RV-Archive.digest.vol-is
June 13, 2000 - June 20, 2000
Subject: Re: Tank Skins
Date: Jun 13, 2000
Mark, I think alot of RV's have this problem, I know mine does. It bugged the hell out of me for a while before I flew the airplane, I don't even notice it any more. The four RV's on our field all have it to some degree. I don't think there is much you can do about it one the puckering is there. Joe Hine RV4 C-FYTQ > > I've recently mounted both tanks and noticed that there is an ever so > slight slight puckering of the tank skin between the attachment screws > on the outboard edge of the tanks, where they meet the outboard leading > edge. The skins were edge formed before dimpling and I thought that > would ensure a tight fit of the tank skin against the splice plate. Has > anyone else had this problem? Is there a way to address this? I don't > see this as any kind of structural problem, but it bugs me to see it! > Thanks! > > Mark Dickens > RV-8 Wings > ________________________________________________________________________________
Date: Jun 13, 2000
Subject: Century Instrument Reliability????
I used 5 rebuilt Century Instruments. 2 of the 5 have been back to shop and I have 18 hours on the airplane. My airspeed had a leak from the ram pressure side to the static side on the maiden flight. And at about 16 hours when I was at 5500 feet it wound up faster than when I was climbing vertically at max A/B during my F16 ride. It came to rest at 42520 feet and has not moved since. Sure hope my two gyro instruments from Century last awhile longer. Has anyone else has similar experience? These are yellow tagged rebuilt instruments and 2 of my aviator friends whose judgement I value recommended Century. Bernie Kerr, 6A N60WM with 18 hours, SE FLA ________________________________________________________________________________
Date: Jun 13, 2000
Subject: Recombinant Gas Battery Charging from dead flat
Thought I had a failproof system to not leaving the master on; but when you sit in the hangar doing something with the master on, it is annoying to have that EIS light blinking at you. I turned the EIS off (which is not my normal procedure when I getting out of the cockpit after a flight)to turn the light off, fiddled with one one of my avionic goodies and then went away for a week. My 11 pound miracle battery was real whimpy with the last electron depleted when I returned. It would not take a charge. After some discussion with Tim at B&C specialty about how to get home from somewhere with a similiar situation, he suggested that it would probably come back to life if we applied 24-28 volts to it for about a minute until the charger read 10 amps. I hooked a12 volt battery in series with a 12 volt charger and in 75 seconds it was at 10 amps. I am chicken and kept a concrete wall between me and the battery while doing this operation. After charging it about 5 hours at 2 amps, it would not start the engine while hot. After it cooled it seems to be just fine and continues to appear normal after 3 one hour flights. ________________________________________________________________________________
Subject: Colorado Pilots
Date: Jun 13, 2000
Yes, from Denver, the route to Leadville is fairly tame....landing/take off there is no sweat...my RV6A with fixed prop.O-320 160HP doesn't seem to know the difference from my 7,500-ft home airport. They give you a nice certificate if you land there also. From Leadville you can go south over Monarch Pass - 13,000-ft gives you good clearance, and then on to Grand Junction its all down hill! RV6A Flying Salida, CO ________________________________________________________________________________
Date: Jun 13, 2000
Subject: Re: Fuel Tabs
I put fuel tank tabs in my 6A. Drew a sideview of the tank with proper diheadral to get an educated guess of the height to set them at. But, I have not used the tanks yet to get an actual gallon amount. L.Adamson RV6A finish ________________________________________________________________________________
Date: Jun 13, 2000
Subject: Make your own custom treminal blocks
Hello Listers: New Page!!!! Make up your own custom terminal blocks AAMR/AirCore/ Terminal blocks or http://members.aol.com/aamrelectr/Page99.html Regards, John @ AAMR/AirCore/Mar ineCore (Chick the blue link to go there) ________________________________________________________________________________
Subject: Push to Talk/MAC Trim Installation
Date: Jun 14, 2000
i don't believe there's any other option on the micro switches included in the Mac grips. i just got through wiring a pair of g7's and any thing other than a good solder joint would be too bulky. i can't really see a big problem with solder (when necessary) especially when there are people who think knife splices are still acceptable. (they probably are, but what do i know....still, they scare me enough to remove them from my production plane after much probs......) Steven DiNieri capsteve(at)wzrd.com > Is this true??? When doing R&D for Chrysler Corp. we were told to never > EVER use crimps. Everything was to be soldered as crimps apply > pressure to > the wire in a very localized spot and that, combined with vibration was > invitation to broken connections. I also never saw a single crimp when > working for Martin Marietta on Longbow, Lantirn, etc. I'm not saying that > crimps are not the way to go......I've been out of that sort of > thing for a > while now, maybe things have changed. Comments from the current experts? > > Bill > > > > > > This may have been discussed before on the list but I wouldn't > personally > > solder anything in any aircraft. > > I used to work as an avionics technician and solder is a big 'no-no' > unless > > it's on a circuit board inside a radio. Soldered wires, cables etc. gets > > brittle and may eventually break with vibrations and general handling of > > harnesses - especially during installation. Use crimps and other > non-solder > > equipment. When wiring harness for avionics, also only crimp > the wires on > > the connectors, I would never solder. > > It still turns into a multi evening project though :) > > > > Just my .02 and advice. > > > > Are > > RV-6 C-GQRV (reserved) > > > > KB wrote: > > Lots and lots of solder connections. I count > > 55 solder connections in my system, 21 of them inside the > little golf ball > > sized knob that sits on top of the stick and houses 5 switches. Another > > great example of a "little task" that turns into a multi > evening project. > > > > > > ________________________________________________________________________________
Date: Jun 14, 2000
Subject: Re: Push to Talk/MAC Trim Installation
In a message dated 6/13/00 6:24:27 PM Pacific Daylight Time, billshook(at)mindspring.com writes: << When doing R&D for Chrysler Corp. we were told to never EVER use crimps. Everything was to be soldered as crimps apply pressure to the wire in a very localized spot and that, combined with vibration was invitation to broken connections. I also never saw a single crimp when working for Martin Marietta on Longbow, Lantirn, etc. I'm not saying that crimps are not the way to go......I've been out of that sort of thing for a while now, maybe things have changed. Comments from the current experts? >> I guess I would qualify as an expert of sorts. For 25 years I worked as a process/Mfg Engineer for a company making military computers for the DOD. I'm well versed in soldering technology and also solderless connections. The reliability data seem to favor crimped connections in MTBF calculations by an order of magnitude, provided they are properly made. Soldering always creates an abrupt transition with stranded wire that can become a stress concentration point if the wiring is not properly supported. MIL-C-22520 and other similar tools are designed to crimp machined military contacts to stranded wire. The contacts must be the correct AWG range (usually spanning three sizes, 18/20/22 AWG for example) for the wire to be terminated. The crimping tools sometimes have adjustments to dial in the specific wire gauge among the three, but not always. Military tools produce a double four sided indent for round contacts and a double two side crimp for ring terminals, so one should seek commercial tools that produce similar features. It is important for the tool nest to hold the terminal/contact so that, when forming the crimp, the terminal and the wire cold flow together to obtain a gas tight joint (a needle nose pliers ain't gonna get it). If you can't do it right then soldering is the next best thing although you must use the right temperature tip and the correct solder/flux (eutectic Sn60/Pb40 or Sn63/Pb37 with RMA core). The flux residues should be removed with solvent (IPA, Acetone) for best results. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: Jun 14, 2000
Agreed - if it's not executed properly, then I guess a solder joint would do. In the case of the 'coolie hat', soldering may be the only way. There are many other areas that may require solder too but I would not use it on any harnesses behind the panel or connection of lights etc. The connectors on most (if not all) TSO'd equipment should be designed for solder-less connections - the AWG requirement is stated in the manuals. You need a pin extractor and some other tools to work with this properly. In all aircraft I worked in (commercial also), I never seen a solder joint unless in headsets, microphones etc. It's not really difficult to get a good crimp with good crimps and quality tools. This ensures that the pressure is distributed equally. It looks nice and clean with two wires soldered together with heat-shrink to protect it but the sharp edges in the solder joint will soon work its way through the heat-shrink - unless it snaps of first. Are (seems like the stiffener fabrication in emp kit never ends!) RV-6 MIL-C-22520 and other similar tools are designed to crimp machined military contacts to stranded wire. The contacts must be the correct AWG range (usually spanning three sizes, 18/20/22 AWG for example) for the wire to be terminated. The crimping tools sometimes have adjustments to dial in the specific wire gauge among the three, but not always. Military tools produce a double four sided indent for round contacts and a double two side crimp for ring terminals, so one should seek commercial tools that produce similar features. It is important for the tool nest to hold the terminal/contact so that, when forming the crimp, the terminal and the wire cold flow together to obtain a gas tight joint (a needle nose pliers ain't gonna get it). If you can't do it right then soldering is the next best thing although you must use the right temperature tip and the correct solder/flux (eutectic Sn60/Pb40 or Sn63/Pb37 with RMA core). The flux residues should be removed with solvent (IPA, Acetone) for best results. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: Jun 13, 2000
I didn't drill any holes in the stick. Just run the wires out the bottom of the stick and lace them out of the way. Worked fine on mine. The "solder/crimp"debate will never be answered. They both have their place in aircraft and in this case, you don't have any choice. Once the wires are soldered and properly laced in the Mac grip, there won't be any movement and no reason for the wires to break. Dave Bristol RV6, Going to the airport in 2 weeks! KBoatri144(at)AOL.COM wrote: > > First, a question, then an observation... > > Question: I need to put a hole in the control stick on my -6 so I can run > the wire bundle from the trim switches and push to talk. The best location ... > > ________________________________________________________________________________
Subject: Wiring Confusion - Electric Gyros
Date: Jun 13, 2000
Listers, I just recieved a couple of four pin connectors today from ACS - part # MS3116e8-4S. They came in a plain plastic bag with no instructions as how to install them. I figured out how they assemble together but have two questions concerning them. 1. Are the wires supposed to be soldered to the cupped pins? - they are way to small for a crimp. 2. Which pins are which? On the back of my RC Allen gyro they call out Pin A - GND Motor, Pin B - +14 VDC Motor, Pin C- GND Light, Pin D - +14VDC Light. I have no trouble knowing how to wire in the gyro BUT the position of the pin labels leaves me confused. This is a rough drawing of what I mean - D o o ------pins (4) B 1A C o o Can any one tell me what the pin labels are supposed to be? The way the labeling is I can see two choices for B,D, & C and four choiced for A. Thanks for the help, ----------------------------------------------------- Doug Murray RV-6 C-GRPA Southern Alberta ________________________________________________________________________________
Date: Jun 13, 2000
Subject: Fuel Tabs
Hi Scott, I put them in my -6 tanks. It's 2.25" up from the bottom of the skin, perpendicular to the middle of the fueling hole when in a tail low attitude. When I did the fuel calibrations last month, it turns out that it indicates 11 gal remaining. I also did stick dip tests at 2 gallons increments, and I came up with about 1/2" per 2 gallons around that area. It looks like I was about a 1/4" too high to get the 1/2 (9.5 gal) fuel like I wanted. (So much for Solid Modeling CAD systems). I did something a little different than Piper (I think), I bent a 1/2" wide strip of .032 that attached at the lower stiffener just forward and just aft of the fueling hole. It's kinda hard to describe, but dirt simple. Contact me offline if you need more details, like maybe a .dxf file. Laird RV-6 (17.9 hrs with some acro in the test card tomorrow) SoCal Has anyone put tabs in the fuel filler neck a-la piper cherokees? I am about ready to do my first tank and would really like to put one in each tank. They have several advantages: 1. They give you an excellent visual point to stop fueling at a known quantity (a calibrated stick here is not as easy to use during fueling) 2. They give you an excellent visual point to estimate the fuel quantity at anything less than full fuel without having to use a stick What I was wondering is has anyone done this and have a calibrated tab length for a calibrated fuel quantity? By the way, I am building an RV6. Scott Fink RV6 ready to skin left wing ________________________________________________________________________________
Date: Jun 14, 2000
I second these comments (re: crimps/connectors). FWIW, the Van's wiring drawing and wiring kit shows the use of a couple of Radio Shack terminal strips . . . You can mount your MAC controllers next to these strips and run their short wires to one side of the strip, then run the servo wires to the other side of the strip. It's clean, neat, and simple. Rick Jory -----Original Message----- From: Are Barstad <abarstad(at)bconnex.net> Date: Tuesday, June 13, 2000 7:04 PM Subject: RE: RV-List: Push to Talk/MAC Trim Installation > >This may have been discussed before on the list but I wouldn't personally >solder anything in any aircraft. >I used to work as an avionics technician and solder is a big 'no-no' unless >it's on a circuit board inside a radio. Soldered wires, cables etc. gets >brittle and may eventually break with vibrations and general handling of >harnesses - especially during installation. Use crimps and other non-solder >equipment. When wiring harness for avionics, also only crimp the wires on >the connectors, I would never solder. >It still turns into a multi evening project though :) > >Just my .02 and advice. > >Are >RV-6 C-GQRV (reserved) > >KB wrote: >Lots and lots of solder connections. I count >55 solder connections in my system, 21 of them inside the little golf ball >sized knob that sits on top of the stick and houses 5 switches. Another >great example of a "little task" that turns into a multi evening project. > > ________________________________________________________________________________
Subject: Re: Turbulence
Date: Jun 14, 2000
>Purely out of curiosity... how does 9 g's "slowly and carefully >applied" >differ from 9 g's "suddenly applied"? Inertia ?? Larry Mac Donald Rochester, N.Y. empennage ________________________________________________________________________________ User-Agent: Microsoft-Outlook-Express-Macintosh-Edition/5.02.2022
Date: Jun 14, 2000
on 6/13/00 23:46, Owens, Laird at Owens(at)aerovironment.com wrote: > > Hi Scott, > > I put them in my -6 tanks. It's 2.25" up from the bottom of the skin, > perpendicular to the middle of the fueling hole when in a tail low attitude. > When I did the fuel calibrations last month, it turns out that it indicates 11 > gal remaining. > > I also did stick dip tests at 2 gallons increments, and I came up with about > 1/2" per 2 gallons around that area. > > It looks like I was about a 1/4" too high to get the 1/2 (9.5 gal) fuel like I > wanted. (So much for Solid Modeling CAD systems). > > I did something a little different than Piper (I think), I bent a 1/2" wide > strip of .032 that attached at the lower stiffener just forward and just aft > of the fueling hole. It's kinda hard to describe, but dirt simple. > > Contact me offline if you need more details, like maybe a .dxf file. > > Laird RV-6 (17.9 hrs with some acro in the test card tomorrow) > SoCal > > > > > Has anyone put tabs in the fuel filler neck a-la piper cherokees? I am > about ready to do my first tank and would really like to put one in each > tank. They have several advantages: > > 1. They give you an excellent visual point to stop fueling at a known > quantity (a calibrated stick here is not as easy to use during fueling) > 2. They give you an excellent visual point to estimate the fuel quantity at > anything less than full fuel without having to use a stick > > What I was wondering is has anyone done this and have a calibrated tab > length for a calibrated fuel quantity? By the way, I am building an RV6. > > Scott Fink > RV6 ready to skin left wing > > On my 6A, the reference points are: when the fuel level first disappears at the bottom of the tank, there is 5.5 gallons remaining. About 1,5 inch more and you have the half, 9.5. Beware both oil and fuel readings are different with trike vs tail wheel models. I think the two gallons per inch is good, in the "visible" range of the tank filling process. I E when you burn down the first half inch, you have used the first gallon. When you have used down to the floor of the tank, you have used about 13 gallons. I think the depth of the tank is about 6 inches so two gal per inch is close. I have never used the tabs so can't speak to that: however you can peer into the RV tank and see the level on the outboard rib while filling. This allows you to eyeball the fuel level pretty good. -- Denis L.(Bum) Walsh ________________________________________________________________________________
Subject: Re: Solder vs crimp WAS Push to Talk/MAC Trim Installation
Date: Jun 14, 2000
Gary wrote: > reliability data seem to favor crimped connections in MTBF calculations by an > order of magnitude, provided they are properly made. Soldering always > creates an abrupt transition with stranded wire that can become a stress > concentration point if the wiring is not properly supported. I'm certainly a non-expert but.... Clue I was once given by an expert is that solder joints ***MUST*** be mechanically sound before soldering. Wires twisted together etc first. Don't use solder as glue. Never heat the solder, just the wires. It does work. You can see all kinds of vibrating equipment such as motors, starting capacitors, alternator diodes etc that are soldered and last for many years. If I were working as an industrial engineer and specifying the setup for a small aircraft assembly line, I would specify crimps. Easy to teach operator to use, more reliable, faster, easier to service in the field etc. I would of course, specify the correct $200+ tool. I wonder how reliable connections made with $4.95 crimpers are?? I had some work done on my Debonair by a former NASA electronic tech who soldered wires to switches etc. Wrapped the wire, soldered, installed shrink tube over it, anchored wire a few inches away. Probably better than poor quality, easily corroded crimps that are poorly done. Hal Kempthorne RV6a N7HK ________________________________________________________________________________
Subject: Turbulence
Date: Jun 14, 2000
Ever ride a rollercoaster? -----Original Message----- From: lm4(at)juno.com [mailto:lm4(at)juno.com] Sent: Wednesday, June 14, 2000 8:11 AM Subject: Re: RV-List: Turbulence >Purely out of curiosity... how does 9 g's "slowly and carefully >applied" >differ from 9 g's "suddenly applied"? Inertia ?? Larry Mac Donald Rochester, N.Y. empennage ________________________________________________________________________________
Date: Jun 14, 2000
I did exactly what Dave mentioned...I ran the wires through black anti-chafe "spaghetti" available from Wicks (its the black stuff), and drilled a small hole at the very bottom of the stick for a zip-tie and fastened it so the rod-end bearings wouldn't interfere. I used a bit of slack and clamped the wires to the seat rib...no interference problems. I also stuffed a piece of foam rubber in the bottom of the stick for insurance to keep some of those slacking thin wires from the stick grip from migrating down to the bottom. Bob Japundza > -----Original Message----- > From: Dave Bristol [mailto:bj034(at)lafn.org] > Sent: Tuesday, June 13, 2000 11:46 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Push to Talk/MAC Trim Installation > > > > I didn't drill any holes in the stick. Just run the wires out > the bottom of the > stick and lace them out of the way. Worked fine on mine. > The "solder/crimp"debate will never be answered. They both > have their place in > aircraft and in this case, you don't have any choice. Once > the wires are soldered > and properly laced in the Mac grip, there won't be any > movement and no reason for > the wires to break. > > Dave Bristol RV6, Going to the airport in 2 weeks! > > KBoatri144(at)AOL.COM wrote: > > > > > First, a question, then an observation... > > > > Question: I need to put a hole in the control stick on my > -6 so I can run > > the wire bundle from the trim switches and push to talk. > The best location ... ________________________________________________________________________________
Date: Jun 14, 2000
Subject: Century Instruments
Century Instruments used to be real good 5 years ago, but they've had lots of turnover since. I have no opinion on the quality of their instruments now. I have had two attitude indicators in a row that did not survive well in my RV-4, but I don't know if it's my environment or their overhaul. Ed Wischmeyer -- NOTE: 5% of messages sent to me don't make it, so use a return receipt to insure delivery. The phone company system drops packets. - - - - - - - - Ed Wischmeyer Web page:
http://members.aa.net/~edwisch Email: edwisch(at)aa.net ________________________________________________________________________________
Date: Jun 14, 2000
Subject: Oshkosh get togeather
Time to organize the RV LIST TABLE at Vans dinner in Oshkosh this next month. In the past, we have met at the table, briefly said hi to one another, then proceeded to listen to the goins on. I felt we didn't get to meet one another much. This year I am going to change that somewhat. Before we go inside there will be, as in the past, a get togeather outside on the grass, at a no host bar. This year I will have something to say RV LIST on it so we can gather there and get to put faces to names VIA the new name badges we all have now thanks to panelpilot. I just got word from Barbara at Vans that the time and place is now set in stone. Pioneer Inn & Marina Saturday July 29, 2000 6:15pm to 7:30pm Cocktails 7:30pm to 9:30pm Dinner Midwest Buffet - $18.50 per person Those of you that would like to be at our table. Get yourself and friend (lover) on the list by sending a note to me off list to cecilth(at)juno.com NOTE NOTE: The list is growing every year. The number of people building RVs, is growing faster. The room at Pioneer Inn holds three hundred of us. DO THE MATH. Make sure your seat is reserved. Send Barbara your money now to reserve your spot. It won't do yourself any good to put yourself on my list unless you have a ticket. ________________________________________________________________________________
Date: Jun 14, 2000
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
> >Gary wrote: >> reliability data seem to favor crimped connections in MTBF calculations by >an > order of magnitude, provided they are properly made. Soldering always >> creates an abrupt transition with stranded wire that can become a stress >> concentration point if the wiring is not properly supported. > >I'm certainly a non-expert but.... > >Clue I was once given by an expert is that solder joints ***MUST*** be >mechanically sound before soldering. Wires twisted together etc first. >Don't use solder as glue. Never heat the solder, just the wires. It does >work. You can see all kinds of vibrating equipment such as motors, starting >capacitors, alternator diodes etc that are soldered and last for many years. True . . . most of the ol' mechanic's tales circulating around out there take tidbits of reliability data out of context and use them to hammer an alternative view. Facts are: both crimp and solder joints turn STRANDED wire into SOLID wire . . . take a look at a cross-section of any crimped/soldered joint and there are NO VOIDS between the strands. I.e., gas and moisture tight . . . Both crimp and solder joints in point to point wiring are subject to motion induced flexure at the transition between where the wire is stranded and where the wire is solid. This is why a crimped joint has TWO supports . . . one for the wire and one for the insulation immediately adjacent to the wire crimp. Solder is a structurally quantifiable material . . . a joint that is held together only with solder has a quantifiable tensile strength. For example, there are bizillions of components attached to circuit boards using only solder as both the mechanical and electrical bond. There are lots of soft and hard soldered assemblies used thoughout the industrialized world that perform as intended for the lifetime of the product. >If I were working as an industrial engineer and specifying the setup for a >small aircraft assembly line, I would specify crimps. Easy to teach >operator to use, more reliable, faster, easier to service in the field etc. >I would of course, specify the correct $200+ tool. Solderless joints do indeed reduce dependency on skill and selection of materials . . they're also less hazardous to upholstery, paint and plastic. >I wonder how reliable connections made with $4.95 crimpers are?? > >I had some work done on my Debonair by a former NASA electronic tech who >soldered wires to switches etc. Wrapped the wire, soldered, installed >shrink tube over it, anchored wire a few inches away. Probably better than >poor quality, easily corroded crimps that are poorly done. Exactly. Bottom line is learn to work with either or both technologies. I have a tool box in my desk at Raytheon. It measures about 3 x 5 x 8 inches. It contains a selection of hand tools that allow me to approach a lot of tasks at work in the office and in the field. It will fit in my briefcase and let me be out-the-door in minutes. No crimp tools. Only a butane powered soldering iron that has a fine enough tip to solder a d-sub connector and enough BTU's to solder a 2AWG terminal onto it's wire. That's a lot of capability in a 3 ounce tool. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 14, 2000
Subject: Re: Wiring Confusion - Electric Gyros
In a message dated 6/13/00 10:40:33 PM Pacific Daylight Time, dgmurray(at)telusplanet.net writes: << I just received a couple of four pin connectors today from ACS - part # MS3116e8-4S. They came in a plain plastic bag with no instructions as how to install them. I figured out how they assemble together but have two questions concerning them. 1. Are the wires supposed to be soldered to the cupped pins? - they are way to small for a crimp.>> They are probably solder cups if they are installed in the connector already. Crimp type pins come separate and you must crimp, then install. << 2. Which pins are which? On the back of my RC Allen gyro they call out Pin A - GND Motor, Pin B - +14 VDC Motor, Pin C- GND Light, Pin D - +14VDC Light. I have no trouble knowing how to wire in the gyro BUT the position of the pin labels leaves me confused. This is a rough drawing of what I mean - D o o ------pins (4) B 1A C o o Can any one tell me what the pin labels are supposed to be? >> On military type connectors (MIL-C-5015 and similar) each pin has one and only one designation, there is not a choice. If you look closely each of the markings will be nearer to one pin than another. If there is a keyway often pin 1(A) will be adjacent to it. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: Jun 14, 2000
Using the strip connector method (as outlined below) allows for tracing bugs and trouble-shooting your installation and adding/deleting/modifying assemblies easier........... rickjory(at)email.msn.com on 06/14/2000 08:50:48 AM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: Push to Talk/MAC Trim Installation I second these comments (re: crimps/connectors). FWIW, the Van's wiring drawing and wiring kit shows the use of a couple of Radio Shack terminal strips . . . You can mount your MAC controllers next to these strips and run their short wires to one side of the strip, then run the servo wires to the other side of the strip. It's clean, neat, and simple. Rick Jory -----Original Message----- From: Are Barstad <abarstad(at)bconnex.net> Date: Tuesday, June 13, 2000 7:04 PM Subject: RE: RV-List: Push to Talk/MAC Trim Installation > >This may have been discussed before on the list but I wouldn't personally >solder anything in any aircraft. >I used to work as an avionics technician and solder is a big 'no-no' unless >it's on a circuit board inside a radio. Soldered wires, cables etc. gets >brittle and may eventually break with vibrations and general handling of >harnesses - especially during installation. Use crimps and other non-solder >equipment. When wiring harness for avionics, also only crimp the wires on >the connectors, I would never solder. >It still turns into a multi evening project though :) > >Just my .02 and advice. > >Are >RV-6 C-GQRV (reserved) > >KB wrote: >Lots and lots of solder connections. I count >55 solder connections in my system, 21 of them inside the little golf ball >sized knob that sits on top of the stick and houses 5 switches. Another >great example of a "little task" that turns into a multi evening project. > > ________________________________________________________________________________
From: "Ollie Washburn" <skybolt-aviator(at)msn.com>
Subject: Re: Recombinant Gas Battery Charging from dead flat
Date: Jun 14, 2000
On the subject of recombinant batteries I read somewhere(can't remember where) that recombinant batteries can not be charged with a 2 amp charger.You might check with mfg. Ollie N795LW 6A flying. ----- Original Message ----- From: <Rv660wm(at)AOL.COM> Sent: Tuesday, June 13, 2000 10:35 PM Subject: RV-List: Recombinant Gas Battery Charging from dead flat > > Thought I had a failproof system to not leaving the master on; ________________________________________________________________________________
From: Scott.Fink(at)Microchip.com.Wed, 14 Jun 2000 09:27:31.-0700(at)matronics.com
Subject: Fuel Tabs
Date: Jun 14, 2000
06/14/2000 09:35:43 AM Laird, I think I get it, you made a U-shaped strip that attached to two different stiffners, right? Excuse my ASCII art, but something like this: ___________ | | | | | | || || || || |___ |____ Where the stiffners are the two "L"s at the bottom. Does this look like what you did? If you have a .dxf file, I would sure appreciate if you could send it to me off list. After a little thought, 11 gallons seems like a really good number to be able to fuel to, with an O360 this would give you two hours of fuel (1.5 hours with reserve), and a little fudge factor on the safe side. Would it be possible to get the results of your dip-stick tests? That would tell me more than I could have hoped for. Scott Fink RV6 ready to skin left wing "Owens, Laird" cc: Sent by: Subject: RE: RV-List: Fuel Tabs owner-rv-list-server@mat ronics.com 06/13/2000 10:46 PM Please respond to rv-list Hi Scott, I put them in my -6 tanks. It's 2.25" up from the bottom of the skin, perpendicular to the middle of the fueling hole when in a tail low attitude. When I did the fuel calibrations last month, it turns out that it indicates 11 gal remaining. I also did stick dip tests at 2 gallons increments, and I came up with about 1/2" per 2 gallons around that area. It looks like I was about a 1/4" too high to get the 1/2 (9.5 gal) fuel like I wanted. (So much for Solid Modeling CAD systems). I did something a little different than Piper (I think), I bent a 1/2" wide strip of .032 that attached at the lower stiffener just forward and just aft of the fueling hole. It's kinda hard to describe, but dirt simple. Contact me offline if you need more details, like maybe a .dxf file. Laird RV-6 (17.9 hrs with some acro in the test card tomorrow) SoCal Has anyone put tabs in the fuel filler neck a-la piper cherokees? ________________________________________________________________________________
Date: Jun 14, 2000
In a message dated 6/14/00 12:13:50 PM Eastern Daylight Time, skybolt-aviator(at)msn.com writes: << On the subject of recombinant batteries I read somewhere(can't remember where) that recombinant batteries can not be charged with a 2 amp charger.You might check with mfg. Ollie N795LW 6A flying >> Hi Ollie, Sorry I mislead you to think I was trying to charge with a 2 amp charger. Originally I was trying to charge with a 10 amp, 12 volt battery; but it was doing nothing. The voltmeter on the battery reads zero and I left it on for several hours. After I hit it with 24 volts, I was charging it with a 6 amp charger; but it was only taking a 2-3 amp charge on the chargers ampmeter. I like your new paint job and meant to talk to you at Sebring about who did it, but got yacking and missed you. Bernie Kerr, 6A N60WM, 19 hours, SE Fla ________________________________________________________________________________
Date: Jun 14, 2000
>> Question: I need to put a hole in the control stick on my -6 so I can run >> the wire bundle from the trim switches and push to talk. On my left stick I took the wires out the bottom but my right stick is removeable. I took the wire bundle out an oval hole out the back. I'm still looking for a good connector plug. When you come around a corner with the wire touching a metal edge, be sure to tie wrap the wire right back onto the bottom of the stick shaft. The wire does a 180 and gets firmly attached to what it just came out of. This eliminates chafing and will increase service life. >> Observation: I thought the MAC trim system would be a simple "plug 'n play" >> installation. Surprise!!... Lots and lots of solder connections. I count >> 55 solder connections in my system, 21 of them inside the little golf ball >> sized knob that sits on top of the stick and houses 5 switches. Another >> great example of a "little task" that turns into a multi evening project. We all know how the Infinity stick grips are the most expensive out here but just to keep the apples with the apples Infinity does 16 solders for you. Each grip comes with three feet of very nice quality cable soldered on. They don't seem quite as expensive when you realize that you get more. Took exactly ten weeks to receive. I recently received my Infinity stick grips and it took about five minutes to figure out that the installation will add several hours to the construction time. It is hard to describe but there's fitting then there's wiring and it all takes time. Very impressive looks though. Flaps, trim, fuel pump, push to talk (on the trigger!), map lights, and one more I haven't decided on. Norman Hunger RV6A Delta, BC ________________________________________________________________________________
Subject: Re: [rv8list] New Vans Service Letter - addendum
Date: Jun 14, 2000
Folks, The point of the service letter mod is to ensure that the fuel pick is where it is supposed to be rather than having rotated so as to unport. Apparently that is what happened with the RV-8 in question that experienced a power failure and off-field landing. Instead of doing this mod couldn't one just take a small inspection mirror and a flashlight in through the fuel inlet and inspect for proper position? Once your fuel lines are tightened nothing will move. Randy Lervold RV-8, #80500, fwf ________________________________________________________________________________
Date: Jun 14, 2000
I am involved in a business making battery chargers and I hope I can help with some comments on this subject. Recombinant batteries should be charged with a regulated charger as they do not take kindly to an overcharge that results in the generation of heat and gas. Most low cost (2 amp) chargers are not regulated but, if you are prepared to monitor continuously the battery voltage while it is charging, and ensure that the battery does not exceed 14.4 volts at a temperature of 77degrees F, no harm will be done. Be careful with unregulated chargers as the voltage can rise quickly at the end of charge if a powerful charger is used. Treat this advice as for emergency only and get yourself a regulated charger. Expect this to cost not less than your battery! Recombinant batteries have a remarkable ability to absorb power (indicated by charging amps) so the heavy charge at the start of the charge will have done no harm. I often see 30 amps on my RV6's ammeter for a few minutes if my battery has done any work. A battery that is warming up under charge is your best warning to back off the charge. All recombinant batteries are fitted with safety valves to prevent explosion but the release of gas is water lost from your battery that is needed and cannot be replaced. A trap exists with regulated chargers in that they are usually polarity protected and won't switch on if the electronic circuit can't detect a voltage. A dead flat battery is therefore regarded as possibly incorrectly connected and the charger does not respond. Having checked for correct polarity connection of the positive and negative leads, jump start the charger from any source that will give you at least 8 volts. Some chargers have a start button for the same purpose but we prefer not to provide this option as a mistake with connection will toast the charger. The charger you purchase will have important safety instructions. Please follow them. Noel Drew ZU-APF RV6 320 hours Durban South Africa www.hawkins(at)iafrica.com -----Original Message----- From: Ollie Washburn <skybolt-aviator(at)msn.com> Date: 14 June 2000 06:15 Subject: Re: RV-List: Recombinant Gas Battery Charging from dead flat > > On the subject of recombinant batteries I read somewhere(can't remember >where) that recombinant batteries can not be charged with a 2 amp >charger.You might check with mfg. Ollie N795LW 6A flying. >----- Original Message ----- >From: <Rv660wm(at)AOL.COM> >To: >Sent: Tuesday, June 13, 2000 10:35 PM >Subject: RV-List: Recombinant Gas Battery Charging from dead flat > > >> >> Thought I had a failproof system to not leaving the master on; > > ________________________________________________________________________________
Date: Jun 14, 2000
Subject: Fuel Pickup Checking
I would encourage everyone to test what the unusable fuel is in the system as well as test the actual fuel capacity. On my RV-4 I drained the tanks using the boost pump and then drained the remaining fuel out of the fuel sump fitting just to see what was left. -Rob Hickman RV-4 N401RH ~45 Hours ________________________________________________________________________________
Date: Jun 14, 2000
Subject: Re: Fuel Pickup Checking
RobHickman(at)AOL.COM wrote: > > I would encourage everyone to test what the unusable fuel is in the system as > well as test the actual fuel capacity. > > On my RV-4 I drained the tanks using the boost pump and then drained the > remaining fuel out of the fuel sump fitting just to see what was left. > > -Rob Hickman > RV-4 N401RH ~45 Hours > And how much did you determine was unusable? (Inquiring minds want to know.) George True ________________________________________________________________________________
Date: Jun 14, 2000
Just for grins, what was the delta fuel amt. ? Did you do it tail low or tail in flying config? RobHickman(at)aol.com on 06/14/2000 03:28:26 PM Please respond to rv-list(at)matronics.com Subject: RV-List: Fuel Pickup Checking I would encourage everyone to test what the unusable fuel is in the system as well as test the actual fuel capacity. On my RV-4 I drained the tanks using the boost pump and then drained the remaining fuel out of the fuel sump fitting just to see what was left. -Rob Hickman RV-4 N401RH ~45 Hours ________________________________________________________________________________
Subject: Coroplast
Date: Jun 14, 2000
Fellow Listers: Just thought I'd mention the use of a product that is great for side upholstery panels in RVs (or any aircraft for that matter). I have mounted my side upholstery fabric (from DJ) on 4mm thick polyboard that goes by the trade name of Coroplast. It is used in the sign making industry and it's construction is just like corrugated cardboard except it is made from polypropylene plastic. It is lightweight and be cut with scissors or an Exacto knife. I attached the sidewall fabric to it with spray adhesive and it is held in place on the fuselage cabin wall with double face carpet tape. Artex Products carries it (the upholstery people that advertise in T-A-P or this supply house carries it ( http://www.southlandsignsupplies.com/catalog/ca20.htm). About $10 for a 4' x 8' piece. Doug =========== Doug Weiler Hudson, WI 715-386-1239 dougweil(at)pressenter.com ________________________________________________________________________________
Date: Jun 14, 2000
In a message dated 06/14/2000 4:36:16 PM Eastern Daylight Time, true(at)uswest.net writes: << And how much did you determine was unusable? (Inquiring minds want to know.) >> I'm not the original poster, but my results were: one cup on the conventional side, and 1.5 cups on the side with the flop tube (I have no idea why I put that thing in there with no other inverted systems.) These results give me added confidence that any water in the tank will be drained long before enough accumulates to reach the pickup tube, which is an issue if you have no gascolator, like me. But then by not having one, I hope never to have vapor lock. -Bill B ________________________________________________________________________________
Date: Jun 14, 2000
Randy, That is exactly what I am planning on doing. I also thought you might be able to determine if the fuel pick-up tube is in the proper position by inserting a small wire into the tank drain, (take the drain out first) & feel if the tube is in the correct position. My wings are on, tanks sealed etc. & I don't want to take the tank covers off. I am also going to fill one tank 100% & use the boost pump to drain that tank via a filter (this will clean the tank) into the other tank. I will use this procedure to ensure that 21 gallon are transferring, Thus the tube is correctly positioned. I will repeat the procedure & ultimately have 10.5 gals in each tank for the initial engine start & run. Mark Steffensen 8A Dallas, TX ----- Original Message ----- From: "Randy Lervold" <randy@rv-8.com> Sent: Wednesday, June 14, 2000 7:20 AM Subject: Re: RV-List: Re: [rv8list] New Vans Service Letter - addendum > > Folks, > > The point of the service letter mod is to ensure that the fuel pick is where > it is supposed to be rather than having rotated so as to unport. Apparently > that is what happened with the RV-8 in question that experienced a power > failure and off-field landing. > > Instead of doing this mod couldn't one just take a small inspection mirror > and a flashlight in through the fuel inlet and inspect for proper position? > Once your fuel lines are tightened nothing will move. > > Randy Lervold > RV-8, #80500, fwf > > ________________________________________________________________________________
Date: Jun 14, 2000
Subject: Tilt up canopy problem
I'm just finishing up building my canopy frame on a RV-6 it is the tilt up version. Me and a fellow RV-6 builder in the area are having the same problem. When the canopy is tilted up the aluminum skin on the canopy frame top interferes with the top forward skin of the fuselage causing it to "pop" and in my case would cause the aluminum to kink if tilted. I already have a 1/16'' gap between the canopy skin and the top fuselage skin is this not enough? Any help or suggestions would be appreciated. Thanks, Eli Lewis Venice, FL RV-6 ________________________________________________________________________________
Subject: Re: RV-List Digest: 65 Msgs - 06/13/00
Date: Jun 14, 2000
With the stick moved forward, the stick length from the f-604 to the top of the stick is 13 13/16 inches. Your stick length will vary depending on where you drill the block that supports the control mechanism. FWIW, I have relieved some material from the flange of the f-604, but only to the point where it begins to turn downward. Tom Barnes -6 finishing ----- Original Message ----- > From: "Norman Hunger" <nhunger(at)sprint.ca> > Subject: RV-List: RV6 Control Stick Movement > > > I found an interesting bit of trivia in the archives that is worth posting > and it leads to my question. > > RV6 control stick movement is 23 degrees left and right then 20 degrees back > and 16 degrees forward. The post was by one of the reputables. > > So what is the height from the top of the seatpan at F-604 to the top of the > stick grip? > > > Thank-you, > Norman Hunger > RV6A Delta BC > > ________________________________________________________________________________
Date: Jun 14, 2000
From: Will Cretsinger <cretsinger(at)arlington.net>
Subject: Re: West System Epoxy - Cotton Fiber
John, imagine no longer! I and others have had inadequate clearance between the spinner and the cowl. The solution is to fill the aft side of the upper and lower cowls with flox and a couple layers of glass, then sand for the perfect gap from the spinner. Will Cretsinger, Arlington, Texas -6A flying through 210 hours and going to Airfair in July! John Oliveira wrote: > > > Cotton Fiber is mixed with the epoxy to make structural fillets or fill > gaps where strength is needed. It works very much like chopped glass > fibers without the problems fibers cause in handling. (getting into > skin, etc.) Much safer. > > I cannot imagine anyplace you would use it on an aluminum airplane. > When hard it is extremely difficult to sand. Right up their with high > density filler. > > If you were using it in a glass airplane, it would be for fillets when > installing structural bulkheads or ribs before taping. > > John Oliveira > RV9a N909RV > ________________________________________________________________________________
Date: Jun 14, 2000
Subject: RV-8 Dwg. 28 r5 error
In preparing to drill my F-824 aft side skins this afternoon, I discovered that the match hole on the F-823 center side skins (as called out on Dwg. 28 r5) is wrong. If you use that match hole, none of the bulkheads line up with the prepunched holes in F-824. The correct match hole on F-823 is one forward of the hole on the drawing. Van's confirmed this and said that they've already issued r6 of this drawing. My fuse kit shipped in early April and still had the r5 drawing. -- Regards, Ken Balch Ashland, MA RV-8 #81125 drilling fuselage skins ________________________________________________________________________________
Date: Jun 14, 2000
It seems to me that by filling only 1/2 gallon of fuel in a tank known to be empty, then watching how much fuel pumps out, one could prove the point without having to deal with so much bulk. Then if the fuel doesn't flow, begin the investigation with a near empty tank. Tom Barnes ----- Original Message ----- From: Mark Steffensen <steffco1(at)home.com> Sent: Wednesday, June 14, 2000 3:45 PM Subject: Re: RV-List: Re: [rv8list] New Vans Service Letter - addendum ~snip~ > I am also going to fill one tank 100% & use the boost pump to drain that > tank via a filter (this will clean the tank) into the other tank. I will use > this procedure to ensure that 21 gallon are transferring, Thus the tube is > correctly positioned. I will repeat the procedure & ultimately have 10.5 > gals in each tank for the initial engine start & run. > > Mark Steffensen > 8A Dallas, TX > > ----- Original Message ----- > From: "Randy Lervold" <randy@rv-8.com> > To: > Sent: Wednesday, June 14, 2000 7:20 AM > Subject: Re: RV-List: Re: [rv8list] New Vans Service Letter - addendum > > > > > > Folks, > > > > The point of the service letter mod is to ensure that the fuel pick is > where > > it is supposed to be rather than having rotated so as to unport. > Apparently > > that is what happened with the RV-8 in question that experienced a power > > failure and off-field landing. > > > > Instead of doing this mod couldn't one just take a small inspection mirror > > and a flashlight in through the fuel inlet and inspect for proper > position? > > Once your fuel lines are tightened nothing will move. > > > > Randy Lervold > > RV-8, #80500, fwf > > > > > > ________________________________________________________________________________
Date: Jun 14, 2000
Subject: Pictures of My RV-6
"rv-list" Hi all, Since I bored you all with tales of my Setrab oil cooler failure and other such nonsence, I thought I'd share some pictures of my new flying machine. It's not quite finished, it still needs the intersection fairings fab'ed, which is why the cowl, gearleg fairings, and wheel pants are not yet painted. I also left the tail fairing unpainted in case I had to change the incidence of the fin or stab. I didn't. I'll post some more pictures of some of the special details that might be of interest in the future. Please turn you mouse to : http://members3.clubphoto.com/laird244198/Laird_RV-6_N515L/ Thanks, Laird RV-6 SoCal PS Hey Gary...How do I get this album tied to the SoCal albums? ________________________________________________________________________________
Date: Jun 14, 2000
What happens years down the road if the plane gets sold or if you forget?? I haven't done the mod yet, but to me it looked pretty simple. Just my humble opinion . . . Rick Jory -----Original Message----- From: Randy Lervold <randy@rv-8.com> Date: Wednesday, June 14, 2000 12:51 PM Subject: Re: RV-List: Re: [rv8list] New Vans Service Letter - addendum > >Folks, > >The point of the service letter mod is to ensure that the fuel pick is where >it is supposed to be rather than having rotated so as to unport. Apparently >that is what happened with the RV-8 in question that experienced a power >failure and off-field landing. > >Instead of doing this mod couldn't one just take a small inspection mirror >and a flashlight in through the fuel inlet and inspect for proper position? >Once your fuel lines are tightened nothing will move. > >Randy Lervold >RV-8, #80500, fwf > > ________________________________________________________________________________
Date: Jun 14, 2000
RobHickman(at)AOL.COM wrote: > > I would encourage everyone to test what the unusable fuel is in the system as > well as test the actual fuel capacity. > I ran mine dry to check them flying and both took 15.6 to fill in my -4. John Kitz N721JK Ohio ________________________________________________________________________________
Subject: Question on gyros...
Date: Jun 14, 2000
I'm planning the panel layout of my RV-8 and am soliciting comments regarding two issues. 1) I'm thinking about running only electric gyros - do you think it would affect resale value considering that an electrical system failure would leave you gyroless? This will be a night VFR plane. 2) Caging during aerobatics - is it necessary? How about an electric gyro that is turned off? Will it still damage the gyro? Will it flop around even if it is not powered up? Thanks for the help, - Bill in Tucson ________________________________________________________________________________
Subject: Re: Pictures of My RV-6
Date: Jun 14, 2000
Plane looks there Laird! You've picqued my interest though. What are the two horizontal things on the roll bar? Also, will your panel fit a tip up or does it make no difference. Do you have an alternate design that allows the throttle, mixture, prop to be placed in the center? Mike Nellis RV-6 Wings - Plainfield, IL http://mnellis.jnet.net/rv-6_page ----- Original Message ----- From: "Owens, Laird" <Owens(at)aerovironment.com> "rv-list" Sent: Wednesday, June 14, 2000 6:25 PM Subject: RV-List: Pictures of My RV-6 > > Hi all, > > Since I bored you all with tales of my Setrab oil cooler failure and other such nonsence, I thought I'd share some pictures of my new flying machine. > > It's not quite finished, it still needs the intersection fairings fab'ed, which is why the cowl, gearleg fairings, and wheel pants are not yet painted. I also left the tail fairing unpainted in case I had to change the incidence of the fin or stab. I didn't. > > I'll post some more pictures of some of the special details that might be of interest in the future. > > Please turn you mouse to : > > http://members3.clubphoto.com/laird244198/Laird_RV-6_N515L/ > > Thanks, > > Laird RV-6 > SoCal > PS Hey Gary...How do I get this album tied to the SoCal albums? > > ________________________________________________________________________________
Date: Jun 14, 2000
Subject: Re: Fuse Jig RV-6 Available
Builders, In a couple of weeks I will have an RV-6 Fuse Jig available. I am #4 on this jig. It has been pased on for $100 (covers the cost of the levelers at the 6 supports I'm told) . It was built somewhere in the Carolinas I believe - very true, very straight, and very nicely built. It will break down into 3 sections for easy transport. Call, Fax, or e-mail if interested. David Wentzell , Racine, Wisconsin 262-632-8440 Days; 681-3451 Eves; Fax: 632-8443 Work, 639-9181 Home ________________________________________________________________________________
Subject: wingtip extensions (and anxious to fly)
Date: Jun 14, 2000
Listers, I am planning on doing the wintip lights tomorrow night and am wondering if the wingtip extensions are necessary for night VFR/IFR certification. I have the extensions but honestly, I'm soon ready for inspection and 2-3 nights of fiddling with fiberglass is not my idea of fun. I don't care that much about aesthetics in regard to the lights, but since I'm using the strobe/position/aft facing whelens...is it likely that the inspector could limit me to day VFR because of the prescribed visibility requirements? Anyone have an inspector flag you for this? Bob Japundza ________________________________________________________________________________
Date: Jun 14, 2000
From: Thomas McIntyre <bogeybrother(at)earthlink.net>
Thats only half the story. How much did you start with? Tom John Kitz wrote: > > RobHickman(at)AOL.COM wrote: > > > > > I would encourage everyone to test what the unusable fuel is in the system as > > well as test the actual fuel capacity. > > > > I ran mine dry to check them flying and both took 15.6 to fill in my -4. > John Kitz > N721JK > Ohio > ________________________________________________________________________________
Date: Jun 14, 2000
Subject: deburr shortcut
any thoughts of using scotch brite pads or emory cloth instead of this tedious deburring???? bob in arkansas ________________________________________________________________________________
Date: Jun 14, 2000
Subject: Re: Tilt up canopy problem
This one really strikes home for me. I did a spectacular job of fitting this area and making a good tight joint, only to open the canopy and screw up both the canopy and forward skin. I cut the canopy portion back about 1/8 inch in the center of the plane between the hinges (and tapered a little beyond the hinges to blend in smoothly). Then I filled the gap with an epoxy filler to ramp down to the level of the underside of the canopy skin. At the very sides of the plane the forward skin and the canopy skin fit up with zero gap. On the top of the plane the gap is not too noticable due to the smooth transition of the epoxy filler. You need to be pretty tall to really see this area anyway. This worked great for me. Bob Porter New Orleans Finishing - 6A > problem. When the canopy is tilted up the aluminum skin on the > canopy frame > top interferes with the top forward skin of the fuselage causing it > to "pop" > > > > ________________________________________________________________________________
From: bcbraem(at)home.com.with.ESMTP (InterMail vM.4.01.02.00 201-229-116)
Date: Jun 14, 2000
Subject: Re: wingtip extensions (and anxious to fly)
"Japundza, Bob" wrote: > > > Listers, > > I am planning on doing the wintip lights tomorrow night and am wondering if the wingtip extensions are necessary for night VFR/IFR certification. I have the extensions but honestly, I'm soon ready for inspection and 2-3 nights of fiddling with fiberglass is not my idea of fun. I don't care that much about aesthetics in regard to the lights, but since I'm using the strobe/position/aft facing whelens...is it likely that the inspector could limit me to day VFR because of the prescribed visibility requirements? Anyone have an inspector flag you for this? > > Bob Japundza > > Bob--As long as you meet the visibility degree requirements, your wing tip lights are OK. Do you have the Aircraft Spruce Catalogue?--it shows the proper placement of the three major lighting schemes (as does the FAR/AIM book). As long as your wingtip strobes/position light can be seen from someone at the tail of your plane, you should be fine & dandy. If you don't have the wingtips on and the Inspector questions your lighting position/angles--take the day VFR limit and re-apply when the wingtips are on. The position of the lights is pretty much a no-brainer, if you follow the published diagrams. Boyd. ________________________________________________________________________________
Date: Jun 14, 2000
From: "Richard V. Reynolds" <rvreynolds(at)macs.net>
Subject: Re: Question on gyros...
Bill Ludwig wrote: > > 1) I'm thinking about running only electric gyros - do you think it would > affect resale value considering that an electrical system failure would > leave you gyroless? This will be a night VFR plane. If you follow Bob Nuckolls advice about the main and essential bus, you should not be gyroless because of "one" electic failure source. If you ontinue flying with "one" source, you better have a plan "B". > > 2) Caging during aerobatics - is it necessary? How about an electric gyro > that is turned off? Will it still damage the gyro? Will it flop around > even if it is not powered up? I am installing switches on gyros, but it is to conseve power in the event of "one" electic failure. I don't know about the flop around without power. Richard Reynolds, Norfolk, VA, RV-6A, wiring the panel. ________________________________________________________________________________
Date: Jun 14, 2000
Subject: RV-4 Paint Scheme
Hi gang, There is a good chance that I will purchase a brand new RV-4 to replace my wonderful N8ZZ, which was destroyed on X-mas day last year. The builder, Pete Fountain, has put together a lovely, well thought out piece of machinery. It has been test flown and is ready for the final paint trim. It is currently painted a solid bright, pure yellow. Do any of you have ideas for a final design. Pete is a real good painter, and is willing to try anything. Thanks in advance. Louis Louis I. Willig larywil(at)home.com RV-4, N8ZW in my near future (610) 668-4964 Philadelphia, PA ________________________________________________________________________________
Date: Jun 14, 2000
Bill L. wrote: > 1) I'm thinking about running only electric gyros - do you think it would > affect resale value considering that an electrical system failure would > leave you gyroless? This will be a night VFR plane. Just my opinion, Bill, but I don't think you ought to install gyros if you aren't trained to use them as I assume you aren't since the bird will be a VFR one. Maybe it wouldn't make sense for you but many RV flyers would do well to make their little gems IFR, which will increase their value, and get the rating. It is a struggle to stay current and I personally worry that I am not very sharp with such low IFR experience and this hot dry California WX. The IFR rating does make you a better VFR pilot as far as flying like an airliner goes anyway. The airplanes resale value will not increase if you try to sell it in a month or two and take a real low-ball price. All electric is okay if done right - better than having a system that sucks -- IMHO. Hal Kempthorne RV6a N7HK ________________________________________________________________________________
Date: Jun 14, 2000
Ok Rob We are all wondering......how much was left. I can attest that in my 4 not much fuel is left in the tank when you get that scary silent sound. That tank took almost the listed capacity when I filled it...about half a litre short I think. Joe Hine RV4 C-FYTQ > > I would encourage everyone to test what the unusable fuel is in the system as > well as test the actual fuel capacity. > > On my RV-4 I drained the tanks using the boost pump and then drained the > remaining fuel out of the fuel sump fitting just to see what was left. > > -Rob Hickman > RV-4 N401RH ~45 Hours > ________________________________________________________________________________
Subject: Re: Rudder/Brake Issue
Date: Jun 14, 2000
> As I recall made the bracket arm extention about 3/4" longer. It is a > lot of extra work, but I have no problem in my -6 with the brakes on > takeoff or landing. I seem to recall that switching the rudder pedal weldments fore/aft (if the left rudder pedal is forward per the plans, for example, I put it behind the right one) made it so that at least one of the original side brackets was long enough, making it only necessary to build one longer per side. Alex Peterson 6A ------ http://USFamily.Net/info - Unlimited Internet - $7.99/mo! ------ ________________________________________________________________________________
Date: Jun 14, 2000
I already have a >1/16'' gap between the canopy skin and the top fuselage skin is this not >enough? >Any help or suggestions would be appreciated. >Thanks, >Eli Lewis >Venice, FL >RV-6 > I am assuming you do not have the front skin riveted in place as yet. Mine would catch until I riveted it in place. The gap is about 1/16". Have good one! Denny ________________________________________________________________________________
Date: Jun 14, 2000
"InterMail vM.4.01.02.00 201-229-116" wrote: > > > "Japundza, Bob" wrote: > > > > > > Listers, > > > > I am planning on doing the wintip lights tomorrow night and am wondering if the wingtip extensions are necessary for night VFR/IFR certification. I have the extensions but honestly, I'm soon ready for inspection and 2-3 nights of fiddling with fiberglass is not my idea of fun. I don't care that much about aesthetics in regard to the lights, but since I'm using the strobe/position/aft facing whelens...is it likely that the inspector could limit me to day VFR because of the prescribed visibility requirements? Anyone have an inspector flag you for this? > > > > Bob Japundza > > > > > Bob--As long as you meet the visibility degree requirements, your wing > tip lights are OK. Do you have the Aircraft Spruce Catalogue?--it shows > the proper placement of the three major lighting schemes (as does the > FAR/AIM book). As long as your wingtip strobes/position light can be > seen from someone at the tail of your plane, you should be fine & dandy. > If you don't have the wingtips on and the Inspector questions your > lighting position/angles--take the day VFR limit and re-apply when the > wingtips are on. The position of the lights is pretty much a > no-brainer, if you follow the published diagrams. > > Boyd. The reply to the original post could be confusing to many builders since it didn't address the question. The reason for the extensions is to extend the lights out far enough so they will be visible to an aircraft above you. If the lights are simply mounted to the tips, the curvature of the wingtips will shield the lights from someone flying above you. Now, whether or not a DAR will flag you, I don't know. However, you will have to determine for yourself whether or not you are comfortable with the less than optimum lighting coverage. And, I don't blame you for being anxious to fly! :-) Sam Buchanan "The RV Journal" http://hoem.hiwaay.net/~sbuc/journal ________________________________________________________________________________
Date: Jun 14, 2000
Subject: Looking for accomodations at OSH
Myself and another pilot friend are looking for hotel/motel accomodations starting Thursday July 27th thru Saturday nite July 29th for Oshkosh. Please respond off list if you can assist. -Don RV8 NJ rv8don(at)aol.com ________________________________________________________________________________
Date: Jun 14, 2000
Subject: Re: Looking for accomodations at OSH
In a message dated 6/14/2000 9:03:02 PM Central Daylight Time, Rv8don(at)AOL.COM writes: << Myself and another pilot friend are looking for hotel/motel accomodations starting Thursday July 27th thru Saturday nite July 29th for Oshkosh. Please respond off list if you can assist. >> A freind of mine is looking to rent out part of there house for 2 people, but they are looking for the full week. chris wilcox f1 rocket 000 oshkosh, wi ________________________________________________________________________________
Date: Jun 14, 2000
> >Listers, > >I just recieved a couple of four pin connectors today from ACS - part # >MS3116e8-4S. They came in a plain plastic bag with no instructions as how to >install them. I figured out how they assemble together but have two >questions concerning them. > >1. Are the wires supposed to be soldered to the cupped pins? - they are >way to small for a crimp. The 31xx series connectors are solder >2. Which pins are which? On the back of my RC Allen gyro they call out Pin >A - GND Motor, Pin B - +14 VDC Motor, Pin C- GND Light, Pin D - +14VDC >Light. I have no trouble knowing how to wire in the gyro BUT the position >of the pin labels leaves me confused. This is a rough drawing of what I >mean - > D > o o ------pins (4) > B 1A C > o o > >Can any one tell me what the pin labels are supposed to be? The way the >labeling is I can see two choices for B,D, & C and four choiced for A. Looking into the FEMALE pins connector with the widest keyway tab pointed UP, the "A" pin is in the upper right corner, "B" is lower right, "C" is lower left and "D" is upper left. Looking into the MALE pins connector the image is reversed with "A" starting in upper left corner. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 14, 2000
Subject: Re: Coroplast
Doug Thanks for the tip. Have you done any tests for fire resistance with this material? Does it create a lot of smoke when burned? Charlie Kuss RV-8 fuel tanks almost done with the ProSeal Boca Raton, Fl. > Fellow Listers: > > Just thought I'd mention the use of a product that is great for side > upholstery panels in RVs (or any aircraft for that matter). I have mounted > my side upholstery fabric (from DJ) on 4mm thick polyboard that goes by the > trade name of Coroplast. It is used in the sign making industry and it's > construction is just like corrugated cardboard except it is made from > polypropylene plastic. > > It is lightweight and be cut with scissors or an Exacto knife. I attached > the sidewall fabric to it with spray adhesive and it is held in place on the > fuselage cabin wall with double face carpet tape. Artex Products carries it > (the upholstery people that advertise in T-A-P or this supply house carries > it ( http://www.southlandsignsupplies.com/catalog/ca20.htm). About $10 for > a 4' x 8' piece. ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Date: Jun 14, 2000
-----Original Message----- From: Mark Steffensen <steffco1(at)home.com> <randy@rv-8.com> Date: Wednesday, June 14, 2000 3:59 PM Subject: Re: RV-List: Re: [rv8list] New Vans Service Letter - addendum > > >I also thought you might be able to determine if the fuel pick-up tube is in >the proper position by inserting a small wire into the tank drain, (take the >drain out first) & feel if the tube is in the correct position. My wings are >on, tanks sealed etc. & I don't want to take the tank covers off. >Mark Steffensen >8A Dallas, TX When installing the pickup tubes, the following will make for a safer installation -- at least on a 6/6A: The tubes should be routed so that the finger screen ends lie against the bottom of the tank with ends centered over the drain holes. Then at each condition inspection or more frequently as desired, the drains can be removed when the tanks are low. You then peer into the drain hole and ensure that 1) the pickup tubes are in their lowest position, and 2) the finger screens are not clogged. Dennis Persyk 6A finishing kit Hampshire, IL C38 ________________________________________________________________________________
Date: Jun 14, 2000
-----Original Message----- From: Japundza, Bob <bjapundza(at)dowagro.com> Date: Wednesday, June 14, 2000 7:27 PM Subject: RV-List: wingtip extensions (and anxious to fly) > >Listers, > >I am planning on doing the wintip lights tomorrow night and am wondering if the wingtip extensions are necessary for night VFR/IFR certification. I have the extensions but honestly, I'm soon ready for inspection and 2-3 nights of fiddling with fiberglass is not my idea of fun. I don't care that much about aesthetics in regard to the lights, but since I'm using the strobe/position/aft facing whelens...is it likely that the inspector could limit me to day VFR because of the prescribed visibility requirements? Anyone have an inspector flag you for this? > >Bob Japundza > The inspector will probably miss it. Traffic will also miss seeing the strobes as they really have a greatly reduced solid angle of visibility if mounted directly to the wingtips. Dennis Persyk 6A finishing kit Hampshire, IL C38 ________________________________________________________________________________
Date: Jun 14, 2000
-----Original Message----- From: David Wentzell <wntzl(at)execpc.com> Date: Wednesday, June 14, 2000 6:48 PM Subject: Re: RV-List: Re: Fuse Jig RV-6 Available > > >Builders, >In a couple of weeks I will have an RV-6 Fuse Jig available. I am #4 on this jig. It >has been pased on for $100 (covers the cost of the levelers at the 6 supports I'm told) >. It was built somewhere in the Carolinas I believe - very true, very straight, and >very nicely built. It will break down into 3 sections for easy transport. > Call, Fax, or e-mail if interested. > David Wentzell , Racine, Wisconsin > 262-632-8440 Days; 681-3451 Eves; Fax: 632-8443 Work, 639-9181 Home > Hey, that's my old jig! It was built by a cabinet maker in Martinsburg, WV., as a matter of fact! I added the precision leveling feet and got the thing level at the six leveling stations to 0.020" with a transit. Great jig! Dennis Persyk 6A finishing kit -- done with jigs for ever, I hope! Hampshire, IL ________________________________________________________________________________
Date: Jun 14, 2000
Bob, The answer you want can be found in FAR 21.1387 thru 21.1401. That is the standard that all Inspectors will/should use to determine the lights position. More to your point is that the position lights must be visible from both the top and bottom as well as straight ahead of the aircraft to 110 degress left or right from the nose. the tai llight must be visible both up and down as well s 70 degrees left and right of the tail. And the Anti-collison light/strobe must "illuminate the vital areas around the plane." Taking all that mumbo jumbo into a compact ball of info, it means that you should plan on installing the wingtip extensions. Mike Robertson RV-8A 95% done and forever to get the rest done >From: "Japundza, Bob" <bjapundza(at)dowagro.com> >Reply-To: rv-list(at)matronics.com >To: "'rv-list(at)matronics.com'" >Subject: RV-List: wingtip extensions (and anxious to fly) >Date: Wed, 14 Jun 2000 17:33:53 -0400 > > >Listers, > >I am planning on doing the wintip lights tomorrow night and am wondering if >the wingtip extensions are necessary for night VFR/IFR certification. I >have the extensions but honestly, I'm soon ready for inspection and 2-3 >nights of fiddling with fiberglass is not my idea of fun. I don't care >that much about aesthetics in regard to the lights, but since I'm using the >strobe/position/aft facing whelens...is it likely that the inspector could >limit me to day VFR because of the prescribed visibility requirements? >Anyone have an inspector flag you for this? > >Bob Japundza > > ________________________________________________________________________________
Date: Jun 15, 2000
Doug, just curious if you have tried a flammability test on this material. I have an acquaintance who was going to use a foil-backed insulation board in his 6 until we tried a flame test on it. The fire it supported was impressive to say the least, and of course he did not use the material. Andy Johnson Fellow Listers: Just thought I'd mention the use of a product that is great for side upholstery panels in RVs (or any aircraft for that matter). I have mounted my side upholstery fabric (from DJ) on 4mm thick polyboard that goes by the trade name of Coroplast. ________________________________________________________________________________
Subject: Re: Tip=up rollbar color
Date: Jun 14, 2000
> My roll bar takes a lot of punishment from the canopy handle resting on > it to hold the canopy open for ventilation during taxi...don't think > powder coating would withstand the punishment much better than my spray > can paint... > > Will Cretsinger, Arlington, Texas > -6A flying through 210 hours Will, I cut some UHMW tape carefully onto the small surface of the canopy handle. Metal doesn't touch metal anymore. Not flying yet but playing with this in the shop...........Norman........ ________________________________________________________________________________
Date: Jun 14, 2000
From: "Derrick L. Aubuchon" <n184da(at)pacbell.net>
I tested my RV-4 before the first flight, in level flight attitude,, and I think I am overestimating when I say I had 1/2 cup remaining. > >RobHickman(at)AOL.COM wrote: > > > > > I would encourage everyone to test what the unusable fuel is in >the system as > > well as test the actual fuel capacity. > > > >I ran mine dry to check them flying and both took 15.6 to fill in my -4. >John Kitz >N721JK >Ohio Derrick L. Aubuchon RV-4 N184DA n184da(at)pacbell.net ________________________________________________________________________________
Date: Jun 14, 2000
> > Cotton Fiber is mixed with the epoxy to make structural fillets or fill > > gaps where strength is needed. It works very much like chopped glass > > fibers without the problems fibers cause in handling. (getting into > > skin, etc.) Much safer. > > > > I cannot imagine anyplace you would use it on an aluminum airplane. > > When hard it is extremely difficult to sand. Right up their with high > > density filler. I used milled glass to build up edges of the cowl slightly (less than 1/16") where I sanded the gap too big. Feel comfortable that the filler for this small amount makes for a good bond. Microballons wouldn't cut it there. Randall Henderson, RV-6 N6R (~100 hrs) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
Date: Jun 14, 2000
Thanks to all the replies. Your help is greatly appreciated. Now off I go to begin soldering. Wiring sure is fun. I just love seing each new item come 'alive'. Thanks again,----------------------------------------------------- Doug Murray RV-6 C-GRPA Southern Alberta ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com> Sent: Wednesday, June 14, 2000 8:10 PM Subject: Re: RV-List: Wiring Confusion - Electric Gyros > > > > >Listers, > > > >I just recieved a couple of four pin connectors today from ACS - part # > >MS3116e8-4S. They came in a plain plastic bag with no instructions as how to > >install them. I figured out how they assemble together but have two > >questions concerning them. > > > >1. Are the wires supposed to be soldered to the cupped pins? - they are > >way to small for a crimp. > > The 31xx series connectors are solder > > >2. Which pins are which? On the back of my RC Allen gyro they call out Pin > >A - GND Motor, Pin B - +14 VDC Motor, Pin C- GND Light, Pin D - +14VDC > >Light. I have no trouble knowing how to wire in the gyro BUT the position > >of the pin labels leaves me confused. This is a rough drawing of what I > >mean - > > > > D > > o o ------pins (4) > > B 1A C > > o o > > > >Can any one tell me what the pin labels are supposed to be? The way the > >labeling is I can see two choices for B,D, & C and four choiced for A. > > Looking into the FEMALE pins connector with the widest keyway > tab pointed UP, the "A" pin is in the upper right corner, "B" is > lower right, "C" is lower left and "D" is upper left. > > Looking into the MALE pins connector the image is reversed > with "A" starting in upper left corner. > > > Bob . . . > -------------------------------------------- > ( Knowing about a thing is different than ) > ( understanding it. One can know a lot ) > ( and still understand nothing. ) > ( C.F. Kettering ) > -------------------------------------------- > http://www.aeroelectric.com > > ________________________________________________________________________________
Date: Jun 15, 2000
Date: Jun 15, 2000
Date: Jun 15, 2000
Might I add that polypropylene is highly flammable normally. Bill Jaugilas Doug Weiler wrote: > > Fellow Listers: > > Just thought I'd mention the use of a product that is great for side > upholstery panels in RVs (or any aircraft for that matter). I have mounted > my side upholstery fabric (from DJ) on 4mm thick polyboard that goes by the > trade name of Coroplast. It is used in the sign making industry and it's > construction is just like corrugated cardboard except it is made from > polypropylene plastic. > > It is lightweight and be cut with scissors or an Exacto knife. I attached > the sidewall fabric to it with spray adhesive and it is held in place on the > fuselage cabin wall with double face carpet tape. Artex Products carries it > (the upholstery people that advertise in T-A-P or this supply house carries > it ( http://www.southlandsignsupplies.com/catalog/ca20.htm). About $10 for > a 4' x 8' piece. > > Doug > > =========== > > Doug Weiler > Hudson, WI > 715-386-1239 > dougweil(at)pressenter.com > ________________________________________________________________________________
Date: Jun 15, 2000
Hi Mike and others, Thanks to all for the compliments on my airplane. I appreciate it very much. Mike asked about the things on the roll bar in the picture. Those are hand hold grips. They are tucked up as close to the slider frame as possible, to avoid any possible head strikes in case of sudden stoppage. I'd highly recommend installing them. It provides a very natural place to grab when getting in and out, particularly on a tail wheel airplane. They are make from 1/4" dia steel tubing (about .050 wall). I stole the idea for someone in the RVator. As far as the panel, I haven't yet done the detail work for a tip up canopy. I'll do that after Arlington. I think it'll have to mount just a little lower that the slider version, but not by much. I'll have to work out the supports that attach it to the subpanel as well. I'm looking for someone here in the SoCal area who is at that stage in the fuse construction so I could trial fit one. (any volunteers?) The throttle and mixture can be mounted in the stock vertical console or in a angle mount below the panel like most people do. That would open up more room for switchs where I put my throttle. I gotta say, I love the throttle over there, and flying with my right hand. Laird RV-6 (did my series of spins,loops and rolls last night, I'm still dizzy) SoCal (19.8 hrs) From: rv-list(at)matronics.com on Wed, Jun 14, 2000 4:58 PM Plane looks there Laird! You've picqued my interest though. What are the two horizontal things on the roll bar? Also, will your panel fit a tip up or does it make no difference. Do you have an alternate design that allows the throttle, mixture, prop to be placed in the center? Mike Nellis RV-6 Wings - Plainfield, IL http://mnellis.jnet.net/rv-6_page ________________________________________________________________________________
Date: Jun 15, 2000
Date: Jun 15, 2000
> > Doug, just curious if you have tried a flammability test on this material. > I > > have an acquaintance who was going to use a foil-backed insulation board > in > > his 6 until we tried a flame test on it. The fire it supported was > impressive > > to say the least, and of course he did not use the material. Andy Johnson Gee, folks, maybe this wasn't such a great idea after all. This material does burn although the fabric that I am attaching it to does not. It is interesting in that Artex Products uses this material as mounting panels for their upholstery kits for certified aircraft. Hmmm??? Anyway I guess to be 100% safe, one might consider treating this material with a fire blocker. ACS sell one on page 284 of their catalog. Doug ________________________________________________________________________________
Date: Jun 15, 2000
Subject: RV spins & acro
Date: Jun 15, 2000
I didn't find exactly what I was looking for in the archives. I've been told by a few IAC email list people that they have been to contests where RV6s have competed (as well as 4s) and done well. Though no one has offered up a name yet. Ok, fess up. Whose doing Sportsman and Intermediate in a RV6? :-) I want to talk to them! I'd like help separating fact from 2nd hand or worse info. The archives are full of advise not to spin a RV. Now does anyone have Pitts time and RV time and spun both? If so, care to comment on how the RV does in comparison? Do different RV design spin significantly differently? A big name on the IAC and airshow circuit recently told me that it would be tantamount to stupid to compete with an RV6 and they are looked down upon overall by the IAC community because they are not the greatest (read safe) in spins and pick up speed very quickly (they did say they thought they were a great plane for tooling around in and going somewhere fast). Not that they confesses to every flying a RV themselves... The fact that people are doing it means it can be done. No one has crashed yet despite multiple competitive flights. Meaning it can be done repeatedly safely. Some RVs even win regional meets. They can be competitive at the lower levels. All levels have spins as a required maneuver. So what gives? lucky ________________________________________________________________________________
From: Bob DiMeo - Oracle <dimeob(at)powertel.com.au>
Subject: Coroplast
Date: Jun 16, 2000
Guys, I think you really needs to think about issues of flammability and toxic gases with respect to interior fabrics, cushions and mountings. I've done a couple of interiors now for my own airplanes and I believe the only way to protect yourself as much as possible is to use mounting systems and fabrics that have gone through the same approval process as those used in certified aircraft. I had to do this with a glare shield that was not approved for my Comanche. It cost me $100 for the test but that was the only way our FSDO was going to let me put the thing in after I'd purchased it. It proved that the shield would put itself out when a flame was removed and it emitted no toxic fumes. After the 'ouch' for the bill, I admit I did feel better about the safety of the installation. The best backing for fabric in my opinion is aluminum. It's the backing use by Piper for the interiors I've done. The best fabric is FAA approved, wherever you get it from. If I remember right, the FAA even approves the glue that holds the Fabric to the aluminum. As for the cushions, I can't say as I've used the ones that were in the plane already. Bob Rv8 #423 > ---------- > From: jaugilas > Sent: Thursday, June 15, 2000 06:42 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Coroplast > > > Might I add that polypropylene is highly flammable normally. > > Bill Jaugilas > > > Doug Weiler wrote: > > > > > Fellow Listers: > > > > Just thought I'd mention the use of a product that is great for side > > upholstery panels in RVs (or any aircraft for that matter). I have > mounted > > my side upholstery fabric (from DJ) on 4mm thick polyboard that goes by > the > > trade name of Coroplast. It is used in the sign making industry and > it's > > construction is just like corrugated cardboard except it is made from > > polypropylene plastic. > > > > It is lightweight and be cut with scissors or an Exacto knife. I > attached > > the sidewall fabric to it with spray adhesive and it is held in place on > the > > fuselage cabin wall with double face carpet tape. Artex Products > carries it > > (the upholstery people that advertise in T-A-P or this supply house > carries > > it ( http://www.southlandsignsupplies.com/catalog/ca20.htm). About $10 > for > > a 4' x 8' piece. > > > > Doug > > > > =========== > > > > Doug Weiler > > Hudson, WI > > 715-386-1239 > > dougweil(at)pressenter.com > > > > > > > ________________________________________________________________________________
Date: Jun 15, 2000
Date: Jun 15, 2000
Date: Jun 15, 2000
Date: Jun 15, 2000
Date: Jun 15, 2000
Subject: Wing wiring?Front or back of spare?
I was wondering if anyone has had any problems with the 5/8 conduit run in front of the main spare. Running the conduit under the tank and between the leading edge ribs doesn't seem like a problem. A little offset in the conduit between the tank and rib 71.5 but not enough to make pulling the wires throw Difficult. My problem lies with when the conduit enters the fuselage, what problem might I encounter with the conduit in front of the spare. My other? Is. Is it that had to get the wiring throw or over the main spare with the conduit behind the rear spare. Thanks Bill H. Pembroke Ma. ________________________________________________________________________________
Date: Jun 15, 2000
Date: Jun 15, 2000
Subject: Re: RV6 2 FATAL
SADNESS http://www.idahostatesman.com/news/daily/20000615/LocalNews/15319.shtml ________________________________________________________________________________
Date: Jun 15, 2000
Subject: where everyone at
test message is anyone out there today? ==== Glenn Williams 8A A&P Yahoo! Photos -- now, 100 FREE prints! http://photos.yahoo.com ________________________________________________________________________________
Date: Jun 16, 2000
From: "Ray Richardson Jr." <sales(at)powersportaviation.com>
Subject: 215 hp Powersport RV6A update
Dear RV'ers We at Powersport want you to know we have completed our propeller testing, including a 200 hp Hartzel constant speed, on our 215 Hp rotary engine and have posted the results on our web site. The new MT 3 blade has not arrived yet. Wisconsin governor Tommy Thompson toured Powersport on May 26 and enjoyed seeing our refinements to our engines and panel displays. He also came to see Ratech's machine shop featuring one of the largest CNC milling machines in the midwest. Powersport will be having a open house and hosting EAA chapter 1229 on Monday June 19 at 7:00 PM and all interested are invited to attend. We will be demonstrating engine running displays on our test stand and showing our almost completed RV6A. We are located at Osceola Wisconsin, east end of the airport OEO. Check out our web site at www.powersportaviation.com and click through the April, May and June updates. We hope to see some of you there. Ray Richardson ________________________________________________________________________________
Date: Jun 15, 2000
> > Doug, just curious if you have tried a flammability test on this material. I > have an acquaintance who was going to use a foil-backed insulation board in > his 6 until we tried a flame test on it. The fire it supported was impressive > to say the least, and of course he did not use the material. Andy Johnson Gee, folks, maybe this wasn't such a great idea after all. This material does burn although the fabric that I am attaching it to does not. It is interesting in that Artex Products uses this material as mounting panels for their upholstery kits for certified aircraft. Hmmm??? Anyway I guess to be 100% safe, one might consider treating this material with a fire blocker. ACS sell one on page 284 of their catalog. Doug ________________________________________________________________________________
Date: Jun 15, 2000
Subject: Re: Wing wiring?Front or back of spare?
In a message dated 6/15/00 7:46:58 PM Eastern Daylight Time, BillyRV6(at)AOL.COM writes: << I was wondering if anyone has had any problems with the 5/8 conduit run in front of the main spare. Running the conduit under the tank and between the leading edge ribs doesn't seem like a problem. >> Once upon a time in RV-list history, there was a bit of a holy war over the issue of running wiring in front of, or behind the spar. I let myself be convinced that you don't want wiring right up against the fuel tank, therefore you should run the wires behind the spar. If I had it to do over again, I would definately do it the other way, and run the wires between the tank and spar. This would make wiring runs much easier. Kyle Boatright RV-6. Fired up the electrical system for the first time today. No smoke, only 1 item inop... ________________________________________________________________________________
Date: Jun 15, 2000
Airtex may use a similar product. Many times the plastic formulation can be changed for fire proofing. I doubt it can be done to the plastic after the fact. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) ----- Original Message ----- From: "Doug Weiler" <dougweil(at)pressenter.com> Sent: Thursday, June 15, 2000 1:05 PM Subject: Re: RV-List: Coroplast > > > > > Doug, just curious if you have tried a flammability test on this material. > I > > have an acquaintance who was going to use a foil-backed insulation board > in > > his 6 until we tried a flame test on it. The fire it supported was > impressive > > to say the least, and of course he did not use the material. Andy Johnson > > Gee, folks, maybe this wasn't such a great idea after all. This material > does burn although the fabric that I am attaching it to does not. It is > interesting in that Artex Products uses this material as mounting panels for > their upholstery kits for certified aircraft. Hmmm??? > > Anyway I guess to be 100% safe, one might consider treating this material > with a fire blocker. ACS sell one on page 284 of their catalog. > > Doug > > ________________________________________________________________________________
Date: Jun 15, 2000
> The tubes should be routed so that the finger screen ends lie against the > bottom of the tank with ends centered over the drain holes. This sounds like a sure-fire way to assure that the pickup tube will be low enpough in the tank to suck up any water or debris that didn't _quite_ make it out the sump drain on pre-flight. Am I missing something? I purposely left my pickup just a bit higher so as to leave any retained water behind in the low spot. Thoughts? Bill B ________________________________________________________________________________
Date: Jun 15, 2000
Subject: Re: Spinning an RV-6
> >Hi Boyd and other, > >Let me start out by saying I'm not an expert in spins. I'll relay >what I did and what I observed. This is just my opinion, and my >observation my be different then someone else in the same seat. >With that said.... > >I've been flying a Citabria and a Decathlon the last 2 year getting >ready for flying my RV-6, but I only got in about 25 hrs total in >the 2 year, just barely enough to stay current. I made a point to >go out and spin the airplane every time I went out. I also got some >acro training in the months before I went up to fly with Mike >Seager. On the second day of flying with Mike, I had him demo >spins, just so I could see what everybody was afraid of. We let the >nose come down thru the horizon before we applied rudder. We didn't >let them develop more that one turn, so it really never had a chance >to get a chance to see the full spin rate. > >Last night I took out my RV to do the acro series in it so I can >make the log entries as to what I can do later (without having to >put it back into the test phase). I donned my parachute (which is >uncomfortable as sitting on a rock) and started with stalls, power >on, and power off, and then did 1/2 spin each way, then 1 turn, and >then 2 turns each way. I was at arco weight of 1375, and all were >power off, ailerons neutral. They seemed a little fast, but nothing >unnerving (again, my opinion). Recovery was always within a 1/2 >turn, and I only bounced my head off the canopy once while applying >a little down elevator. I didn't feel anything dangerous was about >to happen. About the only thing that caught my attention was a big >shudder of the airplane as it was just starting to rotate. > >Satisfied that it didn't have any real nasty habits at that weight, >I proceeded on to left and right rolls, giggling every time. Then >on to loops, boy those are fun....Ok now a loop, and a roll on the >pullout, WHOPPEEEE!!!!! 2 of those then I realized that I was >getting a funny taste in my mouth.....OK, let's fly straight and >level for a while. I'll have to work on that G tolerance :-) > >So...I didn't find anything strange about spinning the RV, but I >only scratched the surface of the envelope there. That's about all >I can relate right now. > >Happy revolutions, > Laird, Just for curiosity, where do you figure your CG was when you were doing the spins? Spin characteristics, and spin recovery can be significantly affected by CG, with aft CG being the worst case. Our aircraft are hand built, and spin characteristics will be greatly affected by the differences between the right and left wing, so other aircraft may have different spin characteristics than yours. Thanks for posting your results. I quoted your whole message so that it will get in the archive. Congratulations on getting flying. Keep us posted on your flight test results. Take care, Kevin Horton RV-8 (cockpit stuff) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
Date: Jun 15, 2000
> Airtex may use a similar product. Many times the plastic formulation can be > changed for fire proofing. I doubt it can be done to the plastic after the > fact. > The corrugated plastic I plan to use actually came from Airtex, along with the upholstery cloth. Been flying two years now and I _might_ get around to installing the interior this summer! Bill B ________________________________________________________________________________
Date: Jun 15, 2000
Kyle: I am one of those guys from RV history who ran the wires behind the tank next to the spar. My QB 6A did not have the holes for the conduit to go behind the spar, so I ran just like I did in my last RV6 through a conduit attached to the spar just like you did the pitot tube. It works a lot better and you have a more direct route to the instrument panel. This is my idea only. Harvey Sigmon - RV6AQB N602 engine stuff. ----- Original Message ----- From: <KBoatri144(at)AOL.COM> Sent: Thursday, June 15, 2000 8:09 PM Subject: Re: RV-List: Wing wiring?Front or back of spare? > > In a message dated 6/15/00 7:46:58 PM Eastern Daylight Time, BillyRV6(at)AOL.COM > writes: > > << I was wondering if anyone has had any problems with the 5/8 conduit run in > front of the main spare. Running the conduit under the tank and between the > leading edge ribs doesn't seem like a problem. >> > > Once upon a time in RV-list history, there was a bit of a holy war over the > issue of running wiring in front of, or behind the spar. I let myself be > convinced that you don't want wiring right up against the fuel tank, > therefore you should run the wires behind the spar. If I had it to do over > again, I would definately do it the other way, and run the wires between the > tank and spar. This would make wiring runs much easier. > > Kyle Boatright > > RV-6. > Fired up the electrical system for the first time today. > No smoke, only 1 item inop... > > ________________________________________________________________________________
Subject: Re: RV-4 Paint Scheme
Date: Jun 15, 2000
Louis Glad to see you are getting another 4...I like the choice of Yellow the trim will have to be what you like best. I have the accent stripes on the side of mine with the rudder and fin to match. I have angles stripes on the wings which IMHO look good as well. Joe Hine RV4 C-FYTQ > Hi gang, > > There is a good chance that I will purchase a brand new RV-4 to replace my > wonderful N8ZZ, which was destroyed on X-mas day last year. The builder, > Pete Fountain, has put together a lovely, well thought out piece of > machinery. It has been test flown and is ready for the final paint trim. It > is currently painted a solid bright, pure yellow. Do any of you have ideas > for a final design. Pete is a real good painter, and is willing to try > anything. Thanks in advance. > > Louis > > > Louis I. Willig > larywil(at)home.com > RV-4, N8ZW in my near future > (610) 668-4964 > Philadelphia, PA ________________________________________________________________________________
Date: Jun 16, 2000
BillyRV6(at)AOL.COM wrote: > > > I was wondering if anyone has had any problems with the 5/8 conduit run in > front of the main spare. Running the conduit under the tank and between the > leading edge ribs doesn't seem like a problem. A little offset in the conduit > between the tank and rib 71.5 but not enough to make pulling the wires throw > Difficult. > > My problem lies with when the conduit enters the fuselage, what problem might > I encounter with the conduit in front of the spare. I've put conduit in the LE ribs. It is a fairly tight turn for the conduit (I used electrical PVC -- had to dip the end in boiling water to get it bent) at the inboard end of the LE... If I was doing it again, I'd think about putting the conduit diagonally through the LE, coming out near the LE at the outboard end. I don't think you need conduit between the tank and main spar... just attach the wires to the spar with clips of some sort. That way, you'll have plenty of flexibility when it comes to bringing the wires into the fuselage. Caveat: I haven't actually put the wires in yet... still figuring things out as I build the fuselage. > My other? Is. Is it that had to get the wiring throw or over the main spare > with the conduit behind the rear spare. Over the spar would be hard to do tidily. Through the spar, you would have to put the wires through near the centreline. And you would have to route and attach the wires with extra care there... the control columns and so on move in the area aft of the spar. Frank. ________________________________________________________________________________
Date: Jun 15, 2000
Subject: Spinning an RV-6
Kevin asked: Laird, Just for curiosity, where do you figure your CG was when you were doing the spins? -- The CG was 72.6 (range 68.7-76.8) at the time of the spin testing. -- Congratulations on getting flying. Keep us posted on your flight test results. -- Thanks Kevin, I appreciate it, and even though I'll be done with my 25 hours this week, I still have a lot of data to collect. I need to get some more instrumation on board and complete my intersection fairings before I can get any real good data. But I figure I have years to learn this little airplane. It has a lot to teach me. Laird RV-6 (now I just have to figure out where to put that alpha/beta vane) SoCal -- Take care, Kevin Horton RV-8 (cockpit stuff) ________________________________________________________________________________
From: "Paul & Gerti RV-4 F-1 Rocket 006" <gertivs(at)netzero.net>
Subject: Re: RV spins & acro
Date: Jun 15, 2000
> I've been told by a few IAC email list people that they have been to > contests where RV6s have competed (as well as 4s) and done well. Though no > one has offered up a name yet. Ok, fess up. Whose doing Sportsman and > Intermediate in a RV6? :-) I want to talk to them! I once thought I would like to try and compete. Like you I thought I would ask around first. At the semi-local IAC chapter in Delano, CA everyone told me to contact Ralph Riddel as the RV-4 expert in competition. Both he and his son have competed in the -4 and won. Ralph is also the primary acro instructor at Sean Tucker's School of Aerobatics in Salinas, Calif. He is good and knows his stuff. You can reach him through the school or his IAC chapter. I later took a lesson from Ralph in a IO-540 Pitts 2-B. The Pitts' handling blew me away. That was the end of any real hope of competion. Me and my -4 are hot heavy and ready to go but could NOT be competitive against the Pitts and someone who knows how to make her dance. Paul Vander Schuur ________________________________________________________________________________
Subject: Flame Block Spray
Date: Jun 15, 2000
> > Anyway I guess to be 100% safe, one might consider treating this material > > fire blocker. ACS sell one on page 284 of their catalog. Every builder should have a look at this stuff. Aircraft Spruce catalog page 284. Thanks to Doug for pointing it out. It's comes in a spray bottle. Too easy. If you're looking for a foam to put on your side walls goto page 39 of the same catalog and have a look at Temperfoam. You can see from it's price that it is supposed to be special. I'm still looking for a suitable glue to glue the fabric onto primered aluminum. What have people been using? Norman Hunger RV6A Delta BC ________________________________________________________________________________
Date: Jun 15, 2000
Subject: Gyros as safety equipment
Somebody wrote: > Just my opinion... but I don't think you ought to install gyros if you > aren't trained to use them Ouch!! Part of the private pilot curriculum for years has been to demonstrate fundamental maneuvers by reference to instruments. This is not to promote ad hoc IFR flying, but to give pilots an out in case they get into a cloud inadvertently. I can tell you from experience, that it's real easy to get into a cloud inadvertently. Those gyros are your life preserver!! Personally, I think that folks should give preference to installing an attitude indicator over a turn coordinator, because the attitude indicator is much easier to fly than the combination of turn coordinator plus airspeed and altitude. (Turn and slip, with the vertical needle, is harder yet to fly than a turn coordinator -- there's really no excuse for putting one in.) Should you install safety equipment in your RV? Hell, yes! Electric for night VFR? Let's look at the risks -- Night VFR can turn into IFR very quickly flying over clouds, into clouds inadvertently, or when over sparse areas with few light. Are electric gyros okay for that? Sure. The risk is that you lose your electrical system while in the clouds, or when unable to find an airport, or when unable to maintain VFR to the destination. It's not like you're planning to fly forever at night on instruments. The risk is a bit higher than having gyros from two power sources (electric and vacuum) but not extravagantly higher, IMHO. Personally, I'd be content with an electric attitude indicator for night flight. I would *not* install all electric gyros if I were installing all three. Vacuum systems aren't that big a deal (my RV-4 has one), put there's a popular mythology the the very expensive electric gyros are somehow better than vacuum. From what my overhaul shop told me, you do *not* want to turn your gyros off when doing aerobatics -- it's less wearing on the bearings to let 'em spin. Consider the risks and the mission, both for you and any possible subsequent buyer, and good luck!! Ed Wischmeyer CFII/RV-4 -- NOTE: 5% of messages sent to me don't make it, so use a return receipt to insure delivery. The phone company system drops packets. - - - - - - - - Ed Wischmeyer Web page: http://members.aa.net/~edwisch Email: edwisch(at)aa.net ________________________________________________________________________________
Subject: Strobe Light Power Supply Kit
Date: Jun 15, 2000
I'm looking in the new MCM Electronics printed catalog on page 115. Part # 80-735 is a Strobe Circuit Kit for $12.75 They show a picture of an empty circuit board and a bunch of small parts, no enclosure. You have to solder it together. I'll quote from the catalog: "Can be used as emergency warning light on autos, radio tower or anywhere a strobe light is needed. Variable flash rate. Dimensions 3 1/2" X 1 3/4" Operates on 6/12 VDC." Does any one know any thing about this? Could it be suitable for us? More info or to order your own free catalog of tons of interesting stuff: www.mcmelectronics.com Regards, Norman Hunger RV6A Delta BC ________________________________________________________________________________
Date: Jun 16, 2000
Norm, The planes I've done have had unprimed aluminum sheets for backing the fabric on the side panels. My Comanche is 40 years old and the unprimed aluminum looked good as new. I would gauge the thickness at maybe .016. I never though to measure it, though. The fabric was glued to the sheet and folded over the edges by about two inches and glued. The panels were either clipped in or screwed into the bulkheads in the Cabin interior. Looks great, lasts a long time. The glue that I used was from 3M and it's a high tack glue, it came in a black spray can. I can't get to the can as I'm 12,000 miles away right now but I would bet that it would stick to anything, including primed aluminum. Bob RV8 #423 > ---------- > From: Norman Hunger > Sent: Friday, June 16, 2000 01:54 AM > To: rv-list(at)matronics.com > Subject: RV-List: Flame Block Spray > > > > > > Anyway I guess to be 100% safe, one might consider treating this > material > > > fire blocker. ACS sell one on page 284 of their catalog. > > Every builder should have a look at this stuff. Aircraft Spruce catalog > page > 284. Thanks to Doug for pointing it out. It's comes in a spray bottle. Too > easy. > > If you're looking for a foam to put on your side walls goto page 39 of the > same catalog and have a look at Temperfoam. You can see from it's price > that > it is supposed to be special. > > I'm still looking for a suitable glue to glue the fabric onto primered > aluminum. What have people been using? > > Norman Hunger > RV6A Delta BC > > > > > ________________________________________________________________________________
Date: Jun 15, 2000
Subject: Skymap IIIC GPS - RS232 Interface to the Notepad...
Hi Listers, For those of you that have had the pleasure of flying with the King (formally Skyforce) Skymap IIIC, you may or may not have noticed there is a nifty "Notepad" feature that allows you to upload roughly 4400 ASCII characters to the IIIC and then page through them. This is handy for something like an "online" check list or directions to the nearest airport with a hamburger joint. In any case, apparently there is a piece of software called Flight Manager Version 3.00 the you can buy for $229 (gulp) that will allow you to upload whatever text you may want to this special Notepad on the IIIC. Realizing that uploading ASCII text to this baby is a pretty trivial task and being a fair programmer, it hit me that I should spend a few hours away from building my plane and come up with a piece of software that might do the same. So here's my question. Does anyone have the technical spec. on how to communicate with the IIIC over the RS232 to manipulate the Notepad data space? There doesn't appear to be a "special" I/O menu for enabling this type of connectivity. I connected up a terminal to the IIIC and banged on it with few typical things, but nothing seemed obvious. Has anyone reverse engineered the Flight Manager code to see what it sends and receives on the RS232 port? Has anyone even used this Flight Manager software? Surfing around on the Bendix/King website, I was really disappointed in the documentation available on the IIIC there. Very pathetic, actually. I couldn't locate any information on the Flight Manager software, nor could I even find any data on available accessories for the IIIC. I did note that I can order a IIIC online direct from Bendix/King and pay full List price. What a deal. I wish they had bagged the online ordering development and focused on something useful - like some documentation... Sheeze. It appears that the old Skyforce website from the UK has been completely decommissioned - at least *their* site used to have a bit of useful information. Anyway, thanks for any information you might have on the aforementioned requirement. Best regards, Matt Dralle RV-4 Builder -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft Great minds discuss ideas, Average minds discuss events, Small minds discuss people... ________________________________________________________________________________
(Content Technologies SMTPRS 2.0.15) with SMTP id for" ; Fri, 16 Jun 2000 07:46:58.-0400(at)matronics.com
Date: Jun 16, 2000
"Doug Weiler" on 06/15/2000 06:41:14 PM Please respond to rv-list(at)matronics.com Subject: Re: RV-List: Coroplast I guess their thoughts are, if the flames get to the side panels the point is mute. You've long since asphyxiated or jumped out. The guy that does all the wiring for Velocity in Vero Beach did a nice presentation at our EAA meeting. He held up a small handfull (six one foot strands) of teflon coated wiring and said if this burns, you will be completely incapacitated before the flame exposes the wire. I would worry more about the wiring. > > It is interesting in that Artex Products uses this material as mounting panels for their upholstery kits for certified aircraft. Hmmm??? ________________________________________________________________________________
From: "Nancy and Walter Shipley" <wshipley(at)esper.com>
Subject: Re: where everyone at
Date: Jun 16, 2000
Yeah, we're still here, Glenn. Say hi to the Orndorff's. Walt Shipley ---------- > From: glenn williams <willig10(at)yahoo.com> > To: rv-list(at)matronics.com > Subject: RV-List: where everyone at > Date: Thursday, June 15, 2000 4:44 PM > > > test message is anyone out there today? > > ==== > Glenn Williams > 8A > A&P > > Yahoo! Photos -- now, 100 FREE prints! > http://photos.yahoo.com > > > ________________________________________________________________________________
From: "CROWELL,JEFF (HP-Boise,ex1)" <jeff_crowell(at)hp.com>
Subject: RE: RV-List Digest: 42 Msgs - 06/15/00
Date: Jun 16, 2000
Tom DeMarino wrote: -------------------------------------------------- Hi Boyd and other, Let me start out by saying I'm not an expert in spins. I'll relay what I did and what I observed. This is just my opinion, and my observation my be different then someone else in the same seat. With that said.... snip Last night I took out my RV to do the acro series in it so I can make the log entries as to what I can do later (without having to put it back into the test phase). I donned my parachute (which is uncomfortable as sitting on a rock) and started with stalls, power on, and power off, and then did 1/2 spin each way, then 1 turn, and then 2 turns each way. I was at arco weight of 1375, and all were power off, ailerons neutral. They seemed a little fast, but nothing unnerving (again, my opinion). Recovery was always within a 1/2 turn, and I only bounced my head off the canopy once while applying a little down elevator. I didn't feel anything dangerous was about to happen. About the only thing that caught my attention was a big shudder of the airplane as it was just starting to rotate. Just a comment from having read and researched Van's comments, and from a background involving quite a few spins: the above described maneuvers are ***not*** spins-they are "incipient spins" or post-stall gyrations. Test flight reports on the RV-6 clearly distinguish between the post-stall phase and the developed spin phase. Recovery characteristics differ too! From conversations with Ken at Van's, I'd approach spins with care and trepidation-their test pilot, whose name escapes me, was ***very*** clear in saying that spins were not a good idea in this airplane. Something to do with the airflow characteristics over the fuselage of the RV-6. This advice is worth what you paid for it. Jeff ________________________________________________________________________________
Subject: Re: Strobe Light Power Supply Kit
Date: Jun 16, 2000
I am interested in what this thing can do also... Anyone have any good or bad information on this? Here is more details: http://www.i-mcm.com/Search/level_5.jhtml?PRODID=44338&SKUID=43582 Bill VonDane, Colorado RV-8A, N912V, Wings http://vondane.com ----- Original Message ----- From: Norman Hunger <nhunger(at)sprint.ca> Sent: Thursday, June 15, 2000 11:58 PM Subject: RV-List: Strobe Light Power Supply Kit > > I'm looking in the new MCM Electronics printed catalog on page 115. Part # > 80-735 is a Strobe Circuit Kit for $12.75 They show a picture of an empty > circuit board and a bunch of small parts, no enclosure. You have to solder > it together. > > I'll quote from the catalog: "Can be used as emergency warning light on > autos, radio tower or anywhere a strobe light is needed. Variable flash > rate. Dimensions 3 1/2" X 1 3/4" Operates on 6/12 VDC." > > Does any one know any thing about this? Could it be suitable for us? > > More info or to order your own free catalog of tons of interesting stuff: > www.mcmelectronics.com > > > Regards, > Norman Hunger > RV6A Delta BC ________________________________________________________________________________
Date: Jun 16, 2000
thanks for the info. i don't really care about being competitive to the point of having to win. i just want to do it and do it to the best that I can with what i have. that will be good enough. what i am trying to gather from a person who knows first hand is whether or not there is a significant difference in the way the 4, 6 and 8 fly WRT aerobatics - especially in the spin department. If you limit yourself to less than one turn spins, do they all behave the same, do they all pick up speed or bleed off speed the same, etc, given the same set of circumstances. lucky >From: "Paul & Gerti RV-4 F-1 Rocket 006" <gertivs(at)netzero.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: RV spins & acro >Date: Thu, 15 Jun 2000 21:48:28 -0700 > > > > > I've been told by a few IAC email list people that they have been to > > contests where RV6s have competed (as well as 4s) and done well. Though >no > > one has offered up a name yet. Ok, fess up. Whose doing Sportsman and > > Intermediate in a RV6? :-) I want to talk to them! > >I once thought I would like to try and compete. Like you I thought I would >ask around first. At the semi-local IAC chapter in Delano, CA everyone >told >me to contact Ralph Riddel as the RV-4 expert in competition. Both he and >his son have competed in the -4 and won. Ralph is also the primary acro >instructor at Sean Tucker's School of Aerobatics in Salinas, Calif. He is >good and knows his stuff. You can reach him through the school or his IAC >chapter. > >I later took a lesson from Ralph in a IO-540 Pitts 2-B. The Pitts' >handling >blew me away. That was the end of any real hope of competion. Me and my >-4 >are hot heavy and ready to go but could NOT be competitive against the >Pitts >and someone who knows how to make her dance. > >Paul Vander Schuur > > ________________________________________________________________________________
Date: Jun 16, 2000
Ah yes, being the underdog. I absolutely LOVE being told I'm competing in a machine that is not as developed, or supported as my competitors. That way, if I lose....that's OK, I'm not in a competitive machine.....but when I WIN....I can just look them in the eye and smile...they know exactly what I mean. So, if I get a wild hair to compete in the RV-4 I'm building....that is exactly what I'll do.....because it's more fun to be on THAT side of the fence and not winning then it is to be on the spectator side and wishing you could. If you and your RV are hot and heavy to do it....then DO IT. My God man, who cares if you win or lose......they expect you to do poorly so any good you do is twice the accomplishment. There is no down side. Bill -4 > I later took a lesson from Ralph in a IO-540 Pitts 2-B. The Pitts' handling > blew me away. That was the end of any real hope of competion. Me and my -4 > are hot heavy and ready to go but could NOT be competitive against the Pitts > and someone who knows how to make her dance. > ________________________________________________________________________________
Subject: Re: Fuel Pickup Checking
Date: Jun 16, 2000
I'm a little confused on how one could get the fuel pickup turned and not find out about it until you were in the air (unless it turned in the air). Proper weight and balance procedures require you to place fuel in each tank and then run the engine until it quits in order to establish unusable fuel (which is a component of empty weight). In conjunction with this test I would think that you'd also want to conduct flow test to ensure that your fuel pump and fuel system are delivering adequate fuel flow to the carburetor. And at the same time, you'd also want to calibrate your fuel gauges, flush out your fuel system, and check your tanks for leaks. When I did this I filled each tank and pumped it dry at least once. (Actually, I had to do it three times, because I had a leak the first time and then I spilled some fuel and screwed up my calibration calculation.) If 1.5 gallons or more of fuel disappeared, I'd start looking for where the fuel is hiding. But even if I didn't catch on that more fuel than usual was remaining, I would have known the quality of fuel remaining in the tank and where that indicated on my gauges. BTW for inquiring minds, I have 1/4 gallon of unusable fuel in each tank in a level flight attitude, and each tank holds exactly 19 gallons (in a tail down attitude). Randy Pflanzer N417G RV-6 (4 hours) ________________________________________________________________________________
Date: Jun 16, 2000
Matt, I have the Skymap IIIC PC Interface DLL (for Win95/88/NT4)& documentation, I will send it to you. Sadly, there is no import lib or header file, so you have to use the "old fashioned" way using LoadLibrary and GetProcAddress. Let me know if you want me to send code snippets. Or maybe I'll just finish my little applet that does what you want and send it out... Mitch Faatz RV-6A Finish Kit Bedford, MA -----Original Message----- From: dralle(at)matronics.com [mailto:dralle(at)matronics.com] Sent: Friday, June 16, 2000 2:47 AM Subject: RV-List: Skymap IIIC GPS - RS232 Interface to the Notepad... Hi Listers, For those of you that have had the pleasure of flying with the King (formally Skyforce) Skymap IIIC, you may or may not have noticed there is a nifty "Notepad" feature that allows you to upload roughly 4400 ASCII characters to the IIIC and then page through them. This is handy for something like an "online" check list or directions to the nearest airport with a hamburger joint. In any case, apparently there is a piece of software called Flight Manager Version 3.00 the you can buy for $229 (gulp) that will allow you to upload whatever text you may want to this special Notepad on the IIIC. Realizing that uploading ASCII text to this baby is a pretty trivial task and being a fair programmer, it hit me that I should spend a few hours away from building my plane and come up with a piece of software that might do the same. So here's my question. Does anyone have the technical spec. on how to communicate with the IIIC over the RS232 to manipulate the Notepad data space? There doesn't appear to be a "special" I/O menu for enabling this type of connectivity. I connected up a terminal to the IIIC and banged on it with few typical things, but nothing seemed obvious. Has anyone reverse engineered the Flight Manager code to see what it sends and receives on the RS232 port? Has anyone even used this Flight Manager software? Surfing around on the Bendix/King website, I was really disappointed in the documentation available on the IIIC there. Very pathetic, actually. I couldn't locate any information on the Flight Manager software, nor could I even find any data on available accessories for the IIIC. I did note that I can order a IIIC online direct from Bendix/King and pay full List price. What a deal. I wish they had bagged the online ordering development and focused on something useful - like some documentation... Sheeze. It appears that the old Skyforce website from the UK has been completely decommissioned - at least *their* site used to have a bit of useful information. Anyway, thanks for any information you might have on the aforementioned requirement. Best regards, Matt Dralle RV-4 Builder -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft Great minds discuss ideas, Average minds discuss events, Small minds discuss people... ________________________________________________________________________________
Date: Jun 16, 2000
Subject: Re: Flame Block Spray
Bob DiMeo - Oracle wrote: > > > Norm, > > The planes I've done have had unprimed aluminum sheets for backing the > fabric on the side panels. My Comanche is 40 years old and the unprimed > aluminum looked good as new. I would gauge the thickness at maybe .016. I > never though to measure it, though. The fabric was glued to the sheet and > folded over the edges by about two inches and glued. The panels were either > clipped in or screwed into the bulkheads in the Cabin interior. Looks great, > lasts a long time. > The glue that I used was from 3M and it's a high tack glue, it came in a > black spray can. I can't get to the can as I'm 12,000 miles away right now > but I would bet that it would stick to anything, including primed aluminum. The adhesive is Scotch 08090. Glad to see Eric's post on this subject which lent some sanity to this discussion. Likewise, I am not too concerned with fumes from burning sidewalls since the toxic fumes emitted from my burning limbs will have already incapacitated me.... And in case somebody wonders about an electrical fire setting the interior walls ablaze, they need to read "The AeroElectric Connection". Sam Buchanan (RV-6 with flammable pilot) "The RV Journal" http://home.hiwaay.net/~sbuc/journal ________________________________________________________________________________
Date: Jun 16, 2000
Subject: Re: Gyros as safety equipment
Ed Wischmeyer wrote: > > > Somebody wrote: > > > Just my opinion... but I don't think you ought to install gyros if you > > aren't trained to use them > > Ouch!! Part of the private pilot curriculum for years has been to > demonstrate fundamental maneuvers by reference to instruments. This is > not to promote ad hoc IFR flying, but to give pilots an out in case they > get into a cloud inadvertently. I can tell you from experience, that > it's real easy to get into a cloud inadvertently. Those gyros are your > life preserver!! > > Personally, I think that folks should give preference to installing an > attitude indicator over a turn coordinator, because the attitude > indicator is much easier to fly than the combination of turn coordinator > plus airspeed and altitude. (Turn and slip, with the vertical needle, is > harder yet to fly than a turn coordinator -- there's really no excuse > for putting one in.) > > Should you install safety equipment in your RV? Hell, yes! Electric for > night VFR? Let's look at the risks -- Night VFR can turn into IFR very > quickly flying over clouds, into clouds inadvertently, or when over > sparse areas with few light. Are electric gyros okay for that? Sure. The > risk is that you lose your electrical system while in the clouds, or > when unable to find an airport, or when unable to maintain VFR to the > destination. It's not like you're planning to fly forever at night on > instruments. The risk is a bit higher than having gyros from two power > sources (electric and vacuum) but not extravagantly higher, IMHO. > > Personally, I'd be content with an electric attitude indicator for night > flight. I would *not* install all electric gyros if I were installing > all three. Vacuum systems aren't that big a deal (my RV-4 has one), put > there's a popular mythology the the very expensive electric gyros are > somehow better than vacuum. From what my overhaul shop told me, you do > *not* want to turn your gyros off when doing aerobatics -- it's less > wearing on the bearings to let 'em spin. > > Consider the risks and the mission, both for you and any possible > subsequent buyer, and good luck!! At the risk of rehashing what has been hashed many, many times before, a properly designed all-electric panel should be more reliable than the conventional setup. For more info, please reference "The AeroElectric Connection" for info about redundant electrical wiring architecture. Sam Buchanan (RV-6 sans attitude indicator........but I don't fly in clouds or at night) "The RV Journal" http://home.hiwaay.net/~sbuc/journal ________________________________________________________________________________
Date: Jun 16, 2000
Subject: 8 vs. 8A
I'm ready to start an RV. I visited Van's last weekend and took a test flight which convinced me. I'm set on the 8 series, but can't decide between the 8 and 8A. Any opinions/suggestions to resolve my dilemma. Brian ________________________________________________________________________________
Date: Jun 16, 2000
Subject: Re: 8 vs. 8A
--- Brian wrote: > > I'm ready to start an RV. I visited Van's last weekend and took a > test > flight which convinced me. I'm set on the 8 series, but can't decide > between the 8 and 8A. Any opinions/suggestions to resolve my > dilemma. LOL!!!!!!! :) :) :) Ha! I'll start this puppy: "A sport plane _must_ have a tailwheel!" Next? Mike Thompson Austin, TX -6 N140RV (Reserved) Fuselage Send instant messages with Yahoo! Messenger. ________________________________________________________________________________
Date: Jun 16, 2000
Boy did you open up a can of worms :-) All kidding aside, I think you will find a long list of compelling reasons to build both aircraft. From what I understand about both models, they fly pretty much the same. The only real difference is in landing and taking off. What it comes down to is what kind of plane do you like to fly. I have always been a trike pilot. I would never be happy with a tail dragger. I find them easier to land and like the extra visibility while taxing. But then I must face the fact that they aren't nearly as cool as a tail dragger ;-) Life is about making choices. I have made mine and I'm happy. Good luck, - Jim Andrews RV-8AQ ( finish ) N89JA ( reserved ) ________________________________________________________________________________
Subject: Re: Spark Plugs
Date: Jun 16, 2000
Hi Fred: Hope you don't mind me posting this to the list but thought it might be of interest to others as this subject has come up before. I have no experience with automotive plugs in aircraft engines. I am not against change but as I have posted before in the interests of safety am really reluctant to change anything under the cowlings that does not have a long term reliability record. An example is the recent oil cooler failure. Without much knowledge on the subject I am assuming that the auto plug that you mention will improve the flame front and give better all around combustion. I believe that this same improvement can be accomplished by using the Champion REM37BY. This plug places the spark deeper into the cylinder creating a better flame front and also prevents the build up of lead and carbon deposits in the plug itself. I believe this plug was developed for engines that were being operated with full rich mixture most of the time such as training aircraft causing excessive lead build up. By using this plug you accomplish what you are looking for but still retain standard aircraft grade harness. As to radio noise this has been taken care of with the newer type of harness and should not be a problem. Just my opinion. Eustace Bowhay Blind Bay, B.C. -----Original Message----- From: Stucklen, Frederic IFC <stuckle(at)ifc.utc.com> Date: Wednesday, June 14, 2000 9:50 AM Subject: Spark Plugs >Eustace, > > Do you have any experience using automotive spark plugs on a Lycolming >O-320-D1A engine with Slick Mag's? Most aviation plugs are resistive (~1K >ohm). 18mm auto plugs come in resistive (AC-86, Autolight C386, etc) or >non-resistive. The resistive plugs are usually around 8000 - 10,000 ohms, >and result in less radio noise, but a colder spark. > What's your opinion on using these? > >Fred Stucklen >N925RV RV-6A ________________________________________________________________________________
Date: Jun 16, 2000
--- "Randy J. Pflanzer" wrote: > > > I'm a little confused on how one could get the fuel pickup turned and > not > find out about it until you were in the air (unless it turned in the > air). I think this could have happened after minimum fuel checks. You put your bird together, do those checks, something requires removing the wing. When the fuel line is disconnected for maybe the umpteenth time the fitting inside also rotates. Perhaps when that fitting is tightened again the fitting doesn't rotate back. Wings on, wings off, wings on wings off... it happens. (Where did I just hear that recently?) :) Mike Thompson Austin, TX -6 N140RV (Reserved) Fuselage Send instant messages with Yahoo! Messenger. ________________________________________________________________________________
Date: Jun 16, 2000
Randy J. Pflanzer wrote: > Proper weight and balance procedures require you to place fuel in each tank > and then run the engine until it quits Oh, no! Is this procedure required by a FAR? I want to run my new engine on the ground as little as possible so I was planning on determining unusable by putting a measured gallon in each tank then draining each by use of the aux pump out the gascolater drain. What doesn't come back out is unusable, right? I would be interested in a script for these pre-flight testing procedures. Someone once said tie the tail down (if it isn't already!) and see that fuel can be pumped to the carb in good quantity to simulate takeoff conditions. Hal Kempthorne RV6a N7HK ________________________________________________________________________________
Subject: 8 vs. 8A
Date: Jun 16, 2000
I have no experience with either, but from reading specs and from having had to make the decision myself. Her are a few points you may want to consider: 1) The nose wheel version doesn't perform quite as well as the tail wheel version. You have to take a slight drop in speed and range. Otherwise, they should perform the same in the air. 2) Tail draggers typically have to be 'flown' until tie-down. Reading maps, programming GPS etc. while taxiing is out of the question. 3) I personally think the tail dragger looks better. 4) As far as I know, you don't have to make up your mind for a long time yet, unless you're planning on a Quick Build (I think). 5) What are your preferences? If the very few extra mph outweighs the lack of visibility on ground - for _you_; then go with the tail dragger. If you're not sure yet, get some time in another tail dragger and see for yourself. Maybe you're ok with it in which case there wouldn't be any reason to hang a nose wheel on the otherwise sleek fuselage. Are RV-6 (tail dragger) -----Original Message----- From: Brian [mailto:briand(at)carolina.rr.com] Sent: June 16, 2000 10:22 AM Subject: RV-List: 8 vs. 8A I'm ready to start an RV. I visited Van's last weekend and took a test flight which convinced me. I'm set on the 8 series, but can't decide between the 8 and 8A. Any opinions/suggestions to resolve my dilemma. Brian ________________________________________________________________________________
Subject: 8 vs. 8A (oops)
Date: Jun 16, 2000
I do have experience with both tail draggers and trikes but not in an RV-8(A). I would be happy with either. Personal preference is the key! Are Are wrote: I have no experience with either, but from reading specs and from having had to make the decision myself. Her are a few points you may want to consider: ________________________________________________________________________________
Date: Jun 16, 2000
Jim Cone posted a great account of spinning his RV-6 several years ago. It is available in the archives. Everyone should read it before test flying, in my opinion. Steve Soule Huntington, VT RV-6A baffles -----Original Message----- From: lucky macy [mailto:luckymacy(at)hotmail.com] Sent: Thursday, June 15, 2000 6:51 PM Subject: RV-List: RV spins & acro I didn't find exactly what I was looking for in the archives. I've been told by a few IAC email list people that they have been to contests where RV6s have competed (as well as 4s) and done well. Though no one has offered up a name yet. Ok, fess up. Whose doing Sportsman and Intermediate in a RV6? :-) I want to talk to them! I'd like help separating fact from 2nd hand or worse info. The archives are full of advise not to spin a RV. Now does anyone have Pitts time and RV time and spun both? If so, care to comment on how the RV does in comparison? Do different RV design spin significantly differently? A big name on the IAC and airshow circuit recently told me that it would be tantamount to stupid to compete with an RV6 and they are looked down upon overall by the IAC community because they are not the greatest (read safe) in spins and pick up speed very quickly (they did say they thought they were a great plane for tooling around in and going somewhere fast). Not that they confesses to every flying a RV themselves... The fact that people are doing it means it can be done. No one has crashed yet despite multiple competitive flights. Meaning it can be done repeatedly safely. Some RVs even win regional meets. They can be competitive at the lower levels. All levels have spins as a required maneuver. So what gives? lucky ________________________________________________________________________________
Date: Jun 16, 2000
Subject: 8 vs. 8A
--- "Barstad, Are" wrote: > > I have no experience with either, but from reading specs and from > having had > to make the decision myself. Her are a few points you may want to > consider: OK, OK, I'll be serious - for now. All good points made thus far. One not made however is resale value. _If_ you intend to sell this bird when you either replace it or tire of it (??), you will get a better price and more interest in an 8A. I think that has been shown over and over again in the -6 aircraft sold. Nobody said life is fair. Mike Thompson Austin, TX -6 N140RV (Reserved) Fuselage Send instant messages with Yahoo! Messenger. ________________________________________________________________________________
Subject: RV spins & acro..Ken Scott
Date: Jun 16, 2000
I talked to ken scott this morning about RV acro and spins in particular. To summarise, he said that if you were blindfolded, you would not be able to tell between any model (4, 6, 6A, 8, 8A) in the way they fly or spin. They all stall the same as none have washout in the wing design and all stall all at once without warning. They all seem to transition into fully developed spins the same way. The only difference is the 6 models, once IN a fully developed spin, take longer to recover once the spin recovery inputs are made and they think it has to do with the different fuselage shape to accomodate the side by side seating arrangement. They all get into (cockpit look and feel) a spin the same way and look and feel the same once in a full spin. They all have relatively the same moments and surface areas, airfoils, etc and there's just not any difference (perosnal rigging issues aside). He suggested they all seem to recover immediately if you are limiting your spins to no more than a couple of revolutions. Im my *opinion* then, in IAC competition at the lower levels where you don't do multi-rotation spins, the RV should be fine if you practice and get training. And like I reported earlier, RVs of all types do reportedly do well at regional IAC meets at the lower levels. BUT, here's the other *perception* question. The 8's spars only protrude into the fuselage about 8 inches as opposed to the 4 and 6 which have spars which span the full with of the fuselage. I don't design airplanes and won't pretend my comments mean diddly squat. It's probably GA standard for the spars to only go through the fuse a bit like the 8's do but then most GA aren't doing aerobatics. For me, there's a psychological comfort in knowing the 4 and 6 wing spars are longer and have more surface attachment area inside the fuse. I have seen a couple of modern purpose built acro wings and they look liked the spars carried all the way through the fuse too. Any thoughts? I told ken I wish the hell Vans would make a RV4 quickbuild... lucky >From: "Stephen J. Soule" <SSoule(at)pfclaw.com> >Reply-To: rv-list(at)matronics.com >To: "'rv-list(at)matronics.com'" >Subject: RE: RV-List: RV spins & acro >Date: Fri, 16 Jun 2000 11:52:39 -0400 > > >Jim Cone posted a great account of spinning his RV-6 several years ago. It >is available in the archives. Everyone should read it before test flying, >in my opinion. > >Steve Soule >Huntington, VT >RV-6A baffles > >-----Original Message----- >From: lucky macy [mailto:luckymacy(at)hotmail.com] >Sent: Thursday, June 15, 2000 6:51 PM >To: rv-list(at)matronics.com >Subject: RV-List: RV spins & acro > > >I didn't find exactly what I was looking for in the archives. > >I've been told by a few IAC email list people that they have been to >contests where RV6s have competed (as well as 4s) and done well. Though no >one has offered up a name yet. Ok, fess up. Whose doing Sportsman and >Intermediate in a RV6? :-) I want to talk to them! > >I'd like help separating fact from 2nd hand or worse info. > >The archives are full of advise not to spin a RV. Now does anyone have >Pitts time and RV time and spun both? If so, care to comment on how the RV >does in comparison? Do different RV design spin significantly differently? > > >A big name on the IAC and airshow circuit recently told me that it would be >tantamount to stupid to compete with an RV6 and they are looked down upon >overall by the IAC community because they are not the greatest (read safe) >in spins and pick up speed very quickly (they did say they thought they >were > >a great plane for tooling around in and going somewhere fast). Not that >they confesses to every flying a RV themselves... > >The fact that people are doing it means it can be done. No one has crashed >yet despite multiple competitive flights. Meaning it can be done >repeatedly > >safely. Some RVs even win regional meets. They can be competitive at the >lower levels. All levels have spins as a required maneuver. So what gives? > >lucky > > ________________________________________________________________________________
Date: Jun 16, 2000
Grooannn...Really...Why MUST it have a tailwheel? Watch the sparks fly now!! Mike Robertson RV-8A >From: Mike Thompson <grobdriver(at)yahoo.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: 8 vs. 8A >Date: Fri, 16 Jun 2000 07:38:56 -0700 (PDT) > > >--- Brian wrote: > > > > I'm ready to start an RV. I visited Van's last weekend and took a > > test > > flight which convinced me. I'm set on the 8 series, but can't decide > > between the 8 and 8A. Any opinions/suggestions to resolve my > > dilemma. > >LOL!!!!!!! >:) :) :) >Ha! >I'll start this puppy: >"A sport plane _must_ have a tailwheel!" > >Next? > >Mike Thompson >Austin, TX >-6 N140RV (Reserved) >Fuselage > > >Send instant messages with Yahoo! Messenger. > > ________________________________________________________________________________
Date: Jun 16, 2000
To get serious for a moment. I think both are excellent aircraft. To me the taildragger (a**dragger for real men) looks sexier but it really all depends on your desires here. I choose the -8A because here in rotten old Hawaii we have a tendency to have some winds. Thats ok for takeoff and landing but makes for a hell of a crosswind on taxiing. The -8(a) has a large vertical find and rudder that wants to weather-van a bunch. The -8A can hold the crosswind during taxiing better generally. Bottom line........go with your gut feeling and what your desires and intent are. Mike R. >From: "Mike Robertson" <mrobert569(at)hotmail.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: 8 vs. 8A >Date: Fri, 16 Jun 2000 06:27:27 HST > > >Grooannn...Really...Why MUST it have a tailwheel? Watch the sparks fly >now!! > >Mike Robertson >RV-8A > > > >From: Mike Thompson <grobdriver(at)yahoo.com> > >Reply-To: rv-list(at)matronics.com > >To: rv-list(at)matronics.com > >Subject: Re: RV-List: 8 vs. 8A > >Date: Fri, 16 Jun 2000 07:38:56 -0700 (PDT) > > > > > >--- Brian wrote: > > > > > > I'm ready to start an RV. I visited Van's last weekend and took a > > > test > > > flight which convinced me. I'm set on the 8 series, but can't decide > > > between the 8 and 8A. Any opinions/suggestions to resolve my > > > dilemma. > > > >LOL!!!!!!! > >:) :) :) > >Ha! > >I'll start this puppy: > >"A sport plane _must_ have a tailwheel!" > > > >Next? > > > >Mike Thompson > >Austin, TX > >-6 N140RV (Reserved) > >Fuselage > > > > > >Send instant messages with Yahoo! Messenger. > > > > > > ________________________________________________________________________________
Date: Jun 16, 2000
> OK flamers, set your sites on me because I'm declaring myself flamebait. :-) > > REAL MEN FLY TAILDRAGGERS. > > Bob Japundza > RV-6 YEAH BABY, I'm standing beside Bob on this one. Bill RV-4 no such thing as a tri geared, sissy -A on an RV-4 :-) ________________________________________________________________________________
Date: Jun 16, 2000
At 06:27 AM 6/16/00 HST, you wrote: > >Grooannn...Really...Why MUST it have a tailwheel? Watch the sparks fly >now!! > >Mike Robertson >RV-8A SO YA WON'T SCAPE THE PAINT OFF! ________________________________________________________________________________
Subject: Re: Flame Block Spray - 8 vs. 8A
Date: Jun 16, 2000
> - I personally think the -8A looks better than the -8! I know, people think > I am crazy, but it's true... You are right, it is true......you ARE CRAZY. :-) Bill -4 ________________________________________________________________________________
Date: Jun 16, 2000
Okay, enough already. Real men do what they want and could care less what some fighter pilot wanaby thinks. Garry RV6 finishing. Bill Shook wrote: > > > OK flamers, set your sites on me because I'm declaring myself flamebait. > :-) > > > > REAL MEN FLY TAILDRAGGERS. > > > > Bob Japundza > > RV-6 > > YEAH BABY, I'm standing beside Bob on this one. > > Bill > RV-4 no such thing as a tri geared, sissy -A on an RV-4 :-) > ________________________________________________________________________________
Date: Jun 16, 2000
Oh come on now....a little poking fun and humor between pilots is hardly a new concept.... > > Okay, enough already. > Real men do what they want and could care less what some fighter pilot wanaby > thinks. > Garry RV6 finishing. > ________________________________________________________________________________
Date: Jun 16, 2000
Subject: Re: .30 cal or .50 cal?
Hi Steve, Well, I've read that "..REAL men, mount .50 cal ONLY!", but I wanted my wife to be able to strafe Misquamicut Beach without too much recoil,, thus we mounted a lone air-cooled Browning .30 cal in the air-intake "mouth" under the RV cowl. The engine runs a little hot with no fresh air coming in, but dang'd if the old lady can't tear up them picnic baskets with only one or two passes.. Saves lotsa' av-gas dont'cha see! Good luck, RJ in CT :=)))))))) ================================================================== > Hi, > > I'm having trouble deciding what kind of machine guns to put in my RV. > I really like the .50's but the weight restrictions seem a little > excessive. The .30's are also a little cheaper. > -Steve ________________________________________________________________________________
Date: Jun 16, 2000
Bill, Sorry, I thought that's what I was doing, and Bob I have flow a Staggering, George LeMay's back in 1981. Sorry I just couldn't help myself. No Mustang yet but hope springs eternal. Now, I'm going to get work. Garry, RV6 still finishing. Bill Shook wrote: > > Oh come on now....a little poking fun and humor between pilots is hardly a > new concept.... > > > > > Okay, enough already. > > Real men do what they want and could care less what some fighter pilot > wanaby > > thinks. > > Garry RV6 finishing. > > > ________________________________________________________________________________
Date: Jun 16, 2000
Hahaha, well then you got me didnt you? Yep, it's friday alright....have a great weekend everyone. Bill > > Bill, > Sorry, I thought that's what I was doing, and Bob I have flow a Staggering, > George LeMay's back in 1981. Sorry I just couldn't help myself. No Mustang yet > but hope springs eternal. Now, I'm going to get work. > Garry, RV6 still finishing. > > > Bill Shook wrote: > > > > > Oh come on now....a little poking fun and humor between pilots is hardly a > > new concept.... > > > > > > > > Okay, enough already. > > > Real men do what they want and could care less what some fighter pilot > > wanaby > > > thinks. > > > Garry RV6 finishing. > > > > > > > ________________________________________________________________________________
Date: Jun 16, 2000
Subject: FS: Duckworks light kit
I just ordered the RMD wingtip lights, so I have the following for sale: Duckworks leading edge landing light kit (for both wings). In original box from Van's. First $150 (plus shipping) takes it. -- Regards, Ken Balch Ashland, MA RV-8 #81125 drilling fuselage skins ________________________________________________________________________________
Date: Jun 16, 2000
Subject: FS: Capacitive fuel sender kit
I went with the float-type senders, so I have this kit for sale. As received from Van's, the first $50 (plus shipping) takes it. -- Regards, Ken Balch Ashland, MA RV-8 #81125 drilling fuselage skins ________________________________________________________________________________
Date: Jun 16, 2000
Subject: Update: RV-8 Dwg. 28 r5 error
FYI... I initially thought I had the problem I described on Wednesday because my aft bulkheads (F-808 - F-812) didn't look as though they'd align properly with the holes in the F-824 using the match hole called out by my drawing 28. Scott R. added to the confusion by informing me that Van's has issued Dwg. 28 r6 to 'fix' this error. What I did yesterday was cleco my F-826, F-827 & F-842 bottom skins in place to see how everything lined up. The positions of F-826 & F-827 are fixed by the holes that match those in F-804. Given that and using the aft match holes in those two skins to place my F-842, it became clear to me that I would need to match my F-824 side skins to the F-823 skins as shown on my dwg. 28 r5. So, consider Dwg. 28 r5 to be correct on this score. My F-811 & F-812, however, will definitely have to be moved further aft by almost 1 inch. Consequently, my main longerons will need to be spread slightly in the very back to accommodate this. They will also, of course, have to be re-notched for the bars on F-811. When I've accomplished all this, I'll mention it to Van's and let them sort out their drawing situation. -- Regards, Ken Balch Ashland, MA RV-8 #81125 drilling fuselage skins ________________________________________________________________________________
Date: Jun 16, 2000
Subject: Re: FS: Duckworks light kit
Just a FYI, team rocket aircraft sells the duckworks landing lights for 69.95 a piece or 135.00 for a set of two plus shipping. Chris Wilcox F1 rocket 000 In a message dated 6/16/2000 2:44:23 PM Central Daylight Time, kbalch1(at)mediaone.net writes: << I just ordered the RMD wingtip lights, so I have the following for sale: Duckworks leading edge landing light kit (for both wings). In original box from Van's. First $150 (plus shipping) takes it. -- Regards, Ken Balch Ashland, MA RV-8 #81125 drilling fuselage skin >> ________________________________________________________________________________
Date: Jun 16, 2000
Looks like Van's has raised their prices, but Team Rocket hasn't yet. I'll match the price of $135 (plus shipping). Ken CW9371(at)AOL.COM wrote: > > Just a FYI, team rocket aircraft sells the duckworks landing lights for 69.95 > a piece or 135.00 for a set of two plus shipping. > > Chris Wilcox > F1 rocket 000 > > In a message dated 6/16/2000 2:44:23 PM Central Daylight Time, > kbalch1(at)mediaone.net writes: > > << I just ordered the RMD wingtip lights, so I have the following for sale: > > Duckworks leading edge landing light kit (for both wings). In original > box from Van's. First $150 (plus shipping) takes it. > > -- > Regards, > Ken Balch > Ashland, MA > RV-8 #81125 > drilling fuselage skin >> ________________________________________________________________________________
Subject: 8 vs. 8A
Date: Jun 16, 2000
Can anyone speak firsthand about the insurance cost differential for a trike vs a taildragger?? I there is a differenc, after a certain level of experience is acquired in a tail dragger does the cost drop to that of a trike? Jack Rowell ________________________________________________________________________________
Subject: Airmaster Props
Date: Jun 16, 2000
Does anyone know anything positive or negative about Airmaster Variable-Pitch Propellers? They have a web site at www.propellor.com Vince RV-8A Wings ________________________________________________________________________________
Date: Jun 16, 2000
Check with your insurance. I got a price break on having an 8a. nose draggers were preferred over tail draggers. Gert Mike Thompson wrote: > > > --- "Barstad, Are" wrote: > > > > I have no experience with either, but from reading specs and from > > having had > > to make the decision myself. Her are a few points you may want to > > consider: > > > > OK, OK, I'll be serious - for now. > All good points made thus far. One not made however is resale value. > > _If_ you intend to sell this bird when you either replace it or tire of > it (??), you will get a better price and more interest in an 8A. I > think that has been shown over and over again in the -6 aircraft sold. > > Nobody said life is fair. > > Mike Thompson > Austin, TX > -6 N140RV (Reserved) > Fuselage > > -- Pursuant to US Code, Title 47, Chapter 5, Subchapter II, '227, any and all nonsolicited commercial E-mail sent to this address is subject to a download and archival fee in the amount of $500 US. E-mailing denotes acceptance of these terms. ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Date: Jun 16, 2000
YOU MENT TO SAY: REAL "OLD" MEN fly obsolete configured planes. At LOCKHEED MARTIN we design MODERN AIRCRAFT F-15,F-16 ect. Hence NO RESALE. ( SORRY COULD NOT RESIST) DO NOT ARCHIEVE ----- Original Message ----- From: Bill Shook <billshook(at)mindspring.com> Sent: Friday, June 16, 2000 12:57 PM Subject: Re: RV-List: 8 vs. 8A > > > OK flamers, set your sites on me because I'm declaring myself flamebait. > :-) > > > > REAL MEN FLY TAILDRAGGERS. > > > > Bob Japundza > > RV-6 > > > YEAH BABY, I'm standing beside Bob on this one. > > Bill > RV-4 no such thing as a tri geared, sissy -A on an RV-4 :-) > > ________________________________________________________________________________
Date: Jun 16, 2000
And exactly how many of those 'real aircraft' leave 3 wheels hanging in the breeze for all to see? If I were building a tri gear, I would make sure it folded up out of sight so that other pilots wouldn't make fun of me. The real reason those F-whatever's are retractable. :-) > > YOU MENT TO SAY: REAL "OLD" MEN fly obsolete configured planes. At > LOCKHEED MARTIN we design MODERN AIRCRAFT F-15,F-16 ect. > Hence NO RESALE. ( SORRY COULD NOT RESIST) > > DO NOT ARCHIEVE ________________________________________________________________________________
Date: Jun 16, 2000
Subject: Modification of F-621 canopy deck
Regarding RV-6 tip-up, F-621 I am considering modifying my F-621 canopy deck to make room for an instrument in the lower left of the panel. Has anyone else done this? Can anyone see a reason I shouldn't do this? Can anyone suggest how I might do this? The basic interference problem is becaue the F-621 angles inward as it goes forward. Thank you for your help. - Glenn Gordon ________________________________________________________________________________
From: "Craig Hiers" <craig-rv4(at)worldnet.att.net>
Date: Jun 16, 2000
There you are on final approach, it's a short narrow grass strip with tall tree's on both sides. You make a nice flare for a three point landing, then a strong gust of wind hits the plane. The next thing you know your a**hole has eaten the cushion you were sitting on.....agian. I would'nt have it any other way. Craig Hiers RV-4 N143CH Tallahassee,FL. a little adrenalin is good for you > And exactly how many of those 'real aircraft' leave 3 wheels hanging in the > breeze for all to see? If I were building a tri gear, I would make sure it > folded up out of sight so that other pilots wouldn't make fun of me. The > real reason those F-whatever's are retractable. :-) > > > > > > YOU MENT TO SAY: REAL "OLD" MEN fly obsolete configured planes. At > > LOCKHEED MARTIN we design MODERN AIRCRAFT F-15,F-16 ect. > > Hence NO RESALE. ( SORRY COULD NOT RESIST) > > ________________________________________________________________________________
Date: Jun 16, 2000
> >Randy J. Pflanzer wrote: > >> Proper weight and balance procedures require you to place fuel in each >tank >> and then run the engine until it quits > >Oh, no! Is this procedure required by a FAR? > >I want to run my new engine on the ground as little as possible so I was >planning on determining unusable by putting a measured gallon in each tank >then draining each by use of the aux pump out the gascolater drain. What >doesn't come back out is unusable, right? > >I would be interested in a script for these pre-flight testing procedures. >Someone once said tie the tail down (if it isn't already!) and see that fuel >can be pumped to the carb in good quantity to simulate takeoff conditions. > >Hal Kempthorne >RV6a N7HK > The following info is from FAA Advisory Circular 90-89A, AMATEUR-BUILT AIRCRAFT AND ULTRALIGHT FLIGHT TESTING HANDBOOK. It was written jointly be the EAA and FAA, and has a lot of good info on flight testing, and all the stuff you should do before you go flying. It is available at: http://www.faa.gov/avr/afs/acs/90-89a.pdf http://members.xoom.com/kevinhorton/docs/90-89A.PDF Lots of other good flight test related links can be found on my RV Links Page, at: http://members.xoom.com/kevinhorton/rvlinks.html Fuel Flow and Unusable Fuel Check: This is a field test to ensure the aircraft engine will get enough fuel to run properly, even if the aircraft is in a steep climb or stall attitude. (1) First, place the aircraft's nose at an angle 5 degrees above the highest anticipated climb angle. The easiest and safest way to do this with a conventional gear aircraft is to dig a hole and place the aircraft's tail in it. For a nose gear aircraft, build a ramp to raise the nose gear to the proper angle. (2) Make sure the aircraft is tied-down and chocked. With minimum fuel in the tanks, disconnect the fuel line to carburetor. The fuel flow with a gravity flow system should be 150 percent of the fuel consumption of the engine at full throttle. With a fuel system that is pressurized, the fuel flow should be at least 125 percent. When the fuel stops flowing, the remaining fuel is the ''unusable fuel'' quantity. (3) Since the fuel consumption of most modern engines is approximately .55 pounds per brake horsepower per hour for a 100 horsepower engine, the test fuel flow should be 82.5 pounds (13.7 gallons) per hour for gravity feed, or 68.75 pounds (11.5 gallons) per hour for a pressurized system. The pounds per hour divided by 60 equals 1.4 pounds and 1.15 pounds per minute fuel rate respectively. NOTE: Formula for fuel flow rate gravity feed is .55 x engine horsepower x 1.50 = pounds of fuel per hour divided by 60 to get pounds per minute, divided by 6 to get gallons per minute. For a pressurized sys-tem, substitute 1.25 for 1.50 to determine fuel flow rate. Comment from Kevin Horton - once the engine is leaned out at cruise power, the fuel consumption will be quite a bit lower than .55 lb/hr/hp. This value looks about right for an engine at full rich mixture. Kevin Horton RV-8 (cockpit stuff) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
Date: Jun 16, 2000
Subject: Re: Airmaster Props
> >Does anyone know anything positive or negative about Airmaster >Variable-Pitch Propellers? They have a web site at www.propellor.com > >Vince >RV-8A Wings > The current models seem to be only for engines such as the Rotax 912/914 and the Jabiru. These engines will be much easier on props than four cylinder Lycomings. Given the very bad things that can happen when props shed a blade, I want to see evidence of thorough testing, and lots of service history on large four cylinder Lycomings before I buy a prop from a small or new company. In my business you don't take any more risk than necessary, and you do everything you can to mitigate the risks you do take. Firewall forward is not a good place to try to save money unless you are prepared to accept the additional risks associated with stuff of uncertain quality or reliablity. Just my opinion, not a flame. Kevin Horton RV-8 (cockpit stuff) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
Date: Jun 16, 2000
Subject: CDI depth needed
Hi, Can someone please tell me the depth of a Mid-Continent CDI for a GPS receiver? Thanks, Glenn Gordon ________________________________________________________________________________
Date: Jun 16, 2000
Subject: .30 cal or .50 cal? (LONG answer)
I always thought the foward baggage compartment would be a good place to mount two .30's, easier on the structure. Switch to rear seat solo for CG reasons, two guns is better than four, you can carry more ammo. Since fighters are really one seat anyway, add a hard point to the spar center section/carrythough for a single ~150lb bomb for the occasional a/g work. .30's are preferable, as two would be more than adequate to down the Cessna's, Bonanza's and other ilk that are usually encountered, also left over rounds could be used in my deer rifle. In all seriousness, I am planning on putting a gun/sword rack in my RV. I currently drive to Idaho a couple of times a year to go hunting with family, intend to fly up once the RV is done. My thoughts (which I will finalize once I start putting the fuse together) is either to attach to the back of the front seat, or along the side of the fuselage, next to the seat. Potential problems with the first options are interference with the pilots head, or control stick. Problems with the second is that I am not a small person, and need all the width I can get. Another option that has occured to me as I write this, would be to leave out the rear seat back, and strap them to the rear seat. Mounting must clamp the weapons in place sturdily enough to hold them done in the event of a crash, able to handle my shotgun or shinai (both about 4ft long, don't bend) or scoped big game rifle (smaller, but heavy approx 10lbs). Placarded "No aerobatics with weapons in weapon rack". Would be interested in hearing the ideas of others along these lines. Similar the the ski/golf club discussions. Brian Huffaker, DSWL (bifft(at)xmission.com) President and Founder Friends of P-Chan RV-8 80091 Riviting fuel tanks 1/5 Starduster II N23UT flying ________________________________________________________________________________
Date: Jun 17, 2000
Subject: Re: RV-9A Week wing theory
Hi there listers, I have been working on my -9 wing kit for a week now, are there any other -9 wing builders out there on this list? Pardon the sarcasm, got tired of deleting hundreds of weak wing dribble last week! Kevin Shannon -9A Wings ________________________________________________________________________________
Date: Jun 16, 2000
Nah...the real reson the fighters went to tri gear is that the y got tired of the "real Men" ground looping them and screwing up the wing tips. Gee...when was the last time I saw a tri-gear ground loop.... HEHE Mike R. >From: "Bill Shook" <billshook(at)mindspring.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: 8 vs. 8A >Date: Fri, 16 Jun 2000 19:57:17 -0400 > > >And exactly how many of those 'real aircraft' leave 3 wheels hanging in the >breeze for all to see? If I were building a tri gear, I would make sure it >folded up out of sight so that other pilots wouldn't make fun of me. The >real reason those F-whatever's are retractable. :-) > > > > > > YOU MENT TO SAY: REAL "OLD" MEN fly obsolete configured planes. At > > LOCKHEED MARTIN we design MODERN AIRCRAFT F-15,F-16 ect. > > Hence NO RESALE. ( SORRY COULD NOT RESIST) > > > > DO NOT ARCHIEVE > > ________________________________________________________________________________
Date: Jun 16, 2000
But I do agree with one thing....Y'all have a good weekend!! Mike R. >From: "Bill Shook" <billshook(at)mindspring.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: 8 vs. 8A >Date: Fri, 16 Jun 2000 19:57:17 -0400 > > >And exactly how many of those 'real aircraft' leave 3 wheels hanging in the >breeze for all to see? If I were building a tri gear, I would make sure it >folded up out of sight so that other pilots wouldn't make fun of me. The >real reason those F-whatever's are retractable. :-) > > > > > > YOU MENT TO SAY: REAL "OLD" MEN fly obsolete configured planes. At > > LOCKHEED MARTIN we design MODERN AIRCRAFT F-15,F-16 ect. > > Hence NO RESALE. ( SORRY COULD NOT RESIST) > > > > DO NOT ARCHIEVE > > ________________________________________________________________________________
Date: Jun 17, 2000
Subject: Re: Skymap IIIC GPS - RS232 Interface to the Notepad...
In a message dated 6/16/00 6:54:29 AM Pacific Daylight Time, grobdriver(at)yahoo.com writes: << > Realizing that uploading ASCII text to this baby is a pretty > trivial task and being a fair programmer, it hit me that I should > spend > a few hours away from building my plane and come up with a piece of > software that might do the same. Matt, keep us informed of your progress. I have a IIIC and if you can figure it out and develop a product for less $$, I'd probably be interested. >> Matt, I have a IIIC too and would also be interested in your progress in developing a software product. Unless the info you need is in the the IIIC owners manual I can't help you. I'm guessing you already have access to that. If not, I can loan you mine. Dale Wotring RV6A wireing etc. ________________________________________________________________________________
Subject: Bending Lexan
Date: Jun 16, 2000
> It amazes me how easy it would be to scratch build a pair of leading edge > landing lights. I have seen a pair of lights that had the same lenses at the > local auto store for less than a tank of gas in my car. Next > > thats the easy part. The hard part is bending the lexan. Actually you wouldn't beleive how easy bending lexan is. Gravity does it for you. I bent a piece of alum into a curve and layed it on a cookie sheet. I pre cut the lexan and balanced it on top of the curve. I don't remember what I set the oven on but I do remember ruining the first one. It really doesn't matter as lexan is dirt cheap and available all over the place these days. Norman Hunger RV6A Delta BC ________________________________________________________________________________
Date: Jun 17, 2000
Subject: RV Training In Knoxville
I will be in Knoxville, Tn next weekend (24 & 25 June) with my RV6. If anyone in that area needs training, contact me off-list. John Henley, CFII, N6LD 350 Hrs 850-609-3175 ________________________________________________________________________________
Date: Jun 17, 2000
Is the Aurora a slider or tip up? Terry E. cole ________________________________________________________________________________
Subject: Re: Bending Lexan
Date: Jun 17, 2000
I made my own leading edge lenses a few years back. I used the wing leading edge skin to form the curve, and protected the lexan from the skin with plastic freezer wrap. As I recall, the temp was in the mid 300's F range. Lexan requires a higher temperature than plexiglass. I learned that it is best to get the oven temperature stabilized so that the oven doesn't cycle ON while the glass is in the oven. If it does, the glass bubbles due to the concentration of heat. I handled the glass with a pair of cotton gloves. After laying the glass in the curved fixture, a bean bag will help hold the material tight to the form while it sets up. You could probably re-heat one that doesn't bend correctly and start all over. I remember that someone published lots of good stuff on temperatures. You could check the archives around 1997. Tom Barnes -6 ----- Original Message ----- From: Norman Hunger <nhunger(at)sprint.ca> Sent: Saturday, June 17, 2000 12:56 AM Subject: RV-List: Bending Lexan > > > It amazes me how easy it would be to scratch build a pair of leading edge > > landing lights. I have seen a pair of lights that had the same lenses at > the > > local auto store for less than a tank of gas in my car. Next > > > > > thats the easy part. The hard part is bending the lexan. > > Actually you wouldn't beleive how easy bending lexan is. Gravity does it for > you. I bent a piece of alum into a curve and layed it on a cookie sheet. I > pre cut the lexan and balanced it on top of the curve. I don't remember what > I set the oven on but I do remember ruining the first one. It really doesn't > matter as lexan is dirt cheap and available all over the place these days. > > Norman Hunger > RV6A Delta BC > > ________________________________________________________________________________
Subject: Re: RV builders in Argentina or Chile?
Date: Jun 17, 2000
> Any replies, in English, Spanish, French, German or eh... Norwegian are welcome My God man....if you can speak all of that, you won't find FAA-ese to be all that difficult. :-) humbled Bill I speak Van-plan-ese. The most contradictory language on this rock. :-) ________________________________________________________________________________
Subject: RV-9A wings
Date: Jun 17, 2000
>are there any other -9 wing builders out there on this list? >Kevin Shannon, -9A Wings I have been working on my wings since March 22nd. Everything has been going quite well. However, I do have one suggestion that may save other builders some time and trouble. If I were to do it over, I would have riveted the flap hinge brackets and associated angles to the ribs before riveting those ribs to the rear spar. It was not easy (for this novice builder) to rivet the flap brackets to the ribs right next to the spar but it would have been simple to squeeze these rivets before the spar was in place. Chris Heitman Dousman WI RV-9A N94ME (reserved) Tanks done and no leaks! ________________________________________________________________________________
Date: Jun 17, 2000
From: Charlie and Tupper England <cengland(at)netdoor.com>
The VonDane's wrote: > > > I am interested in what this thing can do also... Anyone have any good or > bad information on this? > > Here is more details: > http://www.i-mcm.com/Search/level_5.jhtml?PRODID=44338&SKUID=43582 > > Bill VonDane, Colorado > RV-8A, N912V, Wings > http://vondane.com > > ----- Original Message ----- > From: Norman Hunger <nhunger(at)sprint.ca> > To: > Sent: Thursday, June 15, 2000 11:58 PM > Subject: RV-List: Strobe Light Power Supply Kit > > > > > I'm looking in the new MCM Electronics printed catalog on page 115. Part # > > 80-735 is a Strobe Circuit Kit for $12.75 They show a picture of an empty > > circuit board and a bunch of small parts, no enclosure. You have to solder > > it together. > > > > I'll quote from the catalog: "Can be used as emergency warning light on > > autos, radio tower or anywhere a strobe light is needed. Variable flash > > rate. Dimensions 3 1/2" X 1 3/4" Operates on 6/12 VDC." > > > > Does any one know any thing about this? Could it be suitable for us? > > > > More info or to order your own free catalog of tons of interesting stuff: > > www.mcmelectronics.com > > > > > > Regards, > > Norman Hunger > > RV6A Delta BC > Norman & Bill, It's quite likely that the light level will be rather low for a/c use. You can buy similar strobes, prebuilt in a case from burglar/fire alarm dealers for about the same price. Try http://www.wmballen.com or for more light output, try http://www.jcwhitney.com Charlie ________________________________________________________________________________
Date: Jun 17, 2000
Maybe what I did is a bad idea, but I gotta ask just because it hasn't been mentioned. When I installed the pickup tube, I positioned the end of it directly over the drain hole so that I could remove the drain (empty tank first?!) and inspect for/clean trash from the pickup screen on the end of the tube. It seems that in this location it would be simple to visually ascertain that the tube is in the correct position after re-installation or tightening of the fuel line. I also combined the fuel fitting spacer with the anti-rotate tab by using a strip of .040 about 3" long with a hole in one end for the fitting and a notch in the other end (bent 90 deg.) for the tube. One rivet to attach, liberal dose of pro-seal. I anyone's interested can send a jpeg. If I have erred here, somebody let me know before I button this sucker up! From the PossumWorks in TN Mark Phillips -6A, starting other wing... ________________________________________________________________________________
Date: Jun 17, 2000
> Gee...when was the last time I saw a tri-gear ground loop.... When the nose gear broke :-( Sorry, Russell Duffy Navarre, FL RV-8, sn-587, N174KT (flying 7 hours- raining for 3 days now...) ________________________________________________________________________________
Date: Jun 17, 2000
Subject: RV-8 Boo Boo (HELP ASAP)
This is my first attempt at posting a message, I hope my protocol is correct. My project is a RV-8. Currently working on my HORAZONTAL STABILIZER. I think I just made my first BIG error. My concern is that I was too aggressive when trimming the ears off HS-814 (to clear the rib flange and skin). Sent a picture to Van's and from eyeballing it they though I should replace HS-814. Oh @#&#@#, was just ready to skin the darn thing. I think that when I mate the Horz Stab to the fuselage I won't have the edge clearance on the outside AN3,10-3 bolt of HS-814. To help me determine this, is there an "8" builder out there that can from his full size plans or actually measuring the width of the fuselage (to the outside of the F-887 Longerons) (DWG-27) at the bolt line through HS-814? This may help me determine if I have to chance destroying my Stab trying to drill out the 14 rivets on HS-814. The thought makes me shudder. If any HELPERS could email me direct or call me collect at pincjt(at)ix.netcom.com or 515-277-4173. Boy I feel like a dope, thanks in advance for any assistance. It's been great until now! Jack ________________________________________________________________________________
Subject: Re: Modification of F-621 canopy deck
Date: Jun 17, 2000
> Regarding RV-6 tip-up, F-621 > > I am considering modifying my F-621 canopy deck to make room for an > instrument in the lower left of the panel. Has anyone else done this? > Can anyone see a reason I shouldn't do this? Can anyone suggest how I > might do this? The basic interference problem is becaue the F-621 > angles inward as it goes forward. F-621 looks structural to me. I doubt that we can put more than holes in it. To interupt the inside edge might be a no no. Lets call the factory and ask. I'll do it for you. Stay tuned, I'll re-post the results on Monday night. Many have had to lower their panels to accomodate their panel requirements. I have two cardboard designs right now and on is 1 1/2" lower and the other is 1 3/4" lower. Neither bothers my legs for room when I sit in it. Regards, Norman Hunger RV6A Delta BC ________________________________________________________________________________
Date: Jun 17, 2000
Mark: Your installation sounds good to me. What I did with my pickup tube was to place it so that its tip was just outboard of the drain hole. This allows any water to accumulate in the corner where the drain is, but will not get sucked up into the fuel pickup. Downside is that I have just a tad less usable fuel, but maybe also just a tad more piece of mind when it comes to water in the fuel. Regards, Jeff Orear RV6A second wing bottom skin riveting Peshtigo, WI -----Original Message----- From: Mark Phillips <ripsteel(at)edge.net> Date: Saturday, June 17, 2000 11:04 AM Subject: Re: RV-List: Fuel Pickup Checking > >Maybe what I did is a bad idea, but I gotta ask just because it hasn't >been mentioned. > >When I installed the pickup tube, I positioned the end of it directly >over the drain hole so that I could remove the drain (empty tank >first?!) >and inspect for/clean trash from the pickup screen on the end of the >tube. It seems that in this location it would be simple to visually >ascertain that the tube is in the correct position after re-installation >or tightening of the fuel line. > >I also combined the fuel fitting spacer with the anti-rotate tab by >using a strip of .040 about 3" long with a hole in one end for the >fitting and a notch in the other end (bent 90 deg.) for the tube. One >rivet to attach, liberal dose of pro-seal. I anyone's interested can >send a jpeg. > >If I have erred here, somebody let me know before I button this sucker >up! > >>From the PossumWorks in TN >Mark Phillips -6A, starting other wing... > > ________________________________________________________________________________
Date: Jun 17, 2000
Jeff, Piece of mind is a good thing- now if I only had one... From the PossumWorks Mark Jeff Orear wrote: > > > Mark: > > Your installation sounds good to me. What I did with my pickup tube was to > place it so that its tip was just outboard of the drain hole. This allows > any water to accumulate in the corner where the drain is, but will not get > sucked up into the fuel pickup. Downside is that I have just a tad less > usable fuel, but maybe also just a tad more piece of mind when it comes to > water in the fuel. > > Regards, > > Jeff Orear > RV6A > second wing bottom skin riveting > Peshtigo, WI > -----Original Message----- > From: Mark Phillips <ripsteel(at)edge.net> > To: rv-list(at)matronics.com > Date: Saturday, June 17, 2000 11:04 AM > Subject: Re: RV-List: Fuel Pickup Checking > > > > >Maybe what I did is a bad idea, but I gotta ask just because it hasn't > >been mentioned. > > > >When I installed the pickup tube, I positioned the end of it directly > >over the drain hole so that I could remove the drain (empty tank > >first?!) > >and inspect for/clean trash from the pickup screen on the end of the > >tube. It seems that in this location it would be simple to visually > >ascertain that the tube is in the correct position after re-installation > >or tightening of the fuel line. > > > >I also combined the fuel fitting spacer with the anti-rotate tab by > >using a strip of .040 about 3" long with a hole in one end for the > >fitting and a notch in the other end (bent 90 deg.) for the tube. One > >rivet to attach, liberal dose of pro-seal. I anyone's interested can > >send a jpeg. > > > >If I have erred here, somebody let me know before I button this sucker > >up! > > > >>From the PossumWorks in TN > >Mark Phillips -6A, starting other wing... > > > > > ________________________________________________________________________________
Date: Jun 17, 2000
Subject: Magneto gears
Does anyone have magneto gears they want to sell? Looking for Lycoming part numbers 72495 and 61163. If so, send a note to nowakod(at)us.ibm.com. These gears are for my 0-320-B2C in my -6. I understand that Lycoming now makes one gear that will cover both of the above part numbers...that part number is 68C19622. Any insight on a good place to get these would also be appreciated...don ________________________________________________________________________________
Date: Jun 17, 2000
Subject: Re: 8 vs. 8A (viewing pictures)
You might be able to view the pictures by checking the "as web page" option. Open "My Documents" and you will find the "as web page" under the "view" on the tool bar. Good luck. Rollin ________________________________________________________________________________
Subject: Mountain Tour 2000
Date: Jun 17, 2000
Listers: I got back yesterday at 3PM from a trip around the Western US in my airplane. I had a REAL nice time. The route was Carlsbad, NM to Gallup, NM to Cedar City, Utah to Cameron Park (Sacramento), CA to Boise, ID to Missoula, MT to Grand Junction, CO back to Carlsbad. Other states flown over were Arizona, Oregon, Wyoming and Utah. This was about 2485 nautical (2862 statute) miles and was flown in a total of 16.4 hours for an average fuel burn of 7.89 gph at 151 knots (175 mph). I flew almost totally in the mornings. I kept good performance records, and experimented quite a bit with high altitudes. One of the high points was south of the Uintah Mountains in Utah where I was at 17,500 feet at a TAS of 164 knots at a GS of 206 knots (238 mph) while sipping fuel at about 7.5 gph. Life is good. I am trying to write this trip up on my web page, with pictures, but it is going to take a while. I'm afraid I am going to run out of server space also, so the project might not get finished. In the meantime, I do have day one up on my web page. The two big surprises were the low fuel burn and the low average speed. Part of the reason for the fuel burn has to be the amount of time I spent above 12,500. Of course, my cruise speeds were much higher than the average speed. Part of the problem was deviations for weather and sightseeing and I think a significant factor is my inability to recapture lost speed on the climb in the descent. I just cannot speed up much without overspeeding my prop. I have to throttle way back, even if I start letting down 30 minutes out. Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: Jun 17, 2000
Subject: SCAPOOSE
Who, if anyone, is planning on going to Scapoose, Oregon on June 24th??? Let me know off-list if possible. I plan on making the trip. Jim Nice Arlington, WA ________________________________________________________________________________
Subject: Re: Mountain Tour 2000
Date: Jun 17, 2000
> >Larry, > >Thanks for sharing the excellent photos and narration of your trip. My >wife was looking at the pictures with me. Just might get her to go on a >trip afterall! (She's not as enthusiastic about the RV as I am). What kind >of camera are you using? Great pictures. > Thank you Jerry. Well I'm just using a 35mm SLR (Nikon FM). To tell the truth I am not very happy about taking pictures through canopies. Previously I owned a Pacer and loved the ability to take the door off for photography. On this trip I found out that pictures taken under an overcast turn out much better (later in the trip where it was snowing). The pictures taken in sunlight almost always have reflections and/or are washed out. That is in addition to the loss of quality due to the poor optical qualities of the canopy. Anyway, the pictures are sufficient to get the idea across. Larry Pardue ________________________________________________________________________________
Date: Jun 17, 2000
Larry, Thank you very much. Those are the most amazing photos. I know you probably think it's all pretty normal, but here in sunny (FLAT) Florida there isn't much of that to see. I did, however, once fly over the power plant out near cedar key....a very tall structure. :-) Sure we can buzz down the beach....but that doesn't really compare to the pics you shared. New motivation to finish my blazing trail of RV building. I really want to see all of that up close and personal. Bill -4 wings ----- Original Message ----- From: "Larry Pardue" <n5lp(at)carlsbad.net> Sent: Saturday, June 17, 2000 10:55 PM Subject: Re: RV-List: Mountain Tour 2000 > > > > > >Larry, > > > >Thanks for sharing the excellent photos and narration of your trip. My > >wife was looking at the pictures with me. Just might get her to go on a > >trip afterall! (She's not as enthusiastic about the RV as I am). What kind > >of camera are you using? Great pictures. > > > > > Thank you Jerry. > > Well I'm just using a 35mm SLR (Nikon FM). To tell the truth I am not very > happy about taking pictures through canopies. Previously I owned a Pacer > and loved the ability to take the door off for photography. > > On this trip I found out that pictures taken under an overcast turn out much > better (later in the trip where it was snowing). The pictures taken in > sunlight almost always have reflections and/or are washed out. That is in > addition to the loss of quality due to the poor optical qualities of the > canopy. Anyway, the pictures are sufficient to get the idea across. > > Larry Pardue > > ________________________________________________________________________________
Subject: Re: RV-8 Boo Boo (HELP ASAP)
Date: Jun 17, 2000
Jack - it's still great :-)). If Vans recommends that you remake a part, then it is a good idea to follow their advice. I have replaced MANY mis-built parts over the course of building my RV-6. Thats how we all learn. The part you are concerned about is a very important structural part and should be made correctly. Just go on to another part until the replacement piece from Vans arrives. Keep building and have fun ! ----------------------------------------------------- Doug Murray RV-6 C-GRPA Southern Alberta ----- Original Message ----- From: <pincjt(at)ix.netcom.com> Sent: Saturday, June 17, 2000 10:31 AM Subject: RV-List: RV-8 Boo Boo (HELP ASAP) > > This is my first attempt at posting a message, I hope my protocol is correct. My project is a RV-8. Currently working on > my HORAZONTAL STABILIZER. I think I just made my first BIG error. My concern is that I was too aggressive when > trimming the ears off HS-814 (to clear the rib flange and skin). Sent a picture to Van's and from eyeballing it they though I > should replace HS-814. Oh @#&#@#, was just ready to skin the darn thing. I think that when I mate the Horz Stab to the > fuselage I won't have the edge clearance on the outside AN3,10-3 bolt of HS-814. To help me determine this, is there an > "8" builder out there that can from his full size plans or actually measuring the width of the fuselage (to the outside of the > F-887 Longerons) (DWG-27) at the bolt line through HS-814? This may help me determine if I have to chance destroying > my Stab trying to drill out the 14 rivets on HS-814. The thought makes me shudder. If any HELPERS could email me > direct or call me collect at pincjt(at)ix.netcom.com or 515-277-4173. Boy I feel like a dope, thanks in advance for any > assistance. It's been great until now! > Jack > > ________________________________________________________________________________
Date: Jun 18, 2000
Subject: Travel to OK City
I'll be in OK City for about 10 days starting this Monday. Are there any notable events next weekend? (Yes, I know. We just missed 'Air America.') Charlie flying -4 ________________________________________________________________________________
Subject: Solen Radios
Date: Jun 17, 2000
Message to follow not purely RV related...Hit delete now if desired. This past week I had the entire radio stack from my 1967 Bonanza forcibly removed after the hanger was broken into. Since I had a stainless steel bar with locking mechanism installed after the previous theft in 1993, there was considerable damage to the panel and repairs and replacement will be a small fortune. Since I am a list lurker and contributor I would like to ask for the list's help if possible. It appears that 4 airports were hit that night including a deaf pilot who lost all of his specialized voice recognition radio equipment. This seems to be a person or persons who "case" airports finding suitable aircraft and then strike many at one time. The radios are all King as other radios are ignored. Since there must be a market for these radios to make them useful I would like to ask the list for any information you might have regarding offers to sell you radios without serial numbers, or yellow tags or at discounted prices. This informatin will be given to the sheriff's department and to USAIG the insurance company and their investigator. I would hope to do something to prevent any of you from suffering the anguish I felt when I opened the door and found a giant hole ripped in the panel. I felt violated and I had enough thoughts of revenge to do Hannibal Lecter proud. Rather than become an avenging mad man I hope to channel this anger into something useful and stop these thieves once and for all. Thank you for letting me vent. Bob Kellar RV6A (Planning for a move to the airport next month after 10 long years. SN 20988) ________________________________________________________________________________
Date: Jun 18, 2000
If you want to find a market for the radios, look no farther than your friendly electronic auction. I am sure a large bit gets sold there, so much stuff is sold, it's hard to keep track. I would sugest you contact your local police, asking for help in patrolling the airport.......that will not do much, but will get the idea across.....I would suggest you get the word out, try finding a Police Officer/Deputy Sheriff and try giving him a ride, and a chance to take the controls..... I have been a police officer for over 10 years...took me a flight to get me interested and I patrol the local airport every night....have not had any problems at our place since. Also got me interested in RV's, now if I could find someone close to help me get past my fright, and get into actually building my RV instead of just looking over the parts and plans.....Hard to take that 1st step..... anyone close, mind if I look over thier shoulder a little. Dave Cimperman New Philadelphia Ohio ---- Original Message ---- From: rjkellar(at)softcom.net Subject: RE: RV-List: Solen Radios Date: Sat, 17 Jun 2000 22:59:53 -0700 > >Message to follow not purely RV related...Hit delete now if desired. This >past week I had the entire radio stack from my 1967 Bonanza forcibly removed >after the hanger was broken into. Since I had a stainless steel bar with >locking mechanism installed after the previous theft in 1993, there was >considerable damage to the panel and repairs and replacement will be a small >fortune. Since I am a list lurker and contributor I would like to ask for >the list's help if possible. It appears that 4 airports were hit that night >including a deaf pilot who lost all of his specialized voice recognition >radio equipment. This seems to be a person or persons who "case" airports >finding suitable aircraft and then strike many at one time. The radios are >all King as other radios are ignored. Since there must be a market for >these radios to make them useful I would like to ask the list for any >information you might have regarding offers to sell you radios without >serial numbers, or yellow tags or at discounted prices. This informatin >will be given to the sheriff's department and to USAIG the insurance company >and their investigator. I would hope to do something to prevent any of you >from suffering the anguish I felt when I opened the door and found a giant >hole ripped in the panel. I felt violated and I had enough thoughts of >revenge to do Hannibal Lecter proud. Rather than become an avenging mad man >I hope to channel this anger into something useful and stop these thieves >once and for all. Thank you for letting me vent. >Bob Kellar >RV6A (Planning for a move to the airport next month after 10 long years. SN >20988) > > Tusco.Net, Inc. The Best ISP. ________________________________________________________________________________
Date: Jun 18, 2000
Subject: Lexan requires a higher temperature
I am a plastic Fabricator by trade, Lexan forms at approximately 360 F. Lexan also absorbs moisture. Since the forming temp is above the point that moisture turns to steam, the moisture will turn to steam inside of the plastic when it reaches a point above 312 F. If you dry the plastic @ 250 F for approx 12 hours per 1/8" of thickness, You can eliminate the moisture in the plastic. You can then successfully heat it all the way to 400 F with out the bubbles forming since you have driven the moisture out of the plastic. 400 F is the upper limit of the forming temp. It is what I use for deep vacuum forms when I need a very soft form to get all of the detail I need. In a message dated 06/18/2000 2:58:48 AM Eastern Daylight Time, rv-list-digest(at)matronics.com writes: << As I recall, the temp was in the mid 300's F range. Lexan requires a higher temperature than plexiglas. I learned that it is best to get the oven temperature stabilized so that the oven doesn't cycle ON while the glass is in the oven. If it does, the glass bubbles due to the concentration of heat. >> ________________________________________________________________________________
Date: Jun 18, 2000
Subject: Re: Magneto gears
In a message dated 6/17/00 5:12:49 PM Eastern Daylight Time, Aero7ac(at)AOL.COM writes: << Does anyone have magneto gears they want to sell? Looking for Lycoming part numbers 72495 and 61163. If so, send a note to nowakod(at)us.ibm.com. These gears are for my 0-320-B2C in my -6. I understand that Lycoming now makes one gear that will cover both of the above part numbers...that part number is 68C19622. Any insight on a good place to get these would also be appreciated...don >> Try Jeff Rose at Electroair. He usually carries them, or knows where to get 'em. Also, most aircraft salvage places (Wentworth, etc) will have them. Prices are usually $60 - $100 ea.. KB ________________________________________________________________________________
Date: Jun 18, 2000
> Just go on to another part until the replacement > piece from Vans arrives. In a month. ________________________________________________________________________________
Subject: GPS
Date: Jun 18, 2000
I heard recently that a NOTAM was issued in June of 1998 that allows IFR approved GPS units to be used to identify any DME fix or ADF/LOM. I did a search of the FAR's and can find no reference. Does anyone know if an IFR approved GPS can be used is such a manner. I would really like to read it for myself if you can point me in the right direction. Also, does the statement only apply to approach approved units or can an enroute/terminal area approved unit like the Apollo GX-65 be used to identify DME fixes? Just starting to think about avionics and panels and such. Where can I find information detailing what has to be done to have a legal installation in an experimental? How much can I do and how much HAS to be farmed out? I keep having nightmares about spending huge amounts of time and money only to have an inspector waltz in, wave a list of requirements that I've never seen and tell me everything I've done is unacceptable. Vince RV-8A Planning ahead ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Subject: Primer Line Silver Solder
Date: Jun 18, 2000
I am ready to solder the AN800-2 globe unions to the 1/8 OD copper tubing for the primers. 1) Where do I obtain small quantities of silver solder? 2) What is the melting point of 1)? 3) Can I use propane or do I need ox-acetylene? I found some silver solder at Tower Hobbies but it melts at 430F which seems too low. Dennis Persyk 6A finishing kit Hampshire, IL C38 ________________________________________________________________________________
Subject: Re: Primer Line Silver Solder
Date: Jun 18, 2000
> >I am ready to solder the AN800-2 globe unions to the 1/8 OD copper tubing >for the primers. >1) Where do I obtain small quantities of silver solder? >2) What is the melting point of 1)? >3) Can I use propane or do I need ox-acetylene? > I got my silver solder at the local welding supply shop. I used an acetylene (no oxygen) torch. Don't know if propane would get hot enough, but I doubt it. The metal is red hot when it is just hot enough, at least with the silver solder formulation I used (can't remember now what it was. Just told the guy what I was going to do, and he told me what to buy). Larry Pardue Carlsbad, NM RV-6 N441LP Flying ________________________________________________________________________________
Date: Jun 18, 2000
Dennis, Acetylene without oxygen burns very sooty and contains to much carbon. You can purchase a Bernz O Matic torch from home depot that burns Mapp gas and will work well with silver solder. Jim Streit RV-9 emp. Dennis Persyk wrote: > > I am ready to solder the AN800-2 globe unions to the 1/8 OD copper tubing > for the primers. > 1) Where do I obtain small quantities of silver solder? > 2) What is the melting point of 1)? > 3) Can I use propane or do I need ox-acetylene? > > I found some silver solder at Tower Hobbies but it melts at 430F which seems > too low. > > Dennis Persyk 6A finishing kit > Hampshire, IL C38 > ________________________________________________________________________________
Subject: Need measurments for paint booth
Date: Jun 17, 2000
Hi all, I'm getting ready to build a paint booth that will take my RV-8 fuse. Can someone furnish me the following dimensions? landing gear spread: firewall to vert. fin (not including rudder) Thanks! - Bill in Tucson awaiting -8 quick build ________________________________________________________________________________
Subject: Leading Edge Landing Lights
Date: Jun 18, 2000
There is some thing very simple that can be done to the leading edge landing lights to make them better. Paint the entire inside of the cavity white. The whole thing becomes a light. They will cast a glow towards their peripherals that you will notice when taxing on the ground. Not a huge difference but it will cast more light around. It might make them more visible to other aircraft when flying as well. Years ago guys were saying to put a strip of the shiny foil tape across the top inside the compartment. Try the white paint. It will do more. It also looks quite sharp. Norman Hunger RV6A Delta BC ________________________________________________________________________________
Date: Jun 18, 2000
From: David & Betty Burton <dburton(at)foxinternet.net>
Subject: Re: SCAPOOSE
JNice51355(at)AOL.COM wrote: > > Who, if anyone, is planning on going to Scapoose, Oregon on June 24th??? Let > me know off-list if possible. Hi Jim, I intend to be there. I'm going down to Van's earlier in the week with my motorhome, and then intend to help with the fly-in set up. Let's hope for better weather then today (rain and 60). Dave Burton RV6 Seattle ________________________________________________________________________________
Date: Jun 18, 2000
Subject: RV-8 wing rivetting sequence
So- I've got all of my wing skeleton and skins primed, but I haven't yet started on my tanks (other than fitting the z-brackets to the main spar). I'd like to rivet on the leading edge assembly and the top skins before I start building the tanks- mostly so I can feel like I'm progressing, but also so I can get some of my clecoes back! Is there any problem doing this? I can't see any from studying the plans, but the manual has you build the tanks before riveting on the skins- and my other plan deviations have met with disaster. The only objection I can think of to riveting the entire wing together first is that with the bottom skins on, you couldn't use a countersink cage to countersink the nutplates holes that attach the bottom edge of the tank to the spar... Any advice would be appreciated! Matthew Gelber -8A ________________________________________________________________________________
Subject: Engine level w/longerons?
Date: Jun 18, 2000
Listers, Although this question pertaints to my RV-8 I believe the principal would apply to all RVs, so here goes. About six months ago at a local builder's group meeting at my house Bill Benedict was showing another builder how the top of the engine should be level with the main longerons. He had someone raise the tail and shim it so as to level the fuse as measured with a bubble level on the cockpit sides (longerons). He then put the bubble level on the engine to demonstrate this. He indicated you could measure it longitudinally on the tops of the valve covers, tops of the head castings, or the pushrod tubes. Using the bubble level on all three showed the same results. Turns out my engine was not exactly level with the longerons, but rather tilted up a bit. My buddy's SmartLevel was not there at the time so I do not know the precise difference in degrees. I've been thinking about this in the months since wondering whether to worry about it or not. The prop (constant speed) was not mounted at the time and there was some speculation that that weight would bring it down. I am now about to mount my cowl and will need to either address it or not. After doing some preliminary cutting last night on the cowl top half it does appear that the rear of the spinner is not parallel with the face of the cowl, but of course this could be a problem with the cowl (Sam James) as well. No where in the manual or the plans is there any mention of checking that the engine, and thus horizontal thrust line. I could make a small adjustment here by moving some washers in the upper engine mount thus tilting the engine down slightly, but I have never heard any mention on the list of anyone doing this. I have no idea how much that would change things. So here's the question: what does anyone know about this, and should it be addressed (removing my baffling etc. to get to the right hand nut!)? Thanks to those who know, Randy Lervold RV-8, #80500, fwf www.rv-8.com Home Wing VAF... annual fly-in next Saturday at Scappoose! ________________________________________________________________________________
Date: Jun 18, 2000
I silver solder band saw blades with just a propane torch. Works very well. If you need a little more heat use MAP gas. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) ----- Original Message ----- From: "Larry Pardue" <n5lp(at)carlsbad.net> Sent: Sunday, June 18, 2000 10:35 AM Subject: Re: RV-List: Primer Line Silver Solder > > > > >I am ready to solder the AN800-2 globe unions to the 1/8 OD copper tubing > >for the primers. > >1) Where do I obtain small quantities of silver solder? > >2) What is the melting point of 1)? > >3) Can I use propane or do I need ox-acetylene? > > > > > I got my silver solder at the local welding supply shop. > > I used an acetylene (no oxygen) torch. Don't know if propane would get hot > enough, but I doubt it. The metal is red hot when it is just hot enough, at > least with the silver solder formulation I used (can't remember now what it > was. Just told the guy what I was going to do, and he told me what to buy). > > Larry Pardue > Carlsbad, NM > > RV-6 N441LP Flying > > ________________________________________________________________________________
Date: Jun 18, 2000
Since the primer lines are LOW pressure there is no need for anything but ordinary solder. Silver solder is necessary for Injector lines as they are HIGH pressure. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) ----- Original Message ----- From: "Larry Pardue" <n5lp(at)carlsbad.net> Sent: Sunday, June 18, 2000 10:35 AM Subject: Re: RV-List: Primer Line Silver Solder > > > > >I am ready to solder the AN800-2 globe unions to the 1/8 OD copper tubing > >for the primers. > >1) Where do I obtain small quantities of silver solder? > >2) What is the melting point of 1)? > >3) Can I use propane or do I need ox-acetylene? > > > > > I got my silver solder at the local welding supply shop. > > I used an acetylene (no oxygen) torch. Don't know if propane would get hot > enough, but I doubt it. The metal is red hot when it is just hot enough, at > least with the silver solder formulation I used (can't remember now what it > was. Just told the guy what I was going to do, and he told me what to buy). > > Larry Pardue > Carlsbad, NM > > RV-6 N441LP Flying > > ________________________________________________________________________________
Date: Jun 18, 2000
Subject: Re: RV-8 wing rivetting sequence
> >So- I've got all of my wing skeleton and skins primed, but I haven't yet >started on my tanks (other than fitting the z-brackets to the main spar). >I'd like to rivet on the leading edge assembly and the top skins before I >start building the tanks- mostly so I can feel like I'm progressing, but >also so I can get some of my clecoes back! > >Is there any problem doing this? I can't see any from studying the plans, >but the manual has you build the tanks before riveting on the skins- and my >other plan deviations have met with disaster. The only objection I can >think of to riveting the entire wing together first is that with the bottom >skins on, you couldn't use a countersink cage to countersink the nutplates >holes that attach the bottom edge of the tank to the spar... > >Any advice would be appreciated! > >Matthew Gelber Matthew, The only problem I can think of is those nutplates. I'm not sure how you plan to countersink them if you do the top skins first. You want these countersinks to be well done, so I wouldn't mess around trying to do them freehand. My recommendation is to beg, borrow or buy some more clecoes. You might find a local guy who has his project flying, or almost flying who would loan you some clecoes. Kevin Horton RV-8 (cockpit stuff) Ottawa, Canada http://members.xoom.com/kevinhorton/rv8.html ________________________________________________________________________________
Date: Jun 18, 2000
From: David Roseblade <davidagr(at)emirates.net.ae>
Matthew, I am building an RV6, so I am not sure if the same applies, but on a "6" if you rivet the skins on before locating and drilling the tank screw locations you may have difficulty fitting the anchor (plate nuts) for the tanks, on a 6 it is a question of grind to avoid spar strips, check , grind a bit more then use squeezers to install - with the skins installed access is reduced. Additionally I had to file a small amount off each wing and tank skin to have a "snug" fit with minimum gap (1/64). Hope above helps Regards David Roseblade RV6A wings Persian Gulf - Dubai ________________________________________________________________________________
Date: Jun 18, 2000
-----Original Message----- From: Cy Galley <cgalley(at)qcbc.org> Date: Sunday, June 18, 2000 2:03 PM Subject: Re: RV-List: Primer Line Silver Solder > >Since the primer lines are LOW pressure there is no need for anything but >ordinary solder. Silver solder is necessary for Injector lines as they are >HIGH pressure. > >Cy Galley - Editor, B-C Contact! >(Click here to visit our Club site at http://www.bellanca-championclub.com) > Cy, I was shocked to see this recommendation, but since you seem to know whereof you speak, could you help me out of my state of shock by pointing out where I'm wrong? Here's my reasoning: 1) Ordinary solder is 50/50 Tin/Lead, and has a solidus temp of 361F, liquidus temp of 421F (Machinery's Handbook, 24th Ed, p 1250). 2)The cylinder head max temp of my O360A1A is 500F, and recommended operating range is 150F to 400F (Lycoming Operator's Manual, A-section). 3) The AN800-2 globe unions are thermally intimate with the cylinder heads via copper tubing and brass primer fittings. 4) Sooooo, it seems to me that the ordinary solder will be quite soft at normal cylinder head operating temperatures, and fully melted within the allowed head temperature range. Therefore I thought that ordinary solder would by inappropriate in this application. Not so? I had not even considered the question of the pressure in the lines because as you say, it is low. Dennis Persyk 6A finishing kit Hampshire, IL C38 > >> >> > >> >I am ready to solder the AN800-2 globe unions to the 1/8 OD copper tubing >> >for the primers. >> >1) Where do I obtain small quantities of silver solder? >> >2) What is the melting point of 1)? >> >3) Can I use propane or do I need ox-acetylene? >> > ________________________________________________________________________________
Date: Jun 18, 2000
Are the head temps you are using measured at the Spark plug or using the probe wells? Since the primer port is so close to the intake, I would be surprised that the temperature is much above 300 degrees. I know a Shyhawk that I unbrazed the ball end off an injection line and then soft soldered it on to the 320 engine primer line for the Hawk. This was over 10 years ago. I believe it is still working. But if you are a belt and suspenders man, silver solder it. P.S. You can also use compression type fittings which are much cheaper. National Air Parts Association handles them. Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) ----- Original Message ----- From: "Dennis Persyk" <dpersyk(at)worldnet.att.net> Sent: Sunday, June 18, 2000 2:58 PM Subject: Re: RV-List: Primer Line Silver Solder > > > -----Original Message----- > From: Cy Galley <cgalley(at)qcbc.org> > To: rv-list(at)matronics.com > Date: Sunday, June 18, 2000 2:03 PM > Subject: Re: RV-List: Primer Line Silver Solder > > > > > >Since the primer lines are LOW pressure there is no need for anything but > >ordinary solder. Silver solder is necessary for Injector lines as they are > >HIGH pressure. > > > >Cy Galley - Editor, B-C Contact! > >(Click here to visit our Club site at http://www.bellanca-championclub.com) > > > Cy, > I was shocked to see this recommendation, but since you seem to know whereof > you speak, could you help me out of my state of shock by pointing out where > I'm wrong? Here's my reasoning: > 1) Ordinary solder is 50/50 Tin/Lead, and has a solidus temp of 361F, > liquidus temp of 421F (Machinery's Handbook, 24th Ed, p 1250). > 2)The cylinder head max temp of my O360A1A is 500F, and recommended > operating range is 150F to 400F (Lycoming Operator's Manual, A-section). > 3) The AN800-2 globe unions are thermally intimate with the cylinder heads > via copper tubing and brass primer fittings. > 4) Sooooo, it seems to me that the ordinary solder will be quite soft at > normal cylinder head operating temperatures, and fully melted within the > allowed head temperature range. Therefore I thought that ordinary solder > would by inappropriate in this application. Not so? I had not even > considered the question of the pressure in the lines because as you say, it > is low. > > Dennis Persyk 6A finishing kit > Hampshire, IL C38 > > > >> > > >> > > >> >I am ready to solder the AN800-2 globe unions to the 1/8 OD copper > tubing > >> >for the primers. > >> >1) Where do I obtain small quantities of silver solder? > >> >2) What is the melting point of 1)? > >> >3) Can I use propane or do I need ox-acetylene? > >> > > > ________________________________________________________________________________
Date: Jun 18, 2000
What happens to the solder temperatures when you use the more common 60/40 alloy. Does the solidus temperature go up? As I remember the eutectic point was very low at a certain ratio as pure lead melts at 621 Degree F? Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) ----- Original Message ----- From: "Dennis Persyk" <dpersyk(at)worldnet.att.net> Sent: Sunday, June 18, 2000 2:58 PM Subject: Re: RV-List: Primer Line Silver Solder > > > -----Original Message----- > From: Cy Galley <cgalley(at)qcbc.org> > To: rv-list(at)matronics.com > Date: Sunday, June 18, 2000 2:03 PM > Subject: Re: RV-List: Primer Line Silver Solder > > > > > >Since the primer lines are LOW pressure there is no need for anything but > >ordinary solder. Silver solder is necessary for Injector lines as they are > >HIGH pressure. > > > >Cy Galley - Editor, B-C Contact! > >(Click here to visit our Club site at http://www.bellanca-championclub.com) > > > Cy, > I was shocked to see this recommendation, but since you seem to know whereof > you speak, could you help me out of my state of shock by pointing out where > I'm wrong? Here's my reasoning: > 1) Ordinary solder is 50/50 Tin/Lead, and has a solidus temp of 361F, > liquidus temp of 421F (Machinery's Handbook, 24th Ed, p 1250). > 2)The cylinder head max temp of my O360A1A is 500F, and recommended > operating range is 150F to 400F (Lycoming Operator's Manual, A-section). > 3) The AN800-2 globe unions are thermally intimate with the cylinder heads > via copper tubing and brass primer fittings. > 4) Sooooo, it seems to me that the ordinary solder will be quite soft at > normal cylinder head operating temperatures, and fully melted within the > allowed head temperature range. Therefore I thought that ordinary solder > would by inappropriate in this application. Not so? I had not even > considered the question of the pressure in the lines because as you say, it > is low. > > Dennis Persyk 6A finishing kit > Hampshire, IL C38 > > > >> > > >> > > >> >I am ready to solder the AN800-2 globe unions to the 1/8 OD copper > tubing > >> >for the primers. > >> >1) Where do I obtain small quantities of silver solder? > >> >2) What is the melting point of 1)? > >> >3) Can I use propane or do I need ox-acetylene? > >> > > > ________________________________________________________________________________
Date: Jun 18, 2000
Don: I am rebuilding a set of Bendix Mags -20 and 21 for my RV-6. I might have one gear left over, I will check tomorrow at the airport. I will let you know off line if I will be able to help. Harvey ----- Original Message ----- From: <KBoatri144(at)AOL.COM> Sent: Sunday, June 18, 2000 9:46 AM Subject: Re: RV-List: Magneto gears > > In a message dated 6/17/00 5:12:49 PM Eastern Daylight Time, Aero7ac(at)AOL.COM > writes: > > << Does anyone have magneto gears they want to sell? Looking for Lycoming > part > numbers 72495 and 61163. If so, send a note to nowakod(at)us.ibm.com. > These gears are for my 0-320-B2C in my -6. I understand that Lycoming now > makes one gear that will cover both of the above part numbers...that part > number is 68C19622. Any insight on a good place to get these would also be > appreciated...don >> > > Try Jeff Rose at Electroair. He usually carries them, or knows where to get > 'em. Also, most aircraft salvage places (Wentworth, etc) will have them. > Prices are usually $60 - $100 ea.. > > KB > > ________________________________________________________________________________
Date: Jun 18, 2000
Subject: Re: tip up canopy kit to slider conversion????
If the canopy has not been started then I should think it would be a simple chore of ordering all the correct parts for the slider and tossing the tip up parts in the scrap bin. If the canopy is done we are talking major surgery here but it can be done. Gary Zilik RV-6A N99PZ lucky macy wrote: > > Can a 6A tip up canopy QUICK BUILD kit be converted to a slider easily or > are we talking some surgery here? (the archive doesn't want to load up this > morning). > > TIA, ________________________________________________________________________________
Date: Jun 18, 2000
Subject: Re: Dumb and Dumber
that is excellent advise. LOOK b 4 u drill!! ________________________________________________________________________________
Date: Jun 18, 2000
For those who don't know what the word EUTECTIC means, I found this at http://dictionary.com I sure didn't eutectic (yoo-tektik) adj. 1.Of, relating to, or formed at the lowest possible temperature of solidification for any mixture of specified constituents. Used especially of an alloy whose melting point is lower than that of any other alloy composed of the same constituents in different proportions. 2.Exhibiting the constitution or properties of such a solid. n. 1.A eutectic mixture, solution, or alloy. 2.The eutectic temperature. [From Greek eutktos, easily melted: eu-, eu- + tktos, melted (from tkein, to melt).] Cy Galley wrote: > > What happens to the solder temperatures when you use the more common 60/40 > alloy. Does the solidus temperature go up? As I remember the eutectic point > was very low at a certain ratio as pure lead melts at 621 Degree F? > ________________________________________________________________________________
Date: Jun 18, 2000
I would have added the melting point of Tin as well as lead. Both melt well above 500 degrees F but when alloyed, the melting temp drops. The minimum temp is the eutectic point. It happens with a certain ratio of the two metals. Change the percentages and the melting temp goes back up. I am almost certain that the minimum or eutectic point is not at the 50/50 mix. The normal mix for electronics is 60/40. BTW, I am glad my memory hasn't really gone away. It has been 50 years since I used that word in earnest!!! Cy Galley - Editor, B-C Contact! (Click here to visit our Club site at http://www.bellanca-championclub.com) ----- Original Message ----- From: "Gary Zilik" <zilik(at)bewellnet.com> Sent: Sunday, June 18, 2000 5:54 PM Subject: Re: RV-List: Primer Line Silver Solder > > For those who don't know what the word EUTECTIC means, I found this at > http://dictionary.com I sure didn't > > eutectic (yoo-tektik) > adj. > > 1.Of, relating to, or formed at the lowest possible temperature of > solidification for any > mixture of specified constituents. Used especially of an alloy whose > melting point is lower > than that of any other alloy composed of the same constituents in > different proportions. > 2.Exhibiting the constitution or properties of such a solid. > > n. > > 1.A eutectic mixture, solution, or alloy. > 2.The eutectic temperature. > > > [From Greek eutktos, easily melted: eu-, eu- + tktos, melted (from tkein, to > melt).] > > Cy Galley wrote: > > > > > What happens to the solder temperatures when you use the more common 60/40 > > alloy. Does the solidus temperature go up? As I remember the eutectic point > > was very low at a certain ratio as pure lead melts at 621 Degree F? > > > > ________________________________________________________________________________ User-Agent: Microsoft-Outlook-Express-Macintosh-Edition/5.02.2022
Date: Jun 18, 2000
on 6/18/00 16:42, Gary Zilik at zilik(at)bewellnet.com wrote: > > If the canopy has not been started then I should think it would be a simple > chore of ordering all the correct parts for the slider and tossing the tip up > parts in the scrap bin. If the canopy is done we are talking major surgery > here > but it can be done. > > Gary Zilik > RV-6A N99PZ > > lucky macy wrote: > >> >> Can a 6A tip up canopy QUICK BUILD kit be converted to a slider easily or >> are we talking some surgery here? (the archive doesn't want to load up this >> morning). >> >> TIA, > My recollection is that the quick build my hangar mate got did not have any canopy work completed; the canopy parts come with the finish kit. Again my memory dims but don't recall that any of the "finish kit" work was done. The surgery required would entail swapping out the upper fuselage ribs between the panel and the firewall and the bulkhead, which is different. I would estimate the added time to be a week or so. The bigger issue would be getting trade in credit for the tip up parts. If you have a strong preference for the slider, I would go for it. the level of effort at this stage is very minor in the overall scheme of things. Both types of canopy have there strong advocates, although not as emotional an issue as the type of undercarriage. Personally I think they are both marvelous canopies, head and shoulders above all competition. A real strong point of the design. ......But I love my slider :+) > -- Denis L.(Bum) Walsh ________________________________________________________________________________
Date: Jun 18, 2000
Great travelogue, Larry! I like it! I have forwarded the URL to my "Westward Ho!" cohorts. I think I see another trip forming. :-) Sam Buchanan (RV-6, fresh engine, ready to travel again) "The RV Journal" http://home.hiway.net/~sbuc/journal ======================= Larry Pardue wrote: > > > Listers: > > Well I blew all my server space on this deal, but Mountain Tour 2000, my > home movies of an RV trip last week, are more or less up. Corrections have > not been made yet. > > You understand this deal is merely functional, not pretty like Sam > Buchanan's web stuff. > > > Larry Pardue > Carlsbad, NM > > RV-6 N441LP Flying > http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: Jun 18, 2000
I believe the eutetic mixture is 63-37 not 60/40. Cy Galley wrote: > > I would have added the melting point of Tin as well as lead. Both melt well > above 500 degrees F but when alloyed, the melting temp drops. The minimum > temp is the eutectic point. It happens with a certain ratio of the two > metals. Change the percentages and the melting temp goes back up. I am > almost certain that the minimum or eutectic point is not at the 50/50 mix. > The normal mix for electronics is 60/40. > > BTW, I am glad my memory hasn't really gone away. It has been 50 years > since I used that word in earnest!!! > > Cy Galley - Editor, B-C Contact! > (Click here to visit our Club site at http://www.bellanca-championclub.com) > > ----- Original Message ----- > From: "Gary Zilik" <zilik(at)bewellnet.com> > To: > Sent: Sunday, June 18, 2000 5:54 PM > Subject: Re: RV-List: Primer Line Silver Solder > > > > > For those who don't know what the word EUTECTIC means, I found this at > > http://dictionary.com I sure didn't > > > > eutectic (yoo-tektik) > > adj. > > > > 1.Of, relating to, or formed at the lowest possible temperature > of > > solidification for any > > mixture of specified constituents. Used especially of an alloy > whose > > melting point is lower > > than that of any other alloy composed of the same constituents > in > > different proportions. > > 2.Exhibiting the constitution or properties of such a solid. > > > > n. > > > > 1.A eutectic mixture, solution, or alloy. > > 2.The eutectic temperature. > > > > > > [From Greek eutktos, easily melted: eu-, eu- + tktos, melted (from > tkein, to > > melt).] > > > > Cy Galley wrote: > > > > > > > > What happens to the solder temperatures when you use the more common > 60/40 > > > alloy. Does the solidus temperature go up? As I remember the eutectic > point > > > was very low at a certain ratio as pure lead melts at 621 Degree F? > > > > > > > > ________________________________________________________________________________
Date: Jun 18, 2000
> >Great travelogue, Larry! I like it! > >I have forwarded the URL to my "Westward Ho!" cohorts. I think I see >another trip forming. :-) > >Sam Buchanan (RV-6, fresh engine, ready to travel again) >"The RV Journal" http://home.hiway.net/~sbuc/journal > Thank you Sam, And I really am sorry I don't know how to do as nice a web job as you. I know how I want it to look, but I don't have the knowledge or the software or something. Larry ________________________________________________________________________________
Date: Jun 18, 2000
Subject: What size Cleco
You would think by the time you had gotten half way through the wing's that you would know something about dimpling. The problem is that after dimpling the leading edge skin and the ribs the 3/32 cleco's won't hold, they pull through. Do I need to put scrap pieces of aluminum with a number 40 hole drilled in them to put on the back side to have some grip? What else is there to try? Mike in Texas (skinning the wings) ________________________________________________________________________________
Date: Jun 18, 2000
Mike maybe the clecos you are using do not have enough grip length. you might need some deeper ones about 1/2 " long to go through all the skin thickness. Harv > [Original Message] > From: <MRawls3896(at)AOL.COM> > To: > Date: 6/18/00 9:37:30 PM > Subject: RV-List: What size Cleco > > > You would think by the time you had gotten half way through the wing's > that you would know something about dimpling. The problem is that after > dimpling the leading edge skin and the ribs the 3/32 cleco's won't hold, they > pull through. Do I need to put scrap pieces of aluminum with a number 40 hole > drilled in them to put on the back side to have some grip? What else is there > to try? > > Mike in Texas (skinning the wings) > > > > > --- Harvey Sigmon --- flyhars(at)earthlink.net --- EarthLink: It's your Internet. ________________________________________________________________________________
From: "Dustin Norlund" <dustin_norlund(at)geotec.net>
Subject: For Sale.
Date: Jun 18, 2000
I am almost ready to get N555DN into the air and will not need the following parts I have purchased. The first email for asking price of highest offer will get the item. All items are in new condition and have only been unpacked, looked at, then put on a shelf. 1. VANS Gascolator with mounting bracket. GAS-3 and Bracket. $60.00 2. Aircraft Spruce Gascolator - The gold one like used on piper with mounting bracket. $60.00 3. Trim tab skin and trim tab spar. $10.00 .-. / \ .-. .-. / \ / \ .-. _ .-. / \ /-Dustin Norlund------------/---\--/--\------/------\- \ / \ / `-' `-' \ / \ / `-' `-' `-' KD5JXZ PPSEL RV6 N555DN www.555dn.20m.com ________________________________________________________________________________
Subject: Re: What size Cleco
Date: Jun 18, 2000
Mike: You need some of those .50 cal clecos...just kidding. Seriously, some clecos are sturdier than others, but what you can do is use # 41 drill bits. Should make a difference. Don't want to start another thread on 40 vs. 41, but to each his or her own. Pat Hatch RV-4 N17PH @ VRB RV-6, Fuselage ----- Original Message ----- From: <MRawls3896(at)AOL.COM> Sent: Sunday, June 18, 2000 9:35 PM Subject: RV-List: What size Cleco > > You would think by the time you had gotten half way through the wing's > that you would know something about dimpling. The problem is that after > dimpling the leading edge skin and the ribs the 3/32 cleco's won't hold, they > pull through. Do I need to put scrap pieces of aluminum with a number 40 hole > drilled in them to put on the back side to have some grip? What else is there > to try? > > Mike in Texas (skinning the wings) > > ________________________________________________________________________________
Date: Jun 18, 2000
Subject: re: Primer Line Silver Solder
> I am ready to solder the AN800-2 globe unions to the 1/8 OD copper tubing > for the primers. 1) Where do I obtain small quantities of silver solder? > 2) What is the melting point of 1)? 3) Can I use propane or do I need > ox-acetylene? Dennis, I bought mine at McMaster-Carr, along with the flux. The solder is .005 x 1/2" strip, and McMaster Carr got it from Prince & Izant Co, Cleveland OH, 216-362-7000. The label says ".005 x 1/2" SA 50 STRIP X 1 T.O. COIL". (I believe the solder was McMaster Carr part number 7617A14, but I'm not 100% sure. 7617A14 lists for about $19, and has a melting point of 1160F.) I used Superior Silver Solder Flux, #601, also from McMaster Carr. I was able to melt it with a propane torch, but just barely. I used it for the primer lines, and for making restrictor fittings for oil pressure and fuel pressure. It took a lot of propane torch heating, but eventually melted. Tim Lewis ****** Tim Lewis -- Springfield VA RV-6A N47TD - First Flight 18 Dec 99 TimRV6A(at)earthlink.net http://www.geocities.com/timrv6a ________________________________________________________________________________
Subject: 8 vs. 8A)
Date: Jun 18, 2000
I am contemplating a spam-can purchase with a partner for staying current while we build our RV's. I called Avemco for a comparison quote, 47 Stinson (Taildragger) vs. '61 C-172. Even though the Stinson is worth less ($17,000 vs. $26,000), full coverage with $500 deductible is $1,600 for Stinson and $960 for Cessna. Both pilots are 200 hr, PPSEL, only one of us has 25 hrs taildragger time. At least Avemco has a large differential. John Harris RV9A N922JH (reserved) ________________________________________________________________________________
Date: Jun 18, 2000
>So- I've got all of my wing skeleton and skins primed, but I haven't yet >started on my tanks (other than fitting the z-brackets to the main spar). >I'd like to rivet on the leading edge assembly and the top skins before I >start building the tanks- mostly so I can feel like I'm progressing, but >also so I can get some of my clecoes back! I drilled the tank skins to the ribs before riviting on the bottom main skins. Haven't had any problems yet. Did countersink the bottom spar screw holes with bottom skins removed. Finished both wings, now going back and riviting the tanks together. Working fine so far. Brian Huffaker, DSWL (bifft(at)xmission.com) President and Founder Friends of P-Chan RV-8 80091 Riviting fuel tanks 1/5 Starduster II N23UT flying ________________________________________________________________________________
Date: Jun 18, 2000
I am at home with a dull memory but I have a "QuickBuild" RV6A Slider and am working with a friend on a RV6 Tip-Up. So we have both in the hangar and I could take a look. But .... An earlier post is correct that there is no canopy work done in the QB. THe aft top (forward) fuselage skin has to be done along with the track etc. So the back section (AS I RECALL) is not a problem. The ribs to which the panel attaches **ARE** in already (cannot remmber the part numbers). I cannot remember if this is a problem. Would have to take some measurements to see if the panel position changes for the tip up vs the slider. Also, this would *potentially* impact where the roll bar goes. Again, this is from memory and I may be WRONG. If I get a chance, I will try to get some measurements tommorrow. A quick call or email to Van's is probably best though (you knew that ;-) ) James ----- Original Message ----- From: "Denis Walsh" <deniswalsh(at)earthlink.net> Sent: Sunday, June 18, 2000 8:35 PM Subject: Re: RV-List: tip up canopy kit to slider conversion???? > > on 6/18/00 16:42, Gary Zilik at zilik(at)bewellnet.com wrote: > > > > > If the canopy has not been started then I should think it would be a simple > > chore of ordering all the correct parts for the slider and tossing the tip up > > parts in the scrap bin. If the canopy is done we are talking major surgery > > here > > but it can be done. > > > > Gary Zilik > > RV-6A N99PZ > > > > lucky macy wrote: > > > >> > >> Can a 6A tip up canopy QUICK BUILD kit be converted to a slider easily or > >> are we talking some surgery here? (the archive doesn't want to load up this > >> morning). > >> > >> TIA, > > > > My recollection is that the quick build my hangar mate got did not have any > canopy work completed; the canopy parts come with the finish kit. Again my > memory dims but don't recall that any of the "finish kit" work was done. The > surgery required would entail swapping out the upper fuselage ribs between > the panel and the firewall and the bulkhead, which is different. I would > estimate the added time to be a week or so. The bigger issue would be > getting trade in credit for the tip up parts. > > If you have a strong preference for the slider, I would go for it. the > level of effort at this stage is very minor in the overall scheme of things. > > Both types of canopy have there strong advocates, although not as emotional > an issue as the type of undercarriage. Personally I think they are both > marvelous canopies, head and shoulders above all competition. A real strong > point of the design. > > ......But I love my slider :+) > > > > -- > Denis L.(Bum) Walsh > > ________________________________________________________________________________
Date: Jun 18, 2000
Subject: Re: .30 cal or .50 cal? (LONG answer)
Its about time we had something interesting on this list! Andy Johnson, starting fuselage of the fighter. ________________________________________________________________________________
Subject: CDI depth needed
Date: Jun 18, 2000
Glenn, I've got an Mid-Continent CDI w/ GS (MD200-306) and the case is 4 5/8" deep. There's a DB25 connector which will need clearance for the cable connector. It's centered horizontally about a quarter of the way from the top. Don't know if your canopy deck (F-621) is the same as the slider, but I put my CDI in the lower left and cut a notch out of the deck for clearance. I'm also cutting it away on the right side for the radio stack. I'm going to add some reinforcing angles just to make me feel better. Your strength requirements on the tip-up may be more critical. Regards, Greg Young RV-6 N6GY Houston (DWH) wiring & systems -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Glenn & Judi Sent: Friday, June 16, 2000 9:44 PM Subject: RV-List: CDI depth needed Hi, Can someone please tell me the depth of a Mid-Continent CDI for a GPS receiver? Thanks, Glenn Gordon ________________________________________________________________________________
Date: Jun 19, 2000
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
>> I'm wrong? Here's my reasoning: >> 1) Ordinary solder is 50/50 Tin/Lead, and has a solidus temp of 361F, >> liquidus temp of 421F (Machinery's Handbook, 24th Ed, p 1250). >> 2)The cylinder head max temp of my O360A1A is 500F, and recommended >> operating range is 150F to 400F (Lycoming Operator's Manual, A-section). >> 3) The AN800-2 globe unions are thermally intimate with the cylinder heads >> via copper tubing and brass primer fittings. >> 4) Sooooo, it seems to me that the ordinary solder will be quite soft at >> normal cylinder head operating temperatures, and fully melted within the >> allowed head temperature range. Therefore I thought that ordinary solder >> would by inappropriate in this application. Not so? I had not even >> considered the question of the pressure in the lines because as you say, >it >> is low. >> >> Dennis Persyk 6A finishing kit >> Hampshire, IL C38 >> > >> >> >> >> >> > >> >> >I am ready to solder the AN800-2 globe unions to the 1/8 OD copper >> tubing >> >> >for the primers. >> >> >1) Where do I obtain small quantities of silver solder? >> >> >2) What is the melting point of 1)? >> >> >3) Can I use propane or do I need ox-acetylene? "Silver Solder" comes in many different concoctions. The first alloy of silver solder I ran across was at Hughes in Tucson about 38 years ago . . . a 60% tin, 38% lead, 2% silver alloy was used there to make joints on ceramic terminal strips that had silver coated notches in the ceramic to which wires were soldered. If the solder didn't have some silver in it, the liquid solder would disolve the silver on the ceramic and break the bond. This solder melted at a few tens of degress more than ordinary solder. Other alloys have no tin or lead but other mixtures depending on the materials to be joined, strength of the joint and temperatures to which the joint will be exposed. A quick search of the web produced a few exemplar variations on the theme of "silver solder". http://backup.kitco.com/product.solder.html http://www.kappalloy.com/silver.html http://www.lakeshore.com/catalog/products/temperature/accessories/solder/cad free.html http://www.kembla.com.au/brazingmanl.html A visit to your local welding supply store should get you some assitance in acquiring a suitable alloy and flux to go with it. Also, refridgeration supply stores will have solders suited to brass and coppy alloy joining that melts at less than oxy/acet temps. I purchased a material locally that flows nicely at a dull red heat with a hardware store variety propane torch. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 19, 2000
Subject: Re: 8 vs. 8A)
In a message dated 6/18/2000 9:03:28 PM Central Daylight Time, johnh(at)bellsouth.net writes: << I am contemplating a spam-can purchase with a partner for staying current while we build our RV's. I called Avemco for a comparison quote, 47 Stinson (Taildragger) vs. '61 C-172. Even though the Stinson is worth less ($17,000 vs. $26,000), full coverage with $500 deductible is $1,600 for Stinson and $960 for Cessna. Both pilots are 200 hr, PPSEL, only one of us has 25 hrs taildragger time. At least Avemco has a large differential. John Harris RV9A N922JH (reserved) >> As an insurance agent I can tell you that the price for a tail dragger will go down as you build tail wheel time. But a tri gear will always be about 5% to 10 % cheaper to insure. The other thing though is yout quote on the 172 is outrageous. I just wrote insurance for a pilot in a 69 172 worth 35,000 with 240 hours for 545 dollars a year with a 250 ded and 1 million liability. Pays to shop around. Chris ________________________________________________________________________________
Date: Jun 18, 2000
Mike, Another lister asked you to take a good look at your dimple dies. I second the notion because your holes are too big. If they are OK then there might be different things happening. When you dimpled the ribs did you squeeze them or hammer them in the C-Frame? I use an Avery squeezer with a 4 inch throat. When you use the C-Frame on the skins, how big of a hammer do you use? Is it made of metal, wood or plastic? How hard do you hit? I use a plastic mallet and I don't smoke it very hard. Do you drill with #40's or #41's? My vote is for 41's. Is your drill in good shape? (a wobbly one might be making big holes). Regards, Norman Hunger RV6A Delta BC > You would think by the time you had gotten half way through the wing's > that you would know something about dimpling. The problem is that after > dimpling the leading edge skin and the ribs the 3/32 cleco's won't hold, they > pull through. Do I need to put scrap pieces of aluminum with a number 40 hole > drilled in them to put on the back side to have some grip? What else is there > to try? > > Mike in Texas (skinning the wings) ________________________________________________________________________________
Date: Jun 19, 2000
Subject: Re: CDI depth needed
Thanks for the help, It looks like I will put the CDI upper left on the panel just barely clear of the canopy frame. It should be a nice placement, plus it will give me as much depth as I could possibly need. Thanks again, Glenn ________________________________________________________________________________
Subject: Re: GPS
Date: Jun 19, 2000
Check the newest AIM, it has the info you need. Ken Gray RV6 flying since 1996 550 hours, just now painting it! http://pages.tca.net/kgray ----- Original Message ----- From: Vince Welch <vwelch(at)knownet.net> Sent: Sunday, June 18, 2000 9:56 AM Subject: RV-List: GPS > > I heard recently that a NOTAM was issued in June of 1998 that allows IFR > approved GPS units to be used to identify any DME fix or ADF/LOM. I did a > search of the FAR's and can find no reference. Does anyone know if an IFR > approved GPS can be used is such a manner. I would really like to read it > for myself if you can point me in the right direction. Also, does the > statement only apply to approach approved units or can an enroute/terminal > area approved unit like the Apollo GX-65 be used to identify DME fixes? > > Just starting to think about avionics and panels and such. Where can I > find information detailing what has to be done to have a legal installation > in an experimental? How much can I do and how much HAS to be farmed out? > I keep having nightmares about spending huge amounts of time and money > only to have an inspector waltz in, wave a list of requirements that I've > never seen and tell me everything I've done is unacceptable. > > Vince > RV-8A > Planning ahead > > ________________________________________________________________________________
Subject: Brake/Rudder Problem Solved
Date: Jun 19, 2000
To all fellow listers who offered me advice on my problem with applying rudder and brake at the same time, thank you. I made three changes and solved the problem. One, I removed about one inch from the rudder cable attach links that connect the cables to the pedals. This moved the bottom of the pedals aft and gives me more ankle room. Two, I installed 5/8" ID rubber tubing to the bottom cross members. This gives my foot a better feel for the bottom of the pedal. Three, I modified my technique a little. In learning to fly a Citabria, I learned that I needed keep my feet up off of the floor board so that I could stay active on the rudders. I took the advice of others and planted my heel on the floor board of the RV-6 with the balls of my feet on the rubber cross member. This worked just fine as the rudder on my RV is more effective more quickly than the Citabria. I waited nearly all week to test out my solution. We've had a stationary front sitting over the Ohio Valley and the weather has been dreadful. I thought I had patience when I was building. I'm just now beginning to learn the meaning of the word. Saturday didn't look great, but good enough. I get so excited when I pull the airplane from the hanger and I know I'm going flying. I get her all ready, close down the hanger, and climb up on the wing as if I was stepping into my own personal F6F Hellcat on the deck of the Enterprise. Go through the checklist and turn the key to elicit that throaty roar from the exhaust. One of the things I love most is the sliding canopy. Taxiing out, the other airport patrons always turn to look. Takeoff roll was much smoother and a non-event. Can't believe the difference it makes and just how dangerous it was dragging the brakes like I was. Glad that problem has been solved. Now I only wish I'd mounted that CD player somewhere other than the side of the cabin. The vibration makes it so jumpy that I can't use it. Thanks to all on the list for helping out. It makes the problem solving much easier and me much safer. Can't wait to post a travelogue like Larry Pardue. Great story and great pictures. Man I love this airplane. Randy Pflanzer N417G RV-6 (5.5 hours) Indianapolis (UMP) http://members.iquest.net/~rpflanze/ ________________________________________________________________________________
From: "Nancy and Walter Shipley" <wshipley(at)esper.com>
Subject: Re: RV Training In Knoxville
Date: Jun 19, 2000
John, I'm in the Knoxville area and may be interested in flying with you. I'm currently building an 8A, and obviously I would prefer getting a checkout in a 8A, but there are very few of them flying, making a checkout almost impossible. Some questions I have for you are: - do you feel a checkout in a 6 would be beneficial in learning to fly the 8A? - does your 6 have a constant speed prop? My 8A will have a fixed pitch, and I don't have a complex rating. - what are your hourly rates? I'm a fairly low time pilot (300 hrs) with the usual Cessna/Piper background, although I did own a two seat tandem AC (Varga) which I sold about two years ago. No flying time since then. I also was checked out in a Piper cub several years ago, so I do have just a bit of taildragger time. Look forward to hearing from you. Walt Shipley RV8A (finish) (865) 458-9959 ---------- > From: Rv6plt(at)cs.com > To: rv-list(at)matronics.com > Subject: RV-List: RV Training In Knoxville > Date: Saturday, June 17, 2000 8:24 AM > > > I will be in Knoxville, Tn next weekend (24 & 25 June) with my RV6. If anyone > in that area needs training, contact me off-list. > > John Henley, CFII, N6LD 350 Hrs > 850-609-3175 > > > ________________________________________________________________________________
Date: Jun 19, 2000
Subject: Re: RV-8 8 inch Wing Spar Attach ??
BUT, here's the other *perception* question. The 8's spars only protrude into the fuselage about 8 inches as opposed to the 4 and 6 which have spars which span the full with of the fuselage. I don't design airplanes and won't pretend my comments mean diddly squat. It's probably GA standard for the spars to only go through the fuse a bit like the 8's do but then most GA aren't doing aerobatics. For me, there's a psychological comfort in knowing the 4 and 6 wing spars are longer and have more surface attachment area inside the fuse. I have seen a couple of modern purpose built acro wings and they look liked the spars carried all the way through the fuse too. Any thoughts I know this is a exercise in dead horse beating but this poster brings up a good point. Any thoughts from our knowledgable group ????? ________________________________________________________________________________
Date: Jun 19, 2000
Subject: Well Wishes - Was: What ADIZ corridor?
--- Gummos wrote: > P.S. Would all you Lister's keep some kind thoughts for a fellow > builder? > Jack "Kabong" Starn is my building partner and friend and he is has > Cancer. > This Wed he will have his voice box removed. Hopefully, this will > control > the big "C". However, he will have a long recovery and will have to > learn > to talk again. I am sure that a lot of good thoughts can't hurt. > THANKS > AGAIN. Prayers and thoughts from Central Texas. Someone out there in SoCal ought to make sure Jack (Tom too!) gets some RV time after he recovers. Incentive to get back to building! Mike Thompson Austin, TX -6 N140RV (Reserved) Fuselage ________________________________________________________________________________
Subject: Video camera mount
Date: Jun 19, 2000
Greetings, I'm looking for a good way to mount my camcorder to the RV-8, and wondered if anyone can save me some effort (or money). My plan is to mount it to the steel bar that forms the rear seatback support, to the right of the seat, looking forward over my shoulder. After some searching, I found what appears to be a good mount, but it's $95, and I wanted to see if anyone knows of any other alternatives before I spend the money. Here's a link to the mount I found: http://www.ioportracing.com/video.htm Thanks, Russell Duffy Navarre, FL RV-8, 80587 (flying) ________________________________________________________________________________
Date: Jun 19, 2000
Subject: Re: Video camera mount
I am very happy with my RAM-MOUNT attached to my roll over bar on my RV-4. It costs 32$ and I got it at the boat store. I have seen the RAM folks at Oshgosh & they gave a WEB site. Very good qualitity items. They make all kinds of mounts & the most popular are the hand-held radio mounts...... rv8(at)ispchannel.com on 06/19/2000 10:58:25 AM Please respond to rv-list(at)matronics.com Subject: RV-List: Video camera mount Greetings, I'm looking for a good way to mount my camcorder to the RV-8, and wondered if anyone can save me some effort (or money). My plan is to mount it to the steel bar that forms the rear seatback support, to the right of the seat, looking forward over my shoulder. After some searching, I found what appears to be a good mount, but it's $95, and I wanted to see if anyone knows of any other alternatives before I spend the money. Here's a link to the mount I found: http://www.ioportracing.com/video.htm Thanks, Russell Duffy Navarre, FL RV-8, 80587 (flying) ________________________________________________________________________________
Subject: Re: Engine level w/longerons?
Date: Jun 19, 2000
> About six months ago at a local builder's > group meeting at my house Bill Benedict was showing another builder how the > top of the engine should be level with the main longerons. Randy, I don't even remember Bill talking about this. Hmm... At any rate, it seems to me there are too many variables to be able to set this with any confidence. #1 is the weight of the prop, but the main thing is that the mounts will probably sag between 1/16" and 3/16" over time. So it seems to me you could do more harm than good at this point. I've never heard of this anywhere else, but it sounds to me like one of those things, like the H-stab incidence, that you could either obsess about and maybe make a difference, or not and go flying and never know the difference even if there is one. Randall ________________________________________________________________________________
Date: Jun 19, 2000
In racing, many of us carry cameras to help critique our driving later. There are mounts available at http://www.ioportracing.com/welcomeframes.htm http://www.ogracing.com/ogshell/loadpage.pl?id+catroll.html And many others, but all in the same price range you mentioned. Several of us have simply gone to Walmart and bought camera tripods ($30). Its then fairly simple to remove the mount, and secure it to the roll cage...or wherever you'd like. I do suggest a safety lanyard on the camera ..... else ye be smited by said camera while braking into turn one when ye forget to turn the little knob tight. Uh....well, so I'm told :-) Bill -4 wings ----- Original Message ----- From: "Russell Duffy" <rv8(at)ispchannel.com> Sent: Monday, June 19, 2000 10:58 AM Subject: RV-List: Video camera mount > > Greetings, > > I'm looking for a good way to mount my camcorder to the RV-8, and wondered > if anyone can save me some effort (or money). My plan is to mount it to the > steel bar that forms the rear seatback support, to the right of the seat, > looking forward over my shoulder. After some searching, I found what > appears to be a good mount, but it's $95, and I wanted to see if anyone > knows of any other alternatives before I spend the money. Here's a link to > the mount I found: http://www.ioportracing.com/video.htm > > Thanks, > Russell Duffy > Navarre, FL > RV-8, 80587 (flying) > > ________________________________________________________________________________
Subject: Re: GPS
Date: Jun 19, 2000
Vince, I haven't seen the memo/notice about the GPS yet but I will see if I can find it and let you know. As far as the requirements for IFR look at FAR 91.205(d) for a full list of what is required. I am in the very final stages on my 8A and while the panel becomes very full it is doable. Mike Robertson RV-8A Engine start within two weeks.....I hope >From: Vince Welch <vwelch(at)knownet.net> >Reply-To: rv-list(at)matronics.com >To: "'RV List'" >Subject: RV-List: GPS >Date: Sun, 18 Jun 2000 10:56:40 -0400 > > >I heard recently that a NOTAM was issued in June of 1998 that allows IFR >approved GPS units to be used to identify any DME fix or ADF/LOM. I did a >search of the FAR's and can find no reference. Does anyone know if an IFR >approved GPS can be used is such a manner. I would really like to read it >for myself if you can point me in the right direction. Also, does the >statement only apply to approach approved units or can an enroute/terminal >area approved unit like the Apollo GX-65 be used to identify DME fixes? > >Just starting to think about avionics and panels and such. Where can I >find information detailing what has to be done to have a legal installation >in an experimental? How much can I do and how much HAS to be farmed out? > I keep having nightmares about spending huge amounts of time and money >only to have an inspector waltz in, wave a list of requirements that I've >never seen and tell me everything I've done is unacceptable. > >Vince >RV-8A >Planning ahead > > ________________________________________________________________________________
Date: Jun 19, 2000
The cleco's are brand new, I have plenty of grip length. I think I will take a look at ordering a new set of dimples but the one I'm using now has only been used on the tail kit and or the correct size. I have had problems with this in the past but on flat surface they stay just fine. On the leading edge though the spring effect pulls them out. Oedering a new set of dimples (by the way the one I have now were from Avery) ________________________________________________________________________________
Date: Jun 19, 2000
Wow, I obviously have insufficient RAM for this task :-) Thanks a bunch to everyone for the RAM mount info. I just downloaded their catalog and am amazed at how cool these things are. Can't wait to get to the local boat place and see what they have. Of course now my wife will come home and find everything we own mounted to something :-) Very neat gizmos- made my day. Thanks, Russell Duffy Navarre, FL RV-8, 80587 (flying) > I am very happy with my RAM-MOUNT attached to my roll over bar on my RV-4. It > costs 32$ and I got it at the boat store. I have seen the RAM folks at Oshgosh > & they gave a WEB site. Very good qualitity items. They make all kinds of > mounts & the most popular are the hand-held radio mounts...... ________________________________________________________________________________
Subject: Re: GPS
Date: Jun 19, 2000
Vince, Check out a current copy of the Airman's Info Manual, para 1-1-21. It has all the latest info. Mike Robertson RV-8A >From: Vince Welch <vwelch(at)knownet.net> >Reply-To: rv-list(at)matronics.com >To: "'RV List'" >Subject: RV-List: GPS >Date: Sun, 18 Jun 2000 10:56:40 -0400 > > >I heard recently that a NOTAM was issued in June of 1998 that allows IFR >approved GPS units to be used to identify any DME fix or ADF/LOM. I did a >search of the FAR's and can find no reference. Does anyone know if an IFR >approved GPS can be used is such a manner. I would really like to read it >for myself if you can point me in the right direction. Also, does the >statement only apply to approach approved units or can an enroute/terminal >area approved unit like the Apollo GX-65 be used to identify DME fixes? > >Just starting to think about avionics and panels and such. Where can I >find information detailing what has to be done to have a legal installation >in an experimental? How much can I do and how much HAS to be farmed out? > I keep having nightmares about spending huge amounts of time and money >only to have an inspector waltz in, wave a list of requirements that I've >never seen and tell me everything I've done is unacceptable. > >Vince >RV-8A >Planning ahead > > ________________________________________________________________________________
Date: Jun 19, 2000
Take one look at the size and number of bolts used along with the size of the mounting stock in the spar box, add that to the close tolerance for those mounting bolt holes and I don't think there is any question about the strength. I have looked at several aircraft with the wings mounted in the same fashion that are not near as strong as Van's. Mike Robertson RV-8A Not worried >From: pcondon(at)csc.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: RV-8 8 inch Wing Spar Attach ?? >Date: Mon, 19 Jun 2000 09:36:14 -0400 > > >BUT, here's the other *perception* question. The 8's spars only protrude >into the fuselage about 8 inches as opposed to the 4 and 6 which have spars >which span the full with of the fuselage. I don't design airplanes and >won't >pretend my comments mean diddly squat. It's probably GA standard for the >spars to only go through the fuse a bit like the 8's do but then most GA >aren't doing aerobatics. > >For me, there's a psychological comfort in knowing the 4 and 6 wing spars >are longer and have more surface attachment area inside the fuse. I have >seen a couple of modern purpose built acro wings and they look liked the >spars carried all the way through the fuse too. Any thoughts > > >I know this is a exercise in dead horse beating but this poster brings up a >good >point. >Any thoughts from our knowledgable group ????? > > ________________________________________________________________________________
Subject: RV-6 prepunched HS skins for sale
Date: Jun 19, 2000
I recently decided to build an RV-8 as opposed to the RV-6. I no longer need my HS skins. If someone on the list have an 'accident' with their skin(s), you can get them from me cheap at US$30 each. Part number is HS-601-PP. They still have the vinyl coating on them. Are RV-8 C-GQRV (reserved) - building stiffeners AGAIN for an .020 rudder and elevators as opposed to the .016. ________________________________________________________________________________
Subject: Paper Funnel
Date: Jun 19, 2000
Listers: Just got my insurance policy from Scott Smith. Enclosed was the exact item I have been meaning to patent and make a million dollars on, a collapsable paper oil funnel. Is this a reddily available item I have just never seen? I have been using rolled up manilla. The one funnel a year from Scott is not enough. Larry Pardue Carlsbad, NM RV-6 N441LP http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: Jun 19, 2000
From: Steve Nichols <snichols(at)stateengineering.com>
Subject: RV-4 STUFF FOR SALE (WINGS & TAIL etc.)
Listers, It is with mixed emotions that I post the following: Rv-4 wing and tail for sale. philogiston spar skeleton complete no prepunched but I have already drilled all the holes tail 95% complete control surfaces complete fuselage jig (metal) tail horizontal jig any thing else that I have left that I have'nt a;ready loaned out (clecoes etc.) Total: $3500.00 usd Buyer to pay shipping and I live in Alabama Reason: I want to buy a Grumman AA1 Thanks Steve Nichols dna Please reply off list ________________________________________________________________________________
Subject: What size Cleoe
Date: Jun 19, 2000
My experience was that this problem of loose clecoes was noticeable when I dimpled curved surfaces, like the leading edge of the wing. It was non-existent when I dimpled flat surfaces. FWIW I have used the #40 drill bits throughout the project. Steve Soule Huntington, VT RV-6A baffles "Will it ever end?" -----Original Message----- Not trying to restart the big hub-bub on #40 vs #41 but as a new builder I realized very soon that whenever I drilled with #40 and dimpled, my (brand new) clecos pulled out with very little pressure on them. When drilling with a #41 bit this never happened. ________________________________________________________________________________
Date: Jun 19, 2000
Subject: Re: Paper Funnel
Is that the insurance policy (used as a funnel) or did the policy ALSO include a funnel ? n5lp(at)carlsbad.net on 06/19/2000 03:05:26 PM Please respond to rv-list(at)matronics.com Subject: RV-List: Paper Funnel Listers: Just got my insurance policy from Scott Smith. Enclosed was the exact item I have been meaning to patent and make a million dollars on, a collapsable paper oil funnel. Is this a reddily available item I have just never seen? I have been using rolled up manilla. The one funnel a year from Scott is not enough. Larry Pardue Carlsbad, NM RV-6 N441LP http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: Jun 19, 2000
Listers- One thing I have found is that not all clecoes are created equal- the ones I got with my original toolkit from ACS (U.S. Industrial) were "CLECO-LOK". I ordered more later from someone else (not sure who, could dig into reciepts if anyone really needs the info) and they were labeled "KWIK-LOK" (I think- not in the shop right now). The latter ones will grip holes the CLECO-LOK brand won't- they also seem to be more consistently manufactured with less sideways bending of the grip fingers. FWIW From the PossumWorks in TN Mark -6A, starting other wing ________________________________________________________________________________
Date: Jun 19, 2000
> > >Is that the insurance policy (used as a funnel) or did the policy ALSO >include a >funnel ? > > There was a funnel, with advertising on it, stuck in the envelope with the policy. Larry Pardue ________________________________________________________________________________
Date: Jun 19, 2000
>For me, there's a psychological comfort in knowing the 4 and 6 wing spars >are longer and have more surface attachment area inside the fuse. I have >seen a couple of modern purpose built acro wings and they look liked the >spars carried all the way through the fuse too. Any thoughts >I know this is a exercise in dead horse beating but this poster brings up a >good >point. Seems that way at first, but think about it. One -8 wing has broken in flight, and others in ground testing. None of them broke inside the fuse. So having more metal inside the fuse would just be adding weight. It would make that section stronger, but it is already strong enough. Brian Huffaker, DSWL (bifft(at)xmission.com) President and Founder Friends of P-Chan RV-8 80091 Riviting fuel tanks. 1/5 Starduster II N23UT flying ________________________________________________________________________________
Date: Jun 19, 2000
> > Listers- > > One thing I have found is that not all clecoes are created equal- the > ones I got with my original toolkit from ACS (U.S. Industrial) were > "CLECO-LOK". I ordered more later from someone else (not sure who, > could dig into reciepts if anyone really needs the info) and they were > labeled "KWIK-LOK" (I think- not in the shop right now). The latter > ones will grip holes the CLECO-LOK brand won't- they also seem to be > more consistently manufactured with less sideways bending of the grip > fingers. The other thing I found with the Kwik-Lok vs. Cleco brand was that the Cleco brand would often not fit in a #41 hole that had been drilled but not dimpled, while the Kwik-Lok would. They also seemed more consistent and higher quality. When I bought additional clecos, I made sure they were the Kwik-Lok brand. Terry RV-8A wings still ________________________________________________________________________________
Date: Jun 19, 2000
I'd just refer you to page 43 of the "18 Years of the RV-Ator" where Van explains that the RV-8 spar "center section is inherently stiffer than the narrower spar extension of the RV-4 and RV-6" and that "the wing spar concepts we have used in all of our other kits have been a departure from industry standards" (his words, not mine). I'm more concerned about my building skills and the quality of my workmanship than I am Van's design acumen. Please let's bury this horse now... Mark Dickens RV-8 Wings ----- Original Message ----- From: <pcondon(at)csc.com> Sent: Monday, June 19, 2000 8:36 AM Subject: Re: RV-List: RV-8 8 inch Wing Spar Attach ?? > > > BUT, here's the other *perception* question. The 8's spars only protrude > into the fuselage about 8 inches as opposed to the 4 and 6 which have spars > which span the full with of the fuselage. I don't design airplanes and won't > pretend my comments mean diddly squat. It's probably GA standard for the > spars to only go through the fuse a bit like the 8's do but then most GA > aren't doing aerobatics. > > For me, there's a psychological comfort in knowing the 4 and 6 wing spars > are longer and have more surface attachment area inside the fuse. I have > seen a couple of modern purpose built acro wings and they look liked the > spars carried all the way through the fuse too. Any thoughts > > > I know this is a exercise in dead horse beating but this poster brings up a good > point. > Any thoughts from our knowledgable group ????? > > ________________________________________________________________________________
Date: Jun 19, 2000
Subject: Re: What size Cleoe
I never had a problem with # 40 holes. Perhaps you are to aggressive with the dimple process and enlargeing the hole too much. Earl RV4 "Stephen J. Soule" wrote: > > > My experience was that this problem of loose clecoes was noticeable when I > dimpled curved surfaces, like the leading edge of the wing. It was > non-existent when I dimpled flat surfaces. FWIW I have used the #40 drill > bits throughout the project. > > Steve Soule > Huntington, VT > RV-6A baffles "Will it ever end?" > > -----Original Message----- > > Not trying to restart the big hub-bub on #40 vs #41 but as a new builder I > realized very soon that whenever I drilled with #40 and dimpled, my (brand > new) clecos pulled out with very little pressure on them. When drilling > with > a #41 bit this never happened. > ________________________________________________________________________________
Subject: Thanks for the thoughts
Date: Jun 19, 2000
Just a short note of thanks to Gummibear, Texas listers and members of Apple Valley EAA for the good thoughts and prayers (we're not in school so you'all can ignore todays Supreme Court cr*p) You may not hear me for a while but thanks to the lists I'll still on line and "talk" via a keyboard untill I learn to speak again. Been riding observer in a 172 chase plane of UAV's, (Unmanned Airal Vehicle) and got a ride in THE Harmon Rocket. We, Gummibear and Kabong are still at the 95% level on his Rocket. I go in Wednesday and should be back online until 27th or 28th. Thanks for all your thoughts. Kabong ________________________________________________________________________________
Date: Jun 19, 2000
Get some scrap and practice using the #41 drill and see if that works. Cecil > > The cleco's are brand new, I have plenty of grip length. I think I >will >take a look at ordering a new set of dimples but the one I'm using now >has >only been used on the tail kit and or the correct size. I have had >problems >with this in the past but on flat surface they stay just fine. On the >leading >edge though the spring effect pulls them out. > Oedering a new set of dimples (by the way the one I have now were >from >Avery) > > ________________________________________________________________________________
Date: Jun 19, 2000
Make your own, it shouldn't be to hard. Cecil Hatfeild writes: > >Greetings, > >I'm looking for a good way to mount my camcorder to the RV-8, and >wondered >if anyone can save me some effort (or money). My plan is to mount it >to the >steel bar that forms the rear seatback support, to the right of the >seat, >looking forward over my shoulder. After some searching, I found what >appears to be a good mount, but it's $95, and I wanted to see if >anyone >knows of any other alternatives before I spend the money. Here's a >link to >the mount I found: http://www.ioportracing.com/video.htm > >Thanks, >Russell Duffy >Navarre, FL >RV-8, 80587 (flying) > > ________________________________________________________________________________
Date: Jun 19, 2000
I'm amazed that people on this list still talk about what size drill to use for 3/32" rivets in dimpled holes. The correct size is #41. Debur and dimple. Simple. Try it. I guarantee it works. Curved, flat, whatever. Check the archives. This was discusssed to death years ago. The way to decide whether you're being too aggressive with the dimpling process is to check the rivet head after you buck or squeeze it. If it's not proud or depressed you're doing it correctly. How can you be too aggressive anyway? Squeeze as hard as you please; the material stops the dies from coming too close together unless you're using some kind of hydraulic press, for cryin' out loud. Jack Abell EARL FORTNER wrote: > > I never had a problem with # 40 holes. Perhaps you are to aggressive > with the dimple process and enlargeing the hole too much. > Earl RV4 > > "Stephen J. Soule" wrote: > > > > > > My experience was that this problem of loose clecoes was noticeable when I > > dimpled curved surfaces, like the leading edge of the wing. It was > > non-existent when I dimpled flat surfaces. FWIW I have used the #40 drill > > bits throughout the project. > > > > Steve Soule > > Huntington, VT > > RV-6A baffles "Will it ever end?" > > > > -----Original Message----- > > > > Not trying to restart the big hub-bub on #40 vs #41 but as a new builder I > > realized very soon that whenever I drilled with #40 and dimpled, my (brand > > new) clecos pulled out with very little pressure on them. When drilling > > with > > a #41 bit this never happened. > > > ________________________________________________________________________________
Date: Jun 19, 2000
Subject: RV Shirts from "RVPaul"
Message for RVPaul: please contact me at jwlawson(at)hargray.com regarding the shirts that I ordered from you, I haven't received them yet and I've not received any replies to the e-mails that I've sent. For RV Listers: has anyone had any problems getting shirts that they ordered? Semper Fi John Lawson HS done...about to skin the VS...working on the elevators and rudder ________________________________________________________________________________
Date: Jun 19, 2000
Subject: Standard Size Avionics?
Hi, I will soon be cutting my panel for the avionics stack. I will be riveting two angles to the panel to support the radios. Is there an accepted "industry standard" for the spacing on these angles? My Garmins both use the same dimension, but will any future avionics I install (including other brands) mount on the same spacing? -Glenn Gordon ________________________________________________________________________________
Date: Jun 19, 2000
> I'm amazed that people on this list still talk about what size drill to use for > 3/32" rivets in dimpled holes. The correct size is #41. Debur and dimple. > Simple. Try it. I guarantee it works. Curved, flat, whatever. Check the > archives. This was discusssed to death years ago. > Well now that depends on who you talk to doesn't it? I made a call to Van's when I started my kit, and they told me that using a #41 drill bit was pretty freaking stupid. In fact, Ken made fun of the type of people who feel they have to change things like that just to make themselves feel like an engineer. The dies are made for a #40, the rivet is SUPPOSED to have a bit of play in the hole to expand into...the amount of play that is there when you drill with a #40. Two A&P friends of mine have told me the proper size hole for a dimpled 3/32" rivet is a #40. I can tell you that the rivet expanding into the larger size hole WILL GIVE IT A LARGER CROSS SECTION WHEN FINISHED......thereby making it stronger. It seems to me there are just to many people out there trying to 'out think' the designers. Drill whatever size hole you want....but don't come back at me stating that Van's -8 wing is perfect if you won't even consider the most basic aspect of his designs (the rivet hole) to be accurate. Bill -4 wings all #40 and never had one single cleco problem, and not a ripple to be found. ________________________________________________________________________________
Date: Jun 19, 2000
Subject: RV-8 spar -enough already
For those of you who 'feel'that the 8 spar should have an I-beam carry through, I am assuming you would never ever ever fly in a Spitfire (or ME-109, etc). We all know how dangerous those aeroplanes have turned out. The Spit has 7 boltson each 6" stub (3 up/4 down). Either re-engineer your own airplane, or stop bitching and start building. Flying one of these machines (RV-8) is more fun then ............ anything!!!!! Ed Storo RV-8 30hrs ________________________________________________________________________________
Date: Jun 19, 2000
Subject: Re: RV-8 spar -enough already
In a message dated 6/19/2000 10:00:16 PM Central Daylight Time, ERSF2B(at)AOL.COM writes: << For those of you who 'feel'that the 8 spar should have an I-beam carry through, I am assuming you would never ever ever fly in a Spitfire (or ME-109, etc). We all know how dangerous those aeroplanes have turned out. The Spit has 7 boltson each 6" stub (3 up/4 down). Either re-engineer your own airplane, or stop bitching and start building. Flying one of these machines (RV-8) is more fun then ............ anything!!!!! Ed Storo RV-8 30hrs >> I'll agree with you that the RV 8 spar is fine as long as you dont exceed its limitations, but that goes for any spar, so its a good wing. Next I have disagree, the rocket is more fun lol Anyways its time to put the RV 8 spar issue to bed forever. The spar lives up to its design limitations. If your going to exceed them, then don't bitch go buy a giles 202 or something like that chris wilcox F1 rocket 000 ________________________________________________________________________________
(EMWAC SMTPRS 0.83) with SMTP id" <B0003584592@mail-2.lbay.net>; Mon, 19 Jun 2000 20:55:03.-0700(at)matronics.com
Date: Jun 19, 2000
Date: Jun 20, 2000
----- Original Message ----- From: Randy Lervold <randy@rv-8.com> Sent: Sunday, June 18, 2000 10:49 AM Subject: RV-List: Engine level w/longerons? Listers, Although this question pertaints to my RV-8 I believe the principal would apply to all RVs, so here goes. About six months ago at a local builder's group meeting at my house Bill Benedict was showing another builder how the top of the engine should be level with the main longerons. He had someone raise the tail and shim it so as to level the fuse as measured with a bubble level on the cockpit sides (longerons). He then put the bubble level on the engine to demonstrate this. He indicated you could measure it longitudinally on the tops of the valve covers, tops of the head castings, or the pushrod tubes. Using the bubble level on all three showed the same results. Bill Benedict came out to my place one night and put the smart level on the main longeron and also the cylinder casting and it was one degree off. He check the engine mount and noticed the LACK OF A THICK WASHER NEXT TO THE CASE. We corrected the situation and now they read the same degree. The correct way is the only way. Dick Zander N747RZ finishing ________________________________________________________________________________
Subject: Jon Johanson & Ken Scott
Date: Jun 20, 2000
Jon Johanson arrived at our local RV Fly-in (Compton Abbas EGHA - England 60nm SW London) 15 RV aircraft and many RV builders meet Jon, Ken Scott from Van's was also able to attend. Photo's of Jon and Ken appear on www.rv6.co.uk Barry Clifford England ________________________________________________________________________________
Subject: RV-8 aileron hinges
Date: Jun 20, 2000
Here is a tip for anybody who is working on the aileron and hinges. I have been trying to align my ailerons and flaps and have been having quite a bit of fun installing and taking off the top nut that holds the pushrod to the hinge. Anyway I installed a locking one lug nut plate on the aileron side top part of the hinge and now the urge to scream profanities is gone. Ed Perry edperry64(at)netzero.net RV-8 ________________________________________________________________________________
Date: Jun 20, 2000
Subject: Dimpling #40 vs. #32
If you drill #40 holes before you dimple them you're making a huge mistake. The secret to perfect rivets is to drill #32 and DO NOT, repeat, DO NOT, deburr the hole. If you do this, the burr holds a 3/32" rivet firmly in place while you rivet. The shop head of the rivet will also curl back over the burr and form an interlocking joint. I haven't heard this mentioned on the list before so I wanted to pass it on. It has saved me many, many hours of work. Matthew -8A ________________________________________________________________________________
Date: Jun 20, 2000
Subject: Re: Dimpling #40 vs. #32
MATHEW i think you need a bigger hole than you think. the way a rivit works is , it has to be squeezed all the way for it to harden. if you have too small of a hole, the rivit will not expand to harden in the hole area, therefore it will have a soft shear point in the hole. the head and shop head will harden, but not the shank. i would think about this for a moment if i were you. good luck scott tampa rv6a tipper 25 years riviting sheetmetal ________________________________________________________________________________
Date: Jun 20, 2000
Subject: firewall hole covers for cables
Thanks to all on my firewall covers question. For the record I am including them below. Don Jordan -- 6a finish -- Arlington, Tx -- dons6a(at)juno.com ********************************************* >What should I buy for the holes in the firewall? I think I need a >rubber grommet to fit the cable & a 2 pc cover to go over that. That's what I did. It works well and was liked by the inspector. I also put some RTV on the fireshield to help keep out gases from the cockpit. >I ended up with mixture cable having to make a Steep "S" bend. Mine, too. The short one was too short. The long one was too long. I just made the bend. It works just fine. However, my steep bend cable was on the throttle. I have the other cables on my mixture. I could cut and fit those. >My stand off bracket for the Throttle/mixture has a non-bent flange >just sticking out. Looks like I need to bolt about 3 inches more >bracket & turn down 90 degrees for the mixture. I didn't bend mine; but, most do, I think. I really didn't like my attach bracket; but, I got it to work. It was a lot easier than fabricating my own. Jim Sears in KY RV-6A N198JS (just under 48 hours on the tach) *********************************************** > > > > That's what I did - made an extension out of .063 4130 and bolted > it to the existing non-bent flange. It is a tight S-curve to get from the > bracket to the cable pass-though area on the firewall (I used the area to the > right of the battery as I think Van's intended). The finished installation > works smooth as silk though. > > Curt ************************************************* DON, I just finished installing my mixture and throttle cables. I also used Vans bracket. My cables come through the firewall just to the right of the battery box and a few inches off the floorboards. I had to make a bracket like the one you describe with a 90 degree downward bend. Also used rubber grommets and firewall shields from Vans, and it all went together fairly easily. Scott Baldwin N728P> *************************************************** Although you didn't mention it it sounds like you have the old throttle/mixture bracket and a 180HP engine. Van's sells a new bracket now which works slicker than snot on a brass door knob for the 180. You no longer have to make the extension; however it is still a tight fit at teh firewall The boys at FTG have been exit ing the firewall at close quarters with the battery box and down very low, for a straight shot to the mixture.. -- Denis L.(Bum) Walsh *************************************************** Don, The $25 eyeball fittings are nice. You can get them at Aircraft Spruce. No chance of chaffing, a nice mechanical attachment, etc. They do cost more than the grommet/shield thing, and they require more/bigger holes in the firewall, but I like 'em and so do the folks who've seen where I used 'em. KB ________________________________________________________________________________
Subject: Re: RV Shirts from "RVPaul"
Date: Jun 20, 2000
Me, too. No shirt, no money, no reply. Jerry Carter ----- Original Message ----- From: John Lawson <jwlawson(at)hargray.com> Sent: Monday, June 19, 2000 6:32 PM Subject: RV-List: RV Shirts from "RVPaul" > > Message for RVPaul: please contact me at jwlawson(at)hargray.com regarding the shirts that I ordered > from you, I haven't received them yet and I've not received any replies to the e-mails that I've > sent. > > For RV Listers: has anyone had any problems getting shirts that they ordered? > > Semper Fi > John Lawson > HS done...about to skin the VS...working on the elevators and rudder > > ________________________________________________________________________________
Date: Jun 20, 2000
what size clecos do you use ----- Original Message ----- From: "Matthew Gelber" <mgelber(at)pacbell.net> Sent: Tuesday, June 20, 2000 12:06 PM Subject: RV-List: Dimpling #40 vs. #32 > > If you drill #40 holes before you dimple them you're making a huge mistake. > The secret to perfect rivets is to drill #32 and DO NOT, repeat, DO NOT, > deburr the hole. If you do this, the burr holds a 3/32" rivet firmly in > place while you rivet. The shop head of the rivet will also curl back over > the burr and form an interlocking joint. > > I haven't heard this mentioned on the list before so I wanted to pass it on. > It has saved me many, many hours of work. > > Matthew > -8A > > ________________________________________________________________________________
Date: Jun 20, 2000
WHOOOA here. I have been trying to stay out of this but now I feel a very big need to step in. My apologies but this technique is asking for trouble in the future. First I know you meant #42, not #32, but that aside you are asking for fractured rivets in the future. Leaving the burr, just to hold the rivet in place, is setting in a stress point that could very easily lead to fractured and sheared rivets. DO NOT leave the burrs in place. The hole MUST be a round and smooth as you can get it. I can't stress that enough. Mike Robertson RV-8A A&P for 20 years R&D project manager in the past Former military test pilot/ maintenance officer "Das Fed" now, but these ideas are my own. >From: Matthew Gelber <mgelber(at)pacbell.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Dimpling #40 vs. #32 >Date: Tue, 20 Jun 2000 09:06:39 -0700 > > >If you drill #40 holes before you dimple them you're making a huge mistake. >The secret to perfect rivets is to drill #32 and DO NOT, repeat, DO NOT, >deburr the hole. If you do this, the burr holds a 3/32" rivet firmly in >place while you rivet. The shop head of the rivet will also curl back over >the burr and form an interlocking joint. > >I haven't heard this mentioned on the list before so I wanted to pass it >on. >It has saved me many, many hours of work. > >Matthew >-8A > > ________________________________________________________________________________
Date: Jun 20, 2000
Subject: Re: Fun for the hole family, was Dimpling #40 vs. #32
> it's hard to explain so I put up a picture: > http://www.gelber.org/n/interlocking.jpg > One goes this way and one goes that way. I doubt even Billy Barty > could pull > that one apart. Hey!!! Where'd you get pictures of my main spar??!!! Mike Thompson Austin, TX -6 N140RV (Reserved) Fuselage ________________________________________________________________________________
Subject: Leaving the burr (was ... Dimpling #40 vs. #32)
Date: Jun 20, 2000
There are many reasons that aircraft builders deburr holes. Among them, the reference books tell us, is that the burr, if left in place, will flatten out over time and leave you with a loose rivet. Steve Soule Huntington VT RV-6A O-320 baffles -----Original Message----- > The secret to perfect rivets is to drill #32 and DO NOT, repeat, DO NOT, > deburr the hole. If you do this, the burr holds a 3/32" rivet firmly in > place while you rivet. The shop head of the rivet will also curl back over > the burr and form an interlocking joint. ________________________________________________________________________________
Date: May 13, 2000
I had a bit of trouble getting in touch with Paul but eventually got through. He hurried and sent my shirts. I received them shortly after and they were satisfactory. He was worried that his business was being jeopardized because I voiced my concerns to this list. I'll never send the whole 100% again before services are rendered. Money talks. Anh N985VU Maryland > >Me, too. No shirt, no money, no reply. > >Jerry Carter > >----- Original Message ----- >From: John Lawson <jwlawson(at)hargray.com> >To: >Sent: Monday, June 19, 2000 6:32 PM >Subject: RV-List: RV Shirts from "RVPaul" > > >> >> Message for RVPaul: please contact me at jwlawson(at)hargray.com regarding >the shirts that I ordered >> from you, I haven't received them yet and I've not received any replies to >the e-mails that I've >> sent. >> >> For RV Listers: has anyone had any problems getting shirts that they >ordered? >> >> Semper Fi >> John Lawson >> HS done...about to skin the VS...working on the elevators and rudder >> >> > > ________________________________________________________________________________
Date: Jun 20, 2000
In a message dated 06/19/2000 7:19:09 PM Central Daylight Time, e.fortner(at)worldnet.att.net writes: << I never had a problem with # 40 holes. Perhaps you are to aggressive with the dimple process and enlargeing the hole too much. Earl RV4 >> Well I'm using a squeezer and when using the C frame a wooden mallet. I do think that when squeezing that it inlarge's the hole. This has only happened on the leading edge curved surface and not so much the flat surface's. Aggressive! I think not. But thanks for your input. ________________________________________________________________________________
Date: Jun 20, 2000
> I had a bit of trouble getting in touch with Paul but eventually got > through. He hurried and sent my shirts. I received them shortly after and > they were satisfactory. He was worried that his business was being > jeopardized because I voiced my concerns to this list. I'll never send > the whole 100% again before services are rendered. Money talks. He should be worried about his business being jeopardized because he doesn't deliver when promised, not because you told some people about it. Bad business practice yields an early retirement, or change of employment status. I know I'm not sending my money in that direction. ________________________________________________________________________________
Date: Jun 20, 2000
Subject: OSH 2000
Hello Listers: The Oshkosh 2000 show is almost upon us. Team Rocket will have the same booth space as last year (#438) in the north display area -- stop in and say Hi! We are happy to announce our Oshkosh show special pricing, valid thru 1 August 2000: -the entire QB kit (including the empennage kit) will be sold for $29,999 during the show -Empennage kits purchased separately will be sold for $999 during the show Normal pricing for these kits is $32,700 for the QB kit, and $1350 for the empenage kit. The show special will save you over $4000! We will have a selection of our optional parts on display also (these parts can also be seen on our website catalog). For example, our new 3 lever throttle quadrant is an amazing piece of work (black anodized body, with black, red, and blue anodized lever handles), and sells for only $225. You have to see this part to appreciate it! We hope to see you there! Check Six! Mark ________________________________________________________________________________
Date: Jun 20, 2000
You either mean a #42 bit or 3/32" bit. Both holes leave the dimpled hole to small to properly harden the rivet. The rivet needs room to expand in the hole to gain full strength. As for not deburring; well, thats up to you. IMHO holes should be deburred and all edges of parts should be deburred. The front of Van's manual points this out. If it was not important then it would not be printed in the construction manual. Gary Zilik Matthew Gelber wrote: > > If you drill #40 holes before you dimple them you're making a huge mistake. > The secret to perfect rivets is to drill #32 and DO NOT, repeat, DO NOT, > deburr the hole. If you do this, the burr holds a 3/32" rivet firmly in > place while you rivet. The shop head of the rivet will also curl back over > the burr and form an interlocking joint. > > I haven't heard this mentioned on the list before so I wanted to pass it on. > It has saved me many, many hours of work. > > Matthew > -8A > ________________________________________________________________________________
Date: Jun 20, 2000
Uh guys......he was kidding. He did mean #32 drill and he did mean do not deburr...but it was all in jest, making fun of the #40 vs #41 fiasco. ________________________________________________________________________________
Date: Jun 20, 2000
Bill, I absolutely agree and I'll add one other little note. I tried using 41 on the left wing and found that you have to go back and drill 40 on the main spar as the countersink pilot will not go in the hole. I went back and redrilled to 40. No problems with rivets and the right wing is going very well. Bill Christie, Rt. Wing, RV8A, Phoenix ----- Original Message ----- From: Bill Shook <billshook(at)mindspring.com> Sent: Monday, June 19, 2000 7:21 PM Subject: Re: RV-List: What size Cleoe > > > I'm amazed that people on this list still talk about what size drill to > use for > > 3/32" rivets in dimpled holes. The correct size is #41. Debur and > dimple. > > Simple. Try it. I guarantee it works. Curved, flat, whatever. Check > the > > archives. This was discusssed to death years ago. > > > > > Well now that depends on who you talk to doesn't it? I made a call to Van's > when I started my kit, and they told me that using a #41 drill bit was > pretty freaking stupid. In fact, Ken made fun of the type of people who > feel they have to change things like that just to make themselves feel like > an engineer. The dies are made for a #40, the rivet is SUPPOSED to have a > bit of play in the hole to expand into...the amount of play that is there > when you drill with a #40. Two A&P friends of mine have told me the proper > size hole for a dimpled 3/32" rivet is a #40. I can tell you that the > rivet expanding into the larger size hole WILL GIVE IT A LARGER CROSS > SECTION WHEN FINISHED......thereby making it stronger. It seems to me there > are just to many people out there trying to 'out think' the designers. > Drill whatever size hole you want....but don't come back at me stating that > Van's -8 wing is perfect if you won't even consider the most basic aspect of > his designs (the rivet hole) to be accurate. > > Bill > -4 wings all #40 and never had one single cleco problem, and not a > ripple to be found. > > ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Subject: Re: OSH 2000
Date: Jun 20, 2000
Mark: I hope to check out your booth this year as once my RV6-A-QB is done and my flying skills are up to speed a ROCKET is next! I really like the quality of the gear leg covers and fairings purchased from you in March. I assume you got your computer problems handled from the move. Did you have any other duplicate Master Card charges beside mine to reverse? Computer Systems are great when they work. Tom in Ohio ----- Original Message ----- From: <Mlfred(at)AOL.COM> Sent: Tuesday, June 20, 2000 5:48 PM Subject: RV-List: OSH 2000 > > Hello Listers: > > The Oshkosh 2000 show is almost upon us. Team Rocket will have the same booth > space as last year (#438) in the north display area -- stop in and say Hi! > > We are happy to announce our Oshkosh show special pricing, valid thru 1 > August 2000: > -the entire QB kit (including the empennage kit) will be sold for $29,999 > during the show > -Empennage kits purchased separately will be sold for $999 during the > show > > Normal pricing for these kits is $32,700 for the QB kit, and $1350 for the > empenage kit. The show special will save you over $4000! > > We will have a selection of our optional parts on display also (these parts > can also be seen on our website catalog). For example, our new 3 lever > throttle quadrant is an amazing piece of work (black anodized body, with > black, red, and blue anodized lever handles), and sells for only $225. You > have to see this part to appreciate it! > > We hope to see you there! > > Check Six! > Mark > > ________________________________________________________________________________
Date: Jun 20, 2000
Subject: References for Rivet Hole Sizes
Hello everyone, There's a lot of good information in the archives with respect to hole sizes for different rivets. Of particular interest to me, since he was our Tech Counselor before Hughes moved him to Arizona, was Gil Alexander's research & subsequent articles on riveting. The exact specifications are located at his web site - http//home.flash.net/~gila/. Of note, the recommended drill size for a 3/32" rivet is a #40 drill. HOWEVER, not to ruffle anyone's feathers, the minimum hole size is .093 and the maximum hole size is .103 (To the drill gauges!!). This is according to the Missile Command & is the specification for the Dept. of Defense. If I remember correctly, Gil liked to use a #41 drill for 3/32 rivets, but that was his personal preference. I have experimented w/ the C frame tool quite a bit. I do notice a significant difference in the dimples depending on how the tool is mounted. I get the best results after bolting the C frame tool to a piece of 1/4" steel plate, tapping the set once to seat it, and then harder to finish the dimple. May be a little more time consuming, but the results for me are worth it. I'm sure others have special techniques that work best for them. Article 3.3.1 Cleaning Mating Surfaces is also interesting since it addresses deburring. Happy & Safe Building. Blue Skies! ________________________________________________________________________________
Date: Jun 20, 2000
Subject: Rocky Mountain EAA Regional Fly-In
This coming Saturday, June 24 2000, is day one of the Rocky Mountain EAA Regional Fly-In. More importantly is the fact that Ryan and Morine Bendure (RV-4 junkies) are again hosting lunch at their hangar for fellow RV builders and flyers. This is a pot-luck type of affair and side dishes are always welcome. The Bendure's have procured the burgers, hot dogs and refreshments so there is no reason to bring such items. So if your driving, riding your bike or walking in, think about bringing a side dish. If your flying in, also think about bringing a side dish. Of course you don't have to bring anything except an empty stomach. Place: Vance Brand Airport (2V2) 375 Airport Rd. Hangar 34 Longmont, CO Lat/Long: 40-09-49.217N / 105-09-46.933W (40.1636714 / -105.1630369) Time: 1130 Sharp PS; The Rocky Mountain RVators also have a short meeting at this gathering. ________________________________________________________________________________
Subject: packing list
Date: Jun 20, 2000
I just received my qb6A Friday and finished the unpacking today. I started trying to check off the parts against the packing list, but as slow as it is going, I'll eat up my 2000 hrs on the packing list check alone. Is there some trick to this (it doesn't seem in any numerical or alpha order)? Do most of you not bother and trust that nothing was missed, or do you spend the time to go over each item? What is the frequency that there are parts missing that the packing list shows as shipped? - Gary S. - just barely out of the crate. ________________________________________________________________________________
Subject: Engine thrust angle resolved
Date: Jun 20, 2000
Listers, If you remember the question I posted regarding my engine thrust angle relative to the main longeron level then you might be interested in what I learned and did. To refresh your memory, Bill Benedict spotted the fact that my engine was not level with my main longerons, which it in theory is supposed to be. We couldn't quantify it at the time because we only had a bubble level. Well, Monday night I borrowed my buddy's SmartLevel (man what a useful device!) again (I used it for mounting wings and empennage which I highly recommend) and measured everything. With the fuselage completely leveled out, both laterally and longitudinally, the engine had .5 degrees of positive thrust angle (tilted up at the front), and this is with the prop and spinner mounted. I used a straight edge pivoted at the engine mount and the SmartLevel to determine what that was in vertical inches at the back of the spinner... it was 1/4-9/32". Most people with O-360s (parallel valve) and c/s props are reporting about 3/16" sag after 50 hours or so, therefore I would still be left with a small bit of positive thrust angle (maybe a tenth of a degree) once it sagged. Hmmm. I called Van's Monday and talked to Tom Green. We agreed that I'd quantify things and call him back today with the measurements referenced above. Tom referred me to Ken Krueger in the engineering department. I had a great conversation with Ken and learned many things. Did you know that the RV-3/4/8 all are spec'd with 1/2 degree postive angle of incidence on the main wing, while the RV-6/9s use one full degree? The thinking is that the RV-6 would be more of a cross country aircraft carrying more weight and flying at higher altitudes, therefore they gave it the extra half degree to support the weight and keep the tail from sagging at cruise. Remember also that in theory these planes cruise most efficiently when the longerons truly are level in flight, which according to Bill's informal research most RVs do not.
June 13, 2000 - June 20, 2000
RV-Archive.digest.vol-is
