RV-Archive.digest.vol-jw
December 17, 2000 - December 22, 2000
From: "jayeandscott" <jayeandscott(at)compuserve.com>
Subject: Re: Stall Speeds/Vortex Generators
Date: Dec 17, 2000
Well, yes and no. You are correct that it will stall at a higher indicated airspeed in a steep turn, but there will be no difference in the indicated stalling speed caused by altitude-that's why we fly high-the airplane accelerates until the drag equals the thrust-the same power setting must generate the same indicated airspeed at all altitudes-only the true airspeed goes up----- Original Message ----- From: Mike Nellis <mnellis(at)emailusa.net> Sent: Sunday, December 17, 2000 9:26 PM Subject: Re: RV-List: Stall Speeds/Vortex Generators > > Incorrect, the wing works on Angle of Attack not airspeed. > > For example, load the plane up to gross and it might stall at say.....55 > mph. > Take that same plane loaded to gross up to 8000' and do some steep turns and > I'll guarantee that it will stall at a lot higher speed than 55 mph. > > It's all about Angle of Attack not IAS. Typical stall warning devices are > angle of attack sensors not airspeed sensors. > > Mike Nellis - RV-6 N699BM (res) > Plainfield, IL > Building Tanks > http://mnellis.jnet.net/rv-6_page > > > > > > You're right. Indicated airspeed is all the wing works on- TAS and GS are > > for navigating. The only variable could come from unstable air -as in > slight > > updrafts or downdrafts occuring during the two test flights. > > ----- Original Message ----- > > From: Builder's Bookstore <winterland(at)rkymtnhi.com> > > To: > > Sent: Sunday, December 17, 2000 2:37 PM > > Subject: Re: RV-List: Stall Speeds/Vortex Generators > > > > > > > > > > > > > I put vortex generators on my RV6A....what is REALLY puzzling me is > how > > to > > > > reasonably determine the stall speed. > > > > > > > > > > I have my VG set, but haven't installed them yet. When I do, I'm going > to > > look > > > at both indicated airspeed and groundspeed as measured on the GPS. > Between > > the > > > two, I should get a reasonable idea of what the VGs are doing. However, > > the GPS > > > comparison figure is just for academic interest and has no real value. > > > > > > The bottom line is that I don't really care what my calibrated or true > > stall > > > speeds are. From the operational point of view of the pilot, all that > > really > > > matters is Indicated. (Yes, I'm wearing my asbestos suit) I want to know > > how > > > "my" plane is going to respond in a short or power off landing > > configuration; > > > these being the times that the benefits of VGs will most come into play. > > > Indicated will always give that information in an easy to use and > > dependable > > > manner. Any other number is fairy irrelevant to the task at hand at that > > moment. > > > > > > Andy > > > > > > > > > > > > ________________________________________________________________________________
From: "Paul & Gerti RV-4 F-1 Rocket 006" <gertivs(at)netzero.net>
Date: Dec 18, 2000
> > I put vortex generators on my RV6A....what is REALLY puzzling me is how to > > reasonably determine the stall speed. > > > > I am using a TAS indicator...where should it be set? How does one account > > for all the variables without a drogue (spelling) static port, and without a > > very long pitot pick up? > > I take off at 7,500-feet, and do stalls at 10 to 11,000 msl so that probably > > needs to be taken into account....I am really out of my area of expertise > > (expertise, heck...out of my skimpy knowledge of such things!) My first thoughts when reading the VG discussion is why do we need them? The -4 (only model I have flown) is one of the most forgiving airfoils I have ever flown. Hi-lift, relatively slow stall speeds, long onset of burble before full stall...nothing devious whatsoever. But why was not the question...fair enough. How to detiremine the stall speed. 1. Use the aircraft configuration most used during the typical slow speed A. Fuel weight B. Passenger? C. Baggage? (Some may question the wisdom of using a passenger etc in the testing. But I suggest a stall speed test can only be useful if it gives a number in realistic situations) 2. Make sure the aircraft is balanced! A. Center the ball!!! B. Trim 3. Smooth stick A. smooth air B. Don't kill any snakes. Finger tips only 4. Test and retest until you can get a result that is repeatable. After 5 to 10 passes you will have the correct indicated airspeed and the confidence it is right Ditch the GPS. Ditch TAS. Don't worry about altitude. Has absolutley nothing to do with aerodynamic stall speed. Angle of attach is the ONLY detirminant of stall speed and IAS in 1 G flight is the most readily available indicator for most aircraft. My suspicions are that most pro VG people are not really trying to land slower but (more directly) to somehow have safer landings. Their hope is that with a slower stall airspeed the pilot will have a greater margin of er ror before inadvertantly stumbleing in to a stall during a approach turn or landing. Wrong!!!!!!! You can't substitute experience, a smooth stick and judgement with an indicator. But if an indicator of saftey is what you want, get an Angle-of-Attach indicator. (the Navy can't move without it) Short of that use INDICATED AIRSPEED. Paul Vander Schuur ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Subject: Fw: AVflash 6.51a
Date: Dec 18, 2000
----- Original Message ----- From: AVweb's AVflash <AVflash(at)avweb.com> Sent: Monday, December 18, 2000 12:13 AM Subject: AVflash 6.51a > AVflash Vol. 6, Issue 51a Monday, December 18, 2000 > > The Top Headlines From AVweb's Expanded, Illustrated > News Coverage At <http://avweb.com/n/?51a>. > > ALASKA AIRLINES FLIGHT 261: THE HEARINGS... > In the aftermath of the January 31 crash of Flight 261, where an Alaska > Airlines MD-80 plunged uncontrollably into the Pacific Ocean after > failure of part of the aircraft's stabilizer assembly, the NTSB is > uncovering some of the shortcomings of a number of systems currently in > place. We found out last week, through official FAA testimony, that > the jackscrew assembly (a 1960s design) has outlived its paper trail. > FAA officials testified that they could not provide an account of how > the part was approved -- nor could they provide records of the process > which approved it. So, what we are left with is a part with some 35 > years of flight history, but not a single official record or word on > how it came to be approved for installation in the MD-80. > > ...WHAT WE KNOW, NOW... > While the design of the jackscrew assembly was supposed to assure that > the failure of any single part within the assembly can *not* result in > complete loss of control, the crash of Flight 261 explains with > relative certainty that the failure of a single part *is* capable of > causing failure of other parts in the assembly and that those multiple > failures are quite capable of bringing down the aircraft. Further, > while the manufacturer was aware that the assembly was subject to > continuous wear, they were content in the notion that regular > maintenance could assure its operation. Alaska Airlines was inspecting > the jackscrews every 15 months, but the accident aircraft had flown > 8,874 hours since its last inspection -- well beyond the 7,200 > suggested by Boeing. The hearings revealed that the FAA had "accepted" > the carrier's jackscrew maintenance schedule. > > ...AND WHAT THE CREW SAID, THEN > The pilots radioed their Seattle base seeking advice and relaying their > understanding of the serious nature of the situation. Portions of the > communication that were made public last week indicate that the base > operators were not immediately aware of the magnitude of the problem. > This may have induced some agitation in the cockpit as ground-based > counterparts second-guessed the captain's decision to divert to LAX and > the problem proved its ability to overcome each sequence of corrective > measures set forth by the flight crew. During the aircraft's final > dive, the verbal exchange between the pilots appears to imply that they > attempted to stabilize the aircraft in inverted flight and work with > its gyrations to help them roll it back over and keep the nose near the > horizon with rudder and elevator inputs. But all attempts by the crew > to regain control proved futile as the MD-80 made its final plunge to > the ocean. > > ANOTHER OSPREY DOWN, SUSPICIONS UP > $30 billion worth of orders for 360 MV-22 tiltrotor Osprey aircraft > have been suspended pending the results of an investigation into last > Monday's crash, which killed four Marines. The Pentagon is assembling > a review board this week for the MV-22 program to determine if this > accident and three that came before it are indicative of a design > problem with the aircraft -- which is the product of a $40-billion > joint venture of Boeing and Bell Helicopter Textron. The aircraft was > piloted by the Marine Corps' two most experienced Osprey pilots. They > were on a routine precision approach in good weather, past the outer > marker, approximately seven miles from the field when the crew > transmitted an emergency call indicating that the aircraft was going > down. The Marine Corps' investigators are leaning heavily toward > suspicions of mechanical malfunction. > > THE HEWLETT-PACKARD INCIDENT: EMPLOYEE FALLS (?) FROM COMPANY PLANE > Sacramento, Calif., police have found what they believe to be the body > of a woman who, according to the FBI, either fell or jumped from a > Hewlett-Packard-operated de Havilland Twin Otter shortly after it > departed Sacramento airport last Thursday. The 15-seat aircraft, its > two crew and five passengers had made a precautionary landing at > Sacramento after departing Lincoln, Calif., prompted by an illuminated > door-unsafe light in the cockpit. After the landing, at least one > crewmember checked the door and the flight departed Sacramento for San > Jose. Initial reports indicate that the aircraft was roughly ten miles > out of Sacramento, at an altitude approaching 2,000 feet, when the door > opened in flight. At that time, one male passenger reportedly turned > around in his seat and saw that a woman was exiting the aircraft. > > NOTE: AVweb's NewsWire <http://avweb.com/n/?51a> contains more > details on this bizarre incident. > > SILKAIR, THE FINAL REPORT ... ON THE HEELS OF EGYPTAIR 990: On December > 19, 1997, a nearly-new Boeing 737-300, operated by SilkAir as flight > MI185, lost power to its flight data and voice recorders and plunged > from 35,000 feet into a river near Indonesia's capital city of Jakarta, > killing all 104 people on board. Last Monday, NTSB chairman Jim Hall > sent a letter to Indonesian investigators summarizing the board's > opinion on the accident -- that it only could be explained as the > result of intentional actions of one of the flight crew. Last > Thursday, Indonesian investigators submitted their final report and > ruled out the implied "pilot suicide" suggested by Hall's letter. > > CONCORDE BACK IN 2001: Maybe. The French Transport ministry has > announced that British Airways and Air France hope to carry out test > flights early next year -- possibly within the month of February. The > February "test" is an odd development in a timeline that does not > expect to see a completed crash inquiry until sometime in the spring. > It appears that the major safety enhancement will be new fuel-tank > liners, which (it is hoped) will greatly reduce the chance of a fire > the next time the aircraft suffers a burst tire on takeoff roll. > > SPIT FOR SALE: In a stunning combination of aviation and new-media > technology (Why does that sound so familiar?) online auction-house eBay > put a restored Mk XVIII (1945) Spitfire on the auction block this > month. The minimum bid was listed at a mere $1,800,000. At the time of > this writing, nearly ten days since the aircraft went up on auction, > bids had topped out at ... well, there were no bids. The aircraft is > one of ten Spit restoration projects completed by Historic Flying, a > company based in Saffron Walden, Essex, England. > > THE TROUBLE WITH MAJORS: Where to begin ... American Trans Air pilots > picketed at JFK this past Sunday. The pilots, through ALPA, have been > negotiating a new contract for eight months now. Delta appealed > Tuesday's ruling from a federal judge who refused to force the > carrier's pilots, who have been working without contract since > September of last year, to work overtime. At Northwest, union > representatives for mechanics insist that they are overworked. > Unfortunately for them, they can be fired if they refuse to work > overtime. And the beat goes on. > > KUDOS FOR AIRTRAN: Yes, really. AirTran Airways has been awarded > special recognition by the FAA for helping improve the inspection > process for the now infamous DC-9/717/MD-80/MD-90 jackscrew assembly. > To correct problems in a vaguely-worded Airworthiness Directive, > AirTran worked with Boeing as well as the FAA to develop work cards > that not only correctly instruct workers, but also present information > in a manner that humans can understand. > > CALL TO ARMS FOR NEW JERSEY PILOTS: Two recently introduced bills in > New Jersey are intended to prohibit the expansion or extension of any > runway within two miles of a population of 15,000 people or more, or if > a school is located within 3,000 feet of the proposed extension, or if > there is a residence within 1,000 feet of the runway. AOPA has already > mailed nearly 9,000 "Pilot Alerts" to New Jersey members, asking them > to voice their displeasure on these "anti-airport" bills to their local > politicians. > > APACHE FLEET TAKES TO THE GROUND, AGAIN: The Army has concluded, for > the second time in 13 months, that the best place for its fleet of 742 > Boeing AH-64 Apache attack helicopters is on the ground. Last November > the trouble was tail rotor bearings and transmission parts. Now, > apparently the tailrotor swashplate assembly (which effectively > produces yaw control) was found to be faulty on one aircraft at Fort > Bragg, N.C. With the Marine's grounding of the MV-22, you could say the > U.S. military is now "vertically impaired" -- at least to some small > degree. > > OVERSIZED LAWSUIT DISMISSED: According to court papers, the woman > weighs more than 300 lbs., and her accompanying proportions led > Southwest Airlines to suggest that she purchase one seat for herself > and an additional ticket for, well, the rest of her. Not surprisingly, > such treatment motivated the woman to respond through the U.S. court > system. Last week the scales of justice tipped against her when a Los > Angeles, Calif., Superior Court judge ruled that the carrier's policy > was neither illegal nor discriminatory. > > RHINEBECK AERODROME RECEIVES CHALLENGE GRANT: Nostalgic for the smell > of burnt castor oil and the roar of radial engines? Would-be > barnstormers need to visit the Old Rhinebeck Aerodrome in Rhinebeck, > N.Y., where they can explore hangars full of Bleriots, Jennys, and > Fokkers, then watch them fly in afternoon airshows. Whoops, you can't > go now, because the Aerodrome closes each fall for lack of climate > control in the buildings. That's what the recently awarded challenge > grant from the Thomas Thompson Trust in Boston, Mass., is for -- the > Trust will donate $25,000 if the museum can raise $50,000 in matching > contributions. > > NOTE: AVweb's NewsWire <http://avweb.com/n/?51a> tells > you how to contact Rhinebeck to make a donation. > > GREEK CONTROLLERS GET FIVE YEARS, SORT OF: A five-year prison sentence > was levied on two air traffic controllers who were found guilty of > negligent manslaughter with regard to a Ukrainian Aerosweet Yak-42 that > crashed into a mountain in 1997 while under their "care." Regardless, > the duo won their release on appeal and it is unlikely that they will > serve any prison time due to the nature of Greek misdemeanor law -- > which allows guilty parties to pay off their sentences at a rate of > $5.20 per day, or about $9,500 for the entire sentence. > > ON THE FLY... > <http://avweb.com/n/?51a&otf> > Martha King appointed to First Flight Centennial Advisory Board... > A knife-wielding passenger caused an AA jet to divert to LAX... > A Chinese attack jet "unofficially" crashed near a residential area... > Stanwyck Avionics developing graphical AWOS displays for the Internet... > Tennessee Museum of Aviation moves to Gatlinburg-Pigeon Forge Airport... > Workers ignited an old military rocket at the Bartow (Fla.) airport. > > _____________________________ > AVweb's AVscoop Award... > > Congratulations and an AVweb hat go out to Bill Salter, this > week's AVscoop winner. Submit news tips via email to > . Rules and information are at > <http://www.avweb.com/newswire/newstips.html>. > > _______________________________________ > New Articles and Features on AVweb > > _______ > COLUMNS <http://www.avweb.com/toc/columns.html> > "As The Beacon Turns: Rotor Fever" > Too often, pilots become set in their ways, think they know > everything and refuse to open up themselves to the many new > experiences aviation can offer them. So discovered AVweb's Michael > Maya Charles when he went with a friend for some impromptu > "training" in the friend's Hughes 500 helicopter. According to > Michael, it's like "a lot like trying to stand on a basketball on > one foot ... in a 40-knot, gusting wind ... with your eyes closed." > Sounds like fun, huh? > > ____________ > KLYDE MORRIS <http://www.avweb.com/klyde> > Klyde's vacation tour of NASA facilities continues, with a look at some > historical hardware and retired prototypes. But even with the latest > technology, it seems some design features haven't changed from NASA's > earliest days. > > ________ > TRAINING <http://www.avweb.com/toc/training.html> > "Obstacles" > Learning to fly is not without its challenges. They can range from > unsupportive and downright hostile friends and family, to the ever- > present financial bite flight training can take, to overcoming > personal fears and to just plain finding the time. AVweb's series > on primary flight training by Tina Gonsalves continues, as we ride > along with a brand-new student during her first few flight hours and > through her private pilot checkride. > > ___________________________________________________________________ > Reader feedback on AVweb's news coverage and feature articles: > <http://www.avweb.com/toc/avmail.html> > > Reader mail about Clinton's new ATC PBO, user fees, plastic planes, > and Klyde Morris. > > _______________________________________ > Sponsor News and Special Offers > > ________ > SHOPPING <http://www.avweb.com/shopping> > > ATTENTION AUSTRALIAN CESSNA 210 OWNERS/PILOTS: CPA IS COMING DOWNUNDER! > There are still a few openings left in Cessna Pilot Association's 210 > seminar being held in Sydney, Australia, February 2-4. It will be > quite awhile before CPA returns downunder, so if you operate a Cessna > 210 in that part of the world and have wanted to attend CPA's renowned > systems and procedures course, now is your chance. Open to both CPA > members and non-members, pre-registration required. Contact Garth > Bartlett or Heide Koekebakker > , or phone 1-805-922-2580 for further details > and to pre-register. > > CEE BAILEY HAS NEW LINE OF WEDGE-FITTING SUNSHADES WITH FREE SHIPPING > Cee Bailey's new line of wedge-fitting aircraft sunshades reflect 96% > of the radiant heat coming through your acrylic. With winter upon us, > the heat may not bother you, but the rays still permeate through your > acrylic, drying and cracking your interior. Cee Shades also keep out > unwanted eyes looking over your interior. At a special price of $99.95 > for a Piper Cherokee full-cabin set, this is about 40% below other > advertised prices. FREE shipping for AVweb readers through December. > Visit Cee Bailey at <http://www.avweb.com/sponsors/desser/ceebailey>. > > FLIGHT LEVEL'S LOGBOOK 2000 PALM PILOT/POCKET PC COMPANION AVAILABLE > Flight Level, authors of the best selling computer logbook, now has > available the first Palm Pilot/Pocket PC (CE) companion version for > Flight Level 2000 at a special Holiday price of $79, regular $99, till > December 31. You can leave town and keep track of flights, then auto- > sync to your desktop computer when returning home. Pilots now have an > excuse to buy a handheld Personal Data Assistant. Order Flight Level > LogBook 2000 and the Palm Pocket PC companion version at > <http://www.avweb.com/sponsors/fltlevel>. > > HOLIDAY SHOPPING DEAL REMINDERS... > FREE LOGO CAP WITH ANY MARV GOLDEN BRAND HEADSET OR FLIGHT BAG > Ends December 24th at <http://www.avweb.com/sponsors/marvgold>. > > PURCHASE SPORTY'S PROFESSIONAL PRIVATE PILOT VIDEO COURSE > and receive Richard Collins' Air Facts video, "Preflight Tips," FREE, a > $24.95 value at <http://www.avweb.com/sponsors/sportys/sportysfour>. > > TRANS-PLATA ALLOWS YOU TO SWITCH YOUR AIRCRAFT'S POWER SUPPLIES > with microelectronic converters. Receive a special 20% discount on all > their products at <http://www.avweb.com/sponsors/transplata>. > > With every quality Chase-Durer watch purchase receive a sleek, compact > travel alarm FREE at <http://www.avweb.com/sponsors/chasedur>. > > FLYING BUFFALO'S AIRPORT GUIDE CD-ROM MAKES A GREAT GIFT > Special of $50 per region at <http://www.avweb.com/sponsors/buffalo>. > > ________ > SPONSORS <http://www.avweb.com/sponsors> > > PILOT INSURANCE CENTER MAKES IT EASY! > The Pilot Insurance Center (PIC) makes it easy to apply for life > insurance. They will provide a no-obligation, no-hassle quote via > email, phone or fax; work hard to find an A+ rated life insurance > company offering a low "preferred" premium rate; complete your > application over the phone; and overnight it for your signature. PIC > is staffed by pilots who are experienced in finding the best life > insurance coverage for student, helicopter and experimental pilots, as > well as exceptional programs for corporate and ATP pilots. PIC clients > are saving 20-40 percent over the cost of older policies that simply do > not treat pilots fairly. Go to <http://www.avweb.com/sponsors/piclife> > or call PIC at 1-800-380-8376. > > CS&A AVIATION INSURANCE CAN HELP YOU GET THE BEST COVERAGE > Effective December 1, 2000, another aviation market insurer ceased > writing new business. Now more than ever, with a diminishing number of > markets, pilots need an experienced aviation insurance professional to > help them get the best coverage at the best price. CS&A Aviation > Insurance can provide that service. Their specialists deal with the > remaining major markets on a regular basis. Fill out a quick "Quote > Request" form at <http://www.avweb.com/sponsors/csa> or contact them by > phone or email if you have special needs. > > COMING ATTRACTIONS IN THE SMITHSONIAN'S AIR & SPACE MAGAZINE > Scheduled in the February/March 2001 issue: The 1947 rollout of a Tu- > 4, a Soviet B-29 strategic-bomber copy; contemporaries of the Wright > Flyer; early images from NASA's Terra; the secret Swiss, French and > U.S. flying defense; and much more. Order your subscription at > <http://www.avweb.com/sponsors/smithson>. > > ___________________ > Short Final... > > More from our "who's on first?" file... > > A controller trainee (a.k.a., developmental) was heard to say while > training on ground control: > > "Cessna 12345, are you the Cessna behind the Cessna in front of you?" > > Contributions to Short Final are welcomed at . > > ________________________________________ > We Welcome Your Feedback! > > AVflash is a twice-weekly summary of the latest aviation news, > articles, products, features and events featured on AVweb, the > Internet's Aviation Magazine and News Service. > <http://www.avweb.com> > > Letters to the editor intended for publication in AVmail should be > sent to . > > The news in this edition of AVflash and AVweb NewsWire was > researched by Jennifer Whitley , > written by Glenn Pew , > edited by Peter Yost , > HTML by Managing Editor Bob Kaputa . > Executive Editor is Jeb Burnside . > Editor-in-Chief is Mike Busch . > > Comments to AVweb's editorial team <http://avweb.com/a/authors.html> > should be sent to . > > Want to subscribe or unsubscribe? Change/update your email address? > Forgot your AVweb password? No problem! Simply go to our friendly > "Member Services" menu at <http://www.avweb.com/signup>. > > Let's keep the dirty side down, okay? > > ________________________________________ > > Copyright (C) 2000, The AVweb Group. > All rights reserved. > > ________________________________________________________________________________
Subject: Fw: Offset VS
Date: Dec 18, 2000
----- Original Message ----- From: Ed Jungst Sent: Sunday, December 17, 2000 9:20 PM Subject: Offset VS Tom FWIW. I built an RV-6 and flew it 576 wonderful hrs - with a 10 inch wedge on the rudder to get the ball right in the middle. While flying the -6 I built an -8. I never liked having that wedge back there on the -6, and like you, pondered the prospect of offsetting the stab on the -8 (one reason being that I stepped up to an O-360 from the O-320 and had visions of an even bigger wedge). It's not possible to get a firm answer on how much offset (due to many variables), so I took a SWAG and offset by 3/32 of an inch. Lo and behold, the ball is right in the middle! Just put my 89th hr on the RV-8 this balmy 5 below zero afternoon. Am I happy? You bet your sweet slip or skid I am! While 3/32 doesn't sound like much, that's a big tail back there, and we're not talking J-3 Cub airspeeds. Another factor in my decision was that I have looked at literally hundreds of RVs and have noticed that the vast majority have rudder tabs of one size or another. I'd dare say that the remaining ones are either A) unaware of how horseshit their airplanes are flying or, B) are flying with one foot on the floor and one resting on the rudder pedal (I did this until I got fed up with it and kept adding wedge til I got it right on the -6). Best regards, Ed Jungst Glenwood,MN ________________________________________________________________________________
Subject: Venezuela Trip
Date: Dec 18, 2000
----- Original Message ----- From: Randy Simpson <airtime(at)proaxis.com> Sent: Sunday, December 17, 2000 9:43 PM Subject: Re: RV-List: Venezuela Trip > > > Here's a pic of Mike and Diane, and their RV... > http://www.airtimemfg.com/Images/mikesRV4.jpg > It sure is a nice one. He said he'd give me a ride, but it was getting late > in the day, and they had to get back home *bleah* > SOMEDAY, I'll get my first ride in an RV...(he he, hint hint)... > > I was in awe too, hearing Mike tell of his plans to fly down there, when he > flew into Propst Field (here where I live) to buy a Ti-down kit. He had > plans to try the Ti-downs out in the coral reef in the Bahamas, or some > exotic place. Can't wait to hear how they work in that situation *smile* > > Randy Simpson > Albany, Oregon > http://www.airtimemfg.com > > > > >Listers: > > > >I feel like it really is our duty to hang out at the airport. Some may call > >us airport bums but we know it is necessary to be at the place where > >something interesting may happen. > > > >I was out there this afternoon "supervising" the first flight of a Dragonfly > >after an engine rebuild and sell. A N996RV called in for airport advisory > >and I thought that might be an RV, considering the number. Went and met the > >folks in the striking yellow and dark blue RV-4 and was surprised to find it > >was Mike and Diana, of the trip to Venezuela, which I had heard about from > >the list and Doug's Reeves' website http://www.vansaircraft.net . Too bad > >they had to buy our local, high priced gas, but it was certainly nice to > >meet them and get the abbreviated account of their adventures. > > > >They seem to be doing well; well there was just a bit of grousing about > >saddle sores after 62 hours in the cockpit, but they were cheerful. They > >will enjoy getting home though. > > > >Mike and Diane left here right at sunset heading for Tucson International > >and are hoping to make it home to Aurora, OR late tomorrow. Their stop > >previous to Carlsbad was Waco, TX. > > > >Wow! I am in awe. Two people hop into a 4 with its small luggage > >compartment and hop down to Venezuela and back. Amazing people and amazing > >machines. > > > >Larry Pardue > >Carlsbad, NM > > > >RV-6 N441LP Flying > > > > > > ________________________________________________________________________________
Subject: Re: 6-A-QB Verticle Stabalizer
Date: Dec 18, 2000
This prop wash striking the left side of the Vertical Stab problem has to be taken into account on all aerobatic competition airplanes. It is more exaggerated there as they usually have much bigger props. The "BEST" aeronautical solution is more right thrust in the engine. I've never heard of a design that offsets the vertical stab. It is BEST because when you move the VS over to offset the effect of the prop wash hitting the side of the vertical stab at high RPMs it becomes unwanted at anytime the engine isn't running at high RPMs. Some folks want their plane to fly true when the engine is at less than full RPMs. Having said that, it might be impractical to put in more Right Thrust in the engine mount and still have proper clearance between the spinner and cowl or engine/accessories and cowl but it would be at least worth a quick call to Van's to find out. lucky >From: Thomas McIntyre <bogeybrother(at)earthlink.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: 6-A-QB Verticle Stabalizer >Date: Sun, 17 Dec 2000 22:08:15 -0800 > > >1/4 " offset to left on my 160hp RV3. Feet off at 180 mph indicated. >(my usual indicated cruise speed) >Tom >RV3 978TM > > >jayeandscott wrote: > > > > > > I think that is what it means. The offset of the vert stab leadingedge >is to > > angle it into the clockwise(viewed from behind) rolling of the air >coming > > off the propellor. Sounds like a good idea-and it should be a zero-drag > > solution over a small tab on the rudder trailing edge. > > ----- Original Message ----- > > From: Emrath <Emrath(at)home.com> > > To: > > Sent: Sunday, December 17, 2000 12:37 PM > > Subject: Re: RV-List: 6-A-QB Verticle Stabalizer > > > > > > > > I'm not to the point of mounting my Empannage yet, but will someone > > explain > > > what it means to "offset" the VStab to the left? It seems to me, >right > > > rudder is called for and all the trim tabs I recall were 'V' wedges > > fastened > > > to the left face (pilot's side) of the rudder. This has the effect of > > > pushing the rudder to the right so the pilot does not have to hold >right > > > rudder to fly with the ball centered at cruise. So, does "offset" mean > > that > > > the nose of the VStab is offset to the pilots side, relative to the > > trailing > > > edge of the VStab? If so, 3/8" as mentioned by another listener would > > seem > > > to be a large amount. > > > > > > Marty in Brentwood TN, RV6A "belly skinning" (snowed last night and >this > > > morning was 9 degrees in Nashville area - I guess I'll study plans >instead > > > of drilling holes in the garage today). > > > ----- Original Message ----- > > > From: "Ken Cantrell" <kcflyrv(at)pacbell.net> > > > To: > > > Sent: Saturday, December 16, 2000 6:39 PM > > > Subject: Re: RV-List: 6-A-QB Verticle Stabalizer > > > > > > > > > > > > > > Tom, > > > > I offset my VStab 1/8" to the left in hopes that I can avoid a trim >tab > > on > > > > the rudder. Unfortunately I won't be able to give you any results >for > > > about > > > > a year or so. I beleive Van mentions that some builders do this to > > > > compensate for torque and so I decided to do it as well. > > > > > > > > Ken Cantrell - 6QB > > > > 34KC reserved - FWF & electrical stuff > > > > > > > > ----- Original Message ----- > > > > From: Tom & Cathy Ervin <tcervin(at)valkyrie.net> > > > > To: > > > > Sent: Saturday, December 16, 2000 3:33 PM > > > > Subject: RV-List: 6-A-QB Verticle Stabalizer > > > > > > > > > > > > > > > > > > > > > List: I am wondering what people have done concerning an offset of >the > > > > > Verticle Stabalizer? I believe Van's doesn't recommend this do to > > > various > > > > > engine prop combinations but since I will be using a new 0-360-A1A >and > > > > > Hartzel Constant Speed what have other builders done? > > > > > My A\P says the little wedge added to the Verticle Stab >should > > > not > > > > > be seen on Aircraft unless it is a Spam Can. > > > > > Scott if you are out there if Van's knew the specific >engine > > prop > > > > > combo's would they know a specific successful offset for my setup? > > > > > > > > > > Tom in Ohio > > > > > > > > > > > > > > > > > > > > > > > > > > > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Subject: Fitting Tank Skins
Date: Dec 18, 2000
Mike, I ran threaded rod through the tooling holes. and adjuusted them as needed. Peter Laurence > ** Original Subject: RE: RV-List: Fitting Tank Skins > ** Original Sender: N8292W(at)AOL.COM > ** Original Date: Sat, 16 Dec 2000 13:19:56 -0500 (EST) > ** Original Message follows... > > > I taped one side of the ribs to the skin before pulling the skin down. It > kept them pretty close to the right location where you could use a pick > through the drilled skin holes and get them perfect. I hope this helps! > > Mike > -sealing the second tank on my RV-4 > > > How have others dealt with lining up the tank ribs with the pre punched > holes in the tank skin.=A0 Unlike the leading edge ribs there are no > lightening holes to allow for using my wooden pole to move the ribs > around. > > Thanks in advance for the help. > > Mike Nellis - RV-6 N699BM (res) > Plainfield, IL > Building Tanks > http://mnellis.jnet.net/rv-6_page > > > > > > >** --------- End Original Message ----------- ** > Download the Jurassic Park Browser at http://www.jurassicpark.com ________________________________________________________________________________
Date: Dec 18, 2000
> >OK, here I open a can of worms.... > >I put vortex generators on my RV6A....what is REALLY puzzling me is how to >reasonably determine the stall speed. > >I am using a TAS indicator...where should it be set? How does one account >for all the variables without a drogue (spelling) static port, and without a >very long pitot pick up? > >I take off at 7,500-feet, and do stalls at 10 to 11,000 msl so that probably >needs to be taken into account....I am really out of my area of expertise >(expertise, heck...out of my skimpy knowledge of such things!) > >Let's hear some down to earth ideas....PLEASE! > >Rv6A Flying Salida, CO > We need to take a good hard look at why we might want VGs, then we can determine what types of flight testing might be a good thing to do. VGs should do several useful things, and one bad thing. 1. They should lower the stall speed a bit. This means we would have less energy to dissipate after a forced landing, which improves the odds of surviving. It would also help if we were doing short field flying. 2. They might improve the aileron control at the stall. I'm not sure if that is even an issue with RVs. 3. They might improve stall warning, by giving more buffet prior to the stall. 4. They might make the aircraft more resistant to spin entry. 5. They should lower the top speed a bit. Now, each of us needs to figure out which of the above items are important to us. 1. Stall speed - An aircraft should stall at the same indicated airspeed every time, if all the conditions are the same (weight, flap angle, g-loading, power, rate of deceleration). This is good because we are looking at indicated airspeed all the time when we fly. But, indicated airspeed is a poor measure of what speed our aircraft is actually stalling at (which is what we are interested in if we want to see if VGs will help us reduce our speed at impact in a forced landing). An airspeed indicator is nothing more than an expensive differential pressure indicator, with a complicated mechanism to give it a non-linear display. It's accuracy is limited by the accuracy of the pitot and static pressures that it senses. Given that an aircraft must affect the pressure of the atmosphere around it, or it couldn't fly (it needs high pressure below the wing, and low pressure above it), it shouldn't be a surprise that it is a real trick to get an accurate airspeed measurement that uses pressures as the parameter that is sensed. So, if the indicated stall speed decreases 10 mph at the stall, that doesn't mean much, except that we can fly at a bit lower indicated airspeed on final approach. It doesn't mean that our impact speed in a forced landing has decreased by 10 mph. If all we cared about was seeing a low indicated airspeed at the stall, I would suggest putting the pitot tube on a long boom, and bending it up about 10 degrees. Vary the amount of upwards bend until you get a stall speed worth bragging about :-) Now, if you care about what the real stall speed is, this is not an easy thing to measure. In the flight test world, we use a few different techniques. Many larger aircraft will use a static source on a long line trailing behind the aircraft to get it in air that has recovered from the pressures caused by the passage of the aircraft (a.k.a trailing cone static source). I'm told they don't work that well at low speed, but I've never tried one. In any case it would be a lot of work to set one up. For low speed aircraft, another classical technique is to use a "trailing bomb", which is an aerodynamic weight, with a small pitot-static probe on the nose that is suspended below the aircraft. The trailing bomb has a static source error, but it is calibrated in a wind tunnel so they can correct for the error. This makes it pretty much out of reach for us. Another technique is to have a pitot-static probe (some times on a swivel) on a long boom extending ahead of the wing tip. This is the most common technique used by the manufacturers. One RV-6 builder has put one on his aircraft to do some testing of VGs - I'm trying to get him to come back on the list and give a report. His boom is mounted mid span, which isn't quite as good as the wing tip, but it is still a lot better than just using IAS. Another approach could be to use another aircraft with a much lower stall speed (the pace aircraft), and an airspeed system that has been calibrated using some decent method (GPS, etc, see the Flight Test Links on my web site). This method has its risks though, so I would use it with extreme caution. The two aircraft would have to fly formation, doing a very slow deceleration in level flight. The pace aircraft calls the airspeed every couple of knots on the radio. The RV would have two people in it - one looking outside flying formation, and one staring at the airspeed indicator, who would note the radioed speed at which the stall occurs. The RV would have to be close enough to the pace aircraft to match airspeeds, but far enough aft so that they would not collide if the RV did something interesting at the stall. And of course, you need a pace aircraft with a low enough stall speed to absolutely guarantee that it does not stall first, because a collision is quite possible if that happens. The pace aircraft pilot must set a safe minimum speed, and not go below it. You also need both pilots to be experienced formation pilots. 2. though 4. - the other aspects of what a VG could do for us are also worth looking at. You need to do careful testing with and without VGs looking at each of these aspects. 5. top speed - this is an easy one to measure. Take care, -- Kevin Horton RV-8 (fuselage 98% done) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Subject: Re: RV8 S-cowl forward platenuts
Date: Dec 18, 2000
> I just went to drill the holes for the forward attach points to install the > platenuts that go in the inside air intakes on the S cowl closest to the > spinner. The plans call out for three number 8 plate nuts and show a > flange that appears to be about three inches by 3/4 inch to attach them to. > Mine is no where near that big. Closer to two inches by about 1/2 inch. > The best I can do is to install one platenut at best. I have not trimmed > this area so what I have is what was shipped to me in the finish kit. > > Did anyone else have this problem? If so, what did you do? Jim, Hmmm....my flange area was more like 1 inch by about 3 inches. I put a single lug platenut on the forward part of the left side, but otherwise everything fit ok. I took some pictures and posted it on a page just in case you want to look at my platenuts there - see http://rv8asite.homestead.com/cowl.html. Good luck, Jerry Carter 8A cowl and baffles ________________________________________________________________________________
Date: Dec 18, 2000
Yes, of course, you are correct regarding indicated airspeed at altitude. I hit "send" a little to quick and realized that point afterward. Thanks for the correction. Mike Nellis - RV-6 N699BM (res) Plainfield, IL Building Tanks http://mnellis.jnet.net/rv-6_page > > Well, yes and no. You are correct that it will stall at a higher indicated > airspeed in a steep turn, but there will be no difference in the indicated > stalling speed > caused by altitude-that's why we fly high-the airplane accelerates until the > drag equals the thrust-the same power setting must generate the same > indicated airspeed at all altitudes-only the true airspeed goes up----- > Original Message ----- > From: Mike Nellis <mnellis(at)emailusa.net> > To: > Sent: Sunday, December 17, 2000 9:26 PM > Subject: Re: RV-List: Stall Speeds/Vortex Generators > > > > > > Incorrect, the wing works on Angle of Attack not airspeed. > > > > For example, load the plane up to gross and it might stall at say.....55 > > mph. > > Take that same plane loaded to gross up to 8000' and do some steep turns > and > > I'll guarantee that it will stall at a lot higher speed than 55 mph. > > > > It's all about Angle of Attack not IAS. Typical stall warning devices are > > angle of attack sensors not airspeed sensors. > > > > Mike Nellis - RV-6 N699BM (res) > > Plainfield, IL > > Building Tanks > > http://mnellis.jnet.net/rv-6_page > > > > > > > > > > You're right. Indicated airspeed is all the wing works on- TAS and GS > are > > > for navigating. The only variable could come from unstable air -as in > > slight > > > updrafts or downdrafts occuring during the two test flights. > > > ----- Original Message ----- > > > From: Builder's Bookstore <winterland(at)rkymtnhi.com> > > > To: > > > Sent: Sunday, December 17, 2000 2:37 PM > > > Subject: Re: RV-List: Stall Speeds/Vortex Generators > > > > > > > > > > > > > > > > > > I put vortex generators on my RV6A....what is REALLY puzzling me is > > how > > > to > > > > > reasonably determine the stall speed. > > > > > > > > > > > > > I have my VG set, but haven't installed them yet. When I do, I'm going > > to > > > look > > > > at both indicated airspeed and groundspeed as measured on the GPS. > > Between > > > the > > > > two, I should get a reasonable idea of what the VGs are doing. > However, > > > the GPS > > > > comparison figure is just for academic interest and has no real value. > > > > > > > > The bottom line is that I don't really care what my calibrated or true > > > stall > > > > speeds are. From the operational point of view of the pilot, all that > > > really > > > > matters is Indicated. (Yes, I'm wearing my asbestos suit) I want to > know > > > how > > > > "my" plane is going to respond in a short or power off landing > > > configuration; > > > > these being the times that the benefits of VGs will most come into > play. > > > > Indicated will always give that information in an easy to use and > > > dependable > > > > manner. Any other number is fairy irrelevant to the task at hand at > that > > > moment. > > > > > > > > Andy > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 18, 2000
Subject: Re: vortex generators
>Has anyone else installed and flown the VG kit from Vetterman? I spoke with >Larry at some length about the VG's (what a nice and helpful guy), and they >sound like the best $350 you could spend on your airplane, but I'm wondering >if Van himself has gotten his hands on a set and tried them out. I am in the process of testing the Vetterman VG kit. I have gone to some pains to install a swivel pitot head to remove as much position error as possible. I saw the most significant change with flaps extended. I did not go beyond 10 degrees of flaps. I will re-run the entire test sequence using the entire flap range. Pictures and text of the test results can be found at this link: <http://www.ontariorvators.org/pitot/pitot.htm> When I'm satisfied that I have good data, I will report back to the list. Terry Jantzi Kitchener, ONTARIO C-GZRV RV-6 -- <http://www.netrover.com/~tjantzi/terry/> Home Page <http://www.ontariorvators.org> VAFOW ________________________________________________________________________________
Subject: Re: Fitting Tank Skins
Date: Dec 18, 2000
Hi Peter and everyone else that responded to my fuel tank rib position question. Thanks for the tips. I, too, used the rod through the tips method but there were still a couple of flanges in the middle that didn't want to line up near the leading edge and the middle. One list member (I apologies for not remembering his name), mentioned that he used a yard stick and was able to wedge the yard stick between skin and the spar and tap the tip of the rib to position. I didn't have a yard stick but I did have a 4' piece of flat (1/8 x 1.5") of aluminum stock. Sort of an aluminum yardstick if you will. I rounded the top of that so as not to dig into the skin if I should hit it, and it worked great! Tap, Tap, Tap and the flanges lined up as nice as can be. > > Mike, > > I ran threaded rod through the tooling holes. and adjuusted them as needed. > > > Peter Laurence > > > > ** Original Subject: RE: RV-List: Fitting Tank Skins > > ** Original Sender: N8292W(at)AOL.COM > > ** Original Date: Sat, 16 Dec 2000 13:19:56 -0500 (EST) > > > ** Original Message follows... > > > > > > > I taped one side of the ribs to the skin before pulling the skin down. It > > kept them pretty close to the right location where you could use a pick > > through the drilled skin holes and get them perfect. I hope this helps! > > > > Mike > > -sealing the second tank on my RV-4 > > > > > > How have others dealt with lining up the tank ribs with the pre punched > > holes in the tank skin.=A0 Unlike the leading edge ribs there are no > > lightening holes to allow for using my wooden pole to move the ribs > > around. > > > > Thanks in advance for the help. > > > > Mike Nellis - RV-6 N699BM (res) > > Plainfield, IL > > Building Tanks > > http://mnellis.jnet.net/rv-6_page > > > > > > > > > > > > > > > >** --------- End Original Message ----------- ** > > > > > > Download the Jurassic Park Browser at http://www.jurassicpark.com > > ________________________________________________________________________________
Date: Dec 18, 2000
Take a look at this picture for an alternative method of securing the cowling near spinner. This installation is on Paul Golias's plane and seems like a nice, easy, secure method for attaching the cowl at that position. http://mnellis.jnet.net/rv-6_page/images/DCP00889.JPG Mike Nellis - RV-6 N699BM (res) Plainfield, IL Building Tanks http://mnellis.jnet.net/rv-6_page ----- Original Message ----- From: "Jerry Carter" <jcarter8(at)midsouth.rr.com> Sent: Monday, December 18, 2000 9:44 AM Subject: Re: RV-List: RV8 S-cowl forward platenuts > > > I just went to drill the holes for the forward attach points to install > the > > platenuts that go in the inside air intakes on the S cowl closest to the > > spinner. The plans call out for three number 8 plate nuts and show a > > flange that appears to be about three inches by 3/4 inch to attach them > to. > > Mine is no where near that big. Closer to two inches by about 1/2 inch. > > The best I can do is to install one platenut at best. I have not trimmed > > this area so what I have is what was shipped to me in the finish kit. > > > > Did anyone else have this problem? If so, what did you do? > > Jim, > > Hmmm....my flange area was more like 1 inch by about 3 inches. I put a > single lug platenut on the forward part of the left side, but otherwise > everything fit ok. I took some pictures and posted it on a page just in > case you want to look at my platenuts there - see > http://rv8asite.homestead.com/cowl.html. > > Good luck, > > Jerry Carter > > 8A cowl and baffles > > ________________________________________________________________________________
Date: Dec 18, 2000
--- Emrath wrote: > > > I'm not to the point of mounting my Empannage yet, > but will someone explain > what it means to "offset" the VStab to the left? It > seems to me, rightSeems to me Van reported a test some years ago offsetting the vs and reported no change. I think there may be many variables involved. Step hanging off to the side, slight change in incidence, I understand some of the QB left wings were 1" longer etc. I built mine to plans and ended up with a 3/4"x2" tab on the rudder. At 75% power @ cruise no rudder problem. Just my $.02 worth. RV6A O360 180 CP 130 hrs ________________________________________________________________________________
Date: Dec 18, 2000
Subject: Another Radio for Sale
Engines-List , "Rv8list@Egroups" , Rv-List I am posting this for a friend... Please contact him directly... King 170B with the MAC 1700 upgrade witch adds digital tuning, Flip flop on nav and comm. extensive freq memory, synthesized voice freq readout and synthetic voice approach countdown timer. And many flight planning features. A great IFR nav / comm for a great price for a radio that has never been used since OH. Will sell for $1800.00. including tray, manual and Jack... Burrall Sanders - yankeeair(at)earthlink.net http://vondane.tripod.com/forsale/mac1700.htm ________________________________________________________________________________
Date: Dec 18, 2000
Is anyone flying with Jim Frantz's AOA - If so and you are planning to install VGs. I'd be interested in the stall AOA number before and after VG installation. Chuck & Dave Rowbotham RV-8A (painting next week) Niantic, CT (Westerly airport) >From: "Mike Nellis" <mnellis(at)emailusa.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: Re: RV-List: Stall Speeds/Vortex Generators >Date: Mon, 18 Dec 2000 00:26:25 -0500 > > >Incorrect, the wing works on Angle of Attack not airspeed. > >For example, load the plane up to gross and it might stall at say.....55 >mph. >Take that same plane loaded to gross up to 8000' and do some steep turns >and >I'll guarantee that it will stall at a lot higher speed than 55 mph. > >It's all about Angle of Attack not IAS. Typical stall warning devices are >angle of attack sensors not airspeed sensors. > >Mike Nellis - RV-6 N699BM (res) >Plainfield, IL >Building Tanks >http://mnellis.jnet.net/rv-6_page > > > > > > You're right. Indicated airspeed is all the wing works on- TAS and GS >are > > for navigating. The only variable could come from unstable air -as in >slight > > updrafts or downdrafts occuring during the two test flights. > > ----- Original Message ----- > > From: Builder's Bookstore <winterland(at)rkymtnhi.com> > > To: > > Sent: Sunday, December 17, 2000 2:37 PM > > Subject: Re: RV-List: Stall Speeds/Vortex Generators > > > > > > > > > > > > > I put vortex generators on my RV6A....what is REALLY puzzling me is >how > > to > > > > reasonably determine the stall speed. > > > > > > > > > > I have my VG set, but haven't installed them yet. When I do, I'm going >to > > look > > > at both indicated airspeed and groundspeed as measured on the GPS. >Between > > the > > > two, I should get a reasonable idea of what the VGs are doing. >However, > > the GPS > > > comparison figure is just for academic interest and has no real value. > > > > > > The bottom line is that I don't really care what my calibrated or true > > stall > > > speeds are. From the operational point of view of the pilot, all that > > really > > > matters is Indicated. (Yes, I'm wearing my asbestos suit) I want to >know > > how > > > "my" plane is going to respond in a short or power off landing > > configuration; > > > these being the times that the benefits of VGs will most come into >play. > > > Indicated will always give that information in an easy to use and > > dependable > > > manner. Any other number is fairy irrelevant to the task at hand at >that > > moment. > > > > > > Andy > > > > > > > > > > > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
From: "skybolt-aviator" <skybolt-aviator(at)msn.com>
Date: Dec 18, 2000
----- Original Message ----- From: "Builder's Bookstore" <winterland(at)rkymtnhi.com> Sent: Sunday, December 17, 2000 5:37 PM Subject: Re: RV-List: Stall Speeds/Vortex Generators > > > I put vortex generators on my RV6A....what is REALLY puzzling me is how to > > reasonably determine the stall speed. > The bottom line is that I don't really care what my calibrated or true stall > speeds are. > > Andy > > Right on,I agree with you. Ollie&Lorene Washburn RV6-A,N795LW,@FD77. O-360,180HP,C/S,300+hrs. > > ________________________________________________________________________________
Date: Dec 18, 2000
I think your generalizations are off base. Why? because when you say you have never heard of a design with the vertical stab offset. Try Cessna, Beech, Piper, Bellanca, Aeronca for just a few. Most airplanes do have an offset vertical stab and engine offset as well. Neither are perfect, but they compliment the other without having to go to extremes with either. ----- Original Message ----- From: lucky macy <luckymacy(at)hotmail.com> Sent: Monday, December 18, 2000 12:28 PM Subject: Re: RV-List: 6-A-QB Verticle Stabalizer > > This prop wash striking the left side of the Vertical Stab problem has to be > taken into account on all aerobatic competition airplanes. It is more > exaggerated there as they usually have much bigger props. The "BEST" > aeronautical solution is more right thrust in the engine. I've never heard > of a design that offsets the vertical stab. It is BEST because when you > move the VS over to offset the effect of the prop wash hitting the side of > the vertical stab at high RPMs it becomes unwanted at anytime the engine > isn't running at high RPMs. Some folks want their plane to fly true when > the engine is at less than full RPMs. > > Having said that, it might be impractical to put in more Right Thrust in the > engine mount and still have proper clearance between the spinner and cowl or > engine/accessories and cowl but it would be at least worth a quick call to > Van's to find out. > > lucky > > >From: Thomas McIntyre <bogeybrother(at)earthlink.net> > >Reply-To: rv-list(at)matronics.com > >To: rv-list(at)matronics.com > >Subject: Re: RV-List: 6-A-QB Verticle Stabalizer > >Date: Sun, 17 Dec 2000 22:08:15 -0800 > > > > > >1/4 " offset to left on my 160hp RV3. Feet off at 180 mph indicated. > >(my usual indicated cruise speed) > >Tom > >RV3 978TM > > > > > >jayeandscott wrote: > > > > > > > > > > I think that is what it means. The offset of the vert stab leadingedge > >is to > > > angle it into the clockwise(viewed from behind) rolling of the air > >coming > > > off the propellor. Sounds like a good idea-and it should be a zero-drag > > > solution over a small tab on the rudder trailing edge. > > > ----- Original Message ----- > > > From: Emrath <Emrath(at)home.com> > > > To: > > > Sent: Sunday, December 17, 2000 12:37 PM > > > Subject: Re: RV-List: 6-A-QB Verticle Stabalizer > > > > > > > > > > > I'm not to the point of mounting my Empannage yet, but will someone > > > explain > > > > what it means to "offset" the VStab to the left? It seems to me, > >right > > > > rudder is called for and all the trim tabs I recall were 'V' wedges > > > fastened > > > > to the left face (pilot's side) of the rudder. This has the effect of > > > > pushing the rudder to the right so the pilot does not have to hold > >right > > > > rudder to fly with the ball centered at cruise. So, does "offset" mean > > > that > > > > the nose of the VStab is offset to the pilots side, relative to the > > > trailing > > > > edge of the VStab? If so, 3/8" as mentioned by another listener would > > > seem > > > > to be a large amount. > > > > > > > > Marty in Brentwood TN, RV6A "belly skinning" (snowed last night and > >this > > > > morning was 9 degrees in Nashville area - I guess I'll study plans > >instead > > > > of drilling holes in the garage today). > > > > ----- Original Message ----- > > > > From: "Ken Cantrell" <kcflyrv(at)pacbell.net> > > > > To: > > > > Sent: Saturday, December 16, 2000 6:39 PM > > > > Subject: Re: RV-List: 6-A-QB Verticle Stabalizer > > > > > > > > > > > > > > > > > > Tom, > > > > > I offset my VStab 1/8" to the left in hopes that I can avoid a trim > >tab > > > on > > > > > the rudder. Unfortunately I won't be able to give you any results > >for > > > > about > > > > > a year or so. I beleive Van mentions that some builders do this to > > > > > compensate for torque and so I decided to do it as well. > > > > > > > > > > Ken Cantrell - 6QB > > > > > 34KC reserved - FWF & electrical stuff > > > > > > > > > > ----- Original Message ----- > > > > > From: Tom & Cathy Ervin <tcervin(at)valkyrie.net> > > > > > To: > > > > > Sent: Saturday, December 16, 2000 3:33 PM > > > > > Subject: RV-List: 6-A-QB Verticle Stabalizer > > > > > > > > > > > > > > > > > > > > > > > > > > List: I am wondering what people have done concerning an offset of > >the > > > > > > Verticle Stabalizer? I believe Van's doesn't recommend this do to > > > > various > > > > > > engine prop combinations but since I will be using a new 0-360-A1A > >and > > > > > > Hartzel Constant Speed what have other builders done? > > > > > > My A\P says the little wedge added to the Verticle Stab > >should > > > > not > > > > > > be seen on Aircraft unless it is a Spam Can. > > > > > > Scott if you are out there if Van's knew the specific > >engine > > > prop > > > > > > combo's would they know a specific successful offset for my setup? > > > > > > > > > > > > Tom in Ohio > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Get your FREE download of MSN Explorer at http://explorer.msn.com > > ________________________________________________________________________________
Date: Dec 18, 2000
Go back to basics: it will always stall at higher a/s in a steep turn. ----- Original Message ----- From: "Mike Nellis" <mnellis(at)emailusa.net> Sent: Monday, December 18, 2000 12:26 AM Subject: Re: RV-List: Stall Speeds/Vortex Generators > > Incorrect, the wing works on Angle of Attack not airspeed. > > For example, load the plane up to gross and it might stall at say.....55 > mph. > Take that same plane loaded to gross up to 8000' and do some steep turns and > I'll guarantee that it will stall at a lot higher speed than 55 mph. > > It's all about Angle of Attack not IAS. Typical stall warning devices are > angle of attack sensors not airspeed sensors. > > Mike Nellis - RV-6 N699BM (res) > Plainfield, IL > Building Tanks > http://mnellis.jnet.net/rv-6_page > > > > > > You're right. Indicated airspeed is all the wing works on- TAS and GS are > > for navigating. The only variable could come from unstable air -as in > slight > > updrafts or downdrafts occuring during the two test flights. > > ----- Original Message ----- > > From: Builder's Bookstore <winterland(at)rkymtnhi.com> > > To: > > Sent: Sunday, December 17, 2000 2:37 PM > > Subject: Re: RV-List: Stall Speeds/Vortex Generators > > > > > > > > > > > > > I put vortex generators on my RV6A....what is REALLY puzzling me is > how > > to > > > > reasonably determine the stall speed. > > > > > > > > > > I have my VG set, but haven't installed them yet. When I do, I'm going > to > > look > > > at both indicated airspeed and groundspeed as measured on the GPS. > Between > > the > > > two, I should get a reasonable idea of what the VGs are doing. However, > > the GPS > > > comparison figure is just for academic interest and has no real value. > > > > > > The bottom line is that I don't really care what my calibrated or true > > stall > > > speeds are. From the operational point of view of the pilot, all that > > really > > > matters is Indicated. (Yes, I'm wearing my asbestos suit) I want to know > > how > > > "my" plane is going to respond in a short or power off landing > > configuration; > > > these being the times that the benefits of VGs will most come into play. > > > Indicated will always give that information in an easy to use and > > dependable > > > manner. Any other number is fairy irrelevant to the task at hand at that > > moment. > > > > > > Andy > > > > > > > > > > > > ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Date: Dec 18, 2000
Listen up RVers! Terry's site provides a very well organized, professional critique of VGs. It is a must-see. Terry and Kevin Horton provide the List with valuable information about our planes. Don't miss their offerings. Keep up the good work, Terry! Dennis Persyk 6A N600DP 25 hours Hampshire, IL C38 -----Original Message----- From: Terry Jantzi <tjantzi(at)netrover.com> Date: Monday, December 18, 2000 8:14 AM Subject: RV-List: Re: vortex generators > >>Has anyone else installed and flown the VG kit from Vetterman? I spoke with >>Larry at some length about the VG's (what a nice and helpful guy), and they >>sound like the best $350 you could spend on your airplane, but I'm wondering >>if Van himself has gotten his hands on a set and tried them out. > > >I am in the process of testing the Vetterman VG kit. I have gone to some >pains to install a swivel pitot head to remove as much position error as >possible. I saw the most significant change with flaps extended. I did >not go beyond 10 degrees of flaps. I will re-run the entire test >sequence using the entire flap range. > >Pictures and text of the test results can be found at this link: > ><http://www.ontariorvators.org/pitot/pitot.htm> > >When I'm satisfied that I have good data, I will report back to the >list. > >Terry Jantzi >Kitchener, ONTARIO >C-GZRV RV-6 >-- ><http://www.netrover.com/~tjantzi/terry/> Home Page > <http://www.ontariorvators.org> VAFOW > > ________________________________________________________________________________
Subject: Re: Acceptable repairs
Date: Dec 18, 2000
I have often turned to the RV List for help when I probably should have called Van's. I sadly regret that I have encountered several commuications with Van's in which I was treated in an unprofessional and at times, even rude, manner. On several occasions I too was given incorrect technical information. This may in part explain why some of us turn to the RV-List when we really should contact Van's. In defense of Van's, I have unquestionably received a lot of bad information from the RV-List and there is certainly a lot of unfriendly criticism on the List. The difference is, I expect far more of Van's and am keenly disappointed when they do not meet my expectations. Dennis Persyk 6A N600DP 25 hours Hampshire, IL C38 From: kempthornes <kempthornes(at)home.com> Date: Sunday, December 17, 2000 1:48 PM Subject: Re: RV-List: Acceptable repairs > >Harry wrote: >> Just my humble opinion but it seems like you are getting a lot of >> non-expert responses when a phone call, e-mail or fax to Van's would get >you >> a knowledgeable and reliable answer to your question. > >Harry, this a put down for all who try to be helpful and it is wrong. > >My not so humble opinion is that to fail to take advantage of the >discussions, answers and all else that is available from this great group is >a mistake. > >For example, Tom Green, whom I like a lot, told me one time that steel was >hundreds of time stronger than aluminum. The real answer is as low as two! > >Hal Kempthorne >N7HK - Might fly next week! > >> >> Harry Crosby >> Pleasanton, California >> RV-6, working on canopy installation >> >> > > ________________________________________________________________________________
Date: Dec 18, 2000
Just a note of caution to those contemplating the notion of offsetting their VS. I researched this issue fairly thoroughly a while ago when it was approaching time to mount my VS. I had long conversations with Bill Bendict, Ken Krueger, and other experienced builders. Some things to be aware of: 1. As we all know RVs have their engine thrustlines angled to the right to compensate for assymetrical thrust via the engine mount geometry. Of course with the variety of engines, props, and airframe finish details there's no way they can guess correctly for all scenarios, but there is some built-in compensation. 2. Small things like the alignment of your landing gear fairings and wheel pants can effect yaw trim without you realizing it. Other subtle things such as more drag in one wing than the other can influence the final balance also. Wouldn't take much extra drag near the ailerons to induce some yaw. Also, what if your rudder has a bit of twist, or has the horn somehow not centered like mine? What will that do to the final trim? 3. Van's official recommendation is to NOT offset the VS. Since there are many variables, since there is built-in compensation, and since Van's recommends against it, I mounted mine straight. However aesthetically displeasing this may be, I made and mounted an adjustable aluminum tab about midway up the trailing edge. That way I can compensate for anything including changes that may be made down the road. True, many find this visually offensive, but I appreciate the functionality and adjustability of it. Local builder Randall Henderson took the same approach. Now that he's flying I seem to recall that his tab is adjusted pretty much in trail, but at least he has the ability to fine tune it if need be, as will I. FWIW, Randy Lervold RV-8, #80500, painting www.rv-8.com ________________________________________________________________________________
Subject: Re: Dremel tool
Date: Dec 18, 2000
12/18/2000 11:50:42 The qualitity of the Dremmels may have gone down a notch or two...... but the crap I am cutting (fiberglass) may be eating up the dremmel. I never cut fiberglass before working on my airplane......\ JDaniel343(at)AOL.COM Sent by: To: rv-list(at)matronics.com owner-rv-list-server@mat cc: ronics.com Subject: Re: RV-List: Dremel tool 12/17/2000 12:12 AM Please respond to rv-list I purchased my variable speed Dremel in 1974. I find myself constantly using it. Its been sounding a little dirty lately, probably needs new brushes but it sure works good. I don't know how the new ones are, although from the list members it sounds like quality has gone down. John Danielson Engine Installation and finishing kit ________________________________________________________________________________
Subject: Electrical Questions
Date: Dec 18, 2000
Dear listers, I am installing a single belly strobe on my RV-4 using a Kuntzelman streamlined strobe head (kestrobes.com)and a Nova power supply that a friend in the business gave me. (Wingtip Whelens are comming someday, but I can't beat the price of this system: $50 for the head, $14 for the switch = $64) My questions are as follows. 1) What is the appropriate size wire to make a 6 foot run from the switch to the strobe. Assume 10 amps. 2)What is standard aircraft practice? Do I need to run a ground wire, or just ground to the airframe? 3)I have a lot of flexibility as far as where I mount the power supply. What will give the least electrical noise: a)Long 12 volt lines and short high tension strobe lead b)Short 12 vold line and long high tension strobe lead My gut tells me a short strobe lead, but someone told me that the noise actually comes from the 12 volt line when the power supply charges because the resistance and therefore the current of the 12v source to the power supply is constantly changing. Thanks for the enlightenment. PLEASE REPLY OFF LIST AS i ONLY GET THE ONCE DAILY LIST SUMMARY AND i WANT TO WORK ON MY PLANE TONIGHT IF i GET AN ANSWER. Best regards, Don Mei Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 18, 2000
Subject: Re: Epoxy-Fiberglass Question
In a message dated 12/17/00 11:26:07 AM Pacific Standard Time, pincjt(at)ix.netcom.com writes: << Is epoxy compatible with the tips Vans supplies? >> Yes. Harry Crosby Pleasanton, California RV-6, working on canopy installation ________________________________________________________________________________
Subject: Re: External Power Receptacle
Date: Dec 18, 2000
> > >I would like to have an external power receptacle on my RV6A. In the > Spruce catalog page 351 there seems to be two ways to go. A round > Piper one and an oval standard one. Which is best? If you haven't seen those up close you might want to have a look at one before getting one. They're quite big and heavy. My external power receptacle cost around $3. All it is is a lighter socket that's wired directly to the battery. Doubles as an external power source for devices that have lighter socket plugs. I ran #12 wires to it and put a 10A inline fuse at to the battery end so it could carry charging current. Wouldn't use it for starting but it works great for charging. Randall Henderson, RV-6 N6R (~175 hrs) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Subject: Customer Service Was: Acceptable repairs
Date: Dec 18, 2000
People are always going to have good and bad days. I pride myself on the customer support I provide my network users where I work. However, there are days when I don't feel good, haven't slept, got bad news, etc., and I don't treat people as nicely as I should. Remember that the guys at Van's are human and are subject to the same moods we all have. However, if you receive this kind of treatment regularly from the folks at Van's or any company for that matter, ask to speak to their manager. Management definitely does not want you treated poorly. If no one brings it to their attention, they can not help remedy the situation. I have rarely called Van's technical help line but I know some of the guys on the other end can be kind of brusque. One gentleman was downright rude (I thought). After he was done with his diatribe I asked him if I had said something to "piss" him off. I asked if there was anyone else I could speak to. He calmed down immediately and apologized and proceeded to tell me that, no there was no one else I could speak to because he was alone that day. Don't be bashful. The people at Van's aren't gods. Speak up. They'll listen. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Dennis Persyk [mailto:dpersyk(at)worldnet.att.net] Sent: Monday, December 18, 2000 8:32 AM To: rv-list(at)matronics.com Subject: Re: RV-List: Acceptable repairs I have often turned to the RV List for help when I probably should have called Van's. I sadly regret that I have encountered several commuications with Van's in which I was treated in an unprofessional and at times, even rude, manner. On several occasions I too was given incorrect technical information. This may in part explain why some of us turn to the RV-List when we really should contact Van's. In defense of Van's, I have unquestionably received a lot of bad information from the RV-List and there is certainly a lot of unfriendly criticism on the keenly disappointed when they do not meet my expectations. Dennis Persyk 6A N600DP 25 hours Hampshire, IL C38 ________________________________________________________________________________
Subject: Re: Electrical Questions
Date: Dec 18, 2000
I think your amp draw is very high. I would check it carefully. If you use wiring for that amount, a correct in-line fuse can protect the power supply even if one would go to welding cable. The noise of the switching power supply is in the lead to the supply, not as much with the high voltage which can be shielded. If you get noise, then a choke or a ferrite bead should make it quieter. ----- Original Message ----- From: Donald Mei <don_mei(at)hotmail.com> Sent: Monday, December 18, 2000 4:55 PM Subject: RV-List: Electrical Questions > > Dear listers, > > I am installing a single belly strobe on my RV-4 using a Kuntzelman > streamlined strobe head (kestrobes.com)and a Nova power supply that a friend > in the business gave me. (Wingtip Whelens are comming someday, but I can't > beat the price of this system: $50 for the head, $14 for the switch = $64) > My questions are as follows. > > 1) What is the appropriate size wire to make a 6 foot run from the switch to > the strobe. Assume 10 amps. > > 2)What is standard aircraft practice? Do I need to run a ground wire, or > just ground to the airframe? > > 3)I have a lot of flexibility as far as where I mount the power supply. > What will give the least electrical noise: > > a)Long 12 volt lines and short high tension strobe lead > b)Short 12 vold line and long high tension strobe lead > > My gut tells me a short strobe lead, but someone told me that the noise > actually comes from the 12 volt line when the power supply charges because > the resistance and therefore the current of the 12v source to the power > supply is constantly changing. > > Thanks for the enlightenment. > > PLEASE REPLY OFF LIST AS i ONLY GET THE ONCE DAILY LIST SUMMARY AND i WANT > TO WORK ON MY PLANE TONIGHT IF i GET AN ANSWER. > > Best regards, > > Don Mei > Get your FREE download of MSN Explorer at http://explorer.msn.com > > ________________________________________________________________________________
Subject: Re: Stall Speeds/Vortex Generators
Date: Dec 18, 2000
----- Original Message ----- From: "Kevin Horton" <khorton(at)cyberus.ca> Sent: Monday, December 18, 2000 7:42 AM Subject: Re: RV-List: Stall Speeds/Vortex Generators> --> > > We need to take a good hard look at why we might want VGs, then we > can determine what types of flight testing might be a good thing to > do. > > VGs should do several useful things, and one bad thing. > You guys are making this alot more complicated than it needs to be. It lowers stall about 6-7 mph. I can prove this as I have hundreds of hours flying very close to other RV's.Also , let us not forget that the stall reduction at 4 G's is twice that at 1G. That means that in a dog fight I can pull 4 G's 14mph slower than my competition. It is not just about lowering landing speed. It is about margins and screw ups. Also the recovery from stalls is much faster than before. The closer you fly to outside of the envelope , the more you feel the difference. I will give you an example. After installing the VG's, I was flying at night. Going into a dark airpark. During the touch down, the plane would not stay on the runway. I did not realize it at the time, but my overhead rudder pedals had broken. I was left with either to fly or die. I poured the coals to it and guess what happened .The CS prop did a great job of turning me right at a house along the runway. My tires left the runway just as I was becoming airborn. This is great except for the fact that I am now in the dark at no altitude heading for a house. I was left with rolling up on a wing tip and pulling. The good news is that I am here to pass on the story. I cant say that I would not have made it with out VG's, but I was sure glad for the added margins. As far as top end, I'll say it again, I could not see any difference.Terry ________________________________________________________________________________
Date: Dec 18, 2000
Can you not determine stall speeds with GPS in still air by 4 or more headings? ________________________________________________________________________________
Date: Dec 18, 2000
>Since there are many variables, since there is built-in compensation, and >since Van's recommends against it, I mounted mine straight. That's what is so great about building them yourself. >However aesthetically displeasing this may be, I made and mounted an >adjustable >aluminum tab about midway up the trailing edge. That way I can compensate >for anything including changes that may be made down the road. Well, you can adjust the more hidden wedge, just not as immediate. You take a wedge of whatever (wood, plastic, aluminum) and duct tape it on the rudder, usually the port side, depending on what rudder you have to push too much. Too big? File some off. Too small? Make a bigger one. Then use those dimensions to make a permanent one out of plexiglass or aluminum and tape THAT one on and test it. If it works how you want it to, blind rivet it in place. IMHO, looks a bit more "on purpose" than one sticking out of the trailing edge. There is a whole side of the airplane you can't even see it from, and barely from the other side. Michael ________________________________________________________________________________
Subject: Wood propellers
Date: Dec 18, 2000
I'm having trouble finding an inexpensive (relatively) wood prop. I talked to Sensenich and their would prop, adapter, and crush plate came out only $300 less than their metal prop! Anyone have any suggestions. I want to go metal but just don't like that 2600 RPM limit on the metal props (I have the O320). I checked in the Yeller pages but the phone numbers for Props Inc and Pacesetter are incomplete. My email was returned when I tried to email Aymar-Deymuth. Catto props looks promising and they are close by. Anyone have any experience with them? I'm still waiting for a quote on pricing from them. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 ________________________________________________________________________________
Subject: Re: Lycoming Engine Parts / Supplier
Date: Dec 18, 2000
12/18/2000 14:35:01 Retitled for future e-searching b green To: rv-list(at)matronics.com Sent by: cc: owner-rv-list-server@mat Subject: Re: RV-List: Lycoming IO-360-XXX ronics.com 12/14/2000 08:40 PM Please respond to rv-list I believe there website is www.skydynamics.com. I would agree that the sump and exhaust components from Sky Dynamics are top notch. Have had them both on my Skybolt for the last 15 years. > > How is the best way to get in contact with Sky Dynmanics. > > ________________________________________________________________________________
Subject: Re: Vans Use of Torque Tables / Torque Values
Date: Dec 18, 2000
12/18/2000 15:37:12 I recently called Vans to inquire about Torque values for the wing bolts. I did my homework and consulted the FAA text on Acceptable Repair Methods Book & a 30 page text on Torque I found on the internet........ So I thought I was ready to go. I called Vans to double check & here is what I learned: A) Even though we use the expensive NAS 1306 & 1304 bolts for the wing spar (along with the #10 bolts) we are instructed to use the STANDARD elastic stop NUTS in the plans........ Since we cinch up the NUTS with the torque wrench...... the Tech rep at Vans said we use the STANDARD torque values for standard aircraft ansi fasteners, not the exotic NAS XXXX or whathaveyou. B) All values for torque in Vans world are TENSION. Even if a bolt might be in in sheer load, treat the torque value as if the fastener is in tension.....So sayth the Vans Tech Rep. BTW, a neat trick to ensure your torque wrench is (somewhat) accurate or near accurate.........place a bolt in your vise,attach your torque wrench via a socket to the captured bolt and place a known weight on some safety wire and loop the safety wire around the handle at the pivot. Read the deflection on the torque wrench...it should be whatever the weight you hung times the distance from the bolt to the handle pivot. I used a 5 pound metal lifting weight......easy & simple. I got the idea from someone on this e-list..... ________________________________________________________________________________
Date: Dec 18, 2000
Subject: Re: Wood propellers
Have you tried Ed Sterba? He's moved from Wisconsin to Florida, so the phone# in The Yeller Pages is wrong. He does excellent work and will re-pitch your prop as you require. Boyd N600SS SW FL > > > I'm having trouble finding an inexpensive (relatively) wood prop. I talked > to Sensenich and their would prop, adapter, and crush plate came out only > $300 less than their metal prop! Anyone have any suggestions. I want to go > metal but just don't like that 2600 RPM limit on the metal props (I have the > O320). I checked in the Yeller pages but the phone numbers for Props Inc > and Pacesetter are incomplete. My email was returned when I tried to email > Aymar-Deymuth. Catto props looks promising and they are close by. Anyone > have any experience with them? I'm still waiting for a quote on pricing > from them. > > -- > Scott VanArtsdalen, MCSE, CCNA > Network Administrator > Union Safe Deposit Bank > 209-946-5116 > ________________________________________________________________________________
Date: Dec 18, 2000
Jim's PSS AOA does not give any sort of numerical readout on AOA. The sport Version uses LEDs to notify the pilot when you are approaching critical angle of attack by going from Green to Yellow to Red and also with an aural warning "angle, angle, push". The AOA is calibrated for each different wing and each installation so the angle of attack will show the same weather or not the VG's are installed. If the VG's do work and you don't recalibrate the AOA computer, then when the display shows that critical AOA has been reached it will still alert you but the plane will continue flying. By installing VG's you are effectively changing the airfoil and the AOA will have to be recalibrated (an easy process that take just a few minutes depending on experience). http://www.angle-of-attack.com By the way, in case anyone is wondering, I'm not affiliated in any way with Proprietary Software Systems AOA other than as a customer and someone who need to be able to get into fields shorter than 1200' and believes that slow flight by AOA......good. Slow flight by airspeed only......Bad Mike Nellis - RV-6 N699BM (res) Plainfield, IL Building Tanks http://mnellis.jnet.net/rv-6_page ----- Original Message ----- From: "Charles Rowbotham" <crowbotham(at)hotmail.com> Sent: Monday, December 18, 2000 3:25 PM Subject: Re: RV-List: Stall Speeds/Vortex Generators > > Is anyone flying with Jim Frantz's AOA - If so and you are planning to > install VGs. I'd be interested in the stall AOA number before and after VG > installation. > > Chuck & Dave Rowbotham > RV-8A (painting next week) > Niantic, CT (Westerly airport) > > > >From: "Mike Nellis" <mnellis(at)emailusa.net> > >Reply-To: rv-list(at)matronics.com > >To: > >Subject: Re: RV-List: Stall Speeds/Vortex Generators > >Date: Mon, 18 Dec 2000 00:26:25 -0500 > > > > > >Incorrect, the wing works on Angle of Attack not airspeed. > > > >For example, load the plane up to gross and it might stall at say.....55 > >mph. > >Take that same plane loaded to gross and do some steep turns > >and > >I'll guarantee that it will stall at a lot higher speed than 55 mph. > > > >It's all about Angle of Attack not IAS. Typical stall warning devices are > >angle of attack sensors not airspeed sensors. > > > >Mike Nellis - RV-6 N699BM (res) > >Plainfield, IL > >Building Tanks > >http://mnellis.jnet.net/rv-6_page > > > > > > > > > > You're right. Indicated airspeed is all the wing works on- TAS and GS > >are > > > for navigating. The only variable could come from unstable air -as in > >slight > > > updrafts or downdrafts occuring during the two test flights. > > > ----- Original Message ----- > > > From: Builder's Bookstore <winterland(at)rkymtnhi.com> > > > To: > > > Sent: Sunday, December 17, 2000 2:37 PM > > > Subject: Re: RV-List: Stall Speeds/Vortex Generators > > > > > > > > > > > > > > > > > > I put vortex generators on my RV6A....what is REALLY puzzling me is > >how > > > to > > > > > reasonably determine the stall speed. > > > > > > > > > > > > > I have my VG set, but haven't installed them yet. When I do, I'm going > >to > > > look > > > > at both indicated airspeed and groundspeed as measured on the GPS. > >Between > > > the > > > > two, I should get a reasonable idea of what the VGs are doing. > >However, > > > the GPS > > > > comparison figure is just for academic interest and has no real value. > > > > > > > > The bottom line is that I don't really care what my calibrated or true > > > stall > > > > speeds are. From the operational point of view of the pilot, all that > > > really > > > > matters is Indicated. (Yes, I'm wearing my asbestos suit) I want to > >know > > > how > > > > "my" plane is going to respond in a short or power off landing > > > configuration; > > > > these being the times that the benefits of VGs will most come into > >play. > > > > Indicated will always give that information in an easy to use and > > > dependable > > > > manner. Any other number is fairy irrelevant to the task at hand at > >that > > > moment. > > > > > > > > Andy > > > > > > > > > > > > > > > > > > > > Get your FREE download of MSN Explorer at http://explorer.msn.com > > ________________________________________________________________________________
Date: Dec 18, 2000
Exactly! My only point was that the statement "> > > Indicated airspeed is all the wing works on" is not a true statement. Weight, CG, humidity and other factors affect what the stall speed will be. But one thing doesn't change, the wing will always stall at the same AOA regardless of weight, CG, humidity, angle of bank airspeed etc (assuming no airfoil changes like bugs, frost etc.). The only way to know what the optimum Angle of Attack is, is by using some instrument whether it be a stall warning horn, or one of various AOA devices on the market. Mike ----- Original Message ----- From: "skybolt-aviator" <skybolt-aviator(at)msn.com> Sent: Monday, December 18, 2000 10:34 AM Subject: Re: RV-List: Stall Speeds/Vortex Generators > > Go back to basics: it will always stall at higher a/s in a steep turn. > ----- Original Message ----- > From: "Mike Nellis" <mnellis(at)emailusa.net> > To: > Sent: Monday, December 18, 2000 12:26 AM > Subject: Re: RV-List: Stall Speeds/Vortex Generators > > > > > > Incorrect, the wing works on Angle of Attack not airspeed. > > > > For example, load the plane up to gross and it might stall at say.....55 > > mph. > > Take that same plane loaded to gross up to 8000' and do some steep turns > and > > I'll guarantee that it will stall at a lot higher speed than 55 mph. > > > > It's all about Angle of Attack not IAS. Typical stall warning devices are > > angle of attack sensors not airspeed sensors. > > > > Mike Nellis - RV-6 N699BM (res) > > Plainfield, IL > > Building Tanks > > http://mnellis.jnet.net/rv-6_page > > > > > > > > > > You're right. Indicated airspeed is all the wing works on- TAS and GS > are > > > for navigating. The only variable could come from unstable air -as in > > slight > > > updrafts or downdrafts occuring during the two test flights. > > > ----- Original Message ----- > > > From: Builder's Bookstore <winterland(at)rkymtnhi.com> > > > To: > > > Sent: Sunday, December 17, 2000 2:37 PM > > > Subject: Re: RV-List: Stall Speeds/Vortex Generators > > > > > > > > > > > > > > > > > > I put vortex generators on my RV6A....what is REALLY puzzling me is > > how > > > to > > > > > reasonably determine the stall speed. > > > > > > > > > > > > > I have my VG set, but haven't installed them yet. When I do, I'm going > > to > > > look > > > > at both indicated airspeed and groundspeed as measured on the GPS. > > Between > > > the > > > > two, I should get a reasonable idea of what the VGs are doing. > However, > > > the GPS > > > > comparison figure is just for academic interest and has no real value. > > > > > > > > The bottom line is that I don't really care what my calibrated or true > > > stall > > > > speeds are. From the operational point of view of the pilot, all that > > > really > > > > matters is Indicated. (Yes, I'm wearing my asbestos suit) I want to > know > > > how > > > > "my" plane is going to respond in a short or power off landing > > > configuration; > > > > these being the times that the benefits of VGs will most come into > play. > > > > Indicated will always give that information in an easy to use and > > > dependable > > > > manner. Any other number is fairy irrelevant to the task at hand at > that > > > moment. > > > > > > > > Andy > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Corrosion Already?!?
Date: Dec 18, 2000
Dan, I got the wing and fuselage at the same time. When I started the fuselage. most of the skins had surface discoloration under the vinyl, some of it quite severe. This wasn't crystaline in nature but irregular swirls and ripples of black / brown. I pulled all the vinyl off, removed all the discoloration with a scotchbrite pad on a pad sander, then primed it. I checked thickness in several places and lost no more than 1 to 1.5 thousandths of an inch. I spoke with Tom Green at Copperstate and he had no explanation for why this happened, but agreed with my actions. Interestingly enough, none of the non-alclad parts had any corrosion on them. The wing and empennage skins were flawless. Bill Christie, RV8A, Phoenix, AZ ----- Original Message ----- From: Reeves Family <wdaphdas(at)msn.com> Sent: Sunday, December 17, 2000 6:05 PM Subject: RV-List: Corrosion Already?!? > > I purchased my RV-6A empennage kit a little over a year ago but I am just > now starting to work on it. When the kit first arrived, I inventoried the > two boxes and then tucked everything away on a wood shelf in the basement > while I collected tools, attended a workshop, and mostly procrastinated > getting started. My basement is very dry. However, Pennsylvania is very > humid. All of the parts were removed from the boxes and the shipping paper, > the protective vinyl coating left on, and then they were all laid out > together on one of the white foam sheets that everything was shipped with. > I then laid another foam sheet on top of the parts to keep the dust off. > > When I recently started pulling parts off the shelf, I noticed some thin, > white, salt-like crystals on some of the ribs that didn't have the > protective vinyl coating on them. I didn't worry too much about it since I > could brush most of it off with my fingers. However, I started inspecting > everything much closer and unfortunately found much heavier deposits on the > vertical stabilizer skin. This stuff was underneath the vinyl coating on > both sides, all the way around the edges, from the edge of the skin in to > where the rivet holes start. The vinyl coating was still on tight. When I > pulled the vinyl back about an inch from the edges, the corrosion had eaten > through the alclad in several spots close to the edge. All of the other > skins seemed OK. > > Has anyone else experienced something like this? I am not sure why only > this skin and some of the ribs have the problem. I was planning on priming > things as I go but maybe I need to reconsider and prime everything as soon > as they come in the door. Any insights would be greatly appreciated. > > Thanks, > Dan - empennage corroding in Pennsylvania. > > ________________________________________________________________________________
Date: Dec 18, 2000
Subject: Rivinut Question
Does anyone know where I can get a 4-40 rivinut set? Spruce starts at 6-32 and larger. Any help would be greatly appreciated. -Mike ________________________________________________________________________________
Date: Dec 18, 2000
Subject: Another First Flight
I'm pleased to announce that, after two horizontal stabilizers, three rudder skins, many parts to replace the ones I screwed up, five years, five months, and three days, I flew the maiden flight of my RV-6A, "LOT$A JACK," N333JA, at Camarillo Airport, California on 5 December. I had moved the project from my garage in Los Angeles on 5 October, exactly two months prior to the first flight. I have five flights, 6.3 hours, and five landings on the airplane now, each one of which was a genuine greaser. The airplane is a joy to fly (now that I've corrected a heavy wing), much easier to fly and land than the three RV-6As I flew to prepare myself for this first flight, especially the RV-6A I flew with Mike Seager. I've had a hydraulic leak, fuel leak (on the ground), and three oil leaks thus far, but I've managed to fix them all. I continue making minor fixes and fussing with other things as my flight test program unfolds. I was surprised that the airplane is so loud. I actually have difficulty understanding controllers at times, despite a couple of first class radios and Bose headsets. A friend of mine who also flew his first flight recently complains about the same problem. I wonder how many others have the same experience. No controller has yet complained about difficulty hearing or understanding my transmissions, but I can't say the same. I keep fiddling with the squelch, volume, and mike position, but I can't seem to make any headway. If anyone has some ideas, I'd love to hear them. Best wishes to all, Jack Abell ________________________________________________________________________________
Date: Dec 18, 2000
FWW- epoxy is compatible w/polyester based resins, you may use epoxy based resins to adhere to FRP, however, do not use polyester based resin to adhere to epoxy - once you use epoxy you can't go back to polyester. ________________________________________________________________________________
Subject: Slider Fiberglass Skirt
Date: Dec 18, 2000
Several people asked how I made my fiberglass rear skirt for the -6. Here is what I did. I'm sure some of these steps could be streamlined. I had the al. side skirts and plexi clecoed on & the plexi trimmed to final shape. The holes were drilled thru the plexi and the rear frame around the back side. There was about 2.5" gap from the plexi to the rear turtle deck that had to be spanned with the FG skirt. Some I laid up 2 plys of 5.7 oz. BID fiberglass to span the gap. I taped the rear turtle deck to the rear frame with packing tape, with plexi removed. Cut two long strips of cloth on the 45 deg. bias, plenty wide to span from the frame to the turtle deck. Wet out the cloth with epoxy, i chose to brush epoxy on the packing tape, lay a piece of cloth in place, then wet it out by brushing on more resin. Then lay on a 2nd piece of cloth & wet out with the brush. After this hardens, the FG is drilled thru to the holes in the rear frame. Remove this piece & all tape. The FG is then trimmed with scissors 1/4" away from the holes and to about 1/2" overlap onto the top skin. This FG was done in two pieces, one for each side. They met up by the slider track. This piece was then taped over with packing tape, then the plexi reinstalled on the frame. The rear was taped down tight to the top skin. The tape was waxed. Modeling clay is used to form around the slider track. Electricians tape is used around the edges to mark where the fiberglass will be trimmed. Back from this tape, everything is masked off well. I taped down around the side skirts so I could pick up two rivets thru the FG & into the side skirts. Now you're ready to lay up the rear skirt. Cut enough cloth on the bias for about 4 layers. I cut them so they overlapped in the middle above the slider track (this doubles the thickness up there.) Two of the strips were a little narrower than the first two. With this done, time to mix resin. Brush on resin over the lay up area. Then mix up some cotton flock with the epoxy resin. Use this very thick goo to fill in everywhere need to make a smooth transition like around the rear of the plexi and the side skirts. Brush on resin over this goo. Lay on the first piece of fiberglass, starting 3" on the other side of the top track & then down onto the side skirt. Wet out & repeat on the other side. Repeat until done. Wait a couple hrs. until the resin is like rubber & then trim w/ an exacto knife carefully to get to your electrician tape edge. I did this trimming only over the plexi & the side skirts. I just sanded the rear edge to get a smooth edge after the fairing was done. Retape the front edge after the resin hardens. Drill thru FG to the holes in the frame & skirts. Now the FG needs filling. I use WEST Microlite filler mixed with epoxy. Sand the fiberglass & wipe off the dust. Brush resin & filler on the fiberglass. Squeege on thick filler to fill the low spots. When cured, sand with 60 grit on a rubber block. Repeat 2 or 3 times until you're satisfied. Drill the holes again because they now have filler in them & c'sink for the rivets. Open up the slider and pull out the first FG piece you made from under the plexi. Sand the rear edge of the FG skirt. Remove all tape. Rivet on the plexi. Fill the rivet heads w/ epoxy/filler. Brush on straight resin when done filling. Final sand w/ 180/240 grit. Don't sand thru the resin/filler to the FG 'cause pinholes will appear. Close the canopy and then try to imagine getting a fit like that with aluminum! Hope this helps someone. Rick Caldwell -6 170 hrs Melbourne, FL Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 18, 2000
-----Original Message----- From: pcondon(at)csc.com <pcondon(at)csc.com> Date: Monday, December 18, 2000 3:37 PM Subject: Re: RV-List: Vans Use of Torque Tables / Torque Values > >I recently called Vans to inquire about Torque values for the wing bolts. I >did my homework and consulted the FAA text on Acceptable Repair Methods >Book & a 30 page text on Torque I found on the internet........ So I >thought I was ready to go. I called Vans to double check & here is what I >learned: A) Even though we use the expensive NAS 1306 & 1304 bolts for the >wing spar (along with the #10 bolts) we are instructed to use the STANDARD >elastic stop NUTS in the plans........ Since we cinch up the NUTS with the >torque wrench...... the Tech rep at Vans said we use the STANDARD torque >values for standard aircraft ansi fasteners, not the exotic NAS XXXX or >whathaveyou. B) All values for torque in Vans world are TENSION. Even >if a bolt might be in in sheer load, treat the torque value as if the >fastener is in tension.....So sayth the Vans Tech Rep. Maybe someone can help me out re the above. I thought that: 1) Bolt torque is generally set to achieve tension to about 80% of yield strength, to establish proper pre-load. 2) Elastic stop nuts are suitable for use with NAS bolts and their associated (higher) torques (shear nuts -- the thin jobs -- would not be suitable). 3) There are, to my knowledge, no "NAS nuts" -- use regular nuts with NAS bolts. Dennis Persyk N600DP 25 hours Hampshire, IL C38 ________________________________________________________________________________
Date: Dec 18, 2000
Bill, Wilco on the Prince props. Also, you check out Catto props. www.cattoprops.com <http://www.cattoprops.com> I talked to Craig Catto at some length today. He makes composite props for pushers as well but having great success in RV's. He patiently explained his process and answered all my questions. He'll make you a two or three blade prop in about 6 to 8 weeks for under $1000. Real, nice guy. Unless something really changes my mind, I'm going to call him back in Jan or Feb and order a prop from him. I'm going to copy the RV-List on this reply. Hope you don't mind. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Bill VonDane [mailto:bvondane(at)cso.atmel.com] Sent: Monday, December 18, 2000 2:15 PM To: Van Artsdalen, Scott Subject: RE: RV-List: Wood propellers Hey Scott... I'm with you! Check out Prince P-tip Composite props in your AS catalog... I have a friend that is running one on a pusher, and he loves it! They don't list RV's in my catalog, but I was planning on calling them. Let me know what you think... -Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Van Artsdalen, Scott Sent: Monday, December 18, 2000 1:17 PM To: Rv-List (E-mail) Subject: RV-List: Wood propellers I'm having trouble finding an inexpensive (relatively) wood prop. I talked to Sensenich and their would prop, adapter, and crush plate came out only $300 less than their metal prop! Anyone have any suggestions. I want to go metal but just don't like that 2600 RPM limit on the metal props (I have the O320). I checked in the Yeller pages but the phone numbers for Props Inc and Pacesetter are incomplete. My email was returned when I tried to email Aymar-Deymuth. Catto props looks promising and they are close by. Anyone have any experience with them? I'm still waiting for a quote on pricing from them. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 ________________________________________________________________________________
Date: Dec 18, 2000
Subject: Re: Another First Flight(DNA)
In a message dated 12/18/00 5:45:50 PM Eastern Standard Time, jbabell(at)mediaone.net writes: > I keep fiddling with the squelch, volume, and mike > position, but I can't seem to make any headway. If anyone has some > ideas, I'd love to hear them. Congradulations on a sucessful build and first flights. I assume you do not have active noise cancelling headsets?? I have trouble if I forget to activate the active switch on my Lightspeed, but with it on I have had not problems hearing. I am deaf in a crowded noisy bar, but can here very good if there is no background noise so the ANR is a real benefit to me. Bernie Kerr, 6A flying, SE Fla ________________________________________________________________________________
Date: Dec 18, 2000
Dennis Persyk wrote: > 3) There are, to my knowledge, no "NAS nuts" -- use regular nuts with NAS > bolts. Hi Dennis, This caught my eye because, having just mounted the gear legs on my -8, I have recent experience with NAS nuts. The NAS bolts for the gear legs are secured with hardened washers and NAS679A6 all metal lock nuts. The torque specified by Van's for this combination is the same (240 in. lbs.) as for the AN365 type nuts formerly paired with the same NAS bolts. -- Regards, Ken Balch Ashland, MA RV-8 #81125 N118KB (reserved) interior details www.egroups.com/files/bostonrvbuilders ________________________________________________________________________________
Subject: RV-6
Date: Dec 18, 2000
I have a 1993 RV-6 Empenage and Wing kit for sale. The empenage kit is 95% complete. The wing kit which has the Phlogiston spar has been uncrated, but not touched since. Both kits are before the pre-punched era. I did not order the electric trim or any other options. Will sell both kits for $3000.00. Vans cost today would be around $6085.00. I live in Dadeville, Alabama which is 120 miles southwest of Atlanta, Ga. If I can answer any more questions ________________________________________________________________________________
Date: Dec 18, 2000
> >>Has anyone else installed and flown the VG kit from Vetterman? I spoke with >>Larry at some length about the VG's (what a nice and helpful guy), and they >>sound like the best $350 you could spend on your airplane, but I'm wondering >>if Van himself has gotten his hands on a set and tried them out. > > >I am in the process of testing the Vetterman VG kit. I have gone to some >pains to install a swivel pitot head to remove as much position error as >possible. I saw the most significant change with flaps extended. I did >not go beyond 10 degrees of flaps. I will re-run the entire test >sequence using the entire flap range. > >Pictures and text of the test results can be found at this link: > ><http://www.ontariorvators.org/pitot/pitot.htm> > >When I'm satisfied that I have good data, I will report back to the >list. > >Terry Jantzi Terry, Thanks for sharing your progress to date. I'm looking forward to seeing the data for full flap. I'm not sure I understand why you are seeing more of a stall speed decrease than I expected. A 7 But you don't have to understand something for it to be true. I'll quietly ponder this some more. I've got to see if I can find any wind tunnel data that might help explain this. I might have to eat some crow after all :-) Have fun, be careful, -- Kevin Horton RV-8 (fuselage 98% done) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Date: Dec 18, 2000
Subject: Re: RV6-List: RV-6
Joe, It just so happens I am in the market for a wing kit. I was going to order it from Van's after the first of the year. I already have a Empennage kit of my own and mine is also the before pre-punch design. Have you done anything to the wing kit other than uncrate it? Do you still have the inventory sheet? And do you still have the crate? Dave Moore >I have a 1993 RV-6 Empenage and Wing kit for sale. The empenage kit is 95% >complete. The wing kit which has the Phlogiston spar has been uncrated, but >not touched since. Both kits are before the pre-punched era. I did not order >the electric trim or any other options. Will sell both kits for $3000.00. >Vans cost today would be around $6085.00. I live in Dadeville, Alabama which >is 120 miles southwest of Atlanta, Ga. If I can answer any more questions David G. Moore mailto:dgmoore1(at)gte.net Henderson, Nevada ________________________________________________________________________________
(Content Technologies SMTPRS 2.0.15) with ESMTP id for" ; Mon, 18 Dec 2000 14:16:07.-0500(at)matronics.com
Subject: Stall Speeds/Vortex Generators
Date: Dec 18, 2000
12/18/2000 02:11:56 PM If the vortex generators really produce a reduced stall speed, then the angle of attack must increase at stall as a result, right? My buddies -6 with an O-360 and CS prop will thump the tailwheel down soundly on landing while 5-10 MPH above stall. It seems that increasing the pitch angle/stall speed would yield a benefit that would be very impractical for normal RV operations. Based on the way his 1100lb airplane handles I think a tailwheel touchdown at 46-50 MPH would be extremely hard on the gear and engine mount. I was also intrigued by the prospect of vortex generators but would sure hate to have those things out there in the breeze if they will not benefit me in normal ops. Just wondering where the day to day benefit would kick in. Of course it would be fun to tell guys they add 10 kts to cruise and listen to them rationalize it. Eric Henson ________________________________________________________________________________
Date: Oct 13, 2000
Scott, Wood props are beautiful. I could look and admire them them all day long. I have a Canadian Colin Walker prop. I have no idea what the price is since it came with my -6 when I bought it two yrs ago. I like its light color since it's made out of maple. It does not have the metal protective leading edges. For what's it's worth, give Colin a call at 604-581-9602.. He's a pleasant man (as I find most Canadians are) to talk to. Anh N985VU Maryland > > >I'm having trouble finding an inexpensive (relatively) wood prop. I talked >to Sensenich and their would prop, adapter, and crush plate came out only >$300 less than their metal prop! Anyone have any suggestions. I want to go >metal but just don't like that 2600 RPM limit on the metal props (I have the >O320). I checked in the Yeller pages but the phone numbers for Props Inc >and Pacesetter are incomplete. My email was returned when I tried to email >Aymar-Deymuth. Catto props looks promising and they are close by. Anyone >have any experience with them? I'm still waiting for a quote on pricing >from them. > >-- >Scott VanArtsdalen, MCSE, CCNA >Network Administrator >Union Safe Deposit Bank >209-946-5116 > > ________________________________________________________________________________
Date: Dec 18, 2000
Subject: Re: Rivinut Question
In a message dated 12/18/00 2:25:06 PM Pacific Standard Time, N8292W(at)AOL.COM writes: << Does anyone know where I can get a 4-40 rivnut set? Spruce starts at 6-32 and larger. Any help would be greatly appreciated. >> I've got one I'll loan you. You pay postage. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: Dec 18, 2000
I just bought a Culver. Quickest delivery time, low price (795), and his #'s were right on. I wanted 2350 static with 2700 full throttle, right now my static is 2340 and level at 1000 I'm showing 2680. I'm told my numbers will go up as the engine breaks in. I don't have his ph #, but I think he advertises in Sport Aviation. Carey Mills RV4 22hrs ________________________________________________________________________________
Date: Dec 18, 2000
Subject: engine mounting bolts torque values
I now have about 22 hrs on my 4 and would like to re torque the engine bolts. I have no ideal what I did with the values I had, if someone has them please drop me a line. Thanks, Carey ________________________________________________________________________________
Date: Dec 19, 2000
Subject: Re: Lycoming and Auto gas
In a message dated 12/15/2000 1:20:45 PM Pacific Standard Time, bcbraem(at)home.com writes: << Excuse my curiousity/ignorance, but what is this "snowblower" and where is it on the plane/plans? >> Hey, how do you think he gets through those whiteout conditions??? do not archive ________________________________________________________________________________
Date: Dec 18, 2000
I have a Paul Irlbeck prop. I hear that he is not into making props much anymore, but might have time to cut one for you. His work is exceptional. Several builders here in Arizona have his prop, and love it. His prices are very competitive...I think I paid around $700 for mine. His number is (651) 565-3563. Paul Besing RV-6A (197AB) Arizona http://www.lacodeworks.com/besing Finish Kit (Still) ----- Original Message ----- From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com> Sent: Monday, December 18, 2000 1:17 PM Subject: RV-List: Wood propellers > > > I'm having trouble finding an inexpensive (relatively) wood prop. I talked > to Sensenich and their would prop, adapter, and crush plate came out only > $300 less than their metal prop! Anyone have any suggestions. I want to go > metal but just don't like that 2600 RPM limit on the metal props (I have the > O320). I checked in the Yeller pages but the phone numbers for Props Inc > and Pacesetter are incomplete. My email was returned when I tried to email > Aymar-Deymuth. Catto props looks promising and they are close by. Anyone > have any experience with them? I'm still waiting for a quote on pricing > from them. > > -- > Scott VanArtsdalen, MCSE, CCNA > Network Administrator > Union Safe Deposit Bank > 209-946-5116 > > ________________________________________________________________________________
Subject: Re: 6-A-QB Verticle Stabalizer
Date: Dec 18, 2000
[pros and cons of offsetting the v-stab from Randy Lervold snipped] > True, many > find this visually offensive, but I appreciate the functionality and > adjustability of it. Local builder Randall Henderson took the same approach. > Now that he's flying I seem to recall that his tab is adjusted pretty much > in trail, but at least he has the ability to fine tune it if need be, as > will I. Actually I didn't put the tab on until after I'd flown and knew I needed one. It is not in trail, it is bent a little to offset the approx 1/3 -1/2 ball it's out in cruise without it. I suppose it may seem aesthetically less than ideal to some people. But it as Randy said, the tab gives you the flexibility to adjust if things change your trim down the road. Besides the judges at Oshkosh apparently didn't have a problem with it.... :-) Randall Henderson, RV-6 N6R (~175 hrs) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
Date: Dec 19, 2000
Donald Mei wrote: > 1) What is the appropriate size wire to make a 6 foot run from the switch to > the strobe. Assume 10 amps. 10 amps???? You're aiming to *really* visible, aren't you! I suggest that about 2 amps is more likely to be a realistic figure. Frank. ________________________________________________________________________________
Date: Dec 19, 2000
Those look really good... I would love to put a 3 blade prop on my -8A! -Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Van Artsdalen, Scott Sent: Monday, December 18, 2000 5:26 PM Subject: RE: RV-List: Wood propellers Bill, Wilco on the Prince props. Also, you check out Catto props. www.cattoprops.com <http://www.cattoprops.com> I talked to Craig Catto at some length today. He makes composite props for pushers as well but having great success in RV's. He patiently explained his process and answered all my questions. He'll make you a two or three blade prop in about 6 to 8 weeks for under $1000. Real, nice guy. Unless something really changes my mind, I'm going to call him back in Jan or Feb and order a prop from him. I'm going to copy the RV-List on this reply. Hope you don't mind. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Bill VonDane [mailto:bvondane(at)cso.atmel.com] Sent: Monday, December 18, 2000 2:15 PM To: Van Artsdalen, Scott Subject: RE: RV-List: Wood propellers Hey Scott... I'm with you! Check out Prince P-tip Composite props in your AS catalog... I have a friend that is running one on a pusher, and he loves it! They don't list RV's in my catalog, but I was planning on calling them. Let me know what you think... -Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Van Artsdalen, Scott Sent: Monday, December 18, 2000 1:17 PM To: Rv-List (E-mail) Subject: RV-List: Wood propellers I'm having trouble finding an inexpensive (relatively) wood prop. I talked to Sensenich and their would prop, adapter, and crush plate came out only $300 less than their metal prop! Anyone have any suggestions. I want to go metal but just don't like that 2600 RPM limit on the metal props (I have the O320). I checked in the Yeller pages but the phone numbers for Props Inc and Pacesetter are incomplete. My email was returned when I tried to email Aymar-Deymuth. Catto props looks promising and they are close by. Anyone have any experience with them? I'm still waiting for a quote on pricing from them. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 ________________________________________________________________________________
From: "Jones, Bryan D." <bryan.jones@lyondell-citgo.com>
Subject: RV-8 Ldg Gear, Was Vans Use of Torque Tables / Torque Values
Date: Dec 19, 2000
Regarding the landing gear and associated bolting on the -8, I have recently had a problem that others might want to be aware of. I fly my plane from a grass strip. A week or so ago, I was landing and experienced a strange problem. Just after touching down, I began applying braking pressure (maybe a little heavier than normal since it was nearly dark). At that time I experienced what I'd call a fairly extreme chatter (a lot like a nose wheel shimmy, but higher frequency). I let up on the brakes and the chatter stopped. What I believe happened was the wheel was lightly loaded (the plane was still just below stall speed) and it began a slip/skid type situation. The grass strip is in fair condition, but has sections which are moderately rough. When I got back into the hanger, I noticed that I had some fiberglass damage and the left gear was loose. It had about 1/4" play fore and aft. When I pulled the gear attachment cover off to inspect the gear attachment, I found three loose bolts. I have to assume that the chatter caused the loose bolts. Specifically, the chatter action stretched the bolts. I haven't taken the bolts out yet. When I do, I'll know for sure if the bolts stretched or just what the deal is. I've bought new bolts and a new outboard gear leg steel attachment component. I'll probably replace them all, depending on the results of the inspection. Has anyone else experienced this problem? If not, be aware of heavy braking on anything other than very smooth surfaces. I called Van's and the person I discussed the problem with had not heard of this occurring. Bryan Jones -8 765BJ ~58-hrs Pearland, Texas ________________________________________________________________________________
Date: Dec 19, 2000
Subject: Re: RV-8 Ldg Gear, Was Vans Use of Torque Tables / Torque
Values Wow. I'm glad that the gear leg held on and that you and your -8 are both OK. Please keep us posted as to the results of your inspection and any info forthcoming from Van's. This is enough to make me think seriously about avoiding unpaved surfaces in my -8. -- Regards, Ken Balch Ashland, MA RV-8 #81125 N118KB (reserved) interior details www.egroups.com/files/bostonrvbuilders "Jones, Bryan D." wrote: > > Regarding the landing gear and associated bolting on the -8, I have recently > had a problem that others might want to be aware of. I fly my plane from a > grass strip. A week or so ago, I was landing and experienced a strange > problem. Just after touching down, I began applying braking pressure (maybe > a little heavier than normal since it was nearly dark). At that time I > experienced what I'd call a fairly extreme chatter (a lot like a nose wheel > shimmy, but higher frequency). I let up on the brakes and the chatter > stopped. What I believe happened was the wheel was lightly loaded (the > plane was still just below stall speed) and it began a slip/skid type > situation. The grass strip is in fair condition, but has sections which are > moderately rough. > > When I got back into the hanger, I noticed that I had some fiberglass damage > and the left gear was loose. It had about 1/4" play fore and aft. When I > pulled the gear attachment cover off to inspect the gear attachment, I found > three loose bolts. I have to assume that the chatter caused the loose > bolts. Specifically, the chatter action stretched the bolts. > > I haven't taken the bolts out yet. When I do, I'll know for sure if the > bolts stretched or just what the deal is. I've bought new bolts and a new > outboard gear leg steel attachment component. I'll probably replace them > all, depending on the results of the inspection. > > Has anyone else experienced this problem? If not, be aware of heavy braking > on anything other than very smooth surfaces. I called Van's and the person > I discussed the problem with had not heard of this occurring. > > Bryan Jones -8 765BJ ~58-hrs > Pearland, Texas ________________________________________________________________________________
Subject: Re: engine mounting bolts torque values
Date: Dec 19, 2000
12/19/2000 10:27:13 One problem you will run into when doing this re-torque is the break-loose torque is more(higher value) and will give you a misleading value of your assumed clamping force (torque). The other side if the double edged sword is...you have to releive( i.e. loosen ) the torque on a fastener in order to retighten and torque it properly. This un-tightning or loosing of the bolts may lead to localized warping of the casting you are trying to torque. Remember the tightning sequence charts...these were established to lessen the warpage. Rvmils(at)AOL.COM Sent by: To: rv-list(at)matronics.com owner-rv-list-server@mat cc: ronics.com Subject: RV-List: engine mounting bolts torque values 12/18/2000 11:38 PM Please respond to rv-list I now have about 22 hrs on my 4 and would like to re torque the engine bolts. I have no ideal what I did with the values I had, if someone has them please drop me a line. Thanks, Carey ________________________________________________________________________________
Subject: Re: RV-8 Ldg Gear, Was Vans Use of Torque Tables / Torque Values
Date: Dec 19, 2000
> ><bryan.jones@lyondell-citgo.com> > >Regarding the landing gear and associated bolting on the -8, I have >recently >had a problem that others might want to be aware of. I fly my plane from a >grass strip. A week or so ago, I was landing and experienced a strange >problem. Just after touching down, I began applying braking pressure >(maybe >a little heavier than normal since it was nearly dark). At that time I >experienced what I'd call a fairly extreme chatter (a lot like a nose wheel >shimmy, but higher frequency). I let up on the brakes and the chatter >stopped. What I believe happened was the wheel was lightly loaded (the >plane was still just below stall speed) and it began a slip/skid type >situation. The grass strip is in fair condition, but has sections which >are >moderately rough. > >When I got back into the hanger, I noticed that I had some fiberglass >damage >and the left gear was loose. It had about 1/4" play fore and aft. When I >pulled the gear attachment cover off to inspect the gear attachment, I >found >three loose bolts. I have to assume that the chatter caused the loose >bolts. Specifically, the chatter action stretched the bolts. > >I haven't taken the bolts out yet. When I do, I'll know for sure if the >bolts stretched or just what the deal is. I've bought new bolts and a new >outboard gear leg steel attachment component. I'll probably replace them >all, depending on the results of the inspection. > >Has anyone else experienced this problem? If not, be aware of heavy >braking >on anything other than very smooth surfaces. I called Van's and the person >I discussed the problem with had not heard of this occurring. > >Bryan Jones -8 765BJ ~58-hrs >Pearland, Texas Bryan, I followed Van's specs for torqueing the bolts and to leave a slight gap between the U blocks and the wear plates. This led to some loose bolts! I never had the vibration issue, but it took several turns on the nuts to tighten up the gear....and man what a pain that was. Getting a socket on those nuts inside the gear boxes has got to be the worst part to access in the entire airplane. I noticed this looseness at about 50 hours...right when the manual says to retorque them. So, I personally would just tighten the bolts SNUGLY at initial installation and ignore the gap. Crank 'em down and move on. I still have a slight squeeking noise coming from the left gear box area when the plane is rocked laterally. I cannot for the life of me figure out where this is coming from. It did not improve after tightening the nuts. I just replaced the tires and brake pads last month. While the plane was jacked up on stands, I checked the gear legs. Really yanked on them fore and aft. They are rock solid. So far, so good. Best of luck to ya. Brian Denk Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 19, 2000
I took a look at one of his props late last night on a friend's airplane. Wow! Really nice work! I'm going to call him up in Jan and order a two-blade model. Call me crazy but I've never really liked 3-bladed props. I like the looks of the plain old 2 blade props. Or maybe it's from hand-propping my Champ hundreds of times. If my starter goes south, I can hand prop my 4 if it has a two blade prop. Or if I don't want my hands anymore I guess I could try to prop a three blade prop! -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Bill VonDane [mailto:bvondane(at)cso.atmel.com] Sent: Tuesday, December 19, 2000 6:32 AM To: rv-list(at)matronics.com Subject: RE: RV-List: Wood propellers Those look really good... I would love to put a 3 blade prop on my -8A! -Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Van Artsdalen, Scott Sent: Monday, December 18, 2000 5:26 PM To: Bill VonDane Subject: RE: RV-List: Wood propellers Bill, Wilco on the Prince props. Also, you check out Catto props. www.cattoprops.com <http://www.cattoprops.com> I talked to Craig Catto at some length today. He makes composite props for pushers as well but having great success in RV's. He patiently explained his process and answered all my questions. He'll make you a two or three blade prop in about 6 to 8 weeks for under $1000. Real, nice guy. Unless something really changes my mind, I'm going to call him back in Jan or Feb and order a prop from him. I'm going to copy the RV-List on this reply. Hope you don't mind. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Bill VonDane [mailto:bvondane(at)cso.atmel.com] Sent: Monday, December 18, 2000 2:15 PM To: Van Artsdalen, Scott Subject: RE: RV-List: Wood propellers Hey Scott... I'm with you! Check out Prince P-tip Composite props in your AS catalog... I have a friend that is running one on a pusher, and he loves it! They don't list RV's in my catalog, but I was planning on calling them. Let me know what you think... -Bill -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Van Artsdalen, Scott Sent: Monday, December 18, 2000 1:17 PM To: Rv-List (E-mail) Subject: RV-List: Wood propellers Artsdalen, Scott" I'm having trouble finding an inexpensive (relatively) wood prop. I talked to Sensenich and their would prop, adapter, and crush plate came out only $300 less than their metal prop! Anyone have any suggestions. I want to go metal but just don't like that 2600 RPM limit on the metal props (I have the O320). I checked in the Yeller pages but the phone numbers for Props Inc and Pacesetter are incomplete. My email was returned when I tried to email Aymar-Deymuth. Catto props looks promising and they are close by. Anyone have any experience with them? I'm still waiting for a quote on pricing from them. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 ________________________________________________________________________________
Date: Dec 19, 2000
In a discussion with Robby Grove of "Grove Aluminum Landing Gear" fame he said that the weakest parts of the Van's gear design are the mounting bolts. He expects them to strip loose after a certain number of hard landings. It seems that this could be aggravated by off field landings too. It's too bad that we don't have a factory airplane to compare with. I will be interested to hear the status of Bryan's bolts. Ed Perry RV8-QB 180hp/CS 1/2 pitot heat -----Original Message----- From: Ken Balch <kbalch1(at)mediaone.net> Date: Tuesday, December 19, 2000 7:37 AM Subject: Re: RV-List: RV-8 Ldg Gear, Was Vans Use of Torque Tables / Torque Values > >Wow. I'm glad that the gear leg held on and that you and your -8 are both OK. >Please keep us posted as to the results of your inspection and any info forthcoming >from Van's. > >This is enough to make me think seriously about avoiding unpaved surfaces in my -8. > >-- >Regards, >Ken Balch >Ashland, MA >RV-8 #81125 N118KB (reserved) >interior details >www.egroups.com/files/bostonrvbuilders > > >"Jones, Bryan D." wrote: > <bryan.jones@lyondell-citgo.com> >> >> Regarding the landing gear and associated bolting on the -8, I have recently >> had a problem that others might want to be aware of. I fly my plane from a >> grass strip. A week or so ago, I was landing and experienced a strange >> problem. Just after touching down, I began applying braking pressure (maybe >> a little heavier than normal since it was nearly dark). At that time I >> experienced what I'd call a fairly extreme chatter (a lot like a nose wheel >> shimmy, but higher frequency). I let up on the brakes and the chatter >> stopped. What I believe happened was the wheel was lightly loaded (the >> plane was still just below stall speed) and it began a slip/skid type >> situation. The grass strip is in fair condition, but has sections which are >> moderately rough. >> >> When I got back into the hanger, I noticed that I had some fiberglass damage >> and the left gear was loose. It had about 1/4" play fore and aft. When I >> pulled the gear attachment cover off to inspect the gear attachment, I found >> three loose bolts. I have to assume that the chatter caused the loose >> bolts. Specifically, the chatter action stretched the bolts. >> >> I haven't taken the bolts out yet. When I do, I'll know for sure if the >> bolts stretched or just what the deal is. I've bought new bolts and a new >> outboard gear leg steel attachment component. I'll probably replace them >> all, depending on the results of the inspection. >> >> Has anyone else experienced this problem? If not, be aware of heavy braking >> on anything other than very smooth surfaces. I called Van's and the person >> I discussed the problem with had not heard of this occurring. >> >> Bryan Jones -8 765BJ ~58-hrs >> Pearland, Texas > > Request a CDROM 1-800-333-3633 ________________________________________________________________________________
Date: Dec 19, 2000
Subject: Re: RV6-List Digest: 3 Msgs - 12/17/00
CHECKLIST: I have 2 separate checklists I developed which are comprehensive for my 6A. One for prestart, other side for preflight, then one for prelanding. They are laminated and computer generated with some notations in red. Also made up a cheatsheet for the VM 1000 which is somewhat complicated in various modes. It helps a little. I could email you what I have and you could modify/regenerate to suit, then print, then lamiunate. Mine are about 3.5" X 5.0" Doug B. ________________________________________________________________________________
Subject: VS offset to eliminate rudder trim tab
Date: Dec 19, 2000
The "BEST" aeronautical solution is more right thrust in the engine. I've never heard of a design that offsets the vertical stab. My buddie's Bellanca has at least an inch or more offset. Very noticable on that (300 HP modified) ship. Many other planes do also. Just look when you're at Oshkosh, you'll see plenty. I built a 4 previously, and helped on many others. My 4 needed a 1/4" left offset of the VS to eliminate the tab. The offset worked perfectly. My HRII (under construction) has the tab on the HS where the VS attaches enlarged by 3/8 inch on the left side specifically so I can offset my VS about a 1/4" to the left. I'd like to hear a report from anyone who has shimmed the engine to accomplish the same thing. How did it work and how much shim is required? Did you need to adjust the cowl? Adjusting the cowl on a finished RV certainly isn't very appealing. Vince in Indiana ________________________________________________________________________________
Date: Dec 19, 2000
I seriously doubt that you stretched the bolts. The chatter occurred because of looseness. Either the bolts were over-torqued on installation or some one forgot to torque them. ----- Original Message ----- From: Jones, Bryan D. <bryan.jones@lyondell-citgo.com> Sent: Tuesday, December 19, 2000 8:27 AM Subject: RV-List: RV-8 Ldg Gear, Was Vans Use of Torque Tables / Torque Values <bryan.jones@lyondell-citgo.com> > > Regarding the landing gear and associated bolting on the -8, I have recently > had a problem that others might want to be aware of. I fly my plane from a > grass strip. A week or so ago, I was landing and experienced a strange > problem. Just after touching down, I began applying braking pressure (maybe > a little heavier than normal since it was nearly dark). At that time I > experienced what I'd call a fairly extreme chatter (a lot like a nose wheel > shimmy, but higher frequency). I let up on the brakes and the chatter > stopped. What I believe happened was the wheel was lightly loaded (the > plane was still just below stall speed) and it began a slip/skid type > situation. The grass strip is in fair condition, but has sections which are > moderately rough. > > When I got back into the hanger, I noticed that I had some fiberglass damage > and the left gear was loose. It had about 1/4" play fore and aft. When I > pulled the gear attachment cover off to inspect the gear attachment, I found > three loose bolts. I have to assume that the chatter caused the loose > bolts. Specifically, the chatter action stretched the bolts. > > I haven't taken the bolts out yet. When I do, I'll know for sure if the > bolts stretched or just what the deal is. I've bought new bolts and a new > outboard gear leg steel attachment component. I'll probably replace them > all, depending on the results of the inspection. > > Has anyone else experienced this problem? If not, be aware of heavy braking > on anything other than very smooth surfaces. I called Van's and the person > I discussed the problem with had not heard of this occurring. > > Bryan Jones -8 765BJ ~58-hrs > Pearland, Texas > > ________________________________________________________________________________
Date: Dec 19, 2000
How does the Grove gear mount to the -8? Presumably with bolts...? How are his mounting bolts different from Van's? Ken edperry64 wrote: > > In a discussion with Robby Grove of "Grove Aluminum Landing Gear" fame he > said that the weakest parts of the Van's gear design are the mounting bolts. > He expects them to strip loose after a certain number of hard landings. It > seems that this could be aggravated by off field landings too. It's too bad > that we don't have a factory airplane to compare with. I will be interested > to hear the status of Bryan's bolts. > Ed Perry > RV8-QB 180hp/CS 1/2 pitot heat ________________________________________________________________________________
Date: Dec 19, 2000
12/19/2000 11:38:39 There are indeed special nuts that have a higher torque value when used with the NAS-xxxx bolts (and other hi $$ bolts). My point I wanted to convey is that even when using these special NAS close tolerance bolts, we are instructed to use the old reliable 365 nuts. In such a configuration we use the torque value of the regular old aircraft 365 nut........ as suttle point but if you were to go the the torque tables and read down the list for NAS bolts, one might forget that the 365 nuts are the limiting factor here (limiting isn't the right word here but close enough) "Dennis Persyk" t> cc: Sent by: Subject: Re: RV-List: Vans Use of Torque Tables / Torque owner-rv-list-server@mat Values ronics.com 12/18/2000 07:11 PM Please respond to rv-list -----Original Message----- From: pcondon(at)csc.com <pcondon(at)csc.com> Date: Monday, December 18, 2000 3:37 PM Subject: Re: RV-List: Vans Use of Torque Tables / Torque Values > >I recently called Vans to inquire about Torque values for the wing bolts. I >did my homework and consulted the FAA text on Acceptable Repair Methods >Book & a 30 page text on Torque I found on the internet........ So I >thought I was ready to go. I called Vans to double check & here is what I >learned: A) Even though we use the expensive NAS 1306 & 1304 bolts for the >wing spar (along with the #10 bolts) we are instructed to use the STANDARD >elastic stop NUTS in the plans........ Since we cinch up the NUTS with the >torque wrench...... the Tech rep at Vans said we use the STANDARD torque >values for standard aircraft ansi fasteners, not the exotic NAS XXXX or >whathaveyou. B) All values for torque in Vans world are TENSION. Even >if a bolt might be in in sheer load, treat the torque value as if the >fastener is in tension.....So sayth the Vans Tech Rep. Maybe someone can help me out re the above. I thought that: 1) Bolt torque is generally set to achieve tension to about 80% of yield strength, to establish proper pre-load. 2) Elastic stop nuts are suitable for use with NAS bolts and their associated (higher) torques (shear nuts -- the thin jobs -- would not be suitable). 3) There are, to my knowledge, no "NAS nuts" -- use regular nuts with NAS bolts. Dennis Persyk N600DP 25 hours Hampshire, IL C38 ________________________________________________________________________________
Subject: Re: Checklists
Date: Dec 19, 2000
12/19/2000 11:47:32 If you could e-mail the source data to one of the VANS wings groups...they might-(with a quick prior arrangement) host the data so other of us might download the checklists....... "Douglas E. Bostard" To: rv6-list(at)matronics.com Sent by: cc: owner-rv-list-server@mat Subject: RV-List: Re: RV6-List Digest: 3 Msgs - 12/17/00 ronics.com 12/19/2000 09:30 AM Please respond to rv-list CHECKLIST: I have 2 separate checklists I developed which are comprehensive for my 6A. One for prestart, other side for preflight, then one for prelanding. They are laminated and computer generated with some notations in red. Also made up a cheatsheet for the VM 1000 which is somewhat complicated in various modes. It helps a little. I could email you what I have and you could modify/regenerate to suit, then print, then lamiunate. Mine are about 3.5" X 5.0" Doug B. ________________________________________________________________________________
Date: Dec 19, 2000
Does the Grove gear do things differently to try to address this? Larry, RV-8 gearboxes --- edperry64 wrote: > > In a discussion with Robby Grove of "Grove Aluminum Landing Gear" fame he > said that the weakest parts of the Van's gear design are the mounting bolts. > He expects them to strip loose after a certain number of hard landings. It > seems that this could be aggravated by off field landings too. It's too bad > that we don't have a factory airplane to compare with. I will be interested > to hear the status of Bryan's bolts. > Ed Perry > RV8-QB 180hp/CS 1/2 pitot heat > -----Original Message----- > From: Ken Balch <kbalch1(at)mediaone.net> > To: rv-list(at)matronics.com > Date: Tuesday, December 19, 2000 7:37 AM > Subject: Re: RV-List: RV-8 Ldg Gear, Was Vans Use of Torque Tables / Torque > Values > > > > > >Wow. I'm glad that the gear leg held on and that you and your -8 are both > OK. > >Please keep us posted as to the results of your inspection and any info > forthcoming > >from Van's. > > > >This is enough to make me think seriously about avoiding unpaved surfaces > in my -8. > > > >-- > >Regards, > >Ken Balch > >Ashland, MA > >RV-8 #81125 N118KB (reserved) > >interior details > >www.egroups.com/files/bostonrvbuilders > > > > > >"Jones, Bryan D." wrote: > > > <bryan.jones@lyondell-citgo.com> > >> > >> Regarding the landing gear and associated bolting on the -8, I have > recently > >> had a problem that others might want to be aware of. I fly my plane from > a > >> grass strip. A week or so ago, I was landing and experienced a strange > >> problem. Just after touching down, I began applying braking pressure > (maybe > >> a little heavier than normal since it was nearly dark). At that time I > >> experienced what I'd call a fairly extreme chatter (a lot like a nose > wheel > >> shimmy, but higher frequency). I let up on the brakes and the chatter > >> stopped. What I believe happened was the wheel was lightly loaded (the > >> plane was still just below stall speed) and it began a slip/skid type > >> situation. The grass strip is in fair condition, but has sections which > are > >> moderately rough. > >> > >> When I got back into the hanger, I noticed that I had some fiberglass > damage > >> and the left gear was loose. It had about 1/4" play fore and aft. When > I > >> pulled the gear attachment cover off to inspect the gear attachment, I > found > >> three loose bolts. I have to assume that the chatter caused the loose > >> bolts. Specifically, the chatter action stretched the bolts. > >> > >> I haven't taken the bolts out yet. When I do, I'll know for sure if the > >> bolts stretched or just what the deal is. I've bought new bolts and a > new > >> outboard gear leg steel attachment component. I'll probably replace them > >> all, depending on the results of the inspection. > >> > >> Has anyone else experienced this problem? If not, be aware of heavy > braking > >> on anything other than very smooth surfaces. I called Van's and the > person > >> I discussed the problem with had not heard of this occurring. > >> > >> Bryan Jones -8 765BJ ~58-hrs > >> Pearland, Texas > > > > > > > Request a CDROM 1-800-333-3633 > > > > > > > > ________________________________________________________________________________
Date: Dec 19, 2000
Jack, CONGRATULATIONS & WELL DONE !!!! Chuck & Dave Rowbotham RV08A (Painting next week) Niantic, CT Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Subject: Re: Acceptable repairs
Date: Dec 19, 2000
Are, For what you did, t5hat repair looks fine. Carry on and don't worry. Mike Robertson RV-8A N809RS 12.9 hours >From: "Are Barstad" <abarstad(at)bconnex.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Acceptable repairs >Date: Sat, 16 Dec 2000 21:45:24 -0500 > > >I made a goof on one of my wing ribs and made a quick repair. When I was >finished and stood back to admire it, I thought that I could maybe have >made >the attachment on the rib larger with room for more rivets. I couldn't find >this particular answer in AC43. > >Can anyone tell me if they think this repair is acceptable? I rather redo >it >now (before skinning) if it could be better or not pass inspection. > >Please click on link for picture. > >http://www.avsim.com/hangar/fly/hangar/rib1.jpg > >Thanks, >Are >RV-8 Wings > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Subject: Kuntzelman Strobes
Date: Dec 19, 2000
Dear Listers, I am writing to tell of an excellent customer service experience that I just had. I recently purchased a strobe head from Kuntzelman Electronics (kestrobes.com) Last night I test ran the strobe and power supply. After running the strobe for about 5 minutes I shut the system off. When I inspected the head of the Kuntzelman streamlined head I noticed that one side of the lexan enclosure was discoloring. Upon closer inspection, I noticed that one twist of the strobe tube was too close to the lexan and was melting it. I called Kuntzelman and I spoke with a gentleman who immediately pulled my address up on the computer after I gave him my name and said "we'll just ship you out another one" No questions, no "shipping cost is my problem" or "we have to wait until we get the old one back", etc. He just offered to send me another and asked that I send the old one back when I get a chance. This kind of support and service is rare in this world, I urge you all to support this company if they provide a product that suits your needs. Best regards, Don Mei RV-4 N92CT Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Date: Dec 19, 2000
-----Original Message----- From: Jones, Bryan D. <bryan.jones@lyondell-citgo.com> Date: Tuesday, December 19, 2000 8:35 AM Subject: RV-List: RV-8 Ldg Gear, Was Vans Use of Torque Tables / Torque Values <bryan.jones@lyondell-citgo.com> > When I >pulled the gear attachment cover off to inspect the gear attachment, I found >three loose bolts. I have to assume that the chatter caused the loose >bolts. Specifically, the chatter action stretched the bolts. > >I haven't taken the bolts out yet. When I do, I'll know for sure if the >bolts stretched or just what the deal is. I've bought new bolts and a new >outboard gear leg steel attachment component. I'll probably replace them >all, depending on the results of the inspection >>Bryan Jones -8 765BJ ~58-hrs >Pearland, Texas > How will you determine if the bolts stretched? AN bolts have a generous length tolerance, so unless you mic'ed them before installation, it seems the uncertainty in length would far exceed the stretch. My guess is that the bolts were loose and that's why it chattered. Interesting problem. Let us know how it is resolved. Dennis Persyk 6A N600DP still only 25 hours (snow) Hampshire, IL C38 ________________________________________________________________________________
Subject: Re: Vans Use of Torque Tables / Torque Values
Date: Dec 19, 2000
-----Original Message----- From: pcondon(at)csc.com <pcondon(at)csc.com> Date: Tuesday, December 19, 2000 10:42 AM Subject: Re: RV-List: Vans Use of Torque Tables / Torque Values > >There are indeed special nuts that have a higher torque value when used >with the NAS-xxxx bolts (and other hi $$ bolts). My point I wanted to >convey is that even when using these special NAS close tolerance bolts, we >are instructed to use the old reliable 365 nuts. In such a configuration we >use the torque value of the regular old aircraft 365 nut........ as suttle >point but if you were to go the the torque tables and read down the list >for NAS bolts, one might forget that the 365 nuts are the limiting factor >here (limiting isn't the right word here but close enough) > > I sure don't get the sense that you need special nuts for NAS bolts. My AC43.13-1A Change 3, page 118, lists Van's supplied NAS bolts in the middle "steel tension" column. The higher torque values are listed for AN365 nuts along with several other AN, MS and NAS nuts. The message and intent of AC43.13 seems very clear: AN365 nuts are not a limiting factor in establishing bolt torque for NAS bolts. There are special NAS nuts but they are not required to establish proper torque. Dennis Persyk 6A N600DP 25 hours Hampshire, IL C38 ________________________________________________________________________________
Subject: Poor Man's Encoder
Date: Dec 18, 2000
Ever wanted to know exactly what your transponder was showing to controllers ? Where I live, one of the controllers is a pretty cranky, condescending old bastard who thinks he owns the airspace 'cause he helped draft the pattern rules here. It is a training environment with lots of neophytes who are a bit nervous anyway, but get rattled when they are dumped on by "Ol Crank" for being less proficient than an ATP pilot. I have been 2 miles farther back than my estimate when calling, and been reamed and also told, we show you at 1700 if I say I was at 1500.... Anyway, the point of this soliloquy, is that several months ago, on this list, there was a mention of a poor man's encoder readout display in kit form or finished form for only about $150...even less for the do-it-yourself. I thought it was a great feature to have and know that the readout I would see was what the transponder was saying to old skinflint. Long story short, I ordered the kit from the fellow who happens to be an electronic whiz, commercial pilot, and RV4 owner. I was very happy with the kit, had a lot of fun constructing something electronic, leading edge, and novel. Bottom line was I had made a very tiny "solder bridge"......(gimme some slack..I'm old, and the eyes ain't what they were)..... I sent the unit back for testing, and he fixed my boo-boo, nothing to do with the kit or complexity or lack thereof, and gave it back to me ..no charge, working like a champ. I forgot to send postage and he even forgave that....Pretty exemplary service I would say !! So if you want a great feature not found on most factory planes and less on experimentals, which will be a boon to your information at hand while in the airspace, key in at....http://www.am2.com or call Mitch Robbins at 952-894-4716 Minnesota for info on this module which would be a very nice stocking stuffer to yourself from your beloved or however you want to justify a nice goody for yourself. I am in no way related or connected to Mr. Robbins or his enterprise....never met him, but he has created a very useful, low-cost encoder for the little guy and the product and service are second to none. Check it out. Austin. ________________________________________________________________________________
Subject: Re: Circuit Breaker Quesiton
Date: Dec 19, 2000
Kurt, I can help with a few of your questions if someone hasen't already. 1. The RMI MocroEncoder uses a 1 amp CB. I tied mine in on the same CB with the transponder and it has worked great. 2> For your alternator you can use a CB or Fuse. For the voltage regulator it will depend on which regulator you get. Mike Robertson RV-8A N809RS >From: KAKlewin(at)AOL.COM >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Circuit Breaker Quesiton >Date: Fri, 15 Dec 2000 18:33:18 EST > > >For those of you using circuit breakers and not fuses...Im doing some panel >planning and have a few questions as to the type (amp) of breaker for a few >applications... > 1. Amp rating for breaker for RMI Encoder and Monitor > > 2. Amp rating for breaker for the electric primer in the ACS book... > > 3. If I go with a B&C alternator (40a or 60a...havent decided >yet)...what >breakers are required...I would guess I need a 1amp and 5 amp for the >regulator...can I use a breaker for the output or is a fuse a better option >here...??? > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 19, 2000
I am not aware of anything Grove does that is different than Van but when we were talking about his aluminum gear he was stressing to me that the bolts would fail before the landing gear. Ed Perry 180/CS Aluminum gear ordered -----Original Message----- From: Ken Balch <kbalch1(at)mediaone.net> Date: Tuesday, December 19, 2000 9:03 AM Subject: Re: RV-List: RV-8 Ldg Gear > >How does the Grove gear mount to the -8? Presumably with bolts...? How are his >mounting bolts different from Van's? > >Ken > >edperry64 wrote: > >> >> In a discussion with Robby Grove of "Grove Aluminum Landing Gear" fame he >> said that the weakest parts of the Van's gear design are the mounting bolts. >> He expects them to strip loose after a certain number of hard landings. It >> seems that this could be aggravated by off field landings too. It's too bad >> that we don't have a factory airplane to compare with. I will be interested >> to hear the status of Bryan's bolts. >> Ed Perry >> RV8-QB 180hp/CS 1/2 pitot heat > > ________________________________________________________________________________
Date: Dec 19, 2000
> For those of you using circuit breakers and not fuses...Im doing some panel > >planning and have a few questions as to the type (amp) of breaker for a few > >applications... > > 1. Amp rating for breaker for RMI Encoder and Monitor > > > > 2. Amp rating for breaker for the electric primer in the ACS book... > I won't presume to speak for Electric Bob, but I believe the question you need to be asking is: what size wire will you run to these devices? That answer alone will tell you what current rating the fuse or CB must have. This assumes you are not using wire that is too small to carry the load. For these devices, it is hard to find wire that is too light for their current draw. Remember, the fuse or CB is to keep the smoke inside the wire. It will not/can not protect your electronics from self-destructing. Bill Boyd RV-6A O-320/Sensenich FP Hop-Along Air Field, 12VA Clifton Forge, VA ________________________________________________________________________________
Subject: Re: Rib to Spar - Design flaw?
Date: Dec 19, 2000
Are, According to what I see your "repairs" should be fine. This type of repair is found in AC43.13 but I don't have my copy handy to give you a page number. Irregardless, I think you will be fine. Carry on and build. MIke Robertson RV-8A N809RS >From: "Are Barstad" <abarstad(at)bconnex.net> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Rib to Spar - Design flaw? >Date: Sun, 17 Dec 2000 14:31:37 -0500 > > >Am I missing something? It seems to weird that only I have this problem. > >Harry Crosby brought up a good point though: Van's should be able to tell >me >if it's a 'go' or not with my earlier rib fix. I have made the following >web >page to prove that all these ribs must be repaired in order to pass >inspection (at least here in Canada). > >Here's the link that I will send Van's: (This time it's much more >illustrative). Please have a look if you're building an RV-8. > >http://www.bconnex.net/~abarstad/RibToSpar.html > >Are >RV-8 Wings > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Subject: ISP
Date: Dec 19, 2000
Listers, My ISP is calling it quits. Can anyone recommend a reliable, reasonable one (reasonable being in the $9.95/Mo. or less range) Thanks, Bill RV-8 N48WD Tiger-Kat ________________________________________________________________________________
Date: Dec 19, 2000
The encoder read-out device that is being mentioned is nice, but it does NOT necessarily show what you are transmitting...it may or it may not. The connections that the maker calls for are those that are the output of your encoder...not the output of the transponder. If the transponder is having problems it may or may not be transmitting the output from the encoder correctly or at all. The device is interesting and the price is good, but it does NOT tell you positively what you are sending. There are devices on the market that pick up your transponder's transmitted radio frequency emissions, and translate that information to altitude for a direct readout. That type of system WILL tell you exactly what you are really sending. FWIW ________________________________________________________________________________
Subject: Re: Poor Man's Encoder
Date: Dec 19, 2000
The odds are that what this device show is what is being sent as either the transponder sends what the encoder is showing or it doesn't transmit. If it drops a single bit, the receiver will know that there is a missing bit and will discard the info. ----- Original Message ----- From: John <fasching(at)amigo.net> Sent: Tuesday, December 19, 2000 5:58 PM Subject: RV-List: Poor Man's Encoder > > The encoder read-out device that is being mentioned is nice, but it does NOT > necessarily show what you are transmitting...it may or it may not. The > connections that the maker calls for are those that are the output of your > encoder...not the output of the transponder. If the transponder is having > problems it may or may not be transmitting the output from the encoder > correctly or at all. > > The device is interesting and the price is good, but it does NOT tell you > positively what you are sending. There are devices on the market that pick > up your transponder's transmitted radio frequency emissions, and translate > that information to altitude for a direct readout. That type of system WILL > tell you exactly what you are really sending. > > FWIW > > ________________________________________________________________________________
Date: Dec 19, 2000
Subject: Pilots Operating Handbook
I'm in the process of flying off my 40hrs and trying to put together a POH. Does anyone know where I can find one on the web to copy for a guide? Thanks, Carey Mills RV4, 24hrs ________________________________________________________________________________
Subject: 6-A Battery Box
Date: Dec 19, 2000
I am installing the battery box and was wondering if anyone could explain to me why the bottom is attached to the floor stiffeners the way it is. Why is the 7" x 15/16" 6104 piece used and why is only one bolt going through the battery box bottom and the other is just bolted to the floor stiffener. Why can't I just put two nutplates per side on the battery box bottom and do without the extra 7" piece? Van must have had a reason for designing it this way but it sure baffles me!!!! Ross ________________________________________________________________________________
Subject: Re: 6-A Battery Box
Date: Dec 20, 2000
Ross, Those pieces spread the load over a greater length on the floor reinforcement angles. That battery is mighty heavy at 9 g ultimate. Actually, I seem to remember the battery box is designed to even greater g loading than that. Rick Caldwell -6 O-320 CS Melbourne, FL >From: "Ross" <rmickey(at)ix.netcom.com> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: 6-A Battery Box >Date: Tue, 19 Dec 2000 18:00:39 -0800 > > >I am installing the battery box and was wondering if anyone could explain >to >me why the bottom is attached to the floor stiffeners the way it is. Why >is >the 7" x 15/16" 6104 piece used and why is only one bolt going through the >battery box bottom and the other is just bolted to the floor stiffener. >Why >can't I just put two nutplates per side on the battery box bottom and do >without the extra 7" piece? Van must have had a reason for designing it >this way but it sure baffles me!!!! > >Ross > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Subject: "lectric Bob"
Date: Dec 19, 2000
For those hoping "Lectric Bob: will pipe up and give one of his famous in depth answers to our "lectric" questions you need to know he now resides on a new list and can be contract @ owner-aeroelectric-list-server(at)matronics.com. I was having withdrawal symptoms not seeing and reading his well-scripted answers to our questions so I signed up for the aeroelectric-list and now I feel much better... Don ________________________________________________________________________________
Subject: fly with the vinyl on?
Date: Dec 20, 2000
Listers, Just wondering out loud here as I contemplate ripping off another large sheet of internal skin vinyl. Why? Why take it off other than the strips needed for deburring/dimpling? If I am not going to prime the inside of the sheeting then what is the harm other than weight? Won't it continue to provide corrosion protection? Will the stuff degrade and flake off over time? It's plastic and never sees direct UV rays. Seems unlikely to me. Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 19, 2000
Ross, Two things come to mind. First is that the designer (I think it was Andy Hanna) is trying to spread the load of the battery along more of the longerons than just in the area under the box. The added material is also be adding structural reinforcement to the longeron in that highly loaded (during high g's) area. Second possibility is that it's a left over part from the floor mounted rudder pedals and doesn't have anything to do with spreading out the load of the battery. I seem to remember something like that, but then again, I have the overhead rudder pedals. Remember, the opinions you get from the list are just that. Without asking Van's engineering staff, one will never know. Laird (fitting new windshield) SoCal I am installing the battery box and was wondering if anyone could explain to me why the bottom is attached to the floor stiffeners the way it is. Why is the 7" x 15/16" 6104 piece used and why is only one bolt going through the battery box bottom and the other is just bolted to the floor stiffener. Why can't I just put two nutplates per side on the battery box bottom and do without the extra 7" piece? Van must have had a reason for designing it this way but it sure baffles me!!!! Ross ________________________________________________________________________________
Date: Dec 19, 2000
Subject: Re: fly with the vinyl on?
I WONDERED THE SAME THING AS I TUGGED ON ALL THOSE BIG PIECES OF PLASTIC. WHATS THE ANSWER ? MIKE [ RV-4 WITH 195HP O320 JUST HUNG] ________________________________________________________________________________
Date: Dec 19, 2000
> I am installing the battery box and was wondering if anyone could explain to > me why the bottom is attached to the floor stiffeners the way it is. Why is > the 7" x 15/16" 6104 piece used and why is only one bolt going through the > battery box bottom and the other is just bolted to the floor stiffener. Some of the stuff is leftover from the old floor mount rudder pedals. Mount 'er up the way you see fit. Alex Peterson Maple Grove, MN 6A ------ http://USFamily.Net/info - Unlimited Internet - From $7.99/mo! ------ ________________________________________________________________________________
Date: Dec 19, 2000
195 HP O320? -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of MTMCGOWAN(at)AOL.COM Sent: Tuesday, December 19, 2000 8:07 PM Subject: Re: RV-List: fly with the vinyl on? I WONDERED THE SAME THING AS I TUGGED ON ALL THOSE BIG PIECES OF PLASTIC. WHATS THE ANSWER ? MIKE [ RV-4 WITH 195HP O320 JUST HUNG] ________________________________________________________________________________
Date: Dec 19, 2000
BUILT BY LY-CON IN VISALIA, CAL. IT'S A BEAUTY MIKE ________________________________________________________________________________
Date: Dec 20, 2000
lucky macy wrote: > Just wondering out loud here as I contemplate ripping off another large > sheet of internal skin vinyl. Why? Why take it off other than the strips > needed for deburring/dimpling? If I am not going to prime the inside of the > sheeting then what is the harm other than weight? Won't it continue to > provide corrosion protection? > > Will the stuff degrade and flake off over time? It's plastic and never sees > direct UV rays. Seems unlikely to me. I guess it's heavier than paint. How good is the glue that holds the plastic to the aluminium? Will it let go in a few hundred hours? If it lets go, what will the sheet of plastic do? Wrap round/jam up any controls? Frank. ________________________________________________________________________________
From: "jayeandscott" <jayeandscott(at)compuserve.com>
Subject: Re: Stall Speeds/Vortex Generators
Date: Dec 19, 2000
As the box lid to the game says: Such mighty contests from trivia arise-or something to that effect. ----- Original Message ----- From: Mike Nellis <mnellis(at)emailusa.net> Sent: Monday, December 18, 2000 4:54 AM Subject: Re: RV-List: Stall Speeds/Vortex Generators > > Yes, of course, you are correct regarding indicated airspeed at altitude. I > hit "send" a little to quick and realized that point afterward. > > Thanks for the correction. > > Mike Nellis - RV-6 N699BM (res) > Plainfield, IL > Building Tanks > http://mnellis.jnet.net/rv-6_page > > > > > > Well, yes and no. You are correct that it will stall at a higher indicated > > airspeed in a steep turn, but there will be no difference in the indicated > > stalling speed > > caused by altitude-that's why we fly high-the airplane accelerates until > the > > drag equals the thrust-the same power setting must generate the same > > indicated airspeed at all altitudes-only the true airspeed goes up----- > > Original Message ----- > > From: Mike Nellis <mnellis(at)emailusa.net> > > To: > > Sent: Sunday, December 17, 2000 9:26 PM > > Subject: Re: RV-List: Stall Speeds/Vortex Generators > > > > > > > > > > Incorrect, the wing works on Angle of Attack not airspeed. > > > > > > For example, load the plane up to gross and it might stall at > say.....55 > > > mph. > > > Take that same plane loaded to gross up to 8000' and do some steep turns > > and > > > I'll guarantee that it will stall at a lot higher speed than 55 mph. > > > > > > It's all about Angle of Attack not IAS. Typical stall warning devices > are > > > angle of attack sensors not airspeed sensors. > > > > > > Mike Nellis - RV-6 N699BM (res) > > > Plainfield, IL > > > Building Tanks > > > http://mnellis.jnet.net/rv-6_page > > > > > > > > > > > > > > You're right. Indicated airspeed is all the wing works on- TAS and GS > > are > > > > for navigating. The only variable could come from unstable air -as in > > > slight > > > > updrafts or downdrafts occuring during the two test flights. > > > > ----- Original Message ----- > > > > From: Builder's Bookstore <winterland(at)rkymtnhi.com> > > > > To: > > > > Sent: Sunday, December 17, 2000 2:37 PM > > > > Subject: Re: RV-List: Stall Speeds/Vortex Generators > > > > > > > > > > > > > > > > > > > > > > > I put vortex generators on my RV6A....what is REALLY puzzling me > is > > > how > > > > to > > > > > > reasonably determine the stall speed. > > > > > > > > > > > > > > > > I have my VG set, but haven't installed them yet. When I do, I'm > going > > > to > > > > look > > > > > at both indicated airspeed and groundspeed as measured on the GPS. > > > Between > > > > the > > > > > two, I should get a reasonable idea of what the VGs are doing. > > However, > > > > the GPS > > > > > comparison figure is just for academic interest and has no real > value. > > > > > > > > > > The bottom line is that I don't really care what my calibrated or > true > > > > stall > > > > > speeds are. From the operational point of view of the pilot, all > that > > > > really > > > > > matters is Indicated. (Yes, I'm wearing my asbestos suit) I want to > > know > > > > how > > > > > "my" plane is going to respond in a short or power off landing > > > > configuration; > > > > > these being the times that the benefits of VGs will most come into > > play. > > > > > Indicated will always give that information in an easy to use and > > > > dependable > > > > > manner. Any other number is fairy irrelevant to the task at hand at > > that > > > > moment. > > > > > > > > > > Andy > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 19, 2000
Thank you all so much for your responses. Since I am building an all electric two alternator system, I will be using a small, 12 amp battery that will be strapped to the firewall and floor portions of the battery box. It will not be enclosed. It will only extend 4" away from the firewall. I will therefore contemplate leaving the extensions out after I have checked with Vans to make sure they are not needed to stiffen the floor. Ross ________________________________________________________________________________
Subject: radios
Date: Dec 19, 2000
Does anyone have any experience with the ICS Plus combination comm/vor/glidscope/intercom all in one?sure would save space and would be simple. Only costs $1360. Andy ________________________________________________________________________________
Date: Dec 20, 2000
I would under no circumstance fly with the vinyl left on. The accident report on Steve Whitman indicated that it was caused by wing fabric in front of one of the ailerons becoming unattached, disrupting the airflow and inducing flutter in the aileron which quickly destroyed the wing and aircraft. So the vinyl would not have to come loose and jam a control to give you a bad day. Ed Anderson > lucky macy wrote: > > Just wondering out loud here as I contemplate ripping off another large > > sheet of internal skin vinyl. Why? Why take it off other than the strips > > needed for deburring/dimpling? If I am not going to prime the inside of the > > sheeting then what is the harm other than weight? Won't it continue to > > provide corrosion protection? > > > > Will the stuff degrade and flake off over time? It's plastic and never sees > > direct UV rays. Seems unlikely to me. > > I guess it's heavier than paint. How good is the glue that holds the > plastic to the aluminium? Will it let go in a few hundred hours? If it > lets go, what will the sheet of plastic do? Wrap round/jam up any > controls? > > Frank. > > ________________________________________________________________________________
Date: Dec 20, 2000
> snip >Why > can't I just put two nutplates per side on the battery box bottom and do > without the extra 7" piece? Van must have had a reason for designing it > this way but it sure baffles me!!!! > > Ross > This small piece is a holdover from when the rudder pedal torque tube was mounted along the floor instead of overhead. The installation required notching the floor stiffeners. The small piece is a reinforcement for the two center floor stiffeners. The plans have never been updated to reflect the change in the rudder pedal mounting. Since my pedals have the overhead mount I just left the small piece off. Merry Christmas, Stan Blanton RV-6 ________________________________________________________________________________
Date: Dec 20, 2000
I'd be concerned about moisture getting under the edges of the plastic and causing corrosion later on. Besides, you're putting a lot of time and money into this airplane so why try to skimp on a little labor and maybe some *rimer? Dave N87DL 43hrs So.CA Frank and Dorothy wrote: > > lucky macy wrote: > > Just wondering out loud here as I contemplate ripping off another large > > sheet of internal skin vinyl. Why? Why take it off other than the strips > > needed for deburring/dimpling? If I am not going to prime the inside of the > > sheeting then what is the harm other than weight? Won't it continue to > > provide corrosion protection? > > > > Will the stuff degrade and flake off over time? It's plastic and never sees > > direct UV rays. Seems unlikely to me. > > I guess it's heavier than paint. How good is the glue that holds the > plastic to the aluminium? Will it let go in a few hundred hours? If it > lets go, what will the sheet of plastic do? Wrap round/jam up any > controls? > > Frank. > ________________________________________________________________________________
Date: Dec 20, 2000
if it's Alclad then whether it's covered with vinyl or not, gets moisture trapped in between or not, it shouldn't oxidize, right? minus a scratch here or there? remember, this is the inside of the skins. >From: Dave Bristol <bj034(at)lafn.org> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: fly with the vinyl on? >Date: Wed, 20 Dec 2000 07:10:35 -0800 > > >I'd be concerned about moisture getting under the edges of the plastic and >causing >corrosion later on. Besides, you're putting a lot of time and money into >this >airplane so why try to skimp on a little labor and maybe some *rimer? > >Dave N87DL 43hrs So.CA > >Frank and Dorothy wrote: > > > > > lucky macy wrote: > > > Just wondering out loud here as I contemplate ripping off another >large > > > sheet of internal skin vinyl. Why? Why take it off other than the >strips > > > needed for deburring/dimpling? If I am not going to prime the inside >of the > > > sheeting then what is the harm other than weight? Won't it continue >to > > > provide corrosion protection? > > > > > > Will the stuff degrade and flake off over time? It's plastic and >never sees > > > direct UV rays. Seems unlikely to me. > > > > I guess it's heavier than paint. How good is the glue that holds the > > plastic to the aluminium? Will it let go in a few hundred hours? If it > > lets go, what will the sheet of plastic do? Wrap round/jam up any > > controls? > > > > Frank. > > > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Subject: Edge Distance problem solved!
Date: Dec 20, 2000
Thanks again to everyone giving me advice about the rib to spar RV-8 Edge Distance problem. Also, thanks to all that e-mailed me and thanking me for a solution to their similar problem(s). As Kevin Horton says: My advice is only worth as much as you paid for it (nothing) so please only make this modification after you carefully research each individual case. And please do consult Van's and/or your local inspector. IMO, It seems the Canadian Inspectors have less tolerance for not following AC43.13 than the American Inspectors. Of course, I may be wrong. I spoke with Scott at Van's and he remembered that they had a problem designing proper edge distance at this particular area on the RV-8. He further told me that my modifications were fine and that proper strength was restored. My MD-RA inspector (Canadian version of EAA (FAA?) inspectors) told me yesterday he would definitely not pass this as it was before I modified it. 1/8" edge distance on a 1/8" rivet simply won't do it - not even close. He would commit a crime by signing it off. He did tell me though that simply adding another rivet could have solved it but this is almost impossible in this particular case since the 'reinforcement fork' is in the way and too narrow at some of the areas. Are RV-8 Wings Are Barstad Director, Information Services ADP/IICC Investor Communications Direct line: (905) 565-5276 E-mail: abarstad(at)adpiicc.com ________________________________________________________________________________
Date: Dec 20, 2000
The answer is: Take it off! I left the vinyl on my right elevator when I reskinned it, thinking it'd be a nice protection until I got around to painting it. Well, after months out in the sun the vinyl is cracked and impossible to get off. Finn MTMCGOWAN(at)AOL.COM wrote: > > I WONDERED THE SAME THING AS I TUGGED ON ALL THOSE BIG PIECES OF PLASTIC. > WHATS THE ANSWER ? MIKE [ RV-4 WITH 195HP O320 JUST > HUNG] > Why pay for something you could get for free? ________________________________________________________________________________
Date: Dec 20, 2000
For clarity, the question pertains to vinyl on the INSIDE of the skins - not the outside. >From: Finn Lassen <finnlassen(at)netzero.net> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: fly with the vinyl on? >Date: Wed, 20 Dec 2000 11:00:43 -0500 > > >The answer is: Take it off! > >I left the vinyl on my right elevator when I reskinned it, thinking it'd be >a >nice protection until I got around to painting it. Well, after months out >in >the sun the vinyl is cracked and impossible to get off. > >Finn > >MTMCGOWAN(at)AOL.COM wrote: > > > > > I WONDERED THE SAME THING AS I TUGGED ON ALL THOSE BIG PIECES OF >PLASTIC. > > WHATS THE ANSWER ? MIKE [ RV-4 WITH 195HP O320 >JUST > > HUNG] > > > >Why pay for something you could get for free? > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 20, 2000
12/20/2000 11:34:33 Bake a test piece, with the blue wrap on , in the oven at 200 / 225 degrees and see what happens. Temps get pretty close to that in the sun...imagine yourself at a flyin for 8 hours in the blistering sun......the skin gets pretty hot. "lucky macy" To: rv-list(at)matronics.com Sent by: cc: owner-rv-list-server@mat Subject: Re: RV-List: fly with the vinyl on? ronics.com 12/20/2000 10:20 AM Please respond to rv-list if it's Alclad then whether it's covered with vinyl or not, gets moisture trapped in between or not, it shouldn't oxidize, right? minus a scratch here or there? remember, this is the inside of the skins. >From: Dave Bristol <bj034(at)lafn.org> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: Re: RV-List: fly with the vinyl on? >Date: Wed, 20 Dec 2000 07:10:35 -0800 > > >I'd be concerned about moisture getting under the edges of the plastic and >causing >corrosion later on. Besides, you're putting a lot of time and money into >this >airplane so why try to skimp on a little labor and maybe some *rimer? > >Dave N87DL 43hrs So.CA > >Frank and Dorothy wrote: > > > > > lucky macy wrote: > > > Just wondering out loud here as I contemplate ripping off another >large > > > sheet of internal skin vinyl. Why? Why take it off other than the >strips > > > needed for deburring/dimpling? If I am not going to prime the inside >of the > > > sheeting then what is the harm other than weight? Won't it continue >to > > > provide corrosion protection? > > > > > > Will the stuff degrade and flake off over time? It's plastic and >never sees > > > direct UV rays. Seems unlikely to me. > > > > I guess it's heavier than paint. How good is the glue that holds the > > plastic to the aluminium? Will it let go in a few hundred hours? If it > > lets go, what will the sheet of plastic do? Wrap round/jam up any > > controls? > > > > Frank. > > > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Subject: ISP
Date: Dec 20, 2000
Thanks to all who made suggestions as to ISP's. One of them should work out. Regards, Bill RV-8 N46WD Tiger-Kat ________________________________________________________________________________
Date: Dec 20, 2000
Subject: Re: Pilots Operating Handbook
I would like to get as copy of a RV pilots operating handbook even though I have put over 400 hours on my RV4 (282EM) in the last 5 years.I am 69 and those have been the best years of my life flying this incredible airplane.Keep pounding those rivets!!!! ________________________________________________________________________________
Subject: Re: RV-List Digest: 58 Msgs - 12/19/00
Date: Dec 20, 2000
Re: Subject: RV-List: RV-8 Ldg Gear, Was Vans Use of Torque Tables / Torque Values <bryan.jones@lyondell-citgo.com> ------------------- Maybe the lose bolts are what allowed the chatter to occur in the first place? Don Mei Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
From: "Jones, Bryan D." <bryan.jones@lyondell-citgo.com>
Subject: RV-8 Ldg Gear, Was Vans Use of Torque Tables / Torq
ue Values
Date: Dec 20, 2000
Why do you think the bolts wouldn't have stretched? If someone didn't torque them enough, then they were too loose and allowed the chatter event to occur and stretch the bolts. If they were over torqued, then they yielded under the increased load caused by the chatter (occurring for some other reason). -----Original Message----- From: Cy Galley [mailto:cgalley(at)qcbc.org] Sent: Tuesday, December 19, 2000 10:21 AM Subject: Re: RV-List: RV-8 Ldg Gear, Was Vans Use of Torque Tables / Torque Values I seriously doubt that you stretched the bolts. The chatter occurred because of looseness. Either the bolts were over-torqued on installation or some one forgot to torque them. ________________________________________________________________________________
Date: Dec 20, 2000
In a message dated 12/19/00 5:58:55 PM Pacific Standard Time, rmickey(at)ix.netcom.com writes: << Why is the 7" x 15/16" 6104 piece used and why is only one bolt going through the battery box bottom and the other is just bolted to the floor stiffener. >> Ross: If you are asking about the 7" long F-6120E piece, I asked Van's the same question awhile back and the answer was to more evenly distribute the weight of the battery over a greater length of the floor longerons. Harry Crosby Pleasanton, California RV-6, working on canopy installation ________________________________________________________________________________
Date: Dec 20, 2000
I've had parts waiting to be used in the building process where the vinyl let moisture in around the edges. Quite a bit of corrosion set in under the vinyl in these areas. do not arcive Jerry Wilken Albany Oregon ________________________________________________________________________________
Date: Dec 20, 2000
Here's my $.02 If you don't have time to pull the vinyl off, what else will you have no time for??? Do the job right ! My old Drill Instructor once said " If a guy doesn't shine the back of his shoes.. he probably doesn't wipe his ass either !" End of $.02 Ed Cole RV6A > -----Original Message----- > From: pcondon(at)csc.com [SMTP:pcondon(at)csc.com] > Sent: Wednesday, December 20, 2000 8:40 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: fly with the vinyl on? > > > Bake a test piece, with the blue wrap on , in the oven at 200 / 225 > degrees and see what happens. Temps get pretty close to that in the > sun...imagine yourself at a flyin for 8 hours in the blistering > sun......the skin gets pretty hot. > > > > > "lucky macy" > > To: > rv-list(at)matronics.com > Sent by: cc: > > owner-rv-list-server@mat Subject: Re: > RV-List: fly with the vinyl on? > ronics.com > > > > > > 12/20/2000 10:20 AM > > Please respond to > > rv-list > > > > > > > > > if it's Alclad then whether it's covered with vinyl or not, gets moisture > trapped in between or not, it shouldn't oxidize, right? minus a scratch > here or there? remember, this is the inside of the skins. > > > >From: Dave Bristol <bj034(at)lafn.org> > >Reply-To: rv-list(at)matronics.com > >To: rv-list(at)matronics.com > >Subject: Re: RV-List: fly with the vinyl on? > >Date: Wed, 20 Dec 2000 07:10:35 -0800 > > > > > >I'd be concerned about moisture getting under the edges of the plastic > and > >causing > >corrosion later on. Besides, you're putting a lot of time and money into > >this > >airplane so why try to skimp on a little labor and maybe some *rimer? > > > >Dave N87DL 43hrs So.CA > > > >Frank and Dorothy wrote: > > > > > > > > > lucky macy wrote: > > > > Just wondering out loud here as I contemplate ripping off another > >large > > > > sheet of internal skin vinyl. Why? Why take it off other than the > >strips > > > > needed for deburring/dimpling? If I am not going to prime the > inside > >of the > > > > sheeting then what is the harm other than weight? Won't it continue > >to > > > > provide corrosion protection? > > > > > > > > Will the stuff degrade and flake off over time? It's plastic and > >never sees > > > > direct UV rays. Seems unlikely to me. > > > > > > I guess it's heavier than paint. How good is the glue that holds the > > > plastic to the aluminium? Will it let go in a few hundred hours? If it > > > lets go, what will the sheet of plastic do? Wrap round/jam up any > > > controls? > > > > > > Frank. > > > > > > > > > Get your FREE download of MSN Explorer at http://explorer.msn.com > > > > > ________________________________________________________________________________
Date: Dec 20, 2000
-----Original Message----- From: HCRV6(at)AOL.COM <HCRV6(at)AOL.COM> Date: Wednesday, December 20, 2000 11:37 AM Subject: Re: RV-List: 6-A Battery Box > >In a message dated 12/19/00 5:58:55 PM Pacific Standard Time, >rmickey(at)ix.netcom.com writes: > ><< Why is the 7" x 15/16" 6104 piece used and why is only one bolt going >through the battery box bottom and the other is just bolted to the floor >stiffener. >> > >Ross: If you are asking about the 7" long F-6120E piece, I asked Van's the >same question awhile back and the answer was to more evenly distribute the >weight of the battery over a greater length of the floor longerons. > >Harry Crosby >Pleasanton, California >RV-6, working on canopy installation > Let me get this straight: One lister reports Van's says it is a carryover from the floor-mounted pedals and another lister says Van's says it is a required part. Who do you believe -- Van's or Vans'? Dennis Persyk 6A N600DP 265 hours battery box per plans Hampshire, IL ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Date: Dec 20, 2000
I'm still building my RV-4 and I'd like a copy of your RV-4 hand book too! -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: RVPilot4(at)webtv.net [mailto:RVPilot4(at)webtv.net] Sent: Wednesday, December 20, 2000 8:00 AM To: rv-list(at)matronics.com Subject: Re: RV-List: Pilots Operating Handbook I would like to get as copy of a RV pilots operating handbook even though I have put over 400 hours on my RV4 (282EM) in the last 5 years.I am 69 and those have been the best years of my life flying this incredible airplane.Keep pounding those rivets!!!! ________________________________________________________________________________
Subject: Re: First anniversary
Date: Dec 20, 2000
>December 19, 2000 was the first anniversary of the maiden flight of my >RV-6A, N198JS. It's been a wonderful year for us. Absolutely! Same here. I'm now doing the annual condition inspection on my -8. I still can't believe it's been a full year since that most exciting day. I put 160 hours on her this year. What will next year bring? We're planning a lot of long distance traveling next summer during my work sabbatical. Probably up to Van's for a visit, then maybe down to Florida to meet up Jeff Ludwig, Rusty Duffy, Bob Hargrave, and probably lots of other great RV folks along the way. After a year of flying, only two dings so far...a two inch crack in one wheel pant from smacking a chunk of ice during a recent landing, and a leaky crankshaft oil seal. The crack is fixed, the new seal goes in this weekend. Just love this airplane. It's the most fun you can possibly have with your pants still on! Brian Denk RV8 N94BD Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Subject: RV-8 Ldg Gear, Was Vans Use of Torque Tables / Torqu
e Values
Date: Dec 20, 2000
Brian - Thanks for the thoughts. I actually forgot all about the inspection recommendation of 50-hr bolt tightness check. I think this is exactly what happened... the bolts were loose (from general movement and settling of the components) and the gear leg began moving at it's harmonic frequency (chattering) when the tire began slipping and grabbing on the grass. This led to the bolts becoming more loose and probably stretched somewhat. Fortunately, the gear attach box (rivets, screws, etc) look to be in good shape. Someone mentioned that the bolts should give-way before the plane or gear leg... this sounds good to me. Actually it makes the idea of a rough, off-airport landing a little easier to stomach. I'd rather shear off the gear than rip out the gear box. Another question, if you don't mind... how many G's have you seen in your plane? I can't believe what 6 g's must be like. I've been up to about 3.5 g's alone at about 1/2 tanks, and this was pretty extreme. Thanks Bryan Jones -----Original Message----- From: Brian Denk [mailto:akroguy(at)hotmail.com] Sent: Tuesday, December 19, 2000 9:47 AM Subject: Re: RV-List: RV-8 Ldg Gear, Was Vans Use of Torque Tables / Torque Values > ><bryan.jones@lyondell-citgo.com> > >Regarding the landing gear and associated bolting on the -8, I have >recently >had a problem that others might want to be aware of. I fly my plane from a >grass strip. A week or so ago, I was landing and experienced a strange >problem. Just after touching down, I began applying braking pressure >(maybe >a little heavier than normal since it was nearly dark). At that time I >experienced what I'd call a fairly extreme chatter (a lot like a nose wheel >shimmy, but higher frequency). I let up on the brakes and the chatter >stopped. What I believe happened was the wheel was lightly loaded (the >plane was still just below stall speed) and it began a slip/skid type >situation. The grass strip is in fair condition, but has sections which >are >moderately rough. > >When I got back into the hanger, I noticed that I had some fiberglass >damage >and the left gear was loose. It had about 1/4" play fore and aft. When I >pulled the gear attachment cover off to inspect the gear attachment, I >found >three loose bolts. I have to assume that the chatter caused the loose >bolts. Specifically, the chatter action stretched the bolts. > >I haven't taken the bolts out yet. When I do, I'll know for sure if the >bolts stretched or just what the deal is. I've bought new bolts and a new >outboard gear leg steel attachment component. I'll probably replace them >all, depending on the results of the inspection. > >Has anyone else experienced this problem? If not, be aware of heavy >braking >on anything other than very smooth surfaces. I called Van's and the person >I discussed the problem with had not heard of this occurring. > >Bryan Jones -8 765BJ ~58-hrs >Pearland, Texas Bryan, I followed Van's specs for torqueing the bolts and to leave a slight gap between the U blocks and the wear plates. This led to some loose bolts! I never had the vibration issue, but it took several turns on the nuts to tighten up the gear....and man what a pain that was. Getting a socket on those nuts inside the gear boxes has got to be the worst part to access in the entire airplane. I noticed this looseness at about 50 hours...right when the manual says to retorque them. So, I personally would just tighten the bolts SNUGLY at initial installation and ignore the gap. Crank 'em down and move on. I still have a slight squeeking noise coming from the left gear box area when the plane is rocked laterally. I cannot for the life of me figure out where this is coming from. It did not improve after tightening the nuts. I just replaced the tires and brake pads last month. While the plane was jacked up on stands, I checked the gear legs. Really yanked on them fore and aft. They are rock solid. So far, so good. Best of luck to ya. Brian Denk Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 20, 2000
Right on ED! Couldn't have said it better. This guy shouldn't to be building an airplane. I sure wouldn't fly in it. Laird BTW, I've decided to drop the tip up kit for my panel. It could still be done, but there are too many things that need to be modified and/or closely watched when doing the layout for the individuals panel for the average guy to do. I couldn't plan for all the different posibilities, and don't want to put out a 1/2 assed kit that might not work for someone. From: rv-list(at)matronics.com on Wed, Dec 20, 2000 10:55 AM Subject: RE: RV-List: fly with the vinyl on? Here's my $.02 If you don't have time to pull the vinyl off, what else will you have no time for??? Do the job right ! My old Drill Instructor once said " If a guy doesn't shine the back of his shoes.. he probably doesn't wipe his ass either !" End of $.02 Ed Cole RV6A > -----Original Message----- > From: pcondon(at)csc.com [SMTP:pcondon(at)csc.com] > Sent: Wednesday, December 20, 2000 8:40 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: fly with the vinyl on? > > > Bake a test piece, with the blue wrap on , in the oven at 200 / 225 > degrees and see what happens. Temps get pretty close to that in the > sun...imagine yourself at a flyin for 8 hours in the blistering > sun......the skin gets pretty hot. > > > > > "lucky macy" > > To: > rv-list(at)matronics.com > Sent by: cc: > > owner-rv-list-server@mat Subject: Re: > RV-List: fly with the vinyl on? > ronics.com > > > > > > 12/20/2000 10:20 AM > > Please respond to > > rv-list > > > > > > > > > if it's Alclad then whether it's covered with vinyl or not, gets moisture > trapped in between or not, it shouldn't oxidize, right? minus a scratch > here or there? remember, this is the inside of the skins. > > > >From: Dave Bristol <bj034(at)lafn.org> > >Reply-To: rv-list(at)matronics.com > >To: rv-list(at)matronics.com > >Subject: Re: RV-List: fly with the vinyl on? > >Date: Wed, 20 Dec 2000 07:10:35 -0800 > > > > > >I'd be concerned about moisture getting under the edges of the plastic > and > >causing > >corrosion later on. Besides, you're putting a lot of time and money into > >this > >airplane so why try to skimp on a little labor and maybe some *rimer? > > > >Dave N87DL 43hrs So.CA > > > >Frank and Dorothy wrote: > > > > > > > > > lucky macy wrote: > > > > Just wondering out loud here as I contemplate ripping off another > >large > > > > sheet of internal skin vinyl. Why? Why take it off other than the > >strips > > > > needed for deburring/dimpling? If I am not going to prime the > inside > >of the > > > > sheeting then what is the harm other than weight? Won't it continue > >to > > > > provide corrosion protection? > > > > > > > > Will the stuff degrade and flake off over time? It's plastic and > >never sees > > > > direct UV rays. Seems unlikely to me. > > > > > > I guess it's heavier than paint. How good is the glue that holds the > > > plastic to the aluminium? Will it let go in a few hundred hours? If it > > > lets go, what will the sheet of plastic do? Wrap round/jam up any > > > controls? > > > > > > Frank. > > > > > > > > > Get your FREE download of MSN Explorer at http://explorer.msn.com > > > > > ________________________________________________________________________________
Date: Dec 20, 2000
My apolgies to Lucky and the List. I meant to reply directly to Ed and forgot to change the address. My Bad. Sorry, Laird (with foot still in mouth) ________________________________________________________________________________
Date: Dec 20, 2000
12/20/2000 14:41:01 I posted my Word.doc format POH at one of VANS "WING" internet sites. Check at VANS website for a link to a "WING" site(s), URL-over to the site and browse for flight checklists, POH's and lots of goodies like that......can't recall which "WING" site it is, but I know more than one has online, free downloadable stuff like this.....good luck "Van Artsdalen, Scott" To: rv-list(at)matronics.com Sent by: cc: owner-rv-list-server@mat Subject: RE: RV-List: Pilots Operating Handbook ronics.com 12/20/2000 01:33 PM Please respond to rv-list I'm still building my RV-4 and I'd like a copy of your RV-4 hand book too! -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: RVPilot4(at)webtv.net [mailto:RVPilot4(at)webtv.net] Sent: Wednesday, December 20, 2000 8:00 AM To: rv-list(at)matronics.com Subject: Re: RV-List: Pilots Operating Handbook I would like to get as copy of a RV pilots operating handbook even though I have put over 400 hours on my RV4 (282EM) in the last 5 years.I am 69 and those have been the best years of my life flying this incredible airplane.Keep pounding those rivets!!!! ________________________________________________________________________________
Date: Dec 20, 2000
12/20/2000 14:49:31 Wheel pants ??? "Brian Denk" To: rv-list(at)matronics.com Sent by: cc: owner-rv-list-server@mat Subject: Re: RV-List: First anniversary ronics.com 12/20/2000 01:57 PM Please respond to rv-list >December 19, 2000 was the first anniversary of the maiden flight of my >RV-6A, N198JS. It's been a wonderful year for us. Absolutely! Same here. I'm now doing the annual condition inspection on my -8. I still can't believe it's been a full year since that most exciting day. I put 160 hours on her this year. What will next year bring? We're planning a lot of long distance traveling next summer during my work sabbatical. Probably up to Van's for a visit, then maybe down to Florida to meet up Jeff Ludwig, Rusty Duffy, Bob Hargrave, and probably lots of other great RV folks along the way. After a year of flying, only two dings so far...a two inch crack in one wheel pant from smacking a chunk of ice during a recent landing, and a leaky crankshaft oil seal. The crack is fixed, the new seal goes in this weekend. Just love this airplane. It's the most fun you can possibly have with your pants still on! Brian Denk RV8 N94BD Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 20, 2000
According to Cee Bailey's, maker of acrylic bubbles and windows for airplanes, vinyl reacts with acrylic and can cause cracking and crazing in less than a year. The hotter, the quicker. hal ________________________________________________________________________________
Date: Dec 20, 2000
I didn't expect much support on my comment, but Ol' Lucky Macy might run out of luck here. It was a little harsh, but I hope I made a point. That panel will indeed be tricky. Do you want me to ship your blank back to you ? How's that "bird" of yours going back together? Hope your back in the air soon. Good Luck. Ed Cole Maxim Integrated Products Bldg. 120 Ext. 6605 > -----Original Message----- > From: Owens, Laird [SMTP:Owens(at)aerovironment.com] > Sent: Wednesday, December 20, 2000 11:29 AM > To: rv-list(at)matronics.com > Subject: RE: RV-List: fly with the vinyl on? > > > Right on ED! Couldn't have said it better. > > This guy shouldn't to be building an airplane. I sure wouldn't fly in it. > > Laird > > BTW, I've decided to drop the tip up kit for my panel. It could still be > done, but there are too many things that need to be modified and/or > closely watched when doing the layout for the individuals panel for the > average guy to do. I couldn't plan for all the different posibilities, > and don't want to put out a 1/2 assed kit that might not work for someone. > From: rv-list(at)matronics.com on Wed, Dec 20, 2000 10:55 AM > Subject: RE: RV-List: fly with the vinyl on? > To: 'rv-list(at)matronics.com' > > > Here's my $.02 > > If you don't have time to pull the vinyl off, what else will you have no > time for??? > Do the job right ! > > My old Drill Instructor once said " If a guy doesn't shine the back of his > shoes.. > he probably doesn't wipe his ass either !" > > End of $.02 > > Ed Cole > RV6A > > > -----Original Message----- > > From: pcondon(at)csc.com [SMTP:pcondon(at)csc.com] > > Sent: Wednesday, December 20, 2000 8:40 AM > > To: rv-list(at)matronics.com > > Subject: Re: RV-List: fly with the vinyl on? > > > > > > Bake a test piece, with the blue wrap on , in the oven at 200 / 225 > > degrees and see what happens. Temps get pretty close to that in the > > sun...imagine yourself at a flyin for 8 hours in the blistering > > sun......the skin gets pretty hot. > > > > > > > > > > "lucky macy" > > > > To: > > rv-list(at)matronics.com > > Sent by: cc: > > > > owner-rv-list-server@mat Subject: Re: > > RV-List: fly with the vinyl on? > > ronics.com > > > > > > > > > > > > 12/20/2000 10:20 AM > > > > Please respond to > > > > rv-list > > > > > > > > > > > > > > > > > > if it's Alclad then whether it's covered with vinyl or not, gets > moisture > > trapped in between or not, it shouldn't oxidize, right? minus a scratch > > here or there? remember, this is the inside of the skins. > > > > > > >From: Dave Bristol <bj034(at)lafn.org> > > >Reply-To: rv-list(at)matronics.com > > >To: rv-list(at)matronics.com > > >Subject: Re: RV-List: fly with the vinyl on? > > >Date: Wed, 20 Dec 2000 07:10:35 -0800 > > > > > > > > >I'd be concerned about moisture getting under the edges of the plastic > > and > > >causing > > >corrosion later on. Besides, you're putting a lot of time and money > into > > >this > > >airplane so why try to skimp on a little labor and maybe some *rimer? > > > > > >Dave N87DL 43hrs So.CA > > > > > >Frank and Dorothy wrote: > > > > > > > > > > > > > lucky macy wrote: > > > > > Just wondering out loud here as I contemplate ripping off another > > >large > > > > > sheet of internal skin vinyl. Why? Why take it off other than > the > > >strips > > > > > needed for deburring/dimpling? If I am not going to prime the > > inside > > >of the > > > > > sheeting then what is the harm other than weight? Won't it > continue > > >to > > > > > provide corrosion protection? > > > > > > > > > > Will the stuff degrade and flake off over time? It's plastic and > > >never sees > > > > > direct UV rays. Seems unlikely to me. > > > > > > > > I guess it's heavier than paint. How good is the glue that holds the > > > > plastic to the aluminium? Will it let go in a few hundred hours? If > it > > > > lets go, what will the sheet of plastic do? Wrap round/jam up any > > > > controls? > > > > > > > > Frank. > > > > > > > > > > > > > > Get your FREE download of MSN Explorer at http://explorer.msn.com > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: RV-8 Ldg Gear, Was Vans Use of Torque Tables / Torqu e Values
Date: Dec 20, 2000
12/20/2000 15:25:24 I recall a picture of a ground looped RV and the landing gear legs (rods) were rolled up like a clock main spring...implying in this case the bolts held and the rods bent. Likewise my hangermates front whitmann rod (RV-6A) bent (sprattled) back 3/4 of the way and came to rest bent that way after a VERY hard landing. No bolt(s) failed or welds ripped or rivets sprung........ "Jones, Bryan D." tgo.com> cc: Sent by: Subject: RE: RV-List: RV-8 Ldg Gear, Was Vans Use of owner-rv-list-server@mat Torque Tables / Torqu e Values ronics.com 12/20/2000 02:18 PM Please respond to rv-list <bryan.jones@lyondell-citgo.com> Brian - Thanks for the thoughts. I actually forgot all about the inspection recommendation of 50-hr bolt tightness check. I think this is exactly what happened... the bolts were loose (from general movement and settling of the components) and the gear leg began moving at it's harmonic frequency (chattering) when the tire began slipping and grabbing on the grass. This led to the bolts becoming more loose and probably stretched somewhat. Fortunately, the gear attach box (rivets, screws, etc) look to be in good shape. Someone mentioned that the bolts should give-way before the plane or gear leg... this sounds good to me. Actually it makes the idea of a rough, off-airport landing a little easier to stomach. I'd rather shear off the gear than rip out the gear box. Another question, if you don't mind... how many G's have you seen in your plane? I can't believe what 6 g's must be like. I've been up to about 3.5 g's alone at about 1/2 tanks, and this was pretty extreme. Thanks Bryan Jones -----Original Message----- From: Brian Denk [mailto:akroguy(at)hotmail.com] Sent: Tuesday, December 19, 2000 9:47 AM Subject: Re: RV-List: RV-8 Ldg Gear, Was Vans Use of Torque Tables / Torque Values > ><bryan.jones@lyondell-citgo.com> > >Regarding the landing gear and associated bolting on the -8, I have >recently >had a problem that others might want to be aware of. I fly my plane from a >grass strip. A week or so ago, I was landing and experienced a strange >problem. Just after touching down, I began applying braking pressure >(maybe >a little heavier than normal since it was nearly dark). At that time I >experienced what I'd call a fairly extreme chatter (a lot like a nose wheel >shimmy, but higher frequency). I let up on the brakes and the chatter >stopped. What I believe happened was the wheel was lightly loaded (the >plane was still just below stall speed) and it began a slip/skid type >situation. The grass strip is in fair condition, but has sections which >are >moderately rough. > >When I got back into the hanger, I noticed that I had some fiberglass >damage >and the left gear was loose. It had about 1/4" play fore and aft. When I >pulled the gear attachment cover off to inspect the gear attachment, I >found >three loose bolts. I have to assume that the chatter caused the loose >bolts. Specifically, the chatter action stretched the bolts. > >I haven't taken the bolts out yet. When I do, I'll know for sure if the >bolts stretched or just what the deal is. I've bought new bolts and a new >outboard gear leg steel attachment component. I'll probably replace them >all, depending on the results of the inspection. > >Has anyone else experienced this problem? If not, be aware of heavy >braking >on anything other than very smooth surfaces. I called Van's and the person >I discussed the problem with had not heard of this occurring. > >Bryan Jones -8 765BJ ~58-hrs >Pearland, Texas Bryan, I followed Van's specs for torqueing the bolts and to leave a slight gap between the U blocks and the wear plates. This led to some loose bolts! I never had the vibration issue, but it took several turns on the nuts to tighten up the gear....and man what a pain that was. Getting a socket on those nuts inside the gear boxes has got to be the worst part to access in the entire airplane. I noticed this looseness at about 50 hours...right when the manual says to retorque them. So, I personally would just tighten the bolts SNUGLY at initial installation and ignore the gap. Crank 'em down and move on. I still have a slight squeeking noise coming from the left gear box area when the plane is rocked laterally. I cannot for the life of me figure out where this is coming from. It did not improve after tightening the nuts. I just replaced the tires and brake pads last month. While the plane was jacked up on stands, I checked the gear legs. Really yanked on them fore and aft. They are rock solid. So far, so good. Best of luck to ya. Brian Denk Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 20, 2000
Subject: Emp & Wing fixture question
I just bought the material for my fixture (laminated or "engineered" lumber) and I was wondering if I could get by just using two of these relatively expensive pieces of wood. They are 9 1/2" wide, so a guy could rip three 3" wide pieces out of each 10' length and have enough pieces after making so much sawdust to make both uprights and the cross piece. My question is this. Is there any reason why a person needs the dimensions to be 3 1/2" wide, or could I go with the 3" I mentioned earlier? Thanks. Bob Moser East Bethel, MN RV-8 tail and tool kit ordered ________________________________________________________________________________
Subject: Re: Emp & Wing fixture question
Date: Dec 20, 2000
If it is the kind of stress rated lumber or glue lam I think it is I would happily trade you some standard and better (#2) for it. What you have is much stronger and stiffer than common lumberyard stuff. hal ----- Original Message ----- From: <FK27Bob(at)AOL.COM> Sent: Wednesday, December 20, 2000 12:48 PM Subject: RV-List: Emp & Wing fixture question > > I just bought the material for my fixture (laminated or "engineered" lumber) > and I was wondering if I could get by just using two of these relatively > expensive pieces of wood. They are 9 1/2" wide, so a guy could rip three 3" > wide pieces out of each 10' length and have enough pieces after making so > much sawdust to make both uprights and the cross piece. > > My question is this. Is there any reason why a person needs the dimensions to > be 3 1/2" wide, or could I go with the 3" I mentioned earlier? > > Thanks. > > Bob Moser > East Bethel, MN > RV-8 tail and tool kit ordered > > ________________________________________________________________________________
Subject: Vinyl on the canopy
Date: Dec 20, 2000
I read that Vinyl will crack and craze acrylics. My canopy came covered with vinyl. I left most of it on so that it didn't get scratched while I did a thousand other things after fitting the canopy. Should I peel that vinyl off? Steve Soule Huntington, VT RV-6A finishing details ________________________________________________________________________________
Date: Dec 20, 2000
Subject: Just wanna touch one....
Hello All, Just received my -8 Empennage Kit and have begun reconfiguring my Model A/C shop to build the ultimate model A/C (1:1 scale :) ). I live in Mobile, Alabama and would love to Fly/drive somewhere close by and have a look at a close to complete or complete -6 or -8 sometime during the holidays. Anyone close by? Bill Culberson -8 empennage (countin' rivets) ________________________________________________________________________________
Date: Dec 20, 2000
I can't see any reason the 3" dimension shouldn't work for you. You might need some extra material in a couple of locations when you mount the crosspieces that support the wing spars, but I think you're fine. Jim Bower St. Louis, MO RV-6A Wings >From: FK27Bob(at)AOL.COM >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Emp & Wing fixture question >Date: Wed, 20 Dec 2000 15:48:25 EST > > >I just bought the material for my fixture (laminated or "engineered" >lumber) >and I was wondering if I could get by just using two of these relatively >expensive pieces of wood. They are 9 1/2" wide, so a guy could rip three 3" >wide pieces out of each 10' length and have enough pieces after making so >much sawdust to make both uprights and the cross piece. > >My question is this. Is there any reason why a person needs the dimensions >to >be 3 1/2" wide, or could I go with the 3" I mentioned earlier? > >Thanks. > >Bob Moser >East Bethel, MN >RV-8 tail and tool kit ordered > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 20, 2000
Bob, I can't recall any reason why any part of either the empenage or wing jig needs to be 3-1/2" wide. It's probably only because that happens to be the depth of a 2x4. Engineered lumber, especially if it is the laminated veneer kind, is probably excellent because it is relatively stable with moisture changes, but remember that you are going to be working to a string line and not the edge of the lumberYou can use your own ideas to make it rigid. I think I remember making a T shaped section out of 2x4's as the horizontal part. . I recall buying some stuff called "prime trim", which was a pre-painted exterior trim material for houses. I used it as a surface on the empenage jig and snapped and drew my straight lines on that. When you get to the wing jig, you are really just building a frame to support the main spar of the wing by each end and to lock the rear spar in place. I don't think it makes any difference how you get there and with what material, as long as it is solid and doesn't move. When you get to the fuselage jig, you are building a flat, rigid framework to support and lock in place the longerons and bulkheads, but again, you will be working to a string line for straightness, but it must be level. Terry RV-8A #80729 fuselage Seattle > > I just bought the material for my fixture (laminated or "engineered" lumber) > and I was wondering if I could get by just using two of these relatively > expensive pieces of wood. They are 9 1/2" wide, so a guy could rip three 3" > wide pieces out of each 10' length and have enough pieces after making so > much sawdust to make both uprights and the cross piece. > > My question is this. Is there any reason why a person needs the dimensions to > be 3 1/2" wide, or could I go with the 3" I mentioned earlier? > > Thanks. > > Bob Moser > East Bethel, MN > RV-8 tail and tool kit ordered > ________________________________________________________________________________
Date: Dec 20, 2000
2.0.15) with ESMTP id for" ;, Mon(at)webtv.net, 18(at)webtv.net, Dec(at)webtv.net, 2000(at)webtv.net, 14:16:07.-0500(at)matronics.com's message of Mon, 18 Dec 2000 When I read reports on this list of how hard it must be on the landing gear to land at 10 mph slower speed it is no wonder that RV people I know roll their eyes when someone mentions the RV list.The idea is to survive an off airport landing.You have a 75%better chance to survive at 50mph compared to 70 mph. This was told to me by Van himself. ________________________________________________________________________________
Date: Dec 20, 2000
Carey, I made up one for my RV-8A with an IO-360-A1A and C/S prop. It is located on Kevin Horton's website. I'm sorry I don't have his website adddress handy as I am on the road and using another computer from my own. But I know you can find him on the Van's Air Force website. Mike Robertson RV-8A N809RS 12.9 hours >From: Rvmils(at)AOL.COM >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Pilots Operating Handbook >Date: Tue, 19 Dec 2000 20:12:55 EST > > >I'm in the process of flying off my 40hrs and trying to put together a POH. >Does anyone know where I can find one on the web to copy for a guide? >Thanks, >Carey Mills >RV4, 24hrs > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 21, 2000
kempthornes wrote: > > > According to Cee Bailey's, maker of acrylic bubbles and windows for > airplanes, vinyl reacts with acrylic and can cause cracking and crazing in > less than a year. The hotter, the quicker. Yikes! And Vans ships their bubbles with vinyl attached! Frank. ________________________________________________________________________________
Subject: reaming spar joint attach holes
Date: Dec 20, 2000
finishing up the fuselage attach bulkhead and thought I would put the spars in it and bolt everything up for a fit check and a picture, I know the close tolerance bolts won't go through because of primer and slight misalignments, do you'all think it is permissible to hand ream using a .374 as long as I clamp the laminations on either side of the hole I'm reaming? same with the .249 and 3/16 holes? ________________________________________________________________________________
Subject: Re: reaming spar joint attach holes
Date: Dec 20, 2000
> > finishing up the fuselage attach bulkhead and thought I would put the spars > in it and bolt everything up for a fit check and a picture, I know the > close tolerance bolts won't go through because of primer and slight > misalignments, do you'all think it is permissible to hand ream using a .374 > as long as I clamp the laminations on either side of the hole I'm reaming? > same with the .249 and 3/16 holes? > > Scott, I found that if I used the rivet gun on a low psi setting to push the bolts through the holes it worked well. At least in my case, the rapid but gentle rapping on the head would push the bolts through when a heavy hammer would not. You might give it a try before reaming the holes, you can always ream. Ed Anderson ________________________________________________________________________________
Date: Dec 20, 2000
Subject: Re: RV6-List: radios
elizabeth lincoln wrote: > --> RV6-List message posted by: "elizabeth lincoln" > > Does anyone have any experience with the ICS Plus combination > comm/vor/glidscope/intercom all in one?sure would save space and would > be simple. Only costs $1360. > > Andy > CONTACT HANK HUDDLESTON(at)BAHAHUD@AOL.COM HE HAS USED AN ICS RADIO IN HIS > LAST TWO PLANES, ONE AN RV-4 IRWIN ABRAMS @ ABAVAC(at)PACBELL.NET ________________________________________________________________________________
Subject: Re: Vinyl on the canopy
Date: Dec 21, 2000
I left the vinyl on until the last minute. That way i didn't have as much area to mask when I was slobbering epoxy all over the canopy. No ill effects after 1 yr. of flying. Rick Caldwell -6 170 hrs & hoping AlliedSignal honors my warranty after 11 mos. use. Melbourne, FL >From: "Stephen J. Soule" <SSoule(at)pfclaw.com> >Reply-To: rv-list(at)matronics.com >To: "Rv-List (E-mail)" >Subject: RV-List: Vinyl on the canopy >Date: Wed, 20 Dec 2000 16:37:45 -0500 > > >I read that Vinyl will crack and craze acrylics. My canopy came covered >with vinyl. I left most of it on so that it didn't get scratched while I >did a thousand other things after fitting the canopy. > >Should I peel that vinyl off? > >Steve Soule >Huntington, VT >RV-6A finishing details > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 20, 2000
Subject: Poor Man's Encoder
Date: Dec 20, 2000
In a message dated 12/20/00 10:29:46 AM Pacific Standard Time, dpersyk(at)worldnet.att.net writes: << Who do you believe -- Van's or Vans'? >> At the risk of taking another hit from the list--- have you asked Van's yet? Harry Crosby Pleasanton, California RV-6, working on canopy installation ________________________________________________________________________________
From: "Reeves, Doug" <Douglas.Reeves(at)archongroup.com>
Subject: New features on the VAF-World Wide Wing web site (www.vansaircraf
t.net)
Date: Dec 20, 2000
Hi listers, I'd like to make you aware of a new feature of the VAF-World Wide Wing web site (www.vansaircraft.net <http://www.vansaircraft.net>) - the ability to 'Ask A Company Tech Rep'. Several of the advertisers on the site (listed below) have a link under their respective ads pointing to a unique discussion board pertaining to their particular product(s). A representative from each of the companies with a link has agreed to check that board and address any questions posted. The benefits of doing this include the fact that the answers come 'straight from the horse's mouth' and also since everyone can see the answers we all benefit from the knowledge. Think of it as a virtual vendor booth at a virtual fly-in. No waiting. Several of the company reps answering these boards do so on their own time or often times while on the road, so please make a point to thank them on occasion. Two of the boards getting a lot of exercise these days are Sensenich and Whelen (strobes). You might want to start with these. I didn't have any questions, but by looking through the answers posted I learned a few things. - Aerox Oxygen Systems - Axis Products (HVLP painting) - Control Vision (Color Moving Maps) - Lightspeed Aviation (ANR Headsets) - RMI (microENCODER and microMONITOR) - Sensenich Props - Sentry A/C Cylinders - Technology Kitchen (Engine Power Monitor) - Unison (Lasar Electronic Engine Controls) - Vortex Generators (Larry Vetterman) - Whelen Strobe Systems Again, the link to each respective board is under that company's advertisement and will be called 'Ask a Tech Rep', or something like that. Lastly, there are several new additions in the 'Articles' section, the 'Classified' section seems to change hourly, and the RV White Pages now lists over 730 builders/flyers in 17 countries. I hope you find something here helpful. Happy holidays and best regards, Doug Reeves Van's Air Force - World Wide Wing www.vansaircraft.net <http://www.vansaircraft.net> www.vansairforce.net <http://www.vansairforce.net> ________________________________________________________________________________
Subject: Re: Vans Part #LN HS-30-1 Strobe Installation Package
Date: Dec 20, 2000
> How many Molex connectors come with this kit? > > I want to do both wingtips and the tail in a RV6A. > > Thank-you, Norman, Whelen uses AMP Mate-N-Lok connectors which are incompatible with Molex. Sorry, can't tell you how many they provide. Randy Lervold www.rv-8.com ________________________________________________________________________________
Date: Dec 21, 2000
Subject: Re:RV 3 Crash
Hi All, check this out, particuly the last sentence!!! Bruce Stewart http://www.basi.gov.au/occurs/ob200000885.htm ________________________________________________________________________________
Date: Dec 20, 2000
Subject: Re: Whelen Strobe Retrofit
In a message dated 12/20/00 5:31:56 PM Pacific Standard Time, nhunger(at)sprint.ca writes: << I am again a little disappointed that all this very expensive stuff came with no paper work of any kind. I am a first time builder so I would prefer every new electrical item to have a schematic. There was way too many hits in the archives. >> Call them and tell them you want the installation manual. I can make a copy of mine and send it to you if you like. -GV (RV-6A N1GV) vanremog(at)aol.com ________________________________________________________________________________
Date: Dec 20, 2000
> I read that Vinyl will crack and craze acrylics. My canopy came covered > with vinyl I kept mine covered for two years - indoors away from sun and heat. hal ________________________________________________________________________________
Subject: skyforce IIIC GPS
Date: Dec 20, 2000
Has anyone tried Matt's SkyComm software with the Skyforce IIIC GPS? Sounds like a easy way to add check lists and reference data for crosss country flights to the Skyforce IIIC. It's available on Matronic's site and was just wondering how well the modification works. Jerry Calvert Edmond Ok -6 fuselage ________________________________________________________________________________
Subject: Re: Pants or fairings first
Date: Dec 20, 2000
> Vans list the fairings first . I would think I need to do the pants first > , so I will have something to fit the fairings to. > > Don Jordan RV6A Arlington, Tx I don't think it matters if the gear leg fairing or wheel pants go on first with Vans design. After these two are installed, then you fabricate the gear leg intersection fairings between the gear leg fairing and the wheel pants and fuselage. If you are using the Team Rocket ones it is a different story. In that case, the wheel pants go on first. Ross ________________________________________________________________________________
Subject: Re: 6-A Battery Box
Date: Dec 20, 2000
> Let me get this straight: One lister reports Van's says it is a carryover > from the floor-mounted pedals and another lister says Van's says it is a > required part. Who do you believe -- Van's or Vans'? I asked Andy Hannah about this a while back (he designed the new box) and he hemmed and hawed and allowed as to how it was kind of a carryover from the floor mounted rudder pedals. Now this is just my impression but I think that he was a relatively new engineer at the time and might not have been anxious to make things TOO much different from the original, so he left them in there but just made them lower. That being said, I left mine in -- they're part of the required kit and unless and until Vans officially says otherwise I wouldn't want to change it. I mean, they really don't hurt anything anyway, just a little extra complexity in the build phase. Randall Henderson, RV-6 N6R (~175 hrs) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
From: "John Donohue Global" <John_Donohue(at)worldnet.att.net>
Date: Dec 21, 2000
Hello: I don't remember who was asking about the POH and Flight test cards but here is where I found some, http://www.vansairforce.org/flight_test/ http://www.aftershock.org/rv_builders_resources.htm ----- Original Message ----- From: <pcondon(at)csc.com> Sent: Wednesday, December 20, 2000 2:46 PM Subject: RE: RV-List: Pilots Operating Handbook > > I posted my Word.doc format POH at one of VANS "WING" internet sites. > Check at VANS website for a link to a "WING" site(s), URL-over to the site > and browse for flight checklists, POH's and lots of goodies like > that......can't recall which "WING" site it is, but I know more than one > has online, free downloadable stuff like this.....good luck > > > "Van Artsdalen, Scott" > To: rv-list(at)matronics.com > Sent by: cc: > owner-rv-list-server@mat Subject: RE: RV-List: Pilots Operating Handbook > ronics.com > > > 12/20/2000 01:33 PM > Please respond to > rv-list > > > > > I'm still building my RV-4 and I'd like a copy of your RV-4 hand book too! > > -- > Scott VanArtsdalen, MCSE, CCNA > Network Administrator > Union Safe Deposit Bank > 209-946-5116 > > > -----Original Message----- > From: RVPilot4(at)webtv.net [mailto:RVPilot4(at)webtv.net] > Sent: Wednesday, December 20, 2000 8:00 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Pilots Operating Handbook > > > I would like to get as copy of a RV pilots operating > handbook even > though I have put over 400 hours on my RV4 (282EM) in the > last 5 years.I > am 69 and those have been the best years of my life flying > this > incredible airplane.Keep pounding those rivets!!!! > > ________________________________________________________________________________
Date: Dec 21, 2000
Subject: Shipped with vinyl??
Are we sure that the canopy ships with vinyl and not some other plastic? The plastic film protecting my canopy feels more like a polyethylene type film than a polyvinyl. -Glenn Gordon ________________________________________________________________________________
Subject: VM1000 fuel probe inst.
Date: Dec 21, 2000
Have competed the fuel probe installation on the 6A. I was able to get fittings machined that rivet into the bottom rear inboard corner of the tanks that include a threaded bushing set at the correct angle. The installation requires approx 2.5 hours per tank, this includes the time to cut the holes in the tank ribs. This was done prior to pro-sealing and riveting. Have saved the computerized program for the milling of these fittings so could make them available to anyone interested. Contact me of the list. Eustace Bowhay Blind Bay B.C. ________________________________________________________________________________
Date: Dec 21, 2000
Subject: Re: skyforce IIIC GPS
--- Jerry Calvert wrote: > > Has anyone tried Matt's SkyComm software with the Skyforce IIIC GPS? > Sounds > like a easy way to add check lists and reference data for crosss > country > flights to the Skyforce IIIC. It's available on Matronic's site and > was > just wondering how well the modification works. > > Jerry Calvert Ummm.... considering the cost of the unit and Matt's warning that he's not responsible if the program frys the Skyforce software..... _You_ go first and let us know! :) ;) :) I find a plastic covered paper checklist works great! Mike Thompson Austin, TX -6 N140RV (Reserved) Canopy ________________________________________________________________________________
Subject: Gascolator - Fuel Pump Installation
Date: Dec 21, 2000
Have been thinking of installing Van's gascolator and the Air Flow Performance pump both in the wing root space on the 6A. Did the first layout of it yesterday and it looks like it is quite possible with some minor changes to the plumbing. Will do a trial run on this over the holidays using a template of of .032 and see what happens. Eustace Bowhay Blind Bay, B.C. ________________________________________________________________________________
Date: Dec 21, 2000
Thread-Topic: RV-List: reaming spar joint attach holes Thread-Index: AcBq7xZPT/Gjlo+dSOSFRvP8/Igi5gAa4HOg
I wouldn't ream the holes. When I called Vans about reaming the holes, I think Tom wanted to ream me. Apparently they think reaming the holes is a no-no. I used a 2x rivet gun to drive in the bolts and they went in like they were going through butter. Like Ed says, the hammer didn't work where the rivet gun made it easy. Bob Japundza RV-6 N244BJ O-360C/S flying 64 hours > I found that if I used the rivet gun on a low psi setting > to push the > bolts through the holes it worked well. At least in my case, > the rapid but > gentle rapping on the head would push the bolts through when > a heavy hammer > would not. You might give it a try before reaming the holes, > you can always > ream. > > Ed Anderson > > > > > > > ________________________________________________________________________________
Subject: Scrap bin search
Date: Dec 21, 2000
Fellow RVers... Does anyone out there have a piece of .063 x 2" x 2" in their scrap bins? I'm making a bellcrank spacer with a bulge in the side to accomodate my S-Tec roll servo pushrod connection. It would normally be placed right on the edge of the normal spacer. Ralph Capen RV6AQB N822AR Richardson, TX ________________________________________________________________________________
Subject: Re: Gascolator - Fuel Pump Installation
Date: Dec 21, 2000
After this install - will it require wing removal for pump/gascolator servicing? That sounds like a potential disadvantage. I've seen another installation similar to this one - keeps the fuel pump out of the foot area. I think it's a great idea - I'm following this one! Ralph Capen RV6AQB N822AR ________________________________________________________________________________
From: "Schilling David A" <davideng@columbia-center.org>
Subject: fly with the vinyl on?
Date: Dec 21, 2000
Lucky, I was always under the impression the vinyl was put on the skins to help prevent scratches in handling the material. As we are aware, a scratch in the Alcad surface can allow corrosion. May guess is that the Alcad surface would do a fine job protecting your skins without the vinyl as long as you don't scratch them. You might consider priming in the cabin areas. Anyway, I do not think the manufacturer ever intended the covering to be left on, but thats my opinion. You could try calling. I primered the inside of my skins where ever they came into contact with another component such as a bulkhead, but areas left open are only coated with overspray from primer going on the intended areas. I thought it would minimize the weight, yet provide some additional protection. I really hope this helps. Have a Merry Christmas, David Schilling RV-6A ---------- From: lucky macy[SMTP:luckymacy(at)hotmail.com] Sent: Tuesday, December 19, 2000 7:43 PM Subject: RV-List: fly with the vinyl on? Listers, Just wondering out loud here as I contemplate ripping off another large sheet of internal skin vinyl. Why? Why take it off other than the strips needed for deburring/dimpling? If I am not going to prime the inside of the sheeting then what is the harm other than weight? Won't it continue to provide corrosion protection? Will the stuff degrade and flake off over time? It's plastic and never sees direct UV rays. Seems unlikely to me. Get your FREE download of MSN Explorer at http://explorer.msn.com eJ8+IhsPAQaQCAAEAAAAAAABAAEAAQeQBgAIAAAA5AQAAAAAAADoAAEIgAcAGAAAAElQTS5NaWNy b3NvZnQgTWFpbC5Ob3RlADEIAQ2ABAACAAAAAgACAAEEkAYAJAEAAAEAAAAMAAAAAwAAMAIAAAAL AA8OAAAAAAIB/w8BAAAASQAAAAAAAACBKx+kvqMQGZ1uAN0BD1QCAAAAAHJ2LWxpc3RAbWF0cm9u aWNzLmNvbQBTTVRQAHJ2LWxpc3RAbWF0cm9uaWNzLmNvbQAAAAAeAAIwAQAAAAUAAABTTVRQAAAA AB4AAzABAAAAFgAAAHJ2LWxpc3RAbWF0cm9uaWNzLmNvbQAAAAMAFQwBAAAAAwD+DwYAAAAeAAEw AQAAABgAAAAncnYtbGlzdEBtYXRyb25pY3MuY29tJwACAQswAQAAABsAAABTTVRQOlJWLUxJU1RA TUFUUk9OSUNTLkNPTQAAAwAAOQAAAAALAEA6AQAAAAIB9g8BAAAABAAAAAAAAAIyNwEEgAEAJAAA AFJFOiBSVi1MaXN0OiBmbHkgd2l0aCB0aGUgdmlueWwgb24/ANILAQWAAwAOAAAA0AcMABUABwAH AAgABAASAQEggAMADgAAANAHDAAVAAYAMwAoAAQAXQEBCYABACEAAAA0MjNFNEJDQjA1RDdENDEx OTZFRTAwNjA5N0NBNTFFNwAoBwEDkAYAuAgAABQAAAALACMAAAAAAAMAJgAAAAAACwApAAAAAAAD AC4AAAAAAAMANgAAAAAAQAA5AMCkP7Bfa8ABHgBwAAEAAAAkAAAAUkU6IFJWLUxpc3Q6IGZseSB3 aXRoIHRoZSB2aW55bCBvbj8AAgFxAAEAAAAWAAAAAcBrX7A/y0s+Q9cFEdSW7gBgl8pR5wAAHgAe DAEAAAAFAAAAU01UUAAAAAAeAB8MAQAAAB0AAABkYXZpZGVuZ0Bjb2x1bWJpYS1jZW50ZXIub3Jn AAAAAAMABhAVHCjOAwAHECoIAAAeAAgQAQAAAGUAAABMVUNLWSxJV0FTQUxXQVlTVU5ERVJUSEVJ TVBSRVNTSU9OVEhFVklOWUxXQVNQVVRPTlRIRVNLSU5TVE9IRUxQUFJFVkVOVFNDUkFUQ0hFU0lO SEFORExJTkdUSEVNQVRFUklBAAAAAAIBCRABAAAAGAcAABQHAACTDwAATFpGde7f6OD/AAoBDwIV AqQD5AXrAoMAUBMDVAIAY2gKwHNldO4yBgAGwwKDMgPGBxMCg7ozEw19CoAIzwnZOxX/eDI1NQKA CoENsQtgbvBnMTAzFCALChLyDAECYwBAIEx1Y2t5DiwKhQqFHBFJIHdhlwQgB0AccHkEIHVuBIGg IHRoZSAHcHAWAK0EEGkCIB1zdguAeQMgmRxycHUFQB5Fc2sLgJEEIHRvIB2QbHAfQJ0WAHYJ8AVA BPFhdBGwTweRC4AggABwZGwLgGdbHXMAwHQGcQdALhwQQX0EIHcdoArAI/EccBYALA8coCFWIfId gkFsY2H2ZB/wCHBmANAdoCXwA6B/B0AVkAfgBaEDYB4iI4FN+RzgIGcKUAQRBAAdcSGQqyWPHaB3 CGBsJhBkIHCNJMBmC4AdoGpvYiDR0m8jIGN0IoJ5CGEf9f8D8B2ACGApFB60HIEVkCKRZxyBLEEq oW4nIUcdcm2FI4BZLtFtaWdoBUD/BaAAgR1CHeAHcCKCJWUl8P5iIgEkERyAI4Ie0BzRJKC7HFAq sW4rsB1xC4BrIrX0bnUmYXQIcB1RIQEFwN8LgCMgHTEmEDIjbzXRIoN1IHBiHaBsDiEfgSSgYpct QyGQBCBtKDBvcAuAzye0MEIFoCpydHIoMCXw+ycAIoEuG08cQTFyBJA2dfcgITEhH4BmOPIslR2Q JCH/NcMdgTqSB4A2AiBwMOEBkP8r4CzjHKA0ET6BJ0Ed0AIgnyEjGvBAwRyROFFsax2Q7yYAOEQy wzfFcAnwJAMCIHpsOpFvIxEmEECTNvJz3x3gKCEDUjxlKEBvIoIeRf82FzLGHFAtEjCiLQAqRTGh fTGReh2gHYIj4DCSJKB5bxIAK4IesD2BcwNwI/Fk/mQtAB4xB0ArhyfBOz8cQf8y0ScAKDAtIERA NEIEICCSZzMATgwKhUhhIRAksU2TBJA6gUNoBRBzdADA+nMbPURSEDEgBgARsAMQgyJyCoVSVi02 QU4MIwr0InAxODAC0WkteDE0NA3wDNBX4wtZMeY2CqArpCAtWgcKh1i76wwwWYZGA2E6Ww5ZhgyC By4wGvIi8WN5W1NN2FRQOl7DXyJALSBTIfUDEC5BYV1ar1u9BmACMKtc7137VChhZDOCRAWQ5zAA N6AFwDE5JKAB0FeAACA3OjQzIFBNM2EvW71Ub2NvXftyduY4InBTEEBlCcAIYFCB9UFhO2tRLWuT IwEDYAMAjmNsQ2dvYj51Ymor0fdpj137VbFMUwFwcBjQKDA3QJMeeAIgP1YPVxMzNu9YhxQiDAFZ iD5yRiLwHgE8YWcdoEGQUxA2cWJ5xXBwIl7IIiA8X89g0p4+TgxygkXxGzZKdXfR3ypQHTJHUx9h FZB1JhA+g/8cgRxQQBIwAAtRIyBPMAUg3zlBR3EN0EDXC2ByeFEKhf5zHZBLoT2xNhIEoE0hIALD HqQjgVdoeT+EAx1w/GFrHaGCcj3AQQQo4R+l/zpwBSAEIAqFKyAJgDZxAhDfBcANsDhgJ3AigS9M wH+x+yKBhFFJPcAcUD+ANANHNP8gYTxzPP0dgoHKIoUDoD5w/ykBKLMdoBHBRqCFiUsUhFL/LxNJ sUASC4AKUCBSCoVL1vcnV01JdD1XVOGGJTUgPcD/DbAJwCYAI/EdMHLRhNKFQ+c+4wdxiSJ0Jx8x C2BTEP9tkJWTKyA10hHwB5EKhUzA8xYAQGFVVk8wHOEjgQZg/zAAHQIicITgROEgYQeATfaGR0uh LENGUkVFKqE+d0TQRSAmED2xBeBOIPxFeAtQBbAdUSkBdd0aoX8MYBXgK5VXMDSAfqECQHDQOi8v ZZ41LpqwJ9AfQWF131mkUL8Ksl8tPf+lb6Z/p4+oFqTYZTAdkXeG/yixRhAw8Z5heNIoAW1VlZP/ HYBsATCgqSkdgnhQKyBsAf8EIAhQAjAFEDhhHjEEID2x/3e1ZhJQl6VPsb+yz6h/qYPtd7NSIKBF M1eIEAYALQD/B5CpKauIcHAcEp7vn/+hBu53uvCiAG1KL6KPo5u3E/V3s1NEQGMGkG2QcHi43/u5 77r/L2y1vB+9L2/yBPT/HjG38b8/wE/BX7uHJjDFs783oMNvxH8GUQrAJTFFGQD/KxG/H8d/yI/J ms0Tyt/L7/9UQJ01t/TN787/0A+7eM0i+mkhEHPSH9MvrlzN39YvP9c/u2lAEq6m2X/ajyBP/0ET coK349yf3a/ev7uHMAD/YKFrktlv4h/qn+uv7L+0H3upsAZgYzVx4zCa8SshT8sLIDcUTichQXZg oQGg1zfQnqKrlyG2qlALYCaB/yxDBbAdQkTBKxKVongwUiH8NSVZ8Laq9d3kP+VP5l//u4fzk+if 6a/9D/4f/y/t7L8AvwHPdR8aCKN9GHEABiADABAQAAAAAAMAERAAAAAAQAAHMGBmE4dda8ABQAAI MGBmE4dda8ABHgA9AAEAAAAFAAAAUkU6IAAAAAADAA00/TcAAFH0 ________________________________________________________________________________
Date: Dec 21, 2000
Amazing, I can't believe the owner would take off with the boost pump turned off. I wonder if the aircraft was fitted with a fuel pressure gauge? I also wonder if the owner had made any comments about the boost pump to the person who piloted the aircraft during the crash? Wonder how good the nomenclature was on the panel? Did the pilot even know there was a boost pump? I've seen some panels that were signed off that had pretty poor markings. Greg ----- Original Message ----- From: Bruce Stewart <bruces(at)shoalhaven.net.au> Sent: Wednesday, December 20, 2000 10:21 PM Subject: RV-List: Re:RV 3 Crash > > Hi All, > > check this out, particuly the last sentence!!! > > Bruce Stewart > > > http://www.basi.gov.au/occurs/ob200000885.htm > > ________________________________________________________________________________
Date: Dec 21, 2000
Subject: seat belt cost
Listers what are the associated costs for a five point harness in an rv-8 8A? Are there any vendors other than vans with the FAA/TSO markings on the belts? Looking for a good price prefferebly with push button operation. Any of you guys know anyone in the business? Thanks Glenn Williams ==== Glenn Williams 8A A&P N81GW ________________________________________________________________________________
Date: Dec 21, 2000
Is it vinyl? It feels like heavy Saran Wrap to me. Or that plastic they wrap around the boxes on shipping palettes. I don't know what that stuff is made out of. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: kempthornes [mailto:kempthornes(at)home.com] Sent: Wednesday, December 20, 2000 8:41 PM To: rv-list(at)matronics.com Subject: Re: RV-List: Vinyl on the canopy > I read that Vinyl will crack and craze acrylics. My canopy came covered > with vinyl I kept mine covered for two years - indoors away from sun and heat. hal ________________________________________________________________________________
From: "Gerard Pearson" <wildgoose(at)outerbounds.net>
Subject: Re: RV6-List Digest: 2 Msgs - 12/19/00
Date: Dec 21, 2000
----- Original Message ----- From: RV6-List Digest Server <rv6-list-digest(at)matronics.com> Sent: Wednesday, December 20, 2000 12:54 AM Subject: RV6-List Digest: 2 Msgs - 12/19/00 > * > > ____ > From: "Douglas E. Bostard" <dougacft(at)jps.net> > Subject: RV6-List: Re: RV6-List Digest: 3 Msgs - 12/17/00 > > --> RV6-List message posted by: "Douglas E. Bostard" > > CHECKLIST: I have 2 separate checklists I developed which are > comprehensive for my 6A. One for prestart, other side for preflight, > then one for prelanding. They are laminated and computer generated with > some notations in red. Also made up a cheatsheet for the VM 1000 which > is somewhat complicated in various modes. It helps a little. I could > email you what I have and you could modify/regenerate to suit, then > print, then lamiunate. Mine are about 3.5" X 5.0" Doug B. > > > Doug: Could you E mail me a copy of your checklists for the RV-6/A, and for the VM-1000 as well. Wasn't there someone or someplace that had developed an "aircraft-pilot operation handbook" for the RV-4 and/or RV-6. It seems to me I either read something via E-mail or otherwise regarding the POH. Any hints of that in your travels? Thanks Gerard Pearson > > > > > > > > > ________________________________________________________________________________
Date: Dec 21, 2000
Eustace, I saw your -6 installation of the gascolator in the wing root in the RVator years ago. I did something similar. You can see my installation in the left root at: http://members3.clubphoto.com/socal230330/RV-6_Builders_album/ I tried to get the boost pump in there as well, but it was a little too crowded with the flop tube routing. (I wouldn't do that mod again). I also thought that maintance would be a pain. Good luck getting the gascolator AND the HP pump. I look forward to seeing your solution. Laird Owens RV-6, N515L, 150 hrs O-360, Sensenich (83) Simi Valley, SoCal From: rv-list(at)matronics.com on Thu, Dec 21, 2000 7:19 AM Subject: RV-List: Gascolator - Fuel Pump Installation Have been thinking of installing Van's gascolator and the Air Flow Performance pump both in the wing root space on the 6A. Did the first layout of it yesterday and it looks like it is quite possible with some minor changes to the plumbing. Will do a trial run on this over the holidays using a template of of .032 and see what happens. Eustace Bowhay Blind Bay, B.C. ________________________________________________________________________________
Date: Dec 21, 2000
The installation is planned to be fully serviceable with only the removal of the fairing. Eustace -----Original Message----- From: Ralph E. Capen <recapen(at)earthlink.net> Date: Thursday, December 21, 2000 7:40 AM Subject: Re: RV-List: Gascolator - Fuel Pump Installation > >After this install - will it require wing removal for pump/gascolator >servicing? That sounds like a potential disadvantage. I've seen another >installation similar to this one - keeps the fuel pump out of the foot area. >I think it's a great idea - I'm following this one! > >Ralph Capen >RV6AQB N822AR > > ________________________________________________________________________________
Date: Dec 21, 2000
> > >Brian - > >Thanks for the thoughts. I actually forgot all about the inspection >recommendation of 50-hr bolt tightness check. I think this is exactly what >happened... the bolts were loose (from general movement and settling of >the >components) and the gear leg began moving at it's harmonic frequency >(chattering) when the tire began slipping and grabbing on the grass. This >led to the bolts becoming more loose and probably stretched somewhat. >Fortunately, the gear attach box (rivets, screws, etc) look to be in good >shape. Someone mentioned that the bolts should give-way before the plane >or >gear leg... this sounds good to me. Actually it makes the idea of a >rough, >off-airport landing a little easier to stomach. I'd rather shear off the >gear than rip out the gear box. > >Another question, if you don't mind... how many G's have you seen in your >plane? I can't believe what 6 g's must be like. I've been up to about 3.5 >g's alone at about 1/2 tanks, and this was pretty extreme. > >Thanks > >Bryan Jones Bryan, Yeah, I think the 50 hour torque inspection should be HIGHLY emphasized in the manual. There are so many layers of stuff in the gear boxes and they are bound to settle and compress, thus making for some pretty loose bolts. All it takes are a few metal chips sandwiched between the wear plates, belly skin, weldment, longeron, etc etc, and once those buggers get squished or forced out, it's wobbly gear leg time. As for G loads, I've seen about +4.5 and -2 with full tanks. It takes a helluva pull to put more than that on it while solo. I use between 3 and 4 G on a loop pullup. Any less, and you run out of speed over the top..at least at this altitude. Any more, and you're just punishing the airframe and pilot needlessly. Besides, my seat cushion squishes down so much after a mild acro session, that I can hardly see over the glareshield during taxi back to the hangar! There MUST be a better way to design the front seat. I've thought of trashing the whole setup and installing a fiberglass racing bucket seat. Yet more stuff to ponder. Brian Denk Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
From: "Dennis Persyk" <dpersyk(at)worldnet.att.net>
Subject: Re: seat belt cost
Date: Dec 21, 2000
I recommend Hooker Harness. I have them in my 6A and after 25 hours of flying I can say that they are much more comfortable to wear than Van's harness. I find I can tighten the seat belt very firmly across my hips and the wider padding of the Hooker's does not feel uncomfortable which I did experience in the half-dozen or so RV's I've flown in with Van's belts. Hooker seems to be the gold standard for acro people and are OEMs for Extra and many other acro planes. Dennis Persyk 6A N600DP O360A1A/Hartzell 25 hours and snowed in Hampshire, IL C38 -----Original Message----- From: glenn williams <willig10(at)yahoo.com> Date: Thursday, December 21, 2000 10:03 AM Subject: RV-List: seat belt cost > >Listers what are the associated costs for a five point >harness in an rv-8 8A? Are there any vendors other >than vans with the FAA/TSO markings on the belts? >Looking for a good price prefferebly with push button >operation. Any of you guys know anyone in the >business? Thanks > Glenn Williams > >==== >Glenn Williams >8A >A&P >N81GW > > ________________________________________________________________________________
Date: Dec 21, 2000
> Have been thinking of installing Van's gascolator and the Air Flow > Performance pump both in the wing root space on the 6A. Did the first layout > of it yesterday and it looks like it is quite possible with some minor > changes to the plumbing. Will do a trial run on this over the holidays using > a template of of .032 and see what happens. > > Eustace Bowhay Blind Bay, B.C. Good luck to you. I REALLY tried to get this to work but couldn't find the fittings to do it. I wanted to keep the suggested 45 degree angle on the fuel pump. I got real close. The run from the fuel pump into the cabin stuck up above the wing by about 1/4 to 3/8 inch. I think it would work if you could fabricate a short connection between the gasolator and fuel pump with a slightly shallower angle or allow the gasolator to run into the wind more than I wanted to. I am using the Andair gasolator which might make a difference. Ross ________________________________________________________________________________
Date: Dec 21, 2000
Subject: Re: Pilots Operating Handbook
Sorry for my slow response. I have the POH that was submitted to the Western Canada Wing web site, but I haven't posted it to the site yet. Sorry! I'll post it as soon as I can, and send a message to the list when it's ready. Thanks, Tedd McHenry Van's Air Force Western Canada Wing tedd(at)vansairforce.org http://www.vansairforce.org ________________________________________________________________________________
Date: Dec 21, 2000
Without disagreeing, if you want the finest harness ever made, at least from what I've seen/read . . . and are prepared to step up to the plate regarding $$, check out the Schroth systems at www.icdc.com/~morristec/ Apparently he makes these configured for each of the Van's series of aircraft. Rick Jory ----- Original Message ----- From: Dennis Persyk <dpersyk(at)worldnet.att.net> Sent: Thursday, December 21, 2000 10:30 AM Subject: Re: RV-List: seat belt cost > > I recommend Hooker Harness. I have them in my 6A and after 25 hours of > flying I can say that they are much more comfortable to wear than Van's > harness. I find I can tighten the seat belt very firmly across my hips and > the wider padding of the Hooker's does not feel uncomfortable which I did > experience in the half-dozen or so RV's I've flown in with Van's belts. > Hooker seems to be the gold standard for acro people and are OEMs for Extra > and many other acro planes. > > Dennis Persyk 6A N600DP O360A1A/Hartzell 25 hours and snowed in > Hampshire, IL C38 > > -----Original Message----- > From: glenn williams <willig10(at)yahoo.com> > To: rv-list(at)matronics.com > Date: Thursday, December 21, 2000 10:03 AM > Subject: RV-List: seat belt cost > > > > > >Listers what are the associated costs for a five point > >harness in an rv-8 8A? Are there any vendors other > >than vans with the FAA/TSO markings on the belts? > >Looking for a good price prefferebly with push button > >operation. Any of you guys know anyone in the > >business? Thanks > > Glenn Williams > > > >==== > >Glenn Williams > >8A > >A&P > >N81GW > > > > > > ________________________________________________________________________________
Date: Dec 21, 2000
Okay, I have the POH on our web site in MS Word format. I'll have PDF and HTML formats eventually, but only the Word format is ready. http://www.vansairforce.org/POH/ Tedd McHenry Van's Air Force Western Canada Wing tedd(at)vansairforce.org http://www.vansairforce.org ________________________________________________________________________________
Date: Dec 21, 2000
You might want to check the bolts with a micrometer. When checking mine, I found that the area next to the thread on some of the bolts where poorly machined. The holes are machined in line, but the bolts that are supplied are off the shelf. They should be aircraft quality, but a quick check with a micrometer will tell you alot. You will find that the difference between a slip fit and a no-go is about .0003. Richard Luster RV9A, fuselage Marysville, Wash ----- Original Message ----- From: Bob Japundza <Bob.Japundza(at)realmed.com> Sent: Thursday, December 21, 2000 6:35 AM Subject: RE: RV-List: reaming spar joint attach holes > > I wouldn't ream the holes. When I called Vans about reaming the holes, > I think Tom wanted to ream me. Apparently they think reaming the holes > is a no-no. > > I used a 2x rivet gun to drive in the bolts and they went in like they > were going through butter. Like Ed says, the hammer didn't work where > the rivet gun made it easy. > > Bob Japundza > RV-6 N244BJ O-360C/S flying 64 hours > > > > I found that if I used the rivet gun on a low psi setting > > to push the > > bolts through the holes it worked well. At least in my case, > > the rapid but > > gentle rapping on the head would push the bolts through when > > a heavy hammer > > would not. You might give it a try before reaming the holes, > > you can always > > ream. > > > > Ed Anderson ________________________________________________________________________________
Subject: Control Cable - Parking Brake
Date: Dec 21, 2000
Norman, Any solid wire cable with a lock or ratchet should work fine. You'll need to cut it to length and you need a positive means of securing it in the OFF position for landing. Your panel aestetics will dictate the style you pick. I used a cable with a chrome T-handle that locks with a quarter turn (from ACS). On the valve end I used a wire grip and clevis (from Van's), but a B-nut should work just as well. Regards, Greg Young (Houston - DWH) RV-6 N6GY systems & wiring I'm trying to select a cable to operate my parking brake valve. I am looking at Aircraft Spruce pages 148-149. Once again I find there are too many choices and I need some guidance from The List. For starters, there appears to be two types of ends. Threaded ends and solid wire ends. Am I correct to assume that the pivoting we need at the valve end would require a solid wire end? I am leaning towards A-700 with a red knob in the six foot length. It says it may be shortened as required. (05-13272) Does any one have any thoughts that might help? ________________________________________________________________________________
Date: Dec 21, 2000
Hooker Harness is good. ----- Original Message ----- From: glenn williams <willig10(at)yahoo.com> Sent: Thursday, December 21, 2000 9:36 AM Subject: RV-List: seat belt cost > > Listers what are the associated costs for a five point > harness in an rv-8 8A? Are there any vendors other > than vans with the FAA/TSO markings on the belts? > Looking for a good price prefferebly with push button > operation. Any of you guys know anyone in the > business? Thanks > Glenn Williams > > ==== > Glenn Williams > 8A > A&P > N81GW > > > > > ________________________________________________________________________________
Date: Dec 21, 2000
Subject: Freight
When using freight Companies it is best to list your shipment as used parts as this will give you the best rate. Large companies shipping such as Van's and others that ship large amounts daily get good rates. ABF freight for example will charge almost double for a non account holder for an identical package to the same destination. So it behooves the shipper to shop and get the best rates. ________________________________________________________________________________
Date: Dec 21, 2000
Ross-- The AirFlow Performance pump mounts horizontally as opposed to the Facet. You can see a picture of Eustace's first mount of this type (gascolator) in "18 Years of The RV-Ator". Boyd N600SS/IO-540 240 hrs. > > > > Have been thinking of installing Van's gascolator and the Air Flow > > Performance pump both in the wing root space on the 6A. Did the first > layout > > of it yesterday and it looks like it is quite possible with some minor > > changes to the plumbing. Will do a trial run on this over the holidays > using > > a template of of .032 and see what happens. > > > > Eustace Bowhay Blind Bay, B.C. > > Good luck to you. I REALLY tried to get this to work but couldn't find the > fittings to do it. I wanted to keep the suggested 45 degree angle on the > fuel pump. I got real close. The run from the fuel pump into the cabin > stuck up above the wing by about 1/4 to 3/8 inch. I think it would work if > you could fabricate a short connection between the gasolator and fuel pump > with a slightly shallower angle or allow the gasolator to run into the wind > more than I wanted to. I am using the Andair gasolator which might make a > difference. > > Ross > > ________________________________________________________________________________
Date: Dec 22, 2000
glenn williams wrote: > Listers what are the associated costs for a five point > harness in an rv-8 8A? Are there any vendors other > than vans with the FAA/TSO markings on the belts? > Looking for a good price prefferebly with push button > operation. Any of you guys know anyone in the > business? Thanks Have you checked the Yeller Pages? Pacific Aero Harness is who I'm intending to buy my harnesses from. Frank. ________________________________________________________________________________
Date: Dec 21, 2000
Subject: Re: Christen seperator
Scott-- The air/oil separator contains a sliding weight and the ball (valve), however, the parts catalogue does not mention or list these parts. Maybe a call to Aviat? Boyd > > > I have a chance to buy the air/oil seperator for a Christen inverted oil > system at a good price, but the ball for the check valve is badly corroded > and pitted. Does anyone know if it can be removed/repaired at a > reasonable cost, or is the seperator a disposable item (at $300)? > > Scott Fink > ________________________________________________________________________________
Date: Dec 21, 2000
Subject: Re: Allignment of wings
By definition, wing incidence is the angle where the chord centerline of the wing intersects the longitudinal axis of the fuselage. Anything outboard of that is wing twist. Van's description of the wing (airfoil 23013.5) for the RV-6(A)(?-4) calls for NO twist. So there should be +1 degree incidence at the wing root and +1 degree incidence at the wing tip. Boyd > > > I've seen two posts suggesting setting the 1 degree incidence at the tip. Note > that this may not be optimum for stall characteristics, unless you add stall > strips inboard (depending on which way the wings twist). > > Finn > > Request a CDROM 1-800-333-3633 > ________________________________________________________________________________
Date: Dec 21, 2000
Cy Galley wrote: > > > Hooker Harness is good. DOES SOME ONE HAVE THE WEBSITE OR EMAIL OR ADDRESS FOR THESE PEOPLE? bARRY rV9A WINGS ________________________________________________________________________________
Date: Dec 21, 2000
Hi Glen, Check out for an affordable alternative. Robert Huntsinger is the proprietor of Pacific Aero Harness his website,< http://home.att.net/~robh/ >. His belt system is not shown to be a push button type but is of the quick release military variety. He might do a custom push button type ?? It won't hurt to ask. Jim in kelowna-- NACA vents fitted - Aileron tube bellows seals installed. Inboard rudder trim thoughts over Christmas. Best of the Season to all ----- Original Message ----- From: glenn williams <willig10(at)yahoo.com> Sent: Thursday, December 21, 2000 7:36 AM Subject: RV-List: seat belt cost > > Listers what are the associated costs for a five point > harness in an rv-8 8A? Are there any vendors other > than vans with the FAA/TSO markings on the belts? > Looking for a good price prefferebly with push button > operation. Any of you guys know anyone in the > business? Thanks > Glenn Williams > > ==== > Glenn Williams > 8A > A&P > N81GW > > ________________________________________________________________________________
Date: Dec 21, 2000
How about some of the drag race belts I used in my dragster? They are all SFI certified and made to hold up at over 300 MPH impact. Several companies make them, Deist, RFI, etc. Greg Tanner RV-9A Empennage SER #90186 N80BR RESERVED -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of jim jewell Sent: Thursday, December 21, 2000 1:14 PM Subject: Re: RV-List: seat belt cost Hi Glen, Check out for an affordable alternative. Robert Huntsinger is the proprietor of Pacific Aero Harness his website,< http://home.att.net/~robh/ >. His belt system is not shown to be a push button type but is of the quick release military variety. He might do a custom push button type ?? It won't hurt to ask. Jim in kelowna-- NACA vents fitted - Aileron tube bellows seals installed. Inboard rudder trim thoughts over Christmas. Best of the Season to all ----- Original Message ----- From: glenn williams <willig10(at)yahoo.com> Sent: Thursday, December 21, 2000 7:36 AM Subject: RV-List: seat belt cost > > Listers what are the associated costs for a five point > harness in an rv-8 8A? Are there any vendors other > than vans with the FAA/TSO markings on the belts? > Looking for a good price prefferebly with push button > operation. Any of you guys know anyone in the > business? Thanks > Glenn Williams > > ==== > Glenn Williams > 8A > A&P > N81GW > > ________________________________________________________________________________
Subject: Re: Just wanna touch one....
Date: Dec 21, 2000
Try the World Wide Wing of Van's Air Force. They have a "white pages" of folks who are building/flying RVs. If somebody in your neck of the woods has listed themselves, you can hook up with them. Also, check for your local EAA chapter. http://www.metronet.com/~dreeves/rv_white_pages_dev.htm Jim Bower St. Louis, MO RV-6A Wings >From: "William B. Culberson" <billc(at)ceebic.org> >Reply-To: rv-list(at)matronics.com >To: RV List send out >Subject: RV-List: Just wanna touch one.... >Date: Wed, 20 Dec 2000 15:35:24 -0600 > > >Hello All, > >Just received my -8 Empennage Kit and have begun reconfiguring my Model >A/C shop to build the ultimate model A/C (1:1 scale :) ). I live in >Mobile, Alabama and would love to Fly/drive somewhere close by and have >a look at a close to complete or complete -6 or -8 sometime during the >holidays. Anyone close by? > >Bill Culberson >-8 empennage (countin' rivets) > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 21, 2000
True: However one can unintentionally put a negative twist in the left cordline there by negating the need to off set the vertical stabilser. --- bcbraem(at)home.com wrote: > > By definition, wing incidence is the angle where the > chord centerline of > the wing intersects the longitudinal axis of the > fuselage. Anything > outboard of that is wing twist. Van's description > of the wing (airfoil > 23013.5) for the RV-6(A)(?-4) calls for NO twist. > So there should be +1 > degree incidence at the wing root and +1 degree > incidence at the wing > tip. > > Boyd > > > > > > > I've seen two posts suggesting setting the 1 > degree incidence at the tip. Note > > that this may not be optimum for stall > characteristics, unless you add stall > > strips inboard (depending on which way the wings > twist). > > > > Finn > > > > Request a CDROM 1-800-333-3633 > > > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ________________________________________________________________________________
Date: Dec 22, 2000
Subject: Fwd: Venison
It is a little known fact that Santa has to keep his pilot's license current in order to make his deliveries every year, and so the old man wasn't too surprised when he got a letter from CASA informing him that an examiner would be appearing shortly to run him through the usual bi-annual flight review. A detail of elves was sent to wash and polish the sleigh, another group was assigned to inspect, service, and repair all the tack,and a third squad started curry-combing the reindeer. Santa himself got out his logbook and the rest of the paperwork and made sure it was all in order. On the appointed day the examiner arrived, and after the ritual cup of coffee, he went over Santa's log and the paperwork, then followed Santa outside. After a meticulous review of Santa's weight and balance calculations, the examiner watched Santa do the pre-flight, then followed behind him, looking closely at everything from the bells on the back of the sleigh to Rudolph's nose. When he finished, he turned to Santa and said: "It looks pretty good so far. Let me get one thing out of my bags and then we'll take her up". When the examiner returned, Santa was in the sleigh and ready to taxi. As the examiner climbed into the sleigh, Santa noticed that he was carrying a shotgun. "What's that for?" Santa asked. The examiner looked at him, winked and said: "I really shouldn't tell you this, but, you're going to lose an engine on takeoff ..." B ________________________________________________________________________________
Date: Dec 21, 2000
Subject: Van's 2001 Pricing
Hi Listers, For anyone who is interested, Van's have published their price schedule for 2001 on their website The text published was as follows: >>NEW KIT PRICES FOR 2001 For probably the first time ever, we are able to publish our prices for the upcoming year before that year is actually here. Our increased volume has improved our purchasing power and we have improved the efficiency of our operation. These advantages have been passed on to our customers. We are pleased that these prices average a very moderate increase. When you consider the improvements and increased accuracy and quality we have been able to achieve, we think you will agree that the value is better than it has ever been. Note that the RV-3 QB wing price is instead of the standard wing. In other words, a complete RV-3 kit including the QB wing would cost $13,051. No price is given for the RV-9A QuickBuild Kit because we dont have one to sell yet. A pair of RV-9A kits are in the QB pipeline, serving as prototypes. When we have the necessary data about labor times, FAA approval, etc., we will make the kit available. Right now, we estimate that the RV-9A QB kit will be on the market in June, but we are making no promises. We will make an announcement when we are ready to begin taking orders and deposits for RV-9A QuickBuild kits. Standard Kits that are paid in full by December 31, 2000 will ship at 2000 prices. QuickBuild Kits on order with a 25% deposit by December 31, 2000 will ship at 2000 prices.<< For more info, and all the prices, direct your web browsers at: http://www.vansaircraft.com/public/kitprices2001.htm You guys who haven't ordered yet, note that you can still get a kit at 2000 prices if you order and pay for one in full before the 31st Dec. A late Christmas present perhaps??!! Best wishes, Ed Hicks RV-6 QB G-BZRV (Fuselage stuff) Bristol, UK. ________________________________________________________________________________
Date: Dec 21, 2000
From: Dan & Patty Krueger <pndkrueg(at)gulfsurf.infi.net>
Subject: Re: Scrap bin search
> > Does anyone out there have a piece of .063 x 2" x 2" in their scrap bins? > Send me your address and I will cut a chunk out of the remainder of inst panel #1. Dan Krueger ________________________________________________________________________________
Date: Dec 21, 2000
Mike, Fried Skyforce.......well that's kinda why I would like some feedback on it. Yep, I've got the laminated checklists, but the idea of electronic checklists is appealing, but not at the expense of the Skyforce! Abilene is about a month sooner in 2001...we're gonna have to hurry!! Jerry Calvert Edmond Ok -6 fuselage ----- Original Message ----- From: Mike Thompson <grobdriver(at)yahoo.com> Sent: Thursday, December 21, 2000 8:21 AM Subject: Re: RV-List: skyforce IIIC GPS > > > --- Jerry Calvert wrote: > > > > Has anyone tried Matt's SkyComm software with the Skyforce IIIC GPS? > > Sounds > > like a easy way to add check lists and reference data for crosss > > country > > flights to the Skyforce IIIC. It's available on Matronic's site and > > was > > just wondering how well the modification works. > > > > Jerry Calvert > > > Ummm.... considering the cost of the unit and Matt's warning that he's > not responsible if the program frys the Skyforce software..... > _You_ go first and let us know! > > :) ;) :) > > I find a plastic covered paper checklist works great! > > Mike Thompson > Austin, TX > -6 N140RV (Reserved) > Canopy > > ________________________________________________________________________________
Date: Dec 21, 2000
----- Original Message ----- From: "Frank and Dorothy" <frankv(at)infogen.net.nz> Sent: Thursday, December 21, 2000 3:17 PM Subject: Re: RV-List: seat belt cost > Have you checked the Yeller Pages? Pacific Aero Harness is who I'm > intending to buy my harnesses from. > > Frank. > > I have Pacific Aero's in my RV6. I have Hookers in My Zlin50. The PA's use the same materials as hooker but do not come with any padding. This is not an issue unless you are flying real acro.I did fly Sportsman class for two years with them. The PA's are also alot cheaper. But if you want the best belts made, there are no substitutes.Hooker.Terry > > ________________________________________________________________________________
Date: Dec 21, 2000
In a message dated 12/21/2000 3:29:22 PM Central Standard Time, gtanner(at)bendcable.com writes: << How about some of the drag race belts I used in my dragster? They are all SFI certified and made to hold up at over 300 MPH impact. Several companies make them, Deist, RFI, etc. Greg Tanner RV-9A Empennage SER #90186 N80BR RESERVED >> there heavier then aircraft belts. ________________________________________________________________________________
Date: Dec 21, 2000
So what happens if you already reamed the holes?? Is my plane going to fall out of the sky because the bolts are no longer close tolerance and jammed in there with a hammer? Paul Besing RV-6A (197AB) Arizona http://www.lacodeworks.com/besing Finish Kit (Still) > > I wouldn't ream the holes. When I called Vans about reaming the holes, > I think Tom wanted to ream me. Apparently they think reaming the holes > is a no-no. ________________________________________________________________________________
From: "der_Jagdflieger" <der_Jagdflieger(at)prodigy.net>
Subject: NEW AIR FORCE ONE
Date: Dec 21, 2000
As builders and pilots we share a common enthusiasm for airplanes of all sizes, particularly RV's in Van's Air Force. Most of us saw the TV footage last week of the Secret Service delivering his new, armored, stretched black limousine to President-elect Bush in Austin. What few know is they the brass out at Andrews AFB are not to be outdone. If any listers would like to be sent a color photo of the new Air Force One, just email a request to der_Jagdgflieger(at)prodigy.net and I will send you one attached to an email. Although the .jpg file is not very large (93.2KB) it would not be appropriate to send it to the entire list. NOTE: Please do not just hit reply to this message! Send your request to der_Jagdgflieger(at)prodigy.net Howard Walrath RV-6A Flying 165 hours ________________________________________________________________________________
Date: Dec 21, 2000
Please remove the vinyl from your sheet metal before riveting the pieces together. This is definitely a poor alternative to the many corrosion prevention methods. This coating is put on the sheets to protect the material from shipping and handling damage. You can actually order the same material from the mill with no coating if you want -- it's even a little cheaper that way. The vinyl will give you almost no protection from corrosion, and I would wager that it will actually promote the collection of moisture in the long run. Don Winters Wings http://www.geocities.com/dtw_rv6 -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of lucky macy Sent: Wednesday, December 20, 2000 6:38 PM Subject: RE: RV-List: fly with the vinyl on? OK, I see a trend of a reading comprehension problem going on here. The question had nothing to do with a physical problem pulling the vinyl off, being lazy, etc. It's actually a technical question as to whether or not the vinyl would help prevent corrosion on the internal skins if left on when the builder would otherwise not resort to priming the inside of the skins. ________________________________________________________________________________
Subject: Reiff oil sump heater installation
Date: Dec 21, 2000
> For those of you who have oil sump heaters, did you strip the paint off > the sump where the heater bonds to? The directions say to do so, but a > local mechanic who's installed a few said if the sump is painted right > you don't need to strip it. I'm just wondering if I need to go through > the trouble. The mechanic is right - IF the paint is bonded well to the sump you can put the heater over the paint. The reason our instructions say to remove the paint is because we have had a few heaters returned over the years that failed because the paint came off the sump and, of course, the heater came with it. It's easy to tell because the paint will still be bonded to the adhesive on the back of the pad. Naturally the heater will overheat and fail if any part of it comes loose. Frankly, I've installed some over the paint and have never had a problem, including one on my wife's minivan which was put on 9 yrs ago and still going strong. If the paint looks cracked, peeling, etc, remove it. Removing the paint removes one variable in the quality of the bond. When I do remove the paint, here's how I do it. Trace the heater outline on the sump with a felt tip pen, take off the paint on and inside the line with a wire brush in a Dremel tool. Bob Reiff RV4 #2646 Reiff Preheat Systems www.execpc.com/reiff ________________________________________________________________________________
Date: Dec 21, 2000
Well, Boyd. That's the whole point: what to do when a wing does have a twist. Finn bcbraem(at)home.com wrote: > > By definition, wing incidence is the angle where the chord centerline of > the wing intersects the longitudinal axis of the fuselage. Anything > outboard of that is wing twist. Van's description of the wing (airfoil > 23013.5) for the RV-6(A)(?-4) calls for NO twist. So there should be +1 > degree incidence at the wing root and +1 degree incidence at the wing > tip. > > Boyd > > > > > > I've seen two posts suggesting setting the 1 degree incidence at the tip. Note > > that this may not be optimum for stall characteristics, unless you add stall > > strips inboard (depending on which way the wings twist). > > > > Finn > > > > Request a CDROM 1-800-333-3633 > > > Why pay for something you could get for free? ________________________________________________________________________________
Subject: Magneto Drive Gear
Date: Dec 21, 2000
I am looking for a magneto drive gear that would mate a Bendix S4LN20 (non-impulse) magneto to a Lycoming O-320 engine. Any pointers to where I could get one...preferably cheap? Thanks in advance. ________________________________________________________________________________
Subject: Preheater plugged in continuously
Date: Dec 21, 2000
Snipped >Johnny: thanks, old man. I'm not really sure where this is all headed. I'm at 155 hrs since the major, in which we returned the cam to service after magnaflux and dimensional inspection. The lifters were odd-lot units from the parts drawer at the overhauler's shop... perhaps a troubling sign in retrospect. Polishing and cleaning these lifters and assembling them into the bodies was one of the few parts of the o'haul I helped with myself. I have used break in oil, later Aero-shell 15w-50, and never gone long periods between flights (never idle more than 3 weeks, usually fly 1-2x/week) but I do have an oil sump Reiff heater which I often leave plugged in continuously in the hangar. Some say this invites condensation and rust in the upper reaches of the case. I may get to find out! My engine has really been making more or less the same amount of metal since the overhaul was completed... I don't recommend leaving an oil sump heater plugged in continuously unless the engine is being run every day. The web site FAQ has a discussion of this, and it's also in the instructions that come with the heater. The engine manufacturers also don't recommend it. Our oil heater used alone will raise your oil temp about 80-100 deg F over ambient, and the top end around 40. Since there is usually a lot of moisture inside your crankcase, I'm afraid the oil heater will fill the case with warm moist air and condense on the cooler top end parts. If you use the cylinder heaters or some other heater that heats the engine uniformly then I think continuous use is ok, and I do it myself. On the other hand, if the choice is continuous use of the oil heater, or not preheating and cold starting the engine, now you're trading a possible problem for a probable one. I've been trying to talk Teledyne-Mattituck into collecting some data on preheater use vs. corrosion they find inside the engines they see. So far no luck, even though I think it would be a useful contribution to general aviation to get some actual data to help answer this question, rather than relying on opinion as we do now. I'm going to talk to some other overhaulers and see if we can't get it done. Bob Reiff RV4 #2646 Reiff Preheat Systems www.execpc.com/reiff ________________________________________________________________________________
Date: Dec 21, 2000
"Re: RV-List: skyforce IIIC GPS" (Dec 21, 5:52pm)
Oh geeze, be a man! Its a great program; you'll love it! Fried Skyforce, I don't think so. Seriously, if you've got one of these and a computer you owe it to yourself to try it out. Having the online checklist is just too cool. It's also fun to download the screen shots. Don't be scared... It won't hurt - I promise! Matt >-------------- > >Mike, > >Fried Skyforce.......well that's kinda why I would like some feedback on it. >Yep, I've got the laminated checklists, but the idea of electronic >checklists is appealing, but not at the expense of the Skyforce! > >Abilene is about a month sooner in 2001...we're gonna have to hurry!! > >Jerry Calvert >Edmond Ok >-6 fuselage > > >----- Original Message ----- >From: Mike Thompson <grobdriver(at)yahoo.com> >To: >Sent: Thursday, December 21, 2000 8:21 AM >Subject: Re: RV-List: skyforce IIIC GPS > > >> >> >> --- Jerry Calvert wrote: >> > >> > Has anyone tried Matt's SkyComm software with the Skyforce IIIC GPS? >> > Sounds >> > like a easy way to add check lists and reference data for crosss >> > country >> > flights to the Skyforce IIIC. It's available on Matronic's site and >> > was >> > just wondering how well the modification works. >> > >> > Jerry Calvert >> >> >> Ummm.... considering the cost of the unit and Matt's warning that he's >> not responsible if the program frys the Skyforce software..... >> _You_ go first and let us know! >> >> :) ;) :) >> >> I find a plastic covered paper checklist works great! >> >> Mike Thompson >> Austin, TX >> -6 N140RV (Reserved) >> Canopy >> >> > > >-------------- -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft Great minds discuss ideas, Average minds discuss events, Small minds discuss people... ________________________________________________________________________________
Date: Dec 21, 2000
I second the Hooker Harness belts. I haven't flown with them yet, but the look wider than Van's. I also like that you can order your own base and trim colors. John Danielson ________________________________________________________________________________
Date: Dec 21, 2000
Subject: Wire labeling
I purchased a Brothers P-Z tape labeler last September to do miscellaneous labeling like my parts cabinets, etc. I've been meening to post this earlier but just keep forgetting. When I started wiring my panel and the other wiring in the plane, I thought I'd give the labeler a try to label the wires. This is the way to go. The labler is battery powered so it can go where you do. It works great. Just type out the label for the wire your on type, print and cut. I still place a piece of shrink tubing (clear) over the label but I have found that after putting the label in place go over it with a heat gun and it fuses the tape to itself. I've had a hard time removing a label after this process. John Danielson Engine installation and finishing kit ________________________________________________________________________________
Date: Dec 21, 2000
Subject: Re: Christmas Lights
This evening the winds were calm, the sky clear, the stars were bright and my wife and I enjoyed a flight around town looking down at the Christmas lights. Had such a GREAT time we decided to fly over two neighboring towns. Told approach control of our plans and were treated as royalty. The sights are just tremendous. I know how Santa must feel as he travels the world seeing all the decorated houses, streets and businesses in just a few short days. I've planned this evening for many years as I was building with my best friend, lover, and wife. We really enjoyed the evening. Just wanted to share the experience. Keep pounding the rivets. It's worth it. Terry E. Cole N468TC ________________________________________________________________________________
Date: Dec 21, 2000
Subject: Re: Wire labeling
Where do you buy this tape labeler? ________________________________________________________________________________
Date: Dec 22, 2000
Label makers such as the Brothers can be purchased at Office Max, Staples, etc. ________________________________________________________________________________
Date: Dec 21, 2000
> > Hooker Harness is good. > > > DOES SOME ONE HAVE THE WEBSITE OR EMAIL OR ADDRESS FOR THESE PEOPLE? > > bARRY rV9A WINGS Team Rocket sells these and has pictures. http://www.teamrocketaircraft.com/catalog.htm Ross ________________________________________________________________________________
Date: Dec 21, 2000
I cannot believe what I am reading.Save money on seat belts ? come on fellows,if you ever do have an off airport landing the seat belt may rhe last place you should be trying to save money, do your loved ones a favor--- buy HOOKER!! ________________________________________________________________________________
Date: Dec 22, 2000
Subject: First flight question
Hello Folks, I am almost reday to test fly my 6A. Does anyone know who the fellow is that assists you with this event? If so, what is his name and how do I get in touch with him? Bob Claypool, Fresno, CA ________________________________________________________________________________
Date: Dec 21, 2000
> > I cannot believe what I am reading.Save money on seat belts ? come on > fellows,if you ever do have an off airport landing the seat belt may rhe > last place you should be trying to save money, do your loved ones a > favor--- buy HOOKER!! > OK, now what part of your airplane does that NOT apply to? The paint, maybe. I'm happy for you that you can afford the best of everything. The rest of us have to use our judgement to put our money where WE think it is needed to make this very expensive project possible, and yes, safe too, relative as that is. Terry RV-8A fuselage Seattle ________________________________________________________________________________
Date: Dec 22, 2000
In a message dated 12/22/2000 12:57:42 AM Central Standard Time, tcwatson(at)seanet.com writes: << OK, now what part of your airplane does that NOT apply to? The paint, maybe. I'm happy for you that you can afford the best of everything. The rest of us have to use our judgement to put our money where WE think it is needed to make this very expensive project possible, and yes, safe too, relative as that is. Terry >> Well the hooker 5 point harness with military clasp is 299 for 2 of them though team rocket. Thats hardly alotof money when you consider your building an airplane. ________________________________________________________________________________
Date: Dec 22, 2000
The cost on my hooker harness with individual lap pads and the stainless steel ratchet (not needed but nice for acro) was $260. I also needed a slight mod on one of the belts....no charge...even shipped it back free. Not sure how this price compares to other custom belts. Chris ----- Original Message ----- From: "Terry Watson" <tcwatson(at)seanet.com> Sent: Thursday, December 21, 2000 10:48 PM Subject: Re: RV-List: seat belt cost > > > > > > I cannot believe what I am reading.Save money on seat belts ? come on > > fellows,if you ever do have an off airport landing the seat belt may rhe > > last place you should be trying to save money, do your loved ones a > > favor--- buy HOOKER!! > > > OK, now what part of your airplane does that NOT apply to? The paint, > maybe. I'm happy for you that you can afford the best of everything. The > rest of us have to use our judgement to put our money where WE think it is > needed to make this very expensive project possible, and yes, safe too, > relative as that is. > > Terry > RV-8A fuselage > Seattle > > ________________________________________________________________________________
Subject: fuse jig available
Date: Dec 22, 2000
Listers, I have just finished with my 6 fuselage jig. It is located in the philadelphia area and has built five fuselages. It is extremely accurate with planed cross beams. The only other person in this area that I know of who wants it won't need it for 1 1/2 years or so. If anyone is at that point in the building process and is intersted please email me off-list. I paid $220 for it and will release it for same. When you're done there will be another builder lined up who will take it off your hands. Essentially a free jig (minus interest costs) Doug M d.meloche(at)att.net ________________________________________________________________________________
(Content Technologies SMTPRS 2.0.15) with ESMTP id for" ; Fri, 22 Dec 2000 08:31:16.-0500(at)matronics.com
Subject: Panel Fitting
Date: Dec 22, 2000
12/22/2000 08:27:07 AM For the Archive: I came up with a good way to fit your panel last night. I can only speak for a -6 but I'm sure this would work for others as well. This is real easy and will absolutely nail the sucker as far as fit without any extra trimming. First your top fwd skin is drilled and clecoed on and your F-6110 is drilled to the longerons but not drilled to the subpanel. Van draws the cutouts on the instrument panel that are necessary to clear the F-6110 so you can fit the panel in place. Make the cutouts according to Vans lines. Now put the panel in place (without the top skin and determine the relative position being sure to get the 7 degree tilt. This angle is also going to be a 90 degree angle to the topskin since you will have angle stock attatching the top skin to the panlel. Clamp scrap angle to the F-6110 as a stop to set the 7 degrees for the panel. Then let the cutouts on the panel determine how you will drill the F-6110's to the subpanel. Now the lower section of your panel fits like a glove. Get a Flat piece of 1/4 wood sheet and transfer the entire shape of the panel (big rectangle) to it and cut it out as exactly as you can. Make a mark on one side to ensure you keep it oriented the same way throughout the process. Put it in place and drill it to the three tabs on the F-6107 & 8 and to the scrap angle you clamped to the F-6110's. Now you want to transfer the basic shape of the panel with about a inch gap. I used a 3 ft level since its pretty wide. Hold a pen under the level as you move the level along the firewall and subpanel flanges which will make a nice transfer of the shape less the thickness of the pen. Use a jigsaw to cut out the shape you just drew. Clecoe the template in place, put the top skin back on and make a mark along the template on the top skin. Remove the template and put a strip of clear packing tape on the mark to act as mold release. Now clecoe the template back and make a nice thick fillet of Bondo between the top skin (staying on the tape) and the wood template. You want to be sure you fill all the way forward of the wood template so there are no gaps between wood and metal. You may have to lay on your back under the panel. After the Bondo is completely dry, slowly unclecoe the skin and allow the skin to rise off the bondo working from the longeron to the top. You now have a plug that will EXACTLY fit your fuselage shape. You need to remove the bondo overhang that will result on the forward edge. Lay it on your workbench and using a dual action sander to sand the bondo fair with the rest of the board. Now take your panel and mate it to the template being careful to keep the proper orientation. Align it with the lower cutouts, clamp it in place and trace around the bondo on the FORWARD FACING SIDE. The bondo will lay exactly against the metal for a perfect template. Use a cutoff wheel to cut the line and a file to trim away the line you drew. The Panel you just cut will fit like a tupperware lid with no additional trimming. P.S. With exception of the dry time, It takes about as long to do this as it took to write this message. Eric Henson Coconut Creek, Fl ________________________________________________________________________________
Subject: RV4 quickbuild kit for sale, maybe
Date: Dec 22, 2000
I'm considering selling my RV4 kit and getting a RV8 quickbuild. The 4 is completed to about the same stage that the quickbuilds are. I have an 0-360 and CS prop from Van's that I'd keep and use on the 8. The 4 includes all kits including finishing and has electric flaps and new style pants plus the old ones, and other stuff like airbox, baffle kit, etc. Does anyone have any idea if I'll be able to sell the 4, or is there no interest in them since the 8 came out. I would not do it if I have to give away the 4, I'd want to at least get the kit cost out of it. Any one got any input on this? Thanks. Bob Reiff Reiff Preheat Systems www.execpc.com/reiff ________________________________________________________________________________
Date: Dec 22, 2000
Subject: Re: First flight question
I think mike seiger. Contact Vans for number. RClayp5888(at)AOL.COM wrote: > > > Hello Folks, > > I am almost reday to test fly my 6A. Does anyone know who the fellow is that > assists you with this event? If so, what is his name and how do I get in > touch with him? > Bob Claypool, Fresno, CA > ________________________________________________________________________________
(Content Technologies SMTPRS 2.0.15) with ESMTP id for" ; Fri, 22 Dec 2000 08:58:52.-0500(at)matronics.com
Subject: Dual Fuel Gauge
Date: Dec 22, 2000
12/22/2000 08:54:44 AM Anyone using a single fuel gauge that shows both tanks and uses Van's old style senders? Thanks in advance Eric Henson Panel Toys... Dear Santa........ ________________________________________________________________________________
Date: Dec 22, 2000
Subject: Re: skyforce IIIC GPS
--- Jerry Calvert wrote: > > Mike, > > Fried Skyforce.......well that's kinda why I would like some feedback > on it. > Yep, I've got the laminated checklists, but the idea of electronic > checklists is appealing, but not at the expense of the Skyforce! > > Abilene is about a month sooner in 2001...we're gonna have to hurry!! > > Jerry Calvert > Edmond Ok > -6 fuselage What, you're not gonna make it? :) Finished my first set of rear canopy skirts yesterday. I say first set because I'm not sure if they'll be the final set or not. A little adjusting is in order... Instrument panel next (gotta dig out all those panel items I've been squireling away for two years), hang the engine in February. Surely it's a walk in the park from there! :) - Mike ==== Michael E. Thompson (Grobdriver(at)yahoo.com) Austin, TX, USA RV-6 in progress, N140RV (Reserved) EX-AX1 Sub Hunter, P-3 (B/B-TACMOD/C) Orion Aircrew, PP-G,ASEL, Motorglider Driver and Unlimited Air Race Nut! ________________________________________________________________________________
Date: Dec 22, 2000
I believe that if you are getting your seats from DJ at Cleaveland, Hooker will coordinate using strap covers supplied in the same material. We flew into FEP and visited Hooker. My wife picked out some colors from their wide selection. We dealt with Scott McPhillips hoohar(at)mwci.net or 815 233 5478. Nice looking and safe. Dennis Persyk snowed in at C38 -----Original Message----- From: JDaniel343(at)AOL.COM <JDaniel343(at)AOL.COM> Date: Thursday, December 21, 2000 10:29 PM Subject: Re: RV-List: seat belt cost > >I second the Hooker Harness belts. >I haven't flown with them yet, but the look wider than Van's. I also like >that you can order your own base and trim colors. > >John Danielson > > ________________________________________________________________________________
Subject: Re: Dual Fuel Gauge
Date: Dec 22, 2000
Eric, Electronics International (EI) sells a single gauge that workd off resistance style sending units. It reads left/right/both in LED and digital. It also has some useful alarm features. Vans's and Aircraft Spruce sells it. When ordering it you need to tell them that you want the resistance reading model as it is exactly the same gauge as their capacitance unit externally. Mike Robertson Rv-8A N809Rs 12.9 Hours > >Anyone using a single fuel gauge that shows both tanks and uses Van's old >style senders? > >Thanks in advance > >Eric Henson >Panel Toys... Dear Santa........ > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Subject: RE: RV6-List Digest: 1 Msgs - 12/21/00
Date: Dec 22, 2000
Gerard, This is the link to the POH I think you are referring to: http://www.mstewart.net/michael/rv/rvhome.htm Dave Wasn't there someone or someplace that had developed an "aircraft-pilot operation handbook" for the RV-4 and/or RV-6. It seems to me I either read something via E-mail or otherwise regarding the POH. Any hints of that in your travels? Thanks Gerard Pearson ________________________________________________________________________________
Date: Dec 22, 2000
> Anyone using a single fuel gauge that shows both tanks and uses Van's old > style senders? > > Thanks in advance > > Eric Henson > Panel Toys... Dear Santa........ Yes, the Electronics International FL-2R does this quite nicely, approximately $350. Has LED displays of both tanks separately, plus an LCD gallon indication in the center with a switch that directs it to read gallons left, right, or both. A very slick product! Randy Lervold RV-8, #80500, painting www.rv-8.com Home Wing VAF ________________________________________________________________________________
Date: Dec 22, 2000
> How about some of the drag race belts I used in my dragster? They are all > SFI certified and made to hold up at over 300 MPH impact. Several companies > make them, Deist, RFI, etc. Yeah but they're pretty much all bigger bulkier and heavier than the aircraft belts. I have the Schroth harnesses (www.icdc.com/~morristec). Really like them. They are FAA TSO approved and favored by the glider guys for their light weight and ease of use. But the original poster did express some concerns about cost. These are not the way to go if you want to economize. Randall Henderson, RV-6 N6R (~175 hrs) Portland, OR http://www.edt.com/homewing ________________________________________________________________________________
Date: Dec 22, 2000
Yes I do. I use the Electronics International dual gauge with Van's Stewart Warner sending units. I have found the combination to be very accurate and E.I. is the best company you could ever do business with. Feel free to contact me for more details. John Furey RV6A O-360 55hrs ________________________________________________________________________________
Subject: Re: RV4 quickbuild kit for sale, maybe
Date: Dec 22, 2000
Hi Bob, I know a gentleman that may be interested depending on you location ( i.e: anywhere near Idaho) and price. Dave Bergh RV-6 wings Mountain Home ,ID ----- Original Message ----- From: Bob Reiff <Reiff(at)execpc.com> Sent: Friday, December 22, 2000 6:54 AM Subject: RV-List: RV4 quickbuild kit for sale, maybe > > I'm considering selling my RV4 kit and getting a RV8 quickbuild. The 4 is > completed to about the same stage that the quickbuilds are. I have an 0-360 > and CS prop from Van's that I'd keep and use on the 8. The 4 includes all > kits including finishing and has electric flaps and new style pants plus the > old ones, and other stuff like airbox, baffle kit, etc. > > Does anyone have any idea if I'll be able to sell the 4, or is there no > interest in them since the 8 came out. I would not do it if I have to give > away the 4, I'd want to at least get the kit cost out of it. > > Any one got any input on this? > > Thanks. > > Bob Reiff > Reiff Preheat Systems > www.execpc.com/reiff > > ________________________________________________________________________________
Date: Dec 22, 2000
> I'm considering selling my RV4 kit and getting a RV8 quickbuild. The 4 is > completed to about the same stage that the quickbuilds are. I have an 0-360 > and CS prop from Van's that I'd keep and use on the 8. The 4 includes all > kits including finishing and has electric flaps and new style pants plus the > old ones, and other stuff like airbox, baffle kit, etc. > > Does anyone have any idea if I'll be able to sell the 4, or is there no > interest in them since the 8 came out. I would not do it if I have to give > away the 4, I'd want to at least get the kit cost out of it. > > Any one got any input on this? > > Thanks. > > Bob Reiff > Reiff Preheat Systems > www.execpc.com/reiff Bob, As one who watches this kind of stuff (always thinking about starting another project), I think you should be able to get your kit cost back, but that would be about all. Most partially completed kits end up going for less than the cost of the kit. Yours is further along and also complete, that seems to help. The workmanship (or perception on the part of the buyer thereof) of course highly influences this. The RV-4 is an excellent airplane and is still highly desireable, but as you point out much of the interest lately has been steered toward the RV-8 and RV-9 families. I know you'd think that all that labor would count for something, but the market doesn't seem to place much value on it. Of course you know that the minute you certify and fly the plan it is worth MUCH more, usually more than you have into it. Have you considered finishing it just for financial reasons? Randy Lervold RV-8, #80500, painting www.rv-8.com Home Wing VAF ________________________________________________________________________________
Date: Dec 22, 2000
-----Original Message----- From: Mike Robertson <mrobert569(at)hotmail.com> Date: Friday, December 22, 2000 11:11 AM Subject: Re: RV-List: Dual Fuel Gauge > >Eric, > >Electronics International (EI) sells a single gauge that workd off >resistance style sending units. It reads left/right/both in LED and >digital. It also has some useful alarm features. Vans's and Aircraft >Spruce sells it. When ordering it you need to tell them that you want the >resistance reading model as it is exactly the same gauge as their >capacitance unit externally. > >Mike Robertson >Rv-8A N809Rs >12.9 Hours > Mike, I am interested in that gauge. I don't trust fuel gauges in general, but the extremely non-linear level function of the RV tank adds additional complications. I have the SW resistive senders. 1) How does the programming function deal with the first 2-3 gallons of burnoff causing no decline in apparent fuel level? 2) Does the algorithm handle the two or three inflection points in the fuel level Vs gallons remaining curve? Thanks. Dennis Persyk N600DP 25 hours snowed in at C38 ________________________________________________________________________________
Subject: Remote preheater switch
Date: Dec 22, 2000
>Has anyone ever come up with a way to remotely turn on the thing [preheater] in a hangar
December 17, 2000 - December 22, 2000
RV-Archive.digest.vol-jw
