RV-Archive.digest.vol-ko
April 13, 2001 - April 20, 2001
      up throwing out stuff I won't use.  I have heavier battery wire and scat
      tubing so all I'd be using is the smaller gauge wire and terminals.  What
      lengths and gauges should I order to get started.  I'm building a 6 with
      day/night VFR panel.  Has anyone kept track of what they used?  Thanks in
      advance.
      Larry Gagnon
      Kitfox N102LG
      RV6  Finishing Kit  N6LG (reserved)
Date: Apr 13, 2001
Subject: Re: Whelen strobe connectors question
Molex connectors come in either 0.062" or 0.093" pin sizes. The small ones are good for low power connections (trim, nav lights) and the big one's I've used for Pitot heat, Landing light and Taxi light. The Whelan strobe power supply pin (Amp) looks very similar, but is different. My good quality Molex type crimper works fine with the Molex pins, and marginal with the Amp pins. The strobe and the power supply require the use of the Amp pins. In between, where the wings attach, I've used the Molex. When I started wiring the plane, I bought a bunch of different connectors i.e. 2-pin, 4-pin, 6-pin... and the associated pins from Allied. I'm glad I did. I've been able to make every connection needed quickly and professionally. Go to www.allied.avnet.com and search on Molex. Buy your crimp tool from Bob Nuckolls. Good Luck Brian Eckstein 6A Final Assembly ________________________________________________________________________________
Date: Apr 13, 2001
Subject: Re: Wiring RV 6
Larry, I bought the kit.............right at $200. Like you, d/n VFR. I used every inch of wire from the kit plus have purchased quite a bit more..........and I've yet to run the wires out to the wing tips or the tail yet. I've also used every single ring connector. The pre-made battery and solenoid cables were also very handy..........save me from running around to make up my own. Although I DID NOT follow the plans (snipped every tie wrap from the basic harness and just used the wire) that came with the kit.............they were still VERY handy to give me an education in how the basics are done. If I were doing it again I would probably still buy the kit to get me started! Rick Gray RV6 (Ohio) at the Buffalo Farm ________________________________________________________________________________
Date: Apr 13, 2001
In a message dated Fri, 13 Apr 2001 6:46:31 AM Eastern Daylight Time, czechsix(at)juno.com writes: Guys, I was looking through the archives and found a message stating that the Whelen strobe system "kit from Vans comes with a bunch of AMPCPS-3 connectors." Randy Lervold posted a related message stating "Whelen uses the AMP Mate-N-Lok series connectors.........Molex brand connectors crimp the same way but are not compatible with the Mate-N-Lock connectors or pins at all. You will likely encounter, or want to use, Molex connectors elsewhere in the plane." Ok, I'm confused. In Van's catalog under the section for Replacement parts for strobe systems, they list "Molex Connectors" for the power supply / cable connection. No reference to any type of AMP connector. Does this mean that the power supply uses a Molex connector and the strobe itself uses an AMP connector? Does anyone have pictures on a webpage of these connectors? Is the Molex or the AMP better for all-around use on the airframe?>> Randy is right and Van's is wrong. The AMP connectors are used on the Whelen systems. People often confuse without meaning to and Van's has used the term Molex generically here (refering to the white nylon housing type cheapie crimp pin connector, kind of like calling all tissues Kleenex). -GV ________________________________________________________________________________
Subject: Re: RV-4 Horizontal Stab. Question
Date: Apr 13, 2001
Thanks to everyone who responded. I finally got a response from Van's so all of my parts have now been ordered. Thanks again, Ross Scroggs Conyers, GA RV-4 Emp. ----- Original Message ----- From: <pichon.dean(at)ADLittle.com> Sent: Friday, April 13, 2001 8:55 AM Subject: Re: RV-List: RV-4 Horizontal Stab. Question > > > Hi Ross, > > I received my HS-412 hinge fittings undrilled. I remember this because > when I started my -4 (serial #2981), nothing was drilled. Recently, I had > to replace an aileron hinge bracket for similar reasons. I was able to > order from Van's an undrilled bracket. It was not immediately apparent to > the people at Van's that such a part was available, but somebody recalled > its availability and helped me out. You may have similar luck for your > problem. If not, the HS-412 is a simple part and could be fabricated from > sheet stock. The 4130 steel bends much better than aluminum. > > Dean > RV-4 > Arlington, MA > Moving it to the airport > > > |--------+----------------------------------> > | | "Ross Scroggs" | > | | | > | | Sent by: | > | | owner-rv-list-server@mat| > | | ronics.com | > | | | > | | | > | | 04/12/01 08:59 PM | > | | Please respond to | > | | rv-list | > | | | > |--------+----------------------------------> > | | > | To: | > | cc: | > | bcc: | > | Subject: RV-List: RV-4 Horizontal Stab. Question | > > > I need some help. > > I'm having to replace the HS-412 hinge fitting on my HS due to it not > being > properly aligned with the center line of the HS rear spar. When a HS-412 > fitting > is received, is it already drilled for the rivets that attach it to > the spar? I need to be able to slightly move it on the spar to properly > align it with the other fittings. > I sent a question to Van's but I guess all of the technical people are > at Sun-N-Fun. I'd like to order parts but need an answer on the HS-412 > first. > If anybody can remember how they received their part, please let me > know. > > Thanks, > > Ross Scroggs > Conyers, Ga. > RV-4, Empenage started by somebody else > > > **** This message is from Arthur D. Little, Inc., and/or one of > Arthur D. Little's subsidiaries or affiliates and may contain > confidential business information. It is intended for the addressee > only and may not be copied without our permission. If you are not > the intended recipient please contact the sender as soon as possible.**** > > ________________________________________________________________________________
Date: Apr 13, 2001
Subject: Contact with Fred Kunkel?
I've sent Fred a few e-mails, and haven't heard from him. Fred, if you see this, could you please email me at jwlawson(at)hargray.com? Or, if anyone's been in contact with him, would they let him know I'd like to get in touch with him? Thanks! John ________________________________________________________________________________
Date: Apr 13, 2001
Subject: Re: Blast tubes
In a message dated 04/13/2001 7:22:26 PM Eastern Daylight Time, mrobert569(at)hotmail.com writes: > . And the tubes to the vacumn and fuel pumps > are luxury items. Maybe, but after my O-320 tried to quit on me at altitude the first warm day of spring, my luxury blast tube to the fuel pump is about to get larger. Bill Boyd RV-6A O-320/Sensenich FP Hop-Along Air Field, 12VA Clifton Forge, VA ________________________________________________________________________________
From: "Daniel Estrada F." <dani_estrada(at)infosel.net.mx>
Subject: TEST...
Date: Apr 13, 2001
Test ________________________________________________________________________________
Date: Apr 13, 2001
Buy Van's wiring kit. It's worth it. ________________________________________________________________________________
Date: Apr 14, 2001
Subject: Contact w/Fred :-)
To the assembled multitudes: I posted a note yesterday asking Fred Kunkel to get in touch with me. I hope I didn't give any wrong impressions - he's doing just fine, we just got our wires crossed a bit. He continues to give 'way excellent service on tools, I (STILL) highly recommend him (especially for used tools). Semper Fi John RV-6 (wings...waylaid by work again...still plugging away on the control surfaces) ________________________________________________________________________________
Subject: Re: 4 rotary powered RV's at SnF
Date: Apr 13, 2001
> > BTW, Pat and I were listening to a conversation between one of the > owners and a builder. The fuel consumption on his 13B is about > 4gal/hour at idle to 14 gal/hour at full power. I'm not sure if that's > good or bad. Just a number I heard. > > Jim Sears in KY > RV-6A N198JS > > Hi Jim, I think that all the folks flying rotary's now started before Tracy came on the scene, therefore they are all considerably different. Tracy is starting to manufacture components such as reduction drives, electronic fuel controls, etc. so we are likely to start seeing more similiar installations. You will always have differences such as are seen in lycoming installations today. Oil coolers are a prime example of variability in todays installations. The exhaust is a problem because it is hot and noisy, but a big pipe also hangs out of piper malibus and Pilatluses. This does not necessarily detract from the esthetics. Beauty is in the eye of the beholder! Everett Hatch flew his rotary RV4 block to block formation with Van in his 160 HP lycoming and consumed the same amount of fuel. The BSFC may be a little worse on the rotary, but Everett had a pretty efficient radiator system and it is probable to make less drag with water cooling. Bernie Kerr, 160 HP lycoming in 6A ________________________________________________________________________________
Date: Apr 14, 2001
Subject: Re: RV6-List Digest: 1 Msgs - 04/13/01
Does anyone know the positon of the rear seats of this new four placer-facing forward or toward the rear? Bob ________________________________________________________________________________
Date: Apr 14, 2001
Subject: Question re: machine screw sizes
OK, another crayon-level question. When I look at the size of a machine screw and it says, say, 10-32, what does that mean? Semper Fi John RV-6 (a-workin' on them parts of the wings that flop around when the pilot moves the stick) ________________________________________________________________________________
Date: Apr 14, 2001
It's a #10 size in diameter and 32 threads per inch. Greg -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of John Lawson Sent: Saturday, April 14, 2001 6:33 PM Subject: RV-List: Question re: machine screw sizes OK, another crayon-level question. When I look at the size of a machine screw and it says, say, 10-32, what does that mean? Semper Fi John RV-6 (a-workin' on them parts of the wings that flop around when the pilot moves the stick) ________________________________________________________________________________
Subject: Executive Hangar @ Frontrange in Denver
Date: Apr 14, 2001
I will have a beautiful executive hangar available for space to rent at Frontrange Airport just east of Denver sometime in June. It is heated with a bi-fold door and bathroom. Anyone interested? ________________________________________________________________________________
Date: Apr 14, 2001
Subject: Re: Question re: machine screw sizes
The first no. is the hole size. Each number is referrs to a hole size in decimals and NOT parts of an inche! If you have a Cleveland or Avery Cat it will show you exactly what numbers are equal to in decimals. All that (decimals) really does not matter as long as you know that the first number is the hole size. The last number is the threads per inch-double check me on the last number. Bob ________________________________________________________________________________
Date: Apr 14, 2001
Subject: Re: RV-4 CANOPY REPLACEMENT
> >Hi Everyone > This is my first post on the list and I was hoping it could have >been in better circonstances.I went to the airport (Actually a farm >strip)today to start getting my RV-4 ready for another flying season and >since my last visit some vandals managed to break my canopy. > Since I bought the airplane as an already flying RV-4,I have only >a basic idea of the work involved in replacing my canopy.So I have a few >questions for any RV-4s owners > >1.-How much will a new canopy cost ? > Bruno, Ouch!! Sorry to read about your troubles. You can price parts easily from Van's web site: <http://www.vansaircraft.com/> Go to to Online Shopping, Accessories Catalog, and then look down a few inches from the top to find a link "the list". That will give you a text file with all the part numbers, descriptions and prices. I searched that list for canopy, and found: C-401 GRAY TINT PLEX CANOPY $529.23 C-401 CLEAR CLEAR CANOPY BUBBLE $513.85 I can't help you on the other questions, as I'm building an RV-8. Given that you didn't do it the first time, you might want to find a local builder who has already done his canopy and pay him to do yours, or at least get him to help you. I don't think that will get you in trouble with Transport Canada, but you might want to confirm with the Dorval regional office. If they give you a hard time, contact me and I'll put you in touch with the headquarters guy in charge of amateur built aircraft issues. They are currently working on an update to the regulations that should legalize builder assistance. It looks like the updated regulations will take the very practical view that it is safer to allow builders to contract out complex work than force them to do it just to meet the 51% rule. I doubt they will give you grief if someone rebuilds your canopy for you. Good luck, -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Date: Apr 14, 2001
10 is the Diameter- Approximately 3/16" 32 is the number of threads per inch. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh ----- Original Message ----- From: "John Lawson" <jwlawson(at)hargray.com> Sent: Saturday, April 14, 2001 8:32 PM Subject: RV-List: Question re: machine screw sizes > > OK, another crayon-level question. When I look at the size of a machine screw and it says, say, 10-32, what does that mean? > > Semper Fi > John > RV-6 (a-workin' on them parts of the wings that flop around when the pilot moves the stick) > > ________________________________________________________________________________
Date: Apr 14, 2001
# 10 comes from the size of a # 10 number drill and is NOT decimal. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh ----- Original Message ----- From: <Bobpaulo(at)AOL.COM> Sent: Saturday, April 14, 2001 8:10 PM Subject: Re: RV-List: Question re: machine screw sizes > > The first no. is the hole size. Each number is referrs to a hole size in > decimals and NOT parts of an inche! If you have a Cleveland or Avery Cat it > will show you exactly what numbers are equal to in decimals. All that > (decimals) really does not matter as long as you know that the first number > is the hole size. The last number is the threads per inch-double check me on > the last number. Bob > > ________________________________________________________________________________
Date: Apr 14, 2001
"RV-List: RV-4 CANOPY REPLACEMENT" (Apr 14, 5:54pm)
Subject: Re: (Miss-use of the DNA flag?) RV-4 CANOPY REPLACEMENT
>-------------- > >Hi Everyone > This is my first post on the list and I was hoping it could have >been in better circonstances.I went to the airport (Actually a farm >strip)today to start getting my RV-4 ready for another flying season and >since my last visit some vandals managed to break my canopy. > Since I bought the airplane as an already flying RV-4,I have only >a basic idea of the work involved in replacing my canopy.So I have a few >questions for any RV-4s owners > >1.-How much will a new canopy cost ? > >2.-Any special advise on do's and don'ts > >3.-Anyone knows of any good shops selling new canopies (In eastern >Canada/USA will be better) > >4.-Anyone with a good web site so I can see how it is done > >You may e-mail me if you prefered > >Thanks in advance for any imputs you may provide > >Bruno Dionne >Grounded RV-4 CG-DBH (For now ) >Bellefeuille Quebec Canada >E-mail# fo320(at)sympatico.ca > >Do_ not_ archive >-------------- Bruno, I'm curious why you marked this message with the DNA flag? This is material that should have gone into the Archive. Listers at Large, I think I am going to disable the DNA feature soon since so many people have been miss-using it. The continued miss-use really bothers me for some reason. I know of at least one person (on a different List) that actually has the DNA flag in his .signature file so that no matter what he posts, it never gets archived. Remember that even the replies will not be archived unless the replyer removes the DNA flag. Anyway, sorry to be a bummer but dang-it, this bugs me. Comments? Matt PS - I'm definately not picking on you, Bruno! I just used you as a typical example. -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft Great minds discuss ideas, Average minds discuss events, Small minds discuss people... ________________________________________________________________________________
Date: Apr 14, 2001
Subject: Powder Coat Removal
To those that wish to remove Vans Powder coat on gear legs,motor mount etc..There is a process that I just used from a outfit here in Nashville,Tn called Strip Masters.. They use very low pressure(30#) or less with plastic chips.. They are doing commercial aircraft paint removal on special surface's..They did motor mount,gear legs 100.00 Strip Masters Nashville,tn 615-255-4850 1-800-356-8205 John McMahon Floor skins ________________________________________________________________________________
Date: Apr 15, 2001
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
>>Listers at Large, >>I think I am going to disable the DNA feature soon since so many >>people have been miss-using it. Matt; I think that with all the warnings (requests) to keep messages short and not clutter the archive that people tend to err on the side of d* no* archiv* to be kind to your server. Also it is sometimes difficult to decide wheather the information a person thinks they are giving in a response is valuable, or if it is just a quick offhand reply or thought as opposed to a well researched answer to the problem or question of the original poster. As to the original poster not archiving their post, they may feel that it is their own small personal problem without realising that their question may be the same one someone else had but didn't verbalise or that it is of interest to others. I have responded to the list a few times with information I thought might be usefull to the thread and used the DNA feature because I didn't think my lowly thoughts were of general interest. I have on a couple of occasions received replys such as yours asking why I did that. In all of my cases it was out of ignorance and when requested reposted without the DNA message. The ones that particularly bug me are those that repeat the whole of the original message or even part of the whole thread, or those that go on forever chasing an obvious joke without the DNA. My two cents on the subject Matt and we do appreciate this forum even if it is miss-used from time to time. Bob McC ________________________________________________________________________________
Date: Apr 14, 2001
Matt: > Anyway, sorry to be a bummer but dang-it, this bugs me. Comments? I have to admin that I've tended to take the approach of "if in doubt, DNA it." I seem to recall that the original purpose of the DNA feature was to allow chatter on the list without filling up the archive with it. Was that how it went? But that leaves the question: what is "chatter?" Is this thread, for example, chatter? It's not about RV building or flying at all, it's just a meta discussion about the list itself. I suppose I don't quite consider that "chatter," but I'm not sure it needs to be in the archive, either. Before giving up on the DNA feature, perhaps you can clarify how you intended it to be used. Is it covered in your automatic posts about list ettiquette? Tedd McHenry Surrey, BC -6 ________________________________________________________________________________
Date: Apr 14, 2001
Subject: Jabiru track record
Jabiru may not have much of a track record in the U.S., but they have been producing Australian-certified airplanes since '91 and have been producing 4-stroke Australian-certified aircraft engines since '93. Their current line includes an 80 and 120 hp 4 stroke, direct drive engines. They have been flying the 80hp engine in their own airplane (Jabiru LSA 55/2K) since '95. Not quite the track record of Lycoming, but seems they have garnered support from the Oz government. I am not sure whose government you trust more, ours or theirs, but it seems that Jabiru has gone to some lengths to create a good product. That said, I think that unless Van's comes up with a firewall forward kit for the Jabiru, then your engine installation will be just as problematic as a 13B or Chevy. tw ________________________________________________________________________________
Subject: rv-8 video
Date: Apr 15, 2001
I've got the first episode encoded( from the ground up) but need to put it where those interested can get at it. Its 21 meg and in wmv (windows media). Any ideas?? Also the big version is about 80 meg... Steven DiNieri Niagara Falls, New York RV-6A, P28A-160 ________________________________________________________________________________
Subject: Jabiru track record and vacuum pumps
Date: - - - , 20-
>That said, I think that unless Van's comes up with a firewall forward >kit for the Jabiru, then your engine installation will be just as >problematic as a 13B or Chevy. The advantage we have with the Jabiru is that the manufacurers of this new engine are looking at the RV for it's intended use. They already have mounts and firewall forward kits for other homebuilts. I'm sure they'll follow through with a mount and kit for the RVs as well. I'm betting they don't have to, if Van really is looking at the Jabiru for his installations. There is one thing we did miss during all of this discussion. No one has mentioned provisions for a vacuum pump. Many of us, if not most, use them. I sent notes to two of the dealers to pose the question. Although I'm not in the market for one, right now, I'd like to know the engine will meet all of our needs. Jim Sears in KY RV-6A N198JS ________________________________________________________________________________
Date: Apr 15, 2001
Subject: 10-32 screws
John- 10-32 is the size of the screw (#10) and the thread pitch (32). You might want to get a bolt gauge or a screw gauge from the local hardware store to check the pieces you use when you're confused about sizes when you're doing assembly work. I think Avery might sell these, also. Ed Winne RV-9A Palmyra PA ________________________________________________________________________________
Subject: Re: Jabiru track record and vacuum pumps
Date: Apr 15, 2001
> > > There is one thing we did miss during all of this discussion. No one > has mentioned provisions for a vacuum pump. Many of us, if not > most, use them. Jim, I'm not sure if you were referring to the Jabiru, but from their web site, "For those owners wanting to fit vacuum instruments to their aircraft the Jabiru engine design includes a vacuum pump drive, direct mounted through a coupling on the rear of the crankshaft." Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/index.htm ________________________________________________________________________________
Date: Apr 15, 2001
Subject: Thanks! on question re: machine screw sizes
Thanks to all who responded, much appreciated! There are so many doggone ways to describe and designate the sizes and identification of screws, rivets, nuts, bolts, etc....whew. Semper Fi John RV-6 (wings...plugging away at the control surfaces) ________________________________________________________________________________
Date: Apr 15, 2001
> >Jabiru may not have much of a track record in the U.S., but they have been >producing Australian-certified airplanes since '91 and have been producing >4-stroke Australian-certified aircraft engines since '93. Their current >line includes an 80 and 120 hp 4 stroke, direct drive engines. They have >been flying the 80hp engine in their own airplane (Jabiru LSA 55/2K) since >'95. Not quite the track record of Lycoming, but seems they have garnered >support from the Oz government. I am not sure whose government you trust >more, ours or theirs, but it seems that Jabiru has gone to some lengths to >create a good product. > >That said, I think that unless Van's comes up with a firewall forward kit >for the Jabiru, then your engine installation will be just as problematic >as a 13B or Chevy. > >tw > Terry, I don't think the concern is Jabiru's track record, but more the lack of track record on the engine in question (180 hp 8 cylinder model). Each engine can have its own specific problems. I work in the type certification world, and I have seen several examples where major manufacturers have had lots of teething pains on new engine models. They eventually get it sorted out, but I wouldn't be an early buyer of a new model, expecially for a single-engine aircraft. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Date: Apr 15, 2001
Subject: Rear Spar Dimple/Countersink ?????
Happy Easter Listers, Finally getting close to actually setting some rivets in my wing construction. In completing the wing box, I plan to dimple the rear spar bottom flange (for skin) exept at the intersections of the ribs where I plan to countersink for the skin dimple. Does this sound ok? Thanks in advance! Jack DSM RV8, wings ________________________________________________________________________________
Date: Apr 15, 2001
Subject: Re: rv-8 video
Steve, We're only using about 10 megs of the 100megs that our webserver alots us. If the list members can keep it cool, I'm willing to post two episodes a week there in rotation. I'll contact you off-list about getting the file. --Sam > > > I've got the first episode encoded( from the ground up) but need to put it > where those interested can get at it. Its 21 meg and in wmv (windows media). > Any ideas?? Also the big version is about 80 meg... > > > Steven DiNieri > Niagara Falls, New York > RV-6A, P28A-160 > > > >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Cinelogic inc. (818)772-4777 fax 772-4733 sam(at)videoassist.com http://www.videoassist.com ________________________________________________________________________________
Date: Apr 15, 2001
This is what I will do also. I guess it is possible to dimple the rib, rear spar flange and skin but since I assembled the box without dimpling any of these parts I have no choice. I can't see any reasons why a countersink of the rear spar at the rib intersections wouldn't work. If you're uncomfortable with the countersink, you can dimple the skin and carefully remove the 'backside' of the dimple with a dremel tool or a small file. Regards, Are RV-8 Wings -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of pincjt(at)ix.netcom.com Sent: April 15, 2001 10:20 AM Subject: RV-List: Rear Spar Dimple/Countersink ????? Happy Easter Listers, Finally getting close to actually setting some rivets in my wing construction. In completing the wing box, I plan to dimple the rear spar bottom flange (for skin) exept at the intersections of the ribs where I plan to countersink for the skin dimple. Does this sound ok? Thanks in advance! Jack DSM RV8, wings ________________________________________________________________________________
Date: Apr 15, 2001
> I work in the type > certification world, and I have seen several examples where major > manufacturers have had lots of teething pains on new engine models. > They eventually get it sorted out, but I wouldn't be an early buyer > of a new model, expecially for a single-engine aircraft. How about the diesels that we were told about two years ago? When is Renault (SMA) going to come out with their 200 hp? Norman Hunger ________________________________________________________________________________
Date: Apr 15, 2001
Eric,be encouraged,and remember Teddy Roosevelt's words"critics don't count".It's the man in the arena with sweat in his eyes who is trying to do his best who really counts.Hang in there and don't let these critics whose purpose seems to be to flame others get you down. ________________________________________________________________________________
Subject: Re: Alternate engines
Date: Apr 15, 2001
Jim Sears wrote: >If the engine is certified, it will have had to have gone > through testing to get that. What does certification testing consist of ? Hal Kempthorne RV6a N7HK (Valentine) FLYING ________________________________________________________________________________
Subject: Blast tubes
Date: Apr 15, 2001
I find it hard to believe that anything that is bolted to the engine case really benefits from blast cooling. It seems to me that fuel pumps, magnetos, and vacuum pumps will all be at the same temperature as the engine case and a small blast tube could not overcome the temp of of the entire mass. Ed Cole RV6A N2169D Flying RV6A N648RV Finishing -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Mike Robertson Sent: Friday, April 13, 2001 4:18 PM Subject: Re: RV-List: Blast tubes Here's my two cents worth. The tubes to the alternator and the right mag are needed unless you fly in only a cold weather area. I talked to Klaus and he was clear that the newer versions of the LSE ignition module don't need the cooling air anymore. And the tubes to the vacumn and fuel pumps are luxury items. Some may disagree about the vacumn pump but I haven't seen it have a big effect over the years. Mike Robertson RV-8A >From: RGray67968(at)AOL.COM >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Blast tubes >Date: Fri, 13 Apr 2001 18:36:39 EDT > > >Hey folks, > Lots of posts in the archives but nothing concrete as far as what >is >REALLY necessary. What is the REAL scoop on what blast tubes I need? I >worked >really hard to minimize all the clearances on my engine baffles and here I >am >ready to punch 5 (count 'em) 11/16ths holes in them. I planned to run the >tubes to 1 - alternator, 2 - left mag, 3 - right Lightspeed Elect. Ign., 4 >- >vacuum pump, 5 - fuel pump. From you guys flying...........what do I need, >what is just 'nice to have,' and what am I wasting my time on? >Thanks in advance. >Rick Gray RV6AB (Ohio) at the Buffalo Farm >please please please archive pretty please > > ________________________________________________________________________________
Date: Apr 15, 2001
> I find it hard to believe that anything that is bolted to the engine case > really benefits from blast cooling. > It seems to me that fuel pumps, magnetos, and vacuum pumps will all be at > the same temperature as the engine > case and a small blast tube could not overcome the temp of of the entire > mass. Ed, I have tubes going to mags also and I am not convinced they serve a purpose because there is no shroud. My fuel pump has a shroud around it and I think this is effective. I think the one to the alternator is worth while, its is not sinking into the engine and is below the air flow. Anyway the whole engine is cooled by a big blast tube. Ken ________________________________________________________________________________
Date: Apr 15, 2001
The Orndorff "Finishing Kit" tapes Part I has a good video section on cutting plexiglass for an RV6.It would be similar for any RV . ________________________________________________________________________________
Date: Apr 15, 2001
Subject: To serif or not
Somebody posted: > However, for > readability, you can't really beat a sans-serif font (a font that doesn't > have little hooks and flanges at the ends of the strokes of the letters). Frankly, I regard this as an urban legend, and know that this is a good way to start a non-productive argument... that not withstanding, back in a grad school class, the topic was two dimensional Fourier transformation, anti-aliasing, and all that. The point of this discussion, which I barely understood then and barely remember now, is that the serifs make text more readable. Example: look at how many books use serif fonts (essentially all of them), and how many magazines use serifs (most all of 'em, except those that are overly stylized.) Counter example: road signs, aircraft instrument panels -- and that may be because it's too hard to engrave serifs. Frankly, if the font has good contrast and clarity, you're probably okay either way. My pet bugaboos: * long rows of switches where you can't easily find what you want. Group switches to no more than 5 in a group * important switches (like fuel pump) that aren't easily found. Put 'em on the end * inappropriate switches (turn & bank on/off toggle switches, for instance) * mixing important and unimportant switches (fuel pump or master switch buried in a row of lights) Lots of folks don't think human factors are important, and they're often right. When they're wrong, though, the evidence is frequently bent metal. Ed "now looking at human factors professionally" Wischmeyer ________________________________________________________________________________
Date: Apr 15, 2001
When I read of your vandalized canopy it made me think that a locked hanger while expenisive may be in the long run cheaper. Someone wanted some of the aviatonics of a friend's RV4 in Visalia (locked canopy) they busted the canopy and took what they wanted. I remember him saying he did not think he would lock the canapy again,they could open the canopy,take what they wanted without destroying the canopy.Sometimes a lock only keeps out honest people. ________________________________________________________________________________
Date: Apr 15, 2001
Richard Collins mentioned this in Flying magazine last month (April, 01, p. 74) He claims to have had a vacuum pump failure in his C-210 every 200 hours when it was new, seven in all. Installing a blast tube with a shroud has reduced the failure rate to only one in the past 6400 hours. I think I will be installing a blast tube on my pump. Scott Pittman Ordering RV-4 Fuselage > > I find it hard to believe that anything that is bolted to the engine case > > really benefits from blast cooling. > > It seems to me that fuel pumps, magnetos, and vacuum pumps will all be at > > the same temperature as the engine > > case and a small blast tube could not overcome the temp of of the entire > > mass. > > Ed, > I have tubes going to mags also and I am not convinced they serve a purpose > because there is no shroud. My fuel pump has a shroud around it and I think > this is effective. I think the one to the alternator is worth while, its is not > sinking into the engine and is below the air flow. Anyway the whole engine is > cooled by a big blast tube. > Ken > > ________________________________________________________________________________
Date: Apr 15, 2001
Maybe someone can benefit from this, I don't have any clue about the engine and don't want to start a flaming war. Yesterday I spoke to one of our Chapter members who has a modified Long-EZ with twin 80 HP Jabiru engines. He is totally frustrated with the support he has been given by Jabiru on an electrical problem. He is getting lots of ignition noise and also, the alternators don't seem to be putting out their rated power. He has shielded wire throughout and grounded well. The ignition system just seems to be very noisy. As for the alternator's power, I cannot say what the difficulties are. Just some comments about a friend's problems. Marty in Brentwood TN ----- Original Message ----- From: "Kevin Horton" <khorton(at)cyberus.ca> Sent: Sunday, April 15, 2001 8:17 AM Subject: Re: RV-List: Jabiru track record > > > > >Jabiru may not have much of a track record in the U.S., but they have been > >producing Australian-certified airplanes since '91 and have been producing > >4-stroke Australian-certified aircraft engines since '93. Their current > >line includes an 80 and 120 hp 4 stroke, direct drive engines. They have > >been flying the 80hp engine in their own airplane (Jabiru LSA 55/2K) since > >'95. Not quite the track record of Lycoming, but seems they have garnered > >support from the Oz government. I am not sure whose government you trust > >more, ours or theirs, but it seems that Jabiru has gone to some lengths to > >create a good product. > > > >That said, I think that unless Van's comes up with a firewall forward kit > >for the Jabiru, then your engine installation will be just as problematic > >as a 13B or Chevy. > > > >tw > > > > Terry, > > I don't think the concern is Jabiru's track record, but more the lack > of track record on the engine in question (180 hp 8 cylinder model). > Each engine can have its own specific problems. I work in the type > certification world, and I have seen several examples where major > manufacturers have had lots of teething pains on new engine models. > They eventually get it sorted out, but I wouldn't be an early buyer > of a new model, expecially for a single-engine aircraft. > -- > Kevin Horton RV-8 (finishing kit) > Ottawa, Canada > http://eccentrix.com/misc/rv8/rv8.html > > ________________________________________________________________________________
Subject: RV8 Trip Report: Albuquerque to Spokane (long)
Date: Apr 15, 2001
Listers, My trip a few days ago in the RV8 to the Pacific Northwet..uh...northWEST was quite successful! Had a great time and saw some wondrous sights. My backseater for the trip was Gary Seaton, who, after flying with me last year, decided he just had to have an RV. The purpose of the trip was to take Gary to Revelstoke, B.C. to meet with Homer Rogers, builder of an awesome RV-6A for sale. My job: fly Gary there, and do a pre-purchase inspection and flight evaluation of the airplane. Both went exceptionally well. Homer is a terrific guy and builds a fine airplane. We struggled on the way up there to find VFR weather along our chosen route. First stop was Page, Az. Wx was down to yucky VFR upon arrival. We landed, fueled up, and got a ride into town for breakfast. The scud cleared up nicely to a low, scattered layer that was easily topped for our departure. Off we went to Ely, Nevada for the next fuel stop. Yet again, more snow, rain and low ceilings. It was the kind of weather that looks really dreadful from a distance, but sorta dissolves as you get near it. Visibility was just fine but it was COLD! It's still wintertime in some parts of the country! We touched down in Ely, tanked up, checked the charts and weather ahead. The same type of random showers and mist was forecast all the way up to Washington, with improvement farther to the west. Next stop was Nampa, Idaho. Our route took us up over Elko, Nevada, then a slight northerly swing to Nampa. Pretty decent weather and looking better by the minute. More fuel, a few cookies for the crew, and off again. Next waypoint was Baker City. Visibility very good, but had to make the choice: over the top for a smooth, clear ride, but man it's cold up there! Or, down under it, a bit warmer, but have to dodge the occasionally semi-obscured mountains. We did a bit of both. The cabin heater did help, but not much when the canopy shrinks from the cold and every little air leak feels like a blast of arctic air. Gotta work on that. We passed Baker City and pointed the nose at Davenport, Washington. The going was good...very good in fact...until we neared the Oregon/Washington border. A huge wall of misty, blinding white cloud that had no top in site was ahead of us. The sun was lighting it up like a flashbulb and I just could not see through it. So, while constantly looking over my shoulder and down to assure myself that we could get into visual conditions, I started a climbing ascent to see where the top was. After an inspiring RV climb to 14,000', I'd had enough. Still couldn't see through it. The view below and behind was still wide open. "Gary, I think we're done for the day" was my comment. A course reversal and 15 minutes later, we were descending into La Grande, Oregon. Blew the first approach...after the wind sock swapped ends on me on final! Don't ya just hate it when that happens? The next shot at it went much better, but I'm still totally amazed at how the airplane handles closer to sea level than where I typically fly. It's like the wings are filled with helium! I was a slipping madman most of the trip. Kept coming in too high. We stayed the night at La Grande, and returned to the airplane Friday morning to find it covered with a mixture of snow and ice from the precip of the previous night. I put my back seater to work brushing it off...ALL of it. The skies were clearing and off we went. The flight into Washington was simply stunning. Perfectly smooth air and unlimited visibility. Yet again, that changed! Next waypoint was Davenport, then a right hook around the Spokane airspace into Deer Park. More scud, and showers. I pulled some power to slow down to give me more time to make a decision and a 180 turn if necessary. The Davenport airport looked largely deserted, so we continued on to Deer Park. The clouds were definitely low, but seemed to open up as we passed. It was magical. Beautiful terrain, light rain, and occasional bits of sun. We landed at the Park, and also found nobody home. One grumpy A&P type working in a hangar was absolutely NO help at all. We did find the small building that housed a bathroom, charts, coffee, and such. After a few minutes there, Bill and Penny Loomis, the managers, arrived. These folks have got to be the nicest, most supportive and downright wonderful folks in the airport business! They helped me assess the weather situation, from an experienced, local viewpoint, and even called up Castlegar flight service for a weather briefing at our intended Canadian port of entry. Synopsis: VFR not recommended....REALLY not recommended. When I hear terms like "snow pellets, rain showers, mountain obscuration, or visibility less than one mile"...I tend to listen! Bill and Penny mentioned that we consider driving up there..in their loaner car! Done deal. I made my "no-go" decision, we grabbed a quick sandwich at the Subway, and onward to Canada we went. Oh, one more thing, they pulled their Champ out of their hangar so that I could park my RV for the night. WOW..these folks are awesome. Gary called Homer with our plans and Homer agreed to fly the plane down to Castlegar to save us all some time. We drove the three hours up through customs and into Castlegar, B.C. What a drive, and the views were exceptional. Just as Gary was preparing to call Homer's wife, I looked down the flightline and saw...Homer's airplane! He had arrived mere minutes before we did. What timing. I looked the plane over, and mostly admired the craftsmanship and cleverness of Homer's construction skills. Many improvements were made and all were executed with great care. I hopped in the right seat, with Homer in the left and off we went down the river. WOW...we don't have views like this in New Mexico! A few turns, stalls, and we were headed back. I landed it. Man, whatta groovy RV. On the ramp, Homer hops out, and tells me to take Gary up. "HUH!?? ME?? I thought YOU were going to take him up?" Was all I could say. It all went very well, It's just an RV afterall, and handles wonderfully. In fact, I landed it better than I land MY OWN AIRPLANE! Gee, what's up with THAT?!? (NO comments on the training wheel debate, K?) The synopsis of the deal: Gary bought the airplane. Delivery or pickup of the plane will happen at a later date. We flew home in MUCH better conditions, and with a decent tailwind that allowed groundspeeds of 195mph+ most of the way. Total flight time back home along the same route as we came up: 6 hrs., 51 minutes. Keep building your airplanes, folks. The world opens up to you when you fly an RV! Brian Denk RV8 N94BD ________________________________________________________________________________
Date: Apr 15, 2001
> > >>Sometimes a lock only keeps out honest people. > > A lock keeps out only honest people!! There is no lock made which will keep out someone who REALLY > wants to get in. > > Bob McC Ain't that the truth ! A few years ago, vandals broke into an old WW2 hangar here which had about 40 airplanes in it, and they went around randomly smashing canopies etc., and all they took were stupid things like a fire extinguisher and the odd headset....must have been kids. Worst kind of thing though was they smashed the canopy of a T28 which was not locked but they could not figure out how to slide it....then they took nothing. I have always planned not to have a lock on my canopy...my panel sure ain't exotic, but if they want to get in...go ahead..canopy slides easily.... Austin. ________________________________________________________________________________
Date: Apr 15, 2001
Subject: Re: To serif or not
You Go, Boy! The ergodynamics of the aircraft cockpit and further anthropogenic/physiologic considerations are becoming a very important part of aircraft design and accident investigation/prevention. Some of these little things can matter very much under certain "stressed" situations and even under "normal" situations (ie, the location of the fuel selector valve on John Denver's newly acquired aircraft). Also, remember cockpit procedures, communications and POH instructions (remember the airliner that went down over southern Florida because the whole flight crew was trying to trouble shoot a warning light and no one was flying the 'plane?). Boyd Braem N600SS Ed Wischmeyer wrote: > > > Somebody posted: > > > However, for > > readability, you can't really beat a sans-serif font (a font that doesn't > > have little hooks and flanges at the ends of the strokes of the letters). > > Frankly, I regard this as an urban legend, and know that this is a good > way to start a non-productive argument... that not withstanding, back in > a grad school class, the topic was two dimensional Fourier > transformation, anti-aliasing, and all that. The point of this > discussion, which I barely understood then and barely remember now, is > that the serifs make text more readable. > > Example: look at how many books use serif fonts (essentially all of > them), and how many magazines use serifs (most all of 'em, except those > that are overly stylized.) > Counter example: road signs, aircraft instrument panels -- and that may > be because it's too hard to engrave serifs. > > Frankly, if the font has good contrast and clarity, you're probably okay > either way. My pet bugaboos: > * long rows of switches where you can't easily find what you want. Group > switches to no more than 5 in a group > * important switches (like fuel pump) that aren't easily found. Put 'em > on the end > * inappropriate switches (turn & bank on/off toggle switches, for instance) > * mixing important and unimportant switches (fuel pump or master switch > buried in a row of lights) > > Lots of folks don't think human factors are important, and they're often > right. When they're wrong, though, the evidence is frequently bent metal. > > Ed "now looking at human factors professionally" Wischmeyer > ________________________________________________________________________________
Date: Apr 15, 2001
Serif fonts are generally used in print sizes of 12 point or smaller, to make reading easier. They make reading easier because we read mostly by recognizing the overall shape of each word, not by parsing individual letters, and the little horizontal strokes (the serifs) help tie the word together and visually separate it from the other words. (We only parse letters when we encounter an unfamiliar word. This is why it's so easy to miss a small error, such as "spoof" instead of "spool", when proof-reading. The overall shape of one word is much like the other.) But this theory is about how we read lines of text, and serif fonts are used to aid reading lines of text. If you are using labels (single words or short phrases) the advantage of serifs mostly disappears. This is referred to in publishing as "display font," and is generally san-serif. A better way to go with labels is to use a larger font, and not worry about the serifs. An aside: serifs were invented by the Romans, as a way to avoid cracks caused by stress concentration at the ends of strokes when they chiseled characters into stone. That is why serif fonts are often referred to as Roman fonts, to this day. Tedd McHenry Surrey, BC -6 ________________________________________________________________________________
Date: Apr 15, 2001
Subject: Re: RV-List:Miss-use of the DNA flag?
I have never used the "DNA" tag because I try to adhere to the following rule: "If it ain't worth archivin', don't post it". Sam Buchanan "The RV Journal" http://home.hiwaay.net/~sbuc/journal "BOBE." wrote: > > > Eric,be encouraged,and remember Teddy Roosevelt's words"critics don't > count".It's the man in the arena with sweat in his eyes who is trying to > do his best who really counts.Hang in there and don't let these critics > whose purpose seems to be to flame others get you down. ________________________________________________________________________________
Date: Apr 15, 2001
> Richard Collins mentioned this in Flying magazine last month (April, 01, p. > 74) He claims to have had a > vacuum pump failure in his C-210 every 200 hours when it was new, seven in > all. Installing a blast tube > with a shroud has reduced the failure rate to only one in the past 6400 > hours. I think I will be installing a > blast tube on my pump. It is also interesting that in the same article, he notes that he has had numerous electrical failures, far more than vacuum. Alex Peterson Maple Grove, MN 6A ------ http://USFamily.Net/info - Unlimited Internet - From $8.99/mo! ------ ________________________________________________________________________________
Date: Apr 15, 2001
Subject: Which kits to buy first
I am going to buy the Rv7 kit this June. I am planning on buying 2 kits initially, and I was curious which was I should buy first. The empannage and wing kit or the Emp and the fuselage. This is probably a stupid question, but I couldn't find anything on Van's web page to help me out. Also does anyone have the actual dimensions so that I can compare the cockpits width with the RV6. Jimmy Arnold ________________________________________________________________________________
Date: - - - , 20-
>Maybe someone can benefit from this, I don't have any clue about >the engine and don't want to start a flaming war. Yesterday I spoke >to one of our Chapter members who has a modified Long-EZ with >twin 80 HP Jabiru engines. He is totally frustrated with the support >he has been given by Jabiru on an electrical problem. He is getting >lots of ignition noise and also, the alternators don't seem to be >putting out their rated power. > >He has shielded wire throughout and grounded well. The ignition >system just seems to be very noisy. As for the alternator's power, I >cannot say what the difficulties are. Just some comments about a >friend's problems. Hmmmm. This isn't good. Did the friend have any problems before he installed the new engines? Is it possible that he may have done something during the installation that has impacted the system? You say he isn't getting support from Jabiru. Have there been good tech sessions or have they been heated? This alone can cause some difficulties. Like you, I'm not trying to throw flames, either. I look at this as something that would be nice for you to look into for us a bit farther, if you don't mind. We don't want to judge an engine by one person's installation. I've seen some bad and good ones, even with my limited access to those projects of others. However, if his installation is good and the support bad, we need to know that up front before we start sinking dollars into a bad deal. So far, the majority is in favor of this being a good engine. In the meantime, I've got a friend in England who has a Jabiru airplane fitted with what else. :-) I'll contact him and see how his engine is doing. Jim Sears in KY RV-6A N198JS ________________________________________________________________________________
Date: - - - , 20-
> I find it hard to believe that anything that is bolted to the engine >case really benefits from blast cooling. It seems to me that fuel >pumps, magnetos, and vacuum pumps will all be at the same >temperature as the engine case and a small blast tube could not >overcome the temp of of the entire mass. My Cheetah, which is very much like my RV inside the cowl, did not have any blast tubes. During my over nine years of ownership, the only problems I had was with some vapor locking when I let the hot engine sit for a few minutes and with my having to replace one vacuum pump. Everything else was just fine. I did have to replace the mags; but, they were the throw away Slicks that were supposed to last 800 hours. Mine lasted 1200 and 1400 hours. Not bad for throw aways. Oh, yeah. The battery and contacters were out there in the heat, too. The vacuum pump lasted well over 500 hours before it bit the dust. I consider that just fine for a dry one. My RV-6A has some blast tubes to the electric and mechanical fuel pumps to help slow down vapor locking. I've considered other blast tubes; but, I've not put any more on it. So far, no problems in 90 hours. That doesn't mean I won't. Jim Sears in KY ________________________________________________________________________________
Date: Apr 15, 2001
Subject: Re: Which kits to buy first
My opinion for what its worth. Order the standard way, especially if space is a factor. Tail parts first to hone your skills on cheaper parts. Then the Wing Kit. The wings, when finished are easier to store out of the way while building the fuselage. The fuselage takes up more space. Cecil Hatfield ________________________________________________________________________________
Date: Apr 15, 2001
From: Charlie and Tupper England <cengland(at)netdoor.com>
Subject: Re: Jabiru for RV9 ?
> -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of > Knicholas2(at)AOL.COM > Sent: Sunday, April 15, 2001 12:06 PM > To: rv-list(at)matronics.com > Subject: RV-List: Jabiru for RV9 ? > > > I have read with interest the comments on the Jabiru 120hp engine. My RV9 > (..finishing wings...) is slated for an O-235, 117 hp Lycoming. It sounds > like the (proven) Jabiru 120HP may be a good alternative without worrying > about the growing pains of the updoming 200hp. Comments? I tried to call > the U.S. dealer and he is at Fun & Sun - does anyone know the cost? > > Kim Nicholas > Seattle, WA > Bill VonDane wrote: > > > You should be able to get one for $12K or less, but please note: > > The 120hp rating is @ 3300rpm, it only produces 107hp @ 2750rpm... > > -Bill > This only means that you need to obtain a slightly shorter prop, cut for desired compromise of climb/cruise. Downside: probable slight loss in efficiency. Upside: increased ground clearance & likely a more reliable package than a 40 year old used Lyc. Charlie flying Lycosaur -4 ________________________________________________________________________________
Date: Apr 15, 2001
> >I am going to buy the Rv7 kit this June. I am planning on buying 2 kits >initially, and I was curious which was I should buy first. The empannage and >wing kit or the Emp and the fuselage. This is probably a stupid question, >but I couldn't find anything on Van's web page to help me out. Also does >anyone have the actual dimensions so that I can compare the cockpits width >with the RV6. > >Jimmy Arnold > Jimmy, I understand the RV-7 wings are similar or identical to the RV-8 wings. The RV-8 wing spars are match drilled to the carry through structure that is part of one of the fuselage bulkheads. So, the main part of one of the fuselage bulkheads is sent with the wing kit, to keep the carry through structure matched up with the wing spars. On the RV-8, you can't do too much on the fuselage kit unless you have received the wing kit. Vans can tell you whether the above is also true on the RV-7, but I would bet a case of beer that it was (Canadian or British beer only please - "American beer" is an oxymoron ;-) -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Date: Apr 15, 2001
Buy the tail kit first! Unless you have allllllllllllllllll the tools, I'd save my $ for numerous tools that you never thought you would have needed. There are plenty of builders that start the tail, some finish, some do not, THATS when you will really decide if you want to continue. Bob ________________________________________________________________________________
Date: Apr 15, 2001
Jim Sears wrote: > > > Thanks for the report on the 13B. I've watched these folks for a long > time and haven't given much thought to putting one on my airplane > for two reasons. There has been no cookbook produced with parts > to go with it, that I know of. That makes each installation an > experiment. Each installation I saw at Sun-n-Fun was different. I'm > pretty sure that most of us don't want to get into an experiment with > the engine while building our first kits. Secondly, the ones I've seen > usually have an exhaust that looks awful! We go to the trouble to > build a nice airplane only to hang an exhaust under it that extends > well past the cowl. While I appreciate what these guys are doing, > I've decided it isn't the choice for me. > > BTW, Pat and I were listening to a conversation between one of the > owners and a builder. The fuel consumption on his 13B is about > 4gal/hour at idle to 14 gal/hour at full power. I'm not sure if that's > good or bad. Just a number I heard. > > Jim Sears in KY > RV-6A N198JS > Hi Jim, Was that 4 gph at idle, or at 'economy' cruise? 14 gph at .55 lb per HP/hr is about 150 hp. I'll bet that a Lyc data sheet will say just about the same fuel burn for an O320 at full power. Was that at sea level or full throttle at 8000 ft (75%)? Most of the rotary's legendary poor fuel economy is at the very low power settings used in autos. Tracy Crook (the RV-4) has flown his for around 1000 hrs. He can fly with 180hp -4's with almost identical fuel burn, & his plane is probably 'dirtier' than most -4's which really hurts when you are in the 200 mph speed range. Those long exhaust pipes actually look about like the 'swiss muffler' that is very common in Europe to meet noise standards over there. Muffler design for the rotary in a/c is evolving rapidly now, & that issue may go away soon. I agree that the engine installation will be more difficult, but to me, there is a lot of frustration flying with a 40 year old engine (70 year old technology) using a farm tractor carb & ignition. I'm not going to dismantle my flying a/c to install one, but when I build, I'd love to try it. Charlie flying Lycosaur -4 ________________________________________________________________________________
Subject: Inclination on fuel pump
Date: Apr 15, 2001
Facet/Purolator only recommends mounting with the outlet higher than the inlet to aid in purging vapor. There is no specific angle specified. If you want to contact the manufacturer for specific recommendations here is a link: http://www.facet-purolator.com/connect.htm However, do not mention that it is for an airplane as they do not condone the use of their pumps in aircraft due to liability concerns. Chris Heitman Former Facet Distributor RV-9A N94ME (reserved) Canopy http://www.execpc.com/~cjh/rv9a.html -----Original Message----- I believe that the FACET fuel pump that Van recommends and sells (p/n ES 40108) is a special case of requiring a specific orientation. Other pumps (even some different Facet models), do not have this requirement/limitation and can be mounted horizontally/vertically. Boyd Braem ________________________________________________________________________________
Date: Apr 15, 2001
Talking about Tracy, how does 6 GPH doing 170 mph TAS at 12,500' sound? That's what he's getting. Finn Charlie and Tupper England wrote: > Tracy Crook (the RV-4) has flown his for around 1000 hrs. He > can fly with 180hp -4's with almost identical fuel burn, & > his plane is probably 'dirtier' than most -4's which really > hurts when you are in the 200 mph speed range. NetZero Platinum No Banner Ads and Unlimited Access Sign Up Today - Only $9.95 per month! http://www.netzero.net ________________________________________________________________________________
Date: Apr 15, 2001
Subject: Re: RV-List: 4 rotary powered RV's at SnF > > Jim Sears wrote: > > > > > > Thanks for the report on the 13B. I've watched these folks for a long > > time and haven't given much thought to putting one on my airplane > > for two reasons. There has been no cookbook produced with parts > > to go with it, that I know of. That makes each installation an > > experiment. Each installation I saw at Sun-n-Fun was different. I'm > > pretty sure that most of us don't want to get into an experiment with > > the engine while building our first kits. Secondly, the ones I've seen > > usually have an exhaust that looks awful! We go to the trouble to > > build a nice airplane only to hang an exhaust under it that extends > > well past the cowl. While I appreciate what these guys are doing, > > I've decided it isn't the choice for me. > > > > BTW, Pat and I were listening to a conversation between one of the > > owners and a builder. The fuel consumption on his 13B is about > > 4gal/hour at idle to 14 gal/hour at full power. I'm not sure if that's > > good or bad. Just a number I heard. > > > > Jim Sears in KY > > RV-6A N198JS > > Hi Jim, Being one of the four rotaries at Sun & Fun (the blue/white and red RV-6A), I agree that there is as yet no "cook book" approach to installing one. However, the way we will eventually arrive at (or close to) a "best practices" approach is to try a number of different ways and then hopefully close on the best way. We are all sharing our results with others so they can move further toward this goal than we have. At this stage, I would agree that this is not for everyone as you must be willing to experiment and redo. Certainly there is a degree of risk, just as there is with any engine - including Lycomings. We are convinced that the engine itself presents very little risk, the rotary is inherently more reliable than any reciprocating engine. The reason is there are no connecting rods, pinions, valves, valve springs, camshafts, and other things that can fail in a reciprocating engine and of course none of the inertial loads of pistons changing direction many times a second. However there is risk, but it primarily lies in the auxiliary systems (fuel, coolant, oil, etc) that we each designed from scratch. I will be the first to say that if you want to fly, put a Lycoming in your bird and enjoy. If you like a technical challenge then this may be your cup of tea. Your comment about the installations all being different is certainly correct, although the underlying principles and concepts are probably closer than their implementation would indicate. Actually, the different installations actually show that any number of approaches will get you in the air, now we are trying to nail down the "optimum" approaches and practices so those that may want to follow will have it somewhat easier. As with any Lycoming powered RV, the performance depends on the airframe and propeller combination as much as anything. But Tracy Crooks Rotary Powered RV-4 (which is not as aerodynamic clean as it could be) will leave just about any 180 Lycoming powered RV in his tracks. My maximum calibrated True Air Speed to date is 192 MPH at 1656 lbs Gross weight, certainly not the fastest RV-6A, but respectable. Lastly, I agree that the current mufflers you saw are ugly - although I am trying a variation on the "Swiss" muffler that hopefully will not be as bad. But once again we four at Sun & Fun have agree to take different approaches to see which one comes closest to the idea of a light weight, effective sound reduction and without hurting performance more than necessary. We have certainly found some approaches that did not work but others look more promising. For your information, there is one firm that is producing FWF rotary engine installations specifically for the RV and that is PowerSport. However, at the moment their installation is a bit pricey in my opinion. For that reason, most who want a rotary powered bird will have to roll their own for the time being. But anyone who is interested can check their web site at http://www.powersportaviation.com/ Tracy Crook's site is filled with information about rotary engines and also products if you want to roll your own at http://www.rotaryaviation.com/ To my knowledge, there are 8 RVs flying with rotary engines at the current time with approx 12 more RV projects with rotary engines in various stages including several 3 rotor engines in RV-8s. Rotary engines are also flying in Long EZs, Cozys, Velocities, GlasStars, Coots, and one in a Grumman Tiger as well as other airframes. This is what experimental aircraft building is all about. You can draw your line wherever you want to. Most folks will draw the line at an experimental aircraft with a certified engine and some of us have the inclination to push the line a bit further. Best Regards Ed Anderson RV-6A N494BW Rotary Powered Matthews, NC ________________________________________________________________________________
Date: Apr 15, 2001
In a message dated 4/15/01 1:22:59 PM Eastern Daylight Time, edwisch(at)alum.mit.edu writes: > . > > Frankly, if the font has good contrast and clarity, you're probably okay > either way. My pet bugaboos: > * long rows of switches where you can't easily find what you want. Group > switches to no more than 5 in a group > * important switches (like fuel pump) that aren't easily found. Put 'em > on the end > * inappropriate switches (turn & bank on/off toggle switches, for instance) > * mixing important and unimportant switches (fuel pump or master switch > buried in a row of lights) > > Lots of folks don't think human factors are important, and they're often > right. When they're wrong, though, the evidence is frequently bent metal. > > Ed "now looking at human factors professionally" Wischmeyer Building on the human factors theme: Determine which is likely to be your "free" hand. For most side by side folks, it'll be your right hand (you ALWAYS need a hand on the stick, but there are plenty of times when your throttle hand is free for other tasks). For everyone else, your left hand is the free one. Place the switches you're most likely to use in flight, or those that you may need to get to RIGHT NOW in the easiest to reach location for your "free" hand. In my case, I deemed that the fuel pump, trim servo kill, and landing light switches are the ones I'd need easy access to during flight (and especially in the pattern). If you have a panel located trim switch, it should also be easy to reach with the probable free hand. Like Ed said, group the switches, with the critical ones in locations which makes them easiest to find by braille. Any other switches (mags, starter, primer, internal and external lights, etc...) need to be logically organized. In my case, I've got the master, starter, primer, and ignition systems in a group, with lights in another group. If you can locate switches to the throttle quadrant or the control stick, that's a huge bonus, because you don't have to turn loose of anything to operate the switches or flight controls. Obvious candidates are transmit, trim, and flaps, but the more you can add, the better, within reason. One thing you should absolutely try to avoid is cross handed operation. You do not want to have to reach across your body to operate a switch, nor is it good to have to switch hands on the stick to operate a switch. It can be difficult to avoid these problems entirely, but you should not accept them on flight critical items (fill in your list of flight critical switches here). A final thing to consider is dexterity. If you really, really, need to use your dominant hand to operate those little buttons and switches on your radio, you might as well locate the radio near your dominant hand. Operating a radio in turbulence can be tough even with your "better" hand, and may be impossible with your non-dominant hand. Kyle Boatright - Kennesaw, GA RV-6 Slider, O-320/Aymar-Demuth ________________________________________________________________________________
Date: Apr 15, 2001
Subject: Non certified Engines
I am struck with an impression of several people I know having off airport landings and spending a lot more time working on airplanes than flying. ________________________________________________________________________________
Date: Apr 15, 2001
Subject: Re: Looking for ride//Oshkosh
--- I am looking for ride to Oshkosh from the Phoenix Area. Please contact me off line at azduke(at)yahoo.com rv-9a n944wh(reserved) working on horiz. stab > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ==== J. WAYNE HENNESSEY 12212 NORTH PARADISE VILLEGE PKWY #207C PHOENIX, ARIZONA 85032 602-992-8286 --------------------------------------------------- HAVE A NICE DAY ________________________________________________________________________________
Date: Apr 15, 2001
From: Gary and Carolyn Zilik <zilik(at)bewellnet.com>
Subject: Re: Inclination on fuel pump
I must disagree on this one. The facet pump I installed supplied by Van's stated in the instructions that it was very important to mount it at a 45 degree angle. No reason given but I followed the manufacture's instructions. Gary Zilik mdelano wrote: > > The angle of the fuel pump makes no difference. Do not reposition it. I > have an identical pump on my Long EZ. The pump fittings are level with > the wings and mounts on the firewall. Works great. These pumps are used > on many homebuilt A/C and were designed for automobiles. The auto > manufactures mount them in any attitude that is convenient to there > instillation. > > Mark Delano > Tech. Councilor > 6A Finish > ________________________________________________________________________________
Date: Apr 15, 2001
> . This is probably a stupid question, > but I couldn't find anything on Van's web page to help me out. There telephone number is on their web page. ________________________________________________________________________________
Date: Apr 15, 2001
Subject: Non certified engines
Allen Tolle got real good at forced landings in a rotary Wankel RV3 and another gentleman damaged a V 6 3.8 liter Ford powered RV6 in Fresno.I really admire these people for daring to launch out try to do something good for general aviation. ________________________________________________________________________________
Date: Apr 17, 2001
When I was installing my pump I called the manufacurer with this question. They told me if mounted flat, it would significantly reduce the life of the pump. Apparently the piston naturally rotates if installed between 45 and 90 degrees to horizontal, but will tend to remain in the same orientation and wear unevenly if installed flat. Randall Henderson, RV-6 N6R (~200 hrs) Portland, OR www.vanshomewing.org ________________________________________________________________________________
Date: Apr 16, 2001
Subject: kit sequence
I am going to buy the Rv7 kit this June. I am planning on buying 2 kits initially, and I was curious which was I should buy first. The empannage and wing kit or the Emp and the fuselage. This is probably a stupid question, but I couldn't find anything on Van's web page to help me out. Also does anyone have the actual dimensions so that I can compare the cockpits width with the RV6. Jimmy Arnold I agree with Cecil, Kevin and Bob, for the same reasons, but also for another reason... The wing kit comes with the fuselage longerons included, since the wing packaging fits those pieces better. If you order the fuse first, they'd have to separately ship the longerons to you. Ed Winne RV-9A wings Palmyra PA ________________________________________________________________________________
From: "Nancy Jean Burkholder" <nancyb(at)mninter.net>
Subject: Re: RV6-List: Westach fuel level system
Date: Apr 16, 2001
--> RV6-List message posted by: "Shirley Harding" >>Any feedback on performance of Westach products? I used Westach products on an ultralight I owned back in '95. I had a dual CHT/EGT. I had no complaints about their performance. However, I wouldn't put them in my RV. That's my personal preference. I don't think I would have the confidence in them that I would have in the other aviation gages that are going to populate my panel. They were fine for my ultralight, but I will be using my RV for way more demanding missions, and for that I am willing to pay for a higher grade of instruments. nancy b. "Good people are always so sure they're right." Barbara Graham's last words Executed June 5, 1955 at San Quentin ________________________________________________________________________________
Subject: Incredible paint job (flames) on the new RV of the Week
Date: Apr 16, 2001
Thread-Topic: RV-List: rv-8 video Thread-Index: AcDFwHx4OlUreDC7EdWALQAIxwleHwAr1Wgg
From: "Reeves, Doug" <Douglas.Reeves(at)archongroup.com>
Mike Knight sent me both a picture and the specifics of his newly completed and painted 200hp RV-6. If you're in need of some new wallpaper for your monitor you might want to see this. Go to www.vansaircraft.net and click on 'RV of the Week'. Regards, Doug Reeves ________________________________________________________________________________
Subject: Polished aluminum
Date: Apr 16, 2001
Anyone know of any photos on the WWW of a RV-6A finished in polished aluminum? Steve Soule soundproofing the floor of the RV-6A ________________________________________________________________________________
From: "skybolt-aviator" <skybolt-aviator(at)msn.com>
Date: Apr 16, 2001
----- Original Message ----- From: "jra" <j_arnold(at)swbell.net> Sent: Sunday, April 15, 2001 5:54 PM Subject: RV-List: Which kits to buy first I asked Van at S & F if the 7 was wider and his answer was ,they are same width.The7 has 2" more cockpit length. Ollie&Lorene Washburn RV6-A,N795LW,@FD77. O-360,180HP,C/S,300+hrs. ________________________________________________________________________________
Date: Apr 16, 2001
Subject: Re: Polished aluminum
In a message dated 4/16/01 8:24:03 AM Central Daylight Time, SSoule(at)pfclaw.com writes: << Anyone know of any photos on the WWW of a RV-6A finished in polished aluminum? >> Look in the photos here for a nice one: Yahoo! Groups : RV-6and6A Files Eric Newton - Long Beach, Mississippi RV-6A N57ME (Reserved) (Finish Kit) http://www.ericsrv6a.com ________________________________________________________________________________
Date: Apr 16, 2001
In a message dated 4/16/01 9:17:25 AM Central Daylight Time, ENewton57(at)AOL.COM writes: << << Anyone know of any photos on the WWW of a RV-6A finished in polished aluminum? >> Look in the photos here for a nice one: Yahoo! Groups : RV-6and6A Files >> Sorry I forgot to say - click on the April 2000 Minnesota Fly-in and scroll down to find it. Eric Newton - Long Beach, Mississippi RV-6A N57ME (Reserved) (Finish Kit) http://www.ericsrv6a.com ________________________________________________________________________________
Date: Apr 16, 2001
> > > > I have read with interest the comments on the Jabiru 120hp engine. My RV9 > > (..finishing wings...) is slated for an O-235, 117 hp Lycoming. It > sounds > > like the (proven) Jabiru 120HP may be a good alternative without worrying > > about the growing pains of the updoming 200hp. Comments? I tried to call > > the U.S. dealer and he is at Fun & Sun - does anyone know the cost? > > > > Kim Nicholas > > Seattle, WA > > > Bill VonDane wrote: > > > > > > You should be able to get one for $12K or less, but please note: > > > > The 120hp rating is @ 3300rpm, it only produces 107hp @ 2750rpm... > > > > -Bill > > > > This only means that you need to obtain a slightly shorter > prop, cut for desired compromise of climb/cruise. Downside: > probable slight loss in efficiency. Upside: increased ground > clearance & likely a more reliable package than a 40 year > old used Lyc. > > Charlie > flying Lycosaur -4 It also means building your own engine mount, nose gear, cowling, and engineering the same to deal with weight difference and CG issues. On the other hand, you will have no problem finding a low time O-235 for half the price of the Jab. Kevin -9A finishing ________________________________________________________________________________
Date: Apr 16, 2001
Subject: Raleigh, NC visit
Hi Folks, Heading out to Raleigh tomorrow night for a week of work-related meetings at RTP. Staying at the airport Hilton. Will be there Wed, Thurs nights, available to buck or drive rivets or just gab. Last time I was out there I meandered around the airport (Raleigh-Durham) but found no general aviation. At what other airports around there do the RV's hang out? Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward (Yippee!!) ________________________________________________________________________________
From: "Jones, Bryan D." <bryan.jones@lyondell-citgo.com>
Subject: Voltage Issue
Date: Apr 16, 2001
On the way back from Sun N Fun, my system voltage started going high. The plane has been flying for a year with 150+ hrs with no similar problems prior to this. I have Van's alternator and fixed regulator. Battery is a Concord 22 amp-hr. Question 1 - Can a bad battery cause the symptoms of a bad voltage regulator? Question 2 - Anyone know of a good source for an automotive voltage regulator (car make, model and year)? Yes, I've got Mr. Bob's book and I've checked the archives. Anyone having experience with these issues, please help out. Thanks Bryan Jones -8 765BJ Pearland, Texas ________________________________________________________________________________
Date: Apr 16, 2001
Subject: Re: Incredible paint job (flames) on the new RV of the Week
I saw Mike's airplane at Sun-n-Fun. It is a fabulous paint job, very well executed and applied. I think AVWEB also has a picture of it in their coverage of the event. Randy Pflanzer N417G RV-6 (142 hours) > >Mike Knight sent me both a picture and the specifics of his newly >completed and painted 200hp RV-6. If you're in need of some new >wallpaper for your monitor you might want to see this. > >Go to www.vansaircraft.net and click on 'RV of the Week'. > >Regards, >Doug Reeves > > ________________________________________________________________________________
Date: Apr 16, 2001
Subject: Re: Voltage Issue
For a regulator, get a mid 70's Ford regulator, exact year is not a problem. Sam Buchanan (RV-6) "The RV Journal" http://home.hiwaay.net/~sbuc/journal ========================= "Jones, Bryan D." wrote: > > > On the way back from Sun N Fun, my system voltage started going high. The > plane has been flying for a year with 150+ hrs with no similar problems > prior to this. I have Van's alternator and fixed regulator. Battery is a > Concord 22 amp-hr. > > Question 1 - Can a bad battery cause the symptoms of a bad voltage > regulator? > > Question 2 - Anyone know of a good source for an automotive voltage > regulator (car make, model and year)? > > Yes, I've got Mr. Bob's book and I've checked the archives. Anyone having > experience with these issues, please help out. > > Thanks > > Bryan Jones -8 765BJ > Pearland, Texas ________________________________________________________________________________
Subject: Re: Non certified engines
Date: Apr 16, 2001
----- Original Message ----- From: "BOBE." <RVPilot4(at)webtv.net> Sent: Sunday, April 15, 2001 11:31 PM Subject: RV-List: Non certified engines > > Allen Tolle got real good at forced landings in a rotary Wankel RV3 and > another gentleman damaged a V 6 3.8 liter Ford powered RV6 in Fresno.I > really admire these people for daring to launch out try to do something > good for general aviation. > > I stand corrected. Allen Tolle did indeed have to make a force landing after damaging a gear box bearing with his nitrous oxide boosted Wankle powered RV-3. The engine was up to the additional stress of boosted HP but not the gear box. Ed Anderson ________________________________________________________________________________
Subject: Re: Non certified Engines
Date: Apr 16, 2001
----- Original Message ----- From: "BOBE." <RVPilot4(at)webtv.net> Sent: Sunday, April 15, 2001 10:55 PM Subject: RV-List: Non certified Engines > > I am struck with an impression of several people I know having off > airport landings and spending a lot more time working on airplanes than > flying. > I am unaware of any rotary powered aircraft making an off airport landing with the exception of a "Coot" aircraft which did have to land on water due to a thrust bearing failure. This was attributed to the gear box which had no thrust bearing and therefore put excessive thrust loads on the engine thrust bearing. Lycoming power aircraft of course make more off-airport landing than any other power plant simply because their are many more aircraft powered by Lycomings. Yet, most folks would not hesitate to put a Lycoming in their aircraft. Just as in any installation with a Lycoming, any auto conversion success is to a great deal dependent on the thoughtfulness and quality of the installation. Certainly, I am not advocating that anyone give up their Lycoming for auto power, it is simply not for everyone. Fortunately we have the choice to power our experimental aircraft with a variety of power plants. Best Regards Ed Anderson ________________________________________________________________________________
Subject: Prop Balancer
Date: Apr 16, 2001
I am interested in a prop balancer for my RV-4 with a wooden prop if any one has one they would be interested in selling. If not where do I find a new one? Thanks, Jim Baker N513J ________________________________________________________________________________
Date: Apr 16, 2001
Subject: Re: Prop Balancer
I have Mark Landoll's silicon filled 12 pound harmonic balancer on wood prop RV4.It works real good. His address is 1205 Rosebud Lane Newcastle Ok. 73065 Phone (405)392-3847 ________________________________________________________________________________
Date: Apr 16, 2001
Mark Landoll sells a voltage regulator and an over voltage diode with very clear hookup directions at very compeditive prices. ________________________________________________________________________________
Date: Apr 16, 2001
Subject: Re: Raleigh, NC visit
If you ever get to Charlotte, NC look me up. Always a place for a spare bucker and we have a small airport where locals hangout and do a lot of hanger flying and lying. Earl Fortner, RV4 Mike Thompson wrote: > > Hi Folks, > > Heading out to Raleigh tomorrow night for a week of work-related > meetings at RTP. Staying at the airport Hilton. > > Will be there Wed, Thurs nights, available to buck or drive rivets or > just gab. > > Last time I was out there I meandered around the airport > (Raleigh-Durham) but found no general aviation. At what other airports > around there do the RV's hang out? > > Mike Thompson > Austin, TX > -6 N140RV (Reserved) > Firewall Forward (Yippee!!) > ________________________________________________________________________________
Subject: Executive Hangar, Denver CO
Date: Apr 16, 2001
Any one interested in sharing a beautiful executive hangar at Front Range Airport near Denver CO? Bathroom, tools, very nice! ________________________________________________________________________________
Subject: Fiberglassing Cowl Hinges...destructive test results
Date: Apr 16, 2001
I just had the opportunity to drill out the hinges that hold the two halves of the canopy together and thus do a destructive test of the practice of bedding the hinges in fiberglass mat. The results......it did very little.....doing it like I did. After drilling the rivets out, the hinge separated from the fiberglass with little resistance. The mat firmly bonded to the cowl This is how I did it. Sanded the cowl and hinge Drilled 3/16" holes in the hinge between the rivet holes so the fiberglass could squeeze through Used two thickness' of fiberglass mat Used West System epoxy resin When I riveted the hinges on, little to no mat came through the holes I drilled for that purpose. I am reinstalling the hinges and am doing the following Sanded the cowl and hinge Drilled 3/16" holes in the hinge between the rivet holes so the fiberglass could squeeze through Used three thickness' of fiberglass mat Used polyester resin Put down a layer of resin/microballon/thickener under the hinge After riveting, covered the hinge with the same resin/microballon/thickener I switched to polyester resin because I heard somewhere that the mat may not be broken down as well using epoxy resin I used the microballon paste to get some bonding through the 3/16 holes I drilled. I hope I won't have to do another destructive test. I hope it does something because it sure is a pain riveting over fiberglass!!!! Now, for those inquiring minds that just have to know......the reason I had to tear out my hinges is that I installed them with the wrong angle. I have one of the last of the OLD cowls and didn't have the instructions for tilting the hinge to get the zipper effect. I did the zipper thing not thinking that it mattered which way the zipper went. I had it so the hinge eyes extended down from the aft of top cowl and then hidden at the front of the top cowl.....wrong! I couldn't get the top cowl back on after I riveted the side hinges on. Once I saw how the geometry of the thing works, I realized that the hinge eyes need to be switched so the eyes are hidden at the aft of the top cowl and then exposed at the front of the top cowl. Now you know. Ross 6A....if I only had to build it once, I'd be done!!!! ________________________________________________________________________________
Date: Apr 16, 2001
Subject: Re: Question re: machine screw sizes
In a message dated Sat, 14 Apr 2001 10:44:11 PM Eastern Daylight Time, "Cy Galley" writes: # 10 comes from the size of a # 10 number drill and is NOT decimal. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh ----- Original Message ----- From: <Bobpaulo(at)AOL.COM> Sent: Saturday, April 14, 2001 8:10 PM Subject: Re: RV-List: Question re: machine screw sizes > > The first no. is the hole size. Each number is referrs to a hole size in > decimals and NOT parts of an inche! If you have a Cleveland or Avery Cat it > will show you exactly what numbers are equal to in decimals. All that > (decimals) really does not matter as long as you know that the first number > is the hole size. The last number is the threads per inch-double check me on > the last number. Bob > > The screw size has nothing to do with the drill size. A #10 screw (.190") could go in a #10 drilled hole (.1935") but only by chance. A #4 screw (.112" dia) certainly wouldn't go properly in a #4 drilled hole (.209"). The numbering of screws starts at .060" = 0 (0-80 are often used as the pivot screw in the temples of spectacles). Add .013" to this for each screw size up to #12 (.216") for the major diameter of the thread form. For example a #8 would be (.013"*8)+.060" = .164" -GV >> ________________________________________________________________________________
Date: Apr 16, 2001
In a message dated Sun, 15 Apr 2001 9:20:48 AM Eastern Daylight Time, bert murillo writes: Hi: One of the builders came to see my project some weeks ago, and call attention to the fact that my auxiliary fuel pump did not have the angle of inclina tion that should have, according to him. Mine is about 5 degrees) he said is very important to have about 45o or so. NOw my question is, how I would cover the holes on the fuselage (4) Any one have had that problem? >> Just make an adapter bracket out of .125" thick stock and use it as an interposer between the pump and the side of the plane. Countersink the screws that attach to the pump and it will rest flat against the inside of the fuse. -GV ________________________________________________________________________________
Date: Apr 16, 2001
In a message dated Mon, 16 Apr 2001 11:24:37 AM Eastern Daylight Time, "Jones, Bryan D." <bryan.jones@lyondell-citgo.com> writes: On the way back from Sun N Fun, my system voltage started going high. The plane has been flying for a year with 150+ hrs with no similar problems prior to this. I have Van's alternator and fixed regulator. Battery is a Concord 22 amp-hr. Question 1 - Can a bad battery cause the symptoms of a bad voltage regulator? Question 2 - Anyone know of a good source for an automotive voltage regulator (car make, model and year)? >> Get a B&C regulator and quit worrying. -GV ________________________________________________________________________________
Date: Apr 16, 2001
If you're new to sheet metal work, you'll want to start with the emp since a mistake won't be all that costly. While I hope you don't actually make a mistake, it's always possible while you get the hang of the various construction techniques. For that matter it's possible any time, but you get my drift. Next you'll need the wing kit before the fuse kit since some of the fuse parts come in the wing kit, namely the longerons and the main bulkhead, the one that mates with the wing spars. This bulkhead is matched to the wing spars and has so has to be shipped with the wings. You'll not get very far on the fuse without these parts. Then it's fuse and finishing kit. I ordered both at the same time since assembling same together made more sense to me. For example, getting the fuse on it's wheels as soon as possible so can move it around the hanger more easily, even before the tail has been attached. Oh, and before the replies start flying, yes I know, I'll have a balance problem if the engine isn't on there. Got a plan there :-). Have fun and good luck. Ted jra wrote: > > I am going to buy the Rv7 kit this June. I am planning on buying 2 kits > initially, and I was curious which was I should buy first. The empannage and > wing kit or the Emp and the fuselage. This is probably a stupid question, > but I couldn't find anything on Van's web page to help me out. Also does > anyone have the actual dimensions so that I can compare the cockpits width > with the RV6. > > Jimmy Arnold > -- Ted Cross (N0IAK & G0HHY) n0iak(at)qsl.net n0iak(at)amsat.org ICQ: 16040894 N293TC (reserved) RV9A - Wings ________________________________________________________________________________
Date: Apr 16, 2001
Subject: Re: kit sequence
As an aside to the other comments. I purchased the wing first since I had already built a tail and part of the wing for an RV-6. thought I would jump in and build the RV-9 wing and go back to the tail later. There are references to certain drawings and procedures in the wing instructions that assume you already have the tail kit and drawings. Mostly around how to do the trailing edge pieces and instructions apparently located on drawing #5 that comes only with the tail kit. Not a big deal since I could imagine what was being referred to, but an indication that Vans kind of expects you to go in order. Their recent completion of the full preview plans would alleviate the item that I had I would expect. In any case, I'll probably order the tail next. Curt Hoffman Loveland, OH RV-9A (N912WK reserved) Working on Wing ________________________________________________________________________________
Subject: Aileron/gap fairing interference
Date: Apr 17, 2001
Listers, After a search of the archives, I didn't find an answer to this particular problem, so here goes: I laid my gap fairing in place and the aileron rubs on it. After riveting, will the gap fairing tighten up to the rear spar and leave room for the aileron to move? If I rivet the bottom side of the fairing to the rear spar and drill the top side to the skin and it still interferes, will I be able to adjust the fairing? Am I being obsessive (again)? I haven't seen anything related to this issue, so maybe it will be fine once it's riveted in place (hope, hope). As usual, many thanks in advance for all the great help I've been getting here. Jim Bower St. Louis, MO RV-6A N143DJ Wings ________________________________________________________________________________
Date: Apr 16, 2001
You are correct about the screw sizes and drill sizes. They don't correspond but they aren't decimal either. Mea culpa! Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh ----- Original Message ----- From: <Vanremog(at)AOL.COM> Sent: Monday, April 16, 2001 8:08 PM Subject: Re: RV-List: Question re: machine screw sizes > > In a message dated Sat, 14 Apr 2001 10:44:11 PM Eastern Daylight Time, "Cy Galley" writes: > > > # 10 comes from the size of a # 10 number drill and is NOT decimal. > > Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh > > ----- Original Message ----- > From: <Bobpaulo(at)AOL.COM> > To: > Sent: Saturday, April 14, 2001 8:10 PM > Subject: Re: RV-List: Question re: machine screw sizes > > > > > > The first no. is the hole size. Each number is referrs to a hole size in > > decimals and NOT parts of an inche! If you have a Cleveland or Avery Cat > it > > will show you exactly what numbers are equal to in decimals. All that > > (decimals) really does not matter as long as you know that the first > number > > is the hole size. The last number is the threads per inch-double check me > on > > the last number. Bob > > > > > > The screw size has nothing to do with the drill size. A #10 screw (.190") could go in a #10 drilled hole (.1935") but only by chance. A #4 screw (.112" dia) certainly wouldn't go properly in a #4 drilled hole (.209"). The numbering of screws starts at .060" = 0 (0-80 are often used as the pivot screw in the temples of spectacles). Add .013" to this for each screw size up to #12 (.216") for the major diameter of the thread form. > > For example a #8 would be (.013"*8)+.060" = .164" > > -GV > > > >> > > ________________________________________________________________________________
Subject: Re: Aileron/gap fairing interference
Date: Apr 16, 2001
Jim, On my -6A, I had to trim the top flange f the fairing, where it goes under the top skin, quite a bit, over 1". It seems to me there is a drawing about this and you have to compute the dimension to make the spacing correct for your wing. I think Van's calls for 1/4" clearance between the aileron and the fairing. You should refer to Frank Justice's notes about this, or search the Archives. Marty in Brentwood, TN Good Luck. ----- Original Message ----- From: "Jim Bower" <rvbuilder(at)hotmail.com> Sent: Monday, April 16, 2001 9:36 PM Subject: RV-List: Aileron/gap fairing interference > > Listers, > > After a search of the archives, I didn't find an answer to this particular > problem, so here goes: I laid my gap fairing in place and the aileron rubs > on it. After riveting, will the gap fairing tighten up to the rear spar and > leave room for the aileron to move? If I rivet the bottom side of the > fairing to the rear spar and drill the top side to the skin and it still > interferes, will I be able to adjust the fairing? Am I being obsessive > (again)? I haven't seen anything related to this issue, so maybe it will be > fine once it's riveted in place (hope, hope). > > As usual, many thanks in advance for all the great help I've been getting > here. > > > Jim Bower > St. Louis, MO > RV-6A N143DJ > Wings > > ________________________________________________________________________________
Date: Apr 17, 2001
Perhaps my expaination was not clear. All it takes is looking at set of numbered... and one can see what I was re: to. Bob ________________________________________________________________________________
From: "Daniel Estrada F." <dani_estrada(at)infosel.net.mx>
Subject: Electric Elev. Servo..
Date: Apr 16, 2001
Hi every body: Today I have recieved my electric serrvo for my elevator, but I have a doubt: Is the 8A mac servo ok for the RV7A..? thanks Daniel Estrada Mexico City ________________________________________________________________________________
Date: Apr 18, 2001
I have the Westach dual fuel gauge. I'm using it with the standard SW float senders. I think you need to order a different model of gauge if you get the capacitance senders. At any rate, the thing has worked okay for me although it has occasionally gone flakey on one tank (jumps between E and the correct level) athough this could have just been some crud on the sender or a bad ground -- not really sure. It hasn't done that for a while anyway. I mainly use it as a "leak detector" anyway since I always check the tanks visually plus I have a Matronics FUEL SCAN fuel computer (great device BTW). I am looking forward to trying out Mitch Robbins' dual digital fuel gauge that he has under development. He posted something about it a while back but apparently is still working on it. Randall Henderson, RV-6 N6R (~200 hrs) Portland, OR www.vanshomewing.org ________________________________________________________________________________
Subject: Re: Fiberglassing Cowl Hinges...destructive test results
Date: Apr 18, 2001
Microbaloons makes a lousy filler for anything but thin, cosmetic applications, where the item is not subject to flexing. It will make the resin weaker not stronger, and should not be used as a bonding agent IMHO. Instead use milled glass or at the very least, cotton flox. Either one will make more of a structural bond. If you bond your hinges with a slurry of milled glass fibers and squeeze that stuff through holes in the hinges I'll bet you won't be able to get it off. Also, when you say you sanded the hinges, do you mean you really SANDED them? I mean, with 80 or even 60 grit? That's what it takes to make the stuff really bond with aluminum. Randall Henderson, RV-6 N6R (~200 hrs) Portland, OR www.vanshomewing.org ________________________________________________________________________________
Date: Apr 17, 2001
> Instead use milled glass or at the very least, I did add some milled fiberglass as well > Also, when you say you sanded the hinges, do you mean you really SANDED > them? I mean, with 80 or even 60 grit? That's what it takes to make the > stuff really bond with aluminum. Yes ________________________________________________________________________________
Date: Apr 17, 2001
Subject: Re: Electric Elev. Servo..
> > >Hi every body: > >Today I have recieved my electric serrvo for my elevator, but I have a >doubt: > >Is the 8A mac servo ok for the RV7A..? > >thanks > >Daniel Estrada >Mexico City Hola Daniel, I just looked at the elevator trim system for my RV-8, and it uses the 8A servo. The elevators for the -4, -6 and -8 are very similar, and I believe the -7 also. So, I believe you will be fine with that servo. -- Kevin Horton RV-8 (mounting wings) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Date: Apr 17, 2001
Subject: polyester over epoxy
Mickey: A couple suggestions re your plan. Firstly, polyester does not bond well to epoxy. If you want to go to polyester, get the epoxy off. As an alternative, West System makes another epoxy which is formulated for wetting and bonding glass. It is a little nastier than the normal WEST stuff, so wear gloves, but it is superior to use. Secondly, microbaloons are not a very strong filler. Milled glass fiber or colloidal silica will form a much stronger fill. Milled polyester fiber is also stronger than microbaloons, but not as strong as the above. The compromise is that they are heavier and harder to sand. This application requires more strength. Gougeon Brothers, the West guys, are a good source for this stuff as well. It sounds like a report of stuff done rather than a plan. Hope it works for you. Ken Smith Old RV6 kit sitting idle. Plainfield, IL From: "Ross Mickey" <rmickey(at)ix.netcom.com> Subject: RV-List: Fiberglassing Cowl Hinges...destructive test results I am reinstalling the hinges and am doing the following Sanded the cowl and hinge Drilled 3/16" holes in the hinge between the rivet holes so the fiberglass could squeeze through Used three thickness' of fiberglass mat Used polyester resin Put down a layer of resin/microballon/thickener under the hinge After riveting, covered the hinge with the same resin/microballon/thickener I switched to polyester resin because I heard somewhere that the mat may not be broken down as well using epoxy resin I used the microballon paste to get some bonding through the 3/16 holes I drilled. ________________________________________________________________________________
Date: Apr 17, 2001
04/17/2001 08:29:59 AM BTW, thats a hand made cowling. It has an angle valve IO-360 in it and he totally built a plug around his engine and used a finished one piece cowl to act as a male plug to build his actual cowl. Mike is a real glutton for punishment but he sure pulled it out. By the way, if anyone needa a 220HP angle valve like Mikes there is a 0 time rebuild with accessorys in S. Fla. Its been rebuilt by my favorite local engine guy who has a great rep. He wants $20,000 for the engine. Call Mark @ Tropic Air Power 561-964-8870 Eric "Reeves, Doug" (at)matronics.com on 04/16/2001 08:27:02 AM Please respond to rv-list(at)matronics.com Sent by: owner-rv-list-server(at)matronics.com cc: Subject: RV-List: Incredible paint job (flames) on the new RV of the Week Mike Knight sent me both a picture and the specifics of his newly completed and painted 200hp RV-6. If you're in need of some new wallpaper for your monitor you might want to see this. Go to www.vansaircraft.net and click on 'RV of the Week'. Regards, Doug Reeves ________________________________________________________________________________
Date: Apr 17, 2001
17, 2001) at 04/17/2001 08:42:23 AM It sounds like the failure you describe is an adhesive failure (as opposed to a cohesive failure). The bond failed at the interface between the resin and the aluminum. (A cohesive failure is the structural failure of one of the adherends, not the bond interface.) Assuming this is the case, adding fillers to the resin, structural or otherwise, will not improve the performance of the bond. In general, laminating resins such as West System resins are not recommended for structural bonding. Aircraft Spruce and others sell structural adhesives for these applications. I would recommend a paste-type adhesive to provide good gap filling qualities given the likely interface between hinge and cowl. Probably more important than the adhesive selection is the surface preparation. Sanding is good, but I like to precede sanding with a degreasing step. After degreasing and sanding, I acid-etch the metal parts with Metal Prep 79. After etching, it is critical to rinse, dry, and bond the parts in rapid succession. A freshly etched surface is very good for bonding, but it is not stable in air. It will quickly oxidize which will result in a poor quality bond. After rinsing parts, you can dry them quite quickly using kitchen oven or hair dryer/heat gun. Of course, as soon as a part has been degreased, it should be handled only with gloved hands. The aerospace industry had developed techniques for treating aluminum surfaces to provide good bond qualities and good shelf-stability so it is not necessary to make bonds immediately after preparing the surface. Unfortunately, these techniques are expensive and require nasty chemicals. Dean Pichon RV-4 Arlington, MA |--------+----------------------------------> | | "Ross Mickey" | | | | | | Sent by: | | | owner-rv-list-server@mat| | | ronics.com | | | | | | | | | 04/16/01 07:42 PM | | | Please respond to | | | rv-list | | | | |--------+----------------------------------> | | | To: | | cc: | | bcc: | | Subject: RV-List: Fiberglassing Cowl Hinges...destructive test results | I just had the opportunity to drill out the hinges that hold the two halves of the canopy together and thus do a destructive test of the practice of bedding the hinges in fiberglass mat. The results......it did very little.....doing it like I did. After drilling the rivets out, the hinge separated from the fiberglass with little resistance. The mat firmly bonded to the cowl This is how I did it. Sanded the cowl and hinge Drilled 3/16" holes in the hinge between the rivet holes so the fiberglass could squeeze through Used two thickness' of fiberglass mat Used West System epoxy resin When I riveted the hinges on, little to no mat came through the holes I drilled for that purpose. I am reinstalling the hinges and am doing the following Sanded the cowl and hinge Drilled 3/16" holes in the hinge between the rivet holes so the fiberglass could squeeze through Used three thickness' of fiberglass mat Used polyester resin Put down a layer of resin/microballon/thickener under the hinge After riveting, covered the hinge with the same resin/microballon/thickener I switched to polyester resin because I heard somewhere that the mat may not be broken down as well using epoxy resin I used the microballon paste to get some bonding through the 3/16 holes I drilled. I hope I won't have to do another destructive test. I hope it does something because it sure is a pain riveting over fiberglass!!!! Now, for those inquiring minds that just have to know......the reason I had to tear out my hinges is that I installed them with the wrong angle. I have one of the last of the OLD cowls and didn't have the instructions for tilting the hinge to get the zipper effect. I did the zipper thing not thinking that it mattered which way the zipper went. I had it so the hinge eyes extended down from the aft of top cowl and then hidden at the front of the top cowl.....wrong! I couldn't get the top cowl back on after I riveted the side hinges on. Once I saw how the geometry of the thing works, I realized that the hinge eyes need to be switched so the eyes are hidden at the aft of the top cowl and then exposed at the front of the top cowl. Now you know. Ross 6A....if I only had to build it once, I'd be done!!!! **** This message is from Arthur D. Little, Inc., and/or one of Arthur D. Little's subsidiaries or affiliates and may contain confidential business information. It is intended for the addressee only and may not be copied without our permission. If you are not the intended recipient please contact the sender as soon as possible.**** ________________________________________________________________________________
Date: Apr 17, 2001
Does the Landoll balancer require modification to the spinner? Does is require different prop bolts? Does it require modification to Van's prop extender? Steve Soule O-320 D1A and Aymar Demuth wood prop -----Original Message----- I have Mark Landoll's silicon filled 12 pound harmonic balancer on wood prop RV4.It works real good. His address is 1205 Rosebud Lane Newcastle Ok. 73065 Phone (405)392-3847 ________________________________________________________________________________
Subject: More incredible RV flame paint job pictures
Date: Apr 17, 2001
Thread-Topic: RV-List: Incredible paint job (flames) on the new RV of the Week Thread-Index: AcDG129OcisunjK8EdWALQAIxwleHwAZE+Lw
Yesterday I sent out an email about Mike Knight's newly painted 200hp RV-6 being the 'RV of the Week' on my site. Over 1,000 people viewed it yesterday. Through the course of the day yesterday, Mike sent me (5) more images from various angles (one of the interior). If you'd like to see them simply go to www.vansaircraft.net and click on 'RV of the Week'. Thanks and enjoy, Doug Reeves VAF-World Wide Wing ________________________________________________________________________________
From: "James Norman, MD" <jnorman(at)InterMapSystems.com>
Subject: Epoxy Cowl Hinge
Date: Apr 17, 2001
Has anybody tried the carbon fiber or fiberglass hinge made by B.G. Enterprises? It looks like it should work as good or better than trying to get the metal hinge to stick to the fiberglass cowl. Here is a web site... go ALMOST to the bottom of the page to see links to some pictures of the stuff, and a couple of PDF pages which describe the product well. http://www.flash.net/~infaero/ Anxious to see if anybody has used this yet. jim Tampa Getting ready for cowl hinges (first time) From: "Ross Mickey" <rmickey(at)ix.netcom.com> Subject: RV-List: Fiberglassing Cowl Hinges...destructive test results I am reinstalling the hinges and am doing the following Sanded the cowl and hinge Drilled 3/16" holes in the hinge between the rivet holes so the fiberglass could squeeze through Used three thickness' of fiberglass mat Used polyester resin Put down a layer of resin/microballon/thickener under the hinge After riveting, covered the hinge with the same resin/microballon/thickener I switched to polyester resin because I heard somewhere that the mat may not be broken down as well using epoxy resin I used the microballon paste to get some bonding through the 3/16 holes I drilled. ________________________________________________________________________________
Date: Apr 17, 2001
In a message dated 4/17/01 7:44:13 AM Central Daylight Time, SSoule(at)pfclaw.com writes: << Does the Landoll balancer require modification to the spinner? Does is require different prop bolts? Does it require modification to Van's prop extender? >> Hi Steve, I believe the harmonic balancer actually looks like a large ring and bolts to the flywheel out near the starter ring teeth. If you look at your flywheel you'll see a series of holes around it near the starter teeth ring. The harmonic balancer looks like a large donut and the center hole of the donut doesn't contact the spacer or the prop. Hope this helps Eric Newton - Long Beach, Mississippi RV-6A N57ME (Reserved) (Finish Kit) http://www.ericsrv6a.com ________________________________________________________________________________
Date: Apr 17, 2001
The Landoll balancer bolts to the back of the flywheel,does not interfer with with anything on my RV4,comes with bolts,nuts,and instructions.I recommend the silicon filled one,not the solid ring.They both weigh 12 pounds. ________________________________________________________________________________
Date: Apr 17, 2001
Your statement about Microballoons is wrong. It with stands flexing very well. The shaping of the landing gear on Veri-Eze and Long EZ is done with micro. I have used it on fretted aluminum cowlings to rebuild the metal thickness. Works very well even on pieces that a flexed when opening or closing. You do need to use good epoxy not boat resin. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh > Microbaloons makes a lousy filler for anything but thin, cosmetic > applications, where the item is not subject to flexing. ----- Original Message ----- From: "Randall Henderson" <randallh(at)home.com> Sent: Thursday, April 19, 2001 12:54 AM Subject: Re: RV-List: Fiberglassing Cowl Hinges...destructive test results > > Microbaloons makes a lousy filler for anything but thin, cosmetic > applications, where the item is not subject to flexing. It will make the > resin weaker not stronger, and should not be used as a bonding agent IMHO. > > Instead use milled glass or at the very least, cotton flox. Either one will > make more of a structural bond. If you bond your hinges with a slurry of > milled glass fibers and squeeze that stuff through holes in the hinges I'll > bet you won't be able to get it off. > > Also, when you say you sanded the hinges, do you mean you really SANDED > them? I mean, with 80 or even 60 grit? That's what it takes to make the > stuff really bond with aluminum. > > Randall Henderson, RV-6 N6R (~200 hrs) > Portland, OR > www.vanshomewing.org > > ________________________________________________________________________________
Date: Apr 17, 2001
Thread-Topic: RV-List: Fiberglassing Cowl Hinges...destructive test results Thread-Index: AcDG0kDwERAmtXkjTjixBUiij66wnAAc0jjA
Folks, I just want to jump in here and offer some input on what causes hinge eyes to break... It sure doesn't hurt to glue the hinges to the cowl while riveting them on, but the hinges not being strong enough or bonded well enough is not the problem. In the instructions for the baffles, the directions say to have a gap about a half-inch between the baffle and the cowl. I think that's too close. One of the things I will do differently on the next project is increase this distance to no less than an inch, especially around the front of the engine where things shake the most. The problem IMO with having the baffle edges too close to the cowl makes the baffle seal more rigid, and the obvious result is vibration of the engine is transferred directly to the cowl. And then you get broken hinge eyes. Watch any airplane during shutdown and you will see how much movement there is. A larger gap there with a bigger "flap" of baffle material will still seal quite well, and will reduce the amount of vibration transmitted directly to the cowling. Bob Japundza RV-6 N244BJ O-360C/S flying 113 hours ________________________________________________________________________________
Subject: IFR RV's
Date: Apr 17, 2001
Can anyone attest to the stability of an RV8 for IFR flying? I sat in Van's RV8 at S&F last week and it felt like I was look down at the panel - has anyone tried tilting it up a little? Anyone with experience with the new EFIS systems? I trying to layout my panel and debating between a good IFR or simple VFR..... Thanks! Bob Waalkes RV8 QB LaPorte, IN ________________________________________________________________________________
Date: Apr 16, 2001
I seem to recall that these fuel pumps have a ball valve which doesn't seat properly if not at least 45 degrees from horizontal. You can buy these pumps at automotive stores and the instructions show the same inclination. Garth Shearing VariEze and 75% RV-6A Subject: Re: RV-List: Inclination on fuel pump > ________________________________________________________________________________
Subject: Re: Blast tubes
Date: Apr 16, 2001
Don't forget that the blast tubes do not provide blast air when you need it the most on some components. For example, the alternator is working pretty hard to recharge the battery after start-up. But you don't get the significant blast air until you are flying. You need cooling of these components most when you are still on the ground on a hot day. Garth Shearing VariEze and 75% RV-6A Subject: Re: RV-List: Blast tubes ________________________________________________________________________________
Date: Apr 17, 2001
Subject: Re: Executive Hangar, Denver CO
> Alex, what are the specifics? like how much room would I have and what would the rent be? -- Gary Zilik - Pine Junction, Colorado RV-6A N99PZ Flying Engine: Aerosport Power O-360-A1A Prop: Sensenich 72FM8S9-1-83 ________________________________________________________________________________
Date: Apr 17, 2001
Subject: [Fwd: 6000 engine]
passing along this info I got from Jabiru..... Date: Mon, 16 Apr 2001 19:39:26 -0500 From: "Pete Krotje" <gllp(at)athenet.net> Subject: Re: 6000 engine Hello Gary, The Jabiru 6000 had a great many RV builders talking at SNF. For the most complete info, visit www.jabiru.net.au. The engine should run for the first time next week and if things go according to plan we may have some to sell at the end of the year. The first test bed will be a 75% Spitfire in AU and the first six are committed to him. Several RV builders in AU are interested as well ands the FWF kit will be developed in one of their planes. We have been locking in prices and order position by taking a prelim order with $1000.00 down to be held in escrow. Initial price is $13,900.00. The down payment is not mixed with our funds and is refundable on request. If you are interested, I'll send the paperwork. Pete Krotje Jabiru USA Flight Center, LLC ----- Original Message ----- From: "Gary Gunn" <ggunn(at)uswest.net> Sent: Friday, April 13, 2001 9:58 AM Subject: 6000 engine > Saw your 6000 engine on your web-site. Do you guys have any plans to > develop a firewall forward package for the Van's series of kit aircraft? > > Thanks > Gary Gunn > Building a RV-6 > ________________________________________________________________________________
Date: Apr 17, 2001
Subject: Engine Movement
Listers, I have a question regarding how much he engine will move during normal operations. I am installing the top cowling around my O-320 H2AD engine in my RV-6A and of course I must modify the cowling slightly to clear the two buldges in the engine at the top front (fuel pump and prop gov. pads). I have modified the cowling and have created about .50" to .75" clearance. Is this enough? Thanks, Eric Newton - Long Beach, MS RV-6A - N57ME (reserved) (FWF) www.ericsrv6a.com ________________________________________________________________________________
Date: Apr 17, 2001
Garth et all, The primarily reason for the inclination is to help the pump purge any air or fumes that may get in the fuel lines, such as when a tank runs low. There is no ball valve used in these pumps. Instead they use a rounded spring loaded disk valve. I don't RECALL this, it is fact. Over the last 20 + years I have taken these things apart many times. As a Tech Counselor I was asked to write a paper about these pumps and their use in aircraft. I've also flown in excess of 1000 hr. in aircraft that use this pump, with little to no inclination, as the only source of fuel pressure (no engine driven pump). This post is not meant to be a personal attack on Garth or anyone else, but THE LIST would be a lot more useful, if posters would limit there input on technical matters, to what they know to be fact. Garry LeGare, EAA 94585 Tech Consular RV6 Finishing Garth Shearing wrote: > > I seem to recall that these fuel pumps have a ball valve which doesn't seat > properly if not at least 45 degrees from horizontal. You can buy these > pumps at automotive stores and the instructions show the same inclination. > > Garth Shearing > VariEze and 75% RV-6A > > Subject: Re: RV-List: Inclination on fuel pump > > > > ________________________________________________________________________________
Date: Apr 17, 2001
A procedure that works is to bed the hinges into a wet flox/epoxy mixture. Prep the hinge by drilling 1/4" holes between the eyes, countersink them and sand the matting surface with 80 grit. These holes allow the wet flox to squeeze out and form little mounds which act like flox rivets. If you clean these little mounds off the hinge will just peel off as epoxy is weak in peel. Garry LeGare, EAA94585 RV6 Finishing Tech Counselor Ross wrote: > > > Instead use milled glass or at the very least, > > I did add some milled fiberglass as well > > > Also, when you say you sanded the hinges, do you mean you really SANDED > > them? I mean, with 80 or even 60 grit? That's what it takes to make the > > stuff really bond with aluminum. > > Yes > ________________________________________________________________________________
Subject: Re: Engine Movement
Date: Apr 17, 2001
Hey Eric, I would think that's OK. You will most likely pull positive g's during your flying (I do, anyway)so this will tend to pull the engine down. Also, the mounts will settle slightly after some use. I originally had about 1/4 - 3/8" clearance under my alternator pulley & the lower cowl and ended up chewing a slit in the cowl. I finally pulled the prop & put on a smaller belt. Now I have 1/2" or better clearance and no rubbing. Rick Caldwell -6 214 hrs. Looking for places to fly to and RV's to fly with, always. Melbourne, FL >From: ENewton57(at)AOL.COM >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Engine Movement >Date: Tue, 17 Apr 2001 11:56:31 EDT > > >Listers, >I have a question regarding how much he engine will move during normal >operations. >I am installing the top cowling around my O-320 H2AD engine in my RV-6A and >of course I must modify the cowling slightly to clear the two buldges in >the engine at the top front (fuel pump and prop gov. pads). I have >modified the cowling and have created about .50" to .75" clearance. Is >this enough? > >Thanks, >Eric Newton - Long Beach, MS >RV-6A - N57ME (reserved) (FWF) >www.ericsrv6a.com > > ________________________________________________________________________________
Date: Apr 17, 2001
In a message dated 4/17/01 9:23:12 AM Pacific Daylight Time, "versadek"@earthlink.net writes: > > A procedure that works is to bed the hinges into a wet flox/epoxy mixture. > Prep the hinge by drilling 1/4" holes between the eyes, countersink them and > sand the matting surface with 80 grit. These holes allow the wet flox to > squeeze out and form little mounds which act like flox rivets. If you clean > these little mounds off the hinge will just peel off as epoxy is weak in > peel. > Garry LeGare, EAA94585 > RV6 Finishing > Tech Counselor > > > Question....? should the hinge need to be replaced because of some broken eyes, could the hinge be removed without messing up the cowl? ________________________________________________________________________________
Date: Apr 17, 2001
> THE > LIST would be a lot more useful, if posters would limit there input on > technical matters, to what they know to be fact. > Fact: the manufacture recomends mounting the pump at a 45 degree angle. Fact: The pump does not pump very well if not purged of air. -- Gary Zilik - Pine Junction, Colorado RV-6A N99PZ Flying Engine: Aerosport Power O-360-A1A with H2AD Pistons Prop: Sensenich 72FM8S9-1-83 ________________________________________________________________________________
Date: Apr 17, 2001
> > >In a message dated 4/17/01 9:23:12 AM Pacific Daylight Time, >"versadek"@earthlink.net writes: > > >> >> A procedure that works is to bed the hinges into a wet flox/epoxy mixture. >> Prep the hinge by drilling 1/4" holes between the eyes, countersink them and >> sand the matting surface with 80 grit. These holes allow the wet flox to >> squeeze out and form little mounds which act like flox rivets. If you clean >> these little mounds off the hinge will just peel off as epoxy is weak in >> peel. >> Garry LeGare, EAA94585 >> RV6 Finishing >> Tech Counselor >> >> >> > >Question....? should the hinge need to be replaced because of some broken >eyes, could the hinge be removed without messing up the cowl? > > I think this is a good question. My experience has been the weak point is the hinge eyes, not hinge to cowl adhesion. I have replaced several hinge sections due to the eyes breaking but have had no problems with hinges staying on (I drilled holes in the hinge sections and used some epoxy, in addition to the rivets). Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
Date: Apr 17, 2001
--- Bob Japundza wrote: > > > Folks, > > I just want to jump in here and offer some input on what causes hinge > eyes to break... It sure doesn't hurt to glue the hinges to the cowl > while riveting them on, but the hinges not being strong enough or > bonded > well enough is not the problem. > > In the instructions for the baffles, the directions say to have a gap > about a half-inch between the baffle and the cowl. I think that's > too > close. One of the things I will do differently on the next project > is > increase this distance to no less than an inch, especially around the > front of the engine where things shake the most. The problem IMO > with > having the baffle edges too close to the cowl makes the baffle seal > more > rigid, and the obvious result is vibration of the engine is > transferred > directly to the cowl. And then you get broken hinge eyes. Watch any > airplane during shutdown and you will see how much movement there is. > A > larger gap there with a bigger "flap" of baffle material will still > seal > quite well, and will reduce the amount of vibration transmitted > directly > to the cowling. > > Bob Japundza > RV-6 N244BJ O-360C/S flying 113 hours Bob: I only have 3/8" clearance around the cowl and baffles. I have my prop balanced. I am approaching 800 hours without a single cowl hinge repair. Microballons should NOT be used between hinge and cowl. It is not structural and will end up being the weak point that breaks. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 780+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Date: Apr 17, 2001
04/17/2001 02:22:09 PM I wonder if the guys using plenums have problems with hinges breaking? After all the air pressures are not constantly working on the cowling. Anyone know? Eric Larry Pardue (at)matronics.com on 04/17/2001 01:04:44 PM Please respond to rv-list(at)matronics.com Sent by: owner-rv-list-server(at)matronics.com cc: Subject: Re: RV-List: Fiberglassing Cowl Hinges...destructive test resul > > >In a message dated 4/17/01 9:23:12 AM Pacific Daylight Time, >"versadek"@earthlink.net writes: > > >> >> A procedure that works is to bed the hinges into a wet flox/epoxy mixture. >> Prep the hinge by drilling 1/4" holes between the eyes, countersink them and >> sand the matting surface with 80 grit. These holes allow the wet flox to >> squeeze out and form little mounds which act like flox rivets. If you clean >> these little mounds off the hinge will just peel off as epoxy is weak in >> peel. >> Garry LeGare, EAA94585 >> RV6 Finishing >> Tech Counselor >> >> >> > >Question....? should the hinge need to be replaced because of some broken >eyes, could the hinge be removed without messing up the cowl? > > I think this is a good question. My experience has been the weak point is the hinge eyes, not hinge to cowl adhesion. I have replaced several hinge sections due to the eyes breaking but have had no problems with hinges staying on (I drilled holes in the hinge sections and used some epoxy, in addition to the rivets). Larry Pardue Carlsbad, NM RV-6 N441LP Flying http://www.carlsbadnm.com/n5lp/index.htm ________________________________________________________________________________
From: "Clifford Begnaud" <shoeless(at)barefootpilot.com>
Subject: Engine Advise
Date: Apr 17, 2001
I'm considering buying an "experimental" lycoming from Dan Brown in Tulsa, OK. Anyone have any experience with his engines and care to comment on them? Thanks, Cliff RV9 (wings) www.barefootpilot.com ________________________________________________________________________________
Date: Apr 17, 2001
Thread-Topic: RV-List: Fiberglassing Cowl Hinges...destructive test results Thread-Index: AcDHaF4Y6VzSiIN4SvC+uuXtQtmzlwACAz/Q
Gary, You are definitely an exception. What's your secret? Almost every RV driver I know personally (including myself) has had to deal with broken hinge eyes on the bottom of the cowling. Bob Japundza RV-6 N244BJ O-360C/S flying >I only have 3/8" clearance around the cowl and baffles. I have my prop >balanced. I am approaching 800 hours without a single cowl hinge >repair. ________________________________________________________________________________
Date: Apr 17, 2001
It should be because the -7 empenage is the same as the -8 empenage. Mike Robertson RV-8A >From: "Daniel Estrada F." <dani_estrada(at)infosel.net.mx> >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: Electric Elev. Servo.. >Date: Mon, 16 Apr 2001 23:22:40 -0600 > > > >Hi every body: > >Today I have recieved my electric serrvo for my elevator, but I have a >doubt: > >Is the 8A mac servo ok for the RV7A..? > >thanks > >Daniel Estrada >Mexico City > > ________________________________________________________________________________
Subject: Re: IFR RV's
Date: Apr 17, 2001
Bob, We have our -8A set up for IFR and I had the chance to make my first instrument approach last week. IWhile, yes , the panel was a little bit lower than I would like it worked out fine. I actually found it to be a very stable instrument platform.....at least for me. Mike Robertson RV-8A >From: "Bob Waalkes" <waalkes(at)netnitco.net> >Reply-To: rv-list(at)matronics.com >To: "RV LIST" >Subject: RV-List: IFR RV's >Date: Tue, 17 Apr 2001 09:59:04 -0500 > > >Can anyone attest to the stability of an RV8 for IFR flying? I sat in >Van's >RV8 at S&F last week and it felt like I was look down at the panel - has >anyone tried tilting it up a little? Anyone with experience with the new >EFIS systems? > >I trying to layout my panel and debating between a good IFR or simple >VFR..... > >Thanks! > >Bob Waalkes >RV8 QB >LaPorte, IN > > ________________________________________________________________________________
Date: Apr 17, 2001
results I hope this isn't a ridiculous suggestion but has anybody tryed the closed eye version of the hinge material. I can't remember which number is which but the I believe the open eye hinge is MS20257 and closed eye extruded hinge is MS20001. The closed eye hinge seems like it would be much stronger IMO. I'm building an F1 Rocket (my first kit plane) and I plan to use the Carbon Hinge previously referenced on this e-mail thread. The Carbon hinge has closed eyes just like the MS20001 and seems like it would be a more natural bond to the fiberglass cowl halves. The F1 Rocket uses a flange and fasteners (quarter turn or machine screw) to attach the cowl to the fuselage so I don't need hinges for this part. scot > >Gary, > >You are definitely an exception. What's your secret? Almost every RV >driver I know personally (including myself) has had to deal with broken >hinge eyes on the bottom of the cowling. > >Bob Japundza >RV-6 N244BJ O-360C/S flying > > >I only have 3/8" clearance around the cowl and baffles. I have my prop > >balanced. I am approaching 800 hours without a single cowl hinge > >repair. > > ________________________________________________________________________________
Date: Apr 17, 2001
Meangreen, I hope it's OK to call you by your first name. I don't know if a broken eye or two is cause for replacement of the hinge. But there are many experienced RV flyers on "The List" that will be able to answer that question. If they say it's necessary, here is a relatively painless procedure that will spare your paint job. Grind off the flox mounds that are acting like rivets. Carefully slip a 1 1/4" wide wood chisel between the hinge and cowl, gently pry them apart. You'll be surprised at how weak the bond is. Epoxy is very weak in peel as I stated earlier, that is why there is an AD for the small Grumman's, to put pop rivets at the end of bond lines. Prepare the new section of hinge by duplicating the eye and hole locations. Take a Dremmel and grind the rest of the flox nubs off, then Dremmel out 1/2" approx. diameter recess where each nub was. The recess should go through the existing flox to the inside cowl surface. Lightly sand the mating surface where the old hinge met the cowl, with 80 grit. Scotchbrite or sand the hinge. Paint a light coat of epoxy onto the mating surface of the cowl and hinge. Mix up a wet flox/epoxy mixture and fill the recesses with it. Be sure the mixture is wet enough to just squeeze out through the holes in the hinge. Clamp the hinge in place, making sure there is good squeeze out through each hole. You want the epoxy/flox mix to form a domed head like a rivet. Hope this helps. Garry LeGare, EAA94585 Tech Counselor RV6 Finishing MeangreenRV4(at)AOL.COM wrote: > > In a message dated 4/17/01 9:23:12 AM Pacific Daylight Time, > "versadek"@earthlink.net writes: > > > > > A procedure that works is to bed the hinges into a wet flox/epoxy mixture. > > > > Question....? should the hinge need to be replaced because of some broken > eyes, could the hinge be removed without messing up the cowl? ________________________________________________________________________________
Date: Apr 17, 2001
Subject: Re: Inclination on fuel pump
Gary, Yes it is a fact that the manufacture now (they didn't always) recommends that the pumps be mounted at a inclination of 45 . I also recommend installing the pump with some inclination to help purge fumes from the pump body. But in over 1000 hr. of flying I never experienced a fuel pump problem, except for the transistor dying. You forgot one other thing the manufacture recommends, Not to use these pumps in aircraft. Garry LeGare EAA 94585 Tech Counselor RV6 Finishing Gary Zilik wrote: > > > THE > > LIST would be a lot more useful, if posters would limit there input on > > technical matters, to what they know to be fact. > > > > Fact: the manufacture recomends mounting the pump at a 45 degree angle. > > Fact: The pump does not pump very well if not purged of air. > > -- > Gary Zilik - Pine Junction, Colorado > RV-6A N99PZ Flying > Engine: Aerosport Power O-360-A1A with H2AD Pistons > Prop: Sensenich 72FM8S9-1-83 > ________________________________________________________________________________
Date: Apr 17, 2001
In a message dated 4/17/01 11:25:18 AM Pacific Daylight Time, Eric.J.Henson(at)chase.com writes: > > I wonder if the guys using plenums have problems with hinges breaking? > After all the air pressures are not constantly working on the cowling. > Anyone know? > > I have a (home made) plenum, so far in 200 hrs no problem. I would like to mention I had a hinge start to seperate from the cowl. I removed it and remounted it with pro seal,,,,,, end of problem. Fred LaForge RV-4 180 CS EAA tech counselor ________________________________________________________________________________
Date: Apr 17, 2001
My electric fuel pump is mounted level at +450 hours still works great. I guess it's to dumb to know it should be mounted at 45 degrees to work right. ________________________________________________________________________________
Date: Apr 17, 2001
In a message dated 4/17/01 2:12:36 PM Pacific Daylight Time, "versadek"@earthlink.net writes: > > Meangreen, I hope it's OK to call you by your first name. > > I don't know if a broken eye or two is cause for replacement of the hinge. > But > there are many experienced RV flyers on "The List" that will be able to > answer > that question. > > If they say it's necessary, here is a relatively painless procedure that > will > spare your paint job. > > Grind off the flox mounds that are acting like rivets. Carefully slip a 1 > 1/4" > wide wood chisel between the hinge and cowl, gently pry them apart. You'll > be > surprised at how weak the bond is. Epoxy is very weak in peel as I stated > earlier, > that is why there is an AD for the small Grumman's, to put pop rivets at > the end > of bond lines. > > Prepare the new section of hinge by duplicating the eye and hole locations. > Take a > Dremmel and grind the rest of the flox nubs off, then Dremmel out 1/2" > approx. > diameter recess where each nub was. The recess should go through the > existing flox > to the inside cowl surface. Lightly sand the mating surface where the old > hinge > met the cowl, with 80 grit. > > Scotchbrite or sand the hinge. Paint a light coat of epoxy onto the mating > surface > of the cowl and hinge. Mix up a wet flox/epoxy mixture and fill the > recesses with > it. Be sure the mixture is wet enough to just squeeze out through the holes > in the > hinge. Clamp the hinge in place, making sure there is good squeeze out > through > each hole. You want the epoxy/flox mix to form a domed head like a rivet. > > Hope this helps. > Garry LeGare, EAA94585 > Tech Counselor > RV6 Finishing > > > Hey Garry, Meangreen is the name of my RV-4 my name is Tim but I will answer to about anything, the reason I responded to your post is in my area (Bakersfield) nobody epoxies the hinge to the cowl (only rivets) so if and when a hinge cracks/brakes you just rivet on a new hinge or piece of one, I might add to the best of my knowledge there has not been any problems like that. I was more interested in is if one does epoxy the hinge to the cowl and there is a hinge failure can you remove the old hinge without screwing up the cowl? As for me my plane is new and at this time I have not had any of those problems. ________________________________________________________________________________
Date: Apr 17, 2001
As my engine mounts settled inI found the front of the engine dropped approx 1/4-3/8". installing a washer on the bottom of the mounts corrected the problem Joe RV6A O360 c/s --- ENewton57(at)AOL.COM wrote: > > Listers, > I have a question regarding how much he engine will > move during normal operations. > I am installing the top cowling around my O-320 H2AD > engine in my RV-6A and of course I must modify the > cowling slightly to clear the two buldges in the > engine at the top front (fuel pump and prop gov. > pads). I have modified the cowling and have created > about .50" to .75" clearance. Is this enough? > > Thanks, > Eric Newton - Long Beach, MS > RV-6A - N57ME (reserved) (FWF) > www.ericsrv6a.com > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ________________________________________________________________________________
Date: Apr 17, 2001
--- Bob Japundza wrote: > > > Gary, > > You are definitely an exception. What's your secret? Almost every > RV > driver I know personally (including myself) has had to deal with > broken > hinge eyes on the bottom of the cowling. > > Bob Japundza > RV-6 N244BJ O-360C/S flying > > >I only have 3/8" clearance around the cowl and baffles. I have my > prop > >balanced. I am approaching 800 hours without a single cowl hinge > >repair. > NO HINGE on the bottom of the cowl or behind the spinner. Used 0.063 and #10 (3/16") washer head screws. 0.063 that is rivited to the firewalll has a 7 degree bend to meet the cowl flush. This was done by Jerry Scott on his first RV-6 over 8 years ago to fix bottom hinge breaking. Should be in the archives. The hinge is per plans between the cowl top, bottom, and firewall side. The top hinge along the firewall removes from the outside instead of through the oil fill door. I do have metal hinge pin hold down plates that help hold the top and bottom cowl together and keep the hinge pin from coming out into the spinner. Paul Besing (spelling) took photos of this at Copperstate in 1999. The engine was REBUILT and balanced. The prop was also balanced on the airplane. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 780+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Subject: Key West Trip online (pics) / 50 more pics of M.Knights flaming
red RV
Date: Apr 17, 2001
Thread-Topic: Key West Trip online (pics) / 50 more pics of M.Knights flaming red RV Thread-Index: AcDHqUbYTSLZedi3Q/+z5a31r7GCgg=
From: "Reeves, Doug" <Douglas.Reeves(at)archongroup.com>
Hi listers, Two new items on the World Wide Wing (www.vansaircraft.net) that you won't want to miss: HEY MON Randy Pflanzer (RV-6 N417G) wrote an incredible travel story about his recent trip to Sun-n-Fun and then down to Key West with his son (lots of pictures). This is the travel story to email to those friends wondering why you're building a plane. I think you'll agree this should be required reading by all - Randy did a great job. It's in 'Travel Stories'. SOME LIKE IT HOT Michael Knight (Mr. 200hp Flaming Hot RV-6) just uploaded 50 images of his beautiful new RV to his newly created free clubphoto account. Mike's RV was just featured as the 'RV of the Week'. He uploaded many, many shots of his bright red leather interior, panel, and flames on the cowl and tail. I've added a link to these pictures in 'Photo Gallery'. Finally, I'd like to give a great big public thank you to Randy Pflanzer and Michael Knight for providing RV content for the community at large to enjoy and draw inspiration from and to Matt Dralle for providing such an efficient way to let all the RV folks know about it. Regards, Doug Reeves Van's Air Force - World Wide Wing www.vansaircraft.net ________________________________________________________________________________
From: "George Armstrong" <armstrong(at)coastside.net>
Subject: Dream Machines Show
Date: Apr 17, 2001
The annual Dream Machines show is scheduled for 4/29 in Half Moon Bay CA (HAF). Every sort of machine will be there including the Northrop Flying Wing. Cars, boats, motorcycles tractor pulls... By most estimates, 400 aircraft were there last year. $10 per person entrance fee. ________________________________________________________________________________
Date: Apr 19, 2001
> Your statement about Microballoons is wrong. It with stands flexing very > well. The shaping of the landing gear on Veri-Eze and Long EZ is done with > micro. I have used it on fretted aluminum cowlings to rebuild the metal > thickness. Works very well even on pieces that a flexed when opening or > closing. You do need to use good epoxy not boat resin. Okay its probably the resin, but my wheel pants, on the inside corners, have started to show some cracks. Only where I have microbaloons. Sure could be the polyester resin though. Randall ________________________________________________________________________________
Date: Apr 19, 2001
> You are definitely an exception. What's your secret? Almost every RV > driver I know personally (including myself) has had to deal with broken > hinge eyes on the bottom of the cowling. I am another exception. Might be because I didn't use a hinge on the bottom of the cowl -- instead put in .063 AL flanges and six #10 nutplates/screws :-) Seriously though, I think a lot of the hinge breaking could be prevented by taking the time to smooth those sharp inside corners of the hinge segments before installing, using some folded up 350 or 400 grit sandpaper. Randall Henderson, RV-6 N6R (~200 hrs) Portland, OR www.vanshomewing.org ________________________________________________________________________________
Date: Apr 17, 2001
From: Thomas McIntyre <bogeybrother(at)earthlink.net>
Subject: Re: Dream Machines Show
Of the so called 400 airplanes there last year, about 30 were on display. The rest were fly ins parked away from the show area. If you read carefully the Northrop flying wing scheduled to be there is an RC model. Tom George Armstrong wrote: > > The annual Dream Machines show is scheduled for 4/29 in Half Moon Bay CA > (HAF). Every sort of machine will be there including the Northrop Flying > Wing. Cars, boats, motorcycles tractor pulls... By most estimates, 400 > aircraft were there last year. $10 per person entrance fee. > ________________________________________________________________________________
Date: Apr 18, 2001
Subject: Re: Alternate engines
> >Jim Sears wrote: >>If the engine is certified, it will have had to have gone >> through testing to get that. > >What does certification testing consist of ? > >Hal Kempthorne >RV6a N7HK (Valentine) FLYING > Have a look at FAR 33, Sub-part D, in particular, 33.49 Endurance Test. It is too long to post here. You can find FAR 33 at http://www.landings.com/ Go to the bottom of the page, and select Regulations. There is probably one or more Advisory Circulars that deal with this stuff two, but I can't find them on the web. -- Kevin Horton RV-8 (mounting wings) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Date: Apr 18, 2001
In a message dated 4/17/01 10:41:00 PM Central Daylight Time, randallh(at)home.com writes: << > Your statement about Microballoons is wrong. It with stands flexing very > well. The shaping of the landing gear on Veri-Eze and Long EZ is done with > micro. I have used it on fretted aluminum cowlings to rebuild the metal > thickness. Works very well even on pieces that a flexed when opening or > closing. You do need to use good epoxy not boat resin. Okay its probably the resin, but my wheel pants, on the inside corners, have started to show some cracks. Only where I have microbaloons. Sure could be the polyester resin though. >> I have some experience in this area having worked on composite airplanes so perhaps I can make a contribution. Microbaloons mixed with resin can be used to fill or shape in all non structural applications but will not work well as an adhesive. Where strength is a factor use flox (cotton fibers) mixed with epoxy resin. For structural adhesion of two pieces to each other use two part epoxy adhesive (on the aircraft I built this stuff was used to attach the horizontal stabilizer to the fuselage). If you want it to stay put, use adhesive, not filler. Eric Newton - Long Beach, Mississippi RV-6A N57ME (Reserved) (Finish Kit) http://www.ericsrv6a.com ________________________________________________________________________________
Subject: Facet Fuel pumps
Date: Apr 18, 2001
The electric Facet fuel pumps are designed so the internal plunger rotates while in service only when the pump is mounted at a 45 degree angle. This increases the pump life by a factor of 3 according to a facet rep who recently posted this information on the Long EZ list. He implied that if tyhe pumps are installed level then they should be replaced ever 300 hours of operation. ________________________________________________________________________________
Date: - - - , 20-
>Have a look at FAR 33, Sub-part D, in particular, 33.49 Endurance >Test. It is too long to post here. You can find FAR 33 at >http://www.landings.com/ Go to the bottom of the page, and select >Regulations. I just dug out my ASA FAR/AMT and found that FAR 33 has some very good information, if one is really interested in the certification process of an engine. Granted, there's quite a bit to read; but, it looks interesting for those who have the time and desire to read it. Jim Sears in KY RV-6A N198JS ________________________________________________________________________________
Subject: Alternate engines
Date: - - - , 20-
Listers, Below is a note I just got off the Grumman Gang list. Since we're already discussing alternate engines, I thought this might whet your interests, as well. Jim Sears in KY RV-6A N198JS >> Gang, I was following the discussion about an MT-Prop for Tigers in this newsgroup closely and I'm very sorry I was only able to deliver the bad news for US registered Tigers a couple weeks ago. Still, I've noticed a significant desire within the group not only to update our avionics to state-of-the-art equippment, but also to update and improve our aging power plants, hence to improve performance. Here in Europe, where fuel prices generate a stong demand for more economical engines two companies competed in the race for the first certified jet-fuel-driven diesel aircraft engine (yes, Jet Fuel for a piston diesel: Imagine the "Jet A1" sticker in a Tiger-wing!!). One company named Thielert Aircraft Engines, has now made the race and archieved FAA and JAR certification for a turbo charged diesel engine, that from it's performance characteristics, can replace O320 and O360 engines (www.thielert.de). They're putting it into PA28 and C172 airframes here in Europe right now, other airframes are to follow up. Performance, of course is impressive, range nearly doubles and TBO soars to 3,000 hrs, with an engine cost of $ 17,000 for the engine (C172N). The whole installation consists of the engine, and an MT-electrical CS-Prop. The fuel system remains unchanges, but the engine mounts are replaced, so you would probably end up with a 25k to 30k bill. Fuel consumption is is about 13 l/h (= 3.6 GALS/h) with full cuise power available up to 11,000 ft. I don't want to speculate about what numbers an engine like this will take our Grummans to, but you can figure yourself that cutting the fuel consumption by 50% will... well pretty much double the range and reduce the cost of flying SIGNIFICANTLY. So why am I writing all this and raising hopes? There is the most important aviation industrie fair here in Europe commping up next week and as a writer for a large aviation magazine I will of course meet the people from TAE as well. I would like to give these people a very rough estimate on what MAYBE the demand in the US could look like. I am considering Grumman owners as the ideal people to ask. We are usually very keen on performance and economical flying (this is why we have Grummans - right?). So what do you think?? Would you or people you know spend $20K - $25K for an engine/CS-Prop combination that is new in the market, and that well.. let's say: - Doubles your range ? - Reduces costs per hour by 65% ? - Gives you turbo-charged cruise power all the way up to the levels ? How much are aircraft owners like you willing to take the risks associated with putting an engine in your Aircraft that has not 40 years of parctical tests to look back to?? How many would replace their engine right away and how many would rather replace when the next overhaul is due?? Thanks for your feedback, BTW: I don't take orders for TAE, but my Tiger will be one of the fist ones to have a TAE engine installed if we can gather 5-7 AA5 airframes together... rgds, jb -- Jan Brill Marstallweg 9 CH-8005 Zurich, Switzerland Doppelraab-Glider D-5412 Grumman Tiger AA5B N18AP<< ________________________________________________________________________________
Date: Apr 18, 2001
You are completely right about using Flox for applications that need strength. For finishing or filling, the micro is the preferred material as it sands much easier. Burt Rutan had very strict rules as to which he wanted in his plans. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh ----- Original Message ----- From: <ENewton57(at)AOL.COM> Sent: Wednesday, April 18, 2001 7:13 AM Subject: Re: RV-List: Fiberglassing Cowl Hinges...destructive test results > > In a message dated 4/17/01 10:41:00 PM Central Daylight Time, > randallh(at)home.com writes: > > << > Your statement about Microballoons is wrong. It with stands flexing very > > well. The shaping of the landing gear on Veri-Eze and Long EZ is done with > > micro. I have used it on fretted aluminum cowlings to rebuild the metal > > thickness. Works very well even on pieces that a flexed when opening or > > closing. You do need to use good epoxy not boat resin. > > Okay its probably the resin, but my wheel pants, on the inside corners, have > started to show some cracks. Only where I have microbaloons. Sure could be > the polyester resin though. > >> > > I have some experience in this area having worked on composite airplanes so > perhaps I can make a contribution. Microbaloons mixed with resin can be used > to fill or shape in all non structural applications but will not work well as > an adhesive. Where strength is a factor use flox (cotton fibers) mixed with > epoxy resin. For structural adhesion of two pieces to each other use two > part epoxy adhesive (on the aircraft I built this stuff was used to attach > the horizontal stabilizer to the fuselage). > If you want it to stay put, use adhesive, not filler. > > Eric Newton - Long Beach, Mississippi > RV-6A N57ME (Reserved) (Finish Kit) > http://www.ericsrv6a.com > > ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Date: Apr 18, 2001
Talk about your misleading advertising! One of the local radio stations has been running ads that tout the fact that the flying wing is going to be there. I would be incredibly p*ssed off if I went there and found only an RC model! -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Thomas McIntyre [mailto:bogeybrother(at)earthlink.net] Sent: Tuesday, April 17, 2001 9:53 PM To: rv-list(at)matronics.com Subject: Re: RV-List: Dream Machines Show Of the so called 400 airplanes there last year, about 30 were on display. The rest were fly ins parked away from the show area. If you read carefully the Northrop flying wing scheduled to be there is an RC model. Tom George Armstrong wrote: > > The annual Dream Machines show is scheduled for 4/29 in Half Moon Bay CA > (HAF). Every sort of machine will be there including the Northrop Flying > Wing. Cars, boats, motorcycles tractor pulls... By most estimates, 400 > aircraft were there last year. $10 per person entrance fee. > ________________________________________________________________________________
Subject: Fiberglassing Cowl Hinges...destructive test results
Date: Apr 18, 2001
Thread-Topic: RV-List: Fiberglassing Cowl Hinges...destructive test results Thread-Index: AcDHwca+V/eXHZZURmGkbPiG704rZgATUeTQ
I'd say doing what you guys have done is the way to go...leave the hinges out of the bottom and use screws or camlocs down there. One other thing I'd like to mention is there is a lot less shaking of the engine during shutdown if the engine is at a high idle. Even with my balanced prop and electronic ignition if I idle anywhere below 575 RPM I can watch the panel shake sideways, with everything creaking and moaning. I'll notice little black trails of smoke coming from the hinges around the firewall after a flight doing touch and go's on our grass strip, but on x-country flights I hardly ever notice any smoking of the hinges. So, I can say with my experience it's not airloads that kill the hinges, it's definitely from the engine shaking. I have a small crack around the front of the carb scoop where it is bonded to the cowl, and the only way I can figure how the crack appeared is due the proximity of the airbox to the scoop (quarter-inch gap between the airbox and the inside wall of the inlet). I'd have a larger gap in there too next time around. Bob Japundza RV-6 N244BJ O-360C/S flying 113 hours -----Original Message----- From: Randall Henderson [mailto:randallh(at)home.com] Sent: Thursday, April 19, 2001 10:39 PM Subject: Re: RV-List: Fiberglassing Cowl Hinges...destructive test results > You are definitely an exception. What's your secret? Almost every RV > driver I know personally (including myself) has had to deal with broken > hinge eyes on the bottom of the cowling. I am another exception. Might be because I didn't use a hinge on the bottom of the cowl -- instead put in .063 AL flanges and six #10 nutplates/screws :-) Seriously though, I think a lot of the hinge breaking could be prevented by taking the time to smooth those sharp inside corners of the hinge segments before installing, using some folded up 350 or 400 grit sandpaper. Randall Henderson, RV-6 N6R (~200 hrs) Portland, OR www.vanshomewing.org ________________________________________________________________________________
Subject: METO fuel configuration
Date: Apr 18, 2001
Listers, As I scramble to get all final details ready for first flight I have a question about something my DAR wants. When I do my W&B sheet with sample configurations he asked specifically for a METO configuration. He gave me a copy of the checklist he uses, following is what it says... "Aircraft weighted empty - MINIMUM FUEL. Minimum fuel for balance purposes is 1/12 gallon per Maximum-Except-Takeoff-Horsepower (METO), and is the maximum amount of fuel which could be used in weight and balance computations when low fuel might adversly affect the most critical balance conditions. To determine the weight of fuel in punds divide the METO horsepower by two. AC43.13-1A, Chapter 13 paragraph 657. 0. Maximum weight Datum line - Forward and aft C.G. with load limits for crew baggage - check figures" This is a bit confusing to me, and also I have AC43.13-1B, which is dated 9/98, rather than 1A, which doesn't even have a Chapter 13. Anyone have any idea what he's after? He was fairly adamant that I include this. Thanks, Randy Lervold RV-8, #80500, first flight soon www.rv-8.com ________________________________________________________________________________
Date: Apr 18, 2001
Randall, You hit the nail on the head. It is probably the polyester resin. Polyester shrinks more on initial cure than epoxy. It is much more susceptible to vibration induced cracking as well (fiberglass wing tips, fairing etc on older certified aircraft). And most importantly it is a poor adhesive. As others have stated Microballoon/epoxy makes a great non structural filler as long as you don't mix it to dry (it won't stick well). For structural applications flox/epoxy is my personal choice. The nice thing about these do it your self filler concoctions is you can tailor the viscosity to a particular job at hand. Personal I will not use polyester resin on an aircraft. Garry LeGare EAA94585 Tech Counselor RV6 Finishing Without Polyester Resin. Randall Henderson wrote: > > > Your statement about Microballoons is wrong. It with stands flexing very > > well. The shaping of the landing gear on Veri-Eze and Long EZ is done with > > micro. I have used it on fretted aluminum cowlings to rebuild the metal > > thickness. Works very well even on pieces that a flexed when opening or > > closing. You do need to use good epoxy not boat resin. > > Okay its probably the resin, but my wheel pants, on the inside corners, have > started to show some cracks. Only where I have microbaloons. Sure could be > the polyester resin though. > > Randall > ________________________________________________________________________________
Date: Apr 18, 2001
Subject: Boost Pump Placement
I intend to install an Airflow Performance fuel injection system in my RV-6A. The instruction manual recommends NOT installing the boost pump in the engine compartment. That leaves the options of putting it in the cockpit or in the wing root. It is a fairly large assembly. Any recommendations? Are there any photos out there of FI boost pump installations? Charlie San Antonio RV-6AQB - N11CB (reserved) Canopy ________________________________________________________________________________
Subject: Re: Fiberglassing Cowl Hinges...destructive test resul
Date: Apr 18, 2001
I have had a Sam James Plenum installed for about 250 hours now. The only attach at the front of the cowling is 1 #8 screw each side. Standard hinges in all other locations. No movement/breakage(or evidence of) yet.... PS the hinges on the fuselage side have 500+ hours on them (new cowling at 250 hours). Todd RV6 N92TM 160HP Aymar Demuth 500+ hrs in Southern MD ----- Original Message ----- From: <Eric.J.Henson(at)chase.com> Sent: Tuesday, April 17, 2001 2:18 PM Subject: Re: RV-List: Fiberglassing Cowl Hinges...destructive test resul > > > I wonder if the guys using plenums have problems with hinges breaking? > After all the air pressures are not constantly working on the cowling. > Anyone know? > > Eric > NetZero Platinum No Banner Ads and Unlimited Access Sign Up Today - Only $9.95 per month! http://www.netzero.net ________________________________________________________________________________
Date: Apr 18, 2001
Regarding hinge eyes breaking, Bob Haan (Homewing Group) mentioned this problem and thought he'd found the reason. When a hinge eye is viewed through a hand magnifying lens you can see stress cracks on many of them at the start of the curl from the flat part of the hinge. He dresses these with a file and emery cloth. His plane is not flying yet, so haven't confirmed that this is a solution -- but it seems reasonable. John Warren RV-6Q LaCenter, WA ----- Original Message ----- From: "Larry Pardue" <n5lp(at)carlsbad.net> Sent: Tuesday, April 17, 2001 10:04 AM Subject: Re: RV-List: Fiberglassing Cowl Hinges...destructive test resul > > > > > > >In a message dated 4/17/01 9:23:12 AM Pacific Daylight Time, > >"versadek"@earthlink.net writes: > > > > > >> > >> A procedure that works is to bed the hinges into a wet flox/epoxy mixture. > >> Prep the hinge by drilling 1/4" holes between the eyes, countersink them and > >> sand the matting surface with 80 grit. These holes allow the wet flox to > >> squeeze out and form little mounds which act like flox rivets. If you clean > >> these little mounds off the hinge will just peel off as epoxy is weak in > >> peel. > >> Garry LeGare, EAA94585 > >> RV6 Finishing > >> Tech Counselor > >> > >> > >> > > > >Question....? should the hinge need to be replaced because of some broken > >eyes, could the hinge be removed without messing up the cowl? > > > > > > I think this is a good question. > > My experience has been the weak point is the hinge eyes, not hinge to > cowl adhesion. I have replaced several hinge sections due to the eyes > breaking but have had no problems with hinges staying on (I drilled holes > in the hinge sections and used some epoxy, in addition to the rivets). > > Larry Pardue > Carlsbad, NM > > RV-6 N441LP Flying > http://www.carlsbadnm.com/n5lp/index.htm > > ________________________________________________________________________________
Date: Apr 18, 2001
Eric.J.Henson(at)chase.com wrote: > > I wonder if the guys using plenums have problems with hinges breaking? > After all the air pressures are not constantly working on the cowling. > Anyone know? > > Eric > I have a home made aluminum plenum on my RV-6A. Engine is an O-360 swinging a Sensenich 72FM prop. The hinges on the bottom have lost 3 ears each on the cowl side of the hinge. All other hinges are ok. When I was building I was under the assumption that the 6's loose bottom hinges more than the 4's due to the large flat bottom of the cowl catching the pulses from the prop. CS props had more of a tendency than wood props to break hinges. The hinge behind the spinner was also a week point but that has been taken care of on the new S-type cowls with the use of nutplates and screws in this area. The vertical cowl to fuselage hinges have not been much of a problem and the same can be said of the horizontal cowl hinges. Few break. When I finally have to replace the bottom hinges I plan on nutplates and scews. I would stick with the hinges everwhere else as they are effective and low in cost. Gary Zilik ________________________________________________________________________________
Date: Apr 18, 2001
Garry LeGare wrote: > > You forgot one other thing the manufacture recommends, Not to use these > pumps in aircraft. In big letters too! Gary ________________________________________________________________________________
Date: Apr 18, 2001
date.) I wish these people good sucess but I keep remembering people like a man and his son who installed a Ford V6 in an RV4.It burned more fuel (heavier) than a Lycosaur. There were many more problems than just cooling and CG. Bob Murphy Poplar Grove ILL. (C77) ________________________________________________________________________________
Date: Apr 18, 2001
Subject: Red Wing
Is the flyin for the 21st. still on? I read about the flooding in that area and I wonder. Can someone who lives in that area let us know? Bob Murphy Poplar Grove ILL. (C77) ________________________________________________________________________________
Date: Apr 18, 2001
Subject: Re: fuel pump inclination
> > I know I have to mount the pump, with a more >pronounced angle, something like 45o or so.. >So I have to drill new holes...any suggestions >as to what is best to closed the old holes? Hi Bert, Dont know if this could work for you. Could you reuse one of your holes and then rotate the pump to the proper angle so you would only have one hole to deal with? Depending on where the other hole would be, could you use it for a: Fuel line from wing b: Pitot heat wiring to wing c: Nav or strobe wiring to wing d: vent to fuel tank e: outside temp probe wiring If you cant use it for anything, you could just stick a bolt through it and put a nut on the outside. Attach a angle to the outside of the bolt and use it for support for some of your wiring or plumbing from your wing if needed. f: None of the above, I give up. Regards, Tom Velvick Peoria, AZ N9233A rv-4 N188KJ rv-6a wiring panel ________________________________________________________________________________
From: "Doug Weiler" <doug.weiler(at)pressenter.com>
Subject: Re: Red Wing
Date: Apr 18, 2001
Yes, The Twin Cities RV Forum is certainly still on. The airport is far from the river and the only fear had been that the bridge linking WI and Red Wing, MN could possibly close. I checked this morning and it appears that the river level is stable and they are predicting that the road will stay open. Terry Jantzi (world RV altitude record holder) and Wolf Irmscher (WWII German fighter pilot) will be our banquet guest speakers (they are en route from Toronto today). Geo and Becki Orndorff along with Larry Vetterman will be on the program. Powersport Aviation will be bringing their rotary engine on a test stand. Jerry Van Grunsven will be there representing Van's Aircraft. We have a great array of door prizes lined up with a Grand Prize drawing at 2 pm. At 10 am Becki Orndorff will present a program for the wives (with RV-6 and RV-8 rides for them weather permitting). Best RV award will be presented at 2 pm. (Did I mention, coffee, donuts, etc in the morning. Lunch available at noon) So, don't hesitate in spending a fun day with us in Red Wing (RGK). For details check out the website: http://www.pressenter.com/~dougweil/rvforum.html Or call me at home: 715-386-1239 cell 651-398-1184 Doug Weiler pres, MN Wing ----- Original Message ----- From: "BOBE." <RVPilot4(at)webtv.net> Sent: Wednesday, April 18, 2001 11:42 AM Subject: RV-List: Red Wing > > Is the flyin for the 21st. still on? I read about the flooding in that > area and I wonder. Can someone who lives in that area let us know? > > Bob Murphy Poplar Grove ILL. (C77) > ________________________________________________________________________________
Subject: Re: METO fuel configuration
Date: Apr 18, 2001
In all the circles that I travel in, METO power is "Maximum Except Take-off" If you have an IO-360 that is 200HP Takeoff, 180 continuos, Then METO Power would be 180 Hp. How that affects minimum fuel, I have no clue. Tailwinds, Doug Rozendaal dougr(at)petroblend.com www.petroblend.com/dougr > > Randy it seems to me this guy has no clue METO is > maximum engine takeoff power ________________________________________________________________________________
Date: Apr 18, 2001
This is an example of why we should keep in touch with one another on the RV-List. Who wants to be the next unlucky person to select this DAR for their inspection? Minimum fuel for METO indeed! Steve Soule Huntington, VT RV-6A in garage at home waiting for tie down space at the airport to emerge from the snow and mud -----Original Message----- In all the circles that I travel in, METO power is "Maximum Except Take-off" If you have an IO-360 that is 200HP Takeoff, 180 continuos, Then METO Power would be 180 Hp. How that affects minimum fuel, I have no clue. > > Randy it seems to me this guy has no clue METO is > maximum engine takeoff power ________________________________________________________________________________
Subject: Re: Whelen strobe connectors question
Date: Apr 18, 2001
FWIW, the Whelen guys at Sun and Fun and Oskosh have a pocket full of what you need and will give it to you for the asking. Russ Werner HRII, Maui ________________________________________________________________________________
Date: Apr 18, 2001
> "Aircraft weighted empty - MINIMUM FUEL. Minimum fuel for balance purposes > is 1/12 gallon per Maximum-Except-Takeoff-Horsepower (METO), and is the > maximum amount of fuel which could be used in weight and balance > computations when low fuel might adversly affect the most critical balance > conditions. so, (METO)*1/12=X gallons or, (180)*1/12=15 gallons > To determine the weight of fuel in punds divide the METO > horsepower by two. METO = 180 180/2=90 just happens that 15 gallons * 6lb/gal = 90 pounds. Minimum fuel for balance purposes is 1/12 gallon per METO. So I interprate this as meaning to do all weight and balance configurations with no less than 90lb of fuel in the calculations or 15 gallons . (180)/2=90 weight of fuel in pounds METO/2 ________________________________________________________________________________
Date: Apr 18, 2001
Subject: Metal Hinges to Fiberglass
I ask my dog Pugsley how he would attach the aluminum hinge to fiberglass parts. This is what he said: You know Clem, It would be nice if you told me what kind of resin those fiberglass parts were made from, however, here are some basics. Drill and counter sink for rivet installation as per the plans. Locate the 3/32 rivets next to the hinge segments rather than in-between them. Remove stress risers (sharp corners) and taper segments as required with small files and Emory paper. Use soft rivets not old hard ones. Sand the fiberglass under the hinge to remove high spots and irregularities. Squeeze the rivets if possible by hand power. Do not counter sink the hinge (It is weak soft material. If you must, use a backer strip under the shop head). Do not over counter sink the fiberglass (Make it thicker, if necessary). As for bonding: The reason to bond, is to stabilize the metal/fiberglass interface. This will greatly improve the life of the junction and keep both rivets and hinge from fretting (Vibration and thermal expansion rates). If your fiberglass parts are made from epoxy resin, Do Not Use polyester as a glue (OK for polyester parts sanded to fresh material). Do Not Use fiberglass "Mat" as a filler with epoxy resigns. Mat is random orientation glass strands bonded with corn starch, that will not wet out with epoxy's (It is formulated to work with polyester. You shouldn't need Mat in the airplane but if you do, make sure it's not the stuff that has been available for years, i.e.. a new product for epoxy). My favorite bonding agents in this application are the ones that stay flexible and are great glues. "Proseal" is a real good candidate and you have a can handy. Epoxy's are great glues but it is hard to find formulations that don't cure hard. There are some Methacrylates(sp) that are good glues for dissimilar materials and plastics (again hard to find). Remember we are looking for a good glue that dampens vibrations and thermal expansion problems and is resistant to aircraft type chemicals. If you must use epoxy, the use of the holes to make a plastic button head interlock, is a good idea. Don't for get to rough up those surfaces. Squeeze those rivets before everything gets hard. Hey, How about a Milk Bone. ________________________________________________________________________________
Subject: Re: Alternate engines Sun & Fun
Date: Apr 18, 2001
> > I wish these people good sucess but I keep remembering people like a man > and his son who installed a Ford V6 in an RV4.It burned more fuel > (heavier) than a Lycosaur. There were many more problems than just > cooling and CG. > > > Bob Murphy Poplar Grove ILL. (C77) > Thanks Bob, You are correct, there has been many an auto conversion that turned out disappointing - interestingly those are the conversions that seem to be remembered. Matching the right engine with the right airframe is a crucial requirement. If the auto installation weights considerably more than the Lycoming the aircraft is designed for then even if it produces more power the performance is likely to be disappointing. The four rotary powered aircraft at Sun & Fun had installations ranged from being lighter than an 0320 to my own which is about 10 lbs heavier than an a typical 0-360 installation. Attention to detail is critical in keeping the weight down as are design decisions. Just like with Lycomings the aircraft which generally weighs the less performs the best - no different with auto installations. In addition to the Wankle Rotary engine producing the right power/weigh ratio (at least for the RV series airframes), a second important factor in the rotary engines relative success as an aircraft power plant is the fact that there are over a dozen RV projects (at least 8 flying) and we all share information. So by doing this we are able to advance the state of the art by not duplicating each others mistakes and all benefiting from the successful approaches. I expect to see many more than the 7 auto conversions that were at Sun & Fun 2001 in the future. You may be interested in knowing that Sun & Fun 2001 issue a plaque for the "Best Auto Engine" of which I had the honor to receive for my Rotary Powered RV-6A. Ed Anderson RV-6A N494BW Rotary Powered "Best Auto Engine" Sun & Fun 2001. ________________________________________________________________________________
Date: Apr 18, 2001
What a good dog!! You going to sell any pups from that dog? I could sure use some help with my canopy. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Gary Graham [mailto:beeb(at)teleport.com] Sent: Wednesday, April 18, 2001 12:34 PM To: RV List Subject: RV-List: Metal Hinges to Fiberglass I ask my dog Pugsley how he would attach the aluminum hinge to fiberglass parts. This is what he said: You know Clem, It would be nice if you told me what kind of resin those fiberglass parts were made from, however, here are some basics. [dog advice deleted] ________________________________________________________________________________
Date: Apr 18, 2001
Does the DAR have any experience inspecting RVs or has he been inspecting very light planes. If you have a gravity fuel system the amount of fuel in the tank can effect the amount of fuel flow. In that case you have to verify METO at a minimum fuel level to ensure you won't starve the engine on takeoff. This should not be an issue with duel fuel pumps on an RV. Alan Kritzman Cedar Rapids, IA RV-8 ________________________________________________________________________________
Date: Apr 18, 2001
Reposted for future archive searches. Don't worry about being flamed, Harvey. This is good info. If anybody flames you I'll flame 'em right back! -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Harvey Sigmon [mailto:flyhars(at)earthlink.net] Sent: Tuesday, April 17, 2001 10:00 PM To: rv-list(at)matronics.com Subject: RE: RV-List: METO fuel configuration > Randy: I just did my W B and FAA inspection last week. I am really confused as to what your DAR wants. What I did was use the sample that Van supplied with my airplane. I my case we used the most extreme condition for aft CG limit, in van's sample he used 5 gallons which works out for my RV-6A with an 0-320. The things that are important are empty weight, Max gross Wt. Most forward , and most aft CG. I have been a Professional Flight Engineer my whole life and I sure don't understand why he is asking for METO for a W B computation. Guys please don't flame my answer. ________________________________________________________________________________
Date: Apr 18, 2001
Subject: sticking bearings
Yesterday I removed and found that the bearing ball from the vernier throttle cable to the carb was stuck tight. I could barely move it with a bolt inside for leverage; not at all with my fingers. This was a good bearing when I installed it about 100 hours ago. Perhaps the heat inside the compartment has an effect on them, (even on the cool side) Another thing for our annual inspection lists. I pulled it because I am changing over to a vernier control on the mixture and replaced the old bracket with Van's newer one which accomodates both controls. Even with a mixture return spring, I still don't trust the single wire control on the mixture. Anyway, as has become the norm, the bracket needs major modifications to fit. The throttle side fits fine, but the mounting hole for the mixture vernier is pointed downwards as if the mixture cable was routed through the firewall from the panel downwards and along the floor. Mine routes above the rudder pedals and through the firewall about 3-4" above the battery box along side the throttle. The bracket is now cut in pieces and will be riveted back together at an appropriate angle. And speaking about rudder pedals, I also just removed mine to comply with Van's AD about welding flanges along the pedal assembly to prevent it from breaking at the joints when you step on them too often or too hard. What a pain in the butt that was, trying to contort myself to reach all the mounting screws and then trying to twist and turn the pedal assembly out of the airplane. I'm not at all looking forward to having to re-install it. By the way, on close inspection there was no sign wear or of imminent failure. My advise to all those still building: Make yourself some kind of large access door so that you can easily get into the area in front of the panel and aft of the firewall. I guarantee, you'll need to get in their a lot more often than you want. Andy ________________________________________________________________________________
Subject: F-819PP
Date: Apr 18, 2001
Ok guys, I give up. I have searched the drawings until my eyes burn. I can not find the rivet type (AN470 or AN426) for attaching the F-819PP on a RV-8A. I have gone over drawings 27 and 27A until I am sick of looking at them. Can someone PLEASE tell me what the rivet callouts are and WHERE they are located. Vince Welch Frustrated In Ohio ________________________________________________________________________________
Date: Apr 18, 2001
Subject: Re: F-819PP
Hey Vince: You might look in the lower left hand cornerof sheet #28 there you will find a small drawing with the calls for the rivets you are looking for Pat ________________________________________________________________________________
Date: Apr 18, 2001
Hey Gang I've been to the Half Moon Bay Dream Machines for the last 7 years as a volunteer, an exhibitor and a tire kicker and let me tell you its one heck of a show. If you love anything mechanical you will be more than satisfied. It is light on aviation related displays so take that into account when you come. I will go to the source (air boss) about the flying wing and give you a post tomorrow. Best Wishes Tom Van Artsdalen, Scott wrote: > > Talk about your misleading advertising! One of the local radio stations has > been running ads that tout the fact that the flying wing is going to be > there. I would be incredibly p*ssed off if I went there and found only an > RC model! > > -- > Scott VanArtsdalen, MCSE, CCNA > Network Administrator > Union Safe Deposit Bank > 209-946-5116 > > -----Original Message----- > From: Thomas McIntyre [mailto:bogeybrother(at)earthlink.net] > Sent: Tuesday, April 17, 2001 9:53 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Dream Machines Show > > > > Of the so called 400 airplanes there last year, about 30 > were on display. The > rest were fly ins parked away from the show area. If you > read carefully the > Northrop flying wing scheduled to be there is an RC model. > Tom > > George Armstrong wrote: > > > > > > The annual Dream Machines show is scheduled for 4/29 in > Half Moon Bay CA > > (HAF). Every sort of machine will be there including the > Northrop Flying > > Wing. Cars, boats, motorcycles tractor pulls... By most > estimates, 400 > > aircraft were there last year. $10 per person entrance > fee. > > > > ________________________________________________________________________________
Date: Apr 18, 2001
Subject: Re: RV4-List: Prop Balancer
Jim; Grab a Sport Aviation Magazine and look in the classified ads under Props. Look for Mark Landoll's Harmonic balancers. They really work and add 12 pounds to the nose on -4's which is a plus. Rob Ray N557RR --- Jim Baker wrote: > --> RV4-List message posted by: "Jim Baker" > > > I am interested in a prop balancer for my RV-4 with > a wooden prop if any > one has one they would be interested in selling. If > not where do I find > a new one? > > Thanks, > > Jim Baker > N513J > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Date: Apr 18, 2001
Subject: FS: RV-4 roll bar
I have an extra RV-4 roll bar for sale. If anyone needs one, please let me know. Thanks, Mike ________________________________________________________________________________
Date: Apr 18, 2001
Subject: Re: Everybody went to S & F except me!
Hi Chuck; Coming from a No-Cal'r who flew his RV4 to SNF, the Dash Seven looked mighty nice, even if all you have to do is dump a bucket of clecoes in the box, shake it and an airplane pops out....Bottom line: RV's ruled, others drooled. The Cross country of two RV4's from NoCal out to Lakeland was an adventure all it's own. 12 hours of flying and five fuel stops. I counted 38 RV's on the grass Sunday plus the four in front of Van's tent and Bruce Bohannons Tiger and -4. Alot more came and went during the week. I even had a chance to visit with the man himself for a casual chat on several subjects. I asked him if he was going to discontinue the -4 now that the -8 was so popular. He responded with a chuckle: If I did that, how would the Harmon Rocket guys get parts... --- Chuck Rabaut wrote: > --> RV4-List message posted by: "Chuck Rabaut" > > > Jim, > > You are oh so right!!! > > Chuck > > > ----- Original Message ----- > From: Jim Bower <rvbuilder(at)hotmail.com> > > Anyhoo, that's why Van's makes RVs in so many > flavors, right? At least we > > have to study plans, measure, make jigs, measure, > drill, measure, sweat, > > measure, and curse to build our airplanes like > real men do! (Instead of > > those wussy -7 & -9 guys!) > > > > Jim > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Subject: Installing wheels
Date: Apr 18, 2001
I have my plane sitting up on the gear but when I installed the wheels I never installed the cotter pins. Can anyone suggest some reading material where I can find out the proper procedure to install the wheels. The manual wasn't very helpful. I know, shocking considering this is an RV-4. All I have done so far is put the tubes and tires on, slide the wheels on the axles, and screw the nut on finger tight. Should I add any more bearing grease than was already on the bearings? Should I grease the axles? How tight should I torque the axle nuts? Any suggestions, pointers, procedures, etc, would be most welcome. ________________________________________________________________________________
Subject: Dent in Aileron - filler?
Date: Apr 18, 2001
Hey guys, I was assembling an aileron some time ago and didn't have the bucking bar on the back of the rivet when I pulled the trigger. I have a set of seriously hideos dents in my top skin. :-( So now, after trying forever to convince myself that it won't show too badly...I just can't do it. So, can skin that thin be doctored with filler, or am I to rebuild the aileron? I can just replace the skin, but it won't be easy.....so I'm looking for suggestions. Bill -4 wings fuselage on it's way ________________________________________________________________________________
Date: Apr 18, 2001
Subject: Re: Installing wheels
Scott,have someone walk you through packing the wheel bearings the first time.The Orndorff RV Construction Finishing Kit Part 1 covers the Axel & Wheel & brake mount .Every annual I take the wheel off , wash the bearings with solvent,check and repack .I inspect the brakes and the entire axel assembly. This is serious buisness, if it is not right you might a very exciting landing. Good Luck Bob Murphy Poplar Grove ILL. (C77) ________________________________________________________________________________
Date: Apr 18, 2001
Gary I'm glad you have appointed yourself as the RV list Censor. Since only your opinion is correct shall we all send ower corrispondance to you for approvial before we post it on the list. Fact-- Rutan a/c mount the pump horizontal, and they work just fine. There are kit cars that mount the pump flat on the frame, they work also. Mark Delano A&P 6A Gary Zilik wrote: > > > THE > > LIST would be a lot more useful, if posters would limit there input on > > technical matters, to what they know to be fact. > > > > Fact: the manufacture recomends mounting the pump at a 45 degree angle. > > Fact: The pump does not pump very well if not purged of air. > > -- > Gary Zilik - Pine Junction, Colorado > RV-6A N99PZ Flying > Engine: Aerosport Power O-360-A1A with H2AD Pistons > Prop: Sensenich 72FM8S9-1-83 > ________________________________________________________________________________
Subject: Re: wiring
Date: Apr 18, 2001
Tom, I don't know if this will make you feel better or worse, but it's relatively cheap and quick to make a second panel. Once you've got the glareshield curvature and side cut-outs determined you can trace them onto a new blank in no time. I made my 2nd panel out of .090 and eliminated the angle along the top edge. The blessing (and curse) of experimentals is that nothing need be cast in stone. Regards, Greg Young RV-6 N6GY Houston (DWH) engine stuff... > > Has anyone else agonized so much over the placement of > instruments and > avionics as I have? Once you drill a hole or do a cutout you > are stuck > with it. And it seems you always figure out a better > location or see a > instrument panel that has it in a better spot after you cut > it or hear > about a new piece of equipment. Finally forced myself to > mark and cut all > of the locations today whether they were in the right spot or not as > production had come to a standstill. Guess I won't be > looking at any new > panel layouts for a while so I wont be disappointed by my > placements. Seems like every place you put a piece ends up being a > compromise. ________________________________________________________________________________
Date: Apr 18, 2001
Subject: Re: Dent in Aileron - filler?
Microbaloons are very light.scuff the surface with sandpaper.use West system epoxy with baloons.It may take several coats.sand it and paint. Bob Murphy Poplar Grove ILL. (C77) ________________________________________________________________________________
Subject: Re: Boost Pump Placement
Date: Apr 18, 2001
> I intend to install an Airflow Performance fuel injection system in my > RV-6A. The instruction manual recommends NOT installing the boost pump > in the engine compartment. That leaves the options of putting it in the > cockpit or in the wing root. It is a fairly large assembly. > > Any recommendations? I put mine (RV6A) in the same spot as the small pump from Van is supposed to go. I took great pains to get it tucked in there as best as I could. I then made a very complicated panel piece to cover that whole section. I will cover the panel with my interior fabric. I might have a small pocket sewed on first. All of my fuel, brakes and electrical lines go through the small side bulkhead rather than around it. When all the interior panels are installed the occupants will not see any wires or lines anywhere. Norman Hunger RV6A Delta BC ________________________________________________________________________________
Date: Apr 19, 2001
Subject: Navaid question
Will someone quote me an approx $$$ of the Navaid equipment. Also, recommendations as to it's usefullness. Can it be installed after wing completion or do I need to purchase while working on wings? Thanks, ________________________________________________________________________________
Date: Apr 18, 2001
--- Thomas McIntyre wrote: > > > Hey Gang > I've been to the Half Moon Bay Dream Machines for the last 7 years as > a volunteer, > an exhibitor and a tire kicker and let me tell you its one heck of a > show. If you > love anything mechanical you will be more than satisfied. It is > light on aviation > related displays so take that into account when you come. I will go > to the source > (air boss) about the flying wing and give you a post tomorrow. > Best Wishes > Tom Should have at least 5 RVs from the SoCAL Wing there. Had 7 last year. At least 5 of us are committed if it is VFR. More are interested but they have not committed yet. Will arrive as a flight for the Overhead. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 780+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Subject: Re: sticking bearings
Date: Apr 20, 2001
[snip] > Anyway, as has > become the norm, the bracket needs major modifications to > fit. The throttle side fits fine, but the mounting hole for the > mixture vernier is pointed downwards as if the mixture cable > was routed through the firewall from the panel downwards and > along the floor. Mine routes above the rudder pedals and > through the firewall about 3-4" above the battery box along > side the throttle. The bracket is now cut in pieces and will > be riveted back together at an appropriate angle. Hmmm... how are you dealing with the geometry of the cable/mixture arm? The reason that bracket is angled that way is mostly a result of the geometry of the arm. I don't see changing it much without messing that up. I was the first one to use that bracket but I already had a custom (longer) cable and wanted to route it up higher -- it comes out the top right hand corner of the recess, straight down the firewall then 90+ degrees to the bracket. A pretty sharp angle but I have a decent radius on it so it worked out all right. But I'd probably consider just running it through down low like Vans has it set up for if I were doing it over. In any case I didn't have to modify the bracket. Anyway, good luck with it however you end up doing it! Randall Henderson, RV-6 N6R (~200 hrs) Portland, OR www.vanshomewing.org ________________________________________________________________________________
Subject: Re: Navaid question
Date: Apr 19, 2001
Hey Bob, For the price go to their site http://www.navaid-devices.com/index.htm . About $1,300.00. After much thinking I installed my Navaid under the right side flooring as indicated in the drawings and photos that they will provide if you ask. I will let others speak to "it's usefulness" I installed a longer push rod ( same diameter thicker wall ) so as to reach across and connect to the left hand control stick. this requires some extra care to get the position of the servo unit just right but it is worth the effort. You can install during wing construction if you want it in the area just outside the bell-crank area ( conventional ) or do it later on in the fuse or at the wing tip. Due to chronic lower back trouble I had my fuselage mounted on an engine stand and tail support of my own designs at the time. If I had to do the install with the aircraft assembled I would install the unit in the wing tip. All three positions seem to work quite well from what I've seen in the archives and on this very helpful rv-list. Flying is fun, Take off eh! {:-) Jim in Kelowna - fitting cowl ----- Original Message ----- From: <Bobpaulo(at)AOL.COM> Sent: Wednesday, April 18, 2001 9:33 PM Subject: RV-List: Navaid question > > Will someone quote me an approx $$$ of the Navaid equipment. > Also, recommendations as to it's usefullness. > Can it be installed after wing completion or do I need to purchase while > working on wings? Thanks, > > ________________________________________________________________________________
Date: Apr 19, 2001
Subject: Andair gascolator question
Can someone explain to me how the Andair gascolator bowl is attached? I've found a few pictures on the web, and I don't see any screws like Vans gascolator has, just an arrow and some safety wire.... Does the whole thing screw into the base, or is it a 'twist and lock' type operation with safety wire added just for extra security? Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A fuselage, O-360-A4A, Sensenich 87" ________________________________________________________________________________
Subject: Re: Andair gascolator question
Date: Apr 19, 2001
Mark, It's a "twist & Lock" which you saftety wire. Chuck & Dave Rowbotham RV-8A (still working F/G) Niantic, CT > >Can someone explain to me how the Andair gascolator bowl is attached? >I've found a few pictures on the web, and I don't see any screws like >Vans gascolator has, just an arrow and some safety wire.... Does the >whole thing screw into the base, or is it a 'twist and lock' type >operation with safety wire added just for extra security? > >Thanks, > >--Mark Navratil >Cedar Rapids, Iowa >RV-8A fuselage, O-360-A4A, Sensenich 87" > > ________________________________________________________________________________
Date: Apr 19, 2001
Subject: Re: Inclination on fuel pump
> >Gary, >Yes it is a fact that the manufacture now (they didn't always) recommends >that the pumps be mounted at a inclination of 45 . I also recommend >installing the pump with some inclination to help purge fumes from the pump >body. >But in over 1000 hr. of flying I never experienced a fuel pump problem, >except for the transistor dying. >You forgot one other thing the manufacture recommends, Not to use these >pumps in aircraft. >Garry LeGare EAA 94585 >Tech Counselor >RV6 Finishing Garry, If the reason for the 45 deg inclination recommendation is to purge air, it seems like the biggest risk would be to have a problem after running a tank dry. How many times have you run a tank dry? Did you ever have any problems with the pump picking up its prime after running a tank dry? Take care, -- Kevin Horton RV-8 (mounting wings) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Date: Apr 19, 2001
sure...you can fill those dinks (and several others you will create along the way) later on when you are up to your elbows in fiberglass. you will probably use epoxy/micro putty/slurry that is a quite common method for filling...keep riveting... paul m n632m...rv6a/180/cs...inspection tommorrow ________________________________________________________________________________
Subject: METO hp and Weight & Balance
Date: Apr 19, 2001
The following has created some interesting traffic and some possible misunderstandings: >> "Aircraft weighted empty - MINIMUM FUEL. Minimum fuel for balance purposes >> is 1/12 gallon per Maximum-Except-Takeoff-Horsepower (METO), and is the >> maximum amount of fuel which could be used in weight and balance >> computations when low fuel might adversely affect the most critical balance >> conditions. Having the allowable or required fuel quantity based loosely on the fuel demands of the engine seems reasonable enough, but this convoluted work of art was probably written by the same guy that does income tax directions... :=)) It is truly hard to tell whether it is talking about a minimum or a maximum, but after reading it about 10 times I conclude that it describes the MAXIMUM amount of fuel we are allowed to use when figuring CG at Minimum Fuel. When you think about it, it makes sense to set an upper limit when talking about "minimum". I wonder why he didn't just say "the maximum amount of fuel which can be used in Minimum Fuel W&B calcs is..." and leave off the drivel about "when low fuel might... bla bla bla...".. you calculate it regardless of what "might" be... FWIW, the results really seem quite liberal... you could go a long time on 10 or 15 gallons, which is what most RV's apparently would be allowed to use. Depending on how the airplane being worked on is configured, you could possibly make something "look better" on paper by using that much fuel in the Min Fuel W&B calcs... but it seems to me one would be wise to know what the CG does at considerably lower fuel than almost 2 hours worth... just IMHO. Johnny Johnson 49MM RV-3 flying ________________________________________________________________________________
Date: Apr 19, 2001
> The fuel pump debate can go on forever and they most likely will work forever mounted in any orientation. The fact is that the manufacture states how they want it mounted, end of story. Of course being homebuilders we can mount the pump anyway we want. Thats the beauty of these little planes. The fact that the pump works mounted horizontal has been proven by Rutan and the kit cars, I accept that. That does not mean it is right. Mine is mounted as per Van's plans and the manufactuers instructions. All opinions must be voiced on the list, can I not voice mine.? > > Gary > > I'm glad you have appointed yourself as the RV list Censor. Since only your > opinion is correct shall we all send ower corrispondance to you for > approvial before we post it on the list. The day I think I know everything I will stop reading the list. Granted there is very little to learn from most of the drabble but sometimes a gold nugget comes through. I am sorry if I offended you in my post, but I was offended by the rightous statement that I responed to. The almighty Tech Consulor is quoted in my post, those are not my words. While I may agree with his statement that the list should limit input to tech matters I don't flame people for voicing there opinion. Opinion is what makes the list a usefull tool. I still stand behind the two facts I posted in my reply. I am offended that you think I was acting as a censor. Can I not disagree with someones statement? Gary Just a builder who don't know nothin > > > Gary Zilik wrote: > > > > > > THE > > > LIST would be a lot more useful, if posters would limit there input on > > > technical matters, to what they know to be fact. > > > > > > > Fact: the manufacture recomends mounting the pump at a 45 degree angle. > > > > Fact: The pump does not pump very well if not purged of air. > > > > -- ________________________________________________________________________________
Subject: Re: METO hp and Weight & Balance
Date: Apr 19, 2001
04/19/2001 10:24:12 AM Great job of "cypering" this for us Johnny. Now let me ask you one question; WHY? I mean why would 2 hours fuel put you in jeopardy more than nearly dry tanks? If 10 gallons would put you in an aft CG condition then wouldn't full tanks put you in a worse way? Can you explain the reasoning for the DAR's concern to a simple country boy. Please use one syllable words or less, if not I'm gonna have to call that damn Pugsley. That dog really knows his milk bones. Thanks Eric Henson "Johnny Johnson" (at)matronics.com on 04/19/2001 09:24:27 AM Please respond to rv-list(at)matronics.com Sent by: owner-rv-list-server(at)matronics.com cc: Subject: RV-List: METO hp and Weight & Balance The following has created some interesting traffic and some possible misunderstandings: >> "Aircraft weighted empty - MINIMUM FUEL. Minimum fuel for balance purposes >> is 1/12 gallon per Maximum-Except-Takeoff-Horsepower (METO), and is the >> maximum amount of fuel which could be used in weight and balance >> computations when low fuel might adversely affect the most critical balance >> conditions. Having the allowable or required fuel quantity based loosely on the fuel demands of the engine seems reasonable enough, but this convoluted work of art was probably written by the same guy that does income tax directions... :=)) It is truly hard to tell whether it is talking about a minimum or a maximum, but after reading it about 10 times I conclude that it describes the MAXIMUM amount of fuel we are allowed to use when figuring CG at Minimum Fuel. When you think about it, it makes sense to set an upper limit when talking about "minimum". I wonder why he didn't just say "the maximum amount of fuel which can be used in Minimum Fuel W&B calcs is..." and leave off the drivel about "when low fuel might... bla bla bla...".. you calculate it regardless of what "might" be... FWIW, the results really seem quite liberal... you could go a long time on 10 or 15 gallons, which is what most RV's apparently would be allowed to use. Depending on how the airplane being worked on is configured, you could possibly make something "look better" on paper by using that much fuel in the Min Fuel W&B calcs... but it seems to me one would be wise to know what the CG does at considerably lower fuel than almost 2 hours worth... just IMHO. Johnny Johnson 49MM RV-3 flying ________________________________________________________________________________
Subject: Everybody went to S & F except me!
Date: Apr 19, 2001
Rob, I'm glad you had fun and that's great to hear, but you should've reminded him that a Quick Build 4 is what's really needed (I mean I'm not complaining {well not at this moment} but God knows the 4 is way cool but God also knows you sure suffer trying to figure out how to get it together). Chuck ----- Original Message ----- From: rob ray <smokyray(at)yahoo.com> Sent: Wednesday, April 18, 2001 9:34 PM Subject: Re: RV4-List: Fw: RV-List: Everybody went to S & F except me! > > Hi Chuck; > > Coming from a No-Cal'r who flew his RV4 to SNF, the > Dash Seven looked mighty nice, even if all you have to > do is dump a bucket of clecoes in the box, shake it > and an airplane pops out....Bottom line: RV's ruled, > others drooled. > The Cross country of two RV4's from NoCal out to > Lakeland was an adventure all it's own. 12 hours of > flying and five fuel stops. I counted 38 RV's on the > grass Sunday plus the four in front of Van's tent and > Bruce Bohannons Tiger and -4. Alot more came and went > during the week. I even had a chance to visit with > the man himself for a casual chat on several subjects. > I asked him if he was going to discontinue the -4 now > that the -8 was so popular. He responded with a > chuckle: If I did that, how would the Harmon Rocket > guys get parts... > > > --- Chuck Rabaut wrote: > > --> RV4-List message posted by: "Chuck Rabaut" > > > > > > Jim, > > > > You are oh so right!!! > > > > Chuck > > > > > > ----- Original Message ----- > > From: Jim Bower <rvbuilder(at)hotmail.com> > > > Anyhoo, that's why Van's makes RVs in so many > > flavors, right? At least we > > > have to study plans, measure, make jigs, measure, > > drill, measure, sweat, > > > measure, and curse to build our airplanes like > > real men do! (Instead of > > > those wussy -7 & -9 guys!) > > > > > > Jim > > > > > > > > through > > > > http://www.matronics.com/archives > > http://www.matronics.com/emaillists > > > > Matronics! > > > > > > > > > > > > > Yahoo! Auctions - buy the things you want at great prices > http://auctions.yahoo.com/ > > ________________________________________________________________________________
Subject: Inclination on fuel pump
Date: Apr 19, 2001
Information is abundant... Wisdom is scarce. Ed Cole RV6A N2169D Flying RV6A N648RV Finishing > -----Original Message----- > From: Gary Zilik [SMTP:zilik(at)bewellnet.com] > Sent: Thursday, April 19, 2001 6:39 AM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Inclination on fuel pump > > > > > > The fuel pump debate can go on forever and they most likely will work > forever > mounted in any orientation. The fact is that the manufacture states how > they > want it mounted, end of story. Of course being homebuilders we can mount > the > pump anyway we want. Thats the beauty of these little planes. The fact > that > the pump works mounted horizontal has been proven by Rutan and the kit > cars, I > accept that. That does not mean it is right. Mine is mounted as per Van's > plans and the manufactuers instructions. All opinions must be voiced on > the > list, can I not voice mine.? > > > > > Gary > > > > I'm glad you have appointed yourself as the RV list Censor. Since only > your > > opinion is correct shall we all send ower corrispondance to you for > > approvial before we post it on the list. > > The day I think I know everything I will stop reading the list. Granted > there > is very little to learn from most of the drabble but sometimes a gold > nugget > comes through. I am sorry if I offended you in my post, but I was offended > by > the rightous statement that I responed to. The almighty Tech Consulor is > quoted in my post, those are not my words. While I may agree with his > statement that the list should limit input to tech matters I don't flame > people for voicing there opinion. Opinion is what makes the list a usefull > tool. I still stand behind the two facts I posted in my reply. > > > I am offended that you think I was acting as a censor. Can I not disagree > with > someones statement? > > Gary > Just a builder who don't know nothin > > > > > > > Gary Zilik wrote: > > > > > > > > > THE > > > > LIST would be a lot more useful, if posters would limit there input > on > > > > technical matters, to what they know to be fact. > > > > > > > > > > Fact: the manufacture recomends mounting the pump at a 45 degree > angle. > > > > > > Fact: The pump does not pump very well if not purged of air. > > > > > > -- > > > > > ________________________________________________________________________________
Subject: Dream Machines Show
Date: Apr 19, 2001
I appreciate that. Just to clear things up, I've only heard good things about the show. I just wish the ads were more clear. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: Thomas McIntyre [mailto:bogeybrother(at)earthlink.net] Sent: Wednesday, April 18, 2001 6:05 PM To: rv-list(at)matronics.com Subject: Re: RV-List: Dream Machines Show Hey Gang I've been to the Half Moon Bay Dream Machines for the last 7 years as a volunteer, an exhibitor and a tire kicker and let me tell you its one heck of a show. If you love anything mechanical you will be more than satisfied. It is light on aviation related displays so take that into account when you come. I will go to the source (air boss) about the flying wing and give you a post tomorrow. Best Wishes Tom Van Artsdalen, Scott wrote: > > Talk about your misleading advertising! One of the local radio stations has > been running ads that tout the fact that the flying wing is going to be > there. I would be incredibly p*ssed off if I went there and found only an > RC model! > > -- > Scott VanArtsdalen, MCSE, CCNA > Network Administrator > Union Safe Deposit Bank > 209-946-5116 > > -----Original Message----- > From: Thomas McIntyre [mailto:bogeybrother(at)earthlink.net] > Sent: Tuesday, April 17, 2001 9:53 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Dream Machines Show > McIntyre > > > Of the so called 400 airplanes there last year, about 30 > were on display. The > rest were fly ins parked away from the show area. If you > read carefully the > Northrop flying wing scheduled to be there is an RC model. > Tom > > George Armstrong wrote: > Armstrong" > > > > > The annual Dream Machines show is scheduled for 4/29 in > Half Moon Bay CA > > (HAF). Every sort of machine will be there including the > Northrop Flying > > Wing. Cars, boats, motorcycles tractor pulls... By most > estimates, 400 > > aircraft were there last year. $10 per person entrance > fee. > > > > ________________________________________________________________________________
Date: Apr 19, 2001
All of this doesn't make any sense anyway. Only "unuseable" fuel should used for these calculations. You want to have C.G. in allowable range when fuel runs out so you can glide down to a controlled landing, don't you? Get another DAR if he can't see that. Finn Johnny Johnson wrote: > > The following has created some interesting traffic and some possible > misunderstandings: > > >> "Aircraft weighted empty - MINIMUM FUEL. Minimum fuel for balance > purposes > >> is 1/12 gallon per Maximum-Except-Takeoff-Horsepower (METO), and is the > >> maximum amount of fuel which could be used in weight and balance > >> computations when low fuel might adversely affect the most critical > balance > >> conditions. NetZero Platinum No Banner Ads and Unlimited Access Sign Up Today - Only $9.95 per month! http://www.netzero.net ________________________________________________________________________________
Date: Apr 19, 2001
I don't know about the D.A.R.'s concerns, but in my RV-6, the more fuel you burn, the more the CG moves aft. If I fly at maximum takeoff weight with two heavy bubbas on board, I cannot fly down to less than 10 gallons of fuel on board without exceeding the aft CG limit on the airplane. Randy Pflanzer N417G RV-6 (144 hours) > > >Great job of "cypering" this for us Johnny. Now let me ask you one >question; WHY? > >I mean why would 2 hours fuel put you in jeopardy more than nearly dry >tanks? If 10 gallons would put you in an aft CG condition then wouldn't >full tanks put you in a worse way? Can you explain the reasoning for the >DAR's concern to a simple country boy. Please use one syllable words or >less, if not I'm gonna have to call that damn Pugsley. That dog really >knows his milk bones. > >Thanks > >Eric Henson > > >"Johnny Johnson" (at)matronics.com on 04/19/2001 09:24:27 >AM > >Please respond to rv-list(at)matronics.com > > >Sent by: owner-rv-list-server(at)matronics.com > > >To: "RV List" >cc: >Subject: RV-List: METO hp and Weight & Balance > > >The following has created some interesting traffic and some possible >misunderstandings: > >>> "Aircraft weighted empty - MINIMUM FUEL. Minimum fuel for balance >purposes >>> is 1/12 gallon per Maximum-Except-Takeoff-Horsepower (METO), and is the >>> maximum amount of fuel which could be used in weight and balance >>> computations when low fuel might adversely affect the most critical >balance >>> conditions. > >Having the allowable or required fuel quantity based loosely on the fuel >demands of the engine seems reasonable enough, but this convoluted work of >art was probably written by the same guy that does income tax directions... >:=)) > >It is truly hard to tell whether it is talking about a minimum or a >maximum, >but after reading it about 10 times I conclude that it describes the >MAXIMUM >amount of fuel we are allowed to use when figuring CG at Minimum Fuel. >When >you think about it, it makes sense to set an upper limit when talking about >"minimum". I wonder why he didn't just say "the maximum amount of fuel >which can be used in Minimum Fuel W&B calcs is..." and leave off the drivel >about "when low fuel might... bla bla bla...".. you calculate it regardless >of what "might" be... > >FWIW, the results really seem quite liberal... you could go a long time on >10 or 15 gallons, which is what most RV's apparently would be allowed to >use. Depending on how the airplane being worked on is configured, you >could >possibly make something "look better" on paper by using that much fuel in >the Min Fuel W&B calcs... but it seems to me one would be wise to know what >the CG does at considerably lower fuel than almost 2 hours worth... just >IMHO. > >Johnny Johnson >49MM RV-3 flying > > ________________________________________________________________________________
Date: Apr 19, 2001
I reread the ad in the Pacific Flyer last night and it showed a picture of the Flying Wing. It said it was a model of the thing but not an RC model. Ed Cole RV6A N2169D Flying > -----Original Message----- > From: Van Artsdalen, Scott [SMTP:svanarts(at)unionsafe.com] > Sent: Thursday, April 19, 2001 9:15 AM > To: rv-list(at)matronics.com > Subject: RE: RV-List: Dream Machines Show > > > > I appreciate that. Just to clear things up, I've only heard good things > about the show. I just wish the ads were more clear. > -- > Scott VanArtsdalen, MCSE, CCNA > Network Administrator > Union Safe Deposit Bank > 209-946-5116 > > > -----Original Message----- > From: Thomas McIntyre > [mailto:bogeybrother(at)earthlink.net] > Sent: Wednesday, April 18, 2001 6:05 PM > To: rv-list(at)matronics.com > Subject: Re: RV-List: Dream Machines Show > > > > Hey Gang > I've been to the Half Moon Bay Dream Machines for the last > 7 > years as a volunteer, > an exhibitor and a tire kicker and let me tell you its one > heck of a show. If you > love anything mechanical you will be more than satisfied. > It is light on aviation > related displays so take that into account when you come. > I > will go to the source > (air boss) about the flying wing and give you a post > tomorrow. > Best Wishes > Tom > > > Van Artsdalen, Scott wrote: > > > > > > Talk about your misleading advertising! One of the > local > radio stations has > > been running ads that tout the fact that the flying wing > is going to be > > there. I would be incredibly p*ssed off if I went there > and found only an > > RC model! > > > > -- > > Scott VanArtsdalen, MCSE, CCNA > > Network Administrator > > Union Safe Deposit Bank > > 209-946-5116 > > > > -----Original Message----- > > From: Thomas McIntyre > [mailto:bogeybrother(at)earthlink.net] > > Sent: Tuesday, April 17, 2001 > 9:53 > PM > > To: rv-list(at)matronics.com > > Subject: Re: RV-List: Dream > Machines Show > > > McIntyre > > > > > > Of the so called 400 airplanes there > last > year, about 30 > > were on display. The > > rest were fly ins parked away from the > show area. If you > > read carefully the > > Northrop flying wing scheduled to be > there > is an RC model. > > Tom > > > > George Armstrong wrote: > > > Armstrong" > > > > > > > > The annual Dream Machines show is > scheduled for 4/29 in > > Half Moon Bay CA > > > (HAF). Every sort of machine will be > there including the > > Northrop Flying > > > Wing. Cars, boats, motorcycles > tractor > pulls... By most > > estimates, 400 > > > aircraft were there last year. $10 > per > person entrance > > fee. > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 19, 2001
Kevan, excellent question and example of why your postings are among the ones I always read. Yes, on my Q2 I used to run the tank dry quite often. Over the course of approx. 1050 hr, I probably ran the main tank dry 100 times, and no, I never had a problem with the pumps self priming abilities. To properly understand my answer you should be supplied with an explanation of the fuel system of my particular Q2. The fuel system was composed of two fuel tanks, a 22 gal lower tank and a 6.5 gal header tank above it. Fuel was pumped from the lower tank to the header tank by the same model Facet pump as Van recommends. The pump was mounted horizontally on top of the lower fuel tank, perpendicular to the direction of flight. The pump ran continuously as the header tank incorporated an overflow tube, that returned the excess fuel to the lower tank. When the lower tank ran dry, I would shut the pump off. The lower tank fuel gauge was mechanical similar to a Citabria wing tank, and was fairly accurate. The header tank which had a deep sump, and was well baffled, used a sight tube mounted on the dash, which was extremely accurate. The carb was gravity fed from the header tank. Since the engine burned approx. 3.5 gal per hr in cruise, it was not unusual on short flights to start out with only a couple of gallons in the lower tank, and run it dry. However there are some significant differences between the above system and the standard system in an RV6. The RV6 pump must pull fuel through approx. 75" of 3/8 th tube, a valve and 5 bends. My Q2 system, 16" of 1/4" tube and one bend. But the RV6 system has a significant advantage, the engine driven pump is also pulling. Unless of coarse you have a engine driven pump failure just as you run a tank dry. I had the pump fail twice in the 1000 + hrs both times it was the switching transistor. I replaced the transistor, which used to be surface mounted and easy to replace. Why did the transistors fail? I don't know. Could it have been from the vibration of the pump running dry? Quite possibly as the pumps really rattle when they start to run dry. Garry LeGare, EAA 94585 Tech Counselor RV6 Finishing Kevin Horton wrote: > > > > > > Garry, > > If the reason for the 45 deg inclination recommendation is to purge > air, it seems like the biggest risk would be to have a problem after > running a tank dry. > > How many times have you run a tank dry? Did you ever have any > problems with the pump picking up its prime after running a tank dry? > > Take care, > > -- > Kevin Horton RV-8 (mounting wings) > Ottawa, Canada > http://eccentrix.com/misc/rv8/rv8.html > > _- ________________________________________________________________________________
Date: Apr 19, 2001
Gary, No one has a problem with you commenting on issues. It's how. Answering my post with the facts comment and referring to me as a "almighty Tech Counselor" is what ticks people off. Each year as a "almighty Tech Counselor" I inspect at least 35 projects and field about 100 panicky phone calls from builders. I receive nothing for this, except the satisfaction of knowing I've helped a fellow builder. Garry LeGare EAA 94585 Tech Counselor RV6 Finishing Gary Zilik wrote: > > > > > The fuel pump debate can go on forever and they most likely will work forever > mounted in any orientation. The fact is that the manufacture states how they > want it mounted, end of story. Of course being homebuilders we can mount the > pump anyway we want. Thats the beauty of these little planes. The fact that > the pump works mounted horizontal has been proven by Rutan and the kit cars, I > accept that. That does not mean it is right. Mine is mounted as per Van's > plans and the manufactuers instructions. All opinions must be voiced on the > list, can I not voice mine.? > > > > > Gary > > > > I'm glad you have appointed yourself as the RV list Censor. Since only your > > opinion is correct shall we all send ower corrispondance to you for > > approvial before we post it on the list. > > The day I think I know everything I will stop reading the list. Granted there > is very little to learn from most of the drabble but sometimes a gold nugget > comes through. I am sorry if I offended you in my post, but I was offended by > the rightous statement that I responed to. The almighty Tech Consulor is > quoted in my post, those are not my words. While I may agree with his > statement that the list should limit input to tech matters I don't flame > people for voicing there opinion. Opinion is what makes the list a usefull > tool. I still stand behind the two facts I posted in my reply. > > I am offended that you think I was acting as a censor. Can I not disagree with > someones statement? > > Gary > Just a builder who don't know nothin > > > > > > > Gary Zilik wrote: > > > > > > > > > THE > > > > LIST would be a lot more useful, if posters would limit there input on > > > > technical matters, to what they know to be fact. > > > > > > > > > > Fact: the manufacture recomends mounting the pump at a 45 degree angle. > > > > > > Fact: The pump does not pump very well if not purged of air. > > > > > > -- > ________________________________________________________________________________
Subject: N-Number size - 3" or 12"
Date: Apr 19, 2001
17, 2001) at 04/19/2001 02:44:54 PM Hi All, As my -4 nears completion, I have initiated conversations with several DARs. One was "quite certain" my aircraft would require 12" N-numbers due to its high cruising speed. I'm hopeful, but I doubt that it will go any faster than any other RV-4 (with a 180 hp). Can anyone provide me with their help/experiences regarding N-number dimensions? Thanks in advance, Dean Pichon RV-4 Arlington, MA **** This message is from Arthur D. Little, Inc., and/or one of Arthur D. Little's subsidiaries or affiliates and may contain confidential business information. It is intended for the addressee only and may not be copied without our permission. If you are not the intended recipient please contact the sender as soon as possible.**** ________________________________________________________________________________
Date: Apr 19, 2001
From: Thomas McIntyre <bogeybrother(at)earthlink.net>
Subject: Dream Machines @ HMB
I just got of the phone with the Chino air Musuem and they said YES that the Northrop Flying Wing will be there. Not a scale model as I earlier reported Tom ________________________________________________________________________________
Subject: Re: N-Number size - 3" or 12"
Date: Apr 19, 2001
Here is the controlling FAR... 45.29 Size of marks. (a) Except as provided in paragraph (f) of this section, each operator of an aircraft shall display marks on the aircraft meeting the size requirements of this section. (b) Height. Except as provided in paragraph (h) of this part, the nationality and registration marks must be of equal height and on - (1) Fixed-wing aircraft, must be at least 12 inches high, except that: (i) An aircraft displaying marks at least 2 inches high before November 1, 1981 and an aircraft manufactured after November 2, 1981, but before January 1, 1983, may display those marks until the aircraft is repainted or the marks are repainted, restored, or changed; (ii) Marks at least 3 inches high may be displayed on a glider; (iii) Marks at least 3 inches high may be displayed on an aircraft for which an experimental certificate has been issued under 21.191(d) or 21.191(g) for operating as an exhibition aircraft or as an amateur-built aircraft when the maximum cruising speed of the aircraft does not exceed 180 knots CAS; and (iv) Marks may be displayed on an exhibition, antique, or other aircraft in accordance with 45.22. (2) Airships, spherical balloons, and nonspherical balloons, must be at least 3 inches high; and (3) Rotorcraft, must be at least 12 inches high, except that rotorcraft displaying before April 18, 1983, marks required by 45.29(b)(3) in effect on April 17, 1983, and rotorcraft manufactured on or after April 18, 1983, but before December 31, 1983, may display those marks until the aircraft is repainted or the marks are repainted, restored, or changed. (c) Width. Characters must be two-thirds as wide as they are high, except the number "1", which must be one-sixth as wide as it is high, and the letters "M" and "W" which may be as wide as they are high. (d) Thickness. Characters must be formed by solid lines one-sixth as thick as the character is high. (e) Spacing. The space between each character may not be less than one-fourth of the character width. (f) If either one of the surfaces authorized for displaying required marks under 45.25 is large enough for display of marks meeting the size requirements of this section and the other is not, full-size marks shall be placed on the larger surface. If neither surface is large enough for full-size marks, marks as large as practicable shall be displayed on the larger of the two surfaces. If any surface authorized to be marked by 45.27 is not large enough for full-size marks, marks as large as practicable shall be placed on the largest of the authorized surfaces. (g) Uniformity. The marks required by this part for fixed-wing aircraft must have the same height, width, thickness, and spacing on both sides of the aircraft. (h) After March 7, 1988, each operator of an aircraft penetrating an ADIZ or DEWIZ shall display on that aircraft temporary or permanent nationality and registration marks at least 12 inches high. Section iii is for you. Unless you intend to fly a ADIZ or DEWIZ then if your cruising speed is 180 KNOTS CAS you can use the 3". Note! Canada doesn't count. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh ----- Original Message ----- From: <pichon.dean(at)ADLittle.com> Sent: Thursday, April 19, 2001 1:46 PM Subject: RV-List: N-Number size - 3" or 12" > > Hi All, > > As my -4 nears completion, I have initiated conversations with several > DARs. One was "quite certain" my aircraft would require 12" N-numbers due > to its high cruising speed. I'm hopeful, but I doubt that it will go any > faster than any other RV-4 (with a 180 hp). Can anyone provide me with > their help/experiences regarding N-number dimensions? > > Thanks in advance, > > Dean Pichon > RV-4 > Arlington, MA > **** This message is from Arthur D. Little, Inc., and/or one of > Arthur D. Little's subsidiaries or affiliates and may contain > confidential business information. It is intended for the addressee > only and may not be copied without our permission. If you are not > the intended recipient please contact the sender as soon as possible.**** > > ________________________________________________________________________________
From: "Jones, Bryan D." <bryan.jones@lyondell-citgo.com>
Date: Apr 19, 2001
Here are a couple of things to consider, based upon my experience: 1. check the archives. There have been some in-depth debates on this in the last couple of years. 2. YOU'RE the manufacturer and you specify top speeds, cruise speeds, etc. Don't (necessarily) go by what someone else say's their plane will do. Remember, RV's have a reputation as being a fast plane. Don't let this work unfairly against you without justification. 3. My FAA rep just asked if the plane fell within the speed requirements for 3" letters. I truthfully answered and said I expect that it will. He said OK. 4. As with this METO stuff, it's possible you'll get a DAR or FAA rep who is out in left field. Do your homework and present your case. You may get what you want. 12" letters are kind of like voluntarily allowing a search of your car when stopped for a ticket - unnecessary legal exposure. But go ahead with allowing the search (12" letters!) if you think they're going to take you to jail otherwise. Bryan Jones -8 765BJ Pearland, Texas ________________________________________________________________________________
Subject: Bottom Cowling reinforcement
Date: Apr 19, 2001
Hellow everyone. I am a new RV4 owner, and could use some ideas on how to reinforce my bottom cowl so that aerodynamic pressure at cruise speeds won't push the cowl in to the point of the exhaust stacks rubbing and wearing through the cowl. Any ideas would be appreciated. Steve Mullins, PhD. Associate Professor of Economics Drury University 417 873 7299 (Office) 417 873 7537 (Fax) 417 889 5609 (Home) ----- Original Message ----- From: "rob ray" <smokyray(at)yahoo.com> Sent: Wednesday, April 18, 2001 9:34 PM Subject: Re: RV4-List: Fw: RV-List: Everybody went to S & F except me! > --> RV4-List message posted by: rob ray > > Hi Chuck; > > Coming from a No-Cal'r who flew his RV4 to SNF, the > Dash Seven looked mighty nice, even if all you have to > do is dump a bucket of clecoes in the box, shake it > and an airplane pops out....Bottom line: RV's ruled, > others drooled. > The Cross country of two RV4's from NoCal out to > Lakeland was an adventure all it's own. 12 hours of > flying and five fuel stops. I counted 38 RV's on the > grass Sunday plus the four in front of Van's tent and > Bruce Bohannons Tiger and -4. Alot more came and went > during the week. I even had a chance to visit with > the man himself for a casual chat on several subjects. > I asked him if he was going to discontinue the -4 now > that the -8 was so popular. He responded with a > chuckle: If I did that, how would the Harmon Rocket > guys get parts... > > > --- Chuck Rabaut wrote: > > --> RV4-List message posted by: "Chuck Rabaut" > > > > > > Jim, > > > > You are oh so right!!! > > > > Chuck > > > > > > ----- Original Message ----- > > From: Jim Bower <rvbuilder(at)hotmail.com> > > > Anyhoo, that's why Van's makes RVs in so many > > flavors, right? At least we > > > have to study plans, measure, make jigs, measure, > > drill, measure, sweat, > > > measure, and curse to build our airplanes like > > real men do! (Instead of > > > those wussy -7 & -9 guys!) > > > > > > Jim > > > > > > > > through > > > > http://www.matronics.com/archives > > http://www.matronics.com/emaillists > > > > Matronics! > > > > > > > > > > > > > Yahoo! Auctions - buy the things you want at great prices > http://auctions.yahoo.com/ > > ________________________________________________________________________________
Date: Apr 19, 2001
Subject: Re: Raleigh, NC visit
In a message dated 4/16/01 5:33:33 PM Eastern Daylight Time, e.fortner(at)worldnet.att.net writes: << a small airport where locals hangout and do a lot of hanger flying and lying. >> Earl Fortner- what airport is that? Dale Ensing RV builder - new to Charlotte ________________________________________________________________________________
Date: Apr 19, 2001
Mark, Are you talking about the fuel bowl to the housing or the housing to the firewall. For the fuel bowl itself, line up the arrow on the bowl with the front of the upper housing. There is an aligning pine in the upper housing that fits into the top of the fuel bowl lip. Then the locking ring screws onto the fuel bowl. Tighten the locking ring hand tight only. Then you can use safety wire to keep it in place. If you are talking about the housing to the firewall I made a brackett out of angle aluminum that bolts to the top of the housing. Mike Robertson RV8A >From: czechsix(at)juno.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Andair gascolator question >Date: Thu, 19 Apr 2001 06:41:25 -0500 > > >Can someone explain to me how the Andair gascolator bowl is attached? >I've found a few pictures on the web, and I don't see any screws like >Vans gascolator has, just an arrow and some safety wire.... Does the >whole thing screw into the base, or is it a 'twist and lock' type >operation with safety wire added just for extra security? > >Thanks, > >--Mark Navratil >Cedar Rapids, Iowa >RV-8A fuselage, O-360-A4A, Sensenich 87" > > ________________________________________________________________________________
Date: Apr 19, 2001
Mark, The bowl has a small pin in the front and another in the back that point up. The locations of each pin is marked with a small circle on the bowl. These are indexing pins. The pins mate with the top part of the gascolator. There is an o-ring around the top of the bowl. Just line up the pins and push the bowl up into the body. The o-ring makes it a tight fit. There is a lock ring with threads that spins freely on the base of the gascolator body. Once the bowl is inserted spin the ring to ingage the threads on the bowl and tighten it up. The spinning lock ring has several holes through it for safety wiring. These are first class units. The feature that is note worthy is where the in and out fittings attach. Once a fitting is tightened, it may point in the wrong direction. No problem, the assembly the fitting screws into will come out and can be rotated and reinstalled to get the fitting pointing in the right direction! I have the fuel selector also, and it is excellent too. Well worth the extra $$. Jerry Calvert Edmond Ok -6 fuselage/finish kit ----- Original Message ----- From: <czechsix(at)juno.com> Sent: Thursday, April 19, 2001 6:41 AM Subject: RV-List: Andair gascolator question > > Can someone explain to me how the Andair gascolator bowl is attached? > I've found a few pictures on the web, and I don't see any screws like > Vans gascolator has, just an arrow and some safety wire.... Does the > whole thing screw into the base, or is it a 'twist and lock' type > operation with safety wire added just for extra security? > > Thanks, > > --Mark Navratil > Cedar Rapids, Iowa > RV-8A fuselage, O-360-A4A, Sensenich 87" > > ________________________________________________________________________________
Date: Apr 19, 2001
Subject: Re: Engine Movement
In a message dated 4/17/01 3:28:19 PM Pacific Daylight Time, jwiza1(at)yahoo.com writes: << As my engine mounts settled inI found the front of the engine dropped approx 1/4-3/8". installing a washer on the bottom of the mounts corrected the problem >> Question: Do you mean install a washer at the engine mount to fuselage or at lower engine to engine mounts? Harry Crosby Pleasanton, California RV-6, finish kit stuff ________________________________________________________________________________
Date: Apr 19, 2001
Garry, While your Q2 experience does give a certain level of comfort, the differences between the Q2 and RV design and operation make it difficult to take full credit for the Q2 service history when considering our aircraft. For example, it seems that you have never ran the pump dry and then immediately had it reprime in the Q2. Even if your fuel system was installed as Van recommended, it would be a good idea to find out what happens when you run a tank dry. I would rather do this test under controlled conditions than to find out the hard way when this happens and you are not expecting it. It might be a good idea to practice some simulated forced landings (i.e. pull the engine to idle and leave it there until touch down). Then once you have confidence that you are 100% current in forced landings, fly around overhead a quiet airport with a reasonably long runway, and run on one tank until the engine quits. Note what warnings you have that the engine is about to quit. Wait a few seconds (to make this test somewhat representative of what would happen in a real event), then do whatever procedure you have established for an engine failure (boost pump ON, change tanks, mixture to RICH, carb heat ON, etc). Note how long it takes for the engine to restart. If your engine has difficulty restarting, you may need to change your emergency procedures, or you may need to change your fuel system design (or maybe you just have a bad component that needs to be changed) to allow it to purge the air better. This is a good test for anyone to do during their test phase. It will help validate that your fuel system design and components are acceptable. It will also help validate your emergency procedures, and it will help you be better prepared for a real event if it ever occurs. It will also give you confidence if you ever have a low fuel situation, and want to deliberately run one tank dry. You'll feel a lot better about doing that if you have done this test. Take care, Kevin > >Kevan, excellent question and example of why your postings are among >the ones I >always read. > >Yes, on my Q2 I used to run the tank dry quite often. Over the >course of approx. >1050 hr, I probably ran the main tank dry 100 times, and no, I never had a >problem with the pumps self priming abilities. >To properly understand my answer you should be supplied with an explanation of >the fuel system of my particular Q2. >The fuel system was composed of two fuel tanks, a 22 gal lower tank and a 6.5 >gal header tank above it. >Fuel was pumped from the lower tank to the header tank by the same model Facet >pump as Van recommends. >The pump was mounted horizontally on top of the lower fuel tank, perpendicular >to the direction of flight. The pump ran continuously as the header tank >incorporated an overflow tube, that returned the excess fuel to the >lower tank. >When the lower tank ran dry, I would shut the pump off. The lower tank fuel >gauge was mechanical similar to a Citabria wing tank, and was fairly accurate. >The header tank which had a deep sump, and was well baffled, used a sight tube >mounted on the dash, which was extremely accurate. The carb was >gravity fed from >the header tank. >Since the engine burned approx. 3.5 gal per hr in cruise, it was not >unusual on >short flights to start out with only a couple of gallons in the >lower tank, and >run it dry. > >However there are some significant differences between the above >system and the >standard system in an RV6. > > The RV6 pump must pull fuel through approx. 75" of 3/8 th tube, a valve and 5 >bends. >My Q2 system, 16" of 1/4" tube and one bend. >But the RV6 system has a significant advantage, the engine driven pump is also >pulling. Unless of coarse you have a engine driven pump failure just >as you run >a tank dry. > >I had the pump fail twice in the 1000 + hrs both times it was the switching >transistor. I replaced the transistor, which used to be surface >mounted and easy >to replace. >Why did the transistors fail? I don't know. >Could it have been from the vibration of the pump running dry? Quite >possibly as >the pumps really rattle when they start to run dry. >Garry LeGare, EAA 94585 >Tech Counselor >RV6 Finishing > >Kevin Horton wrote: > >> > >> > >> >> Garry, >> >> If the reason for the 45 deg inclination recommendation is to purge >> air, it seems like the biggest risk would be to have a problem after >> running a tank dry. >> >> How many times have you run a tank dry? Did you ever have any >> problems with the pump picking up its prime after running a tank dry? >> >> Take care, >> >> -- >> Kevin Horton RV-8 (mounting wings) >> Ottawa, Canada >> http://eccentrix.com/misc/rv8/rv8.html >> > > _- > ________________________________________________________________________________
Date: Apr 19, 2001
Subject: Facet Pump Orientation
After following with great interest the thread on pump orientation I decided to e-mail the manufacturer for their advice. FWIW here is their unedited reply: "Harry: It is not essential to have the pump positioned as recommended. The pump will work in most any orientation....the preferred orientation is intended to minimize vapor lock and to assure good priming. Regards Craig S. Weber Technical Director Purolator Products" The last phrase sorta says it all in my opinion. Like I said, for what it's worth. Harry Crosby Pleasanton, California RV-6, finish kit stuff Harry Crosby Pleasanton, California RV-6, finish kit stuff ________________________________________________________________________________
Date: Apr 19, 2001
Subject: Re: RV4-List: Bottom Cowling reinforcement
Hi Steve; What type exhaust are you using, how much clearance do the pipes have when not going 150 knots and how is your cowl attached? Rob Ray RV4 N557RR --- Steve Mullins wrote: > --> RV4-List message posted by: "Steve Mullins" > > > Hellow everyone. I am a new RV4 owner, and could use > some ideas on how to > reinforce my bottom cowl so that aerodynamic > pressure at cruise speeds won't > push the cowl in to the point of the exhaust stacks > rubbing and wearing > through the cowl. Any ideas would be appreciated. > > Steve Mullins, PhD. > Associate Professor of Economics > Drury University > 417 873 7299 (Office) > 417 873 7537 (Fax) > 417 889 5609 (Home) > ----- Original Message ----- > From: "rob ray" <smokyray(at)yahoo.com> > To: > Sent: Wednesday, April 18, 2001 9:34 PM > Subject: Re: RV4-List: Fw: RV-List: Everybody went > to S & F except me! > > > > --> RV4-List message posted by: rob ray > > > > > Hi Chuck; > > > > Coming from a No-Cal'r who flew his RV4 to SNF, > the > > Dash Seven looked mighty nice, even if all you > have to > > do is dump a bucket of clecoes in the box, shake > it > > and an airplane pops out....Bottom line: RV's > ruled, > > others drooled. > > The Cross country of two RV4's from NoCal out to > > Lakeland was an adventure all it's own. 12 hours > of > > flying and five fuel stops. I counted 38 RV's on > the > > grass Sunday plus the four in front of Van's tent > and > > Bruce Bohannons Tiger and -4. Alot more came and > went > > during the week. I even had a chance to visit > with > > the man himself for a casual chat on several > subjects. > > I asked him if he was going to discontinue the -4 > now > > that the -8 was so popular. He responded with a > > chuckle: If I did that, how would the Harmon > Rocket > > guys get parts... > > > > > > --- Chuck Rabaut wrote: > > > --> RV4-List message posted by: "Chuck Rabaut" > > > > > > > > > Jim, > > > > > > You are oh so right!!! > > > > > > Chuck > > > > > > > > > ----- Original Message ----- > > > From: Jim Bower <rvbuilder(at)hotmail.com> > > > > Anyhoo, that's why Van's makes RVs in so many > > > flavors, right? At least we > > > > have to study plans, measure, make jigs, > measure, > > > drill, measure, sweat, > > > > measure, and curse to build our airplanes like > > > real men do! (Instead of > > > > those wussy -7 & -9 guys!) > > > > > > > > Jim > > > > > > > > > > > > through > > > > > > http://www.matronics.com/archives > > > http://www.matronics.com/emaillists > > > > > > Matronics! > > > > > > > > > > > > > > > > > > > > > Yahoo! Auctions - buy the things you want at great > prices > > http://auctions.yahoo.com/ > > > > > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Date: Apr 19, 2001
Subject: Re: Everybody went to S & F except me!
Chuck; Amen Brother. I guess the -4's sales sealed the deal so to speak. Quick builds and matched drilling go to the high sellers. Talking with the Van's folks at SNF, it's easy to see the direction Van's is going, away from jigs and drilling. I personally think the 7,8 and 9 and the future 10 are the new breed. I agree, the RV4 is still the best looking and flying of the bunch and I plan on keeping mine a long time.... Rob Ray N557RR --- Chuck Rabaut wrote: > --> RV4-List message posted by: "Chuck Rabaut" > > > Rob, > > I'm glad you had fun and that's great to hear, > but you should've > reminded him that a Quick Build 4 is what's really > needed (I mean I'm not > complaining {well not at this moment} but God knows > the 4 is way cool but > God also knows you sure suffer trying to figure out > how to get it together). > > Chuck > > > ----- Original Message ----- > From: rob ray <smokyray(at)yahoo.com> > To: > Sent: Wednesday, April 18, 2001 9:34 PM > Subject: Re: RV4-List: Fw: RV-List: Everybody went > to S & F except me! > > > > > > > Hi Chuck; > > > > Coming from a No-Cal'r who flew his RV4 to SNF, > the > > Dash Seven looked mighty nice, even if all you > have to > > do is dump a bucket of clecoes in the box, shake > it > > and an airplane pops out....Bottom line: RV's > ruled, > > others drooled. > > The Cross country of two RV4's from NoCal out to > > Lakeland was an adventure all it's own. 12 hours > of > > flying and five fuel stops. I counted 38 RV's on > the > > grass Sunday plus the four in front of Van's tent > and > > Bruce Bohannons Tiger and -4. Alot more came and > went > > during the week. I even had a chance to visit > with > > the man himself for a casual chat on several > subjects. > > I asked him if he was going to discontinue the -4 > now > > that the -8 was so popular. He responded with a > > chuckle: If I did that, how would the Harmon > Rocket > > guys get parts... > > > > > > --- Chuck Rabaut wrote: > > > --> RV4-List message posted by: "Chuck Rabaut" > > > > > > > > > Jim, > > > > > > You are oh so right!!! > > > > > > Chuck > > > > > > > > > ----- Original Message ----- > > > From: Jim Bower <rvbuilder(at)hotmail.com> > > > > Anyhoo, that's why Van's makes RVs in so many > > > flavors, right? At least we > > > > have to study plans, measure, make jigs, > measure, > > > drill, measure, sweat, > > > > measure, and curse to build our airplanes like > > > real men do! (Instead of > > > > those wussy -7 & -9 guys!) > > > > > > > > Jim > > > > > > > > > > > > through > > > > > > http://www.matronics.com/archives > > > http://www.matronics.com/emaillists > > > > > > Matronics! > > > > > > > > > > > > > > > > > > > > > Yahoo! Auctions - buy the things you want at great > prices > > http://auctions.yahoo.com/ > > > > > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Date: Apr 19, 2001
And a big AMEN from the choir! -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: rob ray [mailto:smokyray(at)yahoo.com] Sent: Thursday, April 19, 2001 4:43 PM To: rv4-list(at)matronics.com Subject: Re: Fw: RV4-List: Fw: RV-List: Everybody went to S & F except me! Chuck; Amen Brother. I guess the -4's sales sealed the deal so to speak. Quick builds and matched drilling go to the high sellers. Talking with the Van's folks at SNF, it's easy to see the direction Van's is going, away from jigs and drilling. I personally think the 7,8 and 9 and the future 10 are the new breed. I agree, the RV4 is still the best looking and flying of the bunch and I plan on keeping mine a long time.... Rob Ray N557RR --- Chuck Rabaut wrote: > --> RV4-List message posted by: "Chuck Rabaut" > > > Rob, > > I'm glad you had fun and that's great to hear, > but you should've > reminded him that a Quick Build 4 is what's really > needed (I mean I'm not > complaining {well not at this moment} but God knows > the 4 is way cool but > God also knows you sure suffer trying to figure out > how to get it together). > > Chuck > > > ----- Original Message ----- > From: rob ray <smokyray(at)yahoo.com> > To: > Sent: Wednesday, April 18, 2001 9:34 PM > Subject: Re: RV4-List: Fw: RV-List: Everybody went > to S & F except me! > > > > > > > Hi Chuck; > > > > Coming from a No-Cal'r who flew his RV4 to SNF, > the > > Dash Seven looked mighty nice, even if all you > have to > > do is dump a bucket of clecoes in the box, shake > it > > and an airplane pops out....Bottom line: RV's > ruled, > > others drooled. > > The Cross country of two RV4's from NoCal out to > > Lakeland was an adventure all it's own. 12 hours > of > > flying and five fuel stops. I counted 38 RV's on > the > > grass Sunday plus the four in front of Van's tent > and > > Bruce Bohannons Tiger and -4. Alot more came and > went > > during the week. I even had a chance to visit > with > > the man himself for a casual chat on several > subjects. > > I asked him if he was going to discontinue the -4 > now > > that the -8 was so popular. He responded with a > > chuckle: If I did that, how would the Harmon > Rocket > > guys get parts... > > > > > > --- Chuck Rabaut wrote: > > > --> RV4-List message posted by: "Chuck Rabaut" > > > > > > > > > Jim, > > > > > > You are oh so right!!! > > > > > > Chuck > > > > > > > > > ----- Original Message ----- > > > From: Jim Bower <rvbuilder(at)hotmail.com> > > > > Anyhoo, that's why Van's makes RVs in so many > > > flavors, right? At least we > > > > have to study plans, measure, make jigs, > measure, > > > drill, measure, sweat, > > > > measure, and curse to build our airplanes like > > > real men do! (Instead of > > > > those wussy -7 & -9 guys!) > > > > > > > > Jim > > > > > > > > > > > > through > > > > > > http://www.matronics.com/archives > > > http://www.matronics.com/emaillists > > > > > > Matronics! > > > > > > > > > > > > > > > > > > > > > Yahoo! Auctions - buy the things you want at great > prices > > http://auctions.yahoo.com/ > > > > > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Date: Apr 19, 2001
In a message dated 4/19/01 4:43:37 AM Pacific Daylight Time, czechsix(at)juno.com writes: << or is it a 'twist and lock' type operation with safety wire added just for extra security? >> Basically yes, except that you release the bowl by unscrewing the black locking ring at the top of the bowl. I'm still playing with mine while working out a left wing root mounting set up. Nice piece of hardware. Harry Crosby Pleasanton, California RV-6, finish kit stuff ________________________________________________________________________________
Subject: Re: Bottom Cowling reinforcement
Date: Apr 19, 2001
Steve, On an earlier RV-4, I built a short strut that clamped to the lower cross member of the engine mount at the firewall. It was just long enough to lightly press against the lower cowl when at rest. Bill, RV-8 N48WD ----- Original Message ----- From: "Steve Mullins" <smullins(at)lib.drury.edu> Sent: Thursday, April 19, 2001 3:48 PM Subject: RV-List: Bottom Cowling reinforcement > > Hellow everyone. I am a new RV4 owner, and could use some ideas on how to > reinforce my bottom cowl so that aerodynamic pressure at cruise speeds won't > push the cowl in to the point of the exhaust stacks rubbing and wearing > through the cowl. Any ideas would be appreciated. > > Steve Mullins, PhD. > Associate Professor of Economics > Drury University > 417 873 7299 (Office) > 417 873 7537 (Fax) > 417 889 5609 (Home) > ----- Original Message ----- > From: "rob ray" <smokyray(at)yahoo.com> > To: > Sent: Wednesday, April 18, 2001 9:34 PM > Subject: Re: RV4-List: Fw: RV-List: Everybody went to S & F except me! > > > > --> RV4-List message posted by: rob ray > > > > Hi Chuck; > > > > Coming from a No-Cal'r who flew his RV4 to SNF, the > > Dash Seven looked mighty nice, even if all you have to > > do is dump a bucket of clecoes in the box, shake it > > and an airplane pops out....Bottom line: RV's ruled, > > others drooled. > > The Cross country of two RV4's from NoCal out to > > Lakeland was an adventure all it's own. 12 hours of > > flying and five fuel stops. I counted 38 RV's on the > > grass Sunday plus the four in front of Van's tent and > > Bruce Bohannons Tiger and -4. Alot more came and went > > during the week. I even had a chance to visit with > > the man himself for a casual chat on several subjects. > > I asked him if he was going to discontinue the -4 now > > that the -8 was so popular. He responded with a > > chuckle: If I did that, how would the Harmon Rocket > > guys get parts... > > > > > > --- Chuck Rabaut wrote: > > > --> RV4-List message posted by: "Chuck Rabaut" > > > > > > > > > Jim, > > > > > > You are oh so right!!! > > > > > > Chuck > > > > > > > > > ----- Original Message ----- > > > From: Jim Bower <rvbuilder(at)hotmail.com> > > > > Anyhoo, that's why Van's makes RVs in so many > > > flavors, right? At least we > > > > have to study plans, measure, make jigs, measure, > > > drill, measure, sweat, > > > > measure, and curse to build our airplanes like > > > real men do! (Instead of > > > > those wussy -7 & -9 guys!) > > > > > > > > Jim > > > > > > > > > > > > through > > > > > > http://www.matronics.com/archives > > > http://www.matronics.com/emaillists > > > > > > Matronics! > > > > > > > > > > > > > > > > > > > > > Yahoo! Auctions - buy the things you want at great prices > > http://auctions.yahoo.com/ > > > > > > ________________________________________________________________________________
Subject: avionics
Date: Apr 19, 2001
Listers, Who out there has the best prices nowdays on new avionics? Thanks, Bill RV-8 N48WD ________________________________________________________________________________
Date: Apr 19, 2001
Subject: Re: could this be vapor lock?
Follow-up on my suspected vapor lock problem in the RV-6A is now possible, as my first flight since the problem showed up has now been completed. I screwed up my courage today, and, with an aggressive flight profile in mind, climbed out at Vy until 3500 feet AGL while circling home field. I then headed out to Bob Barrows' place for a session with his Hodges Fuel Volatility Tester. I ran on the avgas tank and with the fuel pump on the whole time. The only little problem was one I had experienced a time or two before on turf strips: the engine choked and quit at the end of the roll-out, after trailing clouds of black smoke most of the way down the runway (so Bob tells me; I never saw it.) Seems the carb is set a bit too rich at idle, or maybe the floats are letting too much fuel get by when they are jiggled and bounced around. This rich idle problem may somehow play into the in-flight stumbling I was having on that hot day last weekend; it's difficult to know for sure. I plan to look into it very soon, pull the carb and check the floats, needle and seat, maybe replace the main jet with one that isn't drilled out so much (I took it from a #43 to a #37 drill bit size, in one jump, about 3 years ago. It seems I overshot the correct setting just a bit.) The upshot of the fuel testing is that my winter blend premium mogas has a reading of 7.5, while the 100LL measures 9.5 Both these readings are in the "green arc" of the tester, but the higher numbers mean more vacuum can be pulled in the syringe before the fuel specimen begins to boil. I neglected to note what the units were; probably inches of mercury, vacuum. The test was performed at 1100 feet MSL, which I am sure affects the readings slightly vs. sea-level. Hard to tell if 2 units higher volatility means the mogas was responsible for the engine's coughing as I throttled back in cruise on that unusually warm day April 7th. The carburetor may be somehow to blame. The search continues. Meanwhile, the price of premium auto fuel has climbed so much, 100LL is hardly any more expensive. Good grief! Discussion and advice always welcome - that's why I share this stuff. Bill Boyd RV-6A O-320/Sensenich FP Hop-Along Air Field, 12VA Clifton Forge, VA ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Subject: RV6-A Nose Wheel & Tube
Date: Apr 19, 2001
List: I just mounted my RV6-A Tire & Tube for the Nose Gear and only needed ONE TUBE!!! I guess all those years of Dirt Bike Riding paid off, but I have to admit this was one tough job. The secret for me was to use GOJO on the tire bead so the rim half with the valve stem hole could be pushed down on the tire until seated. I then took the tube out of the box and fitted it between the rim half and inserted into the tire as far back as possible. Lube the other bead of the tire and push the remaining rim half down just far enough to get a turn or two on each of the 3 bolt and nut combinations. Now reach in the rim and with one finger make sure the tube hasn't worked it's way between the two halves and torque each bolt to 90 in.lbs.. Inflate and dance around the hanger! Worked for me! Tom in Ohio ________________________________________________________________________________
Date: Apr 19, 2001
Double AMEN to the flight characteristics and looks of the -4. I have only had mine for a few weeks (4 flight hours or so) and I can't wipe the silly grin from my face when thinking about, let alone actually flying, it!!! Steve Mullins, Ph.D. Associate Professor of Economics Drury University 417.889.5609 (home) 417.873.7299 (office) ----- Original Message ----- From: "rob ray" <smokyray(at)yahoo.com> Sent: Thursday, April 19, 2001 6:43 PM Subject: Re: Fw: RV4-List: Fw: RV-List: Everybody went to S & F except me! > --> RV4-List message posted by: rob ray > > Chuck; > > Amen Brother. I guess the -4's sales sealed the deal > so to speak. Quick builds and matched drilling go to > the high sellers. Talking with the Van's folks at SNF, > it's easy to see the direction Van's is going, away > from jigs and drilling. I personally think the 7,8 and > 9 and the future 10 are the new breed. > I agree, the RV4 is still the best looking and flying > of the bunch and I plan on keeping mine a long > time.... > > Rob Ray > N557RR > --- Chuck Rabaut wrote: > > --> RV4-List message posted by: "Chuck Rabaut" > > > > > > Rob, > > > > I'm glad you had fun and that's great to hear, > > but you should've > > reminded him that a Quick Build 4 is what's really > > needed (I mean I'm not > > complaining {well not at this moment} but God knows > > the 4 is way cool but > > God also knows you sure suffer trying to figure out > > how to get it together). > > > > Chuck > > > > > > ----- Original Message ----- > > From: rob ray <smokyray(at)yahoo.com> > > To: > > Sent: Wednesday, April 18, 2001 9:34 PM > > Subject: Re: RV4-List: Fw: RV-List: Everybody went > > to S & F except me! > > > > > > > > > > > > Hi Chuck; > > > > > > Coming from a No-Cal'r who flew his RV4 to SNF, > > the > > > Dash Seven looked mighty nice, even if all you > > have to > > > do is dump a bucket of clecoes in the box, shake > > it > > > and an airplane pops out....Bottom line: RV's > > ruled, > > > others drooled. > > > The Cross country of two RV4's from NoCal out to > > > Lakeland was an adventure all it's own. 12 hours > > of > > > flying and five fuel stops. I counted 38 RV's on > > the > > > grass Sunday plus the four in front of Van's tent > > and > > > Bruce Bohannons Tiger and -4. Alot more came and > > went > > > during the week. I even had a chance to visit > > with > > > the man himself for a casual chat on several > > subjects. > > > I asked him if he was going to discontinue the -4 > > now > > > that the -8 was so popular. He responded with a > > > chuckle: If I did that, how would the Harmon > > Rocket > > > guys get parts... > > > > > > > > > --- Chuck Rabaut wrote: > > > > --> RV4-List message posted by: "Chuck Rabaut" > > > > > > > > > > > > Jim, > > > > > > > > You are oh so right!!! > > > > > > > > Chuck > > > > > > > > > > > > ----- Original Message ----- > > > > From: Jim Bower <rvbuilder(at)hotmail.com> > > > > > Anyhoo, that's why Van's makes RVs in so many > > > > flavors, right? At least we > > > > > have to study plans, measure, make jigs, > > measure, > > > > drill, measure, sweat, > > > > > measure, and curse to build our airplanes like > > > > real men do! (Instead of > > > > > those wussy -7 & -9 guys!) > > > > > > > > > > Jim > > > > > > > > > > > > > > > > through > > > > > > > > http://www.matronics.com/archives > > > > http://www.matronics.com/emaillists > > > > > > > > Matronics! > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Auctions - buy the things you want at great > > prices > > > http://auctions.yahoo.com/ > > > > > > > > > > > > > > through > > > > http://www.matronics.com/archives > > http://www.matronics.com/emaillists > > > > Matronics! > > > > > > > > > > > > > Yahoo! Auctions - buy the things you want at great prices > http://auctions.yahoo.com/ > > ________________________________________________________________________________
Date: Apr 19, 2001
Subject: Re: avionics
In a message dated 4/19/01 10:43:45 PM Eastern Daylight Time, rvpilot(at)mpinet.net writes: > Listers, > > Who out there has the best prices nowdays on new avionics? > > Thanks, Bill RV-8 N48WD I've always found Chief to be competitive. When I decided what I wanted, I e-mailed (or called... don't remember) Chief, ACS, and Gulf Coast and told them what my total order would be: I listed the radio, intercom, transponder, encoder, etc.. Then I told them that would be buying all of the stuff from one source in the very near future, and requested their best price for the entire mess. Chief had the lowest price, and came down noticably from their list prices. In addition, I have always found their order desk and tech support to be very patient and helpful. Kyle Boatright - Kennesaw, GA RV-6 Slider, O-320/Aymar-Demuth ________________________________________________________________________________
Date: Apr 19, 2001
I am selling my RV-4 Empennage Kit with MAC Elevator Trim Kit. I decided to build an RV-8. If anyone interested contact me at: newellmahal(at)earthlink.net ----- Original Message ----- From: "Steve Mullins" <smullins(at)lib.drury.edu> Sent: Thursday, April 19, 2001 6:42 PM Subject: Re: Fw: RV4-List: Fw: RV-List: Everybody went to S & F except me! > > Double AMEN to the flight characteristics and looks of the -4. I have only > had mine for a few weeks (4 flight hours or so) and I can't wipe the silly > grin from my face when thinking about, let alone actually flying, it!!! > > Steve Mullins, Ph.D. > Associate Professor of Economics > Drury University > 417.889.5609 (home) > 417.873.7299 (office) > ----- Original Message ----- > From: "rob ray" <smokyray(at)yahoo.com> > To: > Sent: Thursday, April 19, 2001 6:43 PM > Subject: Re: Fw: RV4-List: Fw: RV-List: Everybody went to S & F except me! > > > > --> RV4-List message posted by: rob ray > > > > Chuck; > > > > Amen Brother. I guess the -4's sales sealed the deal > > so to speak. Quick builds and matched drilling go to > > the high sellers. Talking with the Van's folks at SNF, > > it's easy to see the direction Van's is going, away > > from jigs and drilling. I personally think the 7,8 and > > 9 and the future 10 are the new breed. > > I agree, the RV4 is still the best looking and flying > > of the bunch and I plan on keeping mine a long > > time.... > > > > Rob Ray > > N557RR > > --- Chuck Rabaut wrote: > > > --> RV4-List message posted by: "Chuck Rabaut" > > > > > > > > > Rob, > > > > > > I'm glad you had fun and that's great to hear, > > > but you should've > > > reminded him that a Quick Build 4 is what's really > > > needed (I mean I'm not > > > complaining {well not at this moment} but God knows > > > the 4 is way cool but > > > God also knows you sure suffer trying to figure out > > > how to get it together). > > > > > > Chuck > > > > > > > > > ----- Original Message ----- > > > From: rob ray <smokyray(at)yahoo.com> > > > To: > > > Sent: Wednesday, April 18, 2001 9:34 PM > > > Subject: Re: RV4-List: Fw: RV-List: Everybody went > > > to S & F except me! > > > > > > > > > > > > > > > > > Hi Chuck; > > > > > > > > Coming from a No-Cal'r who flew his RV4 to SNF, > > > the > > > > Dash Seven looked mighty nice, even if all you > > > have to > > > > do is dump a bucket of clecoes in the box, shake > > > it > > > > and an airplane pops out....Bottom line: RV's > > > ruled, > > > > others drooled. > > > > The Cross country of two RV4's from NoCal out to > > > > Lakeland was an adventure all it's own. 12 hours > > > of > > > > flying and five fuel stops. I counted 38 RV's on > > > the > > > > grass Sunday plus the four in front of Van's tent > > > and > > > > Bruce Bohannons Tiger and -4. Alot more came and > > > went > > > > during the week. I even had a chance to visit > > > with > > > > the man himself for a casual chat on several > > > subjects. > > > > I asked him if he was going to discontinue the -4 > > > now > > > > that the -8 was so popular. He responded with a > > > > chuckle: If I did that, how would the Harmon > > > Rocket > > > > guys get parts... > > > > > > > > > > > > --- Chuck Rabaut wrote: > > > > > --> RV4-List message posted by: "Chuck Rabaut" > > > > > > > > > > > > > > > Jim, > > > > > > > > > > You are oh so right!!! > > > > > > > > > > Chuck > > > > > > > > > > > > > > > ----- Original Message ----- > > > > > From: Jim Bower <rvbuilder(at)hotmail.com> > > > > > > Anyhoo, that's why Van's makes RVs in so many > > > > > flavors, right? At least we > > > > > > have to study plans, measure, make jigs, > > > measure, > > > > > drill, measure, sweat, > > > > > > measure, and curse to build our airplanes like > > > > > real men do! (Instead of > > > > > > those wussy -7 & -9 guys!) > > > > > > > > > > > > Jim > > > > > > > > > > > > > > > > > > > > through > > > > > > > > > > http://www.matronics.com/archives > > > > > http://www.matronics.com/emaillists > > > > > > > > > > Matronics! > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Auctions - buy the things you want at great > > > prices > > > > http://auctions.yahoo.com/ > > > > > > > > > > > > > > > > > > > > through > > > > > > http://www.matronics.com/archives > > > http://www.matronics.com/emaillists > > > > > > Matronics! > > > > > > > > > > > > > > > > > > > > > Yahoo! Auctions - buy the things you want at great prices > > http://auctions.yahoo.com/ > > > > > > ________________________________________________________________________________
Subject: Pre wire harness relays
Date: Apr 20, 2001
Need help on orientation of wiring. Got the Pre wiring harness . Have put relays on firewall run leads all looked great until I found Drawing OP12 Section A-A Top Left Please look at starter and master relay. Shown is P17 going from left hand side of the starter relay to starter. It also shows P16 going from right of starter relay to right of master relay. This is also shown in the photos and plans showing how to set out the firewall to run wire, and in the RVator, Number 1 - 2000. Problem Now look at drawing OP - 10, bottom left hand side and Lightweight starter circuit diagram. This shows the opposite to all the other drawings and photos. e.g: P17 goes from the right hand side of the starter relay to the starter. P16 goes from the right of the master relay to the left of the starter relay. So what is the go? Which is the correct way? Is OP12 and the photos wrong or are they both right. Thankyou Chris RV 6 Australia ________________________________________________________________________________
Subject: Aussie visit to US
Date: Apr 20, 2001
My wife and I will be travelling around the states for approximately 3 months. We will be landing at LA, going to Portland, going to Vans of course, then pop into Canada. Then flying to Florida, spend a couple of weeks there, buy an old bomb (car), and spend about 6 weeks travelling to Evergreen, Colorado. We will be in Evergreen for a month. We would love to meet any RV builders and flyers along the way. Once in Colorado my wife is doing a course, so I am free for the month, if anyone needs a hand. Would also like to go to Oshkosh if anyone would like to share expenses. If anyone has any suggestions of places that we must see please let us know. Please respond off the list. Thanks Chris and Susie P.S: We are building an RV 6, just finishing off the canopy. ________________________________________________________________________________
Date: Apr 20, 2001
Subject: Air/Oil seperator
Listers, I am thinking of installing an air-oil separator in my -4. The device I have has three inputs/outputs. One is used to connect to the engine breather port on the engine ( 360 A1A ), there is a small hose fitting for the water drain, and a third that I assume is to return the recovered oil to the engine. My question is where to plumb the oil return line? Any answers? Thanks. Ray Grenier RV-4 the last and endless 90% ________________________________________________________________________________
Subject: rv-8 video
Date: Apr 20, 2001
Anyone know what the status of this is? Is it available for download somewhere? Larry Bowen RV-8 fuse Sloooooow Build ... Email: Larry(at)BowenAero.com Web: http://BowenAero.com > -----Original Message----- > From: owner-rv-list-server(at)matronics.com > [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Steven DiNieri > Sent: Sunday, April 15, 2001 2:29 AM > To: rv-list(at)matronics.com > Subject: RV-List: rv-8 video > > > I've got the first episode encoded( from the ground up) but need to put it > where those interested can get at it. Its 21 meg and in wmv > (windows media). > Any ideas?? Also the big version is about 80 meg... > > > Steven DiNieri > Niagara Falls, New York > RV-6A, P28A-160 > > ________________________________________________________________________________
Date: Apr 20, 2001
Subject: Looking for a damaged RV4 canopy
Listers I'm looking for someone with a damaged RV4 canopy that they want to get rid of, you can contact me off list (panelcut(at)aol.com) or call me @ (901)526-0491 Steve Davis The Panel Pilot ________________________________________________________________________________
Subject: Re: Aussie visit to US
Date: Apr 20, 2001
Greetings form El Paso, Texas I am building a 9A and my friend has just received his empannage for the new 7a. Spent two weeks in Australia last year and would like to reciprocate in kind for your fine hospitality while were in your country. If you plan on passing through El Paso, give me some warning and you would be welcome to stay with us for a bit. Marcel Bourgon mbourgon(at)elp.rr.com ----- Original Message ----- From: Chris & Susie <rv6(at)ssc.net.au> Sent: Friday, April 20, 2001 4:24 AM Subject: RV-List: Aussie visit to US > > My wife and I will be travelling around the states for approximately 3 > months. We will be landing at LA, going to Portland, going to Vans of > course, then pop into Canada. Then flying to Florida, spend a couple of > weeks there, buy an old bomb (car), and spend about 6 weeks travelling > to Evergreen, Colorado. We will be in Evergreen for a month. > > We would love to meet any RV builders and flyers along the way. Once in > Colorado my wife is doing a course, so I am free for the month, if > anyone needs a hand. Would also like to go to Oshkosh if anyone would > like to share expenses. > > If anyone has any suggestions of places that we must see please let us > know. > > Please respond off the list. > > Thanks > > Chris and Susie > > P.S: We are building an RV 6, just finishing off the canopy. > > ________________________________________________________________________________
Subject: METO and CG etc
Date: Apr 20, 2001
Eric said: << I mean why would 2 hours fuel put you in jeopardy more than nearly dry << tanks? If 10 gallons would put you in an aft CG condition then wouldn't << full tanks put you in a worse way? Can you explain the reasoning for the << DAR's concern to a simple country boy. Please use one syllable words or << less, if not I'm gonna have to call that damn Pugsley. That dog really << knows his milk bones. As you suggest, if the fuel is not located on the loaded CG of the airplane the amount of fuel will make a difference in where the CG is. If the loaded CG is aft of the fuel, which is the case in my airplane, a light fuel load will aggravate an aft CG situation. I weigh on the bad side of 240... the CG moves waaaay aft when I sit down. :=(( If I sat down in an RV-3 that had a small engine and wood prop, it's possible that the CG would be aft of the aft limit no matter what the fuel load (and I would be writing the list asking how to mount the battery in the spinner...). That's not the case with my airplane, thank goodness. If you find, as I suspect you will, that the CG moves aft with less fuel aboard when nothing else changes, then a light fuel load, large occupants, and lots of baggage behind the seat could be a bad deal IF your airplane tends to have an aft CG when loaded anyway. BTW, who is this Pugsley?? :=)) Randy mentioned: << If I fly at maximum takeoff weight with two heavy << bubbas on board, I cannot fly down to less than 10 gallons of fuel on board << without exceeding the aft CG limit on the airplane. Randy, seriously, I would put something heavy up front, maybe a harmonic balancer (I assume you have a wood prop??) or something. As Finn pointed out, you need to be within the CG envelope at flameout... you and Bubba will be in deep dodo if the fog rolls in and you need to burn below 10 gallons to get to an alternate, etc etc... Johnny Johnson 49MM RV-3 flying ________________________________________________________________________________
Date: Apr 20, 2001
I would have to second that. I just came from Chief a week ago and talked avionics with them. I was so impressed with the helpfullness and time they gave me I plan to buy there if they are even just close on price. Tim Bryan timbryan(at)oregontrail.net RV-6 Finishing kit stuff -ugh ----- Original Message ----- From: <KBoatri144(at)AOL.COM> Sent: Thursday, April 19, 2001 8:01 PM Subject: Re: RV-List: avionics > > In a message dated 4/19/01 10:43:45 PM Eastern Daylight Time, > rvpilot(at)mpinet.net writes: > > > > Listers, > > > > Who out there has the best prices nowdays on new avionics? > > > > Thanks, Bill RV-8 N48WD > > I've always found Chief to be competitive. When I decided what I wanted, I > e-mailed (or called... don't remember) Chief, ACS, and Gulf Coast and told > them what my total order would be: I listed the radio, intercom, > transponder, encoder, etc.. Then I told them that would be buying all of the > stuff from one source in the very near future, and requested their best price > for the entire mess. Chief had the lowest price, and came down noticably > from their list prices. > > In addition, I have always found their order desk and tech support to be very > patient and helpful. > > > Kyle Boatright - Kennesaw, GA > RV-6 Slider, O-320/Aymar-Demuth > > ________________________________________________________________________________
Date: Apr 20, 2001
Subject: Need
I am in need of a set (2) main gear legs for an RV6A, also could use new style wheel pants for same. Please respond to prestige(at)together.net att: Dick Jason ________________________________________________________________________________
Subject: Peltor Headset Question (not building related)
Date: Apr 20, 2001
Thread-Topic: RV-List: Peltor Headset Question (not building related) Thread-Index: AcDJLT3cnTUUYrmMR9u83sAQ9JciUgAdGnIA
Harry, I use the Peltor 7006 headsets. Over the years I've owned various brands of headsets (david clark 13.4's, peltor 7004's.) Recently I bought a pair of Lightspeed QFR passive headsets, but didn't like them because the strain relief on the cord coming out of the earcup would rub on my shoulder harnesses, and if you turned your head quickly they'd come off. Light, but not as comfortable as the Peltors. I bought the 7006's from Chief Aircraft (ask for the web special price of $180.00) about three months ago and love them. They are the most comfortable and quiet headsets I've owned, much more comfortable than the 7004's I have due to the larger earcups. Dave Clarks are like strapping a boat anchor to your head compared to the Peltors IMO. A friend of mine who has Lightspeed 25XL ANR headsets flew with me not too long ago and he said that they were more comfortable than his Lightspeeds, and came close to being as quiet. Bob Japundza RV-6 N244BJ O-360C/S flying 113 hours >Hope no one gets upset at my asking this, but I am considering buying a >Peltor 7006 headset and would sure appreciate any good, bad or indifferent >comments from the list on these units. Thanks. ________________________________________________________________________________
Date: Apr 20, 2001
Subject: Props???
I am currently rebuilding an RV6A damaged in a hard landing. Has anyone experience with 3 blade props vs 2 blades. Performance????? Vibration????? There seems to be a considerable amount of controversy when using 3 blades on Mooney's ???? Composite vs aluminum. To be used on a 0-360 C/S . Also if anyone has a constant speed prop for the above and is looking to sell???? Dick Jason ________________________________________________________________________________
Date: Apr 20, 2001
John Stark was recommended to me by the 'list'. I also bought my GTX327 transponder from him for (I think) 5% over cost. I paid $1220. Best price I could find and I called everybody. I 'second the motion' for Stark Avionics. Rick Gray RV6QB (Ohio) at the Buffalo Farm ________________________________________________________________________________
Subject: Re: Air/Oil seperator
Date: Apr 20, 2001
I had a short tube welded to one of the oil return tubes of my O360A1D, as shown on their website (M-20). Haven't flown yet, though. Jim ----- Original Message ----- From: <GRENIER(at)AOL.COM> Sent: Friday, April 20, 2001 8:29 AM Subject: RV-List: Air/Oil seperator > > Listers, I am thinking of installing an air-oil separator in my -4. The > device I have has three inputs/outputs. One is used to connect to the engine > breather port on the engine ( 360 A1A ), there is a small hose fitting for > the water drain, and a third that I assume is to return the recovered oil to > the engine. My question is where to plumb the oil return line? Any answers? > Thanks. > > Ray Grenier > > RV-4 the last and endless 90% > > ________________________________________________________________________________
Subject: avionics
Date: Apr 20, 2001
A lot of avionics retailers won't quote (over the counter) prices on installed only products (garmin, s-tec) because of manufacturer policies. However, some experimental friendly retailers will sell you whatever you want. I've ordered all my goodies (s-tec 30, gns-430, sl70, gtx-327, nav122, bootstrap gyros, etc) from john start avionics. Seems like a great guy and gets stuff out on time. Some have had him prewire some harnesses for a reasonable fee. He'll usually tell you what the stuff actually costs then figure in his standard markup. 5-10 % for listers. I only recommend him because of how happy I was with my dealing with him. STARK AVIONICS (JOHN STARK) 706-321-1008 jts7(at)mindspring.com http://www.mindspring.com/~jts7/starkav.html DISCOUNT AVIONICS Steve DiNieri N221RV, N5085W Niagara Falls, New York capsteve(at)adelphia.net I've always found Chief to be competitive. When I decided what I wanted, I e-mailed (or called... don't remember) Chief, ACS, and Gulf Coast and told them what my total order would be: I listed the radio, intercom, transponder, encoder, etc.. Then I told them that would be buying all of the stuff from one source in the very near future, and requested their best price for the entire mess. Chief had the lowest price, and came down noticably from their list prices. ________________________________________________________________________________
Subject: Re: RV4-List: Prop Balancer
Date: Apr 20, 2001
Actually, Mark sells a Harmonic Dampener - not a balancer. They're not the same and you should still have the prop balanced if you go this route. > --> RV4-List message posted by: rob ray > > Jim; > > Grab a Sport Aviation Magazine and look in the > classified ads under Props. Look for Mark Landoll's > Harmonic balancers. They really work and add 12 pounds > to the nose on -4's which is a plus. > > Rob Ray > N557RR ________________________________________________________________________________
Subject: rv-8 video
Date: Apr 20, 2001
Episode 1 and 2 are recorded in a couple different formats. I've no place to post them for download, but am investigating the gnutella type file sharing service. Kind of like napster for any files. I've got 2 way cable so I would be able to accommodate a descent amount of traffic. If anyone is familiar with this stuff give me a shout so I can post them. Also if any body wants to cover the cost of a cd-rom and mail I'd burn you a copy. Sunday episode 3 airs, 8 pm. Steven DiNieri 221RV, 5085W Niagara Falls, NY capsteve(at)adelphia.net Anyone know what the status of this is? Is it available for download somewhere? Larry Bowen RV-8 fuse Sloooooow Build ... Email: Larry(at)BowenAero.com Web: http://BowenAero.com > > > I've got the first episode encoded( from the ground up) but need to put it > where those interested can get at it. Its 21 meg and in wmv > (windows media). > Any ideas?? Also the big version is about 80 meg... > > > Steven DiNieri > Niagara Falls, New York > RV-6A, P28A-160 > > ________________________________________________________________________________
Date: Apr 20, 2001
Chuck, Ray, and other variations of -4 drivers, Here is the the input of a -9 builder: It was seeing a pristine RV-4 sitting on the ramp that made me fall in love with the RV series in the first place. I too think that a modern pre-punched version would be a good idea. I chose the -9 for a variety of reasons, but the biggest one was path of least resistance, ease of building and quicker to get in the air. But I still think the -4 is the prettiest. Just my opinion. Kevin in WA -9A finishing 994KS > Chuck; > > Amen Brother. I guess the -4's sales sealed the deal > so to speak. Quick builds and matched drilling go to > the high sellers. Talking with the Van's folks at SNF, > it's easy to see the direction Van's is going, away > from jigs and drilling. I personally think the 7,8 and > 9 and the future 10 are the new breed. > I agree, the RV4 is still the best looking and flying > of the bunch and I plan on keeping mine a long > time.... > > Rob Ray > N557RR > --- Chuck Rabaut wrote: > > --> RV4-List message posted by: "Chuck Rabaut" > > > > > > Rob, > > > > I'm glad you had fun and that's great to hear, > > but you should've > > reminded him that a Quick Build 4 is what's really > > needed (I mean I'm not > > complaining {well not at this moment} but God knows > > the 4 is way cool but > > God also knows you sure suffer trying to figure out > > how to get it together). > > > > Chuck > > > > > > ----- Original Message ----- > > From: rob ray <smokyray(at)yahoo.com> > > To: > > Sent: Wednesday, April 18, 2001 9:34 PM > > Subject: Re: RV4-List: Fw: RV-List: Everybody went > > to S & F except me! > > > > > > > > > > > > Hi Chuck; > > > > > > Coming from a No-Cal'r who flew his RV4 to SNF, > > the > > > Dash Seven looked mighty nice, even if all you > > have to > > > do is dump a bucket of clecoes in the box, shake > > it > > > and an airplane pops out....Bottom line: RV's > > ruled, > > > others drooled. > > > The Cross country of two RV4's from NoCal out to > > > Lakeland was an adventure all it's own. 12 hours > > of > > > flying and five fuel stops. I counted 38 RV's on > > the > > > grass Sunday plus the four in front of Van's tent > > and > > > Bruce Bohannons Tiger and -4. Alot more came and > > went > > > during the week. I even had a chance to visit > > with > > > the man himself for a casual chat on several > > subjects. > > > I asked him if he was going to discontinue the -4 > > now > > > that the -8 was so popular. He responded with a > > > chuckle: If I did that, how would the Harmon > > Rocket > > > guys get parts... > > > > > > > > > --- Chuck Rabaut wrote: > > > > --> RV4-List message posted by: "Chuck Rabaut" > > > > > > > > > > > > Jim, > > > > > > > > You are oh so right!!! > > > > > > > > Chuck > > > > ________________________________________________________________________________
Date: Apr 20, 2001
Subject: Re: need some advice
Why dont you just walk over to Vans? > am building a RV8A...need some advice from another builder on several > things...am located near aurora, ore...am willing to travel to anywhere > in the greater portland-salem aerea....nearing completion, but need some > "expert" advice...thank you.. > j. dawson > RV8A > 503-678-3343 ________________________________________________________________________________
Subject: Everybody went to S & F except me!
Date: Apr 20, 2001
Just one more comment---my wife won't fly tandom. That could be good---could be bad---just depends on whether I want to be alone that day :-) Greg in Bend,OR Wing Spar plate nuts all riveted on -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Im7shannon(at)AOL.COM Sent: Friday, April 20, 2001 8:20 AM Subject: Re: Fw: RV4-List: Fw: RV-List: Everybody went to S & F except me! Chuck, Ray, and other variations of -4 drivers, Here is the the input of a -9 builder: It was seeing a pristine RV-4 sitting on the ramp that made me fall in love with the RV series in the first place. I too think that a modern pre-punched version would be a good idea. I chose the -9 for a variety of reasons, but the biggest one was path of least resistance, ease of building and quicker to get in the air. But I still think the -4 is the prettiest. Just my opinion. Kevin in WA -9A finishing 994KS > Chuck; > > Amen Brother. I guess the -4's sales sealed the deal > so to speak. Quick builds and matched drilling go to > the high sellers. Talking with the Van's folks at SNF, > it's easy to see the direction Van's is going, away > from jigs and drilling. I personally think the 7,8 and > 9 and the future 10 are the new breed. > I agree, the RV4 is still the best looking and flying > of the bunch and I plan on keeping mine a long > time.... > > Rob Ray > N557RR > --- Chuck Rabaut wrote: > > --> RV4-List message posted by: "Chuck Rabaut" > > > > > > Rob, > > > > I'm glad you had fun and that's great to hear, > > but you should've > > reminded him that a Quick Build 4 is what's really > > needed (I mean I'm not > > complaining {well not at this moment} but God knows > > the 4 is way cool but > > God also knows you sure suffer trying to figure out > > how to get it together). > > > > Chuck > > > > > > ----- Original Message ----- > > From: rob ray <smokyray(at)yahoo.com> > > To: > > Sent: Wednesday, April 18, 2001 9:34 PM > > Subject: Re: RV4-List: Fw: RV-List: Everybody went > > to S & F except me! > > > > > > > > > > > > Hi Chuck; > > > > > > Coming from a No-Cal'r who flew his RV4 to SNF, > > the > > > Dash Seven looked mighty nice, even if all you > > have to > > > do is dump a bucket of clecoes in the box, shake > > it > > > and an airplane pops out....Bottom line: RV's > > ruled, > > > others drooled. > > > The Cross country of two RV4's from NoCal out to > > > Lakeland was an adventure all it's own. 12 hours > > of > > > flying and five fuel stops. I counted 38 RV's on > > the > > > grass Sunday plus the four in front of Van's tent > > and > > > Bruce Bohannons Tiger and -4. Alot more came and > > went > > > during the week. I even had a chance to visit > > with > > > the man himself for a casual chat on several > > subjects. > > > I asked him if he was going to discontinue the -4 > > now > > > that the -8 was so popular. He responded with a > > > chuckle: If I did that, how would the Harmon > > Rocket > > > guys get parts... > > > > > > > > > --- Chuck Rabaut wrote: > > > > --> RV4-List message posted by: "Chuck Rabaut" > > > > > > > > > > > > Jim, > > > > > > > > You are oh so right!!! > > > > > > > > Chuck > > > > ________________________________________________________________________________
Subject: avionics
Date: Apr 20, 2001
Rick, the 327 will display the altitude that the encoder is transmitting so it can interface with digital output from a gns-gps or from serial data direct from an encoder. Ii don't know that the 320 does this... Steve In a message dated 4/20/01 8:48:03 AM Eastern Daylight Time, rickjory(at)email.msn.com writes: I agree with Rick based on recent shopping. However, I was told by the vendors and Garmin at SNF that they can not sell the GTX 327 transponder for me to install myself. Can somebody confirm that this is not true? They would sell me the GTX 320. Was also told by Garmin that the inner workings of the 327 and 320 are now the same. Only the front panel is different. Dale Ensing getting close to buying avionics ________________________________________________________________________________
Date: Apr 20, 2001
Give Southeast Aerospace a try. I bought a KT-76A transponder from them including the install kit, rack, and manual and paid $1050. That was on 9/17/99. John Kitz N721JK Ohio ----- Original Message ----- From: <RGray67968(at)AOL.COM> Sent: Friday, April 20, 2001 10:14 AM Subject: Re: RV-List: avionics > > John Stark was recommended to me by the 'list'. I also bought my GTX327 > transponder from him for (I think) 5% over cost. I paid $1220. Best price I > could find and I called everybody. I 'second the motion' for Stark Avionics. > Rick Gray RV6QB (Ohio) at the Buffalo Farm > > ________________________________________________________________________________
Date: Apr 20, 2001
Subject: Re: METO and CG etc
April 13, 2001 - April 20, 2001
RV-Archive.digest.vol-ko
