RV-Archive.digest.vol-jb
August 11, 2000 - August 19, 2000
Subject: | Re: Spacing between elevator horn and HS skin |
Are,
I think I am the one who posed the latest question on this subject. I
e-mailed Van's about those gaps (I have about 0.2" on each side).
Basically, they are ok with anything you can do to bridge that gap, for
example, washers. I got a stack of stainless steel washers with a 1/4" hole
and will use a series of them to compensate for the gap. A longer bolt is
also needed. Van's said to measure your distance and order the right bolt.
I really don't know how the gap happened, as I am using the same basic
empennage as you are (-6/-6A is now using the -8 emp). Hope this helps
Jim Bower
St. Louis, MO
RV-6A N143DJ
Working on wings
>From: "Are Barstad" <abarstad(at)bconnex.net>
>To:
>Subject: RV-List: Spacing between elevator horn and HS skin
>Date: Thu, 10 Aug 2000 10:54:27 -0400
>Even after looking at RV's at Oshkosh I missed these details - argh!
>I just completed the right elevator to the point of inspection (Canadian
>reg's). I then test fitted it to the HS and found that I have a 3/16 inch
>gap between the elevator horn skin and the HS. I gather this must be right
>since I'm building with pre-punched parts. It just seems a lot and I can't
>think of any way to narrow the gap.
>Also, does anyone cover up the inside of the horn where one of the counter
>balance weights is? It looks very 'open' by just leaving it this way.
>Are
>RV-8
>Wings on order
Subject: | Re: Electric Horizons |
In a message dated 8/9/00 6:39:59 PM Central Daylight Time,
jcarter8(at)midsouth.rr.com writes:
<< Any other ideas for an electric horizon?
Jerry Carter
Memphis, TN
Jerry, try Kelley Instruments in Wichita KS. Phone nbr. is 800 835-1054 or
316 945-7171. If you buy one, remember to indicate it is for an 8 degree tilt
panel if for an RV-6 or 6A. Not sure what the tilt the others RV's have.......
Dale Ensing
6A finishing
I have purchased several items, in fact drove there and picked them up. YOu
ca't believe the place. Indescribable. Completey satisfied and will go back.
Rick
In a message dated 8/11/00 10:54:42 AM Central Daylight Time,
nuckolls(at)aeroelectric.com writes:
<< The only way to avoid this is to
get personally involved in the whole production effort for
the piece. Left to their own devices, media reporters and
writers are dismal purveyors of fact. Give the reporter
a couple of issues of Sport Aviation to read.
The Company magazine where I worked did a story on the first plane I built
and when I was just starting on my RV. Even they could not get the facts
straight and they had to reason to angle the story.
Dale Ensing
Hello Jim,
I think Are is referring to the outboard gaps at the stab tips.
Regarding the inboard horn gaps;
I Had the same problem with mine as have others before us.
Instead of washers:
I made two spacers approximately 1 3/8' x 1/2' from some 1/4' aluminum 6061
stock, 2024 would also do.
If your fit requires a different thickness file, grind or use appropriate
thickness material.
I drilled one end to fit the required 1/4" hole. I tapered the other end to
about 1/4" to reduce weight.
I then fit the spacer with a 1/4" bolt to it's position. I oriented the
tapered end toward the center of the circular weld that holds the horn to
it's tubular shaft. Surrounded by welded material this area should be safe
structurally.
I drilled two 1/8" holes through the Spacer and the horn into the area in
the center of the round welded area. Two 1/8" pop rivets hold the spacer in
place for assembly eliminating the need to try to fit washers in a very
restricted blind area later on.
If this is unclear I will make an effort to explain further on request. I do
have drawings that I could send via email or fax
jim in Kelowna BC. RV6a finish kit.
----- Original Message -----
Sent: Friday, August 11, 2000 9:05 AM
Subject: Re: RV-List: Spacing between elevator horn and HS skin
> Are,
hole
bolt.
> Jim Bower
> St. Louis, MO
> RV-6A N143DJ
> Working on wings
> >To:
right
can't
counter
> >Are
> >RV-8
> >Wings on order
From: | "Randy J. Pflanzer" <rpflanze(at)iquest.net> |
Subject: | Re: RV-4 cowling installation |
Doug,
Have you run the engine yet? If you can do so, it helps to get the mounts
to settle somewhat. I don't have the same set up as you (RV-6, 160 hp,
fixed pitch) but I would mount the cowling to the way the engine hangs right
now. If it does happen to sag a little later, you can place a thick washer
between the engine and the mount on the lower mounts to raise the engine
just a tad. I received extra washers with my mounts.
Randy Pflanzer N417G
RV-6 (40 hours)
Sent: Friday, August 11, 2000 9:58 AM
Subject: RV-List: RV-4 cowling installation
> Fellow Listers:
> For those with a flying RV I have a question. I am about to begin
> installation of the cowling on my -4 (180 hp, C/S prop). Is it advisable
to
> set the cowling slightly "low" relative to the prop spinner to allow for
> engine "sag" in the future? Is this really a significant problem. I have
> Lord engine mounts instead of the Barry mts.
> Thanks,
> Doug
> Doug Weiler
> Hudson, WI
> 715-386-1239
> dougweil(at)pressenter.com
From: | EARL FORTNER <e.fortner(at)worldnet.att.net> |
I bought a O-320-E2D and am satisfied although it has not been run
yet.
Earl RV4
"EXT-Richard, Emmanuelle J" wrote:
> > Anybody bought used parts (Bendix fuel injection or anything else) from Wentworth
in MSP? Satisfied? Comments?
Subject: | Re: 5 hour report |
--- Bob Japundza wrote:
> Listers,
> I wanted to briefly outline some observations during flight testing
> of my -6.
Coolness, Bob. Makes me want to leave work early and go dimple more
fuse skin holes!
Keep it up!
Mike Thompson
Austin, TX
-6 N140RV (Reserved)
Fuselage
From: | "Owens, Laird" <Owens(at)aerovironment.com> |
Subject: | Electrical Bonding of Controls |
Hi all,
So...how many of you have electrical bonding straps between the your airframe and
the control surfaces.
Don't think you need them????
Check out:
http://lightning.pwr.eng.osaka-u.ac.jp/lrg/temp/plane.html
Simply awesome!
I understand a lightening strike can weld the heim joints together. Now I know
what your thinking, I never fly in that kind of weather.....but you never know.
Fly safely out there,
Laird RV-6 (I'm going put them in)
SoCal (but then again it never rains in California ;-)
Subject: | rear wing spar construction question (rv-6) |
in drilling the doubler and spar flanges the directions say NOT to drill the
holes that attach the wing ribs until rib assembly. there are 5 stations of 2
holes (10 all together). of course this is up at the inboard area. however
the plans say NOT to rivet these ten holes, which are marked with a circle
around the X's until ribs are attached. yes, i know not to put rivets in
until ribs are ... but should i not drill holes or not?????? or drill and
back drill on to ribs when that time comes. ordorff videos have drilled but
no rivets-for what that's worth. i tried calling vans and the phones being
installed at the new facility. thanx, bob in arkansas
Subject: | rear wing spar construction ealier post |
in looking at the photos in plans these are the 5 ribs that are the walk way.
also earlier i should have said the spar flange STRIPS. thanx again
Subject: | Removable Tail Tie Down |
Hi All....(again..),
I remember reading/seeing somewhere that there was a removable tail tie
down sold by someone for the 6A.......anyone have any info....?
Kurt, OKC
Subject: | Re: rear wing spar construction question (rv-6) |
In a message dated 8/11/00 5:47:55 PM Central Daylight Time, Bobpaulo(at)AOL.COM
writes:
<< in drilling the doubler and spar flanges the directions say NOT to drill
the
Hi Bob,
The ribs will end up with three holes each at the rear spar end. The hole to
not drill yet are the center ones. You should go ahead a drill the outer two
holes in the rear spar with the flanges. Then when you attach the ribs, back
drill the ribs (outer holes) through the holes in the spar and then drill the
center hole in each rib through the spar.
Hope this makes some sense. If not contact me off line and I'll try to help.
Eric Newton Long Beach, MS
RV-6A N57ME (reserved) (Flaps)
Eric's RV-6A
Construction Page
eric, i do not see the third hole. yes it makes sense if, but remember this
is where the flap brace will go (middle of spar). i am up at the walk area,
and on the flange strips. guess i need to study plans more.
<< During taxi, the crew of a US Air departure flight to Ft. Lauderdale, made
a wrong turn and came nose to nose with a United 727. The irate ground
controller lashed out at the US Air crew, screaming "US AIR 2771, WHERE
ARE YOU GOING? I TOLD YOU TO TURN RIGHT ON "CHARLIE" TAXIWAY; YOU
TURNED RIGHT ON "DELTA." STOP RIGHT THERE. I KNOW IT'S DIFFICULT
TO TELL THE DIFFERENCE BETWEEN Cs AND Ds, BUT GET IT RIGHT!!!"
Continuing her lashing to the embarrassed crew, she was now shouting
hysterically, "GOD, YOU'VE SCREWED EVERYTHING UP; IT'LL TAKE FOREVER TO
SORT THIS OUT. YOU STAY RIGHT THERE AND DON'T MOVE UNTIL I TELL YOU TO.
YOU CAN EXPECT PROGRESSIVE TAXI INSTRUCTIONS IN ABOUT A HALF HOUR, AND I
WANT YOU TO GO EXACTLY WHERE I TELL YOU, WHEN I TELL YOU, AND HOW I
TELL YOU! YOU GOT THAT, US AIR 2771??!!"
The humbled crew responded, "Yes, Ma'am."
Naturally, the "Ground Control" frequency went terribly silent after the
verbal bashing of US Air Flight 2771. No one wanted to engage the irate
ground controller in her current state. Tension in every cockpit at LGA
was running high. Shortly after the controller finished her heated
admonishment of the US Air crew, an unknown pilot broke the silence and
asked, "Wasn't I married to you once???"
Doug:
My engine has sagged only a very small amount in 10 years, about 3/16" or so
at the spinner. I would build the cowl about 1/8" low to compensate. I
compensated by about 1/4" but it's probably a little too much. O-320
engine on Lord mounts.
Pat Hatch
RV-4, N17PH @ VRB
RV-6, Fuselage
Sent: Friday, August 11, 2000 10:58 AM
> Fellow Listers:
to
> Thanks,
> Doug
> Doug Weiler
> Hudson, WI
> 715-386-1239
There have been a number references to RV panels and
their 8 degree tilt. My panel measures at 6.3
degrees. Does anyone else have some variation here
and does it matter?
Rob Miller
80153 90% done 56.4% to go
I bought an IO-360 from them complete, when the engine showed up, some
parts were missing. (flywheel, vac pump, I think) They were a little
careless in there crating, the harness and the fuel injection lines were
ruined. The engine also included free shipping, except when it showed up
the driver would not leave it until I gave him a check for shipping. They
were very good about replacing the missing items and exchanged even-up my
sump for a different one (although they stripped it first). Getting my
money back took for the shipping took about six months and I finally had to
talk to the owner (Steve, I think) He was very concerned about making
things right. I started the engine last week for the first time, and it
sounds good. They are very straight forward on what they are selling, they
seem to tell it like it is. The engine I bought had about 100 hrs on it
and they said it had a "prop drag". The log books confirmed the overhaul
and hours, Mattituck confirmed what parts where replaced during the
overhaul, (including the ignition harness) and the NTSB Report confirmed
the "Prop Drag". All in all, I am happy with what I got for the price I
paid. Just be sure to be specific and take the name of who you deal with.
Wentworth in MSP? Satisfied? Comments?
Jim Cimino
RV-8 sn 80039 N7TL Reserved
http://www.geocities.com/jcimino.geo
(570)842-4057 N.E. Pennsylvania
Subject: | Re: 8 Degree Tilt? |
My 6A was 7.5 degrees
Gary Zilik
> and does it matter?
so
My experience is similar. Has sagged about 1/8" in 125 hrs.
Randall Henderson, RV-6 N6R (~125 hrs)
Portland, OR
http://www.edt.com/homewing
Are Lord Mounts better than Barry Mounts? Do they permit "sagging" after a
few years or what? (I already bought Barry Mounts).
Chuck
From: | "Steven DiNieri" <capsteve(at)adelphia.net> |
> removable tail tie
> Kurt, OKC
Give George Orndorff a call. he's got the tie down rings and a drilled
and
tapped block for the tail tie down. was very reasonable......
Pay attention to the holes on plans that are for attaching the flap brace.
Don't drill them until you are attaching the flap brace! If you drill them
in advance, more than likely they won't line up with the brace quite right.
When the brace is being attached, drill through the brace into the spar and
into the rib flange. Just make sure you're hitting the rib flange properly.
The other rib holes I drilled in advance and just back drilled through the
rib flange.
Don't forget that some of the rivets that attach the ribs to the rear spar
need to be flush rivets. Check the plans closely. The other rivets are
universal head. You might want to download Will's wing instructions and
read them over. They will save you a few headaches!!
Jerry Calvert
Edmond Ok -6 fuse
Sent: Friday, August 11, 2000 5:34 PM
Subject: RV-List: rear wing spar construction question (rv-6)
the
of 2
circle
but
a
> Chuck
The only reason I used Lord mounts was on the recommendation of a local RV-4
pilot who was having a rather unusual and persistent high frequency
vibration in his airplane. It was a 160 hp with a C/S prop. He even talked
with the people at Hartzell about it. He finally changed his engine mounts
from Barry to Lord and it went away. The Lord mounts have a "gel" filled
type of bushing which may absorb vibration better. The down side is they
are not cheap!!
Doug Weiler
Subject: | Tailwheel endorsement - really required? |
I'd say that if the other guys in the club feel you're ready then you
probably are. I think the important thing is to learn the idiosyncrasies of
the particular conventional geared aircraft that you are going to fly. For
instance, all my tailwheel time is in Aeronca Champs. I would not even
consider trying to jump into a Starduster without some dual. It is best to
learn them from someone who already knows the plane's gotcha's. Better yet
if that person is a CFI. But my opinion is that anyone who has substantial
time in the aircraft working with you is far better than trying to learn on
your own.
Scott VanArtsdalen, MCSE
Network Administrator
Union Safe Deposit Bank
209-946-5116
-----Original Message-----
From: Brian Huffaker [mailto:bifft(at)xmission.com]
Sent: Wednesday, August 09, 2000 6:29 PM
Subject: Re: RV-List: Tailwheel endorsement - really
required?
>Not to beat a dead horse but... If you don't have a
tailwheel
endorsement,
>I don't believe you are ready to fly a high performance
tail dragger. I
>don't have one as I am "grandfathered." I don't have as
many TW hours as
>Scott but still enough to know from experience that a TW
can bite you
when
>you least expect it. Scott has the right approach.
Ok, what about my current situation. Been getting dual in
the
Starduster for a while now, up to about 20 hours. But, the
guys I have
been getting dual from are just the other guys in the
partnership. (mostly
with an ex-AF pilot 5000+hours). They feel that I'm ready
to solo the
plane. None of them are CFI's. I can't find anybody in the
state of Utah
who does tailwheel instruction (two months of trying has
resulted in only
one person who would even return my call to say he couldn't
do it). So,
no endorsement. Hearing that it may be legal, I'm going to
have to go
check the documents to see if it has the operating
restriction. Would be
tairing my hair out of this if I had any left.
Brian Huffaker, DSWL (bifft(at)xmission.com)
President and Founder Friends of P-Chan
RV-8 80091 Riviting fuel tanks.
1/5 Starduster II N23UT flying
Subject: | Aerosport Power Flyoff Period |
I have an Aerosport Power Limited (Bart LaLonde) O360-A1A and Hartzell
constant speed prop on my 6A. In discussing flyoff period with the local
FISDO, the rep said that flyoff period would depend on the logbook entries
made by Bart. My question: Has anyone on the list secured a 25 hour flyoff
period with one of Bart's engines?
Dennis Persyk 6A
Hampshire, IL C38
George & Becky O. (GBI.com) in Ft worth. Install on the F611 in lieu of
the F612.
Don't get into the rudder that way if it bends
Don Jordan -- 6a finish -- Arlington, Tx -- dons6a(at)juno.com
> tail tie
> Kurt, OKC
Subject: | Re: Free Standing Jig ? |
Hi Sam,
On Mon, 7 Aug 2000, Sam Cherroff wrote:
> I've seen a lot of pictures on the various constructors web pages of the
> assembly jig that is used during construction of all of the surfaces. In every
> case the jig is apparently attached to the ceiling.
> My shop has a 16' ceiling and so anchoring the jigs this way would be
> problematic. Are there plans for a free standing jig? Can anyone point me to
> a site that has pictures?
I built one using a long 2x6, sandwiched between 2x4's at each end, using
2x4 cross-braces and such, built to minimize the possibility of twisting,
warping, etc. over time. All this is pretty straightforward, and I bet if
you just start building you'll figure it out.
BUT -- most pictures I've seen show the jig with long boards or long
pieces of plywood for feet. I could not get the jig to be stable with
this kind of setup. My final solution was to use 1/2-inch lag screws as
feet, screwed into some 2x4's of modest length -- that is, the only part
of the jig that touches the floor are those lag screws. They are simple,
make the jig rock-solid, and the jig can be leveled by simply adjusting
the bolts.
I do have some pictures, but they're still in the camera.
-Steve
will's instructions? i need the addy. thanx, bob
Subject: | rear wing spar construction |
sorry guys. one question, do i drill holes in spar flange strips now or when
attaching ribs?
From: | Scott R McDaniels <smcdaniels(at)juno.com> |
Subject: RV-List: 8 Degree Tilt?
and does it matter?
Rob Miller
Rob,
This post isn't directed at you; but the list in general. So please
don't be offended. I just wanted to point out a problem that exists to
varying degrees because of the large # of different RV models and options
available.
Because of the large # of Models and options, a lot of what gets posted
from one person to another (if they are building a different models) is
not at all relevant. A lot of the issues are very similar from one model
to another, but a lot of it isn't. Particularly as the evolutionary
spread gets bigger between what 2 different builders are building.
Example: Even though the RV-4 and RV-8 are both tandem seating airplanes
their are probably more construction similarities between the RV-4 and
the RV-6 then their are between the RV-4 and the RV-8.
Now we throw the RV-9A in the picture... It is almost in a world all of
its own and it is likely difficult for someone to give (detailed)
construction advice without having built one.
When builders start installing systems (engine, etc.) the info starts to
become much more generic and interrelated, but their are still many
differences. For instance... an oil cooler installation on an O-320
powered RV-4 which causes oil temps that are too low, may not be
adequate on an O-320 powered RV-6A that is operated in a warmer
environment.
Everyone should keep this in mind when posting to a question, or when
reading posts that have been made. At times I see a lot of bandwidth
wasted with posts that wouldn't be relevant to the original question.
More important than the wasted band width though, is that it is very
difficult for new builders to differentiate and decipher all of this
information.
It can easily raise the question...Is any of it right?
Something that I would really like to see on the List is that anyone (and
many do already) that makes a post (question, answer, or otherwise) signs
it with a signature that states:
Name, City/State, RV-model, Engine model, Prop. model, N-number/flight
hours (showing if it is flying).
Any other info could be added that you choose. If you are not at the
point of having an engine or prop yet, that info can just be left off (or
you could write "planning for O-360 with Sensenich fixed metal prop.,
etc.)
All of the E-mail programs I am familiar with allow you to pre make up a
signature and add it to the end of any message (like the one I have on
the end of this message) with only a Ctrl/something key stroke. If you
don't know how to do it on yours, I'm sure someone here on the list could
help.
What does everyone think of the idea? I think it would make the
information on the list much more valuable.
Scott McDaniels
North Plains, OR
These opinions and ideas are my own and may not
reflect the opinions or ideas of my employer.
Subject: | Re: Aerosport Power Flyoff Period |
The new 9A got 15 hours but it was factory built. It has an Aerosport
engine with the MT prop. Sounds possible.
Mike, RV-4, N996RV, Aurora, OR
>Dennis Persyk 6A
>Hampshire, IL C38
Subject: | Re: Navaid servo shaking |
>Sam Buchanan (RV-6 faithfully guided by Navaid and Lowrance AirMap 100)
>"The RV Journal" http://home.hiwaay.net/~sbuc/journal
Sam your just the man I need to talk to. I have the same setup you have,
Lowrance Airmap 100. Is there something I have to program into the lowrance
to get it send info to the NavAid?
I havee with this off and on quite awhile with now success. Could talk me
throught the step you took?
Thanks!
Have a good one,
Denny RV-6
Lebanon, OR
From: | "Jerry Carter" <jcarter8(at)midsouth.rr.com> |
Subject: | Re: RV-8 Wiring Drawings & kit... |
> I have the RV-8 wiring drawings from Van's, but have not ordered the
wiring
> kit yet... Has anyone ordered the kit from Van's? If so, was it a good
> deal? Was it pretty complete? Do you have an inventory of what came in
the
> kit?
If you're planning on using Van's plan for wiring, then go ahead and get the
kit. I bought the kit, then ended up using Bob Nuckoll's plans, including
the firewall ground block, so the precut wires were wrong for me in most
cases. I still used a lot of the wire, especially the larger guage wires,
but, if I had it to do over again, I would just order the wire, contactors
and everything else from Bob or Spruce. The kit has wires that are labeled
as per their plans, which is nice, but you can do something similar with
clear heatshrink and a printer. If you would like, email me off list and I
will be happy to fax you the inventory of what's in their kit.
Jerry Carter
Memphis, TN
My RV-8A website:
http://rv8asite.homestead.com/mainpage.html
entries
flyoff
> >Dennis Persyk 6A
> >Hampshire, IL C38
Ed Storo and Frank Hoover both got 25 hour flyoff periods with Aerosport
0-360 A1A's.
Jerry
Subject: | Van's Alternator |
Lister's,
I have 17 hours on my 8A and all is going well. Today, my alternator stopped
working. My amp meter showed several wild fluctuations & then started to
discharge. I secured all non-essential electrical gear & headed home about
30 mins.
I checked all the wiring looking for grounds etc, the contiinuity was good.
I took off the Van's alternater to inspect & several peices of solder fell
out of the unit.
I am planning on sending back to Van's for replacement.
Have any of you had the any expeirencewith the Van's alternator, or did I
just get a bad one?
Not to happy to have the A/C out of service for several days, but still
smiling.....Mark
Mark Steffensen
8A Dallas, TX Flying 17 hours
Subject: | Re: Van's Alternator |
In a message dated 8/12/00 3:25:07 PM Eastern Daylight Time,
steffco1(at)home.com writes:
<< Lister's,
30 mins.
out of the unit.
just get a bad one?
smiling.....Mark
Mark Steffensen
8A Dallas, TX Flying 17 hours >>
There are quite a few stories in the archives about Van's alternators. Some
experiences have been good, some bad. I know that Mike Seager carries a
spare alternator with him on his travels in the factory RV-6 (to me, this
indicates a bit of a reliablility problem). Also, I know that both the
in-service and spare alternator died on his visit to Lebanon TN last year.
This indicates a bigger problem.
As Bob Nuckolls suggests, I spent the big $ and got the one from B&C.
KB
Subject: | Re: Standard Signature |
Great idea, Scott. I think Matt has been trying to get everyone to
standardize their signatures for some time. Anyway, for those who want to
create a signature on Outlook Express, go to the Tools menu, Options,
Signature, and create your signature. Then before you send a new message go
to Insert and add your signature.
Pat Hatch
RV-4, N17PH @ VRB, 700 hours TT
O-320, Hartzell C/S
RV-6, Fuselage
Sent: Saturday, August 12, 2000 12:26 PM
Subject: RE: RV-List: 8 Degree Tilt?
> and does it matter?
> Rob Miller
> Rob,
please
> available.
> environment.
> information.
N-number/flight
> etc.)
> help.
> Scott McDaniels
> North Plains, OR
Subject: | Re: rear wing spar construction |
In a message dated 8/12/00 11:45:25 AM Central Daylight Time,
Bobpaulo(at)AOL.COM writes:
<< sorry guys. one question, do i drill holes in spar flange strips now or
when
attaching ribs? >>
Now. Drill the holes in the spar flange strips and spar. When you install
the ribs, back drill through the flange strips and into the ribs. Just don't
drill the middle holes until you install the flap brace. That way you know
it will line up correctly.
Eric Newton - Long Beach, Mississippi
RV-6A N57ME (Reserved) (wing skinning)
Eric's RV-6A
Construction Page
From: | Warren Gretz <warrengretz(at)gretzaero.com> |
list-aviation ,
list-avionics ,
list-ez ,
list-glasair ,
list-lancair ,
list-rocket
Subject: | Heated pitot tubes |
Hello builders,
I currently have a large stock of Heated Pitot Tubes in the popular
PH502-12 CR (formaly AN5812) and the AN5814 which has a heated static
source built in to it. Both of these pitot tubes are 12 volt.
I also have heated pitot tube mounting bracket kits for the above pitot
tubes.
There are other items that may be of interest to you for your project.
To see the above mentioned pitot tubes and mouting brackets and all the
rest of my products, look at my website at
http://www.gretzaero.com
You may contact me by phone in the evenings and on weekends. You may
also send me your order by way of my website.
Warren Gretz
Gretz Aero
303-770-3811
In a message dated 8/11/00 8:10:10 PM Pacific Daylight Time,
rmill2000(at)yahoo.com writes:
<< Does anyone else have some variation here >>
Mine is 7 degrees and I triple checked all the dimensions before I nailed
things down. Go figure.
Harry Crosby
-6 finish kit stuff
Subject: | Re: idiot light switches |
Check the archives. There are several sources for dual contact pressure
switches i.e. NO & NC. I purchased a 6 psi switch from Chief that is
working fine on my oil system. I don't have a low pressure fuel light, just
the VM1000 pressure gauge.
Tom Brown RV4 flying 26 hours
RV4Brown(at)aol.com
I will be very interested in knowing what type of sign off is required
in the logbooks to be entitled to the 25 hour test period using an Aerosport
derivative Lycoming engine. I have an Aero-Sport O-360 that is
non-certified. The placard on the engine says it is an Aero Sport not a
Lycoming. I have been assigned the forty hour test period, no landings at any
other airport unless it is an emergency, no night flight, and no passengers.
The propellor is a new Hartzell CS.
I have flown 26 of the forty hours plus a few hours of preflight taxi
time. I don't feel the time has been wasted and I am surprised how fast it
goes by. If you go through a thorough methodical process of testing the
airplane in different weight configurations, ( the 4 is a different airplane
with the back seat loaded),determining the best rate of glide, determining
glide rates at different weights and air speeds, charting speeds versus
power settings via 3 turn GPS procedures at different altitudes, stall speeds
at different weight configurations, spins left and right, performing whatever
aerobatics are going to be signed off in the logbook, rate of climb at
various airspeeds, and performing operational checks on the various systems
and radios, you are going to need the time. In addition, while doing the
above, especially in my case, I have managed to regain some of my flying
skills which were badly neglected during the six year building process. I
think I built a pretty good airplane. However, I have found I have spent at
least three hours of tinkering and making small changes and checking things
out for every hour in the air.
With all that stated, I am ready to get out of the box, go somewhere, and
take some well deserving folks for a ride. Nothing has happened to date that
has put either me or the airplane in peril, but I think it has been good that
I have done this alone for the first 25 hours. I am not sure how I will feel
after flying the next fourteen. So far it continues to be an enjoyable
learning experience. I gain more respect for the design with each flight. I
do wish I had a cloaking device to hide a few of my takeoffs and landings.
It does handle different loaded.
RV4brwon(at)aol.com
From: | Will Cretsinger <cretsinger(at)arlington.net> |
RV-6/6A WING CONSTRUCTION NOTES:
Frank Justice Supplemental Instructions:
http://www.edt.com/homewing/justice/index.html
Will Cretsinger Wing/Tilt Canopy Notes: <http://www.flash.net/~gila>
Frank van der Hulst wing notes:
Hi folks
Just started working on the spar cary through.
looking at the F804-H which according to the drawing has a dimension of
24 21/32. the flat plates which came with the center section and which
are marked F804-H are only 23 31/32 long.
Is the missing 22/32 a problem or a dimensional oops on the drawing.
Gert
Pursuant to US Code, Title 47, Chapter 5, Subchapter II, '227,
any and all nonsolicited commercial E-mail sent to this address
US. E-mailing denotes acceptance of these terms.
In a message dated 8/12/00 4:31:04 PM Central Daylight Time, HCRV6(at)AOL.COM
writes:
<< Anyone know how to do this on AOL? >>
Hi Harry,
On AOL click on "Mail Center" at the top of the page. Then click on "Set Up
Mail Signatures." A little box comes up. Click on "Create." In the
signature name put what ever you want to call the signature. In the space
below type in your signature that want. (See mine below for what it looks
like.) When you are satisfied with it click "OK." The original box comes
back. Click on the button that says "Default ON/OFF" and this signature you
just created will pop up automatically on every email you generate (for that
screen name only).
Hope this helps,
Eric's RV-6A
Construction Page
Yes, I got only 25 hours but only after an AP signed my logbook that all
the applicable ADs had been complied with. (Even though the engine has an
experimental data tag.) (And even though experimentals don't need to show
compliance with ADs). However, if you don't do it, you are guaranteed 40
hours.
RV-6 (42 hours)
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Sent: Saturday, August 12, 2000 10:07 AM
Subject: RV-List: Aerosport Power Flyoff Period
flyoff
> Dennis Persyk 6A
> Hampshire, IL C38
>Hi folks
>Gert
Gert,
I just measured my fuselage to refresh my memory - 24 21/32 is what
my plans say, and that looks just about perfect on my fuselage. I
recall I had to trim it very slightly in length so it wouldn't
interfere with the upper longeron - less than 1/16 was removed.
Something is wrong here - I would talk to Van's and get them to send
new parts, or a drawing change to match your parts.
Kevin Horton RV-8 (mounting elevators, etc)
Ottawa, Canada
http://members.xoom.com/kevinhorton/rv8.html
Subject: | Burlington Colorado Flyin |
Listers,
It is hard to believe but a year has almost past and it is again time
for the RV Builder's Dream Event in Burlington, Colorado. The 5th Annual
Burlington RV Flyin happens this year September 22nd-24th at ITR in
Eastern Colorado.
Events this year include a Poker Run and for you real competitive guys a
Speed Race. Awards judging also takes place so bring your pride and Joy
and take home a beautiful trophy.
Burlington is not for flying RV's only. No matter how you get there
there are forums on how to make it go faster and for the builders
amongst us lots of airplanes to look at and builder/flyers to answer
questions.
If you have MS-WORD http://www.geocities.com/zilik/Burlington.doc has
all the info. For those who do not have MS-WORD I have converted (poorly
mind you) the word document to html and this can be viewed by going to:
http:www.geocities.com/zilik/Burlington.html
So mark you calendars and come and visit us in Burlington, Colorado. The
best RV flyin in the US.
Gary Zilik
RV-6A - 0-360-A1A 75 hrs and counting.
> Thanks!
Denny, I messed around with my Navaid for over six months before I got
it to track the Lowrance. However, the problem was not with the Lowrance
but a lapse in Navaid's documentation.
Fellow Alabama Redneck and RV-6A driver Bob Butler installed a Navaid in
his plane ( http://home.HiWAAY.net/~sbuc/journal/navaid.html ) and the
thing worked perfectly with his Lowrance Airmap 300 right out of the
box. This was really irritating to me since I had been flying my Navaid
for six months with no tracking. One day Bob casually mentioned the
jumpers on the back of his Navaid connector.
"Jumpers? What jumpers?"
Seems that Navaid included a note in the documentation newer than my
unit that if you are using a handheld GPS only, that you need to include
a couple of jumpers to replace the switch that was formerly used to
select either panel nav radio or handheld GPS.
Since I don't have a panel mounted nav, and the notes weren't in my
diagram, I hadn't installed the jumpers. Once the jumpers were plugged
in, the system immediately began to track the Lowrance!
Needless to say I was a bit miffed at Navaid for leaving me dangling for
six months. I called them and the answer I got was "Yeah, I decided that
I had better put that note in the diagram."
An astute electrical type individual would have picked up on the need
for the jumpers after carefully tracing the wiring through the switch,
but I missed it.
So, make sure you have two jumpers on the Navaid connector if you are
using the Smart Coupler with a handheld GPS and no other nav radios. I
don't have the pinout info in front of me, reply if you need more
details or call Navaid.
Yeah.....call Navaid. Let them know that they messed up another builder
by not sending complete documentation.
The GPS only needs to have the NMEA string activated along with the RMC
and RMB sentences. You find these switches in the NMEA setup menu.
That should get you going. If you can't get a green light on the Smart
Coupler then the data isn't getting to the Navaid.
Unless.............you have a bad Smart Coupler. The original coupler on
my unit had a hard time consistently reading data from the Lowrance. I
will spare you the details, but there were several contacts with Navaid
concerning this issue, each time they INSISTED that the coupler was good
and that my wiring had mysteriously gone bad.
It wasn't. I finally got them to replace it at Sun-N-Fun (the coupler
checked good on their test rig) and now it works perfectly. The same
thing has happened to fellow redneck Robin Hunt's Airmap 100 in his
RV-8, Navaid insisted the unit was good, and it wasn't. Apparently some
Smart Couplers have problems reading the Airmap 100. So if all else
looks good, INSIST that Navaid replace the coupler in your unit (they
will do so only after telling you that there HAS to be a problem in your
airplane..(tell them Sam Buchanan sent ya)....we proved them wrong by
switching units between planes.)
Good luck with your installation. The Navaid works beautifully once you
get it going, and I suspect the Lowrance Airmap 100 issue is pretty
rare.
Sam Buchanan (RV-6, 165 hrs)
In a message dated 8/12/00 10:19:37 AM Pacific Daylight Time,
smcdaniels(at)juno.com writes:
<< There have been a number references to RV panels and
and does it matter? >>
Measuring the panel angle as it sits on the ground is fine only if you intend
to drive it on roads. I prefer to fly mine, so it is important that it
reflect a cruise flight attitude. This is 8-10 degrees forward tilt. The
instrument allows for some adjustment.
-GV (RV-6A N1GV)
vanremog(at)aol.com
>I need to find the sensor switches for the low oil & low fuel pressure
>lights???
Our website catalog has a single pole, double throw pressure
switch suitable for a combination oil-pressure warning and hourmeter
control. See http://www.aeroelectric.com/Catalog/catalog.html
(o o)
===========o00o=(_)=o00o========
< Independence Kansas: the >
< Jurassic Park of aviation. >
< Your source for brand new >
< 40 year old airplanes. >
From: | Frank and Dorothy <frankvdh(at)ihug.co.nz> |
Subject: | Re: Bunny's Guide is moving... was Re: rear wing spar construction |
question
(rv-6)
Thanks for the plug Will. But...
I'm changing ISPs, and therefore moving my homepage... the one you
quoted will disappear in a week or so. The Bunny's Guide pages are also
available at <http://members.xoom.com/frankv>
The new version isn't quite done yet, but pretty much everything is
available now via <http://fly.to/bunnysguide>. That address should (in
theory) remain valid forever... whenever I move my pages I'll be able to
point the fly.to address at the new location. The downside of this
redirection is that fly.to adds a pop-up window. That's not a huge pain,
especially if you have something like PopupHunter to automatically kill
their popup window. For those who prefer to go more directly, the new
Bunny's Guide pages will reside at
<http://gringo.whanganui.ac.nz/personal/frankv> for the foreseeable
future. At some time in the distant, unforeseeable future they will
probably move again.
Those people with links to my pages, please update. Thanks!
For the newer list members, the Bunny's Guide to RV Building is my
self-imposed task to provide a central clearing house for exchanging
what we learn about RV building. In practise, it's mostly stuff I've
written, plus some notes provided to the Guide by various people, plus a
fair number of posts copied from the RV-list. Since I'm building a
non-QB RV-6 with tip-up canopy, stuff that's specific to other models,
specific to the QB, or to the slider canopy probably isn't present.
Having said that, there's still a lot of common ground for most RV
builders. I welcome submissions to the Bunny's Guide any time
(especially submissions relating to stuff I haven't done myself yet!).
The submitter may choose to have their submission included in the Guide
either anonymously or with due credit.
Frank
Marton NZ
RV-6 tip-up, building canopy
Subject: | RV8 Flap Brace Installation - Results |
What was the final word on the flap brace tread from March.
We have the same problem, are getting a small concave bowing of the wing
skin - due to the inboard buildup of the doublers(proper word).
Was the resolution just to live with it?
Has anyone received an answer from Van's?
Thanks & Good Building,
Chuck & Dave Rowbotham
RV-8Aqb
Niantic, CT
Subject: | Re: RV8 Flap Brace Installation - Results |
I got new flap braces from Van's, took some doing as the first person I
talked to insisted nothing changed
Finally this person looked in the drawing and told me the angles
changed and i should just re-bent the ones I had (WHAT ???!!!??).
I told hime the dimensions changed also as there is less lenght between
the 2 bends.
He finally agreed to send me one new one as the first was allready
installed. I bowed the installed brace slightly and that pulled the skin
back in line.
Gert
> RV-8Aqb
> Niantic, CT
Subject: | scale on pistons |
During my annual with all the plugs removed I shone a light into the cylinder
and looked in at the top of the piston. About 30-40% of each piston top is
covered by a dry flacky scale.
Is this normal? How much build-up is acceptable. The Sky Ranch book says that
the absense of build-up is a sign that the engine is running too hot and has
melted it off. However with all the recent talk about stuck valves, I can
easily imagine some of this scale breaking free and getting into the valve
seat.
All else looked good. The plugs were relatively clean with very little or no
build-up down near the ceramic piece. There was also a small sheen of oil in
each cylinder.
Andy
Subject: | F-690/Elev Push Tube |
Hey Folks,
Its been one of those weekends.....just when it all seems to be going
together so well.....!!! I assembled the F-690 push tube per the plans,
with out making any cuts or trimming, leaving it at 78" in length. Mounted
the HS and Elevators and went to make the final cut/adjustments and wouldn't
ya know it...its about 1" too short. I checked everything I could think of:
I got the right tube...1 1/2 x 78", The bellcrank is in the proper location,
bellcrank is in the proper position, the controls were locked in the neutral
position, with the elevators in trail (neutral). The bellcrank in the center
was positioned almost vertically (when neutral)....so Im kind of at a loss
what is going on....hmmmmm....any ideas??? Obviously I need a new
tube....but logic would tell me that the folks at vans would make it a bit
long to start and leave a bit to be trimmed. I building a QB, 6A......hey
maybe I got the "SF" version (streched fuselage). Help!!!
Kurt, OKC, OK
RV 6A QB
Subject: | Re: F-690/Elev Push Tube |
Kurt,
I spent my weekend doing the same thing - working on the F-690 and F-689.
Don't toss your F-690 yet. Have you fitted your F-689? The way I read it
you start with the eye-bolts extended to about their max extension on the
F-690 and then fit your F-689. With the elevators in full "nose-up"
(stick-back) position you need about 1/8" clearance from the control arm to
the main spar. I ended up with about 1/4" which means I can shorten my
F-690 (taking up some treads) to get the full stick travel. I did it this
way because determining the controls neutral position seemed to be more
error prone. Maybe someone that's flying can shed some more light on this
for us...
Chuck
RV-6 QB
Sent: Sunday, August 13, 2000 3:44 PM
Subject: RV-List: F-690/Elev Push Tube
> Hey Folks,
Mounted
wouldn't
of:
location,
neutral
center
> Kurt, OKC, OK
> RV 6A QB
Hi All,
in an attempt to liven this list up a bit more
I'm just curious as to what sort of touring
you guys have done in your RV 3's?
Here in Australia theres lotsa things to do but
flying in America seems pretty good after having
a quick look at the map and hearing/ reading a few stories
about what its like over there.
Bruce Stewart
check the archives with the following search string, and you'll find more
info on this.
alex & elevator & bellcrank
Alex Peterson
Maple Grove, MN
6A O360, Airflow, CS
may fly in '01
------ http://USFamily.Net/info - Unlimited Internet - From $7.99/mo! ------
Subject: | Fold-up motor scooter |
Hi gang,
Has anyone on the list tried out the DiBlasi folding motor scooter? I saw
it at 'Kosh
and have been considering trying one out. If it fits in the back seat of a
-4 it would be a great companion on long trips.
Louis
Louis I. Willig
larywil(at)home.com
RV-4, N180PF, 30 hrs.
I0-360, Hartzell C/S
(610) 668-4964
Philadelphia, PA
Subject: | Re: F-690/Elev Push Tube/FIXED!!!! |
Thanks for all the emails guys.....by doing some more head scraching.....and
adjusting of my Rod End Bearings I was able to make it work and still keep
the Rod End Bearings half way or more engaged. Sure is fun to move the stick
and finally see something move......
Thanks again,
Kurt
Subject: | Re: Homecoming Q's |
In a message dated 8/13/00 4:47:49 PM Pacific Daylight Time,
akroguy(at)hotmail.com writes:
<< We'll be flying up the California coast from Corona after
picking it up from the painter. You guys know of any northern California
coastal airports that offer great views and food for us to visit on the way?
Shelter Cove is a nice place.
-GV (RV-6A N1GV)
vanremog(at)aol.com
> Howdy folks,
> Since I've never been to the Aurora/Portland area,
> how long a drive is it to
> get to the beach? My wife would like to get in some
> quiet time while I'm
> immersed in RV heaven. ;) Are there any cheap but
> clean hotels near the
> beach and is the climate conducive to sunning or is
> it cool and cloudy most
> of the time? Gotta keep my sweetie happy...without
> her I wouldn't be flying
> an RV! The homecoming will be the first major RV
> gathering for my freshly
> painted RV8. We'll be flying up the California
> Thanks,
> Brian Denk
> RV8 N94BD
Hi Brian
Half Moon Bay has a nice stroll into town--Barbara's
Fish Trap is one of my favorites.
Shelter Cove also has a good Seafood restaurant.
Rob Miller
The statements and opinions are mine and EXACTLY
reflect those of my employer.
From: | "Sally and George" <aeronut58(at)hotmail.com> |
Gert:
Shouldn't be a problem. Use what you have.
George Kilishek
RV8 N888GK (reserved)
Sent: Saturday, August 12, 2000 5:12 PM
Subject: RV-List: RV8 F804H
> Hi folks
> Gert
Subject: | Re: RV3-List: Re:Travelling |
> Hi All,
> Bruce Stewart
I bought my RV-3 in Seattle, Washington and flew it back to Kansas City,
Missouri via.....
1. Portland, Oregon and the Columbia River Gorge
2. Twin Falls, Idaho
3. Jackpot, Nevada
4. Wendover Utah (Bonneville Salt Flats)
5. Provo, Utah (Great Salt Lake area)
6. Interstate 80 across Wyoming to Cheyenne
7. Direct to Russell, Kansas via a small corner of Colorado
8. Direct to Grain Valley, Missouri
I'd guess this round about route exceeded 2000 miles in a strange plane
over some of the toughest country that the USA has to offer.
It was the most memorable trip I've ever made since my first x-country
in 1954.
Bob Urban - N863WL
I'm going X-Country from Paine Field Everette, WA to Lawrence, MA at the end
of the month. 2500nm+ total distance in a week. How's that? Great circle
is over Mountana, North Dakota, Nebraska, Wisconsin, Michagan, Toronto and
upstate New York.
I just added the RMI fuel flow meter to my MicroMonitor. It helps plan fuel
stops more accurately en-route. So far it's worked great! I'm still
calobrating, so my fuel numbers aren't perfect yet.
Soon I'll post my accurate performance numbers as promised.
Bruce Meacham
Sent: Sunday, August 13, 2000 6:19 PM
Subject: RV3-List: Re:Travelling
> --> RV3-List message posted by: Bruce Stewart <bruce@triton-dive.com>
> Hi All,
> Bruce Stewart
Bruce Meacham wrote:
> --> RV3-List message posted by: "Bruce Meacham"
> upstate New York.
Hi Gang.
IFR, not great circle, was/is my choice over tough/barren country.
IFR = I Follow Roads - Interstate my specialty.
GPS certainly beckons me to fly great circle routes, but Murphy's Law
keeps me thinking... 'WHAT IF'.
This is one reason why my 'lil RV is named 'Serendipity'.
Going down in the middle of hostile nowhere with just my tennies and tooth-
brush would not make for a good day... even with cell phone and ELT aboard.
A MicroMonitor will get into my panel someday, too.
Fuel flow can sure add fun, mental comfort and SAFETY of things.
As it is, I like to keep an hour reserve.
With my RV3 holding only 25 gallons, I figured I might have problems,
but it turns out 2 hours is all I care to fly in one sitting.
My kidneys do fine, but not these damn old bones.
I once had visions of wing + header tank for some super serious
non-stop, long X-countries. Not anymore.
It's hell getting old, kids.
Ya know....
As fast as our RV3's fly, it's good to stop often...
Just to see if the folks down below still speak English.
Be well,
Bob Urban
> when
> attaching ribs? >>
I did the opposite preferring to not assume that the ribs would end up
in precisely the position I had drilled.
In cases such as this I pilot drilled the rib flange then back drilled
through this pilot hole into the spar. So to clarify, I omitted the
holes where the ribs would attach during the initial rear spar assembly.
Doug Gray, Sydney, Australia, RV6 skinning right wing.......
Gert,
Thanks for the info. We have installed both our braces and they don't look
to bad. We had better luck with the second one: since we drilled the brace
to the skin - then the hinge to the skin - then riveted the three together.
I think we'll wait and see how it flys and bow the brace if we need to.
Thanks again for the info.
RV-8A (wings on in 2 weeks)
Niantic, CT
>From: gert <gert(at)execpc.com>
>Subject: Re: RV-List: RV8 Flap Brace Installation - Results
>Date: Sun, 13 Aug 2000 12:38:28 -0500
>the 2 bends.
>back in line.
>Gert
> > RV-8Aqb
> > Niantic, CT
Subject: | Re: Engine Mounts, Barry Mounts , Lord Mounts |
08/14/2000 09:04:16 AM
Reposted for Electronic Searching
dougweil(at)pressenter.com on 08/12/2000 10:11:30 AM
Subject: Re: RV-List: RV-4 cowling installation
after
a
> Chuck
RV-4
talked
are not cheap!!
Doug Weiler
From: | "EXT-Richard, Emmanuelle J" <Emmanuelle.Richard(at)PSS.Boeing.com> |
Dealt with the press at several occasions regarding sports and aviation related
projects. From my experience:
Same experience as previously reported by other listers with "newpaper" type press.
I won't talk to them at all unless you personnally know the journalist or
you are trying to promote a personal project, get some coverage for sponsors
or free advertising.
If you decide to do it. Write the article for them, give them the technical information
(not too tech), the numbers etc so they dont get it wrong. Remember
they will be very flattering and agreeable to anything until they get the material
they are seeking. Don't assume they will keep the promises they make.
After they have left your hangar, you have no control over the information anymore,
it might be even difficult to get a hold of them. Watch what you say:
especially if you are talking with somebody who does not have a clue about aviation,
if you don't want to see it come up in the article, don't even mention/imply
it. Don't say anything negative or that can be interpreted in the wrong
way, that's what they will remember. Don't answer the question they ask you,
use it as an opportunity to talk about what you want to convey. Their job is
to sell newspapers, not to promote aviation - they will talk about what sells.
Writers specialized in the field you are dealing with do usually a pretty decent
job as they have some understanding of the subject and their audience is different.
Still, doing the work for them is a good way to get a decent outcome.
Good luck
They sent me one with the wrong core. Tried to fit it to the engine but no
luck. It was a whole inch out of alignment. Looks like they need to find a new
supplier for alternators. Ether that or develop some kind of simple acceptance
test to weed out the boogers.
- Jim
RV8A ( engine stuff )
N89JA (reserved)
Thread-Topic: RV-List: Van's Alternator
Thread-Index: AcAGAK5UNrPt+1hDSMWn5qFhz6IVzAAABRqQ
From: | "Bob Japundza" <Bob.Japundza(at)realmed.com> |
When I was installing my Van's alternator, I had it on the edge of the
workbench and mysteriously it found its way to the concrete floor,
putting a nice crack in it. Rather than getting another one from Van's,
I ventured down to the local autoparts store (Advance Auto Parts) with
my ailing alternator in tow and asked the person at the counter for a
replacement. Long story short (the usual "its outta a what? Did you
say an airplane?"), he ran the numbers stamped on the alternator and
found that it was from an 81 Honda. He could have a rebuilt one to me
in a day. Cost was $45. I came back the next day, exchanged for the
new one, opened the box, and was pleasantly surprised. The quality of
the rebuild was MUCH better than what Van's sells. The replacement
alternator came with a sheet of detailed test data/graphs showing
various voltages and currents at different alternator RPM's, along with
some care and feeding info. I did have to swap pulleys and remove the
fan. It puts out 40 amps. I'll dig up the paperwork tonight to find
out who the remanufacturer is and their part number and post it to the
list. So far my alternator is working well, without any additional
cooling.
Bob Japundza
RV-6 N244BJ 180-CS 13.5 hours
From: Jim_Andrews(at)tivoli.com [mailto:Jim_Andrews(at)tivoli.com]
Sent: Monday, August 14, 2000 9:17 AM
Subject: Re: RV-List: Van's Alternator
stopped
to
no
find a new
acceptance
- Jim
N89JA (reserved)
Subject: | Van's Alternators |
I have had good service from Mark Landall in Oklahoma City (or thereabouts)
with his alternator..no problems in over 5-years...did have a solid-state
regulator burn up, and he mailed me a replacement the same day I called, and
sent it only on my promise to mail him a check...
He has an ad in Sport Aviation each month...
FWIW RV6A Flying
Salida, CO
Subject: | Re: Fold-up motor scooter |
I briefly tried the DiBlasi scooter at his hanger at LNA, and true to first
impressions, its pretty squirelley handling-wise. As an long time mo'sicle
rider, I personally would not ride it much farther than I can walk. I guess
you could get used to it, but not for what he wants for it as far as I'm
concerned.
Subject: | Re: Van's Alternators |
08/14/2000 01:42:06 PM
I can second Mark Landrol's systems. He also has a light-weight Aluimum
pulley that spins the alternator a little slower too. He also has a Toyota
(or Datsun) starter that I am using on my Lycoming. I know many of these
starters in the field & mine has been running for over 6 years. It is also
lightweight and many hundreds of dollars cheaper then the other brands. I
purchased a junk starter from the junk yard (for 4 dollars) that was the
same make & model of the new one I got from Mark. (I wanted spare parts and
probably had nothing better to do that Saturday). I took the junk starter
apart & was very impressed with the pin bearings & overall qualitity of the
unit. (Didn't want to take my new one apart)
"John" (at)matronics.com on 08/14/2000 12:47:56 PM
Sent by: owner-rv-list-server(at)matronics.com
cc:
Subject: RV-List: Van's Alternators
and
FWIW RV6A Flying
Salida, CO
Subject: | Re: Tailwheel endorsement - really required? |
I thought this issue had been resolved.
The exceptions in (k) do apply. It clearly states in (k) Exceptions. (2) The
rating limitations of this section do not apply to--
(iii) The holder of a pilot certificate when operating an aircraft under the
authority of an experimental or provisional aircraft type certificate;
Now lets get back to building.
Cash Copeland
RV-6 N46FC (Reserved)
Oakland, Ca
In a message dated 8/14/00 1:40:24 PM Central Daylight Time, bj034(at)lafn.org
writes:
Although this does not apply to me (30 plus years in tailwheels), my new
operating limitations (1 day old) state:
"The pilot in command of this aircraft SHALL hold a category/class
rating, or an authorized instructor's logbook endorsement. The pilot in
command MUST meet the requirements of 61.31 (e), (f), (g), (h), (i),
and (j) as appropriate." (emphasis added)
This tells me that the restrictions in (i) DO pertain to my aircraft and
the exceptions in (k) do not apply. I think this is pretty clear and not
open to interpretation.
Dave Bristol
RV-6 and pilot ready to fly, prop governor not
Subject: | Attachment of cowl cheeks |
I'm getting ready to install the cheek pieces on my -4 and would appreciate
recommendations on whether or not to use an adhesive in addition to rivets.
Also, if I use Pro-Seal, do any Listers have experience with its ability to take
paint?
Thanks in advance for the help.
Dean Pichon
Arlington, MA
**** This message is from Arthur D. Little, Inc., and/or one of
Arthur D. Little's subsidiaries or affiliates and may contain
confidential business information. It is intended for the addressee
only and may not be copied without our permission. If you are not
the intended recipient please contact the sender as soon as possible.****
Subject: | Wire mounting in FWF |
Can someone tell me if you need to use a special type of tywrap ( high
temperature ) to secure wires when organizing the mass of sensor wires fire wall
forward?
I currently use the "black" UV protected tywraps everywhere else on the plane.
Jim Andrews
RV-8A ( engine stuff )
180 HP ( O-360 )
Fixed pitch Sensenich (85)
Austin, Texas
N89JA (reserved)
blood type A-
mothers maiden name "Roach"
member in good standing of the "Book of the month club"
From: | "Gardner, Douglas (GA01)" <douglas.gardner(at)honeywell.com> |
Subject: | Lycoming Service School |
Anyone been to the Lycoming engine service school ?? It's 4 days in
Williamsport Pa. I'm ready to order my new 0-360 from Van's for my -8A and
thought this training would be invaluable. Any comments ??
Doug Gardner -8A 80717
Painting interior
Palm Harbor Fla
(EMWAC SMTPRS 0.83) with SMTP id" <B0004967128@mail-2.lbay.net>;
Mon,
14 Aug 2000 14:57:39.-0700(at)matronics.com
Well Dean, I'll give you my 2-cents worth. Unless you are 100% absolutely sure
those cowl
cheeks will never ever need to come off --- I would just rivet them. It doesn't
take many
rivets to attach those cheeks.
I have learned to delay final assembly of items as long as possible. The cheeks
were a case
in point. After the cheeks were positioned with clekos and the cowling was fitted,
I decided
to attach the cheeks with a few screws & nutplates. To make a long story short,
I remove
my cheeks to pull my cowling hinge pins. I also have my adjustable voltage regulator
behind
one of the cheeks.
Anyway, I recommend you just put a few rivets in there --- your cheeks won't pucker.
Clay Smith, RV-4, N9X, waiting for an inspector
Indiana
> paint?
> Dean Pichon
> Arlington, MA
> _-
> _-
> _-
> _-
>** --------- End Original Message ----------- **
Never heard of it, but it sounds like it would be worthwhile... do you have
a link to a web page describing the course and its cost?
Troy Whistman
From: Gardner, Douglas (GA01) [mailto:douglas.gardner(at)honeywell.com]
Sent: Monday, August 14, 2000 3:59 PM
Subject: RV-List: Lycoming Service School
Painting interior
Palm Harbor Fla
From: | "Gordon or Marge Comfort" <gcomfo(at)tc3net.com> |
Subject: RE: RV-List: Van's Alternator
>fan. >
>Bob Japundza
Bob: Why did you remove the fan?
Gordon Comfort
RV-4 N363GC
Subject: | Re: Lycoming Service School |
There is an article by Vicki Kruse in Aug 2000 Private pilot on the school.
(Click here to visit our Club site at http://www.bellanca-championclub.com)
From: "Gardner, Douglas (GA01)" <douglas.gardner(at)honeywell.com>
Sent: Monday, August 14, 2000 3:58 PM
> Thanks,
> Painting interior
> Palm Harbor Fla
What is the difference between an Artificial Horizon set up for 8 degree
panel ?
AHI's still work if the aircraft is climbing or diving (more than 8
degrees), if the AHI has an adjustable "little aeroplane"(zero pitch
adjust knob) shouldn't this be adequate?
Also is there any cheap commercial product that can regulate the vaccum
to the required two inches or so?
Regards Peter (Toronto Canada)
From: | "The Stribling's" <bbattery(at)bendcable.com> |
also
and
Just bought a 160 lycoming with out a starter do you know what kind of
starter or the numbers on case so I can save a buck or two for seats
Thanks Ken S. waiting for finishing kit 6-A
Subject: | Re: Vacuum Gyros |
> panel ?
Peter I don't have the tilt built into my AH. It still works
fine but I have to have the adjustment all the way to the top
to get the horizion lined up with the "little airplane" in level
flight.
Jerry
Subject: | Re: Bart aerosport eng. |
Aero Sport Power
2965 Airport Drive
Kamloops, B.C V2B 7W8
phone (250) 376-2955
fax (250) 376-1995
They also have a web page
Tom Brown RV4 flying with a Bart LaBlonde
Hi Peter,
I didn't get the 8 degree tilt in my attitude indictor on my RV4 (yet).
The A/I works just fine except the segment that indicates the horizontal
attitude is about 3/8" higher than the markings in the surrounding casing
that indicate a horizontal position in normal flight. (Tough to describe) If
the airplane wasn't adjusted upward and I didn't know better, one would think
I was in a serious climb. The airplane can be adjusted up to meet the
horizon. In my opinion, it functions OK but looks stupid. Everytime I look
at it I think "Hey idiot, why didn't you buy one with the 8 degree tilt?" The
price for ignorance can be high! Someday, I will remove it and take it to a
shop to be modified. Before I do that, I will make sure 8 degrees is the
right number.
Tom Brown - RV4 flying
Subject: | dimpled platenuts |
i am looking for dimpled or countersunk platenuts. i tried wicks, avery,
vans, and many of the tool suppliers. does anyone know of WHERE i can locate.
Subject: | Re: dimpled platenuts |
Bob, pls. contact me off-list. I have a large number of different dimpled
nutplates. Depends on which ones you're looking for.
Blue Skies!
Brian,
Fly into "Oceano", good food, great view, and it's on the way...
Chuck
Subject: | Re: Wire mounting in FWF |
fire wall
> forward?
plane.
I Pulled this out of the archives (Bob Nuckolls, July 00):
The white guys are subject to ultra-violet degredation . . .
they also don't take kindly to hyro-carbon and ozone exposure
both of which are found in fair quantity under the cowl.
Ty-wraps treated for better resistance to environmental
stresses are always colored . . . most of the ones I've seen
are either dark green or black. However, it's possible to make
a ty-wrap from funky plastic of ANY color. When you buy them
new in original manufacturer's packaging, it will state on the
lable whether or not the critter is resistant to UV and/or
chemical attack.
My personal preference under the cowl is MS21919DGxx clamps
and/or Dacron flat-lace (string) . . . I've seen both of these
products work well for decades under the cowl.
I would add that there are high-temp tie wraps, which are aqua in color. I
got some of these from AAMR/Air Core (John Caldwell) but unfortunately he's
gone out of business. I'm sure they're overkill plus they cost almost a buck
a piece (!). Just FYI.
Portland, OR
Below is a 1/25/2000 order of mine from Wicks.
Their web search thingy doesn't pick up on the
part numbers. Don't know if that's because
they don't carry them any more or because their
search engine stinks. Maybe if you call them
with this info......
Product ID Product Name Price Quantity Total
MS21047-L08K MS21047-L08K $0.23 25 $5.75
MS21049-L08K MS21049-L08K $0.27 50 $13.50
Tax NC $0.00
Shipping Later Charge $0.00
Total $19.25
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
I've purchased them from Wicks. They are a special order item from them. (They
have to order them in) It took about 2 weeks to get them from Wicks. SkyBolt in
Florida also carries them. See Gary Van Remortal's "Yeller Pages" for their
address & phone number.
Charlie Kuss
Subject: | Re: Century I wing-leveler gyro pinout |
Don,
I found the info on th Century page to be just what I needed. Thanks!
-Don
RV8 NJ
In a message dated 8/11/00 12:31:50 PM Eastern Daylight Time, dons6a(at)juno.com
writes:
<< When you get to Centtry look for diagrams, them 69D875-2 for Century I.
Hope my rambling helped. >>
Try calling Wick's 800 number. I have found them VERY helpful.
Jim Bower
St. Louis, MO
RV-6A N143DJ
>From: Bobpaulo(at)AOL.COM
>Subject: RV-List: dimpled platenuts
>Date: Mon, 14 Aug 2000 23:22:25 EDT
>locate.
08/15/2000 09:01:00 AM
I think your problem will be the mount casting or weldment...depending on
which mount you buy. The Starter is a Datsun 810 starter for Mark Landrols
unit & I think the Toyota starter is used in the Aircraft Spruce mount.
Getting the starter is not the issue its the mount. I am using Mark
Landrols weldment version and am happy with it. Contact Mark from the Ad
in the back og EAA Sport Aviation Mag. ( I met him I got my pulley &
starter asembly from him at Oshgosh). Likewise investigate Spruces
casting........let me know what you end up doing.
bbattery(at)bendcable.com on 08/14/2000 09:42:38 PM
Subject: Re: RV-List: Starters
Toyota
also
and
I took the training a couple of years ago and enjoyed it a great deal. It is
a great help to someone who has little experience with the insides of an
engine -- goes into each system in some detail and provides a complete
overview of the entire product line. Included in he cost is a complete set
of service bulletins and a great deal of other relevant and useful material.
The also have a follow on course that I understand is now available to
graduates that provides actual hands on experience breaking down and building
up an engine. I feel it was worth the money and time.
Ray Grenier
RV-4
Aircraft Supply Co in Dallas...
214-637-3598
Aviation fasteners - you name 'em they got 'em...
Ralph Capen
Thread-Index: AcAGTvcam3YmunQxSqGNrVzblpYGgAAcLN/w
I removed the fan because it turns in the wrong direction when mounted
on an aircraft. On cars it rotates to the left. Van's alternator also
has the fan removed.
Bob Japundza
RV-6 N244BJ O-360CS 15.1 hours
Gordon Comfort
RV-4 N363GC
Subject: | Electronic Ignition Choice |
There are currently three choices for electronic ignition:
Lasar http://www.unisonindustries.com
Lightspeed http://www.lsecorp.com
ElectroAir http://www.fly-gbi.com/eis.htm
The primary differences that I can tell are in the level of redundancy and
the timing mechanism.
Can anyone discuss the pros and cons of these systems? Why did you choose
the system you have (if you have)?
Bruce Meacham
Another similar idea is to buy Mattituck's engine rebuilding video. While
it certainly isn't as in-depth as Lycoming's school, I found it invaluable
to see what was going on inside the case. It has some general rebuilding
info, and takes some of the "magic" out of what's inside that amazingly
expensive hunk of metal. For around $25 I feel it's a great investment.
I would like to go to Lycoming's school, but felt the cost was a little
overdone.
Ed Bundy - Eagle, ID
RV6A, 0320-D1a (160hp)
Sensenich 70x78, N427EM, 350+hrs.
ebundy(at)micron.net
is
Subject: | Re: Electronic Ignition Choice |
I chose the Lasar ignition because it is a certified system and is available as
factory-installed equipment. In case something goes awry, I want to be able to
work with a single supplier (Lycoming) to limit finger-pointing. Also, I am
concerned that an "un-certified" system might increase the number of flight
hours required before sign-off and limit the engine's resale value since it
would probably be labeled "for experimental use only". Having said all that, I
will add the caveat that I have not yet flown the aircraft (-4). I hope to be
ready for taxi tests by the end of the year...
Dean Pichon
Arlington, MA
"Bruce Meacham" on 08/15/2000 10:35:43 AM
cc: (bcc: Dean Pichon/ADLittle)
Subject: RV-List: Electronic Ignition Choice
Bruce Meacham
George Orndorff also sells a good video on the tear down and assembly of a
Lycoming.
It's inexpensive, and a good visual tool.
I bought a copy to use as an EAA Chapter Program.
Ed Cole
RV6A Forever Finishing
> From: Ed Bundy [SMTP:ebundy(at)micron.net]
> Sent: Tuesday, August 15, 2000 7:47 AM
> Subject: Re: RV-List: Lycoming Service School
> overdone.
> It
> is
Hi Bruce,
I made my choice several years ago and without taking a lot of time to
really evaluate the other systems available. My reasoning for choosing a
Lasar system was as follows:
- It was recommended by the firm assembling my engine. They installed it,
set it up and gave me a good price on the system at the time.
- The system was certified at the time. To me that meant that it had gone
through at least some formal testing protocol and was qualified to some
standard. I admit I don't know exactly what those tests and standards
consisted of.
- I felt Unison had been in business for some time and would be there for
parts and service when the system broke down. In today's business world
there are some excellent products that have a short life due to the parent
company closing its doors.
- I liked the concept that the Lasar system was a third redundant ignition
system. When it fails or turns off, the system defaults to the old dual mag
system that has worked reliably for decades. You don't have to remove one
mag to install the lasar system.
- The Lasar system as I understand it is a little more conservative in its
performance and spark advance than some of the other alternatives.
The earlier Lasar systems, mine included are dealing with some software
and hardware modifications. The people on the list that commented about he
Lasar seems to be satisfied with Unison's response to the concerns and
operations difficulties. I have 32 hours time on my unit which was produced
three years ago. The unit turns itself on and off at random apparently due
to a relay built inside the mags on the earlier systems. There is also a
software glitch that can turn the off indicator light on without turning the
Lasar ignition system off.
IMO the product is professionally constructed for aircraft usage. The later
versions of the documentation and systems have been improved. According to
the testing and literature from Unison, most of the real benefit to the
system occur during startup and at altitudes above 6000 feet.
I can't really answer the question as to whether I would bother to put
electronic ignition on again or not. I haven't really had the opportunity to
explore the performance at altitude yet and my system hasn't operated on a
consistent basis. If I was on a tighter budget and endurance or performance
wasn't a high priority, I would probably leave it off. Now, if some of the
other systems are reliable and can be purchased at near the cost of an
equivalent mag system, there is no doubt that I would put one on.
Hope this is helpful.
RV4Brown(at)aol.com
From: | "Bill Shook" <billshook(at)mindspring.com> |
ALRIGHT ALREADY! Geeze, all this talk about how much it costs and not a
single one of you has stated how MUCH that is. I'm going to die or
curiousity here.....
meow
----- Original Message -----
Sent: Tuesday, August 15, 2000 10:46 AM
> overdone.
It
> is
From: | "Randy J. Pflanzer" <rpflanze(at)iquest.net> |
Well Bruce, that sound you hear through the speakers of your PC is a big,
fat can of worms being opened.
Many will debate the pro's and con's of each system. My reasons for
selecting the LASAR system were simple. I wanted a certified system that my
FBO would work on and I felt more comfortable dealing with Unison, who I
believe will be around as long as my RV-6 is. I admit that I didn't give
much consideration to the other systems.
I'll state the biggest con right now and that's cost. This system is not
likely to cost justify itself in the next 10 years, but that's not why I
have it. I can't cost justify my DIGITAL transponder either. I made the
choice that for me, the extra money was worth the certification, field
service availability, and company reputation to stand behind the product.
That's not to imply that the others won't do the same. I just felt that
Unison was a better bet for me.
The LASAR system works very well and the fuel economy, engine smoothness,
and easy starting have been as advertised. When my engine is warm, I can
idle at 400 RPM and it's as smooth as a sewing machine. I like the idea of
the magneto redundancy and the fact that my FBO will work on it. In
addition, the Unison folks have been responsive to a problem I had and they
shipped me out two new magnetos free of charge with a loaner timing light.
I have no doubt that they are committed to their product.
From what I've seen on the List over the years, I think the other systems
are good systems too. I think it's just a matter of balancing the $$$ with
the other factors.
Randy Pflanzer N417G
RV-6 (43 hours)
> Bruce Meacham
Subject: | Re: Static system |
>I have the poly flow installed from Van's for the static system.
>Trying to decide what to use behind the panel. I have figured the poly
>flow with the nylon fittings & the AN fittings with 3/16 alumimun tubing.
>Just can't decide. Could someone help with what they went with & weather
>they were happy or not.??
Don,
I used polyflow tubing all the way to the instruments. I used plastic tubing
fittings from Parker Fitting. I also converted the pitot tubing from the
kit supplied aluminum to plastic via a metal to plastic coupler that Parker
also sells. Routing the plastic up through the cockpit and behind the panel
is made very simple with the plastic tubing.
Brian Denk
RV8 N94BD
I would not argue with anyone's decision on this....you pays your money, and
takes your choice, as they say, BUT
I attended a presentation on the Lasar system...looked good, but you have
the disadvantages of two magnetos to service/repair/replace, plus the
electronics...more stuff, more to go wrong.
Also Unison said the ONLY reason they have the regular mags is because it
was the only way the FAA would give them an STC for the system. But for the
FAA they would have left the mags out of the system.
I choice the Lightspeed unit, replaced only the right mag....simple, far
less expensive than the Lasar,
and less machinery to go wrong. The single electronic unit makes starting
really quick, and when the left mag is shut off, there is absolutely NO drop
in engine RPM. Installation is REALLY simple, you pull the mag, put the
drive gear from the mag on the electronic unit, loosely bolt it on, turn it
till a light on the back of the unit comes one, (engine with nr1 cylinder at
TDC) and tighten it down. That's it!
Also one other reason I chose the Lightspeed unit was its maker, Claus
Saviur (Spelling) - I listened to one of his presentations, and I think the
guy is a near genius...very impressive.
But like women, airplanes, TV shows, etc, do what you like....
RV6A Flying, Salida, CO
One of the units (not the LASAR system) dos not have sensors to determine
detonation margin. They claimed spark advance but I was unable to assertion the
level of cut-off or their method of determination of engine operating parameters
to ensure there was no detonation occurring........
rpflanze(at)iquest.net on 08/15/2000 02:13:49 PM
Subject: Re: RV-List: Electronic Ignition Choice
the other factors.
RV-6 (43 hours)
> Bruce Meacham
Date: Tuesday, August 15, 2000 12:01 PM
Subject: RV-List: Static system
I used 1/8 ID Ace hardware rubber fuel line and Ace brass and plastic tees
and barb fittings. Then I plumbed a accessible test point for system
certification, which is plugged with a 5/32 rivet stem. I have 18-inch
service loops on the static and vacuum lines so I can pull the panel
sections out and work on them without crawling under the panel.
I tested the static system by sealing off the static ports with plastic
sheet discs held by electrical tape. Next, I gently sucked on the test
line, keeping IAS in the green, until I reached 2000 feet and 145 KIAS,
whereupon I clamped it off. After 45 minutes the altitude was 1980 feet,
and the system continued to lose altitude at a rate of 0.48 feet per minute
for the next 1035 minutes. Part of the altitude loss was due to temperature
change during the test. The system is leak tight! I used Century rebuilt
gyros and VSI, ASI and altimeter from Van's (United).
I am familiar with the arguments against using rubber in the gyro lines due
to particulate matter failure and therefore I ran the vacuum lines with Ace
vinyl tubing. It will not collapse at 5.2 inches differential pressure at
temperatures below 150 F.
Dennis Persyk 6A N600DP
Hampshire, IL C38
-----Original Message-----
Hampshire, IL C38
Randall and all,
Thanks, I also found this in the archives. Unfortunately this is only one mans
opinion. I was hoping I could hear from folks that have used tywraps ( black or
whatever ) FWF who are flying and have had some experience with how well they
hold up under general use.
- Jim
RV-8AQ ( 81102 )
FWF O-360
N89JA (reserved)
Hampshire, IL C38
I'm in the process of mounting my replacement Van's alternator and I find that
no matter what I do, my pulley is out of alignment by about an eighth of an inch
in the aft direction. Also the adjustment arm rests behind the alternator not
in front as I would expect.
Is this typical?
- Jim
RV-8AQ ( 81102 )
FWF ( O-360 )
N89JA ( reserved )
I have found over the years that what Bob Nuckols stated was, and is,
correct. Before I become a Fed I turned wrenches and fly for several years.
Every year when it came time to do an Annual I would dig out a handful of
tie wraps knowing I would have to replace many....and it was almost always
the clear/opaque ones. Yes the black/colored ones to get brittle and crack
but not nearly as fast as the clear ones. Actually the best method is to
use the wire bundle lace cord. It also has the added benefit of not having
those sharp little edges from the cut-off ends. But it is rather time
consuming to do that so I must admit that I also use the tie-wraps.
Mike Robertson
"Das Fed"
RV-8A
>Subject: Re: RV-List: Wire mounting in FWF
>Date: Tue, 15 Aug 2000 13:55:05 -0500
>Randall and all,
>mans
>black or
>they
>Thanks,
>- Jim
>RV-8AQ ( 81102 )
>FWF O-360
>N89JA (reserved)
correct. Before I become a Fed I turned wrenches and flew for several
years. Every year when it came time to do an Annual I would dig out a
handful of tie wraps knowing I would have to replace many....and it was
almost always the clear/opaque ones. Yes the black/colored ones do get
brittle and crack but not nearly as fast as the clear ones. Actually the
best method is to use the wire bundle lace cord. It also has the added
benefit of not having those sharp little edges from the cut-off ends. But
it is rather time consuming to do that so I must admit that I also use the
tie-wraps.
Mike Robertson
"Das Fed"
RV-8A
>Randall and all,
>mans
>black or
>they
>Thanks,
>- Jim
>RV-8AQ ( 81102 )
>FWF O-360
>N89JA (reserved)
>that
>inch
>not
>Is this typical?
>Thanks,
>- Jim
>RV-8AQ ( 81102 )
>FWF ( O-360 )
>N89JA ( reserved )
Jim,
Yes, sounds pretty typical. Bend a jog in the mounting arm to position the
alternator pulley in alignment with the flywheel. Run the tension adjustment
bolt in from the rear, through the slotted arm and into the threaded
alternator case. Works fine. Trust me. Have I ever lied to ya? 'Course not.
Brian Denk
RV8 N94BD
Subject: | RV8 spar center section |
hi y'all
on the rv8 spar center section, how much oversized did you make your
filler pieces as place holders for the spars ??
Gert
> Bruce Meacham
I believe that the Lasar system is the only one which advances both the
sparks in each cylinder, unless dual electric and dual ignition systems are
employed with the other two. Given the huge bore of these engines, that
could make a difference in performance given the time it takes the flame
front to cross the cylinder. Maybe the systems compensate somewhat for this
by additional advance; I don't know.
Alex Peterson
Maple Grove, MN
may fly in '01
In a message dated 8/15/00 3:33:57 PM Eastern Daylight Time,
Jim_Andrews(at)tivoli.com writes:
<< FWF who are flying and have had some experience with how well they
hold up under general use. >>
I have had "regular" airplane mechanics belittle tie wraps, but I have seen
them go hundreds of hours on a Kolb Firestar that I was a partner . We used
the white ones extensively on some very hot parts and in a very high
vibratory environment. They are setting right out in the open, so they are
certainly exposed to more UV than under my 6 cowl. I have used them
extensively for securing wiring, etc. under the cowl, but will watch them
carefully.
Bernie Kerr, 6A 40 hours, SE Fla
Subject: | Re: RV8 spar center section |
.005", machined from aluminum, worked perfectly when I mounted the wings.
Randy Lervold
RV-8 #80500, cowling
www.rv-8.com
>hi y'all
>Gert
Gert,
Scott McDaniels from Vans posted about this back in April 99. He
said to make the spacer the same thickness as the spar. He says that
you can put some Boelube or candle wax on the spar to help slip it in
place when the time comes. You may need to file a slight bevel on
the corners of the spar end.
Go to the archives and search on mcdaniels & RV-8 & spar
Kevin Horton RV-8 (cockpit stuff)
Ottawa, Canada
Did you machine each piece individuallly for each corner ??
Just been miking the 4 corners and there is a .002 to .005 deviation
between each of the four corner pieces.
I machined some stock 'under' and was going to use shims.
found some old email in the archives indicating .002 to .003. (per
Van's)
Heck some of my spar pieces have that much deviation between the end of
the spar and between the 2 big holes.
Gert
> Randy Lervold
> www.rv-8.com
Listers,
With two thousand five hundred or so flying RV's out there, I'll toss out an
easy one that I couldn't find in the archives...
I've got a standard "finger width" (3/8" - 1/2") between my baffles and
cowl. So, how far should the airseal fabric extend beyond the baffles? One
inch? Two inches?
Thanks in advance,
Kyle Boatright - Kennesaw, GA
RV-6 Slider, O-320/Aymar-Demuth
To the Airport by Labor Day!
It is not generally necessary to remove fans when they're
turned "the wrong direction" . . . centrifugal fans on the
front of alternators run only slightly less efficiently than
when turned the right direction.
Alternators with external fans are at risk for overheat
when running without the fan . . . you may want to do some
simple in-flight cooling tests to make sure there's enough
ambient air flow . . ..
Nipon-Dienso alternators have internal fans . . .
( Knowing about a thing is different than )
( understanding it. One can know a lot )
( and still understand nothing. )
( C.F. Kettering )
From: | Denis Walsh <deniswalsh(at)earthlink.net> |
Subject: | Re: Airseal Fabric |
KBoatri144(at)AOL.COM wrote:
> Listers,
> inch? Two inches?
> Thanks in advance,
Yes I would say that's about right. Worked for me
D Walsh
Subject: | eight degrees of tilt |
Jerry Springer wrote:
> > panel ?
> flight.
> Jerry
I never heard of the tilt thing when I bought mine so it has none. It is a
sigma tek. It seems to have about + or - 14 degrees of "little airplane"
adjustment. I typically use about 10 degrees of up to get level flight
indicated, so I usually have only a couple degrees remaining.
So I would say it is well worth ordering if you can; however if you have a
regular one it works ok.
D Walsh
name="deniswalsh.vcf"
filename="deniswalsh.vcf"
begin:vcard
n:Walsh;Denis
adr:;;;;;;
version:2.1
email;internet:deniswalsh(at)earthlink.net
fn:Denis Walsh
end:vcard
Gert,
No, our measurements showed the spar stubs to not vary measureably. Now when
you're down around one or two thousands maybe we didn't catch it, but at
five thousands undersized the wings went in snugly but easily... perfect.
Randy
> Van's)
> Gert
wings.
> > Randy Lervold
> > www.rv-8.com
In a message dated 8/15/00 7:26:37 PM Pacific Daylight Time,
KBoatri144(at)AOL.COM writes:
<< I've got a standard "finger width" (3/8" - 1/2") between my baffles and
inch? Two inches? >>
It depends on the airseal material. Some of the material has a natural
roll/curve in it so don't try to fight it. Push it up against a flat surface
(to simulate the cowling) allowing it to curve the direction it will and
determine the proper distance to just achieve tangency with the curve. If
you make the airseal too short it can flip and blow out under pressure. If
you make it too long it will hang past tangency and airflow could lift it
away from the surface.
-GV (RV-6A N1GV)
vanremog(at)aol.com
3 ER's
Whats the story if one flies over the border from Canada to the US?
do you have to go thru the immigration stuff and customs/ quarantine checks
or is it a bit more lax? as I've not been over there this may sound a bit
dumb.
Bruce
>--> RV3-List message posted by: "Bob U."
> the end
> > upstate New York.
Gert,
On my spar, the thinner pieces of material were not quite tight
against the spar bars at the root end. Once I clamped things
together (like they will be once you tighten up the bolts after
sliding them into the fuselage), the thickness was exactly 1.437 (1
7/16) everywhere that I measured.
Ottawa, Canada
>Van's)
>Gert
> > Randy Lervold
Subject: | Re: RV-List:Wing box measurement |
Listers,
Can anyone tell me what the lenght of the long box
is for the wing kit ?
Larry Mac Donald
Rochester N.Y.
lm4(at)juno.com
Subject: | RV-3 airspeed numbers |
About to do the first official flight.
Gross weight will be approx 1000 lbs, CG near forward limit.
Prop clearance: tail down: 14", level: 6".
Any RV-3 flyers care to post some recommended airspeed numbers?
Near tail down take-off speed? Flaps recommended?
Climb-out speed?
Turn to base speed?
On final speed?
Flap setting on final?
Over the numbers speed?
Any other hints?
Finn
Request a CDROM 1-800-333-3633
Anybody know of an RV-4 that I can buy to fly while I'm building my RV-8?
Nothing fancy, but well built - around $40k.
Reply directly to ludwig(at)azstarnet.com.
- Bill in Tucson
I won't be stopping in Canada. Just a very long overfly ~3hrs. There are
no customs issues for overflights. I will file a flight plan and get VFR
flight following in case they think I'm running drugs or something.
Bruce Meacham
Sent: Wednesday, August 16, 2000 1:41 AM
Subject: Re: RV3-List: Re:Travelling
> 3 ER's
checks
> dumb.
> Bruce
> > the end
circle
and
> > > upstate New York.
Subject: | Re: RV3-List: RV-3 airspeed numbers |
I don't know your experience level, so I must assume that your
transitioning from GA like I did, so bare with me if your more experienced
than I give you credit for.
First I want to say: If your active with your EAA club I suggest you talk
with your flight advisor and setup a training regiment. I didn't do it, but
I wish I had.
How much flying have you done in the last thirty days? I would recomend at
least twenty hours in as many different airplanes as possible. Most of that
should be in taildraggers. Flying different airplans gets you used to
unusual flight envirnoments.
If you can find someone in the area to give you some back seat time in an
RV-4, it has an uncany resemblence to the -3's control feel and it will make
a world of difference. RV's are so easy to fly, but they have a very light
and responsive touch that's easy to over control. You really should have
familiarity with this before test flying your aircraft.
My plane is near forward limit too. You will loose elevator effectiveness
and have difficulty doing good three point landing, but forward is always
better than rearward.
Tail down prop clearance doesn't meen much. I have a good 6" tail up. The
angle that's required to scrub the prop is very high.
Assuming enough runway (at least 5,000' I hope for a first flight) I
recomend a zero flap take-off. Take off will happen very fast, twice as
faster as any spam can I know. Keep it simple no flaps.
I recomend a normal two point takeoff. Nothing fancy. Briskly put the
power. Not too fast, but too slow and you'll be airborn before full
throttle. Gently lift the tail off once you have about 30 mph, don't force
it off, it will come up on it's own. Once you have 70mph gently lean back
and you've slipped the searly bonds once again...
> Climb-out speed?
Slowly transition from 70mph takeoff to 110-120mph. This means keeping
pulling the airplane back as the airspeed builds will you stabalize at
110-120. 110-120 should be faster than best climb, but a good speed for
forward visability and cooling. Anticipate the climb angle to be 25-35
degrees (very steep) at this airspeed.
Scan your gauges on climb out. If it's going well climb to a known practice
area 3,000' AGL. Do a clearing turn. Power down and do a couple power off
stalls. If those go without an misbehavior, dropping wings or loss of
positive control, Attempt a power on using 1700 rpm. I don't recomend full
throttle power on stalls at this stage. They can be pretty harry.
> Turn to base speed?
> On final speed?
Just like any other plane. Here are my numbers, your RPMs will likely be
different, but this is probably a good ballpark.
-on downwind stabalize airpspeed at 100mph ~1600 rpm with carb heat out.
-10 flaps throttle back to 1100 rpm pitch for 90
-turn base 20 degrees flaps pitch for 85
-turn base 30 degrees flaps pitch for 80. 80 is right on best glide speed
and a very comfortable place to be on final.
-flare and hold off ignore the airspeed, just keep a continous back motion
on the stick till it hits the stop and do your best to be 1" off the ground
and well aligned.
> Any other hints?
Don't get behind the power curve (slower than 70mph) on final. Below 70mph
and drag comes on like an avalanche, much more than most GA aircraft. Pitch
over to build airspeed and set power to compensate for any altitude loss.
Cross winds: RVs are good in cross winds (plenty of rudder and nimble) but
they take practice. So hold off for now.
Two point landings are prefered on smooth runways. But near impossible on
anything with bumps. So if you have a smooth runway in your flight test
area, when your comfortable level is higher. Still full flaps recomended.
Don't get too worked up before takeoff. Don't invite everyone you know.
Just one or two trusted advisors. Say go when you are ready to go.
Have everything setup and in order before approaching the plane. Just
relax and visualize your flight. Think about emergency proceedures, where
your going to land out should your engine fail.
Good luck! Have fun it's a blast!
Subject: | Van's Alternator |
I bought a Nippon-Denso 60 amp laternator that you recommended to me several
months ago. It has an external fan just under the pulley. Do I understand
you correctly here in that you are saying that it also has an internal fan
and I could remove the external fan if I have a little clearence problem
witth the lower cowling?
Mike Robertson
RV-8A
>From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
>Date: Tue, 15 Aug 2000 21:44:36
> Bob . . .
> ( C.F. Kettering )
>meow
It doesn't seem very expensive to me!
ahb...
Piston Engine Service School
A mechanics' refresher course
on Lycoming's current
production engines, covering:
* Engine construction
* Theory of operation
* Engine servicing
* Inspection, servicing
and troubleshooting
of related components
Course consists of four
seven-hour days, from 8:00 am to 4:00 pm, with a
one-hour lunch break.
Tuition for the Service School is $480 (US) per
student. Tuition includes all course materials
and a one-year subscription to all Textron
Lycoming service bulletins, letters and
instructions
Disassembly/Reassembly Course
This hands-on course is conducted seven hours
a day, for three consecutive weekdays,
immediately following the Piston Engine Service
School. Class size consists of two-student
teams, each working on 4- or 6- cylinder
Lycoming engines, learning proper procedures for
engine disassembly and reassembly. To qualify
for this course, students must have completed the
Service School. Individuals who have previously
completed the Service School may also attend
Tuition for the Disassembly/Reassembly Course is
$500 (US) per student. Tuition includes all course
materials.
08/16/2000 03:01:46 PM
your reply of-----
and the system continued to lose altitude at<<<<<<<
I am a little confused. Where did you apply the suction ? The pitot is ram
air pressure.........
"Dennis Persyk" (at)matronics.com on 08/15/2000
02:16:31 PM
cc:
Subject: Re: RV-List: Static system
>Don Jordan -- 6a finish -- Arlington, Tx -- dons6a(at)juno.com
temperature
Hampshire, IL C38
Subject: | Re: Flight Training-Hints |
08/16/2000 03:53:41 PM
"Bruce Meacham" (at)matronics.com on 08/16/2000 02:31:20
PM
cc:
Subject: RV-List: Re: RV3-List: RV-3 airspeed numbers
but
I wish I had.
that
make
The
> Climb-out speed?
off
full
> Turn to base speed?
> On final speed?
and well aligned.
> Any other hints?
Pitch
Listers
How far from the sidewalls or how far apart have you placed the fuel tank
vent lines in the belly? I am trying to get as close as possible to the
landing intersection fairing.
Cash Copeland
Oakland, Ca
There is also a static port which is the reference pressure for altitude. I
don't know why he is listing am air speed. The rest is all referenced to
altitude.
Sent: Wednesday, August 16, 2000 1:56 PM
> your reply of-----
> 02:16:31 PM
> To:
> cc:
> From: Don R Jordan <dons6a(at)juno.com>
minute
> temperature
due
Ace
> Hampshire, IL C38
From: | "alain nantel" <alain_nantel(at)hotmail.com> |
>locate.
>thanx, bob in arkansas
Why don't you make your own?
All that is required is to use your dimple set you probably have already.
You need to make one small modification to the female die by grinding it up
to the countersink edge to create one flat side, followed by a good
polishing using your scotch brite wheel.
NOTE: The dimple dies still works great even if it's modified this way, it's
also usefull in thight places like when you drill to close to the web on
ribs, etc.
Hope this helps
Alain_Nantel(at)hotmail.com
RV-6 C-GGRS
90% done 90% to go
Hi All,
some friends out here used other pilots to do the first flight
for half an hour or so. This may sound a bit odd however it seems
OK to me after spending 10 years and wads of money the pressure
is certainly very high.
Recently my flying instructor finished his Europa and took it to
the local Air Forse base and used their runway and spent allot
of time just working up speed and feel until he was satisfied that
he had it just right then peeled it of for a short first flight, I should
say though the person in question has lots of hours every week
in different aircraft and in total.
Good luck and let us know how it all goes.
Bruce
>--> RV3-List message posted by: Finn Lassen
>Climb-out speed?
>Turn to base speed?
>On final speed?
>Any other hints?
>Finn
From: | Dan & Patty Krueger <pndkrueg(at)gulfsurf.infi.net> |
For the RV-6 wing kit box it is 172 inches. Finally something I can
answer with authority.
Dan Krueger
Wiring and plumbing engine
> Larry Mac Donald
Subject: | Re: RV flying - basic training |
08/16/2000 03:57:01 PM
PM
cc:
but
I wish I had.
that
make
The
> Climb-out speed?
off
full
> Turn to base speed?
> On final speed?
and well aligned.
> Any other hints?
Pitch
Subject: | Flying 6A For Sale |
Flying 6A , Seattle, For Sale.
Reply off list for details
Subject: | Pitot tube & drilling holes in rib angle 73.5, 71.5 |
Hello I'm just getting ready to rivet the skin to the leading edge ribs. the
two ribs 73.5 & 71.5 need 7/16 holes for the 1/4 inch snap rings for the
pitot tube. On the drawing they show it going throw the 3/4 angle that is
attach to the ribs. By the time you drill the 7/16 hole you don't have a lot
of angle left about 1/8 and the hole is on the edge of the cut out on the
ribs that is made to miss the main spare stiffeners. In anther word the 7/16
hole is a semi circle on the rib metal. no metal all the way around the hole.
Just wondering what others have done.
Thanks Bill H.
Pembroke Ma.
Subject: | Re: Van's Alternator |
If the alternator has an external fan then it most likely does not have an
internal fan. The 40 amp ND on my 6A has internal fans, one at each end. The
60 amp ND on my wife's Isuzu also has two internal fans. The fans are clearly
visable through the slots in the case.
FWIW my alternator came with my engine and was supplied to Bart from Canadian
Aero. This is a brand new ND 40 amp alt with mounting hardware for U$200.00.
They also sell a 60 amp version.
Gary Zilik
RV-6A 75 hrs and climbing.
Subject: | Re: Pitot tube & drilling holes in rib angle 73.5, 71.5 |
In a message dated 8/16/00 5:40:23 PM Central Daylight Time, BillyRV6(at)AOL.COM
writes:
<< Hello I'm just getting ready to rivet the skin to the leading edge ribs.
the
lot
hole.
Just wondering what others have done. >>
Hi Bill,
I drilled mine just above the angle and routed the tube up and through the
two ribs. You can see a picture of it by going here:
http://members.aol.com/shannancmt/pitotube.html
Eric Newton Long Beach, MS
RV-6A N57ME (reserved) (Flaps)
Eric's RV-6A
Construction Page
Date: Wednesday, August 16, 2000 2:47 PM
> your reply of-----
The suction was applied to the static system via a Tee that I have plumbed
in to facillitate static system checking. The pitot tube is capped off with
a 1/4 ID rubber hose segment with a plug in it.
The ASI has two ports: Pitot and static. It measures the differential
pressure between the two. Thus as the static system is pumped down (sucked
on), the ASI responds with a reading. Sucking on the static port is the
same as pressurizing the pitot port as far as the ASI is concerned in this
test. If you have ever assisted in a static system check or watched one,
you would see that one guy mans the pump and the other calls out airspeed
and altitude, as both are varying with pumpdown.
This seems confusing when you read it, so just do it in your own plane and
it will become clearer. I did the check so that when I have the static
system checked I know there will be no leaks. Many shops will ding you for
the whole cost of the check even though they determine in the first few
minutes that the system leaks like a sieve. You don't want to pay shop rate
to have a technicial find leaks in the system that you can find on your own
beforehand. Hope this clears things up a bit.
Hampshire, IL C38
>02:16:31 PM
>To:
>cc:
>temperature
>Hampshire, IL C38
HI:
I will have to get an alternator, for my
lycoming 320, rebuilt.
I see that some of you, up for a auto alternator;
my question, I have read, that you cannot use
a auto alt., because,... something to do with the
direction of rotation....hope someon clarify this
for me.
I do not know the type of alternators Van's sell
I understand the 30 app. is enough for almost
any rv...
Thanks in advance for replies...
Don not archive
Bert
rv6a
Fitting wing.....
bert murillo wrote:
> HI:
In an earlier post you mentioned the possability of getting an Aerosport
Power engine. A 40 amp ND automotive alternator is standard on this
engine. There is also a 60 amp option or you can choose to delete the
alternator from the engine if you have your own unit already.
> for me.
You cant believe everything you read. Alternators really don't care
which way they rotate.
Big clunky automotive units.
> any rv...
30 amps may be a little small if you gots lots of toys and fly at night.
I would think a 40 amp unit would be enough for most RV's.
Gary Zilk
RV-6A 75 hrs
From: | EARL FORTNER <e.fortner(at)worldnet.att.net> |
Feel confident that you are not the only one who has a spare push tube
just a tad short, and that you will also discover other parts that are
not quite what they should be after the cut has been made.
Earl, RV-4 praying that I don't do the same with the canopy.
KAKlewin(at)AOL.COM wrote:
> Hey Folks,
> Kurt, OKC, OK
> RV 6A QB
From: | Malcolm L Harper <mlharper(at)mindspring.com> |
Subject: | Fuel cap etching |
What's the latest source to have fuel caps etched? I tried the guy at panel
cut but have received no answer.
Mal
RV-6 finishing kit
Subject: | Re: Fuel cap etching |
Try Wayne at,
http;//www.engravers.net
Bruce
Glasair III
> Mal
> RV-6 finishing kit
The Panel Cut guy may have fell of the face of the earth, I have a total of
6 unanswered emails. We've decided to have our two panels done at a local
print shop that has a laser engraver. I'll ask about gas caps. Though I
think the only reason this guy is doing it is because my partners business
does allot of work with them. He didn't seem to eager when he found out it
was for 'experimental airplanes'.
Greg
panel
> Mal
> RV-6 finishing kit
Paul , info(at)vansaircraft.com
Subject: | RV-3 N993FL SN 488 finally flies |
This bird was started by Charlie Dorris of Richardson, TX in July 1977!
I picked it up in January 1996. And it finally flew this evening! 23
years old before allowed to fly!
This official first flight was just a very quick flight around a tight
pattern, although I reached 1200' and 120 mph before catching it.
Successful landing by a beginner's standard, just a bounce or two.
This first flight was preceded by several high speed taxi runs, the last
of which was really a low flight just above the runway. After more than
4 hours in a Decathlon over the past week, the RV-3 felt quite
different, in spite of the many hours of taxiing it previously. Unless
you have a new engine that needs full power run-in, I'm a strong
advocate for taxi runs prior to first flight. If you can't control it
during high speed taxiing, how can you hope to control it during your
first landing?
I guess an experienced test pilot would describe the flight as
"uneventful".
Interestingly, most of my attention was on the engine (experimental 13B
Mazda Mikuni carburated rotary installation, with a Ross 2.17-1
re-drive, swinging a Performance Prop's 68x74 prop - pitched towards
cruise) during climb to pattern altitude. I have not yet installed the
cowl cheek extensions. A good deal of heat comes out that way (left side
is where the muffler/exhaust is). This made the side skin where my hand
rests on the throttle(s) noticeably hot to the point where I had to peek
over the side to make sure it wasn't on fire (again), and made me decide
to tighten the pattern.
I'd be hard pressed to give any hard numbers. I'm not sure if I applied
full throttle (I have static run-up prop flutter at 4500 RPM, so
intended to limit RPM to below that). I think max RPM was somewhere
between 4200 and 4700. Temperatures were not a problem. even on this 92F
day. Highest oil temperature I noticed was 198F and water probably 190F.
Yes, this bird does pick up speed easily, so after reducing speed to 100
mph, I applied one notch of flaps, making a marked pitch change, but
easily corrected with a flick of the trim tab switch.
I did notice what I perceived as engine roughness or surging when I
reduced power (~2700 RPM) and pointed the nose down a bit - possibly a
re-drive phenomena (didn't apply carb heat, so could also have been
that).
Didn't have "time" to look at EGT and mixture (oxygen sensor readout)
numbers.
More later for those who may be interested.
Finn
The Panel Guy Steve Davis is alive & well -
He must have a lot to do lately -
This work is aside from his main income -
I dropped off my caps there last week -
I will call to see what's up.
Don Eaves - Memphis...
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Greg Yotz
Sent: Wednesday, August 16, 2000 9:40 PM
Subject: Re: RV-List: Fuel cap etching
Greg
panel
> Mal
> RV-6 finishing kit
From: | "Jerry Carter" <jcarter8(at)midsouth.rr.com> |
> for me.
> any rv...
Bert,
I would suggest a 40 amp B&C alternator without internal voltage regulator -
the ones from Aerosport come with the internal regulator. I bought one from
Bob Nuckolls and added his voltage regulator and overvoltage protection
systems. I did this for peace of mind. A voltage regulator does not protect
you from overvoltage which could fry all your fancy avionics.
Jerry
I've repeatedly had trouble reaching him. He's responded to only two emails
from me out of at least five or six over the past six months or so. It's now
been at least three weeks since he informed me that my name badge was ready and
requested that I send him a stamped envelope, which I did. No response and no
badge.
I understand that he's done good quality work for other people and that he may
be very busy, but his responsiveness to me has not been what I would
characterize as good service. Originally, I emailed him requesting information
on his panels, which, as paying business, should have elicited an immediate and
enthusiastic response, even if the name badge didn't.
I'll never pay him a dime for any goods or services. As far as I'm concerned,
regardless of the quality of his work, he can't be trusted to be 'reachable' or
responsive.
Ken Balch
Ashland, MA
RV-8 #81125 N118KB (reserved)
cockpit stuff
> Greg
> panel
> > Mal
> > RV-6 finishing kit
From: | "Reeves, Doug" <Douglas.Reeves(at)archongroup.com> |
No. I believe they must be moving the server to the new location. Their
site said a few days ago that the server would move soon.
Doug Reeves
www.vansairforce.net
> From: Stephen J. Soule [SMTP:SSoule(at)pfclaw.com]
> Sent: Thursday, August 17, 2000 8:21 AM
> To: Rv-List (E-mail)
> Subject: RV-List: Van's WWW site
> I tried to access Van's web site this morning to order some hardware. I
> got
> a message from their server that I did not have privileges to access Van's
> site. I used the address www.vansaircraft.com. Has the address changed?
someone help this dumb a.... hillbilly. explain etch for fuel caps. thanx bob
in arkansas-doing wings.
Subject: | Re: Van's WWW site |
In a message dated 8/17/2000 8:36:06 AM Central Daylight Time,
SSoule(at)pfclaw.com writes:
<< I tried to access Van's web site this morning to order some hardware. I
got
Steve Soule >>
Arent they closed and moving this week. If they have there server on site it
would explain why its down. Or the server might just be done. It happens, I
know I have lost my site several times.
chris
i ordered a piece tues and one of the gals said if they did not send tue it
would not be sent until next week due to moving all the "stuff".bob
Thread-Topic: electronic ignition questions
Thread-Index: AcAIfQGBcZ961lYiTtqNxi2A8smOsw=
Subject: | electronic ignition questions |
Listers,
I just ordered the Electroair electronic ignition to replace my right
mag from George Orndorff. I want to get my fuel burn down at altitude.
I have a few questions for you guys running the Electroair or Lightspeed
ignitions:
1. Which plugs are you running the electronic ignition on? Jeff Rose
says to run them on the bottom (reduce fouling), George says to run one
side top--the other side on bottom just like the mags do.
2. What plugs are you using on the electronic ignition? Jeff says run
Autolite spark plugs on the bottom, George says stick with the aircraft
plugs--they are less prone to fouling, and he's had problems with the
boots coming off on the automotive spark plugs.
3. Anyone running autogas with electronic ignition? I've been thinking
about running autogas in cruise off one tank and avgas in the other for
takeoffs/landings. I'm thinking the engine will run on autogas better
with the electronic ignition.
4. Does the electronic ignition make your engine run noticeably
smoother?
5. How much of a reduction in fuel consumption do you typically see?
Just trying to get a game plan going so I can spend a minimum amount
fixing and the maximum amount flying. This weekend I'm having the
propeller dynamically balanced. We'll see how much that does to keep
the floor from vibrating.
Bob Japundza
RV-6 N244BJ O-360C/S flying 16.5 hours
Repost for the acchive:
writes:
> On the Century web site...
> http://www.centuryflight.com/pricing/frame/manual.htm
> Note! you can download for free the owners operating manual.
> Operation & Maintenance Manuals List Price
> 68S54 Century II and III $ 200.00
> 68S73 Century I $ 45.00
> 68S89 Century IV/Flight Director $ 200.00
> 68S90 1C651 Yaw Damper $ 45.00
> 68S94 Electronic Trim Amplifier 1C709-() $ 45.00
> 68S304 NSD360A/NSD1000 Horizontal Situation Indicator $ 325.00
> 68S307 Electronic Altitude Hold 1C727 $ 85.00
> 68S652 Gyro Slaving Amplifier, and Bootstrap Synchro 1C714/1D755 $
> 70.00
> 68S653 Century 41 Annunciator/Programmer $ 100.00
> 68S655 Navigation Data Processor $ 110.00
> 68S656 1C753-() Yaw Damper $ 195.00
> 68S1025 Century 21 Service Manual $ 200.00
> 68S1026 Century 31 Service Manual $ 200.00
> 68S1027 Century 41 Service Manual $ 200.00
> 68S1034 Century 2000 Service Manual $ 200.00
> 68S1072 Yaw Damper, 1C753-100/200 Series $ 80.00
> Test Manuals
> 68S371 Century II, III, and IV Test Console (66D1000) $ 200.00
> 68S1029 Century 2000, 21, 31, and 41 Test Drawer (66D1000-14) $
> 200.00
> Operator's Manuals
> *68S72 Century I (196K) $ 20.00
> *68S75 Century IIB (134K) $ 20.00
> *68S25 Century III (210K) $ 20.00
> 68S82 Century IV $ 20.00
> *68S1035 Century 2000 (ZIP file) $ 20.00
> *68S1035 Century 2000 (pdf. file) $20.00
> *68S85 NSD (750K) $ 20.00
> 68S805 Century 21 $ 20.00
> *68S803 Century 41 (851K) $ 20.00
> 68S1024 Century 31 $ 20.00
> Installation Manuals
> Bulletin No. ( ) (English) $ 130.00
> STC $ 1,000.00
> (non discountable)
> *Now available on our web site for you to print free of charge
Subject: | Not building related, but cool... |
I found a real cool site the other day... Check it out:
http://www.terraserver.com/index.asp
-Bill
Dose anyone have any knowledge of any RV builder that has installed a Ballistic
Recovery System in their RV??? Like the ones advertised in Aircraft Spruce.
A builder's wife brought up the fact that an RV-8 might not be a safe place for
the kiddies, so I was wondering if this is a viable alternative or not. My wife
really warmed up to the idea when she understood what it meant. "You mean that
I won't have to bail out if some catastrophic air frame failure occurs?"
As remote a possibility as this is... I rather like the idea of having a
personal parachute ride down to safety but my wife finds this so inconvenient
- Jim
0-360 (N89JA)
Aw come on guys. You'll feel like a real heel if you find out he's been
with his wife in the hospital for the last 2 weeks. I hope that is not the
case, but I've had quite some dealings with Steve (never in a business
sense, and he's never made a dime off of me) and I feel he's one of the
nicest guys you could hope to meet. I don't know what has happened in his
life to cause any perceived lack of attention, but I doubt it is
intentional. Have you tried calling him? Some people are not as 'net
oriented' as some of us. I noticed his email address is @aol.com. Anyone
who has used that service can attest to the REDICULOUS amount of junk mail.
Maybe your domain name is in a filter file used to can some of his junk
mail. I don't know...but my dealings with him have gone amazingly
well....and like I said...he never made a penny. Give him the benefit of
the doubt....and pick up the phone. I just did so and he picked up on the
second ring.
Sent: Thursday, August 17, 2000 9:57 AM
emails
now
ready and
and no
> badge.
may
information
immediate and
concerned,
'reachable' or
> responsive.
> Regards,
> Ken Balch
> Ashland, MA
> cockpit stuff
of
local
I
business
it
> > Greg
> > panel
> > > Mal
> > > RV-6 finishing kit
Hi Jim,
I believe Van wrote an article on this subject in the RVator. You're
taking an awful risk believing my memory, but the gist is roughly as
follows:
- The parachute does not guarantee a soft touchdown -- just something
less than terminal velocity.
- Pretty much all serious airplane accidents happen on takeoff or landing
(if your engine quits at altitude, you deadstick onto a field or a
road). Thus, in the vast majority of potential airplane accidents, the
brs does you no good -- there's no time or opportunity to deploy it.
- As such, the brs offers a false sense of security, and if this causes
you to start slacking off on your emergency procedures/skills then
you are less safe. It is better to _be_ safe than to _feel_ safe.
The BRS seemed neat to me, but only until I read the article.
-S
Subject: | Re: RV Flight Speeds |
08/17/2000 04:30:56 PM
repost for future electronic searching
PM
cc:
but
I wish I had.
that
make
The
> Climb-out speed?
off
full
> Turn to base speed?
> On final speed?
and well aligned.
> Any other hints?
Pitch
Subject: | To all List Members!!! |
Listers
I have just read an email that was left on this forum about MY SERVICES. As
everyone knows, I was doing the BADGES for the members to have a way for all
of us to meet and know each other at events. I apparently did something wrong
according to one member. I have no control over the mail service. I will
finish the badges I have in house and take care of the one that didn't
arrive, but feel I have to quit. I didn't deserve the remarks that were made
about me. I try to respond to every email but some fall through the cracks.
I'm human! .This person has only contacted me twice and I responded both
times, as far as services go everything he has gotten or not gotten was FREE.
Steve Davis
The Panel Pilot
Subject: | Re: The panel pilot |
08/17/2000 04:21:14 PM
Also, If he went to Oshgosh I would think he had a busy work week
there..... and not a vacation week . He may need time to sort things
out........He may have a new e-mail server or new proxy server that isn't
forwarding like it should (I've been there)......
"Bill Shook" (at)matronics.com on 08/17/2000
03:36:19 PM
cc:
Subject: RV-List: The panel pilot
second ring.
emails
now
ready and
and no
> badge.
he
may
information
immediate and
concerned,
'reachable' or
> responsive.
> Regards,
> Ken Balch
> Ashland, MA
> cockpit stuff
total
of
local
I
business
out
it
> > Greg
> > panel
> > > Mal
> > > RV-6 finishing kit
08/17/2000 04:22:53 PM
From your posting I gather you plan to wear a 'chute all the time ?
Jim_Andrews(at)tivoli.com@matronics.com on 08/17/2000 03:36:17 PM
cc:
Subject: RV-List: Plane Chute
Ballistic
Spruce.
for
wife
that
inconvenient
- Jim
0-360 (N89JA)
Subject: | Re: To all List Members!!! |
Listers,
It seems that Steve has decided to compound the poor service I received by making
false assertions in public about the number of emails from me that went
unanswered by him. I never made any claim to have paid him for any goods or
services whatsoever. He sent me a private email almost an hour ago containing
these same assertions, as well as an unkind personal remark, and my response went
out to him approximately half an hour ago. Perhaps he hasn't received it yet.
Since he's chosen to call me a liar in public, I feel perfectly free to publish
his email to me and my response to him here.
Steve,
I can appreciate that you have no control over the US Mail. I can certainly
sympathize with this, as can we all. I look forward to receiving the badge.
My original emails to you were indeed regarding the possibility of your doing my
panel. You were recommended to me by Paul Besing. When I got no response to the
first email, I sent the second. These date back to late last year or very early
this year. I've since changed my email service and my copies of earlier emails
have, unfortunately, been purged. I also sent at least one email requesting
information about having my fuel caps added to the last run and received no reply
to that message either. I can understand that you don't receive all emails
addressed to you (what service provider is perfect, after all), but find it a
little hard to believe that all of my emails fell through the proverbial cracks.
As far as handling things like a 'man', there's nothing to handle. As far as I
was concerned, I wasn't looking for a response from you. I was willing (and
fully expecting) to just let the whole thing drop entirely, since all I'd
actually invested was one set of round-trip postage. When I saw the message on
the list this morning, I decided to simply post my experience as a counterpoint
to the rest. I don't find anything unmanly or even confrontational/contentious
about that. If you do, get over it. One person's perfectly civil commentary on
the service he feels he's received (or not) is not a personal attack. It's just
one more opinion added to the rest. I have no problem with you personally, as
we've never met or even spoken (to the best of my recollection), so unkind
personal remarks on your part are uncalled for and do not speak well of you.
As far as your getting out of the name badge business, that's certainly up to
you, but I believe that it's a valuable service unanimously appreciated by all
who've received the badges, as well as those of us still eagerly anticipating the
arrival of ours. I'm sorry for any part I may have inadvertently played in
generating any ill will.
With no hard feelings...
Best Regards,
Ken Balch
PANELCUT(at)aol.com wrote:
> Ken
> I sent the badge out via US Mail. I have no control over their service. I
> have only received TWO emails from you in response to the badge and responded
> both times.
> I will take care of this BADGE but give me a little slack I have NO CONTROL
> over the postal service. I was on vacation for a week took a little time to
> go to Oshkosh so I might have missed a few but I can only respond to what I
> receive and I try to do that, sometimes I do not get all my emails but have
> no control over that as well. Sorry your so damm unhappy with my services,
> the damm badges were free but thanks to you I will give that up as well.
> Somebody on the list told me I should have charged for them but I thought I
> was doing the list members a favor. Another thing you have never asked me
> about a PANEL the only thing we have ever discussed was the badge. Next time
> handle it like a man and let me know if there is a problem, don't get on a
> public forum to get a response.
> Steve Davis
> The Panel Pilot
I sincerely hope that this will be the end of this minor debacle. I have no hard
feelings toward anyone, however deserved they may be at this point. In the
future, I'll keep my opinions to myself, however valuable they may be to other
builders.
Ken Balch
Ashland, MA
cockpit stuff
PANELCUT(at)AOL.COM wrote:
> Listers
> Steve Davis
> The Panel Pilot
Heck guys done it again!
Really seem to know how to chase away the good guys like Steve, Scott Mc
Daniels, Brian Lloyd to name but a few.
This list is a wonderful relatively FREE service, we all need to be polite
and repectful. I know it is all email and impersonal, but there REAL people
on the receiving end. I deal with the same insensitivity at work everyday
and if I didn't depend on the pay check at the end of the month to pay for
the RV I would tell them to go to hell as well.
I am really sorry that Steve has decided to take this to heart, he did my
caps and they are great. Missed getting the Badge prior to Oshkosh and was
really sorry I didn't, they looked great and the fellows wearing them did so
with pride.
Now go ahead and flame me.
Dave Burnham
Finishing wings.
The Minnesota RV Wing had a great meeting earlier this year at the BRS factory
in South St. Paul, MN. The folks at BRS gave us a great tour and said they get
more requests to develop a system for the RV than any other aircraft. They have
a great background in Ballistic parachutes and they are the ones that developed
a system for the Cirrus.
They are working on designs for the RV's, but there are some major engineering
factors to consider:
First is the large performance envelope for the RV's. How do you design a chute
that will work at speeds from 70 to 200 mph?
Second, how do you support a low wing design where all the strength is in the fuselage,
and then run straps along the fuselage of an aluminum aircraft. It's
relatively easy for a composite aircraft, just form some strap channels and cover
them with a layup of fiberglass.
Third, weight considerations. A system for the RV would probably weigh in the 50
to 80 pound range. And would you be willing to give up space for the system.
Fourth, but less of a concern to the BRS folks....cost. They are estimating a price
of about $6,000 to $8,000 dollars. Insurance policy is the way I see it.
Give them a call and let them know what you think. They are a smallish company
and are driven largely by customer demand.
Hope that helps, they're great folks.
Bob Moser
Subject: | Re: Agle of incidence |
> IN measuring the angle of incidence on the wings,
> what is the best way to do it; I tried with a piece
> of wood, a la, triangle... is hard to get the 3-1/32
> and then one must cut off the small angle, to be
> perpendicular to the wing no?
> Maybe I should use a piece or aluminum angle?
> Bert
> rv6a
Bert,
I used a 48" carpenter's level. The forward part rested on the main spar,
then I used a piece of .063 made into an "L" which I used a cleco side clamp
to clamp onto the carpenter's level for the rear spar. The L was adjusted
with the grinder to exactly the right length. Put your SmartLevel on top of
the carpenter's level, rest the whole thing with the straight part of the L
resting on the rear spar rivet line and the front part of the level on the
main spar and voila, you have a trick leveling device.
BTW, be sure and measure at several points along the spar and average the
readings. Remember also that the wing walk doubler throws the measurements
off so don't measure too far inboard.
Randy Lervold
RV-8, #80500, cowling
www.rv-8.com
Home Wing VAF
I have to agree with Bill Shook's comments about Steve at Panel Pilot. I am
one of those who has this great badge with my name and the type of RV I am
building engraved on it, for free, from Steve. No cost, just as a service
he gave to the RV list, at a significant cost to himself in time and effort.
I had never been particularly interested in engraved panels, but I want to
do business with the Panel Pilot, so I may well have one.
I also run a one-man business. I know that sometimes no matter how much
effort I put into it, someone is going to be unsatisfied sometime which what
I have done or not done for them. My experience over many years has shown
me that the best way to deal with that is to try to give superior service
all the time. That means that most are satisfied with my work, and when
they aren't, they tend to cut me some slack because they know that there was
either a very good reason, or that it will get straightened out, or both.
Those that get bent out of shape about it probably have a problem that has
nothing to do with me or what I did for them.
We all have our priorities. I am confident from what I know of Steve's
service that either the word isn't getting to him, or something high
priority is getting in the way of responding to the inquiries. I am quite
sure he subscribes to the RV list, so he will get the word.
I just want to be sure that when he reads the negative comments on the list,
he understands that many of us are more than satisfied with his work, and
hope to do business with him in the future. I wish him the best.
Terry Watson
RV-8A wings
Seattle
Why yes, actually.
There is a gentleman who has a flying RV-8 near me that has incorporated the
"Silver" brand chute with a lambs wool cover as the permanent seat back cushion
of both is front and back seats. I plan on following suit.
Please don't misunderstand my intention here. I'm sure that my RV is well built
( I know the builder well :-) I'm sure that it's safe. I just believe that
it's better to have a back up plan for EVERY contingency than to be up there
wishing that I had installed that fire suppression system ( yes I'm installing
a
halon system ) or brought along a chute and not have one. I don't want ANY
regrets.
- Jim
RV-8A ( engine stuff )
O-360 ( N89JA )
pcondon(at)csc.com on 08/17/2000 03:17:45 PM
Subject: Re: RV-List: Plane Chute
Sent by: owner-rv-list-server(at)matronics.com
cc:
Ballistic
Spruce.
for
wife
that
inconvenient
- Jim
0-360 (N89JA)
These are all valid concerns. I used to have a 2 seat ultralight that I
used for instruction. The BRS made some of the students (primarily some of
the student's *wives*) more comfortable.
Bear in mind also that there is also a significant weight penalty involved.
My ultralight's gross weight was about 700lbs. The BRS required for that
weight with a maximum deployment speed of 70mph weighed around 15lbs
including mounting hardware. It also costs (today) around $2000 This was
for an airframe that was already designed for a parachute and needed no
structural modifications.
I would hazard a guess that a BRS sized for a 2 place RV and with a speed
rating high enough to do any good would weigh around 30-40 pounds, and cost
a small wad of cash. Maybe another 10-20lbs for airframe beef-up. That
would shave off most of your baggage compartment utility.
IIRC, the Cirrus installation added about 60lbs to the airframe.
Safety is a good thing, but personally, I don't think a proven design like
an RV really benefits from a ballistic chute, especially in light of the
weight and cost penalty.
Ballistic
Spruce.
Their talking about having their fuel caps machine engraved with "100
low lead" or "100 octane only" or their iniatials,etc.etc.
Larry Mac Donald
Rochester N.Y.
> thanx bob
Subject: | Re: RV3-List: RV-3 N993FL SN 488 finally flies |
!!!!!!!!CONGRATULATIONS FINN!!!!!!!!!!!!!!
Please keep up the posting as you continue to expand your flight envelope.
I think there may be interest in hearing more about your experiences with
alternative powerplant applications!
RV-3's forever!!!
Rob Reece
Sent: Wednesday, August 16, 2000 10:25 PM
Subject: RV3-List: RV-3 N993FL SN 488 finally flies
> first landing?
> "uneventful".
> that).
> numbers.
> Finn
RV-3's forever!!!
Rob Reece
> first landing?
> "uneventful".
> that).
> numbers.
> Finn
Subject: | Apology to Ken and the List |
Listers
This is the last response I will make. I have jumped the gun on this
subject and owe this list an apology and Ken Balch as well. I have had a heck
of a time doing these badges and trying to keep them straight. I do not
expect everyone to understand and let it get to me. The thing that has gotten
to me the most was Ken's last email displaying my letter to him. I was angry
and should have never sent it I am truly sorry and please except it. I have
to learn to let things roll off my back, I can't expect someone to have
respect for me if I can't do the same for them. I will try in the future to
not jump so fast and to let it GO.
Steve Davis
From: | "Robert Greener" <rgreener(at)micron.net> |
Subject: | RE: RV3-List: RV-3 N993FL SN 488 finally flies |
Hello Finn,
Congratulations on the first flight of your 3. Wish mine was ready to fly -
I'll just have to work harder.
Glad everything went OK.
Regards.
Rob (RV-3B N418RL Reserved))
Hey man, don't sweat it. If you ever regret not having that chute with
you....you won't be regretting it for very long. :-)
I love to skydive almost as much as I love to fly.....but both in one flight
I don't want.
Sent: Thursday, August 17, 2000 5:42 PM
> Why yes, actually.
the
cushion
built
that
there
installing a
ANY
> regrets.
> - Jim
> O-360 ( N89JA )
> cc:
> Ballistic
> Spruce.
place
> for
My
> wife
> that
> inconvenient
> - Jim
> 0-360 (N89JA)
The only thing I would add to this fascinating discussion is that something
done for FREE is not a service, it's a gift. Brings to mind a saying my
dear old grand pappy used to say about a gift horse and it's mouth.
Sent: Thursday, August 17, 2000 5:20 PM
Subject: Re: RV-List: To all List Members!!!
> Listers,
making
or
containing
response went
yet.
publish
> Steve,
certainly
badge.
doing my
to the
early
emails
requesting
no reply
emails
it a
cracks.
as I
(and
message on
counterpoint
commentary on
It's just
personally, as
you.
to
all
anticipating the
in
> Best Regards,
> Ken Balch
> > Ken
I
responded
> > both times.
CONTROL
to
what I
have
services,
thought I
me
time
a
> > Steve Davis
> > The Panel Pilot
no hard
the
other
> builders.
> Regards,
> Ken Balch
> Ashland, MA
> cockpit stuff
> > Listers
SERVICES. As
all
wrong
made
cracks.
FREE.
> > Steve Davis
> > The Panel Pilot
From: | "EXT-Richard, Emmanuelle J" <Emmanuelle.Richard(at)PSS.Boeing.com> |
I *vaguely* remember so beware. Maybe worth your time to do some research on this
company - now you know it is out there somewhere.
About 5 months ago, meet a couple people in Van Nuys, CA involved in a company
developping recovery chutes. Don't remember their names. They said they were
working with a russian company who was prime in research, development and manufacturing
of parachutes type recovery systems for russian military jets and x-planes
for many many years. Their idea was to use this proven technology and
expertise for the GA market. As far as performance, it seemed very attractive:
chute usable throughout the flight envelope (speed, altitude, attitude), system
was something like 3-5% of the aircraft weight, around the $10 000 area,
some sort of pyrotechnic extration device, reliability 100%.
Subject: | Re: Apology to Ken and the List |
Gladly and gratefully accepted. I'm sure we've all done and said things when
angry that we wish we could take back later. I know that I have and that email
just makes it that much easier to do so. Your public apology shows real class,
at least in my book.
Best Regards,
Ken
> Listers
> Thanks
> Steve Davis
Well said. I think it's only human to jump the gun sometimes.
I stand with you
Earl RV-4
> Listers
> Thanks
> Steve Davis
From: | "skybolt-aviator" <skybolt-aviator(at)email.msn.com> |
Steve---I for one appreciate very much what you did and I,m sure the
majority of the listers feel the same. Don,t let one or two get you
down.Ollie&Lorene Washburn
RV6-A,N795LW@FD77,300+Hrs.
O-360,180HP,HartzellC/S
Sent: Thursday, August 17, 2000 4:51 PM
Subject: RV-List: To all List Members!!!
> Listers
(EMWAC SMTPRS 0.83) with SMTP id" <B0005065293@mail-2.lbay.net>;
Thu,
17 Aug 2000 18:54:37.-0700(at)matronics.com
Subject: | Taxi Test (long) |
Fellow Listers,
Thought some of you might be interested in hearing about my first taxi test. It
was lots of fun
to release the brakes and taxi for the first time. Following are my observations:
- My RV-4 has a light tail --- 42 lbs. at empty weight. This was pretty noticeable
when I
gave it a little throttle to turn it around at the end of the taxiway. Maybe it
was my
imagination, but I don't think so --- it felt like the tail got really light:
Important safety tip,
keep that stick back when goosing it.
- My Skyforce III GPS was difficult to see in the sunlight with my sunglasses
on. After the
taxi test I tore into the panel and mounted the GPS at an angle so it tilts up
directly at my
face. This fixed the problem.
- Still no vacuum on my indicator, but the one gyro I have (attitude indicator)
spooled up and
seemed to work. Hmmm. I've diddled with this problem for a week. Maybe I'll
try
adjusting the regulator's knob the other way this time.
- My oil filter goobered all over the bottom of my airplane again. I've fiddled
with this quite a
bit. First I thought it was too loose, then too tight. So, I pulled it off and
I'm trying another
one. Unfortunately, I can't get a torque wrench in there to torque it to specs,
so it's just a
guess at how tight it must be. We'll see if I got it right with this second one.
- I didn't hear a peep out of my radio. My home field is a quiet place, but I
have yet to hear
a thing. I'm really not looking forward to figuring that problem out.
So, as with every other aspect of progress on this project, I continue to have
plenty of
challenges to keep me busy.
Clay Smith, RV-4, N9X, waiting for an inspection
Indiana
From: | Charlie and Tupper England <cengland(at)netdoor.com> |
this company - now you know it is out there somewhere.
x-planes for many many years. Their idea was to use this proven technology and
system was something like 3-5% of the aircraft weight, around the $10 000 area,
Haven't heard this, but an aero engineer friend with a Yak 52 told me
that they are working on a G.A. EJECTION SEAT for about that price.
From: | "Gary & Tena Strong" <gstrong(at)uswest.net> |
Subject: | F-633 Control Column mount |
I'm installing the F-633 control column mounts, but I'm a little confused in
looking at the drawing and the tape. It says to put them in place against
bulkhead F-604, clamp and then drill the holes but doesn't give any specific
measurements on how to locate the mount. Drawing 47 shows approx.
measurements, but I'm confused on what is the proper way to do this. Is
there a measurement that I should check it side against? Is this just not
critical and as long as I align to Drawing 47 approx. measurements (5/8"
from top and 1/2" from flange side via eyeball estimate) and everything will
be ok? help!! I checked the archives and couldn't find an answer.
-- Gary S. RV6AQB - fuselage
Subject: | Re: Taxi Test (long) |
I can't get a wrench on mine either. Before I installed the engine I
torqued the filter and found that it went from 15/16 - 1 turn to reach
torque from the point that the gasket first touched the plate. It may not
be very scientific, but it should get you in the ballpark.
Ed Bundy - Eagle, ID
RV6A, 0320-D1a (160hp)
Sensenich 70x78, N427EM, 350+hrs.
ebundy(at)micron.net
fiddled with this quite a
off and I'm trying another
specs, so it's just a
second one.
Hello Yall
I had Steve cut my RV-8 panel and am very happy with the quality of the
work and the price. I can not imagine the time it would of taken to do
the same thing by hand. I am expecting the first editions of my custom
armrest overlays tomorrow or maybe Monday. It will likely take one more
clear set before the final cutting.
This type of work takes a lot of time to do right. Steve has a real job
to support himself and the equipment. When he gets busy at work it
sometimes takes the priority that it should. When I get no return call I
know he is busy and just call back in a couple of days.
Steve enjoys doing the panels for people and takes great pride in his
work. Please, let's not remove the fun and run him off like the other
talented people who have quit the list.
Thanks Steve.
George Meketa
RV-8 \ oil cooler and control cables
Subject: | Re: F-633 Control Column mount |
In a message dated 8/17/00 9:31:00 PM Pacific Daylight Time,
gstrong(at)uswest.net writes:
<< I'm installing the F-633 control column mounts, but I'm a little confused
in
looking at the drawing and the tape. >>
Gary: This had me a little confused also so what I did was to assemble
the mounts with the control stick torque tube and then clamped the assembly
in place against F-604. Locate the mounts by shifting as required so that
each mount will be secured with a vertical pair of -10 bolts through holes
that are predrilled in F-604 for the wing spar attach bolts. You can adjust
the position of the mounts slightly in or out by using a different number of
washers as spacers on each side. Use the plan dimensions as your guide to
get the assembly located in approximately the right spot. This seemed to
work for me but I'm a long ways from flying yet and for darn sure no expert.
Harry Crosby
Pleasanton, California
RV-6, working on canopy installation
I second the plug for B&C alternator. And solid state regulator. These are
expensive but very high quality. No mucking around with disabling internal
regulators or finding brackets that work either. The regulator includes
overvoltage protection too, so you just bolt on and go. Very nice.
Randall Henderson, RV-6 N6R (~130 hrs)
Portland, OR
http://www.edt.com/homewing
I can't find my F-805EPP's. Does anyone remember if they came in one of the
bags, or in the big box of parts (quickbuild) ? They are the two little
hangers for the rudder cables under the floorboards. I can't find them on
the inventory sheet. I would just make some new ones, but I am not sure how
much spare scrap .063 I have and I don't want to start hacking holes in my
instrument panel (to get scrap.063) just yet :).
Greg King
RV-8 QB
looking for elusive parts
>Thanks,
>Greg King
Greg,
On my slowbuild, they came in one of the bags.
Ottawa, Canada
http://members.xoom.com/kevinhorton/rv8.html
the
how
Greg....
Now that you mention it, they did not send them to me either. As I recall,
I got two of them from a friend, to whom Van's had sent a number of extra
ones! I think that I would just ask Vans to send them to you. If you make
them, just use a small piece of straight stock from the kit - you can always
replace a small piece of .063 later.
Jerry Carter
Memphis, TN
Drilling the canopy in 102 degree heat :>(
My RV-8A website:
http://rv8asite.homestead.com/mainpage.html
From: | Carroll Bird <catbird(at)taylorelectric.com> |
Subject: | Re: electronic ignition questions |
Bob Japundza wrote:
> Listers,
I run mine on the bottom like Jeff Rose suggests.
I talked to Jeff about this by phone. At that time he suggested the
REM 37BY Champion plugs.
Can't help you with this one I use 100LL
> smoother?
I think that it runs smoother at idle. However I have never run the
engine without the electronic ignition.
At altitude I run 2400 RPM and burn 7.5 GPH At that RPM I cruise
at
153 K.
> Hope this helps. Carroll Bird, Buffalo Gap, TX RV-4 114 hours.
You know this is the type of crap that makes me want to drop off this list.
Here is a guy that is doing a great service to the list only to be flamed. I
very much appreciate the badges from Steve and at Oshkosh I met several
people from the list just because of the badge.
Thanks Steve for my badge and I look forward to working with you on my panel
Len, RV-8A (N901LL)
Fuselage
North Carolina
Subject: | M2 electronic compass |
FYI -
For those of you who were waiting for the arrival of the black-faced M2
electronic compass from Ritchie, it looks like they have changed their mind and
are not going to produce it. Below is my correspondence with Ritchie.
Larry Bowen
RV-8 fuse...slowly
--- Jonathan Sherman wrote:
> Date: Tue, 25 Jul 2000 15:21:12 -0400
> From: Jonathan Sherman <Jon.Sherman(at)Ritchienavigation.com>
> To: Larry(at)BowenAero.com
> Subject: Re: M2
> Larry,
> I'm sorry to say I have some bad news for you. Some circumstances arose
> that prevented us from creating the M-Series with a black dial. Sorry
> about that. I wish we could have done it.
> Jon
> Larry Bowen wrote:
> > Jon -
> > How is the progress on the black-faced M-2? I'd like to get one if it's
> > available.
> > Thanks,
> > Larry Bowen
> > Email: Larry(at)BowenAero.com
> > Web: http://BowenAero.com
> > > -----Original Message-----
> > > From: Jonathan Sherman [mailto:Jon.Sherman(at)Ritchienavigation.com]
> > > Sent: Friday, March 24, 2000 4:35 PM
> > > To: Larry Bowen
> > > Subject: Re: M2
> > > Dear Larry,
> > > The M-2 is not yet available in black but we plan to have it
> > > out in about 2
> > > months. West Marine should have it when we come out with it.
> > > You can either
> > > check with them or with me as to when you can get it.
> > > Jon Sherman
> > > Larry Bowen wrote:
> > > > I like the M2, but want a black card, not a blue one. Does it
> > > exist? Where
> > > > can I get it?
> > > > Thx,
> > > > Larry Bowen
Send instant messages & get email alerts with Yahoo! Messenger.
I'm doing a slow build -8 and mine where in a zip lock type bag with other small
pre-cut parts like the inspection covers for the fuselage tail etc.
-Jeff
---------- Original Message ----------------------------------
Date: Fri, 18 Aug 2000 02:34:56 EDT
>Thanks,
>Greg King
>RV-8 QB
Subject: | Gretz servo kit mount |
Just looking for a little confirmation before I drill some holes. I'm
working on the Gretz-Aero elevator trim kit for my RV-4. Looks to me like
the only way to fit it is to run the cable through the aft most lightening
hole in the elev. web, resulting in the cable/servo crossing the rear deck at
a 45 degree angle. This obviously puts a good bend in the cable, but it
seems to actuate freely nonetheless.
So- who's done it, and how?.....
Bruce Hukari
RV-4 finishing forever
Subject: | Re: Flaring tool |
Bert,
I bought one at eagle hardware for $12, works great on alum. tubing.
Kevin
closing wings
Subject: | Re: RV-3 First Flight Report |
08/18/2000 10:00:25 AM
ReeceRV3(at)email.msn.com on 08/17/2000 06:45:28 PM
Subject: RV-List: Re: RV3-List: RV-3 N993FL SN 488 finally flies
RV-3's forever!!!
Rob Reece
> first landing?
> "uneventful".
> that).
> numbers.
> Finn
Subject: | Re: RV-3 N993FL SN 488 finally flies |
Finn,
CONGRATULATIONS !! & WELL DONE !!
Chuck & Dave Rowbotham
(almost ready to mount wings)
Nianitic, CT
>From: Finn Lassen <finnlassen(at)netzero.net>
>To: rv3-list(at)matronics.com, Tracy Crook , Paul
>Subject: RV-List: RV-3 N993FL SN 488 finally flies
>Date: Wed, 16 Aug 2000 23:25:36 -0400
Subject: | Re: Oil Filter -Torque Problems |
08/18/2000 10:44:16 AM
Repost for future e-searching
ebundy(at)micron.net on 08/17/2000 11:56:16 PM
Subject: Re: RV-List: Taxi Test (long)
second one.
a 37 degree flaring tool ????
For $12, you probably have a 45 degree standard type.
Ed Cole
> From: Im7shannon(at)AOL.COM [SMTP:Im7shannon(at)AOL.COM]
> Sent: Friday, August 18, 2000 7:30 AM
> Subject: Re: RV-List: Flaring tool
> Bert,
> Kevin
> closing wings
well this is all very mind boggling to me, if I wanted to fan my desire to be
argumentive it would be easier to just call one of my ex-wives. Lets get back
to talking about building RVs . I had a little problem with oil canning in
one of the bays in my left wing, and am working thru a solution. (I think)
ANY SUGGESTIONS?
Kevin
-9A closing wings
Greg and all,
I looked for three hours through every little brown bag until I was going
crosseyed. I checked the parts list. I wasted an entire evening looking for
that part. I was pissed.
I called Van's the next day and talked to Tom. He told me that the "pp" on the
part designation indicated that it was prepunched and should be in the bags,
although he had no idea which bag. The long and the short of it was that I
finally just made them myself. Since they are a prepunched part the dimensions
are not on the drawing. Just measure the snap bushing that goes in the hole and
use your unibit to cut the hole. The rest you can extrapolate by just measuring
the drawing it's self. I think it's at half scale if my memory serves me right.
The whole process took me 30 minutes.
The one big point that I have learned on my one year of continuous building
experience is..."Van's occasionally screws up. That's life, get over it, take
up the slack and keep on trucking."
It will all be worth it in the end.
- Jim
RV-8A quick ( engine stuff )
O-360 ( N89JA )
Subject: | San Jose RV Forum |
To all listers within traveling distance...
San Jose, CA's EAA Chapter 62 will be presenting it's 3rd annual RV Builders
Forum
on Thursday Sept 7th.
Location will be at Reid Hill View Airport (RHV) in Vern Miller's
Maintenance Hanger.
Guest Speaker is Ken Krueger from Van's Aircraft. Ken will arrive in the new
RV9
and will present a slide show on Van's new facility in Aurora, Or. as well
as speaking
about the RV9.
Cleveland Tools, Avery Tools, and The Builders Bookstore have all
contributed
door prizes and catalogs.
The prizes so far include hand tools, 18 Years of the RVator, and a Canopy
Cover
for the RV series aircraft.
We will have aircraft on Display along with tool displays, and member's
projects
in various stages.
The fun starts at 6:30 p.m. with the hot dog and hanger flying hour.
The meeting will begin promptly at 7:30.
If your interested in displaying your aircraft, or would like to participate
in any manner, please contact me off-line
For more details contact Ed Cole
408-530-6605 W
408-257-3281 H
edwardmcole(at)home.com (home email address)
Ed Cole
Maxim Integrated Products
Bldg. 120 Ext. 6605
Subject: | Baggage in the wing... |
Forgive what may be a stupid question...
Is there any reason why someone could not build a baggage compartment into
the wing? Say a hinged compartment providing a storage place between two
ribs and the forward and rear spar?
Or is it just the danger of losing the baggage compartment door and thus
disrupting airflow?
Troy Whistman
P.S.--Not planning to do this!! Just wondering! Don't flame! :-)
I am interested in doing an RV workshop and I've seen one advertised by
Sportair in Griffin, GA in October. Has anyone on the list done this
workshop and found it worthy? I will need to travel across the country to
attend and want to make sure the value is there. I've also heard rumors of
a workshop in Maryland in April. Does anyone have info on that one? I
would rather go there (closer - I live in Indiana). Thanks for the help.
Bob Waalkes
RV-8 Waiting on Emp.
Forget it... I know why. Structural strength depends on the skin. Duh! I
realized it right after I posted.
From: Troy Whistman [mailto:TroyW(at)digitalmd.com]
Sent: Friday, August 18, 2000 11:34 AM
Subject: RV-List: Baggage in the wing...
disrupting airflow?
Troy Whistman
>> any rv...
A full up IFR load with EVERYTHING running is less than 30A . . .
and if you're in a cloud, you don't run exterior lights AND
pitot heat. Ergo, the maximum running load for full IFR or Nite/VFR is
about 20 amps. A 30A machine would probably do you just
fine . . .
( Knowing about a thing is different than )
( understanding it. One can know a lot )
( and still understand nothing. )
( C.F. Kettering )
http://www.aeroelectric.com
If you're in a cloud night IFR and don't have your nav lights on the FAA will bust
you.
Now strobes is different matter. Pitot heat depends on the temperature.
Bruce
> >> any rv...
> fine . . .
> Bob . . .
> ( C.F. Kettering )
08/18/2000 02:22:20 PM
Lots of folks have placed baggage lockers in the wing tips. Lots of room
there. Use a doubler and install a door about 10 by 18 inches and you have
a great place to store junque. Check the archives. There was considerable
talk about this in the past. I've seen many versions of the wing tip
locker at the airshows.....Remember Phil's rule: Every little mod takes one
month (on average) to complete and keeps you out of the air by a equal
amount.....I shoulda listened to myself.......
Troy Whistman (at)matronics.com on 08/18/2000 01:29:15 PM
cc:
Subject: RE: RV-List: Baggage in the wing...
disrupting airflow?
Troy Whistman
Subject: | KMT-112 and KG-102A Remote Compass Installation |
Listers,
Looking for anyone with information regarding the installation of a Remote
Compass in an RV, specifically how they installed the KMT-112 in the wing.
Aloha,
Russ Werner
Maui
>A full up IFR load with EVERYTHING running is less than >30A . . .
>pitot heat. Ergo, the maximum running load for full IFR or >Nite/VFR is about
20 amps. A 30A machine would probably do you >just
Depends on the avionics and lighting setup. My ammeter indicates in the 40+ Amp
range with full load turned on, probably a bit more when the radio is transmitting
(although I've not checked the ammeter to be sure). I fly with both landing
lights on day or night when in the vicinity of the airport to increase my
visibility to other traffic, and I run pitot heat when in or near the clouds,
so 40+ amps current consumption on a day IMC approach is a likely scenario for
my ship.
Tim Lewis
N47TD 103 Hours
Gary:
I got old plans but I will try & help. Starting in drg 47 draw a line
appr 5/8 from the Inside face on the f633,
then draw your 2 horz line appo 6 3/16 (centered along the length), Now
we got cross hairs on both of them.
On the top view of drwg 40 ( which I think is right) shows the feet point
in. the lower left side view that shows them pointing out I think is
wrong. Now look at drwg 41 that shows from the center of the weldment to
the edge of the ears of the F633 is 8 3/8's. If i havn't lost you by now,
find the spar holes that will best fit all that & use them to backdrill
the F633 at their cross-hairs. You will later use washers to fill in the
fit of the weldment ears to the rod ends. I am confissed, I wrote this.
writes:
> confused in
> against
> specific
> Is
> just not
> (5/8"
> everything will
Subject: | Re: KMT-112 and KG-102A Remote Compass Installation |
I built a bracket just behind the f606 in the tail, up high away from the
steel parts for the flux detector.
The amp is up front on the left side. I havn't flown it yet so I don't
know if I did good.
> Listers,
> Remote
> wing.
> Aloha,
> Russ Werner
> Maui
If it's the eaa group in Fredrick, Md. putting it on go there. You will
get more out of it and it will cost much less. The Sportair workshops
that I have attended were very basic and would be great for a beginner
but if you have built the stab already don't waste your money.
Earl
> Bob Waalkes
Subject: | -6 Canopy advice needed |
I am trimming the canopy for my RV-6 and have reached a point that has me
stymied. The canopy is down snug to the windshield frame and seems to be
contacting the forward canopy frame pretty well also. The problem is that
the canopy seems to be wider than the fuselage where the windshield comes
around the lower corners. At the junction of the windshield and canopy it
bulges out on both sides by almost two inches. When I press the lower
corners of the windshield in to get anywhere near a close fit to the forward
top skin at the lower corners, particularly on the left side, the rear of the
canopy bulges out of shape. It looks like I will have to cut the windshield
and canopy apart before I can start to drill and cleco point but I'm
reluctant to do that until I hear what some of you guys who have been there
and done that have to suggest. By the way, I just received my finish kit
late last year so this must be one of the newer canopies. All suggestions
will be appreciated.
Harry Crosby
From: | Frank and Dorothy <frankvdh(at)ihug.co.nz> |
Gary,
The important thing is that the mounts be exactly the right sitance
apart as per the length of the hexagonal torque tube that connects the
two sticks together. If the distance apart is wrong, your sticks won't
be parallel. Don't ask me how I know this!
Frank.
Subject: | Re: -6 Canopy advice needed |
If this is a slider. I suggest you cut it to fit more realistically. I had
the same problem with mine and the Factory said cut it and go on from there.
So I picked the mid point between the windshield frame and the canopy roller
and made the cut. Viola the canopy sat on the frame and then required final
trimming around the outside to fit it. Some shimming was also used on the
roll bar to make it seem as on piece again. Good Luck and go slow.
Don
RV-6 QB N767DC
O-360...C/S 112 TAE
From: | "Charles E. Brame" <charleyb(at)earthlink.net> |
Subject: | F633 Control column Mount |
Gary,
Boy, was your post timely. I just came in from my garage in a tizzy over
the control column mounts. Been working on the damn things all day.
Decided to peruse the RV-List and found your post.
The plans leave a lot to be desired.
First. Each mount flange goes outboard versus inboard as shown on DWG
40. Note #3 mentions that it is reversed!
Second: I used the "1/2" approx" dimension shown on DWG 47 to postion
and drill the 3/16" hole in the top of each mount. I then fastened the
mounts on the bulkhead using a bolt through the top hole, made sure the
mounts were aligned vertically and back drilled the 1/4" hole in the
bottom of the mount. BUT - SOMETHING IS WRONG.
When I installed the control column torque tube on the mounts, the tube
hits the top inside of the ribs with only a small amount of stick
forward rotation. My only conclusion is that the mounts are installed
too high. The "approx 1/2" dimension should have been closer to 1/4" and
I am not sure even then that the torque tube will clear the rib.
I'm not sure what my next step will be. Wish I had connected the torque
tube to the mounts before drilling to see what was required to have
torque tube clearance. May order new mounts and redrill using the 1/4"
dimension. May also have to cut out the ribs. May have to do both.
Two small steps forward - one giant leap backwards. &%#@*&
Charlie Brame
RV-6A QB, On the gear
San Antonio, TX
> From: "Gary & Tena Strong" <gstrong(at)uswest.net>
> Subject: RV-List: F-633 Control Column mount
Has anyone else had trouble logging on to the website SourceRV.com? I've
been gone for a month and when I tried to access the logon screen, I received
a screen that said access was Forbidden. When I tried to email the site, my
email was returned. Thanks.
DLCousins(at)aol.com
Subject: | Re: Baggage in the wing... |
Why not? You are building an experimental airplane. Just remember that mod
like this take a lot of time - you may want to do it once you are flying. I
am putting a camera in the right wing, cutting a hole in the lower skin etc.
Lotsa work.
My hangar mate is a retired UAL sheet metal mechanic, a master! He told me
that I should put a 'ring' all the way around the opening using material at
least as heavy as the skin. If the ring is not all one piece, it should be
jointed between corners, not at the corners. The corners are the most
stressed and must have continuous reinforcement. I have seen many
reinforcements on RVs that are not continous at the corners and hence,
nearly useless. If yours are like that, go back and add a corner
reinforcement. You can get them at your hardware store but you might do
better to make them of 2024T3.
Hal Kempthorne
RV6a N7HK
Sent: Friday, August 18, 2000 9:34 AM
> disrupting airflow?
> Troy Whistman
Subject: | F-805EPP ?--Thanks |
Thanks for all the help. I have my custom F-805's primed and installed.
They took a lot less time to build then they took to look for :) do not
archive
Thanks again,
Greg King
RV-8 QB (Fuselage floor)
will bust you.
FAR number violated please? Are you the Administrator?
I believe that, as PIC, I have the right to turn off position lites (if
that is what you ean by 'nav lites') if they disturb me.
Hal Kempthorne
2578 Elliot Court
Santa Clara, CA 95051-1849
408.244.4984 CELL 408.230.0891
RV6a N7HK 99%
1965 Debonair for sale!
Subject: | RV-8 Spar mounting holes |
List,
I need help with a few dimensions ASAP. I am making up the spar stubs that
mount into the fuselage (RV-8) that act as spacers for the spar during
construction. I need the measurements between the mounting holes between the
1/4 inch holes and the 7/16 holes in order to fabricate the spacers. I am
currently a couple of hours away from my project but have access to a
bridgeport and material and need the dimentions to fabricate the parts before
I head back in the morning. If someone could measure up their spar with a
vernier caliper and send me the center dimensions or even the web dimensions
between the holes I can make the spacers in the AM. Help!!
Tom Clark 800525 Ski2001a(at)aol.com
I wonder which canopy is under construction here?????? Assume slider.
In any case, don't start hacking plexi till the metal fits and operates
perfectly. Imagine that the glass is so clean it is invisible and you can
almost see it with just the metal parts working - sliding, tipping, locking
etc.
Then, set the plexi on and eyeball it to the best possible position. You
might want to do wingtips, cowl, fairings etc first to develop a feel for
"nailing jelly to a tree" which I believe is an art. You can even taxi
without the plexi, you know. You could do it just before you fly.
You can not begin to ATTACH windshield or canopy till you SEPARATE them.
Hal Kempthorne
RV6a N7HK
From: | "RION BOURGEOIS" <rion(at)worldnet.att.net> |
Subject: | Re: Sourcerv.com |
Jeremy Benedict, the website creator and administrator of RVSource, is
deceased. They posted how to get a refund for subscribers, and if they
didn't hear from subscribers, they were going to give it to charity, his
school if I recall. Rion
Sent: Friday, August 18, 2000 3:21 PM
Subject: RV-List: Sourcerv.com
received
my
My sincerest apologies. I had not made the connection.
Subject: | Re: Award for Dumbest Blunder |
Subject: | Re: Gretz servo kit mount |
In a message dated 8/18/00 10:45:51 AM Eastern Daylight Time, Boalty(at)AOL.COM
writes:
<< Just looking for a little confirmation before I drill some holes. I'm
at
Bruce Hukari
RV-4 finishing forever >>
Check the archives... Search for my name and Mlfred... You should see a
couple of ideas. As it turned out, I installed it per plans, but I've got
the same (seemingly) acute bend you describe.
Kyle Boatright
Kyle Boatright - Kennesaw, GA
RV-6 Slider, O-320/Aymar-Demuth
To the Airport by Labor Day!
In a message dated 8/18/00 6:29:06 PM Eastern Daylight Time,
AV8TURDON(at)AOL.COM writes:
<< If this is a slider. I suggest you cut it to fit more realistically. I had
and made the cut. >>
This is good advise. One caution - you may not want to cut the canopy
exactly at the gap between the roll bar and the slider canopy. If you do,
you'll end up with a much smaller edge distance on the screws/rivets on the
slider front bow compared to the edge distance for the screws in the roll bar
(ask me how I know).. You may want to cut it a little in front of the gap -
say 1/8 - 3/16".
Ted French wrote:
> I flew for 10 hrs with my magnetic pickup sitting on top of the bottom
> bolt
> holding the rudder on. Looked all over for it.
> Ted
Heck, thats nuthin, I flew the homebuilt airplane I built in my garage.
That has got to be the dumbest blunder there ever was
Gary Zilik - Pine Junction, Colorado
RV-6A N99PZ Flying
Engine: Aerosport Power O-360-A1A with H2AD Pistons
Prop: Sensenich 72FM8S9-1-83
Subject: | Re: RV-8 Spar mounting holes |
Tom,
There are mechanical drawings at Randy's site:
http://www.rv-8.com/pgRandyGriffin.htm
Mark Steffensen
8A Flying 21 hours
Dallas, TX
Sent: Friday, August 18, 2000 8:27 PM
Subject: RV-List: RV-8 Spar mounting holes
> List,
that
the
before
dimensions
Perhaps 91.209?
> will bust you.
> Hal Kempthorne
> 2578 Elliot Court
> RV6a N7HK 99%
Subject: | -9 Wing oil canning |
Hi all,
I had a bay in my left wing upper skin that oil canned slightly, this I
decided was just not acceptable, searched the archives and did not find much
as far as repairs, so devised my own. I laminated a doubler skin to the
underside of the offending skin with pro seal, using a garbage bag with about
10 pounds of water in it to hold everything in the "pillowed out" position
until the pro seal cured. This worked very well for me, Im wondering if
anyone else has tried similar fixes, and what were the successes or failures?
Kevin Shannon
-9A closing wings
In a message dated 8/18/00 5:38:17 PM Central Daylight Time, mphill(at)fgi.net
writes:
<< I finished my rear stablizer,and was very
proud of the workmanship that I test flew it in the yard with all the
neighbors watching >>
.........don't let the Feds know you got airborne without the paper work......
Subject: | Re: -9 Wing oil canning |
>Hi all,
>much
>about
>failures?
>Kevin Shannon
>-9A closing wings
Kevin,
Use caution when adding modifications to structural areas such as this. Also
keep in mind you now have a bit more weight in this wing versus the other
one, which might give you a heavy wing in flight, but then again it may
actually help your trim situation when it's flying. Can't say for sure right
now. It's a roll of the aerodynamic dice. ;)
Oil canning in the wing upper surfaces WILL happen no matter what you do.
When you're in flight, the wings flex under load and you'll have some
canning going on. Don't worry about it, and move on. It's perfectly normal
for the skins to do this. They will also expand and contract due to
temperature changes. You may be cruising along some day through a very cool
air mass, with nice snug skins. Then, you land, it sits in the sun while
hordes of RV dreamers and doers are admiring your airplane, and the skins
start puckering up in the heat. Such is life with a metal airplane. Have
fun.
Brian Denk
RV8 N94BD
113 hrs. Down for paint. Still.
Subject: | Sheared Wing Tips |
Dear Listers
I've heard some conflicting (mis)information on the
sheared wingtips Team Rocket sells and Van's will soon
be selling for all models. Claims of anywhere from +6
to 0 knots increase in groundspeed are out there.
There has also been mention of decreasing stall speed.
I believe Team Rocket sells their tips for $475
including the lighting lens but dont know if that is
for one or both tips. Can anyone clear this up? The
archives are no help on this one.
Rob Miller
Still Finishing after all these years.
From: | "George Armstrong" <armstrong(at)coastside.net> |
I am thinking of putting O2 bottles in each wingtip. I know the arguments
about roll rates etc. The bottles are removable if I want to do acro. If I
remember correctly, we gain about 2% ground speed and fuel efficiency per
thousand feet. I only have 172 time, which means I don't have any
experience with this issue. Does anyone out there have any experience with
O2? Do you really use it or is it a waste of time? How often will the few
thousand feet get you up above the weather or mountain turbulence?
George Armstrong
RV6A wings.
Subject: | Re: Sheared Wing Tips |
Rob:
Price is $475 for both tips -the lighting is in both tips - but Scott told
me that the lens is too small to hold the landing lights. You'd have to cut
those into the wings. I got my hot tips from Dan & Oliver in BFL (see Yeller
pages).
Phil Smith, 80691
Fairfax, CA
RV8, 0-320, Hartzell prop, installing electrical
>Thanks,
>George Armstrong
>RV6A wings.
I don't have personal experience with O2 but a friend of mine markets
a very lightweight oxygen system. Another friend has used it
extensively in his RV-6 as he lives in Las Vegas, is over 50 years old
(age does affect your ability to function at altitude), and regularly
flies over 12,000 feet.
I suggest you contact Ric Lee at:
Ric Lee
He'll be able to answer any/all questions you may have.
BTW, don't expect to get a bargain basement product. Ric won't sell a
product unless it's 100% perfect. But, remember you get what you pay
for, too.
John Ammeter
1975 Jensen Healey
RV-6 (sold 4/98)
EAA Technical Counselor
NRA Life Member
Council Member, Snohomish Indian Tribe
http://members.home.net/ammeterj
In a message dated 8/19/2000 10:46:56 AM Central Daylight Time,
rmill2000(at)yahoo.com writes:
<< I've heard some conflicting (mis)information on the
According to Mark the speed increase is from 0-6 depending on the aircraft
and also how much the owner has had to drink or wants to stretch the truth.
The main reason they would be faster is no drag as the strobes are enclosed
under a lexan.
The price is 475 for the pair.
I have never heard anything about decreasing the stall speed
chris wilcox
f1 builder
In a message dated 8/19/2000 11:55:04 AM Central Daylight Time,
pdsmith(at)pacbell.net writes:
<< Rob:
pages).
Phil Smith, 80691 >>
Phil,
Well its been a while since you have talked to team rocket as scott has long
been gone for a long long times, which is good since he didnt know what he
was talking about.
You can mount landing lights in the wing tip under the lexan tip. However
the have to be the small round 55 watt driving light style.
If you want to mount the duckworks landing light they have to go in the wing
You do have to buy the strobes and the landing lights, they are not included.
chris wilcox
f1 rocket kit 000
Subject: | VM 1000 manifold pressure sensor |
Howdy all,
Has anyone mounted their VM1000 manifold pressure sensor forward of the firewall
in a flying RV?
Just looking for a short cut.
- Jim
O-360 ( N89JA )
Subject: | Re: Rockymountain Instrument |
--- Bill Shook wrote:
> One question I've always had about the Rocky Mountain encoder is how
> readable is the airspeed when it's changing rapidly. Like coming
> down the
> back side of a loop....can you read the airspeed when you're in a
> dive or is
> it just a blur of numbers?
You're looking at the _airspeed_ on the backside of a loop?!?!?
Mike Thompson
Austin, TX
-6 N140RV (Reserved)
Fuselage
Subject: | Re: VM 1000 manifold pressure sensor |
I mounted my sensor on the top forward part of the firewall in a manifold
with the oil pressure sensor and the fuel pressure sensor. There are
pictures on my page. I have not flown it yet, but I do know some people
have done it also.
>Howdy all,
firewall
>in a flying RV?
>Thanks,
>- Jim
>O-360 ( N89JA )
Jim Cimino
RV-8 sn 80039 N7TL Reserved
http://www.geocities.com/jcimino.geo
(570)842-4057 N.E. Pennsylvania
Not much of an entry, but, I drilled my knuckle once (you only do it once),
so I decided to bolt my prop on (Hartzell C/S) and made sure the rear
spinner bulkhead was ready, even set it on top of the engine so I would not
forget it...I did. Had to take the prop off and do it again. I'm sure
I've done worse...but my mind has blocked out the memories.
Jim Cimino
In a message dated 8/19/00 9:21:25 AM Pacific Daylight Time,
bertrv6(at)yahoo.com writes:
<< Question concerning the Rockymountain Instrument;
if one has an eletrical failure , one would be
without any of the information needed, for a safe
flight.
NOT TRUE my engine monitor has a gell cell that runs 8 hrs after you
loose power, Thr monitor has a trickle charger circuit that keeps the gell
cell topped off.
Fred LaForge RV-4 EAA Tech C.
Subject: | Airspeed indicator for sale |
I have a new UMA airspeed indicator for sale. MPH on outside, knots on
inside, un-lighted, 0-240, and does not have any operating range markings.
If anyone is interested, contact me off line. I would like $100.00, and
I'll pay the shipping.
Jim Cimino
August 11, 2000 - August 19, 2000
RV-Archive.digest.vol-jb
