RV-Archive.digest.vol-kq
April 26, 2001 - May 02, 2001
Date: Apr 26, 2001
I have Van's wiring harness kit. Unfortunately (for me) the plans show the location of the terminal block (WH-801) for the tilt up canopy. On the slider, the instrument subpanel is different, so that location won't work ... it would overlap the joint where the two halves of the subpanel are joined. I could pick a somewhat arbitrary location of the terminal block, but with my luck, that would guarantee that the pre-fab wires in the wiring harness would be too short. Has someone else already figured out a good location for the terminal block, so that the wires in the wiring harness still reach? Thanks, Randy ________________________________________________________________________________
Subject: Mounting terminal block on RV-6A slider
Date: Apr 26, 2001
Date: Apr 26, 2001
Subject: Re: Fuel Remaining
on 4/25/01 22:54, Gary A. Sobek at rv6flier(at)yahoo.com wrote: > > --- wvu(at)mail.ameritel.net wrote: >> >> Listers, >> How much is 5.5 gals left in the tank? >> I've always felt reserved after about 2.5 hours of flying with my >> O-320/160. >> 9.5gal/hr. I always feel silly when refueling because both tanks >> would only >> take 20 gals or so to fill up. I came back from SnF this year with >> an >> additional data point - 3.0 hours engine start to stop. 27 gals when >> refueled. That left 11 gals total, or 5.5 gals in each tank. How >> much is >> that at the bottom? >> I'm worried about getting to the destination in choppy wx and the >> ball is >> off centered. How low can I affort to go before the pickup tube is >> exposed >> to air off and on? I'd hate to think of having only 30 minutes of >> reserve, >> or roughly 5 gals total - 2.5 gals in each tank. >> Appreciate all comments.... >> Anh >> -6 >> N985VU >> Maryland > > Before I flew 7GS, I leveled the airplane and filled one tank full. It > took 19.1 gallons. I disconnected the hose from the carb and pumped > all but 0.5 gallons out. I have inverted fuel pickups in both tanks. > The fuel pumped out was placed in the empty tank and the process > repeated with same results. > > I have flown the aircraft 4 hours and when I filled up, calculated that > the remaining fuel would have take me 47 minutes longer. > > I switch tanks every 30 minutes. If I were to run more endurance > tests, I would run one tank dry while still having 5 gallons (or more) > in one tank. Unfortunately I have run both tank down to a point that I > only had 5.5 gallons total on board. > > 5 gallons in one of my tanks looks like there is no fuel in the tank > when viewed from the filler cap. > > I use the MicroMonitor to watch fuel. I am running 3% accuracy. It is > programmed that I only have 36 gallons and it gives me a low fuel alarm > at 5 gallons remaining. The 5 gallons remaining alarm is actually 6 > gallons usable. When the alarm goes off, I switch to the lowest tank > till I get 5 miles from the airport. I then switch to the fullest tank > and land. > > I tend to not do touch and goes with less than 1/2 fuel. I have done > 65 KIAS full power climbs with 10 gallons on board (5 each side) but > was chicken to go any lower. There was no problem with the steep (30 > degrees nose up angle of attack @ 65 KIAS) and fuel flow. Engine ran > fine. > > Hope this helps. > > > ==== > Gary A. Sobek > "My Sanity" RV-6 N157GS O-320 Hartzell, > 788+ Flying Hours So. CA, USA > http://SoCAL_WVAF.tripod.com Dear Anh, I feel your pain. As a retired (and unemployed) air force pilot who spent all his flying career managing and worrying over fuel considerations, I had trouble grappling with the RV situation. My opinion is that van has the best fuel system I have had teh privelege to fly with. . You have two completely independant sources of fuel, with two pumps going for you, either of which will do the job from either tank. Even with one tank dry, you are still as well off as folks with a header tank, or most other systems! The electric pump is located low so it is gravity primed by either tank. Only two controls, a manual switch and a boost pump. A really great system. Not to mention you have four hours of fuel on board which is well beyond the bladder duration of most of the old coots using these planes. SO, you have brought forth a great question: How best to test and use it?? I like Gary's suggestions and think they should be of great value to all. Two things I would offer in addition: First. I do not change tanks every half hour. Most of my flying is solo and I start by feeding the left tank, which helps balance the load in my 6A. I use the left tank until it gets to 3.5 gallons, which is about where the needle hits 1/4 on the Vans cheap gage. (Which I love). Then I switch to the right tank. When it gets between half and quarter it is time to refuel. This practice has given me a lot more confidence that the gage is predictable and that I will recognize my fuel state. Still I use all the techniques Gary mentioned to cross check. It is just a matter of preference and choice of having to trim more or less. Even if you like to switch a lot, I think you could benefit by burning down to this low value enough times to be confident in your gages, and other fuel tending methods. Which leads to the other point. Second. I highly recommend one more test of the system. It took me six months to work up my courage enough to do it, but everyone should do it!! I found a great little airport not too far away that is seldom used but has plenty of runway and no controlled airspace. I flew over to it and orbited at 5,000 feet over the field and ran one tank dry. (the other was near full and had been checked just minutes before.) I then returned to base and carefully filled the tank to note useable fuel for that tank. As a bonus I found out how to restart after running a tank dry. One last thng. As Gary pointed out. the best way to get maximum range if you have to have it, would be to run one tank dry. The next time I ran this test, I found you can do this safely and neatly by monitoriing the fuel pressure gage, as the tank nears empty. When it starts a frenetic jittering dance, turn on the boost pump and switch tanks, and the engine will not even sputter. Having said all that I still don't like to fly around with only one source of fuel available ( I have in line filters). So I never do this (run a tank dry). But if I got caught where I knew I would be flyign for four hours with no other alternatives, I would run a tank dry, with confidence since I know how, now. FWIW, in my 6A with 180 HP, my longest flight was 3+52 minutes and I put in 33.5 gallons at the pump. It was shortly after that when I did the test mentioned above. In other words teh thought that occured to me at the gas pump was: "Gee it sure would be a lot better to have all your fuel in one tank when you get down to 5 gallons!" You see the problem is, even with 3% accuracy, you still ain't sure where which tank has what at five gallons and you fear the possibility of doing the switch trick on base to final with a quiet sound in front and not enough airspeed to get a restart. Ouch. I hope this helps Denis ________________________________________________________________________________
Date: Apr 26, 2001
Subject: Re: Fuel pump question (RV-4)
I had the same concern and wound up using a 90deg hose fitting on the 90deg fuel pump fitting. John Field RV-4 Engine > >My engine mount interferes with the hose that runs from the engine driven >fuel pump output to the carburetor. It fits but the hose is pretty snug up >against the engine mount. Any other 4 builders/flyers have this problem? >What did you do to correct it? The fitting on the fuel pump that the hose >attaches to is a 90 deg fitting. I was thinking of replacing it with a 45 >deg fitting. Good idea or not? > ________________________________________________________________________________
Date: Apr 26, 2001
Subject: Re: tank gasket sealer
In a message dated 4/26/01 6:59:00 AM Pacific Daylight Time, ernest.kells(at)sympatico.ca writes: > Great post!! Vans recent data (RV-9A Wings instrutions on page 7-9) states; > "Clean the screws with solvent and dab sealant on the threads. Many > builders seal the gasket to the tank with sealant as well, viewing the cork > ring as sacrificial if the cover is removed. Similarily, install the fitted > tank sender and gasket with sealant on all the screws." > Based on this I was planning to either use Proseal or use nothing on the > cork and follow other instructions exactly. I can only waffle for another > two days. Now I have the Fulelube option, as well. ARGGH! The fulelube > approach seems the best - - but a pretty important decision. If I can't > decide then I'll use Proseal for peace of mind. > Earnest, I tried using the cork gaskets and they would not hold air. I then made gaskets out of a thick automotive gasket paper and they still would not hold air. I then took off the paper gaskets, soaked them in fuel lube for 24 hours and put them back on. That was last summer and the balloons I used to air test still have positive pressure in them. Kevin in WA -9A finshing stuff ________________________________________________________________________________
Date: Apr 26, 2001
Subject: wing & tail fairings
I recently went to look at an RV6 that had excellent wing and tail fairings. These were custom done. I am considering making a mold and producing them. Please give me feedback on whether you would be interested and at what costs. Tail fairing= wing fairingsThanks, Rick Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Subject: Re: RV8-List: dumb question # 44499776
Date: Apr 26, 2001
Try Sam James, he provides a nice alternative. Jim Stone SDF ----- Original Message ----- From: old ogre <jollyd(at)teleport.com> Sent: Wednesday, April 25, 2001 9:57 PM Subject: RV8-List: dumb question # 44499776 > --> RV8-List message posted by: old ogre > > has anyone decided to replace the van's supplied cowl with a different > cowl?...I sure would like to change mine, but havn't heard of anyone > around the portland-salem washington aerea doing it...any > comments?...thanks...jolly > > > > > > ________________________________________________________________________________
Date: Apr 26, 2001
Subject: Re: MD-42 BS rivets
In a message dated 4/24/01 9:52:49 PM Pacific Daylight Time, bicyclop(at)pacbell.net writes: << The plans call for MD-42 BS pop rivets to hold the ends of the elevator pushrods into the aluminum tube. I can't find enough of those in my kit to do the job but I have a whole bunch of MSP -42's. >> MSP-42s have replaced the MD-42 BS. Harry Crosby Pleasanton, California RV-6, finish kit stuff ________________________________________________________________________________
Date: Apr 26, 2001
Subject: House of Kolor question
PLEASE do not flame me for asking a (stupid?) question, put I could not find a clear answer in the archives. I have fallen in love with some colors made by House of Kolor, used on show cars and custom motorcycles. Will these urethane & polyurethane paints be tough enough for an RV airplane? Thank you. Kim Nicholas RV9 wings ________________________________________________________________________________
Subject: Re: RV-List Digest: Wanted Garmin 195
Date: Apr 26, 2001
12:35:44 PM Do any of you happen to have a Garmin 195 that you would like to sell? If so, please contact me off list. Thanks, Mel Jordan Tucson, AZ Phone 520 575 0738 n6jx(at)earthlink.net Do Not Archieve ________________________________________________________________________________
Date: Apr 26, 2001
Subject: Re: House of Kolor question
Kim, at Sun N Fun a couple of weeks ago, one of the seminars that I dropped into on a "lark", was the painting seminar. It was hosted by the owner of Poly Fiber. He was a powerful and gifted speaker. Amongst other things, he said (and Van says the same thing): choose a manufacturer's system and use their whole system...from the primer on up. Follow their directions . Don't mix and match. He also said that polyurethanes are the only way to go. So I guess the real question is...are House of Color products good to use on airplanes? They are very big in custom cars and motorcycles. You'd have to get an opinion from an airplane guy that used their stuff. Barry Pote RV9a Wings Knicholas2(at)aol.com wrote: > > > PLEASE do not flame me for asking a (stupid?) question, put I could not find > a clear answer in the archives. I have fallen in love with some colors made > by House of Kolor, used on show cars and custom motorcycles. Will these > urethane & polyurethane paints be tough enough for an RV airplane? > > Thank you. > > Kim Nicholas > RV9 wings > ________________________________________________________________________________
From: "Craig Hiers" <craig-rv4(at)worldnet.att.net>
Subject: Fantasy of flight RV flyin
Date: Apr 26, 2001
Ok all you listers, here's an opportunity to fly into Fantasy of Flight, you know the place we all wished we owned. Sam James, Fiberglass guru and all around good guy some how got the Florida RV builders an invatation to have an RV flyin at Fantasy of Flight. As most of you know it is closed to all traffic unless prior arrangments have been made. The details were worked out by Laura Crook (yes, Tracy's wife) and are as follows. If you have any questions please contact me or Laura. Remember, you must RSVP, and if you are still building and want to rent a spammer to fly thats ok too. craig-rv4(at)worldnet.att.net laura_crook(at)hotmail.com Craig Hiers RV-4 N143CH Tallahassee,FL. > We have finalized the plans for the RV Flyout to Fantasy of Flight on May > 26, 2001 (Saturday of Memorial Day weekend) at 10:00 am. Group members who > arenot currently flying an RV and want to rent a plane to fly in, or who > want to drive in are welcome but PLEASE give me an RSVP. > > Admission to the facility will be $24.95 each ($22.95 if you want to admit > to being over 60 years old..); $13.95 for kids. Tour guides will be > provided for our group. A buffet lunch will be served for $7.10 per person. > > I have provided a $100 deposit to hold the date for us, and they require a > minimum of 10 planes to open the private strip to us, so lets work towards a > good turn out (don't want to loose my $100..). If you plan to attend and > have not provided an RSVP yet, PLEASE SEND ME AN RSVP (or call me at > 904/935-2973) by May 19th (I need a count for lunch) > > Here are the details of the arrival procedure: > NO FLY BYS > Fantasy of flights runways are TURF and are 5000 and 2600 feet long and kept > in top condition. No fuel or maintenance is available. This is a private > airstrip and you must be part of our group (RSVP to me) in order to fly in. > > Coordinates: N 28 10' W 81 48.5' Elevation: 139 ' msl > Radio 122.75 > FULL LENGTH OF RUNAY 31/13 CLOSED FOR TAKE OFF AND LANDINGS. > > Arrivals: Runway 4: Right hand pattern. This is the PREFERRED RUNWAY to > eliminate back taxi down the runway to parking. > Runway 22: Left hand pattern. Back taxi to intersection; turn RIGHT to > parking > > Departures: The preferred runway will be 22. If runway 4 is used, aircraft > will back taxi in groups of 5. > > Parking: Guest aircraft parking is on the southeast end of the CLOSED > runway 13/31. > > Runways remain hard after heavy rain, however, braking is poor and it will > spray your airplane with mud. Call ahead for conditions if desired. > > Lighted tower mile west of the runway 4 threshold. > > Vehicle parked in the intersection of the runways indicates the airport is > CLOSED to arrivals and departures. > > Avoid flying over the houses along the lakeshore and the trailer park > adjacent. > Questions or concerns: Jack McCloy 863-984-3500 ext 226 > Cell phone 863-287-5328 > Email jsm180(at)webcombo.net ________________________________________________________________________________
Date: Apr 26, 2001
Subject: (no subject)
I am getting ready to build an RV-7. I was planning on using zinc chromate for corrosion proofing. Are there any opinions on whether this is the right thing to use or is there something better? Thanks, Mark ________________________________________________________________________________
Date: Apr 26, 2001
In a message dated 4/26/01 11:59:52 AM Pacific Daylight Time, Knicholas2(at)aol.com writes: > PLEASE do not flame me for asking a (stupid?) question, put I could not > find > a clear answer in the archives. I have fallen in love with some colors > made > by House of Kolor, used on show cars and custom motorcycles. Will these > urethane & polyurethane paints be tough enough for an RV airplane? > > Thank you. > > Kim Nicholas > RV9 wings > > > If you live in California your pretty much screwed when it comes to urethane paints. Painting your plane is expensive and hard work. Polyurethane (single stage) paints are about one of the best paints to use on your plane. Most any auto paint store can mix any color of any paint in any quantity, use the good stuff because you will not want to do it twice. ________________________________________________________________________________
Date: Apr 26, 2001
I forgot one thing. The guy from Poly Fiber said that Urethanes can kill you. Normal cartridge type breathers are not enough. He recommends Hobby Air System. Barry Pote MeangreenRV4(at)aol.com wrote: > > > In a message dated 4/26/01 11:59:52 AM Pacific Daylight Time, > Knicholas2(at)aol.com writes: > > > PLEASE do not flame me for asking a (stupid?) question, put I could not > > find > > a clear answer in the archives. I have fallen in love with some colors > > made > > by House of Kolor, used on show cars and custom motorcycles. Will these > > urethane & polyurethane paints be tough enough for an RV airplane? > > > > Thank you. > > > > Kim Nicholas > > RV9 wings > > > > > > > > If you live in California your pretty much screwed when it comes to urethane > paints. Painting your plane is expensive and hard work. Polyurethane (single > stage) paints are about one of the best paints to use on your plane. Most any > auto paint store can mix any color of any paint in any quantity, use the good > stuff because you will not want to do it twice. > ________________________________________________________________________________
Date: Apr 26, 2001
In a message dated 4/26/01 1:30:17 PM Pacific Daylight Time, barrypote(at)home.com writes: > > I forgot one thing. The guy from Poly Fiber said that Urethanes can kill > you. Normal cartridge type breathers are not enough. He recommends Hobby > Air System. > Barry Pote > > I live in California and who ever it is (paint police) that regulates the type of paints used has made it illegal to buy the good stuff. I used Corlar Epoxy primer / Imron 5000 and was please with the product. I most definitely would not want to spray this stuff for a living. I agree that gloves, apparel and proper breathing apparatus's are a must. ________________________________________________________________________________
Date: Apr 26, 2001
Subject: Re: ADC filter & chip detection and prop governors
Thanks Richard, I put in my order today for the ADC. Anyone want to purchase an Airwolf remote filter kit for an IO360? Jody Villa > > >----- Original Message ----- >From: "JVilla" <jodyvilla(at)worldnet.att.net> >To: >Sent: Wednesday, April 25, 2001 3:42 PM >Subject: RV-List: ADC filter & chip detection and prop governors > >Jody: > >I have 200 hours on the ADC oil filter system in a 4 with an O-320. I have >had no problems and like it for all the reasons you listed. Just as they >predicted the "bypass" light came on twice in the first 20 hours on the >engine. The filter had picked up a small amount of lint/gasket material >etc. >The bypass light will also come on for a few minutes after a cold (20F or >so) start. It goes out as the oil temp starts to rise. Filter screen >cleaning is easy but one does have to exercise care in re-assemble of the >components, the screen is not bi-directional. I also believe their claims >that the filter lowers oil temps 10 degrees or so. With the cooler on the >rear baffle behind #4 cyl I have it 90% closed by a plate on the exit side >in all but the hottest weather. This was necessary to get the oil up to >180. Along with the cost it is also heavier than a stock system, about 6 >lbs if I recall correctly. The additional hoses and connections represent >added potential failure points; but I think the early oil contamination >warning is worth the down side factors. > >Dick Sipp >RV-4 200 hours > > ________________________________________________________________________________
Date: Apr 26, 2001
Thread-Topic: RV-List: House of Kolor question Thread-Index: AcDOi4qe1jCc/e2JSq+iUkpKWsYxngABBA6A
Kim, You will find the House of Kolor stuff is REALLY expensive stuff ($400 for a pint of some of their metallics; for the matter, Dupont Chromalusion is similarly priced, it's the stuff that changes color depending on the angle you're looking at it from). I asked my auto-painter friend who guided me during the painting process about it when I was painting... He uses many of their funky metallics in painting custom cars (base-coat-clear-coat) for stripes and airbrushing but will use it with a less-expensive base-coat and clear coat, like Dupont Chroma-One (chroma-base? I can't remember). Their metallic flakes come in small clear jars (I think they cost around $100 per jar) and can be added to other-brand paints to really give some neat effects, but I couldn't use them since I used Dupont Centauri (single stage) to paint my bird. One of my do-overs on my next project will be to use a base-coat-clear-coat system. Clear coats really bring out the shine, plus they're a bit softer which allows for buffing. I would think since almost all auto manufactures use base-coat-clear-coat systems they should be as durable as the polyurethanes (Imron, JetGlo, etc.) Maybe others who used clear-coats can comment on durability. Lately I've heard that Sikkens is very good paint to use. It was a topic of conversation at SNF with a friend of mine and he said you can take a can of Sikkens clear coat and look in the can and it's clear, unlike other clear-coats that have a yellow tint to them. This was coming from a guy who used SW Sunfire paint on his RV-8. Bob Japundza RV-6 N244BJ O-360C/S flying F1 tail kit on order -----Original Message----- From: Knicholas2(at)aol.com [mailto:Knicholas2(at)aol.com] Sent: Thursday, April 26, 2001 1:56 PM Subject: RV-List: House of Kolor question PLEASE do not flame me for asking a (stupid?) question, put I could not find a clear answer in the archives. I have fallen in love with some colors made by House of Kolor, used on show cars and custom motorcycles. Will these urethane & polyurethane paints be tough enough for an RV airplane? Thank you. Kim Nicholas RV9 wings ________________________________________________________________________________
Date: Apr 26, 2001
There are a couple on the E-bay aviation page. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of jordan_mel(at)ti.com Sent: Thursday, April 26, 2001 7:37 AM Subject: RV-List: Re: RV-List Digest: Wanted Garmin 195 Do any of you happen to have a Garmin 195 that you would like to sell? If so, please contact me off list. Thanks, Mel Jordan Tucson, AZ Phone 520 575 0738 n6jx(at)earthlink.net Do Not Archieve ________________________________________________________________________________
Date: Apr 26, 2001
I am sorry to not have done this in just one message, but...... ref Sun N Fun painting seminar: Other things he said. There are no 1 part poly Urethanes. The good stuff is 2 parts. Don't use clear coat on polyurethanes. It is not needed with correct technique. They chalk and grey faster. Don't use acyrlics on planes. They are too brittle (not flexible). Barry Pote ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Subject: Heat muff
Date: Apr 26, 2001
I sent an email off to Larry Vetterman but I thought I would tap into the collective wisdom of the list as well. I need to install a heat muff on my Vetterman 4-pipe exhaust system. I was wondering if anyone had any suggestions. Would the universal heat muff sold by Van's fit the 4-pipe exhaust? Is there another muff more suited to this? -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 ________________________________________________________________________________
Date: Apr 26, 2001
Subject: Re: strobes
Mark & listers, The Galls model GR120 only produces 20 watts (16 2/3 Joules). It will only support two strobes. Is this the unit you are referring to Keith? If not, what is the model you are referring to? Whelan's model U-GR083 has also been mentioned lately ($100 new) It produces 45 watts (37.5 Joules) These units aren't even close to being in the same catagory as the Nova X-Pac 904 or the Whelen HDA-CF It's an apples to oranges comparison. My hat is off to Mark for finding a unit which compares to the aviation Whelen HDA-CF for less money!!!! One question for you Mark. How can we contact Strobes N' More? Do they have a web site? Email? Phone?? Charlie Kuss > Keith, > > I looked at Galls in my search for high-watt power supplies and didn't > find anything equivalent to Whelen's HDA-CF system....Whelen does make a > number of power supplies that have lower power ratings though. I'd be > surprised if Galls has a system for $89 that does what my 90 Watt NOVA > system does but if so please let me know what it is. > > One comment I would make is that if the Galls system is in a plastic box, > it will probably create a lot of noise in your comm radio. The NOVA > system (like Whelen) is enclosed completely in metal and according to the > installation instructions, if you ground the case to the airframe (or > "Chassis ground") you should not have any noise. > > Regards, > > --Mark Navratil > Cedar Rapids, Iowa > RV-8A fuselage, O-360-A4A, Sensenich 87" > > > >If it's not too late... > > > >From Galls, inc. www.galls.com or 1-800-477-7766. Galls supplies > >equipment to police and fire departments. They sell a Whelin strobe > >power supply that is the same as the aircraft version except that it's > >in a plastic box as opposed to a metal one and it sells for $89. Same > >inside, just doesn't say "Aircraft" on it. If you are interested I'll > >post the part number. > > > >Keith Hughes ________________________________________________________________________________
Date: Apr 26, 2001
Kim, Our company has been painting everything from race cars to dental office equipment for 30 years. As a few of the other folks have said Urethanes should be handled (and sprayed) for what they are, Hazardous Materials. They contain Isocyanates and other things that make you, and the enviroment sick if misused. To answer your intial question...I personally would not use H Of K products for several reasons. First is the price. Production urethanes are expensive enough let alone small batch producers like H of K. Number two, The level of UV inhibitors may not bee as high in the "show colors" as is in the O.E.M. type paint. Third, all the pretty pearls, flip/flops, and candies are mainly added components to the primary mixing formula or is introduced to the color coat and or clear during coats. So far we have never had a color or texture we couldn't match through Dupont or PPG. All the additives such as pearl and flake is also availible through them. There are several newer brands on the market now. One of them is called Omni. It is a one stage poly-urethane. It's real nice stuff to work with and the cost is comparible to acrylic enamel. We've done several street rods in it and to date (about 3 years) these daily drivers have held up even with the road gunk of winter. Talk with your local auto paint supply house rep. They should be able to answer most if not all your questions. Jim Duckett ________________________________________________________________________________
Date: Apr 26, 2001
Date: Apr 26, 2001
Mark, I didn't read all of your posts carefully enough. After re reading them, I see your mention of a link off of Nova's site. You can reach Strobes N' More directly at: http://strobeguy.safeshopper.com/index.htm?116 For a few dollars more than the 4 head X-Pac 904 ($159.95) you mention (see web page below) http://strobeguy.safeshopper.com/11/cat11.htm?116 you can purchase the Super Pac 906 ($168.95) 6 head power supply. (see web page below) http://strobeguy.safeshopper.com/10/cat10.htm?116 Since you can then power 3 heads off of this 6 head supply, all 3 strobes can receive equal power from the supply. (3 X 30 watts [25 joules] per sequence) You won't have to diminish the power going to the 2 wingtip strobes as the X-Pac 904 does (22.5 + 22.5 + 45 watts [18.75 + 18.75 + 37.5 joules per sequence) This would seem to be a better unit for those folks who need a 3 strobe system. Charlie Kuss Charlie Kuss wrote: > Mark & listers, > The Galls model GR120 only produces 20 watts (16 2/3 Joules). It will only > support two strobes. Is this the unit you are referring to Keith? If not, > what is the model you are referring to? > Whelan's model U-GR083 has also been mentioned lately ($100 new) It produces > 45 watts (37.5 Joules) These units aren't even close to being in the same > catagory as the Nova X-Pac 904 or the Whelen HDA-CF It's an apples to > oranges comparison. My hat is off to Mark for finding a unit which compares > to the aviation Whelen HDA-CF for less money!!!! > One question for you Mark. How can we contact Strobes N' More? Do they have > a web site? Email? Phone?? > Charlie Kuss > > > Keith, > > > > I looked at Galls in my search for high-watt power supplies and didn't > > find anything equivalent to Whelen's HDA-CF system....Whelen does make a > > number of power supplies that have lower power ratings though. I'd be > > surprised if Galls has a system for $89 that does what my 90 Watt NOVA > > system does but if so please let me know what it is. > ________________________________________________________________________________
Date: Apr 26, 2001
Subject: Re: Heat muff
In a message dated 4/26/01 3:45:12 PM Pacific Daylight Time, "versadek"@earthlink.net writes: > Scott, > Call Rick Robins, (303-422-9389) he is the Heat Muff Guru, Larry Vetterman > Gave me > this tip, when I asked whether to use Van's muffs or what? Rick is great to > work > with. He helped me set up the inlet and outlet on a pair of them configured > to run > in series, one on each side with a 2" sceet cross-over behind the carb, to > get max > heat. > I bought one of Rick Robbins Heat Muff and will say there is no better muff made, he puts out real good stuff ________________________________________________________________________________
Date: Apr 26, 2001
In a message dated 4/26/01 2:03:26 PM Pacific Daylight Time, Bob.Japundza(at)realmed.com writes: > > Kim, > > You will find the House of Kolor stuff is REALLY expensive stuff ($400 > for a pint of some of their metallics; for the matter, Dupont > Chromalusion is similarly priced, it's the stuff that changes color > depending on the angle you're looking at it from). I asked my > auto-painter friend who guided me during the painting process about it > when I was painting... He uses many of their funky metallics in > painting custom cars (base-coat-clear-coat) for stripes and airbrushing > but will use it with a less-expensive base-coat and clear coat, like > Dupont Chroma-One (chroma-base? I can't remember). Their metallic > flakes come in small clear jars (I think they cost around $100 per jar) > and can be added to other-brand paints to really give some neat effects, > but I couldn't use them since I used Dupont Centauri (single stage) to > paint my bird. > > One of my do-overs on my next project will be to use a > base-coat-clear-coat system. Clear coats really bring out the shine, > plus they're a bit softer which allows for buffing. I would think since > almost all auto manufactures use base-coat-clear-coat systems they > should be as durable as the polyurethanes (Imron, JetGlo, etc.) Maybe > others who used clear-coats can comment on durability. > > Lately I've heard that Sikkens is very good paint to use. It was a > topic of conversation at SNF with a friend of mine and he said you can > take a can of Sikkens clear coat and look in the can and it's clear, > unlike other clear-coats that have a yellow tint to them. This was > coming from a guy who used SW Sunfire paint on his RV-8. > > Bob Japundza > RV-6 N244BJ O-360C/S flying > The only problem wit base coat clear coat is if you ever have damage like a bird or a rock strike you have to repaint the whole area (no spot painting) as to where on single stage you can spot repair and then buff out the area. ________________________________________________________________________________
Date: Apr 26, 2001
Subject: RV6 fuselage Jig -Free
I have a beautiful RV6 fuselage Jig that I will give to the first builder who picks it up. Ted Gauthier Pontiac, Michigan 1-248-249-1780 Cell daytime 1-248-681-8184 home blunist(at)flash.net ________________________________________________________________________________
Date: Apr 26, 2001
Scott, I am using Larry's four-n2-two exhaust with his heat muff. The quality of the muff equals his exhaust. The "out" tube is restricted to build back pressure for better heating. I am not flying yet, but do have it installed. Here are the dimensions: length = 8 inches diameter = 3 inches. It is mounted just below a slip joint and you need a straight section long enough to fit the 8" length. The part of the muff nearest the engine sets off the exhaust about 3/4". I have about 1" clearance between the engine and the muff at this time. I also have 2 stainless steel pan scrubbing pads stuffed in the muff to help with increasing heat. Hopes this helps. Jerry Calvert Edmond Ok -6 fuselage/finish kit ----- Original Message ----- From: Van Artsdalen, Scott <svanarts(at)unionsafe.com> Sent: Thursday, April 26, 2001 4:37 PM Subject: RV-List: Heat muff > > I sent an email off to Larry Vetterman but I thought I would tap into the > collective wisdom of the list as well. I need to install a heat muff on my > Vetterman 4-pipe exhaust system. I was wondering if anyone had any > suggestions. Would the universal heat muff sold by Van's fit the 4-pipe > exhaust? Is there another muff more suited to this? > -- > Scott VanArtsdalen, MCSE, CCNA > Network Administrator > Union Safe Deposit Bank > 209-946-5116 > > ________________________________________________________________________________
Subject: scoring the angle aluminum - HS-610
Date: Apr 26, 2001
When cutting out the AA6 3/4 x 3/4 angle iron to fabricate the HS-610 for the front spar, I let the saw blade drift a bit and got a bit of a score across the flange tongue of the aluminum. It is 1-5/16" from the tip, and appears to be 1/64" deep, going all the way across. Two rivets would be outside this when fastened to the forward spar. There are a couple of other nicks and scores, mostly scotchbrite-able, from clamps, etc. I am learning lots on this educational project, and am pretty certain that I should get another aluminum angle and start again as the score above seems like it would focus stress and be the ideal fracture spot for the spar. But, I wanted to ask -- how deep is too deep for something like that? If you can't smooth it out with scotch brite, is it so deep that it will concentrate force and fracture? Is there some rule of thumb of score depth vs. bar thickness? While I am striving for perfection, I am also trying to learn when to sweat it and when to not! Thanks, feel free to reply on or off line. Terri Watson Lander, WY RV-6 to 7 fwd spar, HS ________________________________________________________________________________
Date: Apr 26, 2001
In a message dated Thu, 26 Apr 2001 5:38:56 PM Eastern Daylight Time, "Van Artsdalen, Scott" writes: I sent an email off to Larry Vetterman but I thought I would tap into the collective wisdom of the list as well. I need to install a heat muff on my Vetterman 4-pipe exhaust system. I was wondering if anyone had any suggestions. Would the universal heat muff sold by Van's fit the 4-pipe exhaust? Is there another muff more suited to this?>> Scott- Go with Rick Robbins' muffs. -GV ________________________________________________________________________________
Date: Apr 26, 2001
Subject: Re: (no subject)
In a message dated 4/26/01 3:06:50 PM Central Daylight Time, Slgmjg1(at)cs.com writes: << I am getting ready to build an RV-7. I was planning on using zinc chromate for corrosion proofing. Are there any opinions on whether this is the right thing to use or is there something better? Thanks, Mark >> Mark, This is a MUCH debated subject. To get a good idea, go into the archives and type in "primer" as your search topic. Settle in with a nice cup of coffee and start reading. You'll be there for a while. While you are reading the different posts, take note of where the poster is from geographically. It seams that opinions vary from dry climates recommending little or no primer to those living in sea air climates recommending the full acid etch/alodine/two part mil spec epoxy primer. You read it all and then decide for yourself. Thats one of the best parts of building one of these. You get a great education. Good luck, Eric Newton - Long Beach, Mississippi RV-6A N57ME (Reserved) (panel wiring) http://www.ericsrv6a.com ________________________________________________________________________________
Date: Apr 26, 2001
Eric is correct!!! Everyone has an opinon. I tried just about every method as many of us have. Your gonna have to decide for yourself. FYI, I ended up with Variprime. To me the easiest and sticks best. Others will debate that, so in order from keep all the started-takes Erics advise read the archives. Oh, the archives may leave you still undecided. Contact me off list if you want my loooooooooooong story of priming. Bob in Ark sealing tanks. ________________________________________________________________________________
Date: Apr 26, 2001
Subject: Fuel Remaining (thanks)
Thanks to all who responded! Lots of useful info. Anh -6 N985VU Maryland ________________________________________________________________________________
Date: Apr 26, 2001
Scott, I think there's information on heat muffs in the archives. If I remember correctly, Vans universal heat muff is too long to fit on the Vetterman cross over system. It is also my understanding that the exhaust systems sold by Vans (supplied by Vetterman) are now shipped with the Robbins heat muff. John Warren RV-6Q N645W LaCenter, WA ----- Original Message ----- From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com> Sent: Thursday, April 26, 2001 2:37 PM Subject: RV-List: Heat muff > > I sent an email off to Larry Vetterman but I thought I would tap into the > collective wisdom of the list as well. I need to install a heat muff on my > Vetterman 4-pipe exhaust system. I was wondering if anyone had any > suggestions. Would the universal heat muff sold by Van's fit the 4-pipe > exhaust? Is there another muff more suited to this? > -- > Scott VanArtsdalen, MCSE, CCNA > Network Administrator > Union Safe Deposit Bank > 209-946-5116 > > ________________________________________________________________________________
"Rv-List(at)Matronics.Com"
Subject: Gyros Anyone?
Date: Apr 26, 2001
Hi all... Anybody out there overhaul gyros? I have a DG and AI that I need checked out at least, and probably overhauled... Please contact me off list: bill(at)vondane.com And... Thanks Mike and Bill! Bill VonDane, Colorado Springs, CO RV-8A, N8VD, Fuselage http://vondane.com/rv8a/ ________________________________________________________________________________
Date: Apr 26, 2001
In a message dated 4/26/01 10:24:31 PM Eastern Daylight Time, jwdub(at)teleport.com writes: > > > > I sent an email off to Larry Vetterman but I thought I would tap into the > > collective wisdom of the list as well. I need to install a heat muff on > my > > Vetterman 4-pipe exhaust system. I was wondering if anyone had any > > suggestions. Would the universal heat muff sold by Van's fit the 4-pipe > > exhaust? Is there another muff more suited to this? > > -- I haven't been following this thread, but recommend that you call Larry Vetterman. He knows what's available and helped me with my exhaust and heat muff needs. Brian Eckstein 6A getting close ________________________________________________________________________________
Date: Apr 26, 2001
Subject: Re: RV6-List: scoring the angle aluminum - HS-610
Terri: I damaged my HS610 and had to make another. It seemed like a painful choice at the time, because it was the first mistake like that I'd made. But it wasn't the last, and I'm sure there will be many more. Without looking at the part I don't want to venture an opinion. But I will say that if you feel at all uncomfortable about it you should probably redo it. It's not that big a deal in the overall scheme of things, and you'll probably feel better about it afterward. By the way, I prevented further nicks and scratches by taping strips of beer can material to the surfaces I wanted to protect each time I used a file or saw blade. It worked like a charm. You can file the flange stub right down to a few thou thick that way, and then the Scotchbrite wheel easily takes the remainder right off. Tedd McHenry Surrey, BC ________________________________________________________________________________
Date: Apr 26, 2001
Subject: Pseudo Fly-in (NW GA, This weekend)
There is a Boy Scout camporee at the Rome GA airport this weekend. On Saturday morning, the local EAA chapters are giving Young Eagle rides, with Experimentals and other non-certified riff-raff invited as display aircraft. (The Boy Scouts can't take rides in experimentals and ultralights as part of an official Scout activity). There will be food availible on the field (Pancakes, I think), and there is a cafe' on the for lunch. The main area of activity will be on the East side of the field, near the campground and jump base. The activities start as 8:00 AM on Saturday if anyone wants to drop by. Kyle Boatright - Kennesaw, GA RV-6 Slider, O-320/Aymar-Demuth ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Ammeter
I have Vans ammeter with 40 amp shunt. Wiring is from battery to shunt to Elec. Bobs fuse panel, with ammeter wired at shunt. I have only installed fuses for radios, elec. turn coord., panel lights and dimmer. With the radios turned off and I turn the master on the ammeter goes directly to -40. I am going to check amps with a multimeter but am wondering what could be causing this. I know the master solinoid draws quite a bit of current as does the gyro but why -40. Everything else seems to work fine. (engine is not installed) Any hints? John Danielson ________________________________________________________________________________
Date: Apr 27, 2001
house of colors.... oshkosh award winner 1999. enuf said.... ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Re: scoring the angle aluminum - HS-610
> >When cutting out the AA6 3/4 x 3/4 angle iron to fabricate the HS-610 for >the front spar, I let the saw blade drift a bit and got a bit of a score >across the flange tongue of the aluminum. It is 1-5/16" from the tip, and >appears to be 1/64" deep, going all the way across. Two rivets would be >outside this when fastened to the forward spar. > >There are a couple of other nicks and scores, mostly scotchbrite-able, from >clamps, etc. > >I am learning lots on this educational project, and am pretty certain that I >should get another aluminum angle and start again as the score above seems >like it would focus stress and be the ideal fracture spot for the spar. >But, I wanted to ask -- how deep is too deep for something like that? If >you can't smooth it out with scotch brite, is it so deep that it will >concentrate force and fracture? Is there some rule of thumb of score depth >vs. bar thickness? > >While I am striving for perfection, I am also trying to learn when to sweat >it and when to not! > >Thanks, feel free to reply on or off line. > >Terri Watson >Lander, WY >RV-6 to 7 fwd spar, HS > Terri, Typical structural repair manuals (Boeing, etc) will say to use a 10 to 1 slope when dressing out scratches, to avoid having the reduced thickness cause a significant stress concentration. For example, if the damage is 1/64 deep, the area dressed out should extend to 5/32 (10 times 1/64) each side of the damage. Even if you solve the stress concentration/risk of cracking problem, you would lose some strength because of the reduced thickness in this area. The best bet is to talk with Vans. The engineers at Vans should be be able to say whether the part will be strong enough considering the reduced thickness. Take care, -- Kevin Horton RV-8 (mounting wings) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Date: Apr 27, 2001
I had a problem with the HS-614 and ended up ordering another piece from Van's. If I had it to do all over again, I would just order a longer piece of the same material from Wicks, Aircraft Spruce, etc. As far as the strength aspect of that part, why take chances? If Van's tells you it's ok as long as you dress the scoring, how do you know if you will be doing the repair correctly? I'd get a new part and start over. Jim Bower St. Louis, MO RV-6A Wings >From: windsaloft(at)rmisp.com (Terri Watson) >Reply-To: rv-list(at)matronics.com >To: >Subject: RV-List: scoring the angle aluminum - HS-610 >Date: Thu, 26 Apr 2001 18:55:07 -0600 > > >When cutting out the AA6 3/4 x 3/4 angle iron to fabricate the HS-610 for >the front spar, I let the saw blade drift a bit and got a bit of a score >across the flange tongue of the aluminum. It is 1-5/16" from the tip, and >appears to be 1/64" deep, going all the way across. Two rivets would be >outside this when fastened to the forward spar. > >There are a couple of other nicks and scores, mostly scotchbrite-able, from >clamps, etc. > >I am learning lots on this educational project, and am pretty certain that >I >should get another aluminum angle and start again as the score above seems >like it would focus stress and be the ideal fracture spot for the spar. >But, I wanted to ask -- how deep is too deep for something like that? If >you can't smooth it out with scotch brite, is it so deep that it will >concentrate force and fracture? Is there some rule of thumb of score depth >vs. bar thickness? > >While I am striving for perfection, I am also trying to learn when to sweat >it and when to not! > >Thanks, feel free to reply on or off line. > >Terri Watson >Lander, WY >RV-6 to 7 fwd spar, HS > > ________________________________________________________________________________
Date: Apr 27, 2001
04/27/2001 08:52:35 AM barry pote (at)matronics.com on 04/26/2001 05:14:48 PM Please respond to rv-list(at)matronics.com Sent by: owner-rv-list-server(at)matronics.com cc: Subject: Re: RV-List: House of Kolor question Hey Barry, some of this is pretty weird. This is not a flame, I'm not arguing with you, just some of his statements are a little odd. >>I am sorry to not have done this in just one message, but...... ref Sun N Fun painting seminar: >>Other things he said. >>There are no 1 part poly Urethanes. The good stuff is 2 parts. One part, did he mean one stage? By one part I think of open the can and put it on without mixing it with anything. If that's what he meant then well no sh**. If he meant one stage he's wrong, there are both single and double stage polyurethanes. A single stage is a paint that has the color and the clear already mixed together. A dual stage is one that you apply the color base, which dries very flat. Then you apply the clear over it. Basically they are the same paints, one is just separated from the other so you can have greater control over the paint process. >>Don't use clear coat on polyurethanes. It is not needed with correct technique. They chalk and grey faster. See above, I have no idea what he's basing this on. If you put five heavy coats of clear on and park the plane in the sun it will start to grey on you. If you follow the manufacturers recipe this will not happen. >>Don't use acrylics on planes. They are too brittle (not flexible). One of the most commonly used aircraft paints is Sherwin Williams AcryGlow. Its good stuff, as a matter of fact I'm getting ready to place an order for some. Why Acrylic? Its a little easier to repair than poly (theoretically) and its a little less scary than polys in the paint booth. It will still mess you up plenty if you get a good snoot full. All these things will hurt you if you don't take care of yourself. Its also more friendly to color sanding the base coat before applying the clear coat. It allows you to actually color sand your base coat and still get a chemical bond with the clear coat after the sanding process if done within a certain time frame. This is the recipe for a dynamite paint job. One last thing about clears. A good reason to use a base coat clear coat is to seal the edges of your striping. All of us have seen nice paint jobs where the edges of paint stripes are chipping off. The wind sun and weather works non stop on these edges trying to separate the two. With a two stage paint process the edges are sealed from the elements, oil and dirt will never collect in the small edge where your masking tape once was. This makes for a more durable paint job. Ok, really the last thing. "But using a clear adds unnecessary weight to your plane." B.S! If done properly a single stage will come out to the same paint depth as a dual stage paint job. You are intended to use the same amount of clear as is put into a single stage paint at the factory. Its apples to apples, the method of application is the only difference. In addition to that, a clear coat is lighter and thinner than a normal coat of paint. Why? much less solids in a clear coat. A gallon of clear if sprayed to the point of just flowing out, will go much farther than a gallon of base, it just goes on thinner. I am not a paint professional, just a paint junkie. I love the stuff and find the whole art of painting one of the most fulfilling things I have learned. This is all just my opinion, but I'll put my money where my mouth is since I just told you exactly how my plane will be painted. Eric Henson Canopy ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Oil Analysis
Hey Guys, I need some help from those of you that have sent an oil sample out to be analyzed. I bought a couple of analysis packets at Sun-n-Fun this year, and when I got back home, I changed my oil and sent a sample away per the instructions. This is the first time I've ever had my oil analyzed. The engine is a Bart O-320 with 140 hours on it. Yesterday, I got a letter from the company with a list of the trace elements found in the oil. That's it!! So I'm thinking to myself, where is the analysis at? Am I supposed to look at these number of about 7 elements and deduce something from it? I could find nothing else on the sheet to tell me what the numbers meant. Is this what I get for my $25 or is there supposed to be more to it? I would have thought that I would at least get one sentence that says "everything looks normal" or "have a mechanic check out your engine" or something. Help please. Randy Pflanzer N417G RV-6 Indianapolis ________________________________________________________________________________
Subject: Lycoming Crankshaft woes
Date: Apr 27, 2001
Listers, FYI MORE CRANKSHAFT WOES, THIS TIME IT'S LYCOMING Reminiscent of last year's Teledyne Continental crankshaft problems, Textron Lycoming recently released Service Bulletin (SB) 549 highlighting a "potential metallurgical condition" on crankshafts installed in four- cylinder 360-series engines or shipped as spare parts. The suspect crankshafts were shipped from the Lycoming factory May 1, 1997, through April 30, 2000, and are listed by serial number in the SB. Lycoming requires that affected airplanes undergo nondestructive testing at one of several Lycoming-certified facilities listed in the SB, and will extend warranty coverage for cost of the required inspections through October 31 of this year. Lycoming has supplied AOPA with additional information not found in the SB, including the failure events leading up to this SB, the nature of the defect, and testing methods. For more, see AOPA Online ( http://www.aopa.org/whatsnew/regulatory/reglycoming_crank.html ). Jack RV8, wings DSM ________________________________________________________________________________
Date: Apr 27, 2001
1. He said there are no one part polyurethanes. In other words there is one part of paint and another part (catalyst?). He said nothing about stages. He even went so far as to say that a can of 'polyurethane' from Home Depot, is not really polyurethane. 2. As for clear coating, I just report what he said. He also said he did not believe in waxing polyurethanes. He also said he would hold off on using waterbourne's till they are perfected. Barry Pote (just reporting what was said) Eric.J.Henson(at)chase.com wrote: > > > barry pote (at)matronics.com on 04/26/2001 05:14:48 PM > > Please respond to rv-list(at)matronics.com > > Sent by: owner-rv-list-server(at)matronics.com > > To: rv-list(at)matronics.com > cc: > Subject: Re: RV-List: House of Kolor question > > > Hey Barry, some of this is pretty weird. This is not a flame, I'm not > arguing with you, just some of his statements are a little odd. > > >>I am sorry to not have done this in just one message, but...... > ref Sun N Fun painting seminar: > > >>Other things he said. > > >>There are no 1 part poly Urethanes. The good stuff is 2 parts. > > One part, did he mean one stage? By one part I think of open the can and > put it on without mixing it with anything. If that's what he meant then > well no sh**. If he meant one stage he's wrong, there are both single and > double stage polyurethanes. A single stage is a paint that has the color > and the clear already mixed together. A dual stage is one that you apply > the color base, which dries very flat. Then you apply the clear over it. > Basically they are the same paints, one is just separated from the other so > you can have greater control over the paint process. > > >>Don't use clear coat on polyurethanes. It is not needed with correct > technique. They chalk and grey faster. > > See above, I have no idea what he's basing this on. If you put five heavy > coats of clear on and park the plane in the sun it will start to grey on > you. If you follow the manufacturers recipe this will not happen. > > >>Don't use acrylics on planes. They are too brittle (not flexible). > > One of the most commonly used aircraft paints is Sherwin Williams AcryGlow. > Its good stuff, as a matter of fact I'm getting ready to place an order for > some. Why Acrylic? Its a little easier to repair than poly (theoretically) > and its a little less scary than polys in the paint booth. It will still > mess you up plenty if you get a good snoot full. All these things will hurt > you if you don't take care of yourself. Its also more friendly to color > sanding the base coat before applying the clear coat. It allows you to > actually color sand your base coat and still get a chemical bond with the > clear coat after the sanding process if done within a certain time frame. > This is the recipe for a dynamite paint job. > > One last thing about clears. A good reason to use a base coat clear coat is > to seal the edges of your striping. All of us have seen nice paint jobs > where the edges of paint stripes are chipping off. The wind sun and weather > works non stop on these edges trying to separate the two. With a two stage > paint process the edges are sealed from the elements, oil and dirt will > never collect in the small edge where your masking tape once was. This > makes for a more durable paint job. > > Ok, really the last thing. "But using a clear adds unnecessary weight to > your plane." B.S! If done properly a single stage will come out to the same > paint depth as a dual stage paint job. You are intended to use the same > amount of clear as is put into a single stage paint at the factory. Its > apples to apples, the method of application is the only difference. In > addition to that, a clear coat is lighter and thinner than a normal coat of > paint. Why? much less solids in a clear coat. A gallon of clear if sprayed > to the point of just flowing out, will go much farther than a gallon of > base, it just goes on thinner. > > I am not a paint professional, just a paint junkie. I love the stuff and > find the whole art of painting one of the most fulfilling things I have > learned. This is all just my opinion, but I'll put my money where my mouth > is since I just told you exactly how my plane will be painted. > > Eric Henson > Canopy > ________________________________________________________________________________
Date: Apr 27, 2001
Subject: -360 crankshaft "potential metallurgical condition"
23 March 2001 Lycoming issued MANDATORY Service Bulletin number 549. NOTE: Affects only 4-cylinder crankshafts in -360 series engines. (There were some crankshafts not heat treated properly.) This effects crankshafts shipped from the factory between May 1, 1997, and April 30, 2000. Read about the issue: http://www.aopa.org/whatsnew/regulatory/reglycoming_crank.html Read the SB: http://www.aopa.org/whatsnew/regulatory/lycoming_crankshaft_sb.pdf So far, only 1 of 3 RVs in SoCAL with new engines from Van's is effected. He will be having his crankshaft inspected FREE today in Santa Monica (if we are VFR). It was reported that the prop must be removed and that it takes 1 hour to do the inspection. After the work is complete, there is a 6 hour wait to reinstall the prop and fly away. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 788+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Subject: Re: Ammeter
Date: Apr 27, 2001
I would be looking for a short. Somewhere the insulation is cut or scraped off and a wire is touching the airframe. It is in the wiring after the ammeter. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh ----- Original Message ----- From: <JDaniel343(at)aol.com> Sent: Thursday, April 26, 2001 11:31 PM Subject: RV-List: Ammeter > > I have Vans ammeter with 40 amp shunt. Wiring is from battery to shunt to > Elec. Bobs fuse panel, with ammeter wired at shunt. > I have only installed fuses for radios, elec. turn coord., panel lights and > dimmer. > With the radios turned off and I turn the master on the ammeter goes directly > to -40. > I am going to check amps with a multimeter but am wondering what could be > causing this. I know the master solinoid draws quite a bit of current as does > the gyro but why -40. Everything else seems to work fine. (engine is not > installed) > Any hints? > > John Danielson > > ________________________________________________________________________________
Date: Apr 27, 2001
From: "Higgins, John J." <john_higgins(at)merck.com>
Subject: RV-8 QB Kit For Sale
Fellow listers - I was an active lister a couple of years ago when I began an RV-8 kit - work gradually took more and more time - couldn't build so I kept buying parts - I've finally and reluctantly come to the conclusion that I will never have time to finish the airplane - so I'm finally putting it up for sale It's a complete RV-8 QB including the finishing kit - the emp is finished - includes engine mounts, exhaust, Sensenich prop/spinner for O-360, Airflow Performance injection kit, vac pump, VM-1000 & annunciator, PSS Sport AOA kit, Andair gascolator/valve, flight instruments (ex-gyros), RMD tip lights, 3 strobe Whelen kit, intercom, Hooker belts, Johanson seats, electrical parts, construction tapes, some tools - located in New Jersey If anyone is interested, pls contact me off line at: john_higgins(at)merck.com John Higgins ________________________________________________________________________________
Subject: Re: Oil Analysis
Date: Apr 27, 2001
Randy, Aviation Consumer recently (this year) reviewed 5-6 companies offering oil analysis. It was a pretty good article and yes you should be getting an analysis of what the counts mean. Chuck & Dave Rowbotham RV-8A (almost done with F/G) Niantic, CT (Westerly airport) ________________________________________________________________________________
Date: Apr 27, 2001
I think some of the confusion over the statements forwarded by Barry is due to the source of his info. He stated that he attended a Poly Fiber forum, and Poly Fiber markets finish materials almost exclusively to the builders of fabric covered aircraft. Since I have built two fabric covered planes and refinished a J-3, I am familiar with Poly Fiber's products and John's forums. The statements reported by Barry are generally true if you are working with fabric. Acrylic is indeed too brittle for fabric, but is totally acceptable for a metal plane. The water-borne products are a hot topic (and source of competition to Poly Fiber) among the fabric builders, so obviously Poly Fiber is taking a "wait and see" attitude. Experimental fabric builders have painted planes with everything from Rustoleum to latex house paint. That is the reason for John's statement concerning Home Depot paint. Hopefully this will clear the water a bit. The Poly Fiber forum was not a very appropriate site for info concerning painting our metal RVs. Sam Buchanan (RV-6 Classic) "The RV Journal" http://home.hiwaay.net/~sbuc/journal ===================== barry pote wrote: > > > 1. He said there are no one part polyurethanes. In other words there is > one part of paint and another part (catalyst?). He said nothing about > stages. He even went so far as to say that a can of 'polyurethane' from > Home Depot, is not really polyurethane. > > 2. As for clear coating, I just report what he said. > > He also said he did not believe in waxing polyurethanes. > > He also said he would hold off on using waterbourne's till they are > perfected. > > Barry Pote (just reporting what was said) > > Eric.J.Henson(at)chase.com wrote: > > > > > > barry pote (at)matronics.com on 04/26/2001 05:14:48 PM > > > > Please respond to rv-list(at)matronics.com > > > > Sent by: owner-rv-list-server(at)matronics.com > > > > To: rv-list(at)matronics.com > > cc: > > Subject: Re: RV-List: House of Kolor question > > > > > > Hey Barry, some of this is pretty weird. This is not a flame, I'm not > > arguing with you, just some of his statements are a little odd. > > > > >>I am sorry to not have done this in just one message, but...... > > ref Sun N Fun painting seminar: > > > > >>Other things he said. > > > > >>There are no 1 part poly Urethanes. The good stuff is 2 parts. > > > > One part, did he mean one stage? By one part I think of open the can and > > put it on without mixing it with anything. If that's what he meant then > > well no sh**. If he meant one stage he's wrong, there are both single and > > double stage polyurethanes. A single stage is a paint that has the color > > and the clear already mixed together. A dual stage is one that you apply > > the color base, which dries very flat. Then you apply the clear over it. > > Basically they are the same paints, one is just separated from the other so > > you can have greater control over the paint process. > > > > >>Don't use clear coat on polyurethanes. It is not needed with correct > > technique. They chalk and grey faster. > > > > See above, I have no idea what he's basing this on. If you put five heavy > > coats of clear on and park the plane in the sun it will start to grey on > > you. If you follow the manufacturers recipe this will not happen. > > > > >>Don't use acrylics on planes. They are too brittle (not flexible). > > > > One of the most commonly used aircraft paints is Sherwin Williams AcryGlow. > > Its good stuff, as a matter of fact I'm getting ready to place an order for > > some. Why Acrylic? Its a little easier to repair than poly (theoretically) > > and its a little less scary than polys in the paint booth. It will still > > mess you up plenty if you get a good snoot full. All these things will hurt > > you if you don't take care of yourself. Its also more friendly to color > > sanding the base coat before applying the clear coat. It allows you to > > actually color sand your base coat and still get a chemical bond with the > > clear coat after the sanding process if done within a certain time frame. > > This is the recipe for a dynamite paint job. > > > > One last thing about clears. A good reason to use a base coat clear coat is > > to seal the edges of your striping. All of us have seen nice paint jobs > > where the edges of paint stripes are chipping off. The wind sun and weather > > works non stop on these edges trying to separate the two. With a two stage > > paint process the edges are sealed from the elements, oil and dirt will > > never collect in the small edge where your masking tape once was. This > > makes for a more durable paint job. > > > > Ok, really the last thing. "But using a clear adds unnecessary weight to > > your plane." B.S! If done properly a single stage will come out to the same > > paint depth as a dual stage paint job. You are intended to use the same > > amount of clear as is put into a single stage paint at the factory. Its > > apples to apples, the method of application is the only difference. In > > addition to that, a clear coat is lighter and thinner than a normal coat of > > paint. Why? much less solids in a clear coat. A gallon of clear if sprayed > > to the point of just flowing out, will go much farther than a gallon of > > base, it just goes on thinner. > > > > I am not a paint professional, just a paint junkie. I love the stuff and > > find the whole art of painting one of the most fulfilling things I have > > learned. This is all just my opinion, but I'll put my money where my mouth > > is since I just told you exactly how my plane will be painted. > > > > Eric Henson > > Canopy ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Alternator puzzle- oscillating voltage
I am having some trouble with the alternator on my RV-6A and I am wondering if anyone might offer some advice. When I ran the engine the voltage in the system went to about 14.7 volts and the needle on the voltmeter was "waving" with a 1-2 volt fluctuation. I put a VOM on the electrical system and verified the voltage. The panel lights also dim with the same frequency. I removed the alternator and voltage regulator and took them to an alternator shop. The fellow there put them both on the bench and ran them at high speed (big electric motor turning the alternator with a belt). The voltage was smooth as glass and pegged around 13.9 volts. I put the alternator back on the engine and saw the same readings as before, voltage oscillating around 14.7 volts plus or minus 1 volt. I then ran a ground wire directly from the alternator case (the voltage regulator is mounted on but not in the alternator)to the ground bus on the firewall, which in turn is ground to the battery. No change. I then disabled the OV protection Zener Diode. No change. I am running Bob Nuckoll's electrical system with a primary (critical) buss and secondary bus. I have a Cessna-tpe split master switch. The Field wire also goes through a 5A CB. The B lead on the alternator goes through a 60A CB. The alternator is a auto alternator conversion purchased from Mark Landoll, and the voltage regulator is a small flat pack mounted externally on the alternator which has a Ford part number. I'm looking for ideas on why the voltage on the airplane would be higher than on the bench, or why I would see voltage oscillations on the airplane and not the bench. Any help would be appreciated. John Allen RV-6A Signed off and ready to fly (boy,it feels good to say that) Sign Up Now! http://www.onebox.com ________________________________________________________________________________
Date: Apr 27, 2001
Sam, the FORUM was a Painting Forum. It so happened the the owner of Poly Fiber was the speaker. The Axis (HVLP and the Hobby Air) were there too. 95% of the attendees were 'aluminum plane' people. There was a Poly Fiber forum in another tent, but this was not that. Some of the things discussed: (quoting him) LAQUER: soaks through previous coats and makes soft again ENAMEL: are hard paints. Acrylics: harder yet. good for cars. not good for planes that flex more than cars. Water Bourne: soft. doesn't weather well. Aerothane,Randthane, Imron,Airtech are all good polyurethanes. Don't wash down the floor just before painting. The humidity destroys paint jobs. Keep lights (the more lights the better) out of the paint booth. Let them shine throught the plastic walls. You don't want one exploding inside the booth while painting. Many people in attendence said packing tape was better than duct tape for making plastic/pvc paint booths. The best way to paint is to spray so you can look into it and see the reflection of the light in it as you go. Left to right and then right to left with over lapping strokes. Cris-cross pattern is only used with metalics, not with urethanes. Gravity is your friend. Best results are obtained by laying objects to be painted, FLAT. Avoid verticle painting. Paint the fuselage on a roteserie. Practice on luan paneling WITH THE GOOD, EXPENSIVE PRODUCT you are going to use on the plane. 77 degrees with zero humidity is the best conditions to paint. Avoid humid days. 70-80 degrees is OK. 3 coats are best on airplanes. 'Tach' coats are not needed with polyurethanes. "more paint jobs are ruined by rushing to get it ready for OSH or Sun N Fun!" do not rush!!! "Some great home paint jobs take 5 months". Nothing at all was mentioned about POLY FIBERing fabric planes. That was pretty much the whole seminar. The man seemed very knowledgeable. Barry (just reporting....not confused about what I heard) Pote RV 9a Wings Sam Buchanan wrote: > > > I think some of the confusion over the statements forwarded by Barry is > due to the source of his info. He stated that he attended a Poly Fiber > forum, and Poly Fiber markets finish materials almost exclusively to the > builders of fabric covered aircraft. Since I have built two fabric > covered planes and refinished a J-3, I am familiar with Poly Fiber's > products and John's forums. > > The statements reported by Barry are generally true if you are working > with fabric. Acrylic is indeed too brittle for fabric, but is totally > acceptable for a metal plane. > > The water-borne products are a hot topic (and source of competition to > Poly Fiber) among the fabric builders, so obviously Poly Fiber is taking > a "wait and see" attitude. > > Experimental fabric builders have painted planes with everything from > Rustoleum to latex house paint. That is the reason for John's statement > concerning Home Depot paint. > > Hopefully this will clear the water a bit. The Poly Fiber forum was not > a very appropriate site for info concerning painting our metal RVs. > > Sam Buchanan (RV-6 Classic) > "The RV Journal" http://home.hiwaay.net/~sbuc/journal > > ===================== > > barry pote wrote: > > > > > > 1. He said there are no one part polyurethanes. In other words there is > > one part of paint and another part (catalyst?). He said nothing about > > stages. He even went so far as to say that a can of 'polyurethane' from > > Home Depot, is not really polyurethane. > > > > 2. As for clear coating, I just report what he said. > > > > He also said he did not believe in waxing polyurethanes. > > > > He also said he would hold off on using waterbourne's till they are > > perfected. > > > > Barry Pote (just reporting what was said) > > > > Eric.J.Henson(at)chase.com wrote: > > > > > > > > > barry pote (at)matronics.com on 04/26/2001 05:14:48 PM > > > > > > Please respond to rv-list(at)matronics.com > > > > > > Sent by: owner-rv-list-server(at)matronics.com > > > > > > To: rv-list(at)matronics.com > > > cc: > > > Subject: Re: RV-List: House of Kolor question > > > > > > > > > Hey Barry, some of this is pretty weird. This is not a flame, I'm not > > > arguing with you, just some of his statements are a little odd. > > > > > > >>I am sorry to not have done this in just one message, but...... > > > ref Sun N Fun painting seminar: > > > > > > >>Other things he said. > > > > > > >>There are no 1 part poly Urethanes. The good stuff is 2 parts. > > > > > > One part, did he mean one stage? By one part I think of open the can and > > > put it on without mixing it with anything. If that's what he meant then > > > well no sh**. If he meant one stage he's wrong, there are both single and > > > double stage polyurethanes. A single stage is a paint that has the color > > > and the clear already mixed together. A dual stage is one that you apply > > > the color base, which dries very flat. Then you apply the clear over it. > > > Basically they are the same paints, one is just separated from the other so > > > you can have greater control over the paint process. > > > > > > >>Don't use clear coat on polyurethanes. It is not needed with correct > > > technique. They chalk and grey faster. > > > > > > See above, I have no idea what he's basing this on. If you put five heavy > > > coats of clear on and park the plane in the sun it will start to grey on > > > you. If you follow the manufacturers recipe this will not happen. > > > > > > >>Don't use acrylics on planes. They are too brittle (not flexible). > > > > > > One of the most commonly used aircraft paints is Sherwin Williams AcryGlow. > > > Its good stuff, as a matter of fact I'm getting ready to place an order for > > > some. Why Acrylic? Its a little easier to repair than poly (theoretically) > > > and its a little less scary than polys in the paint booth. It will still > > > mess you up plenty if you get a good snoot full. All these things will hurt > > > you if you don't take care of yourself. Its also more friendly to color > > > sanding the base coat before applying the clear coat. It allows you to > > > actually color sand your base coat and still get a chemical bond with the > > > clear coat after the sanding process if done within a certain time frame. > > > This is the recipe for a dynamite paint job. > > > > > > One last thing about clears. A good reason to use a base coat clear coat is > > > to seal the edges of your striping. All of us have seen nice paint jobs > > > where the edges of paint stripes are chipping off. The wind sun and weather > > > works non stop on these edges trying to separate the two. With a two stage > > > paint process the edges are sealed from the elements, oil and dirt will > > > never collect in the small edge where your masking tape once was. This > > > makes for a more durable paint job. > > > > > > Ok, really the last thing. "But using a clear adds unnecessary weight to > > > your plane." B.S! If done properly a single stage will come out to the same > > > paint depth as a dual stage paint job. You are intended to use the same > > > amount of clear as is put into a single stage paint at the factory. Its > > > apples to apples, the method of application is the only difference. In > > > addition to that, a clear coat is lighter and thinner than a normal coat of > > > paint. Why? much less solids in a clear coat. A gallon of clear if sprayed > > > to the point of just flowing out, will go much farther than a gallon of > > > base, it just goes on thinner. > > > > > > I am not a paint professional, just a paint junkie. I love the stuff and > > > find the whole art of painting one of the most fulfilling things I have > > > learned. This is all just my opinion, but I'll put my money where my mouth > > > is since I just told you exactly how my plane will be painted. > > > > > > Eric Henson > > > Canopy > ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Re: House of Kolor question
Just, my input here. May not mean much but... In a message dated 4/27/2001 10:10:02 AM Central Daylight Time, barrypote(at)home.com writes: > > Sam, the FORUM was a Painting Forum. It so happened the the owner of > Poly Fiber was the speaker. The Axis (HVLP and the Hobby Air) were there > too. 95% of the attendees were 'aluminum plane' people. There was a Poly > Fiber forum in another tent, but this was not that. > > Some of the things discussed: (quoting him) > LAQUER: soaks through previous coats and makes soft again > ENAMEL: are hard paints. > Acrylics: harder yet. good for cars. not good for planes that flex > more > Water Bourne: soft. doesn't weather well. > Aerothane,Randthane, Imron,Airtech are all good polyurethanes. > Don't wash down the floor just before painting. The humidity destroys > paint jobs. > Keep lights (the more lights the better) out of the paint booth. Let > them shine throught the plastic walls. You don't want one exploding > inside the booth while painting. Lights can be in the paint booth. THe connections just have to be sealed, aka enclosed in pipes. > Many people in attendence said packing tape was better than duct tape > for making plastic/pvc paint booths. > The best way to paint is to spray so you can look into it and see the > reflection of the light in it as you go. > Left to right and then right to left with over lapping strokes. > Cris-cross pattern is only used with metalics, not with urethanes. > Gravity is your friend. Best results are obtained by laying objects to > be painted, FLAT. Avoid verticle painting. Paint the fuselage on a > roteserie. Right, but thats easier said then done, but if you dont overspray it wont run, so.... > Practice on luan paneling WITH THE GOOD, EXPENSIVE PRODUCT you are going > to use on the plane. > 77 degrees with zero humidity is the best conditions to paint. Avoid > humid days. 70-80 degrees is OK. The catalyst in the paint can be changed to correct for teperature and humity > 3 coats are best on airplanes. Depends on the paint color and product > 'Tach' coats are not needed with polyurethanes. > "more paint jobs are ruined by rushing to get it ready for OSH or Sun N > Fun!" do not rush!!! "Some great home paint jobs take 5 months". > > Nothing at all was mentioned about POLY FIBERing fabric planes. > Also nothing was said about venting the booth so that overspray doenst fall back on the aircraft ________________________________________________________________________________
Date: Apr 27, 2001
Barry, my apologies for mis-characterizing your statements. Your quote "It was hosted by the owner of Poly Fiber" lead me to erroneously jump to the conclusion it was a Poly Fiber forum. I assumed the statements quoted were primarily intended for Poly Fiber customers. Sam Buchanan (RV-6, PPG Concept, DP50 primer, S/W wash primer, Rustoleum whenever the mood struck me.....) ======================== barry pote wrote: > > > Sam, the FORUM was a Painting Forum. It so happened the the owner of > Poly Fiber was the speaker. The Axis (HVLP and the Hobby Air) were there > too. 95% of the attendees were 'aluminum plane' people. There was a Poly > Fiber forum in another tent, but this was not that. ________________________________________________________________________________
Subject: Re: Las Vegas/Henderson/Boulder City RVers)
Date: Apr 29, 2001
Change of plans. NORTH Las Vegas would now be my preferred airport. So.... anyone? Randall Henderson ----- Original Message ----- From: "Randall Henderson" <randallh(at)home.com> Sent: Saturday, April 28, 2001 8:37 AM Subject: RV-List: Las Vegas/Henderson/Boulder City RVers > > I'm taking a trip down to Nevada (Las Vegas area) in late July . Will be > needing to park my RV-6 for 8-9 days. Is there anyone in that area who can > help me with finding a hangar to keep it in for that time? > > Best for me would be Boulder City, but if there's nothing there, Henderson > would probably work. I suppose McCarran Int'l could work but I'd just as > soon not go into the big Int'l airport (and they'd probably just as soon I > didn't as well).... > > Anyone have any ideas, please contact me off-line. > > Randall Henderson, RV-6 N6R (~200 hrs) > Portland, OR > http://www.edt.com/homewing ________________________________________________________________________________
Date: Apr 27, 2001
CW, you are right. I forgot that. Over spray in the air should be vacated from the booth, before it falls into the paint job. Some people used airconditioning filters to clean the air. If you use a fan as a 'sucker', make real sure it is a sealed unit (no sparks). Even if you use it as a "PUSHER" to push air into the booth, you should be careful with the kind of fan. He also gave a nice idea on a paint booth. 'Make a rectangle of PVC'. Hang the plastic from it. Pull the PVC pipe rectangle to the ceiling. Tape the plastic walls to it. You can roll up the 'walls' when not in use and store your paint booth on the ceiling between uses. That's it! I have a plane to build. Barry > > Also nothing was said about venting the booth so that overspray doenst fall > back on the aircraft > > ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Oil ?
Randy, This will not be an easy or short answer to your question. Chemical annalysis had been around for years. It is primarily used to determine the condition of an engine where teardown inspections are not practical or cost prohibitive. I do have a few questions though. Did the lab ask what oil you where using? Application where it was used, ie, air-cooled, water-cooled, Fuel type used and so on. Without having a standard or base in which to gauge the findings, true all you get is a bunch of numbers. You also need to know what things are made of and what is being produced during combustion. Two inert components can and most times do ionize into harmful elements such as acids, which is normal. If you have new oil that has 0ppm of say Cu and you get your findings back and there is 380 ppm of Cu then there is a good probability that something is really going bad with the bearings or something that has a lot of copper in it. Same is true if you use a low ash oil and you get a high ppm of carbon in the findings. A little C is okay and normal but if it's real high then somethings not right. In short the oil annalysis is just a "tool" you use with many other things to determine the health of an engine and how it is performing or being used. It does help steer you in where to start looking. The lab we use charges $135.00 for both coolant and oil but, when we get the results back we can see how the engine was used, what temps is was run at, even if the oil was changed regularly by knowing what elements and compounds to look for. I'd call the lab and ask if they have a comparitive to the oil you use so you have something to go by. Sorry about the length. Jim D. Peformance Engineering ________________________________________________________________________________
Date: Apr 29, 2001
I have my oil analyzed by AOA. I buy the kits from Aircraft Spruce. Their reports come back with a good listing of what the general limits are on the different metals, trend analysis, and notes and alerts on any anomalies. There are a number of articles out there too -- search the web for aircraft engine oil analysis. Randall Henderson, RV-6 N6R (~200 hrs) Portland, OR www.vanshomewing.org ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Re: Alternator puzzle- oscillating voltage
>I'm looking for ideas on why the voltage on the airplane would be higher >than on the bench, or why I would see voltage oscillations on the airplane >and not the bench. Any help would be appreciated. I had a thought, if it runs fine on the bench, then I wonder if your battery is affecting it and is just low causing it to charge at a higher rate? Regards, Tom Velvick Peoria, AZ rv-4 rv-6a wiring panel still >John Allen >RV-6A >Signed off and ready to fly (boy,it feels good to say that) > > >Sign Up Now! http://www.onebox.com > > ________________________________________________________________________________
Date: Apr 27, 2001
Check for a bad connection or bad ground. Make sure you have a ground strap from engine to airframe. Check to see if the regulator is correctly grounded. Some regulators use just the case, others have a ground wire. If you don't find a bad connection then start checking for a high resistance master relay. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh ----- Original Message ----- From: "John Allen" <fliier(at)onebox.com> Sent: Friday, April 27, 2001 10:00 AM Subject: RV-List: Alternator puzzle- oscillating voltage > > I am having some trouble with the alternator on my RV-6A and I am wondering > if anyone might offer some advice. > > When I ran the engine the voltage in the system went to about 14.7 volts > and the needle on the voltmeter was "waving" with a 1-2 volt fluctuation. > I put a VOM on the electrical system and verified the voltage. The panel > lights also dim with the same frequency. > > I removed the alternator and voltage regulator and took them to an alternator > shop. The fellow there put them both on the bench and ran them at high > speed (big electric motor turning the alternator with a belt). The voltage > was smooth as glass and pegged around 13.9 volts. > > I put the alternator back on the engine and saw the same readings as > before, voltage oscillating around 14.7 volts plus or minus 1 volt. > > I then ran a ground wire directly from the alternator case (the voltage > regulator is mounted on but not in the alternator)to the ground bus on > the firewall, which in turn is ground to the battery. No change. I > then disabled the OV protection Zener Diode. No change. > > I am running Bob Nuckoll's electrical system with a primary (critical) > buss and secondary bus. I have a Cessna-tpe split master switch. The > Field wire also goes through a 5A CB. The B lead on the alternator goes > through a 60A CB. The alternator is a auto alternator conversion purchased > from Mark Landoll, and the voltage regulator is a small flat pack mounted > externally on the alternator which has a Ford part number. > > I'm looking for ideas on why the voltage on the airplane would be higher > than on the bench, or why I would see voltage oscillations on the airplane > and not the bench. Any help would be appreciated. > > > John Allen > RV-6A > Signed off and ready to fly (boy,it feels good to say that) > > > Sign Up Now! http://www.onebox.com > > ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Painting
Guys, I don't want to jump in the middle of Barry and Eric BUT... having started with DUCO back in the late 60's, I think I've got a little experience under my belt using automotive and aircraft finishes. First , it seems like the speaker from fun 'n sun is confusing the discussion with using different terminology and comparing "industrial finishes" (Home Depot?) with A&A finishes. Eric brings out good points about stages not "parts". If you look at "parts" with Imron say, you technically have 4 parts but it is considered a 1 stage system. We us both 1 & 2 stage systems. generally 2 stage because we can "seal" the entire surface with clear and we can do so much more as far as stripes, graphics and such with the base coat and it's fast and smooth. Single stage is fine but, if your laying out several colors, you to have to wait a couple of days curing before you lay each color and you will always have a "seam" at the color borders. As far as weight of single stage Vs. two-stage...it's nominal. the real weight is in the primers and sealers, about 60-70% of total. As far as "chalking" generally it only happens when there isn't enough clear applied or the finish was forced dried improperly. The clear is what contains 90% of the UV inhibitor in A&A finishes. Wheather it's a 1 or 2 stage system. Most "industrial finishes" (Home Depot?) have little or no UV protection. So yeah, I can see where the speaker says that it will chalk if you use it. I just can't see myself painting a beutiful thing as an airplane with Home Depot "house paint". Nuff Said!....Where's that roller? Jim D. ________________________________________________________________________________
Subject: Fiberglass question
Date: Apr 27, 2001
I hear that the beauty of working with fiberglass is that it is easy to fix your mistakes. Hopefully that will be true. I began cutting my cowl last weekend. I made the cut and the top half fits beautifully against the top skin! So what's the problem? I didn't keep the gap between colw and spinner equal all the way around! I need to shift the colw a bit to make the gap equal. However, when I do that a gap appears between the edge of the cowl and top skin on the left side! Looks to be about 1/8 inch at the widest. So fiberglass gurus, how can I build that edge back up to meet the top skin again? Thanks. (again) ________________________________________________________________________________
Subject: Re: Fiberglass question
Date: Apr 27, 2001
Can't answer your question . . . just a reminder to leave a small gap ( .025 perhaps? I think Van's says 1/16th inch but this seems like the Grand Canyon) around all of the cowl edges to accommodate painting. I fit my cowl as perfectly as possible, THEN I did the light sanding to make the small clearance for paint. Rick Jory ----- Original Message ----- From: Van Artsdalen, Scott <svanarts(at)unionsafe.com> Sent: Friday, April 27, 2001 11:04 AM Subject: RV-List: Fiberglass question > > I hear that the beauty of working with fiberglass is that it is easy to fix > your mistakes. Hopefully that will be true. I began cutting my cowl last > weekend. I made the cut and the top half fits beautifully against the top > skin! So what's the problem? I didn't keep the gap between colw and > spinner equal all the way around! I need to shift the colw a bit to make > the gap equal. However, when I do that a gap appears between the edge of > the cowl and top skin on the left side! Looks to be about 1/8 inch at the > widest. So fiberglass gurus, how can I build that edge back up to meet the > top skin again? Thanks. (again) > > ________________________________________________________________________________
Date: Apr 27, 2001
You sure can! I did it more than once to get the fit that I wanted. What worked well for me was to take a piece of alum. and cover it with some clear packing tape and then tape and clamp it to the edge of the piece. This gave me a surface to layup over. Much eaiser this way. Karl ________________________________________________________________________________
Date: Apr 27, 2001
17, 2001) at 04/27/2001 02:05:34 PM I had a similar problem as I fitted the (epoxy) cowl to my -4. After "re-fitting" the cowl, I was left with a gap that went from zero to 1/8" at the aft edge of the top cowl where it met with the cheek piece on the left side. Here is what I did: Using a scrap of glass that I had cut off early in the fitting process, I made a "wedge" and glued back on using a structural adhesive. Because I used a scrap originally cut from the same area, it fit quite well. The piece I glued on was oversize, so I carefully sanded it to match the cheekpiece. The bonded joint was a butt-joint (not very strong), so I added a patch of very lightweight glass on the (outside) top surface of the cowl. After feathering the edges of the additional layer of glass, it was not noticeable. You may be able to glass the underside instead of, or in addition to the top side. I didn't want to add thickness to the underside as that surface rested on the cheekpiece. I hope this helps. If you have additional questions, please feel free to contact me offline. Dean Pichon RV-4 Arlington, MA |--------+----------------------------------> | | "Van Artsdalen, Scott" | | | | | | Sent by: | | | owner-rv-list-server@mat| | | ronics.com | | | | | | | | | 04/27/01 01:04 PM | | | Please respond to | | | rv-list | | | | |--------+----------------------------------> | | | To: "'rv-list(at)matronics.com'" | | cc: | | bcc: | | Subject: RV-List: Fiberglass question | I hear that the beauty of working with fiberglass is that it is easy to fix your mistakes. Hopefully that will be true. I began cutting my cowl last weekend. I made the cut and the top half fits beautifully against the top skin! So what's the problem? I didn't keep the gap between colw and spinner equal all the way around! I need to shift the colw a bit to make the gap equal. However, when I do that a gap appears between the edge of the cowl and top skin on the left side! Looks to be about 1/8 inch at the widest. So fiberglass gurus, how can I build that edge back up to meet the top skin again? Thanks. (again) **** This message is from Arthur D. Little, Inc., and/or one of Arthur D. Little's subsidiaries or affiliates and may contain confidential business information. It is intended for the addressee only and may not be copied without our permission. If you are not the intended recipient please contact the sender as soon as possible.**** ________________________________________________________________________________
Date: Apr 27, 2001
04/27/2001 11:05:27 AM, Serialize complete at 04/27/2001 11:05:27 AM John, A very common reason for the fluctuating voltage is a dirty master switch or a bad connection somewhere else in the field winding circuit. I had this problem in my Piper and verified that jumpering around the alternator side of the split master switch fixed the problem. Scott RV6 "John Allen" Sent by: owner-rv-list-server(at)matronics.com 04/27/2001 08:00 AM Please respond to rv-list To: rv-list-digest(at)matronics.com cc: Subject: RV-List: Alternator puzzle- oscillating voltage I am having some trouble with the alternator on my RV-6A and I am wondering if anyone might offer some advice. When I ran the engine the voltage in the system went to about 14.7 volts and the needle on the voltmeter was "waving" with a 1-2 volt fluctuation. I put a VOM on the electrical system and verified the voltage. The panel lights also dim with the same frequency. I removed the alternator and voltage regulator and took them to an alternator shop. The fellow there put them both on the bench and ran them at high speed (big electric motor turning the alternator with a belt). The voltage was smooth as glass and pegged around 13.9 volts. I put the alternator back on the engine and saw the same readings as before, voltage oscillating around 14.7 volts plus or minus 1 volt. I then ran a ground wire directly from the alternator case (the voltage regulator is mounted on but not in the alternator)to the ground bus on the firewall, which in turn is ground to the battery. No change. I then disabled the OV protection Zener Diode. No change. I am running Bob Nuckoll's electrical system with a primary (critical) buss and secondary bus. I have a Cessna-tpe split master switch. The Field wire also goes through a 5A CB. The B lead on the alternator goes through a 60A CB. The alternator is a auto alternator conversion purchased from Mark Landoll, and the voltage regulator is a small flat pack mounted externally on the alternator which has a Ford part number. I'm looking for ideas on why the voltage on the airplane would be higher than on the bench, or why I would see voltage oscillations on the airplane and not the bench. Any help would be appreciated. John Allen RV-6A Signed off and ready to fly (boy,it feels good to say that) Sign Up Now! http://www.onebox.com ________________________________________________________________________________
Date: Apr 27, 2001
Randy, If you would be willing to post your results I could help you and maybe everyone would have a little insight. It is not very hard to tell if something is going haywire. The best information however comes from a consistent baseline on your engine. Fortunately in airplanes the kind of oil you use is not really relevant because it is all ashless. (read, no metallic additives) Tailwinds, Doug Rozendaal dougr(at)petroblend.com www.petroblend.com/dougr snip > Is this what I get for my $25 or is there supposed to be more to it? I would > have thought that I would at least get one sentence that says "everything looks > normal" or "have a mechanic check out your engine" or something. > > Help please. ________________________________________________________________________________
Date: Apr 27, 2001
Randy and others, there is a man in Tulsa named Howard Fenton who does oil analysis. His company is, I believe, called Engine Oil Analysis. He only does aircraft engines. He has a lot of experience with aircraft engines, having worked in the overhaul business for a long time. I strongly recommend this service because he has been very helpful and given useful advice in the past. Mark Goldberg RV-8 N982RV 130 hrs ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Alaska trip planning
Members of EAA's Chapter 42 in Anchorage, Alaska would love to meet those traveling to our beautiful state and will enthusiastically assist you any way we can. Many members are willing to help provide housing. Tools and a float-plane slip can also be provided. Tours of local RV projects can also be arranged. Chapter 42 members do not need much of an excuse to gather for story telling and eating and would love to meet a group of travelers. Several Chapter 42 hang out at Birchwood airport, located about 20 miles northeast of downtown Anchorage. Contact me off-list if you're coming up this way. Fly carefully. Roy Glass Anchorage, AK RV-6, sanding and filling the tip-up canopy frame's f/g and running out of excuses not to cut the plexi ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Re: Nice.....smart ....
--- Bill Shook wrote: > > > Uh...damn...sorry guys...thought I was sending this to Eric only. > Foot in > mouth syndrome...it's a terrible thing to taste. Never apologize for stating the truth. Mike Thompson Austin, TX -6 N140RV (Reserved) Firewall Forward Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Date: Apr 27, 2001
Subject: "Flexible Fiberglass" ??
Hey listers, Does anyone know of a fabric/polymer composite solution that can be hand laid, but after curing becomes more like hard rubber than stiff fiberglass? I need to make a fairing in a location that will have to endure some impact without shattering. Would laminations of glass cloth with RTV silicone as the liquid component work? Is there a two-part version of RTV, instead of the air-dry type? Different hardnesses? What does the stuff cost? How can it be finshed/painted? Thanks, --Sam ________________________________________________________________________________
Subject: Re: "Flexible Fiberglass" ??
Date: Apr 27, 2001
17, 2001) at 04/27/2001 04:46:25 PM I have seen air ducts made with fiberglass and two-part silicone resin. The silicone will not likely accept paint, but you could pigment the resin... There are an infinite number of silicone casting resins available. You might also try two part urethane casting resins. A web-search will turn up many choices. Hapco is an east coast company that makes tooling resins. Most fiberglass has a sizing to help the resin wet it. You may have to experiment to find a good combination of cloth and resin. Finally, vinyl ester resins can be modified to be quite "rubbery". Talk to Dow Chemicals about their Derakane resin. Good Luck, Dean |--------+----------------------------------> | | "Sam Cherroff" | | | | | | Sent by: | | | owner-rv-list-server@mat| | | ronics.com | | | | | | | | | 04/27/01 04:02 PM | | | Please respond to | | | rv-list | | | | |--------+----------------------------------> | | | To: rv-list(at)matronics.com | | cc: | | bcc: | | Subject: RV-List: "Flexible Fiberglass" ?? | Hey listers, Does anyone know of a fabric/polymer composite solution that can be hand laid, but after curing becomes more like hard rubber than stiff fiberglass? I need to make a fairing in a location that will have to endure some impact without shattering. Would laminations of glass cloth with RTV silicone as the liquid component work? Is there a two-part version of RTV, instead of the air-dry type? Different hardnesses? What does the stuff cost? How can it be finshed/painted? Thanks, --Sam **** This message is from Arthur D. Little, Inc., and/or one of Arthur D. Little's subsidiaries or affiliates and may contain confidential business information. It is intended for the addressee only and may not be copied without our permission. If you are not the intended recipient please contact the sender as soon as possible.**** ________________________________________________________________________________
Date: Apr 27, 2001
Check to see if the regulator battery sense input is connected to the main bus through the master switch. If you have it connected to the back-up or "essential bus", the output to the main bus will be too high. The regulator will be trying to regulate the essential bus which is about .8 volts lower than the main bus since there is a power diode between the two. Garth Shearing VariEze and 75% RV-6A ----- Original Message ----- From: John Allen <fliier(at)onebox.com> Sent: April 27, 2001 8:00 AM Subject: RV-List: Alternator puzzle- oscillating voltage > When I ran the engine the voltage in the system went to about 14.7 volts > and the needle on the voltmeter was "waving" with a 1-2 volt fluctuation. > I put a VOM on the electrical system and verified the voltage. The panel > lights also dim with the same frequency. ________________________________________________________________________________
Date: Apr 27, 2001
About 20 years ago I played with a "Conformal Coating" material made by Dow Chemicals originally marketed as an electronic potting compound. I custom-made a complex air hose shape which was laid up much like any other glass lay-up using BID glass. Unfortunately I don't remember the part number, but I have a 1995 issue of a Newark Electronics catalogue which lists a two-part silicone rubber material which looks like it is an equivalent, made by GE. The following part numbers for various viscosities are as follows: RTV-615, "Low viscosity" RTV-630, "Medium viscosity" RTV-60, "Cures to a hard rubber" I would probably go for the low viscosity version for easy wetting out. The disadvantages are high cost, in the order of $100 for a 1 lb. package, and relatively high weight. Cure time is 24-36 hours. They do withstand quite high temperatures, up to 600 degrees F. By the way, I have heard of people using MEK to thin out one part silicon rubber, but I have no personal experience with it. Perhaps someone else on the list can enlighten us. Garth Shearing VariEze and 75% RV-6A ----- Original Message ----- From: Sam Cherroff <sam(at)videoassist.com> Sent: April 27, 2001 1:02 PM Subject: RV-List: "Flexible Fiberglass" ?? > > Hey listers, > Does anyone know of a fabric/polymer composite solution that can > be hand laid, but after curing becomes more like hard rubber than > stiff fiberglass? I need to make a fairing in a location that will have to > endure some impact without shattering. > > Would laminations of glass cloth with RTV silicone as the liquid > component work? Is there a two-part version of RTV, instead of the > air-dry type? Different hardnesses? What does the stuff cost? How > can it be finshed/painted? > > Thanks, > > --Sam > > ________________________________________________________________________________
From: "Doug Weiler" <doug.weiler(at)pressenter.com>
Subject: Vortex generators - long
Date: Apr 27, 2001
Fellow Listers: I just came back from a day spent with Larry Vetterman. He flew his RV-4 from Hot Springs SD and I met him in my -4 in Madison, SD. As you know Larry has installed VGs on his -4 and since his -4 is very similar to mine (180 hp, CS prop, nearly identical empty weights), I wanted to fly in his airplane and compare to a non-VG equipped RV-4. We were at gross weight with the two of us in the airplane. T/O roll is very short, even compared to mine which accelerates like a dragster. Probably less than 300'. We climbed up to altitude and Larry did some slow flight demos. The airplane is rock solid at an IAS of 40 mph (granted highly inaccurate at this speed). Aileron control is superb, certainly more responsive than mine at this speed. Stall break is pretty much the same as mine. I really could not detect any significant difference in top end speed (Larry says his IAS that day at 9500 ft was 178 mph at full throttle and 2400 rpm... same as mine). The approach was really about the same although we certainly could fly a little slower. But the touchdown speed was slower than mine and we did use less runway. The most significant difference I noticed was the much improved yaw stability. In turbulence my RV-4 has a pronounced tail wag. Larry's had none. It just bumped along perfectly straight in yaw. It was much more comfortable in the back seat than mine for that reason. Larry has no aerodynamic reason for this improvement (his airplane had the usual RV yaw prior to installing the VGs). But whatever the reason, it is greatly improved in turbulence and would make the VGs worthwhile for that reason alone. Anyway, I'm not sure if I will install them on my -4 yet, but I am very tempted. Thought you all might be interested. Doug Weiler MN Wing ________________________________________________________________________________
Date: Apr 27, 2001
Folks - this is a completely amazing list - the kit has been sold already John Higgins -----Original Message----- From: Higgins, John J. [mailto:john_higgins(at)merck.com] Sent: Friday, April 27, 2001 9:27 AM Subject: RV-List: RV-8 QB Kit For Sale Fellow listers - I was an active lister a couple of years ago when I began an RV-8 kit - work gradually took more and more time - couldn't build so I kept buying parts - I've finally and reluctantly come to the conclusion that I will never have time to finish the airplane - so I'm finally putting it up for sale It's a complete RV-8 QB including the finishing kit - the emp is finished - includes engine mounts, exhaust, Sensenich prop/spinner for O-360, Airflow Performance injection kit, vac pump, VM-1000 & annunciator, PSS Sport AOA kit, Andair gascolator/valve, flight instruments (ex-gyros), RMD tip lights, 3 strobe Whelen kit, intercom, Hooker belts, Johanson seats, electrical parts, construction tapes, some tools - located in New Jersey If anyone is interested, pls contact me off line at: john_higgins(at)merck.com John Higgins ________________________________________________________________________________
Subject: Re: Vortex generators - long
Date: Apr 27, 2001
One question. You quoted a top speed of 178 with an 0-360 and constant speed? Was that a typo or did I miss something? If that's true, Van's numbers are GROSSLY inaccurate and I thought that wasn't the case. Van's quotes a 75% cruise speed of 189 with a 150hp engine.....what gives? Bill -4 wings and hoping for a top speed of better than 178....van's numbers say a cruise of 200 !! ----- Original Message ----- From: "Doug Weiler" <doug.weiler(at)pressenter.com> Sent: Friday, April 27, 2001 6:22 PM Subject: RV-List: Vortex generators - long > > Fellow Listers: > > I just came back from a day spent with Larry Vetterman. He flew his RV-4 > from Hot Springs SD and I met him in my -4 in Madison, SD. > > As you know Larry has installed VGs on his -4 and since his -4 is very > similar to mine (180 hp, CS prop, nearly identical empty weights), I wanted > to fly in his airplane and compare to a non-VG equipped RV-4. > > We were at gross weight with the two of us in the airplane. T/O roll is > very short, even compared to mine which accelerates like a dragster. > Probably less than 300'. We climbed up to altitude and Larry did some slow > flight demos. The airplane is rock solid at an IAS of 40 mph (granted > highly inaccurate at this speed). Aileron control is superb, certainly more > responsive than mine at this speed. Stall break is pretty much the same as > mine. I really could not detect any significant difference in top end speed > (Larry says his IAS that day at 9500 ft was 178 mph at full throttle and > 2400 rpm... same as mine). > > The approach was really about the same although we certainly could fly a > little slower. But the touchdown speed was slower than mine and we did use > less runway. > > The most significant difference I noticed was the much improved yaw > stability. In turbulence my RV-4 has a pronounced tail wag. Larry's had > none. It just bumped along perfectly straight in yaw. It was much more > comfortable in the back seat than mine for that reason. Larry has no > aerodynamic reason for this improvement (his airplane had the usual RV yaw > prior to installing the VGs). But whatever the reason, it is greatly > improved in turbulence and would make the VGs worthwhile for that reason > alone. > > Anyway, I'm not sure if I will install them on my -4 yet, but I am very > tempted. > > Thought you all might be interested. > > Doug Weiler > MN Wing > > ________________________________________________________________________________
Date: Apr 27, 2001
Bill Shook wrote: > > > One question. You quoted a top speed of 178 with an 0-360 and constant > speed? Was that a typo or did I miss something? If that's true, Van's > numbers are GROSSLY inaccurate and I thought that wasn't the case. Van's > quotes a 75% cruise speed of 189 with a 150hp engine.....what gives? > > Bill > -4 wings and hoping for a top speed of better than 178....van's numbers say > a cruise of 200 !! > > ----- Original Message ----- > From: "Doug Weiler" <doug.weiler(at)pressenter.com> > To: "RV List" > Sent: Friday, April 27, 2001 6:22 PM > Subject: RV-List: Vortex generators - long > > > > > Fellow Listers: > > > > I just came back from a day spent with Larry Vetterman. He flew his RV-4 > > from Hot Springs SD and I met him in my -4 in Madison, SD. > > > > As you know Larry has installed VGs on his -4 and since his -4 is very > > similar to mine (180 hp, CS prop, nearly identical empty weights), I > wanted > > to fly in his airplane and compare to a non-VG equipped RV-4. > > > > We were at gross weight with the two of us in the airplane. T/O roll is > > very short, even compared to mine which accelerates like a dragster. > > Probably less than 300'. We climbed up to altitude and Larry did some > slow > > flight demos. The airplane is rock solid at an IAS of 40 mph (granted > > highly inaccurate at this speed). Aileron control is superb, certainly > more > > responsive than mine at this speed. Stall break is pretty much the same > as > > mine. I really could not detect any significant difference in top end > speed > > (Larry says his IAS that day at 9500 ft was 178 mph at full throttle and > > 2400 rpm... same as mine). > > > > The approach was really about the same although we certainly could fly a > > little slower. But the touchdown speed was slower than mine and we did > use > > less runway. > > > > The most significant difference I noticed was the much improved yaw > > stability. In turbulence my RV-4 has a pronounced tail wag. Larry's had > > none. It just bumped along perfectly straight in yaw. It was much more > > comfortable in the back seat than mine for that reason. Larry has no > > aerodynamic reason for this improvement (his airplane had the usual RV yaw > > prior to installing the VGs). But whatever the reason, it is greatly > > improved in turbulence and would make the VGs worthwhile for that reason > > alone. > > > > Anyway, I'm not sure if I will install them on my -4 yet, but I am very > > tempted. > > > > Thought you all might be interested. > > > > Doug Weiler > > MN Wing > > > > > Bill I am guessing he quoted indicated speed, his true airspeed is probably much faster than that, at least it is in my 180hp RV-6. Ah I went back and read his post and it does say IAS. ________________________________________________________________________________
Date: Apr 27, 2001
> > One question. You quoted a top speed of 178 with an 0-360 and constant > speed? Was that a typo or did I miss something? If that's true, Van's > numbers are GROSSLY inaccurate and I thought that wasn't the case. Van's > quotes a 75% cruise speed of 189 with a 150hp engine.....what gives? > > Bill > -4 wings and hoping for a top speed of better than 178....van's numbers say > a cruise of 200 !! No, no, no.. that was 178 mph IAS at 9500' which translates to a TAS of 207 mph (180 knots) Doug ________________________________________________________________________________
Date: Apr 27, 2001
From: "Builder's Bookstore" <winterland(at)rkymtnhi.com>
I assume 178 mph was indicated airspeed (IAS) at 9500'. At that altitude, True Airspeed (TAS) is 203 mph, which is still a bit slow for a 180 hp CS RV-4, but in the ball park and close to Van's numbers. Andy > > One question. You quoted a top speed of 178 with an 0-360 and constant > speed? Was that a typo or did I miss something? If that's true, Van's > numbers are GROSSLY inaccurate and I thought that wasn't the case. Van's > quotes a 75% cruise speed of 189 with a 150hp engine.....what gives? > ________________________________________________________________________________
Date: Apr 27, 2001
What Doug said was INDICATED airspeed at 9500, true airspeed will be significantly more than that. I'd calculate it but I don't know the temp or pressure. Mike Nellis Stinson 108-2 N9666K RV-6 N699BM (reserved)N Plainfield, IL (LOT) Building Flaps http://bmnellis.com ----- Original Message ----- From: "Bill Shook" <billshook(at)earthlink.net> Sent: Friday, April 27, 2001 5:33 PM Subject: Re: RV-List: Vortex generators - long > > One question. You quoted a top speed of 178 with an 0-360 and constant > speed? Was that a typo or did I miss something? If that's true, Van's > numbers are GROSSLY inaccurate and I thought that wasn't the case. Van's > quotes a 75% cruise speed of 189 with a 150hp engine.....what gives? > > Bill > -4 wings and hoping for a top speed of better than 178....van's numbers say > a cruise of 200 !! > > > ----- Original Message ----- > From: "Doug Weiler" <doug.weiler(at)pressenter.com> > To: "RV List" > Sent: Friday, April 27, 2001 6:22 PM > Subject: RV-List: Vortex generators - long > > > > > > Fellow Listers: > > > > I just came back from a day spent with Larry Vetterman. He flew his RV-4 > > from Hot Springs SD and I met him in my -4 in Madison, SD. > > > > As you know Larry has installed VGs on his -4 and since his -4 is very > > similar to mine (180 hp, CS prop, nearly identical empty weights), I > wanted > > to fly in his airplane and compare to a non-VG equipped RV-4. > > > > We were at gross weight with the two of us in the airplane. T/O roll is > > very short, even compared to mine which accelerates like a dragster. > > Probably less than 300'. We climbed up to altitude and Larry did some > slow > > flight demos. The airplane is rock solid at an IAS of 40 mph (granted > > highly inaccurate at this speed). Aileron control is superb, certainly > more > > responsive than mine at this speed. Stall break is pretty much the same > as > > mine. I really could not detect any significant difference in top end > speed > > (Larry says his IAS that day at 9500 ft was 178 mph at full throttle and > > 2400 rpm... same as mine). > > > > The approach was really about the same although we certainly could fly a > > little slower. But the touchdown speed was slower than mine and we did > use > > less runway. > > > > The most significant difference I noticed was the much improved yaw > > stability. In turbulence my RV-4 has a pronounced tail wag. Larry's had > > none. It just bumped along perfectly straight in yaw. It was much more > > comfortable in the back seat than mine for that reason. Larry has no > > aerodynamic reason for this improvement (his airplane had the usual RV yaw > > prior to installing the VGs). But whatever the reason, it is greatly > > improved in turbulence and would make the VGs worthwhile for that reason > > alone. > > > > Anyway, I'm not sure if I will install them on my -4 yet, but I am very > > tempted. > > > > Thought you all might be interested. > > > > Doug Weiler > > MN Wing > > > > > > ________________________________________________________________________________
Subject: Tail Wag
Date: Apr 27, 2001
Hello All, I just read Doug W.'s post about VG's & his mention of tail wag. Not too long ago I discovered that if I keep pressure on both rudder pedals while in the pattern, especially on final, the tail wag is much reduced. You can tell I'm slow. I've been flying a little over a yr. & just now figured this out. Guess you would call this the "peddle fixed" rudder case. Makes the VS & rudder act as one big VS. Rick Caldwell -6 214 hrs & frustrated with more broken avionics. Don't buy Chinese! Melbourne, FL ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Re: Gyros Anyone?
In a message dated Thu, 26 Apr 2001 10:36:32 PM Eastern Daylight Time, "Bill VonDane" writes: Hi all... Anybody out there overhaul gyros? I have a DG and AI that I need checked out at least, and probably overhauled... Please contact me off list: bill(at)vondane.com And... >> Bill- Try Jeff Chambliss @ California Gyro in Livermore, CA 925-426-0555. -GV ________________________________________________________________________________
Date: Apr 27, 2001
In a message dated Fri, 27 Apr 2001 8:58:37 AM Eastern Daylight Time, rpflanze(at)iquest.net writes: Hey Guys, I need some help from those of you that have sent an oil sample out to be analyzed. I bought a couple of analysis packets at Sun-n-Fun this year, and when I got back home, I changed my oil and sent a sample away per the instructions. This is the first time I've ever had my oil analyzed. The engine is a Bart O-320 with 140 hours on it. Yesterday, I got a letter from the company with a list of the trace elements found in the oil. That's it!! So I'm thinking to myself, where is the analysis at? Am I supposed to look at these number of about 7 elements and deduce something from it? I could find nothing else on the sheet to tell me what the numbers meant. Is this what I get for my $25 or is there supposed to be more to it? I would have thought that I would at least get one sentence that says "everything looks normal" or "have a mechanic check out your engine" or something.>> If you went to Howard Fenton at Engine Oil Analysis in Tulsa, OK you would get commentary in addition to analysis. Howard does oil anaysis of aircraft engines only and has many years of experience in this field. Contact info is (where else?) in the Yeller Pages. ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Re: RV-List:Mounting terminal block on RV-6A slider
From: "Randy Garrett" <rlgarrett7(at)home.com> Subject: RV-List: Mounting terminal block on RV-6A slider I have Van's wiring harness kit. Unfortunately (for me) the plans show the location of the terminal block (WH-801) for the tilt up canopy. On the slider, the instrument subpanel is different, so that location won't work ... it would overlap the joint where the two halves of the subpanel are joined. I could pick a somewhat arbitrary location of the terminal block, but with my luck, that would guarantee that the pre-fab wires in the wiring harness would be too short. Has someone else already figured out a good location for the terminal block, so that the wires in the wiring harness still reach? Thanks, Randy Randy, It doesn't matter if it overlaps the joint in the sub panel bulkhead. The terminal block is slightly flexible and wont break on the slightly irregular surface. It was designed for either canopy style to use the same measurements for component locations. Scott McDaniels Aurora, OR These opinions and ideas are my own and may not reflect the opinions or ideas of my employer. ________________________________________________________________________________
Date: Apr 27, 2001
Thanks Jerry...I did indeed miss that. Sorry for the confusion....but you gotta love the way several of you straightened me out. This list is incredible. Wish I had you guys around for finals week back in college. :-) Bill -4 relieved ----- Original Message ----- From: "Jerry Springer" <jsflyrv(at)earthlink.net> Sent: Friday, April 27, 2001 6:56 PM Subject: Re: RV-List: Vortex generators - long > > Bill Shook wrote: > > > > > > One question. You quoted a top speed of 178 with an 0-360 and constant > > speed? Was that a typo or did I miss something? If that's true, Van's > > numbers are GROSSLY inaccurate and I thought that wasn't the case. Van's > > quotes a 75% cruise speed of 189 with a 150hp engine.....what gives? > > > > Bill > > -4 wings and hoping for a top speed of better than 178....van's numbers say > > a cruise of 200 !! > > > > ----- Original Message ----- > > From: "Doug Weiler" <doug.weiler(at)pressenter.com> > > To: "RV List" > > Sent: Friday, April 27, 2001 6:22 PM > > Subject: RV-List: Vortex generators - long > > > > > > > > Fellow Listers: > > > > > > I just came back from a day spent with Larry Vetterman. He flew his RV-4 > > > from Hot Springs SD and I met him in my -4 in Madison, SD. > > > > > > As you know Larry has installed VGs on his -4 and since his -4 is very > > > similar to mine (180 hp, CS prop, nearly identical empty weights), I > > wanted > > > to fly in his airplane and compare to a non-VG equipped RV-4. > > > > > > We were at gross weight with the two of us in the airplane. T/O roll is > > > very short, even compared to mine which accelerates like a dragster. > > > Probably less than 300'. We climbed up to altitude and Larry did some > > slow > > > flight demos. The airplane is rock solid at an IAS of 40 mph (granted > > > highly inaccurate at this speed). Aileron control is superb, certainly > > more > > > responsive than mine at this speed. Stall break is pretty much the same > > as > > > mine. I really could not detect any significant difference in top end > > speed > > > (Larry says his IAS that day at 9500 ft was 178 mph at full throttle and > > > 2400 rpm... same as mine). > > > > > > The approach was really about the same although we certainly could fly a > > > little slower. But the touchdown speed was slower than mine and we did > > use > > > less runway. > > > > > > The most significant difference I noticed was the much improved yaw > > > stability. In turbulence my RV-4 has a pronounced tail wag. Larry's had > > > none. It just bumped along perfectly straight in yaw. It was much more > > > comfortable in the back seat than mine for that reason. Larry has no > > > aerodynamic reason for this improvement (his airplane had the usual RV yaw > > > prior to installing the VGs). But whatever the reason, it is greatly > > > improved in turbulence and would make the VGs worthwhile for that reason > > > alone. > > > > > > Anyway, I'm not sure if I will install them on my -4 yet, but I am very > > > tempted. > > > > > > Thought you all might be interested. > > > > > > Doug Weiler > > > MN Wing > > > > > > > > > Bill I am guessing he quoted indicated speed, his true airspeed is probably > much faster than that, at least it is in my 180hp RV-6. Ah I went back and > read his post and it does say IAS. > > ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Re: Oil Analysis
> >Hey Guys, > >I need some help from those of you that have sent an oil sample out to be >analyzed. > I bought a couple of analysis packets at Sun-n-Fun this year, and when I got >back home, I changed my oil and sent a sample away per the instructions. This >is the first time I've ever had my oil analyzed. The engine is a Bart O-320 >with 140 hours on it. > >Yesterday, I got a letter from the company with a list of the trace elements >found in the oil. That's it!! So I'm thinking to myself, where is the >analysis >at? Am I supposed to look at these number of about 7 elements and deduce >something >from it? I could find nothing else on the sheet to tell me what the numbers >meant. > >Is this what I get for my $25 or is there supposed to be more to it? I would >have thought that I would at least get one sentence that says "everything >looks >normal" or "have a mechanic check out your engine" or something. > >Help please. > >Randy Pflanzer N417G >RV-6 Indianapolis Randy, I bought my sample kits at Oshkosh & then some more at Sun 'n Fun this year. They are from Aviation Laboratories in Louisiana - maybe they are the same as yours. Both reports include the sentence "Result ** normal sample, send next sample at the normal interval". Here are the detailed analysis results at 105 & 150 hrs on a new O-360-A1A: Tot Hrs Hrs Oil Hrs/qt Iron Cu Nickel Cr Silver Mag Al Lead Si Ti Tin Moly 105 43 3 14 25.8 34.4 3.3 5.6 0.0 6.0 7.8 4481 8.4 0.1 2.7 0.2 150 45 2.5 18 20.0 26.8 1.4 3.2 0.0 3.2 5.8 4198 6.1 0.0 1.2 0.1 I would be interested to know how these figures compare with others. All I can tell is that all the trace element quantities were lower in the second sample - I hope that's a good thing! Regards, Chris Good, http://www.rv.supermatrix.com West Bend, WI RV6A-QB N86CG, 185 hrs ________________________________________________________________________________
Date: Apr 27, 2001
I should have guessed that my oil analysis table would get garbled by the time it reached the list. I've added a link to my web site, in case anyone would like to see the results more clearly. Regards, Chris Good, http://www.rv.supermatrix.com West Bend, WI RV6A-QB N86CG, 185 hrs ________________________________________________________________________________
Date: Apr 27, 2001
From: Gary and Carolyn Zilik <zilik(at)bewellnet.com>
Subject: Re: Tail Wag
Awhile back there was a discussion about tail wag with the RV-3's. One list member said he did a rudder squeeze similar to when squeezing ailerons for heavy wing conditions. Well I thought my 6A tail wagged a little so I bummed a ride in another 6A in similar thermal conditions and noted that his tail didn't wag as much, or so it seemed. So I did the rudder squeeze after a afternoon flight and went right back up. The difference was amazing. I still have a happy tail but not quite so ecstatic as it had been before. Gary Zilik Rick Caldwell wrote: > > Hello All, > > I just read Doug W.'s post about VG's & his mention of tail wag. Not too > long ago I discovered that if I keep pressure on both rudder pedals while in > the pattern, especially on final, the tail wag is much reduced. You can tell > I'm slow. I've been flying a little over a yr. & just now figured this out. > Guess you would call this the "peddle fixed" rudder case. Makes the VS & > rudder act as one big VS. > ________________________________________________________________________________
Date: Apr 27, 2001
Try Instrument overhaul service of San Diego inc. 1-800-466-OVHL They also have good prices on attitude ind. and giros and will set the tilt for you Ken S. Down to all the little stuff and stuff and..... > Hi all... > > Anybody out there overhaul gyros? I have a DG and AI that I need checked > out at least, and probably overhauled... > > Please contact me off list: bill(at)vondane.com > > And... >> > > Bill- > > Try Jeff Chambliss @ California Gyro in Livermore, CA 925-426-0555. > > -GV > > ________________________________________________________________________________
Subject: Oil Analysis
Date: Apr 27, 2001
Chris, I do oil analysis for the Oregon Air Guard. We only work on jets, but I have checked samples for my own plane (Interstate Cadet, C-75) and a couple of other engines. So I can't give you much engine specific info, but that isn't too important anyway. The readout looks almost exactly the same way ours do, so they are probably using a similar spectrometer. Different spectrometers can give SLIGHTLY different results. Individually, all the numbers look OK (but see the note about lead, below), but the trend is the important thing, which means to get useful information, you need to continue sampling at regular intervals. If a bearing or other part starts to wear abnormally, you should see a large jump in one or more elements. With the combination of elements in hand, you can then call Lycoming and they can probably tell you which parts are made of those elements. The numbers are parts per million. The readings of .1 and .2 in titanium and molydenum are measurement errors and do not represent any real presence of either of those elements. Some metals, however, are used by refiners to improve oil performance and may show up in your oil sample even though those metals were not used in manufacturing your engine. So if you change brands of oil, you might find something that was zero before. I presume you use 100LL, which would explain why the lead is so high. If not, then maybe there is a problem, but I don't know where else lead would come from. I usually find only a few hundred parts per million of lead, but I burn 80/87. Oil analysis looks at the concentrations of metals that disperse in the oil through wear. It can not predict catastrophic failure-it can't tell you if your crankshaft is about to break. To get best results, always sample the oil in the same way. The best is probably to sample right after running the engine. Surprisingly, even though we are measuring molecule sized particles, they do settle out, so mixing the oil in some way for sampling is important. The standards we use (oil having known concentrations) to check our spectrometer have to be shaken for a full minute to get proper results, so you can see that thorough mixing is important. Si is silicon and represents dirt. Dirt may come from your oil or may have been in dust in the bottle you put your oil in. These low readings suggest it was in the oil. But if you get an unexplained jump in silicon, perhaps your sampling technique contaminated the oil. In F-15's our crew chiefs have to clean off the tube they get their samples from or we could ground a jet for high aluminum readings when all they did was sample it carelessly. So keep things clean. A very small amount of aluminum oxide from the tube on a quick drain could get you needlessly concerned. I hope this helps. Richard Scott Starting RV-7 Flying 1941 Interstate Cadet -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Chris Good Sent: Friday, April 27, 2001 5:50 PM Subject: Re: RV-List: Oil Analysis > >Hey Guys, > >I need some help from those of you that have sent an oil sample out to be >analyzed. > I bought a couple of analysis packets at Sun-n-Fun this year, and when I got >back home, I changed my oil and sent a sample away per the instructions. This >is the first time I've ever had my oil analyzed. The engine is a Bart O-320 >with 140 hours on it. > >Yesterday, I got a letter from the company with a list of the trace elements >found in the oil. That's it!! So I'm thinking to myself, where is the >analysis >at? Am I supposed to look at these number of about 7 elements and deduce >something >from it? I could find nothing else on the sheet to tell me what the numbers >meant. > >Is this what I get for my $25 or is there supposed to be more to it? I would >have thought that I would at least get one sentence that says "everything >looks >normal" or "have a mechanic check out your engine" or something. > >Help please. > >Randy Pflanzer N417G >RV-6 Indianapolis Randy, I bought my sample kits at Oshkosh & then some more at Sun 'n Fun this year. They are from Aviation Laboratories in Louisiana - maybe they are the same as yours. Both reports include the sentence "Result ** normal sample, send next sample at the normal interval". Here are the detailed analysis results at 105 & 150 hrs on a new O-360-A1A: Tot Hrs Hrs Oil Hrs/qt Iron Cu Nickel Cr Silver Mag Al Lead Si Ti Tin Moly 105 43 3 14 25.8 34.4 3.3 5.6 0.0 6.0 7.8 4481 8.4 0.1 2.7 0.2 150 45 2.5 18 20.0 26.8 1.4 3.2 0.0 3.2 5.8 4198 6.1 0.0 1.2 0.1 I would be interested to know how these figures compare with others. All I can tell is that all the trace element quantities were lower in the second sample - I hope that's a good thing! Regards, Chris Good, http://www.rv.supermatrix.com West Bend, WI RV6A-QB N86CG, 185 hrs ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Start key vs. switch...
Guys, Along the lines of the recent thread on using ignition keys vs. toggle switch / starter button, I am wondering if anyone knows of a source for a keyed ignition switch that has only two positions (off / on) that could be used for the starter only. I don't want to use the standard ignition switch because I'm planning to use at least one Lightspeed system, so I want toggles for the mag and Lightspeed. But for the starter I'd like to have a key instead of just a button for safety reasons previously discussed. Obviously the key would have to be robust enough to handle the starter solenoid current (not sure how much that is?). Most ignition switches for cars and airplanes have multiple positions so if anyone knows where I could find something with only two positions please let me know. Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A fuselage, O-360-A4A, Sensenich 87" ________________________________________________________________________________
Date: Apr 27, 2001
Subject: Re: Strobes
Hi Charlie, I considered the SuperPak 906 as well when I was looking at power supplies, but it actually does NOT give you any advantage in a 3 strobe system. If you look at the specs for this power supply at http://www.strobe.com/pdfs/spak906-install.pdf it says that heads 1,3 and 5 flash together, heads 2, 4 and 6 flash together, and heads 1,3,5 alternate with 2,4,6. So if you want to only drive 3 strobes you have more choices in terms of which outlets you populate, but the resulting power output will be identical to the XPAK 904 that I got. The total power output is the same (90 W), so the first half of the cycle will put out 45 W and the second half will put out 45 W. Two of the strobes will still have to be flashing simultaneously and so each will get 22.5 W. The third strobe will get the full 45 W. So the SuperPak 906 will cost a bit more and probably weigh a bit more but unless you are planning to put five or six strobes on your airplane, the XPak is a better deal. On the other hand......hmmm, let's see.....with six strobes, you could make a couple of them blue and red, have some really cool flash patterns, and start playing "Air Police"... : ) --Mark Navratil Cedar Rapids, Iowa RV-8A fuselage, O-360-A4A, Sensenich 87" ------------------------------- From: Charlie Kuss <chaskuss(at)bellsouth.net> Subject: Re: RV-List: Re: strobes Mark, I didn't read all of your posts carefully enough. After re reading them, I see your mention of a link off of Nova's site. You can reach Strobes N' More directly at: http://strobeguy.safeshopper.com/index.htm?116 For a few dollars more than the 4 head X-Pac 904 ($159.95) you mention (see web page below) http://strobeguy.safeshopper.com/11/cat11.htm?116 you can purchase the Super Pac 906 ($168.95) 6 head power supply. (see web page below) http://strobeguy.safeshopper.com/10/cat10.htm?116 Since you can then power 3 heads off of this 6 head supply, all 3 strobes can receive equal power from the supply. (3 X 30 watts [25 joules] per sequence) You won't have to diminish the power going to the 2 wingtip strobes as the X-Pac 904 does (22.5 + 22.5 + 45 watts [18.75 + 18.75 + 37.5 joules per sequence) This would seem to be a better unit for those folks who need a 3 strobe system. Charlie Kuss ________________________________________________________________________________
Subject: Re: RV6-List: scoring the angle aluminum - HS-610
Date: Apr 28, 2001
A .015" deep cut in .063" stock reduces the area in the affected section 25%. This will increase the stresses by the same factor (not including stress concentration effects). Since this part of the stabilizer is highly loaded (root end) I would replace the part. Anyway by the time you blended out the cut by a 10/1 ratio you could have made a new part. Get used to it, you'll be doing a lot more replacing by the time your done. Good luck Doug Meloche rv6 ordering finish kit > --> RV6-List message posted by: windsaloft(at)rmisp.com (Terri Watson) > > When cutting out the AA6 3/4 x 3/4 angle iron to fabricate the HS-610 for > the front spar, I let the saw blade drift a bit and got a bit of a score > across the flange tongue of the aluminum. It is 1-5/16" from the tip, and > appears to be 1/64" deep, going all the way across. Two rivets would be > outside this when fastened to the forward spar. > > There are a couple of other nicks and scores, mostly scotchbrite-able, from > clamps, etc. > > I am learning lots on this educational project, and am pretty certain that I > should get another aluminum angle and start again as the score above seems > like it would focus stress and be the ideal fracture spot for the spar. > But, I wanted to ask -- how deep is too deep for something like that? If > you can't smooth it out with scotch brite, is it so deep that it will > concentrate force and fracture? Is there some rule of thumb of score depth > vs. bar thickness? > > While I am striving for perfection, I am also trying to learn when to sweat > it and when to not! > > Thanks, feel free to reply on or off line. > > Terri Watson > Lander, WY > RV-6 to 7 fwd spar, HS > > > > > > ________________________________________________________________________________
Date: Apr 28, 2001
As previous posters said, the part is critical enough that I would replace it. Also, order the angle stock from wicks or ACS and get some extra to have around the shop. Believe me you will use it eventually not just for any mistakes you might make, but you'll also find that as you near completion you are having to fabricate a lot of things (i.e. radio stacks, supports for firewall mounted items, etc.) Replace it and move on with confidence that it was done right. Eric Newton - Long Beach, Mississippi RV-6A N57ME (Reserved) (wiring) http://www.ericsrv6a.com ________________________________________________________________________________
Date: Apr 28, 2001
Mark, Digi-Key and Allied electronics have these switches. You will have a hard time finding one to handle the starter solenoid current however. While you in the same catalogs, by a small normally open 12V relay (about $4) and have the switch operate the relay, the relay contacts operating the starter solenoid. This set up opens up a whole range of switch options. Carl Froehlich RV-8A (systems install) Vienna, VA -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of czechsix(at)juno.com Sent: Friday, April 27, 2001 11:18 PM Subject: RV-List: Start key vs. switch... Guys, Along the lines of the recent thread on using ignition keys vs. toggle switch / starter button, I am wondering if anyone knows of a source for a keyed ignition switch that has only two positions (off / on) that could be used for the starter only. I don't want to use the standard ignition switch because I'm planning to use at least one Lightspeed system, so I want toggles for the mag and Lightspeed. But for the starter I'd like to have a key instead of just a button for safety reasons previously discussed. Obviously the key would have to be robust enough to handle the starter solenoid current (not sure how much that is?). Most ignition switches for cars and airplanes have multiple positions so if anyone knows where I could find something with only two positions please let me know. Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A fuselage, O-360-A4A, Sensenich 87" ________________________________________________________________________________
Subject: Ring gear
Date: Apr 28, 2001
Does anybody have any suggestion where we could find a ring gear for the O-320 H2AD. Thanks Michel 1983 RV3 C-GGRV 1,014 hrs and still hummin' ________________________________________________________________________________
Date: Apr 28, 2001
Subject: Re: Start key vs. switch...
You might want to look at repair parts for electric emergency generators, specially the bigger rigs, 10kw, 15 kw etc. They do exactly that AND are designed to be used with hefty starter solenoids. I was going to do similar thing.....off, on, start....that would be a 3 pos. switch. Gert czechsix(at)juno.com wrote: > > > Guys, > > Along the lines of the recent thread on using ignition keys vs. toggle > switch / starter button, I am wondering if anyone knows of a source for a > keyed ignition switch that has only two positions (off / on) that could > be used for the starter only. I don't want to use the standard ignition > switch because I'm planning to use at least one Lightspeed system, so I > want toggles for the mag and Lightspeed. But for the starter I'd like to > have a key instead of just a button for safety reasons previously > discussed. > > Obviously the key would have to be robust enough to handle the starter > solenoid current (not sure how much that is?). Most ignition switches > for cars and airplanes have multiple positions so if anyone knows where I > could find something with only two positions please let me know. > > Thanks, > > --Mark Navratil > Cedar Rapids, Iowa > RV-8A fuselage, O-360-A4A, Sensenich 87" > -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Subject: Re: Ring gear
Date: Apr 28, 2001
> > Does anybody have any suggestion where we could find a ring gear for the > O-320 H2AD. > Try: BOBBY'S PLANES AND PARTS (BOBBY OSBURN) 940-682-4220 USED AIRCRAFT ENGINES AND PARTS He is a good source for O-320 H2AD engines, I got mine from him. Bob Hall, RV-6 Colorado Springs ________________________________________________________________________________
Date: Apr 28, 2001
Subject: Wanted: RV Construction videos
Wanted used George Orndorff RV Construction Videos: Aircraft Sheet Metal Tools Pre-Punched Empennage E-Mail me directly at bhester(at)apex.net -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/ And see my Rans S12xl experimental aircraft Updated 9/22/00 - New Look! ________________________________________________________________________________
Date: Apr 28, 2001
In a message dated 4/27/01 8:20:23 PM Pacific Daylight Time, czechsix(at)juno.com writes: << I am wondering if anyone knows of a source for a keyed ignition switch that has only two positions (off / on) that could be used for the starter only >> Mark: I got one at a local lock and key shop and had the canopy lock rekeyed to use the same key. I haven't made a final decision to use the key switch yet but that that was my idea at the time. I also found similar keyed two position switches at a local electronics store and have been told that boating equipment stores sometimes carry them. Let me know if you can't locate one in your area. Harry Crosby Pleasanton, California RV-6, finish kit stuff ________________________________________________________________________________
Date: Apr 28, 2001
http://www.niagaraairparts.com/ may have them. > >> >> Does anybody have any suggestion where we could find a ring gear for the >> O-320 H2AD. >> > >Try: > >BOBBY'S PLANES AND PARTS (BOBBY OSBURN) 940-682-4220 USED AIRCRAFT ENGINES >AND PARTS > >He is a good source for O-320 H2AD engines, I got mine from him. > >Bob Hall, RV-6 >Colorado Springs > > ________________________________________________________________________________
Date: Apr 28, 2001
Subject: rocket kit for sale
Listers, I have a rocket qb kit for sale. If you are interested, please respond off-line. thanks! Scott ________________________________________________________________________________
Date: Apr 28, 2001
Who makes a set for the RV's? Steve Soule Huntington, VT -----Original Message----- Anyway, I'm not sure if I will install them on my -4 yet, but I am very tempted. ________________________________________________________________________________
Date: Apr 28, 2001
Then again, you could use Leccy' Bob's book setup and use the switch for only on-off and use one of the magneto switches as the starter switch too. Gert HCRV6(at)aol.com wrote: > > > In a message dated 4/27/01 8:20:23 PM Pacific Daylight Time, > czechsix(at)juno.com writes: > > << I am wondering if anyone knows of a source for a keyed ignition switch > that has only two positions (off / on) that could be used for the starter > only >> > > Mark: I got one at a local lock and key shop and had the canopy lock > rekeyed to > use the same key. I haven't made a final decision to use the key switch yet > but that that was my idea at the time. I also found similar keyed two > position switches at a local electronics store and have been told that > boating equipment stores sometimes carry them. Let me know if you can't > locate one in your area. > > Harry Crosby > Pleasanton, California > RV-6, finish kit stuff > -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Date: Apr 28, 2001
Subject: #19 countersink question
I have just finished installing platenuts for the tank on the spar (both rows). The plans call for the most aft row (screw holes) to be either dimpled OR countersunk. I bought from Cleveland a #19 100 degree contersink bit. I thought I was going to countersink but ended up dimpling (screw holes). The reason I changed was that the contersink bit made a very very large hole. I does not seem to give that countersink angle that the smaller bits provide. IS THIS NORMAL? Yes it holds the #8 screw head, and yes I realize no bigee being that the nutplate is going to hold the screw. But before I conter that last row on the tank skin, I want to make sure I am not missing something. Thanks guys, Bob in Arkansas ________________________________________________________________________________
Date: Apr 28, 2001
Subject: close qtr. dimple die
For those of you that used the Avery close qtr. dimple die to dimple wing spars, I have on more curious question. After doing that, will not the platenuts lose some of their self-locking ability? I did this with the inner most 6 screw holes on both sides. Anything one would do other than keep an eye on this area when flying? Bob-last question for a while :) ________________________________________________________________________________
Date: Apr 28, 2001
try Kenny Faeth 1-916-368-1832...he's great! Mail wrote: > > Does anybody have any suggestion where we could find a ring gear for the > O-320 H2AD. > > Thanks > Michel > 1983 RV3 > C-GGRV 1,014 hrs and still hummin' > ________________________________________________________________________________
Date: Apr 28, 2001
I'm not sure I understand the question right but think you're concerned that the platenuts will loose locking ability after you dimple the platenuts itself with the close quarter dies. It will be fine. If you're not convinced you should put a phillips bit on your torque wrench (with an adapter) and see how much torque is required to screw in the screw before and after dimpling the platenut while you hold the platenut in a vise. I haven't tried this myself but doubt you'll find a difference. Are RV-8 Wings Loretto, ON -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bobpaulo(at)aol.com Sent: April 28, 2001 7:08 PM Subject: RV-List: close qtr. dimple die For those of you that used the Avery close qtr. dimple die to dimple wing spars, I have on more curious question. After doing that, will not the platenuts lose some of their self-locking ability? I did this with the inner most 6 screw holes on both sides. Anything one would do other than keep an eye on this area when flying? Bob-last question for a while :) ________________________________________________________________________________
Date: Apr 28, 2001
AIRTECK in orlando florida makes ring gears for the 122 and 149 tooth paterns for many lycoming engines, if you need their number let me know. scott tampa rv6a finishing ________________________________________________________________________________
Date: Apr 28, 2001
Subject: Re: close qtr. dimple die
Arie, yes I have done so. That is why I am concerned. The platenuts do not seem to require as MUCH torque the second time after a screw is used. Thanks, Bob ________________________________________________________________________________
Date: Apr 28, 2001
"THE AVIATION CONSUMER", December, 2000 has a review of oil analysis labs. "LIGHT PLANE MAINTENANCE", October, 2000 has a definitive guide to what the metal particles in your oil analysis/oil filter means as far as various types of possible engine damage/wear. Boyd Braem N600SS why do planes need to be constantly rebuilt? > > > In a message dated Fri, 27 Apr 2001 8:58:37 AM Eastern Daylight Time, rpflanze(at)iquest.net writes: > > > Hey Guys, > > I need some help from those of you that have sent an oil sample out to be analyzed. > I bought a couple of analysis packets at Sun-n-Fun this year, and when I got > back home, I changed my oil and sent a sample away per the instructions. This > is the first time I've ever had my oil analyzed. The engine is a Bart O-320 > with 140 hours on it. > > Yesterday, I got a letter from the company with a list of the trace elements > found in the oil. That's it!! So I'm thinking to myself, where is the analysis > at? Am I supposed to look at these number of about 7 elements and deduce something > from it? I could find nothing else on the sheet to tell me what the numbers > meant. > > Is this what I get for my $25 or is there supposed to be more to it? I would > have thought that I would at least get one sentence that says "everything looks > normal" or "have a mechanic check out your engine" or something.>> > > If you went to Howard Fenton at Engine Oil Analysis in Tulsa, OK you would get commentary in addition to analysis. Howard does oil anaysis of aircraft engines only and has many years of experience in this field. Contact info is (where else?) in the Yeller Pages. > O ________________________________________________________________________________
Date: Apr 28, 2001
> > For those of you that used the Avery close qtr. dimple die to dimple wing > spars, I have on more curious question. After doing that, will not the > platenuts lose some of their self-locking ability? > Bob-last question for a while :) >snip Bob, I just dedicated one platenut to the dimpling task and in fact ran a tap through it to make it easier to use. Stan Blanton RV-6 stanb(at)door.net ________________________________________________________________________________
Date: Apr 28, 2001
Are you using the AN509-8R8 with K1100-08 platenuts? Mine are also a bit easy (they're not dimpled on the RV-8) but I will definately not have to worry about them while flying. Back to the hockey game... Are RV-8 Wings -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bobpaulo(at)aol.com Sent: April 28, 2001 8:02 PM Subject: Re: RV-List: close qtr. dimple die Arie, yes I have done so. That is why I am concerned. The platenuts do not seem to require as MUCH torque the second time after a screw is used. Thanks, Bob ________________________________________________________________________________
Date: Apr 28, 2001
yes same nuts/screw-go pittsburgh! ________________________________________________________________________________
Subject: Hello, I'm a bonehead..nice to meet you
Date: Apr 28, 2001
There is only one group who would completely appreciate the short story I am about to confess. I'm mounting the aileron on my wing for the first time. I'm so excited and happy...bouncing around the garage and singing to the radio. So, I look at the plan and it says the end of the 406 is 1/4 inch from the end of the last rib. No sweat....I just need the proper spacer. So, I measure the thickness of the 414 (1/8") and the 406 (1/16") and my superior math skills come into play...where I figure out I need a 1/16" spacer in between the 406 and the 414. Hey, that's not going to be fun....but I can do it. So, I proceed to spend 15 minutes cutting 1/16" off of a spacer rod and cleaning up the cut with my emery wheel. It is then...after I've burned my fingers twice holding that rod that I figure out what I've just made. I just made....an AN washer. Yup, exactly the same size as the 50 washers I have right in front of me. Damn, I'm good. Toss the newly built washer in the garbage, put an AN washer where it was supposed to be in the first place and laugh at myself for my genius. Now you can all laugh at me too. Hey...you've done worse so just take it easy. :-) Ok, so the aileron is on the wing. I'm happy and it's time to break out that Jamaican rum I've been saving for a good enough reason. I'll celebrate being a bonehead.....a bonehead with a control surface hanging off a wing...all of which built by my own hand. Life is good...and so, by the way, is this rum. :-) 7:30am eastern tomorrow...Formula one. What was it that everyone was saying about there only being two real contenders? Life is really good...go Ralfy go. Bill ________________________________________________________________________________
Date: Apr 28, 2001
Subject: Re: Hello, I'm a bonehead..nice to meet you
bonehead here many times-nice to meet you too. ________________________________________________________________________________
Date: Apr 28, 2001
Subject: RE: Primers (oh no!)
I'm replying on list even though this has been discussed a lot, since I've tried multiple systems and can compare them to each other- this isn't to say that any of these are the best, just that I have a basis for comparison between them. Some other primer might be better but these are all I've used, and like others have said you probably don't need to prime most of the parts anyway. 1) I've used the Tempo zinc chromate cans on alodined parts. Hated it. Took forever to dry and wasn't very tough. Hexavalent chromium is also one of the most carcinogen/mutagenic substances you can buy. I wouldn't use this stuff again even if someone paid me $100 a can to spray it. 2) I've also used the Sherwin-Williams GBP 988 self-etching primer in the spray cans. No need to etch or alodine, just clean the parts good and spray it. This stuff is tougher than the Tempo ZC, dries quicker, and doesn't need alodine first. Very convenient. 3) I've also used Lesonal Self-Etching Primer 072244, a two-part self-etching epoxy primer made by AKZO-NOBEL. Tougher than the above, and you don't need to alodine first. Expensive at $135 per 2-gallon kit. 4) And lastly the AKZO primer sold in the Aircraft Spruce catalog (they only carry one). A two-part epoxy primer, but you need to etch and alodine first. Incredible stuff, dries almost immediately and is bulletproof tough. Supposedly Boeing uses it inside its planes. Also expensive, I think $80 or so for a 2-gallon kit. Like I said, this should be taken with a grain of salt since I haven't used any other primers, but if I were to build another RV (a 4-seater, maybe?), I'd use #4 on every small part that I could alodine without too much trouble, say everything up to the size of a wing rib. I'd use #3 on the skins which due to their size are difficult to alodine. And I'd have a couple cans of #2 handy for when I have a single small part I need to prime but don't want to mix up a whole batch. Another piece of advice, I highly recommend, when getting a kit, deburring all edges and priming parts right out of the box. Just get it all over with all at once. Probably saves a lot of time. Primer #4 above is also way harder to scratch than the aluminum itself so the parts won't get scratched. Sorry if this is beating a dead horse. I'm not trying to advocate any of these, I just wanted to offer them a comparison. Matthew -8A fuse (just out of jig!) -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Slgmjg1(at)cs.com Sent: Thursday, April 26, 2001 1:03 PM Subject: RV-List: (no subject) I am getting ready to build an RV-7. I was planning on using zinc chromate for corrosion proofing. Are there any opinions on whether this is the right thing to use or is there something better? Thanks, Mark ________________________________________________________________________________
Date: Apr 28, 2001
Subject: Re: RE: Primers (oh no!)
Mathew, you make many good points. I am not trying to get another priming thread started, but you left out the one that I finally ended up with-Variprime. No etch, other than cleaning with some Coleman Lant Fluid. It dries very quickly and sticks very very well. How it will do over the years? We are going to have to check back in a 100 yrs. or so. :) Bob ________________________________________________________________________________
Date: Apr 28, 2001
I just read my post again and in reading it. it sounds like I'm advocating using these primers- I'm not. I posted those opinions in case anyone ever does an archive search they'll get a pseudo-data point. I guess I should have made these generic points instead of specific paint comments- 1) some self-etching rattle can primer is nice for the odd part or two 2) alodining skins is a pain (yes, I alodined all my wing skins) 2.5) alodining smaller parts is easy and quick 3) Chromate is hideously toxic, I'm surprised its still legal, avoid avoid avoid 4) Two-part epoxies are tougher/harder than single-part paints. 5) All of these paints are toxic enough to destroy your liver if you don't use proper protection- e.g full mask, gloves, long sleeves. Safer to use them outside, too... 6) I hate painting so much I'm going to try for the polished finish... Sorry, Matthew -8A fuse -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Matthew Gelber Sent: Saturday, April 28, 2001 7:30 PM Subject: RV-List: RE: Primers (oh no!) Blah blah blah blah ________________________________________________________________________________
Date: Apr 28, 2001
Good points! ________________________________________________________________________________
Date: Apr 29, 2001
> 3) Chromate is hideously toxic, I'm surprised its still legal, avoid avoid > avoid Just another data point.....I love the stuff. I find it's fairly tough if applied correctly and I have a piece of steel sitting out in the weather 75 yards from the salt water in Ormond Beach that I put there over a year ago....still no rust. I just took that piece of steel off my shop floor, sprayed the Tempo Chromate on it without prepping it and asked my friend to leave it sitting out in his back yard (you can hit the sand with a rock from his house).....just to see how well it took it. Still looks like the day I sprayed it. The two part epoxy is tougher (I did some parts with that too, before I decided which to use)...but the tempo isn't exactly fragile...and I can always just spray it again just before I assemble. The exterior will be done in epoxy primer and topcoated (base-clear)...but the interior is zinc chromate....cut my assembly time in half too. The stuff dries FAST....here in Orlando. Much faster than epoxy. Like I said...just a datapoint...worth what you paid for it Bill -4 wings master washer fabricator ________________________________________________________________________________
Date: Apr 29, 2001
Subject: Re: rv-8 video
Hey, what format is that? I downloaded week 3 (I have 1 & 2 on tape) as a .asf. Win doze media player wouldn't open it. When I double clicked in my browser, it just opened a window to show me the binary junk. Not much help. Bernie C. Steven DiNieri wrote: > > > To view the rv-8 video try nextelwny.com , I'll be there for a few days. > > Steven DiNieri > Niagara Falls, New York > RV-6A, P28A-160 > -- Go Pens!! Go Pens!!Go Pens!!Go Pens!! ________________________________________________________________________________
Date: Apr 29, 2001
Subject: nutplates lost their locking ability
For those of you that used the Avery close qtr. dimple die to dimple wing spars, I have a curious question. After doing that, the platenuts seem to have lost some of their self-locking ability. I did this with the inner most 6 screw holes on both sides. You have to screw in the female die with a screw into the platenut-all provided from Avery which make a nice dimple. Anything one would do other than keep an eye on this area when flying? Pehaps something around the screw like teflon tape, used on refigeration fittings? If I squeeze the end of the platenut with a pair of pliers the squeeze will not be hoizontal but vertical, which is the opposite of the way the platenuts come. I cant get pliers up there due to spar flange strips. Suggestion?? Bob-last question for a while :) ________________________________________________________________________________
Date: Apr 29, 2001
Subject: Dear eBusiness Professional
Special Offer for eBusiness Professional... Are you ready to drive Targeted traffic to your site, open a floodgate of targeted visitors ready, willing and able to buy from you and change your life forever by bringing an avalanche of eager targeted buyers to your site? We can list your website with all 22 major Search Engines and Finally you can start making serious money online by consistently driving large numbers of targeted visitors to your website from search engines and directories like Yahoo!, AltaVista, AOL, HotBot, Excite, Lycos and more! After we rank your website on the all 22 major search engines, you will start getting a Never-Ending Stampede of Traffic to Your Website! We can list your website with all 22 major Search Engines and For more information please click here: mailto:marketinginfo(at)isfree.com?subject=More_Information Or You may call us at: 718-583-3684 Please call only during: Monday - Friday From 11:00 AM To 7:00 PM Eastern Time No voice mail service available. To be removed from this list, please: mailto:accountsmer01(at)isfree.com?subject=Remove subject line and you will be removed from our list. ________________________________________________________________________________
Subject: safety wiring cowl pins
Date: Apr 29, 2001
Hi, I have to figure out a way to safety the 1/8" Alum cowl pins that are used on the bottom and back of the lower RV-6 cowl. I have to bend some loops into them, but I was wondering if the 1/8" Alum pin will hold up well to that type of bending or if I should get some 1/8 304" stainless rod to use in its place. Suggestions? Thanks! -Glenn Gordon ________________________________________________________________________________
Date: Apr 29, 2001
Subject: Re: safety wiring cowl pins
3/32 coil pins(steel) might serve you better than 1/8 aluminum. Bob Murphy Poplar Grove ILL. (C77) ________________________________________________________________________________
Date: Apr 29, 2001
Subject: Primers(oh no!)
Is the Tempo Zinc Chromate REALLY that toxic if used properly? I've talked to many old timers that used to use it regularly with no mask, no gloves...and despite all, are still with use at a ripe old age. Yet, I I've also heard horror stories about self etching and two part primers actually KILLING people when used improperly(no mask, etc.) Bottom line, aren't hey all about equally toxic...but we reduce most risks with safety precautions...any thoughts? Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
"Rv-List(at)Matronics.Com"
Subject: Switches?
Date: Apr 29, 2001
Ok, I'm a little confused about switches... SPDT, DPDT, 3PDT, C3PO, AHHHH!!!!! Where is a good place to get switches? For a simple OFF/ON of say your NAV lights, is a SPST ok? And what about the switches Nuckolls uses for mags, one is an OFF/ON and one is an OFF/ON/MOM-ON, where do I get these? I am also looking for some mini-bat switches for things like map lights... Thanks... Bill VonDane, Colorado Springs, CO RV-8A, N8VD, Fuselage - Finish kit on the way... http://vondane.com/rv8a/ ________________________________________________________________________________
Date: Apr 29, 2001
Subject: Re: RV-List Digest: 42 Msgs - 04/28/01
As for my $.02, I use the Zinc Oxide from Tempo. Much less toxic, and apparently works the same. I scrub each part using a scotchbrite pad and Coleman fluid to degrease and provide a rough surface. Advantage: Very convenient. Can buy it from Aircraft Spruce and Specialty, you can prime parts right then, not mix up then clean up the spray gun, etc. I like the ability to dab a quick prime on countersunk holes etc. before riveting. Disadvantage: Not very tough, although it gets very much tougher after a few days. But you can always respray immediately before installing. Biggest disadvantage, extensively discussed in this list, is CLOGGING. But I have found the fix! a) always drop your nozzle into a jar of MEK until you need it again, and b) if the can clogs internally, remove the nozzle, turn the can upside down and push a sharp object like a nail into the nozzle end. This will blast out the obstructing material, usually non-mixed paint solids, (gets all over your hand, so wear a glove) and clear the clog. Until I discovered this, I was cursing and throwing away can after can. Now I can use them all up. Gordon Robertson RV8 fuse. 1) I've used the Tempo zinc chromate cans on alodined parts. Hated it. Took forever to dry and wasn't very tough. Hexavalent chromium is also one of the most carcinogen/mutagenic substances you can buy. I wouldn't use this stuff again even if someone paid me $100 a can to spray it. ________________________________________________________________________________
Date: Apr 29, 2001
----- Original Message ----- From: "Glenn & Judi" <foxinsocks(at)mediaone.net> Sent: Sunday, April 29, 2001 7:39 AM Subject: RV-List: safety wiring cowl pins I was wondering if the 1/8" Alum pin will hold up > well to that type of bending or if I should get some 1/8 304" stainless > rod to use in its place. Suggestions? > > Thanks! > -Glenn Gordon > > Glen, those Aluminun pins that come inside the 1/8 piano hinge is not to be used. It is to be replaced with a 1/8 stainless pin. except along the top of the cowl, where it is replaced with 3/32 stell pin. Terry B. ________________________________________________________________________________
Date: Apr 29, 2001
Subject: Re: Switches?
bill, << Ok, I'm a little confused about switches... SPDT, DPDT, 3PDT, C3PO >> SPDT Single Pole Double Throw DPDT Double Pole Double Throw 3PDT 3 Poles Double Throw C3PO cyborg 3rd genertion personal orbitron radio shack has some lightweight switches that have the schematic of thier functions on back of the package, a good place to learn how switches work. keep in mind how many amps these switches must carry. amps is what burns the switch contact points. hope this helps scott tampa rv6a finishing, down with a bad back , in bed for 7 days now. ouchhhh ________________________________________________________________________________
Subject: Switches?
Date: Apr 29, 2001
Look at CK switches available via Digi-Key or Allied electronics. Both have web sites where you can order a free catalog. Carl Froehlich RV-8A (systems install) Vienna, VA -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Bill VonDane Sent: Sunday, April 29, 2001 10:57 AM Subject: RV-List: Switches? Ok, I'm a little confused about switches... SPDT, DPDT, 3PDT, C3PO, AHHHH!!!!! Where is a good place to get switches? For a simple OFF/ON of say your NAV lights, is a SPST ok? And what about the switches Nuckolls uses for mags, one is an OFF/ON and one is an OFF/ON/MOM-ON, where do I get these? I am also looking for some mini-bat switches for things like map lights... Thanks... Bill VonDane, Colorado Springs, CO RV-8A, N8VD, Fuselage - Finish kit on the way... http://vondane.com/rv8a/ ________________________________________________________________________________
Date: Apr 29, 2001
Subject: Meangreen RV-4 Flys at last...
That's right Meangreen is no longer a hangar virgin.After 9 years of building at 7:31 am on 4-28-01 Meangreen left the ground on its maiden flight. I wish I could bottle and sell the high I was on because I would be richer than Bill Gates. Here is some of the recorded data: Stall 55mph full flaps 58mph Clean Ground speed 180mph @ 156 Indicated 200mph @ 183 " " " 220mph @ 185 " " " Oil Temp 180 degrees Oil Pressure 75psi Fuel Pressure 25psi Many Thanks to John Harmon for all his help. ________________________________________________________________________________
Date: Apr 29, 2001
Subject: Re: Primers(oh no!)
Be smart/safe-ALWAYS USE A RESPIRATOR!!!! ________________________________________________________________________________
Subject: Tempo rattle cans
Date: Apr 29, 2001
I have used about 7 cans now and I have yet to not get completely all the paint out without clogging. One thing I always do though is tilt the can upside down and spray until clear (couple seconds) then wipe the tip with a rag. Works for me.....your mileage may vary. Bill ----- Original Message ----- From: "Gordon Robertson" <gordon(at)safemail.com> Sent: Sunday, April 29, 2001 11:06 AM Subject: RV-List: Re: RV-List Digest: 42 Msgs - 04/28/01 > > As for my $.02, I use the Zinc Oxide from Tempo. Much less toxic, and apparently works the same. I scrub each part using a scotchbrite pad and Coleman fluid to degrease and provide a rough surface. > > Advantage: Very convenient. Can buy it from Aircraft Spruce and Specialty, you can prime parts right then, not mix up then clean up the spray gun, etc. I like the ability to dab a quick prime on countersunk holes etc. before riveting. > > Disadvantage: Not very tough, although it gets very much tougher after a few days. But you can always respray immediately before installing. Biggest disadvantage, extensively discussed in this list, is CLOGGING. But I have found the fix! a) always drop your > nozzle into a jar of MEK until you need it again, and b) if the can clogs internally, remove the nozzle, turn the can upside down and push a sharp object like a nail into the nozzle end. This will blast out the obstructing material, usually non-mixed paint solids, > (gets all over your hand, so wear a glove) and clear the clog. Until I discovered this, I was cursing and throwing away can after can. Now I can use them all up. > > Gordon Robertson > RV8 fuse. > > > 1) I've used the Tempo zinc chromate cans on alodined parts. Hated it. > Took forever to dry and wasn't very tough. Hexavalent chromium is also one > of the most carcinogen/mutagenic substances you can buy. I wouldn't use > this stuff again even if someone paid me $100 a can to spray it. > > ________________________________________________________________________________
Date: Apr 29, 2001
In a message dated 4/28/01 4:10:39 PM Pacific Daylight Time, Bobpaulo(at)aol.com writes: << For those of you that used the Avery close qtr. dimple die to dimple wing spars, I have on more curious question. After doing that, will not the platenuts lose some of their self-locking ability? >> I'm not sure I understand your question Bob, but I used new plate nuts after making the dimples with the close quarter tool and it's platenut. Harry Crosby Pleasanton, California RV-6, finish kit stuff ________________________________________________________________________________
Date: Apr 29, 2001
From: Charlie and Tupper England <cengland(at)netdoor.com>
Glenn & Judi wrote: > > > Hi, > I have to figure out a way to safety the 1/8" Alum cowl pins that are > used on the bottom and back of the lower RV-6 cowl. I have to bend some > loops into them, but I was wondering if the 1/8" Alum pin will hold up > well to that type of bending or if I should get some 1/8 304" stainless > rod to use in its place. Suggestions? > > Thanks! > -Glenn Gordon > You can use stainless welding rod for the pins. To safety wire them, you can flatten the end & drill for the safety wire. That's how the top cowl pins on my -4 were done. The loops would probably be more useful on the lower cowl pins. Charlie ________________________________________________________________________________
Date: Apr 29, 2001
I don't remember for sure, but I think my first legal car, a $60 '51 chevy sedan had an ignition switch with which you either locked the ignition so it needed the key, or unlocked it so that just turning the little projection that held the key engaged the starter. That might work to lock or leave unlocked the electrical connection to toggle switches for the mags and a toggle or push button for the starter, or you could use it as the starter switch, with or without the key. If I am remembering correctly, all GM vehicles of about that vintage probably worked the same way. Terry > czechsix(at)juno.com wrote: > > > > > Guys, > > > > Along the lines of the recent thread on using ignition keys vs. toggle > > switch / starter button, I am wondering if anyone knows of a source for a > > keyed ignition switch that has only two positions (off / on) that could > > be used for the starter only. I don't want to use the standard ignition > > switch because I'm planning to use at least one Lightspeed system, so I > > want toggles for the mag and Lightspeed. But for the starter I'd like to > > have a key instead of just a button for safety reasons previously > > discussed. > > > > Obviously the key would have to be robust enough to handle the starter > > solenoid current (not sure how much that is?). Most ignition switches > > for cars and airplanes have multiple positions so if anyone knows where I > > could find something with only two positions please let me know. > > ________________________________________________________________________________
Date: Apr 29, 2001
Subject: Re: "Flexible Fiberglass" ??
Sam Cherroff wrote: > > > Hey listers, > Does anyone know of a fabric/polymer composite solution that can > be hand laid, but after curing becomes more like hard rubber than > stiff fiberglass? I need to make a fairing in a location that will have to > endure some impact without shattering. > > Would laminations of glass cloth with RTV silicone as the liquid > component work? Is there a two-part version of RTV, instead of the > air-dry type? Different hardnesses? What does the stuff cost? How > can it be finshed/painted? > > Thanks, > > --Sam > I've read of guys making induction system ducts with fiberglas & RTV & wondered about using it for gear leg fairings & such. How about trying some of the new paintable silicone caulk & let us know how it works? :-) Charlie ________________________________________________________________________________
Date: Apr 29, 2001
OK, at the risk of showing that I know nothing, I think the idea behind oil sampling is to get a history and track the elements over time. When something starts to let go it will show up as a sudden increase in the element. There are many parts that can be identified by the content of the metal the engine is making. At least that is my understanding after hanging around CAT dealers. Maybe your local CAT dealer can provide this service for less cost. Of course the commentary would not be there since they are "geared up" for Diesel engines. Marty in Brentwood, TN ----- Original Message ----- From: "Boyd C. Braem" <bcbraem(at)home.com> Sent: Saturday, April 28, 2001 6:54 PM Subject: Re: RV-List: Oil Analysis > > > "THE AVIATION CONSUMER", December, 2000 has a review of oil analysis labs. > > "LIGHT PLANE MAINTENANCE", October, 2000 has a definitive guide to what > the metal particles in your oil analysis/oil filter means as far as > various types of possible engine damage/wear. > > Boyd Braem > N600SS > why do planes need to be constantly rebuilt? > > > > > > In a message dated Fri, 27 Apr 2001 8:58:37 AM Eastern Daylight Time, rpflanze(at)iquest.net writes: > > > > > > Hey Guys, > > > > I need some help from those of you that have sent an oil sample out to be analyzed. > > I bought a couple of analysis packets at Sun-n-Fun this year, and when I got > > back home, I changed my oil and sent a sample away per the instructions. This > > is the first time I've ever had my oil analyzed. The engine is a Bart O-320 > > with 140 hours on it. > > > > Yesterday, I got a letter from the company with a list of the trace elements > > found in the oil. That's it!! So I'm thinking to myself, where is the analysis > > at? Am I supposed to look at these number of about 7 elements and deduce something > > from it? I could find nothing else on the sheet to tell me what the numbers > > meant. > > > > Is this what I get for my $25 or is there supposed to be more to it? I would > > have thought that I would at least get one sentence that says "everything looks > > normal" or "have a mechanic check out your engine" or something.>> > > > > If you went to Howard Fenton at Engine Oil Analysis in Tulsa, OK you would get commentary in addition to analysis. Howard does oil anaysis of aircraft engines only and has many years of experience in this field. Contact info is (where else?) in the Yeller Pages. > > O > > ________________________________________________________________________________
Date: Apr 29, 2001
My experience with oil analysis in the '70s on a 235 Cherokee. We routinely sampled oil at each oil change and sent it to the analyst. It continued uneventfully for many oil changes. The analyst, whose name I have since lost, would comment on the source of each element detected such as bearings, rings, cylinder walls, connecting rods, etc. Then, one analysis came back with a significant increase in one combination of elements. Their comments were that we probably had a cylinder scored by a broken ring. Bore scope examination found the scored cylinder. The repair required replacement of piston and cylinder. My conclusion was then to continue the regular analysis and is now, when my 6A is finished and flying I will start with the first oil change and continue. A baseline is needed in order to detect changes. There will probably be an initial higher level of elements from a new or overhauled engine during the break-in period decreasing to some steady state. If you have and engine with no oil analysis history, a few analyses will establish a baseline. Large changes after from the baseline will result from increased wear or deteriorating parts. An analyst with experience in your type of engine should be able to suggest the reason(s) for increases in specific elements. That will help to diagnose or anticipate problems. RHDudley 6A fuselage Emrath wrote: > > > OK, at the risk of showing that I know nothing, I think the idea behind oil > sampling is to get a history and track the elements over time. When > something starts to let go it will show up as a sudden increase in the > element. There are many parts that can be identified by the content of the > metal the engine is making. At least that is my understanding after hanging > around CAT dealers. Maybe your local CAT dealer can provide this service for > less cost. Of course the commentary would not be there since they are > "geared up" for Diesel engines. > > Marty in Brentwood, TN > > ----- Original Message ----- > From: "Boyd C. Braem" <bcbraem(at)home.com> > To: > Sent: Saturday, April 28, 2001 6:54 PM > Subject: Re: RV-List: Oil Analysis > > > > > > > "THE AVIATION CONSUMER", December, 2000 has a review of oil analysis labs. > > > > "LIGHT PLANE MAINTENANCE", October, 2000 has a definitive guide to what > > the metal particles in your oil analysis/oil filter means as far as > > various types of possible engine damage/wear. > > > > Boyd Braem > > N600SS > > why do planes need to be constantly rebuilt? > > > > > > > > > In a message dated Fri, 27 Apr 2001 8:58:37 AM Eastern Daylight Time, > rpflanze(at)iquest.net writes: > > > > > > > > > Hey Guys, > > > > > > I need some help from those of you that have sent an oil sample out to > be analyzed. > > > I bought a couple of analysis packets at Sun-n-Fun this year, and when > I got > > > back home, I changed my oil and sent a sample away per the instructions. > This > > > is the first time I've ever had my oil analyzed. The engine is a Bart > O-320 > > > with 140 hours on it. > > > > > > Yesterday, I got a letter from the company with a list of the trace > elements > > > found in the oil. That's it!! So I'm thinking to myself, where is the > analysis > > > at? Am I supposed to look at these number of about 7 elements and > deduce something > > > from it? I could find nothing else on the sheet to tell me what the > numbers > > > meant. > > > > > > Is this what I get for my $25 or is there supposed to be more to it? I > would > > > have thought that I would at least get one sentence that says > "everything looks > > > normal" or "have a mechanic check out your engine" or something.>> > > > > > > If you went to Howard Fenton at Engine Oil Analysis in Tulsa, OK you > would get commentary in addition to analysis. Howard does oil anaysis of > aircraft engines only and has many years of experience in this field. > Contact info is (where else?) in the Yeller Pages. > > > O > > > > > ________________________________________________________________________________
Date: Apr 29, 2001
In a message dated 4/29/01 6:00:41 PM, cengland(at)netdoor.com writes: >> Hey listers, >> Does anyone know of a fabric/polymer composite solution that can >> be hand laid, but after curing becomes more like hard rubber than >> stiff fiberglass? I need to make a fairing in a location that will have >to >> endure some impact without shattering. >> >> Would laminations of glass cloth with RTV silicone as the liquid >> component work? Is there a two-part version of RTV, instead of the >> air-dry type? Different hardnesses? What does the stuff cost? How >> can it be finshed/painted? >> >> Thanks, >> >> --Sam >> > >I've read of guys making induction system ducts with >fiberglas & RTV & wondered about using it for gear leg >fairings & such. How about trying some of the new paintable >silicone caulk & let us know how it works? :-) > Have you thought about trying Pro- seal? Kevin ________________________________________________________________________________
Date: Apr 29, 2001
> > I've read of guys making induction system ducts with > fiberglas & RTV & wondered about using it for gear leg > fairings & such. How about trying some of the new paintable > silicone caulk & let us know how it works? :-) > > I sure wish there was something a little less nasty than MEK to use as a silicone thinner!!! About three years ago I was using a lot of that stuff (and probably not being as careful as I could have been) and managed to give myself a case of eczema on my hands that is only now going away. Always wear gloves when you are handling invasive solvents!!! ... and use milder ones if they are available. --Sam ________________________________________________________________________________
Date: Apr 30, 2001
There is a poyerster based glazing putty that is used for repairing rubber bumpers. It is called "Poly-flex". Let me know if you need more info. -Glenn Gordon ----- Original Message ----- From: <Im7shannon(at)aol.com> Sent: Sunday, April 29, 2001 10:51 PM Subject: Re: RV-List: "Flexible Fiberglass" ?? > > > In a message dated 4/29/01 6:00:41 PM, cengland(at)netdoor.com writes: > > >> Hey listers, > >> Does anyone know of a fabric/polymer composite solution that can > >> be hand laid, but after curing becomes more like hard rubber than > >> stiff fiberglass? I need to make a fairing in a location that will have > >to > >> endure some impact without shattering. > >> > >> Would laminations of glass cloth with RTV silicone as the liquid > >> component work? Is there a two-part version of RTV, instead of the > >> air-dry type? Different hardnesses? What does the stuff cost? How > >> can it be finshed/painted? > >> > >> Thanks, > >> > >> --Sam > >> > > > >I've read of guys making induction system ducts with > >fiberglas & RTV & wondered about using it for gear leg > >fairings & such. How about trying some of the new paintable > >silicone caulk & let us know how it works? :-) > > > Have you thought about trying Pro- seal? > Kevin > > ________________________________________________________________________________
Subject: Re: Meangreen RV-4 Flys at last...
Date: Apr 30, 2001
CONGRATULATIONS and WELL DONE !! Chuck & Dave Rowbotham RV-8A (Finishing F/G fairings) Niantic, CT (Westerly airport) >From: MeangreenRV4(at)aol.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Meangreen RV-4 Flys at last... >Date: Sun, 29 Apr 2001 13:28:35 EDT > > >That's right Meangreen is no longer a hangar virgin.After 9 years of >building >at 7:31 am on 4-28-01 Meangreen left the ground on its maiden flight. I >wish >I could bottle and sell the high I was on because I would be richer than >Bill >Gates. Here is some of the recorded data: > >Stall 55mph full flaps > 58mph Clean > >Ground speed 180mph @ 156 Indicated > 200mph @ 183 " " " > 220mph @ 185 " " " > >Oil Temp 180 degrees >Oil Pressure 75psi >Fuel Pressure 25psi > >Many Thanks to John Harmon for all his help. > > ________________________________________________________________________________
Date: Apr 30, 2001
Subject: Typical Manifold Pressures
--- "Jones, Bryan D." <bryan.jones@lyondell-citgo.com> wrote: > > Let me rephrase my question - what drop in manifold pressure can be > expected > through the Van's stock filter air box. I believe I may be having an > excessive drop and was wondering what was typical. For example, I've > seen > 29" before startup. Then at full throttle and little airspeed > (takeoff), > I'm seeing 25 or 26". This seems like a lot of loss. Anyone have > experience with a bypass around the filter? How about new and > improved > filter elements (bigger, better)? > > Bryan Jones -8 765BJ > Pearland, Texas > Brian: I think I made a post several years ago about one test I did at 10,000. I slowed to MCA just above stall. I went to full throttle and read manifold pressure. Maintaining level flight, I accelerated till speed stabilized. Manifold pressure was then recorded. I do not remember what the actual manifold pressure was (I think about 20" and then 20.5") but I do remember that I had one-half inch more manifold pressure at speed. This was at 10,000 feet MSL. Your request go me thinking about trying what you suggested. I flew chase for the first Flight of John Allen RV-6A N602JA on Sunday. I had planned on taking the readings during one of the take-offs but kept forgetting. When I returned home to Cable (CCB) I conducted your test. Here is the data that my observer on board recorded: 29 April 2001 1600 local time (2300 Z) 29.97 25 C 1,440 field elevation Taxi back for take-off. Idle 1040 RPM 10" MP Pull on to runway, advance throttle to full open. 27.3" MP Lift off 27.7" MP End of runway climbing at 80 KIAS 27.9" MP Landed put the airplane away. Got ready to leave and saw the data. Missing data point of MP with engine off. 1730 Local (0030 Z) Recored MP with engine shut off. 28.4" MP Hope this helps with the info you are looking for. I read the data that there is very little loss through the filter. The divergent duct air filter box converts ram air to an increase in manifold pressure over static. There is more loss in the filter at static than I thought there was. One test on one airplane is not enough data to draw a statical analysis. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 788+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
From: "Jones, Bryan D." <bryan.jones@lyondell-citgo.com>
Subject: Fuel Remaining and engine out glides
Date: Apr 30, 2001
Item 1 Returning from Sun N Fun, I experienced a situation that relates to this thread. I won't go through the entire story, but I strongly recommend adding the following steps to your test flight routine - run your tanks dry (individually, at altitude and with plenty in the remaining tank of course) and know the characteristics of the system with this low level tank situation. I did much of what was described previously as far as filling the new tanks with measured quantities of fuel and checking the gauges - but... when your motoring along and the fuel gauges begin to drop and respond a little differently than you expect - and you're beyond the point of return between fuel stops (over a bunch of really tall pine trees!), it would be very helpful to know exactly how long the engine will run (at cruise, max endurance, or whatever) when the gauge shows 20, 10, 5% and ZERO!, etc. As it turned out, we landed with almost 45 minutes of reserve (based upon what we put back in the tanks), but it was beginning to get a little unnerving looking for that airport as the gauges began dropping quicker than expected. Item 2 For engine out glides, I learned something this last weekend regarding descents at no or very low power settings with a constant speed prop. With the engine out or idling, pull the prop full coarse/low rpm. The increase in gliding distance is tremendous. If the engine is rotating, it'll be developing oil pressure and the prop will respond. Just be careful when reapplying power - high rpm first! This may be obvious to some, but it was very impressive to me when I tried it for the first time. hope this info helps Bryan Jones -8 765BJ Pearland, Texas ________________________________________________________________________________
From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com>
Date: Apr 30, 2001
Congratulations! You lucky son of a Green! I hope to be writing my first flight note in the not too distant future... -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: MeangreenRV4(at)aol.com [mailto:MeangreenRV4(at)aol.com] Sent: Sunday, April 29, 2001 10:29 AM To: rv-list(at)matronics.com Subject: RV-List: Meangreen RV-4 Flys at last... That's right Meangreen is no longer a hangar virgin.After 9 years of building at 7:31 am on 4-28-01 Meangreen left the ground on its maiden flight. I wish I could bottle and sell the high I was on because I would be richer than Bill Gates. Here is some of the recorded data: Stall 55mph full flaps 58mph Clean Ground speed 180mph @ 156 Indicated 200mph @ 183 " " " 220mph @ 185 " " " Oil Temp 180 degrees Oil Pressure 75psi Fuel Pressure 25psi Many Thanks to John Harmon for all his help. ________________________________________________________________________________
From: "skybolt-aviator" <skybolt-aviator(at)msn.com>
Subject: Eng.
Date: Apr 30, 2001
For anyone looking for engine,JB Aircraft Service @ Sebring has 160hp Lyc O-320 D3G that was made up for a RV and then the fellow 180 and didn't take it.This is a good shop that I have no interestin except I was there to observe some work and told them I would put it on the list Call them @ 863 655 5000 Ollie&Lorene Washburn RV6-A,N795LW,@FD77. O-360,180HP,C/S ________________________________________________________________________________
Date: Apr 30, 1999
Subject: Re: House of Kolor question
If you're going to vent the booth with a fan, then you'll have to have a rigid frame for the booth (a box) since the plastic "curtain" will just blow out or suck in depending on whether the fan pushes or pulls the air. I used 2x4's and stapled the plastic to it. Dave, flying in SoCal barry pote wrote: > > CW, you are right. I forgot that. Over spray in the air should be > vacated from the booth, before it falls into the paint job. Some people > used airconditioning filters to clean the air.... > > He also gave a nice idea on a paint booth. 'Make a rectangle of PVC'. > Hang the plastic from it. Pull the PVC pipe rectangle to the ceiling. > Tape the plastic walls to it. You can roll up the 'walls' when not in > use and store your paint booth on the ceiling between uses.... > ________________________________________________________________________________
Subject: Oil Analysis
Date: Apr 30, 2001
After reading the various responses to the oil analysis issue, I thought I'd throw my hat into the ring. I have a small business in which I perform reliability consulting and full service lube oil analysis. Full service means I collect the samples and supply the interpretation - verbally if necessary and graphical/tabular written reports. Most of my 11-years of experience has been in the industrial arena, however in 1999 I branched out into the aviation world. Anyone interested or having questions can reach me at rii(at)pdq.net. I can tailor the service to meet most circumstances. Bryan Jones -8 765BJ Reliability Innovations Inc. ________________________________________________________________________________
From: "Albert Gardner" <albert.gardner(at)worldnet.att.net>
Date: Apr 30, 2001
The NAPA stores carry a gray self-etching primer in a spray can that I've had good success with, sticks quite well and I'm able to use the complete can with out clogging the tip (so far). I've used about 5 cans of the stuff although I mainly use PPG epoxy primer. Albert Gardner Yuma, AZ RV-9A: N872RV (Reserved) Working on wings ________________________________________________________________________________
Date: Apr 30, 2001
I haven't heard anyone mention SEM Self Etching Primer. I've been using it and can't see anything wrong with it. Has all the good attributes desired. It needs to be used in a well ventilated area however, or with a mask. I'm on my third case (RV9A tail and wings done!). By it by the case and ask the auto body supplier for the case discount. You should get it for around $7.50 a can. If you don't, go to the next supplier. One supplier here in town sells it to me for $7.13 a can by the case. Chuck Weyant ----- Original Message ----- From: "Albert Gardner" <albert.gardner(at)worldnet.att.net> Sent: Monday, April 30, 2001 8:30 AM Subject: Re: RV-List: Primers(oh no!) > > The NAPA stores carry a gray self-etching primer in a spray can that I've > had good success with, sticks quite well and I'm able to use the complete > can with out clogging the tip (so far). I've used about 5 cans of the stuff > although I mainly use PPG epoxy primer. > Albert Gardner > Yuma, AZ > RV-9A: N872RV (Reserved) > Working on wings ________________________________________________________________________________
Date: Apr 30, 2001
Subject: Fwd: [SoCAL-RVlist] The airplane finally flies
--- John Allen wrote: > Date: Mon, 30 Apr 2001 10:53:21 -0700 > Subject: [SoCAL-RVlist] The airplane finally flies > > My RV N602JA took its first flight on Sunday. > > Dennis Ashby, with Gary Sobek and Bob Bohn flying chase, flew the > initial > test flight. Take-off was at 12:30 pm from El Monte and the flight > proceeded > to Apple Valley per the operating limitations. After determining the > airplane performed satisfactorily, and once over the test area, > Dennis > proceeded to execute some performance tests (stalls) and minimal > aerobatics > (aileron roll) to determine its handling characteristics. > > The airplane flew beautifully through its maiden flight. Cylinder > break > in on the factory new cylinders occurred after about 5 minutes. The > airplane flew hands-off in its roll axis, with only a half ball yaw > in cruise. All systems worked properly. The airplane exhibited no > adverse > operating characteristics, and the squawk list is very short. > > There are no words to describe the feeling of watching your 8-year > project > lift into the air and to have it perform so well. > > After the initial flight I flew the airplane for approximately 4 > hours. > Gary Barta flew in formation for much of that period with his > Mooney. > We were flying over the Mojave Desert at 8,500 ft at 150Kts true > (173 > mph) and 2400 RPM. The sun was shining, the visibility was > unlimited, > and big fan out front just kept turning. Its a wonderful thing to > own > an airplane. > > Special thanks to my wife Bernadette. For 8 years she has let me > open > the spigot to the family savings and spend endless hours with my > aluminum > mistress. Those hours belonged to her and to the kids and they gave > them back ungrudgingly. Where do you find a woman like that? > > John Allen > > To unsubscribe from this group, send an email to: > socal-rvlist-unsubscribe(at)egroups.com Another successful first flight. Dennis Ashby is a repeat RV builder and professional pilot. This is the 6th or 7th RV that he made first flight on. Dennis reported that this one flew the best on the first flight of all the others that he test flew. The airplane did fly hands off. We took a photo of this. If it tunrs out, I will post it to the SoCAL RV web site. Congradulations John. To all the builders, keep pounding those rivets. The finished product is worth it. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 788+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Date: Apr 30, 2001
> --- John Allen wrote: > Date: Mon, 30 Apr 2001 10:53:21 -0700 > Subject: [SoCAL-RVlist] The airplane finally flies > > My RV N602JA took its first flight on Sunday. > > Dennis Ashby, with Gary Sobek and Bob Bohn flying chase, flew the > initial > test flight. Take-off was at 12:30 pm from El Monte and the flight > proceeded > to Apple Valley per the operating limitations. After determining the > airplane performed satisfactorily, and once over the test area, Dennis > proceeded to execute some performance tests (stalls) and minimal > aerobatics > (aileron roll) to determine its handling characteristics. > > The airplane flew beautifully through its maiden flight. Cylinder > break > in on the factory new cylinders occurred after about 5 minutes. The > airplane flew hands-off in its roll axis, with only a half ball yaw > in cruise. All systems worked properly. The airplane exhibited no > adverse > operating characteristics, and the squawk list is very short. > > There are no words to describe the feeling of watching your 8-year > project > lift into the air and to have it perform so well. > > After the initial flight I flew the airplane for approximately 4 > hours. > Gary Barta flew in formation for much of that period with his Mooney. > We were flying over the Mojave Desert at 8,500 ft at 150Kts true (173 > mph) and 2400 RPM. The sun was shining, the visibility was unlimited, > and big fan out front just kept turning. Its a wonderful thing to own > an airplane. > > Special thanks to my wife Bernadette. For 8 years she has let me open > the spigot to the family savings and spend endless hours with my > aluminum > mistress. Those hours belonged to her and to the kids and they gave > them back ungrudgingly. Where do you find a woman like that? > > John Allen > > To unsubscribe from this group, send an email to: > socal-rvlist-unsubscribe(at)egroups.com Another successful first flight. Dennis Ashby is a repeat RV builder and professional pilot. This is the 6th or 7th RV that he made first flight on. Dennis reported that this one flew the best on the first flight of all the others that he test flew. The airplane did fly hands off. We took a photo of this. If it tunrs out, I will post it to the SoCAL RV web site. Congradulations John. To all the builders, keep pounding those rivets. The finished product is worth it. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 788+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Subject: Aircraft Insurance Increase
Date: Apr 30, 2001
Well, just got my premium increase from AVEMCO and it is up 23% over last year. Anyone else finding similar increases in their insurance?? Maybe more important, is anyone with a company where the increase is not so unreasonable. At this rate of increase the premium will doubled in less than 5 years time. Ed Anderson Matthews, NC ________________________________________________________________________________
Date: Apr 30, 2001
Subject: Re: Aircraft Insurance Increase
In a message dated 4/30/2001 5:09:26 PM Central Daylight Time, eanderson(at)carolina.rr.com writes: > Well, just got my premium increase from AVEMCO and it is up 23% over last > year. Anyone else finding similar increases in their insurance?? Maybe > more important, is anyone with a company where the increase is not so > unreasonable. At this rate of increase the premium will doubled in less > than 5 years time. > > Ed Anderson > Matthews, NC Standard increase in the industry this year is around 20% so your not out of line. ________________________________________________________________________________
Date: Apr 30, 2001
Try Skysmith for a quote. They are in the yeller pages. John Henley ________________________________________________________________________________
Date: Apr 30, 2001
try sky smith 515/289-1439 e-mail ins(at)skysmith.com Robin Hunt Decatur, AL -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ed Anderson Sent: Monday, April 30, 2001 4:54 PM Subject: RV-List: Aircraft Insurance Increase Well, just got my premium increase from AVEMCO and it is up 23% over last year. Anyone else finding similar increases in their insurance?? Maybe more important, is anyone with a company where the increase is not so unreasonable. At this rate of increase the premium will doubled in less than 5 years time. Ed Anderson Matthews, NC ________________________________________________________________________________
Date: Apr 30, 2001
Subject: Test message!
Just checking to see if I can post to the list after a change -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/ And see my Rans S12xl experimental aircraft ________________________________________________________________________________
Date: Apr 30, 2001
From: "Builder's Bookstore" <winterland(at)rkymtnhi.com>
My Avemco policy also went up about 25%, so it was goodbye Avemco and hello to the Nationwide Van-guard policy. This year's premium is now actually less than last year's bill for double the coverage amount. There were also some issues about the Avemco policy's fine print which drastically reduced coverage of passengers in your plane, (vs. people on the ground) and then cut it even more if those passengers were family members. Check the max limit per person vs. the max limit per passenger provisions in your policy. You want it to read "per person" without reference to whether that person is a passenger or someone else on the ground. Andy > Well, just got my premium increase from AVEMCO and it is up 23% over last > year. Anyone else finding similar increases in their insurance?? ________________________________________________________________________________
Date: Apr 30, 2001
Subject: Re: RV-8 QB Kit For Sale
Give me an idea oh what you are asking for your RV8 QB ________________________________________________________________________________
Date: Apr 30, 2001
> >Well, just got my premium increase from AVEMCO and it is up 23% over last >year. Anyone else finding similar increases in their insurance?? Maybe >more important, is anyone with a company where the increase is not so >unreasonable. At this rate of increase the premium will doubled in less >than 5 years time. > >Ed Anderson >Matthews, NC Ouch! That's ridiculous. I paid for my second year of full coverage last December, and the rate went DOWN. I insure through Nationair's Vanguard program. Brian Denk RV8 N94BD ________________________________________________________________________________
Date: Apr 30, 2001
Subject: Re: Fwd: [SoCAL-RVlist] The airplane finally flies
In a message dated 4/30/01 11:33:00 AM Pacific Daylight Time, rv6flier(at)yahoo.com writes: > > --- John Allen wrote: > > Date: Mon, 30 Apr 2001 10:53:21 -0700 > > Subject: [SoCAL-RVlist] The airplane finally flies > > > > My RV N602JA took its first flight on Sunday. > I know better than anyone how you feel because my RV-4 flew on Saturday....Congrats, Job Well Done..... Tim Barnes N39TB Flying ________________________________________________________________________________
Subject: Shortening oil filler
Date: Apr 30, 2001
I emailed Bart LeBlonde with this problem earlier and he said it's fairly common. My oil filler neck sticks out my oil access door on my -4 cowling. He said a lot of guys just cut it and put it back together with some rubber tubing, oh, and shorten the dipstick too. Anybody want to email me a brief description of how they did it? I was thinking, rubber hose and SS clamps, any better ideas out there? -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 ________________________________________________________________________________
Subject: Insurance Increase
Date: Apr 30, 2001
Is the 23% or so an increase in hull coverage, liability, or both? ________________________________________________________________________________
Date: Apr 30, 2001
Subject: Bowling Green, KY - RV Builders?
Are any of the Bowling Green, KY - RV builders on the list? I'd like to talk with you. Hopeing to start building a RV7A soon :-) -- Surfing the Web from Hopkinsville, KY Visit my web site at: http://www.geocities.com/hester-hoptown/ And see my Rans S12xl experimental aircraft ________________________________________________________________________________
Date: Apr 29, 2001
AOPA has been treating me fairly. Anh -6 N985VU Maryland At 11:11 PM 04/30/2001, you wrote: > > >> >>Well, just got my premium increase from AVEMCO and it is up 23% over last >>year. Anyone else finding similar increases in their insurance?? Maybe >>more important, is anyone with a company where the increase is not so >>unreasonable. At this rate of increase the premium will doubled in less >>than 5 years time. >> >>Ed Anderson >>Matthews, NC > >Ouch! That's ridiculous. I paid for my second year of full coverage last >December, and the rate went DOWN. I insure through Nationair's Vanguard >program. > >Brian Denk >RV8 N94BD > > ________________________________________________________________________________
Date: Apr 30, 2001
In a message dated 4/30/2001 6:16:00 PM Central Daylight Time, akroguy(at)hotmail.com writes: > Ouch! That's ridiculous. I paid for my second year of full coverage last > December, and the rate went DOWN. I insure through Nationair's Vanguard > program. > > Brian Denk > RV8 N94BD Brian, It should go down in the second year if this is your first rv do to time in type etc etc etc ________________________________________________________________________________
Date: Apr 30, 2001
In a message dated Mon, 30 Apr 2001 6:09:14 PM Eastern Daylight Time, "Ed Anderson" writes: Well, just got my premium increase from AVEMCO and it is up 23% over last year. Anyone else finding similar increases in their insurance?? Maybe more important, is anyone with a company where the increase is not so unreasonable. At this rate of increase the premium will doubled in less than 5 years time.>> This year Chaparral beat out Falcon with my AIG policy. No increase full coverage. I was with Falcon for two years. -GV ________________________________________________________________________________
Date: Apr 30, 2001
Subject: RV-6A N602JA First Flight Photos
A few photos of John Allen's RV-6A N602JA on its first flight can be found at: http://members3.clubphoto.com/socal230330/N602JA_First_Flight/ Photos were taken by Trish Russell from RV-6 N157GS. Enjoy. Feel free to download for use on the World Wide Wing or the RVATOR. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 788+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Subject: Salvage Yards
Date: Apr 30, 2001
Here's a list of allegedly bigger salvage yards that have websites: Westcan in Kamloops BC http://www.westcanaircraft.com/index.html Upper Valley Aviation in Chilliwack BC http://www.uppervalleyaviation.com/ Global Aircraft Industries http://www.globalparts.com/index.html Discount Aircraft Salvage in Deer Park Washington http://www.discountaircraftsalvage.com/ I'm now looking for the bigger yards from all over the States. Can anyone supply some more links? Thank-you, Norman Hunger RV6A Delta BC ________________________________________________________________________________
Subject: Re: Salvage Yards
Date: Apr 30, 2001
http://www.sound.net/~hartmann/yelrpage.htm check here and your will find many salvage yards. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh ----- Original Message ----- From: "Norman Hunger" <nhunger(at)sprint.ca> Sent: Monday, April 30, 2001 9:15 PM Subject: RV-List: Salvage Yards > > Here's a list of allegedly bigger salvage yards that have websites: > > Westcan in Kamloops BC > http://www.westcanaircraft.com/index.html > > Upper Valley Aviation in Chilliwack BC > http://www.uppervalleyaviation.com/ > > Global Aircraft Industries > http://www.globalparts.com/index.html > > Discount Aircraft Salvage in Deer Park Washington > http://www.discountaircraftsalvage.com/ > > > I'm now looking for the bigger yards from all over the States. Can anyone > supply some more links? > > Thank-you, > Norman Hunger > RV6A Delta BC > > ________________________________________________________________________________
Date: Apr 30, 2001
Subject: Stuck Slip-Joint on Exhaust System
I had the cowl off today to inspect and make a few tweaks. While going over things, I noticed that one of the slip joints in my exhaust system was frozen. Some penetrating oil, and a bit of manipulation, and it unfroze. It probably rusted because of excess exposure to dihydrogen monoxide during under cowl cleaning. In any case, what can I do (other than not get the exhaust wet) to prevent this from happening again? Will anti-sieze help, or will it just burn off? Thanks, Kyle Boatright - Kennesaw, GA RV-6 Slider, O-320/Aymar-Demuth ________________________________________________________________________________
Date: Apr 30, 2001
Subject: Re: Summer flying events
In a message dated 4/30/2001 9:55:30 PM Eastern Daylight Time, jkitz(at)greenapple.com writes: > http://www.dot.state.oh.us/aviation John: Thanks for the Ohio webb site. I copied the event list . I live in Michigan, but frequently travel Northern Ohio. Dave Pohl ________________________________________________________________________________
Date: Apr 30, 2001
Subject: Com Antenna Placement
Date: Apr 30, 2001
I've got a Bob Archer com antenna in one wing tip connected to a Bob Archer splitter then serving two com radios. I want to try this uncertified method to eliminate external antennas. I've heard enough good reports on his products to be satisfied. However, I would like to run RG-400 from the stack to under the seats in case it isn't good enough. I want to make it quick and easy to add a com ant. Is this the best spot in a RV6A? Who is happy with his com ant below the belly? Norman Hunger RV6A Delta BC ________________________________________________________________________________
Subject: Insurance II
Date: May 01, 2001
My thanks to all who responded to my question concerning rate increases and who offered alternatives. I will now go explore some of those alternatives. Ed Anderson Matthews, NC ________________________________________________________________________________
Date: May 01, 2001
Just renewed by policy with Skysmith for $1208, $70,000 hull coverage, same as last year. I used Avemco the first year, then changed when they increased the premium 30%. Dave Hudgins RV-6A (For Sale) -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Ed Anderson Sent: Monday, April 30, 2001 4:54 PM Subject: RV-List: Aircraft Insurance Increase Well, just got my premium increase from AVEMCO and it is up 23% over last year. Anyone else finding similar increases in their insurance?? Maybe more important, is anyone with a company where the increase is not so unreasonable. At this rate of increase the premium will doubled in less than 5 years time. Ed Anderson Matthews, NC ________________________________________________________________________________
Date: May 01, 2001
Subject: Re: Com Antenna Placement
on 4/30/01 23:43, Norman Hunger at nhunger(at)sprint.ca wrote: > > I've got a Bob Archer com antenna in one wing tip connected to a Bob Archer > splitter then serving two com radios. I want to try this uncertified method > to eliminate external antennas. I've heard enough good reports on his > products to be satisfied. However, I would like to run RG-400 from the stack > to under the seats in case it isn't good enough. I want to make it quick and > easy to add a com ant. Is this the best spot in a RV6A? Who is happy with > his com ant below the belly? > > Norman Hunger > RV6A Delta BC > > I am DLW ________________________________________________________________________________
Subject: Re: Stuck Slip-Joint on Exhaust System
Date: May 01, 2001
>> >I had the cowl off today to inspect and make a few tweaks. While going >over >things, I noticed that one of the slip joints in my exhaust system was >frozen. Some penetrating oil, and a bit of manipulation, and it unfroze. > >It probably rusted because of excess exposure to dihydrogen monoxide during >under cowl cleaning. > >In any case, what can I do (other than not get the exhaust wet) to prevent >this from happening again? Will anti-sieze help, or will it just burn off? > >Thanks, > >Kyle Boatright - Kennesaw, GA >RV-6 Slider, O-320/Aymar-Demuth Kyle, I had the same experience last December when I had to pull cylinder #1 for repair. The slip joint in front of the oil sump was stuck. I sprayed some WD-40 into it and it broke free. I had to pull cylinder #2 last weekend, and the joint came apart without needing more WD. I guess that first shot of lube did the trick. Brian Denk RV8 N94BD My kingdom for a turbine!!! ________________________________________________________________________________
Subject: Re: Shouldn't Be Allowed ??
Date: May 01, 2001
> >Hey Austin, > >The sword cuts both ways ya know. What do they really have to say that is >of interest to you. Know what I mean? I'm a gear head from way back but if >it does not fly, it all seems so dull and utilitarian now. Maybe there is >such a thing as an RV snob??? I spend all day and night thinking about RV's >and loops and rolls and panel toys. Then when I hear the average joe >spouting off about something, I know this sounds bad, but I can't help but >feel sorry for him being all exited about something so mundaine as a souped >up grocery getter. I literally find myself avoiding conversations with >non-builders. Their earthbound minds cannot grasp my desires and passions >and they always say something like, "how do you know it will fly?" Why is >it so small?" Blah blah. The very best you can hope for from a ground >pounder is a simple "Neat". I mean, I never go up to the average Joe and >say "dude, how can you be a spectator of life and let the remote control >dictate who you are that day? Don't you ever want to look back and see some >kind of accomplishment?" > >Face it gang, we're a cult. Do you know the difference between a cult and a >religion? Public acceptance. We are about as close to being accepted by the >general public as a cult of gypsy O.J. Simpson worshipers. Well, so be it. >The sooner we all come to the realization that we will always be viewed by >our neighbors as the wacko plane builder, the better off we'll be. I will >continue to avoid conversations with non-builders (this includes spam >pilots) that will lead to disclosing my unusual level of confidence in my >own abilities. Ya know, if it weren't for the rest of you cultist, I just >really wouldn't have much use for humanity at all. > >Now everyone put on your new Nike's and grab some Cool-Aid. > >Eric Henson > VERRRRY well stated, Eric. It's just about impossible for the typical ground pounder who has never felt the exhilaration of personal flight, to understand WHY we do what we do. I tend to offer the same reply to their questions as my Harley riding friends when asked the same thing: "if I have to explain, you won't understand anyway". If we're a cult, then we're a bunch of the best behaved wackos on the planet! Hey, this reminds me, an upcoming RV "cult" gathering is being held in WACO, Texas, ya know. Hmmmmm..... Bar B Que anyone?? hehehe.. Brian Denk RV8 N94BD Kool-Aid fueled with Nike scuffs on my rudder pedals. ________________________________________________________________________________
Subject: Re: Start key vs. switch...
Date: May 01, 2001
I purchased a 2 position switch from West Marine. Quality was good but heavy. I was using it in my boat. Rob >From: czechsix(at)juno.com >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Start key vs. switch... >Date: Fri, 27 Apr 2001 22:17:35 -0500 > > >Guys, > >Along the lines of the recent thread on using ignition keys vs. toggle >switch / starter button, I am wondering if anyone knows of a source for a >keyed ignition switch that has only two positions (off / on) that could >be used for the starter only. I don't want to use the standard ignition >switch because I'm planning to use at least one Lightspeed system, so I >want toggles for the mag and Lightspeed. But for the starter I'd like to >have a key instead of just a button for safety reasons previously >discussed. > >Obviously the key would have to be robust enough to handle the starter >solenoid current (not sure how much that is?). Most ignition switches >for cars and airplanes have multiple positions so if anyone knows where I >could find something with only two positions please let me know. > >Thanks, > >--Mark Navratil >Cedar Rapids, Iowa >RV-8A fuselage, O-360-A4A, Sensenich 87" > > ________________________________________________________________________________
Date: May 01, 2001
Norman Hunger wrote: > > I've got a Bob Archer com antenna in one wing tip connected to a Bob Archer > splitter then serving two com radios. I want to try this uncertified method > to eliminate external antennas. I've heard enough good reports on his > products to be satisfied. However, I would like to run RG-400 from the stack > to under the seats in case it isn't good enough. I want to make it quick and > easy to add a com ant. Is this the best spot in a RV6A? Who is happy with > his com ant below the belly? > > I have mine mounted on the belly right behind the rear spar attatch bulkhead. Works great on the ground and in the air. -- Gary Zilik - Pine Junction, Colorado RV-6A N99PZ Flying Engine: Aerosport Power O-360-A1A Prop: Sensenich 72FM8S9-1-83 ________________________________________________________________________________
Date: May 01, 2001
> I have mine mounted on the belly right behind the rear spar attatch bulkhead. > Works great on the ground and in the air. Good news, thanks everybody, I'm going to run a line down there for future hook up if I need it......Norman........ ________________________________________________________________________________
Subject: Cracked jugs
Date: May 01, 2001
Listers, Well, the diagnosis came back from Gibson Aviation on my SECOND failed O-360 jug: cracked. This is cylinder #2, and #1 was replaced last December with the same problem. Anyone out there had similar experiences with the front cylinders in an RV? I'm now thinking I need to add CHT probes to all four cylinders instead of just the (supposedly) hottest cyliner #3. I wonder if operating technique...too lean, too rich, too hot, too cold, too fast, too slow...whatever...is killing off these things? I try to lean to best operating smoothness in cruise flight and plan my descents to allow gradual power reduction. Maybe it's the occasional aerobatics with all the associated throttle jockeying (fixed pitch prop) that goes along with it. Hell, who knows. The engine now has about 500 hours SMOH, and I have no idea what the history is on the original cylinders. They are chrome, so they are not new...but just HOW old they actually are is a mystery. Man, this is killing me financially. And these Lycosaurs are supposed to be the BEST engines for our airplanes???? Just venting. Brian Denk RV8 N94BD two jugs down...two to go??? ________________________________________________________________________________
Date: May 01, 2001
Gary when you put that antenna on the belly didn't you listen to the pundits who said your ground transmission wouldn't work very well? Neither did I! Mine is exactly where yours is and works great on the ground (in garage with metal door closed and all sorts of metal things hanging on walls Reid Hillveiw tower 2 1/2 miles away). They report it's crystal clear same for receiving. Radio is a Terra 720. Garry, only two "r" on the list Gary Zilik wrote: > > Norman Hunger wrote: > > > > > I've got a Bob Archer com antenna in one wing tip connected to a Bob Archer > > splitter then serving two com radios. I want to try this uncertified method > > to eliminate external antennas. I've heard enough good reports on his > > products to be satisfied. However, I would like to run RG-400 from the stack > > to under the seats in case it isn't good enough. I want to make it quick and > > easy to add a com ant. Is this the best spot in a RV6A? Who is happy with > > his com ant below the belly? > > > > > > I have mine mounted on the belly right behind the rear spar attatch bulkhead. > Works great on the ground and in the air. > > -- > Gary Zilik - Pine Junction, Colorado > RV-6A N99PZ Flying > Engine: Aerosport Power O-360-A1A > Prop: Sensenich 72FM8S9-1-83 > ________________________________________________________________________________
Subject: RV Wanted
Date: May 01, 2001
05/01/2001 11:17:03 AM Anyone know of an RV-6 for sale that is well built and well maintained? Local guy has the checkbook out but just can't find a clean one. Thanks Eric ________________________________________________________________________________
Date: May 01, 2001
Subject: Re: RV Wanted
Any one looking for an RV to buy might try Trade-A-Plane. ________________________________________________________________________________
Date: May 01, 2001
--- Norman Hunger wrote: > > > I have mine mounted on the belly right behind the rear spar attatch > bulkhead. > > Works great on the ground and in the air. > > Good news, thanks everybody, I'm going to run a line down there for > future > hook up if I need it......Norman........ Mine are mounted just FORWARD of the main spar and work great. ==== Gary A. Sobek "My Sanity" RV-6 N157GS O-320 Hartzell, 788+ Flying Hours So. CA, USA http://SoCAL_WVAF.tripod.com Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Date: May 01, 2001
> Anyone know of an RV-6 for sale that is well built and well maintained? > Local guy has the checkbook out but just can't find a clean one. Try Denny Harjehausen . He lost his medical about 4 months after he finished his 6. Very sad. He lives in Albany, Oregon. Ross ________________________________________________________________________________
Date: May 01, 2001
Subject: Re: Cracked jugs
Brian just a suggestion. I am guessing but here it is anyway 1. I bet your paying about 700.00 per cylinder or in that area. 2. you can buy brand new lycoming cylinders for roughly 1100.00 and they come complete with new pistons, wrist pin, valves and springs. 3. as you know our cylinders run the gammet of hot and cold operations, but what alot of people do not know is how close the temps are to each other: (let me explain) your intake side is pulling frigid air into the head at extremely cold temperatures, on the exhaust side it is extremely hot and can be as high as 1700 degrees. They meet in the middle right between the spark plug holes and cause metal fatigue to occur there and this is what causes the cracking. This is why lycoming reccomends new cylinders be installed, and they have a limited warranty. 4. Although I am sure some of the "new" manufacturers out there put out a great product, I have trouble in my mind messing with technology that may be old but is "proven" (if it aint broke don't fix it) 5. If you decide to go with "new" cylinders one thing I would check is the piston weight and connecting rod weight of opposite cylinders. The weight of the new piston in the lycoming cylinder will be stamped on the box, watch this closely as the oppsing cylinders should be within 1 gram of each other. ( by opposing I mean the left and right cylinders in the front of the engine not side to side. 6. Althought the weight will not cause cracking of your cylinders it makes for a pleasant running engine and will save you in the long run on avionics overhauls caused by excessive vibration. 7. Brian although not all of this is aimed at you as I know some of your background, I am giving this information to help fellow listers from falling into this "money pit". 8. following up, as you are aware you now have had to take apart your baffling and engine cylinders twice now, and if you were to put this into dollars and cents I believe it would be well worth the extra money to buy new cylinders and the resulting "peace of mind" as you know the history of your cylinder and you will have a greater opportunity to make it to T.B.O. as we all know the top end is the weak link and the bottom end will go a long time. I hope this helps regards Glenn Williams --- Brian Denk wrote: > > > Listers, > > Well, the diagnosis came back from Gibson Aviation > on my SECOND failed O-360 > jug: cracked. > > This is cylinder #2, and #1 was replaced last > December with the same > problem. > > Anyone out there had similar experiences with the > front cylinders in an RV? > I'm now thinking I need to add CHT probes to all > four cylinders instead of > just the (supposedly) hottest cyliner #3. I wonder > if operating > technique...too lean, too rich, too hot, too cold, > too fast, too > slow...whatever...is killing off these things? I try > to lean to best > operating smoothness in cruise flight and plan my > descents to allow gradual > power reduction. Maybe it's the occasional > aerobatics with all the > associated throttle jockeying (fixed pitch prop) > that goes along with it. > Hell, who knows. > > The engine now has about 500 hours SMOH, and I have > no idea what the history > is on the original cylinders. They are chrome, so > they are not new...but > just HOW old they actually are is a mystery. > > Man, this is killing me financially. And these > Lycosaurs are supposed to be > the BEST engines for our airplanes???? > > Just venting. > > Brian Denk > RV8 N94BD > two jugs down...two to go??? > > > > through > > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > Matronics! > > > > > ==== Glenn Williams 8A A&P N81GW Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Date: May 01, 2001
> > Just renewed by policy with Skysmith for $1208, $70,000 hull coverage, same > as last year. I used Avemco the first year, then changed when they increased > the premium 30%. > > Dave Hudgins > RV-6A (For Sale) > > Thanks Dave, I will submit a request a quote from Skysmith Ed ________________________________________________________________________________
Date: May 01, 2001
Brian Denk wrote: > > > Brian Denk > RV8 N94BD > two jugs down...two to go??? > Sure wish I could offer some good advice. But you have to look on the bright side of things, at least it aint a 6 cylinder. Gary Zilik ________________________________________________________________________________
Date: May 01, 2001
Y'all get sorta worked up when meeting skeptics, don't you! I used to be a non-believer, so I know how they felt. I flew my Debonair to Oshkosh and talked to some nice builders about their airplanes and was eventually hooked. If those builders had all be as vitriolic as some of you, I might not have built Valentine. Try to remain calm, Hal Kempthorne RV6a N7HK (Valentine) FLYING ________________________________________________________________________________
Subject: FW: fuel pump fitting & oil filler neck problem
Date: May 01, 2001
Thought I would forward the exchange between Bart LeBlonde and myself to the list for archive searches. Bart sent me the fitting referenced in the following emails. He sent me a 45 deg fitting and a straight through fitting so I could use either one. That's $20 + shipping friends and neighbors that he did NOT bill me for. He said to keep whatever fittings I don't use and pass them on to another RV builder who might need them. Think Lycoming would do that? I tell you what, nowhere else will you find this level of customer support. If you are thinking about buying an engine, I cannot recommend Bart highly enough. -- Scott VanArtsdalen, MCSE, CCNA Network Administrator Union Safe Deposit Bank 209-946-5116 -----Original Message----- From: sue gregor [mailto:hailey67(at)hotmail.com] Sent: Tuesday, May 01, 2001 9:44 AM Subject: RE: fitting & new problem (not too bad)reply Scott my only concern would be that the glue would break down from the heat and or the oil and the dip stick tube could fall apart making a big mess at the least. Bart >From: "Van Artsdalen, Scott" <svanarts(at)unionsafe.com > >To: sue gregor > >Subject: RE: fitting & new problem (not too bad)reply > >Thanks! I talked to someone else who used a PVC sleeve to hold the two >halves of the filler neck together. Would this and PVC cement work? If >you >think the hose is best then that's what I'll go with. >-- >Scott VanArtsdalen, MCSE, CCNA >Network Administrator >Union Safe Deposit Bank >209-946-5116 > > > -----Original Message----- > From: sue gregor [mailto:hailey67(at)hotmail.com] > Sent: Tuesday, May 01, 2001 8:05 AM > To: svanarts(at)unionsafe.com > Subject: RE: fitting & new problem (not too bad)reply > > Scott others have used standard hose clamps to secure the >hose. This seems > to work well. > Bart > > > >From: "Van Artsdalen, Scott" > > >To: sue gregor > > >Subject: RE: fitting & new problem (not too bad)reply > > > >Sounds good, Bart. Do you secure the hose with steel hose >clamps? I'm > >pretty bad at this stuff without instructions! > >-- > >Scott VanArtsdalen, MCSE, CCNA > >Network Administrator > >Union Safe Deposit Bank > >209-946-5116 > > > > > > -----Original Message----- > > From: sue gregor >[mailto:hailey67(at)hotmail.com] > > Sent: Monday, April 30, 2001 1:31 PM > > To: svanarts(at)unionsafe.com > > Subject: RE: fitting & new problem >(not too bad)reply > > > > Scott keep the other fitting. You may be >able to help > >another builder out > > with it. Most guys are cutting the dip >sticks on RV4s and > >shortening to the > > desired length. You will need a short >section of 1-1/8the > >hose to reconnect > > the two sections left. This works out better >than finding a > >shorter tube as > > it usually hits the engine mount anyways. >Just remember to > >shorten the dip > > stick the same amount you shorten the tube. > > >Bart > > > > > > >From: "Van Artsdalen, Scott" > > > > >To: sue gregor > > > >Subject: RE: fitting & new problem (not too >bad) > > >Date: Mon, 30 Apr > > > > > >Great! I'll send you the one back that I >don't use. Got > >one other > > >problem. > > >The oil filler tube sticks out above my top >cowling on my > >rv-4. I had to > > >go > > >ahead and cut the opening for the oil door >before I could > >fit the top cowl. > > >It looks like it sticks up a good 2 inches. >I took some > >pictures over the > > >weekend and can send them to you if you >need a better idea > >of what I'm > > >talking about. Is there a shorter filler >tube/dipstick > >combo that I can > > >put > > >on? I need it to be probably about 6 >inches shorter. Any > >ideas? > > >-- > > >Scott VanArtsdalen, MCSE, CCNA > > >Network Administrator > > >Union Safe Deposit Bank > > >209-946-5116 > > > > > > > > > -----Original Message----- > > > From: sue gregor > >[mailto:hailey67(at)hotmail.com] > > > Sent: Wednesday, April 25, >2001 1:30 PM > > > To: >svanarts(at)unionsafe.com > > > Subject: RE: fitting > > > > > > Scott fitting on way. > > > >Bart > > > > > > > > > >From: "Van Artsdalen, >Scott" > > > > > > >To: sue gregor > > > > > >Subject: RE: fitting > > > > > > > > > > >Well, I don't know what the >part number > >would be but I > > >think that 90 deg > > > >fitting on the exit side of >the fuel pump > >needs to be a 45 > > >deg fitting. I > > > >was going to order a KB-045 >from Aircraft > >Spruce. If that > > >sounds right to > > > >you, then if you could send >me one I'd > >really appreciate > > >it! > > > >-- > > > >Scott VanArtsdalen, MCSE, >CCNA > > > >Network Administrator > > > >Union Safe Deposit Bank > > > >209-946-5116 > > > > > > > > > > > > >-----Original Message----- * > > > From: sue >gregor > > >[mailto:hailey67(at)hotmail.com] * > > > Sent: >Wednesday, April 25, > >2001 9:55 AM * > > > To: > >svanarts(at)unionsafe.com * > > > Subject: >fitting > > > > * > > > Scott let me >know what you > >need for a > > >fitting and I will > > > >mail you one. > > > > > > >Bart > > > > > > > > > > > > > >_________________________________________________________________________ * > > > Get Your >Private, Free > >E-mail from MSN > > >Hotmail at > > > >http://www.hotmail.com. > > > > > > > > > > > >_________________________________________________________________________ > > > Get Your Private, Free >E-mail from MSN > >Hotmail at > > >http://www.hotmail.com. > > > > > > >_________________________________________________________________________ E-mail from MSN >Hotmail at > >http://www.hotmail.com. > > >_________________________________________________________________________ >http://www.hotmail.com. ________________________________________________________________________________
Date: May 01, 2001
Thread-Topic: RV-List: Cracked jugs Thread-Index: AcDSVvEJcEIrHemoRtqs7ElSfHRNoAAAfUhw
Hi Brian, If I were you, I'd be raising some serious hell with whomever you bought the engine from and let them buy you a new cylinder. I'm sure you bought the engine expecting it to go to TBO, and if doesn't then the seller didn't live up to his end of the deal. Period. I can understand one cylinder going out, but when you have another that does the same thing I wouldn't just write it off as a freak occurrence. I've heard horror stories where some salvage yards put together engines out of parts laying around the barn which would have no business in any airplane but since they know they're going to sell it as an experimental engine they do it anyway. There's a lot of junk floating around, folks. It sounds like you're not doing anything wrong, Brian; I run around with guys who do acro and have 1500 hours on their engines and no engine problems whatsoever. You could give the cylinder serial number to a Lycoming rep to find out when it was produced, but that won't tell you how many hours are on it obviously. I'm guessing that that your cylinders have high time on them and are past their fatigue life. Your best bet would be to try to get the seller to partially finance the cost of four new lyc or superior cylinders, bolt them on, and be done with your engine woes. If the establishment you purchased the engine from doesn't help you, then by all means spread the word so that others don't deal with them. Your life is worth a lot more than four grand, and you certainly don't want that voice in the back of your mind saying well, I hope a cylinder doesn't disintegrate today while you're flying over something where there's no place to land. At the very least with new cylinders you'll be buying a lot less oil than with the non-chrome cylinders. Bob Japundza RV-6 N244BJ O-360C/S flying 123 hours Kokomo, IN -----Original Message----- From: Brian Denk [mailto:akroguy(at)hotmail.com] Sent: Tuesday, May 01, 2001 10:05 AM Subject: RV-List: Cracked jugs Listers, Well, the diagnosis came back from Gibson Aviation on my SECOND failed O-360 jug: cracked. This is cylinder #2, and #1 was replaced last December with the same problem. Anyone out there had similar experiences with the front cylinders in an RV? I'm now thinking I need to add CHT probes to all four cylinders instead of just the (supposedly) hottest cyliner #3. I wonder if operating technique...too lean, too rich, too hot, too cold, too fast, too slow...whatever...is killing off these things? I try to lean to best operating smoothness in cruise flight and plan my descents to allow gradual power reduction. Maybe it's the occasional aerobatics with all the associated throttle jockeying (fixed pitch prop) that goes along with it. Hell, who knows. The engine now has about 500 hours SMOH, and I have no idea what the history is on the original cylinders. They are chrome, so they are not new...but just HOW old they actually are is a mystery. Man, this is killing me financially. And these Lycosaurs are supposed to be the BEST engines for our airplanes???? Just venting. Brian Denk RV8 N94BD two jugs down...two to go??? ________________________________________________________________________________
Date: May 01, 2001
Eric, Local where? The Bakersfield Bunch has numerous birds, all extremely well built/cared for, I'm sure there's at least one 6 available. Chuck ________________________________________________________________________________
Date: May 01, 2001
Subject: Comm Antenae
Since we are on the subject, I am considering the foil windscreen comm antennae like Van's uses on some of their prototypes. Anyone have good or bad comments on this setup? My airplane is an RV-6A Slider and I have a Terra 720. Thanks, Eric Newton - Long Beach, MS RV-6A - N57ME (reserved) (Panel Wiring) www.ericsrv6a.com ________________________________________________________________________________
Date: May 01, 2001
Brian, A gentleman named Deakins has a very interesting column on Lycoming's latest bulletin. He writes columns for www.avweb.com. It doesn't specifically address your concern, but does provide insight in how to operate these engines for best life. Bill Christie, RV8A fuselage, Phoenix ----- Original Message ----- From: Brian Denk <akroguy(at)hotmail.com> Sent: Tuesday, May 01, 2001 3:05 PM Subject: RV-List: Cracked jugs > > Listers, > > Well, the diagnosis came back from Gibson Aviation on my SECOND failed O-360 > jug: cracked. > > This is cylinder #2, and #1 was replaced last December with the same > problem. > > Anyone out there had similar experiences with the front cylinders in an RV? > I'm now thinking I need to add CHT probes to all four cylinders instead of > just the (supposedly) hottest cyliner #3. I wonder if operating > technique...too lean, too rich, too hot, too cold, too fast, too > slow...whatever...is killing off these things? I try to lean to best > operating smoothness in cruise flight and plan my descents to allow gradual > power reduction. Maybe it's the occasional aerobatics with all the > associated throttle jockeying (fixed pitch prop) that goes along with it. > Hell, who knows. > > The engine now has about 500 hours SMOH, and I have no idea what the history > is on the original cylinders. They are chrome, so they are not new...but > just HOW old they actually are is a mystery. > > Man, this is killing me financially. And these Lycosaurs are supposed to be > the BEST engines for our airplanes???? > > Just venting. > > Brian Denk > RV8 N94BD > two jugs down...two to go??? > > ________________________________________________________________________________
Date: May 01, 2001
05/01/2001 01:06:09 PM Hey Brian, Where did they crack? The old exhaust port crack trick? Seems thats the first place lots of the engine guys look. Best money maker Lyco ever made. "Brian Denk" (at)matronics.com on 05/01/2001 11:05:02 AM Please respond to rv-list(at)matronics.com Sent by: owner-rv-list-server(at)matronics.com cc: Subject: RV-List: Cracked jugs Listers, Well, the diagnosis came back from Gibson Aviation on my SECOND failed O-360 jug: cracked. This is cylinder #2, and #1 was replaced last December with the same problem. Anyone out there had similar experiences with the front cylinders in an RV? I'm now thinking I need to add CHT probes to all four cylinders instead of just the (supposedly) hottest cyliner #3. I wonder if operating technique...too lean, too rich, too hot, too cold, too fast, too slow...whatever...is killing off these things? I try to lean to best operating smoothness in cruise flight and plan my descents to allow gradual power reduction. Maybe it's the occasional aerobatics with all the associated throttle jockeying (fixed pitch prop) that goes along with it. Hell, who knows. The engine now has about 500 hours SMOH, and I have no idea what the history is on the original cylinders. They are chrome, so they are not new...but just HOW old they actually are is a mystery. Man, this is killing me financially. And these Lycosaurs are supposed to be the BEST engines for our airplanes???? Just venting. Brian Denk RV8 N94BD two jugs down...two to go??? ________________________________________________________________________________
Date: May 01, 2001
Subject: Re: Comm Antenae
Eric , Last fall I talked to Gus, I think that's his name (english accent), at Vans he said he gave up trying to make it work properly ( it squealed in his headset and had poor reception and transmission properties) and installed an outside antenna. I've got a Terra 720 with bell mounted antenna that works great, on the ground at least. Garry RV6 Finishing ENewton57(at)aol.com wrote: > > Since we are on the subject, I am considering the foil windscreen comm antennae like Van's uses on some of their prototypes. Anyone have good or bad comments on this setup? My airplane is an RV-6A Slider and I have a Terra 720. > Thanks, > > Eric Newton - Long Beach, MS > RV-6A - N57ME (reserved) (Panel Wiring) > www.ericsrv6a.com > ________________________________________________________________________________
Date: May 01, 2001
I just read Deakins article. He's right in that we can't operate our Lyc's LOP 'cause the engine runs too rough before we get there. Oh well, helped kill lunch hr. anyway. Rick Caldwell RV-6 O-320-D1A C/S leaned to ROP 'cause that's all there is. >Brian, >A gentleman named Deakins has a very interesting column on Lycoming's >latest >bulletin. He writes columns for www.avweb.com. It doesn't specifically >address your concern, but does provide insight in how to operate these >engines for best life. >Bill Christie, RV8A fuselage, Phoenix ________________________________________________________________________________
Date: May 01, 2001
Thread-Topic: RV-List: Cracked jugs Thread-Index: AcDSZKF7FzEV4G2kQ4af3BPuuHkVwAAAAymw
Hi Scott, A little typo...take the word "non" out of the sentence. I hardly read whatever I type. Engines that have chrome cylinders tend to consume oil. This is conventional wisdom that I didn't know about until after I bought my engine (does that mean I'm not wise???). Don't know the exact technical reason why. Mine goes through a quart about every 8-10 hours, it has chrome cylinders; most of it ends up on the belly, but the engine isn't burning the oil. I have a separator which helps, but not much. A friend with an IO-360 with chrome cylinders in his -8 uses about the same amount of oil. Bob Japundza RV-6 N244BJ O-360C/S flying -----Original Message----- From: ABAYMAN(at)aol.com [mailto:ABAYMAN(at)aol.com] Sent: Tuesday, May 01, 2001 12:31 PM Subject: Re: RV-List: Cracked jugs << At the very least with new cylinders you'll be buying a lot less oil than with the non-chrome cylinders. >> Bob, what do you mean by this statement, my engine has chrome cylinders, and i haven't started it up yet to find out the oil consumption, . Do chrome cylinders go through more oil? scott tampa rv6a finishing ________________________________________________________________________________
Date: May 01, 2001
Subject: No Propeller!
Yowsa, here is something I don't ever want to deal with. B. Reg. No.: 26RK M/M: RV4 Desc: 1987 VAN GRUNSEN RV-4 Activity: Pleasure Phase: Cruise GA-A/C: General Aviation Descr: EXP AIRCRAFT HAD PROPELLER COME OFF IN FLIGHT, LANDED ON FOOTBALL FIELD, ONAGA, KS -- Gary Zilik - Pine Junction, Colorado RV-6A N99PZ Flying Engine: Aerosport Power O-360-A1A Prop: Sensenich 72FM8S9-1-83 ________________________________________________________________________________
Subject: RV4 partially complete--- 4 sale---- bargain price---- will
accept any resonable offer
Date: May 01, 2001
Phone 620-431-1874 evenings -- Kansas Ask for Dennis ________________________________________________________________________________
Date: May 01, 2001
Subject: Wiring Diagram
Hi all... I just posted the first draft of my wiring diagram... I am interested in your feedback, but go easy on me, I'm a virgin! What I am looking for is a cheap, simple, and reliable night VFR system... http://vondane.com/rv8a/panel/wd1/N8VD-WD-1.htm Bill VonDane, Colorado Springs, CO RV-8A, N8VD, Fuselage http://vondane.com/rv8a/ ________________________________________________________________________________
Date: May 01, 2001
> > >Brian, >A gentleman named Deakins has a very interesting column on Lycoming's >latest >bulletin. He writes columns for www.avweb.com. It doesn't specifically >address your concern, but does provide insight in how to operate these >engines for best life. >Bill Christie, RV8A fuselage, Phoenix Bill, Funny you should mention that. I read that article just yesterday! I would have never thought that running on the LEAN side of peak was a good idea. Quite a paradigm shift for me. I've been running just rich of peak, as far as my #3 cylinder EGT tells me on a carbureted engine...which is certainly not uniform for all cylinders. It does, however, give me a reference point along with overall smoothness of operation. Along these lines, I received a response from Bart Lalonde just a while ago. His recommendations, which I value greatly, are to have EGT/CHT indications for all four cylinders. Also, he stated that when replacing jugs, do all you can to insure that you use new cylinders or first runout overhauls only. New cylinders are certainly doable, but at a cost premium. Finding first runout overhauls might be a daunting task. Either you'd have to find the cylinders yourself, or trust that they are indeed taking all reasonable measures to assure you that they are truly first runout. Hmm...Eclipse Aviation is going to be building those new jets here pretty soon. I wonder if they'd notice if one of their William's jet engines disappeared from stock.....??? Oooh...gimme gimme.. Brian Denk ________________________________________________________________________________
Subject: uEncoder power supply
Date: May 01, 2001
Listers, Just a heads up for those using Rocky Mountain Instruments MicroEncoders so they don't make the same mistake I did: make sure you power your unit from your avionics master switch or bus, which you will normally switch on *after* engine start. I powered mine from a breaker on the main bus which is energized whenever the master switch is on. During starter engagement your bus voltage will drop to approximately 9.7 volts (measured mine). According to Ron Mowrer at RMI anything below about 10.5 will cause the uEncoder to reset itself to 29.92. Whenever it does this you not only lose your local altimeter setting, and get an incorrect altitude of course, but the thing sits there and flashes. Of course the display goes crazy during this reset. It would have been no problem to wire it this way from the get go, but nowhere in the manual does it mention this problem, and now I have all breakers permanently mounted and placards engraved... grrr. The temporary workaround is to move the power supply up to one of my avionics appliances. This will function fine but leave my placarding incorrect and give me no way to pull the breaker/power to just the uEncoder for troubleshooting. I'll probably gang it on my intercom circuit. Randy Lervold RV-8, #80500, first flight probably thursday www.rv-8.com Home Wing VAF ________________________________________________________________________________
Date: May 01, 2001
Subject: Re: 0-360
If you find one, order two, they are as rare as hens teeth. I am just about ready to write the elephant check to Vans for a 0-time engine. G 2 RV8A ________________________________________________________________________________
Date: May 01, 2001
From: "McShurley, Donald" <dgm(at)slac.stanford.edu>
<76A109862EAED4119176009027EECD1E04381F7C(at)AGAMEMNON.SLAC.Stanford.EDU> -----Original Message----- From: Randy Lervold [mailto:randy@rv-8.com] Sent: Tuesday, May 01, 2001 1:09 PM aeroelectric-list(at)matronics.com Subject: RV-List: uEncoder power supply Listers, Just a heads up for those using Rocky Mountain Instruments MicroEncoders so they don't make the same mistake I did: make sure you power your unit from your avionics master switch or bus, which you will normally switch on *after* engine start. I powered mine from a breaker on the main bus which is energized whenever the master switch is on. During starter engagement your bus voltage will drop to approximately 9.7 volts (measured mine). According to Ron Mowrer at RMI anything below about 10.5 will cause the uEncoder to reset itself to 29.92. Whenever it does this you not only lose your local altimeter setting, and get an incorrect altitude of course, but the thing sits there and flashes. Of course the display goes crazy during this reset. Randy, No big problem. Just put a small automotive d.c. relay in line with the circuit breaker. Switch the relay with power from the avionics buss. This will give you c.b. protection and you won't have to change your labeling Don McShurley ________________________________________________________________________________
From: "Clifford Begnaud" <shoeless(at)barefootpilot.com>
Subject: dimple die
Date: May 01, 2001
Does anyone have one of those fuel tank dimple dies from Cleveland tools that they would like to sell for half price? Cliff RV9A (tanks) www.barefootpilot.com ________________________________________________________________________________
Date: May 02, 2001
Subject: Plans for metal fuselage jig - RV6A
Greetings Listers from the Persian Gulf, I am just finishing my wings and will commence on fuselage within next few weeks. Good straight lumber is about as rare as Rocking Horse Manure here in the UAE, so I have to make it out of steel. Does anyone have any plans or a material list, as I tend to over engineer things and don't want to spend a lot of unnecessary time/effort on the jig. My initial thoughts is to make it as per plans but use steel square tubing of the same dimensions. Being here in the Arabian Gulf makes it impossible to view anyone else's efforts - talk about out on a limb !! Any help would sure be appreciated. Finishing RV6A Wings David Roseblade Persian Gulf , getting hotter by the day ! ________________________________________________________________________________
Subject: Re: uEncoder power supply
Date: May 01, 2001
Hey Randy, I got kinda lucky hear and found out about this early on when I was have some conversation with the folks and Rocky Mountain. Can't rememnber now but not important. Anyway, what I did was tie it into the transponder circuit breaker because that is how most standard encoders are wired, FWIW. Mike Robertson Former RV-8A owner P.S. I am now firmly entrenched in Portland and look forward to all the RV activity here. >From: "Randy Lervold" <randy@rv-8.com> >Reply-To: rv-list(at)matronics.com >To: , , > >Subject: RV-List: uEncoder power supply >Date: Tue, 1 May 2001 13:09:08 -0700 > > >Listers, > >Just a heads up for those using Rocky Mountain Instruments MicroEncoders so >they don't make the same mistake I did: make sure you power your unit from >your avionics master switch or bus, which you will normally switch on >*after* engine start. I powered mine from a breaker on the main bus which >is >energized whenever the master switch is on. During starter engagement your >bus voltage will drop to approximately 9.7 volts (measured mine). According >to Ron Mowrer at RMI anything below about 10.5 will cause the uEncoder to >reset itself to 29.92. Whenever it does this you not only lose your local >altimeter setting, and get an incorrect altitude of course, but the thing >sits there and flashes. Of course the display goes crazy during this reset. > >It would have been no problem to wire it this way from the get go, but >nowhere in the manual does it mention this problem, and now I have all >breakers permanently mounted and placards engraved... grrr. The temporary >workaround is to move the power supply up to one of my avionics appliances. >This will function fine but leave my placarding incorrect and give me no >way >to pull the breaker/power to just the uEncoder for troubleshooting. I'll >probably gang it on my intercom circuit. > >Randy Lervold >RV-8, #80500, first flight probably thursday >www.rv-8.com >Home Wing VAF > > ________________________________________________________________________________
Date: May 01, 2001
Eric, Didn't work for me. Too much RF getting into the headset causing a loud squeal during transmit. Even capacitors didn't help. Finally moved the ant. to the belly where it works great. Bill, RV-8 N48WD ----- Original Message ----- From: <ENewton57(at)aol.com> Sent: Tuesday, May 01, 2001 1:00 PM Subject: RV-List: Comm Antenae > > Since we are on the subject, I am considering the foil windscreen comm antennae like Van's uses on some of their prototypes. Anyone have good or bad comments on this setup? My airplane is an RV-6A Slider and I have a Terra 720. > Thanks, > > Eric Newton - Long Beach, MS > RV-6A - N57ME (reserved) (Panel Wiring) > www.ericsrv6a.com > > ________________________________________________________________________________
Date: May 01, 2001
In a message dated 05/01/2001 1:06:12 PM Eastern Daylight Time, billc(at)dancris.com writes: > A gentleman named Deakins has a very interesting column on Lycoming's latest > bulletin. He writes columns for www.avweb.com. It doesn't specifically > address your concern, but does provide insight in how to operate these > engines for best life. > I read Deakins' post with interest yesterday, but after one read-through, I am not certain it really has much relevance to us flat-four carbureted guys... we can't really operate LOP without unacceptable roughness most of the time. Comments?? Bill B New carby just installed. Bill Boyd RV-6A O-320/Sensenich FP Hop-Along Air Field, 12VA Clifton Forge, VA ________________________________________________________________________________
Date: May 01, 2001
Subject: Re: Oshkosh
Louis: Just go to Van's web site for banquet info. www.vansaircraft.com On the right hand side, there is a specific "Oshkosh" heading you can click on and get the details for getting tickets. Good Luck Dave Pohl ________________________________________________________________________________
Date: May 01, 2001
Randy, the uEncoder on my RV-6 is wired through the main bus since I have no avionics switch. I have seen the uEncoder "reset" maybe three or four times in 260 hrs of operation, and each time it was only necessary to push the ACK knob to get the unit to display properly (well....seems I remember having to reset the altimeter setting a couple of times). I had heard of the possibility of the calibration tables being corrupted by the reset, but it has never happened with my unit. Before you mess up your nice placards and wiring architecture, you may want to fly for a while to see if you do indeed have a problem with resets. I suspect the unit will be very reliable as you have it wired now. Good luck with your tests flights! Sam Buchanan (RV-6, and very happy with the RMI stuff!) "The RV Journal" http://home.hiwaay.net/~sbuc/journal =============== Randy Lervold wrote: > > > Listers, > > Just a heads up for those using Rocky Mountain Instruments MicroEncoders so > they don't make the same mistake I did: make sure you power your unit from > your avionics master switch or bus, which you will normally switch on > *after* engine start. I powered mine from a breaker on the main bus which is > energized whenever the master switch is on. During starter engagement your > bus voltage will drop to approximately 9.7 volts (measured mine). According > to Ron Mowrer at RMI anything below about 10.5 will cause the uEncoder to > reset itself to 29.92. Whenever it does this you not only lose your local > altimeter setting, and get an incorrect altitude of course, but the thing > sits there and flashes. Of course the display goes crazy during this reset. > > It would have been no problem to wire it this way from the get go, but > nowhere in the manual does it mention this problem, and now I have all > breakers permanently mounted and placards engraved... grrr. The temporary > workaround is to move the power supply up to one of my avionics appliances. > This will function fine but leave my placarding incorrect and give me no way > to pull the breaker/power to just the uEncoder for troubleshooting. I'll > probably gang it on my intercom circuit. > > Randy Lervold > RV-8, #80500, first flight probably thursday > www.rv-8.com > Home Wing VAF ________________________________________________________________________________
Date: May 01, 2001
Milk of Magnesia may be used as a high temp antisieze. It is used on turbine engine igniters. Randy Hooper RV-8 Wings ________________________________________________________________________________
Date: May 01, 2001
> >Listers, > >Well, the diagnosis came back from Gibson Aviation on my SECOND failed O-360 >jug: cracked. > >This is cylinder #2, and #1 was replaced last December with the same >problem. > >======================= This can be a tough nut to crack (ahem). We have planes that are made to go up and play around with and that means sometimes getting all over the throttle. Powering up one side of a loop and shutting it down on the back side puts these air cooled gas burners through real steep thermal cycles. The heating up isn't so bad but the shock cooling is a killer. I remember a maximum cooling rate from some time ago was about 1 degree per three seconds. That's near impossible when you're up playing around. The 4 cyl cht recommended by Bart will help you see the thermal cycle you are putting your engine through. Maybe this is part of your problem and maybe not, I've never seen you fly. I know there are plenty of pilots that are not cognizant of the cooling rate of their engine. Not their fault, they were never taught it was something to worry about. In another life I ran a skydiving operation and that is one of the toughest duty cycles you can put on a plane. The first thing they learned from us was to take care of the engine. Many cylinders could be trashed by a ham fisted pilot in a hurry to get back down after a long hard climb. Makes your cash flow turn red in a hurry. The trick was to cool them off slowly at first. Once the temps stabilized you could come down faster. The last three years we were in business we had no cracked cylinders, the first couple of years were expensive lessons. I know how I fly my RV-4 and if I saw or heard one of our jump pilots moving the throttle that fast I would have been all over him/her about buying me some new cylinders. Again, it's a tough nut to crack as these planes are not intended to do straight and level flying. Just sharing lessons learned.. Blue skies, Mike Mike McGee, RV-4 N996RV, O320-E2G, Aurora, OR ________________________________________________________________________________
Subject: bleed valve
Date: May 01, 2001
I am down to plumbing my brake system and am a mechanic by trade so why does the bleed valve for the calipers show as being on the bottom when the trapped air will be at the top Ken S. Down to little things and looking for hanger in bend> ________________________________________________________________________________
Date: May 01, 2001
> Randy, the uEncoder on my RV-6 is wired through the main bus since I > have no avionics switch. I have seen the uEncoder "reset" maybe three or > four times in 260 hrs of operation, and each time it was only necessary > to push the ACK knob to get the unit to display properly (well....seems > I remember having to reset the altimeter setting a couple of times). > > I had heard of the possibility of the calibration tables being corrupted > by the reset, but it has never happened with my unit. > > Before you mess up your nice placards and wiring architecture, you may > want to fly for a while to see if you do indeed have a problem with > resets. I suspect the unit will be very reliable as you have it wired > now. > Good luck with your tests flights! Sam, I have engaged the starter six times now with pressurizing the engine and actually starting it twice and the uEncoder has gone through a reset every time. Nevertheless I will leave it wired as it is for a week or so as you suggest. I can simply pull the breaker prior to starting and then push it in after I start the engine, which I'll probably do the first few times. Then I'll do as you suggest and try starting with the unit hot. If it does indeed reset every time I'll change the power sourse... it can't be good for it to reset like that. Ron at RMI kind of cringed when I told him 9.6 volts. First flight very likely Thursday morning, second flight same day. Thanks! Randy www.rv-8.com ________________________________________________________________________________
Date: May 02, 2001
Subject: Austin's soliloquy...
< And 20 minutes from there, we skim the forest at a slower speed and peer below to see if we can see anything of another yellow Harvard, missing for 50 years, or any of the other "missings" still sleeping there. These granite cliffs that continue their steep plunge far below the green surface of the sea, a great place to fish , and beautiful and dangerous to dive..> Pure poetry, old timer... ________________________________________________________________________________
Subject: Re: Cracked jugs (GAMI)
Date: May 02, 2001
Bill, LOP does make sence, But you need to address the roughness issue first. Based on what I've read - the best way (with IO engines)is with the GAMI injectors, which are now available for Lycomings. They resolve the roughness issue by eliminating early over leaning on the first cylinders in the injection system by having all Cyl lean at the same time. Good Building, Chuck & Dave Rowbotham RV-8A (finishing F/G) Niantic, CT & Westerly airport > >I read Deakins' post with interest yesterday, but after one read-through, I >am not certain it really has much relevance to us flat-four carbureted >guys... we can't really operate LOP without unacceptable roughness most of >the time. Comments?? > >Bill B >New carby just installed. > > >Bill Boyd >RV-6A O-320/Sensenich FP ________________________________________________________________________________
Date: May 02, 2001
Randy Lervold wrote: > > > > Randy, the uEncoder on my RV-6 is wired through the main bus since I > > have no avionics switch. I have seen the uEncoder "reset" maybe three or > > four times in 260 hrs of operation, and each time it was only necessary > > to push the ACK knob to get the unit to display properly (well....seems > > I remember having to reset the altimeter setting a couple of times). > > > > I had heard of the possibility of the calibration tables being corrupted > > by the reset, but it has never happened with my unit. > > > > Before you mess up your nice placards and wiring architecture, you may > > want to fly for a while to see if you do indeed have a problem with > > resets. I suspect the unit will be very reliable as you have it wired > > now. > > Good luck with your tests flights! > > Sam, > I have engaged the starter six times now with pressurizing the engine and > actually starting it twice and the uEncoder has gone through a reset every > time. Nevertheless I will leave it wired as it is for a week or so as you > suggest. I can simply pull the breaker prior to starting and then push it in > after I start the engine, which I'll probably do the first few times. Then > I'll do as you suggest and try starting with the unit hot. If it does indeed > reset every time I'll change the power sourse... it can't be good for it to > reset like that. Ron at RMI kind of cringed when I told him 9.6 volts. > > First flight very likely Thursday morning, second flight same day. > > Thanks! > Randy > www.rv-8.com > Mine actually dumped the tables and I had to reload them all. I just went to radio shack and got a very small unobtrusive toggle switch and wired it through that. The switch is in my panel unmarked, I just turn it on after start. Jerry Springer ________________________________________________________________________________
Subject: Harmonic balancer for sale?
Date: May 02, 2001
Does anyone out there in RV land have a Landoll harmonic balancer for an O-320 that (1) they are not using and (2) want to sell? Steve Soule Huntington, V T RV-6A ________________________________________________________________________________
Date: May 02, 2001
Subject: Re: bleed valve
Ken Stribling wrote: > > I am down to plumbing my brake system and am a mechanic by trade so why does > the bleed valve for the calipers show as being on the bottom when the > trapped air will be at the top > > Ken S. Down to little things and looking for hanger in bend> > > _ Ken, Common practice is to bleed the brakes from the bottom up. Starting with an empty system fill a pump oil can with fluid and attach a hose from the bleed valve to the oil can. Open the bleed valve and start pumping fluid in. Watch the air bubbles rise and when there are no bubbles in the line you are done. Make sure you keep an I on the fluid resevoir so it does no over flow. -- Gary Zilik - Pine Junction, Colorado RV-6A N99PZ Flying Engine: Aerosport Power O-360-A1A with H2AD Pistons Prop: Sensenich 72FM8S9-1-83 ________________________________________________________________________________
From: "Douglas G. Murray" <dgmurray(at)telusplanet.net>
Date: May 02, 2001
Ken - The bleed valve needs to be at the bottom as you need to push fluid up through the system. The air in the system will be pushed out at the reservoir. You will need to do both sides the same way. Bleeding the system from the top down as in automotive applications is extremely difficult if not impossible as the master cylinders are not at the top as in an auto and cannot push fluid through the system above the cylinders. Hope this helps, Douglas G. Murray RV-6 C-GRPA Southern Alberta (a fellow Automotive Technician) > > I am down to plumbing my brake system and am a mechanic by trade so why does > the bleed valve for the calipers show as being on the bottom when the > trapped air will be at the top > > Ken S. Down to little things and looking for hanger in bend> ________________________________________________________________________________
Date: May 02, 2001
Or how about down one of the gear leg fairings? I've seen a number of folks make reference to doing this and this is what I plan to do with mine. At this early point in the game, I think I'll be able to keep most of the antennas inside, save for the GPS disk. Cheers, Brad RV6A Underway... > Since we are on the subject, I am considering the foil windscreen comm antennae like > Van's uses on some of their prototypes. Anyone have good or bad comments on this > setup? My airplane is an RV-6A Slider and I have a Terra 720. ________________________________________________________________________________
Date: May 02, 2001
Subject: Insurance
We have always been satisfied with the rates and service for over 10 years with AUA. Give Mac McGee a call at 800-727-3823. George and Becki Orndorff ________________________________________________________________________________
Date: May 02, 2001
Subject: polished aluminum spinner
We are pleased to offer a polished aluminum spinner made the same size and shape as Van's spinner. The price is $210 plus shipping. Please email or call (940) 648-0841 for further information. George and Becki Orndorff ________________________________________________________________________________
From: "skybolt-aviator" <skybolt-aviator(at)msn.com>
Date: May 02, 2001
Because aircraft brakes are usually bled from bottom which pushes air and fluid up through brakes, lines and master cylinders. Ollie&Lorene Washburn RV6-A,N795LW,@FD77. ----- Original Message ----- From: "Ken Stribling" <bbattery(at)bendcable.com> Sent: Wednesday, May 02, 2001 12:03 AM Subject: RV-List: bleed valve > > I am down to plumbing my brake system and am a mechanic by trade so why does > the bleed valve for the calipers show as being on the bottom when the > trapped air will be at the top > > Ken S. Down to little things and looking for hanger in bend> > > ________________________________________________________________________________
Date: May 02, 2001
Subject: Poetry?
If Austin's writing is prose or poetry,I like it,It brightens my day. Bob Murphy Poplar Grove ILL. (C77) ________________________________________________________________________________
Subject: Re: polished aluminum spinner
Date: May 02, 2001
> We are pleased to offer a polished aluminum spinner made the same size > and shape as Van's spinner. The price is $210 plus shipping. Please email > or call (940) 648-0841 for further information. > > George and Becki Orndorff How much does it weigh? Ross ________________________________________________________________________________
Date: May 02, 2001
Subject: Radio
I have a space problem in the panel of my RV4 .I need to replace my Terra com.Was there an Aussy com.radio of a small dimension a few months ago on the list? Bob Murphy Poplar Grove ILL. (C77) ________________________________________________________________________________
Subject: Instrument Repair
Date: May 02, 2001
Well I started wiring the plane last night and joined the bonehead club, as if I weren't already a member. I am using Van's new 2 1/4" gauges which have the 6/32 studs protruding from the back of the instrument for attachment of the wires with ring terminals. I was working along, proud that I was finally starting to wire the plane and got a little over zealous when tightening one of the nuts on the manifold pressure gauge. It sheared the 6/32 stud in two pieces near the back of the instrument. There is just enough stud remaining to connect the ring terminal without the double nut set up that the other terminals have. To explain that a little clearer. With the normal setup, as the stud protrudes from the back of the instrument there is a nut, washer, ring terminal, washer, star washer, and finally a nut. I can only get the ring terminal, washer, star washer and then the nut with little to no thread protruding from the nut. I think this setup with work, but I would like to replace the stud if this can be easily completed. My question is, can the studs be easily removed or replaced or would I have to replace the instrument itself? Is this something I could easily do my self or do I need to find an avionics repair shop? Thanks in advance. Dan Frank RV-8 finish kit Trophy Club, TX http:\\n808vr.homestead.com ________________________________________________________________________________
From: "Jones, Bryan D." <bryan.jones@lyondell-citgo.com>
Subject: RV-8/A WITH 0-235
Date: May 02, 2001
Based upon the performance I see in my O-320 powered -8, you'd probably be looking at something between 500-1000 fpm climb performance and maybe 150-160-mph top speeds. just an educated guess Bryan Jones -8 765BJ Pearland, Texas ________________________________________________________________________________
Subject: Re: Radio
Date: May 02, 2001
Microair has a comm radio that fits into a 2.25 inch panel hole. Electric Bob markets it on his website. You can read Jim Weir's review there. Rion ----- Original Message ----- From: "BOBE." <RVPilot4(at)webtv.net> Sent: Wednesday, May 02, 2001 9:12 AM Subject: RV-List: Radio > > I have a space problem in the panel of my RV4 .I need to replace my > Terra com.Was there an Aussy com.radio of a small dimension a few months > ago on the list? > > Bob Murphy Poplar Grove ILL. (C77) > > ________________________________________________________________________________
Date: May 02, 2001
Glad to hear that guys. I will be in contact in the future re: the spinner. Just what I wanted. Bob in Arkansas ________________________________________________________________________________
Subject: Re: Radio
Date: May 02, 2001
Bob, check out MicroAir at http://www.microair.com.au/home.asp Mike > > I have a space problem in the panel of my RV4 .I need to replace my > Terra com.Was there an Aussy com.radio of a small dimension a few months > ago on the list? > > Bob Murphy Poplar Grove ILL. (C77) > > > > > > > ________________________________________________________________________________
Date: May 02, 2001
Subject: Throttle Quadrant
Guys, I have a couple questions about the throttle quadrant setup on an 8/8A (sent an e-mail to Vans a few days ago and haven't heard back yet...) I purchased Vans 2 lever throttle quadrant. The quadrant bolts to the left side console F-8100A (RV-8 has a different part number here), and I am wondering if the inboard plate on the quadrant could just be removed and left out? The plans aren't real clear on this....seems like redundant weight to me, and the F-8100A appears more than strong enough to handle the loads here (albeit a bit thinner than the plate currently on the quadrant). Also, on the plans it shows the throttle cable anchor F-864E with 3 holes. Since I am not using a prop lever, I assume that I need only two holes and that these are the top 2? And if so, can I put the holes closer together or will the nuts anchoring the cable housing interfere with each other? Just curious because the plans show a 1" spacing between the top two holes, but my throttle and mixture levers are only 3/4 " apart. Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A fuselage, O-360-A4A, Sensenich 87" ________________________________________________________________________________
Date: May 02, 2001
Subject: RV-8
Wanted: Rv-8 tail group. Please respond offline. Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Date: May 02, 2001
Subject: RV-8A Quickbuild Kit for sale
We have an -8A quickbuild kit for sale for $23,000. For more information, please call 940-648-0841. George and Becki Orndorff ________________________________________________________________________________
Subject: thinner for silicone
Date: May 02, 2001
turpentine can be used as a thinner for silicone sealant. You will get some shrinkage in proportion to the amount of turpentine used when the mixture sets up. Ralph Bookout, Certified Slumlord RV 6 finishing- Visalia, Ca ________________________________________________________________________________
Subject: Re: Radio
Date: May 02, 2001
J.A. Air Center in Dupage IL, is selling the Microairs for $749.00. Tel 1-800-323-5966 There is a dealer selling them in Australia. At current $ conversion rates (conversion rate link is on the site's webpage), the cost in US dollars is $571. http://www.mcp.com.au/microair/ I have one in my Ercoupe and it works fine. It's the only radio I know of that is short enough to fit in standard coupe panel. I will probably put one in my 6A. Don Mack don(at)dmack.net www.dmack.net > > > > I have a space problem in the panel of my RV4 .I need to replace my > > Terra com.Was there an Aussy com.radio of a small dimension a few months > > ago on the list? > > > > Bob Murphy Poplar Grove ILL. (C77) ________________________________________________________________________________
Date: May 02, 2001
Bleeding the brakes is a mis-nomer. You force fluid in the bottom at the "bleed" valve using a oil pump can to fill the system until your master cylinder is at the correct level. This forces the air out at the top. Once you have an air free system you can add fluid at the master cylinder as long as you still have fluid in the master. Once the fluid level is down in the lines, you have to repeat the pump up routine. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh ----- Original Message ----- From: "Ken Stribling" <bbattery(at)bendcable.com> Sent: Tuesday, May 01, 2001 11:03 PM Subject: RV-List: bleed valve > > I am down to plumbing my brake system and am a mechanic by trade so why does > the bleed valve for the calipers show as being on the bottom when the > trapped air will be at the top > > Ken S. Down to little things and looking for hanger in bend> > > ________________________________________________________________________________
Subject: Re: Radio
Date: May 02, 2001
Yes, Its called a MicroAir 760. Its total weight is 14 oz. and fits in a 2 1/4 inch hole. The US distributer is EDMO Distributers out of spokane, WA. Their Number is 1-800-235-3300. They won't sell to you idrectly but will be able to give you who your closest shop is. I actually went down to the EDMO shop and held this little jewel in my hands. While I haven't tried it on an aircraft yet, it is very small, very light weight, and the switches are easy to move. There were two versions, an unlite and a lighted. I would recommend the lighted one. The price was also very nice. At that time it was $850-$950 depending on which version. The company is also making a tranponder although it was not out yet when I was there. Mike Robertson Former RV-8A owner >From: RVPilot4(at)webtv.net (BOBE.) >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Radio >Date: Wed, 2 May 2001 11:12:42 -0500 (CDT) > > >I have a space problem in the panel of my RV4 .I need to replace my >Terra com.Was there an Aussy com.radio of a small dimension a few months >ago on the list? > >Bob Murphy Poplar Grove ILL. (C77) > > ________________________________________________________________________________
Subject: Re: Radio
Date: May 02, 2001
----- Original Message ----- From: "BOBE." <RVPilot4(at)webtv.net> Sent: Wednesday, May 02, 2001 5:12 PM Subject: RV-List: Radio > > I have a space problem in the panel of my RV4 .I need to replace my > Terra com.Was there an Aussy com.radio of a small dimension a few months > ago on the list? > > Bob Murphy Poplar Grove ILL. (C77) > There's an advert in Sport Aviation for this radio. It fits in a standard size hole in your panel (2 3/4" I believe) Marcel de Ruiter Rv4/ G-RVMJ ________________________________________________________________________________
Subject: Re: Throttle Quadrant
Date: May 02, 2001
Mark, You might be able to take out inboard plate but you may have to re-rig the friction. Then again it may be easy. The two holes you would need are the two that are most inline with the quadrant levers so you get a straight line for the cables reducing the chances of binding. As far as hole distance I found that the only think I had to worry about was getting the wrench on the jam nuts to tighten them down. I ran into a bit of a problem with the inboard on and ended up using a hydraulic line wrench and a pair of needle nose pliers. Really...putting the two holes for the cables anywhere on the mounting plate will work fine as long as you can get the wrenches in there. Mike Robertson former RV-8A owner >From: Mark Navratil <czechsix(at)juno.com> >Reply-To: rv-list(at)matronics.com >To: rv-list(at)matronics.com >Subject: RV-List: Throttle Quadrant >Date: Wed, 2 May 2001 13:20:26 -0400 (EDT) > > >Guys, I have a couple questions about the throttle quadrant setup on an >8/8A >(sent an e-mail to Vans a few days ago and haven't heard back yet...) > >I purchased Vans 2 lever throttle quadrant. The quadrant bolts to the left >side console F-8100A (RV-8 has a different part number here), and I am >wondering if the inboard plate on the quadrant could just be removed and >left out? The plans aren't real clear on this....seems like redundant >weight to me, and the F-8100A appears more than strong enough to handle the >loads here (albeit a bit thinner than the plate currently on the quadrant). > >Also, on the plans it shows the throttle cable anchor F-864E with 3 holes. >Since I am not using a prop lever, I assume that I need only two holes and >that these are the top 2? And if so, can I put the holes closer together >or >will the nuts anchoring the cable housing interfere with each other? Just >curious because the plans show a 1" spacing between the top two holes, but >my throttle and mixture levers are only 3/4 " apart. > >Thanks, > >--Mark Navratil >Cedar Rapids, Iowa >RV-8A fuselage, O-360-A4A, Sensenich 87" > > ________________________________________________________________________________
Date: May 02, 2001
Subject: Re: Radio
At Sun N Fun, I talked to the manufacturer. They are making avail the same unit in a different format (rectangular). The digity read out was a little bigger, and thus, better for my tired old eyes. As I understand it, it has the same guts. Barry Pote RV9a Wings Mike Robertson wrote: > > > Yes, Its called a MicroAir 760. Its total weight is 14 oz. and fits in a 2 > 1/4 inch hole. The US distributer is EDMO Distributers out of spokane, WA. > Their Number is 1-800-235-3300. They won't sell to you idrectly but will be > able to give you who your closest shop is. I actually went down to the EDMO > shop and held this little jewel in my hands. While I haven't tried it on an > aircraft yet, it is very small, very light weight, and the switches are easy > to move. There were two versions, an unlite and a lighted. I would > recommend the lighted one. The price was also very nice. At that time it > was $850-$950 depending on which version. The company is also making a > tranponder although it was not out yet when I was there. > > Mike Robertson > Former RV-8A owner > > >From: RVPilot4(at)webtv.net (BOBE.) > >Reply-To: rv-list(at)matronics.com > >To: rv-list(at)matronics.com > >Subject: RV-List: Radio > >Date: Wed, 2 May 2001 11:12:42 -0500 (CDT) > > > > > >I have a space problem in the panel of my RV4 .I need to replace my > >Terra com.Was there an Aussy com.radio of a small dimension a few months > >ago on the list? > > > >Bob Murphy Poplar Grove ILL. (C77) > > > > > ________________________________________________________________________________
Date: May 02, 2001
Subject: Constant Speed Prop for Sale
I've decided I would like to go with an MT prop on my -8. Accordingly, I have a McCauley B2D34C214-B constant speed propeller for sale. This is similar to the prop Lewis Smith used on his RV-8 -- see http://members.aol.com/lousmith/page/rv.html. This propeller has been overhauled by East Coat Propeller Service and has 1122 TT and 0 SMOH. Asking $3900/offer. I will ship CONUS. Rick McBride rickrv6(at)aol.com ________________________________________________________________________________
Subject: Re: Radio
Date: May 03, 2001
The new radio will be avialable at Oshkosh we have been told.. It has been completely re designed and has a proper intercom. Look at there site for details and photos. Will be putting the new model in our 6. It is much better than older model but you might get old model heaps cheaper. Chris RV6 VH-MUM Reserved ----- Original Message ----- From: barry pote <barrypote(at)home.com> Sent: Thursday, May 03, 2001 7:34 AM Subject: Re: RV-List: Radio > > At Sun N Fun, I talked to the manufacturer. They are making avail the > same unit in a different format (rectangular). The digity read out was a > little bigger, and thus, better for my tired old eyes. As I understand > it, it has the same guts. > Barry Pote RV9a Wings > > Mike Robertson wrote: > > > > > > Yes, Its called a MicroAir 760. Its total weight is 14 oz. and fits in a 2 > > 1/4 inch hole. The US distributer is EDMO Distributers out of spokane, WA. > > Their Number is 1-800-235-3300. They won't sell to you idrectly but will be > > able to give you who your closest shop is. I actually went down to the EDMO > > shop and held this little jewel in my hands. While I haven't tried it on an > > aircraft yet, it is very small, very light weight, and the switches are easy > > to move. There were two versions, an unlite and a lighted. I would > > recommend the lighted one. The price was also very nice. At that time it > > was $850-$950 depending on which version. The company is also making a > > tranponder although it was not out yet when I was there. > > > > Mike Robertson > > Former RV-8A owner > > > > >From: RVPilot4(at)webtv.net (BOBE.) > > >Reply-To: rv-list(at)matronics.com > > >To: rv-list(at)matronics.com > > >Subject: RV-List: Radio > > >Date: Wed, 2 May 2001 11:12:42 -0500 (CDT) > > > > > > > > >I have a space problem in the panel of my RV4 .I need to replace my > > >Terra com.Was there an Aussy com.radio of a small dimension a few months > > >ago on the list? > > > > > >Bob Murphy Poplar Grove ILL. (C77) > > > > > > > > > > ________________________________________________________________________________
Date: May 02, 2001
I think putting the antenna in the gear leg fairings is a very bad idea. As a rule of thumb, any antenna (especially the tip) wants to be at least 1/4 wavelength away from the nearest conductive thing. (There are some exceptions here as with a bent whip antenna.) At 120MHz, 1/4 wavelength is about 2 feet. Having it a couple of inches away from a conductor that runs its whole length is going to grossly distort the antenna pattern. It may well not work at all. You can't just put an antenna anywhere that there's room for it. Mine is going to be on the belly just forward of the bagage area to get it as far away from the gear legs as possible. The transponder and GPS operate wavelengths of about 10 inches, so 1/4 wavelength is 2.5" so you have many more choices of where to put those. -- Tom Sargent. RV-6A - Wings done. "Benson, Bradley" wrote: > > Or how about down one of the gear leg fairings? I've seen a number of > folks make reference to doing this and this is what I plan to do with mine. > At this early point in the game, I think I'll be able to keep most of the > antennas inside, save for the GPS disk. > > Cheers, > Brad > RV6A Underway... > > > > Since we are on the subject, I am considering the foil windscreen comm > antennae like > > Van's uses on some of their prototypes. Anyone have good or bad comments > on this > > setup? My airplane is an RV-6A Slider and I have a Terra 720. > ________________________________________________________________________________
From: "Gordon or Marge Comfort" <gcomfo(at)tc3net.com>
Date: May 02, 2001
-----Original Message----- From: Ken Stribling <bbattery(at)bendcable.com> Subject: RV-List: bleed valve >I am down to plumbing my brake system and am a mechanic by trade so why does >the bleed valve for the calipers show as being on the bottom when the >trapped air will be at the top Ken: Near as I can figure out, the so called bleed valve is on the bottom because the brake line is on top. The calipers appear to be the same, whether used on the right or on the left. Whether you fill from the top or from the bottom, there is a good chance that you will not purge all the air from the fitting on the top, which is typically a 90 degree elbow. The only way I was able to eliminate the last bit of air was by cracking the fitting nut and in effect, bleeding it there. Gordon Comfort N363GC ________________________________________________________________________________
Date: May 02, 2001
Subject: Re: RV Wanted
> > >Anyone know of an RV-6 for sale that is well built and well maintained? >Local guy has the checkbook out but just can't find a clean one. > >Thanks > >Eric > Try barnstormers2000.com. I have my 6 lisred and there are others also. Ed H. ________________________________________________________________________________
Date: May 02, 2001
Subject: Re: RV8-List: Re: RV8-List Digest: 1 Msgs - 02/23/01
Gentlemen, and ladies, I looking for 3/8 prop bolts. I think I need AN6 -82. Suggestions? Using Aymar Demuth prop and Van's 2 1/4 extension and crush plate. Thanks, Dan 81243 Finishing kit N417SN reserved. ________________________________________________________________________________
Subject: Re: S-Cowl Browning 6A
Date: May 02, 2001
I was reading some archive letters on the topic of exhaust heat overheating the cowl. Several people talked about ways to combat it, here are two. > > 3) The solution was to RTV on a pair (one each side) of 0.020 aluminum pads > > onto the cowl. Larry said to use high temp RTV and put a bead around the > > perimeter and a few dabs on the inside to space it off the cowl. The idea > > is to make a dead air space between aluminum and cowl like a Thermopane > > window. Larry also advised me to use aluminum instead of stainless steel > > because the aluminum has better thermal properties in this application. > > > > Just a thought: There are a couple of products in the ACS catalog which are > appropriate for this application: Fiberfrax and Koolmat. My understanding > is that many people have adhesion problems with Fibrefax and the recommended > glue. The Koolmat glues on with RTV and I've got a couple of linear feet of > the stuff just waiting to be installed... So is this necessary? What are you flying guys finding? Norman Hunger RV6A Delta BC ________________________________________________________________________________
Subject: Re: Radio
Date: May 02, 2001
Hi Chris and others, I am beginning to look into and make decisions re the panel. The Microair is on the list of items that as yet have not been eliminated. the fact that they might have a transponder in the offing has kept them on the list. If they now have gone over to the standard aviation radio equipment layout with the new radio and transponder I will advance them up the list. Am I right in interpreting from what I've seen on the list today that their new product line will fit the standard radio stack? Flying is fun, Take off eh! Jim in Kelowna, fiddling with LSE ignition system fitting ----- Original Message ----- From: Chris & Susie <rv6(at)ssc.net.au> Sent: Wednesday, May 02, 2001 3:34 PM Subject: Re: RV-List: Radio > > The new radio will be avialable at Oshkosh we have been told.. It has been > completely re designed and has a proper intercom. Look at there site for > details and photos. Will be putting the new model in our 6. It is much > better than older model but you might get old model heaps cheaper. > > Chris RV6 > VH-MUM Reserved > > > ----- Original Message ----- > From: barry pote <barrypote(at)home.com> > To: > Sent: Thursday, May 03, 2001 7:34 AM > Subject: Re: RV-List: Radio > > > > > > At Sun N Fun, I talked to the manufacturer. They are making avail the > > same unit in a different format (rectangular). The digity read out was a > > little bigger, and thus, better for my tired old eyes. As I understand > > it, it has the same guts. > > Barry Pote RV9a Wings > > > > Mike Robertson wrote: > > > > > > > > > Yes, Its called a MicroAir 760. Its total weight is 14 oz. and fits in > a 2 > > > 1/4 inch hole. The US distributer is EDMO Distributers out of spokane, > WA. > > > Their Number is 1-800-235-3300. They won't sell to you idrectly but > will be > > > able to give you who your closest shop is. I actually went down to the > EDMO > > > shop and held this little jewel in my hands. While I haven't tried it > on an > > > aircraft yet, it is very small, very light weight, and the switches are > easy > > > to move. There were two versions, an unlite and a lighted. I would > > > recommend the lighted one. The price was also very nice. At that time > it > > > was $850-$950 depending on which version. The company is also making a > > > tranponder although it was not out yet when I was there. > > > > > > Mike Robertson > > > Former RV-8A owner > > > > > > >From: RVPilot4(at)webtv.net (BOBE.) > > > >Reply-To: rv-list(at)matronics.com > > > >To: rv-list(at)matronics.com > > > >Subject: RV-List: Radio > > > >Date: Wed, 2 May 2001 11:12:42 -0500 (CDT) > > > > > > > > > > > >I have a space problem in the panel of my RV4 .I need to replace my > > > >Terra com.Was there an Aussy com.radio of a small dimension a few > months > > > >ago on the list? > > > > > > > >Bob Murphy Poplar Grove ILL. (C77) > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: May 03, 2001
Subject: Re: Tail Fairing
Glenn, I hope the fairing you refer to was one of mine. I'm pretty good with fiberglass but the paperwork is a whole other story. Just got to get ORGANIZED. It is designed to have three screws in front, one in front of each stabalizer and four on each side in back. This would be what I would consider minimum. If there is any place where there are gaps between the fairing and the plane it might be a good idea to put one there. I think I would put six small, #6 screws , in the lower fairings, more or less evenly spaced in pairs. More questions just ask. Sorry for the delay answering. With a 40 hour job, the fairings, four flight students,and taking Sonya's Cessna 150 apart so we can bring it home to paint it, I didn't get to the e-mail when I should. Your order[ come to think of it] probably wound up in the "new stuff notification" book. Bob Web site www.fairings-etc.com another e-mail bob@fairings-etc.com ________________________________________________________________________________
Date: May 03, 2001
Subject: Re: Tail Fairing screws, BUT
I think my fairing would stay on with two screws in back, but, think what a hell-of-a speed brake it would make if the front did get loose. Please, everyone that has mine, put three in front. I like the idea of four on each side in back. Bob Fairings-Etc. ________________________________________________________________________________
Date: May 02, 2001
Subject: Size of FI servo vs. carb
I'm considering putting the PowerLink FADEC system on my RV-8A. I would strip the fuel injection system and mags off a new IO-360-A1B6 and install the FADEC system in their place. The FADEC throttle bottle is dimensionally the same as the Marvel carb that comes on the O-360-A1A - they anticipate a big upgrade market in this area so this makes sense. So here's the question: how do the dimensions of the IO-360-A1B6 throttle body compare to the Marvel carb on the O-360-A1A? My worry is that the FADEC throttle body, since it's sized to match the carb, would be a lot bigger than that on the stock IO-360-A1B6. This engine has a forward mounted intake, and extending it forward would make it difficult/impossible to fit in the stock cowling, which is pretty tight to start out with. Basically I'm too lazy to get involved in a big cowl project. I know this will earn me the scorn of the rotary guys, but this is my first plane and I'd like to get it flying. Also, if anyone has any idea what the mags and FI system from the IO-360-A1B6 would be worth if I sold them I'm curious... Also if anyone's interested there's a bunch of new info up on their site at www.fadec.com . The price of the system has gone up a bunch since I put my deposit down- I think it's around $8K at this point once you add it all up. Ouch! Technological progress may have to wait, at least for me... Matthew -8A canoe - er - I mean fuselage! ________________________________________________________________________________
Date: May 02, 2001
Subject: O-235 for sale
I have a friend with a LongEze that was concerned that my 6 was going to be faster than his airplane so he upgraded to an O-320 and now has his 235 for sale. The prop probably won't do you RV-9 guys any good tho. Dave Following is what he gave me: O-235 for sale, 1500 TTSN Originally an L2C, modified with custom high compression pistons, 125 hp. B&C starter, oil cooler, carburetor, motor driven and electric fuel pump, etc. complete less mags and harness. $5500 Also available, 6 inch prop extension and propeller, removed from LongEz call Ron at (310) 532-3596 ________________________________________________________________________________
Date: May 03, 2001
Subject: Re: Radio
In a message dated 5/2/2001 10:46:34 PM Central Daylight Time, jjewell(at)okanagan.net writes: > I am beginning to look into and make decisions re the panel. The Microair is > on the list of items that as yet have not been eliminated. the fact that > they might have a transponder in the offing has kept them on the list. If > they now have gone over to the standard aviation radio equipment layout with > the new radio and transponder I will advance them up the list. > Am I right in interpreting from what I've seen on the list today that their > new product line will fit the standard radio stack? > > Flying is fun, Take off eh! > > Jim in Kelowna, fiddling with LSE ignition system fitting there is a company in australia selling the radio for 550 us shipped. Australian dollar is really low so there are great buy right now ________________________________________________________________________________
Date: May 02, 2001
Subject: Re: Aerox Oxygen System
--- Norman Hunger wrote: > > Does any one have one of these? Comments? > > http://www.aerox.com/ > > I'm a couple of years away from flying but I at least want to get the > mounting bracket installed. Any comments on putting the bracket on > the right > side of the RV6 luggage area? > > Thank-you, > Norman Hunger > RV6A Delta BC
April 26, 2001 - May 02, 2001
RV-Archive.digest.vol-kq
