whole list.
Sorry for wasting the bandwidth AGAIN. Wouldn't it be nice if this didn't
happen all the time.....
Sent: Sunday, May 14, 2000 7:01 PM
Subject: Re: RV-List: kickbutt Bill
> Chuck,
> Bill
> From: <GRAYK9(at)aol.com>
> To:
> > Bill Shook,
> > Chuck - RV6 (50%)
Subject: | 6A Baffle Geometry at Inlet C/S and S-Cowl |
I am finishing attaching the airseal fabric around the inlet and forward
upper area on my O360, C/S prop and S-cowl on a 6A. I have cut off the
inboard and outboard sides of the fiberglass inlet ducts that attach to the
upper cowl so that the airseal material slides under them and seals to the
cowl, rather than sealing to the inlet ducts.
When the upper cowl is attached, I can curl two or three fingers just above
and around the inboard inlet wall, where the two cowl halves join. This
seems like a potential leak of air into the lower cowl, thus reducing the
pressure differential between upper and lower cowl cavities.
1) How have others sealed this area: To cowl or to inlet ducts.
2) Do any others have leak paths in this area, and if so, how are the CHT's?
Thanks!
Dennis Persyk 6A finishing kit
Hampshire, IL C38
Subject: | Re: Badge Offer Misunderstanding |
Hi Steve,
How do I get a badge and what do you want on them?
RV6
>Flaps are cool.
I knew I liked one notch of flaps on takeoff, but had forgotten exactly
why, as I always use one notch (A foolish consistency is the hobgoblin of
little minds, etc.). Went out flying this morning and shot a bunch of stop
and go's (you DO stop every time, don't you?) to see why. Oh, yeah, now I
remember: this is for the tail dragging -4 -6 ones among us, but the gear
can get pretty springy on takeoff as the weight is transferred from the
wheels to the wing. One notch of flaps tends to make the gear not feel as
springy. Makes for a straighter and not so "jumpy" a takeoff. You will know
what I mean when you start to fly. Course, maybe it's just
me...........................
Nose draggers? Can't say. Probably not as noticeable an effect.
I have and like manual flaps. I like the ability to pull some on at any
given moment and have it instantaneous. (Oh, great: way to start a
thread....). It does take a healthy yank if you are above 85 when you pull
notch number two, but I figure it is a pretty good excuse to stay in shape.
One of the exercises I do in my weight routine mimics this action. (Look
like Mr. Universe? Na, I just wanna pull on my flaps without hurting myself.)
Michael
RV-4 N232 Suzie Q
flaps are cool...........
Lyle:
I'm not sure why, but for the past 10 years I have turned my fuel selector
to off after a flight with no ill effects. Probably makes no difference
either way, just personal preference--but be consistent. Also, I have often
been asked why I always leave my flaps down. I guess for fear someone is
going to step on them. You're probably thinking, better run a checklist if
you're going to do either one--not a bad idea whether you do or not.
Pat Hatch
RV-4, N17PH @ INT
RV-6, Fuselage
Sent: Sunday, May 14, 2000 3:48 PM
> Hi Listers,
> Thanks,
> Lyle
From: | "Rick Osgood" <randbosgood(at)peoplepc.com> |
Subject: | Any second thoughts |
Another RV lost?? Does anybody else have second thoughts about continuing to
build their RV after reading about these accidents? How do you reassure
yourself and your family that you are not endangering yourself or your
family?
Just questions that sit in the back of my mind....
Rick Osgood
From: | "Mark Dickens" <mddickens(at)mindspring.com> |
Subject: | Re: Any second thoughts |
My thoughts...the RV is an airframe, not a complete airplane...you build the
plane, you select the engine, you install the engine and you maintain the
plane...how do we know he didn't have water in his fuel? I say keep
building and keep in mind YOU are the manufacturer, not Van's
Mark Dickens
RV-8 Wings
Sent: Sunday, May 14, 2000 9:21 PM
Subject: RV-List: Any second thoughts
to
> family?
> Rick Osgood
From: | "Ollie Washburn" <skybolt-aviator(at)msn.com> |
Sent: Sunday, May 14, 2000 10:21 PM
to
> How many second thoughts do you have about driving your car after reading
of so many auto accidents that happen EVERY day>
Micah Froese wrote:
> Considering price, ease of building, and performance, the RV-9 beats not
> only the Glastar but even gets into the Kitfox/Avid line. Two things really
> struck me at Sun-n-Fun this year: the price of Glastars (I saw a built one
> advertised for $125,000.00), and lighter aircraft that are intended for
> Rotax 912s. One could easily build an RV-9 with a used engine for less than
> these aircraft and wind up with a "real" airplane. Plus you wouldn't have to
> deal with finishing composites or covering your creation with "rags". I dare
> say the 9 will become one of the most popular planes out there.
> IMHO,
> Micah Froese
Careful now......don't get the "rag-lovers" stirred up! :-)
A lot of us love "rag" airplanes. A J-3 or Pacer just wouldn't be the
same if it had metal skin.
For the right application, "rags" is good!
Sam Buchanan (RV-6, builder of two rag airplanes, and previous rebuilder
and owner of a J-3)
"The RV Journal" http://home.hiwaay.net/~sbuc/journal
Subject: | F-804 spacer accuracy? |
I'm ready to fabricate the spacer for my F-804 spar carrythrough
bulkhead prior to installing it in the jig and I'm wondering what would
constitute acceptable accuracy for thickness. My spar root ends are
both 1 15/32" thick, but I don't have any means of cutting wood (or
anything else) to the nearest 1/32". If I can come up with a 1.5" thick
spacer, would the 'extra' 1/32" be a problem when I install my wings?
What are other -8 builders doing in this area?
Ken Balch
Ashland, MA
RV-8 #81125
floor ribs
I don't believe the point was that the plane was unsafe and dangerous but a
reminder that poor pillage can be!
Sent: Sunday, May 14, 2000 7:45 PM
Subject: Re: RV-List: Any second thoughts
the
> Mark Dickens
> RV-8 Wings
> From: Rick Osgood <randbosgood(at)peoplepc.com>
> To: rv-list
continuing
> to
> > family?
> > Rick Osgood
Does anyone one know where to get a cover for the RV canopy? I have to move
the aircraft outside for a few months and I would like to cover it up also a
cover for the propeller.
thanks
dan carley
rv3-a 148cw
> How do you reassure
> family?
> Rick Osgood
Rick:
There is an old saying:
"I do not try to cheat death. My goal is to make sure
that death is not a player in the game."
Yes. We all have second thoughts at some point in
time. A friend of mine (flys a RV-6A) had his boss
say this when he saw a photo of his airplane. "You are
putting your life in danger flying." The RV-6A
builder/flyers response was the same as mine: "NO. I
am LIVING my life to the fullest!"
Others have said "It is not how long you live but what
you do with your life in between the time you are born
and die."
I enjoy flying more than anything I do. I will not do
anything that I feel is unsafe. I only have 552.0
hours on my RV-6 since the first flight. Building the
airplane, flying it 307.1 hours, then rebuilding it
after the FORD Thunderbird ran into it, has been worth
everything I have gotten out of it.
I know what you are going though. I HAD THREE
different friends (3 different accidents) lose their
lives in RVs before I finished and flew mine. This
does not count other aviation accidents that I knew
someone. I had meet Charlie (pilot / owner) of the
Questair that had a midair in Southern California this
year, one week before the accident. Jeremy and Bill
were friends of all of us. I believe that all of the
aviators that have gone before us were doing what we
all LOVE to do. At least they were doing what I LOVE
to do most.
I always intend to do everything in aviation as safe
as possible. Yes it is better to be down here wishing
you were up there than to be up there wishing you were
down here. Staying on the ground FOREVER is not an
option. I WILL NOT fly anything that I feel is not
airworthy or when I am not medically fit to fly.
"I always use my superior judgment to avoid situations
where the use of my superior pilot skills are needed."
I am 43 year old pilot, NRA LIFE member, FAA A & P,
and EAA Tech Counselor. I will now get off my soap
box and say sorry for the long post.
Gary A. Sobek
Flying So. CA, USA
http://SoCAL_WVAF.tripod.com
Subject: | Re: canopy cover |
> thanks
> dan carley
> rv3-a 148cw
Dan:
Cleaveland Aircraft Tools has them.
http://www.cleavelandtool.com/catsub1.html
Listed in the catalog under RV ACCESSORIES. Not sure
about the prop cover but I would phone DJ and ask her
if she could make one.
There are other vendors that make them but everyone
that I know (myself included) has one from Cleaveland.
Gary A. Sobek
Flying So. CA, USA
I got one for my -8 form the Cleveland Tools folks. Very nice, very soft,
and comes with its own carry/storage pouch.
Mike Robertson
RV-8A
>From: DFCPAC(at)aol.com
>To: rv3-list(at)matronics.com
>Subject: RV-List: canopy cover
>Date: Sun, 14 May 2000 21:30:22 EDT
>a
>thanks
>dan carley
>rv3-a 148cw
Subject: | Don't turn back, was "Any second thoughts" |
Long time listers will remember a long discussion about turning back after
take off. It has been hinted that happened in this recent accident. I hope
that is not what happened. Anyone who has any doubts about what they will
do if the engine quits after take off please read (or re-read) this message
I dug up in the archive.
Message: #31999 From: "Doug Rozendaal" <dougr(at)petroblend.com> Subject:
Re: Don't Turn Back was, First Flight Anticipation Date: Jan 06, 1998
All,
Since I feel quite strongly about this issue and rather than force feed my
editorial to all, and to save bandwidth, I stuck an essay on the subject on
the web. You can find it at this address:
http://www.petroblend.com/dougr/dnt-turn.htm
If you don't respond to the: engine failure after takeoff without
hesitation, "Lower the nose and Land straight ahead." Please read it. If
you don't have web access and would like a copy e-mail me off the list and I
will send it to you.
Tailwinds,
Doug Rozendaal
Subject: | Re: F-804 spacer accuracy? |
>Regards,
>Ken Balch
Ken,
1. I would recheck the thickness of your spar. On mine, the thinner
pieces of material were not quite tight against the spar bars at the
root end. Once I clamped things together (like they will be once you
tighten up the bolts after sliding them into the fuselage), the
thickness was exactly 1.437 (1 7/16).
2. Scott McDaniels posted on this subject a long time ago - it should
be in the archives. My recollection was he thought that you should
could get away with the slot being exactly the same thickness, as you
can put a slight chamfer on the spar root to help get it started.
That is the way they build them at Vans. He said that you should not
have too much slop here - having the slot about 0.010 too big was all
he recommended (as I recall).
3. I found that wood tended to compress if you tightened the bolts
down too much. I used bolts with larger nuts and washers and a shim
as spacers. Mind you I haven't assembled my wings to the fuselage
yet, so I may live to regret this. See:
http://members.xoom.com/kevinhorton/fuselage/f01.html
Kevin Horton RV-8 (cockpit floors)
Ottawa, Canada
http://members.xoom.com/kevinhorton/rv8.html
My spell checker changed Pilotage to pillage. Sorry about that!!!
Sent: Sunday, May 14, 2000 8:23 PM
a
> From: "Mark Dickens" <mddickens(at)mindspring.com>
> To:
> the
the
> > Mark Dickens
> > RV-8 Wings
> > To: rv-list
> continuing
> > to
reassure
> > > family?
> > > Rick Osgood
Listers,
Not quite RV-related. Has anyone ordered those shirts from Paul Brown from
Palm Beach Garden and not received them yet? - The ones with a picture of
your own RV embroidred on the pockets, supposedly to wear to SNF. I ordered
mine about 2 wks before SNF and didn't expect to have them for SNF but it is
now about 7 weeks later and still have not seen them.
Paul was responsive to my emails in the beginning - one day at most. I got
in touch with him after SNF and he said that he'd have them to me in a week.
That was about 2 weeks ago. I have not heard from him since. Does any know
what happened to him?
N985VU
Maryland
Subject: | enpennage for sale |
completed prepunched enpennage for sale,purchased completed enpennage,wings,
and dont need 2 enpennages,electric trim
Sent: Sunday, May 14, 2000 12:22 AM
Subject: RV-List: Re: Zenith-List: Alum polishing compound recommendation?
elrond(at)xprt.net
> writes:
They
So
Aircraft
> Polishing products
> Lake Country
Manufacturing
> I hope this helps.
> Regards,
> John @ AAMR/AirCore/Mar
> ineCore
> (Chick the blue link to go there)
>family?
Went flying tonight, after I read the post. I thought about it some, while
flying. "Landed in a yard." I saw an airplane "land" in a yard, once. J-3
Cub with someone's name taped to the bottom of the wing as he buzzed a
house. Pulled up, stalled it, landed in a yard. Unless it is a big yard,
that's about the only way to land in one. (I am not trying to second guess
what happened to the RV-4, just thinking out loud.) I was one of the first
on scene and it wasn't pretty. The next day, I had to get in my J-3 and fly
600 miles home. Gave me some time to think about it.
Flying is not like driving. There are more ways and dimensions to screw up
in. But we choose to fly anyway. We make it as safe as we can, considering
the risks. There are risks in everything that is worth doing. How many
people roll their eyes when you tell them you are building your own
airplane? They see the thing flying into a thousand rivets and sheets of
fluttering metal because they don't know what we know. Is it totally
without risk? No. So would I have rather sat on the couch tonight and
watched TV? Hardly. (Unless there was hockey on.)
I went flying. It was one of those darkish still evenings with a grey
overcast that made you just throttle back to 2300 and drift around. No one
was even on the radio. As I took off, I looked at the areas I long ago
picked out for a silent landing, ahead there from here, over there, now,
from this altitude, now over there. As I fly, I still quietly look at
places to land. Not that one, it's actually too close; that one over there,
flat except for the cow trail to the water tank, and the cows are two
fields away. They'll rub an airplane into a ball, you know.
I got mad at myself this morning, as I practiced emergency landings,
because I forgot something on my mental list of things to do. Don't
remember what it was now, as I remembered it on the second try. Yes, I
still go out and see where I'll land from, oh
here. I try to stay prepared.
We have one of the best designs in the industry and we build them the best
way we know how. And, contrary to popular belief, they usually hold
together. We fly them with a skill that increases as we learn, letting the
airplane make us better pilots because we want to KNOW how to fly this
airplane well; it demands that of us. We try to fly often; that's how we
keep current. We do our preflights because we know this is a high
performance aircraft that pretty much everything has to work for it to fly
right. We inspect our own airplanes because we, as builders, know it like
no one else does. And we sometimes don't wait a full year. Because we care
about our airplanes. And we know, if we take care of our airplanes and take
the care to learn to fly them well, our airplanes will take care of us. And
if things don't work, being a mechanical thing (don't tell Suzie Q I said
that), we have practiced what to do to get us back to the earth.
Sometimes the magic works, and sometimes it doesn't. My second thoughts are
to learn from what I have seen and heard, and making my flying environment
the best it can be.
It was a beautiful, still evening flight, floating around the
foothills....................................
Michael
RV-4 N232 Suzie Q
DJ Lauretson, Cleveland Tools catalog. She does very nice work.
Subject: | Re: RV3-List: canopy cover |
Van's Sells a great cover for the -3. It's the only RV-3 cover I could
find.
Bruce Meacham
RV-3 3456B
Sent: Sunday, May 14, 2000 6:30 PM
Subject: RV3-List: canopy cover
> --> RV3-List message posted by: DFCPAC(at)aol.com
move
a
> thanks
> dan carley
> rv3-a 148cw
From: | Thomas McIntyre <bogeybrother(at)earthlink.net> |
Cleveland tool sells one. Thats where I bought mine from.
Tom McIntyre
RV3 978 TM
> find.
> Bruce Meacham
> RV-3 3456B
> From: <DFCPAC(at)aol.com>
> To:
> move
> a
> > thanks
> > dan carley
> > rv3-a 148cw
Subject: | fuel tank please help |
having trouble fitting fuel tank baffle t-602 to wing spar.seems like
baffle is a little too wide.also too long on the flanges. are they suppose to
touch the spar strips? maybe my shims need to be thicker.drawing 18a shows
the flanges to end near the spar strips.the fuel tank skin at the inb. end is
not as long as the main skins which i understand is set by the out.b
skin.manual says leave half inch for wing tip to attach. for punched skin to
line up with ribs mine has aprox. five-eights skin overhang at tip.will the
tank attach fitting to fuse. come out short when wing is fitted later?would
be very grateful for info. on this subject.
tcrv6(at)aol.com left wing
From: | Frank and Dorothy <frankvdh(at)ihug.co.nz> |
Subject: | Threads for aircraft bolts |
Hi all,
I need to tap some thread to attach my roll-over bar (RV-6, tip-up) to
my fuselage, and also some for attaching the lift struts.
According to Will Cretsinger's notes and the plans, I need to tap 10-32,
5/16 x 18, and 8-32 threads in various holes.
I'm almost completely ignorant about threads and taps and suchlike...
Is there any special kind of tap-and-die set that I need? Do I need (God
forfend) "aviation-quality" taps (Avery and Cleaveland don't seem to
sell any), or can I just go down to my local hardware store and buy a
set there? If so, what do I ask for? Are these numbers "Whitworth"? Or
"BS"? Or something else? Are tap-and-die sets like other tools (i.e.
quality costs), or can I safely buy the cheapest that Taiwanese
manufacturing can produce?
Frank.
RV-6 #24692, canopy frame, Marton, NZ
Subject: | F-804 Spacer Accuracy |
>Regards,
>Ken Balch
Ken,
When I did this part, I called out to Van's and talk to Ken Krueger.
He said between 2 to 3 thousanths would be OK. He said the best would be zero,
but than it would be difficult to attach the spar. I had some square tubing
milled on a milling machine to exactly what I wanted. When you use steel, you
don't have to worry about changing the distance when you tighten the bolts. BTW,
my wings slipped right in!
Joe
#80125 (wings painted)
Another RV lost?? >
Rick,
For about 30 seconds, when there's a loss I think about not flying at all
anymore, but I have the identical feelings when there is a fatal car crash.
I have never regretted my decision to build an RV.
Regrettfully, almost all the RV losses we hear about are like most other GA
losses: human error, or some other cause not related to the aircraft type.
Until I see some evidence that RVs fall from the sky because of their design
I'll stick sith it, and I'll continue to fly until aerodynamics no longer
work.
John Harris
Cary, NC
Regarding landing straight ahead, I thought I'd see just how high one would
have to be to make the 180 back home if the engine quit. Not having access
to a high-dollar real simulator and not wanting to bend a real plane, I
resorted to my reasonably realistic MS Flight Simulator. I have tried all
kinds of options (speed, flaps, turn rate, split-S, etc...) to get the plane
back to the runway. I tried it in the 182 and the Extra. I never made it
back from lower than about 700 or 750-feet. This surprised me - I thought
400 or 500-feet would be enough.
Anyone have any RV experience related to the "turn back" performance?
Bryan Jones
-8 ready for inspection
Pearland, Texas
Subject: | Re: Threads for aircraft bolts |
They are standard SAE National Fine threads until you get to the smaller
#8, and #6 then they become USS which is National Coarse. They are NOT
Whitworth but American.
It really doesn't matter, just get the size and threads per inch you need
from your local hardware store.
Some of the Taiwanese are O.K. but why take the risk? You indicate you only
need 3 sizes so get a good quality tap from your hardware store. There
aren't any "aircraft" taps as they are ground to fairly tight tolerances
already.
Sent: Monday, May 15, 2000 5:34 AM
Subject: RV-List: Threads for aircraft bolts
> Hi all,
> Frank.
already.
> Hi all,
> Frank.
05/15/2000 06:25:38 AM
Subject: | Re: GLASSAIR Electrical parts |
Dick, this is the fella who does all the electrical supply for GH. He may be
useful in the future if you need any parts or general info........
AAMRELECTR(at)aol.com on 05/13/2000 12:13:39 PM
Hi Jim:
I also am somewhat familiar with Glassair/Glasstars operation.
For several years we were Stoddard Hamilton's/Glassair's electrical connector
supplier...Until they could not pay their bills, would not pay their bills
and got real unpleasant when asked to pay up.
They had got to the point of not making most of their parts. Almost
everything was farmed out and they slowly dumped most of the original staff
that actually did the work. The staff that made them successful in the first
place.
I am sorry that a bunch of folks lost their jobs, but you are absolutely
right about a group of "Non Value Added personnel."
They made a great kit plane and were at one time a pleasure to work with. I
am sorry that the old company is gone...But in my opinion you reap what you
sow.
So if any of you are building Glassairs or Glasstars and need your your
electrical bits and pieces, we got them.
ineCore
Becki Orndorff did a real nice job on a canopy cover for my 8 and will
make one up for any model RV you have. The material is a reflective
gore-tex type of covering that is lined with a soft / smooth interior.
1" wide straps secure it to the plane. She brags that it could be used
as a survival blanket if need be because it is similar to those
reflective blankets.
Becki did a nice job on my cushions as well and supplied me with all the
material to upholster the inside. I got the nice very light weight
carpet from her too.
She also does a nice cover for props. Kind of a prophylactic for props.
Traash
mailsorter-101-12.iap.bryant.webtv.net (8.8.8-wtv-f/ms.dwm.v7+dul2)
thanks
dan carley
rv3-a 148cw
Subject: | Scribing, respirators, etc. |
>...and scribe a number on the cover and bay
Hmm. I was taught never, but never to scribe aluminum. You can go
through the alclad and let corrosion get a start, but more importantly,
that scribe is a big fatigue crack that you just started.
Hopefully this was a forced air breathing device. Many of the passive
respirators won't work on some of the mean chemicals we use. Don't know
about MEK specifically, but I wouldn't trust anything that didn't have
forced air. Anybody got the straight scoop on this?
Ed Wischmeyer
NOTE: 5% of messages sent to me don't make it, so use a return receipt to
insure delivery. The phone company system drops packets.
Ed Wischmeyer
Web page: http://members.aa.net/~edwisch
Email: edwisch(at)aa.net
name="edwisch.vcf"
filename="edwisch.vcf"
begin:vcard
n:Wischmeyer;Ed
tel;fax:425 898-9566
tel;home:425 898-9856
url:http://members.aa.net/~edwisch
adr:;;18615 NE 53rd Street;Redmond;WA;98052;
version:2.1
email;internet:edwisch(at)aa.net
fn:Ed Wischmeyer
end:vcard
>to
>family?
>Rick Osgood
All activities in life have an element of risk. It's purely a personal
decision on how how much risk can be sustained. Fly the RV like your life
depends on it, because it does. Practice emergency procedures, always have
an "out" from any situation. Don't do Vx takeoffs when not necessary in case
the engine gives up. These planes WILL glide just fine. Been there, done
that, not a scratch on myself or the plane.
Be careful out there folks.
Brian Denk
RV8 N94BD
Subject: | Re: fuel tank please help |
How thick are your spacers that you are placing between the spar and the
baffle? Mine were 7/8 inch which seemed to work ok in my situation, an inch
would work also.
As for the length of the tank skin and where you said it is located, I would
give Van a call or wait to see what others have to say.
John Danielson
Fuselage
You can get small cartriges of tank sealant from Aircraft Spruce. The two
parts are in one cartridge and are mixed together within the cartridge before
applying. I think the come in 2 oz., 4 oz. and 6 oz. sizes.
John Danielson
Fuselage
Subject: | Found thius novel approach |
"One thing that I discovered while building my Emeraude. Don't ever tell a
vendor that you are building a plane. Many of them will refuse to sell you
parts, materials, or service. Instead, tell them you are working on an
invention to aid the handicapped and you'll sue their ass for violating the
disabilities act if they don't sell you what you want!"
I'm wondering anyone can help with a problem encountered while mounting the
engine on an RV6A. I've got an IO-360-A1B6 and the sump just barely touches
the engine mount about 3 inches below the lower Dynafocals. Has anyone run
into this? If so, how did you solve it.
Brian Eckstein
bseckstein(at)cs.com
616-624-6719 h
616-655-3248 w
5 years ago I won a canopy cover at the RV banquet at OSH from George and
Becki Orndorff. You couldn't beleive my surprise when I called them and asked
if the door prize was still valid. "Sure is" was Her reply. "What do you
need RV6,6A." Informed her what I needed and in less then 2 weeks it was
hugging N468TC, and looks great. Terry E. Cole N468TC
Subject: | IO-360-A1B6 on RV6A |
I'm wonderingif anyone can help with a problem encountered while mounting
the
Brian Eckstein
616-624-6719 h
616-655-3248 w
Full-name: BSEckstein
Date: Mon, 15 May 2000 10:57:36 EDT
Subject: (no subject)
Brian Eckstein
616-624-6719 h
616-655-3248 w
The -32, x 18 and -32 are threads per inch, so it doesn't matter what you
call it. #10 is same as 3/16 inch (diameter), but I guess you already knew
that.
Do not buy the real cheap sets (e.g. $15 for multiple dies and taps,
handles, etc.). They are cast, not ground and won't cut a thread.
The individual taps you can buy in hardware stores, Home Depot, Auto
Discount, etc. should be quite adequate for what you need to do.
Finn
> Frank.
>From: Denny Harjehausen <harje(at)proaxis.com>
>To:
>Sent: Sunday, May 14, 2000 10:43 AM
>Subject: Re: RV-List: Cheap Dutchman
>There has
Looks to be a great segueway to enter the certified trainer market like
Lance did for the high performance market with the Columbia. Once the RV
community works the bugs out, it will surely make a fine trainer for quite a
few bucks less than a new C-172. Why else design it with a low HP engine?
P-P design and construction, labor force already constructing quick-builds,
great existing source of kit feedback... sounds ideal to me.
Dave
Subject: | Need platenut advice (long-ish) |
Okay, I'm pretty upset with myself. I've been smoldering under the surface
since my latest screw-up. I've been attaching the top skin on my RV-4
between the instrument panel and the firewall. Now I have several
questions, especially for -4 builders but I could use advice from just about
anyone.
First of all, I installed the instrument panel per plans using the little
angles at the front of the cockpit side rails. When I do this it stands
straight up. When I install the top skin it pulls the firwall aft a bit.
Is this right? What can I do to keep the firewall straight?
Second, the top skin has some serious puckers along the firewall where it
screws on. How did you guys keep the screws on the top skin from distorting
the curve of the top skin when screwed down?
Third, I stripped some of the platenuts while trying to install the screws.
Anyone ever successfully rettaped platenuts or am I looking at installing
new platenuts?
Fourth, the leading edge of the top front skin (fore skin :?), where is this
edge trimmed in relation to the hinge? Some of the hinge is exposed on mine
(really bad trimming).
Fifth, (and finally) I think I am going to re-do this top skin (fore skin),
How can I make sure the holes on the new skin match up correctly with the
holes on the instrument panel and firewall which already have platenuts
installed?
Thanks for sticking with this email this far and thanks for any help you can
give me!!
Scott VanArtsdalen, MCSE
Network Administrator
Union Safe Deposit Bank
209-946-5116
A tap and die set will cost you a pretty penny for a good set...it will be a
good investment, but you really only need the following:
8-32
10-32
1/4-28
5/16-18
Expect to pay about $-5-6 each for these plus a handle to turn them
with...be sure to lubricate your tap with boelube, cutting oil, or something
similar...taps can break easily if you are not careful, and since they are
harder than bolts, drilling them out would not be fun
I bought a tap and die set from Harbour Freight. It is pretty cheap..does
the job, but I can definitely see where a quality set would be the way to
go..I think I paid $15 for my set...a quality set should cost 4 times that
though..
Paul Besing
RV-6A (197AB) Arizona
http://www.lacodeworks.com/besing/
Finish Kit
Sent: Monday, May 15, 2000 3:34 AM
> Hi all,
> Frank.
Cartridge respirators are generally quite acceptable for chemical vapors
such as MEK, assuming you have the right cartridge and the mask fits
properly. The concentrations of the chemical also have to be factored in,
but I would imagine working with MEK as a solvent in a reasonably well
ventilated area would make use of a half-face cartridge respirator very
acceptable.
In an industrial environment, forced or supplied air breathing systems are
reserved for situations where the atmosphere is oxygen deficient, contains
concentrations of materials where the cartridge respirators are not
functional, concentrations of chemicals which are IDLY (immediately
dangerous to life or health) or the material is lethal (hydrogen sulfide,
hydrogen chloride, chlorine, etc). Sometimes we use supplied air to help
keep people cool, but that's not typical.
My experience with respirators is that the cheap ones sometimes don't fit
well. It will leak and you'll become accustomed to the vapors and not
realize that it's leaking, doing yourself no good. I prefer Scott half-face
brand respirators.
Respirators and supplied air are a complex, critical issue. I am not an
expert, but have worked with and around them for many years. Use the above
information at your own risk.
Bryan Jones
Ed Wischmeyer
>Regards,
>Ken Balch
>Ashland, MA
>RV-8 #81125
>floor ribs
>Ken,
1.5" is fine. Use a dense hardwood and trim it down to rough dimension with
a belt sander (I'm sure you can find one somewhere) then finish it to 1.5"
with a sanding block. I used pieces of 2"x2" poplar, made four of them and
used a caliper as a thickness gauge. The stub ends of the spacers were
bolted to short legs made of 2x4 to place the fuselage longerons at waist
level. Caution: do NOT overtorque the bolts holding the spacers in place in
the 804 as most any wood will compress. I made a gap feeler gauge with some
scrap alluminum and checked the spar gap top and bottom as I snugged the
bolts.
This is how I did it, the spars slid in snugly with just a little wiggling
on the wing tips.
Brian Denk
RV8 N94BD
89 hrs.
Subject: | Fwd: Wing Spar ooops |
In a message dated 5/13/00 8:34:18 PM Central Daylight Time, ENewton57 writes:
<< to my horror I realized that I had just put the tie down bracket with the
threaded end facing the top of the spar. No problem to turn it around but now
I have an extra hole in my flange strips (where the top bolt goes through the
tie down bracket, spar web and through two flange strips. I also have an
extra hole in the spar web as well.
Now what? >>
Thanks to all of you who responded to the above inquiry. Most everyone had
the same solution as Vans did when I called them this morning. "Put a rivet
in the flange strip hole, coutersink the tie down bracket enough for the
rivet shop head to clear and just deburr the extra web hole, primer it and
move on." They said it happens a lot (doesn't make me feel any better). Oh
well, I'll just be more carefull and check and double check before committing
any holes to the spar parts (or any other for that matter) in the future.
That's what I get for looking at the plans for the left wing and applying
the orientation of the parts to the right wing spar. (duh??? its upside down
dummy).
Thanks again for the help.
PS - I included the mistake and fix on my web site for future builders (I
hope there are no more that do this).
Eric Newton - Long Beach, Mississippi
RV-6A N57ME (reserved) - Wing Spars
Eric's RV-6A
Construction Page
Full-name: ENewton57
Date: Sat, 13 May 2000 21:34:18 EDT
Subject: Wing Spar ooops
Hi all,
Just made a major oops in the wing spar. I drilled the tie down bracket in
place, (including the top bolt hole that passes through the spar web and two
flange strips) and was getting ready to drill the hole where the tie down
ring passes through the spar flange when to my horror I realized that I had
just put the tie down bracket with the threaded end facing the top of the
spar. No problem to turn it around but now I have an extra hole in my flange
strips (where the top bolt goes through the tie down bracket, spar web and
through two flange strips. I also have an extra hole in the spar web as
well.
Now what?
Thanks for any advise. I'll probably call Van's on Monday as well but would
like some input from the group.
Eric Newton Long Beach, MS
Eric's RV-6A
Construction Page
"Not quite RV-related. Has anyone ordered those shirts from Paul Brown
from Palm Beach Garden and not received them yet? - The ones with a picture
of your own RV embroidred on the pockets, supposedly to wear to SNF....
I don't know if it has anything to do with it, but the Blackjacks ordered 40
shirts from them about six weeks ago which arrived in excellent shape last
week. That big order may have gotten them back up some.
Just speculating...
Mark
RV4
KAWO
Subject: | Re: (no subject) |
I converted an IO-360-A2B to an IO-360-A1B for my RV-6A and I had the same
problem. I used a big washer between the mount ant the engine which actually
moved the engine forward just a little bit. It is enough to prevent touching
and with 130hours+ so far no problems and no signs of rubbing. If you need
more info email to me direct. Cheers
Marc Guay
RV-6A C-FWUV
Ottawa Ontario
Flying 130 hours+
>From: BSEckstein(at)cs.com
>Subject: RV-List: (no subject)
>touches
>Thanks
>Brian Eckstein
>616-624-6719 h
>616-655-3248 w
Subject: | Yeller Pages Update |
Listers!
The latest version of Gary VanRemortel's RV Builders' Yeller Pages is
available at:
http://www.sound.net/~hartmann/yelrpage.htm
Be sure and tell Gary thanks.
- Mike
Our HAZMAT engineering course instructor told us that getting chemical (like
MEK & acetone) on out fingers can get absorbed into the blood stream and do
kidney and liver damage. ( I knew that) What I didn't know that any trace of
the chemical that gets on or under your fingernail get absorbed at a rate of 100
to 1000 times than skin contact.....(I didn't know that) Also, wear a mask
when mixing paints as well as spraying the paints. In days of old we worried
about the spray in the air, today , the chemical reaction of some of the
volatiles we use are dangerous enough to always wear a proper mask.
bryan.jones@lyondell-citgo.com on 05/15/2000 11:36:02 AM
Subject: RE: RV-List: Scribing, respirators, etc.
<bryan.jones@lyondell-citgo.com>
acceptable.
brand respirators.
Bryan Jones
Ed Wischmeyer
Subject: | Re: Need platenut advice (long-ish) |
On all the -4's I've seen and mine the dash upright is more solid than the
forewall upright. No worry here. BESURE the top skin is in place when fitting
the top (and bottom) cowl. and movement transfers misalignment to the spinner
back. I needed to use some thick black gasket material to radius the area the
top skin sits on to even the cowl to the top skin. A thin material here will
hide the hinge. You can tap & bugger the nut palte but eventually you will
replace the screw. BTW, your cheeks need to be fitted in this area & its
important to have the top skin in place because it alligns everything..
svanarts(at)unionsafe.com on 05/15/2000 11:35:38 AM
Subject: RV-List: Need platenut advice (long-ish)
anyone.
new platenuts?
installed?
give me!!
209-946-5116
Subject: | Electric piming the fuel system |
Listers,
Does anyone have any experience with electric priming solenoids for engine
priming?
This sounds like a great idea. It puts one less fuel line inside the cockpit
since you can locate everything on the other side of the firewall.
Thx,
- Jim Andrews
Austin, Texas
RV-8Aq ( fuse & finish )
N89JA (reserved)
Subject: | RV-6/6A Elevator control tube length |
Harry:
I had to cut a 1 1/8 hole in the f607 BH to get the tube in.
If you neutral the stick & f635 bellcrank, then install one rod end on
with 60% threads,
you can install & mark for the other that has 60% threads. I used 5
degrees forward of plumb on the stick. Later I adjusted the f689 to 3
degrees after the elevator stops were on.
Tape a 1/8 shim to the f604, so you will not bottom out on it.
Don Jordan -- 6a finish -- Arlington, Tx -- dons6a(at)juno.com
> -6/6A builders
> For the forward elevator control tube, the one that is 3/4 in.
diameter that
> goes from th control column to the bellcrank, sheet 40 of the plans
> shows a > length of 47 1/2 inches.
> to my fuselage, and also some for attaching the lift struts.
> 10-32, 5/16 x 18, and 8-32 threads in various holes.
If you put the 10-32's under the skin & use the 8-32's forward thru the
skin, you can get by with just the 8-32 Tap & put nuts on the (flush)
10-32's.
The 5/16-18 is used to attach the aft end of the strut to the plate that
screws to the f621. The finish nut is preaty but don't think it will
handle the loads. I would recommend useing nut plates under the 621. It
will be hard to get nuts in there later.
I would buy the best at the hardware store. THe system is SAE I think.
Find a table from the store or our catalogs that tell you the tap drill
size. If you have n't driven any taps before, use lubricate, turn in 1/4
in & out 1/2. You will need to buy a handle for the tap. This is one
thing that has to be done right the first tiime. Just like rivets,
practice on scrap first.
> suchlike...
> (God
> a
> Or
> Frank.
From: | "Japundza, Bob" <bjapundza(at)dowagro.com> |
Subject: | Electric priming the fuel system |
Jim,
I copied a friend's electric primer installation and he really likes it...I
installed the solenoid valve on the firewall and wired it off the boost pump
switch with a pushbutton so that it can activate only when the boost pump is
on.
> Listers,
> priming?
> inside the cockpit
> Thx,
> - Jim Andrews
> Austin, Texas
> N89JA (reserved)
Subject: | RV Flight Trainig/Mike Seger Philadelaphia Appearance |
So Far Mike Seger has these 12 folks signed up for RV training in the
Philadelphia area on July 18, 19th 20th, 2000.
1. L. A. Dobbs, NJ
2. P. Condon, NJ
3. L. Scheer, NY
4. M. Garramone, NY
5. T. Norwood, NY
6. D. L. Davis, PA
7. R. Ziedman, PA
8. e-mail person ghfrost.aol.com
9. R. Gray, Ohio
10. L. Lawson, ?
11. J. Cimino, PA
12. H. Sigmon, DE
Any other RV-listers wanting access to Mike Seger and his RV-6 for Mike's CFI
training please post me a e-mail at pcondon(at)csc.com or philc(at)voicenet.com or
609.654.9587 after 6:00pm est. We have room for 18 training slots. Also, if
there are no objections from the training group, If we collect 10 or 12 $ pre
training slot person we can put Mike up at a hotel while he does the training.
I figure 10 $ per trained person times 18 folks will cover Hotel expenses. We
can schedule alternates so more than 18 can sign up because I expect some folks
may not be able to attend due to last minute problems..............later.
Hello everyone,
Came across a deal on clecos & decided to pass it on to the group.
Sorry, but at the present time I only have 24 kits & they will be sold
on a first come first served basis. The kits consist of the following:
25 - short #40's
25 - #40's
50 - 1/8"
10 - 5/32"
10 - 3/16"
3 - 1/2" side grip clecos
3 - 1" side grip clecos
1 - pair of name brand cleco pliers
The cost of each kit is $48.00 delivered U.S. Priority Mail anywhere
within the continental U.S. The kits are packaged & ready to ship. I've
personally checked all the clecos & there are no bad ones.
Blue Skies!
From: | Karl Schilling <k_schilling(at)iquest.net> |
I used a solenoid from a local auto parts store that is for part of a
nitrous oxide system. It works great, mounted on the firewall just above
the gascolator. I installed a small pushbutton on the switch panel. RV-8
711KN 70 + hrs. and smiling more every day! Want to see it, go to
www.globeswift.com and select Karl's RV-8, there is a very nice RV-4 on
this site that just flew.
-----Original Message-----
From: Jim_Andrews(at)tivoli.com [SMTP:Jim_Andrews(at)tivoli.com]
Sent: Monday, May 15, 2000 01:16
Subject: RV-List: Electric piming the fuel system
Listers,
priming?
From: | Scott.Fink(at)Microchip.com.Mon, 15 May 2000 12:53:37.-0700(at)matronics.com |
Subject: | Cleaning off Mold Release |
05/15/2000 01:00:55 PM
How do you clean off the mold release from the fiberglass parts that have
been "released" so that you can add more layers of cloth? I am using West
Systems epoxy and the paste wax type mold release from AC Spruce.
Scott Fink
RV6 skinning left wing
Scott asked:
Scott Fink
Scott,
Below is an excerpt from the installation instructions for the Glasair style panel
for the RV-6 that I sell.
"The CIP (Composite Instrument Panel) as delivered will have a residue of mold
release agent on the molded surface. This must be removed before any filler or
primer is applied. The best way to remove this mold release is to sand it off
using 320 grit wet/dry sandpaper and some fresh water with a couple drops
of dish washing detergent. Sand enough to see that it's completely dull and fresh
water won't bead on it. This will probably open up some more pin holes,
but it's the only way to assure the release is all gone. If you don't get all
the release off, it could chip easily after the final paint is applied. Let
it dry completely before shooting any primer on it.
If you happened to over trim on any part of your CIP, now is a good time to do
the repairs. You'll have to get some good quality epoxy. Aircraft Spruce carries
"West System" epoxies, and we recommend them. Rough up the back side of
the panel with 180 grit sand paper. Put some masking tape on the front side of
the CIP to form a temporary mold to layup the fiberglass on. Mix up a batch
of epoxy and wet out the back side of the CIP. You can then take some of the
lightweight fiberglass provided in the kit and put down 3 layers. Make sure
they are completely wetted out. Leave alone for 24 hours, then peel back the masking
take and retrim. You can now go ahead and do the preliminary finishing
of your CIP."
This is the process I recommend.
Take it for what it's worth.
Laird RV-6 N515L (taxied the RV for the 1st time yesterday)
SoCal
http://www.planes-wings-things.com/rv-6_panel.htm
Scott:
Your going through the same things everyone has so take a big breath and relax.
1. I glued some angle stock to the front of the firewall. Use silicone sealer,
just a dab every inch or so. The angle could be a 1X2 wood but aluminum is
plentiful at this stage. Make sure it goes from bottom to edge below the
nutplates and hinge.
2. When you redue the skin just place at the edge of the spacer under the hinge.
Also use a strap over the foreskin to pull the skin taught over the
platenut/hinge/spacer/flange. I'll scan an image this evening and send it to you
later.
Just order your new skin and get all the method down before you start.
Isn't this fun!?
More Later
Dave Aronson
RV4 N504RV
> anyone.
> new platenuts?
> installed?
> give me!!
> 209-946-5116
Subject: | Re: F-804 Spacer Accuracy |
>>Regards,
>>Ken Balch
)Ken, when Randy Lervold was at this point we mic'ed his spars, and I machined
four
pieces of aluminum for him. They were .005" oversize. When it came time to fit
the
wings it became obvious that we made the right decision. I am now using the same
pieces.
Randy Griffin
#80925
Fuse just now out of jig! (yeeeee haw)
Subject: | Enpennage for sale -rv6 |
Sorry for being so unclear, the enpennage that is for sale is for a
rv-6,located in Williamsville,Illinois.
Enpennage is completed other than some very minor finish work on the tips.
It was the prepunched version with the powder coated elevator horns.
Workmanship in my opinion is excellent. Call at 217-566-2500 or reply by
email at mphill(at)fgi.net.
Asking price is $1100.oo
Frank,
I was going to suggest you visit your Sears store to get a set of taps
and dies, but they may not operate in N.Z.?
For general knowlege, you can't beat the info in the "Standard aircraft
handbook". It is a condensed collection of nearly everything you ever
wanted to know about aircraft stuff. In fact, I consider it a "must have"
reference. You can get one from Van's and most a/c parts suppliers.
Tom Barnes -6 finishing.
----- Original Message -----
> Hi all,
> Frank.
Subject: | Re: Electric piming the fuel system |
Jim, Aircraft Spruce sells one for just over $40. Check page 155 of
current catalog. (Thanks to Glen Gordon for pointing this out to me).
Tom Barnes -6
Sent: Monday, May 15, 2000 1:15 PM
> Listers,
> priming?
cockpit
> Thx,
> - Jim Andrews
> Austin, Texas
> N89JA (reserved)
Subject: | Rudder/tailwheel springs |
Hi all,
Quick question.
How tight or loose should the tailwheel chains/springs be rigged?
TIA,
Laird RV-6
SoCal
Subject: | Re: IO-360-A1B6 on RV6A |
From: | "Shelby Smith" <shelbyrv6a(at)mindspring.com> |
I believe Steve Barnard had to put some spacers on the lowerengine mounts
and also he removed some of the sump. It was still tight.
Let me know how it works out. Others have had the mount cut and re-welded.
Shelby Smith
N95EB - reserved
>Subject: RV-List: IO-360-A1B6 on RV6A
>Date: Mon, May 15, 2000, 10:00 AM
> the
> Thanks
> Brian Eckstein
> 616-624-6719 h
> 616-655-3248 w
> Thanks
> Brian Eckstein
> 616-624-6719 h
> 616-655-3248 w
Thanks Dave. By the time I'm done I will have built two RV-4's!
BTW, I didn't see it on the plans, what spacer between the hinge and the
firewall flange?!?
209-946-5116
Sent: Monday, May 15, 2000 1:06 PM
Subject: Re: RV-List: Need platenut advice (long-ish)
Scott:
but aluminum is
edge below the
over the
later.
you start.
Isn't this fun!?
More Later
Dave Aronson
RV4 N504RV
under the surface
skin on my RV-4
several
> anyone.
using the little
this it stands
firwall aft a bit.
straight?
firewall where it
install the screws.
> new platenuts?
:?), where is this
is exposed on mine
skin (fore skin),
correctly with the
have platenuts
> installed?
> give me!!
> 209-946-5116
From: | Glenn & Judi <foxinsocks(at)mediaone.net> |
Subject: | O.A.T. Probe Location |
Hi. I would like to install my O.A.T. probe in the NACA air intake in
the side of my RV-6. The probe is 5/8" deep. How far back in the air
intake can I put it and still be assured that it's hitting oncoming
air? The instrument is by Electronics International. I'd like to have
it as flush as possible so that it is not sticking out the side of the
aircraft.
Thanks.
- Glenn Gordon
"You can't make footprints in the sands of time if you're sitting on
your butt. And who wants to make butt-prints in the sands of time?"
Subject: | RV-6 Fuselage Fuel Line |
Listers,
How much rudder pedal travel do you need at the bottom of the suspended
rudder pedals in an RV-6? This is the distance between the resting position
and wherever the pedal is when the rudder horn hits the stop. I'm trying to
determine if my routing of the fuel line from the electric pump to the
firewall is gonna work.
It's a real mess trying to route that fuel line around the structure down
there, while keeping it out of the way of clumsy feet and keeping it clear of
the rudder pedals. If anyone wants to share a few hints, I'm in a listening
mood.
Thanks in advance,
KB
Subject: | Sigma Tek dimension needed |
Hi again... I'm in panel planning stages here. I have a drawing from
Sigma Tek of their model 5000B attitude gyro. The dimension I need
right now is the one they didn't list. Aft of the bezel the instrument
assumes a cylindrical shape almost all the way back. What is the
diameter of the body of the instrument?
Thanks.
- Glenn Gordon
Subject: | Re: Shirts (solved) |
Listers, Paul has responded. He's been busy with a big order. He's
mailing mine out today. Thanks to those in his vicinity who offered to help.
Anh
N985VU
Maryland
>Just speculating...
>Mark
>RV4
>KAWO
Subject: | Re: Cleaning off Mold Release |
I have used WEST epoxy for years in boat projects. Best way to get the
mold release wax or the film of waxy residue off is with a scotch bright
pad and a solution of ammonia and water. Then it can be sanded without
clogging paper. I have had experiences where sanding did not get it all
off without the application of the ammonia solution.
For quick easy wet sanding of small areas, use a spray bottle of windex
(with ammonia) and wet and dry paper.
Simple and effective.
If you are going to lay up right away, use denatured alcohol as a
solvent sparingly to wipe down.
John Oliveira
RV9a 90054
Subject: | Re: O.A.T. Probe Location |
>aircraft.
>Thanks.
>- Glenn Gordon
That's where I had the OAT probe on my RV-6. I found that it read
consistently higher than true OAT. Couldn't figure out why until
someone on the list pointed out that heated air from the engine
cowling was probably 'leaking' from the area where the cowling meets
the fuselage.
I'd considered placing the probe out on the under side of the wing if
I had really wanted an accurate temp but never bothered to do that.
John Ammeter
1975 Jensen Healey
RV-6 (sold 4/98)
EAA Technical Counselor
NRA Life Member
Council Member, Snohomish Indian Tribe
ICQ#48819374
From: | "Marian and Scott Sawby" <mkr(at)netw.com> |
May 10, 2000 - May 15, 2000
RV-Archive.digest.vol-im
