RV-Archive.digest.vol-js
November 27, 2000 - December 02, 2000
>So far it seems I have used
> the 2' most. Oh, also, plan to buy the Smart Level protractor. Any
> thoughts would be great.
I love my 2 foot Smart level and use it the most. That and an average
quality 4 foot bubble are all I have needed.
Ross
6-A Finishing
Subject: | Re: Fuse Blocks - Hinged |
-----Original Message-----
Date: Monday, November 27, 2000 12:55 PM
Subject: Re: RV-List: Fuse Blocks - Hinged
> ""...... I have 18 inch service loops on all my wiring and vacuum
>plumbing. The
>service loop to the breaker panel is about 1 1/4 inches in diameter so is
>not very flexible. However, removing the panel and setting it on the seat
>is a whole lot easier than crawling under the panel!""............
>DC current in looped wire can cause magnetic fields and associated compass
>distress. Have you noticed anything in this area...or is this one of those
>book things where the book say this, but practical experience shows
>something else ..??
>"Dennis Persyk" (at)matronics.com on 11/26/2000
>01:35:44 PM
A very good question. In avionics shop parlance, a "service loop" is extra
wire provided so that the device can be pulled out for maintenance without
disconnecting the wires. As such, it is seldom actually a full 360 degree
loop. In my case the wire simply snakes around in a curving path and at
most has about 90 degrees of curvature to it. It does not influence the
compass by virtue of its curvature.
Note however that there is a magnetic field around a single current-carrying
straight wire. It is proportional to the current and drops off as 1/r where
r is the distance from the wire. When you make an electromagnet you
increase the current by a factor of n times when you wind n turns. Because
of the current around event straight wires you should swing your compass
with everything turned on.
My compass works fine. Its the electric trim, gyros, VM1000 and GX60 that
are giving me grief and its not due to magnetic fields!
Dennis Persyk 6A N600DP O360A1A/Hartzell 15 hours
Hampshire, IL C38
From: | Glenn & Judi <foxinsocks(at)mediaone.net> |
Subject: | Free temporary 12V Power sources |
Hi,
I have (5) 12V power sources available to RV builders.
They are 120VAC in, 12V VDC out, Max 4 Amps. They are referred to as
switching power supplies, and provide a very reliable source (I measured
one at 11.9VDC). I won't tell you you what you can or can't use them
for, but I used mine for powering avionics, testing circuts and electric
gyros during the construction phase of my panel. Whatever you do with
them, it is at your own risk. They need power cords soldered onto
them. They sell for about $70.00 each, but I will give them away for
free under the stipulation that they remain the property of the users of
this list, and that you mail them to another builder from the list when
you are finished with them. Please don't ask for one until you are
really in need of it, other builders need them too.
Please e-mail me directly if you're interested. First come basis.
-Glenn Gordon
RV-6 (fiberglass fairings & stuff)
Losing building motivation as my garage gets colder and colder.
From: | "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> |
Subject: | Re: Horizontal & Vertical Stabilizer Mounting |
Dave: Thanks and believe me I will be doing an Index from here on out!
Tom in Ohio
----- Original Message -----
Sent: Monday, November 27, 2000 9:58 AM
Subject: RV-List: Horizontal & Vertical Stabilizer Mounting
> I made an index as I watched them the second time. Too much fast forward
and
> rewinding without it.
> Horizontal Stabilizer mounting begins on Finish Kit tape two, 28 minutes
> from the start.
> Vertical stabilizer follows at 35 minutes from start.
> Dave Biddle
> RV6A - wiring
> Tom & Cathy Ervin wrote:
> > > I have my Sliding Canopy ready for the fitting of the Plexiglas but
do
> to
> > > cold weather I would like to delay until better weather (Spring) to
> finish
> > > this step.
> > > Does anyone know where on the Orindorf Tapes the Empenage
Final
> > > Mounting is shown? I have the 3 QB,3 Finish & 2 System Tapes.
> > _
Subject: | Re: Left Hand Drill Bits |
I can't refuse this one. I believe your tongue in another part of your body
with your head. You probably have read by now that there are left handed
drill bits. I do agree with and support your political views though.
Subject: | Re: Panel shock mounts or not |
For what ever it's worth I did install shock mounts on
the instrument side as per Eustace, and am very
pleased with the results.
RV6A 125hrs and climbing
--- Eustace Bowhay wrote:
> Hi Harry:
> The shock mounts I use are Aircraft Spruce P/N
> 10-14700 found on page 336 of
> their current catalog @ 3.95 each and cap nuts (
> acorn) AC832 on the front
> of the panel, these are on page 88 am planning 7 or
> 8 on this panel. These
> mounts are the round stand- of type with the two
> screws molded into the
> rubber independent of each other.
> I will be taking some pictures of this panel in the
> next day or two and
> would be happy to send you a copy.
> Eustace Bowhay Blind Bay, B.C.
> From: HCRV6(at)AOL.COM <HCRV6(at)AOL.COM>
> Date: Saturday, November 25, 2000 11:01 AM
> Subject: Re: RV-List: Panel shock mounts or not
> >In a message dated 11/24/00 8:10:01 PM Pacific
> Standard Time,
> >ebowhay(at)jetstream.net writes:
> ><< It is important to use the correct shock mounts
> >Eustace: This may be a dumb question but what
> are the correct shock
> mounts
> >to use? If I recall the shock and vibration stuff
> correctly it is
> possible
> >to make the problem worse instead of better if you
> choose the wrong mounts.
> >Since your installation has worked successfully for
> nine years I want to
> use
> >what you did.
> >Harry Crosby
> >Pleasanton, California
> >RV-6, working on canopy installation
> support the
> Lists
> moment to
> through
> Matronics!
Cecil,
Ignore the ignorant who joke about the existence of left handed drill
bits. These are the same people who think that EZ Outs actually work!!
Broken bolts are often easily removed by drilling a pilot hole (1/3 - 1/2
the diameter of the bolt) using a cobalt drill bit. Trying to use high
speed steel drill bits on a grade 7 or 8 bolt will only destroy the bit
and p*ss you off. (Even on aircraft grade & grade 5 bolts they will cut
faster & cleaner) You then install a left hand drill bit slightly smaller
than the bolt's shank size. Running the drill in reverse, start to drill.
As soon as the bit "bites" it will spin that bolt right out. Works about
2/3 of the time. Using EZ Outs is a sure recipe for disaster. EZ Outs are
so hard, that once you break one of them in the hole, only a plasma arc
machine will remove them. Breaking a drill bit off is almost as bad, if
you can't remove it.
All the major automotive tool vendors, Snap On, Mac, Vulcan, Cornwall &
Matco carry them. McMaster-Carr and MSC also carry them. See Gary Van
Remortal's Yeller Pages for more info on MSC & McMaster-Carr. Ask your
mechanic buddies, they'll have them. Maybe one of them will loan you one?
I often will take a standard drill bit which is dull or broken and
resharpen it as a left hand drill bit. This is easily done using a
sharpening machine or can be done by any good machinist by hand. I learned
that skill years ago working aerospace machine assembly. The "old hands"
laughed at you, if you couldn't sharpen drill bits by hand. It was a
simple matter of saving my ego!! :-)
If all else fails, simply drill the bolt completely out. Drill oversize
and install a thread repair insert such as a HeliCoil or KeenSert insert.
Contact me off list for more info on how to do this. The trick is to make
sure that your pilot hole is fairly well centered.
Charlie Kuss
Broken bolts? We ain't afraid of no "stinkin" broken bolts!
cecilth(at)juno.com wrote:
> Does any one know where to find left hand drill bits? I called Averys
> and they don't sell them and she didn't know where to find them.
Subject: | Left Hand Drill Bits |
If you live in the L.A. basin you are probably within minutes of multiple
tool houses
that supply the aircraft,and other tooling industries with cutting tools.
Look in your
local yellow pages. Cleveland Drills is just one of many companies that make
south-paw
drills.
Randy Griffin
RV-8
Vancouver, Wa.
#80925
N925RG (reserved)
Fuse
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of cecilth(at)juno.com
Sent: Monday, November 27, 2000 7:40 AM
Subject: RV-List: Left Hand Drill Bits
Cecil Hatfield
Thousand Oaks California
RV6A
GET INTERNET ACCESS FROM JUNO!
Juno offers FREE or PREMIUM Internet access for less!
Subject: | Re: sustained knife edge flight |
Lucky,
Well, Van publishes a manoeuvring speed for RVs - the maximum speed
at which you can use full control deflections and be guaranteed that
the structure will take it. This speed applies to all three axes,
although it is usually the pitch axis (elevator) that is limiting.
So, Van has done his homework to be sure that the vertical tail,
canopy, cowling, wheel pants, etc can take the sideloads from full
rudder sideslips at Va. If you plan on using full rudder at speeds
greater than Va, you should be talking to Van, not us.
Kevin Horton RV-8 (fuselage 95% done)
Ottawa, Canada
http://eccentrix.com/misc/rv8/rv8.html
>yes, when you roll to knife edge with the nose pointed up to attempt to
>maintain altitude, you definatly put force on the windward side of the
>plane. That's the whole point of cocking the nose up. Your force the air
>against the side of the aeroplane - canopy very much included. It's like
>sticking your hand out the car window while it's moving. Your arm is no
>airfoil but air hitting the bottom of your hand/arm is enough to keep it up.
> So canopy, vertical stab, cabanes, struts, whatever you got on the
>windward side is going to be subject to loads during nose up knife edge. It
>PARTLY explains why a Extra 300L, with it's 2 place canopy, sustains knife
>edges easier than a Extra 300S with it's only single seat cockpit. Same
>thing as in a slip. The side facing the direction of flight is going to get
>some air force acting on it.
>I'd guess that if you pitched the nose up 20 degrees at 120 mph, rolled to
>knife edge, applied full top rudder which would keep the plane at about 20
>degrees nose up (just guessing here on what that pitch angle might be), the
>wind component on the side facing the oncoming air would be approximately 20
>sin of 120 mph force on the front of the plane. About equal to 41mph.
>Probably not a problem but I wouldn't want to volunteer to be the first to
>try.
>----Original Message Follows----
>From: bcbraem(at)home.com
>Subject: Re: RV-List: sustained knife edge flight
>Date: Sun, 26 Nov 2000 16:57:09 -0500
>lucky--
>I'm not sure I really understand the canopy question. There are really
>no bizarre forces acting the canopy in either knife-edge or inverted
>flight--unless your harness isn't tight and you're hitting the canopy
>with your body. If you subscribe to the-fuselage-as-airfoil theory for
>knife-edge flying, then some high-pressure exists of the "down" side of
>the fuselage while "up" side of the fuselage is low-pressure area.
>But, I've never heard of the pilot of any aerobatic plane having to do
>such a "reinforcement".
>You can save a lot of money by copying the parts list from The Christen
>(Aviat) manual and then buying the parts separately from other
>suppliers. Lycoming also puts out an Engine Operator's Manual for their
>aerobatic engine series that details the changes required. Last I hear
>they were still getting their parts from Aviat.
>The big concern with sustained knife-edge flight with a Lycoming AEIO-
>engine or the Aviat conversion is to do them LEFT WING DOWN as that is
>the side of the sump the oil pick-up line is on.
>But, take a look at the drawings and the recommendations for the
>placement of the certain parts and the running of the oil lines and make
>your own choice.
> > I'm curious if anyone's got any direct experience in how well a RV-6 or 8
> > slider canopy holds up to sustained knife edge flight. Anyone know of a
>web
> > site where someone's done any mods to the canopys to increase side load
> > strength?
> > Also, $700 for an inverted oil system sounds like an opportunity to learn
>to
> > build a system for less. Anyone have any ideas on where I can find plans
> > and parts? Anyone done this yet?
> > TIA,
> > lucky
Subject: | Re: Which Level To Buy? |
>Hi Listers,
>Wanted to upgrade my level collection before starting the wings. Currently
>own a 2' and a 3' (average quality). Looked into purchasing a "machinist
>grade" level but the price of $700-$1000 about knocked me to the floor. I
>said to the salesperson "What? you must think this is for an airplane" So I
>plan to buy a masons level which should be more accurate than those I have
>been using. The question is what size to buy? So far it seems I have used
>Thanks,
>Jack Textor
>RV8, Empennage complete, 213 hrs
>Des Moines, IA
Well, I found a water level to be very useful for leveling the wing
spar end to end. I figure I was able to get the two ends within 1/32
inch of the same height, which is much closer than you can do with
any normal level, even the much ballyhooed "Smart Level". I found a
water level kit at my local hardware store that used a garden hose as
the main part, with some clear tube and valves, etc that you screwed
onto the ends. You have to be careful to get all the bubbles out,
but the directions covered that well enough.
My Smart Level is very useful too, but I think you can be just as
accurate with a good quality bubble level. The Smart Level is
useful, but not indispensable, for those times you want to check
things at various angles.
Take care,
Ottawa, Canada
Subject: | Re: Free temporary 12V Power sources |
I have two electric gyros, AI and DG in need of running. If these have not
all been requested by now, I'd like one and I agree to your terms of passing
it on.
I also agree about the cold garage workings. Going now to drill the rear
side skin on my RV6A.
Marty in Brentwood TN near Nashville.
Sent: Monday, November 27, 2000 5:25 PM
Subject: RV-List: Free temporary 12V Power sources
> Hi,
> -Glenn Gordon
Hi
What supports the rear seat back when a passenger is sitting in it? I have
assembled it. except for the Fiberglas top. It looks like all the weight
will be on the rivet line that attaches the Fiberglas and the seat back. Did
I miss something? If this is true has anybody had any problems with fatigue
or Fiberglas separating?
Thank You,
Ed Perry
RV8QB/180CS
n8vd(at)earthlink.net
Subject: | Sorry, 12V Power Sources ALL GONE. |
Hi,
The (5) regulated 12VDC power sources I have were requested in the first
hour after posting. When those people are done with them, they will be
distributing them again to the rv-list.
-Glenn Gordon
Subject: | Re: Sorry, 12V Power Sources ALL GONE. |
Hi Glen,
I saw your post early on but since I'm only on my tail feathers I didn't
think it fair to ask for one of your power sources. If I were willing to pay
the price where would I find one?
Dennis Thomas
RV-9A Emp
DThomas773(at)AOL.COM wrote:
> Hi Glen,
> Dennis Thomas
> RV-9A Emp
Newark Electronics sells them. But in all honesty, I don't know how precise a
power supply is needed to run avionics. An alterator isn't the cleanest form of
power from what I can tell. Perhaps Electric Bob can give some input on how to
build a simple yet sufficient power supply for this purpose.
-Glenn
Subject: | Knight Upholstery for RV |
RV Builders:
I have moved to Las Vegas. Please note my new telephone number and e-mail
address.
I have been in the upholstery business for 28 years and have been making
upholstery products for kitplanes for 16 years. I have interior kits
available for RV-4, RV-6, RV-6A, and RV-8. I also have cabin covers and
other items. I am the supplier of upholstery products for several kitplane
manufacturers. A list of other kitplane interior products available upon
request.
For more information, call Knight Aircraft Interiors, Inc., at (702)
207-6681 or e-mail me at knightair(at)lv.rmci.net. If you e- mail for
information, please mention either "Knight" or "Upholstery" in your
reference line so I can give your request my immediate attention. Photos
available upon request.
Sincerely,
KNIGHT AIRCRAFT INTERIORS, INC.
"Fly by Knight" Upholstery Products
Sam Knight
What supports the rear seat back when a passenger is sitting in it? The
fiberglass upper/outer edge component and some of the top edge of the
aluminum seat sides.
I have assembled it. except for the Fiberglas top. It looks like all the
weight
or Fiberglas separating? No. It seems reasonably strong to me, for an
aircraft component. It's not as strong as my Chevy truck seats, but it
works.
Bryan Jones -8 765BJ ~55-hrs
Pearland, Texas
Sent: Monday, November 27, 2000 9:11 PM
Subject: RV-List: Rv-8 backseat
Hi
Thank You,
Ed Perry
RV8QB/180CS
Subject: | Fw: Rv-8 backseat |
I have not seen this message posted so it here it is again. Sorry if you
already received it.
Date: Monday, November 27, 2000 7:11 PM
Subject: Rv-8 backseat
>Hi
Did
>Thank You,
>Ed Perry
>RV8QB/180CS
Subject: | Re: Battery Terminal Choices |
Listers:
I have finally decided which battery to buy and am ready to track it
down:
Panasonic LC-X1220P OR AP
20 Ah
7.16 in X 2.99 in X 6.58 in
It comes in either a Bolt and Nut or a threaded Post. My first thought
would be a bolt and Nut as it could be torqued and left alone. The
threaded post might have a problem with stripping. Any comments from
list about this particular battery or the choice of terminal types.
I have an airflow performance fuel injection and the boost pump takes up
al least half of the space that the battery should go in, thus the
smaller battery. Also, notice that Van's is really going through the
e-business nightmare, Web site down, server hardrive lost, questionable
backup. Hope all gets fixed fast.
Dave Aronson
RV4 N504RV
N188sm(at)cs.com wrote:
> Snap on sell them. They are great for removing screws then the heads get bad.
> Stan Mehrhoff
> RV-8 ready for inspection
Subject: | Battery Terminal Choices |
Listers:
Sorry about the last post. Forgot to erase previous message. Do not
archive.
DCA
Subject: | RV-4 tailwheel spring misalignment |
For those who might be interested, here's Van's (Ken really) answer:
"Go ahead and taxi test it. If you notice some tracking problems you have
two options:
1. Remove the tail wheel spring and try to shorten it. Note that this
will require a lathe to turn the end of the spring back down to a thickness
that will fit the tail wheel sleeve.
2. Deconstruct the aft end of the airplane to remove the mount and make
whatever corrections are necessary to straighten the tail wheel spring
assembly.
More than likely it will track just fine and the only problem you will
encounter is uneven tail wheel wear."
Scott VanArtsdalen, MCSE, CCNA
Network Administrator
Union Safe Deposit Bank
209-946-5116
From: Van Artsdalen, Scott [mailto:svanarts(at)unionsafe.com]
Sent: Monday, November 27, 2000 9:09 AM
To: Rv-List (E-mail)
Subject: RV-List: RV-4 tailwheel spring misalignment
I've already emailed Van's about this problem but I thought
I would invite
the few, the proud, the exceedingly opinionated, the members
of the RV-List
to weigh in.
My RV-4 project is up to the point where it's on it's main
gear and the tail
feathers are attached and functional. A fellow RV-4 builder
came over this
weekend to see what I was up to. It's always a good idea to
have another
set of eyes look things over. Well, I'm glad he came over
because he
spotted a major problem that I had not noticed.
My tailwheel spring is canted to the left by about .5 to .75
inches at the
tailwheel. It doesn't sound like much but it is noticable
when you sight
down the centerline of the airplane. I have some thoughts
as to how to fix
it but I don't want to bias anyone. So please, opnions,
suggestions,
answers?
I'll buy lunch for the person that comes up with the
simplest yet safest
solution! If you're not in the California Central Valley
you'll have to
wait until the plane is flying... :-)
209-946-5116
Subject: | 12V Power Sources |
RadioShack.com has 12V (13.8V) power supplies on sale right now.
Go to www.radioshack.com
click on Test and Measurement, click on Power Supplies. On the second page
are 5 to 7 amp supplies for $24 to $33.
this is the link, but it is so long you may have trouble copying and pasting
to your browser.
http://www.radioshack.com/category.asp?catalog%5Fname=CTLG&category%5Fname=C
TLG%5F008%5F001%5F000%5F000&Page=2
Dave Biddle
RV6A wiring and more wiring
If I'm not mistaken, Electric Bob makes and sell them. Try him.
Cecil
writes:
> > Hi Glen,
> didn't
> willing to pay
> > Dennis Thomas
> > RV-9A Emp
> precise a
> cleanest form of
> input on how to
> -Glenn
Cecil Hatfield
RV6A
I had tried Avery and Air Craft Spruce. Now that I see the number of
people that thought I was spoofing them, I suspect the ladies at both
places may have thought the same. If I had asked to talk to Bob Avery for
example, I may have got a different reply. I should have dug deeper I
guess.
Cecil
writes:
> multiple
> tool houses
> tools.
> Look in your
> that make
> south-paw
> drills.
> Randy Griffin
> RV-8
> Vancouver, Wa.
> #80925
> N925RG (reserved)
> Fuse
> cecilth(at)juno.com
> Averys
> Cecil Hatfield
> RV6A
Cecil Hatfield
RV6A
I've been sitting here laughing at all the replys I got, the funny ones
anyway. You mentioned
plasma arc machine. I used one of those about 40 years ago at Hughes
Aircraft in Culiver City.
That machine was a god send, neat and clean as I remember it. Hmmm wonder
if its around
at a good price now many years later.
Anyway thanks to all the good replys and also to the ones who didn't know
left hand drills existed too, for they
made me laugh.
Cecil
writes:
> Cecil,
> drill
> work!!
> - 1/2
> high
> bit
> cut
> smaller
> drill.
> about
> Outs are
> arc
> if
> Cornwall &
> Van
> your
> one?
> learned
> hands"
> oversize
> insert.
> make
> Charlie Kuss
> Averys
Cecil Hatfield
RV6A
Subject: | Re: RV-4 tailwheel spring misalignment |
In a message dated 11/27/00 11:11:02 AM Central Standard Time,
svanarts(at)unionsafe.com writes:
> >> My tailwheel spring is canted to the left by about .5 to .75 inches at the
> tailwheel. <<
> I've had a similar situation on my RV-4 since 1989, however not as marked
> degree of cant. The only noticeable effect has been uneven wear on the
> tailwheel. At annual I simply reverse the tailwheel and this pretty much
> evens the wear out. No ground handling quirks.
Threaded posts are the "norm" for aircraft batteries.
Curious about why you settled on that particular battery, over, say, the
Odyssey. Is that the same technology (absorbed electrolyte) or NI-CAD or
what? Details?
Randall Henderson, RV-6 N6R (~175 hrs)
Portland, OR
http://www.edt.com/homewing
Sent: Tuesday, November 28, 2000 7:25 AM
Subject: Re: RV-List: Battery Terminal Choices
> Listers:
> down:
> 20 Ah
> Dave Aronson
> RV4 N504RV
get bad.
> > Stan Mehrhoff
Subject: | Time is short........ |
If you are reading this post and you still haven't made your contribution
to the RV-List Fundraiser I have one question for you.......WHAT ARE YOU
WAITING FOR?
In the early days of this Fundraiser someone requested that these pleas be
made only a couple of times a week. I tried that approach to see if it
would help. Well I have news for you, It doesn't! We have more people on
this list than ever who have not made any contribution. If you are thinking
that if you don't post anything so you don't need to contribute, please
think again. Just reading the list is entertainment enough for you to make
a contribution. If you use the archives you really need to consider making
that contribution. You are using a valuable resource and not paying your
fair share. I'm sure you don't want to be doing that.
Now please, take the time and use one the methods described below to make
your contribution, you will feel better for it. Al
Subject: | Re: Time is short........ |
Beware!!!!!!!!
I sent my contribution in yesterday. Didn't look at the check boxes close
enough. Checked the Pitts list instead of the RV list as they are adjacent
to each other.
Cash Copeland
QB #60075
RV6 N46FC (Reserved)
Oakland, Ca
In a message dated 11/28/00 10:37:41 AM Pacific Standard Time,
prober(at)iwaynet.net writes:
WAITING FOR?
Any comments on the best source for a certified O360 engine for my RV8. I know
Vans has some good prices but what about remanufactured or rebuilt? Such as
Mattituck engines?
Gary Rush
RV8
From: | "Bill Shook" <billshook(at)mindspring.com> |
Oh for Gods sake. You live in West Palm don't you? Was it a butterfly
ballot or something? I WANT A RECOUNT!
Just kidding
Elephant in Orlando
> Beware!!!!!!!!
adjacent
> to each other.
Bart Lalonde (Aero Sport Power) Also has a certified shop for remans or
overhauls...he's in the yeller pages...
Paul Besing
RV-6A (197AB) Arizona
http://www.lacodeworks.com/besing/
Finish Kit
Sent: Tuesday, November 28, 2000 12:30 PM
Subject: RV-List: 0360 Engine
know
as
> Mattituck engines?
> Thanks,
> Gary Rush
> RV8
"Re: RV-List: Time is short........" (Nov 28, 12:56pm)
Don't worry. The "which lists are you on" check boxes are just for
statistics. They're for me to get an idea of which Lists are contributing.
As Al pointed out, time is running out to make it on the official
"A List" due to be published on December 1st! Won't you take a moment
to make your Contribution today to support all of these valuable
services?
SSL Secure Web: http://www.matronics.com/contributoin
USMail: Matronics
c/o Matt Dralle
PO Box 347
Livermore CA 94551
Thanks to everyone that has made a contribution so far!
Matt
>Beware!!!!!!!!
>to each other.
>Cash Copeland
>QB #60075
>Oakland, Ca
> WAITING FOR?
Great minds discuss ideas,
Average minds discuss events,
Small minds discuss people...
11/28/2000 05:05:02 PM
Usually there is a core value needed to be added to any quotes from any
named "certified" overhauler. By the time you add the core charge to the
overhaul charge(with shipping) and accessories you are darn close( or over
) Vans OEM price for his 0-360.
Unless you have access to below market cores or running engines and do a
partial overhaul,...... again you are hard pressed to get a engine that is
"certified" for much less. There are many GOOD overhaulers that don't offer
"certified" overhauls that will save you thousands. These overhaulers
usually take off the engine data plate and leave it in the log book for you
do with (whatever).
Lots of guys go this route. Check the yeller pages, there are a handfull of
these engine builders there....good luck.....
Gary Rush (at)matronics.com on 11/28/2000 02:30:53 PM
Sent by: owner-rv-list-server(at)matronics.com
cc:
know
as
Mattituck engines?
Gary Rush
RV8
Subject: | Converting a 6A to a 6 |
Folks, I have a friend who is not on the list so I am asking the following
questions on his behalf. I will forward any responses on to him.
Question #1 - What parts are necessary to convert a 6A to a 6? The obvious
parts are the engine mount, gear legs, tailwheel assembly and mount, and the
rear bulkhead but I am sure there are more.
Are there any gueses as to the cost of these parts? (hey...that was two
qestions!)
Question #2 - Has anyone out there done this and, if so, how hard/easy was
it? I imagine getting that rear bulkhead in place is no walk in the park.
Question #3 - I searched the archives but came up with nothing but I thought
I read a post about a gentleman who had all of the parts necessary to do such
a conversion. Does anyone know who this was?
Thanks in advance for any insight to any of my 3 questions.
PS. If you want to reply to me please use the following e-mail address
(Nowakod(at)us.ibm.com)
Don Nowakowski
RV-6 FWF and Panel, N-513DN reserved
>RV8. I know
>Mattituck engines?
>Thanks,
>Gary Rush
>RV8
Well, many listers have been very happy with Bart Lalonde. He sells
engines for experimentals thru AeroSport Power. I think he could
sell you a certified engine too, if you wanted to pay the extra cash,
as I believe he also owns a shop that overhauls engines for type
certified aircraft. I suspect he uses the same people, equipment and
attention to detail for both operations, but he could tell you for
sure.
Contact Bart at (250) 376-2955.
Take care,
Ottawa, Canada
I think Electric Bob is gone. After the beating he took from the list over
"security" I wouldn't blame him.
Dave
> > Hi Glen,
> > Dennis Thomas
> > RV-9A Emp
a
of
to
> -Glenn
Subject: | Re: Van's panel dimmer |
From: | Scott R McDaniels <smcdaniels(at)juno.com> |
Subject: RV-List: Van's panel dimmer problem solved
11/25/2000 09:09:37 PM
All,
A few weeks back I wrote about a problem that I had with the Van's stock
panel dimmer ( ES DIMMER, LAMP 1.5A ). I installed per the directions
only
to find that when I keyed my com transmitter all the lights in the
cockpit
that were hooked up to the dimmer would go out. Clearly RF was getting
into my little dimmer. A little research and some helpful direction from
the list and I was able to solve the problem.
My dimmer circuit board actually had the layout for adding two capacitors
but the holes were empty. A schematic was actually available on page 222
of "18 Years of the RV ator". Unfortunately the values suggested in this
drawing are wrong. The capacitor value needed for the one that's
attached
to the LM317 actually needs to be 0.001 micro farad at 25 volts and not
0.1
as suggested.
I will put the details and pictures on my site tomorrow. The fix works
like a champ. The lights don't even flicker now.
- Jim Andrews
RV-8A ( cowling and more... )
O-360 A1A Sensenich 85
N89JA reserved
Just to let everyone on the list know.
The dimmer has never come with the capacitors installed (even though
there is a place for them on the ckt. board.
They usually are not needed (all of the airplanes at Vans are flying with
this circuit with out the caps and there is know ill effects).
If your particular installation needs them then they can be added.
Unfortunately this wasn't in the documentation provided with the unit but
I believe that is being corrected.
Scott McDaniels
North Plains, OR
These opinions and ideas are my own and may not
reflect the opinions or ideas of my employer.
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
I've already emailed Van's about this problem but I thought I would
invite
the few, the proud, the exceedingly opinionated, the members of the
RV-List
to weigh in.
My RV-4 project is up to the point where it's on it's main gear and the
tail
feathers are attached and functional. A fellow RV-4 builder came over
this
weekend to see what I was up to. It's always a good idea to have another
set of eyes look things over. Well, I'm glad he came over because he
the
tailwheel. It doesn't sound like much but it is noticable when you sight
down the centerline of the airplane. I have some thoughts as to how to
fix
it but I don't want to bias anyone. So please, opnions, suggestions,
answers?
I'll buy lunch for the person that comes up with the simplest yet safest
solution! If you're not in the California Central Valley you'll have to
209-946-5116
Assuming you don't already have one... I would suggest that you install
the retrofit full swivel tail wheel assy. This requires cutting off the
bent portion of the leg, machining the end to except the new assy., and
then drilling the new assy to the leg. This would allow orientating the
clocking of the new one to what ever you want.
Scott McDaniels
North Plains, OR
Subject: | Re: Rv-8 backseat |
Mr Condon,
Do you have any photos of the setup you describe?
Charlie Kuss
pcondon(at)csc.com wrote:
> Vans has a "AD" or "service bulletin" on the RV-4 rear seat. It is simply a
> gusset support on the main longron ( L & R) that supports the rear seat
> back. I added the same fix to the RV-8 fuse. I am building. On my -4, I
> have a small cable slightly drooping from the gussets on the left and
> right. If the seat back were to fail the occupant and seat back get
> stopped by the safety cable. Its a small diameter cable and hardly
> noticable unless you are in the baggage compartment yourself.......simple,
> quick & inexpensive fix.
Subject: | Re: Fairing the Tail Tie-Down Ring on RV's] |
Listers,
For those of you who were interested in seeing John Fasching's tie
down, tail ring fairing, go to the SE Florida RV Builders web site at:
http://www.eGroups.com/files/SEFlaRVbuilders/Aerodynamic+Modifications/John+Fasching%27s+tail+tie+down+fairing.jpg
Charlie Kuss
RV-8A endless inventorying of fuselage parts
Boca Raton, Fl.
My decision to get a new engine from Van was based on much experience with
people's grief with "rebuilt" auto engines.
'Rebuilt' means whatever its seller wants it to mean. In the worst case I
saw the engine was simply patched up from a problem and repainted! The best
of rebuilts come from guys like Victor Aviation here in Palo Alto, CA (okay,
I haven't the $1,000,000 for a fixer upper in Palo Alto but live in nearby
Santa Clara). Victors prices are substantial but the quality is superior to
factory new. He does, for Palo Alto class customers I suppose, rebuild
factory new engines!
Factory new engines are sorta a known quantity while rebuilds may be a pig
in a poke. Unless it is top brand, you may be always wondering if it will
see you thru to the next airport.
Hal Kempthorne
RV6a N7HK
Waiting for FAA inspection!
Sent: Tuesday, November 28, 2000 11:30 AM
know
as
> Mattituck engines?
> Thanks,
> Gary Rush
> RV8
Subject: | Wrong size bushings on O-320 crank |
Listers,
I have a problem with the bushings on the crank flange of my O-320.
Van's sells a 2.25" prop extension which I have already purchased for the O-320
that accepts 7/16" prop bolts. However, my O-320 has
3/8" bushings. My wood prop is also drilled for 7/16" bolts.
Can I simply replace the 3/8" busings with 7/16" bushings?
If this is possible/safe how do I go about doing this?
Jeff Hawkins
Atlanta, Georgia
RV-8
Subject: | Re: Converting a 6A to a 6 |
This is new!! 6A to a 6? I was thinking about switching to a 6A, but
I've yet to start the Fus. I would think Vans would have a parts list
for that, they have one for 6 to 6A. I would bet it would be a MAJOR
undertaking if its already built. I'd check with Van's
Spokane
RV-6 Fuselage (I can hear it calling from the shipping crate)
Scott,
Just did my first night flying and had the same problem with Van's dimmer --- push
the XMIT button and the lights go out. When you update your web page with
the solution, please post the www address. I'd like to see the solution.
Clay Smith, RV-4, N9X, 50+ hours
Indiana
> ** Original Subject: Re: RV-List: Van's panel dimmer
> ** Original Sender: Scott R McDaniels
> ** Original Date: Tue, 28 Nov 2000 18:53:47 -0800
> ** Original Message follows...
> From: Jim_Andrews(at)tivoli.com
> All,
> only
> cockpit
> attached
> 0.1
> as suggested.
> - Jim Andrews
> N89JA reserved
> Scott McDaniels
> North Plains, OR
>** --------- End Original Message ----------- **
If the plane it built already, converting that tail is hard but you also
will have to remount the engine. I looked into adding the needed parts to my
tail when I constructed the Fuselage for my RV6A so that it could be
converted. Not much is needed. One could, I suppose, purchase an engine
mount with both the fittings for the nose gear for the RV6A and the main
gear for the RV6. Built originally as an RV6A and conversion later would be
easy was my thought. Going the other way is more difficult as the gear
mounts on the wing for the RV6A would be tricky to add later. In the end, I
decided once this is flying I'm not going to want to convert it. Builders I
have talked with say once you fly you won't want to work on it.
Marty in Brentwood, TN
Sent: Tuesday, November 28, 2000 10:09 PM
Subject: Re: RV-List: Converting a 6A to a 6
> Bill
> Spokane
As far as accurate machinist's levels are concerned, they are available in 8"
and 12" sizes for around $100. No, they are not made in the US but in Poland,
and the quality is fine. They are cast iron and very heavy. They are so
sensitive that they have plastic grip inserts so the heat from your fingers
doesn't distort the level. The distance between marks on the bubble
represents 0.0005" in 10". I have used mine extensively in setting up the
fuselage jig and elsewhere, setting it on an appropriately sized section of
rectangular aluminum screen enclosure tubing. (Available at Lowe's). If
dropped and knocked out of level, they are adjustable back to tolerance (ask
me how I know). A local machine tool supplier should have a source, or MSC
will have them. Andy Johnson, Boca Raton, FL, drilling fuse skins, in between
honeydo projects.
From: | "Douglas G. Murray" <dgmurray(at)telusplanet.net> |
Subject: | Re: Swivel -Tail Wheel -OOPS! |
Listers-
Those of you that have full swivel tailwheels sure could help me on this
one. I was installing the full swivel assembly on my RV-6 and between my
poor eyes and slow hands I managed to lose part of the locking pin assembly.
I have the main locking pin and a spring that fit together and assemble into
the square hole at the top of the spindle. When I install the spring into
the hole and then the square locking pin the whole assembly will go together
but it doesn't have the breakout tension that should be there. I 'think'
that there should be another spacer that goes in the square spindle hole but
I cannot see where it may have flown across my shop. Can anyone clue me in
on the assembly of this mechanism, and, if there is a spacer, what is the
size of it?
Thanks so much for your help.
Douglas G. Murray RV-6 - fumbling with the little details !!
Southern Alberta
Subject: | Re: Wrong size bushings on O-320 crank |
No problem, it is a relatively simple swap. The problem is getting the
parts.
There are three part#s required. As I recall there was one of them I had
to get used. Not cheap either. I believe I spent about 100.00 for all.Terry
No spacer. I think that you have not assembled the complete
wheel ass. the break out forces arenot determined by the spring.
put the belcrank on top and try it.Terry
I dont think it would be a big deal. The motor mount is easy.
The tricky part would be the weldment for tail spring. I think you
would need to unrivet the rear bulkhead. Not a huge job. I'd do it.Terry
Subject: | Contributions to the RV List |
Just think of the dollars you contribute like votes...every one counts. Don't
leave Matt short a few votes (dollars) for running the Lists just because you
didn't show up at the ballot box. And unlike the Presidential election, you
can submit as many votes as you want!!! What a deal!
And...on a more ominous note...if someone were running the Lists as a commercial
venture to really make some bucks, instead of a labor of love, how much do you
think they'd be charging? Or how much advertising to you think you'd be
seeing? In either/both cases, a LOT. I don't think we want that.
Semper Fi
The old ones will come out with the careful use of a hammer and you can pull the
new ones in using a bolt for a puller with sockets or a
sleeve for a spacer. I had this problem and Bart LaLonde had me use this procedure.
jah wrote:
> Listers,
> Thanks,
> Jeff Hawkins
> Atlanta, Georgia
> RV-8
Hi Cecil,
Contact me off-line & let me know what sizes you're looking for. You also
need to let me know if you're looking for a left hand cut & a right hand
flute, etc.
Blue Skies!
> Cecil Hatfield
> RV6A
Subject: | Horizontal Cowl Pins |
Hi,
I have come up with a pretty slick way of securing the horizontal cowl
pins. I would post them on my server, but the server is down. E-mail
me directly if you're interested, and I will be happy to send you the
pics. Please make sure you take the "rv-list" out of the subject so
that it will get past my mail filters.
-Glenn Gordon
Subject: | ADF in an RV panel |
During the "too cold to work in the garage" period's I've been working on
the designs for my instrument panel. I will be including VOR/GS/LOC as well
as approach certified GPS. That should be enough to get me through the IMC
that I might get stuck in. I am planning on getting my Instrument Rating
in my RV after it's flying if that matters.
Are any of you with flying and/or building RV's that are going to be using
ADF's?
Next, are any of you flying non-RV's and using ADF's?
During a discussion last night with some other builders - the topic of ADF's
came up. Here are some of the comments.
1. They're not fixing 'em when they break - they're just shutting 'em down.
2. It's nothing more than an AM radio that's unreliable for approaches - I
wouldn't depend on one.
3. In a few years they'll all be gone anyway - use the money for gas.
One of the magazines just published a real nice article on ADF approaches -
how easy they really are. I don't recall if they addressed how much longer
ADF transmitters (NDB's I think!) will remain around.
Maybe Das Fed can chime in here!
I'm kinda ahead of myself on this from two perspectives...I'm not instrument
rated and there's plenty of time before I need to commit to what's gonna be
staring me in the face. I'll listen to all opinions offered since there
isn't a book titled
"ADF's For Dummies"!
Ralph Capen
11/29/2000 09:03:18 AM
No digital photos, but Vans site has the servvice bulletin on the RV-4 on
their web site. I simply duplicated the mod for my RV-8. I then took some
small diameter cable and attached or "connected" these two gussets. The
cable slightly drooped while it connected the two gussets. I'll bet once
you see the service buletin fix vans has the cable mod will become clear.
Charlie Kuss (at)matronics.com on 11/28/2000 09:08:29
PM
cc:
Subject: Re: RV-List: Rv-8 backseat
Mr Condon,
Charlie Kuss
a
Terry -
IMHO converting to a tail wheel on a finished fuselage WOULD be a big deal.
On the RV6A there are only onepiece bulkheads at the last two bulkhead
locations in the fuselage. On the RV-6 there are two bulkheads back to back
at both locations. They serve both as an anchor for the HS straps and the
forward part of the tail wheel weldament. The last bulkhead is also doubled
up to anchor the rear of the weldament. I suppose that a VERY dertermined
builder could remove the aft deck and squeeze these bulkheads into location
but the weldament would present a major exersise in aerobics as the builder
attempts to drill the attaching bolt holes. Remember that the rudder rear
spar also attaches to the rear bulkheads and the tailwheel weldament. If I
were to pick the the worst bolts to work with on the entire project, it
would be these three.
The forward end of the conversion would be a very simple job as the mount
should slip into place without major effort, and, as a bonus there is more
space to work with as the nose gear weldaments are not there. The biggest
change up front would be to change the brake lines so they come through the
firewall.
Anyway that's my thoughts on that. I think that the conversion is possible
but the builder would severely test his/her patience on the tail end of the
project.
Douglas G. Murray
Southern Alberta
Sent: Tuesday, November 28, 2000 8:05 PM
Subject: | RV-8 Vent Location |
I sent the following email to Van's. I'm posting the question and answer here for
others and so that the archives will have it too.
QUESTION:
I would like to know if its ok to drill a hole in the aft side of the left landing
gear box ( F-802 ) for the plastic fresh air vent provided in the kit? I'm
thinking that this might be ok if I fabricated a doubler (.063) that would help
support the vent. I could then route the scat from the NASA vent through the
F-802C lighting holes to the vent in the aft side of the landing gear box.
ANSWER:
Jeff,
I received your e-mail question asking if it is okay to cut a hole in
your F-802B-L for mounting the air vent outlet; here are my
thoughts:
We drop tested the RV-8 fuselage and landing gear with only the
holes shown in the plans. The structure passed the drop test.
We did not drop test with the hole you described in your message.
We do not know if the structure with the hole would pass the drop
test. We are not planning to repeat the drop test to determine if the
structure would pass the drop test with the hole you described in
your message.
Basically, you are on your own...I know of an RV-8 that was built
with the hole in the landing gear box, and it was subsequently
crash landed into a soft field. The landing gear legs were almost
completely flattened-out due to the impact, but the fuselage
structure was un-damaged. The aircraft has been repaired and is
back flying again. Does this mean that the airplane with a hole in F-
802B-L would pass an FAR 23 drop test? We don't know.
Hope this helps,
Ken Krueger
Van's Aircraft Engineering
Subject: | Re: ADF in an RV panel |
Ralph,
I wouldn't worry about ADF's at all, especially since your going to use a
GPS. Save the panel space for a CD player or something. I currently fly for
a Regional Airline in Houston and guess what we did last year.....we threw
away all of our approach plates with ADF approaches...quit training aircrews
on ADF approaches...and took them out of our operations specifications. We
fly all over the US, Canada, and Mexico and even then all I use the ADF for
in the RJ is for additional situational awareness while flying an approach
that has a LOM. The only time I would consider adding an ADF is if you
planned on flying in an area, or country, that still used ADF as a primary
approach and hadn't yet established GPS overlays. Additionally, when taking
your Instrument checkride you can do the required non-precision approaches
with only a VOR (LOC and VOR approaches). As I remember an ADF doesent even
need to be in the aircraft....but as always check the FAA Inst Standards Book
as I still think ADF is still a knowledge item for the oral..etc..
Kurt, OKC, OK
RV6A/Finishing Kit
ATP/CFII/EMB120/ERJ145
I'm not an IFR expert only a lowly IFR rated pilot. Just about all the NDB
approaches are being replaced by GPS overlays. Unless there are some
specific NDB approaches that you plan on flying, I think you'd be better
served by leaving out the ADF, freeing up the panel space and saving
yourself one extra antenna installation. I will certainly not be putting one
in my IFR -6
If you like listening to AM radio in flight then it might be worthwhile
Mike Nellis - RV-6 N699BM (res)
Plainfield, IL
Skinning the Wings
http://mnellis.jnet.net/rv-6_page
> ADF's?
ADF's
down.
I
approaches -
longer
instrument
be
> isn't a book titled
> Thanks,
> Ralph Capen
Ralph:
There are two navaids that I think are destined for extinction, ADFs and
DMEs. About the only time you would need an ADF today would be if you
received a clearance such as, "Cleared for the ILS 9L approach, proceed
direct from your present position to the outer marker." In this case you
might have to execute the procedure turn, depending on the approach
procedure. However, 99% of the time you'll get a vector to intercept the
final approach course in which case you wouldn't need the ADF, just the
marker beacon receiver. If you are planning an IFR certified GPS, I
wouldn't worry about ADF or DME.
Pat Hatch
RV-4, N17PH @ VRB, 700 hours TT
O-320, Hartzell C/S
RV-6, Fuselage
O-360, Hartzell C/S
Sent: Wednesday, November 29, 2000 8:58 AM
Subject: RV-List: ADF in an RV panel
well
IMC
> ADF's?
ADF's
down.
I
approaches -
longer
instrument
be
> isn't a book titled
> Thanks,
> Ralph Capen
>ADF's?
If you have approach certified GPS and the other equipment you mention I
can think of only two possible reasons to have a space consuming,
expensive, ADF (How are you going to fit all that stuff?). For
additional redundancy and to be able to listen to the ballgame on AM
radio. Pretty slim reasons for such an investment.
It used to be that many smaller airports only had an NDB approach. Those
can normally be flown with an approach certified GPS now, and although
NDB approaches really aren't that hard, they are much easier with a GPS.
ADF can also help some with orientation during approaches and guide you
to the outer marker many places, but again, GPS does all that better.
Larry Pardue
Carlsbad, NM
RV-6 N441LP
Subject: | RV fiberglass seat back...throw away and make a metal one |
Listers,
I tossed out the fiberglass seat back that Van's provided in my 4 kit. It
fit about as well as a double AA bra on Dolly Parton and I was unconvinced
that it was strong enough for the task.
I made an all aluminum part in just a couple hours. The aluminum part's top
flange had 2 camlocs that latched the baggage compartment closed and made it
quite impossible for that rear seat to collapse into the baggage compartment
regardless of how much "Bubba" is in the back seat.
The new part was made from strips of aluminum, a crescent shaped strip, some
scrap angle, and some sheet aluminum. Sounds complicated but isn't. Use
the fiberglass part as a guide, get your snips, notch some angles to make
the curve (just like you do on the instrument panel), and soon you'll have a
PERFECTLY fitting part that is very strong.
Have fun,
Vince in Indiana
HRII under construction
With the discussion about IFR flying in RVs, I have a question. Isn't a heated
Pitot tube required in a plane certified for IFR flying? And if this is true,
does anyone have any experience with install a heated Pitot tube in an RV8?
Gary Rush
Carlsbad, CA
RV8 Fuselage
Gary,
I just received yesterday my 0-320.
From; Pro Aero Engines Inc.
2965 Airport Rd.
Kamloops BC. V2B 7W8
I had heard they had a good reputation and saved some money. Shipping to
Oregon was $165. plus $75. for custom paper work.
They might have changed their name. When I ordered I had called them Aero
Power Sports.
Do no archive.
Jerry Wilken RV6A
Subject: | Re: IFR questions |
Gary:
While not technically required by the regulations, a heated pitot tube is
certainly a good idea--depending on where you'll be doing your flying. If
you're never going to leave Florida, maybe you wouldn't need it.
In my case, I didn't put it in my RV-4 because although it is certified IFR,
I just didn't plan on doing any heavy IFR flying. However, in my RV-6 I'm
setting it up for solid IFR and have a heated pitot tube, but even so, I
obviously won't be able to fly into know icing conditions. Sorry can't help
you with the RV-8, but Warren Gretz (Yeller Pages) sells a nice setup. The
only criticism that I have on Warren's pitot tube is that is somewhat larger
than I expected, otherwise it is a quality product.
Pat Hatch
O-320, Hartzell C/S
RV-6, Fuselage
O-360, Hartzell C/S
Sent: Wednesday, November 29, 2000 11:23 AM
Subject: RV-List: IFR questions
heated
true,
RV8?
> Thanks,
> Gary Rush
> Carlsbad, CA
> RV8 Fuselage
Subject: | All Stirred up........ |
Well now I think we're getting things stirred up a little. Maybe some of
you non-contributors are starting to feel a little guilty. Well let me just
assure you, unlike the Ralph Nader voters in Florida, YOU can change your
mind and still make a contribution! Yes it will be okay. I promise that
Matt(e) won't let on who you are so you won't be singled out for
ridicule..................In fact, if you make your contribution today, you
will make the "A" list of contributors and no one will ever know how long
you held out unless you want them to know............Just go to:
Or send a check to: Matt Dralle
C/O Matronics
P.O. Box 347
Livermore, CA 94551
And be done with it........ come over to the good side.........be a player
in life's game of "right things to do"..........relieve you conscience of
that heavy burden of guilt.......
MAKE THAT CONTRIBUTION NOW!
Pitts List?????? I think I contributed to that one too.......can I have a
new ballot??? All you folks receiving "The rest of the story" you
should get "Who is Matt(e) Dralle (Part 6 and Part VII)"
today. AL (Look out for (Part Ate) soon!)
>heated
No, though it is probably a real good idea.
>And if this is
>true,
Even though it is not true, many people have experience installing a
heated tube. Gretz makes a nice kit for it and it is quite simple. See
archives.
Larry Pardue
Carlsbad, NM
RV-6 N441LP
I don't think so... I just took an IFR check ride in a plane that didn't
have pitot heat. This doesn't mean having it would be a bad idea, though.
Pearland, Texas
Sent: Wednesday, November 29, 2000 10:24 AM
heated
true,
Gary Rush
Carlsbad, CA
RV8 Fuselage
5.0.3 (Intl)|21 March 2000) at 11/29/2000 11:49:18 AM
Gary,
I know you didn't ask about rebuilding an O-360 yourself but if cost is an
issue, it's worth considering. I got an O360-A4A from Air Salvage of
Dallas a few months ago for $6500, it's a first-run engine taken off a
Cherokee 180 at 2000 TTSN. Lucky Louque at ASOD is a great guy and he
threw in an electric boost pump and complete vacuum system and an oil
cooler in addition to the accessories that already came with the engine
(Bendix mags, carb, alternator, engine driven fuel pump, etc). The only
problem with it was that after removal from the Cherokee, the engine sat
around for a while and has some rust. I need to replace or at least
refinish the cam and will probly chrome the jugs, but the crank is
serviceable as are the accessories. Get the Lycoming overhaul and parts
manuals and it's a pretty easy job....if you can build a fuselage kit you
can overhaul an engine. I don't expect to do all the work myself, I'll
probly have the entire top end sent out for overhaul but even at that, I
should have a reliable powerplant that will go 2000 hours for about $13K. A
good overhaul is just as good as a new engine IMHO...in fact maybe even
better in some ways. I have seen factory-new Lycomings throw rods or have
other mechanical catostrophic failures within their first 100 hours of
operation. In contrast I grew up flying with my dad over hostile terrain
(the Amazon in Brazil) behind overhauled engines....so far 26 years of
flying a C-206 with no problems (and that's a Continental, not a Lycoming).
Good maintenance and proper operation go farther than having "Lycoming" or
"Mattituck" stamped on the overhaul paperwork...
Just my 2 cents.
--Mark Navratil
Cedar Rapids, Iowa
RV-8A hanging flaps and ailerons, inventorying fuse parts, overhauling
O-360....whew!
know
as
Mattituck engines?
Gary Rush
RV8
Subject: | 0360 Engine New vs Rebuilt |
Just to add my two cents on the new - rebuilt engine topic here is my
experience.
I have an IO-360 B1B 180 HP from Aero Sport Power with just 100 hours on it.
I had Bart put the Bendix Injector and new Cylinders on the engine. With 100
Hours on it the engine has not had 1 single problem, it runs perfect the
paint is still on it and the chrome valve covers and intake tubes look new.
I good friend of mine finished his RV-4 about the same time and also has
around 100 hours on it. He purchased a new O-360 from Vans and the airflow
performance fuel injector. After about 50 hours one of the intake tubes was
leaking at the sump. The Lycoming rep came down from Seattle and re flared
the tube into the sump and bore scoped the cylinder. At this time the intake
tube is leaking again and he now needs to replace the sump, Lycoming is going
to pay for this. A lot of the paint on the engine has fallen off. I think
for the price that these engines cost they could figure out how to paint one.
The airflow performance unit drains fuel back into the air cleaner when it
shuts down.
The Bendix unit never leaks fuel anywhere, I have not had any hot start
problems, even in Redding, CA in 98 deg after a fuel stop.
Rob Hickman
RV-4 (Painting)
Subject: | Re: cht probe location |
Hey Scott,
How do you post a question to the RV list?
I want to ask how to install the cht probe that
goes under a spark plug. Does it go under,
above, or in lieu of the copper plug gasket?
Just thought it would be nice to bug you!
See ya,
Don
twofeathersrv6@aol
Ralph,
The NDB's are slowly being phased out. But they are starting with the ones
that are stand alone and not used as part of an approach. But seeing as how
you are planning on an IFR certified GPS I wouldn't bother with the ADF.
All the GPS databases show the location of the NDB's being used for the
final approach fix. In other words if you have a GPS you won't need the
ADF. Save your money for other goodies.
Mike Robertson
Das Fed
RV-8A N809RS
5.1 hours
>From: "Ralph E. Capen" <recapen(at)earthlink.net>
>To: "RV-LIST"
>Date: Wed, 29 Nov 2000 07:58:29 -0600
>well
>ADF's?
>ADF's
>instrument
>isn't a book titled
>Thanks,
>Ralph Capen
Gary,
We installed a heated Pitot Tube in our RV-8A but only because there is so
much moisture here in the air in Hawaii. But it is not required for IFR.
Only for flight into known icing conditions, which I don't think you want to
do in an RV.
Mike Robertson
RV-8A N809RS
5.1 hours
>From: Gary Rush <Gary.Rush(at)west.sun.com>
>Date: Wed, 29 Nov 2000 08:23:51 -0800 (PST)
>heated
>true,
>Thanks,
>Gary Rush
>Carlsbad, CA
>RV8 Fuselage
Subject: | Re: engine hanging party part deaux |
dear listers
well i feel confident it will get hung this time, weather permitting,
saturday 12,2,2000.
around 12:00. food will be bar-be- que or something cajun, and some good ole
fashion lie swapping. everyone is invited. aaaayyeeeeeeeee it don't get no
better than this.
ya'll come
scott
tampa rv6a hangin engine again.
I installed "H" 9 to 1 pistons in my 0320 A2B . They work good ( 400
hrs.) Be advised you cannot use auto gas with this setup.
For what it's worth, I bought my engine from AeroSport power for about $13K.
Downside is that it's not certified, and is an O-320 and not an O-360. Not
dis'ing you, Mark. Just throwing that out there for those who like me are a
little intimidated by doing the engine work.
209-946-5116
[mailto:menavrat(at)collins.rockwell.com]
Sent: Wednesday, November 29, 2000 9:43 AM
To: rv-list(at)matronics.com; Gary.Rush(at)west.sun.com
Subject: RV-List: O360 Engine
Gary,
if cost is an
Salvage of
taken off a
guy and he
and an oil
the engine
etc). The only
the engine sat
at least
crank is
overhaul and parts
fuselage kit you
myself, I'll
even at that, I
for about $13K. A
maybe even
throw rods or have
100 hours of
hostile terrain
26 years of
not a Lycoming).
"Lycoming" or
Just my 2 cents.
--Mark Navratil
Cedar Rapids, Iowa
overhauling
O-360....whew!
for my RV8. I
know
rebuilt? Such
as
Mattituck engines?
Gary Rush
RV8
From the FAA web site: http://www.faa.gov/avr/aai/M_1129_N.TXT
FYI
**** 11/29/2000 Preliminary Accident/Incident Data Record 2 ****
A. Type: I Mid Air: N Missing: N Entry date: 11/29/2000
B. Reg. No.: 319H M/M: EXP Desc: EXP-1999 RV-8
Activity: Pleasure Phase: Landing GA-A/C: General Aviation
Descr: EXPERIMENTAL ACFT WAS LANDING ON RWY 27R WHEN THE PILOT OBSERVED
A
COYOTE ON THE RWY, THE PILOT BRAKED, AND THE ACFT NOSED OVER ON
THE RWY, EL CAJON, CA.
WX: SPECI KSEE 281859Z 00000KT 30SM SKC 25/ A3002
Damage: Unknown
C2. Injury Data: # Crew: 1 Fat: 0 Ser: 0 Min: 0 Unk:
# Pass: 0 Fat: 0 Ser: 0 Min: 0 Unk:
# Grnd: Fat: 0 Ser: 0 Min: 0 Unk:
D. Location. City: EL CAJON State: CA Country: US
E. Event Date: 11/28/2000 Time: 1859
F. Invest Coverage. IIC: Reg/DO: WP09 DO City: SAN DIEGO
Dest: EL CAJON, CA Last Radio Cont: 2 MILE FINAL Flt Plan: UNK
Last Clearance: CLRD TO LAND WX Briefing: U
From: | "Randy J. Pflanzer" <rpflanze(at)iquest.net> |
Fellow Listers,
What is the procedure for correcting a sticking brake? My right brake will
stick for a minute or two after a hard application. I've got a few ideas on
how to fix it but thought I'd ask the List first before I go in and FUBAR.
Thanks.
Randy Pflanzer N417G
RV-6 Indianapolis (105 hours)
>Gary,
> 2965 Airport Rd.
>Power Sports.
>Jerry Wilken RV6A
Aero Sport Power is a division of Pro Aero Engines. Info at:
http://www.aerosportpower.com/
If you want a good engine for a homebuilt for good price, you talk to
the Aero Sport Power side of the company. If you want a good engine
for a type certified aircraft, you send more money, and you talk to
the Pro Aero Engines side.
Ottawa, Canada
Yep. Cleared to land doesn't mean that the runway's clear. I fly out of a
rural airport and have learned to look for dogs, coyotes, pheasants, geese,
and most importantly, deer, and cattle on the runway. It's bad enough
during the day but at night you'll never see them. Part of why I don't
really like to fly out of my home strip at night. I'll do it, but I'm
pretty nervous about it.
209-946-5116
-----Original Message-----
Sent: Wednesday, November 29, 2000 11:45 AM
To: rv-list(at)matronics.com; socal-rvlist(at)egroups.com
Subject: RV-List: RV-8 Incident
FYI
2 ****
PILOT OBSERVED
A
NOSED OVER ON
Damage: Unknown
0 Unk:
0 Unk:
0 Unk:
UNK
Why have an ADF when your GPS will fly the same approach?
> ADF's?
> isn't a book titled
> Thanks,
> Ralph Capen
Subject: | Re: Sticking Brakes |
Maybe you need to check the spring tension and pivot bolt tightness in the toe
paddle hinge areas...I found I had to make mine a little less precision and tad
more sloppier. Then the return spring pushed off fine...till then I had intermittent
brake tension due to non fluid release as the toe paddles wouldn't return
easily enough.
David McManmon
N58DM, RV6 0320H2AD.
90+ hours....but been weathered out 6+ weeks now...blahhhhhh I do not like NY now!!!
Subject: | Re: RV-8 Incident |
Uh, well reading this it doesn't look like the coyote caused the incident.
It looks more like the pilot screwed the pooch...or coyote if you prefer.
Fly the plane...kill the coyote if you have too (Darwin at work) but don't
nose your beautiful plane over to avoid a stray that would likely jump clear
anyway. Bet it was one of those moments when you do something and as you
are doing so there is a part of your brain yelling 'DON'T DO IT MAN' as the
tail starts to come up.........damn.
I hope noone was injured.
-4 wings
> >Record
> >2 ****
> >11/29/2000
> > From: WESTERN PACIFIC REGION OPERATIONS CENTER
Aviation
> >PILOT OBSERVED
> > A
> >NOSED OVER ON
> > Damage: Unknown
Min:
> >0 Unk:
Min:
> >0 Unk:
Min:
> >0 Unk:
> >DIEGO
> >Plan:
> >UNK
Bert...
Here is their web address: http://hometown.aol.com/enginfosys/index.htm
Their e-mail address: EngInfoSys(at)aol.com
Bill VonDane, Colorado Springs, CO
RV-8A, N8VD, Fuselage
http://vondane.com/rv8a/
Sent: Wednesday, November 29, 2000 4:39 PM
Subject: RV-List: add for eis
Hi:
does any one have the E-mail add. for Grand rapids
technologies.
It seems the one i got on their fax is not
correct.
thanks
bert
Hello again,
In my last posting I made a mistreak, I relied on my memory.
The name listed on the net is:
Progressive Air services ltd.
2965 Airport Rd.
Kamloops BC.
Ph-250-376-6226
Bart Lalonde's -Ph -250-376-2955
Now somewhere in this house is the estimate for the rebuild of my engine and
it has the exact name of Bart's operation Hmmm?
Sorry Bout That,
Jim, "I never make mistreaks" Jewell in Kelowna.
In a message dated 11/29/00 1:03:15 AM Eastern Standard Time,
rv6man(at)earthlink.net writes:
Correct, but I seem to remember that the rear bulkhead is doubled on the -6,
so you'l need to add the second one. Still, not a huge job.
Kyle Boatright - Kennesaw, GA
RV-6 Slider, O-320/Aymar-Demuth
Subject: | Re: Electric DG why not GPSS??? |
Ross,
I agree that you don't need a heading bug, and GPSS will work fine for
tracking GPS courses, but...
The problem with GPSS is that you are not getting a heading readout, you're
getting a track readout. If you are going to fly IFR (or even VFR flight
following) you have to be able to follow magnetic headings given to you by
ATC. These headings could be vectors for an ILS approach or for traffic
separation. Either way, ATC is going to expect you and all other aircraft
to fly a magnetic heading. You can see the chaos that would result if some
airplanes were flying GPS tracks and others magnetic headings. Maybe
someday the FAA will change their convention from headings to tracks?
Actually the advantage to flying tracks would be consistency, in that a
track would always look the same on a radar scope whereas headings would be
affected by the wind on a given day.
Hope this answers your question.
Pat Hatch
RV-4, N17PH @ VRB, 700 hrs. TT
O-320, Hartzell C/S
RV-6, Fuselage
pat_hatch(at)msn.com
----- Original Message -----
Sent: Monday, November 27, 2000 2:42 PM
Subject: Re: RV-List: Electric DG why not GPSS???
> Pat,
> I was just wondering why you have to have a heading bug? Why not just use
> the GPSS? http://www.s-tec.com/gpss.html
> Ross
> From: "pat_hatch" <pat_hatch(at)email.msn.com>
> > This has prompted me to go back and re-think my electrical system. I
> > have now decided to go with one B&C alternator and two 17-a.h. batteries
> > per Electric Bob's book--and go with the Sigma-Tek Gold Seal vacuum
> > pump, attitude indicator, and DG with the heading bug.
Randy - Check to see that the slide pins near the calipers are not
corroded or dirty. This may cause the caliper to 'cock' at an angle when
applying the brake and the brake will act as though it is still applied upon
release until a bit of vibration shakes the caliper loose.
Douglas G. Murray
Southern Alberta
Sent: Wednesday, November 29, 2000 12:40 PM
Subject: RV-List: Sticking Brakes
> Fellow Listers,
will
on
> Thanks.
Check current RVator (just got today)
There is a 6 motor mount with gear legs for sale.
From: | "Dave Berryhill" <dwberryhill(at)home.com> |
Subject: | Re: Have You Made Your Contribution Yet? 'A List' Due in Two |
Days!
Hi all! I'm a newbie to this list but I've already learned a lot from the
list and the archives so I'll pitch in. Who do I make the check out to?
Matrinics?
Dave Berryhill
> Hi Listers,
> Just a quick reminder that I will post the "A List" of this year's
> contributors in just a little over 2 days! I would like to thank
> everyone that has made a Contribution so far! I would also like to
> encourage those that have been putting off making their Contribution
> to the last minute, to hurry and surf over to the URL below or pop that
> check in the mail today!
FWIW, I was at Van's yesterday and brought my panel dimmer along with Jim
Andrews' post and the article and schematic out of 18 years of the RV-Ator.
I did not get the name of the gentleman that I talked to (it wasn't Scott or
Scott or Tom), but he said that it was designed my Bill Benedict and are now
being built by his widow. He said none of the dimmer kits have ever had the
capacitors, and no one has ever complained (until I came along that is). He
sort of rolled his eyes when I mentioned "the list". I pointed out the fact
that the original schematic had the capacitors called out, and the unit even
has the ports for them. He made copies of Jim's post and the article and
said he would mention this to Mrs. Benedict. I hadn't seen Scott McD's
post, so maybe he's gotten the word out to the tech guys at Van's.
Mike Robbins
RV8Q 80591 panel
Seattle area
> Scott,
dimmer --- push the XMIT button and the lights go out. When you update your
web page with the solution, please post the www address. I'd like to see
the solution.
> Indiana
with
but
> > Scott McDaniels
From: | "Daniel Estrada F." <dani_estrada(at)infosel.net.mx> |
Hi..!
I was looking on the archives but I could not find what I wanted....
Wich primer from all of this I'm listing is good for priming my empenage?:
(BTW all this primers are from Sherwin Williams)
WASH PRIMER (SPECIALTY COATING)
CM0484684
Primer 1 part
CM0120789
Reducer 1 part
Green
Vinyl Butyral
Excellent conversion primer. Promotes adhesion to clean, deoxidized aluminum
surfaces.
CORROSION PRIMERS
CM0483928
Primer 4 parts
CM0120828
Adduct
or
CM0120838
Special Adduct 1 part
Green
Epoxy
Chromated, low VOC, non-sanding primer for use over CM0484684 or conversion
coated surfaces. Outstanding primer on steel, aluminum, magnesium:
easy spray application
excellent flexibility
chemical and corrosion resistant
CM0724500
Primer 3 parts
CM0724501
Adduct 1 part
Yellow
Epoxy
Meets Mil-P-23377G, Type 1, Class C, composition and performance
specification. Similar to CM0483928.
SANDING SURFACER
CM0480920
Primer 4 parts
CM0120911
Adduct 1 part
White
Epoxy
Low VOC, fill/sanding primer that enhances depth of image on gloss finishes.
Use over corrosion primer. Light sand same day or heavier sanding with
overnight cure. Forms a tough film
Thanks for your help
Daniel Estrada F
RV6A Empenage
Mexico City
Subject: | Re: On rolling of the eyes at Van's-commentary |
In a message dated 11/29/00 9:33:50 PM Pacific Standard Time, kitfox(at)gte.net
writes:
<< He
sort of rolled his eyes when I mentioned "the list". >>
Great body language study. They roll their eyes now and they've shrugged
their shoulders before in response to some of the real issues that have been
raised over the years by "the list". Perhaps they are just weary of
listening to real people struggling in a somewhat democratic fashion to solve
real problems not of our own making. I know it must be irritating to hear
such nonsense.
Maybe a little strong but just a thought, I could be wrong.
-GV (RV-6A N1GV)
vanremog(at)aol.com
Subject: | Re: Panel dimmer |
Scott,
--- push the XMIT button and the lights go out. When you update your web
the solution.
Indiana
I didn't say that the info would be posted to the web site. I said that
it will be added to the instructions supplied with the dimmer unit.
The info that you need is in one of the previous posts of this thread
here on the RV-list.
Scott McDaniels
North Plains, OR
GET INTERNET ACCESS FROM JUNO!
Juno offers FREE or PREMIUM Internet access for less!
From: | "Stucklen, Frederic IFC" <stuckle(at)ifc.utc.com> |
Ralph,
I got my IFR rating in my RV-6A, and, at the time, was required to
demonstrate ADF approaches. (Currently, that's not the case.) I do have an
ADf (KX-86) in the panel, and shoot numerous approaches every year. I also
have a GX-55 Enroute certified GPS, that I use as a secondary backup to
every NDB approach.
My issue is the cost of maintaining an IFR data base in the GPS. With the
ADF, there is no associated maintenance cost, and if the GPS data base
doesn't get updated, I can still perform the approach, using the "VFR Only"
GPS for positional awareness only (Airports doesn't usually change their
locations...)
Learning to fly actual NDB approaches is a great way to hone the skills
that could someday save your butt when everything else fails. Sometimes it's
all to easy to rely on the easiest piece of gear to use (i.e., GPS).
While it is true that NDB's are not being replaced, there are still many
in service, especially in the tropics. Also, many ILS approaches require an
ADF (Kinston, NC, ISO). A certified GPS, with a CURRENT data base, is
required for any substitutions....
Fred Stucklen
N925RV (1670 hrs/7.5 Yrs)
E. Windsor, CT 06088
WK Email: stuckle(at)ifc.utc.com
Hm/Travel Email: wstucklen1(at)juno.com
____
working on
as well
the IMC
Rating
using
ADF's?
of ADF's
'em down.
approaches - I
gas.
approaches -
longer
instrument
gonna be
there
isn't a book titled
Ralph Capen
Hi Listers,
Does any one on list have information or able to tell me anything about
company in Florida building Lycoming engines for experimentals? Air-Tec Inc.
1339 W. Washington St. Orlando Fl.
Dennis Thomas RV-9a Emp
Subject: | Wires through the firewall |
11/30/2000 08:28:25 AM
All,
I need some advice regarding how folks are dealing with the ever increasing
number of wires that need to pass through the firewall. Particularly for
those of you who have engine monitors like the RMI and the VM1000. At last
count I have 15 large pair of sensor and primer wires that need to pass
through. Add to this grounding strap and starter contactor and were
talking about quite a bundle of wires. I currently have four one inch
holes filled with the standard 3/8 inch hole grommet / fire shield combo
but this just barely scratches the surface.
- Jim Andrews
RV-8A ( cowling and FWF )
O360 A1A Sensenich 85
N89JA reserved
http://www.homestead.com/RV8A/files/
Subject: | Wing skin order of installation |
Hello all...
I'm working on my -6 wings and was wanting to know the order of skin
installation most folks
do. The plans tell you to install the main skins first and the video
does the leading edge skin first.
Is there any advantage one way or the other? I have the pre-punched
type.
Gary Gunn
RV-6
5.0.3 (Intl)|21 March 2000) at 11/30/2000 09:40:21 AM
Scott,
No offense taken on my part. Some people don't want to mess with engine
work, or don't want to spend the extra time it takes to do it yourself. My
comment is simply that it's not very difficult....lots of folks are
needlessly intimidated (IMHO) by engine work primarily because it is viewed
as a critical and mysterious mechanical wonder, the type of thing only
A&P's or repair stations should work on. In reality the Lycoming is a very
simple piece of machinery and the overhaul/parts manuals are pretty good.
I'm only saying that if you wanted more power for less money and were
willing to spend the TIME to do it, you could do a quality, safe overhaul
the same way you are building the airframe. A really big and important
side benefit to this is that you will also know how to work on it when
doing routine maintenance once you are flying. Since you are, afterall,
the mechanic for your airplane. The more you know about your engine the
better.
In my case I wanted the O-360 so I am willing to do the extra work to get
it for the same price as the O-320 from AeroSport Power. I have a friend
building an -8 who did the same thing you did (O-320 from AeroSport for
$13K) and he'll be out flying while I'm still building. But I wanted the
-360 for its extra 20 horses, ability to use the f.p. metal Sensenich
without the 2600 rmp limitation, and ability to burn 91 octane in it and
still make rated power. I think some O-320's can burn 91 octane without
putting the low compression pistons in it (and taking the subsequent loss
of 10 hp) but I'm not sure about this.
--Mark Navratil
Cedar Rapids, Iowa
RV-8A hanging flaps....trying to get it to line up...
Subject: RE: RV-List: O360 Engine
$13K.
a
209-946-5116
From: | "Ernest Kells" <ernest.kells(at)sympatico.ca> |
Subject: | Prince P-Tip Propellers |
Does anyone have experience flying a Prince P-Tip prop? The archives are
not much help. Posts seem to confuse these with pure composite or pure
carbon fiber props, some of which appear to have a very poor history.
Prince P-Tip is described on P.166 of the Aircraft Spruce catalogue. It has
a hard maple core sheathed with composite and a leading edge protector.
Seems like the best of both worlds - I really prefer wood and the P-Tip
surfaces are better protected. For me, safety overrides all considerations.
I will closely follow other experience with the RV-9A with O-235 as
experince is gained. I am currently leaning toward Sensenich (wood or
metal), or Amar-Demuth.
Ernest Kells
RV-9A - Building Wings, Planning: O-235 Wood Prop
Sault Ste. Marie, Ontario
Subject: | Re: Wing skin order of installation |
Gary,
I'm pretty much at the same stage as you. I went with the video's order,
and here's why:
The leading edge and tank skins need to be positioned to a line 1" aft of
the leading edge of the spar web. Theoretically, at this point they will be
good and tight against the ribs. But as you drill the skin to the ribs, you
may end up crossing that 1" line by a little bit. If the main skins were
already positioned and you overlapped them with the LE skin, you will need
to trim. I reasoned that my rudimentary trimming skills would make for a
less than beautiful seam between the two skins. However, once the LE and
tank skins are on, the flat main skins can butt up against them with no
worries. Any overage can be trimmed off the trailing edge where an uneven
line will be less noticeable.
This procedure has been done both ways with success, I just feel more
comfortable doing it this way.
Good luck.
Jim Bower
St. Louis, MO
RV-6A
Wings
>From: Gary Gunn <ggunn(at)uswest.net>
>Subject: RV-List: Wing skin order of installation
>Date: Thu, 30 Nov 2000 08:30:54 -0700
>Hello all...
>type.
>Thanks,
>Gary Gunn
>RV-6
Subject: | Wires around the firewall Was: Wires through the firewall |
This is one area where I'm glad I'm building a -4. We have those sexy cheek
cowls that lets us bring things like wires and stuff out the side of the
airplane instead of through the firewall. Speaking of which, have any RV4
builders routed their wires this way? Through the cheek cowls I mean. I've
also heard of builder routing throttle, mixture, and carb heat control
cables this way too. Anyone ever done that? How did you do it? Just
curious.
209-946-5116
[mailto:Jim_Andrews(at)tivoli.com]
Sent: Thursday, November 30, 2000 6:29 AM
To: rv-list(at)matronics.com; rv8list(at)egroups.com
Subject: RV-List: Wires through the firewall
All,
ever increasing
Particularly for
VM1000. At last
need to pass
and were
four one inch
shield combo
- Jim Andrews
N89JA reserved
Subject: | The Looming Avgas Crisis |
Listers:
The attached is a good article on avgas availability.
MAINTENANCE MATTERS <http://www.avweb.com/toc/maint.html>
The vast majority of the U.S. general aviation fleet burns gasoline.
Yet the supply of avgas is by no means assured: Its widespread
availability hinges on the supply of additives and the outcome of
challenges by environmentalists, among other factors. AVweb
contributor Paul Merritt takes a look at what's going on in the
industry and evaluates the issues and the alternatives.
Ernest Kells
Subject: | Re: Wires through the firewall |
From: Jim_Andrews(at)tivoli.com <Jim_Andrews(at)tivoli.com>
Date: Thursday, November 30, 2000 8:31 AM
>All,
>Thanks,
>- Jim Andrews
>N89JA reserved
Jim,
I suspect you may have an inappropriate choice of firewall shields and/or
grommets. I think the Van's SSFS-1 1/4X3/4H shield and an MS35489-22
grommet should give you a 7/16 hole for the wires. The grommet is the tough
part -- you have to find one with a big enough inner hole. You may in fact
do better at ACE hardware than Wicks.
When you install the VM1000 do spring for the extra set of terminals as they
recommend to simplify future maintenance. Its a shame that Vision Micro
doesn't just add $75 or so to the price of the unit and include them. Their
maintenance tech suggested this tip to me and it sure makes the wiring
easier!
Dennis Persyk 6A N600DP O360A1A/Hartzell 16 Hours
Hampshire, IL C38
Hi Gary,
I installed the leading edge and tank skins first and then the main skins.
This allowed me to butt the main skins up against the leading edge and tank
skins before drilling and created a nice tight seam line where they meet. It
works great and no trimming of the skins was necessary. BTW I also have the
pre-punched skins.
Happy Building,
Eric Newton Long Beach, MS,
RV-6A N57ME (reserved) (Fuselage)
Eric's RV-6A
Construction Page
In a message dated 11/30/00 9:42:19 AM Central Standard Time,
ggunn(at)uswest.net writes:
<< I'm working on my -6 wings and was wanting to know the order of skin
does the leading edge skin first. >>
Subject: | Last Call............ |
Well today is the last day for you to make your List contribution in November.
Unfortunately I think that we have fallen short of past years donations. I
have a challenge for all of those who didn't think they needed to make a
contribution. With the exception of some old timers who have contributed
both knowledge and money in the past and who maybe don't have a need to be
on the list anymore and are pretty much just lurking for whatever reason,
why would the rest of you think that you don't need to make a contribution?
Why do you subscribe to the list and basically say it's worthless by your
actions? I mean please tell the rest of us by what yardstick you measure
value? Do you subscribe to any aviation magazines? Do you belong to any
aviation organizations? Don't you pay for those publications and
memberships with associated publications? Do they make available to you
nearly instantaneous responses to your questions? Are they as knowledgeable
about RV aircraft as the people on this list are? What is your value
system? Curious minds (and contributors) want to know. I don't mean to
make you feel bad about yourself (yes I do!) but what are you thinking? I
have come to the conclusion that most if not all the people who haven't
made any contribution at all just delete these pleas without even opening
them because they know I'm right and it's hard to face the truth. So if
your reading this right now I want to take this opportunity to personally
thank you for making your contribution because you probably made one and if
your one of the two or three who haven't made a contribution yet and still
have the guts to read this, please make your contribution
today.......Thanks........Al
--- Gary Gunn wrote:
> Hello all...
> type.
I recommend putting on the leading edges and tanks, then butting the
main skins tho them, take off excess (if necessary) from the rear of
the mains.
Worked for me...
Mike Thompson
Austin, TX
-6 N140RV (Reserved)
Canopy
From: | "Greg Richardson" <kpd_307(at)hotmail.com> |
Daniel,
I plan to use Dupont VeriPrime for my entire plane. It requires little
surface prep (wash with soap and water, vinegar and water, followed by 90%
rubbing alcohol) and is a two part self etching primer. It's drawback is
that it is corrosive to the lungs, and you should plan on wearing a
respirator/ organic filter mask while spraying (a $15 part from any home
improvement store that you should be wearing anyway). I have spoken with
several auto body techs that swear by it, and one that specifically sprayed
his entire boat with it to stop corrosion. Veriprime is listed as a
suitable primer by Van's and is mixed 1:1, stopping those hard calculations
while the paint dries.
Good Luck.
Greg Richardson
Kokomo, IN RV-9A (priming empennage for assy)
Hi Gary,
I'm getting ready to head to the basement to finish up fitting and drilling
my second set of skins and I've got pictures to prove it!
On the first wing I fit and drilled the skins in the following order because
that how Vans recommended it.
Top outboard
Top inboard
bottom outboard
bottom inboard
leading edge - Starting with the top side first
I experienced about 1/4" overlap of the bottom skin and the bottom part of
the leading edge skin which the manual says is normal and needs to be
trimmed up. In my mind, the important things to keep lined up are the
inboard and outboard skin lines on the main spar. I was thinking of
installing the top skins first then the leading edge skins then the bottom
skins and not worrying about the 1" distance on the on the bottom flange of
the main spar. The problem with doing it this way is that the tank skins
might not have the same amount of "wrap around" and might not line up with
the bottom. I'll probably finish up the second skin in the same sequence as
the first (per the plans).
Because of the pre punching, I've found the sequence of assembly on the
videos to be quite a bit different than what's recommended by Vans and I've
been following the construction manual as far as sequence goes.
You can see the sequence of events of evens that I used here along with some
associated problems.
http://mnellis.jnet.net/rv-6_page/
Plainfield, IL
Skinning the Wings
> Hello all...
> type.
> Thanks,
> Gary Gunn
> RV-6
increasing
last
> Thanks,
> - Jim Andrews
Jim,
I'm using mostly Electronics International guages, but have all the same
wires and connections to deal with. I don't have any primer wires or tubes,
but I do have several wires and a computer cable for my Lasar system. So far
I have made four firewall penetrations for wiring (two on each side) with
the same hole size and grommet/shields you describe. One of those is taken
up with the battery hot wire (my battery is behind the firewall in the
bottom of the right fwd baggage hold, can be seen at
www.rv-8.com/pgElectrical.htm). So far it looks like I will be able to get
them all through the remaining three holes.
I think you want those holes to be packed tightly with wires so there is
less air space to seal with the ubiquitous hi-temp RTV. I have split my
grommets so that I can wrap the grommet around the wires and fit many more
through each hole thus creating a tightly packed bundle. Result: fewer
firewall penetrations and a tighter seal in each one that you do make.
Once I finish painting I'll do my final wiring and will be able to tell you
how many penetrations were needed in the final analysis. Until then however
I really think I can get the job done with three plus the battery cable.
Randy Lervold
RV-8, #80500, painting
www.rv-8.com
Home Wing VAF
Jim, I'll be starting to drill the second skin just as soon as this message
is sent.
The problem I see with doing it the way you suggest is that you are assuming
that both the LE skin and the tank skin will overlap the same amount. If
they do not, then you will not have a straight butt line from the outboard
side to the inboard side. If you force them to line up without trimming,
then you are taking the risk that the LE skin will not be flat against the
ribs. I was thinking about ignoring the 1" line on the bottom skins but
decided that I wanted to ensure that there was a straight line when the
skins butt against each other. By doing the top and bottom main skins
first, I can at least ensure that the LE skin is butting tight against the
top main skin and I can trim the bottom where it will not be so visible.
People that are looking under the wing are more apt to notice that the seam
line is not straight before they notice if the trimming is a little of.
My opinion only of course.
> Gary,
> and here's why:
be
you
> Good luck.
> Jim Bower
> St. Louis, MO
> RV-6A
> Wings
> >Hello all...
> >type.
> >Thanks,
> >Gary Gunn
> >RV-6
From: | "Bill Shook" <billshook(at)mindspring.com> |
Anyone know Craig Chipley? He sold me the wings I have (partially done) and
he has some parts he said he was going to send. Now, I can't get a response
from him. Any help would be appreciated. He was in Memphis, now I believe
he's in St. Louis....but don't know for sure. He sent me two emails saying
he would send me the parts right away...but no joy so far and that was
several months ago. Now I NEED them to finish up the wings.
-4 wings
FWIW,
Sterling Primer U1201 is a two part primer that provides corrosion protection
without being top coated.
Gary
RV8
> From: "Greg Richardson" <kpd_307(at)hotmail.com>
> Subject: Re: RV-List: PRIMERS....
> Date: Thu, 30 Nov 2000 17:17:08
> Daniel,
> Good Luck.
> Greg Richardson
11/30/2000 12:31:29 PM
Interesting technique. I thought about this approach but I was concerned
about the sharp little edges of the fireshelds cutting into the wires. How
did you overcome this since they have a fixed 1/2 inch diameter that is
almost the same size as the hole in the grommet when stretched?
- Jim Andrews
N89JA reserved
Subject: | RV-8 Incident - Critters on the RWY |
I've just started flying my RV at night, so of course all the old salts have
been offering me free advice. Some of which is worth what I've paid for it,
and some of which is INVALUABLE. I fly out of Chester CT, 3B9. A well kept,
but small airport. In the evenings, particularly in the winter it can go
hours between any takeoffs or landings. One guy suggested that when ariving
in the evening that I make a low pass over the runway before landing. He
said it would allow me to inspect the RWY and would also most likely scare
away any Deer that may be loitering on the runway or around its edges. Just
a thought.
Don Mei
N92CT RV-4
From: | "Bezinque, David" <David_Bezinque(at)MAXTOR.COM> |
Subject: | RV6 slider track fairing |
How do you bend the slider track fairing? I have tried using a small bending
brake, but the bends are too close together to fit in the brake. Is there a
better way?
Dave Bezinque
RV6 QB S/N3499
Subject: | Re: RV-List Digest: 58 Msgs - 11/29/00 |
Please change my e-mail address: old:
Reason, new computer....
TKS,
Larry Rush
Subject: | Re: Last Call............ |
Al,
Rather than the constantly degrading those that have not contributed and
acting like a victim, why don't you just change the system? If it's that
important than design the subscription as a fee based service up front. I
personally use a lot of information on the internet without paying AND I pay
for services that I value as well.
You shouldn't condemn people for using a free service if it's presented as
such. In a nutshell - Quit whining and do whatever needs to be done to keep
the list alive.....
Bob Waalkes
RV-8 Emp.
Sent: Thursday, November 30, 2000 11:00 AM
Subject: RV-List: Last Call............
November.
I
contribution?
knowledgeable
if
I would also like to add that I belong to a couple other internet lists just
like this one, with fewer problems, less argumentative posters (typical
pilot egos I guess) and they are also free. They utilize sponsors on the
websites as well as classified areas etc. Check them out if you'd like.
http://www.rennlist.org/ These lists are Porsche based, so owners with
money are not the issue on either this list or that one. Perhaps Matt
should enlist the help of John Dunkle of Rennlist fame (German for Racelist)
as to how to make a list like this work while still generating money. John
is an extremely nice guy, and he fixed the multiple post problem years ago.
I am sure he would help Matt out. Rennlist, like matronics, hosts over 35
specific lists....trouble free. Also, being that most on this list support
Matt's business in some way by purchasing parts...it is not like Matronics
has gone unnoticed. Rennlist doesn't sell any Porsche related stuff...just
making money on the sponsors. The sponsor words at the bottom of each
Rennlist post take up far less room then all the Matronics stuff at the
bottom of this one. This list is a great resource, don't get me wrong, but
is neither unique in it's exchange of knowledge, nor infallible in it's
delivery of it. Like Scott at Van's said...there are seeds of knowledge in
here, but mostly its just fertilizer. And as others on this list have said,
the whining gets a bit old.
> Al,
pay
keep
> the list alive.....
> Bob Waalkes
> RV-8 Emp.
> From: "Al Mojzisik" <prober(at)iwaynet.net>
> To:
> November.
> I
be
reason,
> contribution?
your
> knowledgeable
I
opening
personally
> if
still
Correction, it was Ken that said that. Sorry
said,
That's good practice! I'm a young timer but I listen to old timers.
Sometimes they know what they're talking about. Buzzing the runway is a
good idea. Only problem is the cows around our airport are used to
airplanes and aren't spooked by them!
Scott VanArtsdalen, MCSE, CCNA
Network Administrator
Union Safe Deposit Bank
209-946-5116
Sent: Thursday, November 30, 2000 10:42 AM
Subject: RV-List: RV-8 Incident - Critters on the RWY
the old salts have
I've paid for it,
3B9. A well kept,
winter it can go
that when ariving
landing. He
most likely scare
its edges. Just
a thought.
Don Mei
N92CT RV-4
I've been holding off on putting my two cents in on this matter, as I didn't
want to alienate anyone, but I couldn't contain myself any longer. The
'whining', as both Bob & Bill put it, does get extremely old, extremely
quickly. Like instantly, on the first message. I have no problem in paying for
goods and services of value to me, that I understood to be for sale from the
get-go. On the other hand, I have no intention of paying for a service
purported to be 'free', regardless of the value of the list to me and my project
(signal to noise ratio notwithstanding). I'd rather do without it entirely,
particularly as there are now other choices available. The signal to noise is
substantially better on the rv8list, which is entirely free, as are all the
eGroups. The small ads inserted into the messages are easily skipped over and
no more annoying than the Matronics footers on rv-list messages. For myself,
the free eGroups list(s) and Doug Reeves' exceptional, free website (supported,
I believe, by advertising fees) are excellent (and usually superior)
alternatives to the rv-list. If Matt feels that he needs some outside funding
to support the list and to compensate him for his time (certainly deserved),
then he should begin charging for list access. That will instantly separate the
proverbial wheat from the chaff. All that aside, I view being accosted in my
email for donations for a 'free' service (to say nothing about being repeatedly
denigrated for my belief that 'free' services should be FREE or cease to
advertise themselves as such) to be as intrusive and aggravating as unsolicited
telemarketing calls. True, one can delete the offending email, just as one can
hang up on the telemarketer, but it's still annoying.
Ken Balch
> Bill
> > Al,
> pay
> keep
> > the list alive.....
> > Bob Waalkes
> > RV-8 Emp.
> > To:
> > November.
> > I
> be
> reason,
> > contribution?
> your
> > knowledgeable
> I
> opening
> personally
> > if
> still
How
Jim,
I'm at work and can't check the dimensions of the grommets or shields I'm
using. Van's has the grommets vs. shields all worked out so that the shield
allows sufficient clearance for any/all wires coming out? This is all laid
out in the Accessory Catalog. When doing final fitting if the shields get
too close to the wires I would simply trim them back a bit.
Anyone have a better idea?
Randy Lervold
www.rv-8.com
Subject: | Re: RV6-List: RV6 slider track fairing |
One of our builders just did one nicely on an "English Wheel". I assume
you're talking about the bottom/rear part of the fairing that needs a
compund curve to fit the fuselage.
Boyd
Venice, FL
> --> RV6-List message posted by: "Bezinque, David"
> better way?
> Dave Bezinque
> RV6 QB S/N3499
--- bcbraem(at)home.com wrote:
> --> RV6-List message posted by: bcbraem(at)home.com
> assume
> Boyd
He's referring to the cover bridging the rear skirts and covers the
sliding track on the top of the fuselage behind the canopy. One of our
number has made these in the past, I understand.
I've been watching this thread as I will need to do this very soon.
Mike Thompson
Austin, TX
Canopy (could you guess?)
Subject: | weight and balance |
Hi,
Have an RV6 completed and would like to know some other aircraft weights
for the mains and tailwheel. Ours has an alloy V8 and is a little bit
nose heavy.
Paul
Jim,
You might consider the use of a cannon plug for all those smaller wires
to/from the engine. A single disconnect here would save a lot of grief if
you ever have to pull the engine for any reason. For example, Allied
electronics, Inc is a source for lots of goodies. (www.alliedelec.com)
Tom Barnes -6 electrical
Sent: Thursday, November 30, 2000 8:28 AM
> All,
increasing
last
> Thanks,
> - Jim Andrews
> N89JA reserved
I see that Van's doesn't recommend any negative g aerobatics in the RV's
(but says that some mild positive g aeros are o.k.). Is this due to the
structural limitations of the planes or because of the fuel and/or oil
systems?
Dave
Subject: | Re: RV Aerobatics |
11/30/2000 05:32:44 PM
Dave,
Negative Gs are OK, up to -3 as long as your prepared for the consequences.
This means of course, inverted fuel system ( flop tube ) , fuel injection,
inverted oil system, blah blah blah... I'm just planing on doing the
gentleman acro in my 8 which is limited to positive Gs only. If I like
what I see, then, I will spring for all the goodies to make it more
interesting. With my weak stomach and a wife that HATES acro, I will
probably just stick with what I have.
- Jim Andrews
RV-8A ( cowling & FWF )
O-360 A1A Sensenich 85
N89JA reserved
Cannon (sp?) plugs look like a great idea.
How about a hint as to how to find them in the catalog the link pointed to.
I tried cannon and plug - unless I did the search wrong...I'm willing to
learn!
Ralph Capen
From: | "Rick Caldwell" <racaldwell(at)hotmail.com> |
Subject: | Re: weight and balance |
Paul,
My -6 weighed 1057 # with an O-320/Hartzell CS prop, VFR instruments, S-Cowling,
Full paint fairings. I believe the tail weighed 60 #.
Rick Caldwell
-6 162 hrs Melbourne, FL
To: rv-list
Subject: RV-List: weight and balance
Date: Fri, 01 Dec 2000 09:38:32 +0000
-- RV-List message posted by: paul johns
Hi,
nose heavy.
Paul
Paul,
I can't help you with the tail dragger, but my rotary powered RV-6A has
the following W&B
Weight and Balance for RV-6A N494BW
Design CG Range FWD 68.7 AFT 76.8
C.G.
Component Arm Weight Moment
Right Wheel 84.25 420 35385
Left Wheel 84.125 420 35332.5
Nose Wheel 28.5 330 9405
Fuel 70 0 0
Pilot 87.4 0 0
Passenger 87.4 0 0
Baggage 117 0 0
CG Empty Weight
68.48 1170 80122.5
As you can see, I weight roughly 100 lbs heavier than a light VFR RV-6A
(full IFR) and my empy C.G is slight forward of the design limit. Van's
expressed no concerned over the slight forward C.G, were more concerned
about the weight. I also had two 25 AH Concord RG batteries (44 lbs
total)which I have since replace with two Odyssedy batters (total 30 lbs).
As predicted by a forward C.G the aircraft is very stable, probably
slightly slower, and stalls at 58 indicated. No problem on the flare
(plenty of elevator autority for that). I have since had the aircraft
painted which probably put more weight toward the tail which I suspect
probably brings the bird just inside the design limit. The aircraft exceeds
its gross weight before it exceeds its aft C.G design limit.
Hope this helps.
Ed Anderson
Matthews, NC
RV-6A N494BW Rotary Powered
Sent: Friday, December 01, 2000 4:38 AM
> Hi,
> nose heavy.
> Paul
Hi all,
I have a question for the Illinois RVers.
When a friend of mine started to register his Glass Star with the FAA, he
received
a form to fill out before he can register the airplane in Ill., this form it
turns out
is a TAX DUE form for aircraft.
My question is, Have any of you Ill. builders paid the "sales tax". If not
did
you register your airplane? I'm at the point of sending in my paper work to
the
feds. Any help will be greatly appreciated.
Rich
Need an inspection and good weather for first flight
> empty C.G is slight forward of the design limit. Van's
> about the weight.
My FAA man almost wouldn't sign off my 6A because the empty CG was slightly
forward of the design limit. I convinced him that this was only an
operational problem if it was being flown by a pilot whose weight did not
load the airplane within the envelope. As I recall, the numbers we ran hat
day showed that any pilot heavier than about forty pounds brought the CG aft
sufficiently. Neither of us knew any jockey types with a private certificate
who weighed under 40 pounds, so he signed me off. I was not playing any
Clintonesque word-games with the regs by pointing this out to the Fed; the
point is that the airplane, as loaded, must be between the fwd and aft limits
for c.g. An enmpty CG forward of the design limit is not an issue unless you
attempt to fly the plane with no one aboard. Only persons who improperly
hand-prop an airplane by themselves are likekly to attempt such a flight. ;-)
Am I right about this? Run a W&B calcualtion with a pilot in the seat and
I'll bet you come out fine.
Bill Boyd
RV-6A O-320/FP Sensenich
Hop-Along Airfield - 12VA
Clifton Forge, VA
Subject: | Re: Left Hand Drill Bits |
Snap On tools sell them.
They are primarily used to drill out broken bolts
In a message dated 11/30/00 1:34:24 PM Eastern Standard Time,
Jim_Andrews(at)tivoli.com writes:
I got mine thru two holes and I think I have everything plus a few items that
you have except no primer lines. I cut a one inch hole with the the large
unibit (It is scary to use these high dollar items on stainless, but a very
experienced builder said it would not dull them and it does not appear to
dull it) and then wrapped my wires as tight as possible in a peice of
firesleeve. Stuffed all this into a hard plastic peice of an old filler tube
off a plastic gas can to keep the firewall from cutting the firesleeve. It
seems to be working fine but only have 50 hours on it.
Bernie Kerr , 6A SE Fla
Subject: | Re: Last Call............) |
Shame on you.
Contributing to Matt has nothing to do with some imaginary legal contract,
or abstract philosophical concept.
Regardless of how many pretend lawyers try to parse the meaning of the
word "free", Matt is not some charity that exists for the benefit of a few
RV builders, and the rv-list does not simply exist on its own. Donating
to Matt is a way of expressing appreciation for all the _hard work_ he
does for the list -- for the RV community.
And it is more than that. The list is a kind of community, that exists
because of the voluntary contributions of the members of the community.
Some people contribute their time, some contribute their expertise, some
contribute humor and good cheer, and at least some contribute a modest
amount of money. "Voluntary" and "Contribution" are the key ideas here.
Finally, whereas Al's posts have been witty and noble, the only whining
I've seen is from three sanctimonious cheapskates who don't seem to
realize just how foolish they've made themselves look in front of
hundreds, if not thousands, of RV builders.
Disgusted,
-Steve
Go right ahead and archive
Well, said. And I totally agree. Too many cry babies. Must be the younger
spoiled generation.
Don (63)
Flying Rv6 Past contributor
Ed,
I am grateful to you for posting your W&B numbers as there is something in
Van's W&B section that has been bothering me greatly ever since I performed
my W&B a couple of months ago. In my manual's section on W&B, designated
6S14.DOC 5-21-97, p 14-6, the distance between nose wheel and main wheels is
d = (84.125 + 84.25)/2 - 28.56 = 55.63 inches. I note that you have a
slanted wing that EXACTLY matches Van's slanted-wing example, so I must
assume that you used Van's values out of the manual rather than measuring
your plane.
We (helper and I) instead measured the distance between my mains and
nosewheel (axle center to axle center) and obtained a value of 54.69 inches.
I estimate my probable measurement error at plus or minus 1/16 inch -- we
took took care to do the measurement carefully. My wife and I just did a
quick-and-dirty measurement as a reality check and we obtained 54.56 inches
using only one main wheel, so I feel my original value is probably correct
to within the stated error. My wife and I did not take the time to level
the longerons for our Q&D measurement tonight, so I feel that this is a
contributor to the source of the discrepancy between original and latest
measurements.
I therefore assume that there is a one-inch error in Van's example W&B.
This may be attributable to the "new" nosegear on the 6A or simple
measurement error on the part of Van's. My point is that one can incur
considerable error in the calculation of W&B by using Van's worksheet as
opposed to measuring it on your plane.
Dennis Persyk 6A N600DP O360A1A/Hartzell 16 hours
Hampshire, IL C38
Date: Thursday, November 30, 2000 6:20 PM
Subject: Re: RV-List: weight and balance
>Paul,
>the following W&B
> C.G.
>Fuel 70 0 0
>Pilot 87.4 0 0
>Passenger 87.4 0 0
>Baggage 117 0 0
> CG Empty Weight
> 68.48 1170 80122.5
exceeds
>Hope this helps.
>Ed Anderson
>Matthews, NC
Try Amp as mfg and circular connector as product.
learn!
Paul
My RV6, unpainted, basic instrumentation, O320-D2J, wood prop.
Both main gear 475 lbs, tail wheel 65 lbs.
Regards Peter
paul johns wrote:
> Hi,
> nose heavy.
> Paul
They are primarily used to drill out broken bolts<<
Also to drill holes for left hand taps.
In a message dated 11/30/2000 9:44:27 AM Central Standard Time,
menavrat(at)collins.rockwell.com writes:
Hey Scott,
I haven't heard this before and just wondering what you mean by it.
Carey Mills
No part of the rear skirt "needs" a compound curve if you install the canopy
correctly. If you are talking about the cover for the track, all you need is a
piece of scrap AL, a pair of flanging pliers and about 20 min.
Dave
> Boyd
> Venice, FL
> > better way?
> > Dave Bezinque
> > RV6 QB S/N3499
Subject: | Unibit in an Airdrill |
If I use a unibit in an airdrill I get a sloppy hole drilling sheet AL ;
the bit thrashes around in the hole because it does not stay centered. Is
there a simple technique for using a unibit with an aridrill or is the
unibit made only for a drill press?
I seem to have problems with the simplest things.
Mark Gilbert
RV 6A - Wings - getting ready to drill rib holes for the electrical conduit
Sacramento
Try the Digi-Key catalog. Look for AMP circular connectors.
I must have about 6 of them in the sub-panel. Should make removing the panel
a piece of cake.
John Danielson
Engine installation, finishing kit
Subject: | Re: Unibit in an Airdrill |
The secret is to have the drill turn slowly.
I usually use my cordless drill with the unibits, although my Sioux 1/4"
works well because it has a great trigger action.
John Danielson
From: | "Steven DiNieri" <capsteve(at)adelphia.net> |
i've found these aluminum bulkhead fittings that are used in commercial
machine cabinets. they have about a 3/4" inside diameter. there is a knurled
cap on the exterior side that compresses a rubber insert to create the seal
and hold anything passing through. the rubber inserts come in different
sizes and are all that come in contact with the cables or wires.
i wasn't happy with the ole grommet and shield setup either, so i just
went
to a local machine shop and asked what they were using. i figured machine
cabinets have to vibrate. these fitting do weigh a little bit more and
weren't cheap at 12$ a pop.
my wiring is all done and i think i used 6 fittings for everything. i don't
have any left over but if anyone needs a manufacture or part number i'd be
glad to look just drop me an e-mail....
Steven DiNieri
How
Most of the unibits I've encountered are of the single flute variety. this
design lends itself to an unstable path through most any material you
choose, even in a press. Although I own several sized single flute unibits I
bought a good double fluted one for cleaner cuts. at three times the price
I'd still recommend trying one.
Steven DiNieri
Mark Gilbert
Subject: | K & N Fuel Filters for Sale |
I have two, brand new, un-used K & N "billet" fuel filters for sale.
These are the 10 micron, cleanable filters with 3/8 tube flare fittings on
either end. They are approx. 2.0" dia. X 4.0" long. I was planning to use
them on my RV-4 (they fit nicely in the footwells adjacent to the front
control stick), but I am using an Airflow Performance fuel injection system
that already comes with a fuel filter. Therefore, the K & N filters are for
sale. They cost me $60 each. I will sell BOTH for $60 plus whatever it
costs to ship them to your door.
Please respond off list.
Ted Lumpkin
Sent: Thursday, November 30, 2000 6:11 PM
Subject: RV-List: RV Aerobatics
> systems?
> Dave
The plane does fine in neg. It does fly with a nose high attitude inverted.
I dont do more than 2 neg. G's because I dont like the horizontal attach.
If you are consdering neg G's, buy the best 5 point harness with ratchet
that money can buy.Terry
Sent: Wednesday, November 29, 2000 1:09 PM
Subject: Re: RV-List: cht probe location
> Hey Scott,
> See ya,
> Don
Dont use them at all! The are well known for being
completely inacurate.Terry
Rick,
Thanks very much for the info.
Paul
Ed,
Paul
Peter,
Paul
From: | "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> |
Subject: | Fw: AOPA ePilot--Vol. 2, Issue 48 |
From: AOPA e-Pilot Newsletter <aopa(at)mail.0mm.com>
Sent: Friday, December 01, 2000 3:07 AM
Subject: AOPA ePilot--Vol. 2, Issue 48
> AOPA ePilot Volume 2, Issue 48 December 1, 2000
> AOPA values its relationship with you. If you don't want this free
> newsletter, reply with the word UNSUBSCRIBE as the subject. To see
> ePilot with graphics, visit
> ( http://www.aopa.org/members/files/pilot/epilot/001201epilot.html ).
> IN THIS ISSUE:
> Premier jet hits more snags
> Superior Air Parts to remain independent
> Wings of Light thanks AOPA
> Gorton defeated in Washington
> ==> GA NEWS <=
> NTSB RELEASES PAYNE STEWART REPORT
> The NTSB confirmed Tuesday what most had believed in the year since
> the Learjet 35 carrying golfer Payne Stewart and five others
> mysteriously crashed. The crash was indeed a result of a cabin
> depressurization. What the NTSB is unsure of is why the crew was not
> able to get supplemental oxygen after the cabin depressurized.
> Following the 13-month investigation, the NTSB issued 11 safety
> recommendations to the FAA, mostly centering on crew training and
> ways to improve pressurization systems. In addition, NTSB Chairman
> Jim Hall said that with the rapid growth in fractional and charter
> operations, business jets should be treated the same as commercial
> airliners when it comes to safety. For more on the investigation, see
> the NTSB's Web site ( http://www.ntsb.gov/Publictn/2000/aar0004.htm ).
> CRIPPLED SKYHAWK LANDS SAFELY AFTER MIDAIR
> A Cessna 172 safely landed at West Houston Airport, Texas, following
> a midair collision with a Cessna 150 on Sunday. One-third of the
> 172's right wing was left hanging down by the impact. The aircraft
> were flying at 2,000 feet in good visibility, NTSB officials told
> "The Houston Chronicle." The pilot of the Cessna 150, 36-year-old Don
> Lee of Katy, Texas, died after a wing was severed from his aircraft
> by the impact. His airplane crashed along Interstate 10, just outside
> of Katy. The pilot of the Cessna 172, Diana Orendorff, spotted the
> Cessna 150 shortly before the impact and pulled her aircraft into a
> climbing right turn, she told investigators. Aircraft owner Ed
> Oppermann then took control and landed at West Houston on one wheel.
> The aircraft reportedly struck at a 90-degree angle.
> PREMIER JET HITS MORE SNAGS
> Raytheon Aircraft's Premier I business jet program has once again
> been delayed because of holdups in the certification process. In a
> November 15 Securities and Exchange Commission filing, Raytheon
> Company, the aircraft company's parent, disclosed that the jet would
> not receive FAA certification by the end of the year. It marks a
> setback of more than two years. The company, meanwhile, has recorded
> an increase in aircraft sales, to $2.4 billion in the first nine
> months of this year compared to $2.1 billion over the same period in
> 1999, according to the filing. Earlier this year it was revealed that
> Raytheon plans to sell its aircraft unit, but no one has stepped up
> to the plate yet o pay the reported $4 billion asking price. Company
> officials and several potential buyers have refused to comment to
> "ePilot" about the sale. To read more about Raytheon, search under
> key word "Raytheon" on the SEC's Web site
> ( http://www.sec.gov/cgi-bin/srch-edgar ).
> SUPERIOR AIR PARTS TO REMAIN INDEPENDENT
> Superior Air Parts Inc. plans to remain an independent company after
> a deal to sell it to Aviall Inc., a global parts distributor, fell
> through last week. Under the agreement, Aviall would have bought
> Superior for $43 million in cash. But since Aviall wasn't able to
> secure the necessary financing commitments within the specified time,
> the board of directors of Superior terminated the purchase agreement,
> said James P. Wilson, chairman of the board for Superior. The company
> plans to continue its growth rate with products such as the certified
> Millennium pre-owned engine, the XP-360 engine, and other programs.
> Superior Air Parts, headquartered in Dallas, manufactures and
> distributes FAA-approved parts for piston-powered general aviation
> aircraft.
> BONANZA PILOT MAKES EMERGENCY HIGHWAY LANDING
> Some evening rush hour commutes are more exciting than others. Bill
> Hart, 57, was heading to San Jose, California, for a business trip on
> Monday when his Beech Bonanza lost power on short final to San Jose
> International Airport at about 6 p.m. He had plenty of fuel and he
> tried switching tanks, but there was no effect, he said. Since he was
> so low to the ground, Hart notified the tower of the emergency and
> looked for the nearest suitable landing site which turned out to be
> an on ramp to Highway 87. Hart found out later he had dodged a high
> school, homes, and moving cars in the dark. The only damage was small
> dent in the leading edge of the left wing from hitting a mile marker.
> With assistance from the police, the airplane was restarted, taxied
> to the next off ramp, and towed to the airport by flight line
> personnel. Hart said he suspects that the engine was vapor-locked.
> AIRPORT USES NEW KIND OF RUNWAY SURFACE
> The Savannah-Hardin County Airport (SNH) in Tennessee is the first
> general aviation airport in the nation to receive a new type of
> runway surface called ultra- thin whitetopping. The 4-inch concrete
> overlay was installed on the 38-year-old, 5,000-foot asphalt runway
> earlier this year, giving it a whitish appearance. It's an especially
> welcome sight for IFR pilots when they break out of clouds and see a
> big white landing surface amid green fields. Airport officials found
> that it was more expensive than an asphalt overlay but less expensive
> than a total reconstruction, according to a report by the American
> Concrete Pavement Association. However, when looking at maintenance
> costs, it was determined that the asphalt would crack and the runway
> would require a new asphalt overlay in 10 years. Airport officials
> expect the robust concrete surface to last 25 years, the ACPA report
> continued. The runway has already won awards and is being studied by
> the government and other airports.
> For daily news updates, see AOPA Online ( http://www.aopa.org/members ).
> ==> INSIDE AOPA <=
> AOPA TO AIR GA COMMERCIALS
> AOPA will underwrite national cable TV messages promoting the
> value of community airports this holiday season. The 30-second
> commercials will air from December 22 through January 3 on the
> Weather Channel, just as congestion and passenger disgruntlement
> at major airline hub airports reach a peak. "Once again, AOPA is
> action, not talk," said AOPA President Phil Boyer. "Because
> defense of airports is our members' number one priority, we're
> making this investment for the entire general aviation community."
> For more, see AOPA Online
> ( http://www.aopa.org/whatsnew/newsitems/2000/00-4-067.html ).
> AOPA RECOGNIZES CLARK COUNTY AVIATION ASSOCIATION
> AOPA President Phil Boyer gave special recognition to members of the
> Clark County (Nevada) Aviation Association (CCAA) Tuesday during a
> Pilot Town Meeting in Las Vegas. Boyer told the crowd of pilots that
> CCAA was "working tirelessly to make things better for general aviation
> in Las Vegas." CCAA and the North Las Vegas Airport (VGT) are hosting
> a Community Aviation Day this Saturday (December 2) from 9 a.m. to
> 2. p.m. For more, see AOPA Online
> ( http://www.aopa.org/whatsnew/newsitems/2000/00-4-069x.html ).
> WINGS OF LIGHT THANKS AOPA
> Wings of Light, a nonprofit organization that helps people affected
> by aviation accidents, honored AOPA this past week at a Pilot Town
> Meeting in Phoenix. Andrea Waas, founder of the Phoenix-based
> organization, presented a plaque to AOPA President Phil Boyer,
> recognizing AOPA as an affiliate sponsor. "The support of AOPA and
> other sponsors allows Wings of Light to provide our services at no
> cost, and to increase awareness among the public and decision- makers
> of the issues involved with aircraft accidents and the needs of those
> affected," she said.
> ==> ON CAPITOL HILL <=
> GORTON DEFEATED IN WASHINGTON
> Former Democratic Rep. Maria Cantwell rallied to defeat Senate
> aviation subcommittee Chairman Slade Gorton late last week and win
> the last remaining Senate seat still in question at the close of the
> 2000 election cycle. After all of the votes were tallied, Cantwell
> held a 0.08 percent margin--just 1,953 votes more than Gorton out of
> more than 2.5 million ballots cast in Washington State. As in the
> presidential election in Florida, the margin of victory fell below
> one-half of 1 percent, forcing an automatic recount that is expected
> to be completed this week. However, the outcome will likely remain
> unchanged. Cantwell took the lead late last week after a slew of
> late-counted ballots, that were thought to be for Gorton, turned the
> race in her favor. Gorton has not conceded the race yet, but has
> indicated that he will make an announcement following the recount.
> ==> AIRPORT SUPPORT NETWORK <=
> VOLUNTEER OF THE WEEK--CHERYL POPP
> AOPA recently received member inquiries concerning possible closure
> of Cincinnati-Blue Ash Airport (ISZ) in Ohio; however, Airport
> Support Network volunteer Cheryl Popp reported that there is no
> impending threat of closure. Popp, in conjunction with the Blue Ash
> Airport Advisory Committee and the city fathers of Blue Ash, has been
> working on possible acquisition of the airport from Cincinnati for
> several years. Popp said that negotiations between the cities have
> finally begun.
> SOLBERG UNDERGOES CONDEMNATION PROCEEDINGS
> Readington Township has escalated its efforts to prevent improvement
> or further development at Solberg Airport (N51) in New Jersey.
> Airport Support Network volunteer Sim Hitzel has attended local
> meetings and has been reporting regularly to AOPA on these latest
> efforts by the township to strangle the airport and stifle growth.
> The battles between the airport and the township have been ongoing.
> In its largest salvo of the attack, the township is attempting to
> wrestle control (and ownership) of the airport through a state
> condemnation process. Hitzel has also worked diligently with the
> airport's owners as well as local pilots to counter the attack. New
> Jersey pilots stay tuned! What happens at Solberg could migrate to
> other privately owned airports in the state under sanction of state
> legislation.
> To learn more about the Airport Support Network, visit
> ( http://www.aopa.org/asn/ ).
> ==> AOPA AIR SAFETY FOUNDATION NEWS <=
> DEADLINE NEARS FOR DONATION DEDUCTIONS
> There is only a month left to receive tax deductions for charitable
> contributions for this year. The AOPA Air Safety Foundation has
> programs and gifts for every level of contribution. ASF can help you
> put your hard-earned money to work for aviation safety. Call
> 800/955-9115 and ask for Art Keefe or Bob Milanchus or visit AOPA
> Online ( http://www.aopa.org/asf/development/ ).
> ==> QUIZ ME! <=
> Here's a question asked by an AOPA member last week of our AOPA
> technical specialists. Test your knowledge.
> Q: The question was recently put to me: "Why does a red morning sky
> denote bad weather during the day?" I have not been able to find the
> answer and wondered if you could. A: We all probably know the weather
> saying, "Red sky at night, sailors delight. Red sky in morning,
> sailors take warning." A red sky at sunset or early evening indicates
> clouds to the east, with clearing on the western horizon allowing the
> setting sun to be seen. Unsettled weather or storminess may have
> passed. A red sky in the morning indicates clouds to the west as the
> sun is rising, which may advance eastward and bring bad weather. For
> more weather lore, see
> ( http://classroomatsea.noaa.gov/shipops/rhymes.html ).
> Got a technical question for AOPA specialists? Call 800/872-2672, or
> e-mail to ( mailto:inforequest(at)aopa.org ). Send comments on our Quiz
> Me! questions to ( mailto:epilot(at)aopa.org ).
> ==> COMING UP IN "AOPA PILOT" <=
> Fly the U-2 in thin air, take the funky Helio Courier around the golf
> course, and shove the throttles forward in the Cessna CJ2 in the
> January issue of "AOPA Pilot." It will be mailed December 16.
> ==> ePilot CALENDAR <=
> WEEKEND FLYING DESTINATIONS
> In response to member requests, destinations will be posted at least
> one week in advance. CARMEL, CALIFORNIA. The forty-first annual Santa
> and Mrs. Claus Fly-In takes place December 9. Carmel Valley Airport
> (O62), 831/659-0860, is the host airport. Call the airport for event
> information.
> DALLAS, TEXAS. The Frontiers of Flight Museum hosts North Texas
> Aviation's "Contributions to Winning WWII" December 15. Dallas Love
> Field (DAL), 214/670-6073, is the host airport. Call 214/350-3600 for
> event information.
> COLLEGE PARK, MARYLAND. The College Park Aviation Museum hosts
> Santa's Fly-In December 9. Activities for children. Call 301/864-6029
> for event information.
> WEST CHESTER, PENNSYLVANIA. The American Helicopter Museum of
> Education hosts Lunch With Santa December 9 at Brandywine Airport
> (N99), 610/692-6100. Call 610/436-8180 for event information, or
> visit the Web site ( http://www.helicoptermuseum.org/events.htm ).
> For more airport details, see AOPA's Airport Directory
> ( http://www.aopa.org/members/airports ). For more events, see
> ( http://www.aopa.org/pilot/calendar.html ).
> ASF FLIGHT INSTRUCTOR REFRESHER CLINICS
> (All clinics start at 7:30 a.m.)
> The next AOPA Air Safety Foundation Flight Instructor Refresher
> Clinics are scheduled in Chicago and Denver, December 9 and 10.
> Clinics are scheduled in Reston, Virginia, Lincoln, Nebraska, and
> Orlando, Florida, December 16 and 17. For the Flight Instructor
> Refresher Clinic schedule, see
> ( http://www.aopa.org/asf/schedules/aboutfirc.html ).
> ASF SAFETY SEMINARS
> The next AOPA ASF Safety Seminars are scheduled in St. Louis,
> January 8; Springfield, Missouri, January 9; Kansas City, Missouri,
> January 10; and Wichita, January 11. For more information see
> ( http://www.aopa.org/asf/schedules/sssite.html ).
> ASF PINCH-HITTER GROUND-SCHOOL COURSES
> (Pinch-Hitter courses start at 9:30 a.m.)
> The next Pinch-Hitter(R) Ground School will take place
> December 17 in Orlando, Florida. For more Pinch-Hitter courses,
> see ( http://www.aopa.org/asf/schedules/pinch.html ).
> AOPA PILOT TOWN MEETINGS
> Featuring AOPA President Phil Boyer
> (7:30 p.m.; admission is free)
> The next Pilot Town Meetings are in Tallahassee, Florida, January 30;
> Fort Lauderdale, Florida, January 31; and Tampa, Florida, February 1.
> For more information on Pilot Town Meetings, see
> ( http://www.aopa.org/prez/ ).
> For comments on calendar items or to make submissions, contact
> Julie S. Walker at ( mailto:julie.walker(at)aopa.org ).
> ==> YOUR WEEKEND WEATHER <=
> See ( http://www.aopa.org/members/wx/ ).
> ePilot SPONSORS
> Garmin International
> ( http://wwwrd.0mm.com/AOP066001 )
> AOPA Aircraft Financing Program: Apply online today!
> ( http://wwwrd.0mm.com/AOP066005 )
> Comm 1: Radio Simulator VFR and IFR Practice 2-way communications
> with ATC on your home computer today!
> ( http://wwwrd.0mm.com/AOP066007 )
> Pilot Insurance Center -- The lowest life insurance rates for pilots
> -- PERIOD. Get an online quote and compare to see how much you can
> save. ( http://wwwrd.0mm.com/AOP066008 )
> Comair Aviation Academy: One Dream...One School.
> ( http://wwwrd.0mm.com/AOP066002 )
> AOPA Certificate of Deposit Special:
> ( http://wwwrd.0mm.com/AOP066003 )
> ==> CONTACTING ePilot <=
> Got news? Contact "ePilot" editor Nathan A. Ferguson at
> ( mailto:nate.ferguson(at)aopa.org ).
> Having difficulty using this service? Visit the "ePilot Frequently
> Asked Questions" now at
> ( http://www.aopa.org/members/files/pilot/epilot/faq.html ) or write
> to: ( mailto:epilot(at)aopa.org ).
> To UNSUBSCRIBE: reply to this e-mail, a free weekly newsletter on
> general aviation, with the word UNSUBSCRIBE as the subject. Do not
> include a message. To SUBSCRIBE: visit
> ( http://www.aopa.org/members/epilot.html ).
> AOPA, 421 Aviation Way, Frederick, Maryland 21701.
> Telephone: 800/USA-AOPA or 301/695-2000
> Copyright (c) 2000. Aircraft Owners and Pilots Association.
> You are subscribed as tcervin(at)valkyrie.net
From: | "Fesenbek, Gary" <Gary.Fesenbek(at)marykay.com> |
I approached this problem by putting two 21 pin cannon plugs through the
firewall. I have one on the right and one on the left. My aircraft is
finished and I have been flying it for a year now and I only used about half
of the capacity for each side. Plenty of room for expansion. Another thing
that is neat about a cannon plug is that you can build a test plug to insert
between the male and female on the firewall to troubleshoot any problems
that you have with a volt/ampmeter. Although I haven't had any real
problems to put this to the test after flying, during initial installation
it was very handy. Another benefit is that if I am looking for my oil temp
sensor wire, I don't have to search through a bundle of wires to find it. I
know it is in the right plug at pin 7.
Hope this helps.
By the by, I got my plugs from Digikey. Look for them in the RV yeller
pages. Consider using the fire-resistant ones for the firewall. Use one on
the radio stack and it will make removal of the radio stack very very easy.
Gary
RV6A
Dallas, TX
Unibits like to be run slow. Perhaps that will help. I use mine in an
electric hand drill and keep the revs low.
Steve Soule
Huntington, VT
RV-6A various finishing details
-----Original Message-----
From: | Ken Harrill <KHarrill(at)osa.state.sc.us> |
they
Their
easier!
Hampshire, IL C38
Dennis,
I have a VM 1000 on backorder from Chief. Do I order the "extra set of
terminals" from Chief or do I buy them from Vision Microsystems? Do you
have any other insights about the VM 1000 and its installation?
Thanks.
Ken Harrill
RV-6, firewall stuff
Columbia, SC
Dennis,
You are correct in that I used Van's numbers on the worksheet. This was
with the old nose gear strut. As you point out probably not good to assume
anything about arm distance in W&B caculations. Because I was expecting to
be slightly nose heavy and the calculations came out that way I did not
pursue it further. Getting the Longerons level does make a difference.
Ed
> Ed,
performed
is
> your plane.
inches.
inches
> measurements.
> Hampshire, IL C38
> From: Ed Anderson <eanderson(at)carolina.rr.com>
> >Paul,
has
> >the following W&B
> > C.G.
> >Fuel 70 0 0
> >Pilot 87.4 0 0
> >Passenger 87.4 0 0
> >Baggage 117 0 0
> > CG Empty Weight
> > 68.48 1170 80122.5
lbs).
> exceeds
> >Hope this helps.
> >Ed Anderson
> >Matthews, NC
12/01/2000 07:16:08 AM
Ken,
Just did this. The Vision Microsystems part number to ask for is quantity
( 2 ) of the 2010013 and quantity (2) of the 2010012. You can order them
direct from VM. The total damage less shipping is $82.50.
Definitely a MUST!
- Jim Andrews
RV-8A ( cowling )
N89JA reserved
You must have either a defective bit or you are running it way too fast. A
true unibit is self centering.
(Click here to visit our Club site at http://www.bellanca-championclub.com)
----- Original Message -----
Sent: Thursday, November 30, 2000 10:29 PM
Subject: RV-List: Unibit in an Airdrill
> Mark Gilbert
conduit
> Sacramento
Van and his organization have never really "got it"....they have suffered a
never ending barrage of help calls, letters, emails, and a nontrivial builder
"give up rate" because they refuse to make a significant investment in a
complete builder's manual, accurate drawings, assembly drawings, and
companion videos and/or workshops. They give you a box of parts with error
riddend drawings with a "back of the napkin" manual (if you disagree, check
out supporting data supplied by RANS, LANCAIR, KITFOX,etc...). This list has
proven invaluable to most of us (dispite some erroneous info and flaming)
because it provides absolutely essential supplemental data to van's sparse
data. I have a master's degree in engineering, have restored two production
aircraft, have been involved in aviation for over 25 years and I STILL have
struggeld mightily (like most of us) on the construction details of my RV6a.
Just check out the titles of the rv-list email entries. Many, many, many of
us are asking questions about really fundamental stuff that van should
already have guided us through in his documentation. Why do you think George
and Becki made a bundle by sticking a camcorder on a tripod?
So you Van chauvinists, don't get upset...dont flame...peace...peace. I too
have met and talked with Van on several occasions and love the guy and his
airplane. He might not fully understand, however, the value of the "list"
because he doesn't understand why we continue to need it.
Paul M
ready for inspection RV6A,180,c/s
From: | "Randy J. Pflanzer" <rpflanze(at)iquest.net> |
> Disgusted,
> -Steve
Thanks Steve,
You wrote, in better prose than I, exactly what I was feeling. I was going
to add my .02 cents but I don't see the need to continue this mean-spirited
thread. I feel bad for Matt and Al. Keep your head up guys.
Randy Pflanzer N417G
RV-6 Indianapolis (105 hours)
>The EAA has a rememberence wall, maybe this list needs a virtual
>rememberence wall, remembering all the great experience that has left
>this list.
I can only say AMEN and well said.
Wes Hays
Rotan, TX
RV6-A, 0-360 w/CS (Hartzell)
N844WB, Flying
>W&B.
Dennis,
FWIW, I found the same difference when I measured the distance between my
gears on my 6-A. I also figured it was due to the new nosegear.
My 6A came in a bit heavy also. It is painted and basic IFR. CG is well
within limits but with hefty pilots and full luggage it is right at the
aft mark with the tanks empty. (I hope to be on the ground well before
this happens).
Main Wheel, Right = 84.5 inches aft of datum
Main Wheel, Left = 84.437 inches aft of datum
Nose Wheel = 30.5 inches aft of datum
Fuel = 70 inches aft of datum
Pilot & Passenger = 87.4 inches aft of datum
Baggage = 117 inches aft of datum
Right Wheel 430 84.500 36335.00 Empty
C.G.
Left Wheel 437 84.437 36898.97 Equals
Nose Wheel 307 30.500 9363.50
70.36
Total 1174 82597.47
Wes Hays
Rotan, TX
N844WB, Flying
Thread-Topic: RV-List: Unibit in an Airdrill
Thread-Index: AcBbngp4ofQlkdKzTu+GOLfnvJgl1QAAA4iA
From: | "Bob Japundza" <Bob.Japundza(at)realmed.com> |
It depends on the type of unibit you have. If you have the real
"Unibit" brand it will only have one cutting edge, its the one available
from Avery's. Some of the cheaper ones available at hardware stores
have two cutting edges; those will not make nice holes, and will wobble.
Bob Japundza
RV-6 N244BJ O-360C/S flying 59 hours
> sheet AL ;
> centered. Is
> or is the
From: | "Douglas E. Bostard" <dougacft(at)jps.net> |
Subject: | Re: RV6-List Digest: 3 Msgs - 11/30/00 |
I assume you mean the bottom skirts outside the track. I carefully bent
mine by hand but if you encounter a compound curved area try a metal
shrinker on that part. This is especially good for the rear (top of
fuselage) skirts if they don't quite fit tightly onto the upper fus.
skins aft of cockpit. If the latter are drilled an fitted and clecoed
progressively from outboard to center (and trimmed aft later) it helps
to actually have 3 people pulling (stretch forming) and one person
drilling frame and clecoing. Hope this helps. I didn't find anyt
compounds on my side skirts..shaped (bowed) them by hand. Doug
Subject: | FWIW: Left Hand Drill Bits |
Drill bits are either right hand cut-right hand
flutes or left hand cut-left hand flutes. Taps,
reamers, & end mills can be a combination of
directions, i.e., right hand cut, left hand
flutes, etc.
The left hand drill bit was originally developed
for drilling through very thin pieces of
over-lapping metal. Right hand drill bits tend to
lift the pieces of metal away from each other, so
the left hand cutting surface was developed to
push the metal together when drilling through it.
Left hand drill bits are also commonly seen on
gang drills (a machine with a number of chucks
spaced apart according to the work being done). If
the chucks are all being driven by a common
gearing mechanism, then one gear, turning right,
will turn the next gear & chuck to the left, etc.
As has been previously noted, left hand drill bits
work very well when drilling out broken bolts &
screws. Drill bits do not cut smoothly, they
"slap" the metal they're cutting. Therefore, each
time the drill bit goes around it's "slapping" the
shank of the bolt or screw that's stuck & often
will jolt it loose. If not, what could be better
than drilling a hole in the center of a broken
bolt & having the sides collapse inward, leaving
the threads on the material intact? Ez-outs put
outward pressure on the threads.
Left hand drill bits are more expensive than
regular drill bits, the cost being attributed to
limited production & set-up costs.
Hopefully this will shed some light on the subject
& possibly provide a new tool that I hope no one
has the requirement to use, but if so, one that
will be useful. If anyone needs left hand drill
bits let me know. I have several sources that
undoubtedly will be cheaper than a Snap-On dealer.
Blue Skies!
I found that electric drills work far better with a unibit...keep it really
slow, to. Your holes will turn out perfectly round and clean if you take
your time. Air drills are too hard to regulate and start to quickly IMHO.
Paul Besing
RV-6A (197AB) Arizona
http://www.lacodeworks.com/besing/
Finish Kit
Sent: Thursday, November 30, 2000 9:29 PM
> Mark Gilbert
conduit
> Sacramento
"Fesenbek, Gary" wrote:
I need some advice regarding how folks are dealing with the ever increasing
number of wires that need to pass through the firewall.
Hope this helps.
Gary
RV6A
Dallas, TX
From: | "Vern Darley, 11" <vern(at)mindspring.com> |
Subject: | Need to buy an RV-6 project/tools in the SEUS |
I am looking for an RV-6 project and will consider those at any stage.I prefer
SE US since I'm in Atlanta so transportation will be easier.
Thanks!
Vern Darley
5 Perthshire Drive
Peachtree City, GA 30269
w 770 487-6307 9-6 est
h-770 487-5155
I've inadvertently been negative in my -8 a couple of times. Besides the
engine quitting momentarily, I really didn't like the idea of ONE seat belt
latch between me and having to use the parachute. What I mean is, install a
backup lap belt if you plan to do negative stuff. Think about how you'd fly
if you were pressed up against the canopy out of your belt, or more likely,
sailing toward the ground with the canopy torn from the plane.
Look at this months picture in Van's RV calendar. Nice shot of two -4's
flying inverted.
just my 2 cents...
Bryan Jones -8 765BJ ~55-hrs
Pearland, Texas
Sent: Thursday, November 30, 2000 10:34 PM
Subject: Re: RV-List: RV Aerobatics
> systems?
> Dave
Extra Terminals???
Maybe I've missed something as my VM1000 did not come with the part numbers
listed. It looks like the rest of the stuff was there though...
Ralph Capen
Subject: | Would you like a little more whine with that?? |
Gentllemen, gentlemen, can't we just all get along??????????
Obviously Bob, Bill, Ken, and Scott have missed the
point......guy's........you are just reading an e-mail, it's not like I'm
calling you names personally in your face......If you wish to paint
yourself into the literary pictures I draw that is your prerogative. I
can't help that. This method of drumming up VOLUNTARY DONATIONS has been
going on for years. MOST Listers have seen it before and know what's going
on. THEY HAVE A CLUE..... Unfortunately MOST have still decided NOT to make
a donation. I don't hold that against them. If someone feels that they
don't need to make a donation, that is their choice and I respect that. I
REALLY don't think any less of them. Maybe they will make one next year.
However, with that said, IF you are having some sort of personal problem
with my posts then I submit that maybe you ARE having second thoughts about
your position.....in other words: You MAY have a feeling about what is the
right thing to do IN YOUR CASE, however, you are fighting with your own
conscience. Only you can work through that to find the right answer. A
good way to test that is to send Matt(e).........oh let's
say.......$1. Okay now reread my prior appeals and see if they hold the
same power over you. Annoying?? I hope so. They are meant to be. It was
decided a long time ago that the majority of List members don't want to see
advertising as a regular part of the List. This Fundraiser was an option
that we decided to "tolerate" to try to compensate Matt(e) for all that he
does for us.
I DO take exception to some of your comments about Matt(e) attaching his
URL for the Matronic's sites to the end of each post. For gosh sakes, will
you reread those comments and look at what you are saying in front of over
2000 people? If it is so "inconvenient" for you to "see" that at the end of
a post then I would suggest that maybe you should reassess your
relationship with society in general. The rest of us are not here to
service your needs THE WAY YOU WANT THEM SERVED! If any of you are still
naive enough to believe that ANYTHING is free in our society today I would
suggest that you WAKE UP! Whenever you enter a drawing for a "free" prize,
you have just paid for it by entering your name on a zillion mailing lists
when it's sold by the person offering the "free" prize. I can go on and on
(believe me) with other examples of "FREE". In the case of this list you
can send a donation or live with a little guilt or KNOW that you have
contributed to the list IN OTHER WAYS or perhaps just knowing that you WILL
CONTRIBUTE when you feel you are getting something of value from the List
in the future. There is always some method of payment for a FREE service.
Let's talk about political contributions....uh....on second thought......
Now lastly in this diatribe let me thank you personally for the flames
because it's getting cold here in Ohio. Someday I hope to meet Matt(e)
Dralle and he can buy me a beer (or Scotch for those of you who really know
me). But until then, the "Thank you" he sends me privately each year and
the kind words I get off list from many of you is MORE THAN enough to make
me come back each November. (Maybe your worst nightmare.......talk about a
turkey in November......)
In the mean time I will continue to make my contribution by secure credit
card connection at: http://www.matronics.com/contribution or by a check to:
c/o Matt Dralle
Matronics
P.O. Box 347
Livermore, CA 94551
Oh yeah.......one more thing. I'm glad that I can make a contribution to
keep this list alive at little cost to Matt(e) so you guys can freely
express your opinions. I REALLY do respect them......I'll even buy you a
beer if you look me up at Oshkosh........and please, when you spit the hook
out put it in it's proper place back in the bait box....... or do you need
a little more WHINE with that? AL
12/01/2000 10:32:55 AM
Ralph,
The extra terminals are an option. A recommendation by their technical
support staff as a time saver if you ever need to get into the DPU after
you have gone to all the trouble to install 60 jillion wires into it.
Apparently there are dip switches on the DPU that sometimes must be
changed, as well as a back up battery that will eventually play out that
will need to be replaced. Not to mention if the unit needs servicing you
will be faced with the daunting task of removing all your connections to
make this possible. I don't even want to think about trying to remember
where they all would go when I got the DPU back from service.
The term "extra terminals" is a misnomer. It's actually an exact replica
of the terminal blocks that are already attached to the top of your DPU.
The install procedure is to install all your wires to the extra terminal
blocks then insert the blocks into the terminal blocks on the DPU. This
provides you with a kinda quick disconnect feature that allows you to
unattached every connection at once instead of individually without having
to disconnect individual wires.
It's just a feature. Your call as to rather you think it's worth the extra
expense. For what I paid for the VM this was in the noise so I jumped at
it.
- Jim Andrews
RV-8A ( cowling... )
O-360 A!A Sensenich 85
N89JA reserved
http://www.homestead.com/RV8A/files/
Stevo,
You're quick to point of "voluntary" and "contribution" as words that we
should focus on, but what about the "freeloader" that Al uses without
hesitation?
This foolish cheapskate would like to tell you to go fly a warped winged RV.
Revengeful,
Bob Waalkes
RV-8 Emp.
Sent: Thursday, November 30, 2000 7:15 PM
Subject: Shameful (Re: RV-List: Last Call............)
just
> Shame on you.
> Disgusted,
> -Steve
Subject: | Re: Wires through the firewall |
Gary:
It would be helpful if you could supply a part number for the cannon
plug. The web site is a maze and there are no discriptions of the items
listed. Your help would be greatly appreciated as the idea to simplify
the transfer of wires through the firewall with plugs is a good idea.
How does it look? I am currently planning my course of attack for the
VM-1000 and those big, stiff wires look like they will be hard to
minipulate and keep clean looking as they merge into a plug.
David Aronson
FWF
> Hope this helps.
> Gary
> RV6A
> Dallas, TX
Subject: | Re: 0360 Engine New vs Rebuilt |
> >to pay for this. A lot of the paint on the engine has fallen off. I
think
> >for the price that these engines cost they could figure out how to paint
> >one.
> I second that! I bought a new O-320-D1A from Van's for my -6 and it is
I third that! Same deal on my O360. At the first annual I pulled the valve
covers and stripped and primed and repainted them. They're still boring old
Lycoming gray but they look a whole lot better and the paint is sticking
this time. One of these days I'll go after the rest of the engine. Maybe.
Uh-oh, the sun's coming out -- never mind! :-)
Randall Henderson, RV-6 N6R (~175 hrs)
Portland, OR
http://www.edt.com/homewing
Subject: | Re: On rolling of the eyes at Van's-commentary |
Paul,
I too have restored several production aircraft and have been involved in
aviation for over 30 years and had very FEW problems with the plans and
instructions. But then I don't have that engineering degree. Maybe that's your
problem.
Dave
5.0.3 (Intl)|21 March 2000) at 12/01/2000 12:48:13 PM
Carey,
I was the one who posted this in response to a post by Scott. My O-360-A4A
(from a Cherokee 180) lists 91 Octane as the min octane rating on the data
plate. According to other listers the new O-360-A1A's from Van's also has
this same rating. There has been discussion on the List before about
running Premium auto fuel (91 Octane) in these O-360's. I believe several
listers said they were running 91 already (Tim Lewis was one of them if I
recall correctly). Some of the discussion has centered on whether the 91
autofuel is equivalent to whatever spec Lycoming used for this rating. Has
anyone talked to Lycoming about this?? It would be interesting to get
their response although I suspect they will not "approve" autofuel even if
it works just fine.
My thinking is if I have the option of burning 91 octane in my -360, it's
an ace up my sleeve in case the "new avgas" doesn't work out to be
available, affordable, or whatever. Part of the problem right now is that
91 octane is not available at most airports....usually airports that have
autofuel carry regular unleaded because it's cheaper. If you have an engine
modified with low compression pistons you can burn 87 autofuel, but you
also take a loss in horsepower and efficiency. I want to keep the 180 hp
so I'm going with the standard pistons. If I have to in the future, I'll
find a way to get 91 autofuel out to the airport to use in my aircraft.
My comment below was that I haven't seen an O-320 with 91 min octane rating
on the dataplate straight from Lycoming. Any listers running 160 hp
O-320's on 91 autofuel?
--Mark Navratil
Cedar Rapids, Iowa
RV-8A flaps
Subject: Re: RV-List: O360 Engine
> and ability to burn 91 octane in it and
> still make rated power. I think some O-320's can burn 91 octane without
> putting the low compression pistons in it (and taking the subsequent loss
> of 10 hp) but I'm not sure about this.
Hey Scott,
Carey Mills
Subject: | OH NO!!! IT'S A PRIMER QUESTION!! |
5.0.3 (Intl)|21 March 2000) at 12/01/2000 12:52:28 PM
Listers,
I know it's a no-no, but I have a primer question. I'm getting ready to
start my fuselage and I'm wondering if anyone knows of a grey self-etching
primer that is tough enough to be used on the interior of the cockpit
without having to paint over it? It would save some time and weight to
just leave the cockpit in primer. I used a brand X green primer (same as
Vari-prime only half the price) on the wings and emp., but don't want a
green cockpit.
Comments from anyone already flying who have subjected a primer-only finish
to some wear and tear would be especially appreciated.
--Mark Navratil
Cedar Rapids, Iowa
RV-8A flaps
12/01/2000 01:59:11 PM
Did you measure with the mains unloaded.....on jacks. The sprattle of the
taper leg rods might cause the legs come to rest in a different location
when in the air vrs. on the ground.
"Dennis Persyk" (at)matronics.com on 11/30/2000
08:33:29 PM
Sent by: owner-rv-list-server(at)matronics.com
cc:
Ed,
is
your plane.
inches.
measurements.
Hampshire, IL C38
>Paul,
has
>the following W&B
> C.G.
>Fuel 70 0 0
>Pilot 87.4 0 0
>Passenger 87.4 0 0
>Baggage 117 0 0
> CG Empty Weight
> 68.48 1170 80122.5
exceeds
>Hope this helps.
>Ed Anderson
>Matthews, NC
Mark,
The unibit is designed for slow speeds. Other than a drill press I have
found that a battery operated hand drill is the best.
Mike Robertson
RV-8A N809RS
6.1 hours now
>From: Mark Gilbert <mgilbert(at)ix.netcom.com>
>Date: Thu, 30 Nov 2000 20:29:40 -0800
>Mark Gilbert
>Sacramento
Date: Friday, December 01, 2000 1:04 PM
Measured on the ground and weighed on the ground.
Dennis
>08:33:29 PM
>To:
>cc:
>Ed,
>is
>your plane.
>inches.
>measurements.
>Hampshire, IL C38
>>Paul,
>has
>>the following W&B
>> C.G.
>>Fuel 70 0 0
>>Pilot 87.4 0 0
>>Passenger 87.4 0 0
>>Baggage 117 0 0
>> CG Empty Weight
>> 68.48 1170 80122.5
>exceeds
>>Hope this helps.
>>Ed Anderson
>>Matthews, NC
12/01/2000 02:22:24 PM
Greenlee makes a "unibit" clone that dosen't work near as well as the real
unibit. Home Depo was out of Unibits and I needed the bit. I purchased the
Greenlee (very good commerical electrical qualitity stuff) clone unibit(in
electrical section not the tool coral--grunt-grunt) . The Greenlee is not
self centering, does chatter and bores a octagon hole rather that a true
circle hole. I end up using the Greenlee to approach my hole size and
finish with the unibit. Save your money and buy the real unibit....
"Cy Galley" (at)matronics.com on 12/01/2000 08:28:10 AM
cc:
Subject: Re: RV-List: Unibit in an Airdrill
Is
> Mark Gilbert
conduit
> Sacramento
Subject: | Re: Need to buy an RV-6 project/tools in the SEUS |
12/01/2000 02:35:48 PM
vern, be sure to try barnstormmers.com. Also, try the links to all the web
based Vans wings. Some of the larger wing groups are listed on the links
section at the Vans website.
"Vern Darley, 11" (at)matronics.com on 12/01/2000
11:11:45 AM
cc:
Subject: RV-List: Need to buy an RV-6 project/tools in the SEUS
prefer SE US since I'm in Atlanta so transportation will be easier.
Thanks!
Vern Darley
5 Perthshire Drive
h-770 487-5155
12/01/2000 02:38:31 PM
What brand is the double fluted one. The Greenlee brand unibit is almost
useless...it has a double flute. See my post for a writeup on the Greenlee
"Steven DiNieri" (at)matronics.com on 12/01/2000
01:40:22 AM
cc:
Subject: RE: RV-List: Unibit in an Airdrill
variety. this
I
Steven DiNieri
Mark Gilbert
Subject: | Re: OH NO!!! IT'S A PRIMER QUESTION!! |
12/01/2000 02:43:04 PM
I used Mar-Hyde gray. Its a low solid, quick drying etching primer on the
inside fuse. and pilot area. Holds up well, but not as good as a epoxy
primer. Mar-Hyde's not a bad way to go.
(at)matronics.com on 12/01/2000 01:46:21 PM
cc:
Subject: RV-List: OH NO!!! IT'S A PRIMER QUESTION!!
Listers,
green cockpit.
--Mark Navratil
Cedar Rapids, Iowa
RV-8A flaps
The O-360 IS approved for 91oct mogas. See Petersen's website at:
http://www.webworksltd.com/WebPub/PetersenAviation/PetersenAvi
Dave
menavrat(at)collins.rockwell.com wrote:
> Carey,
> it works just fine...
Subject: | Lycoming and Auto gas |
If you look at the following Lycoming publication, titled "Do Not Use
Automotive Gasoline In Textron Lycoming Aircraft Engines That are Certified
for Aviation Gasoline"
http://www.lycoming.textron.com/support/publications/do_not_use_automotive_g
as_in_aircraft.html
Lycoming spells out why they don't want you to do it.
Interestingly, it spends most of it's length talking about quality control,
or lack therof and never mentions lead.
Personally I wouldn't worry about the demise of 100LL. These engines have a
pretty low compression ratio and should run on much lower octane no problem.
I think most of the problems using lower octane occur when the pilot gets
behind on the leaning and causes detonation. Again I'm out on a limb here
cause I (unlike many on this list) don't really know what I'm talking about.
It just seems like the adoption of a FADEC-type computer technology will
allow us to use lower octane fuels without problems since the computers can
watch for detonation and adjust for it.
We should probably be extra-super-carefull about preventing vaporlock in the
fuel lines... if we do have to switch to a lower octane fuel that's one
problem a computer can't help us with.
Matthew Gelber
-8A fuse N48PP
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Dave Bristol
Sent: Friday, December 01, 2000 12:13 PM
Dave
> Carey,
O-360-A4A
Has
Subject: | 2 more days - 10% for Matronics |
Since new VFR and IFR chart revisions just came, we'll hold over our 10% for
Matronics offer for a couple of more days, (lets say till Monday) so that
anyone who needs can fill in or subscribe to your commonly used charts.
When you enter "10% for Matronics" in the special instructions box on our
on-line order form (or say so by phone), we will hold 10% of your order total
as a donation to the maintenance of the RV-list.
This is a simple and convenient way to donate to Matronics and at the same
time, being sure that your charts and approach plates are always up to date.
Andy
eCharts
http://eCharts.cc
Builder's Bookstore
http://buildersbooks.com
970 887-2207
New Chart Revisions as of 11/30/00 (now in stock)
SECTIONALS
New York
San Antonio
Kansas City
New Orleans
Brownsville
Anchorage
Seward
Fairbanks
TERMINAL CHARTS
New York
Boston
Kansas City
New Orleans
Anchorage
Facility Directories - all
Low Enroute Charts - all
Terminal Procedures - all
MISCELLENEOUS
VFR - IFR Planning Charts
Flight Guide - Central States volume
From: | "Doug Weiler" <doug.weiler(at)pressenter.com> |
Regarding peeling paint on engines... when I reworked the cylinders on my
0-320 (Citabria) I used Sacramento Sky Ranch's advice on painting engines.
I striped all the components (case, accessory case, etc). Then cleaned
thoroughly with lacquer thinner and Dupont 3812S enamel thinner. Then
painted with the usual Tempo Lycoming engine paint (no primer!!). Then I
managed to squeeze each component in the oven and bake at 200 degrees for 2
hours. Paint has been on for 4 years and is indestructible!
Doug Weiler
old
> Portland, OR
From: | "Douglas G. Murray" <dgmurray(at)telusplanet.net> |
Mark - I have used Marhyde 5111 self etching primer on a lot of my interior
and found that it is tough and holds up well against abbrasion. I think
that a final coat of paint is still the best finish.
Douglas G. Murray
Southern Alberta
Sent: Friday, December 01, 2000 11:46 AM
> Listers,
> green cockpit.
finish
> --Mark Navratil
> Cedar Rapids, Iowa
> RV-8A flaps
Thread-Topic: RV-List: O360 Engine
Thread-Index: AcBb30aDIVYXnXsKTnizZtw7nnqpwAAAD32w
If you look at Lycoming's website, the article I read in the key
reprints section seems to be pretty clear on their opposition to using
autogas. Some of the reasons they list are inadequate lead to lubricate
the valves and additives only present in auto fuel can cause internal
corrosion. On Petersen's site, they recommend a tankful of avgas
periodically to lubricate the valve stems. When avgas is gone (which
looks like it WILL happen soon) I hope a better alternative is
available, with some sort of lead-substitute.
Bob Japundza
Speaking of cockpit paint, what brand and color gray do most people use?
Gary Rush
RV8 Carlsbad, CA
> From: "Douglas G. Murray" <dgmurray(at)telusplanet.net>
> To:
> Subject: Re: RV-List: OH NO!!! IT'S A PRIMER QUESTION!!
> Date: Fri, 1 Dec 2000 13:53:29 -0700
> Douglas G. Murray
> Southern Alberta
> From: <menavrat(at)collins.rockwell.com>
> To:
> > Listers,
> > green cockpit.
> finish
> > --Mark Navratil
> > Cedar Rapids, Iowa
> > RV-8A flaps
From: | "Dave Berryhill" <dwberryhill(at)home.com> |
Subject: | Re: Lycoming and Auto gas |
.....snip
a
problem.
about.
............snip
I know even less than Matthew about these things so forgive me if this is a
stupid question: What about an automotive Octane Boost additive? Is there
any reason you couldn't (or shouldn't) use this with Av gas?
Dave
Subject: | Re: FWIW: Left Hand Drill Bits |
Hi Fred
No offence but... if you drill through 2 pieces of metal, the left hand
drill bit still tries to lift the top sheet up.
The lifting up occurs because the top sheet tries to ride upwards the
flute spiral before the next hole is started through the bottom sheet.
the flute spiral in the drill bit is formed to effectively remove
debries away from the hole being cut. This is thru for left and right
hand drill bits. It's like left hand thread and right head thread,
turned in the correct directions, both fasten things together.
Am I missing something obvious here (very well possible)
Gert
Subject: | Canon Connectors |
The thread on using Canon connectors to transverse the firewall sounds
intriguing. The Newark Electronics catalog has a bunch of sizes/shapes.
Can someone educate me as to exactly what the procedure and/or
connector type is? As an example, there is something called a "wall
mount receptacle". Is this mounted on the firewall? Which side? Any
verbiage that doesn't leave me dangling or dimpled would be appreciated.
Rick Jory RV8A QB
I try and clamp a piece of wood behind the hole, This stabilizes the
unibit and gives round holes , even with a air drill. Done it many a
times.
Just got through drilling the holes for the back seat throttle through
the f805 and f804 bulkheads. With a good piece of wood you can offset
drill overlapping unibit holes and file the sides straight where needed.
Even in a drill press I try and clamp a chunk of wood to the piece to be
drilled whenever possible. The wood guides the drill and prevents it
from wandering around.
Hope this helps
Gert
> Mark Gilbert
> Sacramento
Subject: | Re: RV-8(A) Vent |
No, you won't need it.
hillstw(at)aol.com
rv8a---100hrs
Subject: | Re: Canon Connectors |
Rick,
You're right about it being confusing. The wall mount plugs have a flange
on them usually with screw mount holes. But even that can get confusing
because there are wall plugs that will have different barrel lengths for
mounting on one side or the other of the wall. I know that sounds crazy but
I've seen them. Then there are screw in plugs and then quarter turn plugs.
It goes on and on. This is one of those areas where I have found it easier
to find a local industrial electronics shop and tell them exactly what I
want.
Now if I just wasn't in Hawaii where they don't even know what I'm talking
about half the time, let alone have any type of selection, Ha, Ha.
Mike Robertson
RV-8A N809RS
6.1 hours
>From: "Rick Jory" <rickjory(at)email.msn.com>
>To: "RV-list"
>Subject: RV-List: Canon Connectors
>Date: Fri, 1 Dec 2000 16:14:25 -0700
>Rick Jory RV8A QB
Subject: | New and improved RV-8/8A wings |
12/01/2000 08:00:58 PM
I just noticed in the latest RVator that Van's has redesigned the 8 wings.
"These improvements, and other minor modifications have had the effect of
increasing the strength of the spar and wing slightly and allow us to rase
the aerobatic gross wieght of the RV-8/8A slightly, to 1600lbs." Anyone
know what the old gross weight was? Just wondering how much improvement
this represents.
Jim Andrews
O-360 A1A Sensenich 85
N89JA reserved
Subject: | Back-Up Belts; was RV Aerobatics |
I am interested in putting a back-up lap strap in my RV-4 for neg. 'G'
work. I would think that you would want complete redundancy. This would
include all failure modes: the strap, the latch and the mount. Has anyone
selected an alternate lap belt mounting point on an RV-4?
Ted Lumpkin
From: Jones, Bryan D. <bryan.jones@lyondell-citgo.com>
Date: Friday, December 01, 2000 9:19 AM
Subject: RE: RV-List: RV Aerobatics
a
fly
>flying inverted.
>just my 2 cents...
>Pearland, Texas
>From: Terry Burch [mailto:rv6man(at)earthlink.net]
>From: "Dave Berryhill" <dwberryhill(at)home.com>
>To:
>> I see that Van's doesn't recommend any negative g aerobatics in the RV's
>> (but says that some mild positive g aeros are o.k.). Is this due to the
>> structural limitations of the planes or because of the fuel and/or oil
>> systems?
>> Dave
Subject: | Re: New and improved RV-8/8A wings |
> this represents.
> Thanks,
> Jim Andrews
> N89JA reserved
Hi Jim,
The old aerobatic gross weight was (& still is for those of us with 'old'
wings) 1550 pounds. So, the slight improvement was 50 pounds.
Ken Balch
Ashland, MA
RV-8 #81125 N118KB (reserved)
getting ready to mount the gear
The old wing was good to 1550 pounds in aerobatics... wonder what they
changed that made it stronger? Anyone know?
Now I finally have something about which I can say: "Back in the old days,
let me how we did it... you kids don't know nothin' bout pain!"
Matthew
-8A fuse N48PP
Sent: Friday, December 01, 2000 6:02 PM
Subject: RV-List: New and improved RV-8/8A wings
this represents.
Jim Andrews
N89JA reserved
I worry like hell about it. It isnt just octane that is the problem. It is
the lead.
The valves need it. The done alot of research and so far the is no good
replacement for
100LL. Our alternative would be to all lower our compression and loss
hp.Terry
Sent: Friday, December 01, 2000 9:01 PM
." Anyone
1550.Terry
Subject: | Re: RV6 slider track fairing |
> How do you bend the slider track fairing? I have tried using a small
bending
> brake, but the bends are too close together to fit in the brake. Is there
a
> better way?
This is the one part I never could figure out why Van's won't supply. And
unless they've updated the plans, they don't even give you an inkling of how
you'd go about making one. I suppose you could make it by hand but really it
needs a form and press, or fiberglass. If I were doing it today I'd make it
out of fiberglass.
Gary VanRemortel used to supply aluminum ones but currently doesn't -- ref.
the following post from October:
> List: I just got an E-Mail from Gary VanRemortel and the Slider Rail
> Fairing is no longer available do to the lack of access to a 30 ton press
> used in there manufacture.
> Gary says he will make more (Sold the original 100) if he can find a
> press. How many other builders could use this product? Maybe with
> enough customers for Gary we could speed up the search for an
> available press? Perhaps another builder has a line on a press?
Portland, OR
Again, I'm probably wrong but as I understand it:
Octane is a measure of a fuel's ability to resist detonation. One of the
things lead does is raise the octane. I said I wasn't worried about this
because of the relatively low compression ratios aircraft engines use
compared to auto engines (=lower risk of detonation). The reason cars get
away with it is because they have computers that make sure this doesn't
happen. I don't think it will be any great problem for FADEC-type systems
to allow the use of auto fuels in the future, without lowering our
compression ratios and power at all.
Supposedly another thing the lead does is lubricate the valves, but Lycoming
doesn't give this as a reason for not using auto gas. If you look at the
document I quoted, their biggest beef with autogas in their arguments
against it are quality control. They say that some of the additives in auto
gas corrode the valves- I think that's in important distinction, they don't
say that lead is the only thing that can lube the valves. Lowering our
compression ratios won't help the valves at all, that's for reducing the
possibility of detonation.
To sum up my thoughts, the 3 biggest problems with UL gas are:
1) Detonation with lower octane fuels. I can't believe this will be a
problem with our 8.5:1 compression ratios as long as we have FADEC-type
controls, and would probably be fine without these controls. Those with
10:1 pistons might have a problem... maybe...
2) Lubrication of valves- I've got no answer for this one- maybe someone
knows how all those old cars run on UL gas?
3) Vapor lock- could be a problem, and something we should think about now
while we build our fuel systems- keep those lines away from the exhaust!
The EAA says that 68% of the GA fleet can use 82UL (auto gas). Does anyone
know what that 68% represents, and what the limiting characteristic of 82UL
is for the other 32%?
Sorry if any of this seems off-topic or stupid, but I'm actually really
interested in why 100LL supposedly spells doom for us. I just don't see how
8.5:1 engines couldn't run on autogas as long as they had a computer control
to manage timing and mixture- many cars are 10.5:1 and race motorcycles are
often 12.5:1 on fuel that's cheaper than avgas. I can see how I (low-time
pilot) could ruin an engine through improper leaning, but not if a computer
runs it.
And it can't be that hard to lubricate the valves... or is it?
I guess I should add that I'm worried enough about the 100LL demise to
consider fuel-injecting and FADECing my engine...
Matthew
-8A fuse N48PP
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Terry Burch
Sent: Friday, December 01, 2000 3:50 PM
Subject: Re: RV-List: Lycoming and Auto gas
the lead.
replacement for
hp.Terry
how
it
it
> out of fiberglass.
It really is quite easy to file up a piece of oak or maple, and bend a piece
of .025" aluminum for this fairing. Including chucking the first couple
tries out, I bet I didn't have 45 minutes in that part. Finish the canopy,
close it, take a few measurements and then go find the block of wood.
Alex Peterson
Maple Grove, MN
6A
------ http://USFamily.Net/info - Unlimited Internet - From $7.99/mo! ------
Gary ,
I used a light gray color in the interior. It is made by PPG and is called
concept paint. A very high gloss and tougher than nails. I was happy to see
that it matched Van's powder coating when he started that service. My dash
and center console is painted a satin black. It seems as though most
builders color the dash to match the interior but I like black dashs.
Douglas G. Murray
Southern Alberta
Sent: Friday, December 01, 2000 3:22 PM
> Thanks,
> Gary Rush
> RV8 Carlsbad, CA
> > To:
interior
> > Douglas G. Murray
> > Southern Alberta
> > To:
> > > Listers,
to
self-etching
to
as
a
> > > green cockpit.
> > finish
> > > --Mark Navratil
> > > Cedar Rapids, Iowa
> > > RV-8A flaps
Subject: | Unibit in an Air drill |
I picked my twin fluted Unibit off the snap-on truck, so I'm not quite
sure
what manufacture it is. our guy carries a lot of non snapper tools to fit
specific needs.. doesn't say on it.
Mathew and listers,
I've been using auto gas for 15 years in my airplanes. That includes
three of them: a C172 with a O320 145hp engine, a Cheetah with a
O320 150hp engine, and my RV-6A with a O320 150hp engine.
Maybe I can give some insight from my experiences.
>FADEC-type controls, and would probably be fine without these
>controls. Those with 10:1 pistons might have a problem... maybe...
I'd say you're right on with this assumption. Fortunately, I've always
had low compression engines and have been able to run 87 octane.
There has never been a problem with the cylinders that I can relate
to the usage of auto gas. Of course, when one uses the aviation
formulas for 87 octane auto gas, it's 82 octane as suggested for the
82UL avfuels.
When I was ready for an engine for my RV-6A, the choice was
obvious to me. I'm not an aerobatic nut and didn't need the high
performance some of you look for. I decided on the 150hp O320 so
that I could safely use auto gas and not have to worry with the AD
on the crankshaft prop flange area. So far, that decision has worked
out just fine.
Petersen does state in letters that I have that many of our higher
compression engines can run on higher octane auto fuels. I don't
remember which ones, at this time; but, I do know that I'll have no
problem finding an engine for a four place RV that runs on auto gas,
if Van ever comes out with a four placer. :-)
>someone knows how all those old cars run on UL gas?
I don't know about old autos; but, my aircraft engines have run just
fine on it. I've had two opportunities to look at the insides of my
aircraft engines (spell that expensive looks) due to internal problems.
The first was due to a cam going sour after I had flown my Cheetah a
couple of years. It had about 1100 hours on it, at the time. We
found nothing in the valves that was unusual. The exhaust valves
had to be replaced; but, the intakes were just fine. The cam problem
seemed to be a common one, especially for an airplane that had sat
for a while. Mine had before I bought it. The engine overhaul was
not too expensive and used many of the old parts. The second
opportunity was this year when I had a valve seat go after 500 hours
of use. It was #3, the hottest cylinder. I attributed the seat problem
to heat. My RV had the same problem until I lowered the temps with
the dam in front of #1. I could still use a higher dam for that. In both
cases, the valves had normal wear and tear.
In the STC I had for the Cheetah, it was recommended to add some
100LL every once in a while. I do this a couple of times a year. It's
worked for me, thus far. An easy way to replenish is to buy some
100LL on a long cross country when I can't get auto gas.
>about now while we build our fuel systems- keep those lines away
>from the exhaust!
That's a good statement whether you use auto gas, or not. I've got a
lot of experience with vapor locks. All have been on the ground. In
every case, it was when I needed to do a fast turnaround. In the
Cheetah, it was usually very easy to clear the lock before takeoff;
but, the RV is a tough one to clear. For it, I just plan my takeoffs
about half an hour after I've landed just to give the gas a little time to
cool down in the lines. Works like a charm.
Personally, I don't think we're going to have to worry too much about
the loss of 100LL because we do have a choice of engines. I did
chose a lower compression engine that works for me. The FADEC
system could be the answer for the rest of you who have to have the
power. Personally, I'm not too worried about the loss of 100LL if I
can find something that will replace the lead that I get from time to
time. Even the loss of that may not be as big a problem as we think.
Jim Sears in KY
RV-6A N198JS (about 77 hours on the tach)
There's a large difference in the detonation resistance of different
engines that has nothing to do with compression ratio. Combustion chamber
shape is a factor (wedges--like a GM small block--are better than
hemispheres, for example). Combustion chamber temperature is also a big
factor, especially exhaust valve temperature. So an air-cooled engine is
automatically at a disadvantage. I don't know how the Lycoming combustion
chamber fares, but I suspect it's not great since it was designed before
the problem was well understood. The relatively high octanes specified,
and the relatively low compression ratios, indicate that detonation is a
problem with these engines.
FADEC will help solve this problem. But, as the AvWeb article mentioned,
this creates another problem for certified airplanes: recertification for
the lower performance with the lower-octane fuel. Fortunately,
re-certification's not a problem for homebuilders. But to the extent that
it hurts the general aviation industry it will affect us.
Street-rodders retrofit hardened valve seats to their heads if they're
going to run unleaded fuel in an older engine. Some also use fuel
additives.
It appears that Lycoming valve stems receive marginal lubrication already,
given the stuck valve problem. So I'd be a bit worried about that, too.
Tedd McHenry
Surrey, BC
Subject: | Wires through the firewall |
12/02/2000 06:29:42 AM
Thanks to all that replied to my query. Lots of good ideas. I don't know
why I never considered electrical plugs but it's definitely a good
solution. I also found that Van's catalog is one of the few that carries
the larger firewall shields FYI. There is also a good write up in Fire
Wall Forward regarding the split grommet approach that sounds pretty good.
Now back to the project to put some of these ideas to good use.
Glenn, if you get this, I accidentally deleted your post and would really
like to read it. Could you please resend at your connivance.
- Jim Andrews
RV-8A ( cowling and FWF )
O360 A1A Sensenich 85
N89JA reserved
Mike,
While we are on the subject I thought I'd mention this .
A bulkhead fitting ( amp connector) would make a nice neat installation.
You will of course have to satisfy yourself of the fire and smoke thing.
But I wanted to mention that Amp makes a neat screw-on plug cap for these
and you can get them with safety wire holes in them.HTH
Larry Mac Donald
Rochester N.Y.
> flange
> confusing
> for
> crazy but
Subject: | Re: First Flight of N331DH - RV6 - SN21754 |
congratulations & well done
i hope to be flying by sun - n - fun.
way to go
scott
tampa
rv6a hanging engine today
Subject: | Re: RV6-List Digest: 2 Msgs - 12/01/00 |
Vern: A few days ago, there were a couple posted in this forum for sale
by one individual...in varying stages of completion. Doug Bostard
Subject: | RV Insurance Emotional. |
I am pissed and if you don't like ranting and raving on the list DELETE NOW.
Over the years it has bothered me that others on the list were getting
higher coverage's at lower costs. A couple of times I requested more
information from the poster but I don't recall getting any. I took these
quotes into Regal (my agent at the time) and showed them. Their response
was, that when they dig into these things they always find differences that
justify the increased cost. This year I decided to shop my insurance and
yes I was aware that insurance carriers block this sort of thing. I chose
both National? with the Vanguard program and SkySmith. National, which I
believe runs their program through Phoenix, came back no quote because Regal
had already requested a quote. I asked the man at National what he thought
I should be paying compared to others he had insured. He gave a figure that
I later compare to what Regal would have charged me at that same carrier and
found out and Regal was about $200.00 higher. SkySmith came back with a
quote from AIG. It was $949.00 for my 1993 RV6A with G&F hull coverage at
55,000, liability 1 mil, Medical 1,000, deductibles 100/500. Regal had been
covering me with AIG at $1500.00, $1200.00, and now wanted $1282.00 for the
same coverage. I tried to go with SkySmith, but it came to light that Regal
had been quoted $1282.00 and therefore AIG was withdrawing the $949.00. To
me this looks like collusion and I don't buy the crap that this is done for
the pilots benefit. I don't think these are the only carriers doing this.
Years ago I tried to get quotes from AVEMCO through AOPA? and the prices
were ridiculous. I came away from that experience thinking that these
organizations were getting together at the expense of the pilots.
I talked with the guy at National (sorry that I forgot his name) and he
explained that National was running a special program through Phoenix to be
very competitive. I believe he told me they were insuring over 300 RV.
I also talked(???) to Scott at SkySmith about this $350.00 extra and he
confirmed that had I gone through him originally, and had Regal not been
able to block me, they would have charged the $949.00 through a special
program that they had with AIG. He also told me that he had some 200 RV
insured. That would be about 500 RV out of 2500 RV flying. These agents
may only deal with those planes in the USA which I assume might be the
majority. Also subtracting planes that are self insured, then there must
still be a lot of RV's out there insured with agents other than either of
the two agents above. I would like to know where you RV owners are insuring
your planes and why. Are you getting screwed like I have been and can this
situation be changed?
Gary Hanson
246RV RV6A
Subject: | Re: Wing skin order of installation |
Gary, this is what I did also. I called Van's and they told me the
instruction manual used to say to put the leading edge and tank skins on
first but after they saw Art Chard and how he built a wing, they changed the
instructions. I guess it really is a matter of personal preference.
Marty, Skinning RV6A fuselage in Brentwood TN.
Sent: Thursday, November 30, 2000 10:59 AM
Subject: Re: RV-List: Wing skin order of installation
> Hi Gary,
> I installed the leading edge and tank skins first and then the main skins.
> This allowed me to butt the main skins up against the leading edge and
tank
> skins before drilling and created a nice tight seam line where they meet.
It
> works great and no trimming of the skins was necessary. BTW I also have
the
> pre-punched skins.
> Happy Building,
> Eric Newton Long Beach, MS,
> RV-6A N57ME (reserved) (Fuselage)
> Eric's RV-6A
> Construction Page
> In a message dated 11/30/00 9:42:19 AM Central Standard Time,
> ggunn(at)uswest.net writes:
> << I'm working on my -6 wings and was wanting to know the order of skin
> installation most folks
> do. The plans tell you to install the main skins first and the video
> does the leading edge skin first. >>
From: | "Bill Shook" <billshook(at)mindspring.com> |
I can't say enough good things about PPG concept. I've done a fair amount
of spraying in my life, including doing it for a living for a couple years
in college. The PPG concept buffs out N I C E and is apparently very
tough. It's been on the front end of my GT-3 car for a couple years now and
even 150mph rocks hitting it with too much regularity has not phased it at
all. Some of the other paint, applied in Germany and generally considered
to be excellent, has fared well also...but the PPG Concept is holding it's
own a little better. For reference, my windshield glass is showing signs of
all the abuse, with tiny specks in it from rocks and track debris....but the
PPG which is on the forward most body panel shows zero signs of abuse.
Tough stuff. For reference I've also used Imron, Amerflint, and PPG base
clear.....and I like the Concept the best. Just a data point for you to
consider.
see
Subject: | Re: Unibit in an Airdrill |
Personally I would never use anything like that in the construction of an
aircraft. The unibit was developed for use in the electrical trade for a quick
and dirty hole, where precision is not required. Your best bet is to buy a
complete set of numbered and fractional drills.
Mark Gilbert wrote:
> If I use a unibit in an airdrill I get a sloppy hole drilling sheet AL ;
> the bit thrashes around in the hole because it does not stay centered. Is
> there a simple technique for using a unibit with an aridrill or is the
> unibit made only for a drill press?
> I seem to have problems with the simplest things.
> Mark Gilbert
> RV 6A - Wings - getting ready to drill rib holes for the electrical conduit
> Sacramento
Subject: | Pilot Building Time |
List,
My aircraft is now only days away from a DAR inspection. After spending the
last 2+ years building an aircraft I need to get ready to fly it. I have been
doing plenty of piper flying but no RV time as of late.
Anyone in the Tulsa, Oklahoma area who would like to have some paid for
(lunch, dinner, gas, oil, and what ever else) flying drop me a line. I would
like to get 10 hours or so in a 6 or 4 soon.
My aircraft is a 6 so a taildragger would be best but anything in the RV breed
would do fine. Just want to get that "sport" feeling down again.
Dustin Norlund
Owasso, OK
RV 6, "taxi testing" - Sand Ridge Airport Collinsville, Ok (10 NE of KTUL)
KD5JXZ - 2M, 440, APRS
Dustin Norlund
RV6 - Taxi Testing
PPSEL, KD5JXZ
Oops, sorry Ralph about that (now) generic name (CANNON).
I just walked through Allied Electronic's web site and found this procedure
to work:
www.alliedelec.com
click on catalog
select by manufacturer "AMPHENOL Corp."
click display document.
Page 519 - Miniature cylindrical connectors (these are MIL-C-26482, Series
1)
look for the bulkhead (PTB-PS) column heading.
If you have their catalog, page 518 shows pictures of the various plugs and
receptacles and gives the definition of how the part number is derived.
Disclaimer: I haven't used these before. I am just now considering them
based on a recent conversation.
Tom Barnes -6 electrical stuff.
Sent: Thursday, November 30, 2000 5:43 PM
Subject: Re: RV-List: Wires through the firewall
> Cannon (sp?) plugs look like a great idea.
> How about a hint as to how to find them in the catalog the link pointed
to.
> I tried cannon and plug - unless I did the search wrong...I'm willing to
> learn!
> Ralph Capen
quick
a
I, and I think most people, mainly use Unibits for large holes, generally
wire pass-thrus and things like that which don't need to be precise. Works a
lot better for those 1/2" and 5/8" holes than a twist drill would, IMHO.
Also work great when drilling a radius hole for a sheet metal inside corner,
they make a nice neat beveled "self-deburred" hole that doesn't take much
finishing.
Portland, OR
> Are these fuses then considered to be accessible in flight? That is a
> requirement isn't it?
No.
> Presently my fuse block hangs down from the front edge of the panel on the
> pax side. I have a short stretch cord that will hold it up which seems
> hokey but it is accessible in flight. But, is there a need?
Perhaps. There has been a whole lot of discussion about this in the past
however, I 'll bet if you go to the rv-list search engine and search for
"fuses & circuit breakers" you'll get more info (and opinions) than you ever
wanted on the subject! Also some stuff in the FAQ about it. In a nutshell,
there's no requirement for fuses or CBs to be accessible in flight, and
there is a lot of argument back and forth whether it's even desirable.
Personally I think it is but your mileage may vary.
Portland, OR
Subject: | Re: engine hanging party part deaux |
Scott, you forgot to give directions or a phone number.
Orlando
Sent: Wednesday, November 29, 2000 1:39 PM
Subject: Re: RV-List: engine hanging party part deaux
> dear listers
> well i feel confident it will get hung this time, weather permitting,
> saturday 12,2,2000.
> around 12:00. food will be bar-be- que or something cajun, and some good
ole
> fashion lie swapping. everyone is invited. aaaayyeeeeeeeee it don't get
no
> better than this.
> ya'll come
> scott
> tampa rv6a hangin engine again.
The unibit is really nice to enlarge hole is sheet metal as it does a much
better job than an ordinary twist drill. It produces a round smooth hole
unlike what happens with a twist drill. Now if you use a reamer after the
twist drill then the holes are comparable.
When working plexiglas, a unibit is the only way to go as it doesn't grab
and crack the plexiglass on breakthru like an ordinary twist drill. The
grabbing still occurs with a twist drill with negative rake.
If you haven't tried one, you don't know what you are missing.
Sent: Saturday, December 02, 2000 9:18 AM
quick
a
Is
> > Mark Gilbert
conduit
> > Sacramento
>of an aircraft. The unibit was developed for use in the electrical
>trade for a quick and dirty hole, where precision is not required.
>Your best bet is to buy a complete set of numbered and fractional
>drills.
Man, did you ever leave yourself open for flaming with that little
statement! Many of us can't agree with you on that one. :-)
For most of us, the Unibit is a must in the construction of a RV. I
have two sizes of them. I found mine to be very useful for drilling
sizes that I didn't have bits for in places where precision was not a
must. With care, nice holes could be made with pretty good
precision. I used the small Unibit to enlarge the holes in the canopy
because it doesn't grab like high speed drill bits. Try that with
numbered and fractional high speed drill bits if you want to see
cracks form in a heatbeat, or should I say a skip of the heart beat
when it happens. Of course, there's the heart attack that follows
closely after the crack appears. :-)
As one who has built a RV-6A that had to have just about all of the
holes drilled by the builder, I'm very happy that I could use a Unibit in
many places and would recommend them to any builder as long as
the builder is willing to use a little care when drilling with them. I can
honestly say that my RV-6A hasn't fallen out of the sky from using the
Unibit. I suspect something else will cause that to happen long
before the Unibit drilled holes will.
Jim Sears in KY
RV-6A N198JS
All this talk about the change in Av fuel has made me wonder......When Uncle
Sam stopped the production of leaded gas for autos years ago, it didn't take
long for the automobile manufacturers to make changes in car engines to run
without it, especially with regards to the valves (hardened valve seats,
etc.). I know that auto companies produce a whole lot more engines than the
aircraft companies but are the companies that produce airplane motors
planning on making any design changes for the inevitable loss of lead in Av
gas?
Dave
In a message dated 12/01/2000 10:51:30 AM Pacific Standard Time,
menavrat(at)collins.rockwell.com writes:
<< Part of the problem right now is that
autofuel carry regular unleaded because it's cheaper. >>
My guess is that in the future, there will be STC's for 180HP spam cans, and
that
high octane mogas without alcohol, etc. will appear at the fields.
Subject: | Re: RV Insurance Emotional. |
Gary,
Try giving Mac McGee a call at Aviation Underwriting Agency (AUA). He
has always given us really good service. His number is 800-727-3823.
George and Becki Orndorff
Subject: | newbie (sort of) questions |
1) Does it make more sense to build both wings at the same time instead of
building only one wing jig and only doing one wing at a time? If so, why
aren't more people doing it that way?
2) If primer is not actually a good corrosion resistor and is meant more to
prep a surface for painting, then why are folks usually only priming and not
painting the the non-alclad aluminum and steel surfaces.
3) Is there a primer which is non-toxic, non-carcinogenic and doesn't smell
up the whole house when you use it in the basement and can be used up NORTH
where it's darn cold in the winter? :-) If not, at least not
toxic/carcinogenic?
4) Does a self-etching primer mean you don't have to use something like
Alumaprep before applying the primer? Can you just spray a self-etching
primer right onto unprepped aluminum/steel?
5) Is the Home Depot combination type paint & dust cartridge filter air mask
good enough?
6) Any old aircraft maintainers vouch that alclad alone is good enough in
high humidity areas over a long time?
oh well, more than enough for now.
TIA,
lucky
Re: 1) Does it make more sense to build both wings at the same time instead
of
I built both wings at the same time and wouldn't do it any other way- I'm
sure it saved me tons of time and possible mistakes- no chance of reading
the plans backwards on the second wing. The jig was easy to build- I used a
single pair of uprights. The only difference is where vans plans show an
angle out on one side to support a spar, just use a 4' piece of angle
instead and attach the middle of this angle to the upright- you wind up with
one wing levered out on each side. Works like a champ!
The only downside is you do have to limbo in and out of the central space
when you need to work on the bottom skins, but it's not too bad (at least
for me, but older gents might not like it much).
Matthew
-8A fuse N48PP
[mailto:owner-rv-list-server(at)matronics.com]On Behalf Of lucky macy
Sent: Saturday, December 02, 2000 10:10 AM
Subject: RV-List: newbie (sort of) questions
toxic/carcinogenic?
good enough?
TIA,
lucky
After I bought one from ASOD, I went to Jenco Co. just out of Dallas. I
needed to pull the pins & replace them.
The boys at the shop said there is not a catolog, but they have a CD. HE
gave me 10 his & hers pins. I could see connectors in boxes as far as I
could see down the building. I think there are thousands of plugs, each
with different pins & extraction/insertion tools. Likely a bunch of
different crimpers also.
My experts & me have broken 3 extraxtion tools & I don't have any wires
out yet. Bernie just sent me copies of some spec pages, so I may learn
from that.
Don Jordan RV6A Arlington, Tx
writes:
> Rick,
> flange on them usually with screw mount holes. But even that can get
> confusing because there are wall plugs that will have different barrel
lengths
> for mounting on one side or the other of the wall. I know that sounds
> crazy but I've seen them. Then there are screw in plugs and then
quarter turn
> plugs. It goes on and on. This is one of those areas where I have
found it
> easier to find a local industrial electronics shop and tell them
exactly
> what I want.
> talking
> Mike Robertson
> RV-8A N809RS
> 6.1 hours
> >To: "RV-list"
> sounds intriguing. The Newark Electronics catalog has a bunch of
> sizes/shapes. Can someone educate me as to exactly what the procedure
and/or
> "wall mount receptacle". Is this mounted on the firewall? Which side?
> Any verbiage that doesn't leave me dangling or dimpled would be
> appreciated.
> >Rick Jory RV8A QB
Subject: | Re: Left Hand Drill Bits |
> Snap On tools sell them.
> They are primarily used to drill out broken bolts<<
> Also to drill holes for left hand taps.
HUH?? Whats the connection here?
Cecil Hatfield
I pay $1030.00 for 35k coverage.I don't want to take a hit for the
total loss.I am with Bodi&Wachs of Wakegan.Phone (847)249-5350
date.)
You may be right about 8 to 1 but H pistons 9 to1 do not like auto
gas.This could wreck your engine.
Subject: | Re: newbie (sort of) questions |
Come on over to the airport and I can show you two good-looking (from 30
feet) Cessna 170-A's that can't be (economically) repaired from the
INTERNAL corrosion. Pop an inspection cover and it looks like someone shook
a bag of powdered sugar in there from the corrosion. If you live in a
high-humidity area, do what you can to make your airplane last forever.
Michael
Subject: | Re: Sticking Brakes |
There was a time when there were some short Cleveland master cylinder
return springs shipped in error. The archives will have the details, but,
the bottom line is make sure your springs are the LONG springs and not the
short ones; otherwise your master cylinder will not be pushed back enough.
It depends on when your kit was shipped. There is a certain length (in
inches) which you have to measure with the spring OFF of the brake. Van's
probably has the measurement for the correct spring. I had the short ones.
I e-mailed Vans and they shipped me a new set for no charge.
This may have nothing to do with your problem, by the way.
Michael
Subject: | Unibit in an Airdrill |
The unibit holes I've drilled during my project are top notch. Much cleaner
that the standard drill bit holes. All have been done using a slow drill
press.
Just another point of view...
Larry Bowen
RV-8, starting gear boxes
Email: Larry(at)BowenAero.com
Web: http://BowenAero.com
> -----Original Message-----
> [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Gerald
> Richardson
> Sent: Saturday, December 02, 2000 10:19 AM
> trade for a quick
> is to buy a
What type of switches do you plan on using? There are so many to choose
from. I am only consideing switches with ratings that are at least 20 amps
at 12VDC.
I have decided that I will use one of the modern lighted switches. The auto
parts, trucks, and marine after market sales outfits have zillions to choose
from in the $10 range. There are generally two ways to go with this. Toggle
switches or rocker switches. Toggles mount in round 1/2" holes and are
considered more versitile. This is a standard hole so they can be replaced
or changed very easily later in the service life. This is the way I will go.
The other option are rocker switches. They are available in many very cool,
modern styles. I have found that most need a thick panel and a very
perfectly cut rectangle hole. (They are mostly designed for plastic
dashboards) They end up loose if you don't make a perfect hole. This is
difficult for the home builder to come up with. Relacements later in life
must match exactly. But there are some seriously sexy rockers out there for
dirt cheap. Every car parts store has a Cole Hersee catalog. Check out the
58328 serries on page 26. I have a bunch of 58328-11 and 58328-04 rockers
(different project) and have them running on the bench. You should be able
to find them for around $10-12 USD and they take 25 amps at 12VDC. These use
a very small bulb that is on all the time so the lens always has a slight
glow. When the rocker is thrown it uncovers more of the bulb so it brightens
up. It is obviously set up for vehicles because it is not very bright. It
could mount high in a panel without bothering the pilot.
Just for a look see I bought a sample Cole Hersee 54109-01 (54110-01 for
flaps). This is a wedge shaped toggle where the whole toggle is illuminated
clear/off and red/on. Very cool looking but all plastic. It makes alot of
light so I don't think it would be good near the top of the panel. I don't
know yet if any of these lighted switches can get onto a dimmer circuit.
Furthermore I should mention that any illuminated switch probably shouldn't
control something off the battery bus.
I have decided to go with lighted toggle switches. I first got interested in
them when I saw them all over the panel of a new truck. They look stunning.
The toggle is made out of aluminum with a small light in the tip. They look
like a lighted diamond sitting on a pedestal. They glow a pale clear color
when they are off then change to green when turned on. I traced the dealer
of the truck and bought one from their parts department. It is made in
Mexico by Carling and has the number 9803 on it. I don't know the rating so
I can't use them. I also got the equivilent spring to center flap switch
there by the same maunafctor with 9915 on it. Both use srew on terminals. I
require fast on tabs called blade terminals. See website for link to the
main company:
http://www.carlingtech.com/index.htm
I have not been able to trace this part number as their local dealer only
takes custom orders with a min of $500. The car parts store had an almost
identical switch made by Cole Hersee. They claim it is a new product, 25
amps at 12VDC, silver contacts, blade terminals, lighted clear when off and
red when on. Part # M-54111-01 for regular on/off switches or M-54111-02 for
the flap switch. I bought a sample and it is made in the USA. The down side
is the toggle is plastic and the on color is red. I would rather have green
on/ clear off. On the other hand these are so easily available and cheap. If
you take a trip to an auto parts store you can browse the Cole Hersee
catalog. You might even be able to get a copy of one. Good for the shop
because it has the wiring diagrams.
I guess I'm trying to find out from you guys if others have looked into this
in detail and found these same switches. They don't appear too bright but it
would be invaluble to hear from some one flying with these.
November 27, 2000 - December 02, 2000
RV-Archive.digest.vol-js
